Europa-Archive.digest.vol-ki
October 18, 2012 - November 27, 2012
      > Hi William,
      > I would recommend against using metallic paints.  I had the same thought as
      > you, until I checked out the relative temperature of car surfaces (put my
      > hand on the hood) at a parking lot on a sunny day:
      > White is definitely the only "cold" colour.  Silver metallic is up there
      > among the other "warm" colours like green, blue and red.  May sound
      > strange,
      > but it is caused by irregular particles in the paint reflecting radiation
      > heat not only outwards (remember:  angle out equals angle in).
      > Regards,
      > Svein
      > LN-SKJ
Subject: silver paint
Date: Oct 18, 2012
Ivor, That is not strictly correct as Peter has only painted the bottom half silver, the top half of the fuselage and the wings/tailplanes are white. My aircraft is a bit similar in that several years ago I painted the underside of the fuselage dark blue and this has not shown itself a problem even on trips down in to Spain, Italy and Morocco. Dave Watts G-BXDY Classic Monowheel 1960 hours From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of PHILLIPS I Sent: 18 October 2012 08:15 Subject: Re: Europa-List: silver paint Hi william What Svein has said is Europa's position on paint, But Peter Kember has painted his tri gear silver and it seems to have no problem. But a few years back an American europa painted blue on the bottom in Arizona, suffered a sagging engine after being heat soaked for a day, In August this year Bob Harrison and myself had ground temperatures of 40C in the Czech republic so Europe can still get very warm, regards Ivor On 18 October 2012 07:02, Sidsel & Svein Johnsen wrote: Hi William, I would recommend against using metallic paints. I had the same thought as you, until I checked out the relative temperature of car surfaces (put my hand on the hood) at a parking lot on a sunny day: White is definitely the only "cold" colour. Silver metallic is up there among the other "warm" colours like green, blue and red. May sound strange, but it is caused by irregular particles in the paint reflecting radiation heat not only outwards (remember: angle out equals angle in). Regards, Svein LN-SKJ ========== target="_blank">http://www.matronics.com/Navigator?Europa-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: electronic engine monitoring and flight instruments
Date: Oct 18, 2012
William We have about 50 panel pictures on the Club web site http://www.theeuropaclub.org/for-builders/panel-instruments/ Ian Rickard G-IANI XS Trigear, 300hours Europa Club Mods Specialist e-mail g-iani(at)ntlworld.com ________________________________________________________________________________
From: Gary Leinberger <Gary.Leinberger(at)millersville.edu>
Date: Oct 18, 2012
Subject: Europa Instruments
In reference to: From: "William Bliss" <william(at)wbliss.co.uk> Sent: Wednesday, October 17, 2012 6:33:32 PM Subject: Europa-List: electronic engine monitoring and flight instruments I am presently flying with the attached panel. It is full IFR, with a Garmi n 430W, a Mode S Garmin 330 GTX, a Tru-Trak 2-axis autopilot (with a back-u p attitude indicator), a Grand Rapids HX EFIS and EIS. I used a EXP buss fo r circuit breakers (that is the EXP indicator above the brakes and throttle ). I also have back-up airspeed (a Winter since I plan to do soaring and h ad a bit of a space problem), vertical speed and altimeter. I am using a Ai rmaster constant speed prop. Yes, it is a bit heavy (panel weighs 42 pounds - and it cost a bit more than 42 pounds - yuk-yuk - sorry, American humor ) but it is what I wanted. Europa is a great IFR platform - the 2-axis auto pilot is really overkill - the plane actually flies better hands off then w ith the autopilot (still wanders a bit but think I just need to do some fin e tuning) - haven't tried it in turbulence yet but have done an hour and ha lf in the soup. I also have a heated pitot tube which I have yet to test - but not planning on going into known icing conditions - but we get that her e (Northeast U.S.). We also have a great deal of traffic and with the new N ext Gen system I wanted to be able to see more of it on the screen - amazin g how much traffic we have and miss. I also use my IPad with Foreflight and a Stratus for weather. The IPad is mounted over the tray on the right wit h a RAM mount. I have a large 3 hole fan with tubing to cool the 430W and the 330GTX (tube s hook into the back of the units) and the other one is split between the E XP and the back of the HX. I also have two small fans on the top of the pan el set up with a thermostat and a timer. They run off the secondary battery (set up as a soaring buss) and they run for up to 45 minutes after shut d own, dependent on instrument temps. I have had the HX reboot twice for, I t hink, overheating but that was a hot day in Florida (90's F) with sun on th e panel. The photo should allow you to zoom in to see details on lettering on switch es and such. The Grant Rapids EFIS and EIS both work very well and provides far more inf o than is necessary. I am running a 912S and everything fits up neatly to t he sensors. It did take about 40 hours to get everything to talk to each ot her and to arrange the screens (will probably do more fiddling but of cours e that is why we call them experimental). Grand Rapids does make a smaller EFIS that I haven't heard anything bad about. I wanted all this stuff because, first, they are neat toys, and second, I f ly in a high traffic area with many days of fogs and low ceilings (my rule is I won't take off until I have at least 1500 AGL) where I use IFR a lot just to get out or back in (why are airports magnets for low ceilings?). Any other questions please let me know. Gary Leinberger A-237 62 hours Lancaster, Pa. gleinberger(at)millersville.edu ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 18, 2012
Hi Alan, Can't believe LaaLaaLand won't let you put Inspection Panels in as per the Manual ? If you have no panels back there at all, installing some as directed in the relevant Chapter won't be a ''Mod'', just bringing you airframe in complia nce with what has been approved ? The small spy hole lets you see in there, the larger access hole is in the correct position for you to get your arm in, folded round the corner and ab le to work on the torque tube / trim items. I would be tempted to do it, get it signed off by an Inspector, raise a Wor ksheet and make an entry in the aircraft's Log Book, at the same time as do ing the pin work. On next years Permit Renewal Form, in the ''any repairs / work carried out since the last Permit'' question, list the Pin repair work and the addition of inspection panels as per Chapter 23, P 3,4,5 ? The torque tube CAN be got out by working down the ''tunnel''. As you have noted, support the rear fuselage with a padded trestle. Fill th e baggage area with foam / cushions to the height of the seatback / D panel hole so you can ''surf'' in and out. If you have the Classic fuel filler, take the hose off and plug the tank inlet. Get cushions and carpet offcuts in the rear hull so you don't point load th e skin with elbows etc, 3 or 4 layers of carpet / underlay should do. Unbol t the pitch pushrod containment tower and remove, should be 8 bolts / nuts holding it to the hull / roof, and 2 on the wooden cross piece [ 3/8'' & 1/ 4'' spanners].Weight the tailplanes aft down and tie the stick forward to p ark the mass balance weight up in the roof. Surf aft and unbolt the mass ba lance arm, 2 bolts / nuts [3/8''&1/4''] and pushrod, 1 bolt / nut [1/2'' &3 /8'' ] from the horn. Bung the arm out and lay the pushrod in the hull. Pad under / over the pushrod so any body weight on it doesn't hurt it.Also pro tect the two glass lay up brackets in the hull for the tower, fill between with stiff foam so they don't get broken. Pad your self up from the hull with cushions so you adopt the ''Superman'' position, with your arm outstretched in front of you, you will have to hold yourself up with the palm of your hand while you are straightening the spl it pin and pulling it out, pointed nose pliers and gently used cutters are needed to pull / curl the split pins out. Start with the outer pins first. Pull the drive pin out with Mole Grips. You can now rotate the entire torque tube to allow better access to the rem aining 2 split pins. Mark everything as to its position, I put a red blob inside the bottom of t he port end on the main tube [ paint or nail varnish ] this won't get knock ed off at the Machine Shop. Mark all else with a indellable marker pen, ie Port / Stb TP12, TP 10 collars, with both the writing as to where, and a li ne though the lot so it can go together on the bench back in the same way. The red nail varnish on the Port TP12 in a place that won't get knocked off is a good plan. Cool lighting in there is needed, so not a 100 watt lead lamp ! and a fan b lowing in helps. Could take 3 to 4 hours of sweating and swearing to get it out, bit longer to put it back. Tools needed. Imperial spanners [ wrenches for those in the US] & Imperial sockets [ 1/4'' , 3/8'' , 1/2''] needle nose pliers, Mole [Vise] grips, si de cutters, copper / hide hammer, a selection of punches, magnetic bowl [ t o put the bolts / nuts in when you are in there, to stop them escaping ] an d a swear box. I have the cranked arm / long pushrod ratchet spanners which help to reach the bolt heads. To get a spanner on the nuts [1/4'' & 3/8''] I have B&Q plastic13mm double pipe clips [ as used to mount central heatin g pipes] to bolt the other end of the spanners to, which spring on to the t wo 1/2'' tube arms [ you can't get both arms up there at the same time ]. Entrust the assembly to a good Machine Shop to drill / ream to suit the O/S pins. Fitting is the reverse of dismantling, only more difficult ! Hard bit is ge tting the new pins aimed to go in and come out the other side ! I am workin g on a clamp / aiming / thumbscrew / press gizzmo at the moment, watch this space. -----Original Message----- From: Alan Carter <alancarteresq(at)onetel.net> Sent: Wed, 17 Oct 2012 21:03 Subject: Europa-List: Re: Mod 73 Thanks Neville. honed the LAA today ref. New Inspection Hole. asically No, s i,m in the UK its new dowels and clamps approved by LAA. o i have to find a small person to climb down inside the tunnel after havin g emoved the mass balance weight. assume this is the easiest way to get at the pins, as you can see them. bviously with the tail propped,and all the panels off for light and air. f i go about it this way. ow long to get it out., and do you see any other problem, egards lan ead this topic online here: http://forums.matronics.com/viewtopic.php?p=385573#385573 -= - The Europa-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Europa-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 18, 2012
Hello Neville. Many thanks for the detailed instructions, this really sound like one hell of a of job to do. Have you ever seen a Whale Surf, i think i will send boy Robin down the tunnel while i stay in the bat-mobile. I will print your instruction off, and check i have all the tools as listed. As for going down the tunnel, I am 14 stone so plan finding a small person to go down the tunnel for me, this will cost me quite a few Beers!! I have not looked down the tunnel yet, but was planning maybe two lengths of wood mounted on layers of carpet laid along each side of the tunnel with plywood screwed to them, so as to make a platform to lay on above any controls lines, and to spread the load, then get boy Robin to Surf down there. Will remove back panel and have a look to see if this is possible. But if you think this is not a good idea, please post. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385646#385646 ________________________________________________________________________________
From: "Richard Collings" <rcollings(at)talktalk.net>
Subject: Re: Mod 73
Date: Oct 19, 2012
Hi Bud I have been following with interest this problem because whilst I was building my Europa I became very unhappy with the design which required a degree of precision machining and fitting that was not available to the average builder - me. I overcame the problem with mod 11969 which replaced the TP14 pins with close tolerance bolts which when tightened up on to a shaped nut plate mounted inside the torque tube clamped everything together so removing any chance of fretting taking place. There is little or no tube distortion and as I had to rig test my design in order to gain LAA approval, found that with all the bolts torque up to 200 lbs inches the assembly could transmit 90 lbs ft before slipping. No glue, no hammering. I would appreciate your opinion on this mod. Regards Richard Collings ----- Original Message ----- From: Bud Yerly To: europa-list(at)matronics.com Sent: Sunday, October 14, 2012 11:40 PM Subject: Re: Europa-List: Re: Mod 73 Pete and Bob Had the same kind of idea. Putting a slotted tube bored for the pins and use flush riveted nutplates in the tube with bolts to clamp the tubes together. Install by sliding in the nutplated tube and aligning the holes. However, that still will distort the tubes when the bolts are turned down making removal almost impossible as in tapered pins. My other idea was an expanding bolt. A 1/4 inch bolt with a steel insert in the center and two bronze bushings at the ends so that as the bolt is tightened, the bronze expands like a rivet and fills the small gap, making it tight. My A&P said, why not just rivet it in place. Just change the stab to allow it to rotate a full 90 degrees to allow riveting. However, what we have works, is maintainable and can be assembled by amateurs using drift pins and bolts (which allow a loose fit) during assembly and allows for a solid install provided the holes and pins are correctly sized for zero clearance. Good ideas though, Bud ----- Original Message ----- From: Pete To: europa-list(at)matronics.com Sent: Sunday, October 14, 2012 5:51 PM Subject: Re: Europa-List: Re: Mod 73 Thinking out loud here, what about very accurately machining substantive internal bolt bushings (made of a material to not cause galvanic corrosion), tap them all the way down the tube to their proper location, then bolt tight the two tubes without fear of distortion? Just throwing it out there, Cheers, Pete On Oct 14, 2012, at 4:47 PM, "Bob Harrison" wrote: You could drill and thread the heads of the parallel pins and use a bolt to Jack the out if needed. Regards Bob Harrison G-PTAG From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 14 October 2012 18:14 To: europa-list(at)matronics.com Subject: Re: Europa-List: Re: Mod 73 No, they would distort the torque tube which must be perfectly circular Graham ------------------------------------------------------------------------- - From: Pete <peterz(at)zutrasoft.com> To: "europa-list(at)matronics.com" Sent: Sunday, 14 October 2012, 14:04 Subject: Re: Europa-List: Re: Mod 73 I fully understand the requirement for an interference pin fit to avoid the hammering out of the holes over time. That said, could "taper pins" be used? cheers, Pete http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronics.com http://www.matronics.com/contribution ========= tp://www.matronics.com/Navigator?Europa-List ========= cs.com ========= matronics.com/contribution ========= href="http://www.matronics.com/Navigator?Europa-List">http://www.matron href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 19, 2012
All Details of Richard Collings mod (11969) is available on the Club web site http://www.theeuropaclub.org/wp-content/uploads/2011/12/11969-TTpins.pdf For UK owners I would expect the LAA to treat it as a "repeat Mod" if you want to use it Ian Rickard G-IANI XS Trigear, 300hours Europa Club Mods Specialist e-mail g-iani(at)ntlworld.com ________________________________________________________________________________
Subject: LG08 bushes
Date: Oct 20, 2012
Hello all, Our Mono has now done 477 hrs and 794 landings. To my dismay, I have just discovered that the bushes on the LG08 forks are quite badly worn. Before ordering new bushes, I am wondering if anybody knows of a more durable material from which these bushes could be manufactured. Regards Kingsley in Oz ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 19, 2012
Hi. Richard. That looks a good fix to me, pulling up on both side of the tube, i can,t see that moving anywhere. Next project is to get rid of the pins on the TB12 drive plate, Make a drive plate with all the external edges angled at 90 degrees ,ie a male drive plate, and a mirrored female drive plate fitted to the stabilator, all of this female drive plate slides up into the male drive plate, all the surfaces making a tight contacting join.,and full transmission load spread over the entire surface, No little pins and no lugs, so no chance of miss alignment damaging or pin wear or breaking . All of this would last the life of the aircraft Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385675#385675 ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 19, 2012
A job done properly http://www.youtube.com/watch?v=bNzDg_6uLZQ&feature=youtube_gdata_player Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385677#385677 ________________________________________________________________________________
Date: Oct 20, 2012
Kingsley, My experience is that 400 to 500 hours is about normal for the LG08 bushes and I have replaced mine 3 times and have the materials ready for the next couple of times. It is not a nice job replacing the bushes, but as with most things on the Europa they are mostly fiddly and play on the mind, but are actually doable in a relatively short time. Dave Watts G-BXDY Classic Monowheel 1960 hrs. -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Kingsley Hurst Sent: 19 October 2012 23:25 Subject: Europa-List: LG08 bushes Hello all, Our Mono has now done 477 hrs and 794 landings. To my dismay, I have just discovered that the bushes on the LG08 forks are quite badly worn. Before ordering new bushes, I am wondering if anybody knows of a more durable material from which these bushes could be manufactured. Regards Kingsley in Oz ________________________________________________________________________________
From: "William Daniell" <wdaniell.longport(at)gmail.com>
Subject: Re: Mod 73 - slightly different
Date: Oct 20, 2012
Stephan Thanks for the idea. I shall do something very similar I think except mine will be easier because I still have the top off. Less swearing. Will From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of SCASSEL Sent: 17 October 2012 03:15 Subject: Europa-List: Re: Mod 73 - slightly different Hi Will, One washer on each bolt. I guess there many different approaches and mine was probably not the best but it made my day. The washer was mounted on a wooden stick (about 1/2=9D x 1/2") A slot was made that hold the washer on place. Tight. You have to press the washer into the slot. It was quite easy to put the washer on the bolt. Same stick (but the opposite side) was used in order to create a long handle to the spanner. A mark was made on the stick so I know exactly how far in the tube I was. The other hand on the bolt. The first tree were quite easy. On the fourth and last nut the washer went off and I had to rig the washer again. ( A small swearing was fired) Best regards Stephan LN-STE Mono ________________________________________________________________________________
Date: Oct 20, 2012
Subject: Re: LG08 bushes
From: Carl Pattinson <carl(at)flyers.freeserve.co.uk>
The bushes are "oilite" which are impregnated with a lubricating oil (not sure how they get the oil in) - if you need to heat the lg arms to sweat the old ones out they will ooze oil from the inserts. I doubt any other material would wear any less as the undercarriage takes a lot of punishment. Just make sure that you replace the top rubber block spacer plate facing exactly the same way as you removed it - the block assembly can be removed without dismantling but can be rotated through 180 degrees. If you do this the undercarriage wont retract fully and you will be faced with having to disassemble everything. You only make the mistake once - we did ! Ideally you can suspend the fuselage using an engine hoist - rope through the engine mounting frame. Its not a nice job but as David says can be done in a couple of hours. Good luck, Carl Pattinson G-LABS. Sent from my ASUS Pad Kingsley Hurst wrote: > >Hello all, > >Our Mono has now done 477 hrs and 794 landings. > >To my dismay, I have just discovered that the bushes on the LG08 forks are quite badly worn. > >Before ordering new bushes, I am wondering if anybody knows of a more durable material from which these bushes could be manufactured. > >Regards > >Kingsley in Oz > > ________________________________________________________________________________
Date: Oct 20, 2012
 Photo E-mail View slideshow | Download images Stephan, Richard did a great job on his mod. I have attached a drawing of our solution which differed only in that the nutplates were riveted to a tube horizontally and 1/4 inch bolts used. (see drawing) It was never submitted as I had a local machine shop that could put out the work for about $300 and make new holes and pins, or if the 3/8 pins weren't installed yet, we could machine the holes to a zero tolerance fit. A drop of Loctite or two and the whole thing stayed solid for so far, 3 years. So we dropped pursuing the idea. Richard's mod 11969 is a perfectly sound solution that should work. I just felt that Redux on the nutplate was a bit tedious when a rivet could be put into a steel tube quickly. I used a 1 1/4 inch tube (Sloppy fit for ease of moving into position into an existing stab, slotted it on the bandsaw, slid it in and marked the holes with a centering punch (inserted into a 1/4 inch tube to center the punch on the hole and gave it a try. A $10 experiment, that works, but it too is tedious. When Roger Bull came out with the Loctite solution and got it all approved, I sure liked not having to go through approvals when what he did works. You know us Yanks, instant gratification. Regards, Bud Yerly ----- Original Message ----- From: Stephan Cassel<mailto:stephan(at)scassel.se> To: europa-list(at)matronics.com Sent: Tuesday, October 16, 2012 1:15 PM Subject: Re: Europa-List: Re: Mod 73 - slightly different Hi Europa pilots/builders I did the mod 73 per instructions five years ago and at first it looked good. After a short while the play was back. My assembly was perhaps a bit tighter then normal so the Loctite did not penetrate enough. In order to get rid of the play I made =93special=94 washer, situated inside the torque tube. Now it was possible to tight the tubes hard together. The result was a zero play system. Complete solid for 5 year (340 hours) . I know another builder that has solved the play in the same fashion with complete success. Here is draft drawing that shows the parts involved. In my case it was only necessary to change the outer bolts: http://aero2012.scassel.se/Images/tailplanemod.PNG l.se/Images/tailplanemod.PNG> It is necessary to create a spanner with looong shank. I used a wooden stick and strapped the spanner to it. After 30-40 minutes and some swearing (not much) it was tight, very tight I may add. Additionally I made a thin black line, 4-5 cm long, on fuselage when TP trailing edge was fully down, parallel with TP skin. This reference line makes it very easy to catch very small play over time. So far the TP is still on the reference line. I check this on every pre flight. Best regards Stephan LN-STE Mono in Norway. http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> These photos will be available on SkyDrive for 30 days. To learn more about SkyDrive, click here<http://g.msn.com/1cl91enus/PMFooter>. To share high quality pictures with your friends and family using MSN Photo E-mail, join MSN<http://g.msn.com/0PHenus1/29>. ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 20, 2012
Hi Richard ,Peter I had thought of solid cores , here you could see the nuts , as the nut would be on the outside of the tube, you could check them or wire lock them, But the 1/4 moons as in your diagram allow any water to escape from within the tube. Further more you could increase and have the say two 1/3rd moons, with two drilled recesses in the back and say two 1/2diameter springs slipped in-between the two part moons . To fit just squeeze the two 1/3rd shaped moons together and pop into the end of the tube , now its holds itself in place . Now you can attach a piece of wood slide it down the tube twist it about and line the holes up then pop the bolts in and tighten up. As for the 2 little springs leave them there, or take another thin piece of wood push down the tube and push them out, as they have done there job, and use them again for the next set of 1/3rd shaped moons you are going to slid down the tube to do the next pin hole. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385704#385704 ________________________________________________________________________________
Subject: Re: Stabalator Flutter
Date: Oct 21, 2012
Alan, I noted no answer to your question on what is flutter. Attached are some video sites for you to look at. In engineering, vibration and aeroelastic concerns on fatique and flutter are very serious studies. Please review: <http://www.aircraftdesigns.com/aircraft-flutter-analysis.html>http://www .aircraftdesigns.com/aircraft-flutter-analysis.html<http://www.aircraftde signs.com/aircraft-flutter-analysis.html> http://www.youtube.com/watch?v=YIHam_isyI8&feature=related I became interested in the subject when government cuts forced us to go to a cheaper hydraulic line in the F4. We were seeing numerous problems with hydraulic failures using the aluminum lines attached. Without hydraulic pressure, the flight controls did not lock in position in certain failures (breaking of the control pack) and controls would begin to buzz at high speed. Luckily the aircraft wing was brutally strong, we had redundant hydraulic controls and with only one hydraulic failure we pilots normally slowed down, declared an emergency and returned to base without incident. One crew lost all hydraulic control on one wing and the back seater could see the aileron flopping about. They slowed to 240 knots and the flutter stopped but hinge and trailing edge damage was evident in only a few seconds of flutter. Later I was involved in a local Twin Commanche incident where rivets were popped all over the stab and I was asked to look at it. See the video below. The type of flutter is evident on stabilators as well as conventional horizontal control surfaces which are not balanced. http://www.youtube.com/watch?v=iTFZNrTYp3k ?v=iTFZNrTYp3k> ----- Original Message ----- From: Alan Carter<mailto:alancarteresq(at)onetel.net> To: europa-list(at)matronics.com Sent: Monday, October 15, 2012 4:21 PM Subject: Europa-List: Stabalator Flutter > Hello ALL. This question is nothing to do with how to fix the Toque Tube and stop flutter. Ok i know stabalators are more efficient than the elevator, and they can,t Rime ice up like an elevator and i have flow many aircraft with stabalators and i don,t like them. Question is what is Flutter only?? I keep hearing the word Stabalator Flutter, I have the obvious idea as to what happens but would like to know more, maybe someone has experienced it. Do the Stabalators flutter independently, or both up and down together, How fast is this fluttering, How is the on-set noticed in the cockpit, Can you feel it through the joy stick,( of course you can, but a tell tell indication maybe in some flight attitude or configuration well before an event). Is it controllable, What would be the position held by the stabalators if you had no control. ete,ete,ete, agian not a test just something we can all chew over. If anyone has experienced flutter please tell us, Alan [/u] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385392#385392 .matronics.com/viewtopic.php?p=385392#385392> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Oct 21, 2012
Wow Bud, that,s pretty scary stuff, have a lot of hours on Twin Coms. glad i knew nothing about flutter then, what happened to it in the video. Well i got the first bit right, slow down, but have not that brutal tail-plane you mention, only have a foam one!, and yes i do have a hang up on tail planes maybe its because i can,t see it. There have been some excellent ideas posted on MOD 73 . how to elimination play and wear in the Toque tube, and this question is just an extension of that topic, so hoping for some airman-ship replies also. Regards Alan Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=385727#385727 ________________________________________________________________________________
Subject: Paint edge around the windows
From: "flying farmer" <rpwheelwright(at)yahoo.co.uk>
Date: Oct 21, 2012
Fellow Europas Does anyone have any suggestions for finishing the Paint edge around the windows? As the paint does not bond well to the Plexi Glass even after scuffing the surface. Richard Wheelwright G-IRPW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385743#385743 ________________________________________________________________________________
Subject: Aerial testing and fuel smell
Date: Oct 21, 2012
On a flight to the Isle of Bute today I found that the radio was intermittently failing to receive and transmit. Not a power problem. I have heard that Europa aerials can be difficult (earth?). How is it best to test and rectify? Good news is that the fuel gauge sender unit leak has been stopped by fitting a 4mm thick nitrile cork gasket ontop of a thin layer of fuel tank sealant William Bliss ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: upholstery
Date: Oct 21, 2012
Dear all again The upholtsery in G-WUFF is coming adrift - and will be more so after I have made a few alterations. Can anyone recommend a UK based upholsterer? North would be better. Thanks William Bliss ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: 914 surging/loss of power
Date: Oct 21, 2012
We are stuck in Lamar CO with 914 problems. Have spent most of the day talking to Bud for ideas. Flew about 4 hours yesterday, stopped for fuel and lunch. Takeoff was normal but when leveled off, noted fuel flow was only 3.5 gph, not the expected 5.5. Increasing throttle gave more MP but same fuel flow. Engine felt rough or different than normal. Landed and inspected under cowl - no problem noted. We had just gotten fuel so thought maybe that caused it. Tried flight this morning when it was cooler, had to make emergency landing because power dropped soon after takeoff. No vibration, just wouldn't climb. Found that our fuel tank vent was plugged, cleared it, ran ground tests & Jim did 20 minute solo test flight with no problem. Loaded plane & departed again, engine power dropped just after gear retract, made another emergency landing. (Obvious answer is don't let Heather in the plane [Wink] ) At this point we're thinking pull carbs for rebuild. Any other ideas? Thanks, Jim & Heather N241BW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385747#385747 ________________________________________________________________________________
Subject: Re: 914 surging/loss of power
Date: Oct 21, 2012
Jim & Heather, I don't know if this has been suggested by anyone else, but check the carb bowl pressurization lines from the air box to the carbs. If there's a leak somewhere along there, it could prevent your carbs from being able to deliver sufficient fuel under boost. In the attached PDF file these lines are RED, GREY/WHITE STRIPE and YELLOW. Check VERY carefully! I had two hidden that took three or four searches to locate. Look carefully at any connection from line to fitting. If that all checks out OK, then you might also check the carb bowl pressure shuttle (92 in the PDF) which transfers from lower pressure input to higher pressure input when you go to high boost. This can be checked by making the purple connection. Disconnect the YELLOW line from the shuttle and the RED line from the airbox. Connect the YELLOW line to the airbox where the RED line was removed. This information was provided by the folks up at Rotax Owner dot Com and they said that it will not harm anything to run like this till you can get home and get a replacement shuttle. I hope this helps. Good luck! Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Oct 21, 2012, at 4:47 PM, "h&jeuropa" wrote: We are stuck in Lamar CO with 914 problems. Have spent most of the day talking to Bud for ideas. Flew about 4 hours yesterday, stopped for fuel and lunch. Takeoff was normal but when leveled off, noted fuel flow was only 3.5 gph, not the expected 5.5. Increasing throttle gave more MP but same fuel flow. Engine felt rough or different than normal. Landed and inspected under cowl - no problem noted. We had just gotten fuel so thought maybe that caused it. Tried flight this morning when it was cooler, had to make emergency landing because power dropped soon after takeoff. No vibration, just wouldn't climb. Found that our fuel tank vent was plugged, cleared it, ran ground tests & Jim did 20 minute solo test flight with no problem. Loaded plane & departed again, engine power dropped just after gear retract, made another emergency landing. (Obvious answer is don't let Heather in the plane [Wink] ) At this point we're thinking pull carbs for rebuild. Any other ideas? Thanks, Jim & Heather N241BW ________________________________________________________________________________
Date: Oct 21, 2012
Jim & Heather, Also, check the pressure line from the airbox to the fuel pressure regulator. This keeps fuel pressure above airbox pressure ensuring sufficient fuel pressure to overcome boost pressure. As with the other lines, check thoroughly where the rubber hose meets a connector. These areas are prone to splitting. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Oct 21, 2012, at 4:47 PM, "h&jeuropa" wrote: We are stuck in Lamar CO with 914 problems. Have spent most of the day talking to Bud for ideas. Flew about 4 hours yesterday, stopped for fuel and lunch. Takeoff was normal but when leveled off, noted fuel flow was only 3.5 gph, not the expected 5.5. Increasing throttle gave more MP but same fuel flow. Engine felt rough or different than normal. Landed and inspected under cowl - no problem noted. We had just gotten fuel so thought maybe that caused it. Tried flight this morning when it was cooler, had to make emergency landing because power dropped soon after takeoff. No vibration, just wouldn't climb. Found that our fuel tank vent was plugged, cleared it, ran ground tests & Jim did 20 minute solo test flight with no problem. Loaded plane & departed again, engine power dropped just after gear retract, made another emergency landing. (Obvious answer is don't let Heather in the plane [Wink] ) At this point we're thinking pull carbs for rebuild. Any other ideas? Thanks, Jim & Heather N241BW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385747#385747 ________________________________________________________________________________
Subject: Re: upholstery
Date: Oct 22, 2012
Try Ricky Biles Tel 07759050736 Excellent workmanship, Ricky specializes in aircraft. He is based in Southampton. Worth the hassle of getting your aircraft to him as you will not be disappointed with the result. Best wishes. Martin Olliver. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385774#385774 ________________________________________________________________________________
Date: Oct 22, 2012
Restricted fuel lines/filters? On 10/21/2012 4:47 PM, h&jeuropa wrote: > > We are stuck in Lamar CO with 914 problems. Have spent most of the day talking to Bud for ideas. Flew about 4 hours yesterday, stopped for fuel and lunch. Takeoff was normal but when leveled off, noted fuel flow was only 3.5 gph, not the expected 5.5. Increasing throttle gave more MP but same fuel flow. Engine felt rough or different than normal. > > Landed and inspected under cowl - no problem noted. We had just gotten fuel so thought maybe that caused it. Tried flight this morning when it was cooler, had to make emergency landing because power dropped soon after takeoff. No vibration, just wouldn't climb. Found that our fuel tank vent was plugged, cleared it, ran ground tests & Jim did 20 minute solo test flight with no problem. Loaded plane & departed again, engine power dropped just after gear retract, made another emergency landing. (Obvious answer is don't let Heather in the plane [Wink] ) > > At this point we're thinking pull carbs for rebuild. Any other ideas? > > Thanks, Jim & Heather N241BW > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385747#385747 > > ________________________________________________________________________________
