Kolb-Archive.digest.vol-am
February 26, 1998 - March 17, 1998
Subject: | Chinaware: Please disregard |
Oops - sorry. Sending too much email to the kolb group today.
Dennis
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
On Thu, 26 Feb 1998, DLSOUDER wrote:
> Could you please provide more information: name and where it could be
> purchased, etc. on your China?
I want mine powder-coated. And, i wasn't clear; is this china riveted
or bolted? Will we see this at Osh or SnF?
Subject: | Re: Problem with Wing Rib Jig |
>> Has anyone else run into this problem and if so what did you do about
>> it?
>> Thanks.
>> Best regards,
>> Bill Kautter >>
On Thu, 26 Feb 1998 GeoR38(at)aol.com wrote:
> I noticed the same thing when building my Firestar and decided that since I
> lived in a 95% humidity area, a trip to the kitchen oven might shrink the
> plans ....and it did!
> GeoR38
Note that the plans book accounts for the possible difference in blueprint
copies and *says to measure* when you make the jig. The blueprint is
a good starting guide. Yes, i spose all those who ordered pre-made ribs
are smiling at the fun they missed out on.
Ben Ransom
Subject: | Re: Where to put it |
>Richard Pike wrote:
>> One good place to put the GPS is on your control stick. On the
>> MKIII, the top of the stick is 3/4" O.D. I took a short length of 3/4" steel
>> tubing about 3" long and cut in in half lengthways, then took a steel strip
>> 1" wide and 6" long and welded it to one end, angling it out and up a bit.
>> Then took some rubber padding and glued to the steel. Took black electrical
>> tape and taped the GPS to the rubber padded side of the steel strip.
>> Peel back the top half of your rubber hand grip, and lay the half
>> round of tubing up against the control stick and tape it in place with black
>> electrical tape, then roll the rubber hand grip back over it.
>> When you get done, the GPS will angle up and out away from the top
>> of your stick at a good angle to read, and if you have the type that has the
>> keypad on the bottom, like some of the Magellen's, you can reach the keypad
>> with your index finger of your flying hand.
>> The rubber handgrip over the electrical tape will keep it plenty
>> secure. Make sure it will clear the windscreen, etc. It clears the MKIII,
>> but it is close.
>> Richard Pike
>> MKIII N420P (42oldpoops)
>Richard
>I like your location idea for GPS. I think I'll try that.
>What nav radio do you have and where have did you put that? And as I
>recall, you also have a transponder. Where did you put that?
>You mentioned before that you mounted the VHF antenna behind the pilot
>seat and a suggested a ground plane of 12" on a side. Do you mean
>something like a 24" strip of aluminum, perhaps glued to the fabric on
>the inside, with the antenna mounted in the middle and protruding down
>through the fabic? Or does this ground plane need to be a 24" circle?
>So far I have been using an icom A-22 with the attached rubber duckie.
>Thanks
>Terry
> I am using a Terra TPX720 handheld and a Terra transponder. I made a
little console that is attached to the aluminum floor pan in front of the
seats. The transponder is on the bottom, and the TPX720 lays on top of it
and is the same width. (I had to cut a big slot in the right side of the
console where the push-to-talk button sticks out. If you look at a TPX720,
you'll understand.) The intercom box sits on top of the whole mess. The
controls are about an inch away from the front edge of the seat.
You have to swing your right leg over it getting in, but then it is
out of the way and you can reach and see everything. The floor pan is
removable, and everything quick disconnects. The radio is hard wired into
the airplane's 12-volt system, and I drilled a little hole in the bottom of
the case and ran 2 wires to the push to talk button atop the control stick
(in front of the GPS).
The ground plane is ideally a flat metallic something at least 12"
on a side, 144 square", and preferably 3' from the nearest similar shaped
metallic protrusion (like the landing gear). On a Kolb: HA!
I have a sheet of .020 aluminum glued to the inside of the belly
fabric, half way between the left main gear to the rear of the cage. It
extends from the frame on the left edge, and under the main tube, so it is
roughly 12" on 3 sides and 8" on the rear. There is a pass-through connector
in the middle of it. At radio shack they sell a solderless BNC connector for
coax, and it is made in such a way that you can stick a thin stiff wire
(model airplane pushrod) into the middle of it for your antenna. You will
have to grind a taper on one end of the antenna wire to fit it into the
center pin, then bed it in epoxy for strength. My antenna goes straight down
for a couple inches, then curves back parallel with the main tube to keep it
out of the grass. It is 24.5" long from the surface of the ground plane to
the end and ATC says it sounds great.
The transponder antenna is in the middle of another 12" square sheet
of aluminum directly below the passenger's thighs. ATC says it works normal.
The encoder is on the underside/rear of the floor pan, you can see it by
looking down past the bottom of the control stick, I put it there so that
the adjustment pots are in reach with out taking anything loose, if it ever
gets out of altitude tolerance, and has to go in the shop.
Sorry this was so long, but it sounded like a how-to question.
Richard Pike
Subject: | Re: Original Firestar hazard |
<< aybe some of you aren't even bothered by this, and I am just a
worry-wart. Quien sabe?
Ron >>
Nadia saben Ron but you can rest assure that I will check mine the first
chance I get.
GeoR38
Subject: | Re: Kolb Service |
>.... Look at the computer software business, no one thinks of
>calling up microsoft for free
>product support for a pirated copy of windows. The analogy is not
>perfect,
>but it is not far off either. Kolb would be well within their rights
>to have
>a separate parts price list for downstream buyers, or to refuse to
>deal with
>them at all. But they don't.
I bought my "Flyer" used in 1991 (out of production since 1984 - I think)
but before signing the check I talked to Dennis on the phone. My main
questions were; What should I generally look for?; What (if any)
modifications should have been made? and; What (if any) flying qualities
or quirks does it have?
I thought Dennis was being a little vague. I couldn't get him to be very
specific on anything regarding the plane except to say that the Flyer was
in general an "OK" design. He stressed the importance of UL training and
pointed out that it would fly very different than any "spam-can." I was a
little put-off but bought the plane anyway and now (nearly 7 years later)
I won't part with it. Being a member of the "UL community" for a while
now, I realize what I was asking was for Kolb Company Inc. (not just
Dennis) to bless what had been a box of tubing, some hardware and some
blueprints the last time he saw it. It had now passed through 2 owners
and may or may not resemble something like an Ultralight. In hindsight,
I'm surprised he even took my call! (Many other manufacturers would not
have.)
I think Cavu' is exactly right. Kolb's first duty is to their direct
customers. They have always tried to keep the price of their kits as low
as possible without sacrificing quality. New kit sales are what keeps the
lights on. Selling parts is more a service than a revenue generator.
Unless my memory is failing again, the seat-pan "fix" was a
recommendation from the UK (British) aviation authority following a fatal
accident which involved a stall at low altitude into a hedge row. IMHO,
few other comparable designs would have faired any better. The pan is
probably a good idea but not something that should be confused with a
mandatory "AD" from FAA. The standards of certification for
"homebuilts"are very different between the USA and the UK. (Not implying
that either one is better!)
-Mick Fine
Green Country Ultralight Flyer's Organization (UFO)
Tulsa, Oklahoma
http://angelfire.com/ok/gcufo
mefine1(at)juno.com
via smtpd (for www.intrig.com [206.54.183.49]) with SMTP; 27 Feb 1998 14:54:15 UT
From: | "Gabriel Ledford" <milquetoast(at)thehole.net> |
Subject: | alternate engines |
Does anybody know how many and which alternate engines have been used
on the Mark III? I've seen a VW conversion, and some information
about (I think) a Japanese engine, but that's it. Is there anything
else useful out there?
Gabe
From: | "merle hargis" <merlepilar(at)worldnet.att.net> |
Subject: | Re: Kolb Customer Support |
I have always had good luck dealing with Kolb Co. Especially ordering
parts.
Merle from Orlando
> From: Cliff and Carolyn Stripling <striplic(at)dfw.net>
> To: Richard neilsen ; kolb(at)intrig.com
> Subject: Re: Kolb Customer Support
> Date: Wednesday, February 25, 1998 6:00 PM
> To all,
> I have never had a conversation with ANY of the Kolb staff that hasn't
been
> very professional and polite.
> Without trying to raise a discussion on this subject, that was my
experience
> exactly.
> Later,
> Cliff & Carolyn Stripling Him: Kolb MKIII - N582CC (39.5 hrs)
> (972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
> Both: 5th Wheel - RV - Travel
> ____________________|_____________________
> ___(+^+)___
> (_)
> 8 8
From: | "rutledge fuller" <rut007(at)hotmail.com> |
Subject: | Chinaware/Cheap Shots |
Boy. I am brand new to this list, and have noticed that you guys will
take every opportunity to take a cheap shot on whoever.
I think I will like it here.
Rutledge "Rut" Fuller
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
is it also possiple to use a bidirectional anttena instead of a ground
plane? with a upward and downward part with opposite polarities?
From: | "Richard neilsen" <neilsenr(at)state.mi.us> |
Subject: | alternate engines -Reply |
There seems to be alot of activity on new 4 stroke engine development but
few actually get to market.
Currently there is one VW(mine) ready to fly and there was a Subaru direct
drive. I talked to the guy that built the Subaru and it worked well but
was too heavy to carry two people. My direct drive Great Planes VW 2180cc
acts like it is going to work well but it hasn't flown yet. It accelerates
on the ground about like a Rotax 912 at maxium gross weight and this is
with just me aboard. The empty weight of my plane is 558 lbs. I could have
cut may be 20 lbs from the plane with less paint, full enclosure, baggage
trays etc.
Dennis Souder is or will be testing the Japanese engine but I don't think
on the MKIII. There is a British vertical twin that looks great but isn't
available yet that I know of. There are a number of other engines that
could be tried like the GEO conversion, BMW conversion, reduction drive
VWs, etc.
Are there any others out there???
>>> "Gabriel Ledford" 02/27/98 01:35am >>>
Gabe
Subject: | FW: alternate engines -Reply |
There are a couple of us building MKIII's that are going to use Subaru's
with reduction drives. I sure would be interested in a Jabaru on a
MKIII, at a claimed installed weight of around 130# and 80 HP it might
be a very good fit. It would be 20# to 30# lighter than the 912 but it
is also spinning the prop about 3300 RPM so the static thrust for take
off might not be as much. There is a Jabaru add in the back of
Kitplanes that has a list of aircraft and Kolb is one of them, anyone
know of this alleged install (Dennis)?
> -----Original Message-----
> From: Richard neilsen [SMTP:neilsenr(at)state.mi.us]
> Sent: Friday, February 27, 1998 8:49 AM
> To: kolb(at)intrig.com
> Subject: alternate engines -Reply
> but few actually get to market.
> direct drive. I talked to the guy that built the Subaru and it worked
> well but was too heavy to carry two people. My direct drive Great
> Planes VW 2180cc acts like it is going to work well but it hasn't
> flown yet. It accelerates on the ground about like a Rotax 912 at
> maxium gross weight and this is with just me aboard. The empty weight
> of my plane is 558 lbs. I could have cut may be 20 lbs from the plane
> with less paint, full enclosure, baggage trays etc.
> think on the MKIII. There is a British vertical twin that looks great
> but isn't available yet that I know of. There are a number of other
> engines that could be tried like the GEO conversion, BMW conversion,
> reduction drive VWs, etc.
> Gabe
I don't know. I just did what one of the techies at work told me to
do. When it comes to electronics, pragmatism rules. I am only passing on
what I have been told, and if it works ok.
Richard Pike
Subject: | RE:Alternate engines |
drive. I talked to the guy that built the Subaru and it worked well but was
too heavy to carry two people. My direct drive Great Planes VW 2180cc acts
like it is going to work well but it hasn't flown yet. It accelerates on
the ground about like a Rotax 912 at maxium gross weight and this is with
just me aboard. The empty weight of my plane is 558 lbs. I could have cut
may be 20 lbs from the plane with less paint, full enclosure, baggage trays
etc.
Last time I weighted my MKIII with full enclosure incl BRS(26 lbs) on
wheels was 468lbs with a 582C and IVO-3bl prop. The difference in weight
between yours and mine is 90 lbs. If the 582C weight is 110 lbs does this
mean that the VW motor is about 200lbs? What Hp ,torque and rpm do you get
with this conversion and which prop do you use ?
Frank ReynenMKIII@430hrs
http://www.webcom.com/reynen
Subject: | Re: Fwd: Re: Chinaware/Cheap Shots |
>Rut,
>Someone accidentially posted a message to the list completely off the
>subject thinking he was sending it elsewhere. Another guy was just
ribbing
>him about it... not really a cheap shot. People here as elsewhere on
the
>net do speak plainly though. Mostly it is a real good group with
positive
>input... after all we all like the subject - Kolbs.
>Later,
Well, cheap shot or not, I thought it was a hoot. The message that was
incorrectly sent was, I believe, from the President of Kolb Aircraft.
Good Job Ben.
From: | Gary Thacker <gthacker(at)mciunix.mciu.k12.pa.us> |
Talkin to a guy the other day and he explained that the reason he didn't
have a chute on his U/L was because the have to be deployed at a altitude
of 1500' agl. Is this true. I find that hard to believe. Anyone know
the facts?
Gary
| Gary Thacker | gthacker(at)mciunix.mciu.k12.pa.us |
| Souderton Pa. | |
| | gthacker(at)wsd.k12.pa.us (work only) |
Subject: | Re: Chinaware/Cheap Shots |
writes:
Rut,
If cheap shots is what floats yer boat, you'll absolutely love the
"Fly-ul" list. It has degraded to 95% cheap shots, back-biting and just
common rudeness and vulgarity.
You can sign-up by sending a message to "LISTSERV(at)PERIM.COM " include in
the body, "subscribe fly-ul".
You are correct about who posted the 'china' message, kinda nice to fly
an aircraft made by regular, everyday folks like the members of this list
ain't it?
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
> the facts?
BRS advertises that they've saved several people deploying as low
as 100'AGL, even 75'. But then also when you become the owner i
believe their owner's documentation says to plan on something much
higher than that. I bet 100' would usually work but man you gotta
be thinking fast to make the pull/no_pull decision. The chute
deploys to taught lines in 0.9 seconds. But then it takes a few
more to slow you down, especially with the slider variety which i
believe is all BRS V and above. (Slider was optional on older models?)
Scary stuff, but not as scary as not having one and needing it. :-/
-Ben Ransom
http://mae.engr.ucdavis.edu/~ransom
bransom(at)ucdavis.edu
Hi,
BRS chutes have been successfully deployed below 100 feet AGL, though a
safer deployment altitude is closer to 500 feet AGL. Factors that
determine deployment timeline include airspeed, attitude, degree of
airframe destruction, spin rate and a million other things. A situation
where the engine quits on takeoff and you deploy during a moderate speed
steady glide are near optimum and result in successful deployments down
low. If one wing folds up over the aircraft and your falling slowly
with high spin rate like a spining maple seed and the rocket has to pull
the chute past, bouncing off or even trying to go through the damaged
wing and the chute has to open with little airspeed and lots of rotation
then deployment will be much longer if at all. Kolb structure has a
vary good record so for our planes, engine out or stall spin are more
likely to be the reason for deployment and are the senarios where the
chute could be real valuable. On the otherhand with a controllable
aircraft that can land at 30 MPH or less, you may be better off just
gliding in to whatever is down there then swinging in under a chute at
20 to 30 feet per second (17 MPH not counting the swing factor). Just
depends on the whats down there. It does give you one more option
though and for pilots options are allways good.
Topher
PS I flew with one of the first BRS chutes sold back in 1982, it was a
soft pack, and the chute was held in a nylon bag only with velcro. It
was mounted on the back bottom of the seat on our Rotec Rally 2B (a real
piece of crap aircraft!) and we flew from a grass strip. Well the
grass was a little long one day and as I rotated for takeoff the grass
brushed on the nylon bag and riped open the Velcro. On climbout just
over the end of the runway the chute fell out of the bag. It did not
deploy or open, just fell out so it was held on by both the risers and
the apex line and the whole mess got to spinning in the propwash trying
to wrap itself around the tail. From my point of view all I knew was
that climb rate went to near zero and I was wagging back and forth in
yaw, and up and down in pitch. I looked over all of the plane that I
could see with my helmet on and couldn't figure out what was happening,
but I remembered to fly the plane such as it was. Finnally I rotated
around in my seat so I could look straight back and I saw the chute back
there spinning around banging the rudder and elevator each time it came
around, leading to the yaw and pitch oscilations. I made it around a
very low pattern and luckily realized to land dead stick or the steal
bridal and chute risers would have hit the prop on flairing. They were
just under the prop as it was. BRS repacked the chute for free in a new
softpack that included a mechanical hook to backup the velcro, and we
never had a problem after that.
FRANK
I got your seat belts off today they are in the U S mail , and will be at
you door on monday .
RICK
Subject: | Four stroke options |
Forwarded to the list, the server sent it to me by mistake:
Jeff
Date: Fri, 27 Feb 1998 20:50:52 -0500
Subject: Kolb-List: Four-stroke options
Richard neilsen wrote:
There are a number of other engines that could be tried like the GEO
conversion, BMW conversion, reduction drive VWs, etc.
Hi All,
I'm mostly in the lurk mode, especially since I'm quite new to
the
light plane experience and still pretty much in the learning mode.
But on this subject I'll throw in my 2 or 3
cents worth. Like many people, I feel that there are many good reasons
to run a four-stroke engine on an Ultralight. So far though, they are
quite a high priced option, and not many have any kind of track record
by which we can judge them by more than the fact that they are
four-strokes.
Weight is a big issue. How heavy can an engine be before we
disqualify
it? I was thinking of a limit of about 135 -140 pounds max. One way to
eliminate a few pounds is by having an engine with a peak torque output
at or near the propeller rpm, thus eliminating the PSRU. There is a lot
to be said about a large displacement, long stroke twins. Europa is in
the final stage of developping a BMW motorcycle based powerplant for
their line of aircrafts. Jabiru has a great little 4 cylinder engine
that's not too heavy. The SVS-1400 flat twin is also a nice looking
engine though a bit too heavy. But except for the BMW, I don't have a
clue on the reliability of these newer powerplants. So we're back to
being test pilots.
I would feel much safer, reliability wise, flying a machine that
has a
known entity as a power plant than experimenting with some new, hitech
engine, that still has to prove itself. Also using a popular engine
does away with the parts availability problem associated with exotic
engines. Conversely, a well proven engine still has to be properly mated
to the airframe and propeller, not a negligeable feat. So where does
that leave us ?
Now here is the quizz question: Where can we find a medium
weight, 2
or 4 cylinder four-stroke , fuel injected, well proven engine that puts
out about 70 HP and 70 ft-pounds of torque at 3000 rpm, is a real miser
on gas and is absolutely reliable ? I have a few candidates, but I would
like folks to think about it.
Guy,
Subject: | 4 stroke engine-BMW |
For what it's worth, I've been driving the same BMW engine for the last
21 years. It is a 750cc boxer (2 cylinder, horizontally opposed) It
has been ultra reliable, and economical. However, at reasonable highway
speeds and somewhat above, the engine is not developing anywhere near
max power. When cruised at max throttle with full load, (driver,
passenger and full saddlebag) at 115 mph (I was in Germany for the first
year I owned it) and 7000 rpm the economy goes down to about 40 mpg from
a normal of about 50 to 54. And on flat terrain, this is still not
fully loading the engine, that's just all the rpm you can get with the
available fuel/air mix.
The 1977 750 cc is rated at 50 hp if I remember correctly. Later
engines and larger engines of course will have greater hp ratings. I
think they are great engines for motorcycles, but I wonder how they
would hold up in an airplane with its demand for higher continuous power
settings.
Weight is another consideration. My R75/7 has a curb weight of 460lbs
which is light for that class of bike, but the engine seems like a
pretty good chunk of that weight. The only difference between different
sized boxers at least of the late 70's early 80's was in the size of the
cylinder/piston. The crank, rods, case, bearings, etc, were said to all
be the same.
my pennys worth.
Tom
124 King Dome Road
Our name is King, our house is a Dome, and it's OUR road!
the same
BMW engine for the last 21 years. It is a 750cc boxer (2
cylinder,
horizontally opposed) It has been ultra reliable, and
economical.
However, at reasonable highway speeds and somewhat above, the
engine is
not developing anywhere near max power. When cruised at max
throttle with
full load, (driver, passenger and full saddlebag) at 115 mph (I was in
Germany
for the first year I owned it) and 7000 rpm the economy goes down to
about 40
mpg from a normal of about 50 to 54. And on flat terrain, this is
still
not fully loading the engine, that's just all the rpm you can get with
the
remember
correctly. Later engines and larger engines of course will have
greater hp
ratings. I think they are great engines for motorcycles, but I
wonder how
they would hold up in an airplane with its demand for higher continuous
power
settings.
Weight is another
consideration. My R75/7 has a curb weight of 460lbs which is light
for
that class of bike, but the engine seems like a pretty good chunk of
that
weight. The only difference between different sized boxers at
least of the
late 70's early 80's was in the size of the cylinder/piston. The
crank,
rods, case, bearings, etc, were said to all be the same.
my pennys
worth.
Tom
124 King Dome
Road
Our name is
road!
Subject: | Re: [Fwd: Re: Where to put it] |
Date: Fri, 27 Feb 1998 09:35:10 -0500
Subject: Kolb-List: Re: Where to put it
> >Terry
> Richard Pike
Richard
Thanks for your imput and it certainly wasn't too long for me.
I will probably install my VHF antenna similar to yours. I haven't
decided to install a transponder yet, but the thought has entered my
mind.
When I built my MK III, I built a console just in front of the pilots
seat which contains ignition switch and misc. toggle switches on the
outside and opens for access to a fuse block on the inside. I may
rethink my design and try to put it all together in this location. This
spot seems like prime real estate for access and visability while
flying.
Terry
Subject: | Ultrlight Vehicle Questions |
If we can't agree on a heavier weight limit, maybe we don't deserve an
increase. Ray from woodbury,MN
Subject: | Re: Ultrlight Vehicle Questions |
I don't think we will ever get a weight increase or any other change to
part 103, and in fact we better all pray that they dont just get rid of
it all together. If FAA knew how successful 103 was going to be they
never would have passed it. I think it is a great rule, the most
freedom to fly granted to the citizens of any nation, and they have been
leanient towords overweight and over fast planes for the most part. I
am getting my pilot cert. and will N number my FSII so I can fly
passengers and not be breaking the 103 rules, I will be able to carry
more fuel for longer legs too. If they were to raise the
weight/speed/fuel/stall I am sure it would come with a host of
regulation and training requirements that I dont want stuck into 103.
Leave well enough alone and if you're flying a non-103 aircraft get it
n-numbered and a Pilot liscense, it costs a bit but it is the law.
From: | george_eagle(at)webtv.net (George Thompson) |
Subject: | 4 stroke engines |
For what it's worth ( 2 cents or less) A few years ago at the local
Copperstate fly in, a guy had a BMW motorcycle engine/ with tranny
mounted on a trailer. It was a drive shaft type. He had a thrust
bearing on the end of the shaft and had mounted a prop it. It wouldnt
pull the load in direct drive, so he shifted down one gear for the
reduction. Now I don't think for a minuet that the tranny would take
that for very long. While it was running tho, it sure put out a bunch of
wind!. I have never heard anything of it since. Has anyone ever heard or
seen this deal since? I think the BMW bike enging is a very reliable
enging but I'm afraid it's just too heavy for the power avaiable. I
realy like the looks of the Jap HKS 700. But it is nearly twice the
price of a 503. Do any of you know of anyone having a HKS 700 on
anything flying? A Firestar flyer @ 250 Hours. Blue Skys and Tail
Winds.
Subject: | looking for fueselage kit |
looking for fueselage kit anyone out there need to get out of teir project
or want to sell for whatever reason contact me at Hasnimus@ aol. com
Once again I bare my throat to the fangs and barbs of my sometimes
thoughtless companions of interest, but since this list is supposed to be
dedicated to doing thing the right and often easy ( as in "once is enough")
way. I thought to pass on a couple of things that I have found this winter.
Keeping in mind of course these are only opinions.
Richards idea of mounting the GPS is a very good one, the only improvement
that I can think of is- if you happened to buy the mounting bracket that
comes with the unit, then drill and tap the top of your stick. This allows
the unit to be folded down when you are not using it and to adjust it for
less glare when traveling in that particular direction. My Magellan unit
holder even has a recess that fits on the stick.
