Kolb-Archive.digest.vol-aj
December 07, 1997 - January 06, 1998
Both: 5th Wheel - RV - Travel
____________________|_____________________
___(+^+)___
(_)
8 8
Subject: | Re: Tail wheel system on the Kolb |
>Has anyone had experienced a tailwheel control chain or springs ever become
>unhooked.
I've not heard of it happening on the Kolbs. However, it is simple to just
squeeze the S hooks closed with a pair of pliers and I bet a fair number of
Kolb owners have done that. There is no disadvantage to doing so.
-Ben
Subject: | Re: VW Powered MK III |
At 12:41 AM 12/7/97 UT, you wrote:
>Hi Richard:
>I know a guy named Larry Bourne from Cathedral City, CA (near Palm Springs)
>who wants to install a VW on his MK III. I'm sure he would really enjoy
>talking or writing to you regarding your experiences. Will you share your
>address and 'phone number?? If so, I'll pass the data on to Larry who is
not
>on the net.
In a perfect world i'd prefer 4-stroke over 2, but as for a VW, I'd be
curious about the final weight and power coming from the VW. Seems like
you sure give away a lot of your useful load and climb rate by this option.
There i go, pushing 2-stroke again.
I myself looked briefly at 1/2 VW conversons thinking in terms of my Firestar.
Apparently you can pull 35hp out of them and w/ good effort that can be had
for equal or even slightly less weight than a 447. However, I guess
because of lower torque, all 35hp can only be done w/ a whimp prop. I have
not yet seen a dynomometer measured torque value from a 1/2VW for
comparison. I had gotten my info from Bob Moore (see his web page below).
He says the biggest prop he can use is 54x24 -- this on his minimax. For
comparison, i run 66x38 (Warp drive prop set at ~10.5 deg). There is some
really interesting VW and other 4stroke info info at:
http://wwww.win.net/~letsfly/4stroke.html
-Ben
Subject: | Re: Answer rough running 912 |
>>Date: Sat, 06 Dec 1997 22:39:15 -0500
>>To: Ben Ransom
>>From: Richard Pike <rpike(at)preferred.com>
>>Subject: Re: Answer rough running 912
>like the recent string about the 912 that leaned itself out with high speed
>ram air. Apparently the airflow through the filter, carb, and carb throat
>was affected by the airflow striking the front side of the airfilter, (which
>stuck out 90 deg. to the engine) and creating a low pressure at the rear.
>He balanced his CHT's by making an airflow deflector and attaching it to the
>inside of the cast aluminum intake manifold just beyond where the carb
>attaches and before the manifold splits. The airflow had been
>angling/swirling through the carb in such a way that one cylinder was
>getting rammed and the other was coming up short.
>> If you think that such a thing might be possible in your case I
>will get the specific details.
>> Richard Pike
>> MKIII N420P (42oldpoops)
> I don't know if this has anything to do with the recent string of
airflow to the carbs comments but years ago when working on dual carb
sports cars there was allways a tube running between the carbs. Nobody knew
what this balance tube did but it was needed to make the engine run smooth.
Do dual carb 2 cycle engines need such a tube?or have such a tube?
Subject: | HELMET WITH RADIO |
I will be flying a Kolb Firestar II with floats off the beach in front
of my house on Dungeness Bay in Washington State. Can anyone recommend
a combination helmet/radio system which will also give me enough
visibility for photography?
Please give me some ideas about where to look. Do I want a hand-held
radio or something built into the plane.
Also, I would like some seat covers that offer a little more comfort
than the ones that came with the plane--perhaps with floatation. Where
do I look?
DEAN HENRY
>become unhooked. I had my third inspection by the EAA tech counselor and
>he mentioned that he has seen systems like this (where the springs and
>chains are just hooked together and not actually locked in a way that
slack in >the chain will not cause it to become unhooked) to release if a
bumpy ride in >the ground or a cross wind landing causes one side of the
system to stretch >and the other to slacken. Just to be safe, we agreed
that it would be a good >idea to post this question in this newsgroup and
find out if anyone experienced >this before.
>Chris
Yes, I've seen the tailwheel springs come loose on a Mark II once. The
pilot was fortunate not to have a crosswind, so the landing was
uneventful. After that, I closed the spring hooks on mine so it wouldn't
happen to me.
Ralph B.
Original FireStar
Subject: | Re: Trailering damage potential alert. |
writes:
>....the root rib to attach into the universal joint, is loose. It turns
>slightly.
Jim,
I have identical situation on a Twinstar I recently purchased. I was
going to try re-torquing as you did but think I'll wait to see what you
discover. I was told by the previous owner that mine has covered many
miles on it's trailer, not to mention the trip from Albuquerque to Tulsa!
Apologies if someone has already solved this, am behind on my mail.
-Mick Fine
Green Country Ultralight Flyer's Organization (UFO)
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Engine choices - are there any besides Rotax -Reply |
writes:
>.... I purchased a Great Plains 2180cc
>long block app 2years ago for =243800.00. I have then had to purchase
>props, carburetors, ignitions systems etc. etc. etc. which I guess I
have
>spent =241500.00 additional.
Wow Rick,
I knew 4-stroke prices had gone up but SHEEESH!! ;-) ;-) ;-) ;-)
Seriously, nice pix on your web page, keep us updated. I know I can't be
the only one who is anxious to see how it works for you.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: TwinStar Windshield |
writes:
>Does anyone have the dimensions for a TwinStar Windshield? ...
>....I put a few photo's up on my web page if your interested in the
>project. (More to come next week... :)
>This link will take you directly to the photos:
><http://www.tcsn.net/mswihart/twinstar.htm>
Great pictures Mark!
I am also "restoring" a TS. Sorry, I can't help with the windscreen, mine
had a homemade enclosure, didn't even have the stock pod. I got all the
prints (I think) and the contruction manual and there are no dimensions
for the windscreen.
My intent is to fabricate a Mark II style enclosure unless someone on the
list can talk me out of doing so! Question for the list: Has anyone else
done this? Help and advice greatly appreciated!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Vacuum cleaner |
Here's my plan, please point-out any flaws;
I will put my old, small, nearly worn-out shop vac minus its can and
(filthy) filter in the attic direcly above my garage/paint area. If
needed, I can run an intake hose to the gable vent for nice fresh (maybe
too cold) outside air. Fab-up some kind of PVC fitting to pass thru the
sheet rock of the ceiling to accept the output hose of the vaccuum (on
top) and the feed hose (on bottom). This should allow me to attach some
kind of corrugated hose of about 1" dia. from the ceiling to my mask and
maybe keep the hose from getting under-foot so much. The smaller "feed
line" should restrict the flow a little but that's needed anyway. BTW, I
bought the mask several years ago from the local American Airlines
surplus store for $5. It is a Scott full face mask like new (looks
indentical to what firefighters use). I didn't need it at the time but am
glad I bought it as the surplus store has since shut down. Gawd I love a
bargain!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Firefly Nosecone |
Is it possible to make the nosecone on the Firefly quickly detachable for
transportation? I'm assuming the rear can't be shortened due to the folded
wings, is this true? It would be a big help to use the 18' enclosed trailer I
already own.
John Caffrey
http://www.win.net/~letsfly/4stroke/vw.htm
Talking to a sailplane pilot at work today about the need for a good
mask/air system when spraying isocyanorotyurlungs type paint, and he claimed
to have hooked a small air compressor up to a light weight hose and attached
it to an elcheapo snorkeling mask. Said to hook up the hose so that it blew
fresh air toward your eyes and nose, and the excess would just leak out
around the edge. Apparently the airflow keeps it from fogging up. Since one
of the Kolb guys said Saturday that that paint could be absorbed through the
eyes, maybe it's a good idea. The price would certainly be right. Comments?
Richard Pike
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
My neighbor is a chemist, retired recently from Boeing in Seattle. I
should him the interest we have expressed lately regarding protection
while spraying paints. He did more than I had bargained for and I
enclose his reply. I hope you can make sense and use of it.
Ron, re the isocyanate question, I have never heard that chemical
filters won't trap isocyanates. Looking in my respirator catalogue, it
says carbon cartridges will filter amines, and an isocyanate is derived
from amines. (None specifically mention isocyanates, but I have some
800 numbers for safety hotlines and I will call Monday, pose the
question).
Of course there are all kinds of isocyanates. The two we can come in
contact with mostly are toluene (tol-you-een) used in foams and older
type urethane paints, and called TDI, and hexa-methylene (meth-ill-een)
used in modern polyurethane glossy paints, and called HMDI. (The latter
is also called an aliphatic (al-i-fat-ick) urethane, and the former an
aromatic (air-o-matic) urethane. When we at the big B were developing a
bug resistant fuel tank coating for the jets, one of my colleagues got a
respiratory problem from carrying partially cured test panels around in
the back of his station wagon. That was a TDI coating. The glossy
topcoat is the HMDI type with much lower toxicity, and I've not heard of
any unusual problems, requiring special filters. About the eyes? I
would guess that any mucous membrane can readily absorb organic
solvents, and if you cover your nose and mouth, that leaves the eyes.
I've sprayed lots of aliphatic coatings using only the carbon type
filters and it hasn't affected me a bit. I'll admit I do look a bit
older than I should for being only 29 years old.
As an aside and while I am on a roll here, here is some history. In
1936, Carruthers of DuPont came up with the nylon polymer and DuPont got
a patent. The Germans tried to come up with a similar polymer without i
nfringing on the patent, and the result was polyurethane. It made
beautiful fibers, but they were low melting and hot irons would melt the
clothing fabric. They used it in foams and some paints, and the foams
found use in WWII German planes for cores in controls and flaps.
I looked up Bhopal and found out the toxic gas was methyl isocyanate, a
volatile gas used for raw materials in other isocyanate products. Here
is the article out of Encarta.
Bhopal, city in central India, capital of Madhya Pradesh State. It is a
railway junction and trade center. In December 1984 deadly
methyl-isocyanate gas was leaked from a chemical plant in Bhopal,
causing the deaths of at least 3300 people; it was the worst industrial
accident in world history. In 1989, after years of litigation, the
United States owners of the plant agreed to pay the Indian government
$470 million. In return, the government agreed to drop criminal charges
against the company and its former chairman. Population (1991)
1,063,662.
Okay, that's it, you've used up today's info coupon.
Dew
-----Original Message-----
good
claimed
attached
blew
one
through the
Comments?
> Richard Pike
Ron
Subject: | Floatation seats |
>do I look?
(At great risk of being flamed) I bought a seat cushion type floatation
device and used the foam in it for my seats. Almost all of these have 2- 1"
thick pieces of foam, rather than 1- 2" piece as it would seem. It's very
comfortable padding, and a 1" thickness seems fine to me. My wife sewed a
cover for it, that slips down over the top of the seat back, and velcros to
the seat bottom. I figure that I can pull it off as a floatation device if
needed. Why you ask? (here comes the part that'll get me in trouble) To
get to the beach, I have to cross a bay that's about 4 miles wide at it's
narrowest point. Unfortunately, I have to do this at an altitude of 1400 ft
or less to avoid the Class C area of Pensacola. Admittedly, there's a
period of time where I have to trust the Rotax a bit more than normal. So
far I've done this once, and it seemed like it took a loooooong time to
cross that bay. I kept wondering things like- "how cold is the water now",
and "should I ditch near that shrimp boat, or get as close to the shore as
possible".
OK, now really let me have it :-)
Rusty "all work and no flying" Duffy
good
claimed
attached
It might be a good idea to specify an oil-less compressor.
Rusty
Subject: | Weight and balance problems in my Firestar II |
Dear Kolb friends,
I just finished doing the weight and balance in my Firestar II with the 503
DCDI engine, and it's simply scary. The numbers don't even come close to the
specified aft C.G. limit! My airplane has no brakes, no electric start and it
was built per plans. My only sin is two thin coats of P-Spray. I knew these
airplanes have the tendency of being tail heavy but this is totally
outrageous. The empty weight of my plane came up to 340 Lbs. The C.G. with no
fuel and me sitting in it is 41%. For the distance from datum to main wheels
and tailwheel I got 8.75 in. and 192.25 in. respectively (is this close to
what you guys get). I don't even want to mention what my calculations tell me
I need to add in weight to the front seat to bring the C.G. to the aft limit
and what this does to my ability to fill the rear most fuel tank and much less
to my original idea of carrying my 145 lbs. wife.
You bet I'll call Kolb tomorrow about this, but I want to know from the users
out there what kind of weights and C.G.'s you are getting. I am way off on my
numbers?.
Help!!!!
Chris
Subject: | Re: Firefly Nosecone |
> already own.
> Thanks,
> John Caffrey
I suggest that you consider modifying the fron of the trailer just to
clear the nosecone.
John Jung
Subject: | Re: Weight and balance problems in my Firestar II |
Chm12345 wrote:
> Dear Kolb friends,
> numbers?.
> Help!!!!
> Chris
Cris,
I recently did weight and balance on my Firestar II and compared the
numbers with several others on this list. I suspect that you have a
problem with the scales or the calculation. I also wrote an Excel
program to do the weight and balance. If you provide the rest of the
numbers, I will run them through the program. If you have Excel, and you
would like, I will send you your own copy.
John Jung
From: | Wayne Welsh <flight(at)mail.on.rogers.wave.ca> |
Subject: | Re: HELMET WITH RADIO |
I've used a Comtronics helmet with standard headset plugged into a Icom 21.
The helmet has the interior cut out to adapt to a headset. This system
worked great. I had to put a whip antenna on for better reception,
transmition, ended up wire tying and taping it onto the gear leg as far
away as possible from the engine. With the spark plug wired shielded and
the antenna away from anything the reception and transmition was very good.
I
>> already own.
>> Thanks,
>> John Caffrey
>clear the nosecone.
>John Jung
John,
Could you explain why? I haven't been able to get a good look at that area. Is
it because there are too many attachments, because it won't gain enough room,
because it's part of the structure?
John Caffrey
Subject: | Weight and balance |
I have a firestar with a 447. No brakes. I weigh 160 to 165 pounds
depending on clothes being worn. I t was neccessary to add 20 lbs.
ballast in the form of copper sheets under the floor boards between me
and the nose cone in order to get an acceptable CG reading. I am a real
believer in doing a very accurate weight and balance. I have a friend
with a 503 on his firestar. Even with brakes his body weight made it
necessary to add 50 lbs. ballast in the nose section.
Ray Lujon , Woodbury , MN
Subject: | Re[2]: Firefly Nosecone |
If you could remove it I don't really think your going to gain much.
The front part of the cage (rudder pedals) extends majority of the way
into the nose cone. You might gain a few inches at best. I would
look at the trailer to see if you could build around it.
Jerry Bidle
FireFly
______________________________ Reply Separator _________________________________
Subject: Kolb-List: Re: Firefly Nosecone
Date: 12/8/97 7:49 AM
I
>> already own.
>> Thanks,
>> John Caffrey
>clear the nosecone.
>John Jung
John,
John Caffrey
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
Subject: | Re: Weight and balance |
...just to chime in on this, my 447 FS KXP came in within CG, somewhat
toward aft limit, but comfortably within. Having to add ballast
in an "ultralight" is no fun at all, so i sure do sympathize w/ anybody
who faces that.
Check and dbl check the bubble level and incidence angle during the
weighing. A small error here will make a big difference in your calc.
I hope this is the problem.
-Ben
Subject: | Re: Floatation seats |
> possible".
OK, i see the next quiz here.
1. How long before Rusty gets wet?
2. Half credit question for newbees: should he fly at best glide angle
or minimum sink speed?
-Ben "i don't really want to hear a zillion answers" Ransom
PS: Rusty, seems nicer if you'd carry a BRF (Ballistic Recovery
Floatation?) device. How dare you save only your own hide
and let that nice plane sink! :-)
> Richard Pike
Never breath air from a compressor.If you think breathing vacume cleaner
air is bad compressor air is worse.All those little oil molecules
vapourised and then pumped into your lungs.Ask any Scuba shop about the
regulations concerning breathable air. In my humble opinion a cleaned shop
vac is the ideal way to go.
Woody
This may be a little off the subject, but if you want to read the very
interesting story of what happened at Bhopal with the Isocyante disaster go
to;
http://gurukul.ucc.american.edu/ted/BHOPAL.htm
Total estimated killed 4000; total estimated injured 400,000
Subject: | Stripping Firestar cage |
Well I have disassembled every part of my fuselage so far. I don't know what
kind of paint was used on the cage but MEK dissolves it. The paint has held
up pretty well except under the adhesive that hold the fabric on. There was
some rusting probably because the polytak had partially disolved the paint.
I tried a couple different things to remove the paint on the cage.
1) rough scotchbrite pad -- nothing
2) emery paper strips -- not bad, but messy and clogged the paper quickly.
Dusty too
3) abrasive wheel in a drill -- quick but dusty and maybe a little aggressive.
4) MEK -- messy, messy, messy
5) 3M Safest Stipper paint and varnish remover -- dissolved the paint in a few
minutes scrubbed off with scotchbrite pad easily, no fumes, gloves not needed.
This stuff works great!! The only drawback is that you cant leave it on to
long or you might get rust.
It also worked on my fuse tube which may have been enamal or aerothane, just
took longer.
Does anyone know how the vertical stab attaches to the tailpost on original
firestar? I want to remove all rivits from tailpost and remove from fuse
tube. Cant figure it out from plans or instruction book.
Is there a list available showing all the material needed for recovering.
Fabric type and quantity, rivits, tapes, paints(polytone,polyspray) and
quantities.
Thanks folks.
Scott Olendorf
Subject: | Firestar II W & B |
Thanks for all the kind replies on my CG questions.
Ben's remark on how sensitive the CG location is to variations of the datum
measurement is correct. I have checked that a change in 0.5 in the datum could
make the difference between being OK or not OK. This weekend I will, very
carefully, recheck the CG using more accurate equipment and procedures.
Please keep sending me data (datum distances in particular and weights) and
opinions particular to the 503 equipped Firestar II. Since I built the
airplane per plans, with only the P-Spray added that could add in tail weight
(but I now is minimal), reassurances that other people with this type of
airplane are doing OK will give me hope until I recheck it this weekend. I
sure don't want to add 50 pounds of weight in the nose since this would drop
my useful load to nothing.
Another important question: Is the correct range 35% or 37%. The plans mention
37% were the manual says 35%. I hope is 37% and gosh I wish Kolb fixed this
little inconsistencies on their documentation, they drive me crazy. Hey Kolb,
just a piece of paper with corrections would suffice, as a matter of fact, I'm
building a Cozy Mark IV and they send a quarterly newsletter were they report
inconsistencies builders find between the plans and reallity and provide
appropriate corrections. You need to do this.
By the way John, what's the configuration on your airplane. I do have EXCEL.
Thanks again to all. I know I may be drowning on a glass of water, but after
year and a half of too much work, one gets paranoid about this kind of things.
Let's keep the our Kolbs safe and fun.
Chris
Russell
I Like you have to fly over a stretch of water every time that I go to
Galveston, about a 1.6 hop over some deep water I had some seats made
out of 2" close cell foam,the same stuff that you find in P F D . It is
true that it is not fire prof , but it will serve as flotation, along
with a firefly hand held strobe light that is attached to it just in case
I ever need it. The little stretch that I fly over dose seem like it
takes a looong time to make it to the other side.
Rick Libersat
>Where
>>do I look?
>floatation
>2- 1"
>very
>sewed a
>velcros to
>device if
> To
>it's
>1400 ft
> So
>to
>now",
>shore as
>possible".
To Terry Swartz and other 912 powered MK III's
I'm a Kolb want-ta-be with questions about your MK III not covered in Kolb
info. pack.
What's your empty weight?
Do you need ballast to get good CG?
Is 912 smooth at all speeds down to about 20% power?
One mode of flight would be as a fake motorglider with engine running at fast
idle, about 1 gal/hr.
Published reports of the Jabiru claim VERY smooth operation down slow idle,
but it's direct drive (small propeller). It's also claimed to be 55 lbs.
lighter than the 912.
Bruce Cruikshank
From: | Scott Bentley <Scott.Bentley(at)Bentley.Com> |
Subject: | 912 Powered MK3 Questions |
Around 560 pounds, similar to the factory model
On paper with the factory's somewhat conservative limits, yes.
In practice, even with the lightest
pilot so far (around 170 pounds), no, with trim set to minimum.
Mine is, at least to my standards.
Scott Bentley
http:\\members.aol.com\scottbntly
Subject: | Re: Re[2]: Firefly Nosecone |
> Jerry Bidle
> FireFly
Thanks John, Jerry and Jim for your opinions on a detachable nosecone. I
don't wish to buy the larger truck which would be required for a bigger
trailer so I'll look into modifying my 18' tag along. My V6 Ford Ranger seems
to be the best compromise between everyday economy and occasional hauling and
from some of the web pages I've visited I see others feel the same.
John Caffrey
Mine is 541 lbs.
On paper I needed 15 lbs when I fly alone. I weigh 165 lbs. I started
with 25 lbs in the nose to put me in the center of the cg envelope when
I frist started to fly the plane. I have reduced it to 10 lbs and
really can't tell and difference in the handling. Kolb says I don't
need any. I intend to keep reducing it.
Mine is very smooth through all rpms now. I have flown with slower
ultralights at 45 and cruised with faster planes at 83 IAS. I'm very
happy with the 912.
> Bruce Cruikshank
From: | "Richard neilsen" <neilsenr(at)state.mi.us> |
Subject: | Re: Answer rough running 912 -Reply |
I will be flying a VW powered MKIII. My empty weight is 558 lbs. and my CG
can only go to the aft limit with a 168 lb. pilot. I don=27t get even
close to the forward limits at max gross weight.
As for the 912 being able to fly at fast idle does 5,000+ constitute fast
idle. It seems that flying the factory demonstrator we would drop
something like a flat rock at 5,000rpm. I only got a few hours in the
factory plane and I wasn=27t trying to remember the exact RPMs but it
takes a lot of RPMs to keep the 912 MKIII in the air. Don=27t get me wrong
the 912 is a fantastic engine that I would give my left........ but
without a in-flight adjustable prop your not going to fly long at what I
would call fast idle.
My =24.02 worth
Rick Neilsen VW powered MKIII
>>> T Swartz 12/09/97 09:12am >>>
B4C9 wrote:
> To Terry Swartz and other 912 powered MK III=27s
> What=27s your empty weight?
fast
idle,
> but it=27s direct drive (small propeller). It=27s also claimed to be 55
lbs.
> Bruce Cruikshank
Subject: | BRS Chute Activation Handle location |
Jerry Bidle posted:
> 2. Where and how is your pull handle positioned.
> We got a VLS for a FireFly, the rip cord is either to short to
> place
> next to the seat or to way long (need 16") to place on the right
> side
> up near the top of the seat.
> We were initially shipped a 5 foot cable, now BRS wants to ship
> us a 8
> foot. I feel it will be to long and are going over board. We
> like
> the position above your head to one side. Our concern is you
> might
> not be able to raise your arms that high to activate it needing
> to
> over come G forces such as would occur in a spiral.
> BRS was not very willing, but I got them to make a custom short
> cable for me to use for my Mark III.
see: http://www.bentley.com/scott/brscable/lookingup.jpg
and: http://www.bentley.com/scott/brscable/furtheraway.jpg
You have to lift your hand, but it is convenient and near other
controls on my plane...
Now i wish I hadn't said i didn't want to hear a zillion answers.
I think the mental exercise is sort of worthwhile.
Here's a solution if anybody's interested:
Assume no wind, 800 fpm descent at best glide speed (assume 60mph).
1400 ft / 800 fpm = 1.75 minutes till splash
60mph = 1 mile p minute. So, 2 minutes till shoreline from middle
of crossing.
1.75 minutes * 1mile p minute = 1.75 miles, glug glug, .25 to go.
So you only need to really worry during the middle 2*.25miles of the
crossing. Of course that's w/ no reserve.
If you had a 10mph wind, your ground speed would be 1.17 miles per minute
IF you turned and went with the tailwind. This would get you to shore
in 1.7 minutes which means you'd just barely make it. Of course the
landing might not be pretty.
Maybe if you put a GPS way-point at the middle of the crossing and know the
wind, you'd know exactly which way to go if it quit at any point near the
middle.
Rusty pointed out to me:
- i forgot to figure in the altitude lost turning back to use the tailwind
- shoreline has enf trees to make that not a lot better than a water ditch
- something about maybe i'm having too little to do at work :-)
After all the techno calculating, here's a picture
(http://mae.engr.ucdavis.edu/~ransom/quiz/fly_020.jpg) Rusty sent me
demonstrating that no matter what, you are going to be listening to
that engine pretty closely while crossing. :-)
I posted all this just because I think it is worth some mental exercise in
these types of things once in awhile. Also, it points out that we should
ALL KNOW WHAT OUR BEST GLIDE SPEED IS, as well as rate of descent at
that speed. BTW, I'm sorta surprised at 800fpm ...i think Rusty even
said 850fpm @60mph. Seems kinda fast and steep, and that is even with the
lightest engine you'd put on that thing (no offense Rusty ;-) ).
-Ben "you know it's really sad when he's answering his own email" Ransom
Richard neilsen wrote:
> I will be flying a VW powered MKIII. My empty weight is 558 lbs. and my CG can
only go to the aft limit with a 168 lb. pilot. I don't get even close to the
> As for the 912 being able to fly at fast idle does 5,000+ constitute fast idle.
It seems that flying the factory demonstrator we would drop something like
a flat rock at 5,000rpm. I only got a few hours in the factory plane and I wasn't
trying to remember the exact RPMs but it takes a lot of RPMs to keep the 912
MKIII in the air. Don't get me wrong the 912 is a fantastic engine that I would
give my left........ but without a in-flight adjustable prop your not going
to fly long at what I would ca
> My $.02 worth
Rick
I believe your recall of 912 RPMs in a M III has escaped you. Red line
on the 912 is 5800 RPMs. Max. continuous RPM is 5500 RPM. 75% power is
5000 RPM. If I want to get somewhere, I'll fly at 5000 RPM which gives
me about 82 MPH. If I'm up just beating up the air, I like about 4500
RPM which is 65 to 70 MPH and about 60 % power. I have flown with other
slower ultralights at 45 MPH and as I recall RPM's were around 3500 -
3700. Stall speed is 35 on my M III.
Terry
From: | Jon Steiger <stei0302(at)cs.fredonia.edu> |
Subject: | Snow ski mounting point? |
I'm in the process of converting a pair of wooden waterskis into snow skis
for my FireFly. I'm at the point now where I have to figure out where to
attach the mounting hardware. Does anyone know where I should mount the ski
in relation to the axle?
The most obvious (to me) place to put the axel would be right above the
center of gravity of the ski. Then, I thought that maybe I'd put the
axel just slightly forward of the center of gravity so that the ski would
have an inclination to put the tips in the air. (Thinking that if my
bungee/safety cable ever broke, the ski tips would come up, rather than
trying to dig into the ground.) I talked to a person here who has made
skis for ULs before, and I've been told that I should put the axle slightly
behind the center of gravity.
Now, my idea that having the mount point slightly forward of the CG (of the
ski) would keep the ski tips up is just conjecture (I have no idea how they'll
act when air is moving over them), and maybe there are more important things
to think about; like how the ski will react when it hits the ground and the
weight of the plane starts to settle in. I definitely want to avoid a
"surprise" landing, if you know what I mean.
