Kitfox-Archive.digest.vol-ce
July 09, 2005 - July 29, 2005
      > 3) It's kinder to the grass
      > 4) It's a reminiscence of the time Kitfoxes were flown by skinheads? :-)
      > Cheers,
      > Michel
Date: Jul 09, 2005
Subject: Re: Windshield Fasteners
All, I used a pan head type machine screw and used an o-ring washer beneath it, so it "nests" into a counter sunk base in the plexiglass. It takes some practice to get the right depth so the o-ring compresses properly without too much head to plexiglass tension. Works great so far !!! No leaks and no cracks. Jeff Smathers John King wrote: > > Guy, > > I prefer to use #6 SS flat head screws with SS Tinnerman washers. I > countersink the windshield holes to fit the Tinnerman washers. I also > use #6 self locking nuts, the type that are riveted in place. Just make > sure you do not secure the screws tightly. I tighten the screws just > enough to allow the Tinnerman washers to move slightly with side > pressure. This is necessary to allow for expansion of the plastic > windshield in extreme temperatures. The screws also allow for easy > removal. Aluminum rivets require drilling to remove and do not allow > for temperature expansion. Screws take more work to install, but save > tons of work later. > > -- > John King > Warrenton, VA > > Guy Buchanan wrote: > > > > >Hi everybody. > > What should I use to fasten my windshield/skylight. The manual > >says aluminum rivet, I assume that's a pop rivet, but it could be a > >standard rivet as well. Should I fasten it with #6 screws and lock nuts for > >maintainability? Or is that too heavy and unnecessary? Thanks for the help. > > > > > >Guy Buchanan > >K-IV 1200 / 582 / 99% done, thanks to Bob Ducar. > > > > > > > > > ________________________________________________________________________________
Date: Jul 09, 2005
Subject: Tires question extended,,
All, I have the standard Aero Trainer 6.0 x 6.0 tires and was thinking of trying to find a 6.0 x 8.0, or in that range....Anyone have a source? Thanks, Jeff Smathers ________________________________________________________________________________
From: "John Anderson" <janderson412(at)hotmail.com>
Subject: Windshield Fasteners
Date: Jul 10, 2005
I used 2.2mm stainless scews and nyliock nuts. Wee bit more weight but being able to controll the tension on on the screen is a positive to me. Makes it easy when change tome comes too. John A. Series 5 Turbo Subaru.. From: Guy Buchanan <bnn(at)nethere.com> Subject: Kitfox-List: Windshield Fasteners Date: Sat, 09 Jul 2005 12:00:44 -0700 Hi everybody. What should I use to fasten my windshield/skylight. The manual says aluminum rivet, I assume that's a pop rivet, but it could be a standard rivet as well. Should I fasten it with #6 screws and lock nuts for maintainability? Or is that too heavy and unnecessary? Thanks for the help. Guy Buchanan K-IV 1200 / 582 / 99% done, thanks to Bob Ducar. Become a fitness fanatic @ http://xtramsn.co.nz/health ________________________________________________________________________________
Date: Jul 09, 2005
Subject: Re: Latest on 912 coolant and oil?
Hey Lowell, What's the skinny on the Motul 5100? I've been using it now for a while?? I just finished up a case my last oil change... Thanks, Ted --- Original Message --- From: "Lowell Fitt" <lcfitt(at)sbcglobal.net> Subject: Re: Kitfox-List: Latest on 912 coolant and oil? > >I suspect that Rotax will have a hard time recommending another engine >manufacturers oil, so my "guess" is that the Honda oil would otherwise be on >the list. That said, the reason I am using the oil from the accepted list >is that an I used to use and previously listedt was delisted because of the >the EPA mandated formula change on that brand of oil (Motul 5100). I began >using an oil formulated and sold by California Power Systems (a Rotax >distributor). Eric said they were planning on testing that oil for the >foaming problem - nothing yet. I have discontinued using that oil. > >Keep in mind that the reason for the new dipstick was at least in part to >compensate for the foaming issue. Rotax has published a number of bulletins >regarding the problems of air in the oil system and this is an area where >caution is appropriate as it seems to me that the vibration issues with our >engines - spinning a prop - is a bit different than a motorcycle, spinning >a chain. I'm usually a bit skeptical of manufacturers claims if it has to >do with recommending their own products etc. but Eric spent a bit of time on >this issue last year at OSH and it got me a little concerned. > >Lowell > >Lowell > > >----- Original Message ----- >From: "Donna and Roger McConnell" <rdmac(at)swbell.net> >To: >Subject: RE: Kitfox-List: Latest on 912 coolant and oil? > > Roger McConnell" >> >> >> Paul, >> I too am getting ready to fire up my engine in the next few days. I >> agree with John on the Honda oil. I called Lockwood and asked them about >> using the Honda oil and there comment was 'If it's good enough for Honda >> engines its good enough for Rotax'. The oil is a full synthetic with gear >> additives. As for coolant I'm using Dexcool and distilled water 50/50. >> Roger Mac >> N619RM ready to taxi >> >> -----Original Message----- >> From: owner-kitfox-list-server(at)matronics.com >> [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jdmcbean >> To: kitfox-list(at)matronics.com >> Subject: RE: Kitfox-List: Latest on 912 coolant and oil? >> >> >> Paul, >> I'm sure you'll get varying comments. Usually it's a good idea to >> follow >> the Engine manufactures recommendation. OK I've said it.... I follow the >> previous recommendation.. 50/50 mix. Use a extended life Antifreeze that >> is >> Silicate Free and I use distilled water. >> >> As for oil... Myself and several others have had great success with Honda >> Pro GN4. You can get it from the local Honda shop, it has the gear >> additive >> for the gear box.. Designed for high rpm engines. >> >> I run 100LL on the 912S and add the TCP that I sell religiously. I also >> change the oil every 25-30 hours. The results say you could probably go >> longer but I have always felt that the oil is the life blood of the engine >> and therefore I change it regularly. Because of the lead in the fuel I do >> pull the tank and clean it as well... "get the lead out" >> >> >> Fly Safe !! >> John & Debra McBean >> www.sportplanellc.com >> "The Sky is not the Limit... It's a Playground" >> >> -----Original Message----- >> From: owner-kitfox-list-server(at)matronics.com >> [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Paul Seehafer >> To: kitfox-list(at)matronics.com >> Subject: Kitfox-List: Latest on 912 coolant and oil? >> >> >> All, >> >> I'm getting ready to run my 912ul on my model IV, so I went and read all >> of >> that (very confusing) stuff on the www.rotax- owners.com site for the >> latest >> and greatest on coolants and oils, plus I searched the kitfox list for >> info. >> But I haven't found anything real current. And seeing how this stuff >> seems >> to be continually changing, I thought I had better ask all of you before >> putting the wrong stuff in my engine. >> >> So, my questions are; >> >> - Has there been any updated information on coolant requirements? >> >> - Is Evans Waterless coolant still the way to go? >> >> - How much coolant will I need to buy for my 912ul Model IV (no heater >> core) >> >> - Is it ok to use standard coolant in the 912 yet? (I tend to go places >> that are pretty far off the beaten path. At times regular coolant can be >> hard enough to find, much less Waterless EVANs NPG) >> >> - What is the best oil to run? >> >> - And last but not least, I heard I have to bleed the oil and coolant >> systems of trapped air prior to starting the engine. Is this true? And >> how >> does one do it if it is? >> >> Suggestions? Ideas? Advice? >> >> Paul Seehafer >> Central Wisconsin >> Model IV-1200 912ul on Aerocet Amphibs >> >> >> > > >_- ====================================================== ====== browse Subscriptions page, FAQ, List >_- ====================================================== ====== > > ________________________________________________________________________________
Date: Jul 10, 2005
It was previously on the recommended list. Last year at the Rotax forum at Oshkosh, Eric Tucker said the new revision of the recommended list was due to the EPA ruling that certain antifoaming additives were no longer allowed. He did mention Motul 5100 by name and apparently the testing Rotax does showed that it no longer met it's foamilg limits. This is my understanding. All of the oils in the new list have been tested by Rotax to meet it's specifications. This is not to imply that other oils do not as I doubt they have tested them all. But, the report was that the oils they recommend have been tested in house, rather than merely looking at the refiners specs. Lowell ----- Original Message ----- From: "flier" <FLIER(at)sbcglobal.net> Subject: Re: Kitfox-List: Latest on 912 coolant and oil? > > Hey Lowell, > > What's the skinny on the Motul 5100? I've been using > it now for a while?? I just finished up a case my > last oil change... > > Thanks, > > Ted > > --- Original Message --- > From: "Lowell Fitt" <lcfitt(at)sbcglobal.net> > To: > Subject: Re: Kitfox-List: Latest on 912 coolant and > oil? > > >> >>I suspect that Rotax will have a hard time > recommending another engine >>manufacturers oil, so my "guess" is that the Honda > oil would otherwise be on >>the list. That said, the reason I am using the oil > from the accepted list >>is that an I used to use and previously listedt was > delisted because of the >>the EPA mandated formula change on that brand of oil > (Motul 5100). I began >>using an oil formulated and sold by California Power > Systems (a Rotax >>distributor). Eric said they were planning on > testing that oil for the >>foaming problem - nothing yet. I have discontinued > using that oil. >> >>Keep in mind that the reason for the new dipstick > was at least in part to >>compensate for the foaming issue. Rotax has > published a number of bulletins >>regarding the problems of air in the oil system and > this is an area where >>caution is appropriate as it seems to me that the > vibration issues with our >>engines - spinning a prop - is a bit different than > a motorcycle, spinning >>a chain. I'm usually a bit skeptical of > manufacturers claims if it has to >>do with recommending their own products etc. but > Eric spent a bit of time on >>this issue last year at OSH and it got me a little > concerned. >> >>Lowell >> >>Lowell >> >> >>----- Original Message ----- >>From: "Donna and Roger McConnell" <rdmac(at)swbell.net> >>To: >>Subject: RE: Kitfox-List: Latest on 912 coolant and > oil? >> >> > Roger McConnell" >>> >>> >>> Paul, >>> I too am getting ready to fire up my engine > in the next few days. I >>> agree with John on the Honda oil. I called > Lockwood and asked them about >>> using the Honda oil and there comment was 'If it's > good enough for Honda >>> engines its good enough for Rotax'. The oil is a > full synthetic with gear >>> additives. As for coolant I'm using Dexcool and > distilled water 50/50. >>> Roger Mac >>> N619RM ready to taxi >>> >>> -----Original Message----- >>> From: owner-kitfox-list-server(at)matronics.com >>> [mailto:owner-kitfox-list-server(at)matronics.com] On > Behalf Of jdmcbean >>> To: kitfox-list(at)matronics.com >>> Subject: RE: Kitfox-List: Latest on 912 coolant > and oil? >>> > >>> >>> Paul, >>> I'm sure you'll get varying comments. > Usually it's a good idea to >>> follow >>> the Engine manufactures recommendation. OK I've > said it.... I follow the >>> previous recommendation.. 50/50 mix. Use a > extended life Antifreeze that >>> is >>> Silicate Free and I use distilled water. >>> >>> As for oil... Myself and several others have had > great success with Honda >>> Pro GN4. You can get it from the local Honda > shop, it has the gear >>> additive >>> for the gear box.. Designed for high rpm engines. >>> >>> I run 100LL on the 912S and add the TCP that I > sell religiously. I also >>> change the oil every 25-30 hours. The results say > you could probably go >>> longer but I have always felt that the oil is the > life blood of the engine >>> and therefore I change it regularly. Because of > the lead in the fuel I do >>> pull the tank and clean it as well... "get the > lead out" >>> >>> >>> Fly Safe !! >>> John & Debra McBean >>> www.sportplanellc.com >>> "The Sky is not the Limit... It's a Playground" >>> >>> -----Original Message----- >>> From: owner-kitfox-list-server(at)matronics.com >>> [mailto:owner-kitfox-list-server(at)matronics.com]On > Behalf Of Paul Seehafer >>> To: kitfox-list(at)matronics.com >>> Subject: Kitfox-List: Latest on 912 coolant and > oil? >>> > >>> >>> All, >>> >>> I'm getting ready to run my 912ul on my model IV, > so I went and read all >>> of >>> that (very confusing) stuff on the www.rotax- > owners.com site for the >>> latest >>> and greatest on coolants and oils, plus I searched > the kitfox list for >>> info. >>> But I haven't found anything real current. And > seeing how this stuff >>> seems >>> to be continually changing, I thought I had better > ask all of you before >>> putting the wrong stuff in my engine. >>> >>> So, my questions are; >>> >>> - Has there been any updated information on > coolant requirements? >>> >>> - Is Evans Waterless coolant still the way to go? >>> >>> - How much coolant will I need to buy for my 912ul > Model IV (no heater >>> core) >>> >>> - Is it ok to use standard coolant in the 912 > yet? (I tend to go places >>> that are pretty far off the beaten path. At times > regular coolant can be >>> hard enough to find, much less Waterless EVANs NPG) >>> >>> - What is the best oil to run? >>> >>> - And last but not least, I heard I have to bleed > the oil and coolant >>> systems of trapped air prior to starting the > engine. Is this true? And >>> how >>> does one do it if it is? >>> >>> Suggestions? Ideas? Advice? >>> >>> Paul Seehafer >>> Central Wisconsin >>> Model IV-1200 912ul on Aerocet Amphibs >>> >>> >>> >> >> >>_- > ====================================================== > ====== > browse > Subscriptions page, > FAQ, > List >>_- > ====================================================== > ====== >> >> > > > ________________________________________________________________________________
Subject: Re: Building A grass Strip
Date: Jul 10, 2005
Get it registered. As houses build up people have much more pull to prevent you from flying from your land then if the strip is registered as an private airport. In Wisconsin the state, country and township all get involved but it wasn't that hard. Paul N102DG ----- Original Message ----- From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> Subject: RE: Kitfox-List: Building A grass Strip > > > Jeff, > What are the reasons for registering your private airport? I had someone > with the government tell me to just fly from it and forget about > registering > it. He said there is no value in registering it. > > I have also been told that insurance is much less expensive if you > register > your strip. > > I have just been flying from my strip so far, but I am still interested in > registering it. > > Randy > > . > > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of > JJProbasco(at)cs.com > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: Building A grass Strip > > > I built a grass strip in PA and got my final airport license last fall. > The > > paperwork side was relatively painless. Raking a shoveling stones - well > that's another story. > > Generally for private airports, the feds are interested only in the air > space > and safe approaches, and your state will probably be more interested in > the > overall design features and ground location. I suggest you start with the > division or aeronautics in the department of transportation for your > state. > PA > was very helpful, and provided an information packet with the necessary > forms/or > pointing to the FAA website for forms and advisories. > > Jeff > Model 5, NSI CAP, still building > > > ________________________________________________________________________________
Subject: Re: Taxi Tests
Date: Jul 10, 2005
Hello, One other thing you might want to check if the problem is still going on! I have matco brakes, and if the breaks have any air or the guide rails are not moving freely, you might have this problem. Ray ----- Original Message ----- From: Marco Menezes<mailto:msm_9949(at)yahoo.com> To: Matronics.com Sent: Saturday, July 09, 2005 2:07 PM Subject: Kitfox-List: Taxi Tests Kitfox list: I did my taxi testing today and identified a few glitches that need working out. Most significant are: 1) My legs are too short and 2) an apparent lack of turning authority (on the ground) when left rudder is applied. She turns to the right easily but left turns require what seems inordinate rudder pressure to achieve a sluggish left turn. I tried tightening the tension on left rudder cable which seemed to help a little. There's still a noticable discrepancy in left rudder authority when compared to right, however. Tailwheel springs and chains are both tight. Any ideas? Also, I deliberately ignored the wise counsel of those on the list who have advised against high speed taxi runs. Result? A 20 mph groundloop to the left. Scary buy no damage, except to ego. Marco Menezes N99KX Model 2 - 582 --------------------------------- ________________________________________________________________________________
Date: Jul 10, 2005
Subject: Re: C-GOOT Flies Again
Rick, Since i do not have first hand experience I cannot verfiy that NSI props are good or bad. But i did a search on Google and found many many instances of NSI warnings. Could this be fact or falicy ? Seems to me there has been troubles in the past with NSI props. Can you dispute that?? I can find more info but the article written by Gary Walsh does infact seem to be very thorough. Possibly Gary and others have had bad luck? Or maybe you have had good luck? Regardless, It seems that everyone should know of "potential Troubles" as this product and manufacturer has incidents on record of failures. So you cannot say they have not had issues if in fact some actualy flew apart. Perhaps in your wisdom, you could show us other props that have flown aprt from other manufacturers. IVO and GSC have a great record that I know of. Best Regards, Kirby Kirby, to put it bluntly; that's crap. You think there has never been a failure of a certified prop or hub? >> SAAA - We are the Builders of AUSTRALIAN EXPERIMENTAL AIRCRAFTImmediate NSI Prop AD. Forthcoming Events. Guido Zuccoli Scholarship ... Immediate NSI Prop AD. A Copy of a letter to Gary Spicer received from Gary Wolf ... www.saaa.com/home.php - 33k - Cached - Similar pages SAAA - We are the Builders of AUSTRALIAN EXPERIMENTAL AIRCRAFT... New Members Insurance Available! Members Fuel Deal. Immediate NSI Prop AD. SAAA opposes Victorian aerodrome fees bill. ... (Back to top) Immediate NSI Prop AD. ... www.saaa.com/home.php?contentpage=news_ paras&PHPSESSID=214bba5b30c15a63ec2b556680f9a4d7 - 34k - Supplemental Result - Cached - Similar pages Steve Trentman's Turbine Powered KR2TLandings now are lots of fun with the NSI prop, The engine being a free turbine I can control the N1 rpm (power) and the N2 rpm (prop speed) Throttle ... home.hiwaay.net/~langford/strent.html - 4k - Cached - Similar pages Garrett JFS 100-13A Turboshaft engine (Zodiac powerplant - kit ...We recorded on a clear cold day/61deg/30.37 baro 390 lbs of thrust at 71000.00 rpm on N1/2090rpm-prop15 deg pitch on the nsi prop/ 17.7 gph fuel flow. ... www.zenithair.com/misc/turbine-power.html - 18k - Cached - Similar pages Aircraft for Sale,Kitfox for sale, Free Aviation Classifeds ...NSI PROP FAILURE * * Are YOU Safe? 7, 18, Jun 4 2005, 07:47 PM In: Last Post Somebody Is Going To Get A ... By: Rich Young. No New Posts, Kitfox test Forum ... kitfox.lazair.com/ - 22k - Cached - Similar pages KitfoxClark Kitfox, early model, Subaru EA-81, NSI prop (Photo & Caption Only). 2000. 06. 78. Sport Aviation. Steinbaum Model IV, Rotax 582, BRS parachute (Photo ... members.eaa.org/home/homebuilders/ selecting/kits/Kitfox.html - 108k - Cached - Similar pages Europa-List Digest: 16 Msgs - 10/24/04NSI Prop Failure (MJ Gregory). 9. 12:05 PM - Re: g-oizi not flying (Simon Smith) ... NSI Prop Failure. --> Europa-List message posted by: "MJ Gregory" ... www.opensubscriber.com/message/ europa-list-digest(at)matronics.com/94734.html - 58k - Cached - Similar pages NSI-VP prop... NSI VP prop. I have now about 120 hours on my NSI prop and Andreas (kit 133) has also clo se to 100 hours on his NSI prop. We are ... 131.238.38.204/~sarangan/mharc/ html//europa-list/1999-09/msg00060.html - 9k - Supplemental Result - Cached - Similar pages Europa-List: NSI Prop... Europa-List: NSI Prop. ... Subject: Europa-List: NSI Prop. Date: Wed, 21 Jul 2004 15:47:37 GMT. ... Europa-List: NSI Prop, Erich Trombley <=. ... 131.238.38.204/~sarangan/mharc/ html//europa-list/2004-07/msg00333.html - 7k - Supplemental Result - Cached - Similar pages [ More results from 131.238.38.204 ] aviation & planes - Immediate NSI Prop AD#1. October 27th 04, 09:56 PM. Robert Schieck. usenet poster. Posts: n/a. Immediate NSI Prop AD. FYI, From: Gary Wolf To: announce@raa ... www.aviationbanter.com/showthread.php?t=2865 - 37k - Supplemental Result - Cached - Similar pages aviation & planes - Immediate NSI Prop ADView Full Version : Immediate NSI Prop AD. Robert Schieck. FYI, From: Gary Wolf To: announce(at)raa.ca www.aviationbanter.com/ q-t_2865-Immediate-NSI-Prop-AD.html - 7k - Supplemental Result - Cached - Similar pages [ More results from www.aviationbanter.com ] NSI PROP.[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index] NSI PROP. To: (Recipients of 'building-fwf-alt' suppressed); Subject: NSI PROP. ... archives.glastar.org/0408/msg00147.html - 8k - Supplemental Result - Cached - Similar pages NSI PROP... NSI PROP. To: (Recipients of 'building-fwf' suppressed); Subject: NSI PROP; From: "building-fwf Listmanager" ; ... archives.glastar.org/0009/msg00354.html - 4k - Supplemental Result - Cached - Similar pages [ More results from archives.glastar.org ] OziPilots Online Forums - Immediate NSI Prop ADSEF friendly index version. OziPilots Online Forums > UseNet Newsgroups > rec.aviation.ultralight > Immediate NSI Prop AD. ... Immediate NSI Prop AD ... www.ozipilotsonline.com.au/forums/showthread. php?s=0e3e579397957e383a6ca2d8ab04f203&threadid=16878&am... - 20k - Supplemental Result - Cached - Similar pages Australian Sport Rotorcraft Association Inc Forums - Hunter Valley ...The engine is EA81, the Redrive is NSI, Prop is Warp Drive and the Rotors Rick's, 27ft I think. I do not have any C of G figures but I do have some ... www.asra.org.au/forum/topic.asp?TOPIC_ID=197 - 71k - Cached - Similar pages Australian Sport Rotorcraft Association Inc Forums... to help out here. The engine is EA81, the Redrive is NSI, Prop is Warp Drive and the Rotors Rick's, 27ft I think. I do not have ... www.asra.org.au/forum/post.asp?method=ReplyQuote& REPLY_ID=440&TOPIC_ID=197&FORUM_ID=26 - 47k - Supplemental Result - Cached - Similar pages [ More results from www.asra.org.au ] The Europa Club - Nigel Charles, Modifications RepresentativeThe NSI prop is shortly being replaced with the latest Airmaster prop. G-MIME first flew in August 2001 and received its permit in December 2001. ... www.europaclub.org.uk/club/nigel_charles.shtml - 6k - Cached - Similar pages EuropaOwners Builders and flyer of Europa Homebuilt kit aircraft.NSI Prop. ... Status: -, PostPosted: Wed Jul 21, 2004 10:49 am Post subject: NSI Prop, Reply with quote. Pete, Sorry to hear about the incident. ... www.europaowners.org/ viewtopic.php?p=996&sid=abf379b3f49276a7445b54e047079a7f - 26k - Supplemental Result - Cached - Similar pages EuropaOwners Builders and flyer of Europa Homebuilt kit aircraft.... They tend to overpromise and underdeliver< I can confirm this. When I had an NSI prop I have never had such poor customer service from any company. ... www.europaowners.org/ viewtopic.php?t=263&sid=76b36e3c50c21c4f1c29584315676358 - 30k - Supplemental Result - Cached - Similar pages [ More results from www.europaowners.org ] General AviationSpecial Safety Feature * NSI PROP FAILURE Are YOU Safe? 6 18 Mar 27 2005, 09:30 AM In: By: This forum is dedicated to the Kitfox Builders and Flyers. ... www.flighttrainingresources.com/ Directory/General_Aviation/ - 93k - Cached - Similar pages GlaStar NSI Engine Group - Installing PropellerThe new NSI prop is 74" so something had to be done. We modified the nose wheel axle to lower it 2''. Just used 1/8" steel plates attached to the original ... www.glastar.ch/nsi/installing/propeller/propeller.html - 16k - Cached - Similar pages GlaStar NSI Engine Group - Operating EngineI recommend that to anyone with the NSI prop, and its probably a good idea with any prop. My engine is also turbine smooth at high rpm and has its "sweet ... www.glastar.ch/nsi/operating/engine/engine.html - 20k - Cached - Similar pages [PDF] January 16 AnnounceFile Format: PDF/Adobe Acrobat - View as HTML ... Other members want to learn from you. Please e-mail photos and text to gregdesign(at)telus.net NSI PROP UPDATE Still no response from ... members.shaw.ca/m1.mustang/ Spinner/RAA/January%2016%20Announce.pdf - Supplemental Result - Similar pages [PDF] Feb. 09/2005 Announce CARs EXEMPTIONS - SOME GOOD NEWSFile Format: PDF/Adobe Acrobat - View as HTML ... We did use the CADORs to show Transport that the NSI prop had actually had an earlier failure in Ottawa back in 1997, and that it had been investigated by the ... members.shaw.ca/m1.mustang/ Spinner/RAA/Feb%2009%202005%20Announce.pdf - Supplemental Result - Similar pages SuperCub.org :: View topic - Turbine Super Cub... The other issue is the prop. As I understand, the NSI prop is designed for fast aircraft and has a high speed airfoil. It is also a composite prop. ... supercub.org/phpBB2/viewtopic.php?p=54730 - 82k - Supplemental Result - Cached - Similar pages Kitfox-List Archive Browser... A slipper clutch was installed at the same time. The engine is also relatively new, being installed shortly before the NSI prop was added. ... www.matronics.com/archive/archive-get. cgi?Kitfox-Archive.digest.vol-ba - 101k - Supplemental Result - Cached - Similar pages Kitfox-List Digest Archive --- Total Messages Posted Fri 12/12/03 ...... The NSI prop was built for and is a perfect match for the NSI EA81. ... Don't know about the IVO, I but do know that the NSI prop is strong. ... www.matronics.com/digest/kitfox-list/ Digest.Kitfox-List.2003-12-12.txt - 31k - Supplemental Result - Cached - Similar pages [ More results from www.matronics.com ] Rotary Wing Forum - I Did It....ordered an IVO CAP... What model IVO blades are used? From experience with the cockpit adjustable NSI prop, it pays to order the cockpit pitch readout accessory. ... www.rotaryforum.com/forum/printthread.php?t=1676 - 20k - Supplemental Result - Cached - Similar pages [PDF] Chapter 54 NewsFile Format: PDF/Adobe Acrobat - View as HTML Page 1. Chapter 54 News - December 2002 PAGE 1 I m borrowing an idea from Holly- wood just to make a point. Al Burns found an ... www.eaa54.org/Newsletters/54NewsletterDecember2002.pdf - Supplemental Result - Similar pages My GyroMy Gyro. Engine: Subaru EJ22 PRSU: NSI Prop: Warp Drive Rotor Blades: Dragon Wings Empty Weight: 683 lbs. First Flight. What a thrill! Another view. ... members.fortunecity.com/lsippell/Page2.html - 9k - Supplemental Result - Cached - Similar pages rec.aviation.ultralight... One Million FR.EE Visitors **, Wayne Chislett, 27 oct 2004 [07:09]. Immediate NSI Prop AD, Robert Schieck, 27 oct 2004 [04:54]. Ultralight ... rec.aviation.ultralight.newsgrouptopics.com/ - 83k - Supplemental Result - Cached - Similar pages EuropaOwners :: View Forum - Europa-List... Posting from Gary Walsh to Europa list...NSI Prop Failure, 0, mj.gregory at talk21.com, 9, Sun Oct 24, 2004 1:28 pm mj.gregory at talk21.com View latest post. ... forum.okhuijsen.org/viewforum.php?f=23& sid=8777a7f5c21976e230c8af2e86c4228c - 80k - Supplemental Result - Cached - Similar pages Immediate NSI Prop AD... << Topic, < Post, Post 1 of 1 Topic 828 of 917, Post >, Topic >>. Immediate NSI Prop AD. ... Gary Wolf President, RAA Canada. 1 Posts in Topic: Immediate NSI Prop AD ... www.talkaboutaviation.com/group/ rec.aviation.ultralight/messages/61566.html - 11k - Supplemental Result - Cached - Similar pages Ultralight, glider... 6, Oct 27, 2004 10:22 PM. Immediate NSI Prop AD, robert schieck From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Subject: Latest on 912 coolant and oil?