Aircraft radios- I have just been through the trial and error mode, mostly
error, of mounting a radio in my FSII. I chose to mount the antenna
underneath, about directly under my right cheek. The radio is mounted on the
left side of the seat against the side of the cage. I also eliminated the
second seat option and mounted a panel there below the throttle and beside
the seat. It takes up all the room that a foot would normally take up. I
chose a Delcom 960 because of aircraft induced poverty. My first attempt
was with a 22" length antenna that a fella EAA member told me about. I have
a SWR meter so I checked it with that. It was terrible! To give the
shortened version I enlisted the help of the radio tech where I work. I
found that I could get a good SWR check using 32" which is 1/4 of the
average length of the wave, but when I bent it to allow for ground clearence
it changed the SWR back to terrible. I eventually ended up with a antenna
that has a bend at 4 1/4 inches and 30 1/2 straight length. This gave me a
match on the SWR that just barely moves the needle. It appears that a remote
location from the radio helps the match. I found that two feet or so
appeared to help. I also checked the rubber antenna that came with the radio
and it appears to be a lot less than perfect. A 2 1/2 to one mismatch.( most
reccomend no more than 1 1/2) I checked the output of the Delcom and found
it to be 6 watts. This is all using my companys sophicated radio equip. With
the antenna installed I can now pick up the airports atis information six
miles from the airport, a feat not matched by the rubber duck. It still has
not been tested from the air, but I am sure that it will be better by far
than using the rubber antenna.
I also had to replace the landing gear legs. I first did it the way that
Kolb says- Or what I felt to be a reasonable facimile thereof -using a piece
of angle iron between the axles to line them up straight. I weld for a
living and I would swear that it was as straight and tight on the angle iron
as it could be, I even clamped it in that position. The finished product had
a two inch toe in. It would have rolled the tires off the wheels before I
could have got it off the ground. Not wanting to drill more holes in the
legs than necessary I snapped a chalk line between the tail post and nose on
the floor (using a plum bob) and measured first the back and then the front
on the wheels to the chalk line. Even the slightest movement of the wheels
as in drilling and the thing can be off as much as two inches. I took the
wheels off the struts and enlarged the first hole in the wheel assembly. I
then put it back on the plane with the bolt on but loose and moved the wheel
until I had a 1/4 inch toe in at the front of the wheel. I then tightened it
down tight enough to hold it while I drilled a 3/16th hole above the first
through the leg to keep it straight. The same process for the other side and
now I have a wheel that will roll. The difficulty that I had, was the
pressure from trying to drill that stuff will misalign your wheels. The
wheels roll nice and straight now. I am sure that there is a easier and
probably better way than this but it allowed me to fix the problem that I
had invented.
I also had trouble with the original "wheel barrow" wheel brakes since the
brake drums are very difficult to get true on the wheel. I had one that
would rub badly causing the cage to sway violently at certain speeds. The
only solution was to drill the mounting holes for the "drum" larger and
tightnen the nylock nut down just enough to be snug but allow the drum to float.
The other thing that drove me nuts about the plane was trying to get the
wing to fit into the tube on the boom when I was folding it. I finally took
a torch and heated the holding tube on the boom and with a round rod belled
it out until it looks like a blunderbuss. It is dificult to describe how
smug I can get when I fold it up now.
Hopefully these things will be of some use to those on the list. You may
have a better way, if so share it. Laziness is the mother of invention I
have been told.
Larry
><< The Laser is coming!>>
>Whats a Laser, does anyone have a picture?
Kolb promoted the Lazer in their advertising for several years but never
produced it.I figured there had to be something inherently wrong with it for
them to spend so much time and money promoting it but never producing
it.Check back issues of kit planes from about 3 years ago.
Woody
Subject: | Re: Ultralight Vehicle Questions |
>Does anyone know why 254 pounds was picked as the limit for empty
>weight, excluding floats and safety devices, to be Part 103 legal? What
>is so magic about 254 pounds? Why can't the limit be raised to a figure
>that is more realistic from a safety standpoint and more in line with the
>majority of " ultralight " vehicles that are on the market today? With
>that one minor change the majority of Part 103 could still be retained.
>What don't I get? It all seems so simple. Maybe that's the problem, too
>simple. Ray Lujon, Woodbury,MN
254 lbs is about 100kg. At the time of the ruling manufacturers were very
excited and happy. They were expecting the limit to be 150 lbs.and foot
launchable.They were overjoyed with the extra weight to play around with.
They said it would enable them to produce safer ultralights.Before the end
of the year "fat" ultralights were born and now compose most of the
ultralight type vehicles out there.
Woody
> Frankly, I think the Kolb guys are heros for supporting the whole line
>of products all the way back to the beginning, including the models which were
>designed and sold by Homer's company. My understanding is that if you are a
>downstream buyer they merely ask you to sign the same waiver that all the
>other buyers do before they will ship you parts. This strikes me as beyond
>reasonable, into downright nice, given the risks presented. Look at the
>computer software business, no one thinks of calling up microsoft for free
>product support for a pirated copy of windows. The analogy is not perfect,
>but it is not far off either. Kolb would be well within their rights to have
>a separate parts price list for downstream buyers, or to refuse to deal with
Molt Taylor had an idea to get around the liability issue. He said he
should offer a guarantee that the aircraft will kill,injure or cause serious
damage. If something happens he fulfilled his guarantee. If nothing happens
then you just have to wait till it does.If a person does not accept this and
decides to buy another type of aircraft good, the manufacturer does not need
this kind of customer.If you want to fly you have to take the risk.
Woody
I just upload the picture you sent me of your radio stack to my webpage at:
http://members.aol.com/WillU/index2.html
Mike also has a nice place to mount the radio at:
http://members.aol.com/CesarU/KolbFSII/mhradio.jpg
Will Uribe
http://members.aol.com/WillU/index.html
<< I am using a Terra TPX720 handheld and a Terra transponder. I made a
gets out of altitude tolerance, and has to go in the shop. >>
Subject: | Re: Howdy! New guy onboard! |
<< I have been reading the mail with interest and anticipate an informative
and enjoyable time being a member of the Kolb List.
you are a famous guy John Hauck....welcome to our list!......GeoR38
dri
ver of By George! the Firestar KX
from Ohio
Hi,
I bet we could talk Scott Bentley into taking a couple digital photos if
Dennis doesn't mind having them posted for the world to see. Since it
sounds like he's planning to spring this at SNF, I can understand if he
doesn't want them posted. I don't think he'd mind if we sent a few copies
around among the list people though. What do you say Scott and Dennis?
I have some poor pictures of the Laser pieces that were hanging around in
the barn when I was up there last year, but they don't really give a good
view of what the plane really looks like.
Rusty (weather is perfect, plane is broken)
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
Subject: | Re: Laser pictures |
The Laser is shown in flight in the Kolb promo video, for those of us
that have it stuck away and forgotten. Cool little plane!
Ron Carroll
Date: Sunday March 01 1998 7:48 AM
Subject: Kolb-List: Laser pictures
>Hi,
if
it
he
copies
Dennis?
around in
good
Subject: | STOWING IN AN ENCLOSED TRAILER |
I am looking for advise from anyone who has developed an easy method to load
and unload a Firestar or FireFly single handily from an enclosed trailer. I
purchased my FireFly along with a trailer from its original owner, Tom, two
months ago. His methods dont work well for me mostly because of a back
problem I have.
Toms method was to stow the plane facing forward in the trailer. He loaded
and unloaded down the door / ramp with the trailer floor kept level. He had
made up 2 wood handles with 5 inch high hooks at the front which engage the
removable fixture which FireFlys use to support the wings in their folded
position. These handles extend back about 2 feet behind the plane and there
is a lift fixture which transfers a lifting force on the handles to a
lifting force on the tail wheel strut.
Since the floor and ramp meet at an angle to each other the rear of the plane
must be lifted up to one height in order to clear the front edge of the wing
in its folded position.. During a different part of the stow or un-stow
movement a different lift height is required to clear the tips of the 3 blade
prop. (Oh my aching back!) Even after trying extended handles with this
method I find the weight too much for my back..
I am thinking that jacking up the front of the trailer to line up the floor
and ramp in the same plane is the way to go. But I am trying to work through
the devil in the details in my mind. Such as, do I push the plane in with
handles like Toms and rig some sort of latching fixture to keep it from
rolling back out (I can easily manage the force required rolling up this
amount of slope on all 3 wheels) or should I rig a hoist to pull the plane in?
Remember that I am in need of method that can be done by only one person.
Any advice, preferably based on experience, would be very much appreciated.
The more details the better.
Thanks. Chris W.
Subject: | storing in an enclosed trailer |
I have an open trailer but I think the loading and unloading would be the
same. My trailer's inside dimensions are 6 ft x 18ft and the floor
surface at the rear is 19.5 inches above the ground. I use 2 ramps, each
wood 2"x12" and 103" long counting the aluminum ramp end at each end. The
FSll sits in the trailer, nose forward with the wheels flush with the
front end . The wings fit within the trailer and do not overhang at the
rear. The nose of the cage overhangs at the front but the trailer tongue
is long enough ( 52") so that it falls short of my pickup. The fuselage
tube is supported just in front of the tail assembly by a pedestal type
support . It is made of steel and the part that supports the tube is V
shaped about 36" long with rug padding. The metal piece running down from
the middle of this support is 17" long. It is attached to an axle 37"
long With two 10" wheels. This support is very stable and is held in
place with six bungee cords. The plane with this support is rolled
rearward onto the ramps. The 10' support wheels go down first, then I
position the ramps outward to fit the track of the wheels on the
Firestar and then continue to roll the plane off the trailer. The long
ramps and the attachedmobile support prevent the leading edge of the
wings from touching the trailer floor at the rear of the trailer. No
lifting at anytime. I have pop riveted metal shed handles to the 3/4"OD x
.035AL wing tips in order to have something to grip. Loading is just the
reverse. I am sure my method is not unique.. Ray Lujon Woodbury MN
From: | Cliff and Carolyn Stripling <striplic(at)dfw.net> |
Larry and all,
>Once again I bare my throat to the fangs and barbs...
Compared to some other news groups, this is a "love fest". I have been
jumped on once or twice... and sometimes with justification.
>brake drums are very difficult to get true on the wheel..
I think everyone has a problem getting those drums exactly centered. I made
mine work better by loosening the shoe mechanism mounting bolts a little
(seems like that was mentioned as someting to do in the plans if that was a
problem) so that the shoe mechanism is just barely loose and can float
against the fixed drum. They are not very powerful, but they work fairly
well for me. For the price, I am satisfied. It would be nice to have
differential braking. I know some guys have rigged up the cables so that
they can be pulled together or separately. I make it a point to seldom have
to use them which is good training I think. One thing I do just after take
off is to pop the brake lever quickly (heard about doing that from someone
on this list earlier) and briefly to stop the spin of my wheels. They are
not balanced and shake the plane and especially the shock mounted instrument
panel for a few seconds if left to rotate freely.
Later,
___(+^+)___
(_)
8 8
Hi,
I have a enclosed trailer that I built for my plane. I however put it in
the trailer with the tail to the front. I did this to make the tongue weight
on the trailer a little lighter. I pull it with a sub.legacy so I didn't
need a whole bunch of weight on the tongue. It has a drop door in the back.
I also built a device that has a trailer ball on it and adjustments so that
I can hold it at the height that will make the door a level ramp. I put
chocks behind the wheels and prop it up. I too would like some sort of a
jack system to lift the tongue, but haven't done anything like that yet.
I took two by twos and made a vee type trap for the rear wheel, narrowing
it down to about three inches wide at the back part, so that all I have to
do is get the rear wheel into the vee and as I push from the front the plane
rear end aligns its self. I do all my pushing on the wing fastening struts.
It is pretty easy and this puts me in the right place to move the front of
the plane to whichever side it needs to go for the prop to clear the sides.
(two blade 68") I also built a cradle for the boom tube that lays in the
middle of the track that is hinged to the floor. It is activated by a L
shaped square tube so that I can lift the tail wheel off the floor. I then
have a wheel chock bolted to the floor at the right distance for the wheels
to butt against, so that I can use a rachet strap both sides of the legs to
hold it in place.
Larry
Subject: | Re: STOWING IN AN ENCLOSED TRAILER |
I made a caddie out of a kids old wagon that is the same height as the
floor of my enclosed trailer. I roll the Twinstar out on the drop down
tailgate and onto the caddie. I then lower the tailgate to ground level
and roll the plane on out. After the wings are swung out and attached the
load on the tail wheel is less and I lift it off the caddie. The
additional height of the caddie make it easier to put the bolts in the tail
feathers. I just reverse the procedure when I put the bird away. Hope
this helps
Merle from Orlando
Subject: Kolb-List: STOWING IN AN ENCLOSED TRAILER
Date: Sunday, March 01, 1998 1:07 PM
load
I
problem I have.
loaded
had
there
plane
wing
blade
through
with
in?
Thanks. Chris W.
Subject: | TwinStar Update & Need Help |
My partner I put a good day's work repairing the wings after they
were ran into by a go-cart driven his kid. The wings were cradled in
a roll-around rack (see website)in the shop when the driver lost
his brakes as he was coming to a stop at the garage. We had to
build 5 false ribs, repair 3 full ribs (left/right wing inboard
& left outboard)and replace a 1 foot section of the leading edge
tube of the right aileron.
I cannot find in the plans the dimensions for the windshield. Am
I missing something out of my plans? I have no idea of how high
it comes off the pod. Can some one clue me into its
dimensions?
The completion of the T/S is on track to be completed for its
participation at the West Coast Fly-In at Paso Robles, California
on May 1st-3rd. We're down to covering the wings, tailfeathers,
installing the gas tank, and windshield.
Everyone is invited to come out and have fun. The club will be
hostig poker runs, precision landings, flour bomb, and
timed flight contests. (Had ta throw in the plug.. :)
-Mark-
<http://www.tcsn.net/mswihart/kolb.htm>
I load my Firestar forward into an enclosed trailer. To avoid having
to lift the tail, I have a long U section, steel track for the
tailwheel. It holds the tail level with the trailer floor for about 10
feet from the back of the trailer and then lets it ramp down. A 2 foot T
is on each end to keep it from rolling over. No lifting is necessary and
the Firestar is easily pushed up the ramps by one person. For the tail
support in the trailer, I set one wing aside to place or remove a
pedestal type support. If I haven't explained this clearly, I'll try
again and get dimensions.
John Jung
http://www.execpc.com/~jrjung/
From: | "Wayland, William C." <wcw2573(at)eagle.sbeach.navy.mil> |
Subject: | RE: STOWING IN AN ENCLOSED TRAILER |
John, could you provide more details of the geometry of your U section
as viewed from the side? Thanks. Chris W. (by the way MJWAY as my
other e-mail address).
> From: John Jung[SMTP:jrjung(at)execpc.com]
> Sent: Monday, March 02, 1998 6:01 AM
> To: Kolb(at)intrig.com
> Subject: Re: STOWING IN AN ENCLOSED TRAILER
> T
> and
> John Jung
From: | ray abbruzzese <rabbruzz(at)unlinfo.unl.edu> |
>Dear Kolb Builders,
SNIP
> We have decided to produce the Laser, we are now in the midst of producing
>parts for it! We will have partial kits available by Sun-N-Fun. We have
>added another welder to our staff last fall so we could start producing Laser
>parts. We are planning to produce a batch of 10 kits initially and now,
>already, we have 10 complete sets of welded tail surfaces. I have been
>enjoying flying it again, spending time getting reacquainted with her
>characteristics and on optimizing the propeller. We are getting a solid 105
>mph cruise at 75% power with a Rotax 582. The Laser will have folding wings,
>we considered eliminating that feature for simplicity's sake, but in the end
>couldn't bring ourselves to produce an aircraft without folding wings. We are
>very excited about the Laser project - look for it at Sun-F-Fun!
>Sincerely,
>Dennis L. Souder
>President, Kolb Aircraft
Can it be true? I wanted one of those SO BAD! I waited and waited for you to
start selling them! They look so good, they MUST fly like a dream!
My question: have you decided on a price yet? Please don't keep us waiting
for details too long, Dennis. S & F still seems so far away.
See you in the sky !
Ray Abbruzzese E-Mail at: rabbruzz(at)unlinfo.unl.edu
Lincoln, Nebraska, USA
Standard Disclaimer: These are my opinions and you all know
about opinions (they are like butts: everybody has one). I
could be wrong and I probably am. Just please do not sue me.
<< The other thing that drove me nuts about the plane was trying to get the
have been told.
Larry >>
Larry!....I never detected that you were such an interesting writer from the
time we communicated before....Keep it up!....OH! I forgot to say...been
there/done that!...I like your2 holer approach on the gear/one sloppy and 1
fine! GeoR38
From: | Scott Bentley <Scott.Bentley(at)Bentley.Com> |
Kolb group
Subject: | NAV/COM Antennae location |
I purchased the American Aircraft Electronics flexible antennae,
and drive it with my Icom A22. This doesn't require a separate ground
plane, and I've put it inside the nose cone. The advantages are that
nothing is sticking out of the plane.
I think that one of the main applications of this design is
composite aircraft.
See http://www.chiefaircraft.com/aircraft/antennae/aae.html (I
think - their web site is down right now.)
I think I got mine from Chief and was happy with them, but
others offer them at the same price - $128.
It seems to work fairly well, but I'm no expert on this kind of
thing.
Subject: | This year at Sun-n-Fun |
I'm making tentative plans to attend this year, flying commercially and
arriving Wednesday night the 22nd (at the show the morning of the 23rd.)
http://www.eaa.org
Who else is going to be there? I think last year one of the outgoing
types arranged a meeting at the Kolb trailer.
BTW, this is a good place to review trailer technology. While my humble
MKIII won't be there, my trailer made an appearance last year, and may
be this year as well.
Subject: | RE: Laser pictures |
I spoke with one of the factory guys yesterday, and they'll post
some pictures somewhere on the web. The person I spoke to is reluctant
to generate too much demand before they can delivery (which will cause
them to get beat up for slow delivery...), so it probable that they
WON'T be linked to http://www.kolbaircraft.com right away.
Thanks Guys, your responses to my posting looking for a Firestar or
Firefly came through. I found a kit that is 90% complete with a 377
Rotax 0 timed engine. I am going to see the aircraft this weekend and
would like to know what I should look for. So far I have been told that
this is one of the older model 91-92 Firestar I's. It has upgraded
landing gear from an FSII, and larger tundra tires. The owner conveyed
that the airframe has one flaw. The tailwheel asy. was damaged during
trailering. I was told that this would be an easy fix and that Kolb
would be able to supply the parts w/o any trouble.
I would appreciate any help that you could provide.
Cliff/Carolyn and John, thank you for your reply. I will certainly take
your advise. One thing that I would like to clarify is that the
aircraft has no covering on it. I thought that this was a plus since it
would allow for a more involved inspection of the airframe. I also
believe that the airframe has been stored inside during it's entire
life. The brand new engine (377 Rotax) is currently stored in the
owners home.
So far in general, it is my understanding that I should make sure that
the airframe is level, dent free, crack free, no loose parts, and is
rust free. Does anyone have any reservations about the tailwheel asy.
being broken from trailering?
Rut Fuller
rutledge fuller wrote:
snip
> owners home.
The tail wheel assy is easily replaced. Check for damage where the
tail boom tube attaches at the back of the cage. Look very closely in
the area of the aft most rivets.
I would discount the engine from new value, because of the long
storage. It is my understanding that crank seals can still age and are
more likely to take a set in storage than in use.
John Jung
You mentioned earlier that the present owner said there would be no
problem getting the part from Kolb, you might want to verify with Kolb
that it is no problem getting any parts you need. On the tail wheel
assembly I would check the boom tube on both ends to make sure it was
not stressed.
> From: rutledge fuller [SMTP:rut007(at)hotmail.com]
> Sent: Tuesday, March 03, 1998 5:46 AM
> Subject: Kolb Found
> take
> it
> owners home.
> Thanks,
> Rut Fuller
> Get Your Private, Free Email at http://www.hotmail.com
Subject: | Re: Fwd: Re: Kolb Found |
>snip
>> owners home.
that
asy.
>John Jung
Very interesting. Do you recommend having the engine rebuilt?
Regardless, do you recommend any Rotax mechanics in the North Florida
area. I am very mechanically inclined myself, but would like to find
someone that could provide me with hands experience/apprenticeship. Is
their such a thing any more?
Thanks.
What do you say all of the list server participants get together Sunday
afternoon at the Kolb tent at Sun 'n Fun and have it out? I think it would be
great to get all that experience together in one place. What does the group
think?
would be
>think?
Mark whines, "I wish I could show up and meet fellow listers at the tent."
-Mark(SNF participant wannabee)- :)
Paso Robles Ultralight Association
<http://www.tcsn.net/mswihart/prua.htm>
West Coast Fly-In '98
http://www.tcsn.net/mswihart/flyin.htm
(Page will be activated 2-28-98)
Subject: | Instruments/Avionics |
First of all I would like to thank everyone for their help thus far in
my venture to purchase a 90% built Kolb Firestar. Now I would like to
open up a discussion on instruments and avionics. This bird will need
everything. What are your recommendations for instrumentation and
avionics? What do you feel is a must, and what is just nice to have?
Are there any specific brands or models that you have found to be
exceptional, and what should I stay away from?
Thank you in advance,
Rutledge Fuller
Subject: | Re: Instruments/Avionics |
Great question Rutledge Fuller. I am currently planning my panel and am
in need of advice from all you experianced flyers as well. I am
thinking right now to go to the advanced technology stuff like the RMI
encoder.(http://rkymtn.com/rmi.htm) It takes care of all the air data
instrumentation for about $850, which seems like alot but it does
airspeed (calibrated and true), altitude, rate of climb/descent,
barometric pressure and outside air temp. It has settable alarms for min
and max speed and altitude. So if you were going to get fairly high
quality gages for all these functions you would spendmore then $800
anyway and the gages would weigh a ton more and use up all your panel.
I will probably get the garmin GPScom handheld and mount it next to
the throttle. For engine instruments there are several units similar to
the RMI that display and/or have alarms for EGT CHT RPM voltage and
anything else I can think of. I might mount the engine instrumentation
at the leading edge of the wing gap fairing so you would look straight
up to see it. That would be for a system that self monitors and alarms
for values that go out of range. That location would allow much shorter
leads from engine to instrument and make it easier to hear the audible
alarm I think. If I go with regular gages I will put them in the panel
Where it would be easier to keep and eye on them.
I'll need a compass and a turn coordination ball and maybe a CPS
"attitude" (flight level) indicator but I dont know how well they work.
I am going to put an AOA gage out the left side of the cockpit about a
foot from the plane outboard of where the throttle is.
What Else do I need?
Topher
From: | "Anderson, Jim L NWP" <Jim.L.Anderson(at)nwp01.usace.army.mil> |
rutledge fuller
Subject: | RE: Instruments/Avionics |
I think you left out the storm scope. (my favorite instrument
is the florescent pink yaw string attached to my windshield)
[SMTP:tophera(at)centuryinter.net]
Sent: Wednesday, March 04, 1998 4:43 PM
To: rutledge fuller
Cc: kolb(at)intrig.com
Subject: Re: Instruments/Avionics
panel and am
the RMI
air data
does
for min
high
$800
panel.
next to
similar to
and
instrumentation
straight
alarms
shorter
audible
the panel
CPS
they work.
about a
Topher
Wow, and they used to call these ULs simple! It is fine to put
expensive electronics in if that's what rings your bell. I myself
held out in my puritan ways for a long time before getting a GPS,
but then thought it was fantastic once i did get it. Still, you
can get analog instruments. I personally like their traditional
looks, altho admittedly the benefit of threshold alarms on EGT and
maybe CHT would be far superior. As for mount location I doubt you'd
hear an audible alarm unless the engine quits :-/ or if you piped
it in thru your headset. As well, i guess it's obvious, but I'd
recommend avoiding any mount location that might add to wing
fold/unfold time.
Regarding absolute required I'd include, in order of importance:
- dual EGT, dual CHT, tach, ASI, compass or GPS, (don't know
about liquid cooled engines)
Optional:
- altimeter, yaw string, ball/slip, whatever
(BTW, yaw string is so simple and far better than ball/slip)
I personally have all above up to whatever. I believe my cost before
GPS was mid $300. (My altimeter is $10 Grand Auto and very adequate.)
If you have a GPS i think you should have a compass and practice using
it occassionally. Take care to mount any compass far enf away from
steel for it to actually work. I've thrown my original compass overboard
and use a Garmin 38 GPS. For backup I use a handheld backpacking compass.
There are hard-cores out there who think EGT is an extra ...all they
want to see out front is their toes and the wild blue yonder. ...just
pointing out the other extreme. :-)
-Ben Ransom
Not knowing anything about you or the type of flying you will do I will
start simple and work up. To get in the air have an airspeed indicator and a
cht.Thats all you need. Keep your speed up and you live, let your engine get
hot and it dies.That is the minimum.It is also nice to know how your engine
is running so put in a tach also.This will tell a lot about how your engine
is running and if something changes you can often see it first on the
tach.Next you may want to know how high you are. Most of the time you can
just look down and say yep I'm high.Other times you may want to know for
sure so buy an altimeter. If you get one with an extra needle on it you can
almost use it for a vertical speed indicator just so you know if you are
going up or down.While you are fiddlin around puttin in the altimeter tape
a piece of yarn to the middle of your windshield to let you know if you are
going straight through the air.A friend of mine owns SkySports and he once
told me not to waste money on an egt.There are to many variables to reading
an egt.But if you have an extra bit of money throw it in it couldn't
hurt.After this basic set up add whatever you want for the flying you are
doing.The sky's the limit.
