Europa-Archive.digest.vol-ow
March 11, 2024 - Present
      I wrote a program in Python 3 to read the iLevil data and store the pressure
      alt as a variable. Then the program converts that to Icarus format (ALT 12345r)
      and sends it to the GTX327.
      Also, the iLevil3 (with the GPS upgrade) works with the EchoUAT as a GPS source.
      Right now I'm trying to determine the protocol the EchoUAT uses to populate
      the pressure altitude over RS232 on COM1. I'm guessing it's GLD90, but not sure
      of the message ID or framing.
      Other thoughts are with being able to 'export' the live data from the iLevil3,
      you can run other instruments like a digital display for ground speed, etc.  I
      hope this is helpful for someone. Please message/email me if you have any questions.
      In this photo from left to right, first is the ground (connected to both sender
      and receiver), the middle is the TX to the GTX327, left is the RX from the iLevil3.
      Here, you can observe the pressure altitude at 515 feet. I've observed that on
      the GTX327, the output is also in Icarus format, rounded, but I'm not certain
      about the resolution without conducting further testing. I can readily adjust
      the program to match this format, but currently, it's reflecting the resolution
      that the iLevil is transmitting (1 foot).
      Kyle
      Europa Tri-gear (under construction)
      http://forums.matronics.com/viewtopic.php?p=513375#513375
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Mar 11, 2024
Subject: Ridiculous mods
Whenever I work on my plane I worry about sticking something pointy through my dynon screen. I tried taping and it never really sticks. In a moment of inspiration I added two thin shock cords to my panel. This lowered my stress and consequently made me disproportionately happy. Will William Daniell LONGPORT +1 786 878 0246 ________________________________________________________________________________
Subject: Re: Ridiculous mods
Date: Mar 11, 2024
What's ridiculous about that?! Only thing missing is the red "remove before flying" tag... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513377#513377 ________________________________________________________________________________
Date: Mar 11, 2024
Good one! William Daniell +1 786 878 0246 On Mon, Mar 11, 2024, 22:39 Area-51 wrote: > goldsteinindustrial(at)gmail.com> > > What's ridiculous about that?! > > Only thing missing is the red "remove before flying" tag... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513377#513377 > > ________________________________________________________________________________
Subject: Re: iLevil send RS232 Icarus to GTX327
Date: Mar 14, 2024
No its a Raspberry Pi Pico that you can get for around $6.00. I installed micro python on it, and saved the code to the file system. The only investment is the pico, 5v power source, and a few wires. -------- Kyle Europa Tri-gear (under construction) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513385#513385 ________________________________________________________________________________
Subject: Tri-gear Mod
Date: Mar 17, 2024
Im expecting the tri-gear shortly from Europa and preparing for the installation. Im in California and looking for a dolly setup to support the fuselage while converting. Ive seen Buds dolly setup and appears to work well. Any suggestions? Just trying to avoid having to reinvent the wheel. -------- N951EU - Tri-gear & 912ULS, N77EU- Mono & 914 I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513386#513386 ________________________________________________________________________________
Subject: Trailing edge elevator deflection issue
Date: Mar 18, 2024
Hello intrepid flyers, An inspection recently showed that the trailing edge deflection on my Europa XS was not to spec. We adjusted the rod-ends at the end of the pitch tube but we only managed to get 12 deg up and 3 deg down (total of 15 deg overall deflection). Any further adjustments would either provide an increase in the up direction with a corresponding reduction in the down direction - maintaining the 15 degree overall deflection. Mass balance weight does not touch its limits and the anti-servo T-Bar is free and does not hit the fusalage. Can some wise builder advise the method used to increase the full deflection range - Id like to get about 16 to 18 degrees if possible. Many thanks to all Tony -------- Tony Vaccarella Mascot NSW 2020 Sydney Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513387#513387 ________________________________________________________________________________
Date: Mar 18, 2024
Subject: Re: Trailing edge elevator deflection issue
Check that all other linkages in the elevator system are working at maximum gearage, i.e. the geometry of all other pushrods and horns are at right angles when at the middle of their range. If too oblique, there will be loss of range. Duncan McF. > On 18/03/2024 12:46 tonyvaccarella wrote: > > > > Hello intrepid flyers, > > An inspection recently showed that the trailing edge deflection on my Europa XS was not to spec. We adjusted the rod-ends at the end of the pitch tube but we only managed to get 12 deg up and 3 deg down (total of 15 deg overall deflection). Any further adjustments would either provide an increase in the up direction with a corresponding reduction in the down direction - maintaining the 15 degree overall deflection. > > Mass balance weight does not touch its limits and the anti-servo T-Bar is free and does not hit the fusalage. > > Can some wise builder advise the method used to increase the full deflection range - Id like to get about 16 to 18 degrees if possible. > > Many thanks to all > > Tony > > -------- > Tony Vaccarella > Mascot NSW 2020 > Sydney Australia > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513387#513387 > > > > > > ________________________________________________________________________________
Date: Mar 18, 2024
Tony, If our stab mechanism is hitting the mechanical mass balance limits at the mass balance arm and you are sure the pitch tube MW bearings are clear on t he pitch torque tube (CS10) in the wing center and there is not mechanical binding there, look at the following: It is quite easy technically to adjust the incidence of the stabilator by c hanging the stabilator balance weight upper and lower mass balance stops. Hopefully you have done the Mod 70, but even if you haven't, it's straight forward. (Mod 70 and or the cable sway supports with original TP18 fitting s can still can be adjusted easily). You are essentially looking to have +13,-5 or a minimum of +12,-4 degrees o f trailing edge travel so 16-18 degrees total from full up to down. Simply carve the upper and lower slots to get the total travel plus the bum p stop rubber and reinstall the bump stop rubbers and recheck. I have an archived a document somewhere, but the main issue is the uncomfor table access if the viewing/inspection plates are small. I see this all the time on prebuy inspections and it can be an 2-8 hour exe rcise but it is worth it to get the stab incidence right. The amount to actually relieve the current stops starts with measurement of course. I personally pull off the installed upper rubber stop (as many builders fai l to adjust for the bump stop thickness) on the top and sometimes the botto m to make my adjustment but always measure and look first. In some cases a large upper stop has been made that has about 20mm between the wood cutout and the fuselage inside top surface. Remove the rubber bump and Demel out the arc to suit your stab throw needs to increase the TE down (mass balanc e hitting the top stop). Some have the upper mass balance stop nearly at th e upper skin so you have the lower limit to move only. In your case with o nly needing a degree, pull the top rubber stop off and see if you can relie ve that a bit, then reinstall your rubber bumper and install a stick betwee n the lower stop and the weight to hold the stop firmly until it dries. To make it pretty, get the arc set by using a thin metal strip bent to a plea sing arc while holding the mass balance firmly to the stop limit. If you have a nose down of -4 degrees and just need a bit on the up stop li mit, the rubber bolted wood dowel normally can be changed. This can be cha nged by simply moving the lower stop down a bit (filling and redrilling) or if clearances are an issue with the stab push pull tube, 3D printing a sma ller cylinder or by center drilling a smaller wood dowel and fitting a rubb er hose sized properly to get more trailing edge up to suite your throw nee ds. Once the total throw is as you desire (normally 17 degrees (+13,-4)) but yo u cut or modified both the upper and lower stops, there is little chance th at the new top and bottom stops are perfect, so one must remove the stabs ( for ease of access) and "simply" remove the TP18 adjustment body bolts and adjust the mass balance arm and reassemble as necessary to get the stab mec hanical stops up front to clear nicely. That is time and patience consumin g to get the desired +13 to -5 hence, 17 degrees may be a better option. A nd this is where the time and patience grows thin. Suck it up and make a p in to replace the bolt to make adjustments of the TP18C easier. Then reins tall the bolt while forcing the pin you made and bolt it up. Carefully and patiently readjust the full down limit to -4 degrees to -5 degrees so the pitch tube doesn't bind on the torque tube (full forward stick also not hit ting the panel). If the controls were built per the manual, you now should only have the trailing edge up or stick aft issue to get adjusted. Again, if the torque tube arms in the center tunnel don't hit the limit at the ro ll tube arm CS08. If you have issues with the original build in this clear ance, much adjusting will be necessary to allow the stick movement, pushrod s, arms and torque tube to work properly. Then you have the issues of push rod adjustment and perhaps even stab push tube lengthening to contend with . I've done them all and it can try ones patience but it is worth it in th e end. To be honest, if you have a weight and balance near 60 per the manual, +12- 4 stab