Europa-Archive.digest.vol-le
February 24, 2014 - March 14, 2014
      Samsung U380 Brightside.............$260
      Samsung I9070 Galaxy S Advance.....$270
      Samsung Galaxy Player 70 Plus......$260
      Samsung I9105 Galaxy S II Plus....$240
      Samsung Galaxy Y S5360.........$220
      Samsung Galaxy Note N7000 .......$270
      Samsung Galaxy Pocket S5300.......$230
      Samsung Galaxy Note SGH-1717.....$250
      Samsung I9100 Galaxy S II.....$200
      Samsung Galaxy Tab 10.1.....$200
      Nokia:
      Nokia Lumia 1520.....$400
      Nokia Lumia 1020.....$350
      Nokia Lumia 925......$330
      Nokia Lumia 928......$300
      Nokia Lumia 920......$290
      Nokia Lumia 820......$280
      Nokia Asha 311......$260
      Nokia 808 PureView....$270
      Nokia N9....$240
      Nokia Lumia 900....$250
      Nokia Lumia 800....$240
      Nokia Lumia 710....$230
      HTC:
      HTC One Max 803s .... $420 USD
      HTC Butterfly S .... $380 USD
      HTC Desire 600 Dual Dim.....$360 USD
      HTC One....$360 USD
      HTC One mini...$350 USD
      HTC First...$350
      HTC Trophy.....$320
      HTC One VX.....$320
      HTC One X+.....$300
      HTC One X......$300
      HTC One XL.....$280
      HTC One S......$270
      HTC One V......$260
      HTC Jetstream....$370
      HTC Panache.....$360
      HTC Butterfly ... $350.00
      HTC Windows Phone 8X......$330
      HTC Tube-5.....$350
      HTC Status.....$330
      HTC Vivid......$250
      Sony Ericsson:
      Sony Xperia Z1 ..... $400 USD
      Sony Xperia Z Ultra .....$380 USD
      Sony Xperia Z .....$370 USD
      Sony Xperia M .....$360 USD
      Sony Xperia L .....$350 USD
      Sony Xperia V .....$340 USD
      Sony Xperia Ion.....$280
      Sony Xperia S.......$260
      Sony Tablet S 3G.......$250
      Motorola:
      Motorola DROID RAZR MAXX......$300
      Motorola MT917......$300
      Motorola XT928......$300
      Motorola RAZR XT912......$290
      Motorola RAZR XT910......$280
      Motorola XOOM 2 Media Edition......$300
      Motorola XOOM 2......$280
      Motorola XOOM Tablet......$180
      Sony PlayStation 4 - 500 GB .... $400 USD
      Other Mobiles:
      LG G2 --- $270
      AT&T Z998 ---- $270
      Google Nexus 5 ----$300
      Others ::
      Xbox One Console..........................$400
      Canon EOS 5D Mark II .... $700
      HP ENVY 14 Beats edition series...... $999.99
      Bose Lifestyle 235 Home Entertainment System ........... $1,599
      Bose Lifestyle V25 Home Entertainment System ........... $1,610
      Apple MacBook Air - Core 2 Duo 2.13 GHz - 13.3 ------ 400.00
      Leica S-Adapter for Hasselblad H-System Lenses
      Leica | 50mm f/0.95 Noctilux M Aspherical Manual Focus Lens
      Leica S - Type 006 - Digital Medium Format Slr Camera Body
      Miller 903471 XMT 304 CC/CV 208-230/460 W/Auto-Link.....$1,700
      PLACE YOUR ORDER WITH US @ MURTEN STORE LTD
      For purchase enquiry you can contact us via any email below... SATISFACTION GUARANTEED
      Contact Name : Stephen Clive Murray
      Email : murtenltd(at)musetr.com
      Skype : murtenltd
      Web :: murt.miiduu.com
      BBM 24Hrs Chat : 27D4D1EE
      MGT
      http://forums.matronics.com/viewtopic.php?p=419232#419232
Subject: Re: Mod 76 - Altitude Hold Autopilot
Date: Feb 24, 2014
Hi Rob Hmm, it looks to me like if you put a some scotch-tape around the nut and jammed in either a box wrench or socket it may work? If you were to use 1/4" socket with lots of extensions and universal/s could you get to the bolt? If not how about using a short, medium or long box wrench? If not, then buy a cheap box wrench, cut, heat up and bend if needed and weld on an extension, or use a box wrench you have and bend up a metal bar and use hose clamps to hold it? Since you are in there, get some inspection lacquer and mark the jam nut for the ball fitting. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419236#419236 ________________________________________________________________________________
Subject: Texel
Date: Feb 24, 2014
Does Tim or Hank or any of our Dutch friends have a date for Texel 2014, please? David Joyce ________________________________________________________________________________
Subject: Mod 76 - Altitude Hold Autopilot
Date: Feb 24, 2014
Nigel: What you describe is almost exactly how I connected the port and starboard pitch push rods to CS10/2, the only difference being that I did not need to magnetize the socket. Both of these connections are relatively easy to reach but that @#$%^&* third horn on CS10/2 is (so far) not within my reach with either fingers or tools. Ron: My problem is access. My combination of universal joints, extensions and sockets will not clear the obstructions which include the support bracket holding CS10/2 and the aileron bell crank where it mounts to the end of CS05 torque tube. In other words, I cannot manage to get the tools to align coaxially with the bolt even if I could get the nut onto the bolt manually, which I can't. Next up: Unless someone presents a simpler solution, I'll remove CS10/2 and attach only the rod end to it and then after CS10/2 is reinstalled, attempt to thread the servo push rod onto the rod end already in place. Only if this fails will I resort to cutting another access port in the bottom of the fuselage. Incidentally, prior to installing CS10/2 I used 5 minute epoxy to hold all of those washers in place and used a greased pin slightly smaller than the size of the bolt holes to maintain alignment during cure. With my many attempts to assemble the rod end to CS10/2 these washers have remained in place. Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of nigel_graham@m-tecque.co.uk Sent: Monday, February 24, 2014 12:11 AM Subject: Re: Europa-List: Mod 76 - Altitude Hold Autopilot Hello Rob, I recently had to strip out and refit the CS10 and had to face the same problem so know exactly what you are up against. There is a solution. Ideally you need a trusty assistant - though I did succeed by myself (it took a whole afternoon though :-( ) I used a long socket, and filled it with spare nuts such that it prevented the nut you are attempting to tighten - sliding down into the barrel of the socket. I magnetised the socket by stroking it a few times with a strong magnet - that ensured that the nut would not drop out. Now the nut can be held precisely. The next bit seems non-intuitive, but tighten the bolt (not the nut) from the other side of the aircraft using your assistant and a long socket drive extension. All you need to focus on is keeping the nut in place (a long socket is easier to hold) until the thread catches. The only other thing to consider is keeping the washers in place until the bolt is inserted - this was done by sticking the washers using a blob of grease. It is possible to achieve without resorting to an angle grinder! Nigel On 23/02/2014 23:52, Rob Housman wrote: Assuming that I am not the only one foolish enough to attempt a retro-fit of Mod 76 (Dynon) to a completed airframe I would appreciate any help from others who have done so. I am currently at an impasse. Removal of CS10 and replacing it with CS10/2 was tedious but relatively straightforward to complete, although the Europa Factory instructions manage to overlook a few essential points. I am stymied by my inability to get the nut on the bolt that attaches the rod end to the horn on CS10/2. With perseverance I managed to get the bolt through the horn on CS10/2 and the rod end, but my not very large hands cannot do both: hold the MS31042-3 nut and rotate it after I get it near the threaded end of the AN3-7A bolt. So far I have failed even to get the nut aligned so the bolt could be turned into the nut. At this point I am considering cutting another access hole in the bottom of the fuselage but only as a last resort would I start cutting. Suggestions? Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress ________________________________________________________________________________
Subject: Re: Texel
Date: Feb 24, 2014
David The Texel airfield website shows the date of the fly as 5-6-7 September. Regards John Europa XL G-JHKP > On 24 Feb 2014, at 16:35, "David Joyce" wrote: > > > Does Tim or Hank or any of our Dutch friends have a date for Texel 2014, please? > David Joyce > > > > ________________________________________________________________________________
From: "Greg Fuchs " <gregoryf.flyboy(at)comcast.net>
Subject: Tufnell bonding to quick connect bellcrank
Date: Feb 24, 2014
Hi William, As others have mentioned, adding flox will keep the glue from running. HINT: A no-sanding method to take up the space between the bellcranks: I don't know if anyone has done this, but I found a pretty slick method to take up the clearance when gluing the 'tuffy' spacer between the bellcranks. Get three 1/16" (or so) strips of double sided foamy tape. The squishy stuff, not the normal double sided tape. Arts and craft store ought to have them. Place the strips full length on each of the long sides of the tufnol, and one in the middle. Carefully place the glue between the strips of tape (not too much), and tenderly press the tufnol spacer into the correct position on the bellcrank. The tape will hold it firm in place so it won't wander around. Assemble the bellcranks together as they would be in normal operation, with all of them bolted onto their swivels. Be sure the aileron weight is unloaded off of the bellcranks (I disconnected mine), so that the mating surfaces are not torqued. You want the surfaces to stay parallel to each other and symmetrical forces all the way along the foam. ..The squishy foam tape acts as a spring to take up the exact gap needed for a zero clearance fit. It also contains the glue between the foam channels so one can avoid using plastic sheeting, which might mess up the gap. The glue will squidge out from the top and bottom a bit though, but it can be carefully wiped away with a q-tip or the like. The foam is sacrificial, and will become a permanent fixture in the plane. Bobs your Uncle! Cheers, Greg Hello everyone I have been trying to bond the piece of Tufnall to the fuselage aerolon quick connect bellcrank. Problem is that the redux simply flows out the bottom of the joint. It is too runny! The build manual describes assembling the wings and letting the bond set in order to achieve a perfect fit. I am sure this problem must have been surmounted by all the builders and it has probably been discussed before. A link to the answer would be appreciated. Thanks William Bliss G-WUFF ________________________________________________________________________________
Subject: Friedrickshafen
Date: Feb 25, 2014
Are our Scandinavian friends planning a group descent on Friedrickshafen this year, and if so are you prepared to have others join and would you like details in the upcoming Europa Flyer? Regards, David Joyce, EC Trips Organiser ________________________________________________________________________________
Subject: Re: where to put OAT sensor?
Date: Feb 25, 2014
Some notes on my mistakes: OAT probe in either the 914 or radiator metal duct work needs an insulator as the ducts warm up and on the second flight and is really terrible until at altitude. If insulated, it is down right tollerable in the duct shortly after engine start. I have put them in the back of the wing fillet gap by the flap, seen them in the gap between the stab and fuselage, in the tail cone trim hole, sticking out the belly (Dynon probe style stuck out of the bottom of the aircraft clear of exhausted air), even the 912 fiberglass plenum, and they all worked. Some magnatometers require wire to the OAT to be installed (Dynon type) so plan your magnatometer and OAT sensor positions to prevent 20 feet of wire running. With the magnetometer behind the baggage bulkhead, one was put in the hole behind the flap bracket (no cover). Do plan for flap movement. Another mag was put under the seat, and the probe put under the right cheek of the passenger. It worked provided your passenger does not have an iron bottom. If you put your Dynon magnetometer in the overhead, consider an overhead vent with the OAT in it. If in a cold climate, when the duct is shut off, you get cockpit temp, so plan accordingly. Just my two cents. Bud ----- Original Message ----- From: nigel_graham@m-tecque.co.uk<mailto:nigel_graham@m-tecque.co.uk> To: europa-list(at)matronics.com Sent: Monday, February 24, 2014 6:43 AM Subject: Re: Europa-List: where to put OAT sensor? "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk> Ahh! wrong plenum. That makes more sense as I would expect induction air downstream of the turbo to be in the high 70's C. Thanks for the clarification. Nigel On 24/02/2014 09:16, David Joyce wrote: > > > > Nigel, Yes I have a 914' but I am talking about the space fed > directly from a NACA inlet which gathers the air before it enters the > turbo. Like all the cowling inlets it will be pressurised by the > slipstream/propwash No doubt post turbo the temperature will be higher > still - which is why 914s don't need carb icing protection. > Regards, David > > "nigel_graham@m-tecque.co.uk" <nigel_graham@m-tecque.co.uk> wrote: "nigel_graham@m-tecque.co.uk" >> <nigel_graham@m-tecque.co.uk> >> >> If I remember correctly, isn't 'DJ powered by a 914? If so, the >> plenum will be fed with heat sinked (sunk?) air fresh from a >> blisteringly hot turbo. Once Mr. Boyle has added his two cents, I'm >> surprised that the difference between plenum and OAT is only 8c! >> >> Nigel >> >> On 23/02/2014 12:04, David Joyce wrote: >>> > >>> >>> >>> Alan & rowland, problem with anywhere subject to ram air >>> pressurization is that it will give an appreciably higher temp than >>> true OAT.(Boyle & his law). I have an airbox temp sensor in my air >>> plenum and also an OAT sensor in the wing root just in front of the >>> flap control slot and the two give significantly different temps >>> once the plane is flying, if I remember rightly by something like >>> 8C. Regards, David Joyce, G-XSDJ >>> >> >> >> Un/Subscription, >> Forums! >> Admin. >> >> >> > > > > > http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Feb 25, 2014
UPDATE: Before removing CS10/2 I tried once more to get the offending nut onto the bolt with the assistance of my son's slightly smaller hands. Success! Once the nut was aligned with the bolt I could turn the bolt with one finger (through the hole in the seat back) just enough to keep the nut it in place. Then with a box wrench on the nut (again through the seat back), and access from the starboard side, used a socket on a very long assembly of extensions to turn the bolt until everything was tight. Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Rob Housman Sent: Monday, February 24, 2014 8:48 AM Subject: RE: Europa-List: Mod 76 - Altitude Hold Autopilot Nigel: What you describe is almost exactly how I connected the port and starboard pitch push rods to CS10/2, the only difference being that I did not need to magnetize the socket. Both of these connections are relatively easy to reach but that @#$%^&* third horn on CS10/2 is (so far) not within my reach with either fingers or tools. Ron: My problem is access. My combination of universal joints, extensions and sockets will not clear the obstructions which include the support bracket holding CS10/2 and the aileron bell crank where it mounts to the end of CS05 torque tube. In other words, I cannot manage to get the tools to align coaxially with the bolt even if I could get the nut onto the bolt manually, which I can't. Next up: Unless someone presents a simpler solution, I'll remove CS10/2 and attach only the rod end to it and then after CS10/2 is reinstalled, attempt to thread the servo push rod onto the rod end already in place. Only if this fails will I resort to cutting another access port in the bottom of the fuselage. Incidentally, prior to installing CS10/2 I used 5 minute epoxy to hold all of those washers in place and used a greased pin slightly smaller than the size of the bolt holes to maintain alignment during cure. With my many attempts to assemble the rod end to CS10/2 these washers have remained in place. Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of
nigel_graham@m-tecque.co.uk Sent: Monday, February 24, 2014 12:11 AM Subject: Re: Europa-List: Mod 76 - Altitude Hold Autopilot Hello Rob, I recently had to strip out and refit the CS10 and had to face the same problem so know exactly what you are up against. There is a solution. Ideally you need a trusty assistant - though I did succeed by myself (it took a whole afternoon though :-( ) I used a long socket, and filled it with spare nuts such that it prevented the nut you are attempting to tighten - sliding down into the barrel of the socket. I magnetised the socket by stroking it a few times with a strong magnet - that ensured that the nut would not drop out. Now the nut can be held precisely. The next bit seems non-intuitive, but tighten the bolt (not the nut) from the other side of the aircraft using your assistant and a long socket drive extension. All you need to focus on is keeping the nut in place (a long socket is easier to hold) until the thread catches. The only other thing to consider is keeping the washers in place until the bolt is inserted - this was done by sticking the washers using a blob of grease. It is possible to achieve without resorting to an angle grinder! Nigel On 23/02/2014 23:52, Rob Housman wrote: Assuming that I am not the only one foolish enough to attempt a retro-fit of Mod 76 (Dynon) to a completed airframe I would appreciate any help from others who have done so. I am currently at an impasse. Removal of CS10 and replacing it with CS10/2 was tedious but relatively straightforward to complete, although the Europa Factory instructions manage to overlook a few essential points. I am stymied by my inability to get the nut on the bolt that attaches the rod end to the horn on CS10/2. With perseverance I managed to get the bolt through the horn on CS10/2 and the rod end, but my not very large hands cannot do both: hold the MS31042-3 nut and rotate it after I get it near the threaded end of the AN3-7A bolt. So far I have failed even to get the nut aligned so the bolt could be turned into the nut. At this point I am considering cutting another access hole in the bottom of the fuselage but only as a last resort would I start cutting. Suggestions? Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress sp; - The Europa-List Email Forum utilities such as List Photoshare, and much much --> http://www.matron================== <http://www.matronics.com/Navigator?Europa-List> < - content also available via the Web --> http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c= <http://www.matronics.com/contribution> ________________________________________________________________________________
Subject: Re: Friedrickshafen
Date: Feb 26, 2014
Hi, This year it will not be any orgenized trip from Scandinavia. I know couple of Europa pilots that are planing to visit Friedrichshafen/Biberach this year. Probable stay at the "Europa Hotel=94 http://www.eberbacherhof.de/ Best of luck Stephan LN-STE Europa Mono. ________________________________________________________________________________
Subject: Cowling fasteners
Date: Feb 27, 2014
I am just starting on the cowlings. As supplied, these are fixed together using screws and anchor nuts. Makes sense for something that has to come off infrequently, but not for cowlings. The Katana I fly now has nifty quarter turn fasteners which means you can get the cowling off and on in seconds. Anyone used these on the Europa, and if so, do you have a part no. and source for them? -------- Jeroen http://www.europaowners.org/main.php?g2_itemId=44165 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419464#419464 ________________________________________________________________________________
Subject: Re: Cowling fasteners
Date: Feb 27, 2014
Have you tried AircraftSpruce? http://www.aircraftspruce.com/categories/air craft_parts/ap/menus/ha/fast_1dzus.html Mike Duane -----Original Message----- From: jglazener <j.glazener(at)planet.nl> Sent: Thu, Feb 27, 2014 2:54 pm Subject: Europa-List: Cowling fasteners I am just starting on the cowlings. As supplied, these are fixed together u sing screws and anchor nuts. Makes sense for something that has to come off infrequently, but not for cowlings. The Katana I fly now has nifty quarter turn fasteners which means you can get the cowling off and on in seconds. Anyone used these on the Europa, and if so, do you have a part no. and sour ce for them? -------- Jeroen http://www.europaowners.org/main.php?g2_itemId=44165 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419464#419464 ________________________________________________________________________________
Date: Feb 27, 2014
Jeroen, The Europa Club has a mod which does exactly that. It is Mod 10405Cowl. You can find it on the Europa Club website. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Feb 27, 2014, at 4:51 PM, jglazener wrote: I am just starting on the cowlings. As supplied, these are fixed together using screws and anchor nuts. Makes sense for something that has to come off infrequently, but not for cowlings. The Katana I fly now has nifty quarter turn fasteners which means you can get the cowling off and on in seconds. Anyone used these on the Europa, and if so, do you have a part no. and source for them? -------- Jeroen http://www.europaowners.org/main.php?g2_itemId=44165 ________________________________________________________________________________
Subject: Nicopress Squeezes Using Aviation Approved Squeezer......comments
requested .
Date: Feb 28, 2014
Gidday, I=92ve attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received. Regards Tony Renshaw ________________________________________________________________________________
Subject: Build Master Task List
From: "alan_hunter1664" <alan_hunter1664(at)yahoo.co.uk>
Date: Feb 28, 2014
I've been reading the Europa build manual, on to my 20th time now I think, and although very good, I find it wordy and not conducive to tracking the progress of work. I was therefore considering producing a Master Task List for each chapter as this would make is far easier to use the kitlog prgramme I've bought to track and report on build progress. Has anyone produced A MTL before that I could use as a starting point? Thanks Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419483#419483 ________________________________________________________________________________
Subject: Re: Build Master Task List
Date: Feb 28, 2014
On 28 Feb 2014, at 12:32, alan_hunter1664 wrote: > I've been reading the Europa build manual, on to my 20th time now I think, and although very good, I find it wordy and not conducive to tracking the progress of work. I was therefore considering producing a Master Task List for each chapter as this would make is far easier to use the kitlog prgramme I've bought to track and report on build progress. Has anyone produced A MTL before that I could use as a starting point? Alan - this MTL idea is new to me, but sounds very sensible for both planning & logging - and I'd be interested to get access to it if it's ever created! The only thing I can think of as a springboard towards producing such a document is the LAA list of inspections. Here's a copy of that list: 1 Workroom conditions Check workroom for suitability and cleanliness. Check thermometer and hygrometer available. Check epoxy ratio balance for accuracy. 2 Education layup Check Euro Chock for quality of layup, correct ply orientation and flox corners for voids. 3 Rudder Check for lean or rich areas in layup, ply orientation, leading and trailing edges for straightness. Check close-out layup and reinforced areas for hinge attachment. 4 Tailplane Check outboard rib for correct layup and accuracy. 5 Tailplane Check skins for quality and ply orientation. Check inboard rib and rear spar for hinge area reinforcements. Check anti-servo tab for correct layup and hinge attachment, free movement without hinge binding. Check correct fitting to torque tube, inboard rib bushes and pip pin operation. Check that both tailplanes have the same incidence. 6 Ailerons Check top skin, bottom skin and close-outs for correct layup, cure and ply orientation and straightness of aileron. 7 Ailerons Check inboard rib and insert for position and push rod attachment pin for correct installation. 8 Ailerons Check correct hinge attachment, position and safety. 9 Ailerons Check mass balance weight for correct attachment. 10 Flaps Check top and bottom skins for correct layup, ply orientation and quality. 11 Flaps Check end ribs for correct layup and insert position accuracy. 12 Flaps Check aileron and flap close-outs for correct layup and ply orientation. 13 Wing Inspection stage 1 Working conditions must have been satisfied prior to start of wing build. Check all layups for full cure using scratch and tap test if in doubt. Ply orientation +/- 10 degrees, wet or dry areas, all joints for correct layup procedure and general cleanliness. 14 Wing Check aileron bellcrank attachment to spar, and inspection hole. Check bellcrank assembly for correct assembly and riveting. 15 Wing Inspect spar to upper and lower skins layups for quality and ply orientation, also root rib, diagonal rib, and walkway rib to skin layups for quality and ply orientation. 16 Wing Inspect outrigger double rib to skin layup for quality and ply orientation, also correct installation of 3mm plywood transverse rib and associated layups between double ribs. 17 Wing Check upper trailing edge skin bond to main wing structure and alignment with leading edge. 18 Wing Check position of inserts and orientation of 12mm stainless root pins. 19 Wing Check hinge arm alignment using templates on outboard and inboard sighting centre as per plans. With ailerons and flaps attached check for smooth operation, interference, travel and outrigger retract and extension mechanism. 20 Fuselage Inspection stage 1 Workroom conditions must have been satisfied prior to start of fuselage build. Check all layups for full cure using scratch and tap test if in doubt. Check ply orientation +/- 10 degrees, wet or dry areas, all joints for correct layup procedure and general cleanliness. Check all parts for quality before assembly. 21 Fuselage Check installation of rear bulkhead. 22 Fuselage Check installation and alignment of tailplane torque tube bushes and tailplane. 23 Fuselage Prior to installation of completed cockpit module into bottom of fuselage, check fitment and operation of flying controls (with wings attached). 24 Fuselage Check final installation of cockpit module into fuselage. 25 Fuselage Check installation and operation of fuel system. 26 Fuselage Check installation of main and tailwheel undercarriage. 27 Fuselage Check installation and operation of electrical system. 28 Fuselage Check installation and operation of panel and instruments. 29 Fuselage Final check of completed fuselage including doors and all hardware. 30 Fuselage Check installation of engine including all systems, propeller and cowlings. Record fuel flow checks in build book. 31 Structure - general Check structure after filling and sanding for excessive sanding which may compromise the integrity of the structure. 32 Final inspection Final check of complete aircraft including rigging and control movements, correct operation of all systems, proper cockpit and panel placarding, cockpit furnishings including harness installation, external markings including registration. Weigh aircraft and forward results and weight schedule to PFA. The tab characters that separate item number, functional area, and description may not survive the e-mail transmission process. If you want a clean copy please ask for an attachment. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Subject: Re: Nicopress Squeezes Using Aviation Approved Squeezer......com
Date: Feb 28, 2014
Hi Tony You can look at my Nicos in two pages at below link. They look like yours. My large tool like yours came with a gauge, you can adjust crimp size. I am pretty sure 43.13 would give you dimension. If you are only going with one Nico, leave some cable sticking out, if two Niocos, then you can capture end with second. I use Teflon shrink tube, needs lots of heat and expensive, but holds up to nasty sharp end of cable. I forget if you are building a mono, check out slick 3 Nico short tailwheel cable. I mentioned it before, turnbuckles can get tangled together and shorten up, very bad because you lose rudder travel. See cause and resolution. http://www.europaowners.org/main.php?g2_itemId=27732 Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419497#419497 ________________________________________________________________________________
Subject: Re: Nicopress Squeezes Using Aviation Approved Squeezer......comments
requested .
Date: Feb 28, 2014
Hi Tony You must leave an inch long tail after the sleeve and shrink a short length of electric wire sleeving on to that end for protection. Two things you can do also, conduct a proof load test, I don=92t know the loads but Europa may, or you could drop an email to Andy Draper at the LAA engineering dept he would know. The other way of being certain is to build the cables with two Nicopress sleeves on each end. I know its more weight but =93Piece of mind=94is worth a few ounces . Best of luck Richard From: Tony Renshaw Sent: Friday, February 28, 2014 10:41 AM Subject: Europa-List: Nicopress Squeezes Using Aviation Approved Squeezer......comments requested . Gidday, I=92ve attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received. Regards Tony Renshaw No virus found in this message. Checked by AVG - www.avg.com 02/27/14 ________________________________________________________________________________
requested .
Date: Mar 01, 2014
Tony, As Richard stated, I used two Nicopress Sleeves for " peace of mind". Good recommendation. Tim Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 > On 1/03/2014, at 6:39 am, "richard" wrote: > > Hi Tony You must leave an inch long tail after the sleeve and shrink a sh ort length of electric wire sleeving on to that end for protection. > Two things you can do also, conduct a proof load test, I don=81ft know the loads but Europa may, or you could drop an email to Andy Draper at the LAA e ngineering dept he would know. The other way of being certain is to build th e cables with two Nicopress sleeves on each end. I know its more weight but =81 gPiece of mind=81his worth a few ounces . > Best of luck > Richard > > From: Tony Renshaw > Sent: Friday, February 28, 2014 10:41 AM > To: europa-list(at)matronics.com > Subject: Europa-List: Nicopress Squeezes Using Aviation Approved Squeezer. .....comments requested . > > Gidday, > I=81fve attached 2 photos of my Nicopress squeezes, and 1 of the jaws of t he tool. Any input gratefully received. > Regards > Tony Renshaw > > > > > > <2014_02_28_Distorted_Nicopress-12.jpeg><2014_02_28_Squeezed_Nicopress_End -14.jpeg> > > <2014_02_28_Nicopress_Crimper_Jaws-11.jpeg> > > No virus found in this message. > Checked by AVG - www.avg.com ________________________________________________________________________________
requested .
Date: Mar 01, 2014
Hi Tim, So did you use two on all the ends, from pedal all the way thru to rudder? TR > On 1 Mar 2014, at 8:52, Tim Ward wrote: > > Tony, > As Richard stated, I used two Nicopress Sleeves for " peace of mind". > Good recommendation. > Tim > > Tim Ward > 12 Waiwetu Street > Fendalton, > Christchurch, 8052 > New Zealand. > > ward.t(at)xtra.co.nz > > Ph 64 3 3515166 > Mob 0210640221 > > >> On 1/03/2014, at 6:39 am, "richard" wrote: >> >> Hi Tony You must leave an inch long tail after the sleeve and shrink a s hort length of electric wire sleeving on to that end for protection. >> Two things you can do also, conduct a proof load test, I don=99t kn ow the loads but Europa may, or you could drop an email to Andy Draper at th e LAA engineering dept he would know. The other way of being certain is to b uild the cables with two Nicopress sleeves on each end. I know its more weig ht but =9CPiece of mind=9Dis worth a few ounces . >> Best of luck >> Richard >> >> From: Tony Renshaw >> Sent: Friday, February 28, 2014 10:41 AM >> To: europa-list(at)matronics.com >> Subject: Europa-List: Nicopress Squeezes Using Aviation Approved Squeezer ......comments requested . >> >> Gidday, >> I=99ve attached 2 photos of my Nicopress squeezes, and 1 of the jaw s of the tool. Any input gratefully received. >> Regards >> Tony Renshaw >> >> >> >> >> >> <2014_02_28_Distorted_Nicopress-12.jpeg><2014_02_28_Squeezed_Nicopress_En d-14.jpeg> >> >> <2014_02_28_Nicopress_Crimper_Jaws-11.jpeg> >> >> No virus found in this message. >> Checked by AVG - www.avg.com >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
requested .
Date: Mar 01, 2014
Yes I did. The 25mm long tail Richard talks about, instead of using tape I u se an additional sleeve. Tim Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 > On 1/03/2014, at 11:22 am, Tony Renshaw wrote: > > Hi Tim, > So did you use two on all the ends, from pedal all the way thru to rudder? > TR > >> On 1 Mar 2014, at 8:52, Tim Ward wrote: >> >> Tony, >> As Richard stated, I used two Nicopress Sleeves for " peace of mind". >> Good recommendation. >> Tim >> >> Tim Ward >> 12 Waiwetu Street >> Fendalton, >> Christchurch, 8052 >> New Zealand. >> >> ward.t(at)xtra.co.nz >> >> Ph 64 3 3515166 >> Mob 0210640221 >> >> >>> On 1/03/2014, at 6:39 am, "richard" wrote: >>> >>> Hi Tony You must leave an inch long tail after the sleeve and shrink a s hort length of electric wire sleeving on to that end for protection. >>> Two things you can do also, conduct a proof load test, I don=81ft know t he loads but Europa may, or you could drop an email to Andy Draper at the LA A engineering dept he would know. The other way of being certain is to build the cables with two Nicopress sleeves on each end. I know its more weight b ut =81gPiece of mind=81his worth a few ounces . >>> Best of luck >>> Richard >>> >>> From: Tony Renshaw >>> Sent: Friday, February 28, 2014 10:41 AM >>> To: europa-list(at)matronics.com >>> Subject: Europa-List: Nicopress Squeezes Using Aviation Approved Squeeze r......comments requested . >>> >>> Gidday, >>> I=81fve attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received. >>> Regards >>> Tony Renshaw >>> >>> >>> >>> >>> >>> <2014_02_28_Distorted_Nicopress-12.jpeg><2014_02_28_Squeezed_Nicopress_E nd-14.jpeg> >>> >>> <2014_02_28_Nicopress_Crimper_Jaws-11.jpeg> >>> >>> No virus found in this message. >>> Checked by AVG - www.avg.com 4 >>> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> a-List"">http://www.matronics.com/Navigator?Europa-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Potential problem with second Nicopress and dull SS control,cable
question
Date: Mar 01, 2014
Gidday, So, I've tried using a second incompressible, but am now concerned I have do ne that correctly. I placed the second one up against the other one, and as t hey compress, we know they exude outward, even a little bit. I reckon the ca ble I between the 2 could now be under tension, continually, and possibly qu ite a lot. Whatever stress it is preloaded is an equivalent weight, which in essence would minimise the stress loading on the cable. I've Lao got cable kicking around that looks more like gal than Stainless St eel, but I know I have only ever bought the right stuff 7x7 3/32" dia contro l cable. Is there a reason why over time Stainess Steel cable can go dull o ver time? Tony Renshaw Sent from my iPad > On 1 Mar 2014, at 9:52 am, Tim Ward wrote: > > Yes I did. The 25mm long tail Richard talks about, instead of using tape I use an additional sleeve. > Tim > > Tim Ward > 12 Waiwetu Street > Fendalton, > Christchurch, 8052 > New Zealand. > > ward.t(at)xtra.co.nz > > Ph 64 3 3515166 > Mob 0210640221 > > >> On 1/03/2014, at 11:22 am, Tony Renshaw wrote: >> >> Hi Tim, >> So did you use two on all the ends, from pedal all the way thru to rudder ? >> TR >> >>> On 1 Mar 2014, at 8:52, Tim Ward wrote: >>> >>> Tony, >>> As Richard stated, I used two Nicopress Sleeves for " peace of mind". >>> Good recommendation. >>> Tim >>> >>> Tim Ward >>> 12 Waiwetu Street >>> Fendalton, >>> Christchurch, 8052 >>> New Zealand. >>> >>> ward.t(at)xtra.co.nz >>> >>> Ph 64 3 3515166 >>> Mob 0210640221 >>> >>> >>>> On 1/03/2014, at 6:39 am, "richard" wrote: >>>> >>>> Hi Tony You must leave an inch long tail after the sleeve and shrink a short length of electric wire sleeving on to that end for protection. >>>> Two things you can do also, conduct a proof load test, I don=99t k now the loads but Europa may, or you could drop an email to Andy Draper at t he LAA engineering dept he would know. The other way of being certain is to b uild the cables with two Nicopress sleeves on each end. I know its more weig ht but =9CPiece of mind=9Dis worth a few ounces . >>>> Best of luck >>>> Richard >>>> >>>> From: Tony Renshaw >>>> Sent: Friday, February 28, 2014 10:41 AM >>>> To: europa-list(at)matronics.com >>>> Subject: Europa-List: Nicopress Squeezes Using Aviation Approved Squeez er......comments requested . >>>> >>>> Gidday, >>>> I=99ve attached 2 photos of my Nicopress squeezes, and 1 of the j aws of the tool. Any input gratefully received. >>>> Regards >>>> Tony Renshaw >>>> >>>> >>>> >>>> >>>> >>>> <2014_02_28_Distorted_Nicopress-12.jpeg><2014_02_28_Squeezed_Nicopress_ End-14.jpeg> >>>> >>>> <2014_02_28_Nicopress_Crimper_Jaws-11.jpeg> >>>> >>>> No virus found in this message. >>>> Checked by AVG - www.avg.com 14 >>>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> a-List"">http://www.matronics.com/Navigator?Europa-List >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> //forums.matronics.com >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> ot;">http://www.matronics.com/contribution >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> a-List"">http://www.matronics.com/Navigator?Europa-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 01, 2014
requested . Tony The final proof is in the testing. AC43-13-1b chapter 7 gives a chart and testing procedure. Attached is a picture of my cable test rig. When I was doing the actual test I had a large ladder between myself and the victim. If they break they can go with a bang. Regards Lance Sandford On 28/02/14 20:41, Tony Renshaw wrote: > Gidday, > Ive attached 2 photos of my Nicopress squeezes, and 1 of the jaws of > the tool. Any input gratefully received. > Regards > Tony Renshaw > ________________________________________________________________________________
requested .
Date: Mar 01, 2014
Hi Lance, Thanks for responding. That looks a great tester. With the various holes, did you do the maths to calculate and what is the formula you use? Good setup. I am impressed. I believe you are close to flying. Is that right? TR. Sent from my iPad > On 1 Mar 2014, at 11:46 am, Lance Sandford wrote: > > Tony > > The final proof is in the testing. > > AC43-13-1b chapter 7 gives a chart and testing procedure. > Attached is a picture of my cable test rig. > When I was doing the actual test I had a large ladder between myself and the victim. If they break they can go with a bang. > > Regards > > Lance Sandford > > >> On 28/02/14 20:41, Tony Renshaw wrote: >> Gidday, >> Ive attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received. >> Regards >> Tony Renshaw > ________________________________________________________________________________
Date: Mar 01, 2014
requested . Tony The beam is part of a sash clamp I used for making window frames many years ago. I set it in the nearest hole to give me the weight I required and adjusted the rest with the much under used weights from my barbell, then carefully lowered the jack and kept my fingers crossed. Im sure a Man of your ability can do the maths for whatever you have available. The check is 60% of 700 lbs for 3 minutes I think, but read the document. Incidentally, the breaking strain of a well made Nicopress is about 1.5 times the minimum breaking strain of the cable hence I only used one on the ends of my cables. I was hoping to be flying by mid year until my neighbour conned me into helping lay 160 meters of concrete during our 30 Degree, 70% humidity days, which has slowed build progress a couple of Months. Lance On 01/03/14 11:12, Tony Renshaw wrote: > > Hi Lance, > Thanks for responding. That looks a great tester. With the various holes, did you do the maths to calculate and what is the formula you use? > Good setup. I am impressed. I believe you are close to flying. Is that right? > TR. > > > Sent from my iPad > >> On 1 Mar 2014, at 11:46 am, Lance Sandford wrote: >> >> Tony >> >> The final proof is in the testing. >> >> AC43-13-1b chapter 7 gives a chart and testing procedure. >> Attached is a picture of my cable test rig. >> When I was doing the actual test I had a large ladder between myself and the victim. If they break they can go with a bang. >> >> Regards >> >> Lance Sandford >> >> >>> On 28/02/14 20:41, Tony Renshaw wrote: >>> Gidday, >>> Ive attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received. >>> Regards >>> Tony Renshaw >> > ________________________________________________________________________________
requested .
Date: Mar 01, 2014
Hi Lance, What powerplant are you using again? I am wondering whether I fit my flap floor hinge hardware at this stage, or just rely on the redux pads, and put them in later? I figure filling and painting might be easier without obstructions, although I will be making up a cover I would imagine, or fill to hide them. Do you have a recommendation there? Also, I am struggling with my rudder cables but might be starting to see light at the wnd of the tunnel, to coin a phrase. I have both stainless steel cable I have bought from ACS and what appears to be Gal cable, probably from Europa but it is not labelled, and I truly dont know where it came from. It must have been Europa, but it definitely is NOT SS, as it is far more magnetic. Did u use the Europa cable or some other? I will do 2 crimps even though I know they are 1.5 the load of the cable, as cheap insurance in case something slips, but, it comes with its own pitfalls. If you dont leave a reasonable gap, it loads up the cable between them, as they pull in when you crimp them, as we all probably know. So, I put 2 butted together for one cable, and if I imagine the internal tension, that atatic load I could have created, I cant leave it as is. I dont know how many times I have done this, but at least I have turnbuckle to make the work a bit easier. I couldnt imagine doing this without then, and the tensioner in the manual, well, I didnt even bother to read the manual properly to digest how those things worked. So, I have mow run out of Nicopress, & cable, at a very inconvenient time. I will get some locally, or ACS to send it out, but there packaging is ridiculous. I think they have a rates deal with their courier company to maximise space over weight, and rhen they charge you on volume. I have asked them to minimise the packaging but you get a box full of these air bladders to fill the space, and then a baby package within. Crazy! Anyway, onward and upward. As for my maths, I have to be really good at my 3 x tables for profile management on descent, and ideally fast at it otherwise, I get high and fast, both of which can get a bit ugly. So, watch your back with that concrete, says he who only learnt the benefits of a Larry Hoe after hand mixing about 1,000 wheelbarrow full of concrete. So, I at the local RSL to watch the Reds against the Waratahs, and need to eat first. Thks for the advice. TR > On 1 Mar 2014, at 13:02, Lance Sandford wrote: > > > Tony > > The beam is part of a sash clamp I used for making window frames many years ago. > I set it in the nearest hole to give me the weight I required and adjusted the rest with the much under used weights from my barbell, then carefully lowered the jack and kept my fingers crossed. > Im sure a Man of your ability can do the maths for whatever you have available. > The check is 60% of 700 lbs for 3 minutes I think, but read the document. > Incidentally, the breaking strain of a well made Nicopress is about 1.5 times the minimum breaking strain of the cable hence I only used one on the ends of my cables. > I was hoping to be flying by mid year until my neighbour conned me into helping lay 160 meters of concrete during our 30 Degree, 70% humidity days, which has slowed build progress a couple of Months. > > Lance > >> On 01/03/14 11:12, Tony Renshaw wrote: >> >> Hi Lance, >> Thanks for responding. That looks a great tester. With the various holes, did you do the maths to calculate and what is the formula you use? >> Good setup. I am impressed. I believe you are close to flying. Is that right? >> TR. >> >> >> Sent from my iPad >> >>> On 1 Mar 2014, at 11:46 am, Lance Sandford wrote: >>> >>> Tony >>> >>> The final proof is in the testing. >>> >>> AC43-13-1b chapter 7 gives a chart and testing procedure. >>> Attached is a picture of my cable test rig. >>> When I was doing the actual test I had a large ladder between myself and the victim. If they break they can go with a bang. >>> >>> Regards >>> >>> Lance Sandford >>> >>> >>>> On 28/02/14 20:41, Tony Renshaw wrote: >>>> Gidday, >>>> Ive attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received. >>>> Regards >>>> Tony Renshaw >>> > > > > > ________________________________________________________________________________
Subject: Classic Coolant Hoses
Date: Mar 01, 2014
I know this is a long shot. I have already emailed the factory a short while ago, awaiting their response. I wanted to ask if anyone knows the whereabouts of possible new unused hoses for a classic fwf installation. I am particularly looking for the one that makes the 180 deg. turn from the filler cap to the starboard radiator, or all of them in a set. Thanks. Troy Maynor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419561#419561 ________________________________________________________________________________
Subject: Cloth Storage Cabinet
Date: Mar 01, 2014
Does anyone have a drawing or the dimensions of the cloth storage cabinet with the fold away table & hinged legs that I could use to build one? Many thanks Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419570#419570 ________________________________________________________________________________
Subject: Europa or Stainless Steel Control Cable
Date: Mar 02, 2014
Gidday, I have gone through my fair share of cable, and consequently I have bits everywhere. I have a roll of cable which appears to be galvanised, or really dull Stainless Steel, which I believe doesnt happen. Why have nice shiny Stainless, if it stains. So, the best advice I have to figure out what is what is to use a magnet. The unknown roll of dull cable I have is extremely attractive to the magnet, and the Stainless is only slightly, but still is drawn towards the magnet on a really long suspended run, like the length in the aft fuselage, towards the magnet when it is mm away, but it still attracts it. So, this other roll I can only imagine might have been that supplied by Europa, and I wouldnt know because this roll has no product code or numbers on it. My question, whilst Id prefer to use Stainless just because it doesnt look like it has been in the aircraft for a million years, however the gal cable (or whatever it is) I am told is more durable especially in terms of bends. This is a conservative approach from gliders where control cabling can have acute bends, but we dont have that. So, should I resurrect this roll of cable out of my waste bin and use it, or should I replace it with Stainless Steel? Thanks for any advice or help, and I appreciate all the help Ive got with this sofar. Regards Tony Renshaw ________________________________________________________________________________
Date: Mar 01, 2014
Hi Tony Nicos for steel and galvanized steel may not be meant for Stainless wire. I forget what was supplied by Europa, but I think I remember it was not correct. I used stainless cable and correct Tin plated Copper Nicos: http://www.mcmaster.com/#nicopress-compatible-sleeve-crimpers/=qwrk00 Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419595#419595 ________________________________________________________________________________
Date: Mar 01, 2014
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Subject: Re: Europa or Stainless Steel Control Cable
Tony=0AI'd say go ahead with the galvanised steel cable. It should be fine in Oz, so long as you don't go =0Aocean sailing with it!=0AGraham=0A=0A=0A =0A=0A________________________________=0A From: Tony Renshaw <tonyrenshaw26 8(at)gmail.com>=0ATo: europa-list(at)matronics.com =0ASent: Saturday, 1 March 201 4, 22:49=0ASubject: Europa-List: Europa or Stainless Steel Control Cable=0A l.com>=0A=0AGidday,=0AI have gone through my fair share of cable, and conse quently I have bits everywhere. I have a roll of cable which appears to be galvanised, or really dull Stainless Steel, which I believe doesn=99t happen. Why have nice shiny Stainless, if it stains. So, the best advice I have to figure out what is what is to use a magnet. The unknown roll of du ll cable I have is extremely attractive to the magnet, and the Stainless is only slightly, but still is drawn towards the magnet on a really long susp ended run, like the length in the aft fuselage, towards the magnet when it is mm away, but it still attracts it. So, this other roll I can only imagin e might have been that supplied by Europa, and I wouldn=99t know beca use this roll has no product code or numbers on it. =0AMy question, whilst I=99d prefer to use Stainless just because it doesn=99t look li ke it has been in the aircraft for a million years, however the gal cable ( or whatever it is) I am told is more durable especially in terms of bends. This is a conservative approach from gliders where control cabling can have acute bends, but we don=99t have that. So, should I resurrect this r oll of cable out of my waste bin and use it, or should I replace it with St ainless Steel?=0AThanks for any advice or help, and I appreciate all the he lp I=99ve got with this sofar. =0ARegards=0ATony Renshaw=0A=0A=0A=0A_ -======================== =========================0A ________________________________________________________________________________
Date: Mar 02, 2014
Hi Graham, Wish I knew if it was what was supplied by Europa. I=92ve had the kit too long to know, things have been moved around, and I don=92t recall the Europa stuff ever being labelled. Maybe someone else might be able to clarify. Worst part is, it looks old even though it mightn=92t be. It reminds me of a Hills Hoist outside clothes line cable, but I think that is more of an Aussie thing. I actually don=92t have enough Nicopress sleeves now so I=92ll need more of those anyway, so I can get some more pretty stuff ;-) You normally use Stainless Steel cable by choice don=92t you?? TR On 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON wrote: > Tony > I'd say go ahead with the galvanised steel cable. It should be fine in Oz, so long as you don't go > ocean sailing with it! > Graham > > > From: Tony Renshaw <tonyrenshaw268(at)gmail.com> > To: europa-list(at)matronics.com > Sent: Saturday, 1 March 2014, 22:49 > Subject: Europa-List: Europa or Stainless Steel Control Cable > > > Gidday, > I have gone through my fair share of cable, and consequently I have bits everywhere. I have a roll of cable which appears to be galvanised, or really dull Stainless Steel, which I believe doesn=92t happen. Why have nice shiny Stainless, if it stains. So, the best advice I have to figure out what is what is to use a magnet. The unknown roll of dull cable I have is extremely attractive to the magnet, and the Stainless is only slightly, but still is drawn towards the magnet on a really long suspended run, like the length in the aft fuselage, towards the magnet when it is mm away, but it still attracts it. So, this other roll I can only imagine might have been that supplied by Europa, and I wouldn=92t know because this roll has no product code or numbers on it. > My question, whilst I=92d prefer to use Stainless just because it doesn=92t look like it has been in the aircraft for a million years, however the gal cable (or whatever it is) I am told is more durable especially in terms of bends. This is a conservative approach from gliders where control cabling can have acute bends, but we don=92t have that. So, should I resurrect this roll of cable out of my waste bin and use it, or should I replace it with Stainless Steel? > Thanks for any advice or help, and I appreciate all the help I=92ve got with this sofar. > Regards > Tony Renshawhttp://forums.matronics.com > > > > > > > > ________________________________________________________________________________
Date: Mar 02, 2014
Yes, stainless was developed for yachts, sea water contamination resistant. There isn't much bending in the Europa so no worries about fatigue.=0AMust be the multi strand stuff though, 7X19 springs to mind but anyway it's fin e wire strands for flexibility.=0AGraham=0A=0AAlso be sure you use the righ t crimps, plated I think, not plain copper. Get a second opinion, I not as young as I once was!=0A=0A=0A=0A=0A=0A________________________________=0A F rom: Tony Renshaw =0ATo: GRAHAM SINGLETON ; europa-list(at)matronics.com =0ASent: Sunday, 2 Mar ch 2014, 6:04=0ASubject: Re: Europa-List: Europa or Stainless Steel Control Cable=0A =0A=0A=0AHi Graham,=0AWish I knew if it was what was supplied by Europa. I=99ve had the kit too long to know, things have been moved a round, and I don=99t recall the Europa stuff ever being labelled.=C2 -=0AMaybe someone else might be able to clarify. Worst part is, it looks old even though it mightn=99t be. It reminds me of a Hills Hoist outs ide clothes line cable, but I think that is more of an Aussie thing. I actu ally don=99t have enough Nicopress sleeves now so I=99ll need m ore of those anyway, so I can get some more pretty stuff ;-)=0AYou normally use Stainless Steel cable by choice don=99t you??=0ATR=0A=0A=0A=0A =0AOn 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON wrote:=0A=0ATony=0A>I'd say go ahead with the galvanised steel cable. It should be fine in Oz, so long as you don't go=C2-=0A>ocean sailing wi th it!=0A>Graham=0A>=0A>=0A>=0A>=0A>=0A>=0A>_______________________________ _=0A>From:=C2-Tony Renshaw =0A>To:=C2-europa- list(at)matronics.com=C2-=0A>Sent:=C2-Saturday, 1 March 2014, 22:49=0A>Sub ject:=C2-Europa-List: Europa or Stainless Steel Control Cable=0A>=0A>=0A> =0A>=0A>Gidday,=0A>I have gone through my fair share of cable, and conseque ntly I have bits everywhere. I have a roll of cable which appears to be gal vanised, or really dull Stainless Steel, which I believe doesn=99t ha ppen. Why have nice shiny Stainless, if it stains. So, the best advice I ha ve to figure out what is what is to use a magnet. The unknown roll of dull cable I have is extremely attractive to the magnet, and the Stainless is on ly slightly, but still is drawn towards the magnet on a really long suspend ed run, like the length in the aft fuselage, towards the magnet when it is mm away, but it still attracts it. So, this other roll I can only imagine m ight have been that supplied by Europa, and I wouldn=99t know because this roll has no product code or numbers on it.=C2-=0A>My question, whil st I=99d prefer to use Stainless just because it doesn=99t look like it has been in the aircraft for a million years, however the gal cabl e (or whatever it is) I am told is more durable especially in terms of bend s. This is a conservative approach from gliders where control cabling can h ave acute bends, but we don=99t have that. So, should I resurrect thi s roll of cable out of my waste bin and use it, or should I replace it with Stainless Steel?=0A>Thanks for any advice or help, and I appreciate all th e help I=99ve got with this sofar.=C2-=0A>Regards=0A>Tony=C2-Rens hawhttp://forums.matronics.com=0A>=0A>=0A>=0A>=0A>=0A>href="http://www.ma tronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europ a-List=0Ahref="http://forums.matronics.com/">http://forums.matronics.com =0Ahref="http://www.matronics.com/contribution">http://www.matronics.com/ ==================== ________________________________________________________________________________
Subject: Re: New cockpit panel
Date: Mar 02, 2014
Believe it or not, the project goes on..... BTW: a new set is already been made and ready for shipping :-) Roland PH-ZTI XS Trigear 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419620#419620 Attachments: http://forums.matronics.com//files/fotos_neu_023_214.jpg http://forums.matronics.com//files/fotos_neu_029_630.jpg ________________________________________________________________________________
Subject: Au revior
Date: Mar 02, 2014
Having just sold my Tri-gear 100hp G-TAGR yesterday (to Paul Norwood at Bournemouth), just to say thanks for the excellent support I've experienced from Europa Club and its members these last few years. The congenial nature of the dialogue, the readiness to help from all its members and the club trips organised by David J have been exceptional - thank you. My plans are to learn to glide and fly tug-planes (if I'm good enough) and possibly build again in a few years time -when the pressures on time are a little reduced. Regards. Clive Sutton Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419621#419621 ________________________________________________________________________________
Date: Mar 02, 2014
Subject: Re: Au revior
You could tow gliders with your Europa, if LAA would allow it! First Europa Classic tug plane was Walter Binder's=0AClassic, he was an early builder i n Germany=0AGraham=0A=0A=0A=0A=0A________________________________=0A From: gtagr =0ATo: europa-list(at)matronics.com =0ASent: S unday, 2 March 2014, 11:06=0ASubject: Europa-List: Au revior=0A =0A=0A--> E uropa-List message posted by: "gtagr" =0A=0AHavin g just sold my Tri-gear 100hp G-TAGR yesterday (to Paul Norwood at Bournemo uth), just to say thanks for the excellent support I've experienced from Eu ropa Club and its members these last few years. The congenial nature of the dialogue, the readiness to help from all its members and the club trips or ganised by David J have been exceptional - thank you.- My plans are to le arn to glide and fly tug-planes (if I'm good enough) and possibly build aga in in a few years time -when the pressures on time are a little reduced.- Regards.- Clive Sutton=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ah ttp://forums.matronics.com/viewtopic.php?p=419621#419621=0A=0A=0A=0A=0A ================== ________________________________________________________________________________
Date: Mar 02, 2014
Clive, sorry to see you go, but enjoy your next phase of flying. I found both gliding and tugging very satisfying. The tugging in particular surprised me as I had expected it to be a bit repetitive and dull. Not a bit of it, as you will no doubt discover! Regards, David Joyce, G-XSDJ "gtagr" wrote: > > > Having just sold my Tri-gear 100hp G-TAGR yesterday (to >Paul Norwood at Bournemouth), just to say thanks for the >excellent support I've experienced from Europa Club and >its members these last few years. The congenial nature of >the dialogue, the readiness to help from all its members >and the club trips organised by David J have been >exceptional - thank you. My plans are to learn to glide >and fly tug-planes (if I'm good enough) and possibly >build again in a few years time -when the pressures on >time are a little reduced. Regards. Clive Sutton > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419621#419621 > > > > > > > >Un/Subscription, >Forums! >Admin. > > > ________________________________________________________________________________
Date: Mar 02, 2014
Just a note for UK owners. I was quite interested in fitting a full width panel although this one works out quite expensive so I asked my inspector for his opinion and he said email Andy draper, which I did and his response was that it is a mod, which would need to be applied for and he would need to see crash test data and such, so in conclusion too much trouble and too expensive. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419626#419626 ________________________________________________________________________________
Subject: Re: Potential problem with second Nicopress and dull SS control,cable
question
Date: Mar 02, 2014
Hi Tony The BGA here in England banned the use of stainless steel for rudder cables about 10 years age. I think it was because with age like us it gets a bit brittle but still looks good! As Graham has said the cable run is very straight forward mostly internal, don=99t worry use the stuff supplied by Europa but get plated Nicropress sleeves. Best wishes Richard From: Tony Renshaw Sent: Saturday, March 1, 2014 12:19 AM Subject: Europa-List: Potential problem with second Nicopress and dull SS control,cable question Gidday, So, I've tried using a second incompressible, but am now concerned I have done that correctly. I placed the second one up against the other one, and as they compress, we know they exude outward, even a little bit. I reckon the cable I between the 2 could now be under tension, continually, and possibly quite a lot. Whatever stress it is preloaded is an equivalent weight, which in essence would minimise the stress loading on the cable. I've Lao got cable kicking around that looks more like gal than Stainless Steel, but I know I have only ever bought the right stuff 7x7 3/32" dia control cable. Is there a reason why over time Stainess Steel cable can go dull over time? Tony Renshaw Sent from my iPad On 1 Mar 2014, at 9:52 am, Tim Ward wrote: Yes I did. The 25mm long tail Richard talks about, instead of using tape I use an additional sleeve. Tim Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 On 1/03/2014, at 11:22 am, Tony Renshaw wrote: Hi Tim, So did you use two on all the ends, from pedal all the way thru to rudder? TR On 1 Mar 2014, at 8:52, Tim Ward wrote: Tony, As Richard stated, I used two Nicopress Sleeves for " peace of mind". Good recommendation. Tim Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 On 1/03/2014, at 6:39 am, "richard" wrote: Hi Tony You must leave an inch long tail after the sleeve and shrink a short length of electric wire sleeving on to that end for protection. Two things you can do also, conduct a proof load test, I don=99t know the loads but Europa may, or you could drop an email to Andy Draper at the LAA engineering dept he would know. The other way of being certain is to build the cables with two Nicopress sleeves on each end. I know its more weight but =9CPiece of mind=9Dis worth a few ounces . Best of luck Richard From: Tony Renshaw Sent: Friday, February 28, 2014 10:41 AM To: europa-list(at)matronics.com Subject: Europa-List: Nicopress Squeezes Using Aviation Approved Squeezer......comments requested . Gidday, I=99ve attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received. Regards Tony Renshaw <2014_02_28_Distorted_Nicopress-12.jpeg><2014_02_28_Squeezed_Nicopress_En d-14.jpeg> <2014_02_28_Nicopress_Crimper_Jaws-11.jpeg> No virus found in this message. Checked by AVG - www.avg.com 02/27/14 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D a-List"">http://www.matronics.com/Navigator?Europa-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D a-List"">http://www.matronics.com/Navigator?Europa-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D a-List"">http://www.matronics.com/Navigator?Europa-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D No virus found in this message. Checked by AVG - www.avg.com 03/02/14 ________________________________________________________________________________
Date: Mar 02, 2014
Mil-DTL-83420 is the general spec that describes the requirements flight co ntrol cables=0A=C2-Composition A - Carbon steel, zinc, or tin over zinc c oated=0Asteel cable is stronger and stiffer than corrosion resistant steel =C2-=0A=C2-=0AMIL-DTL-83420/1 - Wire Rope, Flexible, Type I, Compositio n A.=0A=C2-M83420/1-005 Indicates - Wire Rope, Flexible, Type I, Carbon S teel,=0AConstruction; 7 x 19, Nominal Diameter 5/32=0A=C2-=0AComposition B - Corrosion resistant steel=0AMIL-DTL-83420/2 - Wire Rope, Flexible, Type I, Composition B.=0A=C2-MIL-DTL-781 - Terminal, Wire Rope Swaging, Gener al Specification for.=0A=C2-=0Ause this info to find the spec of cable yo u have=0Athe nicopress is usable on either. best to ck spec on swaging =0A =C2-=0Athe best place I know of for flight control cables is Mcfarlane av iation (USA) =0Aalso a good source for other "stuff"=0A=C2-=0A=C2-=0A =C2-=0A =0A=0A________________________________=0A From: GRAHAM SINGLETON =0ATo: "europa-list(at)matronics.com" =0ASent: Sunday, March 2, 2014 4:14 AM=0ASubject: Re: E uropa-List: Europa or Stainless Steel Control Cable=0A =0A=0A=0AYes, stain less was developed for yachts, sea water contamination resistant. There isn 't much bending in the Europa so no worries about fatigue.=0AMust be the mu lti strand stuff though, 7X19 springs to mind but anyway it's fine wire str ands for flexibility.=0AGraham=0A=0AAlso be sure you use the right crimps, plated I think, not plain copper. Get a second opinion, I not as young as I once was!=0A=0A=0A=0A =0A=0A________________________________=0A From: Tony Renshaw =0ATo: GRAHAM SINGLETON ; europa-list(at)matronics.com =0ASent: Sunday, 2 March 2014, 6:04=0ASubject: Re: Europa-List: Europa or Stainless Steel Control Cable=0A =0A=0A=0AHi Graham,=0AWish I knew if it was what was supplied by Europa. I=99ve had the kit too long to know, things have been moved around, a nd I don=99t recall the Europa stuff ever being labelled.=C2-=0AMay be someone else might be able to clarify. Worst part is, it looks old even though it mightn=99t be. It reminds me of a Hills Hoist outside cloth es line cable, but I think that is more of an Aussie thing. I actually don =99t have enough Nicopress sleeves now so I=99ll need more of t hose anyway, so I can get some more pretty stuff ;-)=0AYou normally use Sta inless Steel cable by choice don=99t you??=0ATR=0A=0A=0A=0A=0AOn 2 Ma r 2014, at 10:18 am, GRAHAM SINGLETON wrot e:=0A=0ATony=0A>I'd say go ahead with the galvanised steel cable. It should be fine in Oz, so long as you don't go=C2-=0A>ocean sailing with it!=0A> Graham=0A>=0A>=0A>=0A>=0A>=0A>=0A>________________________________=0A>From: =C2-Tony Renshaw =0A>To:=C2-europa-list@matro nics.com=C2-=0A>Sent:=C2-Saturday, 1 March 2014, 22:49=0A>Subject:=C2 -Europa-List: Europa or Stainless Steel Control Cable=0A>=0A>=0A>--> Euro pa-List message posted by: Tony Renshaw =0A>=0A>G idday,=0A>I have gone through my fair share of cable, and consequently I ha ve bits everywhere. I have a roll of cable which appears to be galvanised, or really dull Stainless Steel, which I believe doesn=99t happen. Why have nice shiny Stainless, if it stains. So, the best advice I have to fig ure out what is what is to use a magnet. The unknown roll of dull cable I h ave is extremely attractive to the magnet, and the Stainless is only slight ly, but still is drawn towards the magnet on a really long suspended run, l ike the length in=0A the aft fuselage, towards the magnet when it is mm awa y, but it still attracts it. So, this other roll I can only imagine might h ave been that supplied by Europa, and I wouldn=99t know because this roll has no product code or numbers on it.=C2-=0A>My question, whilst I =99d prefer to use Stainless just because it doesn=99t look lik e it has been in the aircraft for a million years, however the gal cable (o r whatever it is) I am told is more durable especially in terms of bends. T his is a conservative approach from gliders where control cabling can have acute bends, but we don=99t have that. So, should I resurrect this ro ll of cable out of my waste bin and use it, or should I replace it with Sta inless Steel?=0A>Thanks for any advice or help, and I appreciate all the he lp I=99ve got with this sofar.=C2-=0A>Regards=0A>Tony=C2-Renshawh ttp://forums.matronics.com=0A>=0A>=0A>=0A>=0A>=0A>href="http://www.matron ics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-Li st=0Ahref="http://forums.matronics.com/">http://forums.matronics.com=0Ahr ef="http://www.matronics.com/contribution">http://www.matronics.com/contr ibution =0A>=0A =0Ahttp://www.matronics.com/Navigator?Europa-List http:// ======================= =0A ================ ________________________________________________________________________________
Date: Mar 02, 2014
Hi Graham Do you have any more info on the Europa classic Tug, as you probably know Euro Fox have sold very well in the UK as glider tugs, we have one, the first one to be cleared by the CAA/BGA. It works very well and gives the Banbury Gliding Club a considerable cost saving on aero tow. A 2000ft tow is about =A314 and 1000ft lob when doing circuit training is half that which put a launch within reach of the cost of a winch launch. I must say I like the idea of the Europa earning its keep. Kind regards Richard From: GRAHAM SINGLETON Sent: Sunday, March 2, 2014 11:56 AM Subject: Re: Europa-List: Au revior You could tow gliders with your Europa, if LAA would allow it! First Europa Classic tug plane was Walter Binder's Classic, he was an early builder in Germany Graham ------------------------------------------------------------------------- ------- From: gtagr <clive.maf(at)googlemail.com> Sent: Sunday, 2 March 2014, 11:06 Subject: Europa-List: Au revior Having just sold my Tri-gear 100hp G-TAGR yesterday (to Paul Norwood at Bournemouth), just to say thanks for the excellent support I've experienced from Europa Club and its members these last few years. The congenial nature of the dialogue, the readiness to help from all its members and the club trips organised by David J have been exceptional - thank you. My plans are to learn to glide and fly tug-planes (if I'm good enough) and possibly build again in a few years time -when the pressures on time are a little reduced. Regards. Clive Sutton Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419621#419====== ==================http://www.matronic s.com/Navigator?Eurp; --> No virus found in this message. Checked by AVG - www.avg.com 03/02/14 ________________________________________________________________________________
Date: Mar 02, 2014
One tip for those installing rudder cables in a mono is to run them inside the light plastic tubing (used extensively in gliders) through the wheel well. It is virtually friction free and protects them entirely from damp & grit. Regards, David Joyce, GXSDJ Mike Baker wrote: > Mil-DTL-83420 is the general spec that describes the >requirements flight control cables > Composition A - Carbon steel, zinc, or tin over zinc >coated > steel cable is stronger and stiffer than corrosion >resistant steel > > MIL-DTL-83420/1 - Wire Rope, Flexible, Type I, >Composition A. > M83420/1-005 Indicates - Wire Rope, Flexible, Type I, >Carbon Steel, > Construction; 7 x 19, Nominal Diameter 5/32 > > Composition B - Corrosion resistant steel > MIL-DTL-83420/2 - Wire Rope, Flexible, Type I, >Composition B. > MIL-DTL-781 - Terminal, Wire Rope Swaging, General >Specification for. > > use this info to find the spec of cable you have > the nicopress is usable on either. best to ck spec on >swaging > > the best place I know of for flight control cables is >Mcfarlane aviation (USA) > also a good source for other "stuff" > > > > > > ________________________________ > From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> > To: "europa-list(at)matronics.com" > > Sent: Sunday, March 2, 2014 4:14 AM > Subject: Re: Europa-List: Europa or Stainless Steel >Control Cable > > > > Yes, stainless was developed for yachts, sea water >contamination resistant. There isn't much bending in the >Europa so no worries about fatigue. > Must be the multi strand stuff though, 7X19 springs to >mind but anyway it's fine wire strands for flexibility. > Graham > > Also be sure you use the right crimps, plated I think, >not plain copper. Get a second opinion, I not as young as >I once was! > > > > > > ________________________________ > From: Tony Renshaw <tonyrenshaw268(at)gmail.com> > To: GRAHAM SINGLETON ; >europa-list(at)matronics.com > Sent: Sunday, 2 March 2014, 6:04 > Subject: Re: Europa-List: Europa or Stainless Steel >Control Cable > > > > Hi Graham, > Wish I knew if it was what was supplied by Europa. Ive >had the kit too long to know, things have been moved >around, and I dont recall the Europa stuff ever being >labelled. > Maybe someone else might be able to clarify. Worst part >is, it looks old even though it mightnt be. It reminds >me of a Hills Hoist outside clothes line cable, but I >think that is more of an Aussie thing. I actually dont >have enough Nicopress sleeves now so Ill need more of >those anyway, so I can get some more pretty stuff ;-) > You normally use Stainless Steel cable by choice dont >you?? > TR > > > > > On 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON > wrote: > > Tony >>I'd say go ahead with the galvanised steel cable. It >>should be fine in Oz, so long as you don't go >>ocean sailing with it! >>Graham >> >> >> >> >> >> >>________________________________ >>From:Tony Renshaw >>To:europa-list(at)matronics.com >>Sent:Saturday, 1 March 2014, 22:49 >>Subject:Europa-List: Europa or Stainless Steel Control >>Cable >> >> >> >> >>Gidday, >>I have gone through my fair share of cable, and >>consequently I have bits everywhere. I have a roll of >>cable which appears to be galvanised, or really dull >>Stainless Steel, which I believe doesnt happen. Why have >>nice shiny Stainless, if it stains. So, the best advice I >>have to figure out what is what is to use a magnet. The >>unknown roll of dull cable I have is extremely attractive >>to the magnet, and the Stainless is only slightly, but >>still is drawn towards the magnet on a really long >>suspended run, like the length in > the aft fuselage, towards the magnet when it is mm away, >but it still attracts it. So, this other roll I can only >imagine might have been that supplied by Europa, and I >wouldnt know because this roll has no product code or >numbers on it. >>My question, whilst Id prefer to use Stainless just >>because it doesnt look like it has been in the aircraft >>for a million years, however the gal cable (or whatever >>it is) I am told is more durable especially in terms of >>bends. This is a conservative approach from gliders where >>control cabling can have acute bends, but we dont have >>that. So, should I resurrect this roll of cable out of my >>waste bin and use it, or should I replace it with >>Stainless Steel? >>Thanks for any advice or help, and I appreciate all the >>help Ive got with this sofar. >>Regards >>TonyRenshawhttp://forums.matronics.com >> >> >> >> >> >>href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List > href="http://forums.matronics.com/">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> > > http://www.matronics.com/Navigator?Europa-List >http://======================= > ================ ________________________________________________________________________________
Date: Mar 02, 2014
Hi Frank, I wasn't aware of the fact, that crash test data is needed in the UK for Experimental aircrafts - have there been made any crash tests with the Europa? I thought that only certified aircrafts have to be crash tested. Well, the cockpit design is generally no other than the DA 20 Katana or many Microlight designs (in fact almost all aircraft have full width panels) and I cannot see any differences concerning crash behavior. BTW on the club homepage you can also find a picture of a full width panel, but I don't know, if it belongs to a UK-builder http://www.theeuropaclub.org/for-builders/panel-instruments/. As for the costs, this is only the price I relay for the producer of it (I'm not the producer), only wanted to make this clear :-). Regards Roland PH-ZTI XS Trigear 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419647#419647 ________________________________________________________________________________
Date: Mar 02, 2014
Hi Roland, the cost all in to get it to the uk worked out about 900 which is abit much for a panel. The full width one on the europa club site is from flight creation which is the American dealer/distributor and those Americans can do near enough what ever they like. Here in the UK everything has to go through the LAA which is governed by the CAA and any change to the instructions is classed as a modification, which means lots of paperwork, money and hoops to jump through which just isn't worth it sometimes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419648#419648 ________________________________________________________________________________
question
Date: Mar 03, 2014
Hi Richard, So yours must be the dull stuff too? I'll check the ACS catalogue again, but I thought that's all they sold, the Stainless Steel stuff. Funny that it's O k in the US, where most of the worlds aviating occurs, but I understand bure aucracy. Thanks for the definitive answer. This stuff I have has been in a 1 5" dia roll since 1996. Do you think that is a concern? Regards Tony Renshaw Sent from my iPad > On 3 Mar 2014, at 3:33 am, "richard" wrote: > > Hi Tony > The BGA here in England banned the use of stainless steel for rudder cable s about 10 years age. I think it was because with age like us it gets a bit b rittle but still looks good! As Graham has said the cable run is very straig ht forward mostly internal, don=99t worry use the stuff supplied by Eu ropa but get plated Nicropress sleeves. > Best wishes > Richard > > From: Tony Renshaw > Sent: Saturday, March 1, 2014 12:19 AM > To: europa-list(at)matronics.com > Subject: Europa-List: Potential problem with second Nicopress and dull SS c ontrol,cable question > > Gidday, > So, I've tried using a second incompressible, but am now concerned I have d one that correctly. I placed the second one up against the other one, and as they compress, we know they exude outward, even a little bit. I reckon the c able I between the 2 could now be under tension, continually, and possibly q uite a lot. Whatever stress it is preloaded is an equivalent weight, which i n essence would minimise the stress loading on the cable. > I've Lao got cable kicking around that looks more like gal than Stainless S teel, but I know I have only ever bought the right stuff 7x7 3/32" dia contr ol cable. Is there a reason why over time Stainess Steel cable can go dull o ver time? > Tony Renshaw > > > Sent from my iPad > >> On 1 Mar 2014, at 9:52 am, Tim Ward wrote: >> >> Yes I did. The 25mm long tail Richard talks about, instead of using tape I use an additional sleeve. >> Tim >> >> Tim Ward >> 12 Waiwetu Street >> Fendalton, >> Christchurch, 8052 >> New Zealand. >> >> ward.t(at)xtra.co.nz >> >> Ph 64 3 3515166 >> Mob 0210640221 >> >> >>> On 1/03/2014, at 11:22 am, Tony Renshaw wrote : >>> >>> Hi Tim, >>> So did you use two on all the ends, from pedal all the way thru to rudde r? >>> TR >>> >>>> On 1 Mar 2014, at 8:52, Tim Ward wrote: >>>> >>>> Tony, >>>> As Richard stated, I used two Nicopress Sleeves for " peace of mind". >>>> Good recommendation. >>>> Tim >>>> >>>> Tim Ward >>>> 12 Waiwetu Street >>>> Fendalton, >>>> Christchurch, 8052 >>>> New Zealand. >>>> >>>> ward.t(at)xtra.co.nz >>>> >>>> Ph 64 3 3515166 >>>> Mob 0210640221 >>>> >>>> >>>>> On 1/03/2014, at 6:39 am, "richard" wrote: >>>>> >>>>> Hi Tony You must leave an inch long tail after the sleeve and shrink a short length of electric wire sleeving on to that end for protection. >>>>> Two things you can do also, conduct a proof load test, I don=99t know the loads but Europa may, or you could drop an email to Andy Draper at the LAA engineering dept he would know. The other way of being certain is t o build the cables with two Nicopress sleeves on each end. I know its more w eight but =9CPiece of mind=9Dis worth a few ounces . >>>>> Best of luck >>>>> Richard >>>>> >>>>> From: Tony Renshaw >>>>> Sent: Friday, February 28, 2014 10:41 AM >>>>> To: europa-list(at)matronics.com >>>>> Subject: Europa-List: Nicopress Squeezes Using Aviation Approved Squee zer......comments requested . >>>>> >>>>> Gidday, >>>>> I=99ve attached 2 photos of my Nicopress squeezes, and 1 of the j aws of the tool. Any input gratefully received. >>>>> Regards >>>>> Tony Renshaw >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> <2014_02_28_Distorted_Nicopress-12.jpeg><2014_02_28_Squeezed_Nicopress _End-14.jpeg> >>>>> >>>>> <2014_02_28_Nicopress_Crimper_Jaws-11.jpeg> >>>>> >>>>> No virus found in this message. >>>>> Checked by AVG - www.avg.com >>>>> Version: 2014.0.4335 / 02/27/14 >>>>> >>>> >>>> >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> a-List"">http://www.matronD=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D >>>> //forums.matronics.com >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> ot;">http://www.matronics.com/cD=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D >>>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> a-List"">http://www.matronD=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D >>> //forums.matronics.com >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> ot;">http://www.matronics.com/cD=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D >>> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> a-List"">http://www.matronics.com/Navigator?Europa-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > > href="http://www.matronics.com/Navigator?Europa-List">http://www.matronh ref="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > No virus found in this message. > Checked by AVG - www.avg.com > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Rudder Pedal Step Stretching
Date: Mar 03, 2014
Gidday, Ive heard it mentioned that to extend this step back a bit might make things more comfortable. Can I get an input on what dimension is recommended? Ive heard about 75 mm would do it, and I will probably build it into my floor mat mod that I want to do. Thanks. Regards Tony Renshaw Sydney Aussie ________________________________________________________________________________
Date: Mar 03, 2014
Hello all, I am skydiver since 1960, and parachutes builder since 1973, all of the parachutes handles for reserve sport, pilot chutes, ejection seat, military equipments are made since 1960 in stainless steel. The handle assembly are tested in accordance with TSO C23c, d or e. Each component are in Stainless steel, handle, cable and swaging ball, and the cable is conform to MIL W 83420 7x7x19 Dia. 2.38 mm or similar, nominal strength is 420 kg > 927 lbs. These handle are perfect in the time. For example I have parachutes in my collection with the differents harware completely rusty but the handle cable and pins of the same origin have very beautiful aspect, after tested these old handle, they are always conform to the TSO as like brand new, but they have 40 years old. The stainless steel cable 7x7x19 is best beacause this cable is very flexible and more easy to work. I install these cables in 1999 on my monowheel; it is interesting if your aircraft is parked near the coast (sea) or if the place where you park is very wet. Note the effort on these cables on the Europa are very low. Also if it is possible install a shrink thermo molding sleeve over the Nicopress because they are sometimes agressive. I agree with David, my cables run into the teflon sleeve, not in full lenght but to 3 meters inside the cockpit module where there is friction possible to others components for protection. Michel AUVRAY Mono 145 Le 02/03/2014 18:48, David Joyce a crit : > > > One tip for those installing rudder cables in a mono is to run them > inside the light plastic tubing (used extensively in gliders) through > the wheel well. It is virtually friction free and protects them > entirely from damp & grit. > Regards, David Joyce, GXSDJ > > > Mike Baker wrote: >> Mil-DTL-83420 is the general spec that describes the requirements >> flight control cables >> Composition A - Carbon steel, zinc, or tin over zinc coated >> steel cable is stronger and stiffer than corrosion resistant steel >> >> MIL-DTL-83420/1 - Wire Rope, Flexible, Type I, Composition A. >> M83420/1-005 Indicates - Wire Rope, Flexible, Type I, Carbon Steel, >> Construction; 7 x 19, Nominal Diameter 5/32 >> >> Composition B - Corrosion resistant steel >> MIL-DTL-83420/2 - Wire Rope, Flexible, Type I, Composition B. >> MIL-DTL-781 - Terminal, Wire Rope Swaging, General Specification for. >> >> use this info to find the spec of cable you have >> the nicopress is usable on either. best to ck spec on swaging >> the best place I know of for flight control cables is Mcfarlane >> aviation (USA) also a good source for other "stuff" >> >> >> >> >> >> ________________________________ >> From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> >> To: "europa-list(at)matronics.com" Sent: >> Sunday, March 2, 2014 4:14 AM >> Subject: Re: Europa-List: Europa or Stainless Steel Control Cable >> >> >> >> Yes, stainless was developed for yachts, sea water contamination >> resistant. There isn't much bending in the Europa so no worries about >> fatigue. >> Must be the multi strand stuff though, 7X19 springs to mind but >> anyway it's fine wire strands for flexibility. >> Graham >> >> Also be sure you use the right crimps, plated I think, not plain >> copper. Get a second opinion, I not as young as I once was! >> >> >> >> >> >> ________________________________ >> From: Tony Renshaw <tonyrenshaw268(at)gmail.com> >> To: GRAHAM SINGLETON ; >> europa-list(at)matronics.com Sent: Sunday, 2 March 2014, 6:04 >> Subject: Re: Europa-List: Europa or Stainless Steel Control Cable >> >> >> >> Hi Graham, >> Wish I knew if it was what was supplied by Europa. Ive had the kit >> too long to know, things have been moved around, and I dont recall >> the Europa stuff ever being labelled. >> Maybe someone else might be able to clarify. Worst part is, it looks >> old even though it mightnt be. It reminds me of a Hills Hoist >> outside clothes line cable, but I think that is more of an Aussie >> thing. I actually dont have enough Nicopress sleeves now so Ill >> need more of those anyway, so I can get some more pretty stuff ;-) >> You normally use Stainless Steel cable by choice dont you?? >> TR >> >> >> >> >> On 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON >> wrote: >> >> Tony >>> I'd say go ahead with the galvanised steel cable. It should be fine >>> in Oz, so long as you don't go >>> ocean sailing with it! >>> Graham >>> >>> >>> >>> >>> >>> >>> ________________________________ >>> From: Tony Renshaw <tonyrenshaw268(at)gmail.com> >>> To: europa-list(at)matronics.com >>> Sent: Saturday, 1 March 2014, 22:49 >>> Subject: Europa-List: Europa or Stainless Steel Control Cable >>> >>> >>> >>> >>> Gidday, >>> I have gone through my fair share of cable, and consequently I have >>> bits everywhere. I have a roll of cable which appears to be >>> galvanised, or really dull Stainless Steel, which I believe doesnt >>> happen. Why have nice shiny Stainless, if it stains. So, the best >>> advice I have to figure out what is what is to use a magnet. The >>> unknown roll of dull cable I have is extremely attractive to the >>> magnet, and the Stainless is only slightly, but still is drawn >>> towards the magnet on a really long suspended run, like the length in >> the aft fuselage, towards the magnet when it is mm away, but it still >> attracts it. So, this other roll I can only imagine might have been >> that supplied by Europa, and I wouldnt know because this roll has no >> product code or numbers on it. >>> My question, whilst Id prefer to use Stainless just because it >>> doesnt look like it has been in the aircraft for a million years, >>> however the gal cable (or whatever it is) I am told is more durable >>> especially in terms of bends. This is a conservative approach from >>> gliders where control cabling can have acute bends, but we dont >>> have that. So, should I resurrect this roll of cable out of my waste >>> bin and use it, or should I replace it with Stainless Steel? >>> Thanks for any advice or help, and I appreciate all the help Ive >>> got with this sofar. >>> Regards >>> Tony Renshawhttp://forums.matronics.com >>> >>> >>> >>> >>> >>> href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List >>> >> href="http://forums.matronics.com/">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >>> >> >> http://www.matronics.com/Navigator?Europa-List >> http://======================= ================ > > ________________________________________________________________________________
Subject: Re: Rudder Pedal Step Stretching
Date: Mar 02, 2014
Hey tony is this what you mean? http://www.theeuropaclub.org/wp-content/uploads/2011/12/10665-Bigfoot.pdf It's on the europa club site mod number 10665 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419695#419695 ________________________________________________________________________________
Date: Mar 03, 2014
Chaps, The LAA mod process is slow but does not need to be expensive, the rate of charges to submit a new mod is in fact quite low. For a new full width panel there would be little stress justification required and no testing. The current panel profile and stiffness have never, to my knowledge, been subjected to any form of compliance testing (nor are there any specific requirements). The revised panel, to full width would need to be shown to have zero or negligible effect on visibility, be shown to have sufficient margins of strength in the means of fastening it to the fuselage, allow full stick movement and not impede exit in the case of an emergency. Much of the above are common sense, wordy type submissions. The stress work involves simple sums to show the shear forces and bending moments applied to the fuselage via the attachments are good. Frans in Holland did a nice job of his full width panel. It seems like a sensible starting point for anyone doing the same. I started the process myself a few years ago (purchasing the club spare panel) but ended up with an articulated mount for an iPad instead - see pictures of GIPOD on 'airlines' etc. Regards John -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419698#419698 ________________________________________________________________________________
Subject: Re: utf-8?Q?Re:_Europa-List:_Europa_or_Stainless_Steel_Control_Cable?
