Kolb-Archive.digest.vol-aa
March 07, 1996 - August 19, 1996
Date: Mar 07, 1996
Subject: ne
From: Cliff & Carolyn Stripling <striplic(at)flash.net>
Hi Everyone... I did not keep a record of my posts during the period of time the mail server was down. I think there were about 3 that didn't get sent. Progress on the MK III (about 85%) is slower (mostly being small details). I have about half my plane back from the paint shop and it looks great. They are doing a fine job. The right wing and vert. stab. have been permanently mounted. The nose cone has been bolted to the frame and basic instrument frame and front including instruments have been hinged to the cone. I have yet to make and mount the side brackets for the hinged frame to mount to and the glare shield that will be attached to those brackets. We have had some "cold for Texas" weather push down on us so I will stay out of the garage a few days. Yesterday, I ordered an ELT. Wag Aero had one for around $185 powered by "D" cells. The best price I had seen before was around $200 to 210. I also ordered a Skysport 7 joule strobe for $49. I am thinking about building my headsets and intercom from kits supplied by RST. Does anyone have any first hand knowledge of the RST products? Later, Cliff & Carolyn Stripling He - Kolb MK III builder (80%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
From: "Kirtland, Charles H." <KIRTLACH(at)pdc02.sch.ge.com>
Subject: ASI Calibration
Date: Mar 08, 1996
Group, I have a friend that has recently completed a Firestar II and is concerned about the accuracy of his ASI. I have bench-checked the accuracy of three local flyer s ASIs using the method outlined in February s "Experimenter" magazine, namely using a manometer tube and calculations of dynamic air pressure. All three check OK and read the same on the bench. In flight we all have different readings, my guess being due to static pressure differences. The readings are all high as compared to GPS readings. Our assumption on the Firestar II is that the mostly-enclosed cockpit creates a negative static pressure in the pod and is causing the higher speed reading. The other two ULs that fly with the Firestar (a Spitfire and a Tierra II) have similar high readings. My questions is (maybe Dennis ?) - exactly where on the Firestar II should a static pickup be mounted so that correct airspeed readings are obtained and how is the static pickup made? Also, in general for any aircraft, just how do you go about finding this correct static pressure place and know that the pressure is a true static pressure? Thanks. Charlie Kirtland ________________________________________________________________________________
Date: Mar 08, 1996
Subject: Drill bits
Since building a Kolb requires drilling a few thousand holes, most of the for 1/8" rivets, anything that makes this task easier is worth looking at. I was having trouble getting the holes precisely where I wanted them, even after using a snap punch. Then I found Black and Decker drill bits. These bits have what they call a bullet tip, a tiny starting point that just fits into the tiny depression made by the snap punch. Now the holes go exactly where I want them. As you all know by now, the 1/8" rivets do not fit into a 1/8" hole so you need a #30 drill bit. Black and Decker does not make the bullet tip bit in numbered sizes (as far as I know). So now I keep a #30 bit in my cordless drill. After drilling with the corded drill and the 1/8" Black and Decker bit, I run the #30 drill through the holes to enlarge them enough for the rivets. Happy drilling. _-_ _,, ,, -/ ) ; || ||_< \\/\/\ _-_ ||/|, _-_ ,._-_ bweber(at)micom.com || \\ || | | || \\ || || || \\ || ;/--|| || | | ||/ || |' ||/ || Keep the shiny _--_-' \\/\\/ \\,/ \\/ \\,/ \\, side up ( ________________________________________________________________________________
Date: Mar 08, 1996
Subject: T bracket for EGT probes
Hi Everyone... I remembered one of the messages that got lost. Everyone seems to be making a coil (like coil springs) out of the EGT prob wires. I needed a way to secure the ends of those coils to keep them away from the muffler and the side of the engine and secure the connections to the wire that runs up to the instrument panel. I made a T shaped bracket out of the thick scrap Lexan. One side of the cross bar of the T is longer than the other. I tie wrapped the probe ends along with the extension wires through holes drilled into the cross bars so that the coils float freely. I bent the vertical stem of the T in order to attach it to the steel tube of the fuselage with a couple of screw up type hose clamps. Now all the wires are secure and will stay in place. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (85%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Mar 11, 1996
Subject: Re: No Subject
The RST stuff that I have seen is quite good. I am told that there are only two suppliers for the speakers and microphones that all of the headset manufacturers use from dave clark on down. Dave Clark also makes a plastic helmet that a headset will fit into. It is a real neat product that they don't advertise, but any dave clark style headset will work with it. Its kind of nice because you don't have to have a dedicated helmet for kolb flying and a separate eadset for GA flying. Like all of the dave clark products it is obscenely expensive. ________________________________________________________________________________
Date: Mar 11, 1996
Subject: Re: ASI Calibration
I used a blade style pitot static pickup from a piper cherokee. I got it at lakeland for $20 because the pitot heat part was broken. I just yanked out the heating element anyway. I mounted it underneath the nose cone of my mark 3 at the back edge of the fiberglass. It looks pretty nice, and the nose skid will protect it in case of a nose over. Unfortunately I can't tell you how it works because I haven't flown yet. ________________________________________________________________________________
Date: Mar 12, 1996
Subject: Graphics Suppliers
Does anyone have a source for custom and/or stock vinyl graphics and pin striping for aircraft applications? Doug Prange Mark III Builder Lincoln, Nebraska evoice(at)acton.com ________________________________________________________________________________
Date: Mar 14, 1996
From: <Joe.Kohler(at)top.monad.net> manderson(at)monad.net
Subject: Joe's FS II "completion", weight and balance
The Kolb is finished. Well, more or less. I haven't run the engine. Need to wait for the snow to melt and the ground to dry to get it outdoors. It took approximately the allotted 400 hours, minus the "think time." I completed the weight and balance and the FS II is certainly fat at 355 pounds: this for a FS II with the fatter tires, heavier (but not streamlined) lift struts, brakes, 503 DC, aileron counterweghts, oil injection tank w oil, two coats Polytone on bottom and three on top (no silver), two fuel tanks, and BRS in wing chute for 750 gross. It is amazing how all this adds up. I guessed 325 would be my max weight, but I was off a bit. I'm not sure I want to get rid of any of the options I have, though I wonder about the two carbs and sort of wished I'd gotten the SC version. The brakes seem a little heavier than I think they could be, the aileron counter weights weigh just about as much as the ailerons, the mounting system for the chute seems a little heavy, and of course the oil injection adds about 5 lbs. Single carb w/o oil injection would save 10 pounds I would guess, and there would be no splitters and a lot less cables. The CG appears to be way back there at .35 (.37 max) with a 180 lb pilot (I'm a little fat too). I don't see that there is anything that can be done about the CG either. I'm curious how other FS II's are coming out weight wise and CG wise. The internal BRS fits nicely, but the mount seems heavy. I bet the cannister version is actually lighter. I finally got my EIS (engine instrument system) from Grand Rapids (Gregg) and I like it as much as I thought I would. In addition to all the engine instrument stuff, it has a fuel gauge input, altimeter, and vertical speed indicator. ________________________________________________________________________________
Date: Mar 16, 1996
Subject: Instrument Panel
Hi Everyone, I have to admit that it looks good, but the extended shock mounted instrument panel is extra work. Most of it went together real fast and easy until I got to the glare shield. I used the .025 sheet of aluminum supplied by Kolb for the sheer web of the wing gap seal (and needed every bit of the width of it). I built a shelf lip of fiberglass to attach the curved upper rear edge to give it a good curved support. The most difficult part is being sure you have a uniform gap between the glare shield and the edges of the instrument panel. The side braces were made from scrap pieces of Lexan from the windshield and a short piece of aluminum angle. The hinged bottom frame was made from aluminum angle with Lexan braces. All in all, I am glad I spent the extra time. Mounting the ELT on the side of the fuselage tube under the fuel tanks after cover was not difficult. There was adequate but blind clearance for drilling and riveting the bracket. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (90%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Mar 18, 1996
Subject: Just about finished!
Hi Everyone... I completely finished the instrument panel and it and the glare shield are all painted flat black... looks pretty good. I used some slit black tubing to protect me from the sharp edge of the glare shield that projects about 1" in front of the panel. In installed a piece of Lexan over the carpet on the floor up by the rudder peddles so that scrubbing heals can slide as well as not wear out the carpet. The Lexan also holds the carpet in place. I have attached all the decals, numbers and placards and re-assembled and riveted the canopy, doors, arm rest and bow tubes. I made a kill switch bracket for the dual igniton to tie wrap to the notch on the frame opposite the flap handle notch. I can't reach the instrument panel strapped in with the shoulder harness. My son is getting me a capacitor and a few electrical connectors and stuff to finish up the wiring in the engine area. I am still undecided about the radios. I was thinking about making up some RST kits for headphones/mic and for an intercom. I suppose I will mount the CB on a Lexan plate behind the pilot seat and use feel-a-vision for operation and the stock dynamic mic. I think I can combine the speaker output with proper resistors along with the ICOM through the intercom. I was thinking of making some kind of between-the-legs bracket for my ICOM so that I can see the face plate for operation. The intercom will probably fit beside or on the opposite side of the same plate as the CB. I will need to buy a PTT switch (and a Y splitter for both to transmit on the ICOM) and headset adaptor for the ICOM. It rained today. We've been in a severe draught. Bless the rain. I was going to pick up my other main wing at the high school paint shop today, but maybe tomorrow it will be clear. As soon as I get both wings back, I can get to work on the wing gap seal. I also had a local cushion shop make up some cushions that are ready to pick up. I hope they will look nice and fit properly. I am looking forward to Sun 'n Fun and possibly meeting some of you there. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (90%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Mar 20, 1996
Subject: Radio mount
I read Cliff's message regarding radio mounting. I thought about it quite a bit for my FS II and finally decided to mount it to the side of the fuselage trusswork tubing that rises diagonally to connect the bottom to the top longeron just in just forward of the seat on the left side. I used a couple of Adel clamps (those rubber covered aluminum clamps) that went around the 3/8" tubing and then attached to the accessory ICOM mounting bracket. The radio thus rests at a slightly inclined angle, and is not in the way, but is easy to read and tune from the pilots seat. I don't know if this would work on a Mark III. By the way, I used also used these clamps to attach the wiring harness in several places, and to anchor the pitot tubing to the top of the cowl so it wouldn't dangle into the rudder pedals. I also used two pairs of clamps to stand off the primer bulb from the fuse tubing between the top longeron and the engine mount: a pair of 1" clamps on each end of the bulb connected to a pair of 1/2" clamps on the fuse tubing. Works great. Does the typical ID plate that has the builders name, serial number, model, address etc. suffice also as the drug interdiction plate and is this usually mounted on the fuse tube just in front of the tailfeathers or do I need two separate plates? Can the "EXPERIMENTAL" be stuck on the inside of the sides of the fuselage fabric in the cockpit area, ie, behind the trusses, so it is visable from outside the cockpit without messing up the aesthetics by sticking it on the outside? ________________________________________________________________________________
Date: Mar 23, 1996
Subject: Kolb MK III
Hi Everyone... I found another use for the hand hold I put into the wing tips of both main wings. When wrestling with the tail to lift it or move it right or left when the plane is folded, the hand holds make it possible to actually lift the tail by the wing tips without breaking your back stooping down to pick up the tail wheel underneath the tail surfaces. The Second Chantz chute went into the cavity above the pilot's head very nicely. I have yet to rig the rip cord but it should not present a problem. The seats I had made locally by a cushion fabrication company (2.5" bottom X 1.25" back) fit like a glove and really finish off the interior and match the yellow paint perfectly. If anyone is interested, they cost me $25 each. They made mine from a paper pattern and they have many colors in stock to chose from. The instrument panel is finished, hung and wired/plumbed and looks nice all in flat black. If there is any builder out there who is just getting started, I have some left over supplies that might be helpful, mostly for free, but some at a reduced price. Things that I bought like paint (almost a gallon each of red & yellow), reducer, calibrated iron, finishing tapes, rib tape, anti-chafe tape, Polytac (1 full can), Stits fabric, snap punch, patterns, builders log & hints, etc. Some of the stuff I consider extra materials sent to me by Kolb I am returning to them if they want it (extra tubing, rivets, bolts, nuts, etc). E-mail if you are interested. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (95%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Mar 25, 1996
Dennis S. I don't know if you can be of any help on the new requirement by the FAA to submit a PROGRAM LETTER which is specific and meets the requirements of FAR 21.193 for experimental certification. The program letter must outline what flight characteristics, including the range or altitudes, airspeeds, aircraft maneuvers, and gross weight / c.g. configurations you plan on conducting to show that the aircraft controllability, maneuverability and stability is satisfactory and meets the requirements of FAR 91.319(b). If anyone has given you a copy of one they prepared, I would be appreciative of a copy to get an idea of exactly what the FAA wants. I am sending this out to the Kolb list as well so maybe somebody out there has a handle on this mumbo- jumbo (at least to me) request. Thanks to everyone - someone! I tentatively weighed my plane... Uh-Oh!!! It is a bit fat... not the typical 430. All those little modifications and a bi-color paint job DO add up... to around 470 (not counting any fluids or radios). Later, Cliff & Carolyn Stripling He - Kolb MK III builder (95%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Mar 26, 1996
Where did you get the notion you need a program letter for a kolb? As I understand it that only applies to experimental exhibition category aircraft. I am going to Lakeland in a 14 passenger russian biplane, an AN-2. That airplane is in experimental exhibition category four and requires a program letter to go anywhere. The normal 51% homebuilt is in the experimental category. The only thing you are constrained by is the operating restrictions issued to you by the FSDO. If this is something new I'd like to know about it. Please post details, ________________________________________________________________________________
Date: Mar 26, 1996
Cliff, regarding the program letter, I spoke with a fellow from the FAA today about getting my experimental certificate and I asked him about the Program Letter. He said it is required for Experimental - Exhibition and Research. It is not required for Experimental - Amature Built, which I'm sure is what you will be doing. My FS II is Ag Cat yellow and Pontiac red. What were your reds and yellows. Mine was also fat at 355 lbs vs. expected 325 and I didn't really add anything extra and kept the paint to a minimum. My CG was at the rear limit. ________________________________________________________________________________
Date: Mar 28, 1996
Subject: Inspection by another builder
Hi Everyone... I really think that having another builder (if you are fortunate enough to have one living nearby) look at your handywork as you progress is a very good idea. George A. has looked at mine several times (as well as a local EAA designee) and made some very good suggestions and pointed out some potential safety hazards. He was by yesterday and I spent part of today correcting some of his observations... actually only a couple of things. I bought some McGueir's Wax (the 3rd part of the 3 part system) and I plan to give the Polytone a protective coat. I tried it on a small area and it does a good job. It is not a polish, but it does protect and it is easy to apply. I am fastening my hoses and wires under the nose cone with tie wraps that I epoxyed to the inner surface of the cone. So far it seems to be working, but it is a pain to hold them in place long enough for the epoxy to harden... several minutes seems like an hour. I have heard from several sources that the "program letter" is not required for amateur built "experimental" certification. I will call the FAA office tomorrow and confirm for myself that that is correct. Sorry I caused a minor stir. It was nice to see the Kolb on Kitplanes magazine this month. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (95%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Mar 29, 1996
Subject: soft tires
Last wknd I pulled the wheels off to (again) see if I could determine why my left main wobbles so badly out of balance. I was also concerned that it looked like the inner tube was pulling around, straining the valve stem away from its hole thru the wheel rim. My particular setup is 6" Azusa aluminum wheels with large tundra tires (18" outside diam) including inner tubes. The larger, heavier tires obviously worsen any inbalance (more mass, bigger radius=more centrifugal force). Although I'm not sure, i think my left main wheel isn't quite round, causing the out-of-balance wobble as the wheel spins after take-off ...a pain in the butt w/ no brakes to stop it. The main reason I'm posting, however, is what I found about my tubes pulling around inside the tires. This must be caused by the low tire pressure (4-5 psi), as that is what happens if you walk a bike home after getting a flat tire. On one side the tube had worked around enf to start the valve stem cracking away from the tube. Just a little more and I would have been trying out 0 psi on that side, possibly causing trouble on a take-off or landing. This happened in only about 30 hours of operation. It was also part of the wheel inbalance problem on one side as enf of the tube had pulled around to make that side the heavy side of the wheel. I'll try two fixes simultaneously, in addition to having replaced the one tube. One, I'll clean the tube and inside of the tire, and swab a little fan-belt stick goo inside as I put the tube/tire back on. Two, if I see the stem start to tilt over time, I'll simply rotate left and right mains, and let the same action that causes the problem work the tubes back. Happy landings! --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Kolb Firestar KXP Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Subject: FS-2 back "seat"
Date: Mar 30, 1996
Greetings, I'm considering the Kolb FireStar-2 and wonder just how usable the rear seat is. It sure looks small in the photos. If you have one, can you actually use it? Thanks, Russell Duffy ________________________________________________________________________________
Date: Mar 30, 1996
Subject: Throttle stop
I have made the throttle stop for my Mark III per the Kolb drawings from .032 aluminum. This arrangement seems too flimsy and bends without much effort. Before I permanently rivet this in place does anyone have suggestions of a different design or maybe heavier material? Doug Prange Mark III Builder Lincoln, Nebraska ________________________________________________________________________________
Date: Mar 31, 1996
>I have made the throttle stop for my Mark III per the Kolb drawings from >.032 aluminum. > >This arrangement seems too flimsy and bends without much effort. > >Before I permanently rivet this in place does anyone have suggestions of a >different design or maybe heavier material? > >Doug Prange >Mark III Builder >Lincoln, Nebraska > Doug & All... I made a forarm rest out of 1 X 4 redwood house trim held in place by two U (curved part on bottom - nuts on top) brackets around the torque tube collars front and back. I shaped the board to look kinda like a baseball bat (to allow more rib room). I backed the board under the U brackets with small steel plates to take pressure off the board and keep it from spliting. The throttle comes up through a slot in the board and the slot privides the idle and full throttle stops. Works fine and looks good. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (95%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Apr 01, 1996
Subject: Kolb list: Lurker questions
I am also considering a Kolb. My leaning is toward the MarkIII. However, the Firestar looks just as fun. My questions concern a couple of things. 1. What are some of your personal feelings toward one or the other? (Firestar vs. MarkIII) 2. Does having a back seat passenger in a FirestarII reduce the fuel load from 10 to 5 gals? I guess that I am asking about the space available. Not necessarily the useful load. 3. Is anyone on the list in the Minneapolis/St. Paul area? Please respond to me directly at: terry_williams(at)is.com I will summarize my responses if you like. tw ________________________________________________________________________________
Subject: FW: Wheels and tires
Date: Apr 04, 1996
---------- From: Jason Omelchuck Subject: Kolb-List: Wheels and tires Date: Thursday, April 04, 1996 7:03AM I am just about to order kits 2 and 3 for the Mark III and know that I want the hydraulic brake package. I think that I also want larger tires than come with this package, and that is where I get confused. What is the diameter of the tires that come with this package? I know that the wheels are 6x6, but when I look in the aircraft spruce catalog the only 2 tires I see are 6x6 in different ply ratings and 15x6x6. How do I know the diameter of these tires? Kolb also quoted me about $50 dollars less for the kit without the tires, but in the catalog the cheapest tires are about $110 with tubes each. Is there some other place to buy tires that is cheeper than aircraft tires? What load rating do I need, the foot note in the book says the load ratings are MAXIMUM loads. How much load can a 1000# aircraft put on a tire when landing? I would also appreciate any input on what I might gain and loose by putting larger tires on my airplane. What kind of surfaces can the stock tires handle, soft sand, gravel bars, plowed fields? Thanks: Jason Omelchuck Portland OR- still searching for any kolb builder locally jason(at)acuityinc.com ________________________________________________________________________________
Date: Apr 05, 1996
From: "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM>
Subject:Tail, elevator hinges Now that I have the tail rigged and everything hinged onto it, I am (the hinges are temporarily attached with 5 or 6 sheet metal screws, each) wondering how smooth it works normally. Everything seems to be in line amazingly well, there doesn't seem to be any jerkiness of the elevator as it moves, and the horizontal stabilizers don't move at all as I move the elvators up and down. The thing that bothers me a little is that it has a slight resistance to movement and creaking sounds come from the hinges. When I get the bracing wires taunt the resistance is highest and creaking sounds worst. I realize that after painting and final ass'y I can spray on some lube and some of this will clear up. I am interested to hear how other builders felt about the elevator hinge operation at this stage of the plane. I have considered calling Dennis and asking if he would OK a design change if I was to put four feet of hinge on each side instead of the two one-foot pcs. Anyone thought about this, considering the importance of this control? Any suggestions, related ideas, etc appreciated. Are there any other Kolb builders in MN? ________________________________________________________________________________
Date: Apr 05, 1996
Subject: Firefly
Hello all, This is the first time for me on the Kolb list. Are there any Kolb Mark III or Firefly builders in the New England area? I'm from NH and would like to talk/visit with any builders or pilots. Some folks say Kolbs are labor intensive. Any comments on the Kolb kits ?? I did have an opportunity to see the Kolb lineup in April/95 at Sun-N-Fun. I was particularly intrigued by the Part 103 capability of the Firefly. I'm looking at 103 ultralights due to a possible medical problems but my heart is torn between the RANS S-12 Airaille and the Kolb Mark III, followed by the Firefly if Plan A falls through. -- | ___________| George McCullough / / | PATCO '81 / O / | Boston ARTCC _____/ /| / __ UL & RANS Airaille / _\_| / / \ wannabee \_____/__\_/___________________/____\ / \ / O ________________________________________________________________________________
Date: Apr 05, 1996
Subject: who
who is on Kolb list ? -- | ___________| George McCullough / / | PATCO '81 / O / | Boston ARTCC _____/ /| / __ UL & RANS Airaille / _\_| / / \ wannabee \_____/__\_/___________________/____\ / \ / O ________________________________________________________________________________
Date: Apr 05, 1996
Subject: which
Which list am I on ? -- | ___________| George McCullough / / | PATCO '81 / O / | Boston ARTCC _____/ /| / __ UL & RANS Airaille / _\_| / / \ wannabee \_____/__\_/___________________/____\ / \ / O ________________________________________________________________________________
Date: Apr 06, 1996
Subject: Meeting each other
Hi All... I tried this last year with a little success (met a couple of guys), but what the heck, why not again. If anyone is going to Sun 'N Fun, most everyone will be there on Monday morning and over at the UL area at least by 11 AM. Why not try to stop by the Kolb tent (logical spot) between 11 and 12 that morning. We might be able to put some faces on each other and maybe swap some stories. Anyway, my son (Jeff) and I will try to be there during that hour and will be going up to strangers saying "Duh! Are you an internet kolb list person?" I might make a little sign to put on my hat to save me that imbarrassment. Anyway, hope to be able to meet you then. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (95%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: Apr 07, 1996
Subject: Re: Firefly
I bought a FireFly and have since sold it to a friend due to change in my work schedule. Having seen him work on it, its not really that that bad. Takes a little time but most things that are good or worth anything take time. The Kolb is not a couple weekend project and for that matter neither is the Rans. Myself I prefer and am more comfortable with the engineering on the Kolb. While everything on the Rans functions (so did the Edsel when it was new), I am a little more concerned about durability of some of the solutions used. Some things seem to be a little cheap and dirty. While they may not cause any major problem, its going to consume time and money to keep fixing it or will let you down at the worst possible place and time. As far as dealing with Kolb, they have been excellent. They made some commitments as condition of my purchasing the kit. They have lived up to everything they said they would do. In fairness to Rans I can't speak for them since I haven't had any direct dealing with them. The planes themselves seem to fly well and most owners seem satisfied. One thing is the Kolb holds its resale value and are easy to sell should you ever desire to. Include that in your comparison. I feel Kolbs estimate for construction time to be fairly accurate for most people that don't have to analyze or reengineer things to death. Just remember time showing your project doesn't count....as my friend is finding. But damn, he sure is having fun with it while he's building. ______________________________ Reply Separator _________________________________ Subject: Kolb-List: Firefly Date: 4/5/96 4:22 PM Hello all, This is the first time for me on the Kolb list. Are there any Kolb Mark III or Firefly builders in the New England area? I'm from NH and would like to talk/visit with any builders or pilots. Some folks say Kolbs are labor intensive. Any comments on the Kolb kits ?? I did have an opportunity to see the Kolb lineup in April/95 at Sun-N-Fun. I was particularly intrigued by the Part 103 capability of the Firefly. I'm looking at 103 ultralights due to a possible medical problems but my heart is torn between the RANS S-12 Airaille and the Kolb Mark III, followed by the Firefly if Plan A falls through. -- | ___________| George McCullough / / | PATCO '81 / O / | Boston ARTCC _____/ /| / __ UL & RANS Airaille / _\_| / / \ wannabee \_____/__\_/___________________/____\ / \ / O ________________________________________________________________________________
Date: Apr 07, 1996
Subject: New enthusiast
I am interested in buying a new or used ultralight or homebuilt. I am totally uninitiated except that I used to work for Piper in Vero Beach, FL and got my private ticket while employed there. That was in the sixties and I have not flown much since that time except commercially. Anyone who would like to give me advice on how to proceed and conserve resources will be greatly appreciated. Thanx. Jim Stafford ________________________________________________________________________________
Date: Apr 07, 1996
Subject: Rear seat, IVO, EIS
I have just completed a FS II. I think the rear seat is just a jump seat just as Kolb says. I am 5-9, 180 pounds, and I fit in it, but me and another me would put the plane a little over the gross weight of 750. I would think it would be fine for an occasional passenger, but I guess if you really want to have passengers a MK III would be a lot better. I mostly want to fly the plane solo so have installed a daypack in place of the rear set, but plan to register it as a 2-place just in case. You can carry 10 gallons of fuel with or without the back seat. Well, I finally fired the plane up, and I want to tell those who haven't experienced it, that the the engine ran as smooth as silk with the IVO. Even at low RPM the engine seemed almost to be suspended on an air cushion on top of the wing. Except for the buffeting of the tail by the prop blast there was almost no vibration of the airframe. I used oil injection augmented as recommended by 100-1 Penzoil in the gas and was also amazed at the lack of oil fumes or residue. There was almost not smoke and after the breaking almost no oil on the prop or the plane. Finally, the EIS engine monitoring system was great. When I went to full power the red warning light came on immediately, which caused me to freak until I noticed I had exceeded my limit of 6500 RPM. I need to raise this limit to 6600 and also put a little pitch into the IVO. ________________________________________________________________________________
Date: Apr 07, 1996
Subject: Kolb builder in NH, Kolb vs other UL types
Hi George and others in New England, My name is Joe Kohler. I live in Alstead, NH which is about 10 mi north of Keene. I have just completed a Kolb FS II. It is a fairly labor intensive kit. I built mine over the winter. I spent just about 400 hours, but it was a lot of fun. I like the Kolb because it has a real wing built around a main tubular spar vs. the ladder type wing common to other ultralights. I think this is a more durable arrangement and I suspect the airfoil may be a little better with real ribs. The Kolb seems to be very rugged. The people at Kolb were great, though I didn't need a great deal of help cause the plane was straighforward to build. I also like it because it is reputed to perform very well. I considered the Firefly, but decided on the FS II because of the 503 dual ignition, oil injection engine and the greater wing area which requires a little less HP to keep in the air (hence the engine doesn't need to work as hard), plus the ability to add things like brakes. I think there is a good chance they may go to the self-certifying medical from what I have read. I'm planning to get an N-number for mine and fly it this summer. Please feel free to arrange a visit if you would like. ________________________________________________________________________________
Date: Apr 08, 1996
Subject: Rudder Cable
I've attached the cables to the rudder of my Mark III and now need to swage to the rudder pedal tangs. My concern is that without any means of adjustment after the cables have been cut and attached, chances are the rudder pedals will be out of alignment when the rudder is in the neutral position or the rudder will be out of alignment when the pedals are in line with each other and there will be no way to make corrections. Any suggestions or is this theory incorrect? Doug Prange Mark III Builder Lincoln, Nebraska ________________________________________________________________________________
Subject: Reply
Date: Apr 08, 1996
Hello Doug, In my FireStar and in Mark's FS II there are turnbuckles installed in the rudder cables just aft of the joystick. These allow for getting the length exactly right and also allow some adjustments to the cables as they slowly stretch out over time. I thought these turnbuckles were standard equipment in all Kolbs but maybe not in the Mark III. They did come with my kit and also with Mark's kit and their installation was explained in the manual. You may want to check them out. I am sorry I have not made it out to your house to check on your project yet but I will be there sooner or later. Mark and I were going to come out last week but I had to go to St. Louis. When are you usually around ? And one final note. The USUA club in Omaha is coming down to my airport this Sat. (April 13) for a competition. Flying should be going on from 9am until at least 5pm. You should come on out and see the guys ! The airport is at 112th and Holdrege. Hope to see you there ! See you in the sky !!! Ray Abbruzzese E-mail at: rabbruzz(at)unlinfo.unl.edu Lincoln, Nebraska, USA Kolb FireStar Owner/Pilot ________________________________________________________________________________
Date: Apr 08, 1996
Subject: *** New BFI ***
Hi Everyone... There is a new BFI in the north Texas area...a quick commercial for a very good friend of mine, George Askenasy, of RITE FLIGHT. Anyone in the Dallas or Ft. Worth Area who is interested in taking lessons in a beautiful completely equiped Kolb Mark III USUA trainer should contact George at (817) 478-6922 or 5318 Jessica Ct, Mansfield, Tx. 76063. He has a custom built enclosed trailer and can travel to you if necessary. Thanks! Cliff & Carolyn Stripling He - Kolb MK III builder (95%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________ Pilots-N-Wannabees
Subject: Re: Nylon tie fasteners (was Re: Inspection by another builder)
Date: Apr 08, 1996
builders list: >I am fastening my hoses and wires under the nose cone with tie wraps that I >epoxyed to the inner surface of the cone. So far it seems to be working, >but it is a pain to hold them in place long enough for the epoxy to >harden... several minutes seems like an hour. I got some really nifty fasteners from Mendelson's. It's a 1" x 1" square of nylon with a peel-off adhesive pad on the bottom. On the top, there is a raised area that you can slide a nylon tie under. The raised section is a saddle, perfect for seating hose and such. You can cut off your nylon tie without disturbing the mount at all. Here's a crude picture: Side: //=_ _=\\ // ======== \\ // |HOLE| \\ ============================== <------------ 1" ------------> Top: ============================== | | | | | | | | | | | ============ | | ----| |---- | | | | | | ----| |---- | | ============ | | | | | | | | | | | ============================== <------------ 1" ------------> Okay, these pictures were probably a waste of time and bandwidth, but what the heck. They cost a few pennies, so I ordered a hundred. -dave -- David Hempy Distance Learning applications programmer Kentucky Educational Television ________________________________________________________________________________
Date: Apr 08, 1996
Subject: Re: Rudder Cable
On Mon, 8 Apr 1996, Doug Prange wrote: > I've attached the cables to the rudder of my Mark III and now need to swage > to the rudder pedal tangs. > > My concern is that without any means of adjustment after the cables have > been cut and attached, chances are the rudder pedals will be out of > alignment when the rudder is in the neutral position or the rudder will be > out of alignment when the pedals are in line with each other and there will > be no way to make corrections. > > Any suggestions or is this theory incorrect? Doug, I had no problem w/ this on my firestar. I swaged the cables to the rudder horns first, then fitted them to the rudder pedals, using electrician's wire tie-bolts to hold them in place for checking before swaging. The other thing to check for is simply that the rudder pedals are more or less 90 degrees to the frame (i think a bit less is better unless you're v. tall). As things turned out i think my left pedal is down about 3/8" in the neutral position. But, your feet don't realize this -- at least mine don't. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Subject: H O Malone Petition to FAA
Date: Apr 08, 1996
-- [ From: Victor M. Worthington * EMC.Ver #2.5.02 ] -- Mr. Malone has petitioned the FAA requesting an interim solution to the weight limitation problem for single place craft while FAA and ARAC work toward a permanent solution to the problem. This petition does not seek to change part 103, only to address the problem of the so call "fat" ultralight . We need to show the FAA that the ultralight community is united on this issue. Please write to the Administrator of the FAA and tell him that you support Mr. Malone's petition. The address is: Mr. David R. Hinson Administrator Federal Aviation Administration 800 Independence Avenue Washington, DC 20591 If you have already been contacted about the petition, I apologize for clogging up your mail box. Vic Worthington vic(at)dcomp.com ________________________________________________________________________________
Date: Apr 09, 1996
Subject: More questions about a Mk III
I am looking at the info pack at the Mk III and I am curious about a couple of things. Does the position of the throttle bother you? Is it difficult to fly in this configuration? I get the feeling that it may seem like trying to ride a bike Has anyone looked into alternate mounting locations? Would it be too uncomfortable to mount the throttle on the left side wall? Looks like your left leg might rub against it. Is the flap lever difficult as well? My impression is that flap actuation could cause quite a wobble because you are either switching hands or crossing over much like the throttle. If you have ever flown an old Mooney with the big manual gear lever you probably understand where I am coming from. tw ________________________________________________________________________________
Date: Apr 09, 1996
Subject: an old subject: UL vs GA
Last week while on vacation visiting my folks, I went for a C-150 ride with my Dad at a local FBO. People say liability costs are the reason General Aviation is all but dead. Now I know another reason; it just isn't as fun as ULing. Some lowlights of the 1 hour flight: 1. wait 20 minutes for the gas attendant to come out to fill the tanks (actually to 2/3 each so as not to go over gross wt). 2. power on at beginning of take-off roll, then fold your arms and wait ... Oh, is this acceleration? I wasn't sure. Climb out at 400-500 fpm (yawn). 3. forward visibility: Sucks. since the C-150 (100 hp Continental) is such a dog, cruise w/ 2 people always feels like we're trying to climb (standard wt, standard atmosphere, sea level). We sink if less than 2200 rpm and this isn't too far down from max rpm. So, it's impossible to see anything much closer than the horizon over the nose. This is kind of scary on take-off cuz you can't see any possible Em landing spots ahead of you. At least there are side windows 4. The ground is thy enemy. In ULs, 500-1000 ft AGL is frequently adequate safety, as an engine out means a Em landing on a dirt road or field at 25 mph. In a C-150, it's 45 mph in a heavier plane -- and this is about as small as GA gets. This and the fact that the plane barely climbs means we get up to 2500 feet to safely drive around. b o r i n g 5. Stiff (boring) controls. My dad gave me the controls, but there was nothing to do. I guess this is so you can do a cross country and experience the poor visibility from too high up for longer periods. One might argue that GA gives you long x-c capability. But the rental cost is too high so we're reluctant to do it anyway. Concession: Ok, i'm Cessna bashing, and using one of the lowest performance planes to do it. I spose a ride in a Long-Eze or Glasair would sway my thinking considerably? Even a C-152 would be slightly better, and there are some other very respectable GA planes. But for all of us ULers who want to just have some flying fun, trust me, we're in the right place. By the wknd i got home to my fine feathered Kolb Firestar, and went out for some *real* flying. Did some serious 90-100 degree wing-overs (where i could actually feel the airplane), engine off glide from 2500' agl, landed on a gentle hill *full* of poppies, buzzed right on the deck (illegal in GA), etc. I thought it would really only be fair if I posted a warning in the local airport office to newcomers that they check out ULs before getting too deep into GA. flame at will... --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 09, 1996
Subject: Re: an old subject: UL vs GA
There is a big difference between transportation and recreation. I am fortunate to have had the chance to do both. I think a more reasonable comparison of UL to light plane is the same as you see with the sailing difference between a sunfish and a cabin cruiser. The sunfish is quick on its feet, has fast reactions, and is just a kick to sail. The cabin cruiser is slow and sluggish but DRY! For day sailing I would pick the sunfish. But on a four day coastal run, give me the comfort of the cabin cruiser. They both have their place. I know many people who think X-country in a UL is great. I owned a Kolb Ultrastar for many years but I carefully picked out the days that I would fly any long (more than 50 miles) trips. I never took a trip of over 100 miles without ground support. Of course that was in the days when forced landing due to engine outage was very common. The ULII engines were kinda of touchy. Plug fowling was very common. However, I have never even considered ground support for a trip in a 172. 300 mile trips in drippy weather, no problem. There is a big difference between recreational flying and flying for transportation. curt ________________________________________________________________________________
Date: Apr 09, 1996
