Europa-Archive.digest.vol-oh
May 04, 2021 - June 14, 2021
      But I've been informed that there's no such thing as ethanol free car petro
      l such as Esso Synergy Supreme and other "super unleaded" brands in the who
      le of Scotland and parts of Northern England, which all get their fuel from
       the Grangemouth refinery regardless of brand name. From September this yea
      r, all car petrol from Grangemouth will continue to have ethanol of at leas
      t 5% and 10% in ordinary unleaded.
      Furthermore a friend's Eurofox experienced partial engine failure after tak
      e-off due to using Esso Synergy Supreme from a local garage, probably stale
       fuel due to low sales turnover. He only just managed to get back onto the
      runway unscathed! After flushing out the fuel system and filling with ordin
      ary E5 unleaded, there's never been another missed beat in his engine.
      So my question remains to be answered by EU pilots and particularly Europa
      owners who have been using E10 for many years, as far as I know. Please let
       me know if you've heard of any problems experienced by any pilot and/or Eu
      ropa owner after using E10 petrol for a long time. Problems not only to do
      with carburettor icing and vapour lock, but also the fuel tank, fuel lines
      and electric pump. Thank you.
      http://forums.matronics.com/viewtopic.php?p=501651#501651
      st Email Forum -
      pa-List">http://www.matronics.com/Navigator?Europa-List
      p;   - MATRONICS WEB FORUMS -
      ums.matronics.com
      p;  - NEW MATRONICS LIST WIKI -
      matronics.com
      p; - List Contribution Web Site -
      p;                  -Matt Dralle, List Admin.
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: May 04, 2021
Subject: Re: Charge warning light
OK so I went ahead and ordered a bandc regulator. I spoke to them about it. It has the same mounting holes and footprint as the ducati VR. It has an internal OVP. If the OVP trips then you cycle the generator. This means I'm going to remove my current OVP which I hope should not be too much of an issue. I also am going to take the opportunity to change my fusible link to a 25A fuze. thanks Will William Daniell LONGPORT +1 786 878 0246 On Mon, May 3, 2021 at 5:36 AM Bud Yerly wrote: > Will, > Yes. > > B&C has dimensions on their website to check your particular aircraft bol t > pattern. > > Bud Yerly > > Get Outlook for Android > > ------------------------------ > *From:* owner-europa-list-server(at)matronics.com < > owner-europa-list-server(at)matronics.com> on behalf of William Daniell < > wdaniell.longport(at)gmail.com> > *Sent:* Monday, May 3, 2021 7:46:26 AM > *To:* europa-list(at)matronics.com > *Subject:* Re: FW: Europa-List: Charge warning light > > So the bottom line is the symptoms suggest that my VR is failing? > > Is the bandc unit a straight drop in? > > Thanks > > Will > > William Daniell > +1 786 878 0246 > > On Sun, May 2, 2021, 19:00 Bud Yerly wrote: > > > Will, > > This is the common failure of an older voltage regulator: > > Most older tech regulator/rectifiers use a small incandescent lamp in the > charge circuit warning. > > If the regulator and battery are putting out the same voltage, the lamp i s > out (12 volts on either side of the lamp). > > If the regulator or one of the rectifier diodes begins to die, the voltag e > difference begins to be different so the lamp glows faintly. > > If the regulator or the rectifier dies completely the warning light does > not illuminate as the warning light circuit depends on regulator output > circuitry. Your first indication is the battery low warning goes on or > your volt meter starts to sag. > > > Note: VRs are temperature sensitive. Try to keep them below 50C (130F) > and if saturated at 70C (150F) or better, let them cool. This is a > problem on a quick refuel and takeoff in the Florida summers with high am p > needs on top of the temperature. Heat is the killer of regulators. > > > Other Regulators to consider: > > Nobody likes Ducati but they work if the amps are kept low and the temps > are reasonable (mine lasted 10+ years). Modest price at $150-170 USD. > > In the US, Silent Hectic is harder to get except from a European > partner/cohort. Works well. $250ish USD typically. > > Since we have a dynamo like Deutz and Kubota tractors, some have used > their regulators. Cheap, $20-$50. Hi amp users may find a high failure > rate. Problems are with temperature as these tend to be flimsy units but > rugged for tractor use. > > > Note: Jabiru uses a Kubota. > > > B&C builds a very nice regulator for the Rotax. Has LED output and a > proper warning system separate from the regulator circuit. Even > overvoltage protection is built in. Works well with GRT, Dynon and > Garmin systems. Van=99s uses them on their RV12s and others are mo ving > that way due to the high number of Dynon and Garmin users. It puts out > 14.5 volts and is adjustable as is the low voltage warning which really > helps gel cell and Lithium Ion battery users unlike the cheaper options. > It is a step above what we are used to. The operational under hood heat > max is in line with the others. Cost is $300ish. > > > I=99ve attached a word doc I just researched last month when my Duc ati VR > went out on 12AY just prior to Sun =98n Fun. > > > I=99ve got my spare Ducati on now but will go to the B&C to check i t out > this summer after I consider a ducting change to my firewall. I keep my > TCU on the footwell and need to do some temperature checks under the hood > to determine if I put my VR next to my TCU under the footwell cover. Thi s > cover has a built in fan and ducting with a timer to keep the TCU cool. I > figure, why not cool the VR along with it. I just have to see how hot > the VR gets putting out power. The TCU never gets warm from operation. > > > Best Regards, > > Bud Yerly > > > *From:* owner-europa-list-server(at)matronics.com < > owner-europa-list-server(at)matronics.com> *On Behalf Of *William Daniell > *Sent:* Sunday, May 02, 2021 4:46 PM > *To:* europa-list(at)matronics.com > *Subject:* Europa-List: Charge warning light > > > I have standard z 16 > > > I have a charge warning light and a Dynon efis and ems > > > This morning the charge light stayed on for about 5 mins albeit glowing > not lit. Normally it goes out within 1 min. The dynon said 13.8v and 6 > amps from start up and my battery charging amps were normal also. > > > Does this mean anything apart from some kind of fault with the light? > For example do these symptoms mean that my regulator about to give up? > > > Thanks > > > Will > > William Daniell > +1 786 878 0246 > > ________________________________________________________________________________
Subject: Re: Question for European friends re E10 car fuel
Date: May 04, 2021
Reply for Griffo: For information I'm in the UK. I agree that having the fuel pump on will not prevent vapour lock, but having positive pressure in the fuel system will help reduce the chance of it as any vapour in the fuel line will be pushed through the fuel lines back to the tank. I also believe that it helps starting especially when the engine is hot and the risk of vapour lock is greater. On the Vans RV12, the fuel pump comes on with the master switch, there is no separate switch to turn off the pump, the only way to turn it of is to pull the circuit breaker/fuse If you search on the Vans forums, you will learn that one reason for having the pump on all the time is to help prevent vapour lock. Vans consider the pump an expendable item as it's cheap to replace. The downside to leaving it on all the time is that (without a fuel pressure gauge as in my aircraft) you will not know if the mechanical pump has failed. This is why I occasionally turn off the electric pump at a safe altitude to see if the low fuel pressure light comes on which will indicate a problem with the mechanical pump. I'm interested to learn if anyone has a valid reason for not leaving the electric pump on all the time. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501697#501697 ________________________________________________________________________________
Date: May 04, 2021
Hi William A few notes on AVC1: ** It's Nickle plated and conductive ** There are 2 grounds on it, I suggest you use both ** If you are not certain that you have Phosphor Bronze Fastons, at minimum replace the two yellow AC wires with them ** If you by chance don't have a capacitor or the one you have is questionable, B&C sells them ** You can read the install manual on line, you may need to get some stuff like LED and or reset switch etc Good luck Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501700#501700 ________________________________________________________________________________
Date: May 04, 2021
Hi David D; I have a fuel pressure gauge which gives some indication of fuel delivery health. I use my auxiliary fuel pump, pre start, to "charge the system" Turn of before engaging the starter. If you dont have to "drain" your electrical system with unnecessary systems you will get a better chance of a "brisk" turn over & engine start (same with a road vehicle, turn of all non essential electrics befor engaging starter). I briefly use my auxiliary pump again during warm up to check for significant rise/fall in fuel line pressure - health of the system check. Auxiliary pump on for take off & climb out to safe altitude. I dont put my auxiliary pump on again, until down wind for a landing/or low level pass. Pump is turned off when taxiing prior to engine shut down. Your auxiliary pump is supposed to be a back up in the event of your main, usually mechanical, pump failing in whole/part. It is routinely turned on, during critical phases of flight, when an engine fuel starvation situation may result in a crash. It is also there for cruise flight if the mechanical pump fails. It is not and never has been a continual fuel supply mechanism. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501701#501701 ________________________________________________________________________________
Date: May 04, 2021
Rotax 91 engines: Fuel vaporisation is usually the result of the heat from a hot engine, low/nil air flow "boiling" fuel in the fuel line (s) that go from the mechanical pump to the carburettors. Boiling/vaporization of the fuel in these lines, is most likely to occur when a hot engine is shut down. No air & fuel flow. Keeping fuel running through these lines will allow "cooling" to take place. Rotax have come up with a partial "fix". It is restricted "bleed" system where fuel vapour and fuel can be vented back to the tank. This allows fresh cool fuel to charge the system close to the carburettors (there can still be a brief period of rough running as the hot gaseous fuel is passes through the carburettors giving a sub optimal fuel/air mix). Using your auxiliary fuel pump on the ground, to push the hot fuel/gas back to the tank and replace it with fresh cool fuel, may certainly assist in speeding the recovery from the fuel vaporisation state. Using your auxiliary pump continuously will add nothing to your engines performance but is likely to drain your wallet a but quicker. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501702#501702 ________________________________________________________________________________
Subject: Re: AVmap EFIS Ultra feedback please
Date: May 04, 2021
I have an AvMap Ultra - The swinging the compass part is a right royal pain in the back side. As per the instructions. I turned on all flight instruments prior to commencing the swing - all four cardinal points and the aircraft is supposed to be as near to flight attitude as you can make it. It works but may need recalibrating from time to time. To be honest, I got mine more for the nice AH display - looks cool in the centre of my panel. Be warned - the AH is a little slow to react to changes of attitude. Other features are also useful but the display is so small I find I use my IPad & GPS for such things as ground speed and other instruments for air speed and climb/decent. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501703#501703 ________________________________________________________________________________
From: "CruisingEuropa" <jan_gonnissen(at)hotmail.com>
Date: May 05, 2021
Thanks Griffo - I heard swinging the compass can be challenging for the AVmap. As you say, still a neat little instrument and I use a handheld Garmin for navigation. Would be great to be able to use the AVmap's HSI with some precision. Cheers. Jan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501708#501708 ________________________________________________________________________________
Subject: blue foam
Date: May 05, 2021
hi everybody. quick question where can i buy blue foam in the uk ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501711#501711 ________________________________________________________________________________
Date: May 05, 2021
Hi Griffo, I agree with most of what you say, especially about vapours returning through the fuel return line to the tank if there are any in the system hence my comment about assisting starting especially when hot. I think the restricted fuel return line is in the build manual, so all Europa's should be fitted with it, I know mine is. I do leave mine on when starting, the pump only draws about 1.5 amps so shouldn't affect starting too much, but I do agree that all electrics are best off when starting. The cost of replacement in the UK is about 40 for the Facet pump (about $80 Aus ?) which isn't a lot when amortised over the life of the pump - mine is still going after 7 years in my ownership and there is no record of it having been changed since build in 2001. I guess it's just down to personal preference so until someone comes up with really good reason not to do it, I'll be leaving mine 'on' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501718#501718 ________________________________________________________________________________
Date: May 05, 2021
DD, There is no really good reason for continually running your auxiliary pump, nor is there a good reason for turning it off when not required, except for the erlier point, that by leaving it on all the time, you may "mask" a failed main pump. Other than this, I see no strong reason for arguing either way. Its just your argument for leaving it on is a bit weak. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501720#501720 ________________________________________________________________________________
Subject: Re: blue foam
Date: May 06, 2021
How much do you need? Would the residuals from the Europa kit suffice? I expect many of us have leftovers . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501724#501724 ________________________________________________________________________________
Date: May 06, 2021
If i may add my own two-pennarth on this topic:- It is a myth that particular brands of fuel in the UK always have the same mix of additives - including ethanol content. The forecourt owners (who might be a single fuel station or number of them dotted around a region), are the ones who specify the mix that gets loaded at the refinery (i know because i asked MRH Driving Retail Group - who operate several forecourts in my area - about how they choose the fuel they sell). It's also not uncommon to find a particular forecourt changing its offer and re-branding from e.g. Shell to e.g. Jet. So I suggest that if an Esso branded pump at a particular forecourt has a track record of no ethanol, it is much more likely that its that way because of the forecourt owners choices at that location than due to the brand being shown on the pump. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501725#501725 ________________________________________________________________________________
Date: May 06, 2021
If i may add my own two-pennarth on this topic:- It is a myth that particular brands of fuel in the UK always have the same mix of additives - including ethanol content. The forecourt owners (who might be a single fuel station or number of them dotted around a region), are the ones who specify the mix that gets loaded at the refinery (i know because i asked MRH Driving Retail Group - who operate several forecourts in my area - about how they choose the fuel they sell). It's also not uncommon to find a particular forecourt changing its offer and re-branding from e.g. Shell to e.g. Jet. So I suggest that if an Esso branded pump at a particular forecourt has a track record of no ethanol, it is much more likely that its that way because of the forecourt owners choices at that location than due to the brand being shown on the pump. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501726#501726 ________________________________________________________________________________
Date: May 06, 2021
Fuel point it which fuel vaporises is also very much a function of fuel pressure. The electric pump pressurises all the fuel lines within the cowling, as opposed to the mechanical pump which only affects the pipes from the pump to the carbs; your fuel return line helps all the time that the engine is running, but the electric pump can return vapour to liquid in a matter of a few moments when turned on (can, not will!) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501738#501738 ________________________________________________________________________________
Date: May 07, 2021
On 2021-05-05, at 16:00, daaza22 wrote: > quick question where can i buy blue foam in the uk ? Europa factory? . . . | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Date: May 07, 2021
Blue foam i believe is known as xps ...this is available at the big home improvement stores here in the usa. Can anyone confirm this? I have used this for small project like air scoops and seat supports and it certainly seems close to the europa supplied blue foam. Will William Daniell +1 786 878 0246 On Fri, May 7, 2021, 05:36 Rowland Carson wrote: > > > > On 2021-05-05, at 16:00, daaza22 wrote: > > > quick question where can i buy blue foam in the uk ? > > > Europa factory? . . . > > | Rowland Carson ... that's Rowland with a 'w' ... > | http://www.rowlandcarson.org.uk > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > > ________________________________________________________________________________
Date: May 07, 2021
Very true Rick, We colonials have lot of experience with fuel vaporisation, temps of 45C + (in the shade) are all too common. In my opinion one of the Rotax 91's (carburettor variants), very few, design anomalies, is the routing of fuel lines over the top of the engine. Not usually a problem in flight, due to plenty of fuel/ air movement BUT definitely something that requires good management, after engine shut down, subsequent start up, taxi, run up, take off & climb out on a hot day. Have no modifications (other than insulating/lagging for partial assistance) to suggest - its all about awareness & management. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501743#501743 ________________________________________________________________________________
Subject: Fwd: Blue Foam
Date: May 07, 2021
I think this message should have gone to the list, not to me. I do not have any need of blue foam, but thanks for the offer, Jim. > Begin forwarded message: > > From: jimlawnn(at)hotmail.com > Subject: Blue Foam > Date: 7 May 2021 at 14:15:19 BST > To: rowlandcarson(at)gmail.com > > Rowland - how much and what size pieces do you need ? I have some left over from my build , generally small pieces which could be delivered to an airfield near you, if they are of any use. > Regards Jim Lawn > > Sent from my iPad | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Subject: Non-Aviation related, hmm actually anti-Aviation!
Date: May 07, 2021
Hi Group No aeroplane work done this past Wednesday. Well at least not done at hangar! Fdale home decided to "LEAK"! Water in bathroom, hallway and kitchen? Couldn't EZ determine where it was coming from. Ripped out sheetrock from under sink and behind dishwasher and found malady. Major job to rip out entire wall and replace all plumbing. Real jigsaw puzzle. Went after pipes with 50 and 80 grit sandpaper, Carbide tipped scribe and Denatured Alcohol. Then pre-bent expanded Aluminium with Fiberglass scrim and is self adhesive to holes, then filled with JB KWIK Weld. Had electric heater warm things up. Then put fillet of Flox in corner of junction of pipe to female fitting flange. Then 4 BID. The BID goes completely over the flanges. One flange is a hex and BID conformed perfectly. The small pipe to right had a Copper pipe laying against it, so it was surgeon skills working with an inspection mirror. Pipe to left is about ~13" long and some of it is hidden behind wall, rot was only ~ 6" long but went full length from flange to flange. Hoping this is a permanent fix. https://1drv.ms/u/s!Ah1S270Nwg9VgdsaSGyQjBD4WiGEiw?e=BxfRYd Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501755#501755 ________________________________________________________________________________
From: Jeffrey Williams <jeffwill55(at)sbcglobal.net>
Date: May 07, 2021
Will, Yes, dense styrofoam is something you can get at a hardware or home improvement store in the USA. Extruded polystyrene insulation (XPS) is manufactured using a process of extrusion, and has a closed cell structure. As an example, Dupont Styrofoam=84=A2 Insulation (Blue Board) is a nonstructural, rigid board insulation manufactured of XPS foam. Since it is insulating material for buildings, you can buy it in bulk - truck (or lorry) loads if you=99d like. All you need is some foam dense and rigid enough to hold the shape you want, and to be smooth enough so the resulting fiberglass surface will be smooth too. XPS should work. However, if you want, you can also get styrofoam from places like Aircraft Spruce, but it is a bit pricey. They have large cell and small cell versions of the stuff. https://www.aircraftspruce.com/categories/building_materials/bm/menus/cm/f oam.html (They probably just buy it from Home Depot and mark up the price.) I would expect the folks at Aircraft Spruce could ship it to the UK, but I don=99t know for sure. For what it=99s worth, I have some leftover chunks of blue foam, but I am in the USA. Regards, Jeff W. > On May 7, 2021, at 6:38 AM, William Daniell wrote: > > Blue foam i believe is known as xps ...this is available at the big home improvement stores here in the usa. > > Can anyone confirm this? > > I have used this for small project like air scoops and seat supports and it certainly seems close to the europa supplied blue foam. > > Will > William Daniell > +1 786 878 0246 > > On Fri, May 7, 2021, 05:36 Rowland Carson > wrote: > > > On 2021-05-05, at 16:00, daaza22 > wrote: > > > quick question where can i buy blue foam in the uk ? > > > Europa factory? . . . > > | Rowland Carson ... that's Rowland with a 'w' ... > | > http://www.rowlandcarson.org.uk > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > > ========== > pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List > ========== > FORUMS - > eferrer noreferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer noreferrer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > ________________________________________________________________________________
Date: May 08, 2021
thanks everybody for the help. Hopefully the little I need can be kindly supplied by my inspector. cheers Darren Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501763#501763 ________________________________________________________________________________
Date: May 08, 2021
In the UK I have bought from: Hampshire Insulated Products The Hangar Thompsons Lane Marwell Winchester SO211JY TEL 01962777730 They can cut and make 3D shapes Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501764#501764 ________________________________________________________________________________
Date: May 08, 2021
Subject: Headset howl
A quite serious case of headset howl has suddenly afflicted N460. The symptoms only occur after about 15-30 mins of flight and only with the engine on. Could this be related to my failing Voltage Regulator? thanks Will William Daniell LONGPORT +1 786 878 0246 ________________________________________________________________________________
Subject: Idle adjustment
Date: May 09, 2021
Hi Everyone, Advice on how to adjust the idle speed on my 912ULS please. The engine is 4yrs since installation with about 80 hours running time. Runs good as gold but recently noticed idle speed is up to 1800/1900 rpm ! Do I adjust this by simply repositioning the throttle cable (quite possibly stretched now) or can it be adjusted by a screw on the carb ? Thankyou Paul Munford G-OVPM ________________________________________________________________________________
Subject: Re: Idle adjustment
Date: May 09, 2021
Hello Paul, First I would suggest that you refer to Europa Mod.20 Throttle Closed Stop. If I recall correctly, this mod is intended to prevent strain on the 2 throttle cables by creating a physical barrier in the cockpit, on top of the tunnel and at the rearward limit of travel of the throttle lever. I deliberately made my cockpit throttle stop adjustable and also screwed back the idle speed adjusters on the two carburettors so that they don't have any role in adjusting idle speed. My adjuster is simply a penny washer with an eccentric hole through which the rear screw holding down the slotted throttle guide plate is fastened. To adjust idle speed, I slightly loosen the screw and rotate the penny washer as needed to alter the rearward throttle limit, before locking the screw again. But you should check the balance of your two carburettors with some good device like a CarbMate. Usually it can be seen that the two carburettors aren't idling exactly the same, so if you want a slower idle then use the cable adjusters where the cable outer sheaths meet the carburettors and take whichever carburettor is "higher" down slightly. Or vice versa if you want a higher idle speed. It can be a bit fiddly, but the end result should be that your carburettors are synchronised and the idle speed is what is desired when the throttle lever in the cockpit is fully back against the stop. Thus also no strain on the cables. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501796#501796 ________________________________________________________________________________
Subject: Water Drain
Date: May 09, 2021
Does anyone know if there is an alternative to Mod 33 water drain valves mod? For what ever reason my aircraft has never had the mod done even though its been run on Mogas. I want to add drain valves but not keen on Mod 33 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501799#501799 ________________________________________________________________________________
Subject: Voltage regulator connection
Date: May 09, 2021
Has anybody seen this voltage regulator connection issue? One of the yellow generator connectors has clearly got hot and is too close to its slot in the plug. It's definitely melted, not vibration or mechanical abrasion and looks like it's simply too close to the edge of its slot in the plug. How to avoid re-occurrence? (Apologies for the first image - auto focus [Rolling Eyes] ) Many thanks in advance, Paul M XS Mono 912 ULS G-PLPM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501802#501802 Attachments: http://forums.matronics.com//files/20210509_125502_121.jpg http://forums.matronics.com//files/20210509_125515_458.jpg http://forums.matronics.com//files/20210509_125602_346.jpg ________________________________________________________________________________
Subject: Re: Voltage regulator connection
Date: May 10, 2021
Most overheating at joints or connectors is due to contact resistance. This could be a loose fit of the connector on the spade or poor crimp joint on the wire. Might even be due to the connector spade going down the side of the connector rather than between the tangs of the connector if its loose in the holder. Alan G-OBJT Sent from my iPad > On 9 May 2021, at 20:47, Paul M 383 wrote: > > > Has anybody seen this voltage regulator connection issue? One of the yellow generator connectors has clearly got hot and is too close to its slot in the plug. > > It's definitely melted, not vibration or mechanical abrasion and looks like it's simply too close to the edge of its slot in the plug. > > How to avoid re-occurrence? > > (Apologies for the first image - auto focus [Rolling Eyes] ) > > Many thanks in advance, > > Paul M > XS Mono 912 ULS > G-PLPM > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501802#501802 > > > > > Attachments: > > http://forums.matronics.com//files/20210509_125502_121.jpg > http://forums.matronics.com//files/20210509_125515_458.jpg > http://forums.matronics.com//files/20210509_125602_346.jpg > > > > > > ________________________________________________________________________________
Date: May 10, 2021
Hi Paul, That is the common failure mode for that connection. I am not sure that the black connector block adds anything to the security of the installation. It is an easy way to connect all of the regulator wires in one go but it masks the physical state of the spade terminals. I always check that each individual terminal is secure after installation. In my current new build I am considering leaving the black plastic bit off and simply protecting each individual terminal with heat shrink insulation. This would enable a good physical inspection of each terminal during routine checks. Brian Davies -----Original Message----- From: owner-europa-list-server(at)matronics.com On Behalf Of Paul M 383 Sent: 09 May 2021 20:45 Subject: Europa-List: Voltage regulator connection --> Has anybody seen this voltage regulator connection issue? One of the yellow generator connectors has clearly got hot and is too close to its slot in the plug. It's definitely melted, not vibration or mechanical abrasion and looks like it's simply too close to the edge of its slot in the plug. How to avoid re-occurrence? (Apologies for the first image - auto focus [Rolling Eyes] ) Many thanks in advance, Paul M XS Mono 912 ULS G-PLPM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501802#501802 Attachments: http://forums.matronics.com//files/20210509_125502_121.jpg http://forums.matronics.com//files/20210509_125515_458.jpg http://forums.matronics.com//files/20210509_125602_346.jpg -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 10, 2021
Hi JonathanM; I like the sound of your idle low speed stop - any chance of a photo or two. On the carburettor balance - here is absolutely no need to go to the expense of a "Carb Mate" any half decent motorcycle shop (or on line) will sell you a pair of cheap vacuum gauges and the bits to adjust down the inlet pulses. Then all you will need are two suitable lengths of tubing, so that you can monitor the vacuum in each carbi, in the cockpit. Don't forget to disconnect the balance tube befor making your readings Oh and do your static/manual adjustment befor doing your pneumatic fine tuning. Simple as!!. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501829#501829 ________________________________________________________________________________
Subject: Re: Water Drain
Date: May 10, 2021
Maaate! - every aircraft should have some effective way of sampling the fuel (sump) in the tank, not just for water but for other contaminants. Oh! & water in fuel is not the sole concern of ULP , unleaded fuels in general or even ethanol blends - water contamination can simply be from the diernal temperature range & atmospheric moisture - fit the drains & do the sampling, befor every first flight of the day. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501830#501830 ________________________________________________________________________________
Date: May 10, 2021
Sorry that the aircraft's away for a while, being used by a friend elsewhere. A photo wouldn't be much use, because it's up to each person to make a penny washer into a gentle spiral / cam by filing the edge progressively nearer to the washer hole, about halfway around the circumference. It's trial and error, to suit the distance between the back of the throttle lever and the aft bolt holding the throttle quadrant box in place. Another way to do it might be to follow the instructions in Mod.20, making a plate as shown but slotting the bolt hole to allow fore and aft movement of the plate. My method with the penny washer is similar but on a smaller scale to the rotating parking brake methods I've seen on a couple of Europa monos. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501832#501832 ________________________________________________________________________________
Date: May 10, 2021
Griffo thanks for the input mate. I know all that, I work on aircraft for a living. I didnt build the plane unfortunately. If I had it would have had the drain valves. Having had the tank outlets out recently i'm in no hurry to revisit that nightmare. However if there is an alternative to Mod 33 then that may be an option. The thing has been flying for 20 odd years without them. The mod is "optional" if your running the thing on Avgas and mandatory (in the UK) if using mogas! Never came across an aircraft without drains before. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501836#501836 ________________________________________________________________________________
Date: May 10, 2021
Not sure what your unhappiness is with mod 33. It was done by builder on mine but not with long pipes to the back. The drains are just slightly forward of the tank, tri-gear, but use the essential hardware of Mod33. Having just changed the aged rubbers sealing the outlets into the tank, replaced with fuel proof silicon, I agree its not an easy area to work in. Alan Sent from my iPad > On 10 May 2021, at 16:10, Matt Dovey wrote: > > > Griffo thanks for the input mate. I know all that, I work on aircraft for a living. I didnt build the plane unfortunately. If I had it would have had the drain valves. Having had the tank outlets out recently i'm in no hurry to revisit that nightmare. However if there is an alternative to Mod 33 then that may be an option. The thing has been flying for 20 odd years without them. The mod is "optional" if your running the thing on Avgas and mandatory (in the UK) if using mogas! Never came across an aircraft without drains before. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501836#501836 > > > > > > > > > ________________________________________________________________________________
Date: May 11, 2021
Matt, Sorry I don't know you or your kit, but I have done my own Mod33 fuel drain for years. About 5 aircraft have a simple 90 degree fitting epoxied to the floor of th e aft floor behind the flaps so it is easy to drain. Make a pair of holes in the aft baggage bay area beyond the flap. Hole sho uld fit a 1/2 inch socket for the Safeair drain. Attach the Safeair to a 1/8" NPT 90 degree fitting. Brass or aluminum is O K. Grease your socket and insert into your sealed and prepared drain hole. Place the 90 degree and drain assembly and glue in with Redux. A variation is to make a ply plate for the 90 degree/drain assembly and re dux the assembly to the plate then simply glue the plate into your prepped holes. Very neat. Simply remove the Safeair and screw in a plug during pa inting. I have a street tee screwed into the two 90 degree brass fittings for my f uel quantity experiment pictured below. The orangish tube is my sight gauge which was added after the original buil d. Today I pipe it into the Fuel Boss. [cid:image003.jpg(at)01D745DA.D9DB3D50] Most of my Trigear guys put the drains in the tank fuel boss. Mono guys put them behind the wing. Below is a typical under the belly fuel drain using a simple 1/8 NPT nipple and a tee to make a drain and sight gauge line. [A picture containing indoor, gear Description automatically generated] There are as many variations as there are airplanes. Note I put my feed li ne through the back and into the seat well where I install fuel filters wit h quick disconnects. I=92m lazy. I have a fuel drain pan and drain hole just in case there is a leak. [A picture containing indoor Description automatically generated] Work with your inspector to see what works for you. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of Matt Dovey Sent: Sunday, May 09, 2021 1:21 PM Subject: Europa-List: Water Drain ilto:mattdovey(at)hotmail.co.uk>> Does anyone know if there is an alternative to Mod 33 water drain valves mo d? For what ever reason my aircraft has never had the mod done even though its been run on Mogas. I want to add drain valves but not keen on Mod 33 Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D501799%23501799&data=04%7C01%7C%7Cc c8b65ab893546b6338108d913101281%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0% 7C637561782019096765%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2 luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=RWtjrreyZrzJ1SY1Dgr NjtqPdxzIScjtkj1kxhZeDJQ%3D&reserved=0 %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7Ccc8b 65ab893546b6338108d913101281%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6 37561782019096765%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=X%2FQ1bI8miPRo9CYWvvuB dldGdsErWTAzIsKatvAodJE%3D&reserved=0 %2Fforums.matronics.com%2F&data=04%7C01%7C%7Ccc8b65ab893546b6338108d9 13101281%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637561782019096765%7C Unknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL CJXVCI6Mn0%3D%7C1000&sdata=fV%2ByLh5woPX5ztHiel1ISUh0F6KFPyV6lm%2F35% 2FOfN%2Fs%3D&reserved=0 %2Fwiki.matronics.com%2F&data=04%7C01%7C%7Ccc8b65ab893546b6338108d913 101281%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637561782019096765%7CUn known%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=%2BnmPNrsilr6sHLmwWa9O0nrv%2FG4dJIG3xJmpa%2B cvHo4%3D&reserved=0 %2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7Ccc8b65ab893546b 6338108d913101281%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637561782019 096765%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=juK0pXBeyhfr8Z89epsQ4D6nCv1WjPRXq OqY0XeV1bo%3D&reserved=0 ________________________________________________________________________________
Date: May 11, 2021