Subject: Re: Aerial testing and fuel smell
Date: Oct 22, 2012
the radio, using the europa fin aerial is a dipole so it needs no earth, sounds more like a connector/connection problem to me. I think tightening the fuel sender gasket was a major factor in curing my fuel smell too. -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385794#385794 ________________________________________________________________________________
Date: Oct 22, 2012
you could try my wife, but even I got short-shrift! Took a good while of banking brownie points before she did them, ha. -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385795#385795 ________________________________________________________________________________
Date: Oct 22, 2012
Jim, I got about the same issue with my 914 some months ago. At full power, the engine run fine or didn't give full power (oscillating RPMs) depending on the time of the day and the ambient temperature (typically more than 30C). After checking many different items (took some weeks), I found 2 mojor items. I replaced the rubber flanges between the manifold and the carbs. One was not hermetic. The other item was to clean up all fuel lines. The grid of my gascolator had a hole and many particles found their way till the pumps. That cleared up the surging/loss of power issue and further enjoyed my Europa for some long trips :-) Hope this helps. Kind regards, Jacques. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385798#385798 ________________________________________________________________________________
Date: Oct 24, 2012
Jeff, check the throttle cable, where it attaches to- the arm, on the exh aust pipe, if its worn it may-be bending, instead of-moving- the turbo arm...At 700 hours I had to replace the cable=0A=0A=0A=0A=0A_______________ _________________=0AFrom: Jeff B <topglock(at)cox.net>=0ATo: europa-list@matro nics.com =0ASent: Monday, October 22, 2012 12:08 PM=0ASubject: Re: Europa-L B =0A=0ARestricted fuel lines/filters?=0A=0AOn 10/21/201 mp;jeuropa" =0A>=0A> We are stuck in Lamar CO with 914 p roblems.- Have spent most of the day talking to Bud for ideas. Flew about 4 hours yesterday, stopped for fuel and lunch.- Takeoff was normal but w hen leveled off, noted fuel flow was only 3.5 gph, not the expected 5.5.- Increasing throttle gave more MP but same fuel flow.- Engine felt rough or different than normal.=0A>=0A> Landed and inspected under cowl - no prob lem noted.- We had just gotten fuel so thought maybe that caused it.- T ried flight this morning when it was cooler, had to make emergency landing because power dropped soon after takeoff.- No vibration, just wouldn't cl imb.- Found that our fuel tank vent was plugged, cleared it, ran ground t ests & Jim did 20 minute solo test flight with no problem.- Loaded plane & departed again, engine power dropped just after gear retract, made anothe r emergency landing.- (Obvious answer is don't let Heather in the plane - [Wink] )=0A>=0A> At this point we're thinking pull carbs for rebuild. - Any other ideas?=0A>=0A> Thanks, Jim & Heather N241BW=0A>=0A>=0A>=0A> =0A> Read this topic online here:=0A>=0A> http://forums.matronics.com/viewt opic.php?p=385747#385747=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A ============= ________________________________________________________________________________
Date: Oct 24, 2012
Subject: Drop of the hat Calais this Saturday
*Drop of the hat Calais this Saturday 27* * * *Hi Guys * ** * The weather is looking hopeful for this weekend, with free landing and food its an event worth making an effort for, Hope to see a bunch of Europa's there,* ** *Ivor* * * On the 27th of October 2012, The Calais Aeroclub is organising an "open day" from 10:00 am to 18:00 pm open to all - pilots and all public. This year is rather exceptional in as such that our Air club is celebrating its 85th anniversary. The local district authorities - who manages the LFAC airfield - has decided that by promoting our Club as well as their airport - that all private planes, local or international, no matter their nationality - that the landing fee on that particular day will be free of charge.. Soft drinks (Coca Cola, Coffee with or withour milk available on site at the Club hangar as well as sandwiches. Hot meal is equally available at the Brasserie des Aviateurs inside the main hall. For your information, Miss Hardelot 2012 will be present - Miss Hardelot is the local and regional elected beauty queen. In the club hangar, we will present various old and recent photos of the club, various planes (Regis Delbaert, a T6 plane -belonging to Gilles and other planes - obviously outside. The Air club comity and myself hope that you could participate on this exceptional day for our club. The more planes land at LFAC - landing is FOC as mentioned above - can only be encouraging for our club not forgetting the local authorities who endeavour in promoting their airfield. Obviously, this day and success depends on weather conditions. Rain clouds or wind is not welcomed on this particular day. All the best to all of you. Hope to see you soon. Sincerest regards Alain Castille A=E9roclub de Calais Chair** ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 24, 2012
Hi All, No one spotted my deliberate mistake in my earlier posting, re the interfer ence fit of the pins.......a typo.... Should have read as 0.0007'' undersize holes in the torque tube, so not a j ob for the local blacksmith ! I was talking to someone about Bud's cooling the pins system when it dawned on my I had missed a zero...... Cheers, Nev. -----Original Message----- From: Neville Eyre <neveyre(at)aol.com> Sent: Thu, 18 Oct 2012 22:26 Subject: Re: Europa-List: Re: Mod 73 Hi Alan, Can't believe LaaLaaLand won't let you put Inspection Panels in as per the Manual ? If you have no panels back there at all, installing some as directed in the relevant Chapter won't be a ''Mod'', just bringing you airframe in complia nce with what has been approved ? The small spy hole lets you see in there, the larger access hole is in the correct position for you to get your arm in, folded round the corner and ab le to work on the torque tube / trim items. I would be tempted to do it, get it signed off by an Inspector, raise a Wor ksheet and make an entry in the aircraft's Log Book, at the same time as do ing the pin work. On next years Permit Renewal Form, in the ''any repairs / work carried out since the last Permit'' question, list the Pin repair work and the addition of inspection panels as per Chapter 23, P 3,4,5 ? The torque tube CAN be got out by working down the ''tunnel''. As you have noted, support the rear fuselage with a padded trestle. Fill th e baggage area with foam / cushions to the height of the seatback / D panel hole so you can ''surf'' in and out. If you have the Classic fuel filler, take the hose off and plug the tank inlet. Get cushions and carpet offcuts in the rear hull so you don't point load th e skin with elbows etc, 3 or 4 layers of carpet / underlay should do. Unbol t the pitch pushrod containment tower and remove, should be 8 bolts / nuts holding it to the hull / roof, and 2 on the wooden cross piece [ 3/8'' & 1/ 4'' spanners].Weight the tailplanes aft down and tie the stick forward to p ark the mass balance weight up in the roof. Surf aft and unbolt the mass ba lance arm, 2 bolts / nuts [3/8''&1/4''] and pushrod, 1 bolt / nut [1/2'' &3 /8'' ] from the horn. Bung the arm out and lay the pushrod in the hull. Pad under / over the pushrod so any body weight on it doesn't hurt it.Also pro tect the two glass lay up brackets in the hull for the tower, fill between with stiff foam so they don't get broken. Pad your self up from the hull with cushions so you adopt the ''Superman'' position, with your arm outstretched in front of you, you will have to hold yourself up with the palm of your hand while you are straightening the spl it pin and pulling it out, pointed nose pliers and gently used cutters are needed to pull / curl the split pins out. Start with the outer pins first. Pull the drive pin out with Mole Grips. You can now rotate the entire torque tube to allow better access to the rem aining 2 split pins. Mark everything as to its position, I put a red blob inside the bottom of t he port end on the main tube [ paint or nail varnish ] this won't get knock ed off at the Machine Shop. Mark all else with a indellable marker pen, ie Port / Stb TP12, TP 10 collars, with both the writing as to where, and a li ne though the lot so it can go together on the bench back in the same way. The red nail varnish on the Port TP12 in a place that won't get knocked off is a good plan. Cool lighting in there is needed, so not a 100 watt lead lamp ! and a fan b lowing in helps. Could take 3 to 4 hours of sweating and swearing to get it out, bit longer to put it back. Tools needed. Imperial spanners [ wrenches for those in the US] & Imperial sockets [ 1/4'' , 3/8'' , 1/2''] needle nose pliers, Mole [Vise] grips, si de cutters, copper / hide hammer, a selection of punches, magnetic bowl [ t o put the bolts / nuts in when you are in there, to stop them escaping ] an d a swear box. I have the cranked arm / long pushrod ratchet spanners which help to reach the bolt heads. To get a spanner on the nuts [1/4'' & 3/8''] I have B&Q plastic13mm double pipe clips [ as used to mount central heatin g pipes] to bolt the other end of the spanners to, which spring on to the t wo 1/2'' tube arms [ you can't get both arms up there at the same time ]. Entrust the assembly to a good Machine Shop to drill / ream to suit the O/S pins. Fitting is the reverse of dismantling, only more difficult ! Hard bit is ge tting the new pins aimed to go in and come out the other side ! I am workin g on a clamp / aiming / thumbscrew / press gizzmo at the moment, watch this space. -----Original Message----- From: Alan Carter <alancarteresq(at)onetel.net> Sent: Wed, 17 Oct 2012 21:03 Subject: Europa-List: Re: Mod 73 Thanks Neville. honed the LAA today ref. New Inspection Hole. asically No, s i,m in the UK its new dowels and clamps approved by LAA. o i have to find a small person to climb down inside the tunnel after havin g emoved the mass balance weight. assume this is the easiest way to get at the pins, as you can see them. bviously with the tail propped,and all the panels off for light and air. f i go about it this way. ow long to get it out., and do you see any other problem, egards lan ead this topic online here: http://forums.matronics.com/viewtopic.php?p=385573#385573 arget=_blank>http://www.matronics.com/Navigator?Europa-List ://forums.matronics.com lank>http://www.matronics.com/contribution -= - The Europa-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Europa-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Oct 24, 2012
From: danny shepherd <danny(at)mcwalterscafe.co.uk>
Subject: Re: Mod 73
On 24/10/2012 21:23, Neville Eyre wrote: Dam, I just saked my local blacksmith to fix thew plroblem !!!!!!!!!!!!!!!!:-) . > Hi All, > No one spotted my deliberate mistake in my earlier posting, re the > interference fit of the pins.......a typo.... > Should have read as 0.0007'' undersize holes in the torque tube, so > not a job for the local blacksmith ! > I was talking to someone about Bud's cooling the pins system when it > dawned on my I had missed a zero...... > Cheers, > Nev. > > > -----Original Message----- > From: Neville Eyre <neveyre(at)aol.com> > To: europa-list > Sent: Thu, 18 Oct 2012 22:26 > Subject: Re: Europa-List: Re: Mod 73 > > Hi Alan, > Can't believe LaaLaaLand won't let you put Inspection Panels in as per > the Manual ? > If you have no panels back there at all, installing some as directed > in the relevant Chapter won't be a ''Mod'', just bringing you airframe > in compliance with what has been approved ? > The small spy hole lets you see in there, the larger access hole is in > the correct position for you to get your arm in, folded round the > corner and able to work on the torque tube / trim items. > I would be tempted to do it, get it signed off by an Inspector, raise > a Worksheet and make an entry in the aircraft's Log Book, at the same > time as doing the pin work. > On next years Permit Renewal Form, in the ''any repairs / work carried > out since the last Permit'' question, list the Pin repair work and the > addition of inspection panels as per Chapter 23, P 3,4,5 ? > The torque tube CAN be got out by working down the ''tunnel''. > As you have noted, support the rear fuselage with a padded trestle. > Fill the baggage area with foam / cushions to the height of the > seatback / D panel hole so you can ''surf'' in and out. If you have > the Classic fuel filler, take the hose off and plug the tank inlet. > Get cushions and carpet offcuts in the rear hull so you don't point > load the skin with elbows etc, 3 or 4 layers of carpet / underlay > should do. Unbolt the pitch pushrod containment tower and remove, > should be 8 bolts / nuts holding it to the hull / roof, and 2 on the > wooden cross piece [ 3/8'' & 1/4'' spanners].Weight the tailplanes > aft down and tie the stick forward to park the mass balance weight up > in the roof. Surf aft and unbolt the mass balance arm, 2 bolts / > nuts [3/8''&1/4''] and pushrod, 1 bolt / nut [1/2'' &3/8'' ] from the > horn. Bung the arm out and lay the pushrod in the hull. Pad under / > over the pushrod so any body weight on it doesn't hurt it.Also protect > the two glass lay up brackets in the hull for the tower, fill > between with stiff foam so they don't get broken. > Pad your self up from the hull with cushions so you adopt the > ''Superman'' position, with your arm outstretched in front of you, you > will have to hold yourself up with the palm of your hand while you are > straightening the split pin and pulling it out, pointed nose pliers > and gently used cutters are needed to pull / curl the split pins out. > Start with the outer pins first. > Pull the drive pin out with Mole Grips. > You can now rotate the entire torque tube to allow better access to > the remaining 2 split pins. > Mark everything as to its position, I put a red blob inside the bottom > of the port end on the main tube [ paint or nail varnish ] this won't > get knocked off at the Machine Shop. Mark all else with a indellable > marker pen, ie Port / Stb TP12, TP 10 collars, with both the writing > as to where, and a line though the lot so it can go together on the > bench back in the same way. The red nail varnish on the Port TP12 in a > place that won't get knocked off is a good plan. > Cool lighting in there is needed, so not a 100 watt lead lamp ! and a > fan blowing in helps. > Could take 3 to 4 hours of sweating and swearing to get it out, bit > longer to put it back. > Tools needed. Imperial spanners [ wrenches for those in the US] & > Imperial sockets [ 1/4'' , 3/8'' , 1/2''] needle nose pliers, Mole > [Vise] grips, side cutters, copper / hide hammer, a selection of > punches, magnetic bowl [ to put the bolts / nuts in when you are in > there, to stop them escaping ] and a swear box. I have the cranked arm > / long pushrod ratchet spanners which help to reach the bolt heads. To > get a spanner on the nuts [1/4'' & 3/8''] I have B&Q plastic13mm > double pipe clips [ as used to mount central heating pipes] to bolt > the other end of the spanners to, which spring on to the two 1/2'' > tube arms [ you can't get both arms up there at the same time ]. > Entrust the assembly to a good Machine Shop to drill / ream to suit > the O/S pins. > Fitting is the reverse of dismantling, only more difficult ! Hard bit > is getting the new pins aimed to go in and come out the other side ! I > am working on a clamp / aiming / thumbscrew / press gizzmo at the > moment, watch this space. > -----Original Message----- > From: Alan Carter <alancarteresq(at)onetel.net > > > To: europa-list > > Sent: Wed, 17 Oct 2012 21:03 > Subject: Europa-List: Re: Mod 73 > > > Thanks Neville. > Phoned the LAA today ref. New Inspection Hole. > Basically No, > As i,m in the UK its new dowels and clamps approved by LAA. > So i have to find a small person to climb down inside the tunnel after having > removed the mass balance weight. > I assume this is the easiest way to get at the pins, as you can see them. > > Obviously with the tail propped,and all the panels off for light and air. > If i go about it this way. > How long to get it out., and do you see any other problem, > Regards > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385573#385573 > > > arget=_blank>http://www.matronics.com/Navigator?Europa-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > * > > arget=_blank>http://www.matronics.com/Navigator?Europa-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > * > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Subject: Re: Drop of the hat Calais this Saturday
Date: Oct 24, 2012
Sounds good Ivor - sorry I will be over in the USA but hope you get good weather and some decent response to the fly-in. Regards Steve Pitt ----- Original Message ----- From: PHILLIPS I To: europa-list(at)matronics.com Sent: Wednesday, October 24, 2012 5:06 PM Subject: Europa-List: Drop of the hat Calais this Saturday Drop of the hat Calais this Saturday 27 Hi Guys The weather is looking hopeful for this weekend, with free landing and food its an event worth making an effort for, Hope to see a bunch of Europa's there, Ivor On the 27th of October 2012, The Calais Aeroclub is organising an "open day" from 10:00 am to 18:00 pm open to all - pilots and all public. This year is rather exceptional in as such that our Air club is celebrating its 85th anniversary. The local district authorities - who manages the LFAC airfield - has decided that by promoting our Club as well as their airport - that all private planes, local or international, no matter their nationality - that the landing fee on that particular day will be free of charge.. Soft drinks (Coca Cola, Coffee with or withour milk available on site at the Club hangar as well as sandwiches. Hot meal is equally available at the Brasserie des Aviateurs inside the main hall. For your information, Miss Hardelot 2012 will be present - Miss Hardelot is the local and regional elected beauty queen. In the club hangar, we will present various old and recent photos of the club, various planes (Regis Delbaert, a T6 plane -belonging to Gilles and other planes - obviously outside. The Air club comity and myself hope that you could participate on this exceptional day for our club. The more planes land at LFAC - landing is FOC as mentioned above - can only be encouraging for our club not forgetting the local authorities who endeavour in promoting their airfield. Obviously, this day and success depends on weather conditions. Rain clouds or wind is not welcomed on this particular day. All the best to all of you. Hope to see you soon. Sincerest regards Alain Castille A=E9roclub de Calais Chair ________________________________________________________________________________
Subject: Working cabin heater
Date: Oct 24, 2012
Hello all, The cold season is starting this week in Eastern Europe! I am looking at options to have a really working cabin heater for my rotax 914 based Europa. Mean that it is still warm enough in the cabin at -20C (flying in winter when everything is white is something marvelous). My understanding is that only a heater with air warmed from the exhaust will achieve that. Does someone has pictures/instruction/specific parts of a working system for a 914 Europa? Thanks, Jacques Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385933#385933 ________________________________________________________________________________
Date: Oct 24, 2012
Subject: Re: Working cabin heater
ploucandco a crit : > > Hello all, > > The cold season is starting this week in Eastern Europe! > > I am looking at options to have a really working cabin heater for my rotax 914 based Europa. Mean that it is still warm enough in the cabin at -20C (flying in winter when everything is white is something marvelous). > > My understanding is that only a heater with air warmed from the exhaust will achieve that. > > Does someone has pictures/instruction/specific parts of a working system for a 914 Europa? > Jacques, Here what we did : http://contrails.free.fr/cellule_chauffage_en.php Very efficient, no fumes, but you need a correctly designed *radiator duct.* Hope this helps, Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Oct 24, 2012
Subject: Re: Mod 73
Hi Group With regard to getting a good fit of pins on my quick build tailplanes that had a lot of play at the tip of the stabilators from the get go (at least 1"), I machined my own pins. What I found was that even while taking extreme care using slightly undersized drill, then reaming to size using plenty of cutting fluid (10 mm), the hole although it was close to proper size (using precision guage pins in .0001 steps to measure), it was a pretty poor finish on the hole if you look with a microscope. In other words half of the metal was only making contact with the pin! After a bit of head scratching, I machined a number of pins with .0001" tolerance in incremental size. I was able to tap these in using lubricant until I could see and feel that there was good contact. Then measuring with my precision pins, I made the "real deal" pins between .0007 to m.0009" interference fit of this "sized" hole. I cheated a little bit where I made the first hole the pin would go in a few tenths larger at least than the second hole, and made the pin a dog bone shape, where the center was a few thousands smaller in diameter so it would not drag and oversize the first hole. The only interference fit on the pin was ~ 1/8" longer than needed. Machining to .0001" takes a bit of practice, but what I did was laid out all my holes and machined the first pin the largest size. This way if I went under, I was able to use this now undersized pin for the smaller holes. Anyway about 33% scrap, not too bad. End result was a really nice fit during final assembly. You can't use a lath tool bit to work within .0001", you need to lap your size. If you're lucky you may get within less than a thousand, if not two or three thousands. In other words, wet and dry sandpaper glued to a tongue depressor. Using a precision micrometer, use sandpaper on any over sized areas to keep uniform diameter. net is you can work within amazing tolerances! I made out of free machining 410 stainless purchased from www.mcmaster.com To make dogbone was easy. Tape over area of interference fit and using tongue depressor with sandpaper go after what you want to make undersized. Perhaps takes 5 or 10 minutes each pin. If you want to see some pics, look under Torque Tube fit: http://www.europaowners.org/main.php?g2_itemId=86924 Ron Parigoris ________________________________________________________________________________
Date: Oct 24, 2012
Merci Gilles. I saw this one but on the Europa, it seems that the amount of heat going in the cockpit with an engine at the lower green limits (winter time!) is not enough to warm up the cabin. If someone can prove me the opposite, I am happy to hear. Jacques. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385938#385938 ________________________________________________________________________________
Date: Oct 24, 2012
Jacques On the Club Web site you will find a copy of the Mod 10986 which describes the heater fitted to G-JULZ. A number of other aircraft have very similar installations. It is also very similar to the MCR-4S heater described by Gilles. Here is a direct link to the Mod http://www.theeuropaclub.org/wp-content/uploads/2011/12/10986all.pdf Ian Rickard G-IANI XS Trigear, 300hours Europa Club Mods Specialist e-mail g-iani(at)ntlworld.com ________________________________________________________________________________
Date: Oct 24, 2012
Thanks Ian. I saw this one as well. The goal is to get +15C in the cabin when the outside air is -20C. Do you or someone else have positive experience that this system will provide this +35C difference in temperature? Sorry to be difficult but I read a few times that such heater will work well when the engine is running hot. Mine is running cool in winter. Jacques Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385943#385943 ________________________________________________________________________________
Subject: Reserve Fuel
Date: Oct 24, 2012
Hi All. I am just putting this in as it may be of use to low hour flyer's or owners that purchased there aircraft like me. I purchased my Europa about 3 months ago and have clocked up just over 35 hours in her. The previous owner flew her in to Headcorn and basically said nothing , leaving the plane with a 600 rpm Mag drop which i had to fix. Eventually I went flying loading extra fuel as i did not know the aeroplane, and thinking the fuel gauge might be over read a little thinking maybe 5 to 8 litres. A few weeks later i decided to drain the tanks and check the gauge, lucky i did for a couple of reasons as follows. I drained both Main and Reserve as i did not know which tank saddle was the reserve, more by chance i drained the Main tanks Saddle first, it was a long process as i used the fuel drain valves under the aircrafts belly. Then i drained the Reserve the same way ,Here i made a discovery, the 8 litres of drained fuel was Stale, contained particles and some emulsified water droplets. I concluded from my detective work (1) That the previous owner never used the Reserve Side of the Tank, and (2) That even though the Fuel Filler Cap Hose goes down the same side as the Reserve saddle the fuel in the reserve does not mix so leaving old stale dirty fuel in the saddle. I have flow 4 Europa's and nothing about Checking Reserve was printed one there Check Lists, so i suspect they are quit a few who never use the Reserve,?? So I have added a line to my Check List, Taxing In on Reserve, and then change back to Main, I am not likely to use Reserve, and the least i fiddle with before Take Off suits me. At least i know i have fresh clean fuel there should i need it, And Taxing In after flying gets me use to putting my hand down the tunnel and correctly moving the fuel cock to the correct selections. I refilled the tank using a 5 litre cans checking the gauge and making a Fuel Ref Chart, to my surprise 58 Lts on the gauge equaled 35 Ltr actually in the tank. It was way out, i must have been very close empty at times, Now i am using my Chart/Gauge tables which is quit accurate. I will get round to re calibrating the gauge now i have instruction Manual. So (3) Know what's actually in the Tank. I have no fuel filters just a Gasolator, so in cleaning this , i run some main fuel then and some reserve fuel, having selected Reserve no fuel came through, another discovery, i have to put my hand down the tunnel to get at the fuel cock, and selected the fuel cock pointer, to the ON RESERVE position , but was actually selected to the FUEL OFF position, ie the fuel cock handle position for Reserve was not as i would have thought to be,it looked and appeared to me to be set correctly. (4) Check and Confirm the position and look of the lever for, Fuel Off and the position and look of the lever for Fuel Reserve , (I am referring to the old early stile fuel cocks)( not the little Red new type cocks) I know some have all the latest gismo's , but others with just the bare bones may find this helpful. So in a nutshell, Fuel/Gauge Tables,Handle the Fuel Cock,Burn some Reserve. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385950#385950 ________________________________________________________________________________
Subject: Re: Reserve Fuel
Date: Oct 25, 2012
Alan, Interesting finds. For the Monowheel Classic, the best! I normally run my reserve in the cruise to avoid what you have said and keep the fuel flow exercised from both sides. Back to Main for LDG and TO. I placed an extension (workshop drill extension adaptor) from the fuel cock to bring it to be easily accessible to the pilot as the fuel selector on the centre armrest. Was the Fuel Gauged table measurements done with the aircraft in the flying attitude? Cheers, Tim Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 On 25/10/2012, at 9:23 AM, "Alan Carter" wrote: > > Hi All. > I am just putting this in as it may be of use to low hour flyer's or owners that purchased there aircraft like me. > I purchased my Europa about 3 months ago and have clocked up just over 35 hours in her. > The previous owner flew her in to Headcorn and basically said nothing , leaving the plane with a 600 rpm Mag drop which i had to fix. > Eventually I went flying loading extra fuel as i did not know the aeroplane, and thinking the fuel gauge might be over read a little thinking maybe 5 to 8 litres. > > A few weeks later i decided to drain the tanks and check the gauge, lucky i did for a couple of reasons as follows. > I drained both Main and Reserve as i did not know which tank saddle was the reserve, more by chance i drained the Main tanks Saddle first, > it was a long process as i used the fuel drain valves under the aircrafts belly. > Then i drained the Reserve the same way ,Here i made a discovery, the 8 litres of drained fuel was Stale, contained particles and some emulsified water droplets. > I concluded from my detective work (1) That the previous owner never used the Reserve Side of the Tank, and (2) That even though the Fuel Filler Cap Hose goes down the same side as the Reserve saddle the fuel in the reserve does not mix so leaving old stale dirty fuel in the saddle. > I have flow 4 Europa's and nothing about Checking Reserve was printed one there Check Lists, so i suspect they are quit a few who never use the Reserve,?? > So I have added a line to my Check List, Taxing In on Reserve, and then change back to Main, I am not likely to use Reserve, and the least i fiddle with before Take Off suits me. > At least i know i have fresh clean fuel there should i need it, And Taxing In after flying gets me use to putting my hand down the tunnel and correctly moving the fuel cock to the correct selections. > > I refilled the tank using a 5 litre cans checking the gauge and making a Fuel Ref Chart, to my surprise 58 Lts on the gauge equaled 35 Ltr actually in the tank. > It was way out, i must have been very close empty at times, Now i am using my Chart/Gauge tables which is quit accurate. I will get round to re calibrating the gauge now i have instruction Manual. So (3) Know what's actually in the Tank. > I have no fuel filters just a Gasolator, so in cleaning this , i run some main fuel then and some reserve fuel, having selected Reserve no fuel came through, another discovery, i have to put my hand down the tunnel to get at the fuel cock, and selected the fuel cock pointer, to the ON RESERVE position , but was actually selected to the FUEL OFF position, ie the fuel cock handle position for Reserve was not as i would have thought to be,it looked and appeared to me to be set correctly. > (4) Check and Confirm the position and look of the lever for, Fuel Off and the position and look of the lever for Fuel Reserve , (I am referring to the old early stile fuel cocks)( not the little Red new type cocks) > I know some have all the latest gismo's , but others with just the bare bones may find this helpful. > So in a nutshell, Fuel/Gauge Tables,Handle the Fuel Cock,Burn some Reserve. > Alan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385950#385950 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 24, 2012
Subject: Introducing Aircraft Specialty
From: Aircraft Specialty <aircraftspecialty(at)gmail.com>
Good evening fellow builders, pilots and enthusiasts. I want to take this opportunity to introduce Aircraft Specialty. We have been working the last few months on developing a web presence and already count a lot of you as customers and friends. Our mission is simple=85..we want to help fellow builders out by building a nd selling the highest quality products at the best prices with excellent customer service. We will do whatever it takes to earn your business and make sure that you are a satisfied customer not just in the days and weeks after your purchase, but forever. Also, we know that your time is extremely valuable, so we have tried to make our web site extremely user friendly. We have developed several interactive applications to simplify some things. For instance, if you need a data plate or are looking to have your fuel caps engraved, you can input all the data on our website exactly as you would like it to appear, add it to your cart and purchase without having to email back and forth to get set up. We also have developed an interactive pricing application to let you design and price custom fuel lines or battery cables right on the website and order with our interactive application. It=92s never been easier. We have also been diligently working on new products to enhance the experience of builders. We are extremely excited to announce the =93Signature Series=94 line of parts to the community. Anything with this logo on it is something that we manufacture in house. It is of the highest quality and also carries our limited lifetime warranty. We have some very unique items, such as our Aftermarket Flap handle, which not only looks great and is easy to install, but also solves a problem that plagues many toggle switches. Our won=92t rotate with the toggle and as such provides a great looking alternative to a standard toggle switch at a price that is cheaper than any other flap shaped switch. We also have a unique, great looking alternate static system that will integrate with the SafeAir1 system, and also eventually our own pitot static system that we are developing. Since we have extremely low overhead and make many of the parts in house, we are able to offer incredible pricing. This also holds true on our clecos and bucking bars. We have been able to secure great pricing due to high volume purchases and rather than keeping our already low prices the same, we have lowered them to pass the savings on to our customers. You can take a look at all of our products by remembering one of three website names. We can be found at www.aircraftspecialty.com, www.kitplanemods.com, or www.kitplanehoses.com. All three domains will take you to the same place. Finally, as a fellow builder, I would like to let everyone know that this business will evolve around YOUR needs. I really welcome comments as well as any constructive criticism that you may have. I definitely welcome the creativity of the homebuilding community and would like to help develop new products that you are interested in. This will benefit the entire community in the long run. If you run into any website issues, please let me know as we are still a small but rapidly growing company and do all our IT in house and will do our best to resolve it Thank you for your time, and we look forward to earning your business. Steve and Dawn steve(at)aircraftspecialty.com ________________________________________________________________________________
Date: Oct 25, 2012
Hi Tim. NZ a beautiful county i had a holiday there. I have done my time on Chipmunks, My Europa is a Mono to Tri Conversion so maybe better! well a lot easier. The Fuel/Tables were done with the aircraft just in its level position on level ground, a couple of litres either way i am not bothering about as if i was down to 15 litres i would be quit worried. Glad you use the reserve fuel, just my choice taxing in on reserve, I like your idea of the extended lever, is it guarded or recessed, can you give some more on how to do it. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385966#385966 ________________________________________________________________________________
Subject: Fuel Selector Extension
Date: Oct 25, 2012
Hi Alan, So the fuel cock is mounted on the floor on the fuselage between the seats and the pilot has to access a door to reach down and change to RESERVE in an emergency. NOT GOOD! So I took off the fuel selector arm and replaced it with a drill extension rod that you can buy down at your local hardware shop. One end has a female adaptor with a grub screw to tighten onto the male axle of the fuel selector cock. (Sounds a little rude!) The other end you can cut to length so that the end will appear above the door through a hole directly above the fuel cock. You can then file the end to the shape of the selector hole to fit it, orientated in the same way as the selector was below. I replaced the door with an aluminum piece and then inscribed on the aluminum OFF/ MAIN /RESERVE and incorporated a spring loaded stop bar to stop turning the selector to OFF by mistake. Consequently you have easily available the ability to switch tanks and turn the fuel off, if necessary, with seconds. I made a bigger selector out of blue foam shaped around the metal selector and then fiberglass to strengthen it, glued and painted. Sorry I haven't a photo as I am in Japan but will be back on Saturday and will try to remember to send you a photo as a picture is much easier to understand. Please remind me if you go ahead with this Tim Ward Mod. All the best, Tim Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 ________________________________________________________________________________
Date: Oct 25, 2012
Hi Alan I'd add a couple of things - you have the fuel drain mod installed which is good. But be aware that you need to drain more fuel than a normal fuel dra in to clear the fuel in the lines between the drain and the tank. I drain a bout 'half jam jar' each side. Also, the fuel return from the engine should be feeding into the reserves s ide so it should refresh the fuel. But if fueling the plane doesn't get to the bottom of the tank to stir things up, the return flow certainly won't. But it worth checking that the fuel return is happening. Regards Roddy Kesterton G-IKRK -----Original Message----- From: Alan Carter <alancarteresq(at)onetel.net> Sent: Thu, 25 Oct 2012 8:56 Subject: Europa-List: Re: Reserve Fuel Hi Tim. Z a beautiful county i had a holiday there. have done my time on Chipmunks, My Europa is a Mono to Tri Conversion o maybe better! well a lot easier. he Fuel/Tables were done with the aircraft just in its level position on le vel round, a couple of litres either way i am not bothering about as if i was d own o 15 litres i would be quit worried. lad you use the reserve fuel, just my choice taxing in on reserve, like your idea of the extended lever, is it guarded or recessed, can you g ive ome more on how to do it. lan ead this topic online here: http://forums.matronics.com/viewtopic.php?p=385966#385966 -= - The Europa-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Europa-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: Fuel Selector Extension
Date: Oct 25, 2012
Alan, One other thing I did. I drilled a hole in the rod extension (door end) and tapped it to be able to screw the same small bolt in to it to tighten the selector to the rod extension. Most important. Works a treat. Tim Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 On 25/10/2012, at 5:38 PM, Tim Ward wrote: > > Hi Alan, > So the fuel cock is mounted on the floor on the fuselage between the seats and the pilot has to access a door to reach down and change to RESERVE in an emergency. NOT GOOD! > So I took off the fuel selector arm and replaced it with a drill extension rod that you can buy down at your local hardware shop. One end has a female adaptor with a grub screw to tighten onto the male axle of the fuel selector cock. (Sounds a little rude!) The other end you can cut to length so that the end will appear above the door through a hole directly above the fuel cock. You can then file the end to the shape of the selector hole to fit it, orientated in the same way as the selector was below. > I replaced the door with an aluminum piece and then inscribed on the aluminum OFF/ MAIN /RESERVE and incorporated a spring loaded stop bar to stop turning the selector to OFF by mistake. > Consequently you have easily available the ability to switch tanks and turn the fuel off, if necessary, with seconds. > I made a bigger selector out of blue foam shaped around the metal selector and then fiberglass to strengthen it, glued and painted. > Sorry I haven't a photo as I am in Japan but will be back on Saturday and will try to remember to send you a photo as a picture is much easier to understand. > Please remind me if you go ahead with this Tim Ward Mod. > > All the best, > > Tim > > > > Tim Ward > 12 Waiwetu Street > Fendalton, > Christchurch, 8052 > New Zealand. > > ward.t(at)xtra.co.nz > > Ph 64 3 3515166 > Mob 0210640221 > > > > > > ________________________________________________________________________________
Date: Oct 25, 2012
Alan Adding and extension, as Tim has done, is a great improvement. Unfortunately owners experience is that the Europa supplied valve becomes stiff to turn after about 150 hours. I replaced mine at 200 hours and replaced the replacement with an Andair at 275 hours. Replacement with an Andair is a Standard Mod and details are available on the Club and LAA web sites. http://www.theeuropaclub.org/wp-content/uploads/2011/12/SM13342-1Andair.pdf The example check list the club publishes on our site http://www.theeuropaclub.org/wp-content/uploads/2011/12/Sample-checklist.pdf does stipulate starting on Reserve for the reasons you have outlined. Possibly we should give greater emphasis to this as some pilots may be using check lists which have dropped this requirement. Ian Rickard G-IANI XS Trigear, 300hours Europa Club Mods Specialist e-mail g-iani(at)ntlworld.com ________________________________________________________________________________
Date: Oct 25, 2012
Hi Alan, I am probably "telling grandmother how to suck eggs" But I discovered the hard way that the plastic 5 litre containers can hold far more than 5 litres. Did you calibrate your 5 litre can before you used it to calibrate your system? The Europa fuel tank does change shape during its life so recalibration is needed but I would not expect the extent of error that you described. I would expect to see a tank capacity of between 58 and 61 litres, not including the reserve section. As I am sure you have spotted, the fuel sender (assuming it is the standard Europa fit) only measures the fuel contents from one side of the saddle so if you are measuring from a complete empty situation, the first 8-9 litres goes into the reserve and does not show on the gauge. Also, the standard fuel sender only has 8 reed switches on it, so the fuel contents "jumps" in steps of about 7 litres. The other thing to be aware of is that if you are draining fuel via the water drains (assuming again that you have the standard water drains mod fitted) it is very hard to completely empty the tank if the aircraft is a Trigear. You are probably better off emptying the tank by use of the electric pump, having disconnected the fuel hose at the mechanical fuel pump. That way you get down to a genuine minimum useable fuel level at flying attitude. This would be your zero point for fuel gauge calibration. The process that I follow, from a completely empty tank, is to pour in about 10 litrs of fuel to ensure the reserve side is full. Then drain the main tank again using the electric pump to remove fuel that has slopped over from the reserve into the main area. Then start the calibration process. Again, my apologies if I am stating the obvious. Regards Brian -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Alan Carter Sent: 25 October 2012 01:23 Subject: Europa-List: Reserve Fuel --> Hi All. I am just putting this in as it may be of use to low hour flyer's or owners that purchased there aircraft like me. I purchased my Europa about 3 months ago and have clocked up just over 35 hours in her. The previous owner flew her in to Headcorn and basically said nothing , leaving the plane with a 600 rpm Mag drop which i had to fix. Eventually I went flying loading extra fuel as i did not know the aeroplane, and thinking the fuel gauge might be over read a little thinking maybe 5 to 8 litres. A few weeks later i decided to drain the tanks and check the gauge, lucky i did for a couple of reasons as follows. I drained both Main and Reserve as i did not know which tank saddle was the reserve, more by chance i drained the Main tanks Saddle first, it was a long process as i used the fuel drain valves under the aircrafts belly. Then i drained the Reserve the same way ,Here i made a discovery, the 8 litres of drained fuel was Stale, contained particles and some emulsified water droplets. I concluded from my detective work (1) That the previous owner never used the Reserve Side of the Tank, and (2) That even though the Fuel Filler Cap Hose goes down the same side as the Reserve saddle the fuel in the reserve does not mix so leaving old stale dirty fuel in the saddle. I have flow 4 Europa's and nothing about Checking Reserve was printed one there Check Lists, so i suspect they are quit a few who never use the Reserve,?? So I have added a line to my Check List, Taxing In on Reserve, and then change back to Main, I am not likely to use Reserve, and the least i fiddle with before Take Off suits me. At least i know i have fresh clean fuel there should i need it, And Taxing In after flying gets me use to putting my hand down the tunnel and correctly moving the fuel cock to the correct selections. I refilled the tank using a 5 litre cans checking the gauge and making a Fuel Ref Chart, to my surprise 58 Lts on the gauge equaled 35 Ltr actually in the tank. It was way out, i must have been very close empty at times, Now i am using my Chart/Gauge tables which is quit accurate. I will get round to re calibrating the gauge now i have instruction Manual. So (3) Know what's actually in the Tank. I have no fuel filters just a Gasolator, so in cleaning this , i run some main fuel then and some reserve fuel, having selected Reserve no fuel came through, another discovery, i have to put my hand down the tunnel to get at the fuel cock, and selected the fuel cock pointer, to the ON RESERVE position , but was actually selected to the FUEL OFF position, ie the fuel cock handle position for Reserve was not as i would have thought to be,it looked and appeared to me to be set correctly. (4) Check and Confirm the position and look of the lever for, Fuel Off and the position and look of the lever for Fuel Reserve , (I am referring to the old early stile fuel cocks)( not the little Red new type cocks) I know some have all the latest gismo's , but others with just the bare bones may find this helpful. So in a nutshell, Fuel/Gauge Tables,Handle the Fuel Cock,Burn some Reserve. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385950#385950 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Oct 25, 2012
Jaques, I also plan this sort of installation (http://www.customflightcreations.com/id18.html) this winter, thus cannot yet post my experiences so far. My (conventional Rotax 914) engine installation is also running cool at low OAT, therefore I installed a water thermostat (an additional oil thermostat might also be an option) - this should help a little. Roland XS Trigear 914 PH-ZTI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385979#385979 ________________________________________________________________________________
Date: Oct 25, 2012
Hi Roland I have a similar set up in my 914 but without the water thermostat, Using one will reduce the water temperature in the Radiator but will Increase the engine water temperature only, You would be better of fitting a cowl flap to reduce cold airflow through The radiator so increasing air temperature behind the radiator then to the cabin, My heater certainly takes the chill out of the air making flying pleasant down to minus 5 C, but it isn=92t as warm as the average car heater, This I intend to rectify this winter=92s maintenance layup with improved Ducting and insulating the heat trunking to the cockpit Ivor G-IVER 914XS On 25 October 2012 14:01, Roland wrote: > > Jaques, > > I also plan this sort of installation ( > http://www.customflightcreations.com/id18.html) this winter, thus cannot > yet post my experiences so far. > > My (conventional Rotax 914) engine installation is also running cool at > low OAT, therefore I installed a water thermostat (an additional oil > thermostat might also be an option) - this should help a little. > > Roland > XS Trigear 914 > PH-ZTI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385979#385979 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Oct 25, 2012
Alan, this mine. When building, my logic was: - "MAIN" (open) is blue (one neutral colour and blue skies) and pointing forward (because normally you wanna fly forward!) - "RES" (reserve) is green (the colour with an inbuild good hope) and pointing upp (because in the case of fuel lack you probably wanna go upp not down) - "CLSD" (closed) is red (the colour which is alarming) and pointing backwards (because in the case you wanna close your tap you do not wanna fly anymore) - position downward not possible to select for clarity Switchable in =BD second. Backplate is aluminium and carved /colour filled. Raimo from Finland OH-XRT 337,40 in an Europa logbook today 1,5 hours in Messerschmitt BF 109 G with one succesfull landing. 2012/10/25 Tim Ward > > Hi Alan, > So the fuel cock is mounted on the floor on the fuselage between the seat s > and the pilot has to access a door to reach down and change to RESERVE in > an emergency. NOT GOOD! > So I took off the fuel selector arm and replaced it with a drill extensio n > rod that you can buy down at your local hardware shop. One end has a fema le > adaptor with a grub screw to tighten onto the male axle of the fuel > selector cock. (Sounds a little rude!) The other end you can cut to lengt h > so that the end will appear above the door through a hole directly above > the fuel cock. You can then file the end to the shape of the selector hol e > to fit it, orientated in the same way as the selector was below. > I replaced the door with an aluminum piece and then inscribed on the > aluminum OFF/ MAIN /RESERVE and incorporated a spring loaded stop bar to > stop turning the selector to OFF by mistake. > Consequently you have easily available the ability to switch tanks and > turn the fuel off, if necessary, with seconds. > I made a bigger selector out of blue foam shaped around the metal selecto r > and then fiberglass to strengthen it, glued and painted. > Sorry I haven't a photo as I am in Japan but will be back on Saturday and > will try to remember to send you a photo as a picture is much easier to > understand. > Please remind me if you go ahead with this Tim Ward Mod. > > All the best, > > Tim > > > Tim Ward > 12 Waiwetu Street > Fendalton, > Christchurch, 8052 > New Zealand. > > ward.t(at)xtra.co.nz > > Ph 64 3 3515166 > Mob 0210640221 > > =========== =========== =========== =========== > > -- Terveisin, Raimo Toivio RWM-SYSTEMS "=E4lyk=E4st=E4 informaatiotekniikkaa vuodesta 1980" 37500 Lemp=E4=E4l=E4 FINLAND p. 03 - 3753 777 f. 03 - 3753 100 www.rwm.fi info(at)rwm.fi ________________________________________________________________________________
Date: Oct 25, 2012
Hello Ivor, as for the temperature in the radiator with a thermostat you are right of course - never thought about it before. Nevertheless I prefer the thermostat compared to the cowl flap since there's no additional controls to care about. At very low temperatures some duct tape should also do the same job as a cowl flap - although far less sophisticated and less controllable. Because some say that no heating at all is needed in the Europa I'm confident, that Bud Yerly's design works okay for me. I get more and more a guess, why our Europas are classified as "Experimentals". Roland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386008#386008 ________________________________________________________________________________
Subject: Re: Dynon
Date: Oct 25, 2012
Hello David, don't know where you are with the Dynon AOA, but the following video (well based on an Advanced EFIS) could be instructive: http://www.youtube.com/watch?v=985BkVkRDUs Jacques. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386010#386010 ________________________________________________________________________________
Date: Oct 25, 2012
Hello Brian and All I have not flown for 14 years and a small plane for 30 years, My machine for the past 14 years was my Honda Blackbird at 200mph a bit faster than the Europa, but as the sticker on the wind shield says, "Id rather be flying" So thank you NPPL i have my L plates on again, keep the posts coming in, its surprising how much one forgets with the passage of time. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386011#386011 ________________________________________________________________________________
Subject: Fuel selector stiff
Date: Oct 25, 2012
My fuel selector hasn't been getting much exercise in the last few years and has gotten rather stiff to operate. It's awkward enough getting to it in the tunnel but as stiff as it is it's almost impossible to operate from the pilot seat. Anyone have any solutions to getting it to loosen back up. thanks, E.G. mono classic sr. #A009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386012#386012 ________________________________________________________________________________
Date: Oct 25, 2012
Raimo, To heck with pictures of fuel selectors. I want to see pictures and movies of the BF-109G!! Is it as difficult a beast on takeoff and landing as rumored? Tell us more! Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Oct 25, 2012, at 2:08 PM, Raimo Toivio wrote: Alan, this mine. When building, my logic was: - "MAIN" (open) is blue (one neutral colour and blue skies) and pointing forward (because normally you wanna fly forward!) - "RES" (reserve) is green (the colour with an inbuild good hope) and pointing upp (because in the case of fuel lack you probably wanna go upp not down) - "CLSD" (closed) is red (the colour which is alarming) and pointing backwards (because in the case you wanna close your tap you do not wanna fly anymore) - position downward not possible to select for clarity Switchable in =BD second. Backplate is aluminium and carved /colour filled. Raimo from Finland OH-XRT 337,40 in an Europa logbook today 1,5 hours in Messerschmitt BF 109 G with one succesfull landing. -- Terveisin, Raimo Toivio RWM-SYSTEMS "=E4lyk=E4st=E4 informaatiotekniikkaa vuodesta 1980" 37500 Lemp=E4=E4l=E4 FINLAND p. 03 - 3753 777 f. 03 - 3753 100 www.rwm.fi info(at)rwm.fi ________________________________________________________________________________
From: "William Daniell" <wdaniell.longport(at)gmail.com>
Date: Oct 26, 2012
Me too!!! From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Robert Borger Sent: 25 October 2012 19:27 Subject: Re: Europa-List: Fuel Selector Extension Raimo, To heck with pictures of fuel selectors. I want to see pictures and movies of the BF-109G!! Is it as difficult a beast on takeoff and landing as rumored? Tell us more! Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Oct 25, 2012, at 2:08 PM, Raimo Toivio wrote: Alan, this mine. When building, my logic was: - "MAIN" (open) is blue (one neutral colour and blue skies) and pointing forward (because normally you wanna fly forward!) - "RES" (reserve) is green (the colour with an inbuild good hope) and pointing upp (because in the case of fuel lack you probably wanna go upp not down) - "CLSD" (closed) is red (the colour which is alarming) and pointing backwards (because in the case you wanna close your tap you do not wanna fly anymore) - position downward not possible to select for clarity Switchable in =BD second. Backplate is aluminium and carved /colour filled. Raimo from Finland OH-XRT 337,40 in an Europa logbook today 1,5 hours in Messerschmitt BF 109 G with one succesfull landing. -- Terveisin, Raimo Toivio RWM-SYSTEMS "=E4lyk=E4st=E4 informaatiotekniikkaa vuodesta 1980" 37500 Lemp=E4=E4l=E4 FINLAND p. 03 - 3753 777 f. 03 - 3753 100 <http://www.rwm.fi/> www.rwm.fi info(at)rwm.fi ________________________________________________________________________________
Date: Oct 26, 2012
Subject: Re: 914 surging/loss of power
Jeff. .at about 700 hours I had the same problem, with engine surging.- A fter replacement of new throttle cable,=0AThe engine was back to normal.=0A =0A=0A=0A________________________________=0AFrom: Jeff B <topglock(at)cox.net> =0ATo: europa-list(at)matronics.com =0ASent: Monday, October 22, 2012 12:08 PM =0ASubject: Re: Europa-List: 914 surging/loss of power=0A=0A--> Europa-List message posted by: Jeff B =0A=0ARestricted fuel lines/fi lters?=0A=0AOn 10/21/2012 4:47 PM, h&jeuropa wrote:=0A> --> Europa-List message posted by: "h&jeuropa" =0A>=0A> We are stuc k in Lamar CO with 914 problems.- Have spent most of the day talking to B ud for ideas. Flew about 4 hours yesterday, stopped for fuel and lunch.- Takeoff was normal but when leveled off, noted fuel flow was only 3.5 gph, not the expected 5.5.- Increasing throttle gave more MP but same fuel flo w.- Engine felt rough or different than normal.=0A>=0A> Landed and inspec ted under cowl - no problem noted.- We had just gotten fuel so thought ma ybe that caused it.- Tried flight this morning when it was cooler, had to make emergency landing because power dropped soon after takeoff.- No vib ration, just wouldn't climb.- Found that our fuel tank vent was plugged, cleared it, ran ground tests & Jim did 20 minute solo test flight with no p roblem.- Loaded plane & departed again, engine power dropped just after g ear retract, made another emergency landing.- (Obvious answer is don't le t Heather in the plane- [Wink] )=0A>=0A> At this point we're thinking pul l carbs for rebuild.- Any other ideas?=0A>=0A> Thanks, Jim & Heather N241 BW=0A>=0A>=0A>=0A>=0A> Read this topic online here:=0A>=0A> http://forums.m atronics.com/viewtopic.php?p=385747#385747=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A =========================0A ================= ________________________________________________________________________________
Subject: Re: Mod 73
Date: Oct 26, 2012
Hello All I have seen a photo of the new Torque Tube made by Europa. As far as i can make out from the picture, is as follows. 1.Basically the TP9 bell crank in the middle, now has a longer tube on each side, 2.The TB12 Drive Plate also has a longer tube on the inside of the Drive Plate this being a slightly smaller diameter than the TP9s extended tubes, So the TP12 Drive plate tube slides directly inside the TP9 Bellcrank tube and a 3/8" pin as before locks them together. So instead of the 4 pins previously used, there are now only 2 pins used. I am saying pins but it could be bolts as i can not tell from the photo.? i am just describing what i can see from the outside photo. The price is around 735 incl Vat, not sure if this just for the 3 above components, or for all the components need, i would guess just the 3 above. Regards . Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386051#386051 ________________________________________________________________________________
Date: Oct 26, 2012
Hello Roland I stated couple of years ago a water thermostat is a must and cars have proved it is something you can really trust. Some of The Europa List-users claimed I am an idiot because adding that "complex" item it makes flying too risky (!). So far I have used it 340 hrs /6 years in my Europa and over 1 million kilometers /34 years in my cars w/o problems. There is no known thermostat problems. In the case of jamming, it will jamm open. As you wrote, a thermostat is automatic - not manual. That is clever. In the other hand, some of us like "many manual levers and knobs to move in and out, upp or down and so". Maybe that is because those pilots would like to be in their dreams a captain of multi-engine-machine and have at least 8 throttle /mixture /prop levers and so to get influence with that girl sitting on the P2 seat. I have water heated carbs and I am happy I have eliminated one knob then again. My grandfather put something front of his cooler to get warmer inside. I prefer automatic system. Also in my house. Also in my life. I am going to fly tomorrow - I promise it really would be not possible here in Finland (my base is about N62) just now without a sophisticated pre-warming /cockpit warming /defrost systems. It is so terrible cold and freezing here just now - be happy you are not Finnish today. Raimo Finland OH-XRT Our AN-2 was almost flipping over today because She lost suddenly the airpressure in Her left gear (attachment). Happily tomorrow there will come here couple of mechanists from Hungary Nyiregyhaza to solve a problem and make some other "minor adjustments" we need to operate this Lady fluently. 2012/10/25 Roland > > Hello Ivor, > > as for the temperature in the radiator with a thermostat you are right of > course - never thought about it before. > > Nevertheless I prefer the thermostat compared to the cowl flap since > there's no additional controls to care about. At very low temperatures so me > duct tape should also do the same job as a cowl flap - although far less > sophisticated and less controllable. > > Because some say that no heating at all is needed in the Europa I'm > confident, that Bud Yerly's design works okay for me. > > I get more and more a guess, why our Europas are classified as > "Experimentals". > > Roland > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=386008#386008 > > =========== =========== =========== =========== > > -- Terveisin, Raimo Toivio RWM-SYSTEMS "=E4lyk=E4st=E4 informaatiotekniikkaa vuodesta 1980" 37500 Lemp=E4=E4l=E4 FINLAND p. 03 - 3753 777 f. 03 - 3753 100 www.rwm.fi info(at)rwm.fi ________________________________________________________________________________
Date: Oct 26, 2012
Raimo Toivio a crit : > Hello Roland > > I stated couple of years ago a water thermostat is a must and cars > have proved it is something you can really trust. > Some of The Europa List-users claimed I am an idiot because adding > that "complex" item it makes flying too risky (!). > So far I have used it 340 hrs /6 years in my Europa and over 1 million > kilometers /34 years in my cars w/o problems. > There is no known thermostat problems. > In the case of jamming, it will jamm open. > > As you wrote, a thermostat is automatic - not manual. That is clever. > In the other hand, some of us like "many manual levers and knobs to > move in and out, upp or down and so". > Maybe that is because those pilots would like to be in their dreams a > captain of multi-engine-machine and have at least 8 throttle /mixture > /prop levers and so to get influence with that girl sitting on the P2 > seat. Raimo, Nothing idiot in a water thermostat. The point is, it only takes care of water temperatures, and not of cooling *drag*. With a thermostat, you need to flow lots of air through the radiator, and only act on the water. Radiator drag doesn't matter much in a slow vehicle such as a car or an old fashion already draggy airplane. But in a sleek airplane, always having maximum radiator drag regardless of flight conditions may amount to some precious knots or vertical feet per minute or climb out performance. Bottom line, it is up to the builder. BTW for the sake of lightness and simplicity, the most important lever to get rid of in a less than 200 mph airplane is the gear lever ;-) Below those speed, nothing to be gained with a retracting gear as opposed to a correctly streamlined fixed gear. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Oct 26, 2012
Hi Raimo, good to hear that your Antonov stunt turned out well. I guess that who can handle a Mono can manage almost any taildragger surprises. BTW, how about the heating system in the AN-2 - the Russians must know the best about that. Maybe you are right regarding the knobs and levers but I like to keep it simple as well. Good luck tomorrow with the hungarian mechanics, I hope You have a heated hangar at your disposal. Greetings from Germany (5C) Roland XS Trigear 914 PH-ZTI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386062#386062 ________________________________________________________________________________
Date: Oct 26, 2012
Fred Klein a crit : > > Gilles...in the spirit of :-)....let me guess...your bird is a fixed > tri-gear, yes? ^^! Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Oct 27, 2012
Hi Bob Takeoff was like Europa Mono takeoff - quite easy but must be careful and concentrate to keep it straight. But landing was awful - at least for me. It was told to me that most of the MEs were destroyed during the war when landing. Speed over the numbers and when touching must be 250 km/h (135 knots). Mustang P51 (a real one!) was a pussycat to land when compare to ME109 (please notice that was a Hi-Pe Simulator as I told to Paul, not a real one [attachment]). What can I say - I am happy I am living and flying just now and not past as a fighter pilot during the war. Raimo 2012/10/26 Robert Borger > Raimo, > > To heck with pictures of fuel selectors. I want to see pictures and > movies of the BF-109G!! Is it as difficult a beast on takeoff and landin g > as rumored? Tell us more! > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop. > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Oct 25, 2012, at 2:08 PM, Raimo Toivio wrote: > > Alan, > > this mine. > > When building, my logic was: > > - "MAIN" (open) is blue (one neutral colour and blue skies) and pointing > forward (because normally you wanna fly forward!) > - "RES" (reserve) is green (the colour with an inbuild good hope) and > pointing upp (because in the case of fuel lack you probably wanna go upp > not down) > - "CLSD" (closed) is red (the colour which is alarming) and pointing > backwards (because in the case you wanna close your tap you do not wanna > fly anymore) > - position downward not possible to select for clarity > > Switchable in =BD second. > > Backplate is aluminium and carved /colour filled. > > Raimo from Finland > OH-XRT > > 337,40 in an Europa logbook > > today 1,5 hours in Messerschmitt BF 109 G with one succesfull landing. > > -- > Terveisin, > Raimo Toivio > > RWM-SYSTEMS > "=E4lyk=E4st=E4 informaatiotekniikkaa vuodesta 1980" > > 37500 Lemp=E4=E4l=E4 > FINLAND > > p. 03 - 3753 777 > f. 03 - 3753 100 > > www.rwm.fi > info(at)rwm.fi > > > -- Terveisin, Raimo Toivio RWM-SYSTEMS "=E4lyk=E4st=E4 informaatiotekniikkaa vuodesta 1980" 37500 Lemp=E4=E4l=E4 FINLAND p. 03 - 3753 777 f. 03 - 3753 100 www.rwm.fi info(at)rwm.fi ________________________________________________________________________________
Date: Oct 29, 2012
From: "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk>
Subject: Re: Vapour lock? Why?
On 31/07/2012 22:27, klinefelter.kevin(at)gmail.com wrote: > > Snip .... /.....//I was chatting with Rob Seaton ( of Rotech in canada)//. He said he learned how too small a fuel line and/or tortured routing can cause "cavitation" at the pumps. So maybe your fuel filter(s), on the suction side of the pump,are causing cavitation in the pump(s). Maybe due to the size (restriction of flow) of the filter, even if they are clean./ /........//Snip/ Kevin, I think Rob Seaton may be on the money with this one. A year or so back, I experienced a dead cut while flying a friend's 914 powered Europa on a hot day. Nifty application of fuel pump restored the noise, but once safely back on the ground, I checked the filters (all clean). This aircraft was fitted with Europa specified Purolator glass shrouded filters that allow you to see the fuel flowing. At low RPM, the filter appeared full, but as power was increased, the filter began to fill with what I thought was air. My first action was to check the pipework and security of connections - but everything seemed fine - it was definitely not drawing in air from anywhere. I then concluded that I had experienced vapour lock and left it at that. Curiosity got the better of me and I started researching cavitation and stumbled upon this very stilted, but interesting presentation on Youtube. Take a look at the first minute from 00.20 - in particular, the glass venturi. This was exactly what I saw in the Purolator filters. http://www.youtube.com/watch?v=K_w3gcvA87I My conclusion is that the Purolator filter has the correct mesh size to trap contaminants, but the filter capacity is too small and creates a pressure drop in the fuel line. Nigel ________________________________________________________________________________
Date: Oct 29, 2012
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Nigel=0Aanother problem with those filters is that sometimes they look clea n but aren't because the contamination is translucent when wet with fuel; s o, more restriction.-=0AYou're right, they are too small. quite high fuel flow with a 914.=0AGraham=0A=0A=0A=0A________________________________=0A F rom: "nigel_graham@m-tecque.co.uk" =0ATo: euro pa-list(at)matronics.com =0ASent: Monday, 29 October 2012, 10:01=0ASubject: Re : Europa-List: Vapour lock? Why?=0A =0A=0A=0A=0AOn 31/07/2012 22:27, klinef elter.kevin(at)gmail.com Snip .........I was chatting with Rob Seaton ( of Rot ech in canada). He said he learned how too small a fuel line and/or torture d routing can cause "cavitation" at the pumps. So maybe your fuel filter(s) , on the suction side of the pump,are causing cavitation in the pump(s). Ma ybe due to the size (restriction of flow) of the filter, even if they are c lean.=0A........Snip=0A=0AKevin, I think Rob Seaton may be on the money wit h this one.- =0AA year or so back, I experienced a dead cut while flying a friend's=0A 914 powered Europa on a hot day. Nifty application of fuel pump=0A restored the noise, but once safely back on the ground, I check ed=0A the filters (all clean). This aircraft was fitted with Europa=0A specified Purolator glass shrouded filters that allow you to see the=0A fuel flowing. At low RPM, the filter appeared full, but as power was=0A increased, the filter began to fill with what I thought was air. My=0A first action was to check the pipework and security of connections -=0A but everything seemed fine - it was definitely not drawing in air=0A fr om anywhere. I then concluded that I had experienced vapour lock=0A and left it at that.=0A=0ACuriosity got the better of me and I started research ing cavitation=0A and stumbled upon this very stilted, but interesting p resentation on=0A Youtube. Take a look at the first minute from 00.20 - in particular,=0A the glass venturi. This was exactly what I saw in the Purolator=0A filters.=0A=0Ahttp://www.youtube.com/watch?v=K_w3gcvA87I =0A=0AMy conclusion is that the Purolator filter has the correct mesh size =0A to trap contaminants, but the filter capacity is too small and=0A ======= ________________________________________________________________________________
Date: Oct 29, 2012
Nigel, Thanks for the link... Fascinating video. Kevin On Oct 29, 2012, at 5:01 AM, "nigel_graham@m-tecque.co.uk" wrote: > > On 31/07/2012 22:27, klinefelter.kevin(at)gmail.com wrote: >> >> Snip .... > .....I was chatting with Rob Seaton ( of Rotech in canada). He said he lea rned how too small a fuel line and/or tortured routing can cause "cavitation " at the pumps. So maybe your fuel filter(s), on the suction side of the pum p,are causing cavitation in the pump(s). Maybe due to the size (restriction o f flow) of the filter, even if they are clean. > ........ Snip > > Kevin, I think Rob Seaton may be on the money with this one. > A year or so back, I experienced a dead cut while flying a friend's 914 po wered Europa on a hot day. Nifty application of fuel pump restored the noise , but once safely back on the ground, I checked the filters (all clean). Thi s aircraft was fitted with Europa specified Purolator glass shrouded filters that allow you to see the fuel flowing. At low RPM, the filter appeared ful l, but as power was increased, the filter began to fill with what I thought w as air. My first action was to check the pipework and security of connection s - but everything seemed fine - it was definitely not drawing in air from a nywhere. I then concluded that I had experienced vapour lock and left it at t hat. > > Curiosity got the better of me and I started researching cavitation and st umbled upon this very stilted, but interesting presentation on Youtube. Take a look at the first minute from 00.20 - in particular, the glass venturi. T his was exactly what I saw in the Purolator filters. > > http://www.youtube.com/watch?v=K_w3gcvA87I > > My conclusion is that the Purolator filter has the correct mesh size to tr ap contaminants, but the filter capacity is too small and creates a pressure drop in the fuel line. > > Nigel ________________________________________________________________________________
Subject: Vapour lock? Why?