The Cessna does what it was desgined to. Try flying IFR in an ultralight. You want fun? Fly a Pitts or a Super Decathlon or a Suhkoi. Those are FUN! > >Last week while on vacation visiting my folks, I went for a C-150 >ride with my Dad at a local FBO. People say liability costs are >the reason General Aviation is all but dead. Now I know another >reason; it just isn't as fun as ULing. > >Some lowlights of the 1 hour flight: >1. wait 20 minutes for the gas attendant to come out to fill the > tanks (actually to 2/3 each so as not to go over gross wt). > >2. power on at beginning of take-off roll, then fold your arms > and wait ... Oh, is this acceleration? I wasn't sure. Climb > out at 400-500 fpm (yawn). > >3. forward visibility: Sucks. since the C-150 (100 hp Continental) > is such a dog, cruise w/ 2 people always feels like we're trying to > climb (standard wt, standard atmosphere, sea level). We sink if less > than 2200 rpm and this isn't too far down from max rpm. So, it's > impossible to see anything much closer than the horizon over the nose. > This is kind of scary on take-off cuz you can't see any possible > Em landing spots ahead of you. At least there are side windows > >4. The ground is thy enemy. In ULs, 500-1000 ft AGL is frequently > adequate safety, as an engine out means a Em landing on a dirt > road or field at 25 mph. In a C-150, it's 45 mph in a heavier > plane -- and this is about as small as GA gets. This and the > fact that the plane barely climbs means we get up to 2500 feet > to safely drive around. b o r i n g > >5. Stiff (boring) controls. My dad gave me the controls, but there > was nothing to do. I guess this is so you can do a cross country and > experience the poor visibility from too high up for longer periods. > One might argue that GA gives you long x-c capability. But the rental > cost is too high so we're reluctant to do it anyway. > >Concession: Ok, i'm Cessna bashing, and using one of the lowest >performance planes to do it. I spose a ride in a Long-Eze or Glasair >would sway my thinking considerably? Even a C-152 would be slightly >better, and there are some other very respectable GA planes. But for >all of us ULers who want to just have some flying fun, trust me, we're >in the right place. > >By the wknd i got home to my fine feathered Kolb Firestar, and went >out for some *real* flying. Did some serious 90-100 degree wing-overs >(where i could actually feel the airplane), engine off glide from 2500' >agl, landed on a gentle hill *full* of poppies, buzzed right on the deck >(illegal in GA), etc. I thought it would really only be fair if I posted >a warning in the local airport office to newcomers that they check out >ULs before getting too deep into GA. > >flame at will... > > --------|-------- > Ben Ransom (*) > UCD Mechanical Engineering Dept. o o > Email: bransom(at)ucdavis.edu > http://mae.engr.ucdavis.edu/~ransom > (916) 752-1834 > > > ___ ___ ___ _____ / /\ /__/\ /__/\ ___ / /::\ / /:/_ \ \:\ \ \:\ /__/| / /:/\:\ / /:/ /\ \ \:\ \ \:\ | |:| / /:/~/::\ / /:/ /:/_ _____\__\:\ _____\__\:\ | |:| /__/:/ /:/\:| /__/:/ /:/ /\ /__/::::::::\ /__/::::::::\ __|__|:| \ \:\/:/~/:/ \ \:\/:/ /:/ \ \:\~~\~~\/ \ \:\~~\~~\/ /__/::::\ \ \::/ /:/ \ \::/ /:/ \ \:\ ~~~ \ \:\ ~~~ ~\~~\:\ \ \:\/:/ \ \:\/:/ \ \:\ \ \:\ \ \:\ \ \::/ \ \::/ \ \:\ \ \:\ \__\/ \__\/ \__\/ \__\/ \__\/ ________________________________________________________________________________
Date: Apr 10, 1996
Kolb , ul
Maybe the gyroplane guys say the same thing when comparing gp's to ul's. On Tue, 9 Apr 1996, Benny wrote: > The Cessna does what it was desgined to. Try flying IFR in an ultralight. > You want fun? Fly a Pitts or a Super Decathlon or a Suhkoi. Those are FUN! > > > > >Last week while on vacation visiting my folks, I went for a C-150 > >ride with my Dad at a local FBO. People say liability costs are > >the reason General Aviation is all but dead. Now I know another > >reason; it just isn't as fun as ULing. > > > >Some lowlights of the 1 hour flight: > >1. wait 20 minutes for the gas attendant to come out to fill the > > tanks (actually to 2/3 each so as not to go over gross wt). > > > >2. power on at beginning of take-off roll, then fold your arms > > and wait ... Oh, is this acceleration? I wasn't sure. Climb > > out at 400-500 fpm (yawn). > > > >3. forward visibility: Sucks. since the C-150 (100 hp Continental) > > is such a dog, cruise w/ 2 people always feels like we're trying to > > climb (standard wt, standard atmosphere, sea level). We sink if less > > than 2200 rpm and this isn't too far down from max rpm. So, it's > > impossible to see anything much closer than the horizon over the nose. > > This is kind of scary on take-off cuz you can't see any possible > > Em landing spots ahead of you. At least there are side windows > > > >4. The ground is thy enemy. In ULs, 500-1000 ft AGL is frequently > > adequate safety, as an engine out means a Em landing on a dirt > > road or field at 25 mph. In a C-150, it's 45 mph in a heavier > > plane -- and this is about as small as GA gets. This and the > > fact that the plane barely climbs means we get up to 2500 feet > > to safely drive around. b o r i n g > > > >5. Stiff (boring) controls. My dad gave me the controls, but there > > was nothing to do. I guess this is so you can do a cross country and > > experience the poor visibility from too high up for longer periods. > > One might argue that GA gives you long x-c capability. But the rental > > cost is too high so we're reluctant to do it anyway. > > > >Concession: Ok, i'm Cessna bashing, and using one of the lowest > >performance planes to do it. I spose a ride in a Long-Eze or Glasair > >would sway my thinking considerably? Even a C-152 would be slightly > >better, and there are some other very respectable GA planes. But for > >all of us ULers who want to just have some flying fun, trust me, we're > >in the right place. > > > >By the wknd i got home to my fine feathered Kolb Firestar, and went > >out for some *real* flying. Did some serious 90-100 degree wing-overs > >(where i could actually feel the airplane), engine off glide from 2500' > >agl, landed on a gentle hill *full* of poppies, buzzed right on the deck > >(illegal in GA), etc. I thought it would really only be fair if I posted > >a warning in the local airport office to newcomers that they check out > >ULs before getting too deep into GA. > > > >flame at will... > > > > --------|-------- > > Ben Ransom (*) > > UCD Mechanical Engineering Dept. o o > > Email: bransom(at)ucdavis.edu > > http://mae.engr.ucdavis.edu/~ransom > > (916) 752-1834 > > > > > > > > ___ ___ ___ > _____ / /\ /__/\ /__/\ ___ > / /::\ / /:/_ \ \:\ \ \:\ /__/| > / /:/\:\ / /:/ /\ \ \:\ \ \:\ | |:| > / /:/~/::\ / /:/ /:/_ _____\__\:\ _____\__\:\ | |:| > /__/:/ /:/\:| /__/:/ /:/ /\ /__/::::::::\ /__/::::::::\ __|__|:| > \ \:\/:/~/:/ \ \:\/:/ /:/ \ \:\~~\~~\/ \ \:\~~\~~\/ /__/::::\ > \ \::/ /:/ \ \::/ /:/ \ \:\ ~~~ \ \:\ ~~~ ~\~~\:\ > \ \:\/:/ \ \:\/:/ \ \:\ \ \:\ \ \:\ > \ \::/ \ \::/ \ \:\ \ \:\ \__\/ > \__\/ \__\/ \__\/ \__\/ > > > ________________________________________________________________________________
Date: Apr 10, 1996
Kolb , ul
Glider enthusiasts say the same thing when comparing g's with powered craft. Then there's the balloonists and the jumpers. Who is the 'real' authority on the best thrill? On Tue, 9 Apr 1996, Benny wrote: > The Cessna does what it was desgined to. Try flying IFR in an ultralight. > You want fun? Fly a Pitts or a Super Decathlon or a Suhkoi. Those are FUN! > > > > >Last week while on vacation visiting my folks, I went for a C-150 > >ride with my Dad at a local FBO. People say liability costs are > >the reason General Aviation is all but dead. Now I know another > >reason; it just isn't as fun as ULing. > > > >Some lowlights of the 1 hour flight: > >1. wait 20 minutes for the gas attendant to come out to fill the > > tanks (actually to 2/3 each so as not to go over gross wt). > > > >2. power on at beginning of take-off roll, then fold your arms > > and wait ... Oh, is this acceleration? I wasn't sure. Climb > > out at 400-500 fpm (yawn). > > > >3. forward visibility: Sucks. since the C-150 (100 hp Continental) > > is such a dog, cruise w/ 2 people always feels like we're trying to > > climb (standard wt, standard atmosphere, sea level). We sink if less > > than 2200 rpm and this isn't too far down from max rpm. So, it's > > impossible to see anything much closer than the horizon over the nose. > > This is kind of scary on take-off cuz you can't see any possible > > Em landing spots ahead of you. At least there are side windows > > > >4. The ground is thy enemy. In ULs, 500-1000 ft AGL is frequently > > adequate safety, as an engine out means a Em landing on a dirt > > road or field at 25 mph. In a C-150, it's 45 mph in a heavier > > plane -- and this is about as small as GA gets. This and the > > fact that the plane barely climbs means we get up to 2500 feet > > to safely drive around. b o r i n g > > > >5. Stiff (boring) controls. My dad gave me the controls, but there > > was nothing to do. I guess this is so you can do a cross country and > > experience the poor visibility from too high up for longer periods. > > One might argue that GA gives you long x-c capability. But the rental > > cost is too high so we're reluctant to do it anyway. > > > >Concession: Ok, i'm Cessna bashing, and using one of the lowest > >performance planes to do it. I spose a ride in a Long-Eze or Glasair > >would sway my thinking considerably? Even a C-152 would be slightly > >better, and there are some other very respectable GA planes. But for > >all of us ULers who want to just have some flying fun, trust me, we're > >in the right place. > > > >By the wknd i got home to my fine feathered Kolb Firestar, and went > >out for some *real* flying. Did some serious 90-100 degree wing-overs > >(where i could actually feel the airplane), engine off glide from 2500' > >agl, landed on a gentle hill *full* of poppies, buzzed right on the deck > >(illegal in GA), etc. I thought it would really only be fair if I posted > >a warning in the local airport office to newcomers that they check out > >ULs before getting too deep into GA. > > > >flame at will... > > > > --------|-------- > > Ben Ransom (*) > > UCD Mechanical Engineering Dept. o o > > Email: bransom(at)ucdavis.edu > > http://mae.engr.ucdavis.edu/~ransom > > (916) 752-1834 > > > > > > > > ___ ___ ___ > _____ / /\ /__/\ /__/\ ___ > / /::\ / /:/_ \ \:\ \ \:\ /__/| > / /:/\:\ / /:/ /\ \ \:\ \ \:\ | |:| > / /:/~/::\ / /:/ /:/_ _____\__\:\ _____\__\:\ | |:| > /__/:/ /:/\:| /__/:/ /:/ /\ /__/::::::::\ /__/::::::::\ __|__|:| > \ \:\/:/~/:/ \ \:\/:/ /:/ \ \:\~~\~~\/ \ \:\~~\~~\/ /__/::::\ > \ \::/ /:/ \ \::/ /:/ \ \:\ ~~~ \ \:\ ~~~ ~\~~\:\ > \ \:\/:/ \ \:\/:/ \ \:\ \ \:\ \ \:\ > \ \::/ \ \::/ \ \:\ \ \:\ \__\/ > \__\/ \__\/ \__\/ \__\/ > > > ________________________________________________________________________________
Date: Apr 10, 1996
---Don wrote--- Who is the 'real' authority on the best thrill? Probably bungy jumpers, extreme skiers, the guy sitting in the right seat during Hoover's engine out manuevers, Alan Shepard, Bill Gates when his company went public. Oh yes, and some men who are in the delivery room during the birth of their first child. ;) tw ________________________________________________________________________________
Date: Apr 12, 1996
Subject: re: best thrill
Terry wrote: >> >> ---Don wrote--- >> Who is the 'real' authority on the best thrill? > > Probably bungy jumpers, extreme skiers, the guy sitting in the > right seat during Hoover's engine out manuevers, Alan Shepard, Bill > Gates when his company went public. > > Oh yes, and some men who are in the delivery room during the birth > of their first child. ;) Alan Shepard is one cool pilot. No doubt about it. I think Neil Armstrong qualifys as an authority on best thrill. Heart rate at 160, touch down at Tranquillity Base with 10 seconds of fuel left. Sounds pretty thrilling to me. And yes, I would agree, watching your child being born is about as big a thrill as there is. am a member of, Chapter 279, puts on a pancake breakfast the 3d Sunday of every month from April till October. We have one coming up April 21. Starts around 8 AM till whenever. Come see our Kolb III. It will probably not be flying by the 21st but it's getting close. Our Chapter is based at Cranland Airport in Hanson, MA, USA. It's somewhat hard to find the dirt road in to the airport area but it's off of Route 58 in Hanson about a mile south of Rt. 27. Look for the airport symbol on a sign on the opposite side of the road from the airport road. Of course, you can fly in also. Cranland is on the sectional charts about 30 nm south of Boston. If the wheather is good there will probably be all kinds of planes flying in. We've had 50+ planes fly in for some of there breakfasts. Ex military, experimental, UL's, aerobatic, you name it. Rich Desmond, if he were willing to answer any questions from the Kolb Internet group about 279's Kolb III, or aircraft in general, and he said sure. Rich is a former A&P and has directed much of the construction of the Chapter's Kolb. Rich said the easiest way to contact him is through his AOL account at desmor(at)aol.com. Hope to meet some people from this Kolb group on the 21st! chuck chuck(at)kronos.com Chuck Cullen Kronos Inc. 400 Fifth Ave. Waltham, MA 02154 ________________________________________________________________________________
Subject: Vertical Stabalizer
Date: Apr 12, 1996
I built my vertical stab some months ago and am now installing it on to the tail boom. It would seem that the steel ring is not at a right angle to the tubes that go on either side of the tail boom. I made sure that the boom was cut square on the end. Is there an offset built into the vertical stabalizer to compensate for slipstream off the propeller. I thought that maybe one of the tubes that slips over the steel part was not on straight but both top and bottom tubes want to point the same direction by about a inch to one side when the steel ring is flush with the end of the fuse tube. I can compensate by putting the steel ring on "crooked" but I just wanted to make sure it is not built with an offset. Thoughts on GA verses Ultralights: When talking thrills, does the person who passes out on a glass elevator EXPIERENCE less of a thrill than the person who bungee jumps. A thrill is judged by the expierence not by the what the act is that causes the thrill. The thing we need to be careful of is not to speak with disrespect of other peoples "thrills" especially when they are so closely tied to our own. It is a real disapointment to fly into an airport in a licensed homebuilt , which looks like an ultralight and be told by someone that ultralights are not welcome here. I have flown gyros, ultralights (back in the early 80's) and general aviation aircraft and loved every moment because my feet were not on the ground. ________________________________________________________________________________
Date: Apr 12, 1996
Subject:Rib flanges to main Dennis may be unavailable today, I'd like to be able to work this weekend, What do you guys think about this? =========================================================================4000002137
Date: Apr 12, 1996
From: Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM GERKEN at RCHVMX Subject:Spaces between rib flanges and bottom of main spar After following the recommended riveting sequence in the Manual (top back, top front, next-down back, next-down front, etc), I have arrived at the bottom two rivets and found that on some of the ribs there is now space between the rib flange and the main spar. (I have been putting the rivets thru the flanges about 3/16 from the free edge.) I measured what looks like the worst of the spaces and it measures .070". Is this going to fly? Thanks ========================================================================= ________________________________________________________________________________
Date: Apr 12, 1996
Subject: Re: flange to main spar gap
On Fri, 12 Apr 1996, Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM wrote: > Subject:Rib flanges to main > Dennis may be unavailable today, I'd like to be able to work this weekend, > What do you guys think about this? > =========================================================================4000002137 > Date: 12 April 1996, 08:16:25 CDT > From: Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM GERKEN at RCHVMX > To: dlsouder at aol.com > Subject:Spaces between rib flanges and bottom of main spar > After following the recommended riveting sequence in the Manual (top back, > top front, next-down back, next-down front, etc), I have arrived at the > bottom two rivets and found that on some of the ribs there is now space > between the rib flange and the main spar. (I have been putting the rivets > thru the flanges about 3/16 from the free edge.) I measured what looks > like the worst of the spaces and it measures .070". Is this going to fly? > > Thanks > ========================================================================= I don't recall much gap on any of mine (Firestar). Also, if it were me, I'd prefer to get Dennis' read on this instead of anybody elses. Try (if you can't reach D.S.) to find another part of the plane to work on. Also, Dennis is sometimes available and open to support calls on Saturday mornings. Email me if you need that phone number. One other tidbit: I syringed in some epoxy in the thin gap between all my rib flanges and main spar. I did this not for direct structural purposes, but rather to take the long term vibration load off the 8 rivets. I'm sure there was v. little gap and negligable weight added by this. I think the bond was v. good and it might even have helped structurally just in terms of reducing the stress concentrations at the rivet points. I've checked in there over time (i had installed inspection ports) and it has not gotten brittle. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 13, 1996
>I syringed in some epoxy in the thin gap between all >my rib flanges and main spar. I did this not for direct structural >purposes, but rather to take the long term vibration load off the 8 >rivets. There was a wise man in Colorado who routinely worked on older GA airplanes, and on my Piper Tripacer when I owned it. There was one substance never to be without, and one of its uses was exactly this--relief of vibrational effects on sheet metal. Propeller spinners for Tripacers (and probably for every other airplane that has one) were quite expense, and the sheet metal tended to crack outward from the several rivets. Dave suggested that I put Shoe-Goo around those rivets, on the inside of the spinner. This was not structural at all, but it certainly prevented those cracks from forming in the sheet aluminum. I used it elsewhere too--where I once had to repair cooling baffles at the front of the engine. I fabricated a piece of sheet aluminum to do what I wanted, and I had to rivet it to the existing baffling. I used enough rivets to make it strong enough just from that, but I also put a layer of Shoe-Goo between the two pieces of aluminum that were held together by the rivets. Nothing I make is gonna fatigue-crack if I can help it! My Shoo-Goo came from K-Mart, but I'm sure you can buy it at any such store. Last I knew, there was a Shoe-Goo II. It's really for fixing the bottoms of sneakers, but if it works for airplanes, then it works! It remains more flexible than epoxy. I did finally fix a shoe with it. I had sneakers on which one sole was almost off. Several years ago, I put a goodly amount of Shoe-Goo in there, squished the sole back on, and it is still fixed. Tom Rampton ________________________________________________________________________________
Date: Apr 14, 1996
Subject: Re: More questions about a Mk III
>I am looking at the info pack at the Mk III and I am curious about >a couple of things. > >Does the position of the throttle bother you? >Is it difficult to fly in this configuration? >Has anyone looked into alternate mounting locations? >Would it be too uncomfortable to mount the throttle on the left >side wall? > Looks like your left leg might rub against it. > >Is the flap lever difficult as well? > My impression is that flap actuation could cause quite a > wobble because you are either switching hands or crossing > over much like the throttle. If you have ever flown an old > Mooney with the big manual gear lever you probably understand > where I am coming from. > I had the same question. What I was wondering was if anyone has or has considered mounting two control sticks in the conventional between the legs position (one for each person) and leave all the other controls as they are in the center. Would this increase weight/complexity too much? Adrio ________________________________________________________________________________
Date: Apr 14, 1996
Subject: Locate a kolb builder
Hello all, I've been enjoying the responses I've recieved from the members of the kolb list on my first query. One member of the list Tapela(at)aol.com is building a Mark III and extended a gracious invitation to visit. I'm not sure my response is getting to him ? Do any of you remember a vehicle to do a reverse search from E-Mail to street address ?? I came across it once and cannot find it now ? -- | ___________| George McCullough / / | PATCO '81 / O / | Boston ARTCC _____/ /| / __ UL & RANS Airaille / _\_| / / \ wannabee \_____/__\_/___________________/____\ / \ / O ________________________________________________________________________________
Date: Apr 14, 1996
From: <Joe.Kohler(at)top.monad.net> manderson(at)monad.net
Subject: Setting the IVOPROP
When I broke in my engine on my Firestar II a couple of weeks ago I noticed that at full throttle the 503 would exceed the maximum RPM of 6600. I am using a 62" three blade IVO initially set at "neutral" pitch (I think). I assume I should add some pitch to my IVO (a seemingly great product with very poor instructions). Do I turn the adjuster clockwise to increase the pitch? Any idea of how many turns from neutral? What static RPM at full throttle should I aim for to (1) maximize climb performance, (2) to maximize cruise, (3) for all around good performance, fuel economy, engine life, etc. Does anyone have any experience with this combination? Thanks, Joe Kohler ________________________________________________________________________________
Date: Apr 15, 1996
Subject: Re: Aftermath
Date: Mon, 15 Apr 96 14:02:54 UT From: GARY MEEKS <GARYWMEEKS(at)msn.com> ...clipped >time of the crash. They (George & Bill) were only up about 25 feet when the >engine died and the nose went up and George pushed forward on the stick (with >no response) and then pulled back on the stick (with no response). The plane >then took a nose dive, and about 10 feet off the ground, the engine kicked >back in and plunged them into the ground. The only thing that the media was Gary, thanks v. much for your post! At first upon reading this I simply wondered, "why the heck did nothing happen when George pushed forward on the stick?". Engine out combined with simultaneous mechanical failure of the controls just can't happen. But, as you know, control surfaces -- especially the elevator -- are very soft in a stall. I would guess that possibly the plane immediately went into a stall, and with no prop wash across the elevator, forward stick was relatively ineffective in the short time it takes to fall 25 feet from a starting point of fairly slow flight speed (typical of climbout). Here's another reason I'm guessing they inadvertantly stalled: Just 2 weeks ago I practiced a full engine off landing in my Kolb Firestar and was reminded how much more forward stick pressure is required with the engine stopped (compared to a normal engine idle glide). It wasn't at all hard for me to get the nose down, but I wasn't in a high pitch, full throttle, slow flight mode when I entered this practice engine out. This need for extra forward stick is caused by the high thrust line of the engine on Kolbs (except for Ultrastars) as well as many other ULs. More exactly, it is caused by the high thrust line suddenly *changing* to only drag from the stopped prop when the engine quits. This is a solid reminder to me, and I hope to others that we'd best keep a good margin of speed on takeoff, and to memorize NOSE DOWN at the *slightest* hint of engine trouble on take-off. My sincere condolences to Bill's family, and George, I hope you have a speedy and healthy recovery. Even if I'm wrong about my interpretation of what happened, I have learned something from your experience. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 15, 1996
From: "C. van Eyk Grobler" <cgrobler(at)skipjack.bluecrab.org>
Subject: Starfire 11
Could anyone please tell me if the Kolb Starfire 11 is considered to be an ultralight, or does it have to be registered as an Experimental Aircraft? Van ________________________________________________________________________________
Date: Apr 15, 1996
Subject: Re: Starfire 11
On Mon, 15 Apr 1996, C. van Eyk Grobler wrote: > Could anyone please tell me if the Kolb Starfire 11 is considered to be > an ultralight, or does it have to be registered as an Experimental > Aircraft? Van Note, it is a Firestar, not starfire. Legally, it is not an UL. It cannot be built under 254 lbs. As well, the rear jump seat is illegal under FAR103 as soon as somebody sits in it. I think, but am not sure, that the Firestar I can be built under 254 if you use the rotax 277 (28 hp), and it is almost the same frame as the II. (same thing tho', you couldn't carry a passenger, legally or otherwise) The Firefly is similar to the Firestar, but offers the dbl benefit of being able to be built under 254 lbs AND use the rotax 447. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 15, 1996
Subject: FireFly Speed/Drag
Kolb list: I read in an article or in the Kolb literature that the second strut on the FireFly is to add more drag, so the level flight top speed is not exceeded on paper. Other "features" such as the winshield and really long chord were were designed with high drag in mind. It seems to me that it would be easier to limit the level flight top speed with a different prop (lower angle) and the RPM limit of the engine. I do understand that Kolb was trying tho keep the full horsepower of the 447, so a real simple fix like a smaller carburetor or smaller prop is out. >From my limited experience with soaring, I have really come to think of drag as the enemy, and have a hard time understanding when someone would actually is trying to increase it. Could someone enlighten me? Would the low pitch prop idea work? -Thanks Brent A. Crosby (Please reply to "brent_crosby(at)lardav.com", which is not necessarily the "reply to" address that our mailer gives to your mailer.-BAC) +-----------------------------------------------------------+ | Brent A. Crosby |LARSON-DAVIS main office: | | LARSON-DAVIS |LARSON-DAVIS | | 15611 East Washington Road |820 North 1681 West | | Valleyford, WA 99036 |Provo, UT 84601 | | | | | voice: (509) 291-3344 | voice: (801) 375-0177 | | fax: (509) 291-3345 | fax: (801) 375-0182 | | email: brent_crosby(at)lardav.com | bbs: (801) 375-0191 | +-----------------------------------------------------------+ | visit our home page at http://www.lardav.com | +-----------------------------------------------------------+ ________________________________________________________________________________
Date: Apr 16, 1996
Subject: Re: FireFly Speed/Drag
On Mon, 15 Apr 1996, Brent Crosby wrote: > Kolb list: > > I read in an article or in the Kolb literature > that the second strut on the FireFly is to add > more drag, so the level flight top speed is not > exceeded on paper. Other "features" such as the > winshield and really long chord were were > designed with high drag in mind. > > It seems to me that it would be easier to limit > the level flight top speed with a different prop > (lower angle) and the RPM limit of the engine. > > I do understand that Kolb was trying tho keep > the full horsepower of the 447, so a real simple > fix like a smaller carburetor or smaller prop is > out. > > >From my limited experience with soaring, I have > really come to think of drag as the enemy, and > have a hard time understanding when someone > would actually is trying to increase it. > > Could someone enlighten me? Would the low pitch > prop idea work? > > -Thanks > Brent A. Crosby Brent, I believe your suggestion for a flatter pitch prop is good except that the engine would overspeed. I would guess this could be prevented with some sort of rpm limiter (electronic ?) add-on to the engine. Although drag is no friend of most airplanes (perhaps an exception for aerobatic types), the FAA allows some pretty nice freedoms IF we can build a plane under 254 lbs and under 63mph. Therefore, with a tax analogy close at hand (from the tax fun i had the last couple days), the Firefly design is like legal tax avoidance -- any legal "paper" allowance is taken for drag that will de-rate the airplane. The need to use FAR 103 "paper" drag numbers (loopholes?), is partly because, with a short wing span, the Firefly would have comparatively little parasitic and induced drag (as well as less wing weight). In short, I bet the plane performs better in the air than it does on paper. The paper version *must* add up to FAR 103, though, or the whole design concept is lost. BTW, I don't mean to imply that calculated drag or other performance parameters are just bunk. I'm suggesting that the FAR nomograms must have some slop, and that if the design is always on the performance side of the slop, the plane could be better in real life than an average (or poor) nomogram airplane. Anybody know about electronic rpm limiters? I bet it might be a relatively simple off-the-shelf adaptation, and -- like Brent said -- a better idea than adding drag (real or paper). --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 16, 1996
Subject: Vibration isolation
I've been reading the mail regarding vibration isolation. I used 3-M structural adhesive between almost all of the parts I rivited together, eg., between the ribs and the leading edges of the tail surfaces and the ailerons. This is great stuff, the same thing that AVID and KITFOX use to ATTACH the wood ribs to the leading edge spar tube. It is a fairly flexible epoxy and it is viscous enough that a little dab pretty much stays put between the rib and whatever. I cleaned the surfaces with acetone and roughed them a little with scotch-brite. I didn't use this where the wing ribs slide over the spar cause I had to use oil to get them to slide on and I figured I couldn't get the oil off. However, I think it really vibration proofs the control surfaces, which are of course very critical. ________________________________________________________________________________
Subject: NEW Kolb "Slingshot"!
Date: Apr 16, 1996
Greetings, Just got back from Sun-N-fun where I bought the first Kolb Slingshot. It's a brand new high performance version of the FireStar-2 with clipped wings, a new much improved enclosure, and stronger landing gear. It currently uses either the 503 or 582 engine and will in the future be able to use the 618 and 912. The price is about $1000 higher than the FireStar but includes several standard features that were options before (2 place $216, full enclosure $295, streamlined lift struts (?) $150) As I understand it, the wing now uses the 6" spar tube and 8 full ribs per wing. The landing gear is a larger tube that turns down to about vertical at the wheels. It looks to be a little wider stance too. The enclosure is quite different. Everything from about the rear of the old front enclosure is now enclosed and includes a window on each side for the passenger. The fuselage sides appear to be about 6 inches taller than the current FireStar but the top 6" of the right side folds down for easier entry. The canopy is a large rigid one piece design (similar to the two on the Mark 3). It hinges on the left side and reaches completely over to the right when closed. The rear of the canopy is about 6 inches higher than before. There is now a curved plexiglas piece that fills in between the wings that extends up to mate to the taller rear of the canopy. This gives the pilot- headroom aplenty. I was sold the instant I sat in it. I'll post a picture on a web page when I get them processed so you can see what all this incoherent babble really looks like. Fortunately my wife took a couple of pictures while I was sitting in the plane. Sadly, I never got any other pictures. They took the plane out to fly it while I was talking to them, and it never came back. It seems there was a photo shoot for one of the magazines scheduled at another field that afternoon. The airshow started about 30 minutes after the Slingshot departed and the storms started before the airshow was finished. We left about 6pm and the weather was still hopeless. Hope you enjoy the long and overly excited post. I don't work for or represent Kolb in any way. I'm just a happy new builder. Some specs from the Sun-N-Fun handout: Wing span: 22 ft Wing area: 110 sq./ft Wing loading: 7.7 lb./sq.ft. @ gross wt. Length: 19 ft. (same folded) Height is 82" (same folded, see note- that I can't seem to find) Width folded: 75" Weight (empty): 345 lb. minimum Gross weight: 850 lb. Load factor +4, -2 Limit Load Fuel capacity: 10 gal Vne: 125 mph Stall speed: 39 mph @ gross weight Other features: Flaperons, full enclosure with rigid hinged canopy, pull start from seated position in aircraft. T.O. Distance: ENGINE SOLO DUAL 503 150 ft 250 ft 582 100 ft 175 ft Climb Rate: 503 1000 fpm 650 fpm 582 1300 fpm 800 fpm Top Speed: 503 90 mph 582 100 mph Cruise Speed: 503 78 mph 582 87 mph Sligshot #1 Russell Duffy ________________________________________________________________________________
Date: Apr 16, 1996
Subject: Re: NEW Kolb "Slingshot"!
Sligshot #1 Way to go Russell! --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Subject: General building questions
Date: Apr 17, 1996
Greetings, Since I have 6-8 weeks to wait for my Slingshot kit to arrive, I thought I would ask a general question. What is everyone doing about primer for the tubing in the structure? Do most people prime it or leave it bare? Do you attempt to prime the inside of the tubing? Is the aluminum tube alclad? I'll probably pay to have the fuselage powder coated. That looks like a very worthwhile option. Thanks, Rusty ________________________________________________________________________________
Date: Apr 18, 1996
Date: Apr 18, 1996
Subject: Mark III Trim cable
I have routed the trim cable on my Mark III under the "H" tube and under the elevator bell crank up to the spring assembly and have temporarily snugged things up before swaging the cable. The cable rubs the bottom of the bell crank so I moved it to the top side where it rubs the top. Also the cable rubs the bottom of the "H" tube going either way. Is the fact that it rubs on a part of the structure anything to be concerned about and which way is the recommended route? Also, should the tension be relieved from the springs when the elevators are in the neutral position which puts slack in the cable with the stick all the way back, or should the tension be relieved when the stick is all the way back? Doug ________________________________________________________________________________
Date: Apr 21, 1996
Subject: Re: Mark III Trim cable
I had the same problem with the trim cable rubbing everything. The double spring assembly also rubbed against the throttle or your leg on mine. So I made a big stink about it to dennis. He has redesigned the entire area. It involves a new elevator bell crank and no more long cable running back to the tail. The beta version of the new system has been tested by Dan the factory pilot who says it works fine. I am supposed to get the new set up after the guys get back from lakeland. Call Dennis and ask him for a drawing of the new set up. ________________________________________________________________________________
Subject: New Web page
Date: Apr 21, 1996
Greetings, While I'm waiting for the my Slingshot kit, I figured I would start working on a web page for it. I plan to keep my building log and photos on the web page for all to see (how slowly I work). Of course, the only thing on the page now is the 2 pictures that my wife took of me sitting in the factory plane at Sun-N-Fun. The pictures give a fairly good look at the new enclosure. Once I get going on the building process (about June ??), the page should get more interesting. Rusty - Slingshot #1 Navarre, FL http://www.gulf.net/~rad/ ________________________________________________________________________________
Date: Apr 21, 1996
Subject: test post
This is a test message. I'mm having problems with another ultralight list and can't figure if it's me or what ?? -- | ^ ___________| / / | ^ / 0 / | _____/ /| / __ __________________ / _\_| / ^ /GM\ /George McCullough | \_____/__\_/______________/____\______/ PATCO'81 BOS ARTCC| / \ \ (603)889-8707 | / o \RANS/KOLB wannabee| O ________________________________________________________________________________
Date: Apr 21, 1996
Subject: Re: test post
George, I got your Kolb post just fine. I'll send this message to you as a Kolb-wide post and repeat it as a private message so you can see if you're getting both posts. Sorry for the extra message to everyone. Please forgive. -- Don >This is a test message. I'mm having problems with another >ultralight list and can't figure if it's me or what ?? >-- > | > ^ ___________| > / / | ^ > / 0 / | > _____/ /| / __ __________________ >/ _\_| / ^ /GM\ /George McCullough | >\_____/__\_/______________/____\______/ PATCO'81 BOS ARTCC| > / \ \ (603)889-8707 | > / o \RANS/KOLB wannabee| > O > > ________________________________________________________________________________
Date: Apr 22, 1996
From: Bill Cloughley <71564.1257(at)CompuServe.COM>
Subject: Ultrastar Floats
I fly a Kolb Ultrastar out of Essex Skypark, MD (NE of Baltimore). I'm thinking about putting floats on my Ultrastar to take advantage of the Chesapeake but I know nothing about ultralight floats. I'm wondering if anyone has any experience or advice for me. Who makes them? Approx cost? How do the floats effect flying performance? Do they make floats that have retractable wheels? Thanks, Bill. ________________________________________________________________________________
Date: Apr 24, 1996
Subject: Please help.
Dear Kolb enthusiasts, I am considering the purchase of a FireFly and would appreciate information any of you could share with me in reference to this neat little airplane, in particular to its flight handling since I have not been able to get any reviews up to now. I had the opportunity to see it at Sun 'n Fun and really liked it. I also had the opportunity to chat with the Kolb people but would like to hear from the users out there. I live in the Miami, Fl area and would like to get in touch with anyone familiar with the FireFly or with the Kolb aircraft in general. I really appreciate the feedback, Christian Martin. ________________________________________________________________________________ **** trial license expired ****) with SMTP id AAA378
Date: Apr 24, 1996
Subject: Paint
I am a new MarkIII builder. We have our tail feathers built and are getting ready to start on the wings. My problem is that I can't find where to get Polytone paint. No paint store here in town knows anything about it. I need to get some now because I need to paint the steel part of the tail post. I am sure there are those of you out there who can give me a phone number or address. Would appreciate an e-mail return from somebody. Thanks Bob ________________________________________________________________________________
Date: Apr 25, 1996
Subject: Craig's Wish (fwd)
Craig Shirgold is a 7 year old boy who lives in Keene, NH. He is dying from an inoperable brain tumor. He made a wish to Children's Wish Foundation that he wants one million 'Get Well' cards sent to him by Aug 15, so he can make the World Book of Records before he dies. Cards can be made or bought. PLEASE send the cards to the following address: Craig Shirgold c/o Children Wish Foundation 32 Perimeter Center East Atlanta, Georgia 30346 Thank you. PLEASE BOTH FORWARD THIS MESSAGE AND MOST IMPORTANTLY SEND A CARD TO CRAIG. ________________________________________________________________________________
From: "Michael E. Goldstein" <goldstn(at)polaris.umpi.maine.edu>
Date: Apr 25, 1996
Subject: Re: Craig's Wish (fwd)
I'm pretty sure that you should NOT do this. Craig long ago recovered from his illness, guiness banned the postcard category and the hospital still suffers from having to deal with all the postcards... >Craig Shirgold is a 7 year old boy who lives in Keene, NH. He is dying >from an inoperable brain tumor. He made a wish to Children's Wish >Foundation that he wants one million 'Get Well' cards sent to him by Aug >15, so he can make the World Book of Records before he dies. Cards can be >made or bought. PLEASE send the cards to the following address: > >Craig Shirgold >c/o Children Wish Foundation >32 Perimeter Center East >Atlanta, Georgia 30346 > > >Thank you. > >PLEASE BOTH FORWARD THIS MESSAGE AND MOST IMPORTANTLY SEND A CARD TO CRAIG. > > Michael E. Goldstein goldstn(at)maine.maine.edu 207-768-9630 goldstn(at)polaris.umpi.maine.edu Computer Services University of Maine at PI ________________________________________________________________________________
From: jstripli(at)hpmail2.fwrdc.rtsg.mot.com (Jeff Stripling)
Subject: Re: Craig's wish
Date: Apr 25, 1996
Earlier, Jim said: > > Craig Shirgold is a 7 year old boy who lives in Keene, NH. He is dying > from an inoperable brain tumor. He made a wish to Children's Wish > Foundation that he wants one million 'Get Well' cards sent to him by Aug > 15, so he can make the World Book of Records before he dies. Cards can be > made or bought. PLEASE send the cards to the following address: > > Craig Shirgold > c/o Children Wish Foundation > 32 Perimeter Center East > Atlanta, Georgia 30346 This is a common urban legend. Craig Shergold is a real person, living in England. He *did* set the record for most number of cards received in 1990 at age 10. Even better, he recovered from his cancer and is now in his mid-teens. Years later, the email requesting cards for him continues to circulate... For more information, check out: http://www.wish.org/wish/craig.html Or dial: 1-800-215-1333, extension 184 -- Jeff Stripling | /\/\ M O T O R O L A jstripli(at)mot.com | / \ Advanced Cellular Products Group (817) 245-6002 | Texas Products Division ________________________________________________________________________________
Date: Apr 25, 1996
Subject: Re: Paint
>To: kearbey(at)cnc.net >From: evoice(at)acton.com (Doug Prange) >Subject: Re: Paint > >Robert: > >I highly recommend R & R Aircraft Supply. > >You can buy all the Poly Fibre Aircraft Coatings at a number of other suppliers around the country but from personal experience Randy at R & R has been great to work with. > >He offers a discount to Kolb builders and is always available to answer questions about covering or finishing and believe me it's well worth it to establish a good relationship with someone who knows their stuff. > >Phone (616) 683-2594 > >Be prepared for a good hit from UPS for hazardous material charges. > >There's no way around it! > >Tell Randy I sent you if you don't mind.(there's nothing in it for me except to have Randy know that all his patience pays off) > >Doug Prange >Mark III Builder 65% >Lincoln, Nebraska > ________________________________________________________________________________
Date: Apr 26, 1996
Subject: Re: Please help.
Contact the Light Aircraft Flyers Association (LAFA). They have owners of Kolb products, a well organized club in the Miami area, a ultralight airport, instructors, and all the help you need to get started. They even have a 24 hour Hot-line: 305-460 3356 This is a great ultralight organization. Too bad there isn't a group like this in every city. If there was, ultralight flying would be much more popular. curt ________________________________________________________________________________
Date: Apr 27, 1996
Subject: KOLB Dealers??
Just subscibed to this group,are there any dealers/flight schools in the NW USA Oregon or Washington? Thanks, Mike ________________________________________________________________________________
Date: Apr 26, 1996
Subject: Re: Paint
On Wed, 24 Apr 1996, Robert Kearbey wrote: > I am a new MarkIII builder. We have our tail feathers built and are > getting ready to start on the wings. > My problem is that I can't find where to get Polytone paint. No paint > store here in town knows anything about it. I need to get some now > because I need to paint the steel part of the tail post. I am sure > there are those of you out there who can give me a phone number or > address. > Would appreciate an e-mail return from somebody. Just posting to add my recommendation to Randy @ R&R (616)683-2594. Also, about 1-2 yrs ago, I posted about problems I had in spraying polytone, with getting some areas of high sheen and others not so high. Somebody gave back a *really good* bunch of advice, discussing reasons behind all this, and which paint guns were good too. I seem to have lost that post, so if anybody has it or the original spray wizard is still in this list, a repost would be most appreciated. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 27, 1996
From: stei0302(at)jane.cs.fredonia.edu (Jon N. Steiger)
Subject: Re: KOLB Dealers??