Anyone have any thoughts about this?
-Jon-
.--- stei0302@cs.fredonia.edu -- http://www.cs.fredonia.edu/~stei0302/ ---.
| DoD# 1038, EAA# 518210, NMA# 117376, USUA# A46209, KotWitDoDFAQ, RP-SEL |
| '96 Dodge Dakota v8 SLT Club Cab, '96 Kolb FireFly 447 (#FF019) |
I do not speak for the SUNY College at Fredonia; any opinions are my own.
From: | "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM> |
Subject: | Snow ski mounting point |
I don't have any experience, but, my opinion...
I think you are BOTH on the right track: Mount the axle slightly behind
the middle of the ski, so the weight of the aircraft doesn't push the tips
down into the snow, but then put a small weight on the back end of the ski so
it hangs tip-up. And you'll have limiter cables and bungees...
Keep the rest of us Northerners posted on the ski progress, it is snowing
outside right now here in MN.
Subject: | FW: Snow ski mounting point? |
Let me start this out by saying that I have never mounted or flown a
plane with a set of skis. With that out of the way it would seem to me
that one important thing to consider is the axle in relation the flat
area of the ski. If there is more surface area ahead of the axle the
rear of the ski will sink first, I would think this more desirable than
more surface area behind the axle which would make the tip sink first.
I don't know if you will encounter any surface soft enough for this to
make a difference but it is worth thinking about.
> From: Jon Steiger [SMTP:stei0302(at)cs.fredonia.edu]
> Sent: Tuesday, December 09, 1997 12:30 PM
> To: kolb(at)intrig.com
> Subject: Snow ski mounting point?
> snow skis
> to
> the ski
> the
> would
> than
> made
> slightly
> (of the
> they'll
> things
> and the
> -Jon-
> .--- stei0302(at)cs.fredonia.edu --
> RP-SEL |
> (#FF019) |
> my own.
Subject: | Re: Snow ski mounting point? |
You put the axle behind the midpoint of the ski's SURFACE area. You
want more surface area in front of the axle than behind, so that if it
starts to sink in, the rear of the ski will sink lower than the front, and
the ski will maintain a "positive angle of attack" relative to the snow. If
the area behind the axle were greater than in front, if is starts to settle
in, the front will settle deeper than the rear, the angle of attack relative
to the snow goes away, and your ski will want to tuck under. On the other
hand, if you are landing on a very short strip, and your brother-in-law
wants some REALLY exciting videos...
Richard Pike
Subject: | Re: Stripping Firestar cage |
Gosh i love this info but a guy could go paranoid with all thes problems and
solutions. First of all i WOULD LIKE TO DECIDE if i should build a firefly or
a 2 seater. I would certainly like a 2 seater but... how can I make up my
mind?
Subject: | Re: Jabiru v/s 912 |
Bruce Cruikshank
According to my info,the published weight of these two engines is roughly
the same; 123 vs 128 lbs respectively including the gearbox in the 912.
Is this correct?
Frank Reynen Mark-III@430 hrs
http://www.webcom.com/reynen
Subject: | Re: Floatation seats and Ben's part time job :-) |
Ben, can you give me your bosses e-mail address :-)
The picture that he posted (I'll get him for this ) looks worse than it
really was. At this point, I'm probably still over land on the North shore
of the bay. Our ATC friend will also note that I'm below the 1400 ft floor
of Pensacola, but never by much. Some of you will notice that the EIS
warning light appears to be on, and well, it is. I had changed a couple of
alarm settings the day before, and somehow turned on the time alarm for 10
minutes. After 10 minutes, the light started flashing, and I acknowledged
it which leaves it on solid for the rest of the flight.
Now, if anyone has incriminating photos of Ben, name your price :-0
Rusty
Subject: | Thanks to all on the replies. |
Dear Kolbers,
Thanks to all for the replies on my posting. I've been trying to call Dennis
but he's away so I'll have to wait for an answer from them. Your postings give
me hope that this situation is not without a solution.
Chris
firefly or
>mind?
One thing to consider is the physical size.I had to cut a hole in the
back of my garage and mount a storage shed to cover the hole so I could
fold up my twinstar and park it inside.When I go flying I don't want to
wait around for anyone,90% of my flying is by myself.So another thing to
consider is your social network. Just some ideas, Final call is yours
Subject: | Tail Heavy Kolbs |
I would like to make a short comment while we are on the topic of weight
and balance. My Kolb FireStar was tail heavy 11 years ago, but now it is
nose heavy. Over the years, this pilot has gained weight and when I
carry two well fitted gas tanks behind the seat (~36 lbs ahead of the CG
on the original), I'm happy that my Kolb was tail heavy to begin with.
The extra tanks do allow me cruise faster than without them on a
cross-country flight not only because of the added weight, but because I
sit farther ahead when I'm sitting against them.
Ralph Burlingame
Original FireStar
Scott
The vertical stabilizer is attached by five rivets into the vertical part
the tailpost near the rear of the fuse tube, and by two rivets into the
horizontal part of the tailpost. This would be in the bottom aft corner
of the stabilizer. I looked at my plans and it's in there (how else could
I have put them in?). The rivets would be covered over with fabric and
would not be easily seen.
Ralph Burlingame
Original FireStar
>original firestar? I want to remove all rivets from tailpost and remove
from
>fuse tube. Can't figure it out from plans or instruction book. Is there
a list >available showing all the material needed for recovering. Fabric
type and >quantity, rivits, tapes, paints(polytone,polyspray)and
quantities.
>Thanks folks.
>Scott Olendorf
Jon
I've been flying off of converted wooden water skis for 10 years now on
my original FireStar. I put the axle 1" ahead of the CG of the ski. My
skis are about 5-1/2 feet long and I can land in snow that comes up to my
thighs when I get out of the plane. I do not have a tail ski but in
recent years I added a triangular piece of oak to the tailwheel post.
This keeps chunks of ice from hitting the tailwheel. I have it
hose-clamped on there around a heavy piece of clear neoprene tubing.
You get the correct angle for the ski by putting a 3" block under the ski
in front of the axle with the edge of the block even with the axle. The
rear cable should be rigged tight at this angle. I rigged the front cable
with the ski flat on the surface. Use a strong bungee on the front
because heavy wet snow needs to be lifted up. In both cases, the tail is
on level ground. I just finished up a new pair of composite skis. They
are also water skis with the same dimensions as the old ones.
Ralph Burlingame
Original FireStar
writes:
>snow skis
>to
>the ski
>the
>would
>than
>made
>slightly
>(of the
>they'll
>things
>and the
> -Jon-
>RP-SEL |
>(#FF019) |
>my own.
RICK M LIBERSAT wrote:
> TERRY
> I just got my EXPERIMENTER magazine today ,their is something in it that
> I think you MUST see it is on the ROTAX 912 their is a very bad problem
> with the fuel pump. I don't know if you have seen it or not , but if I
> were you I would NOT go up in your M III UNTIL you have checked your 912
> out their are some serial. numbers on some fuel pumps that MUST BE
> REPLACED it sounds like ROTAX will put the bill. I AN NOT TRYING TO
> SCARE YOU . but please check it out . You may have already been
> contacted about this if so disregard my message, just don't want anything
> to happen that could of have been prevented,this is the other RICK the
> one with the M III with the 582 and not the vw talk to you
> later
> RICK LIBERSAT N106RL
Thanks Rick
I noticed the info at www.rotax-owner.com and my serial is not
included. I also have an electric backup fuel pump.
Terry
Subject: | Re: removing vert stab |
Getting to this a little late, but...
I believe you may have problems removing the vert stab (upper or lower)
from the steel tailpost. The vert stab is a closed triangle, with all
angles fixed because of the gussets and any "rib" if there is one in the
middle. The tiangle was assembled in the first place while on the tailpost.
This is tough to explain w/out a lot of hand waving.
/| <-gusseted angle
/ i
gusseted / i
angle -> /_____--i "i" and "-" indicates steel tailpost
So, pretend the above picture is a vert stab. The lower right angle
corner is where the AL tubes fit over the steel tailpost. Even if
you remove the rivets holding those 2 tubes to the tailpost, you can't
easily pull the rest of the triangle off. In fact, I think you can do
it, but you have to work it off bit by bit -- like taking pants off w/
your shoes on -- if you'll pardon the analogy.
This all true for KX/KXP and i *think* also for other Kolbs.
Ben Ransom (*)
Email: bransom(at)ucdavis.edu o o
Subject: | Re: WOULD LIKE TO DECIDE |
> mind?
The 2 sides you mention are FAR103 legal UL versus Experimental Category
registered aircraft. That is a pretty big difference, altho fortunately
or unfortunately (i'm not sure) you could build and fly in the gray area
in between. That is, build and fly a FS I or II and fly it single seat,
5 gal, 447. I guess you'd still be breaking the law like the other 10,000
US UL fliers, but I bet even most FireFly owners soon get heavy as well.
Not wanting to make this too simple for you ...it would be a nice feeling
to be positive you are flying in a legal category, ie, the gray area
kinda sucks when/if you are fighting for airport access.
PS: Another option would be to build a FS I w/ 447. If the FAA tightens
up you could drop the 447 for a 277 or rubberband and be legal.
Ben Ransom (*)
Subject: | Re: Re: Jabiru v/s 912 |
Frank,
My source for the Jabiru being lighter than the Rotax was an article in the
August '97 KITPLANES. The Jairu is supposed to weigh 124# installed (it looks
like the bed mount would add a pound or two). Specs. for the Rotax with the
exhaust and cooling systems (124 ,+,+)add up, but 55# may be a bit much.
Tiger Aviation, current Jabiru dealer say the Jabiru powered Drifter SB
"...performs equally well on take off and climb out as with the Rotax (582)
and there is a 15 mph improvement on cruise." when asked.
I have no experince with these type aircraft, what is the power off sink rate
a Mk III with one or two person on board? To fake a motorglider (200 fpm sink
at 45 mph) may require a faster idle then I thought.
Well I measured it last night. From the front of the cage extending
into the nose cone to the inside farthest forward portion, you might
see 7-8 inches max. That's it. Remember you have a stub of the pitot
tube sticking out the front of the nose cone, I didn't count that.
inch or so to which another 5-6" piece of aluminum tube is slide on
using a piece of plastic gasline hose to interconnect them. Then a
piece of aluminum sleeve slit length wise slides over the plastic
tubing to give it rigidity. We copied it on our FireFly and it looks
like it should work well.
Jerry Bidle
Subject: Kolb-List: Firefly Nosecone
Date: 12/7/97 7:37 PM
already own.
John Caffrey
Subject: | Re[2]: Jabiru v/s 912 |
But does the weight for the 912 include the hoses and radiators for
the oil cooler, liquid cooling, and the fluids.
Subject: Kolb-List: Re: Jabiru v/s 912
Date: 12/9/97 5:21 PM
Bruce Cruikshank
Is this correct?
Ron,
The two red tanks that I have fitted into the back of my original
FireStar are each 3 gallons (labeled 2-1/2g). I bought them at a local
Target store. They are made in Canada. They fit so nicely back there it
looks as though they were custom fit for the plane. A friend and I do a
lot of cross-country flying in our original Kolbs and these tanks give me
11 gallons total. Friends say, "Why don't you just install a 10g tank"?
The 5g tank in the UL "looks" more like an ultralight, if you know what I
mean. I can take the two auxiliary tanks out and have a slow flying
machine for just flying around the patch. This way unused gas stores
better in completely sealed tanks and there is less of a chance for
condensation to form in the 5g tank vs the 10g. The funnel also fits very
nicely under the seat.
writes:
>Ralph, I'm just now starting on my 1985 FS-I and your comment about
>2-gas tanks caught my eye. It would appear from the plans that there
>is only room for 1-tank.. let me know how you did it and maybe I can
>build that into mine.
>Thanks,
>Ron Carroll
>Independence, Oregon
Subject: | Fabric weight on wings |
When I received the covering kit for the MKIII it had 2 different
weights of fabric 1.6oz and 1.8oz. There was a note that said use the
heavier on the wings because of the higher wing loading of the MKIII and
the lighter on all other surfaces. Does anyone know what I should use
on the ailerons and flaps? I probably could roll all of the fabric out
and try and see if I have enough of certain weights to do the ailerons
and flaps, but I was hoping somebody might just know.
Subject: | Re: Fabric weight on wings |
having experienced aileron flutter, i'd use the lighter weight on the
ailerons. don't know what's called for, but i'd STILL use the 1.6 and
limit the paint too.
-Ben
Just so happens we ran into the same question last summer.The flaps and
ailerons are of the light fabric.New covering kits should now have a little
note telling you this fact.
Woody
Ralph Burlingame
Original FireStar >>
OK. Does that mean that I have to cover the stabilizer after I rivit it to
the post or do I just put a patch over the rivits?
Scott Olendorf
Scott,
You could cover it while mounted to the tailpost but why? Certainly cover
it before installation, then patch the rivet area.
Ralph Burlingame
Original FireStar
>it to
>Scott Olendorf
Subject: | Firestar II dimensions |
Can anyone tell me the folded dimensions of the Firestar II. I need the
length folded, width folded at the wheels, width folded at the
propeller(3 bladed), and height at top of 503 Rotax engine. I need
these dimensions to determine the size of an enclosed trailer for it.
Herman Leong
Jim,
Two 3gal red auxiliary tanks: (3g + 3g) = 6g + 5g(main tank) = 11gallons
total
Ralph Burlingame
Original FireStar
writes:
>> these tanks give me
>> 11 gallons total.
>Dang, son. How do you squeeze 11 gal gas into 6 gallons worth of gas
>can? What am I missing?
>Firestar II guy with two 5 gal cans in the passenger seat.
>Jim Baker
>Pres, USUA Club 104
>Frontier Ultralight Aviators
Ron,
I made a small bench in the back of the seat on which I set the
auxilliary tanks on. I then run a long bungee cord through the tank
handles so they won't fall out (when I do aerobatics.... ha ha).
Ralph
>Ron,
> Like Ralph, I also carry 2 - 2.5 gallon tanks behind the seat for
>some cross country flights. I allows me to use premium unleaded (not
>available at airports) and land in a hay field to refuel if needed.
>Sometimes I carry a single 5 gallon tank behind the seat, because it
>allows room for a tent on on side and a sleeping bag on the other.
>Have Firestar, will travel. The five gallon tank moves my backrest a few
>inches forward. To avoid adding a floor, the tanks are hung by a rope,
>and secured to the sides.
>John Jung
>>Ralph H Burlingame wrote:
> Ron,
>local Target store. They are made in Canada. They fit so nicely back
there
>it looks as though they were custom fit for the plane. A friend and I
>do a lot of cross-country flying in our original Kolbs and these tanks
>give me 11 gallons total. Friends say, "Why don't you just install a 10g
>tank"? The 5g tank in the UL "looks" more like an ultralight, if you
know
>what I mean. I can take the two auxiliary tanks out and have a slow
flying
very
>Ralph Burlingame
>Original FireStar
From: | Frank & Winnie Hodson <fwhodson(at)megalink.net> |
Subject: | Re: Firestar II dimensions |
According to factory specs the folded widths published are:
FS II with 503 Rotax - Length Folded: 21'3"
Height Folded: 75" with 3-blade prop
Width Folded: 66" with 2-blade prop
(slightly less with a 3-blade prop)
Good luck,
Frank Hodson
Oxford ME
Subject: | snowmobile suit needed |
For you cold weather fliers, can you give me the phone numbers of somewhere I
can order a snowmobile suit. Down here in the south there are none available,
have only found the cotton insulated work types which will do a poor of
blocking the wind, and when I fly when it's cold for our standards, I am
wearing so many clothes that I can barely move. A suit would be great.
thanks,
Subject: | Re: snowmobile suit needed |
> thanks,
> Tim
Call WearGuard at 1-800-388-3300. They have lots of cold weather
clothing such as 30 below insulated suits, parkas, gloves, boots
rated to 85 below...just lots of stuff.
Jim Baker
Pres, USUA Club 104
Subject: | Fwd: Pilot Blacks Out, Plane Lands Itself |
I am forwarding this to the list because I think it is of interest. I know I
am not supposed to rebroadcast AP news so don't tell anyone. Scott
Olendorf
.c The Associated Press
By TRACI CARL
WICHITA, Kan. (AP) - A man who blacked out at the controls of his small plane
flew 250 miles on autopilot and glided to a crash landing in a snowy field,
waking up with injuries no more serious than a broken wrist.
Dr. Bob Frayser, a family physician, was overcome by carbon monoxide fumes
about 30 minutes into an hourlong flight Saturday from his hometown of
Hoisington to Topeka, 160 miles to the east.
The single-engine plane continued on course at a level altitude, crossing
into Missouri and finally running out of gas as Frayser sat unconscious at the
controls. The four-seat plane skidded 500 feet on its belly before crashing
into a row of trees in a meadow near a home in Cairo, Mo.
Frayser, 47, said Thursday he woke up disoriented with a ringing in his ears
and a terrible headache. He staggered about a quarter-mile to a house, where
help was summoned.
``Most credit I give to the Lord,'' he said.
Frayser walked away with a broken wrist, a few cuts around his left eye and
bruises on his ribs from the seat belt.
``The man won the lottery,'' Federal Aviation Administration safety inspector
Jim Wesley told The Hutchinson News.
Frayser had set the autopilot of his Piper Comanche 400 soon after leaving
Great Bend airport on his way to a meeting of the Board of Healing Arts. A
crack in the engine's exhaust system allowed the deadly carbon monoxide gas to
seep into the cabin's heating system.
Frayser said he remembers nothing after the first 100 miles. He was in the
air about two hours and the autopilot flew at an altitude of 5,500 feet.
Warren Morningstar, spokesman for the Aircraft Owners and Pilots Association,
said the autopilot could have sent the plane into a spiral.
Steve Devenport was napping in his recliner when Frayser showed up at his
door.
``I think he thought I was crazy,'' Frayser said. ``Here a guy comes in a
suit and tie, banging on his door at 9:30 in the morning. I don't know if he
thought I was a salesman or a religious person or what.''
Devenport said Frayser, cold and disoriented, kept asking him how far Topeka
was. Then Devenport looked out his back door and saw the tail of the plane
sticking up out of the snow behind his house.
Frayser went back to work Monday.
``I had patients that needed to be seen,'' he said. ``Right now, I'm the only
family practitioner in Hoisington.''
AP-NY-12-11-97 1739EST
Copyright 1997 The Associated Press. The information contained in the AP
news report may not be published, broadcast, rewritten or otherwise
distributed without prior written authority of The Associated Press.
Subject: Kolb-List: Pilot Blacks Out, Plane Lands Itself
Date: Thu, 11 Dec 1997 17:43:47 EST
Itself
.c The Associated
Press
By TRACI CARL
The single-engine plane continued on course at a level altitude, crossing into
help was summoned.
Frayser said he remembers nothing after the first 100 miles. He was in the air
door.
``I think he thought I was crazy,'' Frayser said. ``Here a guy comes in a suit
Press. The information contained in the AP news report may not be published,
broadcast, rewritten or otherwise distributed without prior written authority
To edit your profile, go to keyword NewsProfiles.
For all of today's news, go to keyword News.
> Herman Leong
Herman,
My trailer is 6.5 feet high and wide and 23.5 feet long on the
inside. It has enough room to walk around the plane, but could not be
much smaller without problems. Both the Firestar II and the original
Firestar take up abut the same amount of space in the trailer.
John Jung
> thanks,
> Tim
Try http://www.denniskirk.com or 1-800-328-9280
It is a snowmobile mail order company that I have had good luck with.
John Jung
From: | "Marino, Frank J (Youngstown ARB)" <Frank.Marino(at)yng.afres.af.mil> |
I would like to know what would happen to an engine if you did not
winterize it for the winter if you plan on not using it. Right know I
have mine in my garage do some winter work on it. I think I read some
where that Rotax said to fog the engine with some sort of oil if you are
not going to fly in the cold months. I have a 582 on my MKIII.
FRANK J. MARINO
Chief Loadmaster 773 AS
Subject: | Re: ROTAX ENGINE |
> FRANK J. MARINO
Frank,
If you know that you arn't going to fly, it's probably a good idea.
In Wisconsin, we get very little good flying weather in winter. I don't
winterize, because I'm always hopeing for a flying day in the near
future. Historically, I only fly once or twice during the winter. Not
winterizing has not caused me any problems that I know of and Ihave used
Rotaxes for 8 years.
John Jung
ex-Loadmaster
Subject: | Winterizing the Rotax |
Frank, I also have the 582 on Mkiii and I have it in for winter repairs/updates
in my shop. The shop is somewhat heated and has a concrete floor. Bare metal
would rust in a month in my shop if not protected by an oil film. The oil film
that protects the inside of our Rotax cylinder walls is whatever is left over
after the last time the engine was run, not much I'll bet. I was recently
very surprised by how pourly the Rotax brand injection oil clings to things.
I took the injection tank off the engine last weekend (the plane hasn't flown
since Thanksgiving and has sat motionless in the shop). The bolts that hold
on the oil tank go thru from the inside and so are normally in the oil. I had
purposely let the oil level run very low since I knew I would be draining the
tank to switch brands after break-in so no oil had been on the bolt heads for
a month, except sloshing from flying or trailering. When I removed the bolts,
they were dry, no trace of oil to the touch. This concerns me. I wonder how
well the oil clings after exposure to combustion. I am doing some rather
non-scientific experiments with a couple oil brands right now, comparing
corrosion-protection.
Since I will be making a number of adjustments to the Rotax/Kolb, I plan
to start up the engine every few weeks (which will renew the oil film inside)
for various reasons, so I will not be fogging it. If I wasn't planning on
running it, I would definitely buy some OMC storage fogging oil and follow the
directions on the can. OMC works good, I have used ot before.
The cylinder walls can be inspected if rust is suspected and probably ball-
honed clean, but the main bearings would be big trouble if they corroded.
I would also recommend draining off all the fuel you can, treating the
remaining fuel in tanks, lines, carb bowls with Stabil brand fuel stabilizer,
and then in the spring I would still drain all the lines and especially the
bowls and put all fresh fuel in. Today's fuels are so volatile that I do not
trust them for two-stroke use after three weeks from the pump nozzle, two weeks
if they are mixed with oil.
Questions for the ol' experts: Can the tires be kept from getting flat spots
from sitting for extended periods in one position? Like, maybe inflating to
the max allowable?, or some other method? Removing all the weight might help
but it is not easy to do that. Other ideas?
Gear lube: the Rotax manual sez use 85-140EP. The leaf book advertises
80W-90 "Recommended for Rotax gear boxes". What is really allowable here?
I'd like to use 85W-90 instead of that 85-140EP thick old grease.
Thanks guys...
Subject: | FireFly Gap Seal around BRS VLS Chute |
OK we just reached our next hurdle. Dealing with the gap seal which
goes between the wings on the FIRE-FLY. We have used the BRS VLS
chute which is a box like unit that mounts between the wings. This
has made installing of the gap seal more complex.
It has been recommended that the BRS VLS clam shell box not be covered
Here's solutions being considered:
Fly without any - will it fly
Modify the gap seal fabric - cut out a square area in the center where
the VLS would reside and hem in an elastic "bungee" rope (square hole)
like the draw string of a hood of a coat. Lets see now how do you
fill the bobbin on the sewing machine? It's been a long time since
I done that. Sorry partner, looks like we'll have to use what ever
color and type thread that's on the bobbin.
Again modify the gap seal fabric - cut out and hem the area where the
VLS would reside. Add Velcro to the edges of the cut out area. Make
an L bracket out of lexan which would install on the right and left
sides of the VLS using its mounting tray screws. For this to work
right it would be necessary for the vertical part to profile the wing
shape, the horizontal part would have to be "chemically" welded to the
vertical.
Repeat ! VLS !--- <-- L Bracket
on ! Box !! Lexan w/Velcro on top
both sides +-----------------+!..<--mtg screws
Some doubts if this will even work but it would take some time. BRS
would probably frown on us using the VLS mounting screws locations to
hold the side brackets.
So far I favor the elastic rope method. In both cases I have to sew.
I feel I can hem in the elastic rope much faster than making the lexan
brackets.
Any suggestions welcome. My partner has given me one day (Saturday)
to get this done. It fly's Sunday ready or not.
Jerry Bidle
FireFly
From: | "Bill Weber (DVNS)" <bweber(at)shark.micom.com> |
For a very clean looking wing gap treatment with a BRS mounted in the
wing gap, check out the photo of Mike Holland's FS at:
http://members.aol.com/CesarU/KolbFSII/52.JPG
He made the wing gap seal from aluminum sheet and lexan. It is
attached to the wings with velcro for easy removal. I am planning on
doing mine this way.
* Bill Weber * Keep *
* MICOM Communications Corp. * the shiny *
* Simi Valley, CA * side up *
Subject: | Re: FireFly Gap Seal around BRS VLS Chute |
I made my seal the same way except I sure wish I hadn't used velcro.
It looks easy, and works for a while, but all-in-all I'd rather have
a couple of steel tabs welded to the root rib to carry camlocks or
some other attachment. Same goes for the windscreen if you intend to
use the full enclosure. The short on is bolted on and works fine as
is.
Jim Baker
Pres, USUA Club 104
Jerry,
My original Firestar has flown without the gap seal twice. The stall
speed was increased significantly. Like 3 to 4 mph by my memory (or lack
of it). I do remember that I was supprised how much higher the stall
speed was. And I did't realise it until the second time. After that I
made an aluminum gap seal from .016 2024. Aluminum may be the way to go
for you. My Firestar II has a custom (designed by me) alunimun gap seal
surrounding a soft-pack BRS.
John Jung
> richard pike wrote:
> add the altitude to your distance to go. So if you are one mile from
> goal,
> and 5200' high, it says 2 miles to go. The altitude is not very
> accurate anyway.>
> I would like to know what GPS engine you are talking about here (or do
> you mean all engines?) and exactly where you got your information to say
> that one has to disable the altitude portion of a GPS to get absolute
> accuracy. If what you say stands true, then every one who does not
> disable the altitude portion of their GPS will not be getting accurate
> navigation information because, as you say, the altitude portion of a
> GPS is not particularly accurate (which is a correct staement). I'm
> sure a lot of people would be interested to know the source of this
> info.
The altitude it gives you is the altitude above the center
of the World Geodetic Survey, or WGS-84 Elipsoid. (Remember, the
earth is not perrectly round. WGS-84 is sort of a smoothed model of
the elipsoidal form of the earth....that is, flattened top, bulging
equator) The amount that this varies from sea level differs around
the world, but is a gradual change. For instance, at Altantic City,
NJ, WGS84 0' altitude occurs at about 110'MSL. In Philadelphia, the
variance is just about the same. The varaince between them in,, say
Denver, is different, but probobly not more than 10-20 additional
meters one way or the other.
> Also, if one is approaching Leadville airport in CO at over 10,000ft for
> example, does the GPS add or subtract the sea level altitude or the AGL
> altitude to the position to give the error? Because I was under the
> understanding that GPS gave position on the ground regardless of the
> altitude above sea level, and not an uncorrected GPS position with or
> without the AGL taken into account.
See above.