Yep, Happens with a regulator going bad and or a poor crimped connector or shorting of the connector. Which ever it is, inspect and correct your wire first. Consider buying a "spare" regulator. Each dynamo wire goes into the regulator circuit (GG). If that particular diode is dying in the regulator it can get really hot (short). A terrific read is the Contrails articles on the Ducati regulator. Regulators like the Ducati are used in many different vehicles. The main problem is too much draw. See my techniques article on the Europa Club site (AMP Zealot) or at mine. The other problem is heat. If the regulator is routinely above about 120F (50C) and the draw is high (over 15 amps) it's toast. Cut your amps, monitor the regulator temperature. Use of heat temperature indicating tapes is recommended. Or hook up a thermistor/sensor for your Volt Meter for recording. Here's hoping its just a poor crimp. Best Regards, Bud Yerly https://www.customflightcreations.com -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Paul M 383 Sent: Sunday, May 09, 2021 3:45 PM Subject: Europa-List: Voltage regulator connection Has anybody seen this voltage regulator connection issue? One of the yellow generator connectors has clearly got hot and is too close to its slot in the plug. It's definitely melted, not vibration or mechanical abrasion and looks like it's simply too close to the edge of its slot in the plug. How to avoid re-occurrence? (Apologies for the first image - auto focus [Rolling Eyes] ) Many thanks in advance, Paul M XS Mono 912 ULS G-PLPM Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D501802%23501802&data=04%7C01%7C%7C40ce17de636c4ce604a008d913237afb%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637561865372894593%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=WNOyxTwm2dw2FVyum7LgSgDXfg%2F6mLEdSGR8F4QM%2BJw%3D&reserved=0 Attachments: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2F%2Ffiles%2F20210509_125502_121.jpg&data=04%7C01%7C%7C40ce17de636c4ce604a008d913237afb%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637561865372904580%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=dgdY5ihKvIs6AnBzq1%2F%2BEszZ%2FVRyTbacxVZ6IVBAK1E%3D&reserved=0 https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2F%2Ffiles%2F20210509_125515_458.jpg&data=04%7C01%7C%7C40ce17de636c4ce604a008d913237afb%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637561865372904580%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=7Iuy2JR8q0qK045EPaHOVONcuczQ%2BL8xL0PjRwuE0g4%3D&reserved=0 https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2F%2Ffiles%2F20210509_125602_346.jpg&data=04%7C01%7C%7C40ce17de636c4ce604a008d913237afb%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637561865372904580%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=7uu9N9B17eVp%2B3EobuiKUgyBiswQfW05KEXXyp1QI%2FU%3D&reserved=0 ________________________________________________________________________________
Date: May 10, 2021
There are photos of my throttle stops for both the 914 and it also works for the 912 series Europa Throttle box on the Europa Club website Builders section Bud Yerly notes Throttle friction is the title. Over the years I have done this mod and it is simple and it works. Normally I set my idle to about 1600 hot on a warm day at the carb stop. Then bump the throttle stop up to 1800 for winter and about 1700 ish for summer. Warning, you may need to crack the throttle on the 912S a bit to get up quickly to 2000 RPM otherwise it will shake like the dickens when on a cold start. Best Regards, Bud Yerly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501850#501850 ________________________________________________________________________________
Subject: Re: Headset howl
Date: May 10, 2021
Will, Yes it can. Simply turn off your alternator switch if connected to the C and see if the noise stops. If you are wired differently where the regulator is powered continuously and only the bus is disconnected by the alternator switch, pull the C out of the regulator or just unplug the whole regulator and check. If the noise stops. You are out $170 bucks for a new one. Bud Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501851#501851 ________________________________________________________________________________
Date: May 11, 2021
As usual Bud Yerly giving good inspiration. Just a reminder directed at the newer U.K. audience members, all Mods and Mod variations have to be approved by the LAA before execution. The EAA regime is very different to the U.K. Many approaches are proven, but remember changes must ultimately be compliant with the LAA permit. Your aircraft insurance cover is based on a compliant aircraft. If in doubt check with the Inspector. Regards Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501853#501853 ________________________________________________________________________________
Date: May 11, 2021
Hello Bud, I have problems with my original Ducati regulator, in 2013 I replaced it with the Silent hektik Regulator. It fulfilled its function and after 5 years, alarms flash on my Dynon D100 + D120. After checking, it appears that the Silent hektik regulator is out of order? ... After various searches, I found the MOSFET regulator FH020AA. I installed it on my 912S the alarms went off and all is well. I am attaching the document for this regulator to you. Michel AUVRAY Europa 098, 145, CTSW Le mar. 11 mai 2021 =C3- 04:02, budyerly(at)msn.com a =C3 =A9crit : > > Will, > Yes it can. > Simply turn off your alternator switch if connected to the C and see if > the noise stops. > > If you are wired differently where the regulator is powered continuously > and only the bus is disconnected by the alternator switch, pull the C out > of the regulator or just unplug the whole regulator and check. > > If the noise stops. You are out $170 bucks for a new one. > > Bud > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501851#501851 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Idle adjustments
Date: May 11, 2021
Hi, Thankyou all for your help & excellent advice on getting my Rotax 912 ULS sorted. Will be getting to work this weekend ! Paul Munford G-OVPM ________________________________________________________________________________
Date: May 11, 2021
Thanks bud I will also try that if it comes back. I will unplug the whole thing as my alt switch is down stream of the vr. So having done a bit of interweb research lightspeed suggested turning down the headset volume on the headset volume control if it has one (as opposed the the control on the radio) and turning down the mic gain. This appears to have cured the problem. How permanent this will remains to be seen. Will William Daniell +1 786 878 0246 On Mon, May 10, 2021, 21:02 budyerly(at)msn.com wrote: > > Will, > Yes it can. > Simply turn off your alternator switch if connected to the C and see if > the noise stops. > > If you are wired differently where the regulator is powered continuously > and only the bus is disconnected by the alternator switch, pull the C out > of the regulator or just unplug the whole regulator and check. > > If the noise stops. You are out $170 bucks for a new one. > > Bud > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501851#501851 > > ________________________________________________________________________________
Date: May 11, 2021
Michel, Thank you for that. It looks very similar to the Multistrada 1200 series. I'm not a semiconductor guy and prefer plug and play, but Shindengen is held in high regard for their products and I'm sure it is a good piece of equipment. I've looked at the Multistrada Type but I believe I will go to the B&C, although my Ducati spare is working well (right now). In the US it is easier to get service questions answered SOMETIMES with B&C as they back their equipment and understand their limitations. I heard that there is a Chinese knock off on many regulators that are very price appealing but I tend to shy from them. No offense to the Chinese manufacturers, but producing an electronic component for 20% of the cost of a European, Japanese, US equivalent makes me wonder. For those of you in the UK and other areas where modifications must be approved, use caution. I find it interesting that you can change regulators but not add a screw to your throttle for a stop without permission. So please consider this post as information and discussion and not acceptable for action without thorough research, appropriate permissions and guidance from certified sources commensurate with your countries policies and procedures. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501864#501864 ________________________________________________________________________________
Date: May 12, 2021
Will, I must confess that I nearly threw away my headsets because of poor underst anding of my own intercoms squelch/volume and headset volume relationship. The volume knob on my headset was rolled up during storage in its pouch an d I didn=92t notice. I lowered the volume on my Sigtronics but feedback an d excessive noise was still present. I have no idea how I missed this simp le headset volume verses intercom volume relationship during an hour flight but I was hopping mad and ready to yank my panel when I simply lowered the volume on the headset, readjusted the intercom volume and all was well. D uh. I really should put a paint dab on my headset knob to prevent recurren ce as I am getting more forgetful every day. Best Regards, Bud Yerly From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of William Daniell Sent: Tuesday, May 11, 2021 3:49 PM Subject: Re: Europa-List: Re: Headset howl Thanks bud I will also try that if it comes back. I will unplug the whole thing as m y alt switch is down stream of the vr. So having done a bit of interweb research lightspeed suggested turning down the headset volume on the headset volume control if it has one (as opposed the the control on the radio) and turning down the mic gain. This appear s to have cured the problem. How permanent this will remains to be seen. Will William Daniell +1 786 878 0246 On Mon, May 10, 2021, 21:02 budyerly(at)msn.com > wrote: m>" > Will, Yes it can. Simply turn off your alternator switch if connected to the C and see if the noise stops. If you are wired differently where the regulator is powered continuously an d only the bus is disconnected by the alternator switch, pull the C out of the regulator or just unplug the whole regulator and check. If the noise stops. You are out $170 bucks for a new one. Bud Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501851#501851 felinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fv iewtopic.php%3Fp%3D501851%23501851&data=04%7C01%7C%7Cdf80cb226b75449046c9 08d914b669c3%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63756359595778937 5%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=9H5wmFFbKC%2BjY9REOoXz0QF73bJ80ooFcTxQYCAH iyk%3D&reserved=0> pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matroni cs.com/Navigator?Europa-List FORUMS - eferrer noreferrer" target="_blank">http://forums.matronics.com WIKI - errer noreferrer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/co ntribution ________________________________________________________________________________
Date: May 11, 2021
Terrific suggestions Bud. I have never been a fan of the screw together reusable filters that so many like. I find them to be Heavy, Prone to leaking, Messy, Expensive & Fragile As an alternative, I suggest Hengst H103WK & H102WK https://www.hengst.com/en/online-catalog/search/?catalog=eu These filters area a relativly cheap gauze fuel filter, almost indestructible, light weight & you can see any contamination build up. You can clean them (HP air) but hardly worth while. I have carried a couple of spares for years but never had the occasion to use them. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501866#501866 ________________________________________________________________________________
Date: May 12, 2021
Griffo, I've never had a problem with mine. Not even the quick disconnects or those plastic filter elements. As the dealer I kept mine stock for obvious reasons. I've never found that these were delicate or easily broken unless dropped. I've grown to like them. There is a technique, and with the setup I have, are well protected. My technique is to Loctite the fixed end of the tube, change the rubber rings, tighten the filters down, add the spring per the manual, Wrench down the ends just snug to note compression. Allow to set while I do the other filter, then tighten one more time until I'm satisfied the glass is compressed into the rubber. After install and full of fuel, I check them again after a few hours to be sure there are no leaks and press on. Operationally, I check them after fueling for debris, (with a 914 I run a pump and let the fuel run through the filters on both sides to check for debris), then change them annually or when dirty (which is never). $10 a year. I use AvGas so, I get by longer than those using Jerry Cans and auto fuel. I keep a spare in my cross country kit bag ready to go. One of my clients put a metal polished camping mirror (piece of polished stainless) under his filters so he can see the bottom of the filter easier. Nice touch. Best Regards, Bud Yerly Warning: This post is for discussion purposes only and not acceptable for action without thorough research, appropriate permissions and guidance from certified sources commensurate with your countries policies and procedures. -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Griffo Sent: Tuesday, May 11, 2021 9:13 PM Subject: Europa-List: Re: Water Drain Terrific suggestions Bud. I have never been a fan of the screw together reusable filters that so many like. I find them to be Heavy, Prone to leaking, Messy, Expensive & Fragile As an alternative, I suggest Hengst H103WK & H102WK https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.hengst.com%2Fen%2Fonline-catalog%2Fsearch%2F%3Fcatalog%3Deu&data=04%7C01%7C%7Cb1f2045577554472bd8308d914e3a798%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637563790260060101%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=bhI%2FycYicFnOD%2B6OUOJrXS4tFLnGI3VtP%2BcETPFJe4U%3D&reserved=0 These filters area a relativly cheap gauze fuel filter, almost indestructible, light weight & you can see any contamination build up. You can clean them (HP air) but hardly worth while. I have carried a couple of spares for years but never had the occasion to use them. -------- 46 Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D501866%23501866&data=04%7C01%7C%7Cb1f2045577554472bd8308d914e3a798%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637563790260060101%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=pdLTbvzuXNgJ0tJ8qlxpIPYY0B1cxkzJjH0IwEz7EUQ%3D&reserved=0 ________________________________________________________________________________
Date: May 11, 2021
Hi Bud, You have certainly developed some good coping/management techniques with the screw together filters BUT have you looked at the Hengst ones I have recommended? Don't know about the USA but here in Australia, filter choice is not usually seen as an something the aircraft maker has the last word on (they are a consumable like oil or coolant choice). Further the Hengst filters are quite popular in LSA class aircraft operated in Europe. Soooo much simpler to use than the screw together type. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501868#501868 ________________________________________________________________________________
Date: May 12, 2021
In the US we have similar filters to this and looking on line I am particularly unimpressed with filters with just a straight nipple end. Although easier, inexpensive and used by the auto industry with their new fuel clip seals, the ASTM crowd in LSAs went to them but use common fuel line. I will stick to a metal hose barbed end filter and continue on as I am. You as the manufacturer of the aircraft can make those choices if your country regulations and inspectors allow it. A few years ago, a local A&P broke a similar plastic filter on an LSA by clamping down the hose too hard. This plane had a hose replacement using fuel injection hose, and being a hard hose, he clamped the crap out of it until it cracked. He called me over to his shop and we had a talk about it, and with carb hose and less pressure it seemed to hold just fine. The filter only costs a couple of bucks but it was back to the store to get another. I think the plane was a German LSA. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Griffo Sent: Tuesday, May 11, 2021 10:56 PM Subject: Europa-List: Re: Water Drain Hi Bud, You have certainly developed some good coping/management techniques with the screw together filters BUT have you looked at the Hengst ones I have recommended? Don't know about the USA but here in Australia, filter choice is not usually seen as an something the aircraft maker has the last word on (they are a consumable like oil or coolant choice). Further the Hengst filters are quite popular in LSA class aircraft operated in Europe. Soooo much simpler to use than the screw together type. -------- 46 Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D501868%23501868&data=04%7C01%7C%7C9d041897bebb41501dd708d914f200c3%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637563851889984040%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=rJVVmOI5i2Pg%2B0f1HZwM0hWhdUz5PB%2FxakoZJ4IAL3g%3D&reserved=0 ________________________________________________________________________________
Date: May 12, 2021
All good comments Bud and I would never suggest you change from the "tried & true" if you are happy to stay with it. Just wanted to let you know, that in my opinion, a better alternative is now available. A few points; Your A&P should understand that the hose size must be correct for the fittings and that the hose clamp is primarily for security (hose retention) not leak prevention. Further, tightening hose clamps to the level suggest by your story can only lead to damaged leaking hoses. Don't know why the FI hoses would be so hard - I use exclusively Gates FI fuel hose (made by good old Uncle Sam), in 12 years have never had a problem with fitting or leaking. I also noticed your photos show regular "garden" type hose clamps - my advise - change to FI hose clamps (even if you dont use FI hose) for an even 360 degree clamping pressure and much reduced chance of hose damage. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501880#501880 ________________________________________________________________________________
Date: May 12, 2021
All good comments Bud and I would never suggest you change from the "tried & true" if you are happy to stay with it. Just wanted to let you know, that in my opinion, a better alternative is now available. A few points; Your A&P should understand that the hose size must be correct for the fittings and that the hose clamp is primarily for security (hose retention) not leak prevention. Further, tightening hose clamps to the level suggest by your story can only lead to damaged leaking hoses. Don't know why the FI hoses would be so hard - I use exclusively Gates FI fuel hose (made by good old Uncle Sam), in 12 years have never had a problem with fitting or leaking. I also noticed your photos show regular "garden" type hose clamps - my advise - change to FI hose clamps (even if you dont want to use FI hose) -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501881#501881 ________________________________________________________________________________
Date: May 13, 2021
The gates hose was never the problem. The plastic filter was installed where the hose immediately bent after the barb. Heck of a way to install, especially with a plastic $2.00 filter. When he cranked down on the hose clamp he flexed the hose and the filter snaped. The Breezer was a ELSA and we think it may have been an owner operator installation issue as it was the first Breezer I had seen come through here. No plastic part should ever be held in bending. That was dumb. As far as hose clamps go, we use what we call Breeze clamps rather than the garden hose type. They look the same but are more robust and the screw doesn't protrude into the hose. However, expediency sometimes dictates the automotive supply shop "only has this type", and on the smaller vent hoses the cheap Chinese knock off Breeze type clamps will get used when the client comes with them. You are right, the cheap knock off open cut clamps when over tightened can cut the hose, and the rubber can poke through the gap or they just break. Nasty. I have moved on hose exchanges to the newer style silicone hose lined clamps supplied by my hose vender. Easy to use, a bit heavy, protects the hose. The name on them is AC Delco but I also see Ideal. They work fine on 5/16 hose but not on 1/4 inch. Then the compression or Oetiker clamp comes in handy for those. Why do I choose not to like compression style clamps? Because I do not like to use them in a low pressure carbureted system hose when it comes to removal. They get stuck on the hose and are a pain to get off when the client overtightens and the barb end gets buried in the hose. Especially when repositioning, which occurs during the learning phase. It's like the clamps on the 11mm crossover tube on the Rotax. Trying to find new hose that doesn't cost $10 a foot plus shipping is a pain over here. So, I prefer the Ideal or Dayco lined clamps for my main lines on a change out as I've gone to all 5/16 hose in the Europa so only one fuel line is in the plane. Easier to buy/replace come hose change time. I'm lazy. Although many LSA manufacturers are going to the crimp type or Oetiker clamp in production. From a production point of view I can see them, but I'm not excited about the fact they are one time use. Probably because during fabrication you take it apart and put it together a couple times. I can see the point that if the clamp area is easily accessed, getting a tool in there is not a problem. I've never had a leak with an Oetiker clamp, but then again, I'm not going to use them on a fuel filter. That is why I prefer to do my bosses now with all the joints on the end of the boss and minimize the clamps. We can do that in the US on our own. Others have to ask or get permission for a deviation. Shame. On my filters I use the Colder products quick disconnects. I have a love/hate relationship with them, but for 20 years they only require new O rings on the male ends and have never leaked unless the O ring gets cut. That is why I also hate them. The stupid locking collar will cut the O ring if care is not taken. That way the hose clamps go on and stay on for 5 years on the quick disconnects. Note, I'm on year 7 with the hoses in 12AY with the lined EPA lined R7 or better carb hose. It is really holding up very well. It is still supple, no cracking seen on the ends, and no checking at the clamps. So, the original 1997 Europa supplied Ideal clamps of steel will probably corrode off before the hose starts looking bad. Maybe next year I'll do a hose change. Maybe not? I'm getting older and the hose change requirement must be met to comply with the Rotax manual on my 914. Every one of my cooling hoses has the original style compression clamps and frankly, in Florida they are corroding just a bit now and I can't stand to look at them. Time to upgrade, probably spring clamps on the cooling hoses I guess with all new engine and airframe hoses and clamps. That's two to three days work at my pace now days. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Griffo Sent: Wednesday, May 12, 2021 7:42 PM Subject: Europa-List: Re: Water Drain All good comments Bud and I would never suggest you change from the "tried & true" if you are happy to stay with it. Just wanted to let you know, that in my opinion, a better alternative is now available. A few points; Your A&P should understand that the hose size must be correct for the fittings and that the hose clamp is primarily for security (hose retention) not leak prevention. Further, tightening hose clamps to the level suggest by your story can only lead to damaged leaking hoses. Don't know why the FI hoses would be so hard - I use exclusively Gates FI fuel hose (made by good old Uncle Sam), in 12 years have never had a problem with fitting or leaking. I also noticed your photos show regular "garden" type hose clamps - my advise - change to FI hose clamps (even if you dont want to use FI hose) -------- 46 Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D501881%23501881&data=04%7C01%7C%7Cbb8bcdc1915d45fb4ab508d915a0d7a2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637564602816568109%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=OrG8wHmN2piKZpayw6tY6xnmJ2gfeUZVvBvz7iU8TRQ%3D&reserved=0 ________________________________________________________________________________
Date: May 12, 2021
Good to talk with you Bud, I dont do so well with imperial/US measurements but can struggle through when I must. Back to the filters: Most of the fuel filters of this "type" have poor quality casings, have pleated "paper" type filters and many are opaque (making it impossible to asses contamination build up) The Hengst H102WK & H103WK are almost indestructible. Have gauze filters and clear casings - they are more like $10 each Australian, if bought singly but you can get them down to about $6 Au if purchased in quantity. Like you, I was initially skeptical of the non "barbed" male hose fitting. However using the right sized ID hose, cut to the correct length and supported, where appropriate, has resulted in 12 years/900hrs of no leaks, no inadvertent detachments. One other benefit of the non barb, is that the possibility of tearing the inside of the hose, when temporary removal is done, is eliminated. This then eliminates those troublesome little bits of "rubber" that may appear in your float bowl. The H103WK has a built in 90 degree bend, making tight applications that would benefit from this a breeze. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501885#501885 ________________________________________________________________________________
Subject: Larger oil cooler - Classic
Date: May 12, 2021
Hello fellow Europa enthusiasts! I'm trying to solve the oil cooling issue in my 912 ULS powered Classic. I have the standard cooling setup with a 10 row oil cooler behind the port radiator and slightly enlarged cowl outlets. On hot days (30 C) and loaded to max weight I very quickly reach 120 C oil temp during a climb of just 2000 ft. If I let it cruise a bit it will go down to 115 C within a few minutes, 110 C if I reach cooler air higher up. The coolant stays below 90 C, except the climb phase where it reaches around 100 C. So far after reading your past discussions I came up with 2 possible solutions: 1. Moving the oil cooler below the spinner. 2. Installing an oil/water heat exchanger to supplement the oil cooler. The first is a bit invasive and as I'm not the original builder I don't feel fully confident to perform, yet. The second one is tempting but I thought about trying a simpler solution first: exchanging the oil cooler for a larger model. Mocal makes various sizes - the 13 row should fit without issues and perhaps the 16 row version will fit as well (if it can clear the exhaust pipe). Has anyone tried this approach? How effective this may be without enlarging the cowl outlets? According to charts on Mocal website I should expect a reduction of oil temp of around 8 C (16 row vs 10 row), but that assumes a free air flow which is most likely not the case inside the cowling. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501888#501888 ________________________________________________________________________________
Subject: Re: Larger oil cooler - Classic
Date: May 13, 2021
Hi Michalm, Best solution is to reposition the oil coolant below the spinner. An alterat ion to the lower cowl with a inlet for the oil cooler. Easily done with comp osite experience or get someone to do it for you. No bull nose required just keep with the original profile. See photos. I have to place a barrier in wi nter to keep the temperature up 110C Rotax prefers the engine to run at. Wor ks very well. Cheers, Tim Sent from my iPhone Tim Ward 12 Waiwetu Street Fendalton CHRISTCHURCH 8052 Hom 03315166 > On 13/05/2021, at 18:53, michalm wrote: > > > Hello fellow Europa enthusiasts! > > I'm trying to solve the oil cooling issue in my 912 ULS powered Classic. I have the standard cooling setup with a 10 row oil cooler behind the port ra diator and slightly enlarged cowl outlets. On hot days (30 C) and loaded to m ax weight I very quickly reach 120 C oil temp during a climb of just 2000 ft . If I let it cruise a bit it will go down to 115 C within a few minutes, 11 0 C if I reach cooler air higher up. The coolant stays below 90 C, except th e climb phase where it reaches around 100 C. So far after reading your past d iscussions I came up with 2 possible solutions: > 1. Moving the oil cooler below the spinner. > 2. Installing an oil/water heat exchanger to supplement the oil cooler. > > The first is a bit invasive and as I'm not the original builder I don't fe el fully confident to perform, yet. The second one is tempting but I thought about trying a simpler solution first: exchanging the oil cooler for a larg er model. Mocal makes various sizes - the 13 row should fit without issues a nd perhaps the 16 row version will fit as well (if it can clear the exhaust p ipe). > > Has anyone tried this approach? How effective this may be without enlargin g the cowl outlets? According to charts on Mocal website I should expect a r eduction of oil temp of around 8 C (16 row vs 10 row), but that assumes a fr ee air flow which is most likely not the case inside the cowling. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501888#501888 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: May 13, 2021
I still don't like plastic slip on filters. It is definitely better than l awn mower filters. Sorry. Best Regards, Bud Yerly Get Outlook for Android ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of Griffo Sent: Wednesday, May 12, 2021 11:14:41 PM Subject: Europa-List: Re: Water Drain Good to talk with you Bud, I dont do so well with imperial/US measurements but can struggle through wh en I must. Back to the filters: Most of the fuel filters of this "type" have poor quality casings, have ple ated "paper" type filters and many are opaque (making it impossible to asse s contamination build up) The Hengst H102WK & H103WK are almost indestructible. Have gauze filters an d clear casings - they are more like $10 each Australian, if bought singly but you can get them down to about $6 Au if purchased in quantity. Like you, I was initially skeptical of the non "barbed" male hose fitting. However using the right sized ID hose, cut to the correct length and suppo rted, where appropriate, has resulted in 12 years/900hrs of no leaks, no in advertent detachments. One other benefit of the non barb, is that the possibility of tearing the i nside of the hose, when temporary removal is done, is eliminated. This then eliminates those troublesome little bits of "rubber" that may appear in yo ur float bowl. The H103WK has a built in 90 degree bend, making tight applications that wo uld benefit from this a breeze. -------- 46 Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D501885%23501885&data=04%7C01%7C%7C3 f6be0a3020e4c5f4dfd08d915bdceb2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0% 7C637564727224891711%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2 luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=D%2Bd67kxttQNtcXal% 2BdlU9Px5CUFJdL3emTo5b4v5hPw%3D&reserved=0 %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C3f6b e0a3020e4c5f4dfd08d915bdceb2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6 37564727224901704%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=b1BPzjeBYosZMV9jTqbMeK Oz%2F8q8%2BV0sBhJh1Vha%2FGU%3D&reserved=0 %2Fforums.matronics.com%2F&data=04%7C01%7C%7C3f6be0a3020e4c5f4dfd08d9 15bdceb2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637564727224901704%7C Unknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL CJXVCI6Mn0%3D%7C1000&sdata=ayKPY%2Bj0MmZm7xWJW2XZBtf0AHfrHwBN9K5U4lRZ M8k%3D&reserved=0 %2Fwiki.matronics.com%2F&data=04%7C01%7C%7C3f6be0a3020e4c5f4dfd08d915 bdceb2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637564727224901704%7CUn known%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=bsOVpHmgB5FyQ8CoXZnn0nT4p9MMXR2NjFtjAYOZ9J4% 3D&reserved=0 %2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C3f6be0a3020e4c5 f4dfd08d915bdceb2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637564727224 901704%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=3jgGJv8oSJMKkXIgdOb7bsaW6%2B%2BcK %2FdTS9sJolrVEtk%3D&reserved=0 ________________________________________________________________________________
Date: May 13, 2021
Just to expand the conversation and possibly take a lateral approach: Most people assume you must have a heat exchanger (coolant radiator and oil coolers) located at the front of the cowling, however I have seen several set ups (not Europa) where the heat exchangers are located in non traditional positions, such as above the engine, even in the warm exit air about to depart the cowling. The message; dont assume as far forward as possible, is the only location. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501907#501907 ________________________________________________________________________________
Date: May 13, 2021
Oh well "you can take a horse to water but cant make it drink" Just as a final comment: I first came across these filters being used, as prefilters, in Mercedes diesel cars/vans. I later found that many of the European LSA class aircraft makers also use them - quit a long way from a lawn mower. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501908#501908 ________________________________________________________________________________
Subject: Re: where to put OAT sensor?
Date: May 13, 2021
Has anyone considered the wheel well ? This space is out of the sun, there is lots of room and the wall I have inserted to stop mud going into the lower fuselage is flat on my aircraft, so perfect for mounting things to it by simply drilling a hole. I have to install several OAT senders due to installing two uAvionix AV30s which each require a separate OAT sender. Plus there is a third OAT sender for the Kanardia Airspeed indicator to give TAS. Would stray exhaust really be a problem here ? Regards Trevor -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501910#501910 ________________________________________________________________________________
Date: May 14, 2021
I am with Kingsley - subject to you having a large/deep enough vent -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501915#501915 ________________________________________________________________________________
Date: May 14, 2021
I tried that location and the temperature went up significantly when I ran the engine. I switched to the side air vent and that was perfect. Brian Davies -----Original Message----- From: owner-europa-list-server(at)matronics.com On Behalf Of trevord Sent: 14 May 2021 03:53 Subject: Europa-List: Re: where to put OAT sensor? Has anyone considered the wheel well ? This space is out of the sun, there is lots of room and the wall I have inserted to stop mud going into the lower fuselage is flat on my aircraft, so perfect for mounting things to it by simply drilling a hole. I have to install several OAT senders due to installing two uAvionix AV30s which each require a separate OAT sender. Plus there is a third OAT sender for the Kanardia Airspeed indicator to give TAS. Would stray exhaust really be a problem here ? Regards Trevor -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501910#501910 -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 14, 2021
The repositioning of the oil rad is called the tropical chin mod, heres the link for the UK LAA Mod http://www.lightaircraftassociation.co.uk/engineering/Standard%20Mods/11362%20Chin.pdf Hope this helps Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501918#501918 ________________________________________________________________________________
Date: May 14, 2021
Hi Griffo Im sure you did not mean to, but comments such as Oh well you can take a horse to water but cant make it drink" tend to come across as a bit of a put down because someone has failed to agree with you. It maybe you feel your own view / idea / suggestion is better than others, Im sure we all do from time to time which is why we all build our Europas slightly differently. But it is inappropriate to share that view on an open forum where the background of other contributors is unknown and all views should be welcomed. I hope we can avoid getting into my view is better than yours on this forum. Ultimately, it is for each reader to take away the information thats suits their preference and do what they will with it. There is a lot of knowledge and experience on this forum and as a novice flyer and builder, I have benefited enormously from people sharing their views and ideas without judgement. I would hate others to stop sharing for fear of having their views / ideas / and suggestions put down by inappropriate comments -------- Regards Kelv Weston Kit 497 kelv(at)kdweston.biz Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501919#501919 ________________________________________________________________________________
Date: May 14, 2021
Fwiw, agree :-) PeteZ C-GNPZ > On May 14, 2021, at 6:41 AM, Kelvin Weston wrote: > > > Hi Griffo > Im sure you did not mean to, but comments such as Oh well you can take a horse to water but cant make it drink" tend to come across as a bit of a put down because someone has failed to agree with you. > It maybe you feel your own view / idea / suggestion is better than others, Im sure we all do from time to time which is why we all build our Europas slightly differently. > But it is inappropriate to share that view on an open forum where the background of other contributors is unknown and all views should be welcomed. > I hope we can avoid getting into my view is better than yours on this forum. Ultimately, it is for each reader to take away the information thats suits their preference and do what they will with it. > There is a lot of knowledge and experience on this forum and as a novice flyer and builder, I have benefited enormously from people sharing their views and ideas without judgement. > I would hate others to stop sharing for fear of having their views / ideas / and suggestions put down by inappropriate comments > > -------- > Regards > > Kelv Weston > Kit 497 > kelv(at)kdweston.biz > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501919#501919 > > > > > > > > > ________________________________________________________________________________
Subject: Twisted fuselage, or?