Date: Jul 10, 2005
Gary, Does the Mobil 1 Synthetic have the high pressure additives needed for gear applications? It is these additives that make motorcycle oils appropriate for the 900 series Rotax engines with gear boxes. As to oil change procedures I just drain the oil tank and change the filter and figure that the amount of oil still in the oil cooler, lines, and pump are negligible and not worth the headaches in draining them. This results in minimal headaches in getting air out of the lines too. I am pasting my procedure below. Maybe some one can critique it. It is a synthesis of comments gleaned from the list. Oh, I use Honda GN4 oil. Didn't know until this thread that it was synthetic. 1. "Burp" oil from crankcase to tank by turning prop forward until you heal impolite sounds from the open oil tank. 2. Fill the new filter with new oil. (This takes a while, but can be done while doing other things.) 3. Remove and replace old oil filter with new full oil filter. (Somewhat messy, but not much more than removing old filter.) 4. Drain oil from tank. Replace and re-safety-wire the plug. Put in 3 quarts of oil and check level. Add more as needed. 5. Crank the engine for three 10 second interval with at least 2 minutes between cranks with out starting engine. This is to get any air out of the oil line. Randy . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of gjglh(at)cebridge.net Subject: RE: Kitfox-List: Latest on 912 coolant and oil? Has anyone heard any pros or cons on mobil 1 synthetic. That's what I have been using for the 400 hrs. Gary SPD912LS ________________________________________________________________________________
Subject: C-GOOT Flies Again
Date: Jul 10, 2005
No I don't care to go there. In my wisdom I am sure the only prop failures that have ever occurred and for that matter crashes in all areas of aviation are due to NSIs poor quality. Incidents need to be reported for all. It is the personal attack and lack of impartial investigation and reporting I object too. AS far as my wisdom goes, I have found the older I get the less I know. I struggle to remain silent. Rick -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of kitfox(at)gto.net Subject: Re: Kitfox-List: C-GOOT Flies Again Rick, Since i do not have first hand experience I cannot verfiy that NSI props are good or bad. But i did a search on Google and found many many instances of NSI warnings. Could this be fact or falicy ? Seems to me there has been troubles in the past with NSI props. Can you dispute that?? I can find more info but the article written by Gary Walsh does infact seem to be very thorough. Possibly Gary and others have had bad luck? Or maybe you have had good luck? Regardless, It seems that everyone should know of "potential Troubles" as this product and manufacturer has incidents on record of failures. So you cannot say they have not had issues if in fact some actualy flew apart. Perhaps in your wisdom, you could show us other props that have flown aprt from other manufacturers. IVO and GSC have a great record that I know of. Best Regards, Kirby Kirby, to put it bluntly; that's crap. You think there has never been a failure of a certified prop or hub? >> SAAA - We are the Builders of AUSTRALIAN EXPERIMENTAL AIRCRAFTImmediate NSI Prop AD. Forthcoming Events. Guido Zuccoli Scholarship ... Immediate NSI Prop AD. A Copy of a letter to Gary Spicer received from Gary Wolf ... www.saaa.com/home.php - 33k - Cached - Similar pages SAAA - We are the Builders of AUSTRALIAN EXPERIMENTAL AIRCRAFT... New Members Insurance Available! Members Fuel Deal. Immediate NSI Prop AD. SAAA opposes Victorian aerodrome fees bill. ... (Back to top) Immediate NSI Prop AD. ... www.saaa.com/home.php?contentpage=news_ paras&PHPSESSID=214bba5b30c15a63ec2b556680f9a4d7 - 34k - Supplemental Result - Cached - Similar pages Steve Trentman's Turbine Powered KR2TLandings now are lots of fun with the NSI prop, The engine being a free turbine I can control the N1 rpm (power) and the N2 rpm (prop speed) Throttle ... home.hiwaay.net/~langford/strent.html - 4k - Cached - Similar pages Garrett JFS 100-13A Turboshaft engine (Zodiac powerplant - kit ...We recorded on a clear cold day/61deg/30.37 baro 390 lbs of thrust at 71000.00 rpm on N1/2090rpm-prop15 deg pitch on the nsi prop/ 17.7 gph fuel flow. ... www.zenithair.com/misc/turbine-power.html - 18k - Cached - Similar pages Aircraft for Sale,Kitfox for sale, Free Aviation Classifeds ...NSI PROP FAILURE * * Are YOU Safe? 7, 18, Jun 4 2005, 07:47 PM In: Last Post Somebody Is Going To Get A ... By: Rich Young. No New Posts, Kitfox test Forum ... kitfox.lazair.com/ - 22k - Cached - Similar pages KitfoxClark Kitfox, early model, Subaru EA-81, NSI prop (Photo & Caption Only). 2000. 06. 78. Sport Aviation. Steinbaum Model IV, Rotax 582, BRS parachute (Photo ... members.eaa.org/home/homebuilders/ selecting/kits/Kitfox.html - 108k - Cached - Similar pages Europa-List Digest: 16 Msgs - 10/24/04NSI Prop Failure (MJ Gregory). 9. 12:05 PM - Re: g-oizi not flying (Simon Smith) ... NSI Prop Failure. --> Europa-List message posted by: "MJ Gregory" ... www.opensubscriber.com/message/ europa-list-digest(at)matronics.com/94734.html - 58k - Cached - Similar pages NSI-VP prop... NSI VP prop. I have now about 120 hours on my NSI prop and Andreas (kit 133) has also clo se to 100 hours on his NSI prop. We are ... 131.238.38.204/~sarangan/mharc/ html//europa-list/1999-09/msg00060.html - 9k - Supplemental Result - Cached - Similar pages Europa-List: NSI Prop... Europa-List: NSI Prop. ... Subject: Europa-List: NSI Prop. Date: Wed, 21 Jul 2004 15:47:37 GMT. ... Europa-List: NSI Prop, Erich Trombley <=. ... 131.238.38.204/~sarangan/mharc/ html//europa-list/2004-07/msg00333.html - 7k - Supplemental Result - Cached - Similar pages [ More results from 131.238.38.204 ] aviation & planes - Immediate NSI Prop AD#1. October 27th 04, 09:56 PM. Robert Schieck. usenet poster. Posts: n/a. Immediate NSI Prop AD. FYI, From: Gary Wolf To: announce@raa ... www.aviationbanter.com/showthread.php?t=2865 - 37k - Supplemental Result - Cached - Similar pages aviation & planes - Immediate NSI Prop ADView Full Version : Immediate NSI Prop AD. Robert Schieck. FYI, From: Gary Wolf To: announce(at)raa.ca www.aviationbanter.com/ q-t_2865-Immediate-NSI-Prop-AD.html - 7k - Supplemental Result - Cached - Similar pages [ More results from www.aviationbanter.com ] NSI PROP.[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index] NSI PROP. To: (Recipients of 'building-fwf-alt' suppressed); Subject: NSI PROP. ... archives.glastar.org/0408/msg00147.html - 8k - Supplemental Result - Cached - Similar pages NSI PROP... NSI PROP. To: (Recipients of 'building-fwf' suppressed); Subject: NSI PROP; From: "building-fwf Listmanager" ; ... archives.glastar.org/0009/msg00354.html - 4k - Supplemental Result - Cached - Similar pages [ More results from archives.glastar.org ] OziPilots Online Forums - Immediate NSI Prop ADSEF friendly index version. OziPilots Online Forums > UseNet Newsgroups > rec.aviation.ultralight > Immediate NSI Prop AD. ... Immediate NSI Prop AD ... www.ozipilotsonline.com.au/forums/showthread. php?s=0e3e579397957e383a6ca2d8ab04f203&threadid=16878&am... - 20k - Supplemental Result - Cached - Similar pages Australian Sport Rotorcraft Association Inc Forums - Hunter Valley ...The engine is EA81, the Redrive is NSI, Prop is Warp Drive and the Rotors Rick's, 27ft I think. I do not have any C of G figures but I do have some ... www.asra.org.au/forum/topic.asp?TOPIC_ID=197 - 71k - Cached - Similar pages Australian Sport Rotorcraft Association Inc Forums... to help out here. The engine is EA81, the Redrive is NSI, Prop is Warp Drive and the Rotors Rick's, 27ft I think. I do not have ... www.asra.org.au/forum/post.asp?method=ReplyQuote& REPLY_ID=440&TOPIC_ID=197&FORUM_ID=26 - 47k - Supplemental Result - Cached - Similar pages [ More results from www.asra.org.au ] The Europa Club - Nigel Charles, Modifications RepresentativeThe NSI prop is shortly being replaced with the latest Airmaster prop. G-MIME first flew in August 2001 and received its permit in December 2001. ... www.europaclub.org.uk/club/nigel_charles.shtml - 6k - Cached - Similar pages EuropaOwners Builders and flyer of Europa Homebuilt kit aircraft.NSI Prop. ... Status: -, PostPosted: Wed Jul 21, 2004 10:49 am Post subject: NSI Prop, Reply with quote. Pete, Sorry to hear about the incident. ... www.europaowners.org/ viewtopic.php?p=996&sid=abf379b3f49276a7445b54e047079a7f - 26k - Supplemental Result - Cached - Similar pages EuropaOwners Builders and flyer of Europa Homebuilt kit aircraft.... They tend to overpromise and underdeliver< I can confirm this. When I had an NSI prop I have never had such poor customer service from any company. ... www.europaowners.org/ viewtopic.php?t=263&sid=76b36e3c50c21c4f1c29584315676358 - 30k - Supplemental Result - Cached - Similar pages [ More results from www.europaowners.org ] General AviationSpecial Safety Feature * NSI PROP FAILURE Are YOU Safe? 6 18 Mar 27 2005, 09:30 AM In: By: This forum is dedicated to the Kitfox Builders and Flyers. ... www.flighttrainingresources.com/ Directory/General_Aviation/ - 93k - Cached - Similar pages GlaStar NSI Engine Group - Installing PropellerThe new NSI prop is 74" so something had to be done. We modified the nose wheel axle to lower it 2''. Just used 1/8" steel plates attached to the original ... www.glastar.ch/nsi/installing/propeller/propeller.html - 16k - Cached - Similar pages GlaStar NSI Engine Group - Operating EngineI recommend that to anyone with the NSI prop, and its probably a good idea with any prop. My engine is also turbine smooth at high rpm and has its "sweet ... www.glastar.ch/nsi/operating/engine/engine.html - 20k - Cached - Similar pages [PDF] January 16 AnnounceFile Format: PDF/Adobe Acrobat - View as HTML ... Other members want to learn from you. Please e-mail photos and text to gregdesign(at)telus.net NSI PROP UPDATE Still no response from ... members.shaw.ca/m1.mustang/ Spinner/RAA/January%2016%20Announce.pdf - Supplemental Result - Similar pages [PDF] Feb. 09/2005 Announce CARs EXEMPTIONS - SOME GOOD NEWSFile Format: PDF/Adobe Acrobat - View as HTML ... We did use the CADORs to show Transport that the NSI prop had actually had an earlier failure in Ottawa back in 1997, and that it had been investigated by the ... members.shaw.ca/m1.mustang/ Spinner/RAA/Feb%2009%202005%20Announce.pdf - Supplemental Result - Similar pages SuperCub.org :: View topic - Turbine Super Cub... The other issue is the prop. As I understand, the NSI prop is designed for fast aircraft and has a high speed airfoil. It is also a composite prop. ... supercub.org/phpBB2/viewtopic.php?p=54730 - 82k - Supplemental Result - Cached - Similar pages Kitfox-List Archive Browser... A slipper clutch was installed at the same time. The engine is also relatively new, being installed shortly before the NSI prop was added. ... www.matronics.com/archive/archive-get. cgi?Kitfox-Archive.digest.vol-ba - 101k - Supplemental Result - Cached - Similar pages Kitfox-List Digest Archive --- Total Messages Posted Fri 12/12/03 ...... The NSI prop was built for and is a perfect match for the NSI EA81. ... Don't know about the IVO, I but do know that the NSI prop is strong. ... www.matronics.com/digest/kitfox-list/ Digest.Kitfox-List.2003-12-12.txt - 31k - Supplemental Result - Cached - Similar pages [ More results from www.matronics.com ] Rotary Wing Forum - I Did It....ordered an IVO CAP... What model IVO blades are used? From experience with the cockpit adjustable NSI prop, it pays to order the cockpit pitch readout accessory. ... www.rotaryforum.com/forum/printthread.php?t=1676 - 20k - Supplemental Result - Cached - Similar pages [PDF] Chapter 54 NewsFile Format: PDF/Adobe Acrobat - View as HTML Page 1. Chapter 54 News - December 2002 PAGE 1 I m borrowing an idea from Holly- wood just to make a point. Al Burns found an ... www.eaa54.org/Newsletters/54NewsletterDecember2002.pdf - Supplemental Result - Similar pages My GyroMy Gyro. Engine: Subaru EJ22 PRSU: NSI Prop: Warp Drive Rotor Blades: Dragon Wings Empty Weight: 683 lbs. First Flight. What a thrill! Another view. ... members.fortunecity.com/lsippell/Page2.html - 9k - Supplemental Result - Cached - Similar pages rec.aviation.ultralight... One Million FR.EE Visitors **, Wayne Chislett, 27 oct 2004 [07:09]. Immediate NSI Prop AD, Robert Schieck, 27 oct 2004 [04:54]. Ultralight ... rec.aviation.ultralight.newsgrouptopics.com/ - 83k - Supplemental Result - Cached - Similar pages EuropaOwners :: View Forum - Europa-List... Posting from Gary Walsh to Europa list...NSI Prop Failure, 0, mj.gregory at talk21.com, 9, Sun Oct 24, 2004 1:28 pm mj.gregory at talk21.com View latest post. ... forum.okhuijsen.org/viewforum.php?f=23& sid=8777a7f5c21976e230c8af2e86c4228c - 80k - Supplemental Result - Cached - Similar pages Immediate NSI Prop AD... << Topic, < Post, Post 1 of 1 Topic 828 of 917, Post >, Topic >>. Immediate NSI Prop AD. ... Gary Wolf President, RAA Canada. 1 Posts in Topic: Immediate NSI Prop AD ... www.talkaboutaviation.com/group/ rec.aviation.ultralight/messages/61566.html - 11k - Supplemental Result - Cached - Similar pages Ultralight, glider... 6, Oct 27, 2004 10:22 PM. Immediate NSI Prop AD, robert schieck Date: Jul 10, 2005
Rick, IT seems thast Mr Wheeler is fully aware of th problems with this propellor cuff. Surely he is pissed that so much attention was given and posssibly that is why Gary Walsh has a IVO prop now. Hopefully there will be no more incidents with NSI props , but with what i have read today and in the past-- the problem still exists. Kirby...... wiser and older too :) http://www.saaa.com/home.php <<<>> .... Kitfox-List message posted by: "Rick" No I don't care to go there. In my wisdom I am sure the only prop failures that have ever occurred and for that matter crashes in all areas of aviation are due to NSIs poor quality. Incidents need to be reported for all. It is the personal attack and lack of impartial investigation and reporting I object too. AS far as my wisdom goes, I have found the older I get the less I know. I struggle to remain silent. Rick.... ________________________________________________________________________________
Date: Jul 10, 2005
Thanks for the 411 Lowell. Since the 912 only uses a couple of qtrs and I change about twice a year I've had the case for a couple of years. I'll check and may have to switch over myself. Regards, Ted --- Original Message --- From: "Lowell Fitt" <lcfitt(at)sbcglobal.net> Subject: Re: Kitfox-List: Latest on 912 coolant and oil? > >It was previously on the recommended list. Last year at the Rotax forum at >Oshkosh, Eric Tucker said the new revision of the recommended list was due >to the EPA ruling that certain antifoaming additives were no longer allowed. >He did mention Motul 5100 by name and apparently the testing Rotax does >showed that it no longer met it's foamilg limits. This is my understanding. > >All of the oils in the new list have been tested by Rotax to meet it's >specifications. This is not to imply that other oils do not as I doubt they >have tested them all. But, the report was that the oils they recommend have >been tested in house, rather than merely looking at the refiners specs. > >Lowell > >----- Original Message ----- >From: "flier" <FLIER(at)sbcglobal.net> >To: >Subject: Re: Kitfox-List: Latest on 912 coolant and oil? > > >> >> Hey Lowell, >> >> What's the skinny on the Motul 5100? I've been using >> it now for a while?? I just finished up a case my >> last oil change... >> >> Thanks, >> >> Ted >> >> --- Original Message --- >> From: "Lowell Fitt" <lcfitt(at)sbcglobal.net> >> To: >> Subject: Re: Kitfox-List: Latest on 912 coolant and >> oil? >> >> >>> >>>I suspect that Rotax will have a hard time >> recommending another engine >>>manufacturers oil, so my "guess" is that the Honda >> oil would otherwise be on >>>the list. That said, the reason I am using the oil >> from the accepted list >>>is that an I used to use and previously listedt was >> delisted because of the >>>the EPA mandated formula change on that brand of oil >> (Motul 5100). I began >>>using an oil formulated and sold by California Power >> Systems (a Rotax >>>distributor). Eric said they were planning on >> testing that oil for the >>>foaming problem - nothing yet. I have discontinued >> using that oil. >>> >>>Keep in mind that the reason for the new dipstick >> was at least in part to >>>compensate for the foaming issue. Rotax has >> published a number of bulletins >>>regarding the problems of air in the oil system and >> this is an area where >>>caution is appropriate as it seems to me that the >> vibration issues with our >>>engines - spinning a prop - is a bit different than >> a motorcycle, spinning >>>a chain. I'm usually a bit skeptical of >> manufacturers claims if it has to >>>do with recommending their own products etc. but >> Eric spent a bit of time on >>>this issue last year at OSH and it got me a little >> concerned. >>> >>>Lowell >>> >>>Lowell >>> >>> >>>----- Original Message ----- >>>From: "Donna and Roger McConnell" >>>To: >>>Subject: RE: Kitfox-List: Latest on 912 coolant and >> oil? >>> >>> >> Roger McConnell" >>>> >>>> >>>> Paul, >>>> I too am getting ready to fire up my engine >> in the next few days. I >>>> agree with John on the Honda oil. I called >> Lockwood and asked them about >>>> using the Honda oil and there comment was 'If it's >> good enough for Honda >>>> engines its good enough for Rotax'. The oil is a >> full synthetic with gear >>>> additives. As for coolant I'm using Dexcool and >> distilled water 50/50. >>>> Roger Mac >>>> N619RM ready to taxi >>>> >>>> -----Original Message----- >>>> From: owner-kitfox-list-server(at)matronics.com >>>> [mailto:owner-kitfox-list-server(at)matronics.com] On >> Behalf Of jdmcbean >>>> To: kitfox-list(at)matronics.com >>>> Subject: RE: Kitfox-List: Latest on 912 coolant >> and oil? >>>> >> >>>> >>>> Paul, >>>> I'm sure you'll get varying comments. >> Usually it's a good idea to >>>> follow >>>> the Engine manufactures recommendation. OK I've >> said it.... I follow the >>>> previous recommendation.. 50/50 mix. Use a >> extended life Antifreeze that >>>> is >>>> Silicate Free and I use distilled water. >>>> >>>> As for oil... Myself and several others have had >> great success with Honda >>>> Pro GN4. You can get it from the local Honda >> shop, it has the gear >>>> additive >>>> for the gear box.. Designed for high rpm engines. >>>> >>>> I run 100LL on the 912S and add the TCP that I >> sell religiously. I also >>>> change the oil every 25-30 hours. The results say >> you could probably go >>>> longer but I have always felt that the oil is the >> life blood of the engine >>>> and therefore I change it regularly. Because of >> the lead in the fuel I do >>>> pull the tank and clean it as well... "get the >> lead out" >>>> >>>> >>>> Fly Safe !! >>>> John & Debra McBean >>>> www.sportplanellc.com >>>> "The Sky is not the Limit... It's a Playground" >>>> >>>> -----Original Message----- >>>> From: owner-kitfox-list-server(at)matronics.com >>>> [mailto:owner-kitfox-list-server(at)matronics.com]On >> Behalf Of Paul Seehafer >>>> To: kitfox-list(at)matronics.com >>>> Subject: Kitfox-List: Latest on 912 coolant and >> oil? >>>> Seehafer" >> >>>> >>>> All, >>>> >>>> I'm getting ready to run my 912ul on my model IV, >> so I went and read all >>>> of >>>> that (very confusing) stuff on the www.rotax- >> owners.com site for the >>>> latest >>>> and greatest on coolants and oils, plus I searched >> the kitfox list for >>>> info. >>>> But I haven't found anything real current. And >> seeing how this stuff >>>> seems >>>> to be continually changing, I thought I had better >> ask all of you before >>>> putting the wrong stuff in my engine. >>>> >>>> So, my questions are; >>>> >>>> - Has there been any updated information on >> coolant requirements? >>>> >>>> - Is Evans Waterless coolant still the way to go? >>>> >>>> - How much coolant will I need to buy for my 912ul >> Model IV (no heater >>>> core) >>>> >>>> - Is it ok to use standard coolant in the 912 >> yet? (I tend to go places >>>> that are pretty far off the beaten path. At times >> regular coolant can be >>>> hard enough to find, much less Waterless EVANs NPG) >>>> >>>> - What is the best oil to run? >>>> >>>> - And last but not least, I heard I have to bleed >> the oil and coolant >>>> systems of trapped air prior to starting the >> engine. Is this true? And >>>> how >>>> does one do it if it is? >>>> >>>> Suggestions? Ideas? Advice? >>>> >>>> Paul Seehafer >>>> Central Wisconsin >>>> Model IV-1200 912ul on Aerocet Amphibs >>>> >>>> >>>> >>> >>> >>>_- >> ====================================================== >> ====== >> browse >> Subscriptions page, >> FAQ, >> List >>>_- >> ====================================================== >> ====== >>> >>> >> >> >> > > >_- ====================================================== ====== browse Subscriptions page, FAQ, List >_- ====================================================== ====== > > ________________________________________________________________________________
Date: Jul 10, 2005
As a matter of fact, Ray, another of the minor problems noted in taxi tests was weakness in the left brake. I also have Matco brakes and have tried bleeding the left cylinder repeatedly to no avail. It still feels "mushy" and leaks fluid around the brake shaft where it enters the cylinder. I'm ordering a rebuild kit. I don't understand how this can affect ability to turn. Can you explain? Marco Menezes Model 2 582 - N99KX RAY Gignac wrote: Hello, One other thing you might want to check if the problem is still going on! I have matco brakes, and if the breaks have any air or the guide rails are not moving freely, you might have this problem. Ray ----- Original Message ----- From: Marco Menezes Subject: Kitfox-List: Taxi Tests Kitfox list: I did my taxi testing today and identified a few glitches that need working out. Most significant are: 1) My legs are too short and 2) an apparent lack of turning authority (on the ground) when left rudder is applied. She turns to the right easily but left turns require what seems inordinate rudder pressure to achieve a sluggish left turn. I tried tightening the tension on left rudder cable which seemed to help a little. There's still a noticable discrepancy in left rudder authority when compared to right, however. Tailwheel springs and chains are both tight. Any ideas? Also, I deliberately ignored the wise counsel of those on the list who have advised against high speed taxi runs. Result? A 20 mph groundloop to the left. Scary buy no damage, except to ego. Marco Menezes N99KX Model 2 - 582 --------------------------------- ________________________________________________________________________________
Date: Jul 10, 2005
Also, I deliberately ignored the wise counsel of those on the list who have advised against high speed taxi runs. Result? A 20 mph groundloop to the left. Scary buy no damage, except to ego. I must have missed something here. Why would anyone advise against high speed taxi tests? Dee Young KF II N345DY --------------------------------- ________________________________________________________________________________
Date: Jul 10, 2005
Well, if you apply brake to assist you in turning, and the brake is mush then turning won't be as tight. I may have misunderstood you on your problem! but when the brake is applied it should turn on the dime. Ray ----- Original Message ----- From: Marco Menezes<mailto:msm_9949(at)yahoo.com> To: kitfox-list(at)matronics.com Sent: Sunday, July 10, 2005 9:39 PM Subject: Re: Kitfox-List: Taxi Tests As a matter of fact, Ray, another of the minor problems noted in taxi tests was weakness in the left brake. I also have Matco brakes and have tried bleeding the left cylinder repeatedly to no avail. It still feels "mushy" and leaks fluid around the brake shaft where it enters the cylinder. I'm ordering a rebuild kit. I don't understand how this can affect ability to turn. Can you explain? Marco Menezes Model 2 582 - N99KX RAY Gignac > wrote: Hello, One other thing you might want to check if the problem is still going on! I have matco brakes, and if the breaks have any air or the guide rails are not moving freely, you might have this problem. Ray ----- Original Message ----- From: Marco Menezes To: Matronics.com Subject: Kitfox-List: Taxi Tests Kitfox list: I did my taxi testing today and identified a few glitches that need working out. Most significant are: 1) My legs are too short and 2) an apparent lack of turning authority (on the ground) when left rudder is applied. She turns to the right easily but left turns require what seems inordinate rudder pressure to achieve a sluggish left turn. I tried tightening the tension on left rudder cable which seemed to help a little. There's still a noticable discrepancy in left rudder authority when compared to right, however. Tailwheel springs and chains are both tight. Any ideas? Also, I deliberately ignored the wise counsel of those on the list who have advised against high speed taxi runs. Result? A 20 mph groundloop to the left. Scary buy no damage, except to ego. Marco Menezes N99KX Model 2 - 582 --------------------------------- ________________________________________________________________________________
Date: Jul 10, 2005
I have done the so called high speed taxi myself, no problems. It's the same as full throttle take off or the landing. Keep directional control and you go down center line! Ray ----- Original Message ----- From: Dee Young<mailto:henrysfork1(at)msn.com> To: kitfox-list(at)matronics.com Sent: Sunday, July 10, 2005 11:07 PM Subject: Re: Kitfox-List: Taxi Tests Also, I deliberately ignored the wise counsel of those on the list who have advised against high speed taxi runs. Result? A 20 mph groundloop to the left. Scary buy no damage, except to ego. I must have missed something here. Why would anyone advise against high speed taxi tests? Dee Young KF II N345DY --------------------------------- ________________________________________________________________________________
Date: Jul 10, 2005
I have the same problem with my matco brakes! pilot side is nice and turns on the dime, the passenger side is another question! not as tight and some fluid always seems to seep from the threads on the bleeder valve. I will buy a rebuild kit at Oshkosh if matco has them at the sale tent. Ray ----- Original Message ----- From: Marco Menezes<mailto:msm_9949(at)yahoo.com> To: kitfox-list(at)matronics.com Sent: Sunday, July 10, 2005 9:39 PM Subject: Re: Kitfox-List: Taxi Tests As a matter of fact, Ray, another of the minor problems noted in taxi tests was weakness in the left brake. I also have Matco brakes and have tried bleeding the left cylinder repeatedly to no avail. It still feels "mushy" and leaks fluid around the brake shaft where it enters the cylinder. I'm ordering a rebuild kit. I don't understand how this can affect ability to turn. Can you explain? Marco Menezes Model 2 582 - N99KX RAY Gignac > wrote: Hello, One other thing you might want to check if the problem is still going on! I have matco brakes, and if the breaks have any air or the guide rails are not moving freely, you might have this problem. Ray ----- Original Message ----- From: Marco Menezes To: Matronics.com Subject: Kitfox-List: Taxi Tests Kitfox list: I did my taxi testing today and identified a few glitches that need working out. Most significant are: 1) My legs are too short and 2) an apparent lack of turning authority (on the ground) when left rudder is applied. She turns to the right easily but left turns require what seems inordinate rudder pressure to achieve a sluggish left turn. I tried tightening the tension on left rudder cable which seemed to help a little. There's still a noticable discrepancy in left rudder authority when compared to right, however. Tailwheel springs and chains are both tight. Any ideas? Also, I deliberately ignored the wise counsel of those on the list who have advised against high speed taxi runs. Result? A 20 mph groundloop to the left. Scary buy no damage, except to ego. Marco Menezes N99KX Model 2 - 582 --------------------------------- ________________________________________________________________________________
Subject: Airshow Midair
Date: Jul 10, 2005
Unfortunately weve lost a veteran air show performer today.. Jimmy Franklin and Bobby Younkin.. Jim Leroys Bulldog was also involved but was able to land Apparently Jimmys wing walking son had just finished his routine and was announcing the performance. Fly Safe !! John & Debra McBean www.sportplanellc.com <http://www.sportplanellc.com/> "The Sky is not the Limit... It's a Playground" ________________________________________________________________________________
Date: Jul 11, 2005
Here is some more info about it. http://www.avweb.com/newswire/11_28a/leadnews/190146-1.html Torgeir. > From: jdmcbean [jdmcbean(at)cableone.net] > Sent: 2005-07-11 07:25:43 CEST > To: Kitfox List [Kitfox-list(at)matronics.com] > Subject: Kitfox-List: Airshow Midair > > > Unfortunately weve lost a veteran air show performer today.. Jimmy Franklin > and Bobby Younkin.. Jim Leroys Bulldog was also involved but was able to > land Apparently Jimmys wing walking son had just finished his routine and > was announcing the performance. > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com <http://www.sportplanellc.com/> > "The Sky is not the Limit... It's a Playground" > > > > > > ________________________________________________________________________________
Date: Jul 11, 2005
Marco, a few things on taxing...... Brakes should have no part of your yaw control excepet when turning or braking. You should be able to steer your plane with rudder authority alone during taxing. High speed taxing is what you will work into but not at day 1 of taxing. Remember if you cannot high speed taxi, most likely you are you ready to transition from high speed taxi (take off run ) to Flight and visa versa. If you are a new pilot or taildragger newbie, please listen and get some dual time with a qualified instructor. Hope this helps and Good Luck, Kirby btw i have matco brakes and have no trouble at all. <<<<<> I did my taxi testing today and identified a few glitches that need working out. Most significant are: 1) My legs are too short and 2) an apparent lack of turning authority (on the ground) when left rudder is applied. She turns to the right easily but left turns require what seems inordinate rudder pressure to achieve a sluggish left turn. > > I tried tightening the tension on left rudder cable which seemed to help a little. There's still a noticable discrepancy in left rudder authority when compared to right, however. Tailwheel springs and chains are both tight. Any ideas? > > Also, I deliberately ignored the wise counsel of those on the list who have advised against high speed taxi runs. Result? A 20 mph groundloop to the left. Scary buy no damage, except to ego. > > Marco Menezes > N99KX Model 2 - 582>>> ________________________________________________________________________________
Subject: Re: Airshow Midair
Date: Jul 11, 2005
How awful. I met both of them last year at Oshkosh and was very impressed. Terrible loss. Deke ----- Original Message ----- From: "jdmcbean" <jdmcbean(at)cableone.net> Subject: Kitfox-List: Airshow Midair > > Unfortunately weve lost a veteran air show performer today.. Jimmy Franklin > and Bobby Younkin.. Jim Leroys Bulldog was also involved but was able to > land Apparently Jimmys wing walking son had just finished his routine and > was announcing the performance. > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com <http://www.sportplanellc.com/> > "The Sky is not the Limit... It's a Playground" > > ________________________________________________________________________________
Date: Jul 11, 2005
Subject: Fuel level sensor
Hello guys, Saturday I flew in the mountains with my son. On our way home, I noticed the low fuel warning light on. I became very worried because the mountains offer very little landing places. So I untied, turned myself, opened the canvas behind the seats and looked at the header tank where the low fuel sensor is attached. There was plenty fuel in the wings and ... also in the header tank. False alert. Yesterday, I went for a short flight, the light was still on. I remember that, on my flight to Belgium, it came on once or twice, just after take-off. But it went off after a couple of minutes. This time it stays on on the time. The sensor must be defect. I'll empty the wing tanks and header for fuel and remove the sensor. But - to be prepared - does anyone know how they work and what to expect? Remember I didn't build the plane. The sensor is screwed in the header tank sideways and shorten to earth when no fuel is sensed. Is that a standard Kitfox equipment of something fancy the builder has added? On the panel, the light is next to the oil level light. I like to have them there. With the Jabiru, the oil light is connected to the oil pressure sensor. The low fuel sensor in the header tank is also nice because, once on, I should still have about 20 minutes of fuel at low speed. Any advice before unscrewing would be very welcomed. Cheers, Michel ________________________________________________________________________________
Date: Jul 11, 2005
First I would make sure no light is getting to it. You will get false alert. Black tape or the aluminum stuff will eliminate that. If you do get a low fuel light immediately very that against the fuel level tubes if you have them , if not look at the vent line it will either be empty or be full of air bubbles....time to find a soft spot to land. Don't ask how I know this. You can also get a low fuel light on long descents and that could be low fuel and the fuel feed hole coming uncovered. That scenario you just level off and refill the header and do a more nose up descent. I went with a larger aluminum header tank about 3 gallon. Just a little more peace of mind. Hope that helps. Rick -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Michel Verheughe Subject: Kitfox-List: Fuel level sensor Hello guys, Saturday I flew in the mountains with my son. On our way home, I noticed the low fuel warning light on. I became very worried because the mountains offer very little landing places. So I untied, turned myself, opened the canvas behind the seats and looked at the header tank where the low fuel sensor is attached. There was plenty fuel in the wings and ... also in the header tank. False alert. Yesterday, I went for a short flight, the light was still on. I remember that, on my flight to Belgium, it came on once or twice, just after take-off. But it went off after a couple of minutes. This time it stays on on the time. The sensor must be defect. I'll empty the wing tanks and header for fuel and remove the sensor. But - to be prepared - does anyone know how they work and what to expect? Remember I didn't build the plane. The sensor is screwed in the header tank sideways and shorten to earth when no fuel is sensed. Is that a standard Kitfox equipment of something fancy the builder has added? On the panel, the light is next to the oil level light. I like to have them there. With the Jabiru, the oil light is connected to the oil pressure sensor. The low fuel sensor in the header tank is also nice because, once on, I should still have about 20 minutes of fuel at low speed. Any advice before unscrewing would be very welcomed. Cheers, Michel ________________________________________________________________________________
Date: Jul 11, 2005
Subject: Re: Fuel level sensor
Hi Michel. Do you have an optical or float-type sensor? If your header tank is opaque, it's probably optical. If not, the sensor is just a lever type switch designed to "float" in gasoline. The switch is normally open. When gas in header drops below a certain point, the lever drops closing the circuit and illuminating indicator light on panel. I don't know anything about the opticals but with float type, if indicator light is off, then comes on with header being full, there is probably a short circuit somewhere in the line from the switch to the light. Hope this helps. Marco Menezes Model 2 - 582 N99KX (Taxiing slow for awhile). Michel Verheughe wrote: Hello guys, Saturday I flew in the mountains with my son. On our way home, I noticed the low fuel warning light on. I became very worried because the mountains offer very little landing places. So I untied, turned myself, opened the canvas behind the seats and looked at the header tank where the low fuel sensor is attached. There was plenty fuel in the wings and ... also in the header tank. False alert. Yesterday, I went for a short flight, the light was still on. I remember that, on my flight to Belgium, it came on once or twice, just after take-off. But it went off after a couple of minutes. This time it stays on on the time. The sensor must be defect. I'll empty the wing tanks and header for fuel and remove the sensor. But - to be prepared - does anyone know how they work and what to expect? Remember I didn't build the plane. The sensor is screwed in the header tank sideways and shorten to earth when no fuel is sensed. Is that a standard Kitfox equipment of something fancy the builder has added? On the panel, the light is next to the oil level light. I like to have them there. With the Jabiru, the oil light is connected to the oil pressure sensor. The low fuel sensor in the header tank is also nice because, once on, I should still have about 20 minutes of fuel at low speed. Any advice before unscrewing would be very welcomed. Cheers, Michel ________________________________________________________________________________
Date: Jul 11, 2005
Subject: Re: Windshield Fasteners
I used #10 nutplates, fastened with solid, countersunk rivets to hold them on. This way, I can selectively tighten the truss-head machine screws for the proper "slippage". I used #10's because the head is slightly larger, giving me more area in contact with the winshield/skylight. Lynn On Saturday, July 9, 2005, at 03:00 PM, Guy Buchanan wrote: > > Hi everybody. > What should I use to fasten my windshield/skylight. The manual > says aluminum rivet, I assume that's a pop rivet, but it could be a > standard rivet as well. Should I fasten it with #6 screws and lock > nuts for > maintainability? Or is that too heavy and unnecessary? Thanks for the > help. > > > Guy Buchanan > K-IV 1200 / 582 / 99% done, thanks to Bob Ducar. > > ________________________________________________________________________________
Date: Jul 11, 2005
Michel If your sensor is an optical sensor, about an 25mm diameter, with a very small light inside of it (hard to see) then it is similar to mine which I purchased from Skystar. It is possible that sunlight was reaching it and triggering it. Try wrapping the expose portions of the sensor, the entire sensor not just the threaded shaft, with electrical tape. Also, I mounted mine in the lower hole of the header leaving about 25mm of space on top for the odd air bubble. Once I made these two changes, I have never had a false alarm. SteveZ Calgary -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Michel Verheughe Subject: Kitfox-List: Fuel level sensor Hello guys, Saturday I flew in the mountains with my son. On our way home, I noticed the low fuel warning light on. I became very worried because the mountains offer very little landing places. So I untied, turned myself, opened the canvas behind the seats and looked at the header tank where the low fuel sensor is attached. There was plenty fuel in the wings and ... also in the header tank. False alert. Yesterday, I went for a short flight, the light was still on. I remember that, on my flight to Belgium, it came on once or twice, just after take-off. But it went off after a couple of minutes. This time it stays on on the time. The sensor must be defect. I'll empty the wing tanks and header for fuel and remove the sensor. But - to be prepared - does anyone know how they work and what to expect? Remember I didn't build the plane. The sensor is screwed in the header tank sideways and shorten to earth when no fuel is sensed. Is that a standard Kitfox equipment of something fancy the builder has added? On the panel, the light is next to the oil level light. I like to have them there. With the Jabiru, the oil light is connected to the oil pressure sensor. The low fuel sensor in the header tank is also nice because, once on, I should still have about 20 minutes of fuel at low speed. Any advice before unscrewing would be very welcomed. Cheers, Michel ________________________________________________________________________________
Date: Jul 11, 2005
Deke, Isnt Jimmy Franklin the one who made the "Kitfox speedster" aerobatics show?? With respect Torgeir. wrote: > > > How awful. I met both of them last year at Oshkosh and was very > impressed. > Terrible loss. > Deke > > ----- Original Message ----- > From: "jdmcbean" <jdmcbean(at)cableone.net> > To: "Kitfox List" > Subject: Kitfox-List: Airshow Midair > > >> >> Unfortunately weve lost a veteran air show performer today.. Jimmy > Franklin >> and Bobby Younkin.. Jim Leroys Bulldog was also involved but was able to >> land Apparently Jimmys wing walking son had just finished his routine >> and >> was announcing the performance. >> >> Fly Safe !! >> John & Debra McBean >> www.sportplanellc.com <http://www.sportplanellc.com/> >> "The Sky is not the Limit... It's a Playground" >> >> > > -- Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/ ________________________________________________________________________________
Date: Jul 11, 2005
Yes. Jeff Classic IV > [Original Message] > From: Torgeir Mortensen <torgemor(at)online.no> > To: > Date: 7/11/2005 1:45:57 PM > Subject: Re: Kitfox-List: Airshow Midair > > > Deke, > > Isnt Jimmy Franklin the one who made the "Kitfox speedster" aerobatics > show?? > > With respect > > Torgeir. > > > wrote: > > > > > > > How awful. I met both of them last year at Oshkosh and was very > > impressed. > > Terrible loss. > > Deke > > > > ----- Original Message ----- > > From: "jdmcbean" <jdmcbean(at)cableone.net> > > To: "Kitfox List" > > Subject: Kitfox-List: Airshow Midair > > > > > >> > >> Unfortunately weve lost a veteran air show performer today.. Jimmy > > Franklin > >> and Bobby Younkin.. Jim Leroys Bulldog was also involved but was able to > >> land Apparently Jimmys wing walking son had just finished his routine > >> and > >> was announcing the performance. > >> > >> Fly Safe !! > >> John & Debra McBean > >> www.sportplanellc.com <http://www.sportplanellc.com/> > >> "The Sky is not the Limit... It's a Playground" > >> > >> > > > > > > > -- > Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/ > > ________________________________________________________________________________
Date: Jul 11, 2005
Thank you, Rick, Marco and Steve. Rick, yes it may appear that the light comes on when the sun shines under a certain angle, through the glareshield. This was not the case. My vent line is black rubber and not transparent, I can't see if there are bubbles in it. Marco, I don't know if I have an optical or float-type, I haven't opened it yet. But thanks to you guys, I know now that there are two types. From what you say, it will probably be the float-type because the header tank is in transparent thermoplastic. In fact, when I remove the fabric behind the seats, I can see the level in the tank easily. Well, not easily because usually it is entirely full and I can't notice the top of the liquid. But during this very hot summer, I have noticed that, sometimes, there is gas (although I use AVGAS) on the top of the tank. The two inlets and the vent line are about an inch below the top and it won't vent out. But the sensor is below that and should stay immersed. This is how I could see, when I flew home, that I still had fuel in the header tank and that it was safe to continue to our destination. I expect that the optical sensor has no moving parts. But the float one, obviously has. Probably something is wrong with the float. I will check that out as soon as I empty the wing tanks and can unscrew the sensor. Flying without a low fuel sensor is not a big deal but having it sure makes me feel better! :-) Thanks again for your advice. Cheers, Michel ________________________________________________________________________________
Date: Jul 11, 2005
Hi Michel, Come to think about a little difference between the two systems, the float type has only two wires (normally) and the "opto type" has three wires. Hmm., correct me if I'm wrong. Torgeir. wrote: > > Thank you, Rick, Marco and Steve. > > Rick, yes it may appear that the light comes on when the sun shines > under a > certain angle, through the glareshield. This was not the case. > My vent line is black rubber and not transparent, I can't see if there > are > bubbles in it. > > Marco, I don't know if I have an optical or float-type, I haven't opened > it > yet. But thanks to you guys, I know now that there are two types. > From what you say, it will probably be the float-type because the header > tank > is in transparent thermoplastic. > In fact, when I remove the fabric behind the seats, I can see the level > in the > tank easily. Well, not easily because usually it is entirely full and I > can't > notice the top of the liquid. But during this very hot summer, I have > noticed > that, sometimes, there is gas (although I use AVGAS) on the top of the > tank. > The two inlets and the vent line are about an inch below the top and it > won't > vent out. But the sensor is below that and should stay immersed. > This is how I could see, when I flew home, that I still had fuel in the > header > tank and that it was safe to continue to our destination. > > I expect that the optical sensor has no moving parts. But the float one, > obviously has. Probably something is wrong with the float. I will check > that > out as soon as I empty the wing tanks and can unscrew the sensor. Flying > without a low fuel sensor is not a big deal but having it sure makes me > feel > better! :-) > > Thanks again for your advice. > > Cheers, > Michel > > -- Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/ ________________________________________________________________________________
Date: Jul 12, 2005
Subject: 912s Black plugs
I have 22 hrs. on my 912 runnig a little better now but runs cool on the EGT and the plugs are black which means too much gas. I have my needle valve at 1/12 turns. my question is do I turn my needle valve in or put in different jets? Jon Modle IV. ________________________________________________________________________________
Date: Jul 12, 2005
> From: Torgeir Mortensen [torgemor(at)online.no] > Come to think about a little difference between the two systems, the float > type has only two wires (normally) and the "opto type" has three wires. This is exactly what I was thinking yesterday, when I read the answers on the list, Torgeir! My sensor has only two wires, one going to the earth and the other, to the light. Therefore it must be a simple switch that earth the low-fuel light on the panel. And, as you say, an optical device would need three lines, earth, 12V and the sensor line that goes to the light. I'll know more soon! :-) Cheers, Michel ________________________________________________________________________________
Date: Jul 12, 2005
It is my understanding that the needle adjustment will change the range in which the fuel is delivered. The jet will effect the entire range. Kind of hard to do a full power run and cut clean and check the plugs in the air so I will leave the final answer to someone who has been there done that on a 912. Good luck. Rick N656T -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Kaufjm(at)aol.com Subject: Kitfox-List: 912s Black plugs I have 22 hrs. on my 912 runnig a little better now but runs cool on the EGT and the plugs are black which means too much gas. I have my needle valve at 1/12 turns. my question is do I turn my needle valve in or put in different jets? Jon Modle IV. ________________________________________________________________________________
Subject: Re: 912s Black plugs
Date: Jul 12, 2005
if you are adjusting the needle screw, primarily idle is all tha is affected. consider changing you jets and/or needle clip that is separate from the screw. you can obtain a manual and jets from Bing International. the jet controls primarily top end. the needle/clip control primarily mid range. the term primarily is offered because all three parts of the carburator are somewhat in use at higher rpms. John Kerr -------------- Original message -------------- > > I have 22 hrs. on my 912 runnig a little better now but runs cool on the EGT > and the plugs are black which means too much gas. I have my needle valve at > 1/12 turns. my question is do I turn my needle valve in or put in different > jets? > Jon Modle IV. > > > > > > if you are adjusting the needle screw, primarily idle is all tha is affected. consider changing you jets and/or needle clip that is separate from the screw. you can obtain a manual and jets from Bing International. the jet controls primarily top end. the needle/clip control primarily mid range. the term primarily is offered because all three parts of the carburator are somewhat in use at higher rpms. John Kerr -------------- Original message -------------- -- Kitfox-List message posted by: Kaufjm(at)aol.com I have 22 hrs. on my 912 runnig a little better now but runs cool on the EGT and the plugs are black which means too much gas. I have my needle valve at 1/12 turns. my question is do I turn my needle valve in or put in different jets? Jon Modle IV. ================================================ ________________________________________________________________________________
