Europa-Archive.digest.vol-kp
July 01, 2013 - July 29, 2013
Date: Jul 01, 2013
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Subject: Re: Gumpy visits Wales (& there be dragons Kevin)
Was in Roger Mill's Classic RH seat once over the hills of Derbyshire, we n oticed it was waving.-=0AWe cruised about for ten minutes, throttle close d, 100kts and going up. Silky smooth too.=0AYou just need to understand the sky. One of the great pleasures in life. Especially later life !:-o=0AGrah am=0A=0A=0A________________________________=0A From: graeme bird <graeme@gd bmk.co.uk>=0ATo: europa-list(at)matronics.com =0ASent: Sunday, 30 June 2013, 1 6:11=0ASubject: Europa-List: Gumpy visits Wales (& there be dragons Kevin) .uk>=0A=0ASome great views yesterday approaching Welshpool over Church Stre tton, Long Mynd and then west to the coast at Aberdovey. Turned back before Talybont - anyone landed there?=0A=0ALook you though; there were hills, an d clouds.=0A=0ABeen thinking about the stopping the prop discussion. Glider s also like the hills, threatening clouds and thermal weather. Things we po wer pilots all seem to shy away from.=0A=0A--------=0AGraeme Bird=0AG-UMPY =0AMono Classic/XS 912S/Woodcomp 3000/3W=0ANewby: 75 hours 18 months =0Ag(a t)gdbmk.co.uk=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums .matronics.com/viewtopic.php?p=403650#403650=0A=0A=0A=0A=0AAttachments: =0A=0Ahttp://forums.matronics.com//files/dsc03443_1_145.jpg=0A=0A=0A=0A=0A_ -======================== ============== ________________________________________________________________________________
Subject: Re: wing lift/drag pins
Date: Jun 30, 2013
Hi Graham. I understand a little in what you a saying. In the tail slip the wing is falling backwards to normal flight condition. The pin would stop the wing from pulling out. But in normal level flight i see this bar in compression. At this moment in time, i just can not see how you would get a forward force. I find Europa.s notes mentioning words like "tie bar", but i find many of Europa,s notes not to clear as to exactly what the situation is. I think this bar is say, in compression 90% of the time and 10% in tension some of the time, hence the pin. But what the hell do i know, but im not giving up yet. Need a little micro transducer between the front wing root to see which the bios is. Best Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403665#403665 ________________________________________________________________________________
Date: Jul 01, 2013
Hi Alan. A few comments, 1, wings that have been demonstrated to fly OK for many thousands of hours do not usualy fail in normal flight , it should only happen in extreme circumstances so forget about your 1 "G" straight and level situation. 2, your comments about the WW2 bomber do not demonstrate failure due to aerodynamic loading., During the bomb release phase of flight it would be in 1"G" straight and level flight. the failure occurred because the fuselage holding the wings apart was removed allowing them to react as you describe. 3, there are lots of things in life I do not understand like high energy physics and brain surgery but when people who know about these things try and explain to me I try to listen and learn. you seem to have rejected all the explanations put forward by knowledgeable contributors to this forum. So when you find the answer from other sources please let us know the outcome so that we can all learn something. 4, If a Cessna 150 was over stressed in a high "G" maneuver to the extent that the mainplanes failed they would also fold forwards and upwards probably outboard of the struts.. Tim On 1 July 2013 01:01, Alan Carter wrote: > > > > Hi Graham. > I understand a little in what you a saying. > In the tail slip the wing is falling backwards to normal flight condition. > The pin would stop the wing from pulling out. > > But in normal level flight i see this bar in compression. > At this moment in time, i just can not see how you would get a forward > force. > > I find Europa.s notes mentioning words like "tie bar", > but i find many of Europa,s notes not to clear as to exactly what the > situation is. > > I think this bar is say, in compression 90% of the time and 10% in tension > some of the time, hence the pin. > But what the hell do i know, but im not giving up yet. > > Need a little micro transducer between the front wing root to see which > the bios is. > > Best Regards. > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403665#403665 > > ________________________________________________________________________________
From: "Carl Pattinson" <carl(at)flyers.freeserve.co.uk>
Subject: Gumpy visits Wales (& there be dragons Kevin)
Date: Jul 01, 2013
Talybont used to be owned by Bill Wynn, one of our first Europa builders and past Europa Club chairman (for many years). There was always a welcome for Europa owners wanting to drop in for a cup of tea and a chat. Don't have his contact details any more but might be in Pooleys or the farm strip guide. Many in the Europa community knew Bill well and may still be in contact. -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of graeme bird Sent: 30 June 2013 16:11 Subject: Europa-List: Gumpy visits Wales (& there be dragons Kevin) Some great views yesterday approaching Welshpool over Church Stretton, Long Mynd and then west to the coast at Aberdovey. Turned back before Talybont - anyone landed there? Look you though; there were hills, and clouds. Been thinking about the stopping the prop discussion. Gliders also like the hills, threatening clouds and thermal weather. Things we power pilots all seem to shy away from. -------- Graeme Bird G-UMPY Mono Classic/XS 912S/Woodcomp 3000/3W Newby: 75 hours 18 months g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403650#403650 Attachments: http://forums.matronics.com//files/dsc03443_1_145.jpg ________________________________________________________________________________
Date: Jul 01, 2013
Surely in gliding flight the wings must be pulling the fuselage forwards..........otherwise you would stop! On 1 Jul 2013, at 08:55, houlihan wrote: > Hi Alan. > > A few comments, > 1, wings that have been demonstrated to fly OK for many thousands of hours do not usualy fail in normal flight , it should only happen in extreme circumstances so forget about your 1 "G" straight and level situation. > > 2, your comments about the WW2 bomber do not demonstrate failure due to aerodynamic loading., During the bomb release phase of flight it would be in 1"G" straight and level flight. the failure occurred because the fuselage holding the wings apart was removed allowing them to react as you describe. > > 3, there are lots of things in life I do not understand like high energy physics and brain surgery but when people who know about these things try and explain to me I try to listen and learn. you seem to have rejected all the explanations put forward by knowledgeable contributors to this forum. So when you find the answer from other sources please let us know the outcome so that we can all learn something. > > 4, If a Cessna 150 was over stressed in a high "G" maneuver to the extent that the mainplanes failed they would also fold forwards and upwards probably outboard of the struts.. > > Tim > > > On 1 July 2013 01:01, Alan Carter wrote: > > Hi Graham. > I understand a little in what you a saying. > In the tail slip the wing is falling backwards to normal flight condition. > The pin would stop the wing from pulling out. > > But in normal level flight i see this bar in compression. > At this moment in time, i just can not see how you would get a forward force. > > I find Europa.s notes mentioning words like "tie bar", > but i find many of Europa,s notes not to clear as to exactly what the situation is. > > I think this bar is say, in compression 90% of the time and 10% in tension some of the time, hence the pin. > But what the hell do i know, but im not giving up yet. > > Need a little micro transducer between the front wing root to see which the bios is. > > Best Regards. > Alan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403665#403665 > > > > > > > > ========== > target="_blank">http://www.matronics.com/Navigator?Europa-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > > ________________________________________________________________________________
Date: Jul 01, 2013
Hi Bob. Thats seem,s reasonable , and a windmill goes round, So dose that mean a wing in flight is contributing or generating forward thrust. Tim. What you are saying to me, is, i don,t have the right to ask questions or challenge a reply. I accept there a fare more knowledgeable contributors than me on the forum. But i am still part of it and have the right to reply and ask, why or how dose this occur. I accept wings don,t fall off in normal flight, and this pin is probably for abnormal flight conditions, But if you go back to the beginning of this topic, it indicated to me the in level flight the wing provided some forward force, ie helping the propeller to pull the plane alone. Maybe it does , as Bob said about the glider, so this bar is in tension all the time if in the glide. or may be its in tension only some of the time, I don,t know, Regard . Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403683#403683 ________________________________________________________________________________
Subject: Re: where to locate fuel pressure sensor
Date: Jul 01, 2013
Hi Rowland I along with most agree that the eye watering prices charged for Rotax parts is scandalous but here I am sure you have asked for the wrong part . However if you would like it I can copy my fuel system layout and send it to you , I have completed 45hrs to date with no problems, if you do then contact me off line at rcollings(at)talktalk.net . Regards Richard -----Original Message----- From: Rowland Carson Sent: Friday, June 21, 2013 6:04 PM Subject: Re: Europa-List: where to locate fuel pressure sensor On 13 Jun 2013, at 12:13, richard wrote: > new rotax engines are supplied with just such a manifold, contact Conair > for a price Richard - I spoke with Conair and although I wasn't able to identify _all_ the part numbers for the fuel manifold, the total for those I found came to 578.55 sterling so I think I will be seeking cheaper options! > For what its worth I modified the fuel pipe runs, dispensing with the > rubber pipes in favour of proper aircraft aluminium see Mod No 13304 Where can I find info on Mod 13304? It doesn't appear on the LAA website anywhere I can find. I checked the list of all prototype mods (which only shows up to Mod 12403 for Europas) and the list of Standard Mods for Europas. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Subject: Re: Fuel tank sensor opening problem
Date: Jul 01, 2013
Hi Frans I suggest you contact LAA and ask them for a copy of Mod 10602 which Ian Rickard had approved. This mod introduces a flange plate and seal assembly into the top of the tank. The important thing is that the flange seal is on the inside of the tank so no fuel contacts the out side or the cut edge. Hope this helps Regards Richard Europa xs Tri-gear 45hrs -----Original Message----- From: Frans Veldman Sent: Thursday, June 20, 2013 2:36 PM Subject: Europa-List: Fuel tank sensor opening problem Dear friends, In my fuel tank I have cut two small openings for fuel sensors. Serious fuel leaks started to develop, so I have removed the sensors to have a look. What I discovered is that in the area around the cut outs the tank wall has become swollen and seriously distorted. I remember some discussion on this forum about the treatment the fuel tank received, that this treatment was only on the surface and once you cut a hole in the tank the fuel can reach the unprotected material. I tank mogas and the ethanol in it doesn't help either. The question is now, what should I do? Is there any way to rescue the affected material, or should I cut it out? If I cut out the area, I have a new cut and will face the same problem but on a larger scale, unless there is some way to treat the newly cut opening. If I make a new cut, how can I prevent it from happening again? Of course, replacement of the fuel tank is something I want to avoid at all costs (and even then, I want to have fuel sensors in the new tank so I will have to deal with the same problem anyway). Is there any quick fix possible? This is the flying saison and I don't want to spoil it if there is a way to postpone a more long lasting repair until the winter. Thanks in advance for some great ideas, Frans ________________________________________________________________________________
From: "Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no>
Date: Jul 01, 2013
This has been an interesting discussion, but it appears to me that it got off-track somewhere because "forward" has two meanings (see the attached illustrations): (i) The LIFT does not have a "forward" component, under any circumstances, if FORWARD means the direction of the aircraft's flight. Reason: LIFT is by definition always perpendicular to the direction of flight, as DRAG is always opposite to the direction of flight (i.e. perpendicular to the LIFT). (ii) If, however, one refers to FORWARD as the direction of the aircrafts centerline, then LIFT has a "forward" component as soon as the centerline points up at the nose relative to the direction of flight. The higher the nose points up, the greater this forward component is. At some point it may, as I read the discussion, become larger than the wing DRAG's component parallel to the centerline in the opposite direction, giving a net "forward" force on the wing. (iii) The LIFT does not contribute, under any circumstances, to moving the aircraft forward through the air, as there is no lift component parallel to the direction of flight. A glider is "propelled" by the forward - in the direction of flight - component of the aircraft's WEIGHT only. Regards, Svein LN-SKJ ________________________________________________________________________________
Date: Jul 01, 2013
On Jul 1, 2013, at 6:53 AM, richard wrote: > Hi Frans > I suggest you contact LAA and ask them for a copy of Mod 10602 which Ian Rickard had approved. This mod introduces a flange plate and seal assembly into the top of the tank. The important thing is that the flange seal is on the inside of the tank so no fuel contacts the out side or the cut edge. Hope this helps > Regards Richard > Europa xs Tri-gear 45hrs All, Though still just a the builder, I'm following this topic w/ keen interest and full sympathy for flyers who are experiencing fuel tank leaks and deformation. When I read about the introduction of tank mods such as #10602, am I correct in assuming that work of this nature is done AFTER slicing off the top of the CM, say, 1/2 inch down from the top flat surface?...or perhaps after slicing off one of the head rests, say 1/2 inch up from the top flat surface of the CM? Also...long ago I installed the Europa capacitance fuel gauge PRIOR to installing the tank in the CM. (At the time I was astounded to read the instructions' claim that it is possible to install the gauge AFTER installing the CM by working thru the access hole in the side of the head rest...I salute anyone who managed to do that!) If I recall correctly, the installation included an internal flange plate which I now surmise should prevent fuel contacting the cut edge...much appreciation if anyone can confirm this. Fred A-194 ________________________________________________________________________________
Date: Jul 01, 2013
On 07/01/2013 04:21 PM, Sidsel & Svein Johnsen wrote: > This has been an interesting discussion, but it appears to me that it > got off-track somewhere because "forward" has two meanings (see the > attached illustrations): How does an autogyro (autocopter?) work? What is causing the blades to move forward? > A glider is > propelled by the forward in the direction of flight component of > the aircrafts WEIGHT only. Ok, got it. But without wings (but still with the majority of the weight) will the glider still be propelled forwards? I guess not. Then what exactly is exercising a forward pulling force on the glider's fuselage? The fuselage has only drag. So something must be pulling it forward. Frans ________________________________________________________________________________
Date: Jul 01, 2013
On 07/01/2013 04:29 PM, Fred Klein wrote: > If I recall correctly, the installation included an internal flange > plate which I now surmise should prevent fuel contacting the cut > edge...much appreciation if anyone can confirm this. I did not have the internal flange. I just riveted 5 anchor nuts to the tank and assumed this would be plenty for such a small surface. Well, it is not. I now have made an internal flange myself and hope that with the tank wall locked in between the sensor cap and internal flange that it won't leak anymore. Still the fuel can access the cut line but as this has already happened I'm not sure whether it makes sense to seal it now. Also, you need 5 holes through the tank wall to attach the whole thing, making it even harder to achieve a leak free fit. So, I will leave it as is and if it doesn't leak anymore I'm happy with it. Frans ________________________________________________________________________________
Date: Jul 01, 2013
Good point Svein=0AGraham=0A=0A=0A=0A=0A________________________________=0A From: Sidsel & Svein Johnsen <sidsel.svein(at)oslo.online.no>=0ATo: europa-li st(at)matronics.com =0ASent: Monday, 1 July 2013, 15:21=0ASubject: SV: Europa- List: Re: wing lift/drag pins=0A =0A=0A=0AThis has been an interesting disc ussion, but it appears to me that it got off-track somewhere because "forwa rd" has two meanings (see the attached illustrations):=0A=C2-=0A(i)=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2- The LIFT does not have a =9Cforward=9D co mponent, under any circumstances, if FORWARD means the direction of the air craft=99s flight.=C2- Reason:=C2- LIFT is by definition always pe rpendicular to the direction of flight, as DRAG is always opposite to the d irection of flight (i.e. perpendicular to the LIFT).=0A=C2-=0A(ii)=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2- If, however, one refers to FORWARD as the direction of the aircra fts centerline, then LIFT has a =9Cforward=9D component as soon as the centerline points up at the nose relative to the direction of fligh t.=C2- The higher the nose points up, the greater this forward component is.=C2- At some point it may, as I read the discussion, become larger tha n the wing DRAG=99s component parallel to the centerline in the oppos ite direction, giving a net =9Cforward=9D force on the wing.=0A =C2-=0A(iii)=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2- The LIFT does not contribute, under any circumstan ces, to moving the aircraft forward through the air, as there is no lift co mponent parallel to the direction of flight.=C2- A glider is =9Cpro pelled=9D by the forward =93 in the direction of flight =93 component of the aircraft=99s WEIGHT only.=0A=C2-=0A=C2-=0ARe gards,=0ASvein=0ALN-SKJ ________________________________________________________________________________
Subject: Fuel tank sensor opening problem
Date: Jul 01, 2013
Hi! Fred My oval hole cut in the tank top is protected by the plate internally and a silicone seal round the edges and I have had no problems of the swelling kind except I had a leak once from the pressure "head" by leaving a column of fuel right up the "cobra" filler over night . Better attention to the silicone casket and more intelligent filling seem to have prevented a repeat. No one advised me to ensure that the cut edge should be kept free from fuel contact. However early tanks had to have fuel stored and so be encouraged to " swell" prior to installation into the fuselage/cockpit module over a period of many weeks restrained by a strong frame surrounding it. So movement can be expected but by arranging suitable clamps and tight fixings I would have thought would restrain the swelling anyway. My Kit No is 337 but I know that a number of builders have suffered split tanks . I believe likely caused by letting the tank dry out after the impregnation by fuel . Keep fuel in and such swelling stays stable. (I think !) Regards to all in strife ! Bob Harrison. G-PTAG From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fred Klein Sent: 01 July 2013 15:29 Subject: Re: Europa-List: Fuel tank sensor opening problem On Jul 1, 2013, at 6:53 AM, richard wrote: Hi Frans I suggest you contact LAA and ask them for a copy of Mod 10602 which Ian Rickard had approved. This mod introduces a flange plate and seal assembly into the top of the tank. The important thing is that the flange seal is on the inside of the tank so no fuel contacts the out side or the cut edge. Hope this helps Regards Richard Europa xs Tri-gear 45hrs All, Though still just a the builder, I'm following this topic w/ keen interest and full sympathy for flyers who are experiencing fuel tank leaks and deformation. When I read about the introduction of tank mods such as #10602, am I correct in assuming that work of this nature is done AFTER slicing off the top of the CM, say, 1/2 inch down from the top flat surface?...or perhaps after slicing off one of the head rests, say 1/2 inch up from the top flat surface of the CM? Also...long ago I installed the Europa capacitance fuel gauge PRIOR to installing the tank in the CM. (At the time I was astounded to read the instructions' claim that it is possible to install the gauge AFTER installing the CM by working thru the access hole in the side of the head rest...I salute anyone who managed to do that!) If I recall correctly, the installation included an internal flange plate which I now surmise should prevent fuel contacting the cut edge...much appreciation if anyone can confirm this. Fred A-194 ________________________________________________________________________________
Date: Jul 01, 2013
On 07/01/2013 11:41 AM, Alan Carter wrote: > I don,t know, Just assume your wings fall off. What is your fuselage going to do? It will fall straight down after the short moment it looses its forward speed. Now keep the wings attached. Switch off the engine. Where is the fuselage going? It moves forward and keeps on moving forward. As the fuselage has drag, why is it moving forward against the drag? Who is pulling it? Is the connecting bar between the two rear sockets under compression or unter tension? Frans ________________________________________________________________________________
Date: Jul 01, 2013
Frans, Our postings are crossing a little, but I think the below covers also your last one: > > How does an autogyro (autocopter?) work? What is causing the blades to > move forward? > See http://en.wikipedia.org/wiki/Autogiro > > A glider is > > "propelled" by the forward - in the direction of flight - component of > > the aircraft's WEIGHT only. > > Ok, got it. But without wings (but still with the majority of the > weight) will the glider still be propelled forwards? I guess not. Again: What is meant by "forward"? Without wings, the glider will still be propelled forwards, and still by gravitational force. Unfortunately for the pilot, however, "forward" now means more or less vertical towards the ground .......... > Then what exactly is exercising a forward pulling force on the glider's > fuselage? The fuselage has only drag. So something must be pulling it > forward. > I may be stating the obvious, but a glider is always going down, or rather gliding down - down relative to the air mass through which it moves. If the air mass is moving upwards (thermals) faster than the glider moves downwards through that air mass, the glider climbs relative to the ground even though it goes down relative to the air mass. All the time, it is the gravity that causes it to move, and movement through the air creates lift (if the wings are still on), so that the glider does not fall like a stone through the surrounding air mass. When the total drag on the glider equals the gravity's component in the direction of flight, the glider does not accelerate any more, it has reached constant speed. Same thing with an airplane with engine, if the engine quits. As long as the engine works, though, and we fly level, the engine gives enough pull to equal the total drag, so that we don't need any assistance by the gravity to create speed. At level flight, the lift and the down force by the stabilizer are vertical. Gravity is always vertical. I.e. no fore-or-aft force component from any of these three forces. Only drag, which equals propeller pull at constant speed. Regards, Svein ________________________________________________________________________________
Subject: Re: wing lift/drag pins - ADDITION
Date: Jul 01, 2013
In my most recent posting, I wrote: "...a glider is always going down, or rather gliding down - down relative to the air mass through which it moves". The exception is of course if using the mass inertia of the glider for a short-duration movement up through the air. This is when the in-the-direction-of-the-centerline forward force on the wing may exceed the opposite-direction wing drag component, and the cross tie bar comes under tension, not compression. Regards, Svein ________________________________________________________________________________
Date: Jul 01, 2013
> > A glider is > > "propelled" by the forward - in the direction > > of flight - component of > > the aircraft's WEIGHT only. And thats why they (gliders) obviously fill also sometimes their watertanks - to get more load, to feed gravity and to get speed? Cheers, Raimo -----Alkuperinen viesti----- From: Sidsel & Svein Johnsen Sent: Monday, July 01, 2013 6:24 PM Subject: SV: SV: Europa-List: Re: wing lift/drag pins Johnsen" Frans, Our postings are crossing a little, but I think the below covers also your last one: > > How does an autogyro (autocopter?) work? What is > causing the blades to > move forward? > See http://en.wikipedia.org/wiki/Autogiro > > A glider is > > "propelled" by the forward - in the direction > > of flight - component of > > the aircraft's WEIGHT only. > > Ok, got it. But without wings (but still with > the majority of the > weight) will the glider still be propelled > forwards? I guess not. Again: What is meant by "forward"? Without wings, the glider will still be propelled forwards, and still by gravitational force. Unfortunately for the pilot, however, "forward" now means more or less vertical towards the ground .......... > Then what exactly is exercising a forward > pulling force on the glider's > fuselage? The fuselage has only drag. So > something must be pulling it > forward. > I may be stating the obvious, but a glider is always going down, or rather gliding down - down relative to the air mass through which it moves. If the air mass is moving upwards (thermals) faster than the glider moves downwards through that air mass, the glider climbs relative to the ground even though it goes down relative to the air mass. All the time, it is the gravity that causes it to move, and movement through the air creates lift (if the wings are still on), so that the glider does not fall like a stone through the surrounding air mass. When the total drag on the glider equals the gravity's component in the direction of flight, the glider does not accelerate any more, it has reached constant speed. Same thing with an airplane with engine, if the engine quits. As long as the engine works, though, and we fly level, the engine gives enough pull to equal the total drag, so that we don't need any assistance by the gravity to create speed. At level flight, the lift and the down force by the stabilizer are vertical. Gravity is always vertical. I.e. no fore-or-aft force component from any of these three forces. Only drag, which equals propeller pull at constant speed. Regards, Svein browse Un/Subscription, FAQ, http://www.matronics.com/Navigator?Europa-List Forums! List Admin. ________________________________________________________________________________
Date: Jul 01, 2013
On 07/01/2013 05:24 PM, Sidsel & Svein Johnsen wrote: >> Then what exactly is exercising a forward pulling force on the glider's >> fuselage? The fuselage has only drag. So something must be pulling it >> forward. >> > I may be stating the obvious, but a glider is always going down, I guess it is also obvious that it is going down much quicker without the wings, and with less forward velocity. So the question remains, if the fuselage without wings has a lower forward speed than a fuselage with wings, can't we just say that this means that the wings are pulling the fuselage forwards? No way that the fuselage itself will maintain a forward speed of 100 knots or so, the drag is quite substantial, so something is pulling it forward against the drag. And in the few examples where the wings detached during flight, it is indeed observed that the wings fold forwards. The wings MUST BE pulling the fuselage forwards, because the fuselage would never do this by itself. I can't see how one could argue against that. > All the time, it is the gravity that > causes it to move, Yes, gravity is providing the energy that makes it happen. No doubt about that. But this is something else than saying that the wings play no role in it. Sure the wings play a role in it: they counter partly the gravity and redirect the energy to propel the aircraft forward. > Same thing with an airplane with engine, if the engine quits. As long as > the engine works, though, and we fly level, the engine gives enough pull to > equal the total drag, The engine provides extra energy, so we don't loose altitude while "going down". Frans ________________________________________________________________________________
Date: Jul 01, 2013
> > > A glider is > > > "propelled" by the forward - in the direction of flight - component > > > of the aircraft's WEIGHT only. > > And thats why they (gliders) obviously fill also sometimes their watertanks - > to get more load, to feed gravity and to get speed? > > Cheers, Raimo > Yes, Raimo, that is one of the main reasons for the water ballast. At the same glide ratio, you get higher speed with than without ballast. Just look at the bottom illustration in my first e-mail: Higher weight gives larger gravity component in direction of flight at the same angle of flight vs. horizontal. Larger pulling force gives higher speed - the glider accelerates until the higher pulling force equals the increasing drag. Higher speed gives higher lift (square of speed increase) to carry the higher weight, so that you can maintain the glide ratio (direction of flight vs. horizontal). Regards, Svein ________________________________________________________________________________
Subject: Water ballast
Date: Jul 01, 2013
Yes Raimo, You are correct,the water ballast actually increases the gliders "inertia", and as a consequence,the glide angle is better at higher speeds. The trade off of course is poorer climb Performance in lift,but on good days, The advantage of carrying water out-weighs this. However pilots may find they have to Dump some or all of their water to climb And get home if soaring conditions get Worse. Best Regards Andy Cullum. Sent from my iPhone ________________________________________________________________________________
Date: Jul 01, 2013
Hello Frans. Who is pulling it. Gravity It will move is an arc towards the ground. A wing is similar to a sail on a sailing boat. You can not sail directly into wind you can get to about 30 degrees of it. Sorry Frans but at the moment i am still puzzled. At the moment i am thinking this bar has three purposes, 1. to prevent the drag pulling the wing back, which is most of the time. 2. two provide the rigidity to the structure so keeping the front pin locked into its mounting. 3. to stop the wing coming "forwards" in abnormal wing loadings, Possible very high A/A, near the stall, or gusts, or abnormal flight attitudes. This puts this bar in compression , tension and neutral loads But i am willing to change my mind,as i have used up ask a friend, may be its time to ask the audience, Regards . Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403725#403725 ________________________________________________________________________________
Date: Jul 01, 2013
Frans, The forces are as illustrated in my first posting. If you throttle back the engine, all properly designed and built aircraft automatically pitches down to gain speed. The pitch-down is of course the result of the stabilizer's design and angle of incidence vs. the wings' . Why gain speed: To give required lift. To get enough speed to give the required lift, the pulling force must be kept up. Lost propeller thrust must be compensated by something. As lift CANNOT give force in the direction of flight (remember, BY DEFINTION it is perpendicular to the direction of flight, thus it has no forwards nor backwards component flight-direction-wise). What is this "something" force that compensates for engine power? Look at the bottom illustration in my first posting: To create a forward force (forward meaning in the direction of flight) to maintain speed to maintain lift, the only possible force available is the gravity's flight-direction component. The steeper the pitch-down, the larger this force becomes, and the faster down you fly. This creates more lift (perpendicular to the flight direction), of course, but the vertical component of the lift remains the same - equal to the weight of the aircraft plus the vertical component of the downward stab. force. The gravity component acts on every atom in the structure's molecules, but we commonly consider them all grouped together at what we refer to as the center of gravity (CG), and uses this as point as the one common point where the total pulling force acts. Neither the fuselage nor the wings pull the aircraft forward, good ol' gravity does it all by itself! Do this, Frans: Shake off all your conceptions. Look ONLY at my illustrations. The global airplane forces are actually this simple. Alan, Right on! Regards, Svein ________________________________________________________________________________
Date: Jul 01, 2013
Hi Group I have been following this thread with interest. I have been picking the brain of an ex Grumman X-29 FSW lead wind tunnel engineer as far as our Europa wings trying to move fore or aft, and all I know at the moment (pun intended) is how much I don't know. He asked a few pointed questions about the Europa, can you help me out with answering them?: **** What percent chord is the main spar at? **** What wing section does the aircraft use? **** What is the relationship (distance) between the main spar and the aft fitting? Once I provide him with these details, he will come back with his take on the subject. I will post his answer along with other comments he has made already. Thx. Ron Parigoris BTW Frans, I have always thought of a Gyrocopter as an aeroplane with a big pancake of a wing above you. When you spin up the blades, they don't allow much in the way of airflow through the spinning blades. Think of a big disk you put at a positive angle of attack above you. Kinda neat concept, not very efficient, takes a lot of pushing energy to keep your rotors spinning up to make it act like a solid disc. Here is an E-Mail I sent: Hey Guyz A Europa member was trying to explain to another member why at high angles of attack the wings want to sweep forward. There are other members that tried to explain in words, one just said well, it's the same reason why a Gyrocopter rotor spins in the direction that it does which with little thought seems to be spinning in the wrong direction. Attached is a diagram that is a pretty good visualization. Ron P. Here's his reply: No its not (a good visualization) You have to apply real numbers to those phoney scalers on that figure. At high AOA the drag is significantly higher than shown, but lift not so much so. This would pull the L/D resultant much father aft. Those two plots are implying that the L/D of a wing is the same at cruise and at high AOA which we all KNOW is not true! (the reason you never fly a high performance sailplane near Cl Max!) There is one good reason for putting fwd sweep in a wing planform. It allows less use of washout to keep the tip from stalling. If the wing is swept TOO far fwd, the twist actually reverses! The root must be a lower AOA than the tip, sometimes by a lot. The biggest DISADVATAGE to FSW planform wings is structural divergence. Load the wing up, and without a sufficiently strong wing box structure, the wing tip will twist to a higher AOA producing more twist repeat as necessary until failure (catastrophic I might add!) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403743#403743 ________________________________________________________________________________
