Glasair-Archive.digest.vol-af
February 18, 2010 - June 09, 2012
      the fiber glass and primed it with a light weight epoxy primer and  finished
      it off with an ultra light Pittsburgh, base coat, pearl coat and  top coat
      system. I placed in a light weight starter, a set of lighter Slick mags  and a
      light weight battery and light weight upholstery.
         Before I built Deborah's Glasair, she owned a T-18 that  cruised around
      170 mph on a tricked out 320 Lyc. The first flights on  Deborah's Glasair
      only produced a cruise speed of around 190 mph and we wanted  to strangle Ted
      Setzer when he advertised 225 mph to 235 mph cruise speeds. It  took a lot
      of tweaking over the years to get up to 205/210 mph cruise speed  she now has
      on her Glasair. Even with that, we always felt the Glasair was far  capable
      of greater speeds because on long descents from altitude we would  commonly
      see 225 to 235 speeds and felt it was the prop. This was verified  when we
      met up with a Glasar 2 FT driver that opted out of a Hartzell  for a
      McCauley prop having cruise speeds over 220 mph.
                                                               Charles Raymond
      message dated 2/10/2010 8:02:32 A.M. Eastern  Standard Time,
      mppalmer(at)aol.com writes:
      -->  Glasair-List message posted by: mppalmer(at)aol.com
      Wow, a 20 mph gain is  impressive! Seems like Hartzell has got it
      figured out. (Too bad they  don't make such a prop for the lowly O-320.)
      In addition to a quieter  ride, I bet your engine cooling is better too.
      You might be able to close  down the inlets later and get a few more
      knots. (Whereas, with our  Hartzell prop, with its big, round roots, I
      never noticed a  difference  in speed by reducing the inlets. I suspect
      the drag from  the prop roots is the bigger factor, per Paul Lipps.)
      Now, if only  Glasair would re-loft the airframe on a PC and tweak the
      fiberglass to  reduce drag...
      >My indicated airspeed using my old  Hartzell  averaged around 163 mph
      at those settings
      >at those altitudes.   Using my new blended foil design, I noted
      indicated airspeed of 185  mph.
      Mike Palmer  <><
Subject: Antenna help
Date: Feb 18, 2010
Guys, I am trying to increase the range of my comm radios. New antennas will have to be installed in the fuselage. The VHF-5T antenna would have to be installed on a about a 35 degree angle to fit vertically. The SA-006 is a folded dipole antenna that can be installed as engineered in the fuselage as it is only 26" high and 9.5 inches wide. The manufacturer claims 170 mile range air to ground. My original antenna are the foil ones supplied by Glasair back in 1983. The navs are doing Ok but the comms need to be replaced. What recommendations do you have? RObin Young ________________________________________________________________________________
Subject: Re: Antenna help
Date: Feb 18, 2010
First I would caution you to adjust your expectations. Line of sight for VHF freqs is approximately 120 miles at 10,000 feet. A claim of 170 miles is, in my opinion, unlikely to be achieved on anything near a regular basis. As a project engineer with Bendix avionics in the 70's we struggled to get 130 to 140 miles using digital techniques and 25 watt transmitters at that altitude (10,000). If you read the ad carefully for the SA-006, the writer does not claim 170 mile performance, only that it occurred. The most important part of the equation is altitude of the antennas involved. At 20,000 the line of sight is approximately 1.4 times the 10,000 ft distance or roughly 170 miles. If you routinely fly at that altitude you will likely communicate over those distances. I fly a Glasair III with standard S-H antenna and routinely get line of sight comm. Any tilting of the comm antenna from vertical will diminish performance since the comm signal is vertically polarized. Theoretically a tilt from vertical of 45 degrees causes roughly a 30% loss of signal strength. In practice it's not quite that bad because of scatter/reflections from things metal on the aircraft. Also remember there is an engine in front of a fuselage mounted antenna which will effect the radiation pattern of the antenna. Curious why the foil antenna need to be replaced. If Tx and Rx meet spec, the antenna is installed per the book and all coax and connectors are properly done, you should be able to comm line of sight distances. Have you done a VSWR on your setup? Sorry for the long diatribe but hate to see anyone spend bucks that may not yield a performance increase. Regards, B.J. McClure CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 13:25:22 up 9 days, 6:57, 1 user, load average: 0.17, 0.12, 0.09 > Guys, I am trying to increase the range of my comm radios. New > antennas will have to be installed in the fuselage. The VHF-5T > antenna would have to be installed on a about a 35 degree angle to > fit vertically. > > The SA-006 is a folded dipole antenna that can be installed as > engineered in the fuselage as it is only 26" high and 9.5 inches wide. > The manufacturer claims 170 mile range air to ground. > > My original antenna are the foil ones supplied by Glasair back in > 1983. The navs are doing Ok but the comms need to be replaced. What > recommendations do you have? RObin Young > > > > ________________________________________________________________________________
Date: Feb 18, 2010
BJ...thanks for the reply. I did not put the foil antenna in the vertical stabilizer when I built the plane. My primary radio has been a whip antenna on a ground plane with the back up radio antenna in too much of a horizontal, it has a very low range. I want to improve them but they cannot be removed and reused. You seem knowledgeable about the Sa-006. It will fit better than the VHF-5t. It is also cheaper for some reason. Is it a choice I should consider? Thanks RObin _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of b.j. mcclure Sent: Thursday, February 18, 2010 3:51 PM Subject: Re: Glasair-List: Antenna help First I would caution you to adjust your expectations. Line of sight for VHF freqs is approximately 120 miles at 10,000 feet. A claim of 170 miles is, in my opinion, unlikely to be achieved on anything near a regular basis. As a project engineer with Bendix avionics in the 70's we struggled to get 130 to 140 miles using digital techniques and 25 watt transmitters at that altitude (10,000). If you read the ad carefully for the SA-006, the writer does not claim 170 mile performance, only that it occurred. The most important part of the equation is altitude of the antennas involved. At 20,000 the line of sight is approximately 1.4 times the 10,000 ft distance or roughly 170 miles. If you routinely fly at that altitude you will likely communicate over those distances. I fly a Glasair III with standard S-H antenna and routinely get line of sight comm. Any tilting of the comm antenna from vertical will diminish performance since the comm signal is vertically polarized. Theoretically a tilt from vertical of 45 degrees causes roughly a 30% loss of signal strength. In practice it's not quite that bad because of scatter/reflections from things metal on the aircraft. Also remember there is an engine in front of a fuselage mounted antenna which will effect the radiation pattern of the antenna. Curious why the foil antenna need to be replaced. If Tx and Rx meet spec, the antenna is installed per the book and all coax and connectors are properly done, you should be able to comm line of sight distances. Have you done a VSWR on your setup? Sorry for the long diatribe but hate to see anyone spend bucks that may not yield a performance increase. Regards, B.J. McClure CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 13:25:22 up 9 days, 6:57, 1 user, load average: 0.17, 0.12, 0.09 Guys, I am trying to increase the range of my comm radios. New antennas will have to be installed in the fuselage. The VHF-5T antenna would have to be installed on a about a 35 degree angle to fit vertically. The SA-006 is a folded dipole antenna that can be installed as engineered in the fuselage as it is only 26" high and 9.5 inches wide. The manufacturer claims 170 mile range air to ground. My original antenna are the foil ones supplied by Glasair back in 1983. The navs are doing Ok but the comms need to be replaced. What recommendations do you have? RObin Young st Email Forum - atures Navigator to browse uch as List Un/Subscription, load, 7-Day Browse, Chat, FAQ, more: //www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigat or?Glasair-List WEB FORUMS - vailable via the Web Forums! //forums.matronics.com">http://forums.matronics.com bution Web Site - ous support! -Matt Dralle, List Admin. //www.matronics.com/contribution">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 18, 2010
Now I understand your motivation. I have never used nor tested the SA-006. I would ask for a list of customers who have purchased it and ask them if they get satisfactory performance. This is a terrible suggestion but is it possible to open the vertical fin and install there? It's as near a perfect location as you will find. Remember the radiation pattern for a theoretical dipole is toroidal (doughnut) in shape. Little energy is radiated or received off the ends of the antenna. Once you start tilting and bending the antenna you no longer have much knowledge what the radiation pattern looks like. Making that determination requires a field strength meter and lots of painstaking data collection and plotting. Any legitimate antenna designer should have data for their antenna mounted in an ideal install. It may also be computer generated as opposed to measurement in an anechoic chamber. You might ask if they also have data for the antenna with any degree of deformation. It might give you some clues as to what you can expect. Sorry I couldn't be of more help. B.J. CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 16:43:22 up 9 days, 10:15, 1 user, load average: 0.12, 0.10, 0.10 > BJ...thanks for the reply. I did not put the foil antenna in the > vertical stabilizer when I built the plane. My primary radio has > been a whip antenna on a ground plane with the back up radio antenna > in too much of a horizontal, it has a very low range. I want to > improve them but they cannot be removed and reused. > > You seem knowledgeable about the Sa-006. It will fit better than the > VHF-5t. It is also cheaper for some reason. Is it a choice I > should consider? Thanks RObin > > > > > ______________________________________________________________________ > From: owner-glasair-list-server(at)matronics.com > [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of b.j. > mcclure > Sent: Thursday, February 18, 2010 3:51 PM > To: glasair-list(at)matronics.com > Subject: Re: Glasair-List: Antenna help > > > > > First I would caution you to adjust your expectations. Line of sight > for VHF freqs is approximately 120 miles at 10,000 feet. A claim of > 170 miles is, in my opinion, unlikely to be achieved on anything near > a regular basis. As a project engineer with Bendix avionics in the > 70's we struggled to get 130 to 140 miles using digital techniques and > 25 watt transmitters at that altitude (10,000). If you read the ad > carefully for the SA-006, the writer does not claim 170 mile > performance, only that it occurred. The most important part of the > equation is altitude of the antennas involved. At 20,000 the line of > sight is approximately 1.4 times the 10,000 ft distance or roughly 170 > miles. If you routinely fly at that altitude you will likely > communicate over those distances. I fly a Glasair III with standard > S-H antenna and routinely get line of sight comm. Any tilting of the > comm antenna from vertical will diminish performance since the comm > signal is vertically polarized. Theoretically a tilt from vertical of > 45 degrees causes roughly a 30% loss of signal strength. In practice > it's not quite that bad because of scatter/reflections from things > metal on the aircraft. Also remember there is an engine in front of a > fuselage mounted antenna which will effect the radiation pattern of > the antenna. Curious why the foil antenna need to be replaced. If Tx > and Rx meet spec, the antenna is installed per the book and all coax > and connectors are properly done, you should be able to comm line of > sight distances. Have you done a VSWR on your setup? > > Sorry for the long diatribe but hate to see anyone spend bucks that > may not yield a performance increase. > > Regards, > B.J. McClure > CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 13:25:22 up 9 days, 6:57, > 1 user, load average: 0.17, 0.12, 0.09 > > > > > Guys, I am trying to increase the range of my comm radios. New > > antennas will have to be installed in the fuselage. The VHF-5T > > antenna would have to be installed on a about a 35 degree angle to > > fit vertically. > > The SA-006 is a folded dipole antenna that can be installed as > > engineered in the fuselage as it is only 26" high and 9.5 inches > > wide. The manufacturer claims 170 mile range air to ground. > > My original antenna are the foil ones supplied by Glasair back in > > 1983. The navs are doing Ok but the comms need to be replaced. > > What recommendations do you have? RObin Young > > > > > > > > st Email Forum - > > atures Navigator to browse > > uch as List Un/Subscription, > > load, 7-Day Browse, Chat, FAQ, > > more: > > //www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigator?Glasair-List > > > > WEB FORUMS - > > vailable via the Web Forums! > > //forums.matronics.com">http://forums.matronics.com > > > > bution Web Site - > > ous support! > > -Matt Dralle, List Admin. > > //www.matronics.com/contribution">http://www.matronics.com/contribution > > > > > > > > href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigator?Glasair-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > ________________________________________________________________________________
Date: Feb 18, 2010
BJ, thank you for the talk points. I have contacted a dealer for some references and hopefully will get the manufacturer contact also. If anyone else has experience with a folded dipole antenna on a glasair, please comment. RObin _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of b.j. mcclure Sent: Thursday, February 18, 2010 5:02 PM Subject: RE: Glasair-List: Antenna help Now I understand your motivation. I have never used nor tested the SA-006. I would ask for a list of customers who have purchased it and ask them if they get satisfactory performance. This is a terrible suggestion but is it possible to open the vertical fin and install there? It's as near a perfect location as you will find. Remember the radiation pattern for a theoretical dipole is toroidal (doughnut) in shape. Little energy is radiated or received off the ends of the antenna. Once you start tilting and bending the antenna you no longer have much knowledge what the radiation pattern looks like. Making that determination requires a field strength meter and lots of painstaking data collection and plotting. Any legitimate antenna designer should have data for their antenna mounted in an ideal install. It may also be computer generated as opposed to measurement in an anechoic chamber. You might ask if they also have data for the antenna with any degree of deformation. It might give you some clues as to what you can expect. Sorry I couldn't be of more help. B.J. CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 16:43:22 up 9 days, 10:15, 1 user, load average: 0.12, 0.10, 0.10 BJ...thanks for the reply. I did not put the foil antenna in the vertical stabilizer when I built the plane. My primary radio has been a whip antenna on a ground plane with the back up radio antenna in too much of a horizontal, it has a very low range. I want to improve them but they cannot be removed and reused. You seem knowledgeable about the Sa-006. It will fit better than the VHF-5t. It is also cheaper for some reason. Is it a choice I should consider? Thanks RObin _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of b.j. mcclure Sent: Thursday, February 18, 2010 3:51 PM Subject: Re: Glasair-List: Antenna help First I would caution you to adjust your expectations. Line of sight for VHF freqs is approximately 120 miles at 10,000 feet. A claim of 170 miles is, in my opinion, unlikely to be achieved on anything near a regular basis. As a project engineer with Bendix avionics in the 70's we struggled to get 130 to 140 miles using digital techniques and 25 watt transmitters at that altitude (10,000). If you read the ad carefully for the SA-006, the writer does not claim 170 mile performance, only that it occurred. The most important part of the equation is altitude of the antennas involved. At 20,000 the line of sight is approximately 1.4 times the 10,000 ft distance or roughly 170 miles. If you routinely fly at that altitude you will likely communicate over those distances. I fly a Glasair III with standard S-H antenna and routinely get line of sight comm. Any tilting of the comm antenna from vertical will diminish performance since the comm signal is vertically polarized. Theoretically a tilt from vertical of 45 degrees causes roughly a 30% loss of signal strength. In practice it's not quite that bad because of scatter/reflections from things metal on the aircraft. Also remember there is an engine in front of a fuselage mounted antenna which will effect the radiation pattern of the antenna. Curious why the foil antenna need to be replaced. If Tx and Rx meet spec, the antenna is installed per the book and all coax and connectors are properly done, you should be able to comm line of sight distances. Have you done a VSWR on your setup? Sorry for the long diatribe but hate to see anyone spend bucks that may not yield a performance increase. Regards, B.J. McClure CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 13:25:22 up 9 days, 6:57, 1 user, load average: 0.17, 0.12, 0.09 Guys, I am trying to increase the range of my comm radios. New antennas will have to be installed in the fuselage. The VHF-5T antenna would have to be installed on a about a 35 degree angle to fit vertically. The SA-006 is a folded dipole antenna that can be installed as engineered in the fuselage as it is only 26" high and 9.5 inches wide. The manufacturer claims 170 mile range air to ground. My original antenna are the foil ones supplied by Glasair back in 1983. The navs are doing Ok but the comms need to be replaced. What recommendations do you have? RObin Young st Email Forum - atures Navigator to browse uch as List Un/Subscription, load, 7-Day Browse, Chat, FAQ, more: //www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigat or?Glasair-List WEB FORUMS - vailable via the Web Forums! //forums.matronics.com">http://forums.matronics.com bution Web Site - ous support! -Matt Dralle, List Admin. //www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics. com/Navigator?Glasair-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c st Email Forum - atures Navigator to browse uch as List Un/Subscription, load, 7-Day Browse, Chat, FAQ, more: //www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigat or?Glasair-List WEB FORUMS - vailable via the Web Forums! //forums.matronics.com">http://forums.matronics.com bution Web Site - ous support! -Matt Dralle, List Admin. //www.matronics.com/contribution">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 19, 2010
I found the manufacturer on the SA-006 folded dipole antenna....Bob Archer 310-316-8796. He has installed many of these in Lancairs to handle post construction problems. They do not work well inside graphite but are all working well otherwise. Lancair has purchased as many as 90 at the time from him and they are built into the fuselage in the factory. He was so sure I would like the results, he is sending the unit with an invoice. I either send him a check after testing it or send back the antenna after taping it inside for the test. I appreciate all of your comments. RObin ---------- Forwarded message ---------- From: Robert Buckthal <rbuckthal(at)gmail.com> Date: Thu, Feb 18, 2010 at 3:55 PM Subject: Re: Glasair-List: Antenna help Robin, I mounted the factory foil com antenna on the right side of the fuselage just aft of the hat rack. It bends slightly to conform to the roof line. I'm not aware of having any communications problems. When I transmit I always seem to get a response. I did mount another antenna in the rudder but I inadvertently damaged the coax after the rudder was closed. A runaway dremel opened up a 3/8" circular break in the shielding only. I have no idea whether that kind of damage is fatal to the antenna but I didn't try to repair it. Hope this helps Bob Buckthal llS-FT 810 hours . On Thu, Feb 18, 2010 at 3:12 PM, Robin Young wrote: BJ, thank you for the talk points. I have contacted a dealer for some references and hopefully will get the manufacturer contact also. If anyone else has experience with a folded dipole antenna on a glasair, please comment. RObin _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of b.j. mcclure Sent: Thursday, February 18, 2010 5:02 PM Subject: RE: Glasair-List: Antenna help Now I understand your motivation. I have never used nor tested the SA-006. I would ask for a list of customers who have purchased it and ask them if they get satisfactory performance. This is a terrible suggestion but is it possible to open the vertical fin and install there? It's as near a perfect location as you will find. Remember the radiation pattern for a theoretical dipole is toroidal (doughnut) in shape. Little energy is radiated or received off the ends of the antenna. Once you start tilting and bending the antenna you no longer have much knowledge what the radiation pattern looks like. Making that determination requires a field strength meter and lots of painstaking data collection and plotting. Any legitimate antenna designer should have data for their antenna mounted in an ideal install. It may also be computer generated as opposed to measurement in an anechoic chamber. You might ask if they also have data for the antenna with any degree of deformation. It might give you some clues as to what you can expect. Sorry I couldn't be of more help. B.J. CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 16:43:22 up 9 days, 10:15, 1 user, load average: 0.12, 0.10, 0.10 BJ...thanks for the reply. I did not put the foil antenna in the vertical stabilizer when I built the plane. My primary radio has been a whip antenna on a ground plane with the back up radio antenna in too much of a horizontal, it has a very low range. I want to improve them but they cannot be removed and reused. You seem knowledgeable about the Sa-006. It will fit better than the VHF-5t. It is also cheaper for some reason. Is it a choice I should consider? Thanks RObin _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of b.j. mcclure Sent: Thursday, February 18, 2010 3:51 PM Subject: Re: Glasair-List: Antenna help First I would caution you to adjust your expectations. Line of sight for VHF freqs is approximately 120 miles at 10,000 feet. A claim of 170 miles is, in my opinion, unlikely to be achieved on anything near a regular basis. As a project engineer with Bendix avionics in the 70's we struggled to get 130 to 140 miles using digital techniques and 25 watt transmitters at that altitude (10,000). If you read the ad carefully for the SA-006, the writer does not claim 170 mile performance, only that it occurred. The most important part of the equation is altitude of the antennas involved. At 20,000 the line of sight is approximately 1.4 times the 10,000 ft distance or roughly 170 miles. If you routinely fly at that altitude you will likely communicate over those distances. I fly a Glasair III with standard S-H antenna and routinely get line of sight comm. Any tilting of the comm antenna from vertical will diminish performance since the comm signal is vertically polarized. Theoretically a tilt from vertical of 45 degrees causes roughly a 30% loss of signal strength. In practice it's not quite that bad because of scatter/reflections from things metal on the aircraft. Also remember there is an engine in front of a fuselage mounted antenna which will effect the radiation pattern of the antenna. Curious why the foil antenna need to be replaced. If Tx and Rx meet spec, the antenna is installed per the book and all coax and connectors are properly done, you should be able to comm line of sight distances. Have you done a VSWR on your setup? Sorry for the long diatribe but hate to see anyone spend bucks that may not yield a performance increase. Regards, B.J. McClure CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 13:25:22 up 9 days, 6:57, 1 user, load average: 0.17, 0.12, 0.09 Guys, I am trying to increase the range of my comm radios. New antennas will have to be installed in the fuselage. The VHF-5T antenna would have to be installed on a about a 35 degree angle to fit vertically. The SA-006 is a folded dipole antenna that can be installed as engineered in the fuselage as it is only 26" high and 9.5 inches wide. The manufacturer claims 170 mile range air to ground. My original antenna are the foil ones supplied by Glasair back in 1983. The navs are doing Ok but the comms need to be replaced. What recommendations do you have? RObin Young st Email Forum - atures Navigator to browse uch as List Un/Subscription, load, 7-Day Browse, Chat, FAQ, more: //www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigat or?Glasair-List WEB FORUMS - vailable via the Web Forums! //forums.matronics.com <http://forums.matronics.com/> ">http://forums.matronics.com bution Web Site - ous support! -Matt Dralle, List Admin. //www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics. com/Navigator?Glasair-List href="http://forums.matronics.com ">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c st Email Forum - atures Navigator to browse uch as List Un/Subscription, load, 7-Day Browse, Chat, FAQ, more: //www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigat or?Glasair-List WEB FORUMS - vailable via the Web Forums! //forums.matronics.com <http://forums.matronics.com/> ">http://forums.matronics.com bution Web Site - ous support! -Matt Dralle, List Admin. //www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics. com/Navigator?Glasair-List href="http://forums.matronics.com ">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Feb 23, 2010
Subject: Re: Glasair-List drop me please
can you drop me from the glasair list? thanks! dave In a message dated 2/23/2010 2:11:33 A.M. Central Standard Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-02-22&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-02-22&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Mon 02/22/10: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Feb 23, 2010