Date: Jul 12, 2005
you might try Lockwood Aviation's support. they've been very helpful in guiding me thru some carburetor problems. phone number is on their net site. Fred I have 22 hrs. on my 912 runnig a little better now but runs cool on the EGT and the plugs are black which means too much gas. I have my needle valve at ________________________________________________________________________________
Date: Jul 12, 2005
Subject: Re: C-GOOT Flies Again
Gary, Glad to hear you're back in the air. About 6 months ago the people at Prop-Link told me they were not proceeding with a beta mode (I'd planned to use it as I got my S6 on floats) as they were unhappy with the loads the prop/hub experienced as it transitioned into beta. I don't think that's come up relative to CAP failures. Perhaps the engineers on the list can comment on this as a failure mode applicable to the CAP. Please let us know about your performance as soon as you're back on floats Fred ________________________________________________________________________________
Date: Jul 12, 2005
22 pounds. Deke >Anyone know the full up weight of the NSI CAP 140? > Gary Walsh > C-GOOT ________________________________________________________________________________
Subject: Building A grass Strip
Date: Jul 12, 2005
Paul, Thanks for your reply. That is the main issue that I see that favors registration. I hadn't mentioned it because I was wanting to leave the subject open to see what surfaced. Again thanks for you comment and I will toss out an invitation to come and visit and see the area here. Lots of great things to see. Mount Rushmore. Crazy Horse. Devil's Tower. The Badlands. More... Randy - Black Hills of South Dakota . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Peerenboom Subject: Re: Kitfox-List: Building A grass Strip Get it registered. As houses build up people have much more pull to prevent you from flying from your land then if the strip is registered as an private airport. In Wisconsin the state, country and township all get involved but it wasn't that hard. Paul N102DG ----- Original Message ----- From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> Subject: RE: Kitfox-List: Building A grass Strip > > > Jeff, > What are the reasons for registering your private airport? I had someone > with the government tell me to just fly from it and forget about > registering > it. He said there is no value in registering it. > > I have also been told that insurance is much less expensive if you > register > your strip. > > I have just been flying from my strip so far, but I am still interested in > registering it. > > Randy > > . > > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of > JJProbasco(at)cs.com > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: Building A grass Strip > > > I built a grass strip in PA and got my final airport license last fall. > The > > paperwork side was relatively painless. Raking a shoveling stones - well > that's another story. > > Generally for private airports, the feds are interested only in the air > space > and safe approaches, and your state will probably be more interested in > the > overall design features and ground location. I suggest you start with the > division or aeronautics in the department of transportation for your > state. > PA > was very helpful, and provided an information packet with the necessary > forms/or > pointing to the FAA website for forms and advisories. > > Jeff > Model 5, NSI CAP, still building > > > ________________________________________________________________________________
Date: Jul 12, 2005
Have some knowledge of the subject...built a grass strip in Alabama... The regs vary state to state, so your mileage may vary...but this is how it is in Alabama. They have 3 classes of airport..."personal"-(just me...), "private"-(just me and who I invite...), and "public"-(me, and anyone who wants to...) In Alabama, "personal" airports don't require any registration with the state...(i.e. it will only be my life in jeopardy by a "sub-standard" airport facility ;-) whereas "private" and "public" require registration and inspection by the state board of transportation... Now here comes the rub...the comment about your neighbors not wanting an "airport" in the neighborhood is a very good one...and registration might protect you down the road...but in Alabama, to GET registered requires the state department of transportation guy to basically go around to all of your neighbors and ask them if they mind if you have an airport on your property!!! They then have you under their thumb, and the state guy actually told me that usually what happened was a sort of blackmail where you got to "compensate" them for their "loss of property value" due to living next to an airport ;-) (Would have possibly led to neighbor on neighbor violence ;-) When I asked the state transportation guy if I needed to tell all my flying buddies to stay out cause I was a "personal use" airport...he laughed and told me that they didn't have an "airport-use enforcement division" and try not to be totally obvious ;-) (i.e. don't host a EAA regional flyin, etc...) Thanks to the super-quiet nature of the 912 engine, almost none of my neighbors even know I fly out of the backyard... ;-) and the one's that do think it is cool and have been given rides...and always wave when I fly over. (I do try to avoid direct overflights and simple courtesy goes a long way...i.e. no 6:00 am departures...etc.) Jeremy Casey http://www.kilocharlie.us/images/briarpatch_large.jpg -----Original Message----- From: Randy Daughenbaugh [mailto:rjdaugh(at)rapidnet.com] Subject: Off line RE: Kitfox-List: Building A grass Strip Paul, Thanks for your reply. That is the main issue that I see that favors registration. I hadn't mentioned it because I was wanting to leave the subject open to see what surfaced. Again thanks for you comment and I will toss out an invitation to come and visit and see the area here. Lots of great things to see. Mount Rushmore. Crazy Horse. Devil's Tower. The Badlands. More... Randy - Black Hills of South Dakota . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Peerenboom Subject: Re: Kitfox-List: Building A grass Strip Get it registered. As houses build up people have much more pull to prevent you from flying from your land then if the strip is registered as an private airport. In Wisconsin the state, country and township all get involved but it wasn't that hard. Paul N102DG ----- Original Message ----- From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> Subject: RE: Kitfox-List: Building A grass Strip > > > Jeff, > What are the reasons for registering your private airport? I had someone > with the government tell me to just fly from it and forget about > registering > it. He said there is no value in registering it. > > I have also been told that insurance is much less expensive if you > register > your strip. > > I have just been flying from my strip so far, but I am still interested in > registering it. > > Randy > > . > > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of > JJProbasco(at)cs.com > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: Building A grass Strip > > > I built a grass strip in PA and got my final airport license last fall. > The > > paperwork side was relatively painless. Raking a shoveling stones - well > that's another story. > > Generally for private airports, the feds are interested only in the air > space > and safe approaches, and your state will probably be more interested in > the > overall design features and ground location. I suggest you start with the > division or aeronautics in the department of transportation for your > state. > PA > was very helpful, and provided an information packet with the necessary > forms/or > pointing to the FAA website for forms and advisories. > > Jeff > Model 5, NSI CAP, still building > > > ________________________________________________________________________________
Subject: Selling my fox
Date: Jul 12, 2005
Due to a bad and getting worse financial situation, My wife and I decided that we need to sell our Fox. This has been a tough decision to make, but it comes down to the last thing I own that is worth anything...I just need to bail myself out and start over. I wanted to offer it here first, but I will be soon listing it on barnstormers, then Ebay as a last resort. Here is what I have; Kitfox model 5 with a NSI Turbo & Warp Drive with CAP New vacuum pump Grove gear & tailspring LP windshield, bubble doors with airvents cabin heater, duel fan New Apollo SL40 VHF Comm New Garmin GTX 320A Transponder professionally wired and installed RC Allen IFR Gyro's Here are two pictures; http://home.mchsi.com/~pianome2/leftside.jpg http://home.mchsi.com/~pianome2/panel4.jpg The engine is currently off of the plane. It is ready to be shipped to NSI for a complete overhaul and the cost is included in the price. Asking $34,500 I can answer any questions you may have, also I can supply any pictures you may want. E-mail me or call me at (218) 749-4659 most evenings I'm home. Howard Firm 508 12th St. South Virginia MN 55792 ________________________________________________________________________________
Date: Jul 12, 2005
Subject: Polyfiber Polytone Paint for sale
One gallon each of Bahama Blue and Pontiac Red. Just rec'd. Changed paint scheme. For sale in/near Illinois (can't ship via UPS). $50/gallon. Mark Anliker Sadorus, IL 217-898-4766 ________________________________________________________________________________
Subject: Re: Building A grass Strip
Date: Jul 12, 2005
Randy, I hope that invite extends to all. Last year we flew past your area on our way to Osh. We saw Devil'a Tower, but missed Mt. Rushmore both dorections. I hope to make the trip again sometime - not this year, though. Lowell ----- Original Message ----- From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> Subject: Off line RE: Kitfox-List: Building A grass Strip > > > Paul, > Thanks for your reply. That is the main issue that I see that favors > registration. I hadn't mentioned it because I was wanting to leave the > subject open to see what surfaced. > > Again thanks for you comment and I will toss out an invitation to come and > visit and see the area here. Lots of great things to see. Mount > Rushmore. > Crazy Horse. Devil's Tower. The Badlands. More... > > > Randy - Black Hills of South Dakota > . > > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul > Peerenboom > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: Building A grass Strip > > > > Get it registered. As houses build up people have much more pull to > prevent > you from flying from your land then if the strip is registered as an > private > > airport. In Wisconsin the state, country and township all get involved but > it wasn't that hard. > > Paul N102DG > ----- Original Message ----- > From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> > To: > Subject: RE: Kitfox-List: Building A grass Strip > > >> >> >> Jeff, >> What are the reasons for registering your private airport? I had someone >> with the government tell me to just fly from it and forget about >> registering >> it. He said there is no value in registering it. >> >> I have also been told that insurance is much less expensive if you >> register >> your strip. >> >> I have just been flying from my strip so far, but I am still interested >> in >> registering it. >> >> Randy >> >> . >> >> >> -----Original Message----- >> From: owner-kitfox-list-server(at)matronics.com >> [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of >> JJProbasco(at)cs.com >> To: kitfox-list(at)matronics.com >> Subject: Re: Kitfox-List: Building A grass Strip >> >> >> I built a grass strip in PA and got my final airport license last fall. >> The >> >> paperwork side was relatively painless. Raking a shoveling stones - well >> that's another story. >> >> Generally for private airports, the feds are interested only in the air >> space >> and safe approaches, and your state will probably be more interested in >> the >> overall design features and ground location. I suggest you start with >> the >> division or aeronautics in the department of transportation for your >> state. >> PA >> was very helpful, and provided an information packet with the necessary >> forms/or >> pointing to the FAA website for forms and advisories. >> >> Jeff >> Model 5, NSI CAP, still building >> >> >> > > > ________________________________________________________________________________
Date: Jul 12, 2005
Lowell, Certainly to one plane at a time. Hopefully someday we can accommodate several at a time, but would need some time to plan for that. I have been waiting for Skystar to return to the fly-ins. And some day, I may even be brave enough to try for Cameron Park. I am getting a little braver all the time. Randy . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Lowell Fitt Subject: Re: Off line RE: Kitfox-List: Building A grass Strip Randy, I hope that invite extends to all. Last year we flew past your area on our way to Osh. We saw Devil'a Tower, but missed Mt. Rushmore both dorections. I hope to make the trip again sometime - not this year, though. Lowell ----- Original Message ----- From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> Subject: Off line RE: Kitfox-List: Building A grass Strip > > > Paul, > Thanks for your reply. That is the main issue that I see that favors > registration. I hadn't mentioned it because I was wanting to leave the > subject open to see what surfaced. > > Again thanks for you comment and I will toss out an invitation to come and > visit and see the area here. Lots of great things to see. Mount > Rushmore. > Crazy Horse. Devil's Tower. The Badlands. More... > > > Randy - Black Hills of South Dakota > . > > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul > Peerenboom > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: Building A grass Strip > > > > Get it registered. As houses build up people have much more pull to > prevent > you from flying from your land then if the strip is registered as an > private > > airport. In Wisconsin the state, country and township all get involved but > it wasn't that hard. > > Paul N102DG > ----- Original Message ----- > From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> > To: > Subject: RE: Kitfox-List: Building A grass Strip > > >> >> >> Jeff, >> What are the reasons for registering your private airport? I had someone >> with the government tell me to just fly from it and forget about >> registering >> it. He said there is no value in registering it. >> >> I have also been told that insurance is much less expensive if you >> register >> your strip. >> >> I have just been flying from my strip so far, but I am still interested >> in >> registering it. >> >> Randy >> >> . >> >> >> -----Original Message----- >> From: owner-kitfox-list-server(at)matronics.com >> [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of >> JJProbasco(at)cs.com >> To: kitfox-list(at)matronics.com >> Subject: Re: Kitfox-List: Building A grass Strip >> >> >> I built a grass strip in PA and got my final airport license last fall. >> The >> >> paperwork side was relatively painless. Raking a shoveling stones - well >> that's another story. >> >> Generally for private airports, the feds are interested only in the air >> space >> and safe approaches, and your state will probably be more interested in >> the >> overall design features and ground location. I suggest you start with >> the >> division or aeronautics in the department of transportation for your >> state. >> PA >> was very helpful, and provided an information packet with the necessary >> forms/or >> pointing to the FAA website for forms and advisories. >> >> Jeff >> Model 5, NSI CAP, still building >> >> >> > > > ________________________________________________________________________________
Date: Jul 13, 2005
Hi Gary, Se below. 10:53:33 AM, kitfoxjunky wrote: > > > Hi Torgeir > > I meant to say the "rough spot"..not the "right spot". Sometimes I type > too fast. Figured out this.. > > One thing I think I will miss is the NSI CAP's ability to flatten out > completely, even go into beta. On floats, it was nice to be able to keep > the RPM up and use the pitch selector to control forward motion, even > stop the plane. This is indeed an interesting capability. > One of my big concerns with the IVO was that it could only go > into fine pitch and not flatten out completely. Then again, the design > of the prop (the lack of moving parts) gives me confidence it will never > come apart. Do not have any experience with the variable pitch version (but love to -later on), well -maybe Gary Algate can fill in here?? > I will purchase the in flight adjust option only after I test it > at full fine adjustment when I get the plane back on the floats. If I > can keep the RPM in the 2500 range, and have a slow enough taxi at full > fine so the water does not come over the front of the floats, I will go > for the added expense. I'll hope you'll keep us informed, most interesting. > On wheels the in flight adjustment is simply not > necessary. Even at a courser pitch I use on the ground adjust the plane > literally jumps into the air. Here I've got the same experience and are very satisfied. :) > The IVO Medium Quick Adjust is only 18 LBS. Anyone know the full up > weight of the NSI CAP 140? I seem to remember hearing something like 26 > LBS. > No idea about this one.. Thanks for this interesting info Gary. (Coming weekend I'm going on holiday for three week to Thailand, so I'll be unable to plan any list visit.) Have a nice holiday. Cheers Torgeir. ________________________________________________________________________________
Date: Jul 13, 2005
I've been reading some posts about private airstrips.I agree State and local Laws vary,but one Law doesn't as told to me by the good ole FAA.Any runway used for 30 consecutive days must be registered, the only exemption to this is a special permit issued for an airshow.The application is lengthy I'm 5'11'' and with the first Bi-fold page over my head the rest of it hit the floor.To save you some time on the phone,you can't get the application locally it must come from Teterboro.You have to state the longitude and latitude,as well as elevation of the strip gps is not acceptable. You must use National geological survey maps Regards David Cecil -----Original Message----- From: Jeremy Casey <n79rt(at)kilocharlie.us> Subject: RE: Off line RE: Kitfox-List: Building A grass Strip Have some knowledge of the subject...built a grass strip in Alabama... The regs vary state to state, so your mileage may vary...but this is how it is in Alabama. They have 3 classes of airport..."personal"-(just me...), "private"-(just me and who I invite...), and "public"-(me, and anyone who wants to...) In Alabama, "personal" airports don't require any registration with the state...(i.e. it will only be my life in jeopardy by a "sub-standard" airport facility ;-) whereas "private" and "public" require registration and inspection by the state board of transportation... Now here comes the rub...the comment about your neighbors not wanting an "airport" in the neighborhood is a very good one...and registration might protect you down the road...but in Alabama, to GET registered requires the state department of transportation guy to basically go around to all of your neighbors and ask them if they mind if you have an airport on your property!!! They then have you under their thumb, and the state guy actually told me that usually what happened was a sort of blackmail where you got to "compensate" them for their "loss of property value" due to living next to an airport ;-) (Would have possibly led to neighbor on neighbor violence ;-) When I asked the state transportation guy if I needed to tell all my flying buddies to stay out cause I was a "personal use" airport...he laughed and told me that they didn't have an "airport-use enforcement division" and try not to be totally obvious ;-) (i.e. don't host a EAA regional flyin, etc...) Thanks to the super-quiet nature of the 912 engine, almost none of my neighbors even know I fly out of the backyard... ;-) and the one's that do think it is cool and have been given rides...and always wave when I fly over. (I do try to avoid direct overflights and simple courtesy goes a long way...i.e. no 6:00 am departures...etc.) Jeremy Casey http://www.kilocharlie.us/images/briarpatch_large.jpg -----Original Message----- From: Randy Daughenbaugh [mailto:rjdaugh(at)rapidnet.com] Subject: Off line RE: Kitfox-List: Building A grass Strip Paul, Thanks for your reply. That is the main issue that I see that favors registration. I hadn't mentioned it because I was wanting to leave the subject open to see what surfaced. Again thanks for you comment and I will toss out an invitation to come and visit and see the area here. Lots of great things to see. Mount Rushmore. Crazy Horse. Devil's Tower. The Badlands. More... Randy - Black Hills of South Dakota . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Peerenboom Subject: Re: Kitfox-List: Building A grass Strip Get it registered. As houses build up people have much more pull to prevent you from flying from your land then if the strip is registered as an private airport. In Wisconsin the state, country and township all get involved but it wasn't that hard. Paul N102DG ----- Original Message ----- From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com> Subject: RE: Kitfox-List: Building A grass Strip > > > Jeff, > What are the reasons for registering your private airport? I had someone > with the government tell me to just fly from it and forget about > registering > it. He said there is no value in registering it. > > I have also been told that insurance is much less expensive if you > register > your strip. > > I have just been flying from my strip so far, but I am still interested in > registering it. > > Randy > > . > > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of > JJProbasco(at)cs.com > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: Building A grass Strip > > > I built a grass strip in PA and got my final airport license last fall. > The > > paperwork side was relatively painless. Raking a shoveling stones - well > that's another story. > > Generally for private airports, the feds are interested only in the air > space > and safe approaches, and your state will probably be more interested in > the > overall design features and ground location. I suggest you start with the > division or aeronautics in the department of transportation for your > state. > PA > was very helpful, and provided an information packet with the necessary > forms/or > pointing to the FAA website for forms and advisories. > > Jeff > Model 5, NSI CAP, still building > > > ________________________________________________________________________________
Date: Jul 14, 2005
Subject: List Digest Truncation Fixed!!
Dear Listers, I finally figured out today what was causing the occasional truncation of the daily List Digest emails. Seems that every once in a while a message would contain a single "." (period) on line all by itself. The mailers would see this and assume that this was the universal emailer signal for "end of message", and consequently wouldn't process any of the rest of the Digest message. I've put in a filter today to remove any of these sequences so we should be back in business on the Digests. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
From: "Richard Hutson" <rhutson(at)midsouth.rr.com>
Subject: BUILDING YOUR ON GRASS STRIP
Date: Jul 14, 2005
http://www.dot.state.tx.us/AVN/avninfo.htm While playing on the web, I found this very useful site on the Texas DOT web site. It is very detail manual on how to build your own private air strip. Granted it applies to Texas, but should provide allot of useful information, including a list of manufacturers for items needed on the strip ________________________________________________________________________________
Date: Jul 14, 2005
Fred, the only cap failures I know of were the type one hub that held the blades loosly in the hub. John Oakley > transitioned into beta. I don't think that's come up relative to CAP > failures. Perhaps the engineers on the list can comment on this as a > failure mode applicable to the CAP. > Please let us know about your performance as soon as you're back on ________________________________________________________________________________
Date: Jul 15, 2005
Subject: RE: Gap tapes.
> From: David Savener [david_savener(at)msn.com] > I would like more effective controls for the rudder and elevator on my Model II. > I think I want to seal the gaps. Does it really work? Hello Dave, I have gap sealed the elevator and rudder of my model 3 and yes, I notice a difference. Since your model II has less tail surface, I think it could be a good idea to seal your gaps. > Should I make an S type seal? I have done both the S-type seal and double-seal. Both helps. For the S-type, I used a two-inches off-the-shelf 3M transparent tape that I overlapped about an inch. For the double-type, I joined the same two-inches tape with a one-inch tape in the middle. The trick is to prepare and place the tapes. First, I cut them in lenght that equal the distances between the hinges of the elevator and rudder. I wanted the hinges to be accessible and not covered by tape. In any case, using the S-type, you need to cut them. Then I used a plate of plastic that I sprayed with water, using the bottle my wife uses for ironing clothes. The water helps to keep the tape on the plate when you come with the other tape and static electricity tend to lift it. Once the two tapes together (either overlapping or 1"-on-2") I spray them again with a thin film of water. I put them in place, the water preventing them to be glued too quickly, then I press them in place, squeezing the tiny drops of water out. I believe some people use water mixed with dishwashing soap. Water only worked well for me. I have had these tapes for two years now and they still stick and work well. Maybe I'll replace them next year. Cheers, Michel ________________________________________________________________________________
Date: Jul 15, 2005
Subject: re:gap tapes
I have found that the simplest, longest lasting tape is ordinary fabric tapes applied as per the rest of the airplane. I used this on several airplanes. If you put it over the top of the hinge line, you can cut out access space at the hinge pins, but I've just inspected mine from below. Larry --------------------------------- ________________________________________________________________________________
Subject: RE: 582 Firewall Forward
Date: Jul 15, 2005
I'm hooking up a 582 in a Model I which has never flown before. I'm having a hard time with the throttle cable installation and mounting the coolant filler/recovery tank. To give me some ideas, I was wondering if anyone had digital images of their installation they could send me. Thanks in advance, Bill Severna Park, Maryland ________________________________________________________________________________
Date: Jul 16, 2005
Subject: From the other side.
Hi, Kitfox Friends, Very -very quiet, -on the list, right. Well, here's something, you'll know....and will -remember for a long time...I'll hope :) .. This time, I'll like to show you a different side(?)(-from this side of the pound). This is about the similarity of a Kitfox and a Fighter... He., he , now you'll wonder.. Ok,. Some time ago I got this link to a "download" site, from my god friend; Joe Hemmer(maybe some of you'll know Joe(?)). (Later on I've got plenty of directions to this site..) The link I'll give you, is about(I'll think); a pilot's salute to an outgoing aircraft, in this case a Dassault Mirage III S. This is a video made by some "wild rebels-" flying the Mirage Fighter in the Alps (just like my homeplace). You'll know, when an aircraft is done - it's finished(.), have got all the modifications, being tuned- then, -it's outsource.... I've seen this video numerous of times, don't know why.. Before you'll jump to the link, warning, warning, this file is very large, 36 Mbytes!! If you do not have the bandwidth(it will take forever- to download), have a copy from a friend, It's worth all the struggle... Here's the link: http://www.canardzone.com/content/JetFlightInMountains.wmv Don't know how many times I've been w.. this little record. When you (hopefully)- is enjoying this flight, I'm on the way to Thailand... Happy Holidays to everyone. Torgeir.. PS: Now youll tell me; is there any similarity between a Kitfox and a fighter..(?) (Sure -sure, plenty, but).. Come on, -explain the similarity.. Ill be back in three week.... By the way, here's the actual plane (the leader) from another view (hope this work). http://images.airliners.net/open.file?id=355549&WxsIERv=Qnffnhyg%20Zventr%20VVV%20F&WdsYXMg=Fjvgmreynaq%20-%20Nve%20Sbepr&QtODMg=Jnqqvatgba%20%28JGA%20%2F%20RTKJ%29&ERDLTkt=HX%20-%20Ratynaq&ktODMp=Whar%2017%2C%201993&BP=0&WNEb25u=Wbua%20Uvttvaf%20-%20NveGrnzVzntrf&xsIERvdWdsY=W-2308&MgTUQtODMgKE=Fjvff%20NS%20Zventr%20VVV%20ernql%20sbe%20n%20NPZV%20zvffvba&YXMgTUQtODMgKERD=1383&NEb25uZWxs=2003-05-22%2000%3A00%3A00&ODJ9dvCE=&O89Dcjdg=998&static=yes&width=1024&height=749&sok=JURER%20%20%28cubgb_qngr%20%20%3D%20%27Whar%2017%2C%201993%27%29%20%20BEQRE%20OL%20cubgb_vq%20QRFP&photo_nr=3&prev_id=510712&next_id=355548 All of the above belongs to the link. ________________________________________________________________________________
Subject: Electrical Tools-Wiring Supplies-Harnesses and More
Date: Jul 15, 2005
Hi Everyone, With Matt Dralle's permission, I wanted to let everyone on the list know that Affordable Panels has added electrical tools, electrical supplies, wiring harnesses and more to our inventory. We have some of the lowest prices on everything from tools, terminals, connectors, wire, electroluminescent lighting, etc. Our wiring harnesses for all Trutrak Autopilots are available in "Standard" and "Wing Root Disconnect" form, and we also offer harnesses for the Dynon EFIS, Flightcom and many others at the very best prices. Our full page catalog will be out in a couple of weeks. In the mean time, anyone interested can download the electrical portion of our catalog here. http://www.affordablepanels.com/electrical.htm All electrical orders placed on-line or faxed with a total above $175.00 will ship free via UPS GROUND. Best Regards, Fabian Lefler www.affordablepanels.com ________________________________________________________________________________
Date: Jul 15, 2005
Torgeir, Great video. Thanks for sharing. Jeff Sattin -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Torgeir Mortensen Subject: Kitfox-List: From the other side. --> Hi, Kitfox Friends, Very -very quiet, -on the list, right. Well, here's something, you'll know....and will -remember for a long time...I'll hope :) .. This time, I'll like to show you a different side(?)(-from this side of the pound). This is about the similarity of a Kitfox and a Fighter... He., he , now you'll wonder.. Ok,. Some time ago I got this link to a "download" site, from my god friend; Joe Hemmer(maybe some of you'll know Joe(?)). (Later on I've got plenty of directions to this site..) The link I'll give you, is about(I'll think); a pilot's salute to an outgoing aircraft, in this case a Dassault Mirage III S. This is a video made by some "wild rebels-" flying the Mirage Fighter in the Alps (just like my homeplace). You'll know, when an aircraft is done - it's finished(.), have got all the modifications, being tuned- then, -it's outsource.... I've seen this video numerous of times, don't know why.. Before you'll jump to the link, warning, warning, this file is very large, 36 Mbytes!! If you do not have the bandwidth(it will take forever- to download), have a copy from a friend, It's worth all the struggle... Here's the link: http://www.canardzone.com/content/JetFlightInMountains.wmv Don't know how many times I've been w.. this little record. When you (hopefully)- is enjoying this flight, I'm on the way to Thailand... Happy Holidays to everyone. Torgeir.. PS: Now youll tell me; is there any similarity between a Kitfox and a fighter..(?) (Sure -sure, plenty, but).. Come on, -explain the similarity.. Ill be back in three week.... By the way, here's the actual plane (the leader) from another view (hope this work). http://images.airliners.net/open.file?id=355549&WxsIERv=Qnffnhyg%20Zvent r%20VVV%20F&WdsYXMg=Fjvgmreynaq%20-%20Nve%20Sbepr&QtODMg=Jnqqvatgba%20%2 8JGA%20%2F%20RTKJ%29&ERDLTkt=HX%20-%20Ratynaq&ktODMp=Whar%2017%2C%201993 &BP=0&WNEb25u=Wbua%20Uvttvaf%20-%20NveGrnzVzntrf&xsIERvdWdsY=W-2308&MgTU QtODMgKE=Fjvff%20NS%20Zventr%20VVV%20ernql%20sbe%20n%20NPZV%20zvffvba&YX MgTUQtODMgKERD=1383&NEb25uZWxs=2003-05-22%2000%3A00%3A00&ODJ9dvCE=&O89Dc jdg=998&static=yes&width=1024&height=749&sok=JURER%20%20%28cubgb_qngr%20 %20%3D%20%27Whar%2017%2C%201993%27%29%20%20BEQRE%20OL%20cubgb_vq%20QRFP& photo_nr=3&prev_id=510712&next_id=355548 All of the above belongs to the link. ________________________________________________________________________________
Date: Jul 15, 2005
Subject: Re: From the other side.
I have got to get me one of those . Awsome vid thanks for sharing . John Perry sw wind blowin no water flatland Kansas America Kitfox 2 N718PD -------Original Message------- From: Torgeir Mortensen Date: 07/15/05 19:23:00 Subject: Kitfox-List: From the other side. Hi, Kitfox Friends, Very -very quiet, -on the list, right. Well, here's something, you'll know....and will -remember for a long time...I'll hope :) .. This time, I'll like to show you a different side(?)(-from this side of the pound). This is about the similarity of a Kitfox and a Fighter... He., he , now you'll wonder.. Ok,. Some time ago I got this link to a "download" site, from my god friend; Joe Hemmer(maybe some of you'll know Joe(?)). (Later on I've got plenty of directions to this site..) The link I'll give you, is about(I'll think); a pilot's salute to an outgoing aircraft, in this case a Dassault Mirage III S. This is a video made by some "wild rebels-" flying the Mirage Fighter in the Alps (just like my homeplace). You'll know, when an aircraft is done - it's finished(.), have got all the modifications, being tuned- then, -it's outsource.... I've seen this video numerous of times, don't know why.. Before you'll jump to the link, warning, warning, this file is very large, 36 Mbytes!! If you do not have the bandwidth(it will take forever- to download), have a copy from a friend, It's worth all the struggle... Here's the link: http://www.canardzone.com/content/JetFlightInMountains.wmv Don't know how many times I've been w.. this little record. When you (hopefully)- is enjoying this flight, I'm on the way to Thailand... Happy Holidays to everyone. Torgeir.. PS: Now youll tell me; is there any similarity between a Kitfox and a fighter..(?) (Sure -sure, plenty, but).. Come on, -explain the similarity.. Ill be back in three week.... By the way, here's the actual plane (the leader) from another view (hope this work). http://images.airliners.net/open file?id355549&WxsIERvQnffnhyg%20Zventr%20VVV%20F&WdsYXMgFjvgmreynaq%20-%20 ve%20Sbepr&QtODMgJnqqvatgba%20%28JGA%20%2F%20RTKJ%29&ERDLTktHX%20-%20Ratyna &ktODMpWhar%2017%2C%201993&BP0&WNEb25uWbua%20Uvttvaf%20-%20NveGrnzVzntrf&x IERvdWdsYW-2308&MgTUQtODMgKEFjvff%20NS%20Zventr%20VVV%20ernql%20sbe%20n%20N ZV%20zvffvba&YXMgTUQtODMgKERD1383&NEb25uZWxs2003-05-22%2000%3A00%3A00&ODJ9d CE&O89Dcjdg998&staticyes&width1024&height749&sokJURER%20%20%28cubgb_qng %20%20%3D%20%27Whar%2017%2C%201993%27%29%20%20BEQRE%20OL%20cubgb_vq%20QRFP&ph to_nr3&prev_id510712&next_id355548 All of the above belongs to the link. ________________________________________________________________________________
From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com>
Subject: 582 Coolant/EGT Temp
Date: Jul 17, 2005
I re-pitched my prop for better cruise a little while back...hadn't done much flying until this past week at a fly-in, and now I'm a bit concerned about temperatures... My Coolant Temp mid-day when it was hot and humid was hovering just a hair under 180 on climb-out and dropped to 170 in cruise. My EGT is now at about 900-925 in each cylinder at cruise...the previous owner says that these numbers are fine. Any other opinions (or facts!) Thanks a million! Andrew ________________________________________________________________________________
Subject: Re: 582 Coolant/EGT Temp
Date: Jul 17, 2005
Sounds like your coolant temps are about right (for the conditions). I get nervous when they go above 180 and have had that problem since the beginning on climbout (hot days). My cruise always hangs in there about 165. I think (opinion) that 900 degrees EGT's are a bit on the cool side. Even the Rotax manual recommends somewhere around 1100 or so.....I don't have the manual in front of me... You asked for facts or opinions. The book (facts) says "around" 1050 to 1100. Many like to run close to 1200 (opinion's). I split the difference and run between 1100 and 1150. Again, I don't have the book in front of me so an just using numbers from memory. You have a situation that might prove interesting...If you increased the EGT's to the book number (1100 or so), would this cause your coolant temps to increase???? If it did, you might find yourself like many others, having too high a coolant temp??? Don Smythe Classic IV W/ 582 ----- Original Message ----- > My Coolant Temp mid-day when it was hot and humid was hovering just a hair > under 180 on climb-out and dropped to 170 in cruise. My EGT is now at > about > 900-925 in each cylinder at cruise...the previous owner says that these > numbers are fine. Any other opinions (or facts!) > > Thanks a million! > Andrew > > > ________________________________________________________________________________
From: "Peter Brookes" <pdbrookes(at)blueyonder.co.uk>
Date: Jul 17, 2005
Sounds similar to mine Andrew! Ambient temperature of 27deg C this evening, and water temp right up to 80deg C on climb out, but soon settle in cruise. I would be concerned if it went higher and would consider dropping the rad an inch or so into the airflow more. However, we don't normally get 30deg in England ;-) Pete. Kitfox II 582 -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Andrew Matthaey Subject: Kitfox-List: 582 Coolant/EGT Temp I re-pitched my prop for better cruise a little while back...hadn't done much flying until this past week at a fly-in, and now I'm a bit concerned about temperatures... My Coolant Temp mid-day when it was hot and humid was hovering just a hair under 180 on climb-out and dropped to 170 in cruise. My EGT is now at about 900-925 in each cylinder at cruise...the previous owner says that these numbers are fine. Any other opinions (or facts!) Thanks a million! Andrew ________________________________________________________________________________
From: "Bob Robertson" <aerocontrols(at)clearwave.ca>
Date: Jul 17, 2005
Hi Andrew, Well, your coolant temps are in line...be glad they are not higher. We commonly see temps in the mid to high 180's ...(sometimes hotter) on hot days. The reason your EGTS dropped off is you are operating at a wider throttle setting than before. What is critical is what EGTS are you getting at wide open throttle (WOT).... The midrange EGT ( 5200-5600 rpm) can be easily set by adjusting the jet needle. 900 is a bit low and will result in a build up of carbon in the piston rings. You should aim for 1050-1100 at cruise rpm and 900-1000 at WOT. Quite often the gauges and probes are not that accurate and should only be used as a "relative" (i.e. relative to the last few flights and similar conditions) reading. You might find your coolant temps a bit higher than before (under the same conditions) because you are working the engine just a bit harder to atain the same rpm (coarser pitch on the prop.). You did'nt mention what rpm's you were getting at full throttle and what rpm you were cruising at. Hope this helps Bob Robertson Light Engine Services Ltd. Rotax Service Center St. Albert, Ab. T8N 1M8 Ph: (Tech Support) 1-780-418-4164 Ph: (Order Line) 1-866-418-4164 (TOLL FREE) www.rtx-av-engines.ca ----- Original Message ----- From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> Subject: Kitfox-List: 582 Coolant/EGT Temp > > I re-pitched my prop for better cruise a little while back...hadn't done > much flying until this past week at a fly-in, and now I'm a bit concerned > about temperatures... > > My Coolant Temp mid-day when it was hot and humid was hovering just a hair > under 180 on climb-out and dropped to 170 in cruise. My EGT is now at about > 900-925 in each cylinder at cruise...the previous owner says that these > numbers are fine. Any other opinions (or facts!) > > Thanks a million! > Andrew > > ________________________________________________________________________________
Date: Jul 17, 2005
Well I'm glad my coolant temps are ok, but the EGT's make me nervous with the carboning up issue! The CPS catalog says 930-1200 is normal...I guess I could just re-jet her and lean her out (hasn't been done since last fall, I believe). That oughta help without having to repitch my prop again... Thanks group, Andrew >From: "Bob Robertson" <aerocontrols(at)clearwave.ca> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Re: Kitfox-List: 582 Coolant/EGT Temp >Date: Sun, 17 Jul 2005 15:41:54 -0700 > > > >Hi Andrew, >Well, your coolant temps are in line...be glad they are not higher. We >commonly see temps in the mid to high 180's ...(sometimes hotter) on hot >days. >The reason your EGTS dropped off is you are operating at a wider throttle >setting than before. What is critical is what EGTS are you getting at wide >open throttle (WOT).... The midrange EGT ( 5200-5600 rpm) can be easily set >by adjusting the jet needle. 900 is a bit low and will result in a build >up >of carbon in the piston rings. You should aim for 1050-1100 at cruise rpm >and 900-1000 at WOT. >Quite often the gauges and probes are not that accurate and should only be >used as a "relative" (i.e. relative to the last few flights and similar >conditions) reading. >You might find your coolant temps a bit higher than before (under the same >conditions) because you are working the engine just a bit harder to atain >the same rpm (coarser pitch on the prop.). >You did'nt mention what rpm's you were getting at full throttle and what >rpm >you were cruising at. > >Hope this helps > >Bob Robertson >Light Engine Services Ltd. >Rotax Service Center >St. Albert, Ab. T8N 1M8 >Ph: (Tech Support) 1-780-418-4164 >Ph: (Order Line) 1-866-418-4164 (TOLL FREE) >www.rtx-av-engines.ca > >----- Original Message ----- >From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> >To: >Subject: Kitfox-List: 582 Coolant/EGT Temp > > > > > > > I re-pitched my prop for better cruise a little while back...hadn't done > > much flying until this past week at a fly-in, and now I'm a bit >concerned > > about temperatures... > > > > My Coolant Temp mid-day when it was hot and humid was hovering just a >hair > > under 180 on climb-out and dropped to 170 in cruise. My EGT is now at >about > > 900-925 in each cylinder at cruise...the previous owner says that these > > numbers are fine. Any other opinions (or facts!) > > > > Thanks a million! > > Andrew > > > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Jul 17, 2005
Michel, >Thanks Torgeir but ... just like for "Pell City run.wmv" I can only >hear the sound and the screen remains black. I guess that's the >price I have to pay to work on a Macintosh, using a Netscape >browser. :-( It's not a problem with your computer or your browser, Michel, you just need to download Windoze Media Player for Mac <http://www.microsoft.com/mac/otherproducts/otherproducts.aspx?pid=windowsmedia>. Mike G. N728KF ________________________________________________________________________________
Date: Jul 18, 2005
> From: Michael Gibbs [MichaelGibbs(at)cox.net] > It's not a problem with your computer or your browser, Michel, you > just need to download Windoze Media Player for Mac Thanks Mike but I have Media Player for Mac. I can open some WMV files and see their content. But in the two aforementionned movies, I hear the sound but see nothing, only a black screen. I guess I should have a newer version of the software. But newer versions run only on Mac OS X and I am still on Mac OS 9. And I don't like to be pushed to buy new software when the old one still works fine. ... well, we are getting off-topic here, but ... the computer industry sucks ... in my humble opinion! :-) Cheers, Michel ________________________________________________________________________________
Subject: Kitfox instructor
Date: Jul 18, 2005
From: "Hartin, John" <John.Hartin(at)morganstanley.com>
Just purchased KF 5 looking for instructor near lodi ca John Hartin **** Important Notice to Recipients **** It is important that you do not use e-mail to request, authorize or effect the purchase or sale of any security or commodity, to send fund transfer instructions, or to effect any other transactions. Any such request, orders, or instructions that you send will not be accepted and will not be processed by Morgan Stanley. **************************************** ________________________________________________________________________________
Date: Jul 18, 2005
Subject: Re: [Off-topic] One Six Right
Wonderful video, Michel. Thanks for passign it on! Fred > http://www.onesixright.com/video/aerials.html ________________________________________________________________________________
Date: Jul 18, 2005
Subject: [Off-topic] One Six Right
That is an exellent video....... The music was right also See ya Marwynne -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Fred Shiple Subject: Re: Kitfox-List: [Off-topic] One Six Right Wonderful video, Michel. Thanks for passign it on! Fred > http://www.onesixright.com/video/aerials.html ________________________________________________________________________________
Date: Jul 19, 2005
I just came across a product at an Auto Parts store called WaterWetter... It's supposed to lower coolant temperature in your car by up to 20 degrees by allowing better heat transfer between the block/coolant. It says it can be used with any coolant, water, distilled, etc...Should I give this a try? Even if 180 degrees F on climbout isn't that bad, 165 is even better, right? Andrew >From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com >Subject: Re: Kitfox-List: 582 Coolant/EGT Temp >Date: Sun, 17 Jul 2005 23:06:11 -0400 > > > >Well I'm glad my coolant temps are ok, but the EGT's make me nervous with >the carboning up issue! The CPS catalog says 930-1200 is normal...I guess >I >could just re-jet her and lean her out (hasn't been done since last fall, I >believe). That oughta help without having to repitch my prop again... > >Thanks group, >Andrew > > > >From: "Bob Robertson" <aerocontrols(at)clearwave.ca> > >Reply-To: kitfox-list(at)matronics.com > >To: > >Subject: Re: Kitfox-List: 582 Coolant/EGT Temp > >Date: Sun, 17 Jul 2005 15:41:54 -0700 > > > > > > > >Hi Andrew, > >Well, your coolant temps are in line...be glad they are not higher. We > >commonly see temps in the mid to high 180's ...(sometimes hotter) on hot > >days. > >The reason your EGTS dropped off is you are operating at a wider throttle > >setting than before. What is critical is what EGTS are you getting at >wide > >open throttle (WOT).... The midrange EGT ( 5200-5600 rpm) can be easily >set > >by adjusting the jet needle. 900 is a bit low and will result in a build > >up > >of carbon in the piston rings. You should aim for 1050-1100 at cruise >rpm > >and 900-1000 at WOT. > >Quite often the gauges and probes are not that accurate and should only >be > >used as a "relative" (i.e. relative to the last few flights and similar > >conditions) reading. > >You might find your coolant temps a bit higher than before (under the >same > >conditions) because you are working the engine just a bit harder to atain > >the same rpm (coarser pitch on the prop.). > >You did'nt mention what rpm's you were getting at full throttle and what > >rpm > >you were cruising at. > > > >Hope this helps > > > >Bob Robertson > >Light Engine Services Ltd. > >Rotax Service Center > >St. Albert, Ab. T8N 1M8 > >Ph: (Tech Support) 1-780-418-4164 > >Ph: (Order Line) 1-866-418-4164 (TOLL FREE) > >www.rtx-av-engines.ca > > > >----- Original Message ----- > >From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> > >To: > >Subject: Kitfox-List: 582 Coolant/EGT Temp > > > > > > > > > > > > I re-pitched my prop for better cruise a little while back...hadn't >done > > > much flying until this past week at a fly-in, and now I'm a bit > >concerned > > > about temperatures... > > > > > > My Coolant Temp mid-day when it was hot and humid was hovering just a > >hair > > > under 180 on climb-out and dropped to 170 in cruise. My EGT is now at > >about > > > 900-925 in each cylinder at cruise...the previous owner says that >these > > > numbers are fine. Any other opinions (or facts!) > > > > > > Thanks a million! > > > Andrew > > > > > > > > > > > >http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > ________________________________________________________________________________
Date: Jul 19, 2005
Subject: Re: Fresh air vents??