From: "John Kirkgaard" <john.kirkegaard(at)gmail.com>
Date: May 14, 2021
It looks like I will need some very good advice from you fellow builders. I have measured the fixtures and torque tubes on my Europa a few times. Unfortunately I come to the same result in spite of using different methods. First I level up the fuselage making it 100% level in both directions. Then I measure down to the center of the pin hole forward wing pin bracket, on both sides. Using a horizontal laser-line. The elevation of the two wing fixings are found to be in exactly same level. Then measuring the level of the rear fixings shows that starboard wing pin socket is sitting 8 mm higher than the port one. The measuring the Flap tube I find that the Starboard side is also 9 mm higher than the port side. Going to the Tail plane Torque Tube I find the same picture there. And same for the foot wells. So the solution seems to be quite forward: change the position of the rear wing pin sockets, and ignore, that the fuselage will not be in level between the doors. But... During all measuring, the rudder is absolutely plumb. And my question to you guys: what will happen if I correct everything and leave the rudder approx. 10-11 mm out of plumb? Thanking in advance for any reply. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501923#501923 Attachments: http://forums.matronics.com//files/img_5202_275.jpg ________________________________________________________________________________
Subject: Re: Twisted fuselage, or?
Date: May 14, 2021
Hello John, Presumably this is the aircraft which you first saw in Canada? You've told me about these problems before, if I remember correctly. Were it not for covid 19 considerations, it might be useful for me to come over and give you a hand. Failing that, all that I can suggest is that perhaps we could have a Skype type of discussion while you point a camera at the problems. I think I understand your drawings, but it would be useful for me to see the problem areas "in real time" which might be almost as good as being there in person. Best wishes, Jonathan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501936#501936 ________________________________________________________________________________
Date: May 14, 2021
Hi Kelv/Peter Z, My apologies for any offence taken - certainly not intended. >From my point of view, the saying, should be read as - ideas can be put forward with the best of intentions/experience but not necessarily received/adopted as the need/will to do so is not apparent. Bear in mind, that my suggestion has also been likened unto a lawn mower fitting - put down? - possibly. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501939#501939 ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: May 14, 2021
Bud is enormously helpful to all of us and very generous with his time and I very much respect his advice. He is the most experienced among us having built many aircraft and guided many builders through the process, myself included. Without the encouragement of the forum and especially Bud I would not have achieved my wonderful aircraft. Will William Daniell LONGPORT +1 786 878 0246 On Fri, May 14, 2021 at 2:31 PM Griffo wrote: > > Hi Kelv/Peter Z, > > My apologies for any offence taken - certainly not intended. > > >From my point of view, the saying, should be read as - ideas can be put > forward with the best of intentions/experience but not necessarily > received/adopted as the need/will to do so is not apparent. > > Bear in mind, that my suggestion has also been likened unto a lawn mower > fitting - put down? - possibly. > > -------- > 46 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501939#501939 > > ________________________________________________________________________________
Date: May 14, 2021
Oh, knock it off guys. Everyone has opinions, likes, wants and prejudices. My feelings don=92t ge t hurt and neither should anyone else=92s. However, as in kindergarten, I was taught to stay in line, be nice, keep your hands to yourself and wait y our turn until it is your turn. I, like some others, just aren=92t always good at it. We may have strayed from the teaching of our past and one must try to get what he/she/person/co mrade wants or needs, and we don=92t want to get it without offending or mi sleading someone. Opinions/wants/prejudices are like butt holes, everyone has one, just keep it clean and don=92t abuse anyone else=92s. Techniques are just that, some one=92s technique, not a procedure. Let=92s keep being cheerleaders for on e another. Criticizing should be constructive and taken without offense. Persistently pursue the optimum aircraft for you, and all the 20,000 compro mises one makes building an aircraft, not persistently press your opinions on to others as the only way. I try to speak my piece, and Griffo and I should have gone off line as we ( well I) wandered around the plumbing issues of the Europa just clogging up the forum. My apologies for dragging it out. Best Regards, Bud Yerly From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of William Daniell Sent: Friday, May 14, 2021 5:47 PM Subject: Re: Europa-List: Re: Water Drain Bud is enormously helpful to all of us and very generous with his time and I very much respect his advice. He is the most experienced among us having built many aircraft and guided many builders through the process, myself i ncluded. Without the encouragement of the forum and especially Bud I woul d not have achieved my wonderful aircraft. Will William Daniell LONGPORT +1 786 878 0246 On Fri, May 14, 2021 at 2:31 PM Griffo > wrote: lto:scangriffin(at)bigpond.com.au>> Hi Kelv/Peter Z, My apologies for any offence taken - certainly not intended. >From my point of view, the saying, should be read as - ideas can be put f orward with the best of intentions/experience but not necessarily received/ adopted as the need/will to do so is not apparent. Bear in mind, that my suggestion has also been likened unto a lawn mower fi tting - put down? - possibly. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501939#501939 felinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fv iewtopic.php%3Fp%3D501939%23501939&data=04%7C01%7C%7C361e86c37a9d4b6c57ae 08d9172248ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63756625827926478 7%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=mMxkut5pCEIHFSJw47bvRh9TwboZs%2F78b3%2FMXc LqlHE%3D&reserved=0> pa-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?Europa-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 14, 2021
Well I for one like being the fly on the wall to people=99s conversati ons. Working months with Bud taught me a lot in the way of approaching a pro blem. But I still learn from other=99s conversations. You never know w hat you don=99t know until you know it. Mike Duane N377EA Europa XS conventional gear Jabiru 3300 powered Chandler, Arizona Sent from my iPhone > On May 14, 2021, at 4:49 PM, Bud Yerly wrote: > > =EF=BB > Oh, knock it off guys. > > Everyone has opinions, likes, wants and prejudices. My feelings don =99t get hurt and neither should anyone else=99s. However, as in kind ergarten, I was taught to stay in line, be nice, keep your hands to yourself and wait your turn until it is your turn. > I, like some others, just aren=99t always good at it. We may have s trayed from the teaching of our past and one must try to get what he/she/per son/comrade wants or needs, and we don=99t want to get it without offe nding or misleading someone. > > Opinions/wants/prejudices are like butt holes, everyone has one, just keep it clean and don=99t abuse anyone else=99s. Techniques are jus t that, someone=99s technique, not a procedure. Let=99s keep be ing cheerleaders for one another. Criticizing should be constructive and ta ken without offense. Persistently pursue the optimum aircraft for you, and a ll the 20,000 compromises one makes building an aircraft, not persistently p ress your opinions on to others as the only way. > > I try to speak my piece, and Griffo and I should have gone off line as we ( well I) wandered around the plumbing issues of the Europa just clogging up t he forum. My apologies for dragging it out. > > Best Regards, > Bud Yerly > > From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@mat ronics.com> On Behalf Of William Daniell > Sent: Friday, May 14, 2021 5:47 PM > To: europa-list(at)matronics.com > Subject: Re: Europa-List: Re: Water Drain > > Bud is enormously helpful to all of us and very generous with his time and I very much respect his advice. He is the most experienced among us having built many aircraft and guided many builders through the process, myself in cluded. Without the encouragement of the forum and especially Bud I would n ot have achieved my wonderful aircraft. > Will > > William Daniell > LONGPORT > +1 786 878 0246 > > > On Fri, May 14, 2021 at 2:31 PM Griffo wrote: > > Hi Kelv/Peter Z, > > My apologies for any offence taken - certainly not intended. > > >=46rom my point of view, the saying, should be read as - ideas can be pu t forward with the best of intentions/experience but not necessarily receive d/adopted as the need/will to do so is not apparent. > > Bear in mind, that my suggestion has also been likened unto a lawn mower f itting - put down? - possibly. > > -------- > 46 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501939#501939 > > > > > > > ========== > pa-List" rel="noreferrer" target="_blank">http://www.matronics.com/Nav igator?Europa-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: May 15, 2021
Trevor, My opinion is don't install it on the cowl itself as it is just another thing to slow down cowl removal. Keep it out of direct sunlight if you can. As for the wheel well: In the event of a tire failure or God Forbid a gear up landing, damage is done in the well. I tend to stay away from directly behind the XS cowl exit. Just avoiding the cowl exit air. The wheel well is a nasty hole for dirt and debris. In my opinion it will be slightly warmer than true outside air. (Disclaimer: I have no experience with the actual temperatures in the wheel well.) I've assisted clients in putting the OAT in several places. 1. My favorite is the inlet for the turbo duct. Radiator duct is a little too warm unless right up front. The inlet duct for the Turbo on the 914 metal shelf isn't bad. (Use caution and note on the ground it gets pretty warm. Works fine in flight provided it is on the outer most part of the duct and suspended in the stream.) I have 12AY's OAT in the 914 inlet suspended on a short bolt/spacer held by an Adel Clamp from the metal air dam. Works fine. (GRT and Blue Mtn.) 2. 912S located in the inlet attached to the airbox. (GRT) (Always make sure you mount it for an easy airbox removal or engine removal to facilitate maintenance.) 3. Cockpit inlet ducts of course if there is room as folks have said. Nice and close to the panel normally, so a short run. Dependent on inlet design. (Both Dynon's) 4. In the starboard wing root back before the flap tube just forward of the flap and behind the aft socket was popular for a while. We mounted it carefully to allow for the aux tank. (Dynon and GRT) 5. In the closeout for the Stabilator. (Caution not to impact the stab of course.) (Dynon) 6. Stuck out in the slipstream under the starboard seat was expedient for one client who insisted on it in the cockpit. He only had NACA inlets to the cockpit. Hard to wash the belly without hitting it though. (Dynon) 7. One guy has a ventilation tube plumbed from a NACA in the fin and piped into the overhead. He had his in the tube there just as the NACA entered the fin. (GRT) 8. Another was in the area below the starboard baggage bay inside but just aft of the flap tube where I didn't think it would work well, but air came in the flap slot and it actually worked OK. (GRT) It is an experimental. If it doesn't work, plug the hole and move it. The only way to tell is take separate temperatures. Use a handheld thermometer when in flight placed in your cockpit inlet to check your OAT placement for accuracy. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of trevord Sent: Thursday, May 13, 2021 10:53 PM Subject: Europa-List: Re: where to put OAT sensor? Has anyone considered the wheel well ? This space is out of the sun, there is lots of room and the wall I have inserted to stop mud going into the lower fuselage is flat on my aircraft, so perfect for mounting things to it by simply drilling a hole. I have to install several OAT senders due to installing two uAvionix AV30s which each require a separate OAT sender. Plus there is a third OAT sender for the Kanardia Airspeed indicator to give TAS. Would stray exhaust really be a problem here ? Regards Trevor -------- Trevor Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D501910%23501910&data=04%7C01%7C%7Ce3003334aa1248dbed7008d91684804c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637565580603988747%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=dGb27WR7BkqmODhqndSgb9%2BTmGil%2FJR4XSUNg4s07Go%3D&reserved=0 ________________________________________________________________________________
Date: May 14, 2021
To check your OAT location/reading; try obtaining one of those self contained digital indoor/outdoor thermometers or a fridge one. They usually come with a long lead for the outdoor thermocouple. Use a bit of double sided tape, to mount the "head/readout end in the cockpit. Gap or 100 mph tape to temporarily secure the external lead and thermocouple in the desired position. Works a treat - have even used one to check carburettor inlet temperatures. -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501951#501951 ________________________________________________________________________________
Date: May 15, 2021
Thanks Bud and Griffo - very much appreciated. All points taken - Sometimes it is really nice to think of lots of options... Sometimes you just want to know the correct way to do something - ha I have THREE OAT sensors to mount (two AV30s and a Kanardia airspeed indicator with TAS option) so I am thinking that I will just follow Buds option 1 and mount them on a bracket in front of the air inlet filter. One thing I have noticed on this forum, is that a "picture really is worth a thousand words" Like most, I am an amateur aircraft builder so sometimes the terms used I have to look up and then try to work out what the description means, whereas a photo you get an immediate ah-ha moment - provided you can see enough of the aircraft to work out where it is of course ! Thanks again for the input - much appreciated. Regards Trevor -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501952#501952 ________________________________________________________________________________
Date: May 15, 2021
Hi John As every aircraft is hand made I would expect there to be minor variances on just about every single aircraft. Changing the rear wing pin sockets is a big process particularly as it is attached to the internal cross tube which was added to increase the gross weight. MOD 52. I'd leave well alone and see how it flies. Other members with much more experience may be able to give a better reply such as Bud Yearly. Kind Regards Steve Ivell Mob: 07971 128842 E-mail: steveivell(at)pestproof.co.uk -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of John Kirkgaard Sent: 14 May 2021 13:49 Subject: Europa-List: Twisted fuselage, or? --> It looks like I will need some very good advice from you fellow builders. I have measured the fixtures and torque tubes on my Europa a few times. Unfortunately I come to the same result in spite of using different methods. First I level up the fuselage making it 100% level in both directions. Then I measure down to the center of the pin hole forward wing pin bracket, on both sides. Using a horizontal laser-line. The elevation of the two wing fixings are found to be in exactly same level. Then measuring the level of the rear fixings shows that starboard wing pin socket is sitting 8 mm higher than the port one. The measuring the Flap tube I find that the Starboard side is also 9 mm higher than the port side. Going to the Tail plane Torque Tube I find the same picture there. And same for the foot wells. So the solution seems to be quite forward: change the position of the rear wing pin sockets, and ignore, that the fuselage will not be in level between the doors. But... During all measuring, the rudder is absolutely plumb. And my question to you guys: what will happen if I correct everything and leave the rudder approx. 10-11 mm out of plumb? Thanking in advance for any reply. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501923#501923 Attachments: http://forums.matronics.com//files/img_5202_275.jpg ________________________________________________________________________________
Date: May 15, 2021
Steve and John, Sorry I missed your post John. Perhaps we should go off line to get into the nitty gritty. Many times it is how we level and how much can we fudge. I'd like to know some history on your build, Classic/XS then discuss. Email: budyerly(at)msn.com Leveling is a process. I use a piece of aluminum angle and it on the wing spar bolts out of the cockpit bulkhead and then set my 2 foot digital level on the angle. To compare, I set the digital level on the stab tube facing forward. Don't flip the level, it will most likely be slightly different. If the wing pins and stab tube are level. That is great. It is not uncommon to get the top on slightly askew. If the two wing pins and stab tubes are level within .5 degrees on a fully complete aircraft, I have to accept that. In the build, once cockpit module is set, I level to the wing pins in the back seat bulkhead. I then set my stab tube. The fuselage is flexible and once the tube is set it is necessary to use blocking/timbers to set the stab and wing pins dead even. Then put the top on and drop a plumb bob down the tail post. Cleco the top in place to get the tail vertical to the wings and stab tube. With the tailplanes blocked up, pull the clecos and glue the top up. Put the top on and I screw it down as you can read in my techniques area. On a salvaged Classic Kit to straighten up the plane (my 12AY was one of these) I replaced my stab tub bearings and releveled the tubes to the wing pins. On the Classic foam fin, it is tough to do but essentially, I cut the fin off carefully, then rebuild. It sounds awful but not much more than a couple days and a lot of dust. Then glue it up. Tape the joint line again and fill, fill, fill. The XS is a pain. There are remedies but I'm afraid all are somewhat painful. Again, it comes down to how you measure. Do I care if the area between the doors at the top is slightly off? Not really. People don't notice that. They notice when the fin is leaning in comparison to the wings and tailplane. Email me direct and we'll hopefully find an acceptable solution. Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Steve Ivell Sent: Saturday, May 15, 2021 5:58 AM Subject: RE: Europa-List: Twisted fuselage, or? Hi John As every aircraft is hand made I would expect there to be minor variances on just about every single aircraft. Changing the rear wing pin sockets is a big process particularly as it is attached to the internal cross tube which was added to increase the gross weight. MOD 52. I'd leave well alone and see how it flies. Other members with much more experience may be able to give a better reply such as Bud Yearly. Kind Regards Steve Ivell Mob: 07971 128842 E-mail: steveivell(at)pestproof.co.uk -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of John Kirkgaard Sent: 14 May 2021 13:49 Subject: Europa-List: Twisted fuselage, or? --> It looks like I will need some very good advice from you fellow builders. I have measured the fixtures and torque tubes on my Europa a few times. Unfortunately I come to the same result in spite of using different methods. First I level up the fuselage making it 100% level in both directions. Then I measure down to the center of the pin hole forward wing pin bracket, on both sides. Using a horizontal laser-line. The elevation of the two wing fixings are found to be in exactly same level. Then measuring the level of the rear fixings shows that starboard wing pin socket is sitting 8 mm higher than the port one. The measuring the Flap tube I find that the Starboard side is also 9 mm higher than the port side. Going to the Tail plane Torque Tube I find the same picture there. And same for the foot wells. So the solution seems to be quite forward: change the position of the rear wing pin sockets, and ignore, that the fuselage will not be in level between the doors. But... During all measuring, the rudder is absolutely plumb. And my question to you guys: what will happen if I correct everything and leave the rudder approx. 10-11 mm out of plumb? Thanking in advance for any reply. Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D501923%23501923&data=04%7C01%7C%7Caf4a62f5b0f84f5d2b3e08d917888978%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637566697452585737%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=bKNogrLOP9yd4%2FvetGVRHdHyhnUS7Z7uWvRClXF7RCI%3D&reserved=0 Attachments: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2F%2Ffiles%2Fimg_5202_275.jpg&data=04%7C01%7C%7Caf4a62f5b0f84f5d2b3e08d917888978%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637566697452595728%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=HvHem0nYjQd2D5jlfWLqk6iUY2OA0E8KGyT0eQC16jc%3D&reserved=0 ________________________________________________________________________________
Date: May 15, 2021
My two cents. My original solution was to install the original oil cooler under the spinner without a chin scoop. The client made no attempt to duct out the bottom. In a test it was fine so he flew like that for years until selling the plane. It worked better than behind the glycol cooler. The LAA mod is better as it allows for more room under the muffler for proper ducting. In "Cooling 102" for the Jabiru, I show a duct arrangement, I've had excellent results making the climb oil temps behave. A bit cool on cruise but 180 F in summer at 7500 feet is not unacceptable. It runs too cool in the winter without a plate on the front or better yet a cowl flap to control oil temp. Same idea can work in the Classic, but it is tight depending on your muffler arrangement. The same technique is used in the LAA mod for the inlet. Another thought: Creighton Smith (80 HP Classic) (crouton(at)well.com) uses a Lenovo glycol to oil cooler. He recommends the larger one. It plumbs into the glycol cooler 1 inch hose and oil lines and lies on the top of the engine in his Classic Mono. Not very heavy either. No cowl cutting. Oil and glycol temps run very similar and warm up is faster. On the hottest days, he will cruise climb at 90 Kts for ideal temps in the climb during summer. At high altitude cruise conditions, everything is steady about 200 ish Fahrenheit . His cowl exit is wider than usual to get better cooling in the Key West Florida summers. He cut off the third leg of the original Classic muffler and put on a single pipe exit to reduce back pressure on his 80 HP Rotax. Winter is the hard nut to crack in aircraft. His was no different. He uses tape to block his gills on the top cowl, tape across the radiators, and an in-flight adjustable plate across the cowl exit to block his air exit to try to keep it warm enough when temps are below freezing on start up and terribly cold at altitude when he is flying in Canada. You may wish to talk to him and get real data not just vague numbers. Talk to your inspector and make sure your country rules allow modifications. Talk to real users who have tried to solve the same issues. If you are in a hot climate, or are only a summer flier it makes a difference on what approach you take. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of michalm Sent: Thursday, May 13, 2021 2:48 AM Subject: Europa-List: Larger oil cooler - Classic Hello fellow Europa enthusiasts! I'm trying to solve the oil cooling issue in my 912 ULS powered Classic. I have the standard cooling setup with a 10 row oil cooler behind the port radiator and slightly enlarged cowl outlets. On hot days (30 C) and loaded to max weight I very quickly reach 120 C oil temp during a climb of just 2000 ft. If I let it cruise a bit it will go down to 115 C within a few minutes, 110 C if I reach cooler air higher up. The coolant stays below 90 C, except the climb phase where it reaches around 100 C. So far after reading your past discussions I came up with 2 possible solutions: 1. Moving the oil cooler below the spinner. 2. Installing an oil/water heat exchanger to supplement the oil cooler. The first is a bit invasive and as I'm not the original builder I don't feel fully confident to perform, yet. The second one is tempting but I thought about trying a simpler solution first: exchanging the oil cooler for a larger model. Mocal makes various sizes - the 13 row should fit without issues and perhaps the 16 row version will fit as well (if it can clear the exhaust pipe). Has anyone tried this approach? How effective this may be without enlarging the cowl outlets? According to charts on Mocal website I should expect a reduction of oil temp of around 8 C (16 row vs 10 row), but that assumes a free air flow which is most likely not the case inside the cowling. Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D501888%23501888&data=04%7C01%7C%7C9e51c87085a34c3c30fc08d915db7c8b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637564854688776163%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=dGdA2E7qpRdb%2BJD%2FzsVTW8heaM5Jf%2F861JLjs7ODJ%2F4%3D&reserved=0 ________________________________________________________________________________
Date: May 15, 2021
Steve. It doesn't matter too much what the level of the lift pin sockets are. What matters is the angle of incidence of the wings and also that the lift pins are securely fixed into the alloy plates embedded in the wing roots. Before contemplating moving anything you should measure the angle of incidence of both wings. (method in the builders' manual). They may be identical whilst the placing of the lift pins and lift pin sockets are not precisely the same in relation to the fuselage. The latter probably doesn't matter very much as long as the positioning of the lift pins is mot too far from the centre of those alloy plates. The rear lift pin socket should have been positioned married up with the previously fixed wing pin with the wings checked as having equal AOI. Regards, David Joyce, GXSDJ On 2021-05-15 10:57, Steve Ivell wrote: > > > Hi John > > As every aircraft is hand made I would expect there to be minor > variances on just about every single aircraft. > > Changing the rear wing pin sockets is a big process particularly as it > is attached to the internal cross tube which was added to increase the > gross weight. MOD 52. I'd leave well alone and see how it flies. > > Other members with much more experience may be able to give a better > reply such as Bud Yearly. > > Kind Regards > > Steve Ivell > Mob: 07971 128842 > E-mail: steveivell(at)pestproof.co.uk > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > On Behalf Of John Kirkgaard > Sent: 14 May 2021 13:49 > To: europa-list(at)matronics.com > Subject: Europa-List: Twisted fuselage, or? > > --> > > It looks like I will need some very good advice from you fellow > builders. > > I have measured the fixtures and torque tubes on my Europa a few times. > Unfortunately I come to the same result in spite of using different > methods. > > First I level up the fuselage making it 100% level in both directions. > Then I measure down to the center of the pin hole forward wing pin > bracket, on both sides. Using a horizontal laser-line. > The elevation of the two wing fixings are found to be in exactly same > level. > > Then measuring the level of the rear fixings shows that starboard wing > pin socket is sitting 8 mm higher than the port one. > > The measuring the Flap tube I find that the Starboard side is also 9 mm > higher than the port side. > > Going to the Tail plane Torque Tube I find the same picture there. > And same for the foot wells. > > So the solution seems to be quite forward: change the position of the > rear wing pin sockets, and ignore, that the fuselage will not be in > level between the doors. > > But... During all measuring, the rudder is absolutely plumb. And my > question to you guys: what will happen if I correct everything and > leave the rudder approx. 10-11 mm out of plumb? > Thanking in advance for any reply. > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501923#501923 > > Attachments: > > http://forums.matronics.com//files/img_5202_275.jpg > ________________________________________________________________________________
Date: May 15, 2021
My tail is 1cm lower on one side due i think to fuse twist despite measuring everything about a million times. It doesnt affect the flying characteristics. So it happens... Id echo david's comments. Maybe if your fuse is tilted as it were it doesnt matter provided the wings are the same incidence and structurally sound. William Daniell +1 786 878 0246 On Sat, May 15, 2021, 11:16 wrote: > Steve. It doesn=99t matter too much what the level of the lift pin sockets > are. What matters is the angle of incidence of the wings and also that th e > lift pins are securely fixed into the alloy plates embedded in the wing > roots. Before contemplating moving anything you should measure the angle of > incidence of both wings. (method in the builders=99 manual). They m ay be > identical whilst the placing of the lift pins and lift pin sockets are no t > precisely the same in relation to the fuselage. The latter probably doesn =99t > matter very much as long as the positioning of the lift pins is mot too f ar > from the centre of those alloy plates. The rear lift pin socket should ha ve > been positioned married up with the previously fixed wing pin with the > wings checked as having equal AOI. Regards, David Joyce, GXSDJ > > > On 2021-05-15 10:57, Steve Ivell wrote: > k > > > > Hi John > > As every aircraft is hand made I would expect there to be minor variances > on just about every single aircraft. > > Changing the rear wing pin sockets is a big process particularly as it is > attached to the internal cross tube which was added to increase the gross > weight. MOD 52. I'd leave well alone and see how it flies. > > Other members with much more experience may be able to give a better repl y > such as Bud Yearly. > > Kind Regards > > Steve Ivell > Mob: 07971 128842 > E-mail: steveivell(at)pestproof.co.uk > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com < > owner-europa-list-server(at)matronics.com> On Behalf Of John Kirkgaard > Sent: 14 May 2021 13:49 > To: europa-list(at)matronics.com > Subject: Europa-List: Twisted fuselage, or? > > --> > > It looks like I will need some very good advice from you fellow builders. > > I have measured the fixtures and torque tubes on my Europa a few times. > Unfortunately I come to the same result in spite of using different > methods. > > First I level up the fuselage making it 100% level in both directions. > Then I measure down to the center of the pin hole forward wing pin > bracket, on both sides. Using a horizontal laser-line. > The elevation of the two wing fixings are found to be in exactly same > level. > > Then measuring the level of the rear fixings shows that starboard wing pi n > socket is sitting 8 mm higher than the port one. > > The measuring the Flap tube I find that the Starboard side is also 9 mm > higher than the port side. > > Going to the Tail plane Torque Tube I find the same picture there. > And same for the foot wells. > > So the solution seems to be quite forward: change the position of the rea r > wing pin sockets, and ignore, that the fuselage will not be in level > between the doors. > > But... During all measuring, the rudder is absolutely plumb. And my > question to you guys: what will happen if I correct everything and leave > the rudder approx. 10-11 mm out of plumb? > Thanking in advance for any reply. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501923#501923 > > > Attachments: > > http://forums.matronics.com//files/img_5202_275bsp; --> > <http://forums.matronics.com//files/img_5202_275.jpg> > http://www.matronics.com/Nav=============== ======== > http://www.matronic================== = > > > <http://www.matronics.com/Navigator?Europa-List> > > ________________________________________________________________________________
Subject: Tool for Mod 71 - Nose gear leg change bungee with springs
Date: May 16, 2021
Hello, The club is supposed to have a tool to assist with the implementation of Mod 71. Has anybody seen it or know of its whereabouts? Photo attached as a memory jogger. We have a member who wishes to use it - please contact me asap if you have any information. Regards John Wighton mods(at)theeuropaclub.org -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501963#501963 Attachments: http://forums.matronics.com//files/mod_71_tool_122.jpg ________________________________________________________________________________
Date: May 17, 2021
Tim, your modification looks interesting and not very intrusive. Thanks for the photo. Bud, thank you for your detailed comments. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501980#501980 ________________________________________________________________________________
Date: May 18, 2021
I purchased a Classic recently here in Australia; it gets hot here in summer... really hot... the previous owner was experiencing higher than comfortable oil temperatures with the 912UL; especially while waiting for traffic during taxi and climb out; so he fitted an additional inline cooler off a 2001 BMW/Mercedes and mounted it to the firewall... short story, it worked, and was a simple solution with ample room and airflow to provide results... just ensure the additional oil lines are sufficiently protected from exhaust headers and muffler heat. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501995#501995 ________________________________________________________________________________
Subject: FEA Europa Tests
Date: May 18, 2021
Somebody recently mentioned there are Finite Analysis test results available for the Europa on the LAA website, however I cannot find any such information... Can anyone confirm this information actually exists? Thanks all[/b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501996#501996 ________________________________________________________________________________
Date: May 18, 2021
Hi Area-51 - As I said, the location of heat exchange units, need not be in the oh so conventional, forward location. My last aircraft had the oil cooler mounted, at a right angle, low on the firewall, in the exit air from cowling - worked very well. Did you purchase 19-4293? -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501997#501997 ________________________________________________________________________________
Date: May 18, 2021
Hi Griffo, yes, now custodian of John Bakers build and undertaking some improvements, starting with Mod77... there will be more improvements which I will post once theyre proven. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502007#502007 ________________________________________________________________________________
Date: May 18, 2021
Very far from being knowledgeable on Mod 77 (Europa in general) - just had a quick read through Mod 77- does not appear to be applicable to the Europa Classic - your aircraft? -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502008#502008 ________________________________________________________________________________
Subject: Re: FEA Europa Tests
Date: May 19, 2021