> >Just subscibed to this group,are there any dealers/flight schools >in the NW USA Oregon or Washington? > Nope... No such animal... Kolb keeps its prices down by not supporting a dealer network. You may be able to find a flight school that uses Kolbs though. I'd check the list of ASC, EAA, and USUA instructors in your area. Call them and find out what they use... Good luck! -Jon- .------------------------------------------------------------------------------. | Jon Steiger: DoD# 1038, EAA #518210, USUA# A46209, NMA# 117376, KotWitDoDFAQ | | stei0302@cs.fredonia.edu && http://www.cs.fredonia.edu/~stei0302/ | | '96 Dakota SLT V-8, '91 FZR600R /* Just another mangy hacker */ | `------------------------------------------------------------------------------' ________________________________________________________________________________
Date: Apr 27, 1996
Subject: Ivo vs wood props
Greetings, In wood vs metal prop debates, I've heard that one of the negative features of wood is that you have to keep retorquing the bolts frequently. What does Ivo recommend? do you just bolt it on and forget it, or do you retorque every X number of hours? Are there any negatives to the Ivo props other than the higher cost? Rusty ________________________________________________________________________________
Date: Apr 27, 1996
From: LBPD09A(at)prodigy.com (MRS MARIAN E VITTINGHOFF)
Subject: firefly & firestar with rotax 277
Hi, I am new to all of this so please forgive any breaches in ettiquet. 1. Is anyone building the Firefly with the 277 rotax? 2. Is anyone building the Firestar-1 with the rotax 277 as a legal UL? 3. Does anyone have experience with other light weight engines on these airframes? Thanks for your time . Karl ________________________________________________________________________________
Subject: RE: Ivo vs wood props
Date: Apr 27, 1996
Russel I know a guy who had a wood prop that ran through a rain shower one day and it splintered his prop.Granted he should'nt been in the light shower but he had no where to go and my Ivo prop has metal leading edges to prevent this from happening. Still ,as with any prop ,under that much load & vibration they should be retightened every so often.I retightened mine abought every 30 hrs. or so. ---------- From: Russell Duffy[SMTP:rad(at)gulf.net] Sent: Saturday, April 27, 1996 12:06 PM Subject: Kolb-List: Ivo vs wood props Greetings, In wood vs metal prop debates, I've heard that one of the negative features of wood is that you have to keep retorquing the bolts frequently. What does Ivo recommend? do you just bolt it on and forget it, or do you retorque every X number of hours? Are there any negatives to the Ivo props other than the higher cost? Rusty ________________________________________________________________________________
Date: Apr 28, 1996
Subject: Re: Ivo vs wood props
On Sat, 27 Apr 1996, Russell Duffy wrote: > Greetings, > In wood vs metal prop debates, I've heard that one of the negative > features of wood is that you have to keep retorquing the bolts > frequently. What does Ivo recommend? do you just bolt it on and forget > it, or do you retorque every X number of hours? > > Are there any negatives to the Ivo props other than the higher cost? I use a Warp, which cost ~460 instead of 200 for a wood prop. Here's what I think the advantages are: 1. carbon fiber is *MUCH* tougher and resiliant to gravel, bugs, rain, etc. I too know of ULers who have used up a wood prop in one short dash home thru rain. Carbon fiber is tough enough even without the metal leading edge tape -- unless for something like amphibious use. 2. lighter mass means less wear on gearbox. As well, stronger material allows greater freedom in airfoil and planform design. 3. ground adjustable gives choice for cruise or climb preference (1/2 hour adjustment and retorque time on the Warp 2-blade) 4. carbon is not porous and subject to moisture absorption. Therefore changes in balance due to moisture are not a problem. 5. There is some credence to the argument that designed-in flex (i.e. twist) of the carbon prop yields an automatic "almost constant speed" feature. That is, at low airspeed (of the airplane) and maximum engine power, the air forces on the prop twist it to flatter pitch. Conversely, at higher speed and lower power, this twist force is unloaded giving you a higher (cruise) pitch. I know of somebody who changed from wood to Warp and saw this to be true. I have no wood experience to compare to. 6. if you ever change to a slightly different power engine, you can use the same prop w/ different pitch. 7. It makes Cessna drivers jealous. :) I see no disadvantages except for initial cost. (BTW, damage to wood props in rain is much less severe if you throttle back and fly home slowly.) --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 28, 1996
On Sat, 27 Apr 1996, Russell Duffy wrote: > Greetings, > In wood vs metal prop debates, I've heard that one of the negative > features of wood is that you have to keep retorquing the bolts > frequently. What does Ivo recommend? do you just bolt it on and forget > it, or do you retorque every X number of hours? > > Are there any negatives to the Ivo props other than the higher cost? Oops. forgot to mention the bit about retorquing. On carbon props this may depend on the type of hub. It seems logical that non-porous material hubs would require less re-torquing. However, if you are frequently changing prop pitch, well then I guess you are frequently retorquing. Retorquing a wood fixed-pitch prop should be trivial. Retorquing an adjustable pitch prop/hub is slightly more of a hassle cuz the pitch of the two (or 3) blades nudges around as you torque up. When i change pitch of my Warp prop, I'm rarely lucky enf for the pitches to be within my preferred tolerance on the first try. (I allow about 10 minutes (1/5 of a degree) difference between the two blades, and this is the best you can get *because* of the tendency for them to move while torquing.) Because of this I've sometimes gotten lucky and reset pitch in 15 minutes. Other times I've fought the damn thing for 45 minutes. But by now i've gotten to a pitch i like and haven't changed for several months. Happy pitching, propping, torqueing, etc. Who cares, at least it's playing w/ your toys. :) --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 28, 1996
Subject: How about Warp vs. Ivo Props?
Thanks to Ben for all the great info about Warp drive props. I'm pretty well convinced that I will not be using wood. Now I'm curious about the difference between Ivo and Warp props. It seems to me that the Ivo has all the same advantages over wood as the Warp Drive prop. It does lack the Warp's "almost constant speed" feature, but it's quite a bit cheaper. Kolb charges $255 (extra over the $195 wood prop price) for the Ivo 3 blade and $485 (again extra) for the Warp Drive 3-blade (they don't appear to offer the 2-blade Ivo for the Slingshot). Your comments about torquing and pitch change brought up some interesting questions. I'm not familiar with the Warp drive prop. Do you set the pitch for each blade individually? It sounds like you must have to unbolt the prop to do it. The newer quick adjust Ivo prop seems to be about as easy as you can get. One center bolt adjust all the blades simultaneously and you don't touch the mounting bolts at all. The potential problem would be that the blades might not be exactly the same pitch, and there doesn't seem to be anything you can do about it. Maybe they're matched at the factory, but what if you have to replace one? One other neat potential benefit of the Ivo 3-blade is that you can re-configure it as a 2 blade. If one blade got damage while away from home, you MIGHT be able to switch to 2 blade mode, add pitch, and carefully get back home. Thanks for the info. I'm just trying to put my idle time to good use while I wait for my kit. It's not like I'M spending Sunday on the computer when I have a perfectly good plane to fly :-) Russell Duffy (Slingshot / Serial # SS-003) What happened to #1 ??? ________________________________________________________________________________
Date: Apr 29, 1996
Subject: Re: How about Warp vs. Ivo Props?
On Sun, 28 Apr 1996, Russell Duffy wrote: > Thanks to Ben for all the great info about Warp drive props. I'm pretty > well convinced that I will not be using wood. > > Now I'm curious about the difference between Ivo and Warp props. It > seems to me that the Ivo has all the same advantages over wood as the > Warp Drive prop. It does lack the Warp's "almost constant speed" > feature, but it's quite a bit cheaper. Kolb charges $255 (extra over > the $195 wood prop price) for the Ivo 3 blade and $485 (again extra) for > the Warp Drive 3-blade (they don't appear to offer the 2-blade Ivo for > the Slingshot). > > Your comments about torquing and pitch change brought up some > interesting questions. I'm not familiar with the Warp drive prop. Do > you set the pitch for each blade individually? It sounds like you must > have to unbolt the prop to do it. The newer quick adjust Ivo prop seems > to be about as easy as you can get. One center bolt adjust all the > blades simultaneously and you don't touch the mounting bolts at all. The > potential problem would be that the blades might not be exactly the same > pitch, and there doesn't seem to be anything you can do about it. Maybe > they're matched at the factory, but what if you have to replace one? > One other neat potential benefit of the Ivo 3-blade is that you can > re-configure it as a 2 blade. If one blade got damage while away from > home, you MIGHT be able to switch to 2 blade mode, add pitch, and > carefully get back home. > > Thanks for the info. I'm just trying to put my idle time to good use > while I wait for my kit. It's not like I'M spending Sunday on the > computer when I have a perfectly good plane to fly :-) > Sounds like great features and price on the IVO. I don't know about performance comparisons between warp and ivo. I'm not sure what the IVO is made out of. Is it the IVO that flexes *a lot* (in the forward/ backward direction, perpendicular to blade length)? I don't know if this means anything about performance, but you might want to chk if the material is tough enf to withstand the rain damage type thing. When I bought mine I felt price, performance, and features favored Warp. But of course things can change. Also, I was able to use the efficiency of the 2-blade (compared to 3-blade). As for the warp, the blades are matched only in that they are from the same mold, and serial numbered at the factory (probably for weight and plan form records). If one should need replacement, you could get an identical one from Warp. Yes, you do set the pitch of each blade individually, using a bubble protractor. It is easy, except for the tendency for things to change as you torque up as I mentioned in my earlier post. BTW, we're grounded out here in CA. Winds were 25 mph, gusting to 50 all wknd. Dang! It has tapered off, but now there's that inconvenience of going to work. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Apr 29, 1996
>Greetings, > >In wood vs metal prop debates, I've heard that one of the negative >features of wood is that you have to keep retorquing the bolts >frequently. What does Ivo recommend? do you just bolt it on and forget >it, or do you retorque every X number of hours? A potential caution here about prop bolt tightening, and also about my level of expertise in what I'm about to write: The mechanic that last worked on my engine (an A&P, but who I've since decided was an idiot) cautioned me not to overtorque the prop bolts. The reasoning is that moisture causes expansion, which in turn could overstress the bolts, or maybe it was just that it could cause dimples in the wood under the squash plate. It that's true, it could be possible that constantly re-torqueing the bolts too much could be causing deeper dimples in each cycle of torquing/flying. Could someone with knowlege in this area comment on this? I know that, even tho coated with a moisture "proof" coating, wooden probs do absorb and give off moisture in response to changing humidity. This was probably the major technical problem with the one-bladed Everel prop. Since the counterballance was metal and the blade wooden, it was frequently going out of ballance due to small changes in length (and weight) caused by changes in moisture content. It has occurred to me that with advent of metal and composite props, there may be reason for a re-introduction of the one-bladed prop. The article in Experimenter stated that it was particuarly well suited to aircraft in the 40 horsepower range--that's us. Anybody know of any 1-blade props being marketed now? ..................................................................... Mike Ransom internet: mlransom(at)ucdavis.edu (916) 752-8810 Programmer/Analyst, Dept of Agronomy & Range Science University of California, Davis, U.S.A. ..................................................................... ________________________________________________________________________________
Date: Apr 29, 1996
>Are there any negatives to the Ivo props other than the higher cost? > >Rusty Sorry, got carried away with the one-bladed prop treatise and forgot the following comment I wanted to make: I'm going with wood, in spite of my brother's great experience with the WARP prop and the great reports we've heard about it. My reason is that I fly an UltraStar. The prop is close to the ground and has nothing between it and the ground to break the ground vortex that tends to suck grit up into the prop. Also, the props are sometimes broken by striking the ground--I suppose on rough ground or horrific bounces. I figured I would be breaking or wearing out my prop at some point. You have another option, not mentioned previously, and that is to get a prop with a plastic leading edge. Culver Props will install a urethane leading edge on a new prop for just $45 extra, and I've seen it advertised from prop repair places too. I suppose you could keep repeating the process, tho judging from the aged one I've got on my plane, it looks like it's probably pretty durable. Also, a note about the stainless steel L.E. on the Ivo. The prop of the plane I took instruction in had a really badly dinged up L.E. strip, so I can definitely attest to the fact that it's not ding proof. I don't know what caused the damage, rocks, gravel or rain, but it had really taken a beating. Finally, I heard one story about a fiberglass prop (unknown manufacturer) where the pilot noticed some little lines on his prop during one pre-flight and then on closer inspection, found that it was a crack and that there were in fact *many* cracks in the prop. Being the only such story I've heard, I wouldn't let that sway me away from a fiberglass prop--just saying it might be a good idea to inspect f/g props *very* carefully once in a while. ..................................................................... Mike Ransom internet: mlransom(at)ucdavis.edu (916) 752-8810 Programmer/Analyst, Dept of Agronomy & Range Science University of California, Davis, U.S.A. ..................................................................... ________________________________________________________________________________
Date: Apr 30, 1996
Subject: cabling and props
Fellow builders, I am sure someone can tell me what the best way to cut the 3/32 cable. I have tried several things but it always frays. Makes it very difficult to put through the nico things!!! Next, I am building a MarkIII. Tail feathers are done and just getting ready to start the wings. At the Rotax seminar I went to put on by Mike stratham from california Power Systems I spoke with him about the electric variable pitch prop. I wonder if anybody is using it?? He said it works best for aircraft that cruise at 100 or better but thought that there might be some advantage on the MarkIII also. Hope somebody has one and can contribute. Robert Kearbey D.D.S. 916-533-3262 Oroville, Ca. 9596 ________________________________________________________________________________
Date: Apr 30, 1996
Subject: Re: cabling and props
Robert Kearbey wrote: > > Fellow builders, > > I am sure someone can tell me what the best way to cut the 3/32 > cable. I have tried several things but it always frays. Makes it > very difficult to put through the nico things!!! > > > Robert Kearbey D.D.S. > 916-533-3262 > Oroville, Ca. 9596 Tape around the cable before cutting helps. Perhaps the neatest trick is one of the little die grinders (sort of like a Dremel tool, but bigger) and a narrow abrasive cut-off disc. ________________________________________________________________________________
Date: May 01, 1996
Robert Kearbey wrote: > > Fellow builders, > > I am sure someone can tell me what the best way to cut the 3/32 > cable. I have tried several things but it always frays. Makes it > very difficult to put through the nico things!!! > > Next, I am building a MarkIII. Tail feathers are done and just getting > ready to start the wings. > > At the Rotax seminar I went to put on by Mike stratham from > california Power Systems I spoke with him about the electric > variable pitch prop. I wonder if anybody is using it?? He said it > works best for aircraft that cruise at 100 or better but thought > that there might be some advantage on the MarkIII also. Hope > somebody has one and can contribute. > > Robert Kearbey D.D.S. > 916-533-3262 > Oroville, Ca. 9596I've found that a wrap of tape (mistic tape,etc.) around the cable and then cutting through the center of the wrap with an emory wheel on your moto-tool will give you a clean, almost frayless cable end. John Wells ________________________________________________________________________________
Date: May 01, 1996
From: "Bennett, Steve" <steve.bennett(at)northstarcmc.com>
Subject: RE: cabling and props
>>I am sure someone can tell me what the best way to cut the 3/32 >>cable. I have tried several things but it always frays. Makes it >>very difficult to put through the nico things!!! I found the best way to cut those cables was to use a cold chisel. I took a small one (about a half-inch), set the cable on something solid like a vise or anvil, and then one quick blow with a hammer would very neatly chop the cable with absolutely no fraying or untwisting of the strands. -Steve ________________________________________________________________________________
Date: May 01, 1996
Subject: Painting
Another question to all you experienced Kolb builders. Is it best to paint the whole plain together or to paint it piece at a time and then re-assemble? More specifically, what about painting the tail boom with all tail feathers attached? Bob Kearbey Oroville, Ca. ________________________________________________________________________________
Date: May 01, 1996
On Tue, 30 Apr 1996, Robert Kearbey wrote: > Fellow builders, > > I am sure someone can tell me what the best way to cut the 3/32 > cable. I have tried several things but it always frays. Makes it > very difficult to put through the nico things!!! Wrap the cable with electrical tape about 1/2" on both sides of where you want the cut. Then use a Dremel moto-tool with a fine cutting wheel. Make sure the cable is rock steady while you are cutting. No fraying. _-_ _,, ,, -/ ) ; || ||_< \\/\/\ _-_ ||/|, _-_ ,._-_ bweber(at)micom.com || \\ || | | || \\ || || || \\ || ;/--|| || | | ||/ || |' ||/ || Keep the shiny _--_-' \\/\\/ \\,/ \\/ \\,/ \\, side up ( ________________________________________________________________________________
Date: May 01, 1996
Subject: Re: Painting
On Wed, 1 May 1996, Robert Kearbey wrote: > Another question to all you experienced Kolb builders. > > Is it best to paint the whole plain together or to paint it piece > at a time and then re-assemble? More specifically, what about > painting the tail boom with all tail feathers attached? > hello Bob, I'm just down the road (in Davis) from you. Nice to see another Kolb in the area as there aren't all that many so far. I built and fly a Firestar KXP. On cables: I tried tape but ended up wetting a little solder in the area to cut. I used a little flux and butane torch; not too hot. Don't use wimpy dikes; sharp, hardened and big (aaaaarrr! aaaarrr!) with a quick squeeze works best. On painting: I painted most of my stuff separately and I think it added considerably to the amount of time i put into the whole project. I would think it best to prime the steel parts early just to keep them from getting corroded, but then hold off as much as possible on painting individual parts. Some areas, like the vertical stabilizer to fuselage joint might be just a little difficult for the paint gun to get to, but should be do-able. Another consideration is access to the spray equipment. If you borrow or rent, it is another reason to do as much as possible at one time. Gotta throw in the reminder; if you epoxy primed anything, paint will not stick to it unless you scuff sand it. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: May 01, 1996
From: Mail Delivery Subsystem <MAILER-DAEMON(at)acton.com> (by way of evoice(at)acton.com
(Doug Prange))
Subject: Returned mail: User unknown
This is a MIME-encapsulated message --GAA07457.830950845/acton.com from root@localhost ----- The following addresses have delivery notifications ----- (unrecoverable error) ----- Transcript of session follows ----- ... while talking to mailhost.community.net.: >>> RCPT To: <<< 550 ... User unknown 550 ... User unknown --GAA07457.830950845/acton.com Reporting-MTA: dns; acton.com Arrival-Date: Wed, 1 May 1996 06:40:11 -0500 (CDT) Final-Recipient: RFC822; kearbey(at)cnc.net Action: failed Remote-MTA: DNS; mailhost.community.net Diagnostic-Code: SMTP; 550 ... User unknown Last-Attempt-Date: Wed, 1 May 1996 06:40:44 -0500 (CDT) --GAA07457.830950845/acton.com Date: Wed, 1 May 1996 06:40:11 -0500 (CDT) From: evoice(at)acton.com (Doug Prange) Subject: Kolb-List: Re: cabling and props A GOOD PAIR OF SMALL VICE GRIPS (use the original) HAVE A WIRE CUTTING AREA INSIDE THE JAWS. EXPERIMENT A LITTLE WITH THE ADJUSTMENT AND THEY'LL WORK GREAT. >I am sure someone can tell me what the best way to cut the 3/32 >cable. I have tried several things but it always frays. Makes it >very difficult to put through the nico things!!! --GAA07457.830950845/acton.com-- ________________________________________________________________________________
Date: May 01, 1996
From: Robert Kearbey <kearbey(at)cnc.net> (by way of evoice(at)acton.com (Doug Prange))
Fellow builders, I am sure someone can tell me what the best way to cut the 3/32 cable. I have tried several things but it always frays. Makes it very difficult to put through the nico things!!! THE CUTTING JAWS ON A SMALL VICE-GRIPS WOEK GREAT. BUY THE ORIGINAL.....DON'T ACCEPT THE CHEAP IMITATION! Doug Prange Mark III Builder 65% Lincoln, Nebraska ________________________________________________________________________________
Date: May 02, 1996
>I am sure someone can tell me what the best way to cut the 3/32 >cable. I have tried several things but it always frays. Makes it >very difficult to put through the nico things!!! A way that does an excellent job cutting aircraft cable that I've used for many years: Wrap the cable with a layer or two of masking tape where the cut is to be made. Then cut the cable (slowly) with a Dremel tool and one of their thin cutting disks. It'll make about as pretty a cut as you could want. Skip Staub 1984 Ultrastar ________________________________________________________________________________
Date: May 02, 1996
Subject: Ballistic Parachute
Anyone ever mounted a ballistic parachute, specifically a BRS-5, on an Ultrastar? The instructions that came with the BRS-5 aren't very helpful on exact placement. Looking for some guidance on placement of the canister and primary loop. Bill Cloughley 1984 Ultrastar Essex Skypark, Maryland ________________________________________________________________________________
Date: May 02, 1996
Subject: Firestar II rear seat
I know the Firestart isn't a real two seater but how practical is it really to take someone up on the rear seat. Is it like stuffing a person inside a car trunk to go for a ride or is it actually an enjoyable experience?. I am getting a Firestar II with the second seat option so that I can take my wife up once in a very while. She's not a big woman but neither is she petite. Can a 150 pound adult really fit in this seat and enjoy the flight?. Chris ________________________________________________________________________________
Date: May 02, 1996
Subject: Where would I be able to buy parachute silk or similar?
On 2 May 1996, Bill Cloughley wrote: > Anyone ever mounted a ballistic parachute, specifically a BRS-5, on an > Ultrastar? The instructions that came with the BRS-5 aren't very helpful on > exact placement. Looking for some guidance on placement of the canister and > primary loop. > > Bill Cloughley > 1984 Ultrastar > Essex Skypark, Maryland > ________________________________________________________________________________
Date: May 03, 1996
Subject: Cable Cutting
Hello Kolb People, Well I to tried several tools to cut stainless steel cable and was about to settle for a pair of Sears electrical pliers, that was until John found quite by accident the perfect tool. ( What works the fastest and best, I think is a tool that shears the cable as opposed to the extra work of soldering the cutting area, using tape or wire & cable ties then attacking it with everything but the kitchen sink to get that nice clean cut !) I found no name or # on the tool, it is about 6 " lond and was made in Japan. I can tell you when you see it you will know right away that your cutting headaches are over. Ya know the old saying "Right Tool For The Right Job ?" Works most of the time in my shop here in New Bedford MA. Charles Chieppa ________________________________________________________________________________
Date: May 03, 1996
From: "Dr. Thomas A. W. Pijnenburg" <prodes(at)ibw.com.ni>
Subject: (no subject)
please any ultrafan on the internet; who can get me an address of the hirth engine factory in germany. I am grounded because I can't get spare parts for my Behlen trike with Hirth engine (2702) I would be very grateful for any reaction thomas pijnenburg thomas(at)ibw.com.ni ________________________________________________________________________________
Date: May 05, 1996
Subject: FireStar building photos
Greetings, Through the miracle of e-mail, and the generosity of Mike Holland, I've been receiving some of his FireStar building photos. Since I've got some space on the server, and plenty of time to kill before my Slingshot kit gets here, I posted them on my web page. I'll be adding more as I get them. Enjoy, Rusty http://www.gulf.net/~rad/ ________________________________________________________________________________
Date: May 05, 1996
Subject: thanks
thank you to all who showed interest in my flame-covered firestar at sun-n-fun. would like to hear from someone with their suggestions and impressions. :) wildfire ________________________________________________________________________________
Subject: props & cables
Date: May 06, 1996
Hello, everybody Untill now I've simply been lurking and enjoying all the exchange going on here. The thing that brought me up was Ben Ransom's comment about cutting cables. Ben wrote, " On cables: I tried tape but ended up wetting a little solder in the area to cut. I used a little flux and butane torch; not too hot. Don't use wimpy dikes; sharp, hardened and big (aaaaarrr! aaaarrr!) with a quick squeeze works best." I agree with the part about the dikes but I have a concern about the use of any kind of heat on a controle cable. Let me explain. I fly a Mark II, and also a Fire Star. Both of these planes I purshased and rebuilt after severe damage by a previous owner. The MarkII was severely damaged in an engine out situtation and the the Fire Star was severely damaged in a hanger roof collapse. About a year after rebuilding the Mark II I was taking off at a local ultralight event I suddenly lost rudder control due to a torn cable on take off in rather strong cross wind conditions. What an exciting situation! What I discovered later was that when doing the rebuild job I did some welding near by the cable pulleys and must have gotten the cables a little too hot. I thought I had sheilded them but it does not take much to destroy the temper in the fine strands that make up the cable. By a visible inspection everything seemed OK but one day all of a sudden it broke. There is no way an uncompromised cable is going to tear like that. Boy was I glad it was a rudder cable and not an evelator cable. Since that experience I never use any cable that has come close to being heated ever! About props, I use Ivo Props on both planes and would never go back to wood. I have one electric and one manual pitch change. Both are two blades. I appreciate and respect the comments of you both Ben and Mike Ransom and love the pictures of your planes on your home page. Happy Flying, Eugene PS Been flying Ultralights since 1979 so I'm a kinda oldtimer. ________________________________________________________________________________
Date: May 07, 1996
Subject: Re: props & cables
On Mon, 6 May 1996, Eugene Zimmerman wrote: > Hello, everybody > Untill now I've simply been lurking and enjoying all the exchange going on > here. The thing that brought me up was Ben Ransom's comment about cutting > cables. > Ben wrote, >> " On cables: I tried tape but ended up wetting a little solder in the >> area to cut. I used a little flux and butane torch; not too hot. >> Don't use wimpy dikes; sharp, hardened and big (aaaaarrr! aaaarrr!) with >> a quick squeeze works best." > > I agree with the part about the dikes but I have a concern about the use of > any kind of heat on a controle cable. ...clipped > cable. Since that experience I never use any cable that has come close to > being heated ever! Eugene, your point is well taken. I kind of pictured the possibiliyt of somebody getting a cable really hot as i wrote that suggestion. To clarify, I really only got the cable hot enf to melt electrical solder, and only in the short area (1/2"? ) that ends up looped back for the swage, and therefore is only the end part of the cable under the swage. This part ends up at least 2" down from the thimble, and of course is on the untensioned part. I agree that a totally careless job here could make this a seriously flawed method. In the end, the sharp hefty dikes is perhaps the most important part. BTW, I checked out most of the pictures put up by Rusty of Mike Holland's Firestar build photos. They really are GREAT! It was almost kind of funny seeing a yellow firestar come together, as it looked so much like my own! I've got a few build photos scanned too, and will add them to my web page soon. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Subject: Ivo Props
Date: May 07, 1996
Hello, Kolb enthusiasts This is my response to the questions about how I like my Ivo props. My first Ivo was a standard 66" two blade for the Mark II. It has a 582 engine. I was really impressed with the ability to change pitch by simply changing the shims and was happy to be able to fine tune to my personal preference. I was also impressed with the durability. No more repairing of erosion of the leading edges from dirt, bugs or rain like was necessary with all the wood props I've had on various planes before. My preference is to maximize efficiency at cruise rather than climb out performance. All Kolbs I have seen have more than enough climb out performance already. I can maintain a level comfortable 50-55 m p h with the engine turning a mere 4000 rpm. But just out of curiosity I also tried the flatter climb pitch. Whoa ! Does that ever make it sit on it's tail and climb like a homesick angel ! I also experimented with 2 verses 3 blade configuration and found that I prefer the higher pitch two blade for low rpm cruise efficiency. The 3 blade is somewhat smoother in flight but the extra weight of the 3 blade causes more torsional grief for the gear box on slow idle. My second Ivo was for the Fire Star which has a 377 engine. Because of my experience with first Ivo I decided to get the electric in flight adjustable prop. It is a 60" two blade. The performance I discovered is somewhat different than what I was initially expecting. While the effect of pitch change to rpm is very similar to the Mark II the effect on efficiency is very different. This I discovered is due to the 377 engine's much narrower rpm power band. The 582 has much better low end performance while the 377 engine has a more specific and higher rpm efficiency peak. The result I discovered, is to use the electric pitch change to keep the rpm in this narrow band at all power setting like a constant speed prop for best efficiency. The pitch changes are nearly opposite my first expectations. Rather than change to a greater pitch for a low power cruise which does lower engine rpm, it is much better to keep the engine in it's higher rpm efficient power band. My 377 uses much more fuel to maintain 50-55 mph level flight at 4000 rpm than it does at 5500-6000 rpm. So when I increase power I increase pitch, when I decrease power I decrease pitch to maintain this rpm range. I expect that each engine prop combination has it's own unique characteristics. Do I like my electric Ivo? You bet. There may be a better engine combo and I may try it on the 582 some time. These are simply my personal observations and experiences. Eugene ________________________________________________________________________________
Date: May 08, 1996
Subject: elevator trim
Greetings, As I sit here waiting for my kit to arrive, I got curious about a few things. 1- What provision for trim is included in the standard Kolb package (if any)? Is there a functional, in-flight adjustable elevator trim included or available for the FireStar/Slingshot? 2- Since the Slingshot will have flaperons, has anybody experimented with a "reflex" flap position to increase cruise speed? 3- Has anyone tried mounting the throttle on the stick? Since I'm left handed, I don't want it mounted in the normal left side location. On the Slingshot, the right side of the fuselage folds down which might complicate mounting it on the right side, plus it would be in the way when getting in and out of the plane. Thanks for your input. If any of this is well covered in the manual, you can just tell me to stop being impatient and wait. I CAN wait, but I WON'T stop being impatient :-) Rusty http://www.gulf.net/~rad/ ________________________________________________________________________________
Date: May 08, 1996
From: "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM>
Subject: Props, HINTS file
PROPS... Eugene, thanks for the info! Interesting stuff about Ivo prop/Rotax 582 combo. I read that the Ivo needs some kind of extension. Is that because it flexes more than wood or Warp brand? So you would be spacing it back further to clear the wing?? Your Ivo- it changes the pitch by turning some internal-to-the-blades rods to flex the blades, right? And is it electric? How smoothly does this work? How many hours of operation do you have on it? Eugene, you said the three-blade made the idle pretty rough on the gearbox. Were you using a "B" box? I wonder if this would be less noticable on the "C" box with damper... Some of you guys are probably using the Warp. I don't think they have an in-flight variable pitch prop available, I wonder if it is in the plans for Warp? Has anyone compared the performance of the ground adjustable Warp to a fixed pitch Ivo? I lean toward the higher carbon fiber numbers (stiffer blades) of the Warp, but understand the Ivos are smooth as glass. Have I asked enough questions yet? I definitly will buy some kind of composite prop when my MkIII is ready for an engine. I have purchased and "used up" four wood props on previous (ultralight) planes and was not satisfied with the lifespan. Eventually I bought a three-blade Ultra-prop. Remember that one? Some kind of composite blades, ground adjustable in full-degree increments with blocks bolted thru an aluminum-reinforced hub. It was very heavy compared to wood, and the performance wasn't really any better (in fact it had no twist), but it lived thru anything I threw at it. Just wiped off the bugs & grass once in a while. ANOTHER SUBJECT... As I read the answers to the question about cutting cable, I realized the vast untapped wealth of secrets, tips, shortcuts, procedures, etc. that this group collectively has. I am wondering if we could pull it all together, maybe by subject, into a sort of HINTS FILE FOR THE KOLB BUILDER. Natural additions to this would be the cable cutting techniques, probably the Black and Decker bullet drills, etc. If any of us had designed (or cobbled up) special little fixtures that cut assembly time or improved accuracy, they would be candidates also. Someone mentioned they remember an excellent note concerning spray painting, this would be great to have in the HINTS file. Another one would be experiences with prop/engine combinations. The reason I am asking is it seems I am doing a good job on my kit so far, and understanding things quite well, but I know many of you are miles ahead of me on your kits and even flying, and you know tips that would help me and others. The problem is I don't know what to ask to jog loose the information. Each of us know what neat little tricks we've come up with. Should we try to put something together? I am not sure how we would proceed, and that may be a question for the provider of this communication path. Does anyone have more ideas about implementing this sort of thing? ________________________________________________________________________________
Subject: Re: Props, HINTS file
Date: May 08, 1996
Earlier, Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM said: > > I am not sure how we would proceed, and that may be a question for > the provider of this communication path. Does anyone have more > ideas about implementing this sort of thing? Sounds like a FAQ, or Frequently Asked Questions list. If it was a text file, I could house it here and you would retrive it via a get command to the majordomo program. A better solution IMHO would be an HTML-based list resident somewhere on the Web. This would give you an online resource separate from the list. I don't have any web space available to the outside world. Perhaps someone would like to volunteer to maintain the list: accepting inputs from others, collecting the list & writing the HTML, and finally hosting it on some public web space. -- Jeff Stripling | /\/\ M O T O R O L A jstripli(at)mot.com | / \ Advanced Cellular Products Group (817) 245-6002 | Texas Products Division ________________________________________________________________________________ Pilots-N-Wannabees
Date: May 08, 1996
KOLB list: > <...> > ANOTHER SUBJECT... > As I read the answers to the question about cutting cable, I realized >the vast untapped wealth of secrets, tips, shortcuts, procedures, etc. >that this group collectively has. I am wondering if we could pull it >all together, maybe by subject, into a sort of HINTS FILE FOR THE >KOLB BUILDER. > <...> > I am not sure how we would proceed, and that may be a question for >the provider of this communication path. Does anyone have more >ideas about implementing this sort of thing? > <...> Jim, I maintain a collection of posts to both this list and the ultralight-flight mailing list. My mail reader, Eudora, makes it very easy to maintain extremely usable heirarchy of information. As I read a piece of mail that contains lasting, useful info, I hit something like: Transfer | Ultralight | Flying | Instruction or: Transfer | Ultralight | Planes | Make | Kolb This involves no more than a half dozen keystrokes, which I can do in my sleep at this point. With some four seconds invested in each message (after reading it, or course) I have a substantial archive built up. I am currently working on publishing the archive on the web... look for it in the next few weeks. I don't have a particularly large area on Kolbs. I encourage anyone on the Kolb list with a polite mail reader to build a more Kolb-o-centric database. Shortcomings include: o I have to process each message individually. (Not too bad, as ultralights are my passion!) o I place messages into entirely subjective categories, and I can't easily place a message under two categories (i.e. Instruction *and* Aerobatics) o I'm not aware of a easy way to turn the archive into a nice, heirarchial web page. It's going to be pretty vanilla text pages. But it's the content that matters, anyway, right? I will be posting the files in Eudora's file format, which is mostly straight text. It would be really cool if I can set it up that users can use Eudora, or possibly other mailers, to peruse the archive. I don't know if this will work out or not. I'd love to hear from anyone with related experience. o I don't differentiate between posts to the Kolb list and the Ultralight list. Oh, well. I'm eager to receive suggestions on how this tool can be most useful. -dave -- David Hempy Distance Learning applications programmer Kentucky Educational Television ________________________________________________________________________________
Date: May 09, 1996
Subject: SUN-N-FUN
HELLO: My flameded firestar did not qualify to be entered into competition due to not having the required minimum of 10 hours airframe time but did qualify for Craftmanship Award which I was honored to receive. If anyone has any questions about how or why I did something - let me know. I also do covering on general aviation aircraft. Any questions on aircraft covering or materials or hints on painting - drop a line. JOHN (WILDFIRE) ________________________________________________________________________________
Date: May 09, 1996
Subject: Re: SUN-N-FUN
> >HELLO: > My flameded firestar did not qualify to be entered into competition due >to not having the required minimum of 10 hours airframe time but did qualify >for Craftmanship Award which I was honored to receive. If anyone has any >questions about how or why I did something - let me know. > I also do covering on general aviation aircraft. Any questions on >aircraft covering or materials or hints on painting - drop a line. > You wouldn't happen to have a (or a few) picture(s) of it, would you? I'd really like to take a look at it, and I can always use another picture for the UL Home Page! :) -Jon- .------------------------------------------------------------------------------. | Jon Steiger: DoD# 1038, EAA #518210, USUA# A46209, NMA# 117376, KotWitDoDFAQ | | stei0302@cs.fredonia.edu && http://www.cs.fredonia.edu/~stei0302/ | | '96 Dakota SLT V-8 Club Cab, '91 FZR600R /* Just another mangy hacker */ | `------------------------------------------------------------------------------' ________________________________________________________________________________
Date: May 10, 1996
Subject: Aircraft parts suppliers
Hi, me again: I just ordered a LEAF catalog and the Rotax info-pak that they sell. I might order a couple other catalogs to have on hand as well. Who seems to have the best selection and prices for our needs? Got any favorites? Thanks, Rusty (still got awhile to wait- sigh) http://www.gulf.net/~rad/ ________________________________________________________________________________
Date: May 12, 1996
From: <Joe.Kohler(at)top.monad.net> manderson(at)monad.net
Subject: Building tips
I've noticed there are some new Kolb builders, so I thought I would repeat some building tips I sent through a few months ago. I've added a cable cutting tip since that has been a frequent topic lately. Here are some ideas and suggestions derived from my enjoyable FS II building process. They come with the standard disclaimer: use at your own risk, and verify with the factory if you have any questions. 1. A miter box saw with a metal blade (available from Northern Hydraulics - 1-800-533-5545) is an excellent tool for cutting tubing. 2. A pneumatic riviter, also available from Northern, is very handy and costs only about $60. 3. Duct tape works great for holding parts prior to riviting, e.g., in holding the ribs against the front and rear spars. You can adjust the position if needed and then drill right through the duct tape, which will keep the drill bit from skipping. 4. Cleco's (a sort of temporary rivit available from aircraft supply shops) work well to attach parts prior to riviting. 5. If you obtain a 5/16 th tubing bender the trailing edge of the elevator and ailerons can be made in a single piece with nice radiused corners. 6. When attaching the lower front triangular gussets to the vertical stabilizer, note that some rivits are to be omitted until the stabilizer is attached to the fuselage tube during final assembly. Do not drill holes for these rivits until then. 7. Don't prime the ends of the steel drag strut ends, elevator horns, or lift strut ends that are to be located inside aluminum tubes because the primer will only have to be sanded off in order for the tubes to fit. It might be a good idea to grease these before inserting them to prevent corrosion. 8 . It may be necessary to gently tap the steel elevator horns into the leading edge tube of the elevator in order to get them in far enough to obtain the 1/2" gap between the horizontal stabilizer and the fuselage tube. The protruding ends of these fittings are slightly out of round, which will cause the leading edge of the elevator tube to become slightly out of round where they are tapped in. 9. The AN4-12A bolt that fastens the aluminum tailwheen bar to the lower tube of the bottom vertical stabilizer should be located about an inch in back of the forward end of the bar (I think)(as opposed to near when the bar exits the tube because a hole there would tend to weaken it. 10. A few drops of motor oil dripped into the inside of the H-section used in the wings and fuselage may reduce internal corrosion. 11. On page 24 of the manual, the second sentence should end "...a shorter tube to be placed on the inside bottom of the wing tube" ( I think) ( as opposed to inside top). 12. The two ribs located over the H-section portion of the spar should be slid into position before the H-section is rivited. 13. Before riveting the front spar to the ribs near the inboard end of the wing, install the inboard rib nose (you can't get it on once the LE is rivited on). 14. When installing elevator and rudder hinges, make sure hinges are not installed "upside down" in terms of the location of the hinge pin. Study plans carefully. Put in a couple #6 screws and check the up and down movement before drilling the remaining zillion holes. 15. If you drill out several rivits and feel the holes have become too large you could replace the 1/8 inch rivits with 5/32 rivits. 16. Before covering, the application of adhesive tape over rivits that will be directly under and in contact with the covering, and also over where rivits attach to leading edge tubes, may smooth and sharp transitions and protect the dacron from abrasion from below. 17. Before covering wings apply Polytak to the wings ribs and let dry. After fabric is applied and heat shrunk rub MEK through the fabric and it will stick the fabric to the ribs. Then apply the tape and fabric rivits. 18. A dab of 3-M structural adhesive applied between gussets and tubes, and between ribs and tubes may provide extra security and resistance to vibration and spread loads very uniformly. It's certainly not necessary but it can't hurt either. Clean parts first with acetone. 19. A good way to cut control cable is to lay the cable on a steel object like an anvil or 5 lb. hammer, and give it a whack with a sharp 1/2" wide cold chisel. Cuts off cleanly. ________________________________________________________________________________
Date: May 14, 1996
Subject: Linkage to Kolb Aircraft Home Page
Dear Webmaster: I was inquiring about the possibility of your home page having a link to our home page. Our company is Aviation Laboratories, which specializes in several different aviation parts and services. Our URL is: http://www.avlab.com Our Description: Aviation Laboratories provides aviation parts, aviation products & general aviation services. FBO's, LearJet, Citation, Gulfstream, and Falcon operators utilize oil and hydraulic analysis, rotables, and aviation parts location services. Your generousity will be appreciated and we will return the same opportunity when you reply to our request. I am requesting a small description of your company for your listing on our page. If you have any questions or comments, please call me at (713) 864-6677 ext. 217 or e-mail me. Thank you for your time. Sincerely Duc Nguyen Webmaster Aviation Laboratories ***************************************************************** Duc K. M. Nguyen Phone: (713) 864-6677 Director of the Internet (800) 256-6876 Aviation Laboratories Fax: (713) 864-6990 http://www.avlab.com E-mail: avl@nol.net ***************************************************************** ________________________________________________________________________________
Date: May 15, 1996
Subject: Trailer\transportation
Need info on what is the best method of transporting a Mark III. Airport is 6 mi. away. Do not want to spend $ on hanger space or tie down. Can certain existing trailers be modified, such as a boat trailer? ________________________________________________________________________________
Date: May 15, 1996
Subject: Re: Linkage to Kolb Aircraft Home Page
Just for everyone's information, I have responded to this individual about his request. If anyone new to the list does not know, I maintain the Kolb Aircraft home page, located at http://www.usa.net/~rael/kolb/index.html. Check it out and give me your feedback. I admit I haven't added much to the Web page lately, but I hope to add some new material in the next few months, including building tips as suggested in some earlier posts. I'm building a Mark III and hope to have photos of my progress on the Web before too long. -- Mike Rael rael(at)usa.net http://www.usa.net/~rael ________________________________________________________________________________
Date: May 15, 1996
Subject: Re: Trailer\transportation
>Need info on what is the best method of transporting a Mark III. >Airport is 6 mi. away. Do not want to spend $ on hanger space or tie down. >Can certain existing trailers be modified, such as a boat trailer? > Yeah, Ditto all this, except mine will become a Firestar after I get the rest of the pop rivets in place. My airport is just a little farther, and hangar rent is prohibitive. The wind can scream here, so it isn't going to be tied outside. But since I'm also into river-running, I need to come up with a trailer to serve both functions: A flat bed for my raft, which is 17' long and wider than the folded Kolb, and low enough that I'll be able to get my Kolb up onto it. Enough structure that there's some protection from the wind at freeway speeds (which are now even faster than the Kolb will fly). Maybe I can't easily do this, but I'm gonna try. And if I do succeed, I'll post a picture of it on my home page--which isn't there yet because I need to figure that out too. Tom ________________________________________________________________________________
Date: May 15, 1996
On Wed, 15 May 1996, thomas g. rampton wrote: > >Need info on what is the best method of transporting a Mark III. > >Airport is 6 mi. away. Do not want to spend $ on hanger space or tie down. > >Can certain existing trailers be modified, such as a boat trailer? > > > > Yeah, > > Ditto all this, except mine will become a Firestar after I get the rest of > the pop rivets in place. My airport is just a little farther, and hangar > rent is prohibitive. The wind can scream here, so it isn't going to be tied > outside. > > But since I'm also into river-running, I need to come up with a trailer to > serve both functions: A flat bed for my raft, which is 17' long and wider > than the folded Kolb, and low enough that I'll be able to get my Kolb up > onto it. Enough structure that there's some protection from the wind at > freeway speeds (which are now even faster than the Kolb will fly). > > Maybe I can't easily do this, but I'm gonna try. And if I do succeed, I'll > post a picture of it on my home page--which isn't there yet because I need > to figure that out too. > I think my trailer is close to what you're talking about. See http://mae.engr.ucdavis.edu/~ransom/trailer.html I don't routinely do freeway stuff cuz my airport is close. I've done it though, and 55-60 is okay, but more gets too nerve racking. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: May 15, 1996
From: Cliff & Carolyn Stripling <striplic(at)flash.net>
Subject: Two Place Kolb Wanted
To All... A fellow by the name of Paul Wells is interested in purchasing a two place Kolb and asked that I mention it to the list for him as he has no internet access. He lives out in the country south of Ft. Worth, Tx. and wants a two place design that is foldable. He is an experienced welder and wants to build a trailer to keep it in at the local airport or possibly at home. He said he prefered one already built, but would certainly consider one under construction. If anyone is interested, below is his address and phone. Paul Wells (817) 293-6080 10128 Crowley Rd. Crowley, Tx. 76036 Later, Cliff & Carolyn Stripling He - Kolb MK III builder (95%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate http://www.flash.net/~striplic Both - R/V travel enthusiasts (under construction) ________________________________________________________________________________
Date: May 16, 1996
Subject: Covering the Mark #3 fuselage
Fellow Kolb Builders, I need any input that you all would like to share!! I'm covering my fuselage and would like to inclose it completely as the instructions suggest. It seems that I must install the gas tanks, gas lines and misc. stuff before covering and painting. I would like to paint before installing anything that can wait till then. Are there any options that I may be over looking? Plus are there any suggestions to which I-comm is best? Last, are there any prefered locations for the power supply box and the strob light power supply box. (I guess any wiring ideas in general would be a good help.) Thanks Emerson L. Klotz ________________________________________________________________________________
Date: May 16, 1996
Subject: Single vs. dual carbs
Greetings, Since I have nothing better to do than obsess over details while I'm waiting for my Slingshot kit, I was curious about multiple carbs. Rotax sells the 503 engine with either single (46 HP) or dual carbs (50 HP). I'm assuming that the cruise power can be the same with either arrangement, but the climb power will be affected slightly. It looks to me like the power difference isn't worth the extra trouble of having 2 carbs. Check my logic below and let me know what you think. The advantages as I see it: Single: lighter (2-3 pounds) cheaper ($100) simpler- less to install and cause trouble (linkage, oil line, fuel line, carb itself) Dual: More climb power (4 HP/ 8%) Any comments would be appreciated. Russell Duffy http://www.gulf.net/~rad ________________________________________________________________________________
Date: May 17, 1996
Subject: Re: Single vs. dual carbs
Russell, >It looks to >me like the power difference isn't worth the extra trouble of having 2 >carbs. Check my logic below and let me know what you think. I tend to agree with your logic. Keeping it simple will pay dividends in the long run. If you want to climb and cruise faster the dual carb option will make little difference. Skip 1984 Ultrastar ________________________________________________________________________________
Date: May 19, 1996
From: Brandon Kearbey <bkearbey(at)bcoe.butte.k12.ca.us>
Subject: Throttle configurations
Hello all, My father and I are building a MarkIII. We have finished kit 1 and are now waiting for kit 2 & 3. By looking at the throttle configuration it seems to be a little akward. I saw an advertisement for a dual throttle configuration somewhere and now I can't find it. I would like to hear some input on a couple of questions that my father and I have. 1. How easy is the standard configuration to use? 2. Does anyone know where to get the dual throttle conversion and is it really needed? 3. Has anyone thought of using an on-stick throttle control like a motorcycle throttle? Your input is greatly appreciated. Brandon Kearbey ________________________________________________________________________________
Date: May 20, 1996
On Thu, 16 May 1996, Russell Duffy wrote: > Greetings, > > Since I have nothing better to do than obsess over details while I'm > waiting for my Slingshot kit, I was curious about multiple carbs. Rotax > sells the 503 engine with either single (46 HP) or dual carbs (50 HP). > I'm assuming that the cruise power can be the same with either > arrangement, but the climb power will be affected slightly. It looks to > me like the power difference isn't worth the extra trouble of having 2 > carbs. Check my logic below and let me know what you think. > > The advantages as I see it: > > Single: lighter (2-3 pounds) > cheaper ($100) > simpler- less to install and cause trouble > (linkage, oil line, fuel line, carb itself) > > Dual: More climb power (4 HP/ 8%) Rusty, I've heard that dual carbs would use more fuel, but this may be a blanket assumption. I'd be curious of the real answer. If there were fuel savings, this is also a strong plus for single carb. I've also thought that the 503 dual carb is rated at 52 HP. When you consider the incremental gain of 6 HP for only 2.5 lbs, it is one of the best bargains around. (As a comparison, a 447 SC is 40HP at 79 lbs -- with carb, exhaust, and gearbox -- about 2 lbs/HP!) --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: May 20, 1996
Subject: Download tips.
