Europa-Archive.digest.vol-oc
June 14, 2020 - September 23, 2020
nded
>> Did you replace the outer as well as the inner cables?
>> What thickness is the required inner piano wire?
>> Where do you obtain the piano wire?
>> Did you use the existing fittings on the ends of the cables inside the th
rottle box? if so, how did you do the change over from the original strande
d inner to the solid inner?
>> Any photos would be welcomed too please.
>> Thank you in anticipation
>> Kingsley in Oz
Subject: | Throttle cables with solid inner (piano wire) |
Kingsley,
I used solid stainless steel Bowden wire, .078" diameter. As I did my own
firewall forward I purchased bicycle cable, removed the twisted wire and
inserted the solid Bowden wire. Regarding the connection to the throttle
lever, I used AN111 Cable bushings as pictured below. Both items were
purchased from Aircraft Spruce. Simply bend the end of the Bowden cable
around the bushing forming a closed question mark (?) and secure it with
Redux or JB Weld. Attach the cable to the throttle lever as per the Europa
instructions. 17+ years of trouble free operation. Works a treat.
Erich
N28ET Classic Mono 914
Subject: | Re: Re : IFR certification |
I did my imc training in my trigear
No problems at all.
I know some aircraft are more stable but to say it=99s not a good IFR a
ircraft is not what I have found.
Kevin Challis
G ODJG
> On 16 Jun 2020, at 18:06, Pete wrote:
> =EF=BB
> Great write-up Paul, thx!
> Question, why not leave the gear up till minimums to keep the speed up?
>>> On Jun 16, 2020, at 12:46 PM, Paul McAllister wrote:
>> =EF=BB
>> Hi John,
>> I hope you don't mind me offering a counter opinion. I didn't find my Eur
opa a very good IFR platform. It was okay but I always maintained high pers
onal minimum, 600' on the ILS and 800' for non precision approaches. I live
in the mid west of the US and icing was always a concern. While one should n
ever fly into know icing conditions I had inadvertently picked up ice in ot
her aircraft I have flown and although concerning the aircraft performed wel
l enough to land it. Even then I new that all that had happened was "I got a
way with it"
>> I did catch a small skim of ice on the Europa once and the aircraft immed
iately lost 20 knots and I was worried that it would just quit flying there a
nd then! A flapless landing in a mono isn't possible and I was really (real
ly) nervous lowing the gear. I know we can all say that we should avoid ici
ng conditions but I encountered unforcasted ice many times. Over the years I
got smarter at figuring out potential or possible conditions but I could ne
ver get comfortable. The other challenge is that its slow approach speed is
n't an advantage for instrument approaches. You feel like you are hanging ou
t on the ILS forever in wet moist clouds.
>> I haven't flown my aircraft for some time but in latter years all my IFR f
lying was in VFR conditions. It is nice to be able to fly away from somewher
e crummy to somewhere nice, and I find the National Aerospace System (NAS) a
delight to use.
>> Just my 2 cents worth, and as they say "Your mileage may vary"
>> Cheers, Paul
>>> On Thu, Jun 11, 2020 at 10:24 AM John Wigney
wrote:
>>> Hi Jeff,
>>> There is a good link on this subject at https://www.eaa.org/eaa/aircraft
-building/intro-to-aircraft-building/frequently-asked-questions/equipping-a-
homebuilt-for-ifr-operations
>>> I am not an IFR pilot but I have done 40 plus hours of training in my mo
nowheel. My instructor was very happy with the plane and called it "a good I
FR platform". I chose not to take the check ride as I decided not to fly sin
gle pilot IFR. A major reason for that is that I found the plane to be fairl
y neutral on heading and I was not happy to find myself 10 to 15 degrees off
course if I groped around in the back for something. I have now fitted a he
ading autopilot driven by my Dynon D10A which works very well following the p
ink line on my Garmin 430 so that addresses that primary concern. I really h
ave no need for IFR and am happy to leave it that way.
>>> Anyway, I am not aware of any certification requirement apart from an en
try in the logbook regarding compliance with 14 CFR Part 91, section 91.205
>>> Cheers, John
>>> From: Jeff B <topglock(at)cox.net>
>>> Subject: Europa-List: IFR certification Good morning all, I'm wondering i
f someone out there has any information on certifying the Europa for IFR fli
ght (in the USA). Is there a statement in the operating limitations that mig
ht mention this? I've a person interested in my bird who is asking about it.
Any help would be greatly appreciated. Thank You,
>>> -- Jeff
Kingsley,
Erich
From: | William Daniell <wdaniell.longport(at)gmail.com> |
Subject: | N460HJ wouldnt start this am |
I should think that i had been flying several times with this.
This is 50hours after a hundred hour check.
The engine which was zero hours had been sitting for about 8 years before i
installed it
William Daniell
+1 786 878 0246
Kingsley,
Erich
Subject: | Re: N460HJ wouldnt start this am |
Wow! Should be part of the 5 year rubber service?
Lucky you didnt burn any cyls? How were your egts? (Or did it just open up all
of a sudden?)
Another thing for me to watch for (spares are on my shelf).
Cheers
> The engine which was zero hours had been sitting for about 8 years before i installed
it
> William Daniell
> +1 786 878 0246
> <20200614_130803.jpg>
Well pete interesting that you mentioned that... yes it is and no it was
about the only thing i didn't change.
The colombian knowledge based on every climate from temperate to tropical
is that rotax carb rubbers are known to fail in hot country. Rotax motors
are used and abused (they use them for crop dusting in mxp savannah) in
ways that would make most of us blench and giving me a great deal of
confidence in rotax engines. the knowledge about what fails and doesnt
fail is based on real life. Btw i live in miami.
And yes...very, very lucky. I think cyl burn could have been the best
outcome. The worst doesn't bear thinking about.
I posted it so that everyone can learn through my mistake.
Henceforth i shall change every other year and follow buds advice to check
closely every 25 hours.
Will
William Daniell
+1 786 878 0246
On Tue, Jun 16, 2020, 16:33 Pete wrote:
> Wow! Should be part of the =9C5 year rubber=9D service?
> Lucky you didnt burn any cyl=99s? How were your egt=99s? (Or
did it just open
> up all of a sudden?)
> Cheers
> > On Jun 16, 2020, at 3:54 PM, William Daniell <
> wdaniell.longport(at)gmail.com> wrote:
> > =EF=BB
> before i installed it
> > William Daniell
> > +1 786 878 0246
From: | Paul McAllister <paul.the.aviator(at)gmail.com> |
Pete, for a while I did my practice currency this way. I could actually fly
an approach at 90 knots and still get it slow enough to get the gear out
and land. The trouble with this was that you only needed the slightest
distraction and you would be joining the ranks of =9Cthose who have
=9D
The other challenge is that it was rare to break out in the clear, cloud
bottoms would be straggly and when you are at minimums you have to quickly
decide if the RVR is sufficient, you have enough of the environment in view
and the the runway will provide enough breaking action.
To be honest I always found single pilot IFR really tough and during my
brief stint of professional flying I thought I had died and gone to heaven
with 2 crew operations.
Just my 2 cents worth. Cheers, Paul
> wrote:
> =EF=BB
> Hi John,
> Europa a very good IFR platform. It was okay but I always maintained hig
h
> personal minimum, 600' on the ILS and 800' for non precision approaches.
I
> live in the mid west of the US and icing was always a concern. While one
> should never fly into know icing conditions I had inadvertently picked up
> ice in other aircraft I have flown and although concerning the aircraft
> performed well enough to land it. Even then I new that all that had
> happened was "I got away with it"
> immediately lost 20 knots and I was worried that it would just quit flyin
g
> there and then! A flapless landing in a mono isn't possible and I was
> really (really) nervous lowing the gear. I know we can all say that we
> should avoid icing conditions but I encountered unforcasted ice many
> times. Over the years I got smarter at figuring out potential or possibl
e
> conditions but I could never get comfortable. The other challenge is tha
t
> its slow approach speed isn't an advantage for instrument approaches. You
> feel like you are hanging out on the ILS forever in wet moist clouds.
> flying was in VFR conditions. It is nice to be able to fly away from
> somewhere crummy to somewhere nice, and I find the National Aerospace
> System (NAS) a delight to use.
> Cheers, Paul
> wrote:
>> Hi Jeff,
>> https://www.eaa.org/eaa/aircraft-building/intro-to-aircraft-building/fre
quently-asked-questions/equipping-a-homebuilt-for-ifr-operations
>> monowheel. My instructor was very happy with the plane and called it "a
>> good IFR platform". I chose not to take the check ride as I decided not
to
>> fly single pilot IFR. A major reason for that is that I found the plane
to
>> be fairly neutral on heading and I was not happy to find myself 10 to 15
>> degrees off course if I groped around in the back for something. I have
now
>> fitted a heading autopilot driven by my Dynon D10A which works very well
>> following the pink line on my Garmin 430 so that addresses that primary
>> concern. I really have no need for IFR and am happy to leave it that way
>> entry in the logbook regarding compliance with 14 CFR Part 91, section
>> 91.205.
>> Cheers, John
>> *From: Jeff B **<topglock(at)cox.net> <topglock(at)cox.net>*
>> *Subject: Europa-List: IFR certification Good morning all, I'm wondering
>> if someone out there has any information on certifying the Europa for IF
R
>> flight (in the USA). Is there a statement in the operating limitations t
hat
>> might mention this? I've a person interested in my bird who is asking ab
out
>> it. Any help would be greatly appreciated. Thank You, *
>> *-- Jeff *
Pretty valuable pennies! Thx!
Pete :)
> On Jun 16, 2020, at 8:26 PM, Paul McAllister w
rote:
> =EF=BB
y an approach at 90 knots and still get it slow enough to get the gear out a
nd land. The trouble with this was that you only needed the slightest distra
ction and you would be joining the ranks of =9Cthose who have=9D
> The other challenge is that it was rare to break out in the clear, cloud b
ottoms would be straggly and when you are at minimums you have to quickly de
cide if the RVR is sufficient, you have enough of the environment in view an
> To be honest I always found single pilot IFR really tough and during my br
ief stint of professional flying I thought I had died and gone to heaven wit
>>> =EF=BB
>>> Hi John,
ropa a very good IFR platform. It was okay but I always maintained high per
sonal minimum, 600' on the ILS and 800' for non precision approaches. I liv
e in the mid west of the US and icing was always a concern. While one should
never fly into know icing conditions I had inadvertently picked up ice in o
ther aircraft I have flown and although concerning the aircraft performed we
ll enough to land it. Even then I new that all that had happened was "I got a
way with it"
diately lost 20 knots and I was worried that it would just quit flying there
and then! A flapless landing in a mono isn't possible and I was really (re
ally) nervous lowing the gear. I know we can all say that we should avoid i
cing conditions but I encountered unforcasted ice many times. Over the year
s I got smarter at figuring out potential or possible conditions but I could
never get comfortable. The other challenge is that its slow approach speed
isn't an advantage for instrument approaches. You feel like you are hanging
flying was in VFR conditions. It is nice to be able to fly away from somewh
ere crummy to somewhere nice, and I find the National Aerospace System (NAS)
a delight to use.
>>> Cheers, Paul
>>>> On Thu, Jun 11, 2020 at 10:24 AM John Wigney wrote:
>>>> Hi Jeff,
t-building/intro-to-aircraft-building/frequently-asked-questions/equipping-a
onowheel. My instructor was very happy with the plane and called it "a good I
ntry in the logbook regarding compliance with 14 CFR Part 91, section 91.20
5.
>>>> Cheers, John
if someone out there has any information on certifying the Europa for IFR f
light (in the USA). Is there a statement in the operating limitations that m
ight mention this? I've a person interested in my bird who is asking about i
>>>> -- Jeff
From: | Roger Sheridan <rogersheridan(at)mac.com> |
Subject: | Fuel Tank Fittings |
I hope to find two of these fuel tank outlet fittings originally
produced for Graham Singleton in mod 10823.
Please message me direct if you can help.
Many thanks,
Roger
From: | Kingsley Hurst <kingsnjan(at)westnet.com.au> |
Subject: | Re: Throttle cables with solid inner (piano wire) |
Hello Paul.
My query about solid strand cable was just that . . . . a query. I
have never had an issue with kinking. While my mate and I were working
on the carbs recently, we damaged a cable and I was only considering
replacment with the solid wire arrangement.
I have now purchased some Teflon lined bicycle brake cable with stranded
inners, am in the process of reusing the end fittings inside the
throttle housing and have practiced (on the old cable) cutting the inner
cable using the twist weld method referenced on the list recently by Ron
Parigoris. I must say the twist weld method works brilliantly to stop
fraying and adds no thickness at all to the cable end making it a breeze
to insert in the clamps at the carby end.
Thank you for your concern Paul, much appreciated.
Best
Kingsley
On 16.06.20 6:33 am, Paul McAllister wrote:
> Kingsley, mate I hope you don't mind me saying but you are trying to
> fix something that isn't broken. :)
> I had great success by shortening my cables to a more appropriate
> length and over the years there hasn't been a hint of an issue with
> kinking.
> Cheers, Paul
Thank you Erich, you have answered the question I was most concerned
about. Please see my reply to Paul McAllister.
Best regards
Kingsley
On 15.06.20 2:24 am, erichdtrombley(at)juno.com wrote:
> Kingsley,
> own firewall forward I purchased bicycle cable, removed the twisted
> wire and inserted the solid Bowden wire. Regarding the connection to
> the throttle lever, I used AN111 Cable bushings as pictured below.
> Both items were purchased from Aircraft Spruce. Simply bend the end
> of the Bowden cable around the bushing forming a closed question mark
> (?) and secure it with Redux or JB Weld. Attach the cable to the
> throttle lever as per the Europa instructions. 17+ years of trouble
> Regards,
> Erich
> Main Image
Will,
The photo isn't visible. What failed?
Jim
http://forums.matronics.com/viewtopic.php?p=496877#496877
Jim
Ah ok the matronics server stopped it.
The rubber carb flange....almost completely separated.
So when it would start i opened up the cowling and having checked the plugs
and ignition was just about the pull the float bowls off when the carb came
off in my hand as it were.
I must have landed with it close to that state. I can only guess that the
induction suction plus the turbo airbox kept the carb on in flight.
Will
William Daniell
+1 786 878 0246
On Wed, Jun 17, 2020, 06:59 h&jeuropa wrote:
> Will,
> Thanks
> Jim
Subject: | Re: Fuel Tank Fittings |
Roger,
If you can't find them in the UK, I'm pretty certain I have them.
Jim
http://forums.matronics.com/viewtopic.php?p=496882#496882
I think our IFR experience in our Europa is like Johns. Granted we mostly use
IFR to climb or descend thru a cloud deck and for ATC services, especially in
congested or unfamiliar airspace. Since there is no snow removal at our airport,
we do not fly much in January or February.
However, we have found our Europa carries ice without adversely changing the performance.
Obviously we try to avoid icing and usually do. We have a conventional
heated pitot which draws about 8 amps but with our modified voltage regulator,
we have capacity so it can be used if necessary. There are more efficient
pitots available today.
Since fitting an adjustable cowl flap, cabin heat and windscreen defogging is much
less a problem than originally.
Jim, with the guidance of his regular CFII, has developed detailed IFR procedures
that provide consistent results. He flies approaches frequently enough to
maintain legal proficiency and he now completes both a Biannual Flight Review
and Instrument Proficiency Check every twelve months (helps with insurance).
Our Europa flies hands off when properly trimmed (both pitch and aileron trim)
and we have no autopilot, so all piloting is by hand. Approaches are flown at
cruise settings until reaching the Final Approach Fix (FAF) at which point the
airplane is changed to landing configuration (gear/flaps down, power and pitch
for appropriate rate of descent (usually 500 fpm) and 60 kts).
Having an EFIS makes the mechanics of approaches easier because the information
is presented efficiently. The velocity vector feature of our GRT EFIS reduces
chasing the needles. Our navigation source is a Garmin GNS 430, so all approaches
are setup and performed in a similar manner. Understanding how the GNS
430 operates and having the skill to use its features is key to IFR flight.
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=496887#496887
Replacement of the rubber carb flange is called out in the 5 year rubber replacement
instruction. There was a revision to the flange that is noted in SB 914-019
R1.
Brett from Leading Edge Air Foils suggested we replace the rubber pad under the
expansion tank. It is part no. 860 826. Indeed, when we got it out the old
one was rotted.
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=496888#496888
Hi Jim,
Awesome.
Does that mean you seriously considered alu fuel lines then chose not
to!!
I see pro=99s & cons to both systems.
What is super disappointing is the fuel smell I get using Gates
Barricade from Amazon
https://www.amazon.com/gp/product/B00498G5QC/ref=ppx_yo_dt_b_asin_title_
o02_s01?ie=UTF8&psc=1
I sometimes wonder if it is counterfeit?
A UK supplier shows white liner which is not noticeable on my hose.
https://www.moss-europe.co.uk/fuel-hose-gates-barricade-ethanol-proof-5-16
-id-per-metre-gfh1031x.html
Your opinions are of interest!
Roger.
PS Flew my classic into RAF Waddington today, launch point for the dam
buster raids!
> On 17 Jun 2020, at 16:43, h&jeuropa wrote:
> Roger,
> Jim
This is timely! My inspection of the throttle box discovered one of the cabl
e connections was very frayed right at the TH03 throttle cable eye, hanging b
y threads!
So I am looking at my options to stay with a similar install or going to sol
id wire. I imagine to stay =9Cstock=9DI will need to order a new
cable with the TH03 cable eye connected assuming they are available?
Other wise going Erich=99s route, which allows me to order via aircraf
t spruce.
For those of you who haven=99t inspected this for a while, might be wo
rth a look.
Thanks for any further thoughts.
Jerry
Mono 914
> On Jun 17, 2020, at 3:43 AM, Kingsley Hurst wro
te:
> =EF=BB Thank you Erich, you have answered the question I was most conce
rned about. Please see my reply to Paul McAllister.
> Best regards
> Kingsley
>> Kingsley,
n firewall forward I purchased bicycle cable, removed the twisted wire and i
nserted the solid Bowden wire. Regarding the connection to the throttle lev
er, I used AN111 Cable bushings as pictured below. Both items were purchase
d from Aircraft Spruce. Simply bend the end of the Bowden cable around the b
ushing forming a closed question mark (?) and secure it with Redux or JB Wel
d. Attach the cable to the throttle lever as per the Europa instructions. 1
>> Regards,
>> Erich
y threads!
t spruce.
rth a look.
Jerry
Mono 914
te:
> Best regards
> Kingsley
>> Kingsley,
>> Regards,
>> Erich
y threads!
t spruce.
rth a look.
Jerry
Mono 914
te:
> Best regards
> Kingsley
>> Kingsley,
>> Regards,
>> Erich
y threads!
t spruce.
rth a look.
Jerry
Mono 914
te:
> Best regards
> Kingsley
>> Kingsley,
>> Regards,
>> Erich
y threads!
t spruce.
rth a look.
Jerry
Mono 914
te:
> Best regards
> Kingsley
>> Kingsley,
>> Regards,
>> Erich
y threads!
t spruce.
rth a look.
Jerry
Mono 914
te:
> Best regards
> Kingsley
>> Kingsley,
>> Regards,
>> Erich
y threads!
t spruce.
rth a look.
Jerry
Mono 914
te:
> Best regards
> Kingsley
>> Kingsley,
>> Regards,
>> Erich
Sent again, looks like it bounced on my end, sorry if this is repeat.
Begin forwarded message:
> From: Jerry Rehn <rehn(at)rockisland.com>
> Date: June 17, 2020 at 5:05:58 PM PDT
> To: europa-list(at)matronics.com
> Subject: Re: Europa-List: Throttle cables with solid inner (piano wire)
> Reply-To: europa-list(at)matronics.com
> =EF=BBThis is timely! My inspection of the throttle box discovered one o
f the cable connections was very frayed right at the TH03 throttle cable eye
, hanging by threads!
olid wire. I imagine to stay =9Cstock=9DI will need to order a n
ew cable with the TH03 cable eye connected assuming they are available?