Dear Area 51, As you will know (you don't exist according to the US Govt until recently), that some things are virtual. However, I am aware of some original records (for the Europa and XS type approval) at the LAA and there may well be copies of our own stress analysis (inc FE analysis) and tests (dating back to the late 90's to date). David Stanbridge stated (at the Europa Tech Talk on 22 April 2021) that the BRS Mod would be stressed and submitted to the LAA on 3rd May. He also stated that the MTOW Mod to 1450lbs would be submitted on 21 May 2021 (this week). Maybe this is the FE/test data you refer to? It is really great that Europa is assisting the wider Europa community, David Stanbridge also stated that their 3D scanned external skin geometry files would be shared. This is great for those making Xplane models and also for the Europa Club, as it will make the documentation of future mods much clearer with the ability to use reference data for stress calcs etc. that interface with the OML. -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502014#502014 ________________________________________________________________________________
Date: May 19, 2021
My apologies Area 51 - it seems that if your Europa Classic has already had the the Mod 43 tail wheel upgrade, your aircraft may indeed benefit from Mod 77 -------- 46 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502015#502015 ________________________________________________________________________________
Date: May 19, 2021
Thanks for the clarity there John; much appreciated... looking forward to kitting the Europa out with a Williams turbine and Garmin G5000 in X-Plane and see what happens joining cross wind into Bangkok at Mach 0.8! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502016#502016 ________________________________________________________________________________
Subject: Re: Tool for Mod 71 - Nose gear leg change bungee with springs
Date: May 20, 2021
The tool has been found! Thank you. -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502020#502020 ________________________________________________________________________________
Subject: Re: The Europa Club VSWR Meter
Date: May 20, 2021
Rowland, Apologies for the delay in responding. Your offer is most welcome. I will email you separately for details. Regards JW -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502021#502021 ________________________________________________________________________________
Subject: Noseleg assembly NG01
Date: May 24, 2021
A bit of a random question. I have a noseleg assembly - NG01 (see the rear part of this in the attached image). Should I be able to disassemble this by sliding the sub assembly off the main tube or is this designed to be a friction fit and unmoveable without great effort? I'm concerned that there is corrosion between the outer noseleg tube and inner sleeves of the rear sub assembly, which is why I can't separate them to check, but maybe it's not designed to come apart? Thanks, Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502038#502038 Attachments: http://forums.matronics.com//files/img_0863_168.jpg http://forums.matronics.com//files/img_0863_145.jpg http://forums.matronics.com//files/img_0863_101.jpg ________________________________________________________________________________
Date: May 24, 2021
A bit of a random question. I have a noseleg assembly - NG01 (see the rear part of this in the attached image). Should I be able to disassemble this by sliding the sub assembly off the main tube or is this designed to be a friction fit and unmoveable without great effort? I'm concerned that there is corrosion between the outer noseleg tube and inner sleeves of the rear sub assembly, which is why I can't separate them to check, but maybe it's not designed to come apart? Thanks, Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502039#502039 Attachments: http://forums.matronics.com//files/img_0863_620.jpg ________________________________________________________________________________
Subject: Re: Noseleg assembly NG01
Date: May 24, 2021
If youre talking about the leg and the articulating frame, they should be a good fit with loctite to hold them together (from recent experience of replacing both on HI). > On 24 May 2021, at 15:21, flyingphil2 wrote: > > > A bit of a random question. > > I have a noseleg assembly - NG01 (see the rear part of this in the attached image). Should I be able to disassemble this by sliding the sub assembly off the main tube or is this designed to be a friction fit and unmoveable without great effort? > > I'm concerned that there is corrosion between the outer noseleg tube and inner sleeves of the rear sub assembly, which is why I can't separate them to check, but maybe it's not designed to come apart? > > Thanks, > > Phil > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502039#502039 > > > > > Attachments: > > http://forums.matronics.com//files/img_0863_620.jpg > > > > > > ________________________________________________________________________________
Subject: Re: UMA RPM gauge with Rotax 914
Date: May 26, 2021
Thank you Ron that is all very helpful. Installed wiring as per your information - we will see in many months if this works ! Best wishes all Regards Trevor -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502061#502061 ________________________________________________________________________________
Subject: Vents (again)
Date: May 27, 2021
Hello dear Europa forum members, First let me say I hit the 40hrs mark in my monowheel and so far its flying great. I will add though that learning to land the monowheel (in asphalt) has been a huge challenge. I can do perfect landings in gentle conditions but when not so gentle I am still quite apprehensive. But I admit I wasn't an experienced tailwheel pilot to start with and it just took a bit of time to get up to speed on the proper techniques to fly a TW aircraft, set aside the monowheel nuances. But I am getting there and haven't broken anything (yet). Now to the old subject of vents. First a little rant: Why in the world didn't Europa tell us where to put, in detail, a simple NACA vent? Yes I know, because us Europa builders are "The Few and The Brave" :) I intently read Bud Yerly's comments on vents which, as always very educational, but I really don't want to turn the installation of a vent into an experiment and poke 5 holes into my fuselage before I find a proper location for it. End of rant. Now, I know a lot of people liked the ultimate vent but not sure if the new version is currently available and not sure I want to spend the money for such nice vent (maybe I should). In any case I think that a design for a simple NACA vent, even if not ideal or ultimate, should be available for those of us with no pockets left (or sewn shut by our significant other). With that said, can I please get some feedback on those who have NACA vents that work well? I really could use detailed location and design dimensions. I also could use feedback on how you dealt with the thick(er) fuselage sandwich and the scoop LE lip. I want to follow Buds advice to not place it in the chord line but higher. A nice place would be right in the fuselage seam line but I think it would interfere with the removal of the cockpit module. Since my interior is already painted (yes, I know, big mistake) I would like to minimize how much I bugger up the interior surface so just making the NACA cutout, carving the foam off the edge, filling with flox and bonding a painted scoop inside with adhesive on its own flanges would be a clean solution. The exterior is still unpainted so no harm messing with that side of the fuselage wall. Thanks for the help. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502068#502068 ________________________________________________________________________________
Subject: De-Coupling Flaps & Outriggers
Date: May 27, 2021
Has anyone on the forum De-Coupled the Flaps & Outriggers on an XS Monowheel? If yes, can it be done after the aircraft has been built? If yes, what is involved? Thanks in advance James -------- Seat of my pants Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502071#502071 ________________________________________________________________________________
Subject: Re: De-Coupling Flaps & Outriggers
Date: May 27, 2021
This is an interesting topic which I am also interested. My interest is in that I am of the opinion that the monowheel could become easier to land in gusty or crosswind conditions if the flaps could be decoupled from the gear. How many airplanes have you flown out there where they recommend leaving full flaps when dealing with windy conditions? Now, in fairness to the design, I am very new to the monowheel and still learning. I may find that as I gain more experience it becomes more controllable during landing in such conditions. My issue is not directional control, it is that when the wind is gusty I can't make the airplane stay on the ground once I land. The combination of a light airplane with lots of lift and full flaps makes it want to get up in the air again even if speed is low. One thing to keep in mind though is that the flaps are only down 26 or so degrees so it's not too extreme. Seems enough though to give you a few nice scares when it gets back in the air when you really really slow. At the very least it's annoying. I guess one way to achieve that is to fix them in the down position but that's so ugly. I think I saw a picture of a monowheel out there that has them decoupled. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502072#502072 ________________________________________________________________________________
Date: May 27, 2021
Chris, Two suggestions to avoid bouncing: firstly hold off until the speed has decayed enough that you touch down tail wheel first. Effectively avoid putting the wheel on the ground, holding off just off the ground until the plane lands itself. If you touch down too fast the AOI is inevitably such that you touch main wheel first and you cannot avoid a bounce. Secondly if you have a reasonable amount of runway to play with you can touch down with the throttle slightly open and shut it at the point of touch down. I prefer the first of these approaches but it does take a while to get really comfortable with it. If you do decouple the flaps and gear, you have one extra thing to get wrong and will add considerably to your chances of landing wheels up when you find yourself stressed or distracted. Regards, David Joyce, GXSDJ On 2021-05-27 18:54, n7188u wrote: > > This is an interesting topic which I am also interested. > > My interest is in that I am of the opinion that the monowheel could > become easier to land in gusty or crosswind conditions if the flaps > could be decoupled from the gear. How many airplanes have you flown out > there where they recommend leaving full flaps when dealing with windy > conditions? > > Now, in fairness to the design, I am very new to the monowheel and > still learning. I may find that as I gain more experience it becomes > more controllable during landing in such conditions. My issue is not > directional control, it is that when the wind is gusty I can't make the > airplane stay on the ground once I land. The combination of a light > airplane with lots of lift and full flaps makes it want to get up in > the air again even if speed is low. > > One thing to keep in mind though is that the flaps are only down 26 or > so degrees so it's not too extreme. Seems enough though to give you a > few nice scares when it gets back in the air when you really really > slow. At the very least it's annoying. > > I guess one way to achieve that is to fix them in the down position but > that's so ugly. > > I think I saw a picture of a monowheel out there that has them > decoupled. > > Chris > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502072#502072 > ________________________________________________________________________________
Subject: Re: Vents (again)
Date: May 27, 2021
Hi Chris. My thoughts on vents. In My first Europa I fitted the "Ultimate Ventilator" They worked very well and as the vent opens into the airflow you can fit it where you like within reason. Ultimate Ventilator went out of business.. However Trevor Poulter has produced a far superior product. I would recommend you buy a set. Information on them is on the Europa Club web site. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502074#502074 ________________________________________________________________________________
Date: May 27, 2021
Thanks for the reply. I would inquire but the Europa Club web site says "Following a successful initial run of 20, a further batch is being considered, subject to interest." so it kind of sounds like it's not available right now. But I haven't really email to ask. But are NACA scoops really that bad in the Europa? RVs use them and my LongEZ has a tiny one that provides air to the entire cabin. Works really well! Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502075#502075 ________________________________________________________________________________
Date: May 28, 2021
Chris, Two comments: There is nothing wrong with the NACA duct. They work well. The only issue I have is they take room to install properly. They work great in conjunction with an air deflector or ball shut off, but it is somewhat long and protrudes into the cockpit. Properly ducted and maintainable, they are great. The only reason I liked the Ultimate ventilator was it is easy to install and is acceptable for use in the Europa lower windscreen and or side of the aircraft. Not perfect but it allowed me to have an easy to direct airflow into the cockpit that still sealed when at altitude with minimal effort. As far as Mono landings/decoupling the flaps and gear: David Joyce is spot on. Eric Trombley has a slick setup, but it is not retrofittable easily. He did much work to make it full proof. The mono is unique. It is not a tail dragger at all. It is a monocycle with a cheater wheel on the rear. Think of it as a conventional with stiff gear that are placed six inches apart. I wrote about my technique. Like David, I touch tailwheel first. If you cannot comfortably fly the plane into ground effect and hold it inches above the runway until the speed bleeds off and continue to slow until the tail wheel touches first, the landings can be sporty. The Europa has honest and light controls that allow the pilot to precisely fly the aircraft in formation with other aircraft and in formation with the runway. In my opinion, you must learn to slow flight precisely down the runway constantly correcting for the winds and turbulence while holding exact fuselage alignment with precise small rudder inputs until reaching the landing attitude (which is still above the stall I might add) until the nose has raised high enough to allow the plane to settle tail wheel first which will immediately drop the main wheel to the runway. Don't relax the stick. Keep the stick back and don't relax until in the chocks. Wheel landings are not an option. One must be patient with a fixed pitch prop set IAW the Rotax manual on a 912/914 engine. There is much float due to residual thrust in the flare with a fixed pitch cruise prop. This keeps your plane flying much longer than is normal (or tolerable in my opinion). Much has been discussed on this and some may approach as low as 55Knots. At 55Knots the plane is behind the power curve and only 10 knots above the stall when loaded. The sink is quite pronounced unless power is kept on. Once in the runway proximity, nose high, if the power is cut over a hard surface runway, it is very easy to drop in and if not in exact runway alignment, it can get sporty. Like many others, I'm comfortable with a 60 KIAS stabilized approach. Your inflight final approach RPM is normally still a high 22-2400 RPM even at idle. I put the nose on the aimpoint and pull a bit of power, if still on, to cross the threshold about 55 IAS and concentrate on maintaining runway alignment. I maintain a slow flight attitude as close to the runway as possible and retard any power remaining and patiently wait for the float to diminish and try to get a two point landing. If the main touches first I just keep flying the plane and keeping it straight until it finally settles. Never relax and keep flying through the rollout. A constant speed prop tends to cut out that painfully long float over a hot hard surfaced runway. The blades flatten and with an idle of about 1600-1800 static and allow a simple throttle retard and a smooth round out to the landing attitude. A fully finished airplane with a slick paint job has excellent slow flight characteristics so practice. Consider setting tire pressure to 16PSI to reduce bounce. Grass strips are more forgiving to land on. Less float and a bit softer bounce if any provided it is a smooth runway. Enough of my ramblings. You can read my paper on landing the mono on my website and on the Europa Club website. . Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of n7188u Sent: Thursday, May 27, 2021 5:22 PM Subject: Europa-List: Re: Vents (again) Thanks for the reply. I would inquire but the Europa Club web site says "Following a successful initial run of 20, a further batch is being considered, subject to interest." so it kind of sounds like it's not available right now. But I haven't really email to ask. But are NACA scoops really that bad in the Europa? RVs use them and my LongEZ has a tiny one that provides air to the entire cabin. Works really well! Chris Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D502075%23502075&data=04%7C01%7C%7Cc3dd7e1544874cf2ad0208d921560d90%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637577475746291041%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=QqanU2mLgrlajXYJTpLHqOvR0NRqfJzSc3SCe3Jcv%2B0%3D&reserved=0 ________________________________________________________________________________
Date: May 27, 2021
Mallard wrote: > Has anyone on the forum De-Coupled the Flaps & Outriggers on an XS Monowheel? > If yes, can it be done after the aircraft has been built? > If yes, what is involved? > > Thanks in advance > James I don't know if it can be easily done after completion (anything can be done with enough money and time!) but Justin Kennedy and Ted Gladstone did it during their build... Also don't know what is involved, sorry! HTH, Paul G-PLPM XS Mono 912ULS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502078#502078 Attachments: http://forums.matronics.com//files/g_zted_4_136.jpg ________________________________________________________________________________
Date: May 28, 2021
I converted my Mono to Trike and removing Flap lever/tube was easy! and fitting electric flap motor straight forward. Dave Park G-LDVO > On 28 May 2021, at 07:03, Paul M 383 wrote: > > > > Mallard wrote: >> Has anyone on the forum De-Coupled the Flaps & Outriggers on an XS Monowheel? >> If yes, can it be done after the aircraft has been built? >> If yes, what is involved? >> >> Thanks in advance >> James > > > I don't know if it can be easily done after completion (anything can be done with enough money and time!) but Justin Kennedy and Ted Gladstone did it during their build... > > Also don't know what is involved, sorry! > > HTH, > > Paul > G-PLPM > XS Mono 912ULS > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502078#502078 > > > > > Attachments: > > http://forums.matronics.com//files/g_zted_4_136.jpg > > > > > > ________________________________________________________________________________
Date: May 28, 2021
Just spent last week investigating this very question; it is possible, on paper at least... moving onto this task after first improving the retract system and getting rid of the bungee cord... secret squirrel business! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502080#502080 ________________________________________________________________________________
Date: May 28, 2021
Slightly curious here as to need, is this not trying to re invent the wheel? I only say so as a mono owner, in 12 years no replacement or adjustment needed. Also the single leaver action for gear/flaps/outriggers means less to forget! Sent from my iPhone > On 28 May 2021, at 12:26, Area-51 wrote: > > > Just spent last week investigating this very question; it is possible, on paper at least... moving onto this task after first improving the retract system and getting rid of the bungee cord... secret squirrel business! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502080#502080 > > > > > > > > > ________________________________________________________________________________
Date: May 28, 2021
Thanks for the advice guys. Question to the last poster: Have you found limitations related to cross country flying because of wind conditions with the standard mono? Not referring to those extremes when you have 20 knots direct crosswind. David, I am going to reply to Bud's message on my vents posting but in a nutshell: I am doing fantastic in low wind conditions. I can be so precise as to feel the tailwheel just skipping of the ground with the main still in the air. It's really neat and fun. It's when it gets bumpy that my precision goes out the door but yesterday I went out to practice with almost 10 knots of xwind (it gets bumpy in our field because of trees) and I did fine but was not holding the nose high enough. One go around out of four approaches. Getting there. Just trying to asses the true capabilities of the mono as a dependable xcountry machine. But not giving up on my pretty mono yet!! Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502082#502082 ________________________________________________________________________________
Subject: Re: Classic factory exhaust material?
Date: May 28, 2021
I got the idea about the problem you are facing about your exhaust as I faced the same problem some time ago. I contacted some dissertation writing services (https://www.rushmyessay.com/dissertation-writing-services/) which help me find the welding material for specific materials. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502083#502083 ________________________________________________________________________________
Date: May 28, 2021
Hi Bud and others, As always good advice. First let me say that I read your paper about landing the mono in great detail Bud. I did go out and practiced the low and slow flying exercise over the runway. It helped greatly. When the conditions are calm I am doing better than great. Extremely precise and I am able to land without bounce (tailwheel first) every time. I have learned that, yes, my bounces are directly related to touching down main first. My level of anxiety is certainly dropping as I get more experience (just frustrated at how long it's taking to get to that point). I do believe that I am OK now and could probably successfully land the mono under almost any conditions without breaking it. But can't help feeling certain level of anxiety when the winds comes up. BTW, talking to extremely experienced TW pilots here, they tell me it is simply that way when you fly taildraggers. They told me they are certainly a little less versatile than tri-gear airplanes when traveling and more planning is required. I have a friend with an TW RV-8 with nearly 4000 hrs in taildraggers and he doesn't fly when it gets too windy or gusty. The residual thrust is an issue but I am not going to consider a CS prop until I get more experience. For now I have found a good compromise that gives me plenty of climb power and decent true airspeed (around 115-120). Overall I am really enjoying the mono. But it does take patience and practice. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502084#502084 ________________________________________________________________________________
Date: May 28, 2021
Back to the vent topic, I hear you Bud that the one I have is fairly low profile. I will sent an email to inquire about the ultimate vent alternative and see what happens. But summer is catching up to me and the cockpit is starting to get a little hot (although I have an Arctic Cooler (picture attached) that haven't really tried yet in flight). It works though if you can get ice that is :) Not very practical but fun experiment (got it very cheap used). At what height do you recommend installing it? You mention not in line with the chord line of the wing. But is it ok right in the middle of the seam line or bellow it? Best Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502085#502085 Attachments: http://forums.matronics.com//files/arctic_cooler_2_689.jpg http://forums.matronics.com//files/arctic_cooler_1_124.jpg ________________________________________________________________________________
Date: May 28, 2021
Hi Chris, its a hoot indeed! almost as much fun as my hummelbird :-) This vid is with 15knots xwind from the left, gusty day, with tree rotors. Fun stuff. This is with about 100hrs on a mono. https://youtu.be/1Wmep_9O5QU fwiw, CHeers, Pete On Fri, May 28, 2021 at 9:34 AM n7188u wrote: > > Thanks for the advice guys. Question to the last poster: Have you found > limitations related to cross country flying because of wind conditions with > the standard mono? Not referring to those extremes when you have 20 knots > direct crosswind. > > David, I am going to reply to Bud's message on my vents posting but in a > nutshell: I am doing fantastic in low wind conditions. I can be so precise > as to feel the tailwheel just skipping of the ground with the main still in > the air. It's really neat and fun. It's when it gets bumpy that my > precision goes out the door but yesterday I went out to practice with > almost 10 knots of xwind (it gets bumpy in our field because of trees) and > I did fine but was not holding the nose high enough. One go around out of > four approaches. Getting there. > > Just trying to asses the true capabilities of the mono as a dependable > xcountry machine. But not giving up on my pretty mono yet!! > > Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502082#502082 > > ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: May 28, 2021
Does the arctic cooler actually work? Will William Daniell LONGPORT +1 786 878 0246 On Fri, May 28, 2021 at 10:11 AM n7188u wrote: > > Back to the vent topic, > > I hear you Bud that the one I have is fairly low profile. I will sent an > email to inquire about the ultimate vent alternative and see what happens. > But summer is catching up to me and the cockpit is starting to get a little > hot (although I have an Arctic Cooler (picture attached) that haven't > really tried yet in flight). It works though if you can get ice that is :) > Not very practical but fun experiment (got it very cheap used). > > At what height do you recommend installing it? You mention not in line > with the chord line of the wing. But is it ok right in the middle of the > seam line or bellow it? > > Best Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502085#502085 > > > Attachments: > > http://forums.matronics.com//files/arctic_cooler_2_689.jpg > http://forums.matronics.com//files/arctic_cooler_1_124.jpg > > ________________________________________________________________________________
Date: May 28, 2021
Will, It actually does. I tried it out in the sun, it was around 80 something and I locked the canopy. It kept the cockpit at a good temperature for 15 minutes, then the ice was gone. Keep in mind this is not just blowing air over the ice, it circulates the water in contact with the ice through a coil and then blows the air through the coil. So it doesn't add moisture. But also remember it's not a full blown AC so limited BTU. It did keep the cockpit at a nice fresh temperature. But I am not sure how practical it can be. For local flights sure. The idea is that you only use it on the ground and then turn it off in the air to save ice. But if you go on a breakfast trip, will de ice be there by the time you need it on the way back? The jury still out. I think it will probably be too much hassle and at some point it doesn't get used but I will try this summer. We all know how hot Florida can be :) Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502088#502088 ________________________________________________________________________________
Date: May 28, 2021
Nice landing Pete. Well, I'm still hopeful. As I said, not giving up yet! I got a collection of landing videos I have to put in YouTube. Let me see if I can this weekend. It seems that when the Europa flies everyone at my airport is making videos of me. Of course, my landings get worse proportional to the number of people watching me :) BTW, it does get a lot of attention here. People love watching it. Like a new girl in town :) Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502089#502089 ________________________________________________________________________________
Date: May 29, 2021
Subject: DOTH Sunday 30 May North Coates
Houlihan and I plan to go to N Coates tomorrow (S side of Humber Estuary) arriving around midday. Acclaimed as a 'great little airfield' with the 'best bacon butty south of the Humber' and a small museum, on Sky Demon. PPR needed. Hope to see some of you there. David Joyce, GXSDJ ________________________________________________________________________________
Date: May 29, 2021
Chris, I installed a NACA vent on the lower cowl on the port side (see picture below). The NACA feeds a 2=9D SCAT tube which ties into a plenum that feeds two eye ball vents in the center stack of the instrument pane l. The vents are fully adjustable and work extremely well, even in the hot desert southwest where I live. Erich N28ET Classic Mono 914 ____________________________________________________________ Choose to be safer online. Opt-in to Cyber Safety with NortonLifeLock. Get Norton 360 with LifeLock starting at $9.95/month.* https://store.netzero.net/account/showService.do?serviceId=nz-nLifeLoc k&utm_source=mktg&utm_medium=taglines&utm_campaign=nzlifelk_launch &utm_content=tag995&promoCode=A23457 ________________________________________________________________________________
Date: May 29, 2021
=EF=BBHello James, I de-coupled my flaps and outriggers during the initial build. That sai d, my outriggers are not stock, rather my own design that retract flush into the wings. I use a linear actuator to raise and lower the outrigge rs which are interlocked with the main gear. For the the flaps I insta lled the tri-gear flap motor which has worked well. The installation ca n be done as a retro fit, albeit with a lot of work. Below is a photo taken at Oshkosh. I had just taken off and was in the process of raising the gear and flaps when the photo was taken. Another second or so and the plane would have been cleaned up. Oh well, it =99s still a great photo. Erich Trombley N28ET Classic Mono 914 ____________________________________________________________ Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol& utm_campaign=rss_taglines_more Officials on San Jose Shooting: 'This Was a Planned Event' http://thirdpartyoffers.juno.com/TGL3131/60b251c4bf09051620197st04duc1 11-Year-Old Hit With Felony Charges in $30K Brush Fire http://thirdpartyoffers.juno.com/TGL3131/60b251c4e26d151620197st04duc2 Canadian Accused of Entering US With Interesting 'Undeclared' Items http://thirdpartyoffers.juno.com/TGL3131/60b251c51293051620197st04duc3 ________________________________________________________________________________
Date: May 29, 2021
=EF=BBHello James, I de-coupled my flaps and outriggers during the initial build. That sai d, my outriggers are not stock, rather my own design that retract flush into the wings. I use a linear actuator to raise and lower the outrigge rs which are interlocked with the main gear. For the the flaps I insta lled the tri-gear flap motor which has worked well. The installation ca n be done as a retro fit, albeit with a lot of work. Below is a photo taken at Oshkosh. I had just taken off and was in the process of raising the gear and flaps when the photo was taken. Another second or so and the plane would have been cleaned up. Oh well, it =99s still a great photo. Erich Trombley N28ET Classic Mono 914 ____________________________________________________________ Choose to be safer online. Opt-in to Cyber Safety with NortonLifeLock. Get Norton 360 with LifeLock starting at $9.95/month.* https://store.netzero.net/account/showService.do?serviceId=nz-nLifeLoc k&utm_source=mktg&utm_medium=taglines&utm_campaign=nzlifelk_launch &utm_content=tag995&promoCode=A23457 ________________________________________________________________________________
Date: May 29, 2021
Subject: Europa Monowheel - Cross Country Flying Machine
Hello Chris, You inquired about the utility of the Europa Monowheel as a cross countr y plane, specifically as it pertains to winds. In the eighteenth years of flying my Monowheel all over the United States I have never been grou nded due to high winds other than flying into my home field. I have lan ded the mono in some pretty strong and gusty winds flying in the desert southwest during the summer months. Gusts are certainly the biggest concern with the Europa or any other sma ll plane for that matter. Just last week we had a Piper Arrow crash on landing due to strong gusting winds. The pilot was flying into Las Vega s from Southern California. The plane was totaled. See photo below. I landed in similar conditions a couple of months ago. On the first lan ding I had just touched down when I was launched back into the air by a gust. The wind was 18 kts gusting 30 kts with a 50 degree crosswind fro m the right. Rather than try and save the landing I did a go-around. The tower ask me to state my intentions. I told him I would give it on e more try before heading to another field in the area with more favorab le wind conditions. Las Vegas is in a bowl with mountains surrounding the valley. Fortunately, we have a couple of airports on the other side of the mountains which make for good alternates which I have availed my self to on occasion (especially if the wife is on board as she hates the bumps). I came around for the second attempt and fought it all the way down to t he ground. The gusts were horrendous. I was jockeying the power like a fighter pilot making a carrier landing. I was carrying quite a bit of power when I crossed the threshold. Flying just a foot or so off the ru nway I chopped the power and set the plane down. I am sure it wasn =99t pretty but I did get her landed. The tower commented on the gusty conditions and I responded, =9CI think I found the limits of the plane.=9D I have landed in steady winds up to 35 kts with varying crosswinds. I l and using the crab technique, kicking out the tail and lining up with th e centerline during the flare and aileron to control drift. If I can st raighten out the plane with the rudder on short final I will attempt the landing. If not, then I am landing at another airport. BTW, I make al l my landings with full flaps regardless of the winds. I do, however, t ake off with partial flaps though. The Europa is a marvelous cross country plane and I wouldn=99t hes itate taking it anywhere. That=99s not to say I don=99t ta ke the weather and winds into consideration, I do. In fact, I have have made plenty of unplanned layovers due to weather. It=99s the old adage, =9CIf you fly by air, have time to spare.=9D The Eu ropa has its limitations just like any other small plane. Plan accordi ngly. Blue skies, Erich Trombley N28ET Classic Mono 914 ____________________________________________________________ Choose to be safer online. Opt-in to Cyber Safety with NortonLifeLock. Get Norton 360 with LifeLock starting at $9.95/month.* https://store.netzero.net/account/showService.do?serviceId=nz-nLifeLoc k&utm_source=mktg&utm_medium=taglines&utm_campaign=nzlifelk_launch &utm_content=tag995&promoCode=A23457 ________________________________________________________________________________
Subject: Lifted aircraft nose.