Date: Oct 29, 2012
I plumbed those in - following the book - but I see they are probably not the ideal. So what's the most common solution? Will From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 29 October 2012 05:29 Subject: Re: Europa-List: Vapour lock? Why? Nigel another problem with those filters is that sometimes they look clean but aren't because the contamination is translucent when wet with fuel; so, more restriction. You're right, they are too small. quite high fuel flow with a 914. Graham _____ From: "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk> Sent: Monday, 29 October 2012, 10:01 Subject: Re: Europa-List: Vapour lock? Why? On 31/07/2012 22:27, klinefelter.kevin(at)gmail.com wrote: Snip .... .....I was chatting with Rob Seaton ( of Rotech in canada). He said he learned how too small a fuel line and/or tortured routing can cause "cavitation" at the pumps. So maybe your fuel filter(s), on the suction side of the pump,are causing cavitation in the pump(s). Maybe due to the size (restriction of flow) of the filter, even if they are clean. ........ Snip Kevin, I think Rob Seaton may be on the money with this one. A year or so back, I experienced a dead cut while flying a friend's 914 powered Europa on a hot day. Nifty application of fuel pump restored the noise, but once safely back on the ground, I checked the filters (all clean). This aircraft was fitted with Europa specified Purolator glass shrouded filters that allow you to see the fuel flowing. At low RPM, the filter appeared full, but as power was increased, the filter began to fill with what I thought was air. My first action was to check the pipework and security of connections - but everything seemed fine - it was definitely not drawing in air from anywhere. I then concluded that I had experienced vapour lock and left it at that. Curiosity got the better of me and I started researching cavitation and stumbled upon this very stilted, but interesting presentation on Youtube. Take a look at the first minute from 00.20 - in particular, the glass venturi. This was exactly what I saw in the Purolator filters. http://www.youtube.com/watch?v=K_w3gcvA87I My conclusion is that the Purolator filter has the correct mesh size to trap contaminants, but the filter capacity is too small and creates a pressure drop in the fuel line. Nigel http://www.matro=================== ________________________________________________________________________________
Date: Oct 29, 2012
Best one is an Andair, not cheap though. The old Mini gascolator is too sma ll for a 914, GAS375 would be the one=0A=0AGraham=0A=0A=0A=0A______________ __________________=0A From: William Daniell <wdaniell.longport(at)gmail.com> =0ATo: europa-list(at)matronics.com =0ASent: Monday, 29 October 2012, 11:31=0A Subject: RE: Europa-List: Vapour lock? Why?=0A =0A=0AI plumbed those in =93 following the book =93 but I see they are probably not the ide al.=0ASo what=99s the most common solution?=0AWill=0A=C2-=0AFrom:ow ner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server@matro nics.com] On Behalf Of GRAHAM SINGLETON=0ASent: 29 October 2012 05:29=0ATo: europa-list(at)matronics.com=0ASubject: Re: Europa-List: Vapour lock? Why?=0A =C2-=0ANigel=0Aanother problem with those filters is that sometimes they look clean but aren't because the contamination is translucent when wet wit h fuel; so, more restriction.=C2-=0AYou're right, they are too small. qui te high fuel flow with a 914.=0AGraham=0A=C2-=0A=0A______________________ __________=0A=0AFrom:"nigel_graham@m-tecque.co.uk" =0ATo: europa-list(at)matronics.com =0ASent: Monday, 29 October 2012, 10: 01=0ASubject: Re: Europa-List: Vapour lock? Why?=0A=C2-=0A=C2-=0AOn 31/ 07/2012 22:27, klinefelter.kevin(at)gmail.com wrote:=0A--> Europa-List message posted by: klinefelter.kevin(at)gmail.com=0A>=C2-=0A>Snip ....=0A.....I was chatting with Rob Seaton ( of Rotech in canada). He said he learned how to o small a fuel line and/or tortured routing can cause "cavitation" at the p umps. So maybe your fuel filter(s), on the suction side of the pump,are cau sing cavitation in the pump(s). Maybe due to the size (restriction of flow) of the filter, even if they are clean.=0A........ Snip=0A=0AKevin, I think Rob Seaton may be on the money with this one.=C2- =0AA year or so back, I experienced a dead cut while flying a friend's 914 powered Europa on a ho t day. Nifty application of fuel pump restored the noise, but once safely b ack on the ground, I checked the filters (all clean). This aircraft was fit ted with Europa specified Purolator glass shrouded filters that allow you t o see the fuel flowing. At low RPM, the filter appeared full, but as power was increased, the filter began to fill with what I thought was air. My fir st action was to check the pipework and security of connections - but every thing seemed fine - it was definitely not drawing in air from anywhere. I t hen concluded that I had experienced vapour lock and left it at that.=0A=0A Curiosity got the better of me and I started researching cavitation and stu mbled upon this very stilted, but interesting presentation on Youtube. Take a look at the first minute from 00.20 - in particular, the glass venturi. This was exactly what I saw in the Purolator filters.=0A=0Ahttp://www.youtu be.com/watch?v=K_w3gcvA87I=0A=0AMy conclusion is that the Purolator filte r has the correct mesh size to trap contaminants, but the filter capacity i s too small and creates a pressure drop in the fuel line.=0A=0ANigel=0Ahttp ://www.matro=====================0A =C2-=0A=C2-=0A=C2-=0A=C2-=0Ahttp://www.matronics.com/Navigator?Euro pa-List=0Ahttp://forums.matronics.com=0Ahttp://www.matronics.com/contributi ================== ________________________________________________________________________________
Date: Oct 29, 2012
a second alternative: http://www.stevesaircraft.com/gascolator.php not cheap either tho. Cheers, Pete On Mon, Oct 29, 2012 at 8:40 AM, GRAHAM SINGLETON < grahamsingleton(at)btinternet.com> wrote: > Best one is an Andair, not cheap though. The old Mini gascolator is too > small for a 914, GAS375 would be the one > > Graham > > ------------------------------ > *From:* William Daniell > *To:* europa-list(at)matronics.com > *Sent:* Monday, 29 October 2012, 11:31 > *Subject:* RE: Europa-List: Vapour lock? Why? > > I plumbed those in ' following the book ' but I see they are probably not > the ideal. > So what=92s the most common solution? > Will > > *From:* owner-europa-list-server(at)matronics.com [mailto: > owner-europa-list-server(at)matronics.com] *On Behalf Of *GRAHAM SINGLETON > *Sent:* 29 October 2012 05:29 > *To:* europa-list(at)matronics.com > *Subject:* Re: Europa-List: Vapour lock? Why? > > Nigel > another problem with those filters is that sometimes they look clean but > aren't because the contamination is translucent when wet with fuel; so, > more restriction. > You're right, they are too small. quite high fuel flow with a 914. > Graham > > ------------------------------ > *From:* "nigel_graham@m-tecque.co.uk" > *To:* europa-list(at)matronics.com > *Sent:* Monday, 29 October 2012, 10:01 > *Subject:* Re: Europa-List: Vapour lock? Why? > > > On 31/07/2012 22:27, klinefelter.kevin(at)gmail.com wrote: > > > Snip .... > > *.....I was chatting with Rob Seaton ( of Rotech in canada). He said he > learned how too small a fuel line and/or tortured routing can cause > "cavitation" at the pumps. So maybe your fuel filter(s), on the suction > side of the pump,are causing cavitation in the pump(s). Maybe due to the > size (restriction of flow) of the filter, even if they are clean.* > *........ Snip* > > Kevin, I think Rob Seaton may be on the money with this one. > A year or so back, I experienced a dead cut while flying a friend's 914 > powered Europa on a hot day. Nifty application of fuel pump restored the > noise, but once safely back on the ground, I checked the filters (all > clean). This aircraft was fitted with Europa specified Purolator glass > shrouded filters that allow you to see the fuel flowing. At low RPM, the > filter appeared full, but as power was increased, the filter began to fil l > with what I thought was air. My first action was to check the pipework an d > security of connections - but everything seemed fine - it was definitely > not drawing in air from anywhere. I then concluded that I had experienced > vapour lock and left it at that. > > Curiosity got the better of me and I started researching cavitation and > stumbled upon this very stilted, but interesting presentation on Youtube. > Take a look at the first minute from 00.20 - in particular, the glass > venturi. This was exactly what I saw in the Purolator filters. > > http://www.youtube.com/watch?v=K_w3gcvA87I > > My conclusion is that the Purolator filter has the correct mesh size to > trap contaminants, but the filter capacity is too small and creates a > pressure drop in the fuel line. > > Nigel > > *http://www.matro================== ==* > > * * > > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Europa-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > *http://www.matronics.com/Navigator?Europa-L="nofollow" target="_blan k" href="http://www.matronics.com/contributi= > * > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Oct 29, 2012
I use two Mini Andair Gascolators one on each fuel line for my 914 and one was satisfactory when I had the early gas guzzling Jabiru 3300 and was the butt of all fuel dispensing pump sites. Regards to all. Bob Harrison G-PTAG From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 29 October 2012 12:40 Subject: Re: Europa-List: Vapour lock? Why? Best one is an Andair, not cheap though. The old Mini gascolator is too small for a 914, GAS375 would be the one Graham _____ From: William Daniell <wdaniell.longport(at)gmail.com> Sent: Monday, 29 October 2012, 11:31 Subject: RE: Europa-List: Vapour lock? Why? I plumbed those in =93 following the book =93 but I see they are probably not the ideal. So what=99s the most common solution? Will From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 29 October 2012 05:29 Subject: Re: Europa-List: Vapour lock? Why? Nigel another problem with those filters is that sometimes they look clean but aren't because the contamination is translucent when wet with fuel; so, more restriction. You're right, they are too small. quite high fuel flow with a 914. Graham _____ From: "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk> Sent: Monday, 29 October 2012, 10:01 Subject: Re: Europa-List: Vapour lock? Why? On 31/07/2012 22:27, klinefelter.kevin(at)gmail.com wrote: Snip .... .....I was chatting with Rob Seaton ( of Rotech in canada). He said he learned how too small a fuel line and/or tortured routing can cause "cavitation" at the pumps. So maybe your fuel filter(s), on the suction side of the pump,are causing cavitation in the pump(s). Maybe due to the size (restriction of flow) of the filter, even if they are clean. ........ Snip Kevin, I think Rob Seaton may be on the money with this one. A year or so back, I experienced a dead cut while flying a friend's 914 powered Europa on a hot day. Nifty application of fuel pump restored the noise, but once safely back on the ground, I checked the filters (all clean). This aircraft was fitted with Europa specified Purolator glass shrouded filters that allow you to see the fuel flowing. At low RPM, the filter appeared full, but as power was increased, the filter began to fill with what I thought was air. My first action was to check the pipework and security of connections - but everything seemed fine - it was definitely not drawing in air from anywhere. I then concluded that I had experienced vapour lock and left it at that. Curiosity got the better of me and I started researching cavitation and stumbled upon this very stilted, but interesting presentation on Youtube. Take a look at the first minute from 00.20 - in particular, the glass venturi. This was exactly what I saw in the Purolator filters. http://www.youtube.com/watch?v=K_w3gcvA87I My conclusion is that the Purolator filter has the correct mesh size to trap contaminants, but the filter capacity is too small and creates a pressure drop in the fuel line. Nigel http://www.matro =================== http://www.matronics.com/Navigator?Europa-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Europa-L= <http://www.matronics.com/Navigator?Europa-List> "nofollow" target="_blank" href="http://www.matronics.com/contributi= <http://www.matronics.com/Navigator?Europa-List> <http://www.matronics.com/Navigator?Europa-List> ________________________________________________________________________________
Date: Oct 29, 2012
Mmm yes thanks. It would seem to me that the two fuel lines offer an opportunity to insert redundancy in the fuel filters. Will From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bob Harrison Sent: 29 October 2012 08:20 Subject: RE: Europa-List: Vapour lock? Why? I use two Mini Andair Gascolators one on each fuel line for my 914 and one was satisfactory when I had the early gas guzzling Jabiru 3300 and was the butt of all fuel dispensing pump sites. Regards to all. Bob Harrison G-PTAG From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 29 October 2012 12:40 Subject: Re: Europa-List: Vapour lock? Why? Best one is an Andair, not cheap though. The old Mini gascolator is too small for a 914, GAS375 would be the one Graham _____ From: William Daniell <wdaniell.longport(at)gmail.com> Sent: Monday, 29 October 2012, 11:31 Subject: RE: Europa-List: Vapour lock? Why? I plumbed those in =93 following the book =93 but I see they are probably not the ideal. So what=99s the most common solution? Will From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 29 October 2012 05:29 Subject: Re: Europa-List: Vapour lock? Why? Nigel another problem with those filters is that sometimes they look clean but aren't because the contamination is translucent when wet with fuel; so, more restriction. You're right, they are too small. quite high fuel flow with a 914. Graham _____ From: "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk> Sent: Monday, 29 October 2012, 10:01 Subject: Re: Europa-List: Vapour lock? Why? On 31/07/2012 22:27, klinefelter.kevin(at)gmail.com wrote: Snip .... .....I was chatting with Rob Seaton ( of Rotech in canada). He said he learned how too small a fuel line and/or tortured routing can cause "cavitation" at the pumps. So maybe your fuel filter(s), on the suction side of the pump,are causing cavitation in the pump(s). Maybe due to the size (restriction of flow) of the filter, even if they are clean. ........ Snip Kevin, I think Rob Seaton may be on the money with this one. A year or so back, I experienced a dead cut while flying a friend's 914 powered Europa on a hot day. Nifty application of fuel pump restored the noise, but once safely back on the ground, I checked the filters (all clean). This aircraft was fitted with Europa specified Purolator glass shrouded filters that allow you to see the fuel flowing. At low RPM, the filter appeared full, but as power was increased, the filter began to fill with what I thought was air. My first action was to check the pipework and security of connections - but everything seemed fine - it was definitely not drawing in air from anywhere. I then concluded that I had experienced vapour lock and left it at that. Curiosity got the better of me and I started researching cavitation and stumbled upon this very stilted, but interesting presentation on Youtube. Take a look at the first minute from 00.20 - in particular, the glass venturi. This was exactly what I saw in the Purolator filters. http://www.youtube.com/watch?v=K_w3gcvA87I My conclusion is that the Purolator filter has the correct mesh size to trap contaminants, but the filter capacity is too small and creates a pressure drop in the fuel line. Nigel http://www.matro =================== http://www.matronics.com/Navigator?Europa-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Europa-L= <http://www.matronics.com/Navigator?Europa-List> "nofollow" target="_blank" href="http://www.matronics.com/contributi= <http://www.matronics.com/Navigator?Europa-List> http://www.matronics.com/Navigator?Europa-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Stabalator Flutter
Date: Oct 29, 2012
On Flutter, We dumb engineers really enjoy collecting testing video. The Comanche video and others were setups to determine failure modes. For instance, if you forget to hook up the trim tab or you have forgotten to check that the bushes are installed in the stab or trim rod, or the bearing in your Comanche has failed and you didn't note it on the trim tab preflight that it had 1/4 inch of play. We just had a twin Cessna (conventional stabilizer and elevator) here in Plant City that has severe cracking in its trim tab due to poor maintenance. The owner and inspector did not notice or think it a problem that the trim tab had play in it and upon investigation, the bearing in the trim rod had disengaged from the socket and the trim tab moved 1/4 inch on its own... Any control surface can flutter so it is best to note how much play is in the bearings, hinges, quick disconnects etc. in any aircraft that flies above 120 KIAS. Pay particular attention to those controls which are not balanced on a wing, or tail (Rudders are normally not balanced if near vertical in non aerobatic aircraft. Regards, Bud ----- Original Message ----- From: Alan Carter<mailto:alancarteresq(at)onetel.net> To: europa-list(at)matronics.com Sent: Sunday, October 21, 2012 11:35 AM Subject: Europa-List: Re: Stabalator Flutter > Wow Bud, that,s pretty scary stuff, have a lot of hours on Twin Coms. glad i knew nothing about flutter then, what happened to it in the video. Well i got the first bit right, slow down, but have not that brutal tail-plane you mention, only have a foam one!, and yes i do have a hang up on tail planes maybe its because i can,t see it. There have been some excellent ideas posted on MOD 73 . how to elimination play and wear in the Toque tube, and this question is just an extension of that topic, so hoping for some airman-ship replies also. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385727#385727 .matronics.com/viewtopic.php?p=385727#385727> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: Re: Working cabin heater
Date: Oct 29, 2012
Photo E-mail View slideshow | Download images Jacques, I have been building a similar cabin heater for about 6 years. It is fine until about -10 C. The duct has to be quite well sealed and since most of the heat comes from the oil cooler, if a thermostat is installed one cannot expect it to heat as much. In my experience my oil temps in winter run about 160F or 70C. The air out of the back side of the cooler is normally just under 100F or about 35C. N12AY is pretty tight and my air vents seal pretty well so little air rushes into the cockpit through the inspection holes and center tunnel as I have it all well sealed. Just the sun shine keeps me in winter clothes fairly comfortable. If I close off the oil cooler with a plate over it, that cuts the air flow too much. Unfortunately, I am in Florida, so it rarely gets super cold here. The the mono tends to be drafty through the tunnel and is asking too much from my little heater (basically the same as the Europa Club mod). My only suggestion for a constant high temp source is to pull the coolant from the engine using a similar hookup to the carb heat mod, and use a small oil cooler (or a simple 3/16 inch copper tube coil and fan in the cockpit to bring up the temp for bitter temps.) Where to put it becomes a real problem. I have not been a fan of pulling heat from a muff from the muffler or exhaust system as it is a Carbon Monoxide problem so I will not comment. Sorry I can't help any more. Regards, Bud ----- Original Message ----- From: ploucandco<mailto:jacques(at)platisource.com> To: europa-list(at)matronics.com Sent: Wednesday, October 24, 2012 7:01 PM Subject: Europa-List: Re: Working cabin heater > Thanks Ian. I saw this one as well. The goal is to get +15C in the cabin when the outside air is -20C. Do you or someone else have positive experience that this system will provide this +35C difference in temperature? Sorry to be difficult but I read a few times that such heater will work well when the engine is running hot. Mine is running cool in winter. Jacques Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=385943#385943 .matronics.com/viewtopic.php?p=385943#385943> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> These photos will be available on SkyDrive for 30 days. To learn more about SkyDrive, click here<http://g.msn.com/1cl91enus/PMFooter>. To share high quality pictures with your friends and family using MSN Photo E-mail, join MSN<http://g.msn.com/0PHenus1/29>. ________________________________________________________________________________
Subject: Rudder
Date: Oct 29, 2012
Just thought i'd ask if anyone has a rudder core that is not needed and not started for sale? Rather than repair mine id like to start again. I have vacuum bagged mine and bent the flange that the hinges bond too. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386227#386227 ________________________________________________________________________________
Date: Oct 29, 2012
Gents, I have not had the opportunity to have cavitation or problems with fuel vaporization on my or any of my 914 engine installations. I have had problems with the pumps pulling air from gascolators in the Europa. I do not install them for a number of reasons, primarily as the tank is lower than the gascolator (so the gascolator doesn't trap water, instead it only can trap large particles (which the tank screen should do), act as a filter), and should the seal be just a bit loose or broken, air is sucked into the fuel lines by the pump and in some cases the pump can not self prime. I have also had loose filters, and other things as below. The main problems I have seen are: The fuel fittings or selector valves which are too restrictive (less than 1/4 inch ID for the fuel). Avoid items of cheap quality (normally brass from China). The Purolator fuel filters are assembled too loose and suck air by the gasket when the pump is engaged. Note that under high flow rates over 10 GPH the Purolators do cavitate the fuel. Not so under normal operations. The fuel filter is assembled backwards by the owner. Gascolators installed of dubious quality/or maintained poorly, with wrench marks and dented cans from excessive force used to install or remove them. Once the seal is broken, one may not see a leak but prime is lost, especially at low fuel tank levels. Owner uses a unique fuel line installation which goes next to the muffler, then over the top of the engine to the carb on a 912S without any fire sleeve. Kinked fuel lines in the central tunnel unnoticed during the build. Auto filters using cheap paper which restrict fuel flow if wet. Test Test Test non aviation filters. Failure to install fire sleeve, instead they use thermosleeve which holds radiated heat away but has no insulation. Vaporization also is more common when the lines are routed so as to have a bend forming a high spot in line, in a hot area of the engine compartment. This is a problem in the tail dragger Europa as the highest spot in the fuel system is the top of the engine, so a vapor bubble from heat can form easily when attempting a hot start. The 914 has a noticeable return flow and the 912S has an orifice that allows modest flow and allows the vapor to bleed if the orifice is near the carbs and not really low in the return line at the tank. The new 912 fuel manifold seems to work well mounted up on the cross over tube in the trigear. Fuel pumps normally take care of any heat problems in the fuel as cool fuel flows quickly through the system. However if the engine is off, fuel may not flow enough to cool the lines in a 912S that are installed directly in contact with the top of the engine. The vapor then can build up in the high spot on top of the hot engine. With the carb bowls full of fuel, the cool fuel does not flow very fast past the orifice if it installed very low. Hence the need that the orifice on the return is high up to clear the vapor. Some suggestions are: If one is concerned about flow, two filters in parallel, properly installed, could solve filter clogging where poor fuel quality is common. Install 3/8 lines to slow the flow, but this means less room in tight spots and more connector step downs and more parts to buy. Make sure you are assembling the fuel system in accordance with acceptable methods and standards and or follow the Europa install manual to the letter. After all, it works, but it is the minimum necessary to do the job. Failure to allow for sufficient cooling air in the cowl over the carbs and fuel lines is a problem also, especially with the 912/912S. The 914 lines are at the rear and if clear of the exhaust and the fuel pump delivers proper flow, all is well. Stay away from ethanol laced gasoline as it vaporizes very well and kills seals. Be sure the fuel pump is of the proper size and type recommended as the system is designed for that pump. Hot start problems in the 914 can be irritating as the intake manifold is quite warm after shutdown, as are the fuel lines and carbs. The vapor in the carbs flows into the intake plenum and manifold and leaves a super rich charge in the plenum which will delay start. Many of us crank the engine with the fuel pump off or selector off until it hits, then turn the pump/selector on to keep it running. At higher altitudes and density altitude conditions, it is much worse. This is not a cavitation problem but pure vaporization of fuel in the intake of course. Glad to confuse the issue. Regards, Bud Yerly Tech Support ----- Original Message ----- From: William Daniell<mailto:wdaniell.longport(at)gmail.com> To: europa-list(at)matronics.com Sent: Monday, October 29, 2012 10:08 AM Subject: RE: Europa-List: Vapour lock? Why? Mmm yes thanks. It would seem to me that the two fuel lines offer an opportunity to insert redundancy in the fuel filters. Will From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bob Harrison Sent: 29 October 2012 08:20 To: europa-list(at)matronics.com Subject: RE: Europa-List: Vapour lock? Why? I use two Mini Andair Gascolators one on each fuel line for my 914 and one was satisfactory when I had the early gas guzzling Jabiru 3300 and was the butt of all fuel dispensing pump sites. Regards to all. Bob Harrison G-PTAG From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 29 October 2012 12:40 To: europa-list(at)matronics.com Subject: Re: Europa-List: Vapour lock? Why? Best one is an Andair, not cheap though. The old Mini gascolator is too small for a 914, GAS375 would be the one Graham ------------------------------------------------------------------------- ----- From: William Daniell > To: europa-list(at)matronics.com Sent: Monday, 29 October 2012, 11:31 Subject: RE: Europa-List: Vapour lock? Why? I plumbed those in =93 following the book =93 but I see they are probably not the ideal. So what=99s the most common solution? Will From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 29 October 2012 05:29 To: europa-list(at)matronics.com Subject: Re: Europa-List: Vapour lock? Why? Nigel another problem with those filters is that sometimes they look clean but aren't because the contamination is translucent when wet with fuel; so, more restriction. You're right, they are too small. quite high fuel flow with a 914. Graham ------------------------------------------------------------------------- ----- From: "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk> To: europa-list(at)matronics.com Sent: Monday, 29 October 2012, 10:01 Subject: Re: Europa-List: Vapour lock? Why? On 31/07/2012 22:27, klinefelter.kevin(at)gmail.com wrote: klinefelter.kevin(at)gmail.com Snip .... .....I was chatting with Rob Seaton ( of Rotech in canada). He said he learned how too small a fuel line and/or tortured routing can cause "cavitation" at the pumps. So maybe your fuel filter(s), on the suction side of the pump,are causing cavitation in the pump(s). Maybe due to the size (restriction of flow) of the filter, even if they are clean. ........ Snip Kevin, I think Rob Seaton may be on the money with this one. A year or so back, I experienced a dead cut while flying a friend's 914 powered Europa on a hot day. Nifty application of fuel pump restored the noise, but once safely back on the ground, I checked the filters (all clean). This aircraft was fitted with Europa specified Purolator glass shrouded filters that allow you to see the fuel flowing. At low RPM, the filter appeared full, but as power was increased, the filter began to fill with what I thought was air. My first action was to check the pipework and security of connections - but everything seemed fine - it was definitely not drawing in air from anywhere. I then concluded that I had experienced vapour lock and left it at that. Curiosity got the better of me and I started researching cavitation and stumbled upon this very stilted, but interesting presentation on Youtube. Take a look at the first minute from 00.20 - in particular, the glass venturi. This was exactly what I saw in the Purolator filters. http://www.youtube.com/watch?v=K_w3gcvA87I ?v=K_w3gcvA87I> My conclusion is that the Purolator filter has the correct mesh size to trap contaminants, but the filter capacity is too small and creates a pressure drop in the fuel line. Nigel http://www.matro>============= ====== http://www.matronics.com/Navigator?Europa-List avigator?Europa-List>http://forums.matronics.com com/>http://www.matronics.com/contribution ibution> http://www.matronics.com/Navigator?Europa-L="nofollow" target="_blank" href="http://www.matronics.com/contributi== <http://www.matronics.com/Navigator?Europa-List> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://forums.matronics.com> http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Europa-List< - MATRONICS WEB FORUMS -http://forums.matronics.comhttp://www.matronics.com/contribution http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: Re: Rudder
Date: Oct 29, 2012
Perhaps a few minutes with your cutoff wheel will correct your problem with a couple of layers of glass and some straight edges. Cheaper and frankly faster. Please send a photo direct to me. Bud Yerly Tech Support www.budyerly(at)msn.com ----- Original Message ----- From: spcialeffects<mailto:spcialeffects(at)aol.com> To: europa-list(at)matronics.com Sent: Monday, October 29, 2012 3:58 PM Subject: Europa-List: Rudder > Just thought i'd ask if anyone has a rudder core that is not needed and not started for sale? Rather than repair mine id like to start again. I have vacuum bagged mine and bent the flange that the hinges bond too. Thanks Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=386227#386227 .matronics.com/viewtopic.php?p=386227#386227> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Oct 29, 2012
From: Richard Wheelwright <rpwheelwright(at)yahoo.co.uk>
Subject: Re: Rudder
I have a rudder ready laid up with the hinges attached. It has a cutout for Grahams Rudder mod. But has the bottom corner missing. Can be fixed easily . ( I used it to fix my original) Contact me off list if you are interested =0A-=0A=0A=0A==================== =0A=0ARichard Wheelwright=0A=============== ======0A=0AFrom: spcialeffects <spcialeffects(at)aol.com>=0ATo: euro pa-list(at)matronics.com =0ASent: Monday, 29 October 2012, 19:58=0ASubject: Eu spcialeffects(at)aol.com>=0A=0AJust thought i'd ask if anyone has a rudder cor e that is not needed and not started for sale? Rather than repair mine id l ike to start again. I have vacuum bagged mine and bent the flange that the hinges bond too. Thanks=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahtt p://forums.matronics.com/viewtopic.php?p=386227#386227=0A=0A=0A=0A=0A=0A =============== ________________________________________________________________________________
Date: Oct 30, 2012
Subject: The Aero 2013 Friedrichshafen Europa Gathering #2 is approaching.