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
erned about. Please see my reply to Paul McAllister.
>> Best regards
>> Kingsley
>>> Kingsley,
wn firewall forward I purchased bicycle cable, removed the twisted wire and i
>>> Regards,
>>> Erich
Hello Jerry,
Do you stutter mate? Just joking . . . . . your post came through seven
times on the list!
Since only one cable was frayed, I suspect the TH03 fitting was binding
on the sleeve on which it should pivot freely. This would cause the
fitting to flex the cable at the end of the crimp as it appears it has
done. I further imagine that in cold countries like yours that after a
winter lay-up, any grease on the fitting could become quite sticky and
may well be the culprit.
Best regards
Kingsley
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
>> Best regards
>> Kingsley
>>> Kingsley,
>>> Regards,
>>> Erich
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
>> Best regards
>> Kingsley
>>> Kingsley,
>>> Regards,
>>> Erich
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
>> Best regards
>> Kingsley
>>> Kingsley,
>>> Regards,
>>> Erich
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
>> Best regards
>> Kingsley
>>> Kingsley,
>>> Regards,
>>> Erich
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
>> Best regards
>> Kingsley
>>> Kingsley,
>>> Regards,
>>> Erich
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
>> Best regards
>> Kingsley
>>> Kingsley,
>>> Regards,
>>> Erich
aft spruce.
orth a look.
> Jerry
> Mono 914
> Sent from my iPad
rote:
>> Best regards
>> Kingsley
>>> Kingsley,
>>> Regards,
>>> Erich
Subject: | Propeller? Gearbox? Wow-wow-wow |
From: | "JonathanMilbank" <jdmilbank(at)yahoo.co.uk> |
The title more or less says it all! The engine is a 912ULS with 600 hours total
and the propeller is an Airmaster which is serviced/greased every 100 hours as
specified and is well balanced. The carburettors are regularly checked with
a CarbMate electronic synchroniser and maintained as perfectly matched as possible.
The aircraft is delightfully smooth to fly, yet there is a "fly in the ointment".
During the last 50 hours or so of flying, a constant "wow-wow-wow" sound, akin
to that of a piston twin aircraft with unmatched rpm, has gradually increased.
For most flights since the sound first appeared I could level off in the
cruise, select "Manual" on the propeller control and reduce engine speed to about
4700 rpm, which reduced the sound oscillation to almost nil.
But recently it has become more intrusive, to the extent that further reduction
of engine rpm doesn't eliminate the problem. So I'm thinking of removing the
gearbox and getting it checked over professionally, in case the dogs or their
springs could be the culprits. By the way whenever I do the friction torque check,
it always results in a reading of around 45 to 50 N-m.
Within the last approx. 20 flying hours I've replaced 2 exhaust springs in different
locations, which might be indicative of undesirable vibrations
Any advice please before I resort to gearbox removal. I've done it before and know
what's involved, but if you believe that it might be a wasted exercise please
tell me soon, thanks
http://forums.matronics.com/viewtopic.php?p=496910#496910
Whoops that was meant to go direct, not to the list.
> On 17 Jun 2020, at 21:06, Roger Sheridan
wrote:
> Hi Jim,
> Awesome.
to!!
> Regards,
> Roger.
buster raids!
>> On 17 Jun 2020, at 16:43, h&jeuropa > wrote:
>> Roger,
>> Jim
<http://forums.matronics.com/viewtopic.php?p=496882#496882>
From: | Rowland Carson <rowlandcarson(at)gmail.com> |
Roger - I turned up my own versions of these from aluminium bar stock -
see:
http://www.rowlandcarson.org.uk/aviation/europa_435/making_tank_adaptors.p
hp
and
http://www.rowlandcarson.org.uk/aviation/europa_435/tank_adaptors.php
and
http://www.rowlandcarson.org.uk/aviation/europa_435/tank_adaptor_c_fitted.
php
Sorry, I don=99t feel I want to spend the time on making them
again just now, but if you are really stuck I might consider it!
Alternatively, if you know of or can find a model engineering society in
your neighbourhood one of those guys might be happy to do the job for
you. I attach my dimensioned drawings of the 3 slightly different
adaptors I made. I didn=99t bother to mill flats on them as I
didn=99t have a milling machine at that time and (although
possible) it would have been a bit tedious doing the milling on the
lathe.
Hope this is of some use.
in friendship
Rowland
Subject: | Re: Propeller? Gearbox? "Wow-wow-wow" resonance |
From: | "Remi Guerner" <air.guerner(at)orange.fr> |
Jonathan,
I do not think your gearbox could cause your problem. The cause may be a bug in
the propeller controller. I would ask Airmaster for advice.
Good luck
Remi
http://forums.matronics.com/viewtopic.php?p=496919#496919
Subject: | Biax Material for Europa classic wing |
Hey Guys,
I am actually building an Europa classic (blue foam) Wing. I am running out of
material (biax cloth) and I would now like to buy some new. The problem is, I
don't know what material the "biax" is. Does anyone of you can help me with a
specification or typ of cloth?
http://forums.matronics.com/viewtopic.php?p=496922#496922
From: | Tony Renshaw <tonyrenshaw268(at)gmail.com> |
Subject: | West Systems for wing filling ?? |
Gidday,
Over time I have found exposure to Ampreg products gave me flu type symptoms for
a couple of days after use, so I have migrated to the West Systems 105/106 Resin/Hardner
combination, with far less issues. I am wondering if others have
used it for filling their aircraft, whether it sands well, or whether I should
consider something else? I think at this stage Ill keep to an epoxy based filler,
unless I get a compelling argument to use something else. Hoping to get some
pearls of wisdom.... thanks in advance.
Tony Renshaw
Doubt that its propeller related. Try a stethoscope. If you have 600 hours on it,
you may be ready for some gear box service. I had 700 hours on mine before
getting rebuilt.Dont let it go too long as it is full of expensive parts.
N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
http://forums.matronics.com/viewtopic.php?p=496924#496924
Subject: | Re: Biax Material for Europa classic wing |
From: | "spcialeffects" <spcialeffects(at)aol.com> |
Hi TobiK. I too built a classic but didn't have the biax cloth. I spoke with Andy
D and he told me the very early kits (first 12 or so) used 2 layers of uni.
When i was looking for the Biax cloth ito couldn't get the exact specs not even
from the LAA.
Good Luck
http://forums.matronics.com/viewtopic.php?p=496926#496926
Subject: | Re: West Systems for wing filling ?? |
Yes i to used the west system for the filling stage on the recommendation from
Neville E, It sands much better then the ampreg.
http://forums.matronics.com/viewtopic.php?p=496927#496927
From: | "clivesutton" <clive.maf(at)googlemail.com> |
Hi Jonathan, what you describe is 'Heterodyning' or 'Beat-frequency' created by
the difference between two noise or vibration frequencies very close together.
Do you have a recording on e.g. a mobile phone that i could listen to - along with
the engine speeds in play at the time? And what about:-
1) How the frequency of 'wow-wow' change if you speed up or slow down the engine
a bit?
2) How does the 'wow-wow' effect change with Airspeed?
3) the CS mode idea is viable too - does it occur when that is turned off/the prop
is not trying to hunt for optimum speed vs pitch?
It's impossible to say from just the description given, but assuming the above
items make a significant difference, my initial suspicions would be one prop blade
with a slightly different prop pitch to the others and/or blade tip tracking
differences between blades. Both of those parameters should be quite easy
to check on the ground (no engine running needed) and reporting any variation
you find?
Clive
http://forums.matronics.com/viewtopic.php?p=496930#496930
From: | "Bob Harrison" <ptag.dev(at)talktalk.net> |
You do right Tony , I never had the flu symptoms but have down the years had other
lung contaminants Passive smoking, Driving cranes under British Steel Blast
Furnace Cast House Floor, Rode motor bike in heavy traffic long journeys, Built
a Classing wing Europa With no MASK ever also had pneumonia twice at 3 months
and 14 years, So I now have COPD (Chronic Obstructive Pulmonary Disease)Which
has every indication of taking about 5 years off my life which didn't matter
then but focuses my mind now, particularly when attempting to build an oxygen
Non invasive Ventilator !......because our glorious NHS has me under "house
arrest" until Mid July ....but I can open a window !.
They won't afford me one to stay home only when hospitalized or Care home !
But my oximeter says I'm mostly 94% but no more flying over Mont Blanc !
Best Wishes.
Bob H EX G-PTAG.
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Tony Renshaw
Sent: 19 June 2020 12:40
Subject: Europa-List: West Systems for wing filling ??
Gidday,
Tony Renshaw
This email has been scanned by BullGuard antivirus protection.
For more info visit www.bullguard.com
Hi Everyone,
Thanks for all your replies with suggestions, several of which I'm now following
up. After a thorough in depth investigation with engine cowls off, I've got
a couple more things to try like unclamping the exhaust header tubes and moving
the silencer slightly before tightening again. This is intended to move it a
little further away from the air duct against which it might be vibrating in
flight, when the engine leans over due to torque.
Clive, my mobile 'phone is a Tesco 20 special, which only does calls and texts.
The frequency of the 'wow-wow' doesn't seem to change when I vary rpm in the
cruise, but then I'm only varying it by about 6%. I also can't say that I notice
any change with airspeed. I switch the controller to manual during the cruise
to reduce rpm from 5000 to 4700, so the CS function probably isn't a factor.
Thanks for the pointer regarding one propeller blade tip tracking differently from
the others. Although the wonderful Airmaster propeller which I've had for
nigh on 20 years is virtually 'bomb proof', I'll definitely investigate.
Best wishes,
Jonathan.
http://forums.matronics.com/viewtopic.php?p=496966#496966
Jonathan, a further investigation suggestion that you can do from the comfort of
your home:
1) Download this free sound tool onto your PC: https://www.nch.com.au/tonegen/index.html
2) Create two sine tones and adjust one to be 1hz higher than the first (i used
440Hz + 441Hz). Play it and you might get the effect you are hearing in the
aircraft. The Wow-Wow you hear is effectively the difference between the two
frequencies so a 'Wow' repeats every 1 second in this case. Play with different
frequencies to get the effect you experience . . . [Caveat - audio speakers
and headphones are not that good at reproducing low frequencies - so the quality
of what you hear may be affected by that factor]
3) For an engine running at 4700 RPM and a gearbox reduction of 2.43, the gearbox
shaft is turning at 32.23 rotations per second at that RPM. That shaft has
three prop blades bolted to it - so the frequency of pulsation from any one blade
is 32.23 Hz and the frequency of pulsation from all three blades passing
in front of you at 4700 RPM is 96.69 Hz.
4) based on this logic, if any one of those pulsations is higher or lower than
the other 2 (as a result of e.g. tracking or different pitch setting of one blade)
i suspect that might be your Wow-Wow source.
I'm not sure this rules out your gearbox - but it's something to check
http://forums.matronics.com/viewtopic.php?p=496969#496969
From: | "budyerly(at)msn.com" <budyerly(at)msn.com> |
Jonathan,
By putting the Airmaster in MANUAL mode the prop is fixed, so hunting of the prop
is unlikely if the warble persists at any RPM. As for blade tracking, if the
blades are still firm and not twisting, that rules out a tracking issue normally.
I left some super thin painters tape on all three blades one time after a touch-up.
I know, a good preflight and proper workmanship would have prevented this...
I couldn't figure it and quickly took the brand new plane down to the dealer.
After hauling the plane down to have the gearbox checked, Lockwood could
find nothing. When picking up the plane, I found the thin painters tape, pulled
it off and behold, a good sounding engine again and I had a much lighter
pocket book.
Another "brain fart" I'm not proud of, an owner came in with a blade that was beginning
to show signs of leading edge wear. The thin metal leading edge guard
was slightly dented and pitted on his Warp Drive. I didn't notice it was becoming
de-laminated (slight bubble). I should have caught it on a close inspection
but didn't. This was not a warble sound from the outside, it was a sharp
hum or buzz, but inside it seemed to have a warble. Rebuilt the blades (fairly
cheap) and all was good. If your leading edges are unevenly worn or pitted,
and or the trailing edge of your leading edge tape even slightly loose, refinish
the blades.
Folks are right, the book says for most gearboxes, an overhaul at 600 hours is
required for continuing maintenance. Gearboxes are normally sent off for the
overhaul (which takes 30 minutes at Lockwood). I pull the prop, the gearbox and
drive down and have lunch with the boys, then come back. Nice visit and about
$3-400 if no main gear parts are needed. The time is one hour and the new
seals and bearings are quite cost effective.
Exhaust resonance is tough to find. Exhaust leak soot and spring failures generally
point the way that something is amiss. One must be very careful trying
to troubleshoot this during ground runups.
A problem with the sprag clutch can cause noise, but that is clearly heard around
an idling engine, so I doubt that is an issue.
Vibration noise from the airframe is tough to track. Loose gear components, speed
kits, and anything that vibrates in flight will pick up a power plant frequency
and resonate along with the other vibrations. A slight difference in frequency
will cause a distinct increase and decrease (like that propeller sync
example) giving you fits troubleshooting those type things.
Keep us all posted.
Bud Yerly
http://forums.matronics.com/viewtopic.php?p=496978#496978
TobiK,
The Biaxial cloth is SP Systems XE481
You may be able to get some from Europa.
Cheers
Kingsley in Oz
On 19.06.20 9:14 pm, TobiK wrote:
> Hey Guys,
I don't know what material the "biax" is. Does anyone of you can help me with
a specification or typ of cloth?
Subject: | Question for the classic-mono fliers |
Who out there are flying with an airmaster prop?
What spinner is used, and how does it fit against the classic cowl (Isn't th
e airmaster spinner too small?)?
Are all Classic mono's (with the XS tailwheel) all flying with the 62" prop?
Can the 64" (whirlwind) be used? Could the 64" be used if the XS tailwheel s
pring is lowered allowing for increased deck angle?
How much higher is the XS thrust-line vs the classic?
Many thanks for any/all info!
Pete
Subject: | Re: Question for the classic-mono fliers |
Hi Pete,
My aircraft which I built was a Classic Mono for about 650 hours and had a 912UL
80hp with Airmaster and 62" diameter tapered blades. After converting it to
a tricycle and installing a 912ULS 100hp with 64" diameter wider blades, it has
flown about another 400 hours during which time the firewall forward was altered
to the Neville Eyre cowls, making it very much more like the XS f/w forward.
(See attached image.)
I never actually measured the propeller ground clearance with the fuselage horizontal
while it was still a Mono with 62" propeller, but subjectively I guess
it would be much the same clearance as an XS tricycle with 64" propeller.
While it was still a Classic Mono, Airmaster made spinner bulkheads for me which
very well matched the Classic cowls. No doubt they still have the molds. When
I converted to Nev Eyre's cowls, I acquired a smaller diameter spinner which
matches the XS cowls and gave away my big spinner with bulkheads to someone who
needed them.
I don't believe that it would be necessary to lower the XS tail wheel spring, because
reduced propeller ground clearance with a 64" propeller becomes more significant
when the tail gets raised during take off. Yet I flew happily enough
like that for many hours before concerting to tricycle u/c.
http://forums.matronics.com/viewtopic.php?p=497003#497003
http://forums.matronics.com//files/g_eiky_nev_eyre_cowls_190.jpg
Subject: | Hand propping the Rotax |
It is well known that the Rotax cannot be handpropped, right? This was what I believed...until
I watched this video (2:00 - 3:00):
https://www.youtube.com/watch?v=HDsQIgUYvxY
Remi
http://forums.matronics.com/viewtopic.php?p=497022#497022
Subject: | Frame/gear offset error? |
Hi Folks,
My kit=99s (circa-2001) frame seem to have an offset error on the swi
ng-arm tube centering tabs, making it not possible to drop the gear without i
nterference. Anyone else seen this error? Looks like a fiddly fix to carefu
lly grind down one tab and adding to the other.
Picture is attached (if it gets through - also posted on the Europa Aircraf
t Owners FB page)
Thoughts/experiences anyone?
Many thanks,
Pete
A239
Bud and friends,
Today I found what I believe is the "smoking gun" i.e. the possible cause of the
strange "wow-wow-wow" resonance. While standing in front of the aircraft I saw
that the propeller spinner is now displaced about 5mm to the left and is sagging
about 4 mm. On standing closer it was easy to see that the 2 screws which
secure the upper cowl nearest the spinner, are no longer equally spaced either
side of the spinner. Voila!
Off came the cowls and a couple of hours were spent closely investigating both
the engine bearer frame ( a la Neville Eyre ) which is built to battleship standards
and the undercarriage frame which was found to be crack free and as strongly
secured to the fuselage tunnel as ever. A friend assisted by repeatedly
lifting the engine up and down and side to side, while I used a strong light and
felt all over for evidence of movement due to cracking. Then we swapped roles,
before reaching the conclusion that both frames are sound and solid.
So all this suggests to me that it could be time to replace the Lord engine suspension
rubbers, which haven't been replaced in living memory or 12+ years! But
I seem to recall that there was a bit of indignation in this forum about the
excessive hardness of rubbers supplied by Europa. Please refresh my memory and
let me know if the hardness problem was ever resolved.
I've tried a search and trawling through various topics, to little avail. All I
could find was someone's query about MT04 and Lord J 3608-1.
http://forums.matronics.com/viewtopic.php?p=497027#497027
Subject: | Re: Hand propping the Rotax |
From: | "Hitchflight" <bobhitchcock(at)icloud.com> |
That looks and feels so wrong on a Rotax. And no chocks......
http://forums.matronics.com/viewtopic.php?p=497029#497029
Subject: | Re: Frame/gear offset error? |
Pete,
Could you explain further what is the problem? From the photo I don't see anything
wrong.
Jim
http://forums.matronics.com/viewtopic.php?p=497032#497032
Hi Jim,
The swingarm is not centered and does not clear the frame (pilot side) to drop
the gear. The locating tabs on the swingarm tube are incorrect and nit crnteted,
although are the exact correct width (no lateral play) wrt to the swingarm
bushings.
> On Jun 25, 2020, at 8:01 AM, h&jeuropa wrote:
> Pete,
wrong.
> Thanks,
> Jim
From: | "Pete Jeffers" <pjeffers(at)talktalk.net> |
H Pete,
I am afraid your description and photo do not tell me a great deal about your problem
BUT I would like you to check something that causes a restriction much
as you describe Ie leg not retracting or extending properly. I would use a manual
page to refer you to but I am unable to get onto the Europa Aircraft web site.
I know I am registered but they don't think I am.
There is one unit that can be fitted either one of two ways round. One is right
and the other will give you a problemm such as you describe. I now have a tri
gear so only have immediate access to a Tri Gear manual. Not too helpful when
you are talking Mono problems.
Pete Jeffers ( LAA rep to the Europa Club)
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Pete
Sent: 24 June 2020 16:25
Subject: Europa-List: Frame/gear offset error?
Hi Folks,
My kits (circa-2001) frame seem to have an offset error on the swing-arm tube
centering tabs, making it not possible to drop the gear without interference.
Anyone else seen this error? Looks like a fiddly fix to carefully grind down
Picture is attached (if it gets through - also posted on the Europa Aircraft Owners
FB page)
Many thanks,
Pete
A239
This email has been checked for viruses by AVG.
https://www.avg.com
From: | Erich Trombley <erichdtrombley(at)juno.com> |
Pete,
What do you mean by centering tabs? From you picture it looks like the swing arm
needs to be moved over slightly to the S.B. side. I believe the lateral position
of the swing arm is set by the LG08 legs which are centered in the large
diameter cross tube and LG02A which is bolted to the swing arm. Looking at
your picture it doesnt look like the LG08s have been mounted to the frame yet.
I suspect you just need to clean up the bearing surface on the lower frame to
allow the swing arm to slide closer to the port side down tube. Or perhaps
I am missing something and got it all wrong.
Erich
N28ET Classic Monowheel 914
Indeed the swingarm is centered on the lower frame tube by two small tabs we
lded onto the top of that tube, which ride on the inside vertical surface of
the arm=99s brass bushing blocks. Those tabs are nicely tight on the
swingarm to prevent any lateral sliding of the swingarm on the tube, but sa
dly they are offset to the pilot=99s side on mine, preventing the swin
garm from clearing the vertical tube. I was just wonder if others had seen t
his fabrication error, or if mine was a one-off mistake.