From: "John Kirkgaard" <john.kirkegaard(at)gmail.com>
Date: May 29, 2021
I have found that the previous owner of my Canadian imported Europa XS have extended the vertical nose wheel spindle 50 mm and installed a 50 mm spacer. That means that the nose is lifted 50 mm up leaving the plane in a more nose up attitude when it's on the ground, and off course the wings in a higher AOA. It's probable done to give more prop clearance for the 68" Woodcomp 3000/2 propeller. Have anyone of you had experience with the behavior of the aircraft during take off and landing with the nose gear lowered this 50 mm. I can't really see if it matters or not. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502102#502102 ________________________________________________________________________________
Date: May 29, 2021
Ah the longer prop is better modification. If you retain the Woodcomp at 68 inches you will cut off the back of wheel pant if you pull it backwards and run the prop/engine on the ground. By adding a 50mm to the spindle and a spacer, he may have changed the geome try of the antifriction plate to the horizon. This angles the spindle back and changes the castor angle and the shimmy dampener is slightly affected. You will just have to flare completely to prevent banging down on the nosew heel first. With full flaps and attempting to stick the plane on to the ru nway above a normal landing speed of 45-50 KIAS you will most likely hit th e nose wheel first and porpoise. Not good for any aircraft. >From an inspection standpoint I would say pay attention to the shimmy dampe ner plastic plate for uneven wear, and your bolts going through the gear le g for looseness and elongation. IF the bolts loosen, remove them, and chec k the holes have not become elongated or the bolts necked down from wear. Increasing the ground clearance by jacking the nose up is normally not done . Today=92s composite propeller manufacturers gain very little in increasi ng the blade length beyond 67 inches on a Rotax except for STOL operations. The loss in cruise speed between a 68 to 70 inch Whirlwind and a 64 inch Whirlwind is about one knot at cruise and takeoff distance is not affected in the constant speed prop as the added pitch accelerates about equally. I n STOL aircraft, a longer blade means a bit shorter takeoff but absolutely a very much lower top end. In a glass airplane, like the Europa or Lancair 235, cruise speed difference between a 68 and 64 doesn=92t matter. It is the pitch/twist of the blade on a fixed pitch and on a constant speed prop, the pitch is in the hub. See my website for selecting a propeller for you r Rotax engine. Just my opinion, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of John Kirkgaard Sent: Saturday, May 29, 2021 1:15 PM Subject: Europa-List: Lifted aircraft nose. com> I have found that the previous owner of my Canadian imported Europa XS have extended the vertical nose wheel spindle 50 mm and installed a 50 mm s pacer. That means that the nose is lifted 50 mm up leaving the plane in a more nose up attitude when it's on the ground, and off course the wings in a hig her AOA. It's probable done to give more prop clearance for the 68" Woodcomp 3000/2 propeller. Have anyone of you had experience with the behavior of the aircraft during take off and landing with the nose gear lowered this 50 mm. I can't really see if it matters or not. Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D502102%23502102&data=04%7C01%7C%7C7 0df12b2d5b3432ac5fd08d922c8d58b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0% 7C637579068230703619%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2 luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=7xuB8QGN5OfDerzNtqP PDZLG%2BzLXy4rTEoSHJrpBB8M%3D&reserved=0 %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C70df 12b2d5b3432ac5fd08d922c8d58b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6 37579068230703619%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=qqh14PAXhvOjpcE5BO9c2T E3fVjAn35AbInDwUG2aCQ%3D&reserved=0 %2Fforums.matronics.com%2F&data=04%7C01%7C%7C70df12b2d5b3432ac5fd08d9 22c8d58b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637579068230703619%7C Unknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL CJXVCI6Mn0%3D%7C1000&sdata=jWwylGTWeFladaDs5YmSPHhByBrL67EzvlVAYgK2dw 4%3D&reserved=0 %2Fwiki.matronics.com%2F&data=04%7C01%7C%7C70df12b2d5b3432ac5fd08d922 c8d58b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637579068230703619%7CUn known%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=DTlFuv%2BYw%2B0NoJF%2FSf16hZkvyzfaGZiTWs7XBb y%2FL%2Bs%3D&reserved=0 %2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C70df12b2d5b3432 ac5fd08d922c8d58b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637579068230 713614%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=VMcT5Tp0IgQpA%2FWY4cqGTxciQ5idMFe 22e6mpWtKh3o%3D&reserved=0 ________________________________________________________________________________
Subject: Re: Europa Monowheel - Cross Country Flying Machine
Date: May 30, 2021
Great comments Erich. I can stand by everything you have said. Meet up again next Oshkosh, if planned to go ahead, and I have been vaccinat ed! Cheers, Tim Sent from my iPad Tim Ward 12 Waiwetu Street, Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz 021 0640221 > On 30/05/2021, at 4:10 AM, Erich Trombley wrote: > > =EF=BBHello Chris, > > You inquired about the utility of the Europa Monowheel as a cross country p lane, specifically as it pertains to winds. In the eighteenth years of flyi ng my Monowheel all over the United States I have never been grounded due to high winds other than flying into my home field. I have landed the mono in some pretty strong and gusty winds flying in the desert southwest during th e summer months. > > Gusts are certainly the biggest concern with the Europa or any other small plane for that matter. Just last week we had a Piper Arrow crash on landin g due to strong gusting winds. The pilot was flying into Las Vegas from Sou thern California. The plane was totaled. See photo below. > > I landed in similar conditions a couple of months ago. On the first landi ng I had just touched down when I was launched back into the air by a gust. The wind was 18 kts gusting 30 kts with a 50 degree crosswind from the righ t. Rather than try and save the landing I did a go-around. The tower ask me to state my intentions. I told him I would give it one more try before h eading to another field in the area with more favorable wind conditions. L as Vegas is in a bowl with mountains surrounding the valley. Fortunately, w e have a couple of airports on the other side of the mountains which make fo r good alternates which I have availed myself to on occasion (especially if t he wife is on board as she hates the bumps). > > I came around for the second attempt and fought it all the way down to the ground. The gusts were horrendous. I was jockeying the power like a fight er pilot making a carrier landing. I was carrying quite a bit of power when I crossed the threshold. Flying just a foot or so off the runway I chopped the power and set the plane down. I am sure it wasn=99t pretty but I did get her landed. The tower commented on the gusty conditions and I resp onded, =9CI think I found the limits of the plane.=9D > > I have landed in steady winds up to 35 kts with varying crosswinds. I lan d using the crab technique, kicking out the tail and lining up with the cent erline during the flare and aileron to control drift. If I can straighten o ut the plane with the rudder on short final I will attempt the landing. If n ot, then I am landing at another airport. BTW, I make all my landings with f ull flaps regardless of the winds. I do, however, take off with partial fla ps though. > > The Europa is a marvelous cross country plane and I wouldn=99t hesit ate taking it anywhere. That=99s not to say I don=99t take the weather and winds into consideration, I do. In fact, I have have made plen ty of unplanned layovers due to weather. It=99s the old adage, =9CIf you fly by air, have time to spare.=9D The Europa has its limit ations just like any other small plane. Plan accordingly. > > Blue skies, > Erich Trombley > N28ET Classic Mono 914 > > ____________________________________________________________ > Choose to be safer online. > Opt-in to Cyber Safety with NortonLifeLock. > Get Norton 360 with LifeLock starting at $9.95/month.* > https://store.netzero.net/account/showService.do?serviceId=nz-nLifeLock& utm_source=mktg&utm_medium=taglines&utm_campaign=nzlifelk_launch&utm_c ontent=tag995&promoCode=A23457 > ________________________________________________________________________________
Subject: How to disconnect flap actuator from FL26
From: "Chris Callicott" <c.callicott1(at)btinternet.com>
Date: May 29, 2021
Hi, l I need to replace my electric flap actuator, ie both motor and lead screw assembly. However, the mounting bracket FL26 is bonded and bolted to the fuselage floor (Build manual 28T). Removal of the AN4-23 bolt is not possible owing to location of the baggage bay supporting structure. Please advise how to remove the existing actuator. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502107#502107 ________________________________________________________________________________
Date: May 30, 2021
Chris, In the XS you probably have batteries, or ELT equipment and of course rudde r cables nearby the servo floor attachment. It is highly likely that no provision or access panel has been made over th e flap actuator in the baggage bay floor or through the floor supports. This is a travesty of failure to plan for future maintenance and proper eng ineering I=92m afraid, and is done for expedient construction in the manual . Of course in some countries this may be a major modification and one has to go to the approving authority or be approved by an inspector. Do so. In a stock XS: Remove the cotter pin and nut. Use a cloth or something as a dam to preven t loss of the spacers/washers when ready to pull the AN 4-23 bolt. Failure to do this may result in hours of hunting for parts dropped. Procure an angle drill and small hole saw or similar to simply bore through the wood support to gain sufficient clearance to remove the bolt outboard. Disconnect the linear drive actuator from the flap bar and unplug/disconnec t the wiring. Again, standing on one=92s head in the baggage bay, reach in and undo the b olt connecting the actuator to the flap cross bar using appropriate sockets and extension, mirrors, lights and patience. I prefer to do this with the wings off and use an assistant to peer through the flap tube arcs in the fuselage side and hand me tools. Installation is as frustrating as removal. I always make a plug for my flap drive for troubleshooting and maintenance. These linear drives rarely fail, but can. "If you make it convenient to maintain, easy to access, it seems it will ne ver fail." Below is how I do my baggage bay floors to assure access. Normally a 4 inc h hole in the floor and the hole in one of the ribs is done during construc tion only as needed to gain access and provide a viewing hole. Ensure your country modification procedures are followed. In the US I simp ly made sure I had access. If you make a hole in an airplane or support, o ne must assure the reinforcement is as structurally sound. Bud Yerly [Diagram Description automatically generated] -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of Chris Callicott Sent: Saturday, May 29, 2021 6:54 PM Subject: Europa-List: How to disconnect flap actuator from FL26 et.com> Hi, l I need to replace my electric flap actuator, ie both motor and lead screw assembly. However, the mounting bracket FL26 is bonded and bolted to the f uselage floor (Build manual 28T). Removal of the AN4-23 bolt is not possibl e owing to location of the baggage bay supporting structure. Please advise how to remove the existing actuator. Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D502107%23502107&data=04%7C01%7C%7C9 623b238d35c43c3a8f008d922f5277d%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0% 7C637579258582850019%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2 luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=k0Na6IakXfRfJvmjAhN GYmfd0Im1JNd8EUy%2BPRd%2Ff0k%3D&reserved=0 %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C9623 b238d35c43c3a8f008d922f5277d%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6 37579258582860013%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=fI1qejVvYV1USFmN3r1c7e MA5eok1RVbdfsDney%2BvYc%3D&reserved=0 %2Fforums.matronics.com%2F&data=04%7C01%7C%7C9623b238d35c43c3a8f008d9 22f5277d%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637579258582860013%7C Unknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL CJXVCI6Mn0%3D%7C1000&sdata=5bUiCjnPt%2FmxkxUb3H%2FW38ku2ZLJLzPChfjVPK s%2F7G8%3D&reserved=0 %2Fwiki.matronics.com%2F&data=04%7C01%7C%7C9623b238d35c43c3a8f008d922 f5277d%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637579258582860013%7CUn known%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=giDkDPAzA9vUAuRPX3sBOvnkeguvdCbbgVnGtnbg%2Bm 8%3D&reserved=0 %2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C9623b238d35c43c 3a8f008d922f5277d%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637579258582 860013%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=qZQc9GFm8w6xzGP%2B6AVO4XOzY06rPiW PAHdd276JjAQ%3D&reserved=0 ________________________________________________________________________________
Subject: Re: How to disconnect flap actuator from FL26
Date: May 30, 2021
Hi Bud, Thanks for your response. I concur with your views. I am on the final lap of a 2 year restoration when the actuator failed on a shakedown flight. I may have to drill a hole in one of the baggage bay support panels in order to remove the AN4-23 bolt from FL26. This may allow me to change to motor and retain the existing lead screw. If I can access the other end of the lead screw with the wings and flaps removed from the fuselage, I will swap out the complete actuator. I would appreciate your view on whether or not this is possible. Many thanks for your notes, published on the Europa Club site. They have already been hugely helpful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502128#502128 ________________________________________________________________________________
Subject: Re: Lifted aircraft nose.
Date: May 30, 2021
Thanks to you Bud, for your reply. I checked the bolts through the nose leg a while ago, and found the bolts to be damaged and the holes elongated. I have enlarged the bolt holes reamed them to match some new shoulder bolts and making sure that there is a very tight fit. The nylon friction disc seems to be worn even. Seems like it is possible to make acceptable landings if I just take care. Turning the nose wheel 180 degree will result in a distance of 80 mm between the prop tip and the top of the wheel spat. Not much space for movement if I lover it 50 mm, but on the other hand, if I turn the the wheel backwards I may not be in a situation where the plane is moving up and down. During start I could imagine, that the plane will try to get into the air, despite insufficient air speed. Could that be the situation? Regards John Kirkegaard Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502131#502131 ________________________________________________________________________________
Date: May 30, 2021
Well John sounds like you have it under control. As I said, it is important to make sure you flare it out to preserve the nose gear from hitting first. As far as cutting the nosewheel pant when turned 180 degrees with the prop, if doing a static ground run at full power the nose can compress the nose down (more so with the bungee rather than the springs) and perhaps reduce the clearance between prop and pant. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of John Kirkgaard Sent: Sunday, May 30, 2021 3:54 PM Subject: Europa-List: Re: Lifted aircraft nose. Thanks to you Bud, for your reply. I checked the bolts through the nose leg a while ago, and found the bolts to be damaged and the holes elongated. I have enlarged the bolt holes reamed them to match some new shoulder bolts and making sure that there is a very tight fit. The nylon friction disc seems to be worn even. Seems like it is possible to make acceptable landings if I just take care. Turning the nose wheel 180 degree will result in a distance of 80 mm between the prop tip and the top of the wheel spat. Not much space for movement if I lover it 50 mm, but on the other hand, if I turn the the wheel backwards I may not be in a situation where the plane is moving up and down. During start I could imagine, that the plane will try to get into the air, despite insufficient air speed. Could that be the situation? Regards John Kirkegaard Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D502131%23502131&data=04%7C01%7C%7Caa033b985aa347c2ee4608d923a53f54%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637580014900963647%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=HH25YxuPi8gzjzQjO1AnN5qIJziKO4OjzIFFupvoDD8%3D&reserved=0 ________________________________________________________________________________
Date: May 30, 2021
Chris, I have not changed out the motor in the XS actuator I'm afraid. The manufacturers name is on the motor normally and if you can read it, they can supply the info. On my Motion industries linear actuator I bought a kit from them with new brushes and it was fairly easy to repair. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Chris Callicott Sent: Sunday, May 30, 2021 1:54 PM Subject: Europa-List: Re: How to disconnect flap actuator from FL26 Hi Bud, Thanks for your response. I concur with your views. I am on the final lap of a 2 year restoration when the actuator failed on a shakedown flight. I may have to drill a hole in one of the baggage bay support panels in order to remove the AN4-23 bolt from FL26. This may allow me to change to motor and retain the existing lead screw. If I can access the other end of the lead screw with the wings and flaps removed from the fuselage, I will swap out the complete actuator. I would appreciate your view on whether or not this is possible. Many thanks for your notes, published on the Europa Club site. They have already been hugely helpful. Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D502128%23502128&data=04%7C01%7C%7C73ab1fc53f8f437cfdbb08d92394683c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637579942569719708%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=c7w3vevaAjfqtacnVRHLxCjGr62e150P%2FyE%2BXXMHU8M%3D&reserved=0 ________________________________________________________________________________
Date: May 30, 2021
Thanks once again Bud. I will follow up on a repair kit. BW, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502135#502135 ________________________________________________________________________________
Date: May 30, 2021
Hi Tim, Good to hear from you. Yes, lets meet up at OSH. So looking forward to the event. I flew to SNF this year which was a great primer for OSH. Cheers, Erich > > From: timward <ward.t(at)xtra.co.nz> > Subject: Re: Europa-List: Europa Monowheel - Cross Country Flying Machine > > Great comments Erich. I can stand by everything you have said. > Meet up again next Oshkosh, if planned to go ahead, and I have been vaccinat > ed! > Cheers, > Tim > > Sent from my iPad > Tim Ward > 12 Waiwetu Street, > Fendalton, > Christchurch, 8052 > New Zealand. > ward.t(at)xtra.co.nz > 021 0640221 ____________________________________________________________ Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more Christian Diet Guru, 6 Others Die When Plane Goes Into Lake http://thirdpartyoffers.juno.com/TGL3131/60b41c049c2cd1bf95ba6st04vuc1 Tensions Shake Commemoration of Tulsa Race Massacre http://thirdpartyoffers.juno.com/TGL3131/60b41c04bf7561bf95ba6st04vuc2 Poll: 23% of Republicans Are QAnon Believers http://thirdpartyoffers.juno.com/TGL3131/60b41c04e316d1bf95ba6st04vuc3 ________________________________________________________________________________
Date: May 30, 2021
Lucky Guys! Ill be watching online, as borders still closed and no second vax before aug. ill be there in spirit tho! Have a blast! PeteZ :) > On May 30, 2021, at 7:21 PM, Erich Trombley wrote: > > > Hi Tim, > > Good to hear from you. Yes, lets meet up at OSH. So looking forward to the event. I flew to SNF this year which was a great primer for OSH. > > Cheers, > Erich > >> >> From: timward <ward.t(at)xtra.co.nz> >> Subject: Re: Europa-List: Europa Monowheel - Cross Country Flying Machine >> >> Great comments Erich. I can stand by everything you have said. >> Meet up again next Oshkosh, if planned to go ahead, and I have been vaccinat >> ed! >> Cheers, >> Tim >> >> Sent from my iPad >> Tim Ward >> 12 Waiwetu Street, >> Fendalton, >> Christchurch, 8052 >> New Zealand. >> ward.t(at)xtra.co.nz >> 021 0640221 > > ____________________________________________________________ > Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more > > Christian Diet Guru, 6 Others Die When Plane Goes Into Lake > http://thirdpartyoffers.juno.com/TGL3131/60b41c049c2cd1bf95ba6st04vuc1 > Tensions Shake Commemoration of Tulsa Race Massacre > http://thirdpartyoffers.juno.com/TGL3131/60b41c04bf7561bf95ba6st04vuc2 > Poll: 23% of Republicans Are QAnon Believers > http://thirdpartyoffers.juno.com/TGL3131/60b41c04e316d1bf95ba6st04vuc3 > > > > ________________________________________________________________________________
Date: May 31, 2021
Sent from my iPhone > On 31 May 2021, at 9:21 am, Erich Trombley wrote: > > > Hi Tim, > > Good to hear from you. Yes, lets meet up at OSH. So looking forward to the event. I flew to SNF this year which was a great primer for OSH. > > Cheers, > Erich > >> >> From: timward <ward.t(at)xtra.co.nz> >> Subject: Re: Europa-List: Europa Monowheel - Cross Country Flying Machine >> >> Great comments Erich. I can stand by everything you have said. >> Meet up again next Oshkosh, if planned to go ahead, and I have been vaccinat >> ed! >> Cheers, >> Tim >> >> Sent from my iPad >> Tim Ward >> 12 Waiwetu Street, >> Fendalton, >> Christchurch, 8052 >> New Zealand. >> ward.t(at)xtra.co.nz >> 021 0640221 > > ____________________________________________________________ > Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more > > Christian Diet Guru, 6 Others Die When Plane Goes Into Lake > http://thirdpartyoffers.juno.com/TGL3131/60b41c049c2cd1bf95ba6st04vuc1 > Tensions Shake Commemoration of Tulsa Race Massacre > http://thirdpartyoffers.juno.com/TGL3131/60b41c04bf7561bf95ba6st04vuc2 > Poll: 23% of Republicans Are QAnon Believers > http://thirdpartyoffers.juno.com/TGL3131/60b41c04e316d1bf95ba6st04vuc3 > > > > ________________________________________________________________________________
Subject: Airfoil Profiles
Date: May 30, 2021
Can anyone on the forum tell me what main wing and tailplane profiles are used on the Europa? Thanks in advance... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502141#502141 ________________________________________________________________________________
Date: May 31, 2021
Subject: Re: Airfoil Profiles
That info is in the excellent booklet(s) by Don Dykin, which I could possibly be persuaded to send you a copy of. Where are you? David Joyce, GXSDJ On 2021-05-31 03:54, Area-51 wrote: > > > Can anyone on the forum tell me what main wing and tailplane profiles > are used on the Europa? Thanks in advance... > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502141#502141 > ________________________________________________________________________________
Date: May 31, 2021
Thanks David, searched for Dykin and found some info on the clubs website; will have a read and see if it provides the information Im after! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502148#502148 ________________________________________________________________________________
Date: May 31, 2021
Cut a hole in the baggage bay support to allow access to the bolt. It's onl y plywood supported by fibreglass so a couple of small holes wouldn't be a problem. Kind Regards Steve Ivell Managing Director Pestproof Ltd. 07971 128842 ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of Chris Callicott Sent: Saturday, May 29, 2021 11:53:39 PM Subject: Europa-List: How to disconnect flap actuator from FL26 et.com> Hi, l I need to replace my electric flap actuator, ie both motor and lead screw assembly. However, the mounting bracket FL26 is bonded and bolted to the f uselage floor (Build manual 28T). Removal of the AN4-23 bolt is not possibl e owing to location of the baggage bay supporting structure. Please advise how to remove the existing actuator. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502107#502107 ________________________________________________________________________________
Date: May 31, 2021
Many thanks Steve. Wilco! KR, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502153#502153 ________________________________________________________________________________
Subject: Flap limiting speed 83 kts exceeded
Date: May 31, 2021
One of our group members got distracted during climb out after take off, while the flaps remained extended to 18 degrees. Shortly his speed reached or slightly surpassed 100 knots, so the exceedance was about 20 knots before he quickly stowed the flaps. After carefully examining all the flap hinge plates, the fibre-glass surrounding where they are embedded, hinges inside the fuselage and surrounding structure, flap root pins and the flap root structure generally, flap push-pull rod and lever, no evidence of damage could be found. Subsequent flight confirmed that the flaps seem to be in perfect working order. It also seems that the whole construction is commendably robust. So my questions are "How is the flap limiting speed determined by the designer and what if any factor is allowed in calculations for possible overloads?" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502160#502160 ________________________________________________________________________________
Date: May 31, 2021
Read both of the Dykin writings. They are very informative, however neither provide the information being sought... Specifically searching for actual airfoil profiles employed on the Europa; profile plotting data in excel spread sheet, CSV coordinates, or title tag of airfoil. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502162#502162 ________________________________________________________________________________
Date: May 31, 2021
No doubt you've read the PilotFriend flight test report http://www.pilotfriend.com/flight_reports/reports/18e.htm. At the end under Europa History is stated " Don Dykins designed the Europas wing. Don, as former chief aerodynamicist at British Aerospace, had directed the development of the advanced technology wing of the Airbus." While building my Europa Classic between 1994 and 1997, I recall seeing it written somewhere that the Don Dykins wing profile became known simply as the "Europa profile" and I'll try rummaging through my large pile of Europa info to see if I can find the reference you seek. I'm fairly confident that it was never accorded a formal unique reference listing in any airfoil database. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502164#502164 ________________________________________________________________________________
Date: May 31, 2021
Thanks for the reply Erich, interesting story and good advice. Certainly makes me feel more confident and I have to say that I have been practicing and my landings are becoming more controlled with a very small percentage of them with a small bounce. This weekend I did a nice two hour cross country and enjoyed it greatly. Although I am sure that your landing story still applies to my airplane, am I correct in assuming you used your split gear/landing feature to land with less flaps during that extreme wind condition? Best, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502165#502165 ________________________________________________________________________________
Date: May 31, 2021
Beautiful picture Erich. I hope mine looks like that one day! Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502166#502166 ________________________________________________________________________________
Date: May 31, 2021
Cool Erich, I see it. However, not very eager to mess with my instrument module now. Too lazy :) I think I am going to try just a couple of NACA on the sides. I measured where to put them to keep them out of the way. I will copy the ones in my LongEZ which work well although those are located on a place where the angle favors them greatly (compared to what it will be in the Europa) Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502167#502167 ________________________________________________________________________________
Date: May 31, 2021
I believe that the stall warner mod has a profile of the forward most 6 of the wing profileFred > On May 31, 2021, at 2:39 PM, Area-51 wrote: > > > Read both of the Dykin writings. They are very informative, however neither provide the information being sought... Specifically searching for actual airfoil profiles employed on the Europa; profile plotting data in excel spread sheet, CSV coordinates, or title tag of airfoil. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502162#502162 > > > > > > > > > ________________________________________________________________________________
Date: May 31, 2021
Decided to just go Old School on this one and plot it all out from actuals... Task done :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502170#502170 Attachments: http://forums.matronics.com//files/029a9da9_3a06_42c6_9528_82c08232d91d_126.jpeg ________________________________________________________________________________
Subject: Re: Flap limiting speed 83 kts exceeded
Date: Jun 01, 2021
Jonathan, Well done for 'coming out' over an overspeed occurrence - we have all done it to a larger or lesser extent and the questions you pose are very relevant. I am not speaking for Europa Aircraft (current or past) or for the Club, however, generally, the flap limiting speed is determined having conducted a stress analysis of the whole system. The failure mode that causes the first failure or lowest reserve factor (RF) is associated with a speed within the V-N envelope. A suitable factor is applied (which in any case will include at least 1.5 for LIMIT to ULTIMATE and, most likely, additional factors such as 1.15 fitting factor (at joints) or even 1.33 (for regularly dismantled items). For composite structure failures, there are yet more factors that take into account the environmental influences (e.g. temperature, humidity) and variability of build standard. Regarding loads, as air pressure is proportional to the square of the airspeed the loads can rise very quickly. For your overspeed occurrence, the flaps would have seen a dynamic pressure of approx 1.45 (i.e. 100^2/83^2 = 1.45, hence 45% overload). By definition this is somewhere between LIMIT and ULTIMATE load levels, hence some detrimental deformation may have occurred. The tg Owners Manual states "Vfe Maximum flap extended speed is the highest speed permissible with the flaps in the prescribed extended position". PoH states Vfe as 83kts. Vfe (max speed for extending/retracting flaps) implies the actuator is the weak link. Vf would be a flap limiting speed. You have done exactly the right thing, you have inspected the system for deformation. It is likely that no damage has occurred at all. If damage has occurred, the Europa actuator end attachment holes may have ovalised very slightly (rattle tested?) but I suspect the flap end-pin and bearing (and the attachment into the flap) are over-engineered and will be unaffected. Maybe you could add an additional disassembly/inspection to the flap actuator end fittings when the aircraft is under it's next scheduled maintenance. I suspect Bud may also have some useful input! Regards John -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502172#502172 ________________________________________________________________________________
Date: Jun 01, 2021
The aerofoils are hybrid, derived from first principles and hence unique. If you wish to do your own analysis I suggest you ask Europa Aircraft for the external profile - David Stanbridge recently made an offer to share their 3D scanned data of the Europa OML. Please bear in mind that the section changes root to tip, hence intermediate wing rib coordinate stations are needed to correctly simulate the wing. Some online CAD models of the Europa exists, however, I would be cautious of using them as their accuracy is quite poor. FYI I was fortunate to work at BAe Hatfield under Don Dykins for a short time during my apprenticeship (moving on to the stress office as a career). The only other claim I have to have known him personally was that he had the same preference for cars as myself - he brought a Ford Capri 2.8i I had owned. -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502173#502173 ________________________________________________________________________________
Subject: Re: 3D Printer
Date: Jun 01, 2021
When I say, you'll agree with me. Adhesive printers make your life much easier when you have to print a large number of adhesives or labels Stickers from our shops are often difficult to get. You're not going to find them in shops if you're searching for the sticker for your preferred TV shows the just visit https://printerhow.com, your favorite anime, work-related issues, ID text, massages or even decorating your home using colorful and light sticks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502174#502174 ________________________________________________________________________________
Date: Jun 01, 2021
Thanks for the insight there John! Have got todays results into CAD already. Your right on the hybrid stance; looks a little like an Eppler or Boeing profile (stable up to 400kt cruise)... which doesnt surprise me given the performance envelope... Will see if the factory are willing to supply any data. My experience on this level of study generally ends up with reverse engineering with laser scanning due to highly guarded secret squirrel bunker information that can be measured off any particular given factory part purchased... will just have to use the sunlight to tell me where those stations are and plot out the whole wing accordingly... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502178#502178 ________________________________________________________________________________
Date: Jun 01, 2021
On 2021-06-01, at 15:33, Area-51 wrote: > My experience on this level of study generally ends up with reverse engineering with laser scanning due to highly guarded secret squirrel bunker information that can be measured off any particular given factory part purchased... will just have to use the sunlight to tell me where those stations are and plot out the whole wing accordingly... Area-51 - not sure if I missed something earlier in this thread, but just out of idle curiosity, what is your intended use of the data once captured? in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Date: Jun 01, 2021
Chris, Glad to hear you had a nice cross country. While it is true I have the ability to choose something less than full flaps for landing, I make all my landings full flaps, even in windy/gusty conditions. The view over the nose is better, plus a lower touchdown speed and less float. As mentioned in my original post I do, however, use partial flaps for takeoff. With your fly off almost complete, hopefully you are able to make OSH. Regards, Erich N28ET Classic Mono 914 ____________________________________________________________ Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more On Punishments for Church Sex Abuse, a 'Significant Rewrite' http://thirdpartyoffers.juno.com/TGL3131/60b655246175d551840d9st02duc1 Supreme Court Move Means J&J Owes Women $2B http://thirdpartyoffers.juno.com/TGL3131/60b6552485a29551840d9st02duc2 After Osaka's Surprise Withdrawal, a Lively Debate http://thirdpartyoffers.juno.com/TGL3131/60b65524a912a551840d9st02duc3 ________________________________________________________________________________
Date: Jun 01, 2021
Further to Erich's excellent comments, fwiw, in the std mono, if full flaps is causing issues on a short strip, I pull the flaps up partially once airborne (my speed builds quickly once off the ground), allowing for better climb. I have not yet found it to be limiting, other than it pops off a bumpy strip prematurely. On a typical longer runway, I simply let the speed build to Vx before stowing the flaps all the way in one motion - typically at 2/3's runway. In my XS "dream" build, I am leaving them coupled. I like keeping things simple :) Cheers PeteZ On Tue., Jun. 1, 2021, 11:50 a.m. Erich Trombley, wrote: > > > > Chris, > > Glad to hear you had a nice cross country. While it is true I have the > ability to choose something less than full flaps for landing, I make all my > landings full flaps, even in windy/gusty conditions. The view over the > nose is better, plus a lower touchdown speed and less float. As mentioned > in my original post I do, however, use partial flaps for takeoff. > > With your fly off almost complete, hopefully you are able to make OSH. > > Regards, > Erich > N28ET Classic Mono 914 > > > ____________________________________________________________ > Sponsored by > https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more > > On Punishments for Church Sex Abuse, a 'Significant Rewrite' > http://thirdpartyoffers.juno.com/TGL3131/60b655246175d551840d9st02duc1 > Supreme Court Move Means J&J Owes Women $2B > http://thirdpartyoffers.juno.com/TGL3131/60b6552485a29551840d9st02duc2 > After Osaka's Surprise Withdrawal, a Lively Debate > http://thirdpartyoffers.juno.com/TGL3131/60b65524a912a551840d9st02duc3 > > ________________________________________________________________________________