Subject: Blended foil prop
We had a rare small window to fly our GL 2 SFT / 200 Hp Lyc. on a short 15 mile cross country trip to tank up on 100 LL that was about $1.00/ gallon less than what our home base FBO sells it for. This was our second flight using our new Hartzell Blended foil prop. We had a cross wind and again didn't note any difference in T. O. or climb performance. At the beginning of the take off roll the RPM on our UMA electric tach registered 2,600 RPM and as the plane accelerated down the runway the rpm peaked at 2,750 and bounced off 2,750 mark around 100 rpm on climb out. We hoped the 100 RPM fluctuation was due to engine oil that wasn't fully warmed up to operating temperature as pockets of cool 50 weight oil went through the governor. The air temperature was in the low seventies and we had a stiff breeze and experienced moderate turbulence. Because it was only a 15 mile flight, we elected to cruise at 2,000 feet @ 2,400 rpm, 24 inches MP and 50 degrees lean of peak @ 10.5 gals/ hour. On our old prop we commonly noted GPS ground speeds 180 to 185 mph at that altitude. But on this flight we noted an average GPS ground speed of 205 mph and can't wait to see what we get at altitude. We even had a GPS ground speed of 225 mph, but don't get excited because it was due to a gusty tail wind. This was my wife's first time behind the controls using our new blended foil prop and she remarked on how much faster the plane was and how she had to keep resetting the trim as the plane gained more and more speed after leveling out. She noted a 200 degree oil temperature that was 15 degrees warmer than it previously was using the old prop. I laughed when she said that "the plane is getting there before I am." She found slowing the plane down to enter the pattern a new challenge that required reducing the power, putting in up trim, pushing the prop in and sneaking in a little flaps at 140 mph in an effort to slow the plane down. With the old prop, we could feel the plane slow down by just reducing the power and adding just 50 rpm. But this new blended foil just wants to keep on trucking and requires more adjustments of power, prop, trim and flaps. We plan to fly the plane on a cross country next week at 8,500 feet were we formerly got our best performance and will report what we get. Note: RYC freight is still driving us crazy with their padded "residential" double price delivery charge. Glasair and Hartzell weren't aware of this when they shipped the prop and RYC never advised me of this policy. Glasair's Harry Delong is trying to resolve this. Charles Raymond N16CD ________________________________________________________________________________
From: "Randy Pinkston" <pinkston(at)carolina.rr.com>
Subject: micorvision 3010042 fuel transducer
Date: Feb 24, 2010
Anyone have one for sale? Or know what works in the place of it. Randy Pinkston 704-438-1222 ________________________________________________________________________________
Date: Feb 24, 2010
Subject: Re: micorvision 3010042 fuel transducer
Don't know if it's what you want, but there's a listing on ebay of a bunch of parts. Search under "glasair." John Grosse Randy Pinkston wrote: > > Anyone have one for sale? Or know what works in the place of it. > Randy Pinkston 704-438-1222 > > * > > > * ________________________________________________________________________________
Subject: 3010042
Date: Feb 24, 2010
Will try ebay thanks ________________________________________________________________________________
Date: Feb 25, 2010
Subject: Re: Glasair-List Digest: 3 Msgs - 02/25/10
I would like to replace my panel mount Appollo Fly Buddy Loran with an Appollo Fly Buddy GPS. I know this unit has many short comings and would use it as a back up to my Garmin. Anyone have one for sale? In a message dated 2/25/2010 3:09:52 A.M. Eastern Standard Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-02-24&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-02-24&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Wed 02/24/10: 3 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 11:32 AM - micorvision 3010042 fuel transducer (Randy Pinkston) 2. 11:37 AM - Re: micorvision 3010042 fuel transducer (John Grosse) 3. 03:05 PM - 3010042 (Randy Pinkston) ________________________________ Message 1 _____________________________________ From: "Randy Pinkston" <pinkston(at)carolina.rr.com> Subject: Glasair-List: micorvision 3010042 fuel transducer Anyone have one for sale? Or know what works in the place of it. Randy Pinkston 704-438-1222 ________________________________ Message 2 _____________________________________ From: John Grosse <grosseair(at)comcast.net> Subject: Re: Glasair-List: micorvision 3010042 fuel transducer Don't know if it's what you want, but there's a listing on ebay of a bunch of parts. Search under "glasair." John Grosse Randy Pinkston wrote: > > Anyone have one for sale? Or know what works in the place of it. > Randy Pinkston 704-438-1222 > > * > > > * ________________________________ Message 3 _____________________________________ From: "Randy Pinkston" <pinkston(at)carolina.rr.com> Subject: Glasair-List: 3010042 Will try ebay thanks ________________________________________________________________________________
Date: Feb 25, 2010
I have an 820. Replaced it about a year ago so data card is out at least a year or more. You probably don't need the tray but I will throw that in as well as antenna. If interested shoot me an email off-list at webadmin(at)irapoa.org. Located FL74. Thanks, B.J. McClure CentOS 5.4, Linux 2.6.18-164.11.1.el5 x86_64 12:50:08 up 3 days, 21:17, 2 users, load average: 0.96, 0.92, 1.25 > I would like to replace my panel mount Appollo Fly Buddy Loran with an > Appollo Fly Buddy GPS. I know this unit has many short comings and > would use it as a back up to my Garmin. Anyone have one for sale? > > In a message dated 2/25/2010 3:09:52 A.M. Eastern Standard Time, > glasair-list(at)matronics.com writes: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Glasair-List Digest can also be found in > either of the > two Web Links listed below. The .html file includes the > Digest formatted > in HTML for viewing with a web browser and features > Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain > ASCII version > of the Glasair-List Digest and can be viewed with a generic > text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-02-24&Archive=Glasair > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-02-24&Archive=Glasair > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > > ---------------------------------------------------------- > Glasair-List Digest Archive > --- > Total Messages Posted Wed 02/24/10: 3 > > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 11:32 AM - micorvision 3010042 fuel transducer (Randy > Pinkston) > 2. 11:37 AM - Re: micorvision 3010042 fuel transducer > (John Grosse) > 3. 03:05 PM - 3010042 (Randy Pinkston) > > > > ________________________________ Message 1 > _____________________________________ > > > From: "Randy Pinkston" <pinkston(at)carolina.rr.com> > Subject: Glasair-List: micorvision 3010042 fuel transducer > > Anyone have one for sale? Or know what works in the place of > it. Randy > Pinkston 704-438-1222 > > > ________________________________ Message 2 > _____________________________________ > > > From: John Grosse <grosseair(at)comcast.net> > Subject: Re: Glasair-List: micorvision 3010042 fuel > transducer > > > Don't know if it's what you want, but there's a listing on > ebay of a > bunch of parts. Search under "glasair." > > John Grosse > > Randy Pinkston wrote: > > > > Anyone have one for sale? Or know what works in the place of > it. > > Randy Pinkston 704-438-1222 > > > > * > > > > > > * > > > ________________________________ Message 3 > _____________________________________ > > > From: "Randy Pinkston" <pinkston(at)carolina.rr.com> > Subject: Glasair-List: 3010042 > > Will try ebay ============================================== > =============================================== > - MATRONICS WEB FORUMS > ================================================ - > List Contribution Web Site sp; > ================================================== > > > > > > > > ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Hartzel Blended foil
We had another chance to test our new Hartzel blended foil prop on our Glasair 2S FT-!0360 200 HP engine. We flew the plane with a light cross wind this time and noted a shorter take off roll from the runway end threshold to the hash marks. This time we noted that full take off RPM had settled down to 2600 rpm and that the fluctuating RPM we had on our first flights may have been due to either the prop purging itself of a little air or the oil being a bit warmer. Our last prop required adjusting the hub stop to get 2750 rpm. We climbed to 6,500 feet at a 140 mph indicated airspeed and noted this new prop provided a much higher rate of climb than our old prop did. Once at altitude we flew West at 6,500 feet with 24 inches manifold pressure, 2450 RPM and 50 degrees lean of peak for fifteen miles and recorded GPS ground cruise speeds of 214 mph in one direction and 204 mph on the return course that averaged out to 209 mph and noted an increase of around 15 mph over our old cruise speed. This increase in air speed was a bit lower than the twenty mph increase we noted at 3,000 feet. But this may have been do to slightly warmer temperatures and saturated air from a rain system that was moving in. The visibility for this flight was limited and no were near the crystal clear air we had on our first two tests flights and that may have been the cause. We also noted with our old prop that increasing the RPM over 2350 rpm didn't add to the air speed, but increasing the rpm with the new blended foil did increase airspeed all the way up to 2475 rpm. My guess for this is that the new blended foil has far more bite at higher rpm's than our old prop did. When the weather cooperates we will shoot for 8,500 feet on hopefully a clear day. ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Re: Hartzel Blended foil
Nice report. What was the "old" prop you had? Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com Matt's Building Blog Finishing Up... At 03:27 PM 3/4/2010 Thursday, you wrote: >We had another chance to test our new Hartzel blended foil prop on our Glasair 2S FT-!0360 200 HP engine. We flew the plane with a light cross wind this time and noted a shorter take off roll from the runway end threshold to the hash marks. This time we noted that full take off RPM had settled down to 2600 rpm and that the fluctuating RPM we had on our first flights may have been due to either the prop purging itself of a little air or the oil being a bit warmer. Our last prop required adjusting the hub stop to get 2750 rpm. We climbed to 6,500 feet at a 140 mph indicated airspeed and noted this new prop provided a much higher rate of climb than our old prop did. Once at altitude we flew West at 6,500 feet with 24 inches manifold pressure, 2450 RPM and 50 degrees lean of peak for fifteen miles and recorded GPS ground cruise speeds of 214 mph in one direction and 204 mph on the return course that averaged out to 209 mph and noted an increase of around 15 mph over our old cruise speed. This increase in air speed was a bit lower than the twenty mph increase we noted at 3,000 feet. But this may have been do to slightly warmer temperatures and saturated air from a rain system that was moving in. The visibility for this flight was limited and no were near the crystal clear air we had on our first two tests flights and that may have been the cause. We also noted with our old prop that increasing the RPM over 2350 rpm didn't add to the air speed, but increasing the rpm with the new blended foil did increase airspeed all the way up to 2475 rpm. My guess for this is that the new blended foil has far more bite at higher rpm's than our old prop did. When the weather cooperates we will shoot for 8,500 feet on hopefully a clear day. > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 05, 2010
The prop I had before was a 72" Hartzel constant speed prop that was recommended and sold through Glasair Corp and was recommended for 180/2-00 hp Lyc. It didn't have a name, just serial numbers. Our new prop is a 72 inch constant speed "Blended Foil" prop. My home base builder bolted one on his RV 9 and noted a 10 mph increase in cruise speed. I think my greater performance was due to my plane not being completely stream lined in cruise and with the added thrust this prop produces I had an increase in cruise speed greater than 10 mph ranging between 15 to 20 mph. I have only recorded three short flights with this new Blended Foil design and with the arrival of spring I will be making more cross country flights and will report what I see. As a side note, I placed my prop for sale in Trade A Plane and it sold within two weeks to a Mooney driver. His prop hub was worn out and a prop shop wanted close to $4,000 for a new hub and several thousand dollars for two serviceable blades because one of his blades could no longer be dressed. My old prop had less than 600 hours and after being inspected by a prop shop, determined all it needed was inspection, paint and fresh seals and grease. This Mooney driver would have had to pay $10,300 for a new prop and was happy to find mine for half the price. Also, if you own a low time prop in excellent condition like mine was, I was offered $3,000 by a prop shop. Glasair supplies this new Blended Foil prop for $6,600. They installed one on their factory Glasair Super 2S and noted a 7 mph increase. In a message dated 3/4/2010 9:26:31 P.M. Eastern Standard Time, dralle(at)matronics.com writes: --> Glasair-List message posted by: Matt Dralle Nice report. What was the "old" prop you had? Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com Matt's Building Blog Finishing Up... At 03:27 PM 3/4/2010 Thursday, you wrote: >We had another chance to test our new Hartzel blended foil prop on our Glasair 2S FT-!0360 200 HP engine. We flew the plane with a light cross wind this time and noted a shorter take off roll from the runway end threshold to the hash marks. This time we noted that full take off RPM had settled down to 2600 rpm and that the fluctuating RPM we had on our first flights may have been due to either the prop purging itself of a little air or the oil being a bit warmer. Our last prop required adjusting the hub stop to get 2750 rpm. We climbed to 6,500 feet at a 140 mph indicated airspeed and noted this new prop provided a much higher rate of climb than our old prop did. Once at altitude we flew West at 6,500 feet with 24 inches manifold pressure, 2450 RPM and 50 degrees lean of peak for fifteen miles and recorded GPS ground cruise speeds of 214 mph in one direction and 204 mph on the return course that averaged out to 209 mph and noted an increase of around 15 mph over our old c! ruise speed. This increase in air speed was a bit lower than the twenty mph increase we noted at 3,000 feet. But this may have been do to slightly warmer temperatures and saturated air from a rain system that was moving in. The visibility for this flight was limited and no were near the crystal clear air we had on our first two tests flights and that may have been the cause. We also noted with our old prop that increasing the RPM over 2350 rpm didn't add to the air speed, but increasing the rpm with the new blended foil did increase airspeed all the way up to 2475 rpm. My guess for this is that the new blended foil has far more bite at higher rpm's than our old prop did. When the weather cooperates we will shoot for 8,500 feet on hopefully a clear day. > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 09, 2010
Subject: Hartzell Blended Foil
Sunday we flew our Glasair2S FT 200 HP Lyc again with our new Hartzell Blended foil prop and noted the following: We flew in Moderate Chop , 75 degrees OAT and with five mile visibility in moisture laden air. For the third time, we noted a less than a five hundred foot take off roll at 2600 rpm. We hadn't yet adjusted the prop pitch stop to 2750 rpm and feel that both roll out and climb performance will increase once we make that adjustment. On this flight, rather than tell LISTERS that we noted better climb performance, we decided to jot down the numbers. With a 1,690 pound gross weight and after departing our air port and retracting the flaps we pulled the nose up to an indicated airspeed of 90 mph, 2600 rpm and full rich and recorded a 2,000 foot per minute rate of climb through 1,000 feet above sea level from our home base field that is 725 feet above sea level. Upon reaching 1,200 feet we noted at 90 mph we still had a 2,000 FPM climb rate to 1,500 feet above sea level using the same power settings. While climbing through 1,800 feet we increased our indicated air speed by lowering the nose to 140 mph and reduced the rpm to 2400 and our climb rate dropped down to 1,000 FPM. Our cylinder head temperature never exceeded 330 degrees. We climbed at 1,000 foot per minute @2400 rpm until we reached 6,500 feet and our oil temperature peaked at 212 degrees and once established in cruise our oil temperature dropped to 190 degrees. Our altitude was only 1,000 feet higher than it was on our last flight and averaged 7,000 feet and because of rough air our ground speed averaged 205 mph and was 10 mph less than it was on our last flight. In years past I used to reduce the power after take off with the throttle in an effort to keep our oil temperatures down. That was until I learned that Bendix fuel injection systems have a throttle body jet that keeps the cylinders cool under full throttle and to reduce power by reducing RPM!! Once I employed that method, that ended hot oil temperatures on climb out. I also once belonged to a Gruman Tiger flying club that would sometimes burn out jugs until Grumman issued a notice advising to not have long sustained steep climb outs. To avoid that, we use a cruise climb speed of 160 mph on our Glasair that not only provides for better cooling but better fuel economy and performance. When my son flew piston engine planes his company had a policy of not reducing power more than 3 inches for several minutes at a time to avoid shock cooling and we use that method when coming out of altitude for landings. Chuck Raymond N16CD ________________________________________________________________________________
Date: Mar 24, 2010
Subject: Glasair FT for sale
The fastest way to own a fast airplane! Glasair II FT for sale. 200+ MPH max. 190 MPH economy cruse at 7.2 GPH! This Glasair is a fast, reliable, easy to fly IFR cross country machine. Full IFR with stability mods in pitch & roll plus Autopilot. With 3000 hours on the airframe, the bugs have been worked out and the maintenance is very predictable. Good for another 3000 hours! Based in Phoenix, Arizona. $70,000 USD. Please see http://glasairforsale.freevar.com/ for details. Mike <>< ________________________________________________________________________________
Date: Mar 25, 2010
Subject: Re: Glasair-List Digest: 1 Msgs - 03/24/10
Mike, In the past, I have seen Glasair 2's listed well over $100,000. Too bad you have to sell your plane during a depression. In a message dated 3/25/2010 5:48:29 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-03-24&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-03-24&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Wed 03/24/10: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 02:15 AM - Glasair FT for sale () ________________________________ Message 1 _____________________________________ From: <glasairpilot(at)cox.net> Subject: Glasair-List: Glasair FT for sale The fastest way to own a fast airplane! Glasair II FT for sale. 200+ MPH max. 190 MPH economy cruse at 7.2 GPH! This Glasair is a fast, reliable, easy to fly IFR cross country machine. Full IFR with stability mods in pitch & roll plus Autopilot. With 3000 hours on the airframe, the bugs have been worked out and the maintenance is very predictable. Good for another 3000 hours! Based in Phoenix, Arizona. $70,000 USD. Please see http://glasairforsale.freevar.com/ for details. Mike <>< ________________________________________________________________________________
Subject: brake cylinder
Date: Apr 04, 2010
I have a TD1 with dual brake installation, and it appears that one toe brake cylinder is starting to weep around the oring. As I did not build the aircraft, I do not know where to find parts, and unfortunately, after hours of trying to read the numbers off the cylinder, and borrowing friends kids to see if they would fit any better, and be able to read any better than I, I have given up. I am hoping someone can tell me if I can purchase an oring and replace it, or if I need to purchase an entire assembly. All that I have been able to make out is Model 10-1 ? 0 The consensus has been that the ? is either an 8 or a 9. Any help would be greatly appreciated. Thanks; Shona ________________________________________________________________________________
Date: Apr 04, 2010
Subject: Re: brake cylinder
Shona, This is probably a Clevland part number. Any way you look at it, it will have to be removed to repair it. Most manufacturers use common o-rings and replacing them is quite easy. Good luck BRIAN ALLEY (N320WT) =0ACARBON FIBER COMPOSITES =0A101 Caroline Circle =0AHurricane, WV 25526 =0Awww.carbonfibercomposites.net =0A304-562-6800 home =0A304-395-4932 cell =0A =0AHow are you going to win by a nose if you don't stick out your neck? --- On Sun, 4/4/10, Helicat wrote: From: Helicat <helicat76(at)shaw.ca> Subject: Glasair-List: brake cylinder Date: Sunday, April 4, 2010, 4:01 AM =0A=0A=0A =0A =0A=0A=0A=0A=0A =0A=0A=0A=0AI have a TD1 with dual brake inst allation, and it appears=0Athat one toe brake cylinder is starting to weep around the oring.- As I=0Adid not build the aircraft, I do not know where to find parts, and=0Aunfortunately, after hours of trying to read the numb ers off the cylinder, and=0Aborrowing friends kids to see if they would fit any better, and be able to read=0Aany better than I, I have given up.- I am hoping someone can tell me if I=0Acan purchase an oring and replace it, or if I need to purchase an entire=0Aassembly.- All that I have been abl e to make out is Model 10-1 ? 0-=0AThe consensus has been that the ? is e ither an 8 or a 9. =0A=0AAny help would be greatly appreciated. =0A=0AThank =======0A=0A ________________________________________________________________________________
Date: Apr 04, 2010
Thank you Brian, very much appreciated! Shona _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Brian Alley Sent: Sunday, April 04, 2010 4:06 AM Subject: Re: Glasair-List: brake cylinder Shona, This is probably a Clevland part number. Any way you look at it, it will have to be removed to repair it. Most manufacturers use common o-rings and replacing them is quite easy. Good luck BRIAN ALLEY (N320WT) CARBON FIBER COMPOSITES 101 Caroline Circle Hurricane, WV 25526 www.carbonfibercomposites.net 304-562-6800 home 304-395-4932 cell How are you going to win by a nose if you don't stick out your neck? --- On Sun, 4/4/10, Helicat wrote: From: Helicat <helicat76(at)shaw.ca> Subject: Glasair-List: brake cylinder Date: Sunday, April 4, 2010, 4:01 AM I have a TD1 with dual brake installation, and it appears that one toe brake cylinder is starting to weep around the oring. As I did not build the aircraft, I do not know where to find parts, and unfortunately, after hours of trying to read the numbers off the cylinder, and borrowing friends kids to see if they would fit any better, and be able to read any better than I, I have given up. I am hoping someone can tell me if I can purchase an oring and replace it, or if I need to purchase an entire assembly. All that I have been able to make out is Model 10-1 ? 0 The consensus has been that the ? is either an 8 or a 9. Any help would be greatly appreciated. Thanks; Shona Checked by AVG - www.avg.com 11:32:00 ________________________________________________________________________________
Date: Apr 04, 2010
Subject: Re: Glasair-List Digest: 0 Msgs - 04/03/10
A few years back I spotted brake fluid on my hanger floor and found it was coming out of a brake caliper. So I went to my friendly Ace hardware store and replaced the piston "O" ring with a new one and it has worked fine for the past three years or so..In a message dated 4/4/2010 3:05:11 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-04-03&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-04-03&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Sat 04/03/10: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Apr 04, 2010
Thanks, I appreciate the info. I think that Brian was right, it appears that the toe brakes are Cleveland brake cylinders. The parts manual appears to look the same for model #10-19, and the oring kit is listed for the cylinder. As you mentioned, I have had problems with the plastic brake lines that go into the calipers, they seem to get hot, and expand, causing weeping, and required constant trimming and bleeding. I also went to the local hardware store and installed a 'buffer' between the plastic lines and the caliper. I basically use a high pressure grease gun hose that threads directly into the brake caliper, and requires little to adapt the other end. That has worked wonderfully, and I do not need to trim anymore lines. Recently, I have discovered that a local hydraulic supplier will make the same hoses with certified hydraulic hose for almost the same price. Cheers; Shona _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Sunday, April 04, 2010 7:00 PM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 04/03/10 A few years back I spotted brake fluid on my hanger floor and found it was coming out of a brake caliper. So I went to my friendly Ace hardware store and replaced the piston "O" ring with a new one and it has worked fine for the past three years or so..In a message dated 4/4/2010 3:05:11 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-04-03&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-04-03&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Sat 04/03/10: 0 ---------------------------------------------------------- Today's Message ================================================e the ties Day ================================================ - MATRONICS WEB FORUMS =============================================== - List Contribution Web Site sp; ================================================== ________________________________________________________________________________
Date: Apr 14, 2010
Subject: GL 11 FT nose wheel.