Cheers and thanks,
Pete
> On Jun 25, 2020, at 11:26 AM, Erich Trombley wro
te:
> =EF=BBPete,
> What do you mean by centering tabs? =46rom you picture it looks like the s
wing arm needs to be moved over slightly to the S.B. side. I believe the la
teral position of the swing arm is set by the LG08 legs which are centered i
n the large diameter cross tube and LG02A which is bolted to the swing arm.
Looking at your picture it doesn=99t look like the LG08s have been mo
unted to the frame yet. I suspect you just need to clean up the bearing sur
face on the lower frame to allow the swing arm to slide closer to the port s
ide down tube. Or perhaps I am missing something and got it all wrong. =F0=9F
=A4=94
> Regards,
> Erich
Peter,
Photos can be deceiving but in the photo attached, it appears the brass
bushings may be offset with respect to the swinging arm. As a point of
interest, have you tried inverting each pair of bushings to see if there
is any improvement?
If the tabs as you call them are different distances from the side frame
(a fabrication error as you suspect), I think I would be tempted to
simply grind away that part of the swinging arm that conflicts. There
is not much clearance at the best of times in that area.
Now to answer your question . . . . . No I haven't seen that fabrication
error but I have seen a different one on the same framework.
Cheers
Kingsley
On 26.06.20 1:45 am, Pete wrote:
> Indeed the swingarm is centered on the lower frame tube by two small tabs welded
onto the top of that tube, which ride on the inside vertical surface of the
arms brass bushing blocks. Those tabs are nicely tight on the swingarm to prevent
any lateral sliding of the swingarm on the tube, but sadly they are offset
to the pilots side on mine, preventing the swingarm from clearing the vertical
tube. I was just wonder if others had seen this fabrication error, or if
> Cheers and thanks,
> Pete
Pete,
>From what I see on your pictures, it seems that one weld (image2) is preventing
the swinging arm to be moved to starboard enough to clear the frame when in
the extended position. May be some filing of the excess welding would solve this
issue?
Good luck
Remi Guerner
http://forums.matronics.com/viewtopic.php?p=497044#497044
Hi again,
I have, thanks to Bob Hitchcock, now found the page and picture I refer to. The
assembly I refer to is on P 29M - 7 of the build manual. The item I refer to
which can be fitted the wrong way round is LG 05 ( shock absorber top plate).
Please chech this before you start filing anything.
Pete J
From: Pete Jeffers [mailto:pjeffers(at)talktalk.net]
Sent: 25 June 2020 15:46
Subject: RE: Europa-List: Frame/gear offset error?
H Pete,
Hi Folks,
FB page)
Many thanks,
Pete
A239
https://www.avg.com
Pete,
Please ignore my previous post. After a closer look at your photos, I see now the
tiny tabs you are referring to. You are perfectly right: they are welded in
a position which makes the swinging arm to be offset to the pilot side.
Not easy to fix that properly. Good luck!
Remi
http://forums.matronics.com/viewtopic.php?p=497049#497049
Subject: | Re: Europa Ladies!!! |
From: | "savageema" <alicebetha(at)protonmail.com> |
Watching european amateur girls is great. This is what sites like SexCamsBay (https://sexcamsbay.com)
are made for. seeing all the models doing great cam porn
videos is just amazing and you wish you had more free time to watch.[/code]
http://forums.matronics.com/viewtopic.php?p=497059#497059
Subject: | Fuel pump Classic |
From: | "tennant" <barrington.tennant(at)gmail.com> |
I think it is about time to change the mechanical petrol pump on my classic Europa.
It looks like the new design Rotax pump will foul the right radiator. Does
anyone have experience with this and if so what is the best solution?
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=497062#497062
Subject: | Re: Fuel pump Classic |
Indeed it does. I took mine to a local welder and had him put a 20-ish degre
e outboard angle on the outlet (?) to clear the new pump. The welding may ha
ve resulted in a fin leak, to which i had rectify using JB-weld epoxy, which
is working effectively for now until i can source a new custom radiator.
Cheers and good luck!
Pete
> On Jun 28, 2020, at 7:11 AM, tennant wrote:
gmail.com>
c Europa. It looks like the new design Rotax pump will foul the right radiat
or. Does anyone have experience with this and if so what is the best solutio
n?
> Barry
> Barry Tennant
> D-EHBT
> At EDLM - Germany
I seem to recall that there is at least one europaphile with a five point
harness...in europe i seem to recall. I cant find the thread on the forum.
I have a very reclined seat due to my height and am concerned that in case
of an impact might slide under the belt. Hence my interest in anti
submarine belt aka crotch strap.
Can anyone help?
William Daniell
+1 786 878 0246
Subject: | Re: 5 point harness |
From: | "fklein(at)orcasonline.com" <fklein(at)orcasonline.com> |
I believe that would be Raimo Tolvio.
> On Jun 29, 2020, at 5:04 AM, William Daniell wrote:
> I seem to recall that there is at least one europaphile with a five point harness...in
> I have a very reclined seat due to my height and am concerned that in case of
an impact might slide under the belt. Hence my interest in anti submarine belt
aka crotch strap.
> Can anyone help?
> William Daniell
> +1 786 878 0246
Thanks fred
William Daniell
LONGPORT
+57 310 295 0744
On Mon, Jun 29, 2020, 18:27 fklein(at)orcasonline.com
> > On Jun 29, 2020, at 5:04 AM, William Daniell <
> point harness...in europe i seem to recall. I cant find the thread on the
> forum.
> case of an impact might slide under the belt. Hence my interest in anti
> > Can anyone help?
> > William Daniell
> > +1 786 878 0246
Hi Daniell,
how do you achieve a reclined seat position due to your hight without running out
of space for your legs? Did you also increase the distance to the rudder pedals?
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=497089#497089
Subject: | Lord engine suspension rubbers |
My question concerns MT04 or Lord J 3608-1 suspension rubbers. I recall from perhaps
a few years ago that there was some debate about these items and assertions
that they were either too hard or too soft. Thus far I can't find any reference
on the website to this controversy. Can anyone inform me about this, please?
Also I've been trying to call Karen at Europa without success for almost a week,
to find out about availability. Is she furloughed?
Thanks for whatever information you can provide.
http://forums.matronics.com/viewtopic.php?p=497092#497092
Roland
I dont seem to have photos of my seat so I will take some if I remember
when I next go to the hangar. Here's a pic of the right seat. It has a
hinge and removable wedges to adjust the under thigh support. this photo
is
[image: IMG_6121.jpg]
without the wedges. My instructor flew from that seat the other day and
pronounced it comfortable
[image: IMG_6119 (1).jpg]
The rudder pedals are in the standard location.
My principle with the aircraft was to make it as light as possible.
The seat I made for myself from composite/coremat. It is about 1/4" thick.
It is designed to support my weight evenly from shoulder blades through to
back of thigh so that almost no padding is required. Today I fly with just
a sheepskin - no foam. I am aware of the issue of hard landing and
compression but I considered that the lack of padding would be mitigated
by distributing my weight over a wider area.
There is about an inch from my headphones to the plexi
As it happened when I flew from Colombia to USA I flew every day for two
weeks up to 5 hours a day and was never uncomfortable.
William Daniell
LONGPORT
+1 786 878 0246
On Tue, Jun 30, 2020 at 2:43 AM Roland wrote:
> Hi Daniell,
> running out of space for your legs? Did you also increase the distance to
> the rudder pedals?
> Regards
> Roland
> PH-ZTI
> XS TG 914
Thanks for clarification, Daniell - interesting! I'm not that tall with 1,82 metres
but cockpit space is the only thing I'm missing a bit in the Europa. However
I have to add, that I'm wearing a parachute and without it I'd have 2-3 Inches
more legroom. What also might contribute to comfort in your plane, especially
on longer flights, is perhaps the less upright position of the upper body.
I can see on the photos, that you also have cropped control sticks installed,
which provide more space to the front edge of the seat.
Cheers
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=497105#497105
Subject: | Re: Lord engine suspension rubbers |
Jonathan,
I got parts from the factory last Monday, but this was a very long process. It
seems they are working part time due to the chineese stuff. I did not manage
to talk to Karen but had a contact with Dave.
Regarding the MT04, I had trouble years ago with way too soft parts supplied by
Europa. They supplied replacement parts which I installed 18 months ago, and
they are fine.
Remi
http://forums.matronics.com/viewtopic.php?p=497107#497107
Thanks Remi.
http://forums.matronics.com/viewtopic.php?p=497108#497108
Hello Jonathan,
I did get a response from Dave at Europa when I emailed Karen. I have
Been speaking to him this week and the number I used was 01603
738921.
Gordon
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=497109#497109
Subject: | Carburettor icing with heated carbs |
My aircraft gave me a little excitement last week. It has the radiator hot water
permanently circulating around the inlet manifold ends of both carburettors,
which heats the downstream ends just beyond the throttle butterflies and also
hopefully the butterfly spindles to conduct residual heat into the butterfly
valves. Many aircraft with Rotax 4 stroke engines use this method to prevent carburettor
ice build-up and I've never heard of one with this modification which
suffered from it.
There's been a quite well-known spate of sinking floats, possibly due to a batch
of poor plastic from which the floats are made reacting with ethanol (who knows?)
in the unleaded fuel. I recently acquired 4 spare floats and I changed one
which was half sunken. I'm told that if only one float in a bowl is doing its
job properly, then a richer mixture will happen.
We all know that carburettor ice can happen in air temperatures up to around 25C
and the warmer the air, the more moisture it can hold. Rich fuel / air mixture
makes icing more likely, due to increased fuel evaporation cooling the metal
parts. Also in an carburetted aircraft, long descents with the throttle only
partly open greatly increase the possibility of carburettor ice. But this has
never been reported in a Europa to my knowledge because of the permanent radiator
water circulation as described above.
On the day in question I had just changed worn out propeller blade tape and balanced
the carbs to get rid of an annoying vibration in the cruise. I took off,
climbed ahead then turned downwind in the airfield circuit pattern (ACP) to accelerate
to cruise speed and check for vibrations. All seemed well during an
extended downwind leg, so I closed the throttle to reduce below flap limiting
speed then did a descending curve around onto final approach, using a little throttle
while making a long flat approach. It was an exceptionally warm humid
day!
I decided to make a "touch and go" landing before opening throttle wide to climb
back into the ACP. At about 300 ft while retracting the remaining half of flap,
the engine suddenly went "BRRRP" and shook violently for about 1 or 2 seconds
before becoming smooth again. I immediately considered either landing in a
nearby farm field or landing with a slight downwind on the runway if the engine
didn't die. But because there seemed to be plenty of smooth power restored,
I made a very short tight ACP and landed normally.
After discussion with another pilot who shares my 'plane and witnessed my swift
return from the ground, we agreed that carburettor icing was the most likely
cause, when a lump of ice probably broke free and went through the cylinders.
I removed the top engine cowl and looked for other possible causes and then removed
the float bowls. And there it was! Another one of the floats had sunk and
thereby allowed a richer mixture to worsen the risk of ice.
So on that day all the possible circumstances combined to allow ice to form in
one carburettor, not least being that the throttle was closed and then slightly
open for about 2.5 minutes. I replaced the float and did several more ACPs without
incident. However I can do without that kind of excitement, if the truth
be told.
http://forums.matronics.com/viewtopic.php?p=497110#497110
Subject: | Classic throttle cables |
I had the misfortune to suffer a throttle cable break last week, fortunately whilst
on the ground.
It would seem that Europa only stock one size of cable which are designed
for the XS and these are much longer than the original Classic cables. The problem
is not the inner as these can be cut, but the outer which is about
30cm too long. At present my only solution is to use the new inners with the
Old outers, but I just wondered if
anyone with a Classic has encountered this problem and if so how you resolved
the situation.
Dave at Europa is investigating as he was unaware the Classic required shorter
cables, but this does not help at the moment!
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=497111#497111
Hi! Gordon,
I never understood it possible to have a Europa throttle cable too long?
Mine went through the firewall and took a huge loop( almost to the front of
the cowl before returning back to the carbs for easy and free operation for
alignment to the carbs point of entry.( no clips or tie wraps needed)
Bob Harrison EX G-PTAG.
[mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GBWFH2010
Sent: 01 July 2020 10:04
Subject: Europa-List: Classic throttle cables
whilst on the ground.
problem is not the inner as these can be cut, but the outer which is about
resolved the situation.
shorter cables, but this does not help at the moment!
Gordon Grant
G-BWFH
Subject: | Re: Classic throttle cables |
Solid core (yes i did, also on the ground, and the friction did not allow the throttle
to go full open)? Or original stranded?
I have reverted to teflon coated stranded inners (bicycle brake cable core), and
find it is now very smooth and free.
Pete
the situation.
> Gordon Grant
> G-BWFH
Hello Jonathan,
I just recently switched from the MT04 to the Lord J3608-1. Aware of the QC
issues with the MT04 (which I understand have since been resolved), I
elected to install the Lord mounts after reading the archived posts on the
topic.
I can confirm the Lord mounts are much softer than the MT04s. Also, new
spacers are required as the bore of the Lord mount is larger. I machined
the new spacers such that they were the same length of the Europa supplied
ones. Quite a bit of shimming was required to raise the engine back to its
original location and I found there was significant movement of the engine
during a "botched start." In hind sight I believe the spacers should be
shortened a bit in order to provide more preload on the mounts, which should
result in less shimming and engine movement.
I use the term "botched start" to describe an unsuccessful start of a
warm/hot engine. Typically the engine is still warm from previous flight,
say returning to the airport after flying in for lunch. Using the normal
starting procedure (without choke) the engine fires but not quite on all
cylinders, it seems. There is this jerky motion whereby the engine seems
to stutter back and forth shaking violently. Its rather unnerving, and you
can't seem to the stop the engine quick enough.
BTW, the engine moved so much during the "botched start" that the propeller
spinner contacted the cowl in two places. Ouch! In addition to the spinner
contacting the cowl, I found that the S.B. airbox to carb rubber connecting
hose had come off the aft end of the carb and the airbox had slid partly off
the hose from the turbo. Now that's a lot of shaking!
I now use the following hot start procedure anytime other than starting a
cold soaked engine. Fuel pumps off and throttle wide open. As soon as the
engine starts immediately move the throttle to idle, wait until the engine
just starts to run out of fuel before turning on the fuel pump.
It seems that even a minor change can have significant unintended
consequences. I was not successful in finding information on the internet
regarding pre-load requirements/spacer length for the Lord mounts. If
anyone has such information I would be mighty obliged.
Erich
Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more
Fox Anchor Out Amid Sexual Misconduct Accusations
http://thirdpartyoffers.juno.com/TGL3131/5efccc24584234c231aacst04vuc1
Doomed Groom May Have Infected 100 at His Wedding
http://thirdpartyoffers.juno.com/TGL3131/5efccc24733ed4c231aacst04vuc2
2 Black Kids Played in a Hotel Pool. The Cops Were Called
http://thirdpartyoffers.juno.com/TGL3131/5efccc24930b24c231aacst04vuc3
Thanks everyone. Dave has kindly contacted me with the information I was seeking.
Jonathan
http://forums.matronics.com/viewtopic.php?p=497125#497125
Thanks Bob. Do you have a picture of your engine compartment showing
How your cables were routed?
Gordon
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=497135#497135
Does anyone (uk based) have a mono inner tube they dont need? Or a recommendation
as to which one to buy (no response as yet from Europa) Aviation)?
Roddy Kesterton
G-IKRK
Hi!Gordon,
No I don't have any pics or the plane any longer but I recall the cables
went forward from the standard quadrant box on the XS cockpit module through
the firewall and curved gently upwards to lay on the top of the engine,
forwards and then aligned backwards to the carb connections. They appeared
ridiculously long but no sharp or forced bends and no ties gave a completely
free movement. Once positioned they stayed throttle set by the friction
clamped on the actual throttle lever. But as you said they need to fail in
full throttle mode.
I also only oiled the actuating ends ......none down the cable length
......it only makes drag and collects dust. Mine were bicycle multistrand
cables , not the solid single wire type.
Hope this helps.
Bob Harrison Ex G-PTAG.
Sent: 02 July 2020 09:14
Subject: Europa-List: Re: Classic throttle cables
Gordon
Gordon Grant
G-BWFH
Thanks Bob, that is really useful.
Gordon
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=497138#497138
while we're on the topic, what is the recommended cable lubricant for South
Florida conditions?
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
> Regards
> Gordon
> Gordon Grant
> G-BWFH
Subject: | Re: Mono inner tube |
Hi Roddy,
I too gave up as I got no reply from Europa when I wanted one.
Closest I found to the long curved filling tube (TR67) was from Watts Aviation,
PN D20747 a 700/800-6 AM TUBE with a TR87 Valve.
Although the valve is shorter than the Europa standard, it is perfectly useable.
Watts had to order mine so it took a short while to come from the states, but I
have one in stock, if you need it urgently I could send you that and then you
just replace it for me, with the art that you order.
Best
Jon
http://forums.matronics.com/viewtopic.php?p=497155#497155
Subject: | Not starting 912ULS |
Fitted new radiator hose last week and ran engine to test for leaks.
Went back yesterday and will not start. I had fitted a soft start module. After
failing to start I removed the module and tried on the standard start with the
key start mag switch. Still no start. Checked plug for spark no spark?? Checked
earths seem ok.
Any body any ideas?
Dave Park
Subject: | Re: Not starting 912ULS |
Usually it=99s the failure of the spark boost in the second ECU, I
had to send mine back to Carmo electronics in the Netherlands, =82=AC55
0 to repair both ECU=99s so the spark is restored at cranking RPM
module. After failing to start I removed the module and tried on the
standard start with the key start mag switch. Still no start. Checked
plug for spark no spark?? Checked earths seem ok.
> Any body any ideas?
> Dave Park
From: | Steve Ivell <SteveIvell(at)pestproof.co.uk> |
Hi Dave
If it's the ignition module then you can usually "wake it up" by heating it with
a hair dryer/hot air gun (gently!!). Once it starts it should run fine as the
engine heats the ignition modules.
The Carmo repairs seem to fail after a while and are relatively expensive. There
is a guy called Andy Buchan who is a UK instructor who is supplying new (non-rotax)
modules at 300 per pair. They also have a long lead so you can mount them
away from the engine, say on the firewall, away from the vibration and a bit
less heat.
They have apparently been "road tested" on various aircraft and seem to work well.
May be worth a try.
Kind Regards
Steve Ivell
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com>
On Behalf Of david park
Sent: 05 July 2020 11:41
Subject: Europa-List: Not starting 912ULS
earths seem ok.
Any body any ideas?
Dave Park
From: | D McFadyean <ami-mcfadyean(at)talktalk.net> |
Or deal direct:
https://www.ignitech.cz/en/vyrobky/bikes/rotax/rotax%20912%20and%20914/rotax%20912%20and%20914.htm
Duncan McF.
> On 06 July 2020 at 14:32 Steve Ivell wrote:
> Hi Dave
the engine heats the ignition modules.
them away from the engine, say on the firewall, away from the vibration and a
bit less heat.
well. May be worth a try.
> Kind Regards
> Steve Ivell
the key start mag switch. Still no start. Checked plug for spark no spark?? Checked
earths seem ok.
> Any body any ideas?
> Dave Park
From: | William Daniell <wdaniell.longport(at)gmail.com> |
Fred,
didnt you design a headrest "extension" to raise the shoulder height of the
harness? I can find the posts but not the the design/pics on the forum.
If it was you would you mind sending me some pics and the design
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
On Mon, Jun 29, 2020 at 6:27 PM fklein(at)orcasonline.com <
> forum.
> > Can anyone help?
> > William Daniell
> > +1 786 878 0246
Subject: | Re: NSI CAP 140 Problem |
Hello Dave,
could you send the pdf to me as well, I`m facing also problems with the CAP 140.