Sorry I am late on this. I used Van's NACA vents mounted in the lower cowl. They come with plastic eyeball and lots of duct. I did not use the duct. I bought some radiator hose and slip mounted the eyeballs directly onto the outlet of the NACA. They look pretty good and work great. Maxwell Gerns25(at)netscape.net wrote: What are you guys using for fresh air venting in your kitfoxes? I have a pair of the Vista vents to install but I have the LP Aeroplastics bubble doors and there is not an area flat enough to mount them. I have thought of putting them in the skylight but then you have the rain issues. I am in Utah and it can get pretty hot down here especially when sitting in that greenhouse I call 323MM. I don't really like flying with my doors off and I have tried using bungees to hold the door open a couple of inches. Does anyone have a better idea or a differnt vent I can use? I would love to install some adjustable vents in the panel like in certified airplanes but would hate to undertake this project if there was a better option. Any advice or photos of your installation would be appreciated. Thanks, Darin Hawkes Switch to Netscape Internet Service. As low as $9.95 a month -- Sign up today at http://isp.netscape.com/register Netscape. Just the Net You Need. New! Netscape Toolbar for Internet Explorer Search from anywhere on the Web and block those annoying pop-ups. Download now at http://channels.netscape.com/ns/search/install.jsp Maxwell Duke S6/IO240/Phase II Flight Testing --------------------------------- ________________________________________________________________________________
Date: Jul 19, 2005
I tried water wetter and saw little improvement. Still have half a bottle sitting in the hanger Don Smythe Classic IV W/ 582 ----- Original Message ----- From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> Subject: Re: Kitfox-List: 582 Coolant/EGT Temp > > > I just came across a product at an Auto Parts store called WaterWetter... > > It's supposed to lower coolant temperature in your car by up to 20 degrees > by allowing better heat transfer between the block/coolant. It says it > can > be used with any coolant, water, distilled, etc...Should I give this a > try? > Even if 180 degrees F on climbout isn't that bad, 165 is even better, > right? > > Andrew > > >>From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> >>Reply-To: kitfox-list(at)matronics.com >>To: kitfox-list(at)matronics.com >>Subject: Re: Kitfox-List: 582 Coolant/EGT Temp >>Date: Sun, 17 Jul 2005 23:06:11 -0400 >> >> >> >>Well I'm glad my coolant temps are ok, but the EGT's make me nervous with >>the carboning up issue! The CPS catalog says 930-1200 is normal...I guess >>I >>could just re-jet her and lean her out (hasn't been done since last fall, >>I >>believe). That oughta help without having to repitch my prop again... >> >>Thanks group, >>Andrew >> >> >> >From: "Bob Robertson" <aerocontrols(at)clearwave.ca> >> >Reply-To: kitfox-list(at)matronics.com >> >To: >> >Subject: Re: Kitfox-List: 582 Coolant/EGT Temp >> >Date: Sun, 17 Jul 2005 15:41:54 -0700 >> > >> > >> > >> >Hi Andrew, >> >Well, your coolant temps are in line...be glad they are not higher. We >> >commonly see temps in the mid to high 180's ...(sometimes hotter) on >> >hot >> >days. >> >The reason your EGTS dropped off is you are operating at a wider >> >throttle >> >setting than before. What is critical is what EGTS are you getting at >>wide >> >open throttle (WOT).... The midrange EGT ( 5200-5600 rpm) can be easily >>set >> >by adjusting the jet needle. 900 is a bit low and will result in a >> >build >> >up >> >of carbon in the piston rings. You should aim for 1050-1100 at cruise >>rpm >> >and 900-1000 at WOT. >> >Quite often the gauges and probes are not that accurate and should only >>be >> >used as a "relative" (i.e. relative to the last few flights and similar >> >conditions) reading. >> >You might find your coolant temps a bit higher than before (under the >>same >> >conditions) because you are working the engine just a bit harder to >> >atain >> >the same rpm (coarser pitch on the prop.). >> >You did'nt mention what rpm's you were getting at full throttle and what >> >rpm >> >you were cruising at. >> > >> >Hope this helps >> > >> >Bob Robertson >> >Light Engine Services Ltd. >> >Rotax Service Center >> >St. Albert, Ab. T8N 1M8 >> >Ph: (Tech Support) 1-780-418-4164 >> >Ph: (Order Line) 1-866-418-4164 (TOLL FREE) >> >www.rtx-av-engines.ca >> > >> >----- Original Message ----- >> >From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> >> >To: >> >Subject: Kitfox-List: 582 Coolant/EGT Temp >> > >> > >> > >> > > >> > > I re-pitched my prop for better cruise a little while back...hadn't >>done >> > > much flying until this past week at a fly-in, and now I'm a bit >> >concerned >> > > about temperatures... >> > > >> > > My Coolant Temp mid-day when it was hot and humid was hovering just a >> >hair >> > > under 180 on climb-out and dropped to 170 in cruise. My EGT is now >> > > at >> >about >> > > 900-925 in each cylinder at cruise...the previous owner says that >>these >> > > numbers are fine. Any other opinions (or facts!) >> > > >> > > Thanks a million! >> > > Andrew >> > > >> > > >> > >> > >> >>http://search.msn.click-url.com/go/onm00200636ave/direct/01/ >> >> > > > ________________________________________________________________________________
Date: Jul 19, 2005
I don't know the name of the song, nor the name of the album. But I'm 99% certain that the music was composed & performed by Enya. Stu ________________________________________________________________________________
Date: Jul 19, 2005
we're using those little rotating tabs, one on each door in Houston and they are adequate in the air but doors open on the ground. We tinted the overhead. Normally our altitudes are below 2000msl. So far we only had a few 100deg F days. ________________________________________________________________________________
Subject: HKS (582 replacement) engine conversion
Date: Jul 20, 2005
All, Just finished looking at the HKS engine conversion that Green Sky offers for the Kitfox. I've always wondered about this engine being a good replacement for the 582, and apparently it is. And Green Sky is offering details on the install, the engine, and components as needed. Here's the link http://www.greenskyadventures.com/EnginePricing/HKS/kitfox/kitfox_web_brochure.htm For any of you with the two-stroke blues.... Paul Seehafer Central Wisconsin ________________________________________________________________________________
Date: Jul 20, 2005
> From: Paul Seehafer [av8rps(at)tznet.com] > Just finished looking at the HKS engine conversion that Green Sky offers for > the Kitfox. I also looked at that engine when wanting to replace my 582, Paul. But two things made me go for the Jabiru. First, I understand the HKS has a TBO of only 500 hours, vs. 2,000 for the Jabiru. Then I was told that the HKS will deliver less power (climb rate, cruise speed) than the 582. I am not sure about the latter, only a heresay. I know that the HKS is installed, here in Norway, on a Norwegian prototype seaplane called Omsider. I have seen it flying and it looks fine. I also know that the HKS is also installed on the Xair, a lighter than Kitfox aircraft, with success. But the Xair is a no-cowling overhead tractor engine. I am very pleased with my Jabiru but I'd gladly hear from other engines. Cheers, Michel ________________________________________________________________________________
Subject: Re: HKS (582 replacement) engine conversion
Date: Jul 20, 2005
Michel, I really don't know much about the HKS engine other than occassionally seeing one on an airplane or two, and what I read. But since the purpose of this forum is to share information about our airplanes, I thought it was good stuff to let everyone know about. I personally like the 912, but one always should keep his options open. I appreciate your comments in regards to the HKS and the Jabiru. For the just-getting-started guys any good engine information is valuable in helping them to decide what engine to use. Paul ----- Original Message ----- From: "Michel Verheughe" <michel(at)online.no> Subject: SV: Kitfox-List: HKS (582 replacement) engine conversion > >> From: Paul Seehafer [av8rps(at)tznet.com] >> Just finished looking at the HKS engine conversion that Green Sky offers >> for >> the Kitfox. > > I also looked at that engine when wanting to replace my 582, Paul. But two > things made me go for the Jabiru. First, I understand the HKS has a TBO of > only 500 hours, vs. 2,000 for the Jabiru. Then I was told that the HKS > will deliver less power (climb rate, cruise speed) than the 582. I am not > sure about the latter, only a heresay. > I know that the HKS is installed, here in Norway, on a Norwegian prototype > seaplane called Omsider. I have seen it flying and it looks fine. I also > know that the HKS is also installed on the Xair, a lighter than Kitfox > aircraft, with success. But the Xair is a no-cowling overhead tractor > engine. > > I am very pleased with my Jabiru but I'd gladly hear from other engines. > > Cheers, > Michel > > > ________________________________________________________________________________
Subject: IVO Prop Leading edge protective tape
Date: Jul 20, 2005
All, Any of you guys that are running IVO props (particulary the in flight adjustable) have any idea how to keep the metal leading edges from cracking shortly after you install them? Has anyone used plastic tape on theirs? Just need some input on others experience. The stainless leading edges seem to go bad within hours of installation. There must be a better way. I'm thinking that the answer might be some plastic tape like they use on helicopter blades in desert operations where they erode from sand? Paul Seehafer Central Wisconsin ________________________________________________________________________________
Subject: Re: IVO Prop Leading edge protective tape
Date: Jul 20, 2005
I am running a ground adjustable on a 912 UL. Very pleased with the prop, but would like to stop the wrinkling of the stainless steel tape on the leading edge. I am open to any suggestions. Jimmie ----- Original Message ----- From: "Paul Seehafer" <av8rps(at)tznet.com> Subject: Kitfox-List: IVO Prop Leading edge protective tape > > All, > > Any of you guys that are running IVO props (particulary the in flight > adjustable) have any idea how to keep the metal leading edges from cracking > shortly after you install them? Has anyone used plastic tape on theirs? > Just need some input on others experience. The stainless leading edges seem > to go bad within hours of installation. There must be a better way. > > I'm thinking that the answer might be some plastic tape like they use on > helicopter blades in desert operations where they erode from sand? > > Paul Seehafer > Central Wisconsin > > ________________________________________________________________________________
Date: Jul 20, 2005
Subject: headset advice
Does anyone have advice on picking out a headset? I'd like to do it on a budget, but I don't want to buy junk that I'll want to replace in a few months either. I haven't been able to find any real aircraft headset reviews. I just purchased a model IV Speedster, but when it gets here it will not have the headsets included. The hedset will need two jacks, which seems standard on GA plane headsets. Does anyone know where I can find general info on headset as well? For instance I don't know what the difference is between the dual jacks on GA planes and the single jack that I have on my ultralight headset. Thanks for any reply's! Mike Wausau, WI ________________________________________________________________________________
Date: Jul 20, 2005
Hi Mike, I've had very good experience with Lightspeed Active Noise reduction headsets, first with a 15xl, and for the last year with a 30 3G. The 3G is a big improvement over the 15 xl. The Lightspeeds are very comfortable to wear and do a good job keeping out the noise. I use them in a Citabria, which is relatively noisy inside. It's my understanding that the Bose ANR headset is the best -- quietest -- but it is the most expensive as well. I think the two jacks are standard on GA planes. Hope this helps, Bill 70 Citabria GCBC (Flying) Kitfox Model I - 582 (Building) ________________________________________________________________________________
Date: Jul 20, 2005
I haven't said anything just yet.. I have been testing a different leading edge on the in-flight adjustable IVO. So far I have been very pleased.. no wrinkling or splitting. Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Jimmie Blackwell Subject: Re: Kitfox-List: IVO Prop Leading edge protective tape I am running a ground adjustable on a 912 UL. Very pleased with the prop, but would like to stop the wrinkling of the stainless steel tape on the leading edge. I am open to any suggestions. Jimmie ----- Original Message ----- From: "Paul Seehafer" <av8rps(at)tznet.com> Subject: Kitfox-List: IVO Prop Leading edge protective tape > > All, > > Any of you guys that are running IVO props (particulary the in flight > adjustable) have any idea how to keep the metal leading edges from cracking > shortly after you install them? Has anyone used plastic tape on theirs? > Just need some input on others experience. The stainless leading edges seem > to go bad within hours of installation. There must be a better way. > > I'm thinking that the answer might be some plastic tape like they use on > helicopter blades in desert operations where they erode from sand? > > Paul Seehafer > Central Wisconsin > > ________________________________________________________________________________
Date: Jul 20, 2005
Mike, The single jack vs the dual jack is typically helicopter vs aircraft. You will find the dual jack more common. Headsets become a personal choice. Bose are fantastic headsets that are very pricy.. David Clarks (DC's) have always been an excellent headset. Light Speed is a popular choice. DRE-6000 is what I sell and use in our aircraft. If you're looking for a new headset.. spend a little more and go with the noise canceling headsets.. it is worth it. I choose the DRE's because: They were comfortable and the Noise canceling was excellent. For $300 they were tough to beat. Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Mike Ford Subject: Kitfox-List: headset advice Does anyone have advice on picking out a headset? I'd like to do it on a budget, but I don't want to buy junk that I'll want to replace in a few months either. I haven't been able to find any real aircraft headset reviews. I just purchased a model IV Speedster, but when it gets here it will not have the headsets included. The hedset will need two jacks, which seems standard on GA plane headsets. Does anyone know where I can find general info on headset as well? For instance I don't know what the difference is between the dual jacks on GA planes and the single jack that I have on my ultralight headset. Thanks for any reply's! Mike Wausau, WI ________________________________________________________________________________
Date: Jul 20, 2005
Ok John, what's it going to cost me to be your guinnea pig? Sincerely, I would be happy to be part of your test results. I expect to be flying my airplane within two weeks after AirVenture (I run the seaplane base for the EAA and have about two full time jobs right now, not including my regular life :-) Paul Seehafer ----- Original Message ----- From: "jdmcbean" <jdmcbean(at)cableone.net> Subject: RE: Kitfox-List: IVO Prop Leading edge protective tape > > I haven't said anything just yet.. I have been testing a different leading > edge on the in-flight adjustable IVO. So far I have been very pleased.. > no > wrinkling or splitting. > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com > "The Sky is not the Limit... It's a Playground" > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Jimmie > Blackwell > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: IVO Prop Leading edge protective tape > > > > I am running a ground adjustable on a 912 UL. Very pleased with the prop, > but would like to stop the wrinkling of the stainless steel tape on the > leading edge. I am open to any suggestions. > > Jimmie > > ----- Original Message ----- > From: "Paul Seehafer" <av8rps(at)tznet.com> > To: > Subject: Kitfox-List: IVO Prop Leading edge protective tape > > >> >> All, >> >> Any of you guys that are running IVO props (particulary the in flight >> adjustable) have any idea how to keep the metal leading edges from > cracking >> shortly after you install them? Has anyone used plastic tape on theirs? >> Just need some input on others experience. The stainless leading edges > seem >> to go bad within hours of installation. There must be a better way. >> >> I'm thinking that the answer might be some plastic tape like they use on >> helicopter blades in desert operations where they erode from sand? >> >> Paul Seehafer >> Central Wisconsin >> >> > > > ________________________________________________________________________________
Date: Jul 20, 2005
Subject: Re: headset advice
I'm a flight instructor, and I have experience with many headsets. General advice: Your headset is not a conveniennce item; it is a safety item. Your headset protects you from long term hearing loss. In my opinion, aircraft noise is the biggest source of fatigue on long flight, and limiting it keeps you alert and aware longer. It also allows you to better hear ATC instructions that could be critical to your safety. So while you can shop on a budget, you also don't want to skimp. To me there are two critical aspects to consider when purchasing a headset: comfort and noise attenuation. Many of the cheaper headsets use a ridiculous amount of pressure on your head to keep noise out. It may not feel too bad when you try it on, but you'll feel it after an hour long flight. Weight is also part of comfort. I wouldn't wear a headset that weighed more than about 15 ounces. As far as noise attenuation goes, I would recommend spending the money for an active cancelling headset. They are expensive, but you will not regret spending the extra money. I'll give a brief review of the most popular headsets that I've used. David Clark H10-13.4: David Clark is the gold standard for passive attenuating headsets. The H10-13.4 is their most popular. They make a quality product that acheives an acceptable amount of noise attenuation in a light and comfortable headset. If you decide NOT to get an active cancelling set, this is the one I'd recommend. I have not heard terribly good things about the DC active cancelling (ANR) headsets. They basically just crammed an ANR system into their existing sets, and it apparently it doesn't work nearly as well as the headsets that are designed specifically for ANR technology. I haven't used the DC ANR sets, so feel free to take one for a test flight. Discount retailers sell the passive H10-13.4 for about $270. cheap DC knockoffs: There are many many headsets that look like David Clarks with different colored earcups. They range in price from $89-$200. You get what you pay for with these. I use a Softcomm $100 headset as a spare and while it peforms as advertised, it is NOT suitable for long flights or heavy use. The hardware is not the same quality as David Clark, and you will find they clamp your head pretty tight. With heavy use, some of the screws or other hardware will eventually fall out, and you'll have to replace them to have a working headset. these work great as spares of for an OCCAISIONAL passenger. I would not recommend them for your daily use. The Bose: The best headset money can buy is unquestionably the Bose Aviation Heaset X. It is the only aviation headset they sell. It is extremely small, light and undoubtedly the most comfortable headset there is. Its ANR system is the best out there, but bring spare batteries becasue its passive attenuation is not that great. This isn't a flaw; this headset was just not designed to be a passive headset. Its only drawback is the $1000 pricetag. I received mine as a graduation present, and after having put several hundred hours on it, I can honestly say that if I could go back and buy only one headset when I was a student pilot, I wouldn't hesitate to drop a grand on this headset. Compared to other headsets, it's expensive. Compared to the other costs of flying, it's a bargain. Lightspeed: I have owned a 15 and a 20XL. These were my first forays into ANR. Lightspeed designed their headsets exclusively for ANR. The noise cancelling is really good. In fact, it is almost as good as the Bose. They are quite comfortable, although I find that in the Arizona heat, the earseals made me sweat a lot. One thing about these heasets is they are HUGE. Put one of these on and look in the mirror. They easily double the width of your noggin. This isn't any particular concern unless you are in a tight cockpit. If the pilot and passenger of a C-152 both wear one, they will bang the earcups together a few times. My personal experience with lightspeed is that the construction is too cheap to stand up to daily use. when you put the headset on, you can hear the plastic parts squeek together. Two screws fell out of one rendering it useless and the other one had a speaker quit. If you jiggle the wire around, you can get it to work, but move your head too fast and it'll go off again. I still have the 20XL, but it's out of warranty, and I don't want to deal with sending it in for repair. Bottom line: If you can bring yourself to do it, you will not regret spending the money on a Bose when you look back on the decision a few years from now. If you just can't spend that much, (and believe me, I wouldn't have before I owned one.) try to at least get a quality ANR headset. The David Clarks might be better than what I've heard. I'd try them out and compare them to the lightspeeds. Otherwise, the lightspeed is a good headset; just handle them gently. If you aren't going to spring for ANR, get the David Clarks. They will last forever, and if you decide to upgrade, you'll have a great headset for your passengers. Mike Ford wrote: > >Does anyone have advice on picking out a headset? > >I'd like to do it on a budget, but I don't want to buy >junk that I'll want to replace in a few months either. > >I haven't been able to find any real aircraft headset >reviews. > >I just purchased a model IV Speedster, but when it >gets here it will not have the headsets included. The >hedset will need two jacks, which seems standard on GA >plane headsets. > >Does anyone know where I can find general info on >headset as well? For instance I don't know what the >difference is between the dual jacks on GA planes and >the single jack that I have on my ultralight headset. > >Thanks for any reply's! >Mike >Wausau, WI > > > > ________________________________________________________________________________
Date: Jul 20, 2005
Mike, Hear is something else that may help... From Aviation consumer magazine December 2000. I think the cost should have been used as a reference rather then a scoring area because it skews the data. The other info is interesting... http://www.drecomm.com/Aviation%20Consumer%20ANR%20Evaluation1.htm Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of jdmcbean Subject: RE: Kitfox-List: headset advice Mike, The single jack vs the dual jack is typically helicopter vs aircraft. You will find the dual jack more common. Headsets become a personal choice. Bose are fantastic headsets that are very pricy.. David Clarks (DC's) have always been an excellent headset. Light Speed is a popular choice. DRE-6000 is what I sell and use in our aircraft. If you're looking for a new headset.. spend a little more and go with the noise canceling headsets.. it is worth it. I choose the DRE's because: They were comfortable and the Noise canceling was excellent. For $300 they were tough to beat. Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Mike Ford Subject: Kitfox-List: headset advice Does anyone have advice on picking out a headset? I'd like to do it on a budget, but I don't want to buy junk that I'll want to replace in a few months either. I haven't been able to find any real aircraft headset reviews. I just purchased a model IV Speedster, but when it gets here it will not have the headsets included. The hedset will need two jacks, which seems standard on GA plane headsets. Does anyone know where I can find general info on headset as well? For instance I don't know what the difference is between the dual jacks on GA planes and the single jack that I have on my ultralight headset. Thanks for any reply's! Mike Wausau, WI ________________________________________________________________________________
Date: Jul 20, 2005
Mike - Don't know if it's still available but I bought a Lightspeed x-country ANR set a few years ago, new for under $200. That's a budget price for a set then rated as a "best value" by Aviation Consumer. I've used it alot and am pleased with the performance for the price. Marco Menezes Model 2 582 N99KX Mike Ford wrote: Does anyone have advice on picking out a headset? I'd like to do it on a budget, but I don't want to buy junk that I'll want to replace in a few months either. I haven't been able to find any real aircraft headset reviews. I just purchased a model IV Speedster, but when it gets here it will not have the headsets included. The hedset will need two jacks, which seems standard on GA plane headsets. Does anyone know where I can find general info on headset as well? For instance I don't know what the difference is between the dual jacks on GA planes and the single jack that I have on my ultralight headset. Thanks for any reply's! Mike Wausau, WI --------------------------------- ________________________________________________________________________________
Date: Jul 20, 2005
What do you all know about "wireless" headsets? I am forever becoming tangled in those wires! ----- Original Message ----- From: jdmcbean<mailto:jdmcbean(at)cableone.net> To: kitfox-list(at)matronics.com Sent: Wednesday, July 20, 2005 10:44 AM Subject: RE: Kitfox-List: headset advice Mike, Hear is something else that may help... From Aviation consumer magazine December 2000. I think the cost should have been used as a reference rather then a scoring area because it skews the data. The other info is interesting... http://www.drecomm.com/Aviation%20Consumer%20ANR%20Evaluation1.htm> Fly Safe !! John & Debra McBean www.sportplanellc.com<http://www.sportplanellc.com/> "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com<mailto:owner-kitfox-list-server(at)matronics.com> [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of jdmcbean To: kitfox-list(at)matronics.com Subject: RE: Kitfox-List: headset advice Mike, The single jack vs the dual jack is typically helicopter vs aircraft. You will find the dual jack more common. Headsets become a personal choice. Bose are fantastic headsets that are very pricy.. David Clarks (DC's) have always been an excellent headset. Light Speed is a popular choice. DRE-6000 is what I sell and use in our aircraft. If you're looking for a new headset.. spend a little more and go with the noise canceling headsets.. it is worth it. I choose the DRE's because: They were comfortable and the Noise canceling was excellent. For $300 they were tough to beat. Fly Safe !! John & Debra McBean www.sportplanellc.com<http://www.sportplanellc.com/> "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com<mailto:owner-kitfox-list-server(at)matronics.com> [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Mike Ford To: kitfox-list(at)matronics.com Subject: Kitfox-List: headset advice Does anyone have advice on picking out a headset? I'd like to do it on a budget, but I don't want to buy junk that I'll want to replace in a few months either. I haven't been able to find any real aircraft headset reviews. I just purchased a model IV Speedster, but when it gets here it will not have the headsets included. The hedset will need two jacks, which seems standard on GA plane headsets. Does anyone know where I can find general info on headset as well? For instance I don't know what the difference is between the dual jacks on GA planes and the single jack that I have on my ultralight headset. Thanks for any reply's! Mike Wausau, WI ________________________________________________________________________________
Date: Jul 20, 2005
John With that said where can I get some of the material your are using? Jimmie ----- Original Message ----- From: "jdmcbean" <jdmcbean(at)cableone.net> Subject: RE: Kitfox-List: IVO Prop Leading edge protective tape > > I haven't said anything just yet.. I have been testing a different leading > edge on the in-flight adjustable IVO. So far I have been very pleased.. no > wrinkling or splitting. > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com > "The Sky is not the Limit... It's a Playground" > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Jimmie Blackwell > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: IVO Prop Leading edge protective tape > > > I am running a ground adjustable on a 912 UL. Very pleased with the prop, > but would like to stop the wrinkling of the stainless steel tape on the > leading edge. I am open to any suggestions. > > Jimmie > > ----- Original Message ----- > From: "Paul Seehafer" <av8rps(at)tznet.com> > To: > Subject: Kitfox-List: IVO Prop Leading edge protective tape > > > > > > All, > > > > Any of you guys that are running IVO props (particulary the in flight > > adjustable) have any idea how to keep the metal leading edges from > cracking > > shortly after you install them? Has anyone used plastic tape on theirs? > > Just need some input on others experience. The stainless leading edges > seem > > to go bad within hours of installation. There must be a better way. > > > > I'm thinking that the answer might be some plastic tape like they use on > > helicopter blades in desert operations where they erode from sand? > > > > Paul Seehafer > > Central Wisconsin > > > > > > ________________________________________________________________________________
Date: Jul 20, 2005
Mike, Brian has supplied an excellent review. If you get around a group of higher time GA pilots, all of them will have significant hearing loss. As a physician, I know that the damage is cumulative and once the hearing loss is evident it's too late to recover. The only effective strategy is too prevent the loss in the first place. Protect your hearing with the best ANR headphones you can find. I've used Bose for the past 15 years and would use nothing else. They're expensive, but you only have one pair of ears. Fred ________________________________________________________________________________
Subject: Selling my fox
Date: Jul 20, 2005
Howard, so sorry to hear of the forced sale. Hope your luck changes or at least you get what your asking. Take care. Rick N656T -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Howard Firm Subject: Kitfox-List: Selling my fox Due to a bad and getting worse financial situation, My wife and I decided that we need to sell our Fox. This has been a tough decision to make, but it comes down to the last thing I own that is worth anything...I just need to bail myself out and start over. I wanted to offer it here first, but I will be soon listing it on barnstormers, then Ebay as a last resort. Here is what I have; Kitfox model 5 with a NSI Turbo & Warp Drive with CAP New vacuum pump Grove gear & tailspring LP windshield, bubble doors with airvents cabin heater, duel fan New Apollo SL40 VHF Comm New Garmin GTX 320A Transponder professionally wired and installed RC Allen IFR Gyro's Here are two pictures; http://home.mchsi.com/~pianome2/leftside.jpg http://home.mchsi.com/~pianome2/panel4.jpg The engine is currently off of the plane. It is ready to be shipped to NSI for a complete overhaul and the cost is included in the price. Asking $34,500 I can answer any questions you may have, also I can supply any pictures you may want. E-mail me or call me at (218) 749-4659 most evenings I'm home. Howard Firm 508 12th St. South Virginia MN 55792 ________________________________________________________________________________
Date: Jul 20, 2005
Brian, E-mail me at fultz(at)trip.net if you would be interested in getting rid of the 20XL. I like tinkering with broke headsets. Sometimes I'm successful and sometimes I'm not. Andy F. I still have the 20XL, but it's out of warranty, and I don't want to deal with sending it in for repair. ________________________________________________________________________________
Date: Jul 20, 2005
Hi Andrew, Maybe I missed something. Who complained about Jabiru talk on this list? Michel commented that talk about non-jabiru engines on the Jabiru Engines list was discouraged. Talk about alternate engines is currently ok on the Kitfox list. Cheers, bh on the list since 1995 or 1996 > Alright guys - I hate to be the one to say this (is anybody else thinking > it?), but I am finding it hard to understand why lister's here are trying > to > scare away any topic not strictly Kitfox...I agree, this is a kitfox list, > and should therefore be focused primarily on these great birds - BUT we > all > have boat-loads to learn, and not allowing something like "jabiru talk" > here > is taking away a lot from that. Come on guys, really...we're better than > that. > > Andrew >>Hi Michel, >> >>Bear in mind that this list is not run by SkyStar, the Kitfox kit company, >>so there's quite a bit of leeway in topics. Also, back in the 1990s the >>NSI group had to move out due to discussion problems, then allowed back >>years later. And this list is about Kitfox aircraft, so there may not be >>much tolerance for pushing other kits or aircraft. >> >>The Jabiru Engine list is for just that, users of or people interested in >>the Jabiru engines. >> >>Cheers, >>bh ________________________________________________________________________________
Subject: Non Kitfox Topics
Date: Jul 21, 2005
Let me put on my Janitor Hat and just add this to Bruce's comments. I also missed something and was wondering who made any complaints about engine choices. On this list ANY meaningful and informed discussions about alternative engines for the Kitfox are welcome. Rotax is obviously the king of the mountain, but at one point they weren't. The same goes for any other engine choices whether they be Jabiru, NSI, Eggenfellner, VW, Ford Model A, or Weedeater. The people who make those choices all deserve the same respect as those who chose the Rotax. Informed pro/con discussions about any engine choices further enhance both the Kitfox and the experimental movement in general and should never be inhibited by those who think that only "their" choice is the correct one or by passing on unsubstantiated anecdotal gossip for the purpose of stirring the pot. At one point several years ago IVO prop discussions were next to impossible because of a small number of people who hated the prop and refused to allow any positive comments go unanswered. As there were many IVO owners on the list it was frustrating for any meaningful discussions to happen without those with their own personal vendettas to do what they could to cause disruption. As for the case of NSI "having" to move out then being "allowed" back, that isn't exactly how it was. There were some fervent bashers (about anything non-rotax) and the included pilers who made it impossible for Kitfox owners with NSI packages (roughtly 65 of them at the time) to have any discussions so they decided that it would be best at the time to just form a separate list so they could have quiet and meaningful dialog. Since they were primarily Kitfox owners on that list after about a year they decided rejoin the Kitfox List and things have been relatively civil since then. In recap, all discussions and opinions are welcome, whether they be engines, props, radios, instruments, etc. Just keep them civil and respectful, avoid passing on unsubstantiated heresay, and remember that there's room for everybody's choices here, regardless what those choices may be. Regards, Deke Morisse Kitfox List Administrator > Hi Andrew, > Maybe I missed something. Who complained about Jabiru talk on this list? > Michel commented that talk about non-jabiru engines on the Jabiru Engines > list was discouraged. Talk about alternate engines is currently ok on the > Kitfox list. > Cheers, > bh > on the list since 1995 or 1996 > > > Alright guys - I hate to be the one to say this (is anybody else thinking > > it?), but I am finding it hard to understand why lister's here are trying > > to > > scare away any topic not strictly Kitfox...I agree, this is a kitfox list, > > and should therefore be focused primarily on these great birds - BUT we > > all > > have boat-loads to learn, and not allowing something like "jabiru talk" > > here > > is taking away a lot from that. Come on guys, really...we're better than > > that. > > > > Andrew > > >>Hi Michel, > >> > >>Bear in mind that this list is not run by SkyStar, the Kitfox kit company, > >>so there's quite a bit of leeway in topics. Also, back in the 1990s the > >>NSI group had to move out due to discussion problems, then allowed back > >>years later. And this list is about Kitfox aircraft, so there may not be > >>much tolerance for pushing other kits or aircraft. > >> > >>The Jabiru Engine list is for just that, users of or people interested in > >>the Jabiru engines. > >> > >>Cheers, > >>bh > > ________________________________________________________________________________
Date: Jul 21, 2005
Subject: Wanted GSC prop or blades
Hi All, Does anyone have a 68 in. GSC prop with LE inserts, or 3 matching blades for sale ?? Gil Levesque Kitfox 4 " GROUNDED!!!" Still alive and flyin!!!! Gil ________________________________________________________________________________
From: "John Stoner" <john(at)dakotacubaircraft.com>
Date: Jul 21, 2005
Paul, I was advised years ago by Mike Jacober to use penetrating super glue (hobby shop stuff) and very carefully lay a small bead all the way around each of the stainless leading edges. I put over 200 hours on my three blade ground adjustable and never had a problem with the leading edge, except for gravel and ice dings. Regards, John Stoner KitFox III, 582 Alaska All, Any of you guys that are running IVO props (particulary the in flight adjustable) have any idea how to keep the metal leading edges from cracking shortly after you install them? Has anyone used plastic tape on theirs? Just need some input on others experience. The stainless leading edges seem to go bad within hours of installation. There must be a better way. I'm thinking that the answer might be some plastic tape like they use on helicopter blades in desert operations where they erode from sand? Paul Seehafer Central Wisconsin ________________________________________________________________________________
Subject: Re: Wanted GSC prop or blades
Date: Jul 21, 2005
I have a GSC three bladed prop for a 912 UL that I am not using. It will not fit on a 912ULS. Floran H. ----- Original Message ----- From: "Gill Levesque" <canpilot03(at)yahoo.ca> Subject: Kitfox-List: Wanted GSC prop or blades > > Hi All, > > Does anyone have a 68 in. GSC prop with LE inserts, or 3 matching blades > for sale ?? > > Gil Levesque > > Kitfox 4 > " GROUNDED!!!" > > > Still alive and flyin!!!! > > Gil > > > ________________________________________________________________________________
Date: Jul 21, 2005
Brian, Just send them back. It will most likely only cost postage one way. Rick -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Andy Fultz Subject: RE: Kitfox-List: headset advice Brian, E-mail me at fultz(at)trip.net if you would be interested in getting rid of the 20XL. I like tinkering with broke headsets. Sometimes I'm successful and sometimes I'm not. Andy F. I still have the 20XL, but it's out of warranty, and I don't want to deal with sending it in for repair. ________________________________________________________________________________
Date: Jul 21, 2005
I have never had a problem with Lightspeed repairs. I have set three pairs back to them for small repairs. They have never charged me and in fact they have always upgraded older components to the newest parts. #2 behind BOSE. I have 4 pairs in my Saratoga. greg ----- Original Message ----- From: "Rick" <turboflyer(at)comcast.net> Subject: RE: Kitfox-List: headset advice > > Brian, > Just send them back. It will most likely only cost postage one way. > > Rick > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Andy Fultz > To: kitfox-list(at)matronics.com > Subject: RE: Kitfox-List: headset advice > > > Brian, > > E-mail me at fultz(at)trip.net if you would be interested in getting rid of > the 20XL. I like tinkering with broke headsets. Sometimes I'm successful > and sometimes I'm not. > > Andy F. > > I still have the 20XL, but it's out of warranty, and > I don't want to deal with sending it in for repair. > > > ________________________________________________________________________________
From: "Donna and Roger McConnell" <rdmac(at)swbell.net>
Subject: 912S Starting Procedure
Date: Jul 21, 2005
I need some advice from list members. I did a search in the archives and could find nothing on this subject. I thought it had been discussed at one time or another. What is the best or most accepted way for starting this 912 engine? I do not have a primer on this thing and using the choke seems to have no effect. Is it OK to pump the throttle 2 or 3 times before hitting the starter. And should you let the starter turn the engine over a few times before switching on the mags. I am also concern about engine shake at starting and at shut down.....comments Roger Mac ________________________________________________________________________________
Date: Jul 21, 2005
Subject: Re: 912S Starting Procedure