Date: Jul 01, 2013
Hi Ron. Glad you are interested. If you read the topic from the beginning it imply,s that the sole purpose of this bar was to prevent the wings from being pulled forward all the time during flight. I,m getting to old for all of this, but as an instructor many years ago i use to draw all the forces on the blackboard,and i never drew a wing vector added to the thrust vector, So got me thinking why, and i slowly began to come round to thinking there may be some forward component but not occurring in normal flight. The tie bar came in with the weight increase mod, with the bigger spar pins, the swivelling rear fuselage pin socket and the tie strap on the spar. Then when we had the in flight break up the tie bar became a mandatory mod for all Europa's with the extra long rear wing pins with big washer and nut inside the wing root. I think its purpose is as i have stated, and re enforces the whole structure around the wing and mounting points, and i believe this weak spot was part of the break up, May not have been the initial cause, that may well have been something to do with the Stabalator. I may be wrong, I have never built an aeroplane, and im just a simple country boy,with a pair of eye,s, but do have the right to post my opinion, I am polite, never make fun of, or discourage any member from posting, and always willing to listen to another point of view, I am just interested in this particulate topic, and will look forward to your posting, sorry i can,t give you the information you requested, I just fly the plane. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403746#403746 ________________________________________________________________________________
Date: Jul 02, 2013
Ron, >From your message: > Attached is a diagram that is a pretty good visualization. > Ron P. > > Here's his reply: > No it=C3=A2=82=AC=84=A2s not=C3=A2=82=AC=C2 (a good visualization) > > You have to apply real numbers to those phoney scalers on that figure. > > At high AOA the drag is significantly higher than shown, but lift not so much > so. This would pull the L/D resultant much father aft. > > Those two plots are implying that the L/D of a wing is the same at cruise and > at high AOA which we all KNOW is not true! (the reason you never fly a high > performance sailplane near Cl Max!) > I assume it was my illustration that you forwarded to your friend. If so, I agree with his statement about L/D - the vectors are not to scale at all, and were not intended to be. I realize, however, that I should have emphasized this and also increased the length of the wing drag vector at the high AOA illustration, but this has no bearing on the lift component issue. My message =93 and illustration - had two purposes, which perhaps your friend was not aware of: - To show that lift has no component in the direction of flight, regardless of the angle of attack, while lift may have a =9Cforward=9D component, if "forward" means the direction the nose is pointing. - To show that a glider is pulled forward (in the direction of gliding flight) by gravity, not by any lift component. I have not made any calculation of the magnitude of the =9Cforward=9D lift component vs. drag on Europa or any other airplane, which is why I just referred to arguments and observations presented by others: "At some point it may, as I read the discussion, become larger than the wing DRAG=99s component parallel to the centerline in the opposite direction, giving a net =9Cforward=9D force on the wing." The magnitude of such a =9Cforward=9D component is only dependent on the magnitude of the lift and the angle between the centerline and the direction of flight. The magnitude of drag does not come in here. The resultant force on the wing, however, and whether it acts =9Cforward=9D or =9Cbackward=9D, depends also on the drag magnitude. I apologize if I have caused any confusion about wing L/D vs. AOA (I don=99t really think I have, though!) Regards, Svein ________________________________________________________________________________
Date: Jul 02, 2013
Ron. Just read your friends replay, There was an light certified aeroplane , many years ago, Not sure who made it, maybe Pipe but i think it was Italian company ? but it had forward swept wings. Can, t spell it nether, a Metersocall The Europa has a slim straight wing with a little wash out towards the tips. and made of Glass fibre over foam formers, thats a close as i can get it. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403776#403776 ________________________________________________________________________________
Date: Jul 02, 2013
On 07/01/2013 07:49 PM, Sidsel & Svein Johnsen wrote: > Do this, Frans: Shake off all your conceptions. Look ONLY at my > illustrations. The global airplane forces are actually this simple. I think we are both right, but each of us looking at a different situation. You are talking about the airplane as a whole. But for me, as this was the topic of the original discussion, the question is: what kind of forces do the wings pose on the fuselage? As the fuselage doesn't want to go forward without the wings, but still goes forward with the wings, it looks to me that it is possible that the wings somehow pull the fuselage forward. And of course I have some clues as why the airplane (as a whole) actually flies and I agree with your drawings, but again, the topic was: the rear wing sockets, do they push or do they pull? To really answer this question you should drawn the vector diagrams not for the airplane as a whole, but for each of the components that make up the airplane. And then it would be interesting to see what resultant force is acting on the rear wing sockets. Mind you, I might be totally wrong on my idea. But I have a feeling that it is beyond just our reasoning to really have a grasp which forces are acting where on the individual interconnecting components. As I recall, the "cuff" around the two wingspars was a "fix" for some unforeseen force acting on the wing spars causing them to twist somehow around each other. Despite the great souls working on the original design of the wings, it was not foreseen that the cuffs would be necessary. Has anyone actually ever tried to fly without the rear pip pins in? If so, what happened? If not, what would happen? Could you get away with it, or will the wings fold forward during the landing flare? I don't think the forces are too large anyway, as the original Europa design didn't have the interconnecting bar between the sockets, and the original structure is not really that strong with respect to pulling and pushing forces. Frans ________________________________________________________________________________
Date: Jul 02, 2013
Svein=0AI admire your patience and courtesy,=C2- the persistent deniers o n this tread have =0Ajust about exhausted mine! First of all one should sta rt with the facts; when a wing =0Afails due to high positive load it claps forwards. Saying "I don't believe it because it =0Adoesn't fit my understan ding or theory might be described as "an academic reaction to an inconvenie nt truth"=0AThis "forward lift component" is very counter intuitive, the on ly way to approach it is to =0Arefer to a diagram like yours. The criterion a lot of people overlook is that lift is=0Aperpendicular to line of flight , which is NOT parallel with the centre line of the fuselage.=0ANor is it 1 80deg from the line of gravity.=0AGraham=0A=0A=0A=0A=0A____________________ ____________=0A From: Sidsel & Svein Johnsen <sidsel.svein(at)oslo.online.no> =0ATo: europa-list(at)matronics.com =0ASent: Tuesday, 2 July 2013, 7:23=0ASubj ect: SV: Europa-List: Re: wing lift/drag pins=0A =0A=0A=0ARon,=0A=C2-=0AF rom your message:=0A=C2-=0A> Attached is a diagram that is a pretty good visualization.=0A> Ron P.=0A> =0A> Here's his reply:=0A> No it=C3=A2=82 =AC=84=A2s not=C3=A2=82=AC=C2 (a good visualization)=0A> =0A> You have to apply real numbers to those phoney scalers on that figure.=0A> =0A> At high AOA the drag is significantly higher than shown, but lift not so m uch=0A> so.=C2- This would pull the L/D resultant much father aft.=0A> =0A> Those two plots are implying that the L/D of a wing is the same at cru ise and=0A> at high AOA which we all KNOW is not true! (the reason you neve r fly a high=0A> performance sailplane near Cl Max!)=0A> =0A=C2-=0AI assu me it was my illustration that you forwarded to your friend.=C2- If so, I agree with his statement about L/D =C2-- the vectors are not to scale at all, and were not intended to be.=C2- I realize, however, that I should have emphasized this and also increased the length of the wing drag vector at the high AOA illustration, but this has no bearing on the lift component issue.=0A=C2-=0AMy message =93 and illustration - had two purposes , which perhaps your friend was not aware of:=C2- =0A=C2-=0A-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2- To show that lift has no comp onent in the direction of flight, regardless of the angle of attack, while lift may have a =9Cforward=9D component, if "forward" means the direction the nose is pointing. =C2-=0A-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2- To show that a glider is pulled forward (in the di rection of gliding flight) by gravity, not by any lift component.=0A=C2- =0AI have not made any calculation of the magnitude of the =9Cforward =9D lift component vs. drag on Europa or any other airplane, which is why I just referred to arguments and observations presented by others:=C2 - =C2-"At some point it may, as I read the discussion, become larger th an the wing DRAG=99s component parallel to the centerline in the oppo site direction, giving a net =9Cforward=9D force on the wing." =C2- =C2-The magnitude of such a =9Cforward=9D component is only dependent on the magnitude of the lift and the angle between the cent erline and the direction of flight.=C2- The magnitude of drag does not co me in here.=C2- The resultant force on the wing, however, and whether it acts =9Cforward=9D or =9Cbackward=9D, depends also on the drag magnitude.=0A=C2-=0AI apologize if I have caused any confusio n about wing L/D vs. AOA (I don=99t really think I have, though!)=0A ===================== ________________________________________________________________________________
Date: Jul 02, 2013
Frans, > But for me, as this was the topic of the original discussion, the question is: > what kind of forces do the wings pose on the fuselage? > > As the fuselage doesn't want to go forward without the wings, but still goes > forward with the wings, it looks to me that it is possible that the wings > somehow pull the fuselage forward. > When you fly with the engine pulling on the fuselage (cannot pull on the wings in the Europa!), the fuselage pulls the wings. When you glide, I don't know which part (fuselage or wings) have the best weight/drag ratio, so I don't know whether the fuselage wants to leave the wings behind or vice versa (I do suspect, though, that the wings are holding back the fuselage). At unusual attitude or high G-loading, it has been stated on this forum that wings (on other airplanes) have moved forward when they broke off. This means that there has been a forward (centerline direction) net force acting from the wings onto the fuselage at that time, in addition to a perpendicular (to centerline) component, of course. > And of course I have some clues as why the airplane (as a whole) actually > flies and I agree with your drawings, but again, the topic was: > the rear wing sockets, do they push or do they pull? > > To really answer this question you should drawn the vector diagrams not for > the airplane as a whole, but for each of the components that make up the > airplane. And then it would be interesting to see what resultant force is > acting on the rear wing sockets. > Except in very uncommon circumstances, the rear wing pins on Europa are pushing backwards on the fuselage-mounted sockets, and tries to bend in the fuselage sides/compress the cross tie bar between the left and the right side sockets, as the wings have a resultant force going back and up during normal powered flight. Whether the resultant force can ever be directed forward of the perpendicular to the centerline in the Europa, I have no idea - but I will keep the pins in, just in case! > > Has anyone actually ever tried to fly without the rear pip pins in? If so, what > happened? If not, what would happen? Could you get away with it, or will > the wings fold forward during the landing flare? > I don't think the forces are too large anyway, as the original Europa design > didn't have the interconnecting bar between the sockets, and the original > structure is not really that strong with respect to pulling and pushing forces. > Frans, please promise that you will not be the first one to try that!! ///////// I prefer to end my limited contribution to this tread now, but look very much forward to picking it up again over a cold beer at the Vichy fly-in. Perhaps also the beer's force may be determined by which way we are leaning ..? Regards, Svein ________________________________________________________________________________
Date: Jul 02, 2013
Thx Graham, My sentiments exactly. And to the question of why the spars are strapped together, and why one pin h as to be a pip pin, is because we have simple overlapping spars, and not for k spars, so the asymmetrical load on the pins wants to twist them off, as th e spar ends gets forced away from the other spar. Cheers, Pete On Jul 2, 2013, at 8:19 AM, GRAHAM SINGLETON wrote: > Svein > I admire your patience and courtesy, the persistent deniers on this tread have > just about exhausted mine! First of all one should start with the facts; w hen a wing > fails due to high positive load it claps forwards. Saying "I don't believe it because it > doesn't fit my understanding or theory might be described as "an academic r eaction to an inconvenient truth" > This "forward lift component" is very counter intuitive, the only way to a pproach it is to > refer to a diagram like yours. The criterion a lot of people overlook is t hat lift is > perpendicular to line of flight, which is NOT parallel with the centre lin e of the fuselage. > Nor is it 180deg from the line of gravity. > Graham > > > From: Sidsel & Svein Johnsen <sidsel.svein(at)oslo.online.no> > To: europa-list(at)matronics.com > Sent: Tuesday, 2 July 2013, 7:23 > Subject: SV: Europa-List: Re: wing lift/drag pins > > Ron, > > =46rom your message: > > > Attached is a diagram that is a pretty good visualization. > > Ron P. > > > > Here's his reply: > > No it=C3=A2=82=AC=84=A2s not=C3=A2=82=AC=C2 (a good visualiz ation) > > > > You have to apply real numbers to those phoney scalers on that figure. > > > > At high AOA the drag is significantly higher than shown, but lift not so much > > so. This would pull the L/D resultant much father aft. > > > > Those two plots are implying that the L/D of a wing is the same at cruis e and > > at high AOA which we all KNOW is not true! (the reason you never fly a h igh > > performance sailplane near Cl Max!) > > > > I assume it was my illustration that you forwarded to your friend. If so, I agree with his statement about L/D - the vectors are not to scale at all , and were not intended to be. I realize, however, that I should have empha sized this and also increased the length of the wing drag vector at the high AOA illustration, but this has no bearing on the lift component issue. > > My message =93 and illustration - had two purposes, which perhaps yo ur friend was not aware of: > > - To show that lift has no component in the direction of flight, r egardless of the angle of attack, while lift may have a =9Cforward =9D component, if "forward" means the direction the nose is pointing. > - To show that a glider is pulled forward (in the direction of gl iding flight) by gravity, not by any lift component. > > I have not made any calculation of the magnitude of the =9Cforward =9D lift component vs. drag on Europa or any other airplane, which is why I just referred to arguments and observations presented by others: "At so me point it may, as I read the discussion, become larger than the wing DRAG =99s component parallel to the centerline in the opposite direction, givi ng a net =9Cforward=9D force on the wing." The magnitude of su ch a =9Cforward=9D component is only dependent on the magnitude o f the lift and the angle between the centerline and the direction of flight. The magnitude of drag does not come in here. The resultant force on the w ing, however, and whether it acts =9Cforward=9D or =9Cback ward=9D, depends also on the drag magnitude. > > I apologize if I have caused any confusion about wing L/D vs. AOA (I don =99t really think I have, though!) > > Regards, > Svein > http://www.matronics.com/Navigator?Europa-Listofollow" target="_blank" h ref="http://www.matronics.com/contribution">h > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 02, 2013
Glad I didn't upset everyone {{!-)=0AGraham=0A=0A=0A=0A=0A_________________ _______________=0A From: Pete <peterz(at)zutrasoft.com>=0ATo: "europa-list@mat ronics.com" =0ASent: Tuesday, 2 July 2013, 14:5 4=0ASubject: Re: SV: Europa-List: Re: wing lift/drag pins=0A =0A=0A=0AThx G raham,=0A=0AMy sentiments exactly.=0A=0AAnd to the question of why the spar s are strapped together, and why one pin has to be a pip pin, is because we have simple overlapping spars, and not fork spars, so the asymmetrical loa d on the pins wants to twist them off, as the spar ends gets forced away fr om the other spar.=0A=0ACheers,=0APete=0A=0A=0A=0AOn Jul 2, 2013, at 8:19 A M, GRAHAM SINGLETON wrote:=0A=0A=0ASvein =0A>I admire your patience and courtesy,- =0A ________________________________________________________________________________
Date: Jul 02, 2013
=0A=0AFrans=0AI hope so too, you are a valued member on this forum!=0AThere was one tragic incident with a Europa Classic, one of the rear lift pins p ulled out of the threaded plate in the wing. There were doubts re original construction but nevertheless forward force must have been considerable.=0A Graham=0A=0A=0A________________________________=0A From: Sidsel & Svein Joh nsen =0ATo: europa-list(at)matronics.com =0ASent: Tuesday, 2 July 2013, 13:48=0ASubject: SV: SV: SV: SV: Europa-List: Re: wi ng lift/drag pins=0A =0A=0A=0AFrans,=0A=C2-=0A=0A> I don't think the forc es are too large anyway, as the original Europa design=0A> didn't have the interconnecting bar between the sockets, and the original=0A> structure is not really that strong with respect to pulling and pushing forces.=0A> =0AF rans, please promise that you will not be the first one to try that!!=0A=C2 -=0A/////////=0A=C2-=0AI prefer to end my limited contribution to this tread now, but look very much forward to picking it up again over a cold be er at the Vichy fly-in.=C2- Perhaps also the beer=99s force may be determined by which way we are leaning ?=0A=C2-=0ARegar ds,=0ASvein ________________________________________________________________________________
Date: Jul 02, 2013
Graham & Frans, There were more than doubts - the three alloy plates bonded into the wing root for the lift pin to be screwed into were so misplaced that the drilled hole overlapped the edge of one, just reached the edge of another and was only just missing the third, so seriously reducing the planned strength of the arrangement. It was never established definitely but it was thought likely that the dis -engagement of one tail plane led to a sudden nose up and o0verstress of the wing structure. Regards, David Joyce, G-XSDJ GRAHAM SINGLETON wrote: > > >Frans > I hope so too, you are a valued member on this forum! > There was one tragic incident with a Europa Classic, one >of the rear lift pins pulled out of the threaded plate in >the wing. There were doubts re original construction but >nevertheless forward force must have been considerable. > Graham > > > ________________________________ > From: Sidsel & Svein Johnsen > > To: europa-list(at)matronics.com > Sent: Tuesday, 2 July 2013, 13:48 > Subject: SV: SV: SV: SV: Europa-List: Re: wing lift/drag >pins > > > >Frans, > > >> I don't think the forces are too large anyway, as the >>original Europa design >> didn't have the interconnecting bar between the sockets, >>and the original >> structure is not really that strong with respect to >>pulling and pushing forces. >> >Frans, please promise that you will not be the first one >to try that!! > > ///////// > > I prefer to end my limited contribution to this tread >now, but look very much forward to picking it up again >over a cold beer at the Vichy fly-in. Perhaps also the >beers force may be determined by which way we are >leaning ? > > Regards, > Svein ________________________________________________________________________________
Subject: Where did I go wrong? OFF TOPIC
Date: Jul 02, 2013
Cheers, I am in receipt of another of these gamy emails written in WWI shorthand - that is a page and a half of letters and figures which defy decoding in my tiny experience. I have the terrible feeling that I have failed the group - have fingered a faulty choice of buttons - have failed to read a perfectly obvious discretionary warning, - or worse still, am the only one seeing this block of hieroglyphics which does not exist......and am now for the high jump at the Home for the Delightfully Bewildered. What have I done wrong? Is it faulty genetics, a social failing, even a casually-dropped curse? Help me. Ferg C-FFGG ________________________________________________________________________________
Date: Jul 02, 2013
Hello All. What are the rear tie bar and pins used for. So for all with an open opinion on this topic , this is what Europa Aircraft Company say about the Tie Bar. Which gives the full picture, and states Drag and Forward movement. A requirement to stop the wings fold back, and Forward to stop the wing pulling forward at high angles of attack, and there's no way this forward force would rip the rear mounting out from the fuselage, that occurred after something failed to cause the aircraft to break up. Quote. Europa Tie-bar As the trailing edge lift pin also acts to contain drag loads and the forward component of lift which is produced at high angles of attack, a tie-bar will be fitted across the fuselage to react these loads. A general arrangement of the tie-bar assembly and associated parts is shown in figure 8. Fig 8. Alan Also acts,? what else does it do ?. Don't answer that please. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403832#403832 ________________________________________________________________________________
Date: Jul 03, 2013
>Also acts,? what else does it do ? It transfers lift to the fuselage and locates the trailing edge of the wing at the appropriate angle of incidence (as does the leading edge wing pin). Builders' Manual Ch 26, P 26-1: "There are two pins in each wing to transfer lift to the fuselage; one at the leading edge and one, which doubles to take drag loads, is at the trailing edge." Ch 27, P 27-1: "The wing lift pins locate into sockets, which are to be attached to the fuselage sides, and these hold the wing at the determined angle." >Don't answer that please. Oops sorry, too late! Paul M G-PLPM XS Mono 912S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403850#403850 ________________________________________________________________________________
From: "William Daniell" <wdaniell.longport(at)gmail.com>
Date: Jul 03, 2013
This whole discussion has been fascinating. IMHO lot of the discussion is related to the difficulty of describing a three dimensional event in words (by the way I admire Frans=92 and Svein=92s grasp of English) As I understand this and for the purposes of the discussion Motive power is provided primarily from the fuselage in the form of 1. the engine when running 2. or in its absence the mass of the aircraft which is mostly concentrated in the fuselage being acted upon by the acceleration provided by gravity. Drag affects the aircraft all over its surface but in level flight the wings are forced toward the rear of the aircraft by the relative wind acting upon the leading edge. The wings provide the majority of the lift (a minimal being provided by the fuselage) in two ways but can only be created by forward motion with respect to the relative wind. (if the relative wind is zero then it wont fly) 1. benouille=B4s effect which is perpendicular to the cord 2. force of the relative wind against the lower surface of the wing. I am assuming that this varies in a complex way. One can see the in level flight the mass of the aircraft is supported by the wings and this support is transmitted by the 4 points at which the wings connect to the fuselage. The force of the relative wind against the leading edge trying to fold the wings to the rear of the aircraft is being counteracted by the rear lift sockets and (I would also guess) by the main wing spars. So in this case the tie bar is in compression. I have difficulty with visualizing how the tie bar could be in tension. I suppose that with the relative hitting the lower surface of the wing at a high angle of attack on could foresee a force component towards the front of the fuselage though not in the direction of flight but it seems hard. Maybe Rons engineer can try to explain it to us less technical folks. I am continually surprised by what I learn on the forum. Yours Will Bogota From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: Tuesday, July 02, 2013 09:01 Subject: Re: SV: Europa-List: Re: wing lift/drag pins Glad I didn't upset everyone {{!-) Graham _____ From: Pete <peterz(at)zutrasoft.com> Sent: Tuesday, 2 July 2013, 14:54 Subject: Re: SV: Europa-List: Re: wing lift/drag pins Thx Graham, My sentiments exactly. And to the question of why the spars are strapped together, and why one pin has to be a pip pin, is because we have simple overlapping spars, and not fork spars, so the asymmetrical load on the pins wants to twist them off, as the spar ends gets forced away from the other spar. Cheers, Pete On Jul 2, 2013, at 8:19 AM, GRAHAM SINGLETON wrote: Svein I admire your patience and courtesy, ________________________________________________________________________________
Subject: Dawn to Dusk Challenge
Date: Jul 03, 2013
I am planning an attack on the all time distance record for the D2D Challenge on Sunday if the weather turns out as good as currently forecast. It stands at 2500nm currently, and I calculate that a figure of 8 round UK, Hebrides Orkney & Shetland mainlands and Ireland will do the trick! It will need rather a long time in the air averaging 150kts, but if the weather Gods smile and the donkey keeps going it might just be possible. Plan to fly it atFL95 apart from the lower level bit round SE England. Regards, David Joyce G-XSDJ (mono 914 Woodcomp SR3000W + purpose built, LAA approved 100litre long range tank) PS the 3 planes at the top of the distance record list are: 1 Beech Baron; 2. Mooney; 3. Hawk Jet!! ________________________________________________________________________________
Date: Jul 03, 2013
Hi David, May the weather Gods and saint-Rotax be with you but I'm sure all the Europa fellows will! Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 450 hours F-PLDJ DynAro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures -----Message d'origine----- De: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de David Joyce Envoy: mercredi 3 juillet 2013 19:53 : europa list Objet: Europa-List: Dawn to Dusk Challenge --> I am planning an attack on the all time distance record for the D2D Challenge on Sunday if the weather turns out as good as currently forecast. It stands at 2500nm currently, and I calculate that a figure of 8 round UK, Hebrides Orkney & Shetland mainlands and Ireland will do the trick! It will need rather a long time in the air averaging 150kts, but if the weather Gods smile and the donkey keeps going it might just be possible. Plan to fly it atFL95 apart from the lower level bit round SE England. Regards, David Joyce G-XSDJ (mono 914 Woodcomp SR3000W + purpose built, LAA approved 100litre long range tank) ________________________________________________________________________________
Subject: Re: Dawn to Dusk Challenge
Date: Jul 03, 2013
David, Good luck and following winds. Ivan Sent from my iPad On 3 Jul 2013, at 18:52, "David Joyce" wrote: > > > I am planning an attack on the all time distance record for the D2D Challenge on Sunday if the weather turns out as good as currently forecast. It stands at 2500nm currently, and I calculate that a figure of 8 round UK, Hebrides Orkney & Shetland mainlands and Ireland will do the trick! It will need rather a long time in the air averaging 150kts, but if the weather Gods smile and the donkey keeps going it might just be possible. Plan to fly it atFL95 apart from the lower level bit round SE England. > Regards, David Joyce G-XSDJ (mono 914 Woodcomp SR3000W + purpose built, LAA approved 100litre long range tank) > PS the 3 planes at the top of the distance record list are: > 1 Beech Baron; > 2. Mooney; > 3. Hawk Jet!! > > > > ________________________________________________________________________________
Subject: Philip Levi at the AGM
Date: Jul 03, 2013
Philip, Sorry to send this through the Matronics site but I do not have your email. You were taking photos at the AGM. Can you let us have sight of them for the Magazine, please. Thanks Steve Pitt Chairman ________________________________________________________________________________
Subject: Angle of Incidence on a Classic Taildragger Downunder
Date: Jul 04, 2013
Gidday, I have set up my port wing, pulling it in tight agains the rear face of the cockpit module and setting the incidence. I've used a digital level and upon bonding on the LE lift pin socket I found the incidence had changed nominally. I have attempted to make a small adjustment with the TE socket position which is reduced but not bolted, yet. It was suggested that I could twist the spar nominally to get the angle accurate but to be honest I didn't like doing that although I suppose it wouldn't have mattered that much because we might only be talking about a % of a single degree of twist. Still, I didn't like that idea. Suffice to say I now somehow have 2.8 degrees which is to me unacceptable, BUT, its a lot of work to undo things. That probably isn't completely true as I only have the sockets mounted with Redux, so I could heat them and snap them off and start again, but I worry I'm going to do a lot of work and may well end up right back where I've started. My pins fit nicely in the back of the seat, and that took a lot of mucking around, and I worry that to undo things and redo them I mightn't get the same result. I want to know what people think of this angle, whether anyone else has not set it perfectly, what difference they perceive it might make on their plane, and whether anyone has factual consequence of it not being 100% right. I do worry only about the relationship of the tailplane to the wing, but having a fully flyable tailplane removes some of the problems of not having a perfect AoI. The impact could be however that at optimum in trim cruise the tailplane may be at a slightly different angle at an optimum CoG, and the full range of pitch may be not what was originally planned. So, if anyone has advice I'd really appreciate input. I should also add that I am building a taildraggers, a Bob Berube mod from Florida, which relies on the same moments as the mono wheel by having the design such that the a/c has a similar stature on the ground. Maybe the higher AoI might be a bonus, and help me fly away better, climb better, but no go quite as fast. To be honest, I don't care anymore as I would prefer to not have to undo stuff I have done. I'm becoming pretty good at that but unfortunately keep practicing the skill. Regards Tony Renshaw ________________________________________________________________________________
Date: Jul 04, 2013
Subject: Trip to Australia, is it possible?
Hi Friends, After our recent north cape trip Ilona and I are looking fow a new adventure. Ilona and I always wanted to go to Australia and we are now wondering if we could do that in our own Europa. We suddenly realised that my son will graduate next year and now he is still living at home and yet old enough to carry some responsibility to take care of our house, webshop and animals, this might be a convenient moment to undertake such a journey. We haven't been doing more yet than looking at the world globe and seeing that technically it should be possible. Before putting some time in it and then discovering that some countries would be unsolvable obstacles, I think it may be faster to ask for info on this list. I remember having seen some references to such a trip or the preparations for it, if this is correct it would be very valuable to learn from it. First questions that come to mind are: What time of year would be best for such a trip? I'm aware of the mosson-rain in some countries, but is the whole period unsuitable for flying? What about the middle-east and aziatic countries, is General Aviation possible? Do they tolerate home built airplanes? How much bureaucrazy is involved and how much time is needed to get the necessary permissions? Any info for this wild idea is welcome, either positive or negative. Thanks, Frans ________________________________________________________________________________
Subject: Re: Angle of Incidence on a Classic Taildragger Downunder
Date: Jul 04, 2013
Tony, I can tell you from experience that both wings have to be the same. I set my up with the fuselage bottom only. I now have both top and bottom on and have 30 hours of flight time. I have a left wing low. I went back and measured both wings and the right is 2.4 degrees and the left is 1.7 degrees. Not sure why! I took pictures of the level showing 2.5 degrees on both wings! I have lower the left wing flap about a degree or two, but at low speed the aircraft left wing drops in a second. I'm planning on resetting the front socket. I'm worried about the holes that I drilled in the metal plate that is in the fuselage and will cut out the fuselage skin and add a plate to the ole one then set the wing up correctly. Do it right the first, second, third time. If it's right you will have no troubles when you fly it. Use a laser measure from the tail plane tubes to the wind aileron end plate to set the sweep. Rick Stockton N120EJ Jabiru 3330L Whirlwind Ground Adjustable Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403926#403926 ________________________________________________________________________________
Subject: Re: Trip to Australia, is it possible?
