Kitfox-Archive.digest.vol-fa
September 13, 2007 - October 01, 2007
Date: Sep 13, 2007
Subject: Re: Firewall
Herbert sez: >Why do all of the Kitfoxes that I've seen have the insulation >blanket on the engine side of the firewall instead of the cockpit >side of the firewall? My Model IV had the insulation on the cabin side of the firewall, but I did not use the factory-supplied blanket. Instead, I used a thick, dense, fire-resistant foam that was glued to the firewall in sections between the steel tubes. I don't know if it helped with noise much because these little 'foxes are the noisiest things I've flown, but it looked really nice and I liked it. :-) Mike G. Kitfox List Moderator N728KF Phoenix, AZ ________________________________________________________________________________
Subject: Re: Static port location??? what works best???
Date: Sep 13, 2007
the placement of the static port involves more than the supporting of the material used. I understand that some effort was expended in locating the port on the airframe of the Series IV where it would be least affected by changing air pressures. The location selected is detailed in the plans for the static port assembly from the factory and is located ahead of and below the leading edge of the horizontal stabilizer. the most harrowing flight I have had in my 'Fox was the day that I disconnect the static line at the panel so that I was sensing cabin environment. The instruments were not showing any of the numbers I was accustomed to and I finally abandoned all referrence to instuments and landed by the seat of my pants. I guess that I could have flown a complete new stall profile with the new numbers but I wanted to get on the ground. "Get there syndrome", maybe so.... John Kerr -------------- Original message -------------- From: SUE MICHAELS <michaega(at)verizon.net> Putting a static port in wing near pitot is no longer an option. I would kind of like to put a threaded backing plate somewhere with hose attached and then screw the port after fabric placement. What size hole is the port opening drilled at if I must make my own? Would attaching the port to the back of the door frame at the junction of the stringer work? That would be easy and easier to get to at a later date, possible one on each side.
John Kerr
Subject: Re: (Off Topic) Two is company, three is ...
Date: Sep 13, 2007
Michel next time you're looking at Lars European kitfox site check out OE-AMJ. It's the one I've been working on for the past four years. It will, I hope, soon be flying off to some European fly-ins. Sooner or later we European Kitfoxers have to get together for a big event. I'm just waiting on the mandatory test hours to be flown off. Cheers. Kerry. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134258#134258 ________________________________________________________________________________
Subject: Lowell back on deck
Date: Sep 13, 2007
Glad to see you are getting back on deck. They say close only counts in horseshoes and atom bombs..... I'll bet you have revised views on that one. Good to have you back. Noel ________________________________________________________________________________
Subject: 912S Oil and Water cooling issues
Date: Sep 13, 2007
Thats strange. My problem is getting things warm enough. Model IV-1200 wi th oil cooler. 1250 hours. Clint> Subject: Kitfox-List: 912S Oil and Wat er cooling issues> From: arholland(at)bigriver.net> Date: Thu, 13 Sep 2007 04: d by: "arholland" > > I have a Kitfox Lite Squared. It is the same as the classic 4 except with a smooth cowl and is a tricycl e. It has the GSC 3 blade prop. It has the 912S engine and has about 110 ho urs. My CHT runs about 230 and my oil temp runs about 230. I was running th e waterless coolant and have switched to Prestone Dex-cool. With the Dex-co ol it runs a little cooler on the CHT but the oil temp is still high. Also when the engine is at idle the oil pressure runs about 60psi, however when I am at cruise the oil pressure fluctuates between about 40psi and 60psi. D oes anyone have any ideas to get the cooling under control and what could b e causing the oil pressure fluctuations?> > --------> Allen Holland> Munfor d, TN> > > > > Read this topic online here:> > http://forums.matronics.com/ ==> > > ________________________________________________________________________________
Date: Sep 13, 2007
Gauge or relief valve spring/piston seat??? Of course 230F is not very high. Fluctuation is a concern. PW =========================== > > > > I have a Kitfox Lite Squared. It is the same as the classic 4 > except with a smooth cowl and is a tricycle. It has the GSC 3 blade > prop. It has the 912S engine and has about 110 hours. My CHT runs > about 230 and my oil temp runs about 230. I was running the > waterless coolant and have switched to Prestone Dex-cool. With the > Dex-cool it runs a little cooler on the CHT but the oil temp is > still high. Also when the engine is at idle the oil pressure runs > about 60psi, however when I am at cruise the oil pressure > fluctuates between about 40psi and 60psi. Does anyone have any > ideas to get the cooling under control and what could be causing > the oil pressure fluctuations? > > > > -------- > > Allen Holland > > Munford, TN ________________________________________________________________________________
Subject: Re: Vortex Generators/Turbulator's
Date: Sep 14, 2007
Clint, I used some harrison Vg;s on the lower cowl mods i did and they contributed to a 20F drop in coolant temps http://www.cfisher.com/cowl.html Last weekend I put some Vgs on my wings. I have started a page here http://www.cfisher.com/vg.html I put up a video of some flying with them on to be found there as well. I placed the leading edge of VGs 4.625 inches back from leading edge as measured through the chord not following the curvature of the top of the wing. This puts the centre of the VG at exactly 10% of the chord. So far favorable results, but nothing like I have read about the 8 mph stall speed drops. Looks like about 2 mph drop in stall to about 36-37 mph clean. No speed loss and if any less than 1 mph but no gain either. Slow speed flight does seem a little more stable but I have never complained or had any issues with slow speed flight on my IV. I have been reluctant to put on the VGs as the Kitfox of mine has had such good performance. I did do another mod that has added favorable results this week as week which was correcting the exhaust form how Skystar had cut the 90% elbow and shortened the actual header length. If definitely has added HP as RPM has increased at idle, static and wide open throttle in flight by 200 to 300 rpm . I have now re pitched and picked up some speed as well but will post data once done another re pitch and some more flight data. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134365#134365 ________________________________________________________________________________
Date: Sep 14, 2007
Glad to see you're back to the list. Do you think the VGs on the lip of the cowl will help cooling without the radiator scoop? Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave > Sent: Friday, September 14, 2007 10:46 AM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: Vortex Generators/Turbulator's > > > > Clint, > > I used some harrison Vg;s on the lower cowl mods i did and > they contributed to a 20F drop in coolant temps > http://www.cfisher.com/cowl.html > > Last weekend I put some Vgs on my wings. > I have started a page here http://www.cfisher.com/vg.html > I put up a video of some flying with them on to be found > there as well. > I placed the leading edge of VGs 4.625 inches back from > leading edge as measured through the chord not following the > curvature of the top of the wing. This puts the centre of > the VG at exactly 10% of the chord. > > So far favorable results, but nothing like I have read about > the 8 mph stall speed drops. Looks like about 2 mph drop in > stall to about 36-37 mph clean. No speed loss and if any > less than 1 mph but no gain either. > > Slow speed flight does seem a little more stable but I have > never complained or had any issues with slow speed flight on > my IV. I have been reluctant to put on the VGs as the Kitfox > of mine has had such good performance. > > I did do another mod that has added favorable results this > week as week which was correcting the exhaust form how > Skystar had cut the 90% elbow and shortened the actual header > length. If definitely has added HP as RPM has increased at > idle, static and wide open throttle in flight by 200 to 300 > rpm . I have now re pitched and picked up some speed as > well but will post data once done another re pitch and some > more flight data. > > -------- > Rotax Dealer, Ontario Canada > Flying Videos and Kitfox Info > http://www.cfisher.com/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134365#134365 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 14, 2007
Dave can we see a straight down view of the installation showing the spacing and angles between individual VGs? Liked the video!... Beats the tar out of Flight Sim but the plane seems strangely familiar. Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave > Sent: Friday, September 14, 2007 10:46 AM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: Vortex Generators/Turbulator's > > > > Clint, > > I used some harrison Vg;s on the lower cowl mods i did and > they contributed to a 20F drop in coolant temps > http://www.cfisher.com/cowl.html > > Last weekend I put some Vgs on my wings. > I have started a page here http://www.cfisher.com/vg.html > I put up a video of some flying with them on to be found > there as well. > I placed the leading edge of VGs 4.625 inches back from > leading edge as measured through the chord not following the > curvature of the top of the wing. This puts the centre of > the VG at exactly 10% of the chord. > > So far favorable results, but nothing like I have read about > the 8 mph stall speed drops. Looks like about 2 mph drop in > stall to about 36-37 mph clean. No speed loss and if any > less than 1 mph but no gain either. > > Slow speed flight does seem a little more stable but I have > never complained or had any issues with slow speed flight on > my IV. I have been reluctant to put on the VGs as the Kitfox > of mine has had such good performance. > > I did do another mod that has added favorable results this > week as week which was correcting the exhaust form how > Skystar had cut the 90% elbow and shortened the actual header > length. If definitely has added HP as RPM has increased at > idle, static and wide open throttle in flight by 200 to 300 > rpm . I have now re pitched and picked up some speed as > well but will post data once done another re pitch and some > more flight data. > > -------- > Rotax Dealer, Ontario Canada > Flying Videos and Kitfox Info > http://www.cfisher.com/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134365#134365 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 14, 2007
Noel, I am not sure but I think the rad scoop does help with cooling. The same setup without the scoop? should be ok but i will have to remove to validate for sure. > Do you think the VGs on the lip of the cowl will help cooling without the > radiator scoop? > > Noel -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134389#134389 ________________________________________________________________________________
Date: Sep 14, 2007
Noel, I cannot help you with a pic other than at http://www.cfisher.com/vg.html but you can see how the spacing changes But I followed these directions http://stolspeed.com/content.php?id=27 from last outer rib for a about 3 feet 60mm spacing Then rest of wing to windshield I spaced them 90 mm > Dave can we see a straight down view of the installation showing the spacing > and angles between individual VGs? -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134395#134395 ________________________________________________________________________________
Date: Sep 14, 2007
I installed my firewall blanket on the cabin side of the firewall, after first cutting off the part that forms a pocket, into which the firewall would have slid. I did this after talking with Frank at Skystar. I cut holes where the pads are located, so that the material would not be squeezed between the pads and the engine mount. I agree with you about the padding eventually becoming soaked with oil/whatever. Lynn Matteson Grass Lake, Michigan Kitfox IV Speedster w/Jabiru 2200 flying w/400+ hrs On Sep 12, 2007, at 9:29 AM, Herbert Doud wrote: > Kitfoxers.................I gotta question......... > > With all the messages about proper and safe firewall transition, > it got me ti thinking. (Dangerous!) > > > I didn't build my Kitfox....Too dang old..........So I'm not too > knowledgeable in the building process. > > Why do all of the Kitfoxes that I've seen have the insulation > blanket on the engine side of the firewall instead of the cockpit > side of the firewall? Every GA plane that I've owned or seen, the > insulation is always on the cockpit side, which makes sense to > me. On the engine side, it's exposed to engine fluids and > eventually over time, it's possible for engine fluids to gather in > the padding. That could pose a fire hazzard. > > There's probably a logical answer to my query, but I not going to > tax what's left of my brain cells, trying to answer the question. > I'll let someone else's brain cells work on this. > > Herbert Doud > Kitfox IV ________________________________________________________________________________
Date: Sep 14, 2007
As you know I don't have a scoop on my plane... Then again I haven't had any cooling issues either. I'm just trying to keep options open. Is it advisable to use the same rad for the 912 that I am using with the 582? Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave > Sent: Friday, September 14, 2007 12:21 PM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: Vortex Generators/Turbulator's > > > > Noel, > > I am not sure but I think the rad scoop does help with cooling. > The same setup without the scoop? should be ok but i will > have to remove to validate for sure. > > > > Do you think the VGs on the lip of the cowl will help > cooling without the > > radiator scoop? > > > > Noel > > > -------- > Rotax Dealer, Ontario Canada > Flying Videos and Kitfox Info > http://www.cfisher.com/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134389#134389 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 14, 2007
Noel, I think the rad is the same one -- 4" x 20 " approx. but surely someone will comment for sure to confirm. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134470#134470 ________________________________________________________________________________
Subject: 406 ELT's
Date: Sep 14, 2007
We have been looking into this for sometime and finally got an answer back... We are an OEM for Artex 406 mhz ELT's. There is a model now that is a replacement for the AK-450 and the ACK models. Unfortunately the remote switch in the panel is a little different so it will require a slight mod to the opening for the remote switch. As reported the response time is significantly better then the current system. Fact is Doppler positioning allows the 121.5 signal tracked to within approx 12 mile radius and the 406 signal in within 2 mile radius.. the new system also sends owner data to the satellite so searchers know who, what and where.. I believe it also sends contact information. Here is the bad news.. the current retail is $1148.00 plus S&H. This does include everything needed. Attached is the brochure. Give us a shout if you're looking to upgrade or install the 406 system. Fly Safe !! John & Debra McBean 208.337.5111 www.kitfoxaircraft.com "It's not how Fast... It's how Fun!" 8:59 AM ________________________________________________________________________________
Subject: radiators
Date: Sep 14, 2007
There is 2 different radiators.. The original 582 was smaller. The 912 uses a larger radiator. Fly Safe !! John & Debra McBean 208.337.5111 www.kitfoxaircraft.com "It's not how Fast... It's how Fun!" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Noel Loveys Sent: Friday, September 14, 2007 2:59 PM Subject: RE: Kitfox-List: Re: Vortex Generators/Turbulator's As you know I don't have a scoop on my plane... Then again I haven't had any cooling issues either. I'm just trying to keep options open. Is it advisable to use the same rad for the 912 that I am using with the 582? Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave > Sent: Friday, September 14, 2007 12:21 PM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: Vortex Generators/Turbulator's > > > Noel, > > I am not sure but I think the rad scoop does help with cooling. > The same setup without the scoop? should be ok but i will > have to remove to validate for sure. > > > > Do you think the VGs on the lip of the cowl will help > cooling without the > > radiator scoop? > > > > Noel > > > -------- > Rotax Dealer, Ontario Canada > Flying Videos and Kitfox Info > http://www.cfisher.com/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134389#134389 > > 8:59 AM 8:59 AM ________________________________________________________________________________
Subject: radiators
Date: Sep 14, 2007
John: What are the measurements on the 912 rad? BTW TC says they won't bother with another inspection of my plane if I buy the engine mount from you.... Bet you didn't know you had friends in "high" places :-) Noel Loveys, RPP, AME intern Campbellton, Newfoundland, Canada Kitfox Mod III-A, 582, B box, Ivo IFA Aerocet 1100s noelloveys(at)yahoo.ca > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jdmcbean > Sent: Friday, September 14, 2007 7:45 PM > To: kitfox-list(at)matronics.com > Subject: RE: Kitfox-List: radiators > > > > > There is 2 different radiators.. The original 582 was > smaller. The 912 uses > a larger radiator. > > Fly Safe !! > John & Debra McBean > 208.337.5111 > www.kitfoxaircraft.com > "It's not how Fast... It's how Fun!" > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of > Noel Loveys > Sent: Friday, September 14, 2007 2:59 PM > To: kitfox-list(at)matronics.com > Subject: RE: Kitfox-List: Re: Vortex Generators/Turbulator's > > > As you know I don't have a scoop on my plane... Then again I > haven't had > any cooling issues either. I'm just trying to keep options > open. Is it > advisable to use the same rad for the 912 that I am using > with the 582? > > > Noel > > > -----Original Message----- > > From: owner-kitfox-list-server(at)matronics.com > > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave > > Sent: Friday, September 14, 2007 12:21 PM > > To: kitfox-list(at)matronics.com > > Subject: Kitfox-List: Re: Vortex Generators/Turbulator's > > > > > > > > Noel, > > > > I am not sure but I think the rad scoop does help with cooling. > > The same setup without the scoop? should be ok but i will > > have to remove to validate for sure. > > > > > > > Do you think the VGs on the lip of the cowl will help > > cooling without the > > > radiator scoop? > > > > > > Noel > > > > > > -------- > > Rotax Dealer, Ontario Canada > > Flying Videos and Kitfox Info > > http://www.cfisher.com/ > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=134389#134389 > > > > > > > > > > > > > > > > > > > > > > > > > 8:59 AM > > 8:59 AM > > > > > > > > ________________________________________________________________________________
Date: Sep 15, 2007
Noel sez: >...Flying without headphones isn't uncomfortable either. It >certainly isn't as loud as the C172 I trained in. I don't know, Noel, perhaps your hearing was better back then. :-) Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 15, 2007
Subject: Airdale Wider Bungee Landing Gear
Hi All: Is any of you using the Airdale "Wider is Better" bungee landing gear on model I thru IV Kitfox? My friend Noel is considering it for his Kitfox II. Would like to get your feedback. Thanks! Jos Toro ex Kitfox II/582 (still in love) Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase. http://farechase.yahoo.com/ ________________________________________________________________________________
Date: Sep 15, 2007
Subject: Re: Lowell Fitt Accident
Just a few comments about landing in the tree tops. I had an engine out earlier this year and was forced to land in the trees. I got real lucky and didn't get injured. I landed in the top of several pine trees and the plane then nose dived straight down when the treetops broke. My main gear wedged between to trees and slowed the descent dramatically. The wings also absorbed the falling energy when they broke other tree limbs. My engine came with in 6 inches of the ground. The plane never made contact with ground. I agree about having a light aircraft vs. a 172 or such. I don't know if I would have been so lucky. Damage to the plane was two bent spars , covering on the wings and several places on the fuselage. I am glad I was in my Kitfox rather than my Cessna 175. I don't believe that I would have survived the fall in that much heavier a plane. Just a few comments about the cause of the accident. The engine was a 912UL with 300 hours. The rubber boot that holds the carbs failed. I had changed the boot the previous annual and inspected it within the last month before the accident. The rubber boot had approx 80 hours on it. The rubber boot split about 2/3 the way around . The engine lost vacuum and sputtered and stopped.. There is a solution to the problem , I wrote Rotax and there is another company making these parts. I never got a response from Rotax and the other manufacture showed no interest. The solution for the problem is to have a KEVLAR ring inserted into the mold when the rubber is injected. Here is the reason this KEVLAR band would work. The rubber boot cracks and separates , the engine starts running rough , but would continue to run. You have high vibration at this time making the crack worse causing the engine to run rougher. The KEVLAR would prevent the complete separation of the rubber boot. Hope fully this would buy you enough time to return to the airport safely. I hope the above made since to you. I wish that I could make the manufactures realize that the cost to insert the ring would be a safety measure that would prevent a complete separation of the rubber boot. It would really not make the part last longer , just prevent it from completely failing like mine did. Your comments would be appreciated. If it makes since ,you might want to write ROTAX and see if more than one person complaint would entice them into making this part safer. > think that, if the forest is dense enough, a Kitfox would simply land on > the top of the trees and rescue would come with a fire brigade ladder. I > am not sure but I still feel I stand a better chance to survive a aircraft > crash landing if it is a very light one. After all, a 30 feet wide, 900 > pounds heavy object moving at 40 MPH shouldn't need much to come to a > stop. ________________________________________________________________________________
From: "Jimmie Blackwell" <JimmieBlackwell(at)austin.rr.com>
Date: Sep 15, 2007
Great report and excellent idea on the boots. I am going to write Rotax. Jimmie ----- Original Message ----- From: "Marwynne Kuhn" <marwynne(at)verizon.net> Sent: Saturday, September 15, 2007 7:38 AM Subject: Re: Kitfox-List: Re: Lowell Fitt Accident > > Just a few comments about landing in the tree tops. I had an engine out > earlier this year and was forced to land in the trees. I got real lucky > and didn't get injured. I landed in the top of several pine trees and the > plane then nose dived straight down when the treetops broke. My main gear > wedged between to trees and slowed the descent dramatically. The wings > also absorbed the falling energy when they broke other tree limbs. My > engine came with in 6 inches of the ground. The plane never made contact > with ground. > > I agree about having a light aircraft vs. a 172 or such. I don't know if > I would have been so lucky. Damage to the plane was two bent spars , > covering on the wings and several places on the fuselage. I am glad I > was in my Kitfox rather than my Cessna 175. I don't believe that I would > have survived the fall in that much heavier a plane. > > > Just a few comments about the cause of the accident. The engine was a > 912UL with 300 hours. The rubber boot that holds the carbs failed. I > had changed the boot the previous annual and inspected it within the last > month before the accident. The rubber boot had approx 80 hours on it. > The rubber boot split about 2/3 the way around . The engine lost vacuum > and sputtered and stopped.. There is a solution to the problem , I > wrote Rotax and there is another company making these parts. I never got a > response from Rotax and the other manufacture showed no interest. > > The solution for the problem is to have a KEVLAR ring inserted into the > mold when the rubber is injected. > > Here is the reason this KEVLAR band would work. > > The rubber boot cracks and separates , the engine starts running rough , > but would continue to run. > You have high vibration at this time making the crack worse causing the > engine to run rougher. The KEVLAR would prevent the complete > separation of the rubber boot. Hope fully this would buy you enough time > to return to the airport safely. > > I hope the above made since to you. I wish that I could make the > manufactures realize that the cost to insert the ring would be a safety > measure that would prevent a complete separation of the rubber boot. It > would really not make the part last longer , just prevent it from > completely failing like mine did. > > Your comments would be appreciated. If it makes since ,you might want to > write ROTAX and see if more than one person complaint would entice them > into making this part safer. > > >> think that, if the forest is dense enough, a Kitfox would simply land on >> the top of the trees and rescue would come with a fire brigade ladder. I >> am not sure but I still feel I stand a better chance to survive a >> aircraft crash landing if it is a very light one. After all, a 30 feet >> wide, 900 pounds heavy object moving at 40 MPH shouldn't need much to >> come to a stop. > > > ________________________________________________________________________________
Date: Sep 15, 2007
I have an idea. Why couldn't a rubber cover be put over the boot, like piece of rubber inner tube? It could be sealed on the carb side with silicone sealant or something, pulled over the carb boot, then sealed on the engine side. A safety wire wrap or zip ties might could be used to secure it on the ends and ensure a tight fit into the sealant. That way if the boot split, the cover would keep air from leaking in. Just a thought, Clem Wehner Lawton, OK KFIV-912 -----Original Message----- "The rubber boot split about 2/3 the way around . The engine lost vacuum and sputtered and stopped." ________________________________________________________________________________
Subject: It flys!
Date: Sep 15, 2007
Hello everyone, Just a quick note to let you know Kitfox series 6, N262SC took to the air at about 8 am this morning for its maiden flight. It flew great with no changes needed in rigging! More later. Kevin Cozik Series 6-7 Rotax 914 turbo Czech amphibs Lansing Michigan ________________________________________________________________________________
Date: Sep 15, 2007
Subject: Re: Landing in Treetops
Attending a flight safety conference in Germany, last year, we were told > that light aircraft should rather try to land on tree tops than attempt to > make a sharp manoeuvre to reach an open field, at the risk of not being > able to do it and end in a wall or another hard surface. Personally, I > think that, if the forest is dense enough, a Kitfox would simply land on > the top of the trees and rescue would come with a fire brigade ladder. I > am not sure but I still feel I stand a better chance to survive a aircraft > crash landing if it is a very light one. After all, a 30 feet wide, 900 > pounds heavy object moving at 40 MPH shouldn't need much to come to a > stop. Michel, I have an example of this in my shop. About 25 years ago a pilot had fuel contamination and the engine quit in a Funk B-85 C. He ended up about 100' up in the Cedar tree he landed on. He was rescued by Hook & Ladder truck from Fire Dept. More damage was done to aircraft removing from tree with a huge crane than was done in landing there. I'm slowly restoring that plane. Still has cable marks on door post aluminum cover where the cable wrapped around to remove. Windshield, all windows & airframe not damaged except for wings & doors which were totaled by time aircraft was removed from tree. Two of my friends heard engine quit and ran to where they heard the noise of crash, couldn't find plane till pilot yelled at them from above! Elbie Mendenhall, Restoring the "Cedar Tree Funk" N-77705 ________________________________________________________________________________
Date: Sep 15, 2007
Subject: Re: It flys!
congrats. Have fun. Kevin Cozik wrote: Hello everyone, Just a quick note to let you know Kitfox series 6, N262SC took to the air at about 8 am this morning for its maiden flight. It flew great with no changes needed in rigging! More later. Kevin Cozik Series 6-7 Rotax 914 turbo Czech amphibs Lansing Michigan Maxwell Duke S6/TD/IO240 Dublin, GA --------------------------------- Boardwalk for $500? In 2007? Ha! ________________________________________________________________________________
Date: Sep 15, 2007
Subject: Re: Lowell Fitt Accident --Subject Change-Carb Boots
I just received two new carb boots for my 912ul and I think Lockwood said they do have a KEVLAR reinforcement. They appear much stiffer, as well. Stan Specht Kitfox Model IV Speedster "Columbine" (1250 hrs) Denver, Colorado ________________________________________________________________________________
Subject: It flys!
Date: Sep 15, 2007
Congrats Kevin !!! Fly Safe !! John & Debra McBean 208.337.5111 www.kitfoxaircraft.com "It's not how Fast... It's how Fun!" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Kevin Cozik Sent: Saturday, September 15, 2007 10:10 AM Subject: Kitfox-List: It flys! Hello everyone, Just a quick note to let you know Kitfox series 6, N262SC took to the air at about 8 am this morning for its maiden flight. It flew great with no changes needed in rigging! More later. Kevin Cozik Series 6-7 Rotax 914 turbo Czech amphibs Lansing Michigan 8:59 AM ________________________________________________________________________________
Subject: Broken tailwheel spring- revelation
Date: Sep 15, 2007
It finally happened- I broke my tailwheel spring after a landing. Not during the landing, but after. If you could see the condition of the runway I generally use, you'd understand. Anyway- no real damage, other than the fabric on the rudder having numerous holes punched by the dragging tailwheel. And, of course the need for a new spring. Which, as they say, is the point. This occurred while landing an Avid MK IV. They have that nicely rounded rudder, and the "round" at the bottom keeps the rudder off the asphalt if the spring breaks. I looked at the kitfox I parked next to it, and noted that if *that* spring broke, I'd trash the rudder. And, since I had the avid rudder in hand, I held it up and... Did you know that, with the exception of the rudder horns being higher, and the top of the rudder sitting maybe 1 inch higher, that the rounded rudder will fit right onto the kitfox? The hinge tabs are in *exactly* the correct place. A new stop, or moving the horns, adding an inch to the top of the verticle stabilizer, and suddenly you have a more effective, and less easily damaged rudder. $.02 Jack Kitfox I Rotax 582 GSC prop Avid Mk IV jabiru 2200 prince ptip ________________________________________________________________________________
Subject: Re: Airdale Wider Bungee Landing Gear
Date: Sep 15, 2007
The wider gear works great . I changed mine after experiencing a gear leg failure on the stock gear . I love the wider stance and it is also a little bit taller . With the big tundra tires on it it looks fantastic . If you want pics let me know and i will send to your email. -------- FLY FUN FLY LOW FLY SLOW John Perry Kitfox 2 N718PD 582 cbox 2:62-1 IVO IFA WHEELS NorthAire Floats Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134560#134560 ________________________________________________________________________________
Subject: Re: Rotax Carb rubber boots
Date: Sep 15, 2007
The JBM rubber boots are far superior to the rotax boots . We just changed out a set of rotax boots that went bad in less than a year . Will only fly with JBM boots from now on . Hope fully will not have to changed them for many years but will look at them several times a year and inspect inside and out. -------- FLY FUN FLY LOW FLY SLOW John Perry Kitfox 2 N718PD 582 cbox 2:62-1 IVO IFA WHEELS NorthAire Floats Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134561#134561 ________________________________________________________________________________
From: "barryhuston" <barryhuston(at)roadrunner.com>
Subject: --Subject:: Change-Carb Boots - 912 UL
Date: Sep 15, 2007
Stan & Marwynne & LIST CARB BOOTS -- 912UL Could not locate in Lockwood Catalog --- Page Number or PART # ?? ALSO, Is a there a recommendation on how frequently these should be changed. ?? Barry Huston Model IV - 1200 Tri-Gear Lake Ossipee, NH _____ From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of SOURDOSTAN(at)aol.com Sent: Saturday, September 15, 2007 12:44 PM Subject: Re: Kitfox-List: Re: Lowell Fitt Accident --Subject Change-Carb Boots I just received two new carb boots for my 912ul and I think Lockwood said they do have a KEVLAR reinforcement. They appear much stiffer, as well. Stan Specht Kitfox Model IV Speedster "Columbine" (1250 hrs) Denver, Colorado _____ See what'set="_blank">Make AOL Your Homepage. ________________________________________________________________________________
Date: Sep 15, 2007
John Did not see this before I just sent my previous request " Change Carb Boots - 912UL" Could you provide INFO on purchasing JBM Boots Barry -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of eskflyer Sent: Saturday, September 15, 2007 4:13 PM Subject: Kitfox-List: Re: Rotax Carb rubber boots The JBM rubber boots are far superior to the rotax boots . We just changed out a set of rotax boots that went bad in less than a year . Will only fly with JBM boots from now on . Hope fully will not have to changed them for many years but will look at them several times a year and inspect inside and out. -------- FLY FUN FLY LOW FLY SLOW John Perry Kitfox 2 N718PD 582 cbox 2:62-1 IVO IFA WHEELS NorthAire Floats Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134561#134561 ________________________________________________________________________________
Date: Sep 15, 2007
I inspected my boots several months before I had my engine failure. Pull on them hard and see if you can get them to tear. If they had some KEVLAR in them they would be much better. If they leak they only cause the engine to run rough. It is when they tear as mine did that you have a total power outage. I would be willing to pay extra for the material in them. Good Luck ----- Original Message ----- From: "eskflyer" <eskflyer(at)yahoo.com> Sent: Saturday, September 15, 2007 3:12 PM Subject: Kitfox-List: Re: Rotax Carb rubber boots > > The JBM rubber boots are far superior to the rotax boots . We just changed > out a set of rotax boots that went bad in less than a year . Will only fly > with JBM boots from now on . Hope fully will not have to changed them for > many years but will look at them several times a year and inspect inside > and out. > > -------- > FLY FUN FLY LOW FLY SLOW > John Perry > Kitfox 2 N718PD > 582 cbox 2:62-1 IVO IFA > WHEELS NorthAire Floats > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134561#134561 > > > ________________________________________________________________________________
Subject: Bunches of stuff
Date: Sep 15, 2007
Many thanks to all of you Kitfoxers who responded either to me directly or to the list concerning my question as to why we Kitfoxers put the firewall blanket on the engine side, instead of on the cabin side as do GA aircraft manufacturers. A large number of builders who responded, have eiher done away with the blanket or have installed it on the cabin side of the firewall, which makes sense to this old fart. Now to another subject. I guess everyone who messes with car and airplane engines have heard of Marvel Mystery Oil. I'v used it off and on for 50 years. I bought an ATV sometime back and through short trip useage and many starts, the spark plug was carboning up and fouling. Most of my use with Marvel, was in the engine oil, for break-ins and hard useage. On the container Marvel is also suggested for the fuel, for upper end lube and cleaning of the cylinders. I tried it on the ATV and for a coupla weeks, using the recommended amount in the fuel and it worked super. The plug cleaned up, starts were easier and it idled better........But, I started getting a gasoline puddle under my ATV, coming out of the carb overflow. Bunches of work, but I pulled the carb, looked at the float needle and it had turned gummy and was leaking. So I installed a new needle and put the works back together. A week or so later, I started getting a large fuel puddle under the ATV again. Earlier, it had worked so well, before getting fuel leakage under the ATV, I also had put in in my gas for the 582 on my Kitfox. Worked great there too, keeping clean plugs and smooth idling. I hadn't had the plane out in a coupla weeks and when I saw the gas puddle under the ATV, I hobbled out to the folded wing, mini hanger, checked the carbs for leaking and sure enough, there was a large gas puddle on the floor under the engine. I was mixing the plane gas with the premix oil and adding the suggested amount of Marvel Mystery Oil. I pulled both carbs and checked the rubber tips on the float needles and they were deteriorating. Not being a real fast thinker, I guess, I cussed to myself, about the poor quality of tips on the needle valves and how things just weren't up to the standards of earlier years. I replaced the Bing needles, and made no changes in the Marvel oil as it was sure working good in cleaning up the combustion chanmbers. A week or so later, I had another gas puddle under the plane and the ATV was still leaking gas. Finally the gray mater lit up and I drained the fuel tanks on both the plane and the ATV and again, replaced the float needles on the 2 engines. After I'd used up all the bad words that I learned from all the bad people I knew, I hadda start making up a whole lot of new ones, that I'd like to pass on.... But I can't spell 'em. Any way, I changed the 582 over to oil injection and am using the Marvel in the oil injection system and quit putting Marvel in the ATV. It's been several months now and no more fuel leakage from either engine. It seems that the Marvel is a good product, if it not used where it can come in contact with the rubber tips they are now using on the float needles. (they all used to be brass tips) Marvel sure keeps things cleaned up and seems to work great in the 4 cycle oil engines, But beware of mixing with gasoline in the fuel tanks. My ATV still fouls plugs, so I buy them buy the dozen. If anyon's interested in some old fouled plugs to play with, I have some real cheap. Herbert Doud Kitfox IV/582 New Braunfels, Tx ________________________________________________________________________________
Subject: Re: Bunches of stuff
Date: Sep 15, 2007
How many hours do you get out of your 582 plugs by using Marvel oil ? how do you know your 582 is clean inside ? Dave -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134578#134578 ________________________________________________________________________________
Date: Sep 15, 2007
Very good, should pop off the water quickly with the 914 and the winds today :) Get us some videos before the ice comes -- calling for near freezing next few nights here -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134579#134579 ________________________________________________________________________________
Date: Sep 15, 2007
That's great Kevin! I have seen pics of his Fox and it is got to be one of the best looking I have seen! If you get a chance, post some of your preliminary performance numbers as I am sure many would be interested. As you know, I am especially interested seeing that I am working on a 7 and installing the 914. By the way, I plan on giving you a call one of these nights to discuss your engine and avionics installation. Again, way to go on the maiden flight! -------- Darin Hawkes Series 7 (under Construction) 914 Turbo Ogden, Utah Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134609#134609 ________________________________________________________________________________
Subject: Re: Trailing edge reinforcement tubes - recommended.