I have always had a vibration from my nose strut and as the tire wore down it would become even more noticeable. When I related this to an A&P he asked if I balanced my nose wheel? So I decided to purchase a new tire, mount it and have it balanced. This tiny wheel took well over four ounces to balance!! Another hint is that Chin tires are notorious for being out of round so be sure to check for the tire being out of round. After installing the wheel assembly and test flying the plane, for the first time I felt I was landing on glass!! I have been reporting on my new Blended Foil prop and was able to adjust the hub to get it up to 2750 RPM. After making that adjustment the new prop had so much P factor I could hardly keep the plane on the center line when I added full power. Witnesses say the plane only rolls a short distance before it appears to leap off the runway. After take off I have to apply full right rudder and aileron to keep the plane and haven't seen that since I flew my little 215 Hp S1S Pitts Special. The increased cruise performance appears to be keeping in the added 15 to 20 mph ground speed along with a higher rate of climb. With these warmer temperatures I have been noticing that my oil temperatures have been running hotter than usual with this new prop. Before the new prop my oil temperature ranged between 190 to 200 degrees during the summer months. But with the upper seventy to low eighty degree outside temps I am now flying in I am seeing oil temps in the 200/215 range at altitudes below 3,000 feet. I find slowing the plane down before entering the airport traffic area to 100 mph the oil temperature shoots up. But if I keep the cruise up to over 140 mph and slow the plane down in the down wind the oil temp doesn't shoot up as quickly. I haven't been able to figure out if this is because the new prop works the engine harder or if because of the design that less air is blown into the cowling. One other hint in keeping cylinder and oil temps down on climb out is to maintain full throttle on injected engines. There is a jet in the throttle body that dumps extra fuel on full throttle. To reduce power use your prop control on climb out. After take off and reaching 600 feet I adjust the RPM back to 2550 RPM and climb another few hundred feet and adjust it to 2450 rpm before setting everything when I reach my cruise settings and altitude and have found that keeps my temperatures cooler. ________________________________________________________________________________
Date: Apr 15, 2010
Subject: Re: Glasair-List Digest: 1 Msgs - 04/14/10
I too have noticed "shimmy" when Aircraft Spruce changed over to the Chinese nose tire (Shin). Keeping it inflated to the max helps a lot. (I replaced the friction pad last year too, which helped a lot. 3000 hrs.) Where does one get a balancer? Are there alternative sources for this tire. Desser? I forget the size of the nose gear just now, but I see Desser has oddball sizes. http://www.desser.com/tailwheel.shtml Would be worth paying a little more to have the smoothness. Mike Palmer <>< > ---------------------- > > 1. 08:15 AM - GL 11 FT nose wheel. (Craymondw(at)aol.com) > > > > ________________________________ Message 1 _____________________________________ > > > From: Craymondw(at)aol.com > Subject: Glasair-List: GL 11 FT nose wheel. > > I have always had a vibration from my nose strut and as the tire wore down > it would become even more noticeable. When I related this to an A&P he > asked if I balanced my nose wheel? So I decided to purchase a new tire, mount > > it and have it balanced. This tiny wheel took well over four ounces to > balance!! Another hint is that Chin tires are notorious for being out of round > > so be sure to check for the tire being out of round. After installing the > wheel assembly and test flying the plane, for the first time I felt I was > landing on glass!! > I have been reporting on my new Blended Foil prop and was able to > adjust the hub to get it up to 2750 RPM. After making that adjustment the new > > prop had so much P factor I could hardly keep the plane on the center line > when I added full power. Witnesses say the plane only rolls a short distance > before it appears to leap off the runway. After take off I have to apply > full right rudder and aileron to keep the plane and haven't seen that since I > > flew my little 215 Hp S1S Pitts Special. The increased cruise performance > appears to be keeping in the added 15 to 20 mph ground speed along with a > higher rate of climb. With these warmer temperatures I have been noticing > that my oil temperatures have been running hotter than usual with this new > prop. Before the new prop my oil temperature ranged between 190 to 200 > degrees during the summer months. But with the upper seventy to low eighty degree > > outside temps I am now flying in I am seeing oil temps in the 200/215 > range at altitudes below 3,000 feet. I find slowing the plane down before > entering the airport traffic area to 100 mph the oil temperature shoots up. But > > if I keep the cruise up to over 140 mph and slow the plane down in the > down wind the oil temp doesn't shoot up as quickly. I haven't been able to > figure out if this is because the new prop works the engine harder or if > because of the design that less air is blown into the cowling. One other hint > > in keeping cylinder and oil temps down on climb out is to maintain full > throttle on injected engines. There is a jet in the throttle body that dumps > extra fuel on full throttle. To reduce power use your prop control on climb > out. After take off and reaching 600 feet I adjust the RPM back to 2550 RPM > and climb another few hundred feet and adjust it to 2450 rpm before setting > everything when I reach my cruise settings and altitude and have found > that keeps my temperatures cooler. > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2010
Take your wheel to a motorcycle shop. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of glasairpilot(at)cox.net Sent: Thursday, April 15, 2010 3:29 PM Subject: Glasair-List: Re: Glasair-List Digest: 1 Msgs - 04/14/10 I too have noticed "shimmy" when Aircraft Spruce changed over to the Chinese nose tire (Shin). Keeping it inflated to the max helps a lot. (I replaced the friction pad last year too, which helped a lot. 3000 hrs.) Where does one get a balancer? Are there alternative sources for this tire. Desser? I forget the size of the nose gear just now, but I see Desser has oddball sizes. http://www.desser.com/tailwheel.shtml Would be worth paying a little more to have the smoothness. Mike Palmer <>< > ---------------------- > > 1. 08:15 AM - GL 11 FT nose wheel. (Craymondw(at)aol.com) > > > > ________________________________ Message 1 _____________________________________ > > > From: Craymondw(at)aol.com > Subject: Glasair-List: GL 11 FT nose wheel. > > I have always had a vibration from my nose strut and as the tire wore down > it would become even more noticeable. When I related this to an A&P he > asked if I balanced my nose wheel? So I decided to purchase a new tire, mount > > it and have it balanced. This tiny wheel took well over four ounces to > balance!! Another hint is that Chin tires are notorious for being out of round > > so be sure to check for the tire being out of round. After installing the > wheel assembly and test flying the plane, for the first time I felt I was > landing on glass!! > I have been reporting on my new Blended Foil prop and was able to > adjust the hub to get it up to 2750 RPM. After making that adjustment the new > > prop had so much P factor I could hardly keep the plane on the center line > when I added full power. Witnesses say the plane only rolls a short distance > before it appears to leap off the runway. After take off I have to apply > full right rudder and aileron to keep the plane and haven't seen that since I > > flew my little 215 Hp S1S Pitts Special. The increased cruise performance > appears to be keeping in the added 15 to 20 mph ground speed along with a > higher rate of climb. With these warmer temperatures I have been noticing > that my oil temperatures have been running hotter than usual with this new > prop. Before the new prop my oil temperature ranged between 190 to 200 > degrees during the summer months. But with the upper seventy to low eighty degree > > outside temps I am now flying in I am seeing oil temps in the 200/215 > range at altitudes below 3,000 feet. I find slowing the plane down before > entering the airport traffic area to 100 mph the oil temperature shoots up. But > > if I keep the cruise up to over 140 mph and slow the plane down in the > down wind the oil temp doesn't shoot up as quickly. I haven't been able to > figure out if this is because the new prop works the engine harder or if > because of the design that less air is blown into the cowling. One other hint > > in keeping cylinder and oil temps down on climb out is to maintain full > throttle on injected engines. There is a jet in the throttle body that dumps > extra fuel on full throttle. To reduce power use your prop control on climb > out. After take off and reaching 600 feet I adjust the RPM back to 2550 RPM > and climb another few hundred feet and adjust it to 2450 rpm before setting > everything when I reach my cruise settings and altitude and have found > that keeps my temperatures cooler. > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2010
The Chin tire costs about $18. Aircraft Spruce has a premium tire for $46.00. In a message dated 4/15/2010 3:59:50 P.M. Eastern Daylight Time, glasairpilot(at)cox.net writes: --> Glasair-List message posted by: I too have noticed "shimmy" when Aircraft Spruce changed over to the Chinese nose tire (Shin). Keeping it inflated to the max helps a lot. (I replaced the friction pad last year too, which helped a lot. 3000 hrs.) Where does one get a balancer? Are there alternative sources for this tire. Desser? I forget the size of the nose gear just now, but I see Desser has oddball sizes. http://www.desser.com/tailwheel.shtml Would be worth paying a little more to have the smoothness. Mike Palmer <>< > ---------------------- > > 1. 08:15 AM - GL 11 FT nose wheel. (Craymondw(at)aol.com) > > > > ________________________________ Message 1 _____________________________________ > > > From: Craymondw(at)aol.com > Subject: Glasair-List: GL 11 FT nose wheel. > > I have always had a vibration from my nose strut and as the tire wore down > it would become even more noticeable. When I related this to an A&P he > asked if I balanced my nose wheel? So I decided to purchase a new tire, mount > > it and have it balanced. This tiny wheel took well over four ounces to > balance!! Another hint is that Chin tires are notorious for being out of round > > so be sure to check for the tire being out of round. After installing the > wheel assembly and test flying the plane, for the first time I felt I was > landing on glass!! > I have been reporting on my new Blended Foil prop and was able to > adjust the hub to get it up to 2750 RPM. After making that adjustment the new > > prop had so much P factor I could hardly keep the plane on the center line > when I added full power. Witnesses say the plane only rolls a short distance > before it appears to leap off the runway. After take off I have to apply > full right rudder and aileron to keep the plane and haven't seen that since I > > flew my little 215 Hp S1S Pitts Special. The increased cruise performance > appears to be keeping in the added 15 to 20 mph ground speed along with a > higher rate of climb. With these warmer temperatures I have been noticing > that my oil temperatures have been running hotter than usual with this new > prop. Before the new prop my oil temperature ranged between 190 to 200 > degrees during the summer months. But with the upper seventy to low eighty degree > > outside temps I am now flying in I am seeing oil temps in the 200/215 > range at altitudes below 3,000 feet. I find slowing the plane down before > entering the airport traffic area to 100 mph the oil temperature shoots up. But > > if I keep the cruise up to over 140 mph and slow the plane down in the > down wind the oil temp doesn't shoot up as quickly. I haven't been able to > figure out if this is because the new prop works the engine harder or if > because of the design that less air is blown into the cowling. One other hint > > in keeping cylinder and oil temps down on climb out is to maintain full > throttle on injected engines. There is a jet in the throttle body that dumps > extra fuel on full throttle. To reduce power use your prop control on climb > out. After take off and reaching 600 feet I adjust the RPM back to 2550 RPM > and climb another few hundred feet and adjust it to 2450 rpm before setting > everything when I reach my cruise settings and altitude and have found > that keeps my temperatures cooler. > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2010
The A&P that balanced my nose wheel used a rod that slid through the inner races. The rod had two conical shaped attachments that screwed up against both inner races. The outer ends of the rod had bearings that rested between two tripods. After setting the wheel in the jig the tire's heavy end spun down and by trial and error, he was able to stick on the exact weight onto the rim to balance it. I have seen these wheel balancers I think, in Aircraft Tool Supply company catalogs. I rolled out the tire over a yard stick and found it only rolls 34 inches to complete one revolution. If you factor in how many revolutions that tire makes between 65 mph and even 20 mph, it wouldn't surprise me if the four ounces out of balance my wheel was and considering centrifugal force dynamics, that four ounces could factor out to be several hundred pounds of out of balance force. t In a message dated 4/15/2010 4:10:27 P.M. Eastern Daylight Time, bgray(at)glasair.org writes: --> Glasair-List message posted by: "Bruce Gray" Take your wheel to a motorcycle shop. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of glasairpilot(at)cox.net Sent: Thursday, April 15, 2010 3:29 PM Subject: Glasair-List: Re: Glasair-List Digest: 1 Msgs - 04/14/10 --> Glasair-List message posted by: I too have noticed "shimmy" when Aircraft Spruce changed over to the Chinese nose tire (Shin). Keeping it inflated to the max helps a lot. (I replaced the friction pad last year too, which helped a lot. 3000 hrs.) Where does one get a balancer? Are there alternative sources for this tire. Desser? I forget the size of the nose gear just now, but I see Desser has oddball sizes. http://www.desser.com/tailwheel.shtml Would be worth paying a little more to have the smoothness. Mike Palmer <>< > ---------------------- > > 1. 08:15 AM - GL 11 FT nose wheel. (Craymondw(at)aol.com) > > > > ________________________________ Message 1 _____________________________________ > > > From: Craymondw(at)aol.com > Subject: Glasair-List: GL 11 FT nose wheel. > > I have always had a vibration from my nose strut and as the tire wore down > it would become even more noticeable. When I related this to an A&P he > asked if I balanced my nose wheel? So I decided to purchase a new tire, mount > > it and have it balanced. This tiny wheel took well over four ounces to > balance!! Another hint is that Chin tires are notorious for being out of round > > so be sure to check for the tire being out of round. After installing the > wheel assembly and test flying the plane, for the first time I felt I was > landing on glass!! > I have been reporting on my new Blended Foil prop and was able to > adjust the hub to get it up to 2750 RPM. After making that adjustment the new > > prop had so much P factor I could hardly keep the plane on the center line > when I added full power. Witnesses say the plane only rolls a short distance > before it appears to leap off the runway. After take off I have to apply > full right rudder and aileron to keep the plane and haven't seen that since I > > flew my little 215 Hp S1S Pitts Special. The increased cruise performance > appears to be keeping in the added 15 to 20 mph ground speed along with a > higher rate of climb. With these warmer temperatures I have been noticing > that my oil temperatures have been running hotter than usual with this new > prop. Before the new prop my oil temperature ranged between 190 to 200 > degrees during the summer months. But with the upper seventy to low eighty degree > > outside temps I am now flying in I am seeing oil temps in the 200/215 > range at altitudes below 3,000 feet. I find slowing the plane down before > entering the airport traffic area to 100 mph the oil temperature shoots up. But > > if I keep the cruise up to over 140 mph and slow the plane down in the > down wind the oil temp doesn't shoot up as quickly. I haven't been able to > figure out if this is because the new prop works the engine harder or if > because of the design that less air is blown into the cowling. One other hint > > in keeping cylinder and oil temps down on climb out is to maintain full > throttle on injected engines. There is a jet in the throttle body that dumps > extra fuel on full throttle. To reduce power use your prop control on climb > out. After take off and reaching 600 feet I adjust the RPM back to 2550 RPM > and climb another few hundred feet and adjust it to 2450 rpm before setting > everything when I reach my cruise settings and altitude and have found > that keeps my temperatures cooler. > > > > > > > > > ________________________________________________________________________________
Subject: Zenair aircraft FLOATS
Date: May 06, 2010
I have had quite a few Glasair customers contact me in regards to floats. Here are typical questions and answers. - Does Zenair manufacture a 2200 lbs float? Yes, straight and amphibious. - Factory built or kits? Both. You can purchase a parts kit or pre-drilled kit or factory built. - Prices? www.zenairfloats.com will give you the latest prices. - What type of retracting system? Option of electric or hand pump. System is hydraulic and 100% external so no need to ever open the floats. Main wheels are 600x6 Grove type with a 400X4 at the front. - How do I mount the floats to my aircraft? Zenair supplies a rigging / spreader bar kit. However, you need to have the mounting points on your aircraft. - Are these the same 2200 floats as what the Czech company used to sell? Yes, the Zenair floats were first designed by Zenair in the 1980's and production went to the Czech's in the late 1990's. Zenair has taken back the float production and has made some changes to the floats as to make them easier to build. The Czech company was not selling kits so they got very complex. Now that Zenair is selling kits, its important that they are easy to assemble. - Where do I get more info on this. Please contact me, Mathieu Heintz at 705-526-2871 or by email at newplane(at)gmail.com I do not often get the opportunity get on this forum site. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296944#296944 Attachments: http://forums.matronics.com//files/4s_114.jpg ________________________________________________________________________________
Date: May 06, 2010
Subject: Re: Zenair aircraft FLOATS
On 05/06/2010 01:29 PM, Zenair_Mathieu wrote: > > I have had quite a few Glasair customers contact me in regards to floats. Here are typical questions and answers. > > - Does Zenair manufacture a 2200 lbs float? > Yes, straight and amphibious. > Hi, Glasair is no longer selling the Glastar which had the 2200 lb gross. The current kit is the Sportsman 2+2, which has a 2500 lb gross when on floats. Do you sell a 2500 float that would work on the Sportsman? Thanks, -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the Maine Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: May 06, 2010
Hi DJ, Zenair is only manufacturing the 2200 floats right now. Since there are quite a few Glastar's out there, there is a lot of interest. If Zenair gets enough interest for 2500 floats, Zenair will start offering them. About half the price of certified, lighter, as tough and excellent performance. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296964#296964 ________________________________________________________________________________
Date: May 06, 2010
On 05/06/2010 02:35 PM, Zenair_Mathieu wrote: > Hi DJ, > Zenair is only manufacturing the 2200 floats right now. Since there are quite a few Glastar's out there, there is a lot of interest. > If Zenair gets enough interest for 2500 floats, Zenair will start offering them. About half the price of certified, lighter, as tough and excellent performance. I'm building a Sportsman 2+2 that I hope to have on amphib floats one day, so please mark me down as the first interested person. :-) Thanks, -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the Maine Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: May 06, 2010
DJ, I'm building (from plans, Zenith used to offer all the different float sizes in plans only as well) a set of 1100 amphib Zenith floats for the 701 in the shop, VERY easy to build, good directions. You will enjoy working with Zenith. John Bolding ----- Original Message ----- From: "Dj Merrill" <deej(at)deej.net> Sent: Thursday, May 06, 2010 1:47 PM Subject: Re: Glasair-List: Re: Zenair aircraft FLOATS > > I'm building a Sportsman 2+2 that I hope to have on amphib floats one > day, so please mark me down as the first interested person. :-) > > Thanks, > > -Dj > > -- > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Grumman Yankee Driver N9870L - http://deej.net/yankee/ > Join us on the Maine Aviation Forums - http://forum.deej.net/ > > > ________________________________________________________________________________
Subject: Electronic Circuit Breakers on your EFIS
Date: May 11, 2010
Vertical Power, along with its EFIS partners, recently announced the VP-X Electronic Circuit Breaker System. The VP-X uses proven electronic circuit breakers to simplify wiring and provide advanced electrical system capabilities. Monitor the status of individual devices and the entire electrical system right from your EFIS. Avionics, lights, trim, and flaps can all be controlled using standard switches or the EFIS. The VP-X works with Advanced Flight Systems, Grand Rapids Technologies HX and HX Sport, and MGL Voyager/Odyssey Gen 2 EFIS products. Click to learn more. http://www.verticalpower.com/VPX.html -------- Marc Ausman http://www.verticalpower.com "Move up to a modern electrical system" RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=297360#297360 ________________________________________________________________________________
Subject: ready at last
Date: May 26, 2010
Super IIS RG came in @ 1342 lbs ,,have done high speed taxi test,, feels good. Have a oil leak to find & the final inspection & then go from kit to airplane..nose w is193,,,Left is 484 & right is 472 ,,,It has the extra fuel bay in wing behind spar .Can anyone do the w/b for this header tank holds 10 gals. wing -------? I may have to fill to find out what it is... Randy Pinkston N71RP @ kafp anson county n.c. ________________________________________________________________________________
Date: May 26, 2010
Subject: Re: ready at last
Your plane came out light for a Super2S RG. In order to do a weight and balance you have to measure the distance from the fire wall forward 58 inches (sta 0.0) and back from that point to the nose wheel center line (X). Then measure from the mains center line to sta 0.0 (Y) Once you have thos e numbers you can do a weight and balance. I have a 200 hp, constant speed prop and an IFR panel in my 2S and my nose wheel weight is 273 lbs and the mains were 1,026 lbs. I have a baggage limit of 130 pounds. S.H. had a ta il heavy problem with the 2S when small engines with wood props were used an d solved it with the Super 2S. The Super 2S has a longer distance from the MAC to the fire wall and a larger stab. That heavier main may give you a turn and I solved that by adding a few pounds of lead shot and resin to one wi ng end. To avoid bouncing the nose wheel hard, on your first test flight I would perform a power on landing. I come over the fence at 90 mph and lev el off over the runway to let the speed dissipate then slowly come in with power to gently let my plane down. I just installed a blended foil prop and in very hot humid weather I added ten miles per hour to my already 200mph+ cruise speed. In a message dated 5/26/2010 10:40:07 A.M. Eastern Daylight Time, pinkston(at)carolina.rr.com writes: Super IIS RG came in @ 1342 lbs ,,have done high speed taxi test, feels good. Have a oil leak to find & the final inspection & then go from kit to airplanenose w is193,,,Left is 484 & right is 472 ,,,It has the extra fuel bay in wing behind spar Can anyone do the w/b for this he ader tank holds 10 gals. wing -------? I may have to fill to find out what it is .. Randy Pinkston N71RP @ kafp anson county n.c. ________________________________________________________________________________
Date: May 26, 2010
Randy, I have the pilot's operating handbook for the Super IIS and just got the handbook for my IIS- FT from Glasair for $45 plus shipping. Would send you the Super IIS handbook for $35 plus shipping if you are interested. It 's a very well done handbook so would be nice to have. Jack, almost ready for inspection in Camp Verde, AZ --- On Wed, 5/26/10, Randy Pinkston wrote: From: Randy Pinkston <pinkston(at)carolina.rr.com> Subject: Glasair-List: ready at last Date: Wednesday, May 26, 2010, 8:29 AM =0A=0A=0A =0A=0A=0A =0A=0A=0A=0A=0A=0A=0A=0ASuper IIS RG came in @ 1342 lbs ,,have done high speed taxi=0Atest,, feels good.=C2- Have a oil leak to find & the final inspection=0A& then go from kit to airplane nose w is193,,,Left is 484=0A& right is 472 ,,,It has the extra fuel bay in wing behind spar Can=0Aanyone do the w/b for this=C2-=C2- header tank holds 10 gals. wing -------?=0AI may have to fill to find out w hat it is.. Randy Pinkston N71RP @ kafp=0Aanson county=C2- n.c. =0A=0A=0A=0A =0A=0A=0A=0A=0A ________________________________________________________________________________
Subject: FS: Middle Tennessee Airstrip with home/hangar and more!
Date: Jun 01, 2010
Always trying to play to a new crowd, I got to thinking. Who would be interested (besides every day Cessna Pilots) in living in a home with it's own airstrip. Dawned on me that someone who BUILD aircraft would love this place even more. HUGE 60X90 hangar, attached to a 3000 sf contemporary home. One could tinker and work on their airplane at all hours. If you are interested in learning more, I have built a website for my friends to showcase this property. It is, for sale by owner. $539,000 for the home/hangar/airstrip that includes 21.15 acres of pristine pilot paradise. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299602#299602 Attachments: http://forums.matronics.com//files/26_104.jpg ________________________________________________________________________________
Date: Jun 01, 2010
Subject: Re: FS: Middle Tennessee Airstrip with home/hangar and more!