Date: Jul 04, 2013
Frans, it is possible. A Tiger Moth did it in 2001 or thereabouts. I had planned to do it in 2009 with Ivor Phillips, in one plane each with long range tank sitting in passenger seat. Doing it 2 up would be considerably more of a challenge. We got to an advanced stage in our planning before my son developing Motor Neurone Disease put paid to my plans. We worked out that a March departure was probably optimal. I did write up an article in the Europa Flyer with a brief description of the main issues, but would be p,eased to share that reticle and other fruits of our research with you off list. I have to say hat the more research we did the more apparent it became that it would be very expensive and pone to considerable hassle in many countries once East of central Europe. Regards, David Joyce, G-XSDJ Frans Veldman wrote: > > > Hi Friends, > > After our recent north cape trip Ilona and I are looking >fow a new > adventure. > > Ilona and I always wanted to go to Australia and we are >now wondering if > we could do that in our own Europa. We suddenly realised >that my son > will graduate next year and now he is still living at >home and yet old > enough to carry some responsibility to take care of our >house, webshop > and animals, this might be a convenient moment to >undertake such a journey. > > We haven't been doing more yet than looking at the world >globe and > seeing that technically it should be possible. > > Before putting some time in it and then discovering that >some countries > would be unsolvable obstacles, I think it may be faster >to ask for info > on this list. I remember having seen some references to >such a trip or > the preparations for it, if this is correct it would be >very valuable to > learn from it. > >First questions that come to mind are: What time of year >would be best > for such a trip? I'm aware of the mosson-rain in some >countries, but is > the whole period unsuitable for flying? What about the >middle-east and > aziatic countries, is General Aviation possible? Do they >tolerate home > built airplanes? How much bureaucrazy is involved and >how much time is > needed to get the necessary permissions? > > Any info for this wild idea is welcome, either positive >or negative. > > Thanks, >Frans > > >Un/Subscription, >Forums! >Admin. > > > ________________________________________________________________________________
Date: Jul 04, 2013
PS Flying to the Canaries is a moderately challenging adventure which will give you a good flavour of the difficulties of getting permission to fly a Permit A/C through. Non European country. It took me 5 1/2 months to get permission! David Frans Veldman wrote: > > > Hi Friends, > > After our recent north cape trip Ilona and I are looking >fow a new > adventure. > > Ilona and I always wanted to go to Australia and we are >now wondering if > we could do that in our own Europa. We suddenly realised >that my son > will graduate next year and now he is still living at >home and yet old > enough to carry some responsibility to take care of our >house, webshop > and animals, this might be a convenient moment to >undertake such a journey. > > We haven't been doing more yet than looking at the world >globe and > seeing that technically it should be possible. > > Before putting some time in it and then discovering that >some countries > would be unsolvable obstacles, I think it may be faster >to ask for info > on this list. I remember having seen some references to >such a trip or > the preparations for it, if this is correct it would be >very valuable to > learn from it. > >First questions that come to mind are: What time of year >would be best > for such a trip? I'm aware of the mosson-rain in some >countries, but is > the whole period unsuitable for flying? What about the >middle-east and > aziatic countries, is General Aviation possible? Do they >tolerate home > built airplanes? How much bureaucrazy is involved and >how much time is > needed to get the necessary permissions? > > Any info for this wild idea is welcome, either positive >or negative. > > Thanks, >Frans > > >Un/Subscription, >Forums! >Admin. > > > ________________________________________________________________________________
Date: Jul 04, 2013
On 07/04/2013 04:11 AM, Tony Renshaw wrote: > > > Gidday, I have set up my port wing, pulling it in tight agains the > rear face of the cockpit module and setting the incidence. I've used > a digital level and upon bonding on the LE lift pin socket I found > the incidence had changed nominally. Forget this digital level. Been there, done that. It changes everytime, depending on where you measure and other obscure variables. It drives you nuts and leads nowhere. And is not precise enough anyway. Prepare two blocks of some suitable material (wood, blue foam), about 4 cm or so high, and make sure they are of exactly the same size. Put them on the trailing edge of the wing, at the same distance from the fuselage. Now walk away from the airplane. At least 5 meters, more is better. Bring the top of the leading edge exactly in line with the block on the trailing edge (just like aiming a gun, you could as well put a needle on the block and a hairline cross sticking out of the leading edge). On both sides (port and starboard) you should have the leading edge and blocks in line at exactly the same eye height. You will notice that moving your eye just a cm up or down will make a whole difference. If you do the math, you will find out that this method is many times more precise than any digital level and you will be able to sight fractions of a degree. What's more, you can repeat this with the blocks at varying distances from the fuselage (but keep port and starboard always at the same distance to cancel the wash out!) and get some "avarage" out of it to cancel out minor imperfections of the shape of the wing. You can get it even more precise if you use some reflecting material, or put a bright LED on top of the blocks, or use some sort of back light. It is just like seeing the exact moment of sun rise or sun set. At 20 meters away it is awfully precise to see if both wings are equal: both leds (or lamps) should rise at exactly the same moment over the leading edge while you move your head slowly up! Less than just a millimeter of difference in trailing edge will be clearly visible. I ended up doing the wings this way, the outcome was stable, repeatable and very precise, and during curing of the araldite I kept the blocks on and "sighted" the wings regularly to be sure that nothing moved. The airplane can be flown right into a stall and just bobs up and down like a straight Cessna, not even the smallest tendency to wing drop. > Suffice to say I now somehow have 2.8 degrees > which is to me unacceptable, The target was 2.7 if I recall correctly? Then don't worry. I set mine deliberately at 0.1 steeper because I have a high top and would prefer just a tad more nose down to cancel out the steeper angle of the roof and to get more view over the higher firewall. Flies beautifully! Frans ________________________________________________________________________________
Date: Jul 04, 2013
On Jul 4, 2013, at 9:32 AM, Frans Veldman wrote: >> >> Suffice to say I now somehow have 2.8 degrees >> which is to me unacceptable, > > The target was 2.7 if I recall correctly? I believe the XS build manual calls for 2.5 degrees... Fred ________________________________________________________________________________
From: "Richard Lamprey" <lamprey.richard(at)gmail.com>
Date: Jul 04, 2013
Getting it right first time is good. But also I dimly remember (from the days of the Europa Newsletter, around 1997) the tale of G-KITS, the first factory demonstrator for the Classic tri-gear, where one wing was accidentally built with 1 degree WASHIN, not 1.5 degree washout. You would think it would have stall/ wingdrop characteristics from hell, but apparently it flew just fine, and is still flying - I see its picture online. So perhaps there is some leeway in the AoI. Richard Classic Reg 5Y-LRY, Kenya Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403933#403933 ________________________________________________________________________________
Subject: windscreen de-fogging
Date: Jul 04, 2013
Gentlemen, I'm attempting to select a couple of computer fans to be mounted louvers in the top of the instrument panel module for the purpose of de-fogging the windscreen...I'm uncertain as to what cfm ratings or sizes will do the job. If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient...I'd be grateful I suspect that my local climate in the Pacific NW of the US is similar to conditions in UK. Thanks in advance, Fred A-194 ________________________________________________________________________________
Date: Jul 04, 2013
Subject: Re: windscreen de-fogging
On 07/04/2013 07:12 PM, Fred Klein wrote: > I'm attempting to select a couple of computer fans to be mounted > louvers in the top of the instrument panel module for the purpose of > de-fogging the windscreen...I'm uncertain as to what cfm ratings or > sizes will do the job. I did that too, and despite our damp climate I have used them only twice (and found out that they didn't contribute much anyway). You'd probably better save the weight. Frans ________________________________________________________________________________
Date: Jul 04, 2013
Fred Klein a crit : > > Gentlemen, > > I'm attempting to select a couple of computer fans to be mounted louvers in the top of the instrument panel module for the purpose of de-fogging the windscreen...I'm uncertain as to what cfm ratings or sizes will do the job. > > If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient...I'd be grateful > > I suspect that my local climate in the Pacific NW of the US is similar to conditions in UK. > > Hi Fred, Here is what we did recently : http://contrails.free.fr/cellule_defog_en.php Not much weight involved (about 700-800 g) though we feel that our 380 kg four seater is a bit on the heavy side ;-) FWIW, Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jul 04, 2013
Hi Fred "If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient" I chose to use four 12 volt mini fans. They are run off a 3 position (low, high and off). If 2 are put in series it's low, and if run off bus voltage, then high. Yes idea as a minimiist demister but also to get heat out from under instrument module. You can find info on what I am doing (I did quite a bit of fooling with different fans. There is also a folder on that page "Panel cooling and demisting ideas by others." http://www.europaowners.org/main.php?g2_itemId=27305 I am installing temp probes under the instrument module so will be able to see temps. Ron Parigoris ________________________________________________________________________________
Date: Jul 04, 2013
Tony, Welcome to my world. The first Europa I purchased used had the left wing at 2.6 and the right at 3.1. I moved the sockets in the right fuselage side to 2.6. It flies straight and true. If you were to set both at 2.8 degrees your fuselage will be nose down a bit at cruise, which shouldn't hurt a thing. Just go for it. As for your gear relationship, deck angle etc. on landing, I can only say that the extra bit of incidence will allow you to be closer to the stall angle at the three point touchdown and improve over the nose visibility. In practice I found that I can correct with flap and aileron trimming up to .2 degrees incidence difference and you will never see my changes. At .4 incidence difference, I have to modify the the wing leading edge to get a perfectly straight stall. First consider this: To be sure as Frans and others might say that later, that all digital and spirit or bubble levels are not equal. In fact I have one that is off .3 degrees when tested at three degrees. My test bench is a simple 3 inch block in 60 inches and with the level facing one direction and when the level is rotated 180 degrees putting the scale window on the other side it measures 2.7 degrees rather than the three. That's 10 percent off. So it is best to set your spirit level or digital level on a dead flat surface and check the zero to 3 degree setting. I used to set my level at 2.5 degrees (2.5 inch board at 60 inches) 3 degrees, 5 degrees and 12 degrees for calibration purposes of the wing incidence, and tail planes to make sure things are fairly close to the manual. Since your sockets are only in Redux, snap them off and fix them both is what I would do. I have found that the best way to make sure things don't move is to shore up the wing well during cure. Just in case the temp changes over cure time, I block the gear also if necessary. Trigear, I put a pipe in the main gear, and for the conventional, I block the spring gear itself. I know that you don't really want to hear this but the standard rule in my shop is take it apart and put it together (normally about 5 times) until it is repeatable and easy to do. That means when building glider wings, or rigging the plane, or hanging the cowl if you try to do things in one shot, you will have to redo it to get it right. The worst thing to happen when rigging wings is to have the left spar creep aft during the socket build up then it causes so many troubles down the road. Take your time, make sure it fits all around then tack it in place. The only difference between a professional build and an amateur build, is I know how to fix my mistakes before it affects something else. As for the tail dragger, good luck. It is best to modify the gear to get the position of the axle to leading edge of the wing MAC (about 2/3 out on the wing from fuselage centerline) over the axle with the fuselage in level position. Contact Grove, as Bobby Grove has a couple of solutions. (New gear or 1/4 inch steel plates to increase deck angle and move the axles back about 4-5 inches. As the gear as is, I find it un-gratifying to fly the gear as designed. It is very tough to wheel land the conventional due to the spring stiffness and forward position. With a 10 Knot cross wind I can land on one main and do a wheel landing with ease and no tire wear (without the crosswind, tire wear on a wing low slightly slipped landing is more than I care to pay for). Three point is not a problem. It is quite tough to teach a new guy how to land and takeoff with the gear as set. It's a mono except it doesn't fall over when the wings are pulled off. If you hit mains first with any vertical component, the tail drops faster than you can react and combined with the extra lift from the drooping tail added to the gear spring reaction, you get launched back in the air, then hit the tail wheel, you over correct and down on the main again resulting in a porpoise which continues to increase in speed and frequency naturally and any PIO combination can be a disaster. Just go around and get the tail wheel on first. Don't relax on roll out as between 45 to a fast walk it tends to wander and you have to "stay on it". Not difficult to master, it just takes practice, discipline and the ability to go around early when it doesn't work out on first contact. Go around early and save yourself and the plane. I highly recommend you do not install a fully swiveling tail wheel unless you can lock it from the cockpit as the torque of a 912S with Airmaster is enough that a moment of inattention or failure to keep the stick full back is a real eye opener for the new guy on takeoff if the tail wheel is not positively locked. Next, on landing or a bounce, if slightly sideways, the tail wheel may unlock and you will be off to the races with no tail control but the rudder which is not effective at really low speed on takeoff or roll out... Find a Luscombe with a bad wheel alignment on steroids to practice with on asphalt. Keep it straight, lower your IQ to a 2 and hold it off until hit the tail wheel first. You'll be fine. Regards, Bud ----- Original Message ----- From: Tony Renshaw<mailto:tonyrenshaw268(at)gmail.com> To: europa-list(at)matronics.com Sent: Wednesday, July 03, 2013 10:11 PM Subject: Europa-List: Angle of Incidence on a Classic Taildragger Downunder > Gidday, I have set up my port wing, pulling it in tight agains the rear face of the cockpit module and setting the incidence. I've used a digital level and upon bonding on the LE lift pin socket I found the incidence had changed nominally. I have attempted to make a small adjustment with the TE socket position which is reduced but not bolted, yet. It was suggested that I could twist the spar nominally to get the angle accurate but to be honest I didn't like doing that although I suppose it wouldn't have mattered that much because we might only be talking about a % of a single degree of twist. Still, I didn't like that idea. Suffice to say I now somehow have 2.8 degrees which is to me unacceptable, BUT, its a lot of work to undo things. That probably isn't completely true as I only have the sockets mounted with Redux, so I could heat them and snap them off and start again, but I worry I'm going to do a lot of work and may well end up right back where I've started. My pins fit nicely ! in the back of the seat, and that took a lot of mucking around, and I worry that to undo things and redo them I mightn't get the same result. I want to know what people think of this angle, whether anyone else has not set it perfectly, what difference they perceive it might make on their plane, and whether anyone has factual consequence of it not being 100% right. I do worry only about the relationship of the tailplane to the wing, but having a fully flyable tailplane removes some of the problems of not having a perfect AoI. The impact could be however that at optimum in trim cruise the tailplane may be at a slightly different angle at an optimum CoG, and the full range of pitch may be not what was originally planned. So, if anyone has advice I'd really appreciate input. I should also add that I am building a taildraggers, a Bob Berube mod from Florida, which relies on the same moments as the mono wheel by having the design such that the a/c has a similar stature on the ground. Maybe the higher AoI might be a bonus, and help me fly away better, climb better, but no go quite as fast. To be honest, I don't care anymore as I would prefer to not have to undo stuff I have done. I'm becoming pretty good at that but unfortunately keep practicing the skill. Regards Tony Renshaw http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
From: "Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no>
Date: Jul 04, 2013
Hi Fred, I use the big fan up front! The NACA inlet on the right side, originally intended for fresh air into the cockpit, is not leading air into the cockpit but into the panel (made a duct of bid and epoxy from the NACA to the right underside corner of the panel, easily removable by one screw. On top of the panel, I have made long cutouts about 1/4" wide, close to the front edge. Leave enough un-cut material to maintain strength, ref. the bolts holding the panel to the top of the firewall. It is surprising how tight the panel is along the bottom, but if necessary you can put in some soft foam or other suitable sealing material (I have not). Soon after starting the engine, while the oil is still warming up before starting to taxi, I can see the mist disappearing on the front window. Heating of the air flowing through behind the panel is from the instruments and through the firewall. This ventilation therefore also helps keeping the instrument temps down (never has been an issue, even in southern Europe on hot summer days). As you well know, no air comes into the cockpit unless it also is allowed to escape. I assume you already have made an efficient air outlet from the cockpit, both for this de-mist air, for fresh air into the cockpit in the summer (through the left side NACA in my case) and for cabin heating in the cold season (I take warm air from behind the water cooler). Regards, Svein LN-SKJ ________________________________________________________________________________
Subject: Re: wing lift/drag pins
Date: Jul 04, 2013
Alan, Your analysis of the bar and reason for the aft socket pin is good enough to build the plane or maintain it. Understanding the lift affects is really a vector analysis exercise. I studied a T-28 wing failure accident and we were lucky enough to have a video of the failure. The wing failed at a speed of 270 KIAS and the video clearly showed that when the badly corroded spar and skin failed (main wing spar is at about the 1/4 chord) the wing went full up as if it were folded and hit the pilot on the head killing him instantly not aft at all. In another accident at an airshow the main spar failed first and began to flutter, the pilot unloaded and the main spar failed first, and the wing trailed aft because the wing twisted up and aft spar and upper skin hung on longer. Tragic accidents but changes were made and T-28s still fly on well, when properly maintained. When building model airplanes as a kid and just experimenting with tailless designs, using a Clark Y airfoil, it flipped nose up badly even when the CG was on the CL due to the wing pitching moment. The same test with a symetrical airfoil was a piece of cake. The symetrical airfoil has no pitching moment until the flaperon was deflected then whamo. The wing lift vector is not perpendicular to the chord or angle of attack but is drawn as such in many training documents. In the US Air Force I was drafted to rewrite the aero portion of our pilot texts and teach it for a year. I had to teach the test questions because most pilots (the generals included) are not aerodynamicists they know that the houses get bigger when pushing forward and smaller when pulling back unless you pull too much back stick. Things like if the engine quits, bail out, and you can never have too much fuel (unless you are on fire) works in some cases, but not for us lowly piston engine guys who do not have fuel dumps and ejection seats. Our little bird will pull forward on the aft support at modest and high angles of attack and when unloaded to 1 G or less will go to neutral and then to compression. Get it flying and enjoy the plane. Regards, Bud ----- Original Message ----- From: Alan Carter<mailto:alancarteresq(at)onetel.net> To: europa-list(at)matronics.com Sent: Monday, July 01, 2013 1:36 PM Subject: Europa-List: Re: wing lift/drag pins > Hello Frans. Who is pulling it. Gravity It will move is an arc towards the ground. A wing is similar to a sail on a sailing boat. You can not sail directly into wind you can get to about 30 degrees of it. Sorry Frans but at the moment i am still puzzled. At the moment i am thinking this bar has three purposes, 1. to prevent the drag pulling the wing back, which is most of the time. 2. two provide the rigidity to the structure so keeping the front pin locked into its mounting. 3. to stop the wing coming "forwards" in abnormal wing loadings, Possible very high A/A, near the stall, or gusts, or abnormal flight attitudes. This puts this bar in compression , tension and neutral loads But i am willing to change my mind,as i have used up ask a friend, may be its time to ask the audience, Regards . Alan Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=403725#403725 .matronics.com/viewtopic.php?p=403725#403725> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Jul 04, 2013
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
The AoA that must be accurate is at roughly the outboard end of the spar. =0AAoA at the wing root is pretty irrelevant. Think about it, there's almos t no rolling moment there. =0AI made a jig to measure AoA using the leading edge and the trailing edge, a Vee on it's side for the LE and a straight e dge to sit on the trailing edge. Straight edge to join the two. This is you r datum line, not essential that it is parallel to the wing chord line but you will need to use a digital level.=0ANext get the first wing set up as p er the manual.=0ANow set up the second wing to match the first. =0AIt would n't do any harm to check the wings at the tips too, this will=0Atell you if the wings have different washout angle but maybe you didn't want to know t hat!=0AGraham=0A=0A=0A=0A=0A________________________________=0A From: AirEu pora =0ATo: europa-list(at)matronics.com =0ASent: Thu rsday, 4 July 2013, 16:39=0ASubject: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downunder=0A =0A=0A--> Europa-List message posted by : "AirEupora" =0A=0ATony, I can tell you from expe rience that both wings have to be the same.- I set my up with the fuselag e bottom only.- I now have both top and bottom on and have 30 hours of fl ight time.- I have a left wing low.- I went back and measured both wing s and the right is 2.4 degrees and the left is 1.7 degrees.- =0A=0ANot su re why!- I took pictures of the level showing 2.5 degrees on both wings! =0A=0AI have lower the left wing flap about a degree or two, but at low spe ed the aircraft left wing drops in a second.- I'm planning on resetting t he front socket.- =0A=0AI'm worried about the holes that I drilled in the metal plate that is in the fuselage and will cut out the fuselage skin and add a plate to the ole one then set the wing up correctly.=0A=0ADo it righ t the first, second, third time.- If it's right you will have no troubles when you fly it.- Use a laser measure from the tail plane tubes to the w ind aileron end plate to set the sweep.=0A=0ARick Stockton=0AN120EJ=0AJabir u 3330L=0AWhirlwind Ground Adjustable=0A=0A=0A=0A=0ARead this topic online here:=0A=0A
http://forums.matronics.com/viewtopic.php?p=403926#403926=0A ==================== ________________________________________________________________________________
Date: Jul 04, 2013
Ron, I installed both 40 mm and 80 mm computer CPU fans and frankly, the 40s don't move that much air. The 80s do better at venting the hot air out of the panel. Some electronics get quite warm and I wanted to cool the panel, not really defrost. That was a hopeful side effect of the installation of the fans. The first setup on 12AY I put the fans too far forward and they blow into the windscreen support. To be honest, I can't even feel the air flow moving up the windscreen, it moves sideways. That was a dumb execution of a good idea. On others, I move the fans as far aft toward the pilot as I can to pull the Garmin 430 and Dynon Skyview heat out of the panel. They both get pretty hot. I have found that the air comes up the windscreen, but is not hot enough or fast enough in the winter to feel like a defogger, but at least it moves the air up the windscreen. If you have an Ameriking type cooling fan, one leg of that would be about as strong as my two 80s... The Grand Rapids and Becker radios are pretty cool running and frankly the panel only gets about 10 degrees warmer than the cockpit, so without the heat and high forced air flow of an auto type defogger, I do not see it as much help on a cold day at altitude with a quick descent to the warmer air below steaming things up. Sorry I don't have more info for you. It's just too hot here in Florida. Even in the winter, although my canopy top fogs up and my screen fogs for a second or two, they both clear once the inside and outside temps stabilize. Regards, Bud ----- Original Message ----- From: rparigor(at)suffolk.lib.ny.us<mailto:rparigor(at)suffolk.lib.ny.us> To: Europa Sent: Thursday, July 04, 2013 2:11 PM Subject: Re: Europa-List: windscreen de-fogging Hi Fred "If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient" I chose to use four 12 volt mini fans. They are run off a 3 position (low, high and off). If 2 are put in series it's low, and if run off bus voltage, then high. Yes idea as a minimiist demister but also to get heat out from under instrument module. You can find info on what I am doing (I did quite a bit of fooling with different fans. There is also a folder on that page "Panel cooling and demisting ideas by others." http://www.europaowners.org/main.php?g2_itemId=27305 I am installing temp probes under the instrument module so will be able to see temps. Ron Parigoris http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
From: Kevin Challis <kevinmarie(at)blueyonder.co.uk>
Date: Jul 04, 2013
I have no fans and it gets a little fogged up on the ground in the winter but I open the door and it clears. I never have any problems in the air and I have no heater. Kevin Challis G ODJG Tri gear 912s On 4 Jul 2013, at 19:12, Fred Klein wrote: > > Gentlemen, > > I'm attempting to select a couple of computer fans to be mounted louvers in the top of the instrument panel module for the purpose of de-fogging the windscreen...I'm uncertain as to what cfm ratings or sizes will do the job. > > If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient...I'd be grateful > > I suspect that my local climate in the Pacific NW of the US is similar to conditions in UK. > > Thanks in advance, > > Fred > A-194 > > > > ________________________________________________________________________________
Subject: Europa Tech Support
Date: Jul 04, 2013
Guys, As you know Europa is finally in there new digs at Wombleton Airfield, York, UK. I am so happy for Dave Stanbridge and all the folks at Wombleton, because who would not be excited about owning your own airport and airplane factory. Now that the factory and maintenance facility are co-located, I will no longer be supplying tech support for the factory. Please refer any questions to the numbers on the Europa Website and they will help you out. I will personally monitor the matronics list to keep in touch and pass on my personal comments on your questions if I can be of help. Of course if you call or email me direct I will still assist where I can as the US dealer for Europa Aircraft. I am happy to say that my prostate cancer scare will be soon behind me as well. I will have a few paperwork battles, but it is a relief not to have to shut down the shop, sell off my planes and pee into a bag. I recently repaired the fuel leak on my 914 fuel line and 12AY is patiently waiting for the weather and work schedule to allow a test flight. Regards, Bud Yerly ________________________________________________________________________________
Subject: Re-setting the front socket
Date: Jul 04, 2013
Hi Rick, Andy Cullum G-CGDH, I read your script about adding a plate To your front mounting plate. With respect,I have to say its a relatively easy exercise to machine out the whole old plate with a depth set router,set with the depth just short of the 3mm Mount plate,then you can just peel out the remains of the old plate. Best regards Andy Cullum. Sent from my iPhone ________________________________________________________________________________
Date: Jul 04, 2013
Hi Bud. Good to hear from you, It was for me, a very interesting topic as when i look at the wing attachments they look pretty flimsy, Initially it was said that the load on the pins are always pulling forward,then forward got muddled with forward as if flight forward,which i could not understand,as i have seen many model aircraft wings break off in flight and they just folded straight up, then the overall purpose and workings of this bar and pins slowly fell into place,now i have a much better understanding of it. I have done some work on the plane, now have independent starter and mag switches, new mounting for ipad, and my torque tube has clamps on s, so no free play,but have just fitted a new mag ht coil at 288,made in chine for 2.50. Flying tomorrow to the Isle Of Wight, weather permitting. All the best. Alan Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=403958#403958 ________________________________________________________________________________
Date: Jul 04, 2013
Hi Bud again, Its been 14 years since I was flying, and the old memory is not as good. All I can remember is bendy wings, and use to have a weight and balance sheet and it had this Zero Fuel Weight , think it was about 122000 lbs, I have this C of G calculator and when I do a weight and balance with the Europa figures I get an Out of Zero Fuel Wight some times, can,t see how this applies to a Europa, no wing tanks, Am I missing something, Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403962#403962 ________________________________________________________________________________
Date: Jul 04, 2013
Alan, Hope the flight goes well. Sounds like you have prepared properly. As for CG, I am afraid that since this is such a simple airplane, I pull out the paper form in my checklist and do a quick calc by hand if I am out of one of my standard load calculations. I had a CG calculator on my computer and it worked flawlessly, but found it took longer to start it up, input the garbage, and check the result than it took to do it by hand. Especially with my standardized computations sheets. I purchased expensive scales for my shop wt and balance work and calibrated them of course. Once I do the wt and balance, and compute the ranges, I must admit I have become somewhat cavalier in my wt and balance checks. Yes, I am acquiring bad habits. The reason is, or should I say excuse: When we finish a plane here we do a number of calculations. Initial test flight; then max pilot and pax wt with zero fuel and baggage for max forward CG; then max aft which is usually a 120 pound pilot, max fuel and max baggage; typical pilot and copilot with full fuel and 2.5 gallon landing and a couple of flight bags for local flying; cross country pilot and passenger, full takeoff and landing fuel, full baggage or what the CG or GW will allow. Then I print them up on a sheet for inclusion in the handbook. Should the owner exceed any of these set CG comps (like taking off well over max design gross takeoff weight), I go fly with them and do stalls noting the increases and difference in break, slow flight, maneuvering and approaches and landings with them until they are comfortable, understand the load limit restrictions (as they are well into the safety factors the G limits are changed). I especially do this if the empty plane is really heavy. Many times I add stall strips to give better buffet warning prior to the stall. I have found that I prefer the CG of a fully serviced with oil and coolant airplane empty CG to be 60 inches. That way a 180 pound pilot, full or half fuel load for the test flight and only a flight bag allows me to easily control the plane even if the trim should fail or run away. On cross country cruising, this allows full fuel for takeoff, full luggage at 80 pounds and another 180 pound pilot without worry. Regards, Bud ----- Original Message ----- From: Alan Carter<mailto:alancarteresq(at)onetel.net> To: europa-list(at)matronics.com Sent: Thursday, July 04, 2013 6:10 PM Subject: Europa-List: Re: wing lift/drag pins > Hi Bud again, Its been 14 years since I was flying, and the old memory is not as good. All I can remember is bendy wings, and use to have a weight and balance sheet and it had this Zero Fuel Weight , think it was about 122000 lbs, I have this C of G calculator and when I do a weight and balance with the Europa figures I get an Out of Zero Fuel Wight some times, can,t see how this applies to a Europa, no wing tanks, Am I missing something, Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403962#403962 .matronics.com/viewtopic.php?p=403962#403962> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Jul 04, 2013
Graham, Well said. If a plane comes in here we do the same thing. It saves a lot of head scratching. We measure root, (granted outside of the filler and fillets), mid wing between the flap and aileron, and tip. Then compare the two wing sides. If you adjust the flap and aileron to even them up (the aileron has to be contoured to stay where you want it) it makes trimming a lot less trial and error plus you don't need those ugly bendy tabs. Bud ----- Original Message ----- From: GRAHAM SINGLETON<mailto:grahamsingleton(at)btinternet.com> To: europa-list(at)matronics.com Sent: Thursday, July 04, 2013 3:29 PM Subject: Re: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downunder The AoA that must be accurate is at roughly the outboard end of the spar. AoA at the wing root is pretty irrelevant. Think about it, there's almost no rolling moment there. I made a jig to measure AoA using the leading edge and the trailing edge, a Vee on it's side for the LE and a straight edge to sit on the trailing edge. Straight edge to join the two. This is your datum line, not essential that it is parallel to the wing chord line but you will need to use a digital level. Next get the first wing set up as per the manual. Now set up the second wing to match the first. It wouldn't do any harm to check the wings at the tips too, this will tell you if the wings have different washout angle but maybe you didn't want to know that! Graham ------------------------------------------------------------------------- ----- From: AirEupora <AirEupora(at)sbcglobal.net> To: europa-list(at)matronics.com Sent: Thursday, 4 July 2013, 16:39 Subject: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downunder > Tony, I can tell you from experience that both wings have to be the same. I set my up with the fuselage bottom only. I now have both top and bottom on and have 30 hours of flight time. I have a left wing low. I went back and measured both wings and the right is 2.4 degrees and the left is 1.7 degrees. Not sure why! I took pictures of the level showing 2.5 degrees on both wings! I have lower the left wing flap about a degree or two, but at low speed the aircraft left wing drops in a second. I'm planning on resetting the front socket. I'm worried about the holes that I drilled in the metal plate that is in the fuselage and will cut out the fuselage skin and add a plate to the ole one then set the wing up correctly. Do it right the first, second, third time. If it's right you will have no troubles when you fly it. Use a laser measure from the tail plane tubes to the wind aileron end plate to set the sweep. Rick Stockton N120EJ Jabiru 3330L Whirlwind Ground Adjustable Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=cs.com/Navigator?Europa-Lis t" target="_blank">http://www.matronics.com/Na= - MATRONICS WEB FORUMS href="http://forums.matronics.com/" target="_blank">http://forums.matr &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co=========== ====== <http://forums.matronics.com/viewtopic.php?p=403926#403926>http://www.m atronics.com/Navigator?Europa-List<http://www.matronics.com/Navigator?Eur opa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: G-KITS.
Date: Jul 05, 2013
Hi Richard, Yes saw G-KITS yesterday at Wellesborne,sadly,it's kept outside, and was showing signs of U.V.light degradation,namely the call-sign lettering was badly faded and cracked. More worringly,another Europa there was in the same situation,but that aircraft was showing signs of Osmosis, water blisters under the paint. Water ingress has serious consequences for composite aircraft, It can add serious amounts of weight,affecting C of G and therefore causing flight issues,also the water freezes in winter,or at high altitude Causing structural problems which may Result in the aircraft unable to withstand flight loads. Europas should either be kept in an enclosed trailer or in a hangar that is weather proof when they are not being Flown,and only kept outside for short Periods.....owners beware,your lives may depend on it. Best Regards Andy Cullum G-CGDH. Sent from my iPhone ________________________________________________________________________________
Date: Jul 05, 2013
Thanks Bud,=0AI use Gurney flaps for trim, a few inches of draft excluder s tuck under the trailing edge of one aileron. I always tried to get the flap s reflexed up a bit to match the digital print out of the airfoil. Most fol ks assume it should be flat under the TE but it isn't. Another omission in the manual! Poor old Andy, he was under so much pressure when he wrote it, all sorts of things needing attention, especially the hassles they had with the fuel tank. No one told them the tank would expand when filled with Mog as! Took a year to fix that! =0AGraham=0A=0A=0A=0A=0A______________________ __________=0A From: Bud Yerly <budyerly(at)msn.com>=0ATo: europa-list@matronic s.com =0ASent: Friday, 5 July 2013, 3:02=0ASubject: Re: Europa-List: Re: An gle of Incidence on a Classic Taildragger Downunder=0A =0A=0A=0A =0AGraham, =0AWell said.- If a plane comes in here we do the same thing.- It =0Asa ves a lot of head scratching.- We measure root, (granted outside of the =0Afiller and fillets), mid wing between the flap and aileron, and tip.- Then =0Acompare the two wing sides.- If you adjust the flap and aileron t o even =0Athem up (the aileron has to be contoured to stay where you want i t) it makes =0Atrimming a lot less trial and error plus you don't need thos e ugly bendy =0Atabs.=0ABud-=0A----- Original Message ----- =0A>From: GRA HAM SINGLETON =0A>To: europa-list(at)matronics.com =0A>Sent: Thursday, July 04 , 2013 3:29 PM=0A>Subject: Re: Europa-List: Re: Angle of Incidence on a C lassic Taildragger Downunder=0A>=0A>=0A>The AoA that must be accurate is a t roughly the outboard end of the spar.=0A>AoA =0A at the wing root is pre tty irrelevant. Think about it, there's almost no =0A rolling moment there . =0A>I made a jig to measure AoA using the leading edge =0A and the trail ing edge, a Vee on it's side for the LE and a straight edge to =0A sit on the trailing edge. Straight edge to join the two. This is your datum =0A l ine, not essential that it is parallel to the wing chord line but you will =0A need to use a digital level.=0A>Next get the first wing set up as per the =0A manual.=0A>Now set up the second wing to match the first. =0A>It w ouldn't do =0A any harm to check the wings at the tips too, this will=0A>t ell you if the =0A wings have different washout angle but maybe you didn't want to know =0A that!=0A>Graham=0A>=0A>=0A>=0A>=0A>=0A>=0A>_____________ ___________________=0A> From: AirEupora <AirEupora(at)sbcglobal.net>=0A>To: eu ropa-list(at)matronics.com =0A>Sent: Thursday, 4 July 2013, 16:39=0A>Subject: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downunder=0A global.net>=0A>=0A>Tony, =0A I can tell you from experience that both wing s have to be the same.- I =0A set my up with the fuselage bottom only. - I now have both top and bottom =0A on and have 30 hours of flight time .- I have a left wing low.- I =0A went back and measured both wings an d the right is 2.4 degrees and the left is =0A 1.7 degrees.- =0A>=0A>Not sure why!- I took pictures of the level =0A showing 2.5 degrees on both wings!=0A>=0A>I have lower the left wing flap =0A about a degree or two, but at low speed the aircraft left wing drops in a =0A second.- I'm plan ning on resetting the front socket.- =0A>=0A>I'm =0A worried about the h oles that I drilled in the metal plate that is in the =0A fuselage and wil l cut out the fuselage skin and add a plate to the ole one =0A then set th e wing up correctly.=0A>=0A>Do it right the first, second, third =0A time. - If it's right you will have no troubles when you fly it.- Use =0A a laser measure from the tail plane tubes to the wind aileron end plate to se t =0A the sweep.=0A>=0A>Rick Stockton=0A>N120EJ=0A>Jabiru 3330L=0A>Whirlwi nd Ground =0A Adjustable=0A>=0A>=0A>=0A>=0A>Read this topic online here: =0A>=0A>
http://forums.matronics.com/viewtopic.php?p=cs.com/Navigator?Euro pa-List" target="_blank">http://www.matronics.com/Na=- - - - - - - - MATRONICS WEB FORUMS href="http://forums.matronics.com/" t arget="_blank">http://forums.matr - - - - - - - - - - &nbs//www.matronics.com/contribution" target="_blank">http://www.ma tronics.co===================0A>=0A>=0A >=0A>=0A>=0A>=0A>href="http://www.matronics.com/Navigator?Europa-List">ht tp://www.matronhref="http://forums.matronics.com">http://forums.matronics .comhref="http://www.matronics.com/contribution">http://www.matronics.com =============== ________________________________________________________________________________
Subject: Re: G-KITS.