Date: Sep 15, 2007
Dave, I have not seen the recommendation for the tube but it seems like a great idea! I keep looking at my trailing edge and thinking that it would only take a misplaced elbow or hand to bend it any direction. I will make the mod using your tube dimensions supplied. About the Hysol...I have been using the 50 ml cartridges for years now building model jets and the Kitfox and have never had a problem with the mixing nozzles even when I was working in a 40 degree garage in the winter (I now have a climate controlled shop to work in). The nozzles I use I get from RSHughes and they are square with a green mixer. -------- Darin Hawkes Series 7 (under Construction) 914 Turbo Ogden, Utah Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134612#134612 ________________________________________________________________________________
Date: Sep 15, 2007
Two questions: -Is the wider landing gear from Airdale a direct fit to the Kitfox 4? -What is the cost? Thanks -------- Dave Speedster 912 UL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134621#134621 ________________________________________________________________________________
Subject: Re: Broken tailwheel spring- revelation
Date: Sep 16, 2007
On Sep 15, 2007, at 9:12 PM, Jack L Bell wrote: > It finally happened- I broke my tailwheel spring > after a landing. I did the same thing last year, Jack. My single blade tailwheel spring gave up after about 950 landings. It was on asphalt and the plane went in a 270 degrees ground loop. Luckily the speed was so low that it went well. I have now two blades on my tailwheel spring. I see your point with the Avid rudder that is more curved and doesn't rest on the ground in the event of the lost of the tailwheel. I guess the Kitfox is more squared because Denney and later, Skystar, tried to increase as much as possible the rudder authority with surface. Anyway, I also needed some repair to the rudder as it had been shaved by the asphalt. I repaired it with glassfiber, epoxy, a piece of fabric and paint. It is not a structural part of the aircraft so I guess it should be good enough. Geir-Olav, if you read this: Remember to add a second blade to your tailwheel spring on your model IV! Cheers, Michel Verheughe Norway Kitfox 3 - Jabiru 2200 ________________________________________________________________________________
From: =?iso-8859-1?Q?Geir_Olav_=D8ien?= <geir_olav(at)c2i.net>
Date: Sep 16, 2007
Geir-Olav, if you read this: Remember to add a second blade to your tailwheel spring on your model IV! I ordered a new spring from john, a few days back. Better to be safe than sorry. Geir Olav ien -----Opprinnelig melding----- Fra: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] P vegne av Michel Verheughe Sendt: 16. september 2007 09:52 Til: kitfox-list(at)matronics.com Emne: Re: Kitfox-List: Broken tailwheel spring- revelation On Sep 15, 2007, at 9:12 PM, Jack L Bell wrote: > It finally happened- I broke my tailwheel spring > after a landing. I did the same thing last year, Jack. My single blade tailwheel spring gave up after about 950 landings. It was on asphalt and the plane went in a 270 degrees ground loop. Luckily the speed was so low that it went well. I have now two blades on my tailwheel spring. I see your point with the Avid rudder that is more curved and doesn't rest on the ground in the event of the lost of the tailwheel. I guess the Kitfox is more squared because Denney and later, Skystar, tried to increase as much as possible the rudder authority with surface. Anyway, I also needed some repair to the rudder as it had been shaved by the asphalt. I repaired it with glassfiber, epoxy, a piece of fabric and paint. It is not a structural part of the aircraft so I guess it should be good enough. Geir-Olav, if you read this: Remember to add a second blade to your tailwheel spring on your model IV! Cheers, Michel Verheughe Norway Kitfox 3 - Jabiru 2200 ________________________________________________________________________________
Date: Sep 16, 2007
All, I once attended a forum where a military officer talked about surviving crashes. He was prompted to talk more about this after surviving a crash in a F-14 (?) due to complete engine failure. The best part was that it was right after takeoff, at night, and in a mountain range! Oh yeah, the best part, they went in at 150 knots! It was a very interesting forum, and I learned a lot about crash survivability from what he had to say. Ironically, one of the things discussed was the dispute about whether to try and land a light airplane in the tree tops or not. According to him (and a short video clip from Bob Hoover on the same subject), they both said NOT to land in the tree tops. Rather, fly as far into the crash as possible. Meaning, maintain as much control of the direction of the aircraft as long as possible. They said that trying to land in the tree tops generally indicates stalling just above the tree tops. But doing so will limit your directional control. So if the airplane doesn't land softly in the tree tops like you thought it would, you just might hit a 3 foot oak tree trunk head on instead of that nice soft umbrella you were aiming for. Plus, even if you could land in the umbrella, it is very likely no one will find you there. And if you are injured, it's more likely you will bleed to death before anyone can get to you. AND, if no one saw you go into the tree tops, and you can't wait any longer for fear of dying of injuries, exposure or thirst, you are just as dead if you decide to try and climb down, and fall from a 70 foot tall tree. Not many of us are all that good at climbing (down) trees, especially if injured. All that said, if I had NO choice I would put down in the umbrella of trees. But it would be one of my very last choices. I personally have had 5 engine failures in airplanes, 3 on takeoff. And I am here to write about them mostly because I (instictively more than anything else) flew the airplane to the ground in a controlled glide. And yes, there were large obstacles I could have hit during those emergency off airport landings. But because I was able to maintain aircraft directional control, I was able to avoid hitting any of them. So I am a firm believer in "Fly The Airplane" as far into the crash as possible. But that's just my opinion. I do realize that every situation isn't the same and sometimes you just have to do what you have to do. However, I'm a firm believer if you just focus all of your attention on "flying the airplane", you will have the highest chance of survivability. The ultralight group has a famous saying I like; "You Hav'ta Afta" . Which means "you have to always fly the airplane". I think that says it all, and is the best advice any of us can follow. Paul Seehafer Kitfox IV 912 ul amphib ps - I have a wrecked airplane sitting in my hangar that landed in treetops in a stalled attitude. It now has a 10 inch hole between the rudder pedals in the firewall where a large branch came into the cockpit, just missing the pilot. Had it been inches one way or another, I'd guess it would have been fatal. In this case, after he hit the tops of the trees it fell tail first backwards, landing against a large tree trunk. Pilot walked away with only minor injuries. But I think someone was looking out for this guy that day... ----- Original Message ----- Subject: Kitfox-List: Re: Landing in Treetops Attending a flight safety conference in Germany, last year, we were told > that light aircraft should rather try to land on tree tops than attempt to > make a sharp manoeuvre to reach an open field, at the risk of not being > able to do it and end in a wall or another hard surface. Personally, I > think that, if the forest is dense enough, a Kitfox would simply land on > the top of the trees and rescue would come with a fire brigade ladder. I > am not sure but I still feel I stand a better chance to survive a aircraft > crash landing if it is a very light one. After all, a 30 feet wide, 900 > pounds heavy object moving at 40 MPH shouldn't need much to come to a > stop. Michel, I have an example of this in my shop. About 25 years ago a pilot had fuel contamination and the engine quit in a Funk B-85 C. He ended up about 100' up in the Cedar tree he landed on. He was rescued by Hook & Ladder truck from Fire Dept. More damage was done to aircraft removing from tree with a huge crane than was done in landing there. I'm slowly restoring that plane. Still has cable marks on door post aluminum cover where the cable wrapped around to remove. Windshield, all windows & airframe not damaged except for wings & doors which were totaled by time aircraft was removed from tree. Two of my friends heard engine quit and ran to where they heard the noise of crash, couldn't find plane till pilot yelled at them from above! Elbie Mendenhall, Restoring the "Cedar Tree Funk" N-77705 ------------------------------------------------------------------------- ----- Make AOL Your Homepage. ________________________________________________________________________________
Subject: Re: Light-Sport Pilots license
Date: Sep 16, 2007
I have had an FAA person mention moving the switch on an IVO prop electric prop so it was accessible only from the ground as being legit under the LSA rules. But that was somewhat a tongue in cheek response to me asking about a particular friends airplane. In other words, you may and you may not get away with that. I believe the regs state that if ever the plane is equipped with an inflight prop, it will remove it from Light Sport eligibility. So what you need to do is check to see if the airplane was certified with an inflight prop, and if it's written anywhere in the logs or the airworthiness or operating limitation paperwork. If not, I doubt putting a ground adjustable prop on it (whatever you want to call a ground adjustable prop) will be a problem. BUT according to the rules, technically the aircraft is no longer eligible for Light Sport status if it ever has had an in flight adjustable prop on it. (fwiw - I think that is stupid, but it is the rule...) Out of respect for all the FAA has granted us under Sport Pilot, as a group I think we should try not to "push" the LSA limits by admitting to moving switches, etc. That could sacrifice the credibility we have as sport pilots to the FAA. If you really want an inflight prop, just get a private pilot license. Or, get everyone together to start a letter writing campaign to request the FAA allow in flight props under light sport rules. I perceive that if enough people ask for reasonable changes in the rule, the FAA will actually listen and possibly change them. After all, that's how the Light Sport Aircraft and Pilot rule got this far. Just my two cents worth... Paul Seehafer Kitfox IV 912ul amphib ----- Original Message ----- Subject: Kitfox-List: Re: Light-Sport Pilots license > dcsfoto wrote: >> the FAA has been ask and agrees that putting the switch in a location >> that can only be reached on the ground is ok >> >> David > > I would be interested in seeing a source for that. > > The sticking point is in 14 CFR Part 1.1, where it says "Light-sport > aircraft means an aircraft, other than a helicopter or powered-lift that, > since its original certification, has continued to meet the > following:...(7) A fixed or ground-adjustable propeller if a powered > aircraft other than a powered glider." > > It seems pretty clear that the restriction is permanent, even if an > aircraft is later physically brought back into LSA compliance. However, > the phrase "since its original certification" seems to indicate that this > restriction may be intended for certified aircraft only. I would love to > see an authoritative (FAA) source state emphatically whether or not this > permanent restriction also applies to amateur built experimentals. There > are many differing opinions about this on the internet, but I have yet to > see anything from the FAA that states the case in no uncertain terms. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134202#134202 > > > ________________________________________________________________________________
Date: Sep 16, 2007
Herbert.... I am thinking of adding Marvel to my 582 operation, are you using straight Marvel in the injection system or are you adding it to your regular injection oil? If so in what percentage? Jim Kitfox 2, 582, 1100+ hrs Calgary AB On 15-Sep-07, at 3:59 PM, Herbert Doud wrote: > > Any way, I changed the 582 over to oil injection and am using the > Marvel in the oil injection system and quit putting Marvel in the > ATV. It's been several months now and no more fuel leakage from > either engine. > > ________________________________________________________________________________
Subject: Re: Exhaust parts 582
Date: Sep 16, 2007
Simple mod has turned successful so far . Added in some the the header that was chopped off by Skystar. Net results were 200 - 300 RPM increase at idle, static and wide open in level flight. I can only assume that a few extra ponies have been had. I have no re-pitched and at the same fuel flow as pre exhaust change I am cruise 3 to 5 mph faster. I just changed props from my seaplane prop ( warp 3 blade 68" wide tip ) to a IVO medium 72" 2 blade. Both seem to be about the same 92 to 93 @ 6000 rpm at 20 liters/hour and this is with the King Fox 21 " x 12 tires that cost about 2 to 3 mph. Surely will wheel pants and smaller tires the 582 fox would see over 100 mph. Temps 54F now when i last flew and was seeing 1200 fpm climb on average. So if you want the extra HP this is a easy mod to do . I am not done yet either as I am going to try to lengthen it further but I think the change will be minimal. But will not know till I try it. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134656#134656 ________________________________________________________________________________
Date: Sep 16, 2007
Can i ask why would you want to add it ? I run easy past 300 hours using Bombardier XPS mineral oil and have no reason to need it so far ? -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134659#134659 ________________________________________________________________________________
Date: Sep 16, 2007
Hi all, Just came back from my second flight in which I had planned to do a couple stalls and verify the limited information I had gathered the day before. Today's flight was much more relaxed compared the the initial flight 1 day earlier. The airplane is a joy to fly and I'm really looking forward to these next flight tests. I have a 68" IVO in-flight adjustable prop which I set to 5500 static rpms before takeoff which gave me about 5700 in the climb. These first 2 takeoffs I climbed out at 70-75 mph and 650 fpm. I have not retracted the gear yet so it should be capable of a little better climb. CG was about 10.8 and weight was around 1400 lbs. It is cool here today with morning temps near 40f. I need to do something with the oil temps since I was unable to get them above 180 even in the climb. I leveled off about 3500 msl with 5000 rpms and 31" MP (75 %) and was showing 82 mph +/-. 65 % was only 3 mph slower so the plane really needs to be cleaned up. (Gear still has not been retracted). I'll post more later but overall the flight characteristics are great and the landings have been 2 of my best. I notch of flaps on both landings only because the nose seemed too high without. Kevin Cozik series 6-7 rotax 914 turbo Czech floats Lansing Michigan ----- Original Message ----- From: "darinh" <gerns25(at)netscape.net> Sent: Saturday, September 15, 2007 10:27 PM Subject: Kitfox-List: Re: It flys! > > That's great Kevin! I have seen pics of his Fox and it is got to be one > of the best looking I have seen! If you get a chance, post some of your > preliminary performance numbers as I am sure many would be interested. As > you know, I am especially interested seeing that I am working on a 7 and > installing the 914. By the way, I plan on giving you a call one of these > nights to discuss your engine and avionics installation. Again, way to go > on the maiden flight! > > -------- > Darin Hawkes > Series 7 (under Construction) > 914 Turbo > Ogden, Utah > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134609#134609 > > > ________________________________________________________________________________
Date: Sep 16, 2007
Pictures! Pictures! Jeff Classic IV ----- Original Message ----- From: W Duke To: kitfox-list(at)matronics.com Sent: Saturday, September 15, 2007 12:40 PM Subject: Re: Kitfox-List: It flys! congrats. Have fun. Kevin Cozik wrote: Hello everyone, Just a quick note to let you know Kitfox series 6, N262SC took to the air at about 8 am this morning for its maiden flight. It flew great with no changes needed in rigging! More later. Kevin Cozik Series 6-7 Rotax 914 turbo Czech amphibs Lansing Michigan ________________________________________________________________________________
Date: Sep 16, 2007
From: Dan Billingsley <dan(at)azshowersolutions.com>
Way to go Kevin!! Keep sending the stats and pictures when you get em. Always great to hear of another birth. Dan B Mesa, AZ KF-IV 912s Building http://www.azshowersolutions.com/Build1.html Kevin Cozik wrote: Hi all, Just came back from my second flight in which I had planned to do a couple stalls and verify the limited information I had gathered the day before. Today's flight was much more relaxed compared the the initial flight 1 day earlier. The airplane is a joy to fly and I'm really looking forward to these next flight tests. I have a 68" IVO in-flight adjustable prop which I set to 5500 static rpms before takeoff which gave me about 5700 in the climb. These first 2 takeoffs I climbed out at 70-75 mph and 650 fpm. I have not retracted the gear yet so it should be capable of a little better climb. CG was about 10.8 and weight was around 1400 lbs. It is cool here today with morning temps near 40f. I need to do something with the oil temps since I was unable to get them above 180 even in the climb. I leveled off about 3500 msl with 5000 rpms and 31" MP (75 %) and was showing 82 mph +/-. 65 % was only 3 mph slower so the plane really needs to be cleaned up. (Gear still has not been retracted). I'll post more later but overall the flight characteristics are great and the landings have been 2 of my best. I notch of flaps on both landings only because the nose seemed too high without. Kevin Cozik series 6-7 rotax 914 turbo Czech floats Lansing Michigan ----- Original Message ----- From: "darinh" Sent: Saturday, September 15, 2007 10:27 PM Subject: Kitfox-List: Re: It flys! > > That's great Kevin! I have seen pics of his Fox and it is got to be one > of the best looking I have seen! If you get a chance, post some of your > preliminary performance numbers as I am sure many would be interested. As > you know, I am especially interested seeing that I am working on a 7 and > installing the 914. By the way, I plan on giving you a call one of these > nights to discuss your engine and avionics installation. Again, way to go > on the maiden flight! > > -------- > Darin Hawkes > Series 7 (under Construction) > 914 Turbo > Ogden, Utah > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134609#134609 > > > ________________________________________________________________________________
Date: Sep 16, 2007
Michel, Not so, The tailwheel will be bouncing around and likely go through your rudder. Ask me how i know I have 3 leafs on mine now and hopefully they will have a good long life. . > But you've got a good point there, if I am to break my main leaf now, > the plane will rest on the 'helper' and the rudder will be safe. > -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134714#134714 ________________________________________________________________________________
Date: Sep 16, 2007
Congrats Kevin! I know it was a long haul on that project, but it sounds like all your hard work is paying off now. Keep us posted on future results and specs. And yes, pictures!!! Especially once you start doing your water work! I'm very curious how those 1650 floats work out (I'm in the process of building production prototype 1350 and 1500 amphibs for our planes, and am gathering all good info I can lay my hands on regarding float performance and mods). Paul Seehafer Kitfox IV 912ul amphib ----- Original Message ----- From: "Kevin Cozik" <Kcozik(at)cablespeed.com> Sent: Sunday, September 16, 2007 10:52 AM Subject: Re: Kitfox-List: Re: It flys! > > Hi all, > Just came back from my second flight in which I had planned to do a > couple stalls and verify the limited information I had gathered the day > before. Today's flight was much more relaxed compared the the initial > flight 1 day earlier. The airplane is a joy to fly and I'm really looking > forward to these next flight tests. > I have a 68" IVO in-flight adjustable prop which I set to 5500 static > rpms before takeoff which gave me about 5700 in the climb. These first 2 > takeoffs I climbed out at 70-75 mph and 650 fpm. I have not retracted the > gear yet so it should be capable of a little better climb. CG was about > 10.8 and weight was around 1400 lbs. It is cool here today with morning > temps near 40f. I need to do something with the oil temps since I was > unable to get them above 180 even in the climb. I leveled off about 3500 > msl with 5000 rpms and 31" MP (75 %) and was showing 82 mph +/-. 65 % > was only 3 mph slower so the plane really needs to be cleaned up. (Gear > still has not been retracted). > I'll post more later but overall the flight characteristics are great > and the landings have been 2 of my best. I notch of flaps on both > landings only because the nose seemed too high without. > Kevin Cozik > series 6-7 > rotax 914 turbo > Czech floats > Lansing Michigan > > ----- Original Message ----- > From: "darinh" <gerns25(at)netscape.net> > To: > Sent: Saturday, September 15, 2007 10:27 PM > Subject: Kitfox-List: Re: It flys! > > >> >> That's great Kevin! I have seen pics of his Fox and it is got to be one >> of the best looking I have seen! If you get a chance, post some of your >> preliminary performance numbers as I am sure many would be interested. >> As you know, I am especially interested seeing that I am working on a 7 >> and installing the 914. By the way, I plan on giving you a call one of >> these nights to discuss your engine and avionics installation. Again, >> way to go on the maiden flight! >> >> -------- >> Darin Hawkes >> Series 7 (under Construction) >> 914 Turbo >> Ogden, Utah >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=134609#134609 >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 16, 2007
Thanks for the report, Kevin and congratulations! Fred Shiple Series 6 Bilmar amphibs Toledo OH ________________________________________________________________________________
Date: Sep 16, 2007
Did you leave the elbow bend tight as modified by Kitfox? How about a picture? I would love a few more ponies. Dwight Purdy Model ll (503) > >Simple mod has turned successful so far . >Added in some the the header that was chopped off by Skystar. > >Net results were 200 - 300 RPM increase at idle, static and wide open in >level flight. I can only assume that a few extra ponies have been had. > >I have no re-pitched and at the same fuel flow as pre exhaust change I am >cruise 3 to 5 mph faster. I just changed props from my seaplane prop ( >warp 3 blade 68" wide tip ) to a IVO medium 72" 2 blade. Both seem to be >about the same 92 to 93 @ 6000 rpm at 20 liters/hour and this is with >the King Fox 21 " x 12 tires that cost about 2 to 3 mph. Surely will >wheel pants and smaller tires the 582 fox would see over 100 >mph. Temps 54F now when i last flew and was seeing 1200 fpm climb on >average. > >So if you want the extra HP this is a easy mod to do . I am not done >yet either as I am going to try to lengthen it further but I think the >change will be minimal. But will not know till I try it. > >-------- >Rotax Dealer, Ontario Canada >Flying Videos and Kitfox Info >http://www.cfisher.com/ > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=134656#134656 > > >-- >9/15/2007 7:54 PM -- ________________________________________________________________________________
Subject: Re: Marvel Oil
Date: Sep 16, 2007
Dave: Plugs were running clean and without carbon at 50 hours. Gap was still at 18 thousands. Changed them anyway. Using NGK BR8ES plugs. So far as the combustion chamber being as clean as the plugs, .....I dunno...I have a 582 bluehead with about 175 hours and haven't felt the need to tear it down yet. Running smooth at cruise and idles smooth. Just guessing, at this point, but hope that the chamber and rings are as clean as the plugs. On my old 582 gray head, the plugs pretty well matched the condition of the combustion chamber. Herbert Doud Kitfox IV/582 New Braunfels, Tx ************************* Subject: Kitfox-List: Re: Bunches of stuff From: "dave" <dave(at)cfisher.com> How many hours do you get out of your 582 plugs by using Marvel oil ? how do you know your 582 is clean inside ? Dave -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ ________________________________________________________________________________
Date: Sep 16, 2007
If the Mystery Oil is causing damage to the needle tips, I can't help but wonder what it's doing to the inside of your fuel lines and or oil injection lines? Andy F. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Herbert Doud Sent: Saturday, September 15, 2007 4:59 PM To: Kitfox-List Digest Server Subject: Kitfox-List: Bunches of stuff Many thanks to all of you Kitfoxers who responded either to me directly or to the list concerning my question as to why we Kitfoxers put the firewall blanket on the engine side, instead of on the cabin side as do GA aircraft manufacturers. A large number of builders who responded, have eiher done away with the blanket or have installed it on the cabin side of the firewall, which makes sense to this old fart. Now to another subject. I guess everyone who messes with car and airplane engines have heard of Marvel Mystery Oil. I'v used it off and on for 50 years. I bought an ATV sometime back and through short trip useage and many starts, the spark plug was carboning up and fouling. Most of my use with Marvel, was in the engine oil, for break-ins and hard useage. On the container Marvel is also suggested for the fuel, for upper end lube and cleaning of the cylinders. I tried it on the ATV and for a coupla weeks, using the recommended amount in the fuel and it worked super. The plug cleaned up, starts were easier and it idled better........But, I started getting a gasoline puddle under my ATV, coming out of the carb overflow. Bunches of work, but I pulled the carb, looked at the float needle and it had turned gummy and was leaking. So I installed a new needle and put the works back together. A week or so later, I started getting a large fuel puddle under the ATV again. Earlier, it had worked so well, before getting fuel leakage under the ATV, I also had put in in my gas for the 582 on my Kitfox. Worked great there too, keeping clean plugs and smooth idling. I hadn't had the plane out in a coupla weeks and when I saw the gas puddle under the ATV, I hobbled out to the folded wing, mini hanger, checked the carbs for leaking and sure enough, there was a large gas puddle on the floor under the engine. I was mixing the plane gas with the premix oil and adding the suggested amount of Marvel Mystery Oil. I pulled both carbs and checked the rubber tips on the float needles and they were deteriorating. Not being a real fast thinker, I guess, I cussed to myself, about the poor quality of tips on the needle valves and how things just weren't up to the standards of earlier years. I replaced the Bing needles, and made no changes in the Marvel oil as it was sure working good in cleaning up the combustion chanmbers. A week or so later, I had another gas puddle under the plane and the ATV was still leaking gas. Finally the gray mater lit up and I drained the fuel tanks on both the plane and the ATV and again, replaced the float needles on the 2 engines. After I'd used up all the bad words that I learned from all the bad people I knew, I hadda start making up a whole lot of new ones, that I'd like to pass on.... But I can't spell 'em. Any way, I changed the 582 over to oil injection and am using the Marvel in the oil injection system and quit putting Marvel in the ATV. It's been several months now and no more fuel leakage from either engine. It seems that the Marvel is a good product, if it not used where it can come in contact with the rubber tips they are now using on the float needles. (they all used to be brass tips) Marvel sure keeps things cleaned up and seems to work great in the 4 cycle oil engines, But beware of mixing with gasoline in the fuel tanks. My ATV still fouls plugs, so I buy them buy the dozen. If anyon's interested in some old fouled plugs to play with, I have some real cheap. Herbert Doud Kitfox IV/582 New Braunfels, Tx ________________________________________________________________________________
Subject: Re: Strut fairing questions.