As for slant range, as you can see it won't become a factor until you
reach several thousand feet, just as Mr Pike explained
Jim Baker
Pres, USUA Club 104
On Fri, 12 Dec 1997, John Jung wrote:
> Jerry,
Thanks for the note on this. Last time i went flying i forgot my gap
seal and vaguely remembered some note of this kind. So, i snipped precious
minutes of daylight left and went home to retrieve it (sigh). Next
time i might just give it a whirl w/out the gap seal, altho on mine,
i've also mounted the strobe on the gap seal itself.
(i made my own lexan seal plus the AL leading edge piece you can get
from Kolb.)
-Ben
From: | "b. steinhagen" <bsteinhagen(at)itol.com> |
Subject: | definition of "datum" |
In doing a weight and bal, the manual talks about weight at the mail
wheel times distance from datum??
manual talks
about weight at the mail wheel times distance from datum??
Subject: | RE: FireFly Gap Seal around BRS VLS Chute |
Jerry
A friend of mine has his chute mounted on the bottom of his Kolb. He
made a box out of light weigh foam and put a door on with velcro taps to
keep it closed
it worked out pretty good
FRANK J. MARINO
>From: jerryb(at)jmd.ods.com[SMTP:jerryb(at)jmd.ods.com]
>Sent: Saturday, December 13, 1997 1:32 AM
>Subject: FireFly Gap Seal around BRS VLS Chute
> vertical.
> brackets.
> Jerry Bidle
> FireFly
Subject: | Fwd: For Sale - KOLB Firestar ( WILDFIRE ) |
owner-kolb(at)intrig.com using -f
www.intrig.com (8.8.4/8.7.3) with ESMTP id NAA17655 for
Date: Sun, 30 Nov 1997 14:53:09 -0500 (EST)
Subject: Kolb-List: For Sale - KOLB Firestar ( WILDFIRE )
Rotax 503 DCDCDI ,OIL injectioned, type B gearbox, electric starter, IVO
ground-adjustable three-blade red prop, full instrument
panel-altimeter,airspeed,tachometer,dual egt,dual cht,compass,vsi,G meter,
slip indicator,mag switch,hobbs hour meter,elevator and rudder trim
indicators,low oil level light,microswitches for wing tip Whelen
NAV-STROBE-Tail position lights
Kuntzleman hot-box,26 amp gelcell battery
Custom made 2 doorwraparound windscreen ,clear floor,5-point safety harness
,pitot and static lines strut mounted,custom throttle-choke quadrant,carpeted
inside,heel brakes, custom made full swivel tailwheel ,MAC servos for
inflight elevator and ruder trim , masterswitch , 1/8 -inch stainless steel
AN swagged ends turnbuckles for all control cables The Firestar name was
used in that the plane is painted in Flames using Poly Fiber products
Daytona White, flames in AN yellow, Eagle Orange ending in Tennessee Red,1/8
inch mahogany seat,all wire throughout plane is shielded and grounded, Ptt
and servo switch are on a G-7 control stick ,all stainless steel rivets used
in construction, fabric was rib-stitched on ,polished boom tube.struts and
landing gear
This is a two time winner of the craftmanship award in 96-97 SUN-FUN, 96 EAA
Reserve Grand Champion at Oshkosh, best ultralight 96 Hagerstown, best
ultralight 96 Potomac, and 96 Winchester . Airframe serial number FSII-478,
engine serial number 4488666
For more info
John Tritle $ 15,000 offers
considered
9895 McClanahan Rd.
Greencastle, Pa. 17225
(717-597-2212)
Subject: | Mark III Gap Seal with velcro and switches |
This is part of a message I sent back in March. If anyone is interested
in purchasing a harness with the switches as shown, I believe Dick
Kuntzleman (610 326 9068) might be interested in selling it, or you
could speak with Dennis at the Kolb factory.
Sent: Monday, March 10, 1997 5:53 PM
To: 'Kolb Builders'
Subject: Wing Gap Seal Holddown
I've come up with a far better method than the "spring" default
for securing the trailing edge of the wing gap seal.
see:
http://members.aol.com/mykolbmk3/gaphold.jpg
First, the square tube is covered at the ends with the "cloth"
side of sticky velcro (white in the picture.) Then the "hook" side of
some "not sticky" velcro strip (a thinner, black strip in the picture)
is secured to the gap seal with rivets through an aluminum plate. The
"not sticky" stuff, designed to be sewn onto fabric, was delivered by
mistake with my upholstry kit.
This eliminates the problem that would occur if the spring came
lose, will not scratch the paint on the square tube, and is very easy to
put on and take off.
If you haven't seen them before, there are pictures of the gap
seal on
http://members.aol.com/mykolbmk3/wgapover.jpg
http://members.aol.com/mykolbmk3/wgaprear.jpg
Velcro is used in lots of different applications, but the biggest
problem is attaching the velcro to the airplane or whatever. Eventually the
glue or double stick tape comes loose and the velcro comes off, and it's a mess.
One way to make the velcro stay put where you want it, is to take
your velcro strip and cut out a strip of .020 6061-T6 or 2024-T3 just enough
smaller than the strip so that you can sew it in to a pocket on the back of
the velcro.
Take the velcro and sew another piece of fabric the same size to the
back of it, on the side where you would normally put the glue. Just sew it
around the perimeter. Use something strong, a piece of
hangglider/Quicksilver, etc. dacron is ideal. Slip the aluminum strip inside
the pocket. Sew the end shut. Rivit it where ever you want, use a backing
plate if you need to attach it to a fabric surface, etc. You can see the
rivit heads nestling down in the velcro, but they don't hurt it's grip.
If your velcro is too wide, it will tend to lift up in the middle.
Use two strips side by side in the pocket, and sew down the middle between
them to keep everything lying flat.
Richard Pike
MKIII N420P (42oldpoops)
Technical Counselor EAA 442
DME measures slant range but GPS does not. Fly over the center of your
home airport at 10000 feet. You will easily get the "distance" to be
well under 0.5 miles. GPS distance is always measured as the great
circle length along the 0 elevation datum, almost universally WGS-84.
If you specify a different co-ordinate system, most GPSs do all the work
in WGS-84 and convert positions at display time. At no time in civilian
GPS receivers is the elevation of the ground or the antenna used in
computing distance.
Tom Kuffel, kuffel(at)cyberport.net
Subject: | Re: GPS Slant Range |
>computing distance.
> Interesting. Shortly after I bought my Magellan 2000, the question
was asked if it supported airspeeds in excess of 100 knots. The best way to
find out was to try it, so I loaned it to another controller at the tower
who had a PA-32. He said no problem with the speed range, but when he had
the altitude readout selected, it added the altitude to the range, and when
you were right up to the fix, it still said 1 mile to go, etc. However, if
the altitude readout was turned off, it was right on the money, rangewise.
Since the altitude portion never worked for beans anyway, I took his word
for it and left it turned off, and the little turkey had been otherwise very
accurate. If I ever get the new gas tank finished so that I can get back in
the air, I will turn the altitude mode back on and see.
Richard Pike
> Interesting. Shortly after I bought my Magellan 2000, ... altitude readout
Richard Pike
MKIII N420P (42oldpoops)>
Well at least I've learned something today. Assume the 2000 is a
non-aviation GPS? None of the Garmins, Trimbles, etc I've ever seen
were programed this way. Nor do they have a way to "turn off"
altitude. Don't see how slant range to sea level would be safe even on
a marine GPS operating on the Great Lakes. I'd hit the bottom when the
GPS would say I was still 500 feet off shore. What does the instruction
book for the 2000 have to say.
Ok, tell me what trouble I'm in for, because I used a bit of contact
cement on the back of the velcro and glued it to the stits paint/dope. Did
it a couple of months ago, and it has stuck fast. Is that going to eat
through my wing eventually?
> the velcro.
> Richard Pike
Talk around the ramp & club is about the pilot that lost his plane a few 100ft
after take off and his gap seal ripped loose, got tangled in his prop,
and he crashed at our airport. Turns out he glued his velcro on instead of
sewing it on to the wings.
-Mark-
TwinStar List Lurker
Paso Robles Ultralight Association
a mess.
enough
>> the velcro.
the
inside
>> Richard Pike
> -Mark-
Which really speaks to using the lexan/aluminum gap seal as presented
in the Firestar drawings. There's no way it could ever come off,
velcro or no.
Jim Baker
Pres, USUA Club 104
<< Now, my idea that having the mount point slightly forward of the CG (of
the
they'll
Just a caution: A friend of mine put snow skis for the first time on his
gyrocopter, took off and at 250' and maybe 65mph spun in and was killed. The
only conclusion that the FAA and others came to was that one of the ski tips
had inadvertently gone down and since it represented a large portion of the
airfoil of the gyrocopter, it dominated the directionalcontrol and caused it
to spin in. I know this is not going to be near as dominant on a Kolb,
however, it could cause a surprise , especially if going fast and may cause a
little panic if the skii tip drops on one ski....or both.
My only point is that the attitude of the tip, i suspect should be
forecastable , with pretty darned sturdy bungees or something, but not just a
little bit of gravity due to a slight offset of CG........There's my 2 cents
GeoR38
I doubt it. More likely, on some nice hot summer day, it will soften
up and let go, and make a mess in three places:
1. Where the velcro used to be will be all gummy and snotty.
2. What the velcro used to retain will make the propeller
REALLY unbalanced.
3. Your bank account. (See item 2 above)
Merry Christmas
Richard Pike
Subject: | Re:definition of "datum" |
The datum is the front of the leading edge of the wing.
John Jung
Re: performance w/o gap seal.
I made a flight without the gap seal on my Flyer once and it was kinda
scary. Keep in mind that even with the gap seal, climb rate is pretty
poor (200-250 fpm max.). Take-off seemed normal but by the time I was out
of ground effect and runway, I could tell it was going to be a struggle
to get any more altitude. Well, I made it around the patch without
incident but vowed never to try that again.
I couldn't imagine that removing the gap seal would make such a
difference until I told the story to an aeronautical engineer friend of
mine. He educated me that by removing the seal, essentially what I had
done was cut my aspect ratio in half and added the drag of 2 more wing
tips. Sort of like trading a 29' wing for 2 - 14' wings. (Insert image of
Homer Simpson slapping forehead here - "DOI!")
I made a new seal from .020 alum. sheet and attached it to the wings with
velcro, has worked fine for 3 years. It has a piano hinge about 24"
forward of the trailing edge to allow access to fuel tank. I do like the
idea of using "dzus" fittings and may add a few someday - just in case.
-Mick Fine
Green Country Ultralight Flyer's Organization (UFO)
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: definition of "datum" |
The business of doing a weight and balance is very difficult to understand for
the novice. HOWEVER, THE IMPORTANCE OF DOING A WEIGHT AND BALANCE CORRECTLY
CANNOT BE OVEREMPHASIZED.
Make absolutely sure you understand how it is done, and it would be a very
good idea to have an experienced pilot (who knows how it is done. Don't assume
someone understands it just because he is a pilot. I know many who haven't a
clue) or EAA technical counselor double check your calculations.
This is especially true if you have used an unusual engine, or added any
unusual gear to your project.
The datum line is a chosen point (this point can be chosen by you) from which
you take ALL your measurements. It can be anywhere on the aircraft, or really
anywhere near the aircraft.
For simplicity in your computations you might want to use the very end most
point of the nose. That way you don't need to compute using any negitive
numbers.
It also makes accurate measurements easy. Simply drop a plumb bob from the
nose to the gtound, mark that spot on the ground and measure to the center of
the wheels.
You can drop a plumb bob from the leading edge as well.
Figuring a weight and balance is actually the same as getting an average of
say three numbers. You add up the three numbers and divide by three (that
being the amount of numbers you have.) Now numbers of course all have an equal
value. That is to say that they all represent a quantity of ones.
The numbers that you are going to add together in your weight and balance
calculations do not represent equal values. Each measurement you take(from the
datum line) represents a different weight. So rather than doing a simple
average, you are doing a weighted average. To do so you multiply the
measurement by the weight, then like the simple average, add up all the
results of those multiplications and divide by the total of all the weights.
Think about this a little and it will make sense.
W Grooms
CFI
Subject: | Re: Flying on skis in the winter? |
> Hello,
> Does anyone have any advice regarding flying in the winter on skis?
If you can find a copy of the FAA Advisory Circular 43.13-2,
Acceptable Methods, Techniques, and Practices: Aircraft Alterations
in chapter 5 there is a good set of pictures, how to determine the length of
the front and rear safety cables, how strong the front bungee needs to be, etc.
I looked for a while last night but could not find a URL for FAA
Advisory Circulars. If any body knows one, please share it around!
Anyway , the drawings showed the axle pivot point to be about 45% up
the ski bearing surface, so that 45% of the ski is behind the axle, and 65%
is ahead of the axle. That did not count the curved up nose , just bearing
surface.
A few other things, in case no one can come up with a URL so that we
could all go look at the AC: The main ski incidence angle is determined by
the length of the rear check cable and should be 5 degrees nose high. The AC
made that relative to the fuselage being level to the surface, but where the
Kolb has a fairly good angle of incidence of the wing, I think I would make
it 5 degrees nose high relative to the wing, otherwise if you raise the tail
for takeoff until the wing gets level to the runway, it would stress the
system, because the fuselage gets tail up well past level with the
surface,the rear check cable would be too short.
The front check cable should limit the ski's maximum nose down angle
to 20-35 degrees. The front bungee should be strong enough that the wind
cannot cause the ski to flutter, or accumulated snow cannot likely make it
hang low. There is a table of aircraft weights, (and they are all at least
twice what we would use) but the least rate they specify is at least 20-40
pounds pull to hold up the front of the ski.
To avoid stressing the landing gear, the axle pedestal height should
not exceed 130% of normal height, or distance from the axle to the surface
with tire and wheel installed.
Under ideal conditions, takeoff distance will increase 10%,
increasing as temperatures go below 32 degrees, or snow is not smooth and
packed. Landing distances will increase 20%. It doesn't say why.
If snow is crusty, a crust-cutter cable is suggested to keep the
snow from cutting the bungee.
Merry Christmas
Richard Pike
T Swartz wrote:
> Richard Pike wrote:
> > > Hello,
etc.
> > Anyway , the drawings showed the axle pivot point to be about >
> > Merry Christmas
> > Richard Pike
> Richard
> Here is an index for FAA Advisory Ciculars, but the one you listed isn't
> there.
> http://www.faa.gov/avr/afs/acs/ac-idx.htm
> This is a good one for all builders.
> AC No: 90-89A
> ULTRALIGHT FLIGHT TESTING HANDBOOK
> Terry
>REALLY unbalanced.
I covered a Vector 600 with stits and contact cement then painted over
with latex house paint. It sat outside for 8 years untill I retired it and
when I stripped it down the fabric was still strong and the glue would not
come unstuck very easily.It was a lot harder than stripping fabric put on
with polytac.Later I learned that the HiPec systems wonder glue was contact
cement. That is what I hold my fabric with on my Twinstar and so far no
problem. I would not worry about using contact cement to hold the velcro
on. Of course there are different quality contact cements and you usually
get what you pay for.
Woody
I had long talk with the Stitts guys a while back when I wanted to put a line
of two inch velcro on the inboard wing fabric of my Mark 2. The fabric was
painted with polytone. They recomended stuff called Pliobond, which I found
at the hardware store. Just follow the directions on the bottle. The stuff
is very sticky. I used painters paper tape to mask off all the places where I
didn't want it to be.
<< Turns out he glued his velcro on instead of
sewing it on to the wings. >>
This is an interesting point. I glued the velcro on the gap seal of my mark 2
but I used 2 inch velcro, which is farily hard to find AND I wrapped it all
the way around under the leading edge of the wing. Even if it did come loose
in the back and flap around, which it never did, it could not have gotten into
the prop. The nice thing about this was that when the gap seal got filthy I
could take it home and put it in the washer.
>problem.
> Woody
This sounds like good stuff, but I am not sure what you are
referring to. Exactly what is it that Hipec uses that sticks so good, their
fabric cement or a special glue?
Richard Pike
Subject: | Loose windscreen on Firestar II |
Group,
Sunday my Firestar II was taxied for the first time, and I found a
problem. The (short) windscreen was so loose that the air pushed it down
allowing me to get undeflected, 32 degree air into my face and eyes.
Also the rubber front edge trim started to come off. Did I miss
something in the plans? Is there suppose to be more to attaching the
windscreen than the four screws? Did I just not stretch it tight enough
before drilling the holes? Who has had this problem and how have you
solved it? The good news is, that is the only problem that came up.
John Jung
Subject: | Advisory Circulars |
The following address is for the FAA AC index:
http://www.faa.gov/circdir.htm
Subject: | Re: Loose windscreen on Firestar II |
I had no problem with the same, short windscreen. I did glue the rubber
gasket to the Lexan, and I did leave an ample of overlap with the cowling,
and I did pull it tight. I can press on the top of the screen and it will
not move. I'm relatively short (5'7") and the blast, unfortunately does
just strike my forehead. I wear a classic leather/wool pilot cap, with
astrap under the chin and a pair of quality moto-cross goggles.
A safer alternative would be a motorcycling helmet, of course.
Bruce
On Mon, 15 Dec 1997, John Jung wrote:
> Group,
> John Jung
Two points to the individual who can explain what determines where
the CG is located.
Jim Baker
Pres, USUA Club 104
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
Subject: | Re: Velcro /safety |
IMHO this points out more a problem with lack of responsible preflight
and care more than anything to do with glue/velcro/etc. Things don't
just suddenly flutter loose from a properly cared for and preflighted
airplane, yet the public starts to think so, and heaven forbid, maybe
we do too? This type of pilot error occasionally kills somebody, and
*always* degrades all of aviation. I don't want to sound sin-free
here; I'm just lobbying for a responsible attitude check among those of
us committing aviation.
Ben Ransom (*)
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
Subject: | AIRSPEEDS/ENGINES |
I have been watched the Kolb list for a while and one thing I have
noticed is the variance in speeds reported for different aircraft. I am
considering the MarkIII and know that Kolb is really pretty conservative
with their claims (nice for a change!). I was wondering if everybody
with a MarkIII could post their planes stats. (I don't mean to flood the
List with redundant information but this is more for my info....so you
can E-mail direct to me if you'd like and save workload on the list)
weight=3D
engine=3D
stall=3D
cruise=3D
top level speed=3D
any modifactions or extras that would affect speed.
full/partial enclosure?
drag reduction measures (i.e. wheel pants,etc.)
Thanks a ton....
Jeremy Casey jrcasey(at)mindspring.com
for a while
and one thing I have noticed is the variance in speeds reported for
different
aircraft. I am considering the MarkIII and know that Kolb is
really pretty
conservative with their claims (nice for a change!). I was
wondering if
everybody with a MarkIII could post their planes stats. (I don't mean to
flood
the List with redundant information but this is more for my info....so
you can
list)
weight=3D
engine=3D
stall=3D
cruise=3D
top level speed=3D
speed.
pants,etc.)
Thanks a ton....
Jeremy Casey jrcasey(at)mindspring.com<=
/DIV>
>the CG is located.
>Jim Baker
>Pres, USUA Club 104
> I'm going to stick my neck WAAYYYY out and submit that the Center of
Gravity needs to always be slightly ahead of the center of lift, for the
following reasons:
If the center of gravity is behind the center of lift, the aircraft
will be unstable. The aircraft will try to pitch up, and a stall is likely.
A stall becomes unrecoverable under normal situations, the nose will want to
stay up. Control authority may be insufficient to keep the nose down at slow
speeds.
If the center of gravity is too far ahead of the center of lift, the
aircraft will be very stable, but may not have enough control authority to
take off, or flare when landing. Slow speeds limit control authority.
The CG is determined by the designer's instructions! If unknown,(I
HATE IT when that happens!) 25% back from the leading edge of a non-canard
type aircraft is normally airworthy, not to exceed 30% back.
Richard Pike
From: | "Ronald G. Blaylock" <rgbsr(at)aimnet.com> |
> >the CG is located.
> >Jim Baker
> >Pres, USUA Club 104
I do believe he what determines where the CG is located not what
determines the allowable range of the CG.
But then I've been known to pick nits before....:~)
Ron B.
> following reasons:
> speeds.
> Richard Pike
Ron Blaylock - AMSC USN (retired)
< ron.b(at)cheerful.com > Living in San Jose, California
< rblaylock(at)mail.arc.nasa.gov > Flying from Lodi, California
Mk iii s/n M3-247
Empty weight: 461
Engine: 582, "C" box, recoil start, HAC
Prop: Powerfin 3-bl 66" composite, set at about 18 degrees as measured at tips
Stall speed: around 34 solo no flaps, mushy below 40
Cruise: 65mph seems nice, quieter and economical
Top speed: 85mph with prop pitch set for compromise between speed and climb
Max. climb rate: around 1200 fpm solo in 40 degree weather, as pitched today
Modifications from plans: none significant, Kolb aileron counterbalances added
Full enclosure: yes
Wheel pants: no, but thinking about them for mud reasons
Streamlined struts: yes (standard equip on Mkiii)
> >the CG is located.
R Pike writes....
> following reasons:
Two points awarded. Pull your neck back in.
Every airfoil has a center of lift.
Jim Baker
Pres, USUA Club 104
Subject: | Performance Stats |
I have already got 2 request from listees to compile the results of the
performance numbers. I will compile all information sent to me and post
it on my web page.
Now come on MarkIII builders out there, take a minute and mail it to me.
It's not just a favor for me anymore it's your civic duty!! (Maybe
"duty" is a little strong,,,Let's just say it would be appreciated!)
listees to
compile the results of the performance numbers. I will compile all
information sent to me and post it on my web page.
Now come on
MarkIII builders
out there, take a minute and mail it to me. It's not just a favor
for me
anymore it's your civic duty!! (Maybe "duty" is a little
/DIV>
On our Firefly which may be slightly different, we put fitted ours
first without the rubber which probably helped assure a tighter fit.
We also trimmed the lexan so it only overlaps the nose cone a couple
inches and is flat (parallel) against it, not at an angle riding on
it. (We used a light shinning from inside thru the lexan protective
paper to mark the line of the instrument panel/nose cone, then moved
the line 1" or 2" using width tape needed as cut line.
The lexan with the Firefly cut nice with a good pair of tin snips.
You then have to sand/file the edges a little but it worked good for
us.
We also used tape to establish the top of the windshield trim line.
Another optional thing we did was create a painted glare shield.
While mounted, again using the light method to establish the relative
position of the instrument panel. We marked it at points on the
protective paper. Then removed the lexan, laid a couple 1" wide
strips down to move the line up and placed a 3rd strip to be the final
paint edge. Masked off the other areas, (don't use news paper it
bleeds thru) and painted the inside surface with Krylon semi-flat
black. The semi black versus ultra flat don't rub off as easy and
blacken where it rubs against the nose cone when mounted.
(Note: A handy type of tape is a 3M long-release masking tape. It's
blue in color, not quite as sticky as normal masking tape and will not
leave adhesive behind when removed up to 7 days later. We exceeded 7
days many times. It's pricey like other 3M tapes but is great stuff.
Being low stick, it normally wouldn't pull paint off unless its very
poorly adhered.
We also marked and drilled the mounting holes without the rubber.
Then we pulled it back off, put the rubber on the lexan, and did a
test fit with it. (Mounting holes tighten up) Took it back off, with
the lexan backside up squirted a little silicon between the back part
of the rubber and the lexan. Left it lay to set up and remounted it
when cured. Worked great.
______________________________ Reply Separator _________________________________
Subject: Kolb-List: Loose windscreen on Firestar II
Date: 12/15/97 8:26 AM
Group,
John Jung
Subject: | It's a FireFly - First Flight |
By Jerry Bidle 15-December-1997
Well it happened this Sunday, 14 December. My partner, Gary Hansen
was the pilot for our FireFly's first flight. It is equipped with 447
Rotax, 2 blade IVO prop, BRS 750# VLS chute, brakes and short wind
screen soon to be converted to the full enclosure.
First take off and landing were uneventful. Second takeoff was
aborted due to "it sticking to the runway". Third takeoff went fine.
Being late in the day and a little cold, the flights were limited to
around the pattern. Everything seemed to function as expected. We
both have fallen in love with the EIS system from Grand Rapids
Technologies, it's great.
Another inspection will be completed before its flown again. One
brake cable developed some slack and will need adjustment.
I have not flown it yet, maybe this coming weekend weather permitting.
I need to talk to Dan at Kolb about technique. Just as we were doing
the weight and balance and had it on the scales, about 10 people
showed up at the hangar. Not exactly the time for visitors.
Gary acknowledged that it flies different than what he's used to, a
Citabria & N3-Pup both tractor engine configurations. He commented
about experiencing the characteristics of the high thrust line which
has a tendency to push the nose over (down) as you increase power on
the takeoff roll. On the aborted takeoff he said it would not come
off. I contribute this to technique. He said he applied full back
stick and it would not come off? From observation of the 3rd T/O run,
I appeared he may be holding it in a tail low attitude. The tail was
in low position, rose suddenly, and then it broke ground very shortly
thereafter. He is concerned about it going on it's nose thus may be
over compensating with back stick.
One thing he did say is it picks up speed very quickly. Rate of climb
without pushing it 600-700 fpm. For this flight we had it propped for
6300 static run up, a cruise setting. Hopefully we can fly a littler
earlier in the day while it's a little warmer and gather more precise
performance information.
We still have a few things to do. Figure where to mount the Icom A22
radio and make coax and push to talk connections. Finish the wing
root gap seal around the VLS parachute container. We flew it with the
gap seal front part installed on the Velcro and rear part rolled up
and taped down in front of the chute with 100-MPH tape. I still
considering making a stirrup so I can get in and out of the thing
without tearing of the windshield or falling on my face. Sometimes
being short is not an advantage. (My partner thinks he has it to
himself since I can't get in and out of it)
So far so good. After my partner briefing me on how it acted, I feel
a little less confident about flying it but will give it a go. I like
him, have only tractor configuration experience in the same model
planes. It flies great in the air and appears to be very stable.
Well give more detail and figures as thing progress. A major
milestone of life has been meet this weekend.
Jerry Bidle
Gary Hansen
<< Group,
Reply:
Depends on how current the windshield is. The windshield has gotten larger in
past several years. Before then, the problem as described, could usually be
attributed to not fitting tight enough around nose fairing. Windshields that
were a bit loose would collapse as described; whereas the same windshield, if
it fitted snugly, would stand up just fine.
You could do two things: 1) trim the windshield so it is a bit smaller & make
sure it fits tight over the fairing, or 2) install a reinforching loop toward
rear of windshield to make it stiffer. We made one of 5/16" x 035 alum
tubing which was curved approximately to fit the curve of windshield. This
was held in place by 4 rivets through the lexan into the tube. The bottom of
the loop simply butts against the longerons. It is a pretty simple
installation and keeps the windshield at its max height which gives better air
deflection.
Dennis Souder
Pres Kolb Aircraft
Subject: | Re: It's a FireFly - First Flight |
Congratulations!
I don't at all presume this to be it, but I do know it is possible to be
so married to a previously learned technique that it can be repeated
subconsciously. In other words, it is possible Gary is lifting the tail
(aka pushing the nose down) as a learned habit from Citabria and N3.
Even more likely, it may be that the nose dip of the Kolb is just
a Lot Unlike what he became used to and comfortable with in the other
planes. He would not be the first to show concern for the nose dropping
characteristic of Kolbs powering up on take-off.