At that price I would prefer to take the fifteen minute drive and trailer my plane home and work on it in my large $2,000 heated shed. Knowing Tennessee property taxes, I am sure they far exceed what I pay annually for a hanger!!! In a message dated 6/1/2010 2:42:30 P.M. Eastern Daylight Time, longmeadowfarm(at)aol.com writes: --> Glasair-List message posted by: "Ratherfly" Always trying to play to a new crowd, I got to thinking. Who would be interested (besides every day Cessna Pilots) in living in a home with it's own airstrip. Dawned on me that someone who BUILD aircraft would love this place even more. HUGE 60X90 hangar, attached to a 3000 sf contemporary home. One could tinker and work on their airplane at all hours. If you are interested in learning more, I have built a website for my friends to showcase this property. It is, for sale by owner. $539,000 for the home/hangar/airstrip that includes 21.15 acres of pristine pilot paradise. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299602#299602 Attachments: http://forums.matronics.com//files/26_104.jpg ________________________________________________________________________________
Date: Jun 14, 2010
http://longmeadow.vflyer.com/home/flyer/home/3291623 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301133#301133 ________________________________________________________________________________
Date: Jun 14, 2010
Subject: Re: Blended foil prop
Although I am having better performance with my new blended foil prop, the down side is higher oil temperatures. My cylinder head temperatures still remain below 300 degrees, but my oil temperature has climbed from 190 degrees to close to 220 degrees. It was suggested I install a very expensive Airwolf or ADC spin on remote oil filter system with claims it will bring my oil temp down 15 degrees. Another suggested adding another small oil cooler. But I wondered if that would lower my oil pressure. I don't know if my oil temperature jumped up because this prop pulls harder or if it spoils the air flowing into my cowling. Any suggestions?!! PS: Wentworth Air Salvage quoted me a price for an Airwolf out of a wreck without hoses and filter for close to what AC Spruce sells a new complete kit for!! Chuck Raymond Glasair2S In a message dated 6/13/2010 3:04:43 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-06-12&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-06-12&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Sat 06/12/10: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Jun 15, 2010
Subject: Re: Glasair-List Digest: 2 Msgs - 06/14/10
- - Chuck, is the oil cooler air coming from inside the top cowling space over the heads, or do you have a separate NACA duct for this? Also, you need to look at the air flow into and through the cooler. The tra nsitions should be smooth, not abrupt, and open generously. You can ram too much air into an otherwise fine cooler setup. Jamming eqals turbulence and lower air flow with far less efficiency over the heat exchanger. - - Another consideration. It is OK to have excess power for takeoff, then thro ttle back and climb slower / fly at reduced power, especially in hotter wea ther. Many certified craft do this, especially turbo charged engines and tu rbines. - Or just fly higher in cooler air! - - Deep peace of the Light of the World to you. ------------------------- ------------------------ -- A Gaelic Blessing --- On Tue, 6/15/10, Glasair-List Digest Server wrote: From: Glasair-List Digest Server <glasair-list(at)matronics.com> Subject: Glasair-List Digest: 2 Msgs - 06/14/10 Date: Tuesday, June 15, 2010, 1:57 AM * ======================== ---Online Versions of Today's List Digest Archive ======================== Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below.- The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.- The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: - - http://www.matronics.com/digest/digestview.php?Style=82701&View =html&Chapter 10-06-14&Archive=Glasair Text Version: - - http://www.matronics.com/digest/digestview.php?Style=82701&View =txt&Chapter 10-06-14&Archive=Glasair ====================== ---EMail Version of Today's List Digest Archive ====================== - - - - ----------------------------------------------------- -------- - - - - - - - - - - - - ---Glasair-List Diges t Archive - - - - - - - - - - - - - - - - - - - --- - - - - - - - - - ---Total Messages Posted Mon 06/1 4/10: 2 - - - - ----------------------------------------------------- -------- Today's Message Index: ---------------------- - ---1. 02:57 AM - Re: FS: Middle Tennessee Airstrip with home/hang ar and more!- (Ratherfly) - ---2. 06:44 PM - Re: Blended foil prop- (Craymondw(at)aol.com) ________________________________- Message 1- __________________________ ___________ Subject: Glasair-List: Re: FS: Middle Tennessee Airstrip with home/hangar a nd more! From: "Ratherfly" <longmeadowfarm(at)aol.com> http://longmeadow.vflyer.com/home/flyer/home/3291623 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301133#301133 ________________________________- Message 2- __________________________ ___________ From: Craymondw(at)aol.com Subject: Glasair-List: Re: Blended foil prop Although I am having better performance with my new blended foil prop, the - down side is higher oil temperatures. My cylinder head temperatures- stil l remain below 300 degrees, but my oil temperature has climbed from 190- degrees to close to 220 degrees. It was suggested I install a very expensiv e- Airwolf or ADC spin on remote oil filter system with claims it will bring m y oil- temp down 15 degrees. Another suggested adding another small oil coo ler. But I- wondered if that would lower my oil pressure. I don't know if my o il temperature- jumped up because this prop pulls harder or if it spoils the air flowing into my- cowling. Any suggestions?!! PS: Wentworth Air Salvage quoted me a price for an Airwolf out of a- wrec k without hoses and filter for close to what AC Spruce sells a- new complet e kit for!! - - - - - - - - - - - - - - - - - - - - - - - - - Chuck Raymond Glasair2S- In a message dated 6/13/2010 3:04:43 A.M. Eastern Daylight Time,- glasair-list(at)matronics.com writes: * ======================= Online Versions of Today's List Digest- Archive ======================= Today's- complete Glasair-List Digest can also be found in either of the two Web- Links listed below.- The .html file includes the Digest format ted in- HTML for viewing with a web browser and features Hyperlinked Indexes and- Message Navigation.- The .txt file includes the plain ASCII versio n- of the Glasair-List Digest and can be viewed with a generic text editor- such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 10-06-12&Archive=Glasair Text- Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2010-06-12&Archive=Glasair ===================== EMail Version of Today's List Digest- Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Sat 06/12/10: 0 ---------------------------------------------------------- Today's- Message- Index: ---------------------- le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Jun 16, 2010
Subject: High Oil Temps
EEA tech advisor, Joe Gauthier suggested I check my Vernatherm to see if it was functioning. I thought to my self it couldn't be that, I replaced it about 400 hours ago and how could it break the same time I replaced my prop. So I removed it and placed it in a pot of boiling water for ten minutes and found that it was frozen open!!! Murphy's Law; "If it can't possibly be broken, it usually is!!" Chuck Raymond Glasair 2S N16CD ________________________________________________________________________________
Date: Jul 01, 2010
Subject: Vernatherm
This is a heads up: I discovered Lycoming's new vernatherm valve presses against the drain stop cylinder valve located in the accessory case that the oil screen housing is bolted too. You can see the cylinder by looking into the hole that the vernatherm valve seats against when the oil reaches 180 degrees. If the valve presses against that cylinder it not only prevents that cylinder from opening, it also jams the vernatherm valve as it expands. I found that I had to file off a little under 3/32" off the threaded shaft and crimping nut for it to clear. Chuck Raymond Glasair 16CD ________________________________________________________________________________
Date: Jul 07, 2010
Subject: Trimbox deadband problem
We were having a little "deadband" in our Glasair elevator trim system, where you'd roll the trim wheel an eighth turn with no effect on the trim. I made a little video showing the problem and the solution. (After passing this around, another builder reported he had a similar problem, but in his case, the roll pin holes themselves elongated.) Please see http://members.cox.net/mppalmer and click in the "video of trimbox deadband problem." It's a 30 second WMV file. Hope this helps, Mike Palmer <>< ________________________________________________________________________________
Date: Jul 08, 2010
Subject: Re: Trimbox deadband problem
EEA tech Joe Gautheir felt the factory trim tension was way to taunt and relaxed my trim wire springs. I have been flying my Glasair that way for nineteen trouble free years. In a message dated 7/7/2010 11:38:19 P.M. Eastern Daylight Time, glasairpilot(at)cox.net writes: --> Glasair-List message posted by: We were having a little "deadband" in our Glasair elevator trim system, where you'd roll the trim wheel an eighth turn with no effect on the trim. I made a little video showing the problem and the solution. (After passing this around, another builder reported he had a similar problem, but in his case, the roll pin holes themselves elongated.) Please see http://members.cox.net/mppalmer and click in the "video of trimbox deadband problem." It's a 30 second WMV file. Hope this helps, Mike Palmer <>< ________________________________________________________________________________
Subject: FS:Trutrak autopilot
Date: Jul 31, 2010
Digitrak http://www.trutrakap.com/products/Digitrak.html Fits Standard 2.25" Round Hole Built-in Ground Track DG Track Select Mode GPS Nav Mode Control Wheel Steering 12 Volts only New DT2 - $1,600 This unit has been used for 123 hours. I bought it from a friend and I intended to install it in the RV8 I am building, my partner does not want an A/P in the plane. Asking price $1300.00 for a barely used unit call 704-591-2035 Tad Sargent TeamRV ________________________________________________________________________________
Date: Jul 31, 2010
Subject: Re: FS:Trutrak autopilot
Tad You need to get a new partner. The auto pilot is necessary for safe operation of your airplane. You really should not fly without one. Bob On Saturday, July 31, 2010, Tad Sargent wrote: > > > Digitrak > http://www.trutrakap.com/products/Digitrak.html > > Fits Standard 2.25 Round Hole > Built-in Ground Track DG > Track Select Mode > GPS Nav Mode > Control Wheel Steering > 12 Volts only > New DT2 - $1,600 > > This unit has been used for 123 hours. I bought it from a friend and I intended > to install it in the RV8 I am building, my partner does not want an A/P in the > plane. > > Asking price $1300.00 for a barely used unit > call 704-591-2035 > > Tad Sargent > TeamRV > > ________________________________________________________________________________
Date: Jul 31, 2010
On 7/31/2010 10:32 AM, Robert Buckthal wrote: > > Tad > You need to get a new partner. The auto pilot is necessary for safe > operation of your airplane. You really should not fly without one. Okay, I'll bite. How is it "necessary"? None of the airplanes I've owned have had autopilots, and I've seen plenty of RV8s flying without them, and they all appear to be flying safely... -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Jul 31, 2010
While the pilot work load level flying any Glasair VFR is low, the work load goes up 5 fold flying IFR. If a pilot has everything nailed and doesn't need to hunt for a chart or approach plate, it's doable. Anything else and you're in deep sh*t. An autopilot is a go/nogo item for IFR in a Glasair. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Saturday, July 31, 2010 11:56 AM Subject: Re: Glasair-List: FS:Trutrak autopilot On 7/31/2010 10:32 AM, Robert Buckthal wrote: > > Tad > You need to get a new partner. The auto pilot is necessary for safe > operation of your airplane. You really should not fly without one. Okay, I'll bite. How is it "necessary"? None of the airplanes I've owned have had autopilots, and I've seen plenty of RV8s flying without them, and they all appear to be flying safely... -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Jul 31, 2010
I wouldn't say it quite as firmly as Bruce, but I agree with him. I learned to fly without a headset. Now I wouldn't fly without one with noise canceling. It is a health and a safety issue. I am much better off with the headset and the technology has made it available in my price range. Autopilot technology has trickled down to us nicely in the digital age. It is hard to fine a new airplane without an autopilot these days. The venerable C-172 is only manufactured with the G1000. Nearly every one has the GFC 700 autopilot because the price bump is relatively small. This is a 2 axis autopilot that can fly GPS derived step-downs, and track ILS and GPS vertical guidance. IN A C-172! We have 4 C-172's in our flight school. Every one of them has an autopilot (only one has a G1000). Every one who learns to fly at our school does so with an autopilot equipped aircraft, and a skill set to use it in certain emergency situations. Use beyond that is of course, up to the pilot. My point is you have little or no experience with autopilots so you don't appreciate what they bring to convenience and safety. If you have the space, weight and fiscal allowance, and autopilot will be as good an addition to your capability as a noise canceling headset. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G Chief Instructor, Edwards AFB Aero Club While the pilot work load level flying any Glasair VFR is low, the work load goes up 5 fold flying IFR. If a pilot has everything nailed and doesn't need to hunt for a chart or approach plate, it's doable. Anything else and you're in deep sh*t. An autopilot is a go/nogo item for IFR in a Glasair. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Saturday, July 31, 2010 11:56 AM Subject: Re: Glasair-List: FS:Trutrak autopilot On 7/31/2010 10:32 AM, Robert Buckthal wrote: > > Tad > You need to get a new partner. The auto pilot is necessary for safe > operation of your airplane. You really should not fly without one. Okay, I'll bite. How is it "necessary"? None of the airplanes I've owned have had autopilots, and I've seen plenty of RV8s flying without them, and they all appear to be flying safely... -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Jul 31, 2010
On 7/31/2010 4:39 PM, Doug Dodson wrote: > My point is you have little or no experience with autopilots so you don't > appreciate what they bring to convenience and safety. Hi Doug, I'll try not to take offense at your presumption of my knowledge, but the point is that an autopilot is not a required item to fly an airplane safely. Yes, they may add to the airplane, much like a glass panel, but are not necessary. I'd make the argument that if a person is relying on an autopilot for safe operation, their stick and rudder skills are quite likely not at the level they should be... Bruce makes a good point about IFR flight (whether it be a Glasair or the RV-8 the original poster wrote about). The original poster didn't mention how their RV-8 would be used, but most RV-8s that I am aware of are used for VFR pleasure flight and aerobatics, both cases where hand flying the airplane is far more pleasurable than letting George do the flying. Personally, if I already had the autopilot, I'd spend the effort to convince my partner to install it. They don't have to use it if it is there, but it might be useful on occasion. The only downside I can think of is a slight bit of extra weight, and possibly a slight extra drag on the control stick depending on the servo type. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Jul 31, 2010
No offense intended. I didn't actually realize I replied to someone other than the original poster, whose experience I really don't know either. My presumption of experience was based on this comment: "None of the airplanes I've owned have had autopilots..." Of course, it was a presumption. Many items are not "required", but safety is a relative term. All of the airplanes I have owned have had autopilots. I have actually owned only one and that was a 1966 Mooney M0. The autopilot was far from sophisticated but very useful for the way I employed the aircraft. My current ride, a borrowed 1956 Bonanza, has no autopilot and it can get tedious for anything but the 20 minute $100 hamburger run. It has proved to me the points I am making here. The benefits of an autopilot have nothing whatsoever to do with stick and rudder skills. Stick and rudder skills are for landing the plane. Stick and rudder skills require a tremendous workload when exercised for high accuracy tasks. Autopilots simply relieve workload to allow focus on other, sometimes life critical tasks in low gain flight conditions (moderate gain tasks such as an ILS require more sophisticated and more expensive autopilots. Anyway, unless the airplane is going to spend [insert some high percentage number] of its time within 1 hour of home station, or a purpose built aerobat, or some other very specific exceptional design mission, then in a modern world an autopilot has practical safety value. I would be hard pressed (I try to never say never) to be convinced that an autopilot in a glider is a good idea, but an airplane like a Glasair or RV-8 would almost certainly have increased utility and increased safety with an autopilot. Many RV-8's are used for long distance cross-country with a passenger. "Most" are probably do a good mix of local pleasure flying and travel. The safety feature is realized in its zenith in the all too common VFR in IMC scenario. I'll take a wing leveler over a BRS any day (there is a can of worms, feel free to leave it un-opened). I teach escape strategies to my primary students at our school. "Students" also includes renter pilots doing recurring checks. No commercial or instrument pilot gets away without demonstrating full proficiency in autopilot operations, limitations and techniques. And they have to do all of the tasks without the autopilot too. Summarizing, safety is a relative term, autopilots improve safety in many circumstances not limited to advanced certificates, and they are light and not as expensive as they used to be. - Doug -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Saturday, July 31, 2010 6:16 PM Subject: Re: Glasair-List: FS:Trutrak autopilot On 7/31/2010 4:39 PM, Doug Dodson wrote: > My point is you have little or no experience with autopilots so you don't > appreciate what they bring to convenience and safety. Hi Doug, I'll try not to take offense at your presumption of my knowledge, but the point is that an autopilot is not a required item to fly an airplane safely. Yes, they may add to the airplane, much like a glass panel, but are not necessary. I'd make the argument that if a person is relying on an autopilot for safe operation, their stick and rudder skills are quite likely not at the level they should be... Bruce makes a good point about IFR flight (whether it be a Glasair or the RV-8 the original poster wrote about). The original poster didn't mention how their RV-8 would be used, but most RV-8s that I am aware of are used for VFR pleasure flight and aerobatics, both cases where hand flying the airplane is far more pleasurable than letting George do the flying. Personally, if I already had the autopilot, I'd spend the effort to convince my partner to install it. They don't have to use it if it is there, but it might be useful on occasion. The only downside I can think of is a slight bit of extra weight, and possibly a slight extra drag on the control stick depending on the servo type. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Aug 01, 2010
On 7/31/2010 9:59 PM, Doug Dodson wrote: > The benefits of an autopilot have nothing whatsoever to do with stick and > rudder skills. Stick and rudder skills are for landing the plane. *shrug* We may have to agree to disagree. The particular quote I "challenged" initially (made by Bob) was "The auto pilot is necessary for safe operation of your airplane. You really should not fly without one." Then you and Bruce went on to support that statement to various degrees. If someone is relying on an autopilot in order to safely operate an aircraft, then IMHO they need to go spend more time with their flight instructor. In other words, if they can't fly the airplane safely without the autopilot, then they should not be flying the plane. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Aug 01, 2010
Adding my two cents is that when I fly my Glasair on long cross countries of a thousand miles or so, I have found that one can't fly those distances without encountering weather. My experience is, it is better to have an auto pilot than being in a bad situation wishing you had one. In a message dated 8/1/2010 12:29:42 P.M. Eastern Daylight Time, deej(at)deej.net writes: --> Glasair-List message posted by: Dj Merrill On 7/31/2010 9:59 PM, Doug Dodson wrote: > The benefits of an autopilot have nothing whatsoever to do with stick and > rudder skills. Stick and rudder skills are for landing the plane. *shrug* We may have to agree to disagree. The particular quote I "challenged" initially (made by Bob) was "The auto pilot is necessary for safe operation of your airplane. You really should not fly without one." Then you and Bruce went on to support that statement to various degrees. If someone is relying on an autopilot in order to safely operate an aircraft, then IMHO they need to go spend more time with their flight instructor. In other words, if they can't fly the airplane safely without the autopilot, then they should not be flying the plane. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Aug 16, 2010
Subject: Glasair III fuel filler cap
I lose one of these guys once a year. Anyone know of a cheaper source than Glasair ($134.00)? Robert N957DJ ________________________________________________________________________________
Date: Aug 16, 2010
Salvage yard. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of robert l. hunter Sent: Monday, August 16, 2010 7:58 PM Subject: Glasair-List: Glasair III fuel filler cap I lose one of these guys once a year. Anyone know of a cheaper source than Glasair ($134.00)? Robert N957DJ ________________________________________________________________________________
Date: Aug 17, 2010
Subject: Fuel Cap
Polen Racer, Dick Kyte owns a computerized milling machine. Contact him and I think he could manufacture a gas cap for far less cost. I think Dick has his own web site. ________________________________________________________________________________
Date: Sep 07, 2010
Subject: Blended Foil
Glasair 2S FT, 200 hp Lycoming. I previously reported high oil temps after replacing my old prop with the new blended foil prop and wrongly thought the high temps were from the new prop working harder. Even with my high oil temperature my cylinder temps were below 300 degrees. So upon Glasairs' Harry DeLongs' advice I decided to redirect the air from cooling my rear right cylinder to my oil cooler inlet by installing a cooling fin insert on the aft portion of that cylinders' cooling fins. But as I was re installing my upper cowling I noticed that a piece of silicon seal had come off. On the top cowling there is step in the fiberglass that I filled with a bead of silicon. So I cleaned up that area and replaced it with a self stick 1.25 wide X 3/16 thick Camper Mounting (foam) Tape that I applied to 3M Hi-Strength 90 Spray adhesive. In between the two cowling reinforcement lay ups, I doubled up on the tape to make a continuous smooth seal that spans the width of my cowling. I also have a front baffle that blocks air from moving forward through the forward spinner fairing where I use a folded over truck inner tube riveted to an aluminum baffle in that area. I applied a strip of Camper Sealer tape on top of the inner tube to insure it doesn't leak air. After completing the installation I test flew the plane in 95 degree outside temps and that appeared to solve my problem of very high oil temps that once ranged as high as 220 to 230 degrees. I flew the plane in a 95 degree ambient temperature and recorded that my oil temperature had dropped to between 200 degrees to 209 degrees with a cylinder temperature increase of a few degrees to 305 degrees. After landing I shined a flash light into the inlets and could see that my rear engine baffling was firmly pressed against the newly installed Camper Mounting tape. As I point of interest I met the engineer that designed and tested the new blended foil prop that he designed well over ten years ago. The engineer reported that he wasn't surprised that the prop added another 20 mph during the winter months and less during the higher temps of summer. When I reported that I could feel the prop in the airframe, he reported that the blended foil prop develops a "shock wave" near the tips and that was what I was feeling. ________________________________________________________________________________
Date: Oct 20, 2010
This is an update to an earlier posting about the Zenair floats. After coming back from Oshkosh, it was decided to start developing a 2,500# float as a lot of Glasair owners including others were asking for that. The development work is now complete and parts are being made so we should start shipping the 2,500# float kits in January. Kits will be available as a parts kit (no holes drilled) or a pre-drilled kit (floats are pre-assembled at the factory and disassembled for shipping). For those of you who want amphibious floats, we have good news for you as they will be offered at the same time as the straight floats. Main wheel size will be 18.5" - HUGE and excellent for grass strips. For more info on all this, please see www.zenairfloats.com or call me at 705-526-2871 Cheers Mathieu Heintz Zenair Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316463#316463 ________________________________________________________________________________
Subject: 0-360 WANTED
Date: Oct 29, 2010
Mid time (preferably) O-360 wanted for my RV-7 project. An -A1A model would be ideal but others will be considered. Contact Jerry at rv74me(at)yahoo.com -------- Jerry Kosirog RV7A Finish Kit N855GK (Reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=317462#317462 ________________________________________________________________________________
Subject: Bent tailwheel,
Date: Oct 30, 2010
Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent to one side, easy enough to fix and strengthen but is this a common problem? He operates off grass but smooth. John ________________________________________________________________________________
Date: Oct 31, 2010
Yes. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of John Bolding Sent: Saturday, October 30, 2010 8:38 PM Subject: Glasair-List: Bent tailwheel, Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent to one side, easy enough to fix and strengthen but is this a common problem? He operates off grass but smooth. John ________________________________________________________________________________
Date: Oct 31, 2010
Subject: Re: Bent tailwheel,