Date: Sep 16, 2007
I have to check from Hoerners book but i think it around 4 to 1 ratio -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134742#134742 ________________________________________________________________________________
Date: Sep 16, 2007
Well the Y pipe is what was cut I think at Skystar as well as the 90 Elbow but I added mine to the elbow. Your elbow will be near the cowl and might burn a hole in it but a air outlet could be added there or just a bump. The muffler will not longer be straight below the engine but on a little angle. I am sure there is a way to alter more but I have not spent the time on it yet. Basically I just added 1 1/2 inches to the header directly onto the elbow on the top of it. I could have added to the y pipe but it seemed easier to do it this way. Just out for a 1 hour flight with a friend , I have on the IVO medium right now and it worked well about 4 mph faster that without the exhaust mod. Now all we need to do it put a different pipe on it and see another 5 or 10 hp :) -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134777#134777 Attachments: http://forums.matronics.com//files/8_174.jpg ________________________________________________________________________________
Date: Sep 16, 2007
Herbert , Thanks for the info. I have never needed it in over 35 years of 2 strokes. Did you know it made of Stoddard solvent, Mineral oil and Lard . ? I get 150 hours out of my 582 on BR8ES solid tips that are pre gapped .018 new. Pics here http://www.cfisher.com/152hournkg.html -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134778#134778 ________________________________________________________________________________
Date: Sep 16, 2007
Subject: Re: --Subject:: Change-Carb Boots - 912 UL
The Lockwood number for the new carb boots/sockets is 267 788 (Carb Socket, 912/912S/914, new style w/8mm spacer). Cost from Lockwood is $94.75 each. You should ask them how often to change. Stan Specht Kitfox Model IV Speedster "Columbine" Denver, Colorado ________________________________________________________________________________
From: "JC Propellerdesign" <propellerdesign(at)tele2.se>
Date: Sep 17, 2007
Hi It depends on the Reynolds number, a cyl (tube) with Re <10^5 have drag coefficient 1 - 1,3, and with Re >10^6 = CD 0,30 With an airfoil of length 3:1 (0,333) and Re >10^6 = CD 0,04 with a Re under 10^5 the length have to be 5:1 (0,20) to get same drag CD 0,04 a 2" diameter tube at 100 MPH have Re 1,56*10^5 8" long and Re is 6,26*10^5 and CD will be 0,012 with reference to the surface area so with say total 10 meter of 2" tube the drag will be 60-80 kg and with airfoil 3 kg at 100 MPH And a NACA 67-020 or NACA 67-025 will have little more then half the drag a NACA 0020 - 0025 will have if made correct. Jan ----- Original Message ----- From: dave To: kitfox-list(at)matronics.com Sent: Monday, September 17, 2007 2:35 AM Subject: Kitfox-List: Re: Strut fairing questions. I have to check from Hoerners book but i think it around 4 to 1 ratio -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134742#134742 ________________________________________________________________________________
Subject: Re: Vortex Generators/Turbulator's
Date: Sep 17, 2007
Update on VG testing ......... just in from more aggressive stall testing. power off -- full aft stick - just get a 500 fpm mush with less buffet that without VGs and no nose drop. power on -- 3 stalls - one right wing dropped other 2 no wing drop . still less buffeting that before . So far, satisfied with VGs and no cruise speed loss it seems. as far as claims of these 8 + mph stall speed drops -- in my case that just a myth so far but 2 or 3 mph about the most of got SO FAR . http://www.cfisher.com/vg.html -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134800#134800 ________________________________________________________________________________
Date: Sep 17, 2007
Dave, With about 250 RPM gain at WOT you have increased power with about 12% like going from 60 to 67, or 65 to 73 Hp increasing speed with 3,85 % Jan ----- Original Message ----- From: dave To: kitfox-list(at)matronics.com Sent: Monday, September 17, 2007 5:11 AM Subject: Kitfox-List: Re: Exhaust parts 582 Well the Y pipe is what was cut I think at Skystar as well as the 90 Elbow but I added mine to the elbow. Your elbow will be near the cowl and might burn a hole in it but a air outlet could be added there or just a bump. The muffler will not longer be straight below the engine but on a little angle. I am sure there is a way to alter more but I have not spent the time on it yet. Basically I just added 1 1/2 inches to the header directly onto the elbow on the top of it. I could have added to the y pipe but it seemed easier to do it this way. Just out for a 1 hour flight with a friend , I have on the IVO medium right now and it worked well about 4 mph faster that without the exhaust mod. Now all we need to do it put a different pipe on it and see another 5 or 10 hp :) -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134777#134777 Attachments: http://forums.matronics.com//files/8_174.jpg ________________________________________________________________________________
Date: Sep 17, 2007
>From what I've read MMO is mostly Stoddard solvent (Varisol) and lard. I have no idea what the lard does for the recipe but I know I don't want Varisol soaking the seals in the base of my engine. I might consider using the stuff for the last ten hours or so before an engine tear down for new seals just to clean things up a bit for inspection. sorry guys but I'm with the crowd that is NOT in favour of additives to gas or oil for planes. If you are getting too much carbon in your engine and your oil ratios are correct then you are using the wrong brand of oil. Bombardier, the manufacturer's, oil, Pennzoil air-cooled and "El Cheapo" WallyWorld oil all seem to work well according to the reports from this and other lists. Noel Loveys, RPP, AME intern Campbellton, Newfoundland, Canada Kitfox Mod III-A, 582, B box, Ivo IFA Aerocet 1100s noelloveys(at)yahoo.ca -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Andy Fultz Sent: Sunday, September 16, 2007 9:58 PM Subject: RE: Kitfox-List: Bunches of stuff If the Mystery Oil is causing damage to the needle tips, I can't help but wonder what it's doing to the inside of your fuel lines and or oil injection lines? Andy F. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Herbert Doud Sent: Saturday, September 15, 2007 4:59 PM Subject: Kitfox-List: Bunches of stuff Many thanks to all of you Kitfoxers who responded either to me directly or to the list concerning my question as to why we Kitfoxers put the firewall blanket on the engine side, instead of on the cabin side as do GA aircraft manufacturers. A large number of builders who responded, have eiher done away with the blanket or have installed it on the cabin side of the firewall, which makes sense to this old fart. Now to another subject. I guess everyone who messes with car and airplane engines have heard of Marvel Mystery Oil. I'v used it off and on for 50 years. I bought an ATV sometime back and through short trip useage and many starts, the spark plug was carboning up and fouling. Most of my use with Marvel, was in the engine oil, for break-ins and hard useage. On the container Marvel is also suggested for the fuel, for upper end lube and cleaning of the cylinders. I tried it on the ATV and for a coupla weeks, using the recommended amount in the fuel and it worked super. The plug cleaned up, starts were easier and it idled better........But, I started getting a gasoline puddle under my ATV, coming out of the carb overflow. Bunches of work, but I pulled the carb, looked at the float needle and it had turned gummy and was leaking. So I installed a new needle and put the works back together. A week or so later, I started getting a large fuel puddle under the ATV again. Earlier, it had worked so well, before getting fuel leakage under the ATV, I also had put in in my gas for the 582 on my Kitfox. Worked great there too, keeping clean plugs and smooth idling. I hadn't had the plane out in a coupla weeks and when I saw the gas puddle under the ATV, I hobbled out to the folded wing, mini hanger, checked the carbs for leaking and sure enough, there was a large gas puddle on the floor under the engine. I was mixing the plane gas with the premix oil and adding the suggested amount of Marvel Mystery Oil. I pulled both carbs and checked the rubber tips on the float needles and they were deteriorating. Not being a real fast thinker, I guess, I cussed to myself, about the poor quality of tips on the needle valves and how things just weren't up to the standards of earlier years. I replaced the Bing needles, and made no changes in the Marvel oil as it was sure working good in cleaning up the combustion chanmbers. A week or so later, I had another gas puddle under the plane and the ATV was still leaking gas. Finally the gray mater lit up and I drained the fuel tanks on both the plane and the ATV and again, replaced the float needles on the 2 engines. After I'd used up all the bad words that I learned from all the bad people I knew, I hadda start making up a whole lot of new ones, that I'd like to pass on.... But I can't spell 'em. Any way, I changed the 582 over to oil injection and am using the Marvel in the oil injection system and quit putting Marvel in the ATV. It's been several months now and no more fuel leakage from either engine. It seems that the Marvel is a good product, if it not used where it can come in contact with the rubber tips they are now using on the float needles. (they all used to be brass tips) Marvel sure keeps things cleaned up and seems to work great in the 4 cycle oil engines, But beware of mixing with gasoline in the fuel tanks. My ATV still fouls plugs, so I buy them buy the dozen. If anyon's interested in some old fouled plugs to play with, I have some real cheap. Herbert Doud Kitfox IV/582 New Braunfels, Tx href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron href "http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 17, 2007
Kind of nice eh !! [Laughing] [Laughing] [Laughing] [Laughing] > Dave, > > With about 250 RPM gain at WOT you have increased power with about 12% like going from 60 to 67, or 65 to 73 Hp > > increasing speed with 3,85 % > > Jan -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134871#134871 ________________________________________________________________________________
Date: Sep 17, 2007
All, For any of you having a little trouble interpreting Jan's formulas, here's the laymens formula for determining fairing sizes as I remember it; For every inch of thickness of the part you want to streamline, you need a fairing 4.25 times wider. In other words, if you have a one inch round strut tube, you will need a streamline fairing with a 4.25 inch wide chord. Interestingly, the shape of streamlined chromoly and aluminum for aircraft generally do not meet this rule, as for the most part they have too narrow of a chord (Go figure?) Now this is just a general rule of thumb, and it's off the top of my head. So if you want more technical than that, talk to Jan... Paul Seehafer Kitfox IV 912ul amphib ----- Original Message ----- From: JC Propellerdesign To: kitfox-list(at)matronics.com Sent: Monday, September 17, 2007 3:19 AM Subject: Re: Kitfox-List: Re: Strut fairing questions. Hi It depends on the Reynolds number, a cyl (tube) with Re <10^5 have drag coefficient 1 - 1,3, and with Re >10^6 = CD 0,30 With an airfoil of length 3:1 (0,333) and Re >10^6 = CD 0,04 with a Re under 10^5 the length have to be 5:1 (0,20) to get same drag CD 0,04 a 2" diameter tube at 100 MPH have Re 1,56*10^5 8" long and Re is 6,26*10^5 and CD will be 0,012 with reference to the surface area so with say total 10 meter of 2" tube the drag will be 60-80 kg and with airfoil 3 kg at 100 MPH And a NACA 67-020 or NACA 67-025 will have little more then half the drag a NACA 0020 - 0025 will have if made correct. Jan ----- Original Message ----- From: dave To: kitfox-list(at)matronics.com Sent: Monday, September 17, 2007 2:35 AM Subject: Kitfox-List: Re: Strut fairing questions. I have to check from Hoerners book but i think it around 4 to 1 ratio -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134742#134742 http://www.matron=================== === bsp; available via href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 17, 2007
Well spoken. Re number is the length in mm (millimeter) times airspeed in m/s times 70. (there is a formula for inch, feet and miles too) in short, wing struts is UNDER CRITICAL Re. so need 4 to 1 or 5 to1 in length versus thickness. and / or laminar layer control ( Think golf ball) to trip the boundary layer into TURBULENT layer that have energy to follow the airfoil. can be made of Dyno tape (old one) with big V typed all the way. or cut length vise with a zigzag scissor (for fabric) and the cut turned into the airstream, applied both side of wingstrut. at highest point, or just forward of. CD is Drag Coefficient that relates to something like wet area or frontal area (different coefficients) To get the actual drag, CD times the reference area times Dynamic pressure. simple as that. and at level flight drag equal thrust, and lift equal weight (almost) Jan ----- Original Message ----- From: Paul Seehafer To: kitfox-list(at)matronics.com Sent: Monday, September 17, 2007 9:34 PM Subject: Re: Kitfox-List: Re: Strut fairing questions. All, For any of you having a little trouble interpreting Jan's formulas, here's the laymens formula for determining fairing sizes as I remember it; For every inch of thickness of the part you want to streamline, you need a fairing 4.25 times wider. In other words, if you have a one inch round strut tube, you will need a streamline fairing with a 4.25 inch wide chord. Interestingly, the shape of streamlined chromoly and aluminum for aircraft generally do not meet this rule, as for the most part they have too narrow of a chord (Go figure?) Now this is just a general rule of thumb, and it's off the top of my head. So if you want more technical than that, talk to Jan... Paul Seehafer Kitfox IV 912ul amphib ----- Original Message ----- From: JC Propellerdesign To: kitfox-list(at)matronics.com Sent: Monday, September 17, 2007 3:19 AM Subject: Re: Kitfox-List: Re: Strut fairing questions. Hi It depends on the Reynolds number, a cyl (tube) with Re <10^5 have drag coefficient 1 - 1,3, and with Re >10^6 = CD 0,30 With an airfoil of length 3:1 (0,333) and Re >10^6 = CD 0,04 with a Re under 10^5 the length have to be 5:1 (0,20) to get same drag CD 0,04 a 2" diameter tube at 100 MPH have Re 1,56*10^5 8" long and Re is 6,26*10^5 and CD will be 0,012 with reference to the surface area so with say total 10 meter of 2" tube the drag will be 60-80 kg and with airfoil 3 kg at 100 MPH And a NACA 67-020 or NACA 67-025 will have little more then half the drag a NACA 0020 - 0025 will have if made correct. Jan ----- Original Message ----- From: dave To: kitfox-list(at)matronics.com Sent: Monday, September 17, 2007 2:35 AM Subject: Kitfox-List: Re: Strut fairing questions. I have to check from Hoerners book but i think it around 4 to 1 ratio -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134742#134742 http://www.matron=================== === bsp; available via href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Fuel Master Valve
Date: Sep 17, 2007
I was cleaning out some old boxes and found the original fuel master valve that came with my model 3 kit back in 1991. I simplified the fuel line routing and ended up not using it. If you want it and the little shroud / mount it's in, please contact me privately and I'll send it to you. Regards, John Stoner KF III, 582 Alaska ________________________________________________________________________________
Date: Sep 17, 2007
Call John Mc Bean, he sells them. You can make your own if you can find 1 1/4 " wide springs but they hard to find. IF you want one now just call and get it shipped right away. I forget price but I think 50 to 75$ area. I got one and it works ok. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134941#134941 ________________________________________________________________________________
Date: Sep 17, 2007
Subject: Re: Landing in Treetops
Paul sez: >I agree 100% that a light aircraft has a much higher chance of >survivabilty than would a heavier one. After my accident, I told my partners that I wished the accident had happened in our Piper because the insurance company could just buy us a new one rather than my having to build another one. One of my Kitfox buddies assured me that I probably would not have survived in that faster, heavier airplane. Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Subject: Trim Authority
Date: Sep 17, 2007
I have electric trim on my model 4. It works great except for one thing; When landing with flaps, it doesn't have enough authority to trim hands off at 55 mph. I still need a fair amount of back pressure to keep the speed down. I'm still not comfortable landing at my 1200ft farm field with trees on both ends and being able to trim out all the back pressure would really help. Any ideas? -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134969#134969 ________________________________________________________________________________
Subject: Re: Trim Authority
Date: Sep 18, 2007
Hi, I have a model 6, same initial problem, John McBean on his website I believe sells a tension spring (trim assist) which pre-loads the control stick and really does cure this ill...no more running out of trim w/the electric system, and hands-off to stall works great.? Give him a call.? Cheers.? Mike H. -----Original Message----- From: wingnut <wingnut(at)spamarrest.com> Sent: Mon, 17 Sep 2007 9:44 pm Subject: Kitfox-List: Trim Authority I have electric trim on my model 4. It works great except for one thing; When landing with flaps, it doesn't have enough authority to trim hands off at 55 mph. I still need a fair amount of back pressure to keep the speed down. I'm still not comfortable landing at my 1200ft farm field with trees on both ends and being able to trim out all the back pressure would really help. Any ideas? -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134969#134969 ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 17, 2007
Does the spring system work in conjunction with the existing electric trim? How is it adjusted? Would I then have two separate trim systems to adjust? > have a model 6, same initial problem, John McBean on his website I believe sells a tension spring (trim assist) which pre-loads the control stick and really does cure this ill...no more running out of trim w/the electric system, and hands-off to stall works great. Give him a call. Cheers. Mike H. -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134974#134974 ________________________________________________________________________________
From: "Ernest and Jane Deel" <ernieandjane(at)naxs.net>
Subject: New subscriber-1st post-request for info
Date: Sep 18, 2007
From; Ernest Deel ernieandjane(at)naxs.net Subject; Request for info;; I am considering purchasing a KF IV Speedster (s/n JCS 137) project--no FWF except Rotax engine mount. The plane had minor wing-tip and landing gear damage from a high speed taxi incident and the engine was removed for another project. I will want to convert to a tri-gear (nose wheel) Are approved parts and plans available? From who and where? Is this a complicated conversion? Requiring welding and reinforcement of fuselage and/or firewall? And will I need to make a decision on which engine before beginning work on the landing gear? A close-up picture or sketch showing how the nose gear brackets are attached would be helpful. Will this be considered a major airframe modification? and what kind of "paper-work" and inspections will be required? (Although I built and flew a Vari-Eze I do not have much expertise with tube and fabric or welding) An opinion (guesstimate?) on cost will also be welcome. Engines?? Possibly a Jabiru 2200? Just a couple days ago I saw from www.compactradialengines.com an 85hp MZ-301 with about the best power-weight-cost ratio numbers I have seen? Anybody know about or care to comment on this engine (and the company?) Any help, ideas, comments, will be welcome and greatly appreciated. Also if anyone within a100 miles or so of Grundy VA (southwestern VA) has a Kitfox (tri-gear or tail dgr) I would like a close up look at it. Thanks again! Ernie Ernest Deel Rt 1 Box 349A Vansant, VA 24656 276 859 0434 ernieandjane(at)naxs.net ________________________________________________________________________________
Date: Sep 18, 2007
Here's a theory that might help...get the vortex generators from www.landshorter.com and install them on the bottom of your horizontal stab. This should give your elevator more authority at lower speeds. I have the same characteristics on my Model IV Speedster but probably not quite as bad due to my shorter wing. I actually prefer to run out of trim on final because I can better feel what the airplane is doing. It also forces me to fly with the gentle touch and not be ham-handed. -------- Dave Speedster 912 UL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134991#134991 ________________________________________________________________________________
Date: Sep 18, 2007
Luis, 1200 feet runway plus trees at both end ? Well should be no problem fora Kitfox Long wing. Biggest thing is to learn the skills and practice them to make this easy for you. I would suggest practicing alot of slow flight at or a few mph over stall speed until more comfortable plus with up to 20 degrees flaps. Then Side slipping with and without flaps. Find a grass strip about 2000 feet long with trees near you and try it in there then go to a 1500 foot one. Then a 1200 foot one. You should be able to get in and out of a 1200 foot strip pretty with no concerns after a while . Key is slow approach in control. What speed indicated does your plane stall at ? On mine I can approach at 45 to 50 mph and then sideslip down right to the ground, then kick it straight. If you kick it too early on a long wing you will get more float. As far as trim, I have none. The Kitfox controls are so light It not a concern for me. this forum has some talk on VG testing that I have done over the last few weeks http://forums.matronics.com/viewtopic.php?t=31939 plus more here http://www.cfisher.com/vg.html -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135002#135002 ________________________________________________________________________________
From: "Don & Dianne Usher" <denver7(at)xplornet.com>
Subject: czech floats
Date: Sep 18, 2007
I have a model 111, 582, on Full Lotus floats. Plane empty on wheels weighs 496 lbs, I weigh 150. Not really happy with Full Lotus and have to have amphibs. Looking to buy Czech amphibs. Anybody with this combination? and if so, how is water performance with two people. Thanks. Don ________________________________________________________________________________
Date: Sep 17, 2007
Kitfoxers replying to my use and results of Marvel Mystery Oil. As I've explained previously, I'm using the Marvel in my Rotax injection system, mixed with my regular 2 cycle oil. I add to 13 oz. of Penzoil, 2 cycle oil for air cooled engines, 2 oz. of Marvel oil to the oil injection reservoir, which is a ratio of 50:1, (2.5 oz. per gal of gas) of 2 cycle oil and 320:1,(.40 oz. per gal.) of gas Marvel Oil. (Marvel's recommended ratio of oil to gas. 2 oz. per 5 gal. gas.) 13 oz. of Penzoil in the Rotax injection system, also treats 5 gal. gas. I questioned the effect of Marvel in the only rubber (?) tubing, carrying the oil fom the oil reservoir to the injection pump. I'm keeping a close eye on that 6 inch tubing for any signs of deterioration. There hasn't been any in over a year. I think the very small and fragile needle end of rubber (?) on the end of the float valve needle must be overly affected with it's tiny size, as compared to the larger rubber (?) tubing.. If I see there is any sign of deterioration in the tubing, I'll replace it with a plastic line, possibly urethane. For those folks, having no carbonization and a clean running engine, I see no reason to make any changes. I posted the subect for those Kitfoxers who may be having a dirty plug problem, even with proper leaning and a desire to hopefully, keep cleaner rings and a cleaner combustion chamber. It's worked for me over the past 50 years, with antique cars, with engine break -in, keeping clean combustion chambers and a smooth running lower end. Marvel has been in business making the oil since 1925.. That's a very long marketing time. My NGK BR8ES, plugs in the Rotax, looked like new and still gapped at .018 thousands, when I pulled them at 50 hours and would have gone much longer, but since I had 'em out, I replaced 'em. As mentioned my ATV plugs were fouling like crazy, before Marvel and clean after using Marvel, but I had many float needle replacements, which stopped, when I quit premixing Marvel in the ATV gas, so beware using Marvel for pre-mix in the fuel tank. There's been no leaking of fuel in the Kitfox, since I went to oil injection. Many years ago, I talked with the Marvel folks about the make-up of their product. They were naturally secretive, but after the discussion, I gathered that Marvel was made up of a detergent solvent like Varsol, such as we have been cleaning aircraft engines with, for years and a low level carboning and lubricating grease, basically derrived from animal fat. I can only assume from the Kitfox plug and exhaust pipe cleanliness, that the combustion chamber and rings would be cleaner as well, also drawing on my past experience with old auto engines. Won't know for certain 'till the teardown of my 582 Blue Head, which has about 150 hours to date. Hopefully the foregoing might be of help for some of our group. Herbert Doud Kitfox IV / 582 Blue Head New Braunfels, Tx ************************************************ Subject: Kitfox-List: Re: Marvel Oil From: "dave" <dave(at)cfisher.com> Herbert , Thanks for the info. I have never needed it in over 35 years of 2 strokes. Did you know it made of Stoddard solvent, Mineral oil and Lard . ? I get 150 hours out of my 582 on BR8ES solid tips that are pre gapped .018 new. Pics here http://www.cfisher.com/152hournkg.html Subject: Kitfox-List: Re: Marvel Oil From: "dave" <dave(at)cfisher.com> Herbert , Thanks for the info. I have never needed it in over 35 years of 2 strokes. Did you know it made of Stoddard solvent, Mineral oil and Lard . ? I get 150 hours out of my 582 on BR8ES solid tips that are pre gapped .018 new. Pics here http://www.cfisher.com/152hournkg.html cleanliness and C From: Jim Corner <jcorner(at)shaw.ca> Subject: Re: Kitfox-List: Bunches of stuff Herbert.... I am thinking of adding Marvel to my 582 operation, are you using straight Marvel in the injection system or are you adding it to your regular injection oil? If so in what percentage? Jim Kitfox 2, 582, 1100+ hrs Calgary AB ***************************************** Subject: Kitfox-List: Re: Bunches of stuff From: "dave" <dave(at)cfisher.com> Can i ask why would you want to add it ? I run easy past 300 hours using Bombardier XPS mineral oil and have no reason to need it so far ? -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ ****************************************** Subject: Kitfox-List: Re: Bunches of stuff From: "dave" <dave(at)cfisher.com> How many hours do you get out of your 582 plugs by using Marvel oil ? how do you know your 582 is clean inside ? Dave -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ ************************************************ From: "Andy Fultz" <andynfultz(at)bellsouth.net> Subject: RE: Kitfox-List: Bunches of stuff If the Mystery Oil is causing damage to the needle tips, I can't help but wonder what it's doing to the inside of your fuel lines and or oil injection lines? Andy F. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Herbert Doud Sent: Saturday, September 15, 2007 4:59 PM To: Kitfox-List Digest Server Subject: Kitfox-List: Bunches of stuff ************************************ Subject: Kitfox-List: Re: Marvel Oil From: "dave" <dave(at)cfisher.com> Herbert , Thanks for the info. I have never needed it in over 35 years of 2 strokes. Did you know it made of Stoddard solvent, Mineral oil and Lard . ? I get 150 hours out of my 582 on BR8ES solid tips that are pre gapped .018 new. Pics here http://www.cfisher.com/152hournkg.html ________________________________________________________________________________
Date: Sep 18, 2007
Herbert I respect your opinion and your success speaks for itself. That being said what "would have " happened if you had not used it ? I can point you fora few articles http://www.math.uwaterloo.ca/~rblander/snake_oil.txt Another one that describes the ingredients http://www.ntsb.gov/ntsb/brief2.asp?ev_id 020916X01610&ntsbno=NYC02LA181&akey=1 According to the FAA inspector, the additive that was added to the fuel was Marvel Mystery Oil. An empty 1 gallon can of Marvel Mystery Oil was found in the operator's trash. Instructions found on the can stated that the correct ratio for mixing with fuel was 1 part additive to 100 parts fuel. The contents of Marvel Mystery Oil were 74 percent mineral oil, 25 percent stoddard solvent, and 1 percent lard >According to Lycoming Service Instruction No. 1014M, dated May 22, 1995, the use of fuel additives was not recommended, and voided the engine warranty. I don't think Rotax recommends it either. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135036#135036 ________________________________________________________________________________
Date: Sep 18, 2007
To be honest I was wondering what all the talk about the elevator trim was about. My model III-A seems to trim out pretty well (not quite hands off but close) without any other springs, tabs, or bungee cords. I have lots of elevator control while landing on floats. Generally I touch down just before the wing stops flying and the stick is almost all the way back. In next to calm conditions I expect the plane to be idle taxiing with in three hundred feet... It takes more space than that to get off at gross. I have a tab installed on my rudder to take the work out of keeping straight at cruise. It works like a charm. The only thing is as you take off or land you have to be on the rudder every second. I think a larger rudder would be the only change I would make. I too like to use slips and that little rudder just doesn't give me enough authority to pull a good slip with the pendulum effect of the floats. > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave > Sent: Tuesday, September 18, 2007 7:27 AM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: Trim Authority > > > Luis, > 1200 feet runway plus trees at both end ? Well should be no > problem fora Kitfox Long wing. Biggest thing is to learn the > skills and practice them to make this easy for you. I would > suggest practicing alot of slow flight at or a few mph over > stall speed until more comfortable plus with up to 20 degrees > flaps. Then Side slipping with and without flaps. > > Find a grass strip about 2000 feet long with trees near you > and try it in there then go to a 1500 foot one. Then a 1200 > foot one. You should be able to get in and out of a 1200 > foot strip pretty with no concerns after a while . Key is > slow approach in control. What speed indicated does your > plane stall at ? > > On mine I can approach at 45 to 50 mph and then sideslip down > right to the ground, then kick it straight. If you kick it > too early on a long wing you will get more float. > > As far as trim, I have none. The Kitfox controls are so > light It not a concern for me. > > > this forum has some talk on VG testing that I have done over > the last few weeks http://forums.matronics.com/viewtopic.php?t=31939 > plus more here http://www.cfisher.com/vg.html > > -------- > Rotax Dealer, Ontario Canada > Flying Videos and Kitfox Info > http://www.cfisher.com/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=135002#135002 > > > > > > > > ________________________________________________________________________________
Date: Sep 18, 2007
Ernie, We can help.. please feel free to contact us off list. Fly Safe !! John & Debra McBean 208.337.5111 www.kitfoxaircraft.com "It's not how Fast... It's how Fun!" -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Ernest and Jane Deel Sent: Monday, September 17, 2007 11:32 PM Subject: Kitfox-List: New subscriber-1st post-request for info From; Ernest Deel ernieandjane(at)naxs.net Subject; Request for info;; I am considering purchasing a KF IV Speedster (s/n JCS 137) project--no FWF except Rotax engine mount. The plane had minor wing-tip and landing gear damage from a high speed taxi incident and the engine was removed for another project. I will want to convert to a tri-gear (nose wheel) Are approved parts and plans available? >From who and where? Is this a complicated conversion? Requiring welding and reinforcement of fuselage and/or firewall? And will I need to make a decision on which engine before beginning work on the landing gear? A close-up picture or sketch showing how the nose gear brackets are attached would be helpful. Will this be considered a major airframe modification? and what kind of "paper-work" and inspections will be required? (Although I built and flew a Vari-Eze I do not have much expertise with tube and fabric or welding) An opinion (guesstimate?) on cost will also be welcome. Engines?? Possibly a Jabiru 2200? Just a couple days ago I saw from www.compactradialengines.com <http://www.compactradialengines.com> an 85hp MZ-301 with about the best power-weight-cost ratio numbers I have seen? Anybody know about or care to comment on this engine (and the company?) Any help, ideas, comments, will be welcome and greatly appreciated. Also if anyone within a100 miles or so of Grundy VA (southwestern VA) has a Kitfox (tri-gear or tail dgr) I would like a close up look at it. Thanks again! Ernie Ernest Deel Rt 1 Box 349A Vansant, VA 24656 276 859 0434 ernieandjane(at)naxs.net 11:53 AM ________________________________________________________________________________