Hello Roger, The 912 choke is not a true choke in the pure sense. It en richens the mixture only when the throttle is completely closed. As you will undoubtedly hear, most 912 owners swear by the addition of a primer, while others crank a few turns with only the choke on (enrichener) and then let her have some spark. John P. Marzluf Columbus, Ohio Outback, (out back in the garage) ________________________________________________________________________________
Date: Jul 21, 2005
John, I'm sorry I didn't know you sold the DRE's. I bought a set and concur...they are an excellent value. They are comfortable, quiet, and appear to live up to their great specs. Tom Tomlin ----- Original Message ----- From: "jdmcbean" <jdmcbean(at)cableone.net> Subject: RE: Kitfox-List: headset advice > > Mike, > The single jack vs the dual jack is typically helicopter vs > aircraft. You > will find the dual jack more common. Headsets become a personal choice. > Bose are fantastic headsets that are very pricy.. David Clarks (DC's) have > always been an excellent headset. Light Speed is a popular choice. > DRE-6000 > is what I sell and use in our aircraft. > > If you're looking for a new headset.. spend a little more and go with the > noise canceling headsets.. it is worth it. I choose the DRE's because: > They were comfortable and the Noise canceling was excellent. For $300 they > were tough to beat. > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com > "The Sky is not the Limit... It's a Playground" > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Mike Ford > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: headset advice > > > Does anyone have advice on picking out a headset? > > I'd like to do it on a budget, but I don't want to buy > junk that I'll want to replace in a few months either. > > I haven't been able to find any real aircraft headset > reviews. > > I just purchased a model IV Speedster, but when it > gets here it will not have the headsets included. The > hedset will need two jacks, which seems standard on GA > plane headsets. > > Does anyone know where I can find general info on > headset as well? For instance I don't know what the > difference is between the dual jacks on GA planes and > the single jack that I have on my ultralight headset. > > Thanks for any reply's! > Mike > Wausau, WI > > > ________________________________________________________________________________
Date: Jul 21, 2005
Roger, I have a 912 on my kitfox and I don't use the primer at all, in fact, I have disconnected it (one less place for a possible leak). I typically don't use the primer either unless the engine in cold. I flip on the mags and give her a crank and that is usually it. If it doesn't turn over on the first rotation or two of the prop, I let off the starter and give it a second or two and then try again. It has started everytime. Keep in mind, I leave the throttle completely closed. I read somewhere that the carbs have what is called a "starting choke" and unless the throttle is at idle, it will not engage. This may not help you but it is how I start my 912. Darin Hawkes N323MM - Model III KITFOXZ(at)aol.com wrote: > >Hello Roger, > >The 912 choke is not a true choke in the pure sense. It en richens the >mixture only when the throttle is completely closed. As you will undoubtedly >hear, most 912 owners swear by the addition of a primer, while others crank a few >turns with only the choke on (enrichener) and then let her have some spark. > >John P. Marzluf >Columbus, Ohio >Outback, (out back in the garage) > > Switch to Netscape Internet Service. As low as $9.95 a month -- Sign up today at http://isp.netscape.com/register Netscape. Just the Net You Need. New! Netscape Toolbar for Internet Explorer Search from anywhere on the Web and block those annoying pop-ups. Download now at http://channels.netscape.com/ns/search/install.jsp ________________________________________________________________________________
Date: Jul 21, 2005
My experience with LightSpeed has been excellent. Send it in for repair, they will provide a fair price and superior quality. Joel ________________________________________________________________________________
Subject: Re: IVO Prop Leading edge protective tapeIVO Prop Leading
edge protective tapeIVO Prop Leading edge protective tape
Date: Jul 21, 2005
John, Would the leading edge tape you're testing be suitable on warp speed blades destined for float operations? Joel ________________________________________________________________________________
Date: Jul 22, 2005
I sent them back 2 pairs of 20K bought 4 years ago, and they replaced the headset battery box assembly, new earseal , headset stirrup ....for free including return shipping. Excellent after-sale service. thomas lee. Vixen 912 UL, 432 hrs. >age posted by: "*" > >I have never had a problem with Lightspeed repairs. I have set three pairs >back to them for small repairs. They have never charged me and in fact they >have always upgraded older components to the newest parts. #2 behind BOSE. >I have 4 pairs in my Saratoga. > >greg > > > > > ________________________________________________________________________________
Date: Jul 22, 2005
Thanks a lot for all of the headset advise. Although I haven't had an opertunity to try any of the suggestions, the DRE-6000 (http://www.drecomm.com/) seems very nice for the money. I think that will be a happy medium for me. I am going to need two headsets (pilot and passanger), so I think I'll just get two of these instead of trying to get something even less expensive for the passanger. Thanks again! I'll write up a quick review after I get a chance to try them out. Mike ________________________________________________________________________________
Date: Jul 22, 2005
Joel, First, I have no hands on experience with warp propellors. I have helped with the replacement of the stainless tape on an IVO. Stripped the old tape off, clean with acetone, fill dings with light weight body filler (bondo type stuff), sand smooth and touch up with glossy black. The new self adhesive stainless tape came from an auto parts store. Cut to shape with scissors, peel and stick on, and then outline with the penetrating super glue (CA from the hobby shop). A few hours over a couple of days and the Prop looked nearly new again. Regards, John Stoner ________________________________________________________________________________
Date: Jul 22, 2005
>What is the best or most accepted way for starting this 912 engine? >I do not have a primer on this thing and using the choke seems to >have no effect. As others have mentioned, the enrichment valve (it's not really a choke) on the 912S does not have any effect unless the throttle is completely closed. Here is what worked well for me: Ignition switches.....OFF Throttle..............IDLE Enrichment valve......PULL Starter...............ENGAGE (crank for 3 - 5 seconds) Starter...............RELEASE Enrichment valve......RELEASE Wait 10 to 20 seconds Ignition switches.....ON Starter...............ENGAGE It looks more complicated than it is and it started right up every time with no vibration. Mike G. N728KF ________________________________________________________________________________
Date: Jul 22, 2005
Subject: Kitfox for Sale - Model III-912UL
I hate to do this but I have some other responsibilities that need attention and unfortunately, the airplane is the lowest on the "important list". What I have is the most well built and cared for Kitfox I have ever seen. It is a model III-Rotax 912UL that has many Classic IV upgrades built in during construction. I have pics along with a spec sheet and a brief history of the plane that I can email to anyone interested. This Kitfox was built through the covering and paint stage by Ed Downs...as many of you know, Ed is the president of Skystar, manufacturer of the Kitfox kits. Obviously he knows how to build a kitfox correctly. If you have read the little blue book "How to Fly a Kitfox", this is the airplane that is referred to in that book as "Spirit". The spec sheet has a full history of the airplane, so I won't say anymore, other than to reitterate that this Kitfox is one of the nicest and best built out there. It was purchased from Ed by a friend here in Salt Lake City and the final assembly was completed. I recently purchased it and really hate to sell it. It is in immaculate condition, always hangered and has no damage history. Asking $26,500...no low ball offers please...however, reasonable offers will be entertained. Please email me at gerns25(at)netscape.net for picture and spec sheet requests. Switch to Netscape Internet Service. As low as $9.95 a month -- Sign up today at http://isp.netscape.com/register Netscape. Just the Net You Need. New! Netscape Toolbar for Internet Explorer Search from anywhere on the Web and block those annoying pop-ups. Download now at http://channels.netscape.com/ns/search/install.jsp ________________________________________________________________________________
Date: Jul 24, 2005
Subject: Windshield on Kitfdox IV
I am rebuilding a Kitfox IV and would like some ideas on the material used for the windshield and how to fit it without breaking. Also how do you adjust the oil injection on a 582 for proper flow Travis ________________________________________________________________________________
Date: Jul 24, 2005
Subject: Re: Windshield on Kitfdox IV
I would use Lexan (a polycarbonate) or PETG which is half Lexan and half Acrylic/ both are "unbreakable" and last 10 years in sunlight. They can be broken/torn with really severe treatment by a high speed drill but it is tough to do. Both can be cold formed in a vise and bent at 170 degree angles. Artists use them for cold and hot forming. Lexan is most expensive but is available in silicon coating for abrasion and chemical resistance, but less easily formed with the coating. Both Lexan and PETG are subject to embrittlement when soaked in gasoline for long. I have heard of but not been able to find unbreakable acrylic. Lexan was used in the F-16 canopy but in a refueld first flight to England they went thru hig cirrus at thirty thousand feet and tit abraded it to an opaque surface and had trouble landing; we then developed the silica coating. ________________________________________________________________________________
Date: Jul 24, 2005
The same works for me Paul Model IV 912UL ----- Original Message ----- From: "Michael Gibbs" <MichaelGibbs(at)cox.net> Subject: Re: Kitfox-List: 912S Starting Procedure > >>What is the best or most accepted way for starting this 912 engine? >>I do not have a primer on this thing and using the choke seems to >>have no effect. > > As others have mentioned, the enrichment valve (it's not really a > choke) on the 912S does not have any effect unless the throttle is > completely closed. Here is what worked well for me: > > Ignition switches.....OFF > Throttle..............IDLE > Enrichment valve......PULL > Starter...............ENGAGE (crank for 3 - 5 seconds) > Starter...............RELEASE > Enrichment valve......RELEASE > Wait 10 to 20 seconds > Ignition switches.....ON > Starter...............ENGAGE > > It looks more complicated than it is and it started right up every > time with no vibration. > > Mike G. > N728KF > > > > > > ________________________________________________________________________________
Date: Jul 25, 2005
A brief comment. I use the DRE 6000 and love them. ATC is crisp and clean and I am wear hearing aids for what it's worth. Lowell ----- Original Message ----- From: "jdmcbean" <jdmcbean(at)cableone.net> Subject: RE: Kitfox-List: headset advice > > Mike, > Hear is something else that may help... From Aviation consumer > magazine > December 2000. I think the cost should have been used as a reference > rather then a scoring area because it skews the data. The other info is > interesting... > http://www.drecomm.com/Aviation%20Consumer%20ANR%20Evaluation1.htm > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com > "The Sky is not the Limit... It's a Playground" > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of jdmcbean > To: kitfox-list(at)matronics.com > Subject: RE: Kitfox-List: headset advice > > > Mike, > The single jack vs the dual jack is typically helicopter vs > aircraft. You > will find the dual jack more common. Headsets become a personal choice. > Bose are fantastic headsets that are very pricy.. David Clarks (DC's) have > always been an excellent headset. Light Speed is a popular choice. > DRE-6000 > is what I sell and use in our aircraft. > > If you're looking for a new headset.. spend a little more and go with the > noise canceling headsets.. it is worth it. I choose the DRE's because: > They were comfortable and the Noise canceling was excellent. For $300 they > were tough to beat. > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com > "The Sky is not the Limit... It's a Playground" > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Mike Ford > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: headset advice > > > Does anyone have advice on picking out a headset? > > I'd like to do it on a budget, but I don't want to buy > junk that I'll want to replace in a few months either. > > I haven't been able to find any real aircraft headset > reviews. > > I just purchased a model IV Speedster, but when it > gets here it will not have the headsets included. The > hedset will need two jacks, which seems standard on GA > plane headsets. > > Does anyone know where I can find general info on > headset as well? For instance I don't know what the > difference is between the dual jacks on GA planes and > the single jack that I have on my ultralight headset. > > Thanks for any reply's! > Mike > Wausau, WI > > > ________________________________________________________________________________
Subject: Re: NGK Iridium BR8EIX Spark plug gap??NGK Iridium BR8EIX
Spark plug gap??
Date: Jul 26, 2005
I have been running NGK BR8EIX Iridium plugs for some time now in my Blue head 582. I can't tell you how many hours exactly because my log book is not here but I'm on my second set. One thing I'd mention is you should be using non resistor caps with them. I find they run much better than BR8ES normal plugs. On the box it says not to regap them. I think this is due to the likelyhood of breaking the very fine centre electrode so I just run them as they are and they are great. Rex. rexjan(at)bigpond.com ________________________________________________________________________________
Spark plug gap??
Date: Jul 25, 2005
Rex, What is the factory gap on these plugs (out of the box)? Don Smythe Classic IV W/ 582 ----- Original Message ----- > I find they run much better than BR8ES normal plugs. On the box it says not > to regap them. I think this is due to the likelyhood of breaking the very > fine centre electrode so I just run them as they are and they are great. > > Rex. > ________________________________________________________________________________
Subject: Iridium Plug Gap
Date: Jul 27, 2005
Rex, What is the factory gap on these plugs (out of the box)? Hi ! Don, I don't actually know. My old plugs and the ones in the plane now are all up at my hanger. I could measure them sometime I suppose but it will be hard on used plugs. Even maybe risky on new plugs. The centre electrode is only 0.6mm and I believe is the reason NGK say not to adjust. For the same reason one would need to be careful just measuring. These plugs also have a taper cut ground electrode. As one will get a better spark from the fine centre electrode one would be able to run a larger gap but as I say I haven't attempted to measured it. I just figured I'd do as instructed and fit them as they were and they are such a great improvement I just continue to use them as they are. Rex. rexjan(at)bigpond.com ________________________________________________________________________________
Subject: 912 UL Ignition Problem
Date: Jul 26, 2005
My 912 UL has the older type ignition coils mounted behind the firewall. Today as I was doing my runup one of the ignition systems was not working. Taxing back to the hangar I noted that sometimes the suspect ignition system functions ok and a minute later it was dead. My thought is a broken wire. Would appreciate any suggestions on where to look. Thanks Jimmie ________________________________________________________________________________
Subject: Vertex Standard VXA 700 Handheld Radio
Date: Jul 26, 2005
Sometime back I purchased a VXA 700 Radio and promised the list that I would share my experiences with this radio. Overall, the radio works very well and I enjoy being able to use it as a aircraft radio, wx radio and ham radio. Anyone contemplating buying one of these radios please contact me off list and I will share some of the ups and downs of this handheld radio. Bottom line is I would buy it again. Jimmie ________________________________________________________________________________
Date: Jul 26, 2005
I love mine as well. 73's de N0QK Blue Skies Aviation Six Chuter Region #4 Flight Center Manager Russell Marsolek 1176 West 5th. St. Winona, MN 55987 Phone 507-452-6888 Email rmarsole(at)luminet.net Web www.hbci.com/~rmarsole/ -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jimmie Blackwell Subject: Kitfox-List: Vertex Standard VXA 700 Handheld Radio Sometime back I purchased a VXA 700 Radio and promised the list that I would share my experiences with this radio. Overall, the radio works very well and I enjoy being able to use it as a aircraft radio, wx radio and ham radio. Anyone contemplating buying one of these radios please contact me off list and I will share some of the ups and downs of this handheld radio. Bottom line is I would buy it again. Jimmie ________________________________________________________________________________
Date: Jul 27, 2005
> From: Russell Marsolek [rmarsole(at)luminet.net] > I love mine as well. I'd love too, to be a flying ham. But ... I never work the two meters band, only CW on the 20 and 40 meters. I can't imagine using my morse keyer while flying! :-) > 73's de N0QK N0QK? Wow, how old are you, Russel? How did you get such a short callsign? 73 de LA0HA (PS: Mine is relatively short too, because there are only 4 millions Norwegians and that LA0 is reserved for the foreigners having a Norwegian license. When I took mine, I was still Belgian citizen.) Michel ________________________________________________________________________________
Date: Jul 27, 2005
Had my callsign for quite a while. I use to be N0QKG till I became an "Extra". Two-Meters in the air is a real blast! RLM / N0QK Blue Skies Aviation Six Chuter Region #4 Flight Center Manager Russell Marsolek 1176 West 5th. St. Winona, MN 55987 Phone 507-452-6888 Email rmarsole(at)luminet.net Web www.hbci.com/~rmarsole/ -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Michel Verheughe Subject: SV: Kitfox-List: Vertex Standard VXA 700 Handheld Radio > From: Russell Marsolek [rmarsole(at)luminet.net] > I love mine as well. I'd love too, to be a flying ham. But ... I never work the two meters band, only CW on the 20 and 40 meters. I can't imagine using my morse keyer while flying! :-) > 73's de N0QK N0QK? Wow, how old are you, Russel? How did you get such a short callsign? 73 de LA0HA (PS: Mine is relatively short too, because there are only 4 millions Norwegians and that LA0 is reserved for the foreigners having a Norwegian license. When I took mine, I was still Belgian citizen.) Michel ________________________________________________________________________________
Date: Jul 27, 2005
Say if we were both at 10,000 what do you think the range would be, without repeaters. Rick N656T KC6ART -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Russell Marsolek Subject: RE: Kitfox-List: Vertex Standard VXA 700 Handheld Radio Had my callsign for quite a while. I use to be N0QKG till I became an "Extra". Two-Meters in the air is a real blast! RLM / N0QK Blue Skies Aviation Six Chuter Region #4 Flight Center Manager Russell Marsolek 1176 West 5th. St. Winona, MN 55987 Phone 507-452-6888 Email rmarsole(at)luminet.net Web www.hbci.com/~rmarsole/ -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Michel Verheughe Subject: SV: Kitfox-List: Vertex Standard VXA 700 Handheld Radio > From: Russell Marsolek [rmarsole(at)luminet.net] > I love mine as well. I'd love too, to be a flying ham. But ... I never work the two meters band, only CW on the 20 and 40 meters. I can't imagine using my morse keyer while flying! :-) > 73's de N0QK N0QK? Wow, how old are you, Russel? How did you get such a short callsign? 73 de LA0HA (PS: Mine is relatively short too, because there are only 4 millions Norwegians and that LA0 is reserved for the foreigners having a Norwegian license. When I took mine, I was still Belgian citizen.) Michel ________________________________________________________________________________
Subject: 13 gal fuel tank
Date: Jul 27, 2005
Hopefully some mkember will be able to help with my problem. I have a Kitfox model 4 and have purchased a 13 gal fuel wing tank. I have a 6 gal tank on the right hand side and want to replace the 6 gal with the 13 gal. I have searched and can't find the tank installation and fastening proceedure. Altho I haven't cut into the wing top, I know that there must be some top rib trimming to make way for the larger tank. I'm not clear on how the tank must be secured and what to do about the much larger, unsupported fabric area which will be on the tank top. I shouldn't think the the fabric would be glued to the top of the fuel tank, but unless there is some sort of support, wouldn't there be a problem with ballooning of the unsupported fabic? Hopfully many of the members have gone thru this proceedure............Otherwise, I may have to lash the tank onto the tail section, or possibly fabricate wings, so that it might be towed. Herb ________________________________________________________________________________
Date: Jul 27, 2005
Not sure but I talked one time on my HT over the Twin Cities and I was able to get Winona (120 miles). I would guess over 100 miles with the Vertex 700 but strictly a guess. RLM Blue Skies Aviation Six Chuter Region #4 Flight Center Manager Russell Marsolek 1176 West 5th. St. Winona, MN 55987 Phone 507-452-6888 Email rmarsole(at)luminet.net Web www.hbci.com/~rmarsole/ -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Rick Subject: RE: Kitfox-List: Vertex Standard VXA 700 Handheld Radio Say if we were both at 10,000 what do you think the range would be, without repeaters. Rick N656T KC6ART -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Russell Marsolek Subject: RE: Kitfox-List: Vertex Standard VXA 700 Handheld Radio Had my callsign for quite a while. I use to be N0QKG till I became an "Extra". Two-Meters in the air is a real blast! RLM / N0QK Blue Skies Aviation Six Chuter Region #4 Flight Center Manager Russell Marsolek 1176 West 5th. St. Winona, MN 55987 Phone 507-452-6888 Email rmarsole(at)luminet.net Web www.hbci.com/~rmarsole/ -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Michel Verheughe Subject: SV: Kitfox-List: Vertex Standard VXA 700 Handheld Radio > From: Russell Marsolek [rmarsole(at)luminet.net] > I love mine as well. I'd love too, to be a flying ham. But ... I never work the two meters band, only CW on the 20 and 40 meters. I can't imagine using my morse keyer while flying! :-) > 73's de N0QK N0QK? Wow, how old are you, Russel? How did you get such a short callsign? 73 de LA0HA (PS: Mine is relatively short too, because there are only 4 millions Norwegians and that LA0 is reserved for the foreigners having a Norwegian license. When I took mine, I was still Belgian citizen.) Michel ________________________________________________________________________________
Subject: Oil Cooler
Date: Jul 27, 2005
Just got a new oil cooler from Lockwood. Hoping that someone may have mounted an oil cooler like the one on page 154 of the Lockwood catalog on a 912. I have some ideas on how to mount it, but would like to see how others have mounted this oil cooler. Jimmie ________________________________________________________________________________
From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com>
Date: Jul 28, 2005
Hello Herb - I have a 13 gallon tank in my KF 3...The in-board fabric is in fact fastened to the fuel tank. This helps ease refueling - you can use it as an elbow rest while you're supporting the jerry-can, and you do not need to worry about the fabric moving/ripping etc... Andrew >From: "Hm Doud" <hmdoud(at)ev1.net> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Kitfox-List: 13 gal fuel tank >Date: Wed, 27 Jul 2005 20:58:52 -0700 > > >Hopefully some mkember will be able to help with my problem. > >I have a Kitfox model 4 and have purchased a 13 gal fuel wing tank. I have >a 6 gal tank on the right hand side and want to replace the 6 gal with the >13 gal. > >I have searched and can't find the tank installation and fastening >proceedure. Altho I haven't cut into the wing top, I know that there must >be some top rib trimming to make way for the larger tank. I'm not clear on >how the tank must be secured and what to do about the much larger, >unsupported fabric area which will be on the tank top. I shouldn't think >the the fabric would be glued to the top of the fuel tank, but unless there >is some sort of support, wouldn't there be a problem with ballooning of the >unsupported fabic? > >Hopfully many of the members have gone thru this >proceedure............Otherwise, I may have to lash the tank onto the tail >section, or possibly fabricate wings, so that it might be towed. > >Herb > > ________________________________________________________________________________
Date: Jul 28, 2005
Subject: Re: Dead List
In houston we've been flying 2 hrs daily with noon temps of 94F lately and 102 a couple of weeks ago. With only small eyelids in the door panels it's ok in flight and doors open on ground, but putting it away and gassing up in steel hangars is dehydrating and that's leaving the doors open while we're out. ________________________________________________________________________________
Date: Jul 28, 2005
At 05:14 PM 7/27/2005, you wrote: > >Is all this heat causing everyone to sit in a cool room and vegetate? Was >a blistering 102 in Eastern Virginia today (PHF). Some of us are working hard in spite of the heat. (95F here most days. I have to work mornings/evenings or fry.) I had a great day yesterday. The degausser I rented from Sacramento Sky Ranch came in, and since I had it for only a week I decided I'd better get to it. Well, it ended up taking only a few hours, most of that time spent pulling the panel so I wouldn't fry it. (I already had the engine out to do firewall work.) The actual degauss probably only took 15 minutes. I went from having my compass locked to a heading about 100 degrees off, to having it move a maximum of 10 degrees as I moved it around it's mounting area. It's nice to have something work well for a change. (Yes, I've been having some fun lately.) I'll keep the degausser for the full week, just in case things tend to revert to their previous state, but with the frame demagnetized I'm cut loose to put the engine back in, get it fully hooked up and maybe run it. Who knows, maybe by this time next year I'll be flying! Woohoo! Guy Buchanan K-IV 1200 / 582 / 99% done, thanks to Bob Ducar. ________________________________________________________________________________
Subject: Oil Cooler
Date: Jul 28, 2005
Jimmie, Wish I would have known you were looking for an Oil Cooler... I sell a very nice and effective oil cooler it also has some low profile fittings. Give me a shout on mounting.... May be able to help. Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Jimmie Blackwell Subject: Kitfox-List: Oil Cooler Just got a new oil cooler from Lockwood. Hoping that someone may have mounted an oil cooler like the one on page 154 of the Lockwood catalog on a 912. I have some ideas on how to mount it, but would like to see how others have mounted this oil cooler. Jimmie ________________________________________________________________________________
Subject: Speed fairings
Date: Jul 28, 2005
Hi We have jsut recently seen some jury struts that were all metal (or very well modified!) with speed fairings. does anyone know where one can get these already made or speed fairings for the Jury struts and the horiz stab support bars. We have recently cleaned up a series 7 with; wheel spats speed fairings on : wing spars, jury struts, petrol tank filler caps & horizantal stab this has resulted in a 15 knot increase in speed at same power settings! OR same speed and greatly reduced power settings. Harry Tucker PO Box 2830, White River 1240 South Africa Tel ++ 27 13 751 5018 Fax:++ 27 11 507 5339 Cell + 27 083 45 28824 Skype: harrytucker Email: harry(at)htucker.com DISCLAIMER Internet communications are not secure and therefore Jt's Europe Ltd does not accept legal responsibility for the contents of this message. If you are not the intended recipient please notify the sender immediately and do not disclose the contents to any third party. Any views or opinions expressed are those of the author, and do not necessarily represent those of Jt's Europe Ltd. Although Jt's Europe Ltd believes this email and any attachments are free of any virus or other defect which may affect a computer, it is the responsibility of the recipient to ensure that it is virus-free and Jt's Europe Ltd does not accept any responsibility for any loss or damage arising in any way from its use. --- Rekar Ltd Monkhurst House, Sandy Cross Heathfield, East Sussex, TN21 8QR Phone: 01435 860100 ________________________________________________________________________________
Subject: Ivo prop - In flight adjustable Medium Prop
Date: Jul 28, 2005
Hi We have been using these on all our planes but we get a lot of problems with them. Brushes wearing out, planetary drives breaking after 10 hours, electric motors stopping due to grease getting to "hard". Please remember we fly some 300 to 1000 hours per year! Does anyone know of a good reliable in flight adjustable prop that does not cost an arm and a leg and does not wiegh too much thanks Harry Tucker PO Box 2830, White River 1240 South Africa Tel ++ 27 13 751 5018 Fax:++ 27 11 507 5339 Cell + 27 083 45 28824 Skype: harrytucker Email: harry(at)htucker.com DISCLAIMER Internet communications are not secure and therefore Jt's Europe Ltd does not accept legal responsibility for the contents of this message. If you are not the intended recipient please notify the sender immediately and do not disclose the contents to any third party. Any views or opinions expressed are those of the author, and do not necessarily represent those of Jt's Europe Ltd. Although Jt's Europe Ltd believes this email and any attachments are free of any virus or other defect which may affect a computer, it is the responsibility of the recipient to ensure that it is virus-free and Jt's Europe Ltd does not accept any responsibility for any loss or damage arising in any way from its use. --- Rekar Ltd Monkhurst House, Sandy Cross Heathfield, East Sussex, TN21 8QR Phone: 01435 860100 ________________________________________________________________________________
Date: Jul 28, 2005
Harry, You may want to take a look at operating procedures... I have been operating the in-flight IVO for several hundred hours without interruption. We also have a large group that is operating them. I have not had any issues with the grease getting hard... However, the motor brushes can sometimes carbon up.. this is easily fixed. How many planes do you have operating them and how are they being used ?? Sounds like your in a training environment... I know of 5 of us that are flying in excess of 300 hours a year (which is a hell of a lot of flying) using IVO without those issues. Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Harry Tucker Subject: Kitfox-List: Ivo prop - In flight adjustable Medium Prop Hi We have been using these on all our planes but we get a lot of problems with them. Brushes wearing out, planetary drives breaking after 10 hours, electric motors stopping due to grease getting to "hard". Please remember we fly some 300 to 1000 hours per year! Does anyone know of a good reliable in flight adjustable prop that does not cost an arm and a leg and does not wiegh too much thanks Harry Tucker PO Box 2830, White River 1240 South Africa Tel ++ 27 13 751 5018 Fax:++ 27 11 507 5339 Cell + 27 083 45 28824 Skype: harrytucker Email: harry(at)htucker.com DISCLAIMER Internet communications are not secure and therefore Jt's Europe Ltd does not accept legal responsibility for the contents of this message. If you are not the intended recipient please notify the sender immediately and do not disclose the contents to any third party. Any views or opinions expressed are those of the author, and do not necessarily represent those of Jt's Europe Ltd. Although Jt's Europe Ltd believes this email and any attachments are free of any virus or other defect which may affect a computer, it is the responsibility of the recipient to ensure that it is virus-free and Jt's Europe Ltd does not accept any responsibility for any loss or damage arising in any way from its use. --- Rekar Ltd Monkhurst House, Sandy Cross Heathfield, East Sussex, TN21 8QR Phone: 01435 860100 ________________________________________________________________________________
Date: Jul 28, 2005
Subject: Re: Impression of KF IV on wheels
I have found it easier and simpler to wheel land with full flaps than three point on a KF V. It has a Subaru 135hp engine. We are operating it with a forward cg and have difficulty getting full stick travel with our big bellies. Have been considering another 5lb of lead in the tail or straightening out the stick for more back travel. Every one who has flown it finds it real touchy in three point attitudes. ________________________________________________________________________________
Subject: Kit fox trailer
Date: Jul 28, 2005
I have a Kitfox clasic VI that is almost ready to fly and I was thinking about modifying a trailer to haul it on. Does any one out there tow their fox forward? I always see aircraft being towed backward. ________________________________________________________________________________
Date: Jul 28, 2005
Subject: Re: Kit fox trailer I have one fully enclosed if interested...
In a message dated 7/28/2005 6:27:07 PM Central Daylight Time, kirkhull(at)sbcglobal.net writes: I have a Kitfox clasic VI that is almost ready to fly and I was thinking about modifying a trailer to haul it on. Does any one out there tow their fox forward? I always see aircraft being towed backward. ________________________________________________________________________________
Subject: Oil Cooler
Date: Jul 28, 2005
A possible place for my oil cooler is to attach it to the back of the gear box on my 912 which would mean it would be higher than the pictures I found on Sportflight. I have seen one installation like this. Anyone know of any particular problem with mounting the cooler above the engine? Jimmie ________________________________________________________________________________
Date: Jul 28, 2005
From: Paul Wilson <pwilson(at)climber.org> if interested...
if interested... For an enclosed trailer its just a mater of balance. I would think engine forward would be best. Paul ================= At 05:28 PM 7/28/2005, you wrote: > > >In a message dated 7/28/2005 6:27:07 PM Central Daylight Time, >kirkhull(at)sbcglobal.net writes: > >I have a Kitfox clasic VI that is almost ready to fly and I was thinking >about modifying a trailer to haul it on. Does any one out there tow their >fox forward? I always see aircraft being towed backward. > > ________________________________________________________________________________
Date: Jul 28, 2005
Subject: Re: Speed fairings
The lift struts I have examined were all builder fabricated. Just make ribs and fold some .013Al flashing around the ribs and epoxy/rivet together. The ribs can be made from thin plywood or rigid foam. The jury struts I have examined were builder made from a dowel or balsa wood and covered with fabric. I bet some body putty/filler was used for smoothing. The ones I saw showed excellent quality. Paul ========== At 01:53 PM 7/28/2005, you wrote: > >Hi > >We have jsut recently seen some jury struts that were all metal (or very >well modified!) with speed fairings. >does anyone know where one can get these already made or speed fairings >for the Jury struts and the horiz stab support bars. > >We have recently cleaned up a series 7 with; >wheel spats >speed fairings on : wing spars, jury struts, petrol tank filler caps & >horizantal stab > >this has resulted in a 15 knot increase in speed at same power settings! >OR same speed and greatly reduced power settings. > > >Harry Tucker >PO Box 2830, White River 1240 South Africa >Tel ++ 27 13 751 5018 Fax:++ 27 11 507 5339 >Cell + 27 083 45 28824 >Skype: harrytucker >Email: harry(at)htucker.com > > > DISCLAIMER >Internet communications are not secure and therefore Jt's Europe Ltd >does not accept legal responsibility for the contents of this message. >If you are not the intended recipient please notify the sender immediately >and do not disclose the contents to any third party. Any views or opinions >expressed are those of the author, and do not necessarily represent those >of Jt's Europe Ltd. Although Jt's Europe Ltd believes this email and >any attachments are free of any virus or other defect which may affect >a computer, it is the responsibility of the recipient to ensure that it >is virus-free and Jt's Europe Ltd does not accept any responsibility >for any loss or damage arising in any way from its use. > > >--- >Rekar Ltd >Monkhurst House, Sandy Cross >Heathfield, East Sussex, TN21 8QR >Phone: 01435 860100 > > ________________________________________________________________________________
Subject: Re: Oil Cooler
Date: Jul 28, 2005
Hi, Jimmy, I have never seen one mounted there, but it seems to be a reasonable location as, in my experience, the coolers are quite efficient and some flow restriction for the cooling air is the norm. My thought is, if it fits give it a try and see if it works. The only downside I can think of is the length of the oil line hoses. Lowell. ----- Original Message ----- From: "Jimmie Blackwell" <jablackwell(at)ev1.net> Subject: Kitfox-List: Oil Cooler > > > A possible place for my oil cooler is to attach it to the back of the gear > box on my 912 which would mean it would be higher than the pictures I > found on Sportflight. I have seen one installation like this. > > Anyone know of any particular problem with mounting the cooler above the > engine? > > Jimmie > > > ________________________________________________________________________________
Date: Jul 28, 2005
I made mine by fabricating a mold of wood, waxed it well and used some PVA mold release and layed a couple of layers of light weight glass cloth in epoxy. Popped them off the mold (three pieces per side) and glued them in place, finishing the ends and joints with Micro. If you decide to go this route. Tweak the jury struts to fit closely before finisheng. I did on one side and forgot to on the other side and when stretching the jury strut to fit, it cracked the fairing at the bottim of the "N". Lowell ----- Original Message ----- From: "Paul Wilson" <pwilson(at)climber.org> Subject: Re: Kitfox-List: Speed fairings > > The lift struts I have examined were all builder fabricated. Just make > ribs and fold some .013Al flashing around the ribs and epoxy/rivet > together. The ribs can be made from thin plywood or rigid foam. > The jury struts I have examined were builder made from a dowel or balsa > wood and covered with fabric. I bet some body putty/filler was used for > smoothing. > The ones I saw showed excellent quality. > Paul > ========== > At 01:53 PM 7/28/2005, you wrote: >> >>Hi >> >>We have jsut recently seen some jury struts that were all metal (or very >>well modified!) with speed fairings. >>does anyone know where one can get these already made or speed fairings >>for the Jury struts and the horiz stab support bars. >> >>We have recently cleaned up a series 7 with; >>wheel spats >>speed fairings on : wing spars, jury struts, petrol tank filler caps & >>horizantal stab >> >>this has resulted in a 15 knot increase in speed at same power settings! >>OR same speed and greatly reduced power settings. >> >> >>Harry Tucker >>PO Box 2830, White River 1240 South Africa >>Tel ++ 27 13 751 5018 Fax:++ 27 11 507 5339 >>Cell + 27 083 45 28824 >>Skype: harrytucker >>Email: harry(at)htucker.com >> >> >> DISCLAIMER >>Internet communications are not secure and therefore Jt's Europe Ltd >>does not accept legal responsibility for the contents of this message. >>If you are not the intended recipient please notify the sender immediately >>and do not disclose the contents to any third party. Any views or opinions >>expressed are those of the author, and do not necessarily represent those >>of Jt's Europe Ltd. Although Jt's Europe Ltd believes this email and >>any attachments are free of any virus or other defect which may affect >>a computer, it is the responsibility of the recipient to ensure that it >>is virus-free and Jt's Europe Ltd does not accept any responsibility >>for any loss or damage arising in any way from its use. >> >> >>--- >>Rekar Ltd >>Monkhurst House, Sandy Cross >>Heathfield, East Sussex, TN21 8QR >>Phone: 01435 860100 >> >> > > > ________________________________________________________________________________
Date: Jul 28, 2005
Subject: Re: Speed fairings Just finished adding last week
I simply bought Balsa wood from Balsa USA carved the airfoil shape... then glassed with 4 oz .... 3 coats of primer the one coat of spray.... Looks great...;-) Dave KF 2 582 BH ________________________________________________________________________________
Subject: Kit fox trailer I have one fully enclosed if interested...