Date: Jun 01, 2021
<> How long is the runway and what surface/condition? I'm 'struggling' with the acceleration of a new prop I'm trying and would like a comparison. Duncan McF. > On 01 June 2021 at 17:20 Pete Zut wrote: > > Further to Erich's excellent comments, fwiw, in the std mono, if full flaps is causing issues on a short strip, I pull the flaps up partially once airborne (my speed builds quickly once off the ground), allowing for better climb. I have not yet found it to be limiting, other than it pops off a bumpy strip prematurely. > > On a typical longer runway, I simply let the speed build to Vx before stowing the flaps all the way in one motion - typically at 2/3's runway. > > In my XS "dream" build, I am leaving them coupled. I like keeping things simple :) > > Cheers > PeteZ > > On Tue., Jun. 1, 2021, 11:50 a.m. Erich Trombley, wrote: > > > > > Chris, > > > > Glad to hear you had a nice cross country. While it is true I have the ability to choose something less than full flaps for landing, I make all my landings full flaps, even in windy/gusty conditions. The view over the nose is better, plus a lower touchdown speed and less float. As mentioned in my original post I do, however, use partial flaps for takeoff. > > > > With your fly off almost complete, hopefully you are able to make OSH. > > > > Regards, > > Erich > > N28ET Classic Mono 914 > > > > > > ____________________________________________________________ > > Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more > > > > On Punishments for Church Sex Abuse, a 'Significant Rewrite' > > http://thirdpartyoffers.juno.com/TGL3131/60b655246175d551840d9st02duc1 > > Supreme Court Move Means J&J Owes Women $2B > > http://thirdpartyoffers.juno.com/TGL3131/60b6552485a29551840d9st02duc2 > > After Osaka's Surprise Withdrawal, a Lively Debate > > http://thirdpartyoffers.juno.com/TGL3131/60b65524a912a551840d9st02duc3 > > > > ========== > > pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List > > ========== > > FORUMS - > > eferrer noreferrer" target="_blank">http://forums.matronics.com > > ========== > > WIKI - > > errer noreferrer" target="_blank">http://wiki.matronics.com > > ========== > > b Site - > > -Matt Dralle, List Admin. > > rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution > > ========== > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 01, 2021
John, Thanks for your prompt response. If by "actuator" you're referring to the electric motor which I believe was originally from a Ford car window motor, I'm happy to report that I don't have one. My aircraft was converted by the late great Neville Eyre from monowheel to tri-gear. I took his good advice and retained the cockpit lever which is now only connected to the flaps; this also saves weight and complication. So having checked everything very carefully and also the flap push-pull rod connected to the lever, I'm quite confident that no damage seems to have occurred. Thanks again. Jonathan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502193#502193 ________________________________________________________________________________
Date: Jun 01, 2021
Hi Rowland, basic CFD studies of complete airframe model using OpenFoam Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502194#502194 ________________________________________________________________________________
Date: Jun 01, 2021
Please let us know what the ideal drag-minimizing wing/fuse fairing looks like! ;-) PeteZ On Tue, Jun 1, 2021 at 7:09 PM Area-51 wrote: > goldsteinindustrial(at)gmail.com> > > Hi Rowland, basic CFD studies of complete airframe model using OpenFoam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502194#502194 > > ________________________________________________________________________________
Date: Jun 02, 2021
Jonathan, I'm tied up at the moment and you will all be relieved for a short and fati gue influenced answer on flap over speeds. John W gives some sage advice. Inspection after any overspeed or overstres s is the key to continued airworthiness. Pull the bracket covers, open up the fuselage D tube and inspect all attachments. Look for cracked glass, d elamination, and bolts that have elongated. Some analysis from the top of my very tired head. In the US the Vfe is supposed to be the speed at which maximum design G can be loaded momentarily with the flaps extended. This is an iterative probl em. Once Vfe is set or calculated, then there is another requirement that the V speed must allow for a 1.3 times overspeed (per se) without exceeding design structural limits. That was always concerning to me in my studies. The flap is an airfoil that is fixed to the wing of course and the maximu m speed of a flap setting has to be at the limit times the safety factors. Therefore, we see in many aircraft a Vf1, 2 etc. based on the increment of flap extension speed limits to address the process. So, we see Vf1 of 10 degrees is highest and 20 degrees a little slower, and 30 degrees is quite low. The Europa was designed for one flap setting. It is interesting that the flap drive of the Airbus style externally hinged flap, that our little Europa has, actually takes very little force to exte nd and retract. (The plain flap extension load is horrendously large in co mparison.) These hinged flap designs were brilliant and worth the drag of the brackets . This extension /retraction force is evident in the mono where extension and retraction between 60-90 KIAS has virtually no difference in gear exten sion effort. Yes, the brackets are draggy, but the loads are low and the f lap efficiency is quite good. One builder even installed a manual flap ext ension handle (although I don't know who it was, he was a Flight Crafters client.) Aerodynamically, the pitching moment, lift and drag of the flap i s calculated and the hinge point of the flap and the drive pin are set to r educe the load on the drive mechanism, simplify the gap flow accomplishment , and simplify construction. All brilliantly executed. As a result, I don 't worry as much about the flap drive, I worry more about the flap attach b rackets in an overspeed. Looking at the flap sum of forces for this type flap, The force on the fla ps when extended to nominally 27 degrees is basically a slotted flap with a lift coefficient of somewhere around 2.0 assumed. So, the force of lift vertically on the flap is Cl*1/2* (density)* V square d in fps nominally at 83knots and a roughly 7.5 square foot flap is (2x1/ 2x.00237x19643x7.5)=348 pounds of force upwards. The drag on the flap wi ll be roughly 7 pounds. The pitching moment of the flap will be another co uple of pounds. The moments are summed through the flap mechanism attach p oint and the resultant flap drive pin position load is a small number. Sor ry, I=92m not going to do actual calculations. In a picture it kind of loo ks like this picture attached. More math in public to follow: The load at say 1.3 times 83 knot Vfe is nominally 108 knots. Re-plugging numbers the forces go up significantly: 2x1/2 x.00237x33269x7.5 +590 pound s of force upwards. If I load the aircraft to full G (3.8 Gs) at 108 knots , that 590 pounds times 3.8 or 2240 pounds. So, some poor engineer will calculate all this out for the structural load. Figuring 50,000 psi (working hand laid glass strength) with a glass thick ness of .009, 4 layers, the glass to flox gap load bearing area of about 1. 5 square inches (that flox hole in the bracket), and a one foot hinge momen t arm in a shear mode (roughly half the tensile strength) means, in extrem ely rough numbers a single bracket will hold 1300 pounds of force times thr ee brackets or 3900 pounds. Hence the flap attachment is in very rough ter ms (non exactly measured) about 3900/2240 or 1.74 times stronger than I nee d, which is greater than my safety factor of 1.5 over the 1.3 V of 108 knot s (figuring it very roughly) in a max overspeed. Again, very rough numbers . If I simply up the load the flap area and stuff and multiply by 1.5 times 1 .5 (the super factor the Europa is designed to) based on the normal 83 knot forces I'm sure it will come out similarly . So, the extremely rough numbers give me a ball park confidence that althoug h I am over speeding my flaps, and must inspect my aircraft attachment poin ts I will concentrate my inspection on the flap bracket attachment to the f lap and the wing attach points first. Then I will do a retract test and ma ke sure my flap rig is correct (bent flap tube is a possibility), then insp ect my flap drive attachments/welds/glass supports to assure that they are still sound. Just my thoughts. Don=92t overspeed the flaps if you can help it. I have had a number of demo/checkout flights inadvertently extend flaps in the 90 Knot range for the last 15 years on poor old N12AY because they just don=92 t realize how clean the plane is. In a 914 if you don=92t make a very larg e power reduction from the climbing crosswind to downwind level off, you hi t 90 Knots pretty quick. Failure to monitor airspeed in the final turn can build speed rapidly also even with full flaps. I can=92t tell you how many secondhand owners end up crossing the threshold still doing over 83 Knots. If you make the speed offender do the inspection panel and cover open up and then put it back together, they pay attention to the airspeed more clos ely. Stay within the limits. IF you exceed them, inspect and repair as necessar y. Don=92t just rattle the flaps and blow it off. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of John Wighton Sent: Tuesday, June 01, 2021 4:12 AM Subject: Europa-List: Re: Flap limiting speed 83 kts exceeded john(at)wighton.net>> Jonathan, Well done for 'coming out' over an overspeed occurrence - we have all done it to a larger or lesser extent and the questions you pose are very relevan t. I am not speaking for Europa Aircraft (current or past) or for the Club, ho wever, generally, the flap limiting speed is determined having conducted a stress analysis of the whole system. The failure mode that causes the firs t failure or lowest reserve factor (RF) is associated with a speed within t he V-N envelope. A suitable factor is applied (which in any case will incl ude at least 1.5 for LIMIT to ULTIMATE and, most likely, additional factors such as 1.15 fitting factor (at joints) or even 1.33 (for regularly disman tled items). For composite structure failures, there are yet more factors that take into account the environmental influences (e.g. temperature, humi dity) and variability of build standard. Regarding loads, as air pressure is proportional to the square of the airsp eed the loads can rise very quickly. For your overspeed occurrence, the fl aps would have seen a dynamic pressure of approx 1.45 (i.e. 100^2/83^2 = 1.45, hence 45% overload). By definition this is somewhere between LIMIT a nd ULTIMATE load levels, hence some detrimental deformation may have occurr ed. The tg Owners Manual states "Vfe Maximum flap extended speed is the highest speed permissible with the flaps in the prescribed extended position". PoH states Vfe as 83kts. Vfe (max speed for extending/retracting flaps) im plies the actuator is the weak link. Vf would be a flap limiting speed. You have done exactly the right thing, you have inspected the system for d eformation. It is likely that no damage has occurred at all. If damage has occurred, the Europa actuator end attachment holes may have o valised very slightly (rattle tested?) but I suspect the flap end-pin and b earing (and the attachment into the flap) are over-engineered and will be unaffected. Maybe you could add an additional disassembly/inspection to the flap actuat or end fittings when the aircraft is under it's next scheduled maintenance. I suspect Bud may also have some useful input! Regards John -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D502172%23502172&data=04%7C01%7C%7C3 5529c5618204f09345408d924d581a2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0% 7C637581321682102940%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2 luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=XtDaXBExfUW9W2ru0Kz zH7JOxEs6e7wID1iMpb9IMxI%3D&reserved=0 %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C3552 9c5618204f09345408d924d581a2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6 37581321682102940%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=iOyukBDSGCD%2B55qYSid7 t3%2FE2WVSbZIL3T%2FOu8GsVOk%3D&reserved=0 %2Fforums.matronics.com%2F&data=04%7C01%7C%7C35529c5618204f09345408d9 24d581a2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637581321682102940%7C Unknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL CJXVCI6Mn0%3D%7C1000&sdata=UbU5ysD%2BsWreuUC7QkZl6smus1tbMG%2F3%2FPrW 3qtvGBE%3D&reserved=0 %2Fwiki.matronics.com%2F&data=04%7C01%7C%7C35529c5618204f09345408d924 d581a2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637581321682112935%7CUn known%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=peDaqV%2FUc4p7iBr%2FsND%2FlUP6IekF209k%2BzJq iJqjg2w%3D&reserved=0 %2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C35529c5618204f0 9345408d924d581a2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637581321682 112935%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=eJ4uBMdmb13prIDiZR4LScp49Zi%2Bu%2 F5PGxnVTH4Tmi0%3D&reserved=0 ________________________________________________________________________________
Date: Jun 01, 2021
Petebelow are my best efforts in that regardI too am very curious as to what a rigorous analysis will show...Fred > On Jun 1, 2021, at 5:12 PM, Pete Zut wrote: > > Please let us know what the ideal drag-minimizing wing/fuse fairing looks like! ;-) > > PeteZ > > On Tue, Jun 1, 2021 at 7:09 PM Area-51 > wrote: > > > Hi Rowland, basic CFD studies of complete airframe model using OpenFoam > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502194#502194 <http://forums.matronics.com/viewtopic.php?p=502194#502194> > ________________________________________________________________________________
Date: Jun 01, 2021
Indeed Fred, yours looks =9Cspitfire perfect=9D. Gorgeous! -PeteZ > On Jun 1, 2021, at 10:31 PM, Fred Klein wrote: > > =EF=BBPetebelow are my best efforts in that regardI t oo am very curious as to what a rigorous analysis will show...Fred > >> On Jun 1, 2021, at 5:12 PM, Pete Zut wrote: >> >> Please let us know what the ideal drag-minimizing wing/fuse fairing looks like! ;-) >> >> PeteZ >> >> On Tue, Jun 1, 2021 at 7:09 PM Area-51 wr ote: com> >>> >>> Hi Rowland, basic CFD studies of complete airframe model using OpenFoam >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=502194#502194 >>> > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 02, 2021
It will indeed be interesting to see what the CFD results reveal... after years of playing with this stuff its always surprising in some way; the brain thinks the air will flow a particular way and it often does something different! Today involved a more thorough study and data capture session after the mention of alternate stations along the wing; and indeed they were there when searched for! Will be interesting to watch the stall response... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502202#502202 Attachments: http://forums.matronics.com//files/12e7811b_360b_48ed_bbca_eca9e3da41e7_516.jpeg http://forums.matronics.com//files/1a53355e_938d_472c_b56b_fc8b141d07de_250.jpeg http://forums.matronics.com//files/59efe2a7_bb0e_45d9_960d_cee69fb31249_185.jpeg ________________________________________________________________________________
Date: Jun 02, 2021
Bud, Thanks for taking so much trouble to consider this matter while you were so tired. You mention that "One builder even installed a manual flap extension handle", which is what I'm left with after Neville Eyre helped me with my conversion from mono-wheel to tri-gear. It's remarkable how easy it is to extend and retract the flaps, even without the benefit of bungees. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502204#502204 ________________________________________________________________________________
Date: Jun 02, 2021
Subject: Starter Diode
I fitted a starter Diode and engine would not start. Orientation was as described with band end cathode on starter terminal and other end to earth? Have I got wrong diode. Any advice appreciated Dave Park G-LDVO ________________________________________________________________________________
Date: Jun 02, 2021
JonathanMilbank wrote: > One of our group members got distracted during climb out after take off, while the flaps remained extended to 18 degrees. " Just curious - did you modify your flap drive mechanism to allow selection of 18 degrees as well as the specified 27, or instead of? Paul G-PLPM XS Mono 912ULS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502214#502214 ________________________________________________________________________________
Date: Jun 03, 2021
When we scanned the Europa we used paint that was washed off afterwards. It is commonly used by street artists. An initial attempt without paint led to big gaps in the cloud data. I like the root fairings, they look a bit like Frans Veldmans who was highly active in Europa modifications. Whatever happened to Frans? The tape is probably a better idea, as it limits the data - although there are some coordinates for the sections along the wing - we used them years ago in xfoil. John W -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502215#502215 ________________________________________________________________________________
Date: Jun 03, 2021
Interested to know what polar results Xfoil popped out there John! Would still want to cross reference results to those of Ansys Fluent though. On 3d scanning; shiny surfaces are the devil... dead flat non-reflective surface is going to save a lot of mumbling...water soluble hair spray and talcum powder dust is a magic formula! Plenty of reference dots are required too... washoff flat spray paint costs a bit more :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502217#502217 ________________________________________________________________________________
Date: Jun 03, 2021
Paul, While my aircraft was a mono, the combined flap / undercarriage lever had the standard detents which held the lever either at fully retracted or fully down 27 degrees. When I decided after almost 20 years flying as a mono to convert to tri-gear, Neville Eyre told me to support the aircraft in order to partly retract the gear and use a clinometer to measure an intermediate flap position of 18 degrees. While the flaps were at that angle, I leaned into the cockpit and marked on the slotted guide plate the position of the lever. Neville then cut the guide plate in situ to create an intermediate 18 degree detent notch, which happens to lie approximately halfway along the slot. Thereafter we set about removing the mono-wheel swing arm, linkage and other unnecessary components to leave just the lever connected to the flap push-pull rod. Why Neville specified 18 degrees is something I never questioned, but we use that intermediate setting for take off on the assumption that it reduces drag while still augmenting low speed lift. It also occurs to me that if there existed a graph or table giving different Vfe speeds for various flap settings, then the Vfe for 18 degrees would be considerably higher than 83 knots; perhaps a lot closer to 100 knots. That was a long-winded explanation where I could simply have replied 'as well as'. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502218#502218 ________________________________________________________________________________
Subject: US Fly-In Interest?
Date: Jun 03, 2021
With COVID rules relaxing, how about a Europa fly-in / gathering? Were considering New River Gorge in West Virginia. There are lots of potential activities, check it out online. Beckley, KBKW is the nearest public airport and there are nearby hotels. We can try to arrange a block of rooms and a rental vehicle. Either weekend June 19-20 or June 26-27 are good for us. If interested, reply here or email america(at)theeuropaclub.org. Everyone is welcome, club membership not required. Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502227#502227 ________________________________________________________________________________
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Date: Jun 03, 2021
Frans bought a yacht and is sailing around the world last I heard. We haven't talked since we collaborated on our cooling drag reduction project years ago.. You can catch him on Twitter from time to time. I believe that his fairings were provided by Fred if I'm not mistaken. - Paul On Thu, Jun 3, 2021 at 2:20 AM John Wighton wrote: > > When we scanned the Europa we used paint that was washed off afterwards. > It is commonly used by street artists. An initial attempt without paint > led to big gaps in the cloud data. > > I like the root fairings, they look a bit like Frans Veldman=99s wh o was > highly active in Europa modifications. Whatever happened to Frans? > > The tape is probably a better idea, as it limits the data - although > there are some coordinates for the sections along the wing - we used them > years ago in xfoil. > > John W > > -------- > John Wighton > Europa XS trigear G-IPOD > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502215#502215 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Jun 03, 2021
Subject: Re: US Fly-In Interest?
Sounds like a great idea. 26 27 June would work best for us William Daniell LONGPORT +1 786 878 0246 On Thu, Jun 3, 2021 at 11:45 AM h&jeuropa wrote: > > With COVID rules relaxing, how about a Europa fly-in / gathering? We =99re > considering New River Gorge in West Virginia. There are lots of potentia l > activities, check it out online. Beckley, KBKW is the nearest public > airport and there are nearby hotels. We can try to arrange a block of > rooms and a rental vehicle. Either weekend June 19-20 or June 26-27 are > good for us. If interested, reply here or email america(at)theeuropaclub.or g. > Everyone is welcome, club membership not required. > > Jim & Heather > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502227#502227 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jun 03, 2021
Thanks Paul, l am not so surprised about the sailing adventure. Frans was very foreword thinking, it wouldnt surprise me at all if he had a stash of Bitcoin from Day 1. We met as he was based near Hoogeveen, l was acting as a delegated signatory for Fokkers A380 wing assemblies at the time. His Europa was highly modified, something that surprised me as the Dutch NVAV and authority ILT seemed pretty hot on the need to grant approvals per Mod. -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502233#502233 ________________________________________________________________________________
Date: Jun 03, 2021
JonathanMilbank wrote: > ...create an intermediate 18 degree detent notch, which happens to lie approximately halfway along the slot... > > Why Neville specified 18 degrees is something I never questioned, ... if ... different Vfe speeds for varying flap settings, then ... Vfe for 18 degrees would be considerably higher than 83 knots; perhaps a lot closer to 100 knots. > > That was a long-winded explanation where I could simply have replied 'as well as'. Yes it was (:-D), but it answers my question, thanks. Might 18 be the takeoff flap setting for a Trigear? I don't have one but you do and I guess it's in the Owner's Manual? This might then answer your question (on Vfe for 18) ... if you read Bud's reply and do some math(s). HTH P G-PLPM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502236#502236 ________________________________________________________________________________
Date: Jun 04, 2021
Paul, You're dead right. I logged into the Europa Club's website and found on page 5-6 under Pre-take off check list (vital actions) this: Flaps Check 18 down. On page 2-1 under Limitations, all that is shown for flaps is Max. Flap extension speed (VFE ) 83kts. However my math abilities don't extend to calculating a Vfe for 18 degrees extension, but thanks anyway for your involvement. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502241#502241 ________________________________________________________________________________
Date: Jun 04, 2021
Hi! All. I recall that flap setting for take off on trike G-PTAG was 18Deg. Regards Bob Harrison. -----Original Message----- From: owner-europa-list-server(at)matronics.com On Behalf Of Paul M 383 Sent: 04 June 2021 02:16 Subject: Europa-List: Re: Flap limiting speed 83 kts exceeded --> JonathanMilbank wrote: > ...create an intermediate 18 degree detent notch, which happens to lie approximately halfway along the slot... > > Why Neville specified 18 degrees is something I never questioned, ... if ... different Vfe speeds for varying flap settings, then ... Vfe for 18 degrees would be considerably higher than 83 knots; perhaps a lot closer to 100 knots. > > That was a long-winded explanation where I could simply have replied 'as well as'. Yes it was (:-D), but it answers my question, thanks. Might 18 be the takeoff flap setting for a Trigear? I don't have one but you do and I guess it's in the Owner's Manual? This might then answer your question (on Vfe for 18) ... if you read Bud's reply and do some math(s). HTH P G-PLPM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502236#502236 This email has been scanned by BullGuard antivirus protection. For more info visit www.bullguard.com ________________________________________________________________________________
Subject: Front Wheel Fairing
Date: Jun 04, 2021
Does anyone have the front half of the TriGear front wheel fairing they would be willing to let me buy ? If so, please send me a PM with details Cheers -------- Bob Dawson Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502244#502244 ________________________________________________________________________________
Date: Jun 05, 2021
Hi! All, Just out of interest Frans Veldman and Iloona Koostra now have a catamaran and are in the southern middle of the Pacific. They can be hooked up with on Utube under the cat name of zwerfcat nl . she has a very pleasant video for you to scan . Unfortunately I am not U-Tube familiar so when the U tube buffs find a proper kink please advise and return the favour. Regards Bob Harrison Ex G-PTAG . From: owner-europa-list-server(at)matronics.com On Behalf Of Paul McAllister Sent: 03 June 2021 17:55 Subject: Re: Europa-List: Re: Airfoil Profiles Frans bought a yacht and is sailing around the world last I heard. We haven't talked since we collaborated on our cooling drag reduction project years ago.. You can catch him on Twitter from time to time. I believe that his fairings were provided by Fred if I'm not mistaken. - Paul On Thu, Jun 3, 2021 at 2:20 AM John Wighton > wrote: > When we scanned the Europa we used paint that was washed off afterwards. It is commonly used by street artists. An initial attempt without paint led to big gaps in the cloud data. I like the root fairings, they look a bit like Frans Veldman=99s who was highly active in Europa modifications. Whatever happened to Frans? The tape is probably a better idea, as it limits the data - although there are some coordinates for the sections along the wing - we used them years ago in xfoil. John W -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502215#502215 pa-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution This email has been scanned by BullGuard antivirus protection. For more info visit www.bullguard.com <http://www.bullguard.com/tracking.aspx?affiliate=bullguard&buyaffiliat e=smtp&url=/> ________________________________________________________________________________
From: "fklein(at)orcasonline.com" <fklein(at)orcasonline.com>
Date: Jun 05, 2021
> On Jun 4, 2021, at 4:03 PM, ptag.dev(at)talktalk.net wrote: > > I like the root fairings, they look a bit like Frans Veldman=99s who was highly active in Europa modifications. Whatever happened to Frans? Here=99s a photo of Frans=99 hightop trigger Europaye s, I provided Frans with his wing root fairings ________________________________________________________________________________
Date: Jun 07, 2021
Dave, I didn't see anyone commented on your diode. Pretty much any diode will do. If you get it backwards, the saving grace i s the start solenoid is looking for 12 volts. Of course, the solenoid must be grounded. Most mistakes are the ground is left off the solenoid when putting on the d iode. Another problem is guys don=92t insulate the anode side of the diode and it shorts. The Rotax manual doesn't comment on the diode. But it is an accepted pract ice to extend the life of the contacts in the starter solenoid. The Europa Electrical Chapter 25 advises to use an IN5404 but any will do. IN5404[cid:image001.png(at)01D75B0E.9AC39E20] silicone diode is shown above. Anode or plus side is on the starter switch tab and the cathode or negative goes to the ground bolt holding on the sta rter solenoid. I use at least a #18 or 16 wire from the solenoid fastening bolt to the main firewall ground. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of david park Sent: Wednesday, June 02, 2021 2:44 PM Subject: Europa-List: Starter Diode 748(at)me.com>> I fitted a starter Diode and engine would not start. Orientation was as des cribed with band end cathode on starter terminal and other end to earth? Have I got wrong diode. Any advice appreciated Dave Park G-LDVO %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756 a189af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6 37582564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwU HkZby9t6u3YMcNESeUVsc%3D&reserved=0 %2Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d9 25f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7C Unknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL CJXVCI6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUU hMM%3D&reserved=0 %2Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925 f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUn known%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY% 3D&reserved=0 %2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b 6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812 630692%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM% 2FA4XO38X5pjT4sc%3D&reserved=0 ________________________________________________________________________________
Date: Jun 07, 2021
Dave, OOPS. Look at the diagram, I misspoke. The cathode side on a solenoid spa de contact and the anode or positive goes to the ground. It=92s getting late and the mind is a terrible thing. Follow the pictures in the Bob Knuckles book or the Europa Electrical Diagr am. Goodnight, Bud Yerly From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> On Behalf Of Bud Yerly Sent: Sunday, June 06, 2021 8:01 PM Subject: RE: Europa-List: Starter Diode Dave, I didn't see anyone commented on your diode. Pretty much any diode will do. If you get it backwards, the saving grace i s the start solenoid is looking for 12 volts. Of course, the solenoid must be grounded. Most mistakes are the ground is left off the solenoid when putting on the d iode. Another problem is guys don=92t insulate the anode side of the diode and it shorts. The Rotax manual doesn't comment on the diode. But it is an accepted pract ice to extend the life of the contacts in the starter solenoid. The Europa Electrical Chapter 25 advises to use an IN5404 but any will do. IN5404[cid:image002.png(at)01D75B10.86931730] silicone diode is shown above. Anode or plus side is on the starter switch tab and the cathode or negative goes to the ground bolt holding on the sta rter solenoid. I use at least a #18 or 16 wire from the solenoid fastening bolt to the main firewall ground. Best Regards, Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com<mailto:owner-europa-list-serve r(at)matronics.com> > On Behalf Of david park Sent: Wednesday, June 02, 2021 2:44 PM Subject: Europa-List: Starter Diode 748(at)me.com>> I fitted a starter Diode and engine would not start. Orientation was as des cribed with band end cathode on starter terminal and other end to earth? Have I got wrong diode. Any advice appreciated Dave Park G-LDVO - The Europa-List Email Forum - --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fww w.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a189a f0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582 564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLC JBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby 9t6u3YMcNESeUVsc%3D&reserved=0 - MATRONICS WEB FORUMS - --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Ffo rums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f 1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnkno wn%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVC I6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3 D&reserved=0 - NEW MATRONICS LIST WIKI - --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwi ki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f1c 0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknown %7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6 Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D&am p;reserved=0 - List Contribution Web Site - -Matt Dralle, List Admin. --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fww w.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b61755 08d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63758256481263069 2%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4X O38X5pjT4sc%3D&reserved=0 ________________________________________________________________________________
Date: Jun 07, 2021
What an awesome looking europa!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502257#502257 ________________________________________________________________________________
Subject: Re: Starter Diode
Date: Jun 07, 2021
Bud, Still confused as Europa Manual wiring diagram shows Anode to Earth? Not swi tch. Regards Dave Park > On 7 Jun 2021, at 01:06, Bud Yerly wrote: > > =EF=BB > Dave, > I didn't see anyone commented on your diode. > > Pretty much any diode will do. If you get it backwards, the saving grace i s the start solenoid is looking for 12 volts. Of course, the solenoid must b e grounded. > Most mistakes are the ground is left off the solenoid when putting on the d iode. Another problem is guys don=99t insulate the anode side of the d iode and it shorts. > > The Rotax manual doesn't comment on the diode. But it is an accepted prac tice to extend the life of the contacts in the starter solenoid. The Europa Electrical Chapter 25 advises to use an IN5404 but any will do. > > IN5404 > silicone diode is shown above. Anode or plus side is on the starter switc h tab and the cathode or negative goes to the ground bolt holding on the sta rter solenoid. I use at least a #18 or 16 wire from the solenoid fastening b olt to the main firewall ground. > > Best Regards, > Bud Yerly > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@mat ronics.com> On Behalf Of david park > Sent: Wednesday, June 02, 2021 2:44 PM > To: europa-list(at)matronics.com > Subject: Europa-List: Starter Diode > > > I fitted a starter Diode and engine would not start. Orientation was as de scribed with band end cathode on starter terminal and other end to earth? > Have I got wrong diode. > Any advice appreciated > > Dave Park G-LDVO > > > - The Europa-List Email Forum - > --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fw ww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a189a f0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375825 64812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJB TiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby9t6 u3YMcNESeUVsc%3D&reserved=0 > - MATRONICS WEB FORUMS - > --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Ff orums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f 1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6 Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3D&a mp;reserved=0 > - NEW MATRONICS LIST WIKI - > --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fw iki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f1c 0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknown% 7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn 0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D&r eserved=0 > - List Contribution Web Site - > -Matt Dralle, List Admin. > --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fw ww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b61755 08d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692 %7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4XO38 X5pjT4sc%3D&reserved=0 > > > ________________________________________________________________________________
Date: Jun 07, 2021