If that is all it is, you'll get used to it very quickly. If there is
something amiss, you'll probably realize that too after more trials, altho
that assumes you're sure about correct CG and all other check-out details.
Just figuring it out carefully/slowly will tell. I'll spare you all from
my sermon about the benefits of a lot of high speed taxiing.
Next time go to a major airport and borrow one of the motorized boarding
stairways. :-)
Again, Congrats!!!
-Ben
Subject: | Ski rigging again |
my original FireStar. I put the axle 1" ahead of the CG of the ski (this
is 39" from the tip on the type of skis I have). My skis are about 5-1/2
feet long and I can land in snow that comes up to my thighs when I get
out of the plane. I do not have a tail ski but in recent years I added a
triangular piece of oak to the tailwheel post. This keeps chunks of ice
from hitting the tailwheel. I have it hose-clamped on there around a
are also water skis with the same dimensions as the old ones. The FS II
angles are the same as the original FS. I helped a friend rig his FS II
and it was the same. I might add through personal experience that if you
happen to rig the angle of the ski tipped up high, the drag on the plane
will be tremendous and you may need full power to stay in the air! I
witnessed a FS owner who rigged his short skis wrong and they turned
upside down in flight. He noticed this on approach and tried to upright
the ski while landing. He managed to get that one, but he didn't see the
other ski in the same condition. For unknown reasons, he chose to land in
deep snow when he could have landed in a spot where the snow wasn't so
deep. Upon landing, the inverted ski dug in and flipped the plane on its
back. Ironically, I had warned him prior to flight that his skis could
potentially flip upside down by grabbing hold of the ski and twisting it
around the axle. He's around, but doesn't fly anymore.
If the skis are rigged properly, the plane will have less drag than with
wheels, ie. faster cruise.
Ralph Burlingame
Original FireStar
From: | Cliff and Carolyn Stripling <striplic(at)dfw.net> |
Subject: | Test time about over... |
To all,
I got in a couple of hours today. It was a nice fairly warm day. On
inspection I noticed that my cable splitters had loosened up (meaning
unscrewed a little) some in the bracket I made for them. I thought I had
them tight, evidently not tight enough.
I practiced aborted take off's, did a lot of T & G's, and generally tried to
fly just off the runway and under control - something I practice a lot. It
isn't easy sometimes, depending on winds and gusts.
I am due for an annual and a 50 hour Rotax inspection soon. I missed seeing
Gary and Jerry's Kolb Firefly first flight. Dang it!
Later,
Cliff & Carolyn Stripling Him: Kolb MKIII - N582CC (37.3 hrs)
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
Both: 5th Wheel - RV - Travel
____________________|_____________________
___(+^+)___
(_)
8 8
>the CG is located.
The cg is located where after you hang all the stuff you are going to
hang on your aircraft the aircraft will balance.The mechanical way is to
hang your aircraft from a tree at the recommended balance point the mfg.
gave you.If the nose or tail makes a quick dive for the ground you must
reconsider your options or at least move these options to the side pointed
to the sky. Mathematically if you take your datum point to be 1 foot in
front of the nose and add what weighs what and at what distance from this
imaginary point jumble the numbers around a bit and just like magic you
will know where the balance point is.In the case of an aircraft(in proper
flight attitude) measure from this imaginary point to the front axel and
insert the weight on the scales to this measurement.Measure from the datum
point to the tail wheel and record this weight and distance.Now for the
hard part It may take a good 5 min. but the results are worth it. Multiply
the individual weights in lbs by the distance to the datum point.This gives
ft lbs. add all your foot lbs together and divide by the total
weight.This will give you a number from the datum point and if you were to
hang your plane from a tree it would balance there.Its a miracle!
from datum gives 5 ft/lbs.A 10 lb weight 4ft. from the datum is 40
ft./lbs.Together they are 45 ft.lbs. Divided by the total weight of 15lbs
gives a datum point of 3 ft.If you drew it out you will see that you are
holding a yardstick with a 5 lb weight on one end and a 10 lb weight on the
other and it balances at the foot marker nearest to the heavy weight.Or to
simplify it one more step the fulcrum is twice as far from the light weight
as to the heavy weight
This has been a lot of work so I will look forward to those 2
pints.Perhaps at Osh Kosh.
Woody
>>problem.
>> Woody
> Richard Pike
The HIPEC system uses contact cement as their special glue to hold the
fabric on the wings.I searched untill I found a can that claimed the glue
was water resistant.The fabric was glued together like polytac and the
heating with the iron is claimed to activate the glue and bond it
together.Worked good for me.
Woody
you are right , but dose the bottom of the wing have to be at some
degree in order to get the datum to the wheel? ,For a quick check on my
plane my tail boom will be at 6.5 deg. this would put the bottom of the
wing at the right angle
>John Jung
Jerry
Don't cut any corners tell your partner that you two should not fly
until it is ready if KOLB thought that it did not need the gap seal they
would not have put it in the planes
IF somethings happens no one could say IF you had the gap seal like it
called for maybe this would not have happened " just a thought "
RICK
On Sat, 13 Dec 97 00:32:39 cst jerryb(at)jmd.ods.com writes:
>which
>This
>covered
>where
>hole)
>you
>since
>ever
>the
>Make
>left
>work
>wing
>to the
> vertical.
>BRS
>locations to
>sew.
>lexan
> brackets.
>(Saturday)
> Jerry Bidle
> FireFly
Jerry,
I agree with Rick. I think that you guys should step back and think
soberly about what you are doing. In 10 years of being part of a large
ultralight club, I have observed that people who let there enthusiasm to
fly affect there decisions, seem to have accidents eventually. The
objective should be to keep risk to a minimum so that we don't wreak our
planes or our bodies, allowing us to do much more flying in the future.
Here is my idea about how to reduce risk. If you have one thing that
increases the risk, evaluate it and decide. If you have two things,
don't even think about it. Fix one first, then decide. In evaluating
past accidents, there are usually two or three things that contribute to
the cause. A new plane of a type that you are unfamiliaar with is
already two by my count. The gap seal is three. I am not saying that
you shouln't fly, just keep a perspective when you make the decision. I
am really writing this for everyone, you just presented an example that
made me thing about it.
John Jung
> Jerry
> RICK
> >which goes between the wings on the FIRE-FLY. We have used the BRS VLS
> >This has made installing of the gap seal more complex.
> >covered with the fabric gap seal material if it were possible.
Rick,
On my plans for both the Firestar II and the origianl Firestar, the
bottom of the wing should be at 9 degrees. All measurements are based on
the plane being in that position.
John Jung
RICK M LIBERSAT wrote:
> John
> >John Jung
<< tell your partner that you two should not fly
would not have put it in the planes >>
I agree with this position. I flew my mark 2 the first time without a gap
seal, canopy or altimeter. It was very dumb.
Several years ago, Jack McCornack, Pterodactyl designer and writer
for Ultralight Flying! magazine made a wonderfully wise statement:
There is something worse than being on the ground
wishing that you were up in the air;
it is being up in the air,
and wishing that you were on the ground.
Richard Pike
Subject: | Re[2]: FireFly Gap Seal around BRS VLS Chute |
We installed it where majority of it was in place and small area on
top was rolled up and taped down with 100 MPH tape. It flew fine in
this configuration. We been told it will fly with out the wing root
but didn't want to push the stall numbers any higher until we new what
they were.
Were going to modify it by cutting a hole in it for the BRS VLS chute
and hem a elastic bungee cord around the cut out area to seal it
against the container. It should work fine.
Now if I could just get into the thing. Cliff felt sorry for me and
dropped of some seat belt material to make a stirrup out of. (Were in
Texas) Having tried on Kolb's demonstrator, it suddenly dawned on me
why I can't get in to the thing. Their demonstrator had 5" wheels and
I had to stretch to get in and out of it. We have 6" FireStar wheels
and that raises it just enough it make it really difficult for me to
get in or out.
Got to run,
Jerry Bidle
Subject: Kolb-List: Re: FireFly Gap Seal around BRS VLS Chute
Date: 12/16/97 7:56 AM
Jerry,
John Jung
> Jerry
> RICK
<< On the aborted takeoff he said it would not come
I appeared he may be holding it in a tail low attitude >>
Jerry, if it is anything like my firestar, I have experienced the same dilemma
if you want to call it that, but I attribute the slow take off with the stick
all the way back to the very small tail wheel digging into the turf causing a
lot of friction. For this reason, I always take off with my stick forward to
get the tail wheel off the ground then ease back til ground is broke then I
go nuts into a steep Kolb climb!!
GeoR38
Subject: | Kolb Small Windshield |
Another way to handle the flexing problem sometimes found with the small
windshield is to use thicker Lexan. The Lexan supplied in the kit is .070
thick. I substituted .090 material, same as the full enclosure. It is
much stiffer and yet still very workable. At the same time I extended the
windshield 6 inches so that it protects my face from the slipstream
completely. Even with the extension there is no flexing at all.
Temperatures have been in the mid 40`s this week, making flying here in
Minnesota a real pleasure. I do not use a snowmobile suit. Too bulky.
Makes it almost impossible to get in and out
the Firestar. Ray Lujon, Woodbury, MN
From: | Jhann Gestur Jhannsson <johanng(at)ok.is> |
Subject: | Looking for a used Firestar |
Dear Kolb flyers/builders
My friend in Iceland saw my new Firestar flying last month and only thing
he wants today is to own a Firestar ultralight.
He has asked me to try to find a used Firestar that needs work on airframe
or on the engine, or even without an engine.
If anyone on the list knows of any Firestar like that for sale, please
send me an E-mail.
Merry Christmas from Iceland, where Santa lives.
Jhann G.
E-mail: johanng(at)ok.is
I ordered a Hushacom intercom and 2 headsets before Thanksgiving after
researching quite a bit and flying with them with kolb etc. Today I got their
phone message that they are out of business. I need advice from fellow kolb
fliers on what they are using. It's for my Firestar 2 with a handheld Icom
radio. The front is enclosed but the passenger in ther rear receives a lot of
air noise.
I even talked to all the manufactures at Oshkosh and most of them including
Sigtronics (which I was also very interested in) said I would not be happy
with theirs because of the high wind noise created in the micra phone.
The Hushacom unit does not have a squelch, rather it's on all the time, and
they tell me that's what is needed for our type of airplanes.
Give me some advice on what everybody is using and if you are satisfied.
Subject: | Re: intercom advice |
>Thanks
>Tim
> I am using a Flightcom II MX intercom with the Flitecom 4DX headsets.
I
am satisfied with the performance of both. When I first added the Lexan
rear inclosure to the MKIII, it didn't work too well, all that Lexan gave
too much noise amplification. A friend in the stereo business suggested
some baffling foam, so I cut some out and attached to the inside of the
lexan, and it was amazing. Cut the noise by more than half.
When I had the Anglin J-6, the inside of that airplane was not very sound
absorbing, it had a Rotax 532 also, and without headsets on it was
deafening. I had a Soft Comm brand intercom, it worked almost as good as
this one, but the Soft Comm brand headsets were not near as comfortable.
Richard Pike
timandjan
I have been trying to go with the HUSH-A- COM for about 9/ 10 weeks and I
have been told by RAY ANDERSON it is in the mail over and over again As
far as I an concerned the hush-a-com Ray IS a no good liar and I have
the long distance phone bills to prove it. I will give any vendor the
benefit of the doubt but when they LIE over and over to the people who
are willing to buy their product they are no good snakes
DENNIS SHOLDER you have a very good airplane and your staff are top
noch
but the intercom you are using , well it dose work very good . BUT Ray
Anderson
has lied to me ,as well as Houston, TEXAS LITE FLYERS CLUB.
TIMANDJAN I have talked to two of my friends one in HOUSTON ,THE OTHER
IN DALLAS.
Both are KOLB MK. III owners and use the COMTRONICS intercom and love
it. They have a system that I like and will buy it It will let you
use 2 radio's and transmit on either one while montering the other. I
talked to them today TIM ( did not get his last name) is one of the
tecks. that will be doing the work on my helment to convert it to their
units I will let you know how it works in my M III with a ICOM A 21 /
an a rat shack CB
I hate to say bad things about folks but Ray Anderson sure made a fool
out of me
TERRY SWARTZ you did the right thing by not messing around with
hush-a-com as long as I did.
RICK
>got their
>kolb
>Icom
>lot of
>air noise.
>including
>happy
>time, and
>satisfied.
>Thanks
>Tim
From: | "Rinehart, Mark W." <Mark.W.Rinehart(at)Allison.com> |
Subject: | Mark III Building Time |
Dear KOLB Enthusiasts,
I was surfing the web the other day and ran across a Mark III builder
who said it took him 1785 hours to build his KOLB! I didn't think it
took near that long. The Kolb literature says about 500 hrs to build.
How about it Mark III builders? Could you post your estimated build
time?
Mark Rinehart
Subject: | Re: Mark III Building Time |
npex01.allison.com>
>time?
>Mark Rinehart
Working part time, it took about 4 months to build, and then another 18
months to wire, plumb,cover, and finish. I sent my check in March, and flew
the following October. If I had used the stock gas tank arrangement, and
throttle set up, that would have saved a couple months. I would consider it
a very easy airplane to build.
Richard Pike
It took me 525 hrs over a seven month period to get the MkIII (serial
#022)signed off and flying on floats on Aug 6 1991 and I spend
an additional 175 hrs to complete the enclosure,BRS installation
and retractable wheels and waterrudders. It was the second
customer build MkIII flying. Fred Anderson beat me to it by 7
days.
Frank Reynen MkIII@430hrs
http;//www.webcom.com/reynen
time?
Mark Rinehart
Date: Friday, 19 December 1997 12:15pm ET
Subject: Kolb-List: MARK 2
I HAVE A KOLB MK.2 WITH 87hrs.ON ENGINE AND AIRFRAME.AIRWORTHY.
I WILL ONLY SELL UNASSEMBLED FOR PARTS.LOST MY MEDICAL.
THIS IS A TWO PLACE THAT COULD BE MADE INTO A SINGLE PLACE.
FLYS EXCELLENT.
BOB RIVARD
RIVARD(at)MACOMB.CC.MI.US
PLANE LOCATED AT PORT HURON MICHIGAN.
WILL BE BACK JAN. 5th.
> air noise.
> Thanks
> Tim
I have been talking to Ray at Hush-A-Com since the beginnig of Nov. He
kept telling me it was in the mail. Then he said it came back, and he
sent it again. Still didn't come. I kept calling and believe it or not
it showed up yesterday UPS. I didn't know they were going out of
business.
I had been using a David Clark headset with an Icom A-22. I worked ok
at lower power settings, but at high power settings which created high
noise levels, other pilots couldn't understand me. Said I was breaking
up. I borrowed a Hush-A-Com from a friend and it worked much better but
the headsets are not as comfortable. I'll probably stay with the
Hush-A-Com since I have it now.
Good luck
Terry
Subject: | Polytak VS Polybrush |
Are you suppose to use Polytak for gluing the fabric over the fabric,
for example the 2" overlap on the leading edge of the wing is that
entirely polytak? I know you use Polybursh for patches and tapes.
>time?
I am helping to build a Mk111. I would think we have between 4 and 5
hundred hours. I documented my Twinstar at less than 150 hrs. The high hour
projects often show a high degree of fussyness or a lack of skill with
tools or reading blueprints. I was able to get a good deal on my Twinstar
kit because the original owner had his mind boggled just reading the
prints.On the other hand using my hands,tools,and reading prints are second
nature to me.I am also familiar with Kolb building techniques which
resulted in the reduced building times. So all things considered it still
all depends on you
Don't be scared off.The 500 hr estimate is a good average for an average
project. Some people can put 500 hrs in their paint job. If you need help
just ask the list.
Good luck Woody
From: | "Clifton C. Curtiss" <c45(at)mindspring.com> |
Subject: | ultralight Firestar |
I am building a Firestar and would like to have it
weigh less 254 lb. The 2SI 35hp engine w/belt drive is
advertised to weigh about the same as a Rotax 277.
I would appreciate any comments/remarks
concerning: a) the feasibility of an ultralight
Firestar b) builder's actual Firestar
gross weights c) using the 2SI 35hp
w/belt drive
Folks,
I took my steel parts for kit number one to a local powder coating
company last week. Today when I went to pick them up they told me that
they could not coat my parts. There reason was that there distributor
for the coatings told them that MEK and other solvents eat through the
coating. Has any one else heard of this? Is there more than one type of
powder coating?
I made the mistake of telling him that they were airplane parts. That
might have scared him. I guess next time I'll tell folks that they are
"tractor parts"
I guess I'm back to Primer and Paint.
I hear that Sears has a sale on weather beater this week :-)
Peace,
Mike Sharp
Kolb Mark III
Cut First Tubing, 11-28-97
Folks,
I took my steel
parts for kit
number one to a local powder coating company last week. Today when
I went
to pick them up they told me that they could not coat my parts.
There
reason was that there distributor for the
coatings
told them that MEK and other solvents eat through the coating. Has
any one
else heard of this? Is there more than one type of powder coating?
airplane
parts. That might have scared him. I guess next time I'll
tell folks
that they are "tractor
parts"
Paint.
weather beater
this week :-)
Peace,
Mike Sharp
Kolb Mark III
Cut First Tubing,
11-28-97
Subject: | Re: ultralight Firestar |
> concerning:
> a) the feasibility of an ultralight Firestar
> b) builder's actual Firestar gross weights
> c) using the 2SI 35hp w/belt drive
Clifton,
I have my doubts that any Firestar could make the legal weight without
undesireable changes. Also the 2si people have been having manufacturing
problems this year. To use one of their engines before they demonstrate
that they have their problems solved would be a BIG mistake. Do not be
their unpaid test pilot.
Has anyone in the group made the weight with a Firestar? Does anyone
even know of someone that claims to have made the weight? The only claim
that I am aware of is Kolb's claim that it can be done with a 277.
John Jung
Subject: | Repairman's Certificate |
To all,
I have been trying to get a repairman's certificate for my homebuilt
"experimental" plane. I called the FAA's FSDO office here in Dallas to
inquire on my application. It was mailed to them at the end of October.
They told me that I would have to come down to the office in person and sign
a form - not sure what form. I suppose it is the same form as used to
request the certificate. They will not issue one by mail. I will present
myself on Monday and dot the "i" and cross the "t" for them. I did not know
in advance that this would be necessary. The instructions on how to apply
did not say to go in person and I have not heard of other FSDO offices
requiring such action. Each office must "makes its own rules" about such
things... or it might be possible the general application rules have
recently changed.
Anyone who is about to make application for this certificate might want to
check by phone with their nearest FSDO before sending in paperwork. It
might save them some time.
Later,
___(+^+)___
(_)
8 8
From: | "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM> |
Subject: | FLAT SPOT PREVENTION |
Does anyone know a good way to store your aircraft so the tires don't get flat
spots? I am trying overinflation, any other ideas? Thanks...
Subject: | Re: Repairman's Certificate |
sign
Cliff,
When the DAR did my initial inspection, I signed a form that he brought for
the repairman's certificate. After about 6 weeks, I received the temporary
copy by mail with a statement that the final copy would arrive within 60 (I
think) days. The other day, I arrived home to find a message on my machine
from the FAA office in Birmingham saying that I should fax them a copy of my
drivers license because they needed a picture ID for their paperwork. I
faxed it that night, but can't imagine that it was good enough quality to be
useful. I never heard back from him though, and should receive the
permanent copy by the end of this month according to my notes. We'll see.
Unfortunately, work has been a disaster recently, and I haven't even been to
the hanger in 3 weeks. The only small chances I've had to fly were
eliminated by the weather.
Hope everyone has a happy holiday.
Rusty "Deciding on the next project" Duffy
From: | Frank Metcalfe <fmetcalf(at)ix.netcom.com> |
Subject: | Re: FLAT SPOT PREVENTION |
Try to take the weight off them by jacking the plane up.
> get flat
<< I have been trying to get a repairman's certificate for my homebuilt
request the certificate. >>
That was the drill for my Mark III also. I had to go to Milwaukee FSDO to get
of the repairman's cert paperwork at the same time & location as the
airworthyness insp.
It took only six short months for the permenant certificate to arrive.
writes:
<< Dear KOLB Enthusiasts,
time?
That time log must have included lots of 'thinking time' and probably time
sitting in the partially completed airframe making airplane noises!
Subject: | MKII/TwinStar Design Question |
My pardner had the idea to replace the tailfeather hinges with
aircraft clevis pin assemblies....Has anyone done that? Anyone
know if structural strength would be compromised by removing
those angle brackets...and installing the clevis pin assemblies?
Your input would be appreciated! :)
-Mark Swihart-
TwinStar #46
<http://www.tcsn.net/mswihart/twinstar.htm>
From: | "Richard neilsen" <NEILSENR(at)state.mi.us> |
Subject: | Mark III Building Time -Reply |
My VW powered MKIII took 3 years elapsed time. In this time I took app 6
months off to rebuild my house that burned and had times were just
didn=27t have any motivation. As for the exact hours?? 500-600 seems
close. I also spent at least 100+ additional hours working on a non
standard engine.
>>> =22Rinehart, Mark W.=22 12/19/97
08:00am >>>
who said it took him 1785 hours to build his KOLB=21 I didn=27t think it
time?
Mark Rinehart
From: | "Bill Weber (DVNS)" <bweber(at)micom.com> |
I have never seen flat spots develop on tires even when left sitting for
long periods of time. However, if you are concerned, I would just cut
some 2x4 pieces and put them under the axle to get the tire off the ground.
Subject: | Re: MKII/TwinStar Design Question |
>-Mark Swihart-
>TwinStar #46
I think I would stick with the angle brackets. The stab tubing is kinda
thin, and the angle brackets distribute the load around. Besides, those
angle brackets are a good way to go. Maxair used them for elevator and
aileron hinges for years with no problems. My Hummer had 600 hours on it
when I sold it, and my elevator hinges had no slop. Imagine how long they
will last in their semi-immobile state on the Kolb stab!
Richard Pike
jd_roth(at)juno.com, dwegner(at)isd.net
Merry Christmas everyone and let's have a safe flying year to come.
Ralph Burlingame
Original FireStar
Merry Christmas to all Kolb Flyers and builders. I appreciate all the
help I received during the past year from many experienced ultralight
flyers. I especially want to thank Ralph Burlingame for the encouragement
and time he spent in helping me achieve a life long ambition. May we
all have nothing but happy and smooth landings during 1998. Ray Lujon ,
Woodbury, MN
Subject: | Merry Christmas Kolbers |
To All,
A friend of mine made a web page for me on his computer... actually it is
just a pic of my plane, but very nice. It is sitting in a corner of the
grass (in need of mowing) strip portion of Aero-country airport. The grass
is almost over the tires. That makes for nice soft landings.
http://www.icatgroup.com/ca/
Our son is about to make a "real" web page for Carolyn and me. That will be
a nice Christmas present.
Hope everyone is having a wonderful holiday.
Later,
___(+^+)___
(_)
8 8
Subject: | Seasons Greetings! |
Hope everyone had a Merry Christmas! :) Have a happy
New Year!
-Mark Swihart-
TwinStar #46
Paso Robles Ultralight Assoc.
From: | "Ron Christensen" <SPECTRUMINTERNATIONAL(at)classic.msn.com> |
Subject: | RE: Mark III Building Time |
Hi Mark:
I spent over 1300 hours building my MKIII, however it is significantly
modified from the standard factory kit. I would guess that 500 - 600 hours is
about right if you simply follow factory instructions.
From: owner-kolb(at)intrig.com on behalf of Rinehart, Mark W.
Sent: Friday, December 19, 1997 5:00 AM
Subject: Kolb-List: Mark III Building Time
time?
Mark Rinehart
I have a new rotax 447 with B gear box and complete exhaust system that is
currently excess to my needs.I bought this engine one year ago new from
Danny Day as a spare.I belong to a club here in lower Alabama that is 90
percent Kolbs and we do a lot of cross country flights.We ran the engine up
in accordance with Rotax standards and specifications.Carried it as a spare
on our cross country flights,have not used it in last year.Just to make sure
the engine was what we all consider to be new I had the engine torn down and
checked.No problems I had all new gaskets to include new rings put in as I
spent 30 years in aircraft engine maintenance and this was the only way to
do it,the right way. We fly all makes of Kolbs here in lower Alabama,the
people at Kolb know us well,The builder of award winning Kolbs and in the
past two years Titans lives here .He has built 95 percent of our planes. We
have had built one firestar and had the wings clipped to make it fly
faster.What we have learned is in extremely hot weather you loose lift
getting out of short fields.We have two firestars equipped with Rotax 503's
DCDI.Definately a waste of Money.Have one Fergy II here,owner previously had
a Mark III with 503,after a If your interslong review and analysis the
following is known,the Fergy is a beefed up Mark III,most Fergys have 582's
and this is the basic difference.As far as flying goes they both fly about
the same.If we can be of any assistance do not hesitate to drop a message we
fly 12 months out of the year and we have made one excellent training video
on tearing down a 503.If your in need of and engine ,gearbox and exhaust
system drop me a line.The engine will require a normal break-in.
Lindy and all,
Good to hear that you have a nice bunch of Kolbs down in "Alabamy". I love
that country. A branch of my family is sprinkled from Mobile over toward
Pensicola.
>people at Kolb know us well,The builder of award winning Kolbs...
Could that be John Hauck? He is from Alabama (and I think the southern
part). I met him at SNF and he gave a talk about his "round the US trip" at
the Paradise City forum. He was kind of reserved at first but by the end of
his talk he had gotten into the spirit of it. They almost had to get out
the "hook" to get him off the stage. Very enjoyable. What a trip!
There is also another guy who has built a bunch of Kolbs - Glenn Rinch - who
lives nearby in the Florida panhandle. I saw a video he produced that was
pretty good concerning construction. He included funny references to the
precision "tools" (crude but effective) he used to help build the airframes.
We have serveral Kolbs around the Dallas/Ft.Worth, Tx. area and a few down
near Houston. The rest are kind of scattered around the state. We are
hoping to find a location or fly-in somewhere between the two main areas to
have a Kolb gathering next spring. It is just talk so far.
Later,
___(+^+)___
(_)
8 8
Talk about an all Kolb fly-in sounds like a reason to travel. I would
like to hear more.
John Jung
(/\##/\ Smail3.1.30.16 #30.229) with smtp for
Having just put a FireFire in the air, the FireStar's little brother, I
would find it hard to believe you could do it. You'ld have to watch every
thin washer you used. It would mean:
no silver poly-spray
very light coat of paint
little in instruments - I mean bare bones
no brakes
lightest wheels available
small engine 277 or 2SI 35 HP
small windshield
no extras - none zero
maybe foam in the parachute container to claim the parachutes weight
Note the 2SI 35 HP does not have a charging system -
that what makes it lighter than the 277.
>> concerning:
>Clifton,
>John Jung
Subject: | TwinStar Build Pic's |
I found the original build pic's for the TwinStar that my friend and I
bought. I have started posting them on my web site. They are mostly
pictures of the wings at different angles. I will try and put more on
my page as time permits for those of you who are working on TwinStars..:)
-Mark-
TwinStar #46
<http://www.tcsn.net/mswihart/kolb.htm>
<< We have serveral Kolbs around the Dallas/Ft.Worth, Tx. area and a few down
like to hear more.