Date: Sep 18, 2007
So much controversy ...:-) Being an individual, my experience would be limited what I can fly. When Rotax looks at reliability, their view point is from many thousands of engines over the years and who knows how many hours vs my 400 hrs. in my 582 Bluehead. There are a few Rotax flyers at my field some are very opinionated based on their experience... example...one owner says Amsol is the answer and so on. I listen and respect their opinion, its all important data. However, when Rotax recommends a certain RPM, EGT, even oil, that's my starting point. My baseline. I will stick with that until someone can prove to me beyond the Rotax experience that there is a better way. Then I would be willing to change. Just seems to me a logical way of managing risk when we attempt to break the bonds of earth! Fly safe and enjoy Dave ________________________________________________________________________________
Date: Sep 18, 2007
Thanks for the tips guys. My Kitfox came with a VG kit that the previous owner never got around to installing. I will try that first since it's something I already have. If that doesn't work, I'll look at that spring assist. No doubt that landing at my place will get easier with practice but while I'm learning, I expect that it will help to be able to trim for hands off during final. -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135056#135056 ________________________________________________________________________________
Date: Sep 18, 2007
Subject: Re: New subscriber-1st post-request for info
Ernest sez: >I will want to convert to a tri-gear (nose wheel). > >Are approved parts and plans available? From who and where? Is this >a complicated conversion? Requiring welding and reinforcement of >fuselage and/or firewall? And will I need to make a decision on >which engine before beginning work on the landing gear? I think you are on your own as far as plans go, but the process isn't rocket science. Some welding and reinforcement is required, but I don't think the engine choice matters at this point unless you plan to do something truly exotic. You'll need a mounting plate welded to the tubing just behind the firewall and you'll need to reinforce the tubing just behind the seats. On mine, we did this by welding plates between the tubes, as shown in the attached photos. The nosewheel assembly was supplied by the factory and the main gear is from Grove. Hope this is helpful, Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 18, 2007
Dave, for reference Rotax does recommend oil with a API-TC rating . Pennzoil for Air cooled is a popular choice but so is Bombardier XPS mineral oil. I buy it in bulk. XPS is popular with Ski doo sleds and SeaDoo jet skis as well. It is made by Castrol and a little bit better than Castrol Super 2 stroke but the supper 2 stroke is still a good choice. I do use the Super 2 stroke in my RV bottle just so that I can see it easier as it is blue. There is much controversy over oils whether it be synthetic or mineral oil . But the key is the API-TC rating. You see outboard oil is TCW rated like TC W3 but outboards have different operating parameters that we do. If you want to get on synthetics, my rule is if you don't run you engine a few times a week then it is more likely to have a bearing issue than a Mineral oil user. I have no problem selling Rotax cranks for $1200 to $1500 each so feel free to llet them rust. As far as additives like Marvel oil well that is a personal preference and some swear by it. I can show you my last 3 582's than went well over 300 hours with nothing but XPS oil and they ran fine. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135062#135062 ________________________________________________________________________________
Date: Sep 18, 2007
Luis, I don;t think you will find the VGs will be a better solution than perfecting your short field skills . Take a few days when calm in the AM or before dark and do at least 10 circuits each time to try to hone your skills. I have a you tube video here http://www.cfisher.com/vg.html that at the end shows side slipping down to the ground over 80 foot trees . to land short over obstacles you will need to excel at side slipping and slow flight. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135064#135064 ________________________________________________________________________________
Date: Sep 18, 2007
I agree. No substitute for practice. I do it every chance I get. On the other hand, if there's some gizmo out there that makes the airplane a little easier to handle in certain situations, then that doesn't hurt either. Trimming the airplane for neutral stick pressure during final was part of my training and makes good sense to me. I don't see any advantage in having to hold back pressure during the approach. > Luis, I don;t think you will find the VGs will be a better solution than perfecting your short field skills . Take a few days when calm in the AM or before dark and do at least 10 circuits each time to try to hone your skills. -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135067#135067 ________________________________________________________________________________
Date: Sep 18, 2007
Luis, Most of my flying is 500 agl or so and away from airports. Alot of base legs might be only at 100 agl or so so my trim is not needed as much when at 1000 agl airport circuits. But for sure practice it all.......... and especially forced approaches as one never knows when you might have to find a spot to land with little notice. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135072#135072 ________________________________________________________________________________
Subject: Re: czech floats
Date: Sep 18, 2007
is there a particular reason that you dont like the full-lotus floats? Are you by any chance using the skystar rigging? I was not real happy with the full lotus on the KF using the original skystar rigging till I changed the step position and the angle of incidence on the wing.. now it is a fun machine that will go some amazing places. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135146#135146 ________________________________________________________________________________
Date: Sep 19, 2007
What were your new figures on the step and the incidence?? Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of akflyer > Sent: Tuesday, September 18, 2007 7:51 PM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: czech floats > > > > is there a particular reason that you dont like the > full-lotus floats? Are you by any chance using the skystar > rigging? I was not real happy with the full lotus on the KF > using the original skystar rigging till I changed the step > position and the angle of incidence on the wing.. now it is a > fun machine that will go some amazing places. > > -------- > Leonard Perry > Soldotna AK > Avid "C" / Mk IV > 582 IVO IFA > Full Lotus 1260 > 95% complete > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=135146#135146 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 19, 2007
Call me a relic, but I personally can't see why anyone would take a perfectly good 'fox IV Speedster tailwheel plane and muck (sp?) it up by going to a nosewheel! I think you need to ask yourself why you want to convert....lack of tailwheel experience? Get trained. Is it because the person who caused the wing-tip and gear damage blamed it on the tailwheel? Maybe they needed training. Insurance writers don't like/understand t'wheels? Might be something to that. Tailwheels have been around since day one...well, maybe day two, but they are learnable. Take it from a 70-yr old, who learned in a tailwheel Kitfox...my own...at age 69. As to your other decision...the engine....more and more people are going to Jabiru...'nuf said. Lynn Matteson Grass Lake, Michigan Kitfox IV Speedster w/Jabiru 2200 flying w/400+ hrs On Sep 18, 2007, at 1:32 AM, Ernest and Jane Deel wrote: > From; Ernest Deel ernieandjane(at)naxs.net > Subject; Request for info;; > > I am considering purchasing a KF IV Speedster (s/n JCS 137) > project--no FWF except Rotax engine mount. The plane had minor wing- > tip and landing gear damage from a high speed taxi incident and the > engine was removed for another project. I will want to convert to a > tri-gear (nose wheel) > > Are approved parts and plans available? >From who and where? Is > this a complicated conversion? Requiring welding and reinforcement > of fuselage and/or firewall? And will I need to make a decision on > which engine before beginning work on the landing gear? A close-up > picture or sketch showing how the nose gear brackets are attached > would be helpful. Will this be considered a major airframe > modification? and what kind of "paper-work" and inspections will be > required? (Although I built and flew a Vari-Eze I do not have much > expertise with tube and fabric or welding) An opinion > (guesstimate?) on cost will also be welcome. > > Engines?? Possibly a Jabiru 2200? Just a couple days ago I saw from > www.compactradialengines.com an 85hp MZ-301 with about the best > power-weight-cost ratio numbers I have seen? Anybody know about or > care to comment on this engine (and the company?) > > Any help, ideas, comments, will be welcome and greatly appreciated. > Also if anyone within a100 miles or so of Grundy VA (southwestern > VA) has a Kitfox (tri-gear or tail dgr) I would like a close up > look at it. Thanks again! Ernie > > Ernest Deel > Rt 1 Box 349A > Vansant, VA 24656 > 276 859 0434 > ernieandjane(at)naxs.net > > > http://www.matronics.com/Navigator?Kitfox-List_- > ============================================================ _- > forums.matronics.com_- > =========================================================== ________________________________________________________________________________
Subject: Re: Broken tailwheel spring- revelation
Date: Sep 19, 2007
It might, but you've still got the tailwheel flopping around back there, possibly causing some damage. Better (in my opinion) to do something to prevent...as much as possible...the breakage in the first place. By going to the three-piece spring, you will have two main leaves, thus giving you 100% redundancy....the chances of breaking both main leaves at the same time, thus putting the t'wheel into "flop mode" are pretty slim, I would think. And if you slam it down hard enough to do that, you've got other issues to deal with other than a little rash on the rudder. Lynn Matteson Grass Lake, Michigan Kitfox IV Speedster w/Jabiru 2200 flying w/400+ hrs On Sep 17, 2007, at 4:24 PM, Mike Chaney wrote: > Would a metal tube shaped like a C attached right in front of the > tail wheel spring serve as a stop to prevent damage in the event of > a tail wheel spring break? This could resemble the skid used on > the d tail wheel planes. > > Mike Chaney > > Lynn Matteson wrote: > > Not so fast there, Michel...when I broke my 2-leaf (main and helper/ > booster/whatever) I still got a bit of rash on my rudder because the > tailwheel flopped around a bit and the rear of the plane dropped down > to be SUPPORTED by the helper leaf (as it dragged along in the dirt), > but the tailwheel could STILL cause you damage because it is no > longer held in position by anything. You could still break your main > leaf and cause damage to the plane without the rudder actually > hitting the ground. With the new three-leaf spring, there are two > main leafs that have to break before the above scenario would happen. > My 2-leaf spring broke at about the 450 or so landings mark, and > based on metallurgy, your new one may go before or after that. I had > 43 pounds on my tail during weighing. I bought the 3-leaf model > because it is a safety feature, not because I needed a stiffer spring. > Taking this whole safety/stiffness thing a bit further, one might > conclude that if a spring were to be made of 1/8" (3mm) leaves, one > could use maybe four leaves that are all held by the current two > bolts, that maybe a softer ride would result, and the safety margin > would be much greater. > > > Lynn Matteson ________________________________________________________________________________
Date: Sep 19, 2007
Luis sez: >Trimming the airplane for neutral stick pressure during final was >part of my training and makes good sense to me. It's an FAA requirement that certified airplanes be capable of being trimmed for their approach speed. That doesn't apply to experimentals, of course, but I like it. Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 19, 2007
Lynn sez: >...I personally can't see why anyone would take a perfectly good >'fox IV Speedster tailwheel plane and muck (sp?) it up by going to a >nosewheel! Let's not start the "why the heck would you want to do that?" stuff again. The guy asked for advice on how to do something, not for a bunch of editorials on something that is, after all, a personal decision. Mike G., Kitfox List Co-Moderator N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 19, 2007
You're right...I apologize...it was late at night and I should have been sleeping... Lynn On Sep 19, 2007, at 3:41 AM, Michael Gibbs wrote: > > > Lynn sez: > >> ...I personally can't see why anyone would take a perfectly good >> 'fox IV Speedster tailwheel plane and muck (sp?) it up by going to >> a nosewheel! > > Let's not start the "why the heck would you want to do that?" stuff > again. The guy asked for advice on how to do something, not for a > bunch of editorials on something that is, after all, a personal > decision. > > Mike G., Kitfox List Co-Moderator > N728KF > Phoenix, AZ > > ________________________________________________________________________________
Date: Sep 19, 2007
Hi all - Been away doing the work, kids, and rest of life for the summer and saw this so thought I'd throw in my 2-cents. Trying to land in treetops has been done, but it has become a myth and is far more hazardous than controlling your impact. Go into the NTSB records (www.ntsb.gov) and it's easy to find records like these: "The airplane dipped to the left, struck the trees and fell to the ground." or "the plane hit the tree tops and tumbled through the trees" or a survivable one in a 172: "The airplane clipped the tops of the trees, then plunged down nose-first. Both wings were bent by the impact." There are two reasons that the odds are against a successful tree-top landing. The first is that after the first contact, you have absolutely no control of what's next. One of those long wings is going to hit a tree first (or the gear will) and things are going to pivot on that point. And that first impact will be the fastest one. I'd rather control where the impact with the most energy is going to happen. One of the things instructors teach is that when performing a forced landing in a short field, landing short or hitting trees at the near end with more speed is going to do a lot more damage than controlling where you roll into them while slower at the far end. The second reason that tree-top landings don't generally work out well is that gravity still rules. For every photo that you've probably seen of a plane in the trees, I'll bet you can think of two where the airplane is nose down at the base of some trees. If you don't truly snag enough tree branches to keep you up, the airplane is going to fall. With the engine up front and that tail snagging branches at the back, the nose is going to go straight down. Here's where you need to think of survivability. Would you be willing to hang your plane by the tail at the height of whatever tree, strap in, and then cut the strap? That's about what happens in these situations and there just isn't that much crushable material in front of you to break your fall. There is an upside in that the statitstics show that the Kitfox and Avid series have an amazingly good survivability rate and it's largely due to the slow stall speeds. The overall accident rate for experimentals is much higher than the certified airplanes, largely due to fuel and other systems installations. However, the 'Foxes and Avids land slow (less energy to dissipate) and deform structure in a way that absorbs energy around the central cockpit area, as long as it's not a full frontal impact. Keeping from having a full frontal impact is something that you can control. Bob A&P, Aero Eng Vixen (part-built) Damascus, MD -------- Remember that internet advice may only be worth what you pay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135234#135234 ________________________________________________________________________________
Date: Sep 19, 2007
one more attribute on the Vg's that I failed to mention originally was a greater AOA on climb out was evident. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135246#135246 ________________________________________________________________________________
Date: Sep 19, 2007
My feeling is you are better to be able to be in control into the trees than falling into them. If you have airspeed then you have better control than you will when you run out of airspeed. I had a friend over 20 years ago faced this scenario while flying his Apache and losing one engine. With out being able to maintain altitude on single engine operations his Apache went into 130 foot tall trees . After it slowed , what was left of the fuselage and the 4 occupants suffered only minor injuries until gravity took over and they basically free fell over 100 feet to rock. They all suffered severe back injuries from that alone. I have been PIC in 4 engine outs so far since I learned to fly nearly 30 years ago , one I landed at an airport the other 3 were all forced approaches off airport. Fortunately, none of the occupants ever had injuries nor did the aircraft. I feel lucky and also think that the training and practice I have had contributed to my luck. that being said i could have another forced approach today or tomorrow and if so I hope to handle as best as possible. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135249#135249 ________________________________________________________________________________
Date: Sep 19, 2007
Mike G, The main gear bracket you show does not look stock, who cut that out for you? We need something like that for our model 1. John Oakley -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Michael Gibbs Sent: Tuesday, September 18, 2007 9:58 AM Subject: Kitfox-List: Re: New subscriber-1st post-request for info Ernest sez: >I will want to convert to a tri-gear (nose wheel). > >Are approved parts and plans available? From who and where? Is this >a complicated conversion? Requiring welding and reinforcement of >fuselage and/or firewall? And will I need to make a decision on >which engine before beginning work on the landing gear? I think you are on your own as far as plans go, but the process isn't rocket science. Some welding and reinforcement is required, but I don't think the engine choice matters at this point unless you plan to do something truly exotic. You'll need a mounting plate welded to the tubing just behind the firewall and you'll need to reinforce the tubing just behind the seats. On mine, we did this by welding plates between the tubes, as shown in the attached photos. The nosewheel assembly was supplied by the factory and the main gear is from Grove. Hope this is helpful, Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 19, 2007
> Will this be considered a major airframe modification? and what kind of "paper-work" and inspections will be required? Ernie, If this airplane already has an experimental airworthyness certificate the answer is in the operating limitations issued with it. Some say you need to notify the FSDO in writing about the modification. Some say just put it back into Phase one (test phase) for five hours, I think, and make a log book entry. It seems like every FSDO interprets the regulations differently so a call to your FSDO will probably be needed to be sure. -------- Tom Jones Classic IV, Phase one 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135280#135280 ________________________________________________________________________________
Date: Sep 18, 2007
At 10:32 PM 9/17/2007, you wrote: >Engines?? Possibly a Jabiru 2200? Just a couple days ago I saw from ><http://www.compactradialengines.com>www.compactradialengines.com an >85hp MZ-301 with about the best power-weight-cost ratio numbers I >have seen? Anybody know about or care to comment on this engine (and >the company?) Welcome Ernie! It sounds like a fun project on your hands. I had never seen the engines you referenced so I'm glad you showed them. They look great, but of course are two-stroke, with all the attendant problems, which are: 1. Mixing fuel. Two strokes require oil in their fuel. Rotax uses a convenient oil pump to inject oil into the intake manifolds precluding pre-mix. If these don't have oil injection you'll have to pre-mix. It's not a big deal at home, but I suspect it would be a real pain on the road. (I do a fair amount of long cross countries and it's still a pain for me as I have to carry up to 20 pints, (almost 20 pounds,) of oil with me for a week of flying.) 2. Fuel use. Two strokes are notorious gas hogs. You'll want to check on that for these engines. 3. Noise. Two strokes are notoriously noisy, with a high pitched whine that can be annoying. I sound disparaging, but please note that I'm running a Rotax 582 and have been quite happy with it. I can't help you with the trike conversion but there are plenty that have done it. If you don't get a response here email me privately and I'll try to hook you up with a couple. Guy Buchanan San Diego, CA K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Subject: New float flying vid
Date: Sep 19, 2007
I made a quick vid of a little hunt we were on last week. The camera man cant quit talking but once you get past that it is ok lol.. A little history, I put my floats on my brothers kitfox, as I have been having too much fun flying his plane since he got it up here to even think about working on mine. I was not happy with the performance as I knew it could do better. I have moved the step location 3 times and changed the angle of incidence 3 times also. In this video I had a bit too much angle of incidence on it. You could get it off the water quick, but it had so much drag it slowed me down 8 knots. I added a 3/4" shim to the rear float mount and now have it nailed. The cruise is still good 70 knots at 5800, and takeoff is great with no tendency to porpoise. At about 6:00 minutes into the vid you can see the slew I was taking off of in the first part of the vid, and at 6:10 you can see the little pond. The rest of the vid is just a small part of the flats we hunt. The ducks and geese are really starting to move through and KF makes it a breeze to hunt the area. http://www.youtube.com/watch?v=EKyg7uUV8js -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135331#135331 ________________________________________________________________________________
Date: Sep 19, 2007
Leonard, Was that video shot in the Susitna River flats? John Hart -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of akflyer Sent: Wednesday, September 19, 2007 2:43 PM Subject: Spam: Kitfox-List: New float flying vid I made a quick vid of a little hunt we were on last week. The camera man cant quit talking but once you get past that it is ok lol.. A little history, I put my floats on my brothers kitfox, as I have been having too much fun flying his plane since he got it up here to even think about working on mine. I was not happy with the performance as I knew it could do better. I have moved the step location 3 times and changed the angle of incidence 3 times also. In this video I had a bit too much angle of incidence on it. You could get it off the water quick, but it had so much drag it slowed me down 8 knots. I added a 3/4" shim to the rear float mount and now have it nailed. The cruise is still good 70 knots at 5800, and takeoff is great with no tendency to porpoise. At about 6:00 minutes into the vid you can see the slew I was taking off of in the first part of the vid, and at 6:10 you can see the little pond. The rest of the vid is just a small part of the flats we hunt. The ducks and geese are really starting to move through and KF makes it a breeze to hunt the area. http://www.youtube.com/watch?v=EKyg7uUV8js -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135331#135331 ________________________________________________________________________________
Subject: Re: Spam: New float flying vid
Date: Sep 19, 2007
south of the Kustatan... -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135344#135344 ________________________________________________________________________________
Date: Sep 19, 2007
OK, I know generally where you were. I used to do some of the same stuff in a C-185 on amphibs on the Susitna flats. The areas are very similar in appearance. The video gave a good example of what a Kitfox is capapble of. John Hart -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of akflyer Sent: Wednesday, September 19, 2007 3:52 PM Subject: Spam: Kitfox-List: Re: Spam: New float flying vid south of the Kustatan... -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135344#135344 ________________________________________________________________________________
Date: Sep 19, 2007
Subject: Re: New float flying vid
wow!!! lenny. that was just too much fun..... tnx so much for sharing that with us. i'm john bowman down here in sout la (prairieville) still trying to get my avid hh covered. that fox-- what engine again?? i've got that d ecision to make & the huge $$ to come up with..... between the jab & the ro tax 9's....also looking at a new belgium engine, close to 100 hp, electroni c ignitiion, but no usage data yet available & it's very expensive (more th an the rotax 80 912) but apparently extremely well engineered. i'll send we b site if u'r interested. tnx again. & take care. looks like home except for the snow & ice that's coming or is it? will global warming turn it int o new iberia afore long? are u all up there working in the way cool oil pat ch? or did u just take a wrong turn. also, now soldatna sounds like the li ttle place where we took a bush plane ride (old 180 on wheels) up to the bi g mtn & then down on the grass tops looking for bear etc.... have names of the pilot & his lady who rode with us if it's the same place - u must know them if they're still around. my fantasy is to bring my avid bac k up there flyin & riding in a trlr & air tour some of the places we visite d a couple of yrs back. u be careful now!! u make the lotus float ads come alive. i hope they appreciate u!!! john b.=0A=0A=0A----- Original Message ----=0AFrom: akflyer <akflyer_2000(at)yahoo.com>=0ATo: kitfox-list(at)matronics. com=0ASent: Wednesday, September 19, 2007 2:42:41 PM=0ASubject: Kitfox-List =0A=0AI made a quick vid of a little hunt we were on last week. The camera man cant quit talking but once you get past that it is ok lol..=0A=0AA little history, I put my floats on my brothers kitfox , as I have been having too much fun flying his plane since he got it up he re to even think about working on mine. I was not happy with the performan ce as I knew it could do better. I have moved the step location 3 times an d changed the angle of incidence 3 times also. In this video I had a bit t oo much angle of incidence on it. You could get it off the water quick, bu t it had so much drag it slowed me down 8 knots. I added a 3/4" shim to th e rear float mount and now have it nailed. The cruise is still good 70 kno ts at 5800, and takeoff is great with no tendency to porpoise.=0A=0AAt abou t 6:00 minutes into the vid you can see the slew I was taking off of in the first part of the vid, and at 6:10 you can see the little pond. The rest of the vid is just a small part of the flats we hunt. The ducks and geese are really starting to move through and KF makes it a breeze to hunt the ar ea.=0A=0Ahttp://www.youtube.com/watch?v=EKyg7uUV8js=0A=0A--------=0ALeona rd Perry=0ASoldotna AK=0AAvid "C" / Mk IV =0A582 IVO IFA=0AFull L otus 1260=0A95% complete=0A=0A=0A=0A=0ARead this topic online here:=0A=0Aht tp://forums.matronics.com/viewtopic.php?p=135331#135331=0A=0A=0A=0A=0A=0A ===0A=0A=0A =0A__________________________________________________ __________________________________=0APinpoint customers who are looking for what you sell. =0Ahttp://searchmarketing.yahoo.com/ ________________________________________________________________________________
Date: Sep 19, 2007
he has a 582 in it with IVO IFA 68" 3 blade. I am ordering a set of 72" 2 blade to see if I can get just a bit more thrust out of it. I know that on my pacer I went from a 76X58 cruise prop to a 81X42 climb prop and holy cow did it make a difference in getting off the water..went from a 1500'+ take off run to around 350' only lost 15 knots of cruise -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135389#135389 ________________________________________________________________________________
Date: Sep 19, 2007
Nice video there. What ratio you got 2.58 ? I tried 2.62 on E box this year but lost take off and cruise speed over the 3.00 to 1 gear. I have a 72 " IVO medium 2 blade on now and it really not alot different than my WARP 68" three blade. You won't see a Jabiru on floats perform like that. 912 yes but not a jab or VW unless geared with a bigger prop. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135400#135400 ________________________________________________________________________________
Subject: full Lotus
Date: Sep 19, 2007
I made a comment the other day about my floats. I have no issue with the floats as to performance. I am off the water in flat calm in 8 secs and cruise a 80mph. I live on Kootenay lake in BC and am exposed to the wind. Have an airstrip three miles away where I keep the plane on a trailer. Takes one hour to put it in the water and the same to take it out. Thus the need for amphibs. I have three planes, two on floats and fly vertually every day. Don ________________________________________________________________________________
Date: Sep 19, 2007
2.62 How can it loose performance? You should be spinning the prop a bit faster. Most guys that tried 3:1 said they went back to 2.62... I cant say as I have never tried the 3:1. Were you swinging a longer prop at 3:1? I would really be interested in getting a bit more thrust for mine for taking off the grass or coming up on step when at "gross" or a tad over.. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135421#135421 ________________________________________________________________________________
From: "JC Propellerdesign" <propellerdesign(at)tele2.se>
Date: Sep 20, 2007
Why not a BMW 1100 S, 85-90 HP low fuel consumption. lot cheaper then the other. Jan ----- Original Message ----- From: john taylor To: kitfox-list(at)matronics.com Sent: Thursday, September 20, 2007 2:01 AM Subject: Re: Kitfox-List: New float flying vid wow!!! lenny. that was just too much fun..... tnx so much for sharing that with us. i'm john bowman down here in sout la (prairieville) still trying to get my avid hh covered. that fox-- what engine again?? i've got that decision to make & the huge $$ to come up with..... between the jab & the rotax 9's....also looking at a new belgium engine, close to 100 hp, electronic ignitiion, but no usage data yet available & it's very expensive (more than the rotax 80 912) but apparently extremely well engineered. i'll send web site if u'r interested. tnx again. & take care. looks like home except for the snow & ice that's coming or is it? will global warming turn it into new iberia afore long? are u all up there working in the way cool oil patch? or did u just take a wrong turn. also, now soldatna sounds like the little place where we took a bush plane ride (old 180 on wheels) up to the big mtn & then down on the grass tops looking for bear etc.... have names of the pilot & his lady who rode with us if it's the same place - u must know them if they're still around. my fantasy is to bring my avid back up there flyin & riding in a trlr & air tour some of the places we visited a couple of yrs back. u be careful now!! u make the lotus float ads come alive. i hope they appreciate u!!! john b. ----- Original Message ---- From: akflyer <akflyer_2000(at)yahoo.com> To: kitfox-list(at)matronics.com Sent: Wednesday, September 19, 2007 2:42:41 PM Subject: Kitfox-List: New float flying vid I made a quick vid of a little hunt we were on last week. The camera man cant quit talking but once you get past that it is ok lol.. A little history, I put my floats on my brothers kitfox, as I have been having too much fun flying his plane since he got it up here to even think about working on mine. I was not happy with the performance as I knew it could do better. I have moved the step location 3 times and changed the angle of incidence 3 times also. In this video I had a bit too much angle of incidence on it. You could get it off the water quick, but it had so much drag it slowed me down 8 knots. I added a 3/4" shim to the rear float mount and now have it nailed. The cruise is still good 70 knots at 5800, and takeoff is great with no tendency to porpoise. At about 6:00 minutes into the vid you can see the slew I was taking off of in the first part of the vid, and at 6:10 you can see the little pond. The rest of the vid is just a small part of the flats we hunt. The ducks and geese are really starting to move through and KF makes it a breeze to hunt the area. http://www.youtube.com/watch?v=EKyg7uUV8js -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics - The Kitfox-List Email Forum avigator?Kitfox-List" target=_blank>http://www.matronics.com/Navigator?Kisp; - NEW ===== ------------------------------------------------------------------------- ----- Takvt=48253/*http://mobile.yahoo.com/go?refer=1GNXIC">Internet in your pocket: mail, news, photos & more. ________________________________________________________________________________
