Kitfox-Archive.digest.vol-cl
October 15, 2005 - October 25, 2005
      hard for them with unnecessary negative feedback they have a good chance of
      coming good in the end. Yes they probably could try harder to answer the
      phone and be honest about deliveries. However they can't deliver what they
      don't have and can't get. If you wan't Skystar there please give them a go.
      They have admitted to this list only about 12 months ago that their problems
      were financial based. I think that was very difficult for them to do. Give
      them credit for that !
      Yes I do understand if you are on the wrong end of the stick and not getting
      things especially if you have paid for them. If that's your personal
      experience then you do have the right to complain but consider first.
      Perhaps your complaining might even be the straw that breaks the camels back
      so that in fact the goods you are waiting for that would have eventually
      come might then not come at all because Skystar does dissapear.
      Rex.
      rexjan(at)bigpond.com
Date: Oct 15, 2005
Subject: Skystar order
Ordered the kitfox pilot's guide and it came today in the snail mail. All went well, sent check and in less then 2 weeks got my order. I know it was not much, but! Steve Barrington, NH http://websites.expercraft.com/highwaystar/ My web page. --------------------------------- ________________________________________________________________________________
Date: Oct 15, 2005
Subject: Re: UHS Spinner
At 02:59 PM 10/15/2005, you wrote: >Make sure that the fiberglass back plate is secured to the prop flange >with wide diameter washers. The UHS folks sent fender and flat washers to be stacked over the holes. Hopefully that will prove to be enough, as I'm going to forego the carbon plate for now. I've mounted the spinner and was disappointed with the holes cut for the prop. I recommend to all to order their UHS spinner plain and cut the holes themselves. The cuts and measurements are very simple and anyone can do a neater job than UHS. If I'd been smart I'd have mounted it before I painted it, noticed the problem, and then sent it back for an un-cut unit. Oh well. More silk purses from sow's ears. It appears to run true, however. Thanks John, Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 15, 2005
Subject: Re: Clevis movement
At 02:24 PM 10/15/2005, you wrote: >I replaced the pins with AN45-32 eyebolts, castellated nuts and cotters. I >can then use the eyebolts as lifting eyes when changing from wheels to >floats and back. This is a great idea. I personally think the spar holes should be captured with bolts. Otherwise there's no requirement that they stay in contact with the associated fuselage frame tube. With a clevis, the spar reinforcements can splay up and down, bending the clevis pin and ultimately failing. (I know, it's never happened.) Capturing the spars keeps them round and the attachment bolts in (almost) pure shear. Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 16, 2005
>The UHS folks sent fender and flat washers to be stacked over the holes. >Hopefully that will prove to be enough, I thought there had to be a thick aluminum plate between the prop bolts heads and the prop hub. This could be reference with only the Warp Drive ground adjustable prop, I don't know? And together with the smaller nuts and bolts (4 per blade) all of this sandwiched the two hub halves and secured the adjusted blades. Right now, I cant remember if the thick aluminum plate came with the prop or the spinner assembly! Best of luck with the new components. Eric. ________________________________________________________________________________
Date: Oct 16, 2005
In a message dated 10/16/2005 7:52:27 AM Central Daylight Time, Ceashm an(at)aol.com writes: >The UHS folks sent fender and flat washers to be stacked over the holes. >Hopefully that will prove to be enough, I thought there had to be a thick aluminum plate between the prop bolts heads and the prop hub. This could be reference with only the Warp Drive ground adjustable prop, I don't know? And together with the smaller nuts and bolts (4 per blade) all of this sandwiched the two hub halves and secured the adjusted blades. Right now, I cant remember if the thick aluminum plate came with the prop or the spinner assembly! Best of luck with the new components. Eric. Been solong since I installed mine dont remember...... but, I follwed thier directions and it has been perfect...:-) ________________________________________________________________________________
Date: Oct 16, 2005
At 05:49 AM 10/16/2005, you wrote: >I thought there had to be a thick aluminum plate between the prop bolts heads >and the prop hub. I'm pretty sure this is only for wood props. The HP Warp Drive hub is a solid mass of aluminum so I don't think an additional aluminum plate's going to do much. Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 16, 2005
Subject: Toe in again
As I'm nearing final completion, (one wing on today before the rain hit,) I'm measuring various items. Today it was toe-in. As the previous builder had built new, stronger, tube gear I assumed, wrongly, that he would put it together straight. Unfortunately, it appears I've got about 3/4 degree toe-in per wheel when level and about 1.5 degree toe-in per wheel when on the tail wheel. He built the wheels cambered in about 5 degrees, so the toe-in goes from negative to positive as the tube gear pivots. I'd guess it's 0 at about max deflection. I guess I'll learn more during taxi and early flight tests. Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 16, 2005
Why bolts? Long before the tension & compression forces on the wings (that put shear on the fore & aft pins/bolts) would ever cause failure of either the clevis pins in the front, the bolts in the rear, or failure of the spar attach points for that matter, you'll find those little threaded AN fittings rosette welded into the lift struts ends will fail from the flight loads. If the wings were being slung like rotors I guess there might be a concern. However, the weak point in the kitfox wings are the upper lift strut attach points. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Guy Buchanan Subject: Re: Kitfox-List: Re: Clevis movement At 02:24 PM 10/15/2005, you wrote: >I replaced the pins with AN45-32 eyebolts, castellated nuts and cotters. I >can then use the eyebolts as lifting eyes when changing from wheels to >floats and back. This is a great idea. I personally think the spar holes should be captured with bolts. Otherwise there's no requirement that they stay in contact with the associated fuselage frame tube. With a clevis, the spar reinforcements can splay up and down, bending the clevis pin and ultimately failing. (I know, it's never happened.) Capturing the spars keeps them round and the attachment bolts in (almost) pure shear. Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 16, 2005
As I am finishing my molel IV I have the same probles with the factory gear. Dont remember the exact #s but I wonder if this is normal? Any one Know? -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Guy Buchanan Subject: Kitfox-List: Toe in again As I'm nearing final completion, (one wing on today before the rain hit,) I'm measuring various items. Today it was toe-in. As the previous builder had built new, stronger, tube gear I assumed, wrongly, that he would put it together straight. Unfortunately, it appears I've got about 3/4 degree toe-in per wheel when level and about 1.5 degree toe-in per wheel when on the tail wheel. He built the wheels cambered in about 5 degrees, so the toe-in goes from negative to positive as the tube gear pivots. I'd guess it's 0 at about max deflection. I guess I'll learn more during taxi and early flight tests. Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: KF II Motor Mount on ebay
curious what is the difference...? I have a KF2 .... had an 532 original box and installed a 582 BH "E" box, took some doing but engine mount was the same.... Thanks Dave ________________________________________________________________________________
Subject: Re: Toe in again
Date: Oct 16, 2005
Hi Guy, On hard surface runways (blacktop, concrete), you and your Kitfox will probably do a lot of "dancing", unless the two toe-ins are near perfect. I had one near 0, the other toed in a bit, and it sure did "dance" on landing. Takeoffs were ok. Cheers, bh > As I'm nearing final completion, (one wing on today before the rain hit,) > I'm measuring various items. Today it was toe-in. As the previous builder > had built new, stronger, tube gear I assumed, wrongly, that he would put > it > together straight. Unfortunately, it appears I've got about 3/4 degree > toe-in per wheel when level and about 1.5 degree toe-in per wheel when on > the tail wheel. He built the wheels cambered in about 5 degrees, so the > toe-in goes from negative to positive as the tube gear pivots. I'd guess > it's 0 at about max deflection. I guess I'll learn more during taxi and > early flight tests. > > > Guy Buchanan ________________________________________________________________________________
Subject: Battery
Date: Oct 17, 2005
some time ago there was a discussion about batteries for 'Foxes and a site was given "batteries4everthing". Does anyone know what model number/brand fits the plastic battery case that came with the model IV kit. The Yacht brand battery I have been using fails after about 12 months. John Kerr some time ago there was a discussion about batteries for 'Foxes and a site was given "batteries4everthing". Does anyone know what model number/brand fits the plastic battery case that came with the model IV kit. The Yacht brand battery I have been using fails after about 12 months. John Kerr ________________________________________________________________________________
Subject: Battery
Date: Oct 17, 2005
John, I have been using a sealed battery over the last 2 years and have been very pleased.. have sold several of them. About half way down the page.... http://sportplanellc.com/Products.htm Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of kerrjohna(at)comcast.net Subject: Kitfox-List: Battery some time ago there was a discussion about batteries for 'Foxes and a site was given "batteries4everthing". Does anyone know what model number/brand fits the plastic battery case that came with the model IV kit. The Yacht brand battery I have been using fails after about 12 months. John Kerr some time ago there was a discussion about batteries for 'Foxes and a site was given "batteries4everthing". Does anyone know what model number/brand fits the plastic battery case that came with the model IV kit. The Yacht brand battery I have been using fails after about 12 months. John Kerr ________________________________________________________________________________
Subject: Re: Need Series 5 cowling
Date: Oct 17, 2005
Hi Listers, Its time to start my hunt for a Series 5 top & bottom cowl. It must be the one for the Lycombing or Continental engine which is the "Cessna" style. I have a round cowl set which would be good for a Rotax 912 engine for sale too. Thanks, Ron N55KF Hi Listers, Its time to start my hunt for a Series 5 top bottom cowl. It must be the one for the Lycombing or Continental engine which is the "Cessna" style. I have a round cowl set which would be good for a Rotax 912 engine for sale too. Thanks, Ron N55KF ________________________________________________________________________________
Date: Oct 17, 2005
Subject: rear spar spacer
hi, I`m building the wings for my c4 and it is not clear to me if the rear spar bracket location dimension of 96 1/4 should be measured from the rear spar root location with or without the 1/2 inch spacer on the wing fixture. Should the dimension be taken from the spar tube beginning or from behind the spacer. thank`s to all. JF Hebert ________________________________________________________________________________
Subject: Upper Strut Attach Point
Date: Oct 17, 2005
OK, someone finally said it. I have thought for sometime now that the upper strut attach point (5/16 bolt in tension) is the weak spot in the KF airframe. I don't know of or have not heard of a failure, (but if it did). Has anyone else looked at this or contemplated a re-enforcement or is it just fine and Aeroncas and Cubs and 120s just way over built? Brett ________________________________________________________________________________
Date: Oct 17, 2005
I think John McBean has a reinforcement kit for this. I have seen pics of it, but not installed in a real airplane. From a technical standpoint, isn't that bolt, pin, etc, in shear, not tension? Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Brett Walmsley Subject: Kitfox-List: Upper Strut Attach Point OK, someone finally said it. I have thought for sometime now that the upper strut attach point (5/16 bolt in tension) is the weak spot in the KF airframe. I don't know of or have not heard of a failure, (but if it did). Has anyone else looked at this or contemplated a re-enforcement or is it just fine and Aeroncas and Cubs and 120s just way over built? Brett ________________________________________________________________________________
Subject: SkyStar
Date: Oct 17, 2005
I was asked to pass on a message and there is just no easy way to say it Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although the phones are still being answered with voice mail there is no one there to get the messages and the web is not being monitored This is a Chapter 7 and was filed on Friday 10-14-05. People involved should get a letter from the courts. As always, we are here to help with any support questions regarding your Kitfox.. Although, we cannot provide all the parts we can supply most of them please give us a shout if we can help. Fly Safe !! John & Debra McBean www.sportplanellc.com <http://www.sportplanellc.com/> "The Sky is not the Limit... It's a Playground" ________________________________________________________________________________
Subject: SkyStar
Date: Oct 17, 2005
Thanks for the verification, John. I have been getting messages from various sources and trying to get this substantiated today before sending it out to the list. This is not the end, though. There are buyers in the wings waiting to take over the assets and the business. I doubt if they will take over any debt or obligations, however. Chapter 7 is the "bad" bankruptcy, where the business is essentially dissolved and must sell off everything. Good luck to Frank Miller and the rest of the SS staff, I know they tried hard to avoid this. As John said, this list will continue and we will provide support to each other. Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jdmcbean Subject: Kitfox-List: SkyStar I was asked to pass on a message and there is just no easy way to say it Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although the phones are still being answered with voice mail there is no one there to get the messages and the web is not being monitored This is a Chapter 7 and was filed on Friday 10-14-05. People involved should get a letter from the courts. As always, we are here to help with any support questions regarding your Kitfox.. Although, we cannot provide all the parts we can supply most of them please give us a shout if we can help. Fly Safe !! John & Debra McBean www.sportplanellc.com <http://www.sportplanellc.com/> "The Sky is not the Limit... It's a Playground" ________________________________________________________________________________
Date: Oct 17, 2005
Don, I don't think John has a kit for the lift strut? We're talking the upper rod end fittings. When Skystar did the original static load tests it was the AN threaded fitting that failed. With that said, the spars were so close to failure that it probably didn't matter anyway. Personally, I wouldn't worry about those rod end fittings unless you're used to pulling over 5Gs regularly. Negative loading will yield at somewhat less since those threaded fittings will bend prior to failure but we're still talking over 4Gs negative if I remember correctly. Either way, I wouldn't sweat the struts... Regards, Ted -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Don Pearsall Subject: RE: Kitfox-List: Upper Strut Attach Point I think John McBean has a reinforcement kit for this. I have seen pics of it, but not installed in a real airplane. From a technical standpoint, isn't that bolt, pin, etc, in shear, not tension? Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Brett Walmsley Subject: Kitfox-List: Upper Strut Attach Point OK, someone finally said it. I have thought for sometime now that the upper strut attach point (5/16 bolt in tension) is the weak spot in the KF airframe. I don't know of or have not heard of a failure, (but if it did). Has anyone else looked at this or contemplated a re-enforcement or is it just fine and Aeroncas and Cubs and 120s just way over built? Brett ________________________________________________________________________________
From: "Len Shorethose" <toolowterrain(at)gmail.com>
Subject: Re: SkyStar
Date: Oct 17, 2005
Just a note to all those who are waiting on parts or entire kits like myself. You may have some protection if you ordered anything from Skystar and paid with a credit card. Just call your credit card company and have the charges reversed. I have done so already with the $20K that I gave them the last six months while waiting for my Series 7. I'm told that I will receive a complete refund. We'll see. Now does anyone know of a buyer for my zero time Lycoming O-235L2C ? Len Shorethose ----- Original Message ----- From: "Don Pearsall" <donpearsall(at)comcast.net> Subject: RE: Kitfox-List: SkyStar > > > Thanks for the verification, John. I have been getting messages from > various > sources and trying to get this substantiated today before sending it out > to > the list. > > This is not the end, though. There are buyers in the wings waiting to take > over the assets and the business. I doubt if they will take over any debt > or > obligations, however. Chapter 7 is the "bad" bankruptcy, where the > business > is essentially dissolved and must sell off everything. > > Good luck to Frank Miller and the rest of the SS staff, I know they tried > hard to avoid this. > > As John said, this list will continue and we will provide support to each > other. > > > Don Pearsall > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jdmcbean > To: Kitfox List > Subject: Kitfox-List: SkyStar > > > I was asked to pass on a message and there is just no easy way to say it > Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although > the > phones are still being answered with voice mail there is no one there to > get > the messages and the web is not being monitored This is a Chapter 7 and > was filed on Friday 10-14-05. People involved should get a letter from > the > courts. > > As always, we are here to help with any support questions regarding your > Kitfox.. Although, we cannot provide all the parts we can supply most of > them please give us a shout if we can help. > > > Fly Safe !! > John & Debra McBean > www.sportplanellc.com <http://www.sportplanellc.com/> > "The Sky is not the Limit... It's a Playground" > > > ________________________________________________________________________________
Subject: Parts
Date: Oct 17, 2005
I just talked to one of the lucky ones who recieved parts last week from skystar. Blue Skies Bob Unternaehrer shilocom(at)mcmsys.com ________________________________________________________________________________
Date: Oct 17, 2005
Don, I think what you are doing with the front spars using Castle Bolts and nuts with cotter pins are the best thing anyone can do. I had the same problem Bill In Maine had with the Clevis bolt creeping up, and didn't notice until I did my annual Conditioning inspection. The Safety pin on the left wing only, was extra tight and had started to wear. I exchanged it for a cotter pin which was a lot stronger, but I am going to change it to a Castle Bolt and Nut with cotter pin. I only fold the wings back once a year so certainly no inconvienious . This was a topic a year ago or so and there is really nothing to worry about. The Clevis bolt could come clear out while flying, and aerodynamic's would keep the wing going forward. David Yeamans ----- Original Message ----- From: Don Smythe To: kitfox-list(at)matronics.com Sent: Saturday, October 15, 2005 6:05 PM Subject: Re: Kitfox-List: Clevis movement Loyd, Good question. I opted to do the same but I use castle nuts w/ cotter pins on the front. I don't torque them down to any specific torque but rather run them down and just add a little more. I don't want to squeeze too much. Any pro's to this procedure would be appreciated. Don Smythe ----- Original Message ----- From: "Cudnohufsky's" <7suds(at)chartermi.net> To: Subject: Re: Kitfox-List: Clevis movement > > Bill, > Never had the problem but also never liked the idea of the clevised pin > either. I opted to use a threaded bolt with Nylock in the front the same > as > the rear, I liked the idea of keeping everything drawn tight, but I also > never checked with Skystar to see if there was any flaws in my thinking. > Anyone else? > Lloyd > ----- Original Message ----- > From: "Chenoweth" <chenoweth(at)gwi.net> > To: > Subject: Kitfox-List: Clevis movement > > >> >> Here's a situation I discovered the other day and I wonder if anyone on >> the list has experienced something similar. >> >> The clevis pin that attaches the right front spar to the carry thru wants >> to work its way up. This may have been going on forever but I just >> noticed that the safety pin was up solidly against the spar about 11 >> flight hours ago and pounded the clevis pin fully down. The clevis pin >> is >> now about halfway back up. There is obviously motion somewhere. >> >> There is no obvious looseness in the joint. The left wing doesn't >> manifest this tendency at all. I have a 13 gallon tank on the right and >> fly with it from full to 1/2 full all the time. I don't put any gas in >> my >> left tank and have shutoffs to keep the tanks from cross feeding. In >> other words the right wing weighs 50 pounds or so more than the left. >> >> Other than to note that the safety pins are in there for a reason I have >> no idea if this is a common event or if my plane is unique. Nor do I >> know >> if it is a symptom of something bad. >> >> So if any one has this happening I'd surely like to know and what, if >> anything, was done to correct it. >> >> Thanks very much. >> Bill in Maine >> IV-1200 (582) with 160 hours >> >> >> > > > ________________________________________________________________________________
Subject: Fw: Parts
Date: Oct 17, 2005
----- Original Message ----- From: Bob Unternaehrer Subject: Parts I just talked to one of the lucky ones who recieved parts last week from skystar. Blue Skies Bob Unternaehrer shilocom(at)mcmsys.com ________________________________________________________________________________
Subject: Re: Skystar
Date: Oct 17, 2005
Rex, My very Sentiments, Bravo !!!!! David ----- Original Message ----- From: Rex & Jan Shaw To: kitfox-list(at)matronics.com Sent: Saturday, October 15, 2005 7:18 PM Subject: Kitfox-List: Skystar Does anyone else have problems with Skystar? We bought 10 kits and brought them to South Africa 1 year ago. To be honest the level of service from Skystar since Ed Downs left has been non existent. They never answer emails, never return phone calls, never send out an order without being chased and even then only after several months. Does anyone know what is going on as they have not been answering their phones at all for 3 days and the message answering service is FULL and will take no more messages. Will they go bust OR what? Guys I had my own business for over 30yrs before I sold out and retired. A couple of years in we ran close to the wind financially. At that time we couldn't buy what we wanted. Our credit rating was shaky and we couldn't always supply what the customer wanted. Staff was cut back and so service was difficult to maintain. However we struggled through and went on to do very well. I know we all need to have Skystar there and I think if we don't make it too hard for them with unnecessary negative feedback they have a good chance of coming good in the end. Yes they probably could try harder to answer the phone and be honest about deliveries. However they can't deliver what they don't have and can't get. If you wan't Skystar there please give them a go. They have admitted to this list only about 12 months ago that their problems were financial based. I think that was very difficult for them to do. Give them credit for that ! Yes I do understand if you are on the wrong end of the stick and not getting things especially if you have paid for them. If that's your personal experience then you do have the right to complain but consider first. Perhaps your complaining might even be the straw that breaks the camels back so that in fact the goods you are waiting for that would have eventually come might then not come at all because Skystar does dissapear. Rex. rexjan(at)bigpond.com ________________________________________________________________________________
Date: Oct 18, 2005
Is that a fact that the wing will stay in its flying configuration even if the clevis pins comes out?. I'm having a bit of trouble getting my head around that one. Could someone please explain how because my gut feel is that the wing would fold back immediately the pin was released. Graeme Toft ----- Original Message ----- From: "david yeamans" <dafox(at)ckt.net> Subject: Re: Kitfox-List: Clevis movement > > Don, > > I think what you are doing with the front spars using Castle Bolts > and nuts with cotter pins > are the best thing anyone can do. I had the same problem Bill In Maine > had with the Clevis bolt > creeping up, and didn't notice until I did my annual Conditioning > inspection. The Safety pin on > the left wing only, was extra tight and had started to wear. I exchanged > it for a cotter pin which > was a lot stronger, but I am going to change it to a Castle Bolt and Nut > with cotter pin. I only fold > the wings back once a year so certainly no inconvienious . This was a > topic a year ago or so > and there is really nothing to worry about. The Clevis bolt could come > clear out while flying, and > aerodynamic's would keep the wing going forward. > > > David Yeamans > > > ----- Original Message ----- > From: Don Smythe > To: kitfox-list(at)matronics.com > Sent: Saturday, October 15, 2005 6:05 PM > Subject: Re: Kitfox-List: Clevis movement > > > Loyd, > Good question. I opted to do the same but I use castle nuts w/ > cotter > pins on the front. I don't torque them down to any specific torque but > rather run them down and just add a little more. I don't want to squeeze > too much. Any pro's to this procedure would be appreciated. > > Don Smythe > > ----- Original Message ----- > From: "Cudnohufsky's" <7suds(at)chartermi.net> > To: > Subject: Re: Kitfox-List: Clevis movement > > > <7suds(at)chartermi.net> > > > > Bill, > > Never had the problem but also never liked the idea of the clevised pin > > either. I opted to use a threaded bolt with Nylock in the front the > same > > as > > the rear, I liked the idea of keeping everything drawn tight, but I > also > > never checked with Skystar to see if there was any flaws in my > thinking. > > Anyone else? > > Lloyd > > ----- Original Message ----- > > From: "Chenoweth" <chenoweth(at)gwi.net> > > To: > > Subject: Kitfox-List: Clevis movement > > > > > >> > >> Here's a situation I discovered the other day and I wonder if anyone > on > >> the list has experienced something similar. > >> > >> The clevis pin that attaches the right front spar to the carry thru > wants > >> to work its way up. This may have been going on forever but I just > >> noticed that the safety pin was up solidly against the spar about 11 > >> flight hours ago and pounded the clevis pin fully down. The clevis > pin > >> is > >> now about halfway back up. There is obviously motion somewhere. > >> > >> There is no obvious looseness in the joint. The left wing doesn't > >> manifest this tendency at all. I have a 13 gallon tank on the right > and > >> fly with it from full to 1/2 full all the time. I don't put any gas > in > >> my > >> left tank and have shutoffs to keep the tanks from cross feeding. In > >> other words the right wing weighs 50 pounds or so more than the left. > >> > >> Other than to note that the safety pins are in there for a reason I > have > >> no idea if this is a common event or if my plane is unique. Nor do I > >> know > >> if it is a symptom of something bad. > >> > >> So if any one has this happening I'd surely like to know and what, if > >> anything, was done to correct it. > >> > >> Thanks very much. > >> Bill in Maine > >> IV-1200 (582) with 160 hours > >> > >> > >> > > > > > > > > > -- > > ________________________________________________________________________________
Date: Oct 17, 2005
At 06:42 PM 10/17/2005, you wrote: >Personally, I wouldn't worry about >those rod end fittings unless you're used to pulling over 5Gs regularly. Well, You got me thinking. A bad thing. Blew an entire evening. individual strut load of 757 pounds, assuming constant loading over the span and both struts loaded equally. (A dubious assumption, at best.) My strut ends are Aurora MW-4H-12's, which appear to be custom units, consisting of 5/16" bodies with 9/16" wide balls drilled to 1/4. Since Skystar supplied AN hardware, this was a reasonable thing to do. Now my Aurora catalog shows MW-5 (5/16") spherical bearings have a radial static load capacity of 3133 pounds. This gives a reserve factor of 4.1. Yes folks, that means the spherical bearing will fail at a load factor of 4.1. Hmmm. I wonder what happened to six. Next I checked the threads. The 5/16-24 threads have a tensile stress area of .058 sq. in. This gives an average stress across the threads of 13ksi. I checked McMaster Carr for threaded rod and found the following three possibilities: 18-8 Stainless, "minimum tensile strength" = 70ksi, failure load factor = 5.4 Non Rated steel, "minimum tensile strength" = 58ksi, failure load factor = 4.5 Grade B7 steel, "minimum tensile strength" = 125ksi, failure load factor = 9.6 Any bets on which Skystar used? I'd bet mild steel. I haven't even addressed stress concentration factors or fatigue life, though the low strength steels will have superior fatigue life and higher crack resistance. As an aside, the 1/4" bolt, being AN hardware and therefore 125ksi tensile material, is good for about 7.7ksi in shear, giving load factor to failure of about 10.2. possibility reduce my maximum load factor to about 2.7. This would reduce Vno by about 18%. (For example, a K-IV-1200 Vno would go from 99 mph to 81 mph.) I don't know if Vne would change. Of course you could always modify your struts. (Does anybody know what Skystar did in '01 to beef up the struts? I saw replacement struts available on the web site.) series units, good to 7639 pounds. (I may do this anyway. Make sure the ball is custom made to fit the wing fitting. Don't fill with washers.) I'd also replace the stud with a larger diameter Grade B7 steel. It looks like you might be able to use a 3/8" body (AW-6) with a custom ball. (1/4" hole and 7/16" width.) If I can remember tomorrow I'll call Aurora and see what's possible. PS Does anyone have a pair of good pre-'01 K-IV-1200 struts they'd give/sell me? I'll pull them and get some answers for us. Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 17, 2005
Subject: VFR Lighting Requirements
INNOCENT GLOBAL 0.0000 1.0000 -4.4912 All, Currently my day VFR Kitfox has no lights. It appears I am required to run an anti-collision light at a minimum. (FAR 91.205b11) Does this sound correct? Does anyone have a recommendation for a minimalist anti-collision light system? Thank you in advance, Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Subject: radiator scoop
Date: Oct 18, 2005
I have a kitfox III with a 582, I installed a scoop on the radiator and wonder if anyone has done same and can tell me what the height of the opening should be to get proper cooling for the 582. thanks, Bill Durham ________________________________________________________________________________
Subject: Re: VFR Lighting Requirements INNOCENT GLOBAL 0.0000
1.0000 -4.4912
Date: Oct 18, 2005
I saw Van's new RV 10 in TX and he did not have strobes or nav lights. Vic ----- Original Message ----- From: "Guy Buchanan" <bnn(at)nethere.com> Subject: Kitfox-List: VFR Lighting Requirements INNOCENT GLOBAL 0.0000 1.0000 -4.4912 > > All, > Currently my day VFR Kitfox has no lights. It appears I am > required to run an anti-collision light at a minimum. (FAR 91.205b11) Does > this sound correct? Does anyone have a recommendation for a minimalist > anti-collision light system? > > Thank you in advance, > > > Guy Buchanan > K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. > > > ________________________________________________________________________________
Date: Oct 18, 2005