travel is quite acceptable. If it is a nose heavy or tail heavy bea st, then go for full travel. If you notice the left and right stab incidence is noticeably different the n a bit of extra work will make all that work out also, see pdf attached. Whatever you do, the mechanical bolts and metal fittings can't bind at the cockpit module linkages. If you can adjust only one stop, life is good. If you must adjust both, and then find the limit is with the pitch tube hit ting the mechanical limits. Life will suck a bit. Then we must adjust the stick travel and limits to just clear and then go back to the stab stop li mits and continue aft until all is well. I've only had two cups of coffee, so email back if you need more clarificat ion Tony. Best Regards, Bud Yerly ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of tonyvaccarella Sent: Monday, March 18, 2024 8:46 AM Subject: Europa-List: Trailing edge elevator deflection issue Hello intrepid flyers, An inspection recently showed that the trailing edge deflection on my Europ a XS was not to spec. We adjusted the rod-ends at the end of the pitch tube but we only managed to get 12 deg up and 3 deg down (total of 15 deg overa ll deflection). Any further adjustments would either provide an increase in the up direction with a corresponding reduction in the down direction - ma intaining the 15 degree overall deflection. Mass balance weight does not touch its limits and the anti-servo T-Bar is f ree and does not hit the fusalage. Can some wise builder advise the method used to increase the full deflectio n range - Id like to get about 16 to 18 degrees if possible. Many thanks to all Tony -------- Tony Vaccarella Mascot NSW 2020 Sydney Australia Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D513387%23513387&data=05%7C02%7C%7C05c71 51b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63 8463629861228628%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMz IiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=u5uWqVQ6h9Af7d3XGhj%2 FikYeo3DeEtk289vdqBST%2BAk%3D&reserved=0<http://forums.matronics.com/view topic.php?p=513387#513387> %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C02%7C%7C05c7151b 7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63846 3629861242995%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=3CJg7INhDjFzwZ%2BCP6pbSs XTx4GhjEZEV7V2emOhgf0%3D&reserved=0<http://www.matronics.com/Navigator?Eu ropa-List> %2Fforums.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749 e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861255912%7CUnkn own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C0%7C%7C%7C&sdata=eDLD%2BWCNhAxoZTkDWMCqgdBjco5EqjeTqKEvzRyrGz A%3D&reserved=0<http://forums.matronics.com/> %2Fwiki.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4aea210008dc4749e0 ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861267765%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C0%7C%7C%7C&sdata=G%2Bo9ZUKTY3lKMBSYkHIM4xsg2HIE1V2G0E70SO98Yik% 3D&reserved=0<http://wiki.matronics.com/> F%2Fmatronics.com%2Fcontribution&data=05%7C02%7C%7C05c7151b7fcf4aea210008 dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861278512% 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=I6T5XrhwaGi1DmFH5zCDgm8uguHrKNvAWOEITN Qx3wk%3D&reserved=0 ________________________________________________________________________________
Date: Mar 18, 2024
Hi Bud, As always - a very informative reply. As it stands now - the mass balance arm top or bottom dont come anywhere ne ar the stops - so thats not the issue - what else can I look at? What I dont understand is that I originally check this before first flight an we were getting bout 14 deg up and on rechecking this weekend I barely g ot 9 deg up. Its got me scratching my head. Regards, Tony =C2- =C2- Tony, If our stab mechanism is hitting the mechanical mass balance limits at the mass balance arm and you are sure the pitch tube MW bearings are clear on t he pitch torque tube (CS10) in the wing center and there is not mechanical binding there, look at the following: =C2- It is quite easy technically to adjust the incidence of the stabilator by c hanging the stabilator balance weight upper and lower mass balance stops. =C2- Hopefully you have done the Mod 70, but even if you haven't, it's straight forward.=C2- (Mod 70 and or the cable sway supports with original TP18 fi ttings can still can be adjusted easily). =C2- You are essentially looking to have +13,-5 or a minimum of +12,-4 degrees o f trailing edge travel so 16-18 degrees total from full up to down. Simply carve the upper and lower slots to get the total travel plus the bum p stop rubber and reinstall the bump stop rubbers and recheck. =C2- I have an archived a document somewhere, but the main issue is the uncomfor table access if the viewing/inspection plates are small. =C2- I see this all the time on prebuy inspections and it can be an 2-8 hour exe rcise but it is worth it to get the stab incidence right. The amount to actually relieve the current stops starts with measurement of course. =C2- I personally pull off the installed upper rubber stop (as many builders fai l to adjust for the bump stop thickness) on the top and sometimes the botto m to make my adjustment but always measure and look first.=C2- In some ca ses a large upper stop has been made that has about 20mm between the wood c utout and the fuselage inside top surface.=C2- Remove the rubber bump and Demel out the arc to suit your stab throw needs to increase the TE down (m ass balance hitting the top stop). Some have the upper mass balance stop ne arly at the upper skin so you have the lower limit to move only.=C2- In y our case with only needing a degree, pull the top rubber stop off and see i f you can relieve that a bit, then reinstall your rubber bumper and install a stick between the lower stop and the weight to hold the stop firmly unti l it dries.=C2- To make it pretty, get the arc set by using a thin metal strip bent to a pleasing arc while holding the mass balance firmly to the s top limit. =C2- If you have a nose down of -4 degrees and just need a bit on the up stop li mit, the rubber bolted wood dowel normally can be changed.=C2- This can b e changed by simply moving the lower stop down a bit (filling and redrillin g) or if clearances are an issue with the stab push pull tube, 3D printing a smaller cylinder or by center drilling a smaller wood dowel and fitting a rubber hose sized properly to get more trailing edge up to suite your thro w needs.=C2- =C2- Once the total throw is as you desire (normally 17 degrees (+13,-4)) but yo u cut or modified both the upper and lower stops, there is little chance th at the new top and bottom stops are perfect, so one must remove the stabs ( for ease of access) and "simply" remove the TP18 adjustment body bolts and adjust the mass balance arm and reassemble as necessary to get the stab mec hanical stops up front to clear nicely.=C2- That is time and patience con suming to get the desired +13 to -5 hence, 17 degrees may be a better optio n.=C2- And this is where the time and patience grows thin.=C2- Suck it up and make a pin to replace the bolt to make adjustments of the TP18C easi er.=C2- Then reinstall the bolt while forcing the pin you made and bolt i t up.=C2- Carefully and patiently readjust the full down limit to -4 degr ees to -5 degrees so the pitch tube doesn't bind on the torque tube (full f orward stick also not hitting the panel).=C2- If the controls were built per the manual, you now should only have the trailing edge up or stick aft issue to get adjusted.=C2- Again, if the torque tube arms in the center t unnel don't hit the limit at the roll tube arm CS08.=C2- If you have issu es with the original build in this clearance, much adjusting will be necess ary to allow the stick movement, pushrods, arms and torque tube to work pro perly.=C2- Then you have the issues of push rod adjustment and perhaps ev en stab push tube lengthening to contend with.=C2- I've done them all and it can try ones patience but it is worth it in the end. =C2- To be honest, if you have a weight and balance near 60 per the manual, +12- 4 stab travel is quite acceptable.=C2- If it is a nose heavy or tail heav y beast, then go for full travel. =C2- If you notice the left and right stab incidence is noticeably different the n a bit of extra work will make all that work out also, see pdf attached. =C2- Whatever you do, the mechanical bolts and metal fittings can't bind at the cockpit module linkages.=C2- =C2-If you can adjust only one stop, life is good.=C2- If you must adjust both, and then find the limit is with the pitch tube hitting the mechanical limits.=C2- Life will suck a bit.=C2 - Then we must adjust the stick travel and limits to just clear and then go back to the stab stop limits and continue aft until all is well. =C2- I've only had two cups of coffee, so email back if you need more clarificat ion Tony. =C2- Best Regards, Bud Yerly =C2- =C2- From:=C2-owner-europa-list-server(at)matronics.com on behalf of tonyvaccarella Sent:=C2-Monday, March 18, 2024 8:46 AM To:=C2-europa-list(at)matronics.com Subject:=C2-Europa-List: Trailing edge elevator deflection issue =C2- Hello intrepid flyers, An inspection recently showed that the trailing edge deflection on my Europ a XS was not to spec. We adjusted the rod-ends at the end of the pitch tube but we only managed to get 12 deg up and 3 deg down (total of 15 deg overa ll deflection). Any further adjustments would either provide an increase in the up direction with a corresponding reduction in the down direction - ma intaining the 15 degree overall deflection. Mass balance weight does not touch its limits and the anti-servo T-Bar is f ree and does not hit the fusalage. Can some wise builder advise the method used to increase the full deflectio n range - Id like to get about 16 to 18 degrees if possible. Many thanks to all Tony -------- Tony Vaccarella Mascot NSW 2020 Sydney Australia Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D513387%23513387&data=05%7C02%7C%7C05c71 51b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63 8463629861228628%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMz IiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=u5uWqVQ6h9Af7d3XGhj%2 FikYeo3DeEtk289vdqBST%2BAk%3D&reserved=0 st Email Forum - =http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C02% 7C%7C05c7151b7fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C 1%7C0%7C638463629861242995%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQ IjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=3CJg7INhDjF zwZ%2BCP6pbSsXTx4GhjEZEV7V2emOhgf0%3D&reserved=0 -=C2-=C2- - MATRONICS WEB FORUMS - =http%3A%2F%2Fforums.