John, I built a Glasair 1 TD in 1984 and still fly it. The problem you described happened to me early on. I reinstalled the strut with the mill fiber as the manual indicated and added bi=directional cloth around the outside and onto the fuselage. It was probably 4-6 layers. No problems since. Robin Young 286YM. ----->Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent to one >side, easy enough to fix and strengthen but is this a common problem? He >operates off grass but smooth. > >John > ________________________________________________________________________________
Date: Oct 31, 2010
Thanks for the reply Robin but the part that bent is the steel piece that the wheel mounts in, any problems there? Thanks John ----- Original Message ----- From: "Robin Young" <robin02(at)mindspring.com> Sent: Sunday, October 31, 2010 2:14 PM Subject: Re: Glasair-List: Bent tailwheel, > > John, I built a Glasair 1 TD in 1984 and still fly it. The problem you > described happened to me early on. I reinstalled the strut with the mill > fiber as the manual indicated and added bi=directional cloth around the > outside and onto the fuselage. It was probably 4-6 layers. No problems > since. Robin Young 286YM. > > ----->Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent > to one >>side, easy enough to fix and strengthen but is this a common problem? He >>operates off grass but smooth. >> >>John >> > > > ________________________________________________________________________________
Date: Nov 01, 2010
Subject: PLEASE READ - List Fund Raiser Kickoff!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's solely through the Contributions of List members that these Matronics Lists are possible. There is NO advertising to support the Lists. You might have noticed the conspicuous lack of flashing banners and annoying pop-ups on the Matronics Email List email messages and web site pages including: * Matronics List Forums http://forums.matronics.com * Matronics List List Wiki http://wiki.matronics.com * Matronics List Search Engine http://www.matronics.com/search * Matronics List Browser http://www.matronics.com/listbrowse You don't find advertising on any of these pages because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these Lists. Your personal Contribution counts! Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include: * Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com * Andy Gold of the Builder's Bookstore http://www.buildersbooks.com * Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Matt Dralle Matronics Email List Administrator RV-8 Builder and Flyer ________________________________________________________________________________
Date: Nov 01, 2010
John, the fork is not where the streeses showed on mine. I have gone to the Grove gear and increased my gross to 1900lbs from the original 1500lb. landing weight. Still there has been no problem. RObin -----Original Message----- >From: John Bolding <jnbolding1(at)teleshare.net> >Sent: Oct 31, 2010 4:03 PM >To: glasair-list(at)matronics.com >Subject: Re: Glasair-List: Bent tailwheel, > > >Thanks for the reply Robin but the part that bent is the steel piece that >the wheel mounts in, any problems there? > >Thanks John > > >----- Original Message ----- >From: "Robin Young" <robin02(at)mindspring.com> >To: ; >Sent: Sunday, October 31, 2010 2:14 PM >Subject: Re: Glasair-List: Bent tailwheel, > > >> >> John, I built a Glasair 1 TD in 1984 and still fly it. The problem you >> described happened to me early on. I reinstalled the strut with the mill >> fiber as the manual indicated and added bi=directional cloth around the >> outside and onto the fuselage. It was probably 4-6 layers. No problems >> since. Robin Young 286YM. >> >> ----->Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent >> to one >>>side, easy enough to fix and strengthen but is this a common problem? He >>>operates off grass but smooth. >>> >>>John ________________________________________________________________________________
Date: Nov 01, 2010
And I'll bet you make wheel landings rather than full stall. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Robin Young Sent: Monday, November 01, 2010 1:12 PM Subject: Re: Glasair-List: Bent tailwheel, John, the fork is not where the streeses showed on mine. I have gone to the Grove gear and increased my gross to 1900lbs from the original 1500lb. landing weight. Still there has been no problem. RObin -----Original Message----- >From: John Bolding <jnbolding1(at)teleshare.net> >Sent: Oct 31, 2010 4:03 PM >To: glasair-list(at)matronics.com >Subject: Re: Glasair-List: Bent tailwheel, > > >Thanks for the reply Robin but the part that bent is the steel piece that >the wheel mounts in, any problems there? > >Thanks John > > >----- Original Message ----- >From: "Robin Young" <robin02(at)mindspring.com> >To: ; >Sent: Sunday, October 31, 2010 2:14 PM >Subject: Re: Glasair-List: Bent tailwheel, > > >> >> John, I built a Glasair 1 TD in 1984 and still fly it. The problem you >> described happened to me early on. I reinstalled the strut with the mill >> fiber as the manual indicated and added bi=directional cloth around the >> outside and onto the fuselage. It was probably 4-6 layers. No problems >> since. Robin Young 286YM. >> >> ----->Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent >> to one >>>side, easy enough to fix and strengthen but is this a common problem? He >>>operates off grass but smooth. >>> >>>John ________________________________________________________________________________
Date: Nov 01, 2010
Yep...all wheel landings. RObin -----Original Message----- >From: Bruce Gray <bgray(at)glasair.org> >Sent: Nov 1, 2010 1:21 PM >To: glasair-list(at)matronics.com >Subject: RE: Glasair-List: Bent tailwheel, > > >And I'll bet you make wheel landings rather than full stall. > >Bruce >www.Glasair.org > >-----Original Message----- >From: owner-glasair-list-server(at)matronics.com >[mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Robin >Young >Sent: Monday, November 01, 2010 1:12 PM >To: glasair-list(at)matronics.com >Subject: Re: Glasair-List: Bent tailwheel, > > >John, the fork is not where the streeses showed on mine. I have gone to >the Grove gear and increased my gross to 1900lbs from the original >1500lb. landing weight. Still there has been no problem. RObin > >-----Original Message----- >>From: John Bolding <jnbolding1(at)teleshare.net> >>Sent: Oct 31, 2010 4:03 PM >>To: glasair-list(at)matronics.com >>Subject: Re: Glasair-List: Bent tailwheel, >> > >> >>Thanks for the reply Robin but the part that bent is the steel piece >that >>the wheel mounts in, any problems there? >> >>Thanks John >> >> >>----- Original Message ----- >>From: "Robin Young" <robin02(at)mindspring.com> >>To: ; >>Sent: Sunday, October 31, 2010 2:14 PM >>Subject: Re: Glasair-List: Bent tailwheel, >> >> > >>> >>> John, I built a Glasair 1 TD in 1984 and still fly it. The problem >you >>> described happened to me early on. I reinstalled the strut with the >mill >>> fiber as the manual indicated and added bi=directional cloth around >the >>> outside and onto the fuselage. It was probably 4-6 layers. No >problems >>> since. Robin Young 286YM. >>> >>> ----->Got a buddy with a II TD and 40 hrs total time, tailwheel assy >bent >>> to one >>>>side, easy enough to fix and strengthen but is this a common >problem? He >>>>operates off grass but smooth. >>>> >>>>John > > ________________________________________________________________________________
Date: Nov 03, 2010
Subject: November List Fund Raiser
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, they will instantly cease to receive these Fund Raiser messages for the rest of the month! Its just that simple. I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 04, 2010
Subject: Re: Glasair-List Digest: 0 Msgs - 11/02/10
how do i stop receiving this ????i no longer own a glasair...and dont want the e-mails...thanks! In a message dated 11/3/2010 2:03:45 A.M. Central Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-11-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-11-02&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 11/02/10: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Nov 04, 2010
Buy another Glasair!!!! In a message dated 11/4/2010 10:28:57 A.M. Eastern Daylight Time, Davesbox1(at)aol.com writes: how do i stop receiving this ????i no longer own a glasair...and dont want the e-mails...thanks! In a message dated 11/3/2010 2:03:45 A.M. Central Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-11-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-11-02&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 11/02/10: 0 ---------------------------------------------------------- Today's Message ================================================nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP b k you for p; -Matt Dralle, List ======================== e the ties Day ================================================ - MATRONICS WEB FORUMS ================================================= (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?Glasair-List) ________________________________________________________________________________
Date: Nov 04, 2010
lol....ok.... In a message dated 11/4/2010 9:46:32 A.M. Central Daylight Time, Craymondw(at)aol.com writes: Buy another Glasair!!!! In a message dated 11/4/2010 10:28:57 A.M. Eastern Daylight Time, Davesbox1(at)aol.com writes: how do i stop receiving this ????i no longer own a glasair...and dont want the e-mails...thanks! In a message dated 11/3/2010 2:03:45 A.M. Central Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-11-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2010-11-02&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 11/02/10: 0 ---------------------------------------------------------- Today's Message ================================================nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP b k you for p; -Matt Dralle, List ======================== e the ties Day ================================================ - MATRONICS WEB FORUMS ================================================= =================================== ttp://www.aeroelectric.com/">www.aeroelectric.com m/ href="http://www.buildersbooks.com/">www.buildersbooks.com "http://www.homebuilthelp.com/">www.homebuilthelp.com tp://www.matronics.com/contribution">http://www.matronics.com/contribution ==================================== href="http://www.matronics.com/Navigator?Glasai r-List">http://www.matronics.com/Navigator?Glasair-List ==================================== ms.matronics.com/">http://forums.matronics.com =================================== (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?Glasair-List) ________________________________________________________________________________
Date: Nov 04, 2010
On 11/04/2010 10:41 AM, Craymondw(at)aol.com wrote: > Buy another Glasair!!!! I often wish I hadn't sold mine... -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Please use Netiquette Guidelines http://tools.ietf.org/html/rfc1855 Kindly TRIM your email replies and post AFTER the relevant text ________________________________________________________________________________
Date: Nov 04, 2010
Subject: 100LL
Just received disturbing information from my options trader son. He just learned that OPEC won't sell anymore oil unless it gets better than $85/ barrel. But if expected 1970's inflation hits this summer look for oil in the $150/barrel range. If that happens $5/ gallon 100 LL will look cheap by comparison as gas prices more than double. Just returned from the Caribbean where the Mexican resorts will no longer accept the dollar. They regard it as worthless as the PESO once was. ________________________________________________________________________________
Subject: Re: 100LL
Date: Nov 04, 2010
Bullshit Sent from cell On Nov 4, 2010, at 1:41 PM, Craymondw(at)aol.com wrote: > Just received disturbing information from my options trader son. He just l earned that OPEC won't sell anymore oil unless it gets better than $85/ barr el. But if expected 1970's inflation hits this summer look for oil in the $1 50/barrel range. If that happens $5/ gallon 100 LL will look cheap by compar ison as gas prices more than double. Just returned from the Caribbean where t he Mexican resorts will no longer accept the dollar. They regard it as worth less as the PESO once was. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Subject: Re: 100LL
Date: Nov 04, 2010
What makes you think so? Steve Gray KHHG On Nov 4, 2010, at 3:59 PM, Sportypilot wrote: > Bullshit > > Sent from cell > > On Nov 4, 2010, at 1:41 PM, Craymondw(at)aol.com wrote: > >> Just received disturbing information from my options trader son. He just l earned that OPEC won't sell anymore oil unless it gets better than $85/ barr el. But if expected 1970's inflation hits this summer look for oil in the $1 50/barrel range. If that happens $5/ gallon 100 LL will look cheap by compar ison as gas prices more than double. Just returned from the Caribbean where t he Mexican resorts will no longer accept the dollar. They regard it as worth less as the PESO once was. >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 04, 2010
Subject: Re: 100LL
Hope you don't have to eat those words. I hear BS tastes real good with lots of Ketchup! In a message dated 11/4/2010 5:27:41 P.M. Eastern Daylight Time, redstripe9(at)hoosierlink.net writes: What makes you think so? Steve Gray KHHG On Nov 4, 2010, at 3:59 PM, Sportypilot <_sportypilot(at)stx.rr.com_ (mailto:sportypilot(at)stx.rr.com) > wrote: Bullshit Sent from cell On Nov 4, 2010, at 1:41 PM, _Craymondw(at)aol.com_ (mailto:Craymondw(at)aol.com) wrote: Just received disturbing information from my options trader son. He just learned that OPEC won't sell anymore oil unless it gets better than $85/ barrel. But if expected 1970's inflation hits this summer look for oil in the $150/barrel range. If that happens $5/ gallon 100 LL will look cheap by comparison as gas prices more than double. Just returned from the Caribbean where the Mexican resorts will no longer accept the dollar. They regard it as worthless as the PESO once was. D========= (mip://0563f628/3D"http://www.aeroelectric.com") (mip://0563f628/3D"http://www.buildersbooks.com") (mip://0563f628/3D"http://www.homebuilthelp.com") (mip://0563f628/3D"http://www.matronics.com/contribution") D========= (mip://0563f628/3D"http://www.matronics.com/Navigator?Glasair-List") D========= (mip://0563f628/3D"http://forums.matronics.com") D========= ________________________________________________________________________________
Subject: Re: 100LL
Date: Nov 04, 2010
sorry fellas just not so- last month flew from ktpl- nug in panama stoppin g in 5 countries and the US dollar was in demand everywhere i went- i cant imagine the resorts want the euro or the peso over our dollar....lolololo lol...if they do ...give it to them! -----Original Message----- From: Steve Gray <redstripe9(at)hoosierlink.net> Sent: Thu, Nov 4, 2010 4:19 pm Subject: Re: Glasair-List: 100LL What makes you think so? Steve Gray KHHG On Nov 4, 2010, at 3:59 PM, Sportypilot wrote: Bullshit Sent from cell On Nov 4, 2010, at 1:41 PM, Craymondw(at)aol.com wrote: Just received disturbing information from my options trader son. He just learned that OPEC won't sell anymore oil unless it gets better than $85/ barrel. But if expected 1970's inflation hits this summer look for oil in the $150/barrel range. If that happens $5/ gallon 100 LL will look cheap by comparison as gas prices more than double. Just returned from the Cari bbean where the Mexican resorts will no longer accept the dollar. They reg ard it as worthless as the PESO once was. =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D -=3D -=3D -- Please Support Your Lists This Month -- -=3D (And Get Some AWESOME FREE Gifts!) -=3D -=3D November is the Annual List Fund Raiser. Click on -=3D the Contribution link below to find out more about -=3D this year's Terrific Free Incentive Gifts provided -=3D by: -=3D -=3D * AeroElectric www.aeroelectric.com -=3D * The Builder's Bookstore www.buildersbooks.com -=3D * HomebuiltHELP www.homebuilthelp.com -=3D -=3D List Contribution Web Site: -=3D -=3D --> http://www.matronics.com/contribution -=3D -=3D Thank you for your generous support! -=3D -=3D -Matt Dralle, List Admin. -=3D -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D -=3D - The Glasair-List Email Forum - -=3D Use the Matronics List Features Navigator to browse -=3D the many List utilities such as List Un/Subscription, -=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, -=3D Photoshare, and much much more: -=3D -=3D --> http://www.matronics.com/Navigator?Glasair-List -=3D -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D -=3D - MATRONICS WEB FORUMS - -=3D Same great content also available via the Web Forums! -=3D -=3D --> http://forums.matronics.com -=3D -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D ________________________________________________________________________________
Date: Nov 05, 2010
Subject: Reminder
Dear Listers, A quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: 100LL
Date: Nov 04, 2010
Don't believe everything you hear Sent from cell On Nov 4, 2010, at 5:57 PM, Craymondw(at)aol.com wrote: > Hope you don't have to eat those words. I hear BS tastes real good with lo ts of Ketchup! > > In a message dated 11/4/2010 5:27:41 P.M. Eastern Daylight Time, redstripe 9(at)hoosierlink.net writes: > What makes you think so? > > Steve Gray > KHHG > > On Nov 4, 2010, at 3:59 PM, Sportypilot wrote: > >> Bullshit >> >> Sent from cell >> >> On Nov 4, 2010, at 1:41 PM, Craymondw(at)aol.com wrote: >> >>> Just received disturbing information from my options trader son. He just learned that OPEC won't sell anymore oil unless it gets better than $85/ ba rrel. But if expected 1970's inflation hits this summer look for oil in the $ 150/barrel range. If that happens $5/ gallon 100 LL will look cheap by compa rison as gas prices more than double. Just returned from the Caribbean where the Mexican resorts will no longer accept the dollar. They regard it as wor thless as the PESO once was. >>> >>> >> > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dctric w ww.bui//www.homebuilthelp.com"' href='mip://0563f628/3D"http://www.homebui lthe.com/contribution"' href='mip://0563f628/3D"http://www.matronics.com/c on=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D://3D" http://www.matronics.com/Navigator?Glasair-List"' href='mip://0563f628/3D" http://www.matronics.com/Navigator?Glasair-List"'>http://www.matro3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=ums.matronics.com" ' href='mip://0563f628/3D"http://forums.matronics.com"=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Subject: Re: 100LL
Date: Nov 04, 2010
I am a oil broker.. Don't believe everything You hear.. Sent from cell On Nov 4, 2010, at 4:19 PM, Steve Gray wrote: > What makes you think so? > > Steve Gray > KHHG > > On Nov 4, 2010, at 3:59 PM, Sportypilot wrote: > >> Bullshit >> >> Sent from cell >> >> On Nov 4, 2010, at 1:41 PM, Craymondw(at)aol.com wrote: >> >>> Just received disturbing information from my options trader son. He just learned that OPEC won't sell anymore oil unless it gets better than $85/ ba rrel. But if expected 1970's inflation hits this summer look for oil in the $ 150/barrel range. If that happens $5/ gallon 100 LL will look cheap by compa rison as gas prices more than double. Just returned from the Caribbean where the Mexican resorts will no longer accept the dollar. They regard it as wor thless as the PESO once was. >>> >>> >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Subject: Re: 100LL
Date: Nov 05, 2010
Why couldn't you have said that the first time? Must we be so callow? Steve ________________________________________________________________________ On Nov 4, 2010, at 5:12 PM, Sportypilot wrote: > I am a oil broker.. Don't believe everything > You hear.. > > Sent from cell > > On Nov 4, 2010, at 4:19 PM, Steve Gray wrote: > >> What makes you think so? >> >> Steve Gray >> KHHG >> >> On Nov 4, 2010, at 3:59 PM, Sportypilot wrote: >> >>> Bullshit >>> >>> Sent from cell >>> >>> On Nov 4, 2010, at 1:41 PM, Craymondw(at)aol.com wrote: >>> >>>> Just received disturbing information from my options trader son. He just learned that OPEC won't sell anymore oil unless it gets better than $85/ barrel. But if expected 1970's inflation hits this summer look for oil in the $150/barrel range. If that happens $5/ gallon 100 LL will look cheap by comparison as gas prices more than double. Just returned from the Caribbean where the Mexican resorts will no longer accept the dollar. They regard it as worthless as the PESO once was. >>>> >>>> >>> >>> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 05, 2010
Subject: Re: 100LL
> > What makes you think so? > If it were true, we'd probably see at least one news report about it... :-) -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Please use Netiquette Guidelines http://tools.ietf.org/html/rfc1855 Kindly TRIM your email replies and post AFTER the relevant text ________________________________________________________________________________
Date: Nov 05, 2010
Subject: 100LL
One way to hedge gasoline prices is by owning petroleum commodities funds. As the value of the funds increase the return will be far greater than what is paid for the increased prices of gasoline. With Yo' Momma suspending off shore drilling he really hurt the industry. The country has a little left in reserve now, but with any recovery those reserves will begin to dwindle. The air carriers are pulling aircraft out of storage along with trucking fleets and that will place added pressure on limited supplies. Add to that China's huge monthly increases of oil imports and the added strain that is creating. Another factor is the falling value of the dollar. A lot depends on what the Federal Reserve does with interest rates. If they increase rates that will improve the dollar stabilizing prices. The above information was researched and forwarded to me through relatives in the investment industry and a personal Wealth Management adviser. This coming flying season will be interesting. ________________________________________________________________________________
Date: Nov 05, 2010
Subject: Re: Reminder
anyone have a direct e-mail to Mr Matt Dralle? the matronics list administrator? thanks! Dave / Texas In a message dated 11/5/2010 2:14:44 A.M. Central Daylight Time, dralle(at)matronics.com writes: http://www.matronics.com/contribution ________________________________________________________________________________
Date: Nov 05, 2010
Subject: Re: US Cash not accepted in Mexico
>From http://www.bajabushpilots.com/ "US Cash cannot be used at major airports. A new rule has been put in effect that limits transactions of US dollars in Mexico. This Mexican IRS law, took effect October 31, 2010. Because of this law, ASA informed the BPI that ASA can no longer accept US currency for product or . . ." ________________________________________________________________________________
Date: Nov 07, 2010
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 09, 2010
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 11, 2010
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "vittorio pajno" <vittorio.pajno(at)fastwebnet.it>
Subject: Info
Date: Nov 12, 2010
Spect. Matronix I would like to contact a couple of amateur builders of the Glasair with fixed landing gear in order to have some info. My e-mail is : vittorio.pajno(at)fastwebnet.it Thanks for your help Best regards from V.Pajno ________________________________________________________________________________
Date: Nov 13, 2010
Subject: Please Make A Contribution...
Date: Nov 15, 2010
Subject: List Fund Raiser & Some Very Nice Comments...
Dear Listers, I've been getting some really nice comments from Listers along with their List Support Contributions. I've shared some of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of sweet gifts available, so browse the extensive selection and pickup a nice item along with your qualifying Contribution. Contribution Web Site: http://www.matronics.com/contribution Or drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ------------------------------------------------------- You are providing a great service. Thanks so very much. David L Keep up the good work! A great website - wish I'd found it earlier! Bob S Thanks for providing a site for information. Jim S Thanks again for providing a great service to our community! Alex M Thanks and keep up the good work! Robert B. Great forum! David S Thanks for providing the Kolb List for the last 12 years. John H Long time lurker, it's a great resource...many thanks. Ian C Your work and effort are greatly appreciated. Nicolas L Thank you very much for keeping the list going! Svein J Thank you for your support to the community. Valin T I am a long time subscriber and a slow builder because of work and two moves, but still enjoy the process and your list. CL M Thanks for providing this service. It can't be beat! Thomas W I'm no longer a builder or flier but I like to keep in touch with the List - which is the best organised list I've seen on the Internet. Gerry C Matt, you are doing a GREAT service to the community of KOLB Builders and Flyers. John B I've been flying for almost two years and still find these Lists as a great resource for information.....now I get to answer a question once-in-a-while too. Ralph C Thanks for this great service. Dale E I couldn't keep on building without the support I get from this List. Thomas S This is a great service to all of us. Michael W I am no longer actively building, but I really like to keep up with what's going on, and I especially like to follow Bob Nuckolls - and your RV-8. Terrence W I really appreciate your work and consider the lists to be a great value. Christopher R Thanks Matt for a great resource! Geoff T Many thanks for providing this service. I love it. William V One of the best Internet Deals going... Owen B Thanks for the great site. Danny S A valuable resource. George A Thanks for running a great list. Ted P ________________________________________________________________________________
Date: Nov 17, 2010
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade T1 Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for narly 20 years (yeah, I really said *20* years) worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution Or drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2010
Subject: Just A Few Days Left; Well Behind Last Year...
Dear Listers, There are just a few more days left of this year's List Fund Raiser. Response has been good so far, but we're well behind last year at this point. If you've been waiting until the last minute to make your Contribution, now might be good time to show your support and maybe pick up a nice gift as well! Please remember that there is no commercial advertising on these Lists and the *only* means of keeping them running is through your Contributions during this Fund Raiser. If it weren't for your individual Contributions, these Lists could easily become economically infeasible and simply cease to exist. You probably can't even take the family out to dinner for $20 these days, but your individual Contribution of the same amount makes a huge difference in keeping the List services alive. Please make a Contribution today with a Credit Card or Paypal: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2010
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2010
Subject: Contributions Down By 17%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 17%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash or worse, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Wite, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2010
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal, or a personal check: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 25, 2010
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2010
Subject: No "Black Friday" For List Fund Raiser...