Look at where the lower lift strut attach is positioned. With the wing generating lift, the front spars are pushing inward on the spar carry-thru. The rear spars are pulling outward... --- Original Message --- From: "Graeme Toft" <msm(at)byterocky.net> Subject: Re: Kitfox-List: Clevis movement > >Is that a fact that the wing will stay in its flying configuration even if >the clevis pins comes out?. I'm having a bit of trouble getting my head >around that one. Could someone please explain how because my gut feel is >that the wing would fold back immediately the pin was released. > >Graeme Toft >----- Original Message ----- >From: "david yeamans" <dafox(at)ckt.net> >To: >Subject: Re: Kitfox-List: Clevis movement > > >> >> Don, >> >> I think what you are doing with the front spars using Castle Bolts >> and nuts with cotter pins >> are the best thing anyone can do. I had the same problem Bill In Maine >> had with the Clevis bolt >> creeping up, and didn't notice until I did my annual Conditioning >> inspection. The Safety pin on >> the left wing only, was extra tight and had started to wear. I exchanged >> it for a cotter pin which >> was a lot stronger, but I am going to change it to a Castle Bolt and Nut >> with cotter pin. I only fold >> the wings back once a year so certainly no inconvienious . This was a >> topic a year ago or so >> and there is really nothing to worry about. The Clevis bolt could come >> clear out while flying, and >> aerodynamic's would keep the wing going forward. >> >> >> David Yeamans >> >> >> ----- Original Message ----- >> From: Don Smythe >> To: kitfox-list(at)matronics.com >> Sent: Saturday, October 15, 2005 6:05 PM >> Subject: Re: Kitfox-List: Clevis movement >> >> >> >> Loyd, >> Good question. I opted to do the same but I use castle nuts w/ >> cotter >> pins on the front. I don't torque them down to any specific torque but >> rather run them down and just add a little more. I don't want to squeeze >> too much. Any pro's to this procedure would be appreciated. >> >> Don Smythe >> >> ----- Original Message ----- >> From: "Cudnohufsky's" <7suds(at)chartermi.net> >> To: >> Subject: Re: Kitfox-List: Clevis movement >> >> >> > --> Kitfox-List message posted by: "Cudnohufsky's" >> <7suds(at)chartermi.net> >> > >> > Bill, >> > Never had the problem but also never liked the idea of the clevised pin >> > either. I opted to use a threaded bolt with Nylock in the front the >> same >> > as >> > the rear, I liked the idea of keeping everything drawn tight, but I >> also >> > never checked with Skystar to see if there was any flaws in my >> thinking. >> > Anyone else? >> > Lloyd >> > ----- Original Message ----- >> > From: "Chenoweth" <chenoweth(at)gwi.net> >> > To: >> > Subject: Kitfox-List: Clevis movement >> > >> > >> >> >> >> Here's a situation I discovered the other day and I wonder if anyone >> on >> >> the list has experienced something similar. >> >> >> >> The clevis pin that attaches the right front spar to the carry thru >> wants >> >> to work its way up. This may have been going on forever but I just >> >> noticed that the safety pin was up solidly against the spar about 11 >> >> flight hours ago and pounded the clevis pin fully down. The clevis >> pin >> >> is >> >> now about halfway back up. There is obviously motion somewhere. >> >> >> >> There is no obvious looseness in the joint. The left wing doesn't >> >> manifest this tendency at all. I have a 13 gallon tank on the right >> and >> >> fly with it from full to 1/2 full all the time. I don't put any gas >> in >> >> my >> >> left tank and have shutoffs to keep the tanks from cross feeding. In >> >> other words the right wing weighs 50 pounds or so more than the left. >> >> >> >> Other than to note that the safety pins are in there for a reason I >> have >> >> no idea if this is a common event or if my plane is unique. Nor do I >> >> know >> >> if it is a symptom of something bad. >> >> >> >> So if any one has this happening I'd surely like to know and what, if >> >> anything, was done to correct it. >> >> >> >> Thanks very much. >> >> Bill in Maine >> >> IV-1200 (582) with 160 hours >> >> >> >> >> >> >> > >> > >> > >> >> >> -- >> >> > > >_- ====================================================== ====== browse Subscriptions page, FAQ, List >_- ====================================================== ====== > > ________________________________________________________________________________
Date: Oct 18, 2005
There's no requirement for lights for day VFR. --- Original Message --- From: "Vic Jacko" <vicwj(at)earthlink.net> Subject: Re: Kitfox-List: VFR Lighting Requirements INNOCENT GLOBAL 0.0000 1.0000 - 4.4912 > >I saw Van's new RV 10 in TX and he did not have strobes or nav lights. > >Vic >----- Original Message ----- >From: "Guy Buchanan" <bnn(at)nethere.com> >To: ; >Subject: Kitfox-List: VFR Lighting Requirements INNOCENT GLOBAL 0.0000 >1.0000 -4.4912 > > >> >> All, >> Currently my day VFR Kitfox has no lights. It appears I am >> required to run an anti-collision light at a minimum. (FAR 91.205b11) Does >> this sound correct? Does anyone have a recommendation for a minimalist >> anti-collision light system? >> >> Thank you in advance, >> >> >> Guy Buchanan >> K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. >> >> >> > > >_- ====================================================== ====== browse Subscriptions page, FAQ, List >_- ====================================================== ====== > > ________________________________________________________________________________
Date: Oct 18, 2005
Graeme, This has been a topic that has surfaced numerous times in the past. I frankly strugle with it a bit also, but I remember once a guy ewporting on the list that he was trailering a newly completed and unflown Kitfox to the airport and the wing holddown came loose on one side and before he could stop the wing had extended and mowed down a couple of roadside signs. Lowell ----- Original Message ----- From: "Graeme Toft" <msm(at)byterocky.net> Subject: Re: Kitfox-List: Clevis movement > > Is that a fact that the wing will stay in its flying configuration even if > the clevis pins comes out?. I'm having a bit of trouble getting my head > around that one. Could someone please explain how because my gut feel is > that the wing would fold back immediately the pin was released. > > Graeme Toft > ----- Original Message ----- > From: "david yeamans" <dafox(at)ckt.net> > To: > Subject: Re: Kitfox-List: Clevis movement > > >> >> Don, >> >> I think what you are doing with the front spars using Castle Bolts >> and nuts with cotter pins >> are the best thing anyone can do. I had the same problem Bill In Maine >> had with the Clevis bolt >> creeping up, and didn't notice until I did my annual Conditioning >> inspection. The Safety pin on >> the left wing only, was extra tight and had started to wear. I exchanged >> it for a cotter pin which >> was a lot stronger, but I am going to change it to a Castle Bolt and Nut >> with cotter pin. I only fold >> the wings back once a year so certainly no inconvienious . This was a >> topic a year ago or so >> and there is really nothing to worry about. The Clevis bolt could come >> clear out while flying, and >> aerodynamic's would keep the wing going forward. >> >> >> David Yeamans >> >> >> ----- Original Message ----- >> From: Don Smythe >> To: kitfox-list(at)matronics.com >> Sent: Saturday, October 15, 2005 6:05 PM >> Subject: Re: Kitfox-List: Clevis movement >> >> >> >> Loyd, >> Good question. I opted to do the same but I use castle nuts w/ >> cotter >> pins on the front. I don't torque them down to any specific torque but >> rather run them down and just add a little more. I don't want to >> squeeze >> too much. Any pro's to this procedure would be appreciated. >> >> Don Smythe >> >> ----- Original Message ----- >> From: "Cudnohufsky's" <7suds(at)chartermi.net> >> To: >> Subject: Re: Kitfox-List: Clevis movement >> >> >> <7suds(at)chartermi.net> >> > >> > Bill, >> > Never had the problem but also never liked the idea of the clevised >> pin >> > either. I opted to use a threaded bolt with Nylock in the front the >> same >> > as >> > the rear, I liked the idea of keeping everything drawn tight, but I >> also >> > never checked with Skystar to see if there was any flaws in my >> thinking. >> > Anyone else? >> > Lloyd >> > ----- Original Message ----- >> > From: "Chenoweth" <chenoweth(at)gwi.net> >> > To: >> > Subject: Kitfox-List: Clevis movement >> > >> > >> >> >> >> Here's a situation I discovered the other day and I wonder if anyone >> on >> >> the list has experienced something similar. >> >> >> >> The clevis pin that attaches the right front spar to the carry thru >> wants >> >> to work its way up. This may have been going on forever but I just >> >> noticed that the safety pin was up solidly against the spar about 11 >> >> flight hours ago and pounded the clevis pin fully down. The clevis >> pin >> >> is >> >> now about halfway back up. There is obviously motion somewhere. >> >> >> >> There is no obvious looseness in the joint. The left wing doesn't >> >> manifest this tendency at all. I have a 13 gallon tank on the right >> and >> >> fly with it from full to 1/2 full all the time. I don't put any gas >> in >> >> my >> >> left tank and have shutoffs to keep the tanks from cross feeding. In >> >> other words the right wing weighs 50 pounds or so more than the left. >> >> >> >> Other than to note that the safety pins are in there for a reason I >> have >> >> no idea if this is a common event or if my plane is unique. Nor do I >> >> know >> >> if it is a symptom of something bad. >> >> >> >> So if any one has this happening I'd surely like to know and what, if >> >> anything, was done to correct it. >> >> >> >> Thanks very much. >> >> Bill in Maine >> >> IV-1200 (582) with 160 hours >> >> >> >> >> >> >> > >> > >> > >> >> >> -- >> >> > > > ________________________________________________________________________________
From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com>
Date: Oct 18, 2005
You only need a good anti-collision light if you plan on flying the 30 min's before/after sunrise/sunset. Andrew >From: "flier" <FLIER(at)sbcglobal.net> >Reply-To: kitfox-list(at)matronics.com >To: , >Subject: Re: Kitfox-List: VFR Lighting Requirements Date: Tue, 18 Oct 2005 > > >There's no requirement for lights for day VFR. > > >--- Original Message --- >From: "Vic Jacko" <vicwj(at)earthlink.net> >To: >Subject: Re: Kitfox-List: VFR Lighting >Requirements INNOCENT GLOBAL 0.0000 1.0000 - >4.4912 > > > > > >I saw Van's new RV 10 in TX and he did not have >strobes or nav lights. > > > >Vic > >----- Original Message ----- > >From: "Guy Buchanan" <bnn(at)nethere.com> > >To: ; list(at)matronics.com> > >Subject: Kitfox-List: VFR Lighting Requirements >INNOCENT GLOBAL 0.0000 > >1.0000 -4.4912 > > > > > > >> > >> All, > >> Currently my day VFR Kitfox has no lights. >It appears I am > >> required to run an anti-collision light at a >minimum. (FAR 91.205b11) Does > >> this sound correct? Does anyone have a >recommendation for a minimalist > >> anti-collision light system? > >> > >> Thank you in advance, > >> > >> > >> Guy Buchanan > >> K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob >Ducar. > >> > >> > >> > > > > > >_- >====================================================== >====== >browse >Subscriptions page, >FAQ, >List > >_- >====================================================== >====== > > > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Subject: Parts for Sale for 912S
Date: Oct 18, 2005
I am sorry if the report is true about Skystar. If anyone is interested in these parts please let me know-I have been building an Avid. -brand new Skystar 912/s choke kit-was $52 with shipping-now $35 includes shipping -brand new 912s Rotax radiator. Is $346 retail plus $20 shipping -now $310 includes shipping -radiator brackets for 912S radiator hangs in front of engine like the Avid-$50 -912S installation DVD-pretty good DVD-$18 email or call 7042315204 ________________________________________________________________________________
Date: Oct 18, 2005
At 06:42 PM 10/17/2005, you wrote: >Personally, I wouldn't worry about >those rod end fittings unless you're used to pulling over 5Gs regularly. I went back and reduced the strut loads by an 80 pound wing weight and 78 pounds of fuel in the inboard 36". This reduced the nominal 1-g strut load to 636 pounds which improved the eye safety factor to 4.9 and the threaded rod safety factor to 5.3, both still well below 6. The eye safety factor reduces the Vno by about 10%, bringing it from 99 mph to 89 mph. Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 18, 2005
Many years ago before Skystar, I think it was Dan Denny that said (if you have what it takes) you could pull those front pins while the aircraft is in flight and nothing would happen. Something to do with where the center of lift is and the configuration of the struts. Of course, I have no knowlege of anyone who was able to provide proof of that assertion. Anybody want to give it a whirl? Deke > > Look at where the lower lift strut attach is > positioned. With the wing generating lift, the front > spars are pushing inward on the spar carry-thru. The > rear spars are pulling outward... > > > --- Original Message --- > From: "Graeme Toft" <msm(at)byterocky.net> > To: > Subject: Re: Kitfox-List: Clevis movement > > > > > >Is that a fact that the wing will stay in its flying > configuration even if > >the clevis pins comes out?. I'm having a bit of > trouble getting my head > >around that one. Could someone please explain how > because my gut feel is > >that the wing would fold back immediately the pin > was released. > > > >Graeme Toft > >----- Original Message ----- > >From: "david yeamans" <dafox(at)ckt.net> > >To: > >Subject: Re: Kitfox-List: Clevis movement > > > > > > >> > >> Don, > >> > >> I think what you are doing with the front > spars using Castle Bolts > >> and nuts with cotter pins > >> are the best thing anyone can do. I had the same > problem Bill In Maine > >> had with the Clevis bolt > >> creeping up, and didn't notice until I did my > annual Conditioning > >> inspection. The Safety pin on > >> the left wing only, was extra tight and had > started to wear. I exchanged > >> it for a cotter pin which > >> was a lot stronger, but I am going to change it to > a Castle Bolt and Nut > >> with cotter pin. I only fold > >> the wings back once a year so certainly no > inconvienious . This was a > >> topic a year ago or so > >> and there is really nothing to worry about. The > Clevis bolt could come > >> clear out while flying, and > >> aerodynamic's would keep the wing going forward. > >> > >> > >> David Yeamans > >> > >> > >> ----- Original Message ----- > >> From: Don Smythe > >> To: kitfox-list(at)matronics.com > >> Sent: Saturday, October 15, 2005 6:05 PM > >> Subject: Re: Kitfox-List: Clevis movement > >> > >> > > >> > >> Loyd, > >> Good question. I opted to do the same but I > use castle nuts w/ > >> cotter > >> pins on the front. I don't torque them down to > any specific torque but > >> rather run them down and just add a little more. > I don't want to squeeze > >> too much. Any pro's to this procedure would be > appreciated. > >> > >> Don Smythe > >> > >> ----- Original Message ----- > >> From: "Cudnohufsky's" <7suds(at)chartermi.net> > >> To: > >> Subject: Re: Kitfox-List: Clevis movement > >> > >> > >> > --> Kitfox-List message posted > by: "Cudnohufsky's" > >> <7suds(at)chartermi.net> > >> > > >> > Bill, > >> > Never had the problem but also never liked the > idea of the clevised pin > >> > either. I opted to use a threaded bolt with > Nylock in the front the > >> same > >> > as > >> > the rear, I liked the idea of keeping > everything drawn tight, but I > >> also > >> > never checked with Skystar to see if there was > any flaws in my > >> thinking. > >> > Anyone else? > >> > Lloyd > >> > ----- Original Message ----- > >> > From: "Chenoweth" <chenoweth(at)gwi.net> > >> > To: > >> > Subject: Kitfox-List: Clevis movement > >> > > >> > > > >> >> > >> >> Here's a situation I discovered the other day > and I wonder if anyone > >> on > >> >> the list has experienced something similar. > >> >> > >> >> The clevis pin that attaches the right front > spar to the carry thru > >> wants > >> >> to work its way up. This may have been going > on forever but I just > >> >> noticed that the safety pin was up solidly > against the spar about 11 > >> >> flight hours ago and pounded the clevis pin > fully down. The clevis > >> pin > >> >> is > >> >> now about halfway back up. There is obviously > motion somewhere. > >> >> > >> >> There is no obvious looseness in the joint. > The left wing doesn't > >> >> manifest this tendency at all. I have a 13 > gallon tank on the right > >> and > >> >> fly with it from full to 1/2 full all the > time. I don't put any gas > >> in > >> >> my > >> >> left tank and have shutoffs to keep the tanks > from cross feeding. In > >> >> other words the right wing weighs 50 pounds or > so more than the left. > >> >> > >> >> Other than to note that the safety pins are in > there for a reason I > >> have > >> >> no idea if this is a common event or if my > plane is unique. Nor do I > >> >> know > >> >> if it is a symptom of something bad. > >> >> > >> >> So if any one has this happening I'd surely > like to know and what, if > >> >> anything, was done to correct it. > >> >> > >> >> Thanks very much. > >> >> Bill in Maine > >> >> IV-1200 (582) with 160 hours > >> >> > >> >> > >> >> > >> > > >> > > >> > > >> > >> > >> -- > >> > >> > > > > > >_- > ====================================================== > ====== > browse > Subscriptions page, > FAQ, > List > >_- > ====================================================== > ====== > > > > > > ________________________________________________________________________________
Date: Oct 18, 2005
All, I want to join those that have expressed their sympathy for the employees of SkyStar and those that have outstanding orders with the company, this truly is bad news for everyone. As John McBean indicated, though, support for builders and pilots will continue. Murle Williams has asked me to let you all know that he will continue to offer his builder-assist program and his array of Kitfox and Avid products. Murle can be reached at: Web: http://MurleWilliamsAviation.com E-mail: murle.williams(at)juno.com Phone: (602) 978-0553 If any of you feel that you will not be able to complete your aircraft and have kits or parts you would like to sell, please contact Murle or myself off-list. Best of luck to everyone, Mike G. N728KF ________________________________________________________________________________
Date: Oct 18, 2005
I agree Guy. That's why I use 5G. 6G is ultimate (the struts broke at that value) and I don't want to experience ultimate loading! --- Original Message --- From: Guy Buchanan <bnn(at)nethere.com> Subject: RE: Kitfox-List: Upper Strut Attach Point > >At 06:42 PM 10/17/2005, you wrote: >>Personally, I wouldn't worry about >>those rod end fittings unless you're used to pulling over 5Gs regularly. > >I went back and reduced the strut loads by an 80 pound wing weight and 78 >pounds of fuel in the inboard 36". This reduced the nominal 1-g strut load >to 636 pounds which improved the eye safety factor to 4.9 and the threaded >rod safety factor to 5.3, both still well below 6. The eye safety factor >reduces the Vno by about 10%, bringing it from 99 mph to 89 mph. > > >Guy Buchanan >K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. > > >_- ====================================================== ====== browse Subscriptions page, FAQ, List >_- ====================================================== ====== > > ________________________________________________________________________________
Subject: Header Tank
Date: Oct 18, 2005
Anyone on the list have a header tank p/n 90064.000 that is surplus to your needs and would sell? p/n is from S-6 assembly manual. Jay C. ________________________________________________________________________________
Date: Oct 18, 2005
Andrew, Allow me to make a big mistake here. It's been awhile since I looked into the lighting thing. In the US, we are required lighting from sunset to sunrise. In Canada, they are required lighting from twilight to twilight. I think twilight is 1/2 hours before sunrise to 1/2 hour after sunset. So, your comment below is for Canada operators only??? Forgive me if I messed this up. Don Smythe ----- Original Message ----- From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> Subject: Re: Kitfox-List: VFR Lighting Requirements > > > You only need a good anti-collision light if you plan on flying the 30 > min's > before/after sunrise/sunset. > ________________________________________________________________________________
From: "Kerry Skyring" <kerryskyring(at)hotmail.com>
Date: Oct 18, 2005
Ron wrote, >Its time to start my hunt for a Series 5 top & bottom cowl. It must be the >one for the Lycombing or Continental engine which is the "Cessna" style. Hi Ron, we have an unused cowl for the Continental 0-200 engine on a Series 5. Problem is we are in Vienna Austria and the freight costs would probably make this non-viable for you. However keep it in mind and if you don't source anything locally give me an email and we will try to work out a viable deal. Kerry. S5 builders helper. Taxied it on Sunday. Ohitsjustwunderbar. > > ________________________________________________________________________________
Date: Oct 18, 2005
Don, That is exactly what I meant! Andrew >From: "Don Smythe" <dosmythe(at)cox.net> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Re: Kitfox-List: VFR Lighting Requirements >Date: Tue, 18 Oct 2005 13:29:27 -0400 > > >Andrew, > Allow me to make a big mistake here. It's been awhile since I looked >into the lighting thing. In the US, we are required lighting from sunset >to >sunrise. In Canada, they are required lighting from twilight to twilight. >I think twilight is 1/2 hours before sunrise to 1/2 hour after sunset. So, >your comment below is for Canada operators only??? > Forgive me if I messed this up. > >Don Smythe > >----- Original Message ----- >From: "Andrew Matthaey" <spaghettiohead(at)hotmail.com> >To: >Subject: Re: Kitfox-List: VFR Lighting Requirements > > > > > > > > You only need a good anti-collision light if you plan on flying the 30 > > min's > > before/after sunrise/sunset. > > > > ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Lighting
The last time I looked, Lighting is not required for VFR flying.. Howard ________________________________________________________________________________
Date: Oct 18, 2005
Hi John, I'm very sorry to hear of this. I don't know what Chapter 7 Bankruptcy means. Is there some hope for recovery? Thanks, Bruce Harrington Ex-IV-1200 N194KF, but still a promoter of Kitfoxes. > I was asked to pass on a message and there is just no easy way to say it > Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although > the > phones are still being answered with voice mail there is no one there to > get > the messages and the web is not being monitored This is a Chapter 7 and > was filed on Friday 10-14-05. People involved should get a letter from > the > courts. > > As always, we are here to help with any support questions regarding your > Kitfox.. Although, we cannot provide all the parts we can supply most of > them please give us a shout if we can help. > > > Fly Safe !! > John & Debra McBean ________________________________________________________________________________
Subject: EA-81 turbo with reduction drive FOR SALE
Date: Oct 18, 2005
I have decided to sell the engine package less firewall engine mount. It was originally an NSI engine. I have completely rebuilt the engine to include the heads. The redrive unit has the latest upgrade from NSI, which I believe was new shaft and material, larger bearings and the like. Below is a list of mods and parts: Total run time appx 70 hours, engine was not running at time of nose wheel collapse. Oil pan was damaged by nose strut but can be easily repaired. Engine has since been run, and oil changed as well as redrive oil. This engine makes over 150HP. I will include radiator and necessary plumbing from aircraft. This engine is complete and ready to mount to NSI engine mount for aircraft of your choosing. It was in a model 5 Kitfox. Mounts on engine are included. No break in necessary, its been done. Keep in mind the rotax engine is going for about 20K and does not make this kind of power nor is it rated for continuous full power operation. New pistons and rings All new bearings and seals Pistons, pins, rings and block cryogenic treated, not over sized Pistons ceramic coated tops molly sides Cylinders line honed Crank zero run out reconditioned rods with new bushings weight matched new turbo cam coated by Swain reconditioned lifters stainless down pipe and stack heads have stainless valves, 3 angle valve cut, ceramic tops and scallops, new bronze guides, coated HP springs, reconditioned rockers intake manifold special Swain heat dissipating coating Oil lines are Teflon New Taylor ignition wires Stainless headers by Dawley Aviation with special Swain coating, with EGT holes MOCAL oil thermostat plumbed with lines will provide cooler New oil pump remote filter mount and Teflon lines new water pump Turbo completely rebuilt and upgraded to include new compressor section, Swain coated exhaust turbine section, hard line cooling line and more. Ellison TBI 3A, all fuel lines Teflon to include line to firewall Powder coated aluminum valve covers Dual electronic ignition and pick ups, programmable Alternator with overage voltage unit Engine block heater, not that I needed it here in sunny california I will give the list first shot and then either sell it locally or list on EBay. This is a strong smooth engine. You wont be dissapointed. If you have the non-turbo NSI then this would be an easy swap for much more power and higher density altitude capabilites. If your serious and would like to see her run let me know ASAP. Rick If you like private emails at wingsdown(at)comcast.net ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Lighting
Sorry, I meant, VFR, daytime flying.... Howard ________________________________________________________________________________
Subject: Re: Lighting
Date: Oct 18, 2005
How about VFR flights at "night"? Don Smythe ----- Original Message ----- > The last time I looked, Lighting is not required for VFR flying.. > > Howard ________________________________________________________________________________
Date: Oct 18, 2005
Chapter 7 is the liquidation of a company/individual. This is NOT a restructuring. It is the liquidation of assets and the dismissal of debts/ Best, Joe Bruce Harrington wrote: > >Hi John, >I'm very sorry to hear of this. I don't know what Chapter 7 Bankruptcy >means. Is there some hope for recovery? >Thanks, >Bruce Harrington >Ex-IV-1200 N194KF, but still a promoter of Kitfoxes. > > > >>I was asked to pass on a message and there is just no easy way to say it >>Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although >>the >>phones are still being answered with voice mail there is no one there to >>get >>the messages and the web is not being monitored This is a Chapter 7 and >>was filed on Friday 10-14-05. People involved should get a letter from >>the >>courts. >> >>As always, we are here to help with any support questions regarding your >>Kitfox.. Although, we cannot provide all the parts we can supply most of >>them please give us a shout if we can help. >> >> >>Fly Safe !! >>John & Debra McBean >> >> > > > > ________________________________________________________________________________
Subject: left wing tip
Date: Oct 18, 2005
Hi Folks, I have been rebuilding a damaged Mod. lV Speedster and was waiting till I got to the wing before ordering a wing tip from Skystar. Looks like I waited too long. Does anyone have or know where I can get a left Speedster type wing tip? Also could use a left flaperon. Eric ________________________________________________________________________________
Date: Oct 18, 2005
Anti-Collision lights, Position Lights... Andrew >From: "Don Smythe" <dosmythe(at)cox.net> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Re: Kitfox-List: Lighting >Date: Tue, 18 Oct 2005 18:06:25 -0400 > > >How about VFR flights at "night"? > >Don Smythe > >----- Original Message ----- > > > The last time I looked, Lighting is not required for VFR flying.. > > > > Howard > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 18, 2005
Out of curiosity, it was mentioned that there were other parties (standing in the wings) possibly waiting to take over. Does Chap 7 allow for the company to continue maybe under a different name or whatever? Don Smythe ----- Original Message ----- From: "Joe Bienkowski" <joeb47(at)verizon.net> Subject: Re: Kitfox-List: SkyStar > > Chapter 7 is the liquidation of a company/individual. > > This is NOT a restructuring. > > It is the liquidation of assets and the dismissal of debts/ > > Best, > Joe > > Bruce Harrington wrote: > >> >>Hi John, >>I'm very sorry to hear of this. I don't know what Chapter 7 Bankruptcy >>means. Is there some hope for recovery? >>Thanks, >>Bruce Harrington >>Ex-IV-1200 N194KF, but still a promoter of Kitfoxes. >> >> >> >>>I was asked to pass on a message and there is just no easy way to say it >>>Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although >>>the >>>phones are still being answered with voice mail there is no one there to >>>get >>>the messages and the web is not being monitored This is a Chapter 7 and >>>was filed on Friday 10-14-05. People involved should get a letter from >>>the >>>courts. >>> >>>As always, we are here to help with any support questions regarding your >>>Kitfox.. Although, we cannot provide all the parts we can supply most of >>>them please give us a shout if we can help. >>> >>> >>>Fly Safe !! >>>John & Debra McBean >>> >>> >> >> >> >> > > > ________________________________________________________________________________
Subject: SkyStar
Date: Oct 18, 2005
Hi Don, I am not a lawyer, so I will gladly offer a legal opinion for free! I think under a chapter 7, everything becomes an asset that must be sold to satisfy creditors (mostly Phil Reed in this case), including the Skystar name, web site domain, etc. So they are free to sell that to someone who wants to start over again as a brand new business. Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Don Smythe Subject: Re: Kitfox-List: SkyStar Out of curiosity, it was mentioned that there were other parties (standing in the wings) possibly waiting to take over. Does Chap 7 allow for the company to continue maybe under a different name or whatever? Don Smythe ----- Original Message ----- From: "Joe Bienkowski" <joeb47(at)verizon.net> Subject: Re: Kitfox-List: SkyStar > > Chapter 7 is the liquidation of a company/individual. > > This is NOT a restructuring. > > It is the liquidation of assets and the dismissal of debts/ > > Best, > Joe > > Bruce Harrington wrote: > >> >>Hi John, >>I'm very sorry to hear of this. I don't know what Chapter 7 Bankruptcy >>means. Is there some hope for recovery? >>Thanks, >>Bruce Harrington >>Ex-IV-1200 N194KF, but still a promoter of Kitfoxes. >> >> >> >>>I was asked to pass on a message and there is just no easy way to say it >>>Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although >>>the >>>phones are still being answered with voice mail there is no one there to >>>get >>>the messages and the web is not being monitored This is a Chapter 7 and >>>was filed on Friday 10-14-05. People involved should get a letter from >>>the >>>courts. >>> >>>As always, we are here to help with any support questions regarding your >>>Kitfox.. Although, we cannot provide all the parts we can supply most of >>>them please give us a shout if we can help. >>> >>> >>>Fly Safe !! >>>John & Debra McBean >>> >>> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 18, 2005
They jumped on Ch 7 just before the law changed making 7's more difficult. Liquidation means assets get sold and proceeds applied to satisfy debts. Secured creditors (those to whom assets are pledged as collateral) are first in line. Others will get pennies on the dollar, if anything. It's possible that someone wanting to continue the business could acquire some of the assets. Under Ch 7, however, I wouldn't bet my fox that there will be a fully functional Skystar successor anytime soon. Anybody got a cargo pod to sell? Don Smythe wrote: Out of curiosity, it was mentioned that there were other parties (standing in the wings) possibly waiting to take over. Does Chap 7 allow for the company to continue maybe under a different name or whatever? Don Smythe ----- Original Message ----- From: "Joe Bienkowski" Subject: Re: Kitfox-List: SkyStar > > Chapter 7 is the liquidation of a company/individual. > > This is NOT a restructuring. > > It is the liquidation of assets and the dismissal of debts/ > > Best, > Joe > > Bruce Harrington wrote: > >> >>Hi John, >>I'm very sorry to hear of this. I don't know what Chapter 7 Bankruptcy >>means. Is there some hope for recovery? >>Thanks, >>Bruce Harrington >>Ex-IV-1200 N194KF, but still a promoter of Kitfoxes. >> >> >> >>>I was asked to pass on a message and there is just no easy way to say it >>>Unfortunately, SkyStar is officially in Chapter 7 Bankruptcy. Although >>>the >>>phones are still being answered with voice mail there is no one there to >>>get >>>the messages and the web is not being monitored This is a Chapter 7 and >>>was filed on Friday 10-14-05. People involved should get a letter from >>>the >>>courts. >>> >>>As always, we are here to help with any support questions regarding your >>>Kitfox.. Although, we cannot provide all the parts we can supply most of >>>them please give us a shout if we can help. >>> >>> >>>Fly Safe !! >>>John & Debra McBean >>> >>> >> >> >> >> > > > Marco Menezes Model 2 582 N99KX --------------------------------- ________________________________________________________________________________
