Europa-Archive.digest.vol-ot
February 15, 2023 - May 10, 2023
      > sensor I
      > used the time and speed to tell me how to jet the carb (mostly the speed).
      >  I was running Shell V'Power and I tried 100LL avgas which slowed me down
      > actually,
      > puzzled I tested the specific gravity of both fuel types...big difference.
      > 100LL is always .72 but auto fuel changes greatly seasonally.  The summer
      > Shell
      > VPower was .82 giving much richer mixture, in winter I tested Shell VPower
      > and it was .75.
      > The lesson is, if winter fuel has a lighter specific gravity it will give
      > you a
      > leaner mixture than what you had in summer.  Fuel density matters too
      > http://forums.matronics.com/viewtopic.php?p=510168#510168
      > ________________________________  Message 6
      > _____________________________________
      > From: William Daniell <wdaniell.longport(at)gmail.com>
      > Subject: Re: Europa-List: No charge lamp stays on
      > I had the same issue - Bob Nickolls said that the charge light system in
      > the Ducati regulator is very primitive and not to pay attention.   A
      > reliable voltmeter is required.
      > Eventually my charge light went out by itself.  The battery charged just
      > fine while it was on.
      > William Daniell
      > LONGPORT
      > +1 786 878 0246
      > On Tue, Feb 14, 2023 at 12:46 PM Paul Mansfield
      > wrote:
      > > Which video Martin (link or vid ref number)?
      > > I thought I'd watched them all, but don't recall one on Reg/Rec or
      > > charging troubleshooting...!
      > > Cheers,
      > > Paul M
      > > G-PLPM
      > > -------- Original message --------
      > > From: Martin Tuck <mjktuck(at)cs.com>
      > > Date: 14/02/2023 16:30 (GMT+00:00)
      > > To: europa-list(at)matronics.com
      > > Thanks Giles,
      > > I haven=99t done anything to the aircraft since the last time I fle
      > w and all
      > > seemed well then. I found a good video on troubleshooting the system on t
      > he
      > > Rotax Owners site so I=99ll be looking to perform those checks and
      > see what
      > > might be going on.
      > > Martin
      > > Sent from my iPhone
      > > On Feb 14, 2023, at 5:07 AM, GTH  wrote:
      > > =EF=BB
      > > Le 14/02/2023 ?? 03:26, Martin Tuck a ??crit??:
      > >  Hi Folks, *
      > > Hi Martin,
      > > I'd first check actual voltages with a reliable voltmeter, then perform a
      > > serious check of the wiring and connections.
      > > Did your alternator charge before? Did you disconnect/connect *anything *
      > > since last time you ran the engine with no issues?
      > > Best regards
      > > Gilles
      > > http://contrails.free.fr
      > >  rails.free.fr%2F&data=05%7C01%7C%7C8ea3591876ba4f2447af08db0ea8cabc%7C84d
      > f9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638119890335969623%7CUnknown%7CTWFp
      > bGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%
      > 7C3000%7C%7C%7C&sdata=InRipetsCPzljMdA%2BeJ5Dd3R1KF31dtQ5pgJCi%2FQwZA%3D&
      > reserved=0>
      > > http://lapierre.skunkworks.free.fr
      > >  erre.skunkworks.free.fr%2F&data=05%7C01%7C%7C8ea3591876ba4f2447af08db0ea8
      > cabc%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638119890335969623%7CUnkn
      > own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV
      > CI6Mn0%3D%7C3000%7C%7C%7C&sdata=lk5LfCbl%2BC26gt8XwYaPdiWErbqpymRoYEX1Uvh
      > Jhhs%3D&reserved=0>
      > ________________________________  Message 7
      > Subject: Re: Europa-List: MT04 Engine mounts
      > Pete
      > How much did you shorten the spacers?
      > Will
      > William Daniell
      > LONGPORT
      > +1 786 878 0246
      > On Sat, Feb 11, 2023 at 5:57 PM Pete  wrote:
      > > I love my lords.waaaay quieter than the old europa rubbers,
      > > Cheers,
      > > PeteZ
      > > On Feb 11, 2023, at 5:08 PM, Bud Yerly  wrote:
      > > =EF=BB
      > > Re the motor mounts:
      > > Engine Rubber Isolation Mounts:
      > > 1.            Europa Rotax Mount MT04 hard mount.
      > > Alternate isolation mount:
      > > 1.            A/C Spruce Part# 08-00662 but not sure of how firm the
      > > rubber is.
      > > MFR Model # SET OF 8  About $50 plus shipping/tax
      > > 2.            Lockwood 860-690 is really expensive $30 each.  Just a Lord
      > > Mount J3608-1
      > > Bud Yerly
      > > *From:* owner-europa-list-server(at)matronics.com <
      > > owner-europa-list-server(at)matronics.com> *On Behalf Of *Paul McAllister
      > > *Sent:* Saturday, February 11, 2023 3:59 PM
      > > *To:* europa-list(at)matronics.com
      > > *Subject:* Europa-List: MT04 Engine mounts
      > > Hi, is anyone aware of a US supplier for the MT04 engine mounts or is
      > > Europa the only source. - Paul
      > ________________________________  Message 8
      > From: GTH <gilles.thesee(at)free.fr>
      > Le 14/02/2023  20:36, William Daniell a crit:
      > > in theDucati regulatoris veryprimitive and not to pay attention.
      > > A reliable voltmeter is required.
      > > Eventuallymy charge light went out by itself. Thebattery charged
      > > just fine while it was on.
      > William and all,
      > Agreed.
      > First measure actual voltages.
      > Yes Bob Nuckolls on http://www.aeroelectric.com/ and on the 'List is key.
      > Best regards
      > Gilles
      > ________________________________  Message 9
      > From: MIKE CHRISTINE DUANE <duanefamly(at)aol.com>
      > I would imagine you can tell if it=99s operating properly if your pane
      > l voltage reading prior to start is about 12.5volts and with engine
      > running (
      > charging system working properly) you should see about 14.8volts.
      > Mike Duane N377EA
      > Europa XS Conventional Gear
      > Sent from my iPhone
      > > On Feb 14, 2023, at 12:48 PM, GTH  wrote:
      > > =EF=BB
      > > Le 14/02/2023 ?? 20:36, William Daniell a ??crit??:
      > in t
      > he??Ducati regulator??is very??primitive and not to pay attention.?? ??A
      > rel
      > iable voltmeter is required.??
      > >> Eventually??my charge light went out by itself.?? The??battery charged
      > ju
      > > William and all,
      > > Agreed.
      > key.
      > > Best regards
      > > Gilles
      > ________________________________  Message 10
      > Subject: Europa-List: Re: New engine runs a little rough when weather is
      > cold.
      > From: "n7188u" <chmgarb(at)gmail.com>
      > All very good info. Thanks. A couple of comments:
      > - I have balanced carbs at 3500 and agree found it to work well. But there
      > is so
      > much info out there. Some say better at lower RPM, some at higher. And
      > since
      > Rotax doesn't say, well, here we are. I tried at the lower range this time.
      > - I saw your O2 setup a while back Area-51. And I like it. But heard that
      > having
      > the sensor too close to the pipe exit can cause outside air to mix with the
      > exhaust and produce erroneous readings. But your solution is certainly
      > attractive.
      > Who sells that short adapter to mount the O2 sensor and coupling hoses?
      > - The info from dmac7 is very interesting. These issues I am having
      > started this
      > winter (well, if you can call it that in Florida). But we do get winter
      > fuel
      > here too. Per Lockwood, he says winter fuels are terrible for our use.
      > Maybe
      > that is the culprit and the solution is to retune carbs during winter. I
      > have
      > to do the same on my 503 powered Kolb (24 years old now) but since that is
      > second
      > nature and expected in the 2-stroker I never had issues.
      > I will fly with this new tuning setup and will report back at some time in
      > the
      > future.
      > Chris
      > http://forums.matronics.com/viewtopic.php?p=510174#510174
      > ________________________________  Message 11
      > From: Martin Tuck <MJKTuck(at)cs.com>
      > Hi Paul,
      > Assuming you are a subscriber to RotaxOwner.com, the video can be found
      > under Videos: 912 Videos: Charging System Troubleshooting.
      > https://www.rotax-owner.com/en/videos-topmenu/rotax-minute/404-charging
      > Regards,
      > Martin Tuck
      > > Cheers,
      > > Paul M
      > > G-PLPM
      > > Thanks Giles,
      > > I havent done anything to the aircraft since the last time I flew and
      > > all seemed well then. I found a good video on troubleshooting the
      > > system on the Rotax Owners site so Ill be looking to perform those
      > > checks and see what might be going on.
      > > Martin
      > > Sent from my iPhone
      > >>> Hi Folks,
      > >> Hi Martin,
      > >> perform a serious check of the wiring and connections.
      > >> /anything / since last time you ran the engine with no issues?
      > >> Best regards
      > >> Gilles
      > ________________________________  Message 12
      > Subject: Europa-List: Anyone need a McMaster Carr Catalog?
      > From: "rparigoris" <rparigor(at)hotmail.com>
      > Hi Group
      > Anyone need a McMaster Carr Catalog? I have a few spares.
      > Ron P.
      > http://forums.matronics.com/viewtopic.php?p=510176#510176
      > ________________________________  Message 13
      > cold.
      > From: "Area-51" <goldsteinindustrial(at)gmail.com>
      > Chris, the setup i just bought the bits off fleabay and made one; the case
      > is 3D
      > printed in PETG with two velcro securing straps and the T'piece for the
      > sensor
      > i had to custom drill and tap to suit... i can make more units ready to use
      > out of the box, and they would be around $600 Aud plus postage; the unit
      > can
      > be used in the cockpit during flight testing for specific altitudes tests
      > also
      > and has self contained battery power or plug into 12v supply and
      > recharging.
      > The tail pipe fitting length negates proximity contamination to external
      > atmospheric
      > air and fits 36mm - 40mm tail pipe sizes with provision for safety cable
      > attachment should the T'piece depart during flight.
      > Balancing carbis at 3500/4000 etc is fine however its a lazy way of going
      > about
      > it and will only offer Intermediate range tuning, so that would be needle
      > height
      > adjustment only. Adjusting mixtures and butterflies for smooth idle are
      > best
      > achieved at the lowest possible rpm (operational idle rpm is set
      > afterward);
      > have had triple SU Aston Martin DB3's happily idling at 150rpm while
      > setting
      > mixtures... SU and Stromberg CV tuning method would be the most
      > appropriate applied
      > approach for Bing64 series. The only other point to note is symmetry of
      > needle height position; if they are not the same height on each carbi and
      > your
      > tuning is complete then you have an issue remaining either an air leak,
      > high
      > or low float level, or unbalanced butterfly valves; take everything back
      > to default
      > and start again to find the reason for rich or lean side.
      > Seasonal changes in specific gravity of fuels will alter the tuning
      > slightly on
      > cold startups as it affects the barometric vaporisation point of the fuel
      > (for
      > Darwinian safety reasons modern pump gas is designed not to vaporise, its
      > designed
      > to be sprayed and atomised at high pressure). Avgas however will readily
      > vaporise and has a specific barometric vaporisation point that must be
      > deliverable
      > and adhered to to prevent vapor locking up to a specified pressure and
      > temperature.
      > Bud might offer a better explanation as i never cease to expect everybody
      > to just
      > automatically know all this stuff!
      > http://forums.matronics.com/viewtopic.php?p=510177#510177
Subject: Re: Europa-List Digest: 13 Msgs - 02/14/23
Date: Feb 15, 2023
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Feb 15, 2023
Date: Feb 15, 2023
Subject: Re: New engine runs a little rough when weather is cold.
fwiw, up here in the frozen tundra when spring comes with the warmer weather and the stations are slow to switch their premium tanks over due to lack of volume, we also see lots of running issues and vapor lock with the "winter gas" formulation. Cheers, PeteZ On Tue, Feb 14, 2023 at 9:50 PM n7188u wrote: > > All very good info. Thanks. A couple of comments: > > - I have balanced carbs at 3500 and agree found it to work well. But there > is so much info out there. Some say better at lower RPM, some at higher. > And since Rotax doesn't say, well, here we are. I tried at the lower range > this time. > > - I saw your O2 setup a while back Area-51. And I like it. But heard that > having the sensor too close to the pipe exit can cause outside air to mix > with the exhaust and produce erroneous readings. But your solution is > certainly attractive. Who sells that short adapter to mount the O2 sensor > and coupling hoses? > > - The info from dmac7 is very interesting. These issues I am having > started this winter (well, if you can call it that in Florida). But we do > get winter fuel here too. Per Lockwood, he says winter fuels are terrible > for our use. Maybe that is the culprit and the solution is to retune carbs > during winter. I have to do the same on my 503 powered Kolb (24 years old > now) but since that is second nature and expected in the 2-stroker I never > had issues. > > I will fly with this new tuning setup and will report back at some time in > the future. > > Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510174#510174 > > ________________________________________________________________________________
Date: Feb 15, 2023
Subject: Re: MT04 Engine mounts
Hi William, Had to reduce the spacer lengths to 1.500=9D to deal with the very la rge startup and shutdown movements of the high compression 912ULS. That said I believe Erich with his lower compression 914 got away with 1.592=9D w hich I found to be *really* quiet and smooth - except with my 912ULS it would bang around during startup and shutdown (when I had the heavy and gear-box abusing warpdrive, I may be able to lengthen them with my now super-light E-prop). Cheers, PeteZ On Tue, Feb 14, 2023 at 2:47 PM William Daniell wrote: > Pete > How much did you shorten the spacers? > Will > William Daniell > LONGPORT > +1 786 878 0246 > > > On Sat, Feb 11, 2023 at 5:57 PM Pete wrote: > >> I love my lords.waaaay quieter than the old europa rubbers, >> >> Cheers, >> PeteZ >> >> On Feb 11, 2023, at 5:08 PM, Bud Yerly wrote: >> >> =EF=BB >> >> Re the motor mounts: >> >> >> >> Engine Rubber Isolation Mounts: >> >> 1. Europa Rotax Mount MT04 hard mount. >> >> Alternate isolation mount: >> >> 1. A/C Spruce Part# 08-00662 but not sure of how firm the >> rubber is. >> >> MFR Model # SET OF 8 About $50 plus shipping/tax >> >> 2. Lockwood 860-690 is really expensive $30 each. Just a >> Lord Mount J3608-1 >> >> >> >> Bud Yerly >> >> *From:* owner-europa-list-server(at)matronics.com < >> owner-europa-list-server(at)matronics.com> *On Behalf Of *Paul McAllister >> *Sent:* Saturday, February 11, 2023 3:59 PM >> *To:* europa-list(at)matronics.com >> *Subject:* Europa-List: MT04 Engine mounts >> >> >> >> Hi, is anyone aware of a US supplier for the MT04 engine mounts or is >> Europa the only source. - Paul >> >> ________________________________________________________________________________
Date: Feb 15, 2023
Date: Feb 15, 2023
It will vary but winter mogas has typically 10% more butane to help it start in cooler seasons, butane has 20% less energy than gasoline and evaporates easily so it doesn't age well in a vented tank. The EPA mandates the Ried vapour pressure =RVP, and butane is how they adjust this. Mogas usually more volatile than 100LL. 100LL has additives to reduce icing and static and anti oxidents to prevent gum build up, it ages well. I would suggest buy a spcific gravity tester, from Fisher Scientific, only $20 when I bought mine. Good to know what's in the tank. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510187#510187 ________________________________________________________________________________
Date: Feb 15, 2023
nice little summary on that I stumbled across fwiw https://www.yellowbullet.com/threads/specific-gravity-of-racing-fuel.170626/ PeteZ On Wed, Feb 15, 2023 at 1:44 PM dmac7 wrote: > > It will vary but winter mogas has typically 10% more butane to help it > start in cooler seasons, butane has 20% less energy than gasoline and > evaporates easily so it doesn't age well in a vented tank. > The EPA mandates the Ried vapour pressure =RVP, and butane is how they > adjust this. Mogas usually more volatile than 100LL. > 100LL has additives to reduce icing and static and anti oxidents to > prevent gum build up, it ages well. I would suggest buy a spcific gravity > tester, from Fisher Scientific, only $20 when I bought mine. Good to know > what's in the tank. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510187#510187 > > ________________________________________________________________________________
Date: Feb 15, 2023
That is a good bit of info in that link. Another useful test if running pump gas, or even avgas, is to check for ethanol content of the fuel before putting the fuel into the aircraft; its a simple and quick process and can prevent carbi icing scenarios. Basically take a glass container put 100ml of water in, draw a line at the water level, put 100ml of the fuel in the container and give it a stir; if the water level increases then thats the % of ethanol in the fuel. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510190#510190 ________________________________________________________________________________
Subject: Europa Club Membership location map trial
Date: Feb 16, 2023
https://www.theeuropaclub.org/news/member-location-map-trial Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510195#510195 ________________________________________________________________________________
Date: Feb 16, 2023
Subject: Re: Europa Club Membership location map trial
Hello Bob, I am certainly in favour of the member map. I like to know where other members live as it all adds to the flavour. Cheers mate Kingsley On 16.02.23 6:41 pm, Hitchflight wrote: > > https://www.theeuropaclub.org/news/member-location-map-trial > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510195#510195 > > ________________________________________________________________________________
Date: Feb 16, 2023
ditto! PeteZ On Thu, Feb 16, 2023 at 6:14 AM Kingsley Hurst wrote: > kingsnjan(at)westnet.com.au> > > Hello Bob, > > I am certainly in favour of the member map. I like to know where other > members live as it all adds to the flavour. > > Cheers mate > > Kingsley > > > On 16.02.23 6:41 pm, Hitchflight wrote: > bobhitchcock(at)icloud.com> > > > > https://www.theeuropaclub.org/news/member-location-map-trial > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=510195#510195 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 16, 2023
I=99m in! Sent from my iPhone > On Feb 16, 2023, at 4:44 AM, Pete Zut wrote: > > =EF=BB > ditto! > PeteZ > >> On Thu, Feb 16, 2023 at 6:14 AM Kingsley Hurst wrote: au> >> >> Hello Bob, >> >> I am certainly in favour of the member map. I like to know where other >> members live as it all adds to the flavour. >> >> Cheers mate >> >> Kingsley >> >> >> On 16.02.23 6:41 pm, Hitchflight wrote: om> >> > >> > https://www.theeuropaclub.org/news/member-location-map-trial >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=510195#510195 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> ========== >> pa-List" rel="noreferrer" target="_blank">http://www.matronics.com/Na vigator?Europa-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> ="noreferrer" target="_blank">https://matronics.com/contribution >> ========== >> >> >> ________________________________________________________________________________
Date: Feb 16, 2023
On 2023-02-16, at 08:41, Hitchflight wrote: > https://www.theeuropaclub.org/news/member-location-map-trial Bob - I hope that many members will support this - it looks a good idea. Am I correct in thinking that the intention is to show home addresses, NOT aircraft bases? With so many Rotax engines being stolen, I would not want to have pointers published that thieves could use to locate potential targets. Yes, I know the map will be members-only, but the black hats may well have the tools to circumvent website security as well as the ones used to liberate engines! I=99ve recently been doing something similar with online maps using the Leaflet templates, which I found really easy to use - see: http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php <http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php> in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Date: Feb 16, 2023
Sadly here in Canada, all that is needed by those blackhats is to log into our government registry and do a quick search, by engine even LOL PeteZ On Thu, Feb 16, 2023 at 10:17 AM Rowland Carson wrote: > On 2023-02-16, at 08:41, Hitchflight wrote: > > https://www.theeuropaclub.org/news/member-location-map-trial > > > Bob - I hope that many members will support this - it looks a good idea. > > Am I correct in thinking that the intention is to show home addresses, NO T > aircraft bases? With so many Rotax engines being stolen, I would not want > to have pointers published that thieves could use to locate potential > targets. Yes, I know the map will be members-only, but the black hats may > well have the tools to circumvent website security as well as the ones us ed > to liberate engines! > > I=99ve recently been doing something similar with online maps using the > Leaflet templates, which I found really easy to use - see: > > http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php > > in friendship > > Rowland > > | Rowland Carson ... that's Rowland with a 'w' ... > | http://www.rowlandcarson.org.uk > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > > ________________________________________________________________________________
Date: Feb 17, 2023
SSBhbSBPSyB3aXRoIHRoaXPCoFJlZ2FyZHNUcmV2b3JTZW50IGZyb20gbXkgR2FsYXh5Ci0tLS0t LS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS1Gcm9tOiBSb3dsYW5kIENhcnNvbiA8cm93bGFu ZGNhcnNvbkBnbWFpbC5jb20+IERhdGU6IDE3LzAyLzIzICA0OjE1IGFtICAoR01UKzEyOjAwKSBU bzogRXVyb3BhIGUtbWFpbCBsaXN0IDxldXJvcGEtbGlzdEBtYXRyb25pY3MuY29tPiBTdWJqZWN0 OiBSZTogRXVyb3BhLUxpc3Q6IEV1cm9wYSBDbHViIE1lbWJlcnNoaXAgbG9jYXRpb24gbWFwIHRy aWFsIE9uIDIwMjMtMDItMTYsIGF0IDA4OjQxLCBIaXRjaGZsaWdodCA8Ym9iaGl0Y2hjb2NrQGlj bG91ZC5jb20+IHdyb3RlOmh0dHBzOi8vd3d3LnRoZWV1cm9wYWNsdWIub3JnL25ld3MvbWVtYmVy LWxvY2F0aW9uLW1hcC10cmlhbEJvYiAtIEkgaG9wZSB0aGF0IG1hbnkgbWVtYmVycyB3aWxsIHN1 cHBvcnQgdGhpcyAtIGl0IGxvb2tzIGEgZ29vZCBpZGVhLkFtIEkgY29ycmVjdCBpbiB0aGlua2lu ZyB0aGF0IHRoZSBpbnRlbnRpb24gaXMgdG8gc2hvdyBob21lIGFkZHJlc3NlcywgTk9UIGFpcmNy YWZ0IGJhc2VzPyBXaXRoIHNvIG1hbnkgUm90YXggZW5naW5lcyBiZWluZyBzdG9sZW4sIEkgd291 bGQgbm90IHdhbnQgdG8gaGF2ZSBwb2ludGVycyBwdWJsaXNoZWQgdGhhdCB0aGlldmVzIGNvdWxk IHVzZSB0byBsb2NhdGUgcG90ZW50aWFsIHRhcmdldHMuIFllcywgSSBrbm93IHRoZSBtYXAgd2ls bCBiZSBtZW1iZXJzLW9ubHksIGJ1dCB0aGUgYmxhY2sgaGF0cyBtYXkgd2VsbCBoYXZlIHRoZSB0 b29scyB0byBjaXJjdW12ZW50IHdlYnNpdGUgc2VjdXJpdHkgYXMgd2VsbCBhcyB0aGUgb25lcyB1 c2VkIHRvIGxpYmVyYXRlIGVuZ2luZXMhSeKAmXZlIHJlY2VudGx5IGJlZW4gZG9pbmcgc29tZXRo aW5nIHNpbWlsYXIgd2l0aCBvbmxpbmUgbWFwcyB1c2luZyB0aGUgTGVhZmxldCB0ZW1wbGF0ZXMs IHdoaWNoIEkgZm91bmQgcmVhbGx5IGVhc3kgdG8gdXNlIC0gc2VlOmh0dHA6Ly93d3cucm93bGFu ZGNhcnNvbi5vcmcudWsvd2VkX3dhbGtzL3B1YnNfbWFwLnBocGluIGZyaWVuZHNoaXBSb3dsYW5k CnwgUm93bGFuZCBDYXJzb24gwqAgwqAgwqAgwqAgwqAuLi4gdGhhdCdzIFJvd2xhbmQgd2l0aCBh ICd3JyAuLi58IDxyb3dsYW5kY2Fyc29uQGdtYWlsLmNvbT4gwqAgwqAgwqAgwqAgwqAgwqBodHRw Oi8vd3d3LnJvd2xhbmRjYXJzb24ub3JnLnVrfCBTa3lwZSwgVHdpdHRlcjogcm93bGFuZF9jYXJz b24gwqAgwqAgwqBGYWNlYm9vazogUm93bGFuZCBDYXJzb24KCg= ________________________________________________________________________________
Date: Feb 17, 2023
And ditto! Brian Phillips. On 16/02/2023 10:43 pm, Pete Zut wrote: > ditto! > PeteZ > > On Thu, Feb 16, 2023 at 6:14 AM Kingsley Hurst > wrote: > > > > Hello Bob, > > I am certainly in favour of the member map. I like to know where > other > members live as it all adds to the flavour. > > Cheers mate > > Kingsley > > > On 16.02.23 6:41 pm, Hitchflight wrote: > > > > > https://www.theeuropaclub.org/news/member-location-map-trial > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=510195#510195 > > > > > > > > > > > > > > > > > > > > ========== > pa-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Europa-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > ="noreferrer" target="_blank">https://matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Feb 17, 2023
Hi Rowland The suggestion is to create a map with the approximate position of the Members home. This is achieved by using a truncated version of the Members postal code. This map to only be available to Members using the password privileges. In the settings page both new and existing Members can define if they are happy to release personal detail in the Membership settings options: https://www.theeuropaclub.org/members/ Currently 23% of the Europa Club Membership have positively selected that they do not want any personal information disclosed (including by default map information). The Club will respect the Members wishes. So the map would show 77% of locations if active today. In respect of thefts from airfields the Europa Club is acutely aware of the sensitivity of the subject. The Europa Club has no intention to publish at this time. Poignant, my home airfield was targeted Christmas 2020. The theft of engines, including mine, was traumatic! Installation of high tech, high cost security security equipment and processes followed. Regards Bob Rowland_Carson wrote: > On 2023-02-16, at 08:41, Hitchflight wrote: > > https://www.theeuropaclub.org/news/member-location-map-trial (https://www.theeuropaclub.org/news/member-location-map-trial) > > > Bob - I hope that many members will support this - it looks a good idea. > > Am I correct in thinking that the intention is to show home addresses, NOT aircraft bases? With so many Rotax engines being stolen, I would not want to have pointers published that thieves could use to locate potential targets. Yes, I know the map will be members-only, but the black hats may well have the tools to circumvent website security as well as the ones used to liberate engines! > > Ive recently been doing something similar with online maps using the Leaflet templates, which I found really easy to use - see: > > http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php (http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php) > > in friendship > > Rowland > > > | Rowland Carson ... that's Rowland with a 'w' ...| http://www.rowlandcarson.org.uk (http://www.rowlandcarson.org.uk)| Skype, Twitter: rowland_carson Facebook: Rowland Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510210#510210 ________________________________________________________________________________
Date: Feb 17, 2023
Rowland_Carson wrote: > On 2023-02-16, at 08:41, Hitchflight wrote: > > https://www.theeuropaclub.org/news/member-location-map-trial (https://www.theeuropaclub.org/news/member-location-map-trial) > > > Bob - I hope that many members will support this - it looks a good idea. > > Am I correct in thinking that the intention is to show home addresses, NOT aircraft bases? With so many Rotax engines being stolen, I would not want to have pointers published that thieves could use to locate potential targets. Yes, I know the map will be members-only, but the black hats may well have the tools to circumvent website security as well as the ones used to liberate engines! > > Ive recently been doing something similar with online maps using the Leaflet templates, which I found really easy to use - see: > > http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php (http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php) > > in friendship > > Rowland > > > | Rowland Carson ... that's Rowland with a 'w' ...| http://www.rowlandcarson.org.uk (http://www.rowlandcarson.org.uk)| Skype, Twitter: rowland_carson Facebook: Rowland Carson Hi Rowland, The intention is to use the first part of an individuals post code for their location. This will identify the general location, but not the specific address of the individual. The individuals name and email address would be displayed, but not their address or phone number. In this way, an individual can be contacted, but it is then up to the individual to decide if they wish to engage. Best Regards Bob Dawson Europa Club Treasurer -------- Bob Dawson Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510211#510211 ________________________________________________________________________________
Date: Feb 17, 2023
Hi Pete Z. In May 2018 the privacy GDPR laws changed in the UK & EU. The laws are very different in Canada and the USA. This side of the pond there is the threat of fines or other sanctions for publishing a Members contact details without permission. Consequently we are obliged to proceed cautiously and with consent. The Europa Committee will likely review and decide at the next Committee meeting. Thanks for the feedback Regards Bob peterz(at)zutrasoft.com wrote: > Sadly here in Canada, all that is needed by those blackhats is to log into our government registry and do a quick search, by engine even LOL > > > PeteZ > > > > On Thu, Feb 16, 2023 at 10:17 AM Rowland Carson wrote: > > > > On 2023-02-16, at 08:41, Hitchflight wrote: > > > > > https://www.theeuropaclub.org/news/member-location-map-trial (https://www.theeuropaclub.org/news/member-location-map-trial) > > > > > > > > > > > > > Bob - I hope that many members will support this - it looks a good idea. > > > > > > Am I correct in thinking that the intention is to show home addresses, NOT aircraft bases? With so many Rotax engines being stolen, I would not want to have pointers published that thieves could use to locate potential targets. Yes, I know the map will be members-only, but the black hats may well have the tools to circumvent website security as well as the ones used to liberate engines! > > > > > > Ive recently been doing something similar with online maps using the Leaflet templates, which I found really easy to use - see: > > > > > > http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php (http://www.rowlandcarson.org.uk/wed_walks/pubs_map.php) > > > > > > in friendship > > > > > > Rowland > > > > > > > > | Rowland Carson ... that's Rowland with a 'w' ... > > | http://www.rowlandcarson.org.uk (http://www.rowlandcarson.org.uk) > > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510212#510212 ________________________________________________________________________________
Date: Feb 17, 2023
On 2023-02-17, at 08:47, BobD wrote: > The intention is to use the first part of an individuals post code for their location. This will identify the general location, but not the specific address of the individual. The individuals name and email address would be displayed, but not their address or phone number. In this way, an individual can be contacted, but it is then up to the individual to decide if they wish to engage. Bob - that all sounds excellent, thanks for the clarification. Count me in for a display flag. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Date: Feb 17, 2023
I like this idea in that it allows members to be aware of where other members may live in general. The email info would allow for contact in a general sense. Remember, there is still the emergency contact list for those traveling that might be in need of some faster assistance. Mike Duane N377EA EUROPA XS Conventional Gear Chandler, AZ Sent from my iPhone > On Feb 17, 2023, at 4:04 AM, Rowland Carson wrote: > > >> On 2023-02-17, at 08:47, BobD wrote: >> >> The intention is to use the first part of an individuals post code for their location. This will identify the general location, but not the specific address of the individual. The individuals name and email address would be displayed, but not their address or phone number. In this way, an individual can be contacted, but it is then up to the individual to decide if they wish to engage. > > Bob - that all sounds excellent, thanks for the clarification. Count me in for a display flag. > > in friendship > > Rowland > > | Rowland Carson ... that's Rowland with a 'w' ... > | http://www.rowlandcarson.org.uk > | Skype, Twitter: rowland_carson Facebook: Rowland Carson > > > > > ________________________________________________________________________________
Subject: Europa Classic sight gauge tubing MPD: 1998-019 R1
Date: Feb 17, 2023
UK Classic and possibly XS owners who have recently been informed by their inspectors to comply with Mandatory Permit Directive MPD : 1998-019 R1 subject Flexible Fuel Tubing. I WANT TO SPLIT THE COST WITH YOU. After measuring generously, the total length I need is 7 meters / 23 ft. Looking at the LAS website, I ascertain that 23 ft at 4.14/ft will cost 95.22 and probably delivery + VAT to be added. But its "provenance" is debatable, even though LAS Aerospace Ltd no doubt has impeccable credentials. https://www.lasaero.com/products/article/S03RCYQ1X My inspector is keen for me to acquire TYGON, which fulfils the MPD requirement as "tubing manufactured from an identifiable material" and so he provided me with this link to Tubing International https://www.tubinginternational.com/cart/ which comes in at 167.24 incl shipping and VAT. That gets me a 50 ft / 15 meter roll, which is more than double what I need. Would anyone like to buy the leftover half roll from me for, shall we say, 70.00 incl shipping? Looking forward to a stampede of replies. Jonathan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510219#510219 ________________________________________________________________________________
Subject: Re: Europa Classic sight gauge tubing MPD: 1998-019 R1
Date: Feb 17, 2023
Jonathan Id be interested in this as am in the process of changing all fuel lines, including sight gauges. Do you want to email me off forum to avoid clogging things up here? dpc(at)knightonweb.com Thanks David > On 17 Feb 2023, at 20:15, JonathanMilbank wrote: > > > UK Classic and possibly XS owners who have recently been informed by their inspectors to comply with Mandatory Permit Directive MPD : 1998-019 R1 subject Flexible Fuel Tubing. I WANT TO SPLIT THE COST WITH YOU. > > After measuring generously, the total length I need is 7 meters / 23 ft. Looking at the LAS website, I ascertain that 23 ft at 4.14/ft will cost 95.22 and probably delivery + VAT to be added. But its "provenance" is debatable, even though LAS Aerospace Ltd no doubt has impeccable credentials. https://www.lasaero.com/products/article/S03RCYQ1X > > My inspector is keen for me to acquire TYGON, which fulfils the MPD requirement as "tubing manufactured from an identifiable material" and so he provided me with this link to Tubing International https://www.tubinginternational.com/cart/ which comes in at 167.24 incl shipping and VAT. That gets me a 50 ft / 15 meter roll, which is more than double what I need. Would anyone like to buy the leftover half roll from me for, shall we say, 70.00 incl shipping? > > Looking forward to a stampede of replies. Jonathan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510219#510219 > > > > > > > > > ________________________________________________________________________________
Date: Feb 17, 2023
David, I've tried to send a reply to you vie Gmail and yahoo mail, but keep getting rejected with messages like "No such address exists". Here's what I was trying to send: G r e a t t h a t y o u r e p l i e d s o q u i c k l y . I ' m p r o b a b l y g o i n g t o p l a c e m y o r d e r i n t h e n e x t c o u p l e o f d a y s a n d h o p e f u l l y i t w o n ' t t a k e t o o l o n g t o a r r i v e . T o m o r r o w m o r n i n g S a t 1 8 t h I ' l l b e d o i n g m y b i e n n i a l f l i g h t r e v i e w , w h i c h m i g h t n o t h a p p e n u n t i l a f t e r n o o n d e p e n d i n g o n w e a t h e r . S o i f y o u w a n t t o t a l k , I ' m u s u a l l y a b l e t o r e c e i v e P P R r e q u e s t s e t c , f o r o u r c l u b b e t w e e n 1 0 : 0 0 a n d 2 2 : 0 0 . O b v i o u s l y n o t w h i l e I ' m f l y i n g t h o u g h . S o p l e a s e g i v e m e a c a l l a t y o u r c o n v e n i e n c e , b u t i t m i g h t g o t o a v o i c e m a i l m e s s a g e s a y i n g " L o n g s i d e a i r f i e l d . . . . . . " w h i c h w i l l b e m y v o i c e . M y m o b i l e n u m b e r 0 7 8 2 5 8 1 1 1 1 1 w h i c h y o u ' l l a l s o s e e i n t h e f l i g h t g u i d e s f o r o u r a i r f i e l d n e a r P e t e r h e a d . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510224#510224 ________________________________________________________________________________
Date: Feb 18, 2023
Jonathan, I certainly do not know LAA requirements, but I can share my sight gauge and fuel hose experience. I tried Tygon F4040 fuel hose initially. It will get hard and lose flexibility in less than a year as I recall. It is yellow initially and gets more yellow with time. What I have been using for the last 6-8 years is Tygon SE200. This is clear tubing with a Teflon liner. There has been no change in color or opacity since installed. The liner will not withstand flexing, so for protection, I slid the SE200 inside clear flexible tubing that I purchased a the local DIY store. The only place I use this is for my sight gauge. All other fuel hoses in my Europa are Gates Barricade, which meets SAE J30R14T1 specification. This hose has very low permeation so smell is minimized. It comes in carburetor version and fuel injection version. The fuel injection hose is stiffer and more difficult to slide on fittings but also will keep it's shape better around sharp bends. The carburetor version is softer and easier to slide on fittings but can collapse or deform around sharp bends. I also have replaced all barb fittings in my fuel and oil system with AN style hose ends. They are much easier to work with than the original Europa barb fittings. Hope this helps but I have no idea if allowed in the UK. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510236#510236 ________________________________________________________________________________
Subject: Re: October 2022 Zoom Episode 1
Date: Feb 18, 2023
Hi Group Here's links to February 2023 Zoom Episode 4 about Flap: Drive Engagement Mod, Drive Tube Protection and Upstop: https://1drv.ms/u/s!Ah1S270Nwg9Vgfxo4GyieZqPm54XaQ?e=wZeNkp For whatever reason, Matronics always cuts off some of the hyper-link when I post links. Just copy the entire link and paste into URL of browser. ** You don't need PowerPoint loaded on your computer to view ** When viewing PowerPoint, you can click the white box with orange print on the upper right "Present". This will give you full screen. Press ESC to escape Present mode. ** Click Enter to go Forward and Backspace to go Back (you can also use Forward and Back Arrows on Keyboard) ** You can Save PowerPoint to your computer, if you do you will need PowerPoint loaded to view No PDF this Episode because it has Videos. Ron and Wayne Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510240#510240 ________________________________________________________________________________
Date: Feb 19, 2023
Jim, Many thanks for your words of wisdom. As you're probably aware, in the UK we seem to enjoy less freedom and are subject to detailed annual permit renewal inspections. So if my inspector says "Jump!" then I reply "How high Sir?" At last year's inspection he told me that he would like me to replace the sight gauge tubing before the next inspection, preferably using the TYGON which seemingly is being used by several UK aircraft types. I'll have to keep my fingers crossed, hoping that it lasts as long as what is currently installed and still in quite good condition after 26 years. Unfortunately the old tubing was supplied by Europa as part of the build kit, with no way now of knowing who manufactured it. The picture of what I've already ordered shows fairly clear tubing without a hint of yellow. It'll be interesting to see what comes out of the package. My other hope is that the formulation of US mogas may be a little different from the UK. For one thing, we can still buy mogas at certain fuel stations with zero ethanol in it, which is what I always use. Jonathan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510246#510246 ________________________________________________________________________________
Date: Feb 19, 2023
Jonathan you could find another inspector. Thats what happens when I tell LAA members something they dont like at permit time. Especially if it involves them spending money or their aircraft maybe grounded. Safety usually comes a poor third. Not sure why after all this time your inspector is quoting MPD 1998-019 R1. Unless he's new to you. Its been around since 1998 and should be carried out every permit renewal inspection. I carry it out on any aircraft it am carrying out a Permit renewal inspection on. I inspect all flexible lines and hose for deterioration. Not just fuel lines. I have only found out about Tygon hose in the last week. I've only ever used standard commercially available fuel hose. I change it on-condition. Because its cheap it gets changed often as needed and not every 26 years. If I was going your inspection I would suggest that to you. Unless you really want Tygon hose at that is. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510250#510250 ________________________________________________________________________________
Date: Feb 19, 2023
Is this an alternative to the Tygon Tube we are all talking about? Alan Sent from my iPad > On 19 Feb 2023, at 19:18, Matt Dovey wrote: > l.co.uk> > > Jonathan you could find another inspector. Thats what happens when I tell L AA members something they dont like at permit time. Especially if it involve s them spending money or their aircraft maybe grounded. Safety usually comes a poor third. Not sure why after all this time your inspector is quoting MP D 1998-019 R1. Unless he's new to you. Its been around since 1998 and should be carried out every permit renewal inspection. I carry it out on any aircr aft it am carrying out a Permit renewal inspection on. I inspect all flexibl e lines and hose for deterioration. Not just fuel lines. > I have only found out about Tygon hose in the last week. I've only ever us ed standard commercially available fuel hose. I change it on-condition. Beca use its cheap it gets changed often as needed and not every 26 years. If I w as going your inspection I would suggest that to you. Unless you really want Tygon hose at =C2=A3=C2=A3=C2=A3 that is. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510250#510250 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Subject: Europa fuel sight guage shorter route up seat back
Date: Feb 19, 2023
After looking through documents available at The Europa Club, LAA Europa TADS and my paper documents, I can't find anything giving Mod approval or instructions / diagrams on how to re-route the fuel sight guage from the tank outlet in the tunnel and up the seat back, which several Europas seem to have done. I'm considering doing this, but need to have some documentary support to show my inspector. Please help. Thank you. Jonathan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510252#510252 ________________________________________________________________________________
Date: Feb 20, 2023
Per Jim's recommendation I also used the SE-200 tubing. For those in the US it is sold by McMaster Carr as "Ultra-Chemical-Resistant Versilon PVC Tubing 1/4 ID, 3/8 OD" PN 6519T13. The stuff is great and after 3 years it has not stained and remains crystal clear making reading the fuel level very easy. However, I installed my tube right against the cockpit module's seat back in the center (if someone has seen Bud Yerly's airplane, but without the fancy base). That means I did not have to bend this tube to place it in the foot well as the plans indicate. I have 1/4" aluminum tubing from the tank and vent and bent 90s at the top and bottom of the seat back center. From there a straight run of the SE-200 against the seat back. No bends. Jim is right, the stuff doesn't like bends because the FEP liner inside will collapse. But in a near straight line it is amazing for fuel sight gage use. Also, pushing the tube into the 1/4" tubing is hard because the liner separates and bunches up in front of the tubing. But with some patience it is doable. Certainly worth the effort. But I don't know if you can change the location of the fuel sight gage in England. Could you use barbed fittings and use the SE-200 only on the vertical run where you read the fuel level? Honestly, I have no clue why Europa didn't place it against the seat back. Easy to see and fairly accurate. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510256#510256 ________________________________________________________________________________
Date: Feb 20, 2023
Subject: Dynon HDX Autopilot Settings
Hi folks, I'm back in the air after determining my no generator issues were due to a poor connection. When I first installed the Dynon Autopilot on my HDX system, it worked right out of the box using the default settings in terms of sensitivities, gains, etc. for both roll and pitch. A software upgrade introduced a tendency for an aggressive roll tendency when initiating a turn. Others on the Dynon forum had the same issues. Then another software update provided 'the fix' but it was also clear that for me the default settings no longer worked in the pitch axis. I have gone through the process for adjusting the settings as provided by the autopilot tuning manual but it still 'wanders' having captured altitude quite nicely. I'm thinking of asking Dynon how to reinstall previous software versions but then I thought I would ask anyone who has a Dynon HDX system with an autopilot who is running the current software if they could send me their settings. Any pointers would be appreciated. Regards, Martin Tuck ________________________________________________________________________________
Subject: Slope soaring a Europa?