John Jung
yea! that does sound like a great idea, maybe I could get up enough steam ot
try to fly down from Ohio ( with a ground crew of course) GeoR38
>>> concerning:
The 35 hp 2SI and the 35 hp Cuyuna OLII-02 look to be the same but I
have no idea if the crankshafts are the same or not. That said, I've
been advised that the belt drive reduction unit on the Cuyuna, as installed
on a Kolb Ultrastar, will end up breaking the engine's crankshaft if the
belt is tensioned improperly. I have no idea if this problem will
translate to the 2SI engine and its belt reduction drive.
Skip: Take it from one who knows. Forget the thought of putting a belt drive
on a Kolb. I put one on my firestar with disasterous results.
The only practical way to use a belt drive is to mount your prop beneath the
engine.
You probably have never thought about this, but the large pully that your prop
mounts on has a shaft that must be secured. You cannot secure it at the same
place a gear drive would mount because of that shaft. (The engine block is in
the way).
Therefor, you must mount it below the engine mounting plate, with pillow
blocks.
The gear reduction unit puts your prop up, off the engine mounting block by 9
inches.
The minimum distance you will be able to mount your prop below the mounting
plate will be 9 inches. You are relocating the thrust line of your aircraft by
at least 18 inches. IT WON'T WORK!!!!! Also, you are limiting the overall
diameter of your prop, requiring you to use a three blade prop. A three bladed
prop is not as efficient as a two blade prop, and you will not be able to fold
your wings.(Porbably the main reason you bought a Kolb in the first place.)
As for the purchase of a 2SI engine. Take the advice of many many pilots with
lots of time under their belts. In a nutshell " FORGET IT !!!!!!!!!!!!
THEY HAVE HAD NOTHING BUT TROUBLE WITH THEIR ENGINES. THEY HAVE A DON'T GIVE A
DAMN ATTITUDE TOWARD THEIR CUSTOMERS.
BUY RELIABILITY. IT'S WELL WORTH IT IN THE LONG RUN
Best of luck
W. Grooms
>on a Kolb.
Thanks for your thoughtful insight. It was, however, Jerry Biddle that was
looking for the information and I was just answering him.
That said, the problem with a belt drive may not be a bad as you think.
It all depends on the aircraft and the belt adjustment. A Kolb Ultrastar,
like I have, uses a Cuyuna engine with a belt reduction drive. To date,
the 1984 Ultrastar hasn't had a problem. The engine is installed inverted
and the Ultrastar has the tailboom running from the wing to the tail. Prop
clearance could become a problem if a gear reduction box was installed
in place of the belt drive. To get the necessary prop clearance one might
then have to resort to a less efficient 3 bladed prop.
FWIW, the thrust line of the Ultrastar with the belt reduction drive is
better than any other model Kolb has designed since the Ultrastar. I
think that both Homer and Dennis will back me on that. There is no
pitch change with power application as the thrust line is right where
it should be. :) Your observation may be correct for later model Kolbs
with the tail boom mounted under the engine.
>Best of luck
>W. Grooms
The same to you and thanks for your input.
Skip
>engine.
prop
>the way).
>blocks.
> Not necessarily. Manta used to make a belt drive that bolted to the PTO
end of the engine and could be mounted either up or down. It worked ok but
was a little difficult to adjust. It was a very thick aluminum plate that
clamped around a steel prop shaft at one end.
I mounted one on a Hummer several years ago. It was for a Zenoah 250.
Is Manta still in business? If they are still as indifferent to customer
service as they used to be, I would suspect the are down the tube.
Richard Pike
WGrooms511 wrote:
> A three bladed
> your wings.(Probably the main reason you bought a Kolb in the first place.)
Just so no one gets the wrong information, Kolbs do fold with three
blades. One blade goes straight down between the wings. One compromise
is that the other two blades are higher then the engine, and may require
a higher enclosed trailer.
John Jung
Being part of this group has been such a good experience for me that
I thought I would try the FLY-UL list. After a week, all I got out of it
is a better apperciation for this group. So I would like to thank each
of you and wish you all a Happy New Year.
Also I got an hour of flying in today, inspite of the 25 degree
temperature and inch of snow on the ground (Wisconsin). The lakes have
thin ice or no ice at all so I didn't get to land on any lakes. The
trick is to get flying weather between the time the ice is thick enough
and before the snow gets too deep.
John Jung
<< >>>I would appreciate any comments/remarks
>>> concerning:
I had a Cuyuna 35 hp engine on my old Pterodactyl and did suffer 2 engine outs
but I.m sure that a well placed EGT would have eliminated that problem. I
thought that the engine was very reliable and had no problem with the belt
drive. I flew it from 83 to 90. GeoR38
writes:
>...... There is no pitch change with power application as the
>thrust line is right where it should be. :)
Same with my Flyer, Skip. Homer's idea was to keep the vertical center of
thrust as close to the vertical center of drag as possible. It works very
well
but the prop(s) become(s) a target for any tall grass or pebble kicked up
by
the tires.
If someone is still set on a belt drive, Hegar is still making them as
far as I know. Challenger used (uses?) them long after gear drive was
adopted by most other
manufacturers. I recently got a replacement prop shaft from them for a
decent price
for my C'II which, BTW is for sale. Hegar's number is - (503) 659-1234.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
John;
It's true that wings will fold if the prop is mounted high, on a gear
reduction unit, but if it mounted low, as on a standard belt reduction unit,
they will not fold. I had the belt reduction setup (mounted low) and it won't
even come close.
W. Grooms
From: | Frank & Winnie Hodson <fwhodson(at)megalink.net> |
--I'd like to see further discussion and/or explanations re: 2 vs. 3
blade prop efficiency and preferrences. I'm getting close to ordering
the engine/prop kit for my F.S.II.
Frank Hodson
Oxford, ME
fwhodson@megalink.net | http://www.megalink.net/~fwhodson
Are you speaking of one particular belt drive or all belt drives in
general.I have a belt drive on a Hirth and think it is the greatest thing
ever.My friends with gear boxes have problems with bearings and leaks and
unexpected breakages.(next time you change a bearing change the 6305
bearing to a 7305 bearing.This has a higher thrust rating but don't put it
in backwards). My belt drive is very simple.All bearings and belts are
easily inspected and belts don't just break. They crack,they stretch, They
slowly disintigrate but they don't just break. The maintenance is
minimal.Is there something about the Rotax that does not allow a proper
belt drive to be installed?As for moving the thrust line 18", if you can do
it,do it,the nearer to the center line of the aircraft the better. Of
course this may not be practical and that is why the thrust line is so high.
Woody
writes:
> Thanks,
> Frank Hodson
> Oxford, ME
My Twinstar is still a long way from being in need of a prop but here is
my
reason for buying a 3-blade when the time comes:
Any prop in pusher configuration with it's centerline at or near the
trailing edge of the wing encounters air moving faster over the top of
the
wing than under it. This causes a small pulse or beat each time the blade
passes the trailing edge. Of course with two blades, the opposite blade
is
passing the trailing edge at nearly the same instant (in the opposite
direction
of course). A 3-blade prop will stagger, or even-out the pulses because
only
one blade is passing the trailing edge at any one time. Many people talk
about
how much "smoother" a 3-blade is and most assume it has to do with static
balance but I think its more likely the above reason. 3 blades are harder
to
balance and more likely to get out of balance than 2, they are also less
efficient
but I'll trade that for "smoothness" anyday. This was something I read
(probably
a Barnaby Wainfan article in Kitplanes) and was one of those rare times
when
my light bulb went on.
Happy Holidays!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
mike.louis(at)aero.dot.state.mn.us, dmattsen(at)isd.net,
scott.pierskalla(at)usa.net, jd_roth(at)juno.com, dwegner(at)isd.net
John,
In Minneapolis, some lakes are great for landing on with very little snow
so far this year. I've had two recent flights off the lakes that were
nothing short of spectacular. For the benefit of those people living in
the western and southern part of the country, winter lake flying in the
north means being able to fly in ground effect for extended periods
depending on the length of the lake. Talk about "low and slow", you can't
get any lower or slower and still be able to stay in the air. For those
of you saying, "Isn't that dangerous flying so low"? Not at all because
you are flying next to the surface so that if the engine decides to "take
a hike", you just simply land. I keep trying to tell new pilots this is
the ideal place to train because there are no obstacles to hit, you don't
have to be confined to a runway, and you can always land directly into
the wind. If there is less than three inches of snow you can use wheels.
More than that, time for the skis. Hmmmm maybe I really should retire
here after all.
Ralph Burlingame
Original FireStar
>enough and before the snow gets too deep.
>John Jung
Subject: | When it's cooooold outside! |
To all,
Reading about "skimming the frozen lakes" sounds like a lot of fun. Makes
me a little jealous, but only for a moment... as my weak back begins to
tighten up on me from just the thought of the cold.
OK you cold weather flyers, I have a "newbie to 2-cycles" question. With a
Rotax 582, what do you do except cover the radiators (I have 2 widths (50
degrees F.) and sometimes 3 widths (40 degrees F.) of duct tape on now with
no cardboard or other insulation underneath) to keep the engine water warmer
in colder weather? I also see a noticable change in the viscosity of the
2-cycle oil on a cold day, but there is not much that can be done about
that. At what low air temp is it not a good idea to fly? ...or is that not
even the correct criteria to measure. Rather does it depend more on what
the minimum operating water temp of the engine is in flight and therefore...
depending how much you insulate the radiators? And if that is so, what is
that magic minimum water temp. Is that temp considered at cruise or as an
absolute minumum at any time. For instance, it would be coldest on decent.
Educate this "cold natured, kinda like it warm down south guy" in on the
basics of flying up north in colder weather.
P.S. As an aside, my wife and I just got back from a few days on the beach
at Puerto Vallarta, Mex. Eat your hearts out - plenty of SUN, WARM nice
ocean breezes, "strong" marguaritas and great food.
Thanks!
___(+^+)___
(_)
8 8
Woody;
Glad you asked that question. It gives me a chance to explain my response.
I have nothing against belt drives. In fact I rather prefer them.
My advice to the question of using a belt drive system on a Kolb could be
better put in these words.
There are many people with many specialties involved in designing and building
an airplane.
You, as builder should do just that; build according to plans supplied by the
designer. The plans for your Kolb call for a gear drive.
You are not an aircraft engineer, therefor you should not design, nor
redesign, nor modify the design.
There are many ramifications that you may not realize will effect the end
product.
You then become a test pilot.
I was a test pilot once, testing the modification mentioned in the origional
question.
I am lucky to be alive.
Dennis at Kolb preaches this advice all the time.
It's good advice.
Take it!
scott.pierskalla(at)usa.net, ggleiter(at)minn.net, dwegner(at)isd.net,
dmattsen(at)isd.net, jburlin181(at)aol.com
Subject: | Re: When it's cooooold outside! |
Cliff,
I have fan-cooled 377, so I can't answer questions about the
liquid-cooled 582. I can answer some of your other questions. I fly only
when the outside air temperature is 20 degrees above or warmer. I flew
once when it was calm and -20 degrees with near disastrous results. I
took off and as soon I got into the air, my face-shield, on the helmet I
was wearing, frosted up so I could not see a thing! I had to lift it up
to see, but when I did, the searing cold air streamed on my face. I made
an immediate uneventful landing, but a guy on a snowmobile said that the
right side of my face was "white". I reached up and felt my cheek. It was
hard as a rock! I thought I had disfigured myself, but I thawed out
without any harmful consequences. Sorry I digressed, but a good story. By
the way, the engine ran fine. I do not do a thing to my engine as far as
jetting goes. The reason being, the Bing carburetor charts show very
little difference in main jet sizes from summer to winter for the Rotax
377. I used to change the main jet to a 175 in the winter, but I found
that it wasn't necessary. The nominal is 165. I use a 50:1 mix with
premium unleaded auto gas. I do use the synthetic "Klotz" oil, and for
the first time this year I switched to "Mobil 1" synthetic gear oil for
the gearbox. I noticed it runs cooler in the summer and makes the engine
easier to start in the winter.
The sun on a warm beach and good food sounds pretty good, but I'd rather
be skimming those frozen lakes ..... just kidding.
Ralph Burlingame
Original FireStar
writes:
>To all,
>Makes me a little jealous, but only for a moment... as my weak back
begins
>to tighten up on me from just the thought of the cold. OK you cold
weather >flyers, I have a "newbie to 2-cycles" question. With a Rotax
582, what do you >do except cover the radiators (I have 2 widths (50
degrees F.) and sometimes 3 >widths (40 degrees F.) of duct tape on now
with no cardboard or other >insulation underneath) to keep the engine
water warmer in colder weather? I >also see a noticable change in the
viscosity of the 2-cycle oil on a cold day, >but there is not much that
can be done about that. At what low air temp is it >not a good idea to
fly? ...or is that not even the correct criteria to measure. >Rather
does it depend more on what the minimum operating water temp of the
>engine is in flight and therefore...depending how much you insulate the
>radiators? And if that is so, what is that magic minimum water temp.
Is that >temp considered at cruise or as an absolute minumum at any time.
For >instance, it would be coldest on decent. Educate this "cold natured,
kinda like >it warm down south guy" in on the basics of flying up north
in colder weather.
beach
>Thanks!
> ___(+^+)___
> (_)
> 8 8
Their is one thing for sure you guys up north are for sure a lot more
toughter than us southern guy's I don't see how you can fly in the cold
fridige weather . But I can just imagine it must be a beautiful sight to
see the blankets of snow !!
RICK
writes:
>Cliff,
>only when the outside air temperature is 20 degrees above or warmer. I
>flew once when it was calm and -20 degrees with near disastrous
>results. I took off and as soon I got into the air, my face-shield, on
>the helmet I was wearing, frosted up so I could not see a thing! I had
>to lift it up to see, but when I did, the searing cold air streamed on
>my face. I made an immediate uneventful landing, but a guy on a
>snowmobile said that the right side of my face was "white". I reached
>up and felt my cheek. It was hard as a rock! I thought I had
>disfigured myself, but I thawed out without any harmful consequences.
>Sorry I digressed, but a good story. By the way, the engine ran fine.
>I do not do a thing to my engine as far as jetting goes. The reason
>being, the Bing carburetor charts show very little difference in main
>jet sizes from summer to winter for the Rotax 377. I used to change
>the main jet to a 175 in the winter, but I found that it wasn't
>necessary. The nominal is 165. I use a 50:1 mix with premium unleaded
>auto gas. I do use the synthetic "Klotz" oil, and for the first time
>this year I switched to "Mobil 1" synthetic gear oil for the gearbox.
>I noticed it runs cooler in the summer and makes the engine easier to
>rather be skimming those frozen lakes ..... just kidding.
>Ralph Burlingame
>Original FireStar
> writes:
>>To all,
>begins
>now with no cardboard or other >insulation underneath) to keep the
>engine water warmer in colder weather? I >also see a noticable change
>in the viscosity of the 2-cycle oil on a cold day, >but there is not
>much that can be done about that. At what low air temp is it >not a
>good idea to fly? ...or is that not even the correct criteria to
>measure. >Rather does it depend more on what the minimum operating
>water temp of the >engine is in flight and therefore...depending how
>much you insulate the >radiators? And if that is so, what is that
>magic minimum water temp. Is that >temp considered at cruise or as an
>absolute minumum at any time. For >instance, it would be coldest on
>decent. Educate this "cold natured, kinda like >it warm down south
>guy" in on the basics of flying up north in colder weather.
>beach
>nice
>>Thanks!
>> ___(+^+)___
>> (_)
>> 8 8
Rick,
I didn't mention that I wear long underwear, T-shirt, sweatshirt,
sweater, insulating jacket, and then an outside winter jacket. You dress
in layers then it's like flying in the summer and I'm not cold at all. In
fact there are days where I have to unzip the outer jacket because I'm
beginning to sweat!
Ralph Burlingame
Original FireStar
writes:
>more toughter than us southern guy's I don't see how you can fly in
>the cold fridige weather . But I can just imagine it must be a
>beautiful sight to see the blankets of snow !!
> RICK
Subject: | Re: winter flying |
I second the comments about the joys of winter flying. Flying for miles at
45 mph and 1 foot agl over an immense emergency landing field is almost
indescribable.
Here in central Massachusetts we do get a fair amount of snow, but it's
very unpredictable. Some years the good ice precedes the big snow, and
some years the snow dumps on the ice and it's never usable.
Last week we got socked with 20 inches of snow in one day, and most of the
lakes were already iced over. Then two days later it was in the 40's and
pouring rain, so the lakes are really trashed. And the hangar door is
hidden behind several feet of snow soaked with rain and frozen solid.
Puerto Vallarta is sounding pretty good......
-Steve
Subject: | I'm a cold weather wimp |
Boy, my hat's off to you guys that fly in 20 degree weather. I didn't fly
my SS today because it was only in the upper 40's, and remember, the SS is
quite fully enclosed. Give me 90 plus degrees any day. If I can't work up
a sweat just walking to the car, it's too cold :-)
The SS is flying well, and the 503 has been flawless though it recently took
about 6 pulls to get it started after sitting neglected for 4 weeks. I'm
still chasing the elusive goal of ASI accuracy. I've redesigned my static
port and still it's off, but not by as much as before. If I disconnect the
static port, it's off the other way (high rather than low readings). I
should either ignore it, or just re-mark the instrument somehow, but still
the error bugs me. Ben mentioned that there was a small screw visible
through the pitot port of his ASI, but he refuses to turn it to find out
what it does (some friend huh ). I think he only told me this because he
knows that I'll eventually have to turn it to find out. Please spare me
from this torture. Does anyone know what this screw adjusts? Someone on
one of the newsgroups told me not to touch it, but that's just like handing
me the screwdriver :-)
In other news, I've finally decided on the next project. After receiving
Sonerai-IIS and KR1 plans, I've decided to order an RV-8 kit. This means
I'll be selling the SS at some point to help finance the new project. Don't
get me wrong, I'm convinced that the SS is the cream of the crop in very
light planes. I had hoped that this type of flying would appeal to me as
much as it does to so many others, but so far, that hasn't been the case.
Everyone have a safe New Years.
Russell Duffy
SlingShot SS-003, N8754K
RV-8 coming soon
rad(at)pen.net
http://www.pen.net/~rad/
> Thanks,
> Frank Hodson
> Oxford, ME
, Think of it this way. It takes horse power to move a blade through the
air.It is easier to move 1 blade than 2 and 2 blades rather than 3. We do
not have to room to spin a 1 blade prop but a 2 blade will fit nice.If we
pitch the prop to limit our rpm to 6300 rpm we will have a theoretical
distance we can move in one revolution. There is less air resistance on a
fine pitch than a course pitch and on a 3 blade you will have to decrease
pitch to make it easier to spin that extra blade around. A finer pitch will
reduce the theoretical distance you can travel in one revolution.Since
6300rpm is a good rule of thumb for max rpm no matter how many blades you
can see where a reduction in top end will occur. I do not know if the finer
blade pitch will aid in climb because of the extra hp required to spin that
extra blade. In general a 2 blade is the most efficient but a 3 blade is
good if you have a limited amount of room to spin a prop because the blades
are often shorter. 3 blade are also smoother running. This is my opinion
and I am sure there are others out there with a differing opinion so choose
what seems most logical and go for it.(2 costs less than 3 also)The comment
about the pulses when the 2 blade goes by the trailing edge may not apply
to the kolbs because the centerline of the prop is above the trailing edge
so only 1 blade passes the trailing edge of the wing at a time unlike the
Challenger configuration Wainfarn was commenting on.
Woody
>Woody;
>My advice to
Boy you sure put a damper on the fun of building a plane.If you modify
know what you are doing. If you have a belt drive or gear drive it does not
matter a bit unless you are worried about "p factor". I hope I don't break
your bubble but Homer is just a truck drivin farmer. I respect his opinion
a lot more than educated engineers.I do not believe in modifying for the
sake of modifying but there are times when you may have a better idea and a
bit of research will give you an indication of what to expect.
>product.
>question.
>It's good advice.
>Take it!
I have been a test pilot on 7 aircraft and will do it again next summer
(right Andy)I tested a Kolb Flyer to destruction and kissed my ass goodbye
but managed to walk away. You live you learn.I have tested a new theory on
aerodynamics. We will never progress if everyone is afraid to try new
ideas.I will take the chances to try something new but you can rest assured
I have done everything to assure my butt will be protected.After all I have
grown quite attached to it over the years.
Woody
Subject: | 2 VS 3 blade Props |
Am currently running a 3-blade 64" Ivo on the MKIII. Tried a 2-blade 66"
Warp on it and found no improvement on performance, but there was a
noticable increase in noise, and roughness. Did not try the Warp in 3-blade
configuration. One of the neighbors commented on the "odd whapping noise"
that it made while I was trying out the 2-blade. I think it was due to the
blades symmetrically cutting through the air coming off the inboard
trailing edges. I base this on having heard some VariEzes making a similar
sound.
I was using a Rotax 532 with a 3" prop extension with both props.
Richard Pike
MKIII N420P (42oldpoops)
<< The comment
Woody >>
Yep! that sounds good too....you guys really know your business! GeoR38
<< about
to >>
Sounds like a great explanation to me! Thanks GeoR38
Subject: | Forwarded mail... |
>John Jung
John, I have to say ...you enjoy your flying. I was working on my house
today (the 'little' project that has been hampering me from getting started
on a markIII) when the temp got down in the low 30's with 15 to 20 mph
winds. That's when this ex-florida boy say time to go INSIDE! I can't
imagine open cockpit 25 degree flying with that 45-50 mph 'breeze' blasting
by you. What does that wind chill work out to? Absolute zero or something
like that? Hats of to the determined pilot of the week!
Jeremy Casey jrcasey(at)mindspring.com
P.S. In defense of us southern boys...the transplanted snowbirds I know down
here aren't real crazy about our 98 degree 99 percent humidity July's
either. NO offense intended to Northerners....to each his own!
>....about the pulses when the 2 blade goes by the trailing edge may not
>apply
>edge
>the
> Woody
I'm not even sure it was WainfaRn I was paraphrasing but I do know that
the article I referred to was not about any plane in particular. It was a
general piece on pusher vs. tractor installations. I'll try to find the
source and post it to the list if anyone cares.
-Mick Fine
Green Country Ultralight Flyer's Organization (UFO)
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Flying in cold weather. |
Jeff Stripling wrote:
> I can't
Jeff and Group,
I am not crazy about the cold either. I would rather be down south in
the winter. But I have learned the trick to enjoying the (northern)
outside in winter. It is to dress properly. When I fly at this time of
year, I wear bib ski pants, two jackets, thinsulate gloves, winter
boots, and long underwear in addition to regular clothes. Also, I fly
with a full face helmet all year round. But in cold weather, I tuck my
jacket collar under the helmet. I am able to keep the face shield open
by slouching a little in the seat.
Some people wonder about changing their Rotax jetting for cold
weather. Here is what I have found on 277's, 377's and 447's. I have run
stock jets with the clip set one notch higher (leaner) than recommended
all year round. I did notice, Saturday, that the 377 Firestar can reach
1250 EGT while desending if I don't reduce the power enough. I plan to
move the clip back down (to stock) so that I don't have to monitor the
gage so closely. In spring it will need to be moved back, because the
engine tends to run too rich in hot weather.
John Jung
Subject: | Jetting changes, my humble opinion... |
The thing with two-stroke jetting is: there is only as much power available
as your mixture allows. Example: Your Rotax is running great, propped just
right, etc. then winter comes along. The air is denser, the prop turns a
little harder, the dense air is more resitive to your plane going thru it,
and the dense air gives your wings more lift. The denser air means more
molecules per cubic gulp, but if you don't change your MAIN JET to match, you
won't get the benefit of the denser air in your combustion process, all you'll
get is a leaner mixture (that is why you'll notice higher EGT temps). If you
richen the mixture you can cool it back down and get power you never knew your
Rotax had, like turbocharging! The main jet is all that requires changing.
Then when it warms up again in Spring, you need to progressively jet back
down (leaner) so you keep that optimum mixture (and you don't want to foul
plugs). Experiement and MAKE SOME NOTES. A little chart works great.
If you once go thru the initial pain of trying this for each 20 degrees F
you want to operate your two-stroke in, I gaurantee you will always be willing
to do a five-minute jet change before flying. The performance is that much
better, really. The process depends on which engine, how many carbs, what
exhaust, what air cleaner, prop,..., so nobody can do the experiment for you.
You will need maybe five different main jets by the time you are thru, at
about four bucks each. You will save that back in fuel costs in the hot summer
months. Determine the mixture by static RPM and spark plug readings, and
by all means consult with a local two-stroke expert if you have any questions.
The entire range of RPM is affected by a main jet change, except idle. So
changing the main according to temperature and air pressure is perfect.
Main jet changes are easier than changing the needle position and do not
require you to "tune" anything or have the engine running. Just pop the
bowl and unscrew the jet and install the desired one with a 1/4" nut driver.
It is not a bad idea to dump the fuel out of the bowls now and then anyway.
OR, buy HAC carbs and be done with it. I have done it each way and it is worth
the hassle/money. HAC has provided great mixture control for my dual-carb 582
for temp range from 90 to 35 F and altitudes from 900 to 7500' MSL. I am very
glad I bought it when the engine was ordered. I don't think I would spend
$600 for it though.
One more thing, if you read your manual it probably says something like;
"Your Rotax engine has been set up properly for your operating environment
by experienced Rotax technicians and should not require any adjustment."
Yea, right. So they somehow put in a main jet that would keep it from
melting pistons in the coldest, most dense air they thought I would operate
it in. OK, then what is my engine supposed to do with all that extra fuel
when the air temperature warms up? Toss it out the exhaust system and coat
my prop I guess. Maybe Rotax company owns NGK spark plug company :-).
Subject: | belt vs geardrives |
Kolb people,
I haven't been following this thing too closely, but why would anyone
want to use a belt drive on a FireStar if the gear drives are proven
trouble-free. I mean I've got a 1986 model gearbox (maybe an "A"-type)
and I've never had a problem with it. The idea of adjusting a belt drive
certainly doesn't make a bit of sense to me. Why mess with success?
Ralph Burlingame
Original FireStar
The wind chill for 25 degree's at 50 mph is -15 brrrr...
Subject: | Re: Jetting changes, my humble opinion... |
<< The denser air means more
you'll
your
Changing the main jet will only affect performance at or near full throttle.
Large temperature changes like we in the north find when going from summer to
winter affect two strokes performance in the mid-range throttle setting as
well.
On most flights we operate at high power settings for only brief periods but
run at mid-range (cruise) for long periods of time. Cruise performance and
cruise economy can be greatly improved with the proper needle jet and winter
flying for me in Wisconsin has required a different needle jet.
An interesting exercise in 'carb 101' is to remove the air filter(s) and with
the throttle raise the carb slide to the 50% open position. For those bings
with a primer port, the bottom of the slide would be at the level of that
port. Mark that position on your throttle lever. Then raise the slide to the
point where it is just to the full open position and again mark your throttle
lever where this full open position is located.
Then go and fly! (put everything back together first...) Take note of the
throttle position at your normal cruise RPM and then you will know which jet
you are running on at cruise (most of your flight time). If the throttle
setting is much below 3/4 open, you are running on the needle jet and the
needle jet is determining your mixture. This is the jet to adjust to make
EGT's correct at cruise RPMs.