Subject: Re: Upper Strut Attach Point
Date: Oct 18, 2005
Thanks Guy You made my brain hurt. So, it is the weak point, no? ----- Original Message ----- From: "Guy Buchanan" <bnn(at)nethere.com> Subject: RE: Kitfox-List: Upper Strut Attach Point > > At 06:42 PM 10/17/2005, you wrote: >>Personally, I wouldn't worry about >>those rod end fittings unless you're used to pulling over 5Gs regularly. > > Well, > You got me thinking. A bad thing. Blew an entire evening. > individual strut load of 757 pounds, assuming constant loading over the > span and both struts loaded equally. (A dubious assumption, at best.) My > strut ends are Aurora MW-4H-12's, which appear to be custom units, > consisting of 5/16" bodies with 9/16" wide balls drilled to 1/4. Since > Skystar supplied AN hardware, this was a reasonable thing to do. Now my > Aurora catalog shows MW-5 (5/16") spherical bearings have a radial static > load capacity of 3133 pounds. This gives a reserve factor of 4.1. Yes > folks, that means the spherical bearing will fail at a load factor of 4.1. > Hmmm. I wonder what happened to six. > Next I checked the threads. The 5/16-24 threads have a tensile > stress area of .058 sq. in. This gives an average stress across the > threads > of 13ksi. I checked McMaster Carr for threaded rod and found the following > three possibilities: > > 18-8 Stainless, "minimum tensile strength" = 70ksi, failure > load factor = 5.4 > Non Rated steel, "minimum tensile strength" = 58ksi, failure > load factor = 4.5 > Grade B7 steel, "minimum tensile strength" = 125ksi, failure > load factor = 9.6 > > Any bets on which Skystar used? I'd bet mild steel. > I haven't even addressed stress concentration factors or fatigue > life, though the low strength steels will have superior fatigue life and > higher crack resistance. > As an aside, the 1/4" bolt, being AN hardware and therefore 125ksi > tensile material, is good for about 7.7ksi in shear, giving load factor to > failure of about 10.2. > possibility reduce my maximum load factor to about 2.7. This would reduce > Vno by about 18%. (For example, a K-IV-1200 Vno would go from 99 mph to 81 > mph.) I don't know if Vne would change. Of course you could always modify > your struts. (Does anybody know what Skystar did in '01 to beef up the > struts? I saw replacement struts available on the web site.) > series units, good to 7639 pounds. (I may do this anyway. Make sure the > ball is custom made to fit the wing fitting. Don't fill with washers.) I'd > also replace the stud with a larger diameter Grade B7 steel. It looks like > you might be able to use a 3/8" body (AW-6) with a custom ball. (1/4" hole > and 7/16" width.) If I can remember tomorrow I'll call Aurora and see > what's possible. > > PS Does anyone have a pair of good pre-'01 K-IV-1200 struts they'd > give/sell me? I'll pull them and get some answers for us. > > > Guy Buchanan > K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. > > > ________________________________________________________________________________
Subject: Wing clevis pin
Date: Oct 19, 2005
Is that a fact that the wing will stay in its flying configuration even if the clevis pins comes out?. I'm having a bit of trouble getting my head around that one. Could someone please explain how because my gut feel is that the wing would fold back immediately the pin was released. Graeme Toft Hi ! Graeme, me too ! and it concerns me because that point on the Kitfox might be a concern. My plane was built by a mechanical engineer and when I picked it up he said to keep that pin greased as it tends chafe. I would like to see more feedback on what is the best thing to do at this point because I'm thinking the bolt idea is good. It would need to be a bolt that does not have thread in the hole in the spar though and I wonder what the correct grade would be. Also should it be tightened or just take up any play ? On the point of the wing staying forward in flight. that's interesting because just last night I attended a lecture on BAK and it was actually mentioned about wing attachment bolts. It was stated about the forces prevailing on these bolts and it was definitely stated there was quite a strain with the wing drag trying to push the wings back. So I'd be interested in any views because until convinced otherwise I'm in favour of the idea the wing will fold back very smartly indeed if that pin fails or whatever. I can see it needs shear strength rather than tensile. I await further discussion with interest please. Rex. PS that's not very nice news about Skystar. It will be good to get news next that someone will take it on. Let's hope ! rexjan(at)bigpond.com ________________________________________________________________________________
Subject: Skystar
Date: Oct 18, 2005
Anyone got any recommended courses of action to take when you just got screwed by the chapter 7? About 60 days ago I was told my 912s was about 60 days out. I think I just got screwed. I hear I should be getting a letter but of course considering that I ordered a kit and it was 'sent to someone else accidentally', I have little faith that this letter will be in my box anytime soon... Anybody else in my sinking boat with me? One question I have is that considering Skystar told me my engine money was in the hands of Rotax, does this mean I will get the engine on order? My luck it would arrive in Idaho and be sold off to pay for this Chapter 7 crap.... I cannot have any respect for the Chapter 7 decision....filing to erase debts to people that held faith is nothing short of immoral. Hindsight is 20/20 and I should have never considered a Kitfox. Sad but true. My experience has been maddening. Luckily I have most of my kit but I would have felt better with the engine I paid for. ________________________________________________________________________________
Subject: Skystar
Date: Oct 18, 2005
For all those still owed parts by Skystar: As I said before, I am just an amateur lawyer, so take this advice as such. I have been "screwed" out of $15,000 owed to me by a creditor to my business because the creditor declared CH 7 bankruptcy. Did I get even ONE CENT. NO. Why? Because I was very far down in the line of creditors, and the first ones to file claims with the BK court get paid first. You have to decide if it is worth paying a lawyer to help you make a claim, and you have to do it fast. I have no idea how much the assets of Skystar are, and how much the current creditors are owed now, but I have to think that there will not be much of anything left as it stands right now. Otherwise they would not have declared Ch 7. So the time to make a decision is now. Make a claim right now or write it off as a bad debt. PS, I saw the final statement in the case of my BK claim. Guess who got the most money? The creditors? Wrong. The lawyers did. Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Greaves Subject: Kitfox-List: Skystar Anyone got any recommended courses of action to take when you just got screwed by the chapter 7? About 60 days ago I was told my 912s was about 60 days out. I think I just got screwed. I hear I should be getting a letter but of course considering that I ordered a kit and it was 'sent to someone else accidentally', I have little faith that this letter will be in my box anytime soon... Anybody else in my sinking boat with me? One question I have is that considering Skystar told me my engine money was in the hands of Rotax, does this mean I will get the engine on order? My luck it would arrive in Idaho and be sold off to pay for this Chapter 7 crap.... I cannot have any respect for the Chapter 7 decision....filing to erase debts to people that held faith is nothing short of immoral. Hindsight is 20/20 and I should have never considered a Kitfox. Sad but true. My experience has been maddening. Luckily I have most of my kit but I would have felt better with the engine I paid for. ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Re: rear spar spacer
JF, My Classic 4 manual from 1994 says 96 and 3/4 inches from the "Root end" of the rear spar. Service letter 25A describes the process. You may end up moving the bracket slightly when you rig the wings on the fuselage. I just went out and measured this on my classic 4. The measurement on it is close to 97 inches on both left and right rear spars. Tom Jones quichotte_40 wrote: > >hi, I`m building the wings for my c4 and it is not clear to me if the >rear spar bracket location dimension of 96 1/4 should be measured >from the rear spar root location with or without the 1/2 inch spacer >on the wing fixture. Should the dimension be taken from the spar >tube beginning or from behind the spacer. thank`s to all. JF >Hebert > > > > ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Skystar website service letters and bullitins
I just checked and found the service letters and bulletins still accessible on Skystars website. If you have not done so already, it might be prudent to print off those that apply to your kitfox. Go to www.skystar.com and click on "technical Support". There is a key at the beginning of the list that tells which plane each letter or bulletin applies to. Tom Jones ________________________________________________________________________________
From: "John Anderson" <janderson412(at)hotmail.com>
Date: Oct 19, 2005
Thought. If the wing is hard against the false rib when the pin is in, i.e. you have to pull the wing tip hard forward to get the front pin in, the pin will be under tension and tend not to work. But if there is a slight gap between the false and last wing rib, i.e the pin slips in easily, it would be more likely to work. Perhaps putting a rubber seal packer between the false and last rib would reduce the chance of pin movement?? John A. From: "Rex & Jan Shaw" <rexjan(at)bigpond.com> Subject: Kitfox-List: Wing clevis pin Date: Wed, 19 Oct 2005 10:39:21 +0930 Is that a fact that the wing will stay in its flying configuration even if the clevis pins comes out?. I'm having a bit of trouble getting my head around that one. Could someone please explain how because my gut feel is that the wing would fold back immediately the pin was released. Graeme Toft Hi ! Graeme, me too ! and it concerns me because that point on the Kitfox might be a concern. My plane was built by a mechanical engineer and when I picked it up he said to keep that pin greased as it tends chafe. I would like to see more feedback on what is the best thing to do at this point because I'm thinking the bolt idea is good. It would need to be a bolt that does not have thread in the hole in the spar though and I wonder what the correct grade would be. Also should it be tightened or just take up any play ? On the point of the wing staying forward in flight. that's interesting because just last night I attended a lecture on BAK and it was actually mentioned about wing attachment bolts. It was stated about the forces prevailing on these bolts and it was definitely stated there was quite a strain with the wing drag trying to push the wings back. So I'd be interested in any views because until convinced otherwise I'm in favour of the idea the wing will fold back very smartly indeed if that pin fails or whatever. I can see it needs shear strength rather than tensile. I await further discussion with interest please. Rex. PS that's not very nice news about Skystar. It will be good to get news next that someone will take it on. Let's hope ! rexjan(at)bigpond.com ________________________________________________________________________________
Date: Oct 18, 2005
At 08:59 PM 10/18/2005, you wrote: >Sport Plane will continue to support the Kitfox family to the best of our >ability...... John, Any idea who I would contact regarding purchasing Skystar assets? Thanks, Guy Buchanan 16718 Peace Valley Lane Ramona, CA 92065-7046 USA 1-760-789-4482 1-760-809-6145: Cell bnn(at)nethere.com ________________________________________________________________________________
Subject: Kitfox Value
Date: Oct 19, 2005
Another curiosity question. I have seriously considered selling my Classic IV and just wonder what the Skystar Chap 7 does to a Kitfox value. On one hand, you might not be able to get repair parts any more which would decrease the value. On the other hand, you can't buy a new Kitfox anymore which would drive the cost up. Just not sure which way the market swings in this kind of situation. Getting repair parts doesn't seem to be that big a deal. Just thinking out loud, there aren't too many parts on a Kitfox that can't be duplicated or rebuilt from scratch (IMO) Don Smythe ________________________________________________________________________________
Subject: Re: Kitfox Value
Date: Oct 19, 2005
My bets the value will go DOWN big time,,,at least for the short run, depending what happens. Even if someone takes it over and trys to sell things again,,,,everyone will always be skeptical. This will be the ?? times it has sold or changed management.. Bob U. ----- Original Message ----- From: "Don Smythe" <dosmythe(at)cox.net> Subject: Kitfox-List: Kitfox Value > > Another curiosity question. I have seriously considered selling my Classic IV and just wonder what the Skystar Chap 7 does to a Kitfox value. On one hand, you might not be able to get repair parts any more which would decrease the value. On the other hand, you can't buy a new Kitfox anymore which would drive the cost up. Just not sure which way the market swings in this kind of situation. > > Getting repair parts doesn't seem to be that big a deal. Just thinking out loud, there aren't too many parts on a Kitfox that can't be duplicated or rebuilt from scratch (IMO) > > Don Smythe > > ________________________________________________________________________________
Subject: Parts Needed
Date: Oct 19, 2005
Alas, the time has finally come. My tailwheel leaf spring gave up the ghost this past weekend. Of course, I do not have a spare, and am in need of a replacement. I have sent off a parts request to SkyStar just for the heck of it but have little faith that I'll get and answer much less make a purchase. Luckily I have a friend that borrowed his unused Matco assembly to me temporarily to get me back home. I am in need of the leaf spring assembly for a Model 3 with the Maule type tailwheel. If there's anyone out there that know of a source for these replacement leaf springs, please let me know. Thank you, Steve Magdic N490PA Wisconsin ________________________________________________________________________________
Date: Oct 19, 2005
Subject: Re: Parts Needed
Steve: Check www.airdale.com under products. It should fit. Jose --- "Magdic, Steve" wrote: > > > Alas, the time has finally come. My tailwheel leaf > spring gave up the ghost this past weekend. > Of course, I do not have a spare, and am in need of > a replacement. I have sent off a parts request > to SkyStar just for the heck of it but have little > faith that I'll get and answer much less make a > purchase. > Luckily I have a friend that borrowed his unused > Matco assembly to me temporarily to get me back > home. > I am in need of the leaf spring assembly for a Model > 3 with the Maule type tailwheel. > If there's anyone out there that know of a source > for these replacement leaf springs, please let me > know. > Thank you, > Steve Magdic > N490PA > Wisconsin > > > > browse > Subscriptions page, > FAQ, > > > > > > Jose M. Toro, P.E. Kitfox II/582->Jabiru 2200 "A slow flight in the Caribbean..." __________________________________ Access over 1 million songs. Try it free. http://music.yahoo.com/unlimited/ ________________________________________________________________________________
Subject: Re: SkyStar
Date: Oct 19, 2005
Please excuse this "commercial" post. At this point, it seems the best way to contact the folks we have not been able to call directly. First, in light of the recent Chapter 7 filing, we too would like to express our concern for the employees of Skystar and for the builders who may be caught up in the circumstances. As many of you know, LP Aero Plastics has been supplying formed acrylic windshields and windows for the Kitfox series aircraft for some time. We have sold some of these directly to builders, and in some cases as proprietary parts to Skystar. It has been our policy, in the case of proprietary parts, to support kit builders directly when the kit manufacturer can no longer do so. If any of you have windshield/window orders pending through Skystar, please contact me at 800-957-2376 or 724-744-4448, FAX 724-744-7372, or e-mail jpfister(at)lpaero.com or windshields(at)lpaero.com . We would like to make sure you get your windows. Thanks, Jeff Pfister LP Aero Plastics, Inc. ________________________________________________________________________________
From: "Kevin Schlosser" <kschlosser(at)proformtool.com>
Date: Oct 19, 2005
Steve, I bought a leaf spring from Aircraft Spruce for homebuilts. It needed minor modification (Ground 2 small notches to fit between the mounting bolts in the rear) as it was 11/2" wide, I believe. I also made a small bushing for the front hole as it was 1/16" too large. It has worked really well on my Scott 2000 tailwheel and it was approx. $30.00. I believe it was a couple of inches longer than stock, but I put it on as it came - I like the stance with the tail a bit higher than original. Kevin (Model 3) N333KF ________________________________________________________________________________
Date: Oct 19, 2005
Steve, a friend used a J3 Cub spring. He had to shim the hole at the fuse end, but it worked. Lowell ----- Original Message ----- From: "Magdic, Steve" <steve.magdic(at)1psg.com> Subject: Kitfox-List: Parts Needed > > Alas, the time has finally come. My tailwheel leaf spring gave up the > ghost this past weekend. > Of course, I do not have a spare, and am in need of a replacement. I have > sent off a parts request > to SkyStar just for the heck of it but have little faith that I'll get and > answer much less make a > purchase. > Luckily I have a friend that borrowed his unused Matco assembly to me > temporarily to get me back home. > I am in need of the leaf spring assembly for a Model 3 with the Maule type > tailwheel. > If there's anyone out there that know of a source for these replacement > leaf springs, please let me know. > Thank you, > Steve Magdic > N490PA > Wisconsin > > > ________________________________________________________________________________
Subject: Re: Skystar
Date: Oct 19, 2005
The link below is to the Idaho Courts site. http://www.id.uscourts.gov/ On that page is a link to Electronic Case Filing\Bankruptcy EFC login. You will need to create a login account and will be charged an 8 cents per page access fee, which is pretty cheap to find out what's going on if you have a lot of money at stake. I lost 90% of my pre-paid flight training funds in a bankruptcy proceeding over 20 years ago. My attendance at the courthouse is all that got me the 10% I didn't lose. Best of luck to those of you with deposits outstanding. The Kitfox line of aircraft are too good to just go away, so I am sure someone will buy the assets and keep building planes. I hope it's someone in North America. Joel Model 5 912 GTA CS prop Aerocomp amphibs (final assembly) http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 19, 2005
Steve, I have tail wheel springs..... Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Magdic, Steve Subject: Kitfox-List: Parts Needed Alas, the time has finally come. My tailwheel leaf spring gave up the ghost this past weekend. Of course, I do not have a spare, and am in need of a replacement. I have sent off a parts request to SkyStar just for the heck of it but have little faith that I'll get and answer much less make a purchase. Luckily I have a friend that borrowed his unused Matco assembly to me temporarily to get me back home. I am in need of the leaf spring assembly for a Model 3 with the Maule type tailwheel. If there's anyone out there that know of a source for these replacement leaf springs, please let me know. Thank you, Steve Magdic N490PA Wisconsin ________________________________________________________________________________
Date: Oct 19, 2005
As far as values go..Skystar never gave any support to owners of kitfox models 1-3 other than a few misc parts that fit 3 and 4's thru commomality of design. Having said that, i think there isn't a thing in a kitfox you cant produce on you own...or someone at your local EAA chapter can. I own a model 3..so while i hate to see any of you guys lose money on parts that didn't show up(thats the bad part) ..you just joined the same boat with the mods1-3 owners...and we're doing just fine. These planes continue to change hands for a fair price i think. Just a different opinion though..dan >From: "Bob Unternaehrer" <shilocom(at)mcmsys.com> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Re: Kitfox-List: Kitfox Value >Date: Wed, 19 Oct 2005 06:15:00 -0500 > > >My bets the value will go DOWN big time,,,at least for the short run, >depending what happens. Even if someone takes it over and trys to sell >things again,,,,everyone will always be skeptical. This will be the ?? >times it has sold or changed management.. Bob U. >----- Original Message ----- >From: "Don Smythe" <dosmythe(at)cox.net> >To: "Kitfox List" >Subject: Kitfox-List: Kitfox Value > > > > > > Another curiosity question. I have seriously considered selling my >Classic IV and just wonder what the Skystar Chap 7 does to a Kitfox value. >On one hand, you might not be able to get repair parts any more which would >decrease the value. On the other hand, you can't buy a new Kitfox anymore >which would drive the cost up. Just not sure which way the market swings >in >this kind of situation. > > > > Getting repair parts doesn't seem to be that big a deal. Just thinking >out loud, there aren't too many parts on a Kitfox that can't be duplicated >or rebuilt from scratch (IMO) > > > > Don Smythe > > > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 19, 2005
Subject: Skystar
I'm a semi-retired lawyer who used to do Chapter 7's and 13's some years ago. I'm not current on the changes in the Bankruptcy Code rammed thru Congress last year by the Credit Card industry, but Skystar's filing on 10/14 should fall under the old code. Following are my best recollections of the process. Don's not quite right regarding unsecured creditors. After the secured creditors and "priority" debts (e.g. lawyer's fees) are paid, unsecured creditors get what's left. It's not on a first-come basis, rather those who file a "proof of claim" with the court receive a pro-rata distribution of the residual bankruptcy estate. As a practical matter, at least in personal Ch 7's, the residual is often zippo. In its filing, Skystar would have had to include a list of creditors which will, theoretically, name all of you out there who have paid for stuff and not received it. They're required to send a proof of claim form to each listed creditor and a notice with instructions on completing and filing the form. It must be filed by the deadline on the notice (usually 90 days after the "first meeting of creditors") or you maybe SOL. Those who are on the hook for big bucks should go to the Idaho bankruptcy court's website and pay whatever it costs to have a look at the list of creditors and the notice to creditors. If you're not on the list, call Skystar's bankruptcy counsel and/or go see your own lawyer ASAP. If you are on it and don't get a claim form or notice within 10 days or so of the deadline for claims, go online get the form (official form 10), fill it out and send it in before the drop-dead date. Don Pearsall wrote: For all those still owed parts by Skystar: As I said before, I am just an amateur lawyer, so take this advice as such. I have been "screwed" out of $15,000 owed to me by a creditor to my business because the creditor declared CH 7 bankruptcy. Did I get even ONE CENT. NO. Why? Because I was very far down in the line of creditors, and the first ones to file claims with the BK court get paid first. You have to decide if it is worth paying a lawyer to help you make a claim, and you have to do it fast. I have no idea how much the assets of Skystar are, and how much the current creditors are owed now, but I have to think that there will not be much of anything left as it stands right now. Otherwise they would not have declared Ch 7. So the time to make a decision is now. Make a claim right now or write it off as a bad debt. PS, I saw the final statement in the case of my BK claim. Guess who got the most money? The creditors? Wrong. The lawyers did. Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Greaves Subject: Kitfox-List: Skystar Anyone got any recommended courses of action to take when you just got screwed by the chapter 7? About 60 days ago I was told my 912s was about 60 days out. I think I just got screwed. I hear I should be getting a letter but of course considering that I ordered a kit and it was 'sent to someone else accidentally', I have little faith that this letter will be in my box anytime soon... Anybody else in my sinking boat with me? One question I have is that considering Skystar told me my engine money was in the hands of Rotax, does this mean I will get the engine on order? My luck it would arrive in Idaho and be sold off to pay for this Chapter 7 crap.... I cannot have any respect for the Chapter 7 decision....filing to erase debts to people that held faith is nothing short of immoral. Hindsight is 20/20 and I should have never considered a Kitfox. Sad but true. My experience has been maddening. Luckily I have most of my kit but I would have felt better with the engine I paid for. Marco Menezes Model 2 582 N99KX --------------------------------- ________________________________________________________________________________
Date: Oct 19, 2005
http://lazair.com/kitfox/index.php?showtopic=49 Seems to be a list here. bh > > I'm a semi-retired lawyer who used to do Chapter 7's and 13's some years > ago. I'm not current on the changes in the Bankruptcy Code rammed thru > Congress last year by the Credit Card industry, but Skystar's filing on > 10/14 should fall under the old code. Following are my best recollections > of the process. > > Don's not quite right regarding unsecured creditors. After the secured > creditors and "priority" debts (e.g. lawyer's fees) are paid, unsecured > creditors get what's left. It's not on a first-come basis, rather those > who file a "proof of claim" with the court receive a pro-rata distribution > of the residual bankruptcy estate. As a practical matter, at least in > personal Ch 7's, the residual is often zippo. > > In its filing, Skystar would have had to include a list of creditors which > will, theoretically, name all of you out there who have paid for stuff and > not received it. They're required to send a proof of claim form to each > listed creditor and a notice with instructions on completing and filing > the form. It must be filed by the deadline on the notice (usually 90 days > after the "first meeting of creditors") or you maybe SOL. > > Those who are on the hook for big bucks should go to the Idaho bankruptcy > court's website and pay whatever it costs to have a look at the list of > creditors and the notice to creditors. If you're not on the list, call > Skystar's bankruptcy counsel and/or go see your own lawyer ASAP. If you > are on it and don't get a claim form or notice within 10 days or so of the > deadline for claims, go online get the form (official form 10), fill it > out and send it in before the drop-dead date. ________________________________________________________________________________
Subject: Skystar
Date: Oct 19, 2005
In ref to Marco's letter......The list of creditors is published on another site... http://lazair.com/kitfox/index.php?showforum=3 Hope it helps, Dan >From: Marco Menezes <msm_9949(at)yahoo.com> .> >.>Those who are on the hook for big bucks should go to the Idaho bankruptcy >court's website and pay whatever it costs to have a look at the list of >creditors and the notice to creditors. If you're not on the list, call >Skystar's bankruptcy counsel and/or go see your own lawyer ASAP. If you are >on it and don't get a claim form or notice within 10 days or so of the >deadline for claims, go online get the form (official form 10), fill it out >and send it in before the drop-dead date. > > >Don Pearsall wrote: > >For all those still owed parts by Skystar: As I said before, I am just an >amateur lawyer, so take this advice as such. I have been "screwed" out of >$15,000 owed to me by a creditor to my business because the creditor >declared CH 7 bankruptcy. Did I get even ONE CENT. NO. Why? Because I was >very far down in the line of creditors, and the first ones to file claims >with the BK court get paid first. > >You have to decide if it is worth paying a lawyer to help you make a claim, >and you have to do it fast. I have no idea how much the assets of Skystar >are, and how much the current creditors are owed now, but I have to think >that there will not be much of anything left as it stands right now. >Otherwise they would not have declared Ch 7. > >So the time to make a decision is now. Make a claim right now or write it >off as a bad debt. > >PS, I saw the final statement in the case of my BK claim. Guess who got the >most money? The creditors? Wrong. The lawyers did. > > >Don Pearsall > > >-----Original Message----- >From: owner-kitfox-list-server(at)matronics.com >[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Greaves >To: kitfox-list(at)matronics.com >Subject: Kitfox-List: Skystar > > >Anyone got any recommended courses of action to take when you just got >screwed by the chapter 7? About 60 days ago I was told my 912s was about 60 >days out. I think I just got screwed. I hear I should be getting a letter >but of course considering that I ordered a kit and it was 'sent to someone >else accidentally', I have little faith that this letter will be in my box >anytime soon... >Anybody else in my sinking boat with me? One question I have is that >considering Skystar told me my engine money was in the hands of Rotax, does >this mean I will get the engine on order? My luck it would arrive in Idaho >and be sold off to pay for this Chapter 7 crap.... >I cannot have any respect for the Chapter 7 decision....filing to erase >debts to people that held faith is nothing short of immoral. Hindsight is >20/20 and I should have never considered a Kitfox. Sad but true. My >experience has been maddening. Luckily I have most of my kit but I would >have felt better with the engine I paid for. > > >Marco Menezes >Model 2 582 N99KX > >--------------------------------- > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 19, 2005
Subject: Kitfox V and Jabiru 2200
Hi Guys: Would a Kitfox V be underpowered with a Jabiru 2200? I'm just curious! Jose M. Toro, P.E. Kitfox II/582->Jabiru 2200 "A slow flight in the Caribbean..." __________________________________ Access over 1 million songs. Try it free. http://music.yahoo.com/unlimited/ ________________________________________________________________________________
From: "Clifford Begnaud" <shoeless(at)barefootpilot.com>
Subject: Re: Kitfox V and Jabiru 2200
Date: Oct 19, 2005
In my opinion, a model 5 would be underpowered with a Jabiru 3300. Cliff > > Hi Guys: > > Would a Kitfox V be underpowered with a Jabiru 2200? > I'm just curious! > > > Jose M. Toro, P.E. > Kitfox II/582->Jabiru 2200 > "A slow flight in the Caribbean..." > > > > __________________________________ > Access over 1 million songs. Try it free. > http://music.yahoo.com/unlimited/ > > > > > > ________________________________________________________________________________
Subject: Skystar foxes etc
Date: Oct 19, 2005
Deep sympathies to all who are caught in the Skystar Chapter 7 bankruptcy - the customers and the people at Skystar. I don't know if it helps anyone but maybe there's some consolation in that the Kitfox is still being produced as a factory built aircraft in Europe i.e. the Eurofox. I hasten to add that I have no connection to Eurofox and most of what I know about them is what I have learnt from a search on google. See below, two links which have quite a lot of info. Because I am in Austria, next door to Slovakia where the Eurofox is made, I also hear a bit of hangar talk about the Eurofox but I have yet to see one in the fabric. I suspect this info. is of little use to kit builders because the Eurofox is sold as a factory built plane, not a kit. But surely a factory built plane must have parts supplies and so maybe this is a source of at least some parts for kit builders? I don't know. I just hope this goes a little way to reassuring everyone that the design is a good one, that the plane has a future and we will all be able to keep flying them and those who are in the process of building will be able to complete them. By the way, we have had the final, final, inspection of the S5 outback and now need to do a bit more paperwork and lots and lots of run-ups and taxying but the day of the first flight is approaching. I will soon post some photos. Wish us luck. Kerry. http://rlsa.bydanjohnson.com/index.cfm?b=6&m=4&i=23 http://www.rlsa.us/eurofox.htm > > ________________________________________________________________________________
Date: Oct 20, 2005