Dear Listers, Curiously, even though the number of List subscriptions are significantly up this year, support during this year's Fund Raiser is still substantially behind last year. There are only a couple more days left in November and the end of the Fund Raiser is quickly approaching. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid, other sources of income might be required including some sort of advertising. Please don't let that happen! Your personal Contribution of $20 or $30 goes a long ways to keeping the operation a float. Please make sure your name is on this year's List of Contributors published in December. The Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Just Three Days Left & Some Very Nice Comments...
Dear Listers, There are just three days left in this year's List Fund Raiser. Won't you take a monment and make a quick Contribution today to support the continued upgrade and operation of these Forum services. I've received some more really nice comments from Listers along with their List Support Contributions, and I've share a few below. There are some sweet gifts available this year, so browse the selections and pickup a nice item along with your qualifying Contribution. Contribution Web Site: http://www.matronics.com/contribution Or drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ------------------------------------------------------- Great resource, keep it coming... Marten V. Thanks for maintaining these essential lists! Rumen D. Great Service! Douglas D. Thanks for this great service! Peter T. Thanks for your enduring support of homebuilding communications! Daniel M. You do a great job and provide a valuable service. Mark B. It's really a great source I have used a lot. Robert K. Reading the RV-10 list is part of my morning routine... Perry C. Great job running these lists. Edward T. Thanks for doing a tough job. Mic T. Your List was such a great resource for me when I built in "98". Ron V. Its a very useful forum. Dave F. Really enjoy your list... William D. Great service, Gerald T. The list still is a valuable source of information and there are many worthwhile postings. Graham H. The list has seen me through an RV-9A, RV-10, and now an RV-12. Albert G. Thanks for a great resource! Barry H. Thank you for maintaining this excellent site. Bill W. The Matronics Email list are an invaluable service. William C. I appreciate the RV-10 list. Vijay P. Thanks for a great list and all of the work you do. Ian W. Thanks for keeping up this very useful list. George R. The list is excellent and I find it very handy for any problems I come up against during construction. Greg W. The lists are an important part of my day. I've met lots of people and made lots of friends. Dave S. It's really a great source I haved used a lot. Robert K. I read the Pietenpol List everyday. PF B. ________________________________________________________________________________
Date: Nov 29, 2010
Dear Listers, The List of Contributors (LOC) is just around the corner with just two more days in this year's Fund Raiser! Later in December I will post a list of everyone that so generously made a Contribution to support the Lists this year. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2010
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means at least two things. For better or worse, its my 47th birthday! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been drooling over one of the really nice gifts that are available this year with a qualifying Contribution, then now is the time to jump on one!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. Hopefully everyone feels the same. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 14, 2010
Subject: 2010 List of Contributors
Dear Listers, The 2010 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and its time that I publish this year's List of Contributors. Its the people on this list that directly make the Email Lists and Forums possible. Their generous contributions keep the servers and Internet connection up and running. You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some great products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - www.aeroelectric.com Jon Croke - HomebuiltHELP - www.homebuilthelp.com Andy Gold - The Builder's Bookstore - www.buildersbooks.com And finally, I'm proud to present The 2010 Fund Raiser List of Contributors: http://www.matronics.com/loc/2010.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Dec 14, 2010
Subject: Glasair spars
I just read a report about a wing skin on a Cessna Columbia "disbonding seven feet during a production acceptance flight test." The FAA is issuing an AD and looking into if "unsafe condition is likely to exist in other products of the same type of design." As I was building my Glasair I needed to disbond my rudder skins because of a mistake I made and was surprised how easily they came apart and hoped my wing skins would fair better. I had a friend that manufactured glass sail boats help me and he sanded my spars and wing skins with 80 grit paper and washed them with acetone before laminating them together. During the construction he would comment on the parts and would ask in his thick German accent; ""Vat did Glasair design..a tank?!!" When I incorrectly laminated a foot long fiber glass right angle to the inside of a fuselage skin I at first tried to pop it off using a hammer and chisel and couldn't and ended spending a long time sawing it off with a hack saw blade. Four years later when my nose gear sheared off the plane as I was landing on a sandy soil threshold causing my right wing dug into the ground and cart wheeling the plane. My concern was disbonding of the wing skins. I tapped the entire length of the spar with a coin and couldn't detect any disbonding. My German fiberglass expert friend advised that if my skins hadn't rippled there wouldn't be any disbonding. All of my damage was at the point of contact. My G-Meter was pegged at 14G's and I couldn't decide if the wing actually stood 14 G's or if that was the shock of the nose digging into the ground. Bob Heredeen pulled very high G's in both his Glasair 2 and 3 for years. Also Glasair uses a different resin than Lancair that may be stronger. I completed my plane in the spring of 1991 and had the nose wheel assembly part company in 1996. After I repaired my plane I pulled my chute from my Pitt's S1S and flew up to 6,000 feet and did aerobatics to test my wings and pulled close to six G's. I never bailed out of a plane before and hoped I wouldn't have to. I would also add that there has never been an in flight structural failure of a Glasair. My hope is that the FAA doesn't jump the gun and issue an AD on Glasair's and that they first contact the company and retrieve some data. ________________________________________________________________________________
Date: Dec 16, 2010
Actually, there has been a structural failure of a Glasair III. It was similar to the Columbia incident. Chip Beck was flying his GIII at an airshow, during his acro routine he experienced a wing skin/spar delamination. Fuel was sloshing all over. He said he was pulling about 9 G's at the time. The wing was originally closed by Phoenix Composites using a non-standard closing method and material. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Tuesday, December 14, 2010 11:45 AM Subject: Glasair-List: Glasair spars I just read a report about a wing skin on a Cessna Columbia "disbonding seven feet during a production acceptance flight test." The FAA is issuing an AD and looking into if "unsafe condition is likely to exist in other products of the same type of design." As I was building my Glasair I needed to disbond my rudder skins because of a mistake I made and was surprised how easily they came apart and hoped my wing skins would fair better. I had a friend that manufactured glass sail boats help me and he sanded my spars and wing skins with 80 grit paper and washed them with acetone before laminating them together. During the construction he would comment on the parts and would ask in his thick German accent; ""Vat did Glasair design..a tank?!!" When I incorrectly laminated a foot long fiber glass right angle to the inside of a fuselage skin I at first tried to pop it off using a hammer and chisel and couldn't and ended spending a long time sawing it off with a hack saw blade. Four years later when my nose gear sheared off the plane as I was landing on a sandy soil threshold causing my right wing dug into the ground and cart wheeling the plane. My concern was disbonding of the wing skins. I tapped the entire length of the spar with a coin and couldn't detect any disbonding. My German fiberglass expert friend advised that if my skins hadn't rippled there wouldn't be any disbonding. All of my damage was at the point of contact. My G-Meter was pegged at 14G's and I couldn't decide if the wing actually stood 14 G's or if that was the shock of the nose digging into the ground. Bob Heredeen pulled very high G's in both his Glasair 2 and 3 for years. Also Glasair uses a different resin than Lancair that may be stronger. I completed my plane in the spring of 1991 and had the nose wheel assembly part company in 1996. After I repaired my plane I pulled my chute from my Pitt's S1S and flew up to 6,000 feet and did aerobatics to test my wings and pulled close to six G's. I never bailed out of a plane before and hoped I wouldn't have to. I would also add that there has never been an in flight structural failure of a Glasair. My hope is that the FAA doesn't jump the gun and issue an AD on Glasair's and that they first contact the company and retrieve some data. ________________________________________________________________________________
Date: Dec 16, 2010
> The wing was originally closed by Phoenix Composites using a > non-standard closing method and material. Would you elaborate on this a little. What exactly was the "method" and "materials". Thanks in advance. B.J. McClure Glasair III N300JJ x86_64 ________________________________________________________________________________
Date: Dec 16, 2010
>From what I've been told is that they used a mixture of resin, mill fiber, and cabosil. Cabosil in high strength bonds is a no-no. All it does is weaken the bond. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of B.J. McClure Sent: Thursday, December 16, 2010 12:47 PM Subject: RE: Glasair-List: Glasair spars The wing was originally closed by Phoenix Composites using a non-standard closing method and material. Would you elaborate on this a little. What exactly was the "method" and "materials". Thanks in advance. B.J. McClure Glasair III N300JJ x86_64 ________________________________________________________________________________
Date: Dec 16, 2010
Subject: Re: Glasair spars
Know your materials and in critical areas follow the manual. In a message dated 12/16/2010 1:36:08 P.M. Eastern Standard Time, bgray@glasair .org writes: >From what I=99ve been told is that they used a mixture of resin, mill fiber, and cabosil. Cabosil in high strength bonds is a no-no. All it doe s is weaken the bond. Bruce www.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of B.J. McClure Sent: Thursday, December 16, 2010 12:47 PM Subject: RE: Glasair-List: Glasair spars The wing was originally closed by Phoenix Composites using a non-standard closing method and material. Would you elaborate on this a little. What exactly was the "method" and "materials". Thanks in advance. B.J. McClure Glasair III N300JJ x86_64 ======================== ============ (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) ======================== ============ (http://www.matronics.com/Navigator?Glasair-List) ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Dec 16, 2010
Thanks. Appreciate the info. > >From what Ive been told is that they used a mixture of resin, mill > fiber, and cabosil. Cabosil in high strength bonds is a no-no. All it > does is weaken the bond. > > > > > Bruce > www.Glasair.org > > > > -----Original Message----- > From: owner-glasair-list-server(at)matronics.com > [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of B.J. > McClure > Sent: Thursday, December 16, 2010 12:47 PM > To: glasair-list(at)matronics.com > Subject: RE: Glasair-List: Glasair spars > > > > > > > The wing was originally closed by Phoenix Composites using a > non-standard closing method and material. > > > Would you elaborate on this a little. What exactly was the "method" > and "materials". Thanks in advance. > > B.J. McClure > Glasair III N300JJ > > x86_64 > > > > > > > > > x86_64 ________________________________________________________________________________
From: "Randy Pinkston" <pinkston(at)carolina.rr.com>
Subject: super II srg done
Date: Mar 02, 2011
Just finished this bird, It's @ Anson county kafp & was painted there also if anyone wants a good paint job for the money, can contact gene @ 704-984-0144.. 214mph8.5gph@8000@75%power 214mph8.5gph@8000@75%25power> ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Re: super II srg done
Congratulations....Post some pictures.=0A=0A=0A=0A_________________________ _______=0AFrom: Randy Pinkston <pinkston(at)carolina.rr.com>=0ATo: glasair-lis t(at)matronics.com=0ASent: Wed, March 2, 2011 2:49:33 PM=0ASubject: Glasair-Li st: super II srg done=0A=0A =0AJust finished this bird, It=99s @ Anso n county kafp & was painted there also if =0Aanyone wants a good paint job for the money, can contact gene @ 704-984-0144.. =0A214mph8.5gph@8000@75%p ================= =0A ________________________________________________________________________________
Subject: pics
Date: Mar 03, 2011
71rp is done ________________________________________________________________________________
Subject: Re: Glasair-List Digest: 1 Msgs - 03/03/11
Date: Mar 05, 2011
After 16 years since we finished our Glasair, I can attest to the truism that the work on a homebuilt aircraft is never done. Still tweaking ours. Mike Palmer <>< ===================== 71rp is done ________________________________________________________________________________
Date: Apr 04, 2011
Subject: Pitot-static tube
Aero Instruments heated pitot-static tube AN-5814 (12 volt) for sale. Best offer. Email me off list. ________________________________________________________________________________
Date: Jul 09, 2011
Subject: Sale of Glasair III
I intend to put my bird up for sale this summer, and request suggestions from the community as to what sites for listing might be the most effective. Thanks in advance, Robert N957DJ ________________________________________________________________________________
Date: Jul 09, 2011
Subject: Re: Sale of Glasair III
On 7/9/2011 8:34 AM, Robert L. Hunter wrote: > I intend to put my bird up for sale this summer, and request > suggestions from the community as to what sites for listing might be > the most effective. > Two I use are: http://barnstormers.com/cat.php http://aviationclassifieds.com/ Also, AOPA and EAA have free listings on their respective websites. Also http://www.trade-a-plane.com/ but they are very expensive. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 09, 2011
You should list it here first because you might find someone that wants to up grade. In a message dated 7/9/2011 10:58:08 A.M. Eastern Daylight Time, deej(at)deej.net writes: On 7/9/2011 8:34 AM, Robert L. Hunter wrote: I intend to put my bird up for sale this summer, and request suggestions from the community as to what sites for listing might be the most effective. Two I use are: _http://barnstormers.com/cat.php_ (http://barnstormers.com/cat.php) _http://aviationclassifieds.com/_ (http://aviationclassifieds.com/) Also, AOPA and EAA have free listings on their respective websites. Also _http://www.trade-a-plane.com/_ (http://www.trade-a-plane.com/) but they are very expensive. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - _http://deej.net/sportsman/_ (http://deej.net/sportsman/) Glastar Flyer N866RH - _http://deej.net/glastar/_ (http://deej.net/glastar/) (http://www.matronics.com/Navigator?Glasair-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 03, 2011
Subject: Re: Glasair-List Digest: 0 Msgs - 08/02/11
Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having big problems. AOPA told me that numerous owners are having problems and I can't begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how Law originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-02&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Aug 03, 2011
I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent funding assurance for several years, but it's not funny. Now everyone that isn't ATC or specifically safety related is on furlough until congress reconvenes in September. I say we find new jobs for the 4000 now proven "unnecessary" personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having big problems. AOPA told me that numerous owners are having problems and I can't begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how Law originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-02&Archive=Glasair ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; ________________________________________________________________________________
Date: Aug 03, 2011
Doug, Thanks for the moral support. Chuck Raymond In a message dated 8/3/2011 2:35:00 P.M. Eastern Daylight Time, douglas.dodson(at)pobox.com writes: I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent funding assurance for several years, but it=99s not funny. Now everyone tha t isn=99t ATC or specifically safety related is on furlough until congress reconvenes in September. I say we find new jobs for the 4000 now proven =9Cunnece ssary=9D personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G ____________________________________ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw@ao l.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having bi g problems. AOPA told me that numerous owners are having problems and I can' t begin to imagine how much fuel revenue is being lost on everything from JE TA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how La w originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by coopera tion. Batist goes on to say that when laws impede the function of society they n o longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * Online Versions of Today's List Digest Archive Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2011-08-02&Archive=Glasair ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; http://www.matronics.com/Navigator?Glasair-List http://forums.matronics.com http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Glasair-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 04, 2011
Subject: Re: Glasair-List Digest: 3 Msgs - 08/03/11
Doug, When I fly my plane to Oshkosh and register our Glasair, the EAA has no doubt that my wife and I own that plane and know where we live. But when I tried to re register my plane several times with the FAA they just couldn't seem to figure out who my wife and I are and where we live and have grounded our plane because it has "expired" due to their incompetence of letting their data base become compromised and made it our problem and not theirs. My son was one of the youngest captain's flying a 747 for an airline and was dragged out of the left seat and made vice president of a new division handling TSA mandates. He often flew to meet with Washington TSA heads and passed on to me this quote from a top Washington TSA official; "My job is to get every general aviation plane out of the sky." This is the mind set of a government that wants central planning. We as a people are loosing our freedoms one freedom at a time and I am one pissed off American. In a message dated 8/4/2011 3:06:29 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-03&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-03&Archive=Glasair =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Wed 08/03/11: 3 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 09:37 AM - Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Craymondw(at)aol.com) 2. 11:34 AM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Doug Dodson) 3. 01:13 PM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Craymondw(at)aol.com) ________________________________ Message 1 _____________________________________ From: Craymondw(at)aol.com Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having big problems. AOPA told me that numerous owners are having problems and I can't begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how Law originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ================================================ Online Versions of Today's List Digest Archive ================================================ Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-02&Archive=Glasair ============================================== EMail Version of Today's List Digest Archive ============================================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________ Message 2 _____________________________________ From: "Doug Dodson" <douglas.dodson(at)pobox.com> Subject: RE: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent funding assurance for several years, but it's not funny. Now everyone that isn't ATC or specifically safety related is on furlough until congress reconvenes in September. I say we find new jobs for the 4000 now proven "unnecessary" personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having big problems. AOPA told me that numerous owners are having problems and I can't begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how Law originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ======================= Online Versions of Today's List Digest Archive ======================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-02&Archive=Glasair ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; ________________________________ Message 3 _____________________________________ From: Craymondw(at)aol.com Subject: Re: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Doug, Thanks for the moral support. Chuck Raymond In a message dated 8/3/2011 2:35:00 P.M. Eastern Daylight Time, douglas.dodson(at)pobox.com writes: I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent funding assurance for several years, but it=99s not funny. Now everyone tha t isn=99t ATC or specifically safety related is on furlough until congress reconvenes in September. I say we find new jobs for the 4000 now proven =9Cunnece ssary=9D personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G ____________________________________ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw@ao l.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having bi g problems. AOPA told me that numerous owners are having problems and I can' t begin to imagine how much fuel revenue is being lost on everything from JE TA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how La w originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by coopera tion. Batist goes on to say that when laws impede the function of society they n o longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * Online Versions of Today's List Digest Archive Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2011-08-02&Archive=Glasair ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; http://www.matronics.com/Navigator?Glasair-List http://forums.matronics.com http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Glasair-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 04, 2011
Subject: re registration forms
What is the site for electronic registration? ________________________________________________________________________________
Date: Aug 04, 2011
http://www.faa.gov/licenses_certificates/aircraft_certification/aircraft_reg istry/ Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Thursday, August 04, 2011 8:56 AM Subject: Glasair-List: re registration forms What is the site for electronic registration? ________________________________________________________________________________
Date: Aug 04, 2011
Screw it. I'm moving to China. Do they have beer there? - Doug _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Thursday, August 04, 2011 8:27 AM Subject: Glasair-List: Re: Glasair-List Digest: 3 Msgs - 08/03/11 Doug, When I fly my plane to Oshkosh and register our Glasair, the EAA has no doubt that my wife and I own that plane and know where we live. But when I tried to re register my plane several times with the FAA they just couldn't seem to figure out who my wife and I are and where we live and have grounded our plane because it has "expired" due to their incompetence of letting their data base become compromised and made it our problem and not theirs. My son was one of the youngest captain's flying a 747 for an airline and was dragged out of the left seat and made vice president of a new division handling TSA mandates. He often flew to meet with Washington TSA heads and passed on to me this quote from a top Washington TSA official; "My job is to get every general aviation plane out of the sky." This is the mind set of a government that wants central planning. We as a people are loosing our freedoms one freedom at a time and I am one pissed off American. In a message dated 8/4/2011 3:06:29 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-03&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-03&Archive=Glasair ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Wed 08/03/11: 3 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 09:37 AM - Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Craymondw(at)aol.com) 2. 11:34 AM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Doug Dodson) 3. 01:13 PM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Craymondw(at)aol.com) ________________________________ Message 1 _____________________________________ From: Craymondw(at)aol.com Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having big problems. AOPA told me that numerous owners are having problems and I can't begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how Law originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ======================= Online Versions of Today's List Digest Archive ======================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-02&Archive=Glasair ============================================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________ Message 2 _____________________________________ From: "Doug Dodson" <douglas.dodson(at)pobox.com> Subject: RE: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent funding assurance for several years, but it's not funny. Now everyone that isn't ATC or specifically safety related is on furlough until congress reconvenes in September. I say we find new jobs for the 4000 now proven "unnecessary" personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having big problems. AOPA told me that numerous owners are having problems and I can't begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how Law originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ======================= Online Versions of Today's List Digest Archive ======================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2011-08-02&Archive=Glasair ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; ________________________________ Message 3 _____________________________________ From: Craymondw(at)aol.com Subject: Re: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Doug, Thanks for the moral support. Chuck Raymond In a message dated 8/3/2011 2:35:00 P.M. Eastern Daylight Time, douglas.dodson(at)pobox.com writes: I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent funding assurance for several years, but it=99s not funny. Now everyone tha t isn=99t ATC or specifically safety related is on furlough until congress reconvenes in September. I say we find new jobs for the 4000 now proven =9Cunnece ssary=9D personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G ____________________________________ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw@ao l.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having bi g problems. AOPA told me that numerous owners are having problems and I can' t begin to imagine how much fuel revenue is being lost on everything from JE TA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how La w originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by coopera tion. Batist goes on to say that when laws impede the function of society they n o longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * Online Versions of Today's List Digest Archive Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2011-08-02&Archive=Glasair ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; http://www.matronics.com/Navigator?Glasair-List http://forums.matronics.com http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Glasair-List) (http://www.matronics.com/contribution) the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; ________________________________________________________________________________
Date: Aug 04, 2011