Date: Jul 05, 2013
Thank you Andy. My Europa lives in a nice hangar on a country airfield in Kenya for 10 months each year. The other 2 months, it sits at the main lightplane airfield of Kenya, outside in the sun and rain (because there is no space in any hangar there), waiting for a Civil Aviation inspector to inspect it for its annual "Kenya Restricted Certificate of Airworthiness". Eventually an inspector will come, usually facilitated to do so by a fat brown envelope. This happens year after year. I have a Cambrai cover for the fuselage, but nothing for wings and tailplane, so last year, at inspection time, I had a local cover-maker make covers for wings and tail. The sun came out, it rained, more sun, and more rain. The covers were soaked, then warmed, soaked again etc. Finally the inspector came and went, advising me that to get the Certificate renewed, I would have to paint the words 'no push' in red paint on the ailerons. Two months later, I noticed some of the osmosis bubbles had formed on the stabilator surface, not many, but entirely due to wet covers and osmosis. So moral of the story, try to keep it out of sun and rain for long period, but if you cant avoid this, don't put covers on the wings and tail. Best Richard Kenya Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403992#403992 ________________________________________________________________________________
Subject: Outside aircraft
Date: Jul 05, 2013
Hi Richard, Thanks for your message,personally I would never leave DH outside for any Appreciable time,with or without covers. I've done quite a bit of gliding in my time,so I'm well familiar with composites and their draw-backs. Did you sand back,dry out and re-paint Your tailplanes? The aircraft I saw here in the U.K.at first Looked ok,but on closer inspection,it was obvious it was in a sorry state,with Quite a few blisters mid-way on the D-box on the wing,..just where you don't want to see them. So,it looks like it would require major strip dry out at 35-40 c dehumidifiers, Silica gel etc,and even then there could Be underlying freezing damage to the structure,which would require investigation before any re-painting was carried out. If you do leave your aircraft out,a polish with good old beeswax is a good tip to help keep the water out. Best Regards Andy Cullum. Sent from my iPhone ________________________________________________________________________________
Date: Jul 05, 2013
Hi Guys, I would like to make a few comments / observations, not in any particular o rder, on some of the postings on here recently. G-KITS, originally had a set of Classic wings, built by a third party, wher e the port wing had 1.5 degrees of washIN, not evenly distributed along the wing, but mostly in the outboard panel. Wings rigged using the root area a s datum. It flew, as you would expect, one wing low. Attempts to trim this out with aileron re rigging and flap drooping were un successful, so the port wing was re rigged, can't remember by how much in d egrees, but the figure of .3'' down at the leading edge comes to mind. Went much better after that, with some stall strip juggling it stalled true , BUT spins in one direction were frightening [ as in change of underpants frightening !]. G-KITS was then retro fitted with a new set of XS wings,[ the original G-KI TS wings went on the then retired G-YURO which was lost from active service in a take off incident when the Arplast prop decided, uncommanded, to go i nto Beta.........] Sockets had been unbolted / sweated off, alloy plates replaced and wing ref itted as per Manual. Seatback spar bush re aligned with a hot, tapered pin ''pugler''. Warm the pin, shove it through the seatback / wing spars and g o for a coffee. UV degradation.... the paint would have been AERODUR C100UVR, about as good as paints get, the registration decals would have been Fascal vinyl, with a 7 year life... how old is KITS now ?..... Quality polyurathane paints li ve quite well in Miami and Bahama marina's, unlike some of the ''unquality' ' water thinned cr*p Wing incidence cock up.......do it correctly, NOW ! Sweat the sockets off and redo it. Make sure the wings are fully forward, by tieing the spar tang s forward with rope, or chocking with wedges. If using a digital level, MAKE SURE YOU READ IT FROM THE SAME DIRECTION [ LOOKING INBOARD AT IT ON THE PORT WING, AND OUTBOARD AT IT ON THE STARBOARD WING] I have seen builders doing ''dry runs'' and looking inboard at the r eadout on both wings, any error in the tool itself, or in fuselage levellin g will be doubled. Tap the level to see which way the reading ''skips'', ge t the ''skip'' the same on both wings. This will be as close a matters in t he real world. Shore the wings in several places so no movement is possible during the ove rnight Redux cure. Osmosis.... people are confusing Osmosis with Micro Blistering. What will b e evident on a painted Epoxy surface is Micro Blistering, where water has g ot between the paint and the substrate, usually as a result of covering a w et [ water] surface and letting it sweat like a sauna, the moisture has gon e through the paint skin and is trapped. Leaving this out in the sun will usually dry it out. Left uncovered is a better option than covers. Micro Bl isters are not a structural issue, merely water sitting on top of the epoxy substrate. Cover a car with a non breathing cover, left wet, the same Micro Blisterin g will occur over a steel substrate. Osmosis [ in the GRP meaning of the word ] is the reaction with chemicals in / on the glass fibres [ usually the PVA binder holding the CSM together] and water, usually within polyester resin, which turns to acid [ and will smell of vinegar if the bubble is popped.] My Inspector said ''that's the one with all the Mods''....... working from memory, there were 32 Mods incorporated into the XS Kit by 1996, since the n there have been 8 MANDATORY MODS, the rest have been upgrades. Put this i nto perspective, the Slingsby Firefly has 1200 + mods, wonder how many mods apply to a C150 ? The tie bar was introduced to allow the Gross weight to be raised to 1370 l bs, if anyone is happy to have the 1300 lb limit, the tie bar is not requir ed [ nor is it required to change to the swivelling rear sockets.] Bit of History, the original G-YURO front wing pins were .75'' long, and th ere was no top hat stiffener from thigh support to door sill. Pete Clark [b less him] was ''vigorously exploring the flight envelope'', and pulled a ' 'bit'' of G, and the front pin popped out of the socket and rode above sai d socket. Apart from the ''bang'' which scared the s**t out of Pete and Rog er Bull [ who was riding shotgun], nothing else happened, though it took so me effort to de rig the wing later. A longer front pin [ same length as the flap pin,] and the top hat stiffene r cured that. Regarding Inspections, if the Inspector chosen for Permit Renewals only ''k nowledge'' of the Europa is ''that's the one with all the Mods'', he probab ly [ or more likely definitely] isn't the Inspector you need to do the Perm it, especially if you are not the builder of the aircraft. I once worked on a Europa that the current owner had just bought, with 5 ho urs flight time since the previous Permit, that had been Inspected by an '' old timer'' Inspector, and there were so many flight safety faults with it, I had to ''dob in'' the Inspector to LaaLaaLand. Turns out he was an exper t in Austers and the like, but knew SFA about the Europa. LAA didn't take a ny action as he had since retired from Inspecting. Comparing a C150 with the Europa is pure folly, like comparing a Morris 100 0 with a Ford Focus ST ? I have 1.4 hrs in a C150, time I am never going to get back..... wasted... -----Original Message----- From: Richard Lamprey <lamprey.richard(at)gmail.com> Sent: Thu, Jul 4, 2013 6:10 pm Subject: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downu nder .com> Getting it right first time is good. But also I dimly remember (from the d ays of the Europa Newsletter, around 1997) the tale of G-KITS, the first factor y demonstrator for the Classic tri-gear, where one wing was accidentally buil t with 1 degree WASHIN, not 1.5 degree washout. You would think it would hav e stall/ wingdrop characteristics from hell, but apparently it flew just fine , and is still flying - I see its picture online. So perhaps there is some leewa y in the AoI. Richard Classic Reg 5Y-LRY, Kenya Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403933#403933 ________________________________________________________________________________
Date: Jul 05, 2013
NEv=0Awasn't it an Ivoprop that went into Beta?=0AGraham=0A=0A=0A=0A=0A=0A_ _______________________________=0A From: Neville Eyre <neveyre(at)aol.com>=0AT o: europa-list(at)matronics.com =0ASent: Friday, 5 July 2013, 22:37=0ASubject: Re: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downunder =0A =0A=0A=0AHi Guys,=0AI would like to make a few comments / observations, not in any particular order, on some of the postings on here recently.=0AG -KITS, originally had a set of Classic wings, built by a third party, where the port wing had 1.5 degrees of washIN, not-evenly distributed along th e wing, but mostly in the outboard panel. Wings rigged using the root area as datum. It flew, as you would expect, one wing low.=0AAttempts to trim th is out with aileron re rigging and flap drooping were unsuccessful,-so th e port wing was re rigged, can't remember by how much in degrees, but the f igure of .3'' down at the leading edge comes to mind.=0AWent much better af ter that, with some stall strip juggling it stalled true, BUT spins in one direction were frightening-[ as in change of underpants frightening !]. =0AG-KITS was then retro fitted with a new set of XS wings,[ the original G -KITS-wings went on the then retired G-YURO which was lost from active se rvice in a take off incident-when the Arplast prop decided, uncommanded, to go into Beta.........]=0ASockets had been unbolted / sweated off, alloy plates replaced and wing refitted as per Manual. Seatback spar bush re alig ned with a hot, tapered-pin- ''pugler''. Warm the pin, shove it through the seatback / wing spars and go for a coffee.=0AUV degradation.... the pa int would have been AERODUR C100UVR, about as good as paints get, the regis tration decals would have been Fascal vinyl, with a 7 year life... how old is KITS now ?..... Quality- polyurathane paints live quite well in Miami and Bahama marina's, unlike some of the ''unquality'' water thinned cr*p=0A -=0AWing--incidence cock up.......do it correctly, NOW ! Sweat the so ckets off and redo it. Make sure the wings are fully forward, by tieing the spar tangs forward with rope, or chocking with wedges.=0A-If using a-d igital level, MAKE SURE YOU READ IT FROM THE SAME DIRECTION [ LOOKING INBOA RD AT IT ON THE PORT WING, AND OUTBOARD AT IT ON THE STARBOARD WING] I have seen builders doing ''dry runs'' and looking inboard at the readout on bot h wings, any error in the tool itself, or in fuselage levelling will be dou bled. Tap the level to see which way the reading ''skips'', get the ''skip' ' the same on both wings. This will be as close a matters in the real world .-=0AShore the wings in several places so no movement is possible during the overnight Redux cure.=0A-=0AOsmosis.... people are confusing Osmosis with Micro Blistering. What will be evident on a painted Epoxy surface is M icro Blistering, where water has got between the paint and the substrate, u sually as a result of covering a wet [ water] surface and letting it sweat like a sauna, the moisture has gone through the paint skin and is trapped. Leaving this out in- the sun will usually dry it out. Left uncovered is a better option than covers. Micro Blisters are not a structural issue, mere ly water sitting on top of the epoxy substrate.=0A-Cover a car with a non breathing cover, left wet, the same Micro Blistering will occur over a ste el substrate. =0AOsmosis [- in the GRP meaning of the word ]-is the rea ction with chemicals in / on the glass fibres [ usually the PVA binder hold ing the CSM together] and water, usually within- polyester-resin,-whi ch turns to acid [ and will smell of vinegar if the bubble is-popped.]=0A -=0AMy Inspector said ''that's the one with all the Mods''.......- work ing from memory, there were 32 Mods incorporated into the XS Kit by 1996, s ince then there have been 8 MANDATORY MODS, the rest have been upgrades. Pu t this into perspective, the Slingsby Firefly has 1200 + mods, wonder how m any mods apply to a C150 ?=0AThe tie bar was introduced to allow the Gross weight to be raised to 1370 lbs, if anyone is happy to have the 1300 lb lim it, the tie bar is not required [ nor is it required to change to the swive lling rear sockets.]=0ABit of History, the original G-YURO front wing pins were .75'' long, and there was no top hat stiffener from thigh support to d oor sill. Pete Clark [bless him] was ''vigorously exploring the flight enve lope'', and- pulled a ''bit'' of- G, and the front pin popped out of th e socket and rode above said socket. Apart from the ''bang'' which scared t he s**t out of Pete and Roger Bull [ who was riding shotgun], nothing else happened, though it took some effort to de rig-the wing later.=0AA longer front pin [ same length as the flap pin,] and the top hat stiffener cured -that.-=0ARegarding Inspections, if the Inspector chosen for Permit Ren ewals only ''knowledge'' of the Europa is ''that's the one with all the Mod s'', he probably [ or more likely definitely] isn't the Inspector you need to do the Permit, especially if you are not the builder of the aircraft.=0A I once worked on a Europa that the current owner had just bought, with 5 ho urs flight time since the previous Permit, that had been Inspected by an '' old timer'' Inspector, and there were so many flight safety faults with it, I had to ''dob in'' the Inspector to LaaLaaLand. Turns out he was an exper t in-Austers and the like, but knew SFA about the-Europa. LAA didn't ta ke any action as he had since retired from Inspecting.=0AComparing a C150 w ith the Europa is pure folly, like comparing a Morris 1000 with- a Ford F ocus ST ?=0AI have 1.4 hrs in a C150, time I am never going to get back.... . wasted...=0A--=0A-=0A-----Original Message-----=0AFrom: Richard Lam prey =0ATo: europa-list =0ASent: Thu, Jul 4, 2013 6:10 pm=0ASubject: Europa-List: Re: Angle of I ncidence on a Classic Taildragger Downunder=0A=0A=0A--> Europa-List message posted by: "Richard Lamprey" Getting it right first time is good. But also I dimly remember (from the days =0Aof the Eur opa Newsletter, around 1997) the tale of G-KITS, the first factory =0Ademon strator for the Classic tri-gear, where one wing was accidentally built =0A with 1 degree WASHIN, not 1.5 degree washout. You would think it would hav e =0Astall/ wingdrop characteristics from hell, but apparently it flew just fine, and =0Ais still flying - I see its picture online. So perhaps there is some leeway in =0Athe AoI. Richard=0AClassic Reg 5Y-LRY, Kenya Read thi s topic online here: http://forums.matronics.com/viewtopic.php?p=403933#4 03933 arget="_blank">http://www.matronics.com/Navigator?Europa-List=0Atp: //forums.matronics.com=0A_blank">http://www.matronics.com/contribution =0A ============= ________________________________________________________________________________
Subject: Re: Outside aircraft
Date: Jul 05, 2013
Sounds to me like this ship would deserve full sand bagging for checking POS and NEG G-loading before flight test... On Jul 5, 2013, at 11:33 AM, andrew cullum wrote: > The aircraft I saw here in the U.K.at first > Looked ok,but on closer inspection,it was obvious it was in a sorry state,with > Quite a few blisters mid-way on the D-box on the wing,..just where you don't want to see them. > So,it looks like it would require major strip dry out at 35-40 c dehumidifiers, > Silica gel etc,and even then there could > Be underlying freezing damage to the structure,which would require investigation before any re-painting was > carried out. ________________________________________________________________________________
Date: Jul 05, 2013
i have read the discussion on the issue of defogging and it appears that are no actual answers out there yet regarding airflow, temperature, etc. I will add my meager data to the pool My bird has a Blue Mountain EFIS 4 series which shuts down at temps above abt 144F. I have a 24 cfm fan in a convective tower directly above the EFIS leading into a 3 in louver directed into the plexi. On a 90F sunny day as so many local days are here on Long Island, without the fan, the EFIS will blackout within an hour of the plane out of the hangar, flying or not. The installed fan slows the inexorable rise somewhat say by 15 min to overheat. Clearly unacceptable cooling. However, it has actually cleared plexi condensation in two instances where it existed, in about 5 minutes (this was light grey mist, not dripping condensation). As I contemplate my move to much warmer clime, i will need to re-engineer the cooling. These little muffin fans are not likely to be useful even if ganged together. High velocity outside air is probably the best answer. Actual flight testing is needed. As usual, your mileage will vary Ira -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404012#404012 ________________________________________________________________________________
Subject: Re: Angle of Incidence on a Classic Taildragger Downunder
Date: Jul 05, 2013
No, it was definitely the Arplast, the Ivoprop gears stripped when being cy cled on the bench ! We never flew it. As I said before, if an Ivoprop was u sed as a ceiling fan, I wouldn't walk under it without a crash helmet on ! The Arplast had done the same trick on the ground previously, Roger Sherida n P1, with me shotgun, sitting in front of the hangar at Wombleton, Went Be ta and we backed up ! Alan whatshisname came back to sort it, with bits he had left over from wha t looked like his R/C helicopter bin, never trusted it , pretty poor engine ering. Nev -----Original Message----- From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> Sent: Fri, Jul 5, 2013 11:06 pm Subject: Re: Europa-List: Re: Angle of Incidence on a Classic Taildragger D ownunder NEv wasn't it an Ivoprop that went into Beta? Graham From: Neville Eyre <neveyre(at)aol.com> To: europa-list(at)matronics.com Sent: Friday, 5 July 2013, 22:37 Subject: Re: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downunder Hi Guys, I would like to make a few comments / observations, not in any particular o rder, on some of the postings on here recently. G-KITS, originally had a set of Classic wings, built by a third party, wher e the port wing had 1.5 degrees of washIN, not evenly distributed along the wing, but mostly in the outboard panel. Wings rigged using the root area a s datum. It flew, as you would expect, one wing low. Attempts to trim this out with aileron re rigging and flap drooping were un successful, so the port wing was re rigged, can't remember by how much in d egrees, but the figure of .3'' down at the leading edge comes to mind. Went much better after that, with some stall strip juggling it stalled true , BUT spins in one direction were frightening [ as in change of underpants frightening !]. G-KITS was then retro fitted with a new set of XS wings,[ the original G-KI TS wings went on the then retired G-YURO which was lost from active service in a take off incident when the Arplast prop decided, uncommanded, to go i nto Beta.........] Sockets had been unbolted / sweated off, alloy plates replaced and wing ref itted as per Manual. Seatback spar bush re aligned with a hot, tapered pin ''pugler''. Warm the pin, shove it through the seatback / wing spars and g o for a coffee. UV degradation.... the paint would have been AERODUR C100UVR, about as good as paints get, the registration decals would have been Fascal vinyl, with a 7 year life... how old is KITS now ?..... Quality polyurathane paints li ve quite well in Miami and Bahama marina's, unlike some of the ''unquality' ' water thinned cr*p Wing incidence cock up.......do it correctly, NOW ! Sweat the sockets off and redo it. Make sure the wings are fully forward, by tieing the spar tang s forward with rope, or chocking with wedges. If using a digital level, MAKE SURE YOU READ IT FROM THE SAME DIRECTION [ LOOKING INBOARD AT IT ON THE PORT WING, AND OUTBOARD AT IT ON THE STARBOARD WING] I have seen builders doing ''dry runs'' and looking inboard at the r eadout on both wings, any error in the tool itself, or in fuselage levellin g will be doubled. Tap the level to see which way the reading ''skips'', ge t the ''skip'' the same on both wings. This will be as close a matters in t he real world. Shore the wings in several places so no movement is possible during the ove rnight Redux cure. Osmosis.... people are confusing Osmosis with Micro Blistering. What will b e evident on a painted Epoxy surface is Micro Blistering, where water has g ot between the paint and the substrate, usually as a result of covering a w et [ water] surface and letting it sweat like a sauna, the moisture has gon e through the paint skin and is trapped. Leaving this out in the sun will usually dry it out. Left uncovered is a better option than covers. Micro Bl isters are not a structural issue, merely water sitting on top of the epoxy substrate. Cover a car with a non breathing cover, left wet, the same Micro Blisterin g will occur over a steel substrate. Osmosis [ in the GRP meaning of the word ] is the reaction with chemicals in / on the glass fibres [ usually the PVA binder holding the CSM together] and water, usually within polyester resin, which turns to acid [ and will smell of vinegar if the bubble is popped.] My Inspector said ''that's the one with all the Mods''....... working from memory, there were 32 Mods incorporated into the XS Kit by 1996, since the n there have been 8 MANDATORY MODS, the rest have been upgrades. Put this i nto perspective, the Slingsby Firefly has 1200 + mods, wonder how many mods apply to a C150 ? The tie bar was introduced to allow the Gross weight to be raised to 1370 l bs, if anyone is happy to have the 1300 lb limit, the tie bar is not requir ed [ nor is it required to change to the swivelling rear sockets.] Bit of History, the original G-YURO front wing pins were .75'' long, and th ere was no top hat stiffener from thigh support to door sill. Pete Clark [b less him] was ''vigorously exploring the flight envelope'', and pulled a ' 'bit'' of G, and the front pin popped out of the socket and rode above sai d socket. Apart from the ''bang'' which scared the s**t out of Pete and Rog er Bull [ who was riding shotgun], nothing else happened, though it took so me effort to de rig the wing later. A longer front pin [ same length as the flap pin,] and the top hat stiffene r cured that. Regarding Inspections, if the Inspector chosen for Permit Renewals only ''k nowledge'' of the Europa is ''that's the one with all the Mods'', he probab ly [ or more likely definitely] isn't the Inspector you need to do the Perm it, especially if you are not the builder of the aircraft. I once worked on a Europa that the current owner had just bought, with 5 ho urs flight time since the previous Permit, that had been Inspected by an '' old timer'' Inspector, and there were so many flight safety faults with it, I had to ''dob in'' the Inspector to LaaLaaLand. Turns out he was an exper t in Austers and the like, but knew SFA about the Europa. LAA didn't take a ny action as he had since retired from Inspecting. Comparing a C150 with the Europa is pure folly, like comparing a Morris 100 0 with a Ford Focus ST ? I have 1.4 hrs in a C150, time I am never going to get back..... wasted... -----Original Message----- From: Richard Lamprey <lamprey.richard(at)gmail.com> Sent: Thu, Jul 4, 2013 6:10 pm Subject: Europa-List: Re: Angle of Incidence on a Classic Taildragger Downu nder .com> Getting it right first time is good. But also I dimly remember (from the d ays of the Europa Newsletter, around 1997) the tale of G-KITS, the first factor y demonstrator for the Classic tri-gear, where one wing was accidentally buil t with 1 degree WASHIN, not 1.5 degree washout. You would think it would hav e stall/ wingdrop characteristics from hell, but apparently it flew just fine , and is still flying - I see its picture online. So perhaps there is some leewa y in the AoI. Richard Classic Reg 5Y-LRY, Kenya Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403933#403933 arget="_blank">http://www.matronics.com/Navigator?Europa-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator_blank"; href="http://forums.matronics. com/">http://forums.matronics.com ________________________________________________________________________________
Date: Jul 06, 2013
Yes,good point Fred. Just to illustrate my point,a few years ago there was a Rallye Minerva parked at a local airfield. It had a composite Hoffman variable pitch propellor,almost brand new. Sadly, the owner hadnt paid the bill for Maintenance,so the company put it outside,without removing the propellor. It remained outside for about 18 months,which meant particularly cold temps in winter,snow etc. I examined the prop and lo and behold, Every blade had a nasty crack at the base close to the vari pitch hub,about 2" long....water ingress and freezing damage obviously. I rest my case. Andy Cullum. Sent from my iPhone On 6 Jul 2013, at 00:28, "Fred Klein" wrote: > > Sounds to me like this ship would deserve full sand bagging for checking POS and NEG G-loading before flight test... > > On Jul 5, 2013, at 11:33 AM, andrew cullum wrote: > >> The aircraft I saw here in the U.K.at first >> Looked ok,but on closer inspection,it was obvious it was in a sorry state,with >> Quite a few blisters mid-way on the D-box on the wing,..just where you don't want to see them. >> So,it looks like it would require major strip dry out at 35-40 c dehumidifiers, >> Silica gel etc,and even then there could >> Be underlying freezing damage to the structure,which would require investigation before any re-painting was >> carried out. > > > > > > ________________________________________________________________________________
Subject: Re: windscreen de-fogging
Date: Jul 06, 2013
You might want to try a couple of the 12v brushless DC fans, they range in size from 30mm up to about 200mm They move a lot of air for their size, like the ones you find in your computer to ventilate the case I had two network file servers running inside a closed cupboard total load of about 1000w with a hole in the bottom Back of the cupboard and one 100mm brushless DC fan to extract the air at the top and didn't have an issue with them overheating Worth a look at least, they normally run about $10 each, or free if you can get your hands on a couple of old computers and pull them apart To get the fans out of the power supply's http://www.ebay.com.au/itm/2x-Brushless-DC-Cooling-Fan-12V-120mm-x-120mm-x-2 5m-/180729347608?pt=AU_Components&hash=item2a144efe18 this link just goes to one I found on ebay no doubt you could find your own regards craig ________________________________________________________________________________
Date: Jul 06, 2013
Ira, I have a comparable system to keep my Blue Mountain EFIS happy, although my fan has inlet above pax feet and outlet through a dozen holes blowing on to pilot screen. Moderately effective as demister, but EFIS starts to complain when temps get up into vicinity of 35C (95 in your old units). I have found that laying a layer of 5mm neoprene with foil on one side, across top of panel (which is painted dark blue for visibility) cuts out direct sun heating and addresses the problem. So I have that Neoprene sheet available in the back and use it intermittently in exceptionally hot conditions Regards, David Joyce, G-XSDJ "rampil" wrote: > > > i have read the discussion on the issue of defogging and >it appears that > are no actual answers out there yet regarding airflow, >temperature, etc. > > I will add my meager data to the pool > > My bird has a Blue Mountain EFIS 4 series which shuts >down at temps > above abt 144F. I have a 24 cfm fan in a convective >tower directly > above the EFIS leading into a 3 in louver directed into >the plexi. > On a 90F sunny day as so many local days are here on >Long Island, > without the fan, the EFIS will blackout within an hour >of the plane out > of the hangar, flying or not. The installed fan slows >the inexorable rise somewhat > say by 15 min to overheat. Clearly unacceptable cooling. >However, > it has actually cleared plexi condensation in two >instances where it existed, > in about 5 minutes (this was light grey mist, not >dripping condensation). > > As I contemplate my move to much warmer clime, i will >need to > re-engineer the cooling. These little muffin fans are >not likely to be useful > even if ganged together. High velocity outside air is >probably the best answer. Actual flight testing is >needed. > > As usual, your mileage will vary > > Ira > > -------- > Ira N224XS > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404012#404012 > > > > > > > >Un/Subscription, >Forums! >Admin. > > > ________________________________________________________________________________
From: "Duncan & Ami" <ami-mcfadyean(at)talktalk.net>
Subject: windscreen de-fogging
Date: Jul 06, 2013
I took an air feed off the top of one of the side NACA ventilators, primarily to squirt cool air over the back of the Terra transponder (which (and the radios too) don't appreciate being cooked behind the standard sealed Europa panel). There are slots cut in the top of the panel below the bottom of the windscreen. It's not foolproof for demisting on the ground (but a wiping cloth is!), but it does keep mist cleared in flight. I had one computer fan previously, which worked similarly, but I took it out (heavy, noisy, power consumer). DMcF. -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fred Klein Sent: 04 July 2013 18:12 Subject: Europa-List: windscreen de-fogging Gentlemen, I'm attempting to select a couple of computer fans to be mounted louvers in the top of the instrument panel module for the purpose of de-fogging the windscreen...I'm uncertain as to what cfm ratings or sizes will do the job. If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient...I'd be grateful I suspect that my local climate in the Pacific NW of the US is similar to conditions in UK. Thanks in advance, Fred A-194 ________________________________________________________________________________
Date: Jul 06, 2013
David, Thank you very much! Insulating reflective foam. An Excellent suggestion :) Now, if I can just figure out how to keep myself from cooking in the cabin .... Ira -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404042#404042 ________________________________________________________________________________
Date: Jul 06, 2013
I can't understand the motivation for these threads, this and the one re G KITS, unless I am being thick it sounds like someone has wandered up to someone elses plane seen letters faded etc and proceeded to have a public, in print for all time, slagging off of it and its state. Is this a good way to carry on? This doesnt sound like the europa forum to me. Even if there were facts rather than views it wouldnt be fair. -------- Graeme Bird G-UMPY Mono Classic/XS 912S/Woodcomp 3000/3W Newby: 75 hours 18 months g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404070#404070 ________________________________________________________________________________
Date: Jul 06, 2013
Subject: Fuel tank question
After a one year pause, I am getting back into building. I am near the stage of bonding the fuel tank into the CM. I read a lot of discussions about tank swellings and cracking, so I am a bit concerned. Doing a google search, I came across a fuel tank mod document written by Bud Yerly where he suggests using a cork pad in the fuselage to support the tank. The details are a bit unclear to me, so I would like solicit opinions from anyone who can give me some insights. Thanks in advance!! ________________________________________________________________________________
Subject: Angle of Incidence
Date: Jul 06, 2013
> Gidday, Spent 15:00 strapped to an aeroplane but thought I should at least say thank you for everyone's input regarding this AOI issue before having a big sleep. I have yet to read all the replies and digest everything but I am miles ahead with the input. Regards Tony Renshaw ________________________________________________________________________________
Subject: Re: Fuel tank question
Date: Jul 06, 2013
Hi Andrew, One question,have you filled your fuel tank with a mix of fuels you are going to use,and contained the tank with a sturdy wooden frame,and left it for at least 6 weeks? The poly-propylene apparently expands by about 10 per cent With the addition of fuel,this was in the old manual,but doesn't appear to be in the new one. Could it be that tanks that have cracked haven't had this pre-soaking? As for the cork at the bottom of the fuselage,sounds like a good idea,I'm sure that Bud can help you out. Best Regards Andy Cullum. Sent from my iPhone On 6 Jul 2013, at 20:47, "Andrew Sarangan" wrote: > > After a one year pause, I am getting back into building. I am near the > stage of bonding the fuel tank into the CM. I read a lot of > discussions about tank swellings and cracking, so I am a bit > concerned. > > Doing a google search, I came across a fuel tank mod document written > by Bud Yerly where he suggests using a cork pad in the fuselage to > support the tank. The details are a bit unclear to me, so I would like > solicit opinions from anyone who can give me some insights. > > Thanks in advance!! > > > > ________________________________________________________________________________
Date: Jul 07, 2013
The 120mm brushless dc fan I linked to yesterday was supposed to move 25 CFM and draw about .4 of an amp Noise level 25db doesn't say what the weight is, but past experience I would say it would be around 100g ________________________________________________________________________________
Date: Jul 07, 2013
Andrew, What I did. 1. make a cradle of 2, locally 3 bid: http://www.europaowners.org/main.php?g2_itemId=89148 The idea is: good support without local bonding / deformation stresses Put in the cradle / tank combination as the manual describes for the bare tank: http://www.europaowners.org/main.php?g2_itemId=89319 No glues / epoxies on the tank. The treated tank (forgot which gas exactly) swells less, but now bonds well to epoxies, making the unmodified original way of installing unwise. 2. put in lock-up EPP strips before putting the cradle / tank combination in: http://www.europaowners.org/main.php?g2_itemId=89154 http://www.europaowners.org/main.php?g2_itemId=89398 The idea is: minimize motion. 3. after bonding de cockpit into the canoe fill the space between cradle and canoe with 2-component reasonably heavy polyurethane foam through the fuel outlet access holes (calibrate the action beforehand to avoid the tunnel and the exposed outboard tank surfaces) This makes a port sandwich and a starboard sandwich - my version (Ron Parigoris' rather) of Bud's cork. The idea is: make the stresses still more distributed and the whole installation stronger. Jan de Jong I have been on the verge of putting the top on for a while. ________________________________________________________________________________
Date: Jul 06, 2013
Hi Andrew "The details are a bit unclear to me, so I would like solicit opinions from anyone who can give me some insights." Here's my attempt at keeping the fuel inside the tank: http://www.europaowners.org/main.php?g2_itemId=28688 Scuffed tunnel, 3 BID, plastic sheet and injected foam to support. Ron Parigoris ________________________________________________________________________________
Date: Jul 07, 2013
The tanks are low density polyethylene, I understand. And they shrink back over time when left empty (but not in my experience by as much as the initial expansion). Fluoridated tanks may be different. The Kitfox company understood this problem in 1990. DMcF -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of andrew cullum Sent: 06 July 2013 22:53 Subject: Re: Europa-List: Fuel tank question --> Hi Andrew, One question,have you filled your fuel tank with a mix of fuels you are going to use,and contained the tank with a sturdy wooden frame,and left it for at least 6 weeks? The poly-propylene apparently expands by about 10 per cent With the addition of fuel,this was in the old manual,but doesn't appear to be in the new one. Could it be that tanks that have cracked haven't had this pre-soaking? As for the cork at the bottom of the fuselage,sounds like a good idea,I'm sure that Bud can help you out. Best Regards Andy Cullum. Sent from my iPhone On 6 Jul 2013, at 20:47, "Andrew Sarangan" wrote: > --> > > After a one year pause, I am getting back into building. I am near the > stage of bonding the fuel tank into the CM. I read a lot of > discussions about tank swellings and cracking, so I am a bit > concerned. > > Doing a google search, I came across a fuel tank mod document written > by Bud Yerly where he suggests using a cork pad in the fuselage to > support the tank. The details are a bit unclear to me, so I would like > solicit opinions from anyone who can give me some insights. > > Thanks in advance!! > > > > ________________________________________________________________________________