Woody
writes:
>... What do you feel is a must, and what is just nice to have?
>Rutledge Fuller
Must Haves:
Air Speed Indicator (ASI).
A "Hall" type (looks like a rain gauge) is very accurate at low speeds.
It can be clamped to the lift strut a few feet outboard of the fuselage.
I'd recommend using one of these at first even if you go with an in-dash
gauge. The problem is the in-dash may not be so accurate below say 40 MPH
while the Hall will be very sensitive (and react very fast) down to 20 or
30 MPH. While you can't really keep your eye on it while in the final
seconds of a landing approach, you can (at altitude) use it to determine
what your true stall speed is. Then, a quick glance at it while crossing
the "fence" is reassuring.
Altimeter.
A "non-sensitive" (single needle) is ok but a sensitive (2 or 3 needle
with a "kollsman" window) is better. Shop around, we have a local
avionics repair shop that will sell used but "out-of certification"
altimeters for a good price ($50-75). They still work perfectly, most
come from pilots who 'trade-up' to IFR panels and need alts. certified to
20 or 30,000 feet.
Exhaust Gas Temperature (EGT) gauge(s).
Dual gauges (one per cylinder) is best. Next best is a "combo" gauge
which has 2 needles and 2 senders. Next best is 2 senders and one gauge
with a switch to read the MAG or PTO cylinder.
Nice To Haves:
Cylinder head temperature (CHT) gauge.
In this case, one is enough (IMHO). Put the sender on the PTO (propeller
end) cylinder as this will (normally) be the hotter of the 2.
Hobbs (hour) meter.
Wire it to come on when the ignition is on. You'll always know how close
you are to "decarboning." You'll also experience a lot of strange noises
and vibrations when you get within 5 or 10 hours of those marks!
Stay Away Froms:
This depends on your personality. Part of the fun (for me anyway) is
flying somewhere I've never been before using only a map and landmarks. I
don't even think a compass is really a necessity but then Oklahoma is
pretty flat and most of the roads run N/S or E/W. If you love gadgets and
have the bucks, go for it. Otherwise, GPS's, Moving Maps and such are
kinda overkill (IMHO). After all, it is an "ultralight."
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
>... That location would allow much
>shorter
>alarm I think.
I think Ben already made the point but I'll second it; I don't think
"audible" alarms would be of any use in even a very quiet UL unless it
was wired to a headset.
Maybe you could forego the headset if you could get some kid to wire up a
mega watt amp and a big woofer like they use in their cars.
("BUMFFFF-BUMFFFF-BUMFFFF-BUMFFFF" ..uh-oh, must be approaching stall!)
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
>writes:
>>Rutledge Fuller
> Must Haves:
It is possible to put the Hall on your panel. On my Hummer, there
was a fairing on the front, very like the Firestar, and I ran a length of 1"
tubing through the fairing, and the panel, and attached the Hall to it on
the panel end. Cut the tubing in a fishmouth, and taped the Hall to it so
that the ram air went into the base intake of the Hall.
Calibrated it by sleeving the next bigger size tubing over the
extended tube that came out the front of the fairing. You can calibrate by
sleeving up/down as necessary. I had the Hall that read to 80 MPH, and it
was quite accurate. It must point straight into the wind while at your
normal inflight angle of attack.
It did look different. People would ask what it was, and I would
tell them it was a 20mm cannon.
Richard Pike
Subject: | Club affiliation in sig line/tag line request..... |
I'm attempting to gather as many E-mail addresses for club
presidents, newsletter writers, or other person in each USUA club
for cross feed of Fly-in info, events, and newsletters. I have all
the Region 5 contacts.....hope to garner a national list.
So, if you would temporarily (or permanently, if you wish) indiacte
your Club affiliation I'll e-mail you seperately for the above info.
Thanks.....
Jim Baker
Pres, USUA Club 104
Frontier Ultralight Aviators
Rut,
I personally consider the EIS to be practically a requirement for this
plane. It's a great instrument and includes practically everything you
could need in one compact package. Mine is currently serving as dual EGT,
dual CHT, Hobbs, tach, fuel gauge, and flight timer. It can also do a few
other things including altimeter and VSI. I chose to use a standard large
ASI and Altimeter just because I wanted to keep the panel similar to other
planes that I might fly. A compass is a legal requirement for me, but I'd
have one anyway.
My plane has a handheld radio mounted on the floor, and a Garmin GPS mounted
the panel. Sorry to offend the minimalists, but I feel the GPS is worth
it's weight in every respect. I can use it to easily and legally fly around
all the special airspace here in Pensacola. If my engine starts to develop
a problem (and I expect the EIS will give me some warning), I can punch 2
buttons and have the nearest airport dialed in. It also provides a crude
backup altitude and airspeed substitute. It's true that you don't HAVE to
have a GPS, but you also don't HAVE to have that computer your typing on, or
your microwave, or TV or.... :-)
Rusty (still no tailwheel) Duffy
<< First of all I would like to thank everyone for their help thus far in
exceptional, and what should I stay away from? >>
I would recommend a EIS (Engine Info System) from Grand Rapids Tech. It
provides everything you want to know about engine operation in a small
package. Total cost for tach, hourmeter, dual egt, dual cht, and two aux.
ports would be around $400.00.
With a single carb you might go to one egt and save a few $$. For an extra
$99.00 you can even get altimeter and rate of climb. It would be difficult to
get all those individual instruments for that money and the EIS unit certainly
saves space. I have one on my 503 and just love it.
Pete Krotje
Woody made an interesting comment about CHT's and EGT's . I understood
that the EGT provided more info about how well an engine was running (
by well, meaning within a reasonable temperature). Also, a tach. Is
necessary for engine break in and performance (maximizing engine load).
My FSII uses only a choke (no primer) so I have my idle set at close to
zero rpm for easier starting (in the air or taxiing I don't like to idle
less than 2500RPM).
One thing that has bugged me is placement of the gas primer bulb. Many
guys in my area place the bulb in a vertical position, that is, entrance
and exit hoses up and down). I think the bulb should be closer to
horizontal to ensure the check valve doesn't get caught in the open (or
closed) position (I should just cut a bulb open to look at how the ball
is configured). {also a must though, is position the bulb where you can
reach it in the cockpit while flying). Your thoughts appreciated.
Jim.
Sent: Wednesday, March 04, 1998 6:28 PM
far in
like to
will need
and
have?
be
do I will
indicator and a
your engine get
your engine
your engine
on the
time you can
know for
it you can
you are
altimeter tape
if you are
and he once
to reading
couldn't
flying you are
Woody
Bravo on your choices and reasons, Mick. I would like to expand on
the altimeter if I may.
An altimeter is especially nice for staying under (or over) Class-C
airspace, over Class-D airspace, and being at the proper altitude when
flying above 3,000' AGL.
Ron
>writes:
>>Rutledge Fuller
> Must Haves:
speeds.
fuselage.
in-dash
MPH
20 or
determine
crossing
>Altimeter.
needle
certified to
>20 or 30,000 feet.
gauge
> Nice To Haves:
(propeller
>Hobbs (hour) meter.
close
noises
> Stay Away Froms:
landmarks. I
and
>-Mick Fine
>Tulsa, Oklahoma
>mefine1(at)juno.com
>Get completely free e-mail from Juno at http://www.juno.com
>Or call Juno at (800) 654-JUNO [654-5866]
Heartily agree. Digital instruments are tops for accuracy as well.
The EIS temperature compensates the EGT and CHT for ambient air temp
where the analog gauges do not.
Jim Baker
Pres, USUA Club 104
Subject: | Instrument/Avionics |
Sorry Gang: Still trying to learn how to use this thing. Much difference
from note pad and pencil. Sent the msg below last night and it came back.
Maybe ya'll will get it this time. Remember the content is Hauck's opinion
only. What I've learned through experience, mistakes, experiments (the
name of the game), and foolishness at times.
john
>Hey Chris:
>Just read your msg ref your idea of instr/avionics for your aircraft. What
>are you building? Sounds like a space shuttle.
>All my little acft: Ultrastar, Firestar, and MK III have very basic,
>straight forward instrumentation. I need the following to be a safe VFR
>local/XC flyer:
>Air speed
>Altimeter
>Mag Compass
>Tach
>Two Stroke: CHT
> EGT
>Four Stroke: Oil Press
> CHT
> WaterTemp
>I want all my gauges positioned so I can see them w/o turning my head,
>Especially the ASI. This is my most important gauge. It keeps me from
>stalling close to the ground when I am busy trying to land. I have made it
>a habit to constantly cross check ASI any time I am maneuvering near mother
>earth. Most accidents that I am aware of in Kolb acft especially, are turn
>stall type close to the ground. Most of these seem to result in serious
>injury and fatalities. No matter how long I fly I can not be sure of my
>speed thru the air, especially when I am dealing with tail and cross winds.
> More than one good aviator has let this one sneak up on him when he is
>flying close to the stall.
>I also need to know how much fuel I have. I usually use sight
>gauges/tubes. I have never had one fail.
>Slip/skid indicator is good to have to keep acft in trim, unless you use a
>yaw string. Don't need a turn coordinator unless I plan on having instr
>qualified acft in IMC conditions.
>The CPS attitude indicator that I have seen advertised is not a gyro. As
>long as you have the acft trimmed up and about 1 g positive, the thing will
>tell you you are straight and level. Even if you are in some unusual
>attitude. Never flown with the expensive CPS toy so I can't say for sure.
>I believe it is only a pendulem (spelling???) type gadget. You could do
>the same thing with a plumb bob hanging from the instr panel.
>I personally have no requirement for AOA, I assume this is angle of attack
>indicator. All three of my Kolbs (Ultrastar, Firestar, and even fat Albert
>the MKIII that weighs 630+ lbs empty, willclimb with full aft stick and
>full throttle. I used to demonstrate that on rides at Lakeland. The acft
>is stalling and climbing at the same time. All of Homer's acft are really
>great performers and hard to get them to fall out ofthe sky if you just
>keep the AS above the stall speed for the given attitude and maneuver you
>are in at the time. Flying right on the stall speed proves one thing. If
>you aren't super careful, you will bust your butt. And even at times when
>you are very experienced and very careful. Keep one eye ball cross
>checking the ASI, give your self 5, 10 or even 15 MPH margin over stall and
>you'll fly a long time and your acft will love you for it.
>Steep (Kolb max performance T/Os) near the ground is an invite for
>disaster. As maneuverable as the Kolbs are, there is a certain amount of
>reaction delay when we get a power failure. You've got to get the nose
>down quick, not just level, if you are close to or in the stall when this
>happens. Save super steep angles of attack for a little higher altitudes
>and you'll have plenty of time to react and get the acft flying.
>What was you last question? Oh yeh, what else can I put on my aircraft?
>Reliability and redundancy. Pitot/static gauges are very reliable,
>especially ASIs. They don't requuire any additional power source. Buy
>rebuilt instruments or find old cores and have them rebuilt. Stay away
>from buying instruments and gauges from UL parts houses unless you have
>much money you don't need. Look in Trade A Plane and other real airplane
>pubs and you will find Instrument Rpr Shops. I've been using Century
>Instrument Repair for years. They have an unconditional guarantee for one
>year on their rebuilds and they come with a yellow tag.
>Better shut her down for now. I've probably said too much already. You
>can take it or leave it. Take what you can use and leave the rest.
>Remember, this is not gospel, only john hauck's own personal opinion, but
>it has worked for me for a long time and I hope for a long time coming.
>john hauck
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
Subject: | Test flight questions |
A little while back someone sent a tidbit of trivia to the list about
someone doing some "inflight destructive testing" of a Kolb something
to the tune of about 9g's positive. I was curious about if this was
reported, was this totally on purpose , is it in any back issues of
flight mags or anything? Who was it that did it? I just wanted to read
about it....
Just wondering.
Jeremy Casey jrcasey(at)mindspring.com
A little while back
someone sent a
tidbit of trivia to the list about someone doing some "inflight
destructive
testing" of a Kolb something to the tune of about 9g's
positive. I was curious about if this was reported, was this
totally on
purpose , is it in any back issues of flight mags or anything? Who
was it
that did it? I just wanted to read about it....
Just
wondering.
Jeremy
Casey
jrcasey(at)mindspring.com<=
/DIV>
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
Subject: | Re: Test flight questions |
I may have mentioned this at one time to a few individuals but not to the
group at large. In earlier times (guessing 1982) Dennis Souder tested an
ultrastar to destruction in flight. A wing drag strut buckled in a wildly
abrupt and full deflection pullout from a sustained high speed dive.
The G meters pegged at 6 (not 9). From that the drag strut was redisgned
to be stronger. At the time they only felt they needed to substantiate
their stated +4G load limits ...i think these were stated as design, not
ultimate load limits, not sure now.
Yes, he used a recovery chute. I've always wondered if he carried a
backup to that, and assumed he did but don't know. Either way, definetly
more balls than I got if you'll pardon the expression. This integrity
to stand behind the design (and really prove it) with his own hide was
part of my reasons in chosing Kolb.
-Ben Ransom
edu>
Hey Gang:
As a result of the tests, the ultrastar and later designs got a chromoly
steel drag strut brace to keep the strut in column.
Dennis was equiped with one Jim Handbury had deployed parachute which saved
his buns. Catch me when I'm in a talkative mood sometime, someplace else,
and I'll tell you how much life insurance you can get from a $500 Handbury
Prcht, or for that matter, any other prcht system.
john hauck
kolb(at)intrig.com
ce.army.mil>
Hi Jim:
Hauck's opinion for what it's worth:
Primer bulb: In and out check valves (all the primers I have used) are
spring loaded. They don't care which way they fly. My experience has
shown that primer bulbs are a good source for eng failures and power loss.
Put your filter in front of the primer bulb. The inlet check valve is
easyto block partially or fully. Don't hesitate to replace. They get pin
hole leaks and cracks in short time.
EGT tells me several things on a 2 stroke:
1. If I have a lean, rich, or correct fuel mixture. (but only if the
engine is propped correctly)
2. Prop Pitch:
Too much: EGT will be low, even if fuel mix is correct.
Too little: EGT will go sky high, even if fuel mixis correct.
If you don't believe me, try this: Fly straight and level, 5800 RPM.
Don't touch the throttle. Pull the nose up and pull off about 10 or 20
MPH. Watch the EGT go down. The eng is being loaded and gets less air.
Fuel mix is richer. Push the nose over and unload the eng. Eng is
breathing more air (same amt of fuel) and the mixture is getting leaner.
EGT Climbs. Push the nose over to land, come back on the throttle, and the
EGT will go out of sight. I usually carry enough throttle to keep the EGT
up or go all the way or just off idle. It is possible to sieze a 2 stroke
in a decent with partial throttle, throttle in mid-range.
Two strokes have many characteristics that 4 strokes to not have. They are
not easy to understand for many of us.
Subject: | FW: Test flight questions |
John, I take it this means you have a parachute on your MKIII.
> -----Original Message-----
> From: john hauck [SMTP:hawk36(at)mindspring.com]
> Sent: Thursday, March 05, 1998 11:55 AM
> To: kolb(at)intrig.com
> Subject: Re: Test flight questions
> about
> something
> was
> Hey Gang:
> chromoly
> saved
> else,
> Handbury
> john hauck
Subject: | prcht vs Life ins. |
A BRS or eqvlt can save "your" life some day. I like to see any life
insurance that can do this and I will mount one my Kolb MKIII tonight and
save 26 lbs in the process.
PS, I just ordered a VLS conversion for my MkIII.
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
Subject: | Re: prcht vs Life ins. |
Hi guys,
What diversity in "required" instrumentation! The electronic
instruments may seem like overkill to some but they are deffinately much
smaller, lighter, and to my way of thinking simpler then the equivilent
mechanical gages. ten million transisters equals one set of springs,
lever arms, sprockets and needles.
A yaw string probably is the best turn coordinator you can get,
especially for the money. The bigest reason to have one isn't just to
make the plane fly coordinated for efficency , but as you approach the
stall aoa in a tight turn staying coordinated is what prevents a spin.
if your yawing the inboard wing stalls first and down you go.
Angle of attack is the key to safe flying IMHO. The stall angle of
attack is constant no matter your aircraft power setting, loading or
attitude. Keeping track of Airspeed works, but stall airspeed changes
with weight, bank angle, power setting. Plus airspeed indicators
generally stink at low airspeed. A simple little aoa gage you can make
for pennys will keep you from unintentionally stalling if you keep your
eye on it.
I'm sounding awful preachy for such a low timer!
Topher
One thing I have not seen yet in the discussion of instruments,
(including yaw strings) is learning to land a MKIII straight ahead. If you
haven't flown one, you are sitting in a wide airplane that has a fast taper
to the nose, you are not seated straight ahead, but at an angle, your feet
pointing toward the middle, and you are on short final with no intuitive
reference of what straight ahead is. Even money you land it partly sideways.
My first flight in the MKIII was at a controlled field, (BIG RUNWAY)
and by the third landing, the controllers were laughing so hard they could
barely talk well enough to make disparaging comments.
We found a string and taped it to the bottom center of the
windshield, and put an end to the jocularity. It is replaced every year with
a new one during the annual. And it's cheap too!
Richard Pike
MKIII N420P (42oldpoops)
Subject: | Re: Instrument/Avionics |
> >john hauck
I found the above comments interesting. I have a Mark III with a 912,
521 lbs. empty. I have never applied full aft stick at full throttle
but have done full power stalls. How do you do this?
Other notes: I have an aircraft type ASI, VSI, & mag compass. I also
have the EIS system since it is the only way to monitor all the engine
functions and still fit it in the panel. I am very pleased with it and
Greg at Grand Rapids Tec was very helpful with any questions. He also
replaced a EGT probe that failed at about 50 hrs. at no charge.
Terry
writes:
>.... ten million transisters equals one set of springs,
"Open the pod bay doors please HAL, .....HAL!!"
Just a thought.... :-)
-Mick Fine
Green Country Ultralight Flyer's Organization (UFO)
Tulsa, Oklahoma
http://angelfire.com/ok/gcufo
mefine1(at)juno.com
writes:
>....An altimeter is especially nice for staying under (or over) Class-C
>Ron
Sometimes living in the "boonies" is a blessing. Most times all I have to
worry about is busting the ARSA around Tulsa Internat'l. (forgive me, I
think it's 'class C' space now but ARSA is easier for me to remember).
The floor is 2400' MSL between the 5 and 10 mile radius of the tower. The
VORTAC antenna is directly east of the tower and right on the 5 mile
radius. Sometimes for fun I'll fly on a north or south flightpath at
2390' (+ or - a few) and (visually) pass the antenna just barely outside
that invisible wall. "Take THAT you bureaucrats!, You passers of laws!,
You pee'ers in punch bowls!!" I say, and then I laugh histerically.
Well, I think its fun even if the guys in the tower have never noticed,
it may be I'm just easily amused. It helps a lot 'tho, especially around
tax-time, which reminds me...
(Please note, the above was written for the purpose of entertainment and
was not meant to berate, ridicule, or irritate any person employed by the
FAA, IRS, FBI, CIA, OMB, State or Local law enforcement agency or meter
reader.)
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
writes:
<< I think you left out the storm scope. (my favorite instrument
HEAR! HEAR!,,,I AGREE WHOLE HEARTEDLY GeoR38 an ol glider pilot!!!
<< Yes, he used a recovery chute. I've always wondered if he carried a
-Ben Ransom >>
one of the main reasons i picked Kolb also!! GeoR38
Subject: | Re: Club affiliation in sig line/tag line request..... |
Sounds good, Jim.
Ralph Burlingame
Original FireStar
Secretary, Minnesota Ultralight Association
writes:
>Thanks.....
>Jim Baker
>Pres, USUA Club 104
Jim,
I also think it is important to put a bypass around the primer bulb so if
the check valves fail, or the bulb clogs up for any reason, the bypass
will allow gas to flow.
I haven't used my choke for years. My primer works great. Give it 3-4
shots before setting up the plane, and the fuel has vaporized enough to
start it on the 1st or 2nd pull of the starter rope.
Ralph Burlingame
Original FireStar
writes:
>Many guys in my area place the bulb in a vertical position, that is,
>entrance and exit hoses up and down). I think the bulb should be closer
to
>(or closed) position (I should just cut a bulb open to look at how the
>ball is configured). {also a must though, is position the bulb where
you
>can reach it in the cockpit while flying). Your thoughts appreciated.
>Jim.
Yes Ben,
I bought my Kolb without even seeing one fly back in '86. From what I
read about Homer Kolb and the performance of his designs, I liked the
plane and it was "love at first flight"! I'm still in love 11 years
later. Gee's, most marriages don't even get this mushy after all these
years.
Ralph Burlingame
Original FireStar
>writes:
>definetly more balls than I got if you'll pardon the expression. This
>integrity to stand behind the design (and really prove it) with his own
hide
>was part of my reasons in chosing Kolb.
> -Ben Ransom >
I have a silly question for you netscape users. How do you put a
clickable link to your webpage in your email messages?
Mike Watson
> Thanks,
> Mike Watson
Mike,
The reason that it is hard to understand, is that it is so easy.
Just type the full address, starting with "http://" and it will
interpret it as an address, and underline it, up to the point that you
leave a space. Here is my example: http://www.execpc.com/~jrjung/
John Jung
>John
>Glade you are on the list , seen your m/3 at osk. in 96 I think it was
>sure looks good
>I need some advice on where did you put your aux fuel tanks , the 10 gal
We built a 25 gal aluminum tank for my MK III. We needed that much fuel
capacity to do my big trip with a 582 that I thought I was going to be
using. However, it is nice to have a large fuel capacity. It allows me to
make to X/C with one less problem, fuel.
We needed cargo space for my gear so the tank went upstairs in the open
area behind my head. This position also allowed me to have a sight gauge
on the left bulk head that is easy to see while flying. Trying to peek
through holes or over or between seats behind you can create difficult
situations, like fuel starvation.
My brother Jim welded up the tank from .052 5052 aluminum. It survived the
terrible crash I experienced during testing and extremely hard landings.
Never had a leak and it is unusual, but ultimate capacity is 25 gal and
useable fuel is also 25 gal. It'll suck every drop oout of that tank. I
don't use primer bulbs in the fuel system. They have caused too many
problems for me in the past. I have a Fawcet electronic fuel pump under
the tank pushing fuel to the engine driven pump. Also had the same set up
on my Firestar, even w/o a battery. Use the elec pump to fill the float
bowl, during t/o and landings, and low level, which is most of the time.
Good thing I didn't have a computer when I was building airplanes or I
would never have gotten them built. The puter is taking most of my time
now days, and nights.
john hauck
To put a link in I just cut and paste, either from an existing link or
from the location window in the browser. Hold the mouse button down on
a link instead of clicking on it and you get a pop up menu that lets you
do things with links like save them, bookmark them or copy them instead
of just the default open them. This is a good one:
http://www.nh.ultranet.com/~alison/index.htm
especially her story of the crash of her Rans S-10.
http://www.nh.ultranet.com/~alison/flying/s10death.htm
and her analysis of the cause of the crash.
http://www.nh.ultranet.com/~alison/flying/aftermath.htm
and her experiance at flying Ultralights for the first time
http://www.nh.ultranet.com/~alison/flying/scary.htm
on the subject of fuel system failures, Ralph how does your primer work?
Is it hooked to the primer bulb or a separate line and pump all
together. It sounds like those bulbs are dangerous enough that I am
trying to figure out how to eliminate it from my system.
A plane will not stall below the stall Angle of Attack, So John Hauck's
planes must be rigged so that full aft stick at the climb out angle,
power setting cg postion and weight he is using does not have enough
athority to achieve stall aoa. Conventional configuration aircraft can
be made just as stall resistant as canards and vice versa, it is just a
matter of limiting control power so you can not achieve stall aoa for a
given configuration and flight condition. The reasons us aero engineers
don't do that are that usually the resulting poor control authority is
unacceptable to pilots, and it generally reduces aircraft performance
significantly, since the wing is never allowed to get quite to max lift,
and full stall landings are not possible. it also only applies to a
small cg and weight range. As John pointed out if you do end up
stalling in a real steep (slow) climbout it will require lots of
altitude to regain enough airspeed (lower aoa enough) to start flying
again. So, with the not as reliable as we would like engines we use,
climb fast and live long.
topher
Subject: | Re: AOA gadgets (was something else) |
> eye on it.
Most would probably say watching an AOA indicator (gauge of some sort)
is a mistake. One should be familiar enf with the feel of the plane
to know automatically the warning signs of an impending stall. That is
why on "real airplanes" they do these as audible horns or stick shakers.
In any case, the plus side of flying Kolbs and many other ULs is that
an impending stall is easy to recognize. I personally wouldn't bother
with any gadgetry on this, or if you did, make it some sort of buzzer
(or electric shock device?) that will interrupt whatever else you might
be doing.
I know that once i got my GPS, I sometimes spent so much time bedazzled
by paging thru the functions that I was destracting myself from flying.