Date: Feb 21, 2023
Hi Group If anyone ever wanted to know if it's possible to slope soar a short wing variant, the answer would be ABSOLUTELY! As a matter of fact, if you got rid of 20 foot of short wing span it would still work!!: https://www.reddit.com/r/Unexpected/comments/116m7jm/it_seems_pretty_windy/?utm_source=share&utm_medium=ios_app&utm_name=iossmf Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510258#510258 ________________________________________________________________________________
From: Steve Styles <info(at)stylesfabrications.co.uk>
Subject: Re: Dynon HDX Autopilot Settings
Date: Feb 22, 2023
TWFydGluDQpUaGVyZSBpcyBhIGdyZWF0IGd1eSBhdCBEeW5vbiwgaGUgYW5zd2VyZWQgYWxsIG15 IHF1ZXN0aW9uIHJlbGF0aW5nIHRvIHRoaXMgc3ViamVjdC4NCg0KRGF2aWQgUmVhZG91dCwgZW1h aWwg4oCYc3VwcG9ydEBkeW5vbmF2aW9uaWNzLmNvbeKAmQ0KDQpTdGV2ZSBzdHlsZXMNCg0KU1RZ TEVTIEZBQlJJQ0FUSU9OUyBMVEQNCjAxMjEgNTE1IDQ0NDkNCjA3OTg5IDE3OTQ5Mw0KaW5mb0Bz dHlsZXNmYWJyaWNhdGlvbnMuY28udWsNCg0KT24gMjEgRmViIDIwMjMsIGF0IDAxOjQ4LCBNYXJ0 aW4gVHVjayA8bWprdHVja0Bjcy5jb20+IHdyb3RlOg0KDQrvu78tLT4gRXVyb3BhLUxpc3QgbWVz c2FnZSBwb3N0ZWQgYnk6IE1hcnRpbiBUdWNrIDxNSktUdWNrQGNzLmNvbT4NCg0KSGkgZm9sa3Ms DQoNCkknbSBiYWNrIGluIHRoZSBhaXIgYWZ0ZXIgZGV0ZXJtaW5pbmcgbXkgbm8gZ2VuZXJhdG9y IGlzc3VlcyB3ZXJlIGR1ZSB0byBhIHBvb3IgY29ubmVjdGlvbi4NCg0KV2hlbiBJIGZpcnN0IGlu c3RhbGxlZCB0aGUgRHlub24gQXV0b3BpbG90IG9uIG15IEhEWCBzeXN0ZW0sIGl0IHdvcmtlZCBy aWdodCBvdXQgb2YgdGhlIGJveCB1c2luZyB0aGUgZGVmYXVsdCBzZXR0aW5ncyBpbiB0ZXJtcyBv ZiBzZW5zaXRpdml0aWVzLCBnYWlucywgZXRjLiBmb3IgYm90aCByb2xsIGFuZCBwaXRjaC4NCg0K QSBzb2Z0d2FyZSB1cGdyYWRlIGludHJvZHVjZWQgYSB0ZW5kZW5jeSBmb3IgYW4gYWdncmVzc2l2 ZSByb2xsIHRlbmRlbmN5IHdoZW4gaW5pdGlhdGluZyBhIHR1cm4uIE90aGVycyBvbiB0aGUgRHlu b24gZm9ydW0gaGFkIHRoZSBzYW1lIGlzc3Vlcy4gVGhlbiBhbm90aGVyIHNvZnR3YXJlIHVwZGF0 ZSBwcm92aWRlZCAndGhlIGZpeCcgYnV0IGl0IHdhcyBhbHNvIGNsZWFyIHRoYXQgZm9yIG1lIHRo ZSBkZWZhdWx0IHNldHRpbmdzIG5vIGxvbmdlciB3b3JrZWQgaW4gdGhlIHBpdGNoIGF4aXMuDQoN CkkgaGF2ZSBnb25lIHRocm91Z2ggdGhlIHByb2Nlc3MgZm9yIGFkanVzdGluZyB0aGUgc2V0dGlu Z3MgYXMgcHJvdmlkZWQgYnkgdGhlIGF1dG9waWxvdCB0dW5pbmcgbWFudWFsIGJ1dCBpdCBzdGls bCAnd2FuZGVycycgaGF2aW5nIGNhcHR1cmVkIGFsdGl0dWRlIHF1aXRlIG5pY2VseS4NCg0KSSdt IHRoaW5raW5nIG9mIGFza2luZyBEeW5vbiBob3cgdG8gcmVpbnN0YWxsIHByZXZpb3VzIHNvZnR3 YXJlIHZlcnNpb25zIGJ1dCB0aGVuIEkgdGhvdWdodCBJIHdvdWxkIGFzayBhbnlvbmUgd2hvIGhh cyBhIER5bm9uIEhEWCBzeXN0ZW0gd2l0aCBhbiBhdXRvcGlsb3Qgd2hvIGlzIHJ1bm5pbmcgdGhl IGN1cnJlbnQgc29mdHdhcmUgaWYgdGhleSBjb3VsZCBzZW5kIG1lIHRoZWlyIHNldHRpbmdzLg0K DQpBbnkgcG9pbnRlcnMgd291bGQgYmUgYXBwcmVjaWF0ZWQuDQoNClJlZ2FyZHMsDQpNYXJ0aW4g VHVjaw0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBFdXJvcGEtTGlzdCBFbWFpbCBGb3J1bSAt DQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3Nl DQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlv biwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZB USwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0V1cm9wYS1MaXN0DQpfLT0NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdy ZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0g ICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAg ICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0KXy09IEFkZCBzb21lIGluZm8gdG8g dGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2khDQpfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0 cm9uaWNzLmNvbQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdl YiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0g ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpf LT0gICAtLT4gaHR0cHM6Ly9tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoN Cg= ________________________________________________________________________________
Subject: Tygon LP-1200 sight gauge tubing
Date: Feb 23, 2023
Available from ebay US in 10ft lengths: https://www.ebay.com/itm/185314064140?_trkparms=amclksrc%3DITM%26aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20180816085401%26meid%3Ddb3930ecde3b4d49980ec11dd8038543%26pid%3D100970%26rk%3D1%26rkt%3D1%26sd%3D185314064140%26itm%3D185314064140%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100970.m5481&_trkparms=pageci%3Aaa795da9-b366-11ed-a910-32e7b8cf1fa2%7Cparentrq%3A7ddd5c611860a6e6986d5853ffff8f30%7Ciid%3A1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510260#510260 ________________________________________________________________________________
Date: Feb 24, 2023
See you are been the good knight here Sent from my iPad > On 22 Feb 2023, at 21:32, Steve Styles wro te: > > =EF=BB Martin > There is a great guy at Dynon, he answered all my question relating to thi s subject. > > David Readout, email =98support(at)dynonavionics.com=99 > > Steve styles > > STYLES FABRICATIONS LTD > 0121 515 4449 > 07989 179493 > info(at)stylesfabrications.co.uk > >>> On 21 Feb 2023, at 01:48, Martin Tuck wrote: >>> >> >> Hi folks, >> >> I'm back in the air after determining my no generator issues were due to a poor connection. >> >> When I first installed the Dynon Autopilot on my HDX system, it worked ri ght out of the box using the default settings in terms of sensitivities, gai ns, etc. for both roll and pitch. >> >> A software upgrade introduced a tendency for an aggressive roll tendency w hen initiating a turn. Others on the Dynon forum had the same issues. Then a nother software update provided 'the fix' but it was also clear that for me t he default settings no longer worked in the pitch axis. >> >> I have gone through the process for adjusting the settings as provided by the autopilot tuning manual but it still 'wanders' having captured altitude quite nicely. >> >> I'm thinking of asking Dynon how to reinstall previous software versions b ut then I thought I would ask anyone who has a Dynon HDX system with an auto pilot who is running the current software if they could send me their settin gs. >> >> Any pointers would be appreciated. >> >> Regards, >> Martin Tuck ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= >> >> >> ________________________________________________________________________________
Subject: CKT silencer crack
Date: Feb 26, 2023
This damage looks difficult to repair by welding. The "collar" into which the exhaust header tube is held with springs, has broken the weld most of the way around where it attaches to the silencer box. There are other broken small welds where the other header tubes get inserted. Throughout the 300 hours total in the air since the silencer was first installed, the carburettors have been kept electronically balanced and the Airmaster propeller is also well balanced. The silencer was suspended with utmost care to avoid strains as the flange nuts got tightened, making sure to tighten the telescopic joint in #1 header tube last. I'll probably have to replace the whole exhaust system. This topic is just FYI. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510288#510288 Attachments: http://forums.matronics.com//files/ckt_silencer_crack_189.doc ________________________________________________________________________________
Subject: Re: CKT silencer crack
Date: Feb 27, 2023
Morning Jonathan Hope your keeping well? I had a very similar failure with my silencer at around the same number of hrs on my aircraft, new silencer was indeed required. I have just had the number 3 cylinder down pipe fail on friday afternoon whilst flying. The Number 2 down pipe had no more than 30hrs on it before the failure Hope you can get things fixed soon. Kind regard's Donald Donald Sent from my iPhone > On 27 Feb 2023, at 00:10, JonathanMilbank wrote: > > > This damage looks difficult to repair by welding. The "collar" into which the exhaust header tube is held with springs, has broken the weld most of the way around where it attaches to the silencer box. There are other broken small welds where the other header tubes get inserted. > Throughout the 300 hours total in the air since the silencer was first installed, the carburettors have been kept electronically balanced and the Airmaster propeller is also well balanced. The silencer was suspended with utmost care to avoid strains as the flange nuts got tightened, making sure to tighten the telescopic joint in #1 header tube last. > I'll probably have to replace the whole exhaust system. This topic is just FYI. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510288#510288 > > > > > Attachments: > > http://forums.matronics.com//files/ckt_silencer_crack_189.doc > > > > > > ________________________________________________________________________________
Date: Feb 28, 2023
Subject: Beringer wheel & brake
Hello All Im considering the Beringer wheel and looking for experience of others with Beringer. Ive had 3 pinch flats on my mono and will get the better tubes and higher inflation to help prevent future failure but still concerned about being stranded on a strip. Perhaps the tubeless tire Beringer will work better and still allow for less tire pressure and help with landing. Also the added breaking power. Thanks for any input and advice! Jerry 914 Mono XS ________________________________________________________________________________
Date: Feb 28, 2023
Subject: Re: Beringer wheel & brake
Jerry, I was delighted with how well it worked for me. Clearly better braking and lighter. My only cabeat is that it is possibly a mistake to fit it with the bicycle brake style lever on the P1 column. You may come to want to be able to brake from P2 position somewhere down the line, so I recommend a lever system in the conventional Europa position. David Joyce, formerly GXSDJ On 2023-02-28 21:49, Jerry Rehn wrote: > > Hello All > I'm considering the Beringer wheel and looking for experience of others > with Beringer. I've had 3 pinch flats on my mono and will get the > better tubes and higher inflation to help prevent future failure but > still concerned about being stranded on a strip. > Perhaps the tubeless tire Beringer will work better and still allow for > less tire pressure and help with landing. Also the added breaking > power. > Thanks for any input and advice! > Jerry > 914 Mono XS > ________________________________________________________________________________
Date: Mar 01, 2023
Hi Jerry, I fitted the Beringer wheel 6 years ago and I am very happy with the performance as the braking is progressive without being too powerful. Make sure you get the pressure limiter which is what provides that feel. My system came with the stick mounted brake lever, I hesitated to send it back but thought I would give it a try especially as Beringer offered to swap it if I wasnt happy with it. It took several flights to get used to it because initially you feel like you should be doing something with the right hand but once accustomed to it its really pleasant for just that reason. It frees up your hand to do other tasks when taxiing but giving you constant control over your braking inputs. I used the 7 Air Trac tyre on my mono. As David pointed out an issue could be if you instruct on your aircraft but thats not something I envisage doing. I suppose you could add a second brake on the other stick but it would increase cost and add weight and you wouldnt want the uninitiated playing with it! If you have had several pinch punctures you cant be far from a prop strike with a fully compressed gear and compressed tyre. ________________________________________________________________________________
Date: Mar 01, 2023
Here is how my centrally mounted brake lever looks. There is a park brake button just out of view on pax side of installation. Ergonomic inasmuch as very close to throttle. Installation fairly complicated but well within abilities of anyone who has built his plane. I am not an instructor but have found myself flying from R hand seat on a number of occasions over the years and as we all get older and probably do more buddy flying it is comforting for either pilot to have ability to land the plane. David Joyce On 2023-03-01 08:27, John Archer wrote: > > Hi Jerry, > > I fitted the Beringer wheel 6 years ago and I am very happy with the > performance as the braking is progressive without being too powerful. > Make sure you get the pressure limiter which is what provides that > feel. > > My system came with the stick mounted brake lever, I hesitated to send > it back but thought I would give it a try especially as Beringer > offered to swap it if I wasn't happy with it. > It took several flights to get used to it because initially you feel > like you should be doing something with the right hand but once > accustomed to it it's really pleasant for just that reason. It frees up > your hand to do other tasks when taxiing but giving you constant > control over your braking inputs. > I used the 7" Air Trac tyre on my mono. > > As David pointed out an issue could be if you instruct on your aircraft > but that's not something I envisage doing. I suppose you could add a > second brake on the other stick but it would increase cost and add > weight and you wouldn't want the uninitiated playing with it! > > If you have had several pinch punctures you can't be far from a prop > strike with a fully compressed gear and compressed tyre. > ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Mar 01, 2023
Subject: Tank repair options
https://tbbonding.com/glue-polyethylene/ I came across this looking for adhesive for a kayak. thought it might be of interest. It specifically mentions tank repair. Will William Daniell LONGPORT +1 786 878 0246 ________________________________________________________________________________
Subject: Hats
Date: Mar 01, 2023
Im having some Europa hats embroidered. The attachment shows how they will look. They are adjustable so one size fits all. They can only be mailed to US and Canada addresses. The cost delivered is $27. If anyone from outside the US / Canada is interested and will attend Oshkosh, I could bring their hats for pick up. I previously emailed directly to my North America Zoom list. Before I obtained a quote, some expressed interest. After providing the price to those interested, some agreed to purchase. Some that expressed interest have not responded whether they want to purchase knowing the price. To add another wrinkle, some want hats but without the word Club. The supplier has agreed they can produce hats with the word Europa and the airplane artwork, with or without Club, at the same price. Anyone interested please let me know the following via PM or email America(at)theeuropaclub.org: If you have agreed to purchase, do you want with or without Club on your hat(s)? If you expressed interest but havent agreed to purchase, I will assume you do not desire to purchase if I dont hear by Wed 3/8. If you havent responded previously and wish to purchase, let me know and advise whether you want Club on your hat(s). I plan to place the order Thursday 3/9. Payment can be check or PayPal. I will advise payment details after I place the order. Thank you. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510316#510316 Attachments: http://forums.matronics.com//files/hatfinal_770.jpeg ________________________________________________________________________________
Date: Mar 02, 2023
Subject: Fwd: Beringer wheel & brake
> > Hello All > Im considering the Beringer wheel and looking for experience of others with Beringer. Ive had 3 pinch flats on my mono and will get the better tubes and higher inflation to help prevent future failure but still concerned about being stranded on a strip. > Perhaps the tubeless tire Beringer will work better and still allow for less tire pressure and help with landing. Also the added breaking power. > Thanks for any input and advice! > Jerry > 914 Mono XS ________________________________________________________________________________
Date: Mar 02, 2023
Subject: Beringer Brake and Wheel
Apologize for repeat on this, I am not getting replies from matronics. Went to their site and I see one reply, so thanks! Still investigating problems. Jerry Mono XS 914 Sent from my iPad ________________________________________________________________________________
Subject: Re: Fwd: Beringer wheel & brake
Date: Mar 02, 2023
I have the Beringer complete kit but no hours using it yet. It's been on the market about 10 years many Europa owners have been using it. In the beginning there were worries expressed about it getting flats too or rotating on the rim at low air pressure but I have yet to read one post with any complaints, that says something. The other issue is do you use the motorcycle style brake handle? My answer is a Big Yes! It is much better ergonomically for a pilot. I can hold the stick back with brake applied by the left hand while I advance the throttle with the right hand, it's great. It's complete with parking brake and a anti lock brake type feature that is actually a pressure limiter, you don't have to install this feature but why not? I run the brake line into the cockpit through the landing gear frame tube. The Brake disk won't ever rust, it's SS, twice as thick as before. Aug 15, /22 posted some photos of my installation, "what did you do with your Europa" I'm sure you will get other comments but I think it's a real improvment. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510323#510323 ________________________________________________________________________________
Subject: Re: Who has Nev's cowlings
Date: Mar 02, 2023
So Rob Martin just made me a set of Nev Cowlings for K365 and I am busy trying to work out if I have to use standard Europa ducting, radiators, plenum etc. Seems that I dont but I will need details of Laminovas, bigger water rads, baffles etc I have a 912S and standard Europa engine mount having failed to source the Nav one peice mount. -------- Graeme Bird kit4 (Wagstaff) TBD Kit3 G-CLXU (Gregory) mono 914 xs Woodcomp Kit2 G-PATS - (kesterton) Mono Classic 912 warpdrive Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510325#510325 ________________________________________________________________________________
Date: Mar 02, 2023
Jerry the photos of the Beringer wheel & brake were posted 8/15 2022 but they are to be found in the 8/12...2022 " what did you do with your Europa last week". I chose the Airtrac 800-6, here is a photo of the Beringer with 800-6 beside a 700-6. The 700-6 is 0.7 lbs lighter and 1/2" shorter and 1" narrower. The total weight of the wheel and brake with 800-6 Airtrac is 19.99 lbs. or 9.07 Kg, take your pick. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510326#510326 Attachments: http://forums.matronics.com//files/win_20180318_13_01_38_pro_151.jpg ________________________________________________________________________________
Date: Mar 02, 2023
Graeme - I have Nev's cowl. See: http://www.rowlandcarson.org.uk/aviation/europa_435/cowl_assemble_e.php <http://www.rowlandcarson.org.uk/aviation/europa_435/cowl_assemble_e.php> and http://www.rowlandcarson.org.uk/aviation/europa_435/aft_baffle.php <http://www.rowlandcarson.org.uk/aviation/europa_435/aft_baffle.php> for some pictures of my installation. Do a find for =9Ccowl=9D, =9Cduct=9D, or =9Cbaffle" on the following web page and you=99ll get links to pictures of the stuff I have done to fit Nev=99s cowl around my 912ULS and standard Europa factory engine mount: http://www.rowlandcarson.org.uk/aviation/europa_435/photo_list.php <http://www.rowlandcarson.org.uk/aviation/europa_435/photo_list.php> You can also use the FreeFind search that appears at top left of every web page of my build journal. in friendship Rowland > On 2023-03-02, at 22:50, graeme bird wrote: > > > So Rob Martin just made me a set of Nev Cowlings for K365 and I am busy trying to work out if I have to use standard Europa ducting, radiators, plenum etc. Seems that I dont but I will need details of Laminovas, bigger water rads, baffles etc I have a 912S and standard Europa engine mount having failed to source the Nav one peice mount. > > -------- > Graeme Bird > kit4 (Wagstaff) TBD > Kit3 G-CLXU (Gregory) mono 914 xs Woodcomp > Kit2 G-PATS - (kesterton) Mono Classic 912 warpdrive > Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510325#510325 > > > > > > > > > | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Subject: Re: Tank repair options
Date: Mar 03, 2023
That's very interesting, if what they say is true replacing cracked fuel tanks could be a thing of the past. Thx William Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510333#510333 ________________________________________________________________________________
Date: Mar 03, 2023
I have no first hand experience of this ....just to clarify. But i might get some to see how it works. Will William Daniell +1 786 878 0246 On Fri, Mar 3, 2023, 10:53 dmac7 wrote: > > That's very interesting, if what they say is true replacing cracked fuel > tanks could be a thing of the past. Thx William > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510333#510333 > > ________________________________________________________________________________
Subject: Wire Trace Supplier
Date: Mar 06, 2023
Looking for a reliable supplier for aviation spec shielded single and multi trace wire? Also needing to source fire proof shrink wrap for fabricating custom looms. Prices and delivery time experiences are helpful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510354#510354 ________________________________________________________________________________
Subject: RE: Europa-List Digest: 1 Msgs - 03/06/23
Date: Mar 07, 2023
Subscriber deceased please cease emails -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Europa-List Digest Server Sent: 07 March 2023 07:31 Subject: Europa-List Digest: 1 Msgs - 03/06/23 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Europa-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Europa-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 23-03-06&Archive=Europa Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2023-03-06&Archive=Europa =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Europa-List Digest Archive --- Total Messages Posted Mon 03/06/23: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 10:46 PM - Wire Trace Supplier (Area-51) ________________________________ Message 1 _____________________________________ Subject: Europa-List: Wire Trace Supplier From: "Area-51" <goldsteinindustrial(at)gmail.com> Looking for a reliable supplier for aviation spec shielded single and multi trace wire? Also needing to source fire proof shrink wrap for fabricating custom looms. Prices and delivery time experiences are helpful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510354#510354 ________________________________________________________________________________
Subject: RE: Europa-List Digest: 1 Msgs - 03/07/23
Date: Mar 08, 2023
Subscriber deceased - please cease emails -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Europa-List Digest Server Sent: 08 March 2023 07:30 Subject: Europa-List Digest: 1 Msgs - 03/07/23 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Europa-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Europa-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 23-03-07&Archive=Europa Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2023-03-07&Archive=Europa =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Europa-List Digest Archive --- Total Messages Posted Tue 03/07/23: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:20 AM - Re: Europa-List Digest: 1 Msgs - 03/06/23 (Joan Jerrett) ________________________________ Message 1 _____________________________________ From: "Joan Jerrett" <sjnjj(at)uwclub.net> Subject: Europa-List: RE: Europa-List Digest: 1 Msgs - 03/06/23 Subscriber deceased please cease emails -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Europa-List Digest Server Sent: 07 March 2023 07:31 Subject: Europa-List Digest: 1 Msgs - 03/06/23 * ================================================ Online Versions of Today's List Digest Archive ================================================ Today's complete Europa-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Europa-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 23-03-06&Archive=Europa Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2023-03-06&Archive=Europa ============================================== EMail Version of Today's List Digest Archive ============================================== ---------------------------------------------------------- Europa-List Digest Archive --- Total Messages Posted Mon 03/06/23: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 10:46 PM - Wire Trace Supplier (Area-51) ________________________________ Message 1 _____________________________________ Subject: Europa-List: Wire Trace Supplier From: "Area-51" <goldsteinindustrial(at)gmail.com> Looking for a reliable supplier for aviation spec shielded single and multi trace wire? Also needing to source fire proof shrink wrap for fabricating custom looms. Prices and delivery time experiences are helpful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510354#510354 ________________________________________________________________________________
Date: Mar 08, 2023
Subject: Re: RE: Europa-List Digest: 1 Msgs - 03/07/23
To unsubscribe from the Europa list you need to go here http://www.matronics.com/subscribe/ On Wed, 8 Mar 2023 at 2:22 pm, Joan Jerrett wrote: > > Subscriber deceased - please cease emails > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Europa-List > Digest Server > Sent: 08 March 2023 07:30 > To: Europa-List Digest List > Subject: Europa-List Digest: 1 Msgs - 03/07/23 > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Europa-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Europa-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 23-03-07&Archive=Europa > <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 23-03-07&Archive=Europa> > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 2023-03-07&Archive=Europa > <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 23-03-07&Archive=Europa> > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Europa-List Digest Archive > --- > Total Messages Posted Tue 03/07/23: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 03:20 AM - Re: Europa-List Digest: 1 Msgs - 03/06/23 (Joan > Jerrett) > > > ________________________________ Message 1 > _____________________________________ > > > From: "Joan Jerrett" <sjnjj(at)uwclub.net> > Subject: Europa-List: RE: Europa-List Digest: 1 Msgs - 03/06/23 > > > Subscriber deceased please cease emails > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com > [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Europa-List > Digest Server > Sent: 07 March 2023 07:31 > Subject: Europa-List Digest: 1 Msgs - 03/06/23 > > * > > ================================================ > Online Versions of Today's List Digest Archive > ================================================ > > Today's complete Europa-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Europa-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 23-03-06&Archive=Europa > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 2023-03-06&Archive=Europa > <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter2023-03-06&Archive=Europa> > > > ============================================== > EMail Version of Today's List Digest Archive > ============================================== > > > ---------------------------------------------------------- > Europa-List Digest Archive > --- > Total Messages Posted Mon 03/06/23: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:46 PM - Wire Trace Supplier (Area-51) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Europa-List: Wire Trace Supplier > From: "Area-51" <goldsteinindustrial(at)gmail.com> > > > Looking for a reliable supplier for aviation spec shielded single and multi > trace > wire? Also needing to source fire proof shrink wrap for fabricating custom > looms. > > Prices and delivery time experiences are helpful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510354#510354 > > ________________________________________________________________________________
Date: Mar 10, 2023
Brad Shafer is having problems posting here, so I am forwarding his Facebook posts. Like many others, I woke up to gas on the floor and a crack in the tank. Mine was low on the saddle. I liked what Dave Disney had done so I drained the tank and created an opening in the top. With the ability to inspect the inside of the tank (which is a very nice option to have!), I found another narrow crack in the bottom corner that must have been there for awhile. Given the placement of the cracks, I couldn't find a way to gain access with a heat gun so I needed to find another option. I found this (https://tbbonding.com/) as an option to patch poly tanks. I talked with them and felt good about trying. I like the idea that the patch is flexible and will expand with the tank. Jim Butcher Worst case, it doesn't work and I do the full tank replacement. The bonding process was straight forward and fairly easy with access to the inside of the tank. So far it is holding well after 6 months but I'm going to do some more testing to make sure. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510373#510373 Attachments: http://forums.matronics.com//files/brad_3_105.jpg http://forums.matronics.com//files/brad_2_143.jpg http://forums.matronics.com//files/brad_1_299.jpg ________________________________________________________________________________
Subject: Paint Scheme
Date: Mar 10, 2023
Brad Schafer is having problems posting so I am adding his Facebook posts. Found a nice solution for artwork on our Europas. I worked with Alwan Wraps in Michigan (sales(at)alwanwraps.com). For $250, they created a CAD image of a trigear and worked with me to layout the artwork. And then the decals were $450 including the tail and wheel pants. I'm assuming that anyone else wouldn't have to pay the full $240 since the CAD work is done already. See attached pics. Really happy with the results. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510374#510374 Attachments: http://forums.matronics.com//files/brad_5_184.jpg http://forums.matronics.com//files/brad_4_170.jpg ________________________________________________________________________________
Subject: Instrument Panel Inserts
Date: Mar 10, 2023
Brad Schafer is having problems posting here so I am adding his Facebook posts. Jim Butcher For my panel, I used Front Panel Designer. They have a great free design tool and create/ship the panels fairly quick in the US. The hard part was getting the panel outlines into CAD to start. From there, it was actually kinda fun with their design tool. The cost was between $50 and $175 depending on the thickness and complexity (2mm or 3mm). Let me know if anyone wants the CAD or Front Panel Designer files. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510375#510375 Attachments: http://forums.matronics.com//files/brad_9_706.jpg http://forums.matronics.com//files/brad_10_134.jpg http://forums.matronics.com//files/brad_7_750.jpg http://forums.matronics.com//files/brad_6_128.jpg http://forums.matronics.com//files/brad_8_761.jpg ________________________________________________________________________________
Subject: Trim damper assembly
Date: Mar 11, 2023
Hi everyone, Im wondering if anyone else has encountered this problem with the trim damper assembly as I have. >From Page 19-2 - Figure 2, the TS04A bolt is placed through the support bracket - however, when I installed the Nyloc Nut M10 and putting in safety (only by about 1 thread). The spring is fully compressed and causes binding with operating the electric trim. I can't see an easy way out of this and I have been thinking of removing the spring and cutting one or two spirals of the spring. Can anyone kindly offer some wisdom on this? Many thanks Tony -------- Tony Vaccarella Mascot NSW 2020 Sydney Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510382#510382 ________________________________________________________________________________
Date: Mar 11, 2023
Subject: Re: Paint Scheme
From: arwel pritchard <arwel.pritchard(at)powercom.ltd.uk>
Hi That is one good looking aircraft. One thing that worries me though is if you spill fuel whilst re-fuelling, will it damage the decals? Best regards Arwel On 10/03/2023 15:42, h&jeuropa wrote: > > Brad Schafer is having problems posting so I am adding his Facebook posts. > > Found a nice solution for artwork on our Europas. I worked with Alwan Wraps in Michigan (sales(at)alwanwraps.com). For $250, they created a CAD image of a trigear and worked with me to layout the artwork. And then the decals were $450 including the tail and wheel pants. I'm assuming that anyone else wouldn't have to pay the full $240 since the CAD work is done already. See attached pics. Really happy with the results. > > Jim Butcher > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510374#510374 > > > Attachments: > > http://forums.matronics.com//files/brad_5_184.jpg > http://forums.matronics.com//files/brad_4_170.jpg > > ________________________________________________________________________________
Subject: Re: Trim damper assembly
Date: Mar 11, 2023
Not had a problem. Whenever Ive come across something thats doesnt seem to work I always go back to the manual to check I have the right items and assembled them correctly. For example the thickness washer placed under the head of a bolt instead of the nut meant the shoulder of the bolt did not go all the way through a control rod end resulting in too much play in the control. Corrected and all works fine. Alan Sent from my iPhone > On 11 Mar 2023, at 11:04, tonyvaccarella wrote: > > > Hi everyone, > > Im wondering if anyone else has encountered this problem with the trim damper assembly as I have. > >> From Page 19-2 - Figure 2, the TS04A bolt is placed through the support bracket - however, when I installed the Nyloc Nut M10 and putting in safety (only by about 1 thread). The spring is fully compressed and causes binding with operating the electric trim. > > I can't see an easy way out of this and I have been thinking of removing the spring and cutting one or two spirals of the spring. > > Can anyone kindly offer some wisdom on this? > > Many thanks > Tony > > -------- > Tony Vaccarella > Mascot NSW 2020 > Sydney Australia > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510382#510382 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Instrument Panel Inserts
Date: Mar 11, 2023
Looks great! Yes lots of fun getting those profile lines correct Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510387#510387 ________________________________________________________________________________
Subject: the Obsidian Files - So Much Noise!!!
Date: Mar 11, 2023
Well, now that flying the europa is starting to become a bit more second nature, do we make it more enjoyable to fly? Really don't enjoy the noise of a racing bike any more; so its time to shut those fricken carburettors up! Today has been a day of distraction, instead of fitting new hydraulic hoses to some heavy machinery, and there's nothing better than playing with a europa.. The plenum box has been extracted and Cad'd up to analyse its flow and acoustic aspects; its basically currently acting as a fantastic resonator boosting induction noise straight through the firewall. Today has been spent looking at Mass Flow and Dynamic Pressure through the assembly at 6000rpm WOT. The target objective will be implementing passive noise attenuation features to mitigate carburettor induction noise ingress to the cockpit. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510388#510388 Attachments: http://forums.matronics.com//files/4f5a7fcb_d25e_4fa9_8fd8_0923ea9ff540_149.jpeg http://forums.matronics.com//files/c3ce2e93_9c38_47bc_802d_4b59b26889b7_498.jpeg ________________________________________________________________________________
Subject: RE: Europa-List Digest: 3 Msgs - 03/10/23
Date: Mar 13, 2023
Please refrain from sending further emails subscriber deceased!! -----Original Message----- From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Europa-List Digest Server Sent: 11 March 2023 07:31 Subject: Europa-List Digest: 3 Msgs - 03/10/23 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Europa-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Europa-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 23-03-10&Archive=Europa Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2023-03-10&Archive=Europa =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Europa-List Digest Archive --- Total Messages Posted Fri 03/10/23: 3 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 07:40 AM - Re: Tank repair options (h&jeuropa) 2. 07:43 AM - Paint Scheme (h&jeuropa) 3. 07:53 AM - Instrument Panel Inserts (h&jeuropa) ________________________________ Message 1 _____________________________________ Subject: Europa-List: Re: Tank repair options From: "h&jeuropa" <butcher43(at)att.net> Brad Shafer is having problems posting here, so I am forwarding his Facebook posts. Like many others, I woke up to gas on the floor and a crack in the tank. Mine was low on the saddle. I liked what Dave Disney had done so I drained the tank and created an opening in the top. With the ability to inspect the inside of the tank (which is a very nice option to have!), I found another narrow crack in the bottom corner that must have been there for awhile. Given the placement of the cracks, I couldn't find a way to gain access with a heat gun so I needed to find another option. I found this (https://tbbonding.com/) as an option to patch poly tanks. I talked with them and felt good about trying. I like the idea that the patch is flexible and will expand with the tank. Jim Butcher Worst case, it doesn't work and I do the full tank replacement. The bonding process was straight forward and fairly easy with access to the inside of the tank. So far it is holding well after 6 months but I'm going to do some more testing to make sure. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510373#510373 Attachments: http://forums.matronics.com//files/brad_3_105.jpg http://forums.matronics.com//files/brad_2_143.jpg http://forums.matronics.com//files/brad_1_299.jpg ________________________________ Message 2 _____________________________________ Subject: Europa-List: Paint Scheme From: "h&jeuropa" <butcher43(at)att.net> Brad Schafer is having problems posting so I am adding his Facebook posts. Found a nice solution for artwork on our Europas. I worked with Alwan Wraps in Michigan (sales(at)alwanwraps.com). For $250, they created a CAD image of a trigear and worked with me to layout the artwork. And then the decals were $450 including the tail and wheel pants. I'm assuming that anyone else wouldn't have to pay the full $240 since the CAD work is done already. See attached pics. Really happy with the results. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510374#510374 Attachments: http://forums.matronics.com//files/brad_5_184.jpg http://forums.matronics.com//files/brad_4_170.jpg ________________________________ Message 3 _____________________________________ Subject: Europa-List: Instrument Panel Inserts From: "h&jeuropa" <butcher43(at)att.net> Brad Schafer is having problems posting here so I am adding his Facebook posts. Jim Butcher For my panel, I used Front Panel Designer. They have a great free design tool and create/ship the panels fairly quick in the US. The hard part was getting the panel outlines into CAD to start. From there, it was actually kinda fun with their design tool. The cost was between $50 and $175 depending on the thickness and complexity (2mm or 3mm). Let me know if anyone wants the CAD or Front Panel Designer files. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510375#510375 Attachments: http://forums.matronics.com//files/brad_9_706.jpg http://forums.matronics.com//files/brad_10_134.jpg http://forums.matronics.com//files/brad_7_750.jpg http://forums.matronics.com//files/brad_6_128.jpg http://forums.matronics.com//files/brad_8_761.jpg ________________________________________________________________________________
Date: Mar 13, 2023
Subject: any suggestions on a cheaper Absolute Pressure meter?
Looking for something cheaper than the Testo-511 to properly calibrate my E-props CS controller. Cheers and thx! PeteZ ________________________________________________________________________________
Subject: ANDREW SARANGAN Search Engine working again!
Date: Mar 13, 2023
Hi Group Andrews Search Engine stopped adding new posts a while ago. I contacted Andrew and he was kind enough to promptly fix problem! Anyway, his Search (which I prefer over Matronics) is updating and working perfectly!: http://sarangan.org/europa_forum/html/europa-list/ Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510393#510393 ________________________________________________________________________________
Subject: Re: the Obsidian Files - So Much Noise!!!