Date: Jul 07, 2013
Agreed..................=0A-=0AWe will all be able to criticise another a ircraft if we want too, there but for the grace of God go I=0A-=0Afrom th e other one!=0A=0ASent to you from David Joyce=0Awww.eastmidsspas.com=0A=0A =0A=0A________________________________=0A From: graeme bird <graeme@gdbmk. co.uk>=0ATo: europa-list(at)matronics.com =0ASent: Saturday, 6 July 2013, 20:2 4=0ASubject: Europa-List: Re: Outside aircraft=0A =0A=0A--> Europa-List me ssage posted by: "graeme bird" =0A=0AI can't understand the motivation for these threads, this and the one re G KITS, unless I am being thick it sounds like someone has wandered up to someone elses plane s een letters faded etc and proceeded to have a public, in print for all time , slagging off of it and its state. Is this a good way to carry on? This do esnt sound like the europa forum to me. Even if there were facts rather tha n views it wouldnt be fair.=0A=0A--------=0AGraeme Bird=0AG-UMPY=0AMono Cla ssic/XS 912S/Woodcomp 3000/3W=0ANewby: 75 hours 18 months =0Ag(at)gdbmk.co. uk=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics. ========= ________________________________________________________________________________
Date: Jul 07, 2013
Thanks for all the ideas. The problem, as I understand now, is the attachment mechanism, and not necessarily the swelling. If the tank can be supported without bonding its surfaces, then it should be able to relieve the stresses as it expands and contracts. That's what I am gathering from these discussions. More puzzling is, it seems there is no agreement on what the tank is made of. Just in the last few emails, I've heard Polypropylene, HDPE, LDPE all mentioned, and Yerly's article says it is PTFE. I am somewhat familiar with different polymers, and these are all very different materials. I doubt it is PTFE because it is super expensive and nothing will stick to it. I know a chemical test to identify different polymers, but I would need a small chunk of the material. If I ever figure that out, I will make sure to post my results here. On Sun, Jul 7, 2013 at 3:43 AM, Duncan & Ami wrote: > > The tanks are low density polyethylene, I understand. And they shrink back > over time when left empty (but not in my experience by as much as the > initial expansion). Fluoridated tanks may be different. > The Kitfox company understood this problem in 1990. > > DMcF > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of andrew cullum > Sent: 06 July 2013 22:53 > To: europa-list(at)matronics.com > Subject: Re: Europa-List: Fuel tank question > > > --> > > Hi Andrew, > One question,have you filled your fuel tank with a mix of fuels you are > going to > use,and contained the tank with a sturdy wooden frame,and left it for at > least 6 weeks? The poly-propylene apparently expands by about 10 per cent > With the addition of fuel,this was in the old manual,but doesn't appear to > be in the new one. Could it be that tanks that have cracked haven't had this > pre-soaking? As for the cork at the bottom of the fuselage,sounds like a > good idea,I'm sure that Bud can help you out. Best Regards Andy Cullum. > > > Sent from my iPhone > > On 6 Jul 2013, at 20:47, "Andrew Sarangan" wrote: > >> --> >> >> After a one year pause, I am getting back into building. I am near the >> stage of bonding the fuel tank into the CM. I read a lot of >> discussions about tank swellings and cracking, so I am a bit >> concerned. >> >> Doing a google search, I came across a fuel tank mod document written >> by Bud Yerly where he suggests using a cork pad in the fuselage to >> support the tank. The details are a bit unclear to me, so I would like >> solicit opinions from anyone who can give me some insights. >> >> Thanks in advance!! >> >> >> >> > > ________________________________________________________________________________
Date: Jul 07, 2013
When I had my tank and cobra (re/post) fluorinated by an industrial outfit, they confirmed it to be LDPE, fwiw. The finished treated tank had a severe frosted finish.... an indication that the level of treatment was indeed higher than the factory's and I am hoping I will have less swelling issues down the road. Cheers, Pete On Jul 7, 2013, at 1:20 PM, Andrew Sarangan wrote: > > Thanks for all the ideas. The problem, as I understand now, is the > attachment mechanism, and not necessarily the swelling. If the tank > can be supported without bonding its surfaces, then it should be able > to relieve the stresses as it expands and contracts. That's what I am > gathering from these discussions. > > More puzzling is, it seems there is no agreement on what the tank is > made of. Just in the last few emails, I've heard Polypropylene, HDPE, > LDPE all mentioned, and Yerly's article says it is PTFE. I am somewhat > familiar with different polymers, and these are all very different > materials. I doubt it is PTFE because it is super expensive and > nothing will stick to it. I know a chemical test to identify different > polymers, but I would need a small chunk of the material. If I ever > figure that out, I will make sure to post my results here. > > > > > > On Sun, Jul 7, 2013 at 3:43 AM, Duncan & Ami wrote: >> >> The tanks are low density polyethylene, I understand. And they shrink back >> over time when left empty (but not in my experience by as much as the >> initial expansion). Fluoridated tanks may be different. >> The Kitfox company understood this problem in 1990. >> >> DMcF >> >> -----Original Message----- >> From: owner-europa-list-server(at)matronics.com >> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of andrew cullum >> Sent: 06 July 2013 22:53 >> To: europa-list(at)matronics.com >> Subject: Re: Europa-List: Fuel tank question >> >> >> --> >> >> Hi Andrew, >> One question,have you filled your fuel tank with a mix of fuels you are >> going to >> use,and contained the tank with a sturdy wooden frame,and left it for at >> least 6 weeks? The poly-propylene apparently expands by about 10 per cent >> With the addition of fuel,this was in the old manual,but doesn't appear to >> be in the new one. Could it be that tanks that have cracked haven't had this >> pre-soaking? As for the cork at the bottom of the fuselage,sounds like a >> good idea,I'm sure that Bud can help you out. Best Regards Andy Cullum. >> >> >> Sent from my iPhone >> >> On 6 Jul 2013, at 20:47, "Andrew Sarangan" wrote: >> >>> --> >>> >>> After a one year pause, I am getting back into building. I am near the >>> stage of bonding the fuel tank into the CM. I read a lot of >>> discussions about tank swellings and cracking, so I am a bit >>> concerned. >>> >>> Doing a google search, I came across a fuel tank mod document written >>> by Bud Yerly where he suggests using a cork pad in the fuselage to >>> support the tank. The details are a bit unclear to me, so I would like >>> solicit opinions from anyone who can give me some insights. >>> >>> Thanks in advance!! > > > > ________________________________________________________________________________
Date: Jul 07, 2013
Thanks Pete. I am just about to embark on that route. I haven't called them yet, but I am considering Fluoro Seal (http://www.fluoroseal.com) if they are willing to take small jobs. They have a facility that is within an hour driving from me. On Sun, Jul 7, 2013 at 1:37 PM, Pete wrote: > > When I had my tank and cobra (re/post) fluorinated by an industrial outfit, they confirmed it to be LDPE, fwiw. > > The finished treated tank had a severe frosted finish.... an indication that the level of treatment was indeed higher than the factory's and I am hoping I will have less swelling issues down the road. > > Cheers, > Pete > > > On Jul 7, 2013, at 1:20 PM, Andrew Sarangan wrote: > >> >> Thanks for all the ideas. The problem, as I understand now, is the >> attachment mechanism, and not necessarily the swelling. If the tank >> can be supported without bonding its surfaces, then it should be able >> to relieve the stresses as it expands and contracts. That's what I am >> gathering from these discussions. >> >> More puzzling is, it seems there is no agreement on what the tank is >> made of. Just in the last few emails, I've heard Polypropylene, HDPE, >> LDPE all mentioned, and Yerly's article says it is PTFE. I am somewhat >> familiar with different polymers, and these are all very different >> materials. I doubt it is PTFE because it is super expensive and >> nothing will stick to it. I know a chemical test to identify different >> polymers, but I would need a small chunk of the material. If I ever >> figure that out, I will make sure to post my results here. >> >> >> >> >> >> On Sun, Jul 7, 2013 at 3:43 AM, Duncan & Ami wrote: >>> >>> The tanks are low density polyethylene, I understand. And they shrink back >>> over time when left empty (but not in my experience by as much as the >>> initial expansion). Fluoridated tanks may be different. >>> The Kitfox company understood this problem in 1990. >>> >>> DMcF >>> >>> -----Original Message----- >>> From: owner-europa-list-server(at)matronics.com >>> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of andrew cullum >>> Sent: 06 July 2013 22:53 >>> To: europa-list(at)matronics.com >>> Subject: Re: Europa-List: Fuel tank question >>> >>> >>> --> >>> >>> Hi Andrew, >>> One question,have you filled your fuel tank with a mix of fuels you are >>> going to >>> use,and contained the tank with a sturdy wooden frame,and left it for at >>> least 6 weeks? The poly-propylene apparently expands by about 10 per cent >>> With the addition of fuel,this was in the old manual,but doesn't appear to >>> be in the new one. Could it be that tanks that have cracked haven't had this >>> pre-soaking? As for the cork at the bottom of the fuselage,sounds like a >>> good idea,I'm sure that Bud can help you out. Best Regards Andy Cullum. >>> >>> >>> Sent from my iPhone >>> >>> On 6 Jul 2013, at 20:47, "Andrew Sarangan" wrote: >>> >>>> --> >>>> >>>> After a one year pause, I am getting back into building. I am near the >>>> stage of bonding the fuel tank into the CM. I read a lot of >>>> discussions about tank swellings and cracking, so I am a bit >>>> concerned. >>>> >>>> Doing a google search, I came across a fuel tank mod document written >>>> by Bud Yerly where he suggests using a cork pad in the fuselage to >>>> support the tank. The details are a bit unclear to me, so I would like >>>> solicit opinions from anyone who can give me some insights. >>>> >>>> Thanks in advance!! >> >> >> >> > > ________________________________________________________________________________
Date: Jul 07, 2013
On Jul 7, 2013, at 10:37 AM, Pete wrote: > When I had my tank and cobra (re/post) fluorinated by an industrial outfit, they confirmed it to be LDPE, fwiw. Pete...and your kit # is...?... thanks, Fred ________________________________________________________________________________
Date: Jul 07, 2013
Oops...should have included it in my sig.... a239 Indeed it *was* factory fourinated, albeit i have to assume to a lower level . The industrial folks who I used had different levels, the highest of which i s used by the auto industry for their plastic fuel tanks, and is the level I had requested. Lower levels are used by the shampoo co's :-) Cheers, Pete Ps- I am kinda surprised that there were no other takers a couple of years a go to split the min order cost ...... Since the per tank cost was a trivial $ 35 :-) Cheers and blue skies, Pete a239 On Jul 7, 2013, at 3:08 PM, Fred Klein wrote: > > On Jul 7, 2013, at 10:37 AM, Pete wrote: > >> When I had my tank and cobra (re/post) fluorinated by an industrial outfi t, they confirmed it to be LDPE, fwiw. > > Pete...and your kit # is...?... > > thanks, > > Fred > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 07, 2013
PS - the Europa factory obviously treats prior to finish cuts as well..... which pretty well negates the value of the process imho. Cheers, Pete a239 On Jul 7, 2013, at 3:08 PM, Fred Klein wrote: > > On Jul 7, 2013, at 10:37 AM, Pete wrote: > >> When I had my tank and cobra (re/post) fluorinated by an industrial outfi t, they confirmed it to be LDPE, fwiw. > > Pete...and your kit # is...?... > > thanks, > > Fred > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 07, 2013
Pete...your kind offer was moot for me in that my CM was already installed, w/ tank buried within of course...Fred On Jul 7, 2013, at 12:24 PM, Pete wrote: > I am kinda surprised that there were no other takers a couple of years ago to split the min order cost ...... Since the per tank cost was a trivial $35 :-) > ________________________________________________________________________________
Date: Jul 07, 2013
So let me extend this offer to all. I plan to fluorinate my tanks (#A178) sometime in the next month. As per Pete, the setup cost was $300 and per unit cost is $35. If three or four of us can join, the cost will become really trivial. But regardless, I plan to do it anyway. The pictures I saw of swelling tanks makes me think this could be worth thousands of dollars. On Sun, Jul 7, 2013 at 3:58 PM, Fred Klein wrote: > Pete...your kind offer was moot for me in that my CM was already installed, > w/ tank buried within of course...Fred > > On Jul 7, 2013, at 12:24 PM, Pete wrote: > > I am kinda surprised that there were no other takers a couple of years ago > to split the min order cost ...... Since the per tank cost was a trivial $35 > :-) > > ________________________________________________________________________________
Date: Jul 07, 2013
I am about to embark on a tank replacement. I don't have the tank yet but I'm interested, so contact me and tell me more. Brian Long A124 On Sunday, July 7, 2013, Andrew Sarangan wrote: > > > > So let me extend this offer to all. I plan to fluorinate my tanks > (#A178) sometime in the next month. As per Pete, the setup cost was > $300 and per unit cost is $35. If three or four of us can join, the > cost will become really trivial. But regardless, I plan to do it > anyway. The pictures I saw of swelling tanks makes me think this could > be worth thousands of dollars. > > > On Sun, Jul 7, 2013 at 3:58 PM, Fred Klein > > wrote: > > Pete...your kind offer was moot for me in that my CM was already > installed, > > w/ tank buried within of course...Fred > > > > On Jul 7, 2013, at 12:24 PM, Pete wrote: > > > > I am kinda surprised that there were no other takers a couple of years > ago > > to split the min order cost ...... Since the per tank cost was a trivial > $35 > > :-) > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 08, 2013
From: "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk>
Subject: G-IRON flies
On Saturday, 914 powered XS, G-IRON took to the sky for the first time following a major rebuild in the capable hands of owner Terry Clark. In blistering sunshine and slack wind, G-IRON left the Fairoaks runway at 14.30 for a faultless one-hour sortie. The second flight with your trusty scribe onboard to log flight parameters lasted one hour and forty minutes. The plane is beautifully balanced and flies hands-off straight and level. G-IRON has been built to a very high standard by Terry and Ian Rickard and is a credit to them both (pictured below). Nigel ________________________________________________________________________________
Date: Jul 08, 2013
Well done Ian. Pleased for you . Best regards Bob Harrison. G-PTAG From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of nigel_graham@m-tecque.co.uk Sent: 08 July 2013 08:41 Subject: Europa-List: G-IRON flies On Saturday, 914 powered XS, G-IRON took to the sky for the first time following a major rebuild in the capable hands of owner Terry Clark. In blistering sunshine and slack wind, G-IRON left the Fairoaks runway at 14.30 for a faultless one-hour sortie. The second flight with your trusty scribe onboard to log flight parameters lasted one hour and forty minutes. The plane is beautifully balanced and flies hands-off straight and level. G-IRON has been built to a very high standard by Terry and Ian Rickard and is a credit to them both (pictured below). Nigel ________________________________________________________________________________
Subject: Starboard flap pin =?ISO-8859-1?Q?doesn=99t?= engage easy
any longer =?ISO-8859-1?Q?=93?= why?
Date: Jul 08, 2013
Hi, I have my Europa stored in the trailer and rig it any time Im flying. Newly I have the problem, that the starboard flap pin doesnt slide in easy as was always the case before (for two years at any temperature). It feels like it cants and then after wiggling the wing up and down, forth and back it suddenly skips in completely. I always grease those connections very well and also the ring inside the flap operation tube, that catches the pin, is movable as on the other side. Flap operation when rigged is normal. Has anyone of you experienced something similar? Where do I have to focus on? Roland PH-ZTI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404171#404171 ________________________________________________________________________________
Subject: F-8?Q?RE:_Europa-List:_Starboard_flap_?= =?UTF-8?Q?pin_doesn=C3=A2=82=AC=84=A2t_engage_easy_any_lo?=
=?UTF-8?Q?nger_=C3=A2=82=AC=9C_why=3F?
Date: Jul 08, 2013
Hi! Roland, I too assemble and dismantle my a/c every time I fly, I also have occasionally a stubborn entry flap drive pin, even though the flap close out has a tapered guide tube to point the flap in the correct direction. I have to ensure that the "Rose Bearing"(You are calling it a "ring") in the end of the flap drive tube is freely centred before I push the wing into place. If I don't do that and the pin fails to engage the bearing it flexes the flap outwards and "cuts" into the aileron close out flange binding them together. ( an extremely dangerous condition if you were to go fly. Tim Wert did but by some very careful airmanship managed to land the aircraft safe.) I suggest that you thoroughly degrease and clean the bearing and re-lubricate it with oil in preference to grease, But above all before flying ensure it is properly engaged and that the flap outboard end is NOT FOULED INTO THE AILERON LOCKING THE TWO TOGETHER). Although I have never has it happen on the port wing I would suggest that it would be likely there also. Regards Bob Harrison G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Roland Sent: 08 July 2013 10:11 Subject: Europa-List: Starboard flap pin doesnt engage easy any longer why? Hi, I have my Europa stored in the trailer and rig it any time Im flying. Newly I have the problem, that the starboard flap pin doesnt slide in easy as was always the case before (for two years at any temperature). It feels like it cants and then after wiggling the wing up and down, forth and back it suddenly skips in completely. I always grease those connections very well and also the ring inside the flap operation tube, that catches the pin, is movable as on the other side. Flap operation when rigged is normal. Has anyone of you experienced something similar? Where do I have to focus on? Roland PH-ZTI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404171#404171 ________________________________________________________________________________
Subject: Re: G-IRON flies
Date: Jul 08, 2013
Good work guys! Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jul 8, 2013, at 2:41 AM, nigel_graham@m-tecque.co.uk wrote: On Saturday, 914 powered XS, G-IRON took to the sky for the first time following a major rebuild in the capable hands of owner Terry Clark. In blistering sunshine and slack wind, G-IRON left the Fairoaks runway at 14.30 for a faultless one-hour sortie. The second flight with your trusty scribe onboard to log flight parameters lasted one hour and forty minutes. The plane is beautifully balanced and flies hands-off straight and level. G-IRON has been built to a very high standard by Terry and Ian Rickard and is a credit to them both (pictured below). Nigel ________________________________________________________________________________
Date: Jul 08, 2013
Great news Ian and Terry. Looks like you've built another good 'un. Look forward to seeing you both around. Well done and look after this one! Regards Mike ________________________________________________________________________________
Subject: Re: f-8?Q?Re:_Europa-List:_Star?= =?utf-8?Q?board_flap_pin_doesn?= =?utf-8?Q?=C3=A2=C2=C2=99t_engage_easy_a?=
=?utf-8?Q?ny_longer_=C3=A2=C2=C2=93_why=3F?
Date: Jul 08, 2013
Hi Roland, The ''eyeball'' ball socket is held captive by a ring [ collar ], if the r ing has moved outboard, it will allow the eyeball to swivel too far, that i s why the pin will jam in the hole. Find a steel tube that just clears the eyeball, but is smaller than the soc ket housing. Align the eyeball hole parallel to the flap tube. Get someone to hold a piece of wood against their leg and bear against the port side of the flap tube, place the steel tube onto the collar and strike the tube with a hammer. When the ring is engaged deeper, the eyeball will only swivel a very small amount. You must of course use a special Aircraft Hammer, I have these for sale at only =C2=A3120 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! -----Original Message----- From: Roland <schmidtroland(at)web.de> Sent: Mon, Jul 8, 2013 10:11 am Subject: Europa-List: Starboard flap pin doesn=C3=A2=C2=C2=99t engage ea sy any longer =C3=A2=C2=C2=93 why? Hi, I have my Europa stored in the trailer and rig it any time I=C3=A2=C2=C2 =99m flying. Newly I have the problem, that the starboard flap pin doesn=C3=A2=C2=C2=99t slid e in easy as was always the case before (for two years at any temperature). It feels like it cants and then after wiggling the wing up and down, forth and back it sudde nly skips in completely. I always grease those connections very well and also t he ring inside the flap operation tube, that catches the pin, is movable as on the other side. Flap operation when rigged is normal. Has anyone of you experienced something similar? Where do I have to focus o n? Roland PH-ZTI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404171#404171 ________________________________________________________________________________
Date: Jul 08, 2013
Hi Andrew, If you do go ahead with it in the next month or two, and if you were interested (ie-if you had to ship further away than expected) I could ship my small 3Gallon tank to you in my Europa tank crate which you could then use, and when completed you could ship (at my cost of course) my little tank to an address in ogdensburg packaged simply in a cardboard box. Just a thought. I could send you some pics of the crate. If I were to participate, I'd have to bring the tank to osh and am leaving on the 23rd :-) Btw, great to hear you resumed you build! Funny how life keeps getting in the way.... Here too of course. Cheers, Pete On Jul 7, 2013, at 5:17 PM, Andrew Sarangan wrote: > > So let me extend this offer to all. I plan to fluorinate my tanks > (#A178) sometime in the next month. As per Pete, the setup cost was > $300 and per unit cost is $35. If three or four of us can join, the > cost will become really trivial. But regardless, I plan to do it > anyway. The pictures I saw of swelling tanks makes me think this could > be worth thousands of dollars. > > > > On Sun, Jul 7, 2013 at 3:58 PM, Fred Klein wrote: >> Pete...your kind offer was moot for me in that my CM was already installed, >> w/ tank buried within of course...Fred >> >> On Jul 7, 2013, at 12:24 PM, Pete wrote: >> >> I am kinda surprised that there were no other takers a couple of years ago >> to split the min order cost ...... Since the per tank cost was a trivial $35 >> :-) >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Jul 08, 2013
Apologies to the list......email was meant for Andrew only... Cheers, Pete On Jul 8, 2013, at 3:00 PM, Pete wrote: > Hi Andrew, > > If you do go ahead with it in the next month or two, and if you were interested (ie-if you had to ship further away than expected) I could ship my small 3Gallon tank to you in my Europa tank crate which you could then use, and when completed you could ship (at my cost of course) my little tank to an address in ogdensburg packaged simply in a cardboard box. > > Just a thought. I could send you some pics of the crate. If I were to participate, I'd have to bring the tank to osh and am leaving on the 23rd :-) > > > Btw, great to hear you resumed you build! Funny how life keeps getting in the way.... Here too of course. > > Cheers, > Pete > > > On Jul 7, 2013, at 5:17 PM, Andrew Sarangan wrote: > >> >> So let me extend this offer to all. I plan to fluorinate my tanks >> (#A178) sometime in the next month. As per Pete, the setup cost was >> $300 and per unit cost is $35. If three or four of us can join, the >> cost will become really trivial. But regardless, I plan to do it >> anyway. The pictures I saw of swelling tanks makes me think this could >> be worth thousands of dollars. >> >> >> >> On Sun, Jul 7, 2013 at 3:58 PM, Fred Klein wrote: >>> Pete...your kind offer was moot for me in that my CM was already installed, >>> w/ tank buried within of course...Fred >>> >>> On Jul 7, 2013, at 12:24 PM, Pete wrote: >>> >>> I am kinda surprised that there were no other takers a couple of years ago >>> to split the min order cost ...... Since the per tank cost was a trivial $35 >>> :-) >> >> >> >> ________________________________________________________________________________
Subject: Whats happened to DOTH's
Date: Jul 08, 2013
Having just got my bird back in the air after various delays this year, I was wondering where to go and it struck me that I have not seen any Drop of the Hat fly ins on the forum this year, unless I have missed them. The weather looks great this week and I note that there is a free landing voucher for Swansea in the July issue of the Light Aircraft mag so am proposing to head there on Thursday for lunch. Look forward to meeting anyone else who can make it. PPR required. Swansea Radio 119.700 Richard Iddon. G-RIXS ________________________________________________________________________________
Subject: D2D
Date: Jul 09, 2013
Just to say that' S*d's Law was in operation on Sunday. In the middle of the best Wx the UK has seen for months, possibly years I got up at 3.30am in Prestwick to find it raining & cloudbase at 300ft!! Couldn't take off before 10.00am by which time it was too late to do anything except fly home and watch the tennis. Pity! The preliminary trials had suggested it was quite possible for me to fly the 2550nm course at an average of 150kts with just two brief refuelling stops, thus upstaging a Hawk Jet, a Mooney and a Beech Baron, previous holders of the record for longest distance flown. I had hoped that this would raise the flag for Europa, Permit aircraft and Monos - the latter in response to someone who recently asked "What are monos good for?" - I don't think a Trike could have hoped to do this! Regards, David Joyce, G-XSDJ ________________________________________________________________________________
Subject: D2D
Date: Jul 09, 2013
Hi! David . Sorry you didn't make it but why not a weekday ? Regards Bob H. -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of David Joyce Sent: 09 July 2013 12:36 Subject: Europa-List: D2D --> Just to say that' S*d's Law was in operation on Sunday. In the middle of the best Wx the UK has seen for months, possibly years I got up at 3.30am in Prestwick to find it raining & cloudbase at 300ft!! Couldn't take off before 10.00am by which time it was too late to do anything except fly home and watch the tennis. Pity! The preliminary trials had suggested it was quite possible for me to fly the 2550nm course at an average of 150kts with just two brief refuelling stops, thus upstaging a Hawk Jet, a Mooney and a Beech Baron, previous holders of the record for longest distance flown. I had hoped that this would raise the flag for Europa, Permit aircraft and Monos - the latter in response to someone who recently asked "What are monos good for?" - I don't think a Trike could have hoped to do this! Regards, David Joyce, G-XSDJ ________________________________________________________________________________
Subject: Re: Whats happened to DOTH's
Date: Jul 09, 2013
We flew in to Swansea today and it is very nice too- but no cafe. Sitting in the sunshine on the grass outside is fine but there appear to be no facilities (not so much as a chair!) when the cafe is shut. The firemen made us a very nice cuppa and told us the cafe is open Fiday, Saturday and other times at random. It would be worth checking that the with the tower when ringing for PPR that the cafe is open- apparently they tell by the smell of bacon cooking. We did warn them of a possible influx of Europas so perhaps they will make an extra effort! Enjoy the outing. Bill & Sue Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404334#404334 ________________________________________________________________________________
Subject: Re: Trip to Australia, is it possible?
Date: Jul 10, 2013
Count me in! Just one small problem- need to finish my plane first. I do however feel it might not take as long as getting all the permits.. See http://europaowners.org/main.php?g2_itemId644&g2_imageViewsIndex=1 -------- Jeroen http://www.europaowners.org/main.php?g2_itemId=44165 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404358#404358 ________________________________________________________________________________
Subject: Any idea what hole in FL-16 Flap Hing Arm is for?
Date: Jul 10, 2013
Hi Group Anyone have any idea why both of my FL-16 Flap Hinge Arms have a hole on the square end?: https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1655&authkey=!AF7B8FVUzjNaSt8 Thx. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404403#404403 ________________________________________________________________________________
Subject: Foot well got burned!
Date: Jul 10, 2013
Hi Group I accidentally burned my starboard foot-well! I replaced my lanterns alkaline battery (EverReady) ~ Christmas 2010. It hasn't seen any use since then. I sit down in front of my Europa XS Mono to study the undercarriage mounting frame, need some light. No problem, I grab my lantern that I always store with the lens up (in case it is left on), turn it on and use it for 5 or so minutes. I turn it off and rest it on my starboard foot-well, again with the lens up. After about 10 minutes I pick it up, turn it on to use it again and see what I think is water on my foot-well, it's turning the Phenolic resin black! I'm not sure just what leaked out of the battery, but it was water clear and had the viscosity of 3 in 1 oil. I was able to get off perhaps 1/2 of the damage, I tried water, alcohol and acetone with scotchbright. Anyway the resin sure did react quick to whatever it was that leaked out.: https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1656&authkey=!AEWLOllC2BXrnI0 Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404404#404404 ________________________________________________________________________________
Subject: Re: Any idea what hole in FL-16 Flap Hing Arm is for?
Date: Jul 10, 2013
Hi Ron, Not the right place for a hole to connect to the flap cross tube. Nope, no idea why that hole is there. If it were me, I'd just ignore it. You are free to do as you will. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jul 10, 2013, at 1:51 PM, rparigoris wrote: Hi Group Anyone have any idea why both of my FL-16 Flap Hinge Arms have a hole on the square end?: https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1655&authkey=!AF7B8FVUzjNaSt8 Thx. Ron Parigoris ________________________________________________________________________________
Date: Jul 10, 2013
Ron...reading on p.9 of chap. 28M: > Step 14 > Attach the hinge arms FL16 to the brackets FL18 then swing them up to engage between the two pairs of lugs that are welded to the cross-tube, rotating the tube so that the lugs and the hinge arms are in line. Clamp the lugs and hinge arms together then, using the two small diameter holes in each lug as a centre, drill right through with a 4.8 mm drill. Insert an AN3-5A bolt in each hole and reposition the clamp if necessary before drilling the second hole then, placing on an AN960-10L washer, tighten each bolt up with an MS21042-3 nut and remove the clamps. The flaps will now extend and retract together and only require linking to the landing gear retraction mechanism. Manual indicates you should have 2 small holes...not 1...what size is your hole? I don't recall if my FL 16s had one or two holes... F. On Jul 10, 2013, at 11:51 AM, rparigoris wrote: > > Hi Group > > Anyone have any idea why both of my FL-16 Flap Hinge Arms have a hole on the square end?: > https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1655&authkey=!AF7B8FVUzjNaSt8 > > Thx. > Ron Parigoris > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404403#404403 > > > > > > > > > > > > > -- > BEGIN-ANTISPAM-VOTING-LINKS > ------------------------------------------------------ > > Teach CanIt if this mail (ID 02JWGXHlz) is spam: > Spam: https://antispam.roaringpenguin.com/canit/b.php?i=02JWGXHlz&m=b15dd3cf2289&t 130710&c=s > Not spam: https://antispam.roaringpenguin.com/canit/b.php?i=02JWGXHlz&m=b15dd3cf2289&t 130710&c=n > Forget vote: https://antispam.roaringpenguin.com/canit/b.php?i=02JWGXHlz&m=b15dd3cf2289&t 130710&c=f > ------------------------------------------------------ > END-ANTISPAM-VOTING-LINKS ________________________________________________________________________________
Date: Jul 10, 2013
OOPS...misread the manual...the "two small holes" are in the lugs, not in the FL 16s...in truth, I don't recall my FL 16s having ANY holes... On Jul 10, 2013, at 1:26 PM, Fred Klein wrote: > > Ron...reading on p.9 of chap. 28M: > >> Step 14 >> Attach the hinge arms FL16 to the brackets FL18 then swing them up to engage between the two pairs of lugs that are welded to the cross-tube, rotating the tube so that the lugs and the hinge arms are in line. Clamp the lugs and hinge arms together then, using the two small diameter holes in each lug as a centre, drill right through with a 4.8 mm drill. Insert an AN3-5A bolt in each hole and reposition the clamp if necessary before drilling the second hole then, placing on an AN960-10L washer, tighten each bolt up with an MS21042-3 nut and remove the clamps. The flaps will now extend and retract together and only require linking to the landing gear retraction mechanism. > > Manual indicates you should have 2 small holes...not 1...what size is your hole? > > I don't recall if my FL 16s had one or two holes... > > F. > > On Jul 10, 2013, at 11:51 AM, rparigoris wrote: > >> >> Hi Group >> >> Anyone have any idea why both of my FL-16 Flap Hinge Arms have a hole on the square end?: >> https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1655&authkey=!AF7B8FVUzjNaSt8 >> >> Thx. >> Ron Parigoris >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=404403#404403 >> >> >> >> >> >> >> >> >> >> >> >> >> -- > > > > > > > > > -- > BEGIN-ANTISPAM-VOTING-LINKS > ------------------------------------------------------ > > Teach CanIt if this mail (ID 04JWIxqCg) is spam: > Spam: https://antispam.roaringpenguin.com/canit/b.php?i=04JWIxqCg&m=b801e1d25aea&t 130710&c=s > Not spam: https://antispam.roaringpenguin.com/canit/b.php?i=04JWIxqCg&m=b801e1d25aea&t 130710&c=n > Forget vote: https://antispam.roaringpenguin.com/canit/b.php?i=04JWIxqCg&m=b801e1d25aea&t 130710&c=f > ------------------------------------------------------ > END-ANTISPAM-VOTING-LINKS ________________________________________________________________________________
Subject: Europa Ownres website
Date: Jul 10, 2013
I am so elegantly infuriated to take the time to write my frustrations with the asinine subject website. Every time I try to get what I paid for, I am frustrated by the kindergarten precautions to entry. I had to fill out my name and address FIVE times to get to where I could email to acquire a new password. I have more than one address and cannot keep a list of all the myriad passwords and names and addresses these children require - when in fact they had my name and address on application - PLUS a request to remember them for future application - which they DID NOT. What is the problem? Cannot they tell who's emailing them? Why are they unable to acknowledge receipt of one email? They got the money - it's time to belly up to the bar. Ferg Kyle eight thousand passwords ________________________________________________________________________________
Subject: Re: f-8?Q?Re:_Europa-List:_Starboard_flap_pin_doesn=C3=A2=3F=3Ft_enga?=
=?utf-8?Q?ge_easy_any_longer_=C3=A2=3F=3F_why=3F?