Date: Mar 03, 2014
SGkgRGF2aWQsDQoNCldoaWxzdCBJIGRvIG5vdCBkaXNhZ3JlZSB3aXRoIHRoZSBhZHZhbnRhZ2Vz IG9mIHBsYXN0aWMgdHViaW5nIGJlaW5nIHVzZWQgaW4gdGhpcyBtYW5uZXIsIGFzIGFuIGluc3Bl Y3RvciB3aG8gZWFjaCB5ZWFyIGlzIHJlcXVpcmVkIGJ5IExBQSB0byBjZXJ0aWZ5IHRoZSBjb25k aXRpb24gb2YgdGhlc2UgY2FibGVzLCBJIGhhdmUgdG8gYWRkIHRoYXQgaXQgaXMgaW1wb3NzaWJs ZSB0byBpbnNwZWN0IGNhYmxlcyB0aGF0IGFyZSBpbnNpZGUgYSBwbGFzdGljIHR1YmUuICBUaG9z ZSB3aG8gaGF2ZSBnb25lIGRvd24gdGhpcyByb3V0ZSBmb3IgcHJvdGVjdGlvbiB3aWxsIGJlIGF3 YXJlIG9mIHRoZSB3b3JrIGludm9sdmVkIGluIGdhaW5pbmcgdmlzdWFsIGFjY2VzcyB0byB0aGUg ZW50aXJlIGxlbmd0aCBvZiBjYWJsZSB0aGF0IGxpZXMgb3V0IG9mIHNpZ2h0Lg0KDQpQZXRlICBK ZWZmZXJzICBMQUEgSW5zcC4NCg0KDQoNCg0KDQoNCkZyb206IERhdmlkIEpveWNlDQpTZW50OiDi gI5TdW5kYXnigI4sIOKAjjLigI4g4oCOTWFyY2jigI4g4oCOMjAxNCDigI4xN+KAjjrigI40OA0K VG86IGV1cm9wYS1saXN0QG1hdHJvbmljcy5jb20NCg0KDQoNCg0KDQotLT4gRXVyb3BhLUxpc3Qg bWVzc2FnZSBwb3N0ZWQgYnk6ICJEYXZpZCBKb3ljZSIgPGRhdmlkam95Y2VAZG9jdG9ycy5vcmcu dWs+DQoNCk9uZSB0aXAgZm9yIHRob3NlIGluc3RhbGxpbmcgcnVkZGVyIGNhYmxlcyBpbiBhIG1v bm8gaXMgdG8gDQpydW4gdGhlbSBpbnNpZGUgdGhlIGxpZ2h0IHBsYXN0aWMgdHViaW5nICh1c2Vk IGV4dGVuc2l2ZWx5IA0KaW4gZ2xpZGVycykgdGhyb3VnaCB0aGUgd2hlZWwgd2VsbC4gSXQgaXMg dmlydHVhbGx5IA0KZnJpY3Rpb24gZnJlZSBhbmQgcHJvdGVjdHMgdGhlbSBlbnRpcmVseSBmcm9t IGRhbXAgJiBncml0Lg0KUmVnYXJkcywgRGF2aWQgSm95Y2UsIEdYU0RKDQoNCg0KT24gU3VuLCAy IE1hciAyMDE0IDA4OjU1OjA3IC0wODAwIChQU1QpDQogIE1pa2UgQmFrZXIgPGdhbGFoYXZAeWFo b28uY29tPiB3cm90ZToNCj4gTWlsLURUTC04MzQyMCBpcyB0aGUgZ2VuZXJhbCBzcGVjIHRoYXQg ZGVzY3JpYmVzIHRoZSANCj5yZXF1aXJlbWVudHMgZmxpZ2h0IGNvbnRyb2wgY2FibGVzDQo+ICBD b21wb3NpdGlvbiBBIC0gQ2FyYm9uIHN0ZWVsLCB6aW5jLCBvciB0aW4gb3ZlciB6aW5jIA0KPmNv YXRlZA0KPiBzdGVlbCBjYWJsZSBpcyBzdHJvbmdlciBhbmQgc3RpZmZlciB0aGFuIGNvcnJvc2lv biANCj5yZXNpc3RhbnQgc3RlZWwgDQo+ICANCj4gTUlMLURUTC04MzQyMC8xIC0gV2lyZSBSb3Bl LCBGbGV4aWJsZSwgVHlwZSBJLCANCj5Db21wb3NpdGlvbiBBLg0KPiAgTTgzNDIwLzEtMDA1IElu ZGljYXRlcyAtIFdpcmUgUm9wZSwgRmxleGlibGUsIFR5cGUgSSwgDQo+Q2FyYm9uIFN0ZWVsLA0K PiBDb25zdHJ1Y3Rpb247IDcgeCAxOSwgTm9taW5hbCBEaWFtZXRlciA1LzMyDQo+ICANCj4gQ29t cG9zaXRpb24gQiAtIENvcnJvc2lvbiByZXNpc3RhbnQgc3RlZWwNCj4gTUlMLURUTC04MzQyMC8y IC0gV2lyZSBSb3BlLCBGbGV4aWJsZSwgVHlwZSBJLCANCj5Db21wb3NpdGlvbiBCLg0KPiAgTUlM LURUTC03ODEgLSBUZXJtaW5hbCwgV2lyZSBSb3BlIFN3YWdpbmcsIEdlbmVyYWwgDQo+U3BlY2lm aWNhdGlvbiBmb3IuDQo+ICANCj4gdXNlIHRoaXMgaW5mbyB0byBmaW5kIHRoZSBzcGVjIG9mIGNh YmxlIHlvdSBoYXZlDQo+IHRoZSBuaWNvcHJlc3MgaXMgdXNhYmxlIG9uIGVpdGhlci4gYmVzdCB0 byBjayBzcGVjIG9uIA0KPnN3YWdpbmcgDQo+ICANCj4gdGhlIGJlc3QgcGxhY2UgSSBrbm93IG9m IGZvciBmbGlnaHQgY29udHJvbCBjYWJsZXMgaXMgDQo+TWNmYXJsYW5lIGF2aWF0aW9uIChVU0Ep IA0KPiBhbHNvIGEgZ29vZCBzb3VyY2UgZm9yIG90aGVyICJzdHVmZiINCj4gIA0KPiAgDQo+ICAN Cj4gDQo+IA0KPiBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KPiBGcm9tOiBHUkFI QU0gU0lOR0xFVE9OIDxncmFoYW1zaW5nbGV0b25AYnRpbnRlcm5ldC5jb20+DQo+IFRvOiAiZXVy b3BhLWxpc3RAbWF0cm9uaWNzLmNvbSIgDQo+PGV1cm9wYS1saXN0QG1hdHJvbmljcy5jb20+IA0K PiBTZW50OiBTdW5kYXksIE1hcmNoIDIsIDIwMTQgNDoxNCBBTQ0KPiBTdWJqZWN0OiBSZTogRXVy b3BhLUxpc3Q6IEV1cm9wYSBvciBTdGFpbmxlc3MgU3RlZWwgDQo+Q29udHJvbCBDYWJsZQ0KPiAg DQo+IA0KPiANCj4gWWVzLCBzdGFpbmxlc3Mgd2FzIGRldmVsb3BlZCBmb3IgeWFjaHRzLCBzZWEg d2F0ZXIgDQo+Y29udGFtaW5hdGlvbiByZXNpc3RhbnQuIFRoZXJlIGlzbid0IG11Y2ggYmVuZGlu ZyBpbiB0aGUgDQo+RXVyb3BhIHNvIG5vIHdvcnJpZXMgYWJvdXQgZmF0aWd1ZS4NCj4gTXVzdCBi ZSB0aGUgbXVsdGkgc3RyYW5kIHN0dWZmIHRob3VnaCwgN1gxOSBzcHJpbmdzIHRvIA0KPm1pbmQg YnV0IGFueXdheSBpdCdzIGZpbmUgd2lyZSBzdHJhbmRzIGZvciBmbGV4aWJpbGl0eS4NCj4gR3Jh aGFtDQo+IA0KPiBBbHNvIGJlIHN1cmUgeW91IHVzZSB0aGUgcmlnaHQgY3JpbXBzLCBwbGF0ZWQg SSB0aGluaywgDQo+bm90IHBsYWluIGNvcHBlci4gR2V0IGEgc2Vjb25kIG9waW5pb24sIEkgbm90 IGFzIHlvdW5nIGFzIA0KPkkgb25jZSB3YXMhDQo+IA0KPiANCj4gDQo+IA0KPiANCj4gX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX18NCj4gRnJvbTogVG9ueSBSZW5zaGF3IDx0b255cmVu c2hhdzI2OEBnbWFpbC5jb20+DQo+IFRvOiBHUkFIQU0gU0lOR0xFVE9OIDxncmFoYW1zaW5nbGV0 b25AYnRpbnRlcm5ldC5jb20+OyANCj5ldXJvcGEtbGlzdEBtYXRyb25pY3MuY29tIA0KPiBTZW50 OiBTdW5kYXksIDIgTWFyY2ggMjAxNCwgNjowNA0KPiBTdWJqZWN0OiBSZTogRXVyb3BhLUxpc3Q6 IEV1cm9wYSBvciBTdGFpbmxlc3MgU3RlZWwgDQo+Q29udHJvbCBDYWJsZQ0KPiAgDQo+IA0KPiAN Cj4gSGkgR3JhaGFtLA0KPiBXaXNoIEkga25ldyBpZiBpdCB3YXMgd2hhdCB3YXMgc3VwcGxpZWQg YnkgRXVyb3BhLiBJ4oCZdmUgDQo+aGFkIHRoZSBraXQgdG9vIGxvbmcgdG8ga25vdywgdGhpbmdz IGhhdmUgYmVlbiBtb3ZlZCANCj5hcm91bmQsIGFuZCBJIGRvbuKAmXQgcmVjYWxsIHRoZSBFdXJv cGEgc3R1ZmYgZXZlciBiZWluZyANCj5sYWJlbGxlZC4gDQo+IE1heWJlIHNvbWVvbmUgZWxzZSBt aWdodCBiZSBhYmxlIHRvIGNsYXJpZnkuIFdvcnN0IHBhcnQgDQo+aXMsIGl0IGxvb2tzIG9sZCBl dmVuIHRob3VnaCBpdCBtaWdodG7igJl0IGJlLiBJdCByZW1pbmRzIA0KPm1lIG9mIGEgSGlsbHMg SG9pc3Qgb3V0c2lkZSBjbG90aGVzIGxpbmUgY2FibGUsIGJ1dCBJIA0KPnRoaW5rIHRoYXQgaXMg bW9yZSBvZiBhbiBBdXNzaWUgdGhpbmcuIEkgYWN0dWFsbHkgZG9u4oCZdCANCj5oYXZlIGVub3Vn aCBOaWNvcHJlc3Mgc2xlZXZlcyBub3cgc28gSeKAmWxsIG5lZWQgbW9yZSBvZiANCj50aG9zZSBh bnl3YXksIHNvIEkgY2FuIGdldCBzb21lIG1vcmUgcHJldHR5IHN0dWZmIDstKQ0KPiBZb3Ugbm9y bWFsbHkgdXNlIFN0YWlubGVzcyBTdGVlbCBjYWJsZSBieSBjaG9pY2UgZG9u4oCZdCANCj55b3U/ Pw0KPiBUUg0KPiANCj4gDQo+IA0KPiANCj4gT24gMiBNYXIgMjAxNCwgYXQgMTA6MTggYW0sIEdS QUhBTSBTSU5HTEVUT04gDQo+PGdyYWhhbXNpbmdsZXRvbkBidGludGVybmV0LmNvbT4gd3JvdGU6 DQo+IA0KPiBUb255DQo+PkknZCBzYXkgZ28gYWhlYWQgd2l0aCB0aGUgZ2FsdmFuaXNlZCBzdGVl bCBjYWJsZS4gSXQgDQo+PnNob3VsZCBiZSBmaW5lIGluIE96LCBzbyBsb25nIGFzIHlvdSBkb24n dCBnbyANCj4+b2NlYW4gc2FpbGluZyB3aXRoIGl0IQ0KPj5HcmFoYW0NCj4+DQo+Pg0KPj4NCj4+ DQo+Pg0KPj4NCj4+X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCj4+RnJvbTogVG9u eSBSZW5zaGF3IDx0b255cmVuc2hhdzI2OEBnbWFpbC5jb20+DQo+PlRvOiBldXJvcGEtbGlzdEBt YXRyb25pY3MuY29tIA0KPj5TZW50OiBTYXR1cmRheSwgMSBNYXJjaCAyMDE0LCAyMjo0OQ0KPj5T dWJqZWN0OiBFdXJvcGEtTGlzdDogRXVyb3BhIG9yIFN0YWlubGVzcyBTdGVlbCBDb250cm9sIA0K Pj5DYWJsZQ0KPj4NCj4+DQo+Pi0tPiBFdXJvcGEtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogVG9u eSBSZW5zaGF3IA0KPj48dG9ueXJlbnNoYXcyNjhAZ21haWwuY29tPg0KPj4NCj4+R2lkZGF5LA0K Pj5JIGhhdmUgZ29uZSB0aHJvdWdoIG15IGZhaXIgc2hhcmUgb2YgY2FibGUsIGFuZCANCj4+Y29u c2VxdWVudGx5IEkgaGF2ZSBiaXRzIGV2ZXJ5d2hlcmUuIEkgaGF2ZSBhIHJvbGwgb2YgDQo+PmNh YmxlIHdoaWNoIGFwcGVhcnMgdG8gYmUgZ2FsdmFuaXNlZCwgb3IgcmVhbGx5IGR1bGwgDQo+PlN0 YWlubGVzcyBTdGVlbCwgd2hpY2ggSSBiZWxpZXZlIGRvZXNu4oCZdCBoYXBwZW4uIFdoeSBoYXZl IA0KPj5uaWNlIHNoaW55IFN0YWlubGVzcywgaWYgaXQgc3RhaW5zLiBTbywgdGhlIGJlc3QgYWR2 aWNlIEkgDQo+PmhhdmUgdG8gZmlndXJlIG91dCB3aGF0IGlzIHdoYXQgaXMgdG8gdXNlIGEgbWFn bmV0LiBUaGUgDQo+PnVua25vd24gcm9sbCBvZiBkdWxsIGNhYmxlIEkgaGF2ZSBpcyBleHRyZW1l bHkgYXR0cmFjdGl2ZSANCj4+dG8gdGhlIG1hZ25ldCwgYW5kIHRoZSBTdGFpbmxlc3MgaXMgb25s eSBzbGlnaHRseSwgYnV0IA0KPj5zdGlsbCBpcyBkcmF3biB0b3dhcmRzIHRoZSBtYWduZXQgb24g YSByZWFsbHkgbG9uZyANCj4+c3VzcGVuZGVkIHJ1biwgbGlrZSB0aGUgbGVuZ3RoIGluDQo+IHRo ZSBhZnQgZnVzZWxhZ2UsIHRvd2FyZHMgdGhlIG1hZ25ldCB3aGVuIGl0IGlzIG1tIGF3YXksIA0K PmJ1dCBpdCBzdGlsbCBhdHRyYWN0cyBpdC4gU28sIHRoaXMgb3RoZXIgcm9sbCBJIGNhbiBvbmx5 IA0KPmltYWdpbmUgbWlnaHQgaGF2ZSBiZWVuIHRoYXQgc3VwcGxpZWQgYnkgRXVyb3BhLCBhbmQg SSANCj53b3VsZG7igJl0IGtub3cgYmVjYXVzZSB0aGlzIHJvbGwgaGFzIG5vIHByb2R1Y3QgY29k ZSBvciANCj5udW1iZXJzIG9uIGl0LiANCj4+TXkgcXVlc3Rpb24sIHdoaWxzdCBJ4oCZZCBwcmVm ZXIgdG8gdXNlIFN0YWlubGVzcyBqdXN0IA0KPj5iZWNhdXNlIGl0IGRvZXNu4oCZdCBsb29rIGxp a2UgaXQgaGFzIGJlZW4gaW4gdGhlIGFpcmNyYWZ0IA0KPj5mb3IgYSBtaWxsaW9uIHllYXJzLCBo b3dldmVyIHRoZSBnYWwgY2FibGUgKG9yIHdoYXRldmVyIA0KPj5pdCBpcykgSSBhbSB0b2xkIGlz IG1vcmUgZHVyYWJsZSBlc3BlY2lhbGx5IGluIHRlcm1zIG9mIA0KPj5iZW5kcy4gVGhpcyBpcyBh IGNvbnNlcnZhdGl2ZSBhcHByb2FjaCBmcm9tIGdsaWRlcnMgd2hlcmUgDQo+PmNvbnRyb2wgY2Fi bGluZyBjYW4gaGF2ZSBhY3V0ZSBiZW5kcywgYnV0IHdlIGRvbuKAmXQgaGF2ZSANCj4+dGhhdC4g U28sIHNob3VsZCBJIHJlc3VycmVjdCB0aGlzIHJvbGwgb2YgY2FibGUgb3V0IG9mIG15IA0KPj53 YXN0ZSBiaW4gYW5kIHVzZSBpdCwgb3Igc2hvdWxkIEkgcmVwbGFjZSBpdCB3aXRoIA0KPj5TdGFp bmxlc3MgU3RlZWw/DQo+PlRoYW5rcyBmb3IgYW55IGFkdmljZSBvciBoZWxwLCBhbmQgSSBhcHBy ZWNpYXRlIGFsbCB0aGUgDQo+PmhlbHAgSeKAmXZlIGdvdCB3aXRoIHRoaXMgc29mYXIuIA0KPj5S ZWdhcmRzDQo+PlRvbnkgUmVuc2hhd2h0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPj4NCj4+ DQo+Pg0KPj4NCj4+DQo+PmhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ RXVyb3BhLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/RXVyb3BhLUxp c3QNCj4gaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLyI+aHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tDQo+IGhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRp b24iPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24gDQo+Pg0KPiANCj4gaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9FdXJvcGEtTGlzdCANCj5odHRwOi8vPT09 PT09PT09PT09PT09PT09PT09PT0gDQo+ID09PT09PT09PT09PT09PT0gDQoNCl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0g ICAgICAgICAgLSBUaGUgRXVyb3BhLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0 cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExp c3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBT ZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFy ZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL05hdmlnYXRvcj9FdXJvcGEtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAg ICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28g YXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1 bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250 cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3Vw cG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlz dCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9u DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ= ________________________________________________________________________________
Date: Mar 03, 2014
Pete, My use of the tube, approved by my inspector (in fact suggested by him) is simply to cover the gap across the wheel well. It is fixed there with a cable tie and can readily be slid fore or aft for inspection. Regards, David (Joyce) wrote: > Hi David, > > Whilst I do not disagree with the advantages of plastic >tubing being used in this manner, as an inspector who >each year is required by LAA to certify the condition of >these cables, I have to add that it is impossible to >inspect cables that are inside a plastic tube. Those who >have gone down this route for protection will be aware of >the work involved in gaining visual access to the entire >length of cable that lies out of sight. > > Pete Jeffers LAA Insp. > > > > > > >From: David Joyce > Sent: Sunday, 2 March 2014 17:48 > To: europa-list(at)matronics.com > > > > > > > > One tip for those installing rudder cables in a mono is >to > run them inside the light plastic tubing (used >extensively > in gliders) through the wheel well. It is virtually > friction free and protects them entirely from damp & >grit. > Regards, David Joyce, GXSDJ > > > Mike Baker wrote: >> Mil-DTL-83420 is the general spec that describes the >>requirements flight control cables >> Composition A - Carbon steel, zinc, or tin over zinc >>coated >> steel cable is stronger and stiffer than corrosion >>resistant steel >> >> MIL-DTL-83420/1 - Wire Rope, Flexible, Type I, >>Composition A. >> M83420/1-005 Indicates - Wire Rope, Flexible, Type I, >>Carbon Steel, >> Construction; 7 x 19, Nominal Diameter 5/32 >> >> Composition B - Corrosion resistant steel >> MIL-DTL-83420/2 - Wire Rope, Flexible, Type I, >>Composition B. >> MIL-DTL-781 - Terminal, Wire Rope Swaging, General >>Specification for. >> >> use this info to find the spec of cable you have >> the nicopress is usable on either. best to ck spec on >>swaging >> >> the best place I know of for flight control cables is >>Mcfarlane aviation (USA) >> also a good source for other "stuff" >> >> >> >> >> >> ________________________________ >> From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> >> To: "europa-list(at)matronics.com" >> >> Sent: Sunday, March 2, 2014 4:14 AM >> Subject: Re: Europa-List: Europa or Stainless Steel >>Control Cable >> >> >> >> Yes, stainless was developed for yachts, sea water >>contamination resistant. There isn't much bending in the >>Europa so no worries about fatigue. >> Must be the multi strand stuff though, 7X19 springs to >>mind but anyway it's fine wire strands for flexibility. >> Graham >> >> Also be sure you use the right crimps, plated I think, >>not plain copper. Get a second opinion, I not as young as >>I once was! >> >> >> >> >> >> ________________________________ >> From: Tony Renshaw <tonyrenshaw268(at)gmail.com> >> To: GRAHAM SINGLETON ; >>europa-list(at)matronics.com >> Sent: Sunday, 2 March 2014, 6:04 >> Subject: Re: Europa-List: Europa or Stainless Steel >>Control Cable >> >> >> >> Hi Graham, >> Wish I knew if it was what was supplied by Europa. Ive >>had the kit too long to know, things have been moved >>around, and I dont recall the Europa stuff ever being >>labelled. >> Maybe someone else might be able to clarify. Worst part >>is, it looks old even though it mightnt be. It reminds >>me of a Hills Hoist outside clothes line cable, but I >>think that is more of an Aussie thing. I actually dont >>have enough Nicopress sleeves now so Ill need more of >>those anyway, so I can get some more pretty stuff ;-) >> You normally use Stainless Steel cable by choice dont >>you?? >> TR >> >> >> >> >> On 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON >> wrote: >> >> Tony >>>I'd say go ahead with the galvanised steel cable. It >>>should be fine in Oz, so long as you don't go >>>ocean sailing with it! >>>Graham >>> >>> >>> >>> >>> >>> >>>________________________________ >>>From: Tony Renshaw <tonyrenshaw268(at)gmail.com> >>>To: europa-list(at)matronics.com >>>Sent: Saturday, 1 March 2014, 22:49 >>>Subject: Europa-List: Europa or Stainless Steel Control >>>Cable >>> >>> >>> >>> >>>Gidday, >>>I have gone through my fair share of cable, and >>>consequently I have bits everywhere. I have a roll of >>>cable which appears to be galvanised, or really dull >>>Stainless Steel, which I believe doesnt happen. Why have >>>nice shiny Stainless, if it stains. So, the best advice I >>>have to figure out what is what is to use a magnet. The >>>unknown roll of dull cable I have is extremely attractive >>>to the magnet, and the Stainless is only slightly, but >>>still is drawn towards the magnet on a really long >>>suspended run, like the length in >> the aft fuselage, towards the magnet when it is mm away, >>but it still attracts it. So, this other roll I can only >>imagine might have been that supplied by Europa, and I >>wouldnt know because this roll has no product code or >>numbers on it. >>>My question, whilst Id prefer to use Stainless just >>>because it doesnt look like it has been in the aircraft >>>for a million years, however the gal cable (or whatever >>>it is) I am told is more durable especially in terms of >>>bends. This is a conservative approach from gliders where >>>control cabling can have acute bends, but we dont have >>>that. So, should I resurrect this roll of cable out of my >>>waste bin and use it, or should I replace it with >>>Stainless Steel? >>>Thanks for any advice or help, and I appreciate all the >>>help Ive got with this sofar. >>>Regards >>>Tony Renshawhttp://forums.matronics.com >>> >>> >>> >>> >>> >>>href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List >> href="http://forums.matronics.com/">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >>> >> >> http://www.matronics.com/Navigator?Europa-List >>http://======================= >> ================ > >Un/Subscription, >Forums! >Admin. ________________________________________________________________________________
Date: Mar 03, 2014
Subject: Re: Europa or Stainless Steel Control Cable
imho plastic tube is a good idea. If the tube is split the cable can be spr ung out of it for =0Ainspection , then popped back in. I think Lancairs spe cify nylon tube to duct the rudder cables.=0AA few of those in the UK. Find an inspector who does Lancairs?=0AGraham=0A=0A=0A=0A=0A___________________ _____________=0A From: David Joyce <davidjoyce(at)doctors.org.uk>=0ATo: europa -list(at)matronics.com =0ASent: Monday, 3 March 2014, 9:09=0ASubject: Re: Euro pa-List: Europa or Stainless Steel Control Cable=0A =0A=0A--> Europa-List m essage posted by: "David Joyce" =0A=0APete, My u se of the tube, approved by my inspector (in fact suggested by him) is simp ly to cover the gap across the wheel well. It is fixed there with a cable t ie and can readily be slid fore or aft for inspection. Regards, David (Joyc e:=0A> Hi David,=0A> =0A> Whilst I do not disagree with the advantages of p lastic tubing being used in this manner, as an inspector who each year is r equired by LAA to certify the condition of these cables, I have to add that it is impossible to inspect cables that are inside a plastic tube.=C2- T hose who have gone down this route for protection will be aware of the work involved in gaining visual access to the entire length of cable that lies out of sight.=0A> =0A> Pete=C2- Jeffers=C2- LAA Insp.=0A> =0A> =0A> =0A > =0A> =0A> =0A> From: David Joyce=0A> Sent: =8ESunday=8E, =8E2=8E =8EMarch=8E =8E2014 =8E17=8E :=8E48=0A> To: europa-list(at)matronics.com=0A> =0A> =0A> =0A> =0A> =0A> k>=0A> =0A> One tip for those installing rudder cables in a mono is to run them inside the light plastic tubing (used extensively in gliders) through the wheel well. It is virtually friction free and protects them entirely fr om damp & grit.=0A> Regards, David Joyce, GXSDJ=0A> =0A> =0A> On Sun, 2 Mar =0A>> Mil-DTL-83420 is the general spec that describes the requirements fli ght control cables=0A>>=C2- Composition A - Carbon steel, zinc, or tin ov er zinc coated=0A>> steel cable is stronger and stiffer than corrosion resi stant steel=C2- MIL-DTL-83420/1 - Wire Rope, Flexible, Type I, Compositio n A.=0A>>=C2- M83420/1-005 Indicates - Wire Rope, Flexible, Type I, Carbo n Steel,=0A>> Construction; 7 x 19, Nominal Diameter 5/32=0A>>=C2- Compos ition B - Corrosion resistant steel=0A>> MIL-DTL-83420/2 - Wire Rope, Flexi ble, Type I, Composition B.=0A>>=C2- MIL-DTL-781 - Terminal, Wire Rope Sw aging, General Specification for.=0A>>=C2- use this info to find the spec of cable you have=0A>> the nicopress is usable on either. best to ck spec on swaging=C2- the best place I know of for flight control cables is Mcfa rlane aviation (USA) also a good source for other "stuff"=0A>>=C2- =C2- =0A>> =0A>> ________________________________=0A>> From: GRAHAM SINGLETON < grahamsingleton(at)btinternet.com>=0A>> To: "europa-list(at)matronics.com" Sent: Sunday, March 2, 2014 4:14 AM=0A>> Subject: Re: Europa-List: Europa or Stainless Steel Control Cable=0A>>=C2- =0A>> =0A> > Yes, stainless was developed for yachts, sea water contamination resistan t. There isn't much bending in the Europa so no worries about fatigue.=0A>> Must be the multi strand stuff though, 7X19 springs to mind but anyway it' s fine wire strands for flexibility.=0A>> Graham=0A>> =0A>> Also be sure yo u use the right crimps, plated I think, not plain copper. Get a second opin ion, I not as young as I once was!=0A>> =0A>> =0A>> =0A>> =0A>> =0A>> _____ ___________________________=0A>> From: Tony Renshaw <tonyrenshaw268(at)gmail.c om>=0A>> To: GRAHAM SINGLETON ; europa-list @matronics.com Sent: Sunday, 2 March 2014, 6:04=0A>> Subject: Re: Europa-Li st: Europa or Stainless Steel Control Cable=0A>>=C2- =0A>> =0A>> Hi Graha m,=0A>> Wish I knew if it was what was supplied by Europa. I=99ve had the kit too long to know, things have been moved around, and I don =99t recall the Europa stuff ever being labelled. Maybe someone else might be able to clarify. Worst part is, it looks old even though it mightn =99t be. It reminds me of a Hills Hoist outside clothes line cable, but I t hink that is more of an Aussie thing. I actually don=99t have enough Nicopress sleeves now so I=99ll need more of those anyway, so I can g et some more pretty stuff ;-)=0A>> You normally use Stainless Steel cable b y choice don=99t you??=0A>> TR=0A>> =0A>> =0A>> =0A>> =0A>> On 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON wrote: =0A>> =0A>> Tony=0A>>> I'd say go ahead with the galvanised steel cable. It should be fine in Oz, so long as you don't go ocean sailing with it!=0A>>> Graham=0A>>> =0A>>> =0A>>> =0A>>> =0A>>> =0A>>> =0A>>> ___________________ _____________=0A>>> From: Tony Renshaw <tonyrenshaw268(at)gmail.com>=0A>>> To: europa-list(at)matronics.com Sent: Saturday, 1 March 2014, 22:49=0A>>> Subjec t: Europa-List: Europa or Stainless Steel Control Cable=0A>>> =0A>>> =0A>>> =0A>>> =0A>>> Gidday,=0A>>> I have gone through my fair share of cable, and consequently I have bits everywhere. I have a roll of cable which appears to be galvanised, or really dull Stainless Steel, which I believe doesn =99t happen. Why have nice shiny Stainless, if it stains. So, the best a dvice I have to figure out what is what is to use a magnet. The unknown rol l of dull cable I have is extremely attractive to the magnet, and the Stain less is only slightly, but still is drawn towards the magnet on a really lo ng suspended run, like the length in=0A>> the aft fuselage, towards the mag net when it is mm away, but it still attracts it. So, this other roll I can only imagine might have been that supplied by Europa, and I wouldn =99t know because this roll has no product code or numbers on it. =0A>>> My question, whilst I=99d prefer to use Stainless just because it doesn =99t look like it has been in the aircraft for a million years, howev er the gal cable (or whatever it is) I am told is more durable especially i n terms of bends. This is a conservative approach from gliders where contro l cabling can have acute bends, but we don=99t have that. So, should I resurrect this roll of cable out of my waste bin and use it, or should I replace it with Stainless Steel?=0A>>> Thanks for any advice or help, and I appreciate all the help I=99ve got with this sofar. Regards=0A>>> To ny Renshawhttp://forums.matronics.com=0A>>> =0A>>> =0A>>> =0A>>> =0A>>> =0A >>> href="http://www.matronics.com/Navigator?Europa-List">http://www.matr onics.com/Navigator?Europa-List=0A>> href="http://forums.matronics.com/"> http://forums.matronics.com=0A>> href="http://www.matronics.com/contribut ion">http://www.matronics.com/contribution =0A>>> =0A>> =0A>> http://www.ma tronics.com/Navigator?Europa-List http://=========== ============ ============ ==C2- =C2- =C2- =C2- =C2- =C2- =C2- - MATRONICS WEB FORUMS ==C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- ________________________________________________________________________________
Date: Mar 03, 2014
Pete If turnbuckles are installed in the rear fuselage it is a simple matter to disconnect the cables at the turnbuckles and draw the cable forward from the rudder pedal end to inspect the hidden portion of cable. Lance Sandford in OZ On 03/03/14 18:55, pjeffers(at)talktalk.net wrote: > Hi David, > Whilst I do not disagree with the advantages of plastic tubing being > used in this manner, as an inspector who each year is required by LAA > to certify the condition of these cables, I have to add that it is > impossible to inspect cables that are inside a plastic tube. Those > who have gone down this route for protection will be aware of the work > involved in gaining visual access to the entire length of cable that > lies out of sight. > Pete Jeffers LAA Insp. > > ________________________________________________________________________________
Subject: EASA noise certificate
Date: Mar 03, 2014
Hi all, In order to renew a special airworthness certificate (permit to fly) I need a copy of EASA noise certificate of a Europa XS trigear with Rotax 914 fitted with a groud adjustable Warp drive propeller with C or N blades. Anybody out there who can help me out ? Kees de Bussy PH-GOO (previous F-PSMU) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419703#419703 ________________________________________________________________________________
Date: Mar 03, 2014
Hi Craig and co. I want to put 75 mm onto the shelf, bringing it aft into the footwell, to give me a place for my heels. Is that a dumb idea because only being 5 9 or 175 cm, I think my legs will easily fit, and I imagine because of the upright nature of the pedals at neutral, that it might be nice to build a heel support. Bad idea??? TR On 3 Mar 2014, at 10:00 pm, craig wrote: > Yes tony, you can take about 75mm off, I worked out where the mounts were > going to be then cut it back > To leave about 15mm past the end of the rearmost mounts > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw > Sent: Monday, March 03, 2014 12:30 PM > To: europa-list(at)matronics.com > Subject: Europa-List: Rudder Pedal Step Stretching > > > Gidday, > I've heard it mentioned that to extend this step back a bit might make > things more comfortable. Can I get an input on what dimension is > recommended? I've heard about 75 mm would do it, and I will probably build > it into my floor mat mod that I want to do. > Thanks. > Regards > Tony Renshaw > Sydney Aussie > > > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > ________________________________________________________________________________
From: Gerry Holland <gholland@content-stream.co.uk>
Date: Mar 03, 2014
Tony I made some heel rests without all that work. When I get home tonight I'll see if I can find photos. Used aluminium 'rice' plate. Very light and bendable. Gerry Sent from my iPhone > On 3 Mar 2014, at 11:40, Tony Renshaw wrote: > > > Hi Craig and co. > I want to put 75 mm onto the shelf, bringing it aft into the footwell, to give me a place for my heels. Is that a dumb idea because only being 5 9 or 175 cm, I think my legs will easily fit, and I imagine because of the upright nature of the pedals at neutral, that it might be nice to build a heel support. Bad idea??? > > TR > >> On 3 Mar 2014, at 10:00 pm, craig wrote: >> >> Yes tony, you can take about 75mm off, I worked out where the mounts were >> going to be then cut it back >> To leave about 15mm past the end of the rearmost mounts >> >> -----Original Message----- >> From: owner-europa-list-server(at)matronics.com >> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw >> Sent: Monday, March 03, 2014 12:30 PM >> To: europa-list(at)matronics.com >> Subject: Europa-List: Rudder Pedal Step Stretching >> >> >> Gidday, >> I've heard it mentioned that to extend this step back a bit might make >> things more comfortable. Can I get an input on what dimension is >> recommended? I've heard about 75 mm would do it, and I will probably build >> it into my floor mat mod that I want to do. >> Thanks. >> Regards >> Tony Renshaw >> Sydney Aussie >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> > > > > > > ________________________________________________________________________________
Date: Mar 03, 2014
hi Gerry, I have no clue what aluminium =93rice=94 plate is. Look forward to the photos. Thanks. TR On 3 Mar 2014, at 10:50 pm, Gerry Holland <gholland@content-stream.co.uk> wrote: <gholland@content-stream.co.uk> > > Tony > I made some heel rests without all that work. When I get home tonight I'll see if I can find photos. > Used aluminium 'rice' plate. Very light and bendable. > Gerry > > Sent from my iPhone > >> On 3 Mar 2014, at 11:40, Tony Renshaw wrote: >> >> >> Hi Craig and co. >> I want to put 75 mm onto the shelf, bringing it aft into the footwell, to give me a place for my heels. Is that a dumb idea because only being 5=92 9=94 or 175 cm, I think my legs will easily fit, and I imagine because of the upright nature of the pedals at neutral, that it might be nice to build a heel support. Bad idea??? >> >> TR >> >>> On 3 Mar 2014, at 10:00 pm, craig wrote: >>> >>> Yes tony, you can take about 75mm off, I worked out where the mounts were >>> going to be then cut it back >>> To leave about 15mm past the end of the rearmost mounts >>> >>> -----Original Message----- >>> From: owner-europa-list-server(at)matronics.com >>> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw >>> Sent: Monday, March 03, 2014 12:30 PM >>> To: europa-list(at)matronics.com >>> Subject: Europa-List: Rudder Pedal Step Stretching >>> >>> >>> Gidday, >>> I've heard it mentioned that to extend this step back a bit might make >>> things more comfortable. Can I get an input on what dimension is >>> recommended? I've heard about 75 mm would do it, and I will probably build >>> it into my floor mat mod that I want to do. >>> Thanks. >>> Regards >>> Tony Renshaw >>> Sydney Aussie >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> ----- >>> No virus found in this message. >>> Checked by AVG - www.avg.com >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 03, 2014
In his day Dave Bosomworth fixed me up on an emergency basis once when I was at Templhof Berlin ! but it was for a Woodcomp SL 3000 CS prop. but don't split hairs though !!Regards \Bob Harrison G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of kees de bussy Sent: 03 March 2014 11:12 Subject: Europa-List: EASA noise certificate --> Hi all, In order to renew a special airworthness certificate (permit to fly) I need a copy of EASA noise certificate of a Europa XS trigear with Rotax 914 fitted with a groud adjustable Warp drive propeller with C or N blades. Anybody out there who can help me out ? Kees de Bussy PH-GOO (previous F-PSMU) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419703#419703 ________________________________________________________________________________
Date: Mar 03, 2014
IMHO Bad idea . I just put a piece of 1.5" "I" section aluminium across the footwell step and it works for me and I'm 5'9" and on a long flight you will need to practice "walking" with as much room as you can have to prevent the onset of cramp in the legs. Also keep your knee from being near the draught vent more cause for cramp! After a 4hour 30 minute flight to Krems Vienna My choice was to pretend walking like hell or choose landing along or across vineyard wires on fields as for as the eye could see, with tears streaming down my face. Also dose up on a good layer of Quinine tablets ! Regards Bob H G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw Sent: 03 March 2014 11:40 Subject: Re: Europa-List: Rudder Pedal Step Stretching --> Hi Craig and co. I want to put 75 mm onto the shelf, bringing it aft into the footwell, to give me a place for my heels. Is that a dumb idea because only being 5' 9" or 175 cm, I think my legs will easily fit, and I imagine because of the upright nature of the pedals at neutral, that it might be nice to build a heel support. Bad idea??? TR On 3 Mar 2014, at 10:00 pm, craig wrote: > Yes tony, you can take about 75mm off, I worked out where the mounts > were going to be then cut it back To leave about 15mm past the end of > the rearmost mounts > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony > Renshaw > Sent: Monday, March 03, 2014 12:30 PM > To: europa-list(at)matronics.com > Subject: Europa-List: Rudder Pedal Step Stretching > > --> > > Gidday, > I've heard it mentioned that to extend this step back a bit might make > things more comfortable. Can I get an input on what dimension is > recommended? I've heard about 75 mm would do it, and I will probably > build it into my floor mat mod that I want to do. > Thanks. > Regards > Tony Renshaw > Sydney Aussie > > > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Mar 03, 2014
Hi Bob, I know what an "I" section is, but I just can't imagine what you mean. If you said "L" shape, to protect the Trailing edge of the rudder pedal attachment shelf, I would have been with you, but I'm a tad lost. Tony R Sent from my iPad > On 3 Mar 2014, at 11:09 pm, "Bob Harrison" wrote: > > > IMHO Bad idea . I just put a piece of 1.5" "I" section aluminium across the > footwell step and it works for me and I'm 5'9" and on a long flight you will > need to practice "walking" with as much room as you can have to prevent the > onset of cramp in the legs. > Also keep your knee from being near the draught vent more cause for cramp! > After a 4hour 30 minute flight to Krems Vienna My choice was to pretend > walking like hell or choose landing along or across vineyard wires on fields > as for as the eye could see, with tears streaming down my face. Also dose up > on a good layer of Quinine tablets ! > Regards > Bob H G-PTAG > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw > Sent: 03 March 2014 11:40 > To: craig; europa-list(at)matronics.com > Subject: Re: Europa-List: Rudder Pedal Step Stretching > > --> > > Hi Craig and co. > I want to put 75 mm onto the shelf, bringing it aft into the footwell, to > give me a place for my heels. Is that a dumb idea because only being 5' 9" > or 175 cm, I think my legs will easily fit, and I imagine because of the > upright nature of the pedals at neutral, that it might be nice to build a > heel support. Bad idea??? > > TR > >> On 3 Mar 2014, at 10:00 pm, craig wrote: >> >> Yes tony, you can take about 75mm off, I worked out where the mounts >> were going to be then cut it back To leave about 15mm past the end of >> the rearmost mounts >> >> -----Original Message----- >> From: owner-europa-list-server(at)matronics.com >> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony >> Renshaw >> Sent: Monday, March 03, 2014 12:30 PM >> To: europa-list(at)matronics.com >> Subject: Europa-List: Rudder Pedal Step Stretching >> >> --> >> >> Gidday, >> I've heard it mentioned that to extend this step back a bit might make >> things more comfortable. Can I get an input on what dimension is >> recommended? I've heard about 75 mm would do it, and I will probably >> build it into my floor mat mod that I want to do. >> Thanks. >> Regards >> Tony Renshaw >> Sydney Aussie >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > > > > > > > > ________________________________________________________________________________
Date: Mar 03, 2014
Tony .......if you imagine the web of the "I" section being used to bolt about 9" of the section on to aft side of the step you have about an inch flange laying on top of the step and an inch flange protruding into the foot well space. Against which you can push all your weight to lever yourself up the seat back to get out by standing then on the seat without stressing the floor or anywhere else. Sorry I can't get to the plane to submit a photo at present. Regards Bob Harrison G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw Sent: 03 March 2014 12:19 Subject: Re: Europa-List: Rudder Pedal Step Stretching --> Hi Bob, I know what an "I" section is, but I just can't imagine what you mean. If you said "L" shape, to protect the Trailing edge of the rudder pedal attachment shelf, I would have been with you, but I'm a tad lost. Tony R Sent from my iPad > On 3 Mar 2014, at 11:09 pm, "Bob Harrison" wrote: > > --> > > IMHO Bad idea . I just put a piece of 1.5" "I" section aluminium > across the footwell step and it works for me and I'm 5'9" and on a > long flight you will need to practice "walking" with as much room as > you can have to prevent the onset of cramp in the legs. > Also keep your knee from being near the draught vent more cause for cramp! > After a 4hour 30 minute flight to Krems Vienna My choice was to > pretend walking like hell or choose landing along or across vineyard > wires on fields as for as the eye could see, with tears streaming down > my face. Also dose up on a good layer of Quinine tablets ! > Regards > Bob H G-PTAG > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony > Renshaw > Sent: 03 March 2014 11:40 > To: craig; europa-list(at)matronics.com > Subject: Re: Europa-List: Rudder Pedal Step Stretching > > --> > > Hi Craig and co. > I want to put 75 mm onto the shelf, bringing it aft into the footwell, > to give me a place for my heels. Is that a dumb idea because only being 5' 9" > or 175 cm, I think my legs will easily fit, and I imagine because of > the upright nature of the pedals at neutral, that it might be nice to > build a heel support. Bad idea??? > > TR > >> On 3 Mar 2014, at 10:00 pm, craig wrote: >> >> Yes tony, you can take about 75mm off, I worked out where the mounts >> were going to be then cut it back To leave about 15mm past the end of >> the rearmost mounts >> >> -----Original Message----- >> From: owner-europa-list-server(at)matronics.com >> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony >> Renshaw >> Sent: Monday, March 03, 2014 12:30 PM >> To: europa-list(at)matronics.com >> Subject: Europa-List: Rudder Pedal Step Stretching >> >> --> >> >> Gidday, >> I've heard it mentioned that to extend this step back a bit might >> make things more comfortable. Can I get an input on what dimension is >> recommended? I've heard about 75 mm would do it, and I will probably >> build it into my floor mat mod that I want to do. >> Thanks. >> Regards >> Tony Renshaw >> Sydney Aussie >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > > > > > > > > ________________________________________________________________________________
Subject: Re: EASA noise certificate
Date: Mar 03, 2014
Kees, Noise certificates are available from the Europa club. You should find details on the website (www.theeuropaclub.org) or simply contact the chairman. Regards, David Joyce, G-XSDJ "Bob Harrison" wrote: > > > In his day Dave Bosomworth fixed me up on an emergency >basis once when I was > at Templhof Berlin ! but it was for a Woodcomp SL 3000 CS >prop. but don't > split hairs though !!Regards > \Bob Harrison G-PTAG > > -----Original Message----- >From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf >Of kees de bussy > Sent: 03 March 2014 11:12 > To: europa-list(at)matronics.com > Subject: Europa-List: EASA noise certificate > > > > Hi all, > > In order to renew a special airworthness certificate >(permit to fly) I need > a copy of EASA noise certificate of a Europa XS trigear >with Rotax 914 > fitted with a groud adjustable Warp drive propeller with >C or N blades. > Anybody out there who can help me out ? > > Kees de Bussy > PH-GOO (previous F-PSMU) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419703#419703 > > > > > > > > > > > >Admin. > > > ________________________________________________________________________________
Date: Mar 03, 2014
Tony ..........I'm sorry I have had a brain storm I meant "T" section . Probably that will help you get your mind round what I am saying ! I may get a photo put up to you direct by this evening Regards and sorry .. Bob Harrison G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bob Harrison Sent: 03 March 2014 12:40 Subject: RE: Europa-List: Rudder Pedal Step Stretching --> Tony .......if you imagine the web of the "I" section being used to bolt about 9" of the section on to aft side of the step you have about an inch flange laying on top of the step and an inch flange protruding into the foot well space. Against which you can push all your weight to lever yourself up the seat back to get out by standing then on the seat without stressing the floor or anywhere else. Sorry I can't get to the plane to submit a photo at present. Regards Bob Harrison G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw Sent: 03 March 2014 12:19 Subject: Re: Europa-List: Rudder Pedal Step Stretching --> Hi Bob, I know what an "I" section is, but I just can't imagine what you mean. If you said "L" shape, to protect the Trailing edge of the rudder pedal attachment shelf, I would have been with you, but I'm a tad lost. Tony R Sent from my iPad > On 3 Mar 2014, at 11:09 pm, "Bob Harrison" wrote: > > --> > > IMHO Bad idea . I just put a piece of 1.5" "I" section aluminium > across the footwell step and it works for me and I'm 5'9" and on a > long flight you will need to practice "walking" with as much room as > you can have to prevent the onset of cramp in the legs. > Also keep your knee from being near the draught vent more cause for cramp! > After a 4hour 30 minute flight to Krems Vienna My choice was to > pretend walking like hell or choose landing along or across vineyard > wires on fields as for as the eye could see, with tears streaming down > my face. Also dose up on a good layer of Quinine tablets ! > Regards > Bob H G-PTAG > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony > Renshaw > Sent: 03 March 2014 11:40 > To: craig; europa-list(at)matronics.com > Subject: Re: Europa-List: Rudder Pedal Step Stretching > > --> > > Hi Craig and co. > I want to put 75 mm onto the shelf, bringing it aft into the footwell, > to give me a place for my heels. Is that a dumb idea because only being 5' 9" > or 175 cm, I think my legs will easily fit, and I imagine because of > the upright nature of the pedals at neutral, that it might be nice to > build a heel support. Bad idea??? > > TR > >> On 3 Mar 2014, at 10:00 pm, craig wrote: >> >> Yes tony, you can take about 75mm off, I worked out where the mounts >> were going to be then cut it back To leave about 15mm past the end of >> the rearmost mounts >> >> -----Original Message----- >> From: owner-europa-list-server(at)matronics.com >> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony >> Renshaw >> Sent: Monday, March 03, 2014 12:30 PM >> To: europa-list(at)matronics.com >> Subject: Europa-List: Rudder Pedal Step Stretching >> >> --> >> >> Gidday, >> I've heard it mentioned that to extend this step back a bit might >> make things more comfortable. Can I get an input on what dimension is >> recommended? I've heard about 75 mm would do it, and I will probably >> build it into my floor mat mod that I want to do. >> Thanks. >> Regards >> Tony Renshaw >> Sydney Aussie >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > > > > > > > > ________________________________________________________________________________
From: Kevin Challis <kevinmarie(at)blueyonder.co.uk>
Date: Mar 03, 2014
TR I am 5'8" (short) and have the standard rudder pedals setup. I have never found it uncomfortable. Kevin Challis > On 3 Mar 2014, at 11:40, Tony Renshaw wrote: > > > Hi Craig and co. > I want to put 75 mm onto the shelf, bringing it aft into the footwell, to give me a place for my heels. Is that a dumb idea because only being 5 9 or 175 cm, I think my legs will easily fit, and I imagine because of the upright nature of the pedals at neutral, that it might be nice to build a heel support. Bad idea??? > > TR > >> On 3 Mar 2014, at 10:00 pm, craig wrote: >> >> Yes tony, you can take about 75mm off, I worked out where the mounts were >> going to be then cut it back >> To leave about 15mm past the end of the rearmost mounts >> >> -----Original Message----- >> From: owner-europa-list-server(at)matronics.com >> [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw >> Sent: Monday, March 03, 2014 12:30 PM >> To: europa-list(at)matronics.com >> Subject: Europa-List: Rudder Pedal Step Stretching >> >> >> Gidday, >> I've heard it mentioned that to extend this step back a bit might make >> things more comfortable. Can I get an input on what dimension is >> recommended? I've heard about 75 mm would do it, and I will probably build >> it into my floor mat mod that I want to do. >> Thanks. >> Regards >> Tony Renshaw >> Sydney Aussie >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> > > > > > > ________________________________________________________________________________
Date: Mar 03, 2014
I'm just fitting the rudder pedals and cables and was advised by Ivor Phillips to fit these http://www.aircraftspruce.com/catalog/appages/nylaflow.php Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419735#419735 ________________________________________________________________________________
Subject: Re: New cockpit panel
Date: Mar 03, 2014
Hi John, thanks for throwing some light on this. By no stretch of the imagination I could think of a Europa performing a crash test. Indeed Frans and Ilona did a similar Job with an Aluminium front panel on their PH-DIY, although they had some more space available since it is a HI-TOP. Regards Roland PH-ZTI XS Trigear 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419737#419737 ________________________________________________________________________________
Date: Mar 03, 2014
=0A=0A=0A=0ACable swage=0Ahttp://www.faa.gov/regulations_policies/advisory_ circulars/index.cfm/go/document.information/documentid/99861=0A=C2-=C2- =0A =0A=0A________________________________=0A From: Mike Baker <galahav@yah oo.com>=0ATo: "europa-list(at)matronics.com" =0ASe nt: Sunday, March 2, 2014 10:55 AM=0ASubject: Re: Europa-List: Europa or St ainless Steel Control Cable=0A =0A=0A=0AMil-DTL-83420 is the general spec that describes the requirements flight control cables=0A=C2-Composition A - Carbon steel, zinc, or tin over zinc coated=0Asteel cable is stronger an d stiffer than corrosion resistant steel=0A=0A=0AMIL-DTL-83420/1 - Wire Rop e, Flexible, Type I, Composition A.=0AM83420/1-005 Indicates - Wire Rope, F lexible, Type I, Carbon Steel,=0AConstruction; 7 x 19, Nominal Diameter 5/3 2=0A=0AComposition B - Corrosion resistant steel=0AMIL-DTL-83420/2 - Wire R ope, Flexible, Type I, Composition B.=0AMIL-DTL-781 - Terminal, Wire Rope S waging, General Specification for.=0A=0Ause this info to find the spec of c able you have=0Athe nicopress is usable on either. best to ck spec on swagi ng =0A=0Athe best place I know of for flight control cables is Mcfarlane av iation (USA) =0Aalso a good source for other "stuff"=0A=0A=0A=0A =0A=0A____ ____________________________=0A From: GRAHAM SINGLETON <grahamsingleton@bti nternet.com>=0ATo: "europa-list(at)matronics.com" =0ASent: Sunday, March 2, 2014 4:14 AM=0ASubject: Re: Europa-List: Europa o r Stainless Steel Control Cable=0A =0A=0A=0AYes, stainless was developed f or yachts, sea water contamination resistant. There isn't much bending in t he Europa so no worries about fatigue.=0AMust be the multi strand stuff tho ugh, 7X19 springs to mind but anyway it's fine wire strands for flexibility .=0AGraham=0A=0AAlso be sure you use the right crimps, plated I think, not plain copper. Get a second opinion, I not as young as I once was!=0A=0A=0A =0A =0A=0A________________________________=0A From: Tony Renshaw <tonyrensh aw268(at)gmail.com>=0ATo: GRAHAM SINGLETON ; e uropa-list(at)matronics.com =0ASent: Sunday, 2 March 2014, 6:04=0ASubject: Re: Europa-List: Europa or Stainless Steel Control Cable=0A =0A=0A=0AHi Graha m,=0AWish I knew if it was what was supplied by Europa. I=99ve had th e kit too long to know, things have been moved around, and I don=99t recall the Europa stuff ever being labelled.=C2-=0AMaybe someone else mig ht be able to clarify. Worst part is, it looks old even though it mightn =99t be. It reminds me of a Hills Hoist outside clothes line cable, but I think that is more of an Aussie thing. I actually don=99t have enou gh Nicopress sleeves now so I=99ll need more of those anyway, so I ca n get some more pretty stuff ;-)=0AYou normally use Stainless Steel cable b y choice don=99t you??=0ATR=0A=0A=0A=0A=0AOn 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON wrote:=0A=0ATony=0A>I'd say go ahead with the galvanised steel cable. It should be fine in Oz, so l ong as you don't go=C2-=0A>ocean sailing with it!=0A>Graham=0A>=0A>=0A> =0A>=0A>=0A>=0A>________________________________=0A>From:=C2-Tony Renshaw =0A>To:=C2-europa-list(at)matronics.com=C2-=0A> Sent:=C2-Saturday, 1 March 2014, 22:49=0A>Subject:=C2-Europa-List: Euro pa or Stainless Steel Control Cable=0A>=0A>=0A>--> Europa-List message post ed by: Tony Renshaw =0A>=0A>Gidday,=0A>I have gon e through my fair share of cable, and consequently I have bits everywhere. I have a roll of cable which appears to be galvanised, or really dull Stain less Steel, which I believe doesn=99t happen. Why have nice shiny Sta inless, if it stains. So, the best advice I have to figure out what is what is to use a magnet. The unknown roll of dull cable I have is extremely att ractive to the=0A magnet, and the Stainless is only slightly, but still is drawn towards the magnet on a really long suspended run, like the length in =0A the aft fuselage, towards the magnet when it is mm away, but it still a ttracts it. So, this other roll I can only imagine might have been that sup plied by Europa, and I wouldn=99t know because this roll has no produ ct code or numbers on it.=C2-=0A>My question, whilst I=99d prefer t o use Stainless just because it doesn=99t look like it has been in th e aircraft for a million years, however the gal cable (or whatever it is) I am told is more durable especially in terms of bends. This is a conservati ve approach from gliders where control cabling can have acute bends, but we don=99t have that. So, should I resurrect this roll of cable out of my waste bin and use it, or should I replace it with Stainless Steel?=0A>Th anks for any advice or help, and I appreciate all the help I=99ve got with this sofar.=C2-=0A>Regards=0A>Tony=C2-Renshawhttp://forums.matron ics.com=0A>=0A>=0A>=0A>=0A>=0A>href="http://www.matronics.com/Navigator?E uropa-List">http://www.matronics.com/Navigator?Europa-List=0Ahref="http:/ /forums.matronics.com/">http://forums.matronics.com=0Ahref="http://www.ma tronics.com/contribution">http://www.matronics.com/contribution =0A>=0A =0A http://www.matronics.com/Navigator?Europa-List http://======= ================ =0A=0A =0Ahttp://www.ma troni==================== =0A=0A ============= ________________________________________________________________________________
Subject: Anyone figured how to drop TP from a Europa mono?
Date: Mar 03, 2014
Hi Group Has anyone figured how to drop TP from a Europa Mono? Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419752#419752 ________________________________________________________________________________
Subject: Re: Anyone figured how to drop TP from a Europa mono?
Date: Mar 03, 2014
Hey Ron, I'll be the first one...........what's TP? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419754#419754 ________________________________________________________________________________
Date: Mar 04, 2014
Hi Spcialeffects TP is Toilet Paper. Single ply is longer than two ply. Best have a few feet as a tail to help unroll. I have a XS Mono. I could swap out the 914 for a 130 hp 915 with an inverted oil system: http://sportair.aero/12-epapower/epapower/ then put a temporary vertical pole on the wing slightly angled forward (so it won't hit anything when you release), put the TP on it with a careful 2 feet rolled up and taped in place, then when at altitude roll inverted and pull a negative G. This is half TIC (Tongue in Cheek), but I have a 4 foot RC flying wing with a very powerful gear reduced electric motor and huge prop that I actually do this with using a lolly pop and parachute. It climbs a lot quicker than my Europa with a 914 and Airmaster ever will, so in half a minute even with the draggy cargo it's at 1500 feet. It's a pusher and once in a while it falls off when the motor is running and jams things up, but the ESC (Electronic Speed Controller) protects things, just a 45 degree angle glide back down with just enough airspeed to flair. No joking, make that less joking to no joking at all: Angle a tube off the outrigger to hold a roll, then when at altitude when gear is retracted you pull some Gs and get it to fall off? Leave gear down, have the roll tucked away in the wheel well where it is not going to foul things up if you forgot about it and through the gear lever slot have a release? Could be a rubber band holding in place? Perhaps have a autonomous wireless mini RC servo release mechanism that easily clamps to the tailwheel spring? Or outrigger? Hmm, wonder if you put a temporary pole that clamped onto the outrigger perpendicular to airflow, if you side slipped you could get the roll to fall off? Could be kinda fun, when you have a cross wind, put it on the upwind outrigger, fly with a little side-slip, then side-slip the other way when you want to release? Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419759#419759 ________________________________________________________________________________
Date: Mar 04, 2014
Hi Bob and David, Thanks for your input. Unfortunately it is not that simple. I do have the Europa Club noise certificate but that is not accepted by the Dutch authorities. The only thing which is valid is a EASA noise certificate ( issued by a EASA certified ANMI, Aircraft Noise Measurement Institute) of an aircraft which is equipped with exact the same engine, propeller and exhaust. In all other cases we have to go through a time consuming procedure where aircraft performance and noise is measured by a certified organisation. We are lucky, in so far, that there is such an institute in the Netherlands which can do all the measurements at reasonable costs. But of course if I can find a comparable Europa with EASA noise certificate it will save time and money. Anyway, thanks again for trying to help me out but probably we have to do it via the long way. Regards, Kees de Bussy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419760#419760 ________________________________________________________________________________
Date: Mar 04, 2014
Toilet Paper. You go up about 8000 ft, open a roll of TP, throw it out the window so that it streams, then chase it down to see how many times you can cut the streamer before it gets too low to be safe. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Mar 3, 2014, at 11:32 PM, spcialeffects wrote: Hey Ron, I'll be the first one...........what's TP? ________________________________________________________________________________
Date: Mar 04, 2014
The answer to the question is actually simple.... Take the cabin doors off before flight. Europa have been demonstrated to fly well without doors in multiple incidents in the dim past ;) Eject TP upward and outboard to avoid empennage. Hey Ron, does the question imply that you are nearing project completion? -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419766#419766 ________________________________________________________________________________
Date: Mar 04, 2014
From: PETER MORGANS <petermorgans181(at)btinternet.com>
And keep a little bit back for your own use when you land!=0ASorry - couldn 't resist.=0A =0A=0A________________________________=0A From: Robert Borger =0ATo: europa-list(at)matronics.com =0ASent: Tuesday, 4 Mar ch 2014, 13:00=0ASubject: Re: Europa-List: Re: Anyone figured how to drop T orger =0A=0AToilet Paper.- =0A=0AYou go up about 8000 f t, open a roll of TP, throw it out the window so that it streams, then chas e it down to see how many times you can cut the streamer before it gets too low to be safe.=0A=0ABlue skies & tailwinds,=0ABob Borger=0AEuropa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).=0ALittle Toot Sport Biplane, Lycom ing Thunderbolt AEIO-320 EXP=0A3705 Lynchburg Dr.=0ACorinth, TX- 76208-53 31=0ACel: 817-992-1117=0Arlborger(at)mac.com=0A=0AOn Mar 3, 2014, at 11:32 PM, spcialeffects wrote:=0A=0A--> Europa-List message posted by: "spcialeffects" =0A=0AHey Ron, I'll be th - - - - - - - - - - - - -Matt Dralle, List Admin. ==== ________________________________________________________________________________
Date: Mar 04, 2014
Hi! All, I have no information ref: flying with doors off the Europa for the purposes which you have in mind but I was always told by the factory that there should be a maximum air speed limit applied of 110 knots when doing so for photographic purposes. Regards Bob Harrison G-PTAG -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of rampil Sent: 04 March 2014 14:20 Subject: Europa-List: Re: Anyone figured how to drop TP from a Europa mono? The answer to the question is actually simple.... Take the cabin doors off before flight. Europa have been demonstrated to fly well without doors in multiple incidents in the dim past ;) Eject TP upward and outboard to avoid empennage. Hey Ron, does the question imply that you are nearing project completion? -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419766#419766 ________________________________________________________________________________
Date: Mar 04, 2014
Hey Ira Hoping to have airframe complete this summer (most fill complete), fuel system complete, instrument panel populated. Then motor hang/wire things (wiring is half way complete), cowl/prop, glass and paint. Flap pushrod conversion to push-pull cable that will allow switching between both long and short wings is complete. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419775#419775 ________________________________________________________________________________
Date: Mar 04, 2014
I have in fact flown with the door off my Europa for a photographic sortie, and you are right, there is a 110 knot airspeed limit that Europa advise. I have to say the whole experience was horrible and I will not be repeating it. There was a lot of vibration and buffeting although for some unknown reason, when we were on final approach I put my hand up on the windscreen surround where the door would normally shut, and it suddenly all went peaceful (maybe there is an airflow problem that can be overcome in a similar way that car sunroofs often have a pop up deflector that activates when the roof is open). I won't be repeating the exercise to test the idea though. Dave Watts G-BXDY (hoping that the runway will dry out one day. At least we are not now actually underwater). > On 4 Mar 2014, at 16:23, "Bob Harrison" wrote: > > > Hi! All, > I have no information ref: flying with doors off the Europa for the purposes > which you have in mind but I was always told by the factory that there > should be a maximum air speed limit applied of 110 knots when doing so for > photographic purposes. > Regards > Bob Harrison G-PTAG > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of rampil > Sent: 04 March 2014 14:20 > To: europa-list(at)matronics.com > Subject: Europa-List: Re: Anyone figured how to drop TP from a Europa mono? > > > The answer to the question is actually simple.... > > Take the cabin doors off before flight. Europa have been demonstrated to > fly well without doors in multiple incidents in the dim past ;) > > Eject TP upward and outboard to avoid empennage. > > > Hey Ron, does the question imply that you are nearing project completion? > > -------- > Ira N224XS > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419766#419766 > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: instrument module wider than firewall - what to do?
Date: Mar 04, 2014
I was just offering up the instrument module to the firewall (before the top gets bonded on) and the flanges of the IM protrude beyond the edges of the firewall. The way things are stored at present prevents me from easily checking if the IM will fit within the shape of the upper fuselage at the firewall. If it doesn't, it appears that the flanges of the IM will have to be cut back so much that there will scarcely be enough meat left for the fixings. Has anyone else had this problem? Have I been issued with a mis-matched instrument module & fuselage moulding? Any observations welcome. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Subject: Re: instrument module wider than firewall - what to do?
Date: Mar 04, 2014
On Mar 4, 2014, at 11:03 AM, Rowland Carson wrote: > Have I been issued with a mis-matched instrument module & fuselage moulding? Rowland=85I would tend to doubt that; however, I found that the exterior flange, when trimmed to allow the insertion of the instrument panel module into the fuselage, was insufficient. Consequently, I mounted an inside flange which allowed me to use shock mount bolts which provide a 1/2=94 space between module and firewall, useful for both vibration isolation as well as providing a means of cooling air circulation=85a couple of the shock mounts are visible thru my initial cut-out for my instrument sub-panels=85Good luck, Fred ________________________________________________________________________________
Date: Mar 04, 2014
On Mar 4, 2014, at 10:09 AM, David Watts wrote: > I have in fact flown with the door off my Europa for a photographic sortie, David=85was this done with only ONE door off, or both doors off? > for some unknown reason, when we were on final approach I put my hand up on the windscreen surround where the door would normally shut, and it suddenly all went peaceful (maybe there is an airflow problem that can be overcome in a similar way that car sunroofs often have a pop up deflector that activates when the roof is open). =85so with some sort of =93pop up deflector=94, might we be talking about open cockpit ops, leather jackets, and silk scarves to boot in the good ol=92 summertime? F. ________________________________________________________________________________
Date: Mar 04, 2014
With just the passenger door off. From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fred Klein Sent: 04 March 2014 13:53 Subject: Re: Europa-List: Re: Anyone figured how to drop TP from a Europa mono? On Mar 4, 2014, at 10:09 AM, David Watts wrote: I have in fact flown with the door off my Europa for a photographic sortie, David.was this done with only ONE door off, or both doors off? for some unknown reason, when we were on final approach I put my hand up on the windscreen surround where the door would normally shut, and it suddenly all went peaceful (maybe there is an airflow problem that can be overcome in a similar way that car sunroofs often have a pop up deflector that activates when the roof is open). .so with some sort of "pop up deflector", might we be talking about open cockpit ops, leather jackets, and silk scarves to boot in the good ol' summertime? F. --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Subject: TPDD and request for mod assistance.