Date: Mar 15, 2023
Stage one of "shut that noise up" completed. Applied a dense OEM sound absorbing material made by Diver Consolidated Industries; also acts as a secondary low temp heat shield... Not for the novice. It uses a magic 3M adhesive back. You get one chance sticking it down, and it cannot be removed to reposition... then give it a good going over with a roller; done... has added 1kg up from 560g to the plenum. The only way carbi noise is getting out of there now is through the air filter. Will try it out tomorrow and listen if Stage 2 baffles are still required. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510412#510412 Attachments: http://forums.matronics.com//files/01bd6b77_0c48_4675_a0a9_2c45bb3f83bf_110.jpeg http://forums.matronics.com//files/a258bea6_c367_4151_89fc_1cbcb0d85510_447.jpeg http://forums.matronics.com//files/f01ce90b_73f6_4fa1_9e56_005555a0b69b_100.jpeg ________________________________________________________________________________
Date: Mar 15, 2023
an added risk of ingestion. worth it? Cheers, PeteZ On Wed, Mar 15, 2023 at 5:33=AFAM Area-51 <goldsteinindustrial@gmail. com> wrote: > goldsteinindustrial(at)gmail.com> > > Stage one of "shut that noise up" completed. > > Applied a dense OEM sound absorbing material made by Diver Consolidated > Industries; also acts as a secondary low temp heat shield... Not for the > novice. It uses a magic 3M adhesive back. You get one chance sticking it > down, and it cannot be removed to reposition... then give it a good going > over with a roller; done... has added 1kg up from 560g to the plenum. > > The only way carbi noise is getting out of there now is through the air > filter. > > Will try it out tomorrow and listen if Stage 2 baffles are still required . > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510412#510412 > > > Attachments: > > > http://forums.matronics.com//files/01bd6b77_0c48_4675_a0a9_2c45bb3f83bf_1 10.jpeg > > http://forums.matronics.com//files/a258bea6_c367_4151_89fc_1cbcb0d85510_4 47.jpeg > > http://forums.matronics.com//files/f01ce90b_73f6_4fa1_9e56_005555a0b69b_1 00.jpeg > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 15, 2023
oops..... didn't look at the pics - my bad. only on the outside.... please forgive me PeteZ On Wed, Mar 15, 2023 at 6:13=AFAM Pete Zut wro te: > an added risk of ingestion. > > worth it? > > Cheers, > PeteZ > > On Wed, Mar 15, 2023 at 5:33=AFAM Area-51 > wrote: > >> goldsteinindustrial(at)gmail.com> >> >> Stage one of "shut that noise up" completed. >> >> Applied a dense OEM sound absorbing material made by Diver Consolidated >> Industries; also acts as a secondary low temp heat shield... Not for the >> novice. It uses a magic 3M adhesive back. You get one chance sticking it >> down, and it cannot be removed to reposition... then give it a good goin g >> over with a roller; done... has added 1kg up from 560g to the plenum. >> >> The only way carbi noise is getting out of there now is through the air >> filter. >> >> Will try it out tomorrow and listen if Stage 2 baffles are still require d. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=510412#510412 >> >> >> >> >> Attachments: >> >> >> http://forums.matronics.com//files/01bd6b77_0c48_4675_a0a9_2c45bb3f83bf_ 110.jpeg >> >> http://forums.matronics.com//files/a258bea6_c367_4151_89fc_1cbcb0d85510_ 447.jpeg >> >> http://forums.matronics.com//files/f01ce90b_73f6_4fa1_9e56_005555a0b69b_ 100.jpeg >> >> >> =========== =========== =========== =========== =========== >> >> >> >> ________________________________________________________________________________
Date: Mar 15, 2023
Hi Group Here's links to March 2023 Zoom Episode 5 about Fuel Sender Operation and Repair: https://1drv.ms/u/s!Ah1S270Nwg9Vgfx9spnrAw9ZaL5m7w?e=12nuwO For whatever reason, Matronics always cuts off some of the hyper-link when I post links. Just copy the entire link and paste into URL of browser. ** If buffering occurs when viewing mp4 video, open the settings icon and reduce resolution. The settings icon is a gear with a hole in it located on bottom. Ron and Wayne Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510418#510418 ________________________________________________________________________________
Date: Mar 15, 2023
Stage One of "shut that noise up" has been a flying success!!! Worth every one of the 1000g weight penalty; couldn't recommend it more. The mod has worked so well that noise canceling is no longer required.. in fact, its worse now flying with noise canceling than without... at WOT engine noise has gone from high pitched screaming hell to a dull drone... at cruise you could have a cockpit conversation without headphones; its just so much more relaxing and enjoyable... over the moon with the result... Weight & Balance has been affected by moving the CG more forward; with 10L fuel the cg crosses the forward boundary.. so i just have to t/o with 50L on board to balance out closer to center. Planning on adding a bit more aft weight so not too concerned. Will still apply Stage 2 internal baffles to shut things up even more... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510421#510421 Attachments: http://forums.matronics.com//files/41987b1f_3b7a_4d4e_9041_f862d99c8ffe_994.jpeg ________________________________________________________________________________
Date: Mar 15, 2023
Interesting. So you no longer hear the engine revs, but now only the significant hear whine and prop noises? > On Mar 15, 2023, at 7:18 PM, Area-51 wrote: > > > Stage One of "shut that noise up" has been a flying success!!! > > Worth every one of the 1000g weight penalty; couldn't recommend it more. > > The mod has worked so well that noise canceling is no longer required.. in fact, its worse now flying with noise canceling than without... at WOT engine noise has gone from high pitched screaming hell to a dull drone... at cruise you could have a cockpit conversation without headphones; its just so much more relaxing and enjoyable... over the moon with the result... > > Weight & Balance has been affected by moving the CG more forward; with 10L fuel the cg crosses the forward boundary.. so i just have to t/o with 50L on board to balance out closer to center. > > Planning on adding a bit more aft weight so not too concerned. > > Will still apply Stage 2 internal baffles to shut things up even more... > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510421#510421 > > > > > Attachments: > > http://forums.matronics.com//files/41987b1f_3b7a_4d4e_9041_f862d99c8ffe_994.jpeg > > > > > > ________________________________________________________________________________
Date: Mar 15, 2023
Experience is now a low frequency drone from exhaust along with slight level of low frequency carburettor noise; so can still hear the engine and gearbox, its just not a high frequency or high volume level. At cruise the noise volume of engine and air over the canopy is about equal. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510423#510423 ________________________________________________________________________________
Date: Mar 15, 2023
=EF=BB =9C At cruise the noise volume of engine and air over the canopy is ab out equal.=9D which is what i have with the stockish plenum, and softer lord moun ts fwiw. I wonder what id get if i wrapped my plenum too. PeteZ > On Mar 15, 2023, at 8:29 PM, Area-51 wrote : @gmail.com> > > Experience is now a low frequency drone from exhaust along with slight lev el of low frequency carburettor noise; so can still hear the engine and gear box, its just not a high frequency or high volume level. > > At cruise the noise volume of engine and air over the canopy is about equa l. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510423#510423 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Date: Mar 15, 2023
Peter, the material functions by absorbing specific high and low frequency waves of the audible spectrum; its material design purpose is for eliminating resonance drumming on automotive panels. The plenum box on 181 is very thin fibreglass, so its like a drum skin stock untreated. Everyone's ears will respond somewhat differently to sound waves, so results will be perceived differently. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510425#510425 ________________________________________________________________________________
Date: Mar 16, 2023
Area-51, Great feedback and thanks for sharing. Could you share more details, such as specifications, on the soundproofing material and the 3M adhesive used. I searched for Driver Consolidated Industries (DCI) and 3M Magic Tape and found nothing. I love my Europa except for, as you describe and I have done too, the "Screaming from Hell"! I am going to try this right away since if it is as you describe my Europa will go from "Great" to "Fantastic". Since I am going to take my airplane apart for painting I was considering installing a Firewall Blanket to reduce the screaming. I wonder if anyone has done this, results, and if positive materials used. Best, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510426#510426 ________________________________________________________________________________
Date: Mar 16, 2023
A-51, I have this material that I purchased a while back in an attempt to use something to reduce the noise in the cockpit. I never used it because this stuff is like lead in sheets. Incredibly heavy at 0.7 lb/sqft (3.4 kg/sqm), if I did the converting right. But it looks like it is what you used. I include a picture of what I got. It's a butyl based insulation with foil. About 80mil (2mm) thick. Is this close (at least in thickness) to what you used? Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510429#510429 ________________________________________________________________________________
Date: Mar 16, 2023
I'm so excited about this I will go now to the hangar and work on it with the material I have :). If it needs to be thicker I can always add a layer but I think this is what you used. Will report back. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510431#510431 ________________________________________________________________________________
Date: Mar 16, 2023
Just wondering out loud: extra unsupported weight/mass on the carbs? > On Mar 16, 2023, at 11:49 AM, n7188u wrote: > > > I'm so excited about this I will go now to the hangar and work on it with the material I have :). If it needs to be thicker I can always add a layer but I think this is what you used. Will report back. > > Chris > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510431#510431 > > > > > > > > > ________________________________________________________________________________
Date: Mar 16, 2023
A-51, Does your CFD show the ideal location for the carb vents in the plenum? Should be as close to a stagnant velocity point as possible I would guess. In my plenum they are located about as far from the top as in yours but further outboard, more or less in line with the carb intake axis. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510437#510437 ________________________________________________________________________________
Date: Mar 16, 2023
That is light weight sound reduction product at 0.7 lbs sqf. If it works on the firewall please post results. Dad spent many thousands of hours flying in the western Canadian Arctic behind a variety of aircraft that were rather loud but the worst was his Helio Courier with its gear driven Lycoming G0-435 he found a good solution though with adhesive foam & .010 lead at 6 lbs sqf. it was much heavier than the product you have but it made the geared Lycoming seem almost silent. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510438#510438 Attachments: http://forums.matronics.com//files/dads_helio_courier_new_paint_spring_19745_171.jpg ________________________________________________________________________________
Date: Mar 16, 2023
Cool story. I guess that to me this stuff seems heavy. I did have a 1964 Mooney that I removed the sound deadening material from the thin fwd fuselage aluminum skin. It was so lout that it would overpower the ANR headset I had back then and make it squeal during take off until power and prop RPM was brought back a little. I got the plenum out and will be doing the covering it today. The firewall I will do after I take the engine out to facilitate painting. Still don't know what to do there. I may use the "heavy" stuff I have for the metal firewall section (mono) since I heard that part could be a big contributor to noise going into the cabin. But may consider doing a blanket for the composite if I get some positive feedback from the group. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510439#510439 ________________________________________________________________________________
Subject: Re: October 2022 Zoom Episode 1
Date: Mar 16, 2023
Genius. Thx for the vid! PeteZ > On Mar 15, 2023, at 2:26 PM, rparigoris wrote: > > > Hi Group > > Here's links to March 2023 Zoom Episode 5 about Fuel Sender Operation and Repair: > https://1drv.ms/u/s!Ah1S270Nwg9Vgfx9spnrAw9ZaL5m7w?e=12nuwO > > For whatever reason, Matronics always cuts off some of the hyper-link when I post links. Just copy the entire link and paste into URL of browser. > > ** If buffering occurs when viewing mp4 video, open the settings icon and reduce resolution. The settings icon is a gear with a hole in it located on bottom. > > Ron and Wayne > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510418#510418 > > > > > > > > > ________________________________________________________________________________
Date: Mar 16, 2023
Ok, an update from this morning's second test flight... Today was magic; perfect conditions and zero wind; was up in the air just after sunrise; and experienced even more brilliant results... Today I got to use my TSO'd Clarity Aloft in ear comms without any bit of challenge from external noise; they are actually better to use now than the Bose Active X; even on WOT the Clarity Aloft volume was set at about 30%.. the aircraft flight experience is now like cruising down the highway in a wonderful 60's british sports car... it takes a lot to impress me, and i am beyond impressed; the aircraft is just such a joy to be in now. The conditions were so good today i tootled around at 70kt for 75minutes and burnt a whopping 6Lt of fuel... Chris, the product you pictured is the same spec, and its "Diver Consolidate Industries" in victoria australia, google for "DCI Heat Shielding", try emailing Wayne, he will fill you in on how to correctly use this product. For something like a 60's mustang rear quarter you only need a 4x12 inch strip to stop the panel drumming. There are other lighter DCI products for noise attenuation. Regarding the compensation tube positioning; any position 1.5" toward the center of the plenum box away from the carbi induction port will be in static atmospheric conditions and away from induction affects. The plenum box rests upon the top of the undercarriage spaceframe posts and backface firewall; it could be 50kg and still not cause any stress upon the bing carbi mounts. As is the mod has sent hell screaming back to where it fricken came from! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510447#510447 Attachments: http://forums.matronics.com//files/f1273b1d_5e16_4342_9488_a268fd3e6d10_208.jpeg ________________________________________________________________________________
From: Christoph Both <christoph.both(at)acadiau.ca>
Subject: Re: Best practices, Autopilot install MOD 75 & MOD 76
Date: Mar 16, 2023
Hello Europa Community: I am looking at upgrading my existing GRT SX-200 EFIS equipped aircraft to autopilot capabilities. What would be the best practices, from lessons learned and MOD 75&76 prescribed, to install the two lateral/vertical command GRT servos? While the lateral component control from a servo installed under the right seat seems rather straight forward, I am a bit concerned how to best locate and connect the vertical component servo to the CS10 torque tube. MOD76 suggest complete removal of the existing CS10 torque tube and replace with a CS10/2 version having an actuation horn affixed to. Is this the only (difficult) solution or would a connection to the elevator pushrod or already welded on actuation horn be a solution, without purchasing a replacement CS10/2? Perhaps welding/ riveting a horn to the existing CS10 tube would do? I have the GRT servos which look very similar to Dynon or Garmin AP new digital servos - any solutions to make a metal bracket or otherwise securely attach the servos to the aircraft would be appreciated? GRT sells metal servo brackets for general installations. I have a CLASSIC fuselage with original large tunnel. It was mentioned there could be a conflict with the glider wing brake actuating mechanism for the vertical component of the autopilot installation. EUROPA gliders, was there a solution found? Thank you, Christoph Both Wolfville Nova Scotia, Canada Europa Classic #223 2013 ________________________________________________________________________________
Date: Mar 16, 2023
70knts? Mine would be plowing like motorboat offplane lol. Fwiw, my classics airbox is free of touching anything but the carbs. :) PeteZ > On Mar 16, 2023, at 6:34 PM, Area-51 wrote: > > > Ok, an update from this morning's second test flight... > > Today was magic; perfect conditions and zero wind; was up in the air just after sunrise; and experienced even more brilliant results... Today I got to use my TSO'd Clarity Aloft in ear comms without any bit of challenge from external noise; they are actually better to use now than the Bose Active X; even on WOT the Clarity Aloft volume was set at about 30%.. the aircraft flight experience is now like cruising down the highway in a wonderful 60's british sports car... it takes a lot to impress me, and i am beyond impressed; the aircraft is just such a joy to be in now. > > The conditions were so good today i tootled around at 70kt for 75minutes and burnt a whopping 6Lt of fuel... > > Chris, the product you pictured is the same spec, and its "Diver Consolidate Industries" in victoria australia, google for "DCI Heat Shielding", try emailing Wayne, he will fill you in on how to correctly use this product. For something like a 60's mustang rear quarter you only need a 4x12 inch strip to stop the panel drumming. There are other lighter DCI products for noise attenuation. > > Regarding the compensation tube positioning; any position 1.5" toward the center of the plenum box away from the carbi induction port will be in static atmospheric conditions and away from induction affects. > > The plenum box rests upon the top of the undercarriage spaceframe posts and backface firewall; it could be 50kg and still not cause any stress upon the bing carbi mounts. > > As is the mod has sent hell screaming back to where it fricken came from! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510447#510447 > > > > > Attachments: > > http://forums.matronics.com//files/f1273b1d_5e16_4342_9488_a268fd3e6d10_208.jpeg > > > > > > ________________________________________________________________________________
Date: Mar 16, 2023
http://www.dci.com.au/services/thermal_acoustic_shielding Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510450#510450 ________________________________________________________________________________
Date: Mar 17, 2023
For treating firewall areas i would not use the butyl matting product... there is a much lighter product in the DCI line that is a dacron weave with 3M adhesive and foil shielding; it's primarily a medium level heat shield and acoustic isolator for OEM automotive under roof paneling; weighs almost nothing and is perfect for the firewall and upper engine cowl lid... it can be purchased direct in 1000x1000 size sheets. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510451#510451 ________________________________________________________________________________
Date: Mar 17, 2023
I used the Noico material since I already had it (purchased a while back but never used due to the weight). and is installed. Unfortunately we have a few days of bad weather and wind coming so may not be able to test but will try just before sunset today if the wind dies down a little. Regarding the material to use on the firewall, flammability of the material needs to be considered. I did a vertical flame test on the material I used in the airbox and the flame did not propagate. After the starting flame is removed it will burn for a short time but not support it (quits). I don't think it is any worse than the resin the airbox is made of but not 100% sure of course. And even wonder if it was the adhesive that was burning. But if there is a fuel or oil fire in the engine compartment this stuff will certainly not help. And the fumes may be another problem. So I would not consider this material unless more info on this becomes available. I will do a more aggressive test later this weekend using a torch. Want to make sure the material will not support s flame a I saw earlier today. Here are some pictures of the install. Looking forward to testing :) Best, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510456#510456 ________________________________________________________________________________
Date: Mar 17, 2023
Nice job; you don't muck around! Your airbox is slightly different and looks like your engine is possibly set forward?? Technical data on the butyl is provided on the DCI website in support pdf document; or via emailing them. Be mindful though it is shielded by the foil so this prevents air supporting flammability, but at the right temperature butyl will liquify into a tar type goo. If the situation is getting that hot you will likely be having bigger issues to worry about than the butyl igniting. Looking forward to hearing the results... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510457#510457 ________________________________________________________________________________
Date: Mar 17, 2023
A51, I didn't muck around on this one because I am so desperate to see if this work and make my airplane quieter that this morning I woke up before the sun came up and couldn't sleep anymore so went to the hangar and got to work :) Regarding the different airbox, my kit was a mix of bits and pieces scattered all over the country (and world). The airbox was missing but a kind soul in England send me an old one which is what you see here. However, when I tried to install it the thing's size was so off that the top cowling would not fit by a lot! I had to Frankenstein the airbox and chop about an inch of the top and glass it all up again. So yes, it is certainly custom. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510459#510459 ________________________________________________________________________________
Date: Mar 17, 2023
Christoph, On the Europa Club website under Bud Yerly Notes, there is a document called Pitch Autopilot Options which gives several suggestions. About your glider question, we found the mono wheel flap pushrod interfered with the glider spar after the spar was enlarged with the mandatory mod. Our solution was to replace the rod with a push pull cable. We have not completed our glider wings so no idea about interference with the airbrake mechanism. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510460#510460 ________________________________________________________________________________
Date: Mar 17, 2023
Ahhh, that makes sense.. yes, i fitted some buffer pads under mine and had to remove them back to none because the top cowl was standing up too proud after... Today i flew again for 75min and noticed that since installing this mod i am no longer feeling fatigued after i shutdown and exit the cockpit... prior after about 45min flight time i would start thinking about wanting to land and rest.. last three flights i have not had any thought about landing to rest... feeling a lot more connected to the aircraft now. Rolled out on 23 as usual, popped the flaps and undercarriage away and rotated at 90kt into a steep climb at 5000rpm holding at 72kt; watched the dial hit 1000' in a blink, then cruised around at 75kt again... figured, hey i got nowhere to actually go, why burn all that fuel and load everything up?! Did a few more steep climbs up to 2500' then 4000', flew the inbound leg on 72kt simulated engine failure, made the circuit entry at 1000' on a 600fpm decent Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510461#510461 Attachments: http://forums.matronics.com//files/52210861_f501_4109_9e19_fef8c326d349_387.jpeg ________________________________________________________________________________
Date: Mar 18, 2023
Hi Area-51, I follow your posts with much interest - not least because you have a handle on the engineering physics as evidenced by your simulation images. I was going to say that whilst adding mass coating is one route to improvement (Bergers Law 1911), isn't a set of noise-cancelling headphones a more optimum or at least, initial, route to achieve the same thing - and at less weight gain?. Not a criticism, just interested to know why the additional mass route. It will work if you add enough mass, but the carb rubber wear/unknown fire risk increase and general weight penalty does seem a bit onerous. That said, the tinkering/problem-solving with these things is almost as much fun as the flying, of course ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510462#510462 ________________________________________________________________________________
Date: Mar 18, 2023
These are great discussion points, so let's break them down a bit... The weight penalty factor v's noise cancelling headphones: I've added 1000g stationed 50mm ahead of the firewall; my W&B has been marginally affected... The Bose Active X headsets weigh 0.485kg (1.1kg with carry case), the Clarity Aloft weigh 0.135kg (0.320kg with carry case)... The AUW penalty is now the added mass less the gain; we are now at around 0.4kg weight penalty... but hang on a minute, let's now fly two up! Bose headsets with carry cases 2.2kg, Airbox mod with Clarity Aloft headsets and carry cases 1.75kg... just lost 0.45kg!! ... thats two more $100 hamburgers!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510463#510463 ________________________________________________________________________________
Date: Mar 18, 2023
rparigoris wrote: > Hi Group > > Here's links to March 2023 Zoom Episode 5 about Fuel Sender Operation and Repair: > https://1drv.ms/u/s!Ah1S270Nwg9Vgfx9spnrAw9ZaL5m7w?e=12nuwO > > For whatever reason, Matronics always cuts off some of the hyper-link when I post links. Just copy the entire link and paste into URL of browser. > > ** If buffering occurs when viewing mp4 video, open the settings icon and reduce resolution. The settings icon is a gear with a hole in it located on bottom. > > Ron and Wayne Just wanted to say how interesting this video was, completely fascinating stuff regarding the Apollo programme. Thanks for posting. My father mentioned that back in the late 50's they used an English Electric Saturn analogue computer to simulate nuclear reactor fault conditions. It was a hard wired structure that entirely filled two floors of the building they worked from! Changed days. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510464#510464 ________________________________________________________________________________
Date: Mar 18, 2023
Thanks for your reply and i do understand your reasoning. In the Automotive world (based upon ~20+ years in hands-on NVH development there), the other issues were 1) moving the resonating cavity/intake openings as far away as possible from the operators ear - usually to the front of the engine bay, as, like reductions from mass damping, distance makes about the same difference in attenuation (double the distance, halve the sound power), and 2) working to try and tune the intake pipework so that it does not resonate at the typical cruise engine RPM. Most cars have intake resonators that take this problem away - some of them are even closed-loop, measuring the tone and then adjusting the effectiveness of the anti-resonator to minimise it. I wish we had the freedom to tinker here in the UK that you have - changing a nut and bolt can invoke cries for the mandatory need for a scrutinised MOD required, here. And I dearly wish i still had access to the rather expensive test equipment i could get my hands on back then, a Campbells diagram [Sound level or Vibration amplitude vs both RPM and frequency scales - for both engine Vibration and emitted noise vs RPM for e.g. a Rotax engine installation in a Europa], could tell us all so much - why exhaust springs break so easily, why the noise in the cabin is what it is, and what the optimum engine RPMs would be to minimise those etc. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510465#510465 ________________________________________________________________________________
Date: Mar 18, 2023
Oh woww!! Excellent... I totally agree with everything you have imparted... The job is yours, you're hired; report back in month's time Where can we liberate this said test equipment from???? We need to know where to put the Helmoltz resonator!! Flew again today; the results are very consistent.. next stage is an internal baffle for the air box... an extended forward running induction tube was considered however this would end with the inlet port facing forward instead of upward; so any noise emissions would be directed out front like an air horn as apposed to an upwards direction away from the ground below. However so far i am totally satisfied with the result as is, but will take it further with the internal baffle and hear what happens Any technical comments toward the "shut that noise up" project is helpful for Europans.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510467#510467 ________________________________________________________________________________
Date: Mar 19, 2023
As Clive alluded to, resonance in the opposed 4 banger exhaust is an issue as well as intake. The thin fiberglass footwell directly under the feet of the pilot or passenger, especially in the Classic with the exhaust pipe exiting directly aft under the pilots feet, resonates something fierce and sounds just like the carb inlet. Creighton Smith's 96EG underwent a surgery of the heavy Classic Exhaust and the aft lobe was removed, and a straight pipe added. What a racket that made initially. We changed the tuning length and put in an expansion pipe (nothing sophisticated, just cut the pipe and put a wider pipe on the end to change the note). Creighton was a motorcycle racer, and he did an excellent job softening the sound. What a difference. Still louder than my 914 but it didn't bring the airport to a stop on ground runs any more. Prop pressure pulses across the aircraft windscreen in the Europa are not that bad, so I have not been concerned with that as in other light aircraft. However, any looseness in the doors hinges, latches and the D panel in the back are very large drum skins and the low frequency drone is annoying enough and fatiguing, but the rattle is irritating beyond description. Prop power pulses as I call them, is normally not bad on a three blade that is tapered. The two blade wide chord blades can definitely be felt and heard as even the XS nose tends to transmit some of that back to the cockpit. Personally, having a 914 and leather interior makes most of my aircraft remarkably quiet on the inside. The 912S and 912 versions I tend to prefer a rework of the inlet air geometry to break up the intake noise and as far as the exhaust note, I leave it to Robin at CKT Engineering for the 912S exhaust note. It is amazing what a bad baffle in the exhaust sounds like. Many don't realize they have a bad silencer baffle. CKT has done a nice, but expensive, Rotax 912 down pipe exhaust and side exit that makes the little fart can engine sound very quiet. My opinion for what that is worth. Noise is fatiguing. ANR helps the ears, but the vibration of the various noises hitting the body is fatiguing. The Europa has that phenolic type firewall that is very thick and I do not do any heat or soundproofing on it. I do add a thin stainless steel plate some 4-6mm proud of the pilots footwell on some of the 914s as this cuts the heat on the feet. Proper air venting is needed down here in the South. I will not do a painted only interior because it is loud and sound bangs around all through the cockpit with nothing to absorb it. I do not do any firewall sound proofing on a trigear because I build in a firewall aft of the nose gear covered with firewall 2000 (excellent fire and sound proofing). The mono is a different animal. I find the metal firewall an excellent sound transporter and amplifier. The airflow through the slots is also a bugger. I have tried the soft and hard Lord mounts and frankly didn't see any change in apparent vibration (purely measured by feel) Props make a difference as does exhaust plumbing and support. Nothing worse than an exhaust system in contact or firmly attached to the frame on a 912S. The 914, you don't have a choice on the mounting. But in its 15-20 years it has had a few turbo support cracks repaired. One of the reasons I went with the stock kit. Experimenting to fix issues is time consuming/expensive and well, an experiment, sometimes it works, sometimes it doesn't and hopefully, it doesn't add weight. Keep up the good work. Bud Yerly -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Area-51 Sent: Saturday, March 18, 2023 6:45 PM Subject: Europa-List: Re: the Obsidian Files - So Much Noise!!! Oh woww!! Excellent... I totally agree with everything you have imparted... The job is yours, you're hired; report back in month's time Where can we liberate this said test equipment from???? We need to know where to put the Helmoltz resonator!! Flew again today; the results are very consistent.. next stage is an internal baffle for the air box... an extended forward running induction tube was considered however this would end with the inlet port facing forward instead of upward; so any noise emissions would be directed out front like an air horn as apposed to an upwards direction away from the ground below. However so far i am totally satisfied with the result as is, but will take it further with the internal baffle and hear what happens Any technical comments toward the "shut that noise up" project is helpful for Europans.. Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D510467%23510467&data=05%7C01%7C%7Ce88f0b46c7a54be481b708db28033aa4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638147766561533529%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=ayTktzrf9sz%2BVN0b1dnDYl0qTVMjz17wy0l1%2BqT%2BPBk%3D&reserved=0 ________________________________________________________________________________
Date: Mar 19, 2023
Amazing... we should approach Ratheon to finish the job for an Auto Auto Pilot for the Europa Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510470#510470 ________________________________________________________________________________
Subject: What did you do with your Europa this week 19/03/23
Date: Mar 20, 2023
Got to the field at dawn each day and flew six out of the seven days for a total of 8.75hrs. Finally sorted all the cockpit audio recording issues out with the gopro Scrubbed one xcountry mission due to fog and then had a xcountry cruise to visit another Europan for coffee and hangar tour... Did not take any cheese along for the journey; just some apples... midday return flight was a bit too warm in the cockpit; need some aircon installed Really enjoyed flying with the Clarity Aloft headset in the altered cockpit environment; can hear incoming radio calls so much better than before with the Bose headsets. A whole new experience exiting the cockpit feeling joyful instead of fatigued. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510472#510472 Attachments: http://forums.matronics.com//files/f4e47f98_1824_4f01_a9c1_326d9302a7f8_159.jpeg ________________________________________________________________________________
Subject: Pilot Aware in Europe
Date: Mar 21, 2023
Good Day, If any European pilots are interested in supporting expansion of the Pilot Aware (Electronic conspicuity) platform across Europe please would they contact me directly. Thanks, Roger ________________________________________________________________________________
Date: Mar 21, 2023
Yep, that D panel at the back of the cockpit along with its bulk head sure sounds like a brazilian festival drum... that got attended to not that long ago by fitting a 1/4" ply brace for the luggage ties to the reverse face of bulkhead; made a noticeable difference. 181 has a CTK exhaust fitted and i find its performance quite acceptable; DCI SheetHot 5000 had to be fitted to the lower cowl as it was burning and getting pretty close to igniting. The footwell area does not get that warm. I have been receiving some pm's regarding the air box mod; its turning out a common grievance for many other europans. Regulations in the UK may possibly be mitigated by reviewing the mod as a "surface treatment" much like painting, as the box itself is not being modified; just my thoughts here not recommendations to depart from any regulations, especially any fire risk prevention regulations. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510474#510474 ________________________________________________________________________________
Date: Mar 22, 2023
Experiments and discoveries are moving forward over the past few days with some entertaining results. A rudimentary study of some baffle concepts were drafted and run through the simulator; the variations happened by accident due to forgetting to half the density consumption to rpm speed; so the elongated porting was developed and employed on these over calculated equations of x2 actual rpm; once recalibrated the results were pleasing on all the variations. Flow analysis through the air box was applied at 6000, 5500, 5000, 4000 rpm at 1013.25 atmosphere at 20.05C. Filtering for Static Pressure primarily, and Acoustic Energy and Flow Path as added features. Red represents Ambient Atmospheric Pressure which indicates zero restriction to air flow within the airbox at engine rpm. Testing revealed the carburettor porting tubes are slightly undersized causing a pressure drop in these regions at engine speeds above 4000rpm on normally aspirated setups. At 6000rpm the pressure drop equates to approx 600' altitude increase, and at 5500 rpm approx 300' altitude increase, and at 5000rpm around 80' altitude increase. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510475#510475 Attachments: http://forums.matronics.com//files/b4b6c3a5_1516_4c61_9caa_a16ea86d12b7_114.jpeg http://forums.matronics.com//files/5e3d3071_f86a_4ce3_96bf_dbf994ee29de_972.jpeg http://forums.matronics.com//files/79860508_7c0c_4c0d_8f2a_201fdb9d1d25_380.jpeg http://forums.matronics.com//files/dabb99f2_8fec_485f_a172_8d33b4064569_164.jpeg http://forums.matronics.com//files/3c98c93a_9816_4f2f_a91c_abfd458f6483_210.jpeg http://forums.matronics.com//files/532f6ff2_632a_4281_a486_0815710d93d5_189.jpeg ________________________________________________________________________________
Date: Mar 22, 2023
Very interesting conversation guys. Part of what makes owning an Europa fun is this type of interaction. I have not been able to fly the airplane enough to reach a conclusion on this most recent mod to my plane. I only flew around 20 minutes last Friday, was windy and bumpy so had other worries in my mind. Tomorrow AM looks nice so will do a short local before work but really want to do a longer x-country to be able to provide an objective conclusion (on the subject of fatigue). But I hate to report that based on that short flight last Friday I did not find that the mod made as large a difference as I was hoping for based on A51's encouraging results. But again, the jury is still out. I think I do detect a slight difference. Maybe a little softer on the high frequency. And I think it is worth keeping the change. But I was hoping for more. Will report again after I get a few longer flights in. Please do keep in mind that I have a paint only interior and, as Bud indicated, I too agree this is a good reason why my Europa is loud. Clive, I still need to go through all the tech discussion in detail (I am at work dealing with other tech discussions) but I did buy a new Bose A 20 when I started flying my Europa. It is incredibly effective at cutting all low frequency noise (prop) but all the high frequency ones seem to go right through making it VERY annoying. In fact, I sometimes switch to my non-ANR headsets and find the low frequency drone much more pleasant (but yes, it is louder). So I will continue evaluating and will provide some final thoughts later on. And all feedback on this subject is greatly appreciated. I think that if I try something in the near future it will be lighter noise insulation on the metal firewall, some quick prototype level interior paneling to see if I can see a change before commuting to that route, and I really wanted to try a wheel pant I have for the mono, maybe in hopes of deflecting air away from the wheel well and reducing turbulence in that area. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510476#510476 ________________________________________________________________________________
Date: Mar 22, 2023
Fwiw, Classic, mono, no fairings, panted interior, 912s, stock exhaust, factory cold air intake plenum. My biggliest bang was the softer lords swapout. Before with the stock rubbers the gear whine and harsh compression pulses excited the cabin surfaces and the engine was the most overbearing noise. Post rubbers, the gear whine is below the engine, and the engine is below the 130mph cruise air noise. e-props unique sound signature is more noticable than the WDs when pulling throttle back. I doubt i would have heard that with the stock mounts. High freq engine noise is far below the wind noise. Bose do a fantastic job now. E-props reduced the large start stop excursions (and obvious gearbox dogging) experienced with the WD, nullifying my previously required exhaust and oil reservoir clearancing efforts with the softer lords. Unhappy with bose high freq atten? Try the lightspeeds for comparison lol. I also get a noticeable buffet from my unfared mono wheel, but havent got around to fairing it..watching with interest if you do. Cheers, PeteZ > On Mar 22, 2023, at 10:09 AM, n7188u wrote: > > > Very interesting conversation guys. Part of what makes owning an Europa fun is this type of interaction. > > I have not been able to fly the airplane enough to reach a conclusion on this most recent mod to my plane. I only flew around 20 minutes last Friday, was windy and bumpy so had other worries in my mind. Tomorrow AM looks nice so will do a short local before work but really want to do a longer x-country to be able to provide an objective conclusion (on the subject of fatigue). > > But I hate to report that based on that short flight last Friday I did not find that the mod made as large a difference as I was hoping for based on A51's encouraging results. But again, the jury is still out. > > I think I do detect a slight difference. Maybe a little softer on the high frequency. And I think it is worth keeping the change. But I was hoping for more. Will report again after I get a few longer flights in. > > Please do keep in mind that I have a paint only interior and, as Bud indicated, I too agree this is a good reason why my Europa is loud. > > Clive, I still need to go through all the tech discussion in detail (I am at work dealing with other tech discussions) but I did buy a new Bose A 20 when I started flying my Europa. It is incredibly effective at cutting all low frequency noise (prop) but all the high frequency ones seem to go right through making it VERY annoying. In fact, I sometimes switch to my non-ANR headsets and find the low frequency drone much more pleasant (but yes, it is louder). > > So I will continue evaluating and will provide some final thoughts later on. And all feedback on this subject is greatly appreciated. > > I think that if I try something in the near future it will be lighter noise insulation on the metal firewall, some quick prototype level interior paneling to see if I can see a change before commuting to that route, and I really wanted to try a wheel pant I have for the mono, maybe in hopes of deflecting air away from the wheel well and reducing turbulence in that area. > > Chris > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510476#510476 > > > > > > > > > ________________________________________________________________________________
Date: Mar 22, 2023
Interesting Pete, Since I will probably be removing the engine for painting in the next couple of weeks, does anyone have any dimensions for the new spacers needed to retrofit the Lord mounts? I remember Erich telling me a while back that getting the engine to rest in the correct position took a bit of effort. I could give this a try. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510478#510478 ________________________________________________________________________________
Date: Mar 22, 2023
to add one interesting anecdote regarding the noise in my Europa, people tell be that when I fly overhead to enter the pattern (midfield downwind entry is common at my airport due to a Class C at one end of the field) my airplane makes no sound. They can only hear what they think is just wind noise and makes them think it is an electric airplane :) Good job CKT. But inside .... another story. Although I once took a friend up for a ride and he thought I was crazy and that the airplane was not that noisy inside. But he has an F1 Rocket so he may not be a good judge of what a small Rotax powered composite airplane should sound like :) Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510479#510479 ________________________________________________________________________________
Date: Mar 22, 2023
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Mar 22, 2023
Thanks Pete. Good info. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510481#510481 ________________________________________________________________________________
Date: Mar 22, 2023
The wife and I flew in our Europa to Lake Havasu, AZ (KHII) for lunch with a couple of friends. The weather was just spectacular which was a welcome ch ange. This spring as been cold, wet and windy. Certainly, not your typical Las Ve gas weather. The wife snapped this photo as we starting our decent into our home field. Erich Trombley N28ET Classic Mono 914 ________________________________________________________________________________
Subject: Re: What did you do with your Europa this week 19/03/23
Date: Mar 22, 2023
Weather here in FL has been a bit wonky. Nice during the week and then not so good on the weekends when I can fly. I did Area-51 mod of insulating the intake air box with sound deadening material (enjoyed being in project mode) and waiting for weather to improve a little to fly more. I am getting ready to paint the airplane. I have bought a good spray gun, a forced air respirator system, got the paint and I am rebuilding my wood frame spray booth. I am going to wait until after Sun'n Fun next week, in case the weather is awesome and decide to fly the airplane there, to start disassembly and painting. I plan to take my time to paint and implement a few changes on the airplane. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510483#510483 ________________________________________________________________________________
Date: Mar 22, 2023
Choosing not to fly today; instead thought toward identifying drumming areas of the fuselage; details attached along with required acoustic patch sizes. Some areas of hatches and footwell floor are only accessible for treating during building; footwell floor void could probably be filled with expander foam though. Total added mass can be estimated from sizings. Sizings can be reduced 20% and still remain affective. Mid to forward L/R of centre upper cowl - 4"x10" Mid to forward L/R of centre lower cowl - 3"x12" Naca vent slider door rattle Behind naca vent area to L/E of wing - 6"x10" Fuselage, forward foot well floor step area - 4"x4" Forward hatch fuselage area - 2"x8" Mid centre line to rear hatch hinge - 2"x14" Vert stab rib to fuselage fillet - 4"x30" Vert stab trim bar port area - 4"x8" upper 2"x8" lower Fuselage upper lower seam, fuel filler to L/E of h'stab - 3"x50" Fuselage upper 1/8 quadrant, fuel filler to L/E of h'stab - 4"x45" Fuselage belly, flap hinge covers to static port - 6"x40" Hatches, lower frame 1"x 12" and rear corner sections 6"x8"x8" triangle Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510484#510484 ________________________________________________________________________________
Date: Mar 22, 2023
We have been lucky here with conditions past couple of weeks; waiting for winter and cold thick air to arrive... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510485#510485 ________________________________________________________________________________
Date: Mar 22, 2023
It=99s been a fantastic winter season up here in Canuckstan! Lots of snow, but every week has essentially been flyable. I=99ve been getting in an average of about 15hrs/mnth of local zenning-out. Love winter, gooey smooth air, and lotsa white pillow emerge landing spots. Spring has sprung tho, so expecting lotsa rainy weather soon. PeteZ On Mar 22, 2023, at 7:14 PM, Area-51 wrote: gmail.com > We have been lucky here with conditions past couple of weeks; waiting for winter and cold thick air to arrive... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510485#510485 ________________________________________________________________________________
Date: Mar 22, 2023
Magic... what temp is it inside the cockpit during a flight like that? I had 33C on my return leg the other day.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510487#510487 ________________________________________________________________________________
Date: Mar 22, 2023
Always toasty.especially when sunny. I normally have to mix in cold air when its over -10c. PeteZ > On Mar 22, 2023, at 7:58 PM, Area-51 wrote: > > > Magic... what temp is it inside the cockpit during a flight like that? I had 33C on my return leg the other day.. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510487#510487 > > > > > > > > > ________________________________________________________________________________
Date: Mar 23, 2023
Tuesday we flew to Napoleon, MI, about 60 NM. We took our lunch with us, walked the mile and half to a park in town, ate lunch and returned. Unlike the sunny photos above, our weather was overcast with lots of precip showing on the return trip but none reaching the ground. Nice day and good to get in the air after winter. Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510489#510489 ________________________________________________________________________________
Date: Mar 23, 2023
nice! no pic? On Thu, Mar 23, 2023 at 9:58=AFAM h&jeuropa w rote: > > Tuesday we flew to Napoleon, MI, about 60 NM. We took our lunch with us, > walked the mile and half to a park in town, ate lunch and returned. Unlik e > the sunny photos above, our weather was overcast with lots of precip > showing on the return trip but none reaching the ground. Nice day and go od > to get in the air after winter. > > Jim & Heather > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510489#510489 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 23, 2023
Shortest flight yet this morning. Rolled out on 23 after pre-flights and hit rough as guts turbulence straight away until turning xwind at 500'... then spotted a squall approaching at 15nm from the south. Jump plane advised about to drop chutes.... quick decision to re-join circuit downwind and put the bird back on the ground; squall hit the field upon exiting cockpit. Had a random moment noticing how clear headset audio is now with the Clarity Aloft... Crystal!! So good to have all the audio issues finally sorted Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510493#510493 ________________________________________________________________________________
Subject: Re: Finishing tips
Date: Mar 25, 2023
Any idea who wrote this article? Has some excellent tips but I have a few questions for the author. It's posted on the Europa Club site. Thanks, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510496#510496 ________________________________________________________________________________
Subject: Muffler (silencer) suspension puzzle
Date: Mar 25, 2023
In my limited knowledge and experience of light aircraft having flat-four boxer engines, particularly the Rotax 912 series, the various muffler designs have something in common. The muffler boxes all hang by the four exhaust tubes (headers) from the exhaust ports and this has always seemed strange to me. It hardly seems surprising that aircraft owners get cracked tubes, broken springs and occasionally cracks in the muffler boxes. Before going further I want to assure anyone who might be interested that my engine mount rubbers are good, the carburettors and propeller are balanced "to within an inch of their lives", the muffler and tubes get installed with extreme care not to introduce stresses by tightening the manifolds haphazardly. In fact CKT provides a telescopically jointed #1 cylinder tube which, if installed last before tightening the joint clamp, should ensure that there aren't any installation-induced stresses. Yes I've tried the alternative type of tube with the Rotax-provided header pieces which insert into the exhaust ports and it made no difference. It cracked after fewer hours than the older type which it replaced. A friend has an Evektor SportStar with an identical Rotax 912 and its header tubes look segmented, like a vacuum cleaner hose. He never has muffler related problems. Before converting my aircraft from Classic to a more XS-type configuration forward of the firewall, I had the original double-chambered heavy silencer provided by Europa and it also had occasional broken springs and cracked header tubes. Eventually I resorted to making two thick large eliptical "washers", each with a large hole through which the lower engine mounting bolts were secured and a small hole for attaching a bracket. These brackets, being one narrow strip of metal each side going to the sides of the silencer, were then secure by jubilee clips to where the tubes entered the muffler box. That put an end to broken tubes etc for a couple of hundred hours. Now to my question. Why are mufflers allowed to hang unsupported by their tubes and consequently vibrate laterally. Is there a risk that by preventing some or most of these vibrations, cracks and/or damage might occur elsewhere? I'm hopeful of an answer from someone who has formal engineering expertise to offer, relating to "dark arts" like harmonics, oscillations, nodes of vibration, damping, crack prevention and all that esoteric stuff, but in terms that a layman can understand. In summary, what are the associated risks of anchoring the muffler box like I did previously? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510497#510497 ________________________________________________________________________________
Subject: Re: Muffler (silencer) suspension puzzle
Date: Mar 25, 2023
Nearly all and everything contemporary produced is completely designed within a digital computer specified environment; from electronics to mechanical; covering design criteria such as Thermal Expansion & Conductivity, Modal Frequency Vibrational Response, Dynamic Physical Loads & Gravity, Material Elasticity Stress & Strain, Chemical Interactions... This is a very basic matrix of R&D analysis. When a company such as Bombardier develop a power train it is run through the above matrix before being produced and released for industry use. The factory supplied 9XX exhaust system will have the above matrix applied along with field testing results which are fed back into the design process upon a "Continual Improvement" basis, which the end user sees as optional or mandatory factory Service Bulletins. This closed loop system quickly falls apart when third party aftermarket components are brought into the mix; some may cause premature failure, others may prevent it; it depends upon the applied knowledge of who ever is producing the component. The whole exhaust is constantly vibrating at (x)hz at (x)deg and will be tested at the factory based upon the typical operating ranges of the power unit being in the vicinity of 5100rpm and (x)deg give or take 15% either side. Stress and strain fatigue points of the exhaust system will naturally be found around both bending points, and attachment points. Hard mounting the exhaust muffler to the engine block moves any inertia forces of the exhaust into the engine block which may or may not be designed to support such loads beyond (x)hrs of usage at (x)rpm. A rough running engine or loose fixing somewhere in the mix adds another dimension of vibration into the fatigue failure equation. This why its important to keep any motor well serviced and tuned and running smooth. The short answer to the question is "Cycle Count" but that is just going to be too cryptic for most to understand. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510499#510499 ________________________________________________________________________________
Subject: Re: the Obsidian Files - So Much Noise!!!