Tuna
dg.watts(at)talktalk.net wrote:
> Mike,
> I have sent you a .pdf of the NSI Manual.
> If you dont receive it, let me know and Ill send it again.
> Dave Watts
> > On 10 Jul 2019, at 2:06 pm, Mike Kelly wrote:
> > Hello All,
> > I am experiencing a problem with the variable pitch on the Europa.
> > The pitch has become fixed in the "fine" position.
> > The slip ring is good and voltages appearing on the slip ring seem ok.
> > Does anyone have a description/wiring diagram of the system, or can anyone
> > pass on knowledge of where the problem might be?
> > Does anyone have a service manual that may help.
> > A cross section view of the mechanism would be great!
> > Many thanks in anticipation.
> > MK
> > Read this topic online here:
> > http://forums.matronics.com/viewtopic.php?p=490185#490185
http://forums.matronics.com/viewtopic.php?p=497207#497207
Subject: | Re: headrest extension |
Willyeshere are my sketches and a couple of
pixsassembly tested to 10 G=99slet me know if
you would like more infoBest, Fred
> On Jul 8, 2020, at 5:35 AM, William Daniell
wrote:
> Fred,
of the harness? I can find the posts but not the the design/pics on the
forum. If it was you would you mind sending me some pics and the design
> thanks
> Will
> William Daniell
> LONGPORT
> +1 786 878 0246
By the way , are you flying yet?
(I almost went tje subaru route but chickened out)
Will
William Daniell
+1 786 878 0246
On Wed, Jul 8, 2020, 13:02 Fred Klein wrote:
> Willyeshere are my sketches and a couple of pixs
> G=99slet me know if you would like more infoBest,
Fred
> wrote:
> Fred,
> thanks
> Will
> William Daniell
> LONGPORT
> +1 786 878 0246
Sorry
Forgot to say...Thank you!!
Will
William Daniell
+1 786 878 0246
On Wed, Jul 8, 2020, 23:22 William Daniell
> Will
> William Daniell
> +1 786 878 0246
, Fred
>> wrote:
>> Fred,
>> thanks
>> Will
>> William Daniell
>> LONGPORT
>> +1 786 878 0246
WillI did have my initial flight back on Nov. 1, =9919;
however, it was a short one due to engine overheating. I had fallen in
love with my tuned exhaust which placed a lengthy serpentine of exhaust
pipe under my cowl, and have believed that, even after wrapping all the
pipe & muffler w/ heat shield, I was introducing way too much heat under
the cowl and was compromising my cooling system.
After a nasty bout with shingles over the winter, I=99ve now gone
to straight pipes with twin =9CSwiss Mufflers=9Dthe
installation is just now complete. I=99m running 50/50 coolant
(265 deg. boiling point) and can now get almost 20 min. on the ground
before coolant temps reach 210 deg.
At the moment I=99m in the midst of retuning the engine,
relocating my OAT, and having another go at sealing some gaps around my
radiatorsfeeling a bit frustrated.
Fred
> On Jul 8, 2020, at 8:22 PM, William Daniell
> Will
> William Daniell
> +1 786 878 0246
wrote:
>> Fred,
>> thanks
>> Will
>> William Daniell
>> LONGPORT
>> +1 786 878 0246
Subject: | Need MAP Manifold Air Pressure 2 1/4 inch gauge |
Please would someone sell me a serviceable MAP 2 1/4" gauge. Looking on line has
been disappointing, in that all such items seem to come from the States and
therefore incur shipping charges greater than the item new asking price. I live
in Scotland.
Thanks, Jonathan
http://forums.matronics.com/viewtopic.php?p=497240#497240
Subject: | Re: LG frame cracks |
Hi Jim,
I am in process of removing my gear frame to repair/replace the bent bottom gear
pivot tube (present since my purchase, and likely made worse with my side-loading
since), and short of replacing the frame, would like to strip and inspect
the entire frame.
How did you get the frame to un-bond from the epoxy tunnel bedding?
What method did you use to strip the paint/powdercoating?
Can you tell me if the Tubes are all 4130?
Thanks for your detailed pdf report of the cracks, added to my inspection/reenforcing
list.
Pete
> On Nov 12, 2018, at 2:52 PM, h&jeuropa wrote:
> We discovered a potential safety issue and wanted to share this so others become
aware of the situation and can inspect their aircraft.
> We are in the process of our annual condition inspection on our mono wheel.
This year is extensive since motor mounts and bungee cord need replaced. After
being alerted by John Wigney of possible cracks in the lower tubes of the LG
frame, we inspected and discovered our frame is cracked like his. The cracks
are very difficult to find as they are somewhat hidden by the firewall and behind
the vertical tubes of the frame. Using Johns photos, a strong light, and
magnifying glass, we were able to see a crack in the starboard tube. A photo
with our iPad actually gave the best indication of a crack. A dye penetrant
test confirmed the crack. The crack in the port tube wasnt evident until the
powder coat was removed. The attached document has good photos of Johns cracks.
> We removed the frame and had it repaired by an experienced A&P (FAA mechanic)
using techniques called out in AC 43-13. We reamed out the tubes and machined
a tube to be a tight fit similar to Mod 72 for the upper tubes except the insert
is the full length of the tube. The insert is welded to the original tube
with rosette welds, and the cracks were stop drilled prior to welding. One
bolt hole was elongated so we changed it to AN4.
> A side note, when we started to remove the LG frame, we found that some of the
mounting bolts were no longer tight. When doing your inspection, we suggest
you check these nuts and if any are at all loose, inspect very carefully for
cracks.
> Our mono wheel kit was purchased April 2000, kit A185 and has 975 hours.
> Jim & Heather
> http://forums.matronics.com/viewtopic.php?p=484894#484894
> http://forums.matronics.com//files/181001a_photo_summary_of_landing_gear_frame_cracks_131.pdf
Subject: | Europa MT04 engine mounts |
Hello,
Can anyone tell me what the uncompressed length/height of a new uninstalled MT04
is? I measured the ones I recently removed and they vary considerably and obviously
have taken a set. I suspect they are something close to .970 or 24.6mm.
As noted in a previous email, I switched to Lord J3608-1 mounts. I contacted Lord
for the recommended preload, however, they indicated there were too many variable
to take into consideration. That said, they provided me with a drawing
for the 0-200 motor, which isnt very helpful, I am afraid. Interestingly, I
noted two very distinct differences in the Lord mounts as compared to the MT04s.
First is the hardness, the Lord mounts are quite a bit softer. And the second,
which surprised me, is the uncompressed length/height which I had incorrectly
assumed to be the same the MT04. You know what they say when you assume
something. Anyway the Lord mounts are shorter, by how much I cant say at the
moment as I require the uncompressed dimension of the MT04. Armed with this
information I should be able to trim the space by the delta, which I am hoping
will provide the necessary preload.
Kind regards,
Erich
Roger Stone Commutation Ups Outrage to Fever Pitch
http://thirdpartyoffers.juno.com/TGL3131/5f09faa73d807aa66ef8st04vuc1
COVID Surge Worries Experts: 'Early Wave of a Lot of Suffering'
http://thirdpartyoffers.juno.com/TGL3131/5f09faa71e7917aa66ef8st04vuc2
Amid Spread of Misinformation, Whispers on FB's Next Move
http://thirdpartyoffers.juno.com/TGL3131/5f09faa73db847aa66ef8st04vuc3
From: | Karel Vranken <karelvranken9(at)gmail.com> |
Subject: | Re: Europa-List Digest: 2 Msgs - 07/11/20 |
Erich,
The 8 MT04's that I have are between 24.30 mm and 24.90 mm.
Karel Vranken, F-PKRL #447 Mono 1024 h.
Op zo 12 jul. 2020 om 08:40 schreef Europa-List Digest Server <
europa-list(at)matronics.com>:
> Online Versions of Today's List Digest Archive
> Today's complete Europa-List Digest can also be found in either of the
> two Web Links listed below. The .html file includes the Digest formatted
> in HTML for viewing with a web browser and features Hyperlinked Indexes
> and Message Navigation. The .txt file includes the plain ASCII version
> of the Europa-List Digest and can be viewed with a generic text editor
> such as Notepad or with a web browser.
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-07-11&Archive=Europa
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-07-11&Archive=Europa
> EMail Version of Today's List Digest Archive
> Europa-List Digest Archive
> Total Messages Posted Sat 07/11/20: 2
> Today's Message Index:
> 1. 07:07 AM - Re: LG frame cracks (Pete)
> 2. 10:48 AM - Europa MT04 engine mounts (Erich Trombley)
> ________________________________ Message 1
> Subject: Re: Europa-List: LG frame cracks
> From: Pete <peterz(at)zutrasoft.com>
> Hi Jim,
> bottom gear
> side-loading
> the entire frame.
> list.
> Cheers,
> Pete
> others become
> wheel.
> After
> LG
> cracks
> behind
> photo
> penetrant
> the
> cracks.
> mechanic)
> machined
> insert
> of the
> suggest
> for
> cracks.
> hours.
> > Jim & Heather
> ________________________________ Message 2
> From: Erich Trombley <erichdtrombley(at)juno.com>
> Subject: Europa-List: Europa MT04 engine mounts
> Hello,
> uninstalled MT04
> obviously
> contacted Lord
> variable
> I
> MT04s.
> second,
> incorrectly
> the
> this
> hoping
> Kind regards,
> Erich
> Sponsored by
The Lord rubber bush as used in the O-200 mount is part no J3608-1, I think
this is the one you mean.
According to Aircraft Spruce the dimensions are
Top dia 1.36", Bottom dia 1.71". Top hole ID .52" bottom hole ID .97".
Height over all .95", and .80 without including flange.
I have got some unused ones in front of me and those measurements seem to
match.
The rubber hose spacer in the middle measures 40mm long x 20mm dia.
That goes over a metal spacer which I don't have to hand, sorry.
Subject: | Propeller covers |
I have an Airmaster three bladed propeller, I have been looking for a set of covers,
with no success.
Does anyone have any ideas?
Regards Alan Twigg.
Subject: | Re: Propeller covers |
Airmaster used to provide a single blade cover which was intended to be placed
over one blade pointing vertically. There was an approx. 4" wide skirt attached
around the bottom of the cover and which spread out across the spinner. There
were also 4 strips of Velcro (2 of each type) attached to the skirt and long
enough to wrap around the spinner. I used this single waterproof cover outdoors
for several years when I didn't have hangarage and it ensured that no water
ever got into the hub.
http://forums.matronics.com/viewtopic.php?p=497266#497266
Dear Europa forum members,
My Europa XS kit didn't come with an intake airbox (912ULS) and I am looking out
there to see if anyone has one they want to sell even if not in perfect shape
(I can always repair).
Right now I am just proceeding with small K&N filters on the carburetors and move
forward. In the future, if I cant find a used one, I can always go ahead and
consider a new one from Europa. But first let me check if there is an orphan
or broken box waiting to be rescued.
Chris
http://forums.matronics.com/viewtopic.php?p=497267#497267
The other thing that would be useful for me is the splash mold for the NACA although
I could always make a mold from foam so that's not too critical.
http://forums.matronics.com/viewtopic.php?p=497268#497268
Free to a good home. Would this interest you? If so, please pm me thanks.
http://forums.matronics.com/viewtopic.php?p=497269#497269
http://forums.matronics.com//files/europa_plenum_airbox_687.jpg
Thank you Jonathan for offering the airbox. I sent you a PM.
And thanks Franks for the offer to mold a scoop from your mold.
This has been a nice point of building an Europa, you need help and there is plenty
of that to be had out there!
My plane is coming along great. Fuselage is painted and I am in the process of
final assembly. I want to start the engine soon so focusing on that first. The
rest of the plane (wings and stabilators) are done but need finishing so I will
probably be busy for a while getting that done. But it's getting closer!
Chris
http://forums.matronics.com/viewtopic.php?p=497270#497270
=EF=BBKarel,
Thank you for providing the dimensions of the MT04 mounts. This is a bi
g help and I very much appreciated it.
Kind regards,
Erich
N28ET Classic Mono 914
Karel wrote: Erich,The 8 MT04's that I have are between 24.30 mm and 24
.90 mm.
Search for Naya Rivera Has Come to an End
http://thirdpartyoffers.juno.com/TGL3131/5f0cdae591e575adb1f58st03vuc1
LA, San Diego Won't Reopen Schools in Fall
http://thirdpartyoffers.juno.com/TGL3131/5f0cdae5b4eff5adb1f58st03vuc2
Passengers Help Subdue Threatening Man on Flight
http://thirdpartyoffers.juno.com/TGL3131/5f0cdae5d54c55adb1f58st03vuc3
Subject: | Classic firewall.... singleton vs steel & cooling. |
Hi folks,
I found on my classic that the composite firewall pretty well closed off the cowl
exit on my classic, with the muffler tucked up right against it.
I now wonder if the rudder pedal tubes and drive arms can be left on the engine
side of the firewall, and simply fabricate a stainless firewall sheet in line
with the upper firewall, leaving the rudder pedals, and all four engine mounts
on the engine side of the firewall.
I wonder how warm the pedals will get in the summer? My classic does have nicely
overlapping and tight stainless rudder pedal passthroughs.
Does anyone out there have a classic with a firewall as i have described?
Cheers and thx,
Pete
Subject: | Re: Classic firewall.... singleton vs steel & cooling. |
I have a set up (the standard set up) much the same as your proposal.
The rudder pedals don't get hot.
Anything in the tunnel behind the steel firewall gets really hot, unless you have
a monowheel with lots of default circulating cooling air. Accordingly, I have
a 'fireblanket' on the back side of the steel, which reduces temperatures in
the tunnel.
Duncan McF.
> On 18 July 2020 at 18:39 Pete wrote:
> Hi folks,
cowl exit on my classic, with the muffler tucked up right against it.
> Cheers and thx,
> Pete
Subject: | Re: Europa-List Digest: classic firewall |
I had bad cooling problems on my 80hp Classic until I removed the second muffler
and replaced it with a straight pipe.
Now, while it makes more noise, I can climb forever at 85kt in the Florida summer:
30C @1000ft on a relatively cool morning.
That chamber of the muffler blocks a lot of air.
Creighton 96EG. A-009
> On Jul 19, 2020, at 02:35, Europa-List Digest Server
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-07-18&Archive=Europa
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-07-18&Archive=Europa
> Total Messages Posted Sat 07/18/20: 2
> 1. 10:41 AM - Classic firewall.... singleton vs steel & cooling. (Pete)
> 2. 11:01 AM - Re: Classic firewall.... singleton vs steel & cooling. (D
McFadyean)
> ________________________________ Message 1 _____________________________________
> Subject: Europa-List: Classic firewall.... singleton vs steel & cooling.
> Hi folks,
cowl
> Cheers and thx,
> Pete
> ________________________________ Message 2 _____________________________________
> From: D McFadyean <ami-mcfadyean(at)talktalk.net>
> Subject: Re: Europa-List: Classic firewall.... singleton vs steel & cooling.
have
> the tunnel.
> Duncan McF.
>> Hi folks,
>> Cheers and thx,
>> Pete
Subject: | Removing a starter on a classic? |
For the classic owners out there,
With my engine out, but the mount frame still on the engine, is it possible t
o remove the starter to give it a service/inspection (while the engine is ou
t)? Or must the engine frame be removed?
Many thanks!
Pete
Subject: | Re: Removing a starter on a classic? |
Hi Pete,
I recall you do to allow enough room for the starter spline to withdraw. Also to
get at the top bolt. Have a go first, nothing ventured nothing gained. I have
had to replace my starter with the Rotax HD starter as I have the Rotax 912
100hp ULS. Starter too small to start engine during Winter. Had to make a slight
alteration to engine frame to accommodate the longer new starter.
Tim Ward
12 Waiwetu Street
Fendalton
CHRISTCHURCH 8052
Hom 03315166
> With my engine out, but the mount frame still on the engine, is it possible to
remove the starter to give it a service/inspection (while the engine is out)?
> Many thanks!
> Pete
Hi i need to do some small paint repairs and wondered if any body has some europa
supplied top coat paint and primer that is no longer required.
Thanks in advance
http://forums.matronics.com/viewtopic.php?p=497400#497400
William,
I always used tri-flow for lubricating hinges and control cables with good results.
In many aircraft the recommendation is not to use lubricants except for silicone
based dry sprays to prevent accumulation of dirt (its an AD in the Mooneys)
but in fiorida you have to use something that protects metal so i found tri-flow
to be a good compromise.
Chris
http://forums.matronics.com/viewtopic.php?p=497411#497411
Subject: | DOTH Fenland EGCL |
Should anyone be interested in a socially distanced DOTH, I am planning
to take my newly resurrected/permitted plane to Fenland today arriving
at around 12MD. Airfield is open, restaurant probably so and UL91
available. Personally plan to take a picnic.
Regards, David Joyce, GXSDJ
Thanks chris
William Daniell
+1 786 878 0246
On Sat, Jul 25, 2020, 20:48 n7188u wrote:
> William,
> results.
> silicone based dry sprays to prevent accumulation of dirt (its an AD in the
> Mooneys) but in fiorida you have to use something that protects metal so i
> found tri-flow to be a good compromise.
> Chris
Hey Gordon.
Just cut the new cables to suit! Thats what I did on my classic with XS FWF (both
throttle and choke) and have had no trouble at all.
Frank X
http://forums.matronics.com/viewtopic.php?p=497431#497431
Hi David,
I am so pleased to hear that you are up and running/flying again. I
trust your trip to Fenland was enjoyable.
Sorry to say I was un available for several reasons but felt it
important to mention that I only received your invitation on Sunday
early evening. Pretty useless for a doth on Friday. You seem to have
sent it on Friday at 09:13 so where it got to in the mean time goodness
only knows.
I hope some others received your message in time to react.
Pete
davidjoyce(at)doctors.org.uk
Sent: 24 July 2020 09:13
Subject: Europa-List: DOTH Fenland EGCL
<http://www.avg.com/email-signature?utm_medium=email&utm_source=link&
utm_campaign=sig-email&utm_content=emailclient>
Virus-free.
utm_campaign=sig-email&utm_content=emailclient> www.avg.com
Hello Europa Folks,
I am completing a lovely part built Europa here in NZ =AD it is great in ever
y
way, but I have my own preferences on the panel.
It currently has a Dynon Flightdek D180 (normal not super bright version)
which I am happy to sell if anyone is interested =AD all working fine and
recently updated to latest software release.
The Europa mounting for the Dynon is also very nicely made with a sub panel
I prefer the round dials and like the idea of this instrument
https://www.aircraftspruce.com/catalog/inpages/uavionix_av-30.php?clickkey=
Has anyone used one of these and what do they think ?
Also, I have been looking around for a nice ASI that works well for the
speed range and like the look of the UMA and Winter items, but have also
spotted this one on the attached picture =AD great panel layout in my eyes.
Does anyone know who sells this ASI in the attached picture ?
Trevor Dance
+64275 896 988
Europa 272
Waiheke Island
New Zealand
Subject: | Re: DOTH Fenland EGCL |
Would agree with Pete. There is a problem here. The posts are stuttering.
Have reported the issue to Matt Dralle. Hopefully he can find a solution.
http://forums.matronics.com/viewtopic.php?p=497459#497459
Can anybody suggest a good supplier of 8 x 6 tyres for Mono?