Hi Europa Flyers and Builders, The Aero 2013 Friedrichshafen Europa Gathering #2 is approaching very fast. This time we will have acceptable weather. That is for sure. You will find detailed information here:
http://aero2013.scassel.se It would be smashing if Europa flyers/builders from all parts of Europe could participate. Hope to see you at Friedrichshafen 2013. Best regards Stephan LN-STE ________________________________________________________________________________
Subject: Properties for sale near you, Investment Opportunity
Date: Oct 31, 2012
Hello, Kindly check out this new properties close to you, VIEW PROPERTIES for secu re access and more Information. Thanks ________________________________________________________________________________
Date: Nov 01, 2012
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's through solely through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts! Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include: Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you for your support! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Subject: Re: Fuel Return Line
Date: Nov 01, 2012
While trying to understand our recent 914 power problems, we talked to Rob Seaton at Rotech. He suggested we measure how much pressure is required to return the fuel to the tank (from regulator). Remove return hose from top of regulator, plug one side of banjo fitting and blow into other (dont ingest fuel!). it should be very easy (max is 1.5 PSI pressure loss with both pumps on: 914 installation manual sec 14.3) We found with the fuel tank full the pressure required was more than we could easily blow. With the tank half empty not much pressure was required. Our system is per Europa with the return at the bottom of the tank. Calculations show the pressure of the column of fuel in a full tank (15 inches of fuel) is about .4 psi which is certainly less than 1.5 psi. The Europa setup has worked OK for over 400 hours, but perhaps it would be better to return the fuel to the top of the tank. Opinions? Jim & Heather N241BW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386515#386515 ________________________________________________________________________________
Date: Nov 02, 2012
Subject: 912iS paper
(copied from RotaxEngines list) Those interested in the design of the 912iS may want to buy SAE paper nr 2012-32-0049. By 3 Rotax engineers and recently presented at an SAE conference. It costs $23 and can only be printed, during 24 hours, not saved. Some of the figures need to be printed separately to make some very small print readable (primitive but working procedure: zoom to maximise on screen, copy screen to clipboard, paste into picture viewer like Irfanview, crop in picture viewer and print/save). I found it interesting. A lot of questions were answered, quite a view remain. Jan de Jong ________________________________________________________________________________
Date: Nov 02, 2012
=0A=0AJim=0AI have always put the fuel return into the top of the tank, (I used a redesigned tank fitting that incorporated the breather connection (3 /8 aluminum)=0Afuel return and sight gauge return connection. Much less bac k pressure at the top of the tank and the (maybe hot from the engine driven pump)=0Athen mixes with the main bulk of the tank contents before going ba CK TO THE ENGINE. sorry kaps lok again!=0AGraham=0A=0A=0A__________________ ______________=0A From: "h&jeuropa" <butcher43(at)att.net>=0ATo: europa-list@m atronics.com =0ASent: Thursday, 1 November 2012, 19:45=0ASubject: Europa-Li uropa" =0A=0AWhile trying to understand our recent 914 p ower problems, we talked to Rob Seaton at Rotech.=C2- =0A=0AHe suggested we measure how much pressure is required to return the fuel to the tank (fr om regulator). Remove return hose from top of regulator, plug one side of b anjo fitting and blow into other (don=C3=A2=82=AC=84=A2t ingest fuel! ). it should be very easy (max is 1.5 PSI pressure loss with both pumps on: =0A 914 installation manual sec 14.3) =0A=0AWe found with the fuel tank ful l the pressure required was more than we could easily blow.=C2- With the tank half empty not much pressure was required.=C2- Our system is per Eur opa with the return at the bottom of the tank.=C2- Calculations show the pressure of the column of fuel in a full tank (15 inches of fuel) is about .4 psi which is certainly less than 1.5 psi. =0A=0AThe Europa setup has wor ked OK for over 400 hours, but perhaps it would be better to return the fue l to the top of the tank.=C2- Opinions?=0A=0AJim & Heather=0AN241BW=0A=0A =0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/view =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 ================== ________________________________________________________________________________
Date: Nov 02, 2012
Jim, I have my 914 fuel return set up as Graham describes, and no problems. I hav e never checked the return line pressure. What problem are you experiencing? Kevin On Nov 1, 2012, at 8:32 PM, GRAHAM SINGLETON wrote: > Jim > I have always put the fuel return into the top of the tank, (I used a rede signed tank fitting that incorporated the breather connection (3/8 aluminum) > fuel return and sight gauge return connection. Much less back pressure at t he top of the tank and the (maybe hot from the engine driven pump) > then mixes with the main bulk of the tank contents before going baCK TO TH E ENGINE. sorry kaps lok again! > Graham > > From: "h&jeuropa" <butcher43(at)att.net> > To: europa-list(at)matronics.com > Sent: Thursday, 1 November 2012, 19:45 > Subject: Europa-List: Re: Fuel Return Line > > > While trying to understand our recent 914 power problems, we talked to Rob Seaton at Rotech. > > He suggested we measure how much pressure is required to return the fuel t o the tank (from regulator). Remove return hose from top of regulator, plug o ne side of banjo fitting and blow into other (don=C3=A2=82=AC=84=A2t i ngest fuel!). it should be very easy (max is 1.5 PSI pressure loss with both pumps on: 914 installation manual sec 14.3) > > We found with the fuel tank full the pressure required was more than we co uld easily blow. With the tank half empty not much pressure was required. O ur system is per Europa with the return at the bottom of the tank. Calculat ions show the pressure of the column of fuel in a full tank (15 inches of fu el) is about .4 psi which is certainly less than 1.5 psi. > > The Europa setup has worked OK for over 400 hours, but perhaps it would be better to return the fuel to the top of the tank. Opinions? > > Jim & Heather > N241BW > > > > > Read this topic online here: > > http://forums.matronicsease Support ref="http://www.matronics.com/contri bution">http://www.matronics.com/contbsp; -Matt Dralle, List Adm in. --> http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronic s.com > _============= > > > > > > ________________________________________________________________________________
From: Christoph Both <christoph.both(at)acadiau.ca>
Subject: Re: 912iS paper
Date: Nov 02, 2012
Any one out there having obtained the paper and willing to share it with th e EUROPA group? Christoph Both Wolfville Nova Scotia Canada EUROPA #223 From: Jan de Jong <jan_de_jong(at)casema.nl<mailto:jan_de_jong(at)casema.nl>> ropa-list(at)matronics.com> Date: Thursday, 1 November, 2012 8:54 PM ist(at)matronics.com> Subject: Europa-List: 912iS paper (copied from RotaxEngines list) Those interested in the design of the 912iS may want to buy SAE paper nr 20 12-32-0049. By 3 Rotax engineers and recently presented at an SAE conference. It costs $23 and can only be printed, during 24 hours, not saved. Some of the figures need to be printed separately to make some very small p rint readable (primitive but working procedure: zoom to maximise on screen, copy screen to clipboard, paste into picture viewer like Irfanview, crop i n picture viewer and print/save). I found it interesting. A lot of questions were answered, quite a view rema in. Jan de Jong rsbooks.com> m> ________________________________________________________________________________
Date: Nov 02, 2012
I would expect return pressure to depend on the height to which it is pushed , ie the height of the surface or opening. Exit to top of tank will provide equal (in average higher) back pressure tha n if return is at the bottom, all other parameters being equal... Alex, kit 529 Enviado via iPhone Em 01/11/2012, =C3-s 23:32, GRAHAM SINGLETON escreveu: > Jim > I have always put the fuel return into the top of the tank, (I used a rede signed tank fitting that incorporated the breather connection (3/8 aluminum) > fuel return and sight gauge return connection. Much less back pressure at t he top of the tank and the (maybe hot from the engine driven pump) > then mixes with the main bulk of the tank contents before going baCK TO TH E ENGINE. sorry kaps lok again! > Graham > > From: "h&jeuropa" <butcher43(at)att.net> > To: europa-list(at)matronics.com > Sent: Thursday, 1 November 2012, 19:45 > Subject: Europa-List: Re: Fuel Return Line > > > While trying to understand our recent 914 power problems, we talked to Rob Seaton at Rotech. > > He suggested we measure how much pressure is required to return the fuel t o the tank (from regulator). Remove return hose from top of regulator, plug o ne side of banjo fitting and blow into other (don=C3=A2=82=AC=84=A2t i ngest fuel!). it should be very easy (max is 1.5 PSI pressure loss with bot h pumps on: 914 installation manual sec 14.3) > > We found with the fuel tank full the pressure required was more than we co uld easily blow. With the tank half empty not much pressure was required. O ur system is per Europa with the return at the bottom of the tank. Calculat ions show the pressure of the column of fuel in a full tank (15 inches of fu el) is about .4 psi which is certainly less than 1.5 psi. > > The Europa setup has worked OK for over 400 hours, but perhaps it would be better to return the fuel to the top of the tank. Opinions? > > Jim & Heather > N241BW > > > > > Read this topic online here: > > http://forums.matronicsease Support ref="http://www.matronics.com/contri bution">http://www.matronics.com/contbsp; -Matt Dralle, List Adm in. --> http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronic s.com > _============= > > > > > > ________________________________________________________________________________
Subject: Re: [Spam] Re: Fuel Return Line
Date: Nov 03, 2012
Alex, In my opinion it depends on what fluid you are returning. You are right if 100 per cent liquid fuel is returned. Now if 100 percent vapor is returned, returning to the top of the fuel tank will significantly reduce the back pressure. Because one of the most important function of the return line is to allow vapor to escape the fuel system, therefore preventing potential vapor lock, I believe returning to the top of the tank is a better option. Remi Guerner > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386581#386581 ________________________________________________________________________________
Date: Nov 03, 2012
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2012
Remi, I am not disputing whether or not one or the other location is best, it was only to state a fact of physics. And then I wonder if a varying pressure in the return line can affect things like mixture control? Air bubbles I would expect to be rare if not non existent, provided return flow is sufficient. Alex, kit 529 Enviado via iPhone Em 03/11/2012, s 08:36, "Remi Guerner" escreveu: > > Alex, > In my opinion it depends on what fluid you are returning. You are right if 100 per cent liquid fuel is returned. Now if 100 percent vapor is returned, returning to the top of the fuel tank will significantly reduce the back pressure. Because one of the most important function of the return line is to allow vapor to escape the fuel system, therefore preventing potential vapor lock, I believe returning to the top of the tank is a better option. > Remi Guerner > > >> > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=386581#386581 > > > > > > > > > > > ________________________________________________________________________________
From: "Duncan & Ami" <ami-mcfadyean(at)talktalk.net>
Subject: Re: Reserve Fuel
Date: Nov 04, 2012
<<..But it worth checking that the fuel return is happening.>> Yes, that should be on the annual checklist. Alternately, if you have a fuel pressure sensor fitted the action of the return can be checked at every shut down, by watching fuel pressure return quickly back to zero. Without the return, the pressure would be locked-in to the fuel lines (unless the fuel pump valve and/or float valves leak!). Duncan McF. -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of roddyeuropa(at)aol.com Sent: 25 October 2012 09:55 Subject: Re: Europa-List: Re: Reserve Fuel Hi Alan I'd add a couple of things - you have the fuel drain mod installed which is good. But be aware that you need to drain more fuel than a normal fuel drain to clear the fuel in the lines between the drain and the tank. I drain about 'half jam jar' each side. Also, the fuel return from the engine should be feeding into the reserves side so it should refresh the fuel. But if fueling the plane doesn't get to the bottom of the tank to stir things up, the return flow certainly won't. But it worth checking that the fuel return is happening. Regards Roddy Kesterton G-IKRK -----Original Message----- From: Alan Carter <alancarteresq(at)onetel.net> Sent: Thu, 25 Oct 2012 8:56 Subject: Europa-List: Re: Reserve Fuel Hi Tim. NZ a beautiful county i had a holiday there. I have done my time on Chipmunks, My Europa is a Mono to Tri Conversion so maybe better! well a lot easier. The Fuel/Tables were done with the aircraft just in its level position on level ground, a couple of litres either way i am not bothering about as if i was down to 15 litres i would be quit worried. Glad you use the reserve fuel, just my choice taxing in on reserve, I like your idea of the extended lever, is it guarded or recessed, can you give some more on how to do it. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385966#385966 arget=_blank>http://www.matronics.com/Navigator?Europa-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: [Spam] [Spam] Re: Fuel Return Line
Date: Nov 04, 2012
Alex, Varying pressure in the return line may affect the fuel pressure to the carbs, but as long as this fuel pressure stays within the limits specified by Rotax, it should not affect the mixture. Remi Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386716#386716 ________________________________________________________________________________
Date: Nov 04, 2012
Jim, Never had a problem with return pressure as rigged. The Rotax manual says it is supposed to be a minimum of back pressure as you indicated. If you restrict the return pressure, you actually overpressurize the fuel system. Those with gauges that read raw fuel pressure can test this easily, by just clamping the return line just slightly with the engine off and not the rapid rise in pressure. You are very wise to note that the column pressure is only about 1/2 psi. in the full tank. I cannot blow more than 1.5 PSI when checking against my fuel direct reading manual gauge. Check for kinks and plugged vents also. Off until Friday. Hope you find out what the matter is. It must be something simple, as it is hard to find. Regards Bud Yerly ----- Original Message ----- From: h&jeuropa<mailto:butcher43(at)att.net> To: europa-list(at)matronics.com Sent: Thursday, November 01, 2012 2:45 PM Subject: Europa-List: Re: Fuel Return Line > While trying to understand our recent 914 power problems, we talked to Rob Seaton at Rotech. He suggested we measure how much pressure is required to return the fuel to the tank (from regulator). Remove return hose from top of regulator, plug one side of banjo fitting and blow into other (don?Tt ingest fuel!). it should be very easy (max is 1.5 PSI pressure loss with both pumps on: 914 installation manual sec 14.3) We found with the fuel tank full the pressure required was more than we could easily blow. With the tank half empty not much pressure was required. Our system is per Europa with the return at the bottom of the tank. Calculations show the pressure of the column of fuel in a full tank (15 inches of fuel) is about .4 psi which is certainly less than 1.5 psi. The Europa setup has worked OK for over 400 hours, but perhaps it would be better to return the fuel to the top of the tank. Opinions? Jim & Heather N241BW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386515#386515 .matronics.com/viewtopic.php?p=386515#386515> www.aeroelectric.com<http://www.aeroelectric.com/> www.buildersbooks.com<http://www.buildersbooks.com/> www.homebuilthelp.com<http://www.homebuilthelp.com/> http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> ________________________________________________________________________________
Date: Nov 05, 2012
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Make sure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site:
http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Sun Shades
Date: Nov 05, 2012
In the summer the big canopy of the Europa really works as a greenhouse. Until now we have used sunshades purchased at Target and intended to reduce the heat in a car but they are not a convenient size or shape and the suction cups don't work well. At Rough River Troy & Donna Maynor had Aero Shield sun shades fitted to their Europa. We purchased a pair prior to our recent trip to Arizona. Boy are they great! They provide good shade, the suction cups work well and are easy to release and the size is big enough to reduce the heat but small enough that we could position the shade where it was most effective, even on the front windscreen to block the sun in our eyes. We purchased 9" x 16" Aero Shields, Aircraft Spruce Part Number 13-09664. The ones Troy and Donna have are the same width but longer. Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386891#386891 ________________________________________________________________________________
Date: Nov 05, 2012
Subject: Fuel hose size spec with FloScan / 912
We are taking advantage of extended down-time to swap out, and fire-sleeve, all the forward fuel hose per 5 year recommendation. I need to check that we have the correct hose size spec' as I cannot locate the latest published layout on-line. As we found it, 8mm ID hose runs to the mechanical pump then back to the FloScan and downstream of it to the first (s/b) Carb Tee. Beyond that, 6mm hose. We have build and update paperwork to show this spec. However, offering up 8mm hose to the pump outlet fitting it is a worryingly loose fit until the clamp is tightened. Are we happy with this? Glenn Rainey / Martin Burns Classic 912 M/W Cumbernauld EGPG ________________________________________________________________________________
Subject: Sun Shades
Date: Nov 05, 2012
Jim=2C I just wanted to thank you for giving details about the sunshades. I have t rouble reading the awful LCD displays in bright sunlight=2C especially the Garmin GPS. And for giving details about the product source.We often get re ports about wonderful mods but no information whatsoever about how we might incorporate them ourselves. Karl > Subject: Europa-List: Sun Shades > From: butcher43(at)att.net > Date: Mon=2C 5 Nov 2012 05:53:58 -0800 > To: europa-list(at)matronics.com > > > In the summer the big canopy of the Europa really works as a greenhouse. Until now we have used sunshades purchased at Target and intended to reduc e the heat in a car but they are not a convenient size or shape and the suc tion cups don't work well. At Rough River Troy & Donna Maynor had Aero Shi eld sun shades fitted to their Europa. We purchased a pair prior to our re cent trip to Arizona. Boy are they great! They provide good shade=2C the suction cups work well and are easy to release and the size is big enough to reduce the heat but small enough that we could position the shade where it was most effective=2C even on the front windscreen to block the sun in o ur eyes. > > We purchased 9" x 16" Aero Shields=2C Aircraft Spruce Part Number 13-0966 4. The ones Troy and Donna have are the same width but longer. > > Jim & Heather > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=386891#386891 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Nov 06, 2012
Subject: A Message From AeroElectric's Bob Nuckolls...
Dear Listers, The well known Bob Nuckolls of the AeroElectric posted a great message Monday on the AeroElectric-List regarding the Matronics Lists and the importance of supporting the operation during the Fund Raiser. Please take a minute to read Bob's commentary below, reposted to the other Matronics Lists with his permission... Date: Mon, 05 Nov 2012 08:58:41 -0600 From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: Re: Please Make A Contribution Today! At 02:14 AM 11/5/2012, Matt Dralle wrote: > > Each year at the end of the List Fund Raiser, I post a message > acknowledging everyone that so generously made a Contribution to > support the Lists. Its my way of publicly thanking everyone that > took a minute to show their appreciation for the Lists. > I will add my voice to this suggestion. It's easy to enjoy the benefits of what's available to us off-the-shelves at the corner mega-marts. It's seldom that we give pause to learn and understand the processes and tools that made it possible to reach out and select from dozens of options. This, and all civil societies, runs on talent, energy and mobility. Mobility exploited by thousands of hands, machines and transportation that figure into the 'infrastructure' that puts the boxes of Wheaties and Pop Tarts on the shelves. See "I pencil" http://tinyurl.com/36xkhq Any break in that chain of time, talent and resources at least interrupts if not totally halts flow of that benefit. Matt's room full of byte-thrashers is like the natural gas pumping station a few miles from my house. If those pumps stop, who ever is expecting the furnace to come on at the other end of the pipe is at risk for reduced service and/or higher costs for that service. Matt's yearly endeavor to keep his pumps running is a trivial burden on the members of the Lists but of incalculable value to those who participate on them. No donation is too small. We go to a fly-in a willingly chuck a few bucks into the coffee can at the drinks and donuts table, let's chuck a few bucks into Matt's coffee can too. 50,000 pounds of value doesn't get to the shelves on time if one 18-wheeler runs out of gas. The T-bytes of data flow we all enjoy don't get from your keyboard to the screens of others unless Matt pays the light bill and strokes the machines to keep them happy. No, $5 won't get you a free copy of the 'Connection or a fuel sampler but it will go toward the assurance that logging onto your favorite List will open doors that you would be sorely missed should you find that hitting the return key doesn't produce the expected response. $5 from every List customer on Matt's system will go a very long way to keeping the byte-pumps running. $More$ will go a long way to upgrading the size and quality of the machines as the old ones get long in the tooth. No matter what size of donation you choose . . . please do it now . . . Bob . . . Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Mod 73
Date: Nov 06, 2012
Hello All No flutter here, just had to post this, amazing little aeroplane same combat bomb payload as B17. and basically a home build by many. hope you like it, alan http://www.youtube.com/watch?v=rGfQQWOsoB8&feature=player_embedded Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387128#387128 ________________________________________________________________________________
Date: Nov 08, 2012
Subject: Make A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 08, 2012
Subject: Mod parts availability
I am in the process of possibly acquiring a Europa Classic kit that is about 60% complete. The original builder purchased the kit in 1997 and stopped working on it in 2007 due to health reasons. In reference to the Mandatory Mods, if one isn't completed, are the parts still available and in stock at the factory? For example, mandatory Mod 74 (rear wing pin update) has not been completed, nor has the original pin been installed, and I just wanted to make sure that I could still get the necessary parts to accomplish the mod. The website shows a price for Mod 52 (gross weight increase) which includes Mod 74, but again is it in stock and available? Also, for the same reasons, I am concerned about parts availability for Mod 70 (mass balance arm). I sent an e-mail to the factory two days ago to the enquiries@europa-aircraft.com, but received no response. I also tried calling our USA representative, but no luck so far. So, I thought I would inquire to this group of esteemed buillders/owners on Matronics. Thank you in advance. TJ USA ________________________________________________________________________________
Subject: Re: Sun Shades
Date: Nov 08, 2012
Hi All, Here is a link to the products we're talking about, in addition to Aircraft Spruce. I think the ones we have are 9 or 10 x 22 inches long. I'll check next time at the airport. I am sorry Jim and Heather I didn't tell you sooner but I think you ordered as soon as you got home. The website leaves a lot to be desired as far as pictures. And I didn't know it was called Pilot Armour also. Study closely or call them and tell them what you want. I got the copper colored stuff that you use in flight, not the thick silver stuff you use while you're parked. Troy http://www.aero-shields.com/index.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387333#387333 ________________________________________________________________________________
Subject: Re: Questions from Rough River
Date: Nov 08, 2012
Hi All, Here is some follow up information that I will pass along for those of you interested. The sun screens are "Aero Shields or Pilot Armour. Same company? Mine are 9 or 10 inches by 22 inches. Here's a link: http://www.aero-shields.com/index.html The weather stripping I used, which allows the doors to shut much easier but seal very well, is purchased at McMaster-Carr and the catalog number is: 12335A44. Hope this helps. Troy Maynor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387334#387334 ________________________________________________________________________________
Subject: Question for 914 users
Date: Nov 09, 2012
At what stage during the takeoff roll do you see full boost please? Another way of putting it ....... How long after the throttle is at 115% do you see full boost? Thanks in anticipation Kingsley ________________________________________________________________________________
Date: Nov 09, 2012
Subject: Re: Question for 914 users
Kingsley, I will time it in the morning and tell you. Cheers XSMono 914 Airmaster 1020hrs Sue and Bill Sisley On 9/11/2012 5:20 p.m., Kingsley Hurst wrote: > > At what stage during the takeoff roll do you see full boost please? > > Another way of putting it ....... How long after the throttle is at 115% do you see full boost? > > Thanks in anticipation > > Kingsley > > ________________________________________________________________________________
Date: Nov 10, 2012
Kingsley Hurst a crit : > > At what stage during the takeoff roll do you see full boost please? > > Another way of putting it ....... How long after the throttle is at 115% do you see full boost? > > Hi Kingsley, I'd say about 2 to 3 seconds. We do not bang the throttle, but rather advance it steadily in 2 seconds. Takeoff takes place in about 10 seconds. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Nov 10, 2012
Kingsley, Two New Zealand 914 drivers checked this for you today and we both got the same result at 5 seconds. Regards from across the Tasman. Bill MonoXS 914 Airmaster. Sue and Bill Sisley On 10/11/2012 3:38 p.m., Gilles Thesee wrote: > <Gilles.Thesee@ac-grenoble.fr> > > Kingsley Hurst a crit : >> >> >> At what stage during the takeoff roll do you see full boost please? >> >> Another way of putting it ....... How long after the throttle is at >> 115% do you see full boost? >> > > Hi Kingsley, > > I'd say about 2 to 3 seconds. We do not bang the throttle, but rather > advance it steadily in 2 seconds. > Takeoff takes place in about 10 seconds. > > Best regards, ________________________________________________________________________________
Date: Nov 10, 2012
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 10, 2012
Bob, Gilles and Bill Many thanks for your respective inputs. On takeoff I sometimes don't see full boost until I'm well and truly airborne. (Not that I watch it every time). I have always suspected that the boost on our aircraft has been a bit slow to rise. The waste gate cycles freely, I see 34" MAP at 100% throttle position, I'm getting 5700 RPM on less than full boost and the turbo spins freely. Now that you have answered my question and I know what to expect, I shall read up on the manual. If anybody has any ideas what can cause this I am receptive to any suggestions. Thanks again fellows. Kingsley ________________________________________________________________________________
Subject: tri-gear trailer
Date: Nov 10, 2012
hi has any one have a tri-gear trailer is could hire-borrow.I wish to move my tri-gear from thruxton EGHO to my unit in andover thanks jim davis -------- owner g-fizy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387499#387499 ________________________________________________________________________________
Subject: Mono Wheel Inner Tube
Date: Nov 10, 2012
Good news for US monowheel owners. The inner tube with a 90 degree valve stem has been difficult to locate - Wicks Aircraft Supply has had a Chinese tube available for awhile but no tire. Desser Tire (www.desser.com) now has a suitable tube available as well as tires. The part number for the tube is TU 700/800-6 AM and the part number for a Airhawk tire is 700-6 6 PLY AH. The tube appears to be high quality. Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387503#387503 ________________________________________________________________________________
Subject: Re: Mod parts availability
Date: Nov 10, 2012
I would like to thank everyone that responded. Europa Factory did e-mail an d indicate parts availability. Bud Yerly, from Custom Flight Creations, con tacted me and gave me a lot of great info. Ian Rickard, from Club Europa, a lso e-mailed and gave great info. Thank you to all. On Nov 8, 2012, at 8:57 AM, Tyler J wrote: > I am in the process of possibly acquiring a Europa Classic kit that is abo ut 60% complete. The original builder purchased the kit in 1997 and stopped working on it in 2007 due to health reasons. In reference to the Mandatory Mods, if one isn't completed, are the parts still available and in stock at the factory? For example, mandatory Mod 74 (rear wing pin update) has not b een completed, nor has the original pin been installed, and I just wanted to make sure that I could still get the necessary parts to accomplish the mod. The website shows a price for Mod 52 (gross weight increase) which include s Mod 74, but again is it in stock and available? Also, for the same reason s, I am concerned about parts availability for Mod 70 (mass balance arm). > > I sent an e-mail to the factory two days ago to the enquiries@europa-aircr aft.com, but received no response. I also tried calling our USA representat ive, but no luck so far. So, I thought I would inquire to this group of est eemed buillders/owners on Matronics. Thank you in advance. > > TJ > USA > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Nov 12, 2012
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some pointd, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 22 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2012
Kingsley, It seems your wastegate takes more time than normal to move to its position. This may be caused by some undesirable friction in the system. I would first investigate this possible cause. I suggest you disconnect the waste gate bowden cable at both ends and pull it back and forth. Move the waste gate lever back and forth. Both should move easily. If they dont, some cleaning and lubrication should solve the problem. Please let us know your findings. Good luck. Remi Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387667#387667 ________________________________________________________________________________
Date: Nov 12, 2012
As the other New Zealand 914 user that Bill refers to I add a little advice that may help. You state you are only seeing 34 ins, that is what you get when the TCU is not working. How do I know, I took off the other day with the TCU switched off and noted that I only pulled about 33 in manifold but was still getting full rpm, 5780 in my case. This makes sense and though I do not suggest taking off with the TCU switched off it can be tried and would be a good pointer to see if your TCU is working. That is apart from the usual checks to see if the servo is cycling. Cheers Peter -------- Peter Armstrong Auckland, New Zealand DynAero MCR-4S (Do not shoot me :) ). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387706#387706 ________________________________________________________________________________
Date: Nov 13, 2012
Peter, I eventually get 38" at 115% throttle setting. I get 34" at 100% throttle on the climb and it maintains 34" to 12,000 ft so I assume the TCU must be working. The TCU cycles perfectly on turn on. Having said that, I can certainly try a T/O with the TCU turned off to observe what happens. I need to have a fly behind another 914 in case my problem is only imaginary. Thank you for your help. Kingsley Sent from my iPhone On 13/11/2012, at 6:30 AM, "pestar" wrote: > > As the other New Zealand 914 user that Bill refers to I add a little advice that may help. > > You state you are only seeing 34 ins, that is what you get when the TCU is not working. How do I know, I took off the other day with the TCU switched off and noted that I only pulled about 33 in manifold but was still getting full rpm, 5780 in my case. > > This makes sense and though I do not suggest taking off with the TCU switched off it can be tried and would be a good pointer to see if your TCU is working. That is apart from the usual checks to see if the servo is cycling. > > Cheers Peter > > -------- > Peter Armstrong > Auckland, New Zealand > DynAero MCR-4S (Do not shoot me :) ). > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=387706#387706 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2012
Remi, Observing the waste gate lever and cable during the TCU test, it all appears to be nice and free. Notwithstanding, I shall check the cable as you describe. Thank you for taking the time to assist. Kingsley Sent from my iPhone On 12/11/2012, at 6:34 PM, "Remi Guerner" wrote: > > Kingsley, > It seems your wastegate takes more time than normal to move to its position. This may be caused by some undesirable friction in the system. I would first investigate this possible cause. I suggest you disconnect the waste gate bowden cable at both ends and pull it back and forth. Move the waste gate lever back and forth. Both should move easily. If they dont, some cleaning and lubrication should solve the problem. > Please let us know your findings. Good luck. > Remi > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=387667#387667 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 12, 2012
Not sure how you got 33 ins MP without turbo boost. Nominal ambient pressure at sea level is 29.92 ins. You need turbo boost to achieve something higher. Garry Stout -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of pestar Sent: Monday, November 12, 2012 3:31 PM Subject: Europa-List: Re: Question for 914 users As the other New Zealand 914 user that Bill refers to I add a little advice that may help. You state you are only seeing 34 ins, that is what you get when the TCU is not working. How do I know, I took off the other day with the TCU switched off and noted that I only pulled about 33 in manifold but was still getting full rpm, 5780 in my case. This makes sense and though I do not suggest taking off with the TCU switched off it can be tried and would be a good pointer to see if your TCU is working. That is apart from the usual checks to see if the servo is cycling. Cheers Peter -------- Peter Armstrong Auckland, New Zealand DynAero MCR-4S (Do not shoot me :) ). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387706#387706 ________________________________________________________________________________
Date: Nov 12, 2012
It is because I live in the Southern Hemisphere and do not get impacted by Northern Hemisphere FUD. (':D') Seriously I questioned that as well as what you say is correct however that is what my manifold pressure was reading on my EFIS. Cheers Peter -------- Peter Armstrong Auckland, New Zealand DynAero MCR-4S (Do not shoot me :) ). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387738#387738 ________________________________________________________________________________
Date: Nov 13, 2012
Gary, On the 914, even with the waste gate fully open, not all of the exhaust gas bypasses the turbo hence there is still some boost. According to the manual, with a fully open waste gate, the engine will produce 70 Kw (approx 93 HP) instead of the 80 HP the same engine would produce if the turbo charger was removed. Regards Kingsley Sent from my iPhone On 13/11/2012, at 10:28 AM, "Garry Stout" wrote: > > Not sure how you got 33 ins MP without turbo boost. Nominal ambient > pressure at sea level is 29.92 ins. You need turbo boost to achieve > something higher. > > Garry Stout > > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of pestar > Sent: Monday, November 12, 2012 3:31 PM > To: europa-list(at)matronics.com > Subject: Europa-List: Re: Question for 914 users > > > As the other New Zealand 914 user that Bill refers to I add a little advice > that may help. > > You state you are only seeing 34 ins, that is what you get when the TCU is > not working. How do I know, I took off the other day with the TCU switched > off and noted that I only pulled about 33 in manifold but was still getting > full rpm, 5780 in my case. > > This makes sense and though I do not suggest taking off with the TCU > switched off it can be tried and would be a good pointer to see if your TCU > is working. That is apart from the usual checks to see if the servo is > cycling. > > Cheers Peter > > -------- > Peter Armstrong > Auckland, New Zealand > DynAero MCR-4S (Do not shoot me :) ). > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=387706#387706 > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2012
*Warning* Do not attempt to take off with the TCU disabled. If the wastegate is fully closed when the TCU is powered down you will end up over boosting your engine with the possibility of twisting a crankshaft or burning a piston kingsnjan(at)westnet.com. wrote: > Peter, > > Having said that, I can certainly try a T/O with the TCU turned off to observe what happens. > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387748#387748 ________________________________________________________________________________
Date: Nov 13, 2012
Conrad, Thank you very much for the sage advice. Just thinking....... I don't really need to know what happens! Cheers Kingsley Sent from my iPhone On 13/11/2012, at 6:32 PM, "conrad" wrote: > > *Warning* > Do not attempt to take off with the TCU disabled. If the wastegate is fully closed when the TCU is powered down you will end up over boosting your engine with the possibility of twisting a crankshaft or burning a piston > > > > kingsnjan(at)westnet.com. wrote: >> Peter, >> >> Having said that, I can certainly try a T/O with the TCU turned off to observe what happens. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=387748#387748 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2012
Kingsley Hurst a crit : > > Conrad, > > Thank you very much for the sage advice. Just thinking....... I don't really need to know what happens! > Kingsley, Just to make sure. Have you checked that the throttle cables do respond correctly to the throttle lever movements ? IIRC, there have been some instances of cables buckling instead of sliding in their outer cases when one relies only on springs to open the butterflies in the carburettors. To prevent this situation, our airplanes are equipped with solid piano wire 'cables' providing some push-pull action. The carb springs are just there for peace of mind. FWIW, Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Subject: rotax Tacho verses digital
Date: Nov 13, 2012
Interesting that compared to my new digital tacho that controls the VP prop, the rotax tacho over-reads by around 150rpm. Id trust the digital rather than the needle but I wondered if anyone else has found the same? while mentioning needles - my flight sunday took me past a couple. -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387771#387771 Attachments: http://forums.matronics.com//files/dsc01045neddles_iow_196.jpg ________________________________________________________________________________
Subject: Re: rotax Tacho verses digital
Date: Nov 13, 2012
Graeme, Beautiful picture! Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Nov 13, 2012, at 1:05 PM, graeme bird wrote: Interesting that compared to my new digital tacho that controls the VP prop, the rotax tacho over-reads by around 150rpm. Id trust the digital rather than the needle but I wondered if anyone else has found the same? while mentioning needles - my flight sunday took me past a couple. -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387771#387771 Attachments: http://forums.matronics.com//files/dsc01045neddles_iow_196.jpg ________________________________________________________________________________
Date: Nov 13, 2012
Hi Graeme Has the Rotax tacho been calibrated? If not they are often inaccurate. Mine certainly was. Regards Pete -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of graeme bird Sent: 13 November 2012 19:05 Subject: Europa-List: rotax Tacho verses digital Interesting that compared to my new digital tacho that controls the VP prop, the rotax tacho over-reads by around 150rpm. Id trust the digital rather than the needle but I wondered if anyone else has found the same? while mentioning needles - my flight sunday took me past a couple. -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387771#387771 Attachments: http://forums.matronics.com//files/dsc01045neddles_iow_196.jpg -- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean. ________________________________________________________________________________
Date: Nov 13, 2012
On 11/13/2012 08:05 PM, graeme bird wrote: > Interesting that compared to my new digital tacho that controls the > VP prop, the rotax tacho over-reads by around 150rpm. Id trust the > digital rather than the needle but I wondered if anyone else has > found the same? As far as I know it can be somewhat tricky to connect two tacho's at the same time. It is a weird interface, nor digital nor analogue. You can't trust either of them. If you really want to know, you'd better check the rpm against a seperate rev counter on the prop and recalculate this to engine RPM and see if it matches with any of your gauges. > while mentioning needles - my flight sunday took me past a couple. Very nice! I presume this was in the UK? Is this near land's end? Frans ________________________________________________________________________________
Date: Nov 13, 2012
Hi, The Rotax tacho really cannot be trusted. Many years ago, one of my customers told me that when he fitted a CSC-1/P constant speed controller, it showed 600 RPM more than the Rotax tacho! So when the customer thought he was using around 5700 RPM on takeoff he had actually been using 6300 every time. Somewhat ironic that installing the CS controller actually reduced his takeoff performance by about 10% (but hopefully prolonged the life of his 912S). The Rotax tacho has a little pot in it you can twiddle to adjust the displayed RPM but it's impossible to get at when the thing is in situ. Also, if memory serves me right, Rotax decreed that it should be calibrated something like every 50 hours! Cheers, Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387781#387781 ________________________________________________________________________________
Date: Nov 13, 2012
My experience would show as with Mark that the Rotax RPM gauges are not to be trusted. My original was some 200rpm under reading when new. Europa re calibrated it but some 2 years later it had gone way out again. I rely on the digital readout from my EIS from Grand Rapids. Pete Jeffers -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Mark Burton Sent: 13 November 2012 21:02 Subject: Europa-List: Re: rotax Tacho verses digital Hi, The Rotax tacho really cannot be trusted. Many years ago, one of my customers told me that when he fitted a CSC-1/P constant speed controller, it showed 600 RPM more than the Rotax tacho! So when the customer thought he was using around 5700 RPM on takeoff he had actually been using 6300 every time. Somewhat ironic that installing the CS controller actually reduced his takeoff performance by about 10% (but hopefully prolonged the life of his 912S). The Rotax tacho has a little pot in it you can twiddle to adjust the displayed RPM but it's impossible to get at when the thing is in situ. Also, if memory serves me right, Rotax decreed that it should be calibrated something like every 50 hours! Cheers, Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387781#387781 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Nov 14, 2012
Gilles, Thank you again. Yes the levers on the carbs move in unison no matter how fast the throttle lever is advanced. The whole operation is very smooth and fluent. I'm no expert on any of this stuff I can assure you but I would expect the engine not to run smoothly if a throttle cable was to lag the throttle movement. The engine runs like a sewing machine and my only observation is that the MAP seems slower to rise than expected be it true or imaginary! Hence my dilemma. Best regards Kingsley Sent from my iPhone On 13/11/2012, at 9:00 PM, Gilles Thesee <Gilles.Thesee@ac-grenoble.fr> wrote: > > Kingsley Hurst a crit :! >> > > Kingsley, > > Just to make sure. Have you checked that the throttle cables do respond correctly to the throttle lever movements ? > IIRC, there have been some instances of cables buckling instead of sliding in their outer cases when one relies only on springs to open the butterflies in the carburettors. > > To prevent this situation, our airplanes are equipped with solid piano wire 'cables' providing some push-pull action. The carb springs are just there for peace of mind. > > FWIW, > Best regards, > -- > Gilles > http://contrails.free.fr ________________________________________________________________________________
Date: Nov 14, 2012
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 14, 2012
Kingsley Hurst a crit : > my only observation is that the MAP seems slower to rise than expected be it true or imaginary! Hence my dilemma. > What about the MAP lines, water trap, restriction, etc. ? Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Nov 14, 2012
Thanks for the replies, and compliments on my photo. The Needles are at the western end of the Isle of White about halfway along the UK south coast. One might see them when crossing from Cherbourg. New compact camera, 20 Mpixels and I am staggered at the difference. I will add a zoom on portsmouth so you can see if interested. considering its hand held through the perspex. -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387924#387924 Attachments: http://forums.matronics.com//files/portsmouthportion_1_141.jpg ________________________________________________________________________________
Date: Nov 14, 2012
sorry cant seem to attach two pics on one post, so here is the original shot -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387925#387925 Attachments: http://forums.matronics.com//files/dsc01100portsmouth_427.jpg ________________________________________________________________________________
Subject: Re: tri-gear trailer
Date: Nov 15, 2012
Hi, I don't have a dedicated Europa trailer but l have a large flatbed trailer with ramp and hand winch used by the builder of my Europa to move it around. The trouble is l am based in Essex, the trailer is near Stansted Airport. You are welcome to use it if you get really stuck. -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387967#387967 ________________________________________________________________________________
Subject: heavy left wing
Date: Nov 15, 2012
I have finally figured out my overheating problem with the Jabiru engine. Mostly it is the MGL EMS unit telling me that the engine is 36 C hotter than it really is. I have now been able to fly for longer times and distance and one of the first things that got my attention is the heavy left wing. The aileron tip is down about 1 to 1 1/2 inches is straight and level flight. The right is up about 1/4 to 1/2" . I had been thinking since I weight in at 250 pounds that was the cause, but today I added 150 pounds to the PAX seat, Sand Bags!. It helped, but not my much. Bud had sent a picture of adding a pencil to the bottom of the aileron. This bought the aileron up, but the turning increased. I'm thinking that I don't have enough lift on this wing or too much on the right wing. I remember reading a couple of months ago about making the flap stay down by placing a block on the up side of the slot. Is this really a good way to add lift to this wing? Or is there a better way? I remember when I set the Angle of Incidence and even took pictures of both sides. What do I do now? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388012#388012 ________________________________________________________________________________
Date: Nov 16, 2012
Hi! Irrespective of loading it is IMHO that you should start from a point of both ailerons being matched slightly up of dead neutral on the ground, which you should be able to adjust with all the various points to do just that. Then fly and fine tune it from there. Best of luck with the Jabiru but watch out for cyl head distortion, because unless you have calibrated all the instruments the engine temps can't be believed. That engine will soon tell you what temperatures it is suffering without any gauges ! Been there got the "T" shirt. Regards Bob Harrison G-PTAG Now with Rotax 914 !!!! -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of AirEupora Sent: 16 November 2012 01:37 Subject: Europa-List: heavy left wing I have finally figured out my overheating problem with the Jabiru engine. Mostly it is the MGL EMS unit telling me that the engine is 36 C hotter than it really is. I have now been able to fly for longer times and distance and one of the first things that got my attention is the heavy left wing. The aileron tip is down about 1 to 1 1/2 inches is straight and level flight. The right is up about 1/4 to 1/2" . I had been thinking since I weight in at 250 pounds that was the cause, but today I added 150 pounds to the PAX seat, Sand Bags!. It helped, but not my much. Bud had sent a picture of adding a pencil to the bottom of the aileron. This bought the aileron up, but the turning increased. I'm thinking that I don't have enough lift on this wing or too much on the right wing. I remember reading a couple of months ago about making the flap stay down by placing a block on the up side of the slot. Is this really a good way to add lift to this wing? Or is there a better way? I remember when I set the Angle of Incidence and even took pictures of both sides. What do I do now? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388012#388012 ________________________________________________________________________________
Date: Nov 16, 2012
Subject: Who is Matt Dralle & What Are The Lists?