For example, my Mk III (582) would cruise at 5500 RPM at about 1/2 throttle.
Changing to the next lower needle jet brought operating EGT temps to 1100 (a
good number) and reduced fuel consumption by 1/2 gallon per hour.
On my Titan Tornado (503), cruise speed of 95 mph at 5600 RPM happens at less
than 1/2 throttle. With the stock 2.74 needle jets I couldn't maintain 1000
degree EGT. After trying several needle jets, I found that a 2.68 jet gave me
cruise temps of 1100 to 1120 and reduced fuel consumption by a bit more than
1/2 gallon per hour to slightly under 3 gallons per hour at 5600 RPM.
I guess my point, after all this rambling discourse is to pay some attention
to the part of the carb that you use for 95% of your flight time and is the
limiting factor for performance and economy for that time. Take the time to
find out what your limiting jets are for the plane that you fly, the way that
you usually fly it.
Pete Krotje
EAA Tech Counselor
Hortonville Wis.
It would only feel that cold on exposed skin. If one keeps all skin
covered and stays behind the windscreen it is really not a problem.
John Jung
From: | Jon Steiger <stei0302(at)cs.fredonia.edu> |
Subject: | Re: Flying in cold weather. |
>> I can't
>Jeff and Group,
I haven't flown in the really cold stuff yet (my skis are rigged now
though; I'm just waiting for some snow to do a test flight - then they
come off to get painted) but I've flown in temperatures where my hands would
go numb if I didn't have some sort of protection. I found this great little
thing at Wal-Mart; I'm not even sure what its called (A "gator" I think?).
Its in the hats and gloves section of the men's clothing department in the
local store.
Anyway, you pull it over your head and you wear it around your neck -
its a collar that I can tuck into my coat and also up into my full face
helmet. It really helped to close up the neck area where the air is
good at sneaking into.
-Jon-
.--- stei0302@cs.fredonia.edu -- http://www.cs.fredonia.edu/~stei0302/ ---.
| DoD# 1038, EAA# 518210, NMA# 117376, USUA# A46209, KotWitDoDFAQ, RP-SEL |
| '96 Dodge Dakota v8 SLT Club Cab, '96 Kolb FireFly 447 (#FF019) |
I do not speak for the SUNY College at Fredonia; any opinions are my own.
Subject: | Jetting, one last comment |
Pete, you have a valid point that we spend 95% of the time in the midrange.
Great job on the actual data from your experiences with jetting, you must
keep good records! This kind of fine-tuning is what I was talking about
to encourage the guys to think about if they haven't. In my experience
in Ultralights, Kolbs, Snowmobiles, ATVs, Chainsaws and Gocarts using two-
strokes, I have not had to change the midrange needles or needle jet, ever.
This includes after mild porting, adding tuned pipes, changing air filters,
gearing changes, prop changes, and atomspheric changes. I guess you've
taken it a step further than most, my hat's off to you.
The midrange is controlled, as you stated, by the needle in the needle jet.
But it is also affected by the main jet above half throttle. I don't think
many of us are able to maintin level flight below half throttle (wish I could).
Put simply, I beleive that once the midrange circuit is set up (and I admit
that Rotax can't possibly get them all right so we could probably all benefit
from some leaning of the needle jet), in my experience, seasonal changes have
always been adjusted-for by main jet changes only. Maybe its because I tend
to "keep it pinned" all the time. Watch those EGTs, safe flying.
Pete, hey I re-read your note again and I am confused. How can 5600 RPM be
"less than half throttle" on your 503? I am going to have to try what you
suggested just so I know, I guess. If I read it correctly, you are saying
the slide is halfway open, and your RPM reads 5600, when cruising. Is that
right, or did I miss something? I guess there is some missunderstanding
because I commonly say "half-throttle" and mean "half of the available power"
or in other words "halfway from idle RPM to full RPM". That could be where
I am mis-understanding you a little. When talking about carb circuit tuning
I should change my habits and think slide position like you and others do.
Still, 5600 RPM at half-open slide would seem to be somewhat under-loaded.
I will do some experimenting when my exhaust system comes back home. You are
probably right.
Subject: | Fw: Rotax 503 Service Bulletin |
Hi everyone,
I found this post on one of the newsgroups this morning. I took a brief
look at the service note in question
http://www.rotax-owner.com/serviceb/9ul97.pdf and it concerns some engines
between the SN ranges of 4837735 and 4838155. Fortunately, my one year old
engine is well below this range of SN's.
Rusty
>In article <34A8D101.5019(at)aracnet.com>, you say...
>>Just a note to you Rotax 503UL engine owners. Stumbled across a link to
>>the Rotax owners homepage yesterday and saw a Service Bulletin that said
>>the wrist pins for the pistons of certain 503's were suspect and had to
>>be replaced before the next flight.
>> Having just installed my 503 in my plane, and then seeing this, I
>>almost had a cow. Had to run home and check to see if my engine was one
>>of the 130 or so engines affected. Luckily, mine wasn't.
>>The homepare is at www.rotax-owner.com. Look at the list of service
>>bulletins to see if your engine is affected.
>>Hope it's not!
Subject: | Re: 1/2 throttle |
<< How can 5600 RPM be
right, or did I miss something? >>
Yes, I mean that the slide is less than half way open at 5600 rpm cruise.
On my Titan, take off RPM is 6100 and full out straight & level RPM is 6350.
Cleaner (aerodynamically) airplanes will take less power (fuel & air) to
cruise. A wire braced UL will require a much wide carb slide opening to
maintain RPM and in that case, perhaps a main jet change is all that is
required as the engine will be running more on the main jet.
That's why each of us needs to find where we are running and make the right
adjustments to keep EGTs up where they need to be but not high enough to cause
alarm.
All this experimentation came about when the three of us who completed Titans
with 503's couldn't keep EGTs up to 1000 during cruise and changing main jets
did absolutely nothing.
Pete
<< 'm not even sure it was WainfaRn I was paraphrasing but I do know that
I switched from a 66 - 2 blade wood that came with the Firestar to a 3 blade
IVO at the recommendation of Dennis who said that the 3 blade would run
smoother but not perform quite so well...I fond this to be totally true. Also
my pitch changes were made before I had a tach so I haven't optimized yet.
Does anyone know why the 2 blade is more "efficient" than the 3 blade? Of
course the circle area will have a positive effect for the 2 blade....but is
that all? GeoR38
>To all,
>Thanks!
>Cliff & Carolyn Stripling Him: Kolb MKIII - N582CC (37.3 hrs)
>(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
> Both: 5th Wheel - RV - Travel
> ____________________|_____________________
> ___(+^+)___
> (_)
> 8 8
I copied and pasted an old e-mail that I had sent to the Kolb list about a
year ago. I have had two great flights over the last week and was warm and
very comfortable. The outside temp was about +25F
The following was originally sent on Dec. 07,1996:
I have seen a number of comments on winter flying during the last month. I
have about 15 years of winter flying. The last six have been with Kolb
aircraft. I am now flying a Mark 111. Winter flying offers some of the
best flying. There are no thunderstorms or harsh thermals. Most snow
covered fields and frozen lakes are good landing sites.
You must keep warm to enjoy cold weather flying. I have a Rotax 582 on my
Mark 111. I enclose the "carburetor side" radiator with cardboard and
multiple layers of fiberglass strapping tape and then another layer of duct
tape. I also insulate the radiator hoses with plumber's water pipe
insulation (the cheep foam stuff that you buy at a hardware store for home
waterline insulation). A word of caution - Make sure everything is
securely fastened! I also cover up to one quarter of the remaining rad
behind the muffler with duct tape. Close attention must be paid to the
water temp gauge when covering up radiators. I have built a warm air
collector that fastens to the back side of the radiator that is beside the
muffler. A three foot length of 2 1/2 inch "cat" aeroduct flexible ducting
routs the warm air into the cockpit.
I have had excellent results with the above heater. I have used it for over
80 hours.
During the first winter's operation I did not use cardboard to insulate the
carb side rad and no plumber's insulation on the hoses. I have noticed an
additional increase in cabin heating with the extra insulation. My last
flight was on December 3, 96. It was 0 degrees F. I was up for one hour
and did not get cold.
Sears sells an automotive 12 volt car seat warmer that works well when laid
on the ultralight's seat. It keeps your back and bottom toasty warm. I
initially used the car seat warmer before I had my warm air heater
installed, it felt so good I just keep using it. I have run two seat
warmers with no battery drain, the rotax alternator keeps up.
Carb heat is an important feature to have installed when flying in cold damp
weather.
I made my own. I cut two 3 3/4 inch square sheets of .063 aluminum, one for
each carb. Cut a hole in the center of each sheet. The hole must be just
large enough for the carb air cleaner flange to pass through. Weld a four
inch length of 1/2 inch 6061 aluminum tubing along one side of each sheet.
The tubing should have a thickness of .058. I used a scrap of tubing from
the Mark 111 jury struts. The ends of the tubing can be threaded with a 1/8
inch pipe threader. I purchased small hose fittings from a plumbing store
that can be screwed into the ends of the tubing. I routed hot water from
the center plug in the 582's head through the first carb heater on the rear
carb then through the front carb heater and then back to the water pump. I
used good quality 1/4 inch automotive gas line hose and have had no problems
with it. The water pump will have to be drilled and tapped for a 1/8 inch
brass hose fitting. The plug in the center of the head is 1/8 inch pipe
thread.
The 3 3/4 inch sheet should be made to fit tightly on the carb. I welded a
3/8 inch square length of aluminum along the bottom edge of the carb heater.
It is about 1 inch long and is centered along the bottom edge. I drilled a
3/16 inch hole through it lengthwise. I then used a hack saw to cut a slit
from the large center hole all the way through the middle of the 3/8 inch
aluminum stock. An AN 3 bolt can now be inserted in the 3/16 hole and
tightened to secure the carb heater to the carb.
The air cleaner can now be installed and safety wired. The air cleaner is
moved out .063 of an inch when the carb heaters are installed.
The first winter that I flew my Mark 111 with the 582 Rotax I ended up
scuffing my cylinders from ingesting ice particles. The rebuild cost me
over $600.00. I have had no more problems after installing carb heat.
That's it enjoy winter flying!
Kim
Saskatchewan, Canada
Subject: | Re[2]: Flying in cold weather. |
A friend showed up at our hangar on a cold day this last weekend on
his motor cycle. He had a electric vest and gloves which plug into
the bike. I don't recall the exact wattage but it was far less than
the 150 watt power system on a typical Rotax. He too also had a type
of dickey that covered his neck and lower part of his face. Covering
the throat area would help a lot.
Jerry Bidle
______________________________ Reply Separator _________________________________
Subject: Kolb-List: Re: Flying in cold weather.
Date: 12/30/97 4:21 AM
>> I can't
>Jeff and Group,
local store.
-Jon-
This is not a Kolb specific question, and maybe it's been
asked before, but I didn't find an answer that I was
satisfied with.
If a belt redrive costs less and weighs less than a gearbox,
what is the advantage of the gearbox over the belt drive?
Things I could think of:
1) The belt could slip.
A1: Adjust it, if an adjustment is available.
A2: Belt dressing could help quite a bit.
2) A belt may break.
A: Do that preflight!
Paul Vencel mailto:paul.vencel(at)MCI.COM - Work:719-535-4620
They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety.
Benjamin Franklin, 1759
Subject: | Re: Re[2]: Flying in cold weather. |
> Jerry Bidle
Electric clothing is avaible at the following web address;
http://www.sargentcycle.com/ccchilli.htm
http://www.widder.com/
http://www.gerbing.com/products.htm
Kim Steiner
>that all? GeoR38
I beleive a major factor is because the blades on a 3 blade are closer
together. (If you have a blade straight up, you only have to turn the prop
1/3 of the way around in order to have another blade be at the same place,
whereas you have to turn a 2 blade prop 1/2 of the way around.) For the 2
blade prop, that means when a blade cuts through the air, the air has more
time to settle before the next blade comes through, so the "wake" from the
first blade doesn't affect the next one as much. The 2 blade can take a
better "bite" since the air it is travelling through is cleaner than for
the 3 blade.
-Jon-
>weather.
What about those of us with air cooled engines? (277,377,447) I've
heard that the proximity of the carb to the engine won't allow carb
icing. On the other hand, I've also heard that under certain conditions,
the carb will ice up. Do we have to worry about carb icing?
-Jon-
<< The first winter that I flew my Mark 111 with the 582 Rotax I ended up
>scuffing my cylinders from ingesting ice particles. >>
This is a very interesting statement. How did you determine it was ice?
From: | William Hinkelmann <whink(at)mindspring.com> |
Rebuilding my FS-II, decided to try a 2 blade IVO, Had a 3 blade IVO
before, 2 blades did not make it. picked up two 66" blades at Oshkosh.
Guess I could always glue a washer on the surviving 64" blade and fly with
3 blades.
Hope to be flying in Feb or March, depending on the weather in Atlanta or
Mobile.
Am using Stits Poly-Tone but cannot find anything as to ambient
temperatures. is 30 degrees to cold to spray paint? 40 degrees? only
thing that was said was the slower drying the smoother, and increased
temperature causes shorter drying time.
William Hinkelmann
Subject: | Re: 2 VS 3 BLADES |
<< Am using Stits Poly-Tone but cannot find anything as to ambient
temperatures. is 30 degrees to cold to spray paint? 40 degrees? >>
30 or 40 is too cold I think. I sprayed some stits epoxy in the 40s once and
got bit in the butt. The primer peeled right off. There was some
condensation that happened. Tried it again in the high 50s and had no
problem. Same with the poly tone. If you want to slow it up they have
differnet retarders. Try that.
GeoR38 wrote:
> Does anyone know why the 2 blade is more "efficient" than the 3 blade? >
The reason that a two blade is more efficient that a three blade is
that each blade operates in cleaner, less disturbed air. A single blade
is even more efficient but more difficult to balance. That is not a
joke. Planes have flown with single bladed propellers.
John Jung
I had no problem at 60 degrees on the wings, but 50 degrees on the
nose cone was pushing it. I have heard of people painting with poly-tone
at temps colder than 50, but it isn't recommended.
John Jung
<< >Does anyone know why the 2 blade is more "efficient" than the 3 blade?
Of
is
>that all? GeoR38
the 3 blade. >>
Sounds good to me Jon, ...thanks for the feedback!
GeoR38
(how come you didn't know this ....Frank?)
John Jung
I believe you John, after all I still have a 1938 Wakefield rubber band
airplane and the most enjoyable part of building it was whittling out the 1
blade folding prop....very sleek and efficient indeed!! Thanks for the input!
GeoR38
(you didn't know that either, did you, Frank?)
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
Subject: | re:Kolb propellers |
Is that why they use 4-blade props on the P-51?
-----Original Message-----
Date: Tuesday December 30 1997 11:55 AM
Subject: Kolb-List: Re: Propellers
that
was a
the
blade
run
true. Also
yet.
blade? Of
blade....but is
>>that all? GeoR38
closer
prop
place,
the 2
more
the
a
for
>the 3 blade.
> -Jon-
> .--- stei0302(at)cs.fredonia.edu --
RP-SEL |
own.
I have used the Stits process many times and have sprayed poly brush,
poly spray and poltone multiple times below 30 degrees.
Note: The epoxy primer will not cure for weeks at that temperature.
The problem areas noted when spraying other Stits products are all
related to possible moisture condensation, the compressor air heats up
to warmer than ambient air temperature so a moisture filtration system
is a must. Extra care must be taken to avoid runs as the paint
definately dries slower. I found that making rotating stands for the
airframe and wings allowed me to spray on a more horizontal surface and
avoided ecessive running.
I am not recommending painting at such low temperatures, but I
completely covered and painted a 1946 Aeronca 11AC Chief in my garage
during the winter months here in Maine. (It was a lot more desirable
than heating the garage and wondering whether or not we would explode!)
All in all painting in warmer weather has always been easier when time
is not a problem.
Good luck: Frank
Dear fellow Kolbites:
The information thus far on 2 vs 3 blade props has been greately
enjoyed.
I present my FSII with several challenges:
1. I am hefty and would enjoy the increased efficiency.
2. I plan to use the Kolb in several different modes (wheels, skis,
and posibly floats) and desire an adjustable prop.
? Does anyone have experience with the two bladed adjustable prop and
would they summarize thier opinions re; acceptable smoothness and
performance ?
Thanks again: Frank
Subject: | Re: More propellers |
> performance ?
I have a 66" Warp Drive prop on my 377 Firestar and it is very quiet
and efficient. It does have a slight pulsing which makes it sound more
like a four stroke form the ground than most two strokes. It is not as
smooth as a three blade, but I find it acceptable.
John Jung
Subject: | Re: re:Kolb propellers |
Four blades are used to handle more power without getting too big in
diameter. This also one of the reasons for 3 blades. It's a trade-off
with efficiency. P-51's have plenty of power.
John Jung
From: | Wayne Welsh <flight(at)mail.on.rogers.wave.ca> |
Does anyone have any experience with Sport Props.
http://www.teleport.com/~trikes/Sport%20Prop%20main.html
> Of
> is
> >that all? GeoR38
> the 3 blade. >>
> GeoR38
<< Is that why they use 4-blade props on the P-51? >>
yes Ron, otherwise it would have gone too fast with only 3 or 2 blades, and we
all know what can happen when we hit the sound barrier!.......just
funnin".....
Got that Frank?......... GeoR38
Subject: | Re: belt vs geardrives |
>Kolb people,
>Ralph Burlingame
The advantage of a belt drive is the simplicity and ease of
inspection.Belt adjustment is a simple procedure that is not done very
often if done right the first time.In my area in one summer 3 guys had
their bearings give out on the gearboxes. They all claim without
warning.Belt drives are also quieter and smoother with the belts taking the
shock of the engine power stroke.
Woody
Subject: | spar/boom tube material |
I am in the need of a piece of the 6 inch 6061T6 boom tube/spar tube left
over from a Mark 3 or Slingshot.
When I build my firestar 2 the 5 inch tubes were sent 24 inches too long and
they needed to be cut so I had 2 pieces left over. I need a piece of the 6
inch size. I hope to get it from 1-2 feet long, but I can work with any size,
if anybody has a piece laying around that I could talk you out of please let
me know, I am creating!!!!!.
tim
Woody,
I still don't see the logic in wanting a belt drive over a gear drive
because the Rotax gearboxes are well designed and trouble-free. I believe
the belt drives may be more efficient, but the reliability of the
gearboxes outweigh the reasons for using a beltdrive. I have a friend who
took off in his FireStar without any gear oil in his Rotax 447 gearbox
(he forgot to put it in). He flew for over 10 minutes before he heard
squealing noises coming from the engine (he knew at that point what it
was). Even at that, he flew another 10 minutes or so to get back home.
After getting down safely, he got out and walked around the rear of the
plane to see what the gearbox looked like. It was blue on the outside
from the heat generated by it. The point is that the thing didn't fail on
him, but kept right on going in spite of the lack of oil in it! This is
what you call reliability and this is what you want in your aircraft. I
do not know of anyone in this area who has had any Rotax gearbox trouble.
I change my gear oil annually (this is important) and now use Mobil 1
synthetic gear oil in it (runs cooler). Mine is over 11 years old and I
expect many more years out of it. What more could you want for your
plane? Good Luck to you guy.
Looks like warmer temps here on New Years Day in the Minneapolis area. Me
and a buddy are going to take a cross-country in our FireStars.
Ralph Burlingame
Original FireStar
>taking the
> Woody
<< I change my gear oil annually (this is important) and now use Mobil 1
expect many more years out of it. >>
I assume that this is a GEAR OIL type of Mobil 1 not the motor type.
Scott Olendorf
Schenectady, NY USA
Kolb Firestar, Rotax 377
>I do not know of anyone in this area who has had any Rotax gearbox trouble.
On the other hand, how many do you know that have had troubles with
a belt reduction system? I have a friend that has had all kinds of
problems with a gear reduction unit in an airboat. Maybe trouble,
or lack thereof, has something to do with the particular installation
and how the unit is operated and maintained?
>Mine is over 11 years old and I expect many
>more years out of it. What more could you want for your plane?
The belt reduction drive on my 1984 Ultrastar is still operating
with absolutely no problems. It's not extremely high time, but
the original belt is still in one piece. :) If I'm not mistaken,
I believe that you will find that a belt drive is actually more efficient
than a gear or chain drive. New belts are a far cry from the old
V belts that many of us remember. For instance, how much do you worry
about the belts that run the alternater, air conditioner or water pump
on your car? Even Harley-Davidson has reverted to belt drive on their
motorcycles. Many cars use belts to drive their cams/valve drive. :)
It's supposed to be the coldest day of the year here south of the
Tampa Bay area, but it's supposed to be back into the 80=B0+ range
by the weekend. :)
Happy New Year to all.
Skip
You got it Scott ..... just what I said
Ralph B.
>Scott Olendorf
>Schenectady, NY USA
Skip
Was the airboat gear drive a Rotax? When I talk about gear drives, I'm
strictly referring to the Rotax types. Don't forget your UltraStar belt
drive was tested by the Kolb Company before it was marketed. You were not
the "test pilot". I've read of all kinds of problems that can result from
reduction drives that have harmonic resonances that cause vibration and
failure. If you have a belt drive that has been tested for 11 years
without a failure then it would appear to be "reliable", but why
experiment when you have the proven success of a Rotax gear drive,
especially with something you really want to work without problems.
Ralph B.
Original FireStar
writes:
>efficient
>area. Me
>by the weekend. :)
>Skip
Subject: | Throttles,Carb's and props |
Computer has been busted, so did I have a lot of e-mail to read!
About cruising at half-throttle: The Hummer I sold last spring had a
Rotax277 with 2.5:1 belt drive and a 56" prop. At full throttle it only
turned 5800rpm, but then the Hummer was designed for low power, and it
cruised at 4800-5200 rpm at about half throttle, slide about half up. Since
the 277 uses the same 36mm Bing as the 503, I think if an engine is over
carb'd for it's size, and then over propped to keep the horsepower down, it
might normally cruise at 1/2 throttle.
As far as belt drive vs. gearbox, the Maxair belt drive had 600 trouble
free hours on it when I sold it. I have already had to trash one Rotax B
box when it loosened up all it's bearings. The oil had been changed normally.
Concerning 2 vs. 3 blade props. The J-6 Karatoo I sold to build the MKIII
had a Rotax 532 and a Warp drive 66" 2 blade prop. I tried an Ivo in 2 and
3 blade configuration, performance was no better, but it was slightly
smoother.
The MKIII has an Ivo 64" 3 blade. I tried a Warp Drive 2 blade, but it
was
poorer in performance, much noiser, and not nearly as smooth.
If you are using an Ivo, do not rely on the cams to pitch the blades
equally. We have tested several Ivo props locally, and it is normal for the
blades to vary somewhat in pitch. The easiest solution is to make some
little "L shaped" shims that you can insert by loosening the bolts,
reaching down the center cut-out, and slipping between the cams and the
bearing plate while you hold the vertical leg of the "L".
The Ivo gets LOTS better when all the blades are pitched the same. Maybe
that's why I was not impressed with the one I tried on the J-6...
Happy New Year Fellow Flyers
Thanks for all the Good Info
Richard Pike
>Woody,
I am glad you have such good luck with your gear box. Personally I can't
see why every body does not have a belt drive. To each their own, good luck
Woody
Subject: | Firestar picture |
Anyone interested in seeing a picture of my 377 Firestar, (the one
that made it to 17,000 feet with a 377 Rotax), check out:
http://www.classifieds2000.com/cgi-cls/ad.exe?P1+C181+A0+R224213+Q201976583
Oh, did I mention that it's For Sale?
John Jung
>Woody,
Woody
>Woody,
Woody
Hi everybody,
I've been out for awhile, holiday visiting out of town. Glad to be back
and hope to be flying tomorrow.
I skimmed thru most of the propellor discussion and felt my usual compulsion
to jump in on this with a couple of thoughts.
1. I disagree w/ the bit more HP being able to turn more blades. As has been
mentioned, some work had been done in the 30s or 40s with single bladed
props in the interest of greater effeciency. They just used a counter-
weight stub on the other side. 3 blades can use the same HP as 2 or
1 bladed configs assuming the blade length (disk size) and prop pitch
are changed accordingly.
2. The main enchilada on number of blades is thrust disk area. That is,
fewer
blades almost always means they are longer, and therefore have a larger
thrust disk area. This translates to efficiency. An easy analogy is
considering the effiency of the long wings on gliders ...this
higher
aspect ratio = efficiency!
3 bladed configs will generally have higher tip losses (induced drag)
because of their lower aspect ratio, and simply because their are 3 tips
to lose from instead of 2.
3. As for 3-bladed being less efficient because of each blade following
more disturbed air, i think this is not so much a factor except at
static or near static loads. I think >2 blades is usually seen as
a way to accomodate bigger engines when prop diameter is otherwise
exceeded, and also simply to reduce noise. Also note, without changing
the gearbox, a 3 bladed prop will have lower tip speeds and that is
why they are quieter.
Well, that's my $.02. I'm gonna actually go play w/ my airplane now. :-)
-Ben Ransom
by r1.boston.juno.com (8.8.6.Beta0/8.8.6.Beta0/2.0.kim) with ESMTP id TAAAA09495
Subject: | Hello, where'd everybody go? |
OK, is everyone just hung-over or has the list server had another hiccup?
Maybe the problem is at my end but have received no messages since early
12/31. All the computers aren't supposed to crash at once for 2 years
yet!
Happy New Year to All! Thanks for all the help and advice in 1997,
especially Adrian. Here's to a SAFE and prosperous 1998.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
>Date: Fri, 02 Jan 1998 01:42:52 -0500
>To: Cliff and Carolyn Stripling
>From: Richard Pike <rpike(at)preferred.com>
>Subject: Re: IVO shims
>In-Reply-To: <1.5.4.32.19980102034422.0068d150(at)dfw.net>
>>Richard,
>>I know you (or someone else) posted about this before but I did not save the
>>post and wish I had. Would you give the list more info about those shims...
>>what stock material did you use and dimensions and (knowing that it is
>>different for different props) about what thickness is required.
>>Thanks!
> Originally I ground the cams until everything matched. Too much work.
the
easiest method is pure shade tree. Grab the micrometer, and grub through
the scrap bin until you have some .005, some .010, some.015, etc. Then I
cut out a strip about 3/8" to 1/2" wide (I don't remember exactly, and it
really doesn't matter) and about an inch or two long (high tech here, if
you can easily hold it with needle noses while installing it, it is long
enough) and then bend it 90 degrees about 1/2" from the end. Loosen the
bolts enough to slip the bent end under the cam for the prop with the least
pitch, tighten the bolts back down and recheck it. Eventually they all get
the same.
> Now you run the engine up and discover that the total pitch load has
moved your engine out of the desired power band, so you remove and restack
the Ivo shims, and start over! But it's nice when it's finally perfect.
> If you have to use more than one shim, stick a bit of double stick tape
to the bent end, and one won't fall out while you are playing with the other.
operation to your local A/P mechanic, it is guaranteed to have him walking
away shaking his head and muttering!