Date: Sep 20, 2007
John asks: >The main gear bracket you show does not look stock, who cut that out >for you? We need something like that for our model 1. I'm pretty sure that is stock Grove mounting hardware, John. Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 20, 2007
I tried 4 different props and re-pitched each accordingly with the 2.62 gear. On amphibs on grass take off went from 350 to 450 feet. Cruise speed dropped about 5-6 mph and climb I lost about 200 fpm. I flew for about 10 hours with that gear set and quickly changed back to the 3 to 1 gears. I would like to try 3.5:1 gears as well. I did think the faster spinning prop would have cost me some take off but I also thought that it would give me extra cruise. It was louder as well with the prop spinning about 300 rpm faster as well but no where near the tip speed of lycoming or the noise. What Box do you have ? You can likely pick up a used box to try cheaper than new gears to try. If you no like just peddle on Ebay. Cruise speed on amphibs with 3 to 1 is 85 mph and was barely 80 with mph with 2.62s on a good day. Slower turning prop has worked better for me and I guess it does give more torque to the prop for take off and at the speeds we fly at. I should try them again on wheels and see what happens. > 2.62 How can it loose performance? You should be spinning the prop a bit faster. Most guys that tried 3:1 said they went back to 2.62... I cant say as I have never tried the 3:1. Were you swinging a longer prop at 3:1? > -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135441#135441 ________________________________________________________________________________
Date: Sep 20, 2007
With the IFA I set it at minimum pitch (high pitch blades) that gives me about 6150 to 6250 on the take off run, as soon as I break water and pick the nose up it jumps to 6400 so I start adding pitch to keep RPM and EGT under control. In cruise I set power and prop to give me 5800 and 1100 EGT. This works out to a fuel burn of about 5 gallons and hour and 70 knots GS depending on wind. I have heard arguments that the 3 blade WARP pulls harder than the IVO If the 72" is comparable or slightly better than the WARP I would really like to try it out. I cant justify the money at this time for a 912, but damn... I sure would like to fly one on floats to see what the extra power would do, I am betting that the extra 20 ponies would make one hellofa bird out of this.. As it is with the 582, full fuel, gear (decoys guns etc) and just me it is one heck of a plane, but add another 200# passenger and she is lacking on the water. I normally have to make a gear run solo, then come back and pick up the passenger. this is to be expected as I am asking a bit more than she was designed to do...... Once in the air it is fine, but getting from water to air takes a bit of room. All in all, I am not sure one can ask for a better plane for the money spent ( you could ask but would be stupid for doing so), and for dang sure you cant have more fun than this and keep your clothes on! -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135516#135516 ________________________________________________________________________________
Subject: Re: OT New float flying vid
Date: Sep 20, 2007
hmm... a tad... that would be just enough to give me unlimited vertical and the ability to hover and torque roll my Avid the same way I can with my 33% Extra 330.. Really, I would think that another 10-15 HP would do it, but I don't like the idea of paying that much for a 912... I can have two avids or KF's in the air with 582's for the price of one 912 alone if I get a basket case as I have done and re-build it.. I would not think of taking conventional floats the places I go with the Full lotus...one stick or rock and you are done with conventionals... -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135554#135554 ________________________________________________________________________________
Date: Sep 20, 2007
My Aerocet conventional composite floats are a bit lighter than the Full Lotus but as you say they are not good for the real shoal water. Most of our bog holes are around two or three feet deep and true bogs don't have any wood in it. I expect the most dangerous place to land on floats is any area that has been flooded within the last fifty years... No one really knows the depth of the water or what's under the surface! I just got a used 912 that is reported to have only 175 hr on it. Of course I have to get the engine mount from John Mc and no doubt there will be mods to the cowlings and new controls. I have planned to move the header tank back behind the seat and the battery there too. The space behind the panel the small header tank now occupies is where I'll mount the oil reservoir. Because I'll be using a factory built mount, Transport Canada (TC) is going to allow me to do an amendment to my W&B and a three minute climb test that I must be able to make something like 600'... The 582 with the old tach which read 20% too high and time-exed prop could still beat that climb. After that I'll be "tethered" to a 25KT distance for 25 hr. Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of akflyer > Sent: Thursday, September 20, 2007 7:38 PM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: OT New float flying vid > > > > hmm... a tad... that would be just enough to give me > unlimited vertical and the ability to hover and torque roll > my Avid the same way I can with my 33% Extra 330.. > > Really, I would think that another 10-15 HP would do it, but > I don't like the idea of paying that much for a 912... I can > have two avids or KF's in the air with 582's for the price of > one 912 alone if I get a basket case as I have done and re-build it.. > > I would not think of taking conventional floats the places I > go with the Full lotus...one stick or rock and you are done > with conventionals... > > -------- > Leonard Perry > Soldotna AK > Avid "C" / Mk IV > 582 IVO IFA > Full Lotus 1260 > 95% complete > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=135554#135554 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 20, 2007
Leonard, A light Kitfox (or Avid) with even an 80 hp 912 on a set of non-amphib full lotus floats would be an awesome airplane. I've flown a 582 Model IV on 1260 Lotus floats, and my IV-1200 on Aerocet amphibs so I know what you could expect. While the 582 airplane is a fun, good performing airplane (the one I flew had a warp 3 blade, but performance was as you pretty much describe yours, maybe slightly less as no IFA on the warp), the 912 with a IVO IFA will give you supercub or better performance loaded or not (assuming you keep that IVO IFA on it - it definitely helps get off the water). Mine is a HEAVY (776 pounds on the floats) model IV amphib, but yet will get off the water at 1200 pounds (2 people, 3 hrs fuel, and light on gear) in about 13-14 seconds on a 85 degree day, 5 mph wind, at 1200 msl. And it will easily cruise at 100+ mph. Tops out at 124 mph. I do think the lotus floats would slow it down a bit (10 mph would be my guess), but being non-amphib and obviously much lighter, would be a rocketship off the water. I like the Lotus floats for the same reasons you do, the ability to bump into things without much concern. My dislikes are rough water capability, step turning capability, general handling issues compared to a hard float, Utraviolet damage issues, air pressue monitoring, and no storage compartments. But they do work on our little planes. Here are a few pics showing what my Fox does (I can't download or upload video on my chipmunk powered internet dial up service, so this is the best I can do...) I wish I could as your video sounds cool! Paul Seehafer Kitfox IV 912ul Amphib ----- Original Message ----- From: "akflyer" <akflyer_2000(at)yahoo.com> Sent: Thursday, September 20, 2007 2:28 PM Subject: Kitfox-List: Re: New float flying vid > > With the IFA I set it at minimum pitch (high pitch blades) that gives me > about 6150 to 6250 on the take off run, as soon as I break water and pick > the nose up it jumps to 6400 so I start adding pitch to keep RPM and EGT > under control. In cruise I set power and prop to give me 5800 and 1100 > EGT. This works out to a fuel burn of about 5 gallons and hour and 70 > knots GS depending on wind. > > I have heard arguments that the 3 blade WARP pulls harder than the IVO If > the 72" is comparable or slightly better than the WARP I would really like > to try it out. I cant justify the money at this time for a 912, but > damn... I sure would like to fly one on floats to see what the extra power > would do, I am betting that the extra 20 ponies would make one hellofa > bird out of this.. > > As it is with the 582, full fuel, gear (decoys guns etc) and just me it is > one heck of a plane, but add another 200# passenger and she is lacking on > the water. I normally have to make a gear run solo, then come back and > pick up the passenger. this is to be expected as I am asking a bit more > than she was designed to do...... Once in the air it is fine, but getting > from water to air takes a bit of room. > > All in all, I am not sure one can ask for a better plane for the money > spent ( you could ask but would be stupid for doing so), and for dang sure > you cant have more fun than this and keep your clothes on! > > -------- > Leonard Perry > Soldotna AK > Avid "C" / Mk IV > 582 IVO IFA > Full Lotus 1260 > 95% complete > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=135516#135516 > > > ________________________________________________________________________________
Subject: Kitfox Flight Sim
Date: Sep 21, 2007
Occasionally I do a bit of flying the kitfox on Flight Sim I have a model IV that I've adjusted to fly like a 582 with the right sounds too and of course changed the colour schemes to match my own plane. The only problem is my plane is on floats and I haven's seen anything like the Kitfox on floats. Has any one written one?? I have tried to convert a Super Cub to a Kitfox but can't get the ailerons right. Noel ________________________________________________________________________________
Subject: Re: Landing in Treetops
Date: Sep 20, 2007
The alternative is the one left unspoken, and that is to leave yourself an "out." The fun of flying Kitfoxes is flying low for a lot of people. Unfortunately, they are combining that with home-spun fuel and electrical systems. If you're going to fly low enough to limit your choices, accept the potential consequences. For most cases, the "out" is simply to have enough altitude to have a choice of where you're going to have a forced landing. Think of how far you can glide with an additional thousand feet of altitude. Or, if need be, with 2000 or even 5000 feet. It's like buying insurance in that it gives you gliding distance and the probability of SOME field increases by calculating the difference between the radius (your range) and the area of a circle (available landing sites). Bob -------- Remember that internet advice may only be worth what you pay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135601#135601 ________________________________________________________________________________
Subject: Re: Kitfox Flight Sim
Date: Sep 20, 2007
what flight sim? any chance of getting a copy of the plane files? I like to play on the sim while I am at work for 2 weeks and would like to get your plane. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135603#135603 ________________________________________________________________________________
Subject: czech floats
Date: Sep 21, 2007
I did not see any responses to the question on the Czech Floats. While we are on the Float topic (and by the way great video!) lets chat about these Czech floats if anyone has an opinion. gc _____ From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Don & Dianne Usher Sent: Tuesday, September 18, 2007 7:40 AM Subject: Kitfox-List: czech floats I have a model 111, 582, on Full Lotus floats. Plane empty on wheels weighs 496 lbs, I weigh 150. Not really happy with Full Lotus and have to have amphibs. Looking to buy Czech amphibs. Anybody with this combination? and if so, how is water performance with two people. Thanks. Don "http://www.matronics.com/Navigator?Kitfox-List"http://www.matronics.com/Nav igator?Kitfox-List 1:29 PM 12:07 PM ________________________________________________________________________________
Date: Sep 21, 2007
I really have no information to add to the float debate since I have such limited knowledge of the diffrent brands and styles of floats. My experience consists of about 10 hours in a supercub on EDO 2000's and have not landed mine in the water yet (maybe this weekend). I'll keep the list posted as to the performance of the Czech floats. Kevin Cozik Series 6 914 turbo On Fri Sep 21 10:26 , 'Gregory Cronin' <greg@case-assembly.com> sent: > > >I did not see any responses to the question on the Czech >Floats. > >While we are on the Float topic (and by the way great >video!) lets chat about these Czech floats if anyone has an >opinion. > >gc > > >From: owner-kitfox-list-server(at)matronics.com >[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Don & >Dianne Usher >Sent: Tuesday, September 18, 2007 7:40 AM >To: >kitfox-list(at)matronics.com >Subject: Kitfox-List: czech >floats > > >I have a model 111, 582, on Full Lotus floats. >Plane empty on wheels weighs 496 lbs, I weigh 150. Not really happy with Full >Lotus and have to have amphibs. Looking to buy Czech amphibs. Anybody with this >combination? and if so, how is water performance with two people. >Thanks. >Don > >href="http://www.matronics.com/Navigator?Kitfox- List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com > >size=2>Version: 7.5.487 / > > >9/20/2007 12:07 PM > > > > ________________________________________________________________________________
Date: Sep 21, 2007
some Kitfox Videos here http://www.youtube.com/profile?user=kitfoxflyer floats , skis and water. gotta be a few thousand Kitfoxes flying and only 22 vidoes from me plus a few others on you tube. -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135659#135659 ________________________________________________________________________________
Date: Sep 21, 2007
if you want a DVD PM me your addy..I have lots of real nice Alaska scenery and flying, it would be nothing to burn to DVD.. AS much as I hate the thought of spending the money on it.. I may have to seriously look for a 912.. good deal on 3 of them on Ebay right now.. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135661#135661 ________________________________________________________________________________
Date: Sep 21, 2007
akflyer wrote: > what flight sim? any chance of getting a copy of the plane files? I like to play on the sim while I am at work for 2 weeks and would like to get your plane. I'd like that too. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135667#135667 ________________________________________________________________________________
Subject: Re Kitfox-List:: South East Kitfox Owners
Date: Sep 21, 2007
There is a fly-in to Triple Tree airport SC00 next weekend. I hope to go up Friday afternoon and camp under the wing. Any one local going? -----Original Message----- From: Napier, Mark Sent: Friday, August 31, 2007 10:35 AM Subject: RE: Re Kitfox-List:: South East Kitfox Owners Hey Luis, 34A would make a nice Saturday there and back trip. I don't think I could reasonably x-country to FFA from Atlanta with a 582, but I could trailer it. I'm from Greenville, NC, and have wanted an excuse to haul my plane up there and fly around the home patch. There are a couple of grass strips in the area where I might be able to trailer into. A beach landing would be the excuse I need to put on those KingFox tires. Hey Ken, How do you get from EWN to FFA? The area is sewn up with Restricted airspaces. Flying up the coast from Wilmington looks fun but there's R-5306D with no way to go around it. Looking it up on sua.faa.gov says it operates 24/7 from the surface up. But I do see a private airport on a golf course in that space so there must be some method of flying through. Do you know the procedure? Cheers, Mark Napier Subject: Re Kitfox-List:: South East Kitfox Owners From: "wingnut" <wingnut(at)spamarrest.com> Kem Dunnebacke wrote: > Morning, i read that there is interest in a Kitty Hawk fly in? I am Based at Bayboro NC and know there area it is in route for Kitty Hawk. 10 mls west is EWN, class D, fuel, car,logging........LETS GO its a ocean flight with many wonderful views, OBX is on the way with a phone call we get also get fuel.a great place for brunch! i can have local EAA help if needed, i would be glad to help organize incoming pilots. info:252-638-5828 h 252-229-8200 cell > Kem Dunnebacke N3163K kitfoxivplay(at)gmail.com Whoohoo! Lots of great suggestions. No matter what happens, it's already raised my spirits just to have this many people respond. So far, I count seven interested pilots and almost as many suggested destinations :-). They all sound interesting but Kitty Hawk is one that really stands out for me. The thought of a flock of Kitfoxes gathering at the birthplace of aviation gets my heart pumping. What do you say guys? Shall we make it Kitty Hawk? -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131791#131791 - - - - - Appended by Scientific Atlanta, a Cisco company - - - - - This e-mail and any attachments may contain information which is confidential, proprietary, privileged or otherwise protected by law. The information is solely intended for the named addressee (or a person responsible for delivering it to the addressee). If you are not the intended recipient of this message, you are not authorized to read, print, retain, copy or disseminate this message or any part of it. If you have received this e-mail in error, please notify the sender immediately by return e-mail and delete it from your computer. ________________________________________________________________________________
Date: Sep 21, 2007
Oh ya me too. But someone would have to really spell it out step by step how to do that. I sure don't have a clue of how to alter a cub to a kitfox or to build a virtual plane for SimX. I kind of knew it was possible but it sure would be cool to have some guide to make a 1,2,3,4,5,6,or7 on the program. I'd even buy a new computer that might handle it. If someone could make a download I'd sure buy it. Make my lay-over weekends on the road go a lot quicker! :D -------- Scott Denniston K-7/ no power yet 65% or so complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135701#135701 ________________________________________________________________________________
From: =?iso-8859-1?Q?Geir_Olav_=D8ien?= <geir_olav(at)c2i.net>
Subject: 3 leaf tail spring. Bolt size
Date: Sep 22, 2007
I am replacing the single leaf tail spring with a 3 leaf. But I do not know the size of the bolt that is installed. (then I need a =BD=94 longer bolt ) now. Think it is a 5/16=94 bolt, but cant remember. Anybody that know the original size of the bolt on my Kitfox 4. (of course I can go over to the airport, dismantle and find out, but if one of you know the length and size, I would be thankful). Will just replace the spring BEFORE it breaks. Thanks Geir Olav =D8ien Kitfox 4 Jabiru 2200. ________________________________________________________________________________
Subject: East Coast Kitfox Gathering!
Date: Sep 22, 2007
Just a reminder to all you Kitfoxers, the first East Coast Kitfox Gathering is scheduled for October 13th & 14th! day one will be at First Flight and day two at Campbell Airfield in Va. Just wanted to send another reminder. Hope all can attend. Ray _________________________________________________________________ Its the Windows Live Hotmail you love on your phone! http://www.microsoft.com/windowsmobile/mobilehotmail/default.mspx?WT.mc_ID=MobileHMTagline2 ________________________________________________________________________________
Date: Sep 22, 2007
Subject: Re: East Coast Kitfox Gathering!
I live just cross the Carolina Virginia State line but I don't know where Campbell Airfield is. Can some one tell me? GLENN HORNE Kitfox Model II Subject: Kitfox-List: East Coast Kitfox Gathering! > > Just a reminder to all you Kitfoxers, the first East Coast Kitfox > Gathering is scheduled for October 13th & 14th! day one will be at First > Flight and day two at Campbell Airfield in Va. > > > Just wanted to send another reminder. Hope all can attend. > > Ray > > _________________________________________________________________ > It's the Windows LiveT Hotmail you love - on your phone! > http://www.microsoft.com/windowsmobile/mobilehotmail/default.mspx?WT.mc_ID=MobileHMTagline2 > > > ________________________________________________________________________________
Subject: Re: 3 leaf tail spring. Bolt size
Date: Sep 22, 2007
> I am replacing the single leaf tail spring with a 3 leaf. But I do not know the size of the bolt that is installed. (then I need a longer bolt ) now. Think it is a 5/16 bolt, but cant remember. Anybody that know the original size of the bolt on my Kitfox 4. Grir, I have a Classic 4 with one main leaf and one helper leaf. My fuselage bolt goes through 2 spring leaves. It is a AN5-20 (5/16 X 2 inch). The rear bolt goes through one leaf and the Mall tail wheel bracket, it is a AN7-10A (7/16 X 1 inch). The two smaller bolts that secure the tail spring clamp catch 2 leaves. They are AN3-10A (3/16 X 1 inch). If you are installing 2 main leaves plus a helper leaf you probably should add 2 (1/4 inch) to each of the above AN dash numbers. Now, did I help or confuse you? -------- Tom Jones Classic IV, Phase one 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135828#135828 ________________________________________________________________________________
Date: Sep 22, 2007
Follow the this link to see the Campbell airfield on the Washington DC chart: http://skyvector.com/#25-23-3-2715-2468 I was also hoping to get a group picture at the Wright Monument at 3pm. I'm entertaining taking the group picture and making a few coffee mugs as a souvenir for everyone who comes. Maybe a picture of your Kitfox on the other side? > I live just cross the Carolina Virginia State line but I don't > know where Campbell Airfield is. Can some one tell me? -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135831#135831 ________________________________________________________________________________
Date: Sep 23, 2007
On Sep 23, 2007, at 4:12 AM, Tom Jones wrote: > If you are installing 2 main leaves plus a helper leaf you probably > should add 2 (1/4 inch) to each of the above AN dash numbers. Yes, you will have to do that, Geir. And the bad news is: the main bolt is - as I understand it - glued inside the fuselage and you will need to heat it for removal. Med vennlig hilsen, Michel Verheughe Norway Kitfox 3 - Jabiru 2200 ________________________________________________________________________________
Date: Sep 23, 2007
Here is my cell 301-520-3171 call me anytime. Been to Campbell once, nice grass roots field! great folks to. Ray >From: "wingnut" <wingnut(at)spamarrest.com> >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com >Subject: Kitfox-List: Re: East Coast Kitfox Gathering! >Date: Sat, 22 Sep 2007 19:40:15 -0700 > > >Follow the this link to see the Campbell airfield on the Washington DC >chart: > >http://skyvector.com/#25-23-3-2715-2468 > >I was also hoping to get a group picture at the Wright Monument at 3pm. I'm >entertaining taking the group picture and making a few coffee mugs as a >souvenir for everyone who comes. Maybe a picture of your Kitfox on the >other side? > > > > I live just cross the Carolina Virginia State line but I don't > > know where Campbell Airfield is. Can some one tell me? > > >-------- >Luis Rodriguez >Model IV 1200 >Rotax 912UL >Flying Weekly >Laurens, SC (34A) > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=135831#135831 > > _________________________________________________________________ More photos; more messages; more whatever. Windows Live Hotmail - NOW with 5GB storage. ________________________________________________________________________________
Date: Sep 23, 2007
Depending on how the original builder built the plane, this bolt may or may not be glued in place. In building mine I glued (structural adhesive...Hysol 9460) the bolt in place, and when I needed to remove it for the thicker spring/longer bolt, it was a simple matter to shield the fabric with a metal plate with a hole drilled in it, then heat the bolt on the threads. The heat will travel up the bolt, soften the adhesive and allow the bolt to be pushed up into the fuselage. I have an inspection hole nearby to facilitate work done in this area. If you don't have this hole, I think you'll have to remove the hort. stab to reach the area....maybe not. Lynn Matteson Grass Lake, Michigan Kitfox IV Speedster w/Jabiru 2200 flying w/400+ hrs On Sep 23, 2007, at 3:32 AM, Michel Verheughe wrote: > > On Sep 23, 2007, at 4:12 AM, Tom Jones wrote: >> If you are installing 2 main leaves plus a helper leaf you >> probably should add 2 (1/4 inch) to each of the above AN dash >> numbers. > > Yes, you will have to do that, Geir. And the bad news is: the main > bolt is - as I understand it - glued inside the fuselage and you > will need to heat it for removal. > > Med vennlig hilsen, > Michel Verheughe > Norway > Kitfox 3 - Jabiru 2200 > ________________________________________________________________________________
Date: Sep 23, 2007
Geir, I changed mine to a 3 leaf recently and used the existing 5/16" bolt without an issue. As long ass you got close to 1/4" extra bolt you should be ok. I had a spacer between the fuselage and the old spring and I removed it. The 7/16 bolt on tailwheel will likely be too short as it now goes through 2 leaves rather than one. I took off the washer and used it anyhow but the bolt is not through the self locking nut far enough. Thanks for the reminder to replace it before it falls off :) -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135900#135900 ________________________________________________________________________________
Date: Sep 23, 2007
Sorry i can't fine Cmpbell Airfield. Ben here all my life (73) years and never heard of Campbell Airfield. GLENN HORNE Kitfox Model II ----- Original Message ----- From: "wingnut" <wingnut(at)spamarrest.com> Sent: Saturday, September 22, 2007 10:40 PM Subject: Kitfox-List: Re: East Coast Kitfox Gathering! > > Follow the this link to see the Campbell airfield on the Washington DC > chart: > > http://skyvector.com/#25-23-3-2715-2468 > > I was also hoping to get a group picture at the Wright Monument at 3pm. > I'm entertaining taking the group picture and making a few coffee mugs as > a souvenir for everyone who comes. Maybe a picture of your Kitfox on the > other side? > > >> I live just cross the Carolina Virginia State line but I don't >> know where Campbell Airfield is. Can some one tell me? > > > -------- > Luis Rodriguez > Model IV 1200 > Rotax 912UL > Flying Weekly > Laurens, SC (34A) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=135831#135831 > > > ________________________________________________________________________________
Date: Sep 23, 2007
Glenn sez: >Sorry i can't fine Cmpbell Airfield. Ben here all my life (73) years and >never heard of Campbell Airfield. Looks like it is 9VG in Weirwood, VA northeast of Norfolk, on the 050 radial of the Cape Charles (CCV) VOR. Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 23, 2007
OK 9VG . Will look it up. GLENN HORNE Kitfox Model II ----- Original Message ----- From: "Michael Gibbs" <MichaelGibbs(at)cox.net> Sent: Sunday, September 23, 2007 1:43 PM Subject: Kitfox-List: Re: East Coast Kitfox Gathering! > > Glenn sez: > >>Sorry i can't fine Cmpbell Airfield. Ben here all my life (73) years and >>never heard of Campbell Airfield. > > Looks like it is 9VG in Weirwood, VA northeast of Norfolk, on the 050 > radial of the Cape Charles (CCV) VOR. > > Mike G. > N728KF > Phoenix, AZ > > > > ________________________________________________________________________________
Date: Sep 23, 2007
I built the plane, and i made a inspection hole close to the tail spring bolt. I did not glue the bolt in place, only used mastinox on it (anti corrosive). So it is no problem to remove and get access to the bolt. Thanks for the tips. Geir Olav ien Kitfox IV Jabiru 2200 -----Opprinnelig melding----- Fra: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] P vegne av Lynn Matteson Sendt: 23. september 2007 14:36 Til: kitfox-list(at)matronics.com Emne: Re: Kitfox-List: Re: 3 leaf tail spring. Bolt size Depending on how the original builder built the plane, this bolt may or may not be glued in place. In building mine I glued (structural adhesive...Hysol 9460) the bolt in place, and when I needed to remove it for the thicker spring/longer bolt, it was a simple matter to shield the fabric with a metal plate with a hole drilled in it, then heat the bolt on the threads. The heat will travel up the bolt, soften the adhesive and allow the bolt to be pushed up into the fuselage. I have an inspection hole nearby to facilitate work done in this area. If you don't have this hole, I think you'll have to remove the hort. stab to reach the area....maybe not. Lynn Matteson Grass Lake, Michigan Kitfox IV Speedster w/Jabiru 2200 flying w/400+ hrs On Sep 23, 2007, at 3:32 AM, Michel Verheughe wrote: > > On Sep 23, 2007, at 4:12 AM, Tom Jones wrote: >> If you are installing 2 main leaves plus a helper leaf you >> probably should add 2 (1/4 inch) to each of the above AN dash >> numbers. > > Yes, you will have to do that, Geir. And the bad news is: the main > bolt is - as I understand it - glued inside the fuselage and you > will need to heat it for removal. > > Med vennlig hilsen, > Michel Verheughe > Norway > Kitfox 3 - Jabiru 2200 > ________________________________________________________________________________
Subject: KITFOX FOR SALEi
Date: Sep 23, 2007
HELLO TO KITFOX LIST MEMBERS, FIRST OF ALL I;D LIKE TO SAY JIM HAS ENJOYED ALL THE VALUABLE INFORMATION ,AND FUN HE HAS HAD CHATTING BACK AND FORTH WITH ALL OF YOU. LAST JUNE JIM SUFFERED A VERY SERIOUS STROKE. WHILE HE HAS IMPROVED A LOT SINCE THAT TIME HE STILL HAS SOME MAJOR HEALTH PROBLEMS. HE IS UNABLE TO USE HIS LEFT ARM OR HAND. HE CAN WALK A LITTLE WITH THE AID OF A BRACE AND QUAD CANE FOR HIS LEFT LEG, AND HIS VISION WAS SEVERELY DAMAGED. NEEDLESS TO SAY THIS HAS BEEN A VERY DIFFICULT YEAR FOR ALL OF US BOTH PHYSICALLY AND EMOTIONALLY. WE HAVE GIVE IT A LOT OF THOUGHT AND FINALLY DECIDED IT IS TIME TO SELL JIM;S KITFOX SINCE HIS HEALTH NO LONGER PERMITS HIS FLYING. AS YOU CAN IMAGINE THIS WAS A VERY HARD DECISION FOR HIM BECAUSE AS WITH ALL OF YOU I;M SURE FLYING WAS HIS PASSI ON. HIS KITFOX IS A MODEL 4-1200. IT IS WHITE AND RED,IT HAS THE BUNGE CORD MAIN GEAR,A 582 ROTAX ENGINE,THE ENTIRE PLANE HAS LESS THAN 400 HRS. ON IT. IT IS IN EXCELLENT CONDITION,AND NO DAMAGE. FOR SERIOUS ENQUIRIES YOU MAY CALL AREA CODE 812-597-0901. THE PLANE IS NOW AT A PRIVATE AIR STRIP(9IN7) THANKS IN ADVANCE ASKING PRICE IS $24,000.00 JAMES AND VICKIE BURKE ________________________________________________________________________________
Date: Sep 23, 2007
Subject: External Alternator for 912S on Model 7?
Does anyone on the board have experience with the Rotax external alternator and the 912S/Model 7 combination? I'm nearing the completion of Kitfox 7 and will need more electrical power than is available with the internal alternator. I'm wondering if the alternator will fit under the cowl. Thanks for the help, Chris ________________________________________________________________________________
Date: Sep 24, 2007
I have one on my model IV! if you need one, I now a company in Canada that offers one at a decent price. Ray >From: CDE2fly(at)aol.com >Reply-To: kitfox-list(at)matronics.com >To: kitfox-list(at)matronics.com >Subject: Kitfox-List: External Alternator for 912S on Model 7? >Date: Sun, 23 Sep 2007 19:34:35 EDT > >Does anyone on the board have experience with the Rotax external alternator >and the 912S/Model 7 combination? I'm nearing the completion of Kitfox 7 >and >will need more electrical power than is available with the internal >alternator. I'm wondering if the alternator will fit under the cowl. > >Thanks for the help, > >Chris > > _________________________________________________________________ Discover sweet stuff waiting for you at the Messenger Cafe. Claim your treat today! http://www.cafemessenger.com/info/info_sweetstuff.html?ocid=TXT_TAGHM_SeptHMtagline2 ________________________________________________________________________________
Date: Sep 23, 2007
From: Dennis Golden <dgolden@golden-consulting.com>
Subject: Re: External Alternator for 912S on Model 7?