Date: Mar 05, 2014
Hi, This is my TPDD. You can=92t really tell from the photo but the top of the tunnel has been turned into a hinged lid to the underside, where fuel selectors, pumps, etc are to be located. I have an Andair Gascolator on a shelf directly above this reinforced access, which is why it exists. HOWEVER, I could use it as a TPDD. I am using a clear marine deck access fitting with a plastic thread, however I have thought about modifying the lid such that I can screw it out, or in, and in that respect if the shelf was placed accordingly, I=92d be able to remove it inflight for photography etc. I=92ve actually ditched that option to be honest though, with things like CO2 entering being my biggest concern. Still, if you were desperate for a TPDD, this would work fine. :-) P.S. I am challenged to replace the original strength with my mod. Immediately under the throttle slot I have a bulkhead, and it is misleading in the photo how far down the sides I have cut. At the back the side cuts run into the top, and at the front its about 150 mm deep, so the sidewalls of the tunnel are basically intact. I anticipate that the majority of the load is on the vertical faces of the tunnel, engine etc. however the fuselage also is a contributor to the entire load carrying of the engine. I think the flat top of the tunnel is more like the top flange of an I beam, pertinent in the load created with a G manoeuvre by the engine. Without that flange I am struggling to see if I can get the outcome I want, so if anyone has an idea I=92d appreciate it. Still, the wide arse mods and the new profile has a negligible top web to this part of the tunnel, and if I don=92t adopt those, which I don=92t plan on doing, I have more side material in a vertical orientation than they do already, to compensate for the absence of the top web. Still, I plan on doing something, but what is the question. TPDD = Toilet Paper Deployment Device Tony Renshaw Sydney Aussie ________________________________________________________________________________
Date: Mar 05, 2014
I had unfortunately to fly with the passenger door off as it departed the ship due to the passenger shocking the lock with his elbow=85 Kind of =93depressurization=94, all the papers flown in the cockpit with a big noise and buffeting like in a storm on a boat! My first reaction was to fly the ship and then look where to land. As we were fortunately close to our harbor I started to lower the speed and was quite surprised to see that by 80Kt when I put the flaps out it came back to a normal behavior (actually I=92m not even sure if it was =93un-normal=94 reducing from cruise speed except noise and wind inside after it happened or few seconds later)... and I standard landed. So to me under 100 Kt or so, flying with a door off should be a non-even but I wouldn=92t either have to try it again. Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ Dyn=92A=E9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de David Watts Envoy=E9 : mercredi 5 mars 2014 07:13 =C0 : europa-list(at)matronics.com Objet : RE: Europa-List: Re: Anyone figured how to drop TP from a Europa mono? With just the passenger door off. From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fred Klein Sent: 04 March 2014 13:53 Subject: Re: Europa-List: Re: Anyone figured how to drop TP from a Europa mono? On Mar 4, 2014, at 10:09 AM, David Watts wrote: I have in fact flown with the door off my Europa for a photographic sortie, David=85was this done with only ONE door off, or both doors off? for some unknown reason, when we were on final approach I put my hand up on the windscreen surround where the door would normally shut, and it suddenly all went peaceful (maybe there is an airflow problem that can be overcome in a similar way that car sunroofs often have a pop up deflector that activates when the roof is open). =85so with some sort of =93pop up deflector=94, might we be talking about open cockpit ops, leather jackets, and silk scarves to boot in the good ol=92 summertime? F. http://www.matronics.com/Navigator?Europa-List http://forums.matronics.com http://www.matronics.com/contribution _____ <http://www.avast.com/> This email is free from viruses and malware because avast! Antivirus <http://www.avast.com/> protection is active. ________________________________________________________________________________
Date: Mar 05, 2014
Hello Rowland, I had the same problem as you. Added a new flange inside, same solution as Fred mentioned in his reply. It works well. Regards, Alfred Alfred Buess CH-3700 Spiez, Switzerland Europa XS HB-YKI, Ercoupe 415-E N94804 -----Ursprngliche Nachricht----- Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Rowland Carson Gesendet: Dienstag, 4. Mrz 2014 20:03 An: Europa e-mail list list Betreff: Europa-List: instrument module wider than firewall - what to do? --> I was just offering up the instrument module to the firewall (before the top gets bonded on) and the flanges of the IM protrude beyond the edges of the firewall. The way things are stored at present prevents me from easily checking if the IM will fit within the shape of the upper fuselage at the firewall. If it doesn't, it appears that the flanges of the IM will have to be cut back so much that there will scarcely be enough meat left for the fixings. Has anyone else had this problem? Have I been issued with a mis-matched instrument module & fuselage moulding? Any observations welcome. in friendship Rowland ________________________________________________________________________________
Subject: Europa glider tug
From: "flyingphil2" <flyingphil627-europastuff(at)yahoo.co.uk>
Date: Mar 05, 2014
Further to an earlier posting, does anyone have any information or photos of the Europa being used as a glider tug in Germany? It struck me at the last LAA rally that pretty much anything with wings and a 912S was being promoted as a glider tug and trying to tap into the Eurofox success. I'm guessing that cooling could be a big issue on the Europa though? Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419812#419812 ________________________________________________________________________________
From: "Paul McAllister" <paul.the.aviator(at)gmail.com>
Date: Mar 05, 2014
Hi Rowland, I did something similar to what Fred did. Take a look at http://www.europa.net.nz/363/2001/images/flange_in_instrument_panel.jpg Cheers, Paul From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fred Klein Sent: Tuesday, March 4, 2014 3:08 PM Subject: Re: Europa-List: instrument module wider than firewall - what to do? On Mar 4, 2014, at 11:03 AM, Rowland Carson > wrote: Have I been issued with a mis-matched instrument module & fuselage moulding? Rowland.I would tend to doubt that; however, I found that the exterior flange, when trimmed to allow the insertion of the instrument panel module into the fuselage, was insufficient. Consequently, I mounted an inside flange which allowed me to use shock mount bolts which provide a 1/2" space between module and firewall, useful for both vibration isolation as well as providing a means of cooling air circulation.a couple of the shock mounts are visible thru my initial cut-out for my instrument sub-panels.Good luck, Fred ________________________________________________________________________________
Date: Mar 05, 2014
Subject: Re: Europa glider tug
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Phil I believe that Erich Trombley visited with Walter Binder in Germany a couple of years back. He might have some pictures. Paul ________________________________________________________________________________
Date: Mar 06, 2014
Hi Phil, Walter Binders plane D-EPWB is a Classic Monowheel Kit 149 with Wing Fuel Tanks, elect. Retractable Outrigger Legs and a Tail Wheel with a mounting plate on top for the tow clutch. I am not quite sure if this was from an old Cessna Taildragger or a Husky. He is using his own landing strip for towing the smaller glider he is manufacturing. He also manufactures the EB 28 /29. Some years ago he had to use a parachute by test flying. Binder Motorenbau GmbH Alter Frickenh=E4user Weg 15 D-97645 Ostheim v. d. Rh=F6n Vertreten durch die Gesch=E4ftsf=FChrer Walter & Oliver Binder Tel.: +49(0)9777 - 92 00 Fax: +49(0)9777 - 92 01 www.binder-flugmotorenbau.de <http://www.binder-flugmotorenbau.de/> 097779200@t-online.de I am sure that he can help you with some information. Best Regards, Bruno Reith /EA-Germany Partner _____ Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Paul McAllister Gesendet: Mittwoch, 5. M=E4rz 2014 14:35 An: europa-list(at)matronics.com Betreff: Re: Europa-List: Europa glider tug Phil I believe that Erich Trombley visited with Walter Binder in Germany a couple of years back. He might have some pictures. Paul ________________________________________________________________________________
Subject: Re: AW: Europa glider tug
Date: Mar 06, 2014
Thanks for this information. I hadn't made the connection with the name earlier but now I have. Much respect due to this chap - his EB29 has an L/D of 68:1 !! A quick look at google images for 'D-EPWB europa' does in fact show a Europa mono with a tow hook attachment above the tail wheel and very interesting looking outriggers (let alone different cowls and many lightening holes in the swinging arm). Looking at the cowls, I guess he's fixed any potential cooling issues during the tow. Obviously a man who is not afraid to modify his aircraft! Many thanks for the contact info. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419865#419865 ________________________________________________________________________________
Subject: Re: Nicopress Sleeves
Date: Mar 06, 2014
Hi Tony Don't try and tidy it up as you put it, the copper sleeve has been forced round and into the wire strands by the squeeze. If you were to cut across the finished nicopress sleeve and wire joint you would see that it is almost welder together. More importantly during the squeeze you are work hardening the copper sleeve, more squeezing could cause fatigue cracks. Best of luck Richard -----Original Message----- From: Tony Renshaw Sent: Monday, February 17, 2014 12:04 PM Subject: Europa-List: Nicopress Sleeves Gidday, Quick question.why cant I tidy up a nicopress and squeeze it 90 degrees rotated after the first squeeze, to tidy the compress? If the first squeeze is correct, the second squeeze shouldnt disturb the consequences of the first, should it?? Tony R. Sydney Aussie ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Instrument panel Fairing
Date: Mar 08, 2014
Gidday, I'm experimenting with an idea to incorporate a Flood panel light system, us ing dimmable LEDs. I don't want to see them, so I need to hide them in the i nstrument panel coaming, and to do that I need to thicken it. I'm interested if anyone else has done that, and I wouldn't mind making mine capable of ac commodating an energy absorbing material, like a rubber hemispherical sectio n. Below is the start of this little experiment with a foam buildup that I w ill sand back against the original panel, but thicken the coaming, and hopef ully embed my LEDs within, so I can't see them. I also thought of incorporat ing either an annunciator bulge in the middle, or a Caution/warning light in the same spot. I'd like to request input especially from not too tall pilot s (I'm 5'9"_175cm) as to the max thickness I could make the coaming without o bscuring the top instruments. Thanks. Regards Tony Renshaw Johannesburg, then home..Sydney. Sent from my iPad
Subject: Sun 'n Fun in Lakeland FL
Date: Mar 08, 2014
Tired of the winter weather! Join Bud and Anita Yerly at Sun 'n Fun April 1-6, 2014. Custom Flight Creations, your Airmaster Propeller and Europa Aircraft Dealer in the States, will be showing a Europa LSA/Stol aircraft at the tent. We are also showing our new Airmaster AP420 Prop, wheel pants and other odds and ends for you to ponder. Look for us on spot 33 just Northeast of Hangar C near the flight line taxiway (where we were last year). Stop by and chat a bit and get a much needed drink and some shade from the Florida Sun. We will also have videos and photos of some of our modifications and upgrades for the Europa that we normally did not share outside the shop. We have ready to fly away XS aircraft with the Rotax and Jabiru engines, as well as a Motor Glider aircraft on the flight line for sale. We have a number of used fast build kits available for those looking for a new project and partially built kits at the shop for sale. Many aviation companies are pulling out the stops to come on down to get out of the rotten weather. The airshow looks to be great, and the homebuilders are already planning to come on down and camp out. See www.sun-n-fun.org<http://www.sun-n-fun.org/> website if you need reservations, tickets, or just fly or drive in. Come join us for a week of great fun in the sun. So far Jerry Hope, Kim Prout, and Jeff Roberts, Ivan Shaw and many others will be here. More are clearing the ice off their planes and flying, and driving south. Ask about volunteering for Sun 'n Fun for the week (1/2 day of labor required ) and getting a week long pass for free. Heck, the Garmin upgrades and a free week pass pays for half the trip. My EAA Chapter makes sandwiches for the volunteers (yea, a free lunch) from 0900 until 1200 daily starting the Friday before the show until the last day and you get a week long pass. You have to work at least 4 days though. See you then, Bud Yerly ________________________________________________________________________________
Date: Mar 08, 2014
Rowland, This message was delayed by my aging shop computer. Bud ----- Original Message ----- From: Bud Yerly<mailto:budyerly(at)msn.com> To: europa-list(at)matronics.com Sent: Wednesday, March 05, 2014 5:26 PM Subject: Re: Europa-List: instrument module wider than firewall - what to do? Photo E-mail View slideshow <>| Download images <> Rowland, Just my two cents. I have never had a module not fit, but to be sure, the flange on a couple were only just wide enough for the nutplates. I prefer to add a flange on the inside, as others have, and extending the flange to the bottom pilot side also to stiffen up the bottom and top skins. By eliminating the upper and side flanges the panel can be installed slightly higher. However, watch for your clearance for the cowl nutplates. Keep in mind any wire bundles have got to be planned for early, as it is often necessary to cut holes in the lower right and left area for those under the door sill wire bundles, add possibly a center cutout or tunnel to allow a down the centerline wire bundle. One other side benefit to eliminating the flange is interior fabric finish or paint finishes on and around the windscreen area can be made a bit neater (is that a word?) leaving only the pesky cowl nutplates protruding into your line of sight (painted interior) or poking into your fabric headliner... Regards, Bud Yerly <> Panel in conversion from mono to trigear. ----- Original Message ----- From: Rowland Carson<mailto:rowlandcarson(at)gmail.com> To: Europa e-mail list list Sent: Tuesday, March 04, 2014 2:03 PM Subject: Europa-List: instrument module wider than firewall - what to do? > I was just offering up the instrument module to the firewall (before the top gets bonded on) and the flanges of the IM protrude beyond the edges of the firewall. The way things are stored at present prevents me from easily checking if the IM will fit within the shape of the upper fuselage at the firewall. If it doesn't, it appears that the flanges of the IM will have to be cut back so much that there will scarcely be enough meat left for the fixings. Has anyone else had this problem? Have I been issued with a mis-matched instrument module & fuselage moulding? Any observations welcome. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | > http://www.rowlandcarson.org.uk> | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson landcarson> http://www.matronics.com/Navigator?Europa-List avigator?Europa-List> http://forums.matronics.com> http://www.matronics.com/contribution on> These photos will be available on SkyDrive for 30 days. To learn more about SkyDrive, click here<>. To share high quality pictures with your friends and family using MSN Photo E-mail, join MSN<>. ________________________________________________________________________________
Subject: Re: Instrument panel Fairing
Date: Mar 08, 2014
On Mar 8, 2014, at 5:47 AM, Tony Renshaw wrote: > I'm experimenting with an idea to incorporate a Flood panel light system, using dimmable LEDs. I don't want to see them, so I need to hide them in the instrument panel coaming, and to do that I need to thicken it. I'm interested if anyone else has done that, and I wouldn't mind making mine capable of accommodating an energy absorbing material, like a rubber hemispherical section. Tony=85see pixs below=85I made the lip w/ 2 thicknesses of 3/8=94 dense but flexible white foam=85not energy-absorbing=85after rounding off, foam covered w/ 1 layer BID...I also extended the sunshade over the com panel and found that a 36=94 strip of LEDs was perfect and is bonded w/ silicone to the =93back face=94 of the lip or valence which hides the lights from the pilot & passenger=92s eyes. For =93energy-absorbing=94, you might try some of that slotted round closed cell neoprene foam pipe insulation=85just a thought=85 Good luck, Fred ________________________________________________________________________________
From: "Paul & Vanessa Munford" <pmdental(at)btinternet.com>
Subject: Fw: Door latch
Date: Mar 08, 2014
Hi guys & gals, Thanx for your help regarding door fitting - coming along nicely. Got a problem with the door latch. as you can see in the attatched photo. With the inner handle in the fully closed position, the outer handle is cocked up at 40 degees to the horizontal ??? I'm assuming it should be horizontal - streamlined into the airflow. I followed the instructions to the letter & as you can only ever change the positions of the handles by 90 degrees, whats gone wrong ??? Any ideas please Paul Munford trigear kit 625. Thankyou ----- Original Message ----- From: "Dr Paul Munford" <pmdental(at)btinternet.com> Sent: Saturday, March 08, 2014 8:36 PM Subject: Door latch > > -------------------------------------------------------------------------------- > > > Sent from my iPhone ________________________________________________________________________________
Date: Mar 08, 2014
Hi all. Thanx for you help with door fitting - coming along nicely. As you can see I've got a problem with the doorlatch ? Despite following the instructions to the letter, when the inner handle is in the fully closed position the outer handle is cocked up at 40 degrees ??? I'm assuming it should be horizontal into the airflow ?? BUT you can only alter the handle positions by 90 degees. Any ideas / Thankyou Paul Munford, Kit 625 trigear ----- Original Message ----- From: "Dr Paul Munford" <pmdental(at)btinternet.com> Sent: Saturday, March 08, 2014 8:36 PM Subject: Door latch > > -------------------------------------------------------------------------------- > > > Sent from my iPhone ________________________________________________________________________________
Subject: Re: Fw: Door latch
From: Richard Wheelwright <rpwheelwright(at)yahoo.co.uk>
Date: Mar 08, 2014
You may have fixed the anchor nut on the wrong side of the Handel ??? Sent from my iPad > On 8 Mar 2014, at 20:54, "Paul & Vanessa Munford" wrote: > > Hi guys & gals, Thanx for your help regarding door fitting - coming along nicely. Got a problem with the door latch. as you can see in the attatched photo. With the inner handle in the fully closed position, the outer handle is cocked up at 40 degees to the horizontal ??? I'm assuming it should be horizontal - streamlined into the airflow. I followed the instructions to the letter & as you can only ever change the positions of the handles by 90 degrees, whats gone wrong ??? Any ideas please Paul Munford trigear kit 625. Thankyou > ----- Original Message ----- From: "Dr Paul Munford" <pmdental(at)btinternet.com> > To: > Sent: Saturday, March 08, 2014 8:36 PM > Subject: Door latch > > > > > -------------------------------------------------------------------------------- > > >> >> >> >> Sent from my iPhone > ________________________________________________________________________________
Date: Mar 09, 2014
Try swapping the handles -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Paul & Vanessa Munford Sent: Sunday, March 09, 2014 7:08 AM Subject: Europa-List: Fw: Door latch Hi all. Thanx for you help with door fitting - coming along nicely. As you can see I've got a problem with the doorlatch ? Despite following the instructions to the letter, when the inner handle is in the fully closed position the outer handle is cocked up at 40 degrees ??? I'm assuming it should be horizontal into the airflow ?? BUT you can only alter the handle positions by 90 degees. Any ideas / Thankyou Paul Munford, Kit 625 trigear ----- Original Message ----- From: "Dr Paul Munford" <pmdental(at)btinternet.com> Sent: Saturday, March 08, 2014 8:36 PM Subject: Door latch > > ---------------------------------------------------------------------------- ---- > > > Sent from my iPhone ________________________________________________________________________________
Date: Mar 08, 2014
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
try turning the handle over, (inside face to outside) You nned to take the anchor nut off, so have a look and think about it=0Afirst!=0AGraham=0A=0A =0A=0A=0A________________________________=0A From: Paul & Vanessa Munford < pmdental(at)btinternet.com>=0ATo: europa-list(at)matronics.com =0ASent: Saturday, 8 March 2014, 20:54=0ASubject: Europa-List: Fw: Door latch=0A =0A=0AHi guy s & gals, Thanx for your help regarding door fitting - coming along nicely. Got a problem with the door latch. as you can see in the attatched photo. With the inner handle in the fully closed position, the outer handle is coc ked up at 40 degees to the horizontal ??? I'm assuming it should be horizon tal - streamlined into the airflow. I followed the instructions to the lett er & as you can only ever change the positions of the handles by 90 degrees , whats gone wrong ??? Any ideas please Paul Munford trigear kit 625. Thank you=0A----- Original Message ----- From: "Dr Paul Munford" <pmdental@btinte rnet.com>=0ATo: =0ASent: Saturday, March 08, 2014 8:36 PM=0ASubject: Door latch=0A=0A=0A> =0A> =0A> =0A=0A=0A---------------- ----------------------------------------------------------------=0A=0A=0A> =0A> =0A> =0A> Sent from my iPhone ________________________________________________________________________________
Subject: Re: Sun 'n Fun in Lakeland FL
Date: Mar 09, 2014
Hi Bud! Linda and I will certainly be there too, (fresh from Oak City)! -------- Ira N224XS Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=420036#420036 ________________________________________________________________________________
Date: Mar 09, 2014
As ever, you guys are great !!! You were right, - by swapping handles, everything fell into place (wish I had a brain ???!!!). Thanx again. Paul Munford. Trigear kit 625 ----- Original Message ----- From: GRAHAM SINGLETON To: europa-list(at)matronics.com Sent: Saturday, March 08, 2014 11:05 PM Subject: Re: Europa-List: Fw: Door latch try turning the handle over, (inside face to outside) You nned to take the anchor nut off, so have a look and think about it first! Graham ------------------------------------------------------------------------- ----- From: Paul & Vanessa Munford <pmdental(at)btinternet.com> To: europa-list(at)matronics.com Sent: Saturday, 8 March 2014, 20:54 Subject: Europa-List: Fw: Door latch Hi guys & gals, Thanx for your help regarding door fitting - coming along nicely. Got a problem with the door latch. as you can see in the attatched photo. With the inner handle in the fully closed position, the outer handle is cocked up at 40 degees to the horizontal ??? I'm assuming it should be horizontal - streamlined into the airflow. I followed the instructions to the letter & as you can only ever change the positions of the handles by 90 degrees, whats gone wrong ??? Any ideas please Paul Munford trigear kit 625. Thankyou ----- Original Message ----- From: "Dr Paul Munford" To: Sent: Saturday, March 08, 2014 8:36 PM Subject: Door latch > > > ------------------------------------------------------------------------- ------- > > > > Sent from my iPhone ________________________________________________________________________________
Date: Mar 09, 2014
Subject: Wanted Arplast PV50 Manual control Box
I have an Arplast PV50 propeller that uses the standard manual control box and has now become faulty. Anyone who has now fitted the Smart control constant speed system to their PV50 will now possibly have the original control box surplus to requirements. If you have such a unit for sale I would appreciate a call on 07767 796 355 Mike Porter. UK ________________________________________________________________________________
From: "Erich Trombley" <erichdtrombley(at)juno.com>
Date: Mar 10, 2014
Paul wrote: elieve that Erich Trombley visited with Walter Binder in Germany a couple of years back. He might have some pictures. Phill, pictures atta ched. I hope you find them to be of value. Regards,ErichN288ET Classic mono 914 ____________________________________________________________ How to Stay Asleep All Night Try this one weird trick to put your sleep troubles to rest. http://thirdpartyoffers.juno.com/TGL3131/531d1c7c74cd81c7c5f7fst03vuc /9j/4AAQSkZJRgABAQEAyADIAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0a HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAkiBqQDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDyeaVr q4ed8mWRiXP+HpXtHhX4LaFrPhqy1K+1HUxPcx7ysLxqq+3KE/rXi8C/vF4r608D/wDIlaTx/wAs B/M0COQHwF8Kgf8AH7rB/wC3iP8A+N04fAjwmSSbnVjk5x56f/EV6dnFFAzzP/hRHhLvPqv/AIEr /wDE04fAvwgBgtqR9zc/4CvSs0UXCx5t/wAKL8H566j/AOBP/wBalHwN8Hemof8AgV/9avSKKAPO f+FHeDP+eN8frdNTv+FI+C+9ven/ALemr0SigDzwfBPwX/z6XZ/7enpf+FJ+Cf8Anzuv/At/8a9C ooA8+/4Ur4J/58br/wAC5P8AGnD4L+CAeNPuP/AyT/4qu/paLgef/wDCl/BPGNPuOP8Ap7k/xoHw X8Ej/lxuf/AuT/GvQKKAsef/APClvBOOLC4/8C5P8aT/AIUr4J/58Ln/AMC5P8a79hlSMkZ7igDA A5/GgDgP+FK+Ce9hc/8AgXJ/jS/8KX8Ef9A+4P1u5P8AGvQKKLgcD/wpnwQcZ02c44GbyXj/AMep 3/CmvA3/AECZD/29y/8AxVd4KOaLgcIPg54FA/5A7/jdzf8AxVO/4U/4F76KT7fa5v8A4uu5ooA4 f/hT/gT/AKAf/k1N/wDF0v8AwqDwJ/0Ah/4FTf8AxdduaSgDiR8IfAn/AEAVOP8Ap5m/+Lp3/CpP Av8A0AI/+/8AL/8AF12lFAaHFj4SeBR08Pxf9/5f/iqcfhN4F/6F+H/v7J/8VXZUUAcaPhP4GHTw 9B/39k/+Kpf+FUeBv+het/8Av5J/8VXY0UAcf/wqrwP/ANC9bf8Afb//ABVL/wAKs8D/APQu23/f T/412H40lAHIf8Ks8D/9C7a/99P/AI0v/CrfA/8A0Ltr+b/4111FAHJf8Ku8Ef8AQu2n5t/jQfhf 4J7+HrQ8f7X+NdbRQByf/CsPBP8A0Ltn+Tf40o+GXgodPDll/wB8n/GurooA5X/hWfgr/oXLH/vg 0f8ACtPBQ/5lyx/74rqqKAOX/wCFb+C/+hb0/j1io/4Vv4L/AOhb0/8A79V1FFAHMf8ACufBn/Qt ad/35FOHw78Gj/mWtN/8BxXS0UAc2Ph74OH/ADLWl/8AgMtL/wAK/wDB/wD0LOlf+Aqf4V0dFAHO /wDCA+D/APoWdK/8BU/woHgLwgDn/hGdJ/G0T/CuiooAwP8AhBPCOf8AkWNH/wDAKP8Awpf+EG8I /wDQsaP/AOAMf+Fb1FAGD/wg/hL/AKFjR/8AwCj/AMKP+EI8JH/mV9G/8AIv/ia3qKAML/hCPCX/ AELGjf8AgBF/8TR/whHhL/oWNF/8AIv/AImt2igDC/4Qnwl/0K+i/wDgvi/+Jo/4Qnwn/wBCvov/ AIARf/E1u0UAYf8AwhPhP/oV9F/8AIv/AImj/hCvCf8A0LGi/wDgBF/8TW5RQBh/8IV4T/6FjRf/ AAAi/wDiaP8AhC/Cn/QsaN/4ARf/ABNblFAGJ/whfhT/AKFnRv8AwAi/+Jo/4Qvwp/0LOjf+AEX/ AMTW3RQBiDwb4Wx/yLWj/wDgBF/8TS/8Ib4W/wCha0f/AMAYv/ia2qKAMU+DvC7fe8OaQfrYxf8A xNH/AAh3hb/oW9H/APAGL/4mtqigDF/4Q7wt/wBC3o//AIAxf/E0f8Id4W/6FvR//AGL/wCJraoo Axf+EO8Lf9C3o/8A4Axf/E09fCnhtPu+H9KX6WcY/pWvRQBkHwn4aY/N4f0k/Wyj/wAKP+EU8OD/ AJl/Sv8AwCj/AMK1sUYoAyv+EW8OjP8AxIdLH/bnH/hS/wDCMeHv+gFpn/gJH/hWpijFAGWPDPh4 dNC0wf8AbpH/AIUo8NaAOmiab/4CR/4Vp0tAGaPDuh/9AXTv/AVP8KX/AIR/Rf8AoD6f/wCAyf4V oYoPSgCiND0hfu6VYj6W6f4U7+x9LH/MNs/+/C/4VcoxQBUGk6YOmnWn4Qr/AIU8abYL92xth9Il /wAKs0mKAIfsNn/z6Qf9+xTha2w6W8Q/4AKkxRigBoiiHSJP++adtT+6v5UYoxQAvHoKOPSkxRig BePSlzTcUYoAdmjdTaWgBd1GaSigBc0m7nFFHegBc0ZpKKAFzRmkooAXNGaSigBc0ZpKXFABmjNG KSgBc0ZopKAFz7UZ9qSigAzS7qSigAzS5pKKAFz7UZpKKAFz7UZ9qSigAz7UhYjoM0YoxQAufajd SYoxQAufajJpMUYoAXPtRk0mKWgAzRk0UmKAFyaMmkxRigBcmjJpMUtABk0m40YoxQAuTSZNLRQA ZNGTRRQAZNGTRRQAZNGTRRQAmT60uTRRQAmTRk0tFACZPrRk/wCRS0UAJk+tGT60YpaADJoyaTFL QAZNGT60dqKAEyaMmlooATJ9aMmlooATJo5paKAE5o596WigBOaXmk6UdqADmjn3paKAE5o5paKA E5o59aWigBOfX9aOfWlooATn1o59aWigBOaOfWlooATn1/Wjn3paKAE5o59f1paKAE59aPxo4zgU tACc0fjS0UAJ3o70tFACUUtFACUUtFACUtLijFACUnNOxSUAJS0vajFADaMU7FJQAlFONGKAG4ox TsUCgBuKMU6koATFFLSKoRdqjCigAxRS0UAJiilooATFFLRQB8WW/wDrVr6y8Df8iTpP/XuP5mvk +1/1y/WvrLwR/wAiVpP/AF7j+dN7CW5v0uKBRSGJRS4pKACiiloAKKKKAG4AOe9OoooABRRRQAUU UUAFFFFABRRRQAUCiigAxRRRQAUUUUAGKKKKADFFFFABQaKKAAUUtJQAUUYooAKMUUUAGKMUUtAC YoxRiloASjFGKKACjFFFABRRRQAYoxRS0AJiiijFABijFGKMUAGKMUYoxQAYoxRijFABijFGKMUA GKMUUYoAMUYoxRigAxRijFFABRijFFABijFGKKADFGKMUUAGKMUUUAGKMUUUAGKKKKADFGKKKACj FFFABikpaKADFGKKKAEopaKACjFFFABiiiigAxRiiigAxRRRQAYoxRS0AJijFGKMUAGKMUYoxQAU UYoxQAUUYoxQAUYoxS0AJRRijFABRRijFABijFGKMUAFFGKMUAFGKMUUAGKKKKADFGKKKADFGKKK AEpcUUUAGKKKKAEpcUUUAJS0UUAJS4oooAMUlLRQA0YP4GlpelFACUUtFABijFFFABijFGKKAA0Y oooAMUYooxQAYoxRRQAYoxRRQAYoxRijFABiiiloATFGKMUYoAMUYoxRQAYoxRR+FAB70YoxRigA xRijFGKADFGKMUYoAMUYoxRigAoxRijFABRijFGKADFGKMUUAGKMUUYoAMUYoxRigAxRiijFABij FGKMUAFGKMUYoAKKMUtACUUtFACUUtFACUUtFACUUtFACUUtFACUUtFACUUtFACUUtFACUUtFACd 6KWkxQAUUYooAKDRRQAlFLRQB8W2oPmrj1r6w8DHPgnST/0w9fc18oWg/fKPevrDwOMeCtJ7fuB/ M03sJbnQ0d6BS0hiUUtFACUUtFACYoxS0UAJijFLRQAmKMU1d3O7HtgU+gBKMUtJnnFABijFLRQA UUUUAJijFLRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUlLRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACYpaKKAExS0UUAFFFFA CUtFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTA6mUpn5lAJGPX/8AVT6K ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKSlpDQAUUUUAfF1p/rl+tfWHgf8A5ErSv+uH9TXydaf65frX1h4F/wCRK0r/AK4/+zGm9hLc 6IUtIKWkMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACimSDcuMnn0pVzjmgB1FJmloAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkpaQ0AFFFFAHxdaD98vHSvrDwP/AMiXpfOc Q9vqa+TrX/Xr9fSvrDwJ/wAiTpX/AFx/9mNN7CW50QpaQUtIYUUUUAFFFFABRRRQAUUUUAFFFFAB RRSUALSUtFABSEZpaKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKQ0tIa ACiiigD4ttP9ev1r6v8AAgA8E6UB/wA8f/ZjXyhaf65frX1f4E/5EnSv+uP/ALMab2EtzoxS0gpa QwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoopBnPWgBaKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAQ0UtJQAUUUUAfFlpnzV4719YeBP8AkSdK/wCuR/8AQjXylbSOWjiZ 3MasSqFuFz1wPfAr6u8Cf8iTpX/XH/2Y03sJbnRClpBS0hhRRSUALRRRQAUUUUAFFFFABRRSd6AF ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEpaKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAopKWgAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApKWkoAKK KKAPiu0/1619YeAv+RJ0v/rkf/QjXyha/wCuX619X+Av+RK0v/rl/wCzGmI6QUtIKWkMKTFLRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUgGKWgAooooAKKKKACiikHSgBaKKKACiiigBB1P1paKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAp KWkIzQAtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFJQaKACikooA+LrX/AFy19W+A/wDkStL/AOuX9TXyja/61frX1f4D H/FFaZ/1y/8AZjTewludLRSUtIYUUUUAJS0UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUlLSUAFFFFAHxZa/wCuX619X+Av+RK0 v/rl/wCzGvlC1/1y/Wvq3wB/yJOl/wDXI/8AoRpvYR0wpaQUtIYUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRSUALRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAhopaSgB KKWigD4rtv8AXL9a+rvAH/Ik6Z/1zP8A6Ea+UrY/vR9a+rfh/wD8iRpf/XM/+hNTewjp6KQUCkMW iiigAooooAKKKKACiiigAooooAKKKbvXfs3DdjOM80AOooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigBAQehzS0gGCfeloAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAQ0UGigBKKKKAPiy2/1y/Wvqz4ff8AIkaZ3/dn /wBCavlO2/1q/Wvq74f/APIk6Z/1zP8A6Eab2EdMKWkFLSGFJS0UAFFFFABRRRQAUUUUAFFFFABS e9LRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJQaKAEoo ooA+LLbPmr9a+q/h5/yI+m/7j/8AobV8qW3+tWvqz4e/8iRpn+43/obU3sJbnU0UgpaQwooooAKT IzjvS0UAFFFFABRRRQAUUUUAJS0UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAJ0paSloAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAQ0UGigBKKKKAPiy2/1q19V/Dw58D6af9lx/wCPtXypbD96PrX1V8Ox/wAU Ppvurnp/ttTewludUKWkFLSGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUdKKKACik9qWgAooooAKKKKACiiigBDRQaKAEooooA+Lbb/XL9a+q/h6f+KJ0 0YxhG7f7bV8p2/8ArRX1V8Of+RH03/df/wBDam9hLc6qlpKO1IYtFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRSUALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFJ3paACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiikNAC0UgORS0AF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJjnNLRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FACGig0UAJRRRQB8WW3+tWvqr4df8iPpv+6//obV8q2+fMWvqn4cnPgfTv8Adf8A9Dam9hLc6sUt IKWkMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKAENFBooASiiigD4st/9aK+qPhyMeB9O91f/ANDavle3/wBatfVPw5Of A+nf7r/+htTewludWKWkFLSGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFJS0UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFIc4460tFACc0AY9aWigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKAEpaKKACkA+YnPWlooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAQ0GlpDQAlFFFAHxZB /rBX1N8Nc/8ACEWGf9v/ANDavlm3/wBYK+pvht/yJFh/wP8A9Dam9hHXUtJS0hhRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAh6UYpaKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAQ0Gg03aN+7nOMdaAFooooA+LIG+ZRgcGvqL4YtnwTaDP3Wcf+PV8uQ/6wdK+o/hkMeCbP 3L9v9o03sJbnZUdqBR2pDFooooAKKKKACikpaACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKQZ70ALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAhoNBooASiiigD4rtz+8Wvqb4af8iRY+2/ /wBDNfLMH+sFfUfwy/5Emz/3n/8AQjTewludlR2opaQwooooAKKKKAEpaKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKTHOaWigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooASkpTQaAEooo oA+KoP8AWLX1J8Msf8ITZ/V//QjXy3B/rFr6k+GP/IlWnbDOP/Hqb2EdlQKKWkMKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACikzS0AFFFFABRRRQAUUUUAFFFFABRRRQAUU UgoAWiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAoopDQAGkpTQaAEooooA+K4P9YPrX1H8MR/xRVrnuz/APoVfLsH+sFfUXwxIPgq0x/ef/0I03sJ bnZUtIKWkMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoopO9AC0lFHWgAPSloooAKK KSgBaKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKQ0tFACGg0UGgBKKKKAPiqD/AFg+tfUXwv8A+RLtvZ3H618v Qf6wV9RfDD/kSrX/AHn/APQqYludmKO1FLSGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFIaACg0UGgBKKKKAPiuD/WV9Qf C7nwXb+zv/OvmC3x5lfUHwu/5Eq3x/ff+dN7CW52lLSUdqQxaKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKQ0tIaADrSUtBoAS iiigD4rg/wBYBX1B8LjnwXb/APXR/wCdfL8A+evp/wCFv/ImQ8/8tH4pvYS3O2paSgUhi0UUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBGqY lZ9zHcANp6DGf15/QVJRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABSGlpDQAUlLSUAFFFFAHxdaMiOxdN52/J8+3afX3+lfTnwt/wCR LhH/AE0evl+H74r6e+FRz4Nj9pWH8qYludxR2opaQwooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApDS0UAJSUtJQAUUUUAfFUH 36+nvhX/AMibH/11b+lfMMH3xX058LAH8Fopz/rGHBx6U3sJbndUCilpDEpaKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAoopKAFooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii kzQAtFIORS0AFFFFABRRRQAmeaWk70tABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFIaWkNABSUtJQAUUUUAfFcH36+m/hVx4OT/rq39K+Y4Pvivpz4Un/AIo6P/rq39KdhLc7qlpK WkMKKKTvQAtFFFABRRSHNAC0UgIIyO9LQAUUUUAFFFFABRRRQAUUUUAFFJS0AFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUdaKKADpRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABSGg0GgApKWkoAKKSigD4rh++OtfTPwmz/wAIh9Jm/kK+Zofv ivpr4T/8igP+uzfyFMS3O8paSgUhi0UUUAFFFFACE4GaT5val2jOcCloAQDAwO1LRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUCiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKQ0GigApKWkoAKKKK APiqH74r6Z+E5z4R/wC2zfyFfM0X36+l/hL/AMil/wBtj/6CtMS3O/oFFLSGFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFNKgsDzkD1p1ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFIaKACkpaSgAooooA+Kovvj/Cvpj4Tf8ij/wBtj/IV8zxffFfS3wjJPhRvaY/+grTEtz0C lpKWkMKKKTmgBaKSloAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAQ+1LRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUlLSUAFJS0lABRRRQB8VQ/er6W+En/IqN/wBdz/6CtfNMX36+lPhE c+FZB6Tn/wBBWmI9CpaSjtSGLRSdqWgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAGZ JcrtYAAHdxg/5/rT6KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApDS0UAFJS0lABSUtJQAUUUUAfF UON3NfSfwgH/ABSsn/Xc/wDoK182Rfer6U+EP/Iqyd8Tn/0FaZPU9CpaSikULRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUlLRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFIa WkNABSUtJQAUUUUAfFUXUDA9a+kPg8f+KYm/67/+yrXzlF9/pX0d8Id3/CMzbmJ/fYGTnACim9hL c9FoFAo70hi0UUUAFFFFABRRRQAwbstuAAz8uD1H5U+iigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKQ0tFACGg0GigApKWkoAKKKKAPiuL71fR/weOfDM4/6b /wDsor5wi+/X0b8Hcf8ACN3HX/Xc/wDfK03sI9Io7UUCkMBS0gpaACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo6UAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRSUtABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAhooNFABSUppKAC iiigD48i0qbcDxXv/wAIozF4fuEPUT/+yivHo8Yr2f4Wf8ga6/67f+yimQtzv6KKjkjEgwQeCCCD gikWS0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABR1oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigApDS0hoADRQaKACkpaSgAooooA+XI69m+Fv/ACBbr/rt6f7IrxmOvZvhc2dIuv8A rtnj/dFN7Eo76iilpFBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJS0mOc0ALRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACdqKWkoAKSlpKACiiigD5cToK9k+Fn/IHuv+uv/sor xuPpXsvws/5A11/12/8AZRTIR39FFFIsBS0naloAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkNLSUALSUUUABpmTuxtP1p5pKACiiigD5c j6CvZPhZ/wAgi6/67f8AsorxuPoK9k+FfGkXn/Xb/wBlFMlHoFFFLSKCiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKAEIyMUAYFLRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACGi iigANJSmkoAKKKKAPlyPp7CvY/hYf+JVdj/pr/7KK8cj6V7F8K/+QVd/9dR/6CKZCPQqWkHSikWH aloooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigBKKDRQAGmmnGmYywPP50AOooooA+XI+lexfCv/kF3n/XUf8AoIrx2Pp0r2L4V/8A ILvP+uo/9BFN7EI9CpaQdKKRYtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRSUtABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRSdqACiiigANJSmkoAKKKKAPlyPpXsXwr/AOQXdj/p r/7KK8dj6V7D8K/+Qbef9dR/IUyEehilpKO1IsO1LSHigdPSgBaKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiikNABRRRQAGkpTTTQAtFFFA Hy5H0r2H4Vf8gy8/66j/ANBrx6Pp0r2H4V/8g68/66Dt7UyEeh0UUUixCM0tLSUAApaSgUALRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFJnmloAKKKKAEFLRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFIa ACiiigANNNONNNAC0UUUAfLkfT2r2D4V/wDIPvP+ug/lXj8fSvYfhX/yDrz/AK6D+VMhHodFFLSL CkNHaloAQUtFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACHgUA5paKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiikoAWiiigAooooAKKKKACiiigAooooAKKKKAEpaKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACkNLSGgAooooADTTTjTTQAtFFFAHy5H0r2D4V/8AIPvP99f5V4/EOK9g+FQx p97/ANdF/lTJR6JS0lFIoBS0gpaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiikoAWiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKSloAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKQ0tFACUUUUABptONNoAWiiigD5cjr2D4Vf8AHjfD/bX+ VeQR9K9d+FQ/0O9P+0g/nTIR6NRRRSLDtS0UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJ 3paKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiik7UAFFFFAAaaacaaaAFooooA+XYulev/ AAr/AOPG9/31/lXkEfSvXfhV/wAel9/vJ/WmSj0aiiikULRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACUUUUABptLSGgBaKKKA PlyNhjqK9e+FOPsd97sn9a+dYriXP+sf8699+C7ltLvtxz8yfyNMlbnqYooopFB2opaQUALRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUnfpQAtFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUlABRRQaAEpDS0hoAKKWigD4rT71e//AAU/5Buof70f8mrwCP7wr6B+Cv8AyCb4/wC2n8jTJ6nq g6UUUUig7UtFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUlLRQAlFFFACUhpaSgBaKKKAPiyPhq9++Cp/4ll+M/xR/wAmrwBPvV778FP+ QfqHs0f8mpkrc9YFFFFIoWik7UtABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUhpaKACkoooASkpxppoAWikooA+K04b8a9++Ch/wCJfqA9 4/8A2avAE+9XvvwT/wCPDUPTMf8A7NTEtz1oUUDpRSGLRSdqWgAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKSlooASiiigANNNLSUAGKKWi gD4pQfNXv3wTH/Eu1D/ej/k1eBJ96vfPgl/x4ajjsY//AGen0JW560KKKOKRQtFJ2paACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApDS0lA AaKMUUAJSGnGm0AFFLRQB8VRffHPGa98+CS40/UD/tR/+zV4HH96vffgof8AiX6h9Y//AGamT1PW aKQUtIoBnHNLSCigBaKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACikpaA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKAENFFFACUhpxppoAKKWigD4qj+9XvvwUH/Ev1A+8fT/gVeBR/er37 4Kf8g7UP96P+TUyep6wOlFAopFC0UlAoAWiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKTpQAtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUhpaKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigApDS0UAIaKKKAEpKWkoAWiiigD4qj+9XvnwTz9h 1D0zH/7NXgsTYUptXkg5xzXvnwU/5B+ocY5i/wDZqZPU9YFFAopFBSDrmg88UooAWiiigAoopr5K MB1xQA6ikHSloAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApu0bs4GcYzT qKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAQ0UUUABptLSUALRRRQB8VJ1r3z4KH/AEHUB7x/+zV4FH1r334Kf8eWocf88/8A 2amT1PWhTec+gpwopFAOlLSCloAKSlooAKKKKACiiigAooooAKKKKAE5ozRS0AJmlopBQAtFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAJRS0UAFFFFABRRRQAUUUhoAKKKKAEpKcabQAtFFFAHxTH1r334J/8AHlqH /bP/ANmrwJM7q97+Cf8Ax6ah/wBs/wD2amLqeuCigUUhi0UnaloAKKKKACiiigAooooAKKKKACii igAooooASloooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKSgANFFFACUlLSUALRRR QB8Up96vfPgnn7HqH/bP/wBmrwNPvV738Ej/AKLqA/65/wDs1MR64OlFAopDCjvS0UAFJS0UAFFF FABRRSdT1oAWik+lLQAUUUUAFFFFABRRRQA0rkg56U6iigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKaBg n3PNOooAKKKKACiiigAooooAKKKKACiiigAooooAKKKSgBaKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAoopBnNAC0mOKWigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKSgAooooASkpaSgAopaKAPihPvCve/gl/wAeuofSP/2avBE+9XvnwUx9 l1DB7R/+zUyVueuCiiikUFLSdqWgAooooAKKKTnvQAtFIKWgAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACikNLQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJS0UAJRRRQAlJS0lABRRRQB8Up1r3r4J/wCov/pH /wCzV4Kn3q96+CX/AB7agfaP/wBmpk9T14UUn4UD6UihaWkpaACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAENA6UtFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFJS0AFFFFABRRRQAUUUUAFFFFABRRR QAUlBpaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkoNFABRRRQAlJS0lABR RRQB8Up94V7x8Ej+61Ae0f8A7NXg6feFe8fBL/V6h/up/WmStz2AUUCikUFLSUtACdqWiigAoooo AKKKQnAoAWiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACik paACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApD0paKAE70tIBiloAia 3hf78UbfVRTFs7aPPlwRxlhyUXaf0qxRQBB5TquIpWUgYG75h+Pf9aUPIPvx591OamooAYrBhkZ6 45BFPoooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKQ0 tJQAUUUUAJSUtJQAtFFFAHxSnWvd/gkf3eoD/ZT+teDp1r3b4Jf8v3sif1p9Cep7EKKBRSKDtR9K KWgAoopO9AC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUU3DbjzkH9KdQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABSUUdqACiiigBKSlpKACilooA+KE617t8Evu3x/2U/rXhK/er3T4JH5r4ZP3F /maZPU9kFFAopFBS0lLQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFIaWkFAC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRSUAFFFFACUlLSUALRRRQB8UJ1r3L4JZ8y8/65j+deGp1r3T4J EZvR/sL/ADNMk9kFFAopFBS0lLQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSUUUAJSUtJQAUUUUAfFC/er3D4KFhJebRk+UMc+9e IJ96vcPgkP315/1zH86ZJ7OOnSloFFIoKWkHSloAKKQUtABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJRS0AFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFACc0tFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUnegBaKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKTJ3dOKWgAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKQ4FLQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAlFFFACUlLSUAFFFF AHxSv3q9v+CR/wBIvB/0yH868QTrXt/wTH+lXZ/6Zf1pkntIooFFIoKWkpaAEFLSCjvQAtFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRSUAApaK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEo paKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAENFL SUAJSUtJQAUUUUAfFKfer3D4Jn9/dr/0zH868PXr+Ne2/BT/AI+7r/rl/WmSe1iigUUigpaSloAK KQUtABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRSc0ALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFJ2oAKWiigAooooAKKKQ0ALRRRQAUUUUAFFFFABRRSCgBaKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigApKDRQAlJS0lABRRRQB8Ur1r274J4+03X/XL+teIr1xXtvwT/wCPq6/65f1pkntY opBS0igpaSloAQUtIKBQAtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFIKAFooooAKKKKACkAwOt LRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFIaAFpKKWgAooooAKKKKACiiigBDS0UUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAhooNFACUlLSUAFFFFAHxSPvV7d8E/+Pm6/wCuX9a8QXrX t/wUP+lXQz/yy/rTJPaRS0g6UtIoKWkooAWk70tFACGloooAKKTvS0AFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAlLSUtA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSGlpBQAvaiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiikzQAGiiigBKSlpKACiiigD4pX71e 2fBQD7Zcn/pl2+teKIO+RXtvwT/4+Lr/AK5f1pkntIpaQUtIoKKKMUALRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUlAC0UgpaACiiigAooooAKKKSgApaKKACiikoAWiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKSlooASilpKAEpKW koAKKKKAPilete2fBPP2q69PL/rXia9a9u+Cn/HxdDP/ACz6fjTEe0jpS0gpaQwpaSigAxR+NLSd 6AFooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooASgUUtABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAIaWiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKQ0tFACGilpKAEpDTqSgBKKWigD4oXrXtnwUb/S7lf+mf8AWvE1617X8FP+Py4/65f1pkntgpaQ dKXikUFFFFAC0neiloAKKKKACiiigAopBS0AFFFJmgBaK57WvG3h7w9dC11PURFcFN/lJE8jAdiQ gOOnesJ/i94YQjab11OcMsI5x7E5H4gUWA76ivPf+Fx+F8cpqI5x/wAe/wD9elPxj8JhNxe+Ht9m NAXPQaK88T4zeE5ASpvzg/8APqad/wALl8KA4Y3w/wC3f/69FguegUmRkDua4H/hcnhHj99e5PQf ZWqpF8WfCkUzS/aNTKnO2M2p2r9P8+tFmK6PS6K8+/4XL4S/v33/AICnmnL8Y/CJ6z3g+tq9Fh3O +4o4rhB8YPB3e9uV9zaSf4U8fFrwiSB9suSTzgWchP8AKiwHc0VxI+LHgtozJ/a0gUMF5s5+pz/s exoHxZ8Enj+15P8AwBuP/jdFhXR21FcT/wALa8E9f7Xk/wDAG4/+N0n/AAtzwR/0GJP/AABuP/jd Fgujt6K4j/hbfgj/AKDEnBx/x43H/wAbpP8Ahbvgf/oMSf8AgDcf/G6AujuKK4f/AIW74H/6DEn/ AIA3H/xugfFzwOemsSdM/wDHjcf/ABumO6O4orh/+FveB/8AoMyf+ANx/wDG6P8Ahbvgfp/bMn/g Dcf/ABukFzt+KOK4g/F3wOOTrMmOn/Hjcf8Axul/4W74Hzj+2JMj/pxuP/jdAHb0Vw//AAt/wN/0 Gn/8Abj/AON0f8Le8Df9Bl//AABuP/jdAHb8UcVxH/C3vA3/AEGn/wDAG4/+N0f8Le8Df9Bp/wDw BuP/AI3QB2/FHFcR/wALe8DYz/bT4H/Tjcf/ABulHxd8Dk4GsyZP/Tjcf/G6AO3orh/+FveBun9t P/4A3H/xuj/hb3gYHH9tP/4A3H/xugDt80ZriP8Ahb3gX/oNP/4A3H/xuj/hb/gX/oNP/wCAVx/8 boA7iiuH/wCFv+Bv+g0//gDcf/G6T/hcHgX/AKDT/wDgFcf/ABugDuaK4b/hcHgX/oNt/wCAVx/8 bo/4XB4F/wCg23/gFcf/ABugDuaK4b/hcHgX/oNt/wCAU/8A8RR/wuDwL/0G2/8AAK4/+N0AdzRX Df8AC4PAuM/223/gFcf/ABuj/hcHgT/oNv8A+AVx/wDG6AO4xRiuH/4XB4F/6Dbc/wDTlcf/ABul /wCFv+Bf+g2f/AOf/wCIoA7iiuH/AOFv+BP+g4f/AAEn/wDiKd/wtzwL/wBB1f8AwGm/+IoA7Xij iuLHxa8Df9B+P8YJf/ialHxT8EEZ/wCEhth9Vcf0oA7CiuP/AOFp+CP+hhtv++X/AMKT/hangj/o Ybb/AL4f/wCJoA7GiuQX4o+CWHHiK0/HcP6U7/hZ3gr/AKGOy/76P+FAHW0VyZ+JngrH/Ix2P/fd H/CzPBX/AEMlj/33QB1lFcl/ws7wV/0Mdl/30f8ACm/8LQ8E7sf8JHZ/+Pf4UAdfRXJf8LN8Ff8A Qx2X/fR/wpf+Fm+Cv+his/zP+FAHWUVyyfEfwc/3PEFmf+BH/CpV8feFH+7rtmf+B0AdHijFYK+N fDTjK6zan/gVPHi/w83TV7U/8DoA3KKx/wDhKdCPTVbY49Hpw8T6IR/yE7fj/boA1qKyv+Ek0b/o JW//AH3Tx4g0g9NRtv8Av4KANKis3+39IH/MStj9JBS/27pXa/t/++xQBo0Vn/23pfH+n2/IyP3g pf7b0z/n/t/+/goAv0VQ/trTMZ+32/r98Un9taYTgX9uf+2goAv5ozVT+1dOPS+tz9JBSf2tp/e8 gH1kFAFzNGaq/wBp6ef+X23/AO/oo/tPT/8An9t/+/ooAt0VU/tOw/5/bf8A7+Cj+1LD/n9t/wDv 6KALdFVP7TsP+f23/wC/opf7TsM/8ftv/wB/BQBaoqqNSsT0vbf/AL+r/jR/aVjjP223/wC/q0AW qKqf2nYf8/1t/wB/V/xpf7SsP+f22/7+rQBaoqoNTsD0vrb/AL+rR/adh/z/AFt/39WgC3RVT+0r DGftttj/AK6r/jS/2nYf8/tt/wB/V/xoAtUVV/tKx/5/bf8A7+r/AI0f2jY/8/lvx/01WgC1RVX+ 0bH/AJ/Lf/v6tH9o2P8Az+W//f1aALOaM1V/tKw/5/bb/v6tJ/amn5x9vtfp5y/40AW+KOKrf2lY /wDP7b8/9NV/xo/tCyzgXlv/AN/FosBaoqp/aViOt7b/APf1f8aP7Rsf+fy3/wC/goC5boqr/aNi el7b/wDf1aytc8W6boFvbzT+bcCdiqC32t069SBQBvUVw5+KOjj/AJh+pn/gEX/xym/8LT0f/oHa p/3xF/8AHKfKyeZdzuuaOa4ST4q6NGuTp+qHjOBHH/8AHKr2/wAX9EuSRHpWrjHXdHEP/alFmHMu 56HRXDf8LR0jHOnamPqkX/xyk/4Wno+edP1Me5SL/wCOUcrHzI7qiuH/AOFpaRwPsGp/98Rf/HKF +KWjt/y4amPqkX/xyizC6O4orhj8U9HH/MP1PH+5F/8AHKP+Fp6Pj/kH6n/3xH/8coswujuqK4r/ AIWbpOzeLHUSPZI//i6YPijo5bAsNT+uyP8A+Loswujt6K4xviVpKEZstQ5GR8sf/wAXQvxK0phk WGpfikf/AMXS5WF0dpRXFH4maUDzp+pf98xf/HKZ/wALR0g/8uGp/wDfEX/xynZhdHcUVxH/AAs/ Sdhb7BqXHbZHn/0OgfE7SD1sdSH1SP8A+Loswujt6K5CP4hadKjOmn6iVUZPyR//ABdRt8StJQc2 WofTbH/8XSsx3Oyorjh8RtKYZWx1A/8AAY//AIupIviFpkpIFnfrjuyx/wDxdPlYXR11Fcj/AMLC 0zdt+xX312x//F1EfiTpQYj7BqJI9Fj/APi6VmK6OzorkYfiFpk3SzvwfRljH/s9I3xD0xZVj+w3 +4n+7H/8XRZjudfRXIt8QdNVmU2N/wDL/sx//F0wfEbTSSBpup8f7Ef/AMXRZhc7GiuQX4iaa+MW Ooc9crHx/wCP0SfETTI2wbDUT9Ej/wDi6LMLnXcUcVyq+PdPddwsdQ/FY/8A4uk/4T/TcZ+yX3/f Mf8A8XRYDq+KOK5MfEDTGOBaX3/fMf8A8XR/wsDTMgCzvy3oEj/+LoswOsorl/8AhOrDvY34/wCA x/8AxdOHjewxn7He8/7Mf/xdFmB09Fcuvjixb/lxvh9RH/8AF0q+OLBk3/Yr4L15WP8A+Lo1A6ei uZPjfTxj/RLznpxH/wDF1GfHmnjrZX4/4DH/APF0WYHU80c1yv8Awnunhtv2G/5/2Y//AIunHx3p wOPsd9/3zH/8XRZgdRRXLjx3pxyPsl7x6rH/APF0n/Ceafn/AI8r/wD75j/+LoswOqorlD4+04DP 2K//AO+Y/wD4umr4/wBNYkfYb8Y65RP/AIugDraK5N/H2nIm77Ffn2Cx/wDxdKfH2nBc/Yr4/RY+ f/H6AOq4o4rkf+Fhab3sdQB/3Y//AIunH4gad/z46gfosf8A8XRZgdZxRxXJD4g6aTxY6h9dsf8A 8XSt8QNOUZ+w6gfosf8A8XRYDrOKOK5MfEHTiufsOof98x//ABdMb4iaaq5+w6ic9gkf/wAXRYDr +KOK5H/hYem4J+wahx/sR/8AxdIvxF0xn2/YdQ+uyPH/AKHRYDr+KOK5I/EHTdyr9hvyT/sx/wDx dL/wn+nd7K/H1WP/AOLosB1nFHFcj/wsLTMZFlqBx1wsf/xdPPj/AE0f8ud//wB8x/8AxdFgOr4o 4rkx8QdN3FfsV+CPVY//AIumr8Q9NYgfYNRGfVI//i6LAddxRxXI/wDCw9L27vseofTZH/8AF0+P x/psjbRZ3wOM8rH/APF0WA6yiuRHxB03cR9ivxj/AGY//i6Q/ETTM4+xah/3xH/8XTswOu4o4rlD 4/04MB9iv+RnO2P/AOLpP+Fg6b/z5X/t8sfP/j9KwHWZozXJD4g6bgH7HfjP+zH/APF0n/Cw9MJI FlfnHosf/wAXTsxXOuzRmuP/AOFj6Xx/oOoc/wCzH/8AF0H4jaUBk2d+AO+2P/4uizC52NFcWfiX pWM/YdRI9lj/APi6X/hZOlYH+g6jz/sR/wDxdFmF0dnRXHH4jaYBn7DqP/fEf/xdJ/wsfS9ufsGo /wDfEf8A8XRZjudlRXG/8LI0vj/QdQ5/2Y//AIukPxI0tf8Alw1H8Fj/APi6LMV0dnRXGf8ACydL /wCfDUf++Y//AIukPxK0oDmw1H/vmP8A+LoswujtKK4xfiRpjvtGn6jk/wCzF/8AF1qReKYp4fNj 02/ZfpHn/wBDo5WHMjfornH8XRxoWbSNTAH+xH/8XWLcfFfSLZisml6sCP8ApnF/8co5WHMjvaK8 5b4y6Gv/ADC9XP0SH/45SL8ZtCb/AJhWsD6pD/8AHaLMOZHo9FcFF8V9HmGV07VB9Ui/+OVOfidp I/5cdROTj7kf/wAXRysOZHbUVxX/AAs3Sf8Anw1H/vmP/wCLprfFDSVUn+z9S4/2Yv8A4ujlYcyO 3orhx8UNIOcafqXH+xF/8XQfijpAGf7P1P8A74i/+Lo5WHMjt6K4b/haej/9A/U/++Iv/jlH/C09 I/6B2pn/AIBF/wDHKOVhzI7qkxXCH4qaOP8AmG6px/sRf/HKYfixo466Zqv/AHxD/wDHKOWXYXMu 532KK4L/AIWzo/bTNVP/AAGH/wCOUUrMd0fMi9a9r+Cv/H7cf9cv6ivFF617R8Ff+QhP7Rf1FMR7 fS0gpaRQUUUUAFFFFAC0UlFABS0lFABRRRQAUh6UtNagD51+J7Y+IWqMHXKiAbT1/wBUtcaZGrsv igU/4WJqO0Esqw7gRx/q1riWJrRbGb3F3N60kyFlOCfY0cZ4z+NKWPAyePWgQyMlF6k/Wj526ZOP ShxSgOyMyoxVFy2B90Zxk/iaAGliBkN3pdx9fakkl3MzYX5jk4FMzz6elA7MeN34UbiO5poJPGeB S7uWOBz7UBYcXIXg01Xd3CrlmboO5phJPbr0prYxRcWxNuNSBjtz27c1AtO7ZGfyppisK75PfrTP MPHamvTM0rjsSrKw701nxTTj+lAIP3vTtQOwryZPFMLGkPFN3YOeD9RSAdvb1pC5xSM+eTjoBwMU 0cnqPxpFD95NG81GfypM4oAfvNG80w560n40mMl35NJvqPPNGaYiQvSeYfWo6KQyTeaXeTUdNpiJ d5pN/wBcUzNJmkxkm8+tG81HRSAdupd5pnaii7AkDH1pN59aj5paYEm80bzUdLSQD/MNG8+tR0dq AH7zS7zUdBoQEm80eYcVHnmlpgP8w0bzTTSUCsh+80eYfWmHpSUhj9x96Xeaj6UUAP3UbzimZooC xIHO4GrCyHAqmOtWEPA4paj6GpayEbeTWzA2RnPNYVp26Vr2xIAFaozZrwMT7+ma0IiuMHPtWZAx 4Hr6VoRcAe1USXo29/zq2pOOvtVGPr/OrSn8KBWLak5HJxUwPaqqE1KCccdaYJFoNkVMjfgcVTz0 5qZX9QORQPqTg8Uqn17dqizjjNOQ/hzSGWMnZweaEJznefpTAacPakGxOPrTlPp0qIH2/KnA8fjQ Mk3E+v1p4c96iB4pQR15oAmD0oJqEE9TTg3r+lICTdS7jio85pT0oAk3cYo3cVGScUHpTFsSb+et LuqIH9KaSd1MCbJA604Of/rVED8tKKVwHFiaXJpm4BsZ+Y84pM880xEu4jvSqxzyaiB9aU8dqYEu /FG8k4FRZ70u7HPNIYrnmonG7ocH1p+aQ0yRwchcZpNxpp54pirsG0EmhCZMXPammQk/Sm9qQetF wHMxrk/GBcWtq427I5CMe7A//EmunNcn40/1dqO+TUy3RS2ZzSylu9LI5C+1VRx0NS7iy8itLmPk O3bu+KYhVelIQW4PSh9mPlBxjpnNAFkSDHAzUZlOeeBUKn5cLS4JAPSgZKsh6VICTj3qBGO37oOT 171MDlc/pQA9lYYx93vUav8AvPpSs20YxUCSMXboPwpFF/zQRsTJ7U9QUTkZJqikhWTljz6VeKMy qN1A9yEyuW+Y8VMshC/L9KJrbaqqfvHvUiRhF2g5yKGNELuWGM0ke3OM4prj5sc00Jn/AHs0eYaE qsHbBoZXHzHpTAuxxjrT3b5uxFL0DoW7bUWgjdF/jGDmoFUyzqT90elRxrkM5+lOjlKScDv1oGic j7wBx9KckhHAqJJdrbiuaenL5A4poGXkAMecjiq0rfN8tSBsfLVkW4EBfHWhjsZ37wKsinocdcVa V93LL83Y1TMTPIMtj1FWEYIw38r7UrAhsxYSZ3fMas282xTuXcTUEzxSyYQAY70iFkkCipGTF1U7 T91u9K8oC7euOhpsrI6qDjdVViyvx90UxlyOZ/L542mmszHnHWodztzuOKkMmQqbfxpB6C7nEqhe B3qzbK0bMz8kniowmdrH71XFQOmcEcUDSLQlRzg4+tNd1dtkZHBxzVK4wse1Gyx/Oq6O0EYBbLet KwXNX5Ek2nuetQvcb5in8PaqqzNIud2SDVZZWMrHqKB3NB5cFRn6UySXHXBFVS+4Dj8aFxtweaAL UkuVBHf2qF5iNpphPyqPTik75oEWVOfm9qa7uxH0qJWw+OmRUkmBg9DjmgYPIRFjkEVHHcO3yqMM KHIfAB9qYiL52c4wMEUmCHl3D4wST3qYn92F5x/KodpB3M2QemO1MhcvLIgLEIec0hj5ThWUEZHG aaJNtup3HimjDSMQuB6U0/Oi9OtUSWBJuT5e9R5YKW35UH/IpykCP0prlGtwGAH070LcCSOYlW/u 96iY7jhDx/KmwruK7Twe9PRVWYDjBODQFgYshXoVFMjO18Yqe8Aj+790+nes3zsP+NAFwzbWyOo4 p0lwzopODg1WkA8svv6dqdbMrByw4FAiVpNrcHr2pzzpsGBg1BuyMnjFM+8pBFMGWUmzMoOMelF1 MsKLIzhRVNW2sDVDWjI8CKCdqtzQJvQ1TJvlXD5B6U/c6yDByP4qxtLkkmtBnloyAD7VsP8Au3B9 aYIeZf3gZe1I7Ybd6npUDyj5So701pCWxk0hl55gFUkZGKj85gNynHofSoCx29e9LuHQ+lMCcShl 681GCRuy1Q79uKZGXd254zikBJI4/KjeSgps0eG2/lUcYIcpjoKoQ1mOQR92pBJsAU/WmsVwAKhO fvDJ/CkBcM+FwOlRLM34dKaq/KMVGW+U/XBoC7LJPz57CmtLzUYcHHXpVWR/m60CLolzUUtyEXmq wlx3qpdyFoiRTQmXF1IRSbicj616V4E8Q2t/H9mZx5g7E14LLcSElWbpU1pfXVjMJrado3Xoymnz J6Mlaan1VNFb+WxZVx34rx7xv9iN3KLZRwTnFYDfE7Xns/s0kyntv2/NVRL17xN8jbmbrRFcq3HJ qRju5DkUwSFH9u1WL2EByy9KqeWxNQI17O5wACa1kl45NYNtC33qvLNtXBxmrQuhob8lfTNI0vGO lVUlJYdxWjLZj7P5w6VdhXRXVvc80OxAGKi3AMQc8UisSRu7UtgFLENjmgMQKXBI6HNLHCZD0NMV iAycZHpUcmSVrTg015QcrmtG30EuQWVvyphZnOFG447UV3kXh9PLGc5orJtXNFE8GXrXtPwVH+n3 B/6Zf1FeLL1r2j4LH/iYzD/pkf5isTU9uFOFNFOpFBRRRQAUUUUAFFFFABRRRQAUUUlABSHpS0h6 UAfOPxQY/wDCxdWHPCwf+ikrjWrs/iiAPiJqfqyQnj/rkv8AhXFKTVrYze44gnoD/Om7ucelPzjk HrUR60xIec4+tRnmnEn1/WlO0NlQQPQnNAyPihd4b5XwcEdaD3poHOaGA9eSA2FxxmlmZc4Venf1 oYnbj15prPlcdMUmCI+R2PrRkgYpevLDPbmkPSgGPXaFD7xu3fd56f5/lS598Z7VGOn1oJP1phYU Y3ck0jgZ60hp3VSccUB6jCSVGSeOlIc7V9+RRx+NIaABie+c03afmPp70Nx/OkzxSGtgwSPpTacM k4HfimUhoKMcUrHJzSntz2oYDaKKXI280mMSm0pNFIBDRRR2pgFFFB/zxQACigUe1IBKKWkoAU9K SjtxR+dABS0lHpQAUtJS/nQDCiiigA5ooooQCUtAopgFONNpTSuAh6Un50tFABSUvakpDCiiii4B U0JycVB+FTQD5qEBqWuMjitiDGOOaybYYxWvAB09a0Rk9zRg+8Kvxe3SqVuCAKux9uxqhFtDVtB8 tVYz8wFWUz3NMCde3WpR364qNeKmX7tF0Fhy9OfyqVenXiouB7YqYLx04NALceufWpVx0/Kowegp wpFEgApx7U1e+KePrRdgPAx0FOHpTR0p/ekFkGDTxg4FNx2FOA/GgAHHFPHSmgetOH3cUhpB0PTN BPGRml5xSdqYCjn/AOtSmmil96BWAGlApM0CgLBk7uhp30pop2KegB9aOKDQOlArB15pw4NBFAo6 AIfSlz7Uv+elIaLiAUGk9/wpeppg9hB7UhxSleOnSjjPSgVhhxQfu9cUpHOcUh9/0ouA3jt9K5Lx t0tDj1rreB2rk/GeGW1yOmal7opbM48Zzz2qf5dnDZqHGSKfyGwK08zAmVSycVXbg4NWIZivygVH Ovc0xjIzxzUmPl/+tTUI2ADtSjc3fFIBeaeeFyKZyW46U9B83GetNADEsaFCIcN3qZk7kVVbl6Bk hZDID+VaEW/+IdelUnQKoY9u1TxTHaNzVLLViUSM5bPRe1QiR/Ozu6VbYW6WzYOZGrOZsyYzigZL N9/cc0hbaetPZcqNp4FQurdfwpiHlywBYA9qlGwnvVcHC4HWpIg2clcCpGOb5T978KFB25znmhh3 NCtjApiJ0+cbscVIcKRiok6dacy5GfwpFE00gXawzu71LDcPIApPHpVIhcKCcetWIY1Kbt/zHtRc ZIvErZyR2pkikt0/DFWU2kbTgMOhppCs3X2ouBAkUbR+VDw/U1N9mKRKC37w+tTxLHGA2AGFB+dy V5xUjHLDD8u/7w6VG8W4NxgVKYM/PIduBninjb5WKYymIkC5HensE2r0LU6YqBx0pixgYZ+tIEiV E3tHJ/d9KlefHHTPFU4ZXjlZV/1fehWeSY7h8o70/UAD/LuB+bPWo5X7CpHZWZkVDkVCY38zHtSY E0LDaynhm5pGG1flI/KhfccilDeZwF6UXHZiRgnPFPI+YcAUE8kL0FBB2qDii4DZG2gNins6bMg4 zxTZcHr1qMpzj+HtSuAqspX5ql3sY/n7fypkOxWwcc06YrhgcHPFAEgcKny4PpiqskgD78HIqT7i DbTX3MuSFyTQAREykf3etWQAHZ8YZqrxj5QmcDoMU9zllA+8PWhWGNj/AHaNu5Yng01dox6A1LGq yxsTkN2qEI25cgFeQ1O5JY8stGwXv1qBlCrtA4/rUyl4jtyQpqvKTu27t3cUDJYyBHjpxSF1VuxG KQ8Q9DUAXcf0piZNJL50KlTle1VZEVCO/FTHCDYgwvpTQV83cw3cYxSBjArMOmalUKiqT0JqxCFM HTDMcAVC4469OKOgDJW+YY+6KSPdjmif5flHPHahMKsefxpiIWUMxYdM9Kq6grGHvWkgXDY6iomj WRWVunQ0dRNaFDRY+JGBPJ5FbUh/dgntWPpf+jySRs3JP3a1ZAwQ4NDCGxXAG7aBhakZVEWfWolO 7GeKnORHsYfSkihjkbeB9KH4Vdopzg7VyME01WIbkDFMCM8cHvRH+7GOeTTn+cUxTtb5vumgQ9zv fB/A1Gw2SMw7ihmCyL7mnSqWKqOKYuhCQEH3u1CMce1LJgcbaRANufegByt97mkT94GHTmm5+9TY so/WgB8i4ye1Z8x61pOOMd6z7obTt60E2IFb602TkUwNjg9qPNAHNK4rGXcW6iUkjk1CYGI4Gc1e lYSuPyrptG0WG9t8MoDYqZDSOBcHdzWpYeZ5fAJ4rS1bQWtpyFT5RWpo+noIFLp82KpIDBuFlAyV P1otYnaQZUn0rsJ7aFoyuwc+1Ukso4nJAq4qxM0QQ2/7vG3tVebTS7bgcAVpSSpEuKpvdk8Ka0UT NsaESBcdSKPtEjDaCcelRrG8jfWtjT9JaRuVq5NCjFszktZH7ZzV2PSZZMDYcfSuwstDQKpZRWol nFF0QdK53M3VM5G20F227l4+latvoKR8sBW7sA6DpQaHJlKCKcNhDF/AKnZABwtP7c9qa3tUsdhu KKd060VIz5lXOa9o+Cv/ACEpuM/uSf1FeLr1r2b4K/8AITm/64n+YqQPcBS0g6U6kUHaiiigAooo oAKKKKACiiigA7UlFFACGg9KWmnpQB85/FH/AJKFqmeflh/D90tcYF54rs/iev8AxcTVPdIP/RS1 yCjFWjN7hJ9/moT96pZiWfP8VRbefwpgNIoOepoVeeeKkHAxikBEWJH3qavX/wCvStz9PaljUMRk 4HrQh6CPjPH4UKflI4456U1/vcUduKEAhJZsnHP4Uf40vzZ5zQaBDQME0nPWnr0pvejyAQ5xSg0H NC8c0ADE7NuT1zioc571M2DUeB2FA0NzxSKcUpoGPWgBv4Ug+ZgOBk96caQ9qkaEPHGfypAOM44p yruDYI+UZ602kMccY4zSHnAApBQaYCfhRRSGkAUppKdQA2ilpeO/pTuA3tQaKKQCUUtJQAUUUgoA KWiigYUClpKBC0UUCgAoNGKKAEpaSl70AAoNFFACe9KKKSiwCjrQdu3gnd3GOKBRQAhopwxtbP4U mKQXGmp7cfNUJ/lVm2FMDUtVOe9bFuDx0xWZarwvpWrbCr1IuaEAyelaESjIqjCp44q5D879MAUx WLMXzHOMc1cUVAgHb8hVqMDimIkFSL+NNUGpBwOn5UAPVe9SqKavTpUgFAx2Pmp/H5UwCpAPxpDs xw/KpB0+lNGDTu3H8qBjl+brTh1HWmr9KeM496QCDFOHXrz1peOlKMUAGMHNOHTmj/PNKPcUBYQZ 9aMcU7AowKEA0UtOI7UmO3FFw6DdtO7Uo/zilx60xCLQO9LinAUgsNP3elFLilK8/SmgG9qBSkUo pisJ9aTvTucemKKQDenSinU3GOafoHqAHehqXOBSil0Ab+FRkGpm9abjjNCFYjI4rkvGQ4tdvvXX EVyfjDGLfruHt9f/AK1J7of2WckU568U4Lz1pCKQHHNamBIhCc4P5VDId55NTBvkxUZ2kgBSPpTA IkIBxj8TRg5xUyJtxk/pSOvzcZpFIdHAQpY0kTYfn9KcFcx855HepI0VBllz7UDGtsPG7GaGtm2h l7U0/wCs3AYq8kqiPBoY1uZ7bs89qjD7ptuPar+EZdwGDUH2ffNkED3o8gsSfZ5m2sBlaBac5PXN XLeZkTYWztqN3LvnNSV0J44AkLZ6Y7VSMJO4ipjOwyhPFM8zYR70WYECxHzOnSryQkx1EuWUkD9K WFj0Y4o9QJPJG3DYqMw/pT5CRjnIpDMMA+tPYdkQRqy5z61ZiXPzdqcsiNEqhec9abnbkUeoxssf zcY5qazhxNjOQKYVaTBXt2qzDlCBjrSW4E0qYU4A3dKjhtkAVA2JKkkPIPJqFW/ebwcUDJZYUPD9 R707YirtRjn+VRTAvMrdqmuJBBCrr99utIAaYiMgg9armdsldvbNPU71Gec0yQYfrSGNSZSyoeCa dLCZNvzcVGcDnGcVIWOV6igByLtypoRcHB4oZedxbkUIWJ6jNDGPMRDb3b6UhClWOPmyMHPSlU7t 2Sc4pjoTyTjFACtgN0phyMFOR3FOmPyjnmo4m2t83elYB6IcFum6pYsFlQ4+tQ+YWGD1HHFOjcLK C3QUDJJVGc5HpUbJ5oUdM85pzgNznqaj8wKUx1pAJjDYqQBT19KY4zSby28NhaLgkJuQEAZxinAH O7se1MBzMEwBxxU77QcFcDoKAIcfPz2/nRHE8soyaVe+etPjZEljYnsRSSGOcBQyoSGpsa574zUz Mpj4Tg96jRdkkb9VU1QraBcR58rGQ23pSJAFOJPTrVqZwyDgFuoIqq0jEE8fKabJGOjFM4PtUcHM 6qTU4mUjHJwaZGP3zPt+lIexG8OZzyR60wjac1PKCu58EZqHdxsIyx5zTEThGCh8dKYSJbcsv96g ybrbZk/JTUKxMw5AI5FIZVYsrZ6q3rUwcLGrDls81JchGhjaP1xiq5Xkr07U0TYch/ebqmCBYWc4 5pij9KnZg8GzgE96dxnNJK41JXVcsXxit+eQkKCeoqutokdz5v8AF3p844GD8tJiQsoDbTnH4U4v uCZOcVGMmOiFC/PNJFMtSnzGX0psyYXgUNkBQacw8yM470xFcphAaacfKe1Tghk2YGR3qB+oQDvx QA6UghSuKNx8rcc7qYg2jB6ZprMQvTHpTEKzAquQfypqrhCMYNMydvWpckspHSgRGVG5efwpyr81 Nxlie4NWEx3oBEeMtk/hWfe1Nc3SRIwZsYFY0uqJKduelJyQWYyRirf/AFqrSyFuKe77j05pqRbj 70tyS1Y2fmnc3FdpotzHZBVbtwa5O0DLWvBmq5eg1Kx0eotb3sisg+anWtgfKHb8KzYWCjmtKPWk hTYqbuKrl0KuguLbyx8wrDvblE4U81evL6a6B7DsKyZLF5HyAfyrWK7mMn2KMjGSQ4yfSrFvZSSN 901r2OhPIfumunsdFSJV3j8MUpTQRpmDYaM/ytt4966qysUgA4GRVpIERcKuMVKq4rFyubpJD1GD xTWHPSpFxSOPapRRBTT9KkP3uaaVpiExxTCKl/hphHNICMgZoqQY5+tFAj5gTk17L8Ff+QrN/wBc T/MV42vWvZvgrxqk4xwYSenuKkD3AUvGaQU6kUAopKWgAooooAKKKKACiiigBKKKKAENIelKaQ9K APnf4nn/AIuBqQ9Eh/8ARS1yEY+brXXfE7n4g6oOOkH/AKKSuRwyVS2IluMmGG4qM/d6U+Qlm4pu 0hiCOnWmIacAdKvaY2jpHfPqcdxLJFCJLWOO48pZZN6qUPBPRt3GOEPNZ7cfnSEc8UhjQPmxTh/K lwR1BHfmhQcn260xEbjjgU3GB1qY+lNK8Z5phdgFODx0601qFyODxTiMrSAjB5oK0YweAfWlzSAj pfumjvQevHaqAD0qM1MQMf0FRgb3Cjau5u/AH40hjT0ppB60opOjZHFACc9aYaeaRgQe34HNIaGd 6d270ntRSGHOKQZpQflx/Sj2zQAn+NA6+lLSd6QBSU9l2hfmU5GflPSm0wA9aSlpPxoABRRRRcQh opaKBjfailopXQCfWl7UlLQAUClooQBRRRQAUUd6KACiijFMA4paSikAGijFFABRSCigBe1Hakoo AQ9at2o55qpVy1HNAG1bHcqg561q26jI4rMtVzita3XpVkGhD2461eiXviqsI4q7Dx+NP1AsIvPu fapxxjio4xu6ipwOaBE6LmpF6U1fYfWpF+lHkA5eTzUqgetIBT+3rRcaQoA608fdpFHanD0pDFUY 6U8Z+lCinCl5jET5h2qQZ6Z4FVoZMySIfvBqtdqADFO7ZowP0pQMGi4B9TS8CjjP607HfFILBj1P FB60uKTHFAB+NKaXgmlxj1qhDaPpTu9FFwSGj0paMU4CgBtH5U4D0pe+KBWGngClA5oxzS9+KAE5 pBT+tIRincLCH+VNIp36UdqEDG/56U4UUClcLaAfTFMOfTpT/p1oIpgRH6VyfjAECDBIz19D1rr2 zmuQ8ZDDWvTOP8anqP7LOQI9e9N746VKY+aXy/mH6Vsmc5JGhMeMZ7VCqMsmO1XoflX61FM+G6UD IXcHAxilLED9KaZzFIrqBuU9xkVHE2UxRYCwjMV60bsEbjRG2BgijGOtAIUtgZNCSZ7Uxs4p0QG6 gdiaHB3BulEzgD5BjHGaawPRak8oYUvyPSgY2J8Ljoxp4z9BTI/mnPZewqcjGaQytLuyuD+FPjXd 1pWQH5u9Kueq0AWSSseAO1Qq3fHenh+mf0pWG3nbRYYsbBiS2M9KikXPAp0ajPPFNOQzdcGgLhH8 q4weKlU85IpqPl/rxViJF2sSaQ0LCRG24VNuUruX7x71ACMdARTyw8nIGD6UhjXnWMKrN1oRkzyP vdKjSH7QxHA2+tToNm3euPrQmBPtX5RntilKNt2tjb0piq7HzM96nOGO1jg0aDRAo28fw0jgHp19 acVKydcg02SPC7h92gERnpx0NTpGGUFif8KYNox8nFTojdMZU1Ixu3dH61Vkyjnb+NacAWNdhHTO KpTKBcYPfqKBjo8YWmysFDDg+lSeVhcjtVOUnJJI4PegBzMDEob7wOKiO1gwwdy1Lt+Xd+dOEO4s F7jOaQEcR+X3pxHGR9aYuY2KN1qT+HPOD2oGKGbae9QsC3NSfdXPrTokLdMZpeYAjN5Y474pZIzv 57U6Tco4GTntSMzsoyOn60DJFCiRXwPaoL1k3IjYDM3HPNSrnH06VXFustyssqZYDj2oF6E0KvtO V/OhAgYsRkkflViTBXYpw2O1N2jbgDkdTTAVmAhwRxUEfAdvfIqxIgMec1XjTtz05zQBYKAtGd45 XpULIm5hjOKsbcqJB2GM1CzZ28DJouAySNLcgnqV6VF5mCFHfvTpSxkw53YHFR7Sx9O2Kb2EtyzH +8cRnvSXEKREFAOahY+WF+bGe9OuZAjcNlcUWGQ7iMgnrUzeW6KT94cUz5FVXz83pSbGZt4/ShiG kYYH3pH+dWOBSyyfN8wxUbkLJnblWoETHO1SeCevFDcyYx2pzsWjVjgAUweueo4pgIw+fPfFNGGk UNnHSpEQk/TvSGElgQeO9AImkgQdPu+gpsHyQ4xyaZGcSMnPPNSBcofm6CkN7kYLM/I+nFKjhXVT jmnphTg9cVVlYCfLH5s0CJOjn3qE538dKnbLEFaYV+6OaYEKF2PJBXvQ/PTNSRx7Xyfu0MEHPPNA WK6fe6dafwH44XtT1XjbnCigqM4FAhqpjccnnpUg4XnqKMfKD6U442HPFMDmdUdZWKFuayVtUByG q5rYMNwcd6xhOw71m2hWZpLGAfvVbi2AjJrDMz+pqxC7Hua0i0ZtM3opk3cCryXDdqxLfORWvbxS P0FaXEjQiJfvmrUcZJ6U+w02dmzt711Fno2Apfr3FLmSNFG5kWti8oGFP5VtWujoCGcdK1YbaOIf KB+FT/Soc7lqJDHBFHgKgHbpUmKd2o7VJQ09OlKOeKX8c0oGMn8qAHKMGlcUi/1p0nSgCAjsaafr UhHNNxSAaBnjpTe9SdO1MP4UxDRiilCmikB8vL17V7L8FjjV5R/0xb+YrxtetexfBb/kMSf9cW/m KQM90FLSClpDF7UUdqKACiiigAooooAKKKKAEooooAQ0h6UppD0oA+dvib/yUDVeO0P/AKKSuPLM Riu0+JGP+Fh6rlv4YOP+2S1yMsYUbqpbEPcq5FOzg0KMtT2Hy56fhTQmVm+Y0bcN3qZgCAajJG71 pAB+b+InjuaRQeaTBC5HQ0dRQMQnqeKM/LTCpzQc96NgGj71TdAahx71J25pisQtQKcwpg9KQxRT eppwHpSHimJjj0qPFPLUnTODmgCM0wn2qRqZUlCUh7UppKd0FhCc5P8AIUnelHXmjtSuhhSUooNI BtFFFMA7U4dKbS0AFJTgpYNjsM9abQgAUUdzR/kUAJS0f5FBoASiiikAUvb602losMUUdKKOaBBQ aKWgBKU9KKSgAooooAO1HNLRQAlFFH86ACj/ADzRQcZ4zSQAOeKSlpM0/QYncVetfWqPer8C5AxQ Jm1afdGK17frWXaDC88c1sW/UcVRBa8zy1Udya0oBlf61TWJXK5HQ1oRYVeTVaCLEYxVhBzwKgj+ uan4C9aQycDg5NEM6SSMiuGZeuDVHU7tbOxknJ+6OB71x2i648OpLJKuFd/m56is6lTlZcIXPSF6 1Kv8qggkWRFdCCp71YU8VdxWHD8qcOTzSD3p69qAFA4/wqQCkFPApAinIu25Dj+LrVuOmzrlenI5 FSIMrQFh4HFJ+VO/HtS0AAApeMUDpSgdzRcYg4NOFAooENAp348U6gjt2oCw3tSY96eV6UuKYWGg cUc0/wDwoAouAynfj+VGO1LTENpQOKWlBFACYpvf/CnEcUu38KQDOpoPv+VLjn+tJ3pgB60UUo6U AJRj8qKMGkFhu3muT8XJvkteM/5Ndae1cr4swHh/3eP1pdUN7M5mS33fdxwM8tio40PG4dKezZPB 4py885rc5hsj/LtFV2+bvk1OQC2aYB8+f6UWArSR5PzUxBjv0q5LyvSqvlnfxQBMp3HFOkzt4Gab sxjFSdvxoexSsRKPUVOo2kZqPac1MFGz5uT2oAkCgkLgYNOkHUY5p1tt79aJMAnBwKRRVUbXz0qY 7iOR9KhlLD6dqsglogO+KARAcrnPSnRP2AxihQu7k5OeKGX7xDYJoAexw2SM0rtuQAE05cZUZoYB Wx6UDEzlfmOPSnqmU5NNwjJ8v3hViPhDk847UhlU8N6YqQMPLx601lDk9qFGODQ0BJtwOvvVlEVo uo3VXGCPpUyNxU3GMRZY3Uhcq1WLgllCDn1xSpcCNgh5qJZVZmKKc5oKJArAbDkLTggLbt3TrTop QW2MvzYqX5V4xigSIXYHjkUuG8vHWhgGAx2p8RGNvrSGRAetWFO0ArUZZQDxyD0qxb7GhXB596Bp ClmJHGM9DioLqNjPuIJbGM4qeYvuWMt8p6VDdyyLBJHH8zjpQwGMWjT/AGT1NV3j8xenHrTpXHkr nr/FU9sF8g+p6GpGQmNljyCOKfE+N2/ntxUc8mODwOlQLJ82PTvSQxcfvM/w9Kmk6ge1VZGyn1NT IM/PnjGKoSAJnOTTirIflPzU6HrjGaa6OZiOmakdgL/u+WxzUqxFk3MccUhj6g9PeiQ5UIAaGA1D tO4rnaOBQ0uHVVXK55xSmPCgEnOKj2FdvfJoARZzLPKqrjy2xmrjEbNnQ45FZdmpE11lc4k+9Wim HOWbGBxQthESkofJ9eQafyqoGxnoaRpBJHgDGO5oXf5nK/LjpTQE7b/szRheVqom4uM+laF3sFur q2cdQBVGN0LZPXGKAZGy7WVsj5qad2eue9PZMyKc5X0pXDbsYwKYEbZkOHGF702SDcxXOceneklL HGOlTwnIdmPai4FUfeUMOBViAHymYtwe1RsoOQv3utRws33cfMT+VAiRodxAHVqPJ45+8vFTkbSj 5wwqJSxkyzd6YEU2QgQ4oHyqTg/SnujO23+6adccbRwD6UBZWJIcGM5NN3bSuDlTTYDzQw4Vvwpi HqAZmPelZQr8YqOJipyeSpqQHLFsCjYaBnyNzAZqoyAvkjNWCAThefX2qJ07Dg+1JCEQ4jzjn0p4 UsvpSIuOG54p5Y4HHAoKsRYckj+GkRR0IpzP8/XAqNWLvxmgQmQJAPWjrJgDvml287hzSs4h3Oem KGwjHmdgdlQZbArNu9VhRQF5INZV/qTyMwV/lz61llyxOTya5J4hv4T2qGWxUbzJdVuoLlY3R5DK c+YpiAVfTDbiW/75GPes6OHzGAA61JLTrN9lwmfWiM2c1XDRTaRYi0mZz91sfStqz8OyPt+U1r6f KoVeBW/bSL8uB2rsVkeW4u+pmWHhb5V3CultNCtodp2g1LA+avoaHJlqKJIYY0X5UHHtVgVEP0qV TmpuPYd0p3f0popwpjF4pRQKMUhWEPT8ad/Kk7U7H4UwFA5/GlfpRTm+7SGQH+VJTjTKEhCGm4xT qae1MBvQ4opaKQj5eXrXsXwXP/E5k/64t/MV44vWvYPgv/yHHH/TFj+opCPdxTqaKWkULRR2ooAK KKKACiiigAooooAKSiigBDSN0pTSHpQB88fErj4g6oT3EGMf9ckrmX5T/ZxXUfE3H/Ce6lkdEh59 f3S1yaNuTbTIdrkKbc8Hg+tOZwG29cflURTa9KEL5x2piGudzd8VG4qUJzngUjjt3oAjx8vFRHip 8d6iYc57UDGj1p4QuG4ztGaae3Tj9acZGKAZ6dOKAI1Hr2p7ULkmkOPWmIZikIqQ/wAqjPWkMbQO TRThTExrrQv3cUO2RTVYDrzRdhYaajPWpKRlx1H50h3GY96TqKe3JJxj6CmnpSQxKKPel/yKYDaD S4HNNpDCilo7elIBPwopDS0AL2pDmikPSmAUdvelwQaSgAoo60dqQBR1oooAKSiigBaMUCikDAU6 kpelNAN60op2PTFJQA3vS0npS0AJ0pfwopaAG9qKWkouAUelFHekAGk7UtFAWGjrWpZjlTis0da1 bMfL0pg9jZt+3FbFuOQO9ZVsuSvFbMHrjFUiC7CCKt+XvC5I+lVYvvYq9Hg0wsTquFFTqBUadae7 BImb0oA5HxZf5X7PE/yoecVyEcj5VucZ9as6tKZLtvr61SUYIJBI71zb7nQtNj0/w5fExxxv91ly nfFdOvPSuO8FxF9P3so+V2wc5zzXZKOnb2qqV+XUmpa+hIuKlUUwLn24p45wK1IFGRTx1poz6U4D /OKQDtoK0LjbxxS446U8Dj0oAbtpwBpQOacBTBIQd6XHFL2o/h/GkAY5z/WjHPSlpfzpgN7U7AHS jaKMd6ADFHalPSlHTNArABS4pM/5xQaADFG3mjmnEUXAbjn+tGOelOA4FKe3pTQDMe1FO7UmD6UX AZQRTvrRSAbSdO9O6HpRj8KYCHpTaf2pMdqAGnp0rkPGPyvbE+n+Ndg3XiuO8Zn57UZ/zzS6oH8L OZ6mnKp5GSKamcYzUgznjjit1scwmCrYpp4z+lObpTMdqY0O+9tHeoxxJjGakUH/APXTVXn5u/Sk AgXBwRUgjJ420wNhju+72q1A4dsUFWIQu1vxpz+1OlBDcCoc4P8AOgCSLGDg804v+8wajQjfxTnB V8gZpeoxJMMrAdTRH8o2Z6inqB3PPpSbcNQABcc0pHy/yNKTtB6moo2zn0pLcY5VIHqRUh+7u/ip o4FSDZtoGIvyqGBzu7VKh5wT14qDAVuv0p6nc/UUbAOl+VfrTQ6lcd6lkHy+uagRcmgCT+EelTRM jNgEcVGBtUA0sUZVmIFS9hltYS7ZUZNXI4lihLYCtVeNdijDc9akeTe2GU0mUivIMScH3qQbiy55 FOkRS2fUUBW6DPHegNB37tFbnnHFRxPlVP8AEOtPm27cZ+bFQQggKpGe5NAMmZgWyykrTYX+ZuDx 0pf4T+lJEwXqvWgZKJt43N94HHNP4I3etQSDbzjjtRG7+WTgdKVxibOecHd60g+aPugU/nTRh+D1 HNIA6RtubOWz9KGA2Yb1Ht1qAptXPtUpZd/DDLVJJGPKzzxUgU2P7rGOakhEnk5zx6U4rxnBq5bh RGQ3y+9MCGHduyB17VYmQb1kPBPFMVwrYHOOlTB1KD0akMrSH5uv3aADtLcU5l3O2OlNJOzaKASJ oWV1PQ5qPCtgK3TvUYYJIMdO9DAookPQ+go6gyqsbQyTndjMhNWofni6e1LjIYDJ9aIE2x8fwnmh C2HBV8wqcD2qVPvfL6c01cGPf7/nSIx80A9+1MBm/azRF8Z/SoQwY4UZ9ammiSO6znjPrRcQeXMr hxiTnA7UAMl/dqvGWpG37A1SE7kJ9ajYb0wvagGMRc7cc9jRIpCEIcZ60+3UmUoPu+tNlHzsuaQ2 JZJukwx5xSyQhJSwPJNFupV856dadP8AMN1MQjOWj6AKPTvVcZUg5zzViNSbVueaiiXfuJPNUIkY 5TI+9Ub43szc4FITskAz9aXaJZW25A9aAY2BgGwfwqdCCWyRUEg8t8VIn060bCQuxlh3t1Y0qE7D zTZ2b7mflFN3MMccGgZNEpRc+tQkf6Sc9xU24HA9O1BC/LKR2oYyMDMvPamSAk8D5c08EebuB6VJ IuIzg0gKr8jnpSLhT8pzTm4U5HGaWNcDtTERqMN14J5qjrcnl24x3rSOK57XZeiE1jXdoHXgYc1Z GETkk5pveg9frQcV559O0RyrxgelQp8sgqywytVmHNbQZ5mIp2dzrtNl3Rqa6SykxjvXHaS+Yhz0 rp7N813U3eJ4dWPLNnS20mcVpxN+lYtm3A9a1oegqmSXE6cmp16VAn49amXOfWkOxIvSnDrTQKcO TQA73opQOfalPrQIO9L9aSigY4dac33aT/8AXSn7lIRCetNGcc4z9KkOMUzvTCwwijHPrS0h9aYD ME0UozjriikI+XV617B8Fx/xO5P+uLfzFePLXsHwXJGuSD/pi38xSEe7ilpB0paRQooo7UUAFFFF AAaKKKACig0lABRRRQAU09KU0h6UAfPHxMyfH+qe3k/+ikrkULK3Su2+I0Ybx3qjY6+V1/65JXKB Ex7e1NbEvcgVt7YOAajf5DxTmUedx2qN8g4NMkb9Kawyc07tk0bT1oAibilHI5oY5bmkztNCBkRx RnjFPYZpMcZ9KAGg4pobnihgQaXbQMTdmk4pXGOg60xjQCE4zS5qM5zSjpn9KSAdikxwP504Hjmm tVANIpDTx0pD0oAjNFO7U2kMb3ptO6GkNIBKOKO1FGgxcHjtmmng4p5YlVBJO3gZPSmnmiwCUlFH 4UAL2opO1BosAUUUcUAFFJS4FFwDtRRR3oAQUtFFIYUUUUAA607jbSClouISlNB/lQaAG/ypaVdu 5c/d70GmwAUHr1oopCAAnAFNp3am0DDvRmgUe9AByKCfwoNFAAp+atiwGWUcc+tY6jLVtWPysDQJ 7G5aLnuBitWBeBmsu19SOvSteHGKZNi5DjGe9XkAznmqNuyliFrRjHHtTCxPGO9V9Rby9NuH9ENW UAwKzPEcwi0abkjdgcVMthpanmkpaS4YnPJqVIcnbjk9KSJCXLbTir9rFvuEAHJOK5JSOlI9E8NW v2bS4YxXQJ06dsZrP05NsEaAfdXFaagZz0rqirKxi9WPAz2py9uKRR2608DngVQgGKkApoFOA4oA XHGaUD0pq7y/P3ak6Uhi4opfpTgM0xMQUvWlA/Cl/CkMbSgc4pcUY5/+tTExpGelOx7dKMelO7UA Np1GKdigBuM+1GM07H/1qKAGgcUYzTsc8UvekAmKMce9OpcUwI8elIRUmOaTFFxWGdsUYp+KTFAM Z70vanY5pCp2nAyaAsMxQR7U7Hy5PFBoGRkcmuP8ZAGa1yeo/wAa7MiuM8ZZWe2IH8P9TQt0D2Zz Mm1AoFODZWkG18lzTwoC8CtzmDtyKYMdx1qUtkYxUbAjkUaBZgFO7mmsMtxUpJZRn0qBmpgOlXeu MYNJGXiPr6VK5AjDVH5ny9smpKJAxfmoScU5MZxmmsPnxQMcGxzjircOHTjvVQYYbelSKSnANIES NjzNlNJIbpmhlPB3U4ZxgDNNggGGbOf/AK9RvwcipAvc9fQUNGKQx0SbmUk1I0RQ8fdqMLwCOtSZ ckbySwpDWxGygrwPmzSBcrU3lk8/xUz7jbSOvSiwEkbK0O09arncj5AyKsoo24zTJFcHGPlFO+gE kWGUflVjhNrdwORVeHK9ulTNIzL05+lSUiQMHVWHeplA28fSqgOxlParMcpaQ7Pu4xSGG3duQnpT gxiUDnmmgP5gbOOxomLmTGeCuBQA59u3eRwaroPmxg5qwilocHsKjkHyKQQKTGhV4HTNA+duy+tL HnK1N5akNn72MigCKQ5jxzxTIlcNlej045wvp3qxBAw2kH5RSQxvlKhbvgcVXuEyNxPfkVpGPMe9 uCRgVm3Ku8kmB8sQBbP5fzNDCxV8hftCyjO0ZxzV0FQpXFRCL9yuO/amurrzmkxoc7jyjs6nt6VX M7Ou1sD6U7BPzZ5xTYtrAkp81IehaVNqbiTTVbBO3nFOeXMSoFzimWqbWbJ4NP1B7ixsQ5LDk0yR g57jjgVJnDgEZB4FEQHntuwB2zSAYgyBkcnrVhhui2nt3qKXAdgnSn52KoY/KRTFYZEjRbWP3TSS ja7D+8cnFOZ/mEecL9ah6zNgnpigCeM/umUY5HBpQeVGBuPeo0HloMj5f51JO6xqjRjO4flTERtt lkAOeO9OYAysF7Dimu42qCMNQ2/f3wetDGG/Y+3rkcVHGxVsevWpyMKuec9aVYEIZweTQIjf5MMD j6VG33lyOT3pZew6+tODkqEKAnPB9KAHQR5ikB7cVFIh8leu2pLdypkRjj3qSRdlrkng8UAVwwWI IF4YYqEgq3pVhvkiUH7wqOSRn24AJ6dKdwEm+UgnvSgDbvSnXGWiXI5AoiI2qvc80xFdtzuxPJNW Ix+725+YU1lKbiq96PMI+ZRzSGhhBDYapWjIKimM2WG4jcacScrySaQ7IXawLP6VNgSWuxhzTXz0 /vVEWKzEHmmIjAARvapMkwj1pk4xx2NScCDj71AEA+YYPelAOB7U6NAevanH5ckcZoCwx02r8vU1 yWttm6xXXZO3muJ1V994/PeufEP3T08sj+9uUe9J3o796SuI+hsLniopBU3FMb7tVF2ObEU7o0dH fsSa6e0bnrXJaY2JiPWumtH6V20XofOYqFpHT2bfd/nW3ByK52xk5Fb9s+RWzOdGinA/+tUy9OlQ xdOasLSKHinqKatPWgA57UuKWjvR6CExTsUo60uPrTuIQU/+H3puKKQ0RkU01IajNAhtNI5pwzmg imMjH0opc4opEny4vWvXvgx/yHm/64t/MV5AvWvXvgwf+J+3/XFv6UCe57yKWkFLSKFo9KO1FABR RRQAUUUUAFFFFACUUUUAIaQ9KU0h6UAeCfEbafHWpL0YLF/6KWuRUYyK6j4kZXx9qR3DkQ8Z5H7p K5VSc5oJZEF/fGnzhelO4EmfWo5ec07isRugVRio2PfOaeGJ4NMOc0xFc8yYocEGpdhbkDpTH5PN HQY0c/Lnj60u2mDg9M1N1XpSBlZgd2KVTx7U18hv0py8UAEnIqHFSHBHSkwPSmAwAUUNwaZ3pMY/ HfpRRQOnSmJi0w8fjT/rSEZoAjxTalPAqJqBjT1pDS5pDSAXI24wOvWm0UUhhR9aCaBTASiiloBC UUq4yMgkd8HFFIBtFOzxjFIfrTASigUvekAlJS0UXASl60lKKV0AUUtHamADrS96SlHWgAopxpDR cBCCOooNH5flRRcA/Ckpe9BouhCUhpaKBiUUYooAKKDQAWIAGSegAoGOjxvFbVktYsf+sFbljkkU kSzetV6A5rSjXcmKz4MqFwa1IztA/KqJLdpDtXI9a0I6qW2dozV5OnNMCZRnHH41zHjGYrbQW6t/ rG3H6CuoH61wXia5kuNcaJ9u2H5E21lUdomkFeRlwxDHpWtoNv5uqReiNk1XgtWKcY+lbPhSFjqM ny/dXnjpXJTfNOx0SVonc2ykL1FXFHQ4qOBfl6dKsCu45wA/CnYxxQo//VTlFAAOvepB600DIqQU AHfigjjpnFO/ziigAFO70g/pS4oAUigDNLTsfLxQA3tS47UlOA/CmITFKRzS+1LjmkMaKX69KB19 qdTFYb3pe9FO60gG/SinUUwEH6UuKB/kUvagLCCjilxRigBMUhpe9GKAG0Yp2KbigBMUmOc078aM UARkY6Vx3jIjzrf/AHMfqa7M1x/i8L59uGGfk9enJpLdA/hZyZHNSJyOTSOm1silTpu7V0HNsSlV H1pD93ntTWfLUm7tRsV5DTnHpSOgK0dT1pWOF60CGjLrhulRNxJ04NSLwvPemsgK9ahlIkjAZvYU 2RfTr2psPy8VZYfIGoQEKKo+8akXB5qDnGT37VJGKoSLDgcYFOGdtA+ZRTRkNjtSKQ04Vsdc1Kvz dqZjtUsK4X5u1Axjjy/mpvmbuadcHG0jkdxTnjTZ8h9zRcLaEoYOvzcEUxwBIG7UiAEDmllyDipG th0I3SHHIJ4qaWRVZciktVA9jSSjJH92gZIkkb9BRGAxYGoEVM5Bq5CAr5Hf0pDIUYbthqcrhMJx mho4d7Nkg9qWOQllQj5fWkHoIAy8N+HFOkCF48nFSXDKEU4qFgkhB5P0oQWJoAAX9DTljR2Zei+w qPafLUhfwqUriRMd6GMi2lJMY+WlcxryCRT5QduT1+lUyN2dzFTSHsWkjHrUkR8u4X+4OtRKxSLd 1qRNrj7uQetD3BbFuaRC6tgqPTtWfeBWmJVRuI4q9IcxMOMDpWfGXl+8MMB6UXYxkIbp+dJcYB2g /N6VMo2ZPfFQs4d89xSe4EY5JX0p0KKnHXipFU7i5xzTtu09OP50AVi33nHc8VKj/Lt9RQyBh8tQ jKcYoAmjJ8xc8ilcFuenH5VECYzuAz9aaZWZWyOtA9bDkYAsOGOak+0gpJ5aZZRgfWoRHtVXHfpR FbhCXGdzH5qQiSFXfaZdu8elSGFvLkPG4ck0kQw4Gee1DpKkjxKBtK8+tA0RB90KruOAMgihMsGZ yeB0pqQkLk/dzU0C5ZiB93g0xEcGXRiwBx0p0uVYEcrmnhRsYEYyaAqfPu+6BQAyR1wG6U+CQAlS PvUwhXCr2zU0oSNYxGPmHG71oArS5SXHX0p4ZdxXnJ6GkLhmy46HFRuf3hPrQBZiVGLZ6mlnzJGs PYVWRpAxcKT6AVYGYn+b9e1Ahs65UH+76VEFz9KUyDfgPlaTGWY9PamD2JY9rkqew4pkcf7zqOlK icFt3T0pwHzbxkZFAMjZsOQfutTSu07uq0bQTnPSjdmLpjvTYIjYLLNkcYpqnnaetO2dTnvRsLEH bhaVhk0TfPj07USYNxnH1qFCQ7GpCUL7vWgQTLwP50p/1eMdKVtpiz0oU/L05HamBANwk9KV+uf0 p0jAvkCmsxI6UkMbID5W/wBq4e/bfdOfeu0nfFtJ7CuEnOZGJrlxJ7GVR1bI+9APORSd6P51yHvW F9qB70AE9KQdKETKN0T2WRcjt2rpLdsbc1gafH5l0lb6rsbB9K7KDPncdTtKxuWUnQZroLR+lcta t81dFZN0rqPMW5vQn9KtD7vSqMDcir8fSkUiQU8U1akFCEKBQPftSj6d6UjigBKU0Cl7UANo7U7v TT6UDGHOaZ/SpDTDTEJ0ppPNO603A7+tADaKXGOlFAj5ZXrXrnwZ/wCRhb/rk/8ASvI061678GRn X2/65N/SkI96HSlpBS0hi0UfSigAooo70AFFFFABQaKKAEooooAQ0HpQaQ9KAPAviYoPjm+4wSkX P/bNa5WJT0zXV/EZt3jzUF54WH/0WtchI5jYketAmEud1Ru25fm+lSv8yBv5VE+AOeKpEkDblbtS MSeabI3zUM3tQKzLMeFXjg+tVZdu75fWpYzwKhlHz9O9AyJvu9qVG+Whh8vFRjj8KmwwcZNNwQKk U5GewofGKYEa07Ham4pfmXHXmi4rakT8UypZBTEC7vmLAY7DNAxQKVvvfKML6ZpSAAOetN9hQKwq gk9vxNIRxQeAKM00AhHy1GVzUvGO9NNDAhxzQRT/AMaSkMZ2oNOpKQDe3Sk5p4GQenHXmm0DEoFL RQISijtRQMSg06kNFxCCijFOJBRVA6UXGNNJ+NLR0ouguN60opKWkAoo70D8aO9CBjhxSim0uPen cB1J9P1pccUUAN9KQ9aU0UwEpSO9FB/lSAO1Bo7UntQAmaKKDjPAxxSACeKKKSgB8X+sFbll0rDi /wBYK3rAZI4oEzetBlh7VrRgbv8AGsq2PPA61r244FMk0IFO0VcQcdKrQjirkY9R9KYxlzcR2trJ cSHCxru+vtXmjyPPcPcPyzsWNdX40neOxt4Ub/WyEtx2ArjYSXcj0rGpqbU9DYjkUQ+Yv412PhS0 22H2grhpm/SuAEhyIc4ZuMV6tpcSQ2FvGn8KAVnSppSuVUm3E0o1qVVpiDAqXFdJkL0605aAAaco oAFGKkFNFPFABj2pQKdjigDBoAT8KUDNHT3p3agAxQKdiigBv0pcUop1ACClNGMmlHpQA3FKRThQ c5piG4pfz4peMUYpDCijHFOoAbijFOxS9utMQw0EU6m+9IAxR7UCjFMBKMUtLikMZimnrUhpuKAG H3rjPGm7zrbacZX+rV2jDniuM8a7vPtwvXZx+bUdRPY5Z2YrSL93imKrhfmIp8f90962MB3X5jxT CMtwaew+baWoK8cAcCmHoMVTtxTsELz2oj61IxyvakHQjKo0eahZTuHWrC5xzSt1C4oYIZEU6H71 SOCBjNRiPElTDNFhlc8N6YqTPz4HYU2XjLGhC2SeMUg1LSY2/wC1SHO7gVGrHrVlPmXJ60DGA4OD xU5x5ec81XYdCc+1KD8lIpCyRmYfJ+PvSlCgC5zUtqP3gOflpJyDJ8tADAm1lJOKmPO2oHYdvSnq wMGAaWwLYmjRScljSBS7bV5FRRMB3q3FtRjjnNIroVJhh9ijHFPTcuEOc96lnXJyKPMR1UKPmx1p iHCQdT+dPjfcu0DAqLb03GpolO7aBk0MaInlw3luKnhG35utE8PK8dPanRSqq/NyaS2H5EjN/d6H tTmidlUjtSFA20527qS3ldZniYjYDwaQwkYeaueO26oD1YnnPSppl3Rn/ZNQy5+Vj+lAFgJ8oTjd jJp6bYxgGokYcsG7cUsp3LgenWkMftZ1Z92cdKhxmHOSG6ZFReY8QVO3Qmp4gDDz940XYDIcN1+l RvCN3HAqSE7HxgYNTFVK7utFxEcQPT+GnTSIY+Ox9OtS/LsyKrSZdfp6UDK4YiX2xQ45BHSgHysg DOfWnsPNh5BHNIZDIxZdtKigCnKgHckA1Js8xfkPFADB84XBxg5FLk7uDyaVlITp0FMhfnGPmxQF x0eFl6jd2qV3bzRgZyMVFn96xOKkO3YDQA1Wwdjnipk8tCc42tUMgB6fd7mpHt/3SMDj60wG7k80 DHQdKbLlOV79aVotsqlQTupXTdJ9/HoKQrCBCF549aWUytbqsYywOQfSp1Xd+FMjTyFcs+d1MLMp qCFG8e1Iw+UHr9Kl271Zj29KFx5WByaEA1DthU9ealmG/wDeDoRgVVePeFXlV68VdjCiD5ucCmBX eFd6L0GPzpZlSMr79qaJNzq49akuYgZFc8rSAjiQtG2D+FS5P7sN2FMjxvXBxU7DzDgdhQBXI6/L xnihiOBt5qSRCmFBqMqSRntQhEcq5PpTiP3akN0pzfMpqNSFYg0wItvLYHJp5T930qQ8NnFC/MvN A7AANmKaAM571MFCnb0qMYFAdCIj5/pSyDC5p7jnJqJ2OMdRR0Ap3+5bGRs4riJPvmu11ptunsR0 PH0riW65rjxG572VR91sbQOtL3pPpXMeygNC0HFKPu0BY1/D8Pm6igxXQX8HlzZxWf4Ng83VP90V 1Gt22MNiuygvcPncxf75Ix7Y/Nxxit6wfjmudi+V8VtWbciupbHlNWZ01s3HtWlGeKx7RwdvNasN JjRbSpV7VEtSL2pDHU7mkH+RS0xAelAAz7iij6UAH6U0joadSf54oEMI49KbTz06UhoQyPvzTT1p /GfSkPX1piGUUYPrRUiPlpeteufBj/kPt/1yb+leRL1r1z4M/wDIwH/ri39KZL3PexS0g6UtIoWi k4paACiiigAoNFFABRRRQAUlFFABTT0p1NPSgDwL4lx48cX7g8lIv/Ra1x+N3Xmux+JO7/hOdQ9C kX/ota5ILtYYNAmITlVFVp89KuLtx9aglG5sAd6BFPBzzT5AQgJFWE29PSo5844qnsSR22C21qdM q5IFRJlctzTmJJy1Ioi7YxUb4AqyV+TdmoGB3UgQ1aGGak2gU00wI8jtTaD1xTv4c/lSAjJFN7UP QnTmmhMDSrS04D3oANtN2U4U6mJkLDFRnrVg/SoSKHuNDTUeKlYUw0hjaDTsZFNNIBoo704U00xg aOKO9KRSEJRS0hoQwFBoooAbRQaWgBDR7UUGkAh4pKKKBjhSjrT3gkjjhkYALKpZMODkBivQdOQe tR0WEO/SgUlKKAHCj6UCgimCQn60hpaD/nFACfWg0UUAFJS0GgBtFFGaACkpaSgZLD/rBW/YjFYE A/erXQ2eMikJm3a8qtbNuvyj1FZFp/D+lbVuPlpokvw1cXoDVaHkU+7uFtLCe5Y4ESFuKAOG8T3Z udZkVX3RwqET696z7NN0RG35s56Uw5l5YksxzmtKxtwv3l61hU+Bs2g/esM06z+1a1BEwIXeM5r1 eGPYoAHTiuQ8NaZv1ZrjaNqjrXchMLVUfhCpuPjHHtUu0UxOlSAf/XrUgAuKcBilAGO9KMUAGKkF IKXFADgM+1J0PrS0H9aACnUAf/Wo5NAAOadijHFLQAlLjilH6UUAJS/WiloAaOtLzTv8iigA9OKM etKKXr/KgBtOI4oAo60AHakxS4peaBDfbFJTqQ9aBiUe/NO29KDQIZRSkUGgYmKaRTu1IelADTXG +MVJuLfB2/J/Vq7M1xPjVitxb89U/wDiqFuJ7M5l175qJtobvUoJCkEdaidT171sYDo1+bcTkjpQ hLMevNNDfu8kc0sQKnmnoJDx1zTgeOnH0o4Palj4GCKRQmBuxj9KCCOcUp+8CKfjevHrTQiHkv8A SrIA244qIHA5HSnKfn9vekNIjmUnIxjFRojY4P6VcIz1FRr8u5QBSGRj0NW0UFeD1qAqufSrMGBQ NXG7SEYNUQ+9x0xU77g2fWoip25BoCw5G+XhqjP385PNMH3ulE06IpLMBik2NErjCU0MMbc4rJl1 rjAH51my6p5nWXbj0qQudL56RtgsBz61PJqNuAoLqG9jXFyXcb/ekY/jTfNtzk7qNA5js21SB/8A lsuc/wB6nR3lqrZLLj61xRa2bGGIb604BXGBKQfrTFzHcfbrbK/MGz2zTkv4o3UiQfXNcHi4H3Jj +NOa5u41G5Q4pi5j0tJo7mEssi/99Uionyrkc9687h1Enarb4/oa0otUm2rsmP40rFcx2BVlkPzg gHvUkihdhzw1cpLrcwViy5YrjIqxpniA3MSw3YwY+jUiuZHSRqWLhhUDgjA5P1qSOdXkXY+c9cel NuDh2GOvekUOhCmPoRirCRhl96giGyMdDU6sML8+M9qQyrLEoyGB5NRHOGEfULxUl2T5i9etJFgl qQDYQZRk8EDpU0ZdkYMv3qh3+S3rmlEpVvUdeaYCmTavl7Tt6URgM30pZWLJu2U2De456dqAFYYO eop6KjouO9QNuUMMfearEQVW2dcVI0hskO0YHrmhgqRbkPfmi4nCnbnDVBu4A7MeaBisxyOfpQuF fPtTvl2etJJ/qw3UHrQAyVNoyDnce1PDB8EjC9KnVAIsDnjNQhfnP50ANYfusckZq5IN8agdDUOD /CPrViLDxMoOMdBTENVXI5UjA61CyHbuzVne7Wg5we9RITnDcEDNPYBtmduc0yQfvNxzipQSVVlA G001gXdm/h70hkEZBR6IlVTz3HSnr8ke0fdpikNJxywouKwz7jcjg1YDLgk/d7Cgpg4PPtQE3HYR 0oGV2gwPMDbATmpDNu4x1qOUPuC/pSiPJzmmiRIpFDbWzzU0nyZKH71RNC3nrnHSnk8bT2paD6Az bvmIwaEwQ27hqaGO36Gh+ArCmrAxjY25FV5FbzMjkGn5Pp8pNIx2yZoYImx+7zznvUsYARTn34qJ SSCD0qdVAhwaAIZv4uetRr8o6Usg38A0uwgcnmhCHSuMrj0qvg5I7VO20ketIFO0tQMwfELgWir6 muSNdN4lY4Va5jtXDX+I+jyyNqQUlKBQKxPUQo6UooFOWgZ23gCDddSv6DFddq1t5kLcfpWP8Pbf /RJJT3OBXWXsIaNhXoUdIHyuYyvXZ57JD5ctXLViGX0p19DiVhiq9ucPjmtdjgep01o3TFbMDVz9 lJ0rctm4zRcaNJDxUq1Xj9asJ1pDHDmnUlKOetMQuKTv0p1BouA3vSNnPpTxTSPwpANPWmt1p3Q5 prDmmAz+lIadjimmgQ2ikOc0UhHyyvWvXPgyf+Kgb/rk39K8kWvWfg1n/hI1/wCub/yqiT30UtIO lB61JQ6iiigAooooAKKKKACiig0AJRRRQAhpG6UppD0oA8C+JXHji/452xH6/u1rmMBowSOcV0/x KG7x1fYHRIf/AEWK5gNiPBoEVd2GI7UoHPSkkH7vcOue1Ph+dcnihCI2Xr0qu+7dV5xx71Sbdv59 eKYhyD5TkYqJvukCrDcx8d6q4Afv9KQ/MBuAxTT1qSXHaliBbg96A8yE0w8CrDKAzDmo5F7Y/SgL kL001Ln0qI/ep6gRuOKaDUjdKjFAEi9KdQv3fWlHFO4hFpxpg+9Tz0oBjTUbU5jTW+7QFtRvammg CjtQNIbSHk08/wD6qaRUgNA4POMUlONNI4oGIaO1LSYoAO1FFBoAXaOec0n50UUWAbS0+JI2mVZZ PLjz8z7d2B9O9MoASlBXDbgScfLg9KT/AD0ooGhvelpe1A4pBcMUCgUtAgFL6UelKKBiihuKKU0x DaSnd6DSBiCg43cUn9aDQAUhpaKAG0Ec9c0Ud6AQUUdqKBk1t/rq6KxHSufhYvIM44GOFA/lXRWA +7zjik9xM3LT8q2bYfhWVajpWvbr0qhGhEvvxWJ4snZLGC1RuJnO8eoFb0ft2rj/ABHc/aNZaIHK 26Bfx6mplsOJkxpvZWC/JuK5xxkdR+orpdM0tr0iJTtVeWbFZkE15emBLi4lmjtk8uFG+7GvoBXc aDbmOw392bOKHFWsEXrcvaXZpaptTqTyT3rUxgVBCpGPWrYX8qaVhiKPyNPApQOKd060wEHTNOUZ oFOGKAACnDp9KQD1p4FAAKGGcU7H8qbJIse3J+8cCgBwFLSKeOtPoAQUU6j/ACKAE6UoooAoAAPW l/lSU+gBn0pwHtS4H40o69aBCdqKXAxRQMSlNHNOoAbRinfhRjtQAw0pHFKaTuKADBppp1HHagQ3 /wDVQRS0mO9AxpHFBp1NxigBpHFcT40Rnurbb/CnPGf71dsfSuS8VL/pcWeojH82o6hbQ5AKQo4o GC20jmpJGyzY4pqjIBx8wrZHO0RSLtAIH4UkY3/eGDUxI60hwT8tHUBNu2nDbt5603B3c807tQA0 /eGP5VLGcfTvTGyF470iNl9ueTR1GtiWQrjIqNM5x1xUjDKYqHGOhpDWxYV8tUZVt2fenJnZzT1+ ZcZ70ihQu76U8Aqv16VXJIchuFFSmQCLlunQ0AiSXlQT6VTubuK3T5mxgVn3+tJbSMm4Fscc9K5a 71GWaZm3sfqaVwN291vc2IehHUisee/kc5eY/hWbI8jdX/WoTt7saVxWNHz4d2WY0gubcZwq88dK o5SjcnFK4cpe+0QMcECnBrfoTWeTGT6Uu1Mn5unvTuLlL7JAfu5/OlWBduVdgazhGw6P+tKrzJ3O KLhbzNGMXEWSrbh709bqUth0P4CqUVy6/fyRViO6Qng/N709BO5aWSOTuM0SoZNrK2CPSqzxo/fH 0qLE0TZByDTEXVe7ibbzKG6AcmpYLqGY85Rj+tVoLtWZUYlW7VJcQKy/KBkdxQmDNGK7urIkxSMV PPWte08ULM4S7G05xurkkeaIcsWUHoatB4Lhcj5WFFh8zR6PbzQzQbkcN6YNIwDRbuuOhrz6K7ub Jt0UjqvqDXS6V4iguFW3uW8t8cN2aocbGsZ3Ogj/AHsC+YOgxRGPmPGBmki2+WzI2c96g3Pvwx+U H86ksdMo83d+hqNVJfhty9KmnzubHcVDChWUAng0wZYm/dOokPGKhWbaygZ29BVq8UnDD7u3oRVN 9yqp2/dNAakku77y04BlWNm+8KapaQDnHOasIjkdzxxntSGRTRsw3gd6R4vl6Z9qmcMqbDzjrzTS 5C/SkBGIsLtzSDaqFG6k0+Jv3rAjrUdyH81dq8g5oGWGBRWG04pFT5d2CKlfPl555pw2GHhssKAZ XD7WZP71Nh3bmJwMelJGhMxD8elJIxik4HHrTQmWm+W23Du3NJIqs24HquBTIzvj2n605V3N6UAD bo4lTjn9aYXBU4I9xSzB9qjoq/rUK7U2gfebrRcBdnyU6NAZAQuKSVjG3AxTI2cHrx7Uhj2+aZhu xjpT0kHI7+tQOyO3yHp1ohyYyc55oDoMkyZM0+NfmGcc0qBc9aaYtkisPSmIe+YnLHnNRnlWcflU kvIGe4zUbMmzag+b1oAFGU65PpQAMYJpq43KakY4waBkKr8+KJUw3GTTtjbix6VIy4w3bFAiOFgR 071JK2FwBkdqjXKuTipkZXXDdqEMhQZGakGSBkfhTxxHTN3fnNNXEyArluOKVSVRlNOOcFqbIcrk 8UMaOT8SPuuFX0WufIrY19t1+w9OKx88V59R+8fUYBWpIMjoKP4u9AOD60dT7VmdyJM/LjAI69Kc n8NMqWJcleO9Iex6/wCB7fZocbbR8/Oa6CePKnPpzVLwzb+Rodsg/uVqyLkGvSgrRR8fiZc1WTOK 1e3KvmsVQVk9AK7DVrfcrHHSuUlUq9aHMaNo20iugtG4A9q5m0b5lFb9melAI2Yj0qyvWqkP3etW kpMolFOpg9ak+lAB3oNH8qBQIbSn6Uv4U0/5zQMaevtTTUh61H39KBMaelNz2qQ9fWmnFMCM4zRS nrRQSfLC9a9b+DX/ACMJ/wCuTf0ryNetetfBs/8AFRHj/lmw/lQSe+ilpBS0ihaKO1FABRRRQAUG iigA/CiiigBKKKKAENIelKaQ9KAPBviIyr461Af7EX/ota5E7See/pXV/Ej5fHl+fVIf/Ra1yz4A pAR+XlMDpQhCDbRHKDuSmvnPBpkhJmmja/TrUyncuGqDHlufSi4WGSAhhweO1QsMye9Wt4btUMig cin0AhYYb2pynHTg07+HOKPlJ71KHuMyS2T+NRSE7uuasBSrcjNV2HzUxEZ+tRnINTOPSoT1oQCY 3UzGG/GpKaeaAFQ9qeBTVFA60xBjFOB4pW5FRjigAI5pD0p1Nb2oGM/CkIpwoxQw2IzTfankU0jm gY002nYpD1oEFFJS/hQAnakp3am0hhRRRR0ASikpaAEoNFGaAEpRTe9OFAxRRSjpSd6QhacKWNSx 4RmC8tt9KQCmAopSflxxj6UClxnpSAZ3ooPWlpgITnAwBgdu9NNOppoEFJS0lAxKKKO9IAooooQI sWv366SwQ7RXOWefNxnGeDXT6ePlXjFAG5aLwua2rce1ZdoOg4/CtiEcdKaEWWdIIWmf7qKWNefK zTPJcPndK5Ymus8TXJh0ZoQfmuGEY+neuZiQHauMUt2G0TU0e3LSKcZycV6Faw+XEiDoBiuX0GyB kjGOnOa7KNMdqYR2FRanAzSKMU8CgoKdigU4D9aADFOXg4oFKKAClHSlFL2oAOlMmXKAntUo4NNm UtGcDmgAiHyjipAKjhOUFS0AHejFKKcKAG/hQBTqKYCYBFLijFOpAN+lLilo/CgBMUoHNLS/pQAl FKRiigApD0pe1B6UxCdvakpxoIpDGYx1pSKdj+VNoAbjvR2p3vSUAIRxTadSUwGGuT8UDdexjBP7 ocD6tXXEfnXF+MSUuoGXg7B9erUuoX0OWnZdx25AqJHbtTpF3KajXhsVvY5rkx6DIpgPPYU8kNxT MDOKGBIuD3pO4pucnA7054/l3AVPmUNI4zmmkHO44GKcDk9eKGx0ph6Art0Yd6CQfl70/A27/Sok 2n5sEGpbKSJPO8tQrEAU5Zen86hlAb7w/OpNqrGG6LUDSBmAJJrD1TXPKUxQc+p9Kp6vrOSYYXOB 1IPWudkmZ+pNNsETT3BeTe7FmNV3ky3yio803Oakq1hxPPWjio80UDJKTvTaKQWH4780YOKbmjca YDwzA09ZSGqMP2pQw6mkKxOso3YOKDECNymq55NKCw6GquK3YsBpYxyeKsxXaPwwwaprL2NOKo/3 eDTXkS13L8kSSjcPvUiCWIfKSyiqIMsPfIq9BcrIcHC+1MizSJoplkODw1Pa3UqxQ4aopYlbJUYb 1qGOeW3bEnK0xFyOcx/JICfepGiDL5sJ+q1GGSdM8VCPNtjuQ5jz0pgbmk69NaL5MmXjPUHqtdda XMN2FljkDIa8/jMV0oKYEgqSC+utNnDRNtPp/C1S4GkanRno8qljlR8vamxKnyvjMi5zis/TdYg1 KBBuCzL99K0Yh5eWH/6qg1Xc0HjScL8oHH5VmzbURgf/ANdXV3BSGHU1n3CkNzn6UmUhFZTH8vDG rdrnZuaqcQHy8cVYgdELJu+Zh0oTAY7jznAOfm4p5ztwOMimRhdzFuvbNT705BI4HTvQBSXesnzK T71ZEscj4A+bHNRPIqsf0quk5+05IFSykauNvbC1XCHccZ2nvT5ZkMPynPNMV1VclweOmaYiJNxm Xadyqe9WZUGC3HrVD7SiOuWA9OauOf3BZe/TmmgC2/eRswPzdORViFAijcKrRb9uG+Vmq024IcYL Y55pAVrh2e4KjlMce1RyARABT371IseWBJ6ClaIMCW/CmIhkB2ZP50+MbUBx1prEmLB456UEN5a4 556UARrCY9+7qxpqyYATb9cVYlI6t3qqeI89TSGKwAeny53L7VGzH5GHNSTNwODmi4WIpJCW47dK YOOTmnyR4UtmkiCleeopiHDJ6VIgymKjjBElSlDzg4oAQr8hA4xxTWAEAVm+arATCZJqLYCxZu3a gBFI281EW+b2qZtu3Iqu33c46UAWAclRT5I+egFRpygbHapmyV68ii4DGVY1O41BIpK8D5RUh/1b E0x2PkemBSZSRwWsPu1CX61m9qtX7mS7lcnq1VecV589z6zCq1NB3o70DrS1J1IXAx2+lXLBN9zE nqwFVVXcwHH51qaNEX1S3TGfnFEdyajtBnuWmRiKwhQdkFWGFFsAsCfSnlf/ANVemfGSd5My76Ld G1cbeQlJmG2u9njBWuV1aDZIxxTRmzHtiVf0retH+71rAX5XrYs24X3psDoYGyKupkY5rNtm6VoR mkUWBSimrThQCHHnjFFHGKD0oAPekxS0nbrQIQ1GetSH8qaePpTBjT0phHNPptAhh4NFB60UgPlh fvV6x8Gs/wDCRdOPKf8ApXk69a9Z+DZ/4qPH/TN/6UyHue+jpS0gpaRQtFHaigAo70UUAFFFHagA oopKACiiigBDSHpTqaelAHgnxI48cX3+5F/6LFcq2Gjx6V1HxJz/AMJ3qGehSL/0Wtcnn5cdaAGx oCzHpQwp0Z+Y8nH0oOSc8UEiL2zVafIfrlamY471BIOc0DFgOWpZ+vrikgHzcVNLH8uaZJX424po PFA+U4xkU4KAtSUKWyuM4qAcdamdQPmFRsBjPemJkLN2qPvnFSEdqbs/KgBpXio24NSZwaa1ACL9 3rTh07UztT15A/woAXNNYUuaRqLgAofafugjgdTmmijvQA3ndSkcUuOac3SmBDTac1IaBjSKYetS GmGgQlFFLmkMQ+34U2nUGjYBooNFBoAQdKKUfTinHHrimA1I3k3BEdyFLEKucADJP0AptOBxnBPP HFAxnJ7e1ILDKUcCkpc8YpMLCinBeM5HpQpA6jNKpG7mgBMUoopf8aAFpw4ptOWi6AaetNqTjPzZ /Cm0ANppp5pp4ouISg0UUXGNopx5OehFNouAUUox3oNAFuzxuHH6V1FiOBgcVzNj97GPvevaursR wtIDdsxwK2IAT1FZdqoA+la0BAXcTgAZNUhHMeJZ/P1eK3A+WBMt/vGq9lHvnXj8KqLOby7urxv+ WspI+lbejRb5MnoKUO4p9jrdHt2ji3j1xzW+uaqWCBLdRirw60yxyinAUAcU4c0AA/SnCj9KcPpQ A0DtTgMmlxzS0AFOxzQKXGaAAdaUD/OKB19Kd0oAijGCQPWpaRVwc0+gBuOKd/kUAc5pwoAaOlL3 pRQKYgxQOtLS4oAbS4pe/wBKMUDDFH9KdRSATtR9KX2ox7UANNL2FLR3oAaaXFLRQA2g07jNHSmI ZjtSdqfSUDGUmDT6SkBG1cV4yz9st8cjZ/Vq7ciuL8YD/S4gM/6scfi1HVCezOVKN1qu2fMHFWjn pntUDDB65xW9znsPH3ahb73P4VKvTmkdOjUhhHGxckU55dkR3dKdE2xT79Kr3bhYwGoGCyrJkr2q QN8u7AqqmxCNvfrU64BPPFTcdhQS4649s0BttQ5G7OKczcdOtRcpImBWbjGawvEOqfZ4VtYWIYjk 5q7e3X2C3Z8ndjgVw91O9xO0jsSxPegaGPIX5Y89aauSeBnjPFI2MDGfem0tCrC0goH+RRQMbRxi iigAooopAGO/WlpKP1p2AKdTRTutAgFKGpO9JQMfwaOV6Zpo96cDxRcViZJcnDVMkaseG21T4NOV 2T6U76akNdi9FdPAdkmWHQVYRkn9x6VRR1l4aox5kLZUnbVXIsmX2jeBjJF93uKngnEo9/Sq9td7 hjI3U54f44eGqvMnyZO0DqfMi4PpUqSrdKUcYYVXtbhidkvDCpJYQ2XQ4YdKaYiSOWeynV1Yqw5V vWu60TxDFfRyQldtxjlex9xXBwXEcy+RP196QPNZTq0LlWX7ripcS4yaZ6wFfftJ9utVr2JomUsc sevNZ/h3W01QeVL8lyo5X+97itq7Ec27j7vABrPyN0zNgP7wLU2xd2QMdqhRth3kfMOKdNcJu3Z2 8c1JY7dtLc55rOu7kW07Sq37xlxjNNutSRFby2DN2xXNXF27Sku1BN0ajalKzfM2aPtLHnJrm31I qeOaadXI24HPpU2EpHWpNJt+/wAfWoLm/aPlmPHYVkWurq+1WpNVZ1jMoJKEVSQpSIJ9TmmlzvYY PrViPxhdwKkfEm31rnXmcr8gJPtSWsLTSd6om7PUtJ1OPU7T7SjfN/Ep/hraXBQsDjI5NeY2U1xo l0syt+7bh19RXoFvdJd20ckDho5FyDSZpF3RYK5kV93I6CnScj5e59KjUMcKDzT/ADFQKn4UiysP kVg/WlifcwqWRAyj+Ej9aaybI1OOhoAbNGzLz27VVA5xnitDtu/nVGQK3TjFAmPQDb/9apSMR5Iz USs21cjgUuDLxuwKBAQMLycsPSmxjy5eelN+bcCO1OPDc0xExQE7l69aAfm5oBG3HtUALA5PT0pb ldC0f4uahLZ7UqfzoWLB3elMBhbMeP4vSqzklasshJ6CouA/TOaBIkgLG3YHoKn5K9arxMQSvarC J8maA8iJyQM4+Wq9y/8Ao7H0BxVojs33az9TPk2Mv+7xUy0RrBXkkcBM26Rye5qIdKkf71RgcZrz 2fXUVaAd8UvftS470d6n0NhRXR+EYTJr9qpHQ5rnR9K6/wAAxb9ejJH3VParp/EjnxMuWlJnsUfC gU7HtQM4FKa9E+QIpBkVz2rwbkJrpGGRisy/h3RtTJZw8q7XrQsjkKPSq93HtlYEU6zcg/402SdH an8q0ojkVj2r5GK1oSMUii0tSVGB2qQelAxw60dqOKXHFFwExSU6kI7+tADW/lTSacc03tQhMbxT T1p1NPJoAjYNniin9KKCT5VXrXrPwb/5GMHP/LN/6V5OtesfBv8A5GIf9cm/pTJe578KWkFFIodR RQKACiiigAooo7UAFFFJQAUUUUAIaQ9KU0h6UAeCfEs58dXwH/POIf8Ajgrlo0Bj6c10fxIP/FwN SB7JD/6LWubSQBMUC6jQDuNHO2hXy7Y7UHjmkBAV475prrle+afIwDfJnb70wsBQFhIuH4HQVYds xbajj6+vv605z196YiHYOKHX5TTmzjIprOfLJpDRV3kZxnmn8MufT2qDJz7VY/5Z8UCZD3px6cUK uRn0obGfWn6CISvNRt0qbjdTJBRYCIinCnD0pMYNDGJjmjHNOXk0oFADRwOlIakKd6a3TFMVxuO9 B6UCg9aAI2pO3FOYUykxiNTGFSGm96YEY60UHrTu3/1qEhjaKKO1IBtBpw4pSOeaQDR09qU4B5Bp D9Me1BU/nTAaOvSinbVHU/lTsp8o2kLnmgERdqBt96VsZbFLtXgZ96Bh8vvRRinbSMHHWkIB1oFF KKAY7jAwPrzSiminAUADDjNNGM85x3qTjv8AhTGouA000049aQ0ANoPtRRkgdetFwG0e3anbTtz7 +tNoQB2ozRS0BZl6wzvXr1rrtPXgVymnDLCux09cBevFIDbtl4GR1o1u6+x6HcHdtkkHlp+NTWwB xWJ4om869tLIdE/ePQ9gRnQR7IUQjtXXeH7X5VyB8xrmrePfIq4rvdFtwqr1+UVXSxC1lc3YUKqo qcLTUGBUg60Gg4dKcKAKWgBQPype/Sl60uKAAe9L9KP6UooAUUuOKWlxQAgHFGKWlGKAADijFOFF MQfQUUv0/lS9sUhiUvejrRimIU0gBwc06gfSgBvFOxRTqQDRRinYxRQAlHPal/yaO1AAKKXtRQAh 6+1GBQRS9qAGUGnUn9KBiYxSfX0pcc5ox+lMBtIcZ6U802gCM9a4vxj/AMfsH/XMdvdq7Y/lXF+L f+P+P18pf5tS6oXRnNbVb2xUTKORTvuk80o2txmt0YECn5sCpZPmXjtSuu0845oHQAUWQXK2GPHN PSAS8OM+gqV0H+FIrHoKVmCsJJZrDDkL171VK4j6cir/AJ7hcMN3vVGTJY4qGWMLY4NRuQo3ZFIx w3zdKo6ndC3td2OSMA1IzD1u/NzcMgOVXisfkr0pZHLOW9aZmkWgoopKBig8/Q0Z4xQMZ60lKwCG inGheCpwCPQ96YCDp1xingwfZ2BWTzy42ncNm3BzkYznO3v6036UhHOKQCd6X8vyopaAEX6Ud6KT rQAtKMfl0pKKYC844FOLkxqm47Qc7e1N7UlAri/SnZyP6Uylo2AcMggg4qaOYHh/5VXBpSO4oJau WTGR88f5Vatbjd8rcGqMUpBwfwqUpk7l6+1X6EPsy/NFvXcPvCmRXDA+XLnNRQ3X8L8GrEsSzR7v 4vWq3I23JJod8YdOG60RTCUeW4+b3qC3lO4xucY4GaWVAdsicOD2piJ4ri4tLxJIZGjkXlHFeg6R q8eo6a00sqrPFw6d/rXnsDC7XYw/eCtbyDZW4l3kMwwe2aiaNacma9/rYinkEbk1gXWszTMxaU8+ lUZWeUnGTVu08P3lyu8rtUjOSKzRbZVbUpiuA2BVKS63H5nrQ1PR5tMKiRlIb0rFmgclivNIEDTr uNNMymq+DTolRnxIzquDyibjnHHGR3x9PfpRYZct2ZplCZ5NdkbQPo8gmHVDWL4b0kvOs0wIUV1m uT2/9gyxxOBInp3q4xsTLU82Iw2M1o2IwA1ZrH5qety8a/KaSdmD1N+QmVQxbdkflVjwvrf9n3rW ly/+jtkDPRWrFt7/APc4Y8jpVENmQtTlqKF0z2q1dXbepyrdKlKYlbAzzmuR8H66J1+x3B/eqP3Z 9RXWtI/lkqcVmb9CSXHGB9abcqflVaZuJAcfrT5m5C5HSgZCrZAXk8VXVf3nz4qZXEWS/PpUcLZb e3SmhEz7dvAxjiq24Lzjk1PM/OMVVfJU47UAODrsOT1NRzsMj+6aamG9alaMMrIBQBIud4yOKSX1 HSo4siP5uTTwC+RTELGMsvNPuN3ReKSNfmx2FOf7xxnkUICNVbbUefWrPG5QM4qLy9zt2pDIY8iV eeDWgSNpAqmy9ParUSbo+vJpgyPae9ZOvzbdKfjnpWsc78Vg+J2xp31aoqfCzagr1EcQaB0oIpB0 Feez66n8I4deKMfN1o6HrQODSNEPUe9d78N4d2pSP/dTiuDX0r0z4ZxYiuZPcCtaOszizCVqEj0Y UUAcUZrvPlQPSqs6ZVqt/hUcg60CZxmqxYkztrNh4lro9Xh+UkCua6ScUyTetWHy1sQNwKwbV/u4 rZtmyKGM0kJ2/jUq9KgiPFTL/wDroAfn/wDVS9s0i8VJjK0DI+9FFBoAD0zUZpxpp9OtAhvamkU/ GfamHrQAlFFFBJ8rLjNerfBv/kY1/wCubf0ryhetesfBz/kY16f6p/6UyXue/ilpBS0ihaKO1FAA KKKKACiiigApKWkoAKKKKAENIelKaQ9KAPAPiSv/ABX2oH1SH/0WK5Ddhup612PxIJ/4TrUvYQj/ AMhLXItyv8qQAuFfvzUkh+Xr3quTtNTNymCaBEOzimbcNzU4HHSo2IzimLoOjAx/Kl284o5C01iw bPbNDAVh8uBULjCVLmmOwpDKg69KGb5evWntjmoVA70AWIxlCf4ahYEHvirEe4fKO1NdQvH60C6k GOc0hH6U4j0zTgOKYiArxnNM6tUj0wdeKBhSg80je1ApAyyGGyonApMnFO7U0KwzbzSEU80wmgYx hx9KiqVm4pmM4oAbTfwqQDrTO+KAGGilPWkPSi4WGmig0dqBi0maKKQDseoyQaazH0qQjAznGKYB wTn8KYCMQe/HekyDxg0rBVHrUeOBz1/SgAPBORinKDlffpSNjGRSAnHWhhZjjy3TH0qQDpjmoxUm R6+1SMVeAaXb+tIVIVSVIzyD60oPPSmIXbg49PQ0uPwp68joP8aXp0oAj+vpTD1qUj1qNhQA0000 6mmgAHT6U00v40hoASkp1JQAh+lO7daSlHSgDU0xcstdppy4XgnFclpa9K7KwXIX+lJBY2bUY64+ vauNaZr3V7q7bkFsJ9BXTapdCy0eaX+IjYv1Ncvp8O23Qc5PNG7sGyNzSIt849K9B02HZCPeuS0O 2wM4+8cV3FumxFUVT3JjsTqKkApFqQAUFhj8qcBQBS9qAEFO9qKfgUAJj8KVRzRilGOlAABTgKO9 L04oABS4oFL3oATpThRigdKADFLRjNLjigAoo7elFABSmgdKKBBjmlo6UUAHb0opaUcUDG04+1Ap e9ACdaKKDQAUlOpKBCf0pCKd260UDG0nanGkoAb2pp69aeRxSYoAYa4zxeR9vh448oD9Wrs2+nFc T4xDG+i7fu1/m1HVC6M5iRPm5qDkPxkVKHJbntTW5JxW5zsY2/Azz71JFuxle1M3Hb9O1LDLt47H tQwRKcsv+0KYGIbHvSMWLAqajDPvPHFIZYLArt9KhMYPINSsymPjFQiQq2T0pMaI2hQDDcc9a5Hx HN/pAgU/KvOK6+4dDEzBq85vJTNdyOx5LVEi0V+9B9KKTipLFox8vailHI7Dt1oGNpVHsOnc0Fum e1G7A4FAAB0pB14xShiOhoVyAV7HrSAFYANlQ3HBz0pKPek7UbAKTSdqD7inDp0/GgQnekoGc4H5 UUAFHeiimAYo70UdqQDqbRS++DzTAKUGm0vagB/WpI5WHFQg4pw5FAmWH+ZcipoJ8/I55qnG+ODU jLk7161XmQ10L0qrIMj7w7063l3rtY/MKr2828bW+970XC4Kuv3u9U9rkK+x0GlRRCQylRUeqXBd 2OeB0FQaTMxXbUOpQz/acoCYz6Vne5paxJoWpQ22or9pRWhY7Tn+GvRX2eX8mMY/hrydrSbdnYee tdr4d1WSPT/KuQN8Q2KT3FJlRZg67dPc6lIGJKxnAHaspGOcdj1raewM88shPVs0DT4oeSwoURSf QyUsPtD8IcVqW+mWlriR0BYc81I17Bbx4BG4Vi3mpPKcD7tVoibNmpd6wYQUgIHbIrFm1CeddrOd uelV3bIFRipuaWQppM8UA0valZiEHSpE6VH6cVIpwtNAT280lvcLJGxV1OQRXq+g6kNU09Ziy7lX EmPWvJRlmya6LwrqZ0/UlR2/czHaw9+1DuOLPRVAy2SalYYYE8rikYj7wGRTCxZeRUmpHNtYDFNX hVXpzUkkQxnNIF2yJznvSCwP99SahGBuAFPmy0oxnFJsCscGmBEpw3HU1IG2/eFIgO4Z6ClYg5O2 mSO4K8CmgHzMjvUsC7j83enbAXwpoGyNM7qkmO0rjNJCgeRqmY7hyOlAAxSSNSBj8KryDDdelSnm MY4xUf3zzQAwKHkwKmUFNw9KaibZRnpVhiu1hQBVDYb5q5zxa48mJRxk10myuQ8WyZuIUHZc1lV+ E68HG9VHMH0oH3aKUdK4mfVRWgChfvEelH4UDrSLJV616z8N49ukyP8A3nrydOte0eBIfK8OQt/f 5rbDr3jzM1laidT2pDSiiu4+bFFMI4p/FIaBGTqEAeM1x9ym2RhXd3KhkIrj9Rh2St7mmiWJZt+d btq2RXOWbYbH8q3bR/yoe4I1427VZU1TixVpaBkgqxHytV6miPNA0NOd3Sm9qkcfMcUygBrdabT+ KaaAI6KXoKQ9aBDc0UUUEnyovWvWfg3/AMjD0/5Zt/SvJVFes/Bwf8VEv/XJv6UxHv46UtIKWkMX tRR2ooAKKKKACikoAxQAtBoFBoASiiigBDSHpSmkPSgDwL4kceOdS91i/wDRa1yJ+7XYfEY7vHOo 542rEP8AyGtcfJ8q9eKQEZ9DjinBjjAoHPINKPSkFgBpjfM3NSbQ3JpCBuyKdxWFJO0U3tUmAVpu OKYEZ+5iq7tU0nC1BjPBxSARhlfaowp/Wp3Hyrj+dMTp7UgJk+5uqNzk81IrYHNRnk00Ij74obAX /aoZcH6VG3PNADW+amj2HWnFaQdKAEagDjpSHrT+AM0wEH3ec04UgPy0qkbO+760ANY80w8049aa RQA09KTtS0EUAN4x703vTu5oOKAIzTTTjSGgBuBSfWnUlAxQOPxo6nNKn3utOlJL56bvagBjZI65 46UzHepCMKTu74xmgDIx+maAIieVz0HpRg7S/OD3xQw4z+lHIB/iX+VAxqkfdOOfXtQOOopoHNSI nmNhWVfTe4H6mgBR/WlCktjvSr90qB83rSDjofxFSBJnPUn5ego7fWkH3aUdaYmSD7p9qAe/8qaO vWjoaLASj7v9aiYc1IoYjOOBTWGKLCIsU09KfTTQA2m06m0DCkopM0AFLSU4feGDmgDe0pcFeK7S wHy1yWkIcKcCuxsh8oPSgRl+J5t8lpYgnG7e1JbQ5Krj2rP877brdxcE5VW2p+HFb+mIZrheO9Ee 4T7HSadFJDb74o98irnb61vWLTSfNINvtiodLhwma1QOeBRYokX/ADipF/yaao4p4pgO7dKXtSU/ 8KAEpwHFAp1ADQOlOFApcZ6UALSilFKBTATHtR+FO5FGKQhozTh9Kb/F0p1AB3ooxTh0oAbS/wA6 WjFACUuKKKAADmjvQOuPWnGgYUYpewo70CEpaWj/ADxQMO9HaijHFAB+FJxS/hR3oATvSEU7NFAh mKKWigY09KQ0tBoAjauJ8X/8hGLsPKX+bV3DdK4fxhhtSiB6eUP5vR1QnszmSFznNNlUKuR3o24f HaiTYVxnmtrmFkQqMnNNaM/ezTlbDAVJIvSqESYQQq4OexqNxk/LTITjIY/nT0kJHPGDUlEeMHFN cpmluuBuTpWfLP8ALyelLQCPWJkt9NkZOpGK4Jjk10mvXAa1VN38XSuarOTLghO9FL2pKRoFLSfS loAQUoHBpOlOO3YuGbd/F8uMf40ANpcfLnt9aQ0UrgKRg0g59qKcEJjZ8rhSOrDP5dTTATgUhOad xt96AcA8c0ANpaSj+lAWCigD3o70AB4o7UGigAoowaKQDn2eY3lklc/KWXBI+lNoo7U7isFOU4pK ShgSHpUkcnODUANOIIAbtQJomkGxg6U8TlhzUaSZG1umKib5W+tArGlb3xgHyDrU/wDa0p6islTx QCd1SO3Q1v7SY/wigalIDWcOKVs4zSuwsakWozMGTdj0qpd3k3Tcahib5gc0+bHQc1V7onZlQu8n c0xlYdqvQQl2wKvNpo8nJxux60JXKcrGGclaBU0sRUsMVCvFGwABS0lHakhhUg+7UY61IDxTAliG WrXtbOJ495kxt+YVjxyAHritqF42XajZwKaIZ3mk6h9ssI8n5lGDWkQzRrg1yXhyZVMkZPPXFdbC Cqc8ipaNovQcvJ2moyMS9elSg5bIqOY9PmwfSpKEXbvbLc9qjdWL1IyD71Nc8Lz8wHSqERnO7j8q VMqCx/KnxjlfU1NsyrLihAV0bHI9alQY5x2pqx4XpxVlfuKoFAFeJW38cetOKncTyKmysfPakc5j 4/CncCI/MuO4NKq5UN2peNu7vQp+XGMUARTK2OD0ojYk89alcZ6/nTQqpzQA3DBvpXn/AIilaTVp AT93ivQnPzZPpXnevH/iazVhW2PQy9XqGT7inY4602pCcquR8w71xs+mWwgoHWk5FKvXmkUTRdR3 r3XwtCYvD9mvQ+WM14dapuuI1x1bFfQGlRiLTbdOgCCunDrU8bN5e5FFs+lB60ppK6zwRwo/Kk7U o/zxQJkMoyprmdYt+p5rqn6YrJ1CLfG3FMTOPiO2WtyzcYHasaZNsx9a0bF+BmgRvQt2q4nQVnwN 6VeQ8UFFgf5NSxnDCoFyalU4oAnlHcVBVofNHVYjDUCGnrUZqRqaetADTTe9ONNFACZopTRQI+UV xmvWvg3/AMjD/wBsm/pXkq9a9Y+DfHiNf+uTf0pkH0AOlLSClpFBS0UUAFFFFABR2o7UYoAKSlpK