Heaven forbid that someday I'll auger in, but do it exactly on
course! :-)
-Ben Ransom
One other thing, ASI need not stink at low airspeed. In fact, thru many
experiments in static port mount, mine has always been most accurate at
low speed and least accurate at high speed.
Ramble mode off.
From my experience, this is only true when the engine is running and
depending on the pilot, may not be true when the engine is at idle. The
"easy to recognise" power on stall of a Kolb could lead a pilot, who
hasn't practiced engine off stalls, into a real problem. I maintain that
engine off stalls, at least in my Firestar, happen much faster than I
expect and with no warning at all. Power off stalls, also cause a loss
of altitude (easily 50 feet), unlike power on stalls which only reduce
climb rate.
John Jung
I guess I include engine out as a serious indicator of potential for
impending stall. I agree with you that that scenario should be practiced.
...mostly cuz it will impress how careful we better be when it gets
quiet. (Keep thy nose down.) I've taken my plane to the brink
of stall with engine off, but can't recall for sure if I had the nerve
to really stall it. I recall chickening out, thinking like it sure felt
tail-heavy and oh-so-quick to slow down, and I didn't want to go there.
-Ben
From: | "Wood, John T." <woodjt(at)spawar.navy.mil> |
Subject: | RE: Problem with Wing Rib Jig |
Bill,
I am building a FSII. When I started to layout the wing rib fixture,
it was obvious that the dimensions on the "original blue prints" did not
match the blue prints now supplied with the kit. On my set they are
still the only pages that were in the original hand drawn format. You
have to use the measurements stated on the plans and not the plans
themselves. The position of the main spar has to be adjusted to
compensate for the distortion on the blue prints. One of the
considerations in laying out the rib fixture is to check the dimensions
of your pre-welded ribs as they may not match the plans.
> From: William Kautter [SMTP:wkautter(at)gtco.com]
> Sent: Saturday, February 21, 1998 11:59 AM
> To: 'kolb(at)intrig.com'
> Subject: Problem with Wing Rib Jig
> I am in the process of laying out my jig to build the wing ribs and
> have
> run into a problem. I have laid out the jig to the dimensions given in
> the plans and manual. My plans were slightly too long and too tall.
> Also, I made sure that a line draw from the upper and lower surface
> tubes would be flush with the appropriate tangent point on the leading
> and trailing edge spars. However, now according to my jig, the top
> surface pre-bent tubes are too long and the leading edge, trailing
> edge,
> and main spar pre-fabricated flanges are too large.
> Has anyone else run into this problem and if so what did you do about
> it?
> Thanks.
> Best regards,
> Bill Kautter
Subject: | Slip Indicator Question |
I installed a Winter rectangular slip indicator and I am dissapointed
with its very poor response. I knew ahead of time that the pink yaw
string would be much more effective. But this Winter slip indicator is
virtually worthless. My stupid question: Why would my slip indicator
fail to work? Has it something to do with the relatively slow speeds of
our vehicles.?
On another matter this current dicussion of aoa, sensing of an
approaching stall , etc. reminds me of the colorful way this subject is
handled in the book "Stick And Rudder". On page 61 the following is
found: "Because the direction of the air flow differs in various flight
conditions, the pilot can sometimes actually smell the approach of a
stall. At high angle of attack (slow speed, low buoyancy) smells and hot
air from the engine may be wafted up to the pilots head. Or a different
circulation may set up within the cabin so that the pilot smells
gasoline, or bits of dust picked up from the cabin floor." This was
written 54 years ago and is still one possible example of how a "feel
for the plane" is ones best protection against the stall. Can you think
of others from personal experience that are unique with the Kolb?
Ray from Woodbury
Subject: | Re: Slip Indicator Question |
> our vehicles.?
Here is my idea, but I am interested in hearing other ideas. I believe
that the reason that a slip indicator doesn't work well in a Kolb is
because of the limited side area. Mine does work, but I have to take a
carefull look at it to see the change.
John Jung
>our vehicles.?
I assume you mean the standard ball type inclinometer??? I installed one of
these in my SlingShot and it works fine. The only problem is that the pilot
can't seem to keep the ball in the middle as much as he should :-) I
compared it's accuracy to the "yarn" method, and saw no difference. Using
the yarn, I found that it loses all airflow at near stall speed. It just
kinda lays there limp on the canopy, whereas the inclinometer keeps working
fine. I suppose I could put the yarn back on and call it a stall indicator
Rusty (tailwheel on the mend, weather on the decline) Duffy
RUSTY! I think you just found where to put the static port!!
For me, the ball/slip thingy is primarily there to make my "dashboard"
look like a "panel". Really, no kidding. Without it people might ask
why i have such big side panels on my snow mobile. I can feel a slip
or skid weigh before that darn piece of junk does much. The yaw
string on mine is darn good at all speeds.
BTW, many people get a $2 leveler meant for a camper and slap that
baby on their "panel". Works better than my $20 Ball/Slip deal
from LEAF.
-Ben
>> our vehicles.?
>John Jung
Hey Guys:
The way I've been believing all these years is, it doesn't matter how fast
you are flying for a "slip/skid indicator" to work. If it is installed
correctly, when the ball is centered you are trimmed correctly to relative
air. Also helps you make coordinated turns, so you won't be slipping or
skidding the acft. Not only is this for efficiency and making the airplane
look like it is supposed to to the crowd on the ground watching you, but an
out of trim acft probably has a little higher stall speed than one that is
trimmed up the way it is supposed to be. Just hauck's personal opinion
again. I certainly ain't no expert. The slip skid indicator works the
same for all acft, fixed or rotary wing, slow or fast. Has nothing to do
with the shape or size of the acft. Not to be confused with a turn and
bank indicator. To keep the acft trimmed, just step on the ball to center
it. If the ball is on the right of center, right pedal. Yaw string is
opposite. Kolb usually don't put slip/skid indicators in their factory
acft. At S & F and Oshkosh I get me a piece of tape and some yarn (I can
always find some lady in the camping area that is knitting). If the tail
of the string is left, step on the right pedal. Don't quote me guys, I may
be wrong, but thats the way I flies it. If you are making a right turn and
the ball is left of center, you are skidding the acft. Homer's airplanes
are so easy to fly, they don't care if they are in trim or not. We can get
away with a lot of stupid pilot tricks and still survive. But I always
remind myself: They won't fly w/o airspeed. If I keep my a/s above the
stall, no matter what the stall happens to be depending on how hard I am
turning and banking or pulling up, I ain't gonna stall. If I keep my a/s
up I don't have to worry about angle of attack cause I ain't gonna get the
aircraft in that kinda attitude. That's the way my airplanes work. Yours
may be different. That's what is neat about ULs and Experimentals. We can
do it our way, as long as we only hurt ourselves.
PS: The slip/skid indicator should be mounted so that in straight and
level flight the instrument is parallel to the ground. When the instrument
is mounted in the acft, the airframe and instrument should be level in roll
attitude.
john hauck
I feel better knowing that I am not the only one with an inoperative slip
indicator. I agree with you Ben, even though the thing doesn't work, it
does give the " finishing touch" to my panel. I don't have the heart to
pull it out. I paid Sky Sports $35 for mine. Evidently Kolbs have a
relatively coordinated turn built in (what ever that means), at least
coordinated enough to resist being detected by the slip indicator. I wish
the slip indicator did work however, since it is a direct method for
measuring slip or slide. I got very used to using a slip indicator
coodinating my turns during my Cessna training. The yarn method works
well enough but keep in mind it is an indirect measuring device since
what it really measures directly is relative wind. Ray from Woodbury
Subject: | Re: Re[2]: Instruments/Avionics |
On Fri, 06 Mar 98 15:02:18 cst jerryb(at)jmd.ods.com writes:
>Mike,
>What do you do for a living. I just noticed your disclaimer has
>"meter reader"
>listed.
>Jerry Bidle
Oh Jerry,
Its much worse than that I'm afraid! I program computerized metal cutting
(milling) machines that make parts for a little airplane company.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Problem with Wing Rib Jig |
writes:
>...The position of the main spar has to be adjusted to
Believe it or not, even today, many parts of some of the biggest
commercial birds are still made to "Undimensioned Drawings." These are
full size 'layouts' of what the finished part (usually sheet metal) is to
look like. These 'layouts' are drawn or plotted on mylar film which is
very stable compared to paper which grows or shrinks with temperature and
mostly humidity.
I don't know how much trouble or cost it would add but if Kolb's rib
layouts could be plotted on a sheet of mylar, I think it would solve this
problem forever. (...Just a thought, Dennis.)
-Mick (Boeing Commercial Aircraft Group - Tulsa Division) Fine
Tulsa, Oklahoma
mefine1(at)juno.com
writes:
>.... I've taken my plane to the brink
>felt
>there.
>-Ben
This thread is starting to make me appreciate the configuration of the
Flyer all over again. (The thrust line being very close to the vertical
center of drag.) It shows practically no pitch change with throttle
changes. I actually enjoy practicing 'true' dead-sticks and the plane
behaves pretty much the same whether its making noise or not.
You "high thrust line" guys are making me a little nervous about the
Twinstar (still a ways from getting airborne). I'm assuming that its the
thrust line which causes the most notable difference. I think I have a
good idea of what to watch out for when I finally transition and this
stuff helps a bunch!
Ben-
When you do a dead stick, is the prop stopped or wind-milling (or can you
tell)? I believe the drag is less if the prop is stopped and sometimes I
have to slow to the edge of a stall to stop the wind-milling on the
Flyer.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
writes:
>of our vehicles.?
Ray,
I think it has everything to do with our BRAND, but not necessarily TYPE
of vehicle! Being a hard core cheapskate, I bought my "slip indicator"
from the local sailboat store. Its a tiny ball bearing in a curved
plastic tube filled with what looks like antifreeze. Actually they came 2
in a package for 4 or 5 bucks (which gives some idea of the quality) and
I put one on the Flyer. I was disappointed to see that it took real
effort fly so bad as to move the ball off center. Later, I bought a
Challenger 2 and put the other gage on it. Holy Mackerel! It took (takes)
all I've got to keep it centered! ...Oops, I keep forgetting I'm trying
to sell that piece of ..uh, wonderful flying aircraft!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Sort of a joke... |
To all,
...actually smell the approach of a
>stall.
It's a ritual around our house. When I come home from flying my wife smells
my clothes and says "eeew, they stink". I tell her that she is smelling
"fear" and we laugh. Actually it is a various mixture of sweat, gas, oil
and dirt... and maybe a little "fear" thrown in.
Therefore, I suppose when I am flying if I should smell that familiar odor
perhaps I should consider watching my airspeed. I think maybe I will...
Later,
Cliff & Carolyn Stripling Him: Kolb MKIII - N582CC (39.5 hrs)
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
Both: 5th Wheel - RV - Travel
____________________|_____________________
___(+^+)___
(_)
8 8
Subject: | RE: Sort of a joke... |
This is pretty funny. I realized years ago that I CANNOT sneak in a quick
flight without my wife sniffing closely and saying "hey, you've been
flying."
At first I thought it was the "Fragrance of 2-Stroke" but then I noticed
that she could detect it even if I had been up in a Cessna. She claims it
must be a hormonal thing.
Whatever causes it, there really is a grain of truth here...
-Steve
Chris,
The primer is a plunger-pump type bought from Leading Edge Air Foils.
Mine has a small fuel line (1/8" I think) that T's off the main line to
the primer pump, then up to the intake manifold. The instructions said to
drill a small hole in the manifold and put in a fitting for the line.
This pumps fuel directly into the cylinders. A few shots are all that
are necessary. I have the primer installed in the cockpit thinking if I
ever have a fuel pump failure, I might be able to keep it going using the
primer pump.
The primer bulbs are not a problem if you bypass them with fuel line. Of
course you have to kink the bypass line when you squeeze the bulb.
Ralph Burlingame
Original FireStar
>work? Is it hooked to the primer bulb or a separate line and pump all
Ray,
I have practiced stalls many times in my original FireStar. Just prior to
the stall, when the engine is running at about 3000 rpm, you can hear the
impending stall by the "burble" sound coming from the prop. This is the
separated turbulent air from the top of the wing being driven into the
prop. Remember the rectangular wing, that we have, stalls first in the
center right in front of the prop. This makes for a natural stall warning
device and it is really effective. For all you guys who have performed
stalls in your Kolb, you know what I'm talking about. The "burble" sound
is unmistakable and the closer you get to the stall, the louder it gets!
Homer thought of everything, bless his heart.
Ralph Burlingame
Original FireStar
writes:
>aoa, sensing of an approaching stall , etc. reminds me of the colorful
>way this subject is handled in the book "Stick And Rudder". On page 61
>the following is found: "Because the direction of the air flow differs
>in various flight conditions, the pilot can sometimes actually smell
>the approach of a stall. At high angle of attack (slow speed, low
>buoyancy) smells and hot air from the engine may be wafted up to the
>pilots head. Or a different circulation may set up within the cabin so
>that the pilot smells gasoline, or bits of dust picked up from the
>cabin floor." This was written 54 years ago and is still one
>possible example of how a "feel for the plane" is ones best protection
>against the stall. Can you think of others from personal experience
>that are unique with the Kolb? Ray from Woodbury
Subject: | Newbie questions |
Hi everyone,
I have to say that subscribing to this group has been one of the most
helpful moves I've done. I've just been introduced to ultralighting in
the last 6 months and have been spending a lot of my time reading all I
can get on the sport. So basically it's been ground school, a few hours
in a Challenger II (God forbid!)and about 15 minutes in a MK-II. Even to
my uninitiated eyes, there's no comparing the Mark II to the afore
mentionned aircraft.
I am now looking to buy one, so I can train in my airplane. But I get
the feeling though that not many were built as I see a lot of original
Twinstars and a lot of Mark-IIIs but fairly few MK-IIs (around here
anyway!). I just fell in love with the lighter MK-II.
I am trying to find a spec sheet of sorts that would list all the
pertinent info that the factory published at the time and I can't find
anything. It seems so light compared to the MK-III, I'd like to see how
they compare. I would appreciate any help in finding this info. I don't
want to bother the factory, especially in light of the fact that I am
not buying it new, believe me I would if I could.
Another related interest, and I'm sure this subject was beaten to death
in the early age of ultralighting, is the availability (here again) of
Rotax snowmobile engines. I have seen a fine machine (MK-II) that has
about 400 hours on it and around 550 hours on the LC Rotax 537 that
powers it and it has been running flawlessly since new. The owner is the
kind of person who monitors the critical parameters religiously, runs it
fairly conservatively and performs the usual preventive maintenance that
one who holds life dear should. Being new at this, I'm interested in
hearing what you experienced pilots have to say about this. Mick !!!
Being so longwinded, it's lucky that I don't pop in too often !!!
Any comments (and maybe also a bit of history on the MK-II) will be much
appreciated,
Guy
Ray from Woodbury, I believe you are absolutely right, the yaw string
measures relative wind, and if you keep that sucker lined up parallel with
the airframe as you flies through the air, you are going to be trimmed up.
And you can't get any better trimmed up with any other instrument unless
your airplane is a tetrahedrone ?? like the Gooney Bird (c-47) at White
Horse, Yukon Territory, Airport. Kolbs aren't rudder airplanes like, say a
Kit Fox. My old Ultrastar could be flown w/feet off the pedals and do
pretty good turns, but the prop blast was under the tail section. My
Firestar and MK III don't like me to take my feet off of their rudder
pedals and they'll start a slow shuffle that could progress into a very
quickly accelerated flutter if ignored long enough. I think that is
because of the location of the prop above the tail boom and the prop blast
over the tail section. Hasn't been any problem and I have a combined total
hours on the two birds of 1860. The factory MK III, I affectionately call
"Fat Albert", doesn't have that rudder characteristic that my MK III has.
Maybe the location of the rudder hinge in relation to the rudder post and
the rudder. I don't know and it doesn't matter anyway. Yaw string is how
I determine if I have installed my slip/skid indicator correctly. I always
go w/the yaw string and adjust the instrument from it.
john hauck
Subject: | Stowing Ideas - thanks |
Just want to say thanks to all who replied to my request for info /advice on
getting my FireFly in and out of its enclosed trailer. Will head out early
tomorrow to the FF / trailer, take a few measurements and start thinking over
the many good ideas I was given. My special thanks to John Jung for the photo
he sent of his "U" channel tail wheel ramp. Thanks once again to all.
Chris W.
Subject: | Re: Newbie questions |
>... I'm interested in
Guy,
SHHH! Please don't use my name in the same post with the words:
experienced,
snowmobile,
or (especially) longwinded! ;-)
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Sort of a joke... |
writes:
>smells
>smelling
>"fear" and we laugh. ...
I come home and my wife says, "eeew, your clothes stink!" So, I take them
off. Then she says, "eeew, it wasn't your clothes!" So, I go back to the
hangar for the night. The next day I come home and she says, "Well,
thanks alot, I had to tell the girls at work that it was just Bill
Clinton flying naked over the highway again."
Sorry, I thought this was a contest.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
(/\##/\ Smail3.1.30.16 #30.237) with smtp for
rayul(at)juno.com (Raymond L Lujon), kolb(at)intrig.com
Now I know why you can't come to the airport often. The smell of your
clothes gives you away. Can't even make up a story, it gives you away.
Too bad.
Jerry
>To all,
>>stall.
>Later,
> ___(+^+)___
> (_)
> 8 8
(Netscape Mail Server v1.1) with SMTP id AAA150
Hello all..Recently I found a 90 Firestar in Ohio, that I feel I feel
is Cherry enough to bring back to N.J. There are a few options
available to me as far as transporting her. #1 A closed 24 ft. rental
truck. ($602.00 1 way) #2 A flatbed car transporter. ( Loaner ) #3 A
modified ezLoader ( I have to do yet)
boat trailer. Any thoughts on this from you more experienced Kolb
types? Are there any points on the airframe that should be supported
more so than others? Naturally it will be folded for the ride but There
seems to be a wealth of info and opinions here so I thought I would ask
to ensure a safe transport home. Thanks Larry Moore
LLMoore(at)tapnet.net
found a 90
Firestar in Ohio, that I feel I feel is Cherry enough to bring back to
N.J. There are a few options available to me as far as
transporting her.
#1 A closed 24 ft. rental truck. ($602.00 1 way) #2 A
flatbed car
transporter. ( Loaner ) #3 A modified ezLoader ( I have to do
yet)
this from
you more experienced Kolb types? Are there any points on the
airframe that
should be supported more so than others? Naturally it will be
folded for
the ride but There seems to be a wealth of info and opinions here so I
thought I
would ask to ensure a safe transport home. Thanks Larry
Moore
From: | Cliff and Carolyn Stripling <striplic(at)dfw.net> |
Guy and all,
...It seems so light compared to the MK-III, I'd like to see how
>they compare.
My comparison was the MKII with a 503 w/2bld IVO vs. a MKIII with a 582
w/3bld IVO. I flew the II dual and have only flown the III solo (except
with some weight in the passenger seat so far). The II does feel lighter
(and is of course) and performs pretty much the same (II better glide,
little lower stall and seems like equal climb) as the III in my opinion.
The cockpit of the III seems roomier (I think it is a little wider and maybe
taller) and you are sitting up more. In the II I felt like my behind was
down in a bucket. The III is easier to get in and out of. I think the gear
legs on the III are a little shorter and beefier. I like the door and fuel
tank arrangement better too... otherwise I think they are very much alike.
Later,
___(+^+)___
(_)
8 8
Subject: | open looped rudder control |
John,
I've always had a yaw string on my plane from day one. It is a very
effective, so much that when I started flying my feet remained on the
floor and off of the rudder pedals. The differential aileron throw will
produce a fairly coordinated turn. I once flew over a smoke stack that
produced quite a bit of thermal energy. I was flying with my feet off the
pedals and when I hit that man-made thermal energy, the plane began a
slow oscillation about the yaw axis at about 1 Hz. (one complete cycle
per sec). I could hear the cables slapping in the fuselage tube as the
tail was swaying about. I immediately put my feet on the pedals and tried
stopping it, but it didn't help. I then backed off the power and pulled
up close to stall (I was about 2000 feet agl). The oscillation stopped,
but it could have been disastrous. I never flew again with my feet off
the rudder pedals. What had happened was, that thermal activity had
induced enough energy into an open-looped control and caused the plane to
break into the oscillation. Once the wings begin swaying back and forth
in the yaw axis, that kind of action could eventually damage the cage.
Most of the time you can fly with rudder input, but here is a special
case where it proved otherwise.
Ralph Burlingame
Original FireStar
writes:
>say a Kit Fox. My old Ultrastar could be flown w/feet off the pedals
and do
>very quickly accelerated flutter if ignored long enough. I think that
is
>blast over the tail section. Hasn't been any problem and I have a
combined
>total hours on the two birds of 1860. The factory MK III, I
affectionately
>call "Fat Albert", doesn't have that rudder characteristic that my MK
III
>has. Maybe the location of the rudder hinge in relation to the rudder
post
>and the rudder. I don't know and it doesn't matter anyway. Yaw string
is
>how I determine if I have installed my slip/skid indicator correctly. I
>always go w/the yaw string and adjust the instrument from it.
>john hauck
>mostly humidity.
On the blueprint question I can shed a little expertise. I am a draftsman
by trade (Structural steel) and have fought the paper battle for about 3
years. ANY paper will grow in high humidity. You are right about mylar but
you have to have special plotters (or at least inks) to stick to the stuff,
or first time you take the plot down to the damp basement or wherever and
move your hand across it you will wipe all of the ink off!!! Ink does not
soak in to mylar like it does paper, and about the price, it is EXPENSIVE!!!
Sorry but in my experience there is no better way than to buy a $5 compass
and ruler and draw the thing out on your worktable by the dimensions on the
old fashioned blueprint (draw NOT TRACE!).
Jeremy (Draftsman @ Rodgers Metalcraft Inc.) Casey
Subject: | Re: MKII vs MKIII |
>Guy and all,
>>they compare.
>Later,
Hauck's comparison:
MK III is tremendously stronger than the MK II.
6" wing spars vs 5"
6" tail boom vs 5"
10 wing ribs vs 7 (I think CRS)
Airframe much beefier, stronger and stiffer.
Much larger cockpit area.
I'd alwaysgo with a III over the II unless someone gave me a II.
"I love Homer's airplanes."
john hauck
Subject: | cross country that bird! |
Hay what about option 4 fly it cross country from ohio to NJ, sounds
like an adventure to me!
Thanks ralph, sounds like a good system although I am not sure I am
going to like drilling into my manifold. If I have two carbs then I
supose you need to send two lines from the plunger to each minimanifold?
Could you just pump it into the carb somewhere?
Christopher
From: | george_eagle(at)webtv.net (George Thompson) |
Ralph. All the later 503's have a fitting already on the carb to
accept the primer hose. It is covered with a little rubber cap.
Firestar I and II. George
writes:
>feel
Larry,
Having recently brought a Twinstar back to Tulsa from Albuquerque on an
open trailer, I'd say spend the money and rent the "box-truck."
I agonized over the same things you mention and finally got the seller to
agree to loan me his trailer (he wouldn't sell it to me) for the trip. He
was going to be in Tulsa a couple months later so I wouldn't even have to
make another trip to return it. Sounds perfect, right?
Leaving Albu, I probably averaged 30 mph for the first 200 miles due to
strong crosswinds (30, gusting to 40) and having to stop every 10 miles
or so to re-tie things. By the time I got to Tucumcari it was getting
dark and I was a nervous wreck so I stopped for the night. The next
morning I left at sunrise and the wind was nearly calm. About a hundred
miles down the road, the wind started howling again. It got so bad that I
left the plane in Amarillo with a friend's father and came on home (~350
miles) - had to get to work the next day. I waited for 2 weeks for the
wind to die enough that I could go retrieve the plane. I made it back
with the plane in one piece but it did suffer some minor damage on the
elevator trailing edge from rubbing against something.
The quote I got for a 24' "box-truck" was $425. Funny how reasonable that
price seems now! I don't want to think about what it cost me in time,
trouble and wear and tear on the Blazer (not to mention my nerves) by
going the cheapskate way. The old saying, "Its the stingey man who pays
the most" seems to apply.
If you can leave the plane where it is for awhile, shop around for a
better rate on the rental truck. Most people move on the first of the
month so you can often get a better price in the middle of the month when
demand is less. You'll need to build some sort of pedestal for the
tailboom to rest on, don't let the plane rest on the tailwheel while in
transit.
Good Luck!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Yeah, but thrust line is a minor no-brainer when the 447 is between
idle and max power, and power is the fun part. :-) The extra light
elevator and ease of slow down at engine off is just something to be
aware of. It really doesn't make dead sticks scary; ya just need a
touch of forward pressure on the stick until flare.
>Ben-
>Flyer.
Mine is stopped and it won't kick around even if i go fast --- don't recall
trying to bump start at or near Vne though so don't know about that. (Warp
high aspect prop here). I need to go flying again to find out!!