RAY Gignac wrote: > > I have one on my model IV! if you need one, I now a company in Canada > that offers one at a decent price. > > Ray Is that with the round cowl? >> Does anyone on the board have experience with the Rotax external >> alternator >> and the 912S/Model 7 combination? I'm nearing the completion of >> Kitfox 7 and >> will need more electrical power than is available with the internal >> alternator. I'm wondering if the alternator will fit under the cowl. -- Dennis Golden Golden Consulting Services, Inc. ________________________________________________________________________________
Date: Sep 23, 2007
just put one on my M 7 ,fits under cowl no problem but needs some trimming of the flange area to clear the pulley. contact me off line for photos will have cowl back from paint next week david(at)kelm.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136023#136023 ________________________________________________________________________________
Date: Sep 23, 2007
Hi Leonard, I was so desparate to see your video I watched it on someone elses pc this weekend (smile), so I don't need you to burn a DVD. Nice video. Does a good job showing where the full lotus floats are really nice to have. That little 582 Kitfox also looks to perform pretty good from what I could tell by your video. You'd like the 912. Paul Seehafer ----- Original Message ----- From: "akflyer" <akflyer_2000(at)yahoo.com> Sent: Friday, September 21, 2007 12:06 PM Subject: Kitfox-List: Re: New float flying vid > > if you want a DVD PM me your addy..I have lots of real nice Alaska scenery > and flying, it would be nothing to burn to DVD.. > AS much as I hate the thought of spending the money on it.. I may have to > seriously look for a 912.. good deal on 3 of them on Ebay right now.. > > -------- > Leonard Perry > Soldotna AK > Avid "C" / Mk IV > 582 IVO IFA > Full Lotus 1260 > 95% complete > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=135661#135661 > > > ________________________________________________________________________________
Date: Sep 24, 2007
Took off 30 mins ago , got to 100 feet and all windows fogged over. open door flew into sun till it dis-appeared. Landed 15 mins later........ 200 feet from hangar on grass strip and "CLUNK" tail drops..... goes through my head - could it be my three leaf spring just gave in? OR did that BOLT that did not go through the self locking not far enough just fall out ? Regardless-------- I stomped on brakes and hit throttle and got tail off ground and kept it off till i got to hangar then even turned it while tail still in air and shut down......... Tailwheel bolt had fallen out ------ >> NO DAMAGE oh well put another in later :) Happy ending but i should have read and REACTED to my post YESTERDAY >>>>>>>>>>>>>>> > The 7/16 bolt on tailwheel will likely be too short as it now goes through 2 leaves rather than one. I took off the washer and used it anyhow but the bolt is not through the self locking nut far enough. Thanks for the reminder to replace it before it falls off -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136065#136065 ________________________________________________________________________________
Date: Sep 24, 2007
another bolt put in test flew seems ok now -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136082#136082 ________________________________________________________________________________
Date: Sep 24, 2007
Subject: Why glue? - Was tail spring bolt size
This and previous discussions have convinced me to replace my (unbroken) single leaf this winter. So I'm wondering: Given the problems experienced by many with broken tail springs, why would anyone glue this bolt in place to start with? Factory recommendation? Geir Olav ien wrote: I built the plane, and i made a inspection hole close to the tail spring bolt. I did not glue the bolt in place, only used mastinox on it (anti corrosive). So it is no problem to remove and get access to the bolt. Thanks for the tips. Geir Olav ien Kitfox IV Jabiru 2200 -----Opprinnelig melding----- Fra: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] P vegne av Lynn Matteson Sendt: 23. september 2007 14:36 Til: kitfox-list(at)matronics.com Emne: Re: Kitfox-List: Re: 3 leaf tail spring. Bolt size Depending on how the original builder built the plane, this bolt may or may not be glued in place. In building mine I glued (structural adhesive...Hysol 9460) the bolt in place, and when I needed to remove it for the thicker spring/longer bolt, it was a simple matter to shield the fabric with a metal plate with a hole drilled in it, then heat the bolt on the threads. The heat will travel up the bolt, soften the adhesive and allow the bolt to be pushed up into the fuselage. I have an inspection hole nearby to facilitate work done in this area. If you don't have this hole, I think you'll have to remove the hort. stab to reach the area....maybe not. Lynn Matteson Grass Lake, Michigan Kitfox IV Speedster w/Jabiru 2200 flying w/400+ hrs On Sep 23, 2007, at 3:32 AM, Michel Verheughe wrote: > > On Sep 23, 2007, at 4:12 AM, Tom Jones wrote: >> If you are installing 2 main leaves plus a helper leaf you >> probably should add 2 (1/4 inch) to each of the above AN dash >> numbers. > > Yes, you will have to do that, Geir. And the bad news is: the main > bolt is - as I understand it - glued inside the fuselage and you > will need to heat it for removal. > > Med vennlig hilsen, > Michel Verheughe > Norway > Kitfox 3 - Jabiru 2200 > Marco Menezes Model 2 582 N99KX --------------------------------- Yahoo! oneSearch: Finally, mobile search that gives answers, not web links. ________________________________________________________________________________
Date: Sep 24, 2007
Is anyone here flying the Czech floats currently? If so please let us all know what you think. Thanks! gc 1:53 PM ________________________________________________________________________________
Date: Sep 24, 2007
Me too, I sold my aerocet amphibs to Dan Denny a few years ago and really want to replace them next year. The Czech floats seem fairly strong, though not for rough beaching. John Oakley Fox 4 long and short Cap - 912ul -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Gregory Cronin Sent: Monday, September 24, 2007 9:46 AM Subject: RE: Kitfox-List: czech floats Is anyone here flying the Czech floats currently? If so please let us all know what you think. Thanks! gc 1:53 PM ________________________________________________________________________________
Subject: Re: Why glue? - Was tail spring bolt size
Date: Sep 24, 2007
> This and previous discussions have convinced me to replace my (unbroken) single leaf this winter. So I'm wondering: Given the problems experienced by many with broken tail springs, why would anyone glue this bolt in place to start with? Factory recommendation? The builder's manual recommeds epoxying the bolt because it is difficult to access it after the plane is assembled. My opinion...now...is that an inspection ring located to access that bolt is a better idea. -------- Tom Jones Classic IV, Phase one 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136133#136133 ________________________________________________________________________________
Date: Sep 24, 2007
Hope it's a longer one and "in safety". Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave > Sent: Monday, September 24, 2007 11:12 AM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: 3 leaf tail spring. Bolt size > > > > another bolt put in > > test flew > seems ok now > > -------- > Rotax Dealer, Ontario Canada > Flying Videos and Kitfox Info > http://www.cfisher.com/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=136082#136082 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 24, 2007
Noel, did not have a AN bolt so i used a grade 5 bolts course thread with a lock washer. Then After it done I drilled it and put in a cotter pin LOL not AC 43.11 but it just a tailwheel.... next order i get a 7/16 " bolt the right length :) maybe it will bust again by then > ? -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136155#136155 ________________________________________________________________________________
Date: Sep 24, 2007
Yes, I'm flying the 1650s with my first water landings yesterday. I landed about 9am yesterday morning in no wind and glassy conditions. They felt great touching down and there was not much tendency to pitch forward considering the smooth water condition. As I can off the step, the nose came up like normal and then settle in fairly flat......maybe a little too flat as some water made its way over the front of the float. Idle taxing I could see water building up in front of the float which I blamed on the large front cavity where the nosewheel sits. Just for kicks I wanted to see how long it would take to get on step before I turned around to depart but it could not climb up on step no matter what I tried. Now I'm concerned about how the floats are sitting in the water (nearly flat). To make a long story short, I ended up adding about 10 lbs to the rear compartment of each float to get off the water. First try it was up on step almost instantly but the wind and water conditions had also changed to 10 mph. Multiple takeoffs and landings with great results. Fast off the water and very smooth on! I'll try again in the next few days but I'm hoping I won't have to keep the extra weight in the floats and that the reason the water came over the top was more of an amphib problem than a rigging problem. Any thoughts? Kevin Cozik S6 Czech 1650s 914 turbo Lansing Michigan On Mon Sep 24 11:46 , 'Gregory Cronin' <greg@case-assembly.com> sent: > >Is anyone here flying the Czech floats currently? > >If so please let us all know what you think. > >Thanks! >gc > >1:53 PM > > > ________________________________________________________________________________
Date: Sep 24, 2007
located at (P96) which is Jersey Shore, PA we have 2 kitfoxers there (1) avid and there are a few other guys not far from there that also have kitfoxes.....its a nice over 3000 ft level grass strip kept really good. North Central PA just East of Lock Haven , PA (LHV) the piper cub home.and West of Williamport (IPT) hope this helps , where u located? I can email too so as not to mess up this site. should be on my signature -------- Pilotpat Kitfox Classic IV Jabiru 2200 Williamsport , PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136222#136222 ________________________________________________________________________________
Subject: Re: Avid Mk-IV project on Barnstormers
Date: Sep 25, 2007
An update to this posting... This post/ad generated several dozen inquiries and a handful of offers. However, many, many folks have inquired whether I would sell the project WITH my new-in-crate 85hp Jab2200, Jab/Mk-IV engine mount and Jab cowl. I originally intended to keep these items for another project currently in the works. However, now that I've decided to put that project directly on floats, I have emailed all responding to the ad that I am open to offers on the entire turnkey 'Javid' Mk-IV project. Figured it was only fair to give the heads up to members here before revising the Barnstormers listing or posting up on FleaBay. Contact off list please if interested, thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136353#136353 ________________________________________________________________________________
Subject: RE: NSI Isolation Module replacement
Date: Sep 25, 2007
Hello Harold: About a year ago I notified the list that I had developed a direct replacement for the NSI ignition isolation modules, and that I could build a batch of twelve, if there would be enough interest. There was and I did. However they are all sold and I have no more. If there were enough interest to justify building another batch of twelve (or more), I would be willing to do so. I sold them for $ 450.00 each, not including shipping and COD charges. I assume that I can still purchase the necessary required components for the same price as before, but am not certain. Anybody interested, please let me know. Peter Graichen http:/home.neo.rr.com/n10pg/kitfox.htm ________________________________ From: Harold Lanfear [mailto:hlanfear(at)verizon.net] Sent: Tuesday, 25 September, 2007 14:30 Subject: NSI Isolation Module replacement Peter, I saw a note on the NSI Yahoo group that said you built and sold replacements for the NSI isolation modules. I have an NSI EA-81 in my Kitfox with 775 hours on it and pretty sure I'm having a failure (same symptoms as the first time, just prior to NSI going under). If you are still building them, I would buy at least two and replace both modules. Thanks, Harold Lanfear West Grove, PA ________________________________________________________________________________
Subject: Tailwheel bolt went off.... and the rest
From: "Michel Dierick" <michel.dierick(at)skynet.be>
Date: Sep 25, 2007
Hi everone, When I made my landing sunday, I noticed I could not steer my Kitfox either left or right and was unable to vacate the runway. So, I stopped the engine, looked behind and saw the front bolt of the tailwheelspring had broken. Of course, the rudder rested on the tailwheel, causing some very little damage there. I was horrified when I made a closer inspection with my camera. The picture showed that not only the bolt was broken but a piece of the tubing was also broken off. I have no idea how this tube was exactly, so can anybody send me some good clear pictures of this tail section (before covering) so that I can see how the fuselage should be normally ? Many thanks in advance. -------- Flying, yes, but fly safely Michel "TheDailyFly" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136409#136409 Attachments: http://forums.matronics.com//files/dscn2024_25percent_417.jpg http://forums.matronics.com//files/dscn2027_25percent_181.jpg http://forums.matronics.com//files/dscn2022_25percent_111.jpg ________________________________________________________________________________
Date: Sep 25, 2007
> From: Michel Dierick [michel.dierick(at)skynet.be] > So, I stopped the engine, looked behind and saw the front bolt of the > tailwheelspring had broken. Wow! That's really strange, Michel! I can't imagine how that bolt could break. Was it pulled through? Sheared? How about the bracket and the two bolts that hold the spring in place? Do you think it happened by an up-down force or by a side force? Sorry, I can't help you with the inside view, I didn't built my aircraft myself, I am just puzzled but the breaking of that bolt. I didn't think it was possible under normal circumstances. But then ... I still have lot to learn. Cheers, Michel Verheughe Norway Kitfox 3 - Jabiru 2200
Date: Sep 25, 2007
I hanger my Kitfox at W00/Freeway airport located in Mitchellville Maryland . Please email me the info. Ray> Subject: Kitfox-List: Re: East Coast Kitfox Gathering!> From: pkelly20 @comcast.net> Date: Mon, 24 Sep 2007 16:59:43 -0700> To: kitfox-list@matron net>> > located at (P96) which is Jersey Shore, PA we have 2 kitfoxers ther e (1) avid and there are a few other guys not far from there that also have kitfoxes.....its a nice over 3000 ft level grass strip kept really good. N orth Central PA> just East of Lock Haven , PA (LHV) the piper cub home.and West of Williamport (IPT) hope this helps , where u located? I can email to o so as not to mess up this site. should be on my signature> > --------> Pi lotpat> Kitfox Classic IV> Jabiru 2200> Williamsport , PA> > > > > Read thi s topic online here:> > http://forums.matronics.com/viewtopic.php?p=13622 ====================> > > _________________________________________________________________ Capture your memories in an online journal! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us ________________________________________________________________________________
Subject: Re: czech floats
Date: Sep 25, 2007
Greg, I have 25 years of float flying experience, with a total of 2200 hrs in seaplanes. 1300 hours of that seaplane time has been in various light sport type aircraft. I have a bit more than 30 hours in an amphibious Czech float equipped Rans S-7 with a Rotax 100 hp 912s for power. Aircraft empty weight on wheels around 670 lbs, and right close to 900 on floats. The floats are the 4 wheel option 1150/1200a amphibs. The floats work, but lack forward floatation, as well as total floatation for the Rans (note how low the spreader bars are to the water in the attached picture. Also, the rear seat passenger weight is actually is helping keep the front of the floats up. Otherwise the bows would be plowing water over the top when idling). The landing gear has no suspension, and while the main gear does have a down lock, the nosegears are held down purely by hydraulic pressure, consequently causing concerns about gear collapse in the case of hydraulic failure, The hydraulic cyls also tend to leak when sitting with the weight of the airplane on them. The other problem with the floats is that they are approx 15 1/2 ft in length, and that causes you not to be able to rotate well without dragging the heels (which will consequently also keep you from leaving the water). This a a common problem with many older float designs as well. While a long float offers a nice ride and lots of good tracking and stability, they limit your ability to take off short because you can't rotate into a steep attitude. For those reasons I personally would always choose a short float over a long one if the floatation was similar. Oh yeah, a Rans S-7 is longer than my Kitfox IV by almost 5 ft, so the Kitfox would really suffer from not being able to rotate due to the float being so long for the airplane. The Czech floats on this Rans also only have 2 watertight compartments / pump outs. That would never pass muster for a certified float, as it puts the airplane at risk of capsizing if ever one compartment were to leak and fill with water. The good news there is that the later Czech floats are known for not leaking much water. But if you ever hit an underwater obstruction and poke a hole in your float, you have little or no reserve buoyancy with 50% of one float only left watertight. Another thing I don't like about the Czech floats is they are hydrodynamically very draggy. Example, last time I flew this Rans I was doing a downwind takeoff in a 10 mph wind and no matter what I did I couldn't get enough forward water speed to lift off. I tried everything, but finally stopped and turned into the wind and took off no problem. That whole issue is caused by too much reveted skin area causing excess water drag and limiting the ability to accelerate on the step. And being that I fly my Aerocet equipped Kitfox also, I guess I am spoiled as downwind takeoffs are never a problem, even though I have 20 hp less than the Rans, and less wing area. The Aerocets having a smooth fluted bottom have let me acclerate easily for a takeoff at gross weight in a 25+ mph downwind before (ps - don't try this at home - I've been flying floats for a lot of years... Go into the wind like our flight instructors tell us to). I also don't like the fact that there are no storage areas in the czech floats. Ok, so what do I like about the Czech floats? Ground handling is good, and brakes work pretty good or an amphib. Water rudders are sufficiently sized, and the floats will get you off the water relatively quick as they use a pretty flat bottom. Of course, since nothing is ever free, rough water is not the Czech floats forte. I currently am flying my Kitfox 912ul Model IV on Aerocet 1100 amphibs. It weighs 630 lbs on wheels and 776 on amphibs. Those floats too have a lot of issues, with underfloatation being the biggest problem, and a weak landing gear second. But other than that it is hands down the best handling float you will ever fly (I can do a 600-800 foot circular one float takeoff! Yeah, they handle that good...) Because I don't think we have a decent choice out there currently for an amphib float for our planes, I designed my own with all the features I wanted, and felt we need. I am in final design stages and will be going into production soon (has been a MUCH bigger job than I ever expected. Oh well, all good things take time they say...). I expect to have floats available 1st qtr of 2008. Pricing is targeted to compete with the Czech floats. And it will be an attractive float with a real landing gear and nice storage (read as "Not anything weird"). I will let the group know here as I progress with production. The Kitfox is one of my favorite airplanes, so I hope to set up a Kitfox as one of the first airplanes on my new floats. Paul Seehafer ps - did those Avid amphibs not work out for your? ----- Original Message ----- From: "Gregory Cronin" <greg@case-assembly.com> Sent: Monday, September 24, 2007 10:46 AM Subject: RE: Kitfox-List: czech floats > <greg@case-assembly.com> > > Is anyone here flying the Czech floats currently? > > If so please let us all know what you think. > > Thanks! > gc > > 1:53 PM > > > ________________________________________________________________________________
Subject: Re: Tailwheel bolt went off.... and the rest
Date: Sep 25, 2007
looks like it has been repaired before? Rusty too ? whats up with that ? Does not look too healthy . -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136450#136450 ________________________________________________________________________________
Subject: Down wind Float TO
Date: Sep 25, 2007
Paul this is just a note on taking off into the wind. I once saw a bush pilot with a lot of experience taking off down wind with a passenger in his Super Cub. Years later I asked him about that take off not really expecting him to remember. I Still don't know if he remembered that particular take off but there was a reason for the down wind take off which I hadn't considered. His take off was in a fijord with the wind coming down the fijord. If he had taken off into the wind he would have ended up close to the walls of the fijord where there is a great possibility of strong downdrafts. I learned that day there are places where down wind take offs are advisable. Now for a question.... Is there a situation that you can think of where a down wind float landing would be advisable?? Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of > Paul Seehafer > Sent: Tuesday, September 25, 2007 8:52 PM > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: czech floats > > > Greg, > > I have 25 years of float flying experience, with a total of > 2200 hrs in > seaplanes. 1300 hours of that seaplane time has been in > various light sport > type aircraft. I have a bit more than 30 hours in an > amphibious Czech float > equipped Rans S-7 with a Rotax 100 hp 912s for power. > Aircraft empty weight > on wheels around 670 lbs, and right close to 900 on floats. > The floats are > the 4 wheel option 1150/1200a amphibs. > > The floats work, but lack forward floatation, as well as > total floatation > for the Rans (note how low the spreader bars are to the water in the > attached picture. Also, the rear seat passenger weight is > actually is > helping keep the front of the floats up. Otherwise the bows would be > plowing water over the top when idling). The landing gear has no > suspension, and while the main gear does have a down lock, > the nosegears are > held down purely by hydraulic pressure, consequently causing > concerns about > gear collapse in the case of hydraulic failure, The hydraulic > cyls also tend > to leak when sitting with the weight of the airplane on them. > The other > problem with the floats is that they are approx 15 1/2 ft in > length, and > that causes you not to be able to rotate well without > dragging the heels > (which will consequently also keep you from leaving the > water). This a a > common problem with many older float designs as well. While > a long float > offers a nice ride and lots of good tracking and stability, > they limit your > ability to take off short because you can't rotate into a > steep attitude. > For those reasons I personally would always choose a short > float over a long > one if the floatation was similar. Oh yeah, a Rans S-7 is > longer than my > Kitfox IV by almost 5 ft, so the Kitfox would really suffer > from not being > able to rotate due to the float being so long for the > airplane. The Czech > floats on this Rans also only have 2 watertight compartments > / pump outs. > That would never pass muster for a certified float, as it > puts the airplane > at risk of capsizing if ever one compartment were to leak and > fill with > water. The good news there is that the later Czech floats > are known for not > leaking much water. But if you ever hit an underwater > obstruction and poke > a hole in your float, you have little or no reserve buoyancy > with 50% of one > float only left watertight. > > Another thing I don't like about the Czech floats is they are > hydrodynamically very draggy. Example, last time I flew this > Rans I was > doing a downwind takeoff in a 10 mph wind and no matter what I did I > couldn't get enough forward water speed to lift off. I tried > everything, > but finally stopped and turned into the wind and took off no > problem. That > whole issue is caused by too much reveted skin area causing > excess water > drag and limiting the ability to accelerate on the step. And > being that I > fly my Aerocet equipped Kitfox also, I guess I am spoiled as downwind > takeoffs are never a problem, even though I have 20 hp less > than the Rans, > and less wing area. The Aerocets having a smooth fluted > bottom have let me > acclerate easily for a takeoff at gross weight in a 25+ mph > downwind before > (ps - don't try this at home - I've been flying floats for a > lot of years... > Go into the wind like our flight instructors tell us to). I > also don't like > the fact that there are no storage areas in the czech floats. > > Ok, so what do I like about the Czech floats? Ground > handling is good, and > brakes work pretty good or an amphib. Water rudders are > sufficiently sized, > and the floats will get you off the water relatively quick as > they use a > pretty flat bottom. Of course, since nothing is ever free, > rough water is > not the Czech floats forte. > > I currently am flying my Kitfox 912ul Model IV on Aerocet > 1100 amphibs. It > weighs 630 lbs on wheels and 776 on amphibs. Those floats too > have a lot of > issues, with underfloatation being the biggest problem, and a > weak landing > gear second. But other than that it is hands down the best > handling float > you will ever fly (I can do a 600-800 foot circular one float > takeoff! > Yeah, they handle that good...) > > Because I don't think we have a decent choice out there > currently for an > amphib float for our planes, I designed my own with all the > features I > wanted, and felt we need. I am in final design stages and > will be going > into production soon (has been a MUCH bigger job than I ever > expected. Oh > well, all good things take time they say...). I expect to > have floats > available 1st qtr of 2008. Pricing is targeted to compete > with the Czech > floats. And it will be an attractive float with a real > landing gear and nice > storage (read as "Not anything weird"). I will let the > group know here as > I progress with production. The Kitfox is one of my favorite > airplanes, so > I hope to set up a Kitfox as one of the first airplanes on my > new floats. > > Paul Seehafer > > ps - did those Avid amphibs not work out for your? > > ________________________________________________________________________________
Date: Sep 25, 2007
Paul, That is the greatest report on floats I have seen. I am thinking you need to quit your job and write for a magazine. :-) Honestly that is what many of us want to hear, One persons experience and feelings. I now believe you are capable of making a great set of floats. I along with many others are waiting for more info on your system. I learned from you about how many compartments there need to be, also the storage area's is a must, I had forgotten the aerocet had them. I actually put my kids in the floats with their heads sticking out and dressed like elfs, me as santa.( they will never forgive me) Any picture of the floats you want to share. Again, thanks John Oakley Fox 4 speedster long and short 912 ul -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Seehafer Sent: Tuesday, September 25, 2007 5:22 PM Subject: Re: Kitfox-List: czech floats Greg, I have 25 years of float flying experience, with a total of 2200 hrs in seaplanes. 1300 hours of that seaplane time has been in various light sport type aircraft. I have a bit more than 30 hours in an amphibious Czech float equipped Rans S-7 with a Rotax 100 hp 912s for power. Aircraft empty weight on wheels around 670 lbs, and right close to 900 on floats. The floats are the 4 wheel option 1150/1200a amphibs. The floats work, but lack forward floatation, as well as total floatation for the Rans (note how low the spreader bars are to the water in the attached picture. Also, the rear seat passenger weight is actually is helping keep the front of the floats up. Otherwise the bows would be plowing water over the top when idling). The landing gear has no suspension, and while the main gear does have a down lock, the nosegears are held down purely by hydraulic pressure, consequently causing concerns about gear collapse in the case of hydraulic failure, The hydraulic cyls also tend to leak when sitting with the weight of the airplane on them. The other problem with the floats is that they are approx 15 1/2 ft in length, and that causes you not to be able to rotate well without dragging the heels (which will consequently also keep you from leaving the water). This a a common problem with many older float designs as well. While a long float offers a nice ride and lots of good tracking and stability, they limit your ability to take off short because you can't rotate into a steep attitude. For those reasons I personally would always choose a short float over a long one if the floatation was similar. Oh yeah, a Rans S-7 is longer than my Kitfox IV by almost 5 ft, so the Kitfox would really suffer from not being able to rotate due to the float being so long for the airplane. The Czech floats on this Rans also only have 2 watertight compartments / pump outs. That would never pass muster for a certified float, as it puts the airplane at risk of capsizing if ever one compartment were to leak and fill with water. The good news there is that the later Czech floats are known for not leaking much water. But if you ever hit an underwater obstruction and poke a hole in your float, you have little or no reserve buoyancy with 50% of one float only left watertight. Another thing I don't like about the Czech floats is they are hydrodynamically very draggy. Example, last time I flew this Rans I was doing a downwind takeoff in a 10 mph wind and no matter what I did I couldn't get enough forward water speed to lift off. I tried everything, but finally stopped and turned into the wind and took off no problem. That whole issue is caused by too much reveted skin area causing excess water drag and limiting the ability to accelerate on the step. And being that I fly my Aerocet equipped Kitfox also, I guess I am spoiled as downwind takeoffs are never a problem, even though I have 20 hp less than the Rans, and less wing area. The Aerocets having a smooth fluted bottom have let me acclerate easily for a takeoff at gross weight in a 25+ mph downwind before (ps - don't try this at home - I've been flying floats for a lot of years... Go into the wind like our flight instructors tell us to). I also don't like the fact that there are no storage areas in the czech floats. Ok, so what do I like about the Czech floats? Ground handling is good, and brakes work pretty good or an amphib. Water rudders are sufficiently sized, and the floats will get you off the water relatively quick as they use a pretty flat bottom. Of course, since nothing is ever free, rough water is not the Czech floats forte. I currently am flying my Kitfox 912ul Model IV on Aerocet 1100 amphibs. It weighs 630 lbs on wheels and 776 on amphibs. Those floats too have a lot of issues, with underfloatation being the biggest problem, and a weak landing gear second. But other than that it is hands down the best handling float you will ever fly (I can do a 600-800 foot circular one float takeoff! Yeah, they handle that good...) Because I don't think we have a decent choice out there currently for an amphib float for our planes, I designed my own with all the features I wanted, and felt we need. I am in final design stages and will be going into production soon (has been a MUCH bigger job than I ever expected. Oh well, all good things take time they say...). I expect to have floats available 1st qtr of 2008. Pricing is targeted to compete with the Czech floats. And it will be an attractive float with a real landing gear and nice storage (read as "Not anything weird"). I will let the group know here as I progress with production. The Kitfox is one of my favorite airplanes, so I hope to set up a Kitfox as one of the first airplanes on my new floats. Paul Seehafer ps - did those Avid amphibs not work out for your? ----- Original Message ----- From: "Gregory Cronin" <greg@case-assembly.com> Sent: Monday, September 24, 2007 10:46 AM Subject: RE: Kitfox-List: czech floats > <greg@case-assembly.com> > > Is anyone here flying the Czech floats currently? > > If so please let us all know what you think. > > Thanks! > gc > > 1:53 PM > > > ________________________________________________________________________________
Date: Sep 26, 2007
On Sep 26, 2007, at 2:48 AM, dave wrote: > looks like it has been repaired before? > Rusty too ? .... Okay, when I read Michel's email yesterday night, it was through my ISP web interface and I didn't see the photos (plain-text-only interface). Today, Dave's answer made me think there was some photos attached. I went to the forum.matronics.com and saw them. Yes, there is a bit of rust there but ... it brought a question to my mind. My Kitfox model 3 was delivered and built with one spring leaf that lasted about 950 landings before breaking. I have now a new main leaf and a 'helper.' I read that most people (and John sells) a three-leafs set. I see that it is what Michel has. Then I wonder. If the plane is designed for one leaf and it is later changed to three ... is it wise? I mean, three leaves doesn't reduce the load on the tail when landing or taxiing on rough surface. If it prevents the spring to break, doesn't it then invite rupture to happen somewhere else? Just wondering. Cheers, Michel Verheughe Norway Kitfox 3 - Jabiru 2200 ________________________________________________________________________________
Date: Sep 26, 2007
Paul, That was a very interesting piece you wrote about floats. All the more so as I am planning to fit my KF3 with Aerocet amphibs this winter. If you have any tips about using the Aerocets I would sure appreciate it. Thanks Mike Laundy KF3 582 john oakley wrote: Paul, That is the greatest report on floats I have seen. I am thinking you need to quit your job and write for a magazine. :-) Honestly that is what many of us want to hear, One persons experience and feelings. I now believe you are capable of making a great set of floats. I along with many others are waiting for more info on your system. I learned from you about how many compartments there need to be, also the storage area's is a must, I had forgotten the aerocet had them. I actually put my kids in the floats with their heads sticking out and dressed like elfs, me as santa.( they will never forgive me) Any picture of the floats you want to share. Again, thanks John Oakley Fox 4 speedster long and short 912 ul -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Seehafer Sent: Tuesday, September 25, 2007 5:22 PM Subject: Re: Kitfox-List: czech floats Greg, I have 25 years of float flying experience, with a total of 2200 hrs in seaplanes. 1300 hours of that seaplane time has been in various light sport type aircraft. I have a bit more than 30 hours in an amphibious Czech float equipped Rans S-7 with a Rotax 100 hp 912s for power. Aircraft empty weight on wheels around 670 lbs, and right close to 900 on floats. The floats are the 4 wheel option 1150/1200a amphibs. The floats work, but lack forward floatation, as well as total floatation for the Rans (note how low the spreader bars are to the water in the attached picture. Also, the rear seat passenger weight is actually is helping keep the front of the floats up. Otherwise the bows would be plowing water over the top when idling). The landing gear has no suspension, and while the main gear does have a down lock, the nosegears are held down purely by hydraulic pressure, consequently causing concerns about gear collapse in the case of hydraulic failure, The hydraulic cyls also tend to leak when sitting with the weight of the airplane on them. The other problem with the floats is that they are approx 15 1/2 ft in length, and that causes you not to be able to rotate well without dragging the heels (which will consequently also keep you from leaving the water). This a a common problem with many older float designs as well. While a long float offers a nice ride and lots of good tracking and stability, they limit your ability to take off short because you can't rotate into a steep attitude. For those reasons I personally would always choose a short float over a long one if the floatation was similar. Oh yeah, a Rans S-7 is longer than my Kitfox IV by almost 5 ft, so the Kitfox would really suffer from not being able to rotate due to the float being so long for the airplane. The Czech floats on this Rans also only have 2 watertight compartments / pump outs. That would never pass muster for a certified float, as it puts the airplane at risk of capsizing if ever one compartment were to leak and fill with water. The good news there is that the later Czech floats are known for not leaking much water. But if you ever hit an underwater obstruction and poke a hole in your float, you have little or no reserve buoyancy with 50% of one float only left watertight. Another thing I don't like about the Czech floats is they are hydrodynamically very draggy. Example, last time I flew this Rans I was doing a downwind takeoff in a 10 mph wind and no matter what I did I couldn't get enough forward water speed to lift off. I tried everything, but finally stopped and turned into the wind and took off no problem. That whole issue is caused by too much reveted skin area causing excess water drag and limiting the ability to accelerate on the step. And being that I fly my Aerocet equipped Kitfox also, I guess I am spoiled as downwind takeoffs are never a problem, even though I have 20 hp less than the Rans, and less wing area. The Aerocets having a smooth fluted bottom have let me acclerate easily for a takeoff at gross weight in a 25+ mph downwind before (ps - don't try this at home - I've been flying floats for a lot of years... Go into the wind like our flight instructors tell us to). I also don't like the fact that there are no storage areas in the czech floats. Ok, so what do I like about the Czech floats? Ground handling is good, and brakes work pretty good or an amphib. Water rudders are sufficiently sized, and the floats will get you off the water relatively quick as they use a pretty flat bottom. Of course, since nothing is ever free, rough water is not the Czech floats forte. I currently am flying my Kitfox 912ul Model IV on Aerocet 1100 amphibs. It weighs 630 lbs on wheels and 776 on amphibs. Those floats too have a lot of issues, with underfloatation being the biggest problem, and a weak landing gear second. But other than that it is hands down the best handling float you will ever fly (I can do a 600-800 foot circular one float takeoff! Yeah, they handle that good...) Because I don't think we have a decent choice out there currently for an amphib float for our planes, I designed my own with all the features I wanted, and felt we need. I am in final design stages and will be going into production soon (has been a MUCH bigger job than I ever expected. Oh well, all good things take time they say...). I expect to have floats available 1st qtr of 2008. Pricing is targeted to compete with the Czech floats. And it will be an attractive float with a real landing gear and nice storage (read as "Not anything weird"). I will let the group know here as I progress with production. The Kitfox is one of my favorite airplanes, so I hope to set up a Kitfox as one of the first airplanes on my new floats. Paul Seehafer ps - did those Avid amphibs not work out for your? ----- Original Message ----- From: "Gregory Cronin" Sent: Monday, September 24, 2007 10:46 AM Subject: RE: Kitfox-List: czech floats > > > Is anyone here flying the Czech floats currently? > > If so please let us all know what you think. > > Thanks! > gc > > 1:53 PM > > > --------------------------------- For ideas on reducing your carbon footprint visit Yahoo! For Good this month. ________________________________________________________________________________
Date: Sep 25, 2007
Michel, You could have a point there. A other piece I want to change is the tail wheel self. This is for the moment one of plain rubber/plastic, anyhow, very hard and absolutely not chock-absorbing at all. I already decided to change this in a air-chamber like the one on my glider, but this is only a minor problem now. I'm afraid I will have to open the rear fuselage for the repair. That's why I'd like to have some pictures of the tail section before covering. Off-topic I'm in Gent next week, I'll send you the pictures of the "Rue des deux ponts - tweebruggenstraat" -------- Flying, yes, but fly safely Michel "TheDailyFly" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136495#136495 ________________________________________________________________________________
Subject: czech floats
Date: Sep 26, 2007
Your always the right guy to share your knowledge when it comes to floats. Thanks for the information. I did a lot of work on the avid floats. Repainted them and powder coated/anodized all the components. But never did fit them to the plane because I thought they may not be enough float. I have plans to modify them by adding another scallop to each side of the float but have not got to that point. I would be interested in any drawings you would be willing to share of your new design. Always good to hear from you. greg -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Seehafer Sent: Tuesday, September 25, 2007 7:22 PM Subject: Re: Kitfox-List: czech floats Greg, I have 25 years of float flying experience, with a total of 2200 hrs in seaplanes. 1300 hours of that seaplane time has been in various light sport type aircraft. I have a bit more than 30 hours in an amphibious Czech float equipped Rans S-7 with a Rotax 100 hp 912s for power. Aircraft empty weight on wheels around 670 lbs, and right close to 900 on floats. The floats are the 4 wheel option 1150/1200a amphibs. The floats work, but lack forward floatation, as well as total floatation for the Rans (note how low the spreader bars are to the water in the attached picture. Also, the rear seat passenger weight is actually is helping keep the front of the floats up. Otherwise the bows would be plowing water over the top when idling). The landing gear has no suspension, and while the main gear does have a down lock, the nosegears are held down purely by hydraulic pressure, consequently causing concerns about gear collapse in the case of hydraulic failure, The hydraulic cyls also tend to leak when sitting with the weight of the airplane on them. The other problem with the floats is that they are approx 15 1/2 ft in length, and that causes you not to be able to rotate well without dragging the heels (which will consequently also keep you from leaving the water). This a a common problem with many older float designs as well. While a long float offers a nice ride and lots of good tracking and stability, they limit your ability to take off short because you can't rotate into a steep attitude. For those reasons I personally would always choose a short float over a long one if the floatation was similar. Oh yeah, a Rans S-7 is longer than my Kitfox IV by almost 5 ft, so the Kitfox would really suffer from not being able to rotate due to the float being so long for the airplane. The Czech floats on this Rans also only have 2 watertight compartments / pump outs. That would never pass muster for a certified float, as it puts the airplane at risk of capsizing if ever one compartment were to leak and fill with water. The good news there is that the later Czech floats are known for not leaking much water. But if you ever hit an underwater obstruction and poke a hole in your float, you have little or no reserve buoyancy with 50% of one float only left watertight. Another thing I don't like about the Czech floats is they are hydrodynamically very draggy. Example, last time I flew this Rans I was doing a downwind takeoff in a 10 mph wind and no matter what I did I couldn't get enough forward water speed to lift off. I tried everything, but finally stopped and turned into the wind and took off no problem. That whole issue is caused by too much reveted skin area causing excess water drag and limiting the ability to accelerate on the step. And being that I fly my Aerocet equipped Kitfox also, I guess I am spoiled as downwind takeoffs are never a problem, even though I have 20 hp less than the Rans, and less wing area. The Aerocets having a smooth fluted bottom have let me acclerate easily for a takeoff at gross weight in a 25+ mph downwind before (ps - don't try this at home - I've been flying floats for a lot of years... Go into the wind like our flight instructors tell us to). I also don't like the fact that there are no storage areas in the czech floats. Ok, so what do I like about the Czech floats? Ground handling is good, and brakes work pretty good or an amphib. Water rudders are sufficiently sized, and the floats will get you off the water relatively quick as they use a pretty flat bottom. Of course, since nothing is ever free, rough water is not the Czech floats forte. I currently am flying my Kitfox 912ul Model IV on Aerocet 1100 amphibs. It weighs 630 lbs on wheels and 776 on amphibs. Those floats too have a lot of issues, with underfloatation being the biggest problem, and a weak landing gear second. But other than that it is hands down the best handling float you will ever fly (I can do a 600-800 foot circular one float takeoff! Yeah, they handle that good...) Because I don't think we have a decent choice out there currently for an amphib float for our planes, I designed my own with all the features I wanted, and felt we need. I am in final design stages and will be going into production soon (has been a MUCH bigger job than I ever expected. Oh well, all good things take time they say...). I expect to have floats available 1st qtr of 2008. Pricing is targeted to compete with the Czech floats. And it will be an attractive float with a real landing gear and nice storage (read as "Not anything weird"). I will let the group know here as I progress with production. The Kitfox is one of my favorite airplanes, so I hope to set up a Kitfox as one of the first airplanes on my new floats. Paul Seehafer ps - did those Avid amphibs not work out for your? ----- Original Message ----- From: "Gregory Cronin" <greg@case-assembly.com> Sent: Monday, September 24, 2007 10:46 AM Subject: RE: Kitfox-List: czech floats > <greg@case-assembly.com> > > Is anyone here flying the Czech floats currently? > > If so please let us all know what you think. > > Thanks! > gc > > 1:53 PM > > > 8:02 AM 8:02 AM ________________________________________________________________________________
Date: Sep 26, 2007
I will be interested in Paul's floats as well when he gets them ready. I have Aerocet 1100s on 582 and they work well, like Paul says one of the best handling floats on the water but a bit under floated. I could see them be near not very good on a Subaru install. 582 ok but when dual with heavy load it takes more to get up on step and a 582 is likely about 150 lbs less than a Sub on the nose ... and the nose is where they seem under-floated the most. That being said they are very aerodynamic and your speed loss will be far less than some real draggy floats like Full lotus. I think the Aerocet 1100 was set at 1100 displacement per float Before the Amphibs were installed and hence loss some capability. Landing gear is ok but if you operate off non smooth runways like i do with thousands of takeoffs and landings your gear in time will fail . Seaplane ramps can take there toll as well. I have about 20 + videos up with float ones too www.cfisher.com and look for link . -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136536#136536 ________________________________________________________________________________
Subject: Lowell's oil pressure problem. ??