SSBoYXZlIGEgd2hlZWwgYW5kIHR5cmUgSSBkb27igJl0IG5lZWQgaW4gQW5kb3ZlciBIYW1wc2hp
cmUNCg0KSWFuIENvb2sNCkctQ0JISQ0KDQpTZW50IGZyb20gbXkgaVBob25lDQoNCk9uIDI4IEp1
bCAyMDIwLCBhdCAxNjoxNSwgUmljaGFyZCBTY2FubGFuIDxhc3BlbmJ1aWxkQG1lLmNvbTxtYWls
dG86YXNwZW5idWlsZEBtZS5jb20+PiB3cm90ZToNCg0KQ2FuIGFueWJvZHkgc3VnZ2VzdCBhIGdv
b2Qgc3VwcGxpZXIgb2YgOCB4IDYgdHlyZXMgZm9yIE1vbm8/DQo
Subject: | 914 Fuel Pressure Regulator plumbing question |
Hi Group Does anyone by chance know at 40" MP on a 914 how much more Ram Air is
compared to Airbox pressure? My reason for asking is I think the pneumatic connection
to Fuel Pressure Regulator might want to be plumbed to the output of
enrichment solenoid as compared to the airbox. I think what we really want is
more fuel pressure going into carbs compared to pressure on the float bowls, not
airbox pressure. For most part it's the same except when the enrichment solenoid
is activated. I'm installing a UMA Differential sender at the moment and
they what the pneumatic connection reading carb float bowl pressure, not airbox
pressure. It may be there is so little difference that airbox pressure is adequate,
or not? Ron P.
http://forums.matronics.com/viewtopic.php?p=497469#497469
Subject: | Re: 914 Fuel Pressure Regulator plumbing question |
From: | "Remi Guerner" <air.guerner(at)orange.fr> |
Hi Ron,
Years ago, when I was messing with the 914, I did some calculation about that.
I found that ram air pressure was 1.4 percent over static pressure inside the airbox.
This is a very small pressure increase: .025 PSI. This is enough to enriched
the mixture significantly, but this nothing compared to the differential
fuel pressure which is in the 2 to 6 psi range. Therefore plumbing the Fuel Pressure
regulator to the enrichment valve instead of the airbox static pressure
would not change anything.
Remi
http://forums.matronics.com/viewtopic.php?p=497473#497473
Subject: | Right wing anyone? |
After an "Off Piste" moment in which a runway lamp tore off the support wheel assembly
on a Classic Mono we are faced with a considerable repair on the right
wing.
Does anyone have by chance a right wing lying around that they would like to sell??
Best regards
Barry Tennant
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=497480#497480
Subject: | Re: Right wing anyone? |
I have a whole XS here in the States for sale, but that probably won't work for
you. That said, the Classic with the outrigger wiped out is not that difficult
to rebuild unless the spar has been ripped out also. Even if the wing came
aft and crushed the baggage bay Mod 52 it is not that big of a deal. A bit tedious,
many hours, a little bit of figuring, and internal foam work to reestablish
the structure. Go slow and take your time, make it all square again and
it will fly like new.
Frankly, the task of adapting one wing to another Classic is nearly the same amount
of time as the repair.
Best Regards,
Bud Yerly
http://forums.matronics.com/viewtopic.php?p=497487#497487
From: | "flyingphil2" <philipjtiller(at)gmail.com> |
Hi,
I'm soon going to make a wing holder or cradle to hold the wings upright during
the kit build. Before I do, there isn't anyone with a set that they no longer
need is there?
Phil
http://forums.matronics.com/viewtopic.php?p=497490#497490
Thanks Bud,
I was thinking, like you, that to fit an already built wing would mean making about
as much damage as the repair!
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=497493#497493
From: | "John Kirkgaard" <john.kirkegaard(at)gmail.com> |
Bud and Barry.
Does it mean, that I can't simply buy and install a used wing for my XS
without having to make serious additional works/alterations on the new wing to
make it fit?
Regards John
http://forums.matronics.com/viewtopic.php?p=497497#497497
From: | "JonathanMilbank" <jdmilbank(at)yahoo.co.uk> |
Funny man, John.
Now get back to work fixing your own wing, or do you want me to come and show you
how it's done!
:D Jonathan
http://forums.matronics.com/viewtopic.php?p=497499#497499
From: | Rowland Carson <rowlandcarson(at)gmail.com> |
like to sell??
I can=99t resist - you can have Jacob Rees-Mogg for free!
in friendship
Rowland
| http://www.rowlandcarson.org.uk
From: | "Tenzilla" <CaseyKLandwehri(at)yahoo.com> |
Man will you be surprised if i told you that after 3 years i got the same problem?
The thing is just that i got another email adress, it is dornkol(at)yahoo.com,
and it also tells me that i have 19 messages with some hyperlinks. I do not
really know what that means, didn't you find out? I am really afraid that it might
be due to the fact that i once went on to buy instagram followers, and i
thought this might be the cause to this strange message. Please answer me if you
found out what happened.
http://forums.matronics.com/viewtopic.php?p=497555#497555
Subject: | Floats that sink and floats which can't! |
Recently I posted something on Matronics entitled "Carburettor icing with heated
carbs" and now I must put my hand up and admit that the diagnosis was probably
wrong, although I still find it difficult to let that one go!
Today's weather was about as perfect as it gets in North East Scotland, so three
flights were undertaken by a sharing pilot friend and the first two flights
went without a hitch. But on the third climb-out passing 800' AGL, the engine
misfired briefly which prompted my friend to retard the throttle before cautiously
advancing it while he levelled the aircraft. Thereafter it ran as smoothly
as anyone could wish until he landed.
Having already found one sunken floatafter the previously reportedoccurrence of
brief 1 - 2 second violent shaking due to one bank of cylinders failing momentarily,
I removed both float bowls again and at first all 4 floats seemed to be
buoyant. Then I commenced to press each float down in turn to see whether they
bobbed back up to regain their half-submerged levels in the fuel bowl. It quickly
became apparent that one float could only be depressed slightly with my
finger, as though it was already almost resting on the bottom of the bowl.
Here it comes, now wait for it, wait for it, the smoking gun! The brass sleeve
which lines the vertical holes through older floats, had unstuck and slid down
the pin which guides the float vertically, until more than half of the sleeve
was projecting beneath the float. Of course this constitutes an obstruction to
prevent downward movement of the float when the fuel level is dropping, particularly
during high fuel demand such as during the climb-out after take off.
So when fuel is most needed, the float chamber needle valve can't open enough
to let more fuel into the bowl at a sufficient rate.
Recently I acquired some replacement floats after one of my old ones had sunk and
all of the replacement floats were supplied without brass sleeves lining the
vertical holes. I wonder why (not)! Clearly this phenomenon of insecure brass
sleeves must have become known to Rotax/Bing, or why else have they discontinued
installing them? If anyone else was made aware of this, it certainly passed
me by.
You won't be surprised to know that all 4 floats in my carburettors now are of
the new type without the inserted brass sleeves.
Hopefully this isn't old news to you.
http://forums.matronics.com/viewtopic.php?p=497585#497585
To Rowland - May i suggest sinking your "Right Wing" in Atlantic where it belongs!!
To John - It is possible I am sure, but the connections to the fuselage would all
have to be removed and re-fitted in a suitable position to align the wing with
the other. To get at the connection pins & sockets you would have to break
into the wing to fuselage flare. And repair after.
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=497657#497657
Subject: | Re: Floats that sink and floats which can't! |
From: | "Matt Dovey" <mattdovey(at)hotmail.co.uk> |
If you read the article in your link the brass sleeve are still in the new floats.
They are just shorter for the reasons given.
http://forums.matronics.com/viewtopic.php?p=497671#497671
What is also not so easy to see in the cutaway pictures of floats provided in the
article, is that the brass sleeves in the old style of floats have slight flares
at each end to prevent them sliding out as happened with mine. I still have
the defective float, kept as evidence that the brass sleeve which caused the
fuel starvation problem has no flares at the ends.
http://forums.matronics.com/viewtopic.php?p=497672#497672
Subject: | Airmaster EU/Dirk Oyen: Credit where credit is due. |
Following a steady increase in the rate of grease coming out of my 18 year old
Airmaster prop hub and landing on the windscreen, I contacted Dirk at Airmaster
EU. Within a week, a set of "courtesy blades" had been delivered to me in Britain,
and my blades were in Belgium awaiting some parts and a service, along
with a sensible estimate for the works.
I'm well impressed with that! I went flying yesterday with the loaner-blades fitted,
and my machine felt smoother than it has in a while.
Cheers Dirk!
http://forums.matronics.com/viewtopic.php?p=497783#497783
Subject: | Garmin G3X or G5 Autopilot installation |
From: | "tonyvaccarella" <tony(at)weimagine.com.au> |
Hi all,
Im in the process of installing a pair of Garmin G5 instruments (Attitude Indicator
and DG) and a Garmin Autopilot. Part of the configuration process is to enter
the gains for the Roll and the Pitch servos. This is conducted by doing a
number of test flights and adjusting the gains until the autopilots seems to
behave properly.
Have any Europa builders installed a Garmin Experimental auto? If so, would you
mind sharing your configuration data to overcome the need to conduct a lengthy
calibration process?
Best regards,
Tony Vaccarfella
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=497791#497791
Subject: | 965531 CHT TEMPERATURE SENSOR |
Anyone happen to have one of these 2nd hand?
It mounts on cylinder 3
Ours is reading higher than it should at room temperature.
thanks
http://forums.matronics.com/viewtopic.php?p=497798#497798
Subject: | Re: Rotax 912 Spark plug torque setting |
From: | "Gerald Cruz" <excellentdigitizing(at)yandex.com> |
When a blind man bears the standard pity those who follow. Where ignorance is bliss
tis folly to be wise. https://royalcbd.com/benefits-of-cbd-edibles/ (https://royalcbd.com/benefits-of-cbd-edibles/)
http://forums.matronics.com/viewtopic.php?p=497822#497822
Subject: | Rotax 912 Tach connections (Aviaport) |
Dear forum members,
My tachometer (aviasport I think) has three pins in the back and I have no clue
what kind of connector would attach to something like that. A bare connector
socket from something that size would work but doesn't seem very secure. Another
option, I guess, would be to solder a wire with a regular Faston and heatshrink
but before I do anything that radical I am going to see what answers come
from the group.
Best,
Chris
http://forums.matronics.com/viewtopic.php?p=497834#497834
I found your this post while searching for some related information on blog search...Its
a good post..keep posting and update the information. https://royalcbd.com/cbd-oil-without-thc/
(https://royalcbd.com/cbd-oil-without-thc/)
http://forums.matronics.com/viewtopic.php?p=497843#497843
Subject: | Re: Correction - 966385 CHT TEMPERATURE SENSOR |
I think this is definitely an amazing project here. So much good will be coming
from this project. The ideas and the work behind this will pay off so much. https://royalcbd.com/wisconsin/
(https://royalcbd.com/wisconsin/)
http://forums.matronics.com/viewtopic.php?p=497844#497844
Subject: | Re: Oil pressure/Flydat |
If you don"t mind proceed with this extraordinary work and I anticipate a greater
amount of your magnificent blog entries. https://royalcbd.com/west-virginia/
(https://royalcbd.com/west-virginia/)
http://forums.matronics.com/viewtopic.php?p=497848#497848
Question for the group. Bringing Baby Blue out of retirement and will
be changing the oil. Been using a 10-40 blend and would like to switch
to a full synthetic. Is there any reason to not do this in the 912S?
Thanks in advance.
Jeff
789casino ONLINE, legal gambling website, online football betting good value ready to earn money from Get property link Baccarat online 789 casino online service excellent deposit and withdrawal system. That you must be impressed Stable system guarantees the safety of your credit. With various promotions that we have for you to choose from Support team to take care of you to make our games comfortable. (https://www.789betting.com/)
http://forums.matronics.com/viewtopic.php?p=497865#497865
Subject: | Re: Oil peference |
Jeff,
We have been using AeroShell Sport Plus 4 for many years. We like that Rotax endorses
it and that the formula can't be changed without Rotax approval.
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=497877#497877
Sport 4 also has sufficient ZZDP (anti scuff agent) in it; many automotive (including
motorcycle stuff) equivalents don't, because those would contaminate exhaust
catalysts.
Duncan McF.
> On 20 August 2020 at 16:17 "h&jeuropa" wrote:
> Jeff,
endorses it and that the formula can't be changed without Rotax approval.
> Jim & Heather
Jeff,
I forgot to mention, I purchase it from
https://oil-store.com/product/aeroshell-sport-plus-4-case-12-1-liter/
They seem to have the best price.
Jim
http://forums.matronics.com/viewtopic.php?p=497880#497880
Hi Jeff Full synthetic is not recommended if you use 100LL a lot. Semi synthetic AeroShell Sport Plus 4 is a good choice: https://www.shell.com/business-customers/aviation/aeroshell/piston-engine-oil/sports-plus4.html Ron P.
http://forums.matronics.com/viewtopic.php?p=497881#497881
Thanks all for the recommendations.
Jeff
"I believe that forgiving them is God's function. Our job is to arrange
the meeting."
-Gen. Norman Schwarzkopf
Hello everyone,
I'm a new Europa XS owner and even though my aircraft was built to a very high
level of quality, Ive found a problem on the first flight which could some day
mean the difference between life and death!
The Stall Warner doesnt go off when the aircraft is stalled in any configuration
i.e. power on or power off.
Before the flight, while doing a walk-around I tested the 'Stall Warner' by sucking
on it and it worked by sounding a very audible noise in the cockpit.
Can anyone advise why it isnt sounding in flight when an actual stall takes place?
Is there any configuration of the system necessary to set it up correctly?
If there is, does anyone know how it should be carried out?
Thank you in anticipation
James from
Ireland
Subject: | Re: Stall Warner |
There will be a sensor in the cockpit somewhere with a tube leading from the hole
in the leading edge of the wing.
There is wiring from the sensor to the warning horn. The sensor is calibrated while
in flight best to extend tube and wiring so you can get your passenger to
calibrate it at set speed above stall.
Dave
Dave Park
> On 21 Aug 2020, at 01:02, James McErlain wrote:
> Hello everyone,
> James from
> Ireland
Subject: | Rotax rubber motor mounts |
Hi Group I was going through Rotax 914 parts manual and see they offer motor mount
rubber, spacers and washers. Curious has anyone tried them? How did they work
out? Thx. Ron P.
http://forums.matronics.com/viewtopic.php?p=497891#497891
Hi James Go onto Europa Aircraft website and download Modification 61. You will
need to set up an account that's free. Make sure plumbing has no leaks or restrictions
and follow set up procedure. If it were I and couldn't find anything
amiss, try a new pressure switch. Ron P.
http://forums.matronics.com/viewtopic.php?p=497892#497892
Smartass better than a stall Warner in my opinion. I have no connection to t
he company.
https://smartavionics.co.uk/prod-smartass.html
Kevin Challis
G ODJG
> On 21 Aug 2020, at 01:01, James McErlain wrote:
ie>
> Hello everyone,
igh level of quality, I=99ve found a problem on the first flight which
could some day mean the difference between life and death!
> The =98Stall Warner=99 doesn=99t go off when the aircraf
t is stalled in any configuration i.e. power on or power off.
y sucking on it and it worked by sounding a very audible noise in the cockpi
t.
> Can anyone advise why it isn=99t sounding in flight when an actual s
tall takes place? Is there any configuration of the system necessary to set i
t up correctly? If there is, does anyone know how it should be carried out?
> James from
> Ireland
From: | "Pete Jeffers" <pjeffers(at)talktalk.net> |
Hi James,
Sorry to hear you are having stall warner problems. It sounds as though, as per
another reply you have received, that adjustment as per Mod 61 instructions
is likely to be your best solution.
On the assumption that the original owner had this correctly set up then you are
probably looking for leaks in the plumbing system. One source of leaks can be
missing or damaged (perished) 'o' ring seal in the quick connect coupling between
wing an fuselage. This source of leaks can also occur on any of the pitot
and static connections although this is nothing to do with the stall warner
system.
One way or other this fault should not be too difficult to fix.
PS if you have to adjust the pressure switch itself you will find that it is very
sensitive and easy to over adjust. Take care.
Pete Jeffers (LAA rep for The Europa Club)
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of James McErlain
Sent: 21 August 2020 00:55
Subject: Europa-List: Stall Warner
Hello everyone,
James from
Ireland
This email has been checked for viruses by AVG.
https://www.avg.com
From: | "clivesutton" <clive.maf(at)googlemail.com> |
Hello James, welcome to the Europa community!
I've not much to add to the replies you've had so far except to to echo Peter J's
remark about how tricky it can be to set the switch sensitivity. The point
between not working and working is very fine and can only really be done in flight.
I had the same issue on mine at its initial permit testing and after changing
the switch (which didn't help really) i found a way to extend the pipework
and wiring so that the switch could be easily set from the P2 position [i
put the switch behind the parcel tray moulding and drilled a hole through it
to enable a watchmakers screwdriver to go into the switch]. Andy D then flew
the aircraft close to 5kt above the stall whilst i adjusted the switch until it
sounded. It took a few attempts.
In case its useful, and whilst it does not compete with this bulletin board, there
is also a Facebook page for Europa owners you might also find useful
ATB
Clive Sutton
G-YETI
http://forums.matronics.com/viewtopic.php?p=497895#497895
From: | DAVID JOYCE <stranfaer(at)btinternet.com> |
Smart ass is an excellent piece of kit, personally I use the
aforementioned and stall strips, works very well
David JoyceThe other one BXGG
------ Original Message ------
Sent: Friday, 21 Aug, 20 At 07:11
Subject: Re: Europa-List: Stall Warner
to the company.
Kevin Challis
G ODJG
e>
Hello everyone,
very high level of quality, I=99ve found a problem on the first fligh
t
which could some day mean the difference between life and death!
The =98Stall Warner=99 doesn=99t go off when the aircraft
is stalled in any
by sucking on it and it worked by sounding a very audible noise in the
cockpit.
Can anyone advise why it isn=99t sounding in flight when an actual st
all
it up correctly? If there is, does anyone know how it should be carried
out?
James from
Ireland
Sent to you by David Joyce
Hot Tubs, Swimming Pools & Saunas for discerning owners................
www.eastmidsspas.com <http://www.eastmidsspas.com/>
The Zycomm Building 51 Nottingham Road Ripley Derbys DE5 3AS
250 Meters from Sainsbury's Island
0800 4102122 and Direct Mobile 07973 675755
Subject: | Ignition issue and headset crackle |
Bud has provided wisdom but I wondered if anyone else has suffered the same
symptoms and might have a cure.
I have a turbo 80hp.
So it started with a crackle in the deadset that rose and fell with engine
power. This occurred in mid flight after a normal mag check. Prior to
this the Dynon Skyview had been without abnormal noise.
On landing I found that the switching off the left mag silenced the crackle
and switching off the right mag made the engine run rough.
The CDIs have two "in" connectors from the pick ups and two "out"
connectors to the coils. So I swapped the "in" connectors between CDI and
the "out" connectors. Also I tried to start the engine with only one CDI
connected to one out connector. Both CDI work with both in-connectors but
both only work with one "out" connector to the coils. When the CDI is
connected to the "wrong" coil the engine wont start. This leads me to the
conclusion that I have a problem between the CDI and the plugs. In other
words I have a problem in the coil system or in the HT/plug area.
Agreed?
If so, what is my next step? How do I test the coils?
Will
William Daniell
LONGPORT
+1 786 878 0246
Subject: | Re: Europa Aircraft - location change |
From: | "ArmstrongJackson" <zeeshantapra(at)yahoo.com> |
I did not have any tie restraint so this is the reason I asked some movers from
the washington dc movers (https://bestmoversdmv.com/) to take my furniture. I
chose their normal package so that they dont have to expedite it.
http://forums.matronics.com/viewtopic.php?p=497909#497909
Subject: | Mono to TriGear Trailer Conversions |
If anyone has converted their Factory Mono trailer to accommodate a TriGear, please
could they point me at, or send me, some pictures of it?
Clive S
http://forums.matronics.com/viewtopic.php?p=497910#497910
Subject: | The culprit headset crackle |
This is the coil end of lower cyl 3 plug lead
William Daniell
+1 786 878 0246
Subject: | Headset crackle culprit for interest |
So this is the coil after id massacred it to see what happened. I found a
loose plug lead (coil end) and dug the screw out of the lead.
How long this had been like that i dont know....but it might have been like
that for some time held in by the lead in the coil socket and the heat
shield.
William Daniell
+1 786 878 0246
Subject: | Coil end of the ht lead |
William Daniell
+1 786 878 0246
From: | =?utf-8?Q?Gert_Dalgaard_S=C3=B8rensen?= <stabelvej9(at)gmail.com> |
Subject: | New Europa ... ?? |
Hi All
Anyone who know where I can get a new =9CEuropa" ?