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4ae a210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463629861 255912%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6 Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=eDLD%2BWCNhAxoZTkDWMCqgdBjco5Eq jeTqKEvzRyrGzA%3D&reserved=0 -=C2- - NEW MATRONICS LIST WIKI - =http%3A%2F%2Fwiki.matronics.com%2F&data=05%7C02%7C%7C05c7151b7fcf4aea2 10008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63846362986126 7765%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik 1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=G%2Bo9ZUKTY3lKMBSYkHIM4xsg2HIE1V2 G0E70SO98Yik%3D&reserved=0 - - List Contribution Web Site - -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2- -Matt Dralle, List Admin. =https%3A%2F%2Fmatronics.com%2Fcontribution&data=05%7C02%7C%7C05c7151b7 fcf4aea210008dc4749e0ea%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638463 629861278512%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLC JBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=I6T5XrhwaGi1DmFH5zCDgm8ug uHrKNvAWOEITNQx3wk%3D&reserved=0 =C2- ________________________________________________________________________________
Date: Mar 19, 2024
If the mass balance is contacting one stop and not the other that would indicate something in the control circuit has slipped. If the mass balance is not making contact with either stop then that would indicate component binding somewhere in the control circuit. Removing the stabilators and then retest from control stick end is one diagnostic. Removing pins at the base of the cockpit control sticks and retest movement from stabilator end is another diagnostic. Remaining control circuit isolation point is at the forward control tube joint in the spar void. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513393#513393 ________________________________________________________________________________
Date: Mar 19, 2024
I=99m referring to XS=C2-build manual on page 13-13. But remember, the diagram is upside from what you are looking at inside the fuselage. If you happen to take the wings off, look into =C2-fuselage on the starboard side=C2-at the CS10 pitch torque tube where the CS08 aileron crank comes close to it when the control stick is hard left. On mine, I actually have a small nick in the paint on the pitch torque tube from the aileron crank c ontacts it. The port side crank comes really close when hard right but no n ick yet. Are yours coming this close? If not, something is keeping the CS05 torque tube is not rotating sufficiently.Were the two CS08 cranks parallel to each other once the cross-link rod (fig12 pg 13-9) was attached?I would next check CS02 the=C2-control stick fork for interferences.=C2-Good l uck.=C2- Mike Duane N377EAEuropa XS Conventional GearChandler, AZ Sent from the all new AOL app for iOS On Tuesday, March 19, 2024, 04:29, Area-51 wrote: > If the mass balance is contacting one stop and not the other that would ind icate something in the control circuit has slipped. If the mass balance is not making contact with either stop then that would indicate component bind ing somewhere in the control circuit. Removing the stabilators and then retest from control stick end is one diag nostic. Removing pins at the base of the cockpit control sticks and retest movement from stabilator end is another diagnostic. Remaining control circuit isolation point is at the forward control tube jo int in the spar void. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513393#513393 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: Tri-gear Mod
Date: Mar 21, 2024
Sam, Lyle Antieau has Bud's fixture now in Michigan. You could ask him for photos. Paul McAllister is in the midst of converting his mono. I've seen his setup but don't recall the details. You might want to contact either or both of them. They are both in the NA Europa Contact List. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513403#513403 ________________________________________________________________________________
Subject: Solar Eclipse Fly In
Date: Mar 26, 2024
Larry Boggs is inviting Europa enthusiasts to join him and his hangar mates at Shelbyville, IN, KGEZ to view the eclipse on April 8. Shelbyville is in the There will be 4 minutes of totality. Larry says this is a very informal gathering. Bring your own lunch. The hangar will be open but no food offerings. Arrive Monday morning and depart late afternoon. The FAA has issued a Domestic Notice (https://www.faa.gov/air_traffic/publications/domesticnotices/dom24008_gen.html) about the eclipse pointing out that air traffic may be high and some services not available. Please plan accordingly. Be sure to bring sunglasses rated for this event. There are apparently replicas being sold that are not safe. Today, (3/26) Accu Weather is predicting patchy clouds and 68 F. Hope the forecast holds! See you there! Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513411#513411 ________________________________________________________________________________
Subject: Fly-In, Columbia, CA June 1,2
Date: Mar 26, 2024
Europa Fly-In / Drive In June 1,2 (Sat, Sun) Columbia, CA KO22 Thorsten Schilling has arranged this fly-in. It is an opportunity to meet up on the West Coast. The airport has a campground with showers. Airport information is available at https://www.airnav.com/airport/O22 or at https://airfield.guide/filter_airports.asp? Airfield Guide has photos of the campgrounds as well as an aerial view. Great reviews on AirNav. Located in the heart of the California Mother Lode, Columbia is a living gold rush town featuring the largest collection of existing gold rush-era structures in California. Visiting is like traveling back in time to the sights, smells and sounds of a nineteenth century mining town. Its only a 10 minute walk from the airport with restaurants and hotels if you dont wish to camp by your plane. There is no formal agenda, just a casual meet up. Fly or drive and share experiences, look at Europas, add some Passport points and enjoy the town! Europa expert Kim Prout resides in Columbia and is planning to attend. Hope you can join Thorsten. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513413#513413 ________________________________________________________________________________
Date: Mar 26, 2024
Subject: Ts 06 bushing
I have a little play in my trim tab ..one of the ts06 bushes is slightly worn. Does anyone have a source of these other than europa? (Its not the hinges) I am wondering if one of the plastic bushings from mcmaster carr...like https://www.mcmaster.com/product/6362K204 would work. Thoughts anyone? William Daniell +1 786 878 0246 ________________________________________________________________________________
Subject: Re: Ts 06 bushing
Date: Mar 27, 2024
William, Sure, if you can find one that fits well, it=99s worth a try. Let us know how it goes. Blue skies and tailwinds, Bob Borger Europa XS Tri, ROTAX 914, Airmaster C/S Prop Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop 2705 Lynchburg Dr Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com Sent from my iPad > On Mar 26, 2024, at 21:13, William Daniell w rote: > > =EF=BB > I have a little play in my trim tab ..one of the ts06 bushes is slightly w orn. Does anyone have a source of these other than europa? > (Its not the hinges) > I am wondering if one of the plastic bushings from mcmaster carr...like ht tps://www.mcmaster.com/product/6362K204 would work. > Thoughts anyone? > > William Daniell > +1 786 878 0246 ________________________________________________________________________________
Date: Mar 28, 2024
If you had the stock dimensions you could have them turned up in Delrin perhaps. Just a thought; not sure what material the factory originals are... mine are a bit sloppy and rattle a bit at certain attitudes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513425#513425 ________________________________________________________________________________
Date: Mar 28, 2024
Can anyone tell me the thickness of the tube into which the ts06 goes?. The od is 1/2" Thanks Will William Daniell +1 786 878 0246 On Thu, Mar 28, 2024, 03:13 Area-51 wrote: > goldsteinindustrial(at)gmail.com> > > If you had the stock dimensions you could have them turned up in Delrin > perhaps. Just a thought; not sure what material the factory originals > are... mine are a bit sloppy and rattle a bit at certain attitudes. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513425#513425 > > ________________________________________________________________________________
Date: Mar 28, 2024
Good to know... I only noticed it because i put some welding rods into the hinges which took up the hinge play. Its maybe 1/16 at the end of the trim tab Thanksa William Daniell +1 786 878 0246 On Thu, Mar 28, 2024, 03:13 Area-51 wrote: > goldsteinindustrial(at)gmail.com> > > If you had the stock dimensions you could have them turned up in Delrin > perhaps. Just a thought; not sure what material the factory originals > are... mine are a bit sloppy and rattle a bit at certain attitudes. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513425#513425 > > ________________________________________________________________________________
Subject: Glass fiber deformation at fuselage
Date: Apr 01, 2024