Did you know that China has less business restrictions than the USA and aviation growth is explosive there. In a message dated 8/4/2011 12:16:41 P.M. Eastern Daylight Time, douglas.dodson(at)pobox.com writes: Screw it. I=99m moving to China. Do they have beer there? - Doug ____________________________________ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw@ao l.com Sent: Thursday, August 04, 2011 8:27 AM Subject: Glasair-List: Re: Glasair-List Digest: 3 Msgs - 08/03/11 Doug, When I fly my plane to Oshkosh and register our Glasair, the EAA has no doubt that my wife and I own that plane and know where we live. But when I tried to re register my plane several times with the FAA they just couldn 't seem to figure out who my wife and I are and where we live and have grounded our plane because it has "expired" due to their incompetence of l etting their data base become compromised and made it our problem and not theirs. My son was one of the youngest captain's flying a 747 for an airline and was dragged out of the left seat and made vice president of a new division handling TSA mandates. He often flew to meet with Washington TSA heads and passed on to me this quote from a top Washington TSA official; "My job is to get every general aviation plane out of the sky." This is the mind set of a government that wants central planning. We as a people are loosing our freedoms one freedom at a time and I am one pissed off American. In a message dated 8/4/2011 3:06:29 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * Online Versions of Today's List Digest Archive Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 11-08-03&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2011-08-03&Archive=Glasair ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Wed 08/03/11: 3 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 09:37 AM - Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Craymondw(at)aol.com) 2. 11:34 AM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Doug Dodson ) 3. 01:13 PM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Craymondw(at)aol.com) ________________________________ Message 1 _____________________________________ From: Craymondw(at)aol.com Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having big problems. AOPA told me that numerous owners are having problems and I can't begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how Law originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ======================= Online Versions of Today's List Digest Archive ======================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2011-08-02&Archive=Glasair ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________ Message 2 _____________________________________ From: "Doug Dodson" <douglas.dodson(at)pobox.com> Subject: RE: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent funding assurance for several years, but it's not funny. Now everyone that isn't ATC or specifically safety related is on furlough until congress reconvene s in September. I say we find new jobs for the 4000 now proven "unnecessary " personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G _____ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA re registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectly air worthy and they can see I am putting in an effort. I phoned the FAA an d was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having bi g problems. AOPA told me that numerous owners are having problems and I can' t begin to imagine how much fuel revenue is being lost on everything from JETA 747's to 100LL just so the government can collect five bucks. I contacted Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how La w originated. Basically it states that laws must be practical and created by agreement amongst citizens in order for each citizen to benefit by cooperation. Batist goes on to say that when laws impede the function of society they no longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * ======================= Online Versions of Today's List Digest Archive ======================= Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2011-08-02&Archive=Glasair ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; ________________________________ Message 3 _____________________________________ From: Craymondw(at)aol.com Subject: Re: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Doug, Thanks for the moral support. Chuck Raymond In a message dated 8/3/2011 2:35:00 P.M. Eastern Daylight Time, douglas.dodson(at)pobox.com writes: I used electronic. No issue. I am definitely with you on laws and government. It is a joke that the FAA has not received any decent fundin g assurance for several years, but it=99s not funny. Now everyone tha t isn=99t ATC or specifically safety related is on furlough until congress reconvenes in September. I say we find new jobs for the 4000 now proven =9Cunnece ssary=9D personnel and scrap the laws that bureaucracy was established to support! Fat Chance. Doug Dodson Glasair II-S FT Flight Test Engineer, CFI-A/S&MEL/I/G ____________________________________ From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw@a o l.com Sent: Wednesday, August 03, 2011 9:35 AM Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 Have any Glasair drivers had the same problem I am having with this FAA r e registration hastle? I have been trying to re register the plane my wife and I built twenty years ago. I have been mailing the same form back and forth since early last December and the FAA keeps bouncing my application for trivial matters and now have grounded my plane even though it is perfectl y air worthy and they can see I am putting in an effort. I phoned the FAA and was told that their hands are tied because everything on the form has been mandated by congress. I contacted the EAA and they say electronic re registration is smoother than mail in and the mail in pilots are having b i g problems. AOPA told me that numerous owners are having problems and I can ' t begin to imagine how much fuel revenue is being lost on everything from JE TA 747's to 100LL just so the government can collect five bucks. I contacte d Senator Isakson and he mailed me a "Hold Harmless" form so that he can begin an FAA sub comittee investigation over this ridiculous idea. There is a 75 page book let in circulation named "The Law" that was written in the 18th century by an economist named Batist that wrote how L a w originated. Basically it states that laws must be practical and created b y agreement amongst citizens in order for each citizen to benefit by cooper a tion. Batist goes on to say that when laws impede the function of society they n o longer are useful to those citizens and not obeyed. Chuck Raymond Glasair2SFT N16CD In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes: * Online Versions of Today's List Digest Archive Today's complete Glasair-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Glasair-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 11-08-02&Archive=Glasair Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2011-08-02&Archive=Glasair ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Glasair-List Digest Archive --- Total Messages Posted Tue 08/02/11: 0 ---------------------------------------------------------- Today's Message the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; http://www.matronics.com/Navigator?Glasair-List http://forums.matronics.com http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Glasair-List) (http://www.matronics.com/contribution) the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p; http://www.matronics.com/Navigator?Glasair-List http://forums.matronics.com http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Glasair-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 04, 2011
Tsingtao Beer, produced by Tsingtao Brewery <http://en.wikipedia.org/wiki/Tsingtao_Brewery>, has been the best selling beer in China <http://en.wikipedia.org/wiki/China> for eleven consecutive years, and is also the brand most widely exported to other countries. It's just "okay." John Doug Dodson wrote: > > Screw it. Im moving to China. Do they have beer there? > > - Doug > > ------------------------------------------------------------------------ > > *From:*owner-glasair-list-server(at)matronics.com > [mailto:owner-glasair-list-server(at)matronics.com] *On Behalf Of > *Craymondw(at)aol.com > *Sent:* Thursday, August 04, 2011 8:27 AM > *To:* glasair-list(at)matronics.com > *Subject:* Glasair-List: Re: Glasair-List Digest: 3 Msgs - 08/03/11 > > Doug, > > When I fly my plane to Oshkosh and register our Glasair, the EAA has > no doubt that my wife and I own that plane and know where we live. But > when I tried to re register my plane several times with the FAA they > just couldn't seem to figure out who my wife and I are and where we > live and have grounded our plane because it has "expired" due to their > incompetence of letting their data base become compromised and made it > our problem and not theirs. > > My son was one of the youngest captain's flying a 747 for an airline > and was dragged out of the left seat and made vice president of a new > division handling TSA mandates. He often flew to meet with Washington > TSA heads and passed on to me this quote from a top Washington TSA > official; "My job is to get every general aviation plane out of the > sky." This is the mind set of a government that wants central > planning. We as a people are loosing our freedoms one freedom at a > time and I am one pissed off American. > > In a message dated 8/4/2011 3:06:29 A.M. Eastern Daylight Time, > glasair-list(at)matronics.com writes: > > * > > > Online Versions of Today's List Digest Archive > > > Today's complete Glasair-List Digest can also be found in either > of the > two Web Links listed below. The .html file includes the Digest > formatted > in HTML for viewing with a web browser and features Hyperlinked > Indexes > and Message Navigation. The .txt file includes the plain ASCII > version > of the Glasair-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-08-03&Archive=Glasair > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-08-03&Archive=Glasair > > > ====================== > EMail Version of Today's List Digest Archive > ====================== > > > ---------------------------------------------------------- > Glasair-List Digest Archive > --- > Total Messages Posted Wed 08/03/11: 3 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 09:37 AM - Re: Glasair-List Digest: 0 Msgs - 08/02/11 > (Craymondw(at)aol.com) > 2. 11:34 AM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 (Doug > Dodson) > 3. 01:13 PM - Re: Re: Glasair-List Digest: 0 Msgs - 08/02/11 > (Craymondw(at)aol.com) > > > ________________________________ Message 1 > _____________________________________ > > > From: Craymondw(at)aol.com > Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 > > Have any Glasair drivers had the same problem I am having with > this FAA re > registration hastle? I have been trying to re register the plane > my wife > and I built twenty years ago. I have been mailing the same form > back and > forth since early last December and the FAA keeps bouncing my > application for > > trivial matters and now have grounded my plane even though it is > perfectly > air worthy and they can see I am putting in an effort. I phoned > the FAA and > was told that their hands are tied because everything on the form > has been > mandated by congress. I contacted the EAA and they say electronic re > registration is smoother than mail in and the mail in pilots are > having big > problems. AOPA told me that numerous owners are having problems > and I can't > begin to imagine how much fuel revenue is being lost on everything > from JETA > 747's to 100LL just so the government can collect five bucks. I > contacted > Senator Isakson and he mailed me a "Hold Harmless" form so that he > can > begin an FAA sub comittee investigation over this ridiculous idea. > There is a 75 page book let in circulation named "The Law" that was > written in the 18th century by an economist named Batist that > wrote how Law > originated. Basically it states that laws must be practical and > created by > agreement amongst citizens in order for each citizen to benefit by > cooperation. Batist goes on to say that when laws impede the > function of society > they > no longer are useful to those citizens and not obeyed. > Chuck Raymond > Glasair2SFT N16CD > > > In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, > glasair-list(at)matronics.com writes: > > * > > ======================= > Online Versions of Today's List Digest Archive > ======================= > > Today's complete Glasair-List Digest can also be found in either > of the > two Web Links listed below. The .html file includes the Digest > formatted > in HTML for viewing with a web browser and features Hyperlinked > Indexes > and Message Navigation. The .txt file includes the plain ASCII > version > of the Glasair-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 11-08-02&Archive=Glasair > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 2011-08-02&Archive=Glasair > > > ===================== > EMail Version of Today's List Digest Archive > ===================== > > > ---------------------------------------------------------- > Glasair-List Digest Archive > --- > Total Messages Posted Tue 08/02/11: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > ________________________________ Message 2 > _____________________________________ > > > From: "Doug Dodson" <douglas.dodson(at)pobox.com> > Subject: RE: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 > > I used electronic. No issue. I am definitely with you on laws and > government. It is a joke that the FAA has not received any decent > funding > assurance for several years, but it's not funny. Now everyone that > isn't > ATC or specifically safety related is on furlough until congress > reconvenes > in September. I say we find new jobs for the 4000 now proven > "unnecessary" > personnel and scrap the laws that bureaucracy was established to > support! > > > Fat Chance. > > > Doug Dodson > > Glasair II-S FT > > Flight Test Engineer, CFI-A/S&MEL/I/G > > > _____ > > From: owner-glasair-list-server(at)matronics.com > [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of > Craymondw(at)aol.com > Sent: Wednesday, August 03, 2011 9:35 AM > Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 > > > Have any Glasair drivers had the same problem I am having with > this FAA re > registration hastle? I have been trying to re register the plane > my wife and > I built twenty years ago. I have been mailing the same form back > and forth > since early last December and the FAA keeps bouncing my > application for > trivial matters and now have grounded my plane even though it is > perfectly > air worthy and they can see I am putting in an effort. I phoned > the FAA and > was told that their hands are tied because everything on the form > has been > mandated by congress. I contacted the EAA and they say electronic re > registration is smoother than mail in and the mail in pilots are > having big > problems. AOPA told me that numerous owners are having problems > and I can't > begin to imagine how much fuel revenue is being lost on everything > from JETA > 747's to 100LL just so the government can collect five bucks. I > contacted > Senator Isakson and he mailed me a "Hold Harmless" form so that he > can begin > an FAA sub comittee investigation over this ridiculous idea. > > There is a 75 page book let in circulation named "The Law" that was > written in the 18th century by an economist named Batist that > wrote how Law > originated. Basically it states that laws must be practical and > created by > agreement amongst citizens in order for each citizen to benefit by > cooperation. Batist goes on to say that when laws impede the > function of > society they no longer are useful to those citizens and not obeyed. > > Chuck Raymond > Glasair2SFT N16CD > > > In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, > glasair-list(at)matronics.com writes: > > * > > ======================= > Online Versions of Today's List Digest Archive > ======================= > > Today's complete Glasair-List Digest can also be found in either > of the > two Web Links listed below. The .html file includes the Digest > formatted > in HTML for viewing with a web browser and features Hyperlinked > Indexes > and Message Navigation. The .txt file includes the plain ASCII > version > of the Glasair-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 11-08-02&Archive=Glasair > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 2011-08-02&Archive=Glasair > > > ===================== > EMail Version of Today's List Digest Archive > ===================== > > > ---------------------------------------------------------- > Glasair-List Digest Archive > --- > Total Messages Posted Tue 08/02/11: 0 > ---------------------------------------------------------- > > > Today's Message the ies ay - MATRONICS WEB FORUMS - > List Contribution Web Site p; > > > ________________________________ Message 3 > _____________________________________ > > > From: Craymondw(at)aol.com > Subject: Re: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 > > Doug, Thanks for the moral support. Chuck Raymond > > > In a message dated 8/3/2011 2:35:00 P.M. Eastern Daylight Time, > douglas.dodson(at)pobox.com writes: > > > I used electronic. No issue. I am definitely with you on laws and > government. It is a joke that the FAA has not received any decent > funding > > assurance for several years, but it=99s not funny. Now everyone tha > t isn=99t ATC > or specifically safety related is on furlough until congress > reconvenes in > > September. I say we find new jobs for the 4000 now proven =9Cunnece > ssary=9D > personnel and scrap the laws that bureaucracy was established to > support! > > Fat Chance. > > Doug Dodson > Glasair II-S FT > Flight Test Engineer, CFI-A/S&MEL/I/G > > > ____________________________________ > > From: owner-glasair-list-server(at)matronics.com > [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of > Craymondw@ao > l.com > Sent: Wednesday, August 03, 2011 9:35 AM > Subject: Glasair-List: Re: Glasair-List Digest: 0 Msgs - 08/02/11 > > Have any Glasair drivers had the same problem I am having with > this FAA re > > registration hastle? I have been trying to re register the plane > my wife > > and I built twenty years ago. I have been mailing the same form > back and > > forth since early last December and the FAA keeps bouncing my > application > for > trivial matters and now have grounded my plane even though it is > perfectly > > air worthy and they can see I am putting in an effort. I phoned > the FAA > and was told that their hands are tied because everything on the > form has > > been mandated by congress. I contacted the EAA and they say > electronic re > > registration is smoother than mail in and the mail in pilots are > having bi > g > problems. AOPA told me that numerous owners are having problems > and I can' > t > begin to imagine how much fuel revenue is being lost on everything > from JE > TA > 747's to 100LL just so the government can collect five bucks. I > contacted > > Senator Isakson and he mailed me a "Hold Harmless" form so that he > can > begin an FAA sub comittee investigation over this ridiculous idea. > > There is a 75 page book let in circulation named "The Law" that was > written in the 18th century by an economist named Batist that > wrote how La > w > originated. Basically it states that laws must be practical and > created by > > agreement amongst citizens in order for each citizen to benefit by > coopera > tion. > Batist goes on to say that when laws impede the function of > society they n > o > longer are useful to those citizens and not obeyed. > > Chuck Raymond Glasair2SFT N16CD > > > In a message dated 8/3/2011 3:06:17 A.M. Eastern Daylight Time, > glasair-list(at)matronics.com writes: > > * > > > Online Versions of Today's List Digest Archive > > > Today's complete Glasair-List Digest can also be found in either > of the > two Web Links listed below. The .html file includes the Digest > formatted > > in HTML for viewing with a web browser and features Hyperlinked > Indexes > and Message Navigation. The .txt file includes the plain ASCII > version > > of the Glasair-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch > apter > 11-08-02&Archive=Glasair > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha > pter > 2011-08-02&Archive=Glasair > > > ===================== > EMail Version of Today's List Digest Archive > ===================== > > > ---------------------------------------------------------- > Glasair-List Digest Archive > --- > Total Messages Posted Tue 08/02/11: 0 > ---------------------------------------------------------- > > > Today's Message the ies ay - MATRONICS WEB FORUMS > > - List Contribution Web Site p; > > > http://www.matronics.com/Navigator?Glasair-List > > > http://forums.matronics.com > > > http://www.matronics.com/contribution > > > (http://www.matronics.com/Navigator?Glasair-List) > > (http://www.matronics.com/contribution) the ies ay - MATRONICS WEB > FORUMS - List Contribution Web Site p; > > > * * > * * > ** > ** > ** > *http://www.matronics.com/Navigator?Glasair-List* > ** > ** > *http://forums.matronics.com* > ** > ** > *http://www.matronics.com/contribution* > * * > * > > > * ________________________________________________________________________________
Date: Aug 31, 2011
Subject: Ref: Owner
Does anyone have Glasair three driver, Ken Johnson's new e-mail address. Debbie Raymond Glasair 2S owner. ________________________________________________________________________________
From: " Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Need more speed. Anyone need less?
Date: Sep 12, 2011
Glasair 1 Pilots: My son has moved 400+ NM away, so I now have a need to go a lot faster, and I am hoping to find someone that needs to go slower or just needs the 5-6 gph fuel burn! Perhaps one of you fits that bill? I have a well-built and well-proven Zodiac 601XLb taildragger I'd like to trade for a Glasair 1 (TD or RG). I haven't put together a real web page yet, and am missing glass panel and interior shots, but most of the specs are here: http://members.cox.net/n601ge/equiplist/EquipmentList.html Here is a picture of the plane centerline at Conoco-Philips Plaza (!) at Oshkosh in July this year: https://www.facebook.com/photo.php?pid=320080&id=133387926736000&fbid=156365 127771613 I will be listing her for $44K with a fresh inspection, and she should be ready to go by the Copperstate Fly-In in mid-October (http://www.copperstate.org/csj/). I am willing to discuss +/- $5K or so in the deal. Performance One )nee Phoenix Composites) is right here at my field (FFZ) for a pre-buy inspection on the Glasair, if someone is interested. Let's talk if you are interested, Andy ------------------------ Andy Elliott N601GE/Z601XL/TD/Corvair 390 hrs since 11/08 CL: 480-695-9568 ________________________________________________________________________________
Date: Sep 12, 2011
A word of advice, Glasair I RG landing gear parts are no longer made or stocked by the factory. That means that if you bend your landing gear you'll have to manufacturer your own parts or scrap the airplane. GI's cruise at 170 KTS (Most have 160 HP engines) GII's, around 180 KTS (Most have 180 HP engines) GIII's cruise around 230 KTS (300 HP engine) Fixed gear will slow the above airplanes by 10-15 KTS (Except the GIII which doesn't have a fixed gear flavor). Bruce WWW.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Dr. Andrew Elliott Sent: Monday, September 12, 2011 12:36 PM Subject: Glasair-List: Need more speed. Anyone need less? Glasair 1 Pilots: My son has moved 400+ NM away, so I now have a need to go a lot faster, and I am hoping to find someone that needs to go slower or just needs the 5-6 gph fuel burn! Perhaps one of you fits that bill? I have a well-built and well-proven Zodiac 601XLb taildragger I'd like to trade for a Glasair 1 (TD or RG). I haven't put together a real web page yet, and am missing glass panel and interior shots, but most of the specs are here: http://members.cox.net/n601ge/equiplist/EquipmentList.html Here is a picture of the plane centerline at Conoco-Philips Plaza (!) at Oshkosh in July this year: https://www.facebook.com/photo.php?pid=320080&id=133387926736000&fbid=15 6365 127771613 I will be listing her for $44K with a fresh inspection, and she should be ready to go by the Copperstate Fly-In in mid-October (http://www.copperstate.org/csj/). I am willing to discuss +/- $5K or so in the deal. Performance One )nee Phoenix Composites) is right here at my field (FFZ) for a pre-buy inspection on the Glasair, if someone is interested. Let's talk if you are interested, Andy ------------------------ Andy Elliott N601GE/Z601XL/TD/Corvair 390 hrs since 11/08 CL: 480-695-9568 ________________________________________________________________________________
Date: Sep 12, 2011
Subject: Re: Need more speed. Anyone need less?
On 09/12/2011 03:18 PM, Bruce wrote: > GI's cruise at 170 KTS (Most have 160 HP engines) > > GII's, around 180 KTS (Most have 180 HP engines) > > GIII's cruise around 230 KTS (300 HP engine) > > Fixed gear will slow the above airplanes by 10-15 KTS (Except the GIII > which doesn't have a fixed gear flavor). Hmmm.. My Glasair 1 FT with fixed gear, fixed pitch prop had a top speed of 194 kts IAS at 8000 feet. Lyc 150hp. Just fyi, -Dj ________________________________________________________________________________
Date: Sep 12, 2011
You must be going downhill :). Bruce WWW.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Monday, September 12, 2011 3:39 PM Subject: Re: Glasair-List: Need more speed. Anyone need less? On 09/12/2011 03:18 PM, Bruce wrote: > GI's cruise at 170 KTS (Most have 160 HP engines) > > GII's, around 180 KTS (Most have 180 HP engines) > > GIII's cruise around 230 KTS (300 HP engine) > > Fixed gear will slow the above airplanes by 10-15 KTS (Except the GIII > which doesn't have a fixed gear flavor). Hmmm.. My Glasair 1 FT with fixed gear, fixed pitch prop had a top speed of 194 kts IAS at 8000 feet. Lyc 150hp. Just fyi, -Dj ________________________________________________________________________________
Date: Sep 12, 2011
Well built Glasair2 Fts' are faster on average than the Rg's. The reason being is RG gear weights a heck of a lot more. If you find a Glasair 2 with Van's wheel pants they add another 6 to 7 knots over Glasair factory supplied. My Glasair2S was clocked at the 1994 Sun and Fun race doing 227 mph with a 190 hp engine. One of the fastest Glasair2's FT 200Hp is owned by Monte McClain in Crestview Beach Fla. That plane has a newly over hauled engine and he purchased a three a few years back. Try contacting him. a message dated 9/12/2011 3:21:54 P.M. Eastern Daylight Time, BGray(at)glasair.org writes: --> Glasair-List message posted by: "Bruce" A word of advice, Glasair I RG landing gear parts are no longer made or stocked by the factory. That means that if you bend your landing gear you'll have to manufacturer your own parts or scrap the airplane. GI's cruise at 170 KTS (Most have 160 HP engines) GII's, around 180 KTS (Most have 180 HP engines) GIII's cruise around 230 KTS (300 HP engine) Fixed gear will slow the above airplanes by 10-15 KTS (Except the GIII which doesn't have a fixed gear flavor). Bruce WWW.Glasair.org -----Original Message----- From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Dr. Andrew Elliott Sent: Monday, September 12, 2011 12:36 PM Subject: Glasair-List: Need more speed. Anyone need less? Glasair 1 Pilots: My son has moved 400+ NM away, so I now have a need to go a lot faster, and I am hoping to find someone that needs to go slower or just needs the 5-6 gph fuel burn! Perhaps one of you fits that bill? I have a well-built and well-proven Zodiac 601XLb taildragger I'd like to trade for a Glasair 1 (TD or RG). I haven't put together a real web page yet, and am missing glass panel and interior shots, but most of the specs are here: http://members.cox.net/n601ge/equiplist/EquipmentList.html Here is a picture of the plane centerline at Conoco-Philips Plaza (!) at Oshkosh in July this year: https://www.facebook.com/photo.php?pid=320080&id=133387926736000&fbid=15 6365 127771613 I will be listing her for $44K with a fresh inspection, and she should be ready to go by the Copperstate Fly-In in mid-October (http://www.copperstate.org/csj/). I am willing to discuss +/- $5K or so in the deal. Performance One )nee Phoenix Composites) is right here at my field (FFZ) for a pre-buy inspection on the Glasair, if someone is interested. Let's talk if you are interested, Andy ------------------------ Andy Elliott N601GE/Z601XL/TD/Corvair 390 hrs since 11/08 CL: 480-695-9568 ________________________________________________________________________________
Date: Sep 12, 2011
There's a Glasair IIRG on ebay right now listed as "buy now" for $49,000. ________________________________________________________________________________
Date: Nov 01, 2011
Subject: PLEASE READ - 2011 List Fund Raiser Kickoff - 21 Years Strong!!