This one, I got from Iwan 20 years ago, and together we have flown a lot
of hours all over Europa.
Now it either need overhaul or - even better - replacement =F0=9F=98=8E
Gert Dalgaard
OY-GDS, 914, Woodcomp
I have a largish quantity of 6.5cm thick memory foam , actually 2 lots
of 150 x90 cm., which I am happy to give to anyone who cares to collect
it. Having a layer of memory foam under and behind you is an effective
way of lessening the damage to you in the case of a hard or crash
landing. This comes from a NASA designed mattress just replaced by an
even more expensive mattress at the instigation of she who sleeps on the
other side of it! My cushions were made from 2.5 cm sheets of memory
foam, which then came in three colours corresponding to three degrees of
softness. This mattress foam I think corresponds to somewhere between
the medium and softest versions, and would make good extra cushions to
be available for small passengers
Regards, David Joyce.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Subject: | Faston Size for Ignition connectors |
Does anyone know the size of the faston male and female tabs for the faston
ignition system connectors?
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
Subject: | Ignition module earth |
I am replacing my earth leads to the modules and need some termination pins with
the rubber seal that push into the module plugs.
Does anyone know a supplier?
Dave Park G -LDVO
I am replacing the earth leads to my ignition modules and need the terminating
pins with the rubber seal. Does anyone know the spec and supplier?
Dave Park. G -LDVO
Subject: | Re: Ignition module earth |
https://www.corsa-technic.com/item.php?item_id=625
Duncan McF.
> Regards
> Dave Park G -LDVO
From: | Roger Sheridan <rogersheridan(at)mac.com> |
Hi Dave,
I think you want to search for
Female Terminal 1500-0106 Sumitomo.
However, caveat emptor.
Hi Dave,
I don't know where you can get just pins and seals, but the complete
plugs are available here:
https://www.carmo.nl/index.php?main_page=index&cPath=4318_1083_4776&zenid=ing6l3308dln6q5fqcnvhrrlt4
> Regards
> Dave Park G -LDVO
Hi Dave,
The pins and seals are available here (they look to be the same
connectors but I haven't bought any so can not guarantee it):
https://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SM-HM/sm-hm.html
Good luck,
Keith.
> Regards
> Dave Park G -LDVO
Subject: | Re: Airmaster EU/Dirk Oyen: Credit where credit is due. |
I'd like to echo the positive review! Dirk Oyen is THE Airmaster-man in Europe.
That's why I only let him service my propeller...
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=498131#498131
I have had to repair my airbox as it split under the clamp.
Can anyone tell me how critical the airflow into the carburettors via the box is?
Do I need to ensure a smooth and equal airflow?
I suspect not as the quality of the airbox is somewhat rudimentary.
For information I made up some bid' tube and epoxied it into the existing airflow
tube. I have tried to make the entrance a smooth as possible.
Thank you.
Steve Pitt
G-SMDH
Subject: | Re: Airbox for 912S |
Steve, you should be fine as long as the internal diameter of the tube
is equal to or greater than the internal diameter of the carb opening.
Jeff
the meeting."
is? Do I need to ensure a smooth and equal airflow?
> Thank you.
> Steve Pitt
> G-SMDH
When I had a airbox on initial build I bonded alloy tupe in to exits to strengthen
them.
Dave Park
> On 3 Sep 2020, at 15:37, Jeff B wrote:
> Steve, you should be fine as long as the internal diameter of the tube is equal
> Jeff
> "I believe that forgiving them is God's function. Our job is to arrange the meeting."
>> Thank you.
>> Steve Pitt
>> G-SMDH
Steve,
The air entry to the carbs is quite critical and should ideally be smooth and tapering
inwards from a larger diameter, which the Europa airbox more or less achieves.
Generally a 2 degree inward taper will help to preserve lamina flow in
the runner, as is often seen on the runners of injected engines.
This is further evidenced by the adverse impact on carburation that sharply curved
SCAT tube and/or long parallel-sided runners has, such as on some Jabiru and
VW installations.
Duncan McF.
> Jeff
> the meeting."
> > Thank you.
> > Steve Pitt
> > G-SMDH
Subject: | Nose Wheel Shimmy |
When landing on a hard runway I always get nose wheel shimmy. I've checked the
friction on the on the nose wheel fork and found no problem. Has anyone else had
similar problems?
http://forums.matronics.com/viewtopic.php?p=498144#498144
Subject: | Re: Nose Wheel Shimmy |
I have never experienced any problems and have the friction set as per the book.
I do have a nose wheel spat, standard speed kit, and also hold the nose off the
runway until the authority of the tailplane is lost.
Alan
G-OBJT
had similar problems?
A little swipe of Nyogel 774VH on both sides of the fiber washer then
torqued to spec will solve the problem.
Jeff
the meeting."
From: | Paul Hawkins <1963paulhawkins(at)gmail.com> |
To kill shimmy 100% of the time full rudder preferably into wind but either
way the will break the nose-wheel swinging from side to side, in the past
I=99ve tried everything replacing parts raising the nosewheel and gen
tly let
down / slamming it down the only thing that works is catching it early with
full rudder the shimmy will stops immediately straighten up and continue
down the runway.
The key to not getting shimmy in the first place *never ever* pull the
power off just over the runway on short final, you=99ve got the speed
right
leave the power where it is until you land then kill the power or glide
onto the runway from height.
Cheers Paul
G-ROOV 914 XS
> Jeff
> the meeting."
k
> checked the friction on the on the nose wheel fork and found no problem.
> Has anyone else had similar problems?
Subject: | Re: Propeller? Gearbox? "Wow-wow-wow" resonance |
Can also be a worn propshaft bearing(s), where the shaft is rotating in the bearing
(as normal) and simultaneously orbiting around the centre of that rotation
(allowed by radial play).
Duncan McF.
> On 19 June 2020 at 14:58 clivesutton wrote:
> Hi Jonathan, what you describe is 'Heterodyning' or 'Beat-frequency' created
by the difference between two noise or vibration frequencies very close together.
> Do you have a recording on e.g. a mobile phone that i could listen to - along
with the engine speeds in play at the time? And what about:-
> 1) How the frequency of 'wow-wow' change if you speed up or slow down the engine
a bit?
> 2) How does the 'wow-wow' effect change with Airspeed?
> 3) the CS mode idea is viable too - does it occur when that is turned off/the
prop is not trying to hunt for optimum speed vs pitch?
> It's impossible to say from just the description given, but assuming the above
items make a significant difference, my initial suspicions would be one prop
blade with a slightly different prop pitch to the others and/or blade tip tracking
differences between blades. Both of those parameters should be quite easy
to check on the ground (no engine running needed) and reporting any variation
you find?
> Clive
> http://forums.matronics.com/viewtopic.php?p=496930#496930
Now I have a dilemma. I have measured the diameter of the inner carburettor at
45mm. The airbox outer tube is 48/49mm - the inner diameter 39 and 42mm (these
measurements after my fix - several layers of bid to strengthen the orifices
after they collapsed under the tightness of the worm driven band).
I have never had a problem with the carburettors and never given any thought to
a mismatch between the two diameters. I was always aware the the box was poorly
finished and the air intakes were easy to crush, but with the bolt holding
the box to the engine frame it had never departed giving me an inflight issue.
It is also notable that the two orifices were not the same size even before the
collapse.
The only way I can see to equalise the two is to rebuild the airbox as per Dave
Ps suggestion - cut the ends off - find an aluminium tube with inside diameter
of 45mm and bond that in with bid. Anyone got any tube to that size?
Anyone else wishing to add any advice before I carve the boxes up. Also what is
the airbox made from? It looks like chopped strand mat fibreglass.
Steve
G-SMDH
them.
> Dave Park
>> Jeff
meeting."
>>> Thank you.
>>> Steve Pitt
>>> G-SMDH
Subject: | MGL EFIS and autopilot |
I have a Trigear classic with 914 and Arplast prop. I am considering installing
an MGL Challenger EFIS and possibly autopilot servos.
Has anyone out there installed a similar set up? If so, any tips, tricks or pitfalls
to be aware of?
I look forward to hearing from someone.
Cheers
Max Earnshaw
ZK-VMC
Christchurch, New Zealand
http://forums.matronics.com/viewtopic.php?p=498154#498154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Subject: | Re: MGL EFIS and autopilot |
I had the MGL Vogager EFIS and used the Trio Servos. I could not get them to
work correctly. MGL Torrance sold them to me, but they told me that Trio was
the problem and Trio told me that the problem was with MGL.
Before you buy an autopilot system for the Europa you need to determine if your
plane flies straight & level. How much force is needed to bring the nose up
or down once it leaves altitude. For whatever reason by plane took more force
to bring it back to lever than the Trio servo could deliver and would trip and
shut down after a few minutes of trying. If you go back into this Forum you
find a lot of question on how to get them set up. The roll axles worked and
it was easy to install in the co-pilot seat area. The big problem is the pitch
servo and how it connects to the pitch torque tube. I have to manufacture
a clamp with a horn on it. Europa now makes a pitch tube with the horn welded
to it.
I know that the MGL servos worked very well with the later model of the MGL EFIS
. You might check out their forum.
http://forums.matronics.com/viewtopic.php?p=498157#498157
to bring it back to level than the Trio servo could deliver and would trip and
servo and how it connects to the pitch torque tube. I had to manufacture a
to it.
I know that the MGL servos worked very well with the later models of the MGL EFIS
http://forums.matronics.com/viewtopic.php?p=498158#498158
From: | "budyerly(at)msn.com" <budyerly(at)msn.com> |
Steve,
The bing 64 has a 50mm OD inlet for the filter or airbox attachment. The bore
is nominally 36mm.
The airbox (aka really cheap polyester chop and glass bit from Europa) have ends
that attach to the carb are 50 mm tapering up 52 mm ish. The chop on some of
these is so bad I had to reinforce it for the pop rivets on the nutplate it
shattered so bad.
Jeff Roberts was the first I had seen modify his airbox due to cracking. It appeared
he used a piece of two inch aluminum tubing and slid it into the well ground
out holes in his airbox and aligned the tubes with his carbs and allowed
the floxed tubes to cure, then wrapped the glass around the tube outside the
rubber tube to final bond the outside of his tubing.
I copied Jeffs later on using the 1 7/8 inch aluminum tube left over from the main
pitch rod. I ground out the cracked airbox and inserted the 1 7/8 (47.6 mm)
tube with flox and Redux (any epoxy will do) and then wrapped layers of bid
around until I was about 50 mm or 1 15/16 inches diameter. Then shaped to get
an easy fit of my two inch rubber hose. I was OK with this method since the
connecting hose allowed the two inlets on the bing carb inlet sufficient clean
air for normal operation. On a later aircraft I used 2 inch tube. The hose
clamp clearly compressed the hose more on the carb side than on the inlet box
with the two inch tube.
Epoxy sticks to just about anything but oil and grease so it will make a good repair
bond to the clean and roughed up polyester without a problem of bonding.
Remember to rough up the aluminum as usual also.
So you have two methods, either an innie or outie method.
Note: The airbox does not have to be really smooth on the inside. It is a plenum
not a tuned inlet. The bing carb sucks air rather than ram air entering the
carb on the 912S. The transition humps and bumps should be minimized but just
make both ends about the same and all will be fine. Remember, the bing has
an inlet on the inside above and below the bore so make sure they can get reasonably
clear air...
Of course Rotax wants you to buy their $1000 intake plenum. The only problem is
it tends to lack support and since it hangs on the carb, it cracks those expensive
43mm rubber carb manifold to carb flange. Support the inlet plenum, that
supports the carb and those rubber carb flange adapters last almost forever.
Just my opinion,
Best Regards to Mary also,
Bud Yerly
Best Regards,
Bud Yerly
http://forums.matronics.com/viewtopic.php?p=498159#498159
Replace the plastic disk if it shows signs of wear. Inspect your fork properly.
The nose tire pressure has much to do with the shimmy. If below 20 pounds it is
terrible. 35 pounds and it is a delight.
I set my dampener friction between 19 and 21 pounds of pull at the back of the
tire. Use a loop of safety wire around the nut long enough to go around the back
of the tire (wheel pant off please) and use a fish scale to do the pull test.
Typically the break out force is higher than the running or turning force
required to maintain the nose fork turn. If it breaks initially at 21 it is
fine for asphalt surfaces and for use on grass go a bit lower. 16 pounds is a
bit too low for initial break out in my opinion.
Various sticky greases Nylogel or similar help for dynamic steering and taxi ease
with the rudder. I find them useful but not necessary with a nice slick plastic
disk and smooth surfaces on the metal plates.
If the metal surface is worn with groves, fix it. If the spindle is loose, get
a new fork or find someone to fix it dead vertical.
Finally, never inject grease under pressure to lube the nose fork. Grease blows
by the O ring and screws up the friction and makes a mess. On my annual condition
inspection, I simply remove my fork and tire, inspect the components, check
for tightness and lube with a finger full of thick grease (Aeroshell 22)
on the recess in the strut receptacle, and bearing area and I'm good for another
year. It's been 14 years and still doing well enough.
Bud Yerly
http://forums.matronics.com/viewtopic.php?p=498160#498160
I've attached an old paper to a current document I have for working on second hand
purchases and stall spin accidents in experimental aircraft.
It is from notes and early papers I kept at Custom Flight Creations.
It should at least lead you to making an informed decision.
Bud Yerly
http://forums.matronics.com/viewtopic.php?p=498162#498162
http://forums.matronics.com//files/stall_warning_types_for_the_europa_with_evaluation_of_stall_strips_130.pdf
I have a DynAero MCR-4S based in Auckland NZ that has two Voyagers originally fitted
with Trio servos which worked very well. I replaced the Trios with MGL
servos because I am going from a 2 to 3 axis auto pilot and can use the same
CAN bus to control all 3.
Currently flying 2 axis, it took a little more tweaking to get the MGL's servos
tuned and used the MGL forum to get help from an European colleague operating
a MCR-4S (sad to see the old MGL forum disappear).
PM me if you require further information.
Cheers Peter
Peter Armstrong
Auckland, New Zealand
DynAero MCR-4S (Do not shoot me :) ).
http://forums.matronics.com/viewtopic.php?p=498163#498163
From: | =?UTF-8?Q?Erik_Dahlb=c3=a4ck?= <erik(at)erikdahlbeck.com> |
Subject: | Rear wing root socket problems |
Hello,
First time posting here, hoping my attached photos are small enough, etc...
I'm trying to get Europa SE-XRX airworthy again after being grounded for
two years. At first due to some hard-to-diagnose carburettor problems.
914 float bowls, enough said... If interested, I have a post about it
over at Rotax-Owners:
https://www.rotax-owner.com/en/912-914-technical-questions/6881-914ul-carburettor-gremlins?start=15
PROBLEM NO 1
Anyway, after fixing the engine and while doing the annual together with
the previous owner/builder, it was discovered that the rear wing socket
housing, part W26B, starboard side, was cracked in two parts. Further
inspection showed that also the port side was cracked, albeit not having
split in two just yet. Please see attached photos.
I've got the spares from the manufacturer however, I'm curious if this
is a known problem? Any thoughts on what could be the cause? Anything
further to look out for?
My local mechanic seemed just as puzzled as I was when looking at how
thin this part is. I mean what is it, 2 mm?
One thing to consider: The aircraft was built as a monowheel but crashed
on takeoff during flight testing, making a hard landing and a ground
loop. The incident was traced to a construction error in the control
line attachment to the rudder, causing alterations in the design (some
of might be familiar with this). The aircraft was then repaired (by some
sailplane workshop that seemed to know what they were doing, I've seen
the photos at least). Among other things it got a new tail, a CS prop
and was rebuilt as a trigear. Might this new discovery simply be residue
of that old incident?
Also, the builder's manual states that the W26B and C parts should be
loctited together. However, there was no trace of this. I'm not sure if
that instruction has been there since the beginning or if it could be a
later revision? However, I sort of have my doubts as to some loctite
being able to strenghten this construction enough to not break from
whatever broke this...?
Finally, any thoughts on how to reassemble these parts? Where does the
Loctite go? Just on the barrel and make sure the holes align before i
dries? How to you avoid getting loctite on the surfaces between the
barrel and the socket body (W26A)?
PROBLEM NO 2
Due to various reasons, I only got around to cleaning the grease off the
rear socket assemblies, in preparation for reassembly, but doing the
loctite-work in a cold hangar, etc, and also enlisting the help of the
very busy local mechanic, was more than I could get done before last winter.
Now, on inspection, the W26A socket bodies show signs of corrosion.
Please see the other attached photos. Anyone have an opinion on just how
bad this is? Do they also need changing? And does that require
composite-work? I've been looking through the builder's manual but I'm
afraid I'm not quite up to understanding all of it.
Any thoughts on both of the above issues would be greatly appreciated!
Sincerely,
Erik Gunneland Dahlbck
Linkping, Sweden
Europa SE-XRX
From: | "SwiftTG" <david.stanbridge(at)swifttg.com> |
I just wanted to comment on a note in Buds reply regarding the "really cheap polyester
chop and glass bit from Europa". I do not know what part is being referred
to but nothing is now supplied from Europa in chop strand. As a relevant
example the Mod 42 airbox is manufactured from 92125 cloth.
David Stanbridge
Europa Aircraft (2004) Limited
www.europa-aircraft.com
technical@europa-aircraft.com
http://forums.matronics.com/viewtopic.php?p=498165#498165
David,
And we thank you for the quality parts now manufactured.
There was a time in the early 2000s that even the gelcoat was flaking and c
racking terribly on all the accessory parts like speed kits and cowls.
Thanks again,
Bud Yerly
Sent from Mail for Window
s 10
From: SwiftTG<mailto:david.stanbridge(at)swifttg.com>
Sent: Monday, September 7, 2020 7:32 AM
Subject: Europa-List: Re: Airbox for 912S
p polyester chop and glass bit from Europa". I do not know what part is bei
ng referred to but nothing is now supplied from Europa in chop strand. As a
relevant example the Mod 42 airbox is manufactured from 92125 cloth.
David Stanbridge
www.europa-aircraft.com<http://www.europa-aircraft.com>
Sorry to hear of your issues.
The failure of the socket indicates the crash may have been more severe tha
n anticipated.
In all my years, I=92ve seen corrosion on older socket parts that were not
as well protected as the new bits are. I have never seen a failure in the
26A as this was a well engineered and tested part by Europa. If installed
backwards, this can happen.
Please contact Europa Aircraft because the W26 part assembly has not been a
n issue and replacement of the corroded items may be smart. This area is a
critical flight component and the annual inspection and repair may have mi
ssed this part may have been damaged or assembled incorrectly. If the sock
et inner W26B failed, was the interior tube and attachments properly instal
led, checked and inspected is the question.
Loctite is between the barrel and that thin rectangular piece you call it s
o they operate as a unit. The wing pin goes into the fully assembled socke
t and allows it to move up and down just a bit. If not Loctited the barrel
can rotate and make pin insertion more difficult. (Frankly, during wing i
nstall, simply note the orientation of the barrel is all that is needed.) N
ote that the assembly thin side goes on the fuselage side. Don=92t get tha
t backwards as it builds up stress and may be a part of the failure you see
As far as the structural strength, the yoke piece 26A and the barrel 26C ca
rry the load of the wing pulling forward under max G load. This barrel is
designed to move up and down.
As for the Rotax 914:
There is a long and boring troubleshooting guide on my website on keeping t
he 914 running true. The carbs are easily rebuilt with proper attention to
detail. I find the Rotax engine forum informational, but doesn=92t cover
in enough detail. I do find the videos provided by Rotax to be quite compl
ete. The paper I did covers various phases and expands troubleshooting. S
ee the techniques section for an updated version since published in the Eur
opa Club magazine.