The bit about less drag with stopped prop is uncertain. Some argue that
the idling prop is more disk area, therefore more drag, than a stopped
prop. A stopped prop on my FS feels like more drag, but maybe that is
just cuz of the high thrust line disappearing.
-Ben
Subject: | Re: open looped rudder control |
I've flown for long stretches with my feet pulled up near the
seat. Nothing happens, or maybe i'm not very discerning. :-)
It's a nice way to re-arrange my bod' on long XC stretches.
Even in very mild bumps things seem to dampen out to smooth
sailing and I've not felt any need to jump back to the pedals.
As far as turns w/o rudder however, mine feels a noticable slip
inside. In fact, for coordinated turns I like to even think slightly
lead w/ rudder, add aileron. I've posted before the suggestion to
try rudder-only input and see what happens. The plane yaws, banks,
and noses up, all the desired things for the turn -- except for
added power -- but not in the exact best proportions. Don't get
me wrong, i'm not suggesting doing turns w/ rudder only, and I know
you others weren't suggesting doing aileron only turns either. Fun
to blather when you can't get away to get smelly. :-)
-Ben Ransom
<< Its much worse than that I'm afraid! I program computerized metal cutting
I'll be dad blamed....I program an Okuma....ever hear of it ? GeoR38
Subject: | Re: cross country that bird! |
<< To: LLMoore(at)tapnet.net (Lauren L. Moore)
CC: kolb(at)intrig.com
like an adventure to me! >>
I would seriously consider it....only cause I actually got away with that last
summer in an N3-PUP, 100 miles from Barnsville O (near W.Va border) to
Bristolville O.....learned how to use my GPS as well....marked every airport
on the GPS all the way down there and had a van (mine) follow me....one of the
best thrills of my life...and ....fortunately the pup flew like a dream....it
had other unnerving problems though...too embarrassing to say on this
tube.....but it is dangerous to fly an untested (by yourself) airplane for
tirst time. Firsts are always dangerous!! GeoR38
The difference between the two products is an interesting way to look at
the evolution of the company. I have buillt both. The principal problem with
the mark 2 was cabin width. It is about 9" narrower than the 3. Plus the
edge of the cabin area goes up at an angle that brings the tube right by your
shoulder. It looks great when you are standing outside, but it makes it more
difficult to get in. You have to put your butt on the edge and sort of slide
over. Hard for fatties and women in skirts. The lowered cabin sides of the
the three are a great improvement not only for entry/exit but for visibility
and the feeling of not being crammed into the plane.
The gross weight on the 2 was 750. I brought mine in around 375, so with
me and my dad (both over 6 feet) and full fuel we were tightly packed and
right at the edge of the envelope. I flew the plane in that condition most of
the time and it got off and climbed great with the dual ign. 503. A really
great combination of airframe and engine, with low vibration. I would
occasionally fly it with 1/4 fuel by myself just to impress the onlookers and
the performance was spectacular. My nutty brother used to do two turn spins
from 1300 ft. (yes, there were calls from the local folk thinking some one
crashed, and he stopped). We stood it still in a stiff breeze over the FBO to
the amazement of the gawkers. The 100 lbs that the average 2 weighs less
than the 3 make a big difference.
The two has full span ailerons. Super for turbulence. Great control
authority for such a light plane. The alieron linkage is more complicated
than on the three. It had no need for flaps. I don't think the three really
does either, but I think folks just feel better when they have all of the
attributes of a GA plane.
The two is not as mature a design as the three, but it was a knockout
market entry for its day. Its folding design was amazing, but the look and
construction was sufficiently like a Piper Cub that you didn't think you were
taking your life in your hands. In 1987 everything else in its class looked
flimsy. And when Rotax came out with dual ignition a general aviation guy
like my dad was sold.
When you compare them both side by side you can see how Dennis and the boys
were not only responding to what the market wanted, but working out the
implications of their own philosophical view of what a good aircraft in that
class ought to look like. Case in point is the center stick. Most folks were
wary of it to start, but then loved it once they started flying the plane.
I'm sure most new buyers will go for the dual stick option and pay the extra
bucks, because it fits their preconceived notion of what a control system
should look like. But the center stick is a perfect expression of Dennis'
clever engineering driven by a desire to keep things light and do the job
well. It is a very elegant solution to a tough problem. And no one is going
to tear their shorts when they get out of a center stick plane. Its hard
enough to get in and out of any airplane gracefully, but to have to heave your
inboard leg over the stick and then try to get out without scratching the
bottom of you leg or catching your clothes . . .
Who knows, if my dad hadn't found out about McDonalds two big macs for the
price of one deal I'd probably still be flying the two.
with
I forgot about the flaps, CRS again or still, on the III. The Flaps are a
plus for several reasons:
-Gives unexcelled rate of decent w/o unnecessary speed. Ability to get
into a very tight area when you have no other choice, i.e. eng out. Pull
the flap handle all the way and push the nose over. Thefirst time this is
demo'd to you you will swear you are going to auger in. My 1st MK III flt
Dennis came over the trees and landed by the hanger at Homer's. I knew we
were gonna die. Now after several hours in the III it is a normal
sensation to drop out of the sky. The only other kolb design that willdo
that is the Sling Shot. I love them all.
-Soft field, high grass, rough field: Full throttle w/ flaps up, at 30 to
35 MPH pop the flap handle all the way down (I mean snatch it down) and the
MK III will spring into the air. Same for the Sling Shot. The more you
practice this the better you timing and coordination w/the correct air
speed get. Same is true for any flt maneuver that is not what you normally
do on a Sunday afternoon flt. Practice those maneuvers that you probably
won't need until there is an emergency situation. Get good at them and
when the time comes (and you'll never expect it), you'll react w/o sitting
there like a dummy trying to figurre out what to do. I learned this in
Army Rotary Wing Training. We were constantly practicing those things that
would save our acft and our buns. It pays off.
Just a note from a post I read earlier: For me glide ratio really
increases when the blade is stopped. At idle you, for all practical
purposes have a disc the diameter of which is the length of your prop.
Find a good large field and do a lot of eng off, dead stick landings. You
will be surprised how the acft floats and glides w/dead stick. Learn this
cause if you get (or when you get an eng out) you'll know how to compensate
for the increased performance. May keep your acft from getting bent. Same
for stalls of all types: pwr on, pwr off, accelerated, as in turn to final
stalls (but do all this with plenty altitude (several thousand feet).
Homer's airplanes will recover very rapidly from any unusual attitude, but
it takes altitude, more than you will expect. Be safe but learn,
experiment and practice.
I've never been able to get a prop to wind mill on any kolb airplane. In
my younger, much much dumber days, I did eng off loops w/my Firestar. Push
the nose over straight down. At 90 MPH indicated, pull up and over
(barely) the top. Even at 90 the prop would not windmill. Got something
to do with running a gear box. If you want to break your airplane and die,
try the above eng off loop. Don't try this at home. I emphasize: I have
not done an aerobatic maneuver in one of Homer's airplanes since 11 March
1990. They were not designed for aerobatics. They might just wear out and
break if you do enough of them. I still have fun flying them and they will
do great wing overs, stalls, spins, pull ups, and all the things that we
like to do to feel the freedom of this wonderful sport that we enjoy,
momentarily beating gravity.
My, I have rambled on. I'msorry. I won't ever do it again.
john hauck
>GeoR38
G90G94G17
'Course I have! Good solid machine. I believe Mark Swihart is also in NC,
but I think he sells 'em. Us tape punchers gotta stick together!
M30
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
The newer Bing carbs have a primer fitting already installed. The
drill-and-tap fitting is for older carbs.
My 503 is about 8 years old, and was originally a single-carb. 3 years
ago, I upgraded it to dual-carb. So I have one carb with the fitting and
one without! I drilled the manifold and installed the fitting for the old
carb, then T-ed the primer lines and ran one to each.
BUT... the fitting for the old carb is simply a hose-barb fitting on one
end, threaded on the other. It's wide open, so fuel simply pours into the
carb when I hit the primer. The fitting that comes in the new carb is
actually a small nozzle. It delivers a fine spray of fuel into the carb.
Even worse, the nozzle fitting offers a fair amount of back pressure
(since it's a small orifice) while the threaded fitting on the old carb
offers none. Since the lines are T-ed together, the old carb gets lots of
fuel and the new carb gets almost none.
That fitting they send you for the old carb is really dumb - it should be a
nozzle of some type.
-Steve
Subject: | Re[2]: Re: AOA gadgets Rep: Stalls |
I guess stall training and recognition is a benefit of training in GA
aircraft. Everyone should put their plane though a series of stalls
to learn to recognize the warnings they give as you approach the
actual stall itself. This should be part of the flight test process.
Do it at a safe attitude preferably over a suitable landing area in
case the engine quits. Practice power off (engine at idle), full
power, and departure stall. (Sorry guy I don't support the mohco
engine off stuff.) A good training exercise for landings is at
attitude make like your landing, keep it in the proper landing
attitude (nose up/down position) while letting is slow down. Hold it
in that position. As it slows you will normally have to keep coming
back on the stick until it stalls, then perform a normal recovery and
do it again. (Tip: Keep the wings level with rudder, lifting a wing
the handling characteristics and what to expect when operating at
landing speeds. Another little exercise is flying at low speed, just
above stall again preps you for handling characteristics.
You usually find a airplane will have repeatable characteristics.
Even the planes of the same model may be different. Some times you'll
find one wing may have a tendency to drop first. I got a real
surprise one time while taking a biannual flight check in a rented
Cessna 150. While doing a stall, the wing suddenly dropped like a
brick, I mean I never experienced anything like that ever before. I
caught it but it surprised me. I flown some 150's but never
experienced anything like that before or after. There had to be
something wrong with that airplane, stall strips on the wings in wrong
position or missing. The instructor (an older guy) thought it was
funny, a good trainer and test of your ability. He was satisfied, I
wasn't (with the airplane).
______________________________ Reply Separator
Subject: Re: AOA gadgets (was something else)
Author: jrjung(at)execpc.com at MAILGATE
Date: 3/6/98 12:28 PM
that > an impending stall is easy to recognize.
The "easy to recognise" power on stall of a Kolb could lead a pilot,
who hasn't practiced engine off stalls, into a real problem. I
maintain that engine off stalls, at least in my Firestar, happen much
faster than I expect and with no warning at all. Power off stalls,
also cause a loss of altitude (easily 50 feet), unlike power on stalls
which only reduce climb rate.
John Jung
writes:
> --- don't recall trying to bump start at or near Vne though so don't
know about that.
>(Warp
>that
Thanx Ben,
I should have made it clear (to everyone) that the Flyer is direct drive.
As I said, I'm in the camp that believes a stopped prop is less drag
although its hard for me to prove. A spinning vs. stopped prop is
probably only a small difference in frontal area on a plane (mine, not
yours) that is already quite draggy.
My props will spin slowly after killing the ignition without 'diving' but
once they do stop, you can't get 'em going again without using the rope!
While doing the maneuvers I described before, I usually come in
(dead-stick) pretty high and then slip, S-turn, or whatever to get it
down. I can hear the wind howling thru the struts sometimes but neither
prop ever makes another revolution once they have stopped.
Asking whether your prop (with a gear drive) was stopped or not seems a
little foolish now. Some older Quicks, Vectors, Wizards and other
belt-drive designs had a clutch which allowed the prop to free-wheel when
the engine got quiet. I guess I forgot what list I was on!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
I hear you Jerry, but what I really want to know , did you smell
anything? Ray from Woodbury
Chris,
Yes you will need two lines for a dual carb. There is a plug on the back
of each carb that can be removed to plug in the primer line. I didn't
know this at the time I installed my primer line and drilled a hole in
Ralph
writes:
>minimanifold?
>Christopher
>-Steve
> Go to the hobby shop, buy several sizes of telescoping brass tubing,
modify the big one smaller by soldering the tubing into the fitting. To make
a tiny orifice for the fuel, insert a single strand of fine wire into the
thing before you solder it. Just before the solder sets as it cools, pull
the wire out. Saves you having to fool with sub-miniature drills.
Or you could just drill the nozzle fitting out, and just DUMP THE
FUEL IN BOTH!
Crude solution, but it does get rid of back pressure...
Richard Pike
>Date: Sat, 07 Mar 1998 23:46:26 -0500
>To: john hauck
>From: Richard Pike <rpike(at)preferred.com>
>Subject: Re: MKII vs MKIII
>>john hauck
> Don't quit. You have worthwhile things to say, and it takes the
heat off us other ol' windbags.
> Richard Pike
<< My, I have rambled on. I'msorry. I won't ever do it again.
john hauck >>
Please do it again!....good input John!............................GeoR38
Hi Kolbers,
Well I guess yesterday was the last time for winter flying as I had to
throw snow in front of my hanger,s doors to get my plane out. The snow is
melting like crasy.
Since it will be a little while before we fly again it is time to look the
plane over. I will like to know if somebody came up with a good way to
drain the gas out of the tanks without taking the tanks out of the plane,
(like when you have been a while without flying and you want to get rid of
the old gas)
I feed my gas to the carbs from the tops but the 2 tanks are connected on
the bottom by a hose.
Any suggestions?
Lucien
Lucien,
My fuel line on the bottom of the tank is connected to a plastic "T"
where the primer pump is tapped from. I use two surgical clamps (it looks
like a pair of scissors that has long needle-nose type ends - forgot the
name for them) that I can clamp and hold on both sides of the "T". I
then remove the "T" clamp on the fuel line, take off the surgical clamp
on the tank side, then drain the tank. You could cut the fuel line if you
don't have a connector installed (after clamping both sides with the
surgical clamps where you plan on cutting) then drain and add a 1/4"
straight plastic connector later.
Ralph Burlingame
Original FireStar
writes:
>Hi Kolbers,
>to throw snow in front of my hanger,s doors to get my plane out. The
snow
>is melting like crasy. Since it will be a little while before we fly
again it is time >to look the plane over. I will like to know if somebody
came up with a good way >to drain the gas out of the tanks without taking
>plane, (like when you have been a while without flying and you want to
get
>rid of the old gas) I feed my gas to the carbs from the tops but the 2
tanks are
>connected on the bottom by a hose.
> Any suggestions?
> Lucien
>-Steve
Hey Steve: Hang around a while and that's not the only thing from ROTAX
that could be classified as dumb.
jrh
In a message dated 3/8/98 2:07:48 PM, you wrote:
I have a gasolator installed in my firestar 2 so I can drain the tanks easily
as well as before each flight as part of the pre flight.
tim
>>john hauck
> Don't quit. You have worthwhile things to say, and it takes the heat
> Richard Pike
>OK, I'll do it some more, when I'm in the mood.
jrh
Subject: | Re: Rudder Flutter |
vertical fin/rudder, gradually increasing in amplitude and violence. I added
>a mass balance to the rudder similar to what the Firestars use, and that
>cured it.
> Besides, I needed a little extra weight at the tail anyway.
> Richard Pike
Tell me about your rudder balance. I don't have a nav lgt on the rudder
nor did my Firestar or Ultrastar, but the FS and MK III both have it
(occilation).
jrh
by InfoAve.Net (PMDF V5.1-10 #23426)
Hi, My name is Michael. I am in south Georgia. Currently taking lessons
in UL. I am looking at an older Kolb. It has twin 16hp Solo engines with
3-Blade IVO props. What can anyone tell me about this model.?? Would
this be a good choice for a first UL.??
How much would you think it would be worth if seller(who is BFI) brings
everything up to standard, including new paint, spare 18hp Solo engines,
lessons......??
thanks, Hoody
Jerry, if you are serious, I think you are on to something. I always
assumed the center of gravity would be the pivot point for any airplane
in all three of its axis, pitch, yaw and roll. Why I assumed that , I
don't know. Maybe the pivot point for roll and pitch shares the center of
gravity and the pivot point for yaw is determined by the length of the
fuselage and the area of the rudder. Are you saying that the pivot point
in a Kolb is in the nose section? If so, how do you know that. If this is
true, having the slip indicator mounted at or near the yaw pivot point
might have the effect of limiting or completely nullifying the slip
indicator. Ray from Woodbury
> john hauck >>
I was only kidding. I'll be glad to share when I can. Just remember it is
only my own humble opinion as the result of many mistakes, torn fabric,
bent tubes and ego. But I have had a good time doing it. I can't give you
fancy answers why some things work and some things do not, all I know is
that what I do works best for me. That is why I build airplanes, fly, and
live the way I do. If it hadn't been for Homer Kolb I'd still be growing
squash and okra in my vegetable garden that died in 1983, and was never
resurrected (started building Ultrastar in 84). Been hooked real bad on
these ULs ever since, as long as their last name started with Kolb. Only
other brand of UL I have flown except Homer's is Bert Howland's personal
Honey Bee summer of 89. I spent a week at Bert's home in Maryland, NY, on
my way to OshKosh 89, in my Firestar. One of the best flying weeks in my
life. I really miss my buddy, Bert.
johnhauck
writes:
>lessons
>with
>brings
>engines,
>lessons......??
>thanks, Hoody
Hoody,
Must be a Flyer. Excellent aircraft! (But I may be a little biased.) How
many hours are on it or more important, what condition is it in? New
paint will add no strength to old fabric. You can 'punch test' the fabric
(borrow a tester from an A&P mechanic). As with any Kolb aircraft,
condition is everything (the design itself is fine). I've had mine since
'91 and won't part with it. If you're really serious about it, I'll let
you know what you're in for as far as engine maintenance, that's the next
biggest consideration after its general condition.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Instruments/Avionics |
> -Mick Fine
O1( PGMID 176D37A.NC
N2G90G80G70G40G17G0
N4M6T1(3" FACEMILL
N6S265M3
N8G0G90X-3.6988Y-0.0375E1
N10H1D1Z1.M8
N12G0Z0.25
N14G1Z0.02F3.5
N16X3.6989
N18G0Z1.
N20M9M5
N22G0Z0.H0.
N24G0G90X0.Y10.E0
N26M30
Add one more CNC programmer to your list guys. I've been programming for
many years. I started my own CNC programming business in 1989. I've
worked on many exciting projects, one of the most memorable, the F22
Fighter Jet. I was thinking of taking all the F22 parts I've worked on
and scaling it down to make an ultralight, what do you think?---Just
kidding! There are some pictures on my web page if you want to check it
out.
Mike Watson
Programming Solutions, Inc.
http://www.pivot.net/~psi
>lessons......??
>thanks, Hoody
A good example of an old fashioned but excellent ultralight. Never
got to fly one, but have seen them fly and they are agile. Probably a little
buzzier than a single engine, and an extra engine is always something else
to fiddle with, but I bet you could do a lot worse.
It is always a good idea to get a couple friends that are SHARP on
the mechanical stuff to look it over with you, and then discuss it privately
away from the seller and get their opinion of structural/mechanical
integrity. You as the buyer may not be as objective as they would be,
because YOU want it, and they don't, they just don't want you to bust your tail.
One question: how big a 3-blade IVO can a 16 hp Solo turn?
John, I would be interested in why you have been so powerful in your
recommendation of Kolb and how you got to know Homer....also , your vegetable
days sound like a few pages in my life....before Kolb.......one of my
"achievements" was to constuct a successful "Burpee Bean Teepee"....(claim to
fame if you will) before discovering that I could actually realize my
childhood dream of flying....after all, I had mastered the modelling business
as my father owned a model airplane shop. Also....why did you mount your BRS
in the wing root over your head on your great looking Firestar.....what about
if the wing folds over as it probably would in case of structural failure?
GeoR38
<< Been hooked real bad on
johnhauck >>
Oh! I forgot to mention that one of the UL's I was keenly interested in before
I got my Kolb Firestar KX in '91 was the Honey Bee I think it was because it
looked so close to the P-40 with its rudder curvature....that has always been
my favorite fighter and the AVG has always been my real heroes!
GeoR38
>N4M6T1(3" FACEMILL
>N6S265M3 .......
210 surface feet, hmm... Steel?, sounds fast for titanium...
Wow, must be some relationship between obscure technical professions
being attracted to superior aircraft designs!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
<< N4M6T1(3" FACEMILL >>
Thanks Mike ...you just taught this novice that the second parenthesis is not
necessary for a REM......................................GeoR38
>> -Mick Fine
>N2G90G80G70G40G17G0
>N4M6T1(3" FACEMILL
>N6S265M3
>N10H1D1Z1.M8
>N12G0Z0.25
>N14G1Z0.02F3.5
>N16X3.6989
>N18G0Z1.
>N20M9M5
>N22G0Z0.H0.
>N24G0G90X0.Y10.E0
>N26M30
>out.
>Mike Watson
That F22 idea may not be so wild. I am in the process of building an
Avro Arrow.A Canadian Jet fighter from the late 50s.This will conform to the
Canadian Ultralight regulations.Do a web search on it for some good pics.
Woody
Subject: | Req:Ultralight bill of sale |
I remember reading a sample ultralight bill of sale which states that what
is being sold are parts, not an assembled plane, and that the buyer
understands that the seller relinquishes liability for airworthiness, etc.
Have any of you come across such a piece of boilerplate?
Email requested.
Thanks, Bruce Schimmel (bruce(at)schimmel.com)
Subject: | Re: Req:Ultralight bill of sale |
writes:
>what
>etc.
>Email requested.
I've heard of removing the prop and requiring the buyer to sign something
like what you mention. Then, you sell him the prop for a buck or two and
cross your fingers, sacrifice a chicken and say 3 'Hail Mary's.' Then, go
get drunk on the proceeds.
-Mick Fine
Green Country Ultralight Flyer's Organization (UFO)
Tulsa, Oklahoma
http://angelfire.com/ok/gcufo
mefine1(at)juno.com
Have not been on the net lately. Busy working on my
slingshot. Nearing completion, waiting on warp
3-blade tapertip prop-weight&balance-breakin &
inspection.
JR
Busy working on
my
waiting on
warp
3-blade tapertip
inspection.
&nbs=
p;  =
JR
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
I think you can do all sorts of little tricks like that but in the US
legal system I think your still going to be in trouble if the guys widow
takes you to court for that death trap ultralight you sold my husband.
One thing about the gps com combo unit is the user interface. It doesnt
seam as good as the newer units. I wonder when ther are going to update
it. A GPS II with a com would be nice.
Any unconstrained object will rotate about its CG. Doesnt matter what
its shape is. When I have built simulators for various aircraft (f-111,
f-16 f-22, citation X), I have always use the basic six degree of
freedom equations that assume that rotations will take place about the
cg and our match to flight testing is usually accurate enough. I would
be willing to bet that Kolbs rotate about the CG on all axis.
since this is aparently the place for cnc types, can you recommend which
cnc mill is the best overall? And are there affordable CNC mills on the
used market yet? Or can you rent time on them? Or do any of you who
have your oqn business do tiny little one off jobs for prototypes?
Topher
> lessons......??
> thanks, Hoody
Hoody,
My opinion may not be popular with this group, but here it is
anywhay:
While I own two Kolb's and wouldn't mind owning one of each model, I
wouldn't recommend any Kolb for a new pilot with just UL training.
John Jung
> >John Jung
Mark Swihart wrote:
> John,
> Can you please elaborate on this statement, please?
> -Mark-
Sure I will. But first I'll wait until I get the full reaction. Usually
someone else covers some or most of the points that I would, saving me
time, and making a stronger point to boot.
John Jung
From: | "rutledge fuller" <rut007(at)hotmail.com> |
Question: It's hard to tell from the photos, but are Kolb production
wing ribs now welded together? I was looking at an orginal Firestar
this weekend that I am currently planning on buying and noticed that the
ribs built from the factory were rivited together. I am admitting right
now that I don't know jack about building, but was wondering about the
changes/improvements made to this kit in the past 10 years. I seek
everyones observations on this matter. I learn so much from you guys.
Rut Fuller
Subject: | Covering the MKIII |
I am just finishing up covering my last tail / control surface and I
don't think I took any of them beyond 225 degrees because I started to
notice bending in the parts. Did any of you go much beyond the initial
heat setting before you noticed bending?
From: | ray abbruzzese <rabbruzz(at)unlinfo.unl.edu> |
SNIP
>Hoody,
>anywhay:
>John Jung
And I can't believe you would write something like that. What an elite-ist
point of view. As a person who got his Kolb FireStar after ONLY 10 hours of
instruction in a Quicksilver MXL II ("JUST UL TRAINING") and then ONLY 7
solo hours in a Quicksilver MX (two axis controls), I have to strongly
disagree with the above opinion. True, there are some differences from any
other type planes, but that is true for every different type of airplane out
there. If you take your time and do your homework, Kolb's will fit the bill
for any pilot, regardless of the training (UL or GA).
See you in the sky !
Ray Abbruzzese E-Mail at: rabbruzz(at)unlinfo.unl.edu
Lincoln, Nebraska, USA
Standard Disclaimer: These are my opinions and you all know
about opinions (they are like butts: everybody has one). I
could be wrong and I probably am. Just please do not sue me.
I will start it out.The following is from a low timer who flys a
Firestar II solo. I am in no position to agree or disagree with John
Jung. However I will say that since the FSII is a " tail dragger" it
does present a unique challenge on the ground during both take off and
landing that is not found in the tricycle gear.