Date: Jul 28, 2005
I have the remains ( frame ) of an old pop up trailer and was hoping to turn it into a plane trailer. as you said , weight and ballance if better with the enging forward but with all of the open trailers I have seen the aircraft is towed backward. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Paul Wilson if interested... Subject: Re: Kitfox-List: Kit fox trailer I have one fully enclosed if interested... interested... For an enclosed trailer its just a mater of balance. I would think engine forward would be best. Paul ================= At 05:28 PM 7/28/2005, you wrote: > > >In a message dated 7/28/2005 6:27:07 PM Central Daylight Time, >kirkhull(at)sbcglobal.net writes: > >I have a Kitfox clasic VI that is almost ready to fly and I was thinking >about modifying a trailer to haul it on. Does any one out there tow their >fox forward? I always see aircraft being towed backward. > > ________________________________________________________________________________
Date: Jul 28, 2005
Years ago over the San Juan Islands of Washington State I was operating 2 meters and heard a familiar call, W7GEN, so I replied. Dennis lived in Bremerton at the time so I thought nothing of it until he told me he was mobile eastbound from Portland Oregon on Highway 84, a distance of at least 160 miles from my position. On another occasion I served as a simplex repeater during a SET exercise, doing 360's at 4000' over the middle of the county. It would have been a lot easier if I had someone else to handle the radio traffic while I was flying! Joel N7CGZ (gear in storage) Model 5 912 GTA CS prop Aerocomp amphibs ________________________________________________________________________________
Subject: Re: Kitfox 1 for sale
Date: Jul 29, 2005
> > I am, going to sell my Kit Fox 1 It has about 60 hrs, Mosler.1835 engine 9.5 gal gas tank registration number N503JH. $ 13500.00 with trailer will deliver eastern USA If interested email me off list or call me at 336-465-1059 EMAIL plane6013(at)earthlink.net Randy > > > > > > ________________________________________________________________________________
Date: Jul 29, 2005
Subject: Model IV Speedster offered for sale
List, I have my subject aircraft listed on the www.Barnstormers.com web site. Anyone interested please take a look. Regards, Norm ________________________________________________________________________________
Date: Jul 29, 2005
From: "Harris, Robert" <Robert_Harris(at)intuit.com>
Subject: Pulling Kitfox up Trailer Ramps Date: Fri, 29 Jul 2005 09:47:13 -0700 Pulling Kitfox up Trailer Ramps-- Where can I attach my winch cable so I can pull my KF onto a trailer? Is the tail spring a good place or will that damage the tail spring? Robert KF V ________________________________________________________________________________
Subject: New Member and question
Date: Jul 29, 2005
Just got back to work on my model IV after having been in storage for over a year. Had career and financial problems that brought every thing to a halt. It feels good getting back to work on N434DM. I'm about 65 to 70% complete and I'm currently covering the wings. I do have one question for the list, what is the best seal between the cowling and the windscreen, can't seem to find much information about it. Thanks Dan Mc Intyre Kitfox model IV, Jab 2200, N434DM ________________________________________________________________________________
Date: Jul 29, 2005
Subject: Rubber channelRE: Kitfox-List: New Member and question Date: Fri, 29 Jul 2005 10:26:09 -0700 Look on page 127 of the Aircraft Spruce book or go on line and type in part number 05-01300. I just ordered a foot of this from ACS and looks like it should work well. I saw this type of rubber channel on another KF a few weeks ago. Robert -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dan McIntyre Subject: Kitfox-List: New Member and question Just got back to work on my model IV after having been in storage for over a year. Had career and financial problems that brought every thing to a halt. It feels good getting back to work on N434DM. I'm about 65 to 70% complete and I'm currently covering the wings. I do have one question for the list, what is the best seal between the cowling and the windscreen, can't seem to find much information about it. Thanks Dan Mc Intyre Kitfox model IV, Jab 2200, N434DM ________________________________________________________________________________
Date: Jul 29, 2005
Subject: Fwd: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] & They Need Our
Prayers yourgypsyqueen(at)yahoo.com Note: forwarded message attached. Authentication-Results: mta206.mail.mud.yahoo.com from=police.massena.ny.us; domainkeys=neutral (no sig) (Vircom SMTPRS 4.1.361.21) with SMTP id ; From: "Sgt. Anthony M. Fiacco" <afiacco(at)police.massena.ny.us> "st pierre" , "Smith, Todd" , "Patty Shirley" , "Proulx, Gary" , "Metruck, Bruce" , "Livernois_Steven" , "Lebire, Mike" , "Kyriakopoulos, Effie" , "ken cornell" , "James, Michele" , "al huckle" , "Firnstein, Eric" , "Fiacco, Augustus M" , "Melissa Dishaw" , "Dillon" , "Cynthia Brock" , "shannon Boisvert" , "Blair, Thomas E." , "clark baker" Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] & They Need Our Prayers Date: Fri, 29 Jul 2005 14:51:07 -0400 type="multipart/alternative"; ----- Original Message ----- From: Kim & Hattie Bashaw Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] & They Need Our Prayers ----- Original Message ----- From: ML Bashaw Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] & They Need Our Prayers ----- Original Message ----- From: cappiello Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] & They Need Our Prayers ----- Original Message ----- From: Gary Schneider Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] & They Need Our Prayers This has been checked for virus and is clean!! Takes awhile to download but please take the time to wait watch and listen as i believe God is great and Still In all our Hearts! Please America pass this along and honor our fallen and know they are Blessed so that we might be a better America!! God Bless our Service Men & Women now and forever!! Send this to all you know and be proud! When I came home from Viet Nam there were no flags so that much we have learned from the past!! Love a vet and honor all of them!! God keep all who are serving now in your Glory!! God Bless!! Gary S Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] & They Need Our Prayers What follows is a message from Vicki Pierce about her nephew James' funeral (he was serving our country in Iraq): "I'm back, it was certainly a quick trip, but I have to also say it was one of the most amazing experiences of my life. There is a lot to be said for growing up in a small town in Texas. The service itself was impressive with wonderful flowers and sprays, a portrait of James, his uniform and boots, his awards and ribbons. There was lots of military brass and an eloquent (though inappropriately longwinded) Baptist preacher. There were easily 1000 people at the service, filling the church sanctuary as well as the fellowship hall and spilling out into the parking lot. However, the most incredible thing was what happened following the service on the way to the cemetery. We went to our cars and drove to the cemetery escorted by at least 10 police cars with lights flashing and some other emergency vehicles, with Texas Rangers handling traffic. Everyone on the road who was not in the procession, pulled over, got out of their cars, and stood silently and respectfully, some put their hands over their hearts. When we turned off the highway suddenly there were teenage boys along both sides of the street about every 20 feet or so, all holding large American flags on long flag poles, and again with their hands on their hearts. We thought at first it was the Boy Scouts or 4H club or something, but it continued .... for two and a half miles. Hundreds of young people, standing silently on the side of the road with flags. At one point we passed an elementary school, and all the children were outside, shoulder to shoulder holding flags ... kindergartners, handicapped, teachers, staff, everyone. Some held signs of love and support. Then came teenage girls and younger boys, all holding flags. Then adults. Then families. All standing silently on the side of the road. No one spoke, not even the very young children. The military presence..at least two generals, a fist full of colonels, and representatives from every branch of the service, plus the color guard which attended James, and some who served with him ... was very impressive and respectful, but the love and pride from this community who had lost one of their own was the most amazing thing I've ever been privileged to witness. I've attached some pictures, some are blurry (we were moving), but you can get a small idea of what this was like. Thanks so much for all the prayers and support." These photos are awesome!! ups1.jpg ------------------------------------------------ flag2.jpg ------------------------------------------------ flag3.jpg ------------------------------------------------ flag4.jpg ------------------------------------------------ flag5.jpg ------------------------------------------------ flag6.jpg ------------------------------------------------ flag7.jpg ------------------------------------------------ flag8.jpg ------------------------------------------------ road1.jpg ------------------------------------------------ road2.jpg ------------------------------------------------ flag1.jpg THIS IS ONE OF THE MOST MOVING E-MAILS I'VE SEEN TO DATE. GO USA and GOD BLESS ALL OF OUR SOLDIERS! They Need Our Prayers Prayer chain for our Military...please don't break it Please send this on after a short prayer. Prayer for our soldiers...please don't break it Prayer "Lord, hold our troops in your loving hands. Protect them as they protect us. Bless them and their families for the selfless acts they perform for us in our time of need. I ask this in the name of Jesus, our Lord and Savior. Amen." Prayer Request: When you receive this, please stop for a moment and say a prayer for our troops around the world. There is nothing attached.... .. Just send this to all the people in your address book. Do not let it stop with you, please.... Of all the gifts you could give a US Soldier, Sailor, Airman, Marine &others deployed in harm's way, Prayer is the very best one! ----- Original Message ----- From: <A titlehbashaw(at)twcny.rr.com ">Kim Hattie Bashaw ">afiacco(at)police.massena.ny.us ; alove(at)police.massena.ny.us ; csweet(at)police.massena.ny.us ; Gerald B Ware ; Jack Rappa ; jfurnace(at)police.massena.ny.us ; jholmes(at)police.massena.ny.us ; jolson(at)police.massena.ny.us ; klabarge(at)police.massena.ny.us ; Marilyn Clopman ; menglert(at)police.massena.ny.us ; Michelle Daley ; Mike Stewart ; modonnell(at)police.massena.ny.us ; mike sullivan ; NSF_Angel(at)hotmail.com ; titlepatrick.obrien@mesa-air.com ">Pat Obrien ; pserguson(at)police.massena.ny.us ; Scott Rogers ; titlecline69_@excite.com ">Shane Cline ; tammy williams ; travis macdonald ; wlashomb(at)police.massena.ny.us Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] They Need Our Prayers ----- Original Message ----- From: <A titlemlbashaw(at)localnet.com ">ML Bashaw ">Todd Bashaw ; Kim Hattie Bashaw ; Brenda Brue Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] They Need Our Prayers ----- Original Message ----- From: <A titlekcappiel(at)twcny.rr.com ">cappiello ">len demarse ; Steve Savage ; bob sova ; Deb and Greg Demarse ; beverly cappiello ; andy cappiello ; rich white ; Kathy Evans Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] They Need Our Prayers ----- Original Message ----- From: <A titlegawelika(at)igalaxy.net ">Gary Schneider ">johncindy ; john c ; JJ Ogborn ; jim johnson ; Jill Lorenz ; Jennifer Steve Faulk ; jackiemacdon(at)yahoo.com ; Jackie/Greg Glenn ; j starr ; j seip ; Holly McGiffney ; gcarson Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] They Need Our Prayers This has been checked for virus and is clean!! Takes awhile to download but please take the time to wait watch and listen as i believe God is great and Still In all our Hearts! Please America pass this along and honor our fallen and know they are Blessed so that we might be a better America!! God Bless our Service Men Women now and forever!! Send this to all you know and be proud! When I came home from Viet Nam there were no flags so that much we have learned from the past!! Love a vet and honor all of them!! God keep all who are serving now in your Glory!! God Bless!! Gary S Subject: Fw: SOLDIER'S FUNERAL (TEXAS STYLE] They Need Our Prayers
style"WIDTH: 100%; mso-cellspacing: 0in; mso-padding-alt: 0in 0in 0in 0in" cellSpacing0 cellPadding0 width"100%" border0>
001d01c5946e$7a990810$1000000a@massena.gov" volume-600 loopinfinite>
000e01c5946e$7a944d20$1000000a@massena.gov" width68 INCREDIIMAGEATTRIBS"mod_EDIANIM,6397D386-9F0D-46280AF4D-547BC6E01B17,texas_fl_md_clr.imi,Image,My Collection,My Collection,texas_fl_md_clr,TEXAS_~3.GIF,," INCREDIIMAGEEXTENSIONS"mod_EDIANIMEXTENSIONS,124,SU1CTDEsNDYsgUmBSZmVxZ0olcGZTcU4gShNiZmRwYEkOIkoTY2JnTA0mSyBhTCFnUmBSYFJgSxJTUJMMiwwLCxJTUJMMywwLCxUeXBlVmVyc2lvbiwzLDEuMCw">
000f01c5946e$7a96be20$1000000a@massena.gov" width58 INCREDIIMAGEATTRIBS"mod_EDIANIM,E7D958A8-B595-496C094B0-7649A1780AFD,flagmem.imi,Image,My Collection,My Collection,flagmem,FLAGMEM.GIF,," INCREDIIMAGEEXTENSIONS"mod_EDIANIMEXTENSIONS,124,SU1CTDEsNDYsgUmBSSydKMWNwSTBTTCNxY1NicWZNIHFiTCBTZ2ZicUkhZ3BgSQ4KEmBSYFJgSxJTUJMMiwwLCxJTUJMMywwLCxUeXBlVmVyc2lvbiwzLDEuMCw">
001001c5946e$7a96be20$1000000a@massena.gov" width73 INCREDIIMAGEATTRIBS"mod_EDIANIM,56B787E3-8409-46B90AF78-EB2DC5F4B592,aniGif.imi,Image,My Collection,My Collection,aniGif,ANIGIF.GIF,," INCREDIIMAGEEXTENSIONS"mod_EDIANIMEXTENSIONS,124,SU1CTDEsNDYsgUmBSY2ZMJ3BnSyVTcGJgcVNiZkwxYEkOJ3BTSwwkSg0jTiJMI3FkUmBSYFJgSxJTUJMMiwwLCxJTUJMMywwLCxUeXBlVmVyc2lvbiwzLDEuMCw">
001101c5946e$7a96be20$1000000a@massena.gov" width640>
001201c5946e$7a96be20$1000000a@massena.gov" width640>
001301c5946e$7a96be20$1000000a@massena.gov" width640>
001401c5946e$7a96be20$1000000a@massena.gov" width640>
001501c5946e$7a96be20$1000000a@massena.gov" width640>
001601c5946e$7a96be20$1000000a@massena.gov" width640>
001701c5946e$7a96be20$1000000a@massena.gov" width640>
001801c5946e$7a96be20$1000000a@massena.gov" width640>
001901c5946e$7a96be20$1000000a@massena.gov" width640>
001a01c5946e$7a96be20$1000000a@massena.gov" width640>
001b01c5946e$7a96be20$1000000a@massena.gov" width640>
GO USA andGOD BLESS ALL OF OUR SOLDIERS!
They Need Our Prayers style"WIDTH: 100%; mso-cellspacing: 0in; mso-padding-alt: 0in 0in 0in 0in" cellSpacing0 cellPadding0 width"100%" border0> 001c01c5946e$7a96be20$1000000a@massena.gov" alignbaseline border0>
Prayer
Of all the gifts you could give a US Soldier, Sailor, Airman, Marine others
aligncenter> aligncenter> http://www2.incredimail.com/contents/stamps/imstp_emo_en.gif" alignbaseline border0> Checked by AVG Anti-Virus. 7/28/2005 name="ATT0000311.gif" R0lGODlhRAAyAIQAAfz7/Ore79nZ9NbV1//R0fijo6KhoqOj06WMWpd1SrWEKcaMIZVqGnNSEIQ5 QkoxWjU1RisrdgAAbwQEiQAAUwQALzQAGGsDBKABAfQBAedRUWloaVVVqwQFBgAAAAAAACH/C05F VFNDQVBFMi4wAwEAAAAh+QQJDwAdACwAAAAARAAyAAQF/mAnJkoinmiqrmzrusnCNOZr37itMDOT /8AcgqFoKILIpGoQMGweymiS6YRKrznqE8u1aa3d8LK5gUjOaAllzY5IInCOODtwmtNqtv486U8i AIEAAQEDAyobGwaGh0pad2l6bGh+fQKCmAB1iYmLmYKEjTebkGeSa5SVEwefgweciQOts6CGKmSl eZKplRyfhU6cnrTEdSmkeKdpqhO+mMCww8Szmym4kcp8zBMBmJuwTNOzZEt22Hu8qpeB0MLd4r9O K8hou+mqrIPfnbLwmYUbWNAzhU7bNlbtOB1450/QgIAsrhGctGxbM33B+DX0ZsDFQHsGt3FImGjh xkDV/lp8pDghJDMOhjIq6rcxwKsXK1FJOMBBgsWWEfbNZNjwoQ2JutAMOPATqAGZ0orKw2kuz5s4 3ThYPBMBariaU6mWqdfVECF2obS25JrRAYICcAkQIErroYNRVSmoeWNSkAC1fdA8cODgwgUMGDIo XqxYgwa4Bea+q+MAA96xptCMBBWhUj0Lhg0nZky69GIMhy17yZuG1QGTTP3UC53atG3GqBNfzsW3 Z5+FautRoD36tu3cjVdj1svHpdZIFUIjNn5c9GLlvCt6JhjdOnXTyK+Lze6TGTbQtb+TRn2YsYbx eLTLFo5+unrc7UnDZ76sfGDh3eV3n2LsFSeeSlXFkeefT9h0Z9+AGRRomkcJ4qFKgw4aqJ6EEyKI WXwthXgOaA8OyGFp7wlUoXbJrFEBiRp+d2KHKyDVn4gAviigid7ZlmI5H1rIIIbp8diAC45lENGK lAw5UQXDlbjhBVEM1F98LlYwWAuOaWDaXVHYKCQeEcwBBC5wmGkmLmqqyWabc7wJZxhyzslFnXZe gWeeSAAAIfkECQ8AHQAsAAAAAEQAMgAEBf5gJyZKIp5oqq5s67rJwjTma9+4rTAzk//AHIKhaCiC yKRqEDBsHspokumESq856hPLtWmt3fCyuYFIzuhzJEKJQN7rNUeMGwyc5jSawu/z0RMAgoMAAXYs GwaHSQdkeXoSfn2AEwOEl4N3G5sbB5iChgM3jpCRkn9nExOen5lOnAYBra2hKaSQpxSUExyzhQec iZa+viiaj2m5uxGzhq+brMStoie3yae7qrKfmrDb0phNKNZ72BKq6KufZLDD4Jfixnh6ytm84d2b se/wTrbz1yTZu3cpnzB+l4AtAXim3rl06PoF2+AOIYABG1aQcwgRnYBBzoIpsijoDotjAf5RDVQV zeBIkmRYbPRjIEKqjixBufyG0N9JhgIPcLiJs1fIdiQvZmxhjU8cDnY4rMF5b8CBZ4l4vjPpAmXD CIkO2PkmgANECRyObnCQQEOBtwQIgIvpoqlTRQFklaUaQZODC4AxZBhMmLAGtwXifsPoBWgfqHkB HKAaKQMGwIELa96sGYODxmXK6VLEgVUEnBIsYLiMWTDn14Qv3/Bqqk1NNQcmn03NOjPs37JB55mU ZsK50+nQqMZ8wfVvzpcxzAZaivIZC8ydP98ceHroSOCLo26IvfV26M0zjKKux3qk7NrPW86sQXhD SO7fm5dfOPrg+i/cogt+He1RQWvxnYnHmnP2lfLQbg0d6Bt/g/lHmA2kDEhgcg1RUF56FM4H4n8v 0NZegeWUt1qI8yVYIkPVcWhKBSqyuKAGmr343YboXCPhiiEGB4QjGp5onHEG/pjgdtIhYWJxD/pY wWc2HIYjYVQiQc6J56SxBh05OBIBmGQ6QmaZeJwJpplqisFmm128CScWcs6ZBAAh+QQJDwAdACwA AAAARAAyAAQF/mAnJkoinmiqrmzrusnCNOZr37itMDOT/8AcgtdQBI9I1SBg2DySUOSy+Yxac1Pn dWvLQrhglldCLpMnkog68mirN4fwbWyuU+6V/F3CAfj/fgEEAy4GBlJMGxB1dnh6FHyAkpMBB00b GwYBlAOEL4mLjGR3FHkVe5GTqgADl5kDq6oBKqCio46kZBGxkq2YmLC8qim1tqSnqBITwoEDv5mb zJLETaGMpKW5yhPBvL6YBt3Sf54ivtaN2JBnEwfC38DjlCjF6dhlE/l9sZXP4fKSZp04J0pdsnwT dq0KAG+DOIBM6FW7ZhAfwgnRJjXUBPBPpRQE7WnbhvBhoAP+/kyOc0ZNkciDF9txcgUnI8BWSiaa wfYgwjqSCPcB2mhTXiJaOstgM8DBTMyEARsu6QjgaE6XOyFFMKSGA4enGIfS/EeV5Yp6ZDgYMtQp gICvT7sNsITJgQMNBfISILDykJikEu5sNXCgU1OwEwzsHWTA7oULGDJInjxZA94CewFZPQuYlNrC ASIgnuBgMgYMjyFHpsy6NeULLkLeomBIbaXRF0ynhuy6N2sML2STirChTIQBcJ8+kHw69Wnf0FEH 7wzpJzuwyzOgdg49uo1695yOXt788fPurjE46JI0vEWwgbXvXo2+Nezv7ZNdh0+hvPn6rUnHHlaB 6QdUTGRYm7DdfwCyBtkNxVRn3YEXJbggbw3qBtyA1ky4X4UWOkdfg9ttOB2BBo5WhgXzZahhBhDq ZOCH+SjFInculpiBBhyOIgpiSs03IoCo3WVZjz7WAV+QOLp4Xw4R/viUUhTMZ5kGJD6Jg2yMLDlK BResh8OVltkVBEEeUogGGmrIEaMiEbgp5zlyyglKnW7SiWcYeu7JRZ9+XgFooEgAACH5BAkPAB0A LAAAAABEADIABAX+YCcmSiKeaKqubOu6ycI05mvfuK0wM5P/wByCoWgogsikahAwbB7KaJLphEqv OeoTy7VpId0w6yspmyeSySTCfkQ2T7jBIPYOnBCzfi+hUCqAFQ8GTACGhgGJA3UdZHx8foEVHIWH lpeId3BwA5eKL5p5j3qRgRSUAZiqmU5wB6mrhixNG6KjfaUVfhuwsZeacr2+K6G3uH+mEhzCvgC0 cp3NhosptLaPfsi6FMrShwEDmxuV3kt4t9nIfmUc3s7AGwbMzdQn1uil2WUR7vCE7pZSFBuVbRu3 MhO8BTgg7hXAQ/U63MOWTh9CAc3AtYoX7SGAiAMhVTyYZsIBXxr+xXX0GADFRJHpzqhpFwucOHke IaIIScrPA4slJ9BUlXLTyod3XJ4T+WADUDVqYsHb4DBnE4FLe1KIx4ZNUDUYMRXlmNOZk2pZ2c1Z a+AABzRQ1ZzEBMyBAw0aCuglQKDfBnO1+LxhG0EmVA57+aZ0cOEChgyQI0vGm9jSVcDXjrE1DPWB 5MgYGjd+/Lm06QwYHBBLi4uDAQ7jOHyFKqE0htCjT+uWfGEM610R/EQ4gDCuGtuiHe/ejaEFz2Pr OMf9fFs06eWmQztPO1KPcajXUScPj11y8+2BzVTc812NA9C4lZe3rRr9tfXS414APX5+6d4u8BST d+1N4Blq8cmf5x9kqYHC3YCzGXdgguTNp52D6UFHUnHteVaddQuCVp8LL+HHYXsUiAdiiJABiKEt EJ5oXB8q5sbihS+qF11+cfXxoY0hXjBigFkBxSMaElhAIYuoDUlkhriwV2AZSopmF15YalCei14U uaGMtFEZmpM2ZAlESDt2pSYbanRlBSO+1RLBm3B2EUqdjNyJpxh67mknHn6G0WegVwxKKBIAACH5 BAkPAB0ALAAAAABEADIABAX+YCcmSiKeaKqubOu6ycI05mvfuK0wM5P/wByCoWgogsikahAwbB7K aJLphEqvOeoTy7Vprd3wsrmBSM5oyWQdaUc4YqTWnD5P1PgzhVLpPzYGTACDgwEBA3FzdXh3dXt9 FRuAA4SVloQBAgNOkgcBlQEvZHR1d416fJCTn5ethAOSgKygLptli7gSqX0QBp6uwLaSlK2ILLak aKdoj5APgbPAlcIbxK4to7mOu5GC0pZkkgbRrcdOybnNfRQc3t+FsOLWwSvZ2rrqexzk39Tz0iuQ 3cMHqYK+d9M4yUI4SIU9bfkoSODAEECAA7GqVQRg7IRAiPnOUGRIzcDGhij+HuLak2rPmQgkFQY6 CSDFx5UPWrpUg/BQxl8nO3ZQ6WhDBIM71fC7VHLpO6E3HUUwkLONsgn/LoUbRnMQ1HN1OBw4YKBs