I have found some web sites were I was able to see some pictures of the Firestar (or other kolb aircraft) under construction. I would appreciate any input as to any web sites were construction tips or pictures can be found. Also, is there a way to download old messages sent through this mail list, if they are somehow stored. I would immagine there is a lot I could learn from reading old messages. Thanks, Chris ________________________________________________________________________________
Date: May 20, 1996
Ben Ransom wrote: > Rusty, > I've heard that dual carbs would use more fuel, but this may be a > blanket assumption. I'd be curious of the real answer. If there > were fuel savings, this is also a strong plus for single carb. I've also > thought that the 503 dual carb is rated at 52 HP. When you consider > the incremental gain of 6 HP for only 2.5 lbs, it is one of the best > bargains around. (As a comparison, a 447 SC is 40HP at 79 lbs -- with > carb, exhaust, and gearbox -- about 2 lbs/HP!) > > --------|-------- > Ben Ransom (*) > UCD Mechanical Engineering Dept. o o > Email: bransom(at)ucdavis.edu > http://mae.engr.ucdavis.edu/~ransom > (916) 752-1834 Ben, I've seen the 503 dual rated at 52 HP but I can't remember where. All the shiny Rotax info sheets I have list it as 50 HP. I"m also thinking the same people who claimed 52 HP for the dual, rated the single at 48 HP. Unless I hear differently, I guess I've got to trust what's on the Rotax info sheets. As for the fuel issue, I would expect that the dual carb setup would have the same or slightly less fuel flow than the single carb when producing the same HP. It should be just a bit more efficient I think. Of course, at full throttle, the dual will use more fuel because it's producing more power. The other question is redundancy. What happens when one of your dual carbs bellies-up during a flight (no fuel flow, flooding, air leak.. take your pick)? I don't think a single healthy cylinder could supply enough power to keep the plane aloft but it would certainly give you more options for a landing. How long would the engine run before the dead cylinder seized up? Is safety a good reason for dual carbs? The other good point I can see for duals, is that you can optimize the settings for each cylinder. I'm not sure it's necessary, but it seems like you could (maybe that's how you get 52 HP, hee hee). The dual would be the easiest to get since I know that Kolb will supply it. It might turn out to be the best way to go. Thanks for any additional thoughts you might have. Rusty (Ordered the kit 5 weeks ago today) http://www.gulf.net/~rad/ ________________________________________________________________________________
Date: May 20, 1996
Does anyone on the list know where I can obtain a material known as "Poly Board Stiffners". This is a material that looks like white plastic cardboard. I has been used as a backing for fabric on aircraft interiors. I have located a company in PA. which uses this material for aircraft upholstery. It comes in 4' x 6' sheets at a cost of $12.00 each. I would like to located a source for the material closer to home (North Central Illinois). Rich ________________________________________________________________________________
Date: May 20, 1996
Subject: Re: Download tips.
Chis, The only pages I know of are: Mine: http://www.gulf.net/~rad/ Ben Ransom's: http://mae.engr.ucdavis.edu/~ransom Kolb: http://www.usa.net/~rael/kolb/index.html The closest thing to building tips I've seen is on Ben's page with his building photos. If anyone knows of any other sites, please post them to the list because I would certainly be interested too. I don't know of an archive unless someone has kept one personally. Again, if there is one, I'd like to know also. Good luck, Rusty ________________________________________________________________________________
Date: May 21, 1996
Note: This is a resend. I originally sent it last night, but never saw it on the list. Sorry if it's a duplicate. Ben Ransom wrote: > Rusty, > I've heard that dual carbs would use more fuel, but this may be a > blanket assumption. I'd be curious of the real answer. If there > were fuel savings, this is also a strong plus for single carb. I've also > thought that the 503 dual carb is rated at 52 HP. When you consider > the incremental gain of 6 HP for only 2.5 lbs, it is one of the best > bargains around. (As a comparison, a 447 SC is 40HP at 79 lbs -- with > carb, exhaust, and gearbox -- about 2 lbs/HP!) > > --------|-------- > Ben Ransom (*) > UCD Mechanical Engineering Dept. o o > Email: bransom(at)ucdavis.edu > http://mae.engr.ucdavis.edu/~ransom > (916) 752-1834 Ben, I've seen the 503 dual rated at 52 HP but I can't remember where. All the shiny Rotax info sheets I have list it as 50 HP. I"m also thinking the same people who claimed 52 HP for the dual, rated the single at 48 HP. Unless I hear differently, I guess I've got to trust what's on the Rotax info sheets. As for the fuel issue, I would expect that the dual carb setup would have the same or slightly less fuel flow than the single carb when producing the same HP. It should be just a bit more efficient I think. Of course, at full throttle, the dual will use more fuel because it's producing more power. The other question is redundancy. What happens when one of your dual carbs bellies-up during a flight (no fuel flow, flooding, air leak.. take your pick)? I don't think a single healthy cylinder could supply enough power to keep the plane aloft but it would certainly give you more options for a landing. How long would the engine run before the dead cylinder seized up? Is safety a good reason for dual carbs? The other good point I can see for duals, is that you can optimize the settings for each cylinder. I'm not sure it's necessary, but it seems like you could (maybe that's how you get 52 HP, hee hee). The dual would be the easiest to get since I know that Kolb will supply it. It might turn out to be the best way to go. Thanks for any additional thoughts you might have. Rusty (Ordered the kit 5 weeks ago today) http://www.gulf.net/~rad/ ________________________________________________________________________________
Date: May 21, 1996
Note: This is a resend. I originally sent it last night, but never saw it on the list. Sorry if it's a duplicate. Chis, The only pages I know of are: Mine: http://www.gulf.net/~rad/ Ben Ransom's: http://mae.engr.ucdavis.edu/~ransom Kolb: http://www.usa.net/~rael/kolb/index.html The closest thing to building tips I've seen is on Ben's page with his building photos. If anyone knows of any other sites, please post them to the list because I would certainly be interested too. I don't know of an archive unless someone has kept one personally. Again, if there is one, I'd like to know also. Good luck, Rusty ________________________________________________________________________________
From: jstripli(at)hpmail2.fwrdc.rtsg.mot.com (Jeff Stripling)
Date: May 21, 1996
Earlier, Russell Duffy said: > > I don't know of an archive unless someone has kept one personally. > Again, if there is one, I'd like to know also. To retreive a list of previous month's digests, send email to majordomo(at)ftw.mot.com and include this line in the body of your email: index kolb This will return a list of files. Each file represents one month's worth of traffic. To get a file, again address mail to majordomo(at)ftw.mot.com and include this line in your mail: get kolb kolb.YYMM Where YY represents the last two digits of the year and MM represents the two digits of the month, with a leading zero for months 1-9. For example, to get all postings for March, 1996, you would send: get kolb kolb.9603 You must be a member of the list to get files. List digests are available from March, 1996 to the present... -- Jeff Stripling | /\/\ M O T O R O L A jstripli(at)mot.com | / \ Advanced Cellular Products Group (817) 245-6002 | Texas Products Division ________________________________________________________________________________
Date: May 25, 1996
Subject: Fabric Work
Skip : Detailed instructions would be hard to give out over the net. Need to know in detail what you've done and how far you've gone before I can help you any farther. Please let me know how I can get in touch with you so I can be of further assistance. John ( wildfire ) ________________________________________________________________________________
Date: May 25, 1996
Subject: Tool & Equip
Hi all, I=B9m almost ready to order a FireStar II and will be constructing it in a standard two car (19=B9W x 23=B9L) garage. I would like to get some suggestions from the other builders of FireStar=B9s, regarding the the minimum size workbench needed (width & length), and the tools & equipment needed that would help me save time, and do a more accurate and cleaner job. I know that a small Drill Press would come in handy, but how small? I seen a small Black&Decker DPress at Wal-Mart ($175), that had what looked like to be a 10=B2 x 1O=B2 work surface. Would this be too small? Reading through past postings, others have mentioned things like hot glue guns, miter boxes, etc... Any and all suggestions will be greatly appreciated. Curtis ________________________________________________________________________________
Date: May 26, 1996
Subject: Re: Tool & Equip
>Hi all, > >I=B9m almost ready to order a FireStar II and will be constructing it in a standard two car (19=B9W x 23=B9L) garage. I would like to get some= suggestions from the other builders of FireStar=B9s, regarding the the minimum size workbench needed (width & length), and the tools & equipment needed that would help me save time, and do a more accurate and cleaner job. I know that a small Drill Press would come in handy, but how small? I seen a small Black&Decker DPress at Wal-Mart ($175), that had what looked like to be a 10=B2 x 1O=B2 work surface. Would this be too small? Reading through past postings, others have mentioned things like hot glue guns, miter boxes,= etc... > >Any and all suggestions will be greatly appreciated. > >Curtis > My workbench was just a standard 4 X 8 sheet of particle board (thick enough to be really flat and level). I built a frame for it making it a table at the height that suited me. It worked just fine in building all of the parts requiring a flat/level surface. The long tubes for the ailerons and flaps had to be supported off the table but that was no problem. I found I did not miss having a drill press at all. I found that the 6" grinder/wire brush combo was absolutely necessary. You definitely need a vice and various clamps come in handy. I used a lot of duct tape and masking tape to temporarily hold things together. I used a couple hundred sheet metal screws (poor man's clecos). An electric screwdriver is helpful. I used a hand rivet puller and got by just fine (good exercise and a four letter vocabulary enhancer). I found a Dremel tool (especialy the cut off wheels) very handy for many jobs. I wish that I had purchased spray painting equipment, but got around that by imposing on a friend to apply the epoxy chromate and Polytone on the fuselage boom, fiberglass and other aluminum trim parts, having the local high school paint shop paint the flying surfaces and sponge rolling the fuselage Stits cover myself. I would recommend having the fuselage cage and steel parts powder coated (I did not and wish I had). I recommend buying the ribs already made by Kolb. I had a 3 car garage to use and while I did much of the construction in about the space of 1.5 cars, occasionally I expanded to the full 2 car area. I built a simple pipe rack on one wall to sort the various sizes and thicknesses. You have to find places to store finished parts and supplies. I used space under beds, in closets & in the attic. I had a wonderful time building everything... with maybe the possible exception of having to tweak (to make fit perfectly) all of the false ribs. Have fun... Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: May 26, 1996
Subject: 98% done?
Cliff, The tool info was interesting, thanks for passing that along to the list. Your signature says 98% for the MK III. How about teasing us all with a progress report. Just what remains to be done at 98%? Thanks, Russell Duffy (waiting 6 weeks tomorrow) http://www.pcola.gulf.net/~rad (slightly new address, old one still works) ________________________________________________________________________________
Date: May 26, 1996
Subject: Re: 98% done?
>Your signature says 98% for the MK III. How about teasing us all with a >progress report. Just what remains to be done at 98%? Russell & All... I need to finish the back half of the wing gap seal. I have trimmed around the engine, but the bracing, hold down, springs, and muffler heat sink need to be added. I need to install the ELT antenna. I need to fix leaks of antifreeze seeping from under head bolts in the area where the radiator and oil tank brackets are attached. I understand you can use a little high temp RTV on top of and below the bracket to fix this type of leak. I need to break-in the engine. I need to have it inspected by the FAA. I need a 3rd class physical and a bi-annual (including several hours of dual for this very rusty pilot and several more hours of practice). I also would like to get some dual time in a MK III. I need to find an airport and hanger in my area. I need to build or buy a trailer (but that is another whole subject). Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: May 26, 1996
Curtiss, I'd agree with Cliff that a drill press isn't all that necessary. I only used mine a few times and the hand drill would have been fine too. For my tool purchashing, I bought a compressor and paint gun, and a hand rivet tool ...that's about it. Kind of a wierd thing, I used my radial arm saw quite a bit to cut out the AL gussets. This requires care obviously, as you can imagine the saw grabbing the AL and then perhaps your fingers. But if you use a fine tooth ChroMoly blade, hold the stock firmly, and go kind of slow, you'll get easy and beautifully straight-edged gussets. A bench vice is pretty handy and of course a riveter and decent file are bread and butter items. I also made use of some pieces of hard wood dowel ( ~3/4" diam) and also hardwood 1x2 stock. I used these as forms to press or hammer curves into the few gusset pieces that have curves. Also, one comment on workbenches. Mine is/was 4x8 foot, but one of the nice things about it is that the frame underneath is recessed to only ~3 feet wide -- making room for your feet. This allows you to stand right up to the table surface without constantly bending over. A wider workbench isn't worth much cuz you can't reach the other side anyway. Lastly, for shrinking the fabric you'll need an iron and the little bi-metal calibrating thermometer. I think almost any iron would do, but keep an eye out for a rummage sale extra, cuz whatever you use will for evermore have polytac goo stuck to it. I also bought a hobby size (for model airplane) iron which was v. useful for heating small areas. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: May 28, 1996
A table made out of a sheet of plywood works nice. Build a 2x4 frame and a couple of cross members to keep it flat. As tools go, the Kolb doesn't require a lot of tools, but like any project some tools make the job easier. A bench combo belt/disk sander is very handy and used a lot. (Delta makes one, Sears also sells one but my friend killed his in short order, had to take it back and replaced it with the Delta which he has been happy with since.) Regarding the pop rivet tool, you will want a hand version, but in the end I really think you'll want an air powered puller ($50-$60). Most peoples hands can't take the hand puller for long. Again my friend thought he could, finally went out bit the bullet and bought a air compressor and a air powered puller. Their available from Harbor Freight or Northern Hydraulic Northern cost just a little most but they ship faster and are a good company. You will need a hand drill, a variable speed is best to control starting the holes and not running the bit across the metal which can lead to cracks. A good prick punch, Stanley has a yellow handled one don't waste you money on the clones, they don't work that well. Get the one made by General ($12-16). He cuts tubing on a table saw with a metal blade. Seems to work. You may also want a pin punch they diameter of the mandrel of the rivets to drill out the mandrel if necessary. Black and Decker makes a drill bit called a bullet tip. They work good for starting holes. For rivets, always drill your holes under size (.125 or 1/8"), then enlarge them with the correct size (#30 drill) when your sure the holes are in the right place. Another tip is do not mark on aluminum with pencil, use fine point felt tip markers. Pencil lines have been known to develop cracks. While some people will say they done it, when you get to the aircraft industry they don't for that reason. Two good ones are Pilot and a German produced one. The German pens have reddish pink body. Sharpies don't seem to work well for long marking on aluminum for some reason. Here's another. You have to form many flat ends on aluminum tubing, get 2 short pieces of aluminum angle stock (shim it to the correct thickness if necessary) put it in the jaws of a vice. You then squeeze the tubing until you bottom out on the thickness established by the angle stock you have placed in the vice jaws. Work great, same thickness every time. Last thing you need is a deburring tool to deburr the holes you drill. You can use a larger size drill, or there are tools available strictly for that purpose. While working on my RV-6, I made a device which holds a standards aircraft deburring bit. It has hex on one end and a 1/4-28 thread on the other to accept a bit. You put it into a battery powered screwdriver like the B&D super twist. The slower 120 RPM unit works the best since the ideal is to deburr not remove so much metal you counter sink. It saves a lot of time. I loaned mine to my friend, now I can't get it back he likes it so much. You probably will want a good pair of sheet metal (tin) snips. They make a aluminum model (light weight) which come in either 12 or 14". I suggest you get the 14 inch long model as it is easier on your hands, takes less effort. They work well and make a nice smooth cut. Many aircraft metal tools are available from a company called Avery Enterprises located in the Dallas/Fortworth Texas area. They're a great outfit to deal with and supply tools to many of the RV aircraft builders. If you need anything further info, send a email to jerryb(at)ods.com Good luck and have fun. ______________________________ Reply Separator _________________________________ Subject: Kolb-List: Tool & Equip Date: 5/25/96 5:53 PM Hi all, I=B9m almost ready to order a FireStar II and will be constructing it = in a standard two car (19=B9W x 23=B9L) garage. I would like to get = some suggestions from the other builders of FireStar=B9s, regarding the = the minimum size workbench needed (width & length), and the tools & = equipment needed that would help me save time, and do a more accurate = and cleaner job. I know that a small Drill Press would come in handy, = but how small? I seen a small Black&Decker DPress at Wal-Mart ($175), = that had what looked like to be a 10=B2 x 1O=B2 work surface. Would = this be too small? Reading through past postings, others have mentioned = things like hot glue guns, miter boxes, etc... Any and all suggestions will be greatly appreciated. Curtis ________________________________________________________________________________
Date: May 28, 1996
>I used my radial arm saw quite a bit to cut out the AL gussets. >This requires care obviously, as you can imagine the saw grabbing >the AL and then perhaps your fingers. But if you use a fine >tooth ChroMoly blade, hold the stock firmly, and go kind of slow, >you'll get easy and beautifully straight-edged gussets. Ah...just so. Except I used the radial arm saw and a metal abrasive cut-off wheel for the tubes. The trick is to have the tube resting against the back fence and position the wheel centered or just slightly forward over the tube and use the elevation feature to lower the wheel through the tube. Square cut and a light spin on the grinder for the outside and a quick turn of the deburring tool to get the inside edge of the tube. As for work tables....try getting a solid-core door from a building/supply...various widths and lengths. Then get a folding legs set and attach to the bottom. Seems to me I only spent $25 on the table and you can fold up the legs and store it. Jim Baker Oklahoma City ________________________________________________________________________________
Date: May 28, 1996
On Tue, 28 May 1996 JLBAKER40(at)aol.com wrote: > >you'll get easy and beautifully straight-edged gussets. > > Ah...just so. Except I used the radial arm saw and a metal abrasive cut-off > wheel for the tubes. The trick is to have the tube resting against the back > fence and position the wheel centered or just slightly forward over the tube > and use the elevation feature to lower the wheel through the tube. Square cut > and a light spin on the grinder for the outside and a quick turn of the > deburring tool to get the inside edge of the tube. > > As for work tables....try getting a solid-core door from a > building/supply...various widths and lengths. Then get a folding legs set and > attach to the bottom. Seems to me I only spent $25 on the table and you can > fold up the legs and store it. > Ah ...just so again. Folding it up when you're finished is nice cuz you'll need the room to store your airplane! I ended up cutting away 1 foot from the width of mine when I got to this point. :) --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: May 29, 1996
Subject: Re[2]: Tool & Equip
In place of buying legs for the table referenced previously, invest in saw horses. After you complete the tail parts, you reuse for doing the wings. I bought a couple sets of the metal Hirsh saw horses. Note they come in 24 or 30 inch high. The 30 works best for table applications. ______________________________ Reply Separator _________________________________ Subject: Kolb-List: Re: Tool & Equip Date: 5/28/96 9:49 PM >I used my radial arm saw quite a bit to cut out the AL gussets. >This requires care obviously, as you can imagine the saw grabbing >the AL and then perhaps your fingers. But if you use a fine >tooth ChroMoly blade, hold the stock firmly, and go kind of slow, >you'll get easy and beautifully straight-edged gussets. Ah...just so. Except I used the radial arm saw and a metal abrasive cut-off wheel for the tubes. The trick is to have the tube resting against the back fence and position the wheel centered or just slightly forward over the tube and use the elevation feature to lower the wheel through the tube. Square cut and a light spin on the grinder for the outside and a quick turn of the deburring tool to get the inside edge of the tube. As for work tables....try getting a solid-core door from a building/supply...various widths and lengths. Then get a folding legs set and attach to the bottom. Seems to me I only spent $25 on the table and you can fold up the legs and store it. Jim Baker Oklahoma City ________________________________________________________________________________
Date: Jun 04, 1996
Subject: Thanks All !
Kolb List, Much thanks to all who responed to my post. It has saved me both time and money. I was going to build another workbench (4x14) for the wing assembly, in addition to my already (3x8) bench. But it sounds like a sturdy and level 4x8 surface will do fine. I purchased some of the tools/equipment that were reccomended, but have be unable to locate a snap puch yet. Thanks Again.. Curtis ________________________________________________________________________________
From: "bkearbey" <bkearbey(at)bcoe.butte.k12.ca.us>
Date: Jun 04, 1996
Subject: Benjamin: Pictures?
Hello Benjaman, About 2 weeks ago you said that you said you would send us pictures of the dual throttle conversion that your son made. We are getting down to that point and was wondering if you sent the pictures or still are intending to. I would appreciate it very much. Thanks again, Brandon Kearbey | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "MarkIII" (sort of). /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe.butte.k12.ca.us . \_______/ |---------/-----| (_____________//--------------\^ / o ( ) ________________________________________________________________________________
Subject: Re: Re[2]: Tool & Equip
Please stop sending me mail on this KOLB thing, I don't know why I'm getting this stuff and I am certainly not interested, thanks. ________________________________________________________________________________
Date: Jun 05, 1996
Subject: skip(at)netline.net - fabric repair
Skip : Suggestion : use an artist's pallette knife ( available in most art supply stores ) to remove all paint and tape in a 2 inch wide band directly on top of the rib where your fabric now ends. There should be approximately 1 inch of clean fabric on each side of the rib. Remove the rivits which hold the fabric in place by drilling them out with a 1/8 " diameter high speed drill bit. Attach new, clean fabric on top of the old fabric with polytack. ( I would suggest pinking the edges of old and new material for better adhesion ) You should now have a 2 " glued overlap of fabric at the rib. Stretch out the new fabric and attach to the wing structure in accordance with Stits instruction manual and Kolb's. When the new material is in place and the polytack is completely dry, shrink the new fabric in the normal way. This will tighten old and new material alike. Reinstall rivits and 2" reinforcing tape over rib and complete the repair as if it were new construction. 7175972212 John ( wildfire ) PS: GOOD LUCK! Holler if you need any help:) ________________________________________________________________________________
Date: Jun 06, 1996
Subject: nearest kolb
I have a physical problem whick involves getting in and out of confined spaces.ie, struts, guy wires and stuff low to the ground. I went to an Ultralite meet held at Happy Valley airstrip last June 18th. Most of the crafts seem impossible to me. Looked at a Buccaneer but the space to drag legs in seemed difficult. There were several Kolbs there but wasn't able to contact owners.Are there any Kolbs in or near northern New York that I could try to sit in? As I am having difficulty using Netscape Mail, could anyone reply via ....tryon(at)aol.com.... Thanks, Paul Tryon PO Box 11 Keene Valley, NY 12943 (518) 576-9876 ________________________________________________________________________________
Date: Jun 06, 1996
Subject: demo ride in FS-II wanted
I'm a prospective buyer for a Kolb FS-II or Slingshot kit and am looking to get a ride in one before purchasing. I would like to locate someone near east-central Illinois (I'm in Champaign-Urbana) who would be willing and able make this a reality. Thanks in advance. Please reply to: mark(at)sun.sws.uiuc.edu or phone (217) 684-2357. ________________________________________________________________________________
Date: Jun 07, 1996
Subject: More Mail?
Have not received a lot of mail or in fact any on Kolb products. These aircraft are to me the most interesting and look forward to any and all Kolb info from builder, prospective builders and flyers. Thanks Jack, prospective Mark III buyer/flyer. ________________________________________________________________________________
Date: Jun 07, 1996
Subject: rls862(at)aol.com Kolb MarkIII
Hello, My name is Randy and I am interested in building a Mark III and would like to visit a local builder. I am located in the Chicago area. I would appreciate any help. Also does anyone have plans for a dual stick version. Thanks, Randy ________________________________________________________________________________
Date: Jun 08, 1996
Subject: Starting construction
Since there is not much mail going back and forth I guess Ill add a little progress report on my FS II. I finally got most of Kit #1 (I had a little bit of trouble with the shipping), but Barbara, Dennis and Mike have been wonderful, and very patient I should say, at helping me solve this problem. I am currently building an 8 x 4 table which I plan to level and anchor to my garage floor so that the parts are hopefully built straight. Let me tell you, if you add all the hours you spend tinkering with things that are needed to build an airplane and add it to the time actually spent building, WOW. In any case, it is an enjoyable experience. I hope to have the table ready today and start construction of the ribs tomorrow. A question: I noticed that my ribs stampings (the ones that slide over the main spar) are bowed (if a side of the stamping is held flush over a flat surface, the opposite end bows up from the flat surface about 3/4). Dennis told me that this is still OK but I would like to get some feedback from you guys as to how to deal with this when time comes to rivet them to the rib. Will this cause bowing of the rib?; Should I try to get them somewhat straight before building the rib?. I did notice that once they slide on the spar tube they do get better but what about during rib construction?. Also, Cmon, write some more out there. I check the mail list every day hoping to read something and its been pretty quiet lately. I also noticed that John Brooks of NC added a picture of his FS in the June issue of the EAA Sport Aviation magazine. Way to go John. Christian ________________________________________________________________________________
Date: Jun 08, 1996
Subject: Building question & Mail for Christian :-)
Hello again, Since I don't have a manual yet, I've got another one of those nagging questions to ask. I've been told that it's "better" to align the wings to the fuselage cage prior to covering the wings. Is this a requirement, or does it just make it easier/safer to do the alignment. Has anyone covered the wings prior to receiving the fuselage kit? I'm trying to resolve the amount of time I can stay busy with kits 1 & 2 prior to needing kit 3. Note that I'm assuming the Slingshot construction will be similar to the FireStar. Thanks, Rusty (Slingshot sn- SS-003) http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jun 08, 1996
Subject: Slingshot Update
Greetings, Well, I got a letter from Dennis today. The current outlook for availability of the first 2 kits is about mid July. It's about a month longer than I expected but not unreasonable. I'm naturally a little disappointed, but not upset about it. From what he said, it sounds like they're pleased with the flight testing of the proto-type. I sure wish I could afford more power than a 503. Perhaps I'll use the extra month to continue investigating (unauthorized) alternatives. Rusty http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jun 08, 1996
Subject: Benjamin?