ACiiigBDSHpSmkPSgDwL4if8j1qXP/PLj/tklcnLlosDr0rrfiGq/wDCd6kcdRFn/v0lcpKMJgUg KqArwe9SkgUjEH8Kb/FSAQscY5pY269TTSR39akjSmA9Tg0jEZoH3sCmkbSQaBDZACuahVM1Y254 HQ03G3gmkxkZHy49KRV4pQcPhhUm2gTIJOKSM81NIPk7VEowtO4hDjzMGkde34im8h6e3IwaQyIL 61G4xxVjaM/zqJxTAhIUbSrE8c8Ywad95aMU5PpRcQwDikzipHI29AMVFmmAppue9PPSmCkAUhqR gynDAg98jmo6YWGHrQfSlI/WgigCM+lNNPI9ulNYcUANpKU8UUDHKMnFJL1x6Uin5s0rYyc59qVh CA/KuaTPJ5pTSnGR8vQUxjfmDDacN61Hu2sdvHqOtSsV8sAdc/jUD53HOc0AhQVx33dsVIjAog8p Tg8+pqNWYcdvSlynUKw/GkMepGMO33egoU//AFqacbVwuPf1pO/HSjzBk/U88U7GPWo16dKec9OP WlcB1LTeuKdQJjlNB7+9A64pWx05/OnsIiIxTDUrc96jNAyOm4p2KSgBD0po5YADrStTTxQgFzTk JLjPrUdPi/1i/WgLHXaQPl6cV0F1cfY9Kmlzg42jnuaxNGX5VJp3iO5/497NOpO5hj8qi4+pHpsX +jq2eXOa7HQoDt3EVztnFlY1Azt6V3Oj22FjXFaLSJG8joLNNsS9uKuLUMS4GMVYUUFjhUgpq08d KAFA9RTgOaBTqADHNFLTu3SgBAKcBRil70AAHPSg0uPwpaAEHvS0uOKP5UCGH71P9qaw/SnCgBO1 L2op2KAGiil/GloAb+lO/pRRQAY70e1GKWgBP8KdRRQMP0xQaKU+9ABS0nak7UALSUtJzQAuP0pP wo9KCKAEpD04FLjjvRigBmTngU3nNSY5/pQetAEJB9a4fxd/yEI+eRGP5tXd4/CuG8XZOor/ANc1 4/FqOqE9mcyRxxUYAyQR+NTfwnFQH79bGIiqBJmp2ClQPSoDTmz5fFK4WI5HUnK4yKjeQFMGmleT nrVeVwqkfnQ7CHSXAWNgpPNZVxKdpNSySjb9KoyOxPWgVzH1SUu6g1nVf1JCrKT3FZ/esmbQ2Cij 3opXRY5mye3Sm9qPSigAoFAooAKPzopKAF+lKMbepopQN2ABQA2ipVgc9sVJ9lfHagVytRVk2cvs aY1vKvVDQFyGjtRQT/8AWoGFA6UUuTQAUlFGaACiiigBaSigdqACnZ4/Cm0UCYvQ8U/qP5U3tSA4 NGwixGuFqzbxoxIqrE1TQvtkqeoMbcqY2FQ+Z61auz5nTtVFuDTHHYsRNkYqTd8wzVWJsPVluVzS 6iaNGEfMu2tBG3Nj04xWAty6YKnBFSQ6k6yM0n8VWmrk2dhb7aLrAHWqbjBp08xlk3+tRDmlcaQh p38NNNA6UhijrSjpSUopgNJqe1uWgkDjn1FQsM0qD5aNgOn8N3pk1gr0WRCAPevQ4JCYmBHTivJd Hn+zarbS54VxmvXIoyrNjGD6Ui4lm1RdtRXAXfyPanRMUzmlkKyLjg0mWQJyu3OR602TYg3UR5Td g/KexpjtmJuO9Ahy/MqsKlBYS8Go7VMR5PTtUmP3oz3oYxSCCRT4yfQ5HFMByT7U9DzkUADgFWP4 igAstAPWlV8ZFMBJEwKTftONvBp7NlfcU0HJweOKBMa2HSmKmFAJz6VIUyvB5FI3UD0oGMkIw2ew rzTU3MuoTN/tYFejXbhbeV+mFrzGdy0zN6muasz1csj71yLtilpopw6j1rlPoQpVHzUh5xTx1pFG nosXm6pbIecyDtXvtugWFFHQCvDvCMJn8Q2i9cPk17on3celdmHWh89m8vfihTR/WlpvpXSeQOoo 4ooEIfpVO6jyhq6enTpUEq5XpQBxl/CVlPUUWXBrU1WDisiA7XxTI6m9bsMfjWjGax7Z+K1YW460 FlpaeKjU4HNSUCLcXK4zTJkFMjfa1Plff0oGQ96bx3p2KYwoAToDTTTsU1hQIbzRRkUUCPlRa9c+ EcEtt4qaCeJ4po1dHjkUqysMZBB6V5EnWvWPg5x4jUf9Mn6fQUyHufQApaQdKWkUFLSUgHrQA7FF AooAKKKKADvSUtBoASiiigApp6U6mnpQB4H8RMf8J1qXsIs/9+lrkHl3cYPFdh8Q0D+PNSHqIv8A 0UtcfLGY2INIBoHPrRtwTupY93UfSn89xQBVfCsc1Ir8Dt+FI6fvPalYDOMYoQMdGPmzmnS53dKa jc0rnNIBiH0pX5FIv1obg/4UmBEEYsOP0q2UG3PFRI5AxU4UuKoXUgYZFQNwc1cMWVNV5I8cDrQB D601qmEdNkBzQwGBuMUx6eRTcHFJbgR/w9KVOmaD0oXpimhDZOe2KjC/5xUjH5qP4aAI+hoP0oY4 NNyaAZJj5aiapF6U1h3oAZijvRinFcUwIzSHpT6aaEBEaTFOPNNoYwHFB6ClAyKaaTBIO9KeuMjk U0VJkADjt3oAjcEHB49BUfQtx1qaQfNkn86h9/emCFGzaOu76UuF/vfpQOT/APWpT9RUjEAIXO35 T3IpMjJzye1K2Mkbs46EU3HemBKh2jj73X6VIMYqsOvHQVIrHHWlZgWFAx157UoHPtTFbB4PNSfw /SgQ0U89KZ3p46UAMNRtT2696RqAIjTaeabQhEZphqUioyKaGJUsH+sWo8VYtVJlU9vWnbQDtNHX EIP90Vm/PqOtvMSSqn5f6VaaX7LpLNuwz/KtGiptt2kxzIeuKzWrG9Eb2nQF51HTPXFd5psW0dK5 bRbfL7s/nXa2kYWMVo9yIbFpBVhM1GnSpkoLHL2qQCmr9KeBQAU4fSkxTqACnDpQKcBQAmKUdaWg deTmgBQKMcUCloAQD+VLilooAb3paQcnP6U7NABRRRmgAA4ooooEFLSYJ60baBikijPtS45o+lAC dqOcYp2PalxQA2lxxSjml6UAIBzRinUUAN7Uf5FKfSigBp60tLSGgBKDS496DQA00006j6UARn61 wvjA7NSjHrEP5tXdmuG8Y8ajH7xj+bUdUHRnMt93PrTfLD/N3FOOdwp6/fwoxkVqYFdo2KFsYHrU Bn2IUP3exqaWRogyEkZrHvZpAF2YxnmkxrV2JJZjyS1Z8k7N8tOkcunHGKqMSACRzmgkkGdnNQSp xUivubFMbONo5p9CXuY2ptllHoKz+9aGpKRtrPGSaye5vDYUjDFfT0OaSiigsKKKKAEzS5o70Ugu H4Ud6KFBLYoAkijMhqz8kQwOTSkeVHtH3j1qNELdRUti3DzHJ6U9Ed8/eqVI1FXIhjoKm5RUEEwb 5d1SDz4yMqTj2rThcfxLWjCIpPlZRj6UCOc2282BNHj3FNm0OTyWuLR/PjUZZf4x+HeuvXQra7U7 FCtWdPpGo6Q/nQhmjz2zVKQuU4wjH1pOldtJbab4gg2zKtnqI+5MFwH9nH9a5O+0+5066NvdRFJB 044YeoPeqAq/SkpaKBifhRR3FLQAUD/OKKBQAelBoooABxQaKKaAchwamz0quODU2crSYiwoLDdU E4+bp0qaKXajCoZPm5pCIFOGq8DlKokVPG37vHpQyhGODjmk4x/9alI5zSdKBBjimCnnpTBRYBx4 wKAeKcqhs5o8vGKYrje9OH0pvenChAHel7UlA7Z5oAdE3zV7Ro8pudItrjGN6CvGio35Xha9T8G3 Jm8Pwx/88yVqWXHc3plDRDGBVV1O4basuCqt3U1ECCBjORSL2GBfk5/Om3Cp5SrGOW61N95Keq/u w2BxTuBVQlRtP5VIOCCaa5w3IFCkFRzQA5hh+O9TEDC4qEt83K+9ORsjmgCRVww96c4UL71Fu96T O9sA0ICRRtOPWnFRy3pTgp4z2prycsgXGaYhu75eO9BSm8gY9KFfK4oGZusv5Om3DZ/hxXmrde9d 94pl8vSmUfxHFefmuOtue7lcfduKO1KBxTc8U6uc9rYD1py9etJ3pVzmhDWx2Xw+h8zxAjH+BCa9 iXpXlvw0jB1G4fb92P8ArXqS130PgPmM0leuLRS/pSdRWx5wvaigUdBQIByMUxuhqT6imHp9KAMu /hDI3Fc2ybZa7C4TK9O1c3eRBZOnT0piJbQ8itWJqx7ZucVpxdqBl5Tmpgagjx6/SphQBJ3o7e9N FOoAVhUfrT6aeuPSkAnTikag+9J3piGkDPSilFFAHykvWvVvg6P+KljP/TN/6V5SvWvV/g6T/wAJ Gn/XN6fQzPoAUtIOlLSKFoo7UUAFFFFABRRQaACiikoAWkpaSgApp6U6mnpQB4L8QefHupBeqiIH /v0lclMxPWut+IOf+E91Me0X/opa5Jh6mkAkQIGaQseRinKSqkU3acMaBXIHJ3YpQQ3JqQgHnsOt NQDNIfQYSMUwk9zUrIOSOtNZPmwwII6gjmmAnTpQ2SeKcQR3pwG6kBGR2IqxHJtXg/SmGPKkGlVN q4oEyQSfK3FV8ZbipF2hvmyV7gGm4AbNPqA75PKblvMDAAY4xznn8v1qu7Y4qQ9e9RsuWzQxEZ9q Tt0qbZ/eph4B4pDIGPbtTQwzT2X0qFlppCDvS4NJ26UE80egDHB96QHipOvFM20AOHSm96eBxxTG HNAB3pWwBTeaKYCcg9ajbg0/vTX65oAjNJTiOM0gpANAob9aePTikkxnjpQFxh+7mlJBPBOPemmn dB2pgBCjpnjpUbHdISef0qTjvzSMoB+UcH17UhoYFxkY+hqQDp1pYk8yTYrIuATlpAo4Ge/06U4J nHr7mkykRP8AU1Ht/D61YZccBRn161ExycsTmgBnGBjrmgHH1pSO+Me1BwOnH40XCwoc1YSQd6rC nLxQwLZxjPc9h2pxxtwucd8ioUb86kH3cUMmw3qQMUxvpxUrAA8VE1ADDSY+XPvS8evejA9aLgNN NIqZNnmr5mdmedvWllSMSMI33r2z1oTCxBtq5pybrhRjvVcocZq/pOFnZm/hFNvQC/qj7pIYF52j 863LSApDHGvYVg2YN3qYZumc12FhDvlT3NKmuoqnY6bR7fbCvy9etdNCuFAxWXp8e2NR2Fa8X507 jSsiZB+dTrUaipB0pjJF6U4dKAKdigA/GnYoApRQAoFFH0paAF7Ud6KMelAC+9H4UD6UtAhO1Jg4 5NPxS9qBke2nBfalxS+1ACYpccUUvNACYopf5UUAIBS0tFACClo/CjrQAClowKWgAo4opfw/SgBK DxS/hRQAnaj/AD0pTSUAFGKKKAENIadSGgBppKdim80ANauH8X7f7QjHG7y1/m1dwwrhvGOBqSe8 S/zejqg6M5cnK+9ICc89RUh2IW3j6VXModt3QHtWpjcrzvk85NZM7AnYSB6Zq/eSdB/KsyZM/Nz1 pWJZC27pUOT/ABCrBQZzmqufm56UMQ5Nu/rwKAcq3NR5+ducY6UhPzcHij0Aq36CSDH93kVidDXR SgFGGM8VgSrtkYVMjSmxlFHG08fjRUGoUUUUwD8aKBRSsAVPbD58+lQGrVtwrGkJkmN7k1MAAtNi XvTjUMdxyYzmpNxB61nsXjkzyKsGUeWCT0osG5eVuODQ13JAu9CQRWaL0g9Kf9tSQbXX5cUWDU3t I8SqJRHchueAw7V6JpGo2l1DsciSPGD3x9a8ZWNTIvlHNdFYXt3ZyRSQzNujGArHK464x+Joe40z svEnhD7Qn2zT1j45+XiuQncXNm+naipMi/6pzyUNejeH/EEd5CEO3dj54/6isXxdpFpKWmtc+b14 p3K5bnlF1ay2kximXDDoR0YeoqDiukuEW8h+zzDEkf3G6EVzsiNG5Rhhh1FVe+xmMooopjD60tFF DCwlL2o60UAKgzVuO3UpuNV04xVtzhlHpQS0MNsMZFRNGydqvxYaRV9asXMavGy45HegV9THQ4PB xTj93/61Rt8pNCvikU0MNIrbTUjfjUdAyY9KbjilTlaDxihCEPSjjjHp6UGkFAD0PzYqZlyBVcfe H1q4XRI1wctjmmrWJZVP3qBQeuaPxoSGHehjSUn1oAnU7lFeg/Dy5H2e6g44O6vP1KJFhcljXUeA 5turvCW2rJGTn6UmOO56RK2wFuxNRRDc2cVPPzC2MVVjk2LmpNR82V4xTW3YxzUrkSRbjUe47eKA GunzLkU0fewO1P3ZUZ7UxkZZGIpgOZueajj+8fTtUjL8m4imqdrA9aARYZcR5FQxqfOzUkjgr1pq sB160AS7j5wHahiHdj6UifeyakSMeaeODQBEiZJPamAc/TtU0/7sYWoVO4biOlAzlfGMm2KGL+8c 1xp611HjCfdexp6J0rmA7KTtOMjBriq35j6PLo2pCUY49KBTse9ZHqB/npTlxn60wfeqRPvUIHse p/DGDFrdS46sBXoXTpXG/DqAR6B5nd3NdlXoUvgR8jjpc2IkFFIKWtDlAUd80fpR3oEHag0GkPpQ BFIMise/i46VtsOKoXUe9f8A61AGFH8rVpQNkZqkybX9qtwdAKYGhGePap1qrGelWFoAlB49KcCK YKd+tADu1RsPmHOMU7tSd6AEOfwpv1p/fpTTyaAAd6KaevSikI+U1616r8Hv+Rlj/wBx/wCVeVL1 r1f4O/8AIyx+0b/yqjM+gBS0gpQRnrSKFFFFFAAKKKKADtRRRQAUGiigApKKKACmnpSmkPSgDwX4 ikf8J1qI9Fi/D90tcgc5rr/iLET421J+cMIv/RS1ykUYIPNFhMaVwAKkXGMNxUcnTFMZsLwaQxzc E8UwZzTlbJzgmlb1FFhdBgOKjZvMfOfmqRvuk1HFw3PSkMVgdvepUwD1z2oIXbwajjHJFFgJjtxn rUf+NKOuKRhg0xXGkE0beRTu/FLQIbKvy1GD8vvUrPlfXFQgjmiwDgflqNfvMDT1I281GeW3ZoGM ddnf6VC2KmkO4VXYd6VxMOD3pnQ1Ii/LzSFeOlAyIHDVIBxTCvzU4HFMQ4jC009KM5FNPH0pXGJ7 fpSEZopwpoQ3FMdalHJprc/jTBEBpMYPtTyKZ0bI7UAApGpRSGkAylByOaDS44+tFxgRxTW6dOfa nfw00ii4DNx3Zyc1OpOcZH09Kh6dM1Ip9xSZSHEDryfxqM4z/hU/B5yOR6VG6NtBwdvY44NTcqxF 26001JgjpTcVVyWNoB/Kjn60UXEPDgHipY5R3qsB65xQDTsgsXGcY61XdvekyTTCaEhWFDUZptAo QyZiPJH97NRocOPrQw+VRzTQcGgCUsc9ato4VflPUYqhU0WWYCk9gOq0CA7Glx97gGu30W3zJuwM Vzel23kWsac8Dn613Gj2+yEMAcn3qlpEz+KZsW+0r8nY4rQiHFVbeML04zVxMLj3qUaFhR/9apFp iY609QN2e9UBItP4pMcU7H1oABk06inAUAJt5pcc07FH4UAB9qBS0CgA7d6WjtRQAUAdKWlFACYo 7UtHt0oAMYo7UUUAHWgdP8KKd3oAb9KXFLijtQAcUhpaKADrS0n4daUUAJTu/WiigA+lFGKKAEpa COaKACkpTR36UAJSUtJQA00Y+tKaSgBhFcB45kKahCeMCJfr1avQGrzvx8M30R/iEQx+bUnuHRnN mbzQAcBqqySGNtp6VHHIcjcKZdSAjitUc7Ipm3rwelVS3mLknmns+KgLc81WwtxkvTjpUDLhKnf5 lpg+6cr7VIFd9pWmqfl5oflumBUqAZbPQ0IBh5XNYt9Ftk3Y61sIcnbmql9HmNh/ShrQcXZmNRRQ ayOhBRRRmgA7UCiihgBq3a/dbiqlWrQ/Nik9hMuxD5aaPvfjUsAG3nPFM6MazGMl5TB6daznbnGe K0J/9WxzWdVoBMk49uKKu2unyXBHBFbkPheZow6xFxjpirSJc0cwrMrZBrWsdRDNsmPP96lutEeL OFZWHYiskho3wRgiplEaaZ1kN08RV4nKsvKkV0lhrCXYHm/fA+cHv71wNjen5Uf8K0IrtoJldccd azZSkb2t2UcyedBgOPTvXH30XnIZAP3ifex1Irro7tJowMjBHFYd/GILksmNrdRQnZjlqczSVPdw +TMQPunlah7VqQFA6UUlAxaO9FFADgelTM+QD6VXpwbilYCYyHgg1ZS8xFgn5qobscU4YxSFYHOT mm0HpSUFCimnpTu1N5xTEOQ07rUa9aeKLCYvp2oFB7UUCHDGKD0qSKIyuqL1oeNx1UjHtQkFyIUU mead2osA2lH1pB1p2KBiitrwzOsGuW7EZ3HbWIOtXLCUw31vKDgrIp/WgEezId8Te9RyIfLAXihP 4SoznnipxGWTAqTURFzDzUTLtNSqSi7SKJdpjBoAaF+Tp9aQtmkEp20vGzI79qLgKrBoip6moNjE /KacM8EU5yCAV7U0gI0yKeq/N8xpobHQc0P0B7UAWIe5NWpOIlYd6qxkeWMetWZceVgc0ICtMxJz 2pqjjA4pX5X6UhyFYggcUvMaPPfE7g6w6g/dGKw+9X9YkMuqXDk5+aqFcM3eR9Vg48tJIUUo6Ug6 UdMVB2iipY/v1EOtTwLmVfc0Cex7f4Mh8rwza5A+YZrojxWfocQh0e1QdoxWh1r0ofCkfGV5c1ST AUUUHr3qjMO1FFGKBBSUp69KKAGnpVeVc5qzUTjigDFuIzupsXGKvXCdqphdp9qALkRqdT+NVk9q sKQD6UAWF+7Th14NMU0+gQUlLR3pjGmgClIpD0oEGDRSZ9qKQj5QX71erfB7P/CTRe6P/KvK1616 l8IOfE0P+4/8qog+hBS0gpaRQtFFFABRRQaACiiigA70UUUAFJRRQAhpD0pTSHpQB4P8RZGHjXUF /wCuWP8Av2lcmuVXOc11fxFyfHGpcDpF2/6ZLXJ/eOFP1FIGRvy1KuCMc0uMU0kB8YpAOQEZPPAp re3enM3H86awNMNhOcgUxlCsCM1IvXmnYGef5UgEBUL9aYy+hpw6YNKwwwxSAjHyc5qUfOtNK5Xk fnToeODTEM9R3pvOeaV+H61KE3cBc07CICMdqiYYHT2qdwV7U0jcKQyHtj2oCjbTtvzY9qaxwDg0 ARv0yKj25FBNPXFACKPlpkxIFSyDjINQSZNAEeeTTMZPWnEYoxTATkUpzxmgjjrSjmkA36Cn4pvQ 1IvTmmIYeKY3SpHHNNNGgEJpjVKajbpQAwUpxSDilP0oGNNC8nA70hHNHegBc89KDRQKAIj1pQSO DQ3B4pv40DLCnK5pSSRtydvYZqJWC9c4qTehAwp3d6ixdxpGF60xlxUu8owZeGHcdqYDhs9aYmR8 gcCkHvgU9h6n8KYemT0qkSGB77aTjFKOepo560wDp1pvf1pw5700daQBinIBRn5aRT81FhDpBhsZ 6UynSHLZptNIArR0e2NxqEa9gdx/Cs6up8J22fMm/wCAikJ7HX2EO+RV967iyh2xLXNaRCGmBx93 2rsIQFizRJigiWNcGpow28knI7DFQRA9TVtBwDSLJkB6kVIowabHzwamUVQDhThQBzS0AAx704Ck FO/lQAAU6iigA4oo/CloAO1L2oFFABRilo6etACdKU4pKX8KAE7U7t/9eijtQAfrRRS8UAJRil+g paAG0U6jrQAUfWjigUAHr/SlopaAEopaOtACUGg0YoATFLSf56UUAFN9qd6UGgBlBpTikNADGrz3 x3/yEYef+WI/m1eht0rz3x0P+JhDxz5Q/m1K2qDoziJSQelU5MjvV6VTv5+lU5QFl2njPStbGFyu /XpUG7ccDFW2wM+tU24OaZI9wVxxmoznkUShtq89abvcn529uaVxEbphc01D1Bp5HzdeQahdsPQM e6BZPkpjICnTrQ5BXKmlX5ufSlcLGFcxeVKy1BWlqMZ+/wDhWdUM2i9Ao+lFFK5YUUUooASpIW2y Kfeo6UUCZtxD0/iHFRyJtfGKdYyeZDx95anukZow4rJ7gihIAyHFVbePdL7CrEMJaXLvtX3rctbO DaTG6M3eqTBjbIMCu0V6D4cuxtWORFKscc1wu3YcYx9K3YtVt7e1ieMlJFHNXFpk2sdt4j0zTJ9L aQqokA4cdRXiesQKk7D+IfrXUXPiOSdWRpWK/WuV1GbzG3ZyfWn0C+plruHzDPy9farBndlBB6VV PtU1u4DYYZBqGWamn3bEeWfwq5dMJYAc4ArHi+STctWVmPK5+X0rOQ0Nmj+02xP/AC0j/UVlVqQS bZGH97is2QbZGHoa0i7i2Y3vRRQKoAFH+FHakoAWkpRSUALmlGT0pnerVsFLUtAIs4PIoON3HFT3 MYALBQc/pVXNADwM0mKFbinDFIoZ3pwFNYYNKtMkd0o4pe1JQIsWpxMp9DW1vWVdpQcisCKQJICe 1aNtdoTyccVpBmU0yndwiKYqvSoKuTGOZpGJ+b+GqmPyqXuWthuOadSUvakMBUkRwwNRipFpDPYN FuTdaPaz5zlBmtZSdtcl4PuPN0Ly9xPlyFTXVow8kd6RohsnPfrUByetSN8+ecVFt+b5+3QUihpO X4qwMKuMGownzcU6UkEUCewxs7MVEeQu3tVg+/WqpGO3SmDJVXOdtIUJU+1NiJBzng1MeVPvQAJx GKngfzN2c8VWiQ5x1xU8QKnIFACsOOOtV5T5dvJITjCmrZGDn1rO1Z/J0m4bP8BodkioK8keYTv5 k8j+rE1EOuaceetNFecz6+irQCijn/61ApG44fe9qvaenmXsKc/M4/nVEda2vDkXna5aJ6yCiO5n UdoNnvFquy1jQdAoFTU1OFWlNemtj4t7jqTvRRTAAcUtJR1oAD06U2n0lAhvamtTj/KkNAFeZMrV N0welaLLxVV170ARItTr1poAHFOxzQBMp5p/UVGKeOR1oEL1pe1FFAxOo4pPxo7UmeaAGnrRSmig k+Ul616n8H/+Roh/3H/lXla9a9T+EH/Izw/7r/8AoNUQ9z6FFLSClpFCGlFLRQAc0UUUAFFFFABQ aKKAEooooAQ0h6UppG6UAeCfEI/8Vzqfv5X/AKKSuYiGJORXVfERN/jnUB0wIv8A0Wtc+0aCI7Tl vrSApOBuOPWkaIY3ZpWH8XrxilHCsO9AiHPHPalz6Zpwj3ZOeaDH8vHWgY0dcZoYgDvn2pMYbmlI y2aQEiDp1obk05VGM0nQ7qEIa2Me9MP36kYDOcdaiB59qEMHXPepo1yv0qIEf3uemKsRkbaYiGbH 41GBgZqSYgt/9agLlaLhYrnJNBjB/KnHjP1prSZHNTdjSKbjawpwzmnOozn8akEfy570xPyK5Y80 1umam25OcUyTG2lcCEYJqQx8U2PmTFXQBt6VQupmtxkelIp5qeZOf8Kr4xSGSd/rTlxim4yKcKLo AI4qM5FTVC1MRG1RtUhphFAxnekNKeKaaNgEPtQKQ8UoNACnpQBxxRRQA01Gx7cVIcY6VG2Bxjmn pYEIKfk4HIxTB06UH029OtKw7ku7POeaCR15zUY27TnO7tjpSqR1Pb2pWHceCc5X73r6Uw49fmzT t/yYwKY3XtTQhKlWJpSdo+gzSRRF5ljxyx4Fa7QCE7Bywp7akNmWbOULziovLKsQa12GRyKz5QPM epHEq4pygZ5ptOWqsNiGkpaSgLAK9E8OWvk6bCP4m+Y1wdjb/ar2KH+83P0r1XT7b5Y02j0ppGc3 0Oj0a3xHuPU9K3pPkQCqdknlxpkCrzHzGHpUGqVh0AyKuIuAOKjjXjpVhR/jTAeoFSr0qNR+tSLx waYDlp2KAKcBQAelOFGKO9AC/hS9KKO1AAKKDRQAope1JRQAtFFL2oASkpaMe9ABS0UUAHFFH50t ABRRRQAYoo9qPSgAxTsUg6UtACfSinUnegA7dKPSlpe1ADaOnag0UAFFH4UdaAG0dqXqaSgBpFHb vS0h9qAGH6V514+k26jDnj90P5tXorV5t8RTtvrc+sQ/m1LsHRnItLk5qjcylnBI59al80BcGq0m c1qc4hO5aqsCDmpR37UwH1oAXjZhvwquT2xUrtkYpEVdw96BEY9ahk559KvSQ/IcVSlXjApNjsNj ww24qQDaePpQibR0608ZBxT8hFa5h3RMGHzVhOMMR3rqLhGDbW6kVgX0ZSc1Mk0aU30KlKFJUkdB 70lA45FSaXCiiilcYUCiii4i5Yz+VMM/dPWtS9ufKjCKPvVgVP5zFVB5xxSaF1JGZutTRylW2h+n G5cimRPHIuyQFf8AapHiaLqQfcU7InmNzStRi87ybw/IwwH9K0L+yDQ5hIK/wkVyMcvz4rpNK1EH bBKfk9agp7HO3DyRSFX4NV3l3DFdXrelJJ88RzxkNXIyo0bsjDBFUCGU6P7wpvanIOc0yicyYWk8 5uwoi8tpAshIX1qa48tCyp0rPQojjlzIuaZdj98feokP7wU+c5b1qkiWRe1A6c5pKM1VgFpKKX6U AJRS0lACVJG200ylFAGkIme0Z8fKBWaevFTfaH2bNx21ERUpAJQDRSdKYDzzSLSZpVoAfyKKPSgU XJG0q560mOakFMYgNLQOtSTJGj4jbcuOtJ7CIz1pKXvQKAAdqevSmChTQM77wNKTbXMfBw6kV20f QiuM+H9uy2F1cPwskihM98da7Y4TDYpFoa3GQKgx83PQVOxyvHekTHltnv3pFDEODwKdIRnJHPah DhsUsmd1AXIsZIxSS5xtx+NKASDjtT0GGJ60wIMbFWng/e/u0F/bIFNY4+lAEkX+sxVjlW61UQ/M retXyo+X1oBDHU7qwvFj+XocmD94gVvAlifauX8bSKNNhjznc9RN+6b4dXqo4E9aBRSiuFn1tPSI nPSgUvagf5FI0HKPmrqfA0Pm+JrfI4GTXLr1ruPhxD5mvs/9yM9qqn8SObGStRkeuDGKWk7Utekf IC9aSl6dKKAF+tHFIDRQKwGm0456U3vQMCKT/PSl5ooENOeahcVMaaRkUAQbefw705R707FIAaAF XrTxTRTh0oAdR/hR35oxQAlNNOPSkNADTxRSHNFAj5SXrXqXwg/5GeHj+F+3+zXlq9a9S+EB/wCK otxjqr/+g1RB9DClpBS0hhS0UYoAKKKKACiiigApKXvTT1FAAc5XHrS0UUAIaQ9KU0h6UAeF/ELP /Ca6hgH7sXP/AGzWuZXr/Oul+IB/4rfUOflHlcf9s1rmyQrNjv0qQK8g+bGcVG5+b/61XLgYVTVd wCh9R0piIFJH3afGTu64pm3aOnFSovp6UugxsvXIFRp1p3LPtpMAHvQBZXhO2PpTU5yMUnVf5UR8 NigB7DC4I69MVVcYq1IePeoWAoAh4zirEXIx0NRBTnpTxle3WgCN+JPaptnFVzwc1MHBTk0gIJOG NQbeTUz/ADHio9pxg0AMGOalbATAqE8dqkHEfPXHHFAEOSeKjPQ1MuCGPTHSoWPHTH4UAMiAL1dB +TjrVOIfNVjj3oERvg1WYYNWyOOM1XYZpgC/d7UnehaUrz0oe4BUbVOR8vH6VEwpiIjTG6VIaYaA I6YT6VJ0qNuKAGk0U007tRYYuRilpvanD6UrBcQ9KiYCpKa1MLjBRxSZoPP/AOqgYUCkpRRYB2fe jPGOn0ptLTEzU0OJZtVgUDvzk118GkQ3EjySqdxc45rk/Dn/ACF4/pXoEJADAetDZDV2Z1zotnCj FYct7muDu+JJMf3jXpVw36ivONS4u5B/tt/OouXFWKNOH3aMUfw1YB2pDTj0FM70hnSeErQSXkk5 H3OB9a9M0mHdLuHauT8M2X2fTI8jDP8AMeK77SINke/HFW9EYrWRrRQ5w3I29KsRr81RxNvhyO9W Il9qzNiZOtWlx6VCoxVhRTQD1qRaatPFMB1GKKWgBe1KPpSUtAC8UvakpRQAUtFFADc804UAc5pa ACk7UtL9aQDaWlGKO1MAooopAApaT8KKYBzu9qWikoAWj0oooAUUUCigBcUd6KKAE7/SnUUUAHb/ AOtSUtFACd6Q8072pP5UAJSUtFADTTTTjikoAYw4rzP4jHGo23vF/Vq9MPSvM/iT/wAhC1/65f1a kD2ZwbP7ZprEBc96GYoOKZ5gK4NanORMc+tR4z361J/HzzSd+OlACfL0pofDZ9KTHc9qZnjtSuBa 8zMZqhIcNzUo3MP8KjK8dPzoAkJYIpFK38JHSk/5ZYpq+meKYiZHPmK5USbezjINZl7CG9zWhGyg bfWklVNnO3dQNHMtjGMfMPem1ZvItshIxj2qtWbN0JSjofaiigYdqKKKQhadnApgpaYF2G6T7O0b op9G71C0mUxmq+KcKkLD4j84rRgyHGDVG3TL81pxLjBAqWBv2EwZfLl5U1n61pcbhnjU7uoPrT7c kMK0jJ51uY881pFozOEMTBsEU05Wuo1PSWCLMgHTmsGVMZUipasy1K5VzTc5pSKULQUCjmiQ808c VExyaACko70UwD0opaDQAU2lpPxoAO9LRScUALT/AOGmVKjfKygnB689aTB7EZppp1HUUwG05etF IKAJccCg8UDpRxSEGKXtSUUAHenH602lHamIB1ozQaUDikDCrmladLqeoRW0QPzH5m/uiobO0nvr pLe2QySP0Ar1HRtBh0TT4m+9O3+tb39qCkmzVsrKOyso7eJQI4lwo9auHDxjIoDKwyOMimqNy4qT RDmVEQc/lUbBduafOuAqjJpjY2baYEQYfLT9x6nkU0orAEU5AcYoAEAC/WmnK9Kk4C9DTTym6kNI hbOMgdaHUj6U9VDr7ig/f+lAh4AMQbHNSI2GyaZwIeaeg/d7iO1NALv4YjvXE+M3YSwRk+prstuV 7jJriPGbg6lCmfux1nV+E7MEr1Ucv3xSjrScUo/ya4mfUx2AZxQKPxoGO5qS0PTOa9I+GMP+kXk3 90AV5wnWvV/hlDjTrqXHWQDNbUPjODMpWw7O9GKXrSUld58sOoFFFAB2xR070CnUAN9abTjSYoEJ 1o4oxgGjrQMQ8000/App60AJikxSnmjGKBWEFL7UUvIoAMUUd6aKBC00nmnUhoGA55ooFFAj5PXr XqPwh/5Gm3/3X/8AQa8uXrXqXwgx/wAJRDk87X49flqjM+hhS0g6UtIoUUUUUAFFFFABRRRQAGkp e9JQAUUUUAIaRulKaQ9KAPCPiE//ABW2pK3pFj/v0tcquW9Tiui+Im4ePNU75EOP+/SVzKuVz70C ZM43IvtQMFeTQSPKpgXAB9aQDXBAxSx5wefyo2kt05o3FX4pAMK/NTunXn60pGTSHrjtQtRkmflx 27UxFZWz1x1qSIK4K0EeXmgRG5+bHakY8dKGOV5+tGRn+tACoRn0zRKeR6e1AXrUe4luaSGM29/6 UqJlsH8KkIx3oXGeeaAe5Ey7eDSf4U+bk56Coj92mA3AP1pzH5cc01c4zj8acwyKVgIfUCq7jjFW pMbOAPyqq59KBD4VPHTnpk4qV0IJBI4OODn9aZGOMEVOBlcAZ/CgZCO4zzULj5c1OwyOKhk+7QIi 96XOTTe9PjHNMCTA2ioWFTjpjtUTCiwiE1Gw9qmNRmgCOo3HHSpTTGoAh60v9KU0UxhRSCnUgEpr dKk7U08igCuR70vXilYY6UDI/lTACPl6HI600U8KTUpgdA2V4zjI+YfmKLjIQKcEqQLzUgFFxWLm h4TU4s984rqo9TigkeOZsYrjYneKRZEJDLyDVw6j5js86DJ7oKhjOol1ezcYSX5h0zwa4W9k8y8l YdN5/nV6S9iCb1PfArJJySaEAZoPb6UU48HHStBMQ9KktLc3N3HCP42xURPFdB4SszNfPOUyIxgf WhImT0O80+AKkaBfQV1R/cafx95uBWRp0G6ReOBW5Mm+SNMfKtE9RU0XbJP3CDrxWgi8VQtcDjpW ivrUI0JVFTrxUK54qdR81UMevTingUgHangUxBS96Wgc9DQAvagCinYoAKO1FO6UANxS96WgdaAD /PFHaig9KQB0pKXFBFAB9KKKWgBPype1FLQAlKaBRTAKDRR+NAB3o/CiigAFFFGaAFpelJxS0AH+ elFFFABRRRQAUUdKDQA2iig0gGmkpTTT1pgNavM/iQcaja/9cv6tXphrzH4lf8hO16Y8r+rUuqE9 mefuwz0qNVy3TipnTjjGTUS5H4Voc4r9OKhz8vvUz/dB/Oo1TjPY0XGJtzjNN2jHUU8528VXYnOP 4qAsSE4JwM0x26e3SkZnz64FRKzeZ7GkFyUc84pyEBSKjXIanN9/I/GqENGd9NbmRT19aOc5FA6+ lIZTu4VyQP5VlsNpxW3Iu5m3fnWZcxY5H8qmSNIMq0CjpSVJoLRSUlFhWHdqPSgelH9KGACnpycU ylHWi2gFyLANX4iOM1nRHcM1bibkVn1BmlEwDd6sLJiqAPT+lWVOVwaaZBq290NgjlG5DWXrGj7/ AN7ARtI9KmQ46HNaFtOv3X5XGDVpi9DiPs7A4NL5YWun1XS1/wBbByuPyrl532HbghqlotMhkbHA qLtSnk0lUUJS0lL0oAKKc7b5GfAG45wowBSGkAlJTqSmFhO9FLRQAU5DzTaVeDSAc2QaRaV+gNC9 aBCEY7U2pJOtR0XGSfwinUxelOFAgoo70UXExw6UUAZYDIHbmmd6AH96cis7BVGSTTB7Vt+G7Jbr WrWF+V3b2+goA7rwd4cGkWv2q4UNeTD0/wBWvpXQXePs5U+tWIjkDAAAHGKJogU55zSkax0KscgM eP4sYp8WRgGmbPLbYvY9amJy3TtUpFEjEEZqk+d+cVZbgLUbZPyjmmIaFG0Y707OFxjGKF2ryaaz 45oAkJxj3qI5zjtT0bKio8tv5HSgLDVVvMyD8vpQuA2DzT8Ht0qKPcJznpQMnm+6opY5SBg9KZJu 3kdqSD5sUATKyt2xXnPiqTzddl5+7xXo0ibFzmvLNZcyatcMTzvNY1tj0cuV6pQHWl70gpR0rkZ9 IhMcUoHFIelOXpSKHxj5sV7P8PYtnhxW/vOTXjUf3q918IQ+T4ZsxjGUzXRh/iPJzaX7pI3e9Lij +VJXafOhS0UUAHSjvQPalHXFACdqKD0xTfrQIdTaWk70AFGO9O/hptAxpHSig9hQeaBBSZpcUnag A5zR37Ug60vegQlHSlIFIaBiA0Uo4ooEfJ616h8Ij/xVVtn0f/0CvMVr0/4Rf8jTb8/wv/6DVGZ9 DilpBS0igpaKKACiiigAFFFFABRRRQAUlFFACGkPSlNI3SgDwT4irnxxqPTpFj/v2tcqqnq2DXWf EJs+OdRVvu4ix/37WubMeFU0tRPcjJAUgihjui28cUP070qKrAbuTQA1OlNfaX4NWFQYbioHX5+K QCq3+HSkJOaQA49qkA46mgBYiQeadOPk+7UfQ0pkwME0DISmRSHOAO9SDrmoz9/vSAkiLHcDUbqR JxUg+Vs4/Sm565NADc8808DjFMPWhGJ//XTFcGG4YqPaV6/yqQfe/wAaJGFIdhpGF4o48ugD1xRg bSKAuQnpVWRAMYq1xVeZTkc0ATKnTrUhHy8ZFNi6c+lObjp+VDCxGo4qORO2ak3L60cFc5oEym64 oQ461JJ16d+1R4xTDYlzzupGXIz60uxlAyrcjjigZxTQmQMMGmNjGMVLLUBzSAYaYw4qTtTGoAgI p6OEWRTHG+5doLZynIORz14xzngmkbrQDxQMSlpKcKBhimmnCjoO1AiE05Rzmg0q0wHhacpKtuGM j2oFBqbjAsOyhfpRTacKBDhSSfdpRSkUDKLdaATU7xc1CeuPeqELGMyLQ3LGpbcfPn0FN96BpEXe vQvCtl9n02NmHzOd5rhbK2N3ewwj+N+a9WsIQsaKox2AqomU30Oi0iLbHvbHFWbZjLJJL2zUUjfZ dLY9GIwKl01WFkretZt6msVZGlajOK0kQ4qlZqdoJrSC00AqCp1FRqKlWmA8U8U1RThQA4UACgU6 gAFFLiloAKO1FLigBMUUtFMA7Uvaj/PSikAlLSc/UUtACd6O3vS9aKAAUdqAKXtTAQCil7UmKQBS mjtRTAT/AD1opf1paAEpcUUUgDFGO1LRTAQUtLRzxQA00uKKSgAo6DpR3o6UAIaSlpKQCGkNBopg RtXmfxK41K0yP+WX9Wr0xq8x+Jb7dRtflB3RY6e7UuqB7M4NzgVXbvx1qU/Mx20pTMeehrVnMQjO 360SbtqgHIBp3lkMvOaY7tgjtSGIH/vYxUDKDLkH6U7tSqpMg9KAugdDtz6+1RhRn6Vckz5eF6VA qjuvNFg9CH+Lcx6U8/dyO9NZsA4HPpRGRtOfypiJGwI1XIDelQSLsb+8PalYlmzTcnIzSGOeMllG cbqq3MQAK8nFWA2csetDqGDP3xTAwpY8HpUXetSWHPas+RNprKxsmR0qMY3V1xuU5GVBH5GkNJRY oUdfpRRR1oFZisdxzgD6UlFGcKRQA+NyjZrRjIcblrLqxbTeW2D92k1cTNWNuxq3GeKooc4xViNi D/8AWqUSy4rcVKh5yKrKamU9KoVzQhnIj2kZ9iax9R0sXSmWJQHHYVeDVYjk+XrVXA4OSN4pCjjD CmV1+paUl3F5igCb1rlZ4JIHKSKVNDRUZXIqVm3uz+pzTRQKRYtLSUUAFJS0lAC0gopaGAUCikoA l+8lMFOQ008GkKw5jzTKX3ptMZIlPWoh1FSClYTFIooI6HikoFcUGkpO9KPwosMkX1Fb3hO5S116 KSQcFWX86w46sWknlXStSBbntiFflIPBHFStJuG09qzNLy+k2kh+8YhVpNxVyR901JsK+4Sc9D3q UsvkAfxGkfayikK5jUimthEg5jANQSAr8ynpVltrRDHamcBegoArj7gz96mYUo1ObknP4YqBspIF 6+tADonIPTGKlOS4btUcahlJzwKG6ZHSgLk5xuCjNRJk3Lqe3qKCy/KTSs4MvH40AhZF+Xmm2pGT SO2d3OaigzluenpQMuzkfZXcc7RXkV2++6kf1c16fqFx5Ol3DeiGvK3OWrnrM9fK4+82IPpS0nNK K5nse+hKUDFIKUc0honhGXH1r6A0KIQ6NaJ6RCvBrCMveQp6uBX0HaLstIVx0QV1YbqeHnEtIosZ 9KDQfypPaus8MMUtJzSikAUUtGKYhM/rRjNH4CjpQAh+lJzTqbxQAUtJ+NJQAe+aTpTj0o+tADfe ilI7+9J6UAFJkZ4pTim/hQAuP/r0hzmlHSm/jQAoHXmikGaKCT5SVea9O+ERx4qth6h//QDXmuVO MZz3r0n4Sc+KrX6P/wCgGqWxB9EilpB0paRQtFFFABRRRQAUUCigAoooNACUUUUAIaQ9KU0h6UAe EfECLf461Jv+uX/opa5mXcq4znHeut8dkf8ACcahkDAEQ4/65rXKXAAOc1PQCNvmjzS2679wqJTx 16/pVi16tQIcVKryahxmrB+dyKj8vYaPNh5EPenDjcaVhjkCjBZcUARt7DpTGNSMCF4qFvzoGSY+ U4oiwTzQpyMdKbnA6UgJHO0etRMflGO9Lu3fnTSfT9KAGt60R+hpG9KVT8pFJgDZNNXcW5zRk5xU y4pgNqM/SpHYjoOajVwetIBrjjNV5c5zzVwiqs3PtTsIki5XNMkY9jT4uFpHHzdeBQNEDnj606PL DFMfBGO1Oi44ouJjHzupv8VOmyDjFMHWi4EoZhHt/hPakL8YoHTimtTERvTMVKy5qLFAEZpjcVI1 RtQBE1IOlOYcYptA/QKUUmKBQA6kPSjmg9KQyM0LQaBTESCnEk01aKQxaUU0U4UAhwp4pgp4pABH FUG+9V9uEb6VnnrVREWYR+5kY1XJqwPlsc/3mqt1pj6HQ+FrXzL5pwDtThc16Vp6F5lA7Vynhiz+ z6ehYfM3zHNdzo0OW3HgVT2MVrIZrEuZ4bZf4Rk1rW4/dRoDwK5i3m+3azNOeV3nb9BXVWvUVijc 2bUBVq2KqwdB/hVoY9KsRIo4qVelRrUopjJB0pw6Ypo4pw6UCHYpRSU6gAopCcc0o+tACilopaAE o6UtHegBKX8aKU0AIKKKPxoATiimPIo4pwOfxoAd1paKTP4UAFLSc4paYBQelGKTbzmkAtFFFABR mlpMcUAGaWjFFAB2o70tFMBKMUtJQAlH4UtIenFACUUv4UUgGmm/1pxpppgMb8a8u+J3GpWJ5BMX 9TXqBry/4nf8hGyPP+q/q1LqJ7M4Yjke9Pk+QY65HWow/wAwHSnT9Oe3StTnIG27up4qBiQamxuH AqNhnp1pDIRnIqYYfnpTNu07u1MEu00rg0SO+1DimllQLJuzu4pHcOMYxSBUdQjHvxTuAS47/pUb LzjpSyJiXaDxT2XC5BoEV0V1+Y9KD2OPzp4JDEH7uKlUBo8nBxSQyJcZ56Ukh+XH8NKyEv8AKfmo I+XceopghiqvXsaz7uLDVoY7jpTXh3pkjmk0NOxivHio60Xh9qikt9w+X7386g1uU6SnMrK2GGDS UFBxQcdqKMdvSgAopKWi4Fy0uMHY1aUb1gjg5rStLjf8h60rGckaitUyNyOapo2KmVqEyS4GBNOD BT1qBH/lTxtamMuRT5FR3mmQ38Po1Rr8vOf/AK1TRylRTTA4++0+aylKup29mqpXfzRxXkO2QAmu Y1DRnhYvFyvpRYalbcxqXtSlcHnim0jQUcnFJR9aO9AIO9LSUUAOI+UHjn3pKKKAFHWlf71JTj90 EUhDaSndqaRTAUcGpid2WAC+w7VB6VKh4pPYYChulOH0prUCAe9OAzTFqVRzRYCRRgVLao0t5DGi 7mdwoA96QDMee9WdFYDXbEnp56/zo9BI9dtovs1lDAvSJAtWN2Y2xzmmtnawB796EPy54qWbIsRo kkClsc0xjhdnpzmmMSicGpIDxlh1HNADYupzUMso+7jHOM1YcqZfT6VXkRQ7D8aACVei1CD8xPpT ywdcFvmpAMZXjGKAAldoYdTTA3UN0px+6M9qR9u3jrRpYCR1QqvNNdQcstES7wU9KikzkgGgYqd/ Q01TgtinbcKoz0psXBkHpQFkUdemC6Hc4A5TH615ua7zxK+NEm9yv864Nq5a257mVrRsAw3Z9KWk o/CsGe0kBpy/hTe1OFLoM1tAj361Zp6yrXv6fKgFeHeDIvO8SWY9HzXuK9K7MNsz57N3+8ih31pe lN9+aK6LHkC0tJ3ooAUUUCg8n0piA0n+elKab+NAx340h60n6UHOaBAaQUtAoGHWj2NA/nQTQIQn 0pO1LSUAGflpp6U7vRQFxvtQetBoNADDRTwfaigR8ojrXpnwj48U2x7Dfn/vk15sEY9jXo/woDp4 rtRyM78+/wApqjPQ+jB0pkUYiBCkkE5wT0p46UtIoXtRRRQAUUUUAFFFFABSUtJQAUUUUAIaQ9KU 0h6UAeHfEAY8aX5IPKxfj8i1yM5bPI4rrviCufGl9g/wR/8AosVyLbqm4DFXKYFSw5BOahDMOBTt zB6AJHdlfPSpUfenXmmHDJmkQkcCkASZwRSxfdp33hzQPlUnjNMRG/Xiq7EFvarUmCuaqEHNIY7I z/8AWoOD04FRk4+tPywHNMBCvyUgU4pyNxQTg4xSAiIO/FB4NP6tTXHNAB0OcU6M0mPlp4HGaAY1 gSpqoobeeowauFgDjimEKDnHagGKPud6qTKQQ3rVzjHFVpT8uPSmKwsZ4HWnOOR7VEr7T7GrDYOP epAqPHzx3pdvp+NPb71ITjoM0DIpASPpTAOcVOx71H6fWmhDVznim9TUo6/pUZUhqYhGFMbNSmkc bqBlZqiap2HGahPWlcCM/WmHrUhFMIpgJ2pRQKAKBjgKQ9KWg9KQEZpopxpvemhMeKWm0ooGLThT fanCkA9e3en00U78KAGT8QnPeqPerl1/q1HrUNuu+RVpoCSZsWUKcdSelJp9ubq+hh7M3NSaltWd UX+EYrY8JWfmTSXJXIX5RTQp6HbWcGyJVB7YrZvbkaXoM1wW2kLtX/eNU7GImRQF4Aqh48uitja2 aA/PKC2D7UpvQmmibw4Mwbx95u1dtZpwuRXJ+HIgtvGDn7veuzthgVKNC/HVhTVdelTJTAnWpVqF eB1qZTmmFiRaeKYKcDTEPFLTRTulAEcz7AowTk9qenTmlIzSjpQAtFAoFAC0elLRQAlHNL2ooAQU e1KPaigCFY8SZ7dqkGKccUYoC4UfhSjrRigBPxopaKYCClpaKAEopcUHpQAlLRRQAlL/AEopaAEo xilooASg0Ue9ABSUtFADaKU0lACU0040h/yaQEbV5f8AE0f6fZk/88sfq1eosO1eXfFDi9sznnyu Pzahg9medyNtfijcWXkmmv8AKvPNNDZIrQ5yZCduKiY9yeRRu2qRnrUQVytJgT43imbQOBgnNNR8 DBoYgDJoDzITne+B8tMX96uMFcdqsqvGccVGh2uxxxQA5vlj3jtTTJ8o4605mYLgfdaodu3KHoOh pO4yQKrR7qjbci8d+KcnyryflpxdMKpHzdjVdBEextuf0qWPsHXr1pTIF3DGWPU0BxjI5YUAM2Dz WVRjNL224ximvI3mZJxRuz0oD1IzHub6UPb88VaQYBOOewp5Q9e1IZXbTo7qPnh+zjtWFdWU1pLs lX6MOhrqYdwOCKbd2++Nt+1sjPNJopM5A0Vq3OknyVmtwSDnKk9Pp+tZZUg4IwaRadxO9FFGKQ7h 6U5HKMCKbikoA17a5EigHrVwEeuPSufRihyK0re43rSZDiaIbnOanRveqStkCpVfiggvKwpf4vSq qPhqsI4biqGTKx7fnUrbSOec9ar7ivSnb+hoGUb3SoLgZQBW9awbiwngblMr6iurz83+FI21vlYC mCujiqQ9a6i50q3mGV+VvXFZNxpUsTfL8y0rF8xmilp7wvG2HUimhaVikxKUCpNnApSp4FIRGaVe Vx0oK4pB96gBT096aetObr7U08CmA2pEplPWkMcTjim0ZzThQIVetTKcZx3GKYuVwWGcjvTgc0eg mT/8sWpltJ5V3C/911b9acOeDUJGJFoBbntlpcLdWyyJwrLkZq1CAYetch4MunlsZoGIIjIK+w9K 6pG2x+mDUXNlsS7CJOT8tK/+qXZURcu2KnVQEwT0pgII8jeaq/8ALVg4qR3YlgpxVeeTDLxyetFw JD5ZypH4iljA8stnIFKUBXjrjNRsMJgcZ7UARvgd+KETkH1ppGV2569KcpKjrSHuTBwh78mq8xGf TPTFSAbhjOM02UD5RQgG7skbaEOWahV+XI6VH/y0NOwGH4tbGmqnq4rie9dZ4uk/dQL6nOK5I9a5 Kr94+gyxfuxR1oo4FFYnrAKcKaOB0py0D2Ox+H0PmeJo367FJr2UV5T8M4t2rzSYzsjr1bvmuzDr 3D5nNHeuH4UtHak6H1rc80BQPpS9qB6UAL05xRR+tFMQnbpSU7tim0AH40vekFGKADvQQaKO1Awo FAoNAg700+xpaMYoBiGl/PFIBzR36ZoAQikpfekagBeKKSigR8929vFsHyL+Vdt8Po0TxPZ7QB97 p/umuPtv9Wtdl4DbHiaz/wB4/wDoJqjJbnugpaQdKWkWLRRRQAUUUUAFHegUUAFFFFACUUUUAIaQ 9KU0h6UAeHePz/xW1+MjpF/6LWuUb5mI4FdT8Q/l8aX2R1WI5/7ZrXLgHGe3rUDI9i7vamynFTNw f8KjdT60Eixt8nHIp7kdaZEnyNnsafInyj0pgLE2c0Sc89KZF8uRTy2R0oAi/hqMjipN2aXH/wBa gCuyU4r8uKV+tN3cYpDHRjtg0SD5vlFKuQORUefm70AInXimyDJxTjTuo/GgAUYFOUDaajY/Lx/K nxgbaAIWHrTM+2aklPzDmo1GX56dKPIPMkj6dMVHOvycdqd3p0n+q6dKQFVQMVP0Ud/pUSYYVMVw tMRHnPJH6U0j2p7KacUwtIGQOOKaE+b0qQ/eFS7QBxQBXxj3NNPNSH5jUbfKelO4hNvFNYVICCKY w5oDYgb6VC3Wp357VA2KaC5G3pTG6CpTUbUDGjpTqb/npTqAAUHigUtK4yI02pCevHX2qOmJi0op uacpoGOp46+1M704UrASL1p/PSmDrTxSAgu/vKntU1lGscquT056VVujmfpTzIEgPqeKrVKwIinc zXDP6mvQ9CsRZafFHjDEZb61xGiWZvNSjGMqh3NmvSIF4VQKpGc9za01NqtIfujmuG1++N/qdvkj DOzDnt0FdR4gv10rw7Jg7ZJv3ac881wSu0uq2a8/KgNZy1ZpFJRPTtDXESnGOPSust8dfauc0jAh QfzrZkvYbaNnldY0UcsxwKV7IaNIS4qZJOK5z+1jJ/x7xMR/fkO0H8OtQSXsxdVkuevO2FsD8al1 EWonVG5jj/1kiKPdqcNQts485a5u3ktw45XPetWCWJ34x9KSndg4msl1G3Rx+dTq4PeseaGOSNlA Ga5281i50ooRkxt2J5B+tE6nKrhGHNoegK49akzXJab4jW+VXZFj2DrnrWrE00l4rl8qy8AdBSji FLYbpNbmzS/hUf8AdNS10IyCjFFLQAYopaMUAJS4opaAEopaKYBSGlooAT+lKKKKACiil7UAJS0l LQAlFFKaAE70vFJS0AH6UUDilxQAlFLRQAdKSiloAT60lL+FJQAdqbTqafpQAhpDTj1ppoAY1eWf FAZ1Cz/u+Vk8/wC01epHpXlvxSBF/ZnsYv6tSB7M89cce1QAbWyPwqymD149ajIXzGC/zrS5zkf3 jUkTFR0oKqMdKjWQpketLqMQghzk+9NZqXjPWmuQOBQIcTvHpTm5QYNGNuO3GeajJ56/lR0AcpG8 IRzmnzq7ODwMnimD7wbjnng0+WUvjZyuOaBkQAwVpjk9OKegLBmVTtHJPYU5Au/cee1AhijPanxp 8rYAFCGPc3XmhzhMCmBGwVm65pFAB+tL/DnPenqBwaQehOdnG2rSKXgIbpVdV3KvT61oLtWMcgt9 aZSGwquzP8Q6VHNF82ewq9bplulWGi4UrlSDwaRVjB8vK8YK+9VbjTY7mFnbasi8ZHWtW4VgG242 /wA6hgeHy8Kh8wDvQI5S506e3JOxin94CqldmUVg2TWfPpFvMrMm5XxnjvUtDUmc33oH0q9NpdxE pYLuA9OtUipX7wI+opFiGnRyFGyOlN42jmigDWhn3KMVIGPasmKVo2zWhHKJFyKmxDVi4j8VYRyD VNWqRW9KZOxeEgPU0q7mOACcegqsp4qRX7Ux3RIGOPejzPXtUbGmfWgCzuBWk35xUAb3qMu27Bou BNNFC/VAapy2MRbKoEB67asBz0p7E4ouBQazVOfSqc6hBkVoTycHB4rJuHycUhxICcmkPBo7049K ZYrU0ipR8yU3IApAR4xSilJpBQAo9acKB/Kl60AThy8aqcfL0pAKjDDbzT0bjnNCJZIpw1OEDTXE UaAlpGCgfWmE+lbHh2NJ9Zs97hGWQMue9MEavhtLjRdbWC5WSKK5XALcDPau+DBDtPQ1j+KNPkvt O8yHd58B8xAO+O1SaTqI1XS4bjGJANsg9GFZs2jobGAzHHbvTnkwqg9RUHzxbQD96nTfNFkUIokI yVx3FQXCHAp0R2YdifxpWYOmMcZpiCMHHJ5xSkgtt7iiM4kx2Iodv3h46e1LYCJgFxmmKpHGM1I+ Cx7UkRIYKaQx6sBiMr+NQzAeYc1JMSzbRxULo+frTAenUqoph+lEe7jtTWLfMKa2A43xbIDexp/d Q1zvetrxO27VmHYLWLXFV+I+ly+NqSAY9KKB9KUnisj0UKKcvJpozinJQM9K+F8X/H5Jg/wrmvSh 1FcL8Motuk3D4+9J/Su6Fd9HSB8nmEr4iQEGiilxWpxi9qDQaKACkpeaQUxCUDkUvaigYn/6qOlF LxnrQAlGB2+lLjn6UlAAB9aO1FH1oEGMUdaKT9aAENBo+o4o4NAWEpKcelN9qAAUUDjvRQSeA2x/ dqa7LwJ/yM1n/vH/ANBNcba/6sV2XgX/AJGWzy2PmP8AI1Rme5EHb8pAPuM05c7RuIJ744oFLSLF ooooAKKO1FABRQKKAA0lLQaACkoooAQ0h6U4009KAPDfiAS3jbUAegWL/wBFrXNAfKR6V1Hj9W/4 TK/yPlIjx/37WuVUN0qAIZGPv/hSqMrknmnTKSeeKRRjB/OgQ4LgUpOVxU8cYZd38qYwXOf0oGQF e+KUHj2p+V24xSKBtJNMBh29aO9IAN38qXOH55oFYZIvvioiOlWnVXTIquOG7mkDHY+Wmd+alKEr 3qP1zQO4w9fxpQQRimkc0o460AMkyD1p0ZokG4cURg+hpLcBJF+bFRFsHFTv93OKiHLc0wGn1pzH KYHGaccFT7CgDjjpQIrRHEhFSlm8zHao3+V81OeUzQMbnn6VKSMYqNV4yaQ5x1o0AikqTd8vpUJz uINSHO3NAiInJ6U0jPNPOeaYfuY6HrQAi8H/AOtTmFMVjmpeKBXKr+mKhbrVqTvVZh3oGRmmNUna o29aHuAw0oprdKUUwHYo/CgUppDI2qI1I341ETTEwpynimZ5p60WGSCnCmrUgxSugAVItNHWnr0p AUZctIaRzninvjFFrA91cxwoPmdsVQWsdb4TslSza5KZeU4/CuwsYN8y+grPtoI7eGOJOiLgVswu tpZSXL9EXdTb0M1qzkPHd+ZL+GzU/u4xk/WsywVX1z5iqrEijJ7cVm6leNPftcyEks2eTmt/w94f nvZZL/VI5Y0L/JAybd3uw9Pas76XN7a2Ows9UnuLVk0u2DbePtE/CfgOpqZ9PlubsS3Vw07hB5YJ +RG9l/xqe3t3ZAFAQDj5eOKfqk503SLi4jGJNu1D/tNwK57tmqSRh63r0sUv2OzxNODtZ+oU+gA6 msGS61CJtty7q3XG/H8qsaQoS4k3LiY8Kx6+9Ta/NZGBdPt0W7vdwLyoMiL2B9a1jTVtTGdR30Jt K8QyW83k3OJY1/jA+au70q+gu41kikB3du9ed22mtHGBKMSfxCun0C3+yuOSM9ADUSXLLQuEuaOp 2ckm2NmI/OvOlur6VrqC7ZZYEf8AdOByOeld1c3aW+nyTSHCqveuUZYJ9PE0LAtLyVBzis6r902o lK2lmtriMxnA3gn0/KvSNKuJJoVkdQjH07/hXANZ/uec8eldVpV15tso81U28HB5rnw8tbmldHYq xKVMKybW+hZ1gj3sQOTWqCMelenF3OFoeKWkBpasQnenCkpRQAdaMUfSlpgJQBS96OaAEpaPrRQA lL2paKAEpaPaigBDRilo7UAJj8aWgdaKAG04dKKKACiilxQAn4UUv50ZoASiiigApKWkNACfSjtR RQA002nGm0ANNeWfFIv9uslzx5XT/gTV6ma8t+J4J1C1/wCuX9WpMHszztehxUYZQ2WPWpwMZwao SRt5+M/LVmBZl5IxUZTIJqQR4iUtSf8ALPNILjR8y8n6CggEc9qAvz/KakHOapCY1y0q8emKrhf3 fXBzUxcAYzj2qHdlunWpCw5MDqajlO1SFHWpkXcuTQy44xQMjhO4YPC/WpFwu5gelLFGH6U2YBWH PHfFVbQQyMhZMt0pytuZ8VHjA68GnxD5sj7tT5AAztPfNSxAYUYxTWGTgDpT4ELLluD6UxlgHKqM dKuiEKFyM5qpDGH4z05q6xyq46CkUi5bo+/YFI9KvGHMfzdvSqdiW8wkn5WHHtWkZUEfr60ti0Yt 5CBuZ1+Xtis0oiH5QwJHANb9x8/zD58VSuEDQ7xCWcdcUCZlqOfu/UVM3B246dKd5Ds/yptXrhuK FWQ/JIn3R8p9RRYQ2RZC0hdMFO1VXtoLoqssY292FW4hJ98hlyMHPaljjZSvmeXuHXFIehhyeHY5 D/o1yeCRhxVKbQr2I8J5n+7XWuiliwZvrihUxH5gY/jTC5wj2s8Z+eGRfqhpI3aJs813koSUjZ0x 0qrpdvZPHiaGNwXPJGaAuznon3ruH5VPGece1dBf6fasvl20Cqx+6UGKwJYWglZHQg+9SLWxKrds 09TgfSoE5Hc4pxoJJ92aCPeog3FSg5HWqBCHAHtUfvUnBGKaf0qRjh0oY8U3vimyZxQJFW5ast+W q/dNzVJSvOak1SHW8HmvjOKbcReVJtpyTFHytF3Ms1xuQYXFNeYDYjww9qiJp8f3qRx83WmAz0pR SelLQMcOlKKaO1O6UEsBUi9frUXfrUi8kAH9aEBLVmxna3vIZl/gcN+tVo/m9adjBpvYR7PHMlx5 b9Vdc49q5fT1Oh+JLnTGGIZ/3kJPf0q/4ZuBc6DavuLPGNjH3FN8YWjS2lvqVun760OW29SlQbHQ qd9v838NRmT5dnWqml3y32nQzqeHGT9atFACaljQ5sNDgdfenAFYV/vGow4ztyMiooi5fLN36Ux7 FtT8/TgUh2kse1BZQpqsjDPzGjoGhZ4z7UyQDfuB4oLLj3pjP2xSQ7iMMtStIFC5xSDpkjmklQPG pPDZoAUDjIqF/vfWnxlgWP8AD0FQFycmqdhI4HXW3axcexxWb6Va1FzJqNw7feLmqfHFcM9z6rBq 1NDhS0gx+VGKzsdg7Pv0p8Y5/pTKkj6igbPZvh9F5fhqNv77k11lYPg+LyvC9kD3TNbwr0afwo+O xLvWkxcZo49aKPX1qzAX2pKO4pTRcLB2zRQKKAG/5FLS0hpgGKO9JTulADaMUvakFABRij+LNL2o EIev1pPwpaSgBOKKDR0NAAR+FJR60H3oAQHFFIRzRQI8CtfuLXYeB/8AkZbHH9/+hrj7X/VrXYeB /wDkZLP/AH/6GqMj3YUtNHSnUiwpaKKAAUUZooAKKKKADvRRSUAFFFFACGkPSlNIelAHiHxAcjxp ejHy7Ysf98CuZ79a6bx9k+N74f7MWP8Av2tcuVf0qAGuNxyetNA704+hqTAKrxxQBJ5gRMd6jJBP 1pHTgHPy9KQn7oGfwoAeIx8uetMbC/KO9ODcrmo5TuPB70AQNxLilOdw460MDjk/NThTEBbaOtNY 7qa/ekT73P6UAPY/LjFQfxc96syDioSoxS8hkbdcUDrSE89aX29KAFbpn3pF5oZgRimoaEBLIMDr TIxuBpCcnFInD0rgO2gLTk6baj3/ADn0pedwoAZMv3vlHT8qbE3yAVMxBWo/KAGQMUxMcMYpkh2m lh54ps2QfpSGRnB+buakBGKaU/d5pFPB/wA4oYDzxJx0qFhyaCfm70vVTTEQomacTilUU1s7v0oE Rk5qF8+lSMcGmHkUDIqawpxHHWmmgZGR2pBTjTe9Ah4oNNFOPSkNELVGepp7fWojTQAKkWoxUi0w JF9KeKYKkA70gHL15z+FOY7YmNa+leFdZ1aPzrazZYegll+RW+nrW1J8N9TMLIb6yE2NwHz4+hOK WwWOAduMV0HhS2DXTXDDhflFZ+raHfaPd+Rdou7s0bblP411GkJBZ2abvkU4+bFEpIfKzoIVEkgz 90VX8V332fSRbIzK0ndaW1uYvOVVlV1b7rKcg1y+uyy3mpSzOZPLJ2RD+EAUm76CVlqR6BZLNfC6 mjMir/qh15/vGvRbQEpknJrzmzv5bAAPGSgGMrwRXfaNMZrZX3Zz7VjUTuawasdDEg2CkvrBdQ02 a1lfYsq8MP4T2NTwL8nIqwyjyqaQM8ovbG5sLlra7RRICCHBzkeorQ0yKOz/AHkQ/eEY3/3fpXWX ukxag7i4BfcflK8Mv0NLp3ha3tfmmJlx/f6flVxmZuHUwrcm6ukhQHjlz6V0djBtuy5XtV2HTLe1 H7iPCnsvStS3sAw4UBj0NRyuTNE1FGLq6y3VsttGQrv/ACqitjFp8cVnCB+7GXJ/vGugvbWPTIvO 3l5z0Lc5NYZy7NI/LMetcuKly+71OmjexCzqV2YAJq3pmnzTyb7dMKpxuK8VUiElxdBI0f246V22 m2bW0YM825/QdBUUKdwqysixY2Yt9zsP3h6k96vKD1NNHJ+WpBXqRVlocTHCnDPrTRTqoQuTTg3t TaUdaAHZFKKZilGRRcB3tRSZxRn2pgOooz0ooASlpop1IA6UtH+RSUwCg0CigAooooAO1IDnpS0Y xSAWilxSf56UwFptOoNADaDS0ntQAlGKXFNpIAPFFHeg0wG0lKelJSAY3FeXfFA4vrMZ/wCWQ4/F 69RavLfif/yEbM448r/2ZqOoPZnn5BPAqFguc45q/wAbd3SqcverZghiTb8owxUcABJXP50gwGwP vU9eGyQKBbCum1+KTOM4qfAKrkjrVeVsOVHSmwEwWU/1quo21YLn7vSoP4+etS7DJBknrjikBYnD ZwKcZA4UEUsmFj+XGaLdQGQOvU8U+UfNgd6SKHFuXPAFCsWAOM44quguoKgkLLnhRTN4Rdq96JS8 RyvBph2sM9CRUjsTRsqFmbv0qZAWYbKjhTO1SvB/iqaOLDFc07AiWDKturQiVSqtk7vSqUWxVbjm rluXLIeiigpFqBJY2OSMZOParIU/xOM4ziogVLj/AGqueSgIKHOKlloa9vtjB3cd6qsdgO3049K1 EcbcFA3bBHFU7qErghTtz2FAWKDQeem7oai2hCChxj9KuNGVV+cjHygVVZMjax2YFIRXkbDcjKtS SIwTdhsA4Bp6pLJHtGeOvFMMjzSKjnO0YOaOgDHHnRkAFWC4LA1JbqFhwWLexp0SbZNzDOO1SiP5 eB71XQRWaP5fl2rt5X1qPTFUW5UhWzn61buArc7grAdAOtVrNdibwh+9jNZ+RZblVVePHAHFMv7a OaDDEZY9ccipGbn5+3WmiQDpzjoDVCOZnge3kKN+BqMH5a6p4FmjZXgRlP6Vzl5ZyWknI+XPakRY i3GnA81GOlO9MUySZWNIDk/SmDpxSjrSuMfnFRyPhcU4/pTGGRQ9wRnXf3fTNUz0q9eAZxVN0wvN JGq2GLSVLEQI5Ce44pFTKZpgRipZMlFaou9TL80WPShgQ+lFH6Ud6BgOtO7Uds+tH+elMQVIopgP FP6CkIkQlGz+FPZs80xXHeo9/wA2B0p2A77wJdhre6s2OPmEin8MV2M4SaDYfulSrZ715V4bvDaa xC2flb5Wr1AsTDUamsdjm/C8r2Gp3miyn5Q2+M/59q6w/wCrbjp0rlfEsD281pq1uCGhbEu3uK6C 1u0u7WGWNgY5BmkNCf8ALctzz2p0TYk/xqUD58dVFKY18xewIpDJPvnaccUyRAq4wKRTs4/OnsR+ QoD1IRnij1pVPcCnlT940wIyflHvUkx/dqKSfhV4AphO6M0hgGQx7f4s1VnYRs5x0FTBNp64qnff JaXEvYIab2HH4jzqY755G9WNR/SlpBXDLc+sw6tBCge9AoHXNHeoOgUdKlhzuWohVuyXzLmJf7zg frTQS2PetCi8nQ7OP0iWtIVBaJ5dpEn91AP0qevSitD4qo7ybClpPrS0yQo70Y96SgB3vSCloFAA OlJS5pKYCUUvpR9KAAdMUUDijFACcUvak9ulHSgQdD9aKKO3WgBP1pPxpT0pKAAUGjrzSE0AMJIo p2RRQSeAWn+rWuw8EnHiSx/66f0rkLX/AFa12HggA+JLLIH3/wClW9jNbnuw6UUClqSwpaO1BoAK BRRQAUUUUAFJS0lABRRRQAhpD0pTQelAHiHj0f8AFb3xHHyxf+gCucZmHzYxXTeOxnxnf9fux/8A ota5dskEHNTYGRqrFu9SL6EZFIM96cpxkUgFIB+6KaRsbnpSxkeb84cIc8qMn2/WibHFAdRkuMfX 2qE4yB/SpCgAGe9QyfK39aaE9gcjsajZsL1pzDI4prfdoATGealJyB7VGB8vapAMCgBrfdx3qF25 qYmq8mKQ7DSDnpRn1puc0jHnjFAh/FOUHH0qME45/lU0YGKBjljz14NQsfvCpRIAwpkqjdkUgCNQ eacUx1IqNXwcVI545oAryEg5WpFbKdcU3jPWmsdqcUxIcp+bBqRo8rn0qAHLZqwCNtSURDleaaVP NOP3hSqRmmIi2/LzUbAgVZOOlROKYiNV4psoqRBxTZRQxaFYimnpTz/Oox9KBjGGBUZ9KnccVEwp DIWptPamkVQgFKelIKD6Uh3IWqOpHqPvQgsAqRaZTgKYEq9a1tDthdavawldyl8kVkoK67wJb+br vmbc+XGf1qWCPU9PI2LG38I4X0qy0fzbzjFPsbRPmf8Aiq+bdGi2EVlymlzz/wAe2dt/YoLJiZpR 5ZNcGttN/Z0YeVCgY7UP+eldt45uWub+PT+CsC4OPU1zdzbZaG0tkLsxCKv94+/tSW429Cpa2V7b 266iWX7PcP5aruO8n+9tx0q3dxxXep2OmxbmSEebMx7f5/rXR+MdPbS9D0lEyVh3K7Y6Ngf/AF65 PTZvszSzuS0k33q1juZS2NC6sIef5Yrp9Ai8m0jTHTpWHAspwJkKMeVBHNddpVo5ixsOcc1nK7Zp FWRqQAke2ateXu+UAk1Nb2q+WuDnHtVl5ra1T946r+NVZJBuVIdPbd83Aq1JYhB8x3DsKzZ9dyMQ KPqRVG51O8uB87Y/3BisJ4iEEaRpTkbQvdPiJSVgj+lQzeILeJvLtlLyY43DC1zrAyPuY9Kd5LNt eMfd74rleMm/hN1h4rctSTvcSmWaTcT2NRj53WIdWPYVYg0y7vSu1PLTH3yP5Vv6bpMNmoAy7g5L t1NTSoznK7HOpGKsiPStEjhHmM0xJHQ/L+lbH2dMcbhUqAKuMdKOS/Ir0lTjFWRxubbuESbFxUwp BTq22MxcU4U3tTqYBSikz7Uv8qACloooAO9FHWk6UAGPwpeaP8ijv3oAM+1OBptFADqKb2peaYC8 9sUtJmigBaKKWgBKDx2paKQCUHrS9aKYBRR2o/CgApKXvQaAG0YpcCkoASkpfwpDQA2g9aU02gBj V5Z8Uzi+sT/0z/q9eptXlfxRV31KxjRSzNH0HOfmal2B7M8/Ds3yg1E6kOoyc0ofy245zSSs2N38 VUznQzywJsE058DGOtRq43fNT26bxQgFR+m3vUUvDbjnNWIUTbuzUU+Gb6U7AN+9tbkUwjk07Ozv 1pGXcu8UwG5GelTbc9eB7io0I744qcumOentQHUrTSNGNqKW9qI2246jPapcc5/WkYDGR0qRiMgk HJqMRqq7R2qUK2OOlMXgcj8aLWAtxo5KkfdxTpN6sMZz6023kO3Yp96XcyyA/pTAmCtuGRgVbg64 NU1YyHnoKtKcPhGDUFaF6zhEb7VZm75erALl8A/WmWiNxuIzU9woilAX7vXNTYpEkj7duxuen0ol MxO3JIqHIZ/k69Kk3Op2A+/0oLK00Th928cclaWJImkwzAZHentgcSYLN3qJ4PnHmAj0qfULDolH 2gcfLnvVnxFb2Eclu9mqBynz+WapknALnHNNmVPKIAw59e9AkVOVb5FznrmpeidenekYL5K/Nhwe aGT5MbsqeOO1MkaYjhuSykdR1FEZTyQGH3TwRUkWNmwg/WiSJlkKjBFAyJ2WTI9aYnAw2Bt4p+1V 9d2eKmS2woc8bjnmhgFscZbBwfWoL5A0g2R74z1qZW2E7v0o4ZNyjPtSGYN1phX54TnP8NZ5yvBB FdRtBcY7GqOo6apk+RmLUEOJihulODDP/wBamywvC+2RStR/Si4rFkPQG+tRE+9BbB+lDJKtymZc jpVKZst9Kt3LYU1QNSjfoNzVmIbo6rirluB5VNiK7yOUWM/dQkj5R396Ij82KdOMPUaHBpgDjDU2 pJhyp9RUdCGGelLmk/GimKw7NOzxTBT6QArYbn8qT+LNAwDTc80wsWIXKuGB+YcivX9IukvtIt5+ dzx/N9a8bjPNem+D7gPoKxj70bEdKiRUTanWO4hkt5BlJBtYEdqwPDcrWN/PotwxZo2LQs3da3Bn zec1h+JoZLa4tdYhHzQna/HG31/z60dCup02/llzxTt+7bmqtvNFPbx3MbArIuRVlMGPJ/hpFAcF s9PSnk7z+FI21oxj60kO7zcGpGCoUI9qN3rUzOM49Krsfl96bEhGG5eTwKOq/L2pjs44AyD1p8Q+ TJ60DFIBPX5vSs3XX8rQ5uOoxV8f63P51leLX2aHtB5ZwKUrpGlJXmjz+kpe1J3riZ9XSXui96M9 zR3pccVJsFaehx+bq9mm08yrn86zRXQ+D4fN8R2SnJG/NVFamdd2ptnuScKAPpT6atOP0r0j41hS im80tAgPWjPFHGaX/wDXQAUvSk7Un16UAO7U3GacelN6UAKOlLTRSimAf40DgUo/CkoATtRR3o49 OtABntQaOhpKBCUcYpRj04pDQAUnFHpSUANPXrRTu9FAjwG1/wBWtdj4GP8AxUlnn++f/QTXG2n+ rX6V1/gn/kZLH/rp/SqMlue7jpTqaOlOpFhS0UhOBQAtHek6jIpaACiiigANJS0lABRRRQAhpD0p TSHpQB4p46T/AIrLUDnqI/8A0Wtcy3TkfrXU+OiT4xvuOMR/+gLXLMCZOtQA0+xoz8tG1lYccGnf xcYoARDlcE0xg5f6Upxu4PepSuBu3UAQ7hyrdajwGX6VJJHkkiiEHJB79aAK56Y6U0YyQasSqAe3 FROo3U0IYfagNlelO6dKRU9KT2Bbi8bDn8KqPwcYqcnquagbrQMbtPWkwM81Ifu1GRSCwcYpVOf5 Ux854oTp1ouBN1PNDY75ziow2DQc96AHKMtTpeB0pqfrTpcstAEaj1701zxgYpV5WopAetPQCJdw aro+ZAymqq9M+tWo+F9qQIZ/DT4wMCk704HFAWEYflULA4x1qwcEVWmyKYeYij06U2RKkjOMHvRI QaQioeaZjn0qZsdaibii4Iib07U004n3ppoGRsKjNSNUdNBYaKkZHWJZCjBGJCtjg46/zFR96DQC ImPNM6U49abQACpFpg609aYXJVr0L4cwDN1cN2YJn9a8+SvW/hxaBdFDkD97Izf0qWB39kgMe7PB q1LshiaU8KoyTRboAuAPwrG8YXv2PQZFU4ab92OcfWk9EWeeux1DW5rxskFy5+nYU/wxZfbvE4d/ 9XBmbGOWx0/DNQoHt9NecN80p2gZ9K6LwTavDpct8h8ya6cxiQ9Si+ntnNZxGzevLZriFvtJiEDf wt3rzjXNP0631XzrFBHGW5RG+U/T0r06+tke2Hmvj29a46fRUudWjiVf3aHLGm79ASXUueHdJn1K T7feD5W+7zya7RRb2kG5tiqtZrXENhb7nbbtGFFcrc3E91NJK77dx529KiU1BFxg5m7d+I41LLa5 5/SsZ74lsyuznqOeKqyKxAZE+XOC3pVqEQEhlCy+m7/CuWbnPU6IqMCSG488kQo0hHZR0q5Hb3cr qjL5e7oD1rWsUAgRJEjXK54FaCJFC6/Lk9siiOGjuyZVn0IYdJt4FUvD5hPXdzVlLePd80QAH3cj +lPd5o03smV7A0qRSXLZPyxn7w9a25YrSKM7vdsmt1Zm+UYUelX40702KNY1CgVYWuuEbIxkwC4o FKelAqiAFL2oFHagBaX2pBS0wClFHf2ooAKKKUUAHam0GjtQAD8RS54pPwp2PWgBFNOpmKO1AD+1 FIDRQAUd6WkoAXvS59qKSgBc06m0UAOo603mlzTAWlpKO1AAaKOwooATFJTqbQAlJTqSgBtIaU0h pARtXk/xWH/EysfaLr+LV6w1eU/FUgahY/LuHl8jPu1Jh0Z5zhN3JpZMkkjpSFOgp2OAMGrMNCHG T9KGb5SBUjbscCowMrhhQImiC+Wo3UpUDOaijXYoAPSpEbJLNiqQakckez5j0qRAGgoeVZDimISP lpWC5EF2Nz92pVw3amTjHHPpRAPl+bikC2AyFJiuDtIpH8wJ8i7qed3XNNV2fP8ACtMdgV2Cjkel OXIOMZyKQbR8vWlDY6Yz/KkBNE2x8KB7048nH8VV0YvnirkQ3Ku5l4H40XGEeR8pHWrUBAYrtPB7 VFGv75d4+X1qyFxIWT7ueKB2NK1w0asD+Bqa6bG91A24xVOGQ/Ls7nvVpy3lkn1pMpEcZGB8w9T7 VMhS6ycEK3p3qvNb+d5eCVjP39oqf/UnapAGMYHagaJ3hR41API/lVdyxI3duOakB/dq45PU0yPY 5xu5Y81JRGyfOGjHQetQzI4YZ+lWwFhcoFO2kcfJjI4oaBIold4yqE4P8NSpBi36NnOfrUit5YZU 6E9akjnEsbb+/AFAaFdCgTHTPSpF2SDg/NQIU2gbsEdqWGDc+4A4X3piInh4X5e9SjP2faBRKHdG CpiPnvzUCzEW7RjvQBG+OOBnvTrcp5y7SBz0puODvBOehHak2BWjbcR8pB5pASSkCVsL827qO1RT OP4l56irVvKEOMZz6io7iAMhcDDE0wKc0cV1D5cicj7vFY91pE0X7yIeZH6dxW9DC8iOA25kqVEJ jYHO5T0pA0cXkq2CP0pHYmuo1DT7a4+bAWQddvesW90p7PayvvUjI4pPYXLqYty2eBVXrViVdzZq PyyO1CKuQ4q9B/qeKqOMHFWIG/d0S2AZOveoVFTTNn61CO1C2AlbmH6VBU0ZBO09xURGDimJDe9L SUvpTGFSIM1HUsdJiGEfNR2qRx81NxxTAavWu68Bz/NcW57gPXCjrXReEpvK1mNS2BIpTipZSPSp lQ7dvOeKjntlubVraQZR12sDT+d20HO2nOSCeKks5jw/LLZ3Nxolx96FiYz6iuogwysua5vxNC9t c2us24w0LBJcdx/nity1mSWKOaMgxuu4UDRdiKBcDkjjrSNtFx161CrbTxSZ3SMSaQErOOmKaDuX jtSLg7ic5phO0Ar34p2GOLHbUikBSKr84zTkJzwOlICTHJNc94yfGn26f3n9K6UKflyODXK+NmG6 1j44yamexvhVeqjjzSH8qUimmuNn1UNhR1/Sl6Ug96XvSe5ohQPaux+HsO/xLGcfcRjXHL1rvfhn Fu1mWT+5F/Wqp/GjmxrtQkesCikz6Uua9E+RFzwKUc02nUAHHSik/wA8UueKAFzRQKKACkoH1oPS mA7tRSDtS0AIcUCg0dBQAUnaijt9KACkNA4ooEJ0ooozxQAU3vTucU3mgABoo5HFFAjwG1+4K7Dw QT/wklnyR8+OPpXHWn+rWuu8FHb4kse37z+lUZHvI6UtIOlHNIsWlpKWgAoo7UUAFBoooAKKKKAE ooooAQ0jdKU0h6UAeMeN/wDkcL7j/nn3/wCma1zbIpkOOB2FdN4448YX3HUR/wDoC1zY5H0qAEf+ HtUPG5sdalDEAgn6VDk9cUARsvpUic9/wpkh9O9MV8tkfjQBKD8pHQUik9RxSK2cj9KNwAxQBFJI SxzTVOevWmty2e1OXIbgUAGOf1p4XCn3pSM4I705unSgViuyDrVaQfNVpzgelVWOaEMTotMp55qN vpQArKCPWmcAU4DK8Gmkc0rgID82KnPzL+lQlR2qRPu9aAADgc09j8v/ANam5xURmG7Zn6UIBzcV G2CPrTj83cVHJwOKACNcGrQ4TpVaJ8mrJOUHrQCI2zTh2FGO5pw60ANbp0ODUb4PpUzZJAAqFx69 aLgB9qjfmnjpTGzRYRCxx2qM9KkKHFQmgYxhzTWFPOe1NahAQtTDUh6VEaYDaD0pOaTtQwGH+VM7 04009aAHCnrTB2py9u9DAsJXvPhK0a10Oxi2/MsK5P1Ga8JttrTxhvulwD+de53mtnSraMW0XmZU BMipk+VXKjG51qZx1Arzjx9fSXOqx2MTM3kryAe5rL1b4m6ppd2sK28MrbNx3EjH5Vx0PiO9vtdF 5OqvJJJufFTK8olLRnT6kuWtdPtkeWRsKE/vN6fTNetaZYNZabbwOBujjCHAxg14/Hqn2e+jv2jB ZGV1GcZxXSP8S52iwbYYPfPNRzKI1FyO6urcFiz87RxXP/aYbN5ZHPJ5UVhr8SJSsiNY7u2d1c3q fiSbUN6xwiJWB781MpfymkYdzfub9tTnZt7bf4OeBT4x5mIlHzVlWLA2MC4wzIDx2rR05m87lTgn rWDV3qap2RYuxLGFgSN2bgllHFa2m6T5MX2h2BZh36CtC1ZUiGVBqxNbS3ERVEbkdeldChoc7lqF i6eaqPj0FbwiQjOOR0Nc/aW9np7rcahf2yt/Cm/oa07fxPoVzIY4tShLL6/L/OtYrQls0RACmHy2 PWrCpgcCseTxb4fgPz6tbemFbNUJfiT4UiP/ACEt+P7iZzVaE6nU/wAQGKkA4rgZPjB4SiJ3SXjH /Ygz/Wlh+MnhCT7016n+9bHiqEd/25pvIPtXJwfE/wAIT4/4mpT/AK6QsK0JfHPhiK2E51i3ePP8 ByfypcyK5J9jeo/xrEs/Gfhm/OLfWrQt02u+w/rWykkUyb4ZUdT0ZGBFO6JcWtx4/SlFN5+tGfwo EOp1NFL1pgL2o60UhNACdTRSA+9L+FACilpKWgANFFFABRQKXFACc0UtFABRmkpaAF96KbS0AL/+ qlpKMimAUtJS0AJmlzSdqKAHUlJRSAKSgmjINMBDTTTjTaAGNXknxX/5Cdif+mXX8TXrhryT4s/8 f9jx/wAsv6tUvsHQ89U+ppSMng5qFetSBsd6voYA7fNgcU1l+Uihhk5FSI4YfMDmnuIhXhcUbh0x Vh9gXOO1U2kHy80g6E20Fc8flQuR+FNBGwgdacZPkAx7U7AK/IDOaV22RYUfMRUZc7RgD0oyzNzx xQNMjgQovOSTUhGBjpmnKfl9qTAzyT1pPYATGenzE0kgwOPxpzbd2VNNOMnPQUhhbkscCrpbYoHF RwhScU8jbMScEelA0WVceX7U5DudTjI7Ukbo6bMYq1axgnOAVz6UDRLGVK5xx3FT5IjUkHae1MKh Lj5O/OKnbDjBPNA0TQzHbs6DFRrvLbig2jp71Fj3wo61KbhCFaM74z0NIssHHlkBsfhUcMacMMAn 1qMOHQAHJzTtsjsuwD5e2aQIsBd8+z7zY7CoZ7Vrfr/FU9uXhuN74GfvYFLdFXLMXJXPFGgFWONm jzt3Y6AVFdELGx8vbJ2PTFThmA8rJAaiUeeVViBsHfvQBThG2NGxweuatxOF3cbRUUan5l3BvSpi u+NQvDUBYbFMdsgPK9vpWfICCxGOvSrgDo4/un9KbcxhzuA7UAVg3KoabJulk8vA29vWrCwnHHK4 qtKArA4O4dOaYiS0VxuRgDxxzVhpFO5C3aqsMhWTf8uO+KGOZy/8LUkhk0bvEvAA79KlQszN0/2q ryuyqMDHbFJCx83dkjeKLoCK6dLdXaU44qCyZNUt5sADbGdu6oNetZpo1mhyyjkrnmqek3ToXT7j Yx6VLC5QtLDzT8w+7zg1NHaKSxbGBxVdb0xzupOME1Wa+kR+DkGtE0YtMdqduPM/dJ0HYVRhJH4+ 1dNokMt3N5527B2NU/EVukGptsTYHG7AqZNdDSCdjFlqD3qxJ0qH6UkUwBwwp0o6N61GeKlHzRfS mIh70tFFMAp8fWmU5eO9IGXdodahMZ706GXB+lK8jOadyUi5pekfbd8skvlwxj5m71o2tlb29xDP ZXPmGNwcGmWKO+gzJEcMzc4rNhL2t2oZiNrc1DZokepW2SBMPutVlxuTdiszS7ovatGf4TwfUVpI +QqZ4qEzQjnt0vLOSBgCsi7SDXP+G53tzPpFwf39u/y59K6NztbFcxrqPp+p2+sQD7pCTDHUUxPQ 6TOBuNKmM4zUUE0VxAsqfNG65FOUlG+o4oGSKQoYMaiBy22lPzKD0NAH7zc1NATOh2r2pIuGpc5V fSlThuetD2GtyXfnjtXFeMpC2owr6J/Wuzw2/PQVwfiyTfrZUH7sYFZ1PhOvBK9UwzTaWkrkPp4j h/nijPPSgUvFItCqa9L+F8WReS46AL0rzReor1j4ZoV0q4fs0n9K1or30cGZO1Bnd/yopKdkZ5H1 rtPlwFKPQ02lpgFAo/yKMc0AOHT2pTTc+tKPxxQAdqDR2pKEAopaSge1AC45pD2pcUtMBP6UlLmk NABzR2oHFFACfjSCl6HpQcUCENNPFKRQelACZooHtRQI8Atf9Wtdf4J58S2I/wCmn9K5G0/1a113 gv8A5GSy/wCun9KoyPeB0paQUtIsUUUlFAC0UCigAooooAKDRRQAlFFFACGkPSlNIelAHjPjc/8A FY33/bP/ANAWua3HdgfpXR+Of+Ru1DIH/LP/ANFrXNAHGRUA9wkxuzTF5XBpWzz3qEkjigHuNce1 NT739KcT1Jpowc0BYaSQ/BppJLd6OM5NPxg4HOR2oAjYZ6dqepx15pzptUEdfpTY1459aAJFwTTj 0/GmgEE8VGWxnJFAEUh6jrUP4Vax3qB15/GkBGOvrSMO+Oaft9M0rDFMCJOM5FDKOo5qQjHXnNG3 n0FIZD0/wpy8ipHGQO1RpxQIUjmqcmfO5q+f5VA6g84o6gxoHGDQw9qkA46UmOOKBWIPut0xVleU H+FQMpNW4F+UUAB2j2po6nvTpF7io+1Awz83Slb7vSkXrQRx/KkA0DNNINOU44p2M9KaEVz0PFVX HtVzn0qvIvtQxorkcZoC1IRTaEMruKjxViRahx+FAhgCbW3EhgPlwvU57+nGajPSpSKjNMCE02nH rTTRYYop600dakO3d8m7GB1oFcljr2WFPO021m3rIjQIw59q8ZQ16RoN7Evhe3mkJURBlc54OKyq bGlPc4XxQ+7X7lc/6vCY/wA/Wo9EjP2lpdudvAFUbyc3V5NOesjlq6DQo40tN0i53npj73tV7RIe 5cu3iAVVcs2Pmz/SqonXGOah1C4VrzDHC+w6VHAVeTjlV5rG19Ta9lYtQFiJJc8l/wAqenzS5YgZ HNU47lYkK4z3p9rIZHJI/GlyvVjUtkdTZTo8nlp0Ra6XTYVuNzDsccVx/hUG6kbOMk4rp9Q1a30S 1kitcGc/ffPT/d96lLUcmb76tZafGwdxJOvCxDqa5vUvH9y25LUKF+6fL7f8Crk0S58R3MmEkSCL iRx/Ec9KL+COH9zEuFQ4rphTb3OadRLYjvr66k3O0shVjk55x7ZrFnkkD53HnmtKblAueO9Zd86q +elbckUY88myu8rdXJPuarPOc4WmSSF/pQkZZqltI2hCUhvzNVmGBj1FSw24HPFWVAA6Vzzq22PY wuX82shI0CCpA2OlNpMVzN3PcpYeMFZEu7NaGna7qmlyB7C/uLcjsr8flWaM8UADHJxU3NJUYSVp I72y+LPiS3GLj7Hdrj/lpFtP5rW/a/GWJiq3mjOP7zQy9PwNeR0duK09rNdTknleHl9k94svid4b vJgsl1PZ+88WB+YzXT2euaVf7fseq2c7N0VZl3flXzEDjijdhsjr2I61ccQ1uclTJoP4JH1YS4GS vHrTN+a+btO8Ta1puBaapdxr12+aSv5GvYvCXiW81Xw/b3V4VklYsrsFxkg1tCqpOx5mKy+ph1zP Y7EGnisOy1j7bd3CJCyLbv5ZYnIY4B4/OtRLle/Fap32OGxZ+tLmo1kQ45p2eaYh1FJS0AHalFJQ KAFpaTNFAB2pe1JS0AJS9KKWgBMUGig0AJS0UGmAmf0pc0lJikA6im96OfSgANBozR70ANNJTj0p poAYTXk/xZx9vsPeI/zNesNXkvxX41OxP/TH/wBmak9wezPN2J9KBnb9acDklcU0t2Aqmc5LENzY zUoUBgtVskbT0PSlEp/j/OmMkm56dBVNlyeBmrBbdxnimgKFwKOgCJxml56ZNOBVww6U0ZC4zTEO THekJZmO3mliXj5+tOYbKBpEe/CVG0pLKV6dKkkUke1NOMqmCajUY5l+enFX+bdjb6YpTLyoIqfa DH0qkIiO9V3IfypwZwQT9aACRxwKsQpvXG8A+9A9CWFjj7vXpWpCUhg+YncelUYAobOR8vAqYHPI 5APBNBSNCFA4ye9I33tuelQRNnq+0U9HGcZpMpF1UXYMcr3qtEEXci9FPFS/aFSMqO/FNjP7v3qU UwhhNvkjJyd1WC+FXkKx55pqeZlQR0qR40bknLemaYCxh1wXIb3FWXjEg+6AgGapox7IfoatRHdG 8QYDPvSGiqXEsg2phwfWpIo0klKOQGK5xQiRQSL9Owps6BjujX3JNADZ7eMQZh6g881GgAhLNncO lS7w6qmwD1ZqaqN5O0nIz1pARqD5ZI6ZpkiHO717ipgG9PlHcd6cEC/KRVWEQQkD5Ooaq0sOJcFe e1W1xuztxg8UtyfMxtCjFIEiktsu/cevfmnSxtjA+6veomD5yG3Y7VICWAZmyelAMJl3Qbj1qNRk LztxU8g3oCrYUdqrgcNuPy4pMCUsJE+6px2BqvcWML2xeJAsuc8d6mUfdCbSKsBdp6Daf0oA8+u7 aYXLlYn68/LVJvv816klsvn7tq4I64rlvEukRW/+lRJjnBGODQIm8NTRDMS855+lVvFceLiKUfdZ cVl6O0sFysqMQueR6102r2h1DSy0AyyfMuaQzh36f0qMVJKMHBHTio+1NA9xpp0R5xTKd91hyPwp gDDDYpKkkGVVvwqPtRcSCiiimMkjbDe1P/jNQD6VIp/KkI3NGvVty0bH5XrQj0J9U1m3j3iO3lcB 5SfujvXLB8Hirsd7cxQYWeRc9vas2i1I9A1G70zTPE66dpshktFQR7y2ct9a01IU5zzXk0cziZZN x3A5zXpGlXf2zT4bk43MvzY9aEraFKVzSJJ5z0qve26XlpJDIeJFx9KsZ7jGPpSsm5M9KNBs5zw1 eOsU2m3DAS27fKPat3cT+Fc3rsLaXqlvqsaDy2OyXFdDBIsg3KQysuQaYkTZPXPT1pysTUYH7vB9 aljRVj3t1oHcT5/l5+XNTrw/NMwdq4xxT4/mkHFKwydiRHyK8219/M1u5JOcHFekyng7vrXlupv5 mqXL9cyGs6ux35er1CrSdKKDXKfRxFopBS0ix8fWvZfh9Fs8Mxvj77k143H1r3DwbH5fhiyX1XNb UPiPLzZ/urHQZo70dqXpXafOABSmkpQRQAYopR3oo2AMUvSk7Uf0oBi0nb8KDxzSCgBw6dqXPHpT ee9Lj8qYhaKQdaO9AB26UfjRR0oAO9HWjPrSZ460AKetNNFHegBv+FOpKQ/5wKAFAFFAzRQSfP8A af6ta63wb/yMdjj/AJ6iuStP9WK6/wAF/wDIx2Of+en9KozPeB0paQdKWkWFFFRSXNvEP3k8advm cCgCWioEvbWR9iXMLN6BxmpgQwypBHtQAtLQKO1AAKDRQaAEooooAQ0h6UppD0oA8Y8dYPi69x/d jz/3wtc2vSui8cH/AIq7UOx/d9/+ma1zZ5XFQAd/bPrUTj56emf/AK1DDIJoBblWQgU1l57hcUMP m69KHYtt/lQNIjxkccU6Nv3ijHFOK7VBpIsFj0pCJZiRzSK4HHFNkcbtnaos4JpgWGb0qFuuacD8 me9MXlsGkArNgfLUJyTT2XDHFJj1H1oQ3sNJw2c0jtSuOcVG33qLMQ8nikDf4UIfkoA/GgYSUzrS sctgcU5h8ue1AAvI5xTD1px/1dRnnpR5iH4xTVX5s0Z7VL/D1oHYicYNTRN8gPvzVeXpTonIWhCH yN82KaOelIaMfWiwxQMe9K3rQcjr6U3PHtQIaRTugoWk6GgPUjbrUL9PSp2Hcdqgk5pAtyFvpTMY qWTGaZ3oAhbpUZFTOKjph6kTVE3SpmFQv0oCxEeaZSmkpgKOtPFMFPFAyRfpWlHqcsGg3VksrBZH B2/zrMFLJ/q6TVwTsQIhkkVACSxxgV2qwPaWLKItu393n+lc5oVt9ov9xztjGcjrntW/qzlbVmaT O0cY9aVR2VgiryObuJt9wxHSrNmdkMr7eCMCqEagv8x6mtqZFjs44xwuM0paKxaV2U4dpk3OM+1X oBsWRkAACk1nmVEXGDzVxdxs5gv3iu0fjUTKha50fhtZbfSDNESk2dy57iotV1C3voktvszPcl8r ITyD0/KtrU7eHT7WOBMLshVTgdTjmuc8NWrX/iFmwNsA34NaU4amdSeh2thBbaFoqrJsTYmXY/3u 9cZPfwXEsn2dWYA583PX2Fd1qVtbXlm0M6b0KHA/2vWuHvoI4W8mCMeXGMHaO9bIwkZF3LjvjuTW HNK1xJn+GrN/JvnaHncp5O7j/PSo0gqZzsa0aTkyJIs1cijC4p0cQAyRT/QdK46lS59Fg8Elqxel AowO9L7Vhc9iMEtBOc04DnmgUUrmgdB0oH40p7Ug5oAKXPpxSCnACi6AQfSlo6fhR3pAOTrXp/w4 nnl0q6th80UEu/j3H/1q8wXOa7z4c6gYrq9s93/HxGu1fUg/4GtKbtNHm5nTc6DselaLAYrLe335 naVuO7VqYOKZCuIxxUoHFeij5RiDrSiSRW4NOoxTESLct/EKmWdT7VVxSEUAXwwPQ07NZ4LL0NSL O69eaALg6+lFQLcA9RipRIp6GkA+lptFADqB/nFJ2paAClpKBQACiiigAooo7UAJSUo46nNFACU0 049fw6UUANP6U3NONNIoAaf0ryX4tHGoaePWI/zNessK8m+K+Bf2e7n91x/30aTB7M82MhHFI3Tr