Date: Sep 26, 2007
Lowell, I have a friend who has bought a 912 ul Kitfox IV and he is not on this forum but he has heard about your accident. Have you determined what the cause was of your loss of oil pressure that happened on your plane ? Certainly we can all learn from this hopefully. Glad to have read that you and your wife survived the forced approach. Dave -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136538#136538 ________________________________________________________________________________
Subject: Re: Lowell's oil pressure problem. ??
Date: Sep 26, 2007
Dave, Thanks for the post and if you don't mind, I will use this opportunity for an update. First, I have no real idea as to the cause of the low oil pressure indication. A friend at the accident scene checked the oil tank and it contained oil. Just how much, I don't know as he had never seen me check the oil and he had no idea what full was. Tomorrow marks the fourth week since the "rough" landing. Kay and I are doing fine and are pretty much able to take care of each other. I am still in the "clam shell" brace who a friend reminded me resembles almost exactly the chest covering costume of the Ninja Turtles, though mine is a boring white. Another friend mentioned that it would be a better design if it had cup holders molded into it. That would be nice at times. It does make an adequate table, though, when lying down eating. I mention the brace as I am not allowed up without it and showering is prohibited until at least the 6th week. For that reason I do need help with a sponging off every other day and have help in that area. Kay can't do it as she is still in her cast from the broken and pinned thumb. I met with the FAA a couple of weeks ago and recieved calls from AIG and NTSB. The former and latter are interested in having Rotax look at the engine and instrumentation to determine the cause of the low oil indication. And AIG was most helpful, reminding me that the passenger liability applied to Kay, even though she was my wife. I couldn't be more happy with the insurance company. I can't finish whithout a mention of the big four. These are the documents all three entities will be most interested in. Make sure your log book has your latest BFR logged and it is current. Make sure your license and medical are current and in your possesion and of course make sure the annual condition inspection is logged in your aircraft log book. The FAA also asked about the Airworthiness Certificate and the Registration. I told them they were in the aircraft (where they should be) and where they would find them. The Kitfox is in a secured area of a nearby aircraft "boneyard" and I finally recieved the copy of the insurance claim to file - the first came shortly after the accident, but we had so many local friends cleaning up our house for us we can't find anything anymore. I still have personal items in the airplane - my small overnight bag etc. which are available to me as I can arrange for a pick up, but the airpane, according to the FAA is essentially owned by the insurance company, unless I make other arrangements. All in all everything is going well - stronger every day and the appetite is improving despite the brace limiting both lung and stomach capacity. We are in good spirits and are grateful for the support we have had from so many. Thank you all so very much, Lowell and Kay ----- Original Message ----- From: "dave" <dave(at)cfisher.com> Sent: Wednesday, September 26, 2007 7:34 AM Subject: Kitfox-List: Lowell's oil pressure problem. ?? > > Lowell, > > I have a friend who has bought a 912 ul Kitfox IV and he is not on this > forum but he has heard about your accident. Have you determined what the > cause was of your loss of oil pressure that happened on your plane ? > > Certainly we can all learn from this hopefully. > > Glad to have read that you and your wife survived the forced approach. > > Dave > > -------- > Rotax Dealer, Ontario Canada > Flying Videos and Kitfox Info > http://www.cfisher.com/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=136538#136538 > > > ________________________________________________________________________________
Date: Sep 26, 2007
Lowell, thank you so much for the update. You are in all of our thoughts and we share to the extent possible what you are experiencing. John Kerr -------------- Original message -------------- From: "Lowell Fitt" <lcfitt(at)sbcglobal.net> > > Dave, > > Thanks for the post and if you don't mind, I will use this opportunity for > an update. First, I have no real idea as to the cause of the low oil > pressure indication. A friend at the accident scene checked the oil tank > and it contained oil. Just how much, I don't know as he had never seen me > check the oil and he had no idea what full was. > > Tomorrow marks the fourth week since the "rough" landing. Kay and I are > doing fine and are pretty much able to take care of each other. I am still > in the "clam shell" brace who a friend reminded me resembles almost exactly > the chest covering costume of the Ninja Turtles, though mine is a boring > white. Another friend mentioned that it would be a better design if it had > cup holders molded into it. That would be nice at times. It does make an > adequate table, though, when lying down eating. > > I mention the brace as I am not allowed up without it and showering is > prohibited until at least the 6th week. For that reason I do need help with > a sponging off every other day and have help in that area. Kay can't do it > as she is still in her cast from the broken and pinned thumb. > > I met with the FAA a couple of weeks ago and recieved calls from AIG and > NTSB. The former and latter are interested in having Rotax look at the > engine and instrumentation to determine the cause of the low oil indication. > And AIG was most helpful, reminding me that the passenger liability applied > to Kay, even though she was my wife. I couldn't be more happy with the > insurance company. > > I can't finish whithout a mention of the big four. These are the documents > all three entities will be most interested in. Make sure your log book has > your latest BFR logged and it is current. Make sure your license and > medical are current and in your possesion and of course make sure the annual > condition inspection is logged in your aircraft log book. The FAA also > asked about the Airworthiness Certificate and the Registration. I told them > they were in the aircraft (where they should be) and where they would find > them. > > The Kitfox is in a secured area of a nearby aircraft "boneyard" and I > finally recieved the copy of the insurance claim to file - the first came > shortly after the accident, but we had so many local friends cleaning up our > house for us we can't find anything anymore. I still have personal items in > the airplane - my small overnight bag etc. which are available to me as I > can arrange for a pick up, but the airpane, according to the FAA is > essentially owned by the insurance company, unless I make other > arrangements. > > All in all everything is going well - stronger every day and the appetite is > improving despite the brace limiting both lung and stomach capacity. We are > in good spirits and are grateful for the support we have had from so many. > > Thank you all so very much, > > Lowell and Kay > > ----- Original Message ----- > From: "dave" > To: > Sent: Wednesday, September 26, 2007 7:34 AM > Subject: Kitfox-List: Lowell's oil pressure problem. ?? > > > > > > Lowell, > > > > I have a friend who has bought a 912 ul Kitfox IV and he is not on this > > forum but he has heard about your accident. Have you determined what the > > cause was of your loss of oil pressure that happened on your plane ? > > > > Certainly we can all learn from this hopefully. > > > > Glad to have read that you and your wife survived the forced approach. > > > > Dave > > > > -------- > > Rotax Dealer, Ontario Canada > > Flying Videos and Kitfox Info > > http://www.cfisher.com/ > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=136538#136538 > > > > > > > > > > > > > > > > > > > > > > > > >
John Kerr
> --> Kitfox-List message posted by: "Lowell Fitt"
> Dave,
> the chest covering costume of the Ni nja Turtles, though mine is a boring
> insurance company.
> them.
&g t; the airplane - my small overnight bag etc. which are available to me as I
> arrangements.
> Lowell and Kay
> ----- Original Message ----- <BR>> From: "dave" <DAVE(at)CFISHER.COM><BR>> To: <KITFOX-LIST(at)MATRONICS.COM><BR>> Sent: Wednesday, September 26, 2007 7:34 AM
> > --> Kitfox-List message posted by: "dave"
> > Lowell,
Date: Sep 26, 2007
It seems to me that it would depend on the relative strength of the three leaves versus the one-, or two-leaf spring that it is replacing. When I take my plane with its three-leaf spring out of the hangar, it goes over a bumpy area and the tail bounces up and down a bit, and I can see the leaves flexing, so I know the spring action is taking place and not just remaining stiff and transmitting that energy straight up into the tail. I also got to thinking about how much weight is back there. Mine weighed 43 pounds empty at the weigh-in, but the plane never flies empty, so fuel and pilot weight have to be considered when you think about how much weight the spring has to support. I can easily lift my tail when the tanks (26 US gallons) are low, but it becomes a chore when they are full. Lynn Matteson Grass Lake, Michigan Kitfox IV Speedster w/Jabiru 2200 flying w/400+ hrs On Sep 26, 2007, at 2:01 AM, Michel Verheughe wrote: > > > On Sep 26, 2007, at 2:48 AM, dave wrote: >> looks like it has been repaired before? >> Rusty too ? > > .... Okay, when I read Michel's email yesterday night, it was > through my ISP web interface and I didn't see the photos (plain- > text-only interface). Today, Dave's answer made me think there was > some photos attached. I went to the forum.matronics.com and saw > them. Yes, there is a bit of rust there but ... it brought a > question to my mind. > My Kitfox model 3 was delivered and built with one spring leaf that > lasted about 950 landings before breaking. I have now a new main > leaf and a 'helper.' I read that most people (and John sells) a > three-leafs set. I see that it is what Michel has. Then I wonder. > If the plane is designed for one leaf and it is later changed to > three ... is it wise? I mean, three leaves doesn't reduce the load > on the tail when landing or taxiing on rough surface. If it > prevents the spring to break, doesn't it then invite rupture to > happen somewhere else? Just wondering. > > Cheers, > Michel Verheughe > Norway > Kitfox 3 - Jabiru 2200 ________________________________________________________________________________
Subject: Re: Update on Lowell Fitt
Date: Sep 26, 2007
Do we have a more complete description of this emergency off-field landing, and the execution of it, because of 'low oil pressure'? what was it that prevented a return to base? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136611#136611 ________________________________________________________________________________
Date: Sep 26, 2007
Lowell , thanks for update. And please let us know what the cause was to low oil pressure " indication" Was there any evidence of low oil pressure other than the gauge? IE increased temps, engine noise etc ? you said that oil was found in tank which is good but was it being pumped or just not indicated ? There are thousands of 912s out there and hopefully we can find out what happened. Dave > Posted: Wed Sep 26, 2007 10:34 am Post subject: Lowell's oil pressure problem. ?? > > -------------------------------------------------------------------------------- > > Lowell, > > I have a friend who has bought a 912 ul Kitfox IV and he is not on this forum but he has heard about your accident. Have you determined what the cause was of your loss of oil pressure that happened on your plane ? > > Certainly we can all learn from this hopefully. > > Glad to have read that you and your wife survived the forced approach. > > Dave > > -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136612#136612 ________________________________________________________________________________
Date: Sep 26, 2007
Subject: Re: External Alternator for 912S on Model 7?
The pad for the vacuum pump on the 912 series will also take an alternator. Does anyone know of a pad mounted alternator that will fit a 912S? I have done a google search but none specifically say they will fit the 912. C. David Estapa Woodstock, Georgia N97DE S5TD 912ULS (Phase 1) Does anyone on the board have experience with the Rotax external alternator and the 912S/Model 7 combination? I'm nearing the completion of Kitfox 7 and will need more electrical power than is available with the internal alternator. I'm wondering if the alternator will fit under the cowl. Thanks for the help, Chris See what's new ="_blank">Make AOL Your Homepage. ________________________________________________________________________________
Date: Sep 26, 2007
Michel asks: >Good to hear from you, Lowell! May I ask you: since you ended upside >down, you pitchpoled, didn't you? How did it happen? An obstacle on >the ground? I can't speak for Lowell but from the photos I've seen, the airplane was upright when it came to rest, Michel. Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Date: Sep 26, 2007
> so can anybody send me some good clear pictures of this tail section (before covering) so that I can see how the fuselage should be normally ? Michel, here is a picture of a Classic 4 tail wheel bolt tubing. Note the drain holes in the fabric to let the rain water out. -------- Tom Jones Classic IV, Phase one 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136628#136628 Attachments: http://forums.matronics.com//files/tail_spring_bolt_tubing1_146.jpg ________________________________________________________________________________
Date: Sep 26, 2007
Lowell, Glad that you both are doing better and will recover. This incident makes me wonder about the fantastic claims of some oil additives that show engines running with the drain plug removed and zero oil pressure for long periods. Prolong is a brand that comes to mind. I'm not wanting to start a oil debate, really. Just wondering if it would have worked. -- Rex Hefferan SE Colorado / K-II / 582-C / still waiting repairs Lowell Fitt wrote: > > I met with the FAA a couple of weeks ago and recieved calls from AIG > and NTSB. The former and latter are interested in having Rotax look > at the engine and instrumentation to determine the cause of the low > oil indication. And AIG was most helpful, reminding me that the > passenger liability applied to Kay, even though she was my wife. I > couldn't be more happy with the insurance company. > ________________________________________________________________________________
Subject:
Date: Sep 26, 2007
Hello all fellow foxers, After all the posts about tail wheel trouble I feel obligated to share an incident that occurred on September 1, 2007. My son and I were taking off in our Model V when just before rotation I lost all control. The plane veered left and made a 45 degree beeline to the side of the run way which sat on top of a hill. There was no swerving left or right. There was just no control. We cartwheeled nose over wing and ended upside down. The plane was a total loss. My son and I were unharmed but our hearts were broken. The FAA investigator says it may have possibly been due to a broken bolt that held the assembly together. My son happened to be filming our takeoff from the cockpit so I have the whole thing on DVD. I am only posting this in hopes that it will save further heartache in the future. I welcome any questions that anyone may have. Michael Stanard Crumpled Model V ________________________________________________________________________________
Subject: Re: No Title
Date: Sep 26, 2007
Sorry to hear about your loss. Glad no one was hurt. I was wondering if you could share some more info about that bolt. What assembly does it hold together? > The FAA investigator says it may have possibly been due to a broken bolt that held the assembly together. -------- Luis Rodriguez Model IV 1200 Rotax 912UL Flying Weekly Laurens, SC (34A) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136652#136652 ________________________________________________________________________________
Date: Sep 26, 2007
Good job on the forced approach Lowell. I have been flying for nearly 30 years and had 4 realtime forced approaches myself in various aircraft. -loss of power Cessna - landed at International airport - carb fell off - Rotax home built - landed in field fixed and took off again - carbon fouled plug on single ignition hombuilt - landed in field fixed and took off again - prop departure - home built - dead-sticked into field, got a trailer , loaded and took back to shop. Could not fly out as the engine was hanging by just a few bolts and lines, some were sheared off. It is a sudden shock when it happens and the latter of the 4 incidents was the most sudden and shocking as the windshield blew out , door s popped open and dash literally fell into lap. Luckily I did ok on it and never even had to do a diaper change Anyone who would second guess a forced approach has likely never had one. You likely have seen them but i did a few dead-stick videos on you tube last year as well as an airstart. go to www.cfisher.com look for link to you tube . Please ;et us know what caused the low oil temps and pressure . Was it a 912 UL or 912 s ? Dave -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136657#136657 ________________________________________________________________________________
Date: Sep 26, 2007
Michel , I took some pics for you of my tubes inside the inspection hole. hope this helps you. PS -- You will notice I found my missing Garmin antenna. THANKS !! -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136658#136658 Attachments: http://forums.matronics.com//files/tailwheel_016_131.jpg ________________________________________________________________________________
Date: Sep 26, 2007
Michael , Whoa !! sorry to hear this . Sounds like the rudder got stuck somehow ? Glad that you are both ok. Dave -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136659#136659 ________________________________________________________________________________
Subject: Re:
Date: Sep 26, 2007
Oh, no, Michael! Damn. I'm glad you both got out of it ok. Man, this is truly shocking, and sad. Lynn On Sep 26, 2007, at 7:51 PM, MA Stanard wrote: > Hello all fellow foxers, > > After all the posts about tail wheel trouble I feel obligated to > share an incident that occurred on September 1, 2007. My son and I > were taking off in our Model V when just before rotation I lost all > control. The plane veered left and made a 45 degree beeline to > the side of the run way which sat on top of a hill. There was no > swerving left or right. There was just no control. We cartwheeled > nose over wing and ended upside down. The plane was a total loss. > My son and I were unharmed but our hearts were broken. The FAA > investigator says it may have possibly been due to a broken bolt > that held the assembly together. My son happened to be filming our > takeoff from the cockpit so I have the whole thing on DVD. I am > only posting this in hopes that it will save further heartache in > the future. I welcome any questions that anyone may have. > > Michael Stanard > Crumpled Model V > http://www.matronics.com/Navigator?Kitfox-List_- > ============================================================ _- > forums.matronics.com_- > =========================================================== ________________________________________________________________________________
Date: Sep 26, 2007
Yes the Rotax electrical power leaves something to improve upon. Nobody wants the vac pump location because the rpms at that location are way to low = low amps. Best bet is the belt driven unit which has an added pulley behind the prop. Some cowls will need a small bubble. The Europa guys put an alt on the end of the crank, but the Kitfox engine truss and short clearances will defeat that concept. I tried to design a stator pulley to avoid the bubble but could not find enough clearance for even the smallest alt. The front belt might work with a John Deere PM alt without a bubble since the alt is so small. Seems like I remember that alt was around 20a? I suspect you will have to design your own brackets. Do a Google search for a Canadian source version of the big buck Rotax auxiliary belt driven alt. Paul ================== At 03:19 PM 9/26/2007, you wrote: >The pad for the vacuum pump on the 912 series will also take an >alternator. Does anyone know of a pad mounted alternator that will >fit a 912S? I have done a google search but none specifically say >they will fit the 912. > >C. David Estapa >Woodstock, Georgia >N97DE S5TD 912ULS (Phase 1) > > >CDE2fly(at)aol.com writes: >Does anyone on the board have experience with the Rotax external >alternator and the 912S/Model 7 combination? I'm nearing the >completion of Kitfox 7 and will need more electrical power than is >available with the internal alternator. I'm wondering if the >alternator will fit under the cowl. > >Thanks for the help, > >Chris ________________________________________________________________________________
Subject: low oil pressure
Date: Sep 26, 2007
interesting reading http://www.tsb.gc.ca/en/reports/air/1997/a97o0055/a97o0055.asp?print_view=1 -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136704#136704 ________________________________________________________________________________
Date: Sep 26, 2007
Stuart: Saw your name. Contact me off the lisr at: tstuarticehouse.net (Speedster- CDAL, ID.) -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of stuart.jr Sent: Wednesday, September 26, 2007 1:42 PM Subject: Kitfox-List: Re: Update on Lowell Fitt Do we have a more complete description of this emergency off-field landing, and the execution of it, because of 'low oil pressure'? what was it that prevented a return to base? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136611#136611 ________________________________________________________________________________
Date: Sep 26, 2007
After my accident my passenger and I spent some time discussing the what-ifs. What if we had been higher? What if the plane had rolled to the right rather than the left? What if...? Obviously, you can play that game both ways. What if we had been lower? What if we had hit harder? It didn't take long to realize that such musing were worse than pointless. It's easy to be a Monday morning quarterback but Lowell's right. The way to produce a successful outcome in an emergency situation is to practice that situation until your responses become instinctive. Mike G. N728KF Phoenix, AZ ________________________________________________________________________________
Subject: Re: low oil pressure
Date: Sep 27, 2007
Excellent reading. Thanks maybe it will help prevent future accidents . -------- FLY FUN FLY LOW FLY SLOW John Perry Kitfox 2 N718PD 582 cbox 2:62-1 IVO IFA WHEELS NorthAire Floats Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136799#136799 ________________________________________________________________________________
Date: Sep 27, 2007
Would you please give us the name of that company and the web site if they have one. thanks, Paul cannon lite squared 912S still building ________________________________________________________________________________
Date: Sep 27, 2007
Date: Sep 27, 2007
The message is ready to be sent with the following file or link attachments: IMG_0255 ________________________________________________________________________________
Subject: aquamaster floats ???
Date: Sep 27, 2007
I buddy just called and asked if I knew anything about aquamaster floats. He said the guy he got them from said they were for a Kitfox. My buddy just picked up a KF mod I from a guy in CA and is having it shipped up here. I did a quick google searched and cant find anything on these floats. If anyone has any info on them please let me know. This set is 12' long. I am looking for buoyancy info if at all possible. Thanks -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136859#136859 ________________________________________________________________________________
From: "Michel Dierick" <michel.dierick(at)skynet.be>
Date: Sep 27, 2007
I asked the previous owner. The aircraft has been previously repaired after a former bolt rupture. It looks like it hasn't been repaired very properly. I'll see this weekend with a mecanic. Jazeem The paint on your tail section surely looks waaay better than on mine. :) :) Greetz -------- Flying, yes, but fly safely Michel "TheDailyFly" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136866#136866 ________________________________________________________________________________
Subject: Re: fantastic Oil Claims
Date: Sep 27, 2007
Many years ago a friend of mine ran a C210 in solid IFR for almost an hour with no oil pressure. He had used Microlan. wish we could use in the 912, but I think it will damage the clutch in the gearbox. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136881#136881 ________________________________________________________________________________
Date: Sep 27, 2007
Here's a URL for Aqua Floats. http://www.aquafloat.com/ Could the "Master" part of the name be one of their designations for a particular series of their floats? I remember flying a C-180 on Aqua floats in SE Alaska in 1969. Seems the floats were OK, but a bit boxy looking compared with the Edo brand, as I recall. John Hart -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of akflyer Sent: Thursday, September 27, 2007 3:30 PM Subject: Spam: Kitfox-List: aquamaster floats ??? I buddy just called and asked if I knew anything about aquamaster floats. He said the guy he got them from said they were for a Kitfox. My buddy just picked up a KF mod I from a guy in CA and is having it shipped up here. I did a quick google searched and cant find anything on these floats. If anyone has any info on them please let me know. This set is 12' long. I am looking for buoyancy info if at all possible. Thanks -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136859#136859 ________________________________________________________________________________
Subject: Re: Spam: aquamaster floats ???