Hello to everybody Would be great if someone could help me with my issue: Ive got some deforming on my Europa XS Monowheel of the glass fiber at 4 positions on my fuselage, due to an inappropriate cover which got to hot from the sunshine. I guess it tempered the glass fiber. The positions are on both sides directly behind the doors and on top between the doors next to the fixations of the doors. Attached are two pictures of the biggest deformation. So my question is, whether this is an structural damage which I should repair or its still good to fly? In case its a damage, how should I repair this? With which temperature was the glass fiber pre-tempered? Does someone has a datasheet of this glass fiber? Many thanks for your help Best regards, Marcel -------- _____________________________________ Marcel Bodmer Europa XS Monowheel HB-YNK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513437#513437 Attachments: http://forums.matronics.com//files/img_6646_128.jpg ________________________________________________________________________________
Date: Apr 01, 2024
Subject: Re: Glass fiber deformation at fuselage
This appears to be related to an expansion issue between the outer fuselag e and the interior cobra used for fueling. I would look at the bonding on t he inside between the cobra and the fuselage to see if there might have bee n a difference in the expansion rate or amount that could have caused this buckling.=C2-If there is a blob of adhesive or other bonding material dir ectly behind the buckling, you might think about removing this material, sl owly rewarming the fuselage from the inside, and having a smooth contouring backing against the outside at the buckling point to see if you could pres s the warmed fiberglass back into it's original shape.I do not believe it's a structural issue that would cease any flying.=C2-But that is MY 2 cent s and it's only worth the paper it's written on. Mike Duane N377EAEuropa XS Conventional GearChandler, AZ (it's gets really hot here)=C2- com> wrote: Hello to everybody Would be great if someone could help me with my issue: I=C3=A2=82=AC=84=A2ve got some deforming on my Europa XS Monowheel of the glass fiber at 4 positions on my fuselage, due to an inappropriate cov er which got to hot from the sunshine. I guess it tempered the glass fiber. The positions are on both sides directly behind the doors and on top betwe en the doors next to the fixations of the doors. Attached are two pictures of the biggest deformation. So my question is, whether this is an structural damage which I should repa ir or its still good to fly? In case it=C3=A2=82=AC=84=A2s a damage, how should I repair this? With which temperature was the glass fiber pre-tempered? Does someone has a datasheet of this glass fiber? Many thanks for your help Best regards, Marcel -------- _____________________________________ Marcel Bodmer Europa XS Monowheel HB-YNK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513437#513437 Attachments: http://forums.matronics.com//files/img_6646_128.jpg S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 01, 2024
As far as I know, the fuselage shell consists of an outer and an inner fiberglass skin, with a layer of foam about 3mm thick between the two skins. I recall when fitting the door shoot bolt stops modification, that it was necessary to drill right through both skins for the bolt holes and then to pick out the foam surrounding the holes from between the skins. So unless the inner fuselage skin is also affected by excess heat, my guess is that any repair would only be needed to the outer skin. The repair would need to be done by somebody with suitable expertise. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513439#513439 ________________________________________________________________________________
Date: Apr 02, 2024
Hi Marcel, I had the same problem many years ago, but only to the fuel intake side belo w the fuel cap. This was due to the fuel inside =98Cobra=99 bein g attached to the inner skin of the fuselage and contracting and expanding a t a different rate with heat (hot day) where the attachments were placed. I r emoved the cobra and laid up the inside with a number of BID fibreglass laye rs over a large area around the cobra path, to strengthen it. Also made sure there was a gap between the Cobra and inner wall to allow for the contract ing and expanding, then reattached the Cobra. I did not bother to fill the outside deformation and repaint as it was hardl y noticeable and a repaint would be more noticeable, and another job. With regard to your other areas, there maybe a similar attachment installed f or items which has caused the two fuselage thin sandwich walls to deform? Cheers, Tim Sent from my iPad Tim Ward 12 Waiwetu Street, Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz 021 0640221 > On 2/04/2024, at 2:29=AFAM, HB-YNK wrote: > m> > > Hello to everybody > Would be great if someone could help me with my issue: > > I=99ve got some deforming on my Europa XS Monowheel of the glass fib er at 4 positions on my fuselage, due to an inappropriate cover which got to hot from the sunshine. I guess it tempered the glass fiber. The positions a re on both sides directly behind the doors and on top between the doors next to the fixations of the doors. Attached are two pictures of the biggest def ormation. > So my question is, whether this is an structural damage which I should rep air or its still good to fly? > In case it=99s a damage, how should I repair this? > With which temperature was the glass fiber pre-tempered? > Does someone has a datasheet of this glass fiber? > > Many thanks for your help > Best regards, > Marcel > > -------- > _____________________________________ > Marcel Bodmer > > Europa XS Monowheel > HB-YNK > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513437#513437 > > > > > Attachments: > > http://forums.matronics.com//files/img_6646_128.jpg > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Subject: Re: Baggage area tie downs
Date: Apr 02, 2024
I have four u bolts at each corner of the baggage bay. They are bolted to hard points made by floxing a ply layer under the bay floor.. You can get a cargo net from any motorcycle dealer as the are used to tie luggage to a bike. Alan Sent from my iPad > On 9 Mar 2024, at 13:01, JonathanMilbank wrote: > > > I use a smallish net which came with my Skoda car i.e. a VW made in the Czech Republic, with four hooks, one at each corner. The anchor points for each hook are medium / small cable tie wraps. > > Four small holes, similar diameter to the width of the tie wraps, are drilled through the baggage bay bulkhead at about the same level as the "headrests" and through each "headrest". A cable tie is passed through each hole from the opposite side to where the net hook will attach and then pushed back through the same hole. Each cable tie then gets zipped, leaving four loops as anchors on the headrests and rear bulkhead. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513369#513369 > > > > > > > > > ________________________________________________________________________________
Date: Apr 05, 2024
Hi Marcel I believe this is a fairly common problem if the fuselage has been parked in strong sunlight and got hot. If you are a Europa Club member, there is an article in the Europa Flyer No 68 that describes the problem and the fix. The skin can be restored by warming and re-shaping and reinforcement can be added on the inside. -------- Regards Kelv Weston Kit 497 kelv(at)kdweston.co.uk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513447#513447 Attachments: http://forums.matronics.com//files/1_fuel_filler_107.jpg ________________________________________________________________________________
Subject: 914 Airbox Support
Date: Apr 06, 2024
Hi Everyone, I am refurbishing an XS 914 installation & am mildly concerned that the Rotax airbox/plenum seems to be only supported by the carb mount rubbers. During a heavy landing there must be a lot of stress there! On the 912S installation Europa support their lighter airbox with an aluminium strap to the engine frame. Has anybody added such a support to their 914? Grateful for any feedback from 914 operators. Best regards, Roger ________________________________________________________________________________
Subject: Re: 914 Airbox Support
Date: Apr 06, 2024
The 914 plenum is supported by the compressor transfer pipe and a center stud mount between plenum and ring mount frame. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513450#513450 Attachments: http://forums.matronics.com//files/895eb43c_9f30_4f96_babf_4b94458a51ea_585.jpeg ________________________________________________________________________________
Date: Apr 06, 2024
Thanks A51, I missed that stud. > On 6 Apr 2024, at 14:50, Area-51 wrote: > > > The 914 plenum is supported by the compressor transfer pipe and a center stud mount between plenum and ring mount frame. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513450#513450 > > > > > Attachments: > > http://forums.matronics.com//files/895eb43c_9f30_4f96_babf_4b94458a51ea_585.jpeg > > > > > > ________________________________________________________________________________
Date: Apr 06, 2024
Depending on the year of manufacture you may have no airbox support in the center to the engine mount. I have a 1998 914 and it's airbox was supported only by the carb's and turbo hose, later I bought a second hand 2006 version of the airbox from Rotec in Vernon BC, Canada and it came with the center support to engine mount. This later airbox also requires smaller jetting for the carbs, 2/4 carb goes from #64 down to #58 Jet & 1/3 carb from 160 to #56 Jet. So many little changes on the Rotax 914 over the first 10 years they were on the market, it's unlikely most people update these parts since they are so expensive but if you are friendly with your Rotax dealer often they get engines back on trade in and they can sell you the new style parts for a fair price...get them to make you a deal they can be flexible on price for used parts. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513452#513452 ________________________________________________________________________________
Date: Apr 06, 2024