Date: Jul 11, 2013
Nigel, I too have specialized tool for setting these bearings, but I found your price a bit high for a lowly hammer, that's why we have a highly refined tool called a High Inertia Fine Adjustment Tool (HIFAT) for only 150. For others I have a less expensive Government Surplus High Acceleration Mass Mechanical Error Reducer for those fine adjustments at only 56. Regards, Bud ----- Original Message ----- From: Neville Eyre<mailto:neveyre(at)aol.com> To: europa-list(at)matronics.com Sent: Monday, July 08, 2013 12:13 PM Subject: Re: Europa-List: Starboard flap pin doesn=C3=A2=C2=C2=99t engage easy any longer =C3=A2=C2=C2=93 why? Hi Roland, The ''eyeball'' ball socket is held captive by a ring [ collar ], if the ring has moved outboard, it will allow the eyeball to swivel too far, that is why the pin will jam in the hole. Find a steel tube that just clears the eyeball, but is smaller than the socket housing. Align the eyeball hole parallel to the flap tube. Get someone to hold a piece of wood against their leg and bear against the port side of the flap tube, place the steel tube onto the collar and strike the tube with a hammer. When the ring is engaged deeper, the eyeball will only swivel a very small amount. You must of course use a special Aircraft Hammer, I have these for sale at only =C2=A3120 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! -----Original Message----- From: Roland <schmidtroland(at)web.de> To: europa-list Sent: Mon, Jul 8, 2013 10:11 am Subject: Europa-List: Starboard flap pin doesn=C3=A2=C2=C2=99t engage easy any longer =C3=A2=C2=C2=93 why? > Hi, I have my Europa stored in the trailer and rig it any time I=C3=A2=C2=C2=99m flying. Newly I have the problem, that the starboard flap pin doesn=C3=A2=C2=C2=99t slide in easy as was always the case before (for two years at any temperature). It feels like it cants and then after wiggling the wing up and down, forth and back it suddenly skips in completely. I always grease those connections very well and also the ring inside the flap operation tube, that catches the pin, is movable as on the other side. Flap operation when rigged is normal. Has anyone of you experienced something similar? Where do I have to focus on? Roland PH-ZTI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404171#404171 .matronics.com/viewtopic.php?p=404171#404171> arget="_blank">http://www.matronics.com/Navigator?Europa-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: Rogue Hole in FL16
Date: Jul 11, 2013
The hole n the square end are supposed to be to suit the brackets from the c ross tube. So, it's a rogue hole, and if it came from Europa, as I imagine i t must of as a fast build kit, with the bearing possibly pre installed as we ll, get a new one. I don't think you can use it due to the proximity of the w rong hole, compromising the bracket. I undid my temporary setup and now will use some sort of nylon to avoid the f riction scored marks in my setup. Hope this he's. Regards Tony Renshaw Sent from my iPad > >
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt& Chapter 13-07-10&Archive=Europa > > > > > > ________________________________ Message 2 _____________________________ ________ > > > Subject: Europa-List: Any idea what hole in FL-16 Flap Hing Arm is for? > From: "rparigoris" <rparigor(at)suffolk.lib.ny.us> > > > Hi Group > > Anyone have any idea why both of my FL-16 Flap Hinge Arms have a hole on t he square > end?: > https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1655&authkey=!A F7B8FVUzjNaSt8 > > Thx. > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404403#404403 > > > ________________________________ Message 3 _____________________________ ________ > > > Subject: Europa-List: Foot well got burned! > From: "rparigoris" <rparigor(at)suffolk.lib.ny.us> > > > Hi Group > > I accidentally burned my starboard foot-well! > > I replaced my lanterns alkaline battery (EverReady) ~ Christmas 2010. It h asn't > seen any use since then. > > I sit down in front of my Europa XS Mono to study the undercarriage mounti ng frame, > need some light. No problem, I grab my lantern that I always store with th e > lens up (in case it is left on), turn it on and use it for 5 or so minutes . > > > I turn it off and rest it on my starboard foot-well, again with the lens u p. > > After about 10 minutes I pick it up, turn it on to use it again and see wh at I > think is water on my foot-well, it's turning the Phenolic resin black! > > I'm not sure just what leaked out of the battery, but it was water clear a nd had > the viscosity of 3 in 1 oil. > > I was able to get off perhaps 1/2 of the damage, I tried water, alcohol an d acetone > with scotchbright. > > Anyway the resin sure did react quick to whatever it was that leaked out.: > https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1656&authkey=!A EWLOllC2BXrnI0 > > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404404#404404 > > > ________________________________ Message 4 _____________________________ ________ > > > Subject: Re: Europa-List: Any idea what hole in FL-16 Flap Hing Arm is for ? > From: Robert Borger <rlborger(at)mac.com> > > > Hi Ron, > > Not the right place for a hole to connect to the flap cross tube. Nope, n o idea > why that hole is there. If it were me, I'd just ignore it. You are free t o > do as you will. > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop. > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Jul 10, 2013, at 1:51 PM, rparigoris wrote : > > > Hi Group > > Anyone have any idea why both of my FL-16 Flap Hinge Arms have a hole on t he square > end?: > https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1655&authkey=!A F7B8FVUzjNaSt8 > > Thx. > Ron Parigoris > > > ________________________________ Message 5 __
Date: Jul 11, 2013
Morning Tony Why not use some proper jointing compound between the parts. It will also prevent corrosion. I was given a tin of a yellow paste by my original inspector. I have just had a look in the garage to see if I could find the name but I think the tin has been passed on to another builder. Regards Pete -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw Sent: 11 July 2013 08:59 Subject: Europa-List: Rogue Hole in FL16 The hole n the square end are supposed to be to suit the brackets from the cross tube. So, it's a rogue hole, and if it came from Europa, as I imagine it must of as a fast build kit, with the bearing possibly pre installed as well, get a new one. I don't think you can use it due to the proximity of the wrong hole, compromising the bracket. I undid my temporary setup and now will use some sort of nylon to avoid the friction scored marks in my setup. Hope this he's. Regards Tony Renshaw -- This message has been scanned for viruses and dangerous content by Houxou, and is believed to be clean. ________________________________________________________________________________
Subject: flaphinge bushes
Date: Jul 11, 2013
Hi there , I'm in the search for FL 9 flaphinge bushes (for replacement for my outriggers in the outriggerplates) anybody have some spares left or where to order ? for PH-POP kind regards Rob Zeelenberg ________________________________________________________________________________
Date: Jul 11, 2013
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Subject: Re: Rogue Hole in FL16
Pete=0Ait's called Duralac. Should always be used when bolting things toget her. As you say it=0Ainhibits corrosion between dissimilar metals. -That should have been in the manual but I never saw it.=0AGraham=0A=0A=0A_______ _________________________=0A From: Pete Lawless <pete(at)lawless.info>=0ATo: e uropa-list(at)matronics.com =0ASent: Thursday, 11 July 2013, 9:51=0ASubject: R E: Europa-List: Rogue Hole in FL16=0A =0A=0A--> Europa-List message posted by: "Pete Lawless" =0A=0AMorning Tony=0A=0AWhy not use s ome proper jointing compound between the parts. It will also=0Aprevent corr osion. I was given a tin of a yellow paste by my original=0Ainspector.- I have just had a look in the garage to see if I could find the=0Aname but I think the tin has been passed on to another builder.=0A=0ARegards=0A=0APet e=0A=0A=0A=0A-----Original Message-----=0AFrom: owner-europa-list-server@ma tronics.com=0A[mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw=0ASent: 11 July 2013 08:59=0ATo: europa-list(at)matronics.com=0AS ubject: Europa-List: Rogue Hole in FL16=0A=0AThe hole n the square end are supposed to be to suit the brackets from the=0Across tube. So, it's a rogue hole, and if it came from Europa, as I imagine=0Ait must of as a fast buil d kit, with the bearing possibly pre installed as=0Awell, get a new one. I don't think you can use it due to the proximity of=0Athe wrong hole, compro mising the bracket. =0AI undid my temporary setup and now will use some sor t of nylon to avoid the=0Afriction scored marks in my setup. =0AHope this h e's.=0ARegards=0ATony Renshaw=0A=0A=0A=0A=0A-- =0AThis message has been sca nned for viruses and=0Adangerous content by Houxou, and is=0Abelieved to be =========================0A =================== ________________________________________________________________________________
Subject: UK Mono Training
Date: Jul 11, 2013
Im just completing the purchase of a mono and want to get some training to fly it safely. Ive contacted the LAA coaching scheme and are waiting for their reply, but I thought I would ask on here for the experts thoughts. I have about 300 hours flying time, most of it in my former aircraft an Airtourer. I have no tail wheel experience at all. The aircraft Im buying is a 100hp XS mono with a fixed pitch prop. I hope to base the aircraft at Westonzoyland near Bridgewater in Somerset but I still have my old hanger at New Farm near Bristol Airport where the runway is a bit longer than Westonzoylands but slopes and cant be used for circuit work or training. Can anybody recommend suitably qualified instructors in the south West (Gloucester to Exeter) who might be worth approaching if LAA coaching are unable to help. Any ideas appreciated. Dave Disney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404455#404455 ________________________________________________________________________________
Subject: Re: UK Mono Training
Date: Jul 11, 2013
I can recommend Andy Draper. I was in a similar situation although he also did the flight test on the plane. I moved it to Sywell where there is a choice of runways and open grass. I did a few sessions with him and then some solo, later back for a session on the concrete. It was all done through the coaching scheme. I had about 500 hrs but also no tail wheel but havent had a problem so far. I did about 70 Takeoff/landings before moving it to the strip. -------- Graeme Bird G-UMPY Mono Classic/XS 912S/Woodcomp 3000/3W Newby: 75 hours 18 months g(at)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404463#404463 ________________________________________________________________________________
Date: Jul 11, 2013
Pleased to report that we enjoyed a very nice trip to, and a tasty bacon buttie at Swansea today. Despite the tower advising me that the cafe would not be open when I phoned for PPR! Returned via Caernarfon for a brew. One more Europa turned up just as were lining up for departure at Swansea around 1:30. Apologies if you arrived for the DOTH and we missed you. Richard Iddon. G-RIXS On 10 Jul 2013, at 00:45, Bill & Sue wrote: > > We flew in to Swansea today and it is very nice too- but no cafe. > Sitting in the sunshine on the grass outside is fine but there appear to be no facilities (not so much as a chair!) when the cafe is shut. The firemen made us a very nice cuppa and told us the cafe is open Fiday, Saturday and other times at random. It would be worth checking that the with the tower when ringing for PPR that the cafe is open- apparently they tell by the smell of bacon cooking. > We did warn them of a possible influx of Europas so perhaps they will make an extra effort! > > Enjoy the outing. > > Bill & Sue > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404334#404334 > > > > > > > > > > ________________________________________________________________________________
Subject: KOSH ticket and room
Date: Jul 11, 2013
I bought a ticket and got a room at the local college for KOAK this year, but I'm having semi-emergency surgery next Thursday for a collapsed lung. I'll be in the hospital for five to seven days and the doctor has grounded me for two week after I leave the hospital. If anybody is interested in the ticket and or the room let me know off line AirEupora(at)sbcglobal.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404500#404500 ________________________________________________________________________________
Date: Jul 11, 2013
I bought a ticket and got a room at the local college for KOSK this year, but I'm having semi-emergency surgery next Thursday for a collapsed lung. I'll be in the hospital for five to seven days and the doctor has grounded me for two week after I leave the hospital. If anybody is interested in the ticket and or the room let me know off line AirEupora(at)sbcglobal.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404501#404501 ________________________________________________________________________________
Date: Jul 12, 2013
From: KENNETH ATKINSON <kennethatkinson178(at)btinternet.com>
We also enjoyed the DOTH to Swansea yesterday. We flew from Cark to Lands E nd. The lady there was very helpful and the breakfast in a bun was excellen t. I am sorry we were a bit late into Swansea-We did wave as you took off! Swansea were obliging and accepted our LAA voucher OK. We flew back via the Welsh coast.--- A brilliant Europa day!=0A-=0A------ ------------------------- ----------- Cheers Ken Atkinson=0A------ ------------------------- ------------------------- ------------------------ G- CEKV=0A =0A=0A________________________________=0A From: Richard Iddon <ridd on(at)sent.com>=0ATo: europa-list(at)matronics.com =0ASent: Thursday, 11 July 201 3, 22:06=0ASubject: Re: Europa-List: Re: Whats happened to DOTH's=0A =0A Pleased to report that we enjoyed a very nice trip to, and a tasty bacon bu ttie at Swansea today. Despite the tower advising me that the cafe would no t be open when I phoned for PPR! Returned via Caernarfon for a brew. One mo re Europa turned up just as were lining up for departure at Swansea around 1:30. Apologies if you arrived for the DOTH and we missed you.=0A=0ARichard Iddon. =0A=0AG-RIXS=0A=0AOn 10 Jul 2013, at 00:45, Bill & Sue =0A> =0A> We flew in to Swansea today and it is very nice too- but no cafe. =0A> Sitting in the sunshine on the grass outside is fine but there appear to be no facilities (not so much as a chair!) when the cafe is shut. The firemen made us a very nice cuppa and told us the cafe is open Fiday, Saturday and other times at random. It woul d be worth checking that the with the tower when ringing for PPR that the c afe is open- apparently they tell by the smell of bacon cooking.=0A> We did warn them of a possible influx of Europas- so perhaps they will make an extra effort!=0A> =0A> Enjoy the outing.=0A> =0A> Bill & Sue=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http://forums.matronics.com /viewtopic.php?p=404334#404334=0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A =========================0A =================== ________________________________________________________________________________
Subject: UV primer(s)
Date: Jul 12, 2013
I've been using the Stits / Poly Fiber products for filling and priming, namely the SuperFil and the SmoothPrime "pinhole killer", and the EP-420 primer/sealer...have just missed making a serious mistake...and thought it was worth my time to share my experience. I've found all the products very easy to work with and satisfying to bring to the desired level of smoothness...particularly the hi-build SmoothPrime, using a 3 foot sanding board starting at 220 grit before going up to 320 paper. I've been particularly prideful for doing my entire airframe w/ only 2 gallons. And that hi-build SmoothPirme is REALLY heavy stuff...so w/ weight always a concern, i was pretty aggressive with the sanding as I strove to first, achieve as straight and true a (wing) surface as I could, and second, to make sure that as much as possible of the weight of all that SmoothPrime ended up in the canister of the shop vac. It certainly didn't bother me that my wing surfaces, as smooth and true as they may be, got pretty blotchy w/ ALL the SmoothPrime removed in some areas where great areas of blue SuperFil became visable. It didn't bother me because I knew I would be applying the white EP-420 epoxy primer on top...and all of this time, I believed that the EP-420 would provide the necessary UV protection. WRONG !! The EP-420, 2 part epoxy primer DOES NOT provide any UV protection...I had misread or misremembered...and only learned by chance during a conversation on a related matter w/ a Stits tech person. So with that Stits product line, it is the SmoothPrime which provides the UV protection...not the EP-420 primer/sealer! And I'll be working on a 3rd gallon...rolling on 3 coats...sanding it smooth down to 400 grit...but stopping while I still have a white airplane...before applying the EP-420 primer/sealer. Fred ________________________________________________________________________________
Date: Jul 12, 2013
Subject: Re: UV primer(s)
Fred, a suggestion, if you can spray on the Smooth Prime, it will be a lot more consistent and as you know after rolling it on, there is lots more sanding after rolling than if you can spray it on. Also, John Lawton gave me a paint to use that is UV protective, albeit very expensive paint, $500 + a gallon and two qts hardener (and illegal in Calif). Bill McClellan -----Original Message----- >From: Fred Klein <fklein(at)orcasonline.com> >Sent: Jul 12, 2013 5:35 PM >To: europa-list(at)matronics.com >Subject: Europa-List: UV primer(s) > > >I've been using the Stits / Poly Fiber products for filling and priming, namely the SuperFil and the SmoothPrime "pinhole killer", and the EP-420 primer/sealer...have just missed making a serious mistake...and thought it was worth my time to share my experience. > >I've found all the products very easy to work with and satisfying to bring to the desired level of smoothness...particularly the hi-build SmoothPrime, using a 3 foot sanding board starting at 220 grit before going up to 320 paper. I've been particularly prideful for doing my entire airframe w/ only 2 gallons. > >And that hi-build SmoothPirme is REALLY heavy stuff...so w/ weight always a concern, i was pretty aggressive with the sanding as I strove to first, achieve as straight and true a (wing) surface as I could, and second, to make sure that as much as possible of the weight of all that SmoothPrime ended up in the canister of the shop vac. It certainly didn't bother me that my wing surfaces, as smooth and true as they may be, got pretty blotchy w/ ALL the SmoothPrime removed in some areas where great areas of blue SuperFil became visable. It didn't bother me because I knew I would be applying the white EP-420 epoxy primer on top...and all of this time, I believed that the EP-420 would provide the necessary UV protection. WRONG !! > >The EP-420, 2 part epoxy primer DOES NOT provide any UV protection...I had misread or misremembered...and only learned by chance during a conversation on a related matter w/ a Stits tech person. > >So with that Stits product line, it is the SmoothPrime which provides the UV protection...not the EP-420 primer/sealer! And I'll be working on a 3rd gallon...rolling on 3 coats...sanding it smooth down to 400 grit...but stopping while I still have a white airplane...before applying the EP-420 primer/sealer. > >Fred > > ________________________________________________________________________________
Date: Jul 12, 2013
On Jul 12, 2013, at 5:51 PM, William McClellan wrote: > uta suggestion, if you can spray on the Smooth Prime, it will be a lot more consistent and as you know after rolling it on, there is lots more sanding after rolling than if you can spray it on. Also, John Lawton gave me a paint to use that is UV protective, albeit very expensive paint, $500 + a gallon and two qts hardener (and illegal in Calif). Hey Bill...how'ya doin? Re: spraying SmoothPrime...for the life of me, I can't imagine the high viscosity SmoothPrime flowing thru a spray gun. I have VERY minimal experience spray painting, so my comfort level at trying to spray Smoothprime is very low. Have you thinned the stuff?...with what? I'm very comfortable rolling it but that's just playing to my fears. Up til now, I haven't minded the extra sanding since it cuts so nicely...of course, I am planning to spray the EP-420 sealer/primer. Fred ________________________________________________________________________________
Date: Jul 12, 2013
On Jul 12, 2013, at 5:51 PM, William McClellan wrote: > John Lawton gave me a paint to use that is UV protective, albeit very expensive paint, $500 + a gallon and two qts hardener (and illegal in Calif). Bill...what would be the brand of that paint?...if you don't mind letting the NSA know as well... Is that a top coat? Will you / have you still use(d) a sealer for the SmoothPrime? Fred ________________________________________________________________________________
From: Christoph Both <christoph.both(at)acadiau.ca>
Date: Jul 13, 2013
Smooth Prime rolls on very easy, you can control thickness with the proper roller. I did 3 coats as a minimum. Sands easy with 12 to 18 inch foam sand ing block DURABLOCK. Rolling allows better working the stuff into pin holes . Then sprayed epoxy primer filler, sanded to 350. Then another thin epoxy surface prep, hand sanded to 500. Then BASF single stage polyurethane low v olatility paint (still legal in Canada), two full coats. Easy to maintain a nd fix. Christoph Both 223 Classic Wings. Wolfville, Canada Sent from my iPhone On 2013-07-12, at 22:30, "Fred Klein" @orcasonline.com>> wrote: On Jul 12, 2013, at 5:51 PM, William McClellan wrote: uta suggestion, if you can spray on the Smooth Prime, it will be a lot more consistent and as you know after rolling it on, there is lots more sanding after rolling than if you can spray it on. Also, John Lawton gave me a pa int to use that is UV protective, albeit very expensive paint, $500 + a gal lon and two qts hardener (and illegal in Calif). Hey Bill...how'ya doin? Re: spraying SmoothPrime...for the life of me, I can't imagine the high vis cosity SmoothPrime flowing thru a spray gun. I have VERY minimal experience spray painting, so my comfort level at tryin g to spray Smoothprime is very low. Have you thinned the stuff?...with what ? I'm very comfortable rolling it but that's just playing to my fears. Up til now, I haven't minded the extra sanding since it cuts so nicely...of cours e, I am planning to spray the EP-420 sealer/primer. Fred ________________________________________________________________________________
From: "Richard Lamprey" <lamprey.richard(at)gmail.com>
Date: Jul 14, 2013
Dave, you may want to start tailwheel conversion on something simple, then build up. Having completed my monowheel Europe classic in Kenya in 1999, I came to UK for conversion. All my experience was on nosewheels (4000 hours Cessnas and Pipers- mostly Cessna 206), so I started on a docile taildragger, the Citabria, at Compton Abbas (2 hours); then Supercub at Old Sarum (2 hours); then on the PFA coaching scheme's instructor Air Vice Marshall John Brownlow on a borrowed Europa at Cambridge airport (3 hours and thanks to Tony Smythe for loan of G-BWZT). John Brownlow is a very patient coach, and is still very active in his retirement, saving kit plane builders from themselves at first flight stage... You might want to contact him. Best Richard Kenya Classic, 5Y-LRY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404656#404656 ________________________________________________________________________________
Date: Jul 14, 2013
As primitive as it sounds, if you want to spray "thick" liquids I suggest you try an electric airless gun They are quite cheap give an ok finish for priming, and will spray stuff like rubber latex and spray putty With no problems, sure they are a bit noisy but could be a good compromise over the roller. Regards craig ________________________________________________________________________________
Subject: mono wheel dampers
Date: Jul 15, 2013
Does anyone know the price (or at least a previous price) of the dampers us ed in the monowheel? Europa are currently unable to supply them, or give me a price. I have sourced some from a Europa owner who has done mono->trigea r conversion, and need to know to be able to pay him. Thanks Roddy Kesterton G-IKRK #220 ________________________________________________________________________________
Date: Jul 15, 2013
Subject: Re: Starboard flap pin =?UTF-8?B?ZG9lc27DosKAwpl0IGU=?=
=?UTF-8?B?bmdhZ2UgZWFzeSBhbnkgbG9uZ2VyIMOiwoDCkyB3aHk/? On 07/08/2013 06:13 PM, Neville Eyre wrote: > Hi Roland, > The ''eyeball'' ball socket is held captive by a ring [ collar ], if > the ring has moved outboard, it will allow the eyeball to swivel too > far, that is why the pin will jam in the hole. What also helps is to use a bit of sticky grease ("white grease") between the ball and the collar, and not moving the flap drive tube to a different position when the wings are off. The ball will then stay in the right position to catch the pin. Before I had the sticky grease on but some teflon doped oil in it instead, the balls turned with any movement and rigging was sometimes very difficult. Frans ________________________________________________________________________________
Subject: Euro Fly-In
Date: Jul 16, 2013
Hi all, This is a reminder to all Europaers from Europe: Euro Fly-In, the french RSA rally takes place next week end (July 19 - 21) in Vichy. Vichy is located right at the center of France. Informations for the event are available at: http://euroflyin.rsafrance.com/index.php Please check NOTAMS and AIP Sup. Looking forward seeing many of you with your Europa there. Remi Guerner F-PGKL ________________________________________________________________________________
Subject: Europa XS cover
From: "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk>
Date: Jul 17, 2013
I hope someone can help. I'm looking for an Europa XS cover, Just to see if someone has one for sale, or may be a loan for about 2 weeks. This is to keep the aircraft outside for its flight test. I'm not so bothered about the rain or snow we may get the July/August but more the 25+ heat in direct sunlight into the Cockpit. Thank you in advance. -------- Richard Wheelwright G-IRPW Ready For Test Flight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404826#404826 ________________________________________________________________________________
Date: Jul 18, 2013
Subject: Auto Response
I'm in the hospital with a collapsed lung, should be up and about on the 24th ________________________________________________________________________________
Subject: Rough River, KY Fly In
Date: Jul 19, 2013
We just spoke to the event coordinator at Rough River and learned that the only weekend in September or October that there are rooms available is Oct 4/5. Is there any interest? We asked them to pencil in 6 rooms, and have to confirm to RR by July 31 to reserve space. Jim & Heather N241BW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404949#404949 ________________________________________________________________________________
Subject: Re: Rough River, KY Fly In
Date: Jul 19, 2013
J&H, We can probably get there. And in the Europa this year! Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jul 19, 2013, at 1:43 PM, "h&jeuropa" wrote: We just spoke to the event coordinator at Rough River and learned that the only weekend in September or October that there are rooms available is Oct 4/5. Is there any interest? We asked them to pencil in 6 rooms, and have to confirm to RR by July 31 to reserve space. Jim & Heather N241BW ________________________________________________________________________________
Date: Jul 19, 2013
Subject: space still available
Fellow Europaphiles, I still have an 8' pop=up camper rented for the whole 10 days of Airventure. Right now I'm the only one in it. There's room for 3 - 4 more to sleep if anyone wants/need a place to stay for a few nights. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com ________________________________________________________________________________
Subject: Re: space still available
Date: Jul 19, 2013
On Jul 19, 2013, at 12:12 PM, Robert Borger wrote: > > I still have an 8' pop=up camper rented for the whole 10 days of Airventure. Right now I'm the only one in it. There's room for 3 - 4 more to sleep if anyone wants/need a place to stay for a few nights. Bob...are you flying your Europa to KOSH?...Fred ________________________________________________________________________________
Date: Jul 19, 2013
Hi Fred, Good Lord will'n & the creek don't rise, I'll be flying my Europa to KOSH. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jul 19, 2013, at 4:52 PM, Fred Klein wrote: On Jul 19, 2013, at 12:12 PM, Robert Borger wrote: > > I still have an 8' pop=up camper rented for the whole 10 days of Airventure. Right now I'm the only one in it. There's room for 3 - 4 more to sleep if anyone wants/need a place to stay for a few nights. Bob...are you flying your Europa to KOSH?...Fred ________________________________________________________________________________
Date: Jul 19, 2013
Hi Bob My wife and I will be there on the 31st, we have accommodations, motor home with a Jack Russel:) Will connect sometime. Looking forward to a great week. Regards Jerry Sent from Iphone On Jul 19, 2013, at 1:09 PM, Robert Borger wrote: > > J&H, > > We can probably get there. And in the Europa this year! > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop. > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Jul 19, 2013, at 1:43 PM, "h&jeuropa" wrote: > > > We just spoke to the event coordinator at Rough River and learned that the only weekend in September or October that there are rooms available is Oct 4/5. Is there any interest? > > We asked them to pencil in 6 rooms, and have to confirm to RR by July 31 to reserve space. > > Jim & Heather > N241BW > > > > ________________________________________________________________________________
Date: Jul 21, 2013
Subject: outrigger wheels
Hi I have an early classic Europa , the outrigger wheels have now given up the ghost. I am sorry I know this has all been discussed before but can anybody let me know where I can get some new ones? Roger GBWIJ ________________________________________________________________________________
Subject: Re: outrigger wheels
Date: Jul 21, 2013
Also are they available in different colours other then blue i.e orange? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405024#405024 ________________________________________________________________________________
Subject: andair gascolator query
Date: Jul 21, 2013
I've got an Andair GAS375-M gascolator that I plan to fit in the same compartment as the electric fuel pump. Obviously it is desirable to have it mounted with the bottom near the bottom skin of the fuselage so that the drain can be easily activated. However, it's necessary also to have room to remove the bowl. That means cutting an access hole in the bottom skin. Has anyone already got a LAA mod number that includes that sort of thing? I suppose (plan B) it would also be possible to mount the gascolator sufficiently high that the bowl could be removed from inside the aircraft, but that would mean the drain would be a long way from the fuselage floor and so not easy to operate from outside. Maybe it could also be operated from inside if the sample cup is small enough? Any thoughts? in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Date: Jul 21, 2013
Evening Roger This is an extract from an email from the late William Mills giving a source of an alternative supply. The email is dated May 2007 so phone numbers and names may not work. I saved it for future use, but now mainly flying off grass find my outrigger wear is minimal. "Whilst on the outrigger subject, I have found a source of much better outrigger wheels with proper sealed bearings and shielded hubs. They are obtained from: MSA Wheels and Castors Ltd, 10 Maclure Road, Rochdale, Lancs., UK. The spec is: 170299 EP100 Wheel + 8 mm Bush. The bush was inserted as a special order for me, to suit the existing outrigger bolt, so please make reference to the Europa aircraft outrigger wheel. If 'phoning the number is + 44(0)1706 516640 and ask for Neal and mention my name and the wheel's purpose. He knows all about it. You will have to make up two pairs of aluminium spacers about 3/16" thick to accommodate the narrower hub. (the rubber tyre is the same width as the blue ones) I made mine out of 8mm drilled 1/2" dia. solid aluminium bar." Regards Pete -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of trevannan Sent: 21 July 2013 21:42 Subject: Europa-List: outrigger wheels Hi I have an early classic Europa , the outrigger wheels have now given up the ghost. I am sorry I know this has all been discussed before but can anybody let me know where I can get some new ones? Roger GBWIJ -- This message has been scanned for viruses and dangerous content by Houxou, and is believed to be clean. ________________________________________________________________________________
Date: Jul 21, 2013
Subject: Re: andair gascolator query
Hi Rowland In USA, not LAA approved but here is what I did with my two 375s on my monowheel with 914: http://www.europaowners.org/main.php?g2_itemId=28612 Drain and service from outside the aeroplane. NOTE: When fooling with my fuel system on the bench, it is a really bad thing to have a leak in either the drain or bowl O ring of the 375. If you are having a hard time putting the bowl back on, install a new O ring as the old one probably changed dimension (keep some on hand). Another caution, when unscrewing the filter, do not turn from the side opposite where the threads are, it can damage the filter. I inspected my filter inside, and low and behold there was build crud from Andair stuck just about holding onto the adhesive they used during assembly just waiting to get to my carbs. Andair replaced free of charge, good idea to have a very good look inside. Ron Parigoris ________________________________________________________________________________
Date: Jul 21, 2013
On Jul 21, 2013, at 1:42 PM, trevannan wrote: > Hi > I have an early classic Europa , the outrigger wheels have now given up the ghost. I am sorry I know this has all been discussed before but can anybody let me know where I can get some new ones? > Roger GBWIJ A while back I did some back of the envelope computations and as I recall I figured that on touch down we are asking our outrigger wheels to spin up from zero to 5000 rpm in an instant. I can't vouch for the math today, but decided at the time that it was worth my time to investigate a bit and discovered the world of precision bearings...I now have some 100mm wheels with ABEX #9 bearings purchased at a inline skate shop...still building, so no direct experience. I had originally substituted sealed roller bearing wheels for those which were supplied w/ the kit; however, I had second thoughts about using them after seeing the identical wheel on supermarket carts...in this use, they are rarely subject to extreme accelleration. These wheels w/ the ABEX #9 bearing spin up like there's no tomorrow. Fred A194 ________________________________________________________________________________
Date: Jul 22, 2013
Rowland=0A=0ASpeak to Graham Singleton he has a mod and plans for how to do this, I am also in the process of doing with the addition of putting in al uminium lines to the bulkhead .=0A=0Argds=0ADavid=0AThe other one=0A=0ASent to you from David Joyce=0Awww.eastmidsspas.com=0A=0A =0A=0A_______________ _________________=0A From: Rowland Carson <rowlandcarson(at)gmail.com>=0ATo: E uropa e-mail list list =0ASent: Sunday, 21 July 2013, 22:09=0ASubject: Europa-List: andair gascolator query=0A =0A=0A--> Europa-List message posted by: Rowland Carson =0A =0AI've got an Andair GAS375-M gascolator that I plan to fit in the same co mpartment as the electric fuel pump. Obviously it is desirable to have it m ounted with the bottom near the bottom skin of the fuselage so that the dra in can be easily activated. However, it's necessary also to have room to re move the bowl. That means cutting an access hole in the bottom skin. Has an yone already got a LAA mod number that includes that sort of thing?=0A=0AI suppose (plan B) it would also be possible to mount the gascolator sufficie ntly high that the bowl could be removed from inside the aircraft, but that would mean the drain would be a long way from the fuselage floor and so no t easy to operate from outside. Maybe it could also be operated from inside if the sample cup is small enough?=0A=0AAny thoughts?=0A=0Ain friendship =0A=0ARowland=0A=0A| Rowland Carson- - - - - ... that's Rowland w ith a 'w' ...=0A| - - - - - - http://w ww.rowlandcarson.org.uk/=0A| Skype, Twitter: rowland_carson- - - Face book: Rowland Carson=0A| pictures: http://picasaweb.google.com/rowlandcarso ================== ________________________________________________________________________________
Date: Jul 22, 2013
On 22/07/2013 10:59, DAVID JOYCE wrote: > Rowland > Speak to Graham Singleton he has a mod and plans for how to do this, I > am also in the process of doing with the addition of putting in > aluminium lines to the bulkhead . > rgds > David > The other one > */Sent to you from David Joyce > www.eastmidsspas.com > /* > > *From:* Rowland Carson > *To:* Europa e-mail list list > *Sent:* Sunday, 21 July 2013, 22:09 > *Subject:* Europa-List: andair gascolator query > > > > > I've got an Andair GAS375-M gascolator that I plan to fit in the same > compartment as the electric fuel pump. Obviously it is desirable to > have it mounted with the bottom near the bottom skin of the fuselage > so that the drain can be easily activated. However, it's necessary > also to have room to remove the bowl. That means cutting an access > hole in the bottom skin. Has anyone already got a LAA mod number that > includes that sort of thing? > > I suppose (plan B) it would also be possible to mount the gascolator > sufficiently high that the bowl could be removed from inside the > aircraft, but that would mean the drain would be a long way from the > fuselage floor and so not easy to operate from outside. Maybe it could > also be operated from inside if the sample cup is small enough? > > Any thoughts? > > in friendship > > Rowland > > | Rowland Carson ... that's Rowland with a 'w' ... > | > > http://www.rowlandcarson.org.uk/ > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > | pictures: http://w.com/" = --> > <http://picasaweb.google.com/rowlandcarson> > > > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > * > > > * Hi David I am interested to install aluminium fuel circuit in my monowheel. Where do you buy components, tube and connectors ? ________________________________________________________________________________
Date: Jul 22, 2013
On 22/07/2013 10:59, DAVID JOYCE wrote: > Rowland > Speak to Graham Singleton he has a mod and plans for how to do this, I > am also in the process of doing with the addition of putting in > aluminium lines to the bulkhead . > rgds > David > The other one > */Sent to you from David Joyce > www.eastmidsspas.com > /* > > *From:* Rowland Carson > *To:* Europa e-mail list list > *Sent:* Sunday, 21 July 2013, 22:09 > *Subject:* Europa-List: andair gascolator query > > > > > I've got an Andair GAS375-M gascolator that I plan to fit in the same > compartment as the electric fuel pump. Obviously it is desirable to > have it mounted with the bottom near the bottom skin of the fuselage > so that the drain can be easily activated. However, it's necessary > also to have room to remove the bowl. That means cutting an access > hole in the bottom skin. Has anyone already got a LAA mod number that > includes that sort of thing? > > I suppose (plan B) it would also be possible to mount the gascolator > sufficiently high that the bowl could be removed from inside the > aircraft, but that would mean the drain would be a long way from the > fuselage floor and so not easy to operate from outside. Maybe it could > also be operated from inside if the sample cup is small enough? > > Any thoughts? > > in friendship > > Rowland > > | Rowland Carson ... that's Rowland with a 'w' ... > | > > http://www.rowlandcarson.org.uk/ > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > | pictures: http://w.com/" = --> > <http://picasaweb.google.com/rowlandcarson> > > > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > * > > > * Hi David my message is started too quick For the aluminium tube it is necessary annealed aluminum tube. To fold the tube easily. Many Thanks Michel AUVRAY ________________________________________________________________________________