rDRrDkg7xMmBAw0aCsglQKDnARRR0ZQ1m1OinQkP4MadS5ftBgcXMGDIwLhxY7iEowkdCnYRBUBl k66ZEMGx5wyKL4he/Ln0Zw0ObFZexImqXzWbTTPGIDoxadmyMaROuZoZBw573lyNbTr0aNzILyzp jSYCy9ewN9/2TLv2dOTU6zHH9xzt5gkOShtPjL34btW30jxnOXzzA/G1yZf/jIEFUe5Jo2/uTL26 /PmO6WZOesys19539MWcdx2Ayg2IznrQfUdcY+MtOJ+ADm7D3oHSBagggB7WwpyBHK5xW4UWYodh hgV2VyJ4FPqXInK0vRAViX9JuMYFFH4I4mznsYjKhjnq+B5oMs6IW4MiEohfKTqucaR/QZ4gGG4r tnAjkUVK+F5oVcZBGYHdtcGBG2ee6UYEgdUg5nJlvPFmIufMKSYydtJZRp5i4MlnF37+icUogkoB ACH5BAkPAB0ALAAAAABEADIABAX+YCcmSiKeaKqubOu6ycI05mvfuK0wM5P/wByCoWgogsikahAw bDbKaJLpfEivP+rGiu2+tBCvmAWWmM+SiTrC5nDGyDL6rK5P0BRK5fHcGAYAgQABAQMDYnJzdmp4 ehV9fwGCk5SDhYcifoCYLk0bEHN0do0Vj34HkpWqggEHfYCBNp6goYx3pBUQT3+rvQADkKkANgNO tLW3Z3mOfJG+qsW7wrGdxrVp2MqOjwa8z5TRmpUBLtHHaMna25rT355PsJXVn6Fm6RJ5paV/8d+B wNJ6tTBXL9QyfRCc+fvnRFwvTilmXZuTrxSFB0wWBnq3AdUzMtYKqtNHgUPGhYX+IPUTqEKiSDMV K+Th0O5ZuA0re5FLQVAkm5gza+ps6EfoqpYhC3LYsC2PBA4aU+7K6WvniZ4FuzWl8FTjTQNGWZ5w eYbDgQEHDnR7AsFpV3+tnjhwoKFugbsEwlK7mvRMhD9qjS07k6FwXQ13CxBYTGgAAgcXLmAoTLly BruK8/5DgXWO2bUyudqzTJoyhsiSS6u2rAEF2Tlrnwwevdr06ciTa69uzZdeqL8R8jAVnWZC7tq3 U+ve7bqvX3zL3BZ3oBtD8uPLSfN0rm62vQkXqqPGnr0yhu2+KUaXXkcC8uvlSWNwEJE79PWi1CAf Tz7+efTndMeeHatZN158ls2WtwR36w1YR3+FJaccgoVdsEJnMDWYnxrUyQcfhRGClJ6AxBVXR3jy oTYhgqeJGOB93i1yR2nXQbjcfyu8BmOMi7iX4IcUtuiiQdGhI2OKB4KoIAs6arhhHT9GRh8Lh61m 4UDO4WfkItidNiUcIjSZBxsRuMDBYXWBidQnZKo5hjlugjlLnHDASacYc97phZ16YpFnn0oAACH5 BAkPAB0ALAAAAABEADIABAX+YCcmSiKeaKqubOu6ycI05mvfuK0wM5P/wByCoWgogsikahAwbDbK aJLpfEivP+rGiu2+tFyveNncQCQSCnotmbgjEc4YqT2n2W23fr+mPJ5PBgMAhAABAwNeiE52eGt7 en0UgE8HAYWYmQGHKlA2ZRBqjpCRaBQUFZSCmaytZRsGNwOMjo+QbKcQgIKXrb6EB4GJn4yieKS4 qH+Vvb+tA4CDwy6zZrV5fKaoqcLNzpjVGweFNtWhtdmSFdwGlt+s4QbNxNajE3nJ67qwTO+Yr6sK BfhCC909PKfW/eHlD1w0VgTrsblHMd86YQ0LxfNGroU5dG0QbkvFMOOrDYP+nnkseMxRwnUVDARs eGiXs5US0XHQBhNCyYbxUv5iAQqkBA4D0oys8GCmv5NCf01D8XEimwMDIrxU2I8mtEAcfa2ouoaD AAGIFjFaRwFpWKlOHDjQQFdDgQIECIQdmILsI6yHZhmAAJPChQyIE9e9i1cvgGoOLmBITJky3bsE VBSthXQRYbaGK4sWjeGC5NGoEWvoyxIP0gMyHxSWYCH16NKmJ9sezTrnowE7/ciucErCg92VcetG Xrl3IzZwlG4rnoY5YtynrVN2fk3bdFERtCvXXnn1Cb8iE54yZh37cvIZzItAnwzV+kftTWeHH59q 6/TrieLGe6i5x19i3F2NEyB1aExA4G36Pdhegi4tKKAbDuxm4IEZXEAhgPc1OMFxtm3IHwZL/Odd gLZMEF5q2O0Hn4cpbAYig3uUGCGHKGqmonQhiugGjCbOONaPFrY4YIGm2VDXbQ6sYKMkC06kh4QZ YBDlHB1MKUkEYXCJBChwwCGmGKCcyWWaao7BZptevAknFnLOKUWddgYBACH5BAkPAB0ALAAAAABE ADIABAX+YCcmSiKeaKqubOu6ycI05mvfuK0wM5P/wByC11AEj0jVIGDYbJJQ5LL5iFp/0031yn1l Id0w6yuRUM7nsmTCjnA44iDZnFZP1uy8fhIxNJ1OBgEAAAEBA1xzFGZqZXuPEn2AgQOElpeWh4hA A00QZYuNj5CRkxsGS5iqq0xPL62foI14o2xmD6aCq7uZTTedG5+horV3oLmVvLsBB06/nrJ2tKRn k6iDyqqHgc/Bs47FahQV1snZmMCo3bGzd6PiFBCA1+eYrRsHAevf03viFbgCYatH6J4ufV6gtetn C9S4eakIFhpAyZINYOykkaJTgZyTfBIJAcM3cFMLjAv+beVpdKaCvFMRCRocSCihN1G03Bjj6PIU SInbnJizZHIFypQTDgzY2RIgTJrnRupS5eKoHT2GODjsSM7Az3qG/qBadlKho3yGBIg84InrqQIE CEikuKGBAw14NRSAKxdA2ZuO1hwoaKhT0woYMGRYzDgD3r18+3ZycEFx48uOWcD6xoaDoUMGDiPG TPoyhguoLZderMGoWTyCJxoe19GC6tWYT1fG3dg1YDsRmEWIFJorBQu8SevenTxzCqvuIg13SLvC 8eamU2NfrOR1dKZNzyDfnmH57eTdf6/5dlg8+fLaybdGAX09eNppxmM3/z7Dc+/shbfIA+Tpdh52 /92StNNOdIyDhgQE7ocac+8lmBGDDTo4zHbL9ccdfWZh2KB1dUggYXz9WYgTS2jUwcaJFFaIwmbr zdLig440x5+H/oH4G4M3ujjBgblN6MBdeXGYAo0iBnkVkY0ldgEOSV7mgIr8BBlKHg7wdlocR2GI RgRxQAFLBGiSWWYYGK25ZptugulJnHIGQ6cYcN7JBSx6WgEAIfkECQ8AHQAsAAAAAEQAMgAEBf5g JyZKIp5oqq5s67rJwjTma9+4rTAzk//AHILXUASPSNUgYNhsklDksvmIWn9T53Vry1a54FUWIilT zudyeTKJRDhh4FiNRqvZ+PyEExgMmk5OBksBfQNWfk1kZnVqEnp6HAABB4CCAwCZmpuTfkBMG4sS jY6QeXx/gYIBnK2ufQYGLaCLpHemeBypqoOuvpugLqmidqW4ExIRlbxLv7/BLrR0FI5ruGURlqvO vpRPL8Nm1damahGqG73crgNaL9LUacblow/oBqzrnKk34ePkkOjYC6ROnyZQ38ApEjeO3igK6JoZ zOQtXT9F1P45HFWB2URN7dIFuBjqH0A80/4gEJQ4cRemQwpLZjR2IAJKOhVUXvo4CZABTTakaZxA 6ebDCgMH5Wu5LVOXhfP2ZOJQjUKFjjs/ulwKs4W/NQeWUhxw4ACHM1edJDBQgAABg6AuYNCQQYOG AgViQpiJ7UCrAVStXpWLIYPhw4bt4nXLdYODC4gPa4gGdZxfkMjQVrBAOLLnzxguyP2cQVjlUqz6 TIpwtEJn0rBDjyY9mYXQanwOINN1VrBrDIVhk5YdnLTX02o4IHMUQXMF4MKHiy4Om8XXUo8cOX9O Pfph4t6tIzfZ+mp37xnAoxczfk1V3xbOe1cfXsn45dp9b5YvXDZk9HXZVxJ501xVAQUWAIuIGH3r pXCdSWgYiKCChvnHH20OtveehBNSyCB6tZ3w4D/OnZGgghZSaFiGA5IX4YHUnAigfyquiMKI7wmW xgMohuaAAyjYRVd0LIoCoW87ongBkDgIeViRBNYBoxsPCDlkbExecRuJFETwRRxBDOOGG2CGMUyZ ZdKCJphnrmmmIm6+GUqcYKhJZxQAACH5BAkPAB0ALAAAAABEADIABAX+YCcmSiKeaKqubOu6ycI0 5mvfuK0wM5P/wByCoWgogsikahAwbDbKaJLpfEivP+oTy7Vprd3wSguRmM2UtNocaUc44mxzUz6r 72fJZM/nAAABAQMDBiJPTweBg1KDTnV2eGd8kxN/lgEHh08GAZaef4o/c493a5KUewOXhJoGqp+w sIFOK6N5pXmofAegrJqvscGWrGOOkKanurwAvoecwtBzLLZokWa6fYAHTs7A0LK0LKykyNfYExyC 3IeJ38GZLuPHFHl65xzNm97uw1DxxtXo5TonIUI+V534eSL2jw6keucmsFm3KaFCUOEa1klTz5yu ia32KYTnBSAaiNj+zjzQtOHZxT8DtpR0WK7ggY9nWLp6CdNJIRvUOkrgFQGVHZbtXs7ZMOCGPAkC 97TpNIASpJA8mVV0atJmIE8BBAgYwMFOBU0IChBYq5CQAwwZMmiYCUHgGYOwyEKqcKEv3LiA42rQ UKAwW1CZLvzNALSrpE83b1Gw4Hdx4MuYM2BQHJiuUD/MBACKsLcv58yoAW8+LfjF03oDDhRFJ+DA scqpU6+2HNe1I7vXSPPRw0Fimgp8FfPOrdov5rktXkPUQ30vZQzLmWt2nlmjUHsSJVpXrh3zbtTQ iznsGL56tQqTWZePez51dMeS3L/ni31+4ProiYMfdeIdgxx5/m2NJx9qAq7HXkfHIddfggpmd1l6 KEiXH4QUwFfBhP7tZuFl6j3yoIESUljhfCUKVeBe8FkwImqrLZgahiJo+J0aHspI4WYOrDCYBt2l oKNQPMY4o3kYNAAEjh0cyWGHFETgzwlDEpkZBkFeEdR3UFUZBxLjtDHmmOOceeYoaqLpSJtxpAln GGzO2UWddkYBACH+UkNyZWF0ZWQgQnkgRWNsaXBzZSBEaWdpdGFsIEltYWdpbmcgZm9yIFhvb20g U29mdHdhcmUsIEluYy4NCkNvcHlyaWdodCAxOTk3AVVTU1BDTVQAOw== name="ATT0000922.gif" R0lGODlhOgBkAPcAAAAAAC0TFAwsDCssFRsYKzQPLDAvMUoeEmgaClItFmo1HVIIOkwzNnIwKyRV JGdGKzQ0T18sUDtLS0pOUXJTTVFqT29pVU5PZ25Qa1pmaW9ucKEqFuYuC6JLMvBRKpYYYNYlZpZo XudrUSCdLjauRlCMU0qzVVuYYmuKa1m4ZGaybqmJcPKPbXRziKYdmdUbqqRbludatfgC1nuEiqSe m+2wmrrGu/nNtrq6ztPR0OvVzfvl1d7e4v748gAAAP///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH5BAEAAD8ALAAAAAA6AGQA AAj+AH8IHEiwoMGDCBMqXMiwocOHECNKnEixosWLGDNq3MjRYAgKHTWG6PAgZMYQCQaYzPggwEqM DxK8vBgT5EyKMQ1MMABhQgEIDAoIZcAAw82DMRlc6KkBAoQWBHQScGqAQYSjA3NC0DABwoWuXZ2G xXBhgwcOR3N+BesUggGdTrmGaMChroeZOZtu7VpBbM8JGJxiEHHWrgiTSQX75SkBQoUMEy5caNFj R43CddFyfKDgR9OucHkSmNBVMo0WOXqoriEi84YGG2MK5Aohg1gDjZ22kIwhRA3Vq0VsQEAcNszO P/xS7elVg2SnG0SIqLFDdY65xBFs0FxR9o/IpCX+7Ax7Qa/kEB7Si2BRgwYNDRSIb+dwFydyDXrD Nl+6VIN7y+lxsAEFIWhQIAXz2TWRd8kxt5NjT03QQlMX0KCaZR00gEADFBjo3w4sYFbfQ5wN9BcE uUWAnwYZtOCUb9XVEAJnxRGYWmUhZjYiQyUKRFZPb+3mHHi7mbUeDQc2oABxHVAHHIiYHcajTAK5 NyENOdAg2W5aZoDBCh5ssIECHR5IQXrp/fZkjlIu1KMOPWRJQw1wxnnaV17pUEMHxCnAYYE29HBD iGkCh+OOCfXoQQdizucBC3W+Z2B7HynZJwvVqTYomk6u1lBMFvywaAchsMACYXZh2gMNw3GIHwX+ FCjQQZqZHkqrap8qUIGeOdxo6Kb00YBCrBuWScOm6al6IaGP1vBpAhbooGcN1N6wQ609yEicBfBp qIAImUKZ7A1rqpdrAqPOiqZ67LUHH3Ed0kCostmiyQK5mrbppgIHNLrdupi1SqAGs6p6w7jA1TAv nTrQ4JCSCphKbbU73GAxtTM+QJwH5F7mQXXiqikooR+RqMAE0tZpKHANe0gtrTsU2sO8me6JAEQK KPDAxDyb6vNIDTTQJMghggugqpdxIMIKIYQQUUwHdKAumpkJ+NpHHdDHnqa0HuwBnSEs6XREOj/Q tEQIAyiCnkoSSFGsoVo0rmUbmG3B2BORZBP+RumFYEGse09EwQOBZ0RBAyE4XFGsJU0EAwb4IYW3 4AowQNFbb2kQUgc6X4655h3FavlEmBsAOkcdJNC4RKWfvtHgq0fEwOebPzC6RG5lHhLjnuveUdix Q9R6SDPeHtEAtP/+QPAGtfDWe7NXVfr0mDMwQUXFL0TDAA68R/1b0VN/PUUZa+8AAAMI8P304euE Pb8LaeBA+sgbIED962M+/kQzqnRQBbOpgAPOVwHuOaB08+PK9PYnkbAdACEWEAAKJlABCzjgAQJ4 gAN+8JYBDECDzLNI/xJiAQBksCgDAEB0IoA5AQDgfAJxQAkw4kCEDNACEZjAACoQAhiAwGn+BhiA /ABgAAckboM0fID/DHIAAERwgAL5AAa6hz4LVuABFuBeCBsIv4MIYAIPuGJR5vcDBlAgAOkTAAUi IAAHSGdyFVHAEgtyveuBgFRZfEBrPECBAjCgAgB0ARwt0sWCaAAAL4CBdFjwgwq8QAYvEE4CNsCA ABzgLS8AZEYS8ECDTIACL3DBBx5ouUe+IAIfWMABomaUDVIgAcaxyAM6WZArIs4CE4CBQFqzgQC4 IAIRWAAeC+DDN9JkjgMhEOEakAAZOLNSAQBAAQLQgBz+4AOQzNrZ4khLgmgulyGQwQd06TQXohEA AKhjDEAgA1QuQJfcZAgAzCZADgIgAPj+XIALXAADs32gAeNcgCy7iZAd/mCDJQAgOgOwAApgU2qz wwAACUklhQCSgRwsgEMDQMEwVgAALCFoQoK4v7egD6QTQCJGKVLIhiDxOxooYjonGhuROkQCr9Ik BTeigIoyhIH42QlJBbAZm9qQION5ywYHsNLu+FQhJ3BABVNKmphyr40DlGoFTnACpyZEBSowgQkk MMAROKCNFWihCQWA1aw6QAIVKAEKyPbUH6ggBWIlgVkdMIIRsJWtbnXhX/+61wHGdYYkemoK8GoC Esyvr30dIFvX6tfBAnavEoBrCTKggof0lCB3zWtZIbtXwGK1jZHtq15JQAKxmiAFnU117ETvutgS ZJa1eiVtavkKWdyy1rWvBevTDtBVgYA1oSUAbmN9y9zW/la5sI3t0xJAU4Fk4ASLXaxyt7vd7Ao3 jtBCCFhpm93ymveu34VJeLFCV/ZKhEHudchn42sy+nq2rvZFyDbzy9/++ve/AA6wgAcckoAAADs name="ATT0001233.gif" R0lGODlhSQBCAPcAAAAAAAUFBQkJCQwMDB0cGAAAICAeGD8AACQiGionHigoJzw7Oj8/PwAAQAQE QwwMSRQUTwAAYA4OaTYwfzs1fj44fT8/ez8/f18AAH4AAH4AIEI7fH4AQH8/Z38/f0REREpKSkdA fUpCe1RLe2lpaX9/fwAAgAUFggkJhA0NhhAQhxERiBUViBgXiB4chhkYiBoZjBwaiB0ciB4ejiAe hiEfiCQihCMijSklgy0pgi0rjCMjkCsrkzEtgTAwgzUwgDQxijk0gDo3iz87iTQykzIymTw6kjk5 nDw7mj89mD4+nkI+i0I/kUZBhkRAjkxFhUlFjU9JhEVCkkRDmUhGl0hGmk5Ll1VNhFFMjFBNk1FO mVpSg1lTilZTmVtWkFxXmF1alV9bmENDoUpKpVNTqVtbrWBYgmJbiWJclWBdnmBgh2pijGRgnWxn m29vl25pnHNslXNunXZwm3p0nGlor29vr2NjsWtrtX9/p3Fws3BwuHV1un58tnl4uX59uX5+vr0A AL0AE74/P4ADQoIIRoQLSIYRTIwfUI0kUJczZZo6Z74/U75/f/0AAP0FBf0ICP0NDP0QD/sWFPwR EfwUE/wUFPoZFvocGfYhGf0kJP0qKvwxMP04OP0/P95/f/5JSf5cW/5/f4N7mpdjiIN9oYB+t7Vt j4CAgIaCnZSUlIODqY6FoI6JpIOCvoiFt4+Mto2Lu5KKo5KOtZCQo52XrZSSvJyavqioqKSivqmm vr+/v4ODwYyMxJOSwpSUyZ2bwpubzKSixaCgz6ilxq6qwK2qxa+vw6+sxq2pyKOj0aur1LOux7aw wrWyyLizw7m1yby5zLGx1ra22Li31r2717+/07u72by62r+92b+/39+/v/6Bgf2Mi/eRifmQi/6/ v8O/y8K/0sHBwcfHx8PB08TD3MnF0svJ3tLQ2NrW3d/f38TE4s3M4NHP4NTT4dnX4t3b4+De4+Lg 5OPi6ejn6+/u8fj27vPy9Pn38Pr59Pn5+vv7/Pz7+P38+v7+/gAAACH/C05FVFNDQVBFMi4wAwEA AAAh+QQFPAAAACwAAAAASQBCAAAI/gABCBxIsKBBEwgTKlxo4o/BhxAjSpxI8B/DiwkdUtzIsaNF jBc1dhxJsuBHkAtFllzpESVDlSxjSjzpEiFMmThN1lR4M6dPmjV7+sQJ1KXQoTGLojyKdKVSkEyb knyK0YcaC1JzUr1YR90sNdWyJt2Z0Z9ZrGKdkrVp1l81PGEtWMCTduPWl23N4oHrFo+bujPXNsxL 2KyxvYjnhgVQbe5eC4u1Cv5TuHJhxNUI+6VLdLLlz6DbNu68lnLo05U5jy2NunVetKvJmnbdWjXL uylpu4Z9G+OfkLprk16oxB/w4Kdtq2WYzZ8SvMhDKy+p1Gw26NE/2872p7v37+C9/jcoa/n34Oza B+q6IPhiccLZnrNFb3lv2BIFxrcnnve6Qg+hBCjggAQWaOCAHXDGwD8F7KfQe9YtxEEjFFZo4YUY ZmhhIIsMVMI/ETg433vmITShhiimiCFBuvyDG0b++GcCdwqdqOKNKHZC0IciyoeRjTgGeWFBLeon 4kVACqmkQR8aeWSNSkbZiCcP6fJhiE8mlKSUKlIJEQNOPrkllyiGEpEuDWZpIplBMjITllmOySaG 2kjUopomyDlnhWZO9E+YFzUAJ5J7prjRgij9o8uCLiqlp5QHVIiBRwUMqpBBYIb5aJQZACJICSQx kN9LDy046KZKZhDTon8mpEQ2pxC1CCeqQX7zU6sT8bhmoX3mZGUJuuQK4q5zClInYA+VoB+tZQaL bETDMmshIAeE4uyz0FokbYWCXIttRFduC4ib327UogZC/lPuSB8GCci6oR4AyI1ewstRi5GqSK69 HqnYybH8cvTPvGUGzG4GKfZqMEXtomjrwhwxQHCGCkNs5z8FW2zXAZ1m+LDGEpVQAgMcT0yhjiBv 9CHGQ6ZsrsgjcywISwEBACH5BAU8AAAALAAAAAA1AC0AAAj+AAEIHEiwoMGDPI6cOMiwocOHBXmI WQixokWHRSZe3MhRYJExFDuKfHiETMiRKA0qKYMipcuCYuy0fElzzJ2ZNF2O0YMzJ0oye1L4dEnm j9ChKMvsOoq04wk7u1Y03bjwxFNfK6yenGpQKwoUKe74gvEVhVWDqpoGsAo2hYoVe4TtUKEixdcT u7gODNB2xQoWLf4o28GChV8VKPLqBTAgxV8WL17I2BVNR4wXLQqrUKxXQeEWMVy4qAELGxEaLmTE aNGC12IAJIq8EG3DBg5f2IzgsEGDRgweyl4v6JOEhu0cPX6dc5IDx24ieYD1W0xgCiwqOJD/GMYO yo8eOaT+8LE+XS8BG1p6dQkyoUKxdlgoBMniqosNWPz46TVgI0eaYWhsEMIy73CxgRe2sNEDDrDk w095TSGAQw8/tAFNHCM0A88ZazzzRhDgvYJPPhAihQByFGwwhzlzQBMPK+HMEUIFE+QgIolcJUBh BSGMgAo66dSDTiwjiLBBED/IYo+DFa3Dy5O+RAnMlMIkk4wyykQTzTTUoAJLLb/kkgsz8OSzTzzO EJMLLrbAUo2D+j00Dhg8FHGEGGOQUYYdd+zxxy68+AJMMtFYUw4778ADzzz03LMPAPfQM8888LjT zjwPlsjQKQA4AEBVWrGFwlswzHCDDkAI0cQTV2yBSjr+8dwTTyxmbBFFE0OM0o033nDj6zbABhus RSc4BppxOfyQIhzQrAKOPLSYA4cIFYCICCaXWEJJJI84ktIJo0Lmgm09BIFGMaSM8Aw8a7TYBo05 XGuJJZNA0u23YK3Qggs0ZIfFL3GEIIIz75wRQhzFfAEeItlKUq+334KrAguh2cBELV9QUMEGx7jD RQUVhPGLFTgc0jC3EONrrAxGlGJFDz1MQMEw8E0wwQ9awDLFIZY4bG/KKLH1FxF0VOEccj0Ecw4U 4DVXhR+KWFIJyjmBm8IOZSAhg3FH/1LOEjnUZoMLSZiySb330mQVC2PwwFpoXPdijRC8obZaIqBk knZ/TioUMYNbgL0QWg28REOEaJe1sIIhmXxiyVAozJBVX4CB1ooyPGBW2AopFPLIJZxMUjXnn4IL 1lt/9ZEMYYfZRYi3lGgCCU1mESTqAxKsoAcwM9Rll1mDDATJJY9wFQAAHwggAAmpkBWqQY9U8tpA t0DgwFYFOVL89ACAkFJAAAA7 name="ATT0001544.jpg" /9j/4AAQSkZJRgABAQAAAQABAAD/4Rt3RXhpZgAASUkqAAgAAAAJAA8BAgAFAAAAegAAABABAgAM AAAAgAAAABIBAwABAAAAAQAAABoBBQABAAAAjAAAABsBBQABAAAAlAAAACgBAwABAAAAAgAAADIB AgAUAAAAnAAAABMCAwABAAAAAgAAAGmHBAABAAAAsAAAADoCAABTT05ZAABEQ1ItVFJWODQwIABI AAAAAQAAAEgAAAABAAAAMjAwMzowNDoxNCAxMjo0ODozMgASAJqCBQABAAAAjgEAAJ2CBQABAAAA lgEAACKIAwABAAAAAgAAAACQBwAEAAAAMDIxMAOQAgAUAAAAngEAAASQAgAUAAAAsgEAAAGRBwAE AAAAAQIDAAKRBQABAAAAxgEAAASSCgABAAAAzgEAAAWSBQABAAAA1gEAAAmSAwABAAAAAAAAAAqS BQABAAAA3gEAAHySBwA2AAAA5gEAAACgBwAEAAAAMDEwMAGgAwABAAAAAQAAAAKgBAABAAAAgAIA AAOgBAABAAAA4AEAAAWgBAABAAAAHAIAAAAAAAABAAAAfQAAAEwEAABkAAAAMjAwMzowNDoxNCAx Mjo0ODozMgAyMDAzOjA0OjE0IDEyOjQ4OjMyAAIAAAABAAAAAAAAAGQAAACMAAAAZAAAAK4AAAAK AAAAU09OWSBDQU0gAAAAAQAADgcAHAAAAAACAABQcmludElNADAxMDAAAAIAAgAAAAAAAQEAAAAA AgABAAIABAAAAFI5OAACAAcABAAAADAxMDAAAAAACgADAQMAAQAAAAYAAAAPAQIABQAAALgCAAAQ AQIADAAAAL4CAAASAQMAAQAAAAEAAAAaAQUAAQAAAMoCAAAbAQUAAQAAANICAAAoAQMAAQAAAAIA AAAyAQIAFAAAANoCAAABAgQAAQAAAO8CAAACAgQAAQAAAIEYAAAAAAAAU09OWQAARENSLVRSVjg0 MCAASAAAAAEAAABIAAAAAQAAADIwMDM6MDQ6MTQgMTI6NDg6MzIAAP/Y/8QBogAAAQUBAQEBAQEA AAAAAAAAAAECAwQFBgcICQoLAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMF BQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkq NDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqi o6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl 8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImK kpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP0 9fb3+Pn6/9sAhAAEAwMEAwMEBAMEBQQEBQYKBwYGBgYMCQkHCg8NDw8ODQ4OEBIXFBARFhEODhQb FBYYGRoaGhATHB4cGR4XGRoZAQQFBQYFBgwHBwwZEQ4RGRkZGRkZGRkZGRkZGRkZGRkZGRkZGRkZ GRkZGRkZGRkZGRkZGRkZGRkZGRkZGRkZGRn/wAARCAB4AKADASEAAhEBAxEB/9oADAMBAAIRAxEA PwD3HyZzj5FH/As/0oFrcY+V0T6A9PpUXPFTiOFpcc5lTB6YXH+PvWhZxnhXllHOBhR/hWVS7joW tDRGnxygssshB6fPTW0iFhzub3LGuDmaNdWZV3pluj/LGp/CqSpb7sR+WTjOBjkf4V3U7NIzd3dt j1MYOz5d+3JGeeen8jVqKXawJ6Vq1dWJt2NmGUSL6j0xU/AA2/Lgdug/CvPkrM1sktRhYj0b6igs MfMD2HAzStYdtB0eASF2++P61I2MZ3HOOh7UupqrKzIiWAODn9KTzD6fkarlJdnsI5GO+fpVRsk8 sF9aqLWxzSutkUB0ycUor0QsGMg/h26U+N9jZ6ZqfISNS2lDehx+lTGQFtqPyByM5rzqkUpHRBNr U838W63cx6g1pHK9uEiLAoCGZs8fh7f/AKq83vtVv4Q8y3EgYgoSHI98fq1csq0uey6HVCCUdjKi 8S3lherP57hkUR/uyDjgdfXnJxj2r0LT/iLFcaRJPJD/AKVEvzAnarH274rppVnB2kTJKoro7jQd YOoWUVwU8vf1Xdu2/iK6FJw6jHet5pNXRz7e6ydV6045AGKwuOMVcbnI5A96MDrkjj1oAjIIAw2f XIqIuyMSAMdsHpVpiVkxv2nAywI59M0GVGHOPxFNRsZzTfoZw9j9falzjoK7ugkhc+lIaQLUjuNS OnRh/KkmJbAWNcn/APVXM/8ACTXa3Fy8auZF3CRuOORjIH0P6DrivPxbcdjqoqPU5XUrl7hmlnLF 8gEkg5x0x+ArDuNF86KNbq2ciRwGIUu5PQYTqT2xivMotud2b1Yc0eUyV8I3Uk8z2iw2w2/LDI+0 lsk5AwDnpx298VWurKUaj9ht5Y0gmmVS4cfKvYMQAA3TOOM16M1d3M6b9nozqNF1rUrW3jh02O4m dJAZmx/d5MYGPlHzYIx27V7F4dup77T4Z7mBreVlG+MjGCOvWqhUduUipGL23N9WwoJByevHSgyA /wAQHHSluQ97DDJtySah+1oBneu3pncMZpqwW5tthjXsQUvvGAQMg/y9ahhvYrpCYZA+Dgn39KFu Zu8UNeRVyN3J9KjFwpPUHHetkrkybZQgvGnmKopCBAxZgR1zjFW4/wB6QIvnPopzXRzoqz6FtdLv 2BKWVyQODthY4/SqNxMLTf54ZCv8JQ5/LrQpxezBRdzzPxL48udjwW6PZr5gIdhztH+JIrnbbxRJ cMfMKyMOrFRwOnNebiJSnoddOKib2g2s2s3EgiV5pI1DBEQk/l+dL4z0dpreBmVo3SaIOhXh+cH6 HNePOUqU6co99fS36bno0FCanF9lb+vwJtM0l1SFY48xBcLg/dwOP5V51qdlLY+JJ7Zh8kBCgKgU EFcgfk2PQ816LqvnlHokn99zn5fcT83+h2+jWs9zIv2K0iWVYwGKD74GOWHQnpz3/GvWdLvnigZb 5o02BdpBA4xj165B4+gqKdSUpGM4qxXtfEJkvZklYLGikheORnnkeg/nVq51mOKHeCMHH8XtXWno Y8upkv4it7m3kLXEce5iEPU8HnI/z0rhItcWedzLO/8ArXkV4gWUDJAOAenT1rFt3Vi0mmXovENt DZypJdFdpRANpYE7c5DY7Hvjn054oL4yGnrE8KfaMEg/IeT9T17dh+taqUYg1fcoSeO727nWS4UR bDwycBRnPQn2qL/hLp2mmFrcbfPUqS/Q8cc84PNTGsyOVHP6T8evGOlNtgvrdISMbI9OtlH4Yj/z muji+KniTV/KnPiTUo2f7ohneFSe4wmFz7V1uNOLukjqUdNiC+vLvVzE+qzzX7xElHnZpGQ9yC3I PvWNqMF9Evm2UkrjktFI+fTlST+nT6VSk0JW2Mpf7XIyjxJx3kIOfTrVyx1u/t2ljv7mFwRgHzTy PQginrLRoVqfQ9C+G2ux2+sPJE8IdoiAowSfoMjNbXjWOWfR5J2kHMqkkD/b/wDr15OIhyzg/P8A Ro1pyXvLrb9UzZ8NaOX0u3IkI3jJ+QdfxrzrxxpSHxPevDPuHyc8AbwoGCce350px5ff72X5/wCZ nCbfuev6EWh3zadcI8LSFxjeBJ94DBx+lb954m+1KstxGiFX28MTgfQ9qim2tByu9SnZa/ayTh5Y VQxDgbvYZxx7H86br2ts2nH7KmNxOCgwAobHf2H9K6U7mTT7nGx6z9mS5i3SA5+VgVbDcDhvcEcA 4ptl4o+wTfukViVEe7jKAZz2689fp9aUE4iafYfq2opervw3GCh6E4B/An3NYwvt2UbJVRk46/5w KiVpMzV7JDRcZztA5xnvgd/8/SpTIFkOxRlfQ8mnYemzPPWuFUdO3HFa+mRXr6fPfQQXP2OGRUku I4WKRO2SoZhwuQpx9K9fQ11QrX1zI/725Y8cHk1PCksrK0l2kKEfeeM/p8uT/L6VVtCb2Jpods0g sLua5tgf3byQLE7L7qGYD/vo9M+1QvHIxy8js2TnHODTSYuexc0yaaynhuIJGjkhcOgbI3EHpxXp k/j5NT8ONbXMQXUFdQ6P/q3OeoI/A4rixFFVIq/Rp/cy6dTll/XU6qb4nWenaJHpGn2lxHq4UCa4 ZUFvGpDZ8s+Yzlvu4DKAAScnAB4G61J5SGV97MSGB6mvOqq7SNEklp1IUf7KxCyYY4PuBVO8vZZA Vhwp3dd3JrGKu7mTu9yNLjy2JkPzBCduemf/ANVSXF6JYmiaZlUjACgkEeg/n1rpTasGhSlcTKo2 GNMbgc5AU8ZPH41SCbYn+UMcnkAZFCduoWS8iKa4aCMKxVjwCMcfSskXDCdclxkg4XmtYJPUzNiC 4QRohRjgY3BPmGf/ANdTiSIElgxPT6c8cVPKUlY5KO03xIQM5QHFVZ1eGZF2nYSDx2P+c16qGtyQ ZUk5Oc+tWoMy42kn5skk1qRstDpILJ44IJpFzHMhKnHBwSCP0/WqV0I7a+bcyonBGTgDI/8ArUbG SbexflA3RSw7XUZIZTncP8mpGVRcxr0EhBx7/wCcVzPZ2CHMmkbWs2FzBqM0+PmXywVJB2kouCR1 9B6VRSGUsJPMXPIK7uh/zmuVONSKnHZnXKMovke6LLykR/vMB1XJI5rPmuE5b5VPU5PX6VgoJMRD JPuX5MA4xk44pQxe2ZY2zLtIX0Bx1o5bIF2KAjuVHlOzhgc+YvY5xn6cfrThJtwGAXk5A/r+f8qp 8regNO2pmXM5kfAwDk1NFc+UW3DPp7GtOX3bENaFtb7aEZRzkYGeKkSQTNGzZB4ztGSADnp3pKNt RKJg2Nx/ocRPUL+dMe7toTJ9pt2mMgAiKybfLbPUjB3cduPr2PoWKtrYaLSeSOWeKJ2gjxvcKdqZ 4GT25qSzlESn5cnPQVstiGdTZaubnw7DayQ3U3lSTmJY5QsayMFIYjB3YA9R/h0PhSc6Hr2haoZo 9mo200atj7hxjBJ756Ed65q+tJx73Q6fLCak9bdDd8cRx3zJdPcjzEgMeC3J54/nXDytb3NhFIsm L5JgjLuHK46gfhiufDX9gk/MmV3U0Oh8Xny9ZlmjDS5SFigHB+QDn8h+YrmWureEvazB0ul/iQZV ckY3c/49e9cuCusLBLsejXipYiV+5U/tIrvjmwpBwQKrrI8ily24gjOTiuhX3OWy2Fty8uCcq2SM fjWnHCYUOxuScgAfp/Ks5tLQejM3UJjujLyPHOvQZ7Y5Oe1VrRnuhK5PTIJJ68c8UJJRBp2KU/BI HO3IJB61VBZvmyxwMnHpWy2FYtRu5+YrlBxkDrWlFOyqu0EDPBPGKhroTe2xhZj5FuV24yAOn+c1 TuAxjyDyHGOK79OULNSJlvMcbWKlQCA+M1btprNxg+YvqN3FSpPYvlR0V3oi2Ntp9xuLreW32iNo pQ67fMkiIyp6homBHUVWxYpteYOyhcyZP8vapfMKy2Zes7myExVbeNgAXO+ZUAABJ64ycDpnJOAA SQKuDVLCxnSSSwIKE4DwsB09T3oWlkyd3obPirU4or2BLhQzG3jkV0BB5XA71Y0DwzdeJby+ktHt 5rZrQT3UT5WQICOFAU7iWA44HHXKjPm4a31WEkd1ZuOIk/66HJ6xorfbrp7aF5YnwUKrnqBuOB75 qa10vGmYmtZvOZWPA/iJPbrgDH51opJwWpxuWpTttKuFKh7eVjjk4Ixx3z9a07W0li3D7I4OOSen pxUzcZPRkuVmTjTmmiYT2YLjIBY8j6dqBZXEcGIrZIpCRuKYGRjnt61mtFa5DnpYyb3QLth+6hyT weRz9f8A9VUF0HVI4mWO26jBO4f410Rqx5bMd1Yrvo2qw/I1rIyZz8gB7e1P8i+towHsrjAzjCEj 26Cq54S2ZOhh2yAFgOm4ipJ1XAyAcMCQe9d/QrS5XuCnmZRAo2jioUkXOBGD+OKzRZract5qFxa2 FuAqzzxKySSRxo4EisFaRsGJCVG5lZDt3AttLA7Np4d1nUdOmv7GxiuYI5JI2WK4heXKJvciLdvK gEZYLt5Azmi6iV0MCbUDFCHjA2n5cbQM+xqmNYlU5VcHtzVWISseg6tv8S6ro1tpqi2knsok/eSE pkZJYntwK0Ptll4Ozb6pDcXPiCwnljtnSfZbxsSuGyoD5UgHGRye/Qc04P2fJHQ6KEl7S89bGyl9 NqSi8nx5lwPMY+pJyT+P9aUl0U5wcD2Nea0k2jjm3zsAWz0GPpS/Ng+vsOlSiLsjwR6H2zQflOTx jtQth7IaGzwv4A80fXPPXHFGhPSwmzC85Jpu3aOmPpzQLlWh5Z5BiSNs8SjcAfqR/SoJBgfU9K96 +h0W1IwkTSEXM3lIUOGxuyccCojaqXzby+cuB8zLsJ4Gflycc57ms1e9uhq0uVO5ZtDc2d3FNEVY q2cMeK7/AMK32uaTHqD6FpNn4hgmUeYzadcXdvbMy5bCjYQ4zjOcZGeRg1Lim+bqU52p8jXu3ucN rWmS6fKYZrW9tY2YiI3lm0DuB1O1u2T2JrLFqO5zn2rW5itTqdT1S60ifRb3TZnt7iK1UpJG2ChB boajHiG81LUL3WLiV7jU5bnzZZHOd7yMSzDGMc+mMA4GKh7GkNHZHptxB5cxW1kFyjAMjquMqRnp k4IzyMnB7nrTfIkwu4beAM89PWvFMqitNof9mddwAXOQOvTuPamSo0ZwzAAnj34/nSWpklpqRmVA M7Qynvk1IwjI+QbySTgdhTsws7XG5Ktgxn2FKTsJDKwwecdqLAtgSVTu5YtjODSeYcElWHOTijYN jgTbW1z4at7nbIJrWcwyEEYKkbgcVhXkPlwCdUfaTw7A4zjp6V7cb2sdDWpgpAZCzuxOTkEU4F7d gY9xUDpWnkPzJotXnhuUmtZHhkX7rI5BH0Ndz4U+I974esru3eynvDdXK3LMJ2jDkDowA+YHjv0y O9YSpxcubrsVzt0/Z393f5lDxF4v1HxRLa3OpWqubZWjRSzZZSB1ye2O2P8AHBa4ud+VtIUI9TnH 61aVlYz0NfWg89hpcjlEYwE9MDOeQMdutQWRhhtym7MjEEnjAwc8VL2Ljax2n9rsluWMrShyCSvA CjaOR2x1x700alOP3dxKdkoIVS2SCPXnI6/Q4OK89xRlbyJvtjwxh2dkLdRg44G7IGexH6U431x5 rRyJtBxxuwMc4Ptx/Wp0YrW0IJbqSPfIycqQoXoRz0x+H8qu2skyyLudI2WJnUM+3PUenJ46c/hS srBotDWe58tpd4Kuu0n5/YenGfm/SpXncwuFlikZF+R8HGeAf1/rWVuoaLYy4nvo/LW4VFkkYKuf m9SeM+49+301ooraaHeswBDEBAQW4OAR69c0SXYT2OZ0fSLWTwncLeX9pYyTFXjWRnZmYeqorEcZ 6iuU8Q6cLPTUUXFvMwcqwiYtjGPbpzXsQfQ1dkc3eW8ieUi8hwOnFNhtf3vkykkAHoelarYL9iGe EWdywX5tpOPetext7yWON2tZEhfO2VvlRiP9o4H61Emkrju+xHcNLFsACMCMkq4bHscHj6VTku5E xkLk9sUJJiu7G9q8hGiaG6LhnSQEgehH+NbHgaygv9Wtre8gS586QrtLYPA3Z9cYU/5FZ1NKbZUH rY9dfwrpksTxCzIXYvRlB4P0wc89s/pUNz4LsZogGU7wxZHRweM5AAx93k8e9eIqk7jUdNh8HgW1 WLBf7Q7D5jhflzwPp35pT4O0+PCRwssijad0u4kYI44x3/SmqkugKmie48MaVLdhzZiJQxAUMSoy eOSdxPHf1qb/AIRbTeI/Ic9mDv8AfXGQO3FTzTtqLlV9Am0PTWJyD8pGNj/dGcr06cnH41CmiaYq 8pO25sn5/ujoO3uKE5jUEWZ9Is5MMRKHRgxU84H0I478cZ5qIeG4FBkgtXGBsZ9mBjpjnihOZnKC PmS5tbi3kkiKyBkbaVI6Yrr/AABoel3b3M/ieG6uoQgEUMLMvOeWJGD7Ae9e/OSjC6Er3syfVPD6 ypeW6RyQtBKz2bMud6Z4U+5AH4j0ORzf9mS6Zl71AshGFUHJH5U4zUo6BomX/Dg8OyPPL4sW/kOQ YUtgoU4Bzuzz6YxXaW2ofDiORZY/D2oSFR953kZcj1XzMd/Ssp8/Qv3banSw674LkESr4Vj3l/kL aPGzAj/aIP8AOvN/FXg1tR1m5uPC1nJ9ldtzQMgj8pu4UcAr6Y6Zx6E5Rqcj99lON1oieTwjqd3p