Date: Mar 25, 2023
Today is Sunday and the conditions are useless again for flying. So its back into "Shut That Noise Up" project... In this post 181's air box is getting analysed for harmonic resonance. The test passes frequencies from 1hz to 20,000hz through the 1.5mm fibreglass component to see where points of dynamic distortion will be at specific frequencies; blue is zero red is maximum. Four frequencies were isolated from the pack to review what is going on at 3600 / 4000 / 5200 / 5600 rpm. The data provided correlates to where the air box body is "resonating" at specific rpm. The purpose of this is to identify focused points of resonance that can be individually attenuated as opposed to wrapping the entire box.... image order correlates to rpm list above. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510500#510500 ________________________________________________________________________________
Date: Mar 26, 2023
or in my case a pocketed dog gearbox, heavy warpdrive prop, eaten plastic gearbox thrust washer (twice), and lightly loaded cruise prop resonance, resulting in dramatic exhaust cracking (three times). Replaced the pocketed dogs and plastic washer, changed to a lighter prop, and no more cracked exhaust. Magic. Cheers, PeteZ > On Mar 25, 2023, at 10:39 PM, Area-51 wrote: > > > Nearly all and everything contemporary produced is completely designed within a digital computer specified environment; from electronics to mechanical; covering design criteria such as Thermal Expansion & Conductivity, Modal Frequency Vibrational Response, Dynamic Physical Loads & Gravity, Material Elasticity Stress & Strain, Chemical Interactions... This is a very basic matrix of R&D analysis. > > When a company such as Bombardier develop a power train it is run through the above matrix before being produced and released for industry use. > > The factory supplied 9XX exhaust system will have the above matrix applied along with field testing results which are fed back into the design process upon a "Continual Improvement" basis, which the end user sees as optional or mandatory factory Service Bulletins. > > This closed loop system quickly falls apart when third party aftermarket components are brought into the mix; some may cause premature failure, others may prevent it; it depends upon the applied knowledge of who ever is producing the component. > > The whole exhaust is constantly vibrating at (x)hz at (x)deg and will be tested at the factory based upon the typical operating ranges of the power unit being in the vicinity of 5100rpm and (x)deg give or take 15% either side. Stress and strain fatigue points of the exhaust system will naturally be found around both bending points, and attachment points. Hard mounting the exhaust muffler to the engine block moves any inertia forces of the exhaust into the engine block which may or may not be designed to support such loads beyond (x)hrs of usage at (x)rpm. > > A rough running engine or loose fixing somewhere in the mix adds another dimension of vibration into the fatigue failure equation. > > This why its important to keep any motor well serviced and tuned and running smooth. > > The short answer to the question is "Cycle Count" but that is just going to be too cryptic for most to understand. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510499#510499 > > > > > > > > > ________________________________________________________________________________
Date: Mar 26, 2023
Very interesting!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510503#510503 ________________________________________________________________________________
Date: Mar 26, 2023
Hi Dan After some digging I have refreshed the page you referred to so as to recognise and credit the probable authors. Attribution: Thanks to George Sychrovsky & the late Nigel Graham Hope this helps. We are most fortunate that many good people have donated their achievements in life to posterity. Have a contact reference that I will email to you separately. Regards Bob If anyone spots any errors or omissions on the Europa Club website please advise by email to secretary(at)theeuropaclub.org and we would endeavour to fix. danbish99 wrote: > Any idea who wrote this article? Has some excellent tips but I have a few questions for the author. It's posted on the Europa Club site. > > Thanks, > > Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510508#510508 ________________________________________________________________________________
Date: Mar 26, 2023
Thx Jerry, good write up on finishing. I will try to add a Youtube video on a method used by Cory Bird on his aircraft called " Symmetry " a 2004 Oshkosh Grand champion winner. He called his finish technique "the epoxy wipe method" https://www.youtube.com/watch?v=43K1qwoHbnc&t=22s If the link doesn't work just search Youtube for, epoxy wipe method composite aircraft finishing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510510#510510 ________________________________________________________________________________
Date: Mar 26, 2023
Hi Dan The original web article can be found here: http://curedcomposites.com/index.html or the page on finishing here: http://curedcomposites.com/finish.html Another good article on finishing is Wayne Hicks Cozy IV project: http://ez.canardaircraft.com/www.ez.org/canardpages/pages/waynehicks/index.html See Chapter 25 on Finishing -------- Regards Kelv Weston Kit 497 kelv(at)kdweston.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510511#510511 ________________________________________________________________________________
Date: Mar 26, 2023
Hi Dan A pdf attached of the "Epoxy Wipe" or "Skim Coating" method extracted from Wayne Hicks Cozy project. There is also lots of great finishing advice on this forum from Bud Yearly and the late great Nev Eyre. -------- Regards Kelv Weston Kit 497 kelv(at)kdweston.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510512#510512 Attachments: http://forums.matronics.com//files/skimcoating_171.pdf ________________________________________________________________________________
Date: Mar 26, 2023
Today I finally had a chance to get a longer flight in. It's hard to say how much improvement the install of the sound deadening material on the air box has on the internal noise. But there is certainly improvement!! The flight today was very pleasant and more enjoyable. But what really struck me is that, as A51 experienced, I had to lower the intercom volume quite a bit since it felt too loud. Same thing when I was playing music as I generally do. So, even though I can still hear relatively high frequency sound, but maybe less, it seems that overall there is a reduction in noise. But, I have to admit this is all just based on perception. It is indeed hard to quantify the change. But I have to say that despite the increase in weight, it is a keeper. On a different note: I finished rebuilding my spray booth and getting closer to starting the painting process. I will hold off taking the airplane apart this week to see if I fly it to Sun n Fun but by next weekend it will come apart so no more flying until it is done. I also have a couple of pending jobs I want to perform on the airframe. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510513#510513 ________________________________________________________________________________
Subject: Considering a few mods. Opinions?
Date: Mar 26, 2023
Dear Europa Friends, Since my airplane is coming apart for painting, I wanted to implement the cockpit widening mod 67. Any negative experiences with doing this? I think it would help increase the comfort of the airplane as I notice that after a x-country flight my left arm hurts a little from rubbing on the door frame. Since the door will be worked on I am going to change the gas strut attach point (my door was already built with the old style attach point). I know this is basically a must although the current configuration has worked OK. At last, anyone has any experience with installing a monowheel wheel pant? I have a kit for that and was thinking about installing the front part only. I am not doing it for the speed as I know the wheel is basically blocked by the cowling's exhaust but I think it could help seal the wheel well better and possibly reduce turbulent air getting into it (noise). Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510514#510514 ________________________________________________________________________________
Subject: Re: Considering a few mods. Opinions?
Date: Mar 26, 2023
Attached is a rudimentary cross section of free stream air through the forward fuselage voids without lower cowl ducting. >From experience flying in a mono with wheel fairing fitted; with ANR switched on at the time there was no detectible change in cabin noise volume compared to flying in 181. However the degree off air flow through the cockpit was greatly multiplied due to the wheel well being mostly sealed off during flight; not fitting the rear portion of the fairing will greatly diminish this ventilation feature. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510515#510515 Attachments: http://forums.matronics.com//files/9727fbf9_885d_4ac6_bc0d_a372d13ea377_675.jpeg ________________________________________________________________________________
Date: Mar 27, 2023
Lower the wheel such that its 45-50% exposed. Its too high in your sim. (And would love to see an 8.00 tire) Thx! Pete > On Mar 26, 2023, at 10:36 PM, Area-51 wrote: > > > Attached is a rudimentary cross section of free stream air through the forward fuselage voids without lower cowl ducting. > >> From experience flying in a mono with wheel fairing fitted; with ANR switched on at the time there was no detectible change in cabin noise volume compared to flying in 181. However the degree off air flow through the cockpit was greatly multiplied due to the wheel well being mostly sealed off during flight; not fitting the rear portion of the fairing will greatly diminish this ventilation feature. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510515#510515 > > > > > Attachments: > > http://forums.matronics.com//files/9727fbf9_885d_4ac6_bc0d_a372d13ea377_675.jpeg > > > > > > ________________________________________________________________________________
Date: Mar 27, 2023
Already reset it to correct position and sizing ages ago; just haven't updated to the latest solution; its going be an arduous procedure with all the fine details now in the mix... i did mention the above sample is rudimentary... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510517#510517 Attachments: http://forums.matronics.com//files/f5e65cbf_45dc_4360_a986_948276e086fb_104.jpeg ________________________________________________________________________________
Subject: Sun N Fun
Date: Mar 27, 2023
Just a reminder, the Europa Forum is scheduled for Wednesday at 1:00 PM in room CFAA-05. Bud Yerly will be leading the forum. Hope you make it! Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510518#510518 ________________________________________________________________________________
Subject: Europa Sun 'n Fun Forum and gatherings.
Date: Mar 27, 2023
Sun 'n Fun is here! Join us at the Forum! Now that Anita and I are no longer doing a booth at Sun 'n Fun, my blood pressure is down, and my sense of humor is back. Airshows can be a grind. We are volunteers for the event with my local EAA chapter making sandwiches daily with about 40 other volunteers and friends from the local community and our flying community. Jerry Hope and I and our wives are at the Sun 'n Fun Pavillion making sandwiches, drinks and shooting the bull from 0900 until 1130 daily. So far, Anita and I enjoy driving home after lunch and I go to the shop and print some 3D mods and repair parts I have done to tools/and other items. I have made many little tidbits improving my aged CAD skills and patience as these printers are notoriously slow. Frankly, some of what I have done could be whacked out of foam and glass and modded quicker. That's another story. If you all would like to come and chat, we have a place to meet out of the sun and a bit more quiet, so come over to the pavillion about 1130, it is a nice place to meet and exchange ideas. I will be walking the show in the afternoons taking a break from the airshow watching crowds seeing the sites and old friends and if anyone wants to go to the shop in the late afternoon, I'll be available to open it up and assist folks wanting to sift through the mono stuff left over. In the shop, I only have one kit left partially built XS Trigear and Brett Browns trigear and my own trigear. Of course, I'm tearing down my woodworking tools and rehabbing them so it is a mess. That is where the 3D printed parts are going. We've arranged a Forum for Europa Owners on Wednesday March 29th at CFAA-05 FROM 1:00 TO 1:55 (the Nazis will throw us out at 1156). There are problems that just arrived with WiFi in the building so this will be an informal gathering for Europa Owners and the topics are open for discussion. Of course, we also can meet in the Sun 'n Fun Pavillion area daily and gather and talk about individual issues you may be having on your Europa if you don't want to discuss it in the forum. I have a shopping list this year and am not afraid to exercise it, so 12AY is tore down in the shop getting little goodies installed. I may be adding the internal Stratus to my ESG transponder. Some other doo dads are being looked at and more than likely I'll probably just build another Stratux an put it into the cockpit area. My move of the Stratux ADS-B in to the rear near my transmitter antenna has caused interference with the ADS-B operation and although shielded and working, it looks like an amateur did the install. The weather looks reasonable from Tuesday afternoon through the rest of the week so join us. Be sure to bring sun screen and a hat. IT IS HOT! Best Regards, Bud and Anita Yerly Custom Flight Creations, Inc. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510519#510519 ________________________________________________________________________________
Date: Mar 27, 2023
Today has been spent crunching numbers again by adding the butyl layer to 181's air box. The untreated air box was also rerun through the same analysis matrix settings as a control for comparison purposes. Several criteria were examined on both models; the modal natural frequency, the harmonic response, and the harmonic acoustic qualities. Two sets of solutions were applied overall based upon 1 cylinder cycle and 4 cylinder cycles from 3000rpm to 5800rpm; both provided similar attenuation plot results. The images attached are from the 4 cylinder cycle solutions. The attached images relate to distortion of the air box at a nominated frequency of 8200hz, being 4100rpm. Blue represents zero distortion, red maximum measured distortion. The two images clearly show how well the butyl layer attenuates excitation frequencies of the air box; being the image with the most blue. The attached graphs are related to the amplitude of applied frequencies being projected from the air box to the surrounding environment, measured at a near field specific position to the air box being 100mm above the air filter opening, behind the rear at the firewall, inside under the air filter, and corollate to (x2) rpm. The db attenuation qualities of applying the butyl has proven much better than expected. One point to note is the material density applied. The DCI product presents a density of 1310kg/m3 against standard 900kg/m3 of other similar products. It was surprising to make the distinction between the lower amplitude levels on the graphs to the different power setting rpm selected in real flight situations; they are identical to where the smooth running points are being perceived to be. Again these tests are not for determining induction noise affects, they are for determining the inherent acoustic qualities of the air box and how it is affected by environmental frequencies along with its ability to adsorb vibrational frequencies. Can it or can it not absorb and dissipate a specific kind of kinetic energy. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510520#510520 Attachments: http://forums.matronics.com//files/a36fd941_1515_4c04_b9fc_0d14389760b0_191.jpeg http://forums.matronics.com//files/61ad6bda_5185_488d_ba0b_3f8573defecb_173.jpeg http://forums.matronics.com//files/71bda7a8_4377_49aa_8b92_faa9a3fe50c3_650.jpeg http://forums.matronics.com//files/e0f1a51a_5b31_4743_926c_b7eaf6d216da_106.jpeg http://forums.matronics.com//files/3b843e40_1bf6_498e_85b9_a2e3aaeb69bf_110.jpeg http://forums.matronics.com//files/36823efb_a9da_43af_b444_24f772356014_184.jpeg http://forums.matronics.com//files/54d66213_a643_42a1_93d2_5483cc7be7d3_951.jpeg http://forums.matronics.com//files/4db4f5b3_52d3_4cd7_991f_757fc0a54a36_207.jpeg ________________________________________________________________________________
Subject: Re: Sun N Fun
Date: Mar 27, 2023
Ill be there Fred, A194 Sent from my iPhone > On Mar 27, 2023, at 7:37 AM, h&jeuropa wrote: > > > Just a reminder, the Europa Forum is scheduled for Wednesday at 1:00 PM in room CFAA-05. Bud Yerly will be leading the forum. > > Hope you make it! > > Jim > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510518#510518 > > > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2023
I wanted to go but can go Thursday or Friday. I guess I'll have to pass this year. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510524#510524 ________________________________________________________________________________
Subject: Re: Europa Sun 'n Fun Forum and gatherings.
Date: Mar 27, 2023
Hi Bud, I will see if I can go Wednesday but most likely it will have to be Thursday or Friday since my son wants to come and we are limited by his school obligations. If I can't I will go by the pavilion to say hello at 11:30. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510525#510525 ________________________________________________________________________________
Date: Mar 27, 2023
Air spilled from the intake duct looks terrible. I also have the duct open on the lower starboard side of the cowling. I guess that is there for the 914 but I kept it open because it seems to provide some cool air to the oil tank area and rear of the engine. I dare to say it may even augment the flow through the exit a little. My cooling system is working very well so afraid to change anything at this point. I am planning to remove the gills on the top cowling and make that area smooth. I have them closed right now and it seems to me they probably just add turbulence to the air going over them. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510526#510526 ________________________________________________________________________________
Date: Mar 27, 2023
I'll be looking forward to seeing you. Weather is better later in the week . Bud Get Outlook for Android ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of n7188u Sent: Monday, March 27, 2023 3:48:26 PM Subject: Europa-List: Re: Europa Sun 'n Fun Forum and gatherings. Hi Bud, I will see if I can go Wednesday but most likely it will have to be Thursda y or Friday since my son wants to come and we are limited by his school obl igations. If I can't I will go by the pavilion to say hello at 11:30. Chris Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D510525%23510525&data=05%7C01%7C%7Cae92e ef70e8c41b0249508db2efcd6c2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63 8155435751798881%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMz IiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=AOPs8YEy5HXm56jVav ECJAO1hYnPqy2JoEXyy0UhGKU%3D&reserved=0 %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C01%7C%7Cae92eef7 0e8c41b0249508db2efcd6c2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63815 5435751955084%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=f3J7xXyLSaghhp%2FK%2B %2BmschG%2FJWNTKiNiYU0EIhWw%2BgI%3D&reserved=0 %2Fforums.matronics.com%2F&data=05%7C01%7C%7Cae92eef70e8c41b0249508db2efc d6c2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638155435751955084%7CUnkn own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C3000%7C%7C%7C&sdata=OxeNsSqfDVpcgOgN9JBI9Iv%2BTfGe1K1FO0mad6p WShU%3D&reserved=0 %2Fwiki.matronics.com%2F&data=05%7C01%7C%7Cae92eef70e8c41b0249508db2efcd6 c2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638155435751955084%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C3000%7C%7C%7C&sdata=Im3vcFK6nboEDRFiClVKkpx4WHAW%2BbfyrS%2BPA9c 9Oag%3D&reserved=0 F%2Fmatronics.com%2Fcontribution&data=05%7C01%7C%7Cae92eef70e8c41b0249508 db2efcd6c2%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638155435751955084% 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=mb5xy6iPHbRm3IrBPhTYZ92OL3%2BRsA0NV DNe3%2Fvdt7U%3D&reserved=0 ________________________________________________________________________________
Date: Mar 27, 2023
BTW, I did a little number crunching of my own. I measured all the templates I used to cut the airbox sound deadening material and calculated the weight for the Noico material I used. 0.6 kg or 1.3 lbs. It is significant for a single component but for now I'll keep it. Regarding the effect of this additional mass on the carburetor mounts, the airbox is well supported on the back. But that's not to say it has no effect on the carb rubber mounts so I will just double the inspections on that area. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510527#510527 ________________________________________________________________________________
Date: Mar 27, 2023
Curious, how is it supported in the back? Mine is spaced away from the firewall. Thx! PeteZ > On Mar 27, 2023, at 4:11 PM, n7188u wrote: > > > BTW, I did a little number crunching of my own. I measured all the templates I used to cut the airbox sound deadening material and calculated the weight for the Noico material I used. > > 0.6 kg or 1.3 lbs. It is significant for a single component but for now I'll keep it. > > Regarding the effect of this additional mass on the carburetor mounts, the airbox is well supported on the back. But that's not to say it has no effect on the carb rubber mounts so I will just double the inspections on that area. > > Chris > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510527#510527 > > > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2023
An aluminum bar is attached to the back of the box and down to the engine mount (the part that is fixed to the ring mount, not behind the rubber mounts). As shown in the plans. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510530#510530 ________________________________________________________________________________
Date: Mar 27, 2023
Aha! Makes sense. .....I have a classic :) PeteZ On Mon, Mar 27, 2023, 4:57 p.m. n7188u wrote: > > An aluminum bar is attached to the back of the box and down to the engine > mount (the part that is fixed to the ring mount, not behind the rubber > mounts). As shown in the plans. > Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510530#510530 > > ________________________________________________________________________________
Date: Mar 27, 2023
[quote="n7188u"]Today I finally had a chance to get a longer flight in. It's hard to say how much improvement the install of the sound deadening material on the air box has on the internal noise. But there is certainly improvement!! The flight today was very pleasant and more enjoyable. But what really struck me is that, as A51 experienced, I had to lower the intercom volume quite a bit since it felt too loud. Same thing when I was playing music as I generally do. So, even though I can still hear relatively high frequency sound, but maybe less, it seems that overall there is a reduction in noise. But, I have to admit this is all just based on perception. It is indeed hard to quantify the change. But I have to say that despite the increase in weight, it is a keeper. On a different note: I finished rebuilding my spray booth and getting closer to starting the painting process. I will hold off taking the airplane apart this week to see if I fly it to Sun n Fun but by next weekend it will come apart so no more flying until it is done. I also have a couple of pending jobs I want to perform on the airframe. Chris[/quote] Chris, i noticed you mention calc on the added mass of your air box being 0.6kg. This aligns with the lower density of products out there. The affects will be reduced... Adding a second layer will bring the results closer to what the DCI product has provided, but will of course add another 0.6kg. Reviewing the graphs demonstrates the db reduction achievable for a given rpm. The average is 10db but some points it is as much as 25db... the high frequency vibrational load upon the carbi rubbers is reduced as well as a result. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510532#510532 ________________________________________________________________________________
Date: Mar 27, 2023
Thanks for the advice A51. I am right now in the process of disassembling my airplane to paint. When I finish this phase I will get back to the sound issue. Will continue following your analysis and experimentation. Best, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510533#510533 ________________________________________________________________________________
Date: Mar 27, 2023
Went up for another hour and made a point of listening to the volume levels in the cockpit at various rpm. The analysis graphs showed volume levels falling off at 5000rpm, so made a conscious effort to listen and indeed they did!! ... Remarkable!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510534#510534 ________________________________________________________________________________
Date: Mar 27, 2023
Thanks everyone for all the great resources - awesome to be able to reach out for help like this. You've surely saved me a ton of time avoiding sand & fill hell! Best, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510535#510535 ________________________________________________________________________________
Subject: Widening the cockpit - Mod 67
Date: Mar 28, 2023
Hi, As I mentioned on a previous message, I am considering the cockpit widening mod (67). Just checkng to make sure it makes sense since it involves some cutting and will require me to touch up the interior paint which is quite nice right now. My concern is that the mod involves only a partial widening of the lower door edge. It seems that if you do this your arm will still touch this remaining edge of the door. I guess that yes, that remaining width of the door is further outboard than the fuselage door flange so some gain in overall width is achieved. Im looking for some comments regarding this mod. Impression? Are you happy or not if you did it? Is it worth it? I once asked Bud and he gave his nod of approval which to me means a lot. Just wanted to see what other people that have done it to their airplanes thought. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510536#510536 ________________________________________________________________________________
Date: Mar 28, 2023
Hi Chris I have done the width mod and to be honest it's a waste of time and effort. It buys you no more than 15mm on either side and requires you to cut out a chunk of the fuselage door lip and well as doing the same with the door, as well as reworking the door locking mechanism. I'd leave it personally. Kind Regards Steve Ivell Mob: 07971 128842 E-mail: steveivell(at)pestproof.co.uk -----Original Message----- From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of n7188u Sent: Tuesday, March 28, 2023 12:44 PM Subject: Europa-List: Widening the cockpit - Mod 67 Hi, As I mentioned on a previous message, I am considering the cockpit widening mod (67). Just checkng to make sure it makes sense since it involves some cutting and will require me to touch up the interior paint which is quite nice right now. My concern is that the mod involves only a partial widening of the lower door edge. It seems that if you do this your arm will still touch this remaining edge of the door. I guess that yes, that remaining width of the door is further outboard than the fuselage door flange so some gain in overall width is achieved. Im looking for some comments regarding this mod. Impression? Are you happy or not if you did it? Is it worth it? I once asked Bud and he gave his nod of approval which to me means a lot. Just wanted to see what other people that have done it to their airplanes thought. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510536#510536 ________________________________________________________________________________
Subject: Re: Widening the cockpit - Mod 67
Date: Mar 28, 2023
Chris, my aircraft has this mod already done so I didn't know any better but recently I rode in one without it and I can say that I noticed the difference. It wasn't a remarkable difference but was noticeable. I suppose that this comment just muddies the waters for you as I'm sure you will get the opposite view. Why don't you try to sit in one that has the mod first and decide then? Cheers Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510538#510538 ________________________________________________________________________________
Date: Mar 28, 2023
The downward curvature of the canopy prevents sitting close to the door and forces the occupant towards the centreline of the aircraft. So, providing hip space in the centre tunnel is more effective that arm/shoulder space at the door. However, if you are sitting low with good head clearance then it can make a difference, if only to make it less noticeable that the door cill is sticking in to your arm. Duncan McF. > On 28 March 2023 at 12:54 Steve Ivell wrote: > > > > Hi Chris > > I have done the width mod and to be honest it's a waste of time and effort. It buys you no more than 15mm on either side and requires you to cut out a chunk of the fuselage door lip and well as doing the same with the door, as well as reworking the door locking mechanism. I'd leave it personally. > > Kind Regards > > Steve Ivell > Mob: 07971 128842 > E-mail: steveivell(at)pestproof.co.uk > > -----Original Message----- > From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of n7188u > Sent: Tuesday, March 28, 2023 12:44 PM > To: europa-list(at)matronics.com > Subject: Europa-List: Widening the cockpit - Mod 67 > > > Hi, > > As I mentioned on a previous message, I am considering the cockpit widening mod (67). Just checkng to make sure it makes sense since it involves some cutting and will require me to touch up the interior paint which is quite nice right now. > > My concern is that the mod involves only a partial widening of the lower door edge. It seems that if you do this your arm will still touch this remaining edge of the door. I guess that yes, that remaining width of the door is further outboard than the fuselage door flange so some gain in overall width is achieved. > > Im looking for some comments regarding this mod. Impression? Are you happy or not if you did it? Is it worth it? > > I once asked Bud and he gave his nod of approval which to me means a lot. Just wanted to see what other people that have done it to their airplanes thought. > > Chris > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510536#510536 > > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 28, 2023
Hi guys, Thanks for the feedback. Very much appreciated. I still have some time before I need to commit because I will leave the painting of the fuselage to last. Although it doesn't look hard to do I agree it is quite a bit of work. Particularly considering I already have the interior painted and would require sanding off the paint in the areas needed, and then paint it again. I will say that at the last flight I did the contact of my arm against the door sill was bothering me a little. I also think that the continuous slight leaning to the side doesn't add to comfort. But as Duncan said, the head is also an issue that is not addressed my this modification. And I am not really a wide person. I wonder what demographics Europa had in mind when they designed our beloved airplanes [Rolling Eyes] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510540#510540 ________________________________________________________________________________
Date: Mar 28, 2023
V2UgZGlkIHRoZSBoZWlnaHQgbW9kIGFzIHdlbGwgd2hpY2ggaXMgbWFqb3Igc3VyZ2VyeSBhbmQg Y2FuJ3QgYmUgZG9uZSByZXRyb3NwZWN0aXZlbHkuDQpBIHNpbXBsZXIgc29sdXRpb24gdG8gdGhl IHdpZHRoIG1vZCB3b3VsZCBiZSB0byBmYXNoaW9uIGEgcGllY2Ugb2YgZm9hbSB0byBzaXQgdW5k ZXIgdGhlIGRvb3IgbGlwIHRvIHNtb290aCB0aGUgY29udG91ciBhcyB0aGUgbGlwIGlzIHF1aXRl IHByb25vdW5jZWQgd2l0aG91dCB0aGUgd2lkdGggbW9kLi4uLi4gbXVjaCBlYXNpZXIuIPCfmIEN Cg0KS2luZCBSZWdhcmRzDQoNClN0ZXZlIEl2ZWxsDQpNYW5hZ2luZyBEaXJlY3Rvcg0KUGVzdHBy b29mIEx0ZC4NCjA3OTcxIDEyODg0Mg0Kc3RldmVpdmVsbEBwZXN0cHJvb2YuY28udWsNCl9fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fDQpGcm9tOiBvd25lci1ldXJvcGEtbGlzdC1zZXJ2 ZXJAbWF0cm9uaWNzLmNvbSA8b3duZXItZXVyb3BhLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+ IG9uIGJlaGFsZiBvZiBuNzE4OHUgPGNobWdhcmJAZ21haWwuY29tPg0KU2VudDogVHVlc2RheSwg TWFyY2ggMjgsIDIwMjMgNDoyMzo0NyBQTQ0KVG86IGV1cm9wYS1saXN0QG1hdHJvbmljcy5jb20g PGV1cm9wYS1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBFdXJvcGEtTGlzdDogUmU6IFdp ZGVuaW5nIHRoZSBjb2NrcGl0IC0gTW9kIDY3DQoNCi0tPiBFdXJvcGEtTGlzdCBtZXNzYWdlIHBv c3RlZCBieTogIm43MTg4dSIgPGNobWdhcmJAZ21haWwuY29tPg0KDQpIaSBndXlzLA0KDQpUaGFu a3MgZm9yIHRoZSBmZWVkYmFjay4gVmVyeSBtdWNoIGFwcHJlY2lhdGVkLiBJIHN0aWxsIGhhdmUg c29tZSB0aW1lIGJlZm9yZSBJIG5lZWQgdG8gY29tbWl0IGJlY2F1c2UgSSB3aWxsIGxlYXZlIHRo ZSBwYWludGluZyBvZiB0aGUgZnVzZWxhZ2UgdG8gbGFzdC4NCg0KQWx0aG91Z2ggaXQgZG9lc24n dCBsb29rIGhhcmQgdG8gZG8gSSBhZ3JlZSBpdCBpcyBxdWl0ZSBhIGJpdCBvZiB3b3JrLiBQYXJ0 aWN1bGFybHkgY29uc2lkZXJpbmcgSSBhbHJlYWR5IGhhdmUgdGhlIGludGVyaW9yIHBhaW50ZWQg YW5kIHdvdWxkIHJlcXVpcmUgc2FuZGluZyBvZmYgdGhlIHBhaW50IGluIHRoZSBhcmVhcyBuZWVk ZWQsIGFuZCB0aGVuIHBhaW50IGl0IGFnYWluLg0KDQpJIHdpbGwgc2F5IHRoYXQgYXQgdGhlIGxh c3QgZmxpZ2h0IEkgZGlkIHRoZSBjb250YWN0IG9mIG15IGFybSBhZ2FpbnN0IHRoZSBkb29yIHNp bGwgd2FzIGJvdGhlcmluZyBtZSBhIGxpdHRsZS4gSSBhbHNvIHRoaW5rIHRoYXQgdGhlIGNvbnRp bnVvdXMgc2xpZ2h0IGxlYW5pbmcgdG8gdGhlIHNpZGUgZG9lc24ndCBhZGQgdG8gY29tZm9ydC4g QnV0IGFzIER1bmNhbiBzYWlkLCB0aGUgaGVhZCBpcyBhbHNvIGFuIGlzc3VlIHRoYXQgaXMgbm90 IGFkZHJlc3NlZCBteSB0aGlzIG1vZGlmaWNhdGlvbi4NCg0KQW5kIEkgYW0gbm90IHJlYWxseSBh IHdpZGUgcGVyc29uLiBJIHdvbmRlciB3aGF0IGRlbW9ncmFwaGljcyBFdXJvcGEgaGFkIGluIG1p bmQgd2hlbiB0aGV5IGRlc2lnbmVkIG91ciBiZWxvdmVkIGFpcnBsYW5lcyAgW1JvbGxpbmcgRXll c10NCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTUxMDU0MCM1MTA1NDANCg0KDQoNCg0KDQoN Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgRXVyb3BhLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09 IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09 IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpf LT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpf LT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9FdXJvcGEtTGlzdA0KXy09DQpfLT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09 ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBj b250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+ IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAg ICAtIE5FVyBNQVRST05JQ1MgTElTVCBXSUtJIC0NCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBN YXRyb25pY3MgRW1haWwgTGlzdCBXaWtpIQ0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmlj cy5jb20NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0 ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAg LS0+IGh0dHBzOi8vbWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQo ________________________________________________________________________________
Date: Mar 28, 2023
One personal observation regarding finishing: I thought this process was going to be painful, but actually found it to be not as bad as I thought it would. I honestly did not read the entire procedure posted here but I will briefly say what I did. 1.- Clean and carefully scuff sand the fiberglass or gelcoat. 2.- Using the the fishing line technique, apply a nice think coat of expancell plus West Systems 105. What helped a lot was to use an epoxy pump and a sensitive weight scale to exactly measure the ratio of epoxy and expancell. Keeping the mixture consistent between mixes is key. 3.- Apply the mix using a dry wall spreader modified with an angle epoxied at the width of the application end. This is also key to keep the spreader from bending and creating a concave surface. 4.- Wait until the applied coat starts to gel, remove the fishing line, fill the groves left by the line. 5.- Using Dura-Block sanding blocks and very coarse sandpaper sand expancell coat until no depressions are observed. Most of the time a single pass of expancell coat was enough. If a few voids are present fix those. 6.- Now the cool part, I used a modified epoxy 2K filling primer made by 5-Star and rolled it on using a small foam roller. Push hard and fill as many pinholes as you can. 7.- Once cured, apply coat of Dry Guide Coat (I used Mirka brand). 8.- Sand this coat until all of the guidecoat is gone. Don't worry if this results in a good part of the 5-Start 2K to be gone. 9.- Spray one heavy coat of SPI (Southern Polyurethanes) white Epoxy primer. Welcome to pinhole land since this primer will make them show like craters in the moon (it's actually called "cratering" by the people that make the prime which is very prone to doing this). 9.- Now, without sanding the epoxy primer but before 7 days after applying it, use thin 3M polyester glaze to fill every pin hole, one by one. This is tedious but the fantastic quality of the 3M glaze makes the job much easier. The 7 day window is important since the epoxy primer doesn't need to be sanded if the glaze and subsequent 2K is applied within this time frame. 10.- Sand the pinholes. This part is indeed tedious because the polyester putty will stick to the sandpaper. The solution was to use a scrap piece of fiberglass and use it to scrape the glaze of the sandpaper. Use only high quality 3M sanding paper. The cheaper red one seems to work better though and the glaze sticks less. 11.- Spray a heavy coat of SPI grey regular 2K primer. 12.- If any small pinholes show I used red one part lacquer glaze to fill them. Quicker and easier for just a few of them. 13.- Guide coat, sand until the white shows and almost all grey 2K is gone. the guide coat will show the low spots. Here you need to gage what fillers to use to reach perfection. A little more 2K will fill shallow areas but it is a little heavier. Still I used it. Some polyester 2K glaze is also good. I don't think I had anything deep enough to go to expancell. If you do you have to do all the stuff stated above on that area. 14.- Finally, a coat of SPI white epoxy and you can spray the paint (no sanding needed if within 7 days). Or I flew it on primer for 2 years. The stuff still looks like the day it was applied and no issues with bugs or deterioration. The SPI primer is semi gloss so it looks pretty good too. And I used a forced air respiration system and a dust collector from Harbor Freight. I think it is a must. I can provide more detail on the sandpaper used, 3M glaze PN, 5 Star modified epoxy primer, SPI stuff but will have to collect the info. I can also put together a few pictures. I hope I didn't bore anyone with this long post. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510542#510542 ________________________________________________________________________________