This is an issue I have seen on the list a number of times. I had a similar situation and decided after quite a lot of time looking around and getting no where that I would make a template of the original broken one and take it to a spring works for tempering. I had 4 made up for next to nothing. They work beautifully. Im not sure how your liability laws work in the USA but here in Oz no one will fabricate parts for aircraft unless authorised to do so. My tail springs became farm machinery parts. Problem solved. Cheers Graeme Toft -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Lowell Fitt Subject: Re: Kitfox-List: Parts Needed Steve, a friend used a J3 Cub spring. He had to shim the hole at the fuse end, but it worked. Lowell ----- Original Message ----- From: "Magdic, Steve" <steve.magdic(at)1psg.com> Subject: Kitfox-List: Parts Needed > > Alas, the time has finally come. My tailwheel leaf spring gave up the > ghost this past weekend. > Of course, I do not have a spare, and am in need of a replacement. I have > sent off a parts request > to SkyStar just for the heck of it but have little faith that I'll get and > answer much less make a > purchase. > Luckily I have a friend that borrowed his unused Matco assembly to me > temporarily to get me back home. > I am in need of the leaf spring assembly for a Model 3 with the Maule type > tailwheel. > If there's anyone out there that know of a source for these replacement > leaf springs, please let me know. > Thank you, > Steve Magdic > N490PA > Wisconsin > > > -- 12/10/2005 -- 12/10/2005 ________________________________________________________________________________
Subject: Engine Orders
Date: Oct 19, 2005
Who else was told a few months ago by Crystal Loveland that our Rotaxs were a few months from delivery? Being that my listed claim amount over on the lazair website is nothing near the cost of the engine, does this mean my engine money is in the hands of Rotax? And I would assume that when my engine (that my money paid for) arrives in Idaho, it will be sold off to give me a few bucks and cover the lawyer fees. Fortunately the parts I need are likely going to be obtainable from suppliers (ie grove, lp). Who supplies the fuel tanks? ________________________________________________________________________________
From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Subject: Skystar
Date: Oct 19, 2005
Interesting....I am on the list. I am fairly sure that they do not owe me anything. Maybe the list is not as long as it looks. I hope for the best possible outcome...... Whatever that may be. Randy . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of daniel johnson Subject: RE: Kitfox-List: Skystar In ref to Marco's letter......The list of creditors is published on another site... http://lazair.com/kitfox/index.php?showforum=3 Hope it helps, Dan ________________________________________________________________________________
Date: Oct 19, 2005
Man did you see all those employee paid out figures in the 5 figures Bob U. ----- Original Message ----- From: "daniel johnson" <kitfox91je(at)hotmail.com> Subject: RE: Kitfox-List: Skystar > > In ref to Marco's letter......The list of creditors is published on another > site... > http://lazair.com/kitfox/index.php?showforum=3 > Hope it helps, Dan > > > >From: Marco Menezes <msm_9949(at)yahoo.com> > .> > >.>Those who are on the hook for big bucks should go to the Idaho bankruptcy > >court's website and pay whatever it costs to have a look at the list of > >creditors and the notice to creditors. If you're not on the list, call > >Skystar's bankruptcy counsel and/or go see your own lawyer ASAP. If you are > >on it and don't get a claim form or notice within 10 days or so of the > >deadline for claims, go online get the form (official form 10), fill it out > >and send it in before the drop-dead date. > > > > > >Don Pearsall wrote: > > > >For all those still owed parts by Skystar: As I said before, I am just an > >amateur lawyer, so take this advice as such. I have been "screwed" out of > >$15,000 owed to me by a creditor to my business because the creditor > >declared CH 7 bankruptcy. Did I get even ONE CENT. NO. Why? Because I was > >very far down in the line of creditors, and the first ones to file claims > >with the BK court get paid first. > > > >You have to decide if it is worth paying a lawyer to help you make a claim, > >and you have to do it fast. I have no idea how much the assets of Skystar > >are, and how much the current creditors are owed now, but I have to think > >that there will not be much of anything left as it stands right now. > >Otherwise they would not have declared Ch 7. > > > >So the time to make a decision is now. Make a claim right now or write it > >off as a bad debt. > > > >PS, I saw the final statement in the case of my BK claim. Guess who got the > >most money? The creditors? Wrong. The lawyers did. > > > > > >Don Pearsall > > > > > >-----Original Message----- > >From: owner-kitfox-list-server(at)matronics.com > >[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Greaves > >To: kitfox-list(at)matronics.com > >Subject: Kitfox-List: Skystar > > > > > >Anyone got any recommended courses of action to take when you just got > >screwed by the chapter 7? About 60 days ago I was told my 912s was about 60 > >days out. I think I just got screwed. I hear I should be getting a letter > >but of course considering that I ordered a kit and it was 'sent to someone > >else accidentally', I have little faith that this letter will be in my box > >anytime soon... > >Anybody else in my sinking boat with me? One question I have is that > >considering Skystar told me my engine money was in the hands of Rotax, does > >this mean I will get the engine on order? My luck it would arrive in Idaho > >and be sold off to pay for this Chapter 7 crap.... > >I cannot have any respect for the Chapter 7 decision....filing to erase > >debts to people that held faith is nothing short of immoral. Hindsight is > >20/20 and I should have never considered a Kitfox. Sad but true. My > >experience has been maddening. Luckily I have most of my kit but I would > >have felt better with the engine I paid for. > > > > > >Marco Menezes > >Model 2 582 N99KX > > > >--------------------------------- > > > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > ________________________________________________________________________________
Subject: Re: Need Series 5 cowling
Date: Oct 19, 2005
Good Golly, Kerry, Thats just what I need BUT....distance here is the factor. I appreciate ya getting back to me. > Ron wrote, >>Its time to start my hunt for a Series 5 top & bottom cowl. It must be the >>one for the Lycombing or Continental engine which is the "Cessna" style. > > Hi Ron, we have an unused cowl for the Continental 0-200 engine on a > Series > 5. Problem is we are in Vienna Austria and the freight costs would > probably > make this non-viable for you. However keep > it in mind and if you don't source anything locally give me an email and > we > will try to work out a > viable deal. Kerry. > S5 builders helper. > Taxied it on Sunday. Ohitsjustwunderbar. > > >> >> > > > ________________________________________________________________________________
From: "Gordon Faulkner" <hagar(at)othertonair.freeserve.co.uk>
Subject: Large wingtank for Mk3
Date: Oct 20, 2005
Hi, Gordon Faulkner here posting from England. Just joined the list in time to hear the bad news about Skystar; explains why no response from them to my emails. Hope someone picks up the pieces. I've just started a Mk3 kit that was imported to UK by the original owner 15 years ago! The kit had changed ownership a couple of times since arriving in UK but remained unstarted until last month. It had gathered a light coat of rust so I've taken the airframe back to bare metal and recoated it. My kit has two 6 gal aluminium wingtanks so I'd emailed Skystar about buying a 13 gal wing tank for the righthand side to extend my range a little. Does anyone know who manufactured these tanks and how I can contact them? I'm assuming they weren't fabricated in-house by Skystar. Alternatively does anyone have a used 13 gal tank (or even a pair) from a damaged Mk3? My wings will have the standard one inch twist. Obviously I'll pay a fair price and cover the cost of shipment to England. Regards to all. ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Re: Large wingtank for Mk3
Gordon: Steve Winder from Airdale, www.airdale.com, sell wing tanks that fit the Kitfox III wings. Skystar never had those wing tanks since the airfoil on Model III and back is different from Model IV. Best wishes for your project! Jose Jose M. Toro, P.E. Kitfox II/582->Jabiru 2200 "A slow flight in the Caribbean..." __________________________________ Access over 1 million songs. Try it free. http://music.yahoo.com/unlimited/ ________________________________________________________________________________
Date: Oct 20, 2005
didn't see Rotax on the list????????? Smart, hey? >From: "Bob Unternaehrer" <shilocom(at)mcmsys.com> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Re: Kitfox-List: Skystar >Date: Wed, 19 Oct 2005 20:41:24 -0500 > > >Man did you see all those employee paid out figures in the 5 figures Bob >U. > >----- Original Message ----- >From: "daniel johnson" <kitfox91je(at)hotmail.com> >To: >Subject: RE: Kitfox-List: Skystar > > > > > > > In ref to Marco's letter......The list of creditors is published on >another > > site... > > http://lazair.com/kitfox/index.php?showforum=3 > > Hope it helps, Dan > > > > > > >From: Marco Menezes <msm_9949(at)yahoo.com> > > .> > > >.>Those who are on the hook for big bucks should go to the Idaho >bankruptcy > > >court's website and pay whatever it costs to have a look at the list of > > >creditors and the notice to creditors. If you're not on the list, call > > >Skystar's bankruptcy counsel and/or go see your own lawyer ASAP. If you >are > > >on it and don't get a claim form or notice within 10 days or so of the > > >deadline for claims, go online get the form (official form 10), fill it >out > > >and send it in before the drop-dead date. > > > > > > > > >Don Pearsall wrote: > > > > > >For all those still owed parts by Skystar: As I said before, I am just >an > > >amateur lawyer, so take this advice as such. I have been "screwed" out >of > > >$15,000 owed to me by a creditor to my business because the creditor > > >declared CH 7 bankruptcy. Did I get even ONE CENT. NO. Why? Because I >was > > >very far down in the line of creditors, and the first ones to file >claims > > >with the BK court get paid first. > > > > > >You have to decide if it is worth paying a lawyer to help you make a >claim, > > >and you have to do it fast. I have no idea how much the assets of >Skystar > > >are, and how much the current creditors are owed now, but I have to >think > > >that there will not be much of anything left as it stands right now. > > >Otherwise they would not have declared Ch 7. > > > > > >So the time to make a decision is now. Make a claim right now or write >it > > >off as a bad debt. > > > > > >PS, I saw the final statement in the case of my BK claim. Guess who got >the > > >most money? The creditors? Wrong. The lawyers did. > > > > > > > > >Don Pearsall > > > > > > > > >-----Original Message----- > > >From: owner-kitfox-list-server(at)matronics.com > > >[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Greaves > > >To: kitfox-list(at)matronics.com > > >Subject: Kitfox-List: Skystar > > > > > > > > >Anyone got any recommended courses of action to take when you just got > > >screwed by the chapter 7? About 60 days ago I was told my 912s was >about >60 > > >days out. I think I just got screwed. I hear I should be getting a >letter > > >but of course considering that I ordered a kit and it was 'sent to >someone > > >else accidentally', I have little faith that this letter will be in my >box > > >anytime soon... > > >Anybody else in my sinking boat with me? One question I have is that > > >considering Skystar told me my engine money was in the hands of Rotax, >does > > >this mean I will get the engine on order? My luck it would arrive in >Idaho > > >and be sold off to pay for this Chapter 7 crap.... > > >I cannot have any respect for the Chapter 7 decision....filing to erase > > >debts to people that held faith is nothing short of immoral. Hindsight >is > > >20/20 and I should have never considered a Kitfox. Sad but true. My > > >experience has been maddening. Luckily I have most of my kit but I >would > > >have felt better with the engine I paid for. > > > > > > > > >Marco Menezes > > >Model 2 582 N99KX > > > > > >--------------------------------- > > > > > > > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > > > > > ________________________________________________________________________________
Date: Oct 20, 2005
Subject: need builders manual
Hi Folks. I am new to the list. With the unfortunate fall of skystar I am left with a Kitfox 5 sitting on the gear with no wings. With a little info from the great people on this list I hope to scratch build my wings and finish this plane. What I need is a copy of the "wing construction chapter" from the builders manual. if any one can help contact me here or by e-mail and I will pay for the copies or if anyone is building a KF 5, 6, or 7 near Indianapolis, IN I would love to talk with you. Thanks Glen Hi Folks. I am new to the list. With the unfortunate fall of skystar I am left with a Kitfox 5 sitting on the gear with no wings. With a little info from the great people on this list I hope to scratch build my wings and finish this plane. What I need is a copy of the "wing construction chapter" from the builders manual. if any one can help contact me here or by e-mail and I will pay for the copies or if anyone is building a KF 5, 6, or 7 near Indianapolis, IN I would love to talk with you. Thanks Glen ________________________________________________________________________________
Subject: 13 gal tank
Date: Oct 20, 2005
I'll bet there are some Kitfoxers out here who have replaced the 6 gal. gas tank with a 13 gal tank???? I want to replace my right hand tank (a 6 gal) with a 13 gal. tank that I have. The left hand tank has already been replaced with the13 gal tank, before I bought the plane. I haven't cut the fabric out of the RH wing yet, as I wonder how to cut the convex saddles on the tank, from the round front and rear spars. The adhesive that was used to fasten in the tank, when the plane was built, seems to be pretty strong. Has anyone out there made the change and how did you do it? Herbert Doud ________________________________________________________________________________
Date: Oct 20, 2005
Thanks for the help Jose, I'll contact Airdale rightaway. Gordon ----- Original Message ----- From: "Jose M. Toro" <jose_m_toro(at)yahoo.com> Subject: Re: Kitfox-List: Large wingtank for Mk3 > > Gordon: > > Steve Winder from Airdale, www.airdale.com, sell wing > tanks that fit the Kitfox III wings. Skystar never > had those wing tanks since the airfoil on Model III > and back is different from Model IV. Best wishes for > your project! > > Jose > > > Jose M. Toro, P.E. > Kitfox II/582->Jabiru 2200 > "A slow flight in the Caribbean..." > > > > __________________________________ > Access over 1 million songs. Try it free. > http://music.yahoo.com/unlimited/ > > > > > > > > ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Re: 13 gal tank
Herbert, I used fishing line. It was some of the ultra strong but fine type. It was quick and easy. Tom Jones Hm Doud wrote: > >I'll bet there are some Kitfoxers out here who have replaced the 6 gal. gas tank with a 13 gal tank???? > >I want to replace my right hand tank (a 6 gal) with a 13 gal. tank that I have. The left hand tank has already been replaced with the13 gal tank, before I bought the plane. I haven't cut the fabric out of the RH wing yet, as I wonder how to cut the convex saddles on the tank, from the round front and rear spars. The adhesive that was used to fasten in the tank, when the plane was built, seems to be pretty strong. > >Has anyone out there made the change and how did you do it? > >Herbert Doud > > > > ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Re: Upper Strut Attach PointUpper Strut Attach Point
"Flyer" sez: >I agree Guy. That's why I use 5G. 6G is ultimate (the struts broke >at that value) and I don't want to experience ultimate loading! I don't know whose struts broke at 6g, but when I bought my original Model IV kit the promotion material Denney had at the time showed photographs of destructive wing testing they performed in house: the wing, lift struts and associated fuselage attach points survived 14g (simulated with sandbags) without failing. I also had the opportunity to study the effects of my crash landing on the structure--none of the welded or bolted points on the wings, struts, or fuselage failed in what was estimated by the rescuers to be a 20g impact. I have no concerns about the strength of the Kitfox airframe. Mike G. N728KF ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Re: parts needed
Gentlemen, As far as parts you are in better shape than many that own classic aircraft where there are no factory parts available, nor very many to use for patterns! Among your group you have the knowledge, ability, and numbers to have someone who would make perhaps every part on the plane at a price not to much higher than SkyStar should they not find a buyer willing to start it up again. I own a Funk, and we are fortunate in having a good owners association and a man who has all parts available ~ the company went out of business in '48. No more talk of hanging it from ceiling ~ Airplanes are to fly, so fly them and fix when needed. You have a great product ~~ enjoy it and fly it! Elbie Mendenhall Now handling GRS (Galaxy Ballistic Parachutes) and Woodcomp Propellers (ground adjustable & in-flight adjustable, electronic & manual and aircraft our importer sells, Sting Sport LSA and other aircraft in near future. Outstanding Customer Service is our Motto If you like it let others know, If not let me know! Elbie Mendenhall EM Aviation, LLC 13411 NE Prairie Rd Brush Prairie WA 98606 360-260-0772 www.riteangle.com ________________________________________________________________________________
Subject: Re: A Little Good News
Date: Oct 20, 2005
Congratulation Mike. Wanna buy a Fox? Don Smythe ----- Original Message ----- >>From: Michael Gibbs <MichaelGibbs(at)cox.net> >>Reply-To: kitfox-list(at)matronics.com >>To: kitfox-list(at)matronics.com >>Subject: Kitfox-List: A Little Good News >>Date: Thu, 20 Oct 2005 09:33:51 -0700 >> >> >>Hi all, >> >>In the midst of all the doom and gloom, I hope you won't mind a >>little bit of good personal news. It's been 14 months since the >>accident that destroyed my beloved Kitfox IV and I've spent the time ________________________________________________________________________________
Date: Oct 20, 2005
Glen do you have all the parts ? I will be happy to copy my wing chapter for you let me know if and what you need Steve -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of glen rowland Subject: Kitfox-List: need builders manual Hi Folks. I am new to the list. With the unfortunate fall of skystar I am left with a Kitfox 5 sitting on the gear with no wings. With a little info from the great people on this list I hope to scratch build my wings and finish this plane. What I need is a copy of the "wing construction chapter" from the builders manual. if any one can help contact me here or by e-mail and I will pay for the copies or if anyone is building a KF 5, 6, or 7 near Indianapolis, IN I would love to talk with you. Thanks Glen Hi Folks. I am new to the list. With the unfortunate fall of skystar I am left with a Kitfox 5 sitting on the gear with no wings. With a little info from the great people on this list I hope to scratch build my wings and finish this plane. What I need is a copy of the "wing construction chapter" from the builders manual. if any one can help contact me here or by e-mail and I will pay for the copies or if anyone is building a KF 5, 6, or 7 near Indianapolis, IN I would love to talk with you. Thanks Glen ________________________________________________________________________________
Date: Oct 20, 2005
Don: Do you have one for sale? Jose --- Don Smythe wrote: > > > Congratulation Mike. Wanna buy a Fox? > > Don Smythe > > ----- Original Message ----- > >>From: Michael Gibbs <MichaelGibbs(at)cox.net> > >>Reply-To: kitfox-list(at)matronics.com > >>To: kitfox-list(at)matronics.com > >>Subject: Kitfox-List: A Little Good News > >>Date: Thu, 20 Oct 2005 09:33:51 -0700 > >> > > >> > >>Hi all, > >> > >>In the midst of all the doom and gloom, I hope you > won't mind a > >>little bit of good personal news. It's been 14 > months since the > >>accident that destroyed my beloved Kitfox IV and > I've spent the time > > > > browse > Subscriptions page, > FAQ, > > > > > > Jose M. Toro, P.E. Kitfox II/582->Jabiru 2200 "A slow flight in the Caribbean..." __________________________________ ________________________________________________________________________________
Date: Oct 20, 2005
Check out this story on EAA website: http://www.eaa.org/communications/eaanews/051018_skystar.html David Dawe wrote: didn't see Rotax on the list????????? Smart, hey? >From: "Bob Unternaehrer" >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Re: Kitfox-List: Skystar >Date: Wed, 19 Oct 2005 20:41:24 -0500 > > >Man did you see all those employee paid out figures in the 5 figures Bob >U. > >----- Original Message ----- >From: "daniel johnson" >To: >Subject: RE: Kitfox-List: Skystar > > > > > > In ref to Marco's letter......The list of creditors is published on >another > > site... > > http://lazair.com/kitfox/index.php?showforum=3 > > Hope it helps, Dan > > > > > > >From: Marco Menezes > > .> > > >.>Those who are on the hook for big bucks should go to the Idaho >bankruptcy > > >court's website and pay whatever it costs to have a look at the list of > > >creditors and the notice to creditors. If you're not on the list, call > > >Skystar's bankruptcy counsel and/or go see your own lawyer ASAP. If you >are > > >on it and don't get a claim form or notice within 10 days or so of the > > >deadline for claims, go online get the form (official form 10), fill it >out > > >and send it in before the drop-dead date. > > > > > > > > >Don Pearsall wrote: > > > > > >For all those still owed parts by Skystar: As I said before, I am just >an > > >amateur lawyer, so take this advice as such. I have been "screwed" out >of > > >$15,000 owed to me by a creditor to my business because the creditor > > >declared CH 7 bankruptcy. Did I get even ONE CENT. NO. Why? Because I >was > > >very far down in the line of creditors, and the first ones to file >claims > > >with the BK court get paid first. > > > > > >You have to decide if it is worth paying a lawyer to help you make a >claim, > > >and you have to do it fast. I have no idea how much the assets of >Skystar > > >are, and how much the current creditors are owed now, but I have to >think > > >that there will not be much of anything left as it stands right now. > > >Otherwise they would not have declared Ch 7. > > > > > >So the time to make a decision is now. Make a claim right now or write >it > > >off as a bad debt. > > > > > >PS, I saw the final statement in the case of my BK claim. Guess who got >the > > >most money? The creditors? Wrong. The lawyers did. > > > > > > > > >Don Pearsall > > > > > > > > >-----Original Message----- > > >From: owner-kitfox-list-server(at)matronics.com > > >[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Greaves > > >To: kitfox-list(at)matronics.com > > >Subject: Kitfox-List: Skystar > > > > > > > > >Anyone got any recommended courses of action to take when you just got > > >screwed by the chapter 7? About 60 days ago I was told my 912s was >about >60 > > >days out. I think I just got screwed. I hear I should be getting a >letter > > >but of course considering that I ordered a kit and it was 'sent to >someone > > >else accidentally', I have little faith that this letter will be in my >box > > >anytime soon... > > >Anybody else in my sinking boat with me? One question I have is that > > >considering Skystar told me my engine money was in the hands of Rotax, >does > > >this mean I will get the engine on order? My luck it would arrive in >Idaho > > >and be sold off to pay for this Chapter 7 crap.... > > >I cannot have any respect for the Chapter 7 decision....filing to erase > > >debts to people that held faith is nothing short of immoral. Hindsight >is > > >20/20 and I should have never considered a Kitfox. Sad but true. My > > >experience has been maddening. Luckily I have most of my kit but I >would > > >have felt better with the engine I paid for. > > > > > > > > >Marco Menezes > > >Model 2 582 N99KX > > > > > >--------------------------------- > > > > > > > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > > > > > Marco Menezes Model 2 582 N99KX ________________________________________________________________________________
Date: Oct 20, 2005
I've been hesitant to say but, it is very likely that I might. Since retirement (two years now) my interest seemed to have shifted and I just don't have the time to get to the airport. Don Smythe ----- Original Message ----- From: "Jose M. Toro" <jose_m_toro(at)yahoo.com> > Don: > > Do you have one for sale? ________________________________________________________________________________
Subject: Fw: KITFOX
Date: Oct 20, 2005
Received the below from another party. Don't know the origin. Don Smythe ----- Original Message ----- > KITFOX MANUFACTURER SKYSTAR FILES FOR BANKRUPTCY > Kitfox aircraft kit manufacturer Skystar Aircraft Corp. has filed for > bankruptcy under Chapter 7, EAA reported on Tuesday. According to > documents obtained by EAA, the filing took place on Friday, Oct. 14, in > Idaho. Those documents show the company's claimed assets totaled about > $1.1 million, with liabilities of nearly $1.7 million. Skystar President > Frank Miller could not be reached, but the company's bankruptcy attorney, > David Kras, told EAA that plans are to liquidate company assets and pay > off the creditors. Individuals who paid Skystar for kits or parts that > were never delivered may be entitled to file a priority claim, which could > give them a better chance to recover at least some portion of their > payment, EAA said. More... ________________________________________________________________________________
Subject: Fw: KITFOX
Date: Oct 20, 2005
Don, I think that snippet of an article came from Avweb. Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Don Smythe Subject: Kitfox-List: Fw: KITFOX Received the below from another party. Don't know the origin. Don Smythe ----- Original Message ----- > KITFOX MANUFACTURER SKYSTAR FILES FOR BANKRUPTCY > Kitfox aircraft kit manufacturer Skystar Aircraft Corp. has filed for > bankruptcy under Chapter 7, EAA reported on Tuesday. According to > documents obtained by EAA, the filing took place on Friday, Oct. 14, in > Idaho. Those documents show the company's claimed assets totaled about > $1.1 million, with liabilities of nearly $1.7 million. Skystar President > Frank Miller could not be reached, but the company's bankruptcy attorney, > David Kras, told EAA that plans are to liquidate company assets and pay > off the creditors. Individuals who paid Skystar for kits or parts that > were never delivered may be entitled to file a priority claim, which could > give them a better chance to recover at least some portion of their > payment, EAA said. More... ________________________________________________________________________________
Date: Oct 20, 2005
It may now be worth more parted out and sold part by part. Tom Jones Don Smythe wrote: > >I've been hesitant to say but, it is very likely that I might. Since >retirement (two years now) my interest seemed to have shifted and I just >don't have the time to get to the airport. > >Don Smythe > >----- Original Message ----- >From: "Jose M. Toro" <jose_m_toro(at)yahoo.com> > > >>Don: >> >>Do you have one for sale? >> >> > > > > ________________________________________________________________________________
Date: Oct 21, 2005
Do you still have the round cowl available? Would it fit a III? We might be able to work something out as I have the molds for the Cessna style cowl. A friend and I are trying to learn the process of gel coating and producing cowls with these molds. Still too early to know if we will be successful. >From: rliebmann(at)comcast.net >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com >Subject: Re: Kitfox-List: Need Series 5 cowling >Date: Mon, 17 Oct 2005 16:18:02 +0000 > > >Hi Listers, > >Its time to start my hunt for a Series 5 top & bottom cowl. It must be the >one for the Lycombing or Continental engine which is the "Cessna" style. > >I have a round cowl set which would be good for a Rotax 912 engine for sale >too. > >Thanks, Ron N55KF > > >Hi Listers, > >Its time to start my hunt for a Series 5 top bottom cowl. It must be the >one for the Lycombing or Continental engine which is the "Cessna" style. > >I have a round cowl set which would be good for a Rotax 912 engine for sale >too. > >Thanks, Ron N55KF > > ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Future engine choice?
November 27, 2004 A white paper on a revolutionary new approach to engine design has been released at the Global Powertrain Conference (GPC) in Dearborn, Michigan, USA. Quasiturbine technology uses photo-detonation for low-power-efficiency and requires low octane, additive-free gasoline or diesel fuel. It is also multi-fuel compatible (including direct hydrogen combustion) and offers a drastic reduction in existing propulsion system weight, size, maintenance and costs. Utilised within the internal combustion engine, the photo-detonation process could save half the gasoline now consumed by vehicles and provide substantial environmental benefits. The Quasiturbine looks at first like a rotary engine with a deformable rotor made of four identical blades, but because it has no crankshaft and does not follow sinusoidal motion, it has properties far different from the piston and the Wankel rotary piston engine. The Quasiturbine engine has been developed to simultaneously optimize the 14 most important engine parameters, including compatibility with the revolutionary photo-detonation mode (knocking), which the piston engine cannot effectively tolerate. When taken together, these improvements increase fuel efficiency while simultaneously reducing exhaust emissions. Inspired by the turbine, it perfects the piston, and improves on the Wankel. For more information visit following websites, http://quasiturbine.promci.qc.ca/ http://www.gizmag.com/go/3501/ ________________________________________________________________________________
Subject: Where will we get parts in the future?
Date: Oct 21, 2005
----- Original Message ----- > > It may now be worth more parted out and sold part by part. > Tom Jones Ok guys, lets not be too hard on ourselves here. Before everyone gives their airplanes away or parts them out, here's a snippet from the Avid Forum right after Avid went out of business that might make you all feel better. I'm sure someone will pick up the pieces and supply Kitfox parts much the same as Airdale did for Avid. We have a lot of capable and experienced people in this group that may have been looking for this opportunity to open up? And when you think about it, many certified aircraft flying today are no longer supported by their manufacturers, yet they continue to fly just the same utilizing aftermarket suppliers (eg Stinson, Taylorcraft, Funk, Bellanca, old Pipers, Lake, etc, etc) Paul Seehafer (Here's the message sent to the Avid group a couple years ago) --- In avid_flyer(at)yahoogroups.com, "englishav8r" wrote: >> >> Airdale can make and supply ALL the parts for a Standard Avid Flyer. >> (A,B,C, MkIV D, E, Speedwings and Aerobatic Speedwings) >> All the Wing Parts for Magnum, and Catalina. (Ribs, Tanks, Flaperons >> etc..) >> BUT the original Avid Flyer is now nearly 20 years old, Cuyuna powered >> and some of the original parts are Difficult or too expensive for a >> builder to afford! >> >> Most of the parts are made to order as it is just NOT economical to >> have on the shelf stock on some. But we do have short Batch runs on >> certain high cost items in an effort to keep the labor time down.. >> (Flaperons, Landing Gear, Bungees, Ribs, Fiberglass parts) >> >> Raw material costs vary on a week by week basis--especailly when its >> small numbers--hence when are part is required we quote at todays >> prices... >> >> One of the biggest problems are Part finished and used kits out there--- >> Many times we get requests for a Bellcrank, push pull rod, bracket >> etc....In this instance we have to duplicate as per original---usually >> from an original we then work on a time and materials basis >> but we persevere and try to help every one out there. >> We support you and you support us...that's the name of the game.. >> >> We are able to supply an Avid "MkIV" kit right from nose to tail... >> this we already do for the European Market where it is recognised as >> the same type---for certification purposes..BUT fuselage is slightly >> different---longer / wider--- >> >> So in a Nutshell. >> >> If Its On Your Avid, AIRDALE Probably Makes It--- >> >> Maybe this is the Simple message that should go on our web page? >> >> Regards, >> Steve at Airdale.... ________________________________________________________________________________
Subject: Re: Where will we get parts in the future?