Dear Listers, Who is Matt Dralle and what exactly are these Lists anyway? I've been working in the Information Technology industry for over 28 years, primarily in computer networking design and implementation and more recently as an embedded software engineer. I have also done a fair amount of work in web design and development. I started the Matronics Email Lists way back in 1990 shortly after I started building my RV-4 with about 30 fellow RV builders from around the world. Since that time, I have added many other types of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a bonded dual T1 commercial-grade business Internet connection with full static addressing. The computer servers include a dual quad-core Linux server for List web services with 24GB of memory, a quad -core Linux system dedicated to the email processing List functions, and another standalone Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with multi-terra byts of online storage. This entire system is protected by three large, commercial-grade uninterrupted power supply systems (UPS) that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. On the average, the elctric bill is in the neighborhood of $7000-$8000/yr and the newly upgraded dual-T1 Internet connection runs roughly $6000/yr. A while back, I upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists and followed that upgrade up with a second rack upgrade to house the MONSTER web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center prior to the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've mentioned many times before, I don't use commercial advertisments to support any of these systems. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Please make a Contribution today to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 16, 2012
From: "Jeffrey J Paris" <jeffrey-j-paris(at)excite.com>
Subject: Europa Classic Monowheel Fight Test Report
Europaphiles, =C2- Yesterday was a breakthrough day for myself and our Jabiru powered Europa Mo nowheel Classic kit #A012. =C2-After making some changes in the cowl my CH T issues have improved greatly enough for me to take the aircraft and to fin ally experience what can only be described as a delightful flying machine. =C2-I flew for 1.2 hours and took our "Gladys" (In honour of my English Gr andmother) up to 5000 feet to get more familiar with the handling characteri stics of the aircraft. =C2-I am pleased to report that I was able to trim the aircraft =C2-and fly hands off and the airplane flew like she was on a rail! =C2- In a best rate climb from 4000' to 5000' =C2-she climbed at 1600 fpm. =C2 -I also saw 126 knots indicated 123 ground at 2750 RPM burning 6.2 gallons an hour. =C2-Control forces are balanced and responsive. =C2-Slow fligh t, S-turns, turns around a point all very predictable. =C2-My landings are getting better and i'll leave it at that... =C2- Pulling the cowls today and going to give the aircraft a real close inspecti on and hopefully the weather and winds allow me to get up this weekend. =C2- Cheers, =C2- Jeff Paris N127ZP=C2- Rochester NY =C2-Williamson Sodus Airport, NY ________________________________________________________________________________
Date: Nov 16, 2012
Hi Jeff, Congratulations and Welcome to the club of Europa lovers! It=99s just the beginning of a long story I=99m sure J Max Cointe F-PMLH Europa_TriGear Kit #560 912ULS Airmaster 450 hours mcointe(at)free.fr ________________________________________________________________________________
Date: Nov 16, 2012
Subject: Re: heavy left wing
Something to check for with your "heavy wing problem". I had a similar problem with my plane following a major wing repair, not my Europa but my Citabria. It sure seemed that one wing had notably more lift than the other. The incidence was equal wing to wing with no visible or measurable difference between wings but it would not fly straight without input pressure on stick and rudder, it wanted to roll. Because it seemed to be a wing problem, I proceeded to adjust the washout/washin to correct the difference in lift, this can be done with a high wing by adjusting the struts. I could get it to fly hand off but then one aileron was 1 inch up and the other down. Needless to say, I sure didn't like the stall characteristics with unequal washout. Scratching my head and deciding to look outside my box, the problem turned out to be a misinstalled tail wheel spring inputting rudder pressure to one side. This was not an intuitive place to look for me but it sure was the problem. Correcting the spring and rudder, it was then easy to get the plane tuned up and flying hands off straight and level. So you might check if your rudder linkage is inputting pressure to one side. Bill McClellan -----Original Message----- >From: AirEupora <AirEupora(at)sbcglobal.net> >Sent: Nov 15, 2012 5:36 PM >To: europa-list(at)matronics.com >Subject: Europa-List: heavy left wing > > >I have finally figured out my overheating problem with the Jabiru engine. Mostly it is the MGL EMS unit telling me that the engine is 36 C hotter than it really is. > >I have now been able to fly for longer times and distance and one of the first things that got my attention is the heavy left wing. The aileron tip is down about 1 to 1 1/2 inches is straight and level flight. The right is up about 1/4 to 1/2" . I had been thinking since I weight in at 250 pounds that was the cause, but today I added 150 pounds to the PAX seat, Sand Bags!. It helped, but not my much. > >Bud had sent a picture of adding a pencil to the bottom of the aileron. This bought the aileron up, but the turning increased. > >I'm thinking that I don't have enough lift on this wing or too much on the right wing. > >I remember reading a couple of months ago about making the flap stay down by placing a block on the up side of the slot. > >Is this really a good way to add lift to this wing? > >Or is there a better way? I remember when I set the Angle of Incidence and even took pictures of both sides. > >What do I do now? > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=388012#388012 > > ________________________________________________________________________________
Subject: Across UK Stanstead zone
Date: Nov 16, 2012
I used to frequently get permission to route across Luton, London City and even Heathrow (Ascott - Burnham) zones but haven't tried since the Olympics. Has anyone had a route across any of these or Stanstead (say NW to SE) recently? -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388136#388136 ________________________________________________________________________________
Date: Nov 17, 2012
Thanks Bill While flying I have check the ball and played around with the rudder to see if I could pick the wing up using rudder. It helped a a little, but the wing does not want to fly level. I have completed my stalls with light weight and with heavy weight. The right wing always stalls first. Power on stall I could not get the plane to stall. It would turn to the left, almost like a VMC demo on a twin, where I could not control the turn. It was not at an altitude where I felled comfortable doing a complete power on stall with the wing acting this way. I'm thinking that I made a mistake on the angle of incidence. Although I took pictures showing the 2.5 degree on both wings it acts as if there is not enough on this wing. Now, how do I correct it? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388165#388165 ________________________________________________________________________________
Date: Nov 17, 2012
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
First thing to check is the incidence at 2/3 span and almost full-span. I ncidence at the root is not really important.-=0AMake two more templates with a Vee that locates against the-leading-edge and rests on the trail ing edge of the wing,=0A(not flap or aileron) Then compare the two wings at each point. The further outboard the more the effect of any error.=0AGraha m=0A=0A=0A________________________________=0A From: AirEupora <AirEupora@sb cglobal.net>=0ATo: europa-list(at)matronics.com =0ASent: Saturday, 17 November 2012, 16:23=0ASubject: Europa-List: Re: heavy left wing=0A =0A--> Europa-L ist message posted by: "AirEupora" =0A=0AThanks Bi ll=0A=0AWhile flying I have check the ball and played around with the rudde r to see if I could pick the wing up using rudder.- It helped a a little, but the wing does not want to fly level.=0A=0AI have completed my stalls w ith light weight and with heavy weight.- The right wing always stalls fir st.- Power on stall I could not get the plane to stall.- It would turn to the left, almost like a VMC demo on a twin, where I could not control th e turn.- It was not at an altitude where I felled comfortable doing a com plete power on stall with the wing acting this way.- =0A=0AI'm thinking t hat I made a mistake on the angle of incidence.- Although I took pictures showing the 2.5 degree on both wings it acts as if there is not enough on this wing.=0A=0ANow, how do I correct it?=0A=0A=0A=0A=0ARead this topic onl ine here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=388165#388165 ====== ________________________________________________________________________________
Subject: Re: Europa Classic Monowheel Fight Test Report
Date: Nov 17, 2012
Hi Jeff, Congratulations on your success. Sounds like a wonderful flying machine you have. I too have a Monowheel Classic, but with a 912S and a ground adjustable warp drive. I was just curious about you great speeds and had some questions. I was wondering what prop you are using, if you've fitted any drag reducing fairings etc, or it all because of the Jabiru engine. The best I can get in my Classic is about 115 knots indicated at around 5k. Got pix? Troy Maynor Europa Monowheel Classic 195 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388193#388193 ________________________________________________________________________________
Subject: Quiet plane
Date: Nov 18, 2012
Walking with my wife this morning, in glorious weather along the hairpin in the Severn when at around 11.30 an amazingly quiet plane flew over at perhaps 2500ft. Out with the binocs & it proved to be a mono Europa. Had to bite my tongue not to say 'Wouldn't it be great to be flying.' (Su was severely mentally traumatised by some f...oreign pilot in the Alps many years ago and came down saying she would never go in a small plane again! ) But whoever it was, (? Tim), I am sure you had a great flight! David Joyce, G-XSDJ ________________________________________________________________________________
Date: Nov 18, 2012
Hi David 3,300 feet, 110 kts indicated, 11.6 litres per hour. G-RMAC out of Chavenage. Came back at 125 kts with 14.6 litres per hour. Wonderful flying morning, great vis and totally calm air. Regards Pete -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of David Joyce Sent: 18 November 2012 14:53 Subject: Europa-List: Quiet plane Walking with my wife this morning, in glorious weather along the hairpin in the Severn when at around 11.30 an amazingly quiet plane flew over at perhaps 2500ft. Out with the binocs & it proved to be a mono Europa. Had to bite my tongue not to say 'Wouldn't it be great to be flying.' (Su was severely mentally traumatised by some f...oreign pilot in the Alps many years ago and came down saying she would never go in a small plane again! ) But whoever it was, (? Tim), I am sure you had a great flight! David Joyce, G-XSDJ -- This message has been scanned for viruses and dangerous content by Houxou, and is believed to be clean. ________________________________________________________________________________
Date: Nov 18, 2012
Subject: Cabin Heater Bits
Hi Everyone, I need to make up a cabin heating system to sit on my Jabiru 3300 in Europa - does anyone know of anyone that has made up parts to save me having to fabricate from scratch? The exhaust header pipes appear to be 1 1/4" which is quite small. Regards, -Carl. ________________________________________________________________________________
Subject: A spectacle in Uk Norflok
Date: Nov 18, 2012
here is something worth a look from a plane; nothing on tens of miles of sandy beach but thousands of seals and pups at Blakeney Point near Cromer in Norfolk. -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388225#388225 Attachments: http://forums.matronics.com//files/dsc01186blakeney_point_578.jpg ________________________________________________________________________________
Date: Nov 18, 2012
Jeff, Glad to hear you got into the air finally. Keep tweaking the cooling issues and enjoy your plane. Regards, Bud ----- Original Message ----- From: Jeffrey J Paris<mailto:jeffrey-j-paris(at)excite.com> To: europa-list(at)matronics.com Sent: Friday, November 16, 2012 8:23 AM Subject: Europa-List: Europa Classic Monowheel Fight Test Report Europaphiles, Yesterday was a breakthrough day for myself and our Jabiru powered Europa Monowheel Classic kit #A012. After making some changes in the cowl my CHT issues have improved greatly enough for me to take the aircraft and to finally experience what can only be described as a delightful flying machine. I flew for 1.2 hours and took our "Gladys" (In honour of my English Grandmother) up to 5000 feet to get more familiar with the handling characteristics of the aircraft. I am pleased to report that I was able to trim the aircraft and fly hands off and the airplane flew like she was on a rail! In a best rate climb from 4000' to 5000' she climbed at 1600 fpm. I also saw 126 knots indicated 123 ground at 2750 RPM burning 6.2 gallons an hour. Control forces are balanced and responsive. Slow flight, S-turns, turns around a point all very predictable. My landings are getting better and i'll leave it at that... Pulling the cowls today and going to give the aircraft a real close inspection and hopefully the weather and winds allow me to get up this weekend. Cheers, Jeff Paris N127ZP Rochester NY Williamson Sodus Airport, NY www.aeroelectric.com<http://www.aeroelectric.com/> www.buildersbooks.com<http://www.buildersbooks.com/> www.homebuilthelp.com<http://www.homebuilthelp.com/> http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> ________________________________________________________________________________
Date: Nov 19, 2012
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here:
http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: A spectacle in Uk Norflok
Date: Nov 19, 2012
Hello Graeme, Wonderful picture. It is this sort of thing that drives me back into the garage on cold wintry days to get the h... on with finally finishing my plane! Thanks, -------- Jeroen http://www.europaowners.org/main.php?g2_itemId=44165 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388319#388319 ________________________________________________________________________________
Subject: Ultimate Vents
Date: Nov 19, 2012
I have purchased a pair of Ultimate vents which I plan on installing soon. I have seen these put in a number of positions. Does anyone out there feel he has the perfect position and orientation for these vents sorted out, in terms of effectivity, accessibility, and interference? Any particular tips on the installation process? In practice, are these vents by themselves sufficient or are other measures needed to ensure minimum / effective ventilation? Help appreciated, -------- Jeroen http://www.europaowners.org/main.php?g2_itemId=44165 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388320#388320 ________________________________________________________________________________
Subject: Dimention needed please.
Date: Nov 19, 2012
Hi, can someone with a flying or compleated Europa give me the dimension from the back of the control stick to vertical front of the seat unit when the stick is fully aft and also stick fully forward, many thanks, steve. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388341#388341 ________________________________________________________________________________
Subject: Glider Wing Build
Date: Nov 19, 2012
This is an appeal for information from glider wing builders. Steve Leisch (Kit A208) has realised that there are 2 Tufnol bearings part number GAB03 that are not referenced in any of the build documents. I have checked with Karen at Europa and can confirm that GAB03s are diamond shaped Tufnol blocks with a hole in the middle (which is large enough for the airbrake push rod to pass through). Talking to Nev, I believe they are fixed on the root rib to act as an inboard bearing for the airbrake pushrod. The end of the pushrod enters the cabin and is attaches to the cables as per Fig 11 on Page 28a In the Glider manual, section 8-13 refers to cutting the air brake push rods (roughly) to length and fitting the bell crank end. There is no detail for cutting the holes through the ribs forward of the spar, finalising the length, attaching the inboard end fitting on the pushrod or the final connection to the cables. As no one at Europa has any further information I will try and collect as much as I can. I would be pleased to have have any notes, pictures or drawings you may have. When I have got this together I am happy to produce a Build manual supplement covering this area. Ian Rickard G-IANI XS Trigear, 300hours Europa Club Mods Specialist e-mail g-iani(at)ntlworld.com ________________________________________________________________________________
Date: Nov 19, 2012
Steve On G-IRON and measured horizontally at the top of the seat face 65mm and 115mm. This can be varied depending on the adjustment of the push rod lengths and your preference. Ian Rickard G-IANI XS Trigear, 300hours Europa Club Mods Specialist e-mail g-iani(at)ntlworld.com ________________________________________________________________________________
Subject: Re: Dimention needed please.
Date: Nov 19, 2012
Ian, thanks for the quick response, Steve. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388356#388356 ________________________________________________________________________________
Date: Nov 20, 2012
Hello Gilles, Sorry for the delay in replying. I hadn't considered what you have suggested thanks and only got to checking it out two days ago. The line from the equaliser tube to the pressure sensor has a filter which was wrapped in a heat insulating mat. This prevented casual observation of the state of the filter. On removing this covering I found the filter saturated with a brown sludge which I assume was stale condensate of fuel. When I blew through the line (with my mouth) there was a lot of restriction as you can imagine and I was thinking "thanks Gilles", you were right on the ball! I did over two hours flying yesterday after fitting a new filter in a more elevated position and guess what? MAP readings on take-offs are identical to what they were before. (head now shaking!) Because the engine is running so nicely, I have decided to let sleeping dogs lie. There is no point trying to fix something if one is not sure it is 'broke'! Thanks again for your thoughts Gilles. Best regards Kingsley Sent from my iPhone On 14/11/2012, at 10:19 PM, Gilles Thesee <Gilles.Thesee@ac-grenoble.fr> wrote: > What about the MAP lines, water trap, restriction, etc. ? ________________________________________________________________________________
Date: Nov 20, 2012
Subject: Re: Ultimate Vents
On 11/19/2012 12:04 PM, jglazener wrote: > I have purchased a pair of Ultimate vents which I plan on installing > soon. I have seen these put in a number of positions. Does anyone out > there feel he has the perfect position and orientation for these > vents sorted out, in terms of effectivity, accessibility, and > interference? Any particular tips on the installation process? I have them too, I installed them with the knob pointing towards the tail. They are working perfectly, the airstream is adjustable to all positions. I have also installed an overhead vent, which is great if you also want to have some air blowing on your head. (I'm bald and some air there keeps my brain from overheating). > In practice, are these vents by themselves sufficient or are other > measures needed to ensure minimum / effective ventilation? Something often overlooked: If you want to let air in, you also have to let air out somewhere. Otherwise you are just pressurizing the cabin until it won't allow any more fresh air in, only just enough to make up for the air leaks, which, depending of the build, might be quite restrictive. I have still not solved this to my full satisfaction. I have a hose running from the D-panel to the tailpost, thinking that the gap between the rudder and the fin is a low pressure area and would be a low drag air outlet. To my surprise, with the overhead and ultimate vents closed, it actually blows air into the cockpit. And no, I have no idea where that air is leaving again. I have a lockpin in the middle of the door (a MUST if you want to prevent the doors from bulging out during flight and leaking out massive amounts of turbulent air in the low pressure area above the wing roots) and the flap drive slots are sealed by the Fred Klein's wing root fairings. It might be that my cowl flap is so efficient that it pulls air through the rudder cable slots so the tunnel becomes a low pressure area and sucks air out via the inspection holes and power lever slot. The only other openings are the tail plain slots, but if the rudder gap is not a low pressure area I wonder why the tail plain slots would be. So, you might want to think about an air outlet too. Don't make it too efficient though: I have these small windows in the door and they are no fun to open during flight as they actually suck the air out and underpressurize the cabin. What happens then is that the cockpit sucks air from all kind of sources, some not too fresh. The cabin fills quickly with a mixture of hot oil smell, traces of fuel smell, a dash of exhaust smell, etc. So take care not to underpressurize the cabin. The ultimate vents always provide fresh air, only during stalls sometimes some exhaust smell seems to make it into the cockpit. Frans ________________________________________________________________________________
Date: Nov 20, 2012
Hi Frans, Years ago I did some flight testing with the D panel partially open and found that air was blowing from the back fuselage to the cockpit whenever fresh air vents and heating flap were closed. With the vents open or heating on, there were no flow through the D panel opening. So you are right that the rear fuselage is a relatively high pressure area. In the monowheel air is clearly sucked by the wheel well through the flap/gear lever slot. This is probably why in my aircraft the air vents are very effective without any purpose built extraction device. Should an extraction device be necessary, I would try a hose from the D panel to an inverted scoop (or inverted Naca ??) at the bottom of the rear fuselage. Remi Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388389#388389 ________________________________________________________________________________
Date: Nov 20, 2012
Hi Remi, > So you are right that the rear fuselage is a > relatively high pressure area. I had a hose connected to the outlet of the D-panel, all the way to the sternpost. No air from the rear fuselage could get into the hose. The interesting thing is that the sternpost (actually the space between sternpost and rudder) is also a high pressure area. I'm very surprised about that, as the rudder is smaller than the sternpost, and air is streaming over the fin to the rudder and must effect a suction force on the gap between fin and rudder. At least we can conclude that the airflow remains firmly attached to the rear fuselage, which is a good thing as it helps recovering some pressure loss. > Should an extraction device be > necessary, I would try a hose from the D panel to an inverted scoop > (or inverted Naca ??) at the bottom of the rear fuselage. You can't invert Naca scoops, that won't work. But of course, some other kind of scoop would work. The challenge is however to find some "natural" outlet, as the gap between fin and rudder was supposed to be, so the expelling air would reduce some drag instead of creating more. Frans ________________________________________________________________________________
From: Christoph Both <christoph.both(at)acadiau.ca>
Subject: GRT EIS Rotax probes for CLASSIC installation
Date: Nov 20, 2012
Hello Europa builders: I am about to drill holes into the stainless steel CLASSIC exhaust headers to mount the EGT probes. Rotax912S manual says to locate the EGT probes 70m m or 2.75 inches from the exhaust port. Both back exhaust pointing stacks e nd up drilling the thicker, double side flange if I take this measurement. Is this OK? Front exhaust measures 70mm (2.75 inch) on the not- welded part . Is this OK or have CLASSIC engine installations chosen a different distan ce. I have a GRT EIS Model 4000 for Rotax 912. It came with a number of probes but no description of probes and where to mount them. EGT was no issue (see above). However, there is a set of what I assume CHT probes, one terminati ng at one end with a large ring terminal (3/8 inch) and one with a very sma ll ring terminal (1/8 inch). What are they for and where do I mont those? R otax installation manual specifies that 2 probes are to be connected to the hot water location locations provided but then on one page describe tappin g a M-5 (5mm) thread to "install" a probe measuring the CHT directly at the cylinder cooling fins as described. I would appreciate some quick clarification for those who have installed th is combination. Pictures appreciated. Thanks very much. Christoph Both #223 CLASSIC Wolfville, Nova Scotia, Canada ________________________________________________________________________________
Subject: Re: Glider Wing Build
Date: Nov 20, 2012
Ian, I have all the detail on this. I have built 4 MGs and even a Classic MG. Please note that it is fitting process and quite easy but requires (like all airplane building) to rig the wings and derig to get it right. Contact me off line and we will supply you with the appropriate info, tips and tricks. Regards Bud Yerly Europa Tech Support ----- Original Message ----- From: G-IANI<mailto:g-iani(at)ntlworld.com> To: europa-list(at)matronics.com Sent: Monday, November 19, 2012 2:04 PM Subject: Europa-List: Glider Wing Build > This is an appeal for information from glider wing builders. Steve Leisch (Kit A208) has realised that there are 2 Tufnol bearings part number GAB03 that are not referenced in any of the build documents. I have checked with Karen at Europa and can confirm that GAB03s are diamond shaped Tufnol blocks with a hole in the middle (which is large enough for the airbrake push rod to pass through). Talking to Nev, I believe they are fixed on the root rib to act as an inboard bearing for the airbrake pushrod. The end of the pushrod enters the cabin and is attaches to the cables as per Fig 11 on Page 28a In the Glider manual, section 8-13 refers to cutting the air brake push rods (roughly) to length and fitting the bell crank end. There is no detail for cutting the holes through the ribs forward of the spar, finalising the length, attaching the inboard end fitting on the pushrod or the final connection to the cables. As no one at Europa has any further information I will try and collect as much as I can. I would be pleased to have have any notes, pictures or drawings you may have. When I have got this together I am happy to produce a Build manual supplement covering this area. Ian Rickard G-IANI XS Trigear, 300hours Europa Club Mods Specialist e-mail g-iani(at)ntlworld.com www.aeroelectric.com<http://www.aeroelectric.com/> www.buildersbooks.com<http://www.buildersbooks.com/> www.homebuilthelp.com<http://www.homebuilthelp.com/> http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> ________________________________________________________________________________
From: "Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no>
Date: Nov 20, 2012
Hello Christoph, I also have the GRT EIS 4000 (I am very pleased with its performance), 912ULS and XS firewall-forward kit from Europa. Please see the attached photo for where the aft EGT probes are mounted - no double side flange on the exhaust tubes, though, as far as I can see on the photo. My EIS set came with 4 ring terminals, of equal size. They are thermocouples to be pressed against the cylinder head metal, under a bolt to be screwed into the threaded holes provided for the standard Rotax CHT probes. The standard probes measures the temperatures inside the CH cavity, while the ring thermocouple will be exposed to cylinder cooling air. Therefore, you must cover the thermocouples and the adjacent CH metal well with a suitable compound (I used the red high-temp silicone from Loctite). There is a noticeable difference in measured temperature with and without this insulation against air cooling (I did not have it at first). See attached photo. I have not fitted any probes between cooling fins. Since I operate my engine with 50/50 glycol/water, I have also fitted a coolant temp probe into the hose between one of the cylinders and the small black "bottle" on top of the engine (as per Rotax recommendation). This probe is connected to one of the available input channels on the EIS. Why there is one large and one small thermocouple in your set I do not know - it should be 4 of equal size to fit under the head of suitable bolt. Suggest you ask GRT about this. As you probably know, you must not cut and splice the thermocouple cables - they must run from the instrument to the cylinders just as they came from GRT. Regards, Svein LN-SKJ ________________________________________________________________________________
Subject: Venting cabin
From: Gerry Holland <gholland@content-stream.co.uk>
Date: Nov 20, 2012
Hi. I've attached a photo of a venting device I fitted to my Tri-gear when I had it. Cant remember where the idea came from but it worked at extracting air from cabin. The very basic theory is that the shape (sort of airfoil) created lower pressure at the point of the series of holes and air was extracted. I never did any scientific analysis but it did seem to work in conjunction with the overhead eyeball vents fitted. It could have all been bunkum but I was happy! Gerry Gerry Holland
gholland@content-stream.co.uk +44 (0)7808 402404 White Ox Mead Airstrip, Bath. England ________________________________________________________________________________
Date: Nov 21, 2012
Subject: Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of sweet gifts available this year, so please browse the nice selection and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I have been flying my Pietenpol for a month now and am enjoying the fruits of ten hard years of work. I seriously doubt it would ever have been finished but for the help, encouragement and friendships I've received and made through the Pietenpol list. Douwe B Outstanding service to the flying community. George A Matt, I look forward to support each others projects, Glenn B Great list!!! Thanks for all your efforts! Roger C Thank you for keeping up the lists. Without it i would never have completed my aircraft. Stan S Keep up the good work my friend. I don't think I could ever finish my Pietenpol Air Camper without the help I get from this List. Tom S Thank you for keeping these list alive. Lee V The List is invaluable!! Svein J Thanks for continuing to provide the list service! Earl S You have a really GREAT service. Thankyou so much I've been on for nearly 30 years and I still check-in every morning. John B I rely fully on the lists which govern my every decision. The flexibility provides the security I seek. Fergus K My RV 7 Finally flies... 7 years of Matronics.com certainly helped. Martin H Great service here, thanks! I am just getting back to a project I dropped for a few years, great to see your site and all the folks again! James C Thanks for the great site. Robert U The Rotax list is good and the AeroElectric list outstanding! Jay H Thank you for a great resource! Jack T Thanks for your great record of outstanding service to the homebuilding community! Larry W This service is invaluable. Michael W You're doing a great job Matt. Robert D Thanks for all your work, its a great asset to all. John F Thank you for your time & effort Matt! Ted W Matt, been a follower since 2005 on the -10 list, now starting an -8. Keep up the great work! John M Still my favorite place to hang out. William W I'm not a Piet builder, but this is the most informative and congenial list I've ever run across. Please forgive my lurking-I learn a LOT here! Ken M Many thanks for keeping this alive, keep pushing! Adrian C Thanks! Please keep r going! Rich Z Many thanks for your hard work. Robert C Thanks for the Lists! I probably need to subscribe to a few more... John M Been a quick 14 years. Think I subscribed to the Kolb List in 1998, when I got my first computer. Thanks for keeping everything running smoothly for all these years. John H Great resource - thank you. David M I don't post very much, but get the postings, a lot of really practical info. John N Great job Matt, thanks for all you do. Roger M Thanks for ANOTHER great year, Matt! True grassroots experimental aviation has been pushed aside in many ways. But the List represents the evolution of this great tradition of home-building. One man, the plans, the tools, and the List - that's all you need to build the dream! Robert B This message board is a real help to my project and creating friendships. John S Many thanks for your continuing excellent work. Mike G Thank you for your work Matt. Your lists have helped me a great deal during the construction of my plane. Hal B Nice List Van E These lists are priceless for builders. Ronald C Thanks for keeping me in touch with the Pulsar community. Otto S Thanks for keeping up this great warbird sight!! Yak Ron Thanks for providing all the lists for so many years. H H Thanks for all that you do. Your dedication is much appreciated! Warren H Best service on the internet! Owen B I have learned so much from the "list". Nick C Great Service You Are Providing! Giffen M Thanks so much for maintaining these great resources. Dave S I no longer fly due to age and health problems, but I still enjoy the reading from other pilots. Dallas S This is a wonderful site. Robert B Useful service over the last year - thanks. Om T -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Subject: Re: GRT EIS Rotax probes for CLASSIC installation
Date: Nov 21, 2012
Hi Chris, I will reply as I have a classic install but admit I won't be much help. I used an engine monitor that went out of business, called Audio Flight Avionics. It came with two threaded (5mm?) CHT probes that screwed into two holes already tapped on the front left and right rear cylinders. I am 40 miles from my hanger so I can't go out and look or take any measurements very soon. The 3/8" ring terminal you mention is meant to go under on of the spark plugs on the same cyclinder most likely. Don't understand the 1/8" one though. I'd call Grand Rapids for guidance unless someone here knows. I remember having to move the EGT probes slightly away from the heads very slightly,(again can't measure today) in order to get away from the thick area of the exhaust pipe. With that, coincidentally, I was about to broach the subject of EGT here in a few days when I have gathered some data on my plane. It seems two of my cylinders are hotter than they should be, but thats off the point for now. Hope you can get the answers you want. Troy Maynor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388509#388509 ________________________________________________________________________________
Date: Nov 21, 2012
Troy and Chris, > The 3/8" ring terminal you mention is meant to go under on of the spark > plugs on the same cyclinder most likely. I heard this when I was about to do my installation, but as I recall there is no space for a ring terminal in the spark plug recess in the cylinder head. My memory may be failing, though ......... Regards, Svein ________________________________________________________________________________
Date: Nov 21, 2012
Chris, Please check the grtavionics.com website for installation notes and the updated manual . I've attached Rev K. We are a sales point for GRT and install them frequently. EGT s normally are two inches from the outlet of the head, but that is in the crux of the bend. 2.75 is not that bad. Anything beyond that like out to a max of 8 inches decreases accuracy but is still great for trends. Normally only the two rear cylinders are needed on a 912/914 engine. Place the EGT probes on a fairly straight section and drill the hole so as to keep the probe from rubbing on anything. Pay attention to the foot well and oil tank and plan accordingly. GRT avionics has the larger CHT ring terminals which go on the Rotax CHT probes. You unscrew the probes and put the CHT supplied rings on there and they are an exact fit. I believe for the Rotax it is a 12mm.. There is an option for those who desire a bolt on probe to the cylinder fins. This is normally not provided and I am surprised you received one... Regards, Bud Yerly Custom Flight Creations. ----- Original Message ----- From: Christoph Both<mailto:christoph.both(at)acadiau.ca> To: europa-list(at)matronics.com Sent: Tuesday, November 20, 2012 9:03 AM Subject: Europa-List: GRT EIS Rotax probes for CLASSIC installation Hello Europa builders: I am about to drill holes into the stainless steel CLASSIC exhaust headers to mount the EGT probes. Rotax912S manual says to locate the EGT probes 70mm or 2.75 inches from the exhaust port. Both back exhaust pointing stacks end up drilling the thicker, double side flange if I take this measurement. Is this OK? Front exhaust measures 70mm (2.75 inch) on the not- welded part. Is this OK or have CLASSIC engine installations chosen a different distance. I have a GRT EIS Model 4000 for Rotax 912. It came with a number of probes but no description of probes and where to mount them. EGT was no issue (see above). However, there is a set of what I assume CHT probes, one terminating at one end with a large ring terminal (3/8 inch) and one with a very small ring terminal (1/8 inch). What are they for and where do I mont those? Rotax installation manual specifies that 2 probes are to be connected to the hot water location locations provided but then on one page describe tapping a M-5 (5mm) thread to "install" a probe measuring the CHT directly at the cylinder cooling fins as described. I would appreciate some quick clarification for those who have installed this combination. Pictures appreciated. Thanks very much. Christoph Both #223 CLASSIC Wolfville, Nova Scotia, Canada www.aeroelectric.com<http://www.aeroelectric.com/> www.buildersbooks.com<http://www.buildersbooks.com/> www.homebuilthelp.com<http://www.homebuilthelp.com/> http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> ________________________________________________________________________________
Date: Nov 22, 2012
Frans, I now realize how stupid it was to suggest a reversed Naca. I should have thought at it twice before writing! Remi Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=388572#388572 ________________________________________________________________________________
Subject: Fuel Tank
Date: Nov 22, 2012
When i got my kit (second hand and un-started) it came with two petrol tanks, one was coated inside so fuel wouldn't soak into the moulding, a mod apparently? but my question is how would you tell the difference between the two? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388606#388606 ________________________________________________________________________________
Date: Nov 22, 2012
Subject: Re: Fuel Tank
If the 'coating' you refer to is flouronation, then it is very difficult to tell. If the flouronation is done to a high level, then the finish of the plastic is 'frosty', similar to a 'frosted' opaque window. That said, even if the tank has been flouronated (which they are from the Europa factory for many years), if the vent and fill holes are cut open to the finished sizes the fuel will still permeate and swell the plastic through the cuts, since the flouronated layer is only 'atoms' thick. Cheers, Pete A239 as always, still a pile of parts On Thu, Nov 22, 2012 at 12:45 PM, spcialeffects wrote: > > When i got my kit (second hand and un-started) it came with two petrol > tanks, one was coated inside so fuel wouldn't soak into the moulding, a mod > apparently? but my question is how would you tell the difference between > the two? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=388606#388606 > > ________________________________________________________________________________
Date: Nov 22, 2012
Subject: Rear Wing Pins
I just recently purchased a partially completed monowheel "classic" kit. The rear wing pins have not been installed and I have all the parts for Mod 52. The pins with the Mod are sized W24/4 and because I was unsure whether they were the original W24 pin or new, I test fit them into the socket assembly W26A,B,C and they fit perfectly. However, in reading Mod 74, it lists the pins as W24/7. When reading Mod 52, in the body of the text talking about socket assembly, it relates the new W24/5 pin should be test fit. So, can someone tell me the difference between the W24/7, W24/5 and W24/4 terminology as it relates to the pins? I know it is proabably a simple answer for this esteemed group, but I appreciate any info as I am trying to increase my knowledge of this wonderful aircraft. Tyler J. ________________________________________________________________________________
Date: Nov 22, 2012
Subject: Re: Rear Wing Pins W 24
Tyler,=0A-=0ARe Wing pins, W 24, I recently replaced the W 24 wing pins o n my Europa XS, and was surprised at the increased length of the threaded p ortion of the pin that arrived. (Approx 3 times longer than removed pins). =0A-=0AI rang Karen at the Europa factory to check that the part was of t he correct specification.=0A-=0AThe reply was that the long pin was now s tandard , as supplied for the mod 52 (classic wing) modification, ie the pi n is long enough to-pass through the mounting plates, and after cutting a hole in the underside (of the classic) wing-a flox resin pad is created under a washer and nylock nut, hence the longer thread.-=0A-=0ASo a che ck assembly (dry run) should confirm if the installed pin length will allow the nut and washer to all fit.=0A-=0AOr ring Karen first-at the Europa factory and ask if the pins they stock are the same size as the pin you ha ve ( and the current part number) she is very helpful .=0A-=0APS when you go ahead get your inspectors sign off before you close up the access hole !=0A-=0ARegards=0A-=0AKevin=0A =0A=0A________________________________ =0A From: Tyler J <helidogtyler(at)gmail.com>=0ATo: Europa-List(at)matronics.com =0ASent: Thursday, 22 November 2012, 19:35=0ASubject: Europa-List: Rear Win g Pins=0A =0A=0AI just recently purchased a partially completed monowheel "classic"-kit.- The rear wing pins have not been installed and I have a ll the parts for Mod 52.- The pins with the Mod are sized-W24/4 and-b ecause I was unsure whether they were the original W24 pin or new, -I tes t fit them into the socket assembly W26A,B,C and they fit perfectly.- How ever, in reading Mod 74, it lists the pins as W24/7.- When reading Mod 52 , in the body of the text talking about socket assembly, it relates the new W24/5 pin should be test fit.- So, can someone tell me the difference be tween the W24/7, W24/5 and W24/4 terminology as it relates to the pins?- I know it is proabably a simple answer for this esteemed group, but I appre ciate any info as I am trying to increase my knowledge of this wonderful ai ________________________________________________________________________________
Date: Nov 23, 2012
Subject: "Black Friday" For List Fund Raiser...?