ukWnlBJbZ3Em4/6vcRg4HJH0Bru/CPhfWvD628todKS7jLcSNIrODjAZghHrzzgHpk8OpVp8trlQ UuiPUBfyRW6NJJCkqoNyxcqp7gEgZ79qrtrbZLblJXGDtz7/AJdq89yXQ2UdLMpXfiPyGLSOduP4 ecfn/nrWc/iRmb5Tgk5ZtuF/znP+cVHNoQ7JFxfEpdVEUhZiARiQrnp0OOuajuL95DHKjKro+WEh yUHfqMdsfQn61jKoYuXQZDqbq4ZPMJQ5yemTz369P88ipZLyKRC7yNI427FBU5J6jGOw9PSs+Z3J 5tSg99cK7vbAySOw+QDdk44x6gZ6H3+lSR60sUYjVz93nIAxkZ54/kcc1reyLOMQzSSyMLSNAoDM rRhc9fXqePqasadftYt5cdr+7kyCyx8g9ePzrfldrXIakmWfInvZAwCyHcFww9uOveqjwxvMY7my ifnkPECpIGOvfjisPfXwgoz0NXT/ACo5RHLbWz8fKgjBVVOO3boa1LuxtEKsI0jG3/VxjapPHXFX C7ep1KMWrDEeDcViVFUgAqAD9KbFp9uGR/MkRR90I5wecnPPPX8K2ioorlstC0gtrB3nMu6SXAZi cc8fh2q5FqdmvXdknpt6cY/rWFSuk7EKcU7MXVNVtSyG3Hlxkc5A+9j/ACPzrCa8RkBMn7sNglfU jr+VTzOxbkkZl9IpP+sDRkk5znIzwen1qK2u3kcxx4554XoPf0HvU/Ejmm7hBd7IWMiAMrfKG/H9 Knk1HJDBkA24bLAYJ9f896lxMkrIZ9ulkU7mbAJ2/wC179aVZCDH87EkgqgBK9c+nt3pqNh2djSk uY94BUySb9xYj5iT1+vT9ahmj85+Y5MKNzkAYVR1zntx1+lUlY0s0f/Z/9sAQwAPCwwNDAoPDQwN ERAPEhcmGRcVFRcvIiQcJjgxOzo3MTY1PUVYSz1BVEI1Nk1pTlRbXmNkYzxKbHRsYHNYYWNf/9sA QwEQEREXFBctGRktXz82P19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19f/8AAEQgB4AKAAwEiAAIRAQMRAf/EABoAAAMBAQEBAAAAAAAAAAAAAAECAwAEBQb/ xAA+EAABAwMEAQMDAQYFAwQBBQABAAIRAyExBBJBUWETInEFMoGRFCNCUqGxBhUzwdFi4fAkNENy 8URFU1SS/8QAGAEBAQEBAQAAAAAAAAAAAAAAAAECAwT/xAAjEQEBAQADAQEAAgMAAwAAAAAAAREC ITESA0FxMlFhBBMi/9oADAMBAAIRAxEAPwD30ENw7Q3DtRxNZCAfhLvC28SiYMdGFvcAYEpfU8Bb ebWRcMKnYglML4IHyp7j1ZLtJGLoLX/CyhtqTIqGf5ThGKoHuaB8IWLf7ISO1ICQJcQn9M/KCgcO 0we3tTFIfhO2mOlmk7MKjeMBb1W+URSE3TimFmrqZqeChvdFgremCtsCmrqG904W3PV9g6RDPCam ub35lba666dvhbbwmnrm2OW9N3JXRtC0Kkrl9JD0l0kJSFYm1z+l+VvTCqQtytCQphHYE6yYF2rb QmhZVMDaFgEVkXAhFbhayIKISj5RTCqNTBSCcLNiqBFKEQsrDIEA5CwRUALbWdt+FvcPPlFZD0A5 G3YWsc3S7RwIKFhkENp4dCEnlsR/VDDLflKHAkjkdpkIyyyw+ZRGhCER+qyLA2jlaIwUQP1WxlVf QAI/iJ8JrjhYIhQCVvyE0BYsGYwhIVBHbHMJYI/ilF8GVkL9LbvCGGQQBHaNu0ZFZBb5TFEILLIj LLLKgLLFBGcZBYoKgyhPlCEYTo8cvpJvSHSotZbw7T9IQj6Y5TrRbCYFDBy1bYmWTDsA0flaAmhZ DAhYNA/CNuVrIuAWg5Epdjf5y0+E6yEKA4c7h5TNfwQsAiFEh2uB/iH5ThS2NJu1HaRh5WcVVa0J AXDhEPGLysqf4WQEGL/lFBluFllFaAgQigVTopASOCcwplajJCgmSnGYVVkFIVCWXgPHHaR2pABI 4yDwrsHR/sslY8OY13YWc4NFzCqGWUxWpkxuiceUnrgV/Tnj+qGVdZIHtd9rg7uE/wD5ZBlllvyg ITApEQYUVUFMP6qYITDrCzYkOilCZRoQtKCyiNYW4W+FlkSMt2h8LKq0A5EwtCyIhFLfuVt0cJlk N0ARE4+UfyPwgQDkSFg0AQ0QogwhA/CwBH8UrSQPcAPhVYKIShwPf5Rn8qKYFaUFpRPBQ+MIW7WV GWhBZBiB0tAGBC2EPgoutHS1+0VkQL8CUZ8LWWCDbsIyFkFGRslRgdLQhZ/oqy23yhB7VTBhGyWT wYW3HgIWJrLLLoMsssisigsiYNlllkGFluMrLW6Qa3S2FlkARC1lkUwKYFTTA/ooHCdTBTArNgO1 vS208ORCKy1oTGQgHNPf5TLG6h0H5W/CG0dJSDw6VYMVN5APkoueWglwsFwa2ufYaRJnMq+JILtX uH7vIPKWjqXVg5taGXKgzbUpPEAzx0o1AA7Bnys3lW5P9ne8udBfBFwe1Os8Oq+qD97Yd+OUjxIF vKUXaZuMqaOxupc8UyCGRay536pznkk2PCgYDQQ6CMR0puftt3dX6qyR1+qH0iD9siCOFEVtryN0 9E8pWPbtdDiCLkcKDSagMhNJXbpdT6T9jBtfUwR32vRoappcWEw4RleNTfsLZECcq7XNa8O+4N/q rOVLJXucZRXn6b6gCdrmwf6BdrXtdjhdJWLLD4WCV7trZtKi3VNNQsNgBcqpHSE4Kg2ox2HSqNUs PFQmBUwUwKziynWBCAKMqDLLLfCEZb8LBZEZHhBFCMssiigssshkaVvhZZDprHMflCBkCEbGJErK ELBGHEo+4YAKKHCpQ3QLiPhGUUIGIQnbfEFZDaOLfCxBiyIKyFxkIF4AvP4VSaKBwtuBwsCEaFFL PHKE3Uww8oYQlYFDyD+VrdoLSiCFllkZuhCEIgrIJf0WWWXRZ0yyyKHQIoLIgrcLLIrdrLLDhE/p rLLLIrLC2VvxAWRGwiChHCyB2lMMKYKcFZxqHHgIhKCiCsqZAlJVdtZJMARhR3uJJn/upuLI6UCg 0gtkYWNlTXNVrCmZIJY72/BXnVqxLobeMAr069MvBLSJ8ryqw21SM+VjksGm4Nb7WgE3kKdU75JM wizDbRdZ0RIAWNaxBp58wsSNshoaQbxymccwNoSUhJAbeeCrEScLCLTwEppb3NiSRwmqODXkzAGC g2p6VRr2vEwtYmlDSP0U22kAoO1ALnGYH+y3rNIZtECIce/KuVPqHNctpuYWhwI//wA+Vg72tB5h TcBcxlBgLWkxPCixdtUt9rXWC9Cnq3S1wgnpeUBPwF1UKjWEy38dJLi+u86lr27XSH8QuL1S6odu Zg+FXeSHkt2D7gR2uGfeXtMEmSO1rdTzx6WlqPafT9PceD0vVabYhePScXs9lQt78L1mWhpcC4D9 VvizYcFOCpjCIKtRUFGUgP4RB/RZwPK1kAfCIUXRWCy1owoeissihA4R/wBllkNBBHCCKP4QWWlE wVkEUOmWQlYWRBWt0tKCKNkFgsqlZD+6KCHQQgWjBTSggXb0YWujZYqnhZPIW3xYgppQQ6gB44OO 0QQekCAchaBiBCHRlkoHS35KIaVpSgnhaT0gVZZb8LYyKAWRGwsssjQrLBZBlllkTplsLLfhBsLd wsh+IQZH4QWQ/oQiCgsi5qgKae1OUlV7gBsAcZEjws0GvUDmuYMxlSe1zWh3t2A9qBdt27jJwlqV KZYYJDuuFytdJHbSqwIM2H6pamrAbLblcra7jTDd07MIepscRYtJmVPowx1H7tzHTF4PhchEiyd7 tsTdK9wDTtFgsW6uJutjlBxhvlGbAjCV+0Nt+QpBN24tlh9ykaTxB3EDrpWZYhVexzx7IldI58nC dPumXFx8qTKTZhwk8L0HAgl1h2pCiXE7m7eltlz+gJB9MHolRc4UnbS0FdT3Updvc4PHA5XHWLah G0H8rQuBuba6QO2nabAFNTmmARdLbfFSYc68ZWMdI6XUZD3A/aBZSptfDd3apUoClUIpVHObEw7I Ck9+0BwdfiOUWKV65BIDjEWCnSMDdAc2fcpvdL2sODyVRjTeALWPSHStKtse/YTtPa9HT6kVawAE Fv8AdefpqIqVILoNj+F6FJtKlXtfcQT0rNZuOypXFMgOIAPaahVFVm62eF5Gr1Pqu/esG2meFXS1 2Uh7HHb0Vr6Pl64KdpXNpdQK9PcRtI4C6B8qs5hwmCVMMLNP5FFAIhRWWWWQaegstPaCH9igsshG WWWVGWlCVpQ0eFkFkQZWQm1lpQwVuEJWQjLSshPiVAT4uhNlp8QtPiFSBJ6ussshaCGEf9llVD4w st0thE1kZQ8LSiMstK0ohVvgysMrcLassst/4UVllvCyJG/CKH4WUxcFZD44WVRlllkG/sstdZFY LLLIjLG0+FrrfhF7c2prlrPbzeelIat1QSRseBJITuoPNR24+0G3kI/sjWU3jdY8rFX6njkeX7iT eDc/2RmRFiZsCqVg60c89qAaA6YE8wuXKNSuinRquL27WteBO2cjwpWPOV11a9JzaTmiKrBnoLn2 tJB/8lYsaiLiRNrDlEEjIB68ozEyJ4Sl4A8KYBVMkmNvgKbnEiC0BPUbL7G2VqbQ50VMdhUT2l7Y FiidLWsQ+Bz5XQ1jWY/qjI5W5EcT6D23mYV/WLqO10EjBS1y11nP2hIzS6R3+trHMqcRgLc6Qhoe o4OlP+zPqFgYxriMz0npMY1hayoam3k8qjTtMjIVEqulphrgA4wJkBRpaVzmu9N4JaJa539iu6nq KlEv2id2PnpMHUt73U6dzcg43JjPaVMBzvVqbXujaT/sVw6hlMhoosEjIPAVKr/dVc0AeqZMHpcj 6u1pa65JsjUmAfcWyN0WXc2madAuaxtrgOw4dLme0U/TFJ+7fEE8FdAex9J+m1B9roM9FSQtoGqx 1F21gbLvafHSVr6jW3hzVGpT9NwDXF1MG34XRp6DHM99TbJwOSpVTZucJjPCoGGQGmxC6qWnaf3Z dtyQValpqVElhO/cJkplTUtFva9sESMjheuGg45XFp9MwxtaS0d8rvaIAAwFeKVgD/NCYbosAflE BFUjbjy2PhbcI5WWUK0hFCAhHSIN1koBH8UrCVU9N/ZZLJ6W3DlFwyyXcPKINrKDILSP0SF5uhJp 5WuoetBglNTrB03/AFVi4pdaUnqdR+UnrRZxAJxCGLT2iudtcPbHMwj6u0tbkmwRMW8pS9trpX1d rgIyuaptNItceeFDHXvF44WLwCB3hcDnEn0yYi09rqpPkTa3CqYuFlEVmkugmypKJglaUs+UlSpt bKq9nkrSp+q2E26BdE7GVpSF6UVRMJDFZWlKDZDdxK0HWQlIXi822qriiylSqeoNzceVVD/jLLLD pBlgsshGW/osshmMsssiMsst+UNZZZaeyigSAR5RUHuaXlpd8nrykrah2ip0vUAqNJ2lwypphtZW dRptc0iZt8Llo6wVHimO89Ljrvmo6Khe0mQDwpsc5pLgPDvhYvJucXe+s0ZNwccJWuaDupiRxK4t 5IiOU9OpESZCxaR1EyQQLgouAIzCgHlpK28u5hYaVJhTmSlBtJHysPt92RmFMDUwSSO1amNsJaLJ 4VD4WpE3tdzA5mLrkeCCQbELrYfYCUlSmH4N+15uH6Xjyzk9PL85ynTx9a6LKdCiKjbzA4VddTcD dsQn0g9q9ku+PPZZ0pQaWMDegrDCFNtkYVZ0wlSqkUm+4uLScKzPuz+FSs0OZBFljl+mXHTjx2a8 13ptDg1sHcY/4XJVgm9jK669N1Ii25nZ4XA4Bzs4yt65rNdTFURJA4XTQLXPD61MFxN+ly0NrbBt /wCbldDHQJ4m4WbcXHbQoUq7X1D+7AP2DlSr6SrTpF22GtPGYWZUDG2xkHpWfXc5weKlwITTGpT6 IDruc3K6qRYdrX3LbDwuIuhwLXkwmYXOKn0uPYpNIkh0g8KrYOOFxUnlrSN1xgqtJ5LGl8NcTcDp aljGOpZKDIlaVUEkNEkwlLwJJOFGsd52HClWqbW7OXCE1XYCCLYRk8KNCQwAmSqT5RKZBAIAjhUn RlpSF0SgHCQFF7UlC3Si6rteOisyrJ8doGc7g26UrfaXX4Vnt3MyVxvbUBlsFQS1by2q1oM9okyC BcgLlqVvUq3keFak/wB9lmVr+AqOfuYdxt0nNfcxwLObLGmXn25AQawNPus3JKvYOmMU5ParSqEH c6wUmtAYYII8LCm9+D7dwlaiOyod7ZYbeVziLGZnhUeHU3MAHsiI6XKYpue5ri4G8Inq1B28Fzmg umEzJBceZsuamdgDmmSSTCp6tQSfTGw3J5CGLUWDcS5x+O10g9LzDXIeCDaV0O1Ba0wRtiVYlldU hc+oqyC2IK4Hax7nTMFBlcvgVHXj9FLdFw8tY4m5KsNQ1lEbiSQFwurO+1uLKlHc55EAkY8pKtWr ViGggm6mKg3g8DIRrAsZD4Phc0bDJP8A3TSR6ja7aoOw4XNqa3pvbBMrja4jDtqz3lzgXGSFdJMe u6pABBthSrVWl7aV5cLdFM2rRhrC5pLsAFKGtNTJcAbeFrUkdFNsACFRIHA4bU/RMA9xhtN35SWJ 2yP5hEUqx/8AjCYafUH/AOMJ9RflNGPBVho65/hKYfT6mXPe0f8ASFPuJI54N7Fa/RXR+xNx+0VA e4R/YabBufrHBvlPpZHN+ELRdUP+XN+76iCepSOr/TWSBWe/4FlrafLfJCE+QldrNCDEvPyFM63T 4AQxaRBlc1XUs3mk77iNzTwj+2UTPXSlWrUKoAwBwi48+vWdveLxyO0pedrSXfjpVe1jmbPUJ/4U n0pMMMibSsWVdTBBc7cYjkJS4znCoNI+p7Q8Ndx18Kn+U69oBI05g3h2Vk6cwd+pRD9jsp36TVU7 +nTJHRUjSq7vcz4hQVDnEzhUBkDmym1hgQHX6CLZDoIiVMalPcCwlNTuY7NlMGbSmZY9gFRPXots wXWIb/M39V2aCkx8h7A4Quw6XTuBH7M3Cuo8tn2EKLZa4xhdZYGve0YBhTdTuvLOMvKyvReWcZXF 9QIdTnPS5dMCBBXVrKfsPQUtOR6Y7XbjLw6Z5cpy7Vpi0I7Cmoi5C6Gt8Suzk5mMO4RhWqNlqqGX 8JiyV5/0/wAo68P8a83XtjTOd1heOwAhfQ/Uac6Zy8OlSsSMAL0OUCkYIEQZyuhgkhIBEKjBOOFi qrEbR+EwYMQhEXkx/dVpkAOJuSFkM2l7YOSqCmWOx8rp0rGPpAuBkcro9AuEuAJ4VkTcc7qZhroJ bMlUotlxb/DlVhwO0Wac+Ejt7HlzmADg9hakTt0DCDzDbLnFYidpF8JHVyQODytGFe5zXbo8KZcT UaX3DbJnPcXFrYI84UntLiSHG3Cg9BjgQSCtvi0rk09ZoME5TPrtDobJAytGY62O9qAJJI6UG1QG WuQiK4E2VTDPdbypmpybEJa1UAYUTVtG0H5Waq1apAY4Gdys1uxtueV5Tq2yo12Wg4XTU1JNKaZA t+ikMdoqCIJup+oxocCc8Lh9VzzANxlDVu2sDpwUtRKo7dXcTYol4YbGFzUi9zyDeTJKNYkOHVgV Max109Rsebz/ALKzazKo2vMk2XLTpANeJMkZTPoEU5aI7PIV/tMXpvp0WPpgAwUmgqbn3fbK5g0w XG10aIMgiJ4C1KdY9HVatlEtbEly5W6ijUbdzm+Vy15bUIe4OJxHCQOtAAupadOxpa0uBeBAkQlf rA6zQRa/lcpB4j/sqe0sN78J9IT1YdjCz67nWLQBCm77pWsQpqzKAdcoAvHlNAsZuizniFBgTETY q1OoWtMOg9qMiEu8n4SC1N07tzibZPKTeXDJMXHhSkh18EXQDp5II/qqOhu14LXHN56VNjbXk9rl pyDZWLpaP6pqPdb9Y+h07NoQZmzeVan/AIg+kSfaWHE7V8UKhHwj6vbZ/wCF1+Y1H31L659Nf9tY /kLP+vfT2SN7jHQXw1OsBYjHC6KdYERkKfMH1L/8TaQEinTe6O7KFX/E5APp6aTHJXgCoSAOuERK vUHsH/EmtNm6emOzKkfrmucd3qhtrNAXm3+Ubppjtf8AU9VU++sWzmOFN2pqPaRUqF7cfK5xhaFC EdpaDjPoj9UvoubIZXcxv8oVQjhNHO6rXpNO872jnlZmqDrY5VyFz19NuBcyzv7qylU9Tyh6h7XJ RqbCRUkc24TNqF32t3BXTLXRvPa24nlcpqnBEeEPWIGVIZnrq3kc2W9QjAIPyuak51Q5H5QNRwMT hXYXi7m6gjmyo2q4ge5eYaxmCq06pbeR8KXF+bXpMrObh0Tnys4h5uudtRpAg5RFQKYz/Su0TZDb tNsJRUCIf4Wbxi4936ZC75EGCvL+nVH4Y1ru5XVvftMsELPgg8j1HQMlI6Uu524/Kzt68/LrnrtO +Dl1n2lcVCb3XZqgS0rgotMlehymOxjZOYXaxkDMFcmmpkuAn8LtbRtklVk8D+ZD29xCLaI5uj6A nC4/pLbLHXhyklR1oa7TuErwGQ0m+V9JqKDfSfAXgGnLhtF+l0rnxqcgnMhMx4BxKZtMbRCLWhxI J2+RwpqnpVCsHOGAgwbSflVG08wZWVdFDUONM03OLQMWyu2g972y02hec0lwzMBdWmq7GxMDK1xq V1+4C8gdrmqtfMeqXA4SDVvcS1ztzZx0ndVa5oDT+q1qbYk4EHbi/wCiIpiRLyfCUv33JkxC1Rx2 iDEIhnUWhsk2dgJG0/uDqhBjIRdWpupD3EluR0kNZppkTcYQmjTpObDuTf5XXTYHA2F8qbKjCxrc ADITUnhu7vgdql/6Zm1vtIgf7oMuTBsp1XlhuRLuAs4+0iYI6QLqHBrBwfC4qlYuG7orortmxMAi bLgGIJmFmoD6hNhhdGirsaf3gB7lT2jabqWySPbuEyVItddY021SaBNxdoU9RV3s2nHCdzmAbmN2 WvHPlc7wAACZ8qkdGkFMjaSGvPa5arYqGnuLrqjXsFNwcwPcPtdyElN7dxcc9qj0hsY1t8Jq1UED ZkLidqg4RGeFqL2khpfkwFrWbHS2pT9Ise0b3nPSjUoOplxaQWxwVqoBHtA8lLRqNp1BI3DkKEcl QHdKwIEglPULS8gXaldscAIkhZ1rWB6NkwMQEgxawS7vKJpySfwkEgx+q27mJCabTKgU9YSt+4zh Px5CVjpFwtQUAA5mECAPhI8pmic2TAdvmUNtzGEZAMLOMjoqQwAQP1TtJGcKY7KYOBxwg86UFll2 bwZTMeQk/CyDvo1A5t3XXTTExDm/kryqZgiF2t9Jwg3d/dZvTU466rAwchYeCuJj3AwSXDhddIBw Bn8KsHBHa0jhbYM2Ra1pBu38oaXcAFt4wnIYP4wfygCz+YIaWfCxJ6Tb2fzBKatP+a6ohXoioT/C f7rlOn1TD7IHXld/r04Pu/CQ16amLuOZmncW/vDftH9lkm6qa7JgYRbqGxhXGdQOiEQajh5CoNKA L+6O1UV2resCpi7fEnaZptCkNIAfvJ8KrqsRZJ6pHCuIs1gaLY4TNhcvqnCPrFMV1tiFRsBcQrGM SmbqI4Uwe7p7MBFiukPf/MvI0OvEinVs0mzvK9QFZxnsw7hO4S1TBVAfavN+8zK7fjd2OPVN9pXm 0fuPyvU1Q9pGF5dH7yu88c71XpaKNy72hcOiHuPS9BoViVgEwHhYBNECSqynWH7p0nheA9odUJAX pa3VTNNl7X+F5sCCR+Fz5VuFbE3Eylc2CSBbhO9mBMHNkhJBIJzwsr0zBIM2R4xlJuyCB4Ra/d8Q rhqrJ/2T7iLHCmwSU7rxBlINyLxKrTktiJKg4eUWVfdt5Wp2l6M4wT/VYu3s2tdcBJUdJ3cmxUp2 oQznidoMEi6DXy0jpIPc4xjytgnwg72OAcC0/IWNSXEiw6XJTqxdMHlxuB4QdL3D1GOm6GogEPa8 9Fc4dJEDCpWgtAB+FqJUKlR3ebALmaSXOBldj2AtN4IuIXP6gDi6MHCCbt8y6wCxfAscXT1Hmq+7 QJyAkFMgAus6bgKAsruNF3z+iDn3HIQNmENbBKTcZA5HCGGLxNpnlAECTKm+WPvg4TCXCBlUkEOJ cFUEATOcrnYeOk9ogcomOk1x6eJCAd7t2ApsIme0ziDaLFTQbcCFNziHWFuU0XF1MkOObrIG4zCw 9zoEShjHJQY4Tj8rSHktkchDebjCzYLpcYCzxeW/lGhm0IA9GyzTeB8owCCcHpE0DLB2UwJEAlK2 5lx+E0Q6+JQO6CbqYG3N4TOMmOUhdtIlIQ4sIQbm4Wa4OBnntG0m90HAAjFsIStuXVe2WQlaVT0Z 8KtIgWUZTDsKLFg4jBhFr3DBUg134QgjkhB0eq/BcgahNiZHS54N7oQe1UdG4R8IbhOflRA8yjtP eEOldw7stLR/Eo7VtgORKCoc3+Yyjvb2ohq3t6LvDblBTe3tMKjeDPSf9g1bdONQ/Slum4cR7vyF DaFDxT1W9o+s3pSDR0mgRwqGNUFLvWgYWI6CAeoOlhUHSJAW29hF1g/wm32SgRwj+DCIYVPEr1Pp 31IGKNUPnDXRZeTeYV6Veo1pYDLelnB9IDbJhUaV4/036iC5tCu6HYa7seV6rXALj+3C8pkb/O/N S1X2lebp2kvMNdPULt1lQgSCvPbrqgfLDDhhycJc7Xle+nq6Bp3YI/8AsvSaxeX9LrVdZUe2q4w0 Wsvfo6d7gMBnfK1254gGLzvqGr2jZTN+12fV6x0VNrQRNSzZNyeV889xe4kmHG6lqz/qm/spJ8cS kmwQki5WMUS+I3cJXw4AjlT3Si521sFULYfc2/SLTxiMFaA7uIRYCAfKIoHEBHdZT/siLRuEwomn JmEoteUCYHan6lp4yqUziZyg19za39lMvl1khMTGFcFHm+beEQ+Q4OwRlKw7p/VZ8RblUOwWyqQT 4jpI2G+As50fhA7HQP6pn1N+28Ft7KTnQ2JTDbYiyeAurAB2285UGud6lh7eUz2+4wbFLTDg47xC umCxj21N824CLhODATS2CGuzeClbiZsoYn/cBKQBym2DeTuzdCoBAPKsCREyJ8JmtEGCkcCTExCo IF+kA2w4rPFxCbInhTdMygOBY3Tgzc2UmB0g8KhBmLQEqHBgwVPaLkJQ4g3yhuHNipIFkJWntExC S8my0GDifhUa61hayiFRvtPjtUPTBlV2AYMwVNlgDym3Ek/+Ss4CQ3dYXQcYNk0hDaPykIE+3zwg QXTZNtFu0YARewa2AQb+Fg0J9ozMQkd4skTx5wKCwC0Lq00rSO0NqG1UEESL5VQ2LAyVINggrr0l ChqHba+odQaf4m5HalqEZUdTPua4A8OEIk7vldlb6b9PoUTWofVqn1C+0tq5aT0vPAEkA2VFPTEZ CGzmRCUQEIHKCjWgZciA3lykEQJtEoKbWYL/ANFtrJs43WbTaBewR3NFmj8omrM0rHN3uq7QLkK1 LXabRu/9NR3P/mI/quJzu7wgJIhMHTrPqmr1Ul+qdtIhzIsVAOZGCg0dpx+ENAETICBM3LADzHPl UAEIGAUNTaWuuJ/Kdw24S1AJ3BEGVUCT0EASmgErBnSBZPCLXOsAbJtt4wiQAPbP5UU3tIsYKVzO nIeAqU2dqJqLgY5herovqhDAyqwOOA48rz3halEYUqyvR1WrZWpkBsFclBkOST2noOO4SFldj1KG tqaGatKm15jBSVv8VfVq9Ms02gpUyTBqF92jsBRrn90YXEXSZKbY1KrTdqajm1NfrHaquBDZsGDk BPu3fCgHcJw6JWKKtd/ZbcNp+bKe6I7StdaFMTRc2IhCSSFiQ63SdkgXTw6Um1spcLQLiUpcREBS JjEzCxNks+FgZNhhVYDnHAEhBotMxdFxgylFx0iToIE+4SEpb1YpjaJRYbE8KjNYWnM9pyZI8oAi LKZJ3JBQxPwhIJSDkIodqCJk4HCznbQCYgWHlJMhZwDm+RgoQ7ntI9tilfUbt92XcqYdtgH/APCJ pbmC8XVgMSBub7gMhK47BPSNOptF7QjVaHFpbibpoVxLwHst4VBBYD2FgWgNHI/qkFjBwLhDAJaC JueUTHwD0lJBeFmu9x48KKzQZiEl7DtVkY4WkZgGP6JqaUSG3wsbG2FpQc4Ax0iambkmUJQcZkgc rNsIN1qRMKP7FYTCYyl2OOFV6bd+idtWRBwEjWSYJsqMp7R3CdAsqtcR0m3SY/KHpSPb+iIaftAv /ZSKUuMcphUxOeEQJF5ssKcgeEDbiD88oAkm5sEIMHNkAdxiIQUBg5Q3ylFiT0t/CDEXTDf9uNos tH6Jqf2rRC6BYQhPCHyEQsItMXOEVN5hIsF0F5eG+42JTNNlMXhUZhVW3HqVg7xZb4WAVZYHwn3n gAWSIhAS5xyEQTCCZuEXWmyLJhKUzcBEOEYugATxKdpQFoTbR0g1M3hETrMhluFJmF0uEsiFytRd MqU5n+yQKlISUQ22yFQWTGyDrjuQsszUldlwoqjHQjWiWzI6U2mJVh/RSIgkQhLRPgqlEQ4KTRP9 1dmRayy1K6a/+ivP3QF6FYfuVw+mChBpzEgSrfwyBCi0QAeAs55kdKYvpi60SkMhaBtzMrDGLhMQ wcSLBOx04CkDHFkwkmCYMqYLtvlBzb2SsdDrxKbdEhTwY2FspQ4D+yxuCkNj8qYYLrylbayfdY2W kbT3kK4Ez4QaD7rWQgnqEWuP5GUDcWWAFwgDCxsFCM0D9UhcEZ2gKZMq4KN5j5CfvjwptjjKdszC YAQIgpH1IMA8KpET0uWvYxNlYGLr/wBU9N1jNwcKLRZO0uAibK4az3GZn4WZVNw7JRdBp+VMNII4 UO1Cz3i6YANMyg4kAE3IWFwSbqGjMmQiDe4iBdKBc8BaRBhMTpiRdIYhYnCBdAIVhgOsEBexQMdI NN1pVS0INMIbrRwsCJUwWpbQdzgCUZA4SBzIM/hYPgLKGmIASybwma4fha2QIVDDPwnmAeFJzrLN qe2DdQMC7g4Slvu+cIbtt8piCRuGBn4VCTCZkupuFjj8LSDk3Wa0tbgqrO3PS+1aEKN2p4WzSgLE ePlMESENTiyjVxhdBsFN4VHODHwr0jIwkLeAnbayDLYRQVRpRQWRfBlOzCmnp4RBi6cCEoToh6Im q0dlW1FI06sEASFCidtRp6IXq/UaQNOm/wBNxtlolGb6826YZQBE2I+OlgUaPH5XGRDo8rsC5Ktn oQwj4VKRAdxdPpdHqdX/AO2Yx5H3B5XQfpX1Ro/9nR/VYvKfyYi6DhLC6DotZTa4voCQLhv+yiZA IIIM4KTlL4uZO0IgphZOWznKUMuqz6doMTFktQQ6VQXplTqYBVCNyuiiC4iMhcw+43XXof8AVhcu V+Zrpxm11upE0CVwhpPB/C9mu0eg6GgLyqNUtFgsflz+2+fD58Qc0gR/fK2yRYfhddeo2q2TTDKg 5H8QXO0w0+6CF2c5/wBKBAgBWLBstlR3y4+EwqXibKJolkYR27mlrhzO5E1I4ugH82UawGsAPwjJ JlGxznoJCZwmIZtwYSkXRFhZIci8KQH3NwAeglJINrobjMFBxI+08IKDa1kFTblyBJIStJmVcFG2 wtObApXGNschYEAX4UMF2Ag1qWXYJROPBQ3DN+IhUBG3ypMcBM4IRaOR+EqxQ3Kn6QcZi4TjgxcI 7b2Kng5ywepDTCV24yOl0FvvJjjPaXZ7y4/lXTEBIMq5io0EWMINLYg5TNZAgY7UtPUbuMJyNrYB si6AJGRlTBLmm91fUFrjjKL4GOUGZQLoQ6K4wWn9UpN0SZKWb4WjoQJAk2CJAHGcJQJwEReOgimk Ft0BaPlZ0D8rC6IM94QJ8oE2HSHEBQUHzhMZABnCVkbfhY+UBe6wQn2+UpP4RabXygdswJTtIi3K Rp8IiYsEGbAN+04qloLQYDhcJW3i36ptrbmEHHQMgqqjp+irraestwED0jNulVhSplUddJSaXVQ2 RLjAnEqGB+CjC+jqfRNUNNv0tTQ1dTAlj32IXg6gs3HbgZTjtmniJQRKVaTBWW/2WQb8J6ccJE9J CqAQiEJQLoCGGBgg9L6Wk6s7Ss9GrSp+KpgFfLh/QXs/tGjOiZ+06c1qfm0HwolL9R02p2+rU0+k YwZOnfuJ8lefhdran0oAtpNqaTdYll58LhqkMqFrTvZ/C7khUsxQFRrtuFRpt2p1hbn8oY9P6FTY TufVLBMGMr2Ko9OAyu97f+pfP/SXQ9zcGLHpew1rmtn1jVacE8Lyc5dejOPzs9VFV9oqkQvJ+pti ru+7cvSC5PqLNzQtfne3KvNGEHGHTxyrNZLJ4Uagg/0Xdz1SmJa7+im5sttwjRftcJuF3UaFKsw/ w+QrC15cDPK6NA796JwpVGbHFpMwn0YIrNhcv0nVdeHr26t6B+F4Ydttxwved/oGMQvEFOHe4SuH /j/y6/sT1ephVFMFpOElVoERZH1P3TmjM5XqcMIwAErYbI4Wa4tLSRjjtVa8OpuBAYHdJVxAFxMw SmDpz8KrGD03NY83P8Xa53BzSQ4XWdMpwYBRBtbKlu/CLXElBWbW4STOUAcAnKzgALHwoAXTP9Um 4/KAMnwEfCoaxI6IRaImyDzAaRbtakdwI5yqYDjJ8BAAyeksy61kwOY5UBBmBCJMiOkNsiyIbBib oYHPwnbZoCVwJEhZrZsTCgoDCLXXSlpJv+iDpaAOuFMDvLi0REcpHvMRysHwLjCDqe64KSDnaS13 hWFU/gqbgRwlOBHC1mij3Aj2/lLcAFL9oJAlMCHphpmHooPhECPgIOHIUQsyJhC8JhLTBQPS1F9K 0xhYkzK1hKBQglxMeErigOloRMg7kWntCIMLAcIKNMyED1ylb7byjvJIKhlMyOURGVNjrKgA7t0g am4TdPabFTITNmZ6UNNui8T4RBkY/CTdB+Vg4oeuOiYcuhc1OzlebrqtMTwghPlZGYxSP83TTZA4 RXI+hRdUDyXtg4DjddLXSLKbxAntNTAsQi6qhHhEDhU07GvdDjCJ4kBZAhehqtPpTpxV09QioPvY V55VRgnpykCZnIRBJ7WecIfhFwsOQiwk/qu+pqHHSsYQDtuD0uEN8LsoOpikN43RwoIipF2kfCQk k4uu2q+jqH0w2i2hwXN5T6jQ1A4MaaRdEi+QqH+lBj2uD2CRyr/VKTDpyWsALeQuLRE0KwL9seCu /V1aTqb2iq2flc7LqvM0FQt1Ale610sE8L5lpLH7m2LSvXo/UaT6YcXQYuFOUHoTZJWgtEhcg+oU P5ylqa+kWwHGe1icbq29KVmtGBAhcNQTKq/XMfTEDwVyuqzK7RznGsOl3aCrtlpt/uvOL7qgruyG gI1JquqaPVJHKGmG2o1RNQvN1bTSagvhY/SdNcJle2SPRdFrLx90VZNgSYXri9E/C8VzbnJuvP8A h/Lt+3jVgdwAwcKdNpLrZAVXlsNDp3/wo6enLiZgiQvTuOMTYyXHfZTfX2HbEq2rDgxpBXCQckJO 1d3+aONPYdMwkWD+YSl/rsJH3BQ2EMDjTdtdgxZNQeGPEcpn+mt/2n2E3Ago14DrCJypbiLKesYr uMrF0WHyphx/C036TE7M3KdsGwUhYlVbxKYsaJbCUscy4TE3j9EQ+wa7HflURp3fJ4Cfz2laIceZ Txa3KAgmU4F5Sg4TNIAiVgO3BWAjhCRPhbcCLFQlHmQZSP5TWEeUTHOFfBG4CJq7WgJyI/BUqwmD GVZlMLUsSAZbEpIssyTZZ8iAFVwjpEjiVTTtJPhTyYhXp2AixS1MOKZ6Q2dYTta6BdLUa5pwVkSc Du+EhyQmeHSZQi9wtQAiIhKU72wfCRwVIzRYlbEoDBThs4QKFpjGVQUyAplsGyJ0LovGEGicIgSS qNgXQIBBsUd0WHKLo3W7Q2juJUBkmR0mO7agHAYHiE+blDSgEHtFrTEkpja3SBOECP0NRlEVgWFh 83Uk4iY6SNxK2ChK34QKoE+VpQRagm+4RYYWqj9UtPF1KsdLGl7bOEpQ4tNwiXsLIFPaTkjlJAud 0lILb5B9oKkZPCZrm4KcFpCuokAekQSPCtAm8IgN6U0xH3LQ5X2jELQOk1UAHHmESHi0wuhjNzsS nqUi12IKajjh0xKIDiMk/JXQWQYhKRdFqQBHZlb0x0ummzcLrOptEQ79VNEGU5PSwpSSYurMYSRd XDGt5jx2mpjlFPcLpm0owugua3LQk9aiTggJtCil+v8AdMKHgqzalPi4CPrtaqIfs56ut6NvCt6+ IbbygHEjESgkzTb3QuxumDRjnKkw7ebpzUcculS+LN16DJNJefUokzFp6XUwPNM3XC6s8OLd3K83 4e13/XwlWjUljrQLSl0pPqvDgRflPuJy6f8AZYknLp6XpseeH1FIVKcBwkXC5abQHhtSOl0mmKjC WfcvOgtfsqCHDtZjcertBpuo+o70TcCMFcjaQ3i3tCpp3AxTq6mm3oPdBC6xpwwYss24t5SvN1TA Hbwchc17hepqqM6dxMAtuvNaLKy6wxbDQ6PlB4hwPCrkR4SvPsba7crUCGQ74K6KbZEiZU6AD6rB 3ldzmbCWmOCFKOXZIMj8qdRpDrj5XaKZNovwubUtg2vwkO3OySU8GyVlpVG3sVadgGmf9kcT2nbG 6AUXNse1EJBzCZjfCZvubCamQBflZNPtsPFkCB0tvCDjaFDRb7rAcIGmS0yPKDagaLYVG1McISuY 0HA72tMSsGA/fjhde8glu+xyFKoG/wDKuqX9nY8hzbEcJxRAMwgx1oJiE9J4LZnwnaFlrQb3Haz3 FwmRi0pKpG4lwzZKNrjknwkQkB0hK9hbHwnLQ3Byg6S2OFqVU5jKSpwnNj8JKmJWoUAMyJsi2eCs 0H/lYTe9kFWm5nCSo69kpJjKQqBhz2ma4bbZCnJC0nCYhy+5IQlKI3dSnbDZ3XkIQzMf7p2nJ6Uz G6PynB6RRadxicLYGUGugygXSbCFEFgaGyYMqDTBsptcfwmBhbjR4QhEErXVSlhFqCIRIWrhIwCE 1TCDcKNCFp4WAKBQ1hZGVlkUWvhOHkKSIdGURcVbG8J9xdhc8hM18EQUVc6mlpy0VmakyM0GzHyq GqHtLqVbcyYDalqjT/1DhHSfWNZ9KrDV6am3UN2bKtMnImQ4eRB/VX131T6V9S1NbU6DRuaXxvrP EF7vj4hOMM1yEkoX7T2cCQ1xAzZKSDgg/CYmi1zh/FCO45Jk9qcobkNUuEQ8D7q1Nnh5ifhR3ALp 02s09Jhp6n6TS1gL9zarjBYYhMCbp5QlR3QImTj5W3JiOmhQq6h5Zp9m8NLoeYmOPlEk0xFQbXtM Oacgrl38ztIMg9HtUbUNauX6h5qOqXc88ntCKCu0fxArftMYcAEfToCQGgibeVgyhjaMKauF9aRY 56RZVO6xyVKqA15DWgDoJWSXCyXxePr6Kj/pfhePXftqvHRXr6UzR/C8XVtd6715Pw/yrv8Ar/i3 q+VhUKjtPaZrOJXteZ20KoDSSJi6eo2hqKZLml7e4u1c+mAa6709R50ldtUH2Ps4LHJvjj2/p/0T Qav6bT9fRNq1QP8AWcYJUNTTZSH7p5dts4H+Er2fpzmu0jCK9Bojly49R9JfVq1KtOq0ucSQJsVn l52klteJqZfS2kZXnlhEGF6dVr2OLaghwyOlIMEERYrMuM3pxvcRiygZOV6XotOf/wAIChT6W5yN cNMe5sGF1lpNQScCJVP2dmQwDn8pw0KXknqXrOptG73Quao7cLLsNNpmQt6TIs3hJcXY46LJ3DsI WieV2ik0GwS+gwCALdJ9DiBgqrAX/hdQosnCbYBgAfClqRxGWwhuJIK7SwfyrCk2LCU03/blHOUb 2gLq2CFoFrJpK4ocP4eVZhgEubIhdEBaB0ppqLmg3DYNklRhyBldNgtYWQctOkSyTZwRa0gAAW5C 6YWAgfKajmqU98Wulp09pJPVguqy0Jquc0pAgfhKabosF1wPwsG8BNXXAaLnHCT0TDgWr0S2PKBb 5V+k159OmWm4N+PKHoul0tiBwvQI/KIAxCfRrzPTMYMoek4kDbC9SBe3K20A4V+jXlupuHBSlhIs 3C9aLGwMoFjepU+jXkEEcLGQRIK9V1Cm4CWzC3pMmSFfo2PLqgjaSEQDwvTNJhb9ogcIGhT5EJ9H TzZjmbIBxkLvOjpnFkn7E0n7iIV2GvNj3JwgcojC6LTjC0IcJo8oeBCIstCJQxKp+iLWnbhByoyp AAhSmF2HEJCF0etHFlF5kpAqMIcZWRR2LbCs13HCO5ANpR2+VtwRDkQzAQRBiFWXPI3vn4EKAKM8 yix6NH6NptTQ9TTfXPT+oN3Odp6rgGudw34x3lSraL6hpnBuv02nphzd1Opprtde4J7XBU02lre6 rpg90RO6LI0GuoNdTp13DSl28ac3DHdykFy2ENonKWZtKwMlUNDZyttalBv8rE3UDBrQEfaFPwjK I6dNqqenLvU0za7XWIPCg5zTwpzCAcEMUkThHcIFlHeFt4RVg6ywfeJyVDeAmZUh1kwfRaPRV6lJ rhVheVrWvpV3MeQT2OV9D9Oc06Zp3tA7JvK8H6uANW7FulnjJE+q5Nx7uiCUqUEzY2Wl/tdjocCu 3URV0xESOSF5oBLgDj+69+j9KpVKLNmpqU2m7gBYrPPlI3w42+PDpadtT92xhe88A8+V9NRrVvpm ip/tLQ6iAATPubbATaelofplMil73gXceT2vH1/1D9prATIBXLbydPmcY7dZVp13CpTkzmeFzFI3 UbiWjCbhWvPy7EcFaUJWt0oz6Mha0WQ4Wsqbo2RtwlvPlZQg2W7QygTx0gZG0JLooaYRyVjYJVow horSgsAiiEtkY6QMdoNaEUPlHPKDShwjNyh/ZBpRQHxhHgolCe0bIwICUhEg2QstkIQkaYkTGUUI siiNKHKYIW7QDha0ohEYRCrIwt+UWBbC3hHagBfNiiY0xlaRcIxeUI/Q8orxH2TDEIPyEzV6GxGA ERi+UPwiMIyyy0oAospXDKwCJwlFlFNKRxTcWQKQYILLYQaUqxWwiD8IDHKIcnBnhUIJ/K1+FSER
July 09, 2005 - July 29, 2005
Kitfox-Archive.digest.vol-ce