Date: Oct 21, 2005
following up on Paul's comment, (John step in here) but Skystar did not appear to do much actual fabrication beyond the weldments. And I doubt than many of us (you) are missing weldments, perhaps with the exception of motor mounts. There exists a cadre of suppliers to Skystar with the capability of producing the components that are missing out in the garages of the list members. What is needed is someone to pull from those suppliers in committment to deliver...... John McBean is a prime candidate to pull it all together.. John Kerr -------------- Original message -------------- > > ----- Original Message ----- > > > It may now be worth more parted out and sold part by part. > > Tom Jones > > Ok guys, lets not be too hard on ourselves here. Before everyone gives > their airplanes away or parts them out, here's a snippet from the Avid Forum > right after Avid went out of business that might make you all feel better. > I'm sure someone will pick up the pieces and supply Kitfox parts much the > same as Airdale did for Avid. We have a lot of capable and experienced > people in this group that may have been looking for this opportunity to open > up? And when you think about it, many certified aircraft flying today are > no longer supported by their manufacturers, yet they continue to fly just > the same utilizing aftermarket suppliers (eg Stinson, Taylorcraft, Funk, > Bellanca, old Pipers, Lake, etc, etc) > > Paul Seehafer > > > (Here's the message sent to the Avid group a couple years ago) > > --- In avid_flyer(at)yahoogroups.com, "englishav8r" wrote: > >> > >> Airdale can make and supply ALL the parts for a Standard Avid Flyer. > >> (A,B,C, MkIV D, E, Speedwings and Aerobatic Speedwings) > >> All the Wing Parts for Magnum, and Catalina. (Ribs, Tanks, Flaperons > >> etc..) > >> BUT the original Avid Flyer is now nearly 20 years old, Cuyuna powered > >> and some of the original parts are Difficult or too expensive for a > >> builder to afford! > >> > >> Most of the parts are made to order as it is just NOT economical to > >> have on the shelf stock on some. But we do have short Batch runs on > >> certain high cost items in an effort to keep the labor time down.. > >> (Flaperons, Landing Gear, Bungees, Ribs, Fiberglass parts) > >> > >> Raw material costs vary on a week by week basis--especailly when its > >> small numbers--hence when are part is required we quote at todays > >> prices... > >> > >> One of the biggest problems are Part finished and used kits out there--- > >> Many times we get requests for a Bellcrank, push pull rod, bracket > >> etc....In this instance we have to duplicate as per original---usually > >> from an original we then work on a time and materials basis > >> but we persevere and try to help every one out there. > >> We support you and you support us...that's the name of the game.. > >> > >> We are able to supply an Avid "MkIV" kit right from nose to tail... > >> this we already do for the European Market where it is recognised as > >> the same type---for certification purposes..BUT fuselage is slightly > >> different---longer / wider--- > >> > >> So in a Nutshell. > >> > >> If Its On Your Avid, AIRDALE Probably Makes It--- > >> > >> Maybe this is the Simple message that should go on our web page? > >> > >> Regards, > >> Steve at Airdale.... > > > > > > following up on Paul's comment, (John step in here) but Skystar did not appear to do much actual fabrication beyond the weldments. And I doubt than many of us (you) are missing weldments, perhaps with the exception of motor mounts. There exists a cadre of suppliers to Skystar with the capability of producing the components that are missing out in the garages of the list members. What is needed is someone to pull from those suppliers in committment to deliver...... John McBean is a prime candidate to pull it all together.. John Kerr -------------- Original message -------------- -- Kitfox-List message posted by: "Paul Seehafer" ----- Original Message ----- It may now be worth more parted out and sold part by part. Tom Jones Ok guys, lets not be too hard on ourselves here. Before everyone gives their airplanes away or parts them out, here's a snippet from the Avid Forum right after Avid went out of business that might make you all feel better. I'm sure someone will pick up the pieces and supply Kitfox parts much the same as Airdale did for Avid. We have a lot of capable and experienced people in this group that may have been looking for this opportunity to open up? And when you think about it, many certified aircraft flying today are no longer supported b y their manufacturers, yet they continue to fly just the same utilizing aftermarket suppliers (eg Stinson, Taylorcraft, Funk, Bellanca, old Pipers, Lake, etc, etc) Paul Seehafer (Here's the message sent to the Avid group a couple years ago) --- In avid_flyer(at)yahoogroups.com, "englishav8r" wrote: Airdale can make and supply ALL the parts for a Standard Avid Flyer. (A,B,C, MkIV D, E, Speedwings and Aerobatic Speedwings) All the Wing Parts for Magnum, and Catalina. (Ribs, Tanks, Flaperons etc..) BUT the original Avid Flyer is now nearly 20 years old, Cuyuna powered and some of the original parts are Difficult or too expensive for a builder to afford! Most of the parts are made to order as it is just NOT econo mical to have on the shelf stock on some. But we do have short Batch runs on certain high cost items in an effort to keep the labor time down.. (Flaperons, Landing Gear, Bungees, Ribs, Fiberglass parts) Raw material costs vary on a week by week basis--especailly when its small numbers--hence when are part is required we quote at todays prices... One of the biggest problems are Part finished and used kits out there--- Many times we get requests for a Bellcrank, push pull rod, bracket etc....In this instance we have to duplicate as per original---usually from an original we then work on a time and materials basis but we persevere and try to help every one out there. We support you and you support us...that's the name of the game. . We are able to supply an Avid "MkIV" kit right from nose to tail... this we already do for the European Market where it is recognised as the same type---for certification purposes..BUT fuselage is slightly different---longer / wider--- So in a Nutshell. If Its On Your Avid, AIRDALE Probably Makes It--- Maybe this is the Simple message that should go on our web page? Regards, Steve at Airdale.... , ________________________________________________________________________________
Date: Oct 21, 2005
Snip... I'm sure someone will pick up the pieces and supply Kitfox parts much the same as Airdale did for Avid. We have been helping Kitfoxers for the last 2 years from a technical side (not only on the list) and with some parts... We are also trying to gather parts to support the Kitfox family. As most of you know Debra and I both worked at SkyStar until 2 years ago when we started Sport Plane LLC. We are going to do our best to continue the support. If you are in need, or are looking for something give us a shout. I know Steve at Airdale and have worked with him in the past... Unfortunately our web is not 100% current so if you do not see it there give us a call or email. We are established with several vendors and can get most parts from wheels and brakes to gas cap fairings. I have been on the list personally to help whenever I can... I'm not going anywhere.. Need parts ? Let us know if can help. We may not be able to help right away but given a little time and support we can get there. www.sportplanellc.com John McBean -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Paul Seehafer Subject: Kitfox-List: Where will we get parts in the future? ----- Original Message ----- > > It may now be worth more parted out and sold part by part. > Tom Jones Ok guys, lets not be too hard on ourselves here. Before everyone gives their airplanes away or parts them out, here's a snippet from the Avid Forum right after Avid went out of business that might make you all feel better. I'm sure someone will pick up the pieces and supply Kitfox parts much the same as Airdale did for Avid. We have a lot of capable and experienced people in this group that may have been looking for this opportunity to open up? And when you think about it, many certified aircraft flying today are no longer supported by their manufacturers, yet they continue to fly just the same utilizing aftermarket suppliers (eg Stinson, Taylorcraft, Funk, Bellanca, old Pipers, Lake, etc, etc) Paul Seehafer (Here's the message sent to the Avid group a couple years ago) --- In avid_flyer(at)yahoogroups.com, "englishav8r" wrote: >> >> Airdale can make and supply ALL the parts for a Standard Avid Flyer. >> (A,B,C, MkIV D, E, Speedwings and Aerobatic Speedwings) >> All the Wing Parts for Magnum, and Catalina. (Ribs, Tanks, Flaperons >> etc..) >> BUT the original Avid Flyer is now nearly 20 years old, Cuyuna powered >> and some of the original parts are Difficult or too expensive for a >> builder to afford! >> >> Most of the parts are made to order as it is just NOT economical to >> have on the shelf stock on some. But we do have short Batch runs on >> certain high cost items in an effort to keep the labor time down.. >> (Flaperons, Landing Gear, Bungees, Ribs, Fiberglass parts) >> >> Raw material costs vary on a week by week basis--especailly when its >> small numbers--hence when are part is required we quote at todays >> prices... >> >> One of the biggest problems are Part finished and used kits out there--- >> Many times we get requests for a Bellcrank, push pull rod, bracket >> etc....In this instance we have to duplicate as per original---usually >> from an original we then work on a time and materials basis >> but we persevere and try to help every one out there. >> We support you and you support us...that's the name of the game.. >> >> We are able to supply an Avid "MkIV" kit right from nose to tail... >> this we already do for the European Market where it is recognised as >> the same type---for certification purposes..BUT fuselage is slightly >> different---longer / wider--- >> >> So in a Nutshell. >> >> If Its On Your Avid, AIRDALE Probably Makes It--- >> >> Maybe this is the Simple message that should go on our web page? >> >> Regards, >> Steve at Airdale.... ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Kitfox Promotional Videos
Hello All, About a year ago, I completed a video project putting all of the Kitfox promotional videos that I could find on two DVDs. The two completed DVDs were sent to Frank Miller for his approval for me to distribute to the Kitfox list but he never responded. With what has now happened to Skystar, can I legally send these DVDs out? Any lawyers here? If so, is there anyone on here that is interested in viewing them? Thanks, Grant Fluent Newcastle, NE Classic IV 912S ________________________________________________________________________________
Date: Oct 21, 2005
I agree with John. He can get you almost anything you need. Skystar did not make most of its stuff in house, and what they did from what I understand was on jigs that were leased from the previous owner. While this has been hard on those of us that have lost money and struggled with this for some time, it does give some closure and allows us to move on. The suspense is over and now someone will undoubtedly pick up the pieces and make it better than it has been for years. The Fox is still the best plane of its type out there and I am sure it will live on. The real pain is for those that paid for kits and did not get them. If you paid for a kit recently and did not get it you might consider contacting the postal inspector. It is not who you would expect to investigate this type of thing but they are the best at this type of thing. They have unlimited budgets to call witnesses and investigate over the entire county, and e-mail, checks, letters, contracts, advertising and the like fall under mail fraud. A friend and I bought an aircraft engine from a company that did not have what it said it had. I pursued it with the postal inspectors and the head of that company got 54 months in federal prison. While I am sure that the principals in Skystar are suffering a lot, and have lost everything they own, that is still no excuse for taking money for items they know they can not deliver. If that is in fact the case they need to go to jail. Alan jdmcbean wrote: > >Snip... I'm sure someone will pick up the pieces and supply Kitfox parts >much the same as Airdale did for Avid. > >We have been helping Kitfoxers for the last 2 years from a technical side >(not only on the list) and with some parts... We are also trying to gather > > > > ________________________________________________________________________________
Date: Oct 21, 2005
Hi Bruce, The Series 5 cowling is too big for the III. I have found 2 Series 5 "Lycombing" style cowls from "listers" so I will probably buy one of them. I think its great that you have the molds for the cowling. I think that they will bring you $$$ in the fuure allowing you to make and sell them. I'll follow your progress if you let the list know when you start making them. Take care, Ron ----- Original Message ----- From: "Bruce Harrison" <firestarii(at)hotmail.com> Subject: Re: Kitfox-List: Need Series 5 cowling > > > Do you still have the round cowl available? Would it fit a III? > > We might be able to work something out as I have the molds for the Cessna > style cowl. A friend and I are trying to learn the process of gel coating > and producing cowls with these molds. Still too early to know if we will > be > successful. > > >>From: rliebmann(at)comcast.net >>Reply-To: kitfox-list(at)matronics.com >>To: kitfox-list(at)matronics.com >>Subject: Re: Kitfox-List: Need Series 5 cowling >>Date: Mon, 17 Oct 2005 16:18:02 +0000 >> >> >>Hi Listers, >> >>Its time to start my hunt for a Series 5 top & bottom cowl. It must be the >>one for the Lycombing or Continental engine which is the "Cessna" style. >> >>I have a round cowl set which would be good for a Rotax 912 engine for >>sale >>too. >> >>Thanks, Ron N55KF >> >> >>Hi Listers, >> >>Its time to start my hunt for a Series 5 top bottom cowl. It must be the >>one for the Lycombing or Continental engine which is the "Cessna" style. >> >>I have a round cowl set which would be good for a Rotax 912 engine for >>sale >>too. >> >>Thanks, Ron N55KF >> >> > > > ________________________________________________________________________________
Date: Oct 21, 2005
Grant, I would be interested. I loaned out the two VHS tapes out many times and ended up losing them, because I couldn't remember who I loaned them too. The one with the speedster doing acrobatics is the one I miss the most. Thanks, RB Model III 582 -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Grant Fluent Subject: Kitfox-List: Kitfox Promotional Videos Hello All, About a year ago, I completed a video project putting all of the Kitfox promotional videos that I could find on two DVDs. The two completed DVDs were sent to Frank Miller for his approval for me to distribute to the Kitfox list but he never responded. With what has now happened to Skystar, can I legally send these DVDs out? Any lawyers here? If so, is there anyone on here that is interested in viewing them? Thanks, Grant Fluent Newcastle, NE Classic IV 912S ________________________________________________________________________________
Date: Oct 21, 2005
Grant, Count me in. Jeff Classic IV. Ohio > [Original Message] > From: Grant Fluent <gjfpilot(at)yahoo.com> > To: > Date: 10/21/2005 1:47:31 PM > Subject: Kitfox-List: Kitfox Promotional Videos > > > Hello All, > About a year ago, I completed a video project > putting all of the Kitfox promotional videos that I > could find on two DVDs. The two completed DVDs were > sent to Frank Miller for his approval for me to > distribute to the Kitfox list but he never responded. > With what has now happened to Skystar, can I legally > send these DVDs out? Any lawyers here? If so, is > there anyone on here that is interested in viewing > them? > Thanks, > Grant Fluent > Newcastle, NE > Classic IV 912S > > ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Re: Kitfox Promotional Videos
Grant Fluent wrote: > >Hello All, > About a year ago, I completed a video project >putting all of the Kitfox promotional videos that I >could find on two DVDs. The two completed DVDs were >sent to Frank Miller for his approval for me to >distribute to the Kitfox list but he never responded. >With what has now happened to Skystar, can I legally >send these DVDs out? Any lawyers here? If so, is >there anyone on here that is interested in viewing >them? >Thanks, >Grant Fluent >Newcastle, NE >Classic IV 912S > > > > Grant, Count me in also. Jim Gilliatt West Greenwich, RI Series 7 ________________________________________________________________________________
Date: Oct 21, 2005
Grant, I don't know about LEGALLY, as I am sure that the material was copyrighted, but reality should intrude here. There is no one left to tell you that you can't distribute it. Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Grant Fluent Subject: Kitfox-List: Kitfox Promotional Videos Hello All, About a year ago, I completed a video project putting all of the Kitfox promotional videos that I could find on two DVDs. The two completed DVDs were sent to Frank Miller for his approval for me to distribute to the Kitfox list but he never responded. With what has now happened to Skystar, can I legally send these DVDs out? Any lawyers here? If so, is there anyone on here that is interested in viewing them? Thanks, Grant Fluent Newcastle, NE Classic IV 912S ________________________________________________________________________________
Date: Oct 21, 2005
Rex, Thanks for pointing this out. It does look like it would be great for airplanes. I suspect that there is 8 - 10 years of development until it is available though. I am surprised that I hadn't heard of it before. Another link with a useful explanation: http://auto.howstuffworks.com/quasiturbine3.htm Randy . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Rex Hefferan Subject: Kitfox-List: Future engine choice? November 27, 2004 A white paper on a revolutionary new approach to engine design has been released at the Global Powertrain Conference (GPC) in Dearborn, Michigan, USA. Quasiturbine technology uses photo-detonation for low-power-efficiency and requires low octane, additive-free gasoline or diesel fuel. It is also multi-fuel compatible (including direct hydrogen combustion) and offers a drastic reduction in existing propulsion system weight, size, maintenance and costs. Utilised within the internal combustion engine, the photo-detonation process could save half the gasoline now consumed by vehicles and provide substantial environmental benefits. The Quasiturbine looks at first like a rotary engine with a deformable rotor made of four identical blades, but because it has no crankshaft and does not follow sinusoidal motion, it has properties far different from the piston and the Wankel rotary piston engine. The Quasiturbine engine has been developed to simultaneously optimize the 14 most important engine parameters, including compatibility with the revolutionary photo-detonation mode (knocking), which the piston engine cannot effectively tolerate. When taken together, these improvements increase fuel efficiency while simultaneously reducing exhaust emissions. Inspired by the turbine, it perfects the piston, and improves on the Wankel. For more information visit following websites, http://quasiturbine.promci.qc.ca/ http://www.gizmag.com/go/3501/ ________________________________________________________________________________
Date: Oct 21, 2005
Put me in as a yes. Dan Johnson..Ohio >From: "Jeffrey Puls" <pulsair(at)mindspring.com> >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com >Subject: RE: Kitfox-List: Kitfox Promotional Videos >Date: Fri, 21 Oct 2005 15:45:17 -0400 > > >Grant, >Count me in. Jeff Classic IV. Ohio > > > > [Original Message] > > From: Grant Fluent <gjfpilot(at)yahoo.com> > > To: > > Date: 10/21/2005 1:47:31 PM > > Subject: Kitfox-List: Kitfox Promotional Videos > > > > > > Hello All, > > About a year ago, I completed a video project > > putting all of the Kitfox promotional videos that I > > could find on two DVDs. The two completed DVDs were > > sent to Frank Miller for his approval for me to > > distribute to the Kitfox list but he never responded. > > With what has now happened to Skystar, can I legally > > send these DVDs out? Any lawyers here? If so, is > > there anyone on here that is interested in viewing > > them? > > Thanks, > > Grant Fluent > > Newcastle, NE > > Classic IV 912S > > > > > > ________________________________________________________________________________
Date: Oct 21, 2005
Don, That is the same thing I was thinking. I wouldn't think anyone would be upset because someone is helping to promote their product - or at least now helping it maintain popularity... Grant Fluent Newcastle, NE Classic IV 912S --- Don Pearsall wrote: > > > Grant, > I don't know about LEGALLY, as I am sure that the > material was copyrighted, > but reality should intrude here. There is no one > left to tell you that you > can't distribute it. > > Don Pearsall > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On > Behalf Of Grant Fluent > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Kitfox Promotional Videos > > > > Hello All, > About a year ago, I completed a video project > putting all of the Kitfox promotional videos that I > could find on two DVDs. The two completed DVDs were > sent to Frank Miller for his approval for me to > distribute to the Kitfox list but he never > responded. > With what has now happened to Skystar, can I legally > send these DVDs out? Any lawyers here? If so, is > there anyone on here that is interested in viewing > them? > Thanks, > Grant Fluent > Newcastle, NE > Classic IV 912S > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Date: Oct 21, 2005
Hello All, There appears to be some interest in seeing the promotional videos that I have put on two DVD's. For anyone that wants to buy one, I will mail them out for $5. This will cover the postage, dvd media, my time, and wear & tear on my dvd burner. If you'd rather watch them and mail them on to the next person, we can do that too. Keep in mind it will cost over a $1 for postage and your time to package it and mail it to the next person. Send me an email off list if you'd like to buy the dvd's or just watch them and mail them on to the next person. I'll keep the two lists and put the names in the order that they were received. For the 8 people that have already expressed interest, let me know what you'd like to do. Thanks, Grant Fluent Newcastle, NE Classic IV 912S --- Grant Fluent wrote: > > > Hello All, > About a year ago, I completed a video project > putting all of the Kitfox promotional videos that I > could find on two DVDs. The two completed DVDs were > sent to Frank Miller for his approval for me to > distribute to the Kitfox list but he never > responded. > With what has now happened to Skystar, can I legally > send these DVDs out? Any lawyers here? If so, is > there anyone on here that is interested in viewing > them? > Thanks, > Grant Fluent > Newcastle, NE > Classic IV 912S > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
From: "Harris, Robert" <Robert_Harris(at)intuit.com>
Date: Oct 21, 2005
Hi Grant, I would love a copy of the Kitfox promotional videos and will pay you for your time, shipping and materials. Please mail them to the address below with the amount I owe you. P.S. I've watched the 2002 Alaska video many times and love it. Robert Harris 122 Escondido Ave, Suite 201 Vista, CA 92084 760-415-1891 ________________________________________________________________________________
Date: Oct 21, 2005
Hi Grant..i'd love to have a copy to keep. I'll send a check ..whats your address? Dan Johnson..and thanks for doing this. Dan Johnson 1395 Dillingham Court Columbus Ohio 43228 >From: Grant Fluent <gjfpilot(at)yahoo.com> >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com >Subject: Re: Kitfox-List: Kitfox Promotional Videos >Date: Fri, 21 Oct 2005 14:10:23 -0700 (PDT) > > >Hello All, > There appears to be some interest in seeing the >promotional videos that I have put on two DVD's. For >anyone that wants to buy one, I will mail them out for >$5. This will cover the postage, dvd media, my time, >and wear & tear on my dvd burner. > If you'd rather watch them and mail them on to the >next person, we can do that too. Keep in mind it will >cost over a $1 for postage and your time to package it >and mail it to the next person. > Send me an email off list if you'd like to buy the >dvd's or just watch them and mail them on to the next >person. I'll keep the two lists and put the names in >the order that they were received. For the 8 people >that have already expressed interest, let me know what >you'd like to do. >Thanks, >Grant Fluent >Newcastle, NE >Classic IV 912S > > >--- Grant Fluent wrote: > > > > > > > Hello All, > > About a year ago, I completed a video project > > putting all of the Kitfox promotional videos that I > > could find on two DVDs. The two completed DVDs were > > sent to Frank Miller for his approval for me to > > distribute to the Kitfox list but he never > > responded. > > With what has now happened to Skystar, can I legally > > send these DVDs out? Any lawyers here? If so, is > > there anyone on here that is interested in viewing > > them? > > Thanks, > > Grant Fluent > > Newcastle, NE > > Classic IV 912S > > > > > > > > browse > > Subscriptions page, > > FAQ, > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 21, 2005
I am... ----- Original Message ----- From: "Grant Fluent" <gjfpilot(at)yahoo.com> Subject: Kitfox-List: Kitfox Promotional Videos > > Hello All, > About a year ago, I completed a video project > putting all of the Kitfox promotional videos that I > could find on two DVDs. The two completed DVDs were > sent to Frank Miller for his approval for me to > distribute to the Kitfox list but he never responded. > With what has now happened to Skystar, can I legally > send these DVDs out? Any lawyers here? If so, is > there anyone on here that is interested in viewing > them? > Thanks, > Grant Fluent > Newcastle, NE > Classic IV 912S > > > > > > ________________________________________________________________________________
Date: Oct 21, 2005
Subject: skystar demise
hello my name is tony fiacco i live in new york. i just received my notice of chapter 7 bankrupcy from skystar, ive been battling, along with others for two years awaiting over 4,000 worth of parts. i am reaching out via this forum to see what i should do at this point, i apoligize, im a new member and its obvious by one days postings that there already has been discussion on this. can anyone answer my question? i would appreciate it. i called the bankrupcy trustee and she told me i was not alone by far, how many people are involved in this and how much money are we talking? what are the chances of getting any part of the 4,000 worth of parts that were never shipped to me? or will they pay the suppliers mortgage holders first? should i go to the meeting of creditors that is being held soon? any information would be appreciated. thank-you tony fiacco wanna be kitfox builder --------------------------------- ________________________________________________________________________________
Date: Oct 21, 2005
I have to disagree with Alan in one respect. Skystar was in the process of bringing everything they could manufacture in house including Aluminum gear (sent out for gun drilling and heat treating) and they were very near to being able to produce poly wing tanks. They bent their own tail springs, fabricated the flaperons and all the tooling is in fact presently owned by Skystar - soon to be owned by Phil Reed, lien holder. The only things they outsourced for the basic kit was the wheels / brakes covering materials and hardware. Selling engines IMHO was their downfall, but that decision was made by souls long gone.. Without a doubt, the parts will eventually become available if not from one vendor - a successor to Skystar - then from a number of specialty suppliers. Fly carefully and builders try to be patient. Lowell ----- Original Message ----- From: "Alan & Linda Daniels" <aldaniels(at)fmtc.com> Subject: Re: Kitfox-List: Where will we get parts in the future? > > > I agree with John. He can get you almost anything you need. Skystar did > not make most of its stuff in house, and what they did from what I > understand was on jigs that were leased from the previous owner. While > this has been hard on those of us that have lost money and struggled > with this for some time, it does give some closure and allows us to move > on. The suspense is over and now someone will undoubtedly pick up the > pieces and make it better than it has been for years. The Fox is still > the best plane of its type out there and I am sure it will live on. > > The real pain is for those that paid for kits and did not get them. If > you paid for a kit recently and did not get it you might consider > contacting the postal inspector. It is not who you would expect to > investigate this type of thing but they are the best at this type of > thing. They have unlimited budgets to call witnesses and investigate > over the entire county, and e-mail, checks, letters, contracts, > advertising and the like fall under mail fraud. A friend and I bought > an aircraft engine from a company that did not have what it said it had. > I pursued it with the postal inspectors and the head of that company got > 54 months in federal prison. While I am sure that the principals in > Skystar are suffering a lot, and have lost everything they own, that is > still no excuse for taking money for items they know they can not > deliver. If that is in fact the case they need to go to jail. > > Alan > > jdmcbean wrote: > >> >>Snip... I'm sure someone will pick up the pieces and supply Kitfox parts >>much the same as Airdale did for Avid. >> >>We have been helping Kitfoxers for the last 2 years from a technical side >>(not only on the list) and with some parts... We are also trying to gather >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 21, 2005
I might respectfully disagree here. The copywrite is owned by Skystar and I suspect would be considered an asset to be handled by the bankruptcy judge to hopefully compensate claimants. We have guys on the list that will lose sizeable investments due to the bankruptcy, maybe one of them should be first in line for this potentially valuable asset. I was at the factory on the day bankruptcy was filed as well as the day after, I could have wandered through the place with sticky fingers and no one would have been the wiser. My biggest concern is for the guys waiting in line for the crumbs. I hope some do in fact filter down. :Lowell ----- Original Message ----- From: "Don Pearsall" <donpearsall(at)comcast.net> Subject: RE: Kitfox-List: Kitfox Promotional Videos > > > Grant, > I don't know about LEGALLY, as I am sure that the material was > copyrighted, > but reality should intrude here. There is no one left to tell you that you > can't distribute it. > > Don Pearsall > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Grant Fluent > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Kitfox Promotional Videos > > > Hello All, > About a year ago, I completed a video project > putting all of the Kitfox promotional videos that I > could find on two DVDs. The two completed DVDs were > sent to Frank Miller for his approval for me to > distribute to the Kitfox list but he never responded. > With what has now happened to Skystar, can I legally > send these DVDs out? Any lawyers here? If so, is > there anyone on here that is interested in viewing > them? > Thanks, > Grant Fluent > Newcastle, NE > Classic IV 912S > > > ________________________________________________________________________________
Date: Oct 21, 2005
Its nice to be back and hear from you Lowell. My point is that if you prang a gear Grove can still supply them, if you need a cowl, fuel tank, windshield, or most other parts John can have one made by the original supplier for you. They were bringing everything in house because nobody would sell to them anymore IMHO. Almost nobody has those items that they built themselves. The only part that I see that is a problem is the flaperons which are sort of special, made on jigs in-house. I may be wrong on the lease of the fabrication jigs, but my understanding is that Phil has or will have control of them, and the only way they have value is if someone is using them. Phil Reed has a lot in this and he is no dummy by a long shot. As I said the pain is with those that did not get what they paid for. Our group is still out something like 3 engines. Alan Lowell Fitt wrote: > >I have to disagree with Alan in one respect. Skystar was in the process of >bringing everything they could manufacture in house including Aluminum gear >(sent out for gun drilling and heat treating) and they were very near to >being able to produce poly wing tanks. They bent their own tail springs, >fabricated the flaperons and all the tooling is in fact presently owned by >Skystar - soon to be owned by Phil Reed, lien holder. The only things they >outsourced for the basic kit was the wheels / brakes covering materials and >hardware. Selling engines IMHO was their downfall, but that decision was >made by souls long gone.. Without a doubt, the parts will eventually become >available if not from one vendor - a successor to Skystar - then from a >number of specialty suppliers. Fly carefully and builders try to be >patient. > >Lowell > > > > ________________________________________________________________________________
Date: Oct 21, 2005
We are also a Grove distributor.... Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Alan & Linda Daniels Subject: Re: Kitfox-List: Where will we get parts in the future? Its nice to be back and hear from you Lowell. My point is that if you prang a gear Grove can still supply them, if you need a cowl, fuel tank, windshield, or most other parts John can have one made by the original supplier for you. They were bringing everything in house because nobody would sell to them anymore IMHO. Almost nobody has those items that they built themselves. The only part that I see that is a problem is the flaperons which are sort of special, made on jigs in-house. I may be wrong on the lease of the fabrication jigs, but my understanding is that Phil has or will have control of them, and the only way they have value is if someone is using them. Phil Reed has a lot in this and he is no dummy by a long shot. As I said the pain is with those that did not get what they paid for. Our group is still out something like 3 engines. Alan Lowell Fitt wrote: > >I have to disagree with Alan in one respect. Skystar was in the process of >bringing everything they could manufacture in house including Aluminum gear >(sent out for gun drilling and heat treating) and they were very near to >being able to produce poly wing tanks. They bent their own tail springs, >fabricated the flaperons and all the tooling is in fact presently owned by >Skystar - soon to be owned by Phil Reed, lien holder. The only things they >outsourced for the basic kit was the wheels / brakes covering materials and >hardware. Selling engines IMHO was their downfall, but that decision was >made by souls long gone.. Without a doubt, the parts will eventually become >available if not from one vendor - a successor to Skystar - then from a >number of specialty suppliers. Fly carefully and builders try to be >patient. > >Lowell > > ________________________________________________________________________________
Date: Oct 21, 2005
Hi Grant, I would love to have a copy of the DVDs. I'm nearing completion of a Lite 2, 912S, with all the options. Lowell Schaper 6530 County Road 26 Minnetrista, MN 55364 763.479.2630 ________________________________________________________________________________
Date: Oct 21, 2005
Thanks for your input Lowell. You make a very valid point. So far, the response from people wanting to see these videos has been overwhelming. Skystar no longer offered any of these videos when they were in business so I guess I don't see any harm in sending these out to anyone who wants to see them. I am by no means making a profit from this and would just like to help out fellow builders/flyers. Grant Fluent Newcastle, NE Classic IV 912S --- Lowell Fitt wrote: > > > I might respectfully disagree here. The copywrite > is owned by Skystar and I > suspect would be considered an asset to be handled > by the bankruptcy judge > to hopefully compensate claimants. We have guys on > the list that will lose > sizeable investments due to the bankruptcy, maybe > one of them should be > first in line for this potentially valuable asset. > I was at the factory on > the day bankruptcy was filed as well as the day > after, I could have > wandered through the place with sticky fingers and > no one would have been > the wiser. My biggest concern is for the guys > waiting in line for the > crumbs. I hope some do in fact filter down. > > :Lowell > > ----- Original Message ----- > From: "Don Pearsall" <donpearsall(at)comcast.net> > To: > Subject: RE: Kitfox-List: Kitfox Promotional Videos > > > > > > > > Grant, > > I don't know about LEGALLY, as I am sure that the > material was > > copyrighted, > > but reality should intrude here. There is no one > left to tell you that you > > can't distribute it. > > > > Don Pearsall > > > > -----Original Message----- > > From: owner-kitfox-list-server(at)matronics.com > > [mailto:owner-kitfox-list-server(at)matronics.com] On > Behalf Of Grant Fluent > > To: kitfox-list(at)matronics.com > > Subject: Kitfox-List: Kitfox Promotional Videos > > > > > > > Hello All, > > About a year ago, I completed a video project > > putting all of the Kitfox promotional videos that > I > > could find on two DVDs. The two completed DVDs > were > > sent to Frank Miller for his approval for me to > > distribute to the Kitfox list but he never > responded. > > With what has now happened to Skystar, can I > legally > > send these DVDs out? Any lawyers here? If so, is > > there anyone on here that is interested in viewing > > them? > > Thanks, > > Grant Fluent > > Newcastle, NE > > Classic IV 912S > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Subject: Looking for Michael Meyers