Date: Jul 22, 2013
On 22/07/2013 10:59, DAVID JOYCE wrote: > Rowland > Speak to Graham Singleton he has a mod and plans for how to do this, I > am also in the process of doing with the addition of putting in > aluminium lines to the bulkhead . > rgds > David > The other one > */Sent to you from David Joyce > www.eastmidsspas.com > /* > > *From:* Rowland Carson > *To:* Europa e-mail list list > *Sent:* Sunday, 21 July 2013, 22:09 > *Subject:* Europa-List: andair gascolator query > > > > > I've got an Andair GAS375-M gascolator that I plan to fit in the same > compartment as the electric fuel pump. Obviously it is desirable to > have it mounted with the bottom near the bottom skin of the fuselage > so that the drain can be easily activated. However, it's necessary > also to have room to remove the bowl. That means cutting an access > hole in the bottom skin. Has anyone already got a LAA mod number that > includes that sort of thing? > > I suppose (plan B) it would also be possible to mount the gascolator > sufficiently high that the bowl could be removed from inside the > aircraft, but that would mean the drain would be a long way from the > fuselage floor and so not easy to operate from outside. Maybe it could > also be operated from inside if the sample cup is small enough? > > Any thoughts? > > in friendship > > Rowland > > | Rowland Carson ... that's Rowland with a 'w' ... > | > > http://www.rowlandcarson.org.uk/ > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > | pictures: http://w.com/" = --> > <http://picasaweb.google.com/rowlandcarson> > > > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > * > > > * Hi David, my message is started too quick! For the tube it is necessary annealed aluminum tube. To fold the tube easily. Many Thanks Michel AUVRAY ________________________________________________________________________________
Date: Jul 22, 2013
Hi Roger I have a pair of outrigger wheel along with a lot of other Mono parts not used on my Tri-gear. The deal is half list price. Let me know if you would like them Regards Richard Europa Tri-gear, 912ul Woodcomp prop Aircraft flying well, Pilot getting better. -----Original Message----- From: trevannan Sent: Sunday, July 21, 2013 9:42 PM Subject: Europa-List: outrigger wheels Hi I have an early classic Europa , the outrigger wheels have now given up the ghost. I am sorry I know this has all been discussed before but can anybody let me know where I can get some new ones? Roger GBWIJ ________________________________________________________________________________
Date: Jul 22, 2013
Rowland=0AYou could try Mod number 10823, issue 2, which is Colin Smallwood 's installation. (tri gear)=0AThere are a lot of Europas with similar mods but none really identical, depends where you start from,=0Aideally with the cockpit module on the bench.-=0AUse plan A, cut a D shaped biscuit from the bottom, add a hinge and one of the clips used for the cowling access pa nels. I cut the biscuits out with a Stanley knife or a hacksaw blade ground thin.=0AThen flox in the edges.=0A=0AGraham=0A=0A=0A______________________ __________=0A From: Rowland Carson <rowlandcarson(at)gmail.com>=0ATo: Europa e -mail list list =0ASent: Sunday, 21 July 2013, 22:09=0ASubject: Europa-List: andair gascolator query=0A =0A=0A--> Europa-L ist message posted by: Rowland Carson =0A=0AI've g ot an Andair GAS375-M gascolator that I plan to fit in the same compartment as the electric fuel pump. Obviously it is desirable to have it mounted wi th the bottom near the bottom skin of the fuselage so that the drain can be easily activated. However, it's necessary also to have room to remove the bowl. That means cutting an access hole in the bottom skin. Has anyone alre ady got a LAA mod number that includes that sort of thing?=0A=0AI suppose ( plan B) it would also be possible to mount the gascolator sufficiently high that the bowl could be removed from inside the aircraft, but that would me an the drain would be a long way from the fuselage floor and so not easy to operate from outside. Maybe it could also be operated from inside if the s ample cup is small enough?=0A=0AAny thoughts?=0A=0Ain friendship=0A=0ARowla nd=0A=0A| Rowland Carson- - - - - ... that's Rowland with a 'w' . ..=0A| - - - - - - http://www.rowlandc arson.org.uk=0A| Skype, Twitter: rowland_carson- - - Facebook: Rowlan d Carson=0A| pictures: http://picasaweb.google.com/rowlandcarson=0A=0A=0A =============== ________________________________________________________________________________
Date: Jul 22, 2013
Rowland The mod I sent you incorporates a forward bulkhead and a removable panel where the Mono wheel would normally be. I mounted the gascolator about 200mm forward of the fuel selector on the inside of the now disused mono wheel bay low down so the its drain could be accessed easily and assumed I would remove the outer floor panel to service the gascolator. I mounted the electric fuel pump on the forward bulk head and piped the output up and out of the top of the centre section under the instrument module and across to the far side of the starboard foot well top corner. -----Original Message----- From: Rowland Carson Sent: Sunday, July 21, 2013 10:09 PM Subject: Europa-List: andair gascolator query I've got an Andair GAS375-M gascolator that I plan to fit in the same compartment as the electric fuel pump. Obviously it is desirable to have it mounted with the bottom near the bottom skin of the fuselage so that the drain can be easily activated. However, it's necessary also to have room to remove the bowl. That means cutting an access hole in the bottom skin. Has anyone already got a LAA mod number that includes that sort of thing? I suppose (plan B) it would also be possible to mount the gascolator sufficiently high that the bowl could be removed from inside the aircraft, but that would mean the drain would be a long way from the fuselage floor and so not easy to operate from outside. Maybe it could also be operated from inside if the sample cup is small enough? Any thoughts? in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Date: Jul 22, 2013
On 22 Jul 2013, at 12:09, richard wrote: > > Rowland > The mod I sent you incorporates a forward bulkhead and a removable panel where the Mono wheel would normally be Richard - thanks, but the monowheel is occupying the space it normally occupies in my machine! I think Graham Singleton's advice about cutting an access panel is probably easiest to follow. It seems there is no technical issue with cutting a hole in the bottom of the aeroplane .... but no doubt one will have to get a "letter of no technical objection" from whoever is empowered to sign such things now at Europa. Thanks for all the suggestions. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Date: Jul 22, 2013
Subject: Re : andair gascolator query
/ORIGINAL MESSAGE/ // /From: Rowland Carson <rowlandcarson(at)gmail.com> / // /Subject: Europa-List: andair gascolator query/ // /I've got an Andair GAS375-M gascolator that I plan to fit in the same compartment as the electric fuel pump. Obviously it is desirable to have it mounted with the bottom near the bottom skin of the fuselage so that the drain can be easily activated. However, it's necessary also to have room to remove the bowl. That means cutting an access hole in the bottom skin. Has anyone already got a LAA mod number that includes that sort of thing?/ // /I suppose (plan B) it would also be possible to mount the gascolator sufficiently high that the bowl could be removed from inside the aircraft, but that would mean the drain would be a long way from the fuselage floor and so not easy to operate from outside. Maybe it could also be operated from inside if the sample cup is small enough?/ // /Any thoughts? in friendship Rowland/ ------------------------------------------------------------------------ Hi Rowland, I suggest that you consider going with plan B. I installed an Andair gascolator from day 1 (it has worked well) and it is located adjacent to the fuel pump under the baggage shelf. I added a pipe fitting and adapter to the gascolator bowl drain and this is run with rubber hose and adapters to a CAV-110 drain valve on the fuselage belly behind the flap. I placed the two tank drains at the same location. My valves protrude from the surface and I understand that some builders go to the trouble of recessing them so that they are flush . When I need to inspect the gascolator bowl, there is enough flex in the hose to permit this. One problem I ran into is that, inevitably, a small amount of dirt accumulates in the gascolator bowl. When the drain valve is operated to check for water, this dirt also is drained out and some will get trapped on the O ring seal of the drain valve. After some time, the O ring will start to weep and you will get stains on the belly, particularly with blue AVGAS. My fix for this problem was to install an additional small glass filter in the gascolator bowl drain line (e.g. ACS #804 or the original kit filter). I have never had to clean this secondary filter. Cheers, John N262WF, mono XS, 912S Mooresville, North Carolina ________________________________________________________________________________
Subject: rear access platform/tray/trolley/creeper query
Date: Jul 22, 2013
I recall that a while back someone mentioned a device he had constructed to make getting down the back of the fuselage a little easier or at least less uncomfortable. It was essentially just a platform that straddled the pitch pushrod, but there were some good features that seemed to me very clever. I thought I had filed the details away for when I'd need them, but now I can find no trace of the device nor can I remember who presented it. (I think it was even named with a smart acronym.) Any pointers welcomed, and apologies to the originator in advance for being so careless as to lose his excellent piece of design. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Subject: Re: rear access platform/tray/trolley/creeper query
Date: Jul 22, 2013
Rowland Search for all posts by ALAN CARTER. Regards Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405142#405142 ________________________________________________________________________________
Date: Jul 23, 2013
On 23 Jul 2013, at 07:01, Patrick Tunney wrote: > Search for all posts by ALAN CARTER. Patrick - thanks for the pointer, I found his posting of 22 Jan 2013 with pictures. I had forgotten about that design, which post-dates the one I believe I remember. Alan commented on how much the wood had cost him - I think the one I'm trying to find used less wood and had an elegant but simple design, so I'm still open to pointers towards that one if anyone else can remember it. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Date: Jul 23, 2013
Rowland, Although I am not a fan of the gascolator in a Europa, I prefer the Andair. You are so right in wanting to place it as low as possible. Few gascolators work well elevated in the fuselage (the trap function is thwarted) and the unit seal must be 100% as any small leak will cause the pump to loose prime when the fuel is pulled through them. I would have no problem with mounting it under the fuselage with the bowl out in the air and fabricating an aerodynamic fairing to cover it. The cover would need a hole in the bottom for quick draining. One quick turn fastener on the front and back and the whole cover would come off and the device would be serviceable. A desireable but very cramped area would be in the center under the pitch tube and between the tanks. If you make the hole a half inch larger than the bowl it should allow service work. Access holes don't scare me as you must just take the time to put the structure back into the fuselage. Easy to do under construction, but messy with a completed aircraft. Regards, Bud Yerly ----- Original Message ----- From: Rowland Carson<mailto:rowlandcarson(at)gmail.com> To: Europa e-mail list list Sent: Sunday, July 21, 2013 5:09 PM Subject: Europa-List: andair gascolator query > I've got an Andair GAS375-M gascolator that I plan to fit in the same compartment as the electric fuel pump. Obviously it is desirable to have it mounted with the bottom near the bottom skin of the fuselage so that the drain can be easily activated. However, it's necessary also to have room to remove the bowl. That means cutting an access hole in the bottom skin. Has anyone already got a LAA mod number that includes that sort of thing? I suppose (plan B) it would also be possible to mount the gascolator sufficiently high that the bowl could be removed from inside the aircraft, but that would mean the drain would be a long way from the fuselage floor and so not easy to operate from outside. Maybe it could also be operated from inside if the sample cup is small enough? Any thoughts? in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | > http://www.rowlandcarson.org.uk> | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson landcarson> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Jul 24, 2013
Rowland, I have an Andair minigascolator behind the tanks accessed thru a flap and with a drain tap in its bottom, approved by LAA and very serviceable. Regards David Joyce GXSDJ "Bud Yerly" wrotek > Rowland, > Although I am not a fan of the gascolator in a Europa, I >prefer the Andair. You are so right in wanting to place >it as low as possible. Few gascolators work well >elevated in the fuselage (the trap function is thwarted) >and the unit seal must be 100% as any small leak will >cause the pump to loose prime when the fuel is pulled >through them. I would have no problem with mounting it >under the fuselage with the bowl out in the air and >fabricating an aerodynamic fairing to cover it. The >cover would need a hole in the bottom for quick draining. > One quick turn fastener on the front and back and the >whole cover would come off and the device would be >serviceable. A desireable but very cramped area would >be in the center under the pitch tube and between the >tanks. If you make the hole a half inch larger than the >bowl it should allow service work. Access holes don't >scare me as you must just take the time to put the >structure back into the fuselage. Easy to do under >construction, but messy with a completed aircraft. > > Regards, > Bud Yerly > ----- Original Message ----- > From: Rowland Carson<mailto:rowlandcarson(at)gmail.com> > To: Europa e-mail list >list > Sent: Sunday, July 21, 2013 5:09 PM > Subject: Europa-List: andair gascolator query > > >> > > I've got an Andair GAS375-M gascolator that I plan to >fit in the same compartment as the electric fuel pump. >Obviously it is desirable to have it mounted with the >bottom near the bottom skin of the fuselage so that the >drain can be easily activated. However, it's necessary >also to have room to remove the bowl. That means cutting >an access hole in the bottom skin. Has anyone already got >a LAA mod number that includes that sort of thing? > > I suppose (plan B) it would also be possible to mount >the gascolator sufficiently high that the bowl could be >removed from inside the aircraft, but that would mean the >drain would be a long way from the fuselage floor and so >not easy to operate from outside. Maybe it could also be >operated from inside if the sample cup is small enough? > > Any thoughts? > > in friendship > > Rowland > > | Rowland Carson ... that's Rowland with a 'w' >... > | >> >
http://www.rowlandcarson.org.uk> > | Skype, Twitter: rowland_carson Facebook: Rowland >Carson > | pictures: >http://picasaweb.google.com/rowlandcarson> > > > > http://www.matronics.com/Navigator?Europa-List> > http://www.matronics.com/contribution> > > > ________________________________________________________________________________
Subject: Oshkosh Bound
Date: Jul 24, 2013
The three builders/owners/operators of Europa XS Tri-Gear G-CHOX will be at Oshkosh all week: Goff Moore, Ian Swankie, Peter Field. Any other Europa enthusiasts going? It would be good to meet up. You can email us direct on goffmoore(at)aol.com Excited already. Goff Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=405220#405220 ________________________________________________________________________________
Subject: aileron SLOP
Date: Jul 24, 2013
It appears that over the years the dimensions of the aileron control system have changed, and I now have about 3/4inch (19mm) or less travel slop between the ailerons - not a good thing. From the wing bottom windows, it appears to be inboard of the fuselage as there is no slop in the outer wing areas that I could find. I would appreciate any advice as to how to adjust same to cancel this motion. I realise someone has probably already covered this ground, but am jiggered if I can remember how to find it. Cheers, Ferg C-FFGG mono 914 CS prop ________________________________________________________________________________
Subject: Re: Oshkosh Bound
Date: Jul 24, 2013
Hi Goff, Yip, I'm here again as usual this year..just revived today LOL! ....drove in. My trailer (21' trailcruiser with gold honda van) is located right outside the tower service entrance, with a white board on the side for meet up notes. It is Under the big maple tree in the very first front yard of the private house in front of the gate (where the bus stop is near). There is also a blue cooler with light beer in it for the Europa Clan. come stop by! I'm here and all set up now lol :-) Cheers and blue skies (and safe flights to all those flying in) Pete A239 On Jul 24, 2013, at 4:41 AM, "goff" wrote: > > The three builders/owners/operators of Europa XS Tri-Gear G-CHOX will be at Oshkosh all week: Goff Moore, Ian Swankie, Peter Field. > > Any other Europa enthusiasts going? It would be good to meet up. You can email us direct on goffmoore(at)aol.com > > Excited already. > > Goff > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405220#405220 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 24, 2013
Hi Pete, Look forward to seeing you next week! Christoph #223 almost finished.... Sent from my iPad On 2013-07-24, at 1:11 PM, "Pete" wrote: > > Hi Goff, > > Yip, I'm here again as usual this year..just revived today LOL! ....drove in. My trailer (21' trailcruiser with gold honda van) is located right outside the tower service entrance, with a white board on the side for meet up notes. It is Under the big maple tree in the very first front yard of the private house in front of the gate (where the bus stop is near). There is also a blue cooler with light beer in it for the Europa Clan. come stop by! I'm here and all set up now lol :-) > > Cheers and blue skies (and safe flights to all those flying in) > Pete > A239 > > > > > > > > On Jul 24, 2013, at 4:41 AM, "goff" wrote: > >> >> The three builders/owners/operators of Europa XS Tri-Gear G-CHOX will be at Oshkosh all week: Goff Moore, Ian Swankie, Peter Field. >> >> Any other Europa enthusiasts going? It would be good to meet up. You can email us direct on goffmoore(at)aol.com >> >> Excited already. >> >> Goff >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=405220#405220 > > > > > ________________________________________________________________________________
Date: Jul 24, 2013
Pete & Chris, I should be arriving late tomorrow afternoon if weather cooperates. I'll be camping in a pop-up in Camp Schollar. I'll be sure to stop by the trailer to say "Hi" once I'm settled. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jul 24, 2013, at 11:10 AM, Pete wrote: Hi Goff, Yip, I'm here again as usual this year..just revived today LOL! ....drove in. My trailer (21' trailcruiser with gold honda van) is located right outside the tower service entrance, with a white board on the side for meet up notes. It is Under the big maple tree in the very first front yard of the private house in front of the gate (where the bus stop is near). There is also a blue cooler with light beer in it for the Europa Clan. come stop by! I'm here and all set up now lol :-) Cheers and blue skies (and safe flights to all those flying in) Pete A239 ________________________________________________________________________________
Date: Jul 24, 2013
From: Paul McAllister <paul.the.aviator(at)gmail.com>
I plan on being there on Thursday and Friday. I will probably drive. - Paul ________________________________________________________________________________
Date: Jul 24, 2013
Rowland, I put mine under the baggage bay with a small door for access. If you airplane is closed up then this will be a bit of a pain to install. I know that this is taking the thread a bit off topic, and you are LAA constrained but if I was to do it over again I would install two, one in the main line and one in the reserve to remove a single point of failure. I have not ever seen enough debris in mine to cause a problem but I recall Alex Bowman (?) landing out because fine rust passed though his funnel strainer but clogged his gascolator. Not sure if it was an Andair I with Bud when it comes to Andairs, they are the "gold standard" and the new filter element has a much larger area than the original. It would take a lot of crud to block it. Regards, Paul On Tue, Jul 23, 2013 at 11:40 AM, Bud Yerly wrote: > ** > Rowland, > Although I am not a fan of the gascolator in a Europa, I prefer the > Andair. You are so right in wanting to place it as low as possible. Few > gascolators work well elevated in the fuselage (the trap function is > thwarted) and the unit seal must be 100% as any small leak will cause the > pump to loose prime when the fuel is pulled through them. I would have no > problem with mounting it under the fuselage with the bowl out in the air > and fabricating an aerodynamic fairing to cover it. The cover would need a > hole in the bottom for quick draining. One quick turn fastener on the > front and back and the whole cover would come off and the device would be > serviceable. A desireable but very cramped area would be in the center > under the pitch tube and between the tanks. If you make the hole a half > inch larger than the bowl it should allow service work. Access holes don't > scare me as you must just take the time to put the structure back into the > fuselage. Easy to do under construction, but messy with a completed > aircraft. > > Regards, > Bud Yerly > ________________________________________________________________________________
Subject: Re: aileron SLOP
Date: Jul 24, 2013
Ferg, If you take off the wings, fix the yoke and the aileron and then wiggle the w iggly bits where the wing root and the CM meet you should feel any slop, to t ell you where to look. Should there be no slop, I would guess there is a misalignment of the wiggly parts or perhaps the tufnel spacer on its mating face has departed? Brgds, Alex Kaarsberg Em 24/07/2013, =C3-s 12:07, escreveu: > It appears that over the years the dimensions of the aileron control syste m have changed, and I now have about 3/4inch (19mm) or less travel slop betw een the ailerons - not a good thing. =46rom the wing bottom windows, it appe ars to be inboard of the fuselage as there is no slop in the outer wing area s that I could find. > I would appreciate any advice as to how to adjust same to canc el this motion. I realise someone has probably already covered this ground, b ut am jiggered if I can remember how to find it. > Cheers, Ferg > C-FFGG mono 914 CS prop > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
From: "Kingsley Hurst" <kingsnjan(at)westnet.com.au>
Date: Jul 25, 2013
Hello Ferg, I suspect the problem is most likely in one or both of the aileron quick connect mechanisms but before checking them firstly ensure ALL rod end fittings and associated bolts within the whole aileron circuit are properly tightened. Also check that one of the tufnol pads on the quick connects has not come adrift. Assuming everything aforementioned is tight and/or in place, get a helper to hold the control stick progressively in the full left, centre and full right positions while you check the free movement of one aileron at a time in all of those positions. If you find the free movement varies when in each of those positions, the problem will likely be one of misalignment of the bolts on which the quick connects pivot. Check the other aileron in the same manner. If you once had no free play as you describe but do now, I suspect there might have been a collision in a quick connect mechanism during the rigging or de-rigging of the wings at some time. If the problem IS found to be one of misalignment of the quick connect pivot bolts, we will have to discuss a method for fixing this later. Hope this is of some help mate. Cheers from your antipodean cousin Kingsley ----- Original Message ----- From: f.kyle(at)sympatico.ca To: 5EUROPALIST Sent: Thursday, July 25, 2013 1:07 AM Subject: Europa-List: aileron SLOP It appears that over the years the dimensions of the aileron control system have changed, and I now have about 3/4inch (19mm) or less travel slop between the ailerons - not a good thing. From the wing bottom windows, it appears to be inboard of the fuselage as there is no slop in the outer wing areas that I could find. I would appreciate any advice as to how to adjust same to cancel this motion. I realise someone has probably already covered this ground, but am jiggered if I can remember how to find it. Cheers, Ferg C-FFGG mono 914 CS prop No virus found in this message. Checked by AVG - www.avg.com 07/24/13 ________________________________________________________________________________
Date: Jul 25, 2013
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Fergus=0AKingsley has sais it all I think. Until source of play identified that is.=0AGraham=0A=0A=0A=0A________________________________=0A From: King sley Hurst =0ATo: europa-list(at)matronics.com =0ASe nt: Thursday, 25 July 2013, 12:04=0ASubject: Re: Europa-List: aileron SLOP =0A =0A=0A=0A =0AHello Ferg,=0A-=0AI suspect the problem is most likely i n one or both =0Aof the aileron quick connect mechanisms but before checkin g them =0Afirstly-ensure ALL rod end fittings and =0Aassociated bolts wit hin the whole aileron circuit are properly tightened.- =0AAlso check that one of the tufnol pads on the quick connects has not come =0Aadrift.=0A- =0AAssuming everything aforementioned is tight and/or =0Ain place, get a he lper to hold the control stick progressively in the full left, =0Acentre an d full right positions while you check the free movement of one aileron =0A at a time in all of those positions.- If you find the free movement varie s =0Awhen in each of those positions, the problem will likely be one of mis alignment =0Aof the bolts on which the quick connects pivot.- Check the o ther aileron in =0Athe same manner.=0AIf you once had no free play as you d escribe but do =0Anow, I suspect there might have been a collision in a qui ck connect =0Amechanism-during the rigging or de-rigging of the wings at some =0Atime.=0A-=0AIf the problem-IS found to be one of =0Amisalignmen t of the quick connect pivot bolts, we will have to discuss a method =0Afor fixing this later.=0A-=0AHope this is of some help mate.=0A-=0ACheers from your antipodean cousin=0A-=0AKingsley=0A-=0A-=0A-=0A-=0A- =0A-=0A-=0A-=0A-=0A----- Original Message ----- =0AFrom: f.kyle@sym patico.ca =0A>To: 5EUROPALIST =0A>Sent: Thursday, July 25, 2013 1:07 AM=0A >Subject: Europa-List: aileron SLOP=0A>=0A>=0A>It appears that over the ye ars the dimensions of the aileron control system have changed, and I now h ave about 3/4inch (19mm) or less travel slop between the ailerons - not a good thing. From the wing bottom windows, it appears to be inboard of the fuselage as there is no slop in the outer wing areas that I could find.=0A >----------- I would appreciate any advice as to how to adjust same to cancel this motion. I realise someone has probably alre ady covered this ground, but am jiggered if I can remember how to find it. =0A>Cheers, Ferg=0A>C-FFGG mono 914 CS prop=0A>href="http://www.matroni cs.com/Navigator?Europa-List">http://www.matronhref="http://forums.matron ics.com">http://forums.matronics.com=0Ahref="http://www.matronics.com/con tribution">http://www.matronics.com/c =0A>No virus found in this message. =0A>Checked by AVG - www.avg.com=0A>Version: 2013.0.3349 / Virus =0A Datab = ________________________________________________________________________________
Subject: First Flight
Date: Jul 25, 2013
She Fly's !!! On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her wheels from the surface of Wombleton Air Field in Yorkshire, UK. First flight was carried out by Very professional Pilot Ivan Shaw. Ivan's first report on landing is, "She fly's beautifully with no problems, balanced well and flight straight and level" There are a few miner tweets required but nothing major required. The Build was started on 20th December 2005. Total build time 7 years 7 Months 4 days and counting. Total hours 1800 Approx. I would like to to take this opportunity to say thank you to all who have given their support over the years. First, my Wife, Adele. Nev Eyre Ivan Shaw Graham Singleton David Glowa Pat Tunney Ian Rickard Roger Bull John Wheeler Andy Draper Bud Yearly LAA Europa Aircraft 2004 If I have missed someone, this is not intentional as, a first flight make the brain become very cloudy or is that the brain is in the clouds? youtube Vid http://www.youtube.com/watch?v=Tl8LCP9lPTQ Now let have some fun!!!! Thank you again Richard Wheelwright. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405293#405293 ________________________________________________________________________________
Date: Jul 25, 2013
Subject: Re: First Flight
Well done Richard. The real enjoyment starts now Mike (G-MLXP) On Jul 25, 2013 3:09 PM, "Richard Wheelwright" wrote: > rpwheelwright(at)yahoo.co.uk> > > She Fly's !!! > On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her wheels > from the surface of Wombleton Air Field in Yorkshire, UK. First flight was > carried out by Very professional Pilot Ivan Shaw. Ivan's first report on > landing is, > "She fly's beautifully with no problems, balanced well and flight > straight and level" > There are a few miner tweets required but nothing major required. > > The Build was started on 20th December 2005. Total build time 7 years 7 > Months 4 days and counting. Total hours 1800 Approx. > I would like to to take this opportunity to say thank you to all who > have given their support over the years. > First, my Wife, Adele. > Nev Eyre > Ivan Shaw > Graham Singleton > David Glowa > Pat Tunney > Ian Rickard > Roger Bull > John Wheeler > Andy Draper > Bud Yearly > LAA > Europa Aircraft 2004 > > > If I have missed someone, this is not intentional as, a first flight make > the brain become very cloudy or is that the brain is in the clouds? > > youtube Vid http://www.youtube.com/watch?v=Tl8LCP9lPTQ > > Now let have some fun!!!! > > Thank you again > Richard Wheelwright. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405293#405293 > > ________________________________________________________________________________
Date: Jul 25, 2013
Congratulations on a job well done, hope to see you around some air rally's in the near future, Best wishes Ivor (G-IVER) On Thursday, 25 July 2013, Michael Davies wrote: > Well done Richard. The real enjoyment starts now > > Mike (G-MLXP) > On Jul 25, 2013 3:09 PM, "Richard Wheelwright" > > wrote: > >> rpwheelwright(at)yahoo.co.uk > 'rpwheelwright(at)yahoo.co.uk');>> >> >> She Fly's !!! >> On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her >> wheels from the surface of Wombleton Air Field in Yorkshire, UK. First >> flight was carried out by Very professional Pilot Ivan Shaw. Ivan's first >> report on landing is, >> "She fly's beautifully with no problems, balanced well and flight >> straight and level" >> There are a few miner tweets required but nothing major required. >> >> The Build was started on 20th December 2005. Total build time 7 years 7 >> Months 4 days and counting. Total hours 1800 Approx. >> I would like to to take this opportunity to say thank you to all who >> have given their support over the years. >> First, my Wife, Adele. >> Nev Eyre >> Ivan Shaw >> Graham Singleton >> David Glowa >> Pat Tunney >> Ian Rickard >> Roger Bull >> John Wheeler >> Andy Draper >> Bud Yearly >> LAA >> Europa Aircraft 2004 >> >> >> If I have missed someone, this is not intentional as, a first flight make >> the brain become very cloudy or is that the brain is in the clouds? >> >> youtube Vid G-IRPW First Flight 24th July 2013<http://www.youtube.com/watch?v=Tl8LCP9lPTQ> >> >> Now let have some fun!!!! >> >> Thank you again >> Richard Wheelwright. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=405293#405293 >> >> >> >> >> >> >> >> ========== >> target="_blank">http://www.matronics.com/Navigator?Europa-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * > > * > > ________________________________________________________________________________
Date: Jul 25, 2013
Well done Michael . on first flight of G-MLXP Regards Bob Harrison G-PTAG From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Michael Davies Sent: 25 July 2013 15:41 Subject: Re: Europa-List: First Flight Well done Richard. The real enjoyment starts now Mike (G-MLXP) On Jul 25, 2013 3:09 PM, "Richard Wheelwright" wrote: She Fly's !!! On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her wheels from the surface of Wombleton Air Field in Yorkshire, UK. First flight was carried out by Very professional Pilot Ivan Shaw. Ivan's first report on landing is, "She fly's beautifully with no problems, balanced well and flight straight and level" There are a few miner tweets required but nothing major required. The Build was started on 20th December 2005. Total build time 7 years 7 Months 4 days and counting. Total hours 1800 Approx. I would like to to take this opportunity to say thank you to all who have given their support over the years. First, my Wife, Adele. Nev Eyre Ivan Shaw Graham Singleton David Glowa Pat Tunney Ian Rickard Roger Bull John Wheeler Andy Draper Bud Yearly LAA Europa Aircraft 2004 If I have missed someone, this is not intentional as, a first flight make the brain become very cloudy or is that the brain is in the clouds? youtube Vid http://www.youtube.com/watch?v=Tl8LCP9lPTQ Now let have some fun!!!! Thank you again Richard Wheelwright. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405293#405293 ========== target="_blank">http://www.matronics.com/Navigator?Europa-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 25, 2013
On Jul 25, 2013, at 7:05 AM, Richard Wheelwright wrote: > > She Fly's !!! Richard...Congratulations !! ...and thanks for the dollop of inspiration to finish up!...Fred ________________________________________________________________________________
Date: Jul 25, 2013
Hi! Richard I somehow must start reading messages like the Chinese, bottom up . I just congratulated Mike Davies so probably he had a hand in it but I didn't intend to steel your show...for G-IRPW Good show. And now take care , my mentor advised to always "keep scared "! Regards Bob Harrison G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Wheelwright Sent: 25 July 2013 15:06 Subject: Europa-List: First Flight --> She Fly's !!! On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her wheels from the surface of Wombleton Air Field in Yorkshire, UK. First flight was carried out by Very professional Pilot Ivan Shaw. Ivan's first report on landing is, "She fly's beautifully with no problems, balanced well and flight straight and level" There are a few miner tweets required but nothing major required. The Build was started on 20th December 2005. Total build time 7 years 7 Months 4 days and counting. Total hours 1800 Approx. I would like to to take this opportunity to say thank you to all who have given their support over the years. First, my Wife, Adele. Nev Eyre Ivan Shaw Graham Singleton David Glowa Pat Tunney Ian Rickard Roger Bull John Wheeler Andy Draper Bud Yearly LAA Europa Aircraft 2004 If I have missed someone, this is not intentional as, a first flight make the brain become very cloudy or is that the brain is in the clouds? youtube Vid http://www.youtube.com/watch?v=Tl8LCP9lPTQ Now let have some fun!!!! Thank you again Richard Wheelwright. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405293#405293 ________________________________________________________________________________
Date: Jul 25, 2013
Well done Richard! No you've to fly the baby but take care to post parturient syndrome :-) Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 450 hours F-PLDJ DynAro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures -----Message d'origine----- De: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de Richard Wheelwright Envoy: jeudi 25 juillet 2013 16:06 : europa-list(at)matronics.com Objet: Europa-List: First Flight --> She Fly's !!! On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her wheels from the surface of Wombleton Air Field in Yorkshire, UK. First flight was carried out by Very professional Pilot Ivan Shaw. Ivan's first report on landing is, "She fly's beautifully with no problems, balanced well and flight straight and level" There are a few miner tweets required but nothing major required. The Build was started on 20th December 2005. Total build time 7 years 7 Months 4 days and counting. Total hours 1800 Approx. I would like to to take this opportunity to say thank you to all who have given their support over the years. First, my Wife, Adele. Nev Eyre Ivan Shaw Graham Singleton David Glowa Pat Tunney Ian Rickard Roger Bull John Wheeler Andy Draper Bud Yearly LAA Europa Aircraft 2004 If I have missed someone, this is not intentional as, a first flight make the brain become very cloudy or is that the brain is in the clouds? youtube Vid http://www.youtube.com/watch?v=Tl8LCP9lPTQ Now let have some fun!!!! Thank you again Richard Wheelwright. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405293#405293 ________________________________________________________________________________
Date: Jul 25, 2013
Well done Richard , I knew you would get there in the end! =0AGraham=0ADave Glowa next?=0A=0A=0A=0A=0A________________________________=0A From: Richar d Wheelwright =0ATo: europa-list(at)matronics.com =0ASent: Thursday, 25 July 2013, 15:05=0ASubject: Europa-List: First Flight wright(at)yahoo.co.uk>=0A=0AShe Fly's !!!=0AOn the 24th July 2013 at 16:17 Loc al Time G-IRPW finally lifted her wheels from the surface of Wombleton Air Field in Yorkshire, UK. First flight was carried out by Very professional P ilot Ivan Shaw. Ivan's first report on landing is,=0A- - - "She fly's beautifully with no problems, balanced well and flight straight and level" =0AThere are a few miner tweets required but nothing major required.=0A=0A The Build was started on 20th December 2005. Total build time 7 years 7 Mon ths 4 days and counting. Total hours 1800 Approx. =0A- I would like to t o take this opportunity to say thank you to all who have given their suppor t over the years.=0AFirst, my Wife, Adele.=0ANev Eyre=0AIvan Shaw=0AGraham Singleton=0ADavid Glowa=0APat Tunney=0AIan Rickard=0ARoger Bull=0AJohn Whee ler=0AAndy Draper=0ABud Yearly=0ALAA=0AEuropa Aircraft 2004=0A=0A=0AIf I ha ve missed someone, this is not intentional as, a first flight make the brai n become very cloudy or is that the brain is in the clouds?=0A=0Ayoutube Vi d http://www.youtube.com/watch?v=Tl8LCP9lPTQ=0A=0ANow let have some fun!! !!=0A=0AThank you again=0ARichard Wheelwright.=0A=0A=0A=0A=0ARead this topi c online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=405293#40 ====================== ________________________________________________________________________________
Date: Jul 26, 2013