Richard Pike
<< 3 bladed configs will generally have higher tip losses (induced drag)
why they are quieter. >>
I was one of the instigaters of this subject ,and am amazed at the diversity
of comment, all of which I can buy in on, ie, you folks all make a lotta sense
to me...so I would like to bring up another subject that I haven't heard
anyone on here speak about and that is the "weak link" type of landing gears
on the Kolb Firestar. I have a deep appreciation for the idea of the spring
aluminum landing gear approach to "saving" the rest of the plane on tough
landings, but now I have accumulated enough bent ones that it would sure be
nice if there were a way to reuse them if they are not too badly bent. Since I
have 15 bent ones.....Naw, just kiddin but I do have 5 bent ones and 1
actually broke on a landing one time (but I know why) I wonder if anyone of a
mechanical bent (pun intendedf) would be able to tell the group what to
do....or where to go ......or sumpin. (where you been Frank?) GeoR38
Subject: | Update on noisy motor |
HI Kolbers!
If you remember a few months ago I wrote a letter about a noisy motor and
vibrations I had when the RPM was over 3000.
Well we took the motor apart and checked everything. I only had 65 hres on
that motor but I did not want to take any chances. The prop was balanced
and tracking was ok.
There was nothing wrong with the motor except a oil seal on the mag side
that was leaking a little bit.
I did also order news motor mounts from Kolb.
I flew about 1 hres yesterday and everything is back to normal. Except I
cant get the rpm to go over 6000 at full throttle. Before I had 6030 Rpm.
So I guess it is time to look for a adjustable pitch prop, like the IVO.
I guess I will never know if it was the motors mounts that was causing the
problems or may be the timing was out a little bit.
We did not check the timing before we took it apart
Happy flying Lucien
Since I
GeoR38
My theory is straighten once then replace but before I take it off I
need a good bend in it. They can be straightened with a good 5 ton hydrolic
jack. Also keep a pair of restraightened ones on the aircraft if possible
with the tools to swap it out in case you are ever stuck in the boonies.
Woody
by r1.boston.juno.com (8.8.6.Beta0/8.8.6.Beta0/2.0.kim) with ESMTP id OAAAA18183
Subject: | New Years flight |
To all: here's my New Years Day flight
Ground Effect Flying
New Years Day turned out to be a spectacular day for flying. Jerry
Jagerson, Ray Lujon and I were planning to get up early and fly to White
Bear Lake. I did get up early and the forecasted winds were out of the SW
at 10-20 mph. I called Jerry and then Ray to say that it would be too
windy. Jerry called back and said that he thought we should go anyway
because it was going to warm up into the upper 30's. We agreed to meet at
Maple Plain at 11:30 am. The winds were blowing at about 14 mph when I
got out there to set up. Jerry came flying over just before noon and said
it was smooth at 2400 feet. We took off at 12:15 and decided to land at
Cooks Bay on lake Minnetonka. There wasn't much snow on the lake so our
wheels made for a "cushy" landing. I thought the air was pretty smooth,
and from there we flew all over the lake and came back. After adding some
gas to our tanks, we wanted to head over to Lake Waconia about 10 minutes
to the west. As we approached Waconia, we could see a lot of cars,
trucks, snowmobiles, and people out there. We made a straight in approach
into the wind and landed near the shore. I asked a guy in a truck next to
where I parked, where we might find something to eat. He said right up
the street there was a cafe. Jerry and I walked about 3 blocks and found
the place. After getting some good food in our guts, we walked back to
the lake and noticed the winds had died down. We were now prepared to do
some real flying! After discussing our flight plan, we got in our planes
and flew the circumference of that big round lake for over and hour
making about 4 or 5 laps around at about 5 feet AGL doing 40-45 mph. Many
of the snowmobiles wanted to race with us and were passing us up. I
couldn't stand for that any longer and I opened it up. My airspeed
indicator cranked up to 80 mph and left them behind (I really didn't
think it would do that with a 377 Rotax. I wasn't diving because I was
only 20 feet AGL). Jerry and I had a blast all afternoon. I learned that
you can fly really low like this and make very gradual turns to stay
within the boundaries of the lake. Most of the flying was at 4500 RPM so
you can conserve fuel. On our last pass of the east end, we climbed to
1000 feet and headed back to Cooks Bay and called it a day. What a day it
was indeed! It's one New Year's Day I won't forget for years to come.
Thanks for calling me back Jerry.
See what you guys in the south are missing .......
Ralph Burlingame
Original FireStar
Minneapolis
Kolber's (I Iike that name),
I have the uncut 7075 tapered aluminum gear legs off the TwinStar on my
original FireStar. They are heavier duty (thicker and longer) than the
gear legs shipped in my kit. Installed, the plane sits up higher and
makes it more difficult to get in the cockpit, but now it looks more like
a Slingshot. Kolb told me to cut them off, but I didn't for two reasons:
1) the longer legs absorb more shock 2) Landing speeds can be lower due
to the higher angle of attack. I do have to watch my landing speed closer
because I can stall easier on touchdown (I think this is what Kolb was
concerned about).
Like all of our tapered aluminum gear legs, in time they will bend
outward. I just remove the single bolt holding them in the cage and turn
them over so they are now bowed inward. This solves the problem until I
have to turn them back the other way. I try to grease it in on landing,
but every once in awhile I come down harder than I expected. I've had
them 10 years and they are still going strong.
Ralph Burlingame
Original FireStar
>heard anyone on here speak about and that is the "weak link" type of
landing
>gears on the Kolb Firestar. I have a deep appreciation for the idea of
the
>spring aluminum landing gear approach to "saving" the rest of the plane
on
>tough landings, but now I have accumulated enough bent ones that it
would
>sure be nice if there were a way to reuse them if they are not too badly
bent.
>Since I have 15 bent ones.....Naw, just kiddin but I do have 5 bent ones
and 1
of a
>to do....or where to go ......or sumpin. (where you been Frank?)
> GeoR38
Subject: | Re: New Years flight |
I am suprised. I expected to be able to read about those down south
flying in the winter. So who is doing the flying and sharing the
experiences? Ralph and myself, from Minnesota and Wisconsin. Does
anybody down south fly in winter? Or does one have to be in Phoenix to
escape the bad weather?
John Jung
Subject: | Re: Update on noisy motor |
> Happy flying Lucien
If you get 6000 rpm don't worry about the prop if you can accept the
slightly slower climb rate and slightly faster cruise speed, unless of
course you have a bunch of extra money kicking around.
Woody
From: | Tom DeIulio <74650.1521(at)compuserve.com> |
Subject: | Mark III Trim Tabs |
Hello all. Let me introduce myself as a new member of the list, Tom from
Albany, NY. I'm building a Mark III and am currently working on the
elevators. I am concidering installing an inflight adjustable trim tab
similar to those found on the Cessnas. I'm wondering if anyone has
attempted this modification before. If so, how about some feedback. How
well does the spring trim system work called for by the plans? With the
fairly slow speeds at which the Kolbs fly is an adjustable trim tab even
needed? Being new to the light/ultralight scene I can only relate to the
C-172. I'm open to suggestions. Thanks.
Subject: | Re: straight gear...use spring steel |
ITry Kolb.... I've found they are now including same in their advertising. I
find them outstanding on my MKIII. And....a good design...all one piece
..replaces seperate axle...easy to retrofit with sleeve in cage socket. Good
spring action.
Happier hardlanding.
AMAV8R(at)aol.com
Russ in Tucson
Subject: | Re: gear legs.....stress on cage |
I would imagine that Kolb is also concerned with the additional stress on the
cage caused by the additional leverage as a result of the longer gear struts.
I'm a strong believer that the manufacturer has REAL reasons for their
recommendations.. I have high regard for the kolb structural integerity and
listen close to their advice.
Try their spring steel struts...I imagine they'er going to be offering
retrofits.
AMAV8R(at)aol.com
80?!? Now I really am anxious to get my Original Firestar #15
(377-Rotax) finished and flying. There are a few guys in my UL club
that want to take a trip in early June, and they asked me if I could be
ready to go. The trip will be from Albany, Oregon to Sandy River,
Oregon, up the Columbia River Gorge and on to Boise, Idaho, down thru
the Alvord Desert, across southern Oregon to Grants Pass, Oregon and on
home. About a 1,000 mile trip, with lots of camping out and
site-seeing.
The only problem I have is that they are all fairly fast planes (Rans
S-12, Carrera, Titan), and they expect to cruise around 55 to 60 mph.
The slower planes like the MXs, trikes and B1RD will not take part in
this trip, and I hate to commit myself for fear I would be unable to
maintain the necessary speed. I see from your letter that your original
Firestar cooks pretty good, but I'd like your opinion on a sustained
55-60 mph cruise. Your New Year's Day trip sounded great.
Ron Carroll
White
SW
at
some
minutes
approach
to
found
do
planes
Many
that
so
it
>Ralph Burlingame
>Original FireStar
>Minneapolis
Subject: | Re: Mark III Trim Tabs |
Tom,
I know that the trim system in the Mark II works very well. I'm sure the
Mark III would be the same. You can install a MAC trim electrical trim
system from Menzimer Aircraft Components (760) 598-0592 out of Vista,
California. Gary Menzimer won Grand Champion Light Plane at Oshkosh '97
and had this system installed in his FireStar, N423G. I had a chance to
talk to Gary while I was out there and the guy is a real perfectionist.
He has one of the most (if not "the most") beautiful Kolbs ever built.
You can get the MAC trim system from other dealers too. Check in the back
of "Sport Aviation".
Ralph Burlingame
Original FiresStar
writes:
>from Albany, NY. I'm building a Mark III and am currently working on the
>elevators. I am considering installing an inflight adjustable trim ta
similar to >those found on the Cessnas. I'm wondering if anyone has
attempted this >modification before. If so, how about some feedback. How
well does the spring >trim system work called for by the plans? With the
fairly slow speeds at which >the Kolbs fly is an adjustable trim tab even
Richard.Dewitt(at)HBC.honeywell.com, scott.pierskalla(at)usa.net
Hey Ron,
Yes, believe it or not 80 mph, but I could not hold a cruise at full
throttle, of course. The cruising speed of my original FireStar, with a
Rotax 377, is a solid 60 mph at 5500 RPM. This is with a 66" 2-blade IVO
adjusted to 5900 RPM static. I can only get this cruise when my two
auxiliary tanks (plastic gas cans) are full. They are 3g each, right in
back of the seat, which is about 40 lbs. This gives me a forward cg
making the plane nose heavy (I weigh 200 lbs ... maybe I could use a MAC
trim system or go on a diet). As I stop and add gas to the main tank in
the rear (from the auxiliaries), my cg moves to the rear and my cruising
speed will decrease. I pick up about 5 mph in cruise with those tanks
full. Now, another thing that helped me out was a new open windshield
that Ray Lujon helped me make. It's made of .090" lexan and is similar to
the ones on the new FireStars. I picked up ~ 5 mph with this windshield.
My FireStar has no covering in the rear part of the cage. I decided when
I built it, only to cover from the gear forward. It does not have
streamlined struts or wheel pants and it still has the old large wheels
that I got from Kolb. You shouldn't have any problem holding a 55-60 mph
cruise (with a windshield like mine), but the Titan and the Rans may have
to slow down a bit for you.
That sounds like quite a trip for you this summer. If you don't have any
time logged in a Kolb, this may be pushing your limits (testing the new
plane, logging time, etc.). Please use common sense. There is always next
year.
Ralph Burlingame
Original FireStar
writes:
>80 mph? Now I really am anxious to get my Original Firestar #15
(377-Rotax) >finished and flying. There are a few guys in my UL club that
want to take a trip >in early June, and they asked me if I could be ready
to go The trip will be from >Albany, Oregon to Sandy River, Oregon, up
the Columbia River Gorge and on >to Boise, Idaho, down thru the Alvord
Desert, across southern Oregon to >Grants Pass, Oregon and on home. About
a 1,000 mile trip, with lots of >camping out and site-seeing. The only
problem I have is that they are all fairly >fast planes (Rans S-12,
Carrera, Titan), and they expect to cruise around 55 >to 60 mph. The
slower planes like the MXs, trikes and B1RD will not take part >in this
maintain >the necessary speed. I see from your letter that your original
Firestar cooks >pretty good, but I'd like your opinion on a sustained
55-60 mph cruise. Your >New Year's Day trip sounded great.
>Thanks,
>Ron Carroll
The trim tab system works pretty good. Solo I fly with the lever full
forward. With a 130 pound passenger, the trim lever is about half back.
With a passenger at 200 pounds or more, it is full back. The first time you
fly with a passenger, you will be surprised at how much further you need to
pull the stick back to rotate on takeoff.
While you are building, you need to plan on a trim tab for the rudder and
ailerons. Normal behavior for the MKIII with no tabs is to yaw nose right,
and roll left. You can put a little tab on the trailing edge of the rudder
to turn the craft slightly to the left. Take care to keep the trailing edge
of the rudder as light as possible. I put my nav light on it and had
flutter problems.
The tab for the ailerons should be readily adjustable, I have a tab on
the
right aileron that is about 1 1/2" wide and one rib spacing long, and when
I have an adult passenger, it is adjusted almost in trail. Solo, it is
about 20 degrees down.
It is easier to plan your tabs before you cover.
The Kolb MKIII is very responsive to aileron/flap droop or reflex to fine
tune the nose up/down trim. If your ailerons/flaps are floating up at all,
the airplane will act tail heavy even if it is not. Likewise, if the
ailerons/flaps droop any in flight, it will act more nose heavy than it is.
A modification that I am trying this winter is another hole in the flap
handle just about 3/8" closer to the pivot than the normal one. Normal
flaps are up, 15 degrees down, and 40 degrees down. The new hole changes
the leverage ratio so that I have up, 5-7 degrees down, and 15-20 degrees
down. Since I never land two up with 40 degrees of flaps, the modification
will let me try takeoffs with 5 degrees of flap to see what that does to
shorten my short field performance. Or I can adjust it so that up is 2
degrees reflexed for cruising dual with less elevator up trim, and then 3
degrees down for flying solo, and still have 12-15 degrees or so for
landings. If I ever get done glassing up the new gas tank, will try it out.
Richard Pike
There's nothing wrong with the MKIII trim systemin it's standard form,
providing the craft is rigged right. On top of that it doesn't take the
modifications to an alreadyquite adequate design...plus it's no additional
cost. There are other things to consider such as dual throttles mounted
outboard. There is very little comparison to the MKII trim afterthought which
is not too effective.
Russ in Tucson
scott.pierskalla(at)usa.net, dwegner(at)isd.net
Kolber's
For the benefit of those who just read about my 80 mph top speed in an
original FireStar, please remember this was IN GROUND EFFECT flying at 20
feet AGL across a frozen lake surface here in Minneapolis with an outside
air temp of 35 degrees. We are approximately 1000 feet above sea level. I
failed to mention this in my letter to Ron Carroll. I have not measured
my "actual" top speed with my new windshield at cruising altitude, but it
would not be 80 mph.
Ralph (cover my butt) Burlingame
Original FireStar
scott.pierskalla(at)usa.net, dwegner(at)isd.net, ggleiter(at)minn.net
Skip and other Kolber's,
I knew I would get a comment on the "nose heavy" FireStar flying faster
than the aft cg loaded one. What you say is true for conventional
aircraft, but I think the flat-bottom airfoil of the Kolb aircraft may
have something to do with this. The flat-bottom wings have so much lift
that as the speed is increased, the more forward stick (down elevator) is
needed to keep from climbing. This does two things: 1) creates a lot of
drag from the "down elevator" 2) the wing can fly at a negative angle of
attack. Now if the cg is moved forward to make it nose heavy, no forward
stick is needed to keep from climbing at high power settings, which
means: 1) the elevator drag is reduced 2) the wing flies at a slightly
positive or zero angle of attack and creates less induced drag. Both of
these two things minimize the drag and the plane flies faster. When I am
flying, I can turn around and look back at the elevator and actually see
that it is neutral when I carry the added weight up front. Otherwise it
is slightly down in cruise, without the weight. Remember, I didn't cover
the rear part of my cage, so I can see the tail in flight, although this
was not my reason for doing this (another subject). This is my
explanation and I am not an aerodynamics expert, but the FireStar will
fly faster with the added weight up front. I think this might be one of
the reasons "flat-bottom" airfoils aren't widely used for conventional
aircraft. This is going to open up a lot of comments on the subject, and
I am waiting to hear other explanations.
Ok Ben and others, go for it!
Ralph (open-a-can-of-worms) Burlingame
Original FireStar
writes:
>FWIW:
>You may wish to clarify what you have written above. In actuality, you
cruise >faster because of the aft cg not a forward cg. This true for all
conventional >airplanes because as your aft cg increases you unload the
horizontal stabilizer >and cut your induced drag. This is good unless
carried to extreme as an aft cg >decreases stability.
>Regards,
>Skip
<< Like all of our tapered aluminum gear legs, in time they will bend
Ralph Burlingame
Original FireStar >>
Ralph, I appreciate your input on the "what to do with bent gear legs" but you
haven't seen the abuse I have put mine through, ....at least some of them. I
will try the 5 ton thing someone wrote about.and on the ones not so bent I
will turn them over.
Word to the wise....I had MkIII set of legs on once and had to tun them down
to make them fit and that's the one that "broke:" due to poor radius on the
turned down part.
GeoR38
<< e now prepared to do
Thanks for calling me back Jerry. >>
Ralph, I'm from Ohio and I loved your story....truly a memory to treasure....
you are a good one for word pictures..... GeoR38
Got this Frank?
<3.0.3.32.19980104174704.006e44e4(at)bhip.infi.net>
Something isn't adding up here. I don't know how the incidences work out
on the Firestar, but normally the stab/elevator is at an angle of incidence
of several degrees relative to the wing, and if the stab is down a few
degrees, then it is actually more in line with the incidence angle of the
wing than if the stab and elevator are in a straight line. This reduces
elevator drag.
Same as my comment above, drag should be less with a couple degrees down
elevator, which increases total aircraft lift, because the tail is now
somewhat of a lifting airfoil, there is less load on the wing, it's angle
of attack is less, it's induced drag is less, tail induced drag increases
slightly, but total drag is less, right?
Induced drag is drag caused by lift. In a conventional
(non-canard)aircraft, there is a nose down pitching moment caused by the
typical airfoil, and the tail exerts a downward force to counter it. As the
CG moves aft, downforce decreases until the tail is "in trail" for lack of
a better phrase (why do I get involved with these at midnight? Can't
think...) At a given speed, angle of attack, and induced drag increase as
the CG moves forward, and decrease as the CG moves aft. I would not dispute
your results, or control inputs, but the why and how isn't adding up.
Both of
>Original FireStar
I wonder if it is not more a function of the normal Kolb engine thrust
angle relative to the wing. Postulate: When the aircraft is flying with the
wing absolutely level relative to the horizon in level flight, the thrust
line is aimed downward somewhat,(7&1/2 degrees on a MKIII, don't know about
a Firestar) and at very high power settings there is a thrust loss, forward
thrust being dissipated as down thrust. This becomes more pronounced as the
nose is lowered to prevent climb.
With a little more weight toward the nose, it becomes necessary to hold the
nose up a bit, and the prop's thrust line relative to the horizon/angle of
attack is more favorable. Thrust is not wasted being blown up and back, but
straight back instead. The wing is creating a little more drag, but the
improvement in thrust efficiency more than makes up for it. I am not
convinced that this is it, but I have a stake in this too.
As I add weight forward of the CG in the MKIII, it takes a higher angle
of
attack to fly at any given airspeed up to full throttle, and it will not
fly as fast with two as solo. If I could figure out a way to get mine to
fly at zero angle of attack, I know I would pick up 20 knots easy, because
it NEVER flys at less than 6 or 7 degrees relative to the horizon, and 160
square feet of wing is a lot of drag, induced, parasite, or whatever, at 6
degrees.
Richard Pike
>writes:
>>FWIW:
>>Regards,
>>Skip
From: | Cliff and Carolyn Stripling <striplic(at)dfw.net> |
Ralph and all,
I have not altered it yet, but I have a ground adjustable horizontal
stabilizer (operates by adjusting the front attachment point higher or lower
than the "plans location"). I have a storage compartment behind the tanks
but must be careful when using it because of aft CG. At some point and I
don't feel ready yet, I plan to alter it up one then down one to see how the
plane reacts to the change in rigging. I have 5 possible positions with it
being in the middle one now. I had envisioned using it to make possible
more aft loading for camping gear by raising the attach position thereby
raising the tail thereby reducing the angle of attack therefore reducing
lift of the main wings. I cannot think of a scenerio whereby I might need
to lower the position because of excessive weight up front. The most
forward loading CG calculation for two "big guys" is still in the forward CG
range for my plane. It seems to be flying very well right now in the
suggested "plans location".
Later,
___(+^+)___
(_)
8 8
JOHN
I will at anytime I get a chance go out I like to go down to the beach
its only about 20 miles or so to get their ,from their its miles and
miles of flying , this spring their are a few kolbers that hope to link
up at a 1/2 way spot just to chat and look at each other's KOLB'S I hope
that all of this can happen this year,CLIFF maybe you will be settled
down and have some time to spare away from your new house project I hope
so anyway ,, JOHN I know it would be a long flight from Minnesota , but
you sure would be welcomed to zip on down to south east Texas. This last
week or two the wind has been up to a unconformable breeze. John I will
send you a pic of my kolb on my new x-mass toy
Rick
writes:
>John Jung
Cliff
I got part of the intercom in , and the rest will be here on the 5th. it
is the same kind that GEORGE , has so you know how he likes his ,If you
want to try out my flightcom with the patch cord I got from ICOM let me
know and it will be in the mail. Talk to you later
Rick
writes:
>Ralph and all,
>lower
>tanks
>and I
>how the
>with it
>possible
>thereby
>reducing
>need
>forward CG
>Later,
> ___(+^+)___
> (_)
> 8 8
> 55-60 mph cruise.
My original 377 Firestar will cruise at 60 mph at 5400 rpm. I don't
usually go that fast, only because in an open cockpit, that wind hitting
the top of my helmet moves my head slightly. I don't care for that. With
a full windscreen, that problem would be gone and it would cruse 5 or
more mph faster at the same rpm.
John Jung
Subject: | Re: straight gear |
<< My theory is straighten once then replace but before I take it off I
need a good bend in it. >>
I took a slightly different approach. I would turn them over. Just rotate
the leg 180 in the socket. The plane would look funny for a little bit, but
the gear would then bend back the other way. I would only do this a couple of
times.
Subject: | Installing floats on Kolb Firestar II |
Is anyone building or flying a Kolb with floats instead of wheels? I would
like to communicate with you. I have made provisions for front and rear
attachment of floats on my plane, however I have not selected the floats
yet. Anyone with information would be welcome.
Please reply to Frank Thomas at the following address: fthomas(at)gate.net
Frank Thomas
Here are my thoughts on the gear that seem to bend too often: I have
bent 5 legs in 90 hours and 2 1/2 years on my original Firestar with KXP
legs. It is the most common and expensive repairs that I have had to
make. But as I look back on what happened, in each case I was landing on
a very short runway (about 400 feet). I needed to get my airspeed down
to minimum. In 2 cases I landed hard because I got too slow and stalled
at about 10 feet off the ground. Once I touched down just short of the
runway on frozen, plowed field. And 2 legs were bent at one time when I
could stop on a 400 foot runway because of dew on the grass. I had
landed long and counted on the brakes, hit a ditch at the end of the
runway. Considering that, by now, I can change a leg in 30 minutes for
$30, and so far no damage to the plane, I don't consider it a problem. I
just consider it a cost of landing on very short runways. If there were
an alternative that wouldn't risk damaging the plane, I would be
interested. But in the meantime, I am trying to watch my airspeed closer
at short runways and be more willing to go around if I am too fast or
too slow near touchdown. On longer runways I carry extra airspeed down
to 5 feet and then let the plane slow down and never a problem.
John Jung
Wisconsin
From: | "Bill Weber (DVNS)" <bweber(at)micom.com> |
First you must define what you mean by "efficient". You could say efficiency
means the amount of lift produced compared to the amount of drag. In that
case, the factors affecting efficiency are the airfoil shape, pitch and
length. Just like a wing, the longer the airfoil the less induced drag is
produced. The higher the pitch, the more frontal area and therefore more
parasitic drag is produced. So for a propeller, the things affecting
efficiency in this sense is the prop length and pitch.
When a prop is put on an engine we must balance the load created by the
prop to the power output of the engine. there are 3 basic variables; length,
pitch and number of blades. Increasing any one of these will increase the
load on the engine and therefore one of the others must be reduced.
Top speed at a given RPM is strictly dependant on pitch. Pitch determines
how far you move through the air with each turn of the prop. When you go
from 2 blades to three you can either reduce the pitch or the prop
diameter. If you reduce the pitch, your top speed will be lower but your
climb rate will be better - like shifting to a lower gear in a car. If
you keep the same pitch, you must reduce the prop length. However, now
your efficiency may be less but because of the shorter prop length.
However, with less frontal area, the parasitic drag will also be less.
So things are not quite so simple as "2-blade props are more efficient".
It all depends on the engine, plane, prop combination. In the absence of
a cood computer simulation, experimentation is the only way to determine
the best prop for a given plane-engine. In many cases, a 3-blade prop
can be set up to outperform a 2 blade in both climb and top speed.
In all cases, however, the 3-blade will be quieter and smoother.
* Bill Weber * Keep *
* MICOM Communications Corp. * the shiny *
* Simi Valley, CA * side up *
Subject: | New Years Flight |
Kolbers.... Ralph, I knew your New Years day flight was worth telling.
Here is my over-simplified version of optimum cruise . I feel optimum
cruise is obtained when the elevator is neutral, no need for forward or
back pressure on stick (hands off) and the plane is flying level. At this
setting, the angle of attack of the wings is minimum, or even neutral.
The download on the stabilizer matches the pitching moment of the wing.
To achieve these ideal conditions requires that the CG be exactly in the
middle of the allowable range. A forward or rearward CG would require a
corresponding back or forward pressure on the stick (however slight) to
achieve level flight, thereby creating elevator drag and a loss of
airspeed. Both Ralph and I use the small windshield made of .090 lexan,
that is extended 6 inches longer so no slipstream strikes the face. The
additional advantage is the increased cruise airspeed. I have a FS, 447
Rotex. Cruise in summer, 60mph at 4800rpm and 60mph in winter at 4000rpm.
I highly recommend this larger version of the short windshield. Ray Lujon
, Woodbury ,MN
On the subject of gear legs: it was simple on my Firestar (original design) to
put in chrom-moly legs. Pull the sleeve from the gear leg socket, hone out
socket and install 1.125" x .120" 4130 tubing. I had the tubing heat treated
to RC46. I cut the tubing 28.5" long. Hint: don't drill holes in legs before
heat treating as the tubing will probably warp slightly during treating.
Cobalt drill bits cut the heat treated steel easily. I tried untreated tubing,
but it bent. As for gear leg strength vs. center section strength, I landed
hard following an engine out a couple of years ago and bent one gear leg but
the center section was undamaged. Everyone was suprised as I really dropped it
in hard.
Bill Griffin
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
> in hard.
> Bill Griffin
I take it your 4130 gear legs are the same tube for the full length
of the leg? I.E., nothing done to simulate the tapered solid AL legs
from Kolb? I've not bent my gear legs ever but am always curious about
possible weight savings and the 1.125x.120 4130 might be lighter than
solid tapered 7076 AL. I've also thought about titanium or carbon fiber,
and yes, thinking about it is a lot easier than actually doing anything.