Date: Oct 21, 2005
I want to contact Michael Meyers with a question about his Kitfox on Sportflight. His AOL address is no longer good. Any help would be appreciated. Thanks Jim jezim@pro-ns.net ________________________________________________________________________________
Date: Oct 21, 2005
Subject: aero-news
Check out www.aero-news.net for more details of Skystar ________________________________________________________________________________
Subject: Tail light
Date: Oct 21, 2005
I have seen several Kitfoxes in the pictures with wingtip nav lights, but no landing or tail light. I am building fiberglass mounts for a rudder mounted tail light and wing tip navs. What is the minimum for night vfr? We just heard this discusion and it was described only as "position lights" Can't locate my FAR-AIM to check. Ron NB Ore. ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Re: Tail light
Ron all the lights can be incorporated into the one light fixture on the wing tip . Each side has a backwards facing solid on light for the tail position light center strobe on each side then forward facing red and green Port / Starboard lights This is what i have and also a red strobe on top of the fuselage just behind the turtle deck and it passed inspection just fine Take care fly safe fly slow fly low John Perry kitfox 2 N718PD -------Original Message------- From: ron schick Date: 10/21/05 23:32:15 Subject: Kitfox-List: Tail light I have seen several Kitfoxes in the pictures with wingtip nav lights, but no landing or tail light. I am building fiberglass mounts for a rudder mounted tail light and wing tip navs. What is the minimum for night vfr? We just heard this discusion and it was described only as "position lights" Can't locate my FAR-AIM to check. Ron NB Ore. ________________________________________________________________________________
Subject: Tail light
Date: Oct 21, 2005
Ron, the requirement is in part 23.1389. 1 rear white light, red on left, green on right. And the FAR also describes the range each light must cover. Not required unless you are flying from sunset to sunrise. Don Pearsall -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of ron schick Subject: Kitfox-List: Tail light I have seen several Kitfoxes in the pictures with wingtip nav lights, but no landing or tail light. I am building fiberglass mounts for a rudder mounted tail light and wing tip navs. What is the minimum for night vfr? We just heard this discusion and it was described only as "position lights" Can't locate my FAR-AIM to check. Ron NB Ore. ________________________________________________________________________________
Date: Oct 21, 2005
Also landing lights are form Wallmart high intensity offroad mini lights $15 bucks for the pair. Mounted inside the cowl one set for taxi and the other set for landing configuration Works Awsome on the darkest of nights with no moon. John Perry -------Original Message------- From: ron schick Date: 10/21/05 23:32:15 Subject: Kitfox-List: Tail light I have seen several Kitfoxes in the pictures with wingtip nav lights, but no landing or tail light. I am building fiberglass mounts for a rudder mounted tail light and wing tip navs. What is the minimum for night vfr? We just heard this discusion and it was described only as "position lights" Can't locate my FAR-AIM to check. Ron NB Ore. ________________________________________________________________________________
Subject: Tail light
Date: Oct 21, 2005
Ron, Take a look.. frst item on the pg.. http://sportplanellc.com/Products.htm front is green (or red), rear is white and the center is strobe.... Meets the position light requirement. Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of ron schick Subject: Kitfox-List: Tail light I have seen several Kitfoxes in the pictures with wingtip nav lights, but no landing or tail light. I am building fiberglass mounts for a rudder mounted tail light and wing tip navs. What is the minimum for night vfr? We just heard this discusion and it was described only as "position lights" Can't locate my FAR-AIM to check. Ron NB Ore. ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Re: A Little Good News
Thanks everyone, for the kind remarks! I can't tell you how heart-warming and encouraging it is for me. As for a new steed, thanks to Mr. McBean I have already started work on a new Series 6 'fox (sorry Don). The various components of the instrument panel are spread across the dining room table and the wiring nearly complete. The wings are assembled (but not covered) and soon I'll be turning my attention to the fuselage. Now, if it weren't for having to gradually return to work I'd have lots of time to spend on it. :-) In the mean time I went up in my other baby, a Piper Turbo Arrow III named Sabrina, last Wednesday morning with an instructor and we scraped off several layers of rust from my piloting skills. It felt wonderful! Thanks again everyone! Mike G. N728KF ________________________________________________________________________________
Subject: Series 7 tanks
Date: Oct 22, 2005
Anyone know of a good supplier for S7 tanks? Two of the missing parts from my kit. I need the following but it sounds like Mcbean can help me out. Landing gear Wheels/brakes. Muffler and headers for 912S Windshield and turtledeck. Nosegear strut (if I decide against t-dragger sometime). Seems most of this stuff easily obtainable but just concerned about the tanks. Regards, Wade Greaves Oregon City ________________________________________________________________________________
Date: Oct 22, 2005
Subject: need builders manual
Hope you can read this before you go make those coppies because some great guy on the list just e-mailed the chapter I need in pdf format. I will still pay for the coppies or postage if you have started. thanks Glen. Hope you can read this before you go make those coppies because some great guy on the list just e-mailed the chapter I need in pdf format. I will still pay for the coppies or postage if you have started. thanks Glen. ________________________________________________________________________________
From: "Donna and Roger McConnell" <rdmac(at)swbell.net>
Subject: Data Plate
Date: Oct 22, 2005
This will sound like a silly question to some of the more experienced builders but I need some advice on the best and least obtrusive way to attach the data plate on a fabric airframe. I could drill through the fabric and into the frame in two maybe three places and pop rivet it on but drilling into the frame sure sounds extreme. Has anyone used a good RTV adhesive to do this? Will it hold? I am looking in the area on the left side under the horizontal stab. to do this. Roger Mac S7/912S ________________________________________________________________________________
Subject: Re: Data Plate
Date: Oct 22, 2005
I fabricated an alum plate (about 1/2" bigger than the data plate). Pre-drilled holes to match the data plate. Place the alum plate on the inside of the fabric and then pop rivet the data plate through the fabric to the alum plate. I can't remember if I applied some Poly Brush to the alum plate or not? Don Smythe ----- Original Message ----- From: "Donna and Roger McConnell" <rdmac(at)swbell.net> Subject: Kitfox-List: Data Plate > > > This will sound like a silly question to some of the more experienced > builders but I need some advice on the best and least obtrusive way to > attach the data plate on a fabric airframe. I could drill through the > fabric > and into the frame in two maybe three places and pop rivet it on but > drilling into the frame sure sounds extreme. Has anyone used a good RTV > adhesive to do this? Will it hold? I am looking in the area on the left > side > under the horizontal stab. to do this. > > > Roger Mac > > S7/912S > > > ________________________________________________________________________________
Subject: Data Plate
Date: Oct 22, 2005
Mine has hung on under the horizontal since...92..and 500hrs I didn't build it but i'll go look when im out there today and see how it was done...dan >From: "Donna and Roger McConnell" <rdmac(at)swbell.net> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Kitfox-List: Data Plate >Date: Sat, 22 Oct 2005 08:24:24 -0500 > > > >This will sound like a silly question to some of the more experienced >builders but I need some advice on the best and least obtrusive way to >attach the data plate on a fabric airframe. I could drill through the >fabric >and into the frame in two maybe three places and pop rivet it on but >drilling into the frame sure sounds extreme. Has anyone used a good RTV >adhesive to do this? Will it hold? I am looking in the area on the left >side >under the horizontal stab. to do this. > > > Roger Mac > > S7/912S > > ________________________________________________________________________________
Date: Oct 22, 2005
Subject: Re: skystar demise
Hi Tony. Search Matronics archives for the string on Skystar's Bankruptcy. Also check EAA website for good background story. Yes, secured creditors and priority claims get first crack at assets. Unsecured creditors (probably you) will get a pro-rata share of what's left. Cents on the dollar, more likely zero. Later, if you have any specific questions contact me off-list. tony fiacco wrote: hello my name is tony fiacco i live in new york. i just received my notice of chapter 7 bankrupcy from skystar, ive been battling, along with others for two years awaiting over 4,000 worth of parts. i am reaching out via this forum to see what i should do at this point, i apoligize, im a new member and its obvious by one days postings that there already has been discussion on this. can anyone answer my question? i would appreciate it. i called the bankrupcy trustee and she told me i was not alone by far, how many people are involved in this and how much money are we talking? what are the chances of getting any part of the 4,000 worth of parts that were never shipped to me? or will they pay the suppliers mortgage holders first? should i go to the meeting of creditors that is being held soon? any information would be appreciated. thank-you tony fiacco wanna be kitfox builder --------------------------------- Marco Menezes Model 2 582 N99KX --------------------------------- ________________________________________________________________________________
Date: Oct 22, 2005
My data plate is riveted to the metal cover plate that is just under the stabilizer. Ron N55KF > Mine has hung on under the horizontal since...92..and 500hrs I didn't > build > it but i'll go look when im out there today and see how it was done...dan > > >>From: "Donna and Roger McConnell" <rdmac(at)swbell.net> >>Reply-To: kitfox-list(at)matronics.com >>To: >>Subject: Kitfox-List: Data Plate >>Date: Sat, 22 Oct 2005 08:24:24 -0500 >> >> >> >>This will sound like a silly question to some of the more experienced >>builders but I need some advice on the best and least obtrusive way to >>attach the data plate on a fabric airframe. I could drill through the >>fabric >>and into the frame in two maybe three places and pop rivet it on but >>drilling into the frame sure sounds extreme. Has anyone used a good RTV >>adhesive to do this? Will it hold? I am looking in the area on the left >>side >>under the horizontal stab. to do this. >> >> >> Roger Mac >> >> S7/912S >> >> > > > ________________________________________________________________________________
Date: Oct 22, 2005
Lowell is right. Grant's source materials, the promo videos, are intellectual property - assets belonging to Skystar. These are now under control of the Trustee in Bankruptcy. Value added by Grant, i.e. production value, is his however. This muddies the picture. It's unlikely that Trustee would come after Grant for "giving away" DVD's at cost. This asset is of dubious value (to anyone but us) and probably not worth ligitating over. More likely the Trustee would abandon it, if she even becomes aware of it. Nonetheless, to be absolutely safe, Grant should wait until the case is discharged before charging for DVD's. wrote: I might respectfully disagree here. The copywrite is owned by Skystar and I suspect would be considered an asset to be handled by the bankruptcy judge to hopefully compensate claimants. We have guys on the list that will lose sizeable investments due to the bankruptcy, maybe one of them should be first in line for this potentially valuable asset. I was at the factory on the day bankruptcy was filed as well as the day after, I could have wandered through the place with sticky fingers and no one would have been the wiser. My biggest concern is for the guys waiting in line for the crumbs. I hope some do in fact filter down. :Lowell ----- Original Message ----- From: "Don Pearsall" Subject: RE: Kitfox-List: Kitfox Promotional Videos > > > Grant, > I don't know about LEGALLY, as I am sure that the material was > copyrighted, > but reality should intrude here. There is no one left to tell you that you > can't distribute it. > > Don Pearsall > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Grant Fluent > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Kitfox Promotional Videos > > > Hello All, > About a year ago, I completed a video project > putting all of the Kitfox promotional videos that I > could find on two DVDs. The two completed DVDs were > sent to Frank Miller for his approval for me to > distribute to the Kitfox list but he never responded. > With what has now happened to Skystar, can I legally > send these DVDs out? Any lawyers here? If so, is > there anyone on here that is interested in viewing > them? > Thanks, > Grant Fluent > Newcastle, NE > Classic IV 912S > > > Marco Menezes Model 2 582 N99KX --------------------------------- ________________________________________________________________________________
Date: Oct 22, 2005
I mounted an old style Grimes clear lens tail light on the tip of my fin, facing rearwards of course. Had to make a mounting piece out of aluminum for it to sit on. Still looks great after 14 years. Ron ----- Original Message ----- From: "John Perry" <eskflyer(at)pld.com> Subject: Re: Kitfox-List: Tail light > > Ron all the lights can be incorporated into the one light fixture on the > wing tip . Each side has a backwards facing solid on light for the tail > position light center strobe on each side then forward facing red and > green > Port / Starboard lights This is what i have and also a red strobe on top > of > the fuselage just behind the turtle deck and it passed inspection just > fine > > Take care fly safe fly slow fly low > > John Perry > kitfox 2 N718PD > > -------Original Message------- > > From: ron schick > Date: 10/21/05 23:32:15 > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Tail light > > > > I have seen several Kitfoxes in the pictures with wingtip nav lights, but > no > landing or tail light. I am building fiberglass mounts for a rudder > mounted > tail light and wing tip navs. What is the minimum for night vfr? We > just > heard this discusion and it was described only as "position lights" Can't > locate my FAR-AIM to check. Ron NB Ore. > > > ________________________________________________________________________________
Date: Oct 22, 2005
Roger, I attached mine to the access cover below the horizontal stabilizer. At least for vintage 1998 that was acceptable. Lowell ----- Original Message ----- From: "Donna and Roger McConnell" <rdmac(at)swbell.net> Subject: Kitfox-List: Data Plate > > > This will sound like a silly question to some of the more experienced > builders but I need some advice on the best and least obtrusive way to > attach the data plate on a fabric airframe. I could drill through the > fabric > and into the frame in two maybe three places and pop rivet it on but > drilling into the frame sure sounds extreme. Has anyone used a good RTV > adhesive to do this? Will it hold? I am looking in the area on the left > side > under the horizontal stab. to do this. > > > Roger Mac > > S7/912S > > > ________________________________________________________________________________
From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Subject: Data Plate
Date: Oct 22, 2005
Roger, I just riveted it to the fiberglass just in front of the left side door. Used backer washers. What Gross Weight are you going with? 1320? 1550? You may have a more valuable plane at 1320 lbs. Randy . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Donna and Roger McConnell Subject: Kitfox-List: Data Plate This will sound like a silly question to some of the more experienced builders but I need some advice on the best and least obtrusive way to attach the data plate on a fabric airframe. I could drill through the fabric and into the frame in two maybe three places and pop rivet it on but drilling into the frame sure sounds extreme. Has anyone used a good RTV adhesive to do this? Will it hold? I am looking in the area on the left side under the horizontal stab. to do this. Roger Mac S7/912S ________________________________________________________________________________
Date: Oct 22, 2005
Sorry folks. That last message from me was to an individual I didn't mean to post it to the list... Sorry folks. That last message from me was to an individual I didn't mean to post it to the list... ________________________________________________________________________________
From: "John Anderson" <janderson412(at)hotmail.com>
Date: Oct 23, 2005
Where abouts on the fuse should the data plate be fixed? John A. From: "Don Smythe" <dosmythe(at)cox.net> Subject: Re: Kitfox-List: Data Plate Date: Sat, 22 Oct 2005 09:49:35 -0400 I fabricated an alum plate (about 1/2" bigger than the data plate). Pre-drilled holes to match the data plate. Place the alum plate on the inside of the fabric and then pop rivet the data plate through the fabric to the alum plate. I can't remember if I applied some Poly Brush to the alum plate or not? Don Smythe ----- Original Message ----- From: "Donna and Roger McConnell" <rdmac(at)swbell.net> Subject: Kitfox-List: Data Plate > > >This will sound like a silly question to some of the more experienced >builders but I need some advice on the best and least obtrusive way to >attach the data plate on a fabric airframe. I could drill through the >fabric >and into the frame in two maybe three places and pop rivet it on but >drilling into the frame sure sounds extreme. Has anyone used a good RTV >adhesive to do this? Will it hold? I am looking in the area on the left >side >under the horizontal stab. to do this. > > > Roger Mac > > S7/912S > > Discover fun and games at @ http://xtramsn.co.nz/kids ________________________________________________________________________________
Date: Oct 22, 2005
From: "Donna and Roger McConnell" <rdmac(at)swbell.net> > I am looking in the area on the left side > under the horizontal stab. to do this. Roger, mine is pop rivetted in the triangular aluminium plate under the horizontal stab, on the left side. I have a model 3 that has that plate and I guess you plane doesn't, otherwise you wouldn't be asking, am I right? Cheers, Michel ________________________________________________________________________________
Subject: Data Plate
Date: Oct 22, 2005
When the FAA inspected my plane they made me affix my data plate to the inside of the stainless steel firewall behind the co-pilots ruddder pedals. They stated that if there was a fire the plate would stay intact with the surface and in all likelehood would survive. I may not but it would. Jeff Cklassic IV Ohio Jeffrey Puls pulsair(at)mindspring.com ________________________________________________________________________________
Subject: Congratulations
Date: Oct 23, 2005
Hi all, > > In the midst of all the doom and gloom, I hope you won't mind a > little bit of good personal news. It's been 14 months since the > accident that destroyed my beloved Kitfox IV and I've spent the time > recovering from two shattered legs and severe facial injuries. > > It's taken 7 surgeries so far (one more anticipated) and a lot of > physical therapy, but yesterday I went down to the local AME and was > issued a class III medical certificate! I just need a flight review > and I'll be legal to act as pilot in command once again. Where's > that horse, I'm ready to get back on it! > > Thanks for your indulgence, > > Mike G. > N728KF Congratulations Mike, you are an inspiration to us all. Your presence on this list is also most valuable so I'm pleased you will be around for a while yet. Hope you soon find new wings and may they be Kitfox. It takes more than the collapse of Skystar to put me off. As you say Kitfox is the best. Rex. rexjan(at)bigpond.com ________________________________________________________________________________
Subject: DVD's
Date: Oct 23, 2005
Hello All, About a year ago, I completed a video project putting all of the Kitfox promotional videos that I could find on two DVDs. The two completed DVDs were sent to Frank Miller for his approval for me to distribute to the Kitfox list but he never responded. With what has now happened to Skystar, can I legally send these DVDs out? Any lawyers here? If so, is there anyone on here that is interested in viewing them? Hi ! Grant, if you get rolling on this I would be interested for one in those DVD's. Rex. rexjan(at)bigpond.com ________________________________________________________________________________
Subject: Data Plate
Date: Oct 22, 2005
Michel, Yes indeed the Model 7 has cover plates on both sides at the horizontal stab. And the cover is probable as good as any place to attach the data plate. I just think that if I were to loose that cover then the plate is lost too. I would prefer to attach it to something that doesn't get removed. And Don's idea seems easy enough to do. But I appreciate your input. Best Regards Roger Mac -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Michel Verheughe Subject: Re: Kitfox-List: Data Plate From: "Donna and Roger McConnell" <rdmac(at)swbell.net> > I am looking in the area on the left side > under the horizontal stab. to do this. Roger, mine is pop rivetted in the triangular aluminium plate under the horizontal stab, on the left side. I have a model 3 that has that plate and I guess you plane doesn't, otherwise you wouldn't be asking, am I right? Cheers, Michel ________________________________________________________________________________
Date: Oct 22, 2005
I believe the FAA wants the plate to be near the rear of the plane. In case of an emergency landing/fire the rear of the plane would be more survivable therefore, saving the plate. Don Smythe ----- Original Message ----- From: "John Anderson" <janderson412(at)hotmail.com> Subject: Re: Kitfox-List: Data Plate > > > > Where abouts on the fuse should the data plate be fixed? John A. > > > From: "Don Smythe" <dosmythe(at)cox.net> > To: > Subject: Re: Kitfox-List: Data Plate > Date: Sat, 22 Oct 2005 09:49:35 -0400 > > I fabricated an alum plate (about 1/2" bigger than the data plate). > Pre-drilled holes to match the data plate. Place the alum plate on the > inside of the fabric and then pop rivet the data plate through the fabric > to > the alum plate. I can't remember if I applied some Poly Brush to the alum > plate or not? > > Don Smythe > > ----- Original Message ----- > From: "Donna and Roger McConnell" <rdmac(at)swbell.net> > To: > Subject: Kitfox-List: Data Plate > > >> >> >>This will sound like a silly question to some of the more experienced >>builders but I need some advice on the best and least obtrusive way to >>attach the data plate on a fabric airframe. I could drill through the >>fabric >>and into the frame in two maybe three places and pop rivet it on but >>drilling into the frame sure sounds extreme. Has anyone used a good RTV >>adhesive to do this? Will it hold? I am looking in the area on the left >>side >>under the horizontal stab. to do this. >> >> >> Roger Mac >> >> S7/912S >> >> > > > Discover fun and games at @ http://xtramsn.co.nz/kids > > > ________________________________________________________________________________
Date: Oct 22, 2005
It seems I remember that the data plate should be attached so it cannot be easily removed. Putting the plate on a removable piece of the airplane didn't seem to meet the intent of the law. Don Smythe ----- Original Message ----- > the data plate. I just think that if I were to loose that cover then the > plate is lost too. I would prefer to attach it to something that doesn't > get > removed. ________________________________________________________________________________
Date: Oct 22, 2005
From: "Ronald K. Stevens" <rkstevens(at)verizon.net>
Grant, I'd certainly be interested in getting a copy. Just let me know where to send the check and how much you'd like for it. Thanks, Ron Stevens Series 6 Grant Fluent wrote: > >Hello All, > About a year ago, I completed a video project >putting all of the Kitfox promotional videos that I >could find on two DVDs. The two completed DVDs were >sent to Frank Miller for his approval for me to >distribute to the Kitfox list but he never responded. >With what has now happened to Skystar, can I legally >send these DVDs out? Any lawyers here? If so, is >there anyone on here that is interested in viewing >them? >Thanks, >Grant Fluent >Newcastle, NE >Classic IV 912S > > > > ________________________________________________________________________________
Date: Oct 22, 2005
I agree that it should be permanently attached. My neighbor (RV6) had to move his from an inspection cover to the main fuselage to pass his aw inspection. On the Kitfox with fabric your dar may insist it be riveted to metal. I plan on a flange under the fabric to satisfy the requirement >From: "Don Smythe" <dosmythe(at)cox.net> >Reply-To: kitfox-list(at)matronics.com >To: >Subject: Re: Kitfox-List: Data Plate >Date: Sat, 22 Oct 2005 19:50:34 -0400 > > >It seems I remember that the data plate should be attached so it cannot be >easily removed. Putting the plate on a removable piece of the airplane >didn't seem to meet the intent of the law. > >Don Smythe > >----- Original Message ----- > > the data plate. I just think that if I were to loose that cover then the > > plate is lost too. I would prefer to attach it to something that doesn't > > get > > removed. > > ________________________________________________________________________________
Date: Oct 22, 2005
Subject: Re: Series 7 tanks
Hi Wade, I just put my KF5 away for the winter....I know it's kinda' early and all but I am saving some pennies for another kit project. I was thinking of a KF7 but that status changed a bit last week..... Come on by sometime, I'm in Molalla. Jeff Smathers KF5 N456JT NSI Subaru EA-81 and CAP140 Greaves wrote: > > Anyone know of a good supplier for S7 tanks? > Two of the missing parts from my kit. > I need the following but it sounds like Mcbean can help me out. > Landing gear > Wheels/brakes. > Muffler and headers for 912S > Windshield and turtledeck. > Nosegear strut (if I decide against t-dragger sometime). > Seems most of this stuff easily obtainable but just concerned about the tanks. > Regards, > Wade Greaves > Oregon City > ________________________________________________________________________________
Date: Oct 22, 2005
I'm about to attach my data plate as well. FAA AC20-27F states that the data plate may must be attached so that it cannot be removed during normal service. The Seattle FSDO advised me that the tail access covers on my model 5 were not a suitable location for the data plate. AC20-27F further states that the data plate should be adjacent to the aft of the rear-most entrance door or on the fuselage near the tail surface. I am planning to use Don's method of riveting through a backing plate aft of the pilot side door. I want people to see that it was built by me. Joel Model 5 912 GTA CS prop Aerocomp amphibs ________________________________________________________________________________
Date: Oct 23, 2005
Hi Grant, I am highly interested in that DVD`s. Werner Keiper Kitfox 3 E-Mail: werner@keiper-koerdorf.de -----Ursprngliche Nachricht----- Von: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] Im Auftrag von Grant Fluent Gesendet: Freitag, 21. Oktober 2005 19:47 An: kitfox-list(at)matronics.com Betreff: Kitfox-List: Kitfox Promotional Videos Hello All, About a year ago, I completed a video project putting all of the Kitfox promotional videos that I could find on two DVDs. The two completed DVDs were sent to Frank Miller for his approval for me to distribute to the Kitfox list but he never responded. With what has now happened to Skystar, can I legally send these DVDs out? Any lawyers here? If so, is there anyone on here that is interested in viewing them? Thanks, Grant Fluent Newcastle, NE Classic IV 912S ________________________________________________________________________________
From: "Clifford Begnaud" <shoeless(at)barefootpilot.com>
Date: Oct 23, 2005
You put it away for the winter??? I'm just getting mine ready for the winter flying season when I do 80% of my flying. Cliff Erie, CO > Hi Wade, > > I just put my KF5 away for the winter....I know it's kinda' early and all > but I am saving some pennies for another kit project. I was thinking of a > KF7 but that status changed a bit last week..... > > Come on by sometime, I'm in Molalla. > > Jeff Smathers KF5 N456JT NSI Subaru EA-81 and CAP140 > > Greaves wrote: > >> >> Anyone know of a good supplier for S7 tanks? >> Two of the missing parts from my kit. >> I need the following but it sounds like Mcbean can help me out. >> Landing gear >> Wheels/brakes. >> Muffler and headers for 912S >> Windshield and turtledeck. >> Nosegear strut (if I decide against t-dragger sometime). >> Seems most of this stuff easily obtainable but just concerned about the >> tanks. >> Regards, >> Wade Greaves >> Oregon City >> > > > ________________________________________________________________________________
From: "George Wells(at)adelphia.net" <georgewells(at)adelphia.net>
Subject: High Voltage
Date: Oct 23, 2005
I have a Mod 5 with a 912S and recently installed a dual Amp & Volt meter. I previously only had a Amp meter. While flying today the voltage reading started to rise until it was at the top of the scale at appox 18 volts and the amp meter at appox. 5 amps. After I cycled a few accessories the voltage came back down to around 13.5 - 14 volts and the amps at just a slight positive deflection from 0. My question is does this sound like a rectifier or some other problem ? Thanks ________________________________________________________________________________
Date: Oct 23, 2005
From: Frank & Phyllis <frank.phyllis(at)mindspring.com>
Subject: Series 7 Parts
I'd appreciate someone providing me with the source & part # for a Series 7 radiator (PN 54016.102) or the dimensions so I can seek one out. Also, the Series 7 uses a 2" prop extension. Anyone using an IVO prop with a 2" extension? Again, I'd appreciate info re a source for the extension. Finally, what is the Rotax PN for the 912S air filter, Skystar PN 64903.000 (for a Series 7)? Thanks, Frank ________________________________________________________________________________
Date: Oct 23, 2005
Frank, As an IVO dealer I can help with that pretty easy... Give me a shout... I can get the Radiator as well... Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Frank & Phyllis Subject: Kitfox-List: Series 7 Parts I'd appreciate someone providing me with the source & part # for a Series 7 radiator (PN 54016.102) or the dimensions so I can seek one out. Also, the Series 7 uses a 2" prop extension. Anyone using an IVO prop with a 2" extension? Again, I'd appreciate info re a source for the extension. Finally, what is the Rotax PN for the 912S air filter, Skystar PN 64903.000 (for a Series 7)? Thanks, Frank ________________________________________________________________________________
From: "Kerry Skyring" <kerryskyring(at)hotmail.com>
Subject: RE:Was High Voltage - S5 questions
Date: Oct 23, 2005
George wrote.. I have a Mod 5 with a 912S and recently installed a dual Amp & Volt meter... George I can't answer your question but as you are an S5 with 912S flyer then I'd like to put a couple of questions. We are about to receive the flight permit for an S5 with 912S and as the day draws closer questions arise. Any problems with the trim? Our inspector thought the trim indicator was all wrong and we've just spent a day completely re-doing everything to do with the trim (according to the manual) and ended up back where we were in the first place. Did all your rigging come out right? Our down elevator is one or two degrees less than it should be. What's your cruise speed? We have fixed pitch prop, Grove gear and big tyres. And are you pleased with your S5? Sorry about the questions and lack of answers but you probably know how it is as the day approaches - the head scratching and worrying intensifies. Kerry Kitfox builders helper > > ________________________________________________________________________________
Date: Oct 23, 2005
Subject: Re: Trim
You really can not put the trim markings on until you fly. Just use a marker and put a line on the metal strip just for reference were you think is about right. You will be holding on to the stick so tight the first flight that you will have no idea if the trim is right or not. Then when you fly you can see were it really is and remark. When you are happy with that then put your sicker on. Close is good enough for test flying as the stick pressures are not that high even if you are way out of trim, like full up when you forget to reset before takeoff. You will find that the plane does not use much trim except for landing. I use one notch flaps for takeoff and taking the flap off goes to close to cruse climb. Little bumps to the switch will tune it up. It is a bugger getting that sticker on without taking the indicator out, which is why I have colored tape to indicate the takeoff zone on one of my planes. Too many thumbs to install it right Alan Kerry Skyring wrote: > >George wrote.. >I have a Mod 5 with a 912S and recently installed a dual Amp & Volt meter... > >George I can't answer your question but as you are an S5 with 912S flyer >then I'd like to put a couple of questions. We are about to receive the >flight permit for an S5 with 912S and as the day draws closer questions >arise. > >Any problems with the trim? Our inspector thought the trim indicator was all >wrong and we've just spent a day completely re-doing everything to do with >the trim (according to the manual) and ended up back where we were in the >first place. > >Did all your rigging come out right? Our down elevator is one or two degrees >less than it should be. > >What's your cruise speed? We have fixed pitch prop, Grove gear and big >tyres. > >And are you pleased with your S5? > >Sorry about the questions and lack of answers but you probably know how it >is as the day approaches - the head scratching and worrying intensifies. >Kerry >Kitfox builders helper > > > > >> >> > > > > ________________________________________________________________________________
Date: Oct 23, 2005
Subject: Re: High Voltage
Hi George. I noted the same thing happening with my Model 2 (582). It had the original equipment regulator/rectifier that came with the kit. I also noted on inspection that the original regulator showed physical signs of having overheated. I replaced it with a Key West blue box from Aircraft Spruce and the indicated voltage dropped back to 13-14 at full power. There's a good article on regulator/rectifiers for Rotax engines at http://www.georgia-ultralights.com/page/page/898129.htm "George Wells(at)adelphia.net" wrote: I have a Mod 5 with a 912S and recently installed a dual Amp & Volt meter. I previously only had a Amp meter. While flying today the voltage reading started to rise until it was at the top of the scale at appox 18 volts and the amp meter at appox. 5 amps. After I cycled a few accessories the voltage came back down to around 13.5 - 14 volts and the amps at just a slight positive deflection from 0. My question is does this sound like a rectifier or some other problem ? Thanks Marco Menezes Model 2 582 N99KX ________________________________________________________________________________
Subject: Need Series 5 cowling
Date: Oct 23, 2005