Are you sure the diode is not faulty? You can check it with an meter set to read resistance. Should be high resist ance one way and low the other. Have you tried connecting it the other way round? Alan Sent from my iPad > On 7 Jun 2021, at 09:02, david park wrote: > > =EF=BBBud, > Still confused as Europa Manual wiring diagram shows Anode to Earth? Not s witch. > Regards > Dave Park > > >>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>> >> =EF=BB >> Dave, >> I didn't see anyone commented on your diode. >> >> Pretty much any diode will do. If you get it backwards, the saving grace is the start solenoid is looking for 12 volts. Of course, the solenoid mus t be grounded. >> Most mistakes are the ground is left off the solenoid when putting on the diode. Another problem is guys don=99t insulate the anode side of th e diode and it shorts. >> >> The Rotax manual doesn't comment on the diode. But it is an accepted pra ctice to extend the life of the contacts in the starter solenoid. The Europ a Electrical Chapter 25 advises to use an IN5404 but any will do. >> >> IN5404 >> >> >> silicone diode is shown above. Anode or plus side is on the starter swit ch tab and the cathode or negative goes to the ground bolt holding on the st arter solenoid. I use at least a #18 or 16 wire from the solenoid fastening bolt to the main firewall ground. >> >> Best Regards, >> Bud Yerly >> >> -----Original Message----- >> From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@ma tronics.com> On Behalf Of david park >> Sent: Wednesday, June 02, 2021 2:44 PM >> To: europa-list(at)matronics.com >> Subject: Europa-List: Starter Diode >> >> >> I fitted a starter Diode and engine would not start. Orientation was as d escribed with band end cathode on starter terminal and other end to earth? >> Have I got wrong diode. >> Any advice appreciated >> >> Dave Park G-LDVO >> >> >> - The Europa-List Email Forum - >> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fw ww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a189a f0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375825 64812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJB TiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby9t6 u3YMcNESeUVsc%3D&reserved=0 >> - MATRONICS WEB FORUMS - >> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Ff orums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f 1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6 Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3D&a mp;reserved=0 >> - NEW MATRONICS LIST WIKI - >> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fw iki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f1c 0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknown% 7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn 0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D&r eserved=0 >> - List Contribution Web Site - >> -Matt Dralle, List Admin. >> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fw ww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b61755 08d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692 %7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4XO38 X5pjT4sc%3D&reserved=0 >> >> >> ________________________________________________________________________________
Date: Jun 07, 2021
Allan have you put ANODE to switch contact? Dave Park > On 7 Jun 2021, at 09:35, Alan Burrill wrote: > > =EF=BBAre you sure the diode is not faulty? > > You can check it with an meter set to read resistance. Should be high resi stance one way and low the other. > > Have you tried connecting it the other way round? > > Alan > > Sent from my iPad > >>> On 7 Jun 2021, at 09:02, david park wrote: >>> >> =EF=BBBud, >> Still confused as Europa Manual wiring diagram shows Anode to Earth? Not s witch. >> Regards >> Dave Park >> >> >>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>> >>> =EF=BB >>> Dave, >>> I didn't see anyone commented on your diode. >>> >>> Pretty much any diode will do. If you get it backwards, the saving grac e is the start solenoid is looking for 12 volts. Of course, the solenoid mu st be grounded. >>> Most mistakes are the ground is left off the solenoid when putting on th e diode. Another problem is guys don=99t insulate the anode side of t he diode and it shorts. >>> >>> The Rotax manual doesn't comment on the diode. But it is an accepted pr actice to extend the life of the contacts in the starter solenoid. The Euro pa Electrical Chapter 25 advises to use an IN5404 but any will do. >>> >>> IN5404 >>> >>> >>> silicone diode is shown above. Anode or plus side is on the starter swi tch tab and the cathode or negative goes to the ground bolt holding on the s tarter solenoid. I use at least a #18 or 16 wire from the solenoid fastenin g bolt to the main firewall ground. >>> >>> Best Regards, >>> Bud Yerly >>> >>> -----Original Message----- >>> From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@m atronics.com> On Behalf Of david park >>> Sent: Wednesday, June 02, 2021 2:44 PM >>> To: europa-list(at)matronics.com >>> Subject: Europa-List: Starter Diode >>> >>> >>> I fitted a starter Diode and engine would not start. Orientation was as d escribed with band end cathode on starter terminal and other end to earth? >>> Have I got wrong diode. >>> Any advice appreciated >>> >>> Dave Park G-LDVO >>> >>> >>> - The Europa-List Email Forum - >>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2 Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a18 9af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63758 2564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLC JBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby9 t6u3YMcNESeUVsc%3D&reserved=0 >>> - MATRONICS WEB FORUMS - >>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2 Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f 6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnkn own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVC I6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3D &reserved=0 >>> - NEW MATRONICS LIST WIKI - >>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2 Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f 1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6 Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D& ;reserved=0 >>> - List Contribution Web Site - >>> -Matt Dralle, List Admin. >>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2 Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b617 5508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375825648126306 92%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4XO 38X5pjT4sc%3D&reserved=0 >>> >>> >>> ________________________________________________________________________________
Subject: XS Tail wheel assembly
Date: Jun 07, 2021
Hi, I'm looking for all the parts to make a complete XS tailwheel assembly. I ideally want new, unused parts - does anyone have any bits lying around that they'd like to sell? Thanks, Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502262#502262 ________________________________________________________________________________
Date: Jun 07, 2021
I=99m asking if you did it by accident, I know what happens=F0=9F=98 Alan Sent from my iPad > On 7 Jun 2021, at 10:11, david park wrote: > > =EF=BBAllan have you put ANODE to switch contact? > > Dave Park > > >>> On 7 Jun 2021, at 09:35, Alan Burrill wrote: >>> >> =EF=BBAre you sure the diode is not faulty? >> >> You can check it with an meter set to read resistance. Should be high res istance one way and low the other. >> >> Have you tried connecting it the other way round? >> >> Alan >> >> Sent from my iPad >> >>>> On 7 Jun 2021, at 09:02, david park wrote: >>>> >>> =EF=BBBud, >>> Still confused as Europa Manual wiring diagram shows Anode to Earth? Not switch. >>> Regards >>> Dave Park >>> >>> >>>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>>> >>>> =EF=BB >>>> Dave, >>>> I didn't see anyone commented on your diode. >>>> >>>> Pretty much any diode will do. If you get it backwards, the saving gra ce is the start solenoid is looking for 12 volts. Of course, the solenoid m ust be grounded. >>>> Most mistakes are the ground is left off the solenoid when putting on t he diode. Another problem is guys don=99t insulate the anode side of t he diode and it shorts. >>>> >>>> The Rotax manual doesn't comment on the diode. But it is an accepted p ractice to extend the life of the contacts in the starter solenoid. The Eur opa Electrical Chapter 25 advises to use an IN5404 but any will do. >>>> >>>> IN5404 >>>> >>>> >>>> silicone diode is shown above. Anode or plus side is on the starter sw itch tab and the cathode or negative goes to the ground bolt holding on the s tarter solenoid. I use at least a #18 or 16 wire from the solenoid fastenin g bolt to the main firewall ground. >>>> >>>> Best Regards, >>>> Bud Yerly >>>> >>>> -----Original Message----- >>>> From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@ matronics.com> On Behalf Of david park >>>> Sent: Wednesday, June 02, 2021 2:44 PM >>>> To: europa-list(at)matronics.com >>>> Subject: Europa-List: Starter Diode >>>> >>>> >>>> I fitted a starter Diode and engine would not start. Orientation was as described with band end cathode on starter terminal and other end to earth? >>>> Have I got wrong diode. >>>> Any advice appreciated >>>> >>>> Dave Park G-LDVO >>>> >>>> >>>> - The Europa-List Email Forum - >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a1 89af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375 82564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby 9t6u3YMcNESeUVsc%3D&reserved=0 >>>> - MATRONICS WEB FORUMS - >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925 f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnk nown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3 D&reserved=0 >>>> - NEW MATRONICS LIST WIKI - >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6 f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnkno wn%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D&am p;reserved=0 >>>> - List Contribution Web Site - >>>> -Matt Dralle, List Admin. >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b61 75508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630 692%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1h aWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4X O38X5pjT4sc%3D&reserved=0 >>>> >>>> >>>> ________________________________________________________________________________
Date: Jun 07, 2021
Hello Dave, I haven=99t got your previous posts in front of me but I assume you wa nt to put the diode across the starter solenoid. If my assumption is correct, you should connect the anode to the starter mot or side of the starter solenoid and the cathode to the positive (starter swi tch) side of the solenoid. If you have had it connected the other way around and tried starting the eng ine, the diode would have been forward biased trying to carry the full curre nt of the starter motor and more than likely will be ruined. Either check the diode with a multi meter ( on ohms scale) to ensure it cond ucts in one direction but not the other or use a new diode. When connected correctly, on pressing the starter button (or key switch), th e diode is reverse biased and has no effect..... all the current passes thro ugh the solenoid. On releasing the starter button (or key switch), the coll apsing magnetic field in the starter solenoid tries to induce a high voltage spike but this is swamped by the diode because the diode short circuits the current induced by the collapsing magnetic field in the coil. Hope this hasn=99t made it more confusing for you. I could and probab ly should have just said ..... connect it like the manual says. Best regards Kingsley in Oz. Sent from my iPhone > On 7 Jun 2021, at 7:17 pm, david park wrote: > > =EF=BBAllan have you put ANODE to switch contact? > > Dave Park > > >>> On 7 Jun 2021, at 09:35, Alan Burrill wrote: >>> >> =EF=BBAre you sure the diode is not faulty? >> >> You can check it with an meter set to read resistance. Should be high res istance one way and low the other. >> >> Have you tried connecting it the other way round? >> >> Alan >> >> Sent from my iPad >> >>>> On 7 Jun 2021, at 09:02, david park wrote: >>>> >>> =EF=BBBud, >>> Still confused as Europa Manual wiring diagram shows Anode to Earth? Not switch. >>> Regards >>> Dave Park >>> >>> >>>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>>> >>>> =EF=BB >>>> Dave, >>>> I didn't see anyone commented on your diode. >>>> >>>> Pretty much any diode will do. If you get it backwards, the saving gra ce is the start solenoid is looking for 12 volts. Of course, the solenoid m ust be grounded. >>>> Most mistakes are the ground is left off the solenoid when putting on t he diode. Another problem is guys don=99t insulate the anode side of t he diode and it shorts. >>>> >>>> The Rotax manual doesn't comment on the diode. But it is an accepted p ractice to extend the life of the contacts in the starter solenoid. The Eur opa Electrical Chapter 25 advises to use an IN5404 but any will do. >>>> >>>> IN5404 >>>> >>>> >>>> silicone diode is shown above. Anode or plus side is on the starter sw itch tab and the cathode or negative goes to the ground bolt holding on the s tarter solenoid. I use at least a #18 or 16 wire from the solenoid fastenin g bolt to the main firewall ground. >>>> >>>> Best Regards, >>>> Bud Yerly >>>> >>>> -----Original Message----- >>>> From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@ matronics.com> On Behalf Of david park >>>> Sent: Wednesday, June 02, 2021 2:44 PM >>>> To: europa-list(at)matronics.com >>>> Subject: Europa-List: Starter Diode >>>> >>>> >>>> I fitted a starter Diode and engine would not start. Orientation was as described with band end cathode on starter terminal and other end to earth? >>>> Have I got wrong diode. >>>> Any advice appreciated >>>> >>>> Dave Park G-LDVO >>>> >>>> >>>> - The Europa-List Email Forum - >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a1 89af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375 82564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby 9t6u3YMcNESeUVsc%3D&reserved=0 >>>> - MATRONICS WEB FORUMS - >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925 f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnk nown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3 D&reserved=0 >>>> - NEW MATRONICS LIST WIKI - >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6 f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnkno wn%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D&am p;reserved=0 >>>> - List Contribution Web Site - >>>> -Matt Dralle, List Admin. >>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b61 75508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630 692%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1h aWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4X O38X5pjT4sc%3D&reserved=0 >>>> >>>> >>>> ________________________________________________________________________________
Date: Jun 07, 2021
The diode is connected across the starter solenoid coil not the contacts for the starter motor as per the extract from the build manual above. There is n o diode across the starter motor shown in the build manual diagram, at least not my version. With 12v positive on the starter contacter coil the diode, with the cathode o r marked end of the diode connected to positive terminal of the starter coil , is reverse biased and so will not conduct. When the starter button release the falling emf, magnetic field, produces an opposite voltage in the coil a nd can spark across the starter switch contacts eventually damaging the cont acts, the diode shorts out this so the spark does not happen. If the diode is shorted out, or the wrong way round, then solenoid will not w ork, assuming the solenoid will operate without diode connected as a test to ensure it=99s the wiring of the diode that=99s the problem of c ourse. Isn=99t explaining electrical problems by email fun .=F0=9F=A4=A9 Alan Sent from my iPad > On 7 Jun 2021, at 10:44, Kingsley Hurst wrote: > > =EF=BBHello Dave, > > I haven=99t got your previous posts in front of me but I assume you w ant to put the diode across the starter solenoid. > > If my assumption is correct, you should connect the anode to the starter m otor side of the starter solenoid and the cathode to the positive (starter s witch) side of the solenoid. > > If you have had it connected the other way around and tried starting the e ngine, the diode would have been forward biased trying to carry the full cur rent of the starter motor and more than likely will be ruined. > > Either check the diode with a multi meter ( on ohms scale) to ensure it co nducts in one direction but not the other or use a new diode. > > When connected correctly, on pressing the starter button (or key switch), t he diode is reverse biased and has no effect..... all the current passes thr ough the solenoid. On releasing the starter button (or key switch), the col lapsing magnetic field in the starter solenoid tries to induce a high voltag e spike but this is swamped by the diode because the diode short circuits th e current induced by the collapsing magnetic field in the coil. > > Hope this hasn=99t made it more confusing for you. I could and prob ably should have just said ..... connect it like the manual says. > > Best regards > Kingsley in Oz. > > Sent from my iPhone > >>> On 7 Jun 2021, at 7:17 pm, david park wrote: >>> >> =EF=BBAllan have you put ANODE to switch contact? >> >> Dave Park >> >> >>>> On 7 Jun 2021, at 09:35, Alan Burrill wrote: >>>> >>> =EF=BBAre you sure the diode is not faulty? >>> >>> You can check it with an meter set to read resistance. Should be high re sistance one way and low the other. >>> >>> Have you tried connecting it the other way round? >>> >>> Alan >>> >>> Sent from my iPad >>> >>>>> On 7 Jun 2021, at 09:02, david park wrote: >>>>> >>>> =EF=BBBud, >>>> Still confused as Europa Manual wiring diagram shows Anode to Earth? No t switch. >>>> Regards >>>> Dave Park >>>> >>>> >>>>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>>>> >>>>> =EF=BB >>>>> Dave, >>>>> I didn't see anyone commented on your diode. >>>>> >>>>> Pretty much any diode will do. If you get it backwards, the saving gr ace is the start solenoid is looking for 12 volts. Of course, the solenoid m ust be grounded. >>>>> Most mistakes are the ground is left off the solenoid when putting on t he diode. Another problem is guys don=99t insulate the anode side of t he diode and it shorts. >>>>> >>>>> The Rotax manual doesn't comment on the diode. But it is an accepted p ractice to extend the life of the contacts in the starter solenoid. The Eur opa Electrical Chapter 25 advises to use an IN5404 but any will do. >>>>> >>>>> IN5404 >>>>> >>>>> >>>>> silicone diode is shown above. Anode or plus side is on the starter s witch tab and the cathode or negative goes to the ground bolt holding on the starter solenoid. I use at least a #18 or 16 wire from the solenoid fasten ing bolt to the main firewall ground. >>>>> >>>>> Best Regards, >>>>> Bud Yerly >>>>> >>>>> -----Original Message----- >>>>> From: owner-europa-list-server(at)matronics.com <owner-europa-list-server @matronics.com> On Behalf Of david park >>>>> Sent: Wednesday, June 02, 2021 2:44 PM >>>>> To: europa-list(at)matronics.com >>>>> Subject: Europa-List: Starter Diode >>>>> >>>>> >>>>> I fitted a starter Diode and engine would not start. Orientation was a s described with band end cathode on starter terminal and other end to earth ? >>>>> Have I got wrong diode. >>>>> Any advice appreciated >>>>> >>>>> Dave Park G-LDVO >>>>> >>>>> >>>>> - The Europa-List Email Forum - >>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a1 89af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375 82564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby 9t6u3YMcNESeUVsc%3D&reserved=0 >>>>> - MATRONICS WEB FORUMS - >>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925 f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnk nown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3 D&reserved=0 >>>>> - NEW MATRONICS LIST WIKI - >>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6 f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnkno wn%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D&am p;reserved=0 >>>>> - List Contribution Web Site - >>>>> -Matt Dralle, List Admin. >>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F% 2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b61 75508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630 692%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1h aWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4X O38X5pjT4sc%3D&reserved=0 >>>>> >>>>> >>>>> ________________________________________________________________________________
Date: Jun 07, 2021
Thanks everyone, happy now=F0=9F=98=84=F0=9F=98=84=F0=9F=98=84 Dave Park > On 7 Jun 2021, at 11:00, Alan Burrill wrote: > > =EF=BB > > The diode is connected across the starter solenoid coil not the contacts f or the starter motor as per the extract from the build manual above. There i s no diode across the starter motor shown in the build manual diagram, at le ast not my version. > > With 12v positive on the starter contacter coil the diode, with the cathod e or marked end of the diode connected to positive terminal of the starter c oil, is reverse biased and so will not conduct. When the starter button rele ase the falling emf, magnetic field, produces an opposite voltage in the coi l and can spark across the starter switch contacts eventually damaging the c ontacts, the diode shorts out this so the spark does not happen. > > If the diode is shorted out, or the wrong way round, then solenoid will no t work, assuming the solenoid will operate without diode connected as a test to ensure it=99s the wiring of the diode that=99s the problem o f course. > > Isn=99t explaining electrical problems by email fun .=F0=9F=A4=A9 > > Alan > > > Sent from my iPad > >>> On 7 Jun 2021, at 10:44, Kingsley Hurst wrote : >>> >> =EF=BBHello Dave, >> >> I haven=99t got your previous posts in front of me but I assume you want to put the diode across the starter solenoid. >> >> If my assumption is correct, you should connect the anode to the starter m otor side of the starter solenoid and the cathode to the positive (starter s witch) side of the solenoid. >> >> If you have had it connected the other way around and tried starting the e ngine, the diode would have been forward biased trying to carry the full cur rent of the starter motor and more than likely will be ruined. >> >> Either check the diode with a multi meter ( on ohms scale) to ensure it c onducts in one direction but not the other or use a new diode. >> >> When connected correctly, on pressing the starter button (or key switch), the diode is reverse biased and has no effect..... all the current passes t hrough the solenoid. On releasing the starter button (or key switch), the c ollapsing magnetic field in the starter solenoid tries to induce a high volt age spike but this is swamped by the diode because the diode short circuits t he current induced by the collapsing magnetic field in the coil. >> >> Hope this hasn=99t made it more confusing for you. I could and pro bably should have just said ..... connect it like the manual says. >> >> Best regards >> Kingsley in Oz. >> >> Sent from my iPhone >> >>>> On 7 Jun 2021, at 7:17 pm, david park wrote: >>>> >>> =EF=BBAllan have you put ANODE to switch contact? >>> >>> Dave Park >>> >>> >>>>> On 7 Jun 2021, at 09:35, Alan Burrill wrote: >>>>> >>>> =EF=BBAre you sure the diode is not faulty? >>>> >>>> You can check it with an meter set to read resistance. Should be high r esistance one way and low the other. >>>> >>>> Have you tried connecting it the other way round? >>>> >>>> Alan >>>> >>>> Sent from my iPad >>>> >>>>>> On 7 Jun 2021, at 09:02, david park wrote: >>>>>> >>>>> =EF=BBBud, >>>>> Still confused as Europa Manual wiring diagram shows Anode to Earth? N ot switch. >>>>> Regards >>>>> Dave Park >>>>> >>>>> >>>>>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>>>>> >>>>>> =EF=BB >>>>>> Dave, >>>>>> I didn't see anyone commented on your diode. >>>>>> >>>>>> Pretty much any diode will do. If you get it backwards, the saving g race is the start solenoid is looking for 12 volts. Of course, the solenoid must be grounded. >>>>>> Most mistakes are the ground is left off the solenoid when putting on the diode. Another problem is guys don=99t insulate the anode side o f the diode and it shorts. >>>>>> >>>>>> The Rotax manual doesn't comment on the diode. But it is an accepted practice to extend the life of the contacts in the starter solenoid. The E uropa Electrical Chapter 25 advises to use an IN5404 but any will do. >>>>>> >>>>>> IN5404 >>>>>> >>>>>> >>>>>> silicone diode is shown above. Anode or plus side is on the starter s witch tab and the cathode or negative goes to the ground bolt holding on the starter solenoid. I use at least a #18 or 16 wire from the solenoid fasten ing bolt to the main firewall ground. >>>>>> >>>>>> Best Regards, >>>>>> Bud Yerly >>>>>> >>>>>> -----Original Message----- >>>>>> From: owner-europa-list-server(at)matronics.com <owner-europa-list-serve r(at)matronics.com> On Behalf Of david park >>>>>> Sent: Wednesday, June 02, 2021 2:44 PM >>>>>> To: europa-list(at)matronics.com >>>>>> Subject: Europa-List: Starter Diode >>>>>> >>>>>> >>>>>> I fitted a starter Diode and engine would not start. Orientation was a s described with band end cathode on starter terminal and other end to earth ? >>>>>> Have I got wrong diode. >>>>>> Any advice appreciated >>>>>> >>>>>> Dave Park G-LDVO >>>>>> >>>>>> >>>>>> - The Europa-List Email Forum - >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756 a189af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63 7582564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzI iLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZ by9t6u3YMcNESeUVsc%3D&reserved=0 >>>>>> - MATRONICS WEB FORUMS - >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d9 25f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CU nknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM %3D&reserved=0 >>>>>> - NEW MATRONICS LIST WIKI - >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925 f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnk nown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D& amp;reserved=0 >>>>>> - List Contribution Web Site - >>>>>> -Matt Dralle, List Admin. >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b 6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375825648126 30692%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik 1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA 4XO38X5pjT4sc%3D&reserved=0 >>>>>> >>>>>> >>>>>> ________________________________________________________________________________
Date: Jun 07, 2021
=EF=BBHello Alan, I wasn=99t intending to infer the diode should be across the starter m otor as I clearly said starter solenoid in my opening paragraph. Without digging a deeper hole for myself, I offer no excuses for the errors i n my posting other than to say my brain was obviously not engaged properly a fter 8 hrs of driving today. Please accept my apology (and you too Dave) for my misdemeanour. Regards Kingsley. Sent from my iPhone > On 7 Jun 2021, at 8:19 pm, Alan Burrill wrote: > =EF=BB > > > The diode is connected across the starter solenoid coil not the contacts f or the starter motor as per the extract from the build manual above. There i s no diode across the starter motor shown in the build manual diagram, at le ast not my version. > > With 12v positive on the starter contacter coil the diode, with the cathod e or marked end of the diode connected to positive terminal of the starter c oil, is reverse biased and so will not conduct. When the starter button rele ase the falling emf, magnetic field, produces an opposite voltage in the coi l and can spark across the starter switch contacts eventually damaging the c ontacts, the diode shorts out this so the spark does not happen. > > If the diode is shorted out, or the wrong way round, then solenoid will no t work, assuming the solenoid will operate without diode connected as a test to ensure it=99s the wiring of the diode that=99s the problem o f course. > > Isn=99t explaining electrical problems by email fun .=F0=9F=A4=A9 > > Alan > > > Sent from my iPad > >> On 7 Jun 2021, at 10:44, Kingsley Hurst wrote: >> =EF=BBHello Dave, >> >> I haven=99t got your previous posts in front of me but I assume you want to put the diode across the starter solenoid. >> >> If my assumption is correct, you should connect the anode to the starter m otor side of the starter solenoid and the cathode to the positive (starter s witch) side of the solenoid. >> >> If you have had it connected the other way around and tried starting the e ngine, the diode would have been forward biased trying to carry the full cur rent of the starter motor and more than likely will be ruined. >> >> Either check the diode with a multi meter ( on ohms scale) to ensure it c onducts in one direction but not the other or use a new diode. >> >> When connected correctly, on pressing the starter button (or key switch), the diode is reverse biased and has no effect..... all the current passes t hrough the solenoid. On releasing the starter button (or key switch), the c ollapsing magnetic field in the starter solenoid tries to induce a high volt age spike but this is swamped by the diode because the diode short circuits t he current induced by the collapsing magnetic field in the coil. >> >> Hope this hasn=99t made it more confusing for you. I could and pro bably should have just said ..... connect it like the manual says. >> >> Best regards >> Kingsley in Oz. >> >> Sent from my iPhone >> >>> On 7 Jun 2021, at 7:17 pm, david park wrote: >>> =EF=BBAllan have you put ANODE to switch contact? >>> >>> Dave Park >>> >>> >>>> On 7 Jun 2021, at 09:35, Alan Burrill wrote: >>>> =EF=BBAre you sure the diode is not faulty? >>>> >>>> You can check it with an meter set to read resistance. Should be high r esistance one way and low the other. >>>> >>>> Have you tried connecting it the other way round? >>>> >>>> Alan >>>> >>>> Sent from my iPad >>>> >>>>> On 7 Jun 2021, at 09:02, david park wrote: >>>>> =EF=BBBud, >>>>> Still confused as Europa Manual wiring diagram shows Anode to Earth? N ot switch. >>>>> Regards >>>>> Dave Park >>>>> >>>>> >>>>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>>>> =EF=BB >>>>>> Dave, >>>>>> I didn't see anyone commented on your diode. >>>>>> >>>>>> Pretty much any diode will do. If you get it backwards, the saving g race is the start solenoid is looking for 12 volts. Of course, the solenoid must be grounded. >>>>>> Most mistakes are the ground is left off the solenoid when putting on the diode. Another problem is guys don=99t insulate the anode side o f the diode and it shorts. >>>>>> >>>>>> The Rotax manual doesn't comment on the diode. But it is an accepted practice to extend the life of the contacts in the starter solenoid. The E uropa Electrical Chapter 25 advises to use an IN5404 but any will do. >>>>>> >>>>>> IN5404 >>>>>> >>>>>> >>>>>> silicone diode is shown above. Anode or plus side is on the starter s witch tab and the cathode or negative goes to the ground bolt holding on the starter solenoid. I use at least a #18 or 16 wire from the solenoid fasten ing bolt to the main firewall ground. >>>>>> >>>>>> Best Regards, >>>>>> Bud Yerly >>>>>> >>>>>> -----Original Message----- >>>>>> From: owner-europa-list-server(at)matronics.com <owner-europa-list-serve r(at)matronics.com> On Behalf Of david park >>>>>> Sent: Wednesday, June 02, 2021 2:44 PM >>>>>> To: europa-list(at)matronics.com >>>>>> Subject: Europa-List: Starter Diode >>>>>> >>>>>> >>>>>> I fitted a starter Diode and engine would not start. Orientation was a s described with band end cathode on starter terminal and other end to earth ? >>>>>> Have I got wrong diode. >>>>>> Any advice appreciated >>>>>> >>>>>> Dave Park G-LDVO >>>>>> >>>>>> >>>>>> - The Europa-List Email Forum - >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756 a189af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63 7582564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzI iLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZ by9t6u3YMcNESeUVsc%3D&reserved=0 >>>>>> - MATRONICS WEB FORUMS - >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d9 25f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CU nknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM %3D&reserved=0 >>>>>> - NEW MATRONICS LIST WIKI - >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925 f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnk nown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D& amp;reserved=0 >>>>>> - List Contribution Web Site - >>>>>> -Matt Dralle, List Admin. >>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2 F%2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b 6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375825648126 30692%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik 1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA 4XO38X5pjT4sc%3D&reserved=0 ________________________________________________________________________________
Date: Jun 07, 2021
Kingsley, no problem here and I was just ensuring with the diagram that everyone contributing had access to the same info. I think Dave has indicated he has the answer - he might even share what was causing the problem. =F0=9F=98 Alan > On 7 Jun 2021, at 12:02, Kingsley Hurst wrote: > > =EF=BBHello Alan, > > I wasn=99t intending to infer the diode should be across the starter motor as I clearly said starter solenoid in my opening paragraph. > > Without digging a deeper hole for myself, I offer no excuses for the errors in my posting other than to say my brain was obviously not engaged properly after 8 hrs of driving today. > > Please accept my apology (and you too Dave) for my misdemeanour. > > Regards > Kingsley. > > Sent from my iPhone > >> On 7 Jun 2021, at 8:19 pm, Alan Burrill > wrote: >> >> =EF=BB >> >> >> The diode is connected across the starter solenoid coil not the contacts for the starter motor as per the extract from the build manual above. There is no diode across the starter motor shown in the build manual diagram, at least not my version. >> >> With 12v positive on the starter contacter coil the diode, with the cathode or marked end of the diode connected to positive terminal of the starter coil, is reverse biased and so will not conduct. When the starter button release the falling emf, magnetic field, produces an opposite voltage in the coil and can spark across the starter switch contacts eventually damaging the contacts, the diode shorts out this so the spark does not happen. >> >> If the diode is shorted out, or the wrong way round, then solenoid will not work, assuming the solenoid will operate without diode connected as a test to ensure it=99s the wiring of the diode that=99s the problem of course. >> >> Isn=99t explaining electrical problems by email fun.=F0=9F=A4=A9 >> >> Alan >> >> >> Sent from my iPad >> >>> On 7 Jun 2021, at 10:44, Kingsley Hurst wrote: >>> >>> =EF=BBHello Dave, >>> >>> I haven=99t got your previous posts in front of me but I assume you want to put the diode across the starter solenoid. >>> >>> If my assumption is correct, you should connect the anode to the starter motor side of the starter solenoid and the cathode to the positive (starter switch) side of the solenoid. >>> >>> If you have had it connected the other way around and tried starting the engine, the diode would have been forward biased trying to carry the full current of the starter motor and more than likely will be ruined. >>> >>> Either check the diode with a multi meter ( on ohms scale) to ensure it conducts in one direction but not the other or use a new diode. >>> >>> When connected correctly, on pressing the starter button (or key switch), the diode is reverse biased and has no effect..... all the current passes through the solenoid. On releasing the starter button (or key switch), the collapsing magnetic field in the starter solenoid tries to induce a high voltage spike but this is swamped by the diode because the diode short circuits the current induced by the collapsing magnetic field in the coil. >>> >>> Hope this hasn=99t made it more confusing for you. I could and probably should have just said ..... connect it like the manual says. >>> >>> Best regards >>> Kingsley in Oz. >>> >>> Sent from my iPhone >>> >>>> On 7 Jun 2021, at 7:17 pm, david park wrote: >>>> >>>> =EF=BBAllan have you put ANODE to switch contact? >>>> >>>> Dave Park >>>> >>>> >>>>> On 7 Jun 2021, at 09:35, Alan Burrill wrote: >>>>> >>>>> =EF=BBAre you sure the diode is not faulty? >>>>> >>>>> You can check it with an meter set to read resistance. Should be high resistance one way and low the other. >>>>> >>>>> Have you tried connecting it the other way round? >>>>> >>>>> Alan >>>>> >>>>> Sent from my iPad >>>>> >>>>>> On 7 Jun 2021, at 09:02, david park wrote: >>>>>> >>>>>> =EF=BBBud, >>>>>> Still confused as Europa Manual wiring diagram shows Anode to Earth? Not switch. >>>>>> Regards >>>>>> Dave Park >>>>>> >>>>>> >>>>>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>>>>> >>>>>>> =EF=BB >>>>>>> Dave, >>>>>>> I didn't see anyone commented on your diode. >>>>>>> >>>>>>> Pretty much any diode will do. If you get it backwards, the saving grace is the start solenoid is looking for 12 volts. Of course, the solenoid must be grounded. >>>>>>> Most mistakes are the ground is left off the solenoid when putting on the diode. Another problem is guys don=99t insulate the anode side of the diode and it shorts. >>>>>>> >>>>>>> The Rotax manual doesn't comment on the diode. But it is an accepted practice to extend the life of the contacts in the starter solenoid. The Europa Electrical Chapter 25 advises to use an IN5404 but any will do. >>>>>>> >>>>>>> IN5404 >>>>>>> >>>>>>> >>>>>>> silicone diode is shown above. Anode or plus side is on the starter switch tab and the cathode or negative goes to the ground bolt holding on the starter solenoid. I use at least a #18 or 16 wire from the solenoid fastening bolt to the main firewall ground. >>>>>>> >>>>>>> >>>>>>> Best Regards, >>>>>>> Bud Yerly >>>>>>> >>>>>>> -----Original Message----- >>>>>>> From: owner-europa-list-server(at)matronics.com On Behalf Of david park >>>>>>> Sent: Wednesday, June 02, 2021 2:44 PM >>>>>>> To: europa-list(at)matronics.com >>>>>>> Subject: Europa-List: Starter Diode >>>>>>> > >>>>>>> >>>>>>> I fitted a starter Diode and engine would not start. Orientation was as described with band end cathode on starter terminal and other end to earth? >>>>>>> Have I got wrong diode. >>>>>>> Any advice appreciated >>>>>>> >>>>>>> Dave Park G-LDVO >>>>>>> >>>>>>> >>>>>>> - The Europa-List Email Forum - >>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matr onics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C4756a189af0d42 b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6375825648 12620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBT iI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUHkZby9t 6u3YMcNESeUVsc%3D&reserved=0 >>>>>>> - MATRONICS WEB FORUMS - >>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.m atronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f1c0%7 C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknown%7 CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6M n0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUhMM%3D& amp;reserved=0 >>>>>>> - NEW MATRONICS LIST WIKI - >>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwiki.mat ronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d925f6f1c0%7C8 4df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CUnknown%7CT WFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0 %3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3D& reserved=0 >>>>>>> - List Contribution Web Site - >>>>>>> -Matt Dralle, List Admin. >>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matr onics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d42b6175508d92 5f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7C Unknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwi LCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2FA4XO3 8X5pjT4sc%3D&reserved=0 ________________________________________________________________________________