Hello Benjamin, I wrote a letter to you earlier about the pictures of the dual throttle configuration. I hate to bother you again about it but I would like to know if you are still planning to send the pictures. If anyone knows of the company that designs the dual throttle configuration for the Mark III. I saw an add for it in UL flying magazine but I cannot seem to find it know. It was specific for the Mark III. Also, anyone that has a Mark III with the normal configuration, is the configuration hard or unconfortable to use? Thanks again, Brandon Kearbey | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "MarkIII" (sort of). /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe.butte.k12.ca.us . \_______/ |---------/-----| (_____________//--------------\^ / o ( ) ________________________________________________________________________________
Date: Jun 10, 1996
Subject: Re: bowed flanges & wing alignment
ABOUT BOWED RIB-TO-SPAR FLANGES: Christian, I don't remember much of any bowing to my flanges. I would think that when you make each rib, that pressing and riveting the flange to the rib tubes -- which are on a flat jig -- will result in taking out the bow. Your ribs may spring slightly when you pull them from the jig, but you will know that they were drilled and riveted flat. Later, when you slide them onto the spar, you will nudge each rib so that it is aligned fore and aft, and is 90 degrees to the spar as checked with a T-square. See my photo: http://mae.engr.ucdavis.edu/~ransom/build/7wingfr.html for a couple more tips on fastening ribs to spar. WING ALIGNMENT: Rusty, I meant to get back to you again in our little exchange about covering the wings before alignment to the cage. You mentioned someone else's concern about needing to drill and bolt the rear wing attachment to the drag strut column, which needs to be done before covering. I drilled and bolted mine precisely per plans, without checking to verify that my wings would come into alignment. (The FS KXP plans made no mention about allowing for wing alignment with this hole placement; rather, the plans simply dimension how far out the rear attach fitting is to be from the root rib surface. ) So, if you carefully put the fitting in the right place, you could cover the wing before alignment. In fact, during wing alignment, you have enough variables (incidence to each other, incidence to the fuselage, sweep-back (0), dihedral, consideration of averaging out any slight (1/4") droops or rises in leading and trailing edges of both wings), that also contending with free moving rear attach fittings seems like another complication. (See on alignment.) As a precaution, it would be smart to verify that each root rib is not warped, as everything coming into alignment depends on a flat root rib. (The chances of a warped root rib are nearly nill.) Lastly, in my typically verbose beating of any subject, I would add that covering the wing before alignment will primarily just make the wing a little harder to move around since all of the handles (spars, etc) are covered up. Moral of the story: if the rear fitting is sticking out the right amount, covering before alignment will be fine. Happy building and flying everybody. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jun 11, 1996
Subject: New Owner
Hello All, Ordered the FireStar II (w/o 2nd seat) a couple days ago. Went for the finished ribs, breaks, large wheels & tires, heavy duty landing gear and, powder coating of the cage & small parts. Countng the days, almost a week already. Anyone know what kind of (basic) instrument panel comes with the kit if any? Curtis ________________________________________________________________________________
Date: Jun 12, 1996
Subject: Re: New Owner
Way to go Curtis! It's my understanding that no instruments are included normally. They offer a basic package for $450 and a more complete package for $750. The info you got (I assume) from Kolb should have all that in it. I can send you a copy of the instrument info if you get in a bind. Counting the weeks :-( Rusty http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jun 12, 1996
Subject: Instrument Panel
Yes, I know about the 'Custom Instrumetn Panel' package. What I meant in that last post was; is their some sort of basic panel provided in the kit, one that you would have to cut the holes in and install your own instruments? It you take the Custom Panel package and subtract the std. instrument package at $450, you wind up paying $300 for the panel alone. Curtis ________________________________________________________________________________
Date: Jun 12, 1996
Subject: Re: Instrument Panel
Curtis, Though I'm not an expert on the subject, I believe that you cut your instrument holes in the rear surface of the fiberglass nose cone (pod ??). Mike Holland sent a couple of good building pictures that show the mounting of his instruments. They're on my web page as #42 and #43. Enjoy, Rusty http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jun 12, 1996
Bob wrote; >Curtis, A little unclear of what your asking,but we just installed our > instrument panel tonight. We purchased our gauges from skysports and >installed them in a left over piece of aluminum. We cut the aluminum to the >same shape as the fiberglass panel. Then we cut out the fiberglass to >install the panel with all the gauges. Ok, in the FireStar info package, in the options section, they list a "Instrument Panel, instruments and wiring harness assembly" for $750, above that is listed a "Standard package: ASI, Altimeter, Tach/EGT, Hour Meter" for $450. So, does the FS come standard with some sort of panel in which to put your own instruments, or does one have to pay $750 for a panel with instruments, or $300 for a panel with out instruments (750 - 450). >We cut the aluminum to the same shape as the fiberglass panel. Then we cut out >the fiberglass to install the panel with all the gauges. Did this 'Fiberglass Panel' come stand with Kit#2, or did you have to pay extra? >We got this tip from another kolb >owner. The reason for this is the gauges are hard to get to the back of. This >way you take out how ever many screws you mounted the panel with and along >come all the gauges. Hope this might help. Bob Good tip! If it does cost $300 for an empty panel, I think I could fashion one out plexiglass stock and use this tip. Curtis ________________________________________________________________________________
Date: Jun 12, 1996
Rusty wrote; >Though I'm not an expert on the subject, I believe that you cut your >instrument holes in the rear surface of the fiberglass nose cone (pod >??). Mike Holland sent a couple of good building pictures that show the >mounting of his instruments. They're on my web page as #42 and #43. Yes, this is the panel I was referring to. Does on have to pay extra for this panel, or does it come with Kit#2? Mike, could you set me straight on this? Curtis ________________________________________________________________________________
Date: Jun 13, 1996
Subject: Re: Instruments, compass
When I bought my firestar kxp kit 4 years ago, the standard kit came w/ no instruments. I bought a dual CHT, an EGT/Tach, and an ASI all for just under $300 from LEAF. Cutting the holes in the fiberglass nose pod was easy, and access to the rear of the instruments is not all too bad. I figure I'll cut off the panel face and replace with a removable one if I ever decide to reconfigure my instrument placement. I guess Kolb may be offering instrument packages as options, and I'm sure Barbara at Kolb could easily provide accurate information as to waht you get. QUESTION: Any suggestions for a compass? My first compass was an auto store cheapy. I mounted it to the panel, but that turned out to be too close to the steel frame, so the compass was worthless in that position. I'm thinking that other compasses may be of good enf quality that they can be mounted on the panel without totally messing the deviation up beyond reliable adjustment. (I now use a handheld backpacking compass, and standard IFR (I Follow Roads).) Someday I look forward to climbing to 10,000 feet and ceremoniously throwing my old junk compass overboard. Or, maybe dropping it on a strafing run at an oncoming freight train. :) --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jun 13, 1996
From: "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM>
Subject: Radiator for the 582 on MK3, and winter cabin heat.
Where are you guys mounting your radiators? Is anyone trying a small automotive (honda or ?) type, mounting it behind the cabin below the wing? I think I read somewhere that this was an option. I am not only trying to avoid the six hundred dollar bill for the rotax twin radiator, but I am thinking that with the radiator below the wing and behind the cabin it may be posible to duct in some heat. Or maybe I would tap into the system to feed a second small radiator mounted in the nose. Any thoughts, experiences? I know I want it light and simple, but it seems like winter is the longer part of the year around here (Minnesota). I have also seen ads for the muffler-duct heat system (like volks bugs had). Anyone using such a thing? Progress update: After 200 hours all the flight surfaces are complete minus fabric covering. I have used the "bent tube at trailing edge" of all control surfaces using the 5/16" tubing, as shown on page 42 of my Builder's Manual. This definitely added to the total time. I am now waiting for the fuselage cage kit. ________________________________________________________________________________
Date: Jun 13, 1996
Subject: Panel-Answered
Hello All, Mike Holland & James Baker answered my question about the inst. panel. It is part of the nose cone on the FireStar models. Note: (for any new readers) instruments not included, But buy the looks of Mike Holland's build photo's (#42 & 43) their's plenty of space for a decent set of instruments. For those who haven't seen Mike's Holland's or Ben Ransom's build photo's, check out Russell Duffy's home page; http://www.pcola.gulf.net/~rad/ and feast your eyes on some great looking FireStars. Curtis (day 6) ________________________________________________________________________________
Date: Jun 14, 1996
Subject: Re: Radiator for the 582 on MK3, and winter cabin heat.
Jim and all... Down here in Texas I am not interested in more heat... That's a joke guys. I bought the Rotax twin radiator pack because I know very little about engines and cooling plumbing and wanted a tried, safe, effective system. I did find out that the brackets for the Rotax radiator and oil tank fit under the head stud nuts and coolant water will come up those shafts and leak out around the head studs if the mating metal surfaces are not just so so with each other. That is what happened in my case. Most people I talked to about this said not to worry that it would seal itself shortly after the first run in becuase of the sealing properties of the antifreeze. I didn't want it to leak at all and asked the Rotax person at LEAF at Sun'nFun this spring what would be the solution. He said to first drain down the radiator to below the head level, then apply some high temp RTV around the base of the stud (after making sure the area is completely dry of water by cleaning with Acetone) then put the bracket in place (maybe a very little more RTV on top of the bracket in the center around the stud) then torquing down according to Rotax before the RTV sets up. I have not done this yet, but am about to in the next few days. I also had to lengthen the U hose connecting the lower ports of the two radiators using 90 degree elbows (2) and short stubs (2) of radiator hose. I have seen other installations where that did not seem to be a problem. I thought in my case that the hose was in a slight bind. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Jun 16, 1996
Subject: Edge distance and cutting aluminum
Dear friends, I have been scrtching my head about two things: 1) I made my first rib and have noticed that the edge distance between the rivets and the edge of the gussets has to be low (I'm using about 3/16 in. but that forces me to slant the drill bit some to properly catch the 5/16 tubing). What edge distance are you guys using on the rib gussets?. 2) I'm cutting the gussets using large straight metal snips but when the small 1.5 x 1 in gusstes are cut, the curling of the metal is quite noticeable. Any ideas on cutting aluminum (short of a band saw because I don't have one)?. Anyone close to the Miami, Fl area with a bench shear that I could use to cut the gussets?. Thanks, Chris ________________________________________________________________________________
Date: Jun 16, 1996
Subject: TRAILER WANTED
WANTED: ENCLOSED TRAILER SUITABLE FOR TRANSPORTING AND STORING A KOLB FIRESTAR (SINGLE PLACE ULTRALIGHT). NEEDED IMMEDIATELY. PLEASE REPLY TO PHIL AT: kw012393(at)one.net Note that the "0" in the email address is a zero and NOT the letter "o". Please state condition/age/price/additional info about trailer. Thank you! ________________________________________________________________________________
Date: Jun 16, 1996
Subject: Factory powder coating
Greetings, I'm trying to decide whether I want to order the factory powder coating on my upcoming Slingshot fuselage cage. Has anyone actually received one of the factory jobs? I'm concerned that somewhere in the shipping and construction process, it will get scratched up enough that I'll have to do some touch-up work on it anyway. Does this seem like a reasonable concern? Rusty http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jun 16, 1996
Subject: Powder Coating
Rusty wrote; >I'm trying to decide whether I want to order the factory powder coating >on my upcoming Slingshot fuselage cage. Has anyone actually received >one of the factory jobs? I'm concerned that somewhere in the shipping >and construction process, it will get scratched up enough that I'll have >to do some touch-up work on it anyway. Does this seem like a reasonable >concern? "Reasonable concern?" Yes, I'm glad you brought this up. Haven't ordered kit#3 yet, but will be getting it coated when I do. I'll call Barbra this week and ask about it. Can the coating material be touched up easily? Curtis ________________________________________________________________________________
Date: Jun 17, 1996
Subject: Re: Factory powder coating
> I'm trying to decide whether I want to order the factory powder coating > on my upcoming Slingshot fuselage cage. Has anyone actually received > one of the factory jobs? I'm concerned that somewhere in the shipping > and construction process, it will get scratched up enough that I'll have > to do some touch-up work on it anyway. Does this seem like a reasonable > concern? Other than scratching, you might also consider whether you want to weld on any other little fittings. This is usually too hard to predict, and I think it might be easy to add something that you later regret. But, if you have something pretty solid in mind as to what you want, waiting on powder coating till after welding on your own fittings would be better. Rusty, you had talked about putting the throttle somewhere else. You could do this and grind off the standard left side fitting. As an aside to the powder coating issue, I would advise against mounting the throttle on the stick. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jun 17, 1996
Subject: Re: Edge distance and cutting aluminum
On Sun, 16 Jun 1996 CMEng1(at)aol.com wrote: > I have been scrtching my head about two things: > > 1) I made my first rib and have noticed that the edge distance between the > rivets and the edge of the gussets has to be low (I'm using about 3/16 in. > but that forces me to slant the drill bit some to properly catch the 5/16 > tubing). What edge distance are you guys using on the rib gussets?. Sorry, i don't recall exact distance. But I can see from a photo, that with the rivet in, the top of the rivet head is about 1/32" from the edge of the gusset. I didn't put any angle on my holes to get this. > 2) I'm cutting the gussets using large straight metal snips but when the > small 1.5 x 1 in gusstes are cut, the curling of the metal is quite > noticeable. Any ideas on cutting aluminum (short of a band saw because I > don't have one)?. Anyone close to the Miami, Fl area with a bench shear that > I could use to cut the gussets?. I used a radial arm saw with a standard fine tooth blade to cut all my gussets and this worked well. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jun 17, 1996
On Sun, 16 Jun 1996, Russell Duffy wrote: > Greetings, > > I'm trying to decide whether I want to order the factory powder coating > on my upcoming Slingshot fuselage cage. Has anyone actually received > one of the factory jobs? I'm concerned that somewhere in the shipping > and construction process, it will get scratched up enough that I'll have > to do some touch-up work on it anyway. Does this seem like a reasonable > concern? Powder coating is pretty tough and any touch-ups should be rather easy. However, if there is a local powder coating facility, I would most likely want to have it done there. My cost to do it that way was about $100 less than Kolb charges. Also, you have to choose your color before shipping. I don't know what colors Kolb offers, since they did not have this service when I purchased my kit. But the local powder coating facility has thousands of colors available and from what I saw, had perfect matches for all the colors available from Stits. _-_ _,, ,, -/ ) ; || ||_< \\/\/\ _-_ ||/|, _-_ ,._-_ bweber(at)micom.com || \\ || | | || \\ || || || \\ || ;/--|| || | | ||/ || |' ||/ || Keep the shiny _--_-' \\/\\/ \\,/ \\/ \\,/ \\, side up ( ________________________________________________________________________________
Date: Jun 15, 1996
Subject: Test Flight, Firestar: Wow!
Ben let myself and our father test fly his Firestar this weekend. What a plane! With the 447, my climb rate at 50 mph was probably better than my Ultrastar's maximum, and nearly at my Ultrastar's top speed to boot. The most noticable difference, however, was the comfort level. (Maybe a windscreen isn't that bad an idea after all!) In my Ultrastar, anything over 45 seems really windy and I'm generally content to buzz around at that speed (vmax with my slightly anemic engine is about 58 mph). The noise level was a 100% improvement over my Ultrastar. I think that's probably mostly the result of a quieter muffler on the Rotax, but also due to the engine position up and behind the wing. Ben mentioned something about the enclosure behind the head helping with propeller noise too. In my Ultrastar, I'd say that 75% of the noise comes from the engine; in the FS, I'd say that there's less than half the noise overall, and that it's about 75% from the prop. By comparison, it seems like you're only using half the RPM, and the propellor sound is emmensely more satisfying than a screaming engine. Visibility in my Ultrastar is still better though, especially to the rear. Being concerned and cautious about the high thrust line, I found myself climbing out at an angle resulting in about 45-50 mph. I guess it just didn't seem right that anyone should be allowed to climb out any steeper than that! I found the high thrust line to be no problem whatsoever, and that's coming from a plane (the Ultrastar) with a middle to low thrust line. The only place that it was particularly noticable was in idle-power descent, where I had to keep adjusting the stick forward from the position my instincts were telling me. Slips were about 3 times more effective--which probably means that I'm probably just flying sideways in the Ultrastar. My father, Roger, flew the plane beautifully, except for one big plop from about 4 feet up on his second landing or so, which did a good job of proving the landing gear to me (Roger's over 200 pounds). (I think Ben got the heavy duty gear--correct me if I'm wrong--and big soft tires). That landing might have been about as hard as the time I broke my Ultrastar's gear. I guess my dad had the classic problem that transitioning GA pilots have: flaring too high and then losing all your speed before getting down close to the ground. Ben had Roger take a refresher lesson in a Quicksilver on the way up here. Roger had completed ultralight lessons a couple of years ago and has been renting spam cans since. Another problem he had was getting down. Quicksilvers have only about a 6:1 glide ratio (yuk!), and he wasn't used to the much cleaner Kolb (hooray!) Roger's landings when we went back in the afternoon were consistently near-perfect. He said the taildragger configuation wasn't a problem at all, even though the last taildragger he flew much was in the early 50's (his PT-19). Mike Ransom | Davis, Calif., USA | ---================================================--- /O\ -====o====- /-----\ mlransom(at)ucdavis.edu || || Kolb UltraStar ________________________________________________________________________________
Date: Jun 17, 1996
Ben Ransom wrote: > Other than scratching, you might also consider whether you want to weld > on any other little fittings. This is usually too hard to predict, and > I think it might be easy to add something that you later regret. But, if > you have something pretty solid in mind as to what you want, waiting on > powder coating till after welding on your own fittings would be better. > > Rusty, you had talked about putting the throttle somewhere else. You > could do this and grind off the standard left side fitting. As an aside > to the powder coating issue, I would advise against mounting the throttle > on the stick. Ben, Yes the throttle issue is the other problem for me. I'm currently planning to ask Kolb to include the throttle fittings that they would normally weld in place. Maybe I can weld them in a better (for me) location. I still have thoughts about putting the throttle on the stick in one way or another, but I'd prefer a fixed right hand location. One thing's for sure, I can't really decide where I want it until I plant my behind in the seat during construction. I may skip the powder coating and just prime and paint the thing. Sure it'll be REALLY unpleasant, but it's cheaper and I know it'll match the rest of the plane. More to think about. Rusty (8 weeks down, 4 to go) http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jun 17, 1996
Subject: happy father's day
I had posted this to Rusty after some other net-chat, and thought the rest of you Kolb-ites might enjoy ... I hadn't intended it as a father's day thing, but my parents were coming to town this weekend and I got my dad up in my plane. Oh what a feeling! My dad has maybe about 1200 hrs, most of it 40 years ago in B-25s. He's now current in the low-end Cessnas and flies maybe 2 hours a month. He also took about 4 hours in USUA training 2 years ago. So anyway, I figure he's maybe a little rusty in type. I made him stop by on the way up from So. Cal and get a couple times around the pattern with my old BFI. Hearing about how that went, I'm glad I did require the familiarization. He related that the instructor said after the 4th landing ..."well, you had that one pretty much the whole way in." (gulp) Getting into my Firestar, my dad did a little bit of taxiing, one higher speed taxi down the runway, then said he'd go for it. I had given him all the particulars and suggested his first pass be an approach and 5-10' agl pass. He couldn't get the darn thing down and passed over at 100'. He told me later he couldn't see the altimeter either, and that's why he climbed to what looked like a 1200'agl pattern. He was also "used to" the Quicksilver w/ 2 aboard, which sinks badly compared to our fine Kolbs. So, he came back around with a real 5 ft pass, although bobbling a little w/ over-control. Then he came around again and flared out with 20' of altitude left in spite of my major emphasis on this -- i didn't crowd his brain w/ a lot of fluff, honest. I bit my lip and the plane hung on till about 5-6' and dropped in. The landing gear sucked up the drop and he went around and did it again. ...ouch, but successful in the traditional sense (he walked away). We went home for some mid-day family obligations and returned later to see if maybe he had thought thru the correct method enf to pull it off a little nicer. Much to my relief, he had. He went around 4 or 5 times and made perfect landings each time. Yahoo! In all, with everything my dad has helped me with and inspired in me, it was one of the most gratifying moments I've ever experienced. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jun 17, 1996
Subject: Rivet edge distance
Thanks for the replies in reference to the rivet edge distance. Being an A&P mechanic and structural engineer with too much work in FAA blessed machines it is a little hard for me to get used to using less than 2*Diameter for edge distance but it is true that this ribs look definitely overkill. Still, 1/8" edge distance sounds like too little so I'll try a compromise between 3/16 and 1/8. Any comments?. In reference to the powder coating, this is my experience: I am helping a friend build a Kitfox Series V and he got all his fuselage and parts powder coated. The finish is nice and it definitely saves a lot of work even if you have to retouch some small areas. The only problem is that powder coating tends to be thick (very) and though and if you have parts that slide into others (such as control horns) and they are powder coated it is going to be a lot of work remove the coating. My recommendation is to get powder coating in the large components (fuselage cage, tail boom, etc.) but not on the small parts, unless Kolb masks the areas were this parts slide into others. The small parts I would just epoxy prime. Christian. ________________________________________________________________________________
Date: Jun 18, 1996
Subject: First Shipment
Received my FireStar's builders manual and drawings today. After reading page 1 "Introductory Remarks", and reviewing the drawings and instructions for the Horizontal Stabilizer, I realized that large phone bills would be a part of life for the next 10 months or so. When the Introductory Remarks state; "... The plans are not perfect, but they do provide sufficient information for the average builder to complete his airplane.", I knew I'd be in for a long build time. I thought it would be more of a step-by-step process. So much for wishful thinking. The intructions for building the horizontal stabilizer only take up 1/3 of a page. One paragraph, which is only one sentence long states "Don't forget to install the internal sleeve in each horizontal stabilizer." Does this mean their are more instructions forth comming? You can't forget something you didn't know before hand! Curtis ________________________________________________________________________________
Date: Jun 18, 1996
Subject: FIRESTAR DATA
I have purchased a Kolb Firestar from a friend who built it in 1988. It's in great shape and flies wonderfully. Engine is Rotax 377. I weigh 190 lbs. (and at 6'3" it's a cozy cockpit). Can you advise me on the following data: 1) speed for best rate of climb 2) speed for best angle of climb 3) speed for best angle of glide (furthest distance covered in glide) 4) heighth, width, length of the Firestar with wings folded (data needed for possible trailer purchase) 5) what is recommended liftoff speed 6) what is recommended climbout speed 7) what is recommended speed on final approach near threshold These may sound like dumb questions, but, hey, I gotta start somewhere! And who better to ask than a Kolb fan! Thanks for any help you can render. --Phil in Cincinnati at kw012393(at)one.net note: (that first "0" is a zero) ________________________________________________________________________________
Date: Jun 18, 1996
Subject: First Shipment (Curtis)
Curtis, there are some places in the plans where things could be better explained. And there are contradictory directions in the plans and the drawings. And there are outdated things sprinkled in for your convenience. BUT, you will learn to interpret them and call when necessary, and append here as often as you wish (but Dennis at Kolb is the real authority). And if you take the time to read the entire Manual at least twice (without the wife talking to you, or the kids playing on your lap), you will find most of the answers to your questions. The drawings are really quite good, and deserve an hour's study each. Look at them long and hard until you can't find a single detail that you don't clearly understand, BEFORE starting to build. I find it is especially important to read ahead and understand it all because the plane's structure is simple but very dependent on a few basics. The first part you build may not come out as well as you would like (my stabilizers could be better), but you will improve your techniques with each one and your second Kolb will be perfect ;*). The folks at Kolb are always very helpful to me when I call them for help! I reached Dennis one day on a Saturday at 6 pm his time, and he cheerfully answered my questions. Have fun and take your time, your enthusiasm has to last 500 hours. ________________________________________________________________________________
Date: Jun 18, 1996
Subject: Re: First Shipment (Curtis)
Just out of curiosity, are we talking about a manual that comes with the Kolb kit, or a manual which would be used to build a Kolb from plans? I'm not sure if Kolb even offers plans, so maybe this is a stupid question. :) The reason I ask is because I had assumed that the instructions that come with the kit would be fairly straightforward... Open and shut... "Do this, then this, and this" and you have a Kolb, not "Do something like this, and then that, and something similar to this" and you have something which resembles a Kolb... I plan to buy and build a FireFly. I have absolutely no experience with aircraft construction, but I was assured by various folks that it is fairly easy. Seeing this conversation hasn't exactly been a confidence booster, if you know what I mean... :) -Jon- .------------------------------------------------------------------------------. | Jon Steiger: DoD# 1038, EAA #518210, USUA# A46209, NMA# 117376, KotWitDoDFAQ | | stei0302@cs.fredonia.edu && http://www.cs.fredonia.edu/~stei0302/ | | '96 Dakota SLT V-8 Club Cab, '91 FZR600R /* Just another mangy hacker */ | `------------------------------------------------------------------------------' ________________________________________________________________________________
Date: Jun 19, 1996
Subject: Re[2]: First Shipment (Curtis)
What I seen is you need to spend a little time studying the plans. If you building the FireFLy there is a discrepency betwwen two drawing on the wall thichness for 7/8" dia. tubing on the Horizontal Stab. When they made the FireFly drawing they copied the FireStar drawing and missed changing a note on one drawing. Over all the plans for the FireFly are pretty good. The only thing I wish I have was a little better detail of the steel parts. I talked to Dennis about this and I was told they were working on making detail drawing of the parts for identification purposes. That would help a bunch. Even if you drill a hole in the wrong place most things can be repaired using the correct method. There's a lot of help around you that you may not realize. Get connected with you local EAA chapter. Take avantage of it. Well its 3 am in the morning and my typing is getting very poor. Time to wrap it up and head for home. ______________________________ Reply Separator _________________________________ Subject: Kolb-List: Re: First Shipment (Curtis) Date: 6/18/96 9:52 PM Just out of curiosity, are we talking about a manual that comes with the Kolb kit, or a manual which would be used to build a Kolb from plans? I'm not sure if Kolb even offers plans, so maybe this is a stupid question. :) The reason I ask is because I had assumed that the instructions that come with the kit would be fairly straightforward... Open and shut... "Do this, then this, and this" and you have a Kolb, not "Do something like this, and then that, and something similar to this" and you have something which resembles a Kolb... I plan to buy and build a FireFly. I have absolutely no experience with aircraft construction, but I was assured by various folks that it is fairly easy. Seeing this conversation hasn't exactly been a confidence booster, if you know what I mean... :) -Jon- .------------------------------------------------------------------------------. | Jon Steiger: DoD# 1038, EAA #518210, USUA# A46209, NMA# 117376, KotWitDoDFAQ | | stei0302@cs.fredonia.edu && http://www.cs.fredonia.edu/~stei0302/ | | '96 Dakota SLT V-8 Club Cab, '91 FZR600R /* Just another mangy hacker */ | `------------------------------------------------------------------------------' ________________________________________________________________________________
Date: Jun 19, 1996
Subject: New
Hi out there I am new in this ultralight business as well on this postlist. I am planing to spend the winter build me one of thoese ultra kit plane (yes, winter is on its way). To start with I need some addresses. Can any body give me address (post o= r email) address for some of the companies which make those kit panes. I have two questions: Is it a god idea to buy a used one? And by the way, I know some are better then others, which are better than others? Is anybody on the list who lives in Spain?? (I'm going to Spain next mon= th and it would be nice to have a look.) You may email to me direct (arnia(at)iav.is) or to the postlist..............:-))))))) Thank you all / \ =96=96 =C1rni =C1rnason / =96=96\/=96/ =96\ /\ =CDslenskir A=F0alverktalar / =96=96 \/=96 \ / =96\ /=96=96\ 235 Keflav=EDkurflugv=F6llur / 0 \=96=96 @ =96\/=96=96=96 \ S=EDmi: 421-4200 / Date: Jun 19, 1996
On Tue, 18 Jun 1996, Curtis West wrote: > Received my FireStar's builders manual and drawings today. After > reading page 1 "Introductory Remarks", and reviewing the drawings and > instructions for the Horizontal Stabilizer, I realized that large phone > bills would be a part of life for the next 10 months or so. When the > Introductory Remarks state; "... The plans are not perfect, but they do > provide sufficient information for the average builder to complete his > airplane.", I knew I'd be in for a long build time. > > I thought it would be more of a step-by-step process. So much for > wishful thinking. The intructions for building the horizontal > stabilizer only take up 1/3 of a page. One paragraph, which is only one > sentence long states "Don't forget to install the internal sleeve in > each horizontal stabilizer." Does this mean their are more instructions > forth comming? You can't forget something you didn't know before hand! Having a little bit of the "uh-oh" when you really feast your eyes on the plans book and drawings is probably normal. After all, you've generally been picturing the finished plane, not the plans. I thought the plans were clear enough. I had one initial question after my first look thru them and called Kolb to make sure there were no revisions that I should have and might not know to ask for. I was assured that all was correct, and it was. The Plans book is not a rigidly prescriptive step by step read. It is more of a guide to the drawings (blueprints), and I thought the combination of plans book and drawings was very clear. At something like 80 pages, the plans book isn't exactly a meager bunch of vague fluff. All of the material types, dimensions, holes, bolts, nuts, etc are clearly identified on the drawings. You just have to take the materials and make them into what is shown on the drawings, one part at a time. It ain't that hard! I don't think you really want to see instructions that say "insert bolt 453 thru hole 2001, etc..." That would produce many more errors than accurate drawings and a requirment for the builder to use and/or learn some basic skills in reading the blueprints. And like others have said, Dennis is easy to get ahold of and always considerate for any question you might have. All that, combined with this list server, and you have a lot of resources. I'll finish by saying that if you think your first or second stabilizer really stinks and you haven't yet gotten a nicely riveted joint, pack it up and sell it. Nobody should make a crappy airplane. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jun 19, 1996
Subject: Re: FIRESTAR DATA
On Tue, 18 Jun 1996 kw012393(at)one.net wrote: > Can you advise me on the following data: Note: I'm responding for a standard Firestar KXP. -Ben > > 1) speed for best rate of climb high 40s > 2) speed for best angle of climb low 40s > 3) speed for best angle of glide (furthest distance covered in glide) high 40s > 4) heighth, width, length of the Firestar with wings folded (data needed for > possible trailer purchase) approx 5.5 ft to top of engine, 5.5 ft wide at prop (wheel track is about 5'), length is 21.5 w/ wings folded, I think. (Length is shorter w/ wings up.) > > 5) what is recommended liftoff speed I'd recommend 30 ...or forget it, as it will fly itself off. > 6) what is recommended climbout speed I'd recommend 40 - 45. Listen to that engine awfully carefully below 40 on climb out. > 7) what is recommended speed on final approach near threshold 45 on approach, 40 threshold, hold off till it touches down just under 30. > Some of us on this list debated about "best" approach speeds once before. These are my recommended numbers. Also, I've not done enf accurate testing on best climb rates,angles, etc to be very sure of these, but it's a start. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jun 22, 1996
Subject: tailwheel, elevators
Does anyone have a measurement either in degrees or inches of up elevator. We set ours up per builders manual but was just wondering about how much up elevator there should be. Also is there any reason you should not drill and bolt the tail wheel assembly to the lower vertical stabilizer. The manual says to epoxy it in place. Just seems it would be better to drill and bolt it. By the way after a year and a half of on and off working on our firestar 2 its finally ready to start taxiing. Thanks for any info. Bob. ________________________________________________________________________________
Date: Jun 23, 1996
Subject: KOLB Manual and Drawings
Fellow KOLBers, just when you thought we Aussies had gone to sleep for our winter, here we are, after months of lurking! Curtis and Jim's comments on the Kolb manuals and drawings deserve a little extra comment. Jim is spot on - it works! Folks, when it costs $2 per minute, we don't call ANYBODY without good reason! A quick fax or email to Dennis does make one feel more confident, but it adds to the time deniis has to spend away from his real work - designing more great planes. With both wings complete, and all the tail feathers done, I am proud to say we haven't ever had to call Dennis at Kolb. Sure, we made a couple of bits twice, and there a few "gotchas' in the plans, but it can be done, and done convincingly without worrying the factory. Just read the delightfully brief passage in the book usually along the lines of "just get on and do it!", and you will find that it is all amazingly logical and straightforward. Particularly worrying is the "just put the H section in the wing tube and rivet it" - but it really does go like that, and it works. Certainly Curtis, you WONT have to spend ages before you see your bird start to appear before your very eyes. Some of the other manufacturers' manuals look better, have glossy pictures and so on, but they actually tell you too much info some times. Enjoy - the building is something to be anticipated - not dreaded! Now, if we just get time to complete the covering... best wishes Pete Gorton FSII bisi pty ltd 17 Dunstan Parade, Port Melbourne 3207 AUSTRALIA 61-3-9645 2116, fx 61-3-9645 2143, mobile # 0419 601 579 ________________________________________________________________________________
Date: Jun 23, 1996
Subject: three questions about folding wings
I have purchased a used Firestar. The airfield we were using has been sold so I must move to a different place. The only hangar space requires my folding the wings. Questions: 1) Does anyone have a nifty idea for being able to move the Kolb with the wings folded back? Since the boom tube is inaccesable with the wings in this position, it is difficult to maneuver the plane to get it into a tight space. Anyone have plans for some sort of hand dolly, or whatever? 2) Also, (and I just tried this for the first time two days ago), what's the trick to fastening the folded wings into the brackets at the bottom of the vertical stabilizer? Even Wilt Chamberlain couldn't reach those brackets. Is it necessary to stand the plane on its nose and do it from the bottom? 3) Can a Kolb be folded/unfolded with only ONE person doing the work? Anyone with the detailed knowledge of how to do this, please let me know. I'll be very appreciative. The literature says from trailer to fully ready to fly in 8 minutes with no tools. Granted, I'm a novice and very inexperienced at this, but that length of time seems a wee bit optimistic. Help! Thanks, guys and gals, for any assistance you can render. -Phil ________________________________________________________________________________
Date: Jun 23, 1996
Subject: Kolb MK 2 for sale...
Entered on behalf of the owner: Kolb Mk 2, freshly rebuilt Rotax 503 DC (crank, pistons, rings), basic instrument set, intercom, 8 in wheels, full swivel tail wheel, dual brakes, dual throttle, 10 gal fuel tank. Asking $14500.00. Fred Kimmel 405-288-6107 Oklahoma City. Cheers. ________________________________________________________________________________
Date: Jun 23, 1996
Subject: Manual & Drawings
Pete wrote; >Certainly Curtis, you WONT have to spend ages before you see your bird >start to appear before your very eyes. Ages not, but a year at least yes! Being a first time builder, I plan on taken my time to do a better the average build. >Some of the other manufacturers' manuals look better, have glossy pictures >and so on, but they actually tell you too much info some times. At first look, I was suprised to see how terse the manual was, but after hours of reading it, and following along with the drawings, things are looking better. It was not what I expected through. > >Enjoy - the building is something to be anticipated - not dreaded! Dreaded NOT! I very much look forward to building this plane, and know that I will enjoy it. Later Curits ________________________________________________________________________________
Date: Jun 23, 1996
From: Cliff & Carolyn Stripling <striplic(at)flash.net>
Subject: Re: three questions about folding wings
>I have purchased a used Firestar. The airfield we were using has been sold >so I must move to a different place. The only hangar space requires my >folding the wings. > >Questions: > >1) Does anyone have a nifty idea for being able to move the Kolb with the >wings folded back? Since the boom tube is inaccesable with the wings in >this position, it is difficult to maneuver the plane to get it into a tight >space. Anyone have plans for some sort of hand dolly, or whatever? I have seen a nice tail wheel dolly at Sun'n Fun. It was very simple and cradled the tail wheel and pivoted left and right. I made hand holds in the ends of the wing tips of each wing and use those holes to lift and move my tail by the wings when folded. >2) Also, (and I just tried this for the first time two days ago), what's the >trick to fastening the folded wings into the brackets at the bottom of the >vertical stabilizer? Even Wilt Chamberlain couldn't reach those brackets. >Is it necessary to stand the plane on its nose and do it from the bottom? Braze pieces of welding rods to the clips so that you can insert them from a distance. >3) Can a Kolb be folded/unfolded with only ONE person doing the work? >Anyone with the detailed knowledge of how to do this, please let me know. >I'll be very appreciative. I can do it with difficulty by resting the wing on my shoulder while positioning the lift strut, but I do not feel very secure (especially if it is breezy). I have heard of some guys fashioning a tripod or bipod to help hold the wing up and in position while fitting the lift strut. >The literature says from trailer to fully ready to fly in 8 minutes with no >tools. Granted, I'm a novice and very inexperienced at this, but that >length of time seems a wee bit optimistic. Haste makes waste sometimes. When I find myself rushing, I tend to make mistakes... like the day I forgot to disconnect the ailerons and flaps before trying to fold the wings. It could have been a BIG crunch if I had not caught myself at the last minute. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Jun 24, 1996
>I plan to buy and build a FireFly. I have absolutely no experience >with aircraft construction, but I was assured by various folks that >it is fairly easy. Seeing this conversation hasn't exactly been >a confidence booster, if you know what I mean... :) > > -Jon- Jon and All... Don't be dismayed. When your "kit" first arrives and you see that pile of tubes you think to yourself... my God, what did I get myself into. I sat myself down and... I first read everything cover to cover and studied all the drawings to understand the entire overall structure before beginning. After reading and looking at the drawings a time or two (some areas several times), most structures and mechanics began to take shape in my mind. I made sure I understood everything generally before I began. Once that was accomplished, I made steady and easy progress with construction part by part and enjoyed all of the building process. I may have called Kolb twice with a question. I finished in the time estimated (less than 500 hrs) with no fancy tools. Would I do it again??? Definitely YES! The Kolb is a super design and really easy to build. I am watching a guy building a Firefly who lives near me. He is making good progress and having a ball. I suggest buying the pre-built ribs. Building them might get a bit monotonous. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Jun 24, 1996
On Sun, 23 Jun 1996 kw012393(at)one.net wrote: > 2) Also, (and I just tried this for the first time two days ago), what's the > trick to fastening the folded wings into the brackets at the bottom of the yep, brazed welding rod or 1/8" piano wire is what i use and see others have done as well. > 3) Can a Kolb be folded/unfolded with only ONE person doing the work? > Anyone with the detailed knowledge of how to do this, please let me know. > I'll be very appreciative. Yes. This is how i do it ALL the time and this is how i PREFER it. By myself, I move fluidly thru the process and it's easier than directing traffic. I'm not sure what to describe, as it seems like there is no place where you need help. If it is windy, having someone available to help keep parts from blowing over is required. However, I usually assemble and disassemble behind some hangars -- a habit formed because ULs were at first unwelcome at my airport -- and 20 mph winds on the runway are not a problem to me. I can't see using a tri or bipod; this is one more piece of junk to haul around, something else to place in the right position, and probably entails a method more inviting to a wing blowing away during assembly. here's some detail... 1. Pin the lift strut to the cage. 2. I then swing out the wing from folded position and rest it on my jacket or a rag to protect the outside corner from the pavement. - i made some 2"x5" AL plates which i hang on the main cage bulkhead against the cage and the pavement. 3. Pin the spar to the cage. It is helpful to be able to push the plane backward, holding up the inboard front of the wing until the holes come into alignment. The outboard end of the wing is still resting on my jacket and by nudging the plane backward I haven't had to drag the outboard end of the wing forward for pin alignment. 4. Standing in front of the wing, I lift it up, along with the outside end of the lift strut. (I often hike up the lift strut w/ my foot, just cuz it's easier to lift the wing w/ both hands.) For clarity to those who haven't done this, the wing is swinging up from its 2 attach points at the root -- the U joint and spar_to_cage pin just inserted (in step 3). Holding the wing w/ one hand, I place the lift strut into position and rest some of the wing weight onto it so that it won't move. Then wiggle things slightly and insert the pin. For me, the position of the hole and bolt at the end of the lift strut worked out perfectly as I'll attempt to show in ascii below.... ___________ | liftstrut O (0 0 | __________ \ the 2 bolts on the wing tang Basically, I was able to file a little divit in the end of the lift strut, shown by the "(". The divit rests against the bottom bolt of the wing tang, at a position very close to pin alignment. Resting a little wing weight on this divet also keeps the lift strut from falling while I wiggle it slightly for the pin to align. BTW, this divet was almost an accident, as the dimensions (from great plans) essentially made this a coincidence; the divet is *very* slight and an afterthought. > > The literature says from trailer to fully ready to fly in 8 minutes with no > tools. Granted, I'm a novice and very inexperienced at this, but that > length of time seems a wee bit optimistic. > 8 minutes is do-able, but not practical. You must, in reality, factor in untie-ing from the trailer, folding out ramps, talking to others, sipping your coffee, being careful, packing some goodies, and then do a pre-flight. NO other vendor offers a plane that keeps the airplane assembly phase to 8 minutes, solo! And to boot, it is one of the strongest, best performing airplanes you can find. For me, honest engine, it is usually 45 minutes from airport arrival to engine start, and 30 minutes from engine off to leaving for home. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Firestar KXP Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Subject: Lots of questions
Date: Jun 27, 1996
I'm 6'6". Will I fit allright in a Mark 3 Kolb? Are there folks who have Mark 3's for sale somewhere? The aircraft looks simple and beautiful but why is there a build time of 500 hours? It does not seem like there would be that much required. Are the kits mostly prefabricated and how much experience do I need to build one? By the way I did build an Avid flyer about 3 years ago with my father in law. I would appreciate receiving mail from Mark 3 owners and builders and your views and advice on some of my questions. Thanks in advance, Jeff Hanks web: http://www.sisna.com/tlcmanti ________________________________________________________________________________
From: "bkearbey" <bkearbey(at)bcoe.butte.k12.ca.us>
Date: Jun 27, 1996
Subject: Re: Lots of questions
Hello Jeff, My Father and I are currently building a Kolb Mark III together. We are nearly done and should have it flying in a couple of weeks. It has been a lot of fun and a great learning experience. > I'm 6'6". Will I fit allright in a Mark 3 Kolb? Are there folks > who have Mark 3's for sale somewhere? I can't answer your first question seeing that I am only 5'7". I have seen a Kolb for sale in a "Trade a Plane" type magazine. It was going for about $18.000. That is the only one that I have seen but I bet there are others out there. > The aircraft looks simple and beautiful but why is there a build > time of 500 hours? It does not seem like there would be that much > required. Its a build time of 300-500. If you have good basic shop skills and a knowledge for that type of stuff it will be on the lower end of the building time. Details like covering and painting take a while but are not to extremely monotonous. > Are the kits mostly prefabricated and how much experience do I need > to build one? By the way I did build an Avid flyer about 3 years ago > with my father in law. No, the kits are not. All the welding is done for you (such as the whole cage.) It comes as pipes pretty much. At first there is no hint of it being an airplane but it moves rather quickly. You can order the wing ribs already built. This saves time and I recommend it. > I would appreciate receiving mail from Mark 3 owners and builders > and your views and advice on some of my questions. Thanks in > advance, Jeff Hanks I hope I helped out. Now I have some questions for those that are already flying the kolb mark III: I would like to know the operating speeds such as Vne--never exceed Vfe--maximum flaps extended. Vx--best angle of climb Vy--best rate of climb Thanks for your help, Brandon Kearbey | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "MarkIII" (sort of). /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe.butte.k12.ca.us . \_______/ |---------/-----| (_____________//--------------\^ / o ( ) ________________________________________________________________________________
Date: Jun 29, 1996
Subject: Brackets "D"
Dear Kolb Friends, I am in the process of cutting all gussets and brackets I need for my Firestar II out of the 0.032 alluminum sheet and found that the bracket "D", the one that holds the cross-bracing on the stabilizers, is shown as being 6 inches long. I does seem a little out of proportion (too long). I tried calling Kolb but got no answer (today is Saturday). Anyone out there has gone trough this already and talked to Kolb about this. Chris ________________________________________________________________________________
Date: Jun 29, 1996
Subject: Re: Brackets "D"
>I am in the process of cutting all gussets and brackets I need for my >Firestar II out of the 0.032 alluminum sheet and found that the bracket "D", >the one that holds the cross-bracing on the stabilizers, is shown as being 6 >inches long. I does seem a little out of proportion (too long). I tried >calling Kolb but got no answer (today is Saturday). Anyone out there has gone >trough this already and talked to Kolb about this. > >Chris Chris, I noticed that also and e-mailed Dennis for the correct dim. Here's part of his response; "... The 1/2" is correct, the width is 2" and the length 1-1/2". Start off with a 2" x 2" square and bend 1/2"...". How long did it take you to receive your first kit? I've been waiting about 3 weeks now. Happy building Curtis ________________________________________________________________________________
Date: Jun 29, 1996
Subject: Balloon Tires
I'm about to install a pair of balloon tires on my MKIII, anyone have any suggestions concerning the installation of these? I've heard of occassional problems related to rotation of the tube within the tire etc. and would seriously like to avoid any unpleasant surprises. Recommended air pressure?? I'm using the Matco aluminium wheels with disc brakes. Also, on another note, what are other builders doing to reduce or prevent airframe corrosion? Thanks Noel ________________________________________________________________________________
Date: Jun 29, 1996
Subject: Weight & Balance
Well just finished our weight & balance. Worked out good for my dad who weighs 185, but myself at 152 is not with in the limits. It works out to be 38.7% aft cg. If anyone who has ran in to this has any suggestions on how much weight to add, where to add it and what kind of weight to use would make it a little easier. Also is the 38.7% aft cg that far out of specs. By the way, tomorrow, which is Sunday, we are going to take it out to our field and break in the engine and start taxiing. Its been a long time waiting but should be well worth the time spent building it. Thanks for any info. Bob. ________________________________________________________________________________
Date: Jun 29, 1996
Subject: Re: Weight & Balance
>Well just finished our weight & balance. Worked out good for my dad who >weighs 185, but myself at 152 is not with in the limits. It works out to be >38.7% aft cg. If anyone who has ran in to this has any suggestions on how >much weight to add, where to add it and what kind of weight to use would make >it a little easier. Also is the 38.7% aft cg that far out of specs. > By the way, tomorrow, which is Sunday, we are going to take it out to our >field and break in the engine and start taxiing. Its been a long time waiting >but should be well worth the time spent building it. Thanks for any info. Bob, In the Kolb Book it mentioned something about the FS w/503 being a little tail heavy with a pilot weighing less then 160 lb. (i think). I considered using bag's of shot laid out on the floorpan just forward of the pilot seat. I guess this would have to be done when the FS is seating on the scales. Just add your weight material and work the numbers for computing CG. My 2 cents Curtis ________________________________________________________________________________
Date: Jun 30, 1996
Subject: Rear diagonal bracing on the Firestar II rib.