Dear Listers, This year marks 21 years of the Email Lists and Forums at Matronics! I've been running these forums for nearly half my life! I've made some great friends over the years and had countless email and personal conversations with builders about aircraft building and flying. What a great community of people! The advice, support, and friendship has be invaluable over the years. To support the continued operation and upgrade of the List servers, each November I hold a PBS-like fund raiser. It is solely through the Contributions of List members that these Matronics Lists are possible. There is NO advertising to support the Lists. You might have noticed the conspicuous lack of flashing banners and annoying pop-ups on the Matronics Email List email messages and web site pages including: * Matronics List Forums http://forums.matronics.com * Matronics List Search Engine http://www.matronics.com/search * Matronics List Browser http://www.matronics.com/listbrowse * Matronics List List Wiki http://wiki.matronics.com You don't find advertising on any of these pages because I believe in a List experience that is completely about the sport we all enjoy - airplanes! During the month of November, I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these Lists. Your personal Contribution counts! Once again, this year we've got another terrific line up of free gifts to go along with the various Contribution levels. Many of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous people include: * Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com * Andy Gold of the Builder's Bookstore http://www.buildersbooks.com These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, and Andy for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Matt Dralle Matronics Email List Administrator RV-8 Builder (and Rebuilder) and Flyer RV-6 Rebuilder and Flyer RV-4 Builder ________________________________________________________________________________
Date: Nov 03, 2011
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2011
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2011
Subject: Make A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 09, 2011
Subject: Reminder
Dear Listers, Just a quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 11, 2011
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Link
Date: Nov 11, 2011
Here is a link I promised u to send http://thebubblefish.com/inf.php ________________________________________________________________________________
Subject: Link
Date: Nov 11, 2011
Date: Nov 13, 2011
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2011
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some pointd, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for over 21 years (yeah, I really said *21* years) worth of on line archive data available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2011
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Your Contributions alone keep these services up and running. Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2011
Subject: The Value of a Forum...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Arn't the Lists worth at least that much to you? Wouldn't it be great if you could pay that same amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... Won't you take a minute to make your Contribution today and support YOUR Lists? Please make a Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Make Sure You're Listed -- List of Contributors Published
Dec 1! Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, the Lists are a whole lot more valuable than your typical magazine subscription! Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 23, 2011
Subject: Contributions Down By 20%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 20%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Site, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2011
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 27, 2011
Subject: Please Make A Contribution Today...
Dear Listers, A quick reminder that November is the annual List Fund Raiser and the List of Contributors is quickly approching. The Matronics Lists are 100% member supported and all of the operational costs are provided for by your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 29, 2011
Subject: Just Two Days Left - Still Way Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. Over the last few weeks I have received some really nice comments from members on what the Lists have meant to them. I have included some of them below. Please read over the comments and ponder on your own feelings about the Lists and the support and camaraderie you have found here. We are still way behind last year in terms of the number of contributions. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ==================== A Few List Member Comments ===================== I get a lot of useful information and satisfaction from belonging to your groups. Somehow you foster a great sense of community without the baggage that accompanies other lists. Dave S. We do appreciate you running the lists spam and advertising free. Jeff P. I am celebrating my first flight day and you and the lists deserve a thanks since without it my build would have taken twice as long. Chris L. I enjoy the list. Have my morning coffee with it! Buddy M. Your lists are the best investment of my time and money, bar none, when it comes to interfacing with my fellow amateur builders. Owen B. Keep it going!! Thanks for taking over. Wallace J. I enjoy the Pietenpol List a lot. Malcolm Z. Thanks for your great site! As a new CJ-6 owner, your web site is an invaluable resource. Ken B. Great informational source. Fred S. Thanks for doing this! Lance G. Thank you for the service i do enjoy the many hours I use on line with the banter/ serious technical items. Noel G. Thanks for the years of builder support. Roy H. Great forum! Roger C. Thank you VERY MUCH, Matt, for carrying on with this great service. The "Europa" community really appreciates it. All the best, Svein - now celebrating 10 years as a subscriber, I think! Svein J. Matt, I'm building a much nicer and safer airplane because of your efforts. Robert D. 21 years for you 9 years for me on the Zenith lists. Could not imagine building and flying without Matronics. Brian U. Thanks for ALL the hard work and time you put into maintaining these forums. As an EAA Tech counselor I recommend them often. Paul M. This Pietenpol list is a huge part of the motivation that keeps me working on my project. This has been a great place for meeting like minded folks and getting help for the difficult parts. Thomas S. Thanks for the excellent service Matt. Frank S. Matt, I'm a Sonex building, but I have to say that the Piet group is without a doubt the most interesting. Ken M. I can't tell you how much I appreciate the Piet List. This is one of my sanity lifelines! Daniel H. Your site has provided us over the years with excellent connections to others for advice. Good job! Bob M. Kolb List is my #1 source! Henry V. Matt, you do a great job with this site. I've been with it since the beginning! John M. I am very grateful for all of your excellent work on the List. Arthur L. Thank you for the service you provide us all! Nicholas C. ________________________________________________________________________________
Date: Nov 30, 2011
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means a couple of things. Its my birthday again, 48 of them, in fact! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been jones'n over one of those really nice incentive gifts now is the time to jump on one!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. Hopefully everyone feels the same. Below are a few more of the nice comments from Listers I've received this year. Please read them over and see if you don't agree. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ==================== A Few More List Member Comments ===================== I never would have ended up with the great flying airplane I have without the help of people on the Pietenpol list. Thanks for giving us the medium to communicate our questions, tips and suggestions. Matt P. Thanks for the hard work and maintaining the site commercial free. Good luck for the future and this site has been a source of great friendship. Peter B. It is a great resource. Jim G. Thanks so much for your continuing support of the homebuilt community. Gerald A. You are doing an outstanding job running the list's. Keep it going. Bill V. Thanks for keeping this valuable information source going. Best of all the forums. George A. Another Great year on the RV-List! Thomas E. Still the best source of information (& opinion) for builders on a wide range of issues. Martin H. Matt, thanks for hosting and maintaining the lists! Rumen D. It is a great resource. Bryan R. Thanks for your continuing interest in Van's RV8 kitplanes. Peter C. I'm no longer building or flying but like to keep in touch with the current generation of builders. Best wishes to a great list system. Gerry C. A great list that is most useful for builders. Graham H. Thanks for this wonderful tool! Ralph C. Thanks for a great service to the experimental aviation community. Douglas D. Great topics and loads of useful info keep the subject matter relevant. George H. Thanks for keeping this going. Richard R. Great facility and well managed. Victor F. Thanks for a great service. John D. Thank you for you time and efforts they have made Aviation a better place for everyone. Jim W. I still enjoy getting the list in the morning. Don M. You provide a great resource. David M. You have probably saved a few necks over the years. Robert F. Thank you for being there. Benjamin B. You perform a great service. Bruce M. Thank you for providing this invaluable resource. William D. ________________________________________________________________________________
Date: Dec 04, 2011
Subject: Hardware Failure - Matronics Web Servers Currently Offline
failure and is currently not available. Replacement hardware has been ordered and should arrive on Tuesday 12/6/2011. All services should be restored shortly there after. During the outage, the Matronics Forums, Wiki, and other web-based List services will NOT be available. However, during the outage, all normal EMAIL based sevices WILL be available so you may continue to post messages to the various lists without an issue. I am so sorry for any inconvenience this web server outage has caused... Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 07, 2011
Subject: Matronics Web Services Restored!
Dear Listers, web services have been fully restored including the Web Forums, List Browse, Archive Search, Wiki, and AeroElectric web sites. It was quite an ordeal getting the replacement boards for the server, but things went back together tonight and are up and running nicely. The first company I ordered the boards from originally called me a day later to say that, whoops, they really didn't have them in stock after all... Fortunately, I was able to locate some through a different source and had then over-nighted and they arrived today. Thank you for your patience and consideration though the whole thing! The List Contribution web site is also back on line for those wishing to make a donation to the effort: http://www.matronics.com/contribution Best regards, Matt Dralle Matronics List Administrator ________________________________________________________________________________
Date: Dec 19, 2011
Subject: 2011 List of Contributors
Dear Listers, The 2011 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and its time that I publish this year's List of Contributors. Its the people on this list that directly make the Email Lists and Forums possible. Their generous contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some great products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com And finally, I'm proud to present The 2011 Fund Raiser List of Contributors: http://www.matronics.com/loc/2011.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Jan 31, 2012
Subject: GPS
Hi guys, I just purchased a new GPS and want to sell my very reliable old one. It is an aviation Garmin 195 moving map. I had it rewired to plug into a 12v jack. And I have the old cigaret plug. I have the yoke mount and case and will sell everything for $96. If interested phone me at 404-545-4641. Debbie Raymond; Glasair 2SFT 200hp N16CD ________________________________________________________________________________
Date: Feb 08, 2012
Subject: Glasair 3 Kit for Sale
Selling my Glasair 3 kit,. Electric slotted flaps and wingtip extension options. Landing gear installed and plumbed in wing, Wing almost ready to close. Located at KIMM. Available for inspection anytime. Contact via email or call 239-595-4587. Paul ________________________________________________________________________________
From: "L. Shawn Kilpatrick" <lshawnk(at)hotmail.com>
Subject: Hartzell Aerobatic Prop, Governor and Spinner for Glasair
II
Date: Feb 09, 2012
72" Hartzell Aerobatic Prop=2C Spinner with front and backplates and Woodwa rd Gov. Prop PN: HC-C2YR-4CF/FC7666A-4=2C SN: AU9420B=2C TT since new 366 h rs. Prop was Inspected and Resealed by Aircraft Prop Service=2C Inc=2C Whee ling=2C IL in 3/2010. Gov PN D210688=2C SN 2136064P TT 366 hrs=2C Spinner f or Glasair II TT 366 Hours. The Prop is current with all AD=92s. All items in storage since 3/2010. I flew the prop only cross country=2C never aeroba tic. Never experienced any issues with the Prop or Gov. Cost for all three: $7=2C100. Photos and log book available. - Contact L. Shawn Kilpatrick =2C Owner - located Gurnee=2C IL USA - Telephone: 847 826 0648 . ________________________________________________________________________________
Subject: Check your wing to fuselage fittings for tightness!
Date: Jun 04, 2012
We just completed our 16th "annual" inspection. (17th year of flying, 3300 hrs.) I had rechecked the torque on the front and rear wing to fuselage fittings about seven to ten years ago, but to my surprise, the front screws took another quarter turn this time. The rear bolts were still pretty tight but needed an eighth of a turn. I'm thinking that installing Countersunk Tinnerman washers on the front screws (which the factory called for in a SB and then later rescinded) might be a good idea. I'm guessing the screw heads are crushing the glass over time and, as with a wood prop and crushing fibers, need constant re-torquing? (We also checked the engine mount to firewall torque years ago. Those bolts also needed a quarter turn more back then.) FWIW, we fly straight & level. No aerobatics. P.S. The plane is still for sale. glasairforsale,freevar.com Hope this helps, Mike Palmer <>< ________________________________________________________________________________
Subject: Re: Check your wing to fuselage fittings for tightness!
Date: Jun 04, 2012
With 3300 hours tightening them once doesn't sound too bad. Ironically, I just drilled these very holes to mount the wing on my glasair 3 today! Did you mark the nuts when you installed them to have a reference? This way you can tell if they are backing off or if indeed they are working into the fiberglass. Would be useful to know this one. Either way, 17 years and 3300 hours seems like quite a bit of flying to only need that small tweak. Good luck with the sale, too bad you are leaving the ranks of glasairs. Todd Sent from my iPad On Jun 4, 2012, at 5:06 PM, mppalmer(at)aol.com wrote: > > We just completed our 16th "annual" inspection. (17th year of flying, 3300 hrs.) I had rechecked the torque on the front and rear wing to fuselage fittings about seven to ten years ago, but to my surprise, the front screws took another quarter turn this time. The rear bolts were still pretty tight but needed an eighth of a turn. > > I'm thinking that installing Countersunk Tinnerman washers on the front screws (which the factory called for in a SB and then later rescinded) might be a good idea. I'm guessing the screw heads are crushing the glass over time and, as with a wood prop and crushing fibers, need constant re-torquing? > > (We also checked the engine mount to firewall torque years ago. Those bolts also needed a quarter turn more back then.) > > FWIW, we fly straight & level. No aerobatics. > > P.S. The plane is still for sale. glasairforsale,freevar.com > > Hope this helps, > > Mike Palmer <>< > > > > > > > > > ________________________________________________________________________________
Date: Jun 04, 2012
Thanks, Mike. I'll check 'em. Dick Gossen N90GG 22 years flying/1900 hours On Jun 4, 2012, at 4:06 PM, mppalmer(at)aol.com wrote: > > We just completed our 16th "annual" inspection. (17th year of flying, 3300 hrs.) I had rechecked the torque on the front and rear wing to fuselage fittings about seven to ten years ago, but to my surprise, the front screws took another quarter turn this time. The rear bolts were still pretty tight but needed an eighth of a turn. > > I'm thinking that installing Countersunk Tinnerman washers on the front screws (which the factory called for in a SB and then later rescinded) might be a good idea. I'm guessing the screw heads are crushing the glass over time and, as with a wood prop and crushing fibers, need constant re-torquing? > > (We also checked the engine mount to firewall torque years ago. Those bolts also needed a quarter turn more back then.) > > FWIW, we fly straight & level. No aerobatics. > > P.S. The plane is still for sale. glasairforsale,freevar.com > > Hope this helps, > > Mike Palmer <>< > > > > > > > > > ________________________________________________________________________________
Date: Jun 04, 2012
I talked to friend from Germany that built fiber glass yachts beginning in the late 1950's through the late 1970's. Now he produces fiber glass parts for aircraft ranging from wheel pants to wing tips. I remember him telling me that resin continues to cure even after it's initial cure until it eventually disintegrates. Don't worry because that will take a few hundred years or more. He reported the resin cures in a curve that slowly drops off over time. I would imagine that as the resin cures over lets say the first several years that it may also shrink. Has anyone made any studies or taken any measurements? And could this be the reason for screws and bolts becoming loose? Back in 1996 I had my nose wheel assembly part company on my 1991 Glasair 2S Ft when we landed on grass growing on a sandy type of soil and it flung into my right main causing the wing to drop on the dangling right main strut causing the outer bottom skin to dent a little. Those original 3/16 bolts holding on the nose wheel trunions stretched until they snapped causing the nose wheel assembly to part company. When I had the wing in the shop and began to sand it to scarf in layers of cloth I found I couldn't make any progress sanding it by hand. So I used a body grinder beginning with 150 grit paper and nothing happened, I kept switching paper until I ended using 80 steel grit!! I found grinding through the factory layers harder than grinding through aircraft sheet aluminum. My German friend asked me if I had built a tank!! Here is a hint. In case you have to make a fiber glass repair, after you use the heavy cloth and it has cured use a very light fiber glass cloth used on model aircraft as a finishing layer to cover up the weave of the heavier factory glass cloth weave. After that spray it with a two part feather fill and block sand it out. In a message dated 6/4/2012 5:37:03 P.M. Eastern Daylight Time, mppalmer(at)aol.com writes: --> Glasair-List message posted by: mppalmer(at)aol.com We just completed our 16th "annual" inspection. (17th year of flying, 3300 hrs.) I had rechecked the torque on the front and rear wing to fuselage fittings about seven to ten years ago, but to my surprise, the front screws took another quarter turn this time. The rear bolts were still pretty tight but needed an eighth of a turn. I'm thinking that installing Countersunk Tinnerman washers on the front screws (which the factory called for in a SB and then later rescinded) might be a good idea. I'm guessing the screw heads are crushing the glass over time and, as with a wood prop and crushing fibers, need constant re-torquing? (We also checked the engine mount to firewall torque years ago. Those bolts also needed a quarter turn more back then.) FWIW, we fly straight & level. No aerobatics. P.S. The plane is still for sale. glasairforsale,freevar.com Hope this helps, Mike Palmer <>< ________________________________________________________________________________
From: "=?utf-8?B?cm9iaW4wMkBtaW5kc3ByaW5nLmNvbQ==?=" <robin02(at)mindspring.com>
Subject: =?utf-8?B?UmU6IEdsYXNhaXItTGlzdDogQ2hlY2sgeW91ciB3aW5nIHRvIGZ1c2VsYWdlIGZpdHRpbmdzIGZvciB0aWdodG5lc3Mh?
Date: Jun 04, 2012
VGhhbmtzIE1pa2UuIFN0YXJ0aW5nIGFuIGluc3BlY3Rpb24gc29vbi4gIFdoYXQgdG9ycXVlIHZh bHVlcyBhcmUgeW91IHdvcmtpbmcgdG8/IFJvYmluCgpTZW50IGZyb20gbXkgSFRDIG9uIHRoZSBO b3cgTmV0d29yayBmcm9tIFNwcmludCEKCi0tLS0tIFJlcGx5IG1lc3NhZ2UgLS0tLS0KRnJvbTog bXBwYWxtZXJAYW9sLmNvbQpEYXRlOiBNb24sIEp1biA0LCAyMDEyIDU6MDYgcG0KU3ViamVjdDog R2xhc2Fpci1MaXN0OiBDaGVjayB5b3VyIHdpbmcgdG8gZnVzZWxhZ2UgZml0dGluZ3MgZm9yIHRp Z2h0bmVzcyEKVG86IDxnbGFzYWlyLWxpc3RAbWF0cm9uaWNzLmNvbT4KCi0tPiBHbGFzYWlyLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6IG1wcGFsbWVyQGFvbC5jb20KCldlIGp1c3QgY29tcGxldGVk IG91ciAxNnRoICJhbm51YWwiIGluc3BlY3Rpb24uICgxN3RoIHllYXIgb2YgZmx5aW5nLCAzMzAw IGhycy4pIEkgaGFkIHJlY2hlY2tlZCB0aGUgdG9ycXVlIG9uIHRoZSBmcm9udCBhbmQgcmVhciB3 aW5nIHRvIGZ1c2VsYWdlIGZpdHRpbmdzIGFib3V0IHNldmVuIHRvIHRlbiB5ZWFycyBhZ28sIGJ1 dCB0byBteSBzdXJwcmlzZSwgdGhlIGZyb250IHNjcmV3cyB0b29rIGFub3RoZXIgcXVhcnRlciB0 dXJuIHRoaXMgdGltZS4gVGhlIHJlYXIgYm9sdHMgd2VyZSBzdGlsbCBwcmV0dHkgdGlnaHQgYnV0 IG5lZWRlZCBhbiBlaWdodGggb2YgYSB0dXJuLgoKSSdtIHRoaW5raW5nIHRoYXQgaW5zdGFsbGlu ZyBDb3VudGVyc3VuayBUaW5uZXJtYW4gd2FzaGVycyBvbiB0aGUgZnJvbnQgc2NyZXdzICh3aGlj aCB0aGUgZmFjdG9yeSBjYWxsZWQgZm9yIGluIGEgU0IgYW5kIHRoZW4gbGF0ZXIgcmVzY2luZGVk KSBtaWdodCBiZSBhIGdvb2QgaWRlYS4gSSdtIGd1ZXNzaW5nIHRoZSBzY3JldyBoZWFkcyBhcmUg Y3J1c2hpbmcgdGhlIGdsYXNzIG92ZXIgdGltZSBhbmQsIGFzIHdpdGggYSB3b29kIHByb3AgYW5k IGNydXNoaW5nIGZpYmVycywgbmVlZCBjb25zdGFudCByZS10b3JxdWluZz8KCihXZSBhbHNvIGNo ZWNrZWQgdGhlIGVuZ2luZSBtb3VudCB0byBmaXJld2FsbCB0b3JxdWUgeWVhcnMgYWdvLiBUaG9z ZSBib2x0cyBhbHNvIG5lZWRlZCBhIHF1YXJ0ZXIgdHVybiBtb3JlIGJhY2sgdGhlbi4pCgpGV0lX LCB3ZSBmbHkgc3RyYWlnaHQgJiBsZXZlbC4gTm8gYWVyb2JhdGljcy4KClAuUy4gVGhlIHBsYW5l IGlzIHN0aWxsIGZvciBzYWxlLiBnbGFzYWlyZm9yc2FsZSxmcmVldmFyLmNvbQoKSG9wZSB0aGlz IGhlbHBzLAoKTWlrZSBQYWxtZXIgPD48CgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBH bGFzYWlyLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0 dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNo IGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwg Ny1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1v cmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9HbGFz YWlyLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JV TVMgLQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZv cnVtcyEKXy09Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFu ayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgo ________________________________________________________________________________
Subject: Errata on tighting wing/fuse hardware
Date: Jun 05, 2012
I guess I wasn't clear. This was the second time I've re-torqued the hardware in the life of the plane. But you're correct - twice in 17 years isn't bad. The nuts are marked with nail polish. It's not a matter of the nuts backing out. It's a matter of the fiberglass changing dimension. It could be the high density foam crushing over time in addition to the resin shrinking. Yes, I can believe that the resin is constantly shrinking/curing. Someone told me once that, with the Glasairs, this is because the resin was never oven cured and so is constantly shrinking as it (still) cures. Remember how the factory started to oven cure the fiberglass gear legs on the FT's and TD's after a while? Taking them to a certain temperature in the oven made thema a lot stronger. Before they were oven cured, they used to creep outward. I know that here, in sunny, hot Phoenix, the dark red fairings on our Glasair have shrunk. You can see the texture of the weave of the cloth over time - kinda like the bones poking out in an emaciated person. And, consistent with oven curing, the engine mount to fuse bolts only needed to be re-torqued once. The heat of the engine compartment seems to have done a final cure and any further shrinkage there has been minimal. In any event, next time you're doing maintenance on the airplane, check for things like this. We tend to think the static parts stay static. But no harm in putting a wrench on them to make sure. Report your results here. It should be interesting to know what the rest of you find with attach hardware tightness on your plane. Mike <>< ________________________________________________________________________________
Date: Jun 05, 2012
Subject: Re: Errata on tighting wing/fuse hardware
Fiber glass pioneers like you will provide the data for future designs and maintenance and your knowledge will be incorporated into manuals. That German friend of mine informed me that the first German made fiber glass glider manufactured back in the late 1950's still flies!! 1950's resins, glass cloth and building techniques have evolved since then and there is no co mparison with today's products and technology. My German friend thinks over built Glasairs will be the D.C.3's of the future. After 21 years my fuselage skins are beginning to pull in a tiny bit and what was once a perfectly faired surface is beginning to look a little puckered in spots. From new, when I hangered my plane, I use a jack with a one foot by one foot board with a cushion of hard rubber foam and jack my wing up until the wheel comes off the ground, then I let the jack down completely and then jack it up about and inch or so to take the weight off the landing gear so that it doesn't splay out. Before I flew a Glasair I flew Grumman Tigers that had fiberglass legs and noticed the landing gear splayed out after a while and hoped to avoid that. I too mark all bolts and nuts with a line of red paint. When I saw that on my over hauled engine I thought it was a good idea. Too bad you are dropping out, I always took your advice. Chuck Raymond N16CD Gl2SFT 200HP In a message dated 6/5/2012 10:47:44 P.M. Eastern Daylight Time, mppalmer(at)aol.com writes: --> Glasair-List message posted by: mppalmer(at)aol.com I guess I wasn't clear. This was the second time I've re-torqued the hardware in the life of the plane. But you're correct - twice in 17 years isn't bad. The nuts are marked with nail polish. It's not a matter of the nuts backing out. It's a matter of the fiberglass changing dimension. It could be the high density foam crushing over time in addition to the resin shrinking.
February 18, 2010 - June 09, 2012
Glasair-Archive.digest.vol-af