Some miscellaneous ramblings on the airbox. As stated, your engine airbox depends on the year group. My 1998 timeframe engine also has no brace. The only time a brace is nice on the non braced airbox mod (done sometime around 2010), is when using a t hin silicone turbo discharge hose connected to the airbox. (The heavy doub le or triple braided black hose supplied by Rotax on the old engines was qu ite stiff and combined with the carb sockets at the manifold and hose clamp s kept the airbox on securely (nearly all the time with balanced carbs.) T he issue with the airbox in the old days was it kept sliding off the port c arb due to oil accumulation. If you flew often, the oil thrown out of the turbo was but a wisp and if the engine was well tuned it stayed put. If yo u didn't fly often and the 2-inch hose became oil soaked, then the plenum h ose to carb would slide off (especially at full boost) and if the carbs wer e not well synchronized (read as "shaky engine") it slid off fairly often j ust when you didn't want it to. I found the used 914 I bought had carbs tha t were no longer a matched set any more due to some wear in the piston thro at, as the pistons were well out of sync. I bought two new matched carbs a nd with that carb change, proper tuning, and cleaning my airbox to carb rub bers, all stayed where put and the engine ran flawless now for 10 years. E ven after I upgraded the TCU to give me 40 inches takeoff power it stayed p ut. If equipped with old oil soaked hoses or a thin silicone discharge hose, or you left your carb to airbox hoses get really oil soaked, it is prudent to clean your airbox to carb rubber hose with acetone or similar solvent to m ake them squeaky clean (or replace them). (Washing your intake plenum out h elps also.) To assist in security of a shaky engine, a couple of padded hos e clamps and a piece of sheet metal could hold the airbox firmly to the rin g mount to prevent slipping. Also, a couple of Adel Clamps and a piece of tube and bolts could work also on the older manifold without welding on a b ung like the new airbox has. In a pinch, a piece of safety wire on the por t side to the ring mount frame at the upper block bolt was also OK at preve nting the plenum from slipping aft but only temporarily. A nicely made pie ce of .040 aluminum with a bit of a bevel for stiffness on the edges or a f lute down the middle and nicely formed ends could in fact hold the box firm ly in place and at the same time keep it from sliding off. To remove the c arbs for cleaning, or to flush the accumulation of turbo oil out of the ple num after setting a long time, it only required removing the bolt between t he Adels the two carb clamps and it was free. Once I had perfectly synchronized carb pistons and flew more often, I never again had an issue. Someplace in the shop I still have my Adel Clamps, a long bolt and tube just in case because I wondered about this new silicone turbo hose I added this year and it's contribution to airbox security. Tod ay my plane has sat for two years due to a wing delam repair and repaint, a number of upgrades and some other issues my old Classic has, however, toda y my procedure is to suck the oil out of the turbo cold side before start i f it has sat (for months) and it seems to run very well. I hope to get the motivation to fly it again this summer. It's too good of an airplane to j ust sit. My health is now pretty good, and I just flew a ride with a local instructor in a 172 and will fly some more proficiency flights to get my a ir sense back and return to Europa Flying. My civilian CFI says I'm more t han proficient enough, however, he has some learning to do. There is a dif ference between currency and proficiency. I've only flown 2 hours in two y ears with 3 landings in the last 30 days which is not proficiency in my boo k. Now to take him out and wring out the 172 and get him to understand why an airplane does certain things and as an instructor know how to rectify s tudent mistakes. Have fun guys, the flying season is now arriving. The spring storms will s ubside soon and adventure awaits... Bud Yerly ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of Roger Sheridan Sent: Saturday, April 6, 2024 8:21 AM Subject: Europa-List: 914 Airbox Support Hi Everyone, I am refurbishing an XS 914 installation & am mildly concerned that the Rot ax airbox/plenum seems to be only supported by the carb mount rubbers. During a heavy landing there must be a lot of stress there! On the 912S installation Europa support their lighter airbox with an alumin ium strap to the engine frame. Has anybody added such a support to their 914? Grateful for any feedback from 914 operators. Best regards, Roger %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C02%7C%7C84f98b66 0a7e477ae6c808dc563482d4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63848 0030745619292%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=pekNiH4aekpokmv6vQMX0x8z %2BAQ%2FhkyASsFAy1IIuNw%3D&reserved=0<http://www.matronics.com/Navigator? Europa-List> %2Fforums.matronics.com%2F&data=05%7C02%7C%7C84f98b660a7e477ae6c808dc5634 82d4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638480030745633929%7CUnkn own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C0%7C%7C%7C&sdata=pIFDaJyHKLC7oYyIcmPTi85Htyi1qjz%2Fs1Sv0KcY%2 BZc%3D&reserved=0<http://forums.matronics.com/> %2Fwiki.matronics.com%2F&data=05%7C02%7C%7C84f98b660a7e477ae6c808dc563482 d4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638480030745645261%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C0%7C%7C%7C&sdata=CgfeuqD9hbSfq%2BlHjS0Xuow1v0pJOCJpCK3H5ZubsLg% 3D&reserved=0<http://wiki.matronics.com/> F%2Fmatronics.com%2Fcontribution&data=05%7C02%7C%7C84f98b660a7e477ae6c808 dc563482d4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638480030745656254% 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=uqtaS4DXZuovWh%2Fc4Q%2BxRZdqti2yxHikuY ZhdHIBPBQ%3D&reserved=0 ________________________________________________________________________________
From: John Kirkegaard <john.kirkegaard(at)googlemail.com>
Subject: test
Date: Apr 07, 2024
Subject: test
Date: Apr 07, 2024
Date: Apr 07, 2024
on my turbo 912 I use a giant zip tie round the engine mount and the airbox with a piece of 1/2 inch hose in between(x 2 - one at each end of the airbox.) William Daniell LONGPORT +1 786 878 0246 On Sat, Apr 6, 2024 at 2:10=AFPM Bud Yerly wrote: > Some miscellaneous ramblings on the airbox. > > As stated, your engine airbox depends on the year group. > > My 1998 timeframe engine also has no brace. The only time a brace is nic e > on the non braced airbox mod (done sometime around 2010), is when using a > thin silicone turbo discharge hose connected to the airbox. (The heavy > double or triple braided black hose supplied by Rotax on the old engines > was quite stiff and combined with the carb sockets at the manifold and ho se > clamps kept the airbox on securely (nearly all the time with balanced > carbs.) The issue with the airbox in the old days was it kept sliding of f > the port carb due to oil accumulation. If you flew often, the oil thrown > out of the turbo was but a wisp and if the engine was well tuned it staye d > put. If you didn't fly often and the 2-inch hose became oil soaked, then > the plenum hose to carb would slide off (especially at full boost) and if > the carbs were not well synchronized (read as "shaky engine") it slid off > fairly often just when you didn't want it to. I found the used 914 I boug ht > had carbs that were no longer a matched set any more due to some wear in > the piston throat, as the pistons were well out of sync. I bought two ne w > matched carbs and with that carb change, proper tuning, and cleaning my > airbox to carb rubbers, all stayed where put and the engine ran flawless > now for 10 years. Even after I upgraded the TCU to give me 40 inches > takeoff power it stayed put. > > If equipped with old oil soaked hoses or a thin silicone discharge hose, > or you left your carb to airbox hoses get really oil soaked, it is pruden t > to clean your airbox to carb rubber hose with acetone or similar solvent to > make them squeaky clean (or replace them). (Washing your intake plenum ou t > helps also.) To assist in security of a shaky engine, a couple of padded > hose clamps and a piece of sheet metal could hold the airbox firmly to th e > ring mount to prevent slipping. Also, a couple of Adel Clamps and a piec e > of tube and bolts could work also on the older manifold without welding o n > a bung like the new airbox has. In a pinch, a piece of safety wire on th e > port side to the ring mount frame at the upper block bolt was also OK at > preventing the plenum from slipping aft but only temporarily. A nicely > made piece of .040 aluminum with a bit of a bevel for stiffness on the > edges or a flute down the middle and nicely formed ends could in fact hol d > the box firmly in place and at the same time keep it from sliding off. T o > remove the carbs for cleaning, or to flush the accumulation of turbo oil > out of the plenum after setting a long time, it only required removing th e > bolt between the Adels the two carb clamps and it was free. > > Once I had perfectly synchronized carb pistons and flew more often, I > never again had an issue. Someplace in the shop I still have my Adel > Clamps, a long bolt and tube just in case because I wondered about this n ew > silicone turbo hose I added this year and it's contribution to airbox > security. Today my plane has sat for two years due to a wing delam repai r > and repaint, a number of upgrades and some other issues my old Classic ha s, > however, today my procedure is to suck the oil out of the turbo cold side > before start if it has sat (for months) and it seems to run very well. I > hope to get the motivation to fly it again this summer. It's too good of > an airplane to just sit. My health is now pretty good, and I just flew a > ride with a local instructor in a 172 and will fly some more proficiency > flights to get my air sense back and return to Europa Flying. My civilia n > CFI says I'm more than proficient enough, however, he has some learning t o > do. There is a difference between currency and proficiency. I've only > flown 2 hours in two years with 3 landings in the last 30 days which is n ot > proficiency in my book. Now to take him out and wring out the 172 and ge t > him to understand why an airplane does certain things and as an instructo r > know how to rectify student mistakes. > > Have fun guys, the flying season is now arriving. The spring storms will > subside soon and