Briefly stated, on takeoff you must have training, among other things on
the correct way to correct for the tendency of the airplane to pull to
the right. During landing , correct procedure on contact and rollout must
be learned in order to prevent ground looping. Ray from Woodbury
Subject: | Re[2]: Instruments/Avionics |
I've found a number of people in communications networking are also
pilots. What's the relationship
Are they into networking (higher income) as a means to support their
habit or is it because networking tends to be very stressful and
flying is therapeutic. When flying I find I clear my mind of other
things thus forget about the job, dates, problems, etc. thus reduces
my stress level.
On the other hand while working on the project and it was close to
being done while trying to complete it before I shipped out again was
very stressful. Just ask my partner. Since its been completed it
like a big weight has been lifted off of me.
Jerry Bidle
______________________________ Reply Separator _________________________________
Subject: Kolb-List: Re: Instruments/Avionics
Date: 3/8/98 10:18 PM
>N4M6T1(3" FACEMILL
>N6S265M3 .......
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
> Thanks,
> Rut Fuller
No, only the back of the inside ribs are welded.
Those are the ribs that attach to the fuselage and allow folding.
John Jung
I found temperature control difficult and uncertain at best. You may
think you have 225 degrees but it could be 250. Also your fabric could be
extra sensitive to heat. Work slowly and watch closely the " effects"
of your iron, first and foremost, as well as the temperature you are
using. I found applying heat carefully to the fabric on the upper
surface of the structure and to the fabric on the lower surface of the
structure at the same time stressed the structure evenly. Ray from
Woodbury
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
I see there is a little brew-ha going from this thread, but before
commenting on that aspect of it, I'd advise against a Flyer as a first
ultralight on other grounds. That is, I understand that the Solo engines
are less reliable and minimally adequate HP for the Flyer. Certainly it is
okay to go with less reliable and barely powerful enf engines, as all
early ULers did, but that imparts additional risks that you'd have to
deal with -- such as engine out, single engine operation pretty likely
early on. This could spell trouble for a low time pilot. These days a
newbee has many options to buy a newer, forgiving plane (Kolb or whatever)
with a newer, more reliable (and single) engine.
As far as the bit about a Kolb for UL-only trained, my opinion is: that
is perfect so long as the UL training is/was good training. It is
probably reasonable to say that Kolb models since the Flyer are a little
testier than Quicksilvers, so the newbee should have more experience
compared to flying somethng like a Quick. I've heard many other people
with more experience than I say this too.
More complex aspects:
- taildragger (GA has an endorsement for this kinda thing :-) )
- 2 engine instead of one (GA has a rating for this kinda thing :-) )
- engine reliability (they're running close to full power more of the time)
- point ignition instead of electronic
- not sure, but i think Flyer also has no spring in landing gear
like Ultrastar
All are somewhat minor, but they add up, and you have other options.
-Ben Ransom
John,
I took to my FireStar with just 3.5 hours in a Quicksilver MX. Of
course, the private pilot training and RC planes helped out a little, but
then I wiped out the FS gear on my first landing. It got much better
after that. I think it's 90% skill,
10% knowledge.
Ralph Burlingame
Original FireStar
>anywhay: While I own two Kolb's and wouldn't mind owning one of each
model, >I wouldn't recommend any Kolb for a new pilot with just UL
training.
>John Jung
Subject: | aero trader needed |
Need some help, threw away a recent Aero Trader that I need. I saw a plane in
there that a friend is real interested in but can't find the issue nor do
remember what issue it was. I picked a free copy up at the airport some time
this year, let me describe the airplane. It's a twin, very unique looking
plane, has a glass frontal cockpit that kind a is round with a lot of windows.
If I had to describe it I would say it looks like Volkswagen micro bus, or a
See Bee with a smaller fuselage and windows. I believe the plane was British
and had inline cylinder motors. We also saw it as Oshkosh this year and if I
remember it correctly, the asking price in the Aero Trader was $90,000. If you
have a copy of this issue I would appreciate the phone number, we are having a
hard time tracking it down because neighter of us know the name of the plane.
thanks
Richard.Dewitt(at)HBC.honeywell.com
Rut,
All of the Kolb ribs are still riveted together and have always been his
way. The factory will build the ribs for a fee. In 1986 I paid $99 for
them to do that and it was well worth it. I'm not sure what they charge
now.
The newer FS have a 7-rib wing as opposed to the early version, that I
have, with 5 ribs. They can be built to carry two, so they are also
beefier in construction. Other changes are: aileron control system,
redesigned cage and elevator-stabilizer control mechanism in the tail,
streamlined lift struts. The new "bare-bones" ones are faster than my
original. Except for speed and weight, the flight characteristics are
similar between the two planes.
I built my FS with average building skills and had never have built
anything before except model airplanes. Believe it or not, one of my
worst skills is "following directions". I really had to work at this one.
It's been built for 11 years and it's built right because I followed the
plans. I wouldn't say that it's hard to build, it's just a labor of love
where the objective is to be able to fly a nice performing plane as your
reward for building. Once finished, you can fulfill that life-long dream
of flying a plane that you constructed with your own two hands.
Ralph Burlingame
Original FireStar
writes:
>the ribs built from the factory were rivited together. I am admitting
>right now that I don't know jack about building, but was wondering about
the
>Thanks,
>Rut Fuller
Hi John,
Your comment about training is bewildering. What training would you
recommend if not UL.
Could you elaborate on it more detail. Exactly what do you have in
mind.
Jerry
Subject: Kolb-List: Re: newbee
Date: 3/9/98 9:52 AM
> lessons......??
> thanks, Hoody
Hoody,
anywhay:
John Jung
I have a GA background. During the transition to UL's I learned a few
thing. The two main things I found was there is a significant speed
decay when you chop the power. Speed bleeds off quickly due to the
high drag of UL's and you need to compensate for it now. The other
was the effect of the high center of thrust pusher configuration.
Had I not had prior tail wheel experience, that could make things a
little more interesting to say the least. For a total newie, lack of
tail wheel experience would make it a little challenging but can be
mastered safely with a little care and proper direction.
Some how I don't picture a GA airplane as the best trainer for
preparation of a UL, a light (UL) type) 2 seat trainer would be better
but it's not the only answer.
Jerry Bidle
> lessons......??
> thanks, Hoody
Hoody,
anywhay:
John Jung
On Mon, 09 Mar 98 22:24:00 cst jerryb(at)jmd.ods.com writes:
>their
>other
>reduces
> my stress level.
My department is less than 10 individuals. I'm the only "pilot" (UL or
GA). Another guy flys RC gliders. I smile the most, he is second.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
writes:
I think what's confusing you sounded confusing to me too. The "root-rib"
(inboard most) of each wing is partly welded 4130 steel tubing (aft of
the spar) and riveted aluminum tube (forward of the spar). All ribs
outboard of this one are riveted aluminum. An earlier post (about
locating a BRS?) mentioned a welded rib. I think this root rib is what it
referred to.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Numerical Control, was ..something completely unrelated. |
writes:
>.... When I have built simulators for various aircraft
>(f-111,
>freedom equations...
Ever hear of "Flight Safety Int'l."? Sounds like you have some of the
same customers. They have a pretty big operation in Tulsa also.
>which
Like aircraft, "best overall" is impossible to say without defining some
pretty specific parameters. Most basic (and critical) is size. What is
the minimum X,Y,Z envelope you can live with? Regardless of what size you
decide on, the first part you'll have a chance to make any money on will
be .5" too big for your machine!
>used market yet?
Like aircraft, condition is everything. All equipment wears out, unless
it was useless in the first place. Be VERY careful, paint and polish is
cheap. Right now, US industry is generally doing very well. Most shops
are busy again (finally!) and so new and surplus equipment is in demand.
-Good luck!
Like aircraft ...Oh sorry, that doesn't apply here....
Our local vo-tech school (they don't like being called that nowadays but
I still say "ARSA" too) has what's called a "small manufacturing
incubation program" - or something like that. It sounds like just what
you need. You take them your idea and after reviewing it, they may decide
you're on to something. If so, they'll help you with the design, produce
prototypes (with some very nice, brand new machines), counsel you on your
business plan, equipment purchases, etc. The idea is to help get more
businesses going so their students will have more chances for employment.
(Its probably a good program although I personally think it smacks of
"tax-and-spend liberalism" ..but that's another subject.) Check with your
local (state funded) college or vo-tech, you might be amazed at what they
offer.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
> like Ultrastar
I built and flew one of the first flyers.I liked it but those 2 engines
did give me a lot of trouble.I even flew on the original Chryslers.Other
than that it was great. I don't know what all this bitchin about
taildraggers is for.I have never had any trouble with the tail wheel or
skid.I transitioned myself from a Cessna with no problem. I have taught a
student to fly in an Ultrastar in the days befor 2 seat trainers. The
taildragger problem is a non issue as far as I am concerned due to the low
landing speeds and quick deceleration on the ground. Taxing on the ground is
a minor problem but you can get used to it.
I did end up converting it to a single engine and sold it soon after.
Woody
Subject: | Re: aero trader needed |
>thanks
> You are obviously describing a Humber-Pudge "Sprightly", and if you
send me the $90,000, I will be glad to tell you more...
Richard Pike
MKIII N420P (42oldpoops)
> johnhauck >>
GeoR38:
I won't take up a lot of space tonight to explain everything. If you are
going to Sun and Fun, and/or Oshkosh be glad to sit down and talk with you
at great length about Kolb and my affiliation with the Kolb crew.
Right off the top of my head, counting my own kolbs and factory acft I have
about 3,000 hours in them over the last 14 years. Several two four or six
years I was inbetween acft, building, etc. and not flying so conservatively
speaking, I accumulated this 3,000 hours kolb time in 8 to 9 years. This
time is divided extensively between all models: Ultrastar, Firestar, MK
III, with only about 50 hours in the Sling Shot at Lakeland and Oshkosh. I
have flown these airplanes in many geographic areas from Key West to
Deadhorse (Arctic Ocean), Alaska, San Diego, Ca to Caribou, Ma, Seattle, Wa
to Brownsville, Tx, I forget how many Canadian Provinces at the moment,
from fbelow sea level at ElCentro, Ca to 10,000 feet at Mt Mckinley,
Alaska, 13,500 feet over illinois on a return flight from Oshkosh to
Alabama (stopped climbing because I was freezing dressed in shorts and t
shirt. Be in all kinds of weather, turbulence, heat, cold, day night.
I've lived with these airplanes for extended periods: 21 days, 25 days w/
Firestar (32 states), not counting all the two week trips to S&F and
Oshkosh. The little airplanes always bring me home. I feel very
comfortable in Homer's airplanes. They are easy to fly, yet are also very
exciting to fly. They have great STOL capability and I enjoy that
immensely. They come closer to the characteristics of helicopters I flew
in the Army, than any other Ul; and airplane I have flown. I have a great
deal of plain on confidence in Kolbs.
Met Homer at Sun & Fun in 84 one month after I bought my 1st kit from him.
Talked to him on the phone, at S&F and Oshkosh, Flew the Firestar to see
him in 88 and 89. Stayed in his home on those trips. Built two Oshkosh
and one S&F Grand Champions, and one S&F Reserve Grand Champion. If you do
that you get to be friendly with the Boss (just kidding and not trying to
blow my own horn). For many years Kolbs were consistently chosen Grand
Chap and both Oshkosh and Sun and Fun.
Wore a Jim Handbury Hand Deployed prcht on my chest for 12 or 13 hundred
hours flying US and FS. Mounted 2d Chantz in center sec of MK III. Cen
Sec was empty space not being utilized. For my long trip I needed all the
cargo area possible. Seriously, I have no fear of a wing folding on the MK
III. It has a 6 inch main spar, tremendously strong lift strut w/jury
strut to keep it in column under negative loads. Unintentional tests I
have experienced w/the MK III wing indicate there's no way I can pull this
wing off in flight, but do go out and try to prove me wrong. I emphasize I
have never flown any aerobatic maneuvers in my MK III and don't intend to.
When I find something I like better than what I fly, that will out perform,
outlast, and is any way near as crash worthy as Homer's chromoly cages,
I'll build it and fly it. So far I am completely satisfied with the MK
III. The Slig Shot I love and it is tempting, but I couldn't be loyal to
two airplanes. Takes a lot of time being loyal to one.
Hope this answered your questions.
john hauck
I HAVE A NEW 582 ON MY SLINGSHOT WITH DUAL
ROTAX RADIATORS. DOES ANYONE KNOW
IF A THERMOSTAT COMES INSTALLED IN A
NEW ENGINE, OR DOES IT NEED ONE. I HAVE
SOMEWHAT OF A LEARNING CURVE TO GO
THROUGH ON THE 582.
THANKS JOHN
SLINGSHOT WITH
DUAL
ANYONE
KNOW
INSTALLED IN
A
NEED ONE. I
HAVE
SOMEWHAT OF A
LEARNING CURVE TO
GO
THROUGH ON THE 582.
&nbs=
p;
THANKS JOHN
Subject: | Have you heard of |
I spoke to a guy named Glenn Rink last night about helping me complete a
Kolb project that I am planning on taking over. This guy was very
helpful and knowledgable about Kolb aircraft. I was wondering if anyone
knows this gentleman or has had any dealings with him in the past. I
must say that I am very impressed with him after talking with him on the
telephone.
> >John Jung
Mark Swihart wrote:
> John,
> -Mark-
Here is what I think is adequate training for a Kolb:
A Recreational Pilots License or equivalent AND a minimum of 50 hours
of ultralight experience. Or a Recreational License and min. 50 hours
general aviation plus an ultralight checkout.
Why? Because there is too much to lose.
In a 10 miles radius from my home, there have been 6 Firestars and 4
Ultrastars. Three of the Firestars have been involved in major
accidents with an average loss of $10,000. per accident for the planes
only. That does not include the medical expenses. All three pilots had
serious injuries and none are currently flying. All four of the
Ultrastars have spent more years waiting to be repaired than they have
being flown. At least their accidents didn't involve serious injuries.
I believe that the problem is that too many people think of Kolbs as
ultralights rather than light aircraft. Kolbs are great flying planes,
but less forgiving than Quicksilvers (the most common ultralight) and
much more expensive to repair.
Granted, my sample area is only a tiny part of the US, but I think
you can understand why I am cautious in my recommendations.
John Jung
Original 377 Firestar
Firestar II N6163J
>John Jung
>Firestar II N6163J
I must say that I believe that it is necessary to be properly trained by
a compotent flight instructor and to be checked out in similar aircraft
before venturing out on your own. I also feel that ground school is
also important. I tend to agree with John. I myself am fairly new to
aviation with just 60.5 hours in GA, mostly in the Piper PA-28 Tomahawk.
Education, knowledge, and experience will certainly make one a more
compotent pilot. I feel that it is my duty as a pilot to remain up to
date on all my training to keep the skies safe. If uneducated and
untrained pilots fill the sky laws and regulations may change and take
our freedom away due to increases in accidents.
While FAR 103 allows us to fly w/o an offical licence, I feel that the
FAA, EAA, and the USUA believe that education, knowledge, and experience
are essential tools for everyone intending to fly.
I recommend to the new guy, to proceed with caution. That doesn't mean
not to purchase that aircraft, but to gain all the knowledge and
training that you can untill you are confident about your skills. Then
countinue to pursue countinued education.
That's my 2 cents. From a new guy too.
Good Luck and Fly Safe
John,
I wish I had all the experiance you have in Kolbs... to be in the right
place at the right time!
training,
I agree that when you have more than $10k in a new aircraft it makes no
sense to go roll the thing into a ball and bust yourself up as well to
save a few hundered to get some good dual instruction in a similar
aircraft. I wish there were more kolbs around being used for training
but there are none around here. My approach is to get my student pilot
liscense in a Champ. it is a taildragger 90 horsepower and is probably
fairly close to a kolb in flying qualities, except the thrust line and a
bit faster. by the time my instructor signs me off for solo I hope to
have the plane done, and I can spend alot of time slowly getting used to
the Kolb. It will cost me about a thousand dollars to get through to
solo but I will be much less likely to roll the plane up and lose it, or
me! Plus I will be well on my way to getting my private ticket and that
will allow me to move up to a laser or slingshot or what ever
eventually! There is no comparison between the time I have in easy to
fly ultralights and time I have in the Champ, which I hope is Kolb like.
Going from a quicksilver or Rotec rally 2B, its real cheap copy that I
flew, to a Kolb wold deffinately test a person. I have flown the Champ
fairly well but I am real glad I have a GIB telling me what to do and
guiding the controls when I need help.
Mick
I built engineering simulators, for aircraft development, and testpilot
flying qualities evaluation, not pilot training syms like Flight Safety
Int'l. They were mostly software projects with a minimum of hardware to
give the testpilots a feel for what was going on. The Citation X
simulator was a pilot and hardware in the loop project but I only worked
on the actual simulation software and recomended some ideas for the
hardware.
Topher
John, Pretty bad news about all the crack-ups. I personally don't
think of a Kolb FS (the only model I've flown) as more difficul than other
ultralights i've flown, but like any unfamiliar plane I gave it a healthy
in your area, it at least begs the question whether they had anything
besides location and kit vendor in common ...i.e., builder, instructor,
weather, club, field, pilot attitude, etc. I can see why you feel
the way you do considering the dismal record in your area, but I think on
average, 50 hours is way more than necessary to do well in a Kolb.
-NTSB mode off (for now), Ben Ransom
> > >John Jung
> Mark Swihart wrote:
> > John,
> > -Mark-
> John Jung
> Firestar II N6163J
Ben Ransom
UCD Mechanical Engineering Dept.
Email: bransom(at)ucdavis.edu
(530) 752-1834 Fax: 752-4158
dwegner(at)isd.net
Kolber's
I believe the Kolbs have more airplane-like flight qualities than other
"more forgiving" ultralights, but the stall on the Kolbs is pretty
gentle. As I said in an earlier post, there is also a natural stall
warning from the rectangular wing. With these airplane-like flying
qualities, the pilot needs a higher skill level to fly them. Since most
of us didn't have access to a Kolb trainer, this leaves training to
another 2-place UL, or an airplane. If you go the airplane route, the
Kolb is so light, by comparison, that this may be quite a surprise on the
first flight. If you go the UL route, the Kolb has more performance and
this too could also pose a problem to the newbie. Ideally, it would be
best to train in a Mark II or III. Since this is not always possible,
maybe training in both the UL and airplane would be the way to go. This
is what I did and I'm still flying safe 11 years later. Just my opinion.
Thanks John Hauck for the email on "why you fly Kolbs". You said a lot
there guy and it was great!
Ralph Burlingame
Original FireStar
77-80,86-93
All of the inputs to this thread are very interesting. Hoody's question
is about a certain Kolb model in which I have 316.3 hours. This is small
potatoes (PIC hour wise) compared to some others but I'd like to respond
to Ben's points:
>...More complex aspects:
With me (150#) in seat, I'd guess there's less than 15# on the Flyer's
tailwheel. This is purely a guess but I bet its less than a FS and a ton
less than a C140, Champ or even a Cub. Still, it does have it's nosewheel
back under the rudder (where it belongs) and you must keep that in mind.
I've heard many GA pilots say that the FS and later Kolbs are much more
docile than GA taildraggers and the Flyer is likely more docile than a FS
(I don't know, I've never flown a FS). I have had no tailwheel training.
I did run off a runway once (it was a straight crosswind of 15 gusting to
20 and I really shouldn't have been out in the first place), no damage to
me or the plane but I sure thought I was gonna buy a runway light for a
couple seconds.
The distance from aircraft centerline to prop centerline is about 24".
With one engine out, the Flyer will (with no rudder input and full power
on the remaining engine) crab towards the dead engine about 10-15 and
stop there. You can hold it straight which uses about 1/4 of the rudder
travel but it seems to fly just as well in either attitude. My plane will
not hold altitude on one engine although I've heard other Flyer pilots
say theirs will. It will give a nice looong glide 'tho!
IMHO, there is no "critical engine" as in a typical GA twin. I'd be
surprised if either engine alone has the thrust (at a 24" moment) to
overcome the control surfaces but that's just a guess, NOT proven fact! I
make fairly wide shallow turns when on one engine, just in case, but I
can turn either direction and its never shown any tendency to depart from
controlled flight.
>time)
Sorry Ben, the props are bolted directly to the engines and are thus
"self-limiting" on power output. While the Solo 210cc (with points) is
rated at 16 hp max, that is measured at 7800 rpm. I turn a 36 x 10" prop
on each engine and never see over 5200 rpm. Following the power curve,
that's 11 hp or 69% of the max power rating... fixed, forever. No matter
how many throttle handles you bend, you can never push the engine beyond
69% of its maximum output. I've never seized one of my Solos.
The weak point is really the main bearings. These engines were designed
for a side load on the crank, not a thrust load. The bearings will begin
to get 'sloppy' after 70-80 hours and will need replaced every 100 hours
max. It's always been a progressive deterioration with plenty of warning.
To me, its not a big deal to replace them but then, I have always liked
to take things apart and see how many parts are left-over when I put it
back together. The upshot is there's 2 bearings per engine and they cost
$7.00 each. Seals are $2 to 3 each. (Beats hell out of CPS parts don't
it?!)
I'd love to have CDI on my C2 (447) or Twinstar (503) also. CDI is great
but if your engine is an older model, its pretty expensive to retrofit.
I'd guess more than half of the UL engines in current operation are still
point fired. Think of how reliable GA engines are and they are nearly
100% point fired. Besides, replacing the bearings requires removing the
stator (timing) plate anyway. BTW, Solo uses the same points as Rotax.
> like Ultrastar
True, It has short steel legs. I run my wheelbarrow tires with 15 psi or
less. Its nice and cushy on a plane which weighs slightly over 200#! I've
dropped it in more than a few times and have never damaged the gear (my
pride, yes but never the gear).
I've had my Flyer nearly 7 years. Its not fast, sleek, or even very
pretty (now anyway) but to its credit, its very forgiving but also very
responsive. It is also very strong for its weight. True, there are many
other choices out there but I'm pretty happy with mine and I think its an
excellent plane for a newbee who's had "proper" training. Now, if we
could just figure out what that is...
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
writes:
>... this leaves
>training to another 2-place UL, or an airplane. If you go the airplane
>route, the Kolb is so light, by comparison, that this may be quite a
>surprise on the first flight. If you go the UL route, the Kolb has
>more performance and this too could also pose a problem to the newbie.
Ralph,
I think you hit it dead center. I had about 10 hrs dual and 10 solo in a
C152 when I 'transitioned' to my Flyer. The most important thing had to I
learn was not to be afraid to put the nose down to go down, somewhat the
opposite of the 152. On my first approach, I was afraid that even with
the power pulled back, my speed would build very quickly if I dropped the
nose even a little.... HA! HA! HA! HA! (I greased it in on my second
try.)
At the time, I had only ridden in a couple different UL-types (one was a
Mk. II). I never had any 'instruction' in either UL but even those short
experiences probably helped more than I realized at the time. Some
"formal" UL training on top of the GA time would have been a more ideal
situation.
I have to disagree with John J., 50 hours is more than the minimum
required for a PP ticket! Granted, I have most of my time in a "lowly"
Flyer but a FS can't be that much more complex. It might actually be less
demanding on the pilot due to more available power (you can't 'power'
your way out of much with a Flyer!). Many UL pilots get out of the sport
before they ever see 50 hours. It could be they'd stay with it if they
had something they really enjoyed flying.
Just some thoughts...
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Have you heard of |
>telephone.
Back around 1979 Glen Rinck sold me an Easy Riser ultralight weight
shift bi-plane. It had a McCullogh 101 engine with reduction drive, and was
covered in unpainted blue fabric. It more than made up for that drabness
with wingtips painted white with day-glow orange stripes.
I gave him $300 for the Riser and a pretty dilapidated trailer.
Glen is taller and weighed somewhat more than I did, so the thrust
line being about 5 degrees off, and the engine being mounted about an inch
and a half too high on the cage probably didn't affect his flying as much as
it did mine. The first time I unweighted the harness in a thermal, the Riser
started an outside loop. Chopping the throttle to idle let it recover. I
called Chuck Slusarczyk the next day, and he gave me the angles and
measurements for getting the thrust line right. I still have them written
down in a little green notebook.
I seem to remember seeing him being in on a trophy winning Kolb in a
magazine article last year. Obviously he is still as gung-ho as ever. He
struck me as being an up-front guy that would tell it as it is. If you get
involved with him on the project, say hello for me and give him my e-mail
address.
Richard Pike
Subject: | Flyers, Taildraggers & Training |
The Kolb Flyer:
My first solo was in our first Flyer after only several hours of crow hops.
Tail dragger was not an issue, twin engine was not an issue, nothing was a
problem. It was a very docile predictable slow flying ultralight. Good
analysis, Mick, I agree. But, low climb rate ... esp. for heavier pilot,
could be an issue, which could result in departure stall.