Bud Yerly
www.customflightcreations.com
s 10
From: Erik Dahlb=E4ck<mailto:erik(at)erikdahlbeck.com>
Sent: Sunday, September 6, 2020 5:18 PM
Subject: Europa-List: Rear wing root socket problems
Hello,
https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.rot
ax-owner.com%2Fen%2F912-914-technical-questions%2F6881-914ul-carburettor-gr
emlins%3Fstart%3D15&data=02%7C01%7C%7C8482b0ef213641821e7208d852aa5b7
2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637350238926500351&sdata
=pMvGV5%2BI41Zjnn3nQnSV8Wo37dGxDwnn9%2Ff%2Bu5P7T%2F0%3D&reserved=0
PROBLEM NO 1
PROBLEM NO 2
Sincerely,
Erik Gunneland Dahlb=E4ck
Link=F6ping, Sweden
Europa SE-XRX
From: | Richard Churchill-Coleman <richard.churchill-coleman(at)sky.com> |
Bud
Not just the accessories - I have a fuselage top with flaking =98gelco
at=99 which I am still trying to resolve.
Richard C-C
> On 7 Sep 2020, at 13:30, Bud Yerly wrote:
> =EF=BB
> David,
> Thanks again,
> Bud Yerly
> Sent from Mail for Windows 10
> From: SwiftTG
> To: europa-list(at)matronics.com
ap polyester chop and glass bit from Europa". I do not know what part is bei
ng referred to but nothing is now supplied from Europa in chop strand. As a r
> David Stanbridge
> st Email Forum -
> pa-List">http://www.matronics.com/Navigator?Europa-List
> p; - MATRONICS WEB FORUMS -
> ums.matronics.com
> p; - NEW MATRONICS LIST WIKI -
> matronics.com
> p; - List Contribution Web Site -
> p; -Matt Dralle, List Admin.
> http://www.matronics.com/contribution
Subject: | 914 Float Bowl Issues |
Hello Erik,
I just read your post on the Rotax-Owners site. The issue you described has
long plagued many 914 owners. Jim Butcher and I recently published an
article in the Europa Flyer addressing this issue (and others) as well as a
fix. If you aren't a member you might consider joining. Good information
specific to the Europa is disseminated. As a result of the COVID-19 the
Europa Club held its annual membership meeting virtually. I must say, using
ZOOM opened up the audience internationally with many USA builders able to
join, myself included.
Anyway, specific to the loose float bowl, I modified the float bowl to
accept the 912 spring clamp which provides the requisite pressure on the
gasket as it ages and shrinks. The bolt is still utilized, however, the
clamping pressure is provided by the spring clip. Pretty straight forward
modification requiring that the cast nub on the bottom of the float bowl,
adjacent to the bolt hole, be removed. This allows the spring clip to fully
seat. I used a Dremel, although, a file will do the trick.
Let me know if you have any questions.
Kind regards,
Erich
N28ET Classic Mono 914
Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more
Gender Reveal Party Has Now Burned Through 7K Acres
http://thirdpartyoffers.juno.com/TGL3131/5f56497cc9dbc497b6e0fst03duc1
Booted Djokovic Sorry for Hitting Line Judge With Ball
http://thirdpartyoffers.juno.com/TGL3131/5f56497ced459497b6e0fst03duc2
US Sailor Goes Missing From Aircraft Carrier
http://thirdpartyoffers.juno.com/TGL3131/5f56497d1ab6c497b6e0fst03duc3
From: | D McFadyean <ami-mcfadyean(at)talktalk.net> |
The (substantial) wear marks on W26A show that is was installed the correc
t way around.
The wear mark on the inside vertical surface of W26 just above the central
bolt indicate that at some point W26A was leaning heavily on W26 in a 'nega
tive g' direction of loading, which may explain how it then broke i.e. the
weight of the wing transmitted in bending through the lift pin caused W26A
to lever against W26.
That wouldn't occur during a normal flight maneuver and when properly rigge
d. Perhaps the downward leverage occurred during derigging after removing t
he spar pins, and assuming the spar cups were misplaced.
I'd check the lift pins for bending too and that these are not angled (or b
ent) above the centreline of the inboard spar projections (and/or that W26
has been set vertically).
Duncan Mcf.
re than anticipated.
> In all my years, I=99ve seen corrosion on older socket parts th
at were not as well protected as the new bits are. I have never seen a fai
lure in the 26A as this was a well engineered and tested part by Europa. I
f installed backwards, this can happen.
been an issue and replacement of the corroded items may be smart. This are
a is a critical flight component and the annual inspection and repair may h
ave missed this part may have been damaged or assembled incorrectly. If th
e socket inner W26B failed, was the interior tube and attachments properly
installed, checked and inspected is the question.
l it so they operate as a unit. The wing pin goes into the fully assembled
socket and allows it to move up and down just a bit. If not Loctited the
barrel can rotate and make pin insertion more difficult. (Frankly, during
wing install, simply note the orientation of the barrel is all that is need
ed.) Note that the assembly thin side goes on the fuselage side. Don
=99t get that backwards as it builds up stress and may be a part of the fai
lure you see.
26C carry the load of the wing pulling forward under max G load. This barr
el is designed to move up and down.
ping the 914 running true. The carbs are easily rebuilt with proper attent
ion to detail. I find the Rotax engine forum informational, but doesn
=99t cover in enough detail. I do find the videos provided by Rotax to
be quite complete. The paper I did covers various phases and expands troub
leshooting. See the techniques section for an updated version since publis
hed in the Europa Club magazine.
> Bud Yerly
> Sent from Mail https://go.microsoft.com/fwlink/?LinkId=550986 for W
indows 10
> From: Erik Dahlb=C3=A4ck mailto:erik(at)erikdahlbeck.com
> To: europa-list(at)matronics.com mailto:europa-list(at)matronics.com
> Hello,
etc...
for
ww.rotax-owner.com%2Fen%2F912-914-technical-questions%2F6881-914ul-carburet
tor-gremlins%3Fstart%3D15&data=02%7C01%7C%7C8482b0ef213641821e7208d85
2aa5b72%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637350238926500351&
;sdata=pMvGV5%2BI41Zjnn3nQnSV8Wo37dGxDwnn9%2Ff%2Bu5P7T%2F0%3D&reserve
d=0
> PROBLEM NO 1
ith
et
ing
s
hed
e
ome
n
due
if
a
e
> PROBLEM NO 2
the
e
winter.
how
m
> Sincerely,
> Erik Gunneland Dahlb=C3=A4ck
> Link=C3=B6ping, Sweden
> Europa SE-XRX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Anyone up for a DOTH in the southern half (England/Wales) of the UK this week?
Wednesday or Thursday, venue TBA but many places now open. Early mist/fog could
be an issue in some areas (Severn Valley for example) by then.
Duncan McF.
From: | William Daniell <wdaniell.longport(at)gmail.com> |
Subject: | Re: 914 Float Bowl Issues |
I have a turbo 912 with the stock spring clips on the float bowl. The key
is to use nitrile or cork float bowl gaskets.
Will
William Daniell
LONGPORT
+1 786 878 0246
On Mon, Sep 7, 2020 at 10:58 AM wrote:
> Hello Erik,
> has long plagued many 914 owners. Jim Butcher and I recently published a
n
a
> fix. If you aren=99t a member you might consider joining. Good in
formation
> using ZOOM opened up the audience internationally with many USA builders
> able to join, myself included.
d
> fully seat. I used a Dremel, although, a file will do the trick.
> Kind regards,
> Erich
> Top News - Sponsored By Newser
> - *Gender Reveal Party Has Now Burned Through 7K Acres*
> <http://thirdpartyoffers.juno.com/TGL3132/5f56497cc9dbc497b6e0fst03duc
1>
> - *Booted Djokovic Sorry for Hitting Line Judge With Ball*
> <http://thirdpartyoffers.juno.com/TGL3132/5f56497ced459497b6e0fst03duc
2>
> - *US Sailor Goes Missing From Aircraft Carrier*
> <http://thirdpartyoffers.juno.com/TGL3132/5f56497d1ab6c497b6e0fst03duc
3>
Not flown yet but complete and paperwork at the LAA actually being worked ri
ght now.
Alan
> On 7 Sep 2020, at 16:14, Ian Cook wrote:
> =EF=BB Richard how is the building going. With Bicester closing down I d
on=99t Alan Twigg has still not flown his MG yet. I now have about 70H
rs on mine,
> Sent from my iPhone
>>> On 7 Sep 2020, at 15:38, Richard Churchill-Coleman wrote:
>> =EF=BB Bud
lcoat=99 which I am still trying to resolve.
>> Richard C-C
>> Sent from my iPad
>>> =EF=BB
>>> David,
d cracking terribly on all the accessory parts like speed kits and cowls.
>>> Thanks again,
>>> Bud Yerly
>>> From: SwiftTG
om>
heap polyester chop and glass bit from Europa". I do not know what part is b
eing referred to but nothing is now supplied from Europa in chop strand. As a
>>> David Stanbridge
>>> Read this topic online here:
>>> st Email Forum -
>>> ums.matronics.com
>>> matronics.com
Ian, only the gliding club has closed. 6 gliders and a tug remain privately.
GA still active and busier than before. Visitors welcome.
Alan
> On 7 Sep 2020, at 17:01, Alan Twigg wrote:
> =EF=BBNot flown yet but complete and paperwork at the LAA actually bein
g worked right now.
> Alan
> Sent from my iPhone
don=99t Alan Twigg has still not flown his MG yet. I now have about 7
0Hrs on mine,
>> Sent from my iPhone
>>> =EF=BB Bud
elcoat=99 which I am still trying to resolve.
>>> Richard C-C
>>> Sent from my iPad
>>>> =EF=BB
>>>> David,
nd cracking terribly on all the accessory parts like speed kits and cowls.
>>>> Thanks again,
>>>> Bud Yerly
>>>> From: SwiftTG
com>
>>>> David Stanbridge
>>>> st Email Forum -
>>>> ums.matronics.com
>>>> matronics.com
From: | "Hitchflight" <bobhitchcock(at)icloud.com> |
Hi Duncan
Great idea. Im free Wednesday and Friday. Where do you propose?
http://forums.matronics.com/viewtopic.php?p=498204#498204
From: | "JonathanMilbank" <jdmilbank(at)yahoo.co.uk> |
Apart from the obvious religious and older English connotations, what doth you
mean by "DOTH"? It seems to be known only among the flying fraternity in England.
http://forums.matronics.com/viewtopic.php?p=498225#498225
From: | "Email Security Gateway" <dralle(at)matronics.com> |
Subject: | User Quarantine Account Information |
V2VsY29tZSB0byB0aGUgIEVtYWlsIFNlY3VyaXR5IEdhdGV3YXkgLiAgVGhpcyBtZXNzYWdlIGNv
bnRhaW5zIHRoZSBpbmZvcm1hdGlvbiB5b3Ugd2lsbCBuZWVkIHRvIGFjY2VzcyB5b3VyIFNwYW0g
UXVhcmFudGluZSBhbmQgUHJlZmVyZW5jZXMuCgpZb3VyIGFjY291bnQgaGFzIGJlZW4gc2V0IHRv
IHRoZSBmb2xsb3dpbmcgdXNlcm5hbWUgYW5kIHBhc3N3b3JkOgogICAgVXNlcm5hbWU6ICBldXJv
cGEtbGlzdEBtYXRyb25pY3MuY29tIAogICAgUGFzc3dvcmQ6ICBKWCt2PVZZSktkcnFOeDlHIAoK
VG8gbG9naW4gdG8geW91ciBTcGFtIFF1YXJhbnRpbmUgdXNlIHRoZSBmb2xsb3dpbmcgbGluazog
IGh0dHBzOi8vOTYuNjguMTcxLjIxIAoKICAK
Bicester is quite central. A bit expensive at 15.
D.
> On 08 September 2020 at 10:01 Hitchflight wrote:
> Hi Duncan
> Regards
> Bob
Subject: | Re: User Quarantine Account Information |
Matt,
Apparently, I have received one of these for each of my accounts (Rotax,
Europa & AeroElectric)
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules
Prop.
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
> On Sep 8, 2020, at 4:46 AM, Email Security Gateway
wrote:
> Welcome to the Email Security Gateway . This message contains the
information you will need to access your Spam Quarantine and
Preferences.
> Your account has been set to the following username and password:
> Username: europa-list(at)matronics.com
> Password: JX+v=VYJKdrqNx9G
> To login to your Spam Quarantine use the following link:
https://96.68.171.21
JonathanMilbank wrote:
> Apart from the obvious biblical and older English connotations, what doth you
mean by "DOTH"? It seemeth only to be known among the flying fraternity in England.
Google hath not given a relevant answer.
DOTH = Drop Of The Hat
PS Thanks for all your advice on the Scotland trip. LambHolm and your friend Tommy
was a delight.
http://forums.matronics.com/viewtopic.php?p=498254#498254
> D
[/quote]Never been there before. Happy with that choice. Food available?
http://forums.matronics.com/viewtopic.php?p=498255#498255
I would love to have joined the DOTH, but unfortunately the exhaust pipe on? No.
2 cylinder has failed (again), so I am grounded, until a replacement arrives.
Bob Dawson
Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3
http://forums.matronics.com/viewtopic.php?p=498257#498257
From: | Bob Hitchcock <bobhitchcock(at)icloud.com> |
Hi Duncan
Thanks. Have just PPRd. The chap has told me about the heritage centre and coffee
and cake shop
See you late morning.
PPR mandatory.
> On 8 Sep 2020, at 14:51, D McFadyean wrote:
> Not sure. Take sandwiches!
> Visitor instructions attached.
> Duncan.
>>> D
01869 254841 is the new phone number for mandatory PPR.
Coffee, cake and sandwiches shop will be open.
http://forums.matronics.com/viewtopic.php?p=498265#498265
Now confirmed as Bicester, late morning Wednesday 9th.
D.
week?
could be an issue in some areas (Severn Valley for example) by then.
> Duncan McF.
Subject: | Spam Quarantine Summary - (1) |
RGVhciAgZXVyb3BhLWxpc3RAbWF0cm9uaWNzLmNvbSAsIHRoaXMgaXMgeW91ciBxdWFyYW50aW5l
IHN1bW1hcnkgZnJvbSB0aGUgIEVtYWlsIFNlY3VyaXR5IEdhdGV3YXkgLgoKWW91IGhhdmUgIDEg
IG1lc3NhZ2VzIGluIHlvdXIgc3BhbSBxdWFyYW50aW5lIGluYm94LiAgVG8gdmlldyB0aGUgY29u
dGVudHMgb2YgeW91ciBxdWFyYW50aW5lIGluYm94IG9yIHRvIG1hbmFnZSB5b3VyIHNwYW0gcHJl
ZmVyZW5jZXMsIHBsZWFzZSBvcGVuIHRoZSBmb2xsb3dpbmcgbGluayBpbiB5b3VyIGJyb3dzZXI6
Cmh0dHBzOi8vOTYuNjguMTcxLjIxL2NnaS1tb2QvaW5kZXguY2dpP2V0PTE2MDAwMzY1MDgmcGFz
c3dvcmQ9ZjRkYzZlYTkxMjQzZGU3MGE2ZDZlZDc2ZjkyYjc3ZGUmdXNlcj1ldXJvcGEtbGlzdCU0
MG1hdHJvbmljcy5jb20mbG9jYWxlPWVuX1VTJnJvbGU9X25vZG9tYWlucwo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R0lGODlhBwAXANUAAABMhQBJggJNhjprkXiQoouapgBUjQBQiRlejwBelwBZkgBknQBwqABqogCC
uwB8tAB2rgCOxwCIwQCg2ACa0gCUzQC17QCy6gCu5gCq4gCl3Qa06iS56lTN88/x/K7n+Mzx/OH3
/f///7CwsAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAAAABwAXAAAGXkCRUBQCgUSejmVp
+WwuUCgHQ61mrtiMZsvVTL7gCWVMplTO6EpkzY5I3nCJY053PO74B2TPhzD+gAwNg4QNC4eICwmL
jAkKj5AKBpOUBggHmJkEAgCdnSMFAwGjAUEAOw=
uwB8tAB2rgCOxwCIwQCg2ACa0gCUzQC17QCy6gCu5gCq4gCl3QOz6iS56lTN88/x/K7n+Mzx/OH3
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAAAABwAXAAAGXkAQKCQqiixIS8cj
ujidmw9mSuVkrtiMZsvVTL7gCWVMplTO6EpkzY5I3nCJY053PO74B2TPhzD+gAwNg4QNC4eICwmL
jAkKj5AKBpOUBgeXmAgAm5sCBAGgAQMFI0EAOw=
Thanks for the reply I will check out MGL forums. I was proposing to use
MGL servos so maybe should work ok. My plane flies very true so hopefully
that will be ok too.
Cheers
Max
> them to work correctly. MGL Torrance sold them to me, but they told me
> that Trio was the problem and Trio told me that the problem was with MGL.
> your plane flies straight & level. How much force is needed to bring the
> nose up or down once it leaves altitude. For whatever reason by plane took
> more force to bring it back to level than the Trio servo could deliver and
> would trip and shut down after a few minutes of trying. If you go back
> into this Forum you find a lot of question on how to get them set up. The
> roll axles worked and it was easy to install in the co-pilot seat area.
> The big problem is the pitch servo and how it connects to the pitch torque
> tube. I had to manufacture a clamp with a horn on it. Europa now makes a
> pitch tube with the horn welded to it.
> MGL EFIS . You might check out their forum.
From: | Richard Holder <richard.holder(at)outlook.com> |
> the inner carburettor at 45mm. The airbox outer tube is
> strengthen the orifices after they collapsed under the
> never given any thought to a mismatch between the two
> with the bolt holding the box to the engine frame it
> same size even before the collapse.
> rebuild the airbox as per Dave Ps suggestion - cut the
> to that size?
> the boxes up. Also what is the airbox made from? It
Steven, just seen this.
When my airbox tubes compressed I used short lengths of
steel exhaust pipe with the correct OD (to match the carb
inlet OD).
I dremelled away enough of the original fibreglass to get
the exhaust tube (ET) to fit nicely using the carbs as the
locational template. I drilled a few holes in the ET to
allow keying. I then resined (with a filler) in the ETs
without worrying about the actual orifice size.
When the resin had gone off I dremelled out all the
surplus resin on the inside leaving it reasonably smooth.
Much stronger than the original, and as the air passage is
now much larger than it was the engine runs less rich !
And I can do the Jubillee clips up tight. I bought short
lengths of silicone hose with ID to match the carb inlet.
Not patented !
Richard
From: | "clivesutton" <clive.maf(at)googlemail.com> |
Anyone up for a DOTH trip meeting tomorrow Monday 14th Sept to North Coates (Lincolnshire
coast) , arriving midday-ish TBC?
Haven't been there before, but looks like a gem: 760 x 20m grass, small museum,
5 to land. EGD307 nearby but local arrangements in place.
See http://www.northcoatesflyingclub.co.uk/
http://forums.matronics.com/viewtopic.php?p=498331#498331
Subject: | Re: Rear wing root socket problems |
Thank you Bud, Duncan and others for your input.
David Stanbridge reached out to me in response to my post here and I've
E-mailed them the pictures as well. Their recommendation was to remove
the rust and oil it to prevent further corrosion.
Now, my local mechanic and I decided to have me paint the W26A using
"hammer paint" after sanding. Here's to hoping that the parts will still
fit. It shouldn't rust anymore anyway...
The way I recall it, the W26B was correctly oriented when we found the
totally broken one. However, it had almost fallen off so I can't be
sure. The port side one however, which I later discovered to be cracked
as well, was correctly oriented. That is if I remember correctly. I
might again here just be assuming it was installed correctly due to
having read the builder's manual afterwards.
And yes, I am a member of the Europa Club and will sure check out the
914-tips, thank you all.
/ Erik
> correct way around.
> central bolt indicate that at some point W26A was leaning heavily on
> W26 in a 'negative g' direction of loading, which may explain how it
> then broke i.e. the weight of the wing transmitted in bending through
> the lift pin caused W26A to lever against W26.
> rigged. Perhaps the downward leverage occurred during derigging after
> removing the spar pins, and assuming the spar cups were misplaced.
> (or bent) above the centreline of the inboard spar projections (and/or
> that W26 has been set vertically).