Dear Listers, The number of List subscriptions are up by a fair amount this year, but support during this year's Fund Raiser is substantially behind last year, and there's only about a week left until the end of the Fund Raiser. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid, other sources of income might be required including some sort of advertising. Please don't let that happen! Your personal Contribution of $20 or $30 goes a long ways to keeping this operation a float. Please make sure your name is on this year's List of Contributors! The List Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 23, 2012
Subject: Monowheel brake disc
SGkgYWxsLA0KVGhpcyBtZXNzYWdlIGlzIGZvciBidWlsZGVyIGhhdmUgbWFkZSB0cmktZ2VhciBj b252ZXJzaW9uLiBBZnRlciBteSBzb24gYnV5IGEgbW9ub3doZWVsICg1NTAgaG91cnMpIHdlIGhh dmUgbWFkZSBhIHRyaS1nZWFyIGNvbnZlcnNpb24uDQpGb3IgbXkgbW9ub3doZWVsIEkgaGF2ZSBw cm9qZWN0IHRvIHVzZSB0aGlzIHdoZWVsIHdpdGggYSBDb25kb3IgdGlyZSwgZHVyaW5nIHJlcGxh Y2VtZW50IHRpcmUgSSBkaXNjb3ZlciB0aGF0IHRoZSBicmFrZSBkaXNjIHN1cHBvcnQgKHdoZWVs IHNpZGUgb3Bwb3NpdGUgdG8gdGhlIGRpc2MpIGhhdmUgZGVmb3JtYXRpb24gYWJvdXQgMiBtbS4N Cg0KRG9lcyBhbnlvbmUgaGF2ZSBtb25vd2hlZWwgYnJha2UgZGlzYyBhdmFpbGFibGUgKHdpdGgg bm8gbWFueSBob3VycyBmbGlnaHQpIG5vIGRlZm9ybWF0aW9uIG9uIHRoZSBvcHBvc2l0ZSBzdXJm YWNlIG9mIHRoZSBkaXNjICh3aGVlbCBzaWRlKS4gc2VlIHRoZSBkcmF3aW5nIGpvaW50Lg0KSSBh bSBpbnRlcmVzdGVkLg0KDQpNYW55IFRoYW5rcw0KDQpNaWNoZWwgQVVWUkFZDQoNCg0KDQoNCg0K DQpGcm9tOiBUeWxlciBKDQpEYXRlOiAyMDEyLTExLTIyIDIwOjM1DQpUbzogRXVyb3BhLUxpc3QN ClN1YmplY3Q6IEV1cm9wYS1MaXN0OiBSZWFyIFdpbmcgUGlucw0KSSBqdXN0IHJlY2VudGx5IHB1 cmNoYXNlZCBhIHBhcnRpYWxseSBjb21wbGV0ZWQgbW9ub3doZWVsICJjbGFzc2ljIiBraXQuICBU aGUgcmVhciB3aW5nIHBpbnMgaGF2ZSBub3QgYmVlbiBpbnN0YWxsZWQgYW5kIEkgaGF2ZSBhbGwg dGhlIHBhcnRzIGZvciBNb2QgNTIuICBUaGUgcGlucyB3aXRoIHRoZSBNb2QgYXJlIHNpemVkIFcy NC80IGFuZCBiZWNhdXNlIEkgd2FzIHVuc3VyZSB3aGV0aGVyIHRoZXkgd2VyZSB0aGUgb3JpZ2lu YWwgVzI0IHBpbiBvciBuZXcsICBJIHRlc3QgZml0IHRoZW0gaW50byB0aGUgc29ja2V0IGFzc2Vt Ymx5IFcyNkEsQixDIGFuZCB0aGV5IGZpdCBwZXJmZWN0bHkuICBIb3dldmVyLCBpbiByZWFkaW5n IE1vZCA3NCwgaXQgbGlzdHMgdGhlIHBpbnMgYXMgVzI0LzcuICBXaGVuIHJlYWRpbmcgTW9kIDUy LCBpbiB0aGUgYm9keSBvZiB0aGUgdGV4dCB0YWxraW5nIGFib3V0IHNvY2tldCBhc3NlbWJseSwg aXQgcmVsYXRlcyB0aGUgbmV3IFcyNC81IHBpbiBzaG91bGQgYmUgdGVzdCBmaXQuICBTbywgY2Fu IHNvbWVvbmUgdGVsbCBtZSB0aGUgZGlmZmVyZW5jZSBiZXR3ZWVuIHRoZSBXMjQvNywgVzI0LzUg YW5kIFcyNC80IHRlcm1pbm9sb2d5IGFzIGl0IHJlbGF0ZXMgdG8gdGhlIHBpbnM/ICBJIGtub3cg aXQgaXMgcHJvYWJhYmx5IGEgc2ltcGxlIGFuc3dlciBmb3IgdGhpcyBlc3RlZW1lZCBncm91cCwg YnV0IEkgYXBwcmVjaWF0ZSBhbnkgaW5mbyBhcyBJIGFtIHRyeWluZyB0byBpbmNyZWFzZSBteSBr bm93bGVkZ2Ugb2YgdGhpcyB3b25kZXJmdWwgYWlyY3JhZnQuDQoNClR5bGVyIEouDQoNCg0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCl8tPQ0KXy09ICAgICAgIC0tIFBsZWFzZSBTdXBwb3J0IFlvdXIgTGlzdHMgVGhpcyBNb250 aCAtLQ0KXy09ICAgICAgICAgICAoQW5kIEdldCBTb21lIEFXRVNPTUUgRlJFRSBHaWZ0cyEpDQpf LT0NCl8tPSAgIE5vdmVtYmVyIGlzIHRoZSBBbm51YWwgTGlzdCBGdW5kIFJhaXNlci4gIENsaWNr IG9uDQpfLT0gICB0aGUgQ29udHJpYnV0aW9uIGxpbmsgYmVsb3cgdG8gZmluZCBvdXQgbW9yZSBh Ym91dA0KXy09ICAgdGhpcyB5ZWFyJ3MgVGVycmlmaWMgRnJlZSBJbmNlbnRpdmUgR2lmdHMgcHJv dmlkZWQNCl8tPSAgIGJ5Og0KXy09ICAgDQpfLT0gICAgICogQWVyb0VsZWN0cmljIHd3dy5hZXJv ZWxlY3RyaWMuY29tDQpfLT0gICAgICogVGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3LmJ1aWxk ZXJzYm9va3MuY29tDQpfLT0gICAgICogSG9tZWJ1aWx0SEVMUCB3d3cuaG9tZWJ1aWx0aGVscC5j b20NCl8tPQ0KXy09ICAgTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6DQpfLT0NCl8tPSAgIC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT0NCl8tPSAgIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09DQpfLT0gICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0NCl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0g ICAgICAgICAgLSBUaGUgRXVyb3BhLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0 cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExp c3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBT ZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFy ZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL05hdmlnYXRvcj9FdXJvcGEtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAg ICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28g YXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1 bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ= ________________________________________________________________________________
Subject: Re: Monowheel brake disc
From: RCC Sky Mail <richard.churchill-coleman(at)sky.com>
Date: Nov 23, 2012
Michel I have just bought the Beringer mono wheel and brake kit for my unbuilt XS m ono. As a result i have all the parts of the unused original mono wheel and b rake set available for sale, together or separately. Kind regards Richard On 23 Nov 2012, at 10:22, mau11 wrote: > Hi all, > This message is for builder have made tri-gear conversion. After my son bu y a monowheel (550 hours) we have made a tri-gear conversion. > For my monowheel I have project to use this wheel with a Condor tire, duri ng replacement tire I discover that the brake disc support (wheel side oppos ite to the disc) have deformation about 2 mm. > > Does anyone have monowheel brake disc available (with no many hours flight ) no deformation on the opposite surface of the disc (wheel side). see the d rawing joint. > I am interested. > > Many Thanks > > Michel AUVRAY > > > > From: Tyler J > Date: 2012-11-22 20:35 > To: Europa-List > Subject: Europa-List: Rear Wing Pins > I just recently purchased a partially completed monowheel "classic" kit. T he rear wing pins have not been installed and I have all the parts for Mod 5 2. The pins with the Mod are sized W24/4 and because I was unsure whether t hey were the original W24 pin or new, I test fit them into the socket assem bly W26A,B,C and they fit perfectly. However, in reading Mod 74, it lists t he pins as W24/7. When reading Mod 52, in the body of the text talking abou t socket assembly, it relates the new W24/5 pin should be test fit. So, can someone tell me the difference between the W24/7, W24/5 and W24/4 terminolo gy as it relates to the pins? I know it is proabably a simple answer for th is esteemed group, but I appreciate any info as I am trying to increase my k nowledge of this wonderful aircraft. > > Tyler J. > > > ========================= > lectric.com > m">www.buildersbooks.com > ebuilthelp.com > w.matronics.com/contribution > ========================= > http://www.matronics.com/Navigator?Europa-List > ========================= > nics.com > ========================= > > ________________________________________________________________________________
Subject: Battery Charging
Date: Nov 23, 2012
Hello All. Winter is coming, its not a good time for Batteries in the cold weather. Has anyone fitted an external charging point to the fuselage. My Battery is located in the rear on the Starboard side of the plane. Is there a purpose make kit on the market one can use,? Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388767#388767 ________________________________________________________________________________
Subject: Electrics
Date: Nov 24, 2012
Does anybody know what retains the cables pushed into the terminal block (see photo)? The ignition circuit kill wires are the two white cables and we have had some trouble with these not making a good connection. There are rubber grommets that fit around the wires and appear to be the only means of securing a contact by applying pressure to the cable when fitted inside the block. Peter Field. G-CHOX ________________________________________________________________________________
Subject: Electrics
Date: Nov 24, 2012
Hi! Peter, The grommets are to stop the ingress of water and maintain the wire central, so mine are mounted vertically, perhaps that would help ? I presume that you have a tang crimped to the wire which engages in the slot in the socket from memory? Regards Bob Harrison. From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Field Sent: 24 November 2012 10:39 Subject: Europa-List: Electrics Does anybody know what retains the cables pushed into the terminal block (see photo)? The ignition circuit kill wires are the two white cables and we have had some trouble with these not making a good connection. There are rubber grommets that fit around the wires and appear to be the only means of securing a contact by applying pressure to the cable when fitted inside the block. Peter Field. G-CHOX ________________________________________________________________________________
Subject: Electrics
Date: Nov 24, 2012
Hi Pete, I can see from your photo that these white wires are not pushed fully home. You will notice that each of the other wires in the plastic multi connector shows two black/dark coloured parallel strips just inside where they enter the connector block. These are water seals. If you now look at your two offending white wires these strips do not look the same because they are not fully pushed home. So the answer to your question is to push them further in. You will find that they pop into place when in the correct position and should then look like the other wires. Give it a try, think you will find this fixes your problem. Pete _____ From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Field Sent: 24 November 2012 10:39 Subject: Europa-List: Electrics Does anybody know what retains the cables pushed into the terminal block (see photo)? The ignition circuit kill wires are the two white cables and we have had some trouble with these not making a good connection. There are rubber grommets that fit around the wires and appear to be the only means of securing a contact by applying pressure to the cable when fitted inside the block. Peter Field. G-CHOX _____ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Nov 24, 2012
Thank you for the information. On Nov 22, 2012, at 2:04 PM, K BURNS wrote: > Tyler, > > Re Wing pins, W 24, I recently replaced the W 24 wing pins on my Europa XS , and was surprised at the increased length of the threaded portion of the p in that arrived. (Approx 3 times longer than removed pins). > > I rang Karen at the Europa factory to check that the part was of the corre ct specification. > > The reply was that the long pin was now standard , as supplied for the mod 52 (classic wing) modification, ie the pin is long enough to pass through t he mounting plates, and after cutting a hole in the underside (of the classi c) wing a flox resin pad is created under a washer and nylock nut, hence the longer thread. > > So a check assembly (dry run) should confirm if the installed pin length w ill allow the nut and washer to all fit. > > Or ring Karen first at the Europa factory and ask if the pins they stock a re the same size as the pin you have ( and the current part number) she is v ery helpful . > > PS when you go ahead get your inspectors sign off before you close up the a ccess hole ! > > Regards > > Kevin > > From: Tyler J <helidogtyler(at)gmail.com> > To: Europa-List(at)matronics.com > Sent: Thursday, 22 November 2012, 19:35 > Subject: Europa-List: Rear Wing Pins > > I just recently purchased a partially completed monowheel "classic" kit. T he rear wing pins have not been installed and I have all the parts for Mod 5 2. The pins with the Mod are sized W24/4 and because I was unsure whether t hey were the original W24 pin or new, I test fit them into the socket assem bly W26A,B,C and they fit perfectly. However, in reading Mod 74, it lists t he pins as W24/7. When reading Mod 52, in the body of the text talking abou t socket assembly, it relates the new W24/5 pin should be test fit. So, can someone tell me the difference between the W24/7, W24/5 and W24/4 terminolo gy as it relates to the pins? I know it is proabably a simple answer for th is esteemed group, but I appreciate any info as I am trying to increase my k nowledge of this wonderful aircraft. > > Tyler J. > http://www.matronics.com/contributuropa-List" rel="nofollow" target="_ blank">http://www.matronics.com/Nav.matronics.com/" rel="nofollow" target= "_blank">http://forums.matronics=============== == > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Nov 24, 2012
Subject: Re: Electrics
On 11/24/2012 11:39 AM, Peter Field wrote: > Does anybody know what retains the cables pushed into the terminal block > (see photo)? The ignition circuit kill wires are the two white cables > and we have had some trouble with these not making a good connection. Apart from that they are not pushed fully home, as some others have mentioned, I see a few more worrying things. First, these wires should go to your ignition-switch and nowhere else. But within a very short distance I see a screw terminal (which are invented to connect lamp sockets to your house wiring - vibration free -, but are totally unsuitable for car purposes, let alone aircraft purposes), and some (soldered) connection within a shrink tube. Why is there not just a straigth cable going to your ignition switch? This is just asking for trouble, and it looks like your trouble already started. The vast majority of electrical failures are due to bad connections, so you should keep the amount of connections down to the absolute minimum, and where unavoidable, use high quality connectors (and houshold screw terminals do not in the least qualify for this). Furthermore it looks like some bare metal wires are poking out of the wires coming out of the screw terminal. I'm not sure what I'm seeing here but if these metal wires are connected to the ignition wire, they just have to touch anything and your ignition is killed. To elaborate more on connectors: The problem with these screw terminals is that they do not separate the electrical and mechanical connection. An electrical connection (clamping) creates a stress point in the metal, and any movement (vibration) focuses on this stress point using the rest of the wire as a lever, quickly causing metal fatigue and unexpected and unpredictable break of the wire. A good connector always has some way to retain the wire upstream of the electrical connection, so that the electrical connection point is absolutely free from any movement. (This also applies to soldering: Any solder joint should be free from any movement and vibration). For connecting a lamp socket to your house wiring that screw terminal is ok, because houses do not move or vibrate very often. If you ever have a carb going bad and your engine starts to shake or vibrate heavily, within a few minutes the wire will fall from the screw terminal. When that happens, the wire will dangle down and if it touches some metal it will kill the ignition. Frans ________________________________________________________________________________
Subject: Running too cool, considering blocking some of intake
Date: Nov 24, 2012
My 912ULS runs too cool at around 80deg C, as I have the cowl home I am wondering about blocking some of the radiator air intake off, maybe half of it and adding a couple of LED landing lights. Some sort of variable vent might be best though. Any suggestions? -------- Graeme Bird G-UMPY Mono Classic/XS FWFD 912ULS/Woodcomp 3000/W Newby: 35 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388801#388801 ________________________________________________________________________________
Subject: tri gear socket installation
Date: Nov 24, 2012
Hello Today I have been busy trial fitting my gear sockets. but I have got a problem and wondered if anyone has experience this during building and how they have overcome it? After taking my time setting everything up as per the build manual I inserted the gear legs and sockets into the holes clamping the axle's in position against angled bar with the axle center line on fuselage station 70 and the axle end 36.75' from the fuselage center line. With all this set up the socket flanges are approx 13 - 15 mm of the fuselage. I tried altering the fuselage underside to ground height but this made very little difference to the distance between socket flanges and the fuselage. I managed to get the gap down to approx 5-8mm by reducing the fuselage underside to ground height to 395mm, this is very different to the 413mm quoted in the build manual. I have attached some photos showing the gap between sockets and fuselage and also the position of the socket tubes within the baggage bays when inserted. Any comments or solutions to my problem would be much appreciated. Many thanks for taking the time in trying to help me find a solution to the problems I'm experiencing. Kind regards Donald -------- Fireflier Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388820#388820 Attachments: http://forums.matronics.com//files/port_axle_494.jpeg http://forums.matronics.com//files/starboard_axle_172.jpeg http://forums.matronics.com//files/starboard_socket_position_in_baggage_bay_539.jpeg http://forums.matronics.com//files/starboard_leg_socket_188.jpg http://forums.matronics.com//files/port_socket_position_in_baggage_bay_886.jpg http://forums.matronics.com//files/port_leg_socket_744.jpeg ________________________________________________________________________________
Date: Nov 25, 2012
How long are your sockets from the bolt hole, to bottom of the tube, at the rear of the socket eg near the tail Mine measure at 245mm (9.5 inches), perhaps yours are longer than they should be. My gap when installed was about 4mm. Regards craig ________________________________________________________________________________
Date: Nov 25, 2012
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal, or a personal check: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 25, 2012
Hello Peter, If you want to remake those white-wire connections, I can supply you (for free) with the correct crimp terminals (male & female) for that Rotax connector. Cheers, Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388904#388904 ________________________________________________________________________________
Subject: Re: tri gear socket installation
Date: Nov 25, 2012
Hi Donald, 1/2'' to 5/8'' gaps betwen the socket flange and the outer skin is not unus ual, I could never work out where the variation came from ? Most important is the ST 70 dimension. Then ensure the track is true with the legs clamped to an angle straight ed ge.Take measurements from tailplane torque tube ends to check this. Then ensure the horizontal datum of the angle aligns with the aircrafts hor izontal datum [ tailplane torque tube / wing spar bushes ]. Then check the lateral position from the aircrafts centre line [ also check the positive camber of the axle shafts and adjust [ worsen] the side to si de positioning to get the camber of the shafts nearer to each other. Forget about closing up the gap between the socket flanges and the fuselage skin. If you can close up the gap [ dropping the fuselage ] without buggering up any of the other parameters, well and good, otherwise go for it and use a t hick Redux pad in the gap. I have slipped in some plywood shims to bulk out the gap if it as large as you describe [ Redux is expensive, slivers of wo od will be free !] Other things I do different, the lay up of the socket to Rib 1, don't smear Redux on the socket and do the lay up with Ampreg, do a HOT Redux lay up i n 1 ply of Bid, 2'' onto each side of the Rib around the socket, peel ply a nd let cure. Then do the lay ups as per Manual. Do a hot Redux lay up on the outer face of the socket flange, peel ply etc, before doing the 2 Bid lay up on to the skin. Do the hot Redux lay ups ont o plastic sheet, wet out well, then slap it on like an elastoplast ! Ampreg doesn't stick too well to steel, and I don't like messing with two d ifferent epoxy systems going wet on wet ? Cheers, Nev. -----Original Message----- From: fireflier <fireflier(at)btinternet.com> Sent: Sun, 25 Nov 2012 1:04 Subject: Europa-List: tri gear socket installation Hello Today I have been busy trial fitting my gear sockets. but I have got a prob lem nd wondered if anyone has experience this during building and how they have vercome it? After taking my time setting everything up as per the build manual I insert ed he gear legs and sockets into the holes clamping the axle's in position aga inst ngled bar with the axle center line on fuselage station 70 and the axle end 6.75' from the fuselage center line. With all this set up the socket flang es re approx 13 - 15 mm of the fuselage. I tried altering the fuselage underside to ground height but this made very ittle difference to the distance between socket flanges and the fuselage. I anaged to get the gap down to approx 5-8mm by reducing the fuselage undersi de o ground height to 395mm, this is very different to the 413mm quoted in the uild manual. I have attached some photos showing the gap between sockets and fuselage an d lso the position of the socket tubes within the baggage bays when inserted. Any comments or solutions to my problem would be much appreciated. Many thanks for taking the time in trying to help me find a solution to the roblems I'm experiencing. Kind regards onald -------- ireflier ead this topic online here: http://forums.matronics.com/viewtopic.php?p=388820#388820 ttachments: http://forums.matronics.com//files/port_axle_494.jpeg ttp://forums.matronics.com//files/starboard_axle_172.jpeg ttp://forums.matronics.com//files/starboard_socket_position_in_baggage_bay_ 539.jpeg ttp://forums.matronics.com//files/starboard_leg_socket_188.jpg ttp://forums.matronics.com//files/port_socket_position_in_baggage_bay_886.j pg ttp://forums.matronics.com//files/port_leg_socket_744.jpeg -======================== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Europa-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Europa-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Date: Nov 25, 2012
Donald, Obviously, writing a post after Nev I have little to add on how to do things right. I did however have the same problem and in my case at least it turned out to be faulty measurements. There are quite a few variables and any one of them can knock the measurements off. My garage for instance has a drain in the middle and the floors slope very slightly towards that. I ended up having to grind the whole lot out again. The second time round the plates did fit against the skin. It really is worth checking everything 10 times to avoid that. See: http://www.europaowners.org/main.php?g2_itemId=44767 Regards, -------- Jeroen http://www.europaowners.org/main.php?g2_itemId=44165 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388911#388911 ________________________________________________________________________________
Date: Nov 25, 2012
On 11/25/2012 03:41 PM, jglazener wrote: > Obviously, writing a post after Nev I have little to add on how to do > things right. I did however have the same problem and in my case at > least it turned out to be faulty measurements. There are quite a few > variables and any one of them can knock the measurements off. My > garage for instance has a drain in the middle and the floors slope > very slightly towards that. To avoid this problem I welded two vertical bars to my build craddle with adjustable ends, so I could attach an artificial floor straight edge to it, and adjust everything independantly from the floor. This might be a solution for you if your floor is not perfectly even, or when you use a movable build craddle. Also make sure you end up with some degree of toe in on the axles, as the aircraft weight and roll friction will push the wheels outward a little. This prevents the problem that the tires wear prematurely on the inboard side. (After 200 hours, I still have even wear on the tires, never had to swap or reverse them). > It really is worth checking everything 10 times to avoid that. Yep, don't rush it. It is hard to readjust later on. Frans ________________________________________________________________________________
Date: Nov 25, 2012
Subject: Re: Running too cool, considering blocking some of intake
graeme bird a crit : > > My 912ULS runs too cool at around 80deg C, as I have the cowl home I am wondering about blocking some of the radiator air intake off, maybe half of it and adding a couple of LED landing lights. Some sort of variable vent might be best though. Any suggestions? > Hi Graeme, http://contrails.free.fr/engine_aerodyn_radia_en.php http://contrails.free.fr/tunnel_en.php http://contrails.free.fr/engine_air_inlets.php Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Subject: starboard door
Date: Nov 25, 2012
Hi There all, To-day flight was cut short because the starboard (probably badly secured) departed from the ship 10 mn after takeoff. As we speak we don't know where it grounded but at least on quite on a no-man's land. Luckily no other damage and normal flying back and landing. Has anyone a complete starboard door available for sale (best would be with bronze window but we'll consider every proposal)? Max Cointe F-PMLH Europa_TriGear Kit #560 912ULS Airmaster 450 hours mcointe(at)free.fr ________________________________________________________________________________
Date: Nov 25, 2012
Graeme, > My 912ULS runs too cool at around 80deg C, as I have the cowl home I am > wondering about blocking some of the radiator air intake off, maybe half of it > and adding a couple of LED landing lights. Some sort of variable vent might be > best though. Any suggestions? I have for several years flown in cold and hot weather with Van's variable shutter in front of approx. 50% of the radiator - see attached photo (the photo was taken before I installed an oil thermostat, so I have no plates in front of the oil cooler anymore). My 912ULS has 50/50 glycol/water, and I have not experienced problems even on hot airfields. However, to be on the safe side if flying much in hot summers, the shutter can be removed in 30 minutes for such seasonal flying, as this will allow more air to pass through the radiator. I purchased the shutter fra Van's Aircraft in the US, and the Bowden cable with accessories from Aircraft Spruce. Regards, Svein LN-SKJ ________________________________________________________________________________
Subject: Handheld with external antenna
Date: Nov 25, 2012
Hi Max, So sorry to read about your sudden cabriolet conversion. Did you have a chance to test the Icom handheld with the external antenna before this happened? If so, how did it work? I have now purchased the AAE VHF-5T antenna, which I plan to fix vertically to the fuselage inside skin on the right side behind the luggage bay bulkhead (I have the transponder antenna on the left side). Any particular recommendations (e.g. type of adhesive that you used). Regards, Svein LN-SKJ ________________________________________________________________________________
Subject: Re: SV: Running too cool, considering blocking some of intake
Date: Nov 25, 2012