Just a heads up. The following items are being offered for sale. The engine is broken in and has less than 75 hours. If there is something not listed please let me know and we can figure something out. I am offering at 75 percent of new unless otherwise stated or agreed upon. Many of these items are based on 2002 prices. No tax and actual UPS shipping only. I accept Pay Pal at wingsdown(at)comcast.net for fast delivery. I will be posting pics to a web site soon. If you need some right away just let me know. I have decided to sell the engine package less firewall engine mount to firewall. It was originally an NSI engine. I have completely rebuilt the engine to include the heads. The redrive unit has the latest upgrade from NSI, which I believe was new shaft and material, larger bearings and the like. Below is a list of mods and parts: Total run time appx 70 hours, engine was not running at time of nose wheel collapse. Oil pan was damaged by nose strut but can be easily repaired or replaced for about 300 dollars. . Engine has since been run, and oil changed as well as redrive oil. This engine makes over 150HP. I will include radiator and necessary plumbing from aircraft. This engine is complete and ready to mount to NSI engine mount for aircraft of your choosing. It was in a model 5 Kitfox. Mounts on engine are included. No break in necessary, its been done. Keep in mind the rotax engine is going for about 20K and does not make this kind of power nor is it rated for continuous full power operation. New pistons and rings All new bearings and seals Pistons, pins, rings and block cryogenic treated, not over sized Pistons ceramic coated tops molly sides Cylinders line honed Crank zero run out reconditioned rods with new bushings weight matched new turbo cam coated by Swain reconditioned lifters stainless down pipe and stack heads have stainless valves, 3 angle valve cut, ceramic tops and scallops, new bronze guides, coated HP springs, reconditioned rockers intake manifold special Swain heat dissipating coating Oil lines are Teflon New Taylor ignition wires Stainless headers by Dawley Aviation with special Swain coating, with EGT holes MOCAL oil thermostat plumbed with lines will provide cooler New oil pump remote filter mount and Teflon lines new water pump Turbo completely rebuilt and upgraded to include new compressor section, Swain coated exhaust turbine section, hard line cooling line and more. Ellison TBI 3A, all fuel lines Teflon to include line to firewall Powder coated aluminum valve covers Dual electronic ignition and pick ups, programmable Alternator with overage voltage unit Engine block heater, not that I needed it here in sunny California I will give the list first shot and then either sell it locally or list on EBay. This is a strong smooth engine. You wont be disappointed. If you have the non-turbo NSI then this would be an easy swap for much more power and higher density altitude capabilities. If your serious and would like to see her run let me know ASAP. ITEMS FOR SALE: EA-81 TURBO engine with redrive ready to run $8,700 list 2002 price with out upgrades list 11,500. Vacuume pump Kit for EA-81 includes pump, drive assy, suction gauge by rapco, filter and clamps. $750.00 list at $998.00 CAP 140 In-flight adjustable three blade hub assembly, includes hub assembly, electronics control unit, panel switch and indicator lamp.$1625.oo list $2165 CAP digital pitch indication gage with latest software upgrade $521.00 list $695.00 Header tank aluminum***sold Air oil separators 2 custom aluminum powder coated$288 ea list $385 Strobe kit with Nav lights multi station comet selectable flash, plus collision white belly tail strobe $657.00 List $877 Strobe Whelen model 70821 red lens anti collision with power pack $181.00 Garmin 295 GPS with latest data base, extras $500.00 list N/A Transponder Garmin GTX 327 solid state with rack, $ 1425.00 list $1895.00. Pre wired Transcal encoder add $150.00 to price Comm Radio Bendix King (97A TSO with mounting rack $825 list $1100.oo E.L.T. Ameri king AK-450 with comm. Capability $138.00 list $184 Headset Bose Aviation X like new with case and original box $850.00 list $995.00. Headset Lightspeed 20X with soft case, very nice $326.00 list $435.00. Traffic Alert ADT-300 Barley installed in aircraft $490.00 list $650.00 Fuel Flow gage JPI-450 with transducer $430.00 list $573.75 EGT digital by E.I. $180.00 list $239 I have two $180. each. Hand Held Com/Nav radio VXA-200 by Yaesu. This unit has it all. Altitude indication, density altitude pressure altitude, temperature and VOR great rugged little radio, with extra NMHI battery $465.00 List $620.00 Com/Nav antenna by Advance Aircraft Electronics model VHF5-1, thin flat for many applications to include composite aircraft. $94.00 list at $125.00 Volt/Amp gage digital by E.I. Electronics international model VA-1A $214.00 list $285.00 Carb Ice temp gage by Westach with sending probe $53.00 lists at $69.80 Intercom by PS Engineering model PM100 II Also have digital cockpit recorder, cant find price will include for additional $100.00 $335 List $449.00 Electric Clock MD-90 BLET $169.00 List $226 Battery RG35AXC with custom aluminum power coated hold down and cables $125.00 Battery PC680 with aluminum mounting box $75.00 was set up as back up battery. PRIMARY INSTRUMENTS Air speed indicator W27859 by Winter zero to 180MPH $240.00 list $320.00 Directional Gyro model RCA11A-8 non electric TSO $438.00 list $548.00 Altimeter zero to 20,000 feet model BG-3 $406.00 list $542.00 Vertical Speed indicator $232.00 list $310.00 Turn coordinator by Electro gyro corp. model 1394T100-7Z 12-32V $630.00 list $840.00 HSI Attitude Gyro most likely RC Allen , it is vacuum but will have to verify model and price VDO gages 2 1/8 Tachometer, water temp,oil pressure, oil temperature, boost 0-15psi, RPM gage large 3 1/8 maybe 3 not sure, egt 0-1600F Interior Oregon Aero temper foam seats, two sets plus extra seat cushion for seat height adjustment, done in dark blue Best seats i have ever sat on makes the flight very comfortable.$499 list at $670.00 Leather interior , this is for a model 5, may work on others, medium blue, carbon fiber seat reinforced seat back included, leather covered front, rear baggage cover with white embroidered EXPERIMENTAL on opening cover, open area under turtle deck, center consol sides, left and right kick panels, control stick boots and covers. I may have enough to do the glare shied but will have to check. $1,200 List N/A Cushions Standard velour in blue and red four cushions total $100.00 Heater cockpit 210CFM high output with two fans $260 list $345 Airframe Turtle deck with smoke lexan glass, has scratch in glass $150.00 Cowling upper only not round type, NACCA scoop installed , also two sets of vents aft, oil access and inspection door. $300.00 Cargo bay bag with aluminum bottom insert, $95.00 Long Wings with lift struts and braces, struts fared in, flapperons. These items were damaged. Left substantially more than the right. They will both need have the fabric removed and be inspected, repaired and re-certified for airworthiness. I would say major damage to the left wing and minor to moderate to the right. I can e-mail detail pics of both. Considering the cost of new wings at over $4000.00 I think a fair starting point would be about $1500 I am open to offers higher or a little lower. Will assist freight pick up , no shipping from this end. Personal pick up is fine and I will help you load up. Wing towing braces $ 55.00 Electric elevator trim servo, dont really know but figure on 75 percent of replacement. Wheel pants left side only $50.00 Rudder Elevator Control rigging and pulleys Wheels (2) Brakes (2) Master cylinders (4) Fuel control valve by Andair replaced stock unit $180 list $240 I am sure there is more but thats all for now. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Kerry Skyring Subject: Re: Kitfox-List: Need Series 5 cowling Ron wrote, >Its time to start my hunt for a Series 5 top & bottom cowl. It must be the >one for the Lycombing or Continental engine which is the "Cessna" style. Hi Ron, we have an unused cowl for the Continental 0-200 engine on a Series 5. Problem is we are in Vienna Austria and the freight costs would probably make this non-viable for you. However keep it in mind and if you don't source anything locally give me an email and we will try to work out a viable deal. Kerry. S5 builders helper. Taxied it on Sunday. Ohitsjustwunderbar. > > ________________________________________________________________________________
Subject: Header Tank
Date: Oct 23, 2005
-----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Jay Carter Subject: Kitfox-List: Header Tank Anyone on the list have a header tank p/n 90064.000 that is surplus to your needs and would sell? p/n is from S-6 assembly manual. Jay C. ________________________________________________________________________________
Date: Oct 23, 2005
The following items are being offered for sale. The engine is broken in and has less than 75 hours. If there is something not listed please let me know and we can figure something out. I am offering at 75 percent of new unless otherwise stated or agreed upon. Many of these items are based on 2002 prices. No tax and actual UPS shipping only. I accept Pay Pal at wingsdown(at)comcast.net for fast delivery. I will be posting pics to a web site soon. If you need some right away just let me know. I have decided to sell the engine package less firewall engine mount to firewall. It was originally an NSI engine. I have completely rebuilt the engine to include the heads. The redrive unit has the latest upgrade from NSI, which I believe was new shaft and material, larger bearings and the like. Below is a list of mods and parts: Total run time appx 70 hours, engine was not running at time of nose wheel collapse. Oil pan was damaged by nose strut but can be easily repaired or replaced for about 300 dollars. . Engine has since been run, and oil changed as well as redrive oil. This engine makes over 150HP. I will include radiator and necessary plumbing from aircraft. This engine is complete and ready to mount to NSI engine mount for aircraft of your choosing. It was in a model 5 Kitfox. Mounts on engine are included. No break in necessary, its been done. Keep in mind the rotax engine is going for about 20K and does not make this kind of power nor is it rated for continuous full power operation. New pistons and rings All new bearings and seals Pistons, pins, rings and block cryogenic treated, not over sized Pistons ceramic coated tops molly sides Cylinders line honed Crank zero run out reconditioned rods with new bushings weight matched new turbo cam coated by Swain reconditioned lifters stainless down pipe and stack heads have stainless valves, 3 angle valve cut, ceramic tops and scallops, new bronze guides, coated HP springs, reconditioned rockers intake manifold special Swain heat dissipating coating Oil lines are Teflon New Taylor ignition wires Stainless headers by Dawley Aviation with special Swain coating, with EGT holes MOCAL oil thermostat plumbed with lines will provide cooler New oil pump remote filter mount and Teflon lines new water pump Turbo completely rebuilt and upgraded to include new compressor section, Swain coated exhaust turbine section, hard line cooling line and more. Ellison TBI 3A, all fuel lines Teflon to include line to firewall Powder coated aluminum valve covers Dual electronic ignition and pick ups, programmable Alternator with overage voltage unit Engine block heater, not that I needed it here in sunny California I will give the list first shot and then either sell it locally or list on EBay. This is a strong smooth engine. You wont be disappointed. If you have the non-turbo NSI then this would be an easy swap for much more power and higher density altitude capabilities. If your serious and would like to see her run let me know ASAP. ITEMS FOR SALE: EA-81 TURBO engine with redrive ready to run $8,700 list 2002 price with out upgrades list 11,500. Vacuume pump Kit for EA-81 includes pump, drive assy, suction gauge by rapco, filter and clamps. $750.00 list at $998.00 CAP 140 In-flight adjustable three blade hub assembly, includes hub assembly, electronics control unit, panel switch and indicator lamp.$1625.oo list $2165 CAP digital pitch indication gage with latest software upgrade $521.00 list $695.00 Header tank aluminum***sold Air oil separators 2 custom aluminum powder coated$288 ea list $385 Strobe kit with Nav lights multi station comet selectable flash, plus collision white belly tail strobe $657.00 List $877 Strobe Whelen model 70821 red lens anti collision with power pack $181.00 Garmin 295 GPS with latest data base, extras $500.00 list N/A Transponder Garmin GTX 327 solid state with rack, $ 1425.00 list $1895.00. Pre wired Transcal encoder add $150.00 to price Comm Radio Bendix King (97A TSO with mounting rack $825 list $1100.oo E.L.T. Ameri king AK-450 with comm. Capability $138.00 list $184 Headset Bose Aviation X like new with case and original box $850.00 list $995.00. Headset Lightspeed 20X with soft case, very nice $326.00 list $435.00. Traffic Alert ADT-300 Barley installed in aircraft $490.00 list $650.00 Fuel Flow gage JPI-450 with transducer $430.00 list $573.75 EGT digital by E.I. $180.00 list $239 I have two $180. each. Hand Held Com/Nav radio VXA-200 by Yaesu. This unit has it all. Altitude indication, density altitude pressure altitude, temperature and VOR great rugged little radio, with extra NMHI battery $465.00 List $620.00 Com/Nav antenna by Advance Aircraft Electronics model VHF5-1, thin flat for many applications to include composite aircraft. $94.00 list at $125.00 Volt/Amp gage digital by E.I. Electronics international model VA-1A $214.00 list $285.00 Carb Ice temp gage by Westach with sending probe $53.00 lists at $69.80 Intercom by PS Engineering model PM100 II Also have digital cockpit recorder, cant find price will include for additional $100.00 $335 List $449.00 Electric Clock MD-90 BLET $169.00 List $226 Battery RG35AXC with custom aluminum power coated hold down and cables $125.00 Battery PC680 with aluminum mounting box $75.00 was set up as back up battery. PRIMARY INSTRUMENTS Air speed indicator W27859 by Winter zero to 180MPH $240.00 list $320.00 Directional Gyro model RCA11A-8 non electric TSO $438.00 list $548.00 Altimeter zero to 20,000 feet model BG-3 $406.00 list $542.00 Vertical Speed indicator $232.00 list $310.00 Turn coordinator by Electro gyro corp. model 1394T100-7Z 12-32V $630.00 list $840.00 HSI Attitude Gyro most likely RC Allen , it is vacuum but will have to verify model and price VDO gages 2 1/8 Tachometer, water temp,oil pressure, oil temperature, boost 0-15psi, RPM gage large 3 1/8 maybe 3 not sure, egt 0-1600F Interior Oregon Aero temper foam seats, two sets plus extra seat cushion for seat height adjustment, done in dark blue Best seats i have ever sat on makes the flight very comfortable.$499 list at $670.00 Leather interior , this is for a model 5, may work on others, medium blue, carbon fiber seat reinforced seat back included, leather covered front, rear baggage cover with white embroidered EXPERIMENTAL on opening cover, open area under turtle deck, center consol sides, left and right kick panels, control stick boots and covers. I may have enough to do the glare shied but will have to check. $1,200 List N/A Cushions Standard velour in blue and red four cushions total $100.00 Heater cockpit 210CFM high output with two fans $260 list $345 Airframe Turtle deck with smoke lexan glass, has scratch in glass $150.00 Cowling upper only not round type, NACCA scoop installed , also two sets of vents aft, oil access and inspection door. $300.00 Cargo bay bag with aluminum bottom insert, $95.00 Long Wings with lift struts and braces, struts fared in, flapperons. These items were damaged. Left substantially more than the right. They will both need have the fabric removed and be inspected, repaired and re-certified for airworthiness. I would say major damage to the left wing and minor to moderate to the right. I can e-mail detail pics of both. Considering the cost of new wings at over $4000.00 I think a fair starting point would be about $1500 I am open to offers higher or a little lower. Will assist freight pick up , no shipping from this end. Personal pick up is fine and I will help you load up. Wing towing braces $ 55.00 Electric elevator trim servo, dont really know but figure on 75 percent of replacement. Wheel pants left side only $50.00 Rudder Elevator Control rigging and pulleys Wheels (2) Brakes (2) Master cylinders (4) Fuel control valve by Andair replaced stock unit $180 list $240 I am sure there is more but thats all for now. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Jay Carter Subject: Kitfox-List: Header Tank Anyone on the list have a header tank p/n 90064.000 that is surplus to your needs and would sell? p/n is from S-6 assembly manual. Jay C. ________________________________________________________________________________
Subject: Rick Please contact me off line
Date: Oct 23, 2005
The following items are being offered for sale. The engine is broken in and has less than 75 hours. If there is something not listed please let me know and we can figure something out. I am offering at 75 percent of new unless otherwise stated or agreed upon. Many of these items are based on 2002 prices. No tax and actual UPS shipping only. I accept Pay Pal at wingsdown(at)comcast.net for fast delivery. I will be posting pics to a web site soon. If you need some right away just let me know. I have decided to sell the engine package less firewall engine mount to firewall. It was originally an NSI engine. I have completely rebuilt the engine to include the heads. The redrive unit has the latest upgrade from NSI, which I believe was new shaft and material, larger bearings and the like. Below is a list of mods and parts: Total run time appx 70 hours, engine was not running at time of nose wheel collapse. Oil pan was damaged by nose strut but can be easily repaired or replaced for about 300 dollars. . Engine has since been run, and oil changed as well as redrive oil. This engine makes over 150HP. I will include radiator and necessary plumbing from aircraft. This engine is complete and ready to mount to NSI engine mount for aircraft of your choosing. It was in a model 5 Kitfox. Mounts on engine are included. No break in necessary, its been done. Keep in mind the rotax engine is going for about 20K and does not make this kind of power nor is it rated for continuous full power operation. New pistons and rings All new bearings and seals Pistons, pins, rings and block cryogenic treated, not over sized Pistons ceramic coated tops molly sides Cylinders line honed Crank zero run out reconditioned rods with new bushings weight matched new turbo cam coated by Swain reconditioned lifters stainless down pipe and stack heads have stainless valves, 3 angle valve cut, ceramic tops and scallops, new bronze guides, coated HP springs, reconditioned rockers intake manifold special Swain heat dissipating coating Oil lines are Teflon New Taylor ignition wires Stainless headers by Dawley Aviation with special Swain coating, with EGT holes MOCAL oil thermostat plumbed with lines will provide cooler New oil pump remote filter mount and Teflon lines new water pump Turbo completely rebuilt and upgraded to include new compressor section, Swain coated exhaust turbine section, hard line cooling line and more. Ellison TBI 3A, all fuel lines Teflon to include line to firewall Powder coated aluminum valve covers Dual electronic ignition and pick ups, programmable Alternator with overage voltage unit Engine block heater, not that I needed it here in sunny California I will give the list first shot and then either sell it locally or list on EBay. This is a strong smooth engine. You wont be disappointed. If you have the non-turbo NSI then this would be an easy swap for much more power and higher density altitude capabilities. If your serious and would like to see her run let me know ASAP. ITEMS FOR SALE: EA-81 TURBO engine with redrive ready to run $8,700 list 2002 price with out upgrades list 11,500. Vacuume pump Kit for EA-81 includes pump, drive assy, suction gauge by rapco, filter and clamps. $750.00 list at $998.00 CAP 140 In-flight adjustable three blade hub assembly, includes hub assembly, electronics control unit, panel switch and indicator lamp.$1625.oo list $2165 CAP digital pitch indication gage with latest software upgrade $521.00 list $695.00 Header tank aluminum***sold Air oil separators 2 custom aluminum powder coated$288 ea list $385 Strobe kit with Nav lights multi station comet selectable flash, plus collision white belly tail strobe $657.00 List $877 Strobe Whelen model 70821 red lens anti collision with power pack $181.00 Garmin 295 GPS with latest data base, extras $500.00 list N/A Transponder Garmin GTX 327 solid state with rack, $ 1425.00 list $1895.00. Pre wired Transcal encoder add $150.00 to price Comm Radio Bendix King (97A TSO with mounting rack $825 list $1100.oo E.L.T. Ameri king AK-450 with comm. Capability $138.00 list $184 Headset Bose Aviation X like new with case and original box $850.00 list $995.00. Headset Lightspeed 20X with soft case, very nice $326.00 list $435.00. Traffic Alert ADT-300 Barley installed in aircraft $490.00 list $650.00 Fuel Flow gage JPI-450 with transducer $430.00 list $573.75 EGT digital by E.I. $180.00 list $239 I have two $180. each. Hand Held Com/Nav radio VXA-200 by Yaesu. This unit has it all. Altitude indication, density altitude pressure altitude, temperature and VOR great rugged little radio, with extra NMHI battery $465.00 List $620.00 Com/Nav antenna by Advance Aircraft Electronics model VHF5-1, thin flat for many applications to include composite aircraft. $94.00 list at $125.00 Volt/Amp gage digital by E.I. Electronics international model VA-1A $214.00 list $285.00 Carb Ice temp gage by Westach with sending probe $53.00 lists at $69.80 Intercom by PS Engineering model PM100 II Also have digital cockpit recorder, cant find price will include for additional $100.00 $335 List $449.00 Electric Clock MD-90 BLET $169.00 List $226 Battery RG35AXC with custom aluminum power coated hold down and cables $125.00 Battery PC680 with aluminum mounting box $75.00 was set up as back up battery. PRIMARY INSTRUMENTS Air speed indicator W27859 by Winter zero to 180MPH $240.00 list $320.00 Directional Gyro model RCA11A-8 non electric TSO $438.00 list $548.00 Altimeter zero to 20,000 feet model BG-3 $406.00 list $542.00 Vertical Speed indicator $232.00 list $310.00 Turn coordinator by Electro gyro corp. model 1394T100-7Z 12-32V $630.00 list $840.00 HSI Attitude Gyro most likely RC Allen , it is vacuum but will have to verify model and price VDO gages 2 1/8 Tachometer, water temp,oil pressure, oil temperature, boost 0-15psi, RPM gage large 3 1/8 maybe 3 not sure, egt 0-1600F Interior Oregon Aero temper foam seats, two sets plus extra seat cushion for seat height adjustment, done in dark blue Best seats i have ever sat on makes the flight very comfortable.$499 list at $670.00 Leather interior , this is for a model 5, may work on others, medium blue, carbon fiber seat reinforced seat back included, leather covered front, rear baggage cover with white embroidered EXPERIMENTAL on opening cover, open area under turtle deck, center consol sides, left and right kick panels, control stick boots and covers. I may have enough to do the glare shied but will have to check. $1,200 List N/A Cushions Standard velour in blue and red four cushions total $100.00 Heater cockpit 210CFM high output with two fans $260 list $345 Airframe Turtle deck with smoke lexan glass, has scratch in glass $150.00 Cowling upper only not round type, NACCA scoop installed , also two sets of vents aft, oil access and inspection door. $300.00 Cargo bay bag with aluminum bottom insert, $95.00 Long Wings with lift struts and braces, struts fared in, flapperons. These items were damaged. Left substantially more than the right. They will both need have the fabric removed and be inspected, repaired and re-certified for airworthiness. I would say major damage to the left wing and minor to moderate to the right. I can e-mail detail pics of both. Considering the cost of new wings at over $4000.00 I think a fair starting point would be about $1500 I am open to offers higher or a little lower. Will assist freight pick up , no shipping from this end. Personal pick up is fine and I will help you load up. Wing towing braces $ 55.00 Electric elevator trim servo, dont really know but figure on 75 percent of replacement. Wheel pants left side only $50.00 Rudder Elevator Control rigging and pulleys Wheels (2) Brakes (2) Master cylinders (4) Fuel control valve by Andair replaced stock unit $180 list $240 I am sure there is more but thats all for now. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Harris, Robert Subject: Kitfox-List: Rick Please contact me off line Hi Rick, Can you please contact me off line at 760-415-1810 or e-mail me at Robert_harris(at)intuit.com Thanks, Robert ________________________________________________________________________________
Subject: Re: Trim
Date: Oct 24, 2005
http://www.sportflight.com/cgi-bin/uploader.pl?action=view&epoch=1069446885, works great indeed! JohnA. From: Alan & Linda Daniels <aldaniels(at)fmtc.com> Subject: Kitfox-List: Re: Trim Date: Sun, 23 Oct 2005 15:17:39 -0600 You really can not put the trim markings on until you fly. Just use a marker and put a line on the metal strip just for reference were you think is about right. You will be holding on to the stick so tight the first flight that you will have no idea if the trim is right or not. Then when you fly you can see were it really is and remark. When you are happy with that then put your sicker on. Close is good enough for test flying as the stick pressures are not that high even if you are way out of trim, like full up when you forget to reset before takeoff. You will find that the plane does not use much trim except for landing. I use one notch flaps for takeoff and taking the flap off goes to close to cruse climb. Little bumps to the switch will tune it up. It is a bugger getting that sticker on without taking the indicator out, which is why I have colored tape to indicate the takeoff zone on one of my planes. Too many thumbs to install it right Alan Kerry Skyring wrote: > >George wrote.. >I have a Mod 5 with a 912S and recently installed a dual Amp & Volt meter... > >George I can't answer your question but as you are an S5 with 912S flyer >then I'd like to put a couple of questions. We are about to receive the >flight permit for an S5 with 912S and as the day draws closer questions >arise. > >Any problems with the trim? Our inspector thought the trim indicator was all >wrong and we've just spent a day completely re-doing everything to do with >the trim (according to the manual) and ended up back where we were in the >first place. > >Did all your rigging come out right? Our down elevator is one or two degrees >less than it should be. > >What's your cruise speed? We have fixed pitch prop, Grove gear and big >tyres. > >And are you pleased with your S5? > >Sorry about the questions and lack of answers but you probably know how it >is as the day approaches - the head scratching and worrying intensifies. >Kerry >Kitfox builders helper > > > > >> >> > > > > ________________________________________________________________________________
From: "Gordon Faulkner" <hagar(at)othertonair.freeserve.co.uk>
Subject: Altering early wing section
Date: Oct 24, 2005
Dear Foxfolk, Is there a consensus view regarding the benefits (or otherwise) of infilling the underside of the early wing ribs? I've been told that the cruise performance of my Mk3 will be improved by altering the standard wing section to the one introduced on the Mk4. Since I'm soon to start making my wings this would be the time to make the change but I'd feel happier about the decision after hearing a few more opinions. Is there anyone on list who's actually made this particular modification? Much of my flying will be from short grass airstrips, my home airfield has 300 yards available. Gordon Faulkner ________________________________________________________________________________
Date: Oct 24, 2005
Subject: Re: Trim
FWIW. On a somewhat related note someone suggested to me on the intial test flight, err on the side of too much down trim. That way you do not have an unexpected and too early lift off proceeding rapidly to a dangerously nose high attitude. Maxwell Alan & Linda Daniels wrote: You really can not put the trim markings on until you fly. Just use a marker and put a line on the metal strip just for reference were you think is about right. You will be holding on to the stick so tight the first flight that you will have no idea if the trim is right or not. Then when you fly you can see were it really is and remark. When you are happy with that then put your sicker on. Close is good enough for test flying as the stick pressures are not that high even if you are way out of trim, like full up when you forget to reset before takeoff. You will find that the plane does not use much trim except for landing. I use one notch flaps for takeoff and taking the flap off goes to close to cruse climb. Little bumps to the switch will tune it up. It is a bugger getting that sticker on without taking the indicator out, which is why I have colored tape to indicate the takeoff zone on one of my planes. Too many thumbs to install it right Alan Kerry Skyring wrote: > >George wrote.. >I have a Mod 5 with a 912S and recently installed a dual Amp & Volt meter... > >George I can't answer your question but as you are an S5 with 912S flyer >then I'd like to put a couple of questions. We are about to receive the >flight permit for an S5 with 912S and as the day draws closer questions >arise. > >Any problems with the trim? Our inspector thought the trim indicator was all >wrong and we've just spent a day completely re-doing everything to do with >the trim (according to the manual) and ended up back where we were in the >first place. > >Did all your rigging come out right? Our down elevator is one or two degrees >less than it should be. > >What's your cruise speed? We have fixed pitch prop, Grove gear and big >tyres. > >And are you pleased with your S5? > >Sorry about the questions and lack of answers but you probably know how it >is as the day approaches - the head scratching and worrying intensifies. >Kerry >Kitfox builders helper > > > > >> >> > > > > --------------------------------- ________________________________________________________________________________
Date: Oct 24, 2005
> From: Gordon Faulkner [hagar(at)othertonair.freeserve.co.uk] > I've been told that the cruise performance of my Mk3 will be improved by > altering the standard wing section to the one introduced on the Mk4. Hello Gordon, I also have a Mk3 with the undercambered wings. But I wouldn't try to change it, even if it may increase a bit my cruise speed. I know very little about airfoils but I think that what you will gain in cruise speed, you will loose as lift at slow speed. And, on a warm sunny day, with a chubby passenger, no wind, wet and long grass ... 300 yards is not all that much of a distance to take off, is it? Just my twopence, old chap! Cheers, Michel ________________________________________________________________________________
Date: Oct 24, 2005
Subject: Re: Altering early wing section
In a message dated 10/24/2005 8:25:09 AM Central Daylight Time, michel(at)online.no writes: > From: Gordon Faulkner [hagar(at)othertonair.freeserve.co.uk] > I've been told that the cruise performance of my Mk3 will be improved by > altering the standard wing section to the one introduced on the Mk4. Hello Gordon, I also have a Mk3 with the undercambered wings. But I wouldn't try to change it, even if it may increase a bit my cruise speed. I know very little about airfoils but I think that what you will gain in cruise speed, you will loose as lift at slow speed. And, on a warm sunny day, with a chubby passenger, no wind, wet and long grass ... 300 yards is not all that much of a distance to take off, is it? Just my twopence, old chap! Cheers, Michel I have a Model 2.....my EW strip is less that 800 feet and the NS is 400. Yes, I fly in and out at gross weight all the time... KF2 582 IVO prop Dave ________________________________________________________________________________
Subject: S-5 Rudder Pedal Reinforcements
Date: Oct 24, 2005
Has anyone tried installing rudder pedal reinforcing gussets after the rudder pedals were assembled? What is the best way to do so? I can remove the pedals from the fuselage okay, but would rather not remove the rivets holding them onto the torque tubes if I can avoid it. It seems to me that the plastic bushings over the torque tubes would melt by the heat of welding. Riveting doesn't seem strong enough & one must drill into structure to rivet. Any tales of experience will be appreciated. Thanks, Grant Krueger S-5 TD w/O-235 ________________________________________________________________________________
Date: Oct 24, 2005
I have a casted kit for this. Give me a shout off-line... Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Tinne maha Subject: Kitfox-List: S-5 Rudder Pedal Reinforcements Has anyone tried installing rudder pedal reinforcing gussets after the rudder pedals were assembled? What is the best way to do so? I can remove the pedals from the fuselage okay, but would rather not remove the rivets holding them onto the torque tubes if I can avoid it. It seems to me that the plastic bushings over the torque tubes would melt by the heat of welding. Riveting doesn't seem strong enough & one must drill into structure to rivet. Any tales of experience will be appreciated. Thanks, Grant Krueger S-5 TD w/O-235 ________________________________________________________________________________
Date: Oct 24, 2005
Subject: Prop blade pitch
I have a Kitfox IV Speedster with a Rotax 912, which originally had a Ivo in flight adjustable prop. I fanially got tired of replacing the broken adjustment mechanism and puttin up with the harmonics of all blade not (apparently) being set to the same pitch. replaced it with a 3 blade Warp drive Prop, but am having trouble with where to set the pitch. The first suggestion I got had me at 17 degrees and the engine won't wind up all the way in a staic runnup. HELP>>>>>>>>>>>>> ________________________________________________________________________________
Date: Oct 24, 2005
Subject: list
I just sold my kitfox How do I get off the list L , Green ________________________________________________________________________________
Subject: Re: Prop blade pitch
Date: Oct 24, 2005
Try going down to about 12 degress, then just fine tune it. It will take lots of trial and error to get it set just right and you won't really know until you fly it at different settings. I would suggest using a digital level or laser to really get your blades set exactly the same. Be sure to have each blade rotated to exactly the same position as the first one to take your measurements. I used a piece of wood cut to a lenght that would allow it to stand up on the floor and touch the bottom of the blade tip when the blade was parallel to the floor. Also, on the warp drive you need to check for blade alignment in addition to pitch. Just put a stationary object on the floor and rotate the blades around and make sure the tip of each blade passes the same distance to the object, no more than 1/8" difference. Use shims behind the hub to adjust alignment. Once you get the pitch set where you like it, put index marks on the blade root and hub. You can set up different settings for bush work or for cruise. The marks will get you very close when changing from one setting to another. Good luck, Cliff > > I have a Kitfox IV Speedster with a Rotax 912, which originally had a Ivo > in flight adjustable prop. I fanially got tired of replacing the broken > adjustment mechanism and puttin up with the harmonics of all blade not > (apparently) being set to the same pitch. replaced it with a 3 blade Warp > drive Prop, but am having trouble with where to set the pitch. The first > suggestion I got had me at 17 degrees and the engine won't wind up all the > way in a staic runnup. HELP>>>>>>>>>>>>> > ________________________________________________________________________________
Subject: Re: list
Date: Oct 24, 2005
All taken care of L. Have a great day. Deke List Janitor ----- Original Message ----- From: <LGreen4899(at)aol.com> Subject: Kitfox-List: list > > I just sold my kitfox How do I get off the list L , Green > > > > > > ________________________________________________________________________________
Date: Oct 24, 2005
Subject: Re: Short field. WAS: Altering early wing section
In a message dated 10/24/2005 12:01:44 PM Central Daylight Time, michel(at)online.no writes: Aerobatics(at)aol.com wrote: > I have a Model 2.....my EW strip is less that 800 feet and the NS is 400. > Yes, I fly in and out at gross weight all the time... Then you are a better pilot than I am, Dave. But it should't be too difficult. :-) Cheers, Michel do not archive NO No I didnt mean to offend...... :-) Its the plane ... Its about proper numbrs etc. at gross weight, it stalls around 38 mph... Base I am at 50 final I start slowing down so at short final 45, then over the threashold at 40 and 1 to 3 altitude..... gives a bit of speed for flare. 3 point full stall, is the only way for real short landings...:-) It does take a bit of practice, but it just goes to show...if I can do it anybody can! Dave ________________________________________________________________________________
Date: Oct 24, 2005
In a message dated 10/24/2005 3:17:41 PM Central Daylight Time, michel(at)online.no writes: No offence taken, my friend. If I am not good at short field it's because I fly from a 2,400 ft asphalt runway and that's plenty of space. I don't have to worry if I float after flaring, I have plenty of space. But the few times I have been taking off from a short gras field, on a hot day and with a passenger, I was surprised how short the runway was. It felt very short but as Einstein once said, it's all relative! :-) Cheers, Michel Agreed.... By the way, you might want to practice short field landings... It is an amazing plane and it my someday come in very handy, especially in an emergency Best, Dave ________________________________________________________________________________
Date: Oct 24, 2005