Date: Jun 07, 2021
Ptroblem started while rewiring a new panel and engine would not start due t o a different problem. When looking to replace diode I got confused with dif fering advice and written instructions, but was sure it should be as diagra m. All good now ready for continental adventures again?? Regards Dave Park > On 7 Jun 2021, at 12:29, Alan Burrill wrote: > > =EF=BBKingsley, no problem here and I was just ensuring with the diagra m that everyone contributing had access to the same info. > > I think Dave has indicated he has the answer - he might even share what wa s causing the problem. =F0=9F=98 > > Alan > >> On 7 Jun 2021, at 12:02, Kingsley Hurst wrote: >> >> =EF=BBHello Alan, >> >> I wasn=99t intending to infer the diode should be across the starte r motor as I clearly said starter solenoid in my opening paragraph. >> >> Without digging a deeper hole for myself, I offer no excuses for the erro rs in my posting other than to say my brain was obviously not engaged proper ly after 8 hrs of driving today. >> >> Please accept my apology (and you too Dave) for my misdemeanour. >> >> Regards >> Kingsley. >> >> Sent from my iPhone >> >>>> On 7 Jun 2021, at 8:19 pm, Alan Burrill wrote: >>>> >>> =EF=BB >>> >>> >>> The diode is connected across the starter solenoid coil not the contacts for the starter motor as per the extract from the build manual above. There is no diode across the starter motor shown in the build manual diagram, at l east not my version. >>> >>> With 12v positive on the starter contacter coil the diode, with the cath ode or marked end of the diode connected to positive terminal of the starter coil, is reverse biased and so will not conduct. When the starter button re lease the falling emf, magnetic field, produces an opposite voltage in the c oil and can spark across the starter switch contacts eventually damaging the contacts, the diode shorts out this so the spark does not happen. >>> >>> If the diode is shorted out, or the wrong way round, then solenoid will n ot work, assuming the solenoid will operate without diode connected as a tes t to ensure it=99s the wiring of the diode that=99s the problem o f course. >>> >>> Isn=99t explaining electrical problems by email fun .=F0=9F=A4=A9 >>> >>> Alan >>> >>> >>> Sent from my iPad >>> >>>>> On 7 Jun 2021, at 10:44, Kingsley Hurst wro te: >>>>> >>>> =EF=BBHello Dave, >>>> >>>> I haven=99t got your previous posts in front of me but I assume y ou want to put the diode across the starter solenoid. >>>> >>>> If my assumption is correct, you should connect the anode to the starte r motor side of the starter solenoid and the cathode to the positive (starte r switch) side of the solenoid. >>>> >>>> If you have had it connected the other way around and tried starting th e engine, the diode would have been forward biased trying to carry the full c urrent of the starter motor and more than likely will be ruined. >>>> >>>> Either check the diode with a multi meter ( on ohms scale) to ensure it conducts in one direction but not the other or use a new diode. >>>> >>>> When connected correctly, on pressing the starter button (or key switch ), the diode is reverse biased and has no effect..... all the current passes through the solenoid. On releasing the starter button (or key switch), the collapsing magnetic field in the starter solenoid tries to induce a high vo ltage spike but this is swamped by the diode because the diode short circuit s the current induced by the collapsing magnetic field in the coil. >>>> >>>> Hope this hasn=99t made it more confusing for you. I could and p robably should have just said ..... connect it like the manual says. >>>> >>>> Best regards >>>> Kingsley in Oz. >>>> >>>> Sent from my iPhone >>>> >>>>>> On 7 Jun 2021, at 7:17 pm, david park wrote: >>>>>> >>>>> =EF=BBAllan have you put ANODE to switch contact? >>>>> >>>>> Dave Park >>>>> >>>>> >>>>>>> On 7 Jun 2021, at 09:35, Alan Burrill wrote: >>>>>>> >>>>>> =EF=BBAre you sure the diode is not faulty? >>>>>> >>>>>> You can check it with an meter set to read resistance. Should be high resistance one way and low the other. >>>>>> >>>>>> Have you tried connecting it the other way round? >>>>>> >>>>>> Alan >>>>>> >>>>>> Sent from my iPad >>>>>> >>>>>>>> On 7 Jun 2021, at 09:02, david park wrote: >>>>>>>> >>>>>>> =EF=BBBud, >>>>>>> Still confused as Europa Manual wiring diagram shows Anode to Earth? Not switch. >>>>>>> Regards >>>>>>> Dave Park >>>>>>> >>>>>>> >>>>>>>>> On 7 Jun 2021, at 01:06, Bud Yerly wrote: >>>>>>>>> >>>>>>>> =EF=BB >>>>>>>> Dave, >>>>>>>> I didn't see anyone commented on your diode. >>>>>>>> >>>>>>>> Pretty much any diode will do. If you get it backwards, the saving grace is the start solenoid is looking for 12 volts. Of course, the soleno id must be grounded. >>>>>>>> Most mistakes are the ground is left off the solenoid when putting o n the diode. Another problem is guys don=99t insulate the anode side o f the diode and it shorts. >>>>>>>> >>>>>>>> The Rotax manual doesn't comment on the diode. But it is an accept ed practice to extend the life of the contacts in the starter solenoid. The Europa Electrical Chapter 25 advises to use an IN5404 but any will do. >>>>>>>> >>>>>>>> IN5404 >>>>>>>> >>>>>>>> >>>>>>>> silicone diode is shown above. Anode or plus side is on the starte r switch tab and the cathode or negative goes to the ground bolt holding on t he starter solenoid. I use at least a #18 or 16 wire from the solenoid fast ening bolt to the main firewall ground. >>>>>>>> >>>>>>>> >>>>>>>> Best Regards, >>>>>>>> Bud Yerly >>>>>>>> >>>>>>>> -----Original Message----- >>>>>>>> From: owner-europa-list-server(at)matronics.com <owner-europa-list-ser ver(at)matronics.com> On Behalf Of david park >>>>>>>> Sent: Wednesday, June 02, 2021 2:44 PM >>>>>>>> To: europa-list(at)matronics.com >>>>>>>> Subject: Europa-List: Starter Diode >>>>>>>> >>>>>>>> >>>>>>>> I fitted a starter Diode and engine would not start. Orientation wa s as described with band end cathode on starter terminal and other end to ea rth? >>>>>>>> Have I got wrong diode. >>>>>>>> Any advice appreciated >>>>>>>> >>>>>>>> Dave Park G-LDVO >>>>>>>> >>>>>>>> >>>>>>>> - The Europa-List Email Forum - >>>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A %2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=04%7C01%7C%7C47 56a189af0d42b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C 637582564812620700%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=d2yFiqBfE8TCD9qLmlbZwUH kZby9t6u3YMcNESeUVsc%3D&reserved=0 >>>>>>>> - MATRONICS WEB FORUMS - >>>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A %2F%2Fforums.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508 d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7 CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL CJXVCI6Mn0%3D%7C1000&sdata=SBC%2BHeUkzr3LiivK88gfvqg0yBuA5ly76yuWCWUUh MM%3D&reserved=0 >>>>>>>> - NEW MATRONICS LIST WIKI - >>>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A %2F%2Fwiki.matronics.com%2F&data=04%7C01%7C%7C4756a189af0d42b6175508d9 25f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637582564812630692%7CU nknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C1000&sdata=o8qJjaCYZwDfnYZL5ZTUYwVjcHuo0CD7LEX42XsDfhY%3 D&reserved=0 >>>>>>>> - List Contribution Web Site - >>>>>>>> -Matt Dralle, List Admin. >>>>>>>> --> https://na01.safelinks.protection.outlook.com/?url=http%3A %2F%2Fwww.matronics.com%2Fcontribution&data=04%7C01%7C%7C4756a189af0d4 2b6175508d925f6f1c0%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63758256481 2630692%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2F4PsRd1psVqvnaU7%2FNqFY9pTbwXM%2 FA4XO38X5pjT4sc%3D&reserved=0 > ________________________________________________________________________________
Subject: Re: XS Tail wheel assembly
Date: Jun 07, 2021
Make sure you apply Mod77 when you fit the tailwheel assembly; its made a huge difference to affective ground control on the aircraft... flew circuits for the first time yesterday after fitting the mod and found it more precise and responsive to minor rudder inputs and ability to maintain centerline... finding it no more challenging than a Motorfalke to handle on the ground. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502278#502278 ________________________________________________________________________________
Date: Jun 07, 2021
PhilWhile I recognize you as a highly experienced Europa builder, I pass along two modifications to the stock Europa tailwheel which have been recommended to me by others. First, add a stop to prevent the tailwheel from rotating more than approximately 30 deg in either direction...shown below is a half inch thick aluminum stopmine came to me as part of the Singleton tail wheel mod. Second, I cut off the ears of the stock fitting and made up a bracket from 1/8=9D 4130 plate configured to a design suggested to me by William Mills, RIP, which has two beneficial attributes: there are 3 sets of holes which allow for adjusting the sensitivity of rudder pedal inputs(the outermost set of holes for the novice and allowing for less sensitivity, and by using the innermost sets of holes the result is less sensitivity and decreased turning radius) and the sets of holes are further forward than the holes in the stock =9Cears=9D so that string lines dropping thru the holes are perfectly aligned with the vertical tail wheel pivot rod which decreases the strain on the entire assembly. PS: Ignore the bronze split-bolts shown in lieu of the second set of nicopress sleeves. > On Jun 7, 2021, at 2:27 AM, flyingphil2 wrote: > I'm looking for all the parts to make a complete XS tailwheel assembly. > I ideally want new, unused parts - does anyone have any bits lying around that they'd like to sell? > > Thanks, > Phil > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502262#502262 ________________________________________________________________________________
Date: Jun 08, 2021
Subject: Auto pilot pitch control.
I seem to remember at some time seeing where a Europa builder put the auto pilot pitch servo on the floor in front of the control column with the push rod connected to the elevator circuit via the bottom of the control column mechanism. I would very much appreciate it if someone can advise me who incorporated this idea please or point me in the direction of photos of same. Was it Ira Rampil by any chance? Many thanks Kingsley in Oz. Sent from my iPhone ________________________________________________________________________________
Subject: Re: Europa Monowheel - Cross Country Flying Machine
Date: Jun 08, 2021
Erich and others, Thanks for your input on the flap position on landing. Excellent info and it really makes me realize that I just need to learn to land the mono. so for now I will not think about any mods until I build more time in it. I really wanted to do OSH but my father is falling ill and need to use vacation time to go visit him (he's in Spain). So no OSH this year. In a way I think I want to build a little more time in it before going there anyway. I am a big fan of Triple Tree and will really try to go there if I can. It happens in September. A little closer and can be done with minimal time off from work. That's a nice grass runway for the mono! Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502291#502291 ________________________________________________________________________________
Date: Jun 08, 2021
Phil, Sorry to disagree with Fred but I feel strongly you do not want to limit tailwheel travel to 30 degrees. I too have the Singleton mod and as you can see it allows the tail wheel to turn around 80 degrees in either direction. This is a great help in manoeuvring either whilst taxying or pulling the plane around in the hangar. Experienced mono pilots can almost pivot on the main wheel with a judicious use of throttle and brake.(Emphasis on judicious - overdo it and you go A over T and break the prop). I have no figures for it but I would be very surprised if you need as much as 20 degree tail wheel turn in the process of landing or T/O, where the emphasis should be on sticking meticulously to a straight line, correcting any deviation sooner rather than later. I understand the function of the stop is to prevent the wheel twisting beyond 90 degrees when the rudder cables would be crossed and rudder action would make things worse rather than going back to neutral position. Regards, David Joyce GXSDJ On 2021-06-08 06:19, Fred Klein wrote: > Phil...While I recognize you as a highly experienced Europa builder, I > pass along two modifications to the stock Europa tailwheel which have > been recommended to me by others. > > First, add a stop to prevent the tailwheel from rotating more than > approximately 30 deg in either direction...shown below is a half inch > thick aluminum stop...mine came to me as part of the Singleton tail > wheel mod. > > Second, I cut off the ears of the stock fitting and made up a bracket > from 1/8" 4130 plate configured to a design suggested to me by William > Mills, RIP, which has two beneficial attributes: there are 3 sets of > holes which allow for adjusting the sensitivity of rudder pedal > inputs...(the outermost set of holes for the novice and allowing for > less sensitivity, and by using the innermost sets of holes the result > is less sensitivity and decreased turning radius)... and the sets of > holes are further forward than the holes in the stock "ears" so that > string lines dropping thru the holes are perfectly aligned with the > vertical tail wheel pivot rod which decreases the strain on the entire > assembly. > > PS: Ignore the bronze split-bolts shown in lieu of the second set of > nicopress sleeves. > >> On Jun 7, 2021, at 2:27 AM, flyingphil2 >> wrote: >> >> I'm looking for all the parts to make a complete XS tailwheel >> assembly. >> I ideally want new, unused parts - does anyone have any bits lying >> around that they'd like to sell? >> >> Thanks, >> Phil >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=502262#502262 ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Jun 08, 2021
Subject: Re: Auto pilot pitch control.
Kingsley I put my lateral servo on the cockpit floor and the pitch in the rear fuse...if you want pics let me know if that helps Will William Daniell LONGPORT +1 786 878 0246 On Tue, Jun 8, 2021 at 6:55 AM Kingsley Hurst wrote: > kingsnjan(at)westnet.com.au> > > I seem to remember at some time seeing where a Europa builder put the auto > pilot pitch servo on the floor in front of the control column with the push > rod connected to the elevator circuit via the bottom of the control column > mechanism. > > I would very much appreciate it if someone can advise me who incorporated > this idea please or point me in the direction of photos of same. > > Was it Ira Rampil by any chance? > > Many thanks > Kingsley in Oz. > > Sent from my iPhone > > ________________________________________________________________________________
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Date: Jun 08, 2021
That was probably me. I'll see if I still have some photos of what I did. On Tue, Jun 8, 2021 at 5:55 AM Kingsley Hurst wrote: > kingsnjan(at)westnet.com.au> > > I seem to remember at some time seeing where a Europa builder put the auto > pilot pitch servo on the floor in front of the control column with the push > rod connected to the elevator circuit via the bottom of the control column > mechanism. > > I would very much appreciate it if someone can advise me who incorporated > this idea please or point me in the direction of photos of same. > > Was it Ira Rampil by any chance? > > Many thanks > Kingsley in Oz. > > Sent from my iPhone > > ________________________________________________________________________________
Date: Jun 09, 2021
Subject: G-GIWT air tests
A problem on my early flights, when I transmit, trim indicator goes dim and eventually trim does not work if radio used a lot. Radio savvy friend told me to isolate radio antenna by substituting my handheld Arial, this worked but only to prove I and an antenna/ trim issue. My radio man has given me two ferrite sleeves to fit around the trim indicator cables which he suspects are the issue; but he recommended that I ask the Europa community who have no doubt seen this issue. I have carefully routed trim cables on port side of fuselage and antenna on Stbd. I await the Miriad of expert experience guys. Thanks Alan Twigg Europa Motorglider Kit 463 Sent from my iPad ________________________________________________________________________________
From: "fklein(at)orcasonline.com" <fklein(at)orcasonline.com>
Date: Jun 09, 2021
Davidyou wrote: "Sorry to disagree with Fred but I feel strongly you do not want to limit tailwheel travel to 30 degrees. I too have the Singleton mod and as you can see it allows the tail wheel to turn around 80 degrees in either direction.=9D Of course I defer to your judgement and experience on all matters EuropaI believe I had written to limit tailwheel travel to 30 deg. in either direction, and I had just eyeballed the 30 deg. from my build photoit may well be closer to 40 deg. in either direction which would yield the 80 deg. you mention which appears to be what your photo indicates. As I recall, Graham=99s instructions called for dressing the limiting block so that it mates with the tail spring when tailwheel rotates to its max. Some additional dressing of my install may be called for. Thanks for your comment, Fred > On Jun 8, 2021, at 8:25 AM, davidjoyce(at)doctors.org.uk wrote: > > Phil, Sorry to disagree with Fred but I feel strongly you do not want to limit tailwheel travel to 30 degrees. I too have the Singleton mod and as you can see it allows the tail wheel to turn around 80 degrees in either direction. This is a great help in manoeuvring either whilst taxying or pulling the plane around in the hangar. Experienced mono pilots can almost pivot on the main wheel with a judicious use of throttle and brake.(Emphasis on judicious - overdo it and you go A over T and break the prop). I have no figures for it but I would be very surprised if you need as much as 20 degree tail wheel turn in the process of landing or T/O, where the emphasis should be on sticking meticulously to a straight line, correcting any deviation sooner rather than later. I understand the function of the stop is to prevent the wheel twisting beyond 90 degrees when the rudder cables would be crossed and rudder action would make things worse rather than going back to neutral position. > > Regards, David Joyce GXSDJ > ________________________________________________________________________________
Date: Jun 09, 2021
Subject: Re: G-GIWT air tests
I haven't seen this issue but I did have an issue with my glass panels and I successfully used ferrite beads to resolve my problem. If possible loop the wires through the bead a couple of times. On Wed, Jun 9, 2021 at 11:21 AM Alan Twigg wrote: > > A problem on my early flights, when I transmit, trim indicator goes dim > and eventually trim does not work if radio used a lot. > Radio savvy friend told me to isolate radio antenna by substituting my > handheld Arial, this worked but only to prove I and an antenna/ trim issue. > My radio man has given me two ferrite sleeves to fit around the trim > indicator cables which he suspects are the issue; but he recommended that I > ask the Europa community who have no doubt seen this issue. > I have carefully routed trim cables on port side of fuselage and antenna > on Stbd. > I await the Miriad of expert experience guys. > Thanks > Alan Twigg > Europa Motorglider > Kit 463 > > Sent from my iPad > > ________________________________________________________________________________
Date: Jun 10, 2021
Alan, My trim indicator also goes berserk when I press the PTT. Per Becker recommendation I moved the radio's power feed away from the avionics power bus and connected it directly to the battery bus, with its own inline fuse. This was done more to reduce noise that was being injected by my Garmin 496 mounted in the panel (this thing is incredibly noisy) than to fix the trim indicator issue. BTW, my effort was placed mostly on having a dead quiet electrical system (from an audio standpoint) and I was extremely successful in doing this. The only thing I can hear in the air is the processor in my tablet doing a little work once in a while :) Back to the trim issue, I just ignore it. When I am flying I don't even realize this happens as I'm generally not looking at the trim indicator when I press the PTT. If you must fix it Best, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502309#502309 ________________________________________________________________________________
Date: Jun 10, 2021
Thanks for all of your comments on this - it's really useful. Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502310#502310 ________________________________________________________________________________
Subject: One radio many sound inputs
Date: Jun 10, 2021
Hello All, As my lovely gauges arrived for the Europa, they all seem to have SOUND outputs. Meanwhile, my XCOM 760 Radio has a single "MUSIC" input. Looking for Audio Panels, I find lovely bits of kit from $2000 to $7000 which seems excessive on a 2 place homebuilt. Meanwhile, I can buy a HiFi Quality sound mixer meant for street buskers for around $65 - most of these will require a voltage converter from 12v to the classic USB 5v, but otherwise very cheap. What are other builders doing ? I have 2 x AV30 that can scream at you if you exceed AOA, The Kanardia airspeed indicator that can warn if exceeded VNE etc, even my trusty old Garmin 296 can speak to me in UK English (have not had this working yet), plus a stall warner and so on, so I am thinking I will need around 4 to 6 sound inputs to feed my XCOM radio if I wish the sound to be played over the headsets. Once reasonable levels are set, I will not likely need to adjust the input sound levels. My Bose A20 already has a music input jack point, so I actually have that bit covered. Thoughts ? -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502313#502313 ________________________________________________________________________________
Date: Jun 11, 2021
Subject: Re: One radio many sound inputs
Trevor, I refitted my panel a couple of years back with a G5 Touch system and all the bells and whistles. It needed an audio panel to blend all the inputs but I didn't want to make room on the panel for a surface mounted one. It was a relief, planning wise and financially when my electronic guru recommended the Gretz Aero audio mixer, available from Aircraft Spruce for a mere 160 dollars. No voltage reducer needed. It fits inside the panel readily accessible(for initial set up) behind my right hand removable sub panel. It has worked faultlessly since. Regards, David Joyce, GXSDJ On 2021-06-10 23:36, trevord wrote: > > Hello All, > > As my lovely gauges arrived for the Europa, they all seem to have SOUND > outputs. Meanwhile, my XCOM 760 Radio has a single "MUSIC" input. > > Looking for Audio Panels, I find lovely bits of kit from $2000 to $7000 > which seems excessive on a 2 place homebuilt. Meanwhile, I can buy a > HiFi Quality sound mixer meant for street buskers for around $65 - most > of these will require a voltage converter from 12v to the classic USB > 5v, but otherwise very cheap. > > What are other builders doing ? > > I have 2 x AV30 that can scream at you if you exceed AOA, The Kanardia > airspeed indicator that can warn if exceeded VNE etc, even my trusty > old Garmin 296 can speak to me in UK English (have not had this working > yet), plus a stall warner and so on, so I am thinking I will need > around 4 to 6 sound inputs to feed my XCOM radio if I wish the sound to > be played over the headsets. Once reasonable levels are set, I will not > likely need to adjust the input sound levels. > > My Bose A20 already has a music input jack point, so I actually have > that bit covered. > > Thoughts ? > > -------- > Trevor > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502313#502313 > ________________________________________________________________________________
Date: Jun 11, 2021
Thanks David, This looks perfect functionally - great to hear you had reliable service. Just a couple of further questions... What radio do you have that it feeds into ? I have read that the XCOM760 does not work properly unless with an aircraft audio panel - something to do with impedance .... or do you feed the radio INTO the Gretz and then from the Gretz to the headset ? The "range" of input/outputs suggest that it can do both. I guess the downside would be if everything goes through the Gretz and then to the headset, then if it fails, I would lose the radio also ... Thanks again, this is exactly the kind of thing I was looking for... I also have no panel space ! Regards Trevor -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502324#502324 ________________________________________________________________________________
Date: Jun 11, 2021
Trevor< I am embarrassed to say that I found myself with about 20,000 surplus insurance money to play with after my take off incident had resulted in a technical write off of my plane and Nev Eyre (bless him) and Ivan Shaw had masterminded an inexpensive means of repairing the broken bodywork. So I bought a dream panel. based around the G3X Touch with G5 back up, three axis autopilot, full ADSB etc. The radio is a Garmin GNC255 nav/com. There were five inputs into the audio panel - radio, SmartAss, transponder, EFIS and Nav, but space for lots more. The combined output goes to the headsets. I wouldn't worry about the reliability aspect - I think the components are mostly simple resistors that should have a near infinite life expectation. On top of that I see in the blurb that it says it is possible to arrange to have fail safe connection to your primary (radio) source. Best of luck, David On 2021-06-11 09:34, trevord wrote: > > Thanks David, > > This looks perfect functionally - great to hear you had reliable > service. > > Just a couple of further questions... > > What radio do you have that it feeds into ? I have read that the > XCOM760 does not work properly unless with an aircraft audio panel - > something to do with impedance .... or do you feed the radio INTO the > Gretz and then from the Gretz to the headset ? > > The "range" of input/outputs suggest that it can do both. > > I guess the downside would be if everything goes through the Gretz and > then to the headset, then if it fails, I would lose the radio also ... > > Thanks again, this is exactly the kind of thing I was looking for... I > also have no panel space ! > > Regards > Trevor > > -------- > Trevor > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502324#502324 > ________________________________________________________________________________
Date: Jun 11, 2021
Great Thanks Regards Trevor -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502326#502326 ________________________________________________________________________________
Date: Jun 11, 2021
Just a small point, Whilst the units are still available from Aircraft Spruce, the company's web site is gone and the emails to info(at)gretzaero.com bounce. Do you know of another contact for the company ? Regards Trevor -------- Trevor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502327#502327 ________________________________________________________________________________
Date: Jun 11, 2021
Trevor, Afraid not. David On 2021-06-11 11:06, trevord wrote: > > Just a small point, > > Whilst the units are still available from Aircraft Spruce, the > company's web site is gone and the emails to info(at)gretzaero.com bounce. > > Do you know of another contact for the company ? > > Regards > Trevor > > -------- > Trevor > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502327#502327 > ________________________________________________________________________________
From: Richard Churchill-Coleman <richard.churchill-coleman(at)sky.com>
Date: Jun 11, 2021
Trevor I have bought (but not yet installed) a unit with a similar functionality th at is still available here: http://vx-aviation.com/AMX.html Rgds Richard Sent from my iPhone > On 11 Jun 2021, at 11:14, davidjoyce(at)doctors.org.uk wrote: > > =EF=BB > Trevor, Afraid not. David > > > > >> On 2021-06-11 11:06, trevord wrote: >> >> >> Just a small point, >> >> Whilst the units are still available from Aircraft Spruce, the company's w eb site is gone and the emails to info(at)gretzaero.com bounce. >> >> Do you know of another contact for the company ? >> >> Regards >> Trevor >> >> -------- >> Trevor >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=502327#502327 >> >> >> >> >> http://forums.matronics.com >> sp; &nb"http://www.matronics.com/contribution" tar get="_blank" rel="noopener n==== >> >> >> ========================== ========================== ========================= _ ========================== ========================== ========================== ========================== ========================== ============== ________________________________________________________________________________
Date: Jun 11, 2021
Hi Trevor, Whilst I cannot endorse this product, it has been used successfully to mix, balance & amplify audio sources. Regards, Roger https://www.amazon.co.uk/Behringer-MX400-Micromix-Noise-Channel/dp/B000KGY AYQ/ref=sr_1_6?dchild=1&keywords=behringer+400&qid=1623409437&sr= 8-6 > On 11 Jun 2021, at 11:06, trevord wrote: > > > Just a small point, > > Whilst the units are still available from Aircraft Spruce, the company's web site is gone and the emails to info(at)gretzaero.com bounce. > > Do you know of another contact for the company ? > > Regards > Trevor > > -------- > Trevor > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502327#502327 > > > > > > > > > ________________________________________________________________________________
Date: Jun 12, 2021
Alan, The trim motor is located very close to the comm antenna if your antenna is located in the rudder flange per the manual. If the comm antenna is not well tuned, there may be excessive radiation from it that interferes with the trim motor. I'd suggest you check the standing wave ratio (SWR) of the comm antenna at different frequencies. You might try wrapping the trim motor in conductive foil (aluminum foil) to see if shielding it solves the problem. Ferrite sleeves often do not solve the problem as they are not universal and the ones that are readily available are not correct for our VHF frequencies. I tried a lot of ferrite sleeves when I had my Blue Mountain EFIS trying to solve problems with very little success. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502344#502344 ________________________________________________________________________________
Date: Jun 12, 2021
Thanks Jim, I put an antenna behind the cockpit in the roof, the ferrite sleeve seems to have fixed the problem, tommorrow I will fly to prove it. Alan Sent from my iPhone > On 12 Jun 2021, at 15:29, h&jeuropa wrote: > > > Alan, > The trim motor is located very close to the comm antenna if your antenna is located in the rudder flange per the manual. If the comm antenna is not well tuned, there may be excessive radiation from it that interferes with the trim motor. I'd suggest you check the standing wave ratio (SWR) of the comm antenna at different frequencies. > > You might try wrapping the trim motor in conductive foil (aluminum foil) to see if shielding it solves the problem. > > Ferrite sleeves often do not solve the problem as they are not universal and the ones that are readily available are not correct for our VHF frequencies. I tried a lot of ferrite sleeves when I had my Blue Mountain EFIS trying to solve problems with very little success. > > Jim > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502344#502344 > > > > > > > > > ________________________________________________________________________________
Date: Jun 12, 2021
Alan, I recently installed a new Garmin 200 into my panel and I ran my coax across my FP-5 fuel flow and on certain frequencies 134 and up the FP-5 was a light show and finally went blank. If your trim indicator is in the panel, rerouting the com may help, shielding the trim indicator, if nearby the radio may be an area to look at if the coil doesn't work. Finally, if you run your com coax on the same side as the 5 wire trim bundle, that has caused problems before. As Jim said, ferrites can work but there may still be certain frequencies that interfere. A Faraday box does work. You don't need Mu metal as there isn't a lot of magnetic flux in the coax. That said, I have one of the old style needle type Mac trim indicators and it can be fluctuated by high current ops or the nearby new Garmin Com radio to my surprise. Keep plugging away. Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Alan Twigg Sent: Saturday, June 12, 2021 11:01 AM Subject: Re: Europa-List: Re: G-GIWT air tests Thanks Jim, I put an antenna behind the cockpit in the roof, the ferrite sleeve seems to have fixed the problem, tommorrow I will fly to prove it. Alan Sent from my iPhone > On 12 Jun 2021, at 15:29, h&jeuropa wrote: > > > Alan, > The trim motor is located very close to the comm antenna if your antenna is located in the rudder flange per the manual. If the comm antenna is not well tuned, there may be excessive radiation from it that interferes with the trim motor. I'd suggest you check the standing wave ratio (SWR) of the comm antenna at different frequencies. > > You might try wrapping the trim motor in conductive foil (aluminum foil) to see if shielding it solves the problem. > > Ferrite sleeves often do not solve the problem as they are not universal and the ones that are readily available are not correct for our VHF frequencies. I tried a lot of ferrite sleeves when I had my Blue Mountain EFIS trying to solve problems with very little success. > > Jim > > > > > Read this topic online here: > > https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D502344%23502344&data=04%7C01%7C%7Cf81d5bfdcc07466d0eff08d92db3a3f3%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637591071834005806%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=HtKN5tPSut76HRtU7shin%2Fd8xkoVsuIPfk0o8Xqx8Cg%3D&reserved=0 > > > > > > > > > ________________________________________________________________________________
Date: Jun 13, 2021
Please remove me from all lists thank you sldpileit(at)aol.com -----Original Message----- From: Alan Twigg <alan.twigg775(at)gmail.com> Sent: Sat, Jun 12, 2021 11:01 am Subject: Re: Europa-List: Re: G-GIWT air tests Thanks Jim, I put an antenna=C2- behind the cockpit in the roof, the ferr ite sleeve seems to have fixed the problem, tommorrow I will fly to prove i t. Alan Sent from my iPhone
May 04, 2021 - June 14, 2021
Europa-Archive.digest.vol-oh