adventure awaits... > > Bud Yerly > > > ------------------------------ > *From:* owner-europa-list-server(at)matronics.com < > owner-europa-list-server(at)matronics.com> on behalf of Roger Sheridan < > rogersheridan(at)gmail.com> > *Sent:* Saturday, April 6, 2024 8:21 AM > *To:* Europa List > *Subject:* Europa-List: 914 Airbox Support > m > > > > Hi Everyone, > > I am refurbishing an XS 914 installation & am mildly concerned that the > Rotax airbox/plenum seems to be only supported by the carb mount rubbers. > > During a heavy landing there must be a lot of stress there! > > On the 912S installation Europa support their lighter airbox with an > aluminium strap to the engine frame. > > Has anybody added such a support to their 914? > > Grateful for any feedback from 914 operators. > > Best regards, > > Roger > ========== > st Email Forum - > pa-List" id="OWA84ef5614-ca1d-fc24-0c41-d8f26da56a8b" class="OWAAutoL ink" > data-auth="NotApplicable"> > https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.mat ronics.com%2FNavigator%3FEuropa-List&data=05%7C02%7C%7C84f98b660a7e477ae6 c808dc563482d4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638480030745619 292%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1 haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=pekNiH4aekpokmv6vQMX0x8z%2BAQ%2Fhk yASsFAy1IIuNw%3D&reserved=0 > ========== > p; - MATRONICS WEB FORUMS - > 1e8a846a-d5fb-640d-c872-39e3781d8b33" class="OWAAutoLink" > data-auth="NotApplicable"> > https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums. matronics.com%2F&data=05%7C02%7C%7C84f98b660a7e477ae6c808dc563482d4%7C84d f9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638480030745633929%7CUnknown%7CTWFp bGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D% 7C0%7C%7C%7C&sdata=pIFDaJyHKLC7oYyIcmPTi85Htyi1qjz%2Fs1Sv0KcY%2BZc%3D&res erved=0 > ========== > p; - NEW MATRONICS LIST WIKI - > f1e0fa-0b8a-0a83-b107-abb585b40165" class="OWAAutoLink" > data-auth="NotApplicable"> > https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwiki.ma tronics.com%2F&data=05%7C02%7C%7C84f98b660a7e477ae6c808dc563482d4%7C84df9 e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638480030745645261%7CUnknown%7CTWFpbG Zsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C 0%7C%7C%7C&sdata=CgfeuqD9hbSfq%2BlHjS0Xuow1v0pJOCJpCK3H5ZubsLg%3D&reserve d=0 > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > ="OWAfb76c392-0c78-b48a-db44-995c121dc500" class="OWAAutoLink" > data-auth="NotApplicable"> > https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fmatron ics.com%2Fcontribution&data=05%7C02%7C%7C84f98b660a7e477ae6c808dc563482d4 %7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638480030745656254%7CUnknown% 7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6M n0%3D%7C0%7C%7C%7C&sdata=uqtaS4DXZuovWh%2Fc4Q%2BxRZdqti2yxHikuYZhdHIBPBQ% 3D&reserved=0 > ========== > > ________________________________________________________________________________
Subject: Re: Airmaster constant speed unit issue
Date: Apr 15, 2024
Delving into the treacherous world of Division 2 alongside Boosthive's elite boosting services was an exhilarating adventure. Their team's skill and expertise were evident from the moment I enlisted their help, and together, we tackled each challenge with precision and finesse. With Boosthive by my side, victory was not just a possibilityit was inevitable. For agents seeking to dominate the Division and rise to the top, there's no better choice. Click here to embark on your journey to greatness: https://boosthive.eu/division-2 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513464#513464 ________________________________________________________________________________
Date: Apr 15, 2024
The only problem Ive had in 800+ hours with the Airmaster occurres when carbon accumulates on the slip ring obscures the rpm sensor trigger. Thats the little round brass insert. Cleaning it off will fix it. -------- N951EU - Tri-gear & 912ULS, N77EU- Mono & 914 I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513465#513465 ________________________________________________________________________________
Date: Apr 19, 2024
From: Ken Atkinson <kennethatkinson178(at)btinternet.com>
Subject: Sleap DOTH
Hi all, is there a DOTH to Sleap tomorrow Sat? Ken G-CEKV ________________________________________________________________________________
Subject: Re: Solar Eclipse Fly In
Date: Apr 20, 2024
Here's a late update. The weather looked marginal Sunday evening, and we were thinking we would have to file IFR but Monday morning it was severe clear all the way. We arrived about 11 AM and there was no traffic. It looked like there were maybe 40 or 50 planes on the ramp at the time of the eclipse but by an hour after totality most had departed. We used the grass runway and had it to ourselves. The eclipse was awesome! The temperature dropped as the moon covered the sun and just before totality the sky got an eerie color like before a big storm. All the exterior lights came on since their sensers were tricked. It was worth traveling to view! Our iPad didn't get much in the way of photos, but here is a link from VAF: https://vansairforce.net/threads/pics-solar-eclipse-2024-pics-taken-by-rvators.225926/#post-1760033 I think the photo of all the aircraft in the air is awesome! We had a great time, Larry made good burgers and his music was just right. We gave Larry and Kim Europa rides and scored two Europa Passport points! Larry is planning another Europa event this year, we're looking forward to it. Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513476#513476 ________________________________________________________________________________
Date: Apr 20, 2024
Excellent jim This year ill get there Will William Daniell +1 786 878 0246 On Sat, Apr 20, 2024, 11:21 h&jeuropa wrote: > > Here's a late update. > > The weather looked marginal Sunday evening, and we were thinking we would > have to file IFR but Monday morning it was severe clear all the way. > > We arrived about 11 AM and there was no traffic. It looked like there > were maybe 40 or 50 planes on the ramp at the time of the eclipse but by an > hour after totality most had departed. We used the grass runway and had it > to ourselves. > > The eclipse was awesome! The temperature dropped as the moon covered the > sun and just before totality the sky got an eerie color like before a big > storm. All the exterior lights came on since their sensers were tricked. > It was worth traveling to view! Our iPad didn't get much in the way of > photos, but here is a link from VAF: > https://vansairforce.net/threads/pics-solar-eclipse-2024-pics-taken-by-rvators.225926/#post-1760033 > I think the photo of all the aircraft in the air is awesome! > > We had a great time, Larry made good burgers and his music was just right. > We gave Larry and Kim Europa rides and scored two Europa Passport points! > > Larry is planning another Europa event this year, we're looking forward to > it. > > Jim & Heather > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513476#513476 > > ________________________________________________________________________________
Subject: Airmaster SoftWare update
From: "John Kirkgaard" <john.kirkegaard(at)gmail.com>
Date: Apr 21, 2024
I was trying to alter the preset rpm by using Airmasters setting program. I did not give the wanted result, and in turn I asked Airmaster support. The support guy sent me a new software update for the controller. But.... Installing that resulting in immediately frying my controller. It got bricked, as they say. Completely damaged. Asking Airmaster how that could happen their only answer: buy a new controller - . After receiving the new controller I opened the old one up and found two burned components inside. (and a terrible smell) Well had no other choices, but to others: take care installing new software from Airmaster. I have had my propeller and controller for many years, so despite the plane has just been completed and started flying a couple of years ago there is no warranty (fair enough). However I am wondering how many people, building experimental aircraft, do manage to get the propeller installed and test flown within the warranty period. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513485#513485 ________________________________________________________________________________
Date: Apr 21, 2024
Subject: Re: Airmaster SoftWare update
I find it incredulous that Airmaster, a leader in the experimental market, would provide an untested piece of software to their customers that wound up frying the controller. Did they not fully test this software prior to se nding it out? I really do not want to start thinking that they are purposef ully sending out this software in order to sell replacement controllers. Ha s anyone else had this issue? Could this be making owners reluctant to upda te their software because they don't want to take any chances? And why woul dn't Airmaster stand behind their products and repair or replace the contro ller they damaged?=C2- Mike Duane N377EAEuropa XS Conventional GearChandler, Arizona, USA egaard(at)gmail.com> wrote: .com> I was trying to alter the preset rpm by using Airmasters setting program. I did not give the wanted result, and in turn I asked Airmaster support. The support guy sent me a new software update for the controller. But.... Installing that resulting in immediately frying my controller. It g ot bricked, as they say. Completely damaged. Asking Airmaster how that could happen their only answer: buy a new controller - . After receiving the new controller I opened the old one up and found two bu rned components inside. (and a terrible smell) Well had no other choices, but to others: take care installing new software from Airmaster. I have had my propeller and controller for many years, so despite the plane has just been completed and started flying a couple of years ago there is no warranty (fair enough). However I am wondering how many people, building experimental aircraft, do manage to get the propeller installed a nd test flown within the warranty period. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513485#513485 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 22, 2024