I noticed that in all photos I see of the Firestar II wing without fabric there is an aditional diagonal 5/16" bracing, on all ribs, that go from the bottom of the rear 4" vertical bracing to the top-front of the aluminum plate just behind it. My drawings don't show this tubing. As shown on the drawings, there is only 4 diagonal bracings in each rib (two in front of the spar and two on the rear). Has anyone noticed this?. How are the ribs that come pre-built from the Kolb?. Also, if anyone has noticed other inconsistencies in the drawings (such as the one on the dimmensions of the "D" bracket on the stabilizers), could you tell me about them?. I'm beginning to worry a little that if I don't catch one I'll end up ruining a component on the airplane. Chris. ________________________________________________________________________________
Date: Jul 01, 1996
Subject: Spain
Hi Kolb fans One question: I am going to Spain later this month so are there any Kolb builders in Sp= ain? / \ =96=96 Arni Arnason / =96=96\/=96/ =96\ /\ Selbraut 12 / =96=96 \/=96 \ / =96\ /=96=96\ 170 Seltjarnarnes / 0 \=96=96 @ =96\/=96=96=96 \ Iceland / Date: Jul 01, 1996
Subject: Re: Balloon Tires
On Sat, 29 Jun 1996, N.B. Del More wrote: > I'm about to install a pair of balloon tires on my MKIII, anyone have any > suggestions concerning the installation of these? > > I've heard of occassional problems related to rotation of the tube within > the tire etc. and would seriously like to avoid any unpleasant surprises. > I think i'm the one that reported a problem w/ the tube working around inside the tire. This is happening only on one of my wheels, a wheel that is defective in that the rim is not concentric w/ the center hole. I need to replace the damn wheel. I'm now on my second tube and it is working itself around to pull the valve stem just like the first, and I need to move it before it goes too far. My good wheel causes no problems. Tire pressure: ~4.5 psi for my single place Firestar kxp. You won't need much more at all on a 2 place Kolb. > I'm using the Matco aluminium wheels with disc brakes. > > Also, on another note, what are other builders doing to reduce or prevent > airframe corrosion? I bet just keeping it hangared or garaged makes most of the difference, assuming your frame was cleaned and primed well in the first place. Mine's not old enf to show corrosion anyway. As an added item, i put in 2 inspection ports on each wing -- one on the root and one at the lift+drag+main_spar joint. I figured in addition to being able to look inside, I could also open up to vent the wing if i ever had any condensation inside. Inspection ports can be put in during initial covering or later as an add-on. I got mine from Aircraft Spruce for dirt cheap ($1 ea?) As another anti-corrosion effort, i had dipped all my rivets in rustoleum before setting, as well as dabbed them w/ epoxy before covering. (rustoleum is easy cuz it won't "go off" during your overall build time). --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jul 01, 1996
> >it a little easier. Also is the 38.7% aft cg that far out of specs. > > By the way, tomorrow, which is Sunday, we are going to take it out to our > >field and break in the engine and start taxiing. Its been a long time > Bob, > >Curtis West wrote: > bag's of shot > laid out on the floorpan just forward of the pilot seat. I guess this I would try to put the ballast as far forward as possible, e.g. in the nose pod. That provides the longest moment, and therefore requires the least amount of added weight. At least get some of the weight in the nose pod. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jul 01, 1996
Subject: Directions to Kolb in Pheonixville, PA
Hello to Kolb enthusiasts', Can anyone provide me with the directions to the Kolb Co. here in PA? Is it possible to take a ride in a Firestar at the facility? Thanks Kevin ________________________________________________________________________________
Date: Jul 02, 1996
Subject: SlingShot (non)update
Greetings, In case anyone was curious, the SlingShot is still in the non-project stage. Yesterday was 10 weeks since I ordered the plane at Sun-N-Fun and so far, no word of delivery. At this point, I'm still hoping to have it here (first 2 kits) by the end of July. The idle time is making me do crazy things like looking for alternate engines. Yep, Dennis should love some of the engines I'm looking at :-) Rusty ________________________________________________________________________________
Date: Jul 03, 1996
Subject: Rudder cables
To all who read this! My sons and I are about 98% finished with our MarkIII. Just have one question. The rudder cables rub where they enter the top of tube. Tube alignment with fuselage cage is as it should be. I may tape a little piece of rubber on the inside of the tube so that the cables won't chafe. Has anybody had or seen this problem? Bob ________________________________________________________________________________
Date: Jul 07, 1996
Subject: Climb RPM ?
Greetings, Still killing time waiting for the kit and debating options. I'm pretty much planning to use one of the in-flight adjustable Ivo props on a 503 in the Slingshot, and I'm curious about how much advantage it will give (maybe Dennis will tell us since they were planning to test one). If you have a flying plane, can you tell me what rpm you see at you best climb rate? I would need to know which engine you're using too in order to look up the power curve. Thanks in advance, Rusty ________________________________________________________________________________
Date: Jul 07, 1996
Subject: Kolb Slingshot Questions
My name is Frank Beeler from Knoxville Tennessee. I have been looking for a project to replace the Moni Motorglider I completed a few years ago. I have a few questions and request for all you KOLBER'S out there so here it goes. 1. I was unable to make it to Sun&Fun this year but have seen some articles on the Kolb Slingshot. If any of you were able to look this aircraft over I would like to hear what you thought about it. I have received Kolb's info pack and video but because the plane is so new there was little information and no video on the Slingshot. If you have pictures (binary) you could attach that would be great. 2. Have any builders purchase the Quick-Build option. If so were you pleased with the craftsmanship and do you feel it was worth the money. 3. Does anyone have a Kolb project underway that is within a few hours drive of Knoxville? If so I would like to make arrangements for a visit if possible. I have enjoyed being on the E-mail list and learning more about the Kolb Aircraft. I get the impression most of you are pleased with building and flying your aircraft. Thanks in advance for any information or advice. By the way there is a new home page just getting started on the Moni Motorglider at http://ourworld.compuserve.com/hompages/CEmmons/ my Moni (N364TB) is the yellow Tri-gear in the group photo. ________________________________________________________________________________
Date: Jul 07, 1996
My name is Frank Beeler from Knoxville Tennessee. I have been looking for a project to replace the Moni Motorglider I completed a few years age. I have a few questions and request for all you Kolbers out there so here it goes. 1. I was unable to make it to Sun & Fun this year but have seen some articles on the Kolb Slingshot. If any of you were able to look this aircraft over i would like th hear what you thought about it. I have received Kolb's info pack and video but the plane is so new there was really little information and no video on the Slingshot. If you have pictures (binary) you could attach that would be great. 2. Have any builders purchased the Quick-Build option? If so were you pleased with the craftsmanship and do you feel it was worth the money? 3. Does anyone have a Kolb project underway that is within a few hours drive of Knoxville? If so I would like to make arrangements for a visit if possible. I have enjoyed being on the E-mail list and learning more about the Kolb line of Aircraft. I get the impression most of you are pleased with building and flying your aircraft. Thanks in advance for any information or advice. By the way there is a new home page just getting started on the Moni Motorglider. If your would like to visit at http://ourworld.compuserve.com/hompages/CEmmons/ my Moni(N364TB) is the yellow tri-gear in the group photo. ________________________________________________________________________________
Date: Jul 08, 1996
Subject: Kolb Builder's Advice
Howdy, My name is Jim and I'm looking to build a Kolb FIreFly or FireStar. I was hoping some of you might offer some advice on which to build and if you know where I might be able to find an uncompleted kit for sale. My main concern is whether I should worry about keeping my aircraft a legal ultralight or not, in order to be able to sell it easily in the future. Thanks much, Jim J H Byers byersj(at)radium.hanscom.af.mil ________________________________________________________________________________
Date: Jul 08, 1996
Subject: checklists
EAA Chap. 279's Kolb MkIII is nearly completed. I do not know all the details of what is left to do. Last time I saw it 2 weeks ago all I could tell was it needed seats. Some club members started grumbling that it would never be finished. Our EAA tech. counselor, and 2 or 3 experienced builders finally got together to decide which one of them will do what to get the thing in the air. I think there might be a maximum number of people you can use for a specific project. The Mythical Man Month theory applied to aircraft construction. One thing the group asked me to help with is to see if I could get examples of checklists for preflight, takeoff and landing from the inet Kolb group. The president of our flying club said he thought Kolb used to supply checklists but not anymore. I checked old email and I don't see much. In addition to normal prefilght items ( such as "kick tires" and "make sure control surfaces are not hooked up backwards" ) I would be interested in any Kolb specific info. For example, in previous email, Michael Ranson said one of his prefilght items is to empty his pockets. If something falls out of a pocket, it could get sucked into the pusher prop. Maybe the checklists could be the start of a Kolb group FAQ. So, whatever anybody would like to contribute, thanks in advance. chuck chuck(at)kronos.com Chuck Cullen Kronos Inc. 400 Fifth Ave. Waltham, MA 02154 ________________________________________________________________________________
Subject: Non stock landing gear
Date: Jul 08, 1996
I noticed in the last issue of Kit Planes there were several Kolbs and one MKIII had a landing gear that was taller than the stock Kolb (at least the gear I received). I was wondering if there is any type of heavy duty landing gear or any other gear configuration for the MKIII that anyone has used, manufactured or purchased. If so I would be grateful for some information. Thanks;Jason Omelchuck jason(at)acuityinc.com ________________________________________________________________________________
Date: Jul 10, 1996
Subject: Slingshot Ramblings
Greetings All, I talked to Dennis today and he told me that I have to quit telling people that he doesn't really exist (an off-line joke I've had with a few people) :-) He also mentioned that the e-mail messages he's sent me keep bouncing. It seems the Kolb list, for reasons I can't explain, shows a very incorrect "reply to" address on my messages. Does anyone else have that proplem? Please note the correct address on my signature file. The Slingshot news is good and bad. It sounds like the fuselage is coming along ahead of schedule, but the wing/tail kit is slightly behind. With any luck, my first kit will be ready before Oshkosh. I guess I'll just have to mope around the house and annoy my wife for awhile longer. Dennis sounds quite pleased with the flight characteristics of the Slingshot. I'll be in Pennsylvania for a week in mid August so I plan to try out that back seat, and get those pictures I missed at Sun-N-Fun. I also found out that Dan's a CFI and gives tailwheel training in the MK-3. I plan to try to get my tailwheel endorsement during the week I'm up there. This will all work out well for me. I would normally be stuck visiting my in-laws and now I have the perfect excuse to disappear for a few days :-) -- Russell Duffy rad(at)gulf.net http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jul 10, 1996
Subject: e-mail test only (sorry)
Sorry to waste everyones electrons. I think I found MY mistake regarding the incorrect "reply to" address. I seem to have messed up my mail configuration a few weeks ago. This is a test to make sure it's correct now. -- Russell Duffy rad(at)gulf.net http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jul 10, 1996
Subject: Questions
Hello All, I have a few questions that I have asked before but I have not recieved any reply to. We are getting very close to finishing our Mark III. Everything is painted and now we just have to attach the nose cone, hook up the instruments and some other minor details. Where the rudder cables enter the forward part of the fuse. tube, the cables rub on the top of the tube. Has anyone else had this problem and what did you do to fix it? Could someone give me the speeds for the Mark III, such as Vne, Vfe, stall speed 1+2 persons ect.? I would really appreciate a response. Thank you Brandon Kearbey | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "MarkIII" (sort of). /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe.butte.k12.ca.us . \_______/ |---------/-----| (_____________//--------------\^ / o ( ) ________________________________________________________________________________
Date: Jul 11, 1996
Subject: Re: checklists
Just getting back to catching up on my mail. This came in on the Kolb list but I thought my response should go to the UL list as well. On Mon, 8 Jul 1996, Chuck Cullen wrote: > EAA Chap. 279's Kolb MkIII is nearly completed. > ............................ > One thing the group asked me to help with is to see if I could get examples > of checklists for preflight, takeoff and landing from the inet Kolb group. > The president of our flying club said he thought Kolb used to supply > checklists but not anymore. If you are nearing completion of a UL, run (don't walk) to the FAA document storage site at: http://152.123.186.6/CIRCDIR.HTM First download the free Adobe viewer which you will need to view/print the documents which are mostly in .PDF format. Then take the link to miscellaneous advisory circulars and download the Advisory Circular: AC90-89A Amateur-Built Aircraft and Ultralight Flight Testing Handbook. There is a wealth of information covering what you should do during the first 50 hours of flight time on your new plane. There are other Advisory Circulars here as well, including indexes by title and number. But I could not find the (in)famous AC 103-7 on-line. _-_ _,, ,, -/ ) ; || ||_< \\/\/\ _-_ ||/|, _-_ ,._-_ bweber(at)micom.com || \\ || | | || \\ || || || \\ || ;/--|| || | | ||/ || |' ||/ || Keep the shiny _--_-' \\/\\/ \\,/ \\/ \\,/ \\, side up ( ________________________________________________________________________________
Date: Jul 12, 1996
Subject: BRS parachutes
Hello again, I seem to be the one filling everyones mailbox these days. Sure wouldn't mind seeing building updates from some of your projects (hint). I decided that if I can scrape the money together for a parachute without pushing the project back too far, I'll get a BRS chute for the Slingshot. The recent events here in Pensacola haven't been too aviation friendly. In fact, the F-16 crash was about 3/4 mile from my parents house. My question concerns the pusher configuration of the Kolbs. Are you required to shut down the engine and wait for the prop to stop before deploying the chute? Will the lines survive a prop strike (wood, composite, etc ??)? I would think you want to stop the prop if possible, but don't think it would be reasonable to expect in some cases. The opening speed limit of the chute would be a factor too. If I have to wait an extra 5-10 seconds in full plummet mode, speed might exceed the chutes limits. What would be your procedure in an emergency? Thanks for enduring more of my time wasting questions. -- Russell Duffy rad(at)gulf.net http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jul 12, 1996
From: HB!HB1!MHansen(at)hbi.attmail.com (Hansen, Mark)
Subject: RE: Questions
---------- From: bkearbey Subject: Kolb-List: Questions Date: Wednesday, July 10, 1996 19:08PM Hello, My name is Mark Hansen, I have a friend with the same problem. He came to look at my twinstar but they are not the same. I have not seen an answer to this. If anyone knows what to do please send me a note. Thanks Mark Hansen Internet!hb!hb1!mhansen(at)hbi.attmail.com --------------------------------------------------- Hello All, I have a few questions that I have asked before but I have not recieved any reply to. We are getting very close to finishing our Mark III. Everything is painted and now we just have to attach the nose cone, hook up the instruments and some other minor details. Where the rudder cables enter the forward part of the fuse. tube, the cables rub on the top of the tube. Has anyone else had this problem and what did you do to fix it? Thank you Brandon Kearbey bkearbey(at)ben.bcoe.butte.k12.ca.us ________________________________________________________________________________
Date: Jul 15, 1996
About rubbing control cables, I have not gotten to that point of my airplane yet but I would think that there are a couple of things you might do. First try calling or E-Mailing Dennis at Kolb (dlsouder(at)aol.com). The rudder horn might have to be lowered on the rudder ( I realize this is not trivial if it has been drilled) this may or may not work being as it is the wrong end. Put some kind of plastic rub block to hold it off the tube, this would be the simplest but would probably have to be changed regularly. Cut and weld the stands for the fairleads shorter. If it doesn't rub badly maybe you could have a custom fairlead made with the hole off center towards the bottom? My airplane is starting to look like an airplane, I am rigging the wings tomorrow and with the limited space I have it should be a challenge. The fuselage will be just outside a garage door, one wing will be in the garage, one wing will be down the driveway and the tail will be sticking through a open gate. I really envy the people with the pictures on Russels web page that have a space large enough to hold a completed airplane, sure would make it allot easier. I am Planning on putting a subaru engine on my plane, the bottom line is I do not like flying under two stroke power (I have yet to find someone with 200 or more hours that hasn't had a engine failure) and paying $6000 for a two stroke engine is not something I can bring myself to do, and paying $10,000 for a rotax 912 is something I cannot afford to do. I am hoping to have my engine come in at around 150lbs with reduction and am not planning on putting any electrical or starter on it, we will have to see how well that plan pans out. Because I am doing my own engine my first flight should be around the end of next summer. Any ideas or suggestions are always welcome, Happy flying. jason(at)acuityinc.com ________________________________________________________________________________
From: Matthias Petry <midwestengines(at)globalnet.co.uk>
Date: Jul 15, 1996
0M8R4KGxGuEAAAAAAAAAAAAAAAAAAAAAPgADAP7/CQAGAAAAAAAAAAAAAAABAAAACwAAAAAAAAAA EAAADAAAAAEAAAD+////AAAAAAoAAAD///////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// ///////////////////////////////////////////////////////////////////////////c pWgAV+AHBAAAAABlAAAAAAAAAAAAAAAAAwAAMgYAAI8SAAAAAAAAAAAAAAAAAAAAAAAAJQIAAAAA AAAMAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4AALoAAAAADgAAugAAALoOAAAAAAAAug4A AAAAAAC6DgAAAAAAALoOAAAAAAAAug4AABQAAADkDgAAAAAAAOQOAAAAAAAA5A4AAAAAAADkDgAA AAAAAOQOAAAMAAAA8A4AAAoAAAD6DgAAEAAAAOQOAAAAAAAAnREAAGcAAAAKDwAAAAAAAAoPAAAA AAAACg8AAAAAAAAKDwAAAAAAAAoPAAAAAAAACg8AAAAAAAAKDwAAAAAAAAoPAAAAAAAAshAAAAIA AAC0EAAAAAAAALQQAAAAAAAAtBAAAEMAAAD3EAAARAAAADsRAABEAAAAfxEAAB4AAAAEEgAAWAAA AFwSAAAzAAAAnREAAAAAAAAAAAAAAAAAAAAAAAAAAAAAug4AAAAAAAAKDwAAAAAAAAAABAAFAAEA AgAKDwAAAAAAAAoPAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoPAAAAAAAACg8AAAAAAACdEQAAAAAA ALwPAAAAAAAAug4AAAAAAAC6DgAAAAAAAAoPAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoPAAAAAAAA vA8AAAAAAAC8DwAAAAAAALwPAAAAAAAACg8AALIAAAC6DgAAAAAAAAoPAAAAAAAAug4AAAAAAAAK DwAAAAAAALIQAAAAAAAAAAAAAAAAAADggG6BenK7Ac4OAAAIAAAA1g4AAA4AAAC6DgAAAAAAALoO AAAAAAAAug4AAAAAAAC6DgAAAAAAAAoPAAAAAAAAshAAAAAAAAC8DwAA9gAAALwPAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANDQ0NDQ1Zb3UgYXJlIGxvb2tpbmcgZm9yIGFuIG9w dGlvbiB0byBjdXJyZW50IGFpcmNyYWZ0IGVuZ2luZZJzID8NDQ1Zb3UgYXJlIGludGVyZXN0ZWQg aW4gYSBsaWdodCA1MCBCSFAgKDcyLDc1IGxiLiBkcnkgd2VpZ2h0KSALb3IgYSAxMDAgQkhQICgx MTYsODQgbGIuIGRyeSB3ZWlnaHQpIGVuZ2luZSA/DQ0NWW91IHdhbnQganVzdCBhIGZldyBtb3Zp bmcgcGFydHMsIGVhc3kgc2VydmljZSwgZ29vZCBwcm9kdWN0IHN1cHBvcnQgZXRjLiA/DQ0NSGF2 ZSBhIGxvb2sgYXQgdGhlIGZpcnN0IAtKQVItRSBDZXJ0aWZpZWQgV2Fua2VsLVR5cGUgUm90YXJ5 IEVuZ2luZSAoRkFSIDMzIGFwcGxpZWQpC2luIHRoZSB3b3JsZCAuDQ0NTWVldCB1cyBhdCBPU0hL T1NIIDE5OTYNDWF0IHRoZQ0NRElBTU9ORCBVTklURVMgRU5HSU5FUyBDYW5hZGENDUV4aGliaXRp b24gU3RhbmQNDUhvcGUgdG8gc2VlIHlvdQ0NTWF0dGhpYXMgUGV0cnkNTWFuYWdpbmcgRGlyZWN0 b3INDUlmIHlvdSBuZWVkIGluZm9ybWF0aW9uIGluIGFkdmFuY2UsIHBsZWFzZSBjb250YWN0IHVz ICEhDQ1NaWQtV2VzdCBFbmdpbmVzIEx0ZC4NSGFuZ2FyIFNFIDM4DSAgICAgICAgICAgICAgICBU ZWw6IDAxNDUyIDg1NzQ1NiAgICAgICAgICAgICAgIEdsb3VjZXN0ZXJzaGlyZSBBaXJwb3J0ICAg ICAgICAgICAgRmF4OiAwMTQ1MiA4NTY1MTkNU3RhdmVydG9uDUdsb3MgR0w1MSA2U1INRS1NYWls CW1pZHdlc3RlbmdpbmVzQGdsb2JhbG5ldC5jby51aw1fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0NDQ0NDRcAmQKkgi6lxkGm iQWniQWovQypbgSqAAB3d3d3d3h3d3TO7MB3dwd3d3d3d3d3cAVYj4UHd3d3d3d3d3d4e3t7e3t7 e3t4B3d3d3d4dwAzsDM/sDM/MAB3d3d3d3d4//9M7swI//cHd3d3d3d3cAVYj/94UHd3d3d3d3d3 eLe3t7e3t7e3sAd3d3d3eHAzC/sAO/MA+/AzB3d3d3d3eP/0zuzAj//3B3d3d3d3cAVYj///d4UH d3d3d3d3d4t7e3t7e3t7e3AHd3d3d3hwMzA/v7+/v7MDMwd3d3d3d3j/jO7MCP//9wd3d3d3cAVY j///iHd4UHd3d3d3d3eHt7e3t7e3t7eAB3d3d3d4cDMz+/AAAAv7AzMHd3d3d3d4+M7swI////cH d3d3d1VYj///iACHd4UHd3d3d3d3i3t7e3t7e3t7Awd3d3d3eHO/v78I94gAv7+/B3d3d3d3eIf3 zAh3d3/3B3d3d3dQf///iABVCHd4UHd3d3d3eLe3t7e3t7e3twMHd3d3d3hzMzvw+PeIDwvwAHd3 d3d3cAAAeMCP////9wd3d3d3UH//iABVVVCHd4UHd3d3d3h7e3t7e3t7e3iAB3d3d3d4dwADAABD AwAARAMAAAAEAABkBAAAhwQAAKUEAAAlBQAAOgUAADsFAADFBQAA6wUAAC0GAAAuBgAAMQYAADIG AABLBgAA/fv99v30/fDsAOrm5AD94gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAnUBAANjJAAG XQUAYxIAAANdBQAGXQQAYzAAAAZdBABjSAAAA2MoAAhVgV0DAGMkAAADYxgAA2McAAAQAAMAAAED AAACAwAAAwMAAAQDAAAFAwAABgMAAEMDAABEAwAARQMAALADAACxAwAAsgMAAP4DAAD/AwAAAAQA AGQEAABlBAAAZgQAAH4EAAB/BAAAhgQAAIcEAAClBAAApgQAALcEAAC4BAAAyAQAAMkEAADYBAAA 6gQAAOsEAAAkBQAAJQUAADsFAABIBQAArQUAALcFAADFBQAA6wUAAC0GAAAuBgAALwYAADAGAAAx BgAA/gABbyNDAf4AAW8jQwH+AAFvI0MB/gABbyNDAf4AAW8jQwH+AAFvI0MB+wABbyNDAf4AAW8j CAH7AAFvI0MB+wACbyNDAfsAAW8jQwH7AAFvI0MB+wABbyNDAfsAAW8jQwH7AAFvI0MB+wADbyO5 AfsAAW8jQwH7AAFvI0MB+wABbyNDAfsAAW8jQwH7AAFvI0MB+wABbyNDAfsAAW8jyAH7AAFvI0MB +wABbyNDAfsAAW8jQwH7AAFvI0MB+wABbyNDAfsAAW8jQwH7AAFvI0MB+wABbyNDAfsAAW8jQwH7 AAFvI0MB+wAAAAAAAPsAAAAAAAD+AAAAAAAA+wAAAAAAAPsAAAAAAAD7AAAAAAAA+wAAAAAAAPsA AAAAAAD5AAAAAAAA/gAAAAAAAP4AAAAAAAAAAAAAAAAAAAAAAQ8AAAIAAAUBAAEAACwxBgAAMgYA AP0AAW8jQwEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAUBAQ4AEQAIAAEA SwAPAAAAAAAcAABA8f8CABwACFN0YW5kYXJkAAIAAAADAGEJCAAAAAAAAAAAAAAAAAAAAAAAAAAm AEFA8v+hACYAGUFic2F0ei1TdGFuZGFyZHNjaHJpZnRhcnQAAAAAAAAAAAAAAAAkAB9AAQDyACQA CUtvcGZ6ZWlsZQAADAAPAA8IAAK4EXAjAQIAACIAIEABAAIBIgAIRnXfemVpbGUADAAQAA8IAAK4 EXAjAQIAAAAAAAAyAwAABAAyBgAAAAD/////AQAEIP//AQAAAAAAMgMAAAAAAAAAAAAAAAALAQAA DgEAAAADAABLBgAABAAAAwAAMQYAADIGAAAFAAYAAAAAAAYAAABDAAAARQAAALAAAACyAAAA/gAA AAABAABkAQAAZgEAAH4BAAB/AQAAhgEAAIcBAAClAQAApgEAALcBAAC4AQAAyAEAAMkBAADqAQAA 6wEAACQCAAAlAgAAOgIAADsCAABIAgAAWAIAAOsCAAAzAwAABwAFAAcABQAHAAUABwAFAAcABQAH AAUABwAFAAcABQAHAAUABwAFAAcABQAHAAUABwAFAAcABQAHAPYAEU1hdHRoaWFzIFBldHJ5Li4u FUM6XE1XRVNFQ1xNV0VfRkFYLmRvYxFNYXR0aGlhcyBQZXRyeS4uLhxDOlxCbGVpYnRcTVdFU0VD XE1XRV9GQVguZG9jAi4uG0M6XEJMRUlCVFxNV0VTRUNcT1NLT1NILkRPQwIuLhxDOlxCTEVJQlRc TVdFU0VDXE9TS09TSDIuRE9DEU1hdHRoaWFzIFBldHJ5Li4uHEM6XEJsZWlidFxNV0VTRUNcT1NL T1NIMi5ET0MRTWF0dGhpYXMgUGV0cnkuLi4cQzpcQmxlaWJ0XE1XRVNFQ1xPU0tPU0gzLmRvY/9A UXVpY2tMaW5rIE1lc3NhZ2VDZW50ZXIARkFYL01PREVNAFFMTUNEUlZSAFF1aWNrTGluayBNZXNz YWdlQ2VudGVyAFF1aWNrTGluayBNZXNzYWdlQ2VudGVyAAAAAAAAAAAACgMAA0QAAAADBAAAAQAJ AAAAAAAAAAAAAAD+/wAAAAAAAAAAUXVpY2tMaW5rIE1lc3NhZ2VDZW50ZXIAAAAAAAAAAAAKAwAD RAAAAAMEAAABAAkAAAAAAAAAAAAAAP7/AAAAAAAAAAABgAEAAgAAAAIAAAAJAAEAAQACAAAAAAAA AAIAAABnABUWkAEAAFRpbWVzIE5ldyBSb21hbgAMFpABAgBTeW1ib2wACyaQAQAAQXJpYWwAFUaQ AQAAQnJ1c2ggU2NyaXB0IE1UABQGkAEAAEJsYWNrIENoYW5jZXJ5AAoikAEAAEhlbHYAIgAEADEI iBgAAMQCAACpAQAAAADVfAcm1XwHJgAAAAACAAAAAABPAAAAxAEAAAEAAQAAAAQAgxADAAAAAAAA AAAAAAABAAEAAAABAAAAAAAAAFkCAAAAADMAAAAbRGVhciBBaXJjcmFmdCBNYW51ZmFjdHVyZXIs AAAAAi4uAi4uAAAAAAAAAAAAAHd3j3d3d3eAd3d3d3d3d4///////////wd3d3d3d3d3d3d3d4/8 z///cHd3d3ePgM7MzMT3iAd3d3d3d3d3d3d3d4+AZmaHgHd3d3d3d3eHd3d3d3iIiIh3d3d3d3d3 d3d3d3d4///8z/cAd3d3j4DMzMzE94gHd3d3d3d3d3d3d3ePgGZmh4B3d3d3d3d3ePu7u7uHd3d3 d3d3d3d3d3d3d3d3d4/8z///iHd3d4+AAAAABPeIB3d3d3d3d3d3d3d3j4BmZoeAd3d3d3d3d3eI iIiId3d3d3d3d3d3d3d3d3d3d3d4////iHd3d3ePiIiIiIj3iAd3d3d3d3d3d3d3d4+A5maHgHd3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d4//iHd3d3d3j////////4gHd3d3d3d3d3d3d3eP gAAAh4B3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d4iHd3d3d3d3h3dwEAAAACAAAAAwAA AAQAAAAFAAAABgAAAAcAAAAIAAAACQAAAP7////9////DgAAAP7///8WAAAA/v////////////// ///////////////////////////+//////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// ////////////////////////////////////////////////////////////UgBvAG8AdAAgAEUA bgB0AHIAeQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+QYAoPCdRgC0yEYAAAAAABYABQH/ /////////wEAAAAACQIAAAAAAMAAAAAAAABGAAAAACCzUQh2crsB4IBugXpyuwENAAAAQAMAAAAA AABXAG8AcgBkAEQAbwBjAHUAbQBlAG4AdAAAAAIAAgAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAQAA AAAAAAAAAAAAGgACAQIAAAADAAAA/////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAACPEgAAAAAAAAEAQwBvAG0AcABPAGIAagAAAGMAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAASAAIB////////////////AAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAGoAAAAAAAAABQBTAHUAbQBtAGEAcgB5AEkAbgBmAG8AcgBt AGEAdABpAG8AbgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACgAAgH/////BAAAAP////8AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAtAEAAAAAAAABAAAA/v///wMAAAAE AAAABQAAAAYAAAAHAAAACAAAAP7///8KAAAACwAAAAwAAAD+//////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// /////////////////////////////////////////////////////////wEA/v8DCgAA/////wAJ AgAAAAAAwAAAAAAAAEYYAAAATWljcm9zb2Z0IFdvcmQgRG9rdW1lbnQACgAAAE1TV29yZERvYwAQ AAAAV29yZC5Eb2N1bWVudC42APQ5snEAAAAAAAAAAAAAAADQzxHgobEa4QAAAAAAAAAAAAAAAAAA /v8AAAQAAgAAAAAAAAAAAAAAAAAAAAAAAQAAAOCFn/L5T2gQq5EIACsns9kwAAAAhAEAABEAAAAB AAAAkAAAAAIAAACYAAAAAwAAALwAAAAEAAAAyAAAAAUAAADUAAAABgAAAOAAAAAHAAAA7AAAAAgA AAAAAQAACQAAAAwBAAASAAAAGAEAAAoAAABAAQAADAAAAEwBAAANAAAAWAEAAA4AAABkAQAADwAA AGwBAAAQAAAAdAEAABMAAAB8AQAAAgAAAOQEAAAeAAAAHAAAAERlYXIgQWlyY3JhZnQgTWFudWZh Y3R1cmVyLAAeAAAAAQAAAAA6aRAeAAAAAwAAAC4uAAAeAAAAAQAAAAD//38eAAAAAQAAAABORgAe AAAACwAAAE5vcm1hbC5kb3QAAB4AAAADAAAALi4AAB4AAAACAAAAMgBGAB4AAAAeAAAATWljcm9z b2Z0IFdvcmQgZm9yIFdpbmRvd3MgOTUARgBAAAAAAAAAAAAAAABAAAAABQBEAG8AYwB1AG0AZQBu AHQAUwB1AG0AbQBhAHIAeQBJAG4AZgBvAHIAbQBhAHQAaQBvAG4AAAAAAAAAAAAAADgAAgD///// //////////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJAAAA6AAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAP///////////////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA////////////////AAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD///////////////8AAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD+/wAABAACAAAAAAAAAAAA AAAAAAAAAAABAAAAAtXN1ZwuGxCTlwgAKyz5rjAAAAC4AAAACAAAAAEAAABIAAAADwAAAFAAAAAE AAAAXAAAAAUAAABkAAAABgAAAGwAAAALAAAAdAAAABAAAAB8AAAADAAAAIQAAAACAAAA5AQAAB4A AAAEAAAATVdFAAMAAAAAMAAAAwAAAAMAAAADAAAAAQAAAAsAAAAAAAAACwAAAAAAAAAMEAAAAgAA AB4AAAAcAAAARGVhciBBaXJjcmFmdCBNYW51ZmFjdHVyZXIsAAMAAAAAAAAA7uCAd3j3iIiIiIiI iIiIiId4iAd3d3d3d3d3jwd3d3d3d3d39//////5mZuZmf//////f493d3d493d3d3uqfu7nAHd4 93d3d3d3d3d3d3d3eIgHd3d3d3d3dwgHd3d3d3d3d4eIiIiImZmIiZmYiIiIiHiP////j393d3e7 qn7ud3B3ePd3d3d3d3d3d3ciJ3iIB3cAAAAAAAAAAAAAAAAAd3d3d3d3eZmXjweZmXd3d3d3eHd3 d4j393d3e6fu53dwd3j3d3d3d3d3d3d3qqd4iAd4iIiIiIiIiIiIiIiIiAd3d3d3d3d3d48Hd3d3 d3d3d3eHd3iHj393d7un7nd3dwd4////////////////+IgHePd3d3d3d3d3d3d3d3iAd3d3d3d3 d3cIB3d3d3d3d3d3eIiIeHj393d7fud3d3cHd4d3d3d3d3d3d3d3d3eIB3j3//////////////d4 iAd3AAAAAAAAAAAAAAAAAHd3d3d3h4eHj394iI53d3d3cHd4d3d3d3d3d3d3d3d3eAd494iIiIiI iIiIiIiHeIgHeIiIiIiIiIiIiIiIiIgHd3d3d4h4eHj3gAAId3d3d3B3d4iIiIiIiIiIiIiIiIh3 ePf/////////////93iIB3j3d3d3d3d3d3d3d3d4gHd3d3eHh4eHiAd3gId3d3dwd3d3d3d3d3d3 d3d3d3d3d3j3iIiIiIiIiIiIiId4iAd49//////////////3eIgHd3d3iHh4eHgHd4CHd3d3cHd3 d3d3d3d3d3d3d3d3d3d493d3d3d3d3d3d3d3eIgHePeIiIiIiIiIiIiIh3iIB3d3d4d3d3d4B3eA h3d3d3B3d3d3d3d3d3d3d3d3d3d3ePd3d3d3d3d3d3ciJ3iIB3j3//////////////d4iAd3d3eH d3d36Ad3gIh4eHhwd3d3d3d3d3d3d3d3d3d3d3j3d3d3d3d3d3d3qqd4iAd494iIiIiIiIiIiIiH eIgHd3d3h3d3fneAAAj/h4eHgHd3d3d3d3d3d3d3d3d3d3d4////////////////+IgHePd3d3d3 d3d3d3d3d3iIB3d3d4d3d+d6qIiH9/h4eHB3d3d3d3d3d3d3d3d3d3d3d4d3d3d3d3d3d3d3d3eI B3j3d3d3d3d3d3d3Iid4iAd3d3d4d+53quu3d39/h4cHd3d3d3d3d3d3d3d3d3d3d3d4d3d3d3d3 d3d3d3d3eAd493d3d3d3d3d3d6qneIgHd3d3eO7neq7rt3d39/h4B3d3d3d3d3d3d3d3d3d3d3d3 d4iIiIiIiIiIiIiIiIh3eP////////////////iIB3d3d3eOd6qu67d3d39/gHd3d3d3d3d3d3d3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3eHd3d3d3d3d3d3d3d3iAd3d3d3h3qq7uu3d3d39/B3d3d3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3eHd3d3d3d3d3d3d3d3gHd3d3d3iqqu7rt3d3 d38Hd3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3eIiIiIiIiIiIiIiIiId3d3d3d3 iq7uu7d3d3dwd3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3 d3d3d3d3d3iI7ru3d3dwB3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3 d3d3d3d3d3d3d3d3d3d3eIi7t3cAB3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3iIiId3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3dwAA AAAAAAAAAAAAAAAHd3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3dwAAAAAAAAAAAAAAAA AAd3d3gzMzMzMzMzMzMzMzMzMHAAAAAAAAAAAAAAAAAHd3dwAAAAAAAAAAAAAAAAB3d3iIiIiIiI iIiIiIiIiIiAd3d4t7e3t7e3t7e3t7e3tzCIiIiIiIiIiIiIiIiIgHd3iIiIiIiIiIiIiIiIiIB3 d493d3d3d3d3d3d3d3d3iAd3eHt7e3t7e3t7e3t7e3swj3d3d3d3d3d3d3d3d4gHd493d3d3d3d3 d3d3d3eIB3ePd3d/f39/f39/f39/d4iAd4e3t7e3t7e3t7e3t7e3AI93d3d/////93d3d3eIgHeP d3d3f/////d3d3d3iIB3j3d3eHh4eHh4eHh4eHeIgHeLe3t7e3t7e3t7e3t7dwCPf///8AAAAA// //d3iIB3j3////AAAAAP///3d4iAd493d3d3d3d3d3d3d3d3iIB3h7e3t7e3t7e3t7e3t7gAj3iI iIAAAAAIiIiHd4iAd494iIiAAAAACIiIh3eIgHePd3d3f/////////93d4iAd4t7e3t7e3t7e3t7 e3t4AI93d3d4iIiIh3d3d3eIgHePd3d3eIiIiId3d3d3iIB3j3d3f/AAAAAAAAAA/3eIgHi3t7e3 t7e3t7e3t7e3sDCPd3d3d3d3d3d3eZd3iIB3j3d3d3d3d3d3d3mXd4iAd495l3iAAAAAAAAAAIh3 iIB4e3t7e3t7e3t7e3t7e3Awj3d3d3d3d3d3d3mXd4iAd493d3d3d3d3d3d5l3eIgHePeZd4gAAA AAAAAACId4iAeLe3t7e3t7e3t7e3t7eAMI93d3d3d3d3AAAAAAAAAACPd3d3d3d3d3AAAAAAAAAH j3d3d3iIiIiIiIiId3eIgHh7e3t7e3t7e3t7e3t7gDCP/////////4iIiIiIiIiAj/////////+I iIAAAAiIgI93d3d3d3d3d3d3d3d3iICHt7e3t7e3t7e3t7e3twgweHd3d3d3d3eIiIiID4iIgHh3 d3d3d3d3j3d4iIgH94CP/////////////////4iAi3t7e3t7e3t7e3t7e3sIMHeHd3d3d3d3iIiI iA+IiIB3h3d3d3d3d493eAeIB/eAeHd3d3d3d3d3d3d3d3d4gIe3t7e3t7e3t7e3t7e4CzB3eIiI iIiIiIiIiIgPiIiAd3iIiIiIiIiPd3gHiAf3gHeHd3d3d3d3d3d3d3d3d4CLe3t7e3t7e3t7e3t7 eAcwd3d3d3d3d3eIiIiIiIiIgHd3d3d3d3d3j3d3iIiId4B3eIiIiIiIiIiIiIiIiIiHj/////// //////////CLMHd3d3d3d3d3iIiIiP+IiIB3d3d3d3d3d493d3d3d3eAd3d3d3d3d3d3d3d3d3d3 d3iHd3d3d3d3d3d3d3d3tzB3d3d3d3d3d4iIiIiI+IiAd3d3d3d3d3ePd/////93gHd3d3d3d3d3 d3d3d3d3d3d3ePt7e3t7e3t7e3t7e3swd3d3d3d3d3eIiIgI+PiIgHd3d3d3d3d3j3//////94B3 d3d3d3d3d3d3d3d3d3d3d3j3t7e3t7e3t7e3t7e3MHd3d3d3d3d3iIiICIiIiIB3d3d3d3d3d49/ //////eAd3d3d3d3d3d3d3d3d3d3d3d4+3t7e3t7e3t7e3t7ezB3d3d3d3d3d4iIiIAIiIiAd3d3 d3d3d3ePf//////3gHd3d3d3d3d3d3d3d3d3d3d3ePe3t7e3t7e///////8Hd3d3d3d3d3eP//// ////8Hd3d3d3d3d3j3//////94B3d3d3d3d3d3d3d3d3d3d3d3j7e3t7e3t7eIiIiIiId3d3d3d3 d3d3j/////////B3d3d3d3d3d49///////eAd3d3d3d3d3d3d3d3d3d3d3d3j7e3t7e3t4d3d3d3 d3d3d3d3d3d3d4/////////wd3d3d3d3d3ePf//////wgHd3d3d3d3d3d3d3d3d3d3d3d3j7e3t7 e3h3d3d3d3d3d3d3d3d3d3eP////////8Hd3d3d3d3d3j3//////94B3d3d3d3d3d3d3d3d3d3d3 d3d3j/////+Hd3d3d3d3d3d3d3d3d3d3iIiIiIiIiIB3d3d3d3d3d3iIiIiIiIiHd3d3d3d3d3d3 d3d3d3d3d3d3d3iIiIiId3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3 d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3d3dwCOs196crsBQAAAAACOs196crsBAwAA AAEAAAADAAAATwAAAAMAAADEAQAAAwAAAAAAAADQzxHgobEa4QAAAAD+/wAABAACAAAAAAAAAAAA AAAAAAAAAAABAAAAAtXN1ZwuGxCTlwgAKyz5rjAAAAC4AAAACAAAAAEAAABIAAAADwAAAFAAAAAE AAAAXAAAAAUAAABkAAAABgAAAGwAAAALAAAAdAAAABAAAAB8AAAADAAAAIQAAAACAAAA5AQAAB4A AAAEAAAATVdFAAMAAAAAMAAAAwAAAAMAAAADAAAAAQAAAAsAAAAAAAAACwAAAAAAAAAMEAAAAgAA AB4AAAAcAAAARGVhciBBaXJjcmFmdCBNYW51ZmFjdHVyZXIsAAMAAAAAAAAA0M8R4KGxGuEAAAAA AAAAAAAAAAAAAAAA//////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////////// //////////////////////////////////////////// ________________________________________________________________________________
Date: Jul 15, 1996
Date: Jul 15, 1996
Subject: Prop Noise
We have been flighing the Mark III we completed last summer and now with 80 hours on the 912 engine are questioning the noise level in the cabin. The cabin is completely enclosed and yet the noise is so loud that when we radio the airport ________________________________________________________________________________
Date: Jul 15, 1996
Subject: Lexan edging
Photos of some Mark III's I've seen have what looks like black edging around the lexan windshield and doors. Does anyone have a source for this stuff? Also, similar material for the edge of of the nose cone? Doug Prange Mark III Builder ~85% Lincoln, Nebraska ________________________________________________________________________________
Date: Jul 15, 1996
Subject: Re: Subaru
Jason, I looked into the Subaru engine and it looked like it would be closer to 200 pounds to me (EA-81 w/drive, wet). This probably did include the electrics though. If you aren't already on the Subaru mailing list, let me know and I'll send you the signup info. I was on it, but got off when I decided the engine wouldn't work for my Slingshot project. I tend to agree about the 2-stroke situation even though I have no experience with them. I can't find a suitable substitute, so it looks like I'll be using the 503. I have, however, heard mostly good things about it. One question about the lack of a starter, won't it be a little tough hand proping an engine on the Kolb? Good luck with the rigging and thanks for the update. -- Russell Duffy rad(at)gulf.net http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Jul 16, 1996
Subject: Gone for a little while
To all... I will be out of touch for a few days while my wife and I are moving. We are downsizing to an apartment. It is not easy leaving a nice big home we still love, but we are only two people now with both kids grown and gone. The time is right. I found a home for the Kolb at Aero-country airport near McKinney, Tx. It is about 30 miles from the apartment. Now that it is at an airport, I have no excuse to keep from flying. Hopefully that will happen when the pilot gets himself ready. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Jul 17, 1996
Subject: re: BRS parachutes
> From: Russell Duffy <rad(at)gulf.net> > Subject: BRS parachutes > > Are you required to shut down the engine and wait for the prop to stop > before deploying the chute? No. If you are in a situation where you actually have to fire the chute, you should fire it as soon as you can and then shut down the engine. I suspect you usually don't have to worry about shutting down the engine. My guess is that when most ballistic chutes have been fired from an aircraft with an engine, the engine was not running at the time. Does anybody have any statistics? I supposed BRS does. Remember this thought provoking comment from Jason Omelchuck: > the bottom line is I do not like flying under two stroke power > (I have yet to find someone with 200 or more hours that > hasn't had a engine failure) > Will the lines survive a prop strike (wood, composite, etc ??)? Yes. > If I have to wait an extra 5-10 seconds in full plummet mode, speed might > exceed the chutes limits. What would be your procedure in an emergency? A ballistic chute opens in about 2 seconds. I don't think a Kolb can exceed the chutes limits. If they can handle a C152 they can handle a Kolb. I would like to conduct a little survey. The flying club I am a member of does not want to put a ballistic chute on the Kolb Mk III we're building. Some of the members have experienced engine out emergency landings in other types of experimental aircraft. The most recent was a club member flying a Avid who had a gas leak, ran out of gas, and landed on the grass median of I90 in upstate New York. The police fined him $100. I am wondering what percentage of Kolb's (all types) now flying do not have a ballistic chute. If you want to email me any info you have, I will summarize the results. Any other opinions you want to add are welcome and I will try to summarize them as well. On another subject, thanks to Bill Weber for the info about the FAA advisory papers on the web. There is a ton of additional info there also. The web address is www.faa.com (The IP number Bill gave works too). chuck chuck(at)kronos.com Chuck Cullen Kronos Inc. 400 Fifth Ave. Waltham, MA 02154 ________________________________________________________________________________
Subject: Re: 2 vs 4, again.
Date: Jul 20, 1996