Date: Mar 28, 2023
"I wonder what demographics Europa had in mind when they designed our beloved airplanes" Ivan Shaw is 6' 2" and not slim (I'd say that to his face, so no worries :-D) https://www.theeuropaclub.org/the-europa/creator-ivan-shaw HTH Paul G-PLPM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510543#510543 Attachments: http://forums.matronics.com//files/screenshot_20230328_171244_acrobat_for_samsung_105.jpg http://forums.matronics.com//files/b02db01a_83ec_4d94_9f3d_20cc2c057693_75880_178.jpeg ________________________________________________________________________________
Date: Mar 28, 2023
Yikes, that is tight (sorry Ivan, you know we love you the same) :) I guess he really wanted to go fast. Mission accomplished on that front. Good idea on the foam piece. Will try that first. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510544#510544 ________________________________________________________________________________
Date: Mar 28, 2023
First Day of Sun 'n Fun. It was wildly busy doing volunteer work. I went through the LSA and Spot Landing contest. My old friend and EAA member John Moody (The father of Ultralights) porpoised his little ultralight yesterday and luckily at 80+ he got a scratch on his arm and cracked his helmet when he hit hard on the nose and the plane flipped upside down (it is a biplane) and we got him medical attention and he is fine. It P.O.ed his wife as he broke his pledge to stop flying his Easy Riser. So I didn't see much and after running errands also, we got home had supper and I'm vegging out. Tomorrow the front comes through and we are doing the Europa Seminar at 1 PM still showing at CFAA-05 on the second floor room 206 so watch the signs. Fly/Drive Safe and see you there. Bud Yerly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510548#510548 ________________________________________________________________________________
Date: Mar 28, 2023
Im glad to hear John is ok. I always enjoyed watching his show. Now it seems Ill go to SnF on Saturday. Not a fan of going that day but my son has school obligations and he wants to come. We would like to see the night show and pitch a tent to sleep then head back home on Sunday. Ill try to fly the Europa but forecast calls for a windy day on Sunday. Will see as the day nears. Could always take the LongEZ (that plane doesnt mind windy days but cant take anything in it) Anyone there with an Europa on Saturday? Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510549#510549 ________________________________________________________________________________
Date: Mar 29, 2023
Always onwards into the realm of investigation and dissection... "trust the science"!!!! Ever wondered what's inside a 912's factory Rotax muffler? Today's episode of "shut that noise up" was spent looking at the back end of the rotax; running the numbers on the factory stock 912is exhaust muffler... how well does it actually look on paper? Well, let's tear it apart and find out?! Thankfully no destructive work was required; and no animals were harmed in this episode.. these days we can simply grab a CAD model and whiz it through some predefined plugins and see what gets spat out... personally when i first turned the cad viewer to xray i was astounded, i said to myself "that is a joke; that won't be doing a bloody thing... what's the replacement price on that again?!"... let's come back to that knee jerk assumption later... So we ran our pre calc's, established our base frequency range for 5000rpm, and got to work preping the model for analysis. Several tests were run looking at low band, medium band, and wide band results; the focus here is primarily on the low band results. Well, the low band results showed zero attenuation of sound transmission until 320Hz with awesome attenuation capabilities of 32db at 460Hz!!! This is great!! Only problem being 460Hz equates to 12600rpm, and 320Hz equates to 9600rpm so my knee jerk assumption appears supported. So the factory 912is muffler is as affective as that of a Chonda generator, i.e, empty expansion box with pipe going in and pipe going out... To be fair the muffler does provide affective mid range attenuation in the frequency range most noticeable for human hearing, which is mostly the higher frequencies being generated by the muffler itself. It would be great to compare a CTK muffler but i won't be cutting 181's unit apart any time soon to CAD it up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510550#510550 Attachments: http://forums.matronics.com//files/1f6e1548_17dd_4e90_b588_bec23798c896_142.jpeg http://forums.matronics.com//files/1f5250e7_b701_4e0f_ab87_d7db7b6abb6c_133.jpeg http://forums.matronics.com//files/bbb2fa18_f533_44b8_af14_2621feb7dce5_804.jpeg http://forums.matronics.com//files/837fd3bd_185e_4aea_8d09_b55c4b67f09f_197.jpeg http://forums.matronics.com//files/7d9ff80c_01ff_408b_b9af_ae19cd58199b_105.jpeg http://forums.matronics.com//files/f2ce52d8_42f6_42d5_94cd_271b3e433dea_122.jpeg http://forums.matronics.com//files/d471b1b6_b67d_4966_a489_e94eccb8dc70_351.jpeg ________________________________________________________________________________
Date: Mar 29, 2023
Seminar for Europa owners in room 205. 1:00PM BUD YERLY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510551#510551 ________________________________________________________________________________
Date: Mar 30, 2023
An update on yesterday's recon into an exhaust muffler... spent the day trying a few different things mods; all that was mostly achieved was a transposition along the frequency band but not much db reduction... gave up for now and went back to testing the carbi box... and... Well as expected 181's stock factory air box did pretty much zip to shut things up; on average about 3db across the whole range. Then the Mod box got some scrutiny. Mod box rocks... on average around 25db to 40db reduction through the target range; WOT rpm primary frequencies are returning up around 30db and secondary harmonic ranges are returning around 15db reduction. Will have to build this Mod box and see if the actuals match! A 25db noise reduction from the engine will make eating cheese inflight more enjoyable again. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510554#510554 Attachments: http://forums.matronics.com//files/4541ab07_5f7e_46ca_bbdf_81db650db7be_323.jpeg http://forums.matronics.com//files/4a5b083a_2868_4a19_87ec_52ec2fb91a84_865.jpeg http://forums.matronics.com//files/24cfd4c9_e4c0_4e33_a6fa_51941a51b4ae_144.jpeg http://forums.matronics.com//files/21aad5b2_293e_406a_9d29_95687c07c806_189.jpeg ________________________________________________________________________________
Date: Mar 30, 2023
question: the mod is an additional resonating structure installed within the stock box? thx, PeteZ On Thu, Mar 30, 2023 at 8:25=AFAM Area-51 <goldsteinindustrial@gmail. com> wrote: > goldsteinindustrial(at)gmail.com> > > An update on yesterday's recon into an exhaust muffler... spent the day > trying a few different things mods; all that was mostly achieved was a > transposition along the frequency band but not much db reduction... gave up > for now and went back to testing the carbi box... and... > > Well as expected 181's stock factory air box did pretty much zip to shut > things up; on average about 3db across the whole range. Then the Mod box > got some scrutiny. > > Mod box rocks... on average around 25db to 40db reduction through the > target range; WOT rpm primary frequencies are returning up around 30db an d > secondary harmonic ranges are returning around 15db reduction. > > Will have to build this Mod box and see if the actuals match! > > A 25db noise reduction from the engine will make eating cheese inflight > more enjoyable again. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510554#510554 > > > Attachments: > > > http://forums.matronics.com//files/4541ab07_5f7e_46ca_bbdf_81db650db7be_3 23.jpeg > > http://forums.matronics.com//files/4a5b083a_2868_4a19_87ec_52ec2fb91a84_8 65.jpeg > > http://forums.matronics.com//files/24cfd4c9_e4c0_4e33_a6fa_51941a51b4ae_1 44.jpeg > > http://forums.matronics.com//files/21aad5b2_293e_406a_9d29_95687c07c806_1 89.jpeg > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 30, 2023
Correct. Grafted component, either 3D print or dissolvable Styrofoam plug with fibreglass skin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510558#510558 ________________________________________________________________________________
Date: Mar 31, 2023
Loving your posts on this topic, a great mix of detail and humour. Can i ask where you get your geometry from - do you use a 3D scanner? And which CAD and CAE analysis tools please? On the potential to improve exhaust silencer re-radiated noise, i worked with the owner of CKT a few years ago to help him develop a cabin heater based on a shroud around the silencer (loads of heat power there). It didn't progess to a for sale product for internal reasons, but i know them fairly well/they might let me have redacted CAD geometry for it that might help what you are doing? Reducing the noise radiated from the cylindrical silencer is always going to be difficult. The flatter ends are a possible area. Think Rayleigh pistons - where noise radiation is concerned as the size and stiffness of the surface controls both frequency range and ability to re-radiate. https://pdf.sciencedirectassets.com/271589/1-s2.0-S0307904X00X01564/1-s2.0-0307904X94902275/main.pdf?X-Amz-Security-Token=IQoJb3JpZ2luX2VjEK%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2FwEaCXVzLWVhc3QtMSJGMEQCIFCPjos5H%2FxtbWXTp0wy4ttVGOOXES6hmuoA3NU%2FelO3AiBSvyBAtdtBgFV0%2FZeEEveCMCdsEnkhYVcq8DmHIghHFSq8BQiI%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F8BEAUaDDA1OTAwMzU0Njg2NSIMT87Jt%2B5AWqa5DONdKpAFFgQ0ZRCs%2BitnanKhrL9SRt6alPFvk%2BiZkTt7tJo2%2FG9CanwenQDevtY7EQ%2BHBl3YN%2FlajVeD6YMlJY5Kmi2AdNAYiEpFML20kNU0ZGnfzVl0HRPGpfIFfK1LtqDQx%2Fkhg2sKGG3ULSJnWiGADe7VNGZ5PGuT8S27rgKuqdYgpjmvOPbPA4Q7kfy0B56JQNLLi1XrBJSZVQdmEKcOvZxGZiKvlSGYkTvyx0nzynw7Je%2Fb%2Bl54FWPgTiGnQD6JTDkxJOOcBs2ESO%2FwFbwuTi01nTLz8xGidWom6Ti7BA4kbgPS6IIPcX12uwBGv1l%2BxaTnVVt5Sn733EqFMAyty2EHnuLTJPSNcHPkkVwAEDDa4ZlAsMEjWiIBZSE6Y6A30ls%2FMtge0oS9Go3wKM5EAh73widuMW%2BQVxly64tmb%2BmhH08SfdVKosb6kUh%2F6MYP7OXcQAv%2B0CFZcwbX0LPhBkIYKO6QhvhuhDwheTUvWSuigOjlgnFrnj571yyxuSbjcfiRAKqf%2BghFPXVDCSEPdDSrhAtvS%2Fg%2FzyhbX3C6WWdQXTctXp9mqcYVStRHQfcQyvNDxpc4hdLjlekWrbeUFwC4tItne2hiFzc%2FZKYFwpklF%2Bmtjc2NoPYauVHs2CvwWh6b62YZXb%2BvCmb3tHeLWKm4jKFCYCADmAG%2BWgiLspajl3LR3Emsc6Y3YQGMpCKGwGhgb8vnlIuu8W36C7DFVVmgCAF%2FZtmxcMZy0EkVOgIBk1ZiUsSTkBQb9jeCMlc2ui4K4HlXmXkk9sSE4%2Bb8tYOREhQqo9e1GGwnlsnw0tZcBAUqHm3NUaUz7Ws5W7V3qBvxrhlII2QAUE3cihyeAkv7GNWxMR%2FHDW0YVCTq%2By99gPEwrIWaoQY6sgGidEQi4U%2FVUKVRIurC1fytQzTPz%2FF57FzXZezoRYdSbAAi%2B1RqeVpNiv5M5jyYQ5LdJlHo78KQBSjYkG6VDLYdJSBnDErV17oswO%2FTuclaFYYjAvc0DdMbs1dcgUioy61xSgU%2BZT%2BOaAD5EzGjvKckqnIp5LAFU4oPO%2B3ZkoSHPcUEoBvgmRjJyhFZSGXiwUP33vUUDPWw0khKdb%2BqSCLJyDWL7CooxhHiJ0N%2BbvioMb0I&X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Date 230331T082620Z&X-Amz-SignedHeaders=host&X-Amz-Expires=300&X-Amz-Credential=ASIAQ3PHCVTYZ2H7EOU6%2F20230331%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Signature=0b39266fb3035ffa19801e2e95d6f48fd7439ded42e3d98af17ed78b5cf3afc8&hash=c94750c0094bd2380a79e3269efbeb9952004ef59c085c9357d5c3952ac56d5c&host=68042c943591013ac2b2430a89b270f6af2c76d8dfd086a07176afe7c76c2c61&pii=0307904X94902275&tid=spdf-d9a29853-e7ac-4f32-be27-28a83645! 038c&sid =ef7407d46aa3e3448c68b7f301780e85663egxrqb&type=client&tsoh=d3d3LnNjaWVuY2VkaXJlY3QuY29t&ua=01015901545057560352&rr=7b0734f35bafdd77&cc=gb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510559#510559 ________________________________________________________________________________
Date: Mar 31, 2023
Thanks Clive, Most of the CAD is reverse engineered; the europa is an OCD paradise. Open Foam is open source and great for people that want access to physics analysis, but if you can learn the other industrial commercial level packages thats great too; same same results... Blender has just upgraded to a full CAD capability; another free open source package... after a while they all taste like chicken to me though. Not a fan of and never have been one for exhaust affected cabin heating; always ends in sudden death. Recipe for disaster and up there on the top shelf for a Darwin Award. It needs a separation medium layer to be even remotely considered as an option. And with a rotax why even bother, just run it off the coolant system. The CKT kit i can probably work out internals by tapping around with a spanner; but if someone want to through a CAD model at me i'll give it a whirl.. exhaust is a bit more tricky due to hot gasses cooling rapidly, so speed of sound is transitioning from x to y to z; so not that straight forward designing on paper or computer... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510560#510560 ________________________________________________________________________________
Date: Mar 31, 2023
Stepping a bit over the line me thinks with the Darwin Award and always bit. Other flying risks outrank the subject by factors. Exhaust cabin heating can be done safely, with careful inspection and inflight monitoring- especially with the stainless construction. In fact, my classics cabin CO levels are determined not by the heat channels but instead by the outlet position of the stock exhaust (I extended it), in combination with flap position, speed, cabin vent/heat pressurization and the europas open fuse flap slots in a high pressure zone. PeteZ > On Mar 31, 2023, at 5:37 AM, Area-51 wrote: > > > Thanks Clive, > > Most of the CAD is reverse engineered; the europa is an OCD paradise. > > Open Foam is open source and great for people that want access to physics analysis, but if you can learn the other industrial commercial level packages thats great too; same same results... Blender has just upgraded to a full CAD capability; another free open source package... after a while they all taste like chicken to me though. > > Not a fan of and never have been one for exhaust affected cabin heating; always ends in sudden death. Recipe for disaster and up there on the top shelf for a Darwin Award. It needs a separation medium layer to be even remotely considered as an option. And with a rotax why even bother, just run it off the coolant system. > > The CKT kit i can probably work out internals by tapping around with a spanner; but if someone want to through a CAD model at me i'll give it a whirl.. exhaust is a bit more tricky due to hot gasses cooling rapidly, so speed of sound is transitioning from x to y to z; so not that straight forward designing on paper or computer... > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510560#510560 > > > > > > > > > ________________________________________________________________________________
Date: Mar 31, 2023
, , still not convinced; happy with the abstractionated abstention.... Carrying on with noise and climate control OCD'ness Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510565#510565 ________________________________________________________________________________
Date: Mar 31, 2023
The latest from Sun 'n Fun 2023 It's really nice weather this week. A bit breezy, but clear skies, and delightfully warm (HOT to many) and well attended by fliers and the public. Wednesday folks finally started to fly in as the weather fronts abated by Tuesday up north. It was a huge fly in day filling most of the GA Camping area and some in the homebuilt camping. Wednesday Fred Klein, Jerry Hope, Lyle Antieu, Jim, and I all discussed Fred's accident with the rocker switches having been inadvertently switched off and unnoticed. I was asked to do a critique of Fred's switches and his fix to put guards on his ignition, and engine control switches. A smart move on his part. These small rocker switches are neat, but difficult to see if they are on and off as they are a very low profile. Fred's repairs are nearly complete and the engine undamaged so a bit more time and he'll be flying again. My only comment for Fred was to replace rockers with lever lock switches that cannot be inadvertently shut off by simply hitting them. In my previous military and civil training our instructors always required a blindfold cockpit check prior to solo. Knowledge by wrote memory and feel sharpens the quick reactions of a pilot. I'm a fan of it, but in the civil training environment normally, it is not even a training that is considered. I find it speeds checklist operations and assists in emergencies and normal ops such as running out of gas in the main side or aux, night flying, and old guy mental fog. As I said, the Sun 'n Fun GA fly in side has been very well attended but homebuilt camping is only about 1/2 full on Wednesday and another 20 or so flew in on Thursday. John Wigney flew his beautiful Europa Mono in on Wednesday afternoon. He reports the new homebuilt camping area, near the VOR was quite nice and his comment that there were only two showers for men and two for women meant a bit of patience was needed in the AM. However, the campground hosts were doing evening meals and morning light breakfast which John said was very nice. The only drawback I saw was the tram for transportation to and from the area was a bit annoying as it ran about every 20 minutes but occasionally was longer. It is a long walk from the VOR to the airshow East End and a reliable tram was now needed. John walked the 1/4 mile in short time from the LSA area and there were numerous carts stopping to pick folks up from the ultralight/LSA area to homebuilt camping. I saw Chuck Reinas's trigear, but did not run into Chuck. It was not as hot on Thursday, but Anita's foot was sore, my back got twisted up stepping off a sidewalk, so after doing some volunteer work in the AM and some Airmaster Sale visits, we went home a bit early at 2 PM. I got a well needed nap in the afternoon, and corrected my back and Anita got her foot taken care of. A win-win for us. Jerry Hope leaves Saturday and I think many others will from the homebuilt area as another front is crossing the Ohio valley area. Florida will be unaffected but those flying home East of Ohio will be heading out I'm sure with a healthy tail wind for a change. Saturday, Anita and I have grand baby visits in Orlando, and we will be away from the show for the day, but back Sunday to volunteer/assist and staying through the teardown. Best Regards, Bud and Anita Yerly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510566#510566 ________________________________________________________________________________
Subject: Canopy ball stud
Date: Apr 01, 2023
Does anyone know the dimensions of the canopy ball studs, please? What is the thread and the diameter of the ball ? Here are links to suppliers: https://www.ebay.co.uk/itm/112402496613?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=cIQwD279Q8a&sssrc=2349624&ssuid=dW2b1pNUSLS&var=&widget_ver=artemis&media=COPY https://www.sgs-engineering.com/gas-struts/end-fixings/ball-extensions I've fitted new gas struts which are proving sticky / jerky when opening the canopies a little, then become smoother when the canopy opens wider. A threaded end has broken off one ball stud and I'm loathe to unscrew another in order to make measurement of the thread. Hopefully the gas struts will become smoother in operation with the passage of time. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510567#510567 ________________________________________________________________________________
Subject: Re: Canopy ball stud
Date: Apr 01, 2023
Most gas struts will have a C strap clip at each end (some have a wire spring clip); extend the strut all the way and remove the clip; the socket will come away from the ball. Give the shaft a light coating of silicone grease to affect smooth op. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510569#510569 ________________________________________________________________________________
Date: Apr 02, 2023
Hi Jonathan Ends up I have a spare ball stud and just measured it for you. A little difficult, I measured across threads and got .186". A 10-32 die wouldn't go on by hand.I tried a 5 x .8mm tap into the nut and it wouldn't go in? OK got it figured. The threads are 10-32. They plated after they ran a die on them. I ran die on threads and just a tad of plating came off. So: ** The threads are 10-32 The length of threaded portion is .390" with a rounded tip There is a shoulder on the .390" which is .394" diameter and ~.062" long which isn'tthreaded Where you grab with a wrench (circle with 2 flats) has the circle diameter at .312" and the flats .270" (7mm) ** The ball is .314" in diameter Hope that helps Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510576#510576 ________________________________________________________________________________
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Date: Apr 06, 2023
Subject: Tri gear leg assembly
Hello everyone, I am in the midst of converting my mono to a tri gear. The manual talks about installing the legs and then proceeding with the installation of the wheel assembly. Is there any reason why I cannot assemble all of the wheel & brake components and then install the leg into the sockets? Thanks, Paul ________________________________________________________________________________
Subject: Re: the Obsidian Files - So Much Noise!!!
Date: Apr 06, 2023
Episode 82 of "shut that noise up" Upon the eve of Easter, while out looking out over the distant full moon lit pastures for a pink and white rabbit an idea emerged instead... With feverish reckless abandon i quickly searched through some 12,000 images of my electronic memory and found photos of 181's CKT exhaust. Rushing back to the table with assumptions in mind the computer was turned on and the images again reviewed,.. using the burn markings of the CKT muffler a model of what could possibly be a similar internal structure, three absorber sections with a central expansion chamber, was modelled and then sent through the acoustic analyser with results being spat out shortly after. What was found??? The CKT absorber/reflector style muffler provided better overall attenuation than the factory Rotax reflector style unit; broader low range, medium, and high range attenuation. On a broadband level the CKT styled unit provided on average 4db greater attenuation than the Rotax. Low range was shown to be affective from 50Hz upwards where as the Rotax offers none until 320Hz. Peak attenuation levels on the CKT styled unit happened between 2000Hz and 3200Hz where the Rotax is 450Hz to 4000Hz with most attenuation taking place within this band. So the CKT style Absorber/Reflector muffler is more quiet on a broadband basis and works best at attenuating more mid-field frequencies than the factory Rotax unit. Happy Easter to all... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510600#510600 Attachments: http://forums.matronics.com//files/9440bb11_1048_4ad5_8038_ce7f92e944d8_128.jpeg http://forums.matronics.com//files/73a548a8_2223_4831_a435_ac0816303864_404.jpeg http://forums.matronics.com//files/0864e426_4dd6_4e78_b929_963b2a6c799d_763.jpeg ________________________________________________________________________________
Subject: Re: Tri gear leg assembly
Date: Apr 07, 2023
Hi Paul You need to set up the correct angle of the legs using the spindle as a gui de. If you have the wheel and brake on it you won't be able to get the corr ect alignment. The legs only bolt into the socket so once the socket is set up you can rem ove the leg and build up on the bench if you prefer. Cheers Kind Regards Steve Ivell 07971 128842 steveivell(at)pestproof.co.uk ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of Paul McAllister Sent: Thursday, April 6, 2023 8:11:16 PM Subject: Europa-List: Tri gear leg assembly Hello everyone, I am in the midst of converting my mono to a tri gear. Th e manual talks about installing the legs and then proceeding with the insta llation of the wheel assembly. Is there any reason why I cannot assemble all of the wheel & brake componen ts and then install the leg into the sockets? Thanks, Paul ________________________________________________________________________________
Date: Apr 07, 2023
UGF1bCwNCkNvbW1vbiBzZW5zZSBpcyBubyBsb25nZXIgY29tbW9uLiAgRm9sbG93aW5nIHRoZSBt YW51YWwgZXhwbGljaXRseSB3aXRob3V0IGxvb2tpbmcgYWhlYWQgY2FuIGNhdXNlIHlvdSBkZWxh eXMgYW5kIGZyYW5rbHkgbW9yZSB0aW1lLg0KDQpPbmNlIHRoZSBnZWFyIGxlZ3MgYXJlIGluc3Rh bGxlZCwgZ2xhc3NlZCBpbiBhbmQgcHJvcGVybHkgYm9sdGVkIGluIGV4YWN0IGFsaWdubWVudCwg Z2V0IHJpZCBvZiB0aGUgdG9vbGluZyBhbmdsZSBpcm9uIGV0Yy4gdXNlZCBmb3IgYWxpZ25tZW50 LiAgSSBub3JtYWxseSBpbnN0YWxsIHRoZSB3aGVlbHMsIHRpcmVzIGFuZCBicmFrZXMuICBIYXZl IGEgcG9zdCBoYW5keSB0byBob2xkIHRoZSB0YWlsIHVwIGlmIHRoZSBlbmdpbmUgaXMgcmVtb3Zl ZC4gIEluc3RhbGwgdGhlIGJyYWtlIGxpbmVzLCBtYXN0ZXIgY3lsaW5kZXIsIHBhcmtpbmcgYnJh a2UgYW5kIGJyYWtlIGhhbmRsZXMgYXQgdGhpcyB0aW1lIGZvciBhIHRyaWdlYXIgY29udmVyc2lv bi4gIEkgYmxlZWQgdGhlIGJyYWtlcyBhZnRlciB0aGUgYnJha2UgaW5zdGFsbCBpcyBjb21wbGV0 ZSBsb29raW5nIGZvciB0cm91YmxlIGluIG15IGluc3RhbGxhdGlvbiB3aGlsZSBldmVyeXRoaW5n IGlzIG9wZW4uICBQdWxsIHVucmVhc29uYWJseSBoYXJkIG9uIHRoZSBicmFrZSBoYW5kbGVzIHRv IGFzc3VyZSB5b3VyIGZpdHRpbmdzIGFyZSBwcm9wZXJseSB0aWdodGVuZWQgYW5kIGNoZWNrIGZv ciBsZWFrcy4gIEkgdGVtcG9yYXJpbHkgaW5zdGFsbCB0aGUgbm9zZSBnZWFyICh3aXRob3V0IHNw cmluZ3MgYW5kIG9yIGJ1bmdlZSwgc2FmZXR5IGNhYmxlIGV0Yy4gYW5kIGNsYW1wIGl0IGluIHBs YWNlLiAgSSB0aGVuIGNsb3NlIHVwIHRoZSBmaXJld2FsbCBhcmVhIGFuZCBzZWFsIHRoZSBiZWxs eSBob2xlIHdpdGggYW4gYWNjZXNzIHBsYXRlLiAgSSBvZnRlbiBtb3ZlIG15IHB1bXBzIHRvIHRo ZSBvbGQgd2hlZWwgd2VsbCwgYnV0IGl0IGlzIG5vdCBuZWNlc3NhcnkuICBNb3N0IG9mIHRoZSB0 aW1lIHNvbWUgY2xlYW51cCBvZiBhbiBvbGQgZmlyZXdhbGwgZm9yd2FyZCBpcyBuZWVkZWQgc28g SSBkbyB0aGF0IGFzIHdlbGwuICBJIHRoZW4gcmVtb3ZlIHRoZSBub3NlIHdoZWVsIGxlZyBpZiBp biBhIHNtYWxsIHNob3AgcHJvdmlkZSB0aGUgZW5naW5lIGlzIG9mZi4gIEl0IGlzIHF1aXRlIGFu IGFua2xlIGJpdGVyLiAgSW4gbXkgc2hvcCBJIGluc3RhbGwgdGhlIHdoZWVsIHBhbnRzIGFmdGVy IHRoZSB3aGVlbHMgYXJlIG9uIGJlY2F1c2UgSSBjYW4gZWxldmF0ZSB0aGUgYWlyY3JhZnQgdXNp bmcgbXkgY3JhZGxlIHRvIGEgc2l0dGluZyB3b3JrIGhlaWdodC4gIEl0IGdldHMgbWUgb2ZmIG15 IGtuZWVzLiAgSG93ZXZlciwgaW5zdGFsbGluZyB0aGUgd2hlZWwgcGFudHMgYW5kIHNwZWVkIGtp dCBpcyBzaW1wbHkgYSBqb2IgdGhhdCBpcyBlYXNpbHkgZG9uZSB3aXRoIHRoZSB3aGVlbHMgb24g dGhlIGdyb3VuZCBhbmQgZnJhbmtseSwganVzdCBhcyBmYXN0LCBidXQgd2l0aCBhIGJpdCBtb3Jl IGx5aW5nIG9uIHRoZSBmbG9vciB0aW1lLg0KDQpXaGVuIGRvbmUgYW5kIHJlYWR5IGZvciB0aGUg ZW5naW5lIGFnYWluLCBJIGluc3RhbGwgdGhlIG5vc2UgZ2VhciBsZWcgZnVsbHksIGFkZCB0aGUg c3ByaW5ncywgc2FmZXR5IGNhYmxlIGFuZCB0aGVuIHNldCB0aGUgbm9zZSBnZWFyIHN0ZWVyaW5n IGZyaWN0aW9uIHRvIDE2LTE5IHBvdW5kcy4gIEkgdXNlIGEgYml0IG9mIE55ZSBncmVhc2Ugb24g dGhlIHBsYXN0aWMgZnJpY3Rpb24gZGlzayBidXQgaXQgaXMgbm90IG5lY2Vzc2FyeS4gIERvIG5v dCBmb3JnZXQgdGhlIE8gcmluZyBvciB0aGUgbm9zZSBnZWFyIHNwaW5kbGUgZ3JlYXNlIHdpbGwg bGVhayBvdXQgb3ZlciB0aW1lIHJ1aW5pbmcgeW91ciBzdGVlcmluZyBhbmQgY2F1c2luZyBzaGlt bXkuICBJIGN1dCB0aGUgY293bCBmb3IgdGhlIG5vc2UgZ2VhciBsZWcgYW5kIHRyaWFsIGZpdCBp dCBhcyBpdCBzaG91bGQgc3RpbGwgZml0IGFzIGJlZm9yZSBldmVuIHdpdGggdGhlIGVuZ2luZSBv ZmYuIFRoZW4gcmVpbnN0YWxsIHRoZSBlbmdpbmUgYW5kIGR1Y3RpbmcuICBQYXkgYXR0ZW50aW9u IHRvIHRoZSBhbGlnbm1lbnQgYXMgbmV3IGlzb2xhdGlvbiBtb3VudHMgYXJlIGluc3RhbGxlZCBh bmQgdGhlIHNwYWNlciB3YXNoZXJzIG1heSBoYXZlIGJlZW4gbWlzcGxhY2VkLiAgUmVhbGlnbiBl dmVyeXRoaW5nIGFzIHRoZSBlbmdpbmVzIG5ldyBpbnN0YWxsIG1heSBiZSBvZmYgc2xpZ2h0bHkg ZnJvbSB0aGUgY293bC4gIEkgZmluZCBJIHN0aWxsIGhhdmUgdG8gIG1vZGlmeSB0aGUgY293bCBu b3NlIGdlYXIgc2xvdCBhcyBuZWVkZWQgZm9yIHRoZSBleGhhdXN0IHRpcC9ub3NlIGdlYXIgbGVn IGluc3RhbGxhdGlvbiBhcm91bmQgYSAzIGJsYWRlIHByb3AgZHJpbGwgdGhhdCBtdXN0IGJlIGRv bmUgRm9yIHRob3NlIHdpdGggcmVtb3ZhYmxlIGV4aGF1c3QgZXh0ZW5zaW9ucyB0aGUgZXhoYXVz dCBob2xlIGlzIG5vdCBhIGh1Z2UgaXNzdWUuICBCdXQgZm9yIHRob3NlIHdpdGggYSB3ZWxkZWQg cGlwZSB0aGUgY293bCBtYXkgYmUgdmVyeSBkaWZmaWN1bHQgdG8gZ2V0IG9uIGFuZCBvZmYgZWFz aWx5LiAgSSBhY3R1YWxseSBlbmxhcmdlIG15IGhvbGVzIGZvciB0aGUgZ2VhciBsZWcgYW5kIGV4 aGF1c3QgZHVlIHRvIG15IGxhY2sgb2YgcGF0aWVuY2UuDQoNClRoZW4gSSBnZXQgdG8gdGhlIHdp bmdzIGFuZCBwdWxsIHRoZSBtb25vIGJyYWNrZXRzIG9mZiBhbmQgY2xlYW4gdXAgdGhlIG91dGJv YXJkIGZsYXAgYnJhY2tldHMgYW5kIGFkZCBuZXcgY292ZXJzLg0KDQpGaWxsIHNhbmQsIHByaW1l LCBwYWludC4gIERvIHRoZSBhbm51YWwsIGFjY29tcGxpc2ggdGhlIHBhcGVyd29yayBhbmQgbG9n cywgZG9jdW1lbnQgeW91ciBjaGFuZ2VzLCBwZXJmb3JtIGEgd2VpZ2h0IGFuZCBiYWxhbmNlLCBh Y2NvbXBsaXNoIHRoZSBBbm5leCBFLCB0YXhpIGNoZWNrcyBhbmQgc3RlZXJpbmcgYWRqdXN0bWVu dCBhbmQgZ28gZmx5Lg0KDQpJdOKAmXMgcXVhbGl0eSB0aW1lIHdpdGggeW91ciBhaXJwbGFuZS4N Cg0KSnVzdCBteSBvcGluaW9uLA0KQnVkIFllcmx5DQoNCg0KDQpGcm9tOiBvd25lci1ldXJvcGEt bGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSA8b3duZXItZXVyb3BhLWxpc3Qtc2VydmVyQG1hdHJv bmljcy5jb20+IE9uIEJlaGFsZiBPZiBQYXVsIE1jQWxsaXN0ZXINClNlbnQ6IFRodXJzZGF5LCBB cHJpbCAwNiwgMjAyMyAzOjExIFBNDQpUbzogZXVyb3BhLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3Vi amVjdDogRXVyb3BhLUxpc3Q6IFRyaSBnZWFyIGxlZyBhc3NlbWJseQ0KDQpIZWxsbyBldmVyeW9u ZSwgIEkgYW0gaW4gdGhlIG1pZHN0IG9mIGNvbnZlcnRpbmcgbXkgbW9ubyB0byBhIHRyaSBnZWFy LiAgVGhlIG1hbnVhbCB0YWxrcyBhYm91dCBpbnN0YWxsaW5nIHRoZSBsZWdzIGFuZCB0aGVuIHBy b2NlZWRpbmcgd2l0aCB0aGUgaW5zdGFsbGF0aW9uIG9mIHRoZSB3aGVlbCAgYXNzZW1ibHkuDQoN CklzIHRoZXJlIGFueSByZWFzb24gd2h5IEkgY2Fubm90IGFzc2VtYmxlIGFsbCBvZiB0aGUgd2hl ZWwgJiBicmFrZSBjb21wb25lbnRzIGFuZCB0aGVuIGluc3RhbGwgdGhlIGxlZyBpbnRvIHRoZSBz b2NrZXRzPw0KDQpUaGFua3MsIFBhdWwNCg= ________________________________________________________________________________
Date: Apr 10, 2023
Subject: Best practices
Hi all, I=99m at the stage in my tri gear conversion where I need to think ab out how I am going to cover the hole in the belly and I am looking for ideas from those who have gone before me. Think light =F0=9F=98=84 My initial thought is to cut some 3 mm foam and cover it with some plies of uni on each side. I would have a couple of access holes or perhaps one oval shaped hole. Any suggestions would be appreciated. ________________________________________________________________________________
Date: Apr 11, 2023
Subject: Re: Best practices
Hello Paul, Well I recently closed in my mono hole and followed instructions that Bud posted (or emailed me, can't remember). I started by doing 3 layers of bi-direction cloth on a glass table and used a vacuum bag to make it flat as possible. Then taped that up against the bottom and traced out the hole from the inside. Then I used G10 board as the access cover plate and cut that shape plus an extra 5mm or so. From there I freeCAD designed some spacers to give a nice even 2mm gap around the access G10 cover and placed that in the hole and filled the void with flox and over lapped with 3 layers of bid to mount nut plates to later. With the trace line cut I held the patch in place with tape and ran 3 layers of bid from the panel to the side walls to glue in. Its now complete but I have a video that talks a little about it here. https://youtu.be/7auXi3WRYwc Hope this helps, /Kyle On Mon, Apr 10, 2023 at 11:29=AFAM Paul McAllister <paul.the.aviator@ gmail.com> wrote: > Hi all, > > > I=99m at the stage in my tri gear conversion where I need to think about how > I am going to cover the hole in the belly and I am looking for ideas from > those who have gone before me. Think light =F0=9F=98=84 > > > My initial thought is to cut some 3 mm foam and cover it with some plies > of uni on each side. I would have a couple of access holes or perhaps one > oval shaped hole. > > > Any suggestions would be appreciated. > ________________________________________________________________________________
Date: Apr 11, 2023
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: The Obsidian File - Mono Wheel Fairing
Date: Apr 12, 2023
The second black op Obsidian File has been sanctioned for declassification... techniques rumored used for original data extraction have been dispelled however some information remain redacted... some names have been changed to protect operatives still active within current high level field ops. A quick review of data within this file focuses upon the debated myth and legend of the Europa Mono wheel fairing... preliminary assessment of the facts shrouding this vicarious circle of assumptions points towards the successful mitigation of noise and turbulence; however the studies reviewed so far are just loose preliminary tasks used to verify test field integrity. The attached images show Acoustic Power "noise levels", and the first image Velocity "air movement"... higher resolution and longer solution solving iterations will provided more clarity toward actuals; bit what has been revealed so far is useful and indicative toward a standard equipped mono. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510618#510618 Attachments: http://forums.matronics.com//files/256a4c41_9447_4ada_ba7f_2fd68dd8ffac_148.jpeg http://forums.matronics.com//files/9e9b6832_ed20_4082_8e66_c6035de71cdc_159.jpeg http://forums.matronics.com//files/d18d1170_1065_4cf9_8f6e_e67a3e14bd35_430.jpeg http://forums.matronics.com//files/e93466fa_5e5f_4708_83e5_f6af78a94d35_139.jpeg ________________________________________________________________________________
Subject: Re: The Obsidian File - Mono Wheel Fairing
Date: Apr 13, 2023
Today was spent raising the resolution of the analysis and re-running the preliminary solution... Some points of interest were glanced over also being static pressure inside the engine cowl, flow velocity through various airframe vents and openings... Regarding the main gear area... as the images show, with the gear retracted and set at its operational position, due to the existing lower cowl faring, it remains just on the cusp of free-stream air during flight; however, about 80db of noise is being displayed downstream; whether this is caused by the wheel or the cowl faring is not yet determined... some updated images attached. The areas responsible where most noise is generated are the flap tube ports in the fuselage; somewhere in the order of 90db. However this may alter with the wings installed. Next session will be looking at same results while utilising a wheel faring. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510619#510619 Attachments: http://forums.matronics.com//files/0a671ac1_a63e_4d5c_af6d_e994e808fb4d_848.jpeg http://forums.matronics.com//files/458792ae_5942_4348_b4a9_34e08873ef81_897.jpeg http://forums.matronics.com//files/13f14713_6987_4d35_aacb_fc82482c92f8_184.jpeg ________________________________________________________________________________
Subject: Coolant Hose
Date: Apr 15, 2023
We are in the midst of the install of our replacement 914. Europa supplies a coolant hose for the inlet to the coolant pump that has a 90 degree bend and a 180 degree bend in order to have the pump inlet facing to port. But the inlet can be rotated to face starboard. Is there is reason not to use a shorter, simpler hose that would just be a 90 degree bend to go to the coolant radiator? Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510622#510622 ________________________________________________________________________________
Subject: Re: Coolant Hose
Date: Apr 15, 2023
I had to replace the 180 degree hose to the radiator and did it with a 90 degree silicone hose. I inserted a coil spring inside to keep it from collapsing and has worked well for 4 years now. You can find the spring at McMaster Carr and it works great for tight bends on silicone hoses. -------- N951EU - Tri-gear & 912ULS, N77EU- Mono & 914 I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510623#510623 ________________________________________________________________________________
Date: Apr 15, 2023
Hi Jim, I think the pipe will have to bend in order to avoid the ring mount. Sounds worth a try. Regards, Roger > On 15 Apr 2023, at 11:53, h&jeuropa wrote: > > > We are in the midst of the install of our replacement 914. Europa supplies a coolant hose for the inlet to the coolant pump that has a 90 degree bend and a 180 degree bend in order to have the pump inlet facing to port. > > But the inlet can be rotated to face starboard. Is there is reason not to use a shorter, simpler hose that would just be a 90 degree bend to go to the coolant radiator? > > Jim & Heather > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510622#510622 > > > > > > > > > ________________________________________________________________________________
Subject: Builder in Norther CA (Sacramento) Area?
Date: Apr 17, 2023
Hi all- any europa builders (completed) in N. California (Sacramento) area that could assist a potential buyer of a mostly finished XS monowheel in looking over build quality? Can compensate. Thanks in advance - please private message me for details. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510644#510644 ________________________________________________________________________________
Subject: Spotted!!
Date: Apr 17, 2023
Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510649#510649 Attachments: http://forums.matronics.com//files/d26256b9_02ac_49c9_9de9_465af6177e43_328.jpeg ________________________________________________________________________________
Subject: Re: Spotted!!
Date: Apr 17, 2023
Looks like a liberty. > On Apr 17, 2023, at 9:53 PM, Area-51 wrote: > > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510649#510649 > > > > > Attachments: > > http://forums.matronics.com//files/d26256b9_02ac_49c9_9de9_465af6177e43_328.jpeg > > > > > > ________________________________________________________________________________
Date: Apr 18, 2023
Yes... a few sold recently at real bargain prices... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510652#510652 ________________________________________________________________________________
Date: Apr 19, 2023
Subject: Tri-gear nose wheel O ring size & NGO5 dimensions.
Hello everyone, My kit was missing the BS214 O ring and NG05 friction plate. I'm at the point of giving up trying to get them from Europa and making them. I need to know the thickness of the nylon friction plate, the size of the hole and the O ring thickness. My guess is 1/8" thickness of the material with a 1 1/8" hole and a 1" ID O ring , 1/8 thick. If anyone can help I'd appreciate the information. Thanks, Paul ________________________________________________________________________________
Subject: Re: Tri-gear nose wheel O ring size & NGO5 dimensions.