Taildraggers:
The taildragger thing is really a non-issue. Not all tail draggers have
tail
dragger vices. It is so very simple and elementary, and yet so often
overlooked, even in in-depth discussions on taildraggers. What makes a tail
dragger bad is a lot of weight on the tail! Simple. When there is a lot of
weight on the tail, that means that the CG of the airplane is behind the main
wheels. The further behind the main wheels, the more vicious the airplane.
Because with the CG behind the wheels, you introduce an end-swapping tendency
... a tendency for the back end to swap ends with the front end. Also things
like rhythmical bouncing start appearing with increasing weight on the tail.
On all Kolb models the tail is kept very light, which means the CG is right
between the main gear - a very good place to be. You can do this with a
pusher because you dont pay a terribly high price if you go up on your nose
and look like a lawn dart. I learned this valuable lesson in my KR2 which
tended to be light on the tail when Solo. There I once paid the higher price,
up on the nose and quick as you can blink, the prop was a nub.
Training:
In my (own) observation over the (almost 20 years of ultralighting), the
tendency toward accidents does not correlate well with lack of GA experience,
total flight hours, or hours of training. The correlation is more basic:
training vs. no-training. Those who get training do much better than those
who dont get training. But even this does not quite hit the exact mark, more
precisely yet: it is the pilots attitude. If he has the proper attitude he
is a learner and will get training. He will have an attitude of being careful
and an attitude of not being presumptuous.
We have been doing quite a bit of training at Kolb Aircraft since Dan,
our
flight instructor came aboard. Dan has been flight instructing his entire
life in GA aircraft. When I asked him who his worst students were, he replied
without even needing to think: airline pilots. May sound strange, but many
airplane pilots started flying the heavy stuff and never flew the ubiquitous
150s. Why were they poor students: because they had a bad attitude, they
assumed since they could fly airlines, they could fly anything. Wrong! They
had some things to learn ... one of which was not to land 50 ft in the air!
And of course any real pilot can fly an ultralight. I have seen this
so
often - and have seen the results. Bad attitudes = no training = accidents.
Good attitude = learner attitude = safer flying.
There was a fatal accident at Kolb Aircraft (not in a Kolb airplane).
An
unknown pilot flew in and landed. Had a smoke, took off and gained about 700
ft altitude. His engine quit and he wound up stalling and spinning in, he was
killed. He was not able to land his UL (which was 700 feet directly over a
3000 ft grass strip) without power! (We later learned he was not a neophyte.)
This accident made a big impression on me and - my wife and daughter because I
was flying too (but away from the strip) - they heard the crash and assumed it
was me. Not sure what happened, controls were all intact, etc. He probably
never learned to fly the airplane without power. There are pilots who never
fly without power - these are not learners. Learners take the time to check
out the characteristics of their airplane without power, etc. Learners dont
assume they have it all together. They are humble enough to seek out advice,
ask questions, and have the patience to learn first, and fly later.
I really appreciated Jack McCormacks article a year or two ago in Ultralight
Flying: it was called Booster Shot or something like that. Basically he did
a very stupid thing, he tried to take off at Sun-N-Fun with a flat tire on his
trike. Everyone tried to stop him, but off he went anyway ... right into the
big ditch. The gist of the article was that he had done similar stupid things
before and learned the hard way, but now the immunization evidently had worn
off and now he needed a booster shot.
Back in the days of yore, I was one hot-shot UltraStar pilot. I could
make
that airplane do almost anything - I probably had over 1000 hours flying them.
I regularly did loops, snap rolls, spins, 90 degree whip stalls ... never
could make it slow roll though. I was ever ready for another impromptu
airshow! One time I flew up behind Bill Martin while we were flying together,
got real close and grabbed his rudder. Then I shook it back and forth
vigorously! Needless to say Bill kept far from me afterwards. The most
ridiculous thing I ever did was a power-off snap roll, just before landing
about 150 feet in the air. Of course there was that time that I did manage to
fail a wing doing some radical loops - but thats another story.
Time for my booster shot. Anyway, the day of the UltraStars faded away
with
the coming of the FireStars and soon I was abusing them instead of the Ultras.
Some years later, one of the locals had an UltraStar powered with a 503. He
was anxious for me to check it out. There was no ASI, but having developed
well calibrated cheeks - who needs an ASI - not me. I took off and I remember
being disappointed with the power, I had expected great things with that 503!
Got about mid-field about 50 ft AGL, and I felt some turbulence - still not
climbing well. I started looking for the lowest gap in the tree line ahead.
And all of a sudden I was looking straight at the ground. Before you could
say, or even think of any expletive, it was all over. I had been flying on
the back side of the power curve and did not know it. I had been busy
thinking what about the 503 could be different, wrong or causing problems, I
had been distracted in my thinking and overlooked the obvious. I wasnt hurt
- I went on to my graduation from seminary that very same day.
Just another illustration that an incorrect attitude ... a careless one
even with much experience - can do the best of us in. One more quick
illustration: I was in Taiwan building TwinStars. The importer also sold
maxairs and had a MaxAir Rocket back in the corner of the hangar. They wanted
it flown on the grand opening day of their ultralight club. The only other
person to have flown it was Phil Lockwood when he had been there. We got it
started and they wanted the hot-shot pilot to fly it. Never flew a rocket
before, but I knew I could! Didnt even need anyone to show me how, even if
there was such a person. Got it started and blast-off; boy what a rush! I
liked that Rocket! But like I said, I never flew a rocket before ... wasnt
acquainted with its power off glide, for instance. Very soon I had an
opportunity to experience the Rockets power-off glide! The 532 engine
abruptly seized and ... silence. Well, the rocket flies great with no power,
but only one problem: not much glide ratio; nothing like I had been accustomed
to with our Kolbs. Little 22 ft wing span, lots of wires, and pretty heavy
come down fast. I was very close to the strip ... but not close enough.
Dont know if I mentioned about the topography in Taiwan. Very few places to
land. Couldnt make it to the strip, and the terrain was very rough around
the strip almost similar to a quarry. Nothing flat much bigger than a pool
table. Hit hard and broke the rocket pretty bad. I hurt my heel and limped
for about 6 months afterward.
Again, a bad attitude, this time of presumption. All this sounds worse
that
it is - I hope. Keep it mind these things were stretched out over a period of
20 years ... with some normal flying in-between. I liked to think of myself
as a good pilot. Technically I am, but I had a lot of bad attitudes about
flying. I use myself as an example - I could speak of others - have a lot of
stories about them I could tell, but am doing my best to be humble and stretch
out that last booster shot.
And I am not the only one, I see others - many others, doing a lot of what
I
have done in the past (and occasionally still do). I think the freedoms we
ultralighters have, tends to encourage bad attitudes. I now have a wife who
works on my bad flying attitudes - but she couldnt do a whole lot for me.
But then along came our daughter and she has been very instrumental in helping
daddy with his bad flying attitudes.
Hope this helps one or more of you to fly safer. I am not here because
I am
a good pilot, I am still here only because God, for reasons known only too
himself, has seen fit to keep me here. Now I am trying to do my part as well.
Very Sincerely,
Dennis (working-on-his-bad-attitudes) Souder
<< > >While I own two Kolb's and wouldn't mind owning one of each model, I
> >John Jung
Mark Swihart wrote:
> John,
> -Mark-
John Jung >>
It is quite evident to me anyway.....that the best ultralight to LEARN on is
the pterodactyl....only one control stick and very safe built in anti stall
features!!....but no one ever talks about
THAT!..........................GeoR38
Subject: | Re: Flyers, Taildraggers & Training |
>The Kolb Flyer:
hops.
I am
well.
>Very Sincerely,
Dennis:
I have printed out your referenced msg to keep reminding myself that I am
getting older, slower, and gravity has not changed a bit since I started
flying 31 years ago (I was a late bloomer, started at 28).
Attitude says it all. It is easy to feel that the other guy is going to
make the mistake and not me cause I have a little experience. In Army
aviation we were constantly taking check rides, flew with co-pilots, and
had a safety system that was alive, well, and active. We could check each
other. Just the opposite when I retired and started flying ULs. Nobody to
check up on me to see if I was making mistakes in flying and in attitude.
I am now a free bird left to my own fate. I had an overconfident attitude
from the get go. There was nothing in the field of ultralighting that I
couldn't do and survive, I thought. I was so good I didn't need any formal
training and taught myself to fly off an unimproved 600 feet grass strip
that is now known as Gantt International Airport, I guess because it has
been extended to 750 feet. I broke my brand new Ultrastar on my first
landing after amassing 30 minutes flt time. I learned the hard way then
and continued to learn the hard way for almost six years. Just like Dennis
I had a higher power watching out for me or I would not be knocking out
this msg this morning. I stared death right smack dab in the face on 11
March 1990. I said my last words as I watched the trees rush up to greet
me on the side of a mountain in North Alabama, but my Jim Handbury Hand
Deployed parachute opened, the kevlar bridal held as it cut thru lift strut
and chromoly steel cage, and the fuselage protected me when I went down
thru the hard woods and hit the ground. I didn't get a scratch.
That crash culminated 6 years of hard, push it to the limit, no holds
barred flying. To me I was not flying unsafely, I did not fly over woods,
water, or terrain without enough altitude to make a good emergency landing.
I flew an immaculately maintained aircraft, a strong, safe reliable
aircraft. What I did wrong was fly hundreds of aerobatics in an
unaerobatic aircraft. I flew overweight, overspeed, in all kinds of wind
and weather. I used the excuse of being caught in bad weather because I
flew long, extensive XCs, when in reality I was exposing myself to these
conditions because of impatience. Impatience can kill you and me:
learning to fly, pushing weather, flying an aircraft that needs maintenance
but rather fly a little longer than stop and fix the problem, etc.
Flying Kolbs is an exhilirating experience. That's why I do it. It is
exciting and makes me pump adrenelin (sp??) at times. I like that. But I
fly in an unstable environment controlled by gravity and the ground is very
hard and unforgiving. If I want to fly tomorrow, I got to be a big boy and
fly safely today.
My MK III has never performed an aerobatic maneuver in over 1100 hours, nor
I since 11 March 1990, 8 years ago this afternoon about 1500 hours (ironic
I should share this with you today. I didn't know what today's date was
until I typed it, and then looked at the current date on my computer) I
performed my last aerobatic maneuver. Not because I am afraid to, but I
have not had the chance to fly an aerobatic aircraft (designed to perform
aerobatics).
I still fly hard, perform many spins, stalls in all configurations, power
off flight (dead stick - engine shut off), extremely short field T/Os and
ldgs, recovery from unusual attitudes, practice forced landings, and
anything that I thinkwill help me survive when something happens
unexpectantly, and that's when it is going to happen. I try to stay
prepared. I try to be a big boy now. I want to fly for a long time.
I haven't flown in over 6 weeks, waiting exhaust system. Got it yesterday.
I am anxious to fly, but I have some maintenance that needs to be done
first. Our UL Club has a breakfast flyout Saturday morning. I want to
participate, but I probably won't be ready. I will be disappointed, but
there will be another time.
I'll fly tomorrow.
john hauck
> >John Jung
Mark Swihart wrote:
> John,
> -Mark-
John Jung >>
<< More complex aspects:
like Ultrastar
-Ben Ransom >>
Ben points out that this plane is a little more of a handful for a beginner
than would be necessary (considering the present options)....but if the buyer
is willing to do some EXTRA learnin, and survives the process...then the
conclusion is go with it.
GeoR38
<< If so, they'll help you with the design, produce
offer.
-Mick Fine >>
Mick...you are a smart guy....I teach Electronics and Spanish at a Vo-tech
here in Ohio!.......................................GeoR38...the ol glider
pilot
I just finished reading your posts and have one thing to say:
EXCELLENT!
I have only 10 years experience in ultralighting, but generally have
come to the same conclusions. I just wish that I could express them as
you both do.
John Jung
Subject: | Re: MKII vs MKIII |
<< >John, I would be interested in why you have been so powerful in your
vegetable
GeoR38:
john hauck
----------------------- Headers --------------------------------
Return-Path:
Received: from rly-za02.mx.aol.com (rly-za02.mail.aol.com [172.31.36.98]) by
air-z >>
WOW!.....I can't wait to go to Oshkosh and get the .....REST, of the
story!!!....Thank you John, it is your kind of experience that makes a list
like this so powerful...GeoR38
<< I believe that the problem is that too many people think of Kolbs as
John Jung
Firestar II N6163J
John you may be correct in being so conservative, and your experience supports
it. It would be interesting to know just HOW those planes augered in,
however, as I have a similar experience ...only with pteradactyls....two guys
INSISTED on teaching themselves how to fly and WOULD NOT listen to even the
instructor who sold them the plane and they ended up with piles of junk and
broken ribs (theirs) and legs............GeoR38
<< >All are somewhat minor, but they add up, and you have other options.
-Mick Fine
Tulsa, Oklahoma >>
Mick 5....Ben 1....Good show Mick! I think Ben was mean to me once!....but I
can't really remember. ...................GeoR38 just teasin!!!
GeoR38,
Since you expressed an interest:
The first Firestar was destroyed by a pteradactyl pilot who thought
he knew "how to fly". The plane that he built "lived" less han 10 hours.
The pilot flew slow at 50 feet of altitude, stalled and hit nose first.
The second was a by a 3,000 plus hour general aviation/aerobatic
pilot who didn't need any "ultralight" dual time before transitioning to
his new Firestar II. His plane died on the first landing, when he
started his flair too high, stalled and hit nose first.
The third was a new pilot who had 20 hours dual time in a Mark III.
His new Firestar II "lived" 18.3 hours, until the engine quit on
takeoff, he stalled and hit nose first. His plane was not built per
plans. It had a smaller rudder and vertical stabilizer which may have
contributed.
Why do I share these things? Because the experience of others, in my
area, has helped me to resist the temptation to "push the limit", and to
seek out more trainning after I already "knew how to fly".
John Jung
<< I think the freedoms we
helping
I am
well.
Very Sincerely,
Dennis (working-on-his-bad-attitudes) Souder >>
Dennis, I only met you once, with your wife and daughter, in the parking lot
of a restaurant near Rt 80 at Warren Ohio and I can tell you, you do not have
the image of the Evil Knevil that you just painted here!....but welcome to
Earth and thank you very much for your great story....and don't do anything to
jeopardize that litlle girls future!!
...................................GeoR38...driver of ByGeorge! the Firestar
ps....attitude!....what a great way to sum it up
<< GeoR38,
contributed.
John Jung
John, I see where you come from on the know it all attitude of the pilots but
let me just approach it from a slightly different angle...
The first pilot was flying by the wind in the face approach learned by his
experience in the pterodactyl (which definitely flys slower, safely) and he
had a severe problem of being on the bottom edge of the envelope for a kolb.
The 2nd pilot knew it all about planes and landed too slow....happens all the
time on kolb, even on mine by those who I let fly it ...ask Frank M
The 3rd modified the tail ...shades of Jim Lee at Sun and Fun!!!.....what can
I say!....the Kolb must be landed faster and you shouldn't modify it!!
I'm the ol glider pilot ...so that's the way I was taught to land an airplane
....fast...to punch through any ground turbulence! Now I know that ground
turbulence was not the factor for your cases, but the Kolb needs to be landed
faster than stall speed ...way faster.....I have 5 pairs of gear to prove
it....no one has talked about that.
GeoR38
Subject: | Mark 111 tail weld failure |
HI all;
I am in the process of repairing the tail on my Mark 111. I have one of
the early Mark 111 ultralights, it was in the second or third production run
at Kolb Aircraft. It has 265 hours on it. My bottom 4130 steel tube has
broke where it attaches to the steel ring that fits on the end of the six
inch tail tube (this broken tube is located about two inches below the
elevator control horn).
The early Mark 111 ultralights had a light weight tail weldment. A Kolb
newsletter a number of years ago stated that they were going to supply a
reinforcement kit for the early Mark 111 tail assemblies. The original Kolb
Mark 111 had a failure in this area
- Has anyone seen one of these kits?
- Has anyone reinforced their tail with extra braces?
- What is the size and wall thickness of the newer steel tail assemblies?
I strongly agree with the safety discussions that have been posted on this
list over the last week or so. I must add that proper pre-flight and
post-flight inspections are a life and death issue. I found a crack in the
tail weldment during an inspection. You must get down on your knees to
properly inspect the tail area. If I had not inspected this area I may not
have been here to write this e-mail.
Brian "KIm" Steiner
Saskatchewan, Canada
BME
pilots but
his
and he
kolb.
all the
Fun!!!.....what can
airplane
ground
landed
prove
> GeoR38
Why are these people working out of the parameters? One of the first
things that I was taught, even before stepping foot into my GA trainer
was the limits that I had to live in. This is why I am partial to
analog instruments as well. I like to mark my limits on the guages. An
example would be air speed. Min, max, all the V speeds. I was also
taught to monitor these gauges constantly (departure, pattern, final
approach, etc.). Are these UL pilots not doing this? I strongly feel
that all pilots should have the limits memorized, written on plaqards
within the aircraft, and documented on pre-flight checklists. Am I
missing something here? It seems to me that most if not all of the
accidents list previously would not have happened if the pilots were
paying attention to the limits of the aircraft, and factoring in a
safety margin.
I know one thing, before I step foot into my first Kolb, which is
hopefully soon, I will be more than familiar with the weight/balance and
performance parameters of my aircraft. Not to mention being familiar
with the airspace and procedures within the area that I will be
operating.
From: | "Henry C. Wortman" <hwortman(at)mail.datasys.net> |
Subject: | Flight Characteristics |
While there has been some excellent discussions on the matter of flight
characteristics of the Ultrastar, Flightstar, FSII, Pterodactyl etc.
there are some of us who are learning in Quad City Challengers. I know
that this may raise the ire of some purists who think that tail draggers
are the only thing to hold dear to your heart but I (and some others)
would like to hear some pros (if any) and cons on the Challengers. I
feel certain that some of you have had some experience with these
vehicles and we would like to hear your evaluation.
I think you guys have a great discussion group and I enjoy and
appreciate your openness in helping each other.
Thanks : Henry
>once!....but I
Uh.. that really was NOT the intent and I think Ben knows it. I just
thought his list best summed-up some relevant points about the 'Flyer'.
You do know that don't you Ben? ..Ben? ...Now put down that tie-down
stake and let's talk this thing out!
On another point, Dennis mentioned the low climb rate of the Flyer and of
course he's absolutely right. On the very best of days, it'll do 250 fpm
(and I weigh 150#). On a hot summer day, 100-150 fpm is all it'll do.
This is a VERY important point that I left out.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Subject: | Re: Flight Characteristics |
writes:
>...would like to hear some pros (if any) and cons on the Challengers. I
Henry,
This is after all, the "Kolb" list. You may have noticed a little bias
towards that maker. I think comparing Kolbs to other designs here might
just turn into a "put-down" contest. Although that might be fun too.
BTW, you said "we". Who, exactly is "we". Henry, you're a spy for Quad
City aren't you? I have always suspected those Canadians were just
lulling us into a false sense of security, just waiting to pounce when we
least expect! Its not our nuclear technology they've been after, its our
superior ultralight designs! Gawd, how devious, they plan to take over
the world with reverse-engineered 'Flyers' ! Well, you can't make ME
talk, I have an iron-will!
Ok, Ok, I give! Check out my C2 which is for sale at:
http://www.angelfire.com/ok/froghair/pix.html
I've cleverly incorporated some mods which make it fly almost half as
nice as a Kolb!
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
<< Uh.. that really was NOT the intent and I think Ben knows it. I just
-Mick Fine >>
Actually I need to apologize to Ben too cause I think it was someone else who
"attacked" me on my egt readings/mounting at the Y. I can thank Dennis for
saving my butt on that one.!
And I agree that climb rate is a very powerful tool to have for that odd ball
circumstance when you may find yourself trapped in a gully that won't allow
maneuvering. Tell me about it! I was not used to being "underpowered" when I
flew the Global (VW/2) engined N3 Pup and required about 1/2 hr just to gain
400 feet!! Scary then but a great memory now....and it happened just 9 months
ago that I ferried that puppy 100 miles.....strange
plane/area/destination....WOW! can hardly believe I survived...anyway
underpowering is a negative!................GeoR38
Dear Henry,
If you like the discussions - you'll love the airplanes! :-)
More seriously:
Some differences between Kolb and Challenger reflect different design goals.
Challenger aimed for less drag, Kolb for STOL performance. The Kolbs are
better shorter field airplanes than Challengers, but Challengers may be a bit
faster. Challenger buried the engine behind the fuselage (to reduce drag) but
this results in a smaller prop which is crucial for acceleration and climb.
Their recent change from 50 something inch props to 60 was a step in the right
direction, but there is still a world of difference between a 60" and the 66"
which is Kolb's minimum size. The FireStar II's can swing a 68 and the Mark-
III a 72". As part and parcel to the Challenger package, the engine is
mounted upside down, which is not everyone's choice of orientation.
The Kolb has a more convention wing construction with truss ribs. The
Challengers have the sailcloth wing type construction with 2 spars and curved
tubes for ribs in between. (You can cover Challenger withs Stits with the
addition of more rib tubes.)
For a comparison for 2-place aircraft, you have the basic choice between
tandem with Challenger and Side-by-side with the Kolb Mark-III. If you want
to look at the Tandem FS-II compared to Challenger, then you don't have the
dual controls with Kolb, but you have a less expensive aircraft with the
FireStar-II. Also you have the choice of the larger engines with the Kolb
Mark-III, Rotax 582, 618 and 912.
Kolb uses a lot of welded chrom-moly steel where Challenger uses mostly pop
riveted aluminum. Personally I think welded chrom-moly steel is far superior.
The 4130 steel is a much more expensive material than 6061 aluminum, plus the
welding is a more expensive process because it takes more skill to weld than
pop rivet. I don't think you'll find any knowledgeable person claiming that
pop-riveted aluminum makes for a superior structurer over welded 4130. I
mention both of these things because these features increase the cost of the
Kolb airframe. Or alternately you could say this helps keep the cost of the
Challenger down.
Plus Kolb's use more steel in the the other higher stress areas of the
airplane in the wings and tail. Challenger sells through dealers and Kolb
direct. Challengers pricing and dealer network results in more motivated
people out in the field extoling the virtues of Challengers and they sell a
lot of airplanes.
There has been quite a bit of discussion of the ul new group on Challengers -
with my favorite contributor Dan Zank presiding.
Kolb has folding wings which many find a plus.
Hope this helps!
Dennis Souder
Pres Kolb Aircraft
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
superior.
the
than
that
I don't consider myself a "knowledgeable" person by any stretch of the
imagination but I have a good bit of experience with chrom-moly mountain
bike frames. They are incredibly strong, I have seen these things take
severe punishment and never so much as get a dent in the tubing! And like
John Hauck mentioned about his landing under a Jim Handbury parachute, if
you have to crash through trees hanging under an uncontrollable parachute
then I would want to be in a chrom-moly cage NOT a thin wall aluminum tube
structure...
A safe feeling is a nice feeling....
my $.02 worth.
Jeremy Casey jrcasey(at)mindspring.com
And like
>structure...
>my $.02 worth.
After reading my own post there I want to put a disclaimer in it 'cause I
don't want to misquote anyone. John Hauck never mentioned anything about a
pop riveted anything!!!! That was not a direct quote for sure... just
thought it was relevant to the Challenger question that was posted.
Sorry....
CYA mode off now...
Subject: | FLIGHT CHARACTERISTICS |
Subj: RE: Flight Characteristics
Date: 98-03-12 10:45:48 EST
Reply-to: jstewart(at)ncfcomm.com (jstewart(at)ncfcomm.com)
To: DLSOUDER(at)aol.com ('DLSOUDER')
Challenger luker here: Don't boo me, I just found a better deal on a
Challenger before I found a Kolb. I thought I'd add a few comments on
Dennis's comments. If I could get ahold of a Mark III to compare with my
C-II, my next plane (this fall) might be a Kolb. Mine is an '88 503 DC.
It has the smaller re-drive and the 54" prop. Still, climb rate is
plenty, stall is around 25, with top end around 75. I'll be streamlining
the struts in the next couple of weeks to improve that. Having the engine
upside down has it's trade-offs. One one hand, I have a lower thrust line,
but on the other, I had a plug wire (now safety-tied) fall off 3 times.
The Kolb frame sounds like the better way to go, and similar to the Rans
tail on a C-II flailing around, which they seem to do. The controversy
over the adverse yaw with doors on was enough for me to put on the vertical
stabs before I even flew it.
I wonder how Challenger would do without Don Zank. He's one great dealer,
whether you bought a plane from him or not, and has given me advice freely
on the Fly-UL list many times. Dennis, are you admitting you're a luker on
the Fly-UL group? If you are, speak up more often :>)
Although 2 people can have my wings of in 12 minutes, and on in 20, I'd
need a rack to put them on a trailer. The folding wings are a definate
plus for the Kolb
Check out our NNFC Web Site below. Lots of pictures, and 1 Kolb for sale
120 miles away in Lincoln, NE. I'd certainly like to get some time in it
this Spring before he sells it. Otherwise, there's no other 2-place Kolbs
that I know of in the area. Looks like I'll have to figure out a way to go
to S-n-F to compare both! I need to meet both Dennis and Don someday.