SGVsbG8gSm9obixIYXZpbmcgaGFkIGdyZWF0IHN1cHBvcnQgZnJvbSBBaXJtYXN0ZXIsIEkgZmlu ZCBpdCBhc3RvbmlzaGluZyB0aGF0IGFpcm1hc3RlciB3b3VsZCBtYWtlIHRoaXMgbWlzdGFrZTsg dGhleSBhcmUgdmVyeSBjYXV0aW91cyBhbmQgYWx3YXlzIGxvb2tpbmcgdG8gc2FmZXR5IGZpcnN0 LkFyZSB5b3Ugc3VyZSB0aGF0IGluIGRvaW5nIHRoZSB1cGRhdGUgeW91IGRpZCBub3QgbWFrZSBh IG1pc3Rha2UgbGlrZSBwb3dlcmluZyB0aGUgZGV2aWNlIG9uIGEgYmVuY2ggYW5kIHJldmVyc2lu ZyB0aGUgcG9sYXJpdHkgP0kgc2F5IHRoaXMgYmVjYXVzZSBJIGhhdmUgYWN0dWFsbHkgZG9uZSB0 aGlzIG15c2VsZiBmcnlpbmcgdHdvIFVhdmlvbmljcyBkZXZpY2VzIGFuZCBhIEthbmFyZGlhIEFs aXRpbWV0ZXIsIGl0IGlzIHNvIGVhc3kgZG9uZSBhbmQgb25seSB0YWtlcyBhIHNlY29uZCBvZiBu b3QgdGhpbmtpbmcgYW5kIHRoZSBlbGVjdHJvbmljcyBpcyBsYW5kZmlsbC5SZWdhcmRzVHJldm9y wqBTZW50IGZyb20gbXkgR2FsYXh5Ci0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS1G cm9tOiBKb2huIEtpcmtnYWFyZCA8am9obi5raXJrZWdhYXJkQGdtYWlsLmNvbT4gRGF0ZTogMjIv MDQvMjQgIDQ6MDUgYW0gIChHTVQrMTI6MDApIFRvOiBldXJvcGEtbGlzdEBtYXRyb25pY3MuY29t IFN1YmplY3Q6IEV1cm9wYS1MaXN0OiBBaXJtYXN0ZXIgU29mdFdhcmUgdXBkYXRlIC0tPiBFdXJv cGEtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkpvaG4gS2lya2dhYXJkIiA8am9obi5raXJrZWdh YXJkQGdtYWlsLmNvbT5JIHdhcyB0cnlpbmcgdG8gYWx0ZXIgdGhlIHByZXNldCBycG0gYnkgdXNp bmcgQWlybWFzdGVycyBzZXR0aW5nIHByb2dyYW0uSSBkaWQgbm90IGdpdmUgdGhlIHdhbnRlZCBy ZXN1bHQsIGFuZCBpbiB0dXJuIEkgYXNrZWQgQWlybWFzdGVyIHN1cHBvcnQuVGhlIHN1cHBvcnQg Z3V5IHNlbnQgbWUgYSBuZXcgc29mdHdhcmUgdXBkYXRlIGZvciB0aGUgY29udHJvbGxlci5CdXQu Li4uIEluc3RhbGxpbmcgdGhhdCByZXN1bHRpbmcgaW4gaW1tZWRpYXRlbHkgZnJ5aW5nIG15IGNv bnRyb2xsZXIuIEl0IGdvdCBicmlja2VkLCBhcyB0aGV5IHNheS4gQ29tcGxldGVseSBkYW1hZ2Vk LkFza2luZyBBaXJtYXN0ZXIgaG93IHRoYXQgY291bGQgaGFwcGVuIHRoZWlyIG9ubHkgYW5zd2Vy OiBidXkgYSBuZXcgY29udHJvbGxlciAtIC4gQWZ0ZXIgcmVjZWl2aW5nIHRoZSBuZXcgY29udHJv bGxlciBJIG9wZW5lZCB0aGUgb2xkIG9uZSB1cCBhbmQgZm91bmQgdHdvIGJ1cm5lZCBjb21wb25l bnRzIGluc2lkZS4gKGFuZCBhIHRlcnJpYmxlIHNtZWxsKVdlbGwgaGFkIG5vIG90aGVyIGNob2lj ZXMsIGJ1dCB0byBvdGhlcnM6IHRha2UgY2FyZSBpbnN0YWxsaW5nIG5ldyBzb2Z0d2FyZSBmcm9t IEFpcm1hc3Rlci5JIGhhdmUgaGFkIG15IHByb3BlbGxlciBhbmQgY29udHJvbGxlciBmb3IgbWFu eSB5ZWFycywgc28gZGVzcGl0ZSB0aGUgcGxhbmUgaGFzIGp1c3QgYmVlbiBjb21wbGV0ZWQgYW5k IHN0YXJ0ZWQgZmx5aW5nIGEgY291cGxlIG9mIHllYXJzIGFnbyB0aGVyZSBpcyBubyB3YXJyYW50 eSAoZmFpciBlbm91Z2gpLiBIb3dldmVyIEkgYW0gd29uZGVyaW5nIGhvdyBtYW55IHBlb3BsZSwg YnVpbGRpbmcgZXhwZXJpbWVudGFsIGFpcmNyYWZ0LCBkbyBtYW5hZ2UgdG8gZ2V0IHRoZSBwcm9w ZWxsZXIgaW5zdGFsbGVkIGFuZCB0ZXN0IGZsb3duIHdpdGhpbiB0aGUgd2FycmFudHkgcGVyaW9k LlJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZTpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20v dmlld3RvcGljLnBocD9wPTUxMzQ4NSM1MTM0ODVfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PV8tPcKgwqDCoMKgwqDCoMKgwqDCoCAt IFRoZSBFdXJvcGEtTGlzdCBFbWFpbCBGb3J1bSAtXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3Qg RmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZV8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBz dWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLF8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2Fk LCA3LURheSBCcm93c2UsIENoYXQsIEZBUSxfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOl8tPV8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/RXVy b3BhLUxpc3RfLT1fLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PV8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBNQVRST05J Q1MgV0VCIEZPUlVNUyAtXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEg dGhlIFdlYiBGb3J1bXMhXy09Xy09wqDCoCAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t Xy09Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT1fLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIE5FVyBNQVRST05JQ1MgTElT VCBXSUtJIC1fLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lr aSFfLT3CoMKgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29tXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT1fLT3CoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtXy09wqAgVGhhbmsg eW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtTWF0dCBEcmFsbGUsIExpc3QgQWRt aW4uXy09wqDCoCAtLT4gaHR0cHM6Ly9tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 ________________________________________________________________________________
Date: Apr 21, 2024
Trevor, The controller was not removed from the instrument panel. All cables were still in place during the update. Everything seemed to work well, until the update was completed and the power was switched on. The 3 red lights and a smell of burned components. Regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513495#513495 ________________________________________________________________________________
Date: Apr 21, 2024
DuaneFamly, I'm absolutely sure that the update-software is not made faulty by intention. In Europe we have a extremely good support by Airmasters representative. Unfortunately he has been on a long (well deserved) vacation, and I had to rely on support from Airmaster in N.Z. And to be frank, getting help from there is like contacting an Indian call center. Looking back, I should have been more patient and waited for the normally excellent support from Dirk. Regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513496#513496 ________________________________________________________________________________
Date: Apr 22, 2024
I have had a fair bit of contact with Dirk, he did once warn me against trying old er spec controllers with newer prop actuation motors. But the software update should never fry the board on an AC200. Airmaster should create a compatibility table as an annex to the installation manual. The purpose of a firmware update should also be included in the table. For others thinking of changing the settings on their controller, this does not require any new software. Once connected to a PC running the setup software, the parameters for t/o, climb and cruise can be adjusted, then loaded very easily. -------- John Wighton Europa XS trigear G-IPOD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513497#513497 ________________________________________________________________________________
Date: Apr 22, 2024
John, My set-up software seemed to run fine. I had, however the issue, that de- spite uploading the new settings (and then confirmed by downloading the new settings for check), during flight I could not achieve the new settings. It was not a big problem, but asked Airmaster if they new what could be the reason for that. Well the rest is history... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513499#513499 ________________________________________________________________________________
Date: Apr 23, 2024
John and other Airmaster Owners, In my nearly 20 years as an Airmaster Dealer, I have changed many a control ler programing, and troubleshot systems and installations on many planes. Nearly all of these were fairly simple to solve. However, on one occasion I did simply swap out a controller (I still have the original and it works fine.) It was discovered the belt driven alternator had a bad field causin g massive EMP which affected the Hall Effect transducer in the brush block (tach pickup). This was a bugger to troubleshoot. I knew it was the aux a lternator as the prop worked perfectly with the alternator field wire disco nnected. As far as changing RPM settings with the program, it is an issue usually wi th the difference in RPM shown on the Tach and that driven by the prop cont roller. In all my years, I find tachs are notoriously off. I typically ta ke my prop tachometer (optical device which counts the blades and converts to prop RPM.) I calculate the gearbox ratio and show that the RPM at the p rop is correct (confirming the programming), and the tach was off typically within limits but at 5500 RPM a 2% error is obviously 110 RPM. (An error that is OK for slow turning engines but not the Rotax.) I spent time with t he clients researching the tach operational tolerances. I found the Airmas ter tach pickup was more accurate than most tachometers, EIS or Engine Info rmation Systems, and even certified tachs. But I was happy to help the cus tomer fix his tach RPM error issue through the AC200 programming app rather than trying to adjust a tach (especially an EFIS equipped with an engine m onitor tach) issue. I was more interested in getting them flying safely wit h no fear of overrevving the engine. On another aircraft, we had the wrong gearbox ratio programmed, as the clie nt had the 912S in mind when the prop was purchased but settled on a 912 UL with the lower gear ratio. I also found on a few occasions that customers that didn't take the tried-a nd-true prop blade and diameter recommendations ( I was one of them) and th e owner found many problems occur getting the prop to perform properly. Th e owner blamed the settings, but on analysis I found the blade was too larg e of an area for the engine power. Case in point, the 912UL cannot take a prop any longer than 62 inches, a modest width and the tip must be narrow ( a tapered blade Warp Drive works well) unless really geared down. The wide chord blade may be great for high altitude but at sea level you can't even get 5400 for takeoff power with the 80-horse engine. Then at altitude the power loss doesn't provide enough power and torque to even get the desired cruise RPM. I purchased a propeller design program and spent inordinate a mounts of time refining my blade choices for the Rotax to match the blade t o the power and torque range of the Rotax 912, 912S and 914 engine versions . This is not a fun drill as the customer is always right, and since he is adamant on the blade choice, he gets to pay the dumb tax later when changi ng blades. John to your particular electrical issue: If you were able to install the USB to Serial cable and hook to your laptop successfully and make the RPM change it is possible during your hookup and removal of cables (especially in tight areas) a circuit board may be damag ed. Circuit boards can be brittle although the AC200 has very robust connec tions, I can see how it will happen. For those who have never had an issue , here is what the inside of an AC200 looks like: [cid:3f2455a6-672e-48fb-867f-4d40b648d6b6][X] One can see the pin connectors are quite robust but again, they are soldere d, and a solder joint can break, or some part of the joint or