Congrats, I bet it all seemed too hard at times, but you wont be thinking that now Regards Craig from oz -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Wheelwright Sent: Friday, July 26, 2013 12:06 AM Subject: Europa-List: First Flight She Fly's !!! On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her wheels from the surface of Wombleton Air Field in Yorkshire, UK. First flight was carried out by Very professional Pilot Ivan Shaw. Ivan's first report on landing is, "She fly's beautifully with no problems, balanced well and flight straight and level" There are a few miner tweets required but nothing major required. The Build was started on 20th December 2005. Total build time 7 years 7 Months 4 days and counting. Total hours 1800 Approx. I would like to to take this opportunity to say thank you to all who have given their support over the years. First, my Wife, Adele. Nev Eyre Ivan Shaw Graham Singleton David Glowa Pat Tunney Ian Rickard Roger Bull John Wheeler Andy Draper Bud Yearly LAA Europa Aircraft 2004 If I have missed someone, this is not intentional as, a first flight make the brain become very cloudy or is that the brain is in the clouds? youtube Vid http://www.youtube.com/watch?v=Tl8LCP9lPTQ Now let have some fun!!!! Thank you again Richard Wheelwright. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405293#405293 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Flap pushrod hits pitch pushrod
Date: Jul 25, 2013
Hi Group We're in the process of installing the flap control on our XS Monowheel. We needed to tweak (bend) the pushrod a little to get it to clear the rear liftpin tierod and pitch cross tube. Things are looking about as good as they are going to get. When gear is up or down when the flap pushrod is at rest (1 positive G), the rod is resting on the aft most right side of the tunnel. The thing I'm not crazy about, if I push the flap pushrod port, which would represent negative G's (bouncing on the ground), it can rub on the pitch pushrod, or the head of the front attachment bolt for the pitch pushrod. Have those flying just ignored this, or put some sort of wear block/guide to keep it from the pitch pushrod? Details most welcomed. Thx. Sincerely Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405324#405324 ________________________________________________________________________________
Date: Jul 26, 2013
Congratulations Richard, well done! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405325#405325 ________________________________________________________________________________
From: "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk>
Date: Jul 26, 2013
Thank you all for your kind words. The test flying program is now underway. I hope to be at fly-ins in the not too distant future. Thank you again to all who have helped along the way. -------- Richard Wheelwright G-IRPW First Flight 24th July 2013 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405330#405330 ________________________________________________________________________________
Subject: Re: Flap pushrod hits pitch pushrod
Date: Jul 26, 2013
On Jul 25, 2013, at 11:55 PM, rparigoris wrote: > We needed to tweak (bend) the pushrod a little to get it to clear the rear liftpin tierod and pitch cross tube. Ron...I don't recall having any interference between these components...Fred ________________________________________________________________________________
Date: Jul 26, 2013
Ron, mine does the same. I wrapped it with nylon spiral wrap that is used for cables. Its seems to do a nice job of protecting things. Paul On Fri, Jul 26, 2013 at 1:55 AM, rparigoris wrote: > rparigor(at)suffolk.lib.ny.us> > > Hi Group > > We're in the process of installing the flap control on our XS Monowheel. > > We needed to tweak (bend) the pushrod a little to get it to clear the > rear liftpin tierod and pitch cross tube. > > Things are looking about as good as they are going to get. > > When gear is up or down when the flap pushrod is at rest (1 positive G), > the rod is resting on the aft most right side of the tunnel. > > The thing I'm not crazy about, if I push the flap pushrod port, which > would represent negative G's (bouncing on the ground), it can rub on the > pitch pushrod, or the head of the front attachment bolt for the pitch > pushrod. > > Have those flying just ignored this, or put some sort of wear block/guide > to keep it from the pitch pushrod? > > Details most welcomed. > > Thx. > Sincerely > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405324#405324 > > ________________________________________________________________________________
Subject: G Load testing
Date: Jul 27, 2013
I have seen a few photos on the group over the years with a/c inverted and bags of sand, concrete, gold coins etc stacked evenly on the wings to simulate the G loading, question is how are people supporting the weight for this test through the fuselage itself obviously the top of the cockpit would be insufficient to take such a load of what 8000+ pounds, assuming 6g x 1370lb, or do I have the math wrong on this my thoughts were it may be easier to keep the A/C upright and load the weight into the cockpit with the whole lot supported by cradle and a few extra supports under each wing ________________________________________________________________________________
Date: Jul 26, 2013
Will be there Wed thru Fri! Sent from Iphone On Jul 24, 2013, at 5:54 PM, Paul McAllister wr ote: > I plan on being there on Thursday and Friday. I will probably drive. - Pa ul > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 26, 2013
Friends, Made it today by pickup. Long story but here. Camper on the corner of Scha ick Ave & 22nd St in Camp Scholler near the Red Barn Store. Sent from my iPhone On Jul 26, 2013, at 18:06, Jerry Rehn wrote: Will be there Wed thru Fri! Sent from Iphone On Jul 24, 2013, at 5:54 PM, Paul McAllister wr ote: > I plan on being there on Thursday and Friday. I will probably drive. - Pa ul > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jul 26, 2013
LOL... Should have read Schaick Ave & forty second St .... good thing i wa s on a bicycle .;-) Great to finally meet you in person Bob! My trailer cooler is stocked if any folks want to drop by (right at the towe r/bus stop service gate) Cheers, Pete Ps the weather is perfect....more like Ottawa Canada than the hot Midwest th is year :-) On Jul 26, 2013, at 7:18 PM, Robert Borger wrote: > Friends, > > Made it today by pickup. Long story but here. Camper on the corner of Sc haick Ave & 22nd St in Camp Scholler near the Red Barn Store. > > Sent from my iPhone > > On Jul 26, 2013, at 18:06, Jerry Rehn wrote: > > Will be there Wed thru Fri! > > Sent from Iphone > > On Jul 24, 2013, at 5:54 PM, Paul McAllister w rote: > >> I plan on being there on Thursday and Friday. I will probably drive. - P aul > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 27, 2013
Subject: Re: G Load testing
wrong thought Craig. It has to be done the standard way. Design load is 4.5 G (from dilute memory)=0ADon't try it without a qualified Inspector, easy to break something.=0AGraham=0A=0A=0A=0A=0A________________________________ =0A From: craig <craigb(at)onthenet.com.au>=0ATo: europa-list(at)matronics.com =0ASent: Saturday, 27 July 2013, 0:00=0ASubject: Europa-List: G Load testin au>=0A=0AI have seen a few photos on the group over the years with=0Aa/c in verted and bags of sand, concrete, gold coins etc stacked=0Aevenly on the w ings to simulate the G loading, question is how are=0Apeople supporting the weight for this test through the fuselage itself=0Aobviously the top of th e cockpit would be insufficient to take such a load=0Aof what 8000+ pounds, assuming 6g x 1370lb, or do I have the math wrong on=0Athis=0A=0Amy though ts were it may be easier to keep the A/C upright and load the=0Aweight =0Ai nto the cockpit with the whole lot supported by cradle and a few extra=0Asu ======================== ________________________________________________________________________________
Date: Jul 27, 2013
Hi Craig, It is a must in Germany and other countries to do a positive static g-load test. You have to support the fuselage very strong and rigid with the bottom upwards. You install the wings level and measure the distance of the wing tips to the floor (using a mixing stick, taped on the wing tip.) Then you have to put weight on (sand sacks or cement sacks with 25 kg each) in an exactly definite position and in three steps, so at the end you will get the full load as required and in the correct position on the wings. After each (loading) step you have to measure the distance from the wingtip end to the floor. After these three steps you remove the load and measure again to get the setting difference of the whole plain before and after the loading procedure. With this test we demonstrate the maximum wing load. We do not do flying load tests as the results can get worse (accident Miles/Sweeting). We have got also wing load tests which failed do to not proper made fuselage. Believe me, when you do this test in the very late phase and you can hear the noise and cracking sound of the fuselage setting and the fuselage is still ok after this, the next some pints of bitter are tasting terrific good. Attached are some info about the set up and procedure of the wing load and tailwing load test. If you need more info, please let me know. Safe and happy flying, Bruno -----Urspr=FCngliche Nachricht----- Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von craig Gesendet: Samstag, 27. Juli 2013 01:00 An: europa-list(at)matronics.com Betreff: Europa-List: G Load testing I have seen a few photos on the group over the years with a/c inverted and bags of sand, concrete, gold coins etc stacked evenly on the wings to simulate the G loading, question is how are people supporting the weight for this test through the fuselage itself obviously the top of the cockpit would be insufficient to take such a load of what 8000+ pounds, assuming 6g x 1370lb, or do I have the math wrong on this my thoughts were it may be easier to keep the A/C upright and load the weight into the cockpit with the whole lot supported by cradle and a few extra supports under each wing ________________________________________________________________________________
Date: Jul 27, 2013
Yes but doesn't there have to be a 50% safety margin on g load After all you could pull nearly 6 g in a turn (80 degrees bank) taking Evasive action for example. But back to the original question how does one support the a/c adequately for the testing in the inverted position From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: Saturday, July 27, 2013 6:44 PM Subject: Re: Europa-List: G Load testing wrong thought Craig. It has to be done the standard way. Design load is 4.5 G (from dilute memory) Don't try it without a qualified Inspector, easy to break something. Graham _____ From: craig <craigb(at)onthenet.com.au> Sent: Saturday, 27 July 2013, 0:00 Subject: Europa-List: G Load testing I have seen a few photos on the group over the years with a/c inverted and bags of sand, concrete, gold coins etc stacked evenly on the wings to simulate the G loading, question is how are people supporting the weight for this test through the fuselage itself obviously the top of the cockpit would be insufficient to take such a load of what 8000+ pounds, assuming 6g x 1370lb, or do I have the math wrong on this my thoughts were it may be easier to keep the A/C upright and load the weight into the cockpit with the whole lot supported by cradle and-> http://forums.matronics.com http://www.===================== No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Re: AW: G Load testing
Date: Jul 27, 2013
Bruno, Thanks for your post -we can trust a German to provide some excellent detail! That photo gives me great confidence in the design - they are bags of cement? Clive :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405403#405403 ________________________________________________________________________________
Date: Jul 27, 2013
Friends, Oops, Schaick Ave & 42nd St in Camp Scholler near the Red Barn Store. Best regards, Robert Borger, President Geowhiziks & Doodlebugging, Inc. Certified Petroleum Geophysicist AAPG#101 3705 Lynchburg Dr. Corinth, TX 76208-5331 (H) 940-497-2123 (C) 817-992-1117 Sent from my iPad On Jul 26, 2013, at 19:18, Robert Borger wrote: > Friends, > > Made it today by pickup. Long story but here. Camper on the corner of Sc haick Ave & 22nd St in Camp Scholler near the Red Barn Store. > > Sent from my iPhone > > On Jul 26, 2013, at 18:06, Jerry Rehn wrote: > > Will be there Wed thru Fri! > > Sent from Iphone > ________________________________________________________________________________
Date: Jul 27, 2013
craig a crit : > > Yes but doesnt there have to be a 50% safety margin on g load > Graig and all, The 50 % margin is for calculation only, especially in a homebuilt. Contrary to popular belief, the 4.5 g load for instance, is a once-in-a-lifetime limit not to be inflicted on the airframe repeatedly. Safe load is considered to be approximately 80% of certified load. > After all you could pull nearly 6 g in a turn (80 degrees bank) taking > > Evasive action for example. > Any airplane can break in flight if mishandled. It would take a really ham fisted pilot to reach as high as 6g. Additionally in peacetime I would advise to only perform avoiding actions ;-) Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jul 27, 2013
Hi Richard Very well done, few people other than other plane builders will appreciate what you have achieved . I hope we will meet again at the LAA Rally. Richard Collings G-CGZV Tri-gear 912ul Woodcomp prop I year old 52 hrs From: Michael Davies Sent: Thursday, July 25, 2013 3:40 PM Subject: Re: Europa-List: First Flight Well done Richard. The real enjoyment starts now Mike (G-MLXP) On Jul 25, 2013 3:09 PM, "Richard Wheelwright" wrote: She Fly's !!! On the 24th July 2013 at 16:17 Local Time G-IRPW finally lifted her wheels from the surface of Wombleton Air Field in Yorkshire, UK. First flight was carried out by Very professional Pilot Ivan Shaw. Ivan's first report on landing is, "She fly's beautifully with no problems, balanced well and flight straight and level" There are a few miner tweets required but nothing major required. The Build was started on 20th December 2005. Total build time 7 years 7 Months 4 days and counting. Total hours 1800 Approx. I would like to to take this opportunity to say thank you to all who have given their support over the years. First, my Wife, Adele. Nev Eyre Ivan Shaw Graham Singleton David Glowa Pat Tunney Ian Rickard Roger Bull John Wheeler Andy Draper Bud Yearly LAA Europa Aircraft 2004 If I have missed someone, this is not intentional as, a first flight make the brain become very cloudy or is that the brain is in the clouds? youtube Vid http://www.youtube.com/watch?v=Tl8LCP9lPTQ Now let have some fun!!!! Thank you again Richard Wheelwright. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405293#405293 ========== target="_blank">http://www.matronics.com/Navigator?Europa-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
From: "A. Buess - Aviatik" <ykibuess(at)bluewin.ch>
Date: Jul 27, 2013
Clive, We made a strong steel support for the wings to avoid any damage to the fuselage. I published a short report about our load test with some pictures in the Europa Flyer #30, that you can find on the Europa Club website. The load test is worth wile, but it is thrilling! Good luck Alfred -------------------------------------------------- Alfred Buess CH-3700 Spiez, Switzerland Email ykibuess(at)bluewin.ch Europa XS HB-YKI, Ercoupe 415-E N94804 -----Ursprngliche Nachricht----- Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von gtagr Gesendet: Samstag, 27. Juli 2013 13:25 An: europa-list(at)matronics.com Betreff: Europa-List: Re: AW: G Load testing Bruno, Thanks for your post -we can trust a German to provide some excellent detail! That photo gives me great confidence in the design - they are bags of cement? Clive :D ________________________________________________________________________________
Subject: Re: Rough River, KY Fly In
Date: Jul 27, 2013
Hi All, Not the best week for me as I am scheduled to work, but may be able to get off. Probably chilly then too but I'll take what I can get. Haven't got to fly much this year due to rain every day or a wet field when it's not or work. Hopefully things will get better soon. Hope to see you all there and have a beautiful weekend. Pencil me in. I'll call and get reserved. Thanks. Troy and Donna Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405418#405418 ________________________________________________________________________________
Date: Jul 27, 2013
Bruno, Thanks for your post -we can trust a German to provide some excellent detail! That photo gives me great confidence in the design - they are bags of cement? Clive :D Yes, these are bags of cement, borrowed from a local DIY shop. Bruno -----Urspr=FCngliche Nachricht----- Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von A. Buess - Aviatik Gesendet: Samstag, 27. Juli 2013 14:23 An: europa-list(at)matronics.com Betreff: AW: Europa-List: Re: AW: G Load testing Clive, We made a strong steel support for the wings to avoid any damage to the fuselage. I published a short report about our load test with some pictures in the Europa Flyer #30, that you can find on the Europa Club website. The load test is worth wile, but it is thrilling! Good luck Alfred -------------------------------------------------- Alfred Buess CH-3700 Spiez, Switzerland Email ykibuess(at)bluewin.ch Europa XS HB-YKI, Ercoupe 415-E N94804 -----Urspr=FCngliche Nachricht----- Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von gtagr Gesendet: Samstag, 27. Juli 2013 13:25 An: europa-list(at)matronics.com Betreff: Europa-List: Re: AW: G Load testing Bruno, Thanks for your post -we can trust a German to provide some excellent detail! That photo gives me great confidence in the design - they are bags of cement? Clive :D ________________________________________________________________________________
Date: Jul 27, 2013
Does anyone have any photos that show the entire wing under load where I can see the deflection? On Sat, Jul 27, 2013 at 6:24 AM, gtagr wrote: > > Bruno, > Thanks for your post -we can trust a German to provide some excellent > detail! That photo gives me great confidence in the design - they are bags > of cement? > Clive :D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405403#405403 > > ________________________________________________________________________________
Date: Jul 27, 2013
Subject: Replacement tailwheel
Hi All, I still have my original 10 y/o tailwheel on my Europa. Its starting to get a bit worn and hard after 1100 hours so I thought it was getting time to replace it. I ordered a tailwheel for an RV from AC Spruce but when it arrived I discovered that the tread width is 1.5" and the one on my airplane is 2". I have been searching around for something that is 6 x 2 " and I found that Colson casters make one. It is a 400 lb rating and roller bearings. I am using 4" Colson casters for my out riggers and they seem to hold up to the landing speeds. I was wondering what others have dome for replacement tail wheels, and has anyone tried Colson as a tail wheel. BTW, the AC Spruce wheel cost $125, the Colson wheel cost $11.50 ! Thanks- Paul ________________________________________________________________________________
Subject: Old Classic needs upgrade to 912S 100hp
Date: Jul 28, 2013
Neville Eyre has kindly given me answers to some questions and also pointed out that the newer 912S has a larger starter motor, which won't fit into my old-style engine bearer frame. So I'm going to need to acquire a new-ish engine (few 100 hours) with the smaller starter. How much of a "rod for my own back" will I be making by doing this? How much trouble will I have starting? Is it "wrist-slashingly" frustrating? How long before the starter might need replacing? Another serious issue will be engine heat dissipation and Neville has indicated that others have created a "gob" in the cowling below the propeller, directing 1/3 of its air through the oil cooler and 2/3 through the shrouds covering the cylinders. Please would you help me by sending pictures of such a "gob" intake and also of the additional cooling modifications inside the cowling. All suggestions for effecting this modification and any associated diagrams will be gratefully received. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405476#405476 ________________________________________________________________________________
Date: Jul 28, 2013
The issue of load testing should be approached very carefully. as a30+ experienced aeronautical engineer, Chief of Stress at Pilatus Aircraft hopefully l can assist with a few pointers. The design load level LIMIT loading is determined from the certification basis (or approval basis) of the aircraft. For LAA projects this is likely to be +4/-2, without the consideration of gusts. The VN diagram submitted by Europa for the original will be basis that needs to be used. Additional factors applicable will include the ULTIMATE factor, usually 1.5, Special Factors, these could include a factor for composites (usually negotiated as 1.5 to account for hot humid material property degradation), plus others that are agreed with the approving/certifying agency. For a wing bending test, which is important but NOT the only test that is required, the calculation for total load would be 621kg x 4 x1.5 x1.5 - (wing mass). The wing mass can be left on and is conservative). This makes a total mass of 5590kg or 2790kg per wing for Europa XS. The next step is to determine the spanwise and chordwise distribution of this load. There are many issues to be considered here, however, a justification of the distribution used, coupled with the correct angle of attach, is sufficient. Other cases with loader total loading may be more critical, such as torsional cases driven by manoeuvre control inputs or flap loads should also be considered. Typically for an aircraft of the Europa class the load calcs take around 200-1000hrs. A test plan to cover the critical ones needs to be created and submitted for approval (and often observation) by the authorities. It is normal to correlate test data with predictive calculations (done using a combination of finite element models and hand calcs). Hence the test is normally a confirmation of the predicted structural performance (deformed shape, stress/strain levels, failure locations if ULT+ loads are applied. A light aircraft design and certification can absorb many 10,000 of man hours. Typically around 20 to 50 times the retail price of the aircraft (rough guide as the cost curve is exponential). Making the design certification cost of a 750kg VLA around 2 to 5 million. Hopefully this has been useful to someone? Regards John -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405477#405477 ________________________________________________________________________________
Date: Jul 28, 2013
Incidentally l counted 43 bags per wing at 25kg per bag making a per wing total of 1075kg, loaded to 38% ULT. Which identifies the normal issues, the loading method is not appropriate for the required mass. A higher density material or a whiffle tree is required. Regards JW -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405478#405478 ________________________________________________________________________________
Subject: Re: Old Classic needs upgrade to 912S 100hp
Date: Jul 28, 2013
Jonathan, After I put 1000 hours on the 912UL in my classic, I replaced it with a 912ULS using the original classic starter plus a Skydrive Soft Start Module and their Carb Heat Kit too. I now have over 1000 hours on this setup too and as long as the battery is in good condition it starts just fine, summer or winter. Dave Watts Classic Monowheel G-BXDY On 28 Jul 2013, at 10:31, "jonathanmilbank" wrote: > > Neville Eyre has kindly given me answers to some questions and also pointed out that the newer 912S has a larger starter motor, which won't fit into my old-style engine bearer frame. So I'm going to need to acquire a new-ish engine (few 100 hours) with the smaller starter. > > How much of a "rod for my own back" will I be making by doing this? How much trouble will I have starting? Is it "wrist-slashingly" frustrating? How long before the starter might need replacing? > > Another serious issue will be engine heat dissipation and Neville has indicated that others have created a "gob" in the cowling below the propeller, directing 1/3 of its air through the oil cooler and 2/3 through the shrouds covering the cylinders. > > Please would you help me by sending pictures of such a "gob" intake and also of the additional cooling modifications inside the cowling. All suggestions for effecting this modification and any associated diagrams will be gratefully received. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405476#405476 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 28, 2013
Hi Paul, Here are some pictures. 02+04 is preparation with a soft foam blanket on which we also marked the position of the concrete bags, each 25 kg. 07 shows the support winches, which you can release very slowly and jumpless 15 shows the measurement after each load increase, 16+17 the full load of each side and 21 the full load spread. Each side 1035 kg concrete bags, therefore 2.070 kg in total. To this you have to add the wing weight of 94-100 kg complete, depends on build. The winches were released free (you can see it on the loose foam supports). One problem was that the support timber sticks were too short, so that we had to do some work on the wing surface later. A similar test was also done with the tail plane 100 to 150 kg and opposite (pictures 9839, 9842 and 9845 With picture 9854 you can see, that this load test on a classic one failed. The fuselage/cockpit was not correct made and the fuse started to bulk out. This was later repaired and than ok. This is the wing load test, approved by the OUV and LBA here in Germany Bruno _____ Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Paul McAllister Gesendet: Samstag, 27. Juli 2013 17:34 An: europa-list(at)matronics.com Betreff: Re: Europa-List: Re: AW: G Load testing Does anyone have any photos that show the entire wing under load where I can see the deflection? On Sat, Jul 27, 2013 at 6:24 AM, gtagr wrote: Bruno, Thanks for your post -we can trust a German to provide some excellent detail! That photo gives me great confidence in the design - they are bags of cement? Clive :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405403#405403 ========== target="_blank">http://www.matronics.com/Navigator?Europa-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 29, 2013
Thanks john this "For a wing bending test, which is important but NOT the only test that is required, the calculation for total load would be 621kg x 4 x1.5 x1.5 - (wing mass). The wing mass can be left on and is conservative). This makes a total mass of 5590kg or 2790kg per wing for Europa XS." Is more or less what I was expecting, I take it the extra 1.5 multiplier is for the Composite factor you mentioned Regards craig ________________________________________________________________________________
Subject: Tri-gear Flap Cross Tube Slot Length
Date: Jul 29, 2013
Gidday, Building a taildragger version I am not constrained by gear/flap geometry to determine the flap I can deploy, since they will be electric. I feel I recall the tricycle undercarriage versions can deploy 30 degrees of flap and I was wondering if someone with that amount could measure the length of their slots as a guide whilst I remove the fuse material. I don't have the cross tube connected to the flap motor as yet, and am doing it by sanding the slots incrementally as I lower the flaps, as I didn't trust myself with the jig I made up. (I'm getting tired of fixing my mistakes). Thanks in advance. Regards Tony Renshaw Sydney Aussie ________________________________________________________________________________
Subject: Re: Tri-gear Flap Cross Tube Slot Length
Date: Jul 28, 2013
Hi Tony I just did this job on my Mono and will explain the way I did it, which seems to be a good way to do it, but first: I have read that if you drop the flaps more than the book value of 27 degrees (target is 26-27, do not exceed 27), that yes you will produce a little more lift (and drag), but you can become airborne with ailerons that are less than effective. I think the factory mentioned this in older Tech Talk. Check with others. I am only speaking from what I read, not someone who has flown with more. For me no more than 27 degrees. Now for flap cross tube slot, I took a 1/2"steel rod, about 6" long and bored a hole in it the precise diameter of the flap drive pin. I then made a slot 3/4" in diameter to allow 27 degrees of flap travel with the 1/2" rod on the flap drive pin sticking inside the fuse. Then I turned a piece of aluminium that's the diameter of the flap cross tube, about 1.25" long (plus two thicknesses of 80 grit sandpaper), with one side cut at a 30 degree angle and then bored a 1/2" hole in the center where this is now a nice slip fit onto my 1/2" rod. Now with a helper, I threw the flap from retracted to 27 degrees with the 1/2" rod on the flap drive pin and with the 30 degree angle of the aluminium rod set on the 1/2" rod, just used the point of the tip of the 30 degree angle pushed against the fuse and traced with a pencil the needed slot. Mind you this is not a perfect slot because the flap drive pin is not perpendicular with the fuse, but close enough to allow full throw without going "too much". It ends up that a closet wood pole is the same diameter as the flap cross tube, so I just stuck some 80 grit and had a terrific sanding bar. Once I have everything set up exactly as I want and can cycle the gear, or in your case actuate the motor, I will just take a carpenters pencil, cut down to about an inch long and sharpened to give desired clearance, and mark the fuse by resting the pencil on the flap cross tube, using the flap cross tube as a guide. By using the flap cross tube as a guide, this will make the perfect mark to follow. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405533#405533 ________________________________________________________________________________
Date: Jul 28, 2013
Subject: Fixing misaligned spar bush
I just noticed that one of the port wing's spar bush seems slightly misaligned. This is the bush near the inboard tip. It is recessed a bit to much on one side, and protrudes a bit too far on the other side of the spar. It also looks like it might be a tilted. As a result, I am unable to slide the spar socket over it. I expect this will be a problem when rigging (which I haven't done yet). Is there a fix for this? I was hoping that I can use some heat to soften the area and reposition that bush. Does that sound like a safe thing to do? ________________________________________________________________________________
Subject: Flap Deployment Limit for an Electric Flap Aircraft
Date: Jul 29, 2013
Gidday again, Does anyone know of someone with greater than the 27/30 degrees of flap deployable, and could I get their contact details? I'm interested in knowing what the handling differences are, and appreciate the aircraft has not been flight tested with greater than 30 degrees. I have electric flaps, so it appears to me as I do that setup that a greater range is available, albeit it does increase the size of the slots in the fuselage which might need to be reinforced should this occur. Regards Tony Renshaw Sydney Aussie ________________________________________________________________________________
Subject: Re: Fixing misaligned spar bush
Date: Jul 28, 2013
Hi Andrew First thing is you want to make sure that you can mate both wings together and pin them together with the spar pins. Distance and alignment are critical here. Then you want to make the bushings on the cockpit module to match the spar pins. Bay, you really want to make sure the spar bushings in the wing are stuck and will not change. If you heated a pin the size of the spar bushings I'm pretty sure you could soften and perhaps realign. That said I would speak with Bud or Europa. If I had to do it without guidance, I may remove the suspect bushing, really scuff sand things good and Redux/flox in place. Another thing I would look at is I have a set of glider wings. With the glider wings you are supposed to match the wings to your bushings in the cockpit module, so the wings are not drilled for the spar holes. You drill and install the spar bushings. The bushings I think are kinurled and look like they would take very well to Redux/Floxing in place. I don't know if the dimensions are the same as the short wing bushings and if they take better to bonding in p[lace, but worth investigating. Especially on my port wing, I have taken a rubber mallet and beat my port spar pip pin into position, especially after rigging "too" many times in a day. Normally I use a deep socket that fits my port pip pin arm perfectly with a 3" extension and use that to lever in place. I usually use carnuba wax to wax the pins. Last time rigging I used a rubber mallet softly as my arm was pretty tired. If the bushing was marginal held in place and let go, that for sure would be a pain. If you don't get an answer, I can take a picture with dimensions of the glider wing spar bushing if you like. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405542#405542 ________________________________________________________________________________
Subject: Re: Flap Deployment Limit for an Electric Flap Aircraft
Date: Jul 28, 2013
Hi Tony I just took a look at the Tri final checklist and they state 27 degrees maximum (same as monowheel). If no one replies, if you read up on the old Europa Tech Talk, there is a blurb that they flew with more than 27 degrees and aileron control was less than stellar. Mind you that is probably on a Classic, and I think the wingspan on a Classic as well as the aileron length is smaller as compared to an XS (I have an XS Monowwheel). I think I read on the group a while back, I think perhaps it was in Africa (?) a guy needed better short field performance and increased flap travel and was somewhat happy with results? For me, I am going to adjust things so I have enough extra travel so I get my outriggers down and locked easily, no more than 27 degrees. A little less is OK by me (like 26). Think about it, take off from grass, bumpy, gusty, get premature launched from dip/gust, of course left cross wind, now right wing drops. Boy, bad situation, leave ailerons semi neutral and step on left rudder and hard. If you throw in a lot of left aileron, you will be increasing the angle of attack on the right wing and may stall it. Above scenario will be worst with 30 degrees than 26 degrees of flaps. Fixed pitch 912, plenty heavy, flying off grass with a high density altitude is going to be far worst than a light 914 off of pavement. I know that my 914 is going to have the Turbo quit, when I'm heavy, flying off of grass, tire pressure a bit low, when it's gusty and my Airmaster controller is going to command a full course at the precise time when the Long Island Sea Breeze gives me a stiff tailwind when I get prematurely launched during take off. Forward slips do a pretty good job increasing drag, just don't raise nose too high. It's true you want to keep the Rotax at 1,800 RPM to make the gearbox happy if you can, but in flight you are going to increase landing distance by a lot. Best tweak engine so it's precisely balanced and happy with a low idle like 1,450 or even a tad bit lower, and only use that low setting during landing, then when on the ground increase to minimum 1,800. Above said, I read of someone putting foam to decrease gap during cruise between the flap and wing. Off the cuff I would think that the foam would make a big disruption to the airflow over the lead edge of the flaps when in the down position, he said he didn't notice much difference. Go figure. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405543#405543 ________________________________________________________________________________
Subject: Is bonding FL16 to fuse a bad idea?
Date: Jul 28, 2013
Hi Group In the very near future I need to bond FL18P and FL18S to the bottom of my fuse. These are the the two hinge brackets that get bolted to the fuse after you bond in place with 4 fasteners. When bonding these in place, you need to try and get them parallel to each other, parallel to the center-line of the fuse while making sure that the pivot holes are aligned with both of your inboard flap hinges (W19s). I'm thinking I will bond my two FL18P and FL18S to a piece of wood (like Fred Klein did) to keep them parallel to each other and in the same plain. The thing is after you goop things up with Redux/flox and ready to bond into position, lefty/righty needs to be in proper position in relation to the flap cross tube and the fore/aft and vertical needs to be in alignment with both the starboard and port inboard center-line of the inboard W19 flap hinges. I'm thinking pretty hard I want to bond both of my FL16s to my fuse with Bondo. The FL16s are the hinge arms that get mounted to the flap cross tube with two fasteners. You see if these FL16s are temporarily bonded in position, once my FL18P + S are temporarily bonded to a piece of wood, then I goop them up with Redux/flox, set into position and I can insert actual pivot hardware between FL18P+ S and FL16s to make sure pivot hole alignment is perfect with inboard W19 flap hinges. Question: Is a bad idea? Or is there an easier way? I just turned two aluminium bushings that center sewing thread in the .1875 ' diameter holes of W19s. Using a mini center drill and a finger pressure only drill chuck, drilling the .0145" holes was a piece of cake. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405545#405545 ________________________________________________________________________________
Subject: Re: Is bonding FL16 to fuse a bad idea?
Date: Jul 28, 2013
Ron...see indented comments...Fred On Jul 28, 2013, at 8:51 PM, rparigoris wrote: > I'm thinking pretty hard I want to bond both of my FL16s to my fuse with Bondo. The FL16s are the hinge arms that get mounted to the flap cross tube with two fasteners. After looking at the build manual and my own photos taken during construction, it's my opinion that bonding the FL16s to the fuselage w/ bondo is not a good idea...I believe the key for this step is to ensure that the bolt holes in the FL18s are perfectly aligned w/ those in the W19s...if you want to trial fit the FL16s, do so as long as you can ensure the FL18s are shimmed in perfect alignment and don't move...once the FL18s are reduxed in place and bolted thru the fuse and you've dispensed w/ the alignment string, bolting the FL16s to the FL18s is straightforward. > > You see if these FL16s are temporarily bonded in position, once my FL18P + S are temporarily bonded to a piece of wood, then I goop them up with Redux/flox, set into position and I can insert actual pivot hardware between FL18P+ S and FL16s to make sure pivot hole alignment is perfect with inboard W19 flap hinges. May be I'm missing something, but this sounds backwards...the FL18s should determine the location of the hinge point w/ the FL16s...not the other way around. > > Question: > Is a bad idea? I think so > Or is there an easier way? Follow the manual and align the FL18s as shown in my pixs...but when I say "follow the manual", I certainly do NOT recommend following the SEQUENCE of operations shown in the manual; namely, to do this whole flap installation AFTER the top is bonded on...I understand that you HAVE already bonded on your top and...for the life of me...I simply cannot imagine having to deal with what you're facing...You have my most sincere condolences...though I presume that you have yet to install the baggage bay rear bulkhead...I give a hearty salute to anyone who has managed to install the flap mechanism AFTER the top has been bonded on the bottom fuselage. I did my damnedest to do absolutely EVERYTHING I could possibly do in the tailcone BEFORE bonding on the top and bonding in the ...of course I used many many clecoes to ensure that trial fitting of the top was skookum (in perfect alignment). > I just turned two aluminium bushings that center sewing thread in the .1875 ' diameter holes of W19s. Using a mini center drill and a finer pressure only drill chuck, drilling the .0145" holes was a piece of cake. You be the Zen master Ron...with what you're facing, being a yoga master wouldn't hurt either, Fred ________________________________________________________________________________
Date: Jul 29, 2013
Hi Fred Thx. for the reply. I think I did a poor job of conveying my idea of Bondoing in place a positioning point. In other words what I want to do is bond the FL18P + S to a piece of wood like you did. Then I want to get FL18P + S in perfect alignment with the inboard flap hinges W19s, checking to make sure they are positioned correctly left and right.
July 01, 2013 - July 29, 2013
Europa-Archive.digest.vol-kp