Date: Apr 19, 2023
Not quite Paul. NG05 is 3.00 IN OD, 1.0 IN ID, PIN HOLE 1/4 IN Centered between ID , and OD edges or 0.5 inches from the edge. ABS plastic. I would machine from FRP G10 of 1/8 inch thick. Easy to do on a drill press. Buy the FRP, 3" Hole saw has to be 3" ID so I use a 3 1/8 OD instrument hole saw. CLOSE ENOUGH . The O-ring depends on your depth cut of the steel spacer defining the O rin g recess. Ideal O ring is 1/8 inch thick. 1 inch ID, 1 1/8 OD. SOME are in need of a 3/16 thick Oring with ID of 1" to seal properly due to builder tolerances in modifying the original non sealed base. This was a cut and file mod . Some cut the bearings, others the steel to preserve the bushing thickness. Idea was to prevent grease from running out on the plate. That leaky grea se decreased friction and was a continuing shimmy issue. Seal the base and life is good. Make sure the spindle is square to the yoke. Bud Yerly Get Outlook for Android ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of Paul McAllister Sent: Wednesday, April 19, 2023 11:37:05 AM Subject: Europa-List: Tri-gear nose wheel O ring size & NGO5 dimensions. Hello everyone, My kit was missing the BS214 O ring and NG05 friction plate. I'm at the po int of giving up trying to get them from Europa and making them. I need to know the thickness of the nylon friction plate, the size of the hole and t he O ring thickness. My guess is 1/8" thickness of the material with a 1 1/8" hole and a 1" ID O ring , 1/8 thick. If anyone can help I'd appreciate the information. Thanks, Paul ________________________________________________________________________________
Date: Apr 20, 2023
Hello Paul I was at Swifts on Tues and picked up that very item. I know that they have several more in stock as I saw them. If you phone the Swift number and ask for Tom Hesp (Rebecca is away at present) you should be able to get it by return. Sent from my iPhone > On 19 Apr 2023, at 16:41, Paul McAllister wrote: > > > Hello everyone, > > My kit was missing the BS214 O ring and NG05 friction plate. I'm at the point of giving up trying to get them from Europa and making them. I need to know the thickness of the nylon friction plate, the size of the hole and the O ring thickness. > > My guess is 1/8" thickness of the material with a 1 1/8" hole and a 1" ID O ring , 1/8 thick. > > If anyone can help I'd appreciate the information. > > Thanks, Paul ________________________________________________________________________________
Date: Apr 20, 2023
Thanks Mike! On Thu, Apr 20, 2023 at 1:57 AM Mike wrote: > > Hello Paul > I was at Swifts on Tues and picked up that very item. > I know that they have several more in stock as I saw them. > If you phone the Swift number and ask for Tom Hesp (Rebecca is away at > present) you should be able to get it by return. > > Sent from my iPhone > > > On 19 Apr 2023, at 16:41, Paul McAllister > wrote: > > > > =EF=BB > > Hello everyone, > > > > My kit was missing the BS214 O ring and NG05 friction plate. I'm at th e > point of giving up trying to get them from Europa and making them. I nee d > to know the thickness of the nylon friction plate, the size of the hole a nd > the O ring thickness. > > > > My guess is 1/8" thickness of the material with a 1 1/8" hole and a 1" > ID O ring , 1/8 thick. > > > > If anyone can help I'd appreciate the information. > > > > Thanks, Paul > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Auxiliary- Longranger Fuel Tank ARM
Date: Apr 23, 2023
Hi fine Europa people, Soon Ill be having my W&B done for my Europa XS. The kit I purchased came with the auxiliary Longranger fuel tank. Although Ive looked, I cant find an official ARM from the datum for this tank. The aircraft fuel tank ARM is 76" while the baggage area is listed as 88". For those of you who have this tank installed, would you mind sharing the ARM utilised for W&B calculations? Many thanks for your help. Tony -------- Tony Vaccarella Mascot NSW 2020 Sydney Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510671#510671 ________________________________________________________________________________
Subject: Re: Auxiliary- Longranger Fuel Tank ARM
Date: Apr 23, 2023
Tony, We use 85 inches. Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510672#510672 ________________________________________________________________________________
Date: Apr 23, 2023
Tony, I just split the difference, ending up with82" but you can easily enough measure from the cowling joggle (the zero ref point) to the centre of the tank. Regards, David Joyce, ex GXSDJ On 2023-04-23 08:29, tonyvaccarella wrote: > > > Hi fine Europa people, > Soon Ill be having my W&B done for my Europa XS. The kit I purchased > came with the auxiliary Longranger fuel tank. Although Ive looked, I > cant find an official ARM from the datum for this tank. The aircraft > fuel tank ARM is 76" while the baggage area is listed as 88". For those > of you who have this tank installed, would you mind sharing the ARM > utilised for W&B calculations? > Many thanks for your help. > Tony > > -------- > Tony Vaccarella > Mascot NSW 2020 > Sydney Australia > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510671#510671 > ________________________________________________________________________________
Date: Apr 23, 2023
The past weekend has not been good for flying; so more numbers were crunched and more fairings were assessed; it was interesting to try some known shapes, no shapes, different retraction heights, and an initial design developed way back near the beginning of all this. As usual the control piece was the standard mono in standard flight configuration at 100kt velocity (51m/sec). The airframe was stripped back to fuselage only to reduce computer power and solving time. Several indicators were implemented, Drag, Lift, Surface Velocity, Surface Acoustic Power... Fairings were tried as semi and fully enclosed scenarios. What the computer said... The standard mono wheel, when retracted, skips on its tyre upon free stream air; most all the remaining tyre remains within a protected pocket created by the lower cowl deflector covering the muffler... employing a fairing does little to reduce drag, however it does reduce acoustic noise within the undercarriage well... a fully sealed fairing reduces this acoustic noise to near zero... the variance upon drag factor between no fairing and fully enclosed is about 1kg out of 38kg total; Lift variance is 1.8kg less with a fairing out of 7.8kg total and is probably due to the tyre skipping on the free stream air... and thats about it for the mono wheel faring with the ball ended enclosed shape providing the best aerodynamic results. Myth Busted... Attached images relate to velocity and acoustic comparisons. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510674#510674 Attachments: http://forums.matronics.com//files/650ac4ad_8ace_4aa2_b79d_18796976a9cc_383.jpeg http://forums.matronics.com//files/32e7836b_5949_4cbd_994b_39d722c8a709_207.jpeg http://forums.matronics.com//files/aaa5982b_700b_4685_bd02_7070a8f2499a_758.jpeg http://forums.matronics.com//files/51777a11_f283_4de4_977b_e4e25da175dc_170.jpeg http://forums.matronics.com//files/1bda5df8_c3ac_4abe_9328_5eba78fd7649_689.jpeg http://forums.matronics.com//files/5a94f80c_231a_48de_809f_756f92b4fb8d_119.jpeg http://forums.matronics.com//files/1e525fe3_d8ab_46b6_80dd_80ab5445d0ca_191.jpeg http://forums.matronics.com//files/469d3cbb_0ecb_4af7_9f9a_3b67e318f705_285.jpeg ________________________________________________________________________________
Date: Apr 23, 2023
Different from noise, i notice significant (and irritating to me lol) buffeting starting at 120knots and increasing slightly as speed increases. Intuitively, buffeting energy would be draggy with the pressure waves traveling outward from the tunnel. PeteZ > On Apr 23, 2023, at 8:56 AM, Area-51 wrote: > > > The past weekend has not been good for flying; so more numbers were crunched and more fairings were assessed; it was interesting to try some known shapes, no shapes, different retraction heights, and an initial design developed way back near the beginning of all this. > > As usual the control piece was the standard mono in standard flight configuration at 100kt velocity (51m/sec). The airframe was stripped back to fuselage only to reduce computer power and solving time. Several indicators were implemented, Drag, Lift, Surface Velocity, Surface Acoustic Power... Fairings were tried as semi and fully enclosed scenarios. > > What the computer said... > > The standard mono wheel, when retracted, skips on its tyre upon free stream air; most all the remaining tyre remains within a protected pocket created by the lower cowl deflector covering the muffler... employing a fairing does little to reduce drag, however it does reduce acoustic noise within the undercarriage well... a fully sealed fairing reduces this acoustic noise to near zero... the variance upon drag factor between no fairing and fully enclosed is about 1kg out of 38kg total; Lift variance is 1.8kg less with a fairing out of 7.8kg total and is probably due to the tyre skipping on the free stream air... and thats about it for the mono wheel faring with the ball ended enclosed shape providing the best aerodynamic results. > > Myth Busted... > > Attached images relate to velocity and acoustic comparisons. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510674#510674 > > > > > Attachments: > > http://forums.matronics.com//files/650ac4ad_8ace_4aa2_b79d_18796976a9cc_383.jpeg > http://forums.matronics.com//files/32e7836b_5949_4cbd_994b_39d722c8a709_207.jpeg > http://forums.matronics.com//files/aaa5982b_700b_4685_bd02_7070a8f2499a_758.jpeg > http://forums.matronics.com//files/51777a11_f283_4de4_977b_e4e25da175dc_170.jpeg > http://forums.matronics.com//files/1bda5df8_c3ac_4abe_9328_5eba78fd7649_689.jpeg > http://forums.matronics.com//files/5a94f80c_231a_48de_809f_756f92b4fb8d_119.jpeg > http://forums.matronics.com//files/1e525fe3_d8ab_46b6_80dd_80ab5445d0ca_191.jpeg > http://forums.matronics.com//files/469d3cbb_0ecb_4af7_9f9a_3b67e318f705_285.jpeg > > > > > > ________________________________________________________________________________
Date: Apr 23, 2023
Interesting... probably worth increasing the velocity parameters to 75m/sec and see what happens Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510676#510676 ________________________________________________________________________________
Date: Apr 23, 2023
Consider also the gap between the frame/wheel and fuselage opening. That g ap has to be cut "like Goldilocks" or just right or air swirls around and g ushes up into the well. NACA had tests on the partially retracted gear and frankly, a half-buried t ire is a good compromise. Drag was decreased slightly in the wind tunnel w ith a narrower gap. In these tests the gap was closed up to the tire and t he tire gap was as small as practical. Photos are grainy and virtually imp ossible to find from NASA. Heinkel did work in this area also. Most 1930-40s aircraft with partially exposed wheels did hide the wheels in the nacelles or made covers for the gap in the wings back to the tire to c lean up the gap and reduce drag. Making a flange with rounded edge in the rear of the wheel well area was also done to clean up the exit and prevent air pressure buildup in the well. ( As done by Seversky in the P-35) Dougl ass put the oil cooler on the C-47 just before the tire to cut the drag. C rude but effective. Bellanca did no streamlining until the Viking series. Adding a small cover to the front helped, so they made a complete door to enclose the gear. A full fairing is nice, but the extra weight and complex ity becomes tedious to complete effectively. Many folks up north simply re moved the rear door. See NACA Report 518 for some drag numbers (very crude stuff, drag is in pou nds, but the tire size is familiar looking) to bounce off your calcs. Enjoy your computer work. I=92m doing 3D printing stuff and cooling airflo w and enclosure mods using similar programs. The learning curve was and st ill is steep. Too many assumptions have to be made to compromise on airflo w and pressure build up. Yuck. It is a hit and miss (for me anyway) on ge tting the best airflow bang for the buck and time. Best Regards, Bud Yerly ________________________________ From: owner-europa-list-server(at)matronics.com<mailto:owner-europa-list-serve r(at)matronics.com> > on behalf of Area-51 > Sent: Sunday, April 23, 2023 9:25:27 AM t(at)matronics.com> Subject: Europa-List: Re: The Obsidian File - Mono Wheel Fairing > Interesting... probably worth increasing the velocity parameters to 75m/sec and see what happens =F0=9F=A4=B7=F0=9F=8F=BC=8D=99=82=EF=B8=8F Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D510676%23510676&data=05%7C01%7C%7Cf5c68 b91124f4faf585008db43fe9378%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63 8178532913400064%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMz IiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=ZNYEwvj7bHDZSoIxiv vTzC1W7Mx4%2F1DOYSUmIjNApX4%3D&reserved=0<http://forums.matronics.com/vie wtopic.php?p=510676#510676> %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C01%7C%7Cf5c68b91 124f4faf585008db43fe9378%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63817 8532913400064%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=2BFLi7Iy0Wy8ZHu3Xy6jY pp8I6cv1HFh2qn3gZk%2BITk%3D&reserved=0<http://www.matronics.com/Navigator ?Europa-List> %2Fforums.matronics.com%2F&data=05%7C01%7C%7Cf5c68b91124f4faf585008db43fe 9378%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638178532913400064%7CUnkn own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C3000%7C%7C%7C&sdata=zO5HWCl3PT%2FEJ40aSfBkZTW2JidmV0a%2B4DaO% 2BDIUlqc%3D&reserved=0<http://forums.matronics.com/> %2Fwiki.matronics.com%2F&data=05%7C01%7C%7Cf5c68b91124f4faf585008db43fe93 78%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638178532913400064%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C3000%7C%7C%7C&sdata=5eva5Xt5x7gUfjSbqWa1ivlwxjP2XjLNNgC2NVGIXEc %3D&reserved=0<http://wiki.matronics.com/> F%2Fmatronics.com%2Fcontribution&data=05%7C01%7C%7Cf5c68b91124f4faf585008 db43fe9378%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638178532913400064% 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=SYpWITnvwFIIRe8XIhntUn9%2BIr4lanSrV aRWn9Xtj4E%3D&reserved=0 ________________________________________________________________________________
Date: Apr 23, 2023
Thanks for the input there Bud; always thought provoking.. Gaps and edges can be noise generators. The semi enclosed fairing has a large gap at the rear to allow tyre passing. On something like the europa installing bristle brushes at the gaps might offer an affective cheap and light solution here. Cooling ducts on 3D printers are a real challenge. I did one a few years back as i wasnt happy with the factory side flow versions; so i designed up a really affective single head unit which resulted in a 150g lighter print head; took five assumptions to get the flow balance correct... works great! Let me know if you are interested, can send you the STL file, ready to print. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510681#510681 ________________________________________________________________________________
Date: Apr 23, 2023
Breakfast today has turned into brunch as all three model variations had a higher velocity of 75m/sec (150kt) applied; and revealed an interesting anomaly. Its not certain or being ruled out that at the higher air speed an acoustic pressure wave is detected traveling rearward along the fuselage belly aft of the main gear. (the fully enclosed fairing does not exhibit this trait). Other results on the acoustic aspect shows db levels increasing some 50%; the loudest areas being where deflected free stream air at the lower engine cowl fairing rejoins slower moving air exiting the engine bay area; some 105db; quite audible over everything... installing a trailing fence may reduce this turbulent corridor. The pressure wave though is interesting, at 70-80db it would be noticeable and the cause of it would likely be related to the flutter of turbulence created by air passing over and behind the cylindrical shape of the tyre. As Bud mentions above there is also the added element of air escaping the gaps of the fairing and exposed main gear rejoining faster moving air... The belly of the fuselage is quite flexible and is likely oscillating enough to cause annoying pressure pulses within the cockpit. Employing fairing fences might provide an answer to the above situation. Regarding Drag and Lift comparatives at 150kt, standard and semi enclosed setups were identical in Drag with the later giving up 3.0kg of Lift; again the tyre is removed from the free stream... The fully enclosed setup provides some 3.0kg Drag reduction and gives up 2.0kg of Lift. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510682#510682 Attachments: http://forums.matronics.com//files/8a81f6a8_a74d_495e_875f_c907cb0e1ce9_212.jpeg http://forums.matronics.com//files/c5e5c0da_b8c0_47f6_8ad8_506a68b62282_464.jpeg http://forums.matronics.com//files/9b70a766_46dc_4944_9fc2_4dcc7aa93d98_213.jpeg ________________________________________________________________________________
Date: Apr 23, 2023
Brunch has turned into lunch.. The fence concept has provided value by reducing the acoustic pressure pulses to almost zero and assisting in keeping trailing turbulence tighter within the fuselage centerline... Drag and Lift gains and losses were not anything worth noting; mostly "shut that noise up"; advantages being greatest using the semi enclosed fairing option, however both semi enclosed and standard setups nullified the trailing pressure pulse effects... two thumbs up on this one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510684#510684 ________________________________________________________________________________
Date: Apr 24, 2023
Fence details? > On Apr 24, 2023, at 12:15 AM, Area-51 wrote: > > > Brunch has turned into lunch.. > > The fence concept has provided value by reducing the acoustic pressure pulses to almost zero and assisting in keeping trailing turbulence tighter within the fuselage centerline... Drag and Lift gains and losses were not anything worth noting; mostly "shut that noise up"; advantages being greatest using the semi enclosed fairing option, however both semi enclosed and standard setups nullified the trailing pressure pulse effects... two thumbs up on this one. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510684#510684 > > > > > > > > > ________________________________________________________________________________
Date: Apr 24, 2023
Lunch has now turned into dinner.. there was a brief hiatus in the weather where the sun came out and a bunch of bananas were lopped from the tree and many hands cut off; of bananas, not apes... So just for entertainment and curiosity the fence concept was extended further to a more aft limit.. that worked favourably; so the concept was developed into a rib extending to around 1m short of the stern. And that appears to also work favourably toward keeping air flowing neatly and quietly downstream to the undercarriage. A secondary affect if shaped with foam and glassed over would be added rigidity of the belly skin and less tendency for panel drumming. Peter the fence is just a 3.00mm piece of flat plate running from the lower engine cowl side face rearward; a block of triangular shaped foam glued to the skin would also work for a temporary trial... ending it just forward of the fuel drain vents will function well; the fence height used in tests is 64.0mm. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510686#510686 Attachments: http://forums.matronics.com//files/5c0d4f52_ccdd_4d1f_8991_350b77ff7b8a_102.jpeg http://forums.matronics.com//files/98ecba07_4c10_4089_84da_feb258ca2f8c_594.jpeg http://forums.matronics.com//files/1b63a2e1_48ca_45ef_bb09_30c364045798_129.jpeg http://forums.matronics.com//files/ed982eee_14f5_49fb_8c7a_4ee40a335cb3_159.jpeg http://forums.matronics.com//files/53c98d9e_97df_42b8_902c_eafa74a11a74_201.jpeg http://forums.matronics.com//files/c6e645a0_3648_422d_84a1_3e917d0a2aff_142.jpeg http://forums.matronics.com//files/454164c8_30b1_4232_bdeb_b879e509c25a_414.jpeg http://forums.matronics.com//files/262db7ea_dbc7_4de8_962d_22427748f1dd_171.jpeg ________________________________________________________________________________
Date: Apr 24, 2023
Lunch has now turned into dinner.. there was a brief hiatus in the weather where the sun came out and a bunch of bananas were lopped from the tree and many hands cut off; of bananas, not apes... So just for entertainment and curiosity the fence concept was extended further to a more aft limit.. that worked favourably; so the concept was developed into a rib extending to around 1m short of the stern. And that appears to also work favourably toward keeping air flowing neatly and quietly downstream to the undercarriage. A secondary affect if shaped with foam and glassed over would be added rigidity of the belly skin and less tendency for panel drumming. Peter the fence is just a 3.00mm piece of flat plate running from the lower engine cowl side face rearward; a block of triangular shaped foam glued to the skin would also work for a temporary trial... ending it just forward of the fuel drain vents will function well; the fence height used in tests is 64.0mm. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510687#510687 Attachments: http://forums.matronics.com//files/5c0d4f52_ccdd_4d1f_8991_350b77ff7b8a_102.jpeg http://forums.matronics.com//files/98ecba07_4c10_4089_84da_feb258ca2f8c_594.jpeg http://forums.matronics.com//files/1b63a2e1_48ca_45ef_bb09_30c364045798_129.jpeg http://forums.matronics.com//files/ed982eee_14f5_49fb_8c7a_4ee40a335cb3_159.jpeg http://forums.matronics.com//files/53c98d9e_97df_42b8_902c_eafa74a11a74_201.jpeg http://forums.matronics.com//files/c6e645a0_3648_422d_84a1_3e917d0a2aff_142.jpeg http://forums.matronics.com//files/454164c8_30b1_4232_bdeb_b879e509c25a_414.jpeg http://forums.matronics.com//files/262db7ea_dbc7_4de8_962d_22427748f1dd_171.jpeg ________________________________________________________________________________
Subject: The Obsidian Files - Doorly Departed
Date: Apr 24, 2023
Have been looking forward to this one... The outcome was disappointing.. was expecting wind in the cockpit; and thats all that really happened... Drag went up 25kg at 100kt for a twin door departation and 17kg for a single door scenario... on both events the wind came into the cockpit!! It swirled around and down into the footwells and rear luggage wells, where it swirled around some more before shooting out straight up at the human head like an upper cut from both front an rear directions before flying out and over the rear of the door frame... Anything left loose in the cockpit is getting sucked up and is going out an opening after slapping the occupants in the head.. for a dual door situation the swirl remains left and right sided; leaning one's head to the centre and back may find a pool of calmness... A single door situation is more exciting; the swirl comes up to the opening on a diagonal from the opposite side hitting the human closest to the opening in the head from the front and rear on the way out; anything left loose in the luggage well, shelf, footwell is going out the opening after slapping the occupant in the face; the occupant can be human dog or cat... a small dog like chihuahua is probably going out the opening... a loose ipad; out the opening... and that's about it.. The aircraft is flyable without one or both doors but it won't be very pleasant at all with 25-30kt winds swirling around like tornado.... Maybe some deflectors will improve a doorless situation... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510689#510689 Attachments: http://forums.matronics.com//files/29147814_5dc4_4c17_8ddf_9be761ece51c_137.jpeg http://forums.matronics.com//files/c3da4c4f_6974_4ff6_b83c_8cb5c4011888_123.jpeg http://forums.matronics.com//files/073d78e2_bbb3_4d31_a543_0c335e5ab1f7_419.jpeg http://forums.matronics.com//files/b0ccd426_c7fb_43fd_a0ac_b161dbac545c_664.jpeg http://forums.matronics.com//files/d941b467_be32_4bb9_b0e8_6c55ccb57f5a_172.jpeg http://forums.matronics.com//files/6e09ada6_17ba_492d_aa23_e0e7e3013f35_163.jpeg http://forums.matronics.com//files/dc3b3168_f943_4603_9941_461124ceb381_152.jpeg http://forums.matronics.com//files/b2c6221a_6d0b_4477_8fef_9572aed30447_202.jpeg http://forums.matronics.com//files/b2020f6f_ca5f_45ae_b7c3_0598c6c5849b_801.jpeg ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Apr 24, 2023
Subject: Re: The Obsidian Files - Doorly Departed
Interestingly my colombian friend whose door opened in flight reported the very same thing. His pax grabbed and partially closed the door. He was worried that the cover would exit the door and wrap round the tail...In the attempt to catch the cover his passenger let go of the door handle and away went the door. They did catch the cover tho. William Daniell +1 786 878 0246 On Mon, Apr 24, 2023, 20:14 Area-51 wrote: > goldsteinindustrial(at)gmail.com> > > Have been looking forward to this one... > > The outcome was disappointing.. was expecting wind in the cockpit; and > thats all that really happened... =F0=9F=A4=B7=F0=9F=8F=BC=8D=99 =82=EF=B8=8F > > Drag went up 25kg at 100kt for a twin door departation and 17kg for a > single door scenario... on both events the wind came into the cockpit!! I t > swirled around and down into the footwells and rear luggage wells, where it > swirled around some more before shooting out straight up at the human hea d > like an upper cut from both front an rear directions before flying out an d > over the rear of the door frame... Anything left loose in the cockpit is > getting sucked up and is going out an opening after slapping the occupant s > in the head.. for a dual door situation the swirl remains left and right > sided; leaning one's head to the centre and back may find a pool of > calmness... A single door situation is more exciting; the swirl comes up to > the opening on a diagonal from the opposite side hitting the human closes t > to the opening in the head from the front and rear on the way out; anythi ng > left loose in the luggage well, shelf, footwell is going out the opening > after slapping the occupant i! > n the face; the occupant can be human dog or cat... a small dog like > chihuahua is probably going out the opening... a loose ipad; out the > opening... and that's about it.. > > The aircraft is flyable without one or both doors but it won't be very > pleasant at all with 25-30kt winds swirling around like tornado.... > > Maybe some deflectors will improve a doorless situation... =F0=9F=A4=94 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510689#510689 > > > Attachments: > > > http://forums.matronics.com//files/29147814_5dc4_4c17_8ddf_9be761ece51c_1 37.jpeg > > http://forums.matronics.com//files/c3da4c4f_6974_4ff6_b83c_8cb5c4011888_1 23.jpeg > > http://forums.matronics.com//files/073d78e2_bbb3_4d31_a543_0c335e5ab1f7_4 19.jpeg > > http://forums.matronics.com//files/b0ccd426_c7fb_43fd_a0ac_b161dbac545c_6 64.jpeg > > http://forums.matronics.com//files/d941b467_be32_4bb9_b0e8_6c55ccb57f5a_1 72.jpeg > > http://forums.matronics.com//files/6e09ada6_17ba_492d_aa23_e0e7e3013f35_1 63.jpeg > > http://forums.matronics.com//files/dc3b3168_f943_4603_9941_461124ceb381_1 52.jpeg > > http://forums.matronics.com//files/b2c6221a_6d0b_4477_8fef_9572aed30447_2 02.jpeg > > http://forums.matronics.com//files/b2020f6f_ca5f_45ae_b7c3_0598c6c5849b_8 01.jpeg > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 24, 2023
Thanks for the input William... Its amazing how the computer can mathematically estimate actuals. Something like a cover could wrap around the head very quickly. I'm not totally finished on this one yet and want to look at how the complete airframe responds in the 3 axis environment when a door departs. All analysis so far are just preliminary static tests to identify generated sound levels and fluid reaction around the component body. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510691#510691 ________________________________________________________________________________
Date: Apr 25, 2023
Subject: RE: Europa-List Digest: 6 Msgs - 04/24/23
From: nicolaandjohn <nicolaandjohn(at)talktalk.net>