Thats very neat, thanks. I am wondering though if its really a problem to be running at 80deg. I tend to get higher temps initially at take off which would get rid of condensation etc. What happens when the engine is running warmer? I cant see any particular reference in the Rotax manual. I guess I could just tape over half of it with aluminium tape and see for now. -------- Graeme Bird G-UMPY Mono 912S/Woodcomp 3000/3W Newby: 45 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388922#388922 ________________________________________________________________________________
intake
Date: Nov 25, 2012
Graeme, I always run with at least 50% of the radiator sealed off with duct tape during the winter months down here in coldest (?) Kent on my monowheel/912S Dave Watts G-BXDY -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of graeme bird Sent: 25 November 2012 18:06 Subject: Europa-List: Re: SV: Running too cool, considering blocking some of intake Thats very neat, thanks. I am wondering though if its really a problem to be running at 80deg. I tend to get higher temps initially at take off which would get rid of condensation etc. What happens when the engine is running warmer? I cant see any particular reference in the Rotax manual. I guess I could just tape over half of it with aluminium tape and see for now. -------- Graeme Bird G-UMPY Mono 912S/Woodcomp 3000/3W Newby: 45 hours g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388922#388922 ________________________________________________________________________________
Date: Nov 25, 2012
Donald,=0A-=0AThe build manual says:-=0A-"If necessary, to ensure that the plate of the gear leg socket is against the side of the fuselage,move t he=0Aaxles as required relative to the fuselage centreline keeping the axle centres on FS70".=0A-=0ABy moving the legs in 1/2 an inch or so equaly o n each side , you will close up the gap to a wedge shape, the manual also s ugests the socket flanges can be adjusted to fit the profile better.=0A- =0AMy fit was-close enougth-for an acceptable-redux filling, after ad justing-the fuselage holes slightly, but it does appears that your legs n eed to come together slightly-.=0A-=0A-=0AThere will be differences i n exact positioning of the sockets due variations -to the elogation requi red of the hole.=0A-=0ATwo-extra check measurement that I-found usefu ll-were from a second angle iron ran through the cockpit, sat on the door sills,pushed hard against the seat back, and dropped a plumbline from the inboard end to find a measurement from the spar face reference points :-=0A -Not e :- F S 70 is 2.25" aft of the forward face of the port spar=0A ------------------------- -- 1.00 aft of the forward face of the Starboard spar.=0A-=0AMark up the fuselage to get a measurement to transfer from your second angle iron / -plumb line, stick a spirit level on the angle Iron to check it is all pa rallel when setting up , and stand back an look at the job, making sure it is all square...=0A-=0AAlso, make sure your build cradle is squared off o n all corners, and can not move.=0A-=0AI set up a false floor with 3 laye rs of 3/4 ply,screwed down onto a pallet, with a timber beam accross to scr ew down and clamp on, you will end up spending days setting your measuremen ts unless everything is fastened down solid.=0A-=0AFinaly, you can do a d ry run by lifting the sockets and legs to a flush position ,an using the fi rst wedge shaped ply brace, hold the assembly in possition , then look at t he axle to see how far in it is sitting .=0A-=0AYou are trying to acheive aligned axles on FS 70, within the factory height specified (prop clearanc e)- 1/2 " or so different track width will make no significant difference , and is the factory recomended solution per the manual.=0A-=0ARegards =0A-=0AKevin=0A-=0A-=0A--=0A-=0A-=0A-=0A- =0A=0A_________ _______________________=0A From: fireflier <fireflier(at)btinternet.com>=0ATo: europa-list(at)matronics.com =0ASent: Sunday, 25 November 2012, 1:02=0ASubjec t: Europa-List: tri gear socket installation=0A =0A--> Europa-List message posted by: "fireflier" =0A=0AHello=0A=0AToday I have been busy trial fitting my gear sockets. but I have got a problem and wondered if anyone has experience this during building and how they have ov ercome it?=0A=0AAfter taking my time setting everything up as per the build manual I inserted the gear legs and sockets into the holes clamping the ax le's in position against angled bar with the axle center line on fuselage s tation 70 and the axle end 36.75' from the fuselage center line.- With al l this set up the socket flanges are approx 13 - 15 mm of the fuselage.=0A =0AI tried altering the fuselage underside to ground height but this made v ery little difference to the distance between socket flanges and the fusela ge.- I managed to get the gap down to approx 5-8mm by reducing the fusela ge underside to ground height to 395mm, this is very different to the 413mm quoted in the build manual.=0A=0AI have attached some photos showing the g ap between sockets and fuselage and also the position of the socket tubes w ithin the baggage bays when inserted.=0A=0AAny comments or solutions to my problem would be much appreciated.=0A=0AMany thanks for taking the time in trying to help me find a solution to the problems I'm experiencing.=0A=0AKi nd regards=0ADonald=0A=0A--------=0AFireflier=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=388820#388 820=0A=0A=0A=0A=0AAttachments: =0A=0Ahttp://forums.matronics.com//files/por t_axle_494.jpeg=0Ahttp://forums.matronics.com//files/starboard_axle_172.jpe g=0Ahttp://forums.matronics.com//files/starboard_socket_position_in_baggage _bay_539.jpeg=0Ahttp://forums.matronics.com//files/starboard_leg_socket_188 .jpg=0Ahttp://forums.matronics.com//files/port_socket_position_in_baggage_b ay_886.jpg=0Ahttp://forums.matronics.com//files/port_leg_socket_744.jpeg=0A == ________________________________________________________________________________
Date: Nov 25, 2012
Nev, Donald, and others having tri gear concerns. Nev is right that the gap is really not that much of a concern especially at 5-8 mm. Organizing the project for efficiency of work comes with practice. The adjustment of the height of the fuselage to gear plane is one excellent way to make and adjustment to the fit. Just don't get too carried away, keep it close to the vertical distance in the book, which keeps the tail from being too low (nose gear higher means banging it more often) or too high which increases the camber angle making tire wear increase. I do bend the flanges a bit to allow me not to have to use as much Redux. Then just bond it in. Unlike Nev, I prefer to glue in the cleaned and dimpled metal sockets first and allow to cure, then put in Rib one the next day. If working alone, I put in both rib ones and let them partially cure, getting a long coffee break. If working with an assistant, we return when the ribs are firm and apply Aeropoxy or Ampreg flox to fill the gaps at the walls and smooth our Redux job a bit and apply more Redux to the leg face for a good bond and follow with the number one layups. If we are making good time, we lay on rib two with Redux then take a quick lunch break. We come back and while the Redux is a bit sticky but the rib is in firmly, we lay in more flox and glass it up. Then I allow it to cure with a bit of peel ply. That makes for a really long day though. However, if you're not on with your glassing MOJO, as the kids say, then I do rib two the next day. Of course you can gather that the one and two ribs are carefully cut to a tight fit and ready to install before hand. In a perfect world, the next day I do the trimming of the three and four ribs and install them. Your back will really need a break when done. Then take the gear out and glass in the bottom. If working alone, and if the top is on already, work gets slowed down a bit, so one rib a day is normally the rule. It is getting winter time, so heating of the project is necessary so it also tends to slow the project a bit. >From start to finish, one week to get the plane level and set, ribs in and legs on. That leaves the next week to get the wheels and brakes in and operating, and the plane rolling. Week three is needed for the wheel pants and such. Then you need a much deserved break but only a short one, as there is more to do. Getting the monowheel hole closed up and figure how to get a lower access hole installed and fuel lines cleaned up and accessories in that big old cockpit module hole. Regards, Bud Yerly ----- Original Message ----- From: Neville Eyre<mailto:neveyre(at)aol.com> To: europa-list(at)matronics.com Sent: Sunday, November 25, 2012 3:57 AM Subject: Re: Europa-List: tri gear socket installation Hi Donald, 1/2'' to 5/8'' gaps betwen the socket flange and the outer skin is not unusual, I could never work out where the variation came from ? Most important is the ST 70 dimension. Then ensure the track is true with the legs clamped to an angle straight edge.Take measurements from tailplane torque tube ends to check this. Then ensure the horizontal datum of the angle aligns with the aircrafts horizontal datum [ tailplane torque tube / wing spar bushes ]. Then check the lateral position from the aircrafts centre line [ also check the positive camber of the axle shafts and adjust [ worsen] the side to side positioning to get the camber of the shafts nearer to each other. Forget about closing up the gap between the socket flanges and the fuselage skin. If you can close up the gap [ dropping the fuselage ] without buggering up any of the other parameters, well and good, otherwise go for it and use a thick Redux pad in the gap. I have slipped in some plywood shims to bulk out the gap if it as large as you describe [ Redux is expensive, slivers of wood will be free !] Other things I do different, the lay up of the socket to Rib 1, don't smear Redux on the socket and do the lay up with Ampreg, do a HOT Redux lay up in 1 ply of Bid, 2'' onto each side of the Rib around the socket, peel ply and let cure. Then do the lay ups as per Manual. Do a hot Redux lay up on the outer face of the socket flange, peel ply etc, before doing the 2 Bid lay up on to the skin. Do the hot Redux lay ups onto plastic sheet, wet out well, then slap it on like an elastoplast ! Ampreg doesn't stick too well to steel, and I don't like messing with two different epoxy systems going wet on wet ? Cheers, Nev. -----Original Message----- From: fireflier <fireflier(at)btinternet.com> To: europa-list Sent: Sun, 25 Nov 2012 1:04 Subject: Europa-List: tri gear socket installation > Hello Today I have been busy trial fitting my gear sockets. but I have got a problem and wondered if anyone has experience this during building and how they have overcome it? After taking my time setting everything up as per the build manual I inserted the gear legs and sockets into the holes clamping the axle's in position against angled bar with the axle center line on fuselage station 70 and the axle end 36.75' from the fuselage center line. With all this set up the socket flanges are approx 13 - 15 mm of the fuselage. I tried altering the fuselage underside to ground height but this made very little difference to the distance between socket flanges and the fuselage. I managed to get the gap down to approx 5-8mm by reducing the fuselage underside to ground height to 395mm, this is very different to the 413mm quoted in the build manual. I have attached some photos showing the gap between sockets and fuselage and also the position of the socket tubes within the baggage bays when inserted. Any comments or solutions to my problem would be much appreciated. Many thanks for taking the time in trying to help me find a solution to the problems I'm experiencing. Kind regards Donald -------- Fireflier Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388820#388820 .matronics.com/viewtopic.php?p=388820#388820> Attachments: http://forums.matronics.com//files/port_axle_494.jpeg nics.com//files/port_axle_494.jpeg> http://forums.matronics.com//files/starboard_axle_172.jpeg matronics.com//files/starboard_axle_172.jpeg> http://forums.matronics.com//files/starboard_socket_position_in_baggage_b ay_539.jpeg<http://forums.matronics.com//files/starboard_socket_position_ in_baggage_bay_539.jpeg> http://forums.matronics.com//files/starboard_leg_socket_188.jpg rums.matronics.com//files/starboard_leg_socket_188.jpg> http://forums.matronics.com//files/port_socket_position_in_baggage_bay_88 6.jpg<http://forums.matronics.com//files/port_socket_position_in_baggage_ bay_886.jpg> http://forums.matronics.com//files/port_leg_socket_744.jpeg .matronics.com//files/port_leg_socket_744.jpeg> _blank>www.aeroelectric.com /" target=_blank>www.buildersbooks.com =_blank>www.homebuilthelp.com blank>http://www.matronics.com/contribution arget=_blank>http://www.matronics.com/Navigator?Europa-List p://forums.matronics.com www.aeroelectric.com<http://www.aeroelectric.com/> www.buildersbooks.com<http://www.buildersbooks.com/> www.homebuilthelp.com<http://www.homebuilthelp.com/> http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> ________________________________________________________________________________
intake
Date: Nov 25, 2012
Photo E-mail View slideshow | Download images According to Rotax there is not a technical minimum cylinder temp but I agree that we know that a warmer cylinder will be more efficient and the crankcase and gearbox will not harbor water in the case. The oil thermostat is one way to get up the oil temp. I have tried to make a simple rear flap to close up the back but you would not believe the pressure coming out of the rear of those radiators and the duct suction pulling on the other side of the flap. A moveable cowl flap will work, but then we're talking repaint of the cowl. So how do we get the glycol temp up? Tape over 1/3 of the glycol cooler is a start. Next is making a removable metal air dam in front of the glycol cooler, but that is not adjustable. So what is needed is an adjustable flap that can be set from the cockpit for those warmer winter days, spring and fall operations or high altitude cruise operations. Those adjustable slotted cooler shutters are a solution. Unless you need every bit of cooling air in the summer like I do here in Florida. Mark Ferkin of High wing LLC (Kitfox guy of fame) makes a shutter for the Rotax coolers. It doesn't work well for our setup but the concept works. Van's aircraft has the slotted flap as addressed above and used on other Northern Europa's but it does block the air needed for summer options. For oil cooling, I have installed the oil thermostat and it is very convenient and automatic so I'm waiting for it to fail... I really have only one idea for a moveable Europa style XS coolers with a two inch drop of the oil cooler. If you have one of my cockpit heaters be sure to leave a cutout for the heater or the cockpit heat gets shut off. See below: Regards, Bud Yerly Just a simple hinge setup with a flapper door to block the air coming out of the glycol cooler and pivoted near the center to reduce pull and hold forces. An oil cooler thermostat takes care of the oil temps. I really thought this would work but the force to hold the flap shut against the air outflow from the coolers (and draw of the cowl ramp) is considerable for a hinged flap at the leading edge. ----- Original Message ----- From: graeme bird<mailto:graeme(at)gdbmk.co.uk> To: europa-list(at)matronics.com Sent: Sunday, November 25, 2012 1:06 PM Subject: Europa-List: Re: SV: Running too cool, considering blocking some of intake > Thats very neat, thanks. I am wondering though if its really a problem to be running at 80deg. I tend to get higher temps initially at take off which would get rid of condensation etc. What happens when the engine is running warmer? I cant see any particular reference in the Rotax manual. I guess I could just tape over half of it with aluminium tape and see for now. -------- Graeme Bird G-UMPY Mono 912S/Woodcomp 3000/3W Newby: 45 hours g(at)gdbmk.co.uk Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=388922#388922 .matronics.com/viewtopic.php?p=388922#388922> www.aeroelectric.com<http://www.aeroelectric.com/> www.buildersbooks.com<http://www.buildersbooks.com/> www.homebuilthelp.com<http://www.homebuilthelp.com/> http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> These photos will be available on SkyDrive for 30 days. To learn more about SkyDrive, click here<http://g.msn.com/1cl91enus/PMFooter>. To share high quality pictures with your friends and family using MSN Photo E-mail, join MSN<http://g.msn.com/0PHenus1/29>. ________________________________________________________________________________
Date: Nov 25, 2012
of intake On 11/25/2012 07:06 PM, graeme bird wrote: > Thats very neat, thanks. I am wondering though if its really a > problem to be running at 80deg. There are a few reasons to keep the engine temperature higher: 1) Wear of the engine. Different parts of the engine expand at different rates when the engine gets warmer. Ideally, you have the engine running always at the same temperature, so all the parts wear in for exactly that specific temperature, and fit nicely together around that specific temperature, without too much friction of leakage. If the temperature changes, friction in some parts increases, and other parts become too sloppy. So, aim to keep the engine always wearing at the same temperature. For that reason, I always keep my engine at 115C and avoid wear at other temperatures. 80C could also if you manage to keep the engine running at that temperature during the summer, but then there are still a couple of other reasons to aim for a higher temperature: 2) Efficiency. The engine gets its energy from burning fuel, more exactly from producing heat, the temperature difference between the pressure of the air before and after the combustion. Ideally, there would be no losses. Unfortunately, we have to cool the engine, and by cooling we take precious energy away. The more we cool, the more we harm the efficiency. So to get the most bang for the buck, you will want to run the engine as hot as possible... without melting some parts. For the Rotax, this sweet point is close to 115C, which is a safe distance from 135C where the cylinder heads become soft and start to deform. 3) Condensation. Byproduct of combustion is water. Part of the combustion gasses including the water is escaping between the pistons and cylinder walls, anything below 100C will condensate this water. So. the condensation in the engine is not just something like the condensation in the fuel tank, but is actually produced at a high rate during your flight. (Don't underestimate the amount of these so called blow-by gasses; these gasses are actually responsible for transporting the oil back from the crankcase into the oil tank). If you run the engine at 80C you will collect a lot of water in the engine, and due to other substances in the fuel, the water will have a low pH and eat away the engine. If your engine only gets hot during take off, it is not sufficient to boil away all the water, and the water collected during the cruise will remain in the engine until the next take off, which might be a long time away, especially in the winter. So, it is best to keep the oil temp during the cruise above 100C to avoid collecting too much water. (You won't find the water at the bottom of the oil tank except in extreme cases, as the oil is formulated to keep a lot of water in suspension, but still this suspended water is corrosive and also worsens lubrication.) Frans ________________________________________________________________________________
Date: Nov 26, 2012
of intake SGkgQnVkIEkgc2VuZCB0byB5b3UgYSBkcmF3aW5nIG9mIG15IENvb2xlcnMgZmxhcC4NCk1pY2hl bCBBVVZSQVkNCkJ1aWxkZXIgMTQ1DQoNCg0KDQoNCg0KDQoNCkZyb206IEJ1ZCBZZXJseQ0KRGF0 ZTogMjAxMi0xMS0yNSAyMjo0OQ0KVG86IGV1cm9wYS1saXN0QG1hdHJvbmljcy5jb20NClN1Ympl Y3Q6IFJlOiBFdXJvcGEtTGlzdDogUmU6IFNWOiBSdW5uaW5nIHRvbyBjb29sLCBjb25zaWRlcmlu ZyBibG9ja2luZyBzb21lIG9mIGludGFrZQ0KIFBob3RvIEUtbWFpbCBWaWV3IHNsaWRlc2hvdyB8 IERvd25sb2FkIGltYWdlcyANCkFjY29yZGluZyB0byBSb3RheCB0aGVyZSBpcyBub3QgYSB0ZWNo bmljYWwgbWluaW11bSBjeWxpbmRlciB0ZW1wIGJ1dCBJIGFncmVlIHRoYXQgd2Uga25vdyB0aGF0 IGEgd2FybWVyIGN5bGluZGVyIHdpbGwgYmUgbW9yZSBlZmZpY2llbnQgYW5kIHRoZSBjcmFua2Nh c2UgYW5kIGdlYXJib3ggd2lsbCBub3QgaGFyYm9yIHdhdGVyIGluIHRoZSBjYXNlLg0KDQpUaGUg b2lsIHRoZXJtb3N0YXQgaXMgb25lIHdheSB0byBnZXQgdXAgdGhlIG9pbCB0ZW1wLiAgSSBoYXZl IHRyaWVkIHRvIG1ha2UgIGEgc2ltcGxlIHJlYXIgZmxhcCB0byBjbG9zZSB1cCB0aGUgYmFjayBi dXQgeW91IHdvdWxkIG5vdCBiZWxpZXZlIHRoZSBwcmVzc3VyZSBjb21pbmcgb3V0IG9mIHRoZSBy ZWFyIG9mIHRob3NlIHJhZGlhdG9ycyBhbmQgdGhlIGR1Y3Qgc3VjdGlvbiBwdWxsaW5nIG9uIHRo ZSBvdGhlciBzaWRlIG9mIHRoZSBmbGFwLiAgQSBtb3ZlYWJsZSBjb3dsIGZsYXAgd2lsbCB3b3Jr LCBidXQgdGhlbiB3ZSdyZSB0YWxraW5nIHJlcGFpbnQgb2YgdGhlIGNvd2wuICBTbyBob3cgZG8g d2UgZ2V0IHRoZSBnbHljb2wgdGVtcCB1cD8gIFRhcGUgb3ZlciAxLzMgb2YgdGhlIGdseWNvbCBj b29sZXIgaXMgYSBzdGFydC4gICBOZXh0IGlzIG1ha2luZyBhIHJlbW92YWJsZSBtZXRhbCBhaXIg ZGFtIGluIGZyb250IG9mIHRoZSBnbHljb2wgY29vbGVyLCBidXQgdGhhdCBpcyBub3QgYWRqdXN0 YWJsZS4gIFNvIHdoYXQgaXMgbmVlZGVkIGlzIGFuIGFkanVzdGFibGUgZmxhcCB0aGF0IGNhbiBi ZSBzZXQgZnJvbSB0aGUgY29ja3BpdCBmb3IgdGhvc2Ugd2FybWVyIHdpbnRlciBkYXlzLCBzcHJp bmcgYW5kIGZhbGwgb3BlcmF0aW9ucyBvciBoaWdoIGFsdGl0dWRlIGNydWlzZSBvcGVyYXRpb25z LiANCg0KVGhvc2UgYWRqdXN0YWJsZSBzbG90dGVkIGNvb2xlciBzaHV0dGVycyBhcmUgYSBzb2x1 dGlvbi4gIFVubGVzcyB5b3UgbmVlZCBldmVyeSBiaXQgb2YgY29vbGluZyBhaXIgaW4gdGhlIHN1 bW1lciBsaWtlIEkgZG8gaGVyZSBpbiBGbG9yaWRhLg0KDQpNYXJrIEZlcmtpbiBvZiBIaWdoIHdp bmcgTExDIChLaXRmb3ggZ3V5IG9mIGZhbWUpIG1ha2VzIGEgc2h1dHRlciBmb3IgdGhlIFJvdGF4 IGNvb2xlcnMuICBJdCBkb2Vzbid0IHdvcmsgd2VsbCBmb3Igb3VyIHNldHVwIGJ1dCB0aGUgY29u Y2VwdCB3b3Jrcy4NClZhbidzIGFpcmNyYWZ0IGhhcyB0aGUgc2xvdHRlZCBmbGFwIGFzIGFkZHJl c3NlZCBhYm92ZSBhbmQgdXNlZCBvbiBvdGhlciBOb3J0aGVybiBFdXJvcGEncyBidXQgaXQgZG9l cyBibG9jayB0aGUgYWlyIG5lZWRlZCBmb3Igc3VtbWVyIG9wdGlvbnMuDQoNCkZvciBvaWwgY29v bGluZywgSSBoYXZlIGluc3RhbGxlZCB0aGUgb2lsIHRoZXJtb3N0YXQgYW5kIGl0IGlzIHZlcnkg Y29udmVuaWVudCBhbmQgYXV0b21hdGljIHNvIEknbSB3YWl0aW5nIGZvciBpdCB0byBmYWlsLi4u DQoNCkkgcmVhbGx5IGhhdmUgb25seSBvbmUgaWRlYSBmb3IgYSBtb3ZlYWJsZSBFdXJvcGEgc3R5 bGUgWFMgY29vbGVycyB3aXRoIGEgdHdvIGluY2ggZHJvcCBvZiB0aGUgb2lsIGNvb2xlci4gIElm IHlvdSBoYXZlIG9uZSBvZiBteSBjb2NrcGl0IGhlYXRlcnMgYmUgc3VyZSB0byBsZWF2ZSBhIGN1 dG91dCBmb3IgdGhlIGhlYXRlciBvciB0aGUgY29ja3BpdCBoZWF0IGdldHMgc2h1dCBvZmYuICBT ZWUgYmVsb3c6DQoNClJlZ2FyZHMsDQpCdWQgWWVybHkNCg0KDQoNCkp1c3QgYSBzaW1wbGUgaGlu Z2Ugc2V0dXAgd2l0aCBhIGZsYXBwZXIgZG9vciB0byBibG9jayB0aGUgYWlyIGNvbWluZyBvdXQg b2YgdGhlIGdseWNvbCBjb29sZXIgYW5kIHBpdm90ZWQgbmVhciB0aGUgY2VudGVyIHRvIHJlZHVj ZSBwdWxsIGFuZCBob2xkIGZvcmNlcy4gIEFuIG9pbCBjb29sZXIgdGhlcm1vc3RhdCB0YWtlcyBj YXJlIG9mIHRoZSBvaWwgdGVtcHMuDQoNCkkgcmVhbGx5IHRob3VnaHQgdGhpcyB3b3VsZCB3b3Jr IGJ1dCB0aGUgZm9yY2UgdG8gaG9sZCB0aGUgZmxhcCBzaHV0IGFnYWluc3QgdGhlIGFpciBvdXRm bG93IGZyb20gdGhlIGNvb2xlcnMgKGFuZCBkcmF3IG9mIHRoZSBjb3dsIHJhbXApIGlzIGNvbnNp ZGVyYWJsZSBmb3IgYSBoaW5nZWQgZmxhcCBhdCB0aGUgbGVhZGluZyBlZGdlLg0KDQoNCg0KDQot LS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0tIA0KRnJvbTogZ3JhZW1lIGJpcmQgDQpUbzogZXVy b3BhLWxpc3RAbWF0cm9uaWNzLmNvbSANClNlbnQ6IFN1bmRheSwgTm92ZW1iZXIgMjUsIDIwMTIg MTowNiBQTQ0KU3ViamVjdDogRXVyb3BhLUxpc3Q6IFJlOiBTVjogUnVubmluZyB0b28gY29vbCwg Y29uc2lkZXJpbmcgYmxvY2tpbmcgc29tZSBvZiBpbnRha2UNCg0KDQotLT4gRXVyb3BhLUxpc3Qg bWVzc2FnZSBwb3N0ZWQgYnk6ICJncmFlbWUgYmlyZCIgPGdyYWVtZUBnZGJtay5jby51az4NCg0K VGhhdHMgdmVyeSBuZWF0LCAgdGhhbmtzLiBJIGFtIHdvbmRlcmluZyB0aG91Z2ggaWYgaXRzIHJl YWxseSBhIHByb2JsZW0gdG8gYmUgcnVubmluZyBhdCA4MGRlZy4gSSB0ZW5kIHRvIGdldCBoaWdo ZXIgdGVtcHMgaW5pdGlhbGx5IGF0IHRha2Ugb2ZmIHdoaWNoIHdvdWxkIGdldCByaWQgb2YgY29u ZGVuc2F0aW9uIGV0Yy4gV2hhdCBoYXBwZW5zIHdoZW4gdGhlIGVuZ2luZSBpcyBydW5uaW5nIHdh cm1lcj8gSSBjYW50IHNlZSBhbnkgcGFydGljdWxhciByZWZlcmVuY2UgaW4gdGhlIFJvdGF4IG1h bnVhbC4NCg0KSSBndWVzcyBJIGNvdWxkIGp1c3QgdGFwZSBvdmVyIGhhbGYgb2YgaXQgd2l0aCBh bHVtaW5pdW0gdGFwZSBhbmQgc2VlIGZvciBub3cuDQoNCi0tLS0tLS0tDQpHcmFlbWUgQmlyZA0K Ry1VTVBZDQpNb25vIDkxMlMvV29vZGNvbXAgMzAwMC8zVw0KTmV3Ynk6IDQ1IGhvdXJzICANCmco YXQpZ2RibWsuY28udWsNCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTM4ODkyMiMzODg5MjIN Cg0KDQpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vYyBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJv dXMgOyAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgbmJzcDsgICAgICAg RmVhdHVyZXMgQ2hhdCwgaHR0cDovL3d3dy5tYXRyb25uYnNwOyAgICB2aWEgdGhlIFdlYiB0aXRs ZT1odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vIGhyZWY9Imh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbS8iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPT09PT09PT09PT09PT0NCg0K DQoNCg0KVGhlc2UgcGhvdG9zIHdpbGwgYmUgYXZhaWxhYmxlIG9uIFNreURyaXZlIGZvciAzMCBk YXlzLiBUbyBsZWFybiBtb3JlIGFib3V0IFNreURyaXZlLCBjbGljayBoZXJlLg0KVG8gc2hhcmUg aGlnaCBxdWFsaXR5IHBpY3R1cmVzIHdpdGggeW91ciBmcmllbmRzIGFuZCBmYW1pbHkgdXNpbmcg TVNOIFBob3RvIEUtbWFpbCwgam9pbiBNU04uIA= ________________________________________________________________________________
Date: Nov 26, 2012
Hi Svein, Haven=92t done much on this. No special rec, but I=92m very curious to ear how your stuff works=85 Max Cointe F-PMLH Europa_TriGear Kit #560 912ULS Airmaster 450 hours mcointe(at)free.fr De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de Sidsel & Svein Johnsen Envoy=E9 : dimanche 25 novembre 2012 18:53 =C0 : europa-list(at)matronics.com Objet : Europa-List: Handheld with external antenna Hi Max, So sorry to read about your sudden cabriolet conversion. Did you have a chance to test the Icom handheld with the external antenna before this happened? If so, how did it work? I have now purchased the AAE VHF-5T antenna, which I plan to fix vertically to the fuselage inside skin on the right side behind the luggage bay bulkhead (I have the transponder antenna on the left side). Any particular recommendations (e.g. type of adhesive that you used). Regards, Svein LN-SKJ ________________________________________________________________________________
Date: Nov 26, 2012
Subject: Contributions Down By 23%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 23%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, dual T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Site, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2012
Hi all Many thanks for all your replies much appreciated and has put my mind to res t that all appears normal with the installation of my tri gear sockets. Not had a chance to go back and re check everything again but will check ove r everything another few times before taking the plunge & bonding in the soc kets. Many thanks for all the comments & suggestions on doing the rest of the proc ess as well, they are all very useful and gives me different options to comp lete the tri gear installation. Kind regards Donald Sent from my iPhone
October 18, 2012 - November 27, 2012
Europa-Archive.digest.vol-ki