Ben Ransom (*)
Email: bransom(at)ucdavis.edu o o
http://mae.engr.ucdavis.edu/~ransom
Subject: | engine out landing |
I made my first unexpected engine out landing yesterday. I gurantee
you that I momentarily thanked myself for all the practice ones I've
done, but then quickly got back to business.
I had been up for 1 hour mostly at cruise rpm. I was unhappy about
high EGT temps, but i let it go, again thinking that higher than
1200 was okay with the single probe. (I was sitting at 1260-1280.)
I began to realize during the flight that i've normally not let
my engine see over 1200 cruise so was planning on richening more upon
landing. I've not been flying much so being rusty contributed to my
accepting the high temp. Also, I realized that i had made a mental
mistake and changed to a smaller jet instead of larger before going
up. (The air was ~20 deg colder yesterday than previous flight about 5
weeks ago.)
I crossed over the center of the runway and came back to idle as i dropped
altitude to turn 90 deg into a downwind pattern leg. At idle for ~10
seconds i added a little throttle to verify my engine was still with me --
which is what i normally do -- and it died. The runway was right there
so it wasn't a real big deal, but i did pucker just a little, partly
cuz of the rude surprise change-over to glider, and also because there
was ~10-12mph crosswind and i had to fly straight against that on my
"base" leg.
Landing was uneventful (and quiet).
I started the engine on second pull right after pulling off the runway.
I richened the main jet and mid-range needle setting and flew a little
more. I was still too lean, verified by adding choke at cruise, and
had the engine quit once more after coming completely back to idle
after touchdown. I'll pull the heads and exhaust manifold before next
flight to inspect and hopefully verify no damage done from running hot.
And, i am finally ordering dual EGT probes (really) so i will have
published EGT limits to believe in.
I'll let y'all know when i find out more about the actual cause.
-Ben "one notch less enamored w/ 2-strokes" Ransom
Subject: | Re: engine out landing |
<< I richened the main jet and mid-range needle setting and flew a little
flight to inspect and hopefully verify no damage done from running hot. >>
Glad to hear you're alive. But you just broke one of the cardinal rules of
Rotax flying. Your engine quit at idle after a presumtive overheat situation
and YOU FLEW ON IT AGAIN WITHOUT DETERMINING IF YOU HAD SEIZED IT. As the
piston starts to overheat and expand past its limits it binds. The energy
from running at cruise will keep it moving, but when you let up on the
throttle it doesn't have enough oomph to overcome the friction and it grabs.
The rule can be stated with great simplicity: if your Rotax quits for no
apparent reason and you even slightly suspect that it overheated you MUST pull
the exhaust and inspect the cylinder walls for scuffing or other evidence of a
seizure.
I bought a wreck of a Rans Airaille a few years ago. The pilot had exactly
your experience. The engine quit at or near idle on landing. By the time he
got it pulled off the runway and scratched his head for a while it had cooled
down some. He started it again and took off. It seized again on take off and
he bought the farm.
Again . . . . I'm very glad you are alive, but I question your judgment
in flying again on the engine beofre you had satisfied yourself that the
cylinder walls weren't scuffed. I'll be very interested to hear your report
on the inspection. (I recomend a flashlight and a dental mirror so you can
see all sides.) I would welcome the group's comments as well.
From: | "b. steinhagen" <bsteinhagen(at)itol.com> |
Ben, I'm interested in your dead-stick experience. I have a FS-II with a 3
blade prop and wonder about the prop drag. Do you have a 3 blade, and how
was your decent profile with the engine stopped as compared to at idle?
Date: Monday, January 05, 1998 2:13 PM
Subject: Kolb-List: engine out landing
>weeks ago.)
>"base" leg.
Subject: | Horiz. Stab. rigging |
>Aieeeeeee!!!! That's not the way it works, son!
>The CG is determined in relation to the wings' Center of Pressure.
>You can't get a more aft CG by adjusting trim.
Jim... Let me come at it with different language. What I would like to do
is carry more weight in the rear baggage compartment. I thought raising the
front of the horizontal stabs would allow the plane to carry more weight in
the tail by increasing the incidence of the tail surface with respect to the
main wings. Raising the front of the tail surface should provide some
increased lift in the tail to help carry that additional weight if nothing
else. Is this not logical? If I am off in my thinking, I sure would like to
know where.
The pitch trim adjustment works pretty much the same way it seems to me. I
realize that at some point you can enter a dangerous rigging configuration
if you go to the extreme and add too much weight in the tail, but I am not
talking about that kind of situation.
I have seen the fronts of the horiz. stabs. rigged way high (like an inch
above the top of the tube) and way low (like mid-fuselage tube) by
builders... probably because they messed up with the incidence rigging of
the main wing in relation to the fuselage and had to compensate by adjusting
the horiz. stabs.
Educate me about this becauce I have always held this as a safe way (within
limits obviously) to carry a little additional weight... in the tail.
Talk to me,
___(+^+)___
(_)
8 8
No, nothing fancy. Just 4130 tubing as far up into the cage as it'll go. Glad
to hear that your engine out landing was uneventful. Practice pays off.
bill griffin
You may be right about it being unwise to fly again right after a possible
overheat situation. It was not necessary (it never is), and I'll admit
i've thought afterwards that i shoulda parked it.
On the other hand, i feel sure I took no unreasonable risks, especially to
my own hide. I feel we all determine our own "cardinal rules", unless
they are written on stone tablets somewhere and I haven't seen em.
We all fly with a probability of engine out, and yesterday I flew with
added probability and added caution to match.
In summary, you're right that i shoulda parked it, but i don't think i
took any risk at all to my health.
-Ben Ransom
Ben,
Thanks for telling us about your deadstick landing. We will all benefit
through your experience. I'm very glad that it happened where it did.
With my 377, the first cold snap in the fall my idle RPM's drop and I
have to turn the idle screw clockwise to get it up to 2000 RPM. If I
don't turn the idle screw up, the engine will want to quit when I close
the throttle, just like yours did. I do not change any jetting and
everything works well for me, now. I am, however, starting to clean the
carbon out with the "Seafoam" I referrered to in an earlier email. I'm
hoping this will solve the stuck ring problem. BTW if you have a stuck
ring, the first one will most likely be the rear (PTO) bottom one. Long
before they both stick on the rear cylinder, you will see a noticeable
"lack of power" from when it was new. I thought, at the time, that the
engine was breaking in and had no idea that its rings could stick. This
will go on for ~ 50 hrs. Then one day you'll be flying along and the EGT
will begin to rise up past 1300 degrees while cruising. When this
happens, bring back the power immediately and look for an emergency
field. If you do it quick enough, it will probably keep running and not
want to seize. How do I know all of this? It happened to me with my
FireStar several years ago.
After taking the engine apart, both rings on the rear cylinder were
stuck. I had
~ 200 hours on the engine since new. Now I pull off the exhaust manifold
after
~ 100 hours and check for stuck rings.
Ralph Burlingame
Original FireStar
Subject: | Re: Horiz. Stab. rigging |
The only safe way to carry more weight is too do the weight and
balance first. If you are within limits, then it should be safe. Now
comes trim, or how to keep from holding pressure on the stick. I
recommend using normal means of trim (tabs and springs) first, and not
changing the design of the plane. A cockpit adjustable trim tab would do
the job for sure.
John Jung
Hold on there,
The engine can quit at idle as in Ben's situation, but that does not
necessarily mean it has seized. This WOULD happen every year to me IF I
didn't turn the idle RPM's up to 2000 RPM when the temperatures took a
drop.
Ralph Burlingame
Original FireStar
for no
pull
of a
seizure.
Although I have a two blade prop, I have done quit a bit of engine
out flying and I believe that my observations are revelant. The bigest
change that I have noticed between engine at idle and engine off is a
much sharper stall with engine off. And the stall comes quicker with
little or no warning. So I you find yourself flying with a real quiet
engine, WATCH THE AIRSPEED.
John Jung
Bill,
Assumming that prop clearance is not an issue; assuming that prop tip
speed is not excessive------
Considering the above conditions, some examples might be in order. :)
(under some circumstances, climb might improve)
I think that even this premis "may" be flawed as the number of cylinders in
an internal combustion engine/2 stroke or 4 stroke might have an
influence on smoothness. We are assuming that all props are properly
statically and dynamicaly balanced --- The noise factor is primarily
determined by prop tip speed. A 3 bladed prop set at a lesser pitch
but with the same blade length might actually create more noise.
I would tend to believe that all combinations of props, etc., can be
made to run smoothly at some RPM, but not necessarily all usuable
RPMs. That considered, prop length and tip speed limitations considered,
I, still believe that the 2 bladed prop (all other conditions being
equal - such as blade efficiency, weight, etc.) will be more efficient.
OK, have at me. :)
Yes, I do know what assuming can lead to.
Skip
On Mon, 5 Jan 1998, Ralph H Burlingame wrote:
> Ben,
Me too (glad it happened where it did). One lesson to take from this,
which might be a little hard to adhere to, is to not reduce throttle
below 4k rpm without a very good emergency field in mind. Of course in
theory i spose we all fly w/ an em "field" option 100% of the time anyway.
Similar to your experience, one of the factors i noticed was that my
idle was slower than usual. I didn't take the time to try bumping it up
before quitting for the day, but did try taxiing around a little and then
leaving it at the abnormally slow idle to see if it would quit there.
It would not quit in this scenario, which lends credence to other
more expensive possibilities. As for rings, the engine is 148 hours,
~30 since total top end disassembly and de-carboning, so i also doubt
stuck rings. It is either just bad mixture, air leak, or heat damage.
CHT temps never showed high (and yes i was looking at them a lot) so
i'm hopeful that it is not heat damage.
Also on the suspicion list is idle mixture combined with slow idle
setting. I couldn't recall which direction of that screw richens, so
i left it alone till getting home to re-read the manual. It is out
exactly 1/2 turn.
Hey! i thought these planes were supposed to be simple! If i were
GA i guess i'd just take it to my mechanic and squawk, or what the
heck, maybe just sue somebody. :-)
-Ben
In this discussion, we should maybe keep some definitions in mind.
"outperform" is one thing, "efficiency" is another. A well
designed and configured (pitch/length) 3 blader will never be more
efficient than a well designed and configured 2 blader on the same
plane/engine/gearbox.
Another note ...one time i found a "rule of thumb" from an aero textbook
about the ideal maximum efficiency for prop tip speed. Altho , i don't
recall the exact number, i do recall doing the calc's and realizing that
my 66" 2-blader running on the standard 2.58 Rotax gearbox is really
turning substantially *below* that ideal prop tip speed. This naturally
invites me to consider changing to a lower ratio gearbox to increase
the prop speed (reducing pitch too), but then i figure i'm loud enf to
piss off enf people already. :-)
Ben Ransom (*)
Richard,
Thanks for your comments. The engine down thrust is something I haven't
even given any thought to. I really don't even know if my original
FireStar has any down thrust. That's something I can check. Your right
about the forward cg (and flying faster) does not seem to be adding up
with conventional theory, but when I'm on my return trip home after using
up the fuel in my auxiliary gas cans, the FireStar's cruise drops ~ 5
mph. Maybe I can coax Homer out of retirement to answer my question.
Ralph Burlingame
Original FireStar
incidence
the
>elevator drag.
the
thrust
about
forward
the
the
of
but
Richard Pike
MKIII N420P (42oldpoops)
Good for you Ben.
Date: Monday January 05 1998 3:15 PM
Subject: Kolb-List: Re: engine out landing
rules of
situation
As the
possible
to
>-Ben Ransom
Subject: | Fw: RV-List: Hot Time |
Hi everyone, I'm forwarding this post from the RV list because almost all of
us could benifit from a little reminder about fueling safety. This guy is
REALLY lucky.
Be careful,
Rusty
>I had a rather exciting experience that occurred while refueling my
>RV-6A. I have a Mazda 13B as a power plant using auto fuel. Not having
>auto fuel at the airport, I have been transporting it in a 5 gallon
>plastic container (approved for auto fuel) and using a funnel to pour
>the gasoline into the wing tank. Sensitive to the risks of static
>electricity, I always "grounded" (I know - I question whether you can
>truly "ground" a plastic container) the plastic container against the
>airframe prior to pouring in the gasoline. I have refuel the aircraft
>many times before using this method (as well numerous lawn mowers, weed
>wackers, etc). I had hauled the aircraft out of the hangar and had it
>sitting in the middle of the tarmac in front of the hanger and had
>commenced to refuel.
>Well, this time it happened. As I was approximately half-way through
>pouring from the five gallon container into the funnel (the plastic
>funnel is a very wide mouth with a filter cartridge in its center- used
>to quickly fill race cars) the fireworks started. The gasoline ignited
>with a "Swoosh" and I found myself holding a flaming funnel as well as
>the five gallon container which had flames coming from its opening.
>Needless to say, things got very exciting and busy in a hurry. As I
>reacted to the flames going off, I swung the container away ,which was
>in my right hand, removed the flaming funnel from the wing tank opening
>with my left hand. In the process I sloshed some flaming gasoline onto
>the wing and tarmac. And flames were now also coming from the opening
>of the wing tank. So by quick count, I had flames coming out of the
>wing tank, some burning on the wing, a patch burning on the tarmac, a
>flaming funnel as well as the 5 gallon container on fire. Did I say
>things got exciting in a hurry? I immediately move the flaming
>container about 12-15 feet away from the aircraft and set it down,
>quickly move the flaming funnel about 5 feet from the container and laid
>it down.. Immediately dashed to the plane and placed the fuel cap into
>the tank opening stuffing out that fire, smothered the fire on the wing,
>ran back to the container and placed its lid on the flaming opening
>smothering that fire, moved the still flaming funnel further away,
>smother the fire on the tarmac and then returned to smother the funnel.
>Finally, all fires are extinguished and I take time for a breath.
>Wasn't timing myself as I was somewhat distracted at the moment, but
>believe the entire event from ignition to all flames out was around
>30-45 seconds (could be wrong about the time, but not by much). Old men
>can move quickly if motivated properly.
>Yes, I did have a fire extinguisher, but had neglected to take it out of
>the car and didn't feel I had the time to dash to the car to get it.. I
>also have a small Halon fire extinguisher mounted between the seats of
>aircraft - but, again distance and flames were between it and me.
>Won't make that mistake again. Also, I will never use a plastic
>container again, but will use a metal one with a little cable attached
>that I can ground to the aircraft. I will also not use a funnel, but
>will probably use one of the rotary pumps with hose and nozzle grounded.
>So the good news is no damage to me or the aircraft and a much wiser me.
>So, while it had not ever happened before, I quickly found out that one
>time is one time too many.
>For your consideration
>Regards
>Ed
<< he engine can quit at idle as in Ben's situation, but that does not
drop. >>
Same with my 582 - when the weather turns cold here in Wis the idle air
control screw must be turned in to richen the idle mixture or the exact
stalling behavior would appear.
Pete Krotje
<< I'll bet dime-to-a-dollar that almost all (near) seizures
occur at or near full throttle with an engine that is not properly
warmed prior to the application of full power. >>
This is another possible scenario for a seizure. And a good point. It
may call for a simplification of the Rule: IF YOUR ROTAX ENGINE STOPS AT ANY
TIME AND YOU DON"T KNOW WHY IT QUIT REMOVE THE EXHAUST AND LOOK FOR EVIDENCE
OF SEIZURE.
> John Jung
> - There was a earlier request on dead stick landings regarding drag ect.
I have done quite a few and I always found that they wern't as smooth as
when the engine was idling. It finally occurred to me that when I landed
nbormally I need to keep 50 MPH airspeed. I can flare when close to the
ground and the stall comes at about 35-40 IAS. When I landed without the
engine I attempted to duplicate the engine landing and always dropped it
how ever high I was when I started the flare. What happens is that the
airspeed bleeds off instantly when the flare is begun- you stall however
high you were at the time. I strongly suggest that yu carry at least 5
mph more speed and 10 wouldn't be too much. That way when you flare you
will have a chance to land without stalling.
Larry
Kolber's
A couple of years ago a friend and I flew into Stanton Airfield, a glider
training base with a large grass field with 2500 and 2000 foot runways
each 300 feet wide. This is the place for first flights and "hanging out"
with other pilots. I was enjoying the good weather that summer day and I
told my buddy that I wanted to try some "dead sticking". I discussed my
plans with the glider operations field manager and proceeded to take off
in my FireStar. I climbed to 2500 feet about 1-1/2 miles to the NW of the
field. At that altitude I throttled back to idle and switched off the
engine. I glided around for less than 5 minutes and decided to set up an
approach to the field. My idea was to set up an approach with plenty of
altitude still left in case I misjudged it. As it turned out, I saw that
I was a little too high, so rather than put it into a side slip, I pulled
back slightly on the stick to slow up. The slower speed increased my sink
rate and I saw that my final approach was right on. About 100 feet up I
increased my speed with forward stick to grease it in. I made a smooth
landing onto the field and it was fun! I think with more practice, I
could be an expert FireStar glider pilot. The advantage here, was the
large field and very little traffic that day which allowed me to do it.
This was not my first experience gliding the FireStar. I had made about
10 intentional dead stick landings at another field the year before.
Ralph Burlingame
Original FireStar
I certainly agree with you here!
Ralph Burlingame
Original FireStar
>point. It may call for a simplification of the Rule: IF YOUR ROTAX
ENGINE >STOPS AT ANY TIME AND YOU DON"T KNOW WHY IT QUIT REMOVE THE
>EXHAUST AND LOOK FOR EVIDENCE OF SEIZURE.
Subject: | Re: nose heavy Kolb |
>mph.
Didn't you mention that the (2) three gal aux tanks were behind the seat?
That would move your cg aft and would cause your airplane to fly faster.
When the aux tanks are dry, it would seem that the cg would then move
forward giving you a forward cg and causing the stability to go up and the
airspeed down. It sounds as if things are working as conventional theory
would dictate.
From: | "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM> |
Subject: | stuck rings and things... |
Ralph B.: One of your last appends talked about a Rotax you had stuck rings
in, at 200 hours. At that time, what oil were you using, what ratio (assuming
no injex system)? Thanks
All Rotax operators: I pulled my X manifold off for high temp coating and
was surprised to see so much buildup of thick black tar-like substance on the
inside of the "Y" pipe near the cylinder. This was also present on the spark
plugs. I immediately blamed it on the oil, of course. Now I am thinking it
could also have been from the fuel. (This is injection-equipped 582).
What deposits might be left behind by the fuel? The EGTs look great but
it could be too rich, would this give me black tar? Or is it excess heavy
unburned oil base from the injex oil? This stuff is stuck to my prop also.
Someone asked about Sport Prop: Also check out Power Fin. Their web address
is: http://www.everett.net/users/expat/index.htm I am very happy with the
PowerFin on the 582 with "C" box and 2.62 ratio, three-bladed 66", pitch
is ground adjustable. I am glad I can adjust the pitch because the Rotax
keeps getting more and more power as it breaks in. I have increased pitch
three times now, +-3/4 of a degree each time, each time the RPM will drop by
400-500 RPM initially and then, a few hours later, I see it is back up to 6800
again. I am using the Warp drive protractor. I started out at 16 degrees
indicated, and will be going to 18 degrees 30 minutes next. All measurements
are measured at the tips, with plane setting level. As I understand the
general concensus from you guys, I am aiming for 6100 or so, Static.
Skip,
Ralph can answer for his original Firestar, but here is how my
original Firestar responds to weight added behind the seat. The CG moves
forward causing me to hold back on the stick to keep altitude at my
normal cruise. To fly without pressure on the stick, I increase the
rpm's until the pressure is off and I find myself cruising faster.
Basicly I don't have adjustable trim, so I use the throttle.
John Jung
> >mph.
> would dictate.
Larry,
I carry the extra airspeed anytime the runway is long enough,
even when the engine is running.
John Jung
> high you were at the time. I strongly suggest that you carry at least 5
> Larry
So how long is this windshield? Mine is made from a 2' by 4' piece of
Lexan. Is your larger than that? What is the dimension up the center?
John Jung
> , Woodbury ,MN
Adding my experience to the above and similar comment by someone else
yesterday ...sorry i can't recall who. The FS pitch forces get even
lighter when the prop stops, and you do feel the lack of top thrust
keeping the nose down. It is therefore easy to let the nose up and
lose airspeed very quickly. You can try this at good altitude over a
long field; my first time I thought it felt tail heavy and whispering
"stall" as I slowed down thru 40-35mph. So, w/ engine out, i want to
hear lots of wind whistling by and feel some stick resistance, e.g. 45
minimum in glide, 50-55 even better, till over the numbers. Note, on
my FS, 47mph seems to be my best glide angle.
I think the lighter stick (in pitch) tends to make you want to fly a
little faster as this stiffens up the pitch forces to what we're used
to, so this is good. In my engine out on Sunday i found myself flying
a little fast and thought later that i never did even think of using my
best glide speed, so that was maybe a bit of a mistake. However, i also
felt i had the runway easily within reach by cutting the base leg.
-Ben Ransom
Subject: | Kolb Long Windshield |
John, here is the information you requested,,,,,,This windshield was cut
from ,090 lexan and the shape follows the curved version that came with
my quick-build kit. If you spread the windshield out on a flat surface
the dimensions are ......Curved rear section; 79 inches, Two side
sections; 13 inches each, Front section that goes around nose cone;42
inches. Distance from center of windshield from front to back; 31 inches.
In addition on my firestar the overlap of lexan on the nose cone in the
middle is 2.5 inches and 3 inches on the sides. Two nearly identical
windshields were cut from a ( as I remember ) 48"x60" piece of lexan
obtained from Commercial Plastics & Supply, St. Paul, MN...Telephone
(612) 645-1666, cost about $52. I remember at the time it was the minimum
they would sell me. On the outer edge of the 79" curved rear section I
attached black plastic truck door edge molding. It has its own
self-adhesive that makes attaching a snap. Covers up any imperfections in
your cutting job and makes for a very attractive finishing touch. This
can be obtained at most auto supply stores. Use your current windshield
as a pattern for the front and sides and with a little trail and error I
found you can use even the rear section as a pattern, just making sure
you keep it symmetrical throughout. I fly with a motorcycle helmet with
a bubble face shield. Prior to installing this larger, thicker
windshield, every time I turned my head to the right or left, the
slipstream nearly tore my head off. No problem now. Ray Lujon
---snip--
> OK, have at me. :)
One situation when a 3-blade prop would be more efficient than a 2 blade
(i.e. it will provide more thrust) is when a 2-blade would require a
pitch angle that would put it near its critical angle of attack. This can
occur when the prop length limit requires a larger pitch to properly load
the engine. It can also occur in high drag, slow speed planes. Slower
forward motion results in a larger angle of attack on the prop airfoil.
An airfoil becomes increasingly less efficient (provides less
lift/thrust) as it approaches its critical angle of attack.
There are probably other instances, but that is all I can think of at the
moment. While building a Kolb, I am flying a QS Sprint with a single
carb 503 Rotax. My 3-blade Powerfin gives me much better climb and
equal top speed that any 2-blade setup provided (same diameter
prop). I have yet to hear a 3 blade that was noisier than a 2-blade on
the same engine, even with the same prop diameter.
Please cancel automatic mail coming to my e-mail address:
treker3150(at)aol.com. Thank You.
To Ray and all,
...cost about $$$....
OUCH! If any of you are lucky enough to be near a Cadillac Plastics
warehouse... I don't know if they are nation wide in metro areas or not...
but they might be. I buy Lexan there by the pound... usually from scrap
pieces that are not full sheets at $1.50/lb. You have to dicker with them a
little as they will ask a lot more at first. I reported earlier that the
piece of Lexan to build my half doors cost $6.00. At first they wanted $20.
Good hunting, er. I mean bargaining.
Later,
Cliff & Carolyn Stripling Him: Kolb MKIII - N582CC (37.3 hrs)
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
Both: 5th Wheel - RV - Travel
____________________|_____________________
___(+^+)___
(_)
8 8
Subject: | cancel automatic e-mail |
Please cancel automatic e-mail being sent to by address:
treker3150(at)aol.com. Thank you.
Subject: | 503 exhaust ports |
FELLOW KOLBERS
I removed Y pipe to inspect for carbon deposits
and noticed sheet metal (schroud) has a smaller hole than
the exhaust port ~1/16" ,will this reduce HP very
much?
Another comment about lexan. It is pretty heavy. I know there
is the issue of lexan rigidity, but keep in mind that .090"
lexan weighs 50% more than .060". The standard FS KX/KXP long center
windscreen is .060 and I used .030 for the side panels, which i'll
admit, was barely adequate, and i even added a 5/16 AL tube brace on
each side panel. But it is still lighter and ounces do add up.
-Ben
Subject: | Re: 503 exhaust ports |
On Thu, 13 Nov 1997, friend wrote:
> FELLOW KOLBERS
> much?
I personally would (and have) removed ridges created by gaskets
and intake manifold casting lines. I'd go after the ridge
made by the sheet metal as well, but i don't have that problem
on mine. Make sure you don't just have an alignment problem
with the shrowd as you don't want to cut away too much and invite
an air leak.
Any removal you do will probably make negligible, undetectable
differences in performance but you'll feel better knowing it is
as good as reasonably possible.
-Ben Ransom
Clarification...The Lexan overlaps the fiberglass nose cone in the middle
( top ), 2.5 " and 3 " on each side of the fuselage steel frame. The long
windshield is heavier than the short windshield but much lighter than the
full enclosure. It provides more than adequate protection from the
elements even during the Minneasota winter but it does not have what I
found objectionable with the full enclosure; annoying light reflections,
difficult to get in and out, rattled while taxing, complicated access to
the recoil starter, stuffy, can become uncomfortable on the ground during
mild weather and it interfered with the fabulous view. Ray Lujon,
Woodbury, MN
Subject: | Re: stuck rings and things... |
I was using Valvoline 2 - cycle engine oil with a 50:1 mix for the first
200 hrs. I have since switched to "Klotz" all synthetic at 50:1.
Ralph Burlingame
Original FireStar
writes:
>rings in, at 200 hours. At that time, what oil were you using, what
ratio
>(assuming no injex system)? Thanks
Subject: | Re: Lexan Sources |
Ben and others,
Maybe my increased cruise speed was partly do to reduced drag and partly
due to even more weight up front. I was concerned about the added weight
of that .090" lexan windshield (I mean it weighed ~ 3 times the old one),
but I have no problem flaring on touchdown. It's such a big improvement
over the old. Not only does it look great, but is very functional as
well.
I think you hit on something Ray L ........
Ralph Burlingame
Original FireStar
writes:
>-Ben
Subject: | Re: long Windshield |
John,
When I'm sitting in the seat, the top of the windshield is about 6 inches
horizontal and about even with the top of my helmet. It comes back much
further than the original supplied with the kit. Like I said earlier, it
definitely improved my cruise by 5 mph. Please don't confuse the faster
cruise, with the new windshield and the added weight issue . I've always
had the faster cruise, even with the old windshield, with added weight up
front.
Ralph Burlingame
Original FireStar
>John Jung
>The
>447
>4000rpm.
>Lujon
>> , Woodbury ,MN
John,
December 07, 1997 - January 06, 1998
Kolb-Archive.digest.vol-aj