UGxlYXNlIGNoYW5nZSB0aGlzIGVtYWlsIGFkZHJlc3MgdG86Sm9obnd0MTk2NEBnbWFpbC5jb23C oFRoYW5rIHlvdVNlbnQgZnJvbSBteSBHYWxheHkKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAt LS0tLS0tLUZyb206IEV1cm9wYS1MaXN0IERpZ2VzdCBTZXJ2ZXIgPGV1cm9wYS1saXN0QG1hdHJv bmljcy5jb20+IERhdGU6IDI1LzA0LzIwMjMgIDA3OjM1ICAoR01UKzAwOjAwKSBUbzogRXVyb3Bh LUxpc3QgRGlnZXN0IExpc3QgPGV1cm9wYS1saXN0LWRpZ2VzdEBtYXRyb25pY3MuY29tPiBTdWJq ZWN0OiBFdXJvcGEtTGlzdCBEaWdlc3Q6IDYgTXNncyAtIDA0LzI0LzIzICogPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT3CoMKgIE9ubGluZSBWZXJzaW9u cyBvZiBUb2RheSdzIExpc3QgRGlnZXN0IEFyY2hpdmUgPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT1Ub2RheSdzIGNvbXBsZXRlIEV1cm9wYS1MaXN0IERp Z2VzdCBjYW4gYWxzbyBiZSBmb3VuZCBpbiBlaXRoZXIgb2YgdGhlIHR3byBXZWIgTGlua3MgbGlz dGVkIGJlbG93LsKgIFRoZSAuaHRtbCBmaWxlIGluY2x1ZGVzIHRoZSBEaWdlc3QgZm9ybWF0dGVk IGluIEhUTUwgZm9yIHZpZXdpbmcgd2l0aCBhIHdlYiBicm93c2VyIGFuZCBmZWF0dXJlcyBIeXBl cmxpbmtlZCBJbmRleGVzIGFuZCBNZXNzYWdlIE5hdmlnYXRpb24uwqAgVGhlIC50eHQgZmlsZSBp bmNsdWRlcyB0aGUgcGxhaW4gQVNDSUkgdmVyc2lvbiBvZiB0aGUgRXVyb3BhLUxpc3QgRGlnZXN0 IGFuZCBjYW4gYmUgdmlld2VkIHdpdGggYSBnZW5lcmljIHRleHQgZWRpdG9yIHN1Y2ggYXMgTm90 ZXBhZCBvciB3aXRoIGEgd2ViIGJyb3dzZXIuIEhUTUwgVmVyc2lvbjrCoMKgwqAgaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2RpZ2VzdC9kaWdlc3R2aWV3LnBocD9TdHlsZT04MjcwMSZWaWV3PWh0 bWwmQ2hhcHRlcj0yMDIzLTA0LTI0JkFyY2hpdmU9RXVyb3BhVGV4dCBWZXJzaW9uOsKgwqDCoCBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhwP1N0eWxlPTgyNzAx JlZpZXc9dHh0JkNoYXB0ZXI9MjAyMy0wNC0yNCZBcmNoaXZlPUV1cm9wYSA9PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT3CoMKgIEVNYWlsIFZlcnNpb24gb2Yg VG9kYXkncyBMaXN0IERpZ2VzdCBBcmNoaXZlID09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PSDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0twqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCBFdXJvcGEtTGlzdCBEaWdlc3Qg QXJjaGl2ZcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0tLcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqAgVG90YWwgTWVzc2FnZXMgUG9zdGVkIE1vbiAwNC8yNC8yMzogNsKgwqDCoMKg wqDCoMKgwqDCoMKgIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0gIFRvZGF5J3MgTWVzc2FnZSBJbmRleDotLS0tLS0tLS0tLS0tLS0tLS0t LS0tIMKgwqDCoMKgIDEuIDAxOjU2IEFNIC0gUmU6IFJlOiBUaGUgT2JzaWRpYW4gRmlsZSAtIE1v bm8gV2hlZWwgRmFpcmluZ8KgIChQZXRlKcKgwqDCoMKgIDIuIDAzOjA4IEFNIC0gUmU6IFRoZSBP YnNpZGlhbiBGaWxlIC0gTW9ubyBXaGVlbCBGYWlyaW5nwqAgKEFyZWEtNTEpwqDCoMKgwqAgMy4g MDM6MDggQU0gLSBSZTogVGhlIE9ic2lkaWFuIEZpbGUgLSBNb25vIFdoZWVsIEZhaXJpbmfCoCAo QXJlYS01MSnCoMKgwqDCoCA0LiAwNToxMiBQTSAtIFRoZSBPYnNpZGlhbiBGaWxlcyAtIERvb3Js eSBEZXBhcnRlZMKgIChBcmVhLTUxKcKgwqDCoMKgIDUuIDA1OjQ3IFBNIC0gUmU6IFRoZSBPYnNp ZGlhbiBGaWxlcyAtIERvb3JseSBEZXBhcnRlZMKgIChXaWxsaWFtIERhbmllbGwpwqDCoMKgwqAg Ni4gMDg6MDIgUE0gLSBSZTogVGhlIE9ic2lkaWFuIEZpbGVzIC0gRG9vcmx5IERlcGFydGVkwqAg KEFyZWEtNTEpICAgX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX1/CoCBNZXNzYWdlIDHC oCBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fVGltZTogMDE6NTY6MDIgQU0g UFNUIFVTRnJvbTogUGV0ZSA8cGV0ZXJ6QHp1dHJhc29mdC5jb20+U3ViamVjdDogUmU6IEV1cm9w YS1MaXN0OiBSZTogVGhlIE9ic2lkaWFuIEZpbGUgLSBNb25vIFdoZWVsIEZhaXJpbmdGZW5jZSBk ZXRhaWxzPz4gT24gQXByIDI0LCAyMDIzLCBhdCAxMjoxNSBBTSwgQXJlYS01MSA8Z29sZHN0ZWlu aW5kdXN0cmlhbEBnbWFpbC5jb20+IHdyb3RlOj4gPiA+IEJydW5jaCBoYXMgdHVybmVkIGludG8g bHVuY2guLj4gPiBUaGUgZmVuY2UgY29uY2VwdCBoYXMgcHJvdmlkZWQgdmFsdWUgYnkgcmVkdWNp bmcgdGhlIGFjb3VzdGljIHByZXNzdXJlIHB1bHNlc3RvIGFsbW9zdCB6ZXJvIGFuZCBhc3Npc3Rp bmcgaW4ga2VlcGluZyB0cmFpbGluZyB0dXJidWxlbmNlIHRpZ2h0ZXIgd2l0aGluIHRoZWZ1c2Vs YWdlIGNlbnRlcmxpbmUuLi4gRHJhZyBhbmQgTGlmdCBnYWlucyBhbmQgbG9zc2VzIHdlcmUgbm90 IGFueXRoaW5nIHdvcnRobm90aW5nOyBtb3N0bHkgInNodXQgdGhhdCBub2lzZSB1cCI7IGFkdmFu dGFnZXMgYmVpbmcgZ3JlYXRlc3QgdXNpbmcgdGhlIHNlbWllbmNsb3NlZCBmYWlyaW5nIG9wdGlv biwgaG93ZXZlciBib3RoIHNlbWkgZW5jbG9zZWQgYW5kIHN0YW5kYXJkIHNldHVwcyBudWxsaWZp ZWR0aGUgdHJhaWxpbmcgcHJlc3N1cmUgcHVsc2UgZWZmZWN0cy4uLiB0d28gdGh1bWJzIHVwIG9u IHRoaXMgb25lLj4gPiA+ID4gPiBSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6PiA+IGh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NTEwNjg0IzUxMDY4ND4gPiA+ ID4gPiA+ID4gPiA+IF9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fwqAgTWVzc2FnZSAy wqAgX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX1RpbWU6IDAzOjA4OjEyIEFN IFBTVCBVU1N1YmplY3Q6IEV1cm9wYS1MaXN0OiBSZTogVGhlIE9ic2lkaWFuIEZpbGUgLSBNb25v IFdoZWVsIEZhaXJpbmdGcm9tOiAiQXJlYS01MSIgPGdvbGRzdGVpbmluZHVzdHJpYWxAZ21haWwu Y29tPkx1bmNoIGhhcyBub3cgdHVybmVkIGludG8gZGlubmVyLi4gdGhlcmUgd2FzIGEgYnJpZWYg aGlhdHVzIGluIHRoZSB3ZWF0aGVyIHdoZXJldGhlIHN1biBjYW1lIG91dCBhbmQgYSBidW5jaCBv ZiBiYW5hbmFzIHdlcmUgbG9wcGVkIGZyb20gdGhlIHRyZWUgYW5kIG1hbnkgaGFuZHNjdXQgb2Zm OyBvZiBiYW5hbmFzLCBub3QgYXBlcy4uLlNvIGp1c3QgZm9yIGVudGVydGFpbm1lbnQgYW5kIGN1 cmlvc2l0eSB0aGUgZmVuY2UgY29uY2VwdCB3YXMgZXh0ZW5kZWQgZnVydGhlcnRvIGEgbW9yZSBh ZnQgbGltaXQuLiB0aGF0IHdvcmtlZCBmYXZvdXJhYmx5OyBzbyB0aGUgY29uY2VwdCB3YXMgZGV2 ZWxvcGVkIGludG9hIHJpYiBleHRlbmRpbmcgdG8gYXJvdW5kIDFtIHNob3J0IG9mIHRoZSBzdGVy bi4gQW5kIHRoYXQgYXBwZWFycyB0byBhbHNvIHdvcmtmYXZvdXJhYmx5IHRvd2FyZCBrZWVwaW5n IGFpciBmbG93aW5nIG5lYXRseSBhbmQgcXVpZXRseSBkb3duc3RyZWFtIHRvIHRoZXVuZGVyY2Fy cmlhZ2UuIEEgc2Vjb25kYXJ5IGFmZmVjdCBpZiBzaGFwZWQgd2l0aCBmb2FtIGFuZCBnbGFzc2Vk IG92ZXIgd291bGQgYmVhZGRlZCByaWdpZGl0eSBvZiB0aGUgYmVsbHkgc2tpbiBhbmQgbGVzcyB0 ZW5kZW5jeSBmb3IgcGFuZWwgZHJ1bW1pbmcuUGV0ZXIgdGhlIGZlbmNlIGlzIGp1c3QgYSAzLjAw bW0gcGllY2Ugb2YgZmxhdCBwbGF0ZSBydW5uaW5nIGZyb20gdGhlIGxvd2VyIGVuZ2luZWNvd2wg c2lkZSBmYWNlIHJlYXJ3YXJkOyBhIGJsb2NrIG9mIHRyaWFuZ3VsYXIgc2hhcGVkIGZvYW0gZ2x1 ZWQgdG8gdGhlIHNraW53b3VsZCBhbHNvIHdvcmsgZm9yIGEgdGVtcG9yYXJ5IHRyaWFsLi4uIGVu ZGluZyBpdCBqdXN0IGZvcndhcmQgb2YgdGhlIGZ1ZWxkcmFpbiB2ZW50cyB3aWxsIGZ1bmN0aW9u IHdlbGw7IHRoZSBmZW5jZSBoZWlnaHQgdXNlZCBpbiB0ZXN0cyBpcyA2NC4wbW0uUmVhZCB0aGlz IHRvcGljIG9ubGluZSBoZXJlOmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMu cGhwP3A9NTEwNjg2IzUxMDY4NkF0dGFjaG1lbnRzOiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5j b20vL2ZpbGVzLzVjMGQ0ZjUyX2NjZGRfNGQxZl84OTkxXzM1MGI3N2ZmN2I4YV8xMDIuanBlZ2h0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvOThlY2JhMDdfNGMxMF80MDg5Xzg0ZGFf ZmViMjU4Y2EyZjhjXzU5NC5qcGVnaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLy9maWxlcy8x YjYzYTJlMV80OGNhXzQ1ZWZfYmIwOV8zMGMzNjQwNDU3OThfMTI5LmpwZWdodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20vL2ZpbGVzL2VkOTgyZWVlXzE0ZjVfNDlmYl84YzdhXzRlZTQwYTMzNWNi M18xNTkuanBlZ2h0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvNTNjOThkOWVfOTdk Zl80MmI4XzkwMmNfZWFmYTc0YTExYTc0XzIwMS5qcGVnaHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tLy9maWxlcy9jNmU2NDVhMF8zNjQ4XzQyMmRfODRhMV8zZTkxN2QwYTJhZmZfMTQyLmpwZWdo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzLzQ1NDE2NGM4XzMwYjFfNDIzMl9iZGVi X2I4NzllNTA5YzI1YV80MTQuanBlZ2h0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMv MjYyZGI3ZWFfZGJjN180ZGU4Xzk2MmRfMjI0Mjc3NDhmMWRkXzE3MS5qcGVnX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX1/CoCBNZXNzYWdlIDPCoCBfX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fVGltZTogMDM6MDg6MTQgQU0gUFNUIFVTU3ViamVjdDogRXVyb3BhLUxp c3Q6IFJlOiBUaGUgT2JzaWRpYW4gRmlsZSAtIE1vbm8gV2hlZWwgRmFpcmluZ0Zyb206ICJBcmVh LTUxIiA8Z29sZHN0ZWluaW5kdXN0cmlhbEBnbWFpbC5jb20+THVuY2ggaGFzIG5vdyB0dXJuZWQg aW50byBkaW5uZXIuLiB0aGVyZSB3YXMgYSBicmllZiBoaWF0dXMgaW4gdGhlIHdlYXRoZXIgd2hl cmV0aGUgc3VuIGNhbWUgb3V0IGFuZCBhIGJ1bmNoIG9mIGJhbmFuYXMgd2VyZSBsb3BwZWQgZnJv bSB0aGUgdHJlZSBhbmQgbWFueSBoYW5kc2N1dCBvZmY7IG9mIGJhbmFuYXMsIG5vdCBhcGVzLi4u U28ganVzdCBmb3IgZW50ZXJ0YWlubWVudCBhbmQgY3VyaW9zaXR5IHRoZSBmZW5jZSBjb25jZXB0 IHdhcyBleHRlbmRlZCBmdXJ0aGVydG8gYSBtb3JlIGFmdCBsaW1pdC4uIHRoYXQgd29ya2VkIGZh dm91cmFibHk7IHNvIHRoZSBjb25jZXB0IHdhcyBkZXZlbG9wZWQgaW50b2EgcmliIGV4dGVuZGlu ZyB0byBhcm91bmQgMW0gc2hvcnQgb2YgdGhlIHN0ZXJuLiBBbmQgdGhhdCBhcHBlYXJzIHRvIGFs c28gd29ya2Zhdm91cmFibHkgdG93YXJkIGtlZXBpbmcgYWlyIGZsb3dpbmcgbmVhdGx5IGFuZCBx dWlldGx5IGRvd25zdHJlYW0gdG8gdGhldW5kZXJjYXJyaWFnZS4gQSBzZWNvbmRhcnkgYWZmZWN0 IGlmIHNoYXBlZCB3aXRoIGZvYW0gYW5kIGdsYXNzZWQgb3ZlciB3b3VsZCBiZWFkZGVkIHJpZ2lk aXR5IG9mIHRoZSBiZWxseSBza2luIGFuZCBsZXNzIHRlbmRlbmN5IGZvciBwYW5lbCBkcnVtbWlu Zy5QZXRlciB0aGUgZmVuY2UgaXMganVzdCBhIDMuMDBtbSBwaWVjZSBvZiBmbGF0IHBsYXRlIHJ1 bm5pbmcgZnJvbSB0aGUgbG93ZXIgZW5naW5lY293bCBzaWRlIGZhY2UgcmVhcndhcmQ7IGEgYmxv Y2sgb2YgdHJpYW5ndWxhciBzaGFwZWQgZm9hbSBnbHVlZCB0byB0aGUgc2tpbndvdWxkIGFsc28g d29yayBmb3IgYSB0ZW1wb3JhcnkgdHJpYWwuLi4gZW5kaW5nIGl0IGp1c3QgZm9yd2FyZCBvZiB0 aGUgZnVlbGRyYWluIHZlbnRzIHdpbGwgZnVuY3Rpb24gd2VsbDsgdGhlIGZlbmNlIGhlaWdodCB1 c2VkIGluIHRlc3RzIGlzIDY0LjBtbS5SZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6aHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD01MTA2ODcjNTEwNjg3QXR0YWNo bWVudHM6IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvNWMwZDRmNTJfY2NkZF80 ZDFmXzg5OTFfMzUwYjc3ZmY3YjhhXzEwMi5qcGVnaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t Ly9maWxlcy85OGVjYmEwN180YzEwXzQwODlfODRkYV9mZWIyNThjYTJmOGNfNTk0LmpwZWdodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzLzFiNjNhMmUxXzQ4Y2FfNDVlZl9iYjA5XzMw YzM2NDA0NTc5OF8xMjkuanBlZ2h0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvZWQ5 ODJlZWVfMTRmNV80OWZiXzhjN2FfNGVlNDBhMzM1Y2IzXzE1OS5qcGVnaHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tLy9maWxlcy81M2M5OGQ5ZV85N2RmXzQyYjhfOTAyY19lYWZhNzRhMTFhNzRf MjAxLmpwZWdodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzL2M2ZTY0NWEwXzM2NDhf NDIyZF84NGExXzNlOTE3ZDBhMmFmZl8xNDIuanBlZ2h0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bS8vZmlsZXMvNDU0MTY0YzhfMzBiMV80MjMyX2JkZWJfYjg3OWU1MDljMjVhXzQxNC5qcGVnaHR0 cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLy9maWxlcy8yNjJkYjdlYV9kYmM3XzRkZThfOTYyZF8y MjQyNzc0OGYxZGRfMTcxLmpwZWdfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX8KgIE1l c3NhZ2UgNMKgIF9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19UaW1lOiAwNTox MjozOSBQTSBQU1QgVVNTdWJqZWN0OiBFdXJvcGEtTGlzdDogVGhlIE9ic2lkaWFuIEZpbGVzIC0g RG9vcmx5IERlcGFydGVkRnJvbTogIkFyZWEtNTEiIDxnb2xkc3RlaW5pbmR1c3RyaWFsQGdtYWls LmNvbT5IYXZlIGJlZW4gbG9va2luZyBmb3J3YXJkIHRvIHRoaXMgb25lLi4uVGhlIG91dGNvbWUg d2FzIGRpc2FwcG9pbnRpbmcuLiB3YXMgZXhwZWN0aW5nIHdpbmQgaW4gdGhlIGNvY2twaXQ7IGFu ZCB0aGF0cyBhbGx0aGF0IHJlYWxseSBoYXBwZW5lZC4uLiBEcmFnIHdlbnQgdXAgMjVrZyBhdCAx MDBrdCBmb3IgYSB0d2luIGRvb3IgZGVwYXJ0YXRpb24gYW5kIDE3a2cgZm9yIGEgc2luZ2xlIGRv b3JzY2VuYXJpby4uLiBvbiBib3RoIGV2ZW50cyB0aGUgd2luZCBjYW1lIGludG8gdGhlIGNvY2tw aXQhISBJdCBzd2lybGVkIGFyb3VuZGFuZCBkb3duIGludG8gdGhlIGZvb3R3ZWxscyBhbmQgcmVh ciBsdWdnYWdlIHdlbGxzLCB3aGVyZSBpdCBzd2lybGVkIGFyb3VuZHNvbWUgbW9yZSBiZWZvcmUg c2hvb3Rpbmcgb3V0IHN0cmFpZ2h0IHVwIGF0IHRoZSBodW1hbiBoZWFkIGxpa2UgYW4gdXBwZXIg Y3V0ZnJvbSBib3RoIGZyb250IGFuIHJlYXIgZGlyZWN0aW9ucyBiZWZvcmUgZmx5aW5nIG91dCBh bmQgb3ZlciB0aGUgcmVhciBvZiB0aGVkb29yIGZyYW1lLi4uIEFueXRoaW5nIGxlZnQgbG9vc2Ug aW4gdGhlIGNvY2twaXQgaXMgZ2V0dGluZyBzdWNrZWQgdXAgYW5kIGlzZ29pbmcgb3V0IGFuIG9w ZW5pbmcgYWZ0ZXIgc2xhcHBpbmcgdGhlIG9jY3VwYW50cyBpbiB0aGUgaGVhZC4uIGZvciBhIGR1 YWwgZG9vcnNpdHVhdGlvbiB0aGUgc3dpcmwgcmVtYWlucyBsZWZ0IGFuZCByaWdodCBzaWRlZDsg bGVhbmluZyBvbmUncyBoZWFkIHRvIHRoZWNlbnRyZSBhbmQgYmFjayBtYXkgZmluZCBhIHBvb2wg b2YgY2FsbW5lc3MuLi4gQSBzaW5nbGUgZG9vciBzaXR1YXRpb24gaXMgbW9yZWV4Y2l0aW5nOyB0 aGUgc3dpcmwgY29tZXMgdXAgdG8gdGhlIG9wZW5pbmcgb24gYSBkaWFnb25hbCBmcm9tIHRoZSBv cHBvc2l0ZSBzaWRlaGl0dGluZyB0aGUgaHVtYW4gY2xvc2VzdCB0byB0aGUgb3BlbmluZyBpbiB0 aGUgaGVhZCBmcm9tIHRoZSBmcm9udCBhbmQgcmVhcm9uIHRoZSB3YXkgb3V0OyBhbnl0aGluZyBs ZWZ0IGxvb3NlIGluIHRoZSBsdWdnYWdlIHdlbGwsIHNoZWxmLCBmb290d2VsbCBpc2dvaW5nIG91 dCB0aGUgb3BlbmluZyBhZnRlciBzbGFwcGluZyB0aGUgb2NjdXBhbnQgaW4gdGhlIGZhY2U7IHRo ZSBvY2N1cGFudCBjYW5iZSBodW1hbiBkb2cgb3IgY2F0Li4uIGEgc21hbGwgZG9nIGxpa2UgY2hp aHVhaHVhIGlzIHByb2JhYmx5IGdvaW5nIG91dCB0aGVvcGVuaW5nLi4uIGEgbG9vc2UgaXBhZDsg b3V0IHRoZSBvcGVuaW5nLi4uIGFuZCB0aGF0J3MgYWJvdXQgaXQuLlRoZSBhaXJjcmFmdCBpcyBm bHlhYmxlIHdpdGhvdXQgb25lIG9yIGJvdGggZG9vcnMgYnV0IGl0IHdvbid0IGJlIHZlcnkgcGxl YXNhbnRhdCBhbGwgd2l0aCAyNS0zMGt0IHdpbmRzIHN3aXJsaW5nIGFyb3VuZCBsaWtlIHRvcm5h ZG8uLi4uIE1heWJlIHNvbWUgZGVmbGVjdG9ycyB3aWxsIGltcHJvdmUgYSBkb29ybGVzcyBzaXR1 YXRpb24uLi4gUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOmh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbS92aWV3dG9waWMucGhwP3A9NTEwNjg5IzUxMDY4OUF0dGFjaG1lbnRzOiBodHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzLzI5MTQ3ODE0XzVkYzRfNGMxN184ZGRmXzliZTc2 MWVjZTUxY18xMzcuanBlZ2h0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvYzNkYTRj NGZfNjk3NF80ZmY2X2I4M2NfOGNiNWM0MDExODg4XzEyMy5qcGVnaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tLy9maWxlcy8wNzNkNzhlMl9iYmIzXzRkMzFfYTU0M18wYzMzNWU1YWIxZjdfNDE5 LmpwZWdodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzL2IwY2NkNDI2X2M3ZmJfNDNm ZF9hMGFjX2IxNjFkYmFjNTQ1Y182NjQuanBlZ2h0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8v ZmlsZXMvZDk0MWI0NjdfYmUzMl80YmI5X2IwZThfNmM1NWNjYjU3ZjVhXzE3Mi5qcGVnaHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tLy9maWxlcy82ZTA5YWRhNl8xN2JhXzQ5MmRfYWEyM19lMGU3 ZTMwMTNmMzVfMTYzLmpwZWdodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzL2RjM2Iz MTY4X2Y5NDNfNDYwM185OTQxXzQ2MTEyNGNlYjM4MV8xNTIuanBlZ2h0dHA6Ly9mb3J1bXMubWF0 cm9uaWNzLmNvbS8vZmlsZXMvYjJjNjIyMWFfNmQwYl80NDc3XzhmZWZfOTU3MmFlZDMwNDQ3XzIw Mi5qcGVnaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLy9maWxlcy9iMjAyMGY2Zl9jYTVmXzQ1 YWVfYjdjM18wNTk4YzZjNTg0OWJfODAxLmpwZWdfX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fX8KgIE1lc3NhZ2UgNcKgIF9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19U aW1lOiAwNTo0NzowMiBQTSBQU1QgVVNGcm9tOiBXaWxsaWFtIERhbmllbGwgPHdkYW5pZWxsLmxv bmdwb3J0QGdtYWlsLmNvbT5TdWJqZWN0OiBSZTogRXVyb3BhLUxpc3Q6IFRoZSBPYnNpZGlhbiBG aWxlcyAtIERvb3JseSBEZXBhcnRlZEludGVyZXN0aW5nbHkgbXkgY29sb21iaWFuwqAgZnJpZW5k IHdob3NlIGRvb3Igb3BlbmVkIGluIGZsaWdodCByZXBvcnRlZCB0aGV2ZXJ5IHNhbWUgdGhpbmcu wqDCoCBIaXMgcGF4IGdyYWJiZWQgYW5kIHBhcnRpYWxseSBjbG9zZWQgdGhlIGRvb3IuSGUgd2Fz IHdvcnJpZWQgdGhhdCB0aGUgY292ZXIgd291bGQgZXhpdCB0aGUgZG9vciBhbmQgd3JhcCByb3Vu ZCB0aGV0YWlsLi4uSW4gdGhlIGF0dGVtcHQgdG8gY2F0Y2ggdGhlIGNvdmVywqAgaGlzIHBhc3Nl bmdlciBsZXQgZ28gb2YgdGhlIGRvb3JoYW5kbGUgYW5kIGF3YXkgd2VudCB0aGUgZG9vci5UaGV5 IGRpZCBjYXRjaCB0aGUgY292ZXIgdGhvLldpbGxpYW0gRGFuaWVsbCsxIDc4NiA4NzggMDI0Nk9u IE1vbiwgQXByIDI0LCAyMDIzLCAyMDoxNCBBcmVhLTUxIDxnb2xkc3RlaW5pbmR1c3RyaWFsQGdt YWlsLmNvbT4gd3JvdGU6PiBnb2xkc3RlaW5pbmR1c3RyaWFsQGdtYWlsLmNvbT4+PiBIYXZlIGJl ZW4gbG9va2luZyBmb3J3YXJkIHRvIHRoaXMgb25lLi4uPj4gVGhlIG91dGNvbWUgd2FzIGRpc2Fw cG9pbnRpbmcuLiB3YXMgZXhwZWN0aW5nIHdpbmQgaW4gdGhlIGNvY2twaXQ7IGFuZD4gdGhhdHMg YWxsIHRoYXQgcmVhbGx5IGhhcHBlbmVkLi4uID1GMD05Rj1BND1CNz1GMD05Rj04Rj1CQz04RD05 OT04Mj1FRj1COD04Rj4+IERyYWcgd2VudCB1cCAyNWtnIGF0IDEwMGt0IGZvciBhIHR3aW4gZG9v ciBkZXBhcnRhdGlvbiBhbmQgMTdrZyBmb3IgYT4gc2luZ2xlIGRvb3Igc2NlbmFyaW8uLi4gb24g Ym90aCBldmVudHMgdGhlIHdpbmQgY2FtZSBpbnRvIHRoZSBjb2NrcGl0ISEgSXQ+IHN3aXJsZWQg YXJvdW5kIGFuZCBkb3duIGludG8gdGhlIGZvb3R3ZWxscyBhbmQgcmVhciBsdWdnYWdlIHdlbGxz LCB3aGVyZSBpdD4gc3dpcmxlZCBhcm91bmQgc29tZSBtb3JlIGJlZm9yZSBzaG9vdGluZyBvdXQg c3RyYWlnaHQgdXAgYXQgdGhlIGh1bWFuIGhlYWQ+IGxpa2UgYW4gdXBwZXIgY3V0IGZyb20gYm90 aCBmcm9udCBhbiByZWFyIGRpcmVjdGlvbnMgYmVmb3JlIGZseWluZyBvdXQgYW5kPiBvdmVyIHRo ZSByZWFyIG9mIHRoZSBkb29yIGZyYW1lLi4uIEFueXRoaW5nIGxlZnQgbG9vc2UgaW4gdGhlIGNv Y2twaXQgaXM+IGdldHRpbmcgc3Vja2VkIHVwIGFuZCBpcyBnb2luZyBvdXQgYW4gb3BlbmluZyBh ZnRlciBzbGFwcGluZyB0aGUgb2NjdXBhbnRzPiBpbiB0aGUgaGVhZC4uIGZvciBhIGR1YWwgZG9v ciBzaXR1YXRpb24gdGhlIHN3aXJsIHJlbWFpbnMgbGVmdCBhbmQgcmlnaHQ+IHNpZGVkOyBsZWFu aW5nIG9uZSdzIGhlYWQgdG8gdGhlIGNlbnRyZSBhbmQgYmFjayBtYXkgZmluZCBhIHBvb2wgb2Y+ IGNhbG1uZXNzLi4uIEEgc2luZ2xlIGRvb3Igc2l0dWF0aW9uIGlzIG1vcmUgZXhjaXRpbmc7IHRo ZSBzd2lybCBjb21lcyB1cCB0bz4gdGhlIG9wZW5pbmcgb24gYSBkaWFnb25hbCBmcm9tIHRoZSBv cHBvc2l0ZSBzaWRlIGhpdHRpbmcgdGhlIGh1bWFuIGNsb3Nlc3Q+IHRvIHRoZSBvcGVuaW5nIGlu IHRoZSBoZWFkIGZyb20gdGhlIGZyb250IGFuZCByZWFyIG9uIHRoZSB3YXkgb3V0OyBhbnl0aGlu Zz4gbGVmdCBsb29zZSBpbiB0aGUgbHVnZ2FnZSB3ZWxsLCBzaGVsZiwgZm9vdHdlbGwgaXMgZ29p bmcgb3V0IHRoZSBvcGVuaW5nPiBhZnRlciBzbGFwcGluZyB0aGUgb2NjdXBhbnQgaSE+wqAgbiB0 aGUgZmFjZTsgdGhlIG9jY3VwYW50IGNhbiBiZSBodW1hbiBkb2cgb3IgY2F0Li4uIGEgc21hbGwg ZG9nIGxpa2U+IGNoaWh1YWh1YSBpcyBwcm9iYWJseSBnb2luZyBvdXQgdGhlIG9wZW5pbmcuLi4g YSBsb29zZSBpcGFkOyBvdXQgdGhlPiBvcGVuaW5nLi4uIGFuZCB0aGF0J3MgYWJvdXQgaXQuLj4+ IFRoZSBhaXJjcmFmdCBpcyBmbHlhYmxlIHdpdGhvdXQgb25lIG9yIGJvdGggZG9vcnMgYnV0IGl0 IHdvbid0IGJlIHZlcnk+IHBsZWFzYW50IGF0IGFsbCB3aXRoIDI1LTMwa3Qgd2luZHMgc3dpcmxp bmcgYXJvdW5kIGxpa2UgdG9ybmFkby4uLi4+PiBNYXliZSBzb21lIGRlZmxlY3RvcnMgd2lsbCBp bXByb3ZlIGEgZG9vcmxlc3Mgc2l0dWF0aW9uLi4uID1GMD05Rj1BND05ND4+PiBSZWFkIHRoaXMg dG9waWMgb25saW5lIGhlcmU6Pj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3Bp Yy5waHA/cD01MTA2ODkjNTEwNjg5Pj4+IEF0dGFjaG1lbnRzOj4+PiBodHRwOi8vZm9ydW1zLm1h dHJvbmljcy5jb20vL2ZpbGVzLzI5MTQ3ODE0XzVkYzRfNGMxN184ZGRmXzliZTc2MWVjZTUxY18x MzcuanBlZz4+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvYzNkYTRjNGZfNjk3 NF80ZmY2X2I4M2NfOGNiNWM0MDExODg4XzEyMy5qcGVnPj4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tLy9maWxlcy8wNzNkNzhlMl9iYmIzXzRkMzFfYTU0M18wYzMzNWU1YWIxZjdfNDE5Lmpw ZWc+PiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzL2IwY2NkNDI2X2M3ZmJfNDNm ZF9hMGFjX2IxNjFkYmFjNTQ1Y182NjQuanBlZz4+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bS8vZmlsZXMvZDk0MWI0NjdfYmUzMl80YmI5X2IwZThfNmM1NWNjYjU3ZjVhXzE3Mi5qcGVnPj4g aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLy9maWxlcy82ZTA5YWRhNl8xN2JhXzQ5MmRfYWEy M19lMGU3ZTMwMTNmMzVfMTYzLmpwZWc+PiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2Zp bGVzL2RjM2IzMTY4X2Y5NDNfNDYwM185OTQxXzQ2MTEyNGNlYjM4MV8xNTIuanBlZz4+IGh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvYjJjNjIyMWFfNmQwYl80NDc3XzhmZWZfOTU3 MmFlZDMwNDQ3XzIwMi5qcGVnPj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLy9maWxlcy9i MjAyMGY2Zl9jYTVmXzQ1YWVfYjdjM18wNTk4YzZjNTg0OWJfODAxLmpwZWc+Pj09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0+Pl9fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fwqAgTWVzc2FnZSA2wqAgX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX1RpbWU6IDA4OjAyOjI3IFBNIFBTVCBVU1N1YmplY3Q6IEV1cm9wYS1M aXN0OiBSZTogVGhlIE9ic2lkaWFuIEZpbGVzIC0gRG9vcmx5IERlcGFydGVkRnJvbTogIkFyZWEt NTEiIDxnb2xkc3RlaW5pbmR1c3RyaWFsQGdtYWlsLmNvbT5UaGFua3MgZm9yIHRoZSBpbnB1dCBX aWxsaWFtLi4uIEl0cyBhbWF6aW5nIGhvdyB0aGUgY29tcHV0ZXIgY2FuIG1hdGhlbWF0aWNhbGx5 ZXN0aW1hdGUgYWN0dWFscy4gU29tZXRoaW5nIGxpa2UgYSBjb3ZlciBjb3VsZCB3cmFwIGFyb3Vu ZCB0aGUgaGVhZCB2ZXJ5IHF1aWNrbHkuSSdtIG5vdCB0b3RhbGx5IGZpbmlzaGVkIG9uIHRoaXMg b25lIHlldCBhbmQgd2FudCB0byBsb29rIGF0IGhvdyB0aGUgY29tcGxldGUgYWlyZnJhbWVyZXNw b25kcyBpbiB0aGUgMyBheGlzIGVudmlyb25tZW50IHdoZW4gYSBkb29yIGRlcGFydHMuQWxsIGFu YWx5c2lzIHNvIGZhciBhcmUganVzdCBwcmVsaW1pbmFyeSBzdGF0aWMgdGVzdHMgdG8gaWRlbnRp ZnkgZ2VuZXJhdGVkIHNvdW5kbGV2ZWxzIGFuZCBmbHVpZCByZWFjdGlvbiBhcm91bmQgdGhlIGNv bXBvbmVudCBib2R5LlJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZTpodHRwOi8vZm9ydW1zLm1h dHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTUxMDY5MSM1MTA2OTEgXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT1fLT3CoMKgwqDC oMKgwqDCoMKgwqAgLSBUaGUgRXVyb3BhLUxpc3QgRW1haWwgRm9ydW0gLV8tPSBVc2UgdGhlIE1h dHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2VfLT0gdGhlIG1hbnkgTGlz dCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbixfLT0gQXJjaGl2ZSBTZWFy Y2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsXy09IFBob3Rvc2hhcmUsIGFu ZCBtdWNoIG11Y2ggbW9yZTpfLT1fLT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP0V1cm9wYS1MaXN0Xy09Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT1fLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLV8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBh dmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIV8tPV8tPcKgwqAgLS0+IGh0dHA6Ly9mb3J1bXMu bWF0cm9uaWNzLmNvbV8tPV8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09Xy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBORVcg TUFUUk9OSUNTIExJU1QgV0lLSSAtXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBF bWFpbCBMaXN0IFdpa2khXy09wqDCoCAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbV8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 Xy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LV8tPcKgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IV8tPcKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJh bGxlLCBMaXN0IEFkbWluLl8tPcKgwqAgLS0+IGh0dHBzOi8vbWF0cm9uaWNzLmNvbS9jb250cmli dXRpb25fLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PSAg ________________________________________________________________________________
Date: Apr 25, 2023
Subject: Official Europa-List Usage Guidelines
UGxlYXNlIGNoYW5nZSB0aGUgYWJvdmUgZW1haWwgZm9yIEpvaG4gUHJpY2UgdG86Sm9obnd0MTk2 NEBnbWFpbC5jb23CoE1hbnkgdGhhbmtzU2VudCBmcm9tIG15IEdhbGF4eQotLS0tLS0tLSBPcmln aW5hbCBtZXNzYWdlIC0tLS0tLS0tRnJvbTogTWF0dCBEcmFsbGUgPGRyYWxsZUBtYXRyb25pY3Mu Y29tPiBEYXRlOiAwMi8wNC8yMDIzICAwNzoyMCAgKEdNVCswMDowMCkgVG86IGRyYWxsZUBtYXRy b25pY3MuY29tIFN1YmplY3Q6IEV1cm9wYS1MaXN0OiBPZmZpY2lhbCBFdXJvcGEtTGlzdCBVc2Fn ZSBHdWlkZWxpbmVzIC0tPiBFdXJvcGEtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogTWF0dCBEcmFs bGUgPGRyYWxsZUBtYXRyb25pY3MuY29tPkRlYXIgTGlzdGVycywgUGxlYXNlIHJlYWQgb3ZlciB0 aGUgRXVyb3BhLUxpc3QgVXNhZ2UgR3VpZGVsaW5lcyBiZWxvdy7CoCBUaGUgY29tcGxldGVFdXJv cGEtTGlzdCBGQVEgaW5jbHVkaW5nIHRoZXNlIFVzYWdlIEd1aWRlbGluZXMgY2FuIGJlIGZvdW5k IGF0IHRoZWZvbGxvd2luZyBVUkw6IMKgwqAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL0ZBUXMv RXVyb3BhLUxpc3QuRkFRLmh0bWwgVGhhbmsgeW91LCBNYXR0IERyYWxsZU1hdHJvbmljcyBFbWFp bCBMaXN0IEFkbWluaXN0cmF0b3IgICoqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKsKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgRXVyb3BhLUxpc3QgVXNhZ2UgR3VpZGVsaW5lcyoq KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioqKioqKioqKioqKlRoZSBmb2xsb3dpbmcgZGV0YWlscyB0aGUgb2ZmaWNpYWwgVXNh Z2UgR3VpZGVsaW5lcyBmb3IgdGhlIEV1cm9wYS1MaXN0LllvdSBhcmUgZW5jb3VyYWdlZCB0byBy ZWFkIGl0IGNhcmVmdWxseSwgYW5kIHRvIGFiaWRlIGJ5IHRoZSBydWxlcyB0aGVyZWluLkZhaWx1 cmUgdG8gdXNlIHRoZSBFdXJvcGEtTGlzdCBpbiB0aGUgbWFubmVyIGRlc2NyaWJlZCBiZWxvdyBt YXkgcmVzdWx0IGluIHRoZSByZW1vdmFsIG9mIHRoZSBzdWJzY3JpYmVycyBmcm9tIHRoZSBMaXN0 LkV1cm9wYS1MaXN0IFBvbGljeSBTdGF0ZW1lbnRUaGUgcHVycG9zZSBvZiB0aGUgRXVyb3BhLUxp c3QgaXMgdG8gcHJvdmlkZSBhIGZvcnVtIG9mIGRpc2N1c3Npb24gZm9ydGhpbmdzIHJlbGF0ZWQg dG8gdGhpcyBwYXJ0aWN1bGFyIGRpc2N1c3Npb24gZ3JvdXAuwqAgVGhlIExpc3QncyBnb2Fsc2Fy ZSB0byBzZXJ2ZSBhcyBhbiBpbmZvcm1hdGlvbiByZXNvdXJjZSB0byBpdHMgbWVtYmVyczsgdG8g ZGVsaXZlcmhpZ2gtcXVhbGl0eSBjb250ZW50OyB0byBwcm92aWRlIG1vcmFsIHN1cHBvcnQ7IHRv IGZvc3RlciBjYW1hcmFkZXJpZWFtb25nIGl0cyBtZW1iZXJzOyBhbmQgdG8gc3VwcG9ydCBzYWZl IG9wZXJhdGlvbi7CoCBSZWFjaGluZyB0aGVzZSBnb2FscyByZXF1aXJlcyB0aGUgcGFydGljaXBh dGlvbiBhbmQgY29vcGVyYXRpb24gb2YgZWFjaCBhbmQgZXZlcnkgbWVtYmVyIG9mIHRoZSBMaXN0 LsKgIFRvIHRoaXMgZW5kLCB0aGUgZm9sbG93aW5nIGd1aWRlbGluZXMgaGF2ZSBiZWVuIGVzdGFi bGlzaGVkOiAtIFBsZWFzZSBrZWVwIGFsbCBwb3N0cyByZWxhdGVkIHRvIHRoZSBMaXN0IGF0IHNv bWUgbGV2ZWwuwqAgRG8gbm90IHN1Ym1pdMKgwqAgcG9zdHMgY29uY2VybmluZyBjb21wdXRlciB2 aXJ1c2VzLCB1cmJhbiBsZWdlbmRzLCByYW5kb20gaHVtb3IsIGxvbmfCoMKgIGxvc3QgYnVkZGll cycgcGhvbmUgbnVtYmVycywgZXRjLiBldGMuIC0gVEhJTksgY2FyZWZ1bGx5IGJlZm9yZSB5b3Ug d3JpdGUuwqAgQXNrIHlvdXJzZWxmIGlmIHlvdXIgcG9zdCB3aWxsIGJlwqDCoCByZWxldmFudCB0 byBldmVyeW9uZS7CoCBJZiB5b3UgaGF2ZSB0byB3b25kZXIgYWJvdXQgdGhhdCwgRE9OJ1Qgc2Vu ZCBpdC4gLSBSZW1lbWJlciB0aGF0IHlvdXIgcG9zdCB3aWxsIGJlIGluY2x1ZGVkIGZvciBwb3N0 ZXJpdHkgaW4gYW4gYXJjaGl2ZcKgwqAgdGhhdCBpcyBncm93aW5nIGluIHNpemUgYXQgYW4gZXh0 cmFvcmRpbmFyeSByYXRlLsKgIFRyeSB0byBiZSBjb25jaXNlIGFuZMKgwqAgdGVyc2UgaW4geW91 ciBwb3N0cy7CoCBBdm9pZCBvdmVybHkgd29yZHkgYW5kIGxlbmd0aHkgcG9zdHMgYW5kwqDCoCBy ZXNwb25zZXMuIC0gS2VlcCB5b3VyIHNpZ25hdHVyZSBicmllZi7CoCBQbGVhc2UgaW5jbHVkZSB5 b3VyIG5hbWUsIGVtYWlsIGFkZHJlc3MswqDCoCBhaXJjcmFmdCB0eXBlL3RhaWwgbnVtYmVyLCBh bmQgZ2VvZ3JhcGhpYyBsb2NhdGlvbi7CoCBBIHNob3J0IGxpbmXCoMKgIGFib3V0IHdoZXJlIHlv dSBhcmUgaW4gdGhlIGJ1aWxkaW5nIHByb2Nlc3MgaXMgYWxzbyBuaWNlLsKgIEF2b2lkwqDCoCBi dWxreSBzaWduYXR1cmVzIHdpdGggY2hhcmFjdGVyIGdyYXBoaWNzOyB0aGV5IGNvbnN1bWUgdW5u ZWNlc3NhcnnCoMKgIHNwYWNlIGluIHRoZSBhcmNoaXZlLiAtIERPTidUIHBvc3QgcmVxdWVzdHMg dG8gdGhlIExpc3QgZm9yIGluZm9ybWF0aW9uIHdoZW4gdGhhdCBpbmZvIGlzwqDCoCBlYXNpbHkg b2J0YWluYWJsZSBmcm9tIG90aGVyIHdpZGVseSBhdmFpbGFibGUgc291cmNlcy7CoCBDb25zdWx0 IHRoZcKgwqAgd2ViIHBhZ2Ugb3IgRkFRIGZpcnN0LiAtIElmIHlvdSB3YW50IHRvIHJlc3BvbmQg dG8gYSBwb3N0LCBETyBrZWVwIHRoZSAiU3ViamVjdDoiIGxpbmUgb2bCoMKgIHlvdXIgcmVzcG9u c2UgdGhlIHNhbWUgYXMgdGhhdCBvZiB0aGUgb3JpZ2luYWwgcG9zdC7CoCBUaGlzIG1ha2VzIGl0 wqDCoCBlYXN5IHRvIGZpbmQgdGhyZWFkcyBpbiB0aGUgYXJjaGl2ZS4gLSBXaGVuIHJlc3BvbmRp bmcsIE5FVkVSIHF1b3RlIHRoZSAqZW50aXJlKiBvcmlnaW5hbCBwb3N0IGluIHlvdXLCoMKgIHJl c3BvbnNlLsKgIERPIHVzZSBsaW5lcyBmcm9tIHRoZSBvcmlnaW5hbCBwb3N0IHRvIGhlbHAgInR1 bmUgaW4iIHRoZcKgwqAgcmVhZGVyIHRvIHRoZSB0b3BpYyBhdCBoYW5kLCBidXQgYmUgc2VsZWN0 aXZlLsKgIFRoZSBpbXBhY3QgdGhhdMKgwqAgcXVvdGluZyB0aGUgZW50aXJlIG9yaWdpbmFsIHBv c3QgaGFzIG9uIHRoZSBzaXplIG9mIHRoZSBhcmNoaXZlIMKgwqAgY2FuIG5vdCBiZSBvdmVyc3Rh dGVkISAtIFdoZW4gdGhlIHBvc3RlciBhc2tzIHlvdSB0byByZXNwb25kIHRvIGhpbS9oZXIgcGVy c29uYWxseSwgRE8gTk9UwqDCoCB0aGVuIGdvIGFoZWFkIGFuZCByZXBseSB0byB0aGUgTGlzdC7C oCBCZSBhd2FyZSB0aGF0IGNsaWNraW5nIHRoZcKgwqAgInJlcGx5IiBidXR0b24gb24geW91ciBt YWlsIHBhY2thZ2UgZG9lcyBub3QgbmVjZXNzYXJpbHkgc2VuZCB5b3VywqDCoCByZXNwb25zZSB0 byB0aGUgb3JpZ2luYWwgcG9zdGVyLsKgIFlvdSBtaWdodCBoYXZlIHRvIGFjdGl2ZWx5IGFkZHJl c3PCoMKgIHlvdXIgcmVzcG9uc2Ugd2l0aCB0aGUgb3JpZ2luYWwgcG9zdGVyJ3MgZW1haWwgYWRk cmVzcy4gLSBETyBOT1QgdXNlIHRoZSBMaXN0IHRvIHJlc3BvbmQgdG8gYSBwb3N0IHVubGVzcyB5 b3UgaGF2ZSBzb21ldGhpbmfCoMKgIHRvIGFkZCB0aGF0IGlzIHJlbGV2YW50IGFuZCBoYXMgYSBi cm9hZCBhcHBlYWwuwqAgIldheSB0byBnbyEiLCAiScKgwqAgYWdyZWUiLCBhbmQgIkNvbmdyYXR1 bGF0aW9ucyIgYXJlIGFsbCByZXNwb25zZXMgdGhhdCBhcmUgYmV0dGVyIHNlbnTCoMKgIHRvIHRo ZSBvcmlnaW5hbCBwb3N0ZXIgZGlyZWN0bHksIHJhdGhlciB0aGFuIHRvIHRoZSBMaXN0IGF0IGxh cmdlLiAtIFdoZW4gcmVzcG9uZGluZyB0byBvdGhlcnMnIHBvc3RzLCBhdm9pZCB0aGUgZmVlbGlu ZyB0aGF0IHlvdSBuZWVkIHRvwqDCoCBjb21tZW50IG9uIGV2ZXJ5IGxhc3QgcG9pbnQgaW4gdGhl aXIgcG9zdHMsIHVubGVzcyB5b3UgY2FuIHRydWx5wqDCoCBjb250cmlidXRlIHNvbWV0aGluZyB2 YWx1YWJsZS4gLSBGZWVsIGZyZWUgdG8gZGlzYWdyZWUgd2l0aCBvdGhlciB2aWV3cG9pbnRzLCBC VVQga2VlcCB5b3VyIHRvbmXCoMKgIHBvbGl0ZSBhbmQgcmVzcGVjdGZ1bC7CoCBEb24ndCBtYWtl IHNuaWRlIGNvbW1lbnRzLCBwZXJzb25hbGx5IGF0dGFja8KgwqAgb3RoZXIgbGlzdGVycywgb3Ig dGFrZSB0aGUgbW9yYWwgaGlnaCBncm91bmQgb24gYW4gb2J2aW91c2x5wqDCoCBjb250cm92ZXJz aWFsIGlzc3VlLsKgIFRoaXMgd2lsbCBvbmx5IGNhdXNlIGEgcG9pbnRsZXNzIGRlYmF0ZSB0aGF0 wqDCoCB3aWxsIGh1cnQgZmVlbGluZ3MsIHdhc3RlIGJhbmR3aWR0aCBhbmQgcmVzb2x2ZSBub3Ro aW5nLiAtIE9jY2FzaW9uYWwgcG9zdHMgYnkgdmVuZG9ycyBvciBpbmRpdmlkdWFscyB3aG8gYXJl IHJlZ3VsYXJseSDCoMKgIHN1YnNjcmliZWQgdG8gYSBnaXZlbiBMaXN0IGFyZSBjb25zaWRlcmVk IGFjY2VwdGFibGUuwqAgUG9zdHMgYnkgwqDCoCBMaXN0IG1lbWJlcnMgcHJvbW90aW5nIHRoZWly IHJlc3BlY3RpdmUgcHJvZHVjdHMgb3IgaXRlbXMgZm9yIHNhbGUgwqDCoCBzaG91bGQgYmUgb2Yg YSBmcmllbmRseSwgaW5mb3JtYWwgbmF0dXJlLCBhbmQgc2hvdWxkIG5vdCByZXNlbWJsZSDCoMKg IGEgdHlwaWNhbCBTUEFNIG1lc3NhZ2UuwqAgVGhlIExpc3QgaXNuJ3QgYWJvdXQgY29tbWVyY2lh bGlzbSwgYnV0IMKgwqAgaXMgYWJvdXQgc2hhcmluZyBpbmZvcm1hdGlvbiBhbmQga25vd2xlZGdl LsKgIFRoaXMgYXBwbGllcyB0byDCoMKgIGV2ZXJ5b25lLCBpbmNsdWRpbmcgdGhvc2Ugd2hvIHBy b3ZpZGUgcHJvZHVjdHMgdG8gdGhlIGVudGlyZSDCoMKgIGNvbW11bml0eS7CoCBJbmZvcm1hbCBw cmVzZW50YXRpb24gYW5kIG1vZGVyYXRpb24gc2hvdWxkIGJlIHRoZSDCoMKgIG9wZXJhdGl2ZXMg d2l0aCByZXNwZWN0IHRvIGFkdmVydGlzaW5nIG9uIHRoZSBMaXN0cy4tLS0tLS0tIFtUaGlzIGlz IGFuIGF1dG9tYXRlZCBwb3N0aW5nLl0gZG8gbm90IGFyY2hpdmUgIF8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Xy09wqDCoMKgwqDC oMKgwqDCoMKgIC0gVGhlIEV1cm9wYS1MaXN0IEVtYWlsIEZvcnVtIC1fLT0gVXNlIHRoZSBNYXRy b25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlXy09IHRoZSBtYW55IExpc3Qg dXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sXy09IEFyY2hpdmUgU2VhcmNo ICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLF8tPSBQaG90b3NoYXJlLCBhbmQg bXVjaCBtdWNoIG1vcmU6Xy09Xy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9FdXJvcGEtTGlzdF8tPV8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09Xy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oCAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC1fLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZh aWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyFfLT1fLT3CoMKgIC0tPiBodHRwOi8vZm9ydW1zLm1h dHJvbmljcy5jb21fLT1fLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PV8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTkVXIE1B VFJPTklDUyBMSVNUIFdJS0kgLV8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25pY3MgRW1h aWwgTGlzdCBXaWtpIV8tPcKgwqAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb21fLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PV8t PcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC1f LT3CoCBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCFfLT3CoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxs ZSwgTGlzdCBBZG1pbi5fLT3CoMKgIC0tPiBodHRwczovL21hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0 ________________________________________________________________________________
Date: Apr 25, 2023
Some further numbers were run this afternoon after William's comment, focusing on trailing wash affecting the horizontal stab and items snagging on a control surface. Airspeed was increased from 100kt to 150kt with some interesting results... basically, flying faster reduces the turbulence within the cockpit after a door departs. The other outcome noticed while slicing through the layers of velocity tracing was all the turbulent flow exits the cockpit at the top center of each door port; the sides of the fuselage remain fairly unaffected and away from the wash; so it would not be too untrue to assume anything such as cloth or lite items sucked out of the cockpit possess little chance or risk toward hitting or snagging on the horizontal stab. So the numbers indicate fly faster to be in a windy bus stop, or fly slower and sit in a tornado... personally not excited or outwardly wishing anybody find themselves in the situation to prove the theory correct. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510694#510694 Attachments: http://forums.matronics.com//files/7c56e3b5_61c7_45c8_92d7_d7f8463505bf_175.jpeg ________________________________________________________________________________
Subject: Help please: PV50 lead screw
Date: Apr 25, 2023
My Arplast PV50 lead screw bearing has gone a bit crunchy so needs replacement. Im looking for tips and advice please from anyone who has done this before I start to disassemble. At the same time Im looking to create some spares so if anyone has the dimensions for the lead screw, bearing and the other parts, or can help me as to where they sourced them, thet would be much appreciated. Thanks in advance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510695#510695 ________________________________________________________________________________
Subject: The Obsidian Files - Departed Canopy
Date: Apr 25, 2023
This file entry leads on from and related to the Doorly Departed file. The weather is still crap for everything but ducks, so more numbers have been crunched as ideas and what ifs spring forth from the ether... This entry looks at a loss of canopy during flight at 100kt. With the doors already suppressed the canopy was removed and numbers once again put through the magic grinder. What was revealed... the aircraft will still fly without a front canopy or doors... the turbulent flow within the cockpit is lowered to chest height with the majority of swirl at across the breadth of the rear of the cabin, leaving the occupant's heads above within 50kt fast moving free stream air; very exciting moment requiring good wrap around eyewear... Turbulent air exits the cockpit along the entire rear breadth of the door port out along the empenage, and along with air drawn up from the fuselage belly will shield about 50% of the horizontal stab in very slow moving air; so highly reduced pitch authority would be a highly probable situational expectation. With only one door departed the above affects are divided to the side of the departed door. That's all for now upon a front canopy departing... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510696#510696 Attachments: http://forums.matronics.com//files/19e5ad44_8ee0_4b79_87a3_7e0915b5be48_850.jpeg http://forums.matronics.com//files/780ecfbd_ae82_4c66_a9ad_a2ee2aba077a_251.jpeg http://forums.matronics.com//files/8ee5fd84_925f_4e13_bd4d_bcbfbeb54497_170.jpeg http://forums.matronics.com//files/c76baa9d_70bb_4788_babe_0627868ffa21_169.jpeg http://forums.matronics.com//files/e4eda943_a068_4bdb_b466_f2feeb858f9b_121.jpeg http://forums.matronics.com//files/b7c855d6_c9fb_44a9_af2f_6b3ea0cbc391_462.jpeg http://forums.matronics.com//files/29b82d9d_9988_4201_8e69_1f40bae089dc_188.jpeg http://forums.matronics.com//files/981f8084_5b7f_494c_a1de_7da686e563ef_190.jpeg http://forums.matronics.com//files/9e836eae_fe45_4e26_a5c4_3ea06bab34fe_217.jpeg ________________________________________________________________________________
Date: Apr 25, 2023
More insight was extracted last night from this study... the above image indicates how the air enters the cockpit after the door has departed; at the lower rear frame rail... it then whips around at the centerline toward the front for the uppercut rearward exit; this creates a vortex in the lower luggage well, and another in the front footwell to head area. Several deflectors were tested at 100kt.. upper forward rail visor, side forward visor, a lower side rail board, and rear lower rail louvre... all additions performed some affect with the louvre setup providing the best outcome toward reducing cockpit turbulence to a pleasant level while doorless. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510701#510701 ________________________________________________________________________________
Date: Apr 26, 2023
Many thanks for your input. Just FYI I measured the actual ARM last weekend and it worked out to by 85.5 inches. Regards, Tony -------- Tony Vaccarella Mascot NSW 2020 Sydney Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510706#510706 ________________________________________________________________________________
Date: Apr 27, 2023
Subject: RE: Europa-List Digest: 1 Msgs - 04/26/23
Q2FuIGFueW9uZSBhZHZpc2Ugd2hvIGNhbiBjaGFuZ2UgbXkgZW1haWwgYWRkcmVzcyBmcm9tIHRo ZSBhYm92ZSB0byB0aGlzOmpvaG53dDE5NjRAZ21haWwuY29twqBTZW50IGZyb20gbXkgR2FsYXh5 Ci0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS1Gcm9tOiBFdXJvcGEtTGlzdCBEaWdl c3QgU2VydmVyIDxldXJvcGEtbGlzdEBtYXRyb25pY3MuY29tPiBEYXRlOiAyNy8wNC8yMDIzICAw Nzo0MiAgKEdNVCswMDowMCkgVG86IEV1cm9wYS1MaXN0IERpZ2VzdCBMaXN0IDxldXJvcGEtbGlz dC1kaWdlc3RAbWF0cm9uaWNzLmNvbT4gU3ViamVjdDogRXVyb3BhLUxpc3QgRGlnZXN0OiAxIE1z Z3MgLSAwNC8yNi8yMyAqID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09wqDCoCBPbmxpbmUgVmVyc2lvbnMgb2YgVG9kYXkncyBMaXN0IERpZ2VzdCBBcmNo aXZlID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09VG9k YXkncyBjb21wbGV0ZSBFdXJvcGEtTGlzdCBEaWdlc3QgY2FuIGFsc28gYmUgZm91bmQgaW4gZWl0 aGVyIG9mIHRoZSB0d28gV2ViIExpbmtzIGxpc3RlZCBiZWxvdy7CoCBUaGUgLmh0bWwgZmlsZSBp bmNsdWRlcyB0aGUgRGlnZXN0IGZvcm1hdHRlZCBpbiBIVE1MIGZvciB2aWV3aW5nIHdpdGggYSB3 ZWIgYnJvd3NlciBhbmQgZmVhdHVyZXMgSHlwZXJsaW5rZWQgSW5kZXhlcyBhbmQgTWVzc2FnZSBO YXZpZ2F0aW9uLsKgIFRoZSAudHh0IGZpbGUgaW5jbHVkZXMgdGhlIHBsYWluIEFTQ0lJIHZlcnNp b24gb2YgdGhlIEV1cm9wYS1MaXN0IERpZ2VzdCBhbmQgY2FuIGJlIHZpZXdlZCB3aXRoIGEgZ2Vu ZXJpYyB0ZXh0IGVkaXRvciBzdWNoIGFzIE5vdGVwYWQgb3Igd2l0aCBhIHdlYiBicm93c2VyLiBI VE1MIFZlcnNpb246wqDCoMKgIGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9kaWdlc3QvZGlnZXN0 dmlldy5waHA/U3R5bGU9ODI3MDEmVmlldz1odG1sJkNoYXB0ZXI9MjAyMy0wNC0yNiZBcmNoaXZl PUV1cm9wYVRleHQgVmVyc2lvbjrCoMKgwqAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2RpZ2Vz dC9kaWdlc3R2aWV3LnBocD9TdHlsZT04MjcwMSZWaWV3PXR4dCZDaGFwdGVyPTIwMjMtMDQtMjYm QXJjaGl2ZT1FdXJvcGEgPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09wqDCoCBFTWFpbCBWZXJzaW9uIG9mIFRvZGF5J3MgTGlzdCBEaWdlc3QgQXJjaGl2ZSA9 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0gwqDCoMKgwqDC oMKgwqDCoMKgwqAgLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqAgRXVyb3BhLUxpc3QgRGlnZXN0IEFyY2hpdmXCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtLS3C oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIFRvdGFsIE1lc3NhZ2VzIFBv c3RlZCBXZWQgMDQvMjYvMjM6IDHCoMKgwqDCoMKgwqDCoMKgwqDCoCAtLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tICBUb2RheSdzIE1lc3Nh Z2UgSW5kZXg6LS0tLS0tLS0tLS0tLS0tLS0tLS0tLSDCoMKgwqDCoCAxLiAwNDo0MyBBTSAtIFJl OiBBdXhpbGlhcnktIExvbmdyYW5nZXIgRnVlbCBUYW5rIEFSTcKgICh0b255dmFjY2FyZWxsYSkg ICBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX8KgIE1lc3NhZ2UgMcKgIF9fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19UaW1lOiAwNDo0Mzo0MSBBTSBQU1QgVVNTdWJq ZWN0OiBFdXJvcGEtTGlzdDogUmU6IEF1eGlsaWFyeS0gTG9uZ3JhbmdlciBGdWVsIFRhbmsgQVJN RnJvbTogInRvbnl2YWNjYXJlbGxhIiA8dG9ueUB3ZWltYWdpbmUuY29tLmF1Pk1hbnkgdGhhbmtz IGZvciB5b3VyIGlucHV0LiBKdXN0IEZZSSBJIG1lYXN1cmVkIHRoZSBhY3R1YWwgQVJNIGxhc3Qg d2Vla2VuZCBhbmRpdCB3b3JrZWQgb3V0IHRvIGJ5IDg1LjUgaW5jaGVzLlJlZ2FyZHMsVG9ueS0t LS0tLS0tVG9ueSBWYWNjYXJlbGxhTWFzY290IE5TVyAyMDIwU3lkbmV5IEF1c3RyYWxpYVJlYWQg dGhpcyB0b3BpYyBvbmxpbmUgaGVyZTpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3Rv cGljLnBocD9wPTUxMDcwNiM1MTA3MDYgXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT1fLT3CoMKgwqDCoMKgwqDCoMKgwqAgLSBUaGUg RXVyb3BhLUxpc3QgRW1haWwgRm9ydW0gLV8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1 cmVzIE5hdmlnYXRvciB0byBicm93c2VfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBh cyBMaXN0IFVuL1N1YnNjcmlwdGlvbixfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1E YXkgQnJvd3NlLCBDaGF0LCBGQVEsXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZTpf LT1fLT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0V1cm9wYS1M aXN0Xy09Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT1fLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTUFUUk9OSUNTIFdF QiBGT1JVTVMgLV8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBX ZWIgRm9ydW1zIV8tPV8tPcKgwqAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbV8tPV8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09Xy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lL SSAtXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2khXy09 wqDCoCAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbV8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Xy09wqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLV8tPcKgIFRoYW5rIHlvdSBm b3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IV8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLl8t PcKgwqAgLS0+IGh0dHBzOi8vbWF0cm9uaWNzLmNvbS9jb250cmlidXRpb25fLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PSAg ________________________________________________________________________________