J.D. Stewart
NCF Communications, Inc.: http://www.ncfcomm.com
Home Page: http://www.users.ncfcomm.com/jstewart/index.html
N.E. NE Flying Club: http://www.users.ncfcomm.com/nnfc/index.html
> to Ben's points:
I'm behind on my email, but wanted to respond to you Mike. Looks like
good points of clarification you made to my comments and assumptions.
After reading from your post based on Flyer experience, it sounds
not too bad at all. The aspects I still would have some reservation
about are the barely adequate power and the off-center engine out
should it happen at the "wrong time". Especially with the
tail-wheel thing, i agree this is really hardly worth mentioning. I
can't discount it entirely tho as my 3 wheeler brother came oh so
close to groundlooping my FS. We can all get very used to what we
fly and forget about the minor "no-brainers" being one more thing for
somebody with different or no experience. As a footnote to that
near groundloop, I think it may be more the high angle of attack
our Kolbs sit at when all wheels are on the ground. A quartering
crosswind gust gets underneath a wing and you better be ruddering
and aileroned for it. Maybe true for a tricycle too? Don't know,
as I don't have enf experience in them :-). The moral is that
a newbee would be fine in a Flyer so long as she/he takes it in
slow steps (the attitude thing), just like anything else.
BTW, on my KSP, the tailwheel is 30# with me (155) in the cockpit.
It is 50# with me out of the cockpit and of course a little more
than that with the wings folded (when I have to lift it --ugh--
onto my trailer).
-Ben Ransom
I spose this is flame-bait, but maybe I can get away with
posting this on the Kolb list (preaching to the choir):
In addition to all of Dennis' substantive comments on Kolbs
vs Challengers...
DON'T YOU THINK LOOKS COUNT?
Mostly teasin, but the Challenger looks do *absolutely
nothin* for me.
One other thing ...my friend seemed to never have room to
carry anything in his Challanger I and also he couldn't
see the gas tank ...he just guessed ---blech! (I guess
that is two other things).
-Ben (now ready for Quad City hate mail) Ransom
From: | "Anderson, Jim L NWP" <Jim.L.Anderson(at)nwp01.usace.army.mil> |
Subject: | RE: Flight Characteristics |
I think everyone (Kolbophytes) was thinking that. Remember beauty
is only skin deep-then you get into pop riveted aluminum. Why do you
think they call them challengers??? OK stop it jim A. I'm sure they are
fine machines.
-----Original Message-----
From: Ben Ransom [SMTP:ransom(at)mae.engr.ucdavis.edu]
Sent: Thursday, March 12, 1998 9:05 AM
To: Kolb
Subject: Re: Flight Characteristics
vs Challengers...
nothin* for me.
From: | "Marino, Frank J (Youngstown ARB)" <Frank.Marino(at)yng.afres.af.mil> |
I'm going to throw my hat in the ring, when I was looking for an
aircraft to build I did a lot of talking to other builders and did a lot
of looking to see who was in business the longest and who was the one I
could rely on for parts. That was the most fun to fly. I went with Kolb
and am not sorry one bit. After I bent the gear on GeoR38's FS (yes I'm
the Frank M he's always slamming on the web)
and after I bent the gear on mine one time I drove to the factory a
couple of times and flew with Dan. Now I have close to 40 hours on my
MKIII and can't wait for spring to get here. I did some mods on mine
this winter like dual sticks full doors and half doors new instrument
panel. But as far as the MKIII is concerned to me it flies like a J3
cub. I would recommend that people at least take some dual flight
instruction and at least solo before flying any ultralight aircraft.
This is my nickels worth, I have no qualms with Kolb or the people that
work there, except for Dennis coming up dual sticks after I spent all
winter making mine. THANKS DENNIS.
FRANK J. MARINO
Chief Loadmaster 773 AS
>From: DLSOUDER[SMTP:DLSOUDER(at)aol.com]
>Sent: Thursday, March 12, 1998 8:05 AM
>To: kolb(at)intrig.com
>Subject: Flight Characteristics
>Dear Henry,
>More seriously:
>but
>right
>superior.
>Challenger down.
>lot of airplanes.
>Hope this helps!
>Dennis Souder
>Pres Kolb Aircraft
Kolb Evaluation of the HKS engine:
We installed the HKS on our SlingShot. For those of you who may not be
familiar with the engine, it is a 2 cylinder 4 stroke horizontally opposed
engine. It has a gear box and flywheel to help it to run smoother. It is
made in Japan and imported by Tom Peghiny at FlightStar. The HKS is very
nicely packaged.
The installation was straightforward with no big problems. It mounts to an
aluminum plate similar to our other models, except we moved it toward the rear
a bit more so the rear engine studs were directly in line with the rear Lord
isolation mounts. The engine does not bolt directly to the alum plate, but
sits on 4 alum bushings to set the engine up for clearance for some of the oil
lines.
This introduces one little problem with mounting the HKS - it puts the prop
shaft to high and this results in the need to carry more back stick than your
otherwise would. This would tend to reduce speed a little.
Other little quirk we didnt like is the powering of the ignition system. The
ignition will run off the coils if the battery fails. Or, if the coils
failed, the battery would provide power. But if your battery developed an
internal short, for instance, the ignition would fail. Rotax runs their
ignition from separate coils.
We used the advanced EIS for engine instruments.
At Kolb we, of course, are vitally interested in performance and so I
evaluated the power from a number of different perspectives.
Top Speed:
Based upon the top speed checks it appears that the HKS was equivalent to the
Rotax 503. Cruise speed with 503 or HKS is 80 mph. (Cruise speed with 582 is
87 mph. Cruise with 912 is 94 mph.)
Prop Swap with Rotax 503:
More recently I took one of our 66 x 34 2-blade wood propellers and installed
it on our famous yellow FireStar with its Rotax 503 and checked its rpm. The
503 turned it 6000 rpm. (It should have been more, maybe the prop is pitched
on the high side or maybe our 500 hr 503 is getting tired. In any case that
was the rpm.)
I put the same prop on the HKS and it turned it 6200 rpm. (That is only
another 77 rpms at the prop.) If the 503 was making 52 hp, then the HKS would
be making about 55 hp to turn the prop 6200 rpm. The 503 probably would not
be making even 52 hp at that rpm, so the HKS would be correspondingly less.
Climb Rates:
The climb rate of the SlingShot with HKS was 750 fpm. This is about
comparable to what a Rotax 503 will do - the 503 may be a bit better. (The
climb rate with the 582 is 1300 fpm.) The climb rate was with a 2-blade 68
Warp drive prop with a climb rpm of 6150 rpm. I also had on a 3-blade Ivo,
but the climb of the Ivo was less than the warp. Curiously the Warp idled
more smoothly than the 3-blade Ivo, but the IVO was smoother at cruise.
All the data seems consistent that power output is close to a Rotax 503. It
does appear to make another 3 hp or so, but this is offset by the somewhat
heavier weight of the HKS.
Plus the HKS does not run as smoothly as the 2-strokes, esp. from 2000 to 3500
rpm. Also the oil pressure drops too low at idle - this could be a sender
problem.
For the yank and bank crowd, the HKS will be disappointing. For those who
want to fly with a 4-stroke and cant afford a 912 and dont have high
expectations for performance, you may be happy with it.
The HKS could be used in the SlingShot or Mark-III. I had hoped to do a
modified FireStar with the HKS, but the higher thrust line and extra vibration
would not be suitable for the lighter FireStar frame.
We plan on removing it soon and trying out a 618 - just for fun; so the HKS
package will be for sale.
Sincerely,
Dennis
I looked at many different kits before I got my list narrowed down to
the Challenger II and the Kolb Mark III. I had info packs and video's on
both. Both had pros and cons that seemed to even out. In the end I went
with the Challenger II. I guess the biggest reason for my decision was
that I found there was a Challenger dealer in Maine not too far from me.
I thought that might be helpful for a first time builder. I can't
comment much further than that because I've still got a long way to go,
I've just finished the tail section and am now starting the wings. So
far so good. One thing us Challenger builders don't have is a group like
this. I belong because I believe a lot of the discussion could apply to
Challengers as well as Kolbs. In my opinion they are pretty similar
birds, give or take here and there.
I can't remember the specs on the Mark III but here are a few on the
Challenger II (as printed in their info pak).
Empty weight 300 lbs.
Useful load 500 lbs.
Load factor +6 -4
Build Time 40-60 hrs. (More for me I can see)
VNE 100 mph
Top level speed 75-90 mph
Cruise 65-80 mph
Stall 22 mph solo, 30 mph dual
Clime 1200 fpm solo, 700 dual
Take off roll 100 ft. solo, 200 ft. dual
Glide ratio 11 to 1 solo, 9 to 1 dual (Soarable)
Mike Watson
China, Maine
<< DON'T YOU THINK LOOKS COUNT?
nothin* for me.
-Ben (now ready for Quad City hate mail) Ransom >>
But I always thought the Challenger looked pretty good......if it was far
enough away!.....hey Ben ...wasn't it the challenger that was deep sixed in
Disneyworld in Fla when 5 of them were supposed to put on regular air shows
but one of the pilots got carried away and did acrobatics and the BRS hung up
in the wing metal??.....GeoR38
writes:
<< Challenger buried the engine behind the fuselage (to reduce drag)
>but
>right
66"
Mark-
>III a 72". >>
I believe this prop size dialog from Dennis !00% and is one of the reasons I
got a Kolb over the nearby CGS Hawk...sorry Chuck...even though you are an
equivalent pioneer like Homer!..........GeoR38
Settle down now Mick, you know these Challengers guys might be able to
learn something .......
Ralph Burlingame
Original FireStar
>might just turn into a "put-down" contest. Although that might be fun
>too.
Dennis,
Thanks for such a good report on your early years. Here I thought you
were strictly a "behind the desk" engineer and company president. I
didn't know that you had all those hours in an UltraStar.
Was that you flying the UltraStar in the Kolb promotional video?
I hope you and John (Hauck) keep this good stuff coming.
Ralph Burlingame
Original FireStar
make
them.
never
>together, got real close and grabbed his rudder. Then I shook it back
and forth
landing
manage to
Subject: | FW: HKS evaluation |
Hey Dennis is good to be hearing so much from you. While you are in a
very talkative mood I was wondering if I could get you to expound on any
modifications/upgrades to the MKIII you have made in the last 2 years.
I received my kit about 2 years ago and I heard through the grape vine
about the lift struts changing to round with a fairing for no reason
other than the streamline struts are hard to get. You announced the new
17 gallon aluminum gas tank option. I have heard something about the
spring steel landing gear legs but no details on them so I will ask my
standard 3 questions, how much does it weigh, how much does it cost and
what are the benefits (do they make the MKIII higher off the ground)?
We all got the formal announcement on the dual controls (very nice to
know). These tidbits of information like the engine evaluations and the
new options are great to hear about and it gives the slow builder like
me the option of buying some of these upgrades if I want them. It is
great to here from people like you and John it really keeps me going
hearing stories of flying and fun when I am in the basement peeling
Polytack from my fingers.
> From: DLSOUDER [SMTP:DLSOUDER(at)aol.com]
> Sent: Thursday, March 12, 1998 2:39 PM
> Subject: HKS evaluation
> be
> opposed
> It is
> very
> nicely packaged.
> to an
> the rear
> rear Lord
> plate, but
> the oil
> lines.
> prop
> than your
> Other little quirk we didn't like is the powering of the ignition
> system. The
> coils
> developed an
> their
> Top Speed:
> to the
> with 582 is
> installed
> rpm. The
> pitched
> case that
> was the rpm.)
> only
> HKS would
> would not
> less.
> Climb Rates:
> (The
> 2-blade 68"
> Ivo,
> idled
> cruise.
> 503. It
> somewhat
> to 3500
> sender
> problem.
> who
> want to fly with a 4-stroke and can't afford a 912 and don't have high
> a
> vibration
> the HKS
> Sincerely,
> Dennis
I think they were either modified Maxair Drifters or the old Advanced
Aviation Lake Buccaneers.
Ralph B.
>far enough away!.....hey Ben ...wasn't it the challenger that was deep
>sixed in Disneyworld in Fla when 5 of them were supposed to put on
regular air
>shows but one of the pilots got carried away and did acrobatics and the
BRS
>hung up in the wing metal??.....GeoR38
Have a favor to ask someone going to sun in fun.
My plans to go have changed due to an illness in the family, I am in the need
of a phone number to a vendor that sets up close to Kolb.
They embroider items, and I bought an item last year and need another. If you
are going and would you please help me and get me their phone number so I
could call them later, please E-mail me.
thaks in advance
tim
>The Kolb Flyer:
hops.
>Taildraggers:
>Training:
>who don't get training. But even this does not quite hit the exact mark, more
>precisely yet: it is the pilot's attitude. If he has the proper attitude he
>had been distracted in my thinking and overlooked the obvious. I wasn't hurt
>- I went on to my graduation from seminary that very same day. I now have
a wife who
>works on my bad flying attitudes - but she couldn't do a whole lot for me.
Boy I sure see a lot of myself in this letter.The comments mirror what I
have been saying to new pilots for years.
I never did do aerobatics. Call me chicken or call me smart but at least
you can call me.I get in enough trouble flying straight and level than to
tempt fate with fancy tricks.I remember kissing my butt goodbye in a Flyer
when I stalled it in a turn at 75 ft. and impacted the ground at 90*.
Walked away with a stiff neck and a great appreciation for that welded steel
frame.
More time should be given to talk about the backside of the power curve.
I got on the wrong side once at sun and fun in an Ultrastar. Scared the
dickens out of me. I made it through a break in the trees and slowly got on
the right side.I don't know if Dennis remembers that but it sure embarrased
me [The owner of the Ultrastar wasn't real impressed either].Diagnosing a
situation like that is hard to do when you are busy trying to save your
hide. The thought of putting the nose nown to gain speed never enters the
mind because you do not usually think of the power curve.As I was saying you
have other things on your mind.
I agree that one of the best safety devices is a wife, but the greatest
is a young child that calls you Daddy.
Woody
>nothin* for me.
Do you really think the Slingshot is a good looking aircraft? It has a
lot of good attributes but looks isn't one of them. Hey Dennis how about
giving me a shot at making a few modifications and getting a pretty plane
for you.
Woody
I have always had trouble believing the Challenger performance numbers.
They just don't match up when comparing to other makes.I find It hard to
believe their climb and cruise numbers with that small prop and reduction
drive. Has anyone flown one enough to confirm these figures.
Woody
I kinda like it :-)
Rusty
Subject: | Lubricating Hinges?? |
The first owner of my FireFly (48hrs) reportedly lubricated the control
surface hinges with some sort of silicon spray lubricant. He was hesitant to
use WD-40 because he felt it or the wash out from the hinges might stain the
fabric gap seal that is glued between the flaperons and the wing. I stopped
by West Marine in Long Beach, CA to check out their selection of lubes.
Picked up a can of BOESHIELD T-9 by PMS Products Inc. of Holland, MI
(1-800-962-1732). Can says that it is technology licensed by the Boeing
Company and among other things is good for inner wings, airframes, wheel
wells, cables and hinges. Can says that it dries to a thin waxy film that
clings to metal for months, and is safe on paints, plastics and vinyls. A 16
oz can was $10. The owner of the Hurricane I flew before buying the FF never
lubed its hinges. So to you guys with tons more experience than me......Do
you lube hinges or not? Does this T-9 sound good? What if any lube do you
use on hinges? Where else on the control linkage should I lube? Thanks in
advance for any advice. Chris W.
>.... I belong because I believe a lot of the discussion could apply to
>birds, give or take here and there. ...
I agree the "numbers" are very similar but numbers don't measure
everything. I can only relate my own feelings:
After flying the 'Flyer' for a couple years, I started to watch for an
US, FS, TS, MK.2 or any newer Kolb design. I was a 'day late and dollar
short' more times than I can count for the next 3 or 4 years. In the
meantime, a good friend started taking me along in his own Mk.2 once in
awhile. Soon I was mainly looking for a 2-place Kolb. After some more
near-misses, the C2 that I have now came up for sale and I bought it more
out of frustration than respect or "desire" for that design.
While the C2 is not a "bad" plane, you just can't make a Kolb out of it
no matter how hard you wish (or how tight you shut your eyes). It just
doesn't have the flying "qualities" that my Flyer or my bud's Mk 2 has
and it never will. If Quad City had a list they'd be saying the same
things about other designs. Mostly, it comes down to personal preference
and for me, the C2 is just not nearly as enjoyable to fly.
-Mick Fine
Green Country Ultralight Flyer's Organization (UFO)
Tulsa, Oklahoma
http://angelfire.com/ok/gcufo
mefine1(at)juno.com
<< I think they were either modified Maxair Drifters or the old Advanced
Ralph B.
regular air
BRS
>hung up in the wing metal??.....GeoR38 >>
Yea, I think you are right Ralph the buccaneers I believe!....anyway that's
why I mounted my BRS under the Boom tube facing 90 degrees and back and down a
little!......GeoR38
<< thought of putting the nose nown to gain speed never enters the
Woody
I see this as an opportunity to post something here that I have pondered for a
long time, that could save HIDE!
My Cuyunna quit on my Pterodactyl years ago at 50 ft take-off climbout! I
glued my eyes to the Ball AIS and waited til it reached 40.....then flattened
out! Of course the act of reaching 40 was also accompanied by dropping the
nose. Which implies negative G's on the disc in the indicator! After
flattening out, the canard non stalling type of craft that it is "mushed"
almost straight down to the ground and hit HARD!!
At least hard enough to bounce me almost straight up at least 6ft! Then ,
totally out of control (I was just a passenger to fate at that time), the
plane came down again selecting 1 fiberglas landing gear to break.......That's
all!
The point of this EXTREMELY interesting story is that I flattened out long
before I should have because the Ball was giving me the wrong data!!! I
wasn't going 40!! Otherwise this 25 MPH plane would still have been flying
instead of "Mushing".
The Ball AIS was reading on the HIGH side because that little disc in there
has MASS and was just FLOATING on Centrifugal force as my nose was making its
rounds!!
Conclusion ......Beware the MASS of the Ball!!!
<< The Ball AIS was reading on the HIGH side because that little disc in there
rounds!!
....................................GeoR38 >>
I mean ASI not AIS ..... and I pride myself in my spelling if nothing
else.....now I hate myself......Naw, just kiddin!
From: | William H Hatfield <hatfield(at)tsixroads.com> |
> Russell Duffy wrote:
> I kinda like it :-)
> Rusty
>Remember good people, "beauty" is in the eyes of the beholder and is only skin
deep.
Bill Hatfield
From: | "rutledge fuller" <rut007(at)hotmail.com> |
What are your suggestions about ultralight insurance? I have not priced
insurance or even looked around to see if it is available.
What are your suggestions?
Hello: I think AVEMCO is trying to get out of the ultralite insurance
business (according to them, they're trying to stay in it). I've had insurance
with AVEMCO since I finished my Firestar 5 years ago. $100,000 liability for
$100. $5,000 hull coverage for $150. Total premium $250/year. Not bad. A
letter came with my renewal notice in Feb. AVEMCO has made "significant
changes to the pricing and limits availabilty for ultralights". They cut
liability coverage to $50,000 and raised the rate to $200 and dropped the hull
coverage to $4000 for $350. Total premium: $550! I talked to Jim Nelson at
AVEMCO who basically said that they had been losing money ever since they
started the ultralight program. $50,000 isn't much liability when you're
talking airplanes. I asked if they couldn't at least raise the liability but
the answer was no. I don't know about the rest of ya'll but I can't pay that
high a premium for that small an amount of insurance. So: whatdoyado? John
Hauck suggested National, but I haven't had a chance to call them yet. Any
other ideas?
Bill Griffin
Frustrated in Ala.
Just insure that you don't crash into anything expensive or living.
Flying high is pretty good insurance.
Sent: Friday, March 13, 1998 12:41 PM
Subject: Insurance
not priced
Subject: | Re: Lubricating Hinges?? |
Chris,
Yes, I feel the hinges should be lubricated regularly and I lube mine
often. I lube all moving parts with Duralube oil that comes in a small
pump can. It can be bought at most auto parts stores and Target. I
lightly spray some on the hinge and immediately wipe off the excess with
a paper towel. The Duralube has better lubricating properties than WD-40
or other lubricants. Your T9 lube may be better. It sounds more like a
spray-grease type of lube.
Ralph Burlingame
Original FireStar
>control surface hinges with some sort of silicon spray lubricant. He
was
>hesitant to use WD-40 because he felt it or the wash out from the hinges
might
>stain the fabric gap seal that is glued between the flaperons and the
wing. I
>stopped by West Marine in Long Beach, CA to check out their selection of
>lubes. Picked up a can of BOESHIELD T-9 by PMS Products Inc. of Holland,
>MI (1-800-962-1732). Can says that it is technology licensed by the
>Boeing Company and among other things is good for inner wings,
airframes,
>wheel wells, cables and hinges. Can says that it dries to a thin waxy
film
>that clings to metal for months, and is safe on paints, plastics and
>vinyls. A 16 oz can was $10. The owner of the Hurricane I flew before
buying >the FF never lubed its hinges. So to you guys with tons more
experience than
>me......Do you lube hinges or not? Does this T-9 sound good? What if
any >lube do you use on hinges? Where else on the control linkage
should I lube?
>Thanks in advance for any advice. Chris W.
> So: whatdoyado?
>John Hauck suggested National, but I haven't had a chance to call them
yet.
>Any
>other ideas?
"...cross your fingers, sacrifice a chicken and say 3 'Hail Mary's.'
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
I don't lube my control surface hinges at all. Somewhere, sometime (poor
memory again), I read something that advised not to use oil on 'exposed'
aluminum-to-steel 'bearing surfaces' (like a piano hinge). The reasoning
was that oil would trap and hold more dirt and would actually cause
faster wear than using nothing at all. I think it also recommended using
parafin on any aluminum-to-aluminum bearing surfaces but there aren't
any of those on a Kolb anyway. I could have just dreamed all this so I
inspect my hinges pretty good on every pre-flight, just in case...
I do use a spray called "LPS-3" on things like the tailwheel pivot and
rudder pedal hinges (steel-to-steel). LPS-3 is pretty thin when sprayed
but 'sets-up' to a thicker grease-like coating after a few minutes (kinda
like 'cosmoline' if you know what that is). Its $4 or 5 a can and there's
several other blends for different uses.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
My nephew, another friend and I formed a LLP (Limited liability
partnership) and let the partnership purchase the plane. My
understanding is that this will somewhat shield the the individuals and
the vulnerability would be the assets of the partnership which is the
plane and whatever else the individuals place into the partnership. Each
partner pays into the partnership based on an hourly fee to cover
maintenance and any other costs.
The same might be done with a LLC (Limited liability corp) for
individual owners. Talk to your attorney and get their advice. It may
be money well spent and cheaper than insurance.
(Netscape Mail Server v1.1) with SMTP id AAA106
Subject: | Weight and Bal.. |
I have a Question for you FIRESTAR owners. Using a 377 Rotax for the
powerplant..How large a person could this combination of plane/power
handle safely. I wonder if a fellow 6'4" and 230 pounds would have a
problem? I haven't bought the plane yet but I might soon. It is in
Ohio and I am in N.J. Larry Moore
owners.
Using a 377 Rotax for the powerplant..How large a person could this
combination
of plane/power handle safely. I wonder if a fellow 6'4" and
230
pounds would have a problem? I haven't bought the plane yet but I
might
soon. It is in Ohio and I am in N.J. Larry
Moore
Subject: | Re: Weight and Bal.. |
Larry,
I think I handle that question for you. I have an original FireStar with
a 377 Rotax that I've been flying for quite some time. The climb rate is
about 900/min with my weight of 200lbs. I am 5' 10" and my head is about
1" from the bottom of the wing when I have my helmet on. The only problem
you might have would be your height of 6' 4", but that depends on how
proportioned you are from head to toe. Much of the time I carry an extra
40lbs of fuel (ahead of the cg) so you can see my climb rate is very
adequate and so would yours. The builder has the option of rigging the
rudder pedals for his comfort and size. If he was a short guy, you may
want to consider re-rigging the rudder cables or possibly adding an
extension for your legs so that the rudder pedals would be more toward
the nose. This would be your only concern, because the 377 on the
original FireStar has power to spare.
Ralph Burlingame
Original FireStar
writes:
To me this is the most depressing subject of all WRT ultralights, and
because of that I've ignored the issue for the last few years. The
basic problem is that you may be trying to insure an illegal activity.
Obviously companies big enf to be in the insurance business don't have
convenient little "gray areas" such as those of us do who fly fat
ultralights. At best, people sign their name to an insurance contract
(the application) in which they state they are flying a FAR 103
compliant vehicle. People sign these because insurance is required
by their local airport. They can only hope that they never need to
file a claim, and if they do, that either nobody will know or contest
that their vehicle was overweight, or perhaps they might be able to
argue that the empty weight was in fact FAR