zTTgryKEXj9OlMwJCd33qj/iHIxUjDI5qE7c454pgTIoLY4p5jVF3VHHt3DmpXfII7ULYVhq42du acijbzSRYzilB/e49DVoBShK7s4xS/fPNTNt8n61VY7W3L+tAEuVHFRYIl6gLimg4OBznrQMq3z9 +lSCFYLvDDJqVZMjByBTDhdoFPA+TIPOOKYyxFGM7c8UgVsntilgfcfVhUkgJbr8tIfqPjI29fm+ lXoB8tVQqLgDn3qeMsD2wDQNImVGZj3FWXhMabsYzTYmyQT+lX50MlvkN26Ui0UkEZj2shLZp9u8 EpkHzBo+9NwIgucljz1p9ukMIZtmN3elYZMZdwVRwetMXIl3DhvUmiVVDgrzkUFQ6qeeBQNDiZZJ gVb93jkdhTlVd7CNjkjOKjQtHENoPHTFG1yQwHzfypDCNlMyjecp1B6VPNuLHB+Xtik8oYXfwfWr iW6GNstlsUAZsnyrtfd8vIoiIKBNpwe+almRkYCUqY24OKhhB8xuNoB/OgNi3FtEewjoetNfG7oc 4605DuXKL8vemu2IxxmkhkaRLuyAw45qu5DTFM8fWroTCnBqpKuTuZgCKb2JKpRcnadq9+etORMx hg2Mc49adLGMA7sZ/WpHTKBoxwBQkBC9wEbBQDioZlBYc4LCpZl3jJH3R2pHyfLLDj+dAiPaUTIN T7y0YPTjmkd0kZfkG0DAA705Y0EKgDFIZNbu0kqp/COahvEW4MkDpuix6U6DCzKzt14qxLHvbfgg p29aBnGNbrZTtEBxn5citXSLxhI0DgsDyoqTWLQ3I8+NMMgzx3FYdjqTQXqmWIhDx0pWYiv4msYb LUB5LZEi7iMfdNYbbQq7c5x82a2vE0hfVPvZAQYrDNUJCUopKXn1pjJE+ZCtRmnRnDUOMNSEN6Ud veijtTASnUneigCSP7wBq0+MVUTg5qcNxSAb0rt/B7SHT5tx/d+Z8ufpzXIQ28lxMkcalmc4Feoa XYR2VjDbL/AvzH1PepZUdyZMbcVKGXy+oPpTCy+YwHYVEp+b2qTUh1K1iv7KS2kB2uvX0PY1jeF7 pzFLYz8TW5wAeuK6JsZXFcvrQbSNfg1SIfu5Pklx60+hOx0zcUqsf+A05NkkKupznkfSmSZ2rtFC GWYvm4qwihUzUESuFU+lWd3GMYzSGRSsTGzegryu4O64lb1c16fdsYrWcngbDj8q8tOTz6nrWVU9 PLl77G96SlNH+elcx762Fo/Sk70oqSiWMfMMc173oEXk6FZR+kQrwi1G+dF9WFfQdoojtIUB+6gH 6V1YdanjZxL3YonH86WkHpS10nhAPWj3pR0/SlP6UAH+cUUfriihAHtTqaKWmAnagdKKPzpgO7Un f2opRQACk/SloH9KAEoxS0lAg4pDQP0o60AFJ70tFACYpDS855oNAAMYopKKBHz/AGv+rFdZ4O/5 GKx/66iuUtP9Wv0rq/B+f+EhscdfNHaqMj3ouqJudgo96i3zTHEamNP77j5j9B2/H8qWO3UOJXJk kxwxH3f930qekWQm3jY/ODJ7OcjP06VKAAMKAPpS0tACVGYYiQfLXcOhA5FS0d8/rQBCY3XBjc8f wvyD+PWnI+7IIKsOoNSVHIm4bl++v3TQA+lqONxIiuMjI6HtT6ACiiigBDSHpSmkPSgDxbx2APF1 97iP/wBAWuXfJxiun8dc+L77A6eX1/3FrnFIxtqAY1AQOKBnnIqRRjdn1prHqKAKrp39e9M2/PU7 HC4qufvbufyoCxKemDxUJXaxwaDIfWlPIBzS1Aaoprcc1JjC037zc0AIuMcUqZ/GnAHOOD7U5evI oAaycjmmsMUsjYbNJ154oGV3zuppHrUkhAamEjFAhRkc9qkwCvGKhDH8KlU4WgZERg04n5fr0pr5 3Zpeqc0eQCdV9qbjH505cdaduG4CmIaaAcNipNuaibhqQxGAY0KADSGkU8/jQA88igCl/KjtQKw4 DIzRjFCnB5p3X6ULYCAjikBIHNSEfWkK8fyoCxGahIycZqc9KjIHr3pXCxXk/rUbdKmdeT0qFvSm FxpPFRkfpUh6Uw0bAQye9VnqzJVZ6YEJpKU0lMBRUgqMU9elIdh60kp+XFOXion+eTA+lCCx1Xhy zCaeLl2UNI56fex/9eq/iO4UBLdOM/Mw/lW1a24hhiRAdqR/xfw//Xrj9VnNxqEzfwhsDFZ7zLjp BsbZqJLhFI4zzipr64BlwpyO1Ns08u2mnbj+ECqhO5smrtdkXJYcyyf7vOK6TS48zW427v3i8Dvz XO22Vfgda6bSD5NxC+c4dT+tZ1TWkbmvSGeGWTz1SZRnyyOW+lVvAbb769eQncUVR+dTeIo1S/lV eeM49KzvCN29tr4hAAjlOHGM/wD6u1bU/hOepozvNRULablXB7mvP9emjtNNFvGc3UzjYVPI55zX Y+J79LOzCvMEVq84tFa587Vbk53HbEDRfqNR5nYqCyEYUFhnq1PC85A6VIxaWT6008cDmuSpO59B gcLYbRR2pR1rE9yMbAKUUUc0ixaTtRTuaQB2puPw/CnCj+lAISl/GjtR7frQAv1oxSUo60gFX6fh XbfDe0SfxEZnGfIiLLx3PFcSK1/D2ryaNq9veKfkVsSD+8h61UXZ3OfFQlOlKMT6ERfl708Cq9rd Q3FvHJDIrxuuVdehq4oBFektT4tpobt7UYqTaRSbCO1MQ3bS4pwHFHegRHilxTyKMUwI8UYNSYoo AQM4709Zz3FNIpAPrQBYWZSOv4U8NmqZWnAsp4oAuUVVEzD3qQTKeuRQBN3ozTQwPQ07NIAPSikJ ooAKKPyooASiiigBppKU96aaAGt0ryT4tg/b9PwD/qz/ADavW2ryT4tHGoWPH/LL+rUgezPNpA1N WTDDtTnPfNR/w9OabRiiUt83ekMfGaiVtzc9qnH3aYnuRjhcYqQYXJ/OmgnuPyqJpCTjbgUCLiYP 505SqN/SqsLkcGnlf3m7JyfaqQdCxvy3X2qvOAMY60HjoaacN3+ak7DuKnKDPUUpGRknNA5jwB3q KQlDgClsCJVIVR1qdvuAjvUEPzMMjHtVlyo4pghsG4TY/gxyatAnGOvaqsP3jnNX4VwDz8tBS2I1 O7r2q9CuAvGVPeqoEYfAOW9KuW2T8voaQy4ikkbR7danM7eTsAyxpg2Ku7OcVH5o8wkZ5oKADk7+ 3SpIf3o28ggfhUZJJI5qSKUJuz19PWgAX5V2sMNQcqow7HP8NLEfNQlk2vu556iiFC9x5Zzt9aRR PG+OC5XHTmmN1EfDZ561FKAksm5s4OMA5o2zPNEd4jjQZPHJoAmbc/Lk7um2pF3qCpYtxz6UHy/I ZgdxUZNV4on8gMjYZv7xqRkpAaPPG00iCEhSCVbvTItw/d+lPwBLjd15xQCJD/10JHajPGG9KcAr OCc7R0oZD5gYcrTQMVVPl+xqCXG5t1XVZAmRjHTFVZYSxZ2HyjpQBUcERqRjy+471J5vy/L9ygFm ZlVMDPHFCoUi+vWgRGG/dunr0JFIF3RqOv0qULgZpvlhG4OG9KAK5QrJt/u9qepJQ5/KluCu7f3N Rrneq4LA9RikA5Nqn5o/bmtaI5TnAzVJ8FOR/wDWpBLJs3Dr/OgZIR8hBHes/U9Nhu7NkEarJ1DY xWtAPMXaepqvPt6N+VD2A8yvhJ5n73O5eOapV2XifS1VVvI1wknDY7GuPYFSRVEjPSloNIKAFqQ8 oKi71InPFIBlFBHNFMApcUlH50WAkTrTh1xUa1atYhNcRozbVY4J9KljOs8IWIO68lTn7sf9a64P gYHaq1papaRpFGflUcVKB5knFJloD8pBFSEfu89Kjnwm0ZzSo+5FU9M1JQgb5vWq9/aJqFlNbH7z r8pPZu1WjhDnFMU4BYCnpcDI8KXrvaPZXGfOtztweuK3IW52k1y2pEaR4it75MiK5+WX6/55rqIV G/cT24o0BF1BlSadIdoUd6iQ4Xih8uw7UhlbVGP9lzv/ALB/lXmfavQ9fzHotxlj93FeeVhWPWyx bsSik4ornPcQ4Uox2FNFOH0oLL2lR+ZqNug/ikUfrX0DGAEUeleE+GIfP8QWMY7yqa94WurD9TwM 3fvxQ6ig0d66DxwA/DFLSU6mAUUUnGeKAHDpRSD607vQAlA//VS9aaKEDHfpSUlKelMBaTmjFKKB B0pD1oPSloAT15pPSl60n0oAPzoooJ/woAbRS03vQA4GimjPrRQI8BtfuL/Sut8GnHiKx/66iuTt PuCur8H/APIxWP8A11FUZHvY6fhS0g6UtIsWikooAWiiigApKWkPAyaAI4v415+Vz/j/AFqSo4jl N2D8xJqSgAooooAQ0h6UppD0oA8U8cfL4x1Dnj93/wCi1rlZX2cjnJrqvHYJ8X3+P+mf/ota5Vl3 cEflUMCYt8m48e1NYlj6UoA8rB7cUw8txQFxshAXtULYzT2OX9qaeT+NAXK7DnIqRXLKAe3AzThj cRTiuB+tADeSvX9aWIEdaYfSlVjnGOlIdkTdW69Ka+OuaaTz1x2ofIBoQDeG60jcDj1oXJ60jkBq LBcjf6VGRgVI5zUfBoDqNHFKGwcUmDn0pMc/pQHUecMfSpEwQRnmq+eKkQ8ihiADDUhB3ZqZun40 yi4WHbuDUZ55px54pooAYRSAhaeRUDHFAE27j2pS3FRLUg+lAIcfmxTj0/pSCh/Y0XQDO/pUmfl5 pg60ppeYXGuKgOanIqNh2pPcdiseT0prLUrDaaaxHemIrkfWmnpUzHjpULdOlMCtL3qs/SrMlVnA oAjNNp3FN71SAcKetMFSLSYeo4nC1c0G2Nzq0Z2K6x5kYN0wKoSnjFdN4aglhtHuVUfvGwM9wPX2 zR0Bmzqc5jsZXJ2fL8oI5+tefnqa6jxHdMIY4d/zHk+9c3bR+fcohPBPPtWdPqzSeiSLM+YLOOPP X5iKpqNxxU17KJLhiuNo4FMtziTPpWi2I62Jl+Vhj1rYsZiwK+1Yv8VXLV2U9aipG8SqcrSO51iE SR2uoIy+TcINxLZwawNK1K30bXWnmVnXYwG0d+1bmhNHrXhW401Dm6s2LoO5U8/41x+qIFAf+dOm TURseLL+PWbjToYbgZZC8n+wD6/kayri581liiG23iG1B6isq2R5HaTnHc1ooMxE4xipqz6HbgqH M7gDt6cUzrSmkGOlcTPqaNNRiFO70MB2pO/WkbijFOzk00fjSilYLEiFQrZ69qZmg008CgEh3+NJ 2opRTABQaSnGk9wCikFLQAtPU4IpgNOWgD3H4Z3q33hJYHIZ7WVoiPY8j+ddn5KjpxXk3wkv9mpX 1izDbLEJVGe6nB/Q166K76DvA+PzCn7PESQ0bhTt2TyDTqK2OEjePPQ03YfyqbAowfWgLkOKUilf eWHyce1SbRigCGlxUuz2oKUICOmkVJtO6m4OelADcYox7U/FGPagCMik21JijFMCPkU4O4HXNO/l SYoAUT9iKkEinvUJGaTHt0oAs5oqtz604SsKQE9FQiYdxTt4PQ0AONNo7UhPWgBrV5J8WwTqFhx/ yyP/AKEa9aPWvJfi1/yEbDGP9V/VqT3B7Hm4QgUrqNmaR5Nq4HX2pu/PA5p+SMBkeN3bNShvY0hQ 7hzSqrcA9KaBiKu5s809lVgcHkUKCtBzg8UxAMKpwpJNCvyMAio/Mw+BR8x5zQA5jzjFCqc0isxz nFPZjtHAGeppWGICM8GmnBakQHtzUpUbeOGpgCAgg9v5U5juNMUMx+b1qZcYwcAetAbEioM5RuM9 6tMH2K+Pl6VXVtg24HNS78eWA3B7elJlIn2odoAIYVehDoFJHy9zWaxfzFf862YmDw+x4o2KEBVl bbgDPNSbEKrvGVA7VCIwqsGIwamhIdAAD6UDB+cMoK4P500rv4OEbt7VKz7XwV6d6ikl8uNnaJm/ 3RyaQyeKHcOfvZ/OnqGimzQr4g3BHViePapjEAn3sswoYyspWediuFbP8QxmlkifYPMwMe/JFS7I 12NKzMw4HtTHYuykAE5wPYUvUY0PCY/kj4z361MzRbI2HTrxUaRbZWQuhVe46U1owk3zFtrcBu1A hY9u5tw5z1FO2KvHJ9TUQT7OSM7vSpBJuj3H7w7etIaEi5kwM4qwzMF+VeQMYqJAo+ckhs05mJHy 96YDUL7trcN1PvTJWZixDECpAN0jHndjmonQ7uuFoBliA+YoX+Id6WcCNenUYFQRMVcEGrUrq8Oc 80AUV3detNmcj58ZJPPFWE+63zD0qSK3SZc79uBQgKbKjxhmABHNG5cqw+73pzRmOTlh5eMMMUyR FiYKvO7pSAeWZlYfwk5FO8s/KABzTVVwAd2WAxzU6PznGeOfagCS3PloxPbvUEq79zBht71YixLG 27AA9KrsSo8vaTu6UDI5oY7yya3kXIx3/nXFjR4prySxmkEUykhJOzV3ixlOWZfu84rD1rTyYft8 H+viOeOcjvQiZI5HUfD2oaeC7w+ZCP8AlpFyKycV6tpFwupWIlYruHDCszXfCVtdBriyPk3GOV/g b/CqD0PPO9KpxUt1aT2c5huImjkHZhUPG33oFckcDg8YqOng5TFMpAHelpO9HamMctWoxhc1BChL VbQFd2aljO68O6k2oaeUYjzoflb3HY1rRHaSO9efaHqB03Ukk/5Zv8jj+td6CGO5e9SyojnJ9fpU i5RhkUxuHX0qUMDnFBQNznNNj5BFSEfKCeKJFEYXad2RTEZ2uWP9oaZJCv8ArANyfWq3hjURd6es cvM1udj884radDt3YrlpyNE8TRXPItbziQfwqf8APNJgdgpy3yj5adJyOKRisaliflqHzg/Aoe5W pk+KJcaM45+Zlrhzz+Fdh4qfGmxoe8lceetc1Xc9vLV7o2l/Cik/pWJ7CHdB9acM03jrSjrSGdP4 FiMvim0XsMn9K9qXivIfhzFv8SK392JjXr3SuygvdPnc1f763kO7c0c5oo6VvseWHeloGOtL70kA d6PyHtRijGaYCil7Ugpf50AApOnpSDjilFACig4NJ9aOhpiF7cUDpQenSjt0oAPUUmaWkoAKOlBo oATBoxzS0lADaO9KTSUCGnrRRiigDwK1/wBWtdZ4P/5GGx/67DrXJ2v+rWur8H/8jDY/9dhVGS3P fB0paQdKWkWFFFFAC0UUUAFFFFABRRSUAFFFFACGkPSlNIelAHinjsn/AITO/wD+2f8A6LWuW+YZ 711fjpM+Lr71/d/+gLXMyryuKkHuQvuC01SPy9KVsnsaQpg4pMBhIpd2aVuOxph6UARgnzuKfK/p TI/vf4U8j73HWhggTLAY4o2/MT2pqdakzz0/KkNDgo6/pTJeVqQH/CoTyaAEQe1JIDTicUgOeooA iI//AFVET83Aqy44zVVsbjihCHNjHWlUdvWm4JWpUOAKBkZjoVeeasHB703ACUIBHwFqBSPTinvk mmBaAHd8ilx7UmCBzRkZoAVgMdOlQuKnGPeoZFwaQPYSP72MVLj5qii+9UvQ8frTEPBAHSonIJ96 cSfamkc0hiLjvTz0puKcMYoAbnj2pnBP1p5GQcDio+lSwGSr7VAxwasPyBUDj5sVSERvioWPGKla oJKLFFeXrzUB6VK9RHpTQiM0lKabVAOFPWohUg4WiwhDlnwBk9q720tktNPt48/dT5yO5rjtHtxc 6lErBiinc2K63WJFt7JnTA3HCn/Paom9BwV5HL6tObi9kfJ29BVe0GyKabptGB9TUErlmPPWp5/3 NpHF0Z/nb+lUlZWHJ3dyueacp2D61GOvSnHrVNEEgarEZG2qYqZSRCxpSWlhrc3PCOsrpGvRzysV t5P3cvPY/wD162PiHpyWuqQm3CiO8Hmjb0FcJu4rWXVZ7+3SK8laVoE2RM3UL6Vm01qaR952JIjH BBIidWGKAx8sL75qADipK5Zs+hwVFJAev40Dp2pO9KPWsz2EhR0xS8U2l70h2FFOx1puaUUgFpMU v4UlIBaQ0tNNUCHUE5oIwBxQf50gClFJTu9IAz0pRSZ4oHSgDp/Al79i8Y6dIThZHMTf8CGP54r6 DXpXy3BK1vKs0fDxsGX6ivpvT7kXlhb3S8rNEsn5jNdeGluj53OqfvxmWxS0gp1dZ4gUdqKWgQlL iilFACEHHBxSg46/pRijFADuKNoxTaKAFKCmleOlOyaXNAEJWgrUhxTTQAwj0pNtSe1GKAIitIRU pFIRQBHj9aTFSbaQigCEim4qYrTcUXAjywPWl809xTiKYRTAXzFPtXk/xZ51Gwx/zy9Pdq9TYV5X 8Uh/xMLH2iP/AKEalg9mecsM01B7cVMwBJxTAMDpVWMBWzuXtTtpxTXUnHPNCSHbjFAJEhHy5xTQ CalBUqAc0xRz14poRGF2tmpUj+Uso/CorhGA3ocAHmpIXbbz3oCxGV2sabncuFPtSnczZNJsVTuP U9s0DHfcTB7UsQw6lqjXlsk/L6VP/dagCRkxkimA8ZP6VKqlvvHioCjeZjmhjRIG/iJ56VNEAP4+ vaonXayjH51OifpxmkgLMLAhlxkn9KuWzKke0Z61VQFSioRUyxspOAOf0o3KLvyyr04pFYCT5AQo qGKTaCnJ9xUrW0gg8xOgNBSJX2E7s/MD0qwESSPc8oXPTNU4mO1g3G7jmpfL5G0ngflSGPtlMe8N LvVvyFT2021G4A29KjIXyNh79TSQqYSWb5kI6YoGMV3l8wvlSKnU7IB/ePtVWGXdI29iOfyqV5lR BsLHnBFIC3CivG3ALHtSSMSoUqAq1WieRShBA3HHNTDIkG8nB6k0tBjXVCm5Rls8D1pIl2nJHTki ppf9RtUYdW4PtUESySRmXjaDhh60DHRES7hjI6inLwrMBwKj3nayoAMDoKdC2Fx6ikA5SQrMPxqF yrcj8akAbd04pRa5OQ/BqhMZCAM7+KmO3ycE4OeDTURV+834UM25gq/dzQCGLskl2/3RzirRjRAi xYHqvcVBLgTqq/e9qkEpwoO3cOpoDYq3siidGcHAPIxT9wkjjyuFAyMCq+oSi4k2qMY6Y71bt0/0 crszhaQDBJ++JKj5hTDuiJH4UwjhuPmU9Ke0R2h+hPWmBJHxuKjGRzQwyOSQw/WljJVM0illKnGT 71IxSAI9vPNKuPLZWGVPWpYkDStu7cimFEy27pVCOZVhoOu+ltcA9K6YkbVOcqwzWfqWmR31o0Zb EinKP6VS0S/llheyuf8AXQevektxbF/U9Lg1a2MUoAYD5ZMcrXn+raFe6RJi4jJjb7kqj5W/wr0y E5Xd0qyYYbpDFcIkkZX7rjIphY8YTr6UhFejXXgXTZ0aWGaW2bP3VwVrlodA83VJdPebZIoOw4+8 e1AjBNORcn1okjaKV43UqysVYHsakhIWhlIsRR7cU6R91OjcMuOlRPgVImJ2rtvDN8LrTxCf9ZDw fcdq4pDlK0dHvTp+qRyf8s2+Vx7U2C3PQRkuM06NtpPpmmlhhTx9RT+vQ5FSajndcUrYO3YOBULj Hz5/Cnox2k4oAseYWAAFZWs6YdT0qeFCPMUb4+O47fjV/G2Rfepk+WTKimL1Mnw1qH9qaRHC+TLB 8kmevHStUQ4Zs9K5a4zoHizdGSlrfdQOit/+v+ddcqn7Nn+I0tho5Pxe+Ftk9ya5c10fi183VunH yqa5w1y1Xqe/lyXswOKbzmnUlZXPVQopw600U4dh6UXGd/8ADKPOpXMmPuxY/M16n2rzj4Xx/u7+ T3Ra9GHTpXZR+A+YzF3xDFBNA60dqK2OAUCl7+lJ+lLSAPxoBOaB05opgANKfekHSloATv0o7UUU wF5pR1pKWgANHQUdaKBCfSk6U6jrQA1enWloHWkoAD04oNL2pOeuKAEPTOaQ+tO/hpvFACDPrRSg UUCPn+0/1a5rrfB//Iw2P/XUVyVr9wV1vg4/8VDZf9dRVGR70v3adSDp+FLSLCiiigBaKKM0AFFF FABSUtJQAUUUUAIaQ9KWkbpQB4t44yfGl8PaP/0Wtc+y5OcCui8bj/irr88f8s//AEBa5sXBB56e tQFiux2NyKkQBo2NRzMpbP8AIU6I7I2HUUAVmk2kjpzTGfcfY9KdNtH41XwQRg0ASI2D0pSTnFMz 9fypqMS+T60AWIhhjmnYw2SP0oXl+lEnBpDBjx8tN2nPP8qcv3eaGOBQJEcmMDHWmpjPNOHzd6Av GaQxJenFQJH71Kc0nRcelNbAIdvpTB2OBRnP/wBapVTkHrQgBv8AV4HOKQH5eae30xTMY4o3EMfG M0wEZpzEY/Gol9aEMlfrzUQxmntyOe1R9DSAeDimSGnZ4qN+R1o9ACPhuKnPPNQRrgf0qTk01poI cRkZppHpTlNJkY6UhiD7vvQ2Md6AvFQyvtXFAEm/0puNxqCOQk1ZUUmAwioXHPWrJT3qBxjvQFis 9VpOtWJeKqOaYIhao2HFPbrTD0pgRmm0402qEApx6U0Ud/xosB1HhW0/czXDKTuPljHU/SovElz+ 9S2HSPrXR6dbNYaVBC/BRNzf7OefzridRn8+9kkPILGoesxx0jcggg8+eOND8zHnNF64e6fbjaDg Vb05RummHy4XC/U1mt941XULaAn3vpTu9NFOqiQpxIKYLYphpjHng0AgNWLYdarVftcbPrUT+E6M PG8y2o+WlPWkHSnkJsXazF/4gV4H055rgkfWYeFojO9KOlH6Ud6R1oB0pRSU7HPQ0AJxninCkIx6 0VIMWg+3rQOlHagApD0pwpKAAdOaO/FJjjJp2M80aDDFHegCikIO9OA4po9qcPUfhQA9PvV718OL 43vg20DEl4C8Jz7Hj9CK8EXrXq3wi1DK6hpzH7u2dP8A0E/0reg7TPLzanzYe66HqlLSDpxTu1d5 8qApaSnf4UAFAopf8aAEpaKKACj3o+lKKYBRR2opAJRtpaKYDcGk5qSkxSAj4op5ApNnpQA003FO KkfSm555FACYpD7U49KbQA0imkDNOPWkxQBCwryj4r8ahp4H/PE/+hGvWm/lXkvxV51Kx3D/AJZH j8TSYPY85QEr1w1OMnOCvHtQrAjOMUxyd2MdarYwHEljkU1c559aaDzT1IxmkBPjC4zTc7aXPy9K jbk7elUIHc8DtURldXYY+WpQFKncB7ULt2+ppDFhBMWT1xRgAfOafDkpxTnjGeafoBX445HNSRsU bLHIqORMSDAoIO0KaVwtoX4pUY/NwKheUiYbRwf0pIgdmOMU5R85wOvTNNDJJTkfSrNqCId0iZXr VdfmARhk1Zd/Ih2cg5ycChjQ6GRjEshQitC33TQ4IAbsRVVCfmR0XYVyD6U60IVmBfGBxihjWxaE R3YXp7VMWmjGDx7VFB8iklt2eanBM4z0pFbDkMbTc7Tnr7Uy4Hl4wGCEZytRAbGwF3MRxnpmrEty kw8lF2grhvrSYya3SOW0O7Ax19aref8AvsAEgcUqqkUTAZyelV88sQCCPWgDQ2ITk4Gaqv5cO53X 5R0571dhHmIrsM1DIyh8kDcx6daQyNZ0ldQhCDHHtVpJnZtvRenPeqT+WrMiLtY85qzHKGjHbsM9 aVh3HyhQrfMd1RwSBl8peBUbtg5Y45xj1qQM0knzqF4/SgLjvs4V1zIPm/iqMERnA5xVlbWaaMi2 R5F78ZxUUUaiTEjAKOD9aLDuO3MYt39alONq8Zz7UBIxHvb7w+6AaQzJ5O0xHzs8PngCgCOQbRlc EGoxhZNyrhaGJKggexoHCnjrTXmIl+Xe3Paqxdy427Avcd6sfLsXu3eoWiXnDYNICJ0zcKQOntV3 zRGVAzVfncFPbmnM4jkYLkr2NMRC6tuznLHtVpP+Pb5+46VXSdVuFd0+WpVZWZircE/dJoGESgxk MScdKlUN1A/SmyKUjUK33utLE4XKbu1IfQQ7t25TjnpUuzHzMAeaay7JMg846UhlLIRQAeWJJODw K5vWrWXTtQXUrf7p4kC10aMyAg4p72q3ds8Ui5DrigTVyrp1wl3AsiH5W7d6txnL9fl9a5bSZW0v UpNMn+6T+7Ymust1Uhm6Ypghu87cHpmuX8TQtDc2+pxDHlna+P0rp9gZ36jFVdSs0vLOSEnG9MdO 9LoNnDeKbRDcQ6jb8w3S5JHZu9c8OK7HT7f+0tNutImOJosmP6iuPdHR2RxtZTgg9jTIJFbkHNTc MtVVNWYeetIYIcHFTxg5yaRI/m3Hp2p+7CniplIunG7Ny38SyW9jHCI1eRONzHtXSaTfLe2STgDc 3DL6GvOxJt+baCK2vC2rG2uWtJMeVN0/2XoS0G5K52jqcjmpO9RqctzUnB4z9KAHEZZasJkbu2Kr M3K+1TK+VxnrTGZXiOybUdJkRdvmxfvE47jtR4Z1FtQ0yPLHfH8kmf51oSg9q5eBj4f8VmD7tnfc oP7p/wD1/wA6BIh8Vsf7Z2A52pWGc1oa7Iz65PntxWfXHU3PpMCv3aEGaOc0HrRWbPRQopy5zTRU idfagZ6t8M49ukXT4+9MP5V3Qrkfh6m3w0rf3pWNdcK7qXwI+TxjvXkHel9KTvxS1Zyi96BRz9KO lMAoNFH1pAOHY0Gm8U6mAfrQBRR2pgJ1paCOaPpQAd6P0pf8ikoAKKDRzQIKMUe1A54oADTacaaa AEppPpTh0+lIR7flQAmaKaSc0UEnzRFrDxjGzOK7XwDfvc+JrFNuB5wrzb8K774Z/wDI0WOf+eoq iD6YXpS0g6fhS0ihaSlooASlFFAoAKKKDQAUGig0AJRRRQAhpG6UppG6UAeNeNGQ+L9RUqOPL/8A Ra1zpRGUAfpW/wCNgv8Awlt+cfN+7z/3wtYAwE9CagbKzR/PjFRy/L8oJqy2c81RuHbPagRC+4tg gUMNjUDr0xUj/OwPFPyAj2qBmo14k6danbpjNKiA9qQBv2tRjcPpTWTnNGdtL1GSnsP5VETk4NO3 nbTerZoAOAaGbHApW5Gf5VETQGw7qPao5fu8U45xkUHlaAIFyO9WVJKVXC+lPRj92gCWo8ZJ4xT1 +ZuelJ1Y9KEBCevSkz8v40+UYHFR7flyKBAOT1/Smn73epEwVx6dqjbr1pDY6ozjtTs80/bQMRTh aUCmYGKcooEOXJP0pcDpSA4NOByc0eQWFZciqU6H0q6CcVE3LUrAV4ExVgDFNAx2qQdKVmAhxUMg FSmon6UwKM/Xiqbdat3FUzTAjaoz0qRqYelMCJqbTmpneqELV/RbcXOrQIwyoO9s9MCs+ut8IWDM s14R/F5aeh7nNMTNTV7k2+jyNyNw2qCeee9cGTuJrpPFVyBKlqjEhRubPrXOxRl5FAxyaiHcqW1i zKfJ0+NBwZG3GqFXNRcNcbV+6o2iqYqohIkTGee9BoFI3FMkTtTDT+1MoGgHUVpwoVC1nwrukUVs hBjJ4wKwrPQ78DC8xDz+NFBo7Vxn1VNaAaKOtL0oNULRRRjDc5HFIA7fSilpB3pAOpO1ISfSjNFg sOpKfIUMjNEhjQ9FLbsfjTDwKAQooxigHjHr7UUMApfwpB/kUUgAf0p1NpwosA4V1/w5vzZ+MLRd 2FuA0Lcdcjj9RXHDqavaZetYahbXa9YZUk/I1UdHcxxFP2lKUT6cU8U+oreRZYUkX7sihhj0NSiv TPiGhwpRSUopiAUopKWgBaSl60UAFFFFABR0oo4pgFL0oopAFFFFMAooooASgil70lICMoKaYz2N S0hoArsp9PypvNWCKayg0AVzXkvxXP8AxMtPIHSI59uTXrrRivJPisp/tSx6f6k/zNJ7h0Z5vI3f j1pq8ndilkXk0gz+VMwJDGjR5B5qA8Dj9Kk3joBTVBJ/xoGSw/Mu0059uQB1FCDCZoRQW/nVCGsP l5pI9v8A9enyDIAqFlxxQBbWRRgAU13Bkx0zUROAvr3pqnM2c5ApXGTtweuWPSodw34I57VZVAx5 44qNbZmfO7pQBYT5VHPWg7MZZjkdBUcSksTnOKmlTKrtHaq6CQ6IgtgfeqwN0cmWGWqtHlCp61Z5 dVPGaRQ5ZFc4zuY+tLht4XdtYHnHpSwJCZAqh42AyTSTSxJIpUEs5wB3pDLduy7v3mDVrcB80eNu c4qlEBMm9RtxxUqO0SAlMqOKVyhbnLHc8mI8dqVdp2lHD54z3qRonYbgO2CpFLDblIWG0ZI6elAw ZVL7mY4AxwetI0aO2FEmPajy0kLJJkn+HaadsaGNVd2Jb0NJjsTRyEQEJ8yg4Jp3UK2cEe1V0RY/ k+77U5mDrsZtgY7QwoAk2SF9/BB4BI6U4wJt4k+Y9/eo4wfL2edkLyalYwiPzFffz0xSGIIcFsNu kHQ4psUbPsVsZA696csvzbl4LcdadIVDE9W9c0xHY6TCltpyujqytzXHTMst7IyMDHv6jsKsW+q3 FvZPbLJhGOVbuv0plmGjt5kco6yNuUbec/WlcZHjoQR8pyKQnfyw+9zVqSGKO3O1tzntURyduI9v 1oDzQwsscJUnrTVT17U8lJIyONwPelXnnp6cUDGckY9KgYZlzmp2Yxls8HHNZssuZF2g8GnsSyxL Psm3Dk96ladZGjGzHY1mzSKCrZOM1fREe1H/AD0LcN2psSHz8KML0PQCmtuV13rtb0xzVpVwgbJD CoZMtJuYn3qbFDhuK49KVFzIMnDY6VGzFdp6+wpsUjvMfkIHqaALjMu7G3Jx1pBHmLIHJpJ+Xypx upgZ0gVGbP4UXHYeMbee1TQPu2qW46VXWQMuD+VLhkbIHy/yo23GZHiHT/Pt/tEI/wBIgbK7RyR3 q1o1+l7YRtkiRcBx71dK5DZzzXMv/wASDXFl62s55X+7zQTsdbFjc27jNJKQYzxQjxmPKkEHkGm4 wPY0FHI6mG0zxBFfpuWOb7+P1rN8X6b9nvEvol/dXA+Ygcb/AP69dh4h09b7SJAg/eRjeMe1ZtiI vEXhF7N/+PiPhc+o6Ggix553qVG5pskbxSNFIu2RDtZfQ02P71MDQD5xH2FNkYLxSrhRnvVaQ5JN ZLVmzfLEmBQpg1EpKn5TgjoaRMcVGx5rU5z0nR70X+nRzbgZFG2T/erT/h461wHhjUls9QEMjYhn +U+x7V3o9j7VLNYu5Milj83anMv3aiRj09aex4HXikUH/LQ89KyfEentqWlM8a5ubc+ZGf5itVeK T7qseelPoB5xJK81w0kvMh+8TScU6Zt91M395yab2rinufTYNWpoOq4x70n40tJj3qDtQ4DFSIBm o161LF1/HtSKZ7V4KQp4VsxgfMCf1ro+tZHhqLyvDmnr/wBMVrYr0IJcqPj8Q71ZPzCl70mfanVR iHpRRjjrRTAAe2KOhpRzR3ouAoox/wDWoozQAc5o70dqM0AHvRRS0wDp0pKdSUCExxRRRj6UAIKX FFN7etADj1ptFNoAWkPWgDFB7UAHrRTCeaKCT5TFd78N8DxRYbc485RXBLXe/DX/AJGex/66iqIZ 9NL92lpq/dp1IoWjvRRQAUUUCgAooooAKKKKAEooooAKaelOpp6UAeN+NYz/AMJVfyc7SyKDnuI0 /wAa5Y5Jz0rqvGWB4s1Ajv5f/oC1y7/6zI71ACsu5c/1qhOvO0dqvtlVqnNjGaLsCqf5UpYbsHNJ Ie9CYck579MUAPH3Sc02GT5qkIx0/CquCJO4oAsl+cUHkH0pFwBmkJ5oGJ3IpznavWhxhqjfpSAF ftR3qPHfFSBdy0xIBjbTSOcU4rg0JtzzSKG7cHoacF/ee3rQfvEflTkIJOf0oFYRh8+e1BHJyDT9 oIxxTG6sM0gIWOTSH7vbikP3+fypGPy/jTCwgODTW60gBz0p3TtQAJ9KmPAqJMZ7VIORzSAjpR1p H4b2p6jHNNAHSgHJoP3abjjpRYB30ppzmnCmsMtSBDetOpMf5xS1I7AR71C5qZulV3phYpXGKqHr mrUtVz1x0poCE0wjipW6+tMxxTAgao6mcd+ai71aJFFehaHapZ6VAjHJYb29z1/KuJ0u2F3qVvCT hWf5iPSu612aKz0mTy12FgI1AHA9qUtELeRxOp3P2u+mlfPzMcGksQTI0h5Ea5qox3MTV7aINLzz ulb9BS2jYreRQlbdIxpuKQ07tVi8x6nimNTh0pp60tRIaaSlJ5o9qBosWa5mXPatIyZ4H3azrc7W Haradfeuaqepl9rkvSloNFcrPp4bB3pQKQ9qXoKRYvagUdqKAHZz+VAFB2lvlBA46nNHekAn40mK XrS44zRcYZJ5Jz9aM8UUGi4gooo+lIAzzxRxmk9KUdc0xi55pKBR/npQIcKkQ4bmo6cKQH0J4E1E 6l4P0+Vvvxp5L/VDj+WK6ce1ea/CO/8AN0u+sC3zQSiRR7MP8RXpIr0qTvBHxeMp+zryiOpwpKWt DlCigUUALS0lLQAUUd+KKACgUUtABRRS0AFJS0UAJRRRQAUlLRQAlJSmkPFADTSUppKAIzXknxbO NRsP+uRP6mvXGFeSfFvLahY+0R/maT3B7HmudyZ9aiBxkYp5wo/So2HHXmqMbjkwB0zQmAvPaox9 amUcUCFDZHWgOVpH5A2ikQcZJoEPbJ+YdqYTjDelDyBRgc+tP274to4oKI3yyg5z9Kaq4IqRQy4U ngUtxICUAGCKAuW0BZcDnipYjtTDdqo28km3jPNWx83DU7gKhOW2ABTVg8wfJ97FV4iF3A0qzNhh +RpjIo+G3HselW0kjdc/daqy8cn8asR7MFuMg8CpsMlCyKQ6sNoGar2kkbSGRyTJ+lTQF5WYbgqk Y+lTQaUifvk+fHIU96AsLGskaMFwas2YwnmMeScU1WcxMzYZ242jtQm5U24x3oaGmakLlZdrDdu9 am2liMDFV7cD5XGc/wB41O8oRd6jOPSkWiCaD5vkwpDZyB1pr/dO7JIqZpwdp7HrUjp+63gfKe9F gKflBsc4bPJNIJflC43c9MUknmugRMZPp3ogJRWOU3nHPpSAckbuWTaoU/rSqHC7cgLTVfB5OeeC aeMu3PX2FINLEywjChV+bpx3p3khWZGUKR97mowxR1P92hwc7z1xnmmOwLH5syr/AA09pvLdkCjb 2fvUSFWcF+FPFTStD5ygK21VwMDrU3AUE/ietSq6Rk7jlj27CqkUwAw/zSE8H0p7FMDA+bvTGObB fooz3Are+wQJoazAgS9dxPX2rnHcK6qycZqzPLIFWPe3ljleeBQLYq3b5Xa8p3t/CBVVIhs+UH0z Vq62lFJC7h1NNtUP3SflpidrmfdRnyiox+NX7YBYFXGNvFLcxqbhUyDu/IU0qy3DDjJ5GKGJIvb1 8nB+90+lU8/M33s+9TFAj43hsgFsVE52SAn+LgUrlD48Jxu+Yc01WPnfhmkiO12U/SkCFWyQdp70 ATjhWbGaWMN5ZZtzKf0pdv7lX/hJ6Um9sbf4f5UMehGp/e8dKlmUzLw7Jg8YpVxu4+lOlwFVfX0p AiRgvlJt+XHX3qprFjDf6c0T8SDlCPWpXHC8njrSAb22k5GafkwMPQNQlb/QbjKzQ8Ae1dCHDjHS uW1yF7O+XUrcEbTh+K3bKZLy1imjYHePXoaQos0wgEeD0Irj4P8AiR+KGj5FrcnKiuxtRuOJBnb1 rn/FFh59j9ptwDLbv5i8ZOKY2jnPGmnLBqEd9EvyXIO/2cf41yw4avSERPEXhcQsB523GT2cV5xJ G8UjRyKVdThgexpkErzkiowxNR9RQDQkkOTuSZ4pDkClHWg80xdBAcHINeh6BqQv9PVnOZk+WTPr 6152a1tAv/sWoKHYiGT5X/oaTQJno0ZyrVKp4xjrUdqB5fNSk4Py/SpNRww6YHUVDdfu7OZyR8sZ /lTixXoKo65MYtCuH/vLtz6ZpPQ0jqzg05DEZ5p1NjHyU6uOW59LhvgQUUUDrUM60KMVPAMyYVcn 0quKuWS7rmJR/E4H60glse9aUnl6Tap/diQfpV4HntUNuuyCNf7qgVNXpLax8bN3k2FA4o70d6CR f5Ud6B09aSgB3SgHNHvTR+dMB1OpO9L2+lABxRSCl7UWAKPaijpTEO7UnvSUvJoASigCjtQAlJml z6UnU0AH6UlLSUAJzzTafTKAFFFAFFBJ8ojrXd/DY48T2PX/AFwrgx1ru/hv/wAjPYf9dlqiGfTi 9KdSL0paRQtFFHagAopKWgAooFFABRRRQAlFFFACGkbpSmkPSgDxjxqSPF+ofWP/ANFrXNls10vj c/8AFXX3HH7vP/fC1y7jB46GoAJWOOvFUmJPSrjqGi9KgXHTvSW4yoRubBPzUFSjVI/+tz2zTJGz wPWqJH79w96jAy3+NNDVJHjIBpaj0sTIATgU11+b6U7HO4H6UyU8/hTAYW3NximsBnnH4VXXd5jd uanY8DIpDFOM8UoPFMzz0qViNtACMd1RLnJI4oBIPX8qfGBn2pAMBLZpV+8OeKcw+bg0bcOMUWAc TjnPsKjJ9adJwOKiPT1pANbBNMY80HrTSO9MRIMZ4z+NNJpR6UxutIYq08Gm5/Kjqw5oAceeaf24 pmfSmknPWmBJSj6Um7PShsegpAKOB0prUgNBP5UDHDI6Eig9KYDSn2qQEY1VnPp0qdicVUmNNbgV nbNQmpHqOmBGabin0YoGV5M4xUNTyVD3q0QzpPCNu32qa62ZWNdu7+7nv9f8aueLb0GKC1UbcfvC vpWn4dtDaaTbowUGT96Tn19a47WbtrvUZZG/vYH0FS/iCO1ynENzgVc1QqjrAgAVBim6UmbtXK5V OTVe7fzLmR/Vqb1kP7JAOtPb71NT71SMD1qhDaaTxTzTaYhlA60uKTFAEkbfvF+taCHkVmL94Vox 9Qa56qPRwMveJzSig9KB0rjZ9VT2CnfUU3vRRY0HDpRQOlHegBaB9OlJ1pR1qQFoooNAx3am9ulA PrR3oEHalpAKKLAH9KDxR2pe9IAH6UDpQvalpgHbpTh0pvb/AOtSj2oA7r4X6j9j8Vrbk/LdxNF+ I+YfyNe4qcivmfQr46brNjeA/wCpnVz9M8/pX0tGwZQykYPIrswz0aPmc4p2rKfcf2p3am06uk8c Wj+VHaigBaWm0tAC0UlLQAUtJRQAtLSUUAKKKSloASilpKYBSUtJSAPYUlOppoAQ00049KaaAGt0 ryH4tll1KxI7w46e5r1015J8WedTsRx/qe/+8aQPZnmhzs5FMPbipn7DtUAfPTPFUzAYVPWiGT5T kcGnKVK/MKhcFRxmkUWF70SNtjzTYz8nfio5cnrTZK3FXBXcPyqzFJheMbjVVflj96njXCZz81Ip iMZPv+9PVRJ94YPekY9ML1qaGP8ADnvTsSPtvvBelWVQq7A8gGq65znOMVYRiRmmA1o9knBzTScN xjaadufexA7U3H7ney/MKCh/yDdyCfSpUj+VZunpVaAAtknGauBTkIj8ZzSGKqq6g8g57VIjypud mJUfwg0bvLBReQaljAiCs/O7+GgC7bojoGXGGGajygkZHzuPIprl4rdVhjCjPUU3qY38z5icN70D JRKPLx5jgHgle1LlgrESDyB1OarqyZZ8fKpxgCpYZI2yG+70Ix1qSx5k+b1XGauQb2HzH92Rkc1T mU/K6RsF7cdBRBuReHZ+aALO3DMyHC1BEsKSbQfvdc+tSPnLYJ5qFiqPkAkUWAsmKNZM8FxwOeKf NE/mDylGQOeahkwu19pGKRvM3ebGd3HIoAegkJZW++P1oViSN/zY4HNRs+9QrZznnFLDEQ7B8YHQ CkMlUjzMlcbTkDtTrV2EkjEA5OelRrbENy2cn1qSJ1GVXr3zRcCxf+WAhjUfNySo61XSPdHuXPXp TXlecKv3Cvt1qYYCgLwaAEKR7kEuSBnKjrT5djRKgBPPy7qk/d7cniQd/wC9TnVJnUswVcUDM2+t y8Sx7sMpzkCnJK0cSjA29DxVhflfbnOOtSGONIt8f3SaYrakLYRmVcN6NjrTWTMu9iQR29adLvKj A+hxVcSS9W65xmgCwIsxvIW21XGWH0qeJWfzFf0zS24QK6sOtICuFZV83K8HoasPIrwofwxUUmVG 3+70qRcSRfcwB196Bjg2FMfXaKY2cYyakix5rZ6dqGGXZscegoYDQ5QgjoRQSWOHOBjrShFxnJFN P3+QTQBM+FjULzxyahVjnFSbgcAUNy3QDAosAk9sksOx1DIww1c3pcr6RqzafIx8lzmNjXTswaID HNZGr2JvbAui/wCkQnehHWkKxstcFYdsRw0hAzUssamMoe4x9axdCv0vrNdx/fR/KwNbKtuG3FMZ yukyHRtcuNMfPlSfNEayPF2ltFdfb40/dzHD47NW54ttWWK3v4gRJAdrY9Cf8atMIda0JVYDbMn/ AHy3/wCugk8ypKluIJLa4khlXa6NtYVFTYDlNBpo60/tTEIelKnWkoFFgPRvC1/9u03Y77poflb3 9DW2/C56815t4f1VtM1SOTJ8l/klHtXpYIaPrnIzUNGsXoRcj5uxrH8UzY0XZ3ZwOtbbH93tA61z XjCTFraQ8cuTUvY0p/GjmV+6KdQPu0VxSPp6PwoTvS9xR3oHapOlCitPRY/M1azQ95k/nWavX2rd 8Jxed4ksEI/5ag01uTWdoNnuK8DA/Cnc/wCRTV9qkr0T45idTml70lLxTsIdxR0pPpQORSAKSnHp xSdvrTAXpSnr60gpaACl7U2nCmAUfhS0maBAcY9KOlFFAwoPWlpvWgQmKO9FA6UAHekpaToaAEpp 604mk9KACimnrRQSfKS13Xw2/wCRmsf+uy1w6Kzbtqs20ZOB0Fdt8OzjxNY4/wCe6dveqIZ9QL93 8KWmr90U6kUL2oNJRQAtFJSigApKWigBKWikoAKKKKAENIelKaD0oA8Z8a8eL9QJ6Hy//Ra1zMnK /KMYrp/HCj/hLL4n/pn/AOgLXLnnp0qBvciZuB2qHBJY4/KptoLEMOnWmjOWA7UAU5eWpuCOD36V I/B9ajlk2mmhMFxnpmnbT96olYdRVlm+XgUMSJIwDHio5On6VIuChqNunWk9hrcqgUdeKl2gcdqh 53UAKvSpG+71pvO3cKcvKc0hsjD9vSpEx2qFutPQ4aizET4y3BpG/L8KQH5qDIM4NIpA2G61G4GM UobNEgJXNAMrNgGlGDUT7t2MZojY5+tMRMcd6a3NMLc07kjpSuGwhHy0KecUrDIpFXmgGOz705QD UdCsaLgSdOlGTThn3ppHFAeYhHtS7cr1o/zinDhcYoGNQce1BxThkimmpB7Eb428HFUZTg9atSNx zVNzk0xELVGe9SNio+9BViOndqDSdqYEUo4pbC1N9qEFsoJ8xwOOtNmPGK3PCFh9ovJ7ntAnH1ar iZzOm1TfZ6TM4wNibFOep6cewrzpjubJrsvFk7R2kMO84YlmA6cVxijLUo6jasrGla4g02WUnDOd oFZjHLZrQv2EdtDCvZctx3NZtEe43tYtWkYkZgWA4omwG2+lQoxBBFOGTyasl7id6FGaWp0T5aTY 0QbKBGT0FWvLpyoAGbHQUuYLGeBl8VoJ0UVTjHzs3pVqFt/NZ1DrwkrTLXagdM0n8NKOlcTR9ZRd 4hSikzSj6VJuLR3o69qD1oQIPwpwHem96UfzpAxRQaB0opAL2pB0o7d6OtMA7UHrSdqXk9KAG0d6 KBTGOBpe3WkH9KcenFJiAdOtHagUCgCRea+jfCeorqfhjTrkHLGBUf8A3l4P8q+cF7V7L8JdQ87R LuxJ5t5t6j0Vv/rg1vh3adjyM4pc1FS7HowpaaKdXcfMDu1FAooAKWiigBaP60dfpRQAUfhRS0AF HaiigAoopaAEooooAKPzopO9MA/CkpaQ0gENNNONNNADTXkPxa41OxP/AEw/9mavXWryD4wf8hHT /wDrl/VqTDozzdm3dKQH2qIn5aVJcqOKswHMSG6cUzJxgHvQ7c0FD5fWkA/eFPrTJVyw9KjzUhI6 Z60DsRjJbGc47VbUjHaqykAZApwZs0AywygEEnBzxUisw2g1Hw20GrEKI8uPShAWFhLLuHHFJGCH +YHJqwT5abh06VHIDtDDvVAK4JRlVcU0IyR4b7ppyZPy5JY06eMAMGJ5HQUaD6FULhuRke1WU+9x 971qKMjO0HC1IGDcAcjvQBKplztZVLE9jUu3LDBPHWmRzZj2bQGzkHFWArFNwAPNShslDxCLZJ93 PWiNUTfsUn+6MVGiiU4PFTRqCzecdrKcLg9aChtr8jsc7STxUywhVPyYXqXqPYrXGfQdqc0LOxfc TGOoqbDQ6NZJvllbZj7gz19zU9ouAqb1znkZpgVEbAJ+brTkXymJ6+hPWmMdd7VkG3kmoVRDcIiS HzB8zjFJJuOHLZz2xTkDxjzN2Dj86QdRC7eayyPlSMBRSxsY0YffI4qPaC/Kq5J4JqdEMcRU456m gByQh1yVPPakm3Rzle3fNPS5O3Z/GOKZNM7TDzU+Zf7tAD4S0S7mxj+EU1H8xmZsbSeMdakkdTHu OAoHftUMBUFtv8Q+XNIaJ04ZgmCvcmnwozEY+YjmquWikwX3L3AqZHxMCnQ9RQMnjG6Vs9h3pIkA +cruUcCoZpJN5CLx396svsW1UDIY9cUAQszCVptnsKlDKyKCcc8mmqqsuCc5FR7eGyOR1xTEiwu2 VthPyryKqzwOgyAQCc05G2Y96dLK4Xb2pFEdo2yR9+Tuok3iTcq8U9xjDDAOKYN8hwzYxQJkM0hZ cd6dGSkOGGS3YU8RK8m4H6A0rRBE6n8aNQBPl/h+btgVIh+978UyJW2SNnpTeW60WGPlbHA7daaH XApz8/KBzikEQIJ9BQIiDnzMD1qcvsi24+9USH5evPSpc4XZxz3pghinI296csOCCadFjzAFUjFW A3Q0gOVvom8P62t4in7LOfnA7GuiiuAWjkByrDII7io9Rt4tRtWt5ej9D6GsPQ7qWG4k0q4OZIfu MO4oEbt8q3KyQuo2OuOlcx4fnezvJ9Ln6q3yn1rpz0z3rm/Eds1vJDqUPDRsA+O/pSY2VPF+lHau owr/ALMvHPsa488V6kkkeqacCyZjmXDCvOdUsX07UZrV+djfKf7w7GrRPXQpU5aSgcUAOoFB6UUx C9K7/wAJ6t9q0/7HISZoRgc9Urz81f0fUH03UorlOi8OPVe9SxxPUVx37Vyfi8/6XaJ/sMf1rrI5 UeNXXmNvmB9RXHeLG3apbjHSL+tZz+E6qC99GR/DRR9Kc33uBXEz6WlsMNGKUjpQaR0xHL0rqPAk fmeKbQH+Hc3/AI7XLDtXY/DxA3iVW/uxORTh8SMcW7UZPyPXh0GOacKaPSlGTXoWPkReMfyp3emn ijNADqd2ptHagApaT2oPFMBenelFN4606gA70v0pKBmmApPFGMUlLQIWgnFA96THvQMU0h/KijvQ AlB4FAoPNAgzTaD6UUCCgmimk80AKOlFIp4/GigR8orXc/Dr/kZrHj/lsv8AOuGHWu3+Hhx4lsOv +vT+dUQz6fT7op9NT7o+lOpFC0UlLQACiiigAo7UUUAFJRRQAUUUUAFNPSlNB6UAeMeOjnxXfcnj y/8A0Ba5ofd+bNdJ46BHi2+IAI/d/wDota5lwajyAa5+bI71Ex61IRu4HaonbaMFaBlNi24jFQvl m5OcVYbjJ71F5ZI3gd+KEIRBkdcVYT7uKropVqmU4bBqhEo4GRTWOeKk5UVA55qeo1sJ0/Omtycf jR1NJnnk0DHYwCKjJIHFTcU18AUgIT1wacvFRsct/KnhvajoMk6+2KYRzmnb8Cm780WFcOMe9SEj Gc9aiXninHv9aBlYjLU3HHFStgNSYFIRGV5zT1Hbil6fSkU96BisaExjpQRx6UwHtSEPxTAMNTxg 8UFeaYD0NP4zUKcnmpjSAQjPTimNmpRjbTCKGNDR1peAKAKY2eakZXnIxxVNvWrMzZGKrNVisQtT acaSgaG000tNY4UmkBXkbL13nhqza10WGQ/K0+XYHsO341wtpA91dxQJ96RwPpXp8whs7UhHyip8 me/vWj0iZtXlY4bxLP5mpMoclF4Az0rOsITPdIgGeefpTb2UzXUjnu1XdPHkWtxcbei7VbHc0tol 7yKd7L5twx96q05+WoAqkiXuKKk/hpo6UZpiHxrucCrgXAqvaj5i1WqhlLYbTpfltGbpk4+tIaiv mYRxx9hzSGytgrb7sfeOKktvu/jUtyuywhTd1O6nRJiD6c0pbGlJ2kTLQKRDxS9K45o+qwc7wF70 opO9KM9Oag7hw5FJ3FL2pPxpAhwpR1pvT6Uo70rDAUe1LSUAOHfk+1JS9utJQJBR+lHalNACGlpM dKKQBinDjr0po6+1O7UAxBS9qXH4UgHFO4DgePQV3/wpvlt/Es1uzYFzAQB6spz/ACzXn4rY8Nag NM8R6feMcLFMu7/dPB/nVRdpXOfF0/aUZRR9JjpThUaEEVJXpnxTQ6iiigQtLSUtAAOtFFFABRRS 0AIKWiigApaSloAKSiigApKWkNAB7UlL1ppoADTaU9KQ0ANavH/i/wA6hp/H/LI4P/AjXsDdK8h+ MIb7Zp7BW27MFtvygktjn8D+VJg9jy8cvt/nTWPPFOcAHgg01XIQpn5SckUzKwzduk96nJby8Y6V XAAkyKkRs/LmgRGmd3Xg1IRwRTT1X0qQ8d6ENiBBnNG8bxjpSh8IQKbjLDFP0EWgQV3Y+UVJbzL5 o2j9KjBHl4FEXynHT0NMRqFz9VI6USBWTCnnNUxKzFV3ZWrEUkce7ejMxpjuWY7fYvH51B5gMu0t nbUy3Jjt23Asx9O1V1kTyuODnBoGKy5bKqBn0oBy3TnpU4T5QOlPjtjGy9Wz1z2o6gRQbNzbuo6V ZaZnChSB9BUU8QWThvwoRXjj30hlq3lDYUv83Spi0CRMrx7SvzFh1NUVDL8+MZ6EVchUMGLMW4/K pKHJPHKoeAfK/c0ecYC3AYEVGipFwjAR9ueacNhXqdp4zQBJb3X+kq+Fwq5IbvQvMkjNlvM6cdKF TzGRVhwVPDZ6irB+VAEGNp+bNAwWBAiyfMeMY9KcsSvC7546c1Gjh5mLdG5NSKd6yKygKPu80hlG OQrNj+EgjNWUb90yg9+9RGMKd275TQ3yoWV8ewpiRNFIsR3EbxnkVIZWlbcqFVYfjUQjRhGS2wdc etOLuH+6AinIx/WkMfujKsp+bHt0qOMM10nuakLwm3bywNzGooHwcOQdvH1oA0L6BYn2qN27JHFR RSxqiLIuSPQVYmY+Wrtll2YHqKppkLszkA56dKBkySCdlTp6YqO4Z87SenTFC5RlZMcU3cZG6ikA 5HK7Uxye9WAGG87cDoTQirjLAZNNkcEcn5e1BRCQm1WZO/FSbuVwRgrg1GxBX5R0pCflVQR60CFZ WlbHQDrR90+wojMmGYN0707zAdxZM8UAIsZYF1ToKY24xpk5K1MkjovTg00/eDMOPSiwMcsfyZY8 55FNVQ3OcDNSZZj6UKNkTHg5OBihDHlQW4btihtjIwVsN3qtMwitZZBncik4qvYTSSafG8jb5GHz ce9F9bFcj5eYsfKrbRQP3g44HrTUbpuXmpj8p9AaZmEeQ3P0qbgI2eBioRw+asSMCiqF69aQ/Qp5 3Vg6/bPG8eo2/EkWN+OpFbxDCTgEUMivu8xdykYI9aQMp2V4t3bRzoev3gexp97Al3ayQv8AdZcf jWJbN/YeqNaOf9Gm5Q+ldAiAqWJzxTEYHhe5MM02nXB+dGyoz+dO8X6b9rtFu4lzJAPmx3T/AOtV bV7d9P1CHVYR8ofEgFdHHKl1bRyr80Mi+nUUAeUGg9K1Nc0z+zNQZE/1L/NH9PSsvFO4kGeKM0h4 padwHZp8chQHgFT14qOpY7ho7eWAJERKVJZowWXGfut1XrzjrQKx23hTVhcWh0/nzIhmPd3X0/Cs 3xC5n1s7Ubckaow61ztldy2V3HcQnDoc/X2rTvrtLzVZrmLIV8Yz1HArKp8J14V++PjA6EqhwTlh nt0/Go6O1FcbPpKQucUnejpSdqlnVEetd58NIs6tcy90hxj6muDXrXo3wyX59QYeiDp9aumveRyY 92w8j0cUpNJS13HyzF60v4UgFFAD6KaO9Op+YB3yKBQPxo7UC2FFBoFHf+lAxaM+lJzRTAd26UlH 40UCAUDijvRQMX60lJS0CCg000ZOBQAHrkUGimnGfSgQvak9B/KjpScUABxmikyBRQI+UxXbfD3/ AJGWx6D9+mPzFcSK7b4ef8jLp+e06fzFUQz6gT7o9MU+mp91adSKFooo70AFAoo70AFFFFABR2oo 70AJRRRQAhoPSlpjkhTgZNAHi/jw/wDFYagAf4Y+P+ALXN7m24Irc8c7z42vwT2i7f8ATNaw3T7p HUdah7jBMA1DcJkMQPypX45HakE6mPae1AiqykfTHpTUbHydu1Tkh0zjkVAQO1ACHl+aD1zQG3cY /Wjtg4OKpCZaBMkQ+b5hUSp95npUbHFIZD82KQyEj5uKgcHzOankJAqP73fmgA3cc0pIZaaMd6Ug CkBXP3qmGNtN2ZNO4A60hhUZJA/GndjzRtBXrQFhqP61M+du7NQY59qlbp7UAVmclqcDx70/YD0F GwAYoAaDk03+LGKkxxmm7cNmgGPHQ5qMnnjpUnBGKiYc/SkwHDGPwo3AGmjPelP1oQCofm5NWBx1 qr39amU5Ao0DUkJozxxUf1NOz8tACjpz2qKZuDUpPFVZmwKkZUkNQk096iaqsgW42m9zQaKBiVFO cR49alqpOcvj0oW4mdB4Nso59UaeZWMcKHaB3c9K3/EV2IbFthG5u5pPCtl9l0LfKDvnYtx/COw+ tYfiq733XlL91eMU572Jh1Zzn3mFadyTDpUUXTed+PWs+3QvKqjqTxVzV5Va58tPuxjaKcuiKjs2 Z3enjpUdSKOKuxA7Hy00ZpzHjFIg3MBQJF2FNsY96kpSMKB6UnSsi0Ki7pFX1NQXg333lryAcDFX LfiTfg/KKowbXuJJGbG3ke9NAx0/7y4VfSrCgdOlV4fnlZzVipfYqOg1OM1IBkU0jD9ODTgcf/qr mmj6HAVNLCH0pRSZzS1kz2UGOKUfnSCnEFW2kEMOMGkUC04d6aKcKQmN7UopaBRcYD/9VHb2pTjP FFIQh6elHOKD70pFADaXPNNxTgB/9amMO1KDSYopCHDr0oFIKXk9zxRcBRT064zimClXrQB9K+Gr 3+0PDun3ZYMZIFLEeuMGteuC+Fd+LjwsbYt89rMykezcj+td6K9Om7xR8Riafs6so9haUUnalFWY C0UlL1oAWiiigBaSilxQAUUUtACUpoooASj+VFKaAE7ikpaKAEpP60tIelACHpTacabQA1q8h+L5 U3dgm2TzNuQwYbQPn6jr/n3r15q8h+Lp239gf+mX9WpA9jy84y3949KEUn8ac3QHqaG7MDTMQaNV b361G4z2/KnZLde1GOpx2oBWI8bRnmnRYZuT0OaaygNkgj61IBj58DHShDFIUNgE0sQJb+dReYWb nHWpWdjwopiHYXDAde9OiY56A5qFFO9WOMVKBsOcZ7UBZFiGE7s+/StAbGUblx2qhFJtHTJqcvuA 4+tNbALJHLtyjfKfemAYXBHIq7AAY8HvTngjEZO75vWmMZJKRGiryR6VP5z7d7FelQW6ABsj5etM yT9/ikBPGryEt/DU4DbVTA2k81SRm3+XnC9quyDbGoz83rQNE0kcUWF3fnTLedIpWXywm84z1zUP zXQUFgNox9aUHamzglfzpDLAt1aVi6jj+6ajOVlG0cDqKUXEcSmQ7sgc0gfzoPtONu7ke9LoMuW2 9vnzzj8qkuXijjESDcx+9z0qlFNsIOeT+NWUjUyZbk4xQMEUDGBlsciplYZVJOF7gVVLlLrAfHsB TVZgxfByTx60gJruJUHyEn2ptu6zJtBXd346UTTyiAlUDSHpuqONNr/MevVc0DJZMPty/wB2oY2k YurjKjke9TrbMCGLdemelSQR7X527j6d6AI0Vwu5lz6UsNuPOeQ4GOnvUjulqWU5+UfnQs/3vlGB +lAyz9rAQByvH6VTM37wgVDdozfNnlqsW6bsE42+lICZIpfKbceO4BpqxFV3kEZ6VI5MY2DgY70h m3p5bdulMCXePLGVz/SowhMTc59KsYAg2DBamIDCyt2PrRsMrBmRvLx168VNFGhDE/N7VLIhYtlQ D61AjGNyhHJpBoOiRPs7bFPXgVDk78EH61dgOIz6etV25JPXmgAfjaccUxjtk/2atRIZU2lfpULK A3PPagBoZtvFNjHOxn4qVuOD+lMSMs7E8Y6UxCzjMEi4zlaZFGiRoiqFVVq1JGNvynJ6GojtVCp+ 9SsXfSxD95t2PlqdYtyZBzTY0+VvSn7hCmz73pijYkiO5Xx6e1SJIN/zdKYGLD6VGuSelAyaTmUH 16Ux878ChtxUc80cEc9RQBka1pxvbV2jGbiL5o/6ik0K/N7Y/OcyR/K9a685JGK5q8jfQtVW7j3G 1n/1g/u0WJ2Nq9t4ry2kt3AIdePY9qxfDV24SbT5ziSE/Kp/Wugi2uiyJyrDKt61zeso+m63DqcQ IjkOJfr/APXFHmI0dc05NS0xlVf36fPGcd/T8a86OfQj8K9WjZZY0dWyrDIIrh/FGlGzvftMQ/cz HJ4+63pTuBz5pKUikpgLR3opKNAFq5a5qnV226VnV+E6cL/ELoNApo60veuJn0dIWk70tJUs64j1 +9XqHwzjxYX0mPvSKM/hXmCda9Z+HKbdAkbH3pj/ACFaUV75w5m7UGdkDmnL/XpTacPeu0+aAHvS nrTR1pcUwHA0DnpQu7GQOntQM+lAC/hSUUUAOGOaO9NHAp3T8aAFpPpSCkpiHUtJnigGgBeneij9 aTigBfakzxxRnmkP/wBegBRSZ5pcgU00AOzTTQOlIelAheab3o96KYBgUUZAopCPlMda7T4f5/4S Sw/67px+IrixXa/D3/kZLD/r4T+YqkQz6iT7op1MTOwfSn0ihe1FFFAAKKKKACijtRQAUUUlABRR RQAUh6UtNPSgDxLx3hfHF6fVYs/9+1rBdcoGzitvx9x401A9OI//AEWtYG8tHwelQD3ISeDz9aq3 HDfIeo5qaVst06VXYN5lAElt869elOcgKeP0otiQvl5O3JIX0PH+Ap059vrQBXjwT/8AWpxK7uBU IbBP1o3HPtTAk38gUZwaiP3sVIeG+lFgFcBkz0I7VHjDcd6A+WIpWPFADX55FJ/DjrmjGRUfQ0ug D144pxAzimDrnFA+9QBJ5fDH+EU0g554p/G35eaR+gpDIxTm6cUKvyE+lN2Fl+lADhjHpQV4+tEa 1Iw+X6UAR9OKG6dMU09fSnDkUXAhpcc9aAvJ+tL3pPYBOBS4o7cUZ4pbDY0f1pwxj6Uw1KvSmxIC M0oGKQ9KUnikxjGOKrynIqVzxVaU0kDIWqFsVKeajYVTAiptOIpKBsQn5SarwRNdXccIIDSOF5qS Y7YzWr4Otln1xZXj3rCpfGe/SqgRNnbtJ9ntQioF8tMAen/16831OYz30rZ43cV3XiC8W3smCEgn p2z7158oWSRtzYpR1lce0S7pMa+c0zA7YlLVnzMXlZj3Na0a/ZtHkfcB5zbQPYVjHrTWsmxvSKQC p4++aiSpRxGTVoz1I2zmrFmmZcntVc81fslwmfWhjJ2/nTPwqVqjIrIocf3dhI/qcVRBKW33cFjm r198trbwDgscmqsqg3CxqcqtPoHUkhG2MCpO9GMDFAqCxX/1f0pe2TQehFNXlayqI9LAVLTCl5oI o7Vzvc+mg7oUcdqBxQKXPPpRcsU0tNp4/GpATqKTtTvxpKLgGBS0tIetFwCg9KMUGkAUfpTc4NA/ zzTsAZpRQMUn8qYDs0ufWkoqQHUoNNFKO1Aj0b4TX/ka/c2ZJ23MGQP9pT/gTXs46V85eD737B4q 024LbVE4Vvo3yn+dfRi9K7cM/dsfMZvT5a/N3HilFNHSnCuk8gPwp1NHWloAWjmiigApaSjvQAUt FLQAlLSUtABSUUUAFFFIaACk70tFADaaf84pxppoAYa8i+MBxeaf6+Uf5tXrpryD4wn/AE7T/wDr lx/301Jh0Z5mDgUHBTigYZOPvfWmjcoLdqowQ9wcdvwFQk5O3o1Pyyuo5/Chw23cV696RSGtk4Xm k3YGBkD0phJ3ZGacBuHQ8dTigYoABVuuaf8A3c9zUfAPyselO5C5xigRM+1Uxk81ZiXcozVTfujO V47VNA27jPIpiW5cKhOAO3pUa/KcA05V3HOaIokQ4ZPfNMC0jFEX61HL57FuyZ+WmTP8wUAhj0q+ keYlzycUDRWYy+VtQ445xTS7bdxzxT3J3bM/N7U2VGePaF6Hk0MCaHmMMR+VWAI5kyz4I6VGq7bd T7dKRIhIm1Ttak9hof5JWZQj5YDJGMVGDhg7oBJn5qlXEL/MysRwTUE5aaRUTIjzliO9IosXCxXE bLKpVT18umxBHjAZyyjhE6bR70+JBFCSzfMf4RzUEcUksz78AHpjtTQMsLB/zymx35qZLgxIoLbp D/FUSRvuCmI7fU1Za3Ufc+Yn2qSrEcrMZlbue9Lh3lzuqJ4yTyDkVNbM3mbOu4elMkJGYfKCMD7x qYBZ920Y2evU0Z+zg4A9fmqASoqM+fnZscUitizHvAYuw46Cow8r3ChSu0dTimAt5mSfm6VNbyoG bK/QYpARFzJMUkcHH3cVJtXPXtzUTxmI79hDN/CDSQS+ZMqDr/FTQFud1eEKB8x700xMIVEZwx9a klg5TLfMeRUbqQeTkkYpajCOSVJE3jO4d6fIpznoB3qGKPc21zj61JIxA2A5PvTAsQEkNleOlEr7 kKA9KmgG6Bdx6CoccnikMngbKguaglVhIXHQVHGzhiG4Ab5easOONm7GaAGxSAqsfYU5NoZjwF6i o2UROEPTHWpFbCEEce9AFi3J8pscc8VXaNvMIBHByc06JyrL7ninSuvnb6AuRT8d6ieZjt2rSStm TtQEc59qYCwyO8hLE0ZMknfFFuvcjqanbCvkUgAMqKRUWeMrSyAMvyg7jS7P3fbJoGIOhzilGBJh aZtyuM9KZH8pxQIsN8zqPSmsduSBwKJOH471Gu53xtJoGG7e27oPSmXdnHe27QTD5XHUdj61OgHp wKHk+f8ApT8hHPaDdyQXU2kznLQk7DWpf2i6jay28gwrL8p9G7Vl+IrWSFo9UtyRJEfn2nGRWrp9 4L21W6T7rdfY0vIkxfDV4/kSWU2fMgbC/TuK09QtY9Qs5LaUcOOv909jWHqiHStehv0X9xMfnx+t dKmH2upBDcjFMDy25ga2uZLd/vRsVNQ123jXSgUj1KFACo2T4HX0auJNMNhKKKB1+tAC1dtT/KqP ertr0rOpsdOF+MuLTu9NBpwNcUj6Gi1YKKDRUnahyfer2PwChTwvC2PvyOenvXjkfWvbvB8Yi8Ka euOWjLcfU1tQ+M83NX+6S8zePNApB+tKOtdZ88OozTaUDB68ULYB6uyjAOM0dv0ptFADu2aTpSjt xTTjFMB2T2pcU0e1KTz0ouAvSk/lRn8abmmIdmim55pw60CFHpSim5460gPNAxaXNIabkCgQrdM0 c+tJmm78d6Bj+30pCaZuG6mmQZoESGkOc0wPntSbifwoAd9aKZk96KAPlkda7X4fHHiSwP8A03T+ Yrix1rs/AA/4qSw/67p/MVRmz6jT7i/Sn01PuinUihaO9FFABRQKKACkpaKACg0UUAJRS0lACGg9 KRt3G3FITzgigDxHx+h/4TK/IzyI/wAP3a1zakqucV0nj+THjK+T/Zj/APQFrlXbGB6VAMjZzuzj C05VUvnHFDAt1PFPRcLmjYFuML+Vkrj8qhlm3nd3qSZ9ysfw4qshzwaAERC5PFKw2mpEIQ4pr8uM DrTDoIE75p4GfWjB200/y9KAEABXd3pue9Bo68Y/CgBwOVppXNCjCnnHtTQ1LQY5uBimjmnNzmo1 BNAEwIU9SaVsOAcD6Uwg4weakWP5fSkBD60K5TIzTnAA96hDAtQBMrDPNSFl21Xz6U40DHMB19Kd jIpqcnGasFMewpCK5GKhOasPjnNV24OKTAcvPWmnpSjgUp5pgQk8559akU8UFAe5po4NHQQ8mlHT r0pp+lH4VBSGSEVWepJTioTTSBkdIae1MNMCMjimN0qXFRvQBUuD82K7LwXZ7LGW5Iz5zbfwHb86 4ogyTbVGWY4Fem28P9maPFbHcPJj5B7f/rrTaJD1lY53xXcDdsB+bODXKxgmQAVo63ceffNznHpU Wkw+beJkcLyamLtG5o1eXKXNXfZb28GBlE5rD71e1OczXbnPeqNFNe6FR+8SL0pSfypKU1pcyEHN a0K7YlHes2BcyrWoMVLKFNIqFpFUdzS81NbLiVpdu7ywWxUDKuoSeZfsdv7uMBRVa2XLM5psjOIj uPzO1WIU2RgU2CHUUGgdagsXNKM009aep/WlJaG1CXLMRvegUH+VIK5HofWYeXNAcKXODToFVmIZ sU1vv4FSdAZ+lL70lA44pWGOo7UlH4UAOFJmjt0pR9KQgxxQfyoFH4c0wExRjmiikAcYoHSjpQDg HigBe1FIKMnFACjind6aKXNFmBLEzKwKHDDkH3r6Z0W9GoaLZXinImhV/wAcc18yLmvc/hde/afC CQlstbSvH17feH866MM/ePGzmnelGfY7ilFIOlAruPmh1LSUfyoAdRSUtAC0UlFAC0UnSloAKUUU dqAEpaSigApMUtIaAA0lLSUAIabTjTaAGtXkPxe2fb7Etj/U/n8zV68a8f8Ai+c6hp49Iufzakw6 M8vVsH2p27nAz+FNkxUYkJ46c0zIlALybQBzVu7iwPl42rVVJMNj+VOknMkPT5d3rQNEIBK7to49 qUqcttyKdHLh8jFK7Evx0+tAiNFw+CQB0qQ52HnvUY+ZqlKfJjOPWmkJiIcKTmpF+VuOlRKh/wCA 1NgZ+/SAsCUKBhulSrJI1uWK8qfzqmoySOg9qmi+Ysmc496Y1uTHdNJC+Nu3rWjkNCcNtbHr0rP5 iAHXinwyhY22ruz2NHQfUmREP3SWYnqO9SBCjnaNy96hhhmMijcEVecZqQfupNpIJJo9AJWcO+Gz x6VLjy/mA6VW/iUjrVpmV0UjGaBjFUyyfKeG61NIiRQrvDfhUdsQz9drD361M7ZT5mHymgZCCy/e G1W6etTKnlhmdyzAetRYLDcWzipI4mlAOPpQIZHc3H2ZfNACbsgf41Kbr5vkB3e4qjEJlkaOTlc5 FX1gxg5pDJEd3lO/HNOUoJncHGOBzRcSRjaqnLe1Iixr+9zjFAx90YndQM9OPeoAqNneNvuKSd96 qQq5B4x1oOSF45JoAkSHGQzHb2Oas26R/fJBVelVAslxMExtxQxBWRN+GBxSGOu23z7g7YPAoiCR MrKSzU7avl4ypYelNT74bpxQA6Rt7b9zbugBNHdQzZOetQO28tk4Ud80uNrLltx7UgLPO7LZLDvU qqJFLHOaVcZO/hsU9Cuzg4/rQgFilCowRh6UdFLU1B8nyfjmlHyjG7NMYiLulj+vPNTXL+VJlRkD j6VEuFmUnoKdJIrBhnn3NIaGx5lfbkn1qa4IjCqeM96hg2pIOfmx0pzfvZMN/D2oAaDiT/ZqQDzS ee3FNDhuig89qnto0edgcgKM0DKkyARg4+anRtxU0kQeNj6elR2/CNnsKBPcBvZwo9amIBYDHNEY Hy44zUwGOR3o9QIXTy+E5psQOcsvHpUgHH/1qCwSP3pgMBJLELxUDYMhYDp0pxdsYHQ0z7o4PJpW YyViflqSPaJBkkKKrryM5waeU5BzzmmIfHt81j6npTZo1W5+XkUkWfOxU0mQQx7UAQtEksbLImVI wQa5Sxd9D1ZrCV/9EmOUJP5V1zE8sD1rD1zTjqFl8iAzR/MhpCLWr2i3emyQbQW6pxn5qzPDF601 r9mkz5sHGD1xVnQtQ+32MaSZ86H5XyfyNZmqf8SbxLHfRA+RMfn7D3H9aBHXXMUU1qySJujkG1h7 V5ZrGmvpeoSWxyYxzGx/iWvVjta2VlYYPIrnfEmm/wBo6exT/XQ/Mnv6imDPO6SnEUlMBO9XbQ8Y qlVmz/1uPWoqfCb0HaaL4607+VJ3p1cTPoaD0Cj/AAooqGdyJI69z8OLs8PaenYQLXhsfJr3rTE8 rTbWPH3YVH6VvQ3PKzZ+5FF2nZ5pvQUvGK6jwhTRRnim5x+FAEn8qTvzUXmjpSmRc8UASg80ZqEy 4/GmmQ9hQBYB5oyKpmYryeKRZsnlqLhYu55pu4VAWz36UZGPancLExdaTzV64OKhJGKz9W1OHTLN 7mcgRr1560CNTzcnpSh2zXFWXi43sn7myfyyflJfmugs9QjuX2A7WA5RuopcyHbQ1SzbaZvzTckj rx0oOOxqhCltq9aytS1yy0tVa4mX5uihufyq8+/+H9TXl/iy0ubTxJ9ouVHlTAeWwOR9KBM7628T abdL+7mIz/fGK1kO9dy8g+leYQawhU2stsgULxJmum8KX1zcRPB5uY4vuZPQUBc63awHIo46UxWf Hzvml75zTAdg+tFAxjrRQI+Wx1rtPh7j/hJbH/run8xXFiuz+H+f+Elscc/v0/nTIZ9SJ90U6mR8 IPpT6RQtFFFABRR2ooAKKKO1ABRRRQAlFFFADXJA4GaT/aIxTqD0oA8N+IPHjK+fvtj6f7i1zPD9 s9q6rx8N3jS+5H3Isf8AfArmVRQyg9agGIFwfmAqvLNxg9RVp0O1skgdqzJUO9mzQmAufl56Unyo 24CgH5QOKNuWA61Qhy/MenWhuOvSpI0FPZRxS0GRKx5561G3H41JtHVaikc4NIY1cbqkXJNQx/Wr P3VHNMSIiOT+VNxhqGOcnvSdaNwFY8UREb+e/FMcZ4pyxkUvMehZdM4/pStkLjmmxydyScU6dwVJ GKkZC6ZXd61VUfMc1aVvkGWqA8k0wAelP4oC8A0HpmgB8fyt0qVn3LUKfXNOPT3pAhrDmo24HSpG qN/u5pMER54o3c00UMMmgRID+XvTe/HT0pqk5pwwepPXtT8gY5TxTSwGfWkBI6mmSdKQIgY/MaTH FN704UDGN06UlObk004xTASoJztjJqaqt433VoQi34ctluNXiLJu8o+YPTI6ZrtdavBHYMpGfMPL euO9Zng+0jTS5Lho0aSV9oz1IHb86Z4puGHmR5GVAHHTNOp2CnrK5x8zb5Wb3rX0kC3sLi52/MRs SsUDLVt3H+j6TDGf4huNTU+FRRpS+JyMWVt0hNMA5pD1py1stjFjqdimoMnFTAYPPNAiW2X58+lX F4qC3HyZ9amFQUPGccU8uUt2VesnDY9KjGcf0onYpACT9Kl7jRRc+ZccfdHpVkdKggX5d5H3qsDm hjQhpB1pzU3vipKHE0LwaSkFA46Ep++1MxT2IyuM009a5prU+ly+peFhRS96Vl2jmmis7HqIcOeD 2pRjNMp1TYYZHpRnvRijFADu1GTtx6UUUCDij3oHSjFAwNFB6Ug6UAGM0vAFA7Cg0AAooHtS9v8A GgAH60d/Wk6YpfekwHrXpvwivymo39izfLJEsq5PdTj+RrzEV0fge9aw8X6bIGIVpvKbns3FXTdp XOTG0/aYecT6JHSlpq9KcK9M+MY6iiigQtL0ptO7UAFFJSigBaKSl9aAClpKU0ABpKKKACg0Unag ApDSmkPSgBD/AEppp1NNADW6V498XsDUbAf9Mv6tXsDdK8e+MJP27Txnjyzx+LUmPozzN8FM/pUO FzTiCx47UgOPrmnYxBh2Ujml8vjrn1ppOTTs4Vs8Uh+QbvYcUZ4qMMNtO7deaYE0fLc8c1bKgxMO 9UwG7VaiJwOfl70ySAAL8pJK1Jne/tTmCbd3O2lQHBOQRRYBH6fKck0qMzBjtIYd6eYsLuA6/rSI CCUOQTQFhUmbjJyvoanRgmRzg+lNWJQFcD9Ke24jjpRYaLUbtGd2e3FAGWXfjmoVB+XFTQb45FZg CPQigdhznn+lOEZKbxgLU0+2STCoB70oGxWRcFvejoBFb5Zj8q/L7VMBvlVMAYqAM6N298Us9yYT GUXO9tv4UlsN7li6QIyhFPNSRPiJlPpVdi8zK3mMqoOgPWpEYr70wBovIzMkY3MMbc81JaSbw4dc fWmO4WPO7pzzUCu4yTjLHgClsMsHAKjG5e7U5lTy8q6levNAOy2UumCelREEjcOFzS6DCPcZMntU vzCRTtO3PNCDYhyxb3qRGWNWeXkY4FMCQjEikuBn3quzASM64kYn8KkTbKqoRsWmviN3RQAMcNSG KifuxIpUHPOKJCcD5etQxv8ANtKYDCr4RnjIZcIncUAUXhbdtc+9PXbHIykEgD71PJ3T7z9M1I8n mKqKAMc5oATO/wCYZ+lPGSmU61VV23EcdegqZGO3npRcC0HQnG7b61GCPM4bp7VXLDPynORz7VIW 2nPXA6UhossXTqOvtTcKy84b1xTDI0u0gk0RsFYKTy1AMkGA49QKd5jZJ2ippfLKKoHOKYUOOO9M aIUba/QbqlDMFZg/1pir+84A4qxJkxbiuMdaQx6ndF8npzUMPEUmcZqSB/3Z96hlUK3puoETQltu d3Spd+SVJHTrVW3zkj+GlDEscGhgSZcvzxTXyUOBk1GGkWTa5yx61Id2APSmBCVIXdmm8iReOD1p 7nt0pqsCfSjzAUKxb5OQKfEG3/N1pit5fI701ZWMvTAPtQBIDtkI689qmckxmom65WgEngk0egCH IAU0DqPTNEvyyZ7ikVjikgOY1NX0bWl1CBD9nmOJQBwPWtbUrOHVtJk8ohiy74m96sXkKXVo8Eoy r/p71ieHLiS1vpdHuG+ZTmM/0pkk/h3VHuNO+xS58234+britgZLVy+txHSNehv4vuSn5x7966q3 bzYlkX7rDIoDyOF8VaR9iuxdQr+4nPOP4W9K5/vXql5ZxXtpJbSjKOMfT3rzG7tpLO7ktpR88bbT TArmnRMUkU0hpB1pNDi7M1gc80/rUUWP9WDnbUo6VxTVj6DDVOaNxe9GKOKO+KyZ6cSe3/1yAdc1 7zDJhEUD5VWvB7MZuYl65cD9a90UkbcV0UNzyc1+yWhJx0oy3rUOT+FOHP4V0HjEgY7eT0rB1nxF baVIqyNlj/CDW0eh5zXm/jrS5lvo9SRSYQNr+1J7AdRaeK7C4ZRvZGbpvGK3o51fBU8V47FrQkgk glgRdv8Aq3XqK77wjqVxf6PG8+DtJUOP4sVKbW49GtDqM/j+FBc0wP2zUTyIBy1XcRy/jPWrnT4Y Y4OGmfAf+7Wfo+sXW0E6nG8xGRHIQc10Gqafa6xatbTr7q46qfWuFufCOq2F351uizYyEkU84qXZ i1R6No2sQapCwB2zRHEiZ6VrAj0rgfC1i2ltLdX06iWTjYDXSS69YxAl7mNf+BVUQZte3FY/iPRB rmmPbeb5cn3kbtn3qs3iywRf9bvwf4VzVaXxnZofkhuGyf7tV5CucFP/AGlopa3kSSC4QgbmU7T7 g1q6Xqd7e61ayQpI3aQqOMVv3HikTrsOnpIo5/ec1SfxJeRfPBaWkR9kpctxc1juvMVIxmgSgj/C vPZPEOrzKSZ44x/soKiW/wBRuGCnUZG/2VfH8qqwuZHozXMaj5nUfU1nX7aPeQtHeyWzxkdGccVx Igmm+8JJHHHc0LpVwwA+wuc9NwpiuTzaT4Vimyuqy+X3jVt/61q2Gt6BpURjtPtLA/7HWse18Oak Jv8Aj3UIex7VtReFp+ruF9gKNA94U+OLRpvKhtLgt234FVNQ8a39vFuhsYR/vuavN4LikIkdyHHd TVqPwdYY/emR+xBfinoL3jhpfiPrPmHy44AO+1D/AI0V6CPCmjKABaJ+FFILM+d+9dt8PQP+Em0/ /run8xXEiu0+Hx2+JbA/9N0/mKa2Ez6jT7i/SnU1PuinUiheKKO1FABQaKKACigUdqADvQaKKAEo oooAQ0h6UppD0oA8U8bRyN401NkR32iNjtXOAI15rl2+a4B64rqPHGD4x1AZOf3ff/pmtcztw3So sMczbom/lVF0dmYEVNLMYjleeeae0oaPeBjNAjPdfkp0IyM55FLM3y81Hb5LY9PamBcUd8UyQdKl TJB5qJvve1KwERGORTSoLsADtqRx8tMU4pDGOu1vpSg5pJDuOTQnA6U+gnuMZfmpuMGpT1zzUfc0 hix/fqy68e1QxA+YPSrDng59KLgiEYxmmuSVpei4IpmRs+lA9iPtt7UbdrdelOx0prmiwh4Py8Uh PFMX60Fu1ICWPYFPXd2p2fmqKM08/WgYrdM5pjdOtDdKaxwAKTAjxz1oPXNGfekJ/CgQgGTSkYGa aSQcimk/LTsA5qYxzTSfpTd1ADacODRxzzQTQCGOPypmKcTyaTNADDWdMTJcYXnnArRkOyMt2FHh 2zW/123jcZRT5jZ74/8Ar1UBS2O806yXT9Lt0KbWji5z1Hcn6muG1i6aZyW6sxJHpXZ+Irt7bSpN rkyStsU9z6mvO7mQvJyc44pPWQ46RJLGHzbhF96t61OHmKjtxS6REwLyspAQZrPu33zM1S/en6Gn w0vUr04dKTadoPvTgK2ujEevFPBz/KkHWpIxl1GKQJFuMYUCpOcUxeMVJtwoO4HPYdqh7jQLycYq C/bM3lrnA4wauwfLuduijrWc2HuOPrnNIZKF2qBTgeMe/pRSA0MYp6UzqaeelR1K2GKTS0lJ7elM aJRkr9KU59qah7U7+GsKiPZy2prYNzEcnpRigHtRWB9CgHWnCm9aUfypDFPFAzRRmgA7UClpBQA4 c80HmkHFLUgFNPWnUh6/SmgFzQaQcUtAAOlL2pM/rRnj+VIBetL3ptOoEKKntpngmSZD88bBl+oq BevpT0ODQhPY+n9PuVvbC3ukPyzRrIPxGatiuP8AhxqJv/B1qHOXt2aA/QdP0IrsAa9SDvFM+IrQ 9nUlB9B31paSiqMQpeP8ikpaAFoo7UUAApaT1paACiiigBDS0UUAFJS0lAB9KQ0tNNABTacaaaAG NXkHxfbbqFiP70OP/Hmr2Bq8e+MP/IR070ER/maTB7HmAXaRzRKFxxRuy/AqYbCBkUzEqBcHNI+S MZ71adQQMVDtOflGce1Fh3ITGeKsRK3QCndE5HNNWRhnpQD1LWPlA9aFGxWC0yJi64I6VOgIFVYl 7iLFmLk0nyrx6U7b15pNvHTjpSAbvbHBpUJ3bmHzdaaxHSnqcuBjimMtLJv+UjAp7r8vy59qjYIr AD61IJS52DtSK2BTj2xVqLe275izN3qordeO/erMXDcttB9aYIkkQhkOfmqy0ZZFkTOagMmGUfw9 AcVPHMfL2j7w6UhlFwXlYbj+FPjEMibZnztOOD0NXBEvlNLIQM96rrbQNIzqobcd340mA5lVYSA+ 7aOvpUcU+IQDk+tPnwp+RSufWomjk+XzMAYwB60ATthkViD0qGNS7eYcgjqBT9z7djoMdvemrIY2 K7Nq7eOKfkBa3NJEoblTwKdtAC8cA9BUUDpt2BqnYKVwH6UBYiyGkAXGAeSTU6FXYBh82f0ppghC 71kGepU01G27sqAMcGpKLM6DDFKZ5IlhDL1HrTom8yLDrz60SL5ZVB396BkckarFvVDwfmpizyt8 pO1accRuRj95gDk0rRifp8uP1oD1GxnMvGabMsgn2rg8ZFOhG2TaeGp1yv7xTxtxzTEx0QHlgbQS fSh8KuzpmoYmw45OM8CrVztZd3RqVhleOMlWRDkk9ae0TjackEcUkXy9D+NSBs7kz3qRliDYi7c8 010OVYDg8ZquWZHxk4HtTlLP7Y6UwLB3jaQegxVgSDZz3qun3BuOfenpgn1FO4xwdFfdtPNPkcsu Oq+lQsQXxjG3qacxJ57mgLskCr5eMncf0pHXdHhm57U1QfLcOT9aekn7leMkDFAXYBtmF9aaSEm+ 7xTVY+ZyPpUkm7eG9sdKEguMcqJFbqx60u/PTqajbHTkZpYuAN3JoAV13LUYG47fyqdW5qNoipL/ AMqAGSId2c/lRFy3NOX5+ueKI0zkUAToCeKjkAWXGaeh/d4HFRyjOD0IpARvuySamVhsz6CozzHi nx7fL+YdafqIhlzwRWF4g09/Li1S2J86AgsB3Hr+FdFcgBVxiopAGj2EfKwxigTMa4ZPEWg/u/8A WnnA/hcVH4W1DfZtZS5WWDgA/wB2qdtJ/wAI5rpgZiLGc/KT29D/AEpuqqdJ12O/h/1U33/T3/xo Ejqc7FZjzgZrzfWJvtWpSy4wWau+hl8yBnzuV6zW0DTryRjIjxyeqN/SlN2LjqcNtAPOab0YV2Fx 4UtFHyXUwb0cCsXUdG+xJvjl81e+B0pcw+WxQnLQ3LEf/rq3DOsoHI3elOWy+12fmLnzEGGz0rLZ XRujKalxU0bUcRKizYpe9ZS3Ey9HNON5Of4/yFYuhI9WGa00tUbun/8AH9b/APXRf517THdK4BzX zwLy5DKwmcMvQjtV+y8R6vZ34vRdyXEigjFwxdefbNa06bicOMxca7Vke/C4QjgimveQxj55Y1/3 nArwuTxHq87+ab+ZC/URnA/Cmg6ne8f6bNn2ds1djicz2uTXdOhHz3kC4/6aCs688S6JLCRNdwmN uxPBrzK28Pa7cD5NMuSP9qM1sx+DNeuYlR7Hyyvd+KLC5maFynhOabzEtrg+oj4FasOv6ZY2scVt bXKxr0Xy+P50/TPCN4tsgu9iyLx8orS/4RONotkkmc+lS0Urma/ibP8Aq7WT/gb4qjc+JLxUbZDA v4k1vDwZacB5pSP97rVyHwnpqJsMRf8A3jT1GcWusa5cL+52qvbamP1qGR9cf/Wyzuo6qGNekwaR ZwALHEAo6CpxY26niJapE2PMY7O4mUP9huHb/aBpf+Edv7wbV04xY6My16iIEX7qgc08DAp6isji LLwlc+SPMcI3pVhvBbyrsa5CjviuwApfwoHZHJReCkHEl5I3uKsr4L00Nl5J29t1dKKD6imKxiw+ GNKiAH2bd/vGrkWmWUH+qto0+i1epCAKAIlijXpGo/Cn7OOlO70hIoAKSg/Wk3ZNMAPSgdaTndjF HU0AGPail+aigR8tjrXafD9c+JbAf9N0/mK4sV2nw+/5GSw/67p/OmQz6iT7op9MT7g+lPpFC0cU dqSgAzzS0lLQAUUUUAFJRRQAUUUUAIaQ9KU0h6UAeLeNiP8AhMdQ4z/qxx/uLXM7+WH610vjXjxd qX1j/wDQFrlzwnPFQxkU38JxwKglO7hTwOuKcZ9x2MB1qVoUjTf2PrQhNlN2DIR0IpYidppWRTuI 5pgfY+MVQizG+FbJpmctnPtSsw2cCoM4qbajJWPp2po5WnDke1KQO1D3AgIyxpwXA55+lBGGyRin AjPORQA0L2x704oP8inHGeoIpJPu0B6DEx83NOZhtxUa57cUHIbmjoAE5FNPJoPWkU/UUANaonye c1M/41HxikBGM9M0pPqaeCPakKjPSgYqYpwPNNXrTgKQEgxg1FJ93injrTZetA+hACc4pcH8qOf/ ANVNOaAFwaY3A708H1qOVs0CImb3oGKhY1Ipoe4yQGoznNO/WmkUANPrRSkUh4oAr3jYh2+tdF4K ttsdzeMgIYiIcde+P8+lcreP+8x6V6ZpVgNP0W3twCr7PMfI6Z5J/wAKtaIhmH4luGe98o4xbx+Y /pk9q40jc2fU1qajcSSrcTMMec/H+6OlZ9om+4QEHGaUbbltbI2SPs+jDnDPXPyctW7rDBEjhX+F awT1qKO1zSvo1EBUkeOc1GvTNTL9ytmYDkHJqaAcsfwqEEgVah4jHHOalgiZacKbUkSl5FUAnNSM dc7EtVQcux+b2qhCP3jN2q3dSxtJI3XbwMdKrwDEf1pDJDTRTqBQ9hgelRnrUhph+lIYnSiij+dM YDrUy8ioeh+lSoec1lUWh2YOfLUD86XtxQetFctj6yDugNOXvTSelOXvxSZYfSijtS0gClHAoHTg UdqAEA9aU0dB70Y//VSAQjvSAc06kwAaYCig0D6UUhBRR3paAEHA607vSCjOPzoGKP8A61OWmilH NCEep/CG+xNqNiWI3Kkyjt3B/pXrIrwH4dah9g8Y2YJxHcboG/EcfrivfV4rvw7vA+Vzany4i/cc KdTRTq3PMAUUD1oFAhe1H8qKWgApe9JQKAFo/lRRQAlFFLQAneg0YoNACUlOpvegAptONNNADWrx 74vlv7SsOMr5X9Wr2A15B8XSRqljgf8ALHkj6mkwezPMT1OB+NJvqwgGGHUVBKBu2rVGACRQtCNj kcimMOQM7uKlAAg5NINCMks2BQqZfHHFNQ7WxVpAKYMGDgLt+73qQO2B0qOVsewoVAyglqYLcmVu 3vQ57VGSFOTSF97ZpDuIgLN9O9WB1GB0py7TH0HFM81SOnzUCRKQWOAc1JEGBxt/Go4WJIFWG3dS cAUygIBkVQM7epNSDd8zkEqo4FRkfLkZy1SA7U3BsDvSHqTWzeZtVgA+Ohq0yFZkxg5HNQ2xST94 ITnsatM256GNDblSYMryPSq9vKfNycBQOmKvblKkHhewqnLI0W7ZFnPQigY4xpM+RtYehqORvvZP PapI9rfP6GoZFMk2E49aQEaOzSb/AO6OAasSRGWJW3fMvJBqJ02dPxqWNclc5A7gmgENUqY+Ackd RVqKEptOflxSOigLgZUcYqe2DSx7n44ouBCYcldoGPpUUaeYrbuQDz7VZZxsbBBPQYqud0QLufl9 BSGPigZE+T14FWIyAcsc44PtS27LJDu5XJ4qORW9cqetMY4/6tsrk5+9608bWRSTt29qgXhfXHHF NQEZy3f0oAhZgk+4MeamVPO6sTxUNzEWk/drtJ71PHnbtHWgRXxtbIbHapxNmFlIySKjddu7PNOj ABGc/jSHcmhX5Ao+9irDQbGBI5xUaTBVXg5Hen+YWCsT09qQwRVaTB4HWlSPc2xB9cUcsvy+lOQN GwC5x3IpgCx7n8tepNOjXaxwe9DFkXev3jxT4lVYmLNQAkuOR3p0QCv85+lQOW64PWpjlmGAABxS sMkdlztP0ppbLgJz9KRkzG3uOtV13QlR27mmD3LIT94GLDHpSK5w2TmmqoJY5OTQFIzzgDnmgBjs WTAHekjHy/NniphsGV5y3NRqATjkgUIBycKTUm7K4XimHjilZlRCKAEz8xpA3zbRRHhulRxQss7b qAJ0BLhfyp9xAVVeOooiwrnLfLUl0cqoU5oQFZRiOlUbKdjApg4BB/CgCGQFiWPamAksoFTOrFAB TEHljOelAjO17T/t+ntGigzL8yZ/lWHYzjVdHksJj/pES4UN146V1T8ndk5rl9Ztn0fUI9UtB+7c 4lX3/wDr/wA6ZLJvD18XtPsMm4SRHofStaZlt2Vm4HQmucvpRa39vrNmf3Fxy3se9bjGPULPKSqd wyGU9DUyV1YqLsyxPIkkWVPzYrAmXzftEXdkOBUsgvLSLLYK4zkGsaLUn+3LJ8uw8N9KxUXc0ckW tInFtcrn7rdRXX3mkaVqtvG72/lyKRzEOorkrmwksJVV3Vt43Iy9CK6HRNVXK28h+Y/dz3oUuVj5 bkZ8Ci4TdarHtPTzCQasL8MriQfM9vGfUMTXV2UoU+1bkMgI+tac1yeRI4O3+FS7P395F9VDVo2/ wt0mJt007S+gxXbJUoXtVCMTTfCmi6eoENhCWH8ToGrbREjXCRoo6DaoFOxjpTuNvFMLIbk0nJPN KSB/FQGFA0AGKCBRnPY8UdT0zQAgHPFPFJ8w6YpFz60gHYo/pR680YHoaYBTc07HtSge1MBM8dKb kntUhDUbCTQIbzjpTSD61NswMZ60bBigRFj3o2881JsFJhc+1AyPAzTvwqQAUHpTEQ4PpQQTxipR 160lAMjCmk2kVLSdOtADMUU/8KKBHysOtdl4B/5GSx/6+E/9CFcaK7TwAP8AipbAf9N0/mKZB9Rp 90U6mJgItPpFC9qKKKACiiigAo7UUUAGKKKKAEooooAQ0h6U6mt0oA8Q8dOP+Ey1JeOPL6f9c1rm y2Fwe/eui8crv8bal8uFHl8+v7ta5u4I/gyF7ZqNAKrBd/TNSsS0XSiJQ2eafLgR4FO4eZXVdqtU Z5fkVI3TjrTecUgY4rgYqN1PSjfRuLsCT+Zp2BE0CNK6xb40JzzI4QfmeKbtJNCMytwSOKkY96m4 yFxginDBXnpntTWPy8c5oDHFMQ0elOJ+UimnAPH8qU4PPemIYvB6UH1ozyeKTtRYYjELQMbc0088 c05Bxj8qAGkdTUbCpifmzUb1IyPHFCn5qeB8tN20AOpQe1RmkXjNFhEpOKjlzkUAktj1pJDzipKE B+WmnrTx04qNs560xDj930qBzwc1Jn5agmJIoAgJ5qZKgz9KlQ8UhkuKTjpQpNBpiEbtTD0zTvwq G4fZC3vQHoN0i2+363BEyFlZ9xX1A5rvNfvmtNKKgku58sH1P+ArB8C2aNPc3UhVdq7Fc/w+uPc8 