Jason Omelchuck wrote: I am Planning on putting a >subaru engine on my plane, the bottom line is I do not like flying under >two stroke power (I have yet to find someone with 200 or more hours that >hasn't had a engine failure) and paying $6000 for a two stroke engine is >not something I can bring myself to do, and paying $10,000 for a rotax >912 is something I cannot afford to do. jason(at)acuityinc.com Jason, I flew about 300 hours getting, and then enjoying a private ticket back in 1978 to 1981. I had two total engine out "dead stick" (misnomer) landings. The first was in a Piper 140, my third dual flight. 200 ft in the air, quiet. Instructor took it, stuck the nose abruptly DOWN, pulled full flaps and we rolled out with the nose against the fence at the end of the runway overrun area. No problem. Never found out what stopped the Lycoming. Everything appeared OK when the mechanic checked it out. He started it up after the inspection, flew it around for awhile. We continued our lesson. ?? Later on an aerobatic instructor and I emptied our wing tanks through dry and leaking gaskets in a Fairchild PT-19. We were practicing inverted turns. 3500 ft and 11 miles out, quiet. Because he knew what he was doing, we made it home. No problem. I'm taking dual now at the Perris CA ultralight center in Quicksilvers with the Rotax 2-strokes. There are a LOT of 2-strokes there and a LOT of activity. I hear no horror stories there. Engine problems are always traceable to operation procedures and maintenance mistakes or omissions, at least in the stories told here. I am NOT recommending that you fly a two-stroke but do study carefully the weight penalty you'll pay for the 4 banger. To me one of the biggest rewards of flying light aircraft is a LOW wing loading. I'd rather be responsible for my own maintenance and operation, then be able to land at a TRUE 27mph, than have the questionably superior reliability of a non-certificated four stroke, but have to dead stick in with higher airspeed because of the higher wingloading. Putting either the Piper or the Fairchild down off the runway would have been a mess because of the airspeed required to fly (not fall) in. Each to his own. For me Light is Right! ________________________________________________________________________________
Date: Jul 22, 1996
> Jason Omelchuck wrote: > I am Planning on putting a > >subaru engine on my plane, the bottom line is I do not like flying under > >two stroke power (I have yet to find someone with 200 or more hours that > >hasn't had a engine failure) and paying $6000 for a two stroke engine is > >not something I can bring myself to do, and paying $10,000 for a rotax > >912 is something I cannot afford to do. jason(at)acuityinc.com On Sat, 20 Jul 1996, Dirksens wrote: > > Jason, I flew about 300 hours getting, and then enjoying a private ticket > back in 1978 to 1981. I had two total engine out "dead stick" (misnomer) > landings. The first was in a Piper 140, my third dual flight. 200 ft in > the air, quiet. > Instructor took it, stuck the nose abruptly DOWN, pulled full flaps and we > rolled out with the nose against the fence at the end of the runway overrun > area. No problem. Never found out what stopped the Lycoming. Everything > appeared OK when the mechanic checked it out. He started it up after the > inspection, flew it around for awhile. We continued our lesson. ?? > > Later on an aerobatic instructor and I emptied our wing tanks through dry > and leaking gaskets in a Fairchild PT-19. We were practicing inverted > turns. 3500 ft and 11 miles out, quiet. Because he knew what he was > doing, we made it home. No problem. > > I'm taking dual now at the Perris CA ultralight center in Quicksilvers with > the Rotax 2-strokes. There are a LOT of 2-strokes there and a LOT of > activity. I hear no horror stories there. Engine problems are always > traceable to operation procedures and maintenance mistakes or omissions, at > least in the stories told here. I am NOT recommending that you fly a > two-stroke but do study carefully the weight penalty you'll pay for the 4 > banger. To me one of the biggest rewards of flying light aircraft is a LOW > wing loading. I'd rather be responsible for my own maintenance and > operation, then be able to land at a TRUE 27mph, than have the questionably > superior reliability of a non-certificated four stroke, but have to dead > stick in with higher airspeed because of the higher wingloading. > > Putting either the Piper or the Fairchild down off the runway would have > been a mess because of the airspeed required to fly (not fall) in. > > Each to his own. For me Light is Right! > This is one of the best, most complete pieces of advice I've ever seen on a given subject on the internet. Light IS Right; ability to land slow means an awful lot, and a decent climb rate at even at cruise power setting isn't bad either. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Jul 23, 1996
Subject: ballistic chutes
In my last post to the Kolb group I said that in an emergency situation I thought it was preferable to fire a ballistic chute before shutting down a pusher prop engine. I assumed that, when flying a Kolb, you may not have much time to fire a ballistic chute since Kolb's are often flown at low altitudes, or you have trouble at takeoff like the accident in Florida, etc. Therefore, it would be preferable to get the chute out as soon as possible and then stop the engine as the second step of the procedure. Maybe not. I received a response from someone who knew of an accident in Maryland, USA, where the pusher prop UL had a structural failure and the ballistic chute got cought in the prop. The crash was fatal. Then I sent BRS email via their web page and following is the response I received. > From: BRSchute(at)aol.com > best to turn off engine first if possible. On a pusher aircraft you > have much more of a chance of a parachute getting into the prop than a > tractor type airplane. During a deployment the parachute will go downwind > even if it's fired straight up. Make sure the rocket and chute are not aimed > at the prop arc. Aim the recovery system (if top mounted) as upright as > possible to avoid the prop, the chute will still go to the back but the > rocket will have a chance to clear the prop and take the parachute to full > line extention leaving the kevlar bridle to take a prop strike not the > parachute or it's nylon lines. The kevlar bridle can take a prop strike, but > still turn off the motor. Please remember to install the recovery system as > directed by the manufacture. > > Gregg Ellsworth > BRS chuck chuck(at)kronos.com ________________________________________________________________________________
Date: Jul 24, 1996
From: "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM>
Subject: Status, 2 questions...Mark III
All controls are now connected and working well (no fabric covering yet). Seats/belts are in, floor pan in (decided to make front half of pan removable for brake service). Installed streamline material onto lift struts last night. The struts look great powdercoated. Question #1: How many of you are using or planning to use the jury strut? The plans make it sound kind of optional. The strutslook so nice and strong I hate to add the ugly little jury strut 8-) . Question #2: I also have the problem of the rudder cables dragging on the front end of the fuselage tube just behind the fairleads. What are we doing about this? A friend suggested I have a couple custom fairleads made with very small or offset center holes. If I had a lathe I would do this. Are there any other solutions in use? Has anyone asked Dennis yet? Overall, the plane is coming together quite well. I added up my hours so far and came up with 297.5. I still haven't started the gap seal, and like I said above have not done any covering. Most of my steel parts are primed and painted. All cables are made and controls working well. Gear is on, brakes need to be plumbed (probably after covering). Also have not put in the wing fold storage brackets yet, waiting till I have a bag of water softener salt (80 lbs) to simulate the engine weight. I built the aileron stops out of Lexan, per suggestion from Dennis. They bolt on with the rod-end bolts at the rear of the fuselage and stop against the fuse tube. They work well and look good (and don't need painting!). There are probably planes built in fewer hours than mine, but I have (and will continue to) go back and rework anything that doesn't suit me until it is satisfactory. This attitude has produced a better plane for me, as I have re-built things several times in some cases and almost everything is meeting spec now. I think I have good timing, with OshKosh next week. My plane will be ready to dissassemble to cover and paint the week after OshKosh, so if I see any good ideas or other solutions while I am there, it is not too late. See you there! ________________________________________________________________________________
Subject: RE: Status, 2 questions...Mark III
Date: Jul 24, 1996
I'm not really sure what you are referring to when you say "streamline material" my struts are streamline aluminum by themselves. I received a news letter about a year ago from Kolb and they mentioned that the 1inch by .058 tube around the end fittings should be extended the whole length of the strut and if you did this and were flying at gross weights in the 800lb range the jury strut was not needed. There have been other postings about the cables rubbing but I do not know the solutions (if any) that were provided by Kolb. >---------- >From: Jim Gerken >GERKEN(at)RCHVMX.VNET.IBM.COM[SMTP:GERKEN(at)RCHVMX.VNET.IBM.COM@acuityinc.com >] >Sent: Wednesday, July 24, 1996 6:27AM >To: kolb(at)hpmail2.ftw.mot.com >Subject: Status, 2 questions...Mark III > > All controls are now connected and working well (no fabric covering >yet). >Seats/belts are in, floor pan in (decided to make front half of pan >removable >for brake service). Installed streamline material onto lift struts >last >night. The struts look great powdercoated. Question #1: How many of >you >are using or planning to use the jury strut? The plans make it sound >kind of >optional. The strutslook so nice and strong I hate to add the ugly >little >jury strut 8-) . > Question #2: I also have the problem of the rudder cables dragging >on the >front end of the fuselage tube just behind the fairleads. What are we >doing >about this? A friend suggested I have a couple custom fairleads made >with >very small or offset center holes. If I had a lathe I would do this. >Are >there any other solutions in use? Has anyone asked Dennis yet? > Overall, the plane is coming together quite well. I added up my >hours >so far and came up with 297.5. I still haven't started the gap seal, >and >like I said above have not done any covering. Most of my steel parts >are >primed and painted. All cables are made and controls working well. >Gear >is on, brakes need to be plumbed (probably after covering). Also have >not >put in the wing fold storage brackets yet, waiting till I have a bag of >water softener salt (80 lbs) to simulate the engine weight. I built >the >aileron stops out of Lexan, per suggestion from Dennis. They bolt on >with >the rod-end bolts at the rear of the fuselage and stop against the fuse >tube. >They work well and look good (and don't need painting!). There are >probably >planes built in fewer hours than mine, but I have (and will continue >to) go >back and rework anything that doesn't suit me until it is satisfactory. >This attitude has produced a better plane for me, as I have re-built >things >several times in some cases and almost everything is meeting spec now. >I think I have good timing, with OshKosh next week. My plane will be >ready >to dissassemble to cover and paint the week after OshKosh, so if I see >any >good ideas or other solutions while I am there, it is not too late. > See you there! > ________________________________________________________________________________
Date: Jul 25, 1996
Subject: One vs two carbs on two-cycle engines
Let me add to the recent discussion on one vs two carbs on two-cycle engines. The result of adding the second carb is improved engine reliability. In 1989 I conducted a survey of two-cycle aircraft engines. The results were published in the September issue of the Experimenter and subsequently in Kitplanes. Engines with a carburetor per cylinder ran significantly longer before failure than did manifolded engines. In fact, none of the dual carb Rotax 503's reported had failed whereas a significant number of the single carb units had failed. And they had comperable operating times. My own Rotax 503 DC, mounted in a B1-RD ultralight, ran 307 hours before the rear rod big end bearing failed and the engine quit. At that time the total complete overhaul cost was $1000. It included the replacement of all moving parts, except for the flywheel, with new parts. If it weren't for the two-cycle aircraft engine, we would be flying 600 lb empty weight aircraft like the J3 cub. I'm putting a Rotax 503 DC DI in my Firestar II. I will include a dual EGT in the instrumentation whose primary purpose is to initially set the carburation. I have yet to hear of an engine saved by its instrumentation after the initial setup. ________________________________________________________________________________
From: "bkearbey" <bkearbey(at)bcoe.butte.k12.ca.us>
Date: Jun 10, 1996
Subject: door hinges
Hello, I was working on the doors today and I tried to keep the hinges as straight as possible to prevent binding. When I put the wire back into the hinges I found it quite difficult to do. Once it was in, though, the door worked perfectly. My question: does anyone else have the problem with this hinge wire being difficult to remove and replace? Thanks Brandon Kearbey | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "HERB" N52BK . /| / | Brandon Kearbey 99% . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Subject: Trailer....maybe?
Date: Jul 26, 1996
I may have a deal for someone on a damaged trailer that I used for my Kolb FS2. Here's the sad story. Had a thunderstorm blow the trailer over and since it was insured, got the estimate to repair and it was about the same price as I quoted as cost. Right now it's not pretty but can be fixed up and is still road-worthy. The insurance guys are going to buy me a new "same-as" trailer and will probably want to wholesale or scrap the damaged one. So, here is your chance to speak up if you need a useable trailer (they'd probably go for about $500 or less if it was offered to them). Specs are as follows (I built it so it wasn't too pretty to start with): Frame is 2 in x 3 in box steel welded and triangulated with members of the same size. Length is about 32 ft interior and perhaps 38-39 ft total. The cage is made of 1 in x 3 in box steel, also triangulated. The sides are .032 aluminum sheet and the top is .062 aluminum sheet. The front of the enclosure slopes forward and wraps downward to form an aero wedge (hard to explain). The sheet has some small tears and is wrinkled (well, more like waved) in some places. The dimensions are 7 ft wide by 7 ft tall. Floor to ceiling is about 6 ft 10 in. The rear doors might have to be removed as they took some damage on the skins but the door frames look OK. There are four D-ring anchors in the floor for the main gear tiedown and I have welded two steel eye bolts in the ceiling to support the tail. I used a WIDE nylon tow strap wrapped several times around the fuse tube and used carabiners on the ends of the strap to latch into the eye bolts. Works nicely and keeps everything riding smoothly. There are two axles, one 2000# and one 3000#. Tounge weight is about 180#. Hitch is 2 in ball. Tires are the small trailer type to keep the floor height close to the ground for loading ease. If interested, let me know and I'll see if the insurance guys want to deal (or wait, for that matter). As for me, 12 weeks to get the new beast. Cheers, Jim Baker Oklahoma City 405-733-3823 ________________________________________________________________________________
Date: Jun 10, 1996
Hello all, > I would like to conduct a little survey. > The flying club I am a member of does not want to put > a ballistic chute on the Kolb Mk III we're building. > Some of the members have experienced engine out emergency landings > in other types of experimental aircraft. The most recent was a club > member flying a Avid who had a gas leak, ran out of gas, and landed > on the grass median of I90 in upstate New York. The police fined him > $100. I am wondering what percentage of Kolb's (all types) now > flying do not have a ballistic chute. If you want to email me any > info you have, I will summarize the results. Any other opinions you > want to add are welcome and I will try to summarize them as well. We decided not to put a chute on our kolb. Nor do we have one on our quiksilver. If your engine goes out I would much rather have control of the aircraft than let it float down. We also do not fly over an area where we cannot land reasonably safe without an engine. I wouldn't want to fly in a plane that I questioned its structural integrity either so why should I put a chute on it? I know there are pros and cons. One con is the cost of the chute and then the repacking. Thats my 2 cents and info for your survey. Brandon Kearbey | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "HERB" N52BK . /| / | Brandon Kearbey 99% . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Date: Jul 26, 1996
> >We decided not to put a chute on our kolb. Nor do we have one on our >quiksilver. If your engine goes out I would much rather have control >of the aircraft than let it float down. We also do not fly over an >area where we cannot land reasonably safe without an engine. I >wouldn't want to fly in a plane that I questioned its structural integrity >either so why should I put a chute on it? I know there are pros and cons. >One con is the cost of the chute and then the repacking. Thats my 2 >cents and info for your survey. > (Please note: When I say "you" in the following paragraph, I am referring to the collective "you" (including myself), and not Brandon specifically.) I definitely agree that if it is at all possible, it is much more preferable to fly a controlled forced landing than to become a passenger with no control whatsoever. If you always fly where you have a potential landing spot, a 'chute becomes less of a priority. Unfortunately, some people live in areas where this is not always possible 100% of the time. However, it is possible that a structural failure can occur in flight. It may not have anything to do with the quality of the aircraft but rather extreme weather conditions and/or unintentional high g-force loading, or a mid-air collision. Of course, careful flight planning, good judgement, and alert piloting can eliminate or at the least, drastically reduce those factors. Consider that the vast majority of GA aircraft don't have chutes, and still the fatality rate of flying is much lower than for other travel or recreational activities. I equate chutes to states without motorcycle helmet laws. You can ride with or without the helmet, your prerogative. You could probably ride for a long time (if not your whole life) without any injuries, but it only takes one incident, and when (if) that happens, you'd be mighty sorry you weren't wearing that helmet. Most GA aircraft are too fast and heavy to make a chute practical. Ultralights have an option that most aircraft don't! Personally, I will take the 'chute, and hope I never need to use it. Nothing would make me happier than to "waste" that money. $1,000-$1,500 sounds like a lot of money, (and it is, for me anyway), but, I immagine it would sound very small indeed when mother earth is spiraling up to meet your soon to be ex-body... -Jon- .------------------------------------------------------------------------------. | Jon Steiger: DoD# 1038, EAA #518210, USUA# A46209, NMA# 117376, KotWitDoDFAQ | | stei0302@cs.fredonia.edu && http://www.cs.fredonia.edu/~stei0302/ | | '96 Dakota SLT V-8 Club Cab, '91 FZR600R /* Just another mangy hacker */ | `------------------------------------------------------------------------------' ________________________________________________________________________________
Date: Jul 26, 1996
Subject: Chute
I feel the same as Herb about the chute. If I had a choice of flying my aircraft into tennis court uncontrolled or into a football field controled but without power.... well you can guess the answer. Todd:) ________________________________________________________________________________
Date: Jul 27, 1996
Subject: Firestare II Building Comments
I have been reading the E-mail supplied by my friend Mark Brinkmoeller regarding the Kolb builders group. After summing up the comments so far over the last few months, I would like to add some hints to you all. I just completed a Firestar II including a three color paint job in 286 hours and without a divorce. 1) Study the drawings and manual as Kolb suggests. Begin acquiring tools and organizing your work place. Try and work on your project on a regular basis to retain cohesion. 2) Definitely invest in an air compressor, pneumatic riveter, and spray gun. All these are hot items of the used tool market so you shouldn't have trouble selling them after the project is finishes. 3) Definitely invest in the pro-made rib option. 4) Make copies of the plans for all gussets and rubber cement them to the aluminum sheet stock supplied. Take the layout to a sheet metal shop and have them cut on a shear. All my gussets were done for $20.00 and all we re perfect. You can also gang drill them at the same time. 5) Cut a 3' x 4' piece of plywood or foil insulation and take all your hardware packages to it with the nomenclature facing out. Catagorize washers, nuts, bolts, etc. in rows. 6) I rigged up a 1750 rpm motor with a 8" abrasive discs at one end and a abrasive flapper wheel at the other to cut, grind, debur and polish parts all in one tool in one location on the workbench. 7) For multi hole drilling of parts such as hinges and tubes, make your layout on masking tape then transfer the tape to the part for center punching and drilling. This method is especially handy on 5" round tubes and f illings. 8) Before painting fuselage tube, mask of 3/4" on each end to avoid adding to the already tight o.d. This will eliminate sanding it back off when you need to fit and refit things. 9) When rigging the wings I used 4 plumbers levels taped to the midway point of the leading and trailing edges of the wings near the lift strut locations. Then mason's lines on the horizontal planes and back to the verti cal stabilizer. You then have all dimensions covered at one time to make corrections in the rigging. 10) Fabric cover the aileron tubes all the way to the inboard ends so the gap seal will have a more compatible surface to adhere to. 11) I am building a trailer at present and may pass on some info on that if it's worth it. I hope some of these items are helpful. Now all I need to do is learn to fly the machine. Sincerely, Jim Schantz Lodi, Wisconsin 608-592-3543 (Comments and replies will reach me through jmbrink(at)ix.netcom.com) ________________________________________________________________________________
Date: Jul 28, 1996
Subject: FIRE FLY FOR SALE
HI Guys and Gals: A change in my plans Will allow someone to Jump three months ahead of everyone else when trying to buy AND BUILD a Kolb fire fly !!! I have the following for sale . Kolb Fire Fly-- Kit #1-- Wings and Tail Kit. Vertical stab completed, Horizontal stab completed, Rudder and elevators completed. Kit #3 Airframe kit. Fuselage and remainder brake option. Fuselage and all 4130 parts painted All plans and manuals with addendums. Can be inspected and picked up at Watseka, Illinois 5,600 Dollars Tell all of your friends THANKS CLARK WOCKNER 1200 W. SMITH ST. WATSEKA , ILL 60970 PH# (815) 432-3507 ________________________________________________________________________________
Date: Jul 28, 1996
Subject: Fire fly wanted
HI Again: About one week ago someone wanted a fire fly. I did not save the e-mail message. Does any one know who it was and would you give me his E mail address?? THANKS CLARK ________________________________________________________________________________
Date: Jul 29, 1996
Subject: Fiberglass
Hello, I have used some stuff called "Marine-Tex" for putting in the pitot tube and some other things in the fiberglass nose fairing. The stuff works well and dries very strong. It is also sandable. I have found it useful for several applications such as the pitot tube in. You can get it at a boat supply store. Its just a tip it you choose to use it. Brandon Kearbey | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "HERB" N52BK . /| / | Brandon Kearbey 99% . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Date: Jul 29, 1996
Subject: lexan
What is the best way to clean dust and other things of the lexan without scratching it? | - - - - Kolb []-| - - - - Mark III .====== | - - - ___ "HERB" N52BK . /| / | Brandon Kearbey 99% . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Date: Jul 30, 1996
Subject: Re: lexan
>What is the best way to clean dust and other things of the lexan >without scratching it? On glider canopies, on airplane plastic windows, we used a commercial cleaning compound and *Bounty* paper towels. On my plastic (but coated) glasses, I've used ordinary Windex and that same brand of paper towel--on advice from my optometrist. For the latter, I keep the Bounty towels, torn to a convenient size, scrupulously clean in a zip-lock bag, since dust on the towel would be like sandpaper. The Bounty brand is said to be the only paper towel soft enough not to scratch the plastic. I suppose it would work for lexan. I don't think I'd get carried away with rubbing, however. Others use soft cloths, and this is probably better yet, *if* the cloth is clean. You can also buy cleaner made for this purpose. Forgot the brand. Old fashioned soap and water, and a cloth, are probably best to get off most of the stuff first, taking care not to scratch the plastic. Other ideas will probably be forthcoming. Grit on the window probably includes much feldspar and quartz--hardnesses 6 and 7 on the Moh scale. Window plastic is what? Maybe 3 at most? Don't rub the grit against the plastic! Tom Rampton ________________________________________________________________________________
Date: Jul 30, 1996
Subject: re: lexan
I use something called Rainx and paper towels on my car windshield. It cleans off dirt and leaves some sort of plastic coating on the windshield so rain runs off easily. I almost don't need the windshield wipers anymore. You have to wipe this stuff on about once a month. I'm pretty sure it will work well on Lexan also. chuck(at)kronos.com ________________________________________________________________________________ by SERV05.SLAC.STANFORD.EDU (PMDF V5.0-6 #10979) id <01I7OAMPVK4M001HGM(at)SERV05.SLAC.STANFORD.EDU> for kolb(at)hpmail2.ftw.mot.com;
Date: Jul 30, 1996
Subject: take me off the auto. mail list
how do I cancel the mail being directed to my address re:Kolb? ________________________________________________________________________________
Date: Jul 30, 1996
Subject: re: lexan
Chuck, >I use something called Rainx and paper towels on my car windshield. >It cleans off dirt and leaves some sort of plastic coating on the >windshield so rain runs off easily. In the "for what it's worth" category --- There are some plastics that Rainx has ruined. Several motorcycle people have made mention of the fact that their windshields were ruined when they used Rainx. Honda Goldwing windscreens particularly come to mind and only some of them. That being the case, you may wish to test it on a small windshield section to start. Don't have to clean the windshield of my Ultrastar. :) Regards, Skip Skip ________________________________________________________________________________
Date: Jul 30, 1996
Subject: re: lexan
> I use something called Rainx and paper towels on my car windshield. > It cleans off dirt and leaves some sort of plastic coating on the > windshield so rain runs off easily. I almost don't need the > windshield wipers anymore. You have to wipe this stuff on about once > a month. I'm pretty sure it will work well on Lexan also. Yes I use that on my car also, but will it keep dust off. I think I might try some on some scrap pieces to make sure nothing happens! Thanks for idea, Brandon Kearbey Kolb | - - - - Mark III []-| - - - - N52BK .====== | - - - ___ "HERB" 99% done . /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 Kolb | - - - - Mark III []-| - - - - N52BK .====== | - - - ___ "HERB" 99% done . /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Date: Jul 31, 1996
Subject: Re: lexan
Try a product called Protect All. It is used mainly by RV and Aircraft industry. Was orginally developed for aircraft and since gone to RV and cycles. Has UV blockers, anti-static type dust repellent and was originally made for aircraft windshields. I know you can buy it at large RV supply stores. If you have any questions about it call the company @ 800 322-4491 or 714 635-4491. I found out about Protect All several years ago and used it on my RV, glasses, car, monitor screen, etc etc. Use only a very small amount at a time. It makes things very slick!!!! .... and seems to last a long time. I hope some day to be using it on my Kolb. I am new to UL so have enjoyed reading info on aol. Hope to find used Firestar some day. Larrry Taylor LTaylor CB(at)aol.com ________________________________________________________________________________
Date: Aug 02, 1996
Subject: tid bits
Hi Kolb builders/flyers: The list is a little sleepy so i thought I'd toss in a little bit of my doings. A couple weeks ago I went flying for a good part of Saturday and Sunday. On the way back into my home area I saw a large disked field with 3 dust devils churning up in the afternoon heat. I'm in the Sacramento valley, and this afternoon was about 105, which is not uncommon. Having toyed w/ thermals a little in the past, i headed right for the biggest of the dust devils. I entered it at 1000'AGL and backed off to 3400 rpm, and circled at 35-40mph. I stayed here quite awhile, maybe about 5-8 minutes. Although not spectacular, i continually gained altitude, and decided i'd had enough at 3000'. Interestingly, I noticed that there were a lot of swallows that seemed to be riding the thermal as well. Another fun thing i did was a variation on an exercise given to me during my early UL training. That is, to fly the plane at minimum flying speed right along the runway, usually with wheels skipping about half the time. The challenge exercises all 4 control inputs: rudder,elevator,aileron, and throttle. The variation, which was partly just luck, was that I got the tailwheel to ride smoothly along the strip for several seconds without the mains touching. This is impossible if it is a little gusty, because you obviously can't predict the changing wind. But it's possible in steady air and nets the same satisfaction as doing a tight 360 turn and hitting your prop wash as you come around. (Be advised i'm not suggesting anyone do dramatic high incidence angle wheel stands.) Last weekend i did some maintenance stuff. The main thing i went after is the where the wing attaches at the rear U-joints to the fuselage. On pre-flights i had noticed that the castle nuts were not quite tight enough, allowing the rear of the wing to click up or down -- not much (1/8"?) -- but enought to seem sloppy. I think paint had worn off the U-joint since new, creating the looseness. I took the wings and U-joints off, which was good to do just on general inspection principles. I then thinned down a new set of washers for the U-joints to a thickness that allows the U-joint castle nuts to be tightened to the perfect tightness AND have the cotter pin meet its hole. I also greased areas where the paint had worn off. happy landings everybody. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Firestar KXP Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Aug 03, 1996
Subject: other tib bits
Greetings all, Thanks for refueling my enthusiasm Ben. Monday will be 16 weeks of waiting for my SlingShot kit :-( I am, however, organizing a small commando raid on the factory to at least visit my kit. It will happen the week of the 12th when I'm up in PA serving a one week in-law sentence. I just found out that I'm going to be scheduled for 4 weeks in Cleveland for training on a new machine we just sold. This should happen in the next 3-4 months just to agrivate my building schedule. There's even the possibility of another 5 week training class too. At least new equipment is job security. In other news, I got an info pack on Hirth engines the other day. On, paper, they have a few advantages over the Rotax. Unfortunately, some of those are unverified, and there are also some disadvantages. To me, Rotax wins the 50 HP contest, but if I were looking for a 65 HP engine (which I wish I could), the Hirth looks pretty good. Of course my favorite is their 4 cyl, 110 HP that weighs only 109 lbs. If I had $6500 to buy one, Dennis would have much cause for concern :-) Has anybody ever considered using a boat fuel tank? I really don't like the idea of using two 5 gal tanks together in the plane. I've been looking into finding a single tank to take their place and perhaps even add to the 10 gal capacity some. Boat tanks seem to come in quite a variety of styles, shapes, and capacities. At this point it's just something I'm considering. Another thing I'm thinking about, is making a small storage locker in the nose of the plane. If I can use one of the metal panel extensions like what Kolb sells in their "custom instrument" package, I'll have some free space behind the fiberglass panel that can be closed in. I wonder if I can attach the metal instrument panel with a full length hinge at the bottom and a couple of quick release attachments at the top. This would allow the panel to hinge forward allowing access to the storage compartment via a hole in the fiberglass instrument panel (like a glove compartment). This would kill two birds with one (elaborate) stone. First, I would have an out-of-the-way place to keep some misc items like a quart of oil, tie-downs, small canopy cover, a few tools, etc. Second, these items would be located far forward of the CG. I've been warned already that I either need to gain weight, or put something heavy in the nose. This would make productive use of the weight shift. I need to get the CG reasonably forward if I hope to carry more than 10 gal of fuel, and I have a good friend who weighs 20 lbs less than me (I'm 165, he's Stickman). I logged many hours in the Grumman that he recently sold and would like to return the favor since he's now planeless. Have fun with those dust devils. -- Russell Duffy rad(at)gulf.net http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Aug 04, 1996
Subject: 89 Firestar
Hi all, I am almost afraid to ask this question since I think I know the answer. I recently purchased a 1989 Firestar and have been flying it quite a bit. I had noticed that just under the engine recoil starter on the main steel tube of the fuselage is a dent of some sort. Also the tube itself seems to be bent a little. It almost looks like a kink that happened in the tube when the tube got bent. I looked at the blueprints and it did not show this tube. I have to assume that this happened from a hard landing which caused the weight of the engine to bend the tube, but it would seem to me to be strongest part of the plane and I can't imagine that being the case. I have been told by a new firestar builder that the dent is not there on his plane. Can anyone shed some light on this one? =============================== Scott Olendorf / Kolb Firestar Schenectady, NY =============================== ________________________________________________________________________________
Date: Aug 05, 1996
Subject: Re: 89 Firestar
On Sun, 4 Aug 1996 Olendorf(at)aol.com wrote: > I am almost afraid to ask this question since I think I know the answer. I > recently purchased a 1989 Firestar and have been flying it quite a bit. I > had noticed that just under the engine recoil starter on the main steel tube > of the fuselage is a dent of some sort. Also the tube itself seems to be > bent a little. It almost looks like a kink that happened in the tube when > the tube got bent. I looked at the blueprints and it did not show this tube. > > I have to assume that this happened from a hard landing which caused the > weight of the engine to bend the tube, but it would seem to me to be > strongest part of the plane and I can't imagine that being the case. I have > been told by a new firestar builder that the dent is not there on his plane. Hi Scott, Sorry to say but you are right, that tube should be straight. It is hard for me to imagine that it would bend from a hard landing unless the engine was something from maybe a Buick. I've seen a firestar that crash landed (power failure over lousy terrain), which tore off the landing gear, also tearing out and forward the ring which holds the front end of the fuselage tube, and bending other tubes in the lower aft part of the cage. I didn't look specifically at the top center tube, but i don't think it was harmed. I had also seen a firestar that landed 15 feet above the ground and was a mess from the nose back, and that tube was straight on this one too. (That plane, by the way, was being sold as parts but was rebuilt by a "keep-em-flyin RC" type in only 4 months and it flies all the time now.) I would say that you need more clues, and, unfortunately you may find them. In other words, it would be very difficult for this to be the only part of the frame to be damaged in any type of mishap. I'd look the whole frame over with a very good eye for splices, rewelds, cracked paint at joints, bends,etc. Even if the center tube is totally airworthy, it is cause to look for other possible demons. The one way i can see this tube getting bent with no other damage, is if maybe the engine was dropped on it from at least a couple feet up, or perhaps if the frame was dropped upside down during transport. Sorry for the bad news, but almost anything is repairable, and hopefully you will find that everything that needed repair on yours has been done well. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Aug 05, 1996