Date: Apr 27, 2023
Subject: Re: Help please: PV50 lead screw
Date: May 01, 2023
Replying to my own post in case it helps someone else. The bearing is 61800-2Z-SKF and is pretty common so all the usual suspects stock it. Ill update when I replace mine and post some images. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510718#510718 ________________________________________________________________________________
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Date: May 04, 2023
Subject: Brake reservoir mounting - Trigear
Hi everyone, Do most folks mount the reservoir on the firewall, or the tunnel Paul ________________________________________________________________________________
Subject: Re: Brake reservoir mounting - Trigear
Date: May 04, 2023
Mounted on tunnel... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510734#510734 ________________________________________________________________________________
Date: May 05, 2023
Mine has no separate reservoir, only the master cylinders for finger brakes mounted inside the tunnel. See attached pictures. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510736#510736 Attachments: http://forums.matronics.com//files/7g_eiky_finger_brakes_244.jpg http://forums.matronics.com//files/4g_eiky_finger_brakes_100.jpg http://forums.matronics.com//files/2g_eiky_finger_brakes_636.jpg http://forums.matronics.com//files/1g_eiky_finger_brakes_556.jpg ________________________________________________________________________________
Date: May 05, 2023
Hi Paul, Since you are installing Matco masters, I would put the reservoir on the fi rewall. Even the Jamar benefits from the master higher up on the firewall. Reason: Maintenance. Matco prefers 5606. It is sticky and stains. Lasts forever but does absor b water from the air and should be changed out once it begins to discolor. Dot 5 silicone brake fluid is normally a nice purple or clear but if it st arts to yellow or turn slightly red, change it. If it is discolored it is contaminated with water. Dot 5 is nice to use as it doesn't stain if you d rip some. So I put the reservoir on the firewall as it is easy to get to a nd inspect on my routine 25 hour inspection/oil change. This requires me t o plumb more line to the masters. I use the =BC inch OD 1/8 ID vinyl tubin g for the reservoir line to make that chore easy as there is no pressure on the line so a simple barb fitting is all that is necessary and it won't le ak. To clean out the old fluid simply tip and drain the reservoir, then ad d fresh and pump the fluid down to a bleeder cup/container filled with flui d until the fluid is clean again. It works fine for me but does require an assistant. Bleeding from the bottom slave cylinder I can do IAW my articl e single handedly and it is excellent exercise getting up and down to drain the reservoir. If working alone, I simply undo the reservoir and let it d rain into a pan setting on the footwell, but only if I have no need for the exercise. Plummbing the Matcos does require some head scratching to make them easy to inspect/service/plumb. Just remember the reservoir should be the highest point in the brake system to operate properly. Putting the reservoir in the tunnel is OK but requires the time to get into the tunnel to check the condition and the level of the fluid. It is a bla ck hole in there, only openned on the annual normally, and you have to plac e your reservoir and line where it is easily serviced. This can be done, b ut it just requires planning. I have my fuel pumps, fuel flow and pressure senders, parking brake, stall horn, and fuel selector in there, so my hole is a bit tight on observation space. I placed my reservoir it where it can be seen (with a flashlight and some h ead cranking) on the firewall behind and offset from the fuel pressure regu lator. I should have put it on the oil tank side. Duh... Best Regards, Bud Yerly ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of Paul McAllister Sent: Thursday, May 4, 2023 10:37 AM Subject: Europa-List: Brake reservoir mounting - Trigear Hi everyone, Do most folks mount the reservoir on the firewall, or the tunnel Paul ________________________________________________________________________________
Date: May 05, 2023
Subject: Oil - Rotax - Synthetic or other
Whats is the consensus on the best oil. I have used the Aeroshell sport PLUS 4 oil up to now mainly because I used AVGAS in Colombia. (Mogas was of doubtful quality.) I have since heard that lost of people use Mobil Synthetic. Any thoughts? William Daniell LONGPORT +1 786 878 0246 ________________________________________________________________________________
Subject: Re: Oil - Rotax - Synthetic or other
Date: May 05, 2023
>From memory, there may be a discussion about this subject on Recreational Flyer forum site, or Rotax page on matronics. The issue with using similar motorcycle grade oils in the 912 is that they do not have additives for high altitude situations above 4000' i think it was... otherwise they worked fine; some with less burn-off between oil changes. Aeroshell also has an additive to flock lead from the oil and transport it to the reservoir. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510742#510742 ________________________________________________________________________________
Date: May 07, 2023
V2lsbCwNCkFlcm9zaGVsbCBTcG9ydCBQbHVzIDQgKEFlcm9zaGVsbCBTUDQpIGlzIGdvb2QgZm9y IGVpdGhlciBNb2dhcyAoQUtJIDkxIG9yIFIrTS8yKSBvZiA5MSBvciA5MiBhbmQgaXMgZmluZSBh bHNvIHdpdGggMTAwTEwgSUFXIFJvdGF4IFNlcnZpY2UgbGV0dGVycyBhbmQgZXhwZXJpZW5jZS4N Cg0KQW55IG90aGVyIG9pbCBtdXN0IGhhdmUgdGhlIHByb3BlciBnZWFyYm94IGFkZGl0aXZlcyB1 c2VkIGluIG1vdG9yY3ljbGVzIGFzIEFyZWEgNTEgbm90ZWQgYWxzby4gIFdlIHVzZWQgdG8gdXNl IE1vYmlsZSBNWDRUIChub3cga25vd24gYXMgUmFjaW5nIDRUIE1vdG9yY3ljbGUgb2lsKSB3aGlj aCBpcyBhIG1vdG9yY3ljbGUvQVRWIG9pbCB1c2luZyBhZGRpdGl2ZXMgZm9yIGdlYXJib3hlcyBi YXRoZWQgaW4gZW5naW5lIG9pbC4gIERvIG5vdCB1c2UgcmVndWxhciBNb2JpbGUgT25lIGluIGEg Um90YXggYWx0aG91Z2ggbWFueSBkaWQgdW50aWwgYWZ0ZXIgMjAxMS0yMDEyIDkxNC1TQi0xOT8/ ICBvciBzbyB3aGVuIHRoZSBndWlkYW5jZSBjaGFuZ2VkIGR1ZSB0byB0aGUgZ2VhcmJveCBhZGRp dGl2ZSBub3QgZm91bmQgaW4gTW9iaWxlIDEgd2hpY2ggbWF5IGhhdmUgY2F1c2VkIHNvbWUgZ2Vh cmJveCBpc3N1ZXMgb2Ygd2hpY2ggdGhlIFJvdGF4IEdvZHMga2VwdCBzZWNyZXQgYW5kIFJvdGF4 IHdlbnQgaGFyZCBvdmVyIGZvciBBZXJvc2hlbGwgU1A0LiAgUHJpbWFyeSByZWFzb24gd2FzIEFl cm9zaGVsbCBkb2VzbuKAmXQgY2hhbmdlIHRoZWlyIG9pbCB3aXRob3V0IG5vdGljZSBhcyBhdXRv IG9pbCBtYW51ZmFjdHVyZXJzIGRvLiAgSWYgeW91IHVzZSBUQ1AgYW5kIFNQNCB0aGUgbGVhZCBz ZXR0bGVzIGluIHRoZSB0YW5rIHdoZW4gdGhlIG9pbCBjb29scy4gIEFzIHlvdSBhbGwga25vdyBJ IGNoYW5nZSBvaWwgZXZlcnkgMjUtMzAgaG91cnMgYW55d2F5IGFzIEkgYmVsaWV2ZSBpbiByb3V0 aW5lIDI1IGhvdXIgaW5zcGVjdGlvbnMgYW5kIHNpbmNlIEkgdXNlIGFuZCB3aWxsIGNvbnRpbnVl IHRvIHVzZSAxMDBMTCBpdCBrZWVwcyB0aGUgb2lsIGNhbiBjbGVhbmVyLiAgWW91IGFsc28ga25v dyBJIGRvbuKAmXQgZm9sbG93IGhlYXJzYXkgYW5kIGRvIG15IG93biByZXNlYXJjaCAoSGF2ZSBp bnRlcm5ldCwgd2lsbCByZXNlYXJjaCEpLg0KDQpNaXNjZWxsYW5lb3VzIFJhbWJsaW5nczoNCklm IHVzaW5nIFN1cGVyIFByZW1pdW0gQXV0byBGdWVsIEFLSSA5MSAod2hhdGV2ZXIgdGhlIGxvY2Fs IHN0YXRpb24gY2FsbHMgaXQpIHdlIG5ldmVyIGhhZCBhIHByb2JsZW0gd2l0aCB0aGUgTW9iaWxl IE1YNFQgYnV0IHRoZXJlIHdlcmUgc3RhcnRpbmcgaXNzdWVzIGlmIHRoZSBnYXMgd2FzIG9sZC4g IEJ1dCBldmVuIGF0IGEgaGlnaGVyIG9pbCBjaGFuZ2UgaW50ZXJ2YWwsIGxvb2sgYXQgdGhlIGNv c3QgZGlmZmVyZW5jZToNCg0KSSBmbHkgbGVzcyB0aGFuIG1vc3Qgb2YgeW91LCBzbyBBZXJvc2hl bGwgU1A0IGlzIGNvc3QgZWZmZWN0aXZlLiAgU1A0IGlzIGFib3V0ICQxMS0xNSBhIHF1YXJ0IGFu ZCBNWDRUIGlzIGFib3V0ICQxMi0xNSBhIHF1YXJ0LiAgRGVwZW5kaW5nIG9uIHdoZXJlIHlvdSBi dXkgaXQuICBJIGJ1eSB0aGUgU1A0IGEgY2FzZSBhdCBhIHRpbWUgKDEyIHF1YXJ0cykgZm9yIGFi b3V0ICQxMzUgaW5jbHVkaW5nIHNoaXBwaW5nLCBhbmQgdGhlIDRUIGlzIGFib3V0ICQ4NiBmb3Ig NiBxdWFydHMgcGx1cyBzaGlwcGluZy4gIEFnYWluLCBkZXBlbmRpbmcgb24gd2hlcmUgeW91IGJ1 eSB5b3VyIG9pbCBjb3N0cyBjaGFuZ2UuICBTaW5jZSBvbmx5IGEgZmV3IGFpcnBvcnRzIGFjcm9z cyB0aGUgVVMgY2FycnkgTU9HQVMgb2YgOTEgQUtJLCBJIGNhbuKAmXQgYXZvaWQgbGVhZGVkIEFW R2FzIHVzZS4gIEkgc3RpY2sgd2l0aCB0aGUgU1A0LiAgRG8gSSByZWxpZ2lvdXNseSB1c2UgdGhl IFRDUCBmdWVsIGFkZGl0aXZlPyAgV2VsbCwgSSB0cnkgdG8uICBJZiBjcm9zcyBjb3VudHJ5IGFu ZCBJIG5lZWQgb2lsIGFuZCB0aGUgRkJPIGRvZXMgbm90IHN0b2NrIFNQNCwgSSB1c2UgZWl0aGVy IHRoZSBWYWx2b2xpbmUgc2VtaSBzeW50aGV0aWMgbW90b3JjeWNsZSBvaWwgb3IgTW9iaWwgTVg0 VCB0byBhZGQgaWYgbXkgb2lsIGxldmVsIGdldHMgbG93IGZvciBzb21lIHJlYXNvbi4NCg0KQWx0 aG91Z2ggc29tZSBzYXkgYSBmdWxsIHN5bnRoZXRpYyBvaWwgb25seSBoYXMgdG8gYmUgY2hhbmdl ZCBldmVyeSAxMDAgSHJzLCBJ4oCZbSBhZnJhaWQgSSBoYXZlIG5vdCBib3VnaHQgaW50byB0aGF0 LiAgRmxvcmlkYSBpcyBob3QsIGh1bWlkLCBhbmQgaXJvbiBnZWFycyBhcmUgcHJvbmUgdG8gcnVz dGluZy4gIFN5bnRoZXRpY3MgYXJlIGdyZWF0IG9pbHMsIGJ1dCBJIHBlcnNvbmFsbHkgYW0gbm90 IGluY2xpbmVkIHRvIGJlIGEgdGVzdCBjYXNlIGR1ZSB0byBvdXIgaGlnaCBodW1pZGl0eSBjb25k aXRpb25zIGFuZCB0aGUgbGFjayBvZiBjb2F0aW5nIE1vYmlsZSBvbmUgc2VlbXMgdG8gaGF2ZSBp biBjb21wYXJpc29uIHRvIHN0YW5kYXJkIG9pbCBvbiB0aGUgZ2VhcnMgd2hlbiB0aGUgcGxhbmUg c2V0cyBmb3Igd2Vla3MvbW9udGhzLg0KDQpBVkdhcyBpcyBhdmVyYWdpbmcgbm93IChvbiBjcm9z cyBjb3VudHJ5KSBhYm91dCAkNyAoU2VicmluZyBpcyAkNSkgYW5kIFByZW1pdW0gOTIgT2N0YW5l IFIrTS8yIGlzIGFib3V0ICQ0L2dhbGxvbiBpbiBUYW1wYS4gIElmIEkgZmx5IDI1IGhvdXJzIGEg eWVhciBob3cgbXVjaCBkbyBJIHNhdmUgYXQgNS02IGdhbC9ociB3aXRoIGEgMjUgaG91ciBvaWwg Y2hhbmdlLiAoTm90ZSBJIHJlYWxseSBvbmx5IGZsZXcgdGhlIEV1cm9wYSAxMCBob3VycyBsYXN0 IHllYXIuKSAgTXkgZ2FzIHVzZSB3b3VsZCBiZSAxMzcgZ2FsbG9ucyBhbmQgYW4gb2lsIGNoYW5n ZSBpcyBhYm91dCAzIHF1YXJ0cy4gIEF2Z2FzL1NQNCBhdCA1LjVHUEggJDk2MiszMyBmb3Igb2ls ID0kOTk1IGJ1dCBub3JtYWxseSB3aXRoIG15IGRpc2NvdW50ICQ2ODgrNDU9JDczMiBhbmQgOTFB S0kgTW9nYXMgdXNlIHdvdWxkIGNvc3QgaW4gbXkgYXJlYSAoTXkgRkYgaXMgNS44IEdQSCBhdCAz MSBpbmNoZXMgb24gU2hlbGwgU3VwcmVtZSBmdWVsKSAkNTgyICsgNDU9ICQ2MjUgYW5kIEkgbXVz dCBub3cgY29uc2lkZXIgSSBjYW7igJl0IGdldCByZWxpYWJsZSBNT0dBUyBvbiBjcm9zcyBjb3Vu dHJ5IGF0IHRoZSBuaWNlIGFpcnBvcnRzLCBob3dldmVyIEkgc3RpbGwgaGF2ZSB0byB3b3JyeSBh Ym91dCBiYWQgb3Igb2xkIGdhcyB0aGF0IGhhcyBiZWVuIHNldHRpbmcgYXQgdGhlIGFpcnBvcnQg YW5kIGluIG15IGFpcnBsYW5lLiAgRm9yIG1lIGl0IGlzIG5vdCB0aGF0IG11Y2ggb2YgYSBkaWZm ZXJlbmNlIG92ZXIgYSB5ZWFycyB3b3J0aCBvZiBmbHlpbmcgYnV0LCBpZiB5b3Ugb25seSBmbHkg bG9jYWwgYW5kIGZseSAzMDAgaG91cnMgYSB5ZWFyLCB5b3UgY2FuIHNhdmUgcXVpdGUgYSBiaXQu ICBUaG9zZSBmb2xrcyBvdmVyc2VhcyB0aGF0IGNhbiBnZXQgZ29vZCBzdXBlciBzdXByZW1lIGZ1 ZWwgYXQgYWlyZmllbGRzIGFuZCBnbyA1MCBob3VycyBiZXR3ZWVuIG9pbCBjaGFuZ2VzIGNhbiBz YXZlIGVub3VnaCB0byBwYXkgYSBtb250aOKAmXMgaGFuZ2FyIGZlZSBhbmQgb3IgYSBtb250aOKA mXMgd29ydGggb2YgaW5zdXJhbmNlIHNvIGl04oCZcyB3b3J0aCBpdCBmb3IgdGhvc2Ugb3ZlcnNl YXMgdG8gbG9vayBmb3IgYWx0ZXJuYXRpdmVzIGR1ZSB0byB0aGVpciBoaWdoIGZ1ZWwgY29zdHMg YW5kIG9pbCBhdmFpbGFiaWxpdHkuICBGb3IgbWUsIGluIHRoZSBUYW1wYSBGbG9yaWRhIGFyZWEs IGl0IGp1c3QgaXNu4oCZdCB3b3J0aCB0aGUgc3RhZ25hbnQgZnVlbCBpc3N1ZXMgc2luY2UgSSBm bHkgc28gbGl0dGxlIGFuZCBTUDQgd29ya3MgYW5kIGlzIHJlbGF0aXZlbHkgY2hlYXAgdG8gYnV5 IGZvciBhIHNwZWNpYWx0eSBvaWwuICBBcyBmYXIgYXMgYXV0byBmdWVsIGdvZXMgdnMgMTAwTEws IG15IHBhcnRpY3VsYXIgOTE0IGxpa2VzIDEwMExMLiAgSXQgc3RhcnRzIHJlYWxseSBmYXN0LiAg Tm8gd29ycmllcyBhYm91dCBraWNrYmFjayBvbiBzdGFydCB3aXRoIHRoYXQgZnVlbCwgbm8gbWF0 dGVyIGhvdyBvbGQgaXQgaXMuICBXaXRoIGV0aGFub2wgbGFjZWQgc3VwZXIgTW9HYXMgb25seSBh dmFpbGFibGUgaGVyZSBpbiBUYW1wYSwgSSBmaW5kIHRoYXQgYnkgdXNpbmcgMTAwTEwgZnVlbCwg bXkgY2FyYnMgYXJlIGFsd2F5cyBjbGVhbiBhbmQgaGF2ZSBzdGF5ZWQgdHVuZWQgZm9yIDQgeWVh cnMsIHRoZSBmbG9hdHMgZG9u4oCZdCBzaW5rIGFuZCBteSBmbG9hdCBib3dscyBsb29rIGxpa2Ug bmV3LiAgT3RoZXJzIGluIHRoZSBhcmVhIGFyZSBub3Qgc28gbHVja3kgdGhhdCBmdWVsIHdpdGgg ZXRoYW5vbCBnYXMuDQoNCk5vdGUsIEkgaGFkIExvY2t3b29kIGRvIGEgNTAwIEhyIHRvcCBvdmVy aGF1bCBvZiBteSA5MTQgcnVubmluZyAxMDBMTCB3aXRoIFRDUCBhbmQgU1A0IG9pbCBhbmQgUm90 YXggRmlsdGVyLiAgVGhlIGVuZ2luZSB3YXMgdW5iZWxpZXZhYmx5IGNsZWFuIG9uIHRoZSBpbnNp ZGUuICBUaGUgb2lsIHRhbmsgaG9sZHMgdGhlIGxlYWQgaW4gc3VzcGVuc2lvbiBsaWtlIGl0IGlz IHN1cHBvc2VkIHRvLiAgVGhlIG9ubHkgdGhpbmcgSSBmaW5kIGlzLCBpbiB0aGUgb2lsIGZpbHRl ciB0aGVyZSBhcmUgc21hbGwgY2h1bmtzIG9mIGNhcmJvbiBmcm9tIHRoZSB0dXJiby4gIFRoZXJl IGlzIGEgbmV3IFNlcnZpY2UgQnVsbGV0aW4gb24gdGhlIDkxNCB0dXJibyBjYW4gd2hpY2ggY2hh bmdlcyB0aGUgZGVzaWduIGFuZCBhZGRzIGEgZmlsdGVyIHNjcmVlbi4gIEl0IG1heSBzZXQgdG9v IGNsb3NlIHRvIG15IGR1Y3Qgc28gSSBkb3VidCBJIGNhbiBjaGFuZ2UgaXQgd2l0aG91dCBsb3dl cmluZyB0aGUgZHVjdC4gIEnigJlsbCBzZWUgaG93IG11Y2ggaXQgY29zdHMuICBJIGxpa2UgdGhl IGRlc2lnbiBidXQsIEkgcHJvYmFibHkgd2lsbCBiZSBzaG9ja2VkIGJ5IHRoZSBwcmljZS4gIFRv IHRlbGwgeW91IHRoZSB0cnV0aCBJIGNhbuKAmXQgd2FpdCBmb3IgdGhlIG5ldyB1bmxlYWRlZCBB VkdhcyBlaXRoZXIuICBJIGJldCB0aGUgQVZHYXMgcHJpY2UganVtcHMgMzAlIGluaXRpYWxseSB3 aGVuIGl0IGNvbWVzIG91dC4NCg0KU28sIHRoZSBjaG9pY2UgaXMgeW91cnMuICBSZXNlYXJjaCBh bmQgZG8geW91ciBvd24gbWF0aCBmb3IgeW91ciBmbHlpbmcgbmVlZHMgYW5kIGZ1ZWwvb2lsIGNv c3RzLiAgSSB3b3VsZG7igJl0IHNraW1wIG9uIGZsdWlkcyB0aG91Z2guICBHb29kIGZyZXNoIGdh cywgYW5kIGdvb2Qgb2lsIGFyZSBhIG11c3QuICBNYWludGVuYW5jZSBiZWNvbWVzIG1vcmUgb2Yg YSB0aW1lIGNoYW5nZSByZXF1aXJlbWVudCB3aXRoIHByb3BlciBmbHVpZHMuICBEbyB0aGUgaW5z cGVjdGlvbnMgYW5kIHRpbWUgY2hhbmdlcyBhbmQgeW91ciBwbGFuZSB3aWxsIHJld2FyZCB5b3Ug d2l0aCBvbmx5IHBlcmlvZGljIG1haW50ZW5hbmNlIGFuZCBsZWF2ZSB5b3UgbW9yZSBtb25leSBm b3IgdXBncmFkZXMuDQoNCllvdSBhbGwga25vdyB3aGF0IGtlZXBzIGFuIGFpcnBsYW5lIGZseWlu ZyBkb27igJl0IHlvdeKApi5NT05FWSENCg0KQnVkIFllcmx5DQoNCg0KRnJvbTogb3duZXItZXVy b3BhLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPG93bmVyLWV1cm9wYS1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tPiBPbiBCZWhhbGYgT2YgV2lsbGlhbSBEYW5pZWxsDQpTZW50OiBGcmlkYXks IE1heSAwNSwgMjAyMyAxMDo1MCBBTQ0KVG86IGV1cm9wYS1saXN0QG1hdHJvbmljcy5jb20NClN1 YmplY3Q6IEV1cm9wYS1MaXN0OiBPaWwgLSBSb3RheCAtIFN5bnRoZXRpYyBvciBvdGhlcg0KDQpX aGF0cyBpcyB0aGUgY29uc2Vuc3VzIG9uIHRoZSBiZXN0IG9pbC4NCkkgaGF2ZSB1c2VkIHRoZSBB ZXJvc2hlbGwgc3BvcnQgUExVUyA0IG9pbCB1cCB0byBub3cgbWFpbmx5IGJlY2F1c2UgSSB1c2Vk IEFWR0FTIGluIENvbG9tYmlhLiAgKE1vZ2FzIHdhcyBvZiBkb3VidGZ1bCBxdWFsaXR5LikNCkkg aGF2ZSBzaW5jZSBoZWFyZCB0aGF0IGxvc3Qgb2YgcGVvcGxlIHVzZSBNb2JpbCBTeW50aGV0aWMu DQpBbnkgdGhvdWdodHM/DQpXaWxsaWFtIERhbmllbGwNCkxPTkdQT1JUDQorMSA3ODYgODc4IDAy NDYNCg= ________________________________________________________________________________
Date: May 07, 2023
Getting an oil with enough ZDDP (anti-scuff) is an issue, with this substan ce being now very diminished in any oil that could be used in an engine wit h a catalyst (because the Zinc contaminates the catalyst). Aeroshell SP4 has loads and the new Rotax synthetic oil * is suggestive tha t it does too (in its comment: Not recommended in automotive applications w ith catalytic aftertreatment systems). Sometimes the MSDS will say how much ZDDP is present, other times not. But if the gearbox screeches momentarily on shutdown, chances are your oil does n't have enough. *ROTAX-XPS-Datasheet-A4-2304-RZ.indd (flyrotax.com) https://www.flyrotax.co m/assets/images/ROTAX-XPS-Datasheet-A4-2304-RZ-1.pdf Duncan McF. > On 07 May 2023 at 01:33 Bud Yerly wrote: > > > Will, > > Aeroshell Sport Plus 4 (Aeroshell SP4) is good for either Mogas (AKI 91 or R+M/2) of 91 or 92 and is fine also with 100LL IAW Rotax Service lett ers and experience. > > > > Any other oil must have the proper gearbox additives used in motorcyc les as Area 51 noted also. We used to use Mobile MX4T (now known as Racing 4T Motorcycle oil) which is a motorcycle/ATV oil using additives for gearb oxes bathed in engine oil. Do not use regular Mobile One in a Rotax althou gh many did until after 2011-2012 914-SB-19?? or so when the guidance chan ged due to the gearbox additive not found in Mobile 1 which may have caused some gearbox issues of which the Rotax Gods kept secret and Rotax went har d over for Aeroshell SP4. Primary reason was Aeroshell doesn=99t cha nge their oil without notice as auto oil manufacturers do. If you use TCP and SP4 the lead settles in the tank when the oil cools. As you all know I change oil every 25-30 hours anyway as I believe in routine 25 hour inspec tions and since I use and will continue to use 100LL it keeps the oil can c leaner. You also know I don=99t follow hearsay and do my own researc h (Have internet, will research!). > > > > Miscellaneous Ramblings: > > If using Super Premium Auto Fuel AKI 91 (whatever the local station c alls it) we never had a problem with the Mobile MX4T but there were startin g issues if the gas was old. But even at a higher oil change interval, loo k at the cost difference: > > > > I fly less than most of you, so Aeroshell SP4 is cost effective. SP4 is about $11-15 a quart and MX4T is about $12-15 a quart. Depending on wh ere you buy it. I buy the SP4 a case at a time (12 quarts) for about $135 including shipping, and the 4T is about $86 for 6 quarts plus shipping. Ag ain, depending on where you buy your oil costs change. Since only a few ai rports across the US carry MOGAS of 91 AKI, I can=99t avoid leaded AV Gas use. I stick with the SP4. Do I religiously use the TCP fuel additive ? Well, I try to. If cross country and I need oil and the FBO does not st ock SP4, I use either the Valvoline semi synthetic motorcycle oil or Mobil MX4T to add if my oil level gets low for some reason. > > > > Although some say a full synthetic oil only has to be changed every 1 00 Hrs, I=99m afraid I have not bought into that. Florida is hot, hu mid, and iron gears are prone to rusting. Synthetics are great oils, but I personally am not inclined to be a test case due to our high humidity cond itions and the lack of coating Mobile one seems to have in comparison to st andard oil on the gears when the plane sets for weeks/months. > > > > AVGas is averaging now (on cross country) about $7 (Sebring is $5) an d Premium 92 Octane R+M/2 is about $4/gallon in Tampa. If I fly 25 hours a year how much do I save at 5-6 gal/hr with a 25 hour oil change. (Note I r eally only flew the Europa 10 hours last year.) My gas use would be 137 ga llons and an oil change is about 3 quarts. Avgas/SP4 at 5.5GPH $962+33 for oil =$995 but normally with my discount $688+45=$732 and 91AKI Mogas u se would cost in my area (My FF is 5.8 GPH at 31 inches on Shell Supreme fu el) $582 + 45= $625 and I must now consider I can=99t get reliable MOGAS on cross country at the nice airports, however I still have to worry about bad or old gas that has been setting at the airport and in my airplan e. For me it is not that much of a difference over a years worth of flying but, if you only fly local and fly 300 hours a year, you can save quite a bit. Those folks overseas that can get good super supreme fuel at airfield s and go 50 hours between oil changes can save enough to pay a month =99s hangar fee and or a month=99s worth of insurance so it=99s worth it for those overseas to look for alternatives due to their high fue l costs and oil availability. For me, in the Tampa Florida area, it just i sn=99t worth the stagnant fuel issues since I fly so little and SP4 w orks and is relatively cheap to buy for a specialty oil. As far as auto fu el goes vs 100LL, my particular 914 likes 100LL. It starts really fast. N o worries about kickback on start with that fuel, no matter how old it is. With ethanol laced super MoGas only available here in Tampa, I find that b y using 100LL fuel, my carbs are always clean and have stayed tuned for 4 y ears, the floats don=99t sink and my float bowls look like new. Othe rs in the area are not so lucky that fuel with ethanol gas. > > > > Note, I had Lockwood do a 500 Hr top overhaul of my 914 running 100LL with TCP and SP4 oil and Rotax Filter. The engine was unbelievably clean on the inside. The oil tank holds the lead in suspension like it is suppos ed to. The only thing I find is, in the oil filter there are small chunks of carbon from the turbo. There is a new Service Bulletin on the 914 turbo can which changes the design and adds a filter screen. It may set too clo se to my duct so I doubt I can change it without lowering the duct. I =99ll see how much it costs. I like the design but, I probably will be shocked by the price. To tell you the truth I can=99t wait for the n ew unleaded AVGas either. I bet the AVGas price jumps 30% initially when i t comes out. > > > > So, the choice is yours. Research and do your own math for your flyi ng needs and fuel/oil costs. I wouldn=99t skimp on fluids though. G ood fresh gas, and good oil are a must. Maintenance becomes more of a time change requirement with proper fluids. Do the inspections and time change s and your plane will reward you with only periodic maintenance and leave y ou more money for upgrades. > > > > You all know what keeps an airplane flying don=99t you .MONEY! > > > > Bud Yerly > > > > > > From: owner-europa-list-server(at)matronics.com <owner-europa-list-serve r(at)matronics.com> On Behalf Of William Daniell > Sent: Friday, May 05, 2023 10:50 AM > To: europa-list(at)matronics.com > Subject: Europa-List: Oil - Rotax - Synthetic or other > > > > Whats is the consensus on the best oil. > > I have used the Aeroshell sport PLUS 4 oil up to now mainly because I used AVGAS in Colombia. (Mogas was of doubtful quality.) > > I have since heard that lost of people use Mobil Synthetic. > > Any thoughts? > > William Daniell > > LONGPORT > > +1 786 878 0246 > ________________________________________________________________________________
Date: May 07, 2023
Think some of the AGIP hi performance oils were pegged as suitable but don't quote me on that... goo point on the ZDDP... Anybody have any thoughts on adding colloidal graphite? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510745#510745 ________________________________________________________________________________
Subject: Re: Europa-List Digest: 2 Msgs - 05/07/23
Date: May 08, 2023
I would think graphite could change the friction on the clutch mechanism in the gearbox. Its a bit of a juggling act! > ________________________________ Message 2 _____________________________________ > > > Subject: Europa-List: Re: Oil - Rotax - Synthetic or other > From: "Area-51" <goldsteinindustrial(at)gmail.com> > > > Think some of the AGIP hi performance oils were pegged as suitable but don't quote > me on that... goo point on the ZDDP... Anybody have any thoughts on adding > colloidal graphite? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=510745#510745 > > > > > > > > ________________________________________________________________________________
Date: May 08, 2023
Subject: EPISODE 6: COWL FITTING INFO
Date: May 08, 2023
Hi Group Here's a link to May 2nd ZOOM: EPISODE 6: COWL FITTING INFO: https://1drv.ms/f/s!Ah1S270Nwg9Vgf9TD8as-OSvuC-t9A?e=JaO6R9 For whatever reason, Matronics always cuts off some of the hyper-link when links are posted. Just copy the entire link and paste into URL of browser. Wayne and Ron BTW: Here's a link you can find prior episodes: http://forum.matronics.com/viewtopic.php?t=16779584 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510762#510762 ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: May 09, 2023
Thanks Bud So Ill stick with sp4 William Daniell +1 786 878 0246 On Sun, May 7, 2023, 04:35 Bud Yerly wrote: > Will, > > Aeroshell Sport Plus 4 (Aeroshell SP4) is good for either Mogas (AKI 91 o r > R+M/2) of 91 or 92 and is fine also with 100LL IAW Rotax Service letters > and experience. > > > Any other oil must have the proper gearbox additives used in motorcycles > as Area 51 noted also. We used to use Mobile MX4T (now known as Racing > 4T Motorcycle oil) which is a motorcycle/ATV oil using additives for > gearboxes bathed in engine oil. Do not use regular Mobile One in a Rotax > although many did until after 2011-2012 914-SB-19?? or so when the > guidance changed due to the gearbox additive not found in Mobile 1 which > may have caused some gearbox issues of which the Rotax Gods kept secret a nd > Rotax went hard over for Aeroshell SP4. Primary reason was Aeroshell > doesn=99t change their oil without notice as auto oil manufacturers do. If > you use TCP and SP4 the lead settles in the tank when the oil cools. As > you all know I change oil every 25-30 hours anyway as I believe in routin e 25 > hour inspections and since I use and will continue to use 100LL it keeps > the oil can cleaner. You also know I don=99t follow hearsay and do my own > research (Have internet, will research!). > > > Miscellaneous Ramblings: > > If using Super Premium Auto Fuel AKI 91 (whatever the local station calls > it) we never had a problem with the Mobile MX4T but there were starting > issues if the gas was old. But even at a higher oil change interval, > look at the cost difference: > > > I fly less than most of you, so Aeroshell SP4 is cost effective. SP4 is > about $11-15 a quart and MX4T is about $12-15 a quart. Depending on > where you buy it. I buy the SP4 a case at a time (12 quarts) for about > $135 including shipping, and the 4T is about $86 for 6 quarts plus shippi ng. > Again, depending on where you buy your oil costs change. Since only a > few airports across the US carry MOGAS of 91 AKI, I can=99t avoid l eaded > AVGas use. I stick with the SP4. Do I religiously use the TCP fuel > additive? Well, I try to. If cross country and I need oil and the FBO > does not stock SP4, I use either the Valvoline semi synthetic motorcycle > oil or Mobil MX4T to add if my oil level gets low for some reason. > > > Although some say a full synthetic oil only has to be changed every 100 > Hrs, I=99m afraid I have not bought into that. Florida is hot, hum id, and > iron gears are prone to rusting. Synthetics are great oils, but I > personally am not inclined to be a test case due to our high humidity > conditions and the lack of coating Mobile one seems to have in comparison > to standard oil on the gears when the plane sets for weeks/months. > > > AVGas is averaging now (on cross country) about $7 (Sebring is $5) and > Premium 92 Octane R+M/2 is about $4/gallon in Tampa. If I fly 25 hours a > year how much do I save at 5-6 gal/hr with a 25 hour oil change. (Note I > really only flew the Europa 10 hours last year.) My gas use would be 137 > gallons and an oil change is about 3 quarts. Avgas/SP4 at 5.5GPH $962+33 > for oil =$995 but normally with my discount $688+45=$732 and 91AKI Mo gas > use would cost in my area (My FF is 5.8 GPH at 31 inches on Shell Supreme > fuel) $582 + 45= $625 and I must now consider I can=99t get relia ble MOGAS on > cross country at the nice airports, however I still have to worry about b ad > or old gas that has been setting at the airport and in my airplane. For > me it is not that much of a difference over a years worth of flying but, > if you only fly local and fly 300 hours a year, you can save quite a bit. > Those folks overseas that can get good super supreme fuel at airfields an d > go 50 hours between oil changes can save enough to pay a month=99s hangar fee > and or a month=99s worth of insurance so it=99s worth it for those overseas to > look for alternatives due to their high fuel costs and oil availability. For > me, in the Tampa Florida area, it just isn=99t worth the stagnant f uel issues > since I fly so little and SP4 works and is relatively cheap to buy for a > specialty oil. As far as auto fuel goes vs 100LL, my particular 914 > likes 100LL. It starts really fast. No worries about kickback on start > with that fuel, no matter how old it is. With ethanol laced super MoGas > only available here in Tampa, I find that by using 100LL fuel, my carbs a re > always clean and have stayed tuned for 4 years, the floats don=99t sink and > my float bowls look like new. Others in the area are not so lucky that > fuel with ethanol gas. > > > Note, I had Lockwood do a 500 Hr top overhaul of my 914 running 100LL wit h > TCP and SP4 oil and Rotax Filter. The engine was unbelievably clean on > the inside. The oil tank holds the lead in suspension like it is > supposed to. The only thing I find is, in the oil filter there are small > chunks of carbon from the turbo. There is a new Service Bulletin on the > 914 turbo can which changes the design and adds a filter screen. It may > set too close to my duct so I doubt I can change it without lowering the > duct. I=99ll see how much it costs. I like the design but, I prob ably > will be shocked by the price. To tell you the truth I can=99t wait for the > new unleaded AVGas either. I bet the AVGas price jumps 30% initially > when it comes out. > > > So, the choice is yours. Research and do your own math for your flying > needs and fuel/oil costs. I wouldn=99t skimp on fluids though. Go od fresh > gas, and good oil are a must. Maintenance becomes more of a time change > requirement with proper fluids. Do the inspections and time changes and > your plane will reward you with only periodic maintenance and leave you > more money for upgrades. > > > You all know what keeps an airplane flying don=99t you.MON EY! > > > Bud Yerly > > > *From:* owner-europa-list-server(at)matronics.com < > owner-europa-list-server(at)matronics.com> *On Behalf Of *William Daniell > *Sent:* Friday, May 05, 2023 10:50 AM > *To:* europa-list(at)matronics.com > *Subject:* Europa-List: Oil - Rotax - Synthetic or other > > > Whats is the consensus on the best oil. > > I have used the Aeroshell sport PLUS 4 oil up to now mainly because I use d > AVGAS in Colombia. (Mogas was of doubtful quality.) > > I have since heard that lost of people use Mobil Synthetic. > > Any thoughts? > > William Daniell > > LONGPORT > > +1 786 878 0246 > ________________________________________________________________________________
Subject: Re: Solved: PV50 lead screw bearing
Date: May 09, 2023
Here are the replacement miroswitches I used to replace the old ones on my prop. https://uk.rs-online.com/web/p/micro-switches/6866840 These are the diodes I used https://uk.rs-online.com/web/p/schottky-diodes-rectifiers/7484975. This is the part number of the motor with out the gearbox P/N 2224U006SR. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=510764#510764 ________________________________________________________________________________
Subject: Re: The Obsidian File - Mono Wheel Fairing
Date: May 09, 2023
Area-51, i follow your posts with great interest - thanks for posting all this in images we can all visualise. A question that you might know some answers to: do you have any drag data that relates to EACH of the individual speed kit fairings, please? The reason i ask is that i took the view when fitting my Mono speed kit fairings, that the inboard and mid-flap brackets would not benefit from fairings - on the basis that they would increase frontal area whereas the brackets as they
February 15, 2023 - May 10, 2023
Europa-Archive.digest.vol-ot