CrnieYtdWtqcfL+8bHQelVLTQUFeRzOosNqRD+EVJo9vmZXYe9RzRtNcZyD3+la1qoitZJfQYHtW M5WjY66cLzuY+qziSViFO7cefasytWWK1uEkxcMlwvIBX5G9s+tZq9dtbwjaNjmqS5pscpATBH0p yYpjD5sVIo2iqZA4/fAA71dUegwKpxDdL/8AWq4tQxjsc8dKnj3JE78Z6AetRKORUzojeXCu7Ofm PtUsZRuP9Wo28nv61IowoFJdYN0qDovbsKfT6CG0AU/FBFJlIZUZqQ+gpjY/HNIoSg/lRRTsAnen pUfenLUy2NKcrSJnwenFNFO/hporjZ9dhpc0EOpw/izTeKcKlnSA6UdulJz6dKXn0oAcPpR+FAFA qRBR3oAoNGgCUd+RmloxigYnToaXOfakwaUDHpTAKWk/Lj2opCHfw5z36UGk5wKPyoABSg0DpRQM tWdy9pdRXEf34nDr+Br6btZhcW0c6/dkUOPoRmvl1PvV9A+Ab83/AIOsXY5aIGE/8BOP5Yrpw796 x4edU7xjM6mnU0Utdp84OFFAooAKd+dNpaAF/KiiigApaSigANLSY/GjmgA70UtJQAlFLTfrQAh6 Uhpx/Gm96AGNXkPxc/5CVjz1h/8AZmr19q8d+Lzf8TSxXAH7nr3PJpA9measxByp+tN8wY7biaac ng8U0j5c+lUYEigfepp+ZTzT0DOuBzTZMBVAoAaFIOaV5CkRwcntRuJ4IGKjK8nHNIok83dHtPer MJAHzcjtVSMb2yR+AqZwQfLx27U0K2pKzh2C0wuS+DSKvljBHzEU6KEls5pASRuxQgdqeoxFgKCx PWnLDt+Y0uF9+OTTAVCyY6VKH8zr2NM4J4PAHFRhTnimPoamF8ncT9KhbdheAQPWhJE3AMMgVPOi PH6DtTYIhsb+SN/LmUAZ4+lTtfL5bOykFW6etV47dNw7tj1qaTyo41OMyE9+1SMsJdK5yQB7elJM XLMv0xUIRXb5easxooQB2xt5pFFcFYpPmYnvVtMFdwGWNUJC277vHvUkVyVTH8S9zQBNcYOApAbv RGN20Yzz1qHzcyAMp2t3pRc/vvKjB+lMCd9wlGHP0q2ZNsfdRVFhMGycnjp6VLHMfvbOfWpGSKCT 8nT+VNP3tretOiDs5JbgdRVbeJsOQ22mBoxKPLVyRz2FDfe9qhgKrHkA4K/Lz0pY23bV55oGDuA2 0iljA6kZqBy3nZ/SnK3H1oEWW4UYGar5zJ8gwelTRsPX8KjEe751OMdqA3JEiO8AgYam3Efl7YQ/ T1601rgpyV6enrUQxJ+8lY7z0pPYaJzgKpVvrRuH41HwWyKftDDf/EOtAE0QO7IqcH9z1w3aqsc2 A27APbFDT7iAO1MC05/dqMjij+GoYsO2akcjy2HpQhg7ZVdtSfw7h+VJFGRBQmWX6UgJ1kVIsYzk U2VVkIIPGO1N8shV601m8tRtUnJoGLG21XO37tQBncnHOasKBIrDAGetVzlGxgj6UhkjtsRCPpg1 IBtwwGciq5aSZV3n7nAqQS4AFOwrjSxJGfyxUrfMuSeOlQuGZsjoak6xADIFACphRxTyu56iYHIx 2qSHO40xIcPlO3rn2odiPwpzK427u9NCkMuaQ+ojMcAio2G7cSflp0p/e+lMlJHHrTAIXLRkE9+K jCn7ucU4ARY7k0pYKu4igRGp521naxsGnXCyLvATpV5WLMWxxUcwByGAIPXNAjzhpbgR/ZjK3lZz szxmtrw/MYLjy2PyydfrRrWmrA4eMYU8jHaqdt1DVIjrbkAqy44NcPdxGzvJYT90H9K7K1nE8CsS TIOGrB8SW+ViuV7fK/8ASqEXNMnXWrBbKVgk8GSkh7j0pio1vP8AvFKyIw4P9K5yzuDBNvBx9K6u C/i1qBY5kUXUf3HJxurCcLm8JWOn0zVVuETJG7ODXU2k4cdeleYWcm/dbP8ALMnQjvXUaDqRhP2W cjP8JrFTadmbuN0d5C47GrQYYqhauCtaCY9K64nOwDClXn+GnjGDxTlqhEWw/wB2nBG7AVIMdKd9 KQXIxG2OooEfvUuaQ460wuMMYxzSiNewp1AoAQKM9KUgUUpoFcT6UdaWk/SgYdqDRRn2xQIOtAoo 6mgYmelJ+FOpp65oEHej3pwpueKYBTe9KTRQAhPy03vTuCO9NPHSgBDnPBooJ5ooEfLFdn4BOPEl h/13T+YrjBXZeA/+Risf+u6fzFNEM+pV+6KdTE+6KfSKFopKU0AFFFFABRRRQAUUUUAJRS0lABTW 6UppD0oA8R8cKV8Wak+c5aM/T92tcjNcZGCK63x1M3/CZ6lHj5f3f/ota5XyA+TwfWpAgjkAXg4O ak35IqKWPHy4HtTU67euKAJpV44JpnHShyQtRP6jrSCwxvvcUsZYbl3HaecZoVSaG468U1sBZVeK c3Kd6ijclKZk556Uhij0pw6ZpOtK2MdcUC0GMaRT6/pTuNvNR9BTEOABzRj9KFIFPXuKYELcNupN 2O9Ol61F04zSGJn5vSgk9aGA3ZpM4JH6UgH8YppJ60HpTSWT5lJBHdaQXFHSkAyeDUfT/wCvUowf /wBVAIQADvUb/e6VNtGOKbikUyMcLTSe9TMMCoWODjPFHQWhGWqCRs1K5FVmPNAxBUq8VCPepV9K QyYHmkalXp9KQ0ybig8CqN+33VFXM8VXt7c6hrENsASGfBA7jvTSdxN2O80CyWx0G0Ur80g8xie5 PUn2Fcvezm71G6uGzhW8tPpXXapdf2fpkr5G4DB9CfQfSuNcokcY/vHc2ampI0oRKsLAXhOfatC+ byNP2Dq5HSqbxobxgh445pury7WjiBOVFZNXkjoi+WEmZUhy5OMe1LbrvlpGcMQdv1qeBSse8d66 ziGqoMhJ6CnOPl9quRAx2MkmPvnFU3PyiovdlONkSWw4J9as1BFwv/1qmByKBFmEAspYfL9aS33S TXEqnhF601jst2+b5jT7ZPK0vzs8yMSBjsPWpuNopId07tU1RQqdu487jmpcHpzTCw9cGhulIo4x TjyKTGiFutRnrUjU30pIpiCj8qPpSGmA09aUUY5opAmTj7oApO9IhoauWa1Pp8vqc1Md3oHB9+1J xSgVmz1B1FHSgdKkB1FJ3pM0WAcKKB9KKAD+lB4OaM8U3v0oAdRQMcUUAL1pO1J/Kj+f0osA6kIo 9OO9GT6UWAcKAOOtJSikA5frXrfwi1HfaX+mswzG6zIPZuD/ACFeRDrXa/DTUBZ+LoI2OFukaE8d +o/UVpTlaaOHMaftMPJdj3cU6o16U/tXpHx7FFOpo/lTqBBRR2pRQAtFJS0AFLSUUAHeg0UUAFFF FABTaU0lACGkPWg0HvQA1q8d+LwJ1bT17eRn/wAeNewN0ryL4sru1axJ/hg/9mNJh0Z5ksfJ5qMj Dc1OW2HJFRbiW5HXiqOckHTj7xFRMuO9SICo6YqNyAaBoaAOpNIST0NDpilRN2AtIoWEFfn7CrDH /loR8xNRrgSAdV9qm2qzYAwRTJEb5kDdM1ZhAxsPFVpei46LTElLdflHrQP0J2mc5VRxTmyq9OWq BfkG7qKsY3JkdKAAvtX+Zp8JGTuqJVG7acVI21GYDnFMPImKc7k+6KmaTMK5zjPeo7c78o3Qd6cy 89DtoKH7OmH6jtU0bAsdwyBUMfPLcDFSxRoq7w34Ug9BYJEV2O3p1zUpKujVDEN87fLt3HmppW2S KmzHvQMiij3MzHJUdMihbYI3zEnAzjtU8j7lyiFf60sTs8YQj5s8UDRAVV5M71UDtQNp8vZyfYU6 Yt5wGwAfzqW1wC27bx1NITJ2UunOR6VCjHft2/hUjSKTlWyDUfnfveDjHagZPHjb8oIzTDGcYXhR 0prTuXBXaq9KVmB6HPFAIsKY0hCsBkjNEQRU3A9KrMNqjKY7dacmdtJlEh27twHzVGwBbH50jvgY TgGm9CvP1piJ164AwKH3Jz2JojBJXGTT5wwGAPemBA3Az97PaoSSxVNhGOpqSTdjbkriom3AZ65q bILkpHGFOfUVNFJ8m3PPeo04Q+4pYtqjJNAyRgNvP51EecEdqkdsLgDOaAPl6fhQDuWYAAASc+1O LLjJ/Ko0H7tSo7VE+ZCcH6UAbWENkoK4LVTyIzjP506OQqqLnpQVZ85AxmgpkyyiWXaOgFQ4Ik5P FRXDeUfkbkjipQ5kiB5zigCEkqeBuHekd2dwPan+WRxn73GKAFjYNjIpDCHBDgjoOtNUArvp6jMv BwvemSn+EUyWPRju2EVKh2ds9qrbvmVicVZc8ZFMAxgFVFNaZYY2fHTrTkwWXJqK4VCGj67hR1As C4FyY3T7oSnS9OtQWcYhj2j0qViR16UPcCEhQM4pkxG9akYqvIFRnD8/xDpQAkoO/P5Co22kYNSt krmoZFOVIoewDlA25qvL9cVLkhagf5hQhENxAlzb+Uec1yMkTWly0LjHNdgOGxnNc94hgkO24RRs XhjSkIS1uvKk54VuD7VduYRdW0kLjhh29a52OR5gEPetKCZreWOFG3o3Uk0uYLHOMpjlZG6qcGr0 Lqqh0fa6nipNetvLuxOv3Zev1rLVytNoEdHHcFwLjGHzywrSS7eQI5ABQ9qytGmSXdCDhiOlSSyX MdywMeNw52dK5pq50xkevaNcCezhkB3blrcQ/LxXA+DZ9tl5RbLA7tvpXcQPla1pu6JmrMtBqeKi U/lmnitTPYkpc03rTunNADhQKbkil5NABSijvTTyaAJBQcZpo6e1L2oAXtTeetOppoATJpeppOlA x1oAWij9KB1oGNNFKM0n9aYgB55oNBoPWgBOKQmg0cUAGe1NJoJ49KYTRYLi5opox35ooEfLYrsv AX/IyWP/AF3T+YrjR1rsfAf/ACMdgf8Apun/AKEKZDPqZPuinU1Puj0p1IoWkpaKACiiigAooooA KKawJGAcULux82M+1ADqSiigAprdKU9f5Uh6UAeGePP+Ry1Hr1j7f9M1rnQNiH0rpPHYDeMdQIPz Bo//AEWtczJngdqkOpG/bv8AhUajD59KWYquHzimAgruBpB1HPjZVfce9SSYx+NRlfwo6AWEPAqG UBjilXd0pesnPFAAgIWkb73FSgbQSaidgXBHShgPA46Ux84p5fDUx+RnigegKc0Hp6UxTtqTkjpT EN28jrT+lHQZFJ1//VTEMcbqjIxUp/GoWIzQA0+1GM9qXGVz+FPH3aQ/UifI7UmcjFSMMrUJ60rA IQe9KhHT+dI2c+2KUHcKQEgPHNJnFJn5eaYWyaGMe5Oyq7g4qc4xVeU4NAFaWoSaklOelRCgBVqQ daaKeOtFgJF6UMaFpWpAMLbUY88VpeDLQTapJdu5Tyhw3pnqfy/nWNdtiE+9dt4Vs2stFjfysyXB 389z2/ACqWxL3IvFt9mO3so02qzbivovasGQAyNj7uau3l2t5fzTb8rFwCe+O9U1j8w9hx3NYSep 104+6NtUBuS56LzWXfv5k7v2zW5L+4s2IA+7jIrnJiSTTpazuFb3YWGAErnqBVyMgqqjPSqkYJPF X7aP5cmuls5CxeMIbG3hX7xyzVnNyy1NL94moosGUbuF9hWcVZFzldlhaljGWAqJeKtQcBn4+Ud6 BEF443LEmT2xWjqpWGzjt1wNiKvHc1U0+M3OrR54VW3NS6nJ513jOfm7UIGRJwij2p+Kav0pxoEO A4pT0pB09qdgkUmUiu1RmpnqE5oQ2GaTNLTaAuFAooFFhoeh5qVuntUIOPzqXqtYVUezldTXlEFP HemDGcU4Vzs+h6Du1GcdqPxpvbrmlYY6l7fWgfWk7UrIBwoxx0pBS0gAYoxzQT0pBndzTAXvRRRQ ADpQKPxpM49qLAL+lHJoFLzSsAoopnenD+VMBQK0dIvW07VbS8HJglWT8AazhUidee9F2TKKlFxZ 9SQyLLEsiHKuoYH2NS/yxXOeCtRGpeEdOm3ZZYhE/wDvLwf5V0VenF3Vz4apBwm4scKWkpRVGYtL SUUAO/pRR2ooAKDRRigAoNFFAC0lH40GgA/Gm0vakoAbSUppKAGNXkfxWH/E1s+f+WPP/fRr1xq8 m+Ko/wCJraf9cM/+PGkD2Z5nIu49OvSmFfTtUjsFbGaM/wB3iq0OcRkLJ7VTOSfpVvLEgCoWUqGJ pvUa0IWLHFSxthCO5pMYTce/QUL8qg81I76Ei5R/mxTicn5TgmmNkMG9eal2nrt5PvTAVQu3FRvj 5V/hzSrkNtK05sD5scCnoLUsJGrJtX7uKFznafug0ifLHxkZ9Kkh/wBZ9wnNCQx4gUt6d6SQYOeC 1SyvsBKjJ6VC/RS3WmwHQOQWBFWgwdcVUVGzhSOfWno7KenApAWpQFVUznio4mKXEaDLZ/hxTXbl SOfWgTeQrOFZmHOMc0upXQmj+W6+c5UNVieTzpWCgBR0qBjuCbEO5+TxT/LLKU6M3c0DJ4E5w3z7 RS27v5hEg2f3ajUPEiqXXgcgGnxurOC5oY1uMncvcbNpIHJNBjUEfw59O9WpVJ6nBPSqcp+buMcU gAddmT+FWI7fzsE9F9Khj6qMr9a0FIih46gc+9MFuZblWkZEwNh5NSQZ35H3aB5YZj5SqGOSPU1I rgdF6UgRKy72G/oOaVWMnA6D2oOJMEZGBTIy6ux6KePpRYYjIFYYb3OakGMr8vXvTCuZOThvWp1T auDz9KEAkKsJGft0p5DvJlHzgdDTE3ZOwHnrSfcU8Ybp1oBEBYsxLHLYqLkgkHmnEHeM9ac6hW6E UgYRNhuakVs/dGarqAScDH41Mg/eKuOtOwXJD8q596cnzNnOfWlZG5HFJGgSTBbPtSGT9F2g4zSt EwdSPuimyn5sDAbqKcJeEy2aBkoHzAjqKlSX5GXdUSyZ6etPhC7mytAxsq+ZtJFSQbtrenam71aT YvHpmkIZBkN+VAEk2Sh46VXH3QG6VN5md2ec04xqYdwxRYCsJNv0pr7vvdqfKgG3FNaTAZCh4piY 8qp2qKkzzgVXRsBSDmpo5BnJp7CRMYz1PekIyymljcySYGOKUgh6BixfKeac4Bfnp6U5gAM/rUEk gJ46dKkYkh+Wq8T4kyRmpHJ8rjrUOGC9fmoE9yWQ/Jk0xm+6O1NRvkw/rSZBpoTFP3cDtVeRucGn F9p71FIwEg96YhCcD39hVSSBbhXil+6w5FXJcf5FVuePSgk5m+082Uo2lmiboad8nkLtBDqfzreu 4FuITFkc9D6GsNcrJ5bj94PlIrNw1K5rINYf/QI06ljuzXO9K39TBMUXy9OMisORSpzjFUCLek3H 2fUoZD93dg/jXpdjawSMp2Ka8nU4Nek+Gr/7RZQuWyyja/Peomu5cWdfZWsMT744wpxjgVtQt+FZ ds27Hp2rTiwvIogi5MuqakHXr7VXU81KprQgmBp1Rg807+tAMf19qXNN9PSloAXilHIpvWlzxQAv SlpnUe1LQA4ZFNPWl4pD92gEO9zSZB4pvaloGBxRn8qBR36+1AB0oJ4oNJ/+qmAueaaTzR39qM0C A00mjf1qNvrQAFuOlRlutBJqNmFMBwY44NFQlsnNFIk+Zx6V2XgEZ8R2PtcJ/wChCuNXrXYeBDjx FYn/AKbp/wChCmSz6mT7op9NT7o+lOpFC0GkpaACiiigAoFHaigAooooAKSiigAprdKdTT0oA8L8 b/8AI7ao3OA0fH/bNa5yZ1C5HP0rpvHSH/hMdUPbdH/6LWuSnIIbb0qfQCB38yRWHIXtRG2Jdn8P pUduPmOe9OYhHBK9e9OwkySUcimj73NSY38+tOZRtpDGrz3qNmHmUA7W9qbgb85oAmYjtTNmQaYc 9hgU9SRkgUAOABjPHzdKgLc4qRpPl/nUbfe4oBjs1IrflUQ+91qTjHSjzDyHE8cUgoUfNmn/AC55 p+QiJ/xNVpM5yBVzHWoCBk0AMBB6in9RntSMoC+9I3txUjBuOab1+YUO3FRg4ND2ARzg1FuBPX9K mbnioyv0oAcx+XNNz82aaaOAaQyQfX3qCc81OOKr3B5ouCRVamj+VBPNAouwHCnCm/56U9aLsB/a lFJ16CjpQFiP7Ob7UbezDbRIwDNjoO5/KvRby8i0/T3ZV2+WgXb0wMcKPeuQ8J2huNZkvGTeluNq qe7H/AZNa3iJzJBDZxjczvuX1OO5pvYS1Zhqp+x7mA3SvmpEQ9WPU/pTrkDMUQOAq81DAsrXDMD8 q/rXNe53pWsiTUM+Qscak+wrJNurA7gVx14rbk/eEOh+6eabIqFSHOVPWohU5dDWdLmVzCSHG4oc r0q0oMdqB/e5q5DbotrPGMFm+57VVvZFTainI24rrT5kedJcsim7Gki6U1ulSIMLVEEo+lSM7JEM fX6VGgywH4VJe8BYhUvUaL2jRhEnuWOCFqlIxlu2OMKvGK0YdsGlqAMM7Z/D1rLg53Mf4jQgZMB7 U7bx0oA6U4f/AK6LiG4wOlHNK340lA1YjeoTUr1CetJFPYWk7dKBS9u9MBtIDS5pKAF/Cpk+7UHb 8aliJzWVRaHbgqnLVQ7v+NOFI3Wl5rkZ9ZB3QoznIH8qTk8+9AzRzSLHdsUdqO1ApAA4p1HOKTP4 YoAXtzQetJk0UWYCUvakz0p2DtGR1pgAoo+tKMYpAIaPwpeDjFJSAUfSj0pelIKYCgY7U5etNHFO FID2L4S6gJNHvLE/eglEg57MP8RXpANeG/C/UPsnipbcn5buIxde4+Yfyr3EV34d3gfI5nT5MQ/M fQOlIKXrW5546ikpaBC0tNzTqACigdKBQAUfyoooAKKKDQA00H0pTSGgBppDSmm0ANavI/iu2NWs /XyP6mvXGrx34v5/tWx2f88Tn86T3B7M83DEszU5W4DAHdREOf51I20fWqtoc4i8bjmnHDpz93+d InTr8tGQEPy8DpQMYyblBphKqvUmp3P7rPSqDHc/AwPakOyLi8Lv9amhO77nU+tVfm2fe+WrkAAT PaqRJC5wxJ5xTLdw7MCeM1MxyzELxVaIbW6dKQ9LF7coKgfhVhAsKZYdTVNQZBkn7vSpvM80hcGq AsKq7ckk57VCfvEn7tJ8wPyvz70kpIU9M0DJImGcUP19AKqxtxkdasZLL93tQCRLbKztnPyg8ZqW 3AeVv7o9arIxYYLYHYVNaZWTHmAe1JjRffCJ121Ar7F3SkBffvTZZkkTBOcGlGyWPYyBmzx7Ckih ynzGJ4UfzpwHmNn+6c1M0K7AF49qaF2nbxu+lACtLlhk59Khddzc/jVnyctyelQTg7wcfu/akh2F hRi21R071aMgZdvP4UWRXymLfnTU5b930HWmCRVYHOAAPY06JhhU53GpJwqxs7DFR253RhgRn6Ug LCrtkPsPyqNzjkckU5gSu4tj1qupAPXimBMuSPrV+FS8YXpxVaIEx7R3q0zMirt+90oGOA2n0NMv CnlrjG4HrSSbgBmq8+c44oG2QMVMiuv602SXcPbNNkbGNvXvTY0OP6UWJJURXYHOKmclCJAPao49 u3Kkg+lB+fgEjFIZYL554FOC4iV8bt9VlPY1YjLFduenegZKFHLZ5xUOzZtz90mpNxxs7005ztJp DJkwDuz16VZjdaorx1/DmpoTnPrmgEWQoZtwGBTZCy9DmnKG2sF5xUJ8xWB65poGLgrg46mnhnBw emeKYgZp8E8fWpHYZHTigOhHKc/0qJWcH5u/ep5Sp4A/CkkCrCMdTTERMg25XrTohleRTWYjjGMi nx5280gHx/u2z61ZGHxioQB5fy1Oj7ewpgMk46nj0qqGw3NWpxvZeKrSD953pWGLLKmzpio25Smt jbnFIJMrj8qADGQMUh44NCHDAY4FLKwVhTJZWk9fSoycsOPmqSVuM1GDn5s0CGzN8tRj7vWpJTwK iOO1MRFI6qrZJ45rHMPmFbnH3s7qv3ufIcfxNwKmt4kEaxlchVpPsK2tyotvHNGYXz7GsbVNJe1t 1nEgdS2OnIrdYeVKUH8PKmpLiKO6tWjf7rDt2NFgOHrp/CV5suntifvfMtc9cwNbztE/VaksLhrW 9hmU42tz9Klo0Xc9osJcqvpW7E2VArk9HuAwXngiukgfpUxNDRU49zUifnUKe9SKasRMPzqTPOKi BpwNAiToaXd81Mz0HelHFAD++RSbqM+9LQAqn0opBSj6UAOx702lB4pB1oAD/kUD86PemnIoBD88 UppmfalJ+tAw/KjNGfwppNMQufUU0tSE4ppagAJ4qMmnFu1QsepzTAGYVE7ehpW6dqgc0IQcmiot 5opCPnMda67wL/yMVhzj9+n/AKEK5EV13gY48Q2PP/LdP/QhTJZ9Up9wU6mJ9xfpT6RQtFHtRQAC iiigAooooAKKBRQAlFFFACGkPSnU1ulAHiHjobvFupD3j7/9M1ribolBtBHJrsPiCWTxZqW3pmP/ ANFrXGs/mSruzwKhAwiX5hjirs946WX2R40Kb9ytjkVE8YRVNRsnmnDHFUIlVMDFPYbRTY4yq81J MMjI5qRlRvmOaYEbdu7VIT+lBb5O/WmADHWpSMJxVfkR5qRZBs5pdA6jCvJNMI+ap3GVyBVcA9aL AOTrk1My5XOaij4zTz1/GnoIUDilzzj1oH3aaxoGA647VC2M1Kq+tQSjBzmmIXtnNR7stjvTN5zQ 453ZxSe4IeRjjpTBjdQW6UHn0oAD97NR5+apF5amsvHOAKQ0N+Ug03aM9aD8ooHJoB7gKrztUznF U5Wy1IZGTzS02lH60APWnikXpS5o9AJB93P9ajkbCE1IOlNMMlzJFbRfflcKKAOu8M2CQaAruWEs 7+Y+PT+FaydQvDd+JtyHAh+Qfh1rqLiaHT7XzFX5Yk+XHp6/U1xtquVlvGzvYn8Kmbsmy6UbsLiT c8kg+7mo0uVjtjhstnoabPxb/wC9VWfyU2rExJJ5zUQimjepNqWhtWqAw7z1fmkkUGNl70lrMxUL xtA4qX5GPvXNNWZ2UpXVjM8yWCVT1Wq96N824dDV26TcvFZzE/dPauqk00cWIhZlc/ex71MtRjl/ pUi5NbHKTQ8Zb+77U3PmT5x0qR28qDA+p9qdp0RaZOuCeSKkZf1R/Lt0j4G1AOOpNZ8QCxgVZ1OX zJdgwctyR7dqhGMfSjoD3HKOad3pKU/lQAGmke1OppPFDBELVGetStUR69KVikLxSGimmnYWwhpO +e1B60ChjQvtSocNSUfxVLVy6crSuWT0pBQDlaQVxyR9fhp80Ex6j9KTrQD/AIUD1qDqHUCj8qBQ wEp1JTu1IBOM0h60tJ3oAPrTt3FNFLQAD+dL9KaKcKGAgPpQT/nFKRg4z+VGKAFBooFA6jnFIA/O nZx3ptOHpQBp6Hd/YNZsrvOPJmV/15r6VjIZQR909K+Wk69a+i/CWo/2p4Y0+5Zst5QR/wDeXg/y rqwz1seDnVPSMzeHWlFNFOrsPnwp1Npw6UCClpBS0AL9KKQ8DNKORQAdqBRRQAtIaKDQAlJ3paSg BppDSmm+v9KAGmvH/i4M6pYgf88v6mvYDXj3xdz/AGtYYz/qD0/3qQP4Web8r0pVLEHPemD5jgZ/ KnhGCq2Plb35qjAkjGzGTTjzyOlQh8vin9TtHTvQLqRSyfLtH41DGhJwOtT7dvYVEm7JNFiticoF Xls4p0Uh24/h7VWdmPy446VNGpDYz0oQiSWQomcdqjU7hnvRIS3yggnpTYIm8zYTnmgOhaQlQAQT TY5f3p2gnsac0bKGCH8abEPJQ7RnJqkFixNIrIFU/MDio5MYHf1pojPzPjrTcPuCnoe1JjJlKsyh RjAqyifU46VWOAy4qxGxXO49s0XGQyKGfHf2qYRuhA68cVAXG4N696nMu0DvikAKg5B4q1bMsYYk 4wKohyzcCtBUHAyucUIZPGCBu37mcd6iZm87GOlJGrIMscZ6Uh3k9BuPegaJi5C8jhqaAduzd+FN RiAEc5xUzbR8xXqMDFGgEf3eFUhR1PrU0UhA9u9QuWKjaPlIqNmG3gfWgC08wcbOoz6UsajftC4O apM4UKc9+MVZyqN5hJJoC5My4Oz1qFcRjGB+VMVyzbkB46VIw3N05oAtNO20s2XeTu3X601JlA+f JxVd1IRe7fypyyoGGcBcUiiw8ykc9+lVWOSS59+KJDx+lIi5OT0xxTERAj7xBqSNdzYzgdqGVeAD nPtTlI8wgdqBj1VVzk8rTCxD5HAIpXHO6hTucYGMDvQAinDfWplGHPORiq8nEmaliB20ASxfe4NP GWJzTE+XHy072HeoKJEUbt2B7VJaph2zzUZ+WMADJqxCmPm6cc0wtqICUZuuPap1OSPl7VGFG85q RQd3BAphoRyBlYug+lR8lsN94dasOSqk5Bqq5C7WznIpoQAgSHJzTZCSq4piH94SR3qQkNgdCKAH bGwGahMkYoZiTjtUkQUn5TxSGifpHwPmNNHzDP4VI3ylVx1FNYEJijYLIaCXYj0qAtiQjripV+RW NVX3HkH5qYvMb5nDVGDk+9OwVjpUj/iIzxgUgHkfu1x1qO4AOM1IzlRn0qvMcimIa6jbUO3C9fpT skoBUTswGMUCGSu27Gz5fWmn19qcTnioWJLgU7E3GtjfzjrUof5c1AQd4FSSja4FCAjmRnXcOo5F NhODjs1SmX92FxUR25AHeh7gY+v2+GWYDkfK1YQ612t1At3bMrjI6NisWXRU2Hy5G3dt3Sk0NM6L wrfb7OJc/NH8tegWku9Fb1ryvQ4JbCfDspVx29a9A0y4BCjPFZ7M1i7o6eNsrU4P+RVGF6tqwqxl hTTwRn3qBW7c4qVcZoF5kgPp1p1RjpThmgB/4UA4puT9KO3tQA/t1pR19qaD7UvSgBwoIo7UZoAD TcH1pQfSm96AFFAbNGDTT9aEAueeaQnmmmmk+1MBWIphIxTWPNRs1ACscDioy1BbOahZuP5UwB2N Ql+fpSljuqF2piuxWPPWiot1FSI+fR1rrvA3/Iw2P/Xwn/oQrkR1rr/Av/IxWP8A18R/+hCqJZ9U J9wfSnUxPuLT6koXtRRRQAUUCigAooooASlooNACdKKWkoAQ0h6U6mt0oA8E+IU4/wCEz1OLH3DH 2/6ZrXIwjcWPauq+If8AyOWqe7J/6LWuVth8vSlsJlguDgelLKY9zGINsz8u7rU0UasAwpkgUE0g GJIePr0qV2LLz9KgA+bpU5Usw9KTGiEqAMYqFjg4q1cDbtPY1XK9/WqEwI+Xim4wMYoZuaQL5hPX ikMXLAdacCaQj5OlIDt5pagPwKYxw1SA85pjdaAJk+77VETjI96XoKiPJoAsL93NV3XeypkAk4yx wB9aex2rjNQs3GKoRFjlaH6nrQze1L1xSAizjOe9OH6USDnNNB9KBDwPm6mkP38HNAPp3pG9R1pM oQ4JxxTAcChjmo89aAFkb3qm/WpmOagbrRoA2lFNp4oGPHSigHik70gZOvNa3h62M2rpOUZo7cZO O7H7orJjGa63QbVorHzHwjOxbdjovTNAh3iK5WKweDdulmfkr3x/QVz5BS1jiPDMeRVnV5zcaxHH 91YxtAzUN2w+0Y7IKxqPodVBaXM+8PO0dqoA7rgemalncs7MabZIZZmxW8VaBhN807mzApMfBp8R C5Bb5s02xdUkKODtamXOIrpGQ5WuacbnVTnYW4ZUbaW5rLkQbmYHAp90/m3LMOnQVARmrp02lciv WUnYatTQjLr9e9RYqxbcZcjPpWzOUW7OWwD17Vc0tRudycBFrMYmScscmtexCx2bOf4m71IyrOd9 3jG1VHApw4NQxkszOTyTUveqEPFLjPSkFOHp/KlsA3n86acU5utMPrmgaGPwai6tT2pjAAj5gcjP 0oQCmmGnZ9qQ0IojPWgdKGxmigSF7UhpRSN7UDJoTkU+oID82P51YIrlqKzPpMsqc0LBRjigUA8f 0rE9hC0o6ijr2xRj1pAA6Uf/AKqBR6cUALmgmjFJg/hSAUUZ4ox060pB7k8UAAI/KkJFGKXHtQAm elLuox05oxzQAZpQaTFAoAd70Cgg5waKQEi17J8KL8TaJdWZPzQTbh9GH+IrxpRyDXf/AArv/s/i WS1J+S5gIxn+Jef8a1pO00efmVPnw8vI9qFL36cUxelPFeifIsWnDpTadQIKWkFOoAO1FFFABRR+ FFAC/nSHrQaKAEpDzRSGgBDTTzTj+VNNADWrxv4wE/2tp4A/5YHP/fVeyNXjvxcTfrenj/p3P/oV IHszzboKeUJVQv404L8/BPFSAbWC9ao57kIT95nHSnuxRPc9KkYHdiopUcqA/X2ph1IjkqtPG0dM cdaFRhjJ6U0bQ3PegPINymTp0p247SMgU3K79ooZR8uGoAAoUbh94VJAMMT70Q8/e/OpGGBlRQPU fI6hcZx71Gr/ADqvrUMkpPLoAccYpLaQCVWPJpXHY0mHy4TOe9RqwQ5blqsKflziq7oC+7FHUZLI u358c4pifOcvwKEJJ+Y7vapAEU88DuKdgI41zJyMAVJI24bVXC96aEJXePu/WrEaAAsTnb+lAeZC kJzwelTIWiKl+cUwSruwM0+TO3GOKQyYSZcMOF29KmX5hznjuKpxgr/D19asRlvWmA+MFs/L0qWJ wpxID7e1NiZRy2eTUjFGyRtx6UhjXkjKfKOR1qrvHmfLytT7BGhJcE9MVWG1ZuPSgY4YIxxxThgv t9O1Rx8/P61YQBAcr830oYhsR/fYxx61YIO5exNRwAg5x941I339x69KBkkkuxOOaqs2R05NOnYn p+NV1JaTBBoEWNx8rOM4poyRhSKaGyAKk5AAAFD2BDQGznk4qbhRkjtQeF4qMbmXLcCgdyQsHj3D pUfGakjKlRx8oqD5TIwB+XPFAyTfxhhU6nCgHFQKpKg54p8J+dt3PpSAmRzuwfwqUczLgfhTDGGY FakjISXNSWhrjM3T6VahTK7icY4qIFDL8wqRTgbe1NiJVIBbmnK2E35qup5Y449aXJ29cDFMBplD Ng9KjZRzzxTDwoNDsHUH0qhDgMBRnk1IQpPXp71GBvXJ/h6U5eO/WkCRIR+7zRCCsoReRUeCE4NT J8m1vakhlliSc4Py0E5HvSo2UJzTF+UE5yTQDIW/2jgVBwH9s1LI24moExnFMQ9xtZgOh6UvRelG NzZpz/dXtzQhELcLz0qvKwxUsvznbVZ85xQIjL7hs5GKGBK04KN2aZnBLZNFxWGSYG0A81C/38ip AoL5pzIMVYiujYkWhyfMY0RrmTJokbbn3pJCIutIxB49KSk70METRuQcnp0YVHINhwenak+63POe tThPNi2n7y9KQyoG5BHbvXS6XcFwvOMGuZ74PFaWmS7JNuaip3Lps9BtpAy8VoRnuTWBp02UraiP FCNGXAakXrxUCn3qVSD+dMRJk9KfUQPpTx1oAf1NFJ0ozzQA8GnA81GOtO6UAOzyaQHjGaTPFBOP amA7gCm55pM0zPPtQCHljTc+tJmmFqBCk0wnqKRjTS3GcUDBic5qJmpWbtUbNjtTENL1GxyOaGPv zUTGgGBfj61C/NKSQOKhY5PFMQu4d+aKhPXnrRQI8IFdd4G48Q2J/wCm6f8AoQrkyrIcMCDgHn0P NdZ4H/5GCx/67p/6EKQmfVEf3F+lPpifdFPpFC0UUUAFAoFFABRRRQAfhRQKKACkoooAKa3SnU1u lAHg3jvyv+E61LzlYx7492P+ua1y7KiuTFnYTxXUeP42bxfqh/20/wDRa1y5hcRL2ApAWFb93gVW 5kkb2HrQrELg01OufelYVyVQfTmpEPz0HoMCkc4IPFAxlz90VXLHdUjsXkwORVdvvgdqEDJFPzHi lV8FsdKXBHeoxwOaAHk5PFMY/PUyRgrmmmL5qBDSaTqRSsmB1oU4HP4UDHOfk6cfSoxhuKc7cYFN TrQtxA4OcVDIuPXmppOtRtTAjC/Lz+FNHDc1JI2F6dahzxn9KPMRI3Sm4HpTQMtmpNopDACo2qYA bqbjJpAQ4/yKhbAqZxzwaryfpQMjaojTzUZpWBbCd6eKj704dqdhj6UdaQdKcvWkMs2kbSTxxqpY swAUd670Rxxwb3ISKEcg8BmH9BXNeGYC91LMP+WSE5K8L71o+IZXi0hlwVMmFAPVV/xNBJz1qN97 JcO27cxIJ5702ZsmWQgcmprcJFa7ict1qheOVjC+prB+9M7V7lMqT4CE561Lp58obwMsTVSUnAFX 7LC7T6V0tWONO7LZl/0lQOB0qzqZjhjV0wcjis9F3TM2fpUF43ITJrFxuzZS5URpz83rSkUqDjFB rQwbIzVhcLb9BxzioVGXAqSZyF2DgN196GBHGOMkda2bg+TpqpuOVTv6+lZlqhknjVR1NXtUfonq eB6Ci2odCnEMLUgFNA4p9DAUdaeOB1po96eKBiGojUrVG2KAIWqPvUrdKj70hhQaeOlNNMCI9aQY weu6nn6U3FAIB0oNLSH+dA0NRsSCrnVaoHrV6M7krCsup6uWVLT5RaKDQOK5j6VCilak70p6UnuU HainCg0rgJngYNHpR3FBzmgABozSUoFAC4o7UcmgUAFFA60p9aAEFLQKB0oABSjigY/WgUgHVr+H b86Zr1leZwIpVLY9Oh/SsjripI+TjpTTInHmi4s+o0IIyOh71IKxfDN8upeHbC6U53wgMf8AaHB/ lWyK9OLurnw04uMnFjqUUn86Ud6ogUUtJ2paAFo4xSUtAB1o/GiigBaQ0tIaAG0hpTTaAA02nU2g BrV458XD/wATqxOf+Xc/+hV7Ea8Z+L2f7e07jOLcnp/tUgezPPJH2jctNE2RkdaikPYU+JcmqMLF 4OWjGDmmE4U5U+mM1FG7RvjHWpiwkj+lMRCjepqBw2Tin56mo2+Zv50hjVViwq4E/c5K9KS1GWO7 tT3J2EA96Olx7jIjztwMVYkYdOmfaqRLxt71OjNJktQFhrqxBFRR485ecL9KsliFbjiqjfK31osM uxu2fl5pZHZehznvSQyBVCnvxTmKrkYzTuhD7dX+0eYfu4p0W6VyGPU81HBMzP8AMuFFWYU3OxGR k0XGkSDHTHFVzMyll6EnmpypL8OF5qGRR5i5oARU4BPrVsjMQGSe9VMEk/PxUqyHdx90UASPv2qc 9Og9KlR+nXiolY7z3we9WIwxyeB9KBknJzg8dqbnpt9eaIjtfONwNOZOcAY3dqT2GNbdJgHFIQN6 5BG2pFQ9R2pVwfmYcUdAEO0lUxgUrrgN1JqElnl3DHy9qsSMQqkn6UMERojKoJz9BT85X5jilLL5 War53d6LASqcJ65pvZiBxS5+UKcUBieBQMSFDnJHepHX5/TNPxtVSO/Wo3bODTEiRPQ800sX+Vvu jpQONpFNkJXHPX0oGSRYyVqrNxNtHap1f5cqTURUbmY559KQEkYCqFz161Mu0q3PPYVCq7yDg46U zcfMwo6UAaDf6tQp+bHamI2wYP3s0xSSvvSBiu4t1pFXLCHLEP06VJuHRT7VVt2MmcdamUFMvxzQ CJ+Uj4P4U0PhMkUzzCVxTg4YbOuKOgxpO7AI4puzDdhTnXCDmkVPk30yRPm7Hg1JhUTJqP7vIpxb cuB0NADo3jaEgn5qlX/VcGoNqBWoWUhMA0uo7k0chXGae7KGB3daqIcnntUzEMypimAr8vx0pgTG cdqXkHFGcAEDPrTFcZHlZKlmI29OtNz82KSUEn2xSuBVZvn2jvVWVwrcHipWPz1E6hv6UCDcfLBz zTDuPy5GPWmtweKQknAFMRLhVXrTCynkHNKQdvNQH5AcVRIFxjgflUe4557UDgZNNc+1AhM8/WkJ AX3qM5XmnEcA/wAqQwfFLFJ3zhlqJye1NU4ww6j2qX3DyLUqiQeavfqKIZNkq4Pei3kB4/hbg1HM hil9qTKR1+mXGVU5rp7eTcM1wel3HKj0rrrCXKrg1nE33NlW4qZT7VWjY4qZDg1oInzgU7NRCnjn n9KYh9ApKUUAOzil+lNH8qXIoAceBSZ9aaWpC3FADs+9NLfzpuTimk+9ADj97rTSeOaZu60me9At gLelNZuab3OTUZb07UDY5z9KjY5oc81GWzTQmDHmoWNOY571CzUxDGY1GW4pzMCKhY4oEBJPSimb scE0UCueHZJOTXW+BiB4hscj/lun/oQrkR16V1vgj/kP2P8A13T/ANCFJIGfVMf3F+lPpkf3F+lP pFBS0dqBQAUdKKKACiiigANFFFACUUUUAIaRulOprdKAPCfHR2+MdU553p/6LWuZLHb8xzXQ+Pnx 431QA9Gj4/7ZrXMzN8vSp1F1IWJBOKkjU9e1Rx/NgVcVcLQA0sCvSo2O8GnNkHbTdn60AIEFRFR5 mfSrTRqkdQoPlagY0kEfhTUIx6kUdM5psYBY0CLEa9wacTxTUbtTjyDQBHJwtQ4/KpHODtpowVoG Rt1qRaa4560gNNCFamtyvGBgUZppXkcUB0Gt8w5qPGO9WDnGMVC+cUCGjFBJI60J1PHWkZsN0osB KoG33prrRuxTgN3NSUV3PH0qs5qzMMD8aqNRYCNqj+lPc96j70AHenrimU4UASLz1p6rTFyDkVYt Y2nmjiX7zsAKVgOw0GBYtDVwmZJX3/7/AKD6Vj+I7iSfUY7ZmLeWNz+7GuvlRIGjhjYqkSbemNi/ 4muEffNezTsc73JzUyfKi6cOaQ6VQsK8Y3Gs27GWGTWlOQZF9AtZdw/716zoq8jpxDSiUsbpsVqw psg3+tZtuNzM1XLiQ+WgU4xXQ9zkWxYTaMsc1Qc75RirbOFg54OKpwDdIxqC3sTAYFNP5VIelRnH amZvckt1+fpn0qGbmc85xxVlQEh3k/KRzVJfWjzDY0tMX980mR8gzTbxs3KqOijr65q1pqYtJXK5 3Hbj1rPclriRie9CBkgp6/Sm4IODj8808flTsAvanDpTR14paQA3So2Oae1RNQA0n6VF3qSmHrQU Oz6U00UUCGnrRSmkoYDf60Gimn9KBkclWbN8oVqpJTrR8S49amavGx0YapyVUzQOM0cdqDTc1w2P sKbuiQUU0GlzSsaju1B6UztTuM4pAOPSmng070oP4daEAi/Sl/z0poz2p3ahgAooyR078daO3Siw Ce9L+FN70+hgAoFIKO/SiwDlXLAFguTyTRjDYzQfalxSABUi/e44qMfyp460xM9o+FV+s3h+azLf vLeYkD/Zbn+ea9AFeLfCu9MHiZ7XI23MDDHuvzf417OK76DvA+RzKnyYiXmPpelJSitjgHCiilpC FooFFABRRRQAUlLSGmAlN7U6m0AIaSlNIaAI2rxv4vca9p3vbN/6FXsprxn4wD/ieaf8uR9nPP8A wKk9wezPNm6VNHwuc1GUzTrf7y9yeKowZMkZY9KYwx/FhR+tT52nHQn0qBhmTGKGA1uRnHSmuMDd U5TEdQyAjigFcmgGI8560OSq06IZTio5v7tPoA5VDY9alkwkeRUEBP51NPyu2kMEdfIO7vVSZ9vH GfpStnbg05oMruPagB8SEru4qzKUEWfWq6EALntRKS6hV6A0BcsQlFX5iD9KlBZXVlwF71VgOOcZ x7VbO2SPc5wBVAOfkAock/pUbuGKrgehNNUlXUbqXjOVHzGkPoM2tG3JypqRGx0+lCxseM1YaAKq YOc0WEJEmWBDYz61dXaAEz15qusilQMYxUjbiBsPOKOg1uTKw71Mfvcc1V2HChT/APXqaD3Y9KCh w3Atjjd1ppygC5pHYbuc8dKTzMtzQtwGupdumPeoSWHyEk4qaVjnlsVGMkg4zxRYVyZsFAOKE2t0 qFciM+meadETjkUDJCp3DinjaT8tMIK9c1NAUY5YcAUDDPybePao22oF7mnH/WNg075NuTjdSAjZ gXzzz2qOU7gDipHUduv0qN2+QcfUUMY3fjaF6VM/94AelVzyV+tWtqmP/dpIZLFhkyBjFIqL5nbB ppkOMDrTC4V15/KgFsSsGwxHaoyGKg4696dKzlcDv7VJ96AIOMelCQmNt38t+nWp9plJA6UxYk2f exUiyPH9zvQNAMBdqgULgLn+lC89Rz3p0gHygCmDHEDyySevamK3y7AajZmzjPApd2TxTEOk++FH pQrjyyPfioX3SSK2/aq9R607buHy0l5CLCBXG3NQyptfk9aRC+KfKNwXuaBjXBC56c1JCfmyRQxz GoPY01WxIee1ADwWMhzS/Nk+lNHK/jTyRjgdKYeYwD58moZWZuhNTBsu3NNI7imIqsnGCKjx27VO xDP7VCxVG+akJkEyEVGi/N1P41Ycbm470zaMkZximIQyA4AzxVaX72P5VKy7V4qux5zmqJYEdqaB nOacpymevNR+Zg5osAxufwpS2FprH5smgZbjtSYDWIK0galYAHFR9DSAlV9jA9u9X1Czw7DgkfcN ZuN1Ptp9kvllsc/LUMouWcrRT7H4INdlpswITFcjcr5yLPH99fve9auj3YIC7ulZPRnRF6HcRPwP erCt1qhbsCoNXFPFakllT3pwP/1qiHSng5xTAkB/OjPNMzzj0oyKAJQ2BQSM1HnigMKAH59aQtgd KjJ/+tTcnqaAHk03dg8Uwnn6UmRQBJkUzPamFqQnI60wAnmozQWppPp+dAATUWTQTg01j6YpiEJq Fzz1pznmoiRkmj0ENL4B71C796ezVCxB7cUyRpbJ7UU0nB7UUwPFRXW+Cf8AkPWP/XxH/wChCuTH Wuq8FnGvWXX/AF6f+hCoQM+q0+4tPpkf3BT6RQtFFFABRRzRQAdqKKKACjvRQaAEopaSgAprdKdS H7poA+f/AB0mfHmrEZPzx/8AotK5u4XawVeldN4/l8rx1qYXn5o8/wDftK5V/mbdn5s0rCJEHl44 96m343c03aDHkmq0r88HpSGTB/mxSMSJcU1Gwu7HWiQ5UHigBzybwfamrIRgVEhyaQghi3amK46Q k8dM0+Jdq8mokbe/04qww4GBxSsMYCSTU8XTmqrBo+g4qwv3eD8tMRHcFd1MTk8GnNGST6U1Rtak MHXGDTGB9KdI5bg00525pisJ6UgkOPpxTSTu5oPAzSAl3Dy896i79aa7YTrTS47UAPAAHWqzn95u FTL92kKZPNP0EIDmpkYAVCo5xQTt6UmMbcOKqGnynPPvUfalsBG9RmnPTaLDuFPFMFSAYpMEOH5V ueG7US6mkzDKw/Pj1PasRevSu18P26W2lGeTJNwecdlHb8aAJNdvGh0uSWLP7xvLUn+Inqa5ezJO 3d3q54qvZDfQ2uAqxgOw9Ce35VUtGPll+OBxWdX4TfD/ABDLiQb2NZcw3Zq5dE1VlX93mnRWlwxE ruw23QhPrU5QscehpIMLGCRU6sMbveq6kdCtcEggUW4xHuPc025YFqsRriMCmSxppijL45qRhxT7 ZTuLBfujrjpQSJeuNqxxr14x6VSXiprokzBT/CKbCheVVAySelMOpt7vs2kbEADbNxb0z/WsaPit HVX/AHQD92+Uf1rMU0LYOpYBqRTUaipF69KAJBwRS5pMdKG9qAsNY1G38qcSaYaQxjU360400gg8 g0DFopaPwoQmMPakpx60lADaYRTjTTQMhk6VHE2yVWqSTpUB61Qk7M2VO5abUdq26Ie1SkVwTVmf X4Kpz00xRSikFH41B3js8dKM0mKXHvSsFh1ApvJ/GnUgACj8KQe1L9KGAopO1APHSkz7UWAUUe35 UgpaGAoo/nSA0p6ClsAvaikxS0MB3anU0U7jNIRveD7z7F4t0qcnAWfax9mBX/2avogelfL0TEMC vDDofevo7w/fDUdCsbvOWlhUtj17/rXZhpbo+fzqm7xqfI1RTh9KaKdXWeEx1LTRS0hDu1FJS0wC iiikAUlLSUwENNNONNoASkpelIaAGNXjnxd/5DViPW3P4fNXsbV418YGK65puB/y7t/6FSB7Hm7H DYBJGKlhxjOOlR4wnvUq5QcHORySKowCaR+CP1pkDFnJ4pXYAYGORQowuVBPsaEBI0hG4beKjVGk O45xUmN5DfhS7dvHvQBLgKvy1XkRi3TBqbv8o4FI/A5PWmBFFkKxPanF8kZ5/GmnG3b0P0qGVijr +nFIZYcr5eQM4po+cZ3c5qszsVHrVhY2SP73NFwFKhSSfxqaNAyZHeosbtvNWI1Kpj+lAEYDBgBk 89Ku8gjptx0qk/mQs3v0qzavvDF26etNBYleJTh84bFVsfOOvWrEpG4E/Sq7Op4U4osMuRsqn19q UMrHZu+brUUY52/jUzKqcx/ebvQCEZQjYUcVOhzGxGM9KjxwM9aFG0bVPWmGxbgX5d+KZvKuu1fm ZuaakzeWEIA5qRSoB6FqQ9AuWCvwc59KjBBzRjlmZu3cVGCNmaEFyw0ZaINULEqcgVYVi8WzOO1N K/JtPahgkRHpxT0BYZ/u01sce1O58vjvQhjkyc7ulOC/KdtR7iMAU532jHOad0IU4Vck8mkGd2DU cjY25zToh3NIZKzbUzzUIDN9McVK/CYLdegpscRbAz2pDIF/1tXUOIDUJQebj071O3ykYFJDuQIS 7Ywd2KkWMFg3cGkbdCSwHJ4pIz/Fn5hTsCZacfr0oSM7uv1qrHI7k/N8o6VaSX93yMsKEAZ2tyu4 VI0oWMHFRg5UbjjNNPTHbrSGSiTK7mwPSkUh+tNSId6M4YgkCgbHPtpnI6HNOA3BjTThU4qkiBEV j1H3qkjzEee1SIyvtVB71DIWDMAOtIbJA/GcZok3CEN3NRqGVA341Nu3gBqoRXDljjFN3fvVz0qS XCHC1DyBu98UhF6DGG9Ka7Y5ApLdhtA3Z45pZ2UYRe9MZWLNy2ck0pYiL+dOVcrmoxypH4UkIbEM c9aq3CnzM5qUyCNsVA7bxT8kBMn3MntUByZsCpVfEXJFRjnle1FhXFl2qnuOKpbsg1YlI+7n8arl AOnrVdCRgbHBpGIIpDy3Hao24NINR5O7oKTnsaYCVOQaC3FAgPXrTT6D60Dk5pGOKQDw3NQzf3l4 NO3DOaRzlelIdy/pl55g2t24YGrSYsb1XU/uW6VzqyPbzh1/H3rct5UvIAhPyt0Poaza5jWLsd7p 9wHiUg9RWqjetcX4fvXCmB/9ZGcHnqK66KXeKUHoaMvK1O3VCj4GPWl3c/0rQRMH4oJ4qItlcelK D8vNAEm7tilJwKi3elG7nHegB+7imluaaxOeajzzRYCTd6U3dTCfemsaLAPLDH1ppYVGTSZHagQ4 00tjvSZ5pvbvTAaWyaazc0EjNRsccUCuDn1qJm9DQ7Y6VE55piEY7qjY+9Kx71CzCmIGbmio859K KQXPHehrqvBn/Ids/wDrun/oQrlR1rqvBp/4nln/ANdk/wDQhSBn1bH9wU6mx/cX6U6kUL2oo7UU AFFJ3paACiiigAoo70GgAzSUUUAFNPSnU1ulAHgHj858dasQPmV4/wD0Ulcu3Cl+K6r4gFV8c6qG /vR/+ilrk3b5WwOtBLAucY6U0xA9yc03ghc/eqRKLDQZwuOeKC244qR0JHrTVix+eTUobIAm3pUm 7jGKkkG04HNREcZp2ENTrkVYR85FQqmBTkUhx15pBZkjt/DUg/nTDjfz1qUr8vFAxrHbkfw+tRn1 FNuS23C9abFnAzxQK4MM01hwKkx61DIG4pgRvzxSHgDIpXGD6052HHy0ARswPAFI68cUhPzZxTjj GaQAPlGabnB7UAZGaafu0CHE+lRyU6o3oYIhbmozjFSHk1HJxSKIT1pKXvRQAg61KWLnJA6AcDFM GMHOc9uKctFgJ4Y2kkVE+8xwB716MkIsI7WHG9o1wg7Fu7Vx/hm1NzrEbEfu4R5r/hXSaxffYdPu pnYec48sA/wZ6Ae/ekg8jitSuPtuqzTdmfC/SpHOyEIO5qrbfPICRVuXHmKpwQKyqPWx1UVZXKsj EtVebPmAc7avGEHc3TFVlUPNjrWkHoZ1I3kWVtg1uATijy/LiqdfmDe1VJt32aQns3FSmDRTH7yY fWtBRxVG0GZCT2rQ7VbMiFhViD5Y+T79f1qLG4qAO+KLwhY2Cn2+tIChnczMe5q5pibroH+6M1T7 Vo6ZGdryZx2qhIZqbhp1XOSOSaqgc06dt9y5xjnFNFAkWE6VKKhU1OoyKAHL1oP50D3oYUmMjbPS m080wjihgiNqbn5qeajPBoHYfSHpQKDQAlJQfekzQMQ01qWkNFgW5BJUJUjqKmkqFifWmhFuybHF XTWXbPtlFaeeM1zVlqe/lVS8eUUcUdKTJzRmuc95DxijFIKUntUjHYpMUo6009aEAoHNL/kU0UtD AAKAKMj1peKAE96MfWl9KBRcAH0pemKB1pPegBe1KOnSkxS4pAL2paQfpS96AJk6jFe2fDG9Fx4X 8gk7raUp17HkV4gnBr0r4UX3l6peWTPjzow6gnqV/wDrGtqLtNHm5pT58O32PXVp1MHSlr0D5McK dTRThQAU6m/55pewpCFooNJQAtJR3opgIaQ0UhoASm0ppO9ADDXjvxdYHXtPTr/oxP8A49XsbdK8 Y+MAI17TSP8An2b/ANCpA9jz5xgZpkW5sj+dD5OD6UISpU9qowJDGDwGHB6dzRkBsLmpFwVDjjNR xpukaiyEWFTcF9qaVfOcr96lY7QuP0pp+ZsfyqgHbtrf7PemSHLBzkGpAMLjPemScngUvQBEAIzT XRWbdinp8owcUkyKjAMeQOMGi6GkJ9nRF8ylbLr05pqOxGwqferAbt69sUrDI41CDH86sKQWAIqC TGPl602ORifp3qhPcfPmWcjPQ8U5wIsKuTjjNRxb2kbJHqKY7OTgEfMeaLAWXLGIMwyfQVCqktvK 4qQoUx8424ppbL8DgUh3LiqVC+9P8sjv/wDWplv+8Ck9hxSs7bu+KYDtw/pT0jP3gfxqPCMenNXI CCg6UD0I4UJlw351JIAkkZXB7nFKeGPNMVWERdiDn7o9KAC4H7vcCQpqFeW3bQPYU35mQ7j0pIiW LAdKALKn36U7JJ+tQ7eOv1qwihxxQxoZ35qNywGF4qdsDGBUMmTjbkUrAEX3lLelWGIPJH0zVdOv PQ96kUHB3En0oGQhc/e61J/CD/DimMGDAACng7vkOOtABw341JCvC85pQqKxA6CnKNrnt70XAlQA sQfrT2ZQQNtMhJaTnGB1p9zglREMmgY25I2KRzmqzYQ7R171NIMwgN1FRIvz80APhGOMZFWguWYf dzTGAVAV49aVX9RRYBp+ZgT2py4znPA6U1/l6etNUNuKt92kMsM3yr61C5BanqPmUHp2pjn990HF IYD5Qcd6eE3fID26mmqNx9qc+6MDb1zTWwhLclGZe9OcFSvGaagKtuNSu43D6U1sIiLk0rZ+8DSj OMe9K4+WmJkM3ODQQGipk2ScdhSqp8oe1AD7fpipiuW3Gobdl3fSpmkXaadhDVI6Cq8nyNjPvTwc HcRUUr5/CkBVlfcc1CxJHFThN8tRTJtlwvSiwDQcDB61OrBIuvNQMg27v5U0vlcUxMax3SCiThcd KaeGFRyP8x5ouA08UxvmAHenDoM0wH5iaBPcaeFpoHfHenNimMcHFIRKjbTnH5imO25sUw8D2qPP OaLgSAc0Px+FNR+eKUnn29KQ2Q3AymfQUunXJhl2EnaentTmXcPrVNo9vT8Kzlo7mkdVY6iK8Ftc x3a5wOHA9K7iwulljSRGyrDNeW291vj2P16Guq8N3fky+QWHlnkAnoazlJKRrTu1qd2DxTw2aqwv uFTZrYRLk0A1HuxxRu5phclydv40A8k1GGoz70xDyfzpu6mFvypue9AXJN3am5pu7mmlqBjiaZnj FIWFMJORQIViKbuH1prn86aW6UxDi1RlqazU3PFGwgZuKjJ/Chzz1qNz6dqYhpNQs1OZveoWPNMQ Hr1oqMnmikI8mHWuo8Gj/ieWYH/PZP8A0IVywrq/Bf8AyHrP/run/oQqSmfVcfEa/Sn01PuLTqRQ tFHag0AAoooFABRR2ooAO9FFBoAKSl7UlABTW6U6mt0oA+f/AIgsD481XOPlMY6f9MkrlpWVs7a6 D4i+Z/wnOq/3fMT/ANFpXNx5280C6gF569DU0f3sVHH0OeKfkg8ZpCJJHKjOOlIJsnpwahZtyc9c 9qeAAoHI9KPQYuctntTHYYJ/SpONuM81WUM0uCePrQBMmXWpC+Bt44pyRgR1XYEscdOlIY9znnB9 KnydgqsBzVpcFOcYFAELdPrSoAe1RvIGc7akj4OTQKw2UmolJzzU83NVJKSGSN8pqJh83FOU5B9R QBnpTEVyD1NOTvT2APApmcdeKAHYytNf7mMUHIHFML880AJnjNRO2aex464qBmoDYXPFQyGnZGKj agCOnCk706gBBUgpg+tPUZIFIZ13heJobCWZV/fTuEi3dMDqfpVHxjcIpt7NHDYJkbB5PbJ/Wukt bTy4IbRDt2wgSv8A3P8AZ+prg9XmF3q9xMrZXftXHoOKAsMsutPkmC3LKe9NgwvWo7sZ/eDtWUrc x0wuoks0zMm1RwabECoZu9RpIHXjr3qUEBSOc+1F+gNdSaxLurM+eTTr04hx6mo4pwiCMetR3rdB mn1J+yJaD5C3qasnp9KjgG1FFSk5XFWYjY87tx6D9ar3J+dVY5bq1W0RkXcDgHqfQVRchppGH3c8 UCexG1a1swhsUcLlhlhmsrGWA9TWlfSGOyCLx0U/4UwMzJY5PU08VGPpTweaYrky9ferCelV0qwu P/1UvICSmmjd2xSZ560h2GHpSGnNimE0AhpqI9alNRnrQUFO4xzTadTsLYY3Wk+lOPUU2lsCG0fW lppoGRSVXbrVmSqzU0JiIcNWtH931xWR0rStGyi1nVV0d+Aq8lQmP5UoqWVNr1EK42fVUZ88ExRm nUnAHXmhulS9zUXtRk0g9KXHNLYABPQd/alpAO+OKcKAGigU7FHt/KgBvpRTqKAExmlxSij04ouA Uo4OfyopR7daQAPWnmmg0Z5ouA9R7dK6Hwddmy8U6dLu2jzgrfQ8Vz4/GrFu5jkVx95TkU07O5nV jzwcT6cXpzThVHSrsX2l2t0pyJolfj3FXhXqJ3R8PJWdh1LSDpTqZAUtJ6YpaQwopODS0xAaQ0Ut ADaQ0ppKAGnpSUppDQAxq8c+L0n/ABOtOQudot2IXdx97rivY2rxf4wc+IdOz90Wx/8AQqAexwPl gjvzTQOcelOVsjPakDBX571RzjyWAXdTAeeD+VJOTIRT4V3MBQIVOXwTUxA4x2qGYbZPkHNNDux4 FPYdiyzE8Z/CnKAePaqwBVxk9amWbaQOhNACuuF5zUEvz9fpUkkgZsVXc5f2FJjBd8a7c8HmpFII 3E8+lRjLD6U8YXaaSB7Cn7uBn60wMcbQMtUgbjBquX+brVBboWSQqZyKZEhL/wBadlOhpQq7geeD SBFh1+TPU9KrRKWcIoPXqKsPLgCmQkiXfj8KOoy8rLEGRWy2KjDhc8UiSB5NxGOKcygpuJp+YDQ4 UDBznvVmAiqu35APWp0YIuM0w0Hs525/CowzHjOMVJOPkxUS5GM96AHlAw2Z69adDCsMG0DOakhI 28L8xoIPJP4UrFCjpinxRqwO47ajHQE/jUwX5cD06Ug2GfeJCg7fWnFQEz6Uxcr7U5iNoA/OmAzC +VjvRGfl9QKRj6YGO1ACgcNyakbHScsD/LtTDn7wP4Uso2qGLVEDhvf2piZZU7uG7VIW/eYzxTYx 83bk80HAkbFDGiWMA7qRs5+XNERIHzYprsKWwx6enPNKY0Bwe9Nib5qk2ZbI/GgZIUHlFcfLTuSo yOKdj5VBPUUwnDeoFUICATim4Cdae2Nu7NRspcAipsCHBiAGxntUXJq3HbDYEySepzUMybGwtBQb v3WFFNLkMq85oCFVUmljy7nv60yR6gty1KyE9R06U9Bt60jnA4psQsZAj/2qa3Oee1JFyMGll2qc D8RQBRk5b8asRcJjOajxuJ+tOD7M8dKEARhfM4/Snbct9KjBAQ880RvnnFMQ6Riq1UV9w5qVm5Iq oWwDz1pWAXkfMpqF2Jfk/nUm88VHLjrjNMQ4v8m0HNQnpz/Knofk461HI3ze9AmMz81RtjfTlHzZ qF+Hz6UmA5ziP+VRs/OMVGJd0mO1Ob72fSjoIfkBaj+tKDlTzSdRzSGgc/lUTe1OJ5pr9c0PYAQ+ pqTqM9hUK1IH4ApDYdsVFIuY/en5po96GtLDRWXIZTWjBeuhG08iobm2xCtwn3T972qunt1rlku5 0RZ6rpF59os4nz82Oa1Fbnk1xPhK7JjaFjyK69D0ram7oUty1ninA1Dk+tAatCUS5pd1R7ueKaG9 6YEmeKQmmA8009T6UWAeTTc+tMJIpuePx4p20ESZ7ZFNz7d6jzjvTc80AOJzTWIzTTxTS2OtMTYE 1Gxoc4FN7c0xATxUbHmnEgZ7VEzYoYDHIqFj/hTz1qJj2oJYm71oqEnJ6UUgPLh1rqvBpxrtn/13 T/0IVyorqfBn/Ids/edP/QhUqxTPq2PlBT6Yn3RT6RQtFFFABRRRQAUUUUAFFFFAB2pKWkoAKa3S nU1ulAHgPxAG7xtqqn+/Hj/v2lcrny90fBGefWuq8eyD/hN9Y9njx/36SuNSUs+fWgTJ3/2aaAxY ggjFOA5B/SrEZUgg8Gl5AUwjZb5iacZM8GppEA6ZxVVvv455pDJiMLkNUQJRqY7MDjqtNZjimSXG kOODSRqRyTVQNlRjJNWoiWU54xSY0SbOeKd9xeTULMQvHT2pxJaPmjoMYI9rZ9aex2ig/dWmN1xz QLqMZm3c5pGNPdgF6VDIeKNAADHINORtrHmmLnbSqKBdRD94tQOfSk+lB+XHFADpFAFQH8RU7fMO TULEbaBleTIJquW9almPOKrMeaAHbv0puaaTRQA7NJmk7UhoBDxWt4fg+0axBlN6xnzGX6VkKa63 wnbbIp7p0+Vhs3Y6D0H1pDRs6ldLb6XcTqSFCnyz0LOeN1edDPmda67xfc+XDb2zMEL/ADlPQDgC uPDLnNFhosoRuqQkFccc1WQ96kU85rOSOinLQrsphk4+6asLyM5pjrvXBpEDK2315o3DYtQhP+BC mT/PMq+tIjBSCaVPnuC/UDpSW4p25SyoxTiPloB/GlQZkUHkelWYDppFS3wOQq/r61mDgVavWOQg wQx5PrVZqaEySzQvdpj+Hk+1T6q+RCmfU4p+lIcyOFyegqlfNuvG5zjjNMRCKkFMFOFMCZOtWFxV ZeDVhSaQMdzmjHNFBoGNY1GacenWm5pAIRTGHNSUxqBgOlH50gpTiiwwIplOOaYaBCdaQ569qBik NADXFV3XmrRqGSmNlfFW7N8Niqpp8DYlFKSujSlLlkma7MWOSeaYPSnLyvFN/OuBn2OHknBWHDpR 2o9KXsOKk6Bc0ZoxzS45pAJR2pQPrSdOKYDs4FHb3pP50nI6UgHZ6Gl4pue9L6UAGTS/rRz6UpK4 UAEN/Fk9Tn/9VJIAoo5paGAo60vekFLmgB459qliqEVIhoEe3/DfUBd+GFhY/PbSNGfp1FdoK8m+ Fd9t1C8sS3EkYkUe4/8A116wDxXoUHeB8fmFPkxEkPpaQUtbHEL6UdKKD0pAGf8AGlpO1FAgPSig 0UANNBo70UwGmmmndKaelADW6V4z8Xtn9uWBP3vs5x/31z/SvZm6V4x8X9v/AAkOngZz9lYf+PUd RS+FnnyENH8uABSgikACR7RSADHeq2MB+MmpIvl5B5FN7jtRG69Mc0xdAmJ/PikibauCKVvmXPPW os4b69/SkMnmfAzgVHuGcn8KAMDDfMRTGHOaYDyd+OKhf5TTtx2/ypSoK5PXGaQLcVWGzHTNSfyH tUMfHBHsKlyQlA2RHJ3HmkYD5do+YVYiRiDmkCbVZiOc07aBcYvr3qWJs8c5qL5euPpT7b74549a AZaMXy7jmlOxArfxUryfJtFQsQeWPPah2GhWOJML3q1HIJBtfiqmOppozyc9+KBeRallw2OuOlNW Q8hu9NK5AcnJxSpg9ewo9B3LgUsoP5Ux87toFTQSxKFEitt77TyRUfv7+lPUCRFZcc/MKkBz0oQf MOKdwnI/CiwxpHQVIFI+fPaod+T078VIVdk+Y/KaQxvB5zTVyxz2pQAFzj9KYZCOe3QYoAcfTvTF +8ueacu0jJJ4qMcd/mFIZZn3EdPlHSq8WGb5zn0qTzcxEHvTIQjMr/w96BPclJ+XIzxT0BcZA2+u aSQBfmXPLUJI4DHseKB7D/l4xSt/q8YqIdeKnTDEZoAbgxleeO9WIThm75qN3VFbgHim27jByaQy 9tyAcZxURjOWNWYADGTuHSowQzdfwpgQLgjaeaeQwAwOlGMHmm7huJyaQEscuHbPpUEjbuvLZo6F itPjjy280xigO4xipLf5HbI9qbG4UMajUnPPc0xE8snRQPxpCNyZxTGHzDg0u7/CkJiKQOvao5FZ /m5xS47n8qsNtEHX5j1qgK6YA6ZqF8hzuHWpwNnzVDK+eaBEJxS7sNgVHuy3XFNB2v1oAkcF14HS qpI3EVaaTCkA1XdPlBHejUCByVSkRgU560+XGVU1AR5bjjinYkkjYY5FN2E7i/H4UMSvSmPL8uMm gRC3HA6VFJ8wwOacx+Xrio1bv+FSMhA2nFS/w4qIn95Uox60AO4AphJ7GlJpm7tQ9gGs34U0nihj lajzUjHDtTwMDnimA04HsaAYD2pSQKbSE5NHQRq6eUlRonUFWHSsu7gayvWi52jlT7VbsG2XCjPW tHU7H7ZbLKh/eR9/UVlNG0Cr4du/J1NecbhXokTb0zmvI4Z2trlHB+61en6dN5tnGysDxUwVmaPY 0w+eKcDxUAbmnZrdbEE+aQE/Sos/LS5NMRJnBpN3vTM0hPy0wHbqZmkY8cdKbnjFCEPBGaaSOabn HApjHvQAue9NbNNJpu7HTrTAceOtR7uRQx5zTc/rTFcax44qNmp7MKhPWkJjCeKjY/lTmb5ahZuK YhrMM0VG3XrRQFjzUV1Pg0ga7Z/9d0/9CFctXUeD/wDkOWf/AF2T/wBCFQimfV8f3RTqYn3BT6RQ tFHaigAFHeiigAooooAKKKDQAUlL2pKACmt0p1NbpQB89fENkTxxqw53F48/9+1rk4UOM10nxIP/ ABcHVgOzx/8AopK5sudmBnNHQllmLhvan7hv/GmRj5elMI5x3pMYTysTtHeowDj5u1RPKA+ODzUy Pu5FILjFy27rigjj2qcEbPrUZx+FV0EVkwH9qvW6lgc1RZvm6Vftj8oxipGgC8Hilbpt6CnA1GW/ eHii4xm8hyMcCk3hzxTjhqBDs5/SmIim+7UGctg1LM2OKYCCFzQBJgbTtNN8zYenbHNOU7enQ1Hk b89qQCqaU56U0kFuBgU9yBimIRzhcGqrvxUksnFU3PNADXbNQt+NOJ96a1JDENHtSUufagBaVsZ4 H0pKDwMmgABA5PFegaRG1rZ2qR/P3QbfvN3Y+wrgdOt/t+pQQc7GcbgPTvXpMs0djazO6qHCfPj+ EfwqKAOO1yVbzVZCx3bPlBPesspCrBSM06T5pSQeppjx7W5PNCGWY7RZh+64xzmoCGXihSyLlHZf oalhuFVcMuWx1pco1OxXBqa3+a4X0WmNtYjb96p7NNrOWPzelLlsU53RZeNCvzBaiRFHQVJJyKEH zUEBgU9AojZjzjpSkCibctuOg2jPHX60MZRmy9wx4wvAx2qFqmiB8vJ6mo8Fn2qMk0xGpafu7FW6 LncxrDJ3OzepzXQahsgs2XnOwKB/M1z4piHCng0wU8UASqc1YSqq1YQ8Uhknak708U1v/wBVADKj NPNMPSgBKDR+FJSASlopKENimomqSmtQBGKUAk4AJPoBTaWmAGoZKmPWonFA2VjQOG704ikximLz NWBgYxzTvaq9k3y1YNcNRWkfVZdV5qaFBpe1N/KnVmemhewo70lLSGKKKQUv50AFFFHNADs0H/PF N9KM0gHcYo4/yKAKKLIBfalFIBxS0gF/z0pce9IOKWiwDgRUqYDcioh7U9fegR0/gq/+w+KrGXOF eTym+jcV74tfMtvIUkVlOGUgivo/TboXmm21yDkSxK+fqK7MM90fO5zTtKMy9+lL1poNLXUeILTq SikAtFHaigQUGlpDQA00GlNJTAaabTjTTQA1q8Z+L/8AyHtNz0+zN/6FXszGvHfi5j+2tPJXlbdu f+BUMT+Fnm/zBOP5U18gLzyKepyPrSheeFqjAcADHu/nTQdg9e1ThCE/CqpPOM02JEgbIx2oHHWk Xj8aTaT826gYbyx9vanBSe9N+7tGcmpUb0pIY3B+XgflSuB6dORSlRnIOSelRufn60ANGSc5qwOm cZqGOP5s44qxH6c+1NBoNiMm85PHtTn5j5qRowuahY/WqYiNUwMtUkT/ADcCmMRilU4Xipe40TyZ 6etRMOFLHnNP3bh7+tRSHdznGO1AEgB8vOaeifJls+1RRt8mKkDEJxQIFyM896lGA386agGOo5pW G1vWmMsIQef4fpU0fzDbUKBlXAP4U+EBJOT1oGWVIAO4nAoZ+MR/nSSFfL+tRx420DJ1HynIyTSA EjnO6lV+nHSlXAb72SaAGMG27QRUL42DIwasNw3NQsofj+VIBq4KZ9BSbCSGWpVwue46U0PtkGO3 QUDHYAXpTkTcwBwFA/WkVmY8jpUuVSInI68Y60ADj93jHNRsCMHaRT0dSrZJ3H1qRz+660AKgRlJ xjAoAK4x3FVjIQNi9DVkj92vqBSGMmJ8vtSwrshweTSDn8afGdh5GaQx0ZlWQ4JwamCMo3NnrTkd dgIHNSOwZcsevahDIJCCwPNIybhilA3u2M7RSE849KYhuCFxmpFfCfShASd1Nlzv470wGs6nGOpq TG0rg0yNfm3HtUi8rn0osJEj/LyKSFCzDPeo93ODzThIUegLi3BCyYHYdaYhDHk1G8jM5pq7hy1M CTABYZPFV5OV4qRm+XIquSwOTTEyPd82PSo2b5+tOlIUZHWoSBxQIsRkYJoU726dOlNHEf1pqHaD mgRHIP3ox2pkx6Y7VZcAwb+lVCCY88jPqKBMY7fJnvUOflp0hOABUbexoEIw+Wq8nHA7ipT92kXB PrSGRIoxlqkG0dKSk6fypBcGP0qNsg4pzEbqYaQ0HQUzjNOz+tNIOaBjh93inYwO9NU9qVzzjNIA 4puaTPFNNAyaGXZMnPeuptDuVfeuOPLL7V1GmPmNR2xUsqFjQn0ezvIVR4gPRlHIrQ023NpEYg25 QflqOI/LVmMmlyK9zVSdrF1Wp+7IqsG96ch96sgmz6U7dUWcjFKKYEhP14pCaZ9PpRn5aYhT+lJu xSFgBSbsHntTACcU0nHajcKaelAgJ49qjY+hpcn0pmaOoATTS3SkLdqY2ARimAGomPvSk/Wo3NMk ax9qhc88cU5mGMVEx96PMQhPPNFNz60VIzzkV1Pg3/kO2Wf+eyf+hCuWFdR4OONcs/8Arsn/AKEK lFM+ro/uL9KfTE+6KfSKFoo7UUAFFFFABRRRQAUUUUAFJS0lABTW6U6mt0oA+dPiCgbx9rRB/wCW kf8A6KSubUAHpXU/EEKPHWrc/MZI/wD0WlcwUCZwTS1EywhTZwelVpZNucU9MFeM1VkfL4NMm7Iw N596lTcpxgcGkj27tvvUwGJD6UD6AWGcGopMjnNPkXcQwNNbJOOaAI1QuKsRFlxmmJhVPUUqMWbj vUjLLk8Y4ppTL9RUQck4qYPheaNhhkAU15eAtN3fMSKa6/vA2eKAGTYIGRUCHmpZOnNNXtx3oQgy ehpccZok2uD/AHhQj7QM9KdhXBF5ps5p2/nNV5pMmgCFm5qFjTn65qM9KQxKSjNJQAlFOFNNMBwG T0plwQp2enWpVDRx+YKqO25ix6mgZ0vg+0L3UtyI98ijy4R/tnv+Fb/iCVINPW2Egfe2ZJP7xpfD to9ppMUJ/dySLvnYj7inkKPesHxHMJNQYKf3aAKo9KUkKJkOBv8Alp7hRt3c49KjjUO3WppcI+Pv L3OKaQNjZEQIMN702N+20flUiQeYu4sAo605HCjaqD64qktCGyqR8+B17USl0OCakmjUTJsao7gf MaGNAl0QPm5rQtpVkX5Tn1rFHegMyNuViKixXQ6HO5lGM5NM1CXzFYBcbiBkd6p2mo4PznDDocVI 7M80Yc9OcelKxQ0jAxTrOMyXsf8AdByaJOtXNMiB85ySGAwCO3vQStyDWZgSka8nOWNZQq3qbA3m xRhUAAFVAeaoEh1OHSminCgCROoqwg49qgTrVpOlSMfxTWpTTGPrRdgNNMJpSfxppoATPpSHrTvw pp69KBi5pdv7sPuXkkbe46f40mKPagBM01qf2pjCgCOg0GigEFRuetPpjdKBkJ6000400nmmBYtm w/f6Vf7cVlo21x2rTibKVz1l1PZyurZ8oDoKdTacoyD0GPXvXKz6JCgcUUg6D0paChR060uRik/W ikAUdqKO1AB2FFL2+tJ3oAcKUUnXnFKOmMUgAUo603PtSg0WAd+tLQg3GnHFAAKcKavJwBT+n8NI RLHwe1e5fDy9N34Tt1Y/NAzRH8+P514Wp5r0z4Vahi6vbBmwHQSqM9xwa3oO0zzM1p8+Hb7Hqq9K dTFNP+td58qxeaXtSCloAWikFLQIKKOlFADaD1oP602gANNPSnGmmgBrdK8d+LgP9sWRz8v2cjH/ AAKvYj0rx/4sIraxZk43eR+PWjqJ/CzzMPtfYF6VMXwvp6U2Q7f4c9qc8eVBIqzAEZnPJpnl/Mfa lUtH8qgGmiUvuO3jNIGPIGFoR/4aVwNoNRqCDTAawOSeacgIXrUygHg9aRkVFpWC/Qj30zI38c0g yWO3NPEe3nnmgehOmNvWnJu524xUGG2VJGdvHVs1QvQs7icEj5fSopOTmpDwtRLIrtjjFHqBHKBs pFVjwBxUm/MihB92pHznpSGNOFXBHSocZapHH8NNjXHQ0xEmMCnKMLSD0zyelT8bAntQHQjXCjkU 4HdwTQygdTxSIQG7e1A9C1v9+MY+tKPmIIpin3pfM4xn8aBkjhsCnQjMfNRq24delKuQNuRyaAsT 5+XjrR842sFyRwfahFxgYyae2Fx+ZoGthz8jjrUIYj5vWph8zDafqaiuMD5U6e1AEXmfPtz17Uux t+SKlt1VeSuT0FW5AhjUqMtjilYNSiFfdn1PNOKuoy3rUwIb5Ap3dcimvz98/NQMj5J3GnrueP6U 1/u8kDFPjIG0vyKA2IhyeDmnidt2002UAS/J900AAtu/Cl5DWxYUHzVAHWptjHr61HbY8wE81a8x TnbQNbDWIQrtFNM27r2qbYPK3segpgRNvA+b1oGKPliXpjNRyfe4PXpUjsBFtI71AVycngUEk2GC /wCzUW4Pj2pd4xtJO36U1MbTxTAmC/d560yVCrcHn0poY9vwpxb5gTzQAmDgU9MEbetA5WofmWSg AJwM00ybmGelK+3d1zxUL8DimIfJzjtUDtk4NSN0U+tQS53KBTENcAjO6oUPOKkB6g1CQUdStAMs FvlpJMGPdUTnI+h7UZO3pTJuSrJ+7CtUExzwOlRsSzUhbCH+9SvoBE3tUeMcU5jxk03OTkDoKQA/ YdqjbAFSMeAfaoGOWpbgkIODQcZoakY859qAEP3s/wAqaaD/AEpuamzLCjntRnNOPy8U+gho60d6 QZ/KlHpSAb3oalyM4pP1pDGgfNW7pL5TGenFYS9fpWlpUuybb60WGjroeQKtR+tUbdhtFXIz2FNI q5aBA+tOzzkVXz71IG7UxkoNLnn0qMHijPSmhPclzig+1R0n40DJCfm/lTCaae1ISKdmIdnNBPFR 5oJpiuIWJ49KYxFBNRk5NAhWNNPTrSGmsfWiwgPU1G55oPr6cVGzE0ANZuKhY+lOb+dRk0yQB96K jYnPHSipKPPx7Cuo8Hf8huz/AOuyf+hCuXFdR4QONZtf+uyf+hCpRTPq5Puin0xPuj6U+kUL2oo7 UUAFFFFABRRRQAUUUUAFFFFACUjdKWkP3TQB88/EBQfHOrHHPmR5/wC/aVy8nEeB3rqviCu7xxq2 GHyvHkf9s0rlZk+Uc0WJY1DtXpVWRcvz+lW4+Bg1FNhTkUCGxja3SpB8zN/hUIbkD1qVQQzfypDJ EHPP1pr/AC8ikViQ2KZ8xXkdKYhQwPBFGNoO09ahCFjuB6VYRflJPFFhjYfvZqacfJ8ooQDqBTpj hKQysJsHBp+75sVAUy3f1qYg7OBzQJCPh+f0phwB9OKYocNkiiU4HFMBxHynHajPyc1CZOMUgbI6 1I9hWbiq7mpXbj6elVmNMSEJpM03vQaAYGiiikMMVJDC0r4UGmjntWqkZtLcAKC7cs392i4GVdBo y2T16UaXam81S2tx/G4/Korr/Xld+7Heuh8H2yeZc3coO1QI946jPUD3NUkD2Opupmi064mVvljJ ZT/z0b1+lefz7idznk11niq4lgtoLZf3bycmL+6o6CuUkjZR+9+96ZpIQ2FSx4OKsS4jcLndUcEZ dgE7nvUjERy4IDVdibkwt/Nh3pwB29acswjtxF5Iyf46kaGaW0aWH5VUfNzUfmuLJYjF82fv+tPo Io3cWJV2MTmoZv5VJcKS6gMagm4b72aljRD3oNJiikWNq5aTAPhz14zVSlpBY2HOfwrQtlWKzVv4 mO7HrWJaSFysbdfWty+lWK0lWPHyLsyRSW4jnppTJKztwWOTTRTW7U0GmMnFPHSokapRSAkSrSdO lVUNWVJoAex+lRk80rUw0gCozTqbTAKdTR1pe9SNDuMUlOphpoYd6aaWg8UCIz0ptONNo6ABqN+l PpjUDIDTakbGB8o69aioQC5rTtTuXbn9ay6t2b4OKipG8TqwdTkqovd6OlFBrhPr6buhwpW5Y4UK Ceg7U2j60Go4Uv4U0fU0/wDSpATA/wAmjFKMUmRj/wCtQAfSl4zR6Glz7UAJigCnUDrRdgJgAfSl wKO1GKQCil70gpaAHD+VOJyevNMp44FMQ4V1Pge++w+KbE/wyP5R/wCBcVyy9KtW8rW80csf30YM KcXZ3Mq1P2kHE+l1p9UdMvFvtOt7pcYljV/zFXhXpp3R8TJWdmOFLSCj2pki0fnRS0CCjtRSd6AE NJSmmmgAPrTTSnikP0oAY3SvIPisf+J5Zqen2c4/OvXmIryH4rj/AInlif8Ap3P86OopfCzzmXIw BQsm771Dphs7sioclW4XP1qzAnGWPtSMCQAO1CvlcbQp68VH84z70CSJFcHhqSX+6tMAYDO0mnNk sv5UDHqcJlic02btSY5/pTlwccUwGquF96kbjinSA460BAMEjmlYBqru6Nx0xQV2soFSLgcCh/vL mmkA1m4xUYkXv+lPbOWxzUQHP4UMESRptffUjHLdaag4y1BO4YFOwDsYPXPanBAAeKaoPGakl+bG 04oAahwcgc1Iclc4qHdt/ClEpf5uaQ7E55QCmFO9IG3jGe1OZT5ftQBIPu9eKkSMsN45AquMj71X IiAu31oGRbTkCpUADYZTUZ4PJNWoSr/6zt+dAXJAxVdoGPfFACrGSx5Pf1p8g3ISg+X1qFRxszkC geg6HiXnilOw55P0oUjHcYFBRNufzp2AduVCq43DvillIAyO4qKHmRmYfKBxUzbSu7dmgCFcpyDg kc0wEl8k59Kf5n+yKixg56ZpAPHzs24VIxKYOz5emKJMbVWPOCOC3WnMx27TyKBvYjdgfbPrTcgA UOOc8n2qRAC4DD8ql+QDkVt25cbAKeP9YNoqdVAGB07VINm8EqOBQUMDb02Nxg9qfF0br7VHGVM7 Y5Wpg20YztXr9aEA11O1fc0k4CxovQ07crNu3YxTHbL5bDY6U7CuQgDIHrTyAAB7UyTOOOpqTcNv TOBQkBAJCG9qlm9j2qv96THvTsHf14qlYRIhYBfQnvTh1aoHO5VAPSlVsDPcdKQIRztb+dRZz360 kj+Z/vd6YgweaYMk5wFA6U2VTsyOtSxFd3ymiYhlx6daaJZUZcJ16io34iXjpUjDjhqqzE7hzwKA HK/y1IjZUg1XUHb0p0Z3cZoT0JsK2EPXrUQ+Y806cfMDnvUf9KVhkcnTrUY4Xg80NyaOgzSAV8ha i75ods4puakaF+tIx4ppalPSgPIYxPtRnK9sA0E0hpDAUvWhelJnFACA96Mmj39KOrUXAQDnNJ/F 7U7vTR1oGKOKntH23CnOOe9Vx1zShsSA0AdpaNkLV9GGaxLCXMSkHrWsrcU0ii2vXrTwefrUCnin ZoGTdKU9ajz70u6mA/rQGxx/SmbhQOlNAPPWkNNP1pMjHrQhXFPWmZpSaaaYhufWm59KCeaaaGAH 61GT70pPoKiJ9qYhzVExp2QaifrQJjWNRk8041HnJ570EjWIzRTT1oqWUcGOtdN4R/5DNr/11Tn/ AIEK5oV1Hg8f8Tuz/wCuyf8AoQqUWz6uT7tOpqfdFOpFC0UUUAFFFFABRRRQAUUUUAFFFFACUjdD S0h6UAfO/j7/AJH3WiP+ekf/AKKSuXZ89eK6nx7/AMjxqxyP9av/AKAtcowpkMQMS3HSllwcUJhZ OafIoI38UgRBsVTu7VIoJO6kaPeijPIqdE2oaLDRCDtzQVz/ACqRUTHzGmSMFHHrQIVIwhx6058A c1CSWPBoZiRjNHoGwm8qRtzSzhzjHSnQjcOR3p0/3QKVhkCj35q1HwPpVQj5qsL93IP6U2JCuVGe Kzrhhu4qxO3NZsshJ59aRRIG4o3471XDUoNDAlZ8imMeKTNNNIBO9KelHPpRTAOvtTaee5H8qYrK WxmgC5ZooO9uv8I960Jy32Qr/D1ZveqMAWR8q3yr607U7lvJEYBVTwfekxoyDy3WvSfDlsNP0m3L ffDeYFx9+T/61ef6date38MCgnc2WwM4Uck/lXpUtxHaWklyVCqseUTH3F7Z9zVEs5XxPqT32uzz O+9gcZ9+9Yr7937zIY9jT2eWe4Z9u9yd3ApjbmbLnmhIGWIoXK5SpINsEo85d1MgE2xtgOMcmpLZ 4lfZONw9atGbLU7PJA0kQ2RjqKQ3znR/srov39wcLz+dF6uLUGF/3Z7VS3v9kKMgxnhqYinMrlhz UUow2M5qaXdhcVDJktzUOxoiGlPSg0mKRQUg6UtIKTGWrRtr7vTmrd1dGa1VSRu3fN7+9UYfvAU7 HJpdRvYiY1FmpH61GaokcrYNSrJVbvTh14/lQDNCMgmrS9Kz4GzV5TSsA49aaace1NPSkA0/nTev 4048im96BhSigUvekAueKQ4oNHbpQA3mg0YoNADDTW9af7U00IBp496a1OpGoGV34NRHrUz1D+NN AFTRMqy/JkjA61DSocNn0oa0HF2dzXUhlo7U2EgpT64JKzPsMHU5oJgKXijpijuKh7HaAqQHC8Uz tT6TAb3o7Uoo/CgBQeBRmlxxxijFIBKB/ninYo/Ci4CdqUdqMcf0pwGaQCDNL0oFHemAopab3pwp CHCpo+1RCnrTA9y+Hd59q8KQqzZaF2jPsOo/nXXivMfhVfcX1izf3ZVH6GvThXoUXeCPjcfT5MRJ DqWkH8qWtTkFpabTqBBSUtFADabTjTTQA00H/PFBoNADGryD4sZ/tqzIzj7P0x71681eP/Fh2Gt2 PzfKLc4GfejqhS+FnnwwTtpCMntgUkgJ6daSMfN8xrSxzjWUh1OCBT2G4gUSnLjGcYp8bIOSfqaN gArsXv8AWq7cHnirTvvKgYNQTKB70WGhRyvH505E+YelRr19qniGR6UAOfBP0FNLMF7HFPb7mA2G zUbLtbA79aewDRu796ccFaYAS2DT8ZH0oAQZEZAA5pucD/61SuFxUOOcYoAmTmgLtOcYqWEAnB4F PkVQ2OSBTEiEfe2nFJj6UEYPHOak2jaOeQaVhlY7i3tUzD5AAamhRHb6Uko/ecDgUWGRQnnt6Yq5 GVdSOtV1T5vlAxUkXybqFsISTO6pydkakfePFRIP4n5WlaRWkOOFPSkMPMGefvZq1EoKbuc1FGid xk96up5ajA+7QMaHRl8tG4704ABeB1qDCxrv/vVMr7+wPFNARy/KBs+73NKHaQYA/SmuG2/7NNiL AkDGKEtQZMU2xt/epiMMhT2p7H1qqfvcdaAJGYLJnn3pz7SFGPekYeooGfmBHSgY/ByDngUZA4Dc e9CH93zUc2c7h0PakxoeSD/FUiFe56d6rQrvqyIxtwTSsBZBBTOeaGBK4XPNRRsNoHX6VLBky+ii gY6HCRbc/MKAm/cjZPvTJtqtuqeDOc/3qYivtI3K33TxTYyBKEz+dTSMpbk96hlVRNkHrSsBalGB wKqlxu29KcJiF29TVd2+bJGKYEo42/rUTSKjbd1OBqF497UAyfgsOaTjdTY/ukUKQseD3piGrtMh 4qOQkZqQMqjPeq8hzk80B6EsLAEmlkfah96hjfAORzSyMDGuTQmIiXkNUUqZA5qdO/eo34Zs0xPc jhwE2tTWBVt3apEAxu9KmXDqwwOKLBcpZyeaic/NxTyfmpr1IEbcU1jgUrZPbHFRn5qTBIbnPWmk 5OaUe1MPFIoKd2pgpenFIBp60fnQfvZoz9KBig/LikPvQelRnNAJC5pynnpUfenA9KAZIcYplITz SE/hRoJDug5poPzUhpVpDN/SXzHjNb0bDaK5XTJMSbc8da6OFsqOapMEi8rU8dRUSHpUgNUO48Hi nA0wHtThQhsdnvR/DTAaXPvQID1o703NBPFOwICabk0ZppOaBXAnmmMe9OJqPtimAhPHtim549qD UZx05pCe4rVEemacxFRk8UAMbPNMY8UrnJpjHtxVE3G89qKMiik0Bwwrp/CH/Ias+375P/QhXM/L 8uM57103hDnWrP8A67J/6EKzRqfWCD5adTF+7TqRQvaiiigBM9KWiigAooooAKKKKAGK6uWCsG2n a2D0NPpAAOg69aWgBKQ/dNLTW6GgD508fHPj3WB6Sp/6LWualjJTNdL48/5H7WjkjEq/+i0rm5sY GCeaZDdmVE3bhntVqTlVC1D0/Cn7+B+VADQzL69akMjBc46VXZucfyqRj+76UAAcvxzzUnDDaRz2 qCMjHNSLyw+tIB8iYbK9uKjHLYqZ8Z64NQ96Bkowi5zSMxY00HcMUcqM0ANdee9ODYFAbd+FNT7x oEV7pqz35q/cjmqLikUkRU4Uh/nSjtQA6pxEY4Vcr8z/AHKZbxedOif3jiuhNrHcNIY1+SNcRr7d BUSdhxVzmHDA4pm5h71p3FrsWMdWk6VRIRNzk9OFqou4pKwyWX5QgGPWnxW5CeY/A/h96iiTzXJq 63yxKpYn2qhDrcqAcZBqreSO8mHOcVNwFyp5qi5LSEk0ho6Twdas15JdBdzJhI17sxra8UTR2+mf ZSd800nzuOhxT/D1v9j0i0ESlbq4UyM391D/ABVgeJJvN1ZkDnZH8qjNVYldzOg8xSfLB5GOKZsP mYY4+tTW8d3IG+zpI21csVHQU6GFTOEmbHrTSEyVEuRBiLLKeuKSDyNjecW39vSr1xEtvBm3Z/LI wcmoVgtjYmYykXG/Ajx1HrVWFchndzDlcle3tVcyO1uEI4qS53x24OPlY1XVyYdrH6UgIZCaik5a nylumKibrSZSENJSUVNig5oFApKAJ4T8wpzY3HFRxdf6U/1qbD6EL9aYTTn68VHTsA4daKTNJ+NF gJ4T81aKdKy4j81aUR+WgRITTaKOfzpdBIXt6UzFO4HU03/PSgaFpc803+lDKwVXKna3Q460hjxS 9KaWBfIGKcCCpGOe1KwXGmmnrmpHxubZnbnjPWoqBiUhpaQ0xDfakI4opc8UO40VpKhNTy9ahdtz sxxknPAwPyFNAxKTmlptMSNKzkJj2ZO3PSrPOazrVsN1/CtLtXHWVmfRZXVvDlAUd+tJ3+lL/LNY HuIUdqWm+lOH1pMY7HvxRj3/ADoH60CldgOHQU7FJ2pR1pCDHNLgUo/lTscUrgM7UoFHalFACYxS Gnjmmn6UAJ3pe9ID70uRTGOqQVHjHGRx1NSLQJnXeANQFj4ptQfuzkxH8en64r3Ja+bLKd7W6iuE OHjcOvFfRlpMtxbRTocrIgcY9xXbhm2rHzmcUrTjMs06m06uk8UWikP+RRQAtFFIfagQU00Gj8KA Gmkpc000AIa8g+K651uzY9oP61681eQ/FUr/AG5ZpnloM/rTW6FL4WeeumEBzxTThVwDyaklIKgd hUCkA81bOccPmKrSEAc9hUy4CZ71D/rGHt+tADi4C7gPpUZy3apSgwtBUKaYhgjzxUwbAwKYTgU9 AMH3oGR7TvyCaRfvcnLVJjZ70gUk7v0ouwBz6U2QlcAd6Q8MOelSj5jk0kNkQDYx6d6eACw5oYkN inKDnPSmIlB28L36UoJb5T2pgbLd89sUuTn8KdwSJpI1xnOOOBUSq2xm7U8b5NgpS2z5fSmCIo8B uamX5jkdKhbofWpANi/WpKG8bsDgdqdHwpHXJpoDHp1p2GI54xQBIAv3OmRSEBSvy0q/fCscmrHl jBdulFwsRqd0gx3qTZ8neiIKZc4+WrDKufRaQyErmPB5+tTRLiDcneozKm/5R8tPLFowOgx2poQn U7SKcECj3qOLcp3DnFOlLcc4NA1sNc9FJ5pq9d2KPc4J6UOOAFJz7UPYCfd5o5A4qAuxbI6e9LCV UNu70zrweKQEg5HNNAIyM/SnKMbT0oYjcKYxseVIz1qxjKkscU0qdysBTc5BPvQBNFtG3Jq0gUn7 30qsFVtvt0qUKBhU4I7+tIYlww3AYz7U5Gwc88dMdqgl8xDzjmpFO/rg8dqYAM8k/dzTWVWYZHTs adGfl2n9ajZwcngY9aOgCZCE9vaopDvb60Nudt1Lj5s9qTAWPk4z8tRuSG4+lOU85BpNu9+KYrjI 87W9alUgr8x6CopSUlVQKGdVO0g9KEIjZuMCmly0e30pygY61DIdp60hi/cFMZ+g702T9RQq7/mP FNMlku7aMZ59qGG7mooV3OS3YVMuO1UgK5faWWoyxCnB606XaGzUG7jFITELcCjdluBjFNi5bJpu 47uBxU2GOYnbmoTU0hwoFR+/VjSAaOBUbjBqQmo25pFDQeaD96lxxSUmMCeelA9Tmm/xUp6UAITw KQtx070h6U1qQDXbninCoW+9UueKBj84GaaOef6U3nFKtAD+9ApKO9AFq0fZMp/CumtZOBXJIcMK 6SxkzGp7YpoRrK/IqZf5VVQ8Cpw2DVjJqUH34qMEcc07P6UagSdulJ1/Cm545pCeKEA7600sKQtT WNPoIXPbtSZ/OkJz0puaAHM1RMeOhpT34pjHmmITdxzTS3tQelN479KAuBqM+1OZvSoy3BxTJGtw KiNOb8aYc0eYCDn86KFPFFIDiRXT+EP+Q1Z/9dk/9CFcwvWun8Icazaf9dk/9CFZmrPrAUtApRSK CiiigAooooAKKKKACiiigAoNFFACU1uhp1NboaAPnTx8f+K51j/rqv8A6AtcrnceO1dN8Qtx8da1 2HnL/wCi1rlUYqeT0pkPccOppq5HJ+lSDaSWzzTWHekBG6EN196nVPkpiqxXdn9asY/d/wBKOgXK 5GDilX5XphOBQrc5piHOxLZBpe2aaD2pRkN1pDQ7d8v0FOkYNGMUxuRg0zIxQP1BZMNUiyZYVCfe peFK80bARXIrOfitOZgycYrOk4yKQyLjPOce1A6UEU4Kdu7B2nvRcCa2bZufuF4rQtZmKrCG6j1r KU9qnjkKeYw42ipkNFy4vd2+cv8AvNvloCO3T+VYbtvbA6DpUk0xbj0p9jB51zGu7bk9acVYGWbW 2ZY87fqakki8tuW3D1qwy+VIBuIUio5cCP5apElCY7Upmn2v2y/ht+cO2Djrim3Jy+Bzit7wdZGW +ku8Z8oFU9ASOT+Ap9Qex2Dbbe3fAXdEnzvnA/2UH0rzyYs9wfMb5mbJOa7LxBdJ/ZyW8PyRuflz 1YdzXGYXzfXmhE6JGhbLeLbsbbfs/iZTipILe1a4jM0znu4XrQguzb/udyw96b9g2RtK8xDY+7Wl iDUnt547fMMbvbFMg4zxVAmFrKRn4lU4X0p73t6mnMiEi3A24NMjulOjyQNbLvZsiXNHkhGfIWeP LElVqvI5ZVyMYqabKW6nrk1WPIGalotCE/Lg1E3BqRs7ttMfg96mxSGUdD0/Og9aMYpMoaTlicAZ PQUUdKBQCJY6e3So46kYUhld+vWmdae3WmfSmAUd6Xtmg+1ACp96r8RwtZ4ODVyFuKQFrtmikBzS 0CD/ABpDwOtOGCOT9KQ9aVmA0CgjFKKRuaSGA609aZT15FAAelRmpW6VG35UANPpTTTutIeOtADT SH7uaU0mOvPShgQSVC38qnkFVzyaaGFFBGDj8KO1A7EkRw9aiHK1kjrWjbvlAKxrK6PRy+pyVLE/ GFxmjv8AjSH9KUdeK4z6qOwCndqQUopFDhThTKeKQDhS0mB2Bp1IQop4pq9OlOFIAI9KbTzSYoAM 4FRt1p3amN1p2ABS+lNFO4xxQMeKetRinLjigTLEfX9K918DX323wpZknLRAxMMf3f8A61eELXqn wrvi0N7YHB2kTL/I/wBK6MO/fPKzanzUL9j0qikFKK7j5cdRRRigANFFFADaKPrSUCENNp1NP+cU ANbmvIPiqQNctc97fj869dNeP/Fk/wDE+s8/8+/9afVCl8LPPyfeo2OakO444qPcd3FWznQ8H1zS R5J7jmhuBz1pqPtbGOtCAlYneAKVjkHNHXHFI3XHOKYhME9RxUm4Y603eMbRUbHmgfoSGUOcEYpC 2I2YHkdKiPTNNbp1pAIrln5NWFY5GarocY44qU/NxTAkIDSAkn6VNGm8sCcY6VEB8o4p6na2etMB oXEnFSH7voe9NAIORSD0NAE6SABR6UzJLtx3qLpUkZ2/jRuMB15HHpVwYBy3pVXbznOBUofPyn0o ARuOach4+amyEYx3FIOWxk4xSGPbb5gNWDIHjYelV2AHOKReF69+aBEq53Y6r2q1Mf3WzIPFU1GW GOKd827BPSmMBuVeFFWI2xFgnFQmU/LkH1p2Qz/KeTTETKOcj7uOKHyy/MORTNxLKfSp3OU+bgqf SgZAcumMYxS4PA/nSsFH3e/PNMLZ7dKkYYy/yn8qXBQ4PT6UxeG479KkZmWPLDgUhg2QvA6UDJpu /wDdgqeTTkJYelMRNnjHtxUZHUn16VJHHjJ3daHTZwDQMDIg+XvSmbC5x8x6VBx5nvU0gwoH8XpQ Mkk3PGqtTo1CLjdz0qFZCyqnQ1IBhcmgQrjaRg/lUTOGbham+URjI5qsUO/jjJ9aHYEKJDjpSl16 D0xTANj0SYAz0oAjztXDetSKdrfyqI/NtbOMUpb+9TERndvJ3cGo7hvkXB+tDnAzmoSDjn+dJgO8 zH0pHII4Oagfd1p8YOwnr3qbsY8H514pxOGxUKls8mnFvlPc00IcsmExj6mlaTapGelQAfLn3prM TnI6U7i0F3blPrUGe1SLnaT0zUTcN1oEKhC0YwvNRtIWAFOLbV9akqw2Rs7RSMr7d+Ds6bscZpAf WmHlqAFJ4poPHX9KGptSUNzzSk4+lNPFGaVwsIetOXHc4FNooGKSCeBgVE5pxprc0AkRLy1TgVFG MNUtAMDR2pBS0AL2oFLSHFMQtbWnS/ugM9KxRV7T32uR60IDpom+Uc1YHvVGE8DrVxTxirBEn404 NTPb+VKKAHA85yadu/Co89qUnjNMBx+lMNHrTc0AwJOKTNISKb2oEOJ59Kax5pCfzppIzTExCeab mj3ppPuRRZgBNRvwaef50xyKaJI+vWmt0oPSmt1pgAx+tFIMc9eTRUlJnF966fwf/wAhuz/67J/6 EK5geldN4R/5DNp/12T/ANCFZmjPrH/GnU0d/rThSKCiiigAooooAKKKKACiiigAo70UUAJTW6Gn U1ulAHzr46QN461jp/rx/wCgLXKXCgHsuTXWeOwf+E61k/8ATdT/AOOLXJ3TZOOaCHuRgnGeoxQz HdTVHenABmyaAexMp21NnIx0xzUJB3ccjFORiI+/NAtSvL3xUKnB71M/zMx9aYFANMZPGoJz2oxz SElVHUUzOM89akZIfu5qEevNOJ4xTVOPzpgH3moY880Dk5NJJigSIHftVZ+T3qWQ81C2Q3B9qRQ0 /dpM0uSDkdaSi4DxSNu2kL360+IoG+dSy9wDig+lDAqY+bnrWjYR/K7/AMQ6H0qk64b6+lWbN9hK sCPWmBqSROQit94iqj5TcMcVZhkAPX8aq3Uu2Mtkg9sUXAy5D+8au68L2wXRvLf5BI5mlP8As8BV HucfrXDqpldFA+Zjt+pr0uGJYLcEt+7gXGD/ABuF/kBimiWc1rtylxqBQPhYhtCjpWSmPMX5M46V PI8Ekjn59zMTmpIYZfOUJgt1xjpVJWJZOBK6YR9ijqtXFkjmgjjcHcgwTj71V7i3MTZ8z5vTNaQL w6WqeUxkP8YHGKsky70SGBiCPLXtVMSubIoy9+DUl8ZEgXLZ3Hp3qAyubUK4+hpB0IJGby/mFNlb cqnABx0okZ/L/lUbsxRc9elSUg6HOKZJ1zT92RUb/eqSxhpO9ONNpddBiHpSClPShBlgKAJIx81S uKdGuKa3fFIHsVWzmmU9+tMpjDtRS0UluAVPARuwc4qvTwwz8tMDSQ9KcTVWKbt3NThwTUiH9qSn quVPzAYH5000XAb39qXgfzNK23d8vC9snJpp60roYlPXgU1umM0A4oAlpjU4ckdKacUXBIj7YxQe vNKRzSUwGH+tLjig0fhSBEEgquasy1WNNFi44ooFFBSAD3q3athsVU71LE2GFTLVG1OXLNM0z1ox z+NCN91sZpO/WuBn1tGXNEeKBTRSjpUm48U4CmjtUg6VICgcdKUUgpRTESClzxjt9KQU6pYB+lGO KDQfu0CGmo2604/nUTE5x+VMYAEnkkewpwAFIOOpzTsjt39qYDhz608etMFSg8YNF2DHjoOMCuw+ Hl99k8UwIThbhWiP8x+orjx/nir+l3bWWoW9yDzFIr/kauDsznxFP2lKUT6NWn1BDIs0SSr911DD 6GphXpHxbQtLjikpaBB3pKWg0ANOf8KTPOKXv6UlAhppDSmmmgBrV478WP8AkYLTp/x7+n0r2Ful eO/Fb/kYrM9vs5GPyo6oUvhZwfbAqF9u6njG0mo2GR0rQ5xxC7hSp93JX9KiH3+Klzj+lIA+bf7U 5mPQUDmnAetUhEe09vyowN2WFTHaE9KjfDLk/WnYVyLv0pyjn6UqDPTOKcVw36UWG2NULuwae/8A rFAFRY2tTz1VqSGx4OBj0oXk46UxflPSlxk0xLcsKODk9KrmTD/M351MO9VJV3XA+UnFK5SRf8vK Bk9KFG786BIQABSxgls035AgZfmAzxTwnzrzzQ3DA075l56UWD0Aod240042nHGKmTcy89qhfG7F Awj+fr2oUEyHcKkiATPy9qU42596BCk5b5RTWzmgHyh3yaF3EbqABj8uB19qlj+Re1AjA7dad35H ApgPULlT6Usrh+M1EOvX24p2VC8frSGLgkik7kdKAWcfKOal25VfWkg2Ij1XpUbNnKP+dTMARnHS o8GRizDC0D1GLwu1V6dxVqJF2nLfNiq3f2zUh5YEUWEiZ8lMKalCF0DZ+YVHwce9TRkgjGKYyDyz u3dKdLz0NWiobcV69xVULyRjOaLAQxhnk2g8VaB2cHtRFCFBIqFnYzFW7Uh6is/XPrxSK29sCh+e R930oQ8j2oBjW4fOKc5V8ADimscN0zk00/62gBrJ8vSmS8BetS7iWHFNkZcMB3piK5CnoeKhYAsD 2p2TjBqNs7uB1oExxTdC2e3NRrxHgHmrezERqlsbdwKTiFwwcc0ig7setSsMR85DVEuQeaLAI/Lc Gk9qYCfMqQ7QvXmkGw0tn5arS/eqySAKrYJ3UAhAMLQzfLjNNLfJgUwDP4VJVhxpTg0043UGjYQv G3mmHFKc470w0ihCPmopDxz1oJ+tKwwNJRR2oAT8aaaWkPDUACg5qQ4C9KavUU5ulPoJjP60tIKT vSHYd3p3GKaDzS9qA8hwNTwNtkWq69elSA80aiZ0Vs/SryNisqzkyqn8K0UbJxWiAtbvWjNMyMUu RmmA7NLnjHrTMig+tADqbn3oJz9aQnBx6UxCk5FNzQTzTQaADcOtNJ9+lN/CgkY/pQK4ZGaacdKM c9aTv9aBCEnIpjZ5pxxTG65pgNz2phx680pPBqM5zQIX8aKT/PSik0CORA4xiuk8Ij/icWn/AF2T /wBCFcz5hNdJ4SP/ABOLU/8ATZP/AEIVmkbM+shS0g60tIoWiiigAooooAKa2dp2gFu2adRQA1dx QbwA2OQDkU6iigAoNFFACUjdKWmt0NAHzt4+cL421g/9NlHP/XNK5CbJw2MZ6V1HxA58caz7Tj/0 Ba5b72O1Mh7jOdmPWlh5NOkA2Z9KbHnrSQPYtYIHbFNk+RetNR+cUk5DNQCQzgjJ7U1eTzTeaB1p gSM26gLmMn0pq8GlJ4xQAhpFpRnmhcAUWAdjPHSq8jYqRjVWQ8mkNEbnmmnJ5pD1ozSGJ+NBoppo AcKUnAzSLx1HSmyngD1oAYeTUkbDODTeAV4GPSkYgyEhQoJ4A7VQFwTYyKr3L7gooHJ4qGT71IDX 8M2xudUU8YiG/J6D3rqdbn8vT90ORG/yRBuuzufxrL8K2sSWMtzKx2u+Hx3Ufw/ia0dWG6RGlKhI 0yYvT0GKpLUhvUwYHhMbKtupmY8Oe1Wba2mlcLHMBJ6HjNaGnwQT2kqohEixli4H6AVFaz3dozxe SGLrgjbzirF5mXfRlJRvPzetW7i7uo7KGN/lQjKnGNw/rSXzx3Lww7fL28cnqaivoGgjjimbO0fL z0p3JKM+7y9xpJZXkhjjKINnTHU0k6MqjByD0xQysVXOMnpUjRFMkixKxxz0qBg2F3dav3kbwwxo WGevFVpOdob7w9KVhpkDFl49aGGaJiSwowSeKRSGH/PFJilIOTRntUjQ2n26bpKYeauWcf7t2xQx olEYWMnuKgIG1sdKmlOI8etREYipAyk/XrTO1PfrTKbGL2oo7UlACgArnIyKdscRrLsbyy20PjjI xxn8R+dN7UdO1ADwwB6k/SpUkwetQhRjJYA9h607aApbeuQcbe5oQWNCN8rTyPlz+lVrd/lwDVju MjIz0PekSNyQcjIxRjmndWzj8Kax9KXoMaeKAaQ8/wD6qVcYPTmgZIOlBoXGaDQA000inNTf1oEt wIww3e3Q5pooPXiloGQy9KqnrViWq7GgdxaBSdqKC00LT1qOnilYs0oDmMVIarWp4xmrB61xVFaR 9Nl9TmpIcOtOHXrTB+NOFZM9EeOtPHSowOakXpUgO/CnAU30/Knc0AOXBp2KFp3496QhOlIelOpr ZAoAhNNPWnHr0pvGaq7KDFOApKco46UXYAPqakFR1KvTcOgNCEyRTmpYz81QjpUqcGmSz3nwZe/b vC1k+7LRp5bf8B4rfJwpbBOPSvO/hbfb7S8sWPKMJV+h4NejCvRpu8Uz43GU/Z15RClpKcKs5hKW ik/OgQhpppxppoAbSdqWmmmA1uleP/FTP9v2xHe3/wAK9gavHfitn/hILTHe3/wpdRS+FnAjoRTW znr9KPmB5FL/AA/hWpzjFU+Zz0pxOeKD94fkKeFGKBXFVRt96Oc04YHT8abuIbgUxBnd16U1/lNK 3A6cUnXmhjBG/Kmtnd169KkAGAMVG4w1AEmMj3xTX2j600Fqd1HzDAFIYRnqDUnXkVB/F1qbeFXr QAoJYcUBSf8AGmpgEkfdNTKwxigYbOBzU6LgfjUWeKkVssooAfkbsd6CcfLmmKQZGzxTnx8oA60w BWwufwpvJbpinFduB0FOx82SaAJEztxwDQEGz5utHmEHpx2prE7euGpgDrvbJ4ApoI3bEJpw44zU QUiTIFO4iV3+6MdOKcMmgRFuaQAL/wDWoGIAwb2NA5OTSNuJBAp6HpwOKkCxGT5OcY9KVWO7NI7j YCPTnimROV5I/CgofK27gLjNNbHl9enanMB97vUUh+TPU44oAYfXoBT4sEcD2zTF3OMY6c1OmMDP GKQEuOBSgfwg496iXczU/YcnBph1F3GNyATg03zUkfhsNUYbe2SQT0FEcfJb+KhgXwPL2ncCu2qU h3SM/TNITkjc3QU8kzDkD0FC7AwXhcGo3YA49aVsltnpTHAIznp0FADS2W+XtQG/e01yAfl4pR8o L9qEIWQ7Wz+lRk5bcD0pGk30jDAFMQ3p+fXFBHzbuRUe4lqkJzgAdqEMfI2I8Dmq2714pWc52/pS OjbfrTEJM/zLUTt6UBcj5s8VG5O72qQHn19aazALSNluO9IV+SkMD90c1BJ/OnE8VE5yQeeKlghC NuKcp4qN2LMtOzg8UluUEnGDR1H0pjZp3VetFwsxSajPWnGm4+al10Ghp696RqWkJ4xSGIetFKBS H/OKPUA+lNIoJoJ5FAApwacx5po+9S96YBigikzxS0AKKXtSCl70CFHSnLQR8tC/SiwXNKzfpz0r XiasG2bbJj8K2Ldxgc1S3EX1PFANRo3FSduB1qg9RzNQpPFMPTrSDpxQFyQmmk03OaQmmIcT700E 5o4Pt9KQ4x6UIA9aaelGfm70jcU9SQ7UlGeeRTT6ZoAM4phNLTXzQCIz96kY9qX8aYTySaA8xRn/ APXRQDxzmikwRxorpvCWP7WteDnzk5/4EK5oda6bwnxq9r/11T/0IVmbM+se9LSdzS0ig7Glo7UC gAooozQAUUdqM0AFFGaKACkoooAKa3T8KU01uhoA+bfH+3/hPdaz/wA/A/8AQFrmXfZkCul8fHHj 7Wuf+Xgf+gLXLMcmnYjqBf5MU6M9qjOKVeKSBkufmo2A5bNRBqVSc49aYWHj+VJgE008U4HigRKV G0Y60mzjNOWT5fenHleaLAiM4xgUw8jHcVKRgVCc+9IZE7YFVZGqabIqqeTQUkFBpMUUgA0lL+FA FAAOR/So2OWrSgtxHpV1eP8AeI8uIepJ5P5Vlr1oAkVSxCgZJ4wBTCMH2pwpSuVyKYArYzgiosFm wOpNBq9o9sbrVII84UNvc+gHJNCWotkdzYWi2OnQo0odY/ugdJJO5/Cs2a4aLU2uXRbhj/A3IrSu X8u2kuZgI1K7YEPVV6Z/Gufs742cjLCwZW6k8n8K0juZPY2ohcahbT3FsI4JEXDIWxuFRadrZ037 QZLWO6nZNsZ6gfX1pkxli0KO7tm+XeVlz1+tUdNvLaNn+0Q7mYcY7VXkHmQWtul9fM11ciPALn39 qivHSW6278qO9PtbVLy+ZfMVVHOCetKILZ7vZvAQUdBFW9gw0YhbeCKluLeSLyYpuGIzzxxUl5aE 3Sw27eZ6VM1qZpoYbuVlI+UuT92gDO1BXjdIg6vgcEGqsmdwz94VZvIHF+0UcnmKrYRv7wqGdXVv mHzVLZS0Kzbmb6U5fkNKgbfmmsaRY0nPNIcUmeKTvUjsOXrWokfl2S46tVKyiFxdRxf3mrfmtC7h FX5V9KmTsXGNzDfL051xHWnLaBVxtqhJCyD+lQp3HKBmSDmozVmePByOarHrWhIo6UUKrO4VFLMx wAo5JoP8qQWF7UnTtQKBzwKYBSng/wCFHG0ev1pR933oCxLA2G6VeVsrms4jYxGVbB6qavIxRNjq Vbg4ZcHpx+hpCJBz+FNPr0pyje3y46dzimtxUsYw0CkNKO1MQ8U/Oe5qPOTmlBFAARTTTmNRn+VA DSacMe9NIp46UxkEoqqatTdKq9/xxQFwoo9qKAQ5T29fanY4poqTt0pFJk1s2HFXv6VmqcMprRU5 WuWsj3MrqbxFHanU2lFc7PfQq1MvSoVqVelSxseO1KPpTRTh/wDqpWYEq/lUmKanvTs1JL3EPTp0 qFzUpqFjTQ0RjHGaU4ycZx2pKMVRQtKM0CgdMUAOFSDpTacv+eKYhy1IKjBqQUIR2nw6vRa+JkiP 3bhDH+PUfyr2YDivnnRrz7Dq1pddPKlVj9M19CRsrorKcqwyD7V24d6WPms3p2qqXckpw9qaOlLW 55AtJ9aWmn1oAP8APNNNLSfyoENNJxSmmmmA1q8f+Kn/ACMVqD2t/wA69gNePfFP/kYrf/r3/wAK OqFL4WcI53DpUJHPtUmM9aYcAitDnFK0E/J/tU52yKhJXPSgQqEqKlTrTFYcZp/0FVtuIVjkUw8U E4x70hIH0pAKGwaYZMtnFKB3AzTlUd+KTKQDk8dKH5/lQuAT2oPLg+tACHgdKUDcDUxUbBmmcAdK YmNT5eBSg4bpQq9xQp5oGTZyPSpAcYxUZHANOI3JnPehDFVhvIqwM7s9qrKPmBzThKwfOPoKASJZ JO9JHJuNRPuIweO9KrCPaetPULFr+Ak/hUZ55NSI6MvNRyMVO2mIbk+Z7GnFhjA+tN525NNTBNKw y6jfKd36VA+cjAwtDyHO0dabv4wfvUXBDs8cdacvG0kfWkjUMPelPC8mgCRSDG3qOlO24XJPao4V 3PkkY9KtSEk7No/CkMr5LdDzUIQmRvmwKkcFfm6GnKuYjzQDCMcnn5adJjGKjUnO309KWUluAOaA JY/mFPZlI2rx9ahh4XB60u35c5ouhokXy1X7uTio3DB12vhSKJH/AHfp2oRlMfNABuBXkdKE3kHG eajYMDipFJVeKEA2EF9xY8iiSLPCnpRG/wA/TqaklICnAp2QFPHOPSnAfIymmZIfH8NSYOd56UCG KoVeetRnd1okLZGP0pMs3SmJ7igYG7rThkEU4DgbqjdjyeKABNu/606VgqduKrK+ZVJNEhJkbng0 LYQjfNHkVG3Tkc04MQccYqOU/PgVAxFJ3U1mKLtP3jSFucmmsCTzjAoGMOck0zIzUjnkcVE/y/jU MpCd6MmhRheaO1JDEalzxTTzSCgBenWmsfanHoKb2pD2Gmm04009aBjs0lLRRcVhDTTk/hS0goGK KUUlLRYTAjjmkFHNFAIeDg0o60wU8CmIcOlOWm5pRVIklRsOta0JHHPWsdfvZzWlbPwv8qANRWBq VT71XQ8U8t81WCJO9GSab2602lYCQH3oFRjjmlzzTAWk3GjtzSHpmn6gKfpSE0nO2gkY70CsIabn 9KU0n8vrTsICR270xqd2/Diom4zQA08im+1OJ4qM/hSQmByaKSikNHJA103hT/kK2/8A11T/ANCF c0K6Xwp/yFrb/rqn/oQrNGzPrIUtIP60tIoXtSUvag0AJRRRQAUUUUAFFFFABRRSdKACmt0NONNb oaAPmzx/t/4TzW/+u4/9AWuV7fSuo+IX/I8a0R/z8D/0Ba5gD5aZBGT81Ob7tOC+vBpCoBagCJTx z0qwgBHNQpK0MqyRO6OjbkdThlPYg1JG4z3pgBGeMUFc8ClJ+bilQ/Nz+lAD0XK0itt6j8KkThWO ajO3HWkJCkkj8etREgZ5pxb5f1qKV8LQMrzEmoP4hTmPNMqSrDjSGj86GoABU1vC1xcRwp96Rgoq FtmRs3YwOvr3re8Pw+RBcak4I2Dy4mx/Eepp9AZL4gEcVitnbYMEI25A7/8A665YCty9Ikt5GKM7 OuQ2O9YyYx0qIsbVhccVIo+SmAfN7U7eRxViIH+/XR+GIFWO5u5PuLhQvd/aucPLV3OiwxWVjDlQ ZRyi4+85/i/CnEmRF4llkSGFZm/eTfMyj+EDoK5yKURvxVnWrt7jUpA7l/LO0H+dZ4NNCaO48Pat pi6LdW9yrm4ByF2ZDjFc7G9utwxKHaTwKi0tg0km19jBemfvUolQzHI71oQ+xNZ2T3d1JLFwsYyQ D0FWLJbZ3eKQYbOA9Q6fZtLeM0bE8dFNaFlDZNcskxEe7gPVbCMxLKebU9lsxJBynPJq08LPcstw 2xs/MT/DSpp95HqrSWDtK0R3gockiprm4l1Nme4UJMxyzHgmlsBi3MDx3jBH3MpyCKgnZ5Wyw5q1 LDJZ3m+J95Q5GOagu55by4aZkVGc5wowKljVioocS8Uj/eoUMJaa/U1JpYYaTvRk+uKXJJ5Oakdj f8MWnmz3Fwfuwpn8T0roIYcM25W3N+tZvhcKtrKf7z/N+HT+ddFt4yOh6Y71hUZtAx5oCzY42iqN zaHZtHHtW9tw2cD8f8ao3sXKoo4b7/asluW2cjcJ8x9qjudPmgs4rl0xHKxC/hW1DYm7un4URQ/f OetReJb37QsEOABGOMdMV0+Rgc8OOlGBRzxRtOe/4VQAKD60UuBjvnNAMTJLZJ5p3FNHUHFLSsAv bNSLIxYFnJPTk5qMjjvSCnYDRibjrT246+tUo328fhU4kyKmwhWbH1qMvQ7VCapRC5MJeeRTxJxV PNKrGq5SbsvB1K+9FVA3vUiux+g60uULkxWlXA61D5lHm0rDEmqo1WJJN3pVc9aLDCgdaPwpKVhj xT+1Rg0uaQIeTV+2YmP6Vm5q5aNzj+lZ1Y+6d2AqctVFvvSgcUelA4riZ9bB3Q9akFRCpB0qGWP7 ClFNFOpATJ0qQVHGakzSJY1x8tQGpXbjFQkGmilsNp3cU0ZoxTGO/wA9KcKaKep7U7IQv+TTgOlM xTxnFFkA5c56VIOvNNUkMCDTgeaYiwh+bIFe8eFL43/hqxmP3hEEb6rwa8FQ8ivWfhlfCTSrmzLZ aKQMv0Yf/WrooP3jx82p3pc3Y72lpo6UorrPm2OpDSUvb+VACGmmnU00CG0006mmmA1q8f8Ainj/ AISG1/64fl0r19q8e+Knza/bj0h/woW6FL4WcK20HvSOopucdqHZjyD0rQ5hjcDApqcHFSEY6UAf KDTQg2D5fWnMQq0dOc01+UJ6VQiNgD/FTVPylTQNxFOKnGcCoRbHxsFP14p5C7eDVdDleaccn5Qc UxDhy2KkAAA3U1fkWnZ3D8aQxx59xTR834Uf7IpvFFwJduFzmmKMnFIM4qSP5QeKYIlIwnPFCv8A LtP8qjZs460p4wdw5oGIzbXwBUyHO3nmq7evWpY+m72oAklHOO1IvPympONnPWmxgBiSaoXoTRqF bPrTZgdpIp28de9Nk+Yrn7vtQGo1WG3nrSR/NJ9KfgCPP4VFuC8AdaLhYViC+3vQSd3T9KCF3L/O nMBvwakZNGdqihyOo64qESr93tUjMoAFNB5j4id6gHGBzUr/AHFYdajUBcN7c02SXLDPC9KBoUtu HPTOMVLhBBn1qAkb+c7Se1Pc8KAScUAM+ZfmAp7nbGD/ABYqMEZ6GnSndgrkUmBLFzHweTTyDt61 XRti5zn2qwGGflPGOtAxAuyPd1Y+tImAvr3p5fd8uOPWoG4PsKAYLJl8N1PYU9mA96SGH5t569BT ZCc7QKEDGkkSDA61JJxgZ600BgyAj8ahlctJ8p6UxPYdLhCAPSnbh5OetRsdwz+dCnKNzigBucRd etMRsuoBp5TEGd3eo0wnQ80ITJZTtK5qCUEAdasvgpyBxUEjDy9y1T2Ai2Zceg9Kjz97ANSoeOOC ajYj7tSwIz0LUhYBc5pGY96j+96ipAXI65pjN8uM0NwMVGT71LKsOJyaYxycUo4FNXJNIYN2oz8t OccCmCgBpPFITTjSNSGIfu03vTj0puKTGIabTvbrTTQMXPNGR2pvWjoKADP60Cgc+1HT/wDVRcBw oGO/86FpOhoAXHFApKXmgQ7jPFOFN/CnUxMcKd7Ug6ZxSxIZpkjUoGY7RvcIv4seB9TTEC1ctW46 8iqrqY5ChKllJB2uGH4EcH6ipLdiJOKYkbUb8VNnNU4WwKnBqxE3VaKTOQKT8TQA+gMN1N7UDrTS AUk0mc0E8YppJxQFx3HrTScikpp4PBoELmjPNNFGaAA+n8qaT0oJ5zTGPpQAh6delR040w4FAhc+ 2aKb+NFIaOV710nhY/8AE0t/+ui4/MVzYrovC3/IVt/+ui/zFZmzPrUdTTqQUtIoXtRRQKACjFLR QAmKKM0ZoAKKWkoAKKM0UAFMb7pp9Nbp+FAHzT8QefHetLz/AMfA/wDQFrlwCK6rx/x481o8c3A4 /wCALXLyN6darQzY0vzxzTCc0nSlAHbPtSGNjXJ5/lTl+9x0oRtu7vSLw2aAY/Hz0suVOajzRI2e DQCJFPqaa33qdtaNmRxtZeoqNzzR0CwDrio5yQMEEVYRflPPXrVSek9hlY8+tFB/LNAGTgdTSG9g pW69OKDwcUZoAVB8wArs2h+z6VDYgj5BucDux61zOlW4uNRhRsbd25s+g5ro55j5hYtn6UpPSw0t SjLGwi2gDaevNc39x2X0OK6xhvhZsD3z2rmb1BHdtt6Hnpiog9SpbENNY8Zp3GKjc1t0Myawtzd3 scI6E5b6DrXfF4rK0lvJ0/feV+6jz/q0/wDr1yfh1B9qkmZNyouMfXtW14if7Ppqxu5M87AsM8KB /DQthfaOUaTdIzHucmkVuaAM9Kb9aSGy3Bs2sd20jp70+Nxu+bNV4/u8VJHgtzWiZDRraXbzO8k1 uSWiGSAeQKvWsENzMVuJhFn+Oo9FgumiZ7N/3g+8N2Mg/wD6qlFkrHbeSeQv8RxV3IsMt7u78Maz 9psblZ2j4DryrU27vZNdmd1gjt5GOTt7mmwXcehSvJEkV4rHbiReMetQ/wCla0+bOFI5GP3VbFDB GfDJdabfCYY8yNujDI/GmzztcytIEEe45wvQVJY3Uul6gJ2jjn2kh45BlXHeo5WNzIxgi8tWOQo7 VDHoUwHEh2/iajfrUiLIjZH41E/U1LRohO1C9aaDigdaRR22ghE0tCF+8x5rVd/LaNFb5eprC0yU LaxKOy/55q8jkn5jz3BFc8jVGzbqrqybQWb1qtq8RsoFQwZkJ2oDxyataa6eap5FV9b1Q3OsiS5k B8ofL3Bc0RVhPUxLmL7DZrbZAy2Xx39a5S+m827Zl+6OFrofEt0VdYSRu2Akg+tcoea0iupLCnY+ XPrxTaO1WIUcHNFL1+n0pSMjgHiiwCCgD0o96XkDHrQAuMjOR/hTcfLn+tOXbhtwOccc0ygBc80/ fimYpCKaWhL3Jty7W5O7PHp/npSEfLmo6k3EJtycHtVrYlobRRRQCAGlzSfwjj8acOF4yW5zx2pg IX4xzSPvRsMCpxnkUh9qSkxoCeKbQf8A9VDEFiQAoJ6DtUWKCilOOxpKVgAUGj8KKLALU8DYcVB6 fWlTrSktDSnLlkmbA5XpRyOcVHEcoKd2xXny0Z9jhp80Ex4pwJpg+tKKh7nWSZp4PFQilzngUgJ1 cinbzUINGaQrEu/jFIc00U8e/wCFMYgNHTFKoFKwp2YCDrTh1pBThwaXqIM/Ling8c5PpzTe1KM/ lTAeKeBk9aaKevWi2oiUcNgV2/w4vfI8QeQx+W4jK/iORXEEKCuxieK1dDvDZa1Z3PQRSqx+laQd pXOTFU/aUZRPfxTqYhBUEH6U+u8+OYUUUUAIaQ04mmmmIaabTqaaAGN/SvIPilj+3bf3i/wr1568 d+KbH/hIrdR2h/otC+JCl8DOEb0pjelOctURPPPatjlRL2pO1J2pm7jFJgiXzMYpjnPpSL9aTBPe lcdhdxUDjinEttwB14oAFOxjGSKLjG7NqjpSqvzZNKcn8OopwAz1x6UIAC56ihxtWnjpinsEJwRn B6GmBXUMRuNO2AfjVghewwGORzmkkVSvLYwOnrRYLkIQ560Mh4GSaTp1qWNsnmgQjKQMYppU7c5p 0pIOBTo/u5oGNAp2e3pQQRzTQDtIx1oC45HJbp0FS/z+lV4WOT7VLk+ZmhAyRvl560gJY+1DH5Ou KQEgUwJOpxTMbm9AKmHCr0pxUbfTNNgV1YA80udxbIwenNNZdp7dKVCSDz1pDFKDhs1YjjBXzGx8 vAFRsBsBI5PFNjY7tp6DijqBY6R7zUYO5cKOPftSyPk4z24xUce7GzHWhgTKu5d3A9qSQhdoH3j2 o8srgnvQEBkGR81MBJA5K/3aeG6r+lSuFAzn7v61UaTacgGkO4SjrVi3TEPyrnsM1Ef3iZP5YqzG SAv8qQEihQW64FUpMmTOAM1akzjOcVDJGPlbINDHcmQ/uVxTOFXPGRRv2R7fxqGTlgSeD2qiSSJl lVmOeOlV2BwwHGfapk2rKSeB3zUR/eZ+bFAegwKVGOOaWP8ANaiG7+9niljIDYLY+lSMWd/lpIFx jp+VKy4+bqVoX5QpH3m60xEmRuxgelV5M9MYxU0nyurE8H0qHdvfPAxTAhJ2nn8KjlBC5/iNTSj7 uaZO4Ee3k1L2GVmLZGcUAnb1pxGSKaSF6ikLQhJxTCeKWVsvxwD2oxx71BaQZ+WkB496TrSjpQAM eKZ2p3amg8UrjsBPFB96aacDxR0GIfSmGnEetNxU3YwPWkPWl96aTzTuAGg9aX2/SkzQA5Rk46fj TTz7UpxTRQAvcelKKT+lB6ZzRcBaDnj39abninfMR16UBYUdaeDTO1OXrTESA8UZ9O9NoFMlIePU HH0p8Z2vycUwdATignmh7AtzVhfP/wCqrStgVnwH5AauIePeqRLLAOBQWB79KjVu1OFVYCTpRnmo 880489KAHDoaDjFNBNHemIOaQ4AoJpO1NIYCg5pP60e1IQntTG+lLnr/AEpjHmn0AaelMPWlJPam mjyJDPvRSDp0zRUlI5euk8L/APIUtz/00X+Yrmx1ro/DPF/D/vj+dZmzPrXvRSHrS0ihwopuaM0A OopuaDQA6im5ozQA6im5ozQA6jNNzRQAtNbpS01jhaAPmzx9x471o4PFx/7ItcsJWwR8u3PRkBrp /H+P+E71r1+0D/0Ba5aqSM+o1uOKGPGBTn6j1pu4BsHmlYaGLnNOPzMecU8DjNRuDmjYBynjFJ3x SR88VMBg0egDmZGlJVFjU9EXOB+eaicDzOKGPPFIWwaAJcgJ1qhMetWJGzVWQ5FIaIyaBTe/WnAU DA04UlKPSgDe8OREzTTgDCJjn3rRuFbOVHJ/KoPDS40+5PPzOMY9hV/ytz55OOuetRJDgyiN6w7R wCcvs6ViawvMThe2CcV0E8O3OwsP1rN1OEvZOfmyvzfWoW5bMD+VRHrUg4ohiM86RjqzYraxmdZo FsLezimOPMm+ZB/X8KoeI5C935ZbcIx+veugi8m1hyFIOzC7f+WaD+prjrqYzytI3VjVmaK8R+U0 1qTO0kD1p6xPIjOAdqY3H0qDQcmdvy1JGRj5qhHyinrgnnNUSzU0+S6t2aazZwwHOztV9jeanayC aZI5EGcvwW9qx4JZrf8Ae2zuv97Bq9EkuolUe4SAt/E+cCtEZsk0vU28P3SStHDc5++jjcKbPM+o ySSWcItyxyI4ziq8NxHptxnyYL5eQRKvy0yOGW+J8kxxZ7ZwAKA6EUE50+5YTQxzqRtdG5FRvI0v MK7F9KbFL9mly0cc69Cr9DTHLMp2fIvpmpZXqMjLjcATt6GoW61Im9AcfdNRN1qWikJQPvUUCpKO it5VFtGiv27Vejufu47d/wDPSubhlwuKsJdFTWbgUpWOvS8SKDzD1Hasy+m8mPMnMjfNzVG2n85V jJG0NljVe+lNzdSOM7egz6VXLbQSkZ85MjFmOSTVUirUq4HSqtXYQUoXpx9KACQcDp19qVfpSACM sPf1oCk9qUjBp67c/MOOxU96AuRgH7pPTtUiN5cpeN2TGQDnnmgjJ/nUmcL8iHcp3GUE57f1/nQB XI4FNqXaMZz3pdgG337CnYCMUmOan2rjvUbL81WSMxR/SpGVlGSrKrjIyOCM9vxFMIoADRRjJ/Sj +dMQUnelxk4HNGM/hQCA800n3o70UhhTacAMc0nFSNCUo6UpXHpyOxpuOKQBmij+tKT2zxTAKVet N70tIa3NG1Py4qwfaqNq+GFXv4a4aqtI+nyyrzQsA9KcBxTOlKOlYHsDhjsKcOvemg9PanDGeeKB j170vehQM8/hinAUWEA6dKmAyOKjA9jUyj5adgY3bQVNTBRkU1xjv0osK+pD06kUo9qMc0ucjHak MUD6U8DjFNxSrjFNITHDpT1pv1p4piHDrVmIfLnvVZasRcCmRLY948OXgv8AQLKcEkmIK31HFa/+ RXD/AA4vBLo89qc7oZcj6NXbg13Q1ifG4mHJVlEWjpR3oNWYDTSUZpD0oAQ0hpTTDQA168e+Jkn/ ABUC/KG3RBRkdOF6V7A3SvH/AIpZ/t+D2h/otC3RM/gZwZ55pjqcdaPmPSnHlevNbHMMUEN1pDn2 pcHcM8VIqBgetLcNiAfpTh19qJOBtprHEmUBVc8AnNAyTknAPfNOHX1OeKOpwD0oC7RxQF0B4J60 5QA3K/TNRtuHtTvm45we1IZKW2uvajec5x09qiU+/SnNyvXmhAOMn7wY4HapHIPUVCu0jnJNObPl n1qkIbjJ5qRPu/SoySTUiYEeM84oAjbO71qRTt57Um1gMdaZnc/OcUhk2/IxinbflyKbwE+lNZjj A70wEQ4Y+lP3/vOOmah/lS4P3u9IETOMc1KWBGPQVW3knPTsakHIyPu0wJQ/Qc4qRnGeDnjpUJbG 0etOGNx/vUDSFI38enUU1V+ZRUzEKo+XDYwT61Du/eYHBph6FjcuzB6rwKTaAgGe/PrTWQCRQH3A r1xjmgpsztPQUvNAKR86jHJ9aniXJzjpVdcFVNS5+QgGq9QHscykgfd4p6Jja2TnvxTFUDnJ/Kpo pPkkO5WA70gGzfcAbHy8cGqsi4BA+9mrEjeYdw+uMVCUKjPHzcmkxgm/y93T2qZSw2/KeabFINuF GR7058EKe9AhZCg+bLFvShm4VsfSmuNo4G7Penx428jgCgdik7EucDqalA3p7010wcg8mpoUCxYP WqQis2c7cZzQ52/KvFPVN0ucimuAZc9PQ0AQjhRkHmmlct8ooHMxy2cCnp8gLetSHkhc5bb6iljx nH60yJgWyVwRTicOxx/9amgGyrUalVPJollLDjimkALz1xmhiEaQMxx2qB/7xqRF3dBx3Jpjn+6P lFSMbn5xnp2qJjkmhn3Sc4prAAil0GtyJuTQCVX9KU/ep0u0bQhznt6VmWQjrTgeKMcYpqnY2eD9 eaAHHtUfenNQRzxmgYh6U0HH40M3FISMUrgKe2KQ0cgCgdc0DEJ5pGoNBFIBy03HQ0GiqAP89Kbn AxTiaaetIAFLSUfSgBRT88Ypg/lSigGO704U0U4U0J7D+1IKKAcHt+VMkdmhulNpwo3HsWrdvWr6 VlW7Df1rSRqaJZZBHrTgeM1EpqTPy1Yh3tRmm5xThj3piFpPxoJ45pKYC0de9JkZxmmnrgUwFbH5 U2nDrzn1oODSEJntTHOelDcU1zQ9gGnrUZpx6038KWwmJ17UUcehoqGUjmBXR+Gv+P8Ah/3hRRUm zPrP+L8aWiikUHaiiigAooooAWk7UUUAAooooAWkoooAKa/3aKKAPmrx/wD8j5rP/Xcf+grXMH7v 4UUVoZCz/wCuf/eqB/vCiipY1sWV/wBSv++f5Con70UUMFuRR/eFWW6GiihDZB3FK/3F+tFFPqS9 iI1DJ0P1ooqWWiI/eNKOtFFJgOPWlTrRRQh9DqfDf/IOl/66f0rSj/1kv0H8qKKJiIJejfWqF9/x 4y/7jfyoorJ7my2OT/hqxpv/AB+xf71FFbmR2sv+pn/65VxMnWiiqM0RN96nL1NFFZsvoP8A4fxo T+tFFWBft/8Ajzm+q1ZhJyvNFFVHcxnsUpfvH61bsOkn+4aKKvqJ7Gc/8VA/49/wooqEUIv/AB7n 61VfrRRSe5aG0CiipKLCdfwqzP8A8fL/AO9RRUMC5p3V/pUcn3pvrRRTYlsVr3759h/SqP8AGtFF UxrYWbh5McYP9aQdKKKT3H0JByG+n9aToKKKAHxfdapD9xvp/WiigRC3+fypw+9H9f60UU4hIcen /AqZL/rf+Ar/ACFFFaMzZo34/wCJHo59Y5P/AEc1ZJ6j6UUVkiugDrTu9FFaAIOtC/eP0oooARvv U7sKKKkENakPWiimMKSiisyhT91fp/Wk7UUUxBS0UVIFi3/1i1on7tFFcuJ3PoMr2G9hSjpRRXOz 6BCnoKf3b8aKKiWwuv8AXclbov8Au/1oHSiiqAmP3RUsfeiiqQh3cUS0UVQiA0qUUVBQ5utIOgoo oAn7CgdaKKoRIO1TpRRQRI9L+Gv3dQ/3k/ka9DHWiiu6Gx8lmH+8MdSNRRVnGRnrRRRQAhpooooA Y3SvHvimB/wkEPHWFf5LRRTjuRP4WcFH0NNeiirZzrcO34VJGTuNFFaR2FLcgl5k/CmS8FcelFFT Iok/j/GpP730oopLYkY3QfT+gp03Vfx/maKKRaEHT8Kd2+tFFLqMVeppW6H60UVoiBF+8fpUi9DR RTYD2+6KrjqPc0UUCZN2pV/1sf8AvCiikMi/u/Spn/1cf+5/7MaKKGOBAPuVYg/1f4iiipDqK3Vf rTl/1qGiin1Gixd/6xv94/zqrH/raKKpiRZf/Wr9Kc/U/Siil0GiKLofpVhANr8fw/4UUVSJY4fd /AUW/wDx7N9aKKGNAv8Aq/woP3E/3TRRSY0RW3+p/Cpx/wAe6/7woookAD7n507oXxRRS6lFaT7y VOvSiirMyCP75/Gom+6T7miihgtiBf8AXPSOTs/E0UVmyokkfU/WkP32ooprYXUhb7o+tEvT8KKK YmNi/wBXUL9G+tFFSxsrN99aWT74+lFFSUhp/wBav1/rTZP+PjHvRRUl9RB3+ppp60UVDKA9aU0U UAQP9wVJL99vrRRQMX/lmv0pi/fP4UUUPcXUa33moP3D/vUUUug30EagdqKKsOggpG6iiipAXtQn b6/4UUUIcdhR0NIOhoooIJF7U5aKKYMUdKD1ooqiUOXpSr92iiqJ6Cw/6w/WtOPt9KKKlbA9ybtT 1+4KKK1ZPQO9Sr2+tFFUxoa/U/WjuPpRRSQhp+9RRRVCD+I/Sl/hWiikAw1G3RaKKGA3v+FJ/E1F FSxIEAIORnmiiipNj//Z ________________________________________________________________________________
Subject: Nose wheel grease
From: Kevin Challis <kevinmarie(at)blueyonder.co.uk>
Date: Mar 10, 2014
I know this has been discussed lots of times. But I need a small amount of the special grease for the nose wheel friction set up. Does anyone have a small pot to sell or able to point me in the right direction? Thanks Kevin Challis G ODJG tri gear 912s classic with xs firewall forward ________________________________________________________________________________
Date: Mar 10, 2014
Subject: Re: Nose wheel grease
NYE Damping grease http://www.nyelubricants.com/products/damping.shtml?pg=cat ---- Kevin Challis wrote: > > I know this has been discussed lots of times. But I need a small amount of the special grease for the nose wheel friction set up. > > Does anyone have a small pot to sell or able to point me in the right direction? > > Thanks > > Kevin Challis > G ODJG tri gear 912s classic with xs firewall forward > > > > > > ________________________________________________________________________________
From: Christoph Both <christoph.both(at)acadiau.ca>
Date: Mar 10, 2014
This product works very well, A small tube cost me $20 and will last for many years. The only draw back is during colder winter flying weather: you need to adjust the friction torque of the nose wheel to a lower value to retain a reasonable movability matching warmer weather. Once properly set as per Bud Yearly's torque recommendation I never had issues with nose wheel shimming. Christoph Both Europa Classic #223 Wolfville, Nova Scotia Canada On 14-03-10 7:46 AM, "Dean Seitz" wrote: > >NYE Damping grease >http://www.nyelubricants.com/products/damping.shtml?pg=cat > > >---- Kevin Challis wrote: >> >> >> I know this has been discussed lots of times. But I need a small amount >>of the special grease for the nose wheel friction set up. >> >> Does anyone have a small pot to sell or able to point me in the right >>direction? >> >> Thanks >> >> Kevin Challis >> G ODJG tri gear 912s classic with xs firewall forward >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Europa glider tug
From: "flyingphil2" <flyingphil627-europastuff(at)yahoo.co.uk>
Date: Mar 10, 2014
Hi Erich, Many thanks for posting the images. Very useful. Regards, Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420097#420097 ________________________________________________________________________________
Date: Mar 11, 2014
Thanks I have ordered some from eBay UK Kevin Challis > On 10 Mar 2014, at 14:09, Christoph Both wrote: > > > This product works very well, A small tube cost me $20 and will last for > many years. The only draw back is during colder winter flying weather: you > need to adjust the friction torque of the nose wheel to a lower value to > retain a reasonable movability matching warmer weather. Once properly set > as per Bud Yearly's torque recommendation I never had issues with nose > wheel shimming. > Christoph Both > Europa Classic #223 > Wolfville, Nova Scotia > Canada > > >> On 14-03-10 7:46 AM, "Dean Seitz" wrote: >> >> >> NYE Damping grease >> http://www.nyelubricants.com/products/damping.shtml?pg=cat >> >> >> ---- Kevin Challis wrote: >>> >>> >>> I know this has been discussed lots of times. But I need a small amount >>> of the special grease for the nose wheel friction set up. >>> >>> Does anyone have a small pot to sell or able to point me in the right >>> direction? >>> >>> Thanks >>> >>> Kevin Challis >>> G ODJG tri gear 912s classic with xs firewall forward > > > > > > ________________________________________________________________________________
Date: Mar 11, 2014
From: William Daniell <wdaniell.longport(at)gmail.com>
Guys which is the NYE product to buy? And where do you get it from in the USA? Will William Daniell LONGPORT +57 310 295 0744 > > ________________________________________________________________________________
Date: Mar 11, 2014
Try this source: http://www.newgateonline.com/manufacturers/nye-lubricants.html Christoph From: William Daniell <wdaniell.longport(at)gmail.com<mailto:wdaniell.longport @gmail.com>> ropa-list(at)matronics.com> Date: Tuesday, 11 March, 2014 9:08 AM ist(at)matronics.com> Subject: Re: Europa-List: Nose wheel grease Guys which is the NYE product to buy? And where do you get it from in the USA? Will William Daniell LONGPORT +57 310 295 0744 ________________________________________________________________________________
Date: Feb 16, 2014
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Subject: Re: sealing fuel lines
Will=0AAircraft Spruce sell a very good tool for sealing hoses with locking wire. Much better than the Jubilee clips which are very hit and miss.=0ADo n't use sealant, too risky.=0AGraham=0A=0A=0A=0A=0A________________________ ________=0A From: William Daniell <wdaniell.longport(at)gmail.com>=0ATo: europ a-list(at)matronics.com =0ASent: Sunday, 16 February 2014, 23:06=0ASubject: Eu ropa-List: sealing fuel lines=0A =0A=0A=0AI am installing the fuel lines. =0A=0AHas anyone used any kind of sealant on hose joints? -=0A=0AI am won dering whether the worm drive clips really seal the fuel lines=0A=0AWill- ======= ________________________________________________________________________________
Date: Mar 12, 2014
On Feb 16, 2014, at 3:23 PM, GRAHAM SINGLETON wrote: > Will > Aircraft Spruce sell a very good tool for sealing hoses with locking wire. Much better than the Jubilee clips which are very hit and miss. > Don't use sealant, too risky. > Graham > > From: William Daniell <wdaniell.longport(at)gmail.com> > To: europa-list(at)matronics.com > Sent: Sunday, 16 February 2014, 23:06 > Subject: Europa-List: sealing fuel lines > > I am installing the fuel lines. > > Has anyone used any kind of sealant on hose joints? > > I am wondering whether the worm drive clips really seal the fuel lines > > Will > > > William Daniell > LONGPORT > +57 310 295 0744 > ank" href="http://www.matronics.com/Navigator?Europa-List">http://www.mat"nof ollow" target="_blank" href="http://forums.matronics.com/">http://f========== > > > > > > ________________________________________________________________________________
Subject: Coaming Extension
Date: Mar 13, 2014
Gidday, I have just extended the coaming over my sub panel, a similar distance that the original one extended over the primary, and then I extended the primary to match. So, I have a coaming made out of a bunch of foam layers, all shaped up and ready to deal with. I=92d like to ask before I glass it over, whether there is any opinion of how far extended the coaming should be over the primary panel? Mine now is 4 1/2=94 or 110 mm, and it appears that it will work well. Still, others may disagree, so this is the time to ask. Thanks, in hope and anticipation. Regards Tony Renshaw P.S. It is going to be trimmed up a little more, but the 5 minute epoxy is challenging my sanding skills. I might use polyester car bog, my favourite contouring product ontop of the foam, and then sand it perfect before 2 plies of BID. Don=92t worry, my BID will lock it in ontop of the coaming and down onto the top of the primary and sub panels. ________________________________________________________________________________
Subject: Rotax - New Oil Filter removal tool
Date: Mar 13, 2014
I'm just about to start the first permit renewal on my aircraft and thought I would get some stuff together to help things along. First up was to buy one of those tools for removing the oil filter. 25 and nice new tool arrives in the post a few days later. Take out of packaging and check against shiny new filter - it doesn't fit. Check with the aircraft and it fits that one OK. Research shows that Rotax have recently changed the filter design - Doh!!! The new filter looked a bit familiar to me and the old gray cells kicked in to remind me that I have a filter removal tool for the oil filter on my BMW K100 motorbike. I dug it out and hey presto BMW tool fits new Rotax oil filter. Not only this, I checked the fit on the aircraft and it will work a treat (Rotax 914 uls, cant vouch for the others). The tool is available from Moto-Bins here http://www.motobins.co.uk/bmw-parts.php?model=K+Series part number 99200 if anyone wants one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420266#420266 Attachments: http://forums.matronics.com//files/r0015560_453.jpg http://forums.matronics.com//files/new_filter_new_tool_464.jpg http://forums.matronics.com//files/new_tool_2_137.jpg http://forums.matronics.com//files/new_tool_1_384.jpg http://forums.matronics.com//files/new_filter_old_tool_694.jpg ________________________________________________________________________________
Subject: Re: Rotax - New Oil Filter removal tool
Date: Mar 13, 2014
I see the link didn't work correctly - use the link and scroll down to 'Tools & toolboxes' that will bring up the page I was trying to link to. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420267#420267 ________________________________________________________________________________
Date: Mar 13, 2014
graham thanks i will look for it...this bizarre thing about this is that i received the post today! Will William Daniell LONGPORT +57 310 295 0744 On Sun, Feb 16, 2014 at 6:23 PM, GRAHAM SINGLETON < grahamsingleton(at)btinternet.com> wrote: > Will > Aircraft Spruce sell a very good tool for sealing hoses with locking wire . > Much better than the Jubilee clips which are very hit and miss. > Don't use sealant, too risky. > Graham > > ------------------------------ > *From:* William Daniell > *To:* europa-list(at)matronics.com > *Sent:* Sunday, 16 February 2014, 23:06 > *Subject:* Europa-List: sealing fuel lines > > I am installing the fuel lines. > > Has anyone used any kind of sealant on hose joints? > > I am wondering whether the worm drive clips really seal the fuel lines > > Will > > > William Daniell > LONGPORT > +57 310 295 0744 > > *ank" href="http://www.matronics.com/Navigator?Europa-List ">http://www.mat "nofol low" target="_blank" href="http://forums.matronics.com/ ">http://f ========= > > * > > > * > =========== tronics.com/Navigator?Europa-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Mar 13, 2014
Excellent tip Dave, thanks. Jim Kelly On Thu, Mar 13, 2014 at 1:00 PM, Dave Disney wrote : > > I'm just about to start the first permit renewal on my aircraft and > thought I would get some stuff together to help things along. First up wa s > to buy one of those tools for removing the oil filter. =A325 and nice new > tool arrives in the post a few days later. Take out of packaging and chec k > against shiny new filter - it doesn't fit. Check with the aircraft and it > fits that one OK. Research shows that Rotax have recently changed the > filter design - Doh!!! > > The new filter looked a bit familiar to me and the old gray cells kicked > in to remind me that I have a filter removal tool for the oil filter on m y > BMW K100 motorbike. I dug it out and hey presto BMW tool fits new Rotax o il > filter. Not only this, I checked the fit on the aircraft and it will work a > treat (Rotax 914 uls, cant vouch for the others). > > The tool is available from Moto-Bins here > http://www.motobins.co.uk/bmw-parts.php?model=K+Series part number > 99200 if anyone wants one. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420266#420266 > > > Attachments: > > http://forums.matronics.com//files/r0015560_453.jpg > http://forums.matronics.com//files/new_filter_new_tool_464.jpg > http://forums.matronics.com//files/new_tool_2_137.jpg > http://forums.matronics.com//files/new_tool_1_384.jpg > http://forums.matronics.com//files/new_filter_old_tool_694.jpg > > =========== =========== =========== =========== > > ________________________________________________________________________________
From: "Paul McAllister" <paul.the.aviator(at)gmail.com>
Subject: Europa glider tug
Date: Mar 13, 2014
Hi Bruno, Would you happen to know how Walter Binder achieved putting fuel tanks in the wings ? In particular did he substitute the Blue for something impervious to fuel ? Paul From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of UVTREITH Sent: Thursday, March 6, 2014 6:09 AM Subject: AW: Europa-List: Europa glider tug Hi Phil, Walter Binders plane D-EPWB is a Classic Monowheel Kit 149 with Wing Fuel Tanks, elect. Retractable Outrigger Legs and a Tail Wheel with a mounting plate on top for the tow clutch. I am not quite sure if this was from an old Cessna Taildragger or a Husky. He is using his own landing strip for towing the smaller glider he is manufacturing. He also manufactures the EB 28 /29. Some years ago he had to use a parachute by test flying. Binder Motorenbau GmbH Alter Frickenh=E4user Weg 15 D-97645 Ostheim v. d. Rh=F6n Vertreten durch die Gesch=E4ftsf=FChrer Walter & Oliver Binder Tel.: +49(0)9777 - 92 00 Fax: +49(0)9777 - 92 01 www.binder-flugmotorenbau.de <http://www.binder-flugmotorenbau.de/> 097779200@t-online.de I am sure that he can help you with some information. Best Regards, Bruno Reith /EA-Germany Partner ________________________________________________________________________________
Date: Mar 13, 2014
Paul, Bruno=0AThere's another German builder whose name I forget, lives jus t North of Hamburg and recently did his first flight.=0AHe copied Walter Bi nder's wing design wrt the outriggers. He probably knows how Walter did the tanks=0AI visited him once years ago with Norbert Hoffmann, (Norbert has d ied sadly)=0AGraham=0A=0A=0A=0A=0A________________________________=0A From: Paul McAllister =0ATo: europa-list(at)matronics.c om =0ASent: Thursday, 13 March 2014, 20:15=0ASubject: RE: Europa-List: Euro pa glider tug=0A =0A=0A=0AHi Bruno,=0A-=0AWould you happen to know how Wa lter Binder achieved putting fuel tanks in the wings ?- In particular did he substitute the Blue for something impervious to fuel ?=0A-=0APaul=0A -=0AFrom:owner-europa-list-server(at)matronics.com [mailto:owner-europa-list -server(at)matronics.com] On Behalf Of UVTREITH=0ASent: Thursday, March 6, 201 4 6:09 AM=0ATo: europa-list(at)matronics.com=0ASubject: AW: Europa-List: Europ a glider tug=0A-=0AHi Phil,=0A-=0AWalter Binders plane D-EPWB is a Clas sic Monowheel Kit 149 with Wing Fuel Tanks, elect. Retractable Outrigger Le gs and a Tail Wheel with a mounting plate on top for the tow clutch. I am n ot quite sure if this was from an old Cessna Taildragger or a Husky.=0AHe i s using his own landing strip for towing the smaller glider he is manufactu ring.=0AHe also manufactures the EB 28 /29. Some years ago he had to use a parachute by test flying.=0ABinder Motorenbau GmbH=0AAlter Frickenh=E4user Weg 15=0AD-97645 Ostheim v. d. Rh=F6n=0AVertreten durch die Gesch=E4ftsf=FC hrer Walter & Oliver Binder=0ATel.: +49(0)9777 - 92 00=0AFax: +49(0)9777 - 92 01=0Awww.binder-flugmotorenbau.de =0A097779200@t-online.de=0A-=0AI am sure that he can help you with some information.=0ABest Regards,=0A-=0ABr =========================0A ________________________________________________________________________________
Date: Mar 13, 2014
Graham can you remember what this tool called? Will William Daniell LONGPORT +57 310 295 0744 On Sun, Feb 16, 2014 at 6:23 PM, GRAHAM SINGLETON < grahamsingleton(at)btinternet.com> wrote: > Will > Aircraft Spruce sell a very good tool for sealing hoses with locking wire . > Much better than the Jubilee clips which are very hit and miss. > Don't use sealant, too risky. > Graham > > ------------------------------ > *From:* William Daniell > *To:* europa-list(at)matronics.com > *Sent:* Sunday, 16 February 2014, 23:06 > *Subject:* Europa-List: sealing fuel lines > > I am installing the fuel lines. > > Has anyone used any kind of sealant on hose joints? > > I am wondering whether the worm drive clips really seal the fuel lines > > Will > > > William Daniell > LONGPORT > +57 310 295 0744 > > *ank" href="http://www.matronics.com/Navigator?Europa-List ">http://www.mat "nofol low" target="_blank" href="http://forums.matronics.com/ ">http://f ========= > > * > > > * > =========== tronics.com/Navigator?Europa-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Mar 13, 2014
Hi William I didn't know that tool existed (thanks Graham), but found it on ACS site: http://www.aircraftspruce.com/catalog/appages/clamptitetoolplated.php?clickkey=87751 Be sure to check out the Video tab! Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420318#420318 ________________________________________________________________________________
Date: Mar 13, 2014
William, I believe Graham was talking about this: http://www.aircraftspruce.com/pages/to/safetywiretools/clamptitetool.php I have one and it works surprisingly well where you have enough room to maneuver the tool. The resulting clamp looks like this=94 This is a double wrap. It can also be done as a single wrap. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Mar 13, 2014, at 10:11 PM, William Daniell wrote: Graham can you remember what this tool called? Will William Daniell LONGPORT +57 310 295 0744 On Sun, Feb 16, 2014 at 6:23 PM, GRAHAM SINGLETON wrote: Will Aircraft Spruce sell a very good tool for sealing hoses with locking wire. Much better than the Jubilee clips which are very hit and miss. Don't use sealant, too risky. Graham From: William Daniell <wdaniell.longport(at)gmail.com> Sent: Sunday, 16 February 2014, 23:06 Subject: Europa-List: sealing fuel lines I am installing the fuel lines. Has anyone used any kind of sealant on hose joints? I am wondering whether the worm drive clips really seal the fuel lines Will William Daniell LONGPORT +57 310 295 0744 ank" href="http://www.matronics.com/Navigator?Europa-List">http://www.mat"nof ollow" target="_blank" href="http://forums.matronics.com/">http://f========== arget="_blank">http://www.matronics.com/Navigator?Europa-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 14, 2014
Bob=0Athanks, yes that's the one. There's more than one manufacturer of the tool.=0AGraham=0A=0A=0A=0A=0A________________________________=0A From: Rob ert Borger =0ATo: europa-list(at)matronics.com =0ASent: Frid ay, 14 March 2014, 3:57=0ASubject: Re: Europa-List: sealing fuel lines=0A =0A=0A=0AWilliam,=0A=0AI believe Graham was talking about this:=0A=0Ahttp:/ /www.aircraftspruce.com/pages/to/safetywiretools/clamptitetool.php=0A=0AI h ave one and it works surprisingly well where you have enough room to maneuv er the tool.=0A=0AThe resulting clamp looks like this=9D=0A=0A=0A=0AT his is a double wrap. =C2-It can also be done as a single wrap.=0A=0ABlue skies & tailwinds,=0ABob Borger=0AEuropa XS Tri, Rotax 914,=C2-Airmaster C/S Prop (50 hrs).=0ALittle Toot Sport Biplane,=C2-Lycoming Thunderbolt AEIO-320=C2-EXP=0A3705 Lynchburg Dr.=0ACorinth, TX =C2-76208-5331=0ACel : 817-992-1117=0Arlborger(at)mac.com=0A=0A=0AOn Mar 13, 2014, at 10:11 PM, Wil liam Daniell wrote:=0A=0AGraham=0Acan you rem ember what this tool called?=0AWill=0A=0A=0A=0AWilliam Daniell=0ALONGPORT =0A=0A+57 310 295 0744=0A=0A=0AOn Sun, Feb 16, 2014 at 6:23 PM, GRAHAM SING LETON wrote:=0A=0AWill=0A>Aircraft Spruce sell a very good tool for sealing hoses with locking wire. Much better than the Jubilee clips which are very hit and miss.=0A>Don't use sealant, too r isky.=0A>Graham=0A>=0A>=0A>=0A>=0A>________________________________=0A> Fro m: William Daniell =0A>To: europa-list@matroni cs.com =0A>Sent: Sunday, 16 February 2014, 23:06=0A>Subject: Europa-List: s ealing fuel lines=0A> =0A>=0A>=0A>I am installing the fuel lines.=0A>=0A> =0A>Has anyone used any kind of sealant on hose joints? =C2-=0A>=0A>=0A>I am wondering whether the worm drive clips really seal the fuel lines=0A> =0A>=0A>Will=C2-=0A>=0A>=0A>=0A>=0A>William Daniell=0A>LONGPORT=0A>=0A>+5 7 310 295 0744=0A>ank" href="http://www.matronics.com/Navigator?Europa-Li st">http://www.mat"nofollow" target="_blank" href="http://forums.matron ics.com/">http://f========== =0A>=0A>=0A>arget="_blan k">http://www.matronics.com/Navigator?Europa-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution =0A=0Ahref="http://www.mat ronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa -List=0Ahref="http://forums.matronics.com/">http://forums.matronics.com =0Ahref="http://www.matronics.com/contribution">http://www.matronics.com/ contribution ________________________________________________________________________________
Date: Mar 14, 2014
Subject: oil
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 Hi, It is time for an oil change again. However, the oil I always used is no longer available. The oil I used was Shell Advance VSX 4T. This was a Rotax approved oil, suitable for leaded and unleaded fuel. There is a replacement for this oil, the Shell Advance AX7, but I'm not sure whether this is just a name change or a formula change. So, what kind of oil are the rest of us using? Any recommendations? Anyone who kan tell me whether the Advance AX7 is just a name change? Frans -----BEGIN PGP SIGNATURE----- Version: GnuPG v2.0.22 (GNU/Linux) iQIcBAEBAgAGBQJTItWWAAoJEC+zXxqs0ZzVbZgP/36Q+6ubWS+np6xDFEhrtHkl yBKuzpdBsZpHzvY4sJ+pvHCNZsVdto0Ke7Jf6jJqejVpcjHA/lncrlJkZ02mcJvf 7bkVQXT+1+6UMQ88PJP6B4xYofjJBVlw4huqU5kZnIumnYm3h2sfh3690S61lkJ2 XSLKLuR4PuMRcEiTrYi/d4Rt4Bk7lAkiAiZDbnkFKUOYg6I4qXeAVV1JStDA6sLM fcS5bW9Hj5EN8/zc/qIsKpDTuGqbHGYZISU4VBim45eqo6q+rGeLxXXlOeznLhYd m/j416/hhi2Wh9HJQ+8y5AMMM4tT9k1g4YY643UlICgcLjMCVtIVszAxx4RLk3eC eYxt0T5KfVHutF3avT7AmFOeijg3mzd8t47xgkFLYB/d8JF2lihXJgK/1fKAtlXP rDwm2N4F1Rmfn2UHm/3ktjslplpgZi1lnsaHtRFyHNgy5cMzHrMcHL5TNNfY5m1W fWFVoQde4UvabtuVm8Nj5V7uRb3Oqi1Iy+EyD3j7tUMBXHsaCy0YvUh3J2ephevX mqbJ+seOm3VzDzbAigUjoGrRvL6K75cnQ3se6c5MwG+EfVDkDF+CtyZRlHm/kXwx 7docGUm2K2Iwl6yE5Z7Yv9ccSnvsCroNsC2cjepbt7yjlJuVTx9RlFUDgNYV/nQf uhjSonVxHdgWTFI6tk/m =UXv/ -----END PGP SIGNATURE----- ________________________________________________________________________________
Subject: Re: oil
From: Ivor Phillips <ivor.phillips(at)ntlworld.com>
Date: Mar 14, 2014
Hi Frans Like you I use the VSX 4 T but now use the shell AX7. It the same oil with slight improvements supposedly , BTW are you going to the Rotax meet at Wels this June ? Regards Ivor Sent from my iPad > On 14 Mar 2014, at 10:10, Frans Veldman wrote: > > > -----BEGIN PGP SIGNED MESSAGE----- > Hash: SHA1 > > Hi, > > It is time for an oil change again. However, the oil I always used is > no longer available. > The oil I used was Shell Advance VSX 4T. This was a Rotax approved > oil, suitable for leaded and unleaded fuel. There is a replacement for > this oil, the Shell Advance AX7, but I'm not sure whether this is just > a name change or a formula change. > So, what kind of oil are the rest of us using? Any recommendations? > Anyone who kan tell me whether the Advance AX7 is just a name change? > > Frans > > -----BEGIN PGP SIGNATURE----- > Version: GnuPG v2.0.22 (GNU/Linux) > > iQIcBAEBAgAGBQJTItWWAAoJEC+zXxqs0ZzVbZgP/36Q+6ubWS+np6xDFEhrtHkl > yBKuzpdBsZpHzvY4sJ+pvHCNZsVdto0Ke7Jf6jJqejVpcjHA/lncrlJkZ02mcJvf > 7bkVQXT+1+6UMQ88PJP6B4xYofjJBVlw4huqU5kZnIumnYm3h2sfh3690S61lkJ2 > XSLKLuR4PuMRcEiTrYi/d4Rt4Bk7lAkiAiZDbnkFKUOYg6I4qXeAVV1JStDA6sLM > fcS5bW9Hj5EN8/zc/qIsKpDTuGqbHGYZISU4VBim45eqo6q+rGeLxXXlOeznLhYd > m/j416/hhi2Wh9HJQ+8y5AMMM4tT9k1g4YY643UlICgcLjMCVtIVszAxx4RLk3eC > eYxt0T5KfVHutF3avT7AmFOeijg3mzd8t47xgkFLYB/d8JF2lihXJgK/1fKAtlXP > rDwm2N4F1Rmfn2UHm/3ktjslplpgZi1lnsaHtRFyHNgy5cMzHrMcHL5TNNfY5m1W > fWFVoQde4UvabtuVm8Nj5V7uRb3Oqi1Iy+EyD3j7tUMBXHsaCy0YvUh3J2ephevX > mqbJ+seOm3VzDzbAigUjoGrRvL6K75cnQ3se6c5MwG+EfVDkDF+CtyZRlHm/kXwx > 7docGUm2K2Iwl6yE5Z7Yv9ccSnvsCroNsC2cjepbt7yjlJuVTx9RlFUDgNYV/nQf > uhjSonVxHdgWTFI6tk/m > =UXv/ > -----END PGP SIGNATURE----- > > > > ________________________________________________________________________________
Subject: oil
Date: Mar 14, 2014
Guys=2C Aeroshell Sport plus 4 is the Rotax approved oil we use in the States=2C wh ich is a semi-synthetic for use with AV gas. I get it from Lockwood for le ss than $10 a quart. It is quite good at suspending the lead. However=2C c an you get it over there? For unleaded fuel I still prefer Mobile One MX4T or now called Racing T. M y turbo responds well with it. Regards=2C Bud > Subject: Re: Europa-List: oil > From: ivor.phillips(at)ntlworld.com > Date: Fri=2C 14 Mar 2014 11:53:53 +0000 > To: europa-list(at)matronics.com > com> > > Hi Frans > Like you I use the VSX 4 T but now use the shell AX7. It the same oil wit h slight improvements supposedly =2C > BTW are you going to the Rotax meet at Wels this June ? > Regards > Ivor > > Sent from my iPad > > > On 14 Mar 2014=2C at 10:10=2C Frans Veldman wr ote: > > l> > > > > -----BEGIN PGP SIGNED MESSAGE----- > > Hash: SHA1 > > > > Hi=2C > > > > It is time for an oil change again. However=2C the oil I always used is > > no longer available. > > The oil I used was Shell Advance VSX 4T. This was a Rotax approved > > oil=2C suitable for leaded and unleaded fuel. There is a replacement fo r > > this oil=2C the Shell Advance AX7=2C but I'm not sure whether this is j ust > > a name change or a formula change. > > So=2C what kind of oil are the rest of us using? Any recommendations? > > Anyone who kan tell me whether the Advance AX7 is just a name change? > > > > Frans > > > > -----BEGIN PGP SIGNATURE----- > > Version: GnuPG v2.0.22 (GNU/Linux) > > > > iQIcBAEBAgAGBQJTItWWAAoJEC+zXxqs0ZzVbZgP/36Q+6ubWS+np6xDFEhrtHkl > > yBKuzpdBsZpHzvY4sJ+pvHCNZsVdto0Ke7Jf6jJqejVpcjHA/lncrlJkZ02mcJvf > > 7bkVQXT+1+6UMQ88PJP6B4xYofjJBVlw4huqU5kZnIumnYm3h2sfh3690S61lkJ2 > > XSLKLuR4PuMRcEiTrYi/d4Rt4Bk7lAkiAiZDbnkFKUOYg6I4qXeAVV1JStDA6sLM > > fcS5bW9Hj5EN8/zc/qIsKpDTuGqbHGYZISU4VBim45eqo6q+rGeLxXXlOeznLhYd > > m/j416/hhi2Wh9HJQ+8y5AMMM4tT9k1g4YY643UlICgcLjMCVtIVszAxx4RLk3eC > > eYxt0T5KfVHutF3avT7AmFOeijg3mzd8t47xgkFLYB/d8JF2lihXJgK/1fKAtlXP > > rDwm2N4F1Rmfn2UHm/3ktjslplpgZi1lnsaHtRFyHNgy5cMzHrMcHL5TNNfY5m1W > > fWFVoQde4UvabtuVm8Nj5V7uRb3Oqi1Iy+EyD3j7tUMBXHsaCy0YvUh3J2ephevX > > mqbJ+seOm3VzDzbAigUjoGrRvL6K75cnQ3se6c5MwG+EfVDkDF+CtyZRlHm/kXwx > > 7docGUm2K2Iwl6yE5Z7Yv9ccSnvsCroNsC2cjepbt7yjlJuVTx9RlFUDgNYV/nQf > > uhjSonVxHdgWTFI6tk/m > > =UXv/ > > -----END PGP SIGNATURE----- > > > > > > > > >
February 24, 2014 - March 14, 2014
Europa-Archive.digest.vol-le