>Hi all, > >I am almost afraid to ask this question since I think I know the answer. Yes, you do. I would be afraid, also. >I >recently purchased a 1989 Firestar and have been flying it quite a bit. I >had noticed that just under the engine recoil starter on the main steel tube >of the fuselage is a dent of some sort. Also the tube itself seems to be >bent a little. It almost looks like a kink that happened in the tube when >the tube got bent. I looked at the blueprints and it did not show this tube. My 1988 FireStar does not have the bend. It is as straight as an arrow. > >I have to assume that this happened from a hard landing which caused the >weight of the engine to bend the tube, but it would seem to me to be >strongest part of the plane and I can't imagine that being the case. Imagine again. A VERY HARD landing could do it (such as a stall from 8 - 10 feet AGL) or someone may have simply dropped an engine on it while changing engines. I also have a question: what size engine are you using ? FireStars of that time were ONLY made for the Rotax 377 and there was MUCH reinforcement that HAD to be done to the airframe in order to fly it with a Rotax 447, 503, 582, etc. If you have a bigger engine than it was designed for that MAY be the reason for the "dent". More horsepower = more thrust bent airframe ???? In any case, I would STRONGLY URGE you to NOT fly it again until you KNOW EXACTLY what is going on and why and have corrected it. Dennis Souder (chief engineer and owner of Kolb Manufacturing) is on this list and I am sure he will help you with this. I talked with several Kolb people at OshKosh yesterday so he may not answer for a little while as the "big show" does not end until Wednesday, but please do not fly it until you have fixed what is wrong. Then again, what do I know ? I'm just one of those mangy television engineers. >I have >been told by a new firestar builder that the dent is not there on his plane. > >Can anyone shed some light on this one? > > >=============================== >Scott Olendorf / Kolb Firestar >Schenectady, NY >=============================== > > I hope this helps. Ray Abbruzzese E-Mail at: rabbruzz(at)unlinfo.unl.edu Lincoln, Nebraska, USA Standard Disclaimer: These are my opinions and you all know about opinions (they are like butts, everybody has one). I could be wrong and I probably am. Just please do not sue me. ________________________________________________________________________________
Subject: FW: 89 Firestar
Date: Aug 05, 1996
Depending on where this dent is you can guess on how it was caused. If it was caused from overstressing the dent would be on the compression side ie on the bottom if it were a hard landing or a prop strike on the up side of the rotation. If it is dented on top my guess would be somebody dropped something on it or maybe a prop strike on the down side of the propeller. You definitely need to talk to Dennis at Kolb before you fly any more. The other thing you need to do is follow and examine every tube welded to this piece to see if it has bent or pulled anything else out of line, keep in mind that it might not be the part directly attached to the bent part, but a tube two or three down the line that was deformed because of the stresses imposed. I recently had a accident where an uncovered wing was dropped and the trailing edge dented. It was amazing how much stuff got tweaked because of the slight dent and bend in that section of tubing. Call the person who sold you the plane and ask if they know how it happened, if it truly was a landing hard enough to bend the tube some other parts were probably overstressed also. >---------- >From: > Olendorf(at)aol.com@acuityinc.com[SMTP:Olendorf(at)aol.com@acuityinc.com] >Sent: Sunday, August 04, 1996 7:59PM >To: kolb(at)hpmail2.ftw.mot.com >Subject: 89 Firestar > >Hi all, > >I am almost afraid to ask this question since I think I know the >answer. I >recently purchased a 1989 Firestar and have been flying it quite a bit. > I >had noticed that just under the engine recoil starter on the main steel >tube >of the fuselage is a dent of some sort. Also the tube itself seems to >be >bent a little. It almost looks like a kink that happened in the tube >when >the tube got bent. I looked at the blueprints and it did not show this >tube. > >I have to assume that this happened from a hard landing which caused >the >weight of the engine to bend the tube, but it would seem to me to be >strongest part of the plane and I can't imagine that being the case. I >have >been told by a new firestar builder that the dent is not there on his >plane. > >Can anyone shed some light on this one? > > >=============================== >Scott Olendorf / Kolb Firestar >Schenectady, NY >=============================== > > ________________________________________________________________________________
Date: Aug 07, 1996
Subject: Protect All
Hello all, I went out and bought some of that Protect All that had been mentioned earlier and used it on the windshield and gap seal. The stuff works great! It really cleans the glass well. I would recommend it for cleaning the lexan. Brandon Kearbey Kolb | - - - - Mark III []-| - - - - N52BK .====== | - - - ___ "HERB" 99% done . /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Date: Aug 07, 1996
Subject: paint
I'm getting ready to paint the metal parts on my firestar II. I've been reading through the poly fiber manual, and they say use only Aero-thane paint and there epoxy primer. I can get Dupont polyurethane (Imron) paint and epoxy primer at cost, which would be a big savings compared to the cost of Aero-thane. Has anybody ever used a paint other than Aero-thane? Will it work? Cal ________________________________________________________________________________
Date: Aug 07, 1996
Subject: Wing rigging
Just a couple of suggestions to Kolb builders: When rigging the wings to the cage on Kolb airplanes, if the distance from the center of the main spar carry thru to the the main spar clevis pins are equal and the distance from the main spar clevis pins to the lift strut clevis pins on the wings are the same and the distance from the the main spar clevis pins and the lift strut clevis pins on the cage are the same both vertically and diagonally, the length of the lift struts must be the same. My measurements were within 1/8" and yet, even though the wings were level span-wise, my lift strut length meaurements differed by 1/2." I was using a 3 foot carpenters level always in the same direction with a lot of iteration. An analysis of possible errors showed that the 1/2" difference could be accounted for within the reading error of the level and the plumb bob! The moral of the story is: trust a tape measure more than an ordinary level. I made my lift struts the same length. Another tip. don't drill the main spar clevis pin holes full size at the same time or you will end up with a sloppy fit. Drill 1/8" first thru all members (both fuselage tangs and the wing tang), then final drill each separately. I actually predrilled the fuselage tang holes and drilled the wing tang last. HFritze ________________________________________________________________________________
Date: Aug 08, 1996
Subject: Re: Wing rigging
When I was growing up, my father made a level using a length of garden hose with glass tubes stuck in the ends. He filled the hose up with water and you could see the water level(s) through the glass tubes. It seems to me that you could use a similar level for doing things like getting your wings level from the center out to the tip. If this is old hat to everyone, forgive me for pointing out the obvious. I have yet to start building anything, let alone a Mark III like I intend to end up with... -- Don (snip) >Just a couple of suggestions to Kolb builders: >An analysis of possible errors showed that the 1/2" difference could be >accounted for within the reading error of the level and the plumb bob! >The moral of the story is: trust a tape measure more than an ordinary >level. I made my lift struts the same length. (snip) > >HFritze ________________________________________________________________________________
Date: Aug 08, 1996
Subject: Re: paint (fwd)
On Wed, 7 Aug 1996, CAL wrote: > I'm getting ready to paint the metal parts on my firestar II. I've > been reading through the poly fiber manual, and they say use only Aero-thane > paint and there epoxy primer. I can get Dupont polyurethane (Imron) paint > and epoxy primer at cost, which would be a big savings compared to the cost > of Aero-thane. Has anybody ever used a paint other than Aero-thane? Will it > work? When I faced this I was told that epoxy primers are not much different. One distinction however, is the chromate epoxies that are sold for aircraft priming. I guess these offer superior corrosion resistance, especially (or maybe only) for aluminum parts. I can't even remember what I used, but I think it was from a local auto and crop duster paint supplier. I trusted the vendor and went with his recommendation. As for Dupont, I would think that's top quality stuff. The Avid or Kitfox show plane is Imron as are many non-fabric homebuilts. For me, I used Stits Polytone so didn't have to deal with the very stringent safety and quality requirements of polyurethane. Have fun. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Aug 09, 1996
From: Cliff & Carolyn Stripling <striplic(at)flash.net>
Subject: Re: paint
>On Wed, 7 Aug 1996, CAL wrote: >> I'm getting ready to paint the metal parts on my firestar II. I've >> been reading through the poly fiber manual, and they say use only Aero-thane >> paint and there epoxy primer. I can get Dupont polyurethane (Imron) paint >> and epoxy primer at cost, which would be a big savings compared to the cost >> of Aero-thane. Has anybody ever used a paint other than Aerothane? Will it >> work? I am kind of a "duh" as concerns paint and painting, but I can tell you of the experiences I have heard about or had happen on my project as concerns the Stits products. If anyone out there knows better, please correct me. Their Polytone system went on my plane just as the Stits manuel said it would. Some guys had trouble with adhesion over the epoxy chromate if they did not get the Polytone or Aerothane sprayed on before the epoxy got dry (like within 30 minutes) or did not sand the surface (or sand it well enough) of the epoxy chromate if allowed to cure before applicaton. I used the overspray before completely dry method on all of the painted metal parts I could. Sure is easier than sanding and I think made a better bond anyway. I even tried rolling on the Polytone with the fine celled foam rollers now available. It saved me from having to tape and mask off all of the inside areas of the plane that I did not want to get overspray on. It worked nicely on the fuselage fabric. You can only tell that it was rolled by looking at the light transmitted through to the inside while looking from the inside. You can see the roll lines. From the outside, the lines are not visible. Something I tried that will NOT work is rolling on the Polyspray. It leaves tiny bubbles that do not pop and they dry to a rough surface. I also used the reducer that evaporates slower. I was told that it is the same as adding retarder to the more volatile formula. That saved me some money and it gave me a nice shiny finish. Questions I would ask myself about the Imron. Is the epoxy primer dissolved by the Polytack cement used in application of the Polyfiber cloth? (probably not) That can make an unholy mess when applying the fabric. Is the Imron flexible enough to not crack and peel on the fabric surface? Talk about ruining your day. Did you watch the Stits video showing how some polyurothanes cracked and peeled off the fabric? You may also consider the flamability of the Imron. In the video, there was a lot of time spent in comparative burn tests. Check it out. Supposedly Aerothane has that quality. I am not sure about Imron. I put Imron on a fiberglass Quickie I built and it was beautiful and durable, but that was a hard surface you can't punch your finger into. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Aug 09, 1996
Subject: Weight & Balance
Hello all you happy Kolb builders. Our MarkIII is 99 9/10 finished!! But we did the weight and balance today. Even with 25 lbs. of shot in the nose and a 150 lb pilot the cg was still at 33%! I talked with a couple of Kolb pilots at Arlington Air show and they said that one had to put weight in the nose of all Kolbs to be pitch stable. My questions are: To those flying MarkIII's, where is your particular cg and do you put weight in the nose? Is it really stable at 33% or not? Should I fly it at 33% knowing it will only get better as the fuel burns off or should I stuff more weight in the nose. Of course, I could always get longer battery cables, I suppose, and stuff the battery in the nose. I don't really like that idea though! I hope Dennis is listening and will respond to me (us). I hope that some of you have experience with this and can comment also. Bob ________________________________________________________________________________
From: Robert Heydasch <Heydaschr(at)worldnet.att.net>
Subject: Re: paint
Date: Aug 10, 1996
> > I'm getting ready to paint the metal parts on my firestar II. I've >been reading through the poly fiber manual, and they say use only Aero-thane >paint and there epoxy primer. I can get Dupont polyurethane (Imron) paint >and epoxy primer at cost, which would be a big savings compared to the cost >of Aero-thane. Has anybody ever used a paint other than Aero-thane? Will it >work? >Cal > > Hi Cal: I am just about ready to order a Firestar 11 kit and I'm not an expert but I have done a little reading on kitbuilding. In his book, "Kitplane Construction", the author does not recommend mixing processes in any manner. There is a possibility that the chemicals used in the Dupont product would not be compatible with the Stitts chemicals if you went with the Stitts covering process. Personally, I will go with Stitts all the way. Good luck with your project! Bob Heydasch HeydaschR(at)worldnet.att.net ________________________________________________________________________________
Date: Aug 10, 1996
Subject: Re: Weight & Balance
Bob and all... I think the tendency toward aft CG (esp. solo) has been known for some time. Pardon me if I am wrong and correct me if so but (from memory) in the literature of the construction manuel doesn't it say that the design weight was for a 180 lb pilot (and I assume the same weight for the passenger) and that if you are light (say 150 more or less) that you should (or might have to) carry some nose ballast (especially single place & full tanks)?. I am sure all side-by-side designs with the seating in front of the normal CG range and fuel behind it have the same tendency to be tail heavy in some loading configurations. I talked about this with Homer Kolb last year before I started construction and asked him if cutting off up to 3.5" to 4" of fuselage tube (which I had read that others had done and which I did) would be OK to possibly help that situation. I am 155 lbs. and was concerned about the aft CG. Elsewhere in the literature (a newsletter I think, but I am not sure) I read that shortening the fuselage tube could cause instability in flight characteristics and perhaps was not a good idea. I certainly did not want that to happen. Mr. Kolb indicated to me that it would be OK to shorten the fuselage up to that amount, but probably no more. No one wants to add unnecessary weight to their plane, but at least the payload of the Kolb will allow for the added ballast. I hope I will not have to add it to mine. I have done preliminary weight and balance and I think that I will be within limits. The lack of "C" gear box ("B" box instead) and electric start (each behind the CG) helps in my case. In addition to shortening the fuselage, I also clipped the wing tip bow the same distance so that folded the wings would not stick out beyond the tail, but that is a whole 'nother story. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Aug 08, 1996
Subject: Re: paint
On Wed, 7 Aug 1996, CAL wrote: > > I'm getting ready to paint the metal parts on my firestar II. I've > been reading through the poly fiber manual, and they say use only Aero-thane > paint and there epoxy primer. I can get Dupont polyurethane (Imron) paint > and epoxy primer at cost, which would be a big savings compared to the cost > of Aero-thane. Has anybody ever used a paint other than Aero-thane? Will it > work? > Cal I strongly urge you to look into powder coating for all uncovered metal parts, especially the fuselage cage. I painted about half the steel parts myself before finding out about powder coating and wish I had found out about it sooner. It came to about $250 for everything. Considering all the time involved in cleaning, mounting, spraying etc, the choice was a no-brainer. The shop had thousands of colors available and there was no problem matching the Stits color I chose. I did do the tail boom myself because it is fairly easy and transporting it to the powder coating shop was problematic. I would expect the Dupont products to work well. Just do as the manual suggests and make sure it won't be hurt by the fabric glue before you proceed very far. For best results, spray the color coat while the primer is still tacky. _-_ _,, ,, -/ ) ; || ||_< \\/\/\ _-_ ||/|, _-_ ,._-_ bweber(at)micom.com || \\ || | | || \\ || || || \\ || ;/--|| || | | ||/ || |' ||/ || Keep the shiny _--_-' \\/\\/ \\,/ \\/ \\,/ \\, side up ( ________________________________________________________________________________
Date: Aug 10, 1996
Subject: Re: Subject: Re: Weight & Balance
Bob and all... I think the tendency toward aft CG (esp. solo) has been known for some time. Pardon me if I am wrong and correct me if so but (from memory) in the literature of the construction manuel doesn't it say that the design weight was for a 180 lb pilot (and I assume the same weight for the passenger) and that if you are light (say 150 more or less) that you should (or might have to) carry some nose ballast (especially single place & full tanks)?. I am sure all side-by-side designs with the seating in front of the normal CG range and fuel behind it have the same tendency to be tail heavy in some loading configurations. I talked about this with Homer Kolb last year before I started construction and asked him if cutting off up to 3.5" to 4" of fuselage tube (which I had read that others had done and which I did) would be OK to possibly help that situation. I am 155 lbs. and was concerned about the aft CG. Elsewhere in the literature (a newsletter I think, but I am not sure) I read that shortening the fuselage tube could cause instability in flight characteristics and perhaps was not a good idea. I certainly did not want that to happen. Mr. Kolb indicated to me that it would be OK to shorten the fuselage up to that amount, but probably no more. No one wants to add unnecessary weight to their plane, but at least the payload of the Kolb will allow for the added ballast. I hope I will not have to add it to mine. I have done preliminary weight and balance and I think that I will be within limits. The lack of "C" gear box ("B" box instead) and electric start (each behind the CG) helps in my case. In addition to shortening the fuselage, I also clipped the wing tip bow the same distance so that folded the wings would not stick out beyond the tail, but that is a whole 'nother story. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Aug 11, 1996
To Brandon and all... I know that Kolb put a 912 on theirs and what did they have to do to >make it flyable? Except for the added weight ballast (not sure how much, but it was attached to the forward most part of the fuselage frame up in the nose cone) I don't think they did anything else. I know you talked about shortening the boom a >couple of inches but that is a little late to do now! ...(actually it was 4") and I might add - certainly un-necessary and also not recommended by Kolb. Our concerns are >if the plane is easily flyable at 33%. This 33% was with a 150 lb pilot > and 25 lbs in the nose. I just pulled out Page 42 of the Kolb manual and it states the percent CG range should be: greater than 20% and less than 37%. I have heard or read elsewhere (recorded as pencil notes in my manual margin) that the aft conservative range is 35%. If your's is 33% (150 lb pilot solo, full fuel + 25 lbs in the nose), isn't that well within range at maximum aft loading including nose ballast? Why not give Kolb a call and discuss it with Dennis. While you have him on the phone, ask him about the 912 installation and what they did if anything except add nose ballast. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Aug 11, 1996
Brandon and all... >Well, we are just down to the details! Going over every inch >tightening and adjusting. We are very close! It'll be about 400 >hrs. and we are just approaching 4 months since kit 1 arrived. Wow! What progress!!! In the excitement of the first few hours, don't forget the guys here on the list. It would be great to hear reports of your first flights. You may already have this advisory circular by the FAA, but if not get the AC-90-89 Amateur-Build Aircraft Flight Testing Handbook. Later, Cliff & Carolyn Stripling He - Kolb MK III builder (98%) - N582CC striplic(at)flash.net She - Dallas Re-Max residential real estate Both - R/V travel enthusiasts ________________________________________________________________________________
Date: Aug 11, 1996
Subject: Weight and balance
I'm building a Firestar II. I got out the old "Airplane Aerodynamics" book by Daniel O. Dommasch et al (fourth edition 1967, Pitman Publishing). On page 446 in the chapter on "Longitudinal Stability and Control" is a formula for calculating the Neutral Point of an aircraft. This is the point where the longitudinal stability is neutral (fixed controls). For the Firestar II the calculated Neutral Point is at 37% of the mean aerodynamic chord (about 23 inches of the 62 inch average chord). This calculation was based on the following values: Wing lift curve slope = 0.1 Taper ratio = 1.0 Aspect ratio = 5.3 Chord = 5.17 ft Tail length = 12.8 ft (quarter chord of wing to hinge line of H-tail. Wing area = 142 sq ft H-tail area = 18.4 sq ft The 37% calculated value compares nicely with Kolb's recommendation for max aft cg. Things that make n.p. worse: lowering aspect ratio (clipping wings), shortening tail length, decreasing H-tail area. Cordially H Fritze ________________________________________________________________________________
Date: Aug 12, 1996
I shortened my fuselage by 3.5" for the w&b issue, as I am 150-155. As I recall, this 3.5" moment arm pretty much offsets the 180-155 difference in pilot weight. My operating CG comes out something like 4% points away from the aft limit. (Firestar KXP w/ 447). To me, a 3.5" shorter fuselage meant better W&B for me, and if anything, just a slightly more zippy tail control ...sounds kinda fun. I haven't flown any other Firestars so can't compare stability, but I can say that mine has no stability problems. Kinda wish i had made my wings 3.5" shorter too, as that space would be very handy in my garage to squeeze around the back of my plane. At the time i was unwilling to tamper with the wings, as i felt that would be a different airplane. 3.5" off of each means a 7" shorter wing span and different wing ends, both of which are fairly important in stall/spin characteristics). If anybody else has shortened the wings on any of the Kolbs, it would be good to hear about perfermance characterstics. --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Aug 12, 1996
Subject: Re: Wt&Balance
One more thing ... Obviously, the advice to shorten the fuse' tube is late for anyone 99.9% finished. The practical, possibly too obvious thing to do is simply to put a seat pad behind your back, moving your 150 lb bod forward 3". I'd do that before adding more ballast to the nose. Or ...what about using a 3 foot Iron pitot tube and helium in the tail feathers? :) --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Aug 12, 1996
Subject: nude Firestar
I've had to move to a different airport (due to our former field closing - after 70 years!) and the Firestar is now in an open T-hangar with no door. It's now uncovered, but I would like to keep it covered (due to blowing rain, bird "bombs", etc.) Does anyone know of a cover cut specifically for the Firestar (so I can eliminate the plastic tarpaulin routine)? I will be very grateful to know the manufacturer, phone number, or whatever, if such a covering system exists. Thanks for any help you can give! Happy landings, Phil ________________________________________________________________________________
Date: Aug 13, 1996
Does anyone know of a cover cut specifically for the Firestar (so I can eliminate the plastic tarpaulin routine)? I've had to move to a different airport (due to our former field closing - after 70 years!) and the Firestar is now in an open T-hangar with no door. It's now uncovered, but I would like to keep it covered (due to blowing rain, bird "bombs", etc.) I will be very grateful to know the manufacturer, phone number, or whatever, if such a covering system exists. Thanks for any help you can give! Happy landings, Phil ________________________________________________________________________________
Date: Aug 13, 1996
Subject: C.G range
To Kolb Builders, When we installed the 912 we simply added some weight (about (20 lb.) in the nose and went flying. We then started removing the weight gradually and wound up eventually removing it all. We thus wound up with a C.G. at 40% with our flight instructor (who weighs about 170 lb.). To our amazement the Mark-III still stalls fairly well. This is how we are currently flying our own Mark-III. The Mark-III has been certified in England and they tested the C.G. as far back as 39% and found that it still had adequate stall characteristics. At 35-37%, all Kolb aircraft have good stall characteristics. Even though we know the C.G. can be further back than 35%, we will be officially leaving it at 35%, the margin is to absorb a certain amount of scale error. Eventually we will be exploring even more aft C.G. conditions. Our large chord wing and large tail volume, would seem to help in handling a more aft C.G. condition. If anyone has any further questions on C.G. please feel free to ask. Sincerely, Dennis L. Souder President, Kolb Aircraft ________________________________________________________________________________
Date: Aug 15, 1996
Subject: trim
I was at oshkosh this year and I saw firestar II there, (the guy did a beautiful job) that had electric trim on the rudder and the elevator. Has any one here put them on? Do you think it's needed? Oh yeah, I painted my metal parts with Imron I'll let you know what happens when I cover it. Cal, ________________________________________________________________________________
Date: Aug 15, 1996
Subject: Re: door hinges
> I saw a picture in EAA Experimenter where the piano wire was placed > in the chuck of a hand held electric drill & I guess, drilled into > the hinge. Seems like it would work. Let us know if you try it. Yes, I tried it but I was taking out the wire. It worked very well. Thanks for the tip whoever put it up a few weeks ago. Kolb | - - - - Mark III []-| - - - - N52BK .====== | - - - ___ "HERB" 99% done . /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Date: Aug 16, 1996
Subject: Hi !
Hi all, new to your list, new to building ultralight aircraft, FireFly is to arive today. Any comments? or help? Have built full scale before. Jeff FL. harley(at)gte.net ________________________________________________________________________________
Date: Aug 16, 1996
Subject: paint
Hi all, Jeff here. Can anyone offer advice on painting the frame,type paint,primer? Not being cheep here but there are lots of good paints. Thanks harley(at)gte.net ________________________________________________________________________________
Date: Aug 16, 1996
Subject: Re: Hi !
> >Hi all, new to your list, new to building ultralight aircraft, >FireFly is to arive today. > Any comments? or help? Great! Another FireFly builder! :) (Well, I'm not a FireFly builder yet, but I hope to be soon.) :) At Oshkosh this year, I finally got to sit in the FireFly and get a good look at it in the flesh. I like it even more now... :) Its a good thing I was already determined to build this kit, because between that and the ride I got with Dan in the Mark III, I'd have a hard time convincing myself not to go for it. :) Anyway, after seeing the FireFly, I had a few questions, most of which I thought of after I left Oshkosh and most of which I have forgotten by now. :) They keep cropping up though, so maybe I'll write them down or something... I noticed that the instrument panel is on the small side. There's not a whole lot of room there, but I noticed that SkySports sells an instrument that is about 3" (I think) which is a combination of 3 or of 4 instruments in one. (You choose the instruments, and they custom build it) I was thinking that this might be great for EGT, CHT, fuel, and perhaps VSI (if possible). That would free up a whole lot of room so that I can make the more important instruments bigger, and in more prominent positions. Anybody tried those combo instruments? On a related note, I'm having a hard time trying to keep my "instrument wish list" small... I'm betting that there isn't a whole lot of leeway for adding a bunch of heavy instruments. I do plan on using the BRS, so I'll potentially have a few extra pounds to play with there... What are the rest of you putting in your panels? My current plan is to have the altimeter and airspeed to be the biggest, and in positions where they can be easily read. EGT and CHT can be considerably smaller. I noticed that Kolb had the hourmeter on the engine, so that'll save space there. I think that does it for the "required" instruments. I'd like to have a fuel meter, though that isn't absolutely a must, just a nice convenience. Same goes for VSI. (hey, its Kolb! I want to know how fast I'm climbing!) ;) I guess I can just use the altimeter and my watch. :) Then there's the slip indicators, G-meters... See? There I go again! :) A compass would probably be a good idea though... As you can tell, I'm still pretty deep in the process of figuring out what I want to do... I guess I don't really have to worry about this stuff until it is pretty much done, but I would like to have an idea of what I'm building, and not making up stuff at the last minute.. (I still have no idea what the paint job is going to look like. I have no doubt that deciding that will be the most difficult part of the entire building process.) :) Speaking of which... Where can I get samples of the Stits colors available? (Not the actual paint, just a sheet with the color names, a patch of color, and maybe a part # or something) Does such a thing exist? Speaking of paint (and I guess this is related to another thread on the Kolb list), does anyone know what Kolb used to paint the metal parts of the FireFly? Whatever it was, it looked (and felt) great! I think I've tortured everyone enough... I'll just stop here. :) -Jon- .------------------------------------------------------------------------------. | Jon Steiger: DoD# 1038, EAA #518210, USUA# A46209, NMA# 117376, KotWitDoDFAQ | | stei0302@cs.fredonia.edu && http://www.cs.fredonia.edu/~stei0302/ | | '96 Dakota SLT V-8 Club Cab, '91 FZR600R /* Just another mangy hacker */ | `------------------------------------------------------------------------------' ________________________________________________________________________________
Date: Aug 16, 1996
Subject: Re: Hi !
> I noticed that the instrument panel is on the small side. There's not >a whole lot of room there, but I noticed that SkySports sells an instrument >that is about 3" (I think) which is a combination of 3 or of 4 instruments >in one. (You choose the instruments, and they custom build it) I was >thinking that this might be great for EGT, CHT, fuel, and perhaps VSI >(if possible). That would free up a whole lot of room so that I can make >the more important instruments bigger, and in more prominent positions. >Anybody tried those combo instruments? Jon, check out the EIS and SuperEIS from Grand Rapids Technology (multi-function displays designed especially for two-cycles). Also, Westach makes 3- and 4-instrument combinations in virtually any configuration. Westach: 707-938-2121 (ask for Roger Westberg), GRT: 616-531-4893 (ask for Greg Toman). Incidentally, these instruments and about 400 more are in an instrument panel layout software program called Panel Planner; for more info call me at 208-323-8724. Gordon Pratt Panel Planner Software Interactive Solutions, Inc. ________________________________________________________________________________
From: "bkearbey" <bkearbey(at)bcoe.butte.k12.ca.us>
Date: Aug 16, 1996
Subject: Re: Hi !
Hello, > I noticed that the instrument panel is on the small side. There's > not > a whole lot of room there, but I noticed that SkySports sells an > instrument that is about 3" (I think) which is a combination of 3 or > of 4 instruments in one. (You choose the instruments, and they > custom build it) I was thinking that this might be great for EGT, > CHT, fuel, and perhaps VSI (if possible). That would free up a > whole lot of room so that I can make the more important instruments > bigger, and in more prominent positions. Anybody tried those combo > instruments? Yes, we put the EIS in our Kolb and it works well. Other instruments that we put in are, Altimeter, Airspeed, Comm Radio, intercom. a Hobbs meter is included in the EIS so that is not necessary. You must be careful though. Even though things fit on the panel doesn't mean that there is enough foot room. Just plan things out first. > Where can I get samples of the Stits colors available? (Not the > actual paint, just a sheet with the color names, a patch of color, > and maybe a part # or something) Does such a thing exist? You can contact Poly fiber and get a color scheme. We got one from them. Sorry, I don't have the number but I bet someone here can give it out. Brandon Kearbey Kolb | - - - - Mark III []-| - - - - N52BK .====== | - - - ___ "HERB" 99% done . /| / | Brandon Kearbey . / | / | bkearbey(at)ben.bcoe. . \_______/ |-----------/-----| butte.k12.ca.us (_____________//----------------\^ / o ( )Http://www.geocities.com/CapeCanaveral/1041 ________________________________________________________________________________
Subject: RE: paint
Date: Aug 17, 1996
Andy,I would suggest powder-coating all the metal parts I could. We powder coat our motorcycle frames and it really work's well,it is very tough & is harder to chip than paint! It also comes in about as many different colors as paint. Franklin Hurst fhurst(at)ecsis.net ---------- From: andy[SMTP:harley(at)gte.net] Sent: Friday, August 16, 1996 7:17 PM Subject: Kolb-List: paint <> ________________________________________________________________________________
Date: Aug 19, 1996
Subject: Re: Hi !
>Jon wrote: > What are the rest of you putting in your panels? My current > plan is to have the altimeter and airspeed to be the biggest, and in > positions where they can be easily read. EGT and CHT can be considerably > smaller. I noticed that Kolb had the hourmeter on the engine, so that'll > save space there. I think that does it for the "required" instruments. > I'd like to have a fuel meter, though that isn't absolutely a must, just > a nice convenience. Same goes for VSI. (hey, its Kolb! I want to know > how fast I'm climbing!) ;) I guess I can just use the altimeter and my > watch. :) Then there's the slip indicators, G-meters... See? There > I go again! :) A compass would probably be a good idea though... > Remember, the Firefly is supposed to be FAR103. As you suggested, more than basic instruments and you might run out of weight, as well as room. At least most of the instruments are plastic featherweight anyway. For my money, i'm happy with the traditional instruments over the more expensive Grand Rapids stuff (okay, i'm a cheapskate). I've heard complaints regarding the traditionals compared to Grand Rap, but find the traditional quite adequate. My preference puts Airspeed 1st for visibility, and all other instruments (cht/egt, rpm, altimeter) can just be in logical, available space. In fact, I would classify altimeter as optional; nice to have but definetly optional. I'd buy a good compass before an altimeter. In fact i don't have a good compass; the one i had was too easily influenced by the nearby frame and impossible to calibrate. (any recommendations?) As for slip indicator, you could gluegun a 5" length of yarn to the windscreen. ...works well, and pretty light :] My preference on instruments for a UL are to stick with the minimums for safety, and develop that other almost forgotten one -- the seat of your pants. > building process.) :) Speaking of which... Where can I get samples > of the Stits colors available? (Not the actual paint, just a sheet > with the color names, a patch of color, and maybe a part # or something) I thought that that color chart maybe came with the kit? If not you can call a Stits dealer: Randy@ R&R (616)683-2594 (MI) -have fun! --------|-------- Ben Ransom (*) UCD Mechanical Engineering Dept. o o Email: bransom(at)ucdavis.edu http://mae.engr.ucdavis.edu/~ransom (916) 752-1834 ________________________________________________________________________________
Date: Aug 19, 1996
Subject: Slingshot news
Gretings all, The weather wasn't as good as I had hoped last week when I was in PA, so I didn't make it over to visit Kolb. I was afraid that I wouldn't get to do all the flying that I needed to get my tailwheel endorsement, and I had some computer duties to take care of at the in-laws house, so I really couldn't justify the 10 hour round trip from where I was. It looks like I'll be going to Cleveland for 4 weeks starting Sept 9th. I talked to Dennis today and it sounds like they could probably get me the first kit just before I leave, but the fuselage won't be ready until about the time I get back in October. By mutual agreement, we decided to wait until I get back and hopefully the full kit will be about ready to ship. I hate going to these training schools in Cleveland anyway, and it would be that much worse if I knew that my kit was sitting in the garage while I was gone. Hopefully, I'll get the whole thing toward the end of October and can actually start building. Dennis, if the plans and builders manual is finished, I'd love to get them before I leave so I can study in the hotel (for 4 loooong weeks). -- Russell Duffy rad(at)gulf.net http://www.pcola.gulf.net/~rad/ ________________________________________________________________________________
Date: Aug 19, 1996
Subject: Mark 3 weight and balance
Fellow Mark 3 builders, Just finished doing a weight and balance on my fat little bird. I went with the Rotax 582 with "c" gear box,72" 3 blade Ivoprop,BRS under the fuselage, full compliment of gauges and an intercom for pilot and passenger. Empty weight came to 496 lb. I took several weight measurements while I had the plane on the scales. I got numbers with myself in the plane, then added weight on the passenger seat and also with different amounts of fuel in the tanks.
March 07, 1996 - August 19, 1996
Kolb-Archive.digest.vol-aa