The early wing section was designed by Dean Wilson for the Avid A model. It is not a standard catalogued section. None-the-less it performs very well at low speed, better than the MK IV section. If you are interested in STOL it is a better profile. If speed is your need you need a different airplane. However you can gain a not inconsequential increase in speed with careful fairing of the struts and roots and landing gear. On a Mod III I'd stick with the original wing and enjoy the superior short field performance. Jerry Liles Gordon Faulkner wrote: > >Dear Foxfolk, >Is there a consensus view regarding the benefits (or otherwise) of infilling >the underside of the early wing ribs? > >I've been told that the cruise performance of my Mk3 will be improved by >altering the standard wing section to the one introduced on the Mk4. Since >I'm soon to start making my wings this would be the time to make the change >but I'd feel happier about the decision after hearing a few more opinions. >Is there anyone on list who's actually made this particular modification? > >Much of my flying will be from short grass airstrips, my home airfield has >300 yards available. > >Gordon Faulkner > > > > ________________________________________________________________________________
Date: Oct 24, 2005
Subject: glass streaks and scratches
Searched the archives for a recent post regarding a spray cleaner of some sort that gets rid of streaking or scratches that impair visibility in your windshield or bubble doors. Anyone remember what the product or solution was? Thanks, Jared ________________________________________________________________________________
From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Date: Oct 24, 2005
Jared, Go to your local car parts store and ask for something for your plastic windshield in your boat. Aircraft Spruce has something too, but may cost more. Also get some "microfiber" towels. They won't scratch your windshield. Randy . -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jareds Subject: Kitfox-List: glass streaks and scratches Searched the archives for a recent post regarding a spray cleaner of some sort that gets rid of streaking or scratches that impair visibility in your windshield or bubble doors. Anyone remember what the product or solution was? Thanks, Jared ________________________________________________________________________________
Date: Oct 24, 2005
Jared I was in My shop with an automotive buffer and tryed it on my winshield. Just like on paint it polished out the scraches like new. As with paint it is easy to " burn through". Use caution but with the right buffing compounds even deep scraches can be buffed out. Test on scraps first. Ron NB Ore. >From: jareds <jareds(at)verizon.net> >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com.Gecko/20040804.Netscape/7.2 (ax) >Subject: Kitfox-List: glass streaks and scratches >Date: Mon, 24 Oct 2005 20:18:08 -0500 > > >Searched the archives for a recent post regarding a spray cleaner of >some sort that gets rid of streaking or scratches that impair visibility >in your windshield or bubble doors. Anyone remember what the product or >solution was? > >Thanks, > >Jared > > ________________________________________________________________________________
Subject: Storage issues
Date: Oct 25, 2005
HI Guys, Im settling into the new plane really well and although my wife wont let me sleep in the hanger with it yet our relationship is becoming firmly established. I do however have a storage problem and need some advise as to how you have all dealt with this issue. I have decided against a pod at this stage leaving behind the seat storage the only option. Has anyone glassed in this area or made shelves or anything similar to help out with carrying your gear around. There appears to be plenty of room behind the seat so some advice, photo's etc detailing how you have managed it would be great. Cheers Graeme Toft ________________________________________________________________________________
Date: Oct 24, 2005
Subject: Re: glass streaks and scratches
Ron, Does this work to get the "cloudiness" out of the glass too? ron schick wrote: > >Jared I was in My shop with an automotive buffer and tryed it on my >winshield. Just like on paint it polished out the scraches like new. As >with paint it is easy to " burn through". Use caution but with the right >buffing compounds even deep scraches can be buffed out. Test on scraps >first. > Ron NB Ore. > > > > >>From: jareds <jareds(at)verizon.net> >>Reply-To: kitfox-list(at)matronics.com >>To: kitfox-list(at)matronics.com.Gecko/20040804.Netscape/7.2 (ax) >>Subject: Kitfox-List: glass streaks and scratches >>Date: Mon, 24 Oct 2005 20:18:08 -0500 >> >> >>Searched the archives for a recent post regarding a spray cleaner of >>some sort that gets rid of streaking or scratches that impair visibility >>in your windshield or bubble doors. Anyone remember what the product or >>solution was? >> >>Thanks, >> >>Jared >> >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 24, 2005
Cheers Graeme, Most people opt for a "baggage sack" for the behind the seat area. The same people who make the Skystar upholstery make them. Or you can make one yourself. Also don't forget for the Series 5 and above, John McBean sells an under-the-seat storage bin. Don Pearsall Sound Appraisal Seattle, WA USA 425-392.4627 FAX 425-557-0107 donpearsall(at)comcast.net http://www.soundappraisal.com -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft Subject: Kitfox-List: Storage issues HI Guys, Im settling into the new plane really well and although my wife wont let me sleep in the hanger with it yet our relationship is becoming firmly established. I do however have a storage problem and need some advise as to how you have all dealt with this issue. I have decided against a pod at this stage leaving behind the seat storage the only option. Has anyone glassed in this area or made shelves or anything similar to help out with carrying your gear around. There appears to be plenty of room behind the seat so some advice, photo's etc detailing how you have managed it would be great. Cheers Graeme Toft ________________________________________________________________________________
Date: Oct 24, 2005
Negative.. Surface defects only Ron >From: jareds <jareds(at)verizon.net> >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com.Gecko/20040804.Netscape/7.2 (ax) >Subject: Re: Kitfox-List: glass streaks and scratches >Date: Mon, 24 Oct 2005 23:16:32 -0500 > > >Ron, > >Does this work to get the "cloudiness" out of the glass too? > >ron schick wrote: > > > > > >Jared I was in My shop with an automotive buffer and tryed it on my > >winshield. Just like on paint it polished out the scraches like new. As > >with paint it is easy to " burn through". Use caution but with the right > >buffing compounds even deep scraches can be buffed out. Test on scraps > >first. > > Ron NB Ore. > > > > > > > > > >>From: jareds <jareds(at)verizon.net> > >>Reply-To: kitfox-list(at)matronics.com > >>To: kitfox-list(at)matronics.com.Gecko/20040804.Netscape/7.2 (ax) > >>Subject: Kitfox-List: glass streaks and scratches > >>Date: Mon, 24 Oct 2005 20:18:08 -0500 > >> > >> > >>Searched the archives for a recent post regarding a spray cleaner of > >>some sort that gets rid of streaking or scratches that impair visibility > >>in your windshield or bubble doors. Anyone remember what the product or > >>solution was? > >> > >>Thanks, > >> > >>Jared > >> > >> > >> > >> > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 24, 2005
I also have one listed in the email I posted. It has a nice lite aluminum bottom to hold stuff witout warping. Rick -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Don Pearsall Subject: RE: Kitfox-List: Storage issues Cheers Graeme, Most people opt for a "baggage sack" for the behind the seat area. The same people who make the Skystar upholstery make them. Or you can make one yourself. Also don't forget for the Series 5 and above, John McBean sells an under-the-seat storage bin. Don Pearsall Sound Appraisal Seattle, WA USA 425-392.4627 FAX 425-557-0107 donpearsall(at)comcast.net http://www.soundappraisal.com -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft Subject: Kitfox-List: Storage issues HI Guys, Im settling into the new plane really well and although my wife wont let me sleep in the hanger with it yet our relationship is becoming firmly established. I do however have a storage problem and need some advise as to how you have all dealt with this issue. I have decided against a pod at this stage leaving behind the seat storage the only option. Has anyone glassed in this area or made shelves or anything similar to help out with carrying your gear around. There appears to be plenty of room behind the seat so some advice, photo's etc detailing how you have managed it would be great. Cheers Graeme Toft ________________________________________________________________________________
Date: Oct 24, 2005
Subject: Cockpit Fumes
Hi all! Does anyone have a recommendation on how to seal the openings where the gear shock-cord comes through? It seems like a likely entrance for exhaust fumes. Thanks, Guy Buchanan K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Subject: Engine Mounts
Date: Oct 25, 2005
Hello, I'm new to the list and am impressed with the support out there. I'm one of the unlucky ones that put down a $12,000 deposit on a Classic IV and got nothing due to the Bankruptcy. I was discouraged at first, but I think the Kitfox is a great plane and decided to buy a completed one and am picking up a model II on Friday. My question is, this has the old 582 plate mount and I would like to upgrade. I have the mount that goes to the firewall, but there are 4 brackets and rubber pieces that bolt to the engine and then the mount. Does anyone know where I could get these, or get dimensions and fabricate my own? Thanks Tom White ________________________________________________________________________________
Subject: Re: Mass balances: WAS Altering early wing section
Date: Oct 25, 2005
Thanks for the wing section info Jerry, the concensus opinion on this list definately is to retain the original Dean Wilson section on my K3 so that's what I've decided to do. For me speed is much less of an issue than short field capability, although an extra 10mph on economy cruise would have been welcome. Obviously with a Vne of 100mph the Kitfox 3 isn't for speed freaks (for that I have a Suzuki TL1000S). Changing subject: my kit has a pair of mass balance weights with it and the Build Manual page W40 describes how to fit them, it's a 1990 kit (number 918). I've downloaded the bulletins from the Skystar site (it's still functional at present) and found a mandatory one dated August 14 1992 stating that mass balances MUST be fitted. This bulletin followed a couple of flaperon flutter incidents. Thing is during the last month the Kifoxes I've looked at here in UK, a K2 and three K3's, don't have mass balances. My guess is there might be a good reason why they haven't been fitted. Anyone know what it is? The ones I have seem really heavy (massive?) for attaching to the very light flaperon structure. Brgds, Gordon ----- Original Message ----- From: "Jerry Liles" <wliles(at)bayou.com> Subject: Re: Kitfox-List: Altering early wing section > > The early wing section was designed by Dean Wilson for the Avid A > model. It is not a standard catalogued section. None-the-less it > performs very well at low speed, better than the MK IV section. If you > are interested in STOL it is a better profile. If speed is your need > you need a different airplane. However you can gain a not > inconsequential increase in speed with careful fairing of the struts and > roots and landing gear. On a Mod III I'd stick with the original wing > and enjoy the superior short field performance. > > Jerry Liles > > Gordon Faulkner wrote: > >> >> >>Dear Foxfolk, >>Is there a consensus view regarding the benefits (or otherwise) of >>infilling >>the underside of the early wing ribs? >> >>I've been told that the cruise performance of my Mk3 will be improved by >>altering the standard wing section to the one introduced on the Mk4. Since >>I'm soon to start making my wings this would be the time to make the >>change >>but I'd feel happier about the decision after hearing a few more opinions. >>Is there anyone on list who's actually made this particular modification? >> >>Much of my flying will be from short grass airstrips, my home airfield has >>300 yards available. >> >>Gordon Faulkner >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Storage issues
Date: Oct 25, 2005
Hya Don, Do you have a contact number or e-address for the "people who make the Skystar upholstery"? My K3 kit doesn't have any upholstery with it and I'd like to fit new rather than search for a used set. Rgds, Gordon ----- Original Message ----- From: "Don Pearsall" <donpearsall(at)comcast.net> Subject: RE: Kitfox-List: Storage issues > > > Cheers Graeme, > Most people opt for a "baggage sack" for the behind the seat area. The > same > people who make the Skystar upholstery make them. Or you can make one > yourself. > > Also don't forget for the Series 5 and above, John McBean sells an > under-the-seat storage bin. > > > Don Pearsall > Sound Appraisal > Seattle, WA USA > 425-392.4627 > FAX 425-557-0107 > donpearsall(at)comcast.net > http://www.soundappraisal.com > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Storage issues > > > HI Guys, Im settling into the new plane really well and although my wife > wont let me sleep in the hanger with it yet our relationship is becoming > firmly established. I do however have a storage problem and need some > advise > as to how you have all dealt with this issue. I have decided against a pod > at this stage leaving behind the seat storage the only option. Has anyone > glassed in this area or made shelves or anything similar to help out with > carrying your gear around. There appears to be plenty of room behind the > seat so some advice, photo's etc detailing how you have managed it would > be > great. > > Cheers > > > Graeme Toft > > ________________________________________________________________________________
Subject: Re: Engine Mounts
Date: Oct 25, 2005
Hya Tom, Not quite sure what parts you mean but I've got a set of 582 engine mounts for a K3 including an aluminium lower plate, a powdercoated "spider" mount and some rubbers, I won't be needing these because I'm fitting a 912. If these parts are any use to you contact me off-list. Fortunately the previous owner of my kit (who didn't start building it) bought a set of 912 engine mounts from Skystar before they went under. Rgds, Gordon ----- Original Message ----- From: "Thomas White" <twhitepa(at)magiclink.com> Subject: Kitfox-List: Engine Mounts > > Hello, > > I'm new to the list and am impressed with the support out there. I'm > one of the unlucky ones that put down a $12,000 deposit on a Classic IV > and got nothing due to the Bankruptcy. I was discouraged at first, but > I think the Kitfox is a great plane and decided to buy a completed one > and am picking up a model II on Friday. My question is, this has the > old 582 plate mount and I would like to upgrade. I have the mount that > goes to the firewall, but there are 4 brackets and rubber pieces that > bolt to the engine and then the mount. Does anyone know where I could > get these, or get dimensions and fabricate my own? > Thanks > Tom White > > > ________________________________________________________________________________
Date: Oct 25, 2005
Subject: Mass balances
> From: Gordon Faulkner [hagar(at)othertonair.freeserve.co.uk] > Changing subject: my kit has a pair of mass balance weights with it and the > Build Manual page W40 describes how to fit them, it's a 1990 kit (number > 918). Gordon, my model 3 is from 1991 (build #998) and it was finished built in 1993, not by me, unfortunately, I am the third owner. It has the mass balances and while it may look heavy in your hand, it feels ok once installed on the flaperons. My understanding is that, with them, you can increase your Vne. Incidentally, mine is, as noted by the builder, 100 MPH. But I believe, with the masses, I can exceed that without risking fluttering of the flaperon. Please double-check this, my memory is as unreliable as any advice I may give! :-) Cheers, Michel ________________________________________________________________________________
Date: Oct 25, 2005
I purchased a "scratch removal kit" at OSH and used it on a sidewinder canopy. I worked good, but was a lot of work to do a perfect job. It took about 6 hours to do a windshield and canopy. The basic idea is several grades of sandpaper starting at 1500 grit and going to 3600 (all done wet) all with velcro back for a random orbital sander, which I purchased from harbor freight. Then a liquid was used on a buffing pad (furnished in the kit)followed by an antistatic cream. There is also a hand kit with some of the same products, only in strips used for hand sanding, which on a complete windshield would way to much work. When at the hanger i'll get the name and address for those who contact me off list at shilocom(at)mcmsys.com Cost was around $80 US. Bob U. ----- Original Message ----- From: "jareds" <jareds(at)verizon.net> Subject: Re: Kitfox-List: glass streaks and scratches > > Ron, > > Does this work to get the "cloudiness" out of the glass too? > > ron schick wrote: > > > > >Jared I was in My shop with an automotive buffer and tryed it on my > >winshield. Just like on paint it polished out the scraches like new. As > >with paint it is easy to " burn through". Use caution but with the right > >buffing compounds even deep scraches can be buffed out. Test on scraps > >first. > > Ron NB Ore. > > > > > > > > > >>From: jareds <jareds(at)verizon.net> > >>Reply-To: kitfox-list(at)matronics.com > >>To: kitfox-list(at)matronics.com.Gecko/20040804.Netscape/7.2 (ax) > >>Subject: Kitfox-List: glass streaks and scratches > >>Date: Mon, 24 Oct 2005 20:18:08 -0500 > >> > >> > >>Searched the archives for a recent post regarding a spray cleaner of > >>some sort that gets rid of streaking or scratches that impair visibility > >>in your windshield or bubble doors. Anyone remember what the product or > >>solution was? > >> > >>Thanks, > >> > >>Jared > >> > >> > >> > >> > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 25, 2005
There is more than the ailerons to worry about flutteron, but don't know what the VNE is rated for on a MOD 3, but can't imagine wanting to go faster than 100 in a mod 3. Bob U. ----- Original Message ----- From: "Michel Verheughe" <michel(at)online.no> Subject: SV: Kitfox-List: Mass balances > > > From: Gordon Faulkner [hagar(at)othertonair.freeserve.co.uk] > > Changing subject: my kit has a pair of mass balance weights with it and the > > Build Manual page W40 describes how to fit them, it's a 1990 kit (number > > 918). > > Gordon, my model 3 is from 1991 (build #998) and it was finished built in 1993, not by me, unfortunately, I am the third owner. > It has the mass balances and while it may look heavy in your hand, it feels ok once installed on the flaperons. > > My understanding is that, with them, you can increase your Vne. Incidentally, mine is, as noted by the builder, 100 MPH. But I believe, with the masses, I can exceed that without risking fluttering of the flaperon. Please double-check this, my memory is as unreliable as any advice I may give! :-) > > Cheers, > Michel > > ________________________________________________________________________________
From: "Kerry Skyring" <kerryskyring(at)hotmail.com>
Subject: Re: Trim
Date: Oct 25, 2005
Thanks John. Yes that looks like a great idea. We will stick with the cable and spring system for now. It was just that our inspector didn't like the lag or delay which you get because of the lack of tension in the spring. Anyway we're done and the focus is now on the first flight. Kerry. http://www.sportflight.com/cgi-bin/uploader.pl?action=view&epoch=1069446885, >works great indeed! JohnA. > > > > > > >> > >> > > > > > > > > > > ________________________________________________________________________________
Date: Oct 25, 2005
What about wing lockers? I seem to remember reading about someone building wing lockers into their kitfox, but I have never seen this. Was this a Skystar option? Does anyone have pics of an installation? -------------- Original message -------------- > > Cheers Graeme, > Most people opt for a "baggage sack" for the behind the seat area. The same > people who make the Skystar upholstery make them. Or you can make one > yourself. > > Also don't forget for the Series 5 and above, John McBean sells an > under-the-seat storage bin. > > > Don Pearsall > Sound Appraisal > Seattle, WA USA > 425-392.4627 > FAX 425-557-0107 > donpearsall(at)comcast.net > http://www.soundappraisal.com > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Storage issues > > > HI Guys, Im settling into the new plane really well and although my wife > wont let me sleep in the hanger with it yet our relationship is becoming > firmly established. I do however have a storage problem and need some advise > as to how you have all dealt with this issue. I have decided against a pod > at this stage leaving behind the seat storage the only option. Has anyone > glassed in this area or made shelves or anything similar to help out with > carrying your gear around. There appears to be plenty of room behind the > seat so some advice, photo's etc detailing how you have managed it would be > great. > > Cheers > > > Graeme Toft > > > > > > What about wing lockers? I seem to remember reading about someone building wing lockers into their kitfox, but I have never seen this. Was this a Skystar option? Does anyone have pics of an installation? -------------- Original message -------------- -- Kitfox-List message posted by: "Don Pearsall" Cheers Graeme, Most people opt for a "baggage sack" for the behind the seat area. The same people who make the Skystar upholstery make them. Or you can make one yourself. Also don't forget for the Series 5 and above, John McBean sells an under-the-seat storage bin. Don Pearsall Sound Appraisal Seattle, WA USA 425-392.4627 FAX 425-557-0107 donpearsall(at)comcast.net http://www.soundappraisal.com -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft To: kitfox-list(at)matronics.com & gt; Subject: Kitfox-List: Storage issues -- Kitfox-List message posted by: "Graeme Toft" HI Guys, Im settling into the new plane really well and although my wife wont let me sleep in the hanger with it yet our relationship is becoming firmly established. I do however have a storage problem and need some advise as to how you have all dealt with this issue. I have decided against a pod at this stage leaving behind the seat storage the only option. Has anyone glassed in this area or made shelves or anything similar to help out with carrying your gear around. There appears to be plenty of room behind the seat so some advice, photo's etc detailing how you have managed it would be great. Cheers Graeme Toft - The Kitfox-List Email Forum - ________________________________________________________________________________
Date: Oct 25, 2005
I am in the market for a cargo pod for a model 4 speedster. Now that Skystar is out of business, I was wondering if anyone on the list had one for sale. Floran H. ----- Original Message ----- From: "Graeme Toft" <msm(at)byterocky.net> Subject: Kitfox-List: Storage issues > > HI Guys, Im settling into the new plane really well and although my wife > wont let me sleep in the hanger with it yet our relationship is becoming > firmly established. I do however have a storage problem and need some > advise as to how you have all dealt with this issue. I have decided > against a pod at this stage leaving behind the seat storage the only > option. Has anyone glassed in this area or made shelves or anything > similar to help out with carrying your gear around. There appears to be > plenty of room behind the seat so some advice, photo's etc detailing how > you have managed it would be great. > > Cheers > > > Graeme Toft > > > ________________________________________________________________________________
Date: Oct 25, 2005
I have 2 wing lockers. Some people seem to really like them, but for the little space they offer, and the work involved in building them, I would not put wing lockers in my next Kitfox. SteveZ Calgary IV/EA81/CAP -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of mscotter(at)comcast.net Subject: RE: Kitfox-List: Storage issues What about wing lockers? I seem to remember reading about someone building wing lockers into their kitfox, but I have never seen this. Was this a Skystar option? Does anyone have pics of an installation? -------------- Original message -------------- > > Cheers Graeme, > Most people opt for a "baggage sack" for the behind the seat area. The same > people who make the Skystar upholstery make them. Or you can make one > yourself. > > Also don't forget for the Series 5 and above, John McBean sells an > under-the-seat storage bin. > > > Don Pearsall > Sound Appraisal > Seattle, WA USA > 425-392.4627 > FAX 425-557-0107 > donpearsall(at)comcast.net > http://www.soundappraisal.com > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Storage issues > > > HI Guys, Im settling into the new plane really well and although my wife > wont let me sleep in the hanger with it yet our relationship is becoming > firmly established. I do however have a storage problem and need some advise > as to how you have all dealt with this issue. I have decided against a pod > at this stage leaving behind the seat storage the only option. Has anyone > glassed in this area or made shelves or anything similar to help out with > carrying your gear around. There appears to be plenty of room behind the > seat so some advice, photo's etc detailing how you have managed it would be > great. > > Cheers > > > Graeme Toft > > > > > > What about wing lockers? I seem to remember reading about someone building wing lockers into their kitfox, but I have never seen this. Was this a Skystar option? Does anyone have pics of an installation? -------------- Original message -------------- -- Kitfox-List message posted by: "Don Pearsall" Cheers Graeme, Most people opt for a "baggage sack" for the behind the seat area. The same people who make the Skystar upholstery make them. Or you can make one yourself. Also don't forget for the Series 5 and above, John McBean sells an under-the-seat storage bin. Don Pearsall Sound Appraisal Seattle, WA USA 425-392.4627 FAX 425-557-0107 donpearsall(at)comcast.net http://www.soundappraisal.com -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft To: kitfox-list(at)matronics.com & gt; Subject: Kitfox-List: Storage issues -- Kitfox-List message posted by: "Graeme Toft" HI Guys, Im settling into the new plane really well and although my wife wont let me sleep in the hanger with it yet our relationship is becoming firmly established. I do however have a storage problem and need some advise as to how you have all dealt with this issue. I have decided against a pod at this stage leaving behind the seat storage the only option. Has anyone glassed in this area or made shelves or anything similar to help out with carrying your gear around. There appears to be plenty of room behind the seat so some advice, photo's etc detailing how you have managed it would be great. Cheers Graeme Toft - The Kitfox-List Email Forum - ________________________________________________________________________________
Subject: Storage issues (Upholstery)
Date: Oct 25, 2005
Here is a message that Sam Knight posted a little while ago. He pops up from time to time to advertise on the list: Don Pearsall _______________________________ Kitfox Builders: I have been in the upholstery business for 30 years and have been making upholstery products for kitplanes for 18 years. I have interior kits available for the Model I, Model II, Model III, Model IV, Lite (Squared), Series 5, Series 6, Vixen, and the Ultralight plus Sky Raider Ultralight. I also have cabin covers and other items. A list of other kitplane interior products available upon request. For more information, call Knight Aircraft Interiors, Inc., at (702) 207-6681 or e mail me at knightair(at)lv.rmci.net. If you e-mail for information, please mention either "Knight" or "Upholstery" in your reference line so I can give your request my immediate attention. Photos available upon request. Sincerely, KNIGHT AIRCRAFT INTERIORS, INC. "Fly by Knight" Upholstery Products Sam Knight -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Gordon Faulkner Subject: Re: Kitfox-List: Storage issues Hya Don, Do you have a contact number or e-address for the "people who make the Skystar upholstery"? My K3 kit doesn't have any upholstery with it and I'd like to fit new rather than search for a used set. Rgds, Gordon ----- Original Message ----- From: "Don Pearsall" <donpearsall(at)comcast.net> Subject: RE: Kitfox-List: Storage issues > > > Cheers Graeme, > Most people opt for a "baggage sack" for the behind the seat area. The > same > people who make the Skystar upholstery make them. Or you can make one > yourself. > > Also don't forget for the Series 5 and above, John McBean sells an > under-the-seat storage bin. > > > Don Pearsall > Sound Appraisal > Seattle, WA USA > 425-392.4627 > FAX 425-557-0107 > donpearsall(at)comcast.net > http://www.soundappraisal.com > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Storage issues > > > HI Guys, Im settling into the new plane really well and although my wife > wont let me sleep in the hanger with it yet our relationship is becoming > firmly established. I do however have a storage problem and need some > advise > as to how you have all dealt with this issue. I have decided against a pod > at this stage leaving behind the seat storage the only option. Has anyone > glassed in this area or made shelves or anything similar to help out with > carrying your gear around. There appears to be plenty of room behind the > seat so some advice, photo's etc detailing how you have managed it would > be > great. > > Cheers > > > Graeme Toft > > ________________________________________________________________________________
Date: Oct 25, 2005
Hey Don, no more info like that until all my interior stuff is sold :) Beside you want folks to get a good deal right. Rick -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Don Pearsall Subject: RE: Kitfox-List: Storage issues (Upholstery) Here is a message that Sam Knight posted a little while ago. He pops up from time to time to advertise on the list: Don Pearsall _______________________________ Kitfox Builders: I have been in the upholstery business for 30 years and have been making upholstery products for kitplanes for 18 years. I have interior kits available for the Model I, Model II, Model III, Model IV, Lite (Squared), Series 5, Series 6, Vixen, and the Ultralight plus Sky Raider Ultralight. I also have cabin covers and other items. A list of other kitplane interior products available upon request. For more information, call Knight Aircraft Interiors, Inc., at (702) 207-6681 or e mail me at knightair(at)lv.rmci.net. If you e-mail for information, please mention either "Knight" or "Upholstery" in your reference line so I can give your request my immediate attention. Photos available upon request. Sincerely, KNIGHT AIRCRAFT INTERIORS, INC. "Fly by Knight" Upholstery Products Sam Knight -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Gordon Faulkner Subject: Re: Kitfox-List: Storage issues Hya Don, Do you have a contact number or e-address for the "people who make the Skystar upholstery"? My K3 kit doesn't have any upholstery with it and I'd like to fit new rather than search for a used set. Rgds, Gordon ----- Original Message ----- From: "Don Pearsall" <donpearsall(at)comcast.net> Subject: RE: Kitfox-List: Storage issues > > > Cheers Graeme, > Most people opt for a "baggage sack" for the behind the seat area. The > same > people who make the Skystar upholstery make them. Or you can make one > yourself. > > Also don't forget for the Series 5 and above, John McBean sells an > under-the-seat storage bin. > > > Don Pearsall > Sound Appraisal > Seattle, WA USA > 425-392.4627 > FAX 425-557-0107 > donpearsall(at)comcast.net > http://www.soundappraisal.com > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Storage issues > > > HI Guys, Im settling into the new plane really well and although my wife > wont let me sleep in the hanger with it yet our relationship is becoming > firmly established. I do however have a storage problem and need some > advise > as to how you have all dealt with this issue. I have decided against a pod > at this stage leaving behind the seat storage the only option. Has anyone > glassed in this area or made shelves or anything similar to help out with > carrying your gear around. There appears to be plenty of room behind the > seat so some advice, photo's etc detailing how you have managed it would > be > great. > > Cheers > > > Graeme Toft > > ________________________________________________________________________________
Date: Oct 25, 2005
I may also have upholstery available... Definitely for the IV, 5, 6 and 7 Fly Safe !! John & Debra McBean www.sportplanellc.com "The Sky is not the Limit... It's a Playground" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Don Pearsall Subject: RE: Kitfox-List: Storage issues (Upholstery) Here is a message that Sam Knight posted a little while ago. He pops up from time to time to advertise on the list: Don Pearsall _______________________________ Kitfox Builders: I have been in the upholstery business for 30 years and have been making upholstery products for kitplanes for 18 years. I have interior kits available for the Model I, Model II, Model III, Model IV, Lite (Squared), Series 5, Series 6, Vixen, and the Ultralight plus Sky Raider Ultralight. I also have cabin covers and other items. A list of other kitplane interior products available upon request. For more information, call Knight Aircraft Interiors, Inc., at (702) 207-6681 or e mail me at knightair(at)lv.rmci.net. If you e-mail for information, please mention either "Knight" or "Upholstery" in your reference line so I can give your request my immediate attention. Photos available upon request. Sincerely, KNIGHT AIRCRAFT INTERIORS, INC. "Fly by Knight" Upholstery Products Sam Knight -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Gordon Faulkner Subject: Re: Kitfox-List: Storage issues Hya Don, Do you have a contact number or e-address for the "people who make the Skystar upholstery"? My K3 kit doesn't have any upholstery with it and I'd like to fit new rather than search for a used set. Rgds, Gordon ----- Original Message ----- From: "Don Pearsall" <donpearsall(at)comcast.net> Subject: RE: Kitfox-List: Storage issues > > > Cheers Graeme, > Most people opt for a "baggage sack" for the behind the seat area. The > same > people who make the Skystar upholstery make them. Or you can make one > yourself. > > Also don't forget for the Series 5 and above, John McBean sells an > under-the-seat storage bin. > > > Don Pearsall > Sound Appraisal > Seattle, WA USA > 425-392.4627 > FAX 425-557-0107 > donpearsall(at)comcast.net > http://www.soundappraisal.com > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Graeme Toft > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Storage issues > > > HI Guys, Im settling into the new plane really well and although my wife > wont let me sleep in the hanger with it yet our relationship is becoming > firmly established. I do however have a storage problem and need some > advise > as to how you have all dealt with this issue. I have decided against a pod > at this stage leaving behind the seat storage the only option. Has anyone > glassed in this area or made shelves or anything similar to help out with > carrying your gear around. There appears to be plenty of room behind the > seat so some advice, photo's etc detailing how you have managed it would > be > great. > > Cheers > > > Graeme Toft > > ________________________________________________________________________________
Date: Oct 25, 2005
great feature in Kitplanes previous issue on care of plex John Kerr -------------- Original message -------------- > > Jared I was in My shop with an automotive buffer and tryed it on my > winshield. Just like on paint it polished out the scraches like new. As > with paint it is easy to " burn through". Use caution but with the right > buffing compounds even deep scraches can be buffed out. Test on scraps > first. > Ron NB Ore. > > > >From: jareds > >Reply-To: kitfox-list(at)matronics.com > >To: kitfox-list(at)matronics.com.Gecko/20040804.Netscape/7.2 (ax) > >Subject: Kitfox-List: glass streaks and scratches > >Date: Mon, 24 Oct 2005 20:18:08 -0500 > > > > > >Searched the archives for a recent post regarding a spray cleaner of > >some sort that gets rid of streaking or scratches that impair visibility > >in your windshield or bubble doors. Anyone remember what the product or > >solution was? > > > >Thanks, > > > >Jared > > > > > > > > > > > great feature in Kitplanes previous issue on care of plex John Kerr -------------- Original message -------------- -- Kitfox-List message posted by: "ron schick" Jared I was in My shop with an automotive buffer and tryed it on my winshield. Just like on paint it polished out the scraches like new. As with paint it is easy to " burn through". Use caution but with the right buffing compounds even deep scraches can be buffed out. Test on scraps first. Ron NB Ore. From: jareds <JAREDS(at)VERIZON.NET> Reply-To: kitfox-list(at)matronics.com To: kitfox-list(at)matronics.com.Gecko/20040804.Netscape/7.2 (ax) Subject: Kitfox-List: glass streaks and scratches Date: Mon, 24 Oct 2005 20:18:08 -0500 -- Kitfox-List message posted by: jareds
Date: Oct 25, 2005
Subject: Prop Pitch
I have a Kitfox IV Speedster powered by a Rotax 912. I have just finished suffering through an Ivo inflight adjustable pitch prop, tiring of the problems and switched to a Warp Drive 3 blade ground adjustable
October 15, 2005 - October 25, 2005
Kitfox-Archive.digest.vol-cl