board flake. My concern with locking plugs is the Molex style connectors can be a pain t o lock in and unlock. I no longer just plug in a Molex until I can see if I can release it easily but still remain secure when clicked in. Heat shri nk is normally placed on the end of a Molex connector and unfortunately the heat shrink wraps under the push to release lever and can prevent full dep ression of the lever and may prevent an unlanch for removal. I trim the he at shrink to assure the hook side opens with clearance to spare. If a plug gets stuck, I suggest to the client to bend the hook side to assure it cle ars the latch and it should allow the plug to slide out easily rather than trying to trim the heat shrink in place. In trying to remove the larger co nnections sometimes torque is applied to the molex and the results can be t erminal. I have also seen the power plug leaned on heavily and the ground and or power connection solder joint causing a broken board or failed joint . In my autopsy of this AC200, a small chunk of solder was found and it sh orted on the board. (Even though the board is vertical, and one would thin k the solder would simply fall to the bottom. He was unlucky as it caused a short of course. However, most of the time a fried controller was a powe r connected to the ground and vice versa. OOPS. As my friend Gary would s ay... I'm going to pay the dumb tax for that." We've all been there. Although I have never had this issue like yours, for servicing I make all my panels easily removable and put the panel on the bench (sometimes I remo ve the AC200 from the panel and do the update process on the bench). I hoo k up my USB serial converter to my laptop, turn on the computer, call up th e program and power up the AC200 and I've never had an issue. The softwar e comes up (once I figure the com port on older non- automatic external USB connection programs) I change the item on the screen and then close the pr ogram and power down the AC200. It would be nearly impossible for a digital to serial conversion cable and processor to fry anything in a working propeller. So, I am sure it is not the cable. As for other issues. If the prop was working before, I am stum ped and blaming you, Airmaster or anyone else is inappropriate with what in formation I have read on your issue. There are other means of frying electronics though. I have witnessed a fellow EAA member doing a show and tell at a meeting of what happens when the battery is connected backwards. It can be exciting w hen the mechanical master contact closes. The only other AC 200 fried here in the States was due to an aftermarket vo ltage regulator that shot A/C current direct to the panel. (A unique home- made device.) As expected, those electrical components without reverse pola rity diode protection died a quick death and some were slow and very diffic ult to troubleshoot. I did hear of one guy (no firsthand knowledge) that h ad a couple of jumper wires connected to the prop contacts trying to troubl eshoot the hub not responding (he didn't realize the brushes were still in contact) and he found with 12 volts applied to the prop and the still conne cted brush block, cables and AC 200 controller, I can only say what he said : I knew I fried it as it smoked and stunk to high heaven. He paid the d umb tax of a new brushblock, cable, AC200 and he even changed out the switc h. Check if Dirk has a loaner AC200 at his shop (if you are working with him). Relay to him the prop program you are working with, which motor is in the hub. If you don't know, look in your logbook. so he can see if his spares will work for you. I have a complete test rig I made for those adamant that their install is c orrect. It is shown below. It has a circuit breaker, AC200, switches ,and can be hooked to a cigarette lighter socket via ring or spade connectors t o connect a small gel cell battery. This is great for ground test and many times to go fly on a test basis. [X] I had a Pipistrel owner that just couldn't get through his head, it wasn't the prop but his wiring. (On panel tear down, the power plug had no ground unless another component was turned on.) Heck of a thing to troubleshoot with absolutely no panel wiring documentation. Let me know what Dirk says. I've cc'd Jack Shaw at Airmaster so he is in t he loop. Email me off-line and let me know what you find. Bud Yerly US Airmaster Dealer. (Retiring but still helping folks in any way I can.) Cell 813 244-8354 (US Eastern Time or GMT -4) email: budyerly(at)msn.com ________________________________ From: owner-europa-list-server(at)matronics.com <owner-europa-list-server@matr onics.com> on behalf of John Kirkgaard Sent: Monday, April 22, 2024 1:46 AM Subject: Europa-List: Re: Airmaster SoftWare update com> DuaneFamly, I'm absolutely sure that the update-software is not made faulty by intentio n. In Europe we have a extremely good support by Airmasters representative. Unfortunately he has been on a long (well deserved) vacation, and I had to rely on support from Airmaster in N.Z. And to be frank, getting help from there is like contacting an Indian call center. Looking back, I should have been more patient and waited for the normally excellent support from Dirk. Regards John Read this topic online here: https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.ma tronics.com%2Fviewtopic.php%3Fp%3D513496%23513496&data=05%7C02%7C%7C93850 8a3e1494a8e995a08dc62900361%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63 8493617895585109%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMz IiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=T2k8%2FZ6q5H326MZPRTW Oli1EbZF8S1Dm7fk9fTVeuH4%3D&reserved=0<http://forums.matronics.com/viewto pic.php?p=513496#513496> %2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=05%7C02%7C%7C938508a3 e1494a8e995a08dc62900361%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63849 3617895594782%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiL CJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=nl911TBdxoTz%2FsY7Lli0ex 7cyp6nYENBmWk1%2Fjcfe5w%3D&reserved=0<http://www.matronics.com/Navigator? Europa-List> %2Fforums.matronics.com%2F&data=05%7C02%7C%7C938508a3e1494a8e995a08dc6290 0361%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638493617895601365%7CUnkn own%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C0%7C%7C%7C&sdata=s8%2B16TbjtZi8qfT4Nu9t%2FoV3yLfnGxf%2FoOS4Vc iY7pY%3D&reserved=0<http://forums.matronics.com/> %2Fwiki.matronics.com%2F&data=05%7C02%7C%7C938508a3e1494a8e995a08dc629003 61%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638493617895606014%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI 6Mn0%3D%7C0%7C%7C%7C&sdata=jUIIeULO2QUrp%2FBTw0rcFIiade4pdNGrXMnT7g%2BxRF Y%3D&reserved=0<http://wiki.matronics.com/> F%2Fmatronics.com%2Fcontribution&data=05%7C02%7C%7C938508a3e1494a8e995a08 dc62900361%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638493617895610001% 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=9L5eVKaxB7rT0C0bzJJC%2FAZw86bVsYHi2cqO VcZVRk0%3D&reserved=0 ________________________________________________________________________________
Date: Apr 26, 2024
Subject: Tri gear legs
I have a friend building, he asks, are the tri gear legs the same for both XS and classic? Alan G-GIWT Sent from my iPhone ________________________________________________________________________________
Subject: VP50 constant speed controller question
Date: Apr 26, 2024
Hi everybody..I am getting together the parts to fit an Arplast VP50 to my Classic Mono. My question is besides the smart avionics CSC controller are they any other brands of constant speed controller that will work with the VP50 .The FlyBox PRP looks interesting . Any thoughts advise welcome Cheers Darren Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513519#513519 ________________________________________________________________________________
Subject: Arplast VP50 parts wanted
Date: Apr 26, 2024
On the back of my last question .Arplast VP50 I need the bracket with the Potentiometer on thats goes on the engine. Also looking for a "Smart avionics CSC -1"controller or any other constant speed controller that will work with the VP50 . If you have any VP50 parts at all you don't need and would sell please let me know. Cheers Darren Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513520#513520 ________________________________________________________________________________
Subject: Re: Tri gear legs
Date: Apr 29, 2024
Hi Alan, yes the legs are the same for both Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513529#513529 ________________________________________________________________________________
Subject: What did you do with you Europa this week - 30/04/24
Date: Apr 30, 2024
First decent autumn day over here today. 15C and 1023 QNH at sea level; so off we took to the skies into the fluffy puffy scenery for a lovely 40min flight around over and under the clouds to have coffee and pancakes; an impromptu mini europa festival fly in at YKBN. Then another spectacular flight back. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513531#513531 Attachments: http://forums.matronics.com//files/42054230_7ec9_4326_802c_efba9c25a46c_556.jpeg ________________________________________________________________________________
Date: Apr 19, 2024
Subject: Sleap DOTH
Subject: Re: Sleap DOTH
Date: May 02, 2024
Hi Ken Just seen your question on todays Matronics digest archive. (Dated Snippet below)FYI Looks like there has been a Matronics email distribution quirk. Past event. Happily you arrived at Sleap and we enjoyed good conversation at the DOTH on Sunday 21st April. Attendees: Ian, Carl, Ken, David, Tony, Pat, John, Pat, Darren & Julie Royle, David, Arwel, Bob. See you at the next one. . Regards Bob Europa-List Digest Archive --- Total Messages Posted Wed 05/01/24: 3 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 04:43 AM - Sleap DOTH (Ken Atkinson) 2. 11:01 PM - Official Europa-List FAQ (Frequently Asked Questions) (Matt Dralle) 3. 11:03 PM - Official Europa-List Usage Guidelines (Matt Dralle) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513545#513545
March 11, 2024 - Present
Europa-Archive.digest.vol-ow