> Duncan Mcf.
>> severe than anticipated.
>> In all my years, Ive seen corrosion on older socket parts that were
>> failure in the 26A as this was a well engineered and tested part by
>> Europa. If installed backwards, this can happen.
>> This area is a critical flight component and the annual inspection
>> and repair may have missed this part may have been damaged or
>> assembled incorrectly. If the socket inner W26B failed, was the
>> interior tube and attachments properly installed, checked and
>> call it so they operate as a unit. The wing pin goes into the fully
>> assembled socket and allows it to move up and down just a bit. If
>> not Loctited the barrel can rotate and make pin insertion more
>> difficult. (Frankly, during wing install, simply note the
>> orientation of the barrel is all that is needed.) Note that the
>> assembly thin side goes on the fuselage side. Dont get that
>> see.
>> This barrel is designed to move up and down.
>> keeping the 914 running true. The carbs are easily rebuilt with
>> proper attention to detail. I find the Rotax engine forum
>> informational, but doesnt cover in enough detail. I do find the
>> videos provided by Rotax to be quite complete. The paper I did
>> covers various phases and expands troubleshooting. See the
>> Bud Yerly
>> Sent from Mail for
>> Windows 10
>> *From: *Erik Dahlbck <mailto:erik(at)erikdahlbeck.com>
>> *Sent: *Sunday, September 6, 2020 5:18 PM
>> *To: *europa-list(at)matronics.com
>> *Subject: *Europa-List: Rear wing root socket problems
>> Hello,
>> etc...
>> https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.rotax-owner.com%2Fen%2F912-914-technical-questions%2F6881-914ul-carburettor-gremlins%3Fstart%3D15&data=02%7C01%7C%7C8482b0ef213641821e7208d852aa5b72%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637350238926500351&sdata=pMvGV5%2BI41Zjnn3nQnSV8Wo37dGxDwnn9%2Ff%2Bu5P7T%2F0%3D&reserved=0
>> PROBLEM NO 1
>> PROBLEM NO 2
>> winter.
>> Sincerely,
>> Linkping, Sweden
>> Europa SE-XRX
Weather tomorrow Tues 15th Sept is not quite as good as today, but would someone
like to suggest a DOTH location for a UK meet-up?
http://forums.matronics.com/viewtopic.php?p=498352#498352
Subject: | Torques to use on brake components bolts |
Dear forum members,
Does anyone know of what torques to use on the brake components at the wheel. At
least in the Cleveland units used in the certified world the torque of the two
bolts that hold the brake pad back plate is very important.
For now I just made it nice'n tight.
Chris
http://forums.matronics.com/viewtopic.php?p=498355#498355
Hi Clive
Id propose the military UAV experimental base at Aberporth. This airport often
defaults to describing themselves as closed for various reasons , but the natives
have been welcoming on previous visits. Suggest I could give them a PPR call
in the morning, then we confirm. Have yet to see the large new model RAF UAVs
land, so that would interest me greatly. Its also possible to walk down the
steep hill to the sea from this base. However if Aberporth say no this time,
then Haverfordwest or Rosemarket for Skokholm and Skomer Islands.
Thoughts?
NB In a few days the seals start to return to the beaches at North Coates. So its
a great destination for spotting wildlife.
http://forums.matronics.com/viewtopic.php?p=498359#498359
Subject: | Re: Torques to use on brake components bolts |
Page 370 in the combined builders manual is your friend and list the torques youre
need.
Alan
G-OBJT
> On 14 Sep 2020, at 17:49, n7188u wrote:
> Dear forum members,
At least in the Cleveland units used in the certified world the torque of the
two bolts that hold the brake pad back plate is very important.
> Chris
Tues DOTH not possible for me, Wed is better.
FLYER mag has free landing for North Coates and Cambridge.
John Wighton
Europa XS trigear G-IPOD
http://forums.matronics.com/viewtopic.php?p=498369#498369
From: | Roger Sheridan <rogersheridan(at)mac.com> |
I have unfortunately been unaware of the recent Doth meetings due to Matronics
mail ending up in my Mac junk folder.
Efforts to improve email filtering have been unsuccessful & I wonder if anyone
out there has a workable solution please.
Roger
> John Wighton
I have just fitted two new soft start modules to my Rotax 912ULS. Should they both
be activated by the start switch and start on both modules. or select only
one module to start then activate the second by going to both. I have only wired
up one module at the moment but have installed wire to be used from the second
module if it is ok to do so.?
Any experts out there?
G-LDVO
Dave Park
There will definitely be others with more in-depth knowledge than me to give you
a solid engineering answer, but my experience leads me to suggest that if both
your ignition systems are the same, then why not use them simultaneously to
get your engine started?
If only one soft start module was fitted, then it would probably be wise to start
using only that one to reduce the likelihood of the "kickbacks" such as ruined
my first starter sprag clutch. That was when I had two earlier design ignition
modules, but now that I have the current design of modules both incorporating
a few seconds of ignition timing retardation, I start using both modules
without hassles.
http://forums.matronics.com/viewtopic.php?p=498390#498390
Subject: | 914 generator disconnected and running fuel pump #1 |
Hi Group I have a curiosity question. If a 914 is wired as per Europa's schematic,
if the battery is taken off line Fuel Pump #1 will run off the generator.
Question: Is there an RPM where the generator will not supply enough power to keep
Fuel Pump #1 running?
In other words if on final with pump #1 running only on generator and you pull
power will the engine quit?
Thx. Ron P.
http://forums.matronics.com/viewtopic.php?p=498391#498391
From: | "Remi Guerner" <air.guerner(at)orange.fr> |
80-90 in Lbs. or 9.5 N.m for the two bolts that hold the brake pad back plate
Remi
http://forums.matronics.com/viewtopic.php?p=498393#498393
Subject: | How to properly hoist a Europa Trigear |
Hello again,
One hopefully simple question: How do you best hoist (or jack) a Europa
Trigear for landing gear maintenance?
At some point on the fuselage? On big cushioned plates under the wings,
centered under the main spar?
Also, is it safe to lift the nose wheel by pushing down the rear part of
the fuselage, perhaps using a wide collar placed just ahead of the
thinnest point, strapped to a weight or attaching point on the floor?
Sincerely,
Subject: | Re: How to properly hoist a Europa Trigear |
HI Erik,
Use an aluminium or steel rod, can't remember the diameter, and push into t
he leg, first remove the cotter pin. Length should be at least 50cm. then j
ack it up with your hydraulic jack. You can now remove the wheel up to the
jack.
Now place a block of wood under the leg end and lower the jack and remove i
t, and the wheel.
For the nose gear I had an eye bolt mounted in the garage floor. Then used
a ratcheting strap just
ahead of the fin, looped through the eye bolt, and lowered the tail that wa
y. Or get someone to push down the tail.
Karl
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr
onics.com> on behalf of Erik Dahlb=E4ck
Sent: 18 September 2020 09:14
Subject: Europa-List: How to properly hoist a Europa Trigear
Hello again,
Sincerely,
an option to get everything off the ground (if ever needed) is to hoist the
plane from the top two engine mounts (on the fuse frame side of the
rubbers) using straps, and support the tail.
Pete
On Fri, Sep 18, 2020 at 4:24 AM Erik Dahlb=C3=A4ck
> Hello again,
> Sincerely,
Thanks Alan and Remi,
80-90 in*lbs is in line with what I use in the Clevelands (75-80, at one point
they changed it a little).
Alan, what do you mean by page 370 of the combined builders manual. My big paper
manual is divided in sections so a little hard to find page 370. I looked around
the manual (its been a while I looked at it in its entirety) and can't find
a list of torques.
Best Regards,
Chris
http://forums.matronics.com/viewtopic.php?p=498410#498410
Oh, just wanted to post a picture of my Europa doing taxi test last weekend. Very
exciting moment to be able to finally put all the parts together, see it as
complete airplane and take it around the neighborhood for a spin. As you can
see a lot of things are still being held by Clecoes.
Still lots to do to complete (pretty much all control surfaces and wings need filling
and lots of little things here and there but it is a complete machine right
now.
Special thanks go out to the this group, the Europa Club and in particular Bud
Yerly for all the help and support during this arduous process. I'll post something
when the airplane finally flies which I expect around the beginning of next
year.
Now all I need to do is find a way to put the wings on that doesn't take an hours
(how in the world Europa claimed the setup would take less than 5 minutes dunno)
Maybe with practice :D
Chris
http://forums.matronics.com/viewtopic.php?p=498411#498411
http://forums.matronics.com//files/chm_europa_taxi_338.jpg
Chris I have a pdf copy of the builders manual, Combined Builders Manual, I downloaded
from the Europa Website.
It contains all the build info for mono and tri-gear builds. I found the torque
settings in there, page 370. Or section CBM 29T.
You need to register with Europa Site to access.
Alan
around the manual (its been a while I looked at it in its entirety) and can't
find a list of torques.
> Best Regards,
> Chris
Subject: | Undercarriage & Flap Lever on the XS Mono Wheel |
Has anyone ever created an extra long lever or an additional attachment to make
the Undercarriage Lever easier to operate?
I have arthritis in the knuckle joints of the first 2 fingers of my right hand
and found it quite difficult to push the lever forward to put down the Mono Wheel
& Flaps.
I was thinking of a longer lever which would give more leverage?
Thanks in advance for any suggestions/advice.
James
Seat of my pants
http://forums.matronics.com/viewtopic.php?p=498413#498413
OK got it Alan. The tri gear manual does seem to have a little more info on torques
for some of the landing gear components. Not so much for the mono but Remi
provided a torque and I'll go with that. Thanks
http://forums.matronics.com/viewtopic.php?p=498414#498414
Subject: | Re: Undercarriage & Flap Lever on the XS Mono Wheel |
Hi James,
Not quite what you were asking for but I get a better & more comfortable
hold on both brake & gear levers with bike handlebar grips.
Roger
attachment to make the Undercarriage Lever easier to operate?
right hand and found it quite difficult to push the lever forward to put
down the Mono Wheel & Flaps.
> James
> Seat of my pants
Subject: | Any use to anybody |
Some instruments free to anybody that may want them, just cover the postage costs.
http://forums.matronics.com/viewtopic.php?p=498419#498419
http://forums.matronics.com//files/img_2090_422.jpg
http://forums.matronics.com//files/img_2089_781.jpg
http://forums.matronics.com//files/img_2088_190.jpg
http://forums.matronics.com//files/img_2087_474.jpg
http://forums.matronics.com//files/img_2086_757.jpg
My thoughts on this: Any extra long lever would need to be dog legged as the
top of the existing lever fits into the recess in the panel. Also the force
needed is very depended on getting the bungee tension correct. If this is
high enough then the force needed to retract or engage the undercarriage
will be minimal.
Roddy Kesteton
G-IKRK
-----Original Message-----
On Behalf Of Mallard
Sent: 18 September 2020 16:07
Subject: Europa-List: Undercarriage & Flap Lever on the XS Mono Wheel
hand and found it quite difficult to push the lever forward to put down the
Mono Wheel & Flaps.
James
Seat of my pants
James,
Ted Gladstone and Justin Kennedy have done several mods to their
Monowheel
Z-TED, including the following reported on the Matronics list as
follows:
Date: Sep 02, 2001
From: Edward Gladstone <Ted_Gladstone(at)compuserve.com>
Subject: tric Flaps on Monowheel
>Shaun Simpkins wrote:-
>Has anyone out there tried decoupling the flaps and gear on a
monowheel<
We are the Edinburgh group who have fitted an electric screwjack
actuator to
operate the flaps on our monowheel Europa. Rowland is correct in that
the
actuator was originally designed to operate the elevation mechanism on a
lounge chair or bed for the elderly. It weighs about the same as the
long
cranked linking tube and its associated couplings. We also developed a
manual emergency method lowering the flaps, should the electric motor
fail,
but Francis Donaldson (PFA Chief Engineer) did no share our enthusiasm
for
it and we locked out this device. Along with many other mods we have
also
changed the lever that operates the undercarriage such that it rotates
from
a horizontal position on the tunnel through 180 deg to end up again in
the
horizontal position on the tunnel. It allows us to fill up the cavity
in
the instrument panel and it can now be operated with a single finger!
The electric flap motor also operates the outriggers in the normal
manner
(for the time being) but we have the intention to also operate the
outriggers with small electric screw jack actuators. When this is done
we will be able to operate the flaps to any angle but, with the existing
setup, we can go down to 30 deg and op to 23 deg without unlatching the
outriggers. At the moment we have decided to abandon any further mods
and concentrate on getting it flying ( it's kit No 15!!!). When its
flying we can amuse ourselves with our further mods and go faster
fairings.
Ted & Justin
G-ZTED
While this may be too radical a solution for you, the principle involved
in
making the undercarriage lever rotate through 180=B0 has clearly
resulted in a
very light operating force. I have always found Ted and Justin very
willing
to share their Europa experiences and am sure they would be happy to
discuss
ideas on the subject.
Best regards,
Dr Mike Gregory
Kit 94
01480 451655
07885 355765
james(at)kingdom.ie>
to
right
the
Mono Wheel & Flaps.
James
Seat of my pants
<http://forums.matronics.com/viewtopic.php?p=498413#498413>
Am I correct in assuming that the aforementioned metal rod (would a
sturdy tube do?) goes in where the attachment for the wheel pants goes
in? Or does that one somehow fit into something else that is mounted
within the wheel axis? (please see attached photo)
Any other options BTW? What if you needed to work on the landing gear
strut for an example, and didn't want the fuselage to be standing on it?
I saw that suggestion about suspending the fuselage from the engine
mounts and the tail. My local mechanic who's helping me with all this
wasn't very fond at all of that idea.
/ Erik
On 2020-09-18 12:46, Karl Heindl wrote:
> HI Erik,
> into the leg, first remove the cotter pin. Length should be at least
> 50cm. then jack it up with your hydraulic jack. You can now remove the
> wheel up to the jack.
> remove it, and the wheel.
> used a ratcheting strap just
> that way. Or get someone to push down the tail.
> Karl
> *From:* owner-europa-list-server(at)matronics.com
> on behalf of Erik Dahlbck
> *Sent:* 18 September 2020 09:14
> *To:* europa-list(at)matronics.com
> *Subject:* Europa-List: How to properly hoist a Europa Trigear
> Hello again,
> Sincerely,
> st Email Forum -
> ums.matronics.com
> matronics.com
To raise the nose wheel I use at least two 30 liter cans of fuel/water to we
igh down the tail with a padded strop over the fuselage in front of the fin.
To service main wheels I use the method described using a piece of steel tub
e pushed in to the axle, a jack and a piece of 1 inch ply to support the leg
Dave Park G-LDVO
> On 21 Sep 2020, at 22:17, Erik Dahlb=C3=A4ck wrote
> =EF=BB
> Thanks,
> Am I correct in assuming that the aforementioned metal rod (would a sturdy
tube do?) goes in where the attachment for the wheel pants goes in? Or does
that one somehow fit into something else that is mounted within the wheel a
> Any other options BTW? What if you needed to work on the landing gear stru
> I saw that suggestion about suspending the fuselage from the engine mounts
and the tail. My local mechanic who's helping me with all this wasn't very f
> / Erik
>> HI Erik,
the leg, first remove the cotter pin. Length should be at least 50cm. then j
ack it up with your hydraulic jack. You can now remove the wheel up to the j
ack.
it, and the wheel.
>> Karl
tronics.com> on behalf of Erik Dahlb=C3=A4ck
>> Hello again,
>> Sincerely,
>> st Email Forum -
>> ums.matronics.com
>> matronics.com
To supplement the taildragger modification we have developed (apologies to those
who await more information on this topic), we developed a clamp on jacking stand.
The problem with using the axle hole is that you cannot get the wheel and
brakes completely off the aircraft.
We have a design that clamps on, using the slight taper (of the original Europa
legs or the Acroflight ones) to ensure it doesn't slide.
Picture attached.
It can be used with a trolley jack or small bottle jack.
John Wighton
http://forums.matronics.com/viewtopic.php?p=498492#498492
http://forums.matronics.com//files/europa_main_gear_clamp_001_262.png
Hi JOhn,
A very neat design, but wouldn't work with leg fairings in place and requir
es a certain amount of expertise and time to manufacture. The axle hole sol
ution is very simple and cheap, and gets the wheel off completely in a matt
er of minutes. Either way, it is useful to have a means of changing a wheel
when touring.
Karl
onics.com> on behalf of John Wighton
Sent: 22 September 2020 10:30
Subject: Europa-List: Re: How to properly hoist a Europa Trigear
those who await more information on this topic), we developed a clamp on ja
cking stand. The problem with using the axle hole is that you cannot get t
he wheel and brakes completely off the aircraft.
ropa legs or the Acroflight ones) to ensure it doesn't slide.
Picture attached.
John Wighton
From: | Justin Kennedy <justin(at)systemwise.co.uk> |
Subject: | Re: Undercarriage |
Hi Roddy,
While our complicated retraction mechanism has stood the test of time the b
ungie has reduced in its efficiency over time and while still easy to opera
te it can be heavy when there is any additional G force. I now leave the U/
C retraction until further up the climb. Then a deft forward move on the st
ick will produce a slightly reduced G and the U/C comes up really easily. I
t takes a few goes to get this trick off without lurching forward but done
right it makes light work of the retraction and is hardly noticeable to the
spectator. I can=92t see why this would not work on the conventional arran
gement. If one tightened the bungie so the lowering would require more forc
e than the retraction then the skill would be to add a little G when loweri
ng the U/C. Next time I have the firewall plates off I will tighten the bun
gie like this though getting it exactly right may prove difficult. This mak
e sense because as I approach the overhead I am climbing slightly to bleed
off the speed. A timely lowering of the U/C as the speed reached U/C operat
ing speed would use the additional G to assist the lowering.
Yet another skill to set us mono pilots apart.
Just my halfpenny=92s worth.
Cheers
Justin
G-ZTED Mono Classic, 912S, Airmaster Prop, Warp drive blades.
Kit No:15
From: | Erich Trombley <erichdtrombley(at)juno.com> |
Subject: | RE: Undercarriage & Flap Lever on the XS Mono Wheel |
Hello James,
If I understand your email correctly the issue you are having is with moving the
lever out of the up gate in order to lower the gear. That being the case I
offer the following suggestions, neither being a mod, however.
First, try tightening the bungee. This greatly reduces the force necessary to
not only raise the undercarriage, but also the forward force required to move
the lever out of the up gate.
Secondly, I have found that if I unload the wing by pushing the control stick forward,
the undercarriage lever will float forward off of the up gate allowing
easy extension of the gear. Typically, I perform this maneuver by first, pulling
the power back and then raising the nose to maintain altitude, as speed drops
below the flap extension speed push the nose over and at the same time lower
the gear as you feel the lever move forward off of the up gate. Works a
treat.
Erich
N28ET
Classic Mono 914
____________________________________________________________
Romney's Decision All but Seals the Deal for Court Pick
http://thirdpartyoffers.juno.com/TGL3131/5f6a14d68a0eb14d534fcst02duc1
Graham's Flip-Flop May Help Save His Seat
http://thirdpartyoffers.juno.com/TGL3131/5f6a14d6aedaf14d534fcst02duc2
Utah Cop on Bodycam: 'It's Going to End in a Shooting'
http://thirdpartyoffers.juno.com/TGL3131/5f6a14d6d52c914d534fcst02duc3
Subject: | Re: RE: Undercarriage & Flap Lever on the XS Mono Wheel |
I concur on all points! :)
-pete
> On Sep 22, 2020, at 11:29 AM, Erich Trombley wrote:
> Hello James,
the lever out of the up gate in order to lower the gear. That being the case
I offer the following suggestions, neither being a mod, however.
forward, the undercarriage lever will float forward off of the up gate allowing
drops below the flap extension speed push the nose over and at the same time
lower the gear as you feel the lever move forward off of the up gate. Works
a treat.
> Regards,
> Erich
> N28ET
> Classic Mono 914
June 14, 2020 - September 23, 2020
Europa-Archive.digest.vol-oc