Date: Sep 27, 2007
I will have pics this evening, but these are a fiberglass float, the aquas are aluminum. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136894#136894 ________________________________________________________________________________
Date: Sep 27, 2007
Please verify address.. is it tstuart(at)icehouse.net? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136908#136908 ________________________________________________________________________________
Subject:
Date: Sep 27, 2007
What assembly was the possible broken bolt holding together? Inquiring minds want to know. Andy F. -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of MA Stanard Sent: Wednesday, September 26, 2007 6:51 PM To: kitfox-list(at)matronics.com Subject: Kitfox-List: Hello all fellow foxers, After all the posts about tail wheel trouble I feel obligated to share an incident that occurred on September 1, 2007. My son and I were taking off in our Model V when just before rotation I lost all control. The plane veered left and made a 45 degree beeline to the side of the run way which sat on top of a hill. There was no swerving left or right. There was just no control. We cartwheeled nose over wing and ended upside down. The plane was a total loss. My son and I were unharmed but our hearts were broken. The FAA investigator says it may have possibly been due to a broken bolt that held the assembly together. My son happened to be filming our takeoff from the cockpit so I have the whole thing on DVD. I am only posting this in hopes that it will save further heartache in the future. I welcome any questions that anyone may have. Michael Stanard Crumpled Model V ________________________________________________________________________________
Subject: Re: Down wind Float TO
Date: Sep 28, 2007
Sure. On a twisty river in mountains. If leaving a city, so you're headed away from the buildings. Bob Vixen part-built Damascus, Md -------- Remember that internet advice may only be worth what you pay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136946#136946 ________________________________________________________________________________
Date: Sep 28, 2007
Michel - Sorry to hear that you need to repair your KF. It looks like the hole has taken a beating and I'm wondering if the bolt/nut was tight. Find the remaining head or other portion of the bolt and show it to a metallurgist. He can tell very easily if the bolt was involved. For example, did th ebolt have a flaw, break in overload, had it cracked long before the failure, or did it break only after numerous cycles of use (as if loose)? Bob A&P, Aero Eng -------- Remember that internet advice may only be worth what you pay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136948#136948 ________________________________________________________________________________
Subject: Re: czech floats
Date: Sep 28, 2007
Hey gang, I want to briefly reply to all of your comments about floats, but am on a time crunch getting ready for a week plus float plane trip to northwest ontario in a Beech 18 with two of my buddies. But when I return, I would be happy to respond to any of the float questions Noel, Michael, and Joe have asked me to explain further. So remind me in about a week and a half. Briefly; John; Thanks for the compliment about what I wrote. Fwiw I do write articles for magazines - check out EAA's August 2006 Sport Pilot for an article I wrote on LSA seaplanes and converting one to floats. Noel; Yes, there are a lot of times a downwind takeoff and landing are needed or at least preferred. I can explain further later. Michael; I'd be happy to give you some good tips on the aerocet float install on your airplane. I think I've learned a lot about what to do and not do with these floats. Would love to see you be able to successfully operate yours. Plus, I can put you in contact with others who have info to share on the aerocet 1100 as well. We've developed a good communications amongst a small group of us aerocet 1100 float flyers, and sharing info between us has proven extremely valuable. Greg and everybody else; I will be happy to explain more about my new floats to you when I return. To make a long story short, they will be a float specifically designed for airplanes like we (me included) like to fly. So having flown Avids and Kitfoxes (as well as other G.A. aircraft) since the mid 80's on floats, I know what we need, and what we don't need. And as I said before, as far as I'm concerned we currently have no good choices out there (sorry, just my opinion..). But my float will change that. It has been in development for over a year now, but I'm not just eyeball engineering things here. I sought out true experts to help me. Running EAA's AirVenture Seaplane Base, and being around the seaplane crowd for a quarter century has provided me with many contacts that have an incredible amount of float operating and building experience, and they were willing to share their knowledge because we're friends. Combining that expert help along with my seaplane flying background, and my frustration over not having a good float choice, I'm convinced will provide guys like us with a marvelous amphib float. Oh yeah, and I promised myself I'd do all I can to make it reasonably priced. I remember not too long ago when I had to scrimp and save to buy my first set of inexpensive floats. So I want to make sure my float is a real value, and is as affordable as I can make it without sacrificing quality. Hopefully this will help you all to understand better where I'm coming from, and why I'm passionate about producing a great float for our airplanes. (see the pic attached if you want an approximate idea what my new floats will look like. Will be very similar to that... but better!) Talk to you all in about a week and a half! Paul Seehafer Kitfox IV 912ul amphib Central Wisconsin ----- Original Message ----- From: "john oakley" <john(at)leptron.com> Sent: Tuesday, September 25, 2007 11:25 PM Subject: RE: Kitfox-List: czech floats > > Paul, > That is the greatest report on floats I have seen. I am thinking you need > to > quit your job and write for a magazine. :-) Honestly that is what many of > us > want to hear, One persons experience and feelings. I now believe you are > capable of making a great set of floats. I along with many others are > waiting for more info on your system. I learned from you about how many > compartments there need to be, also the storage area's is a must, I had > forgotten the aerocet had them. I actually put my kids in the floats with > their heads sticking out and dressed like elfs, me as santa.( they will > never forgive me) > Any picture of the floats you want to share. > > Again, thanks > John Oakley > Fox 4 speedster long and short > 912 ul > > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Seehafer > Sent: Tuesday, September 25, 2007 5:22 PM > To: kitfox-list(at)matronics.com > Subject: Re: Kitfox-List: czech floats > > Greg, > > I have 25 years of float flying experience, with a total of 2200 hrs in > seaplanes. 1300 hours of that seaplane time has been in various light > sport > > type aircraft. I have a bit more than 30 hours in an amphibious Czech > float > > equipped Rans S-7 with a Rotax 100 hp 912s for power. Aircraft empty > weight > > on wheels around 670 lbs, and right close to 900 on floats. The floats are > the 4 wheel option 1150/1200a amphibs. > > The floats work, but lack forward floatation, as well as total floatation > for the Rans (note how low the spreader bars are to the water in the > attached picture. Also, the rear seat passenger weight is actually is > helping keep the front of the floats up. Otherwise the bows would be > plowing water over the top when idling). The landing gear has no > suspension, and while the main gear does have a down lock, the nosegears > are > > held down purely by hydraulic pressure, consequently causing concerns > about > gear collapse in the case of hydraulic failure, The hydraulic cyls also > tend > > to leak when sitting with the weight of the airplane on them. The other > problem with the floats is that they are approx 15 1/2 ft in length, and > that causes you not to be able to rotate well without dragging the heels > (which will consequently also keep you from leaving the water). This a a > common problem with many older float designs as well. While a long float > offers a nice ride and lots of good tracking and stability, they limit > your > ability to take off short because you can't rotate into a steep attitude. > For those reasons I personally would always choose a short float over a > long > > one if the floatation was similar. Oh yeah, a Rans S-7 is longer than my > Kitfox IV by almost 5 ft, so the Kitfox would really suffer from not being > able to rotate due to the float being so long for the airplane. The Czech > floats on this Rans also only have 2 watertight compartments / pump outs. > That would never pass muster for a certified float, as it puts the > airplane > at risk of capsizing if ever one compartment were to leak and fill with > water. The good news there is that the later Czech floats are known for > not > > leaking much water. But if you ever hit an underwater obstruction and > poke > a hole in your float, you have little or no reserve buoyancy with 50% of > one > > float only left watertight. > > Another thing I don't like about the Czech floats is they are > hydrodynamically very draggy. Example, last time I flew this Rans I was > doing a downwind takeoff in a 10 mph wind and no matter what I did I > couldn't get enough forward water speed to lift off. I tried everything, > but finally stopped and turned into the wind and took off no problem. > That > whole issue is caused by too much reveted skin area causing excess water > drag and limiting the ability to accelerate on the step. And being that I > fly my Aerocet equipped Kitfox also, I guess I am spoiled as downwind > takeoffs are never a problem, even though I have 20 hp less than the Rans, > and less wing area. The Aerocets having a smooth fluted bottom have let > me > acclerate easily for a takeoff at gross weight in a 25+ mph downwind > before > (ps - don't try this at home - I've been flying floats for a lot of > years... > > Go into the wind like our flight instructors tell us to). I also don't > like > > the fact that there are no storage areas in the czech floats. > > Ok, so what do I like about the Czech floats? Ground handling is good, > and > brakes work pretty good or an amphib. Water rudders are sufficiently > sized, > and the floats will get you off the water relatively quick as they use a > pretty flat bottom. Of course, since nothing is ever free, rough water is > not the Czech floats forte. > > I currently am flying my Kitfox 912ul Model IV on Aerocet 1100 amphibs. It > weighs 630 lbs on wheels and 776 on amphibs. Those floats too have a lot > of > issues, with underfloatation being the biggest problem, and a weak landing > gear second. But other than that it is hands down the best handling float > you will ever fly (I can do a 600-800 foot circular one float takeoff! > Yeah, they handle that good...) > > Because I don't think we have a decent choice out there currently for an > amphib float for our planes, I designed my own with all the features I > wanted, and felt we need. I am in final design stages and will be going > into production soon (has been a MUCH bigger job than I ever expected. Oh > well, all good things take time they say...). I expect to have floats > available 1st qtr of 2008. Pricing is targeted to compete with the Czech > floats. And it will be an attractive float with a real landing gear and > nice > > storage (read as "Not anything weird"). I will let the group know here > as > I progress with production. The Kitfox is one of my favorite airplanes, > so > I hope to set up a Kitfox as one of the first airplanes on my new floats. > > Paul Seehafer > > ps - did those Avid amphibs not work out for your? > > > ----- Original Message ----- > From: "Gregory Cronin" <greg@case-assembly.com> > To: > Sent: Monday, September 24, 2007 10:46 AM > Subject: RE: Kitfox-List: czech floats > > >> <greg@case-assembly.com> >> >> Is anyone here flying the Czech floats currently? >> >> If so please let us all know what you think. >> >> Thanks! >> gc >> >> 1:53 PM >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: aquamaster floats ???
Date: Sep 28, 2007
here are a few pics of the floats.. I have never seen them before.. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137049#137049 Attachments: http://forums.matronics.com//files/dscf0003_561.jpg http://forums.matronics.com//files/dscf0002_570.jpg http://forums.matronics.com//files/dscf00011_176.jpg ________________________________________________________________________________
Date: Sep 29, 2007
With that tunnel design I can see where they may be very efficient. I would like to try a set before purchasing though. Like tunnel boats they may not be able to take too rough water but on reasonably calm water I can see how you could be off very fast. On rougher water they could transmit a lot of pounding to the airframe. Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of akflyer > Sent: Friday, September 28, 2007 7:04 PM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: aquamaster floats ??? > > > > here are a few pics of the floats.. I have never seen them before.. > > -------- > Leonard Perry > Soldotna AK > Avid "C" / Mk IV > 582 IVO IFA > Full Lotus 1260 > 95% complete > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=137049#137049 > > > > > Attachments: > > http://forums.matronics.com//files/dscf0003_561.jpg > http://forums.matronics.com//files/dscf0002_570.jpg > http://forums.matronics.com//files/dscf00011_176.jpg > > > > > > > > ________________________________________________________________________________
Date: Sep 29, 2007
my thoughts exactly... They are only 12' long, but look to be pretty wide so hopefully they will have enough buoyancy..I will carefully fill them with water and measure it out so I can figure out displacement. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137143#137143 ________________________________________________________________________________
Date: Sep 29, 2007
Bum a set of scales form a transport co. for an hour or two... Or even weigh scales on the highway. Weigh a float or a float on a trailer empty then fill to the "appropriate level" of water and weigh again. The difference in the weight will be your displacement. Around here the portable scales the highways department carries for highway spot checks are more than accurate enough to read your displacement within three or four pounds. Weighing a float can break up a day for the inspectors.... Remember to pump the water out before carrying on the highway though. Noel > -----Original Message----- > From: owner-kitfox-list-server(at)matronics.com > [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of akflyer > Sent: Saturday, September 29, 2007 3:06 PM > To: kitfox-list(at)matronics.com > Subject: Kitfox-List: Re: aquamaster floats ??? > > > > my thoughts exactly... They are only 12' long, but look to > be pretty wide so hopefully they will have enough buoyancy..I > will carefully fill them with water and measure it out so I > can figure out displacement. > > -------- > Leonard Perry > Soldotna AK > Avid "C" / Mk IV > 582 IVO IFA > Full Lotus 1260 > 95% complete > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=137143#137143 > > > > > > > > > > > ________________________________________________________________________________
Subject: 4 stroke engine
Date: Sep 30, 2007
I have been looking around for an alternative engine to get a bit more power for my Avid. 65 HP is fine for wheels and pounding pavement but that is just not what I am into. I have been looking at the Arctic Cat 660 turbo for awhile now and think this may warrant really looking into what it will take to put the "C" gear box on it. Raven RE-drive has been using the 3 Cylinder Suzuki engine for awhile now with good success, but that was the car motor. This is the cut down version for the snowmachines. I am working on getting an AUW for the various components but It will for sure be better than the subie by a long shot. Stock it is a 72% increase in HP (110 HP @ 6700) and at cruise a 82% increase in torque... this means more pitch go faster at cruise.. If you want to monkey with boost and fuel curve etc the HP is nothing short of spectacular..just once I would like to take off on floats with 145 to 160 HP..Gotta be like flying a turbine otter empty with very little fuel. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137261#137261 Attachments: http://forums.matronics.com//files/dtrcat660jdpower2doc_199.pdf ________________________________________________________________________________
Subject: Re: 4 stroke engine
Date: Sep 30, 2007
You mentioned the 3-cylinder Raven, but have you checked into their 4-cylinder? The 1300 Suzi/Geo engine puts out 90-115 hp for a lot less money than a Rotax 912/912S. http://www.raven-rotor.com/html/redrive.html I guess it's the never-changing trade-off of power vs reliability, isn't it? The snowmobile racers can get a LOT of hp out of those their two-strokes, but they're replacing pistons on a weekly basis. The 582 is pretty conservative by comparison. There's an old rule of thumbs regarding not wanting to dip into the last third of anything. Make sure you have a third of everything as an absolute minimum reserve. A third of the hp beyond what you really need, a third of the torque (load), a third additional fuel and oil flow capability, etc. Bob -------- Remember that internet advice may only be worth what you pay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137264#137264 ________________________________________________________________________________
Date: Sep 30, 2007
I would say that it would be quite safe at 112 HP for take off.... That would be very conservative on what you really can do... and the snowmachine racers... The guys at the drags that are getting crazy HP outa the engine that is true.. some change pistons after almost every run, but for mild trail porting and tuning, it is nothing to go for years many thousands of miles and never do anything other than change plugs and clean power valves. With the new technology, fuel injection, ECU's, pipe sensors etc, alot of the old issues are now gone. you done have to worry about jetting for temps or altitude etc. I believe this is the largest contributing factor to all the bad wrap the 2 strokes have gotten. I know a guy locally that has had 5 or 6 engine outs, resulting in the loss of 2 aircraft. All because he know nothing about a 2 stroke and just wont listen when it comes to jetting and operations... the last one he barely hobbled away from and is still in a brace for his broken back. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137267#137267 ________________________________________________________________________________
Date: Sep 30, 2007
Check with B & C Specialties. They used to sell one that fit the 912ul. Stan Specht Kitfox Model IV Speedster "Columbine" (1250+ hrs) Denver, Colorado ________________________________________________________________________________
From: "Don & Dianne Usher" <denver7(at)xplornet.com>
Subject: re: 4 stroke engine
Date: Sep 30, 2007
A friend of mine has the 4 cylinder geo engine in his Rans courier on floats. It is the smoothest running aircraft engine I have ever heard, and he has not touched it in one hundred hours of use. Weighs just a little more than a 912 and he has about $6000 in it. Raven redrive bolts right onto it. Four cylinder, 16 valve, 100hp computer controlled for $6000, Not bad, and parts/service is readily availible and cheap. Don ________________________________________________________________________________
From: "Jay Fabian" <experimental208nd(at)comcast.net>
Subject: 912 UL Carb Needle index
Date: Sep 30, 2007
Hi List, I am pulling my Kitfox 4 out of the hanger after a while of not flying it. I have drained all the Auto fuel with10% alch in it, and just filled it back up with non alch auto gas from the airport. I had moved the Carb needle last year , as I was using the 10% eth gas and had problems. Now I am going to use the new gas but the needle settings are making the 912 run rough at the 2k RPM mark, but smooth at the 3k and higher settings. Out of the 4 slots on the needle, which one will give me the best operations? it is about 65 deg F OAT here in Ma. I started with the clip in the second slot from the bottom of the needle, ( Ran Bad) I moved it one notch up and got the same results, moved it to the bottom one and the low rpms are rough sounding like a Harley sound, middle rpms are fine. Any suggestions? i had this nipped in the but last year but now I am banging my head again Thanks Jay Fabian ________________________________________________________________________________
Subject: floats
Date: Sep 30, 2007
I have to sell my new full lotus floats. Home is on a beach that is always windy. either amphibs or nothing. Great performance with KF 3. Cruise at 80mph and off water in 8 seconds flat calm. Comes complete with rigging that allows main gear left in place. Takes one hour to change from wheels to floats. Have lots of pics email denver7(at)xplornet.com. Don ________________________________________________________________________________
Subject: Re: Tailwheel bolt went off.... and the rest
Date: Oct 01, 2007
Curious why you stripped the covering,Ihave a kitfox 4 with a 2leaf spring and no problems yet with the tail wheel...lots of 3 point landings..some graceful&some not... I have hear some folks are going to 3 leaf springs,maybe that might work as a solution.. Did you have a hard landing when this occured?, or do you think this is a structural failure in the mounting brackets,and/or metal fatage on the the bolts them selves.....A/N hardware? Note: epoxy braced fills [metal on wood] will give a harmonic that the wood might not support,succesfully causing a fracture in the high stress point... Thanks ...Mark..N61AC -------------- Original message from "Zimmermans" <jezim@pro-ns.net>: -------------- IMG_0255
Subject: Re: re: 4 stroke engine
Date: Oct 01, 2007
Thanks don,we needed more people like you to help our effort in after market engines,I fly my fox4 with a VW 2180 82hp and love it,parts are cheap,motor is around $6000.00 new and has a TBO of 1000 hrs. Rotax is way over priced in my opinion for what you get....there motto is market the Rich/famous/just those lost souls that can put it on there credit card....lol -------------- Original message from "Don & Dianne Usher" : -------------- A friend of mine has the 4 cylinder geo engine in his Rans courier on floats. It is the smoothest running aircraft engine I have ever heard, and he has not touched it in one hundred hours of use. Weighs just a little more than a 912 and he has about $6000 in it. Raven redrive bolts right onto it. Four cylinder, 16 valve, 100hp computer controlled for $6000, Not bad, and parts/service is readily availible and cheap. Don
-------------- Original message from "Don & Dianne Usher" <denver7(at)xplornet.com>: --------------
Don
Subject: Final Cerification
Date: Sep 30, 2007
Well I finally finished the 40 hr test period and received my non terminating Certificate on Airworthiness! Aircraft flying beautifully. John A New Zealand. Kitfox Series 5 EA 81 Turbo Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137373#137373 Attachments: http://forums.matronics.com//files/cath1st_ride_706.bmp ________________________________________________________________________________
Subject: ivoprop removal
Date: Oct 01, 2007
hi, first posting, i've got a 3 blade ivoprop on a c gearbox, 618 on mk3 kitfox, the engines has to be removed, i've taken out the big screw in the spinner, but it won't move at all, is it just brute force now to remove it or have i missed something? hot air gun perhaps? any input welcomed, thanks. ________________________________________________________________________________
Subject: Re: ivoprop removal
Date: Oct 01, 2007
I think you are asking how to get the spinner off.. It is possible that the spinner is corroded to the prop hub. nothing else should be holding the spinner on other that the screw in the end of it. -------- Leonard Perry Soldotna AK Avid "C" / Mk IV 582 IVO IFA Full Lotus 1260 95% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137396#137396 ________________________________________________________________________________
Subject: Throttle
Date: Oct 01, 2007
This is a question for those who have a 912 ULS engine and a push-pull throttle with a friction lock. I removed the verner throttle and installed a push-pull throttle. I flew it yesterday for the first time. It was hard to manage the throttle as the throttle springs would cause the throttle to creep open unless it was locked down tight. Did you remove the throttle springs, install lighter springs or do you just have to get used to locking the throttle? Any advice would be apprecated. Floran Higgins Helena, Mt Speedster 912ULS ________________________________________________________________________________
Subject: Throttle
Date: Oct 01, 2007
Floran, I removed the springs on my 912ul, it is much easier to use now and more airplane like. I have been using this for 8 years now. Just for a note, I also removed my chokes and installed an aircraft primer at the same time. It starts on the 2nd blade every time. John Oakley Speedster 4 long and short 912ul cap _____ From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of floran higgins Sent: Monday, October 01, 2007 8:12 AM Subject: Kitfox-List: Throttle This is a question for those who have a 912 ULS engine and a push-pull throttle with a friction lock. I removed the verner throttle and installed a push-pull throttle. I flew it yesterday for the first time. It was hard to manage the throttle as the throttle springs would cause the throttle to creep open unless it was locked down tight. Did you remove the throttle springs, install lighter springs or do you just have to get used to locking the throttle? Any advice would be apprecated. Floran Higgins Helena, Mt Speedster 912ULS ________________________________________________________________________________
Date: Oct 01, 2007
Hi John, it may have locktite on the threads of the bolt. I put locktite on the threads on mine to make sure it stays there. Jim model IV-912ul ________________________________________________________________________________
Date: Oct 01, 2007
Subject: Re: Final Cerification
At 11:48 PM 9/30/2007, you wrote: >Well I finally finished the 40 hr test period and received my non >terminating Certificate on Airworthiness! Aircraft flying >beautifully. John A New Zealand. Kitfox Series 5 EA 81 Turbo Congratulations John! I guess it's time for some cross country. Tell us a little about flying in New Zealand. I've heard a good bit about Australia, but nothing about New Zealand. Is it practical to go north/south to all the islands? What's the flying time between islands? What's the flying time end to end? Are there lots of strips? Is flying popular / necessary? Thanks, Guy Buchanan San Diego, CA K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 01, 2007
Congrats to you John. By the looks of the photo you've done an outstanding job building it and I'm sure you'll have many trouble free hours of flying. Regards, Deke Morisse Mikado Michigan S5/Subaru/CAP 365+ TT > > Well I finally finished the 40 hr test period and received my non > terminating Certificate on Airworthiness! Aircraft flying beautifully. > John A New Zealand. Kitfox Series 5 EA 81 Turbo ________________________________________________________________________________
Subject: Re: Throttle
Date: Oct 01, 2007
Thanks for the infromation. I installed the primer system several years ago.It starts much better than with the chokes Floran Higgins Helena, Mt. Speedster 912ULS ----- Original Message ----- From: john oakley To: kitfox-list(at)matronics.com Sent: Monday, October 01, 2007 8:37 AM Subject: RE: Kitfox-List: Throttle Floran, I removed the springs on my 912ul, it is much easier to use now and more airplane like. I have been using this for 8 years now. Just for a note, I also removed my chokes and installed an aircraft primer at the same time. It starts on the 2nd blade every time. John Oakley Speedster 4 long and short 912ul cap ------------------------------------------------------------------------- ----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of floran higgins Sent: Monday, October 01, 2007 8:12 AM To: kitfox-list(at)matronics.com Subject: Kitfox-List: Throttle This is a question for those who have a 912 ULS engine and a push-pull throttle with a friction lock. I removed the verner throttle and installed a push-pull throttle. I flew it yesterday for the first time. It was hard to manage the throttle as the throttle springs would cause the throttle to creep open unless it was locked down tight. Did you remove the throttle springs, install lighter springs or do you just have to get used to locking the throttle? Any advice would be apprecated. Floran Higgins Helena, Mt Speedster 912ULS ________________________________________________________________________________
From: "Frank Miles" <f.miles.tcp.833(at)clearwire.net>
Subject: Rotax 582 compressions
Date: Oct 01, 2007
Does anyone know what the normal compression range is for the Rotax 582? Second question; the engine manual speaks of decarboning the engine after so many hours, are the oil injected engines as prone to carbon as the engines with the fuel and oil mixed? Frank Miles Klll w/ 582 10:20 AM ________________________________________________________________________________
Date: Oct 01, 2007
Subject: Re: Rotax 582 compressions
At 10:12 AM 10/1/2007, you wrote: >Does anyone know what the normal compression range is for the Rotax 582? I couldn't find a recommendation. I get 118 to 125 psi, depending on the carbon load. I just use it as a relative number anyway. >Second question; the engine manual speaks of decarboning the engine >after so many hours, are the oil injected engines as prone to carbon >as the engines with the fuel and oil mixed? I've never heard of a difference in all the literature I've read. Bob Robertson did, however, say that he no longer de-carbons at 50 hour intervals, waiting instead until the 150 hour rebuild. I also found http://www.decalinchemicals.com/DeeCarb.html which I'm thinking of trying. I spoke with the developer and he had no experience with 2-strokes, but suggested it should work. (I already use his Decalin lead scavenger in my 582.) Guy Buchanan San Diego, CA K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Oct 01, 2007
Floran, my first question is, why did you remove the vernier throttle? That is what I would like to have. I don't like the friction throttle and plan to do something about it. I don't feel like removing the springs will solve my problems. The springs are there for a safety reason. My real problem is that the cables are all messed up on the ends and it is not apparent that the cables can be replaced in the throttle cartridge. Has anyone ever replace the cables in the friction throttle? Barry West ----- Original Message ----- From: john oakley To: kitfox-list(at)matronics.com Sent: Monday, October 01, 2007 9:37 AM Subject: RE: Kitfox-List: Throttle Floran, I removed the springs on my 912ul, it is much easier to use now and more airplane like. I have been using this for 8 years now. Just for a note, I also removed my chokes and installed an aircraft primer at the same time. It starts on the 2nd blade every time. John Oakley Speedster 4 long and short 912ul cap ------------------------------------------------------------------------- ----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of floran higgins Sent: Monday, October 01, 2007 8:12 AM To: kitfox-list(at)matronics.com Subject: Kitfox-List: Throttle This is a question for those who have a 912 ULS engine and a push-pull throttle with a friction lock. I removed the verner throttle and installed a push-pull throttle. I flew it yesterday for the first time. It was hard to manage the throttle as the throttle springs would cause the throttle to creep open unless it was locked down tight. Did you remove the throttle springs, install lighter springs or do you just have to get used to locking the throttle? Any advice would be apprecated. Floran Higgins Helena, Mt Speedster 912ULS ________________________________________________________________________________
Date: Oct 01, 2007
My current 582 in Kitfox IV has 582 which was brand new in June 2006 and has over 300 hours on it and NEVER been apart yet. I use only API-TC rated oil and the brand is Bombardier XPS mineral oil. My last plugs went 152 hours , here hey are here http://www.cfisher.com/152hournkg.html That being said, Rotax does recommend 150 hours so I maybe pushing the limit here. Time will certainly tell. I also use Rotax NGK plugs which some will argue but my experience shows they do last better. http://www.cfisher.com/ngk/ Plus the alum tips ones can cause you to blow your 5k ohm resistor caps. Call Bob and ask him :) this # is here TOLL FREE -tell him what a a dork i am for going 300 hours on my 582 Dave -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137458#137458 ________________________________________________________________________________
Date: Oct 01, 2007
I think it may be of some value to post a few pictures. The next time a spring breaks take a few pix so we can all see how/where the springs are cracking. I for one have never flown my 'Fox off any thing but water. The idea of wheels or better yet, skis, interests me. Noel -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of m4785(at)bellsouth.net Sent: Monday, October 01, 2007 3:25 AM Subject: Re: Kitfox-List: Re: Tailwheel bolt went off.... and the rest Curious why you stripped the covering,Ihave a kitfox 4 with a 2leaf spring and no problems yet with the tail wheel...lots of 3 point landings..some graceful&some not... I have hear some folks are going to 3 leaf springs,maybe that might work as a solution.. Did you have a hard landing when this occured?, or do you think this is a structural failure in the mounting brackets,and/or metal fatage on the the bolts them selves.....A/N hardware? Note: epoxy braced fills [metal on wood] will give a harmonic that the wood might not support,succesfully causing a fracture in the high stress point... Thanks ...Mark..N61AC -------------- Original message from "Zimmermans" <jezim@pro-ns.net>: -------------- ________________________________________________________________________________
Date: Oct 01, 2007
I would venture to guess that the ones who do more landings on rougher strips and off airfields will have more failures. I have the three leaf on now and no complaints - > YET < I rarely see paved surfaces - more roads than airports -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137465#137465 ________________________________________________________________________________
Subject: tail wheels
Date: Oct 01, 2007
Hi guys, I have been flying a grove aluminum tail spring for 8 years. Has any body been talking about them, has there been a problem you know of? John Oakley Speedster 4 long and short 912ul cap ________________________________________________________________________________
From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Date: Oct 01, 2007
I have the aluminum spring gear. I understand it is no longer offered. I nearly always land on rough fields. Should I be changing to a three leaf spring before I have problems? Randy Daughenbaugh, N10NH 180 hours Black Hills of South Dakota, - Near Mount Rushmore Home Strip, Grass Room in Hangar for visitors Series 5/7 (7 Firewall Forward) 912S, Warp Drive Taper Tip Gross Weight 1320 lbs, Flying since November 2004 -----Original Message----- From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of dave Sent: Monday, October 01, 2007 12:26 PM Subject: Kitfox-List: Re: Tailwheel bolt went off.... and the rest I would venture to guess that the ones who do more landings on rougher strips and off airfields will have more failures. I have the three leaf on now and no complaints - > YET < I rarely see paved surfaces - more roads than airports -------- Rotax Dealer, Ontario Canada Flying Videos and Kitfox Info http://www.cfisher.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137465#137465 1:32 PM
September 13, 2007 - October 01, 2007
Kitfox-Archive.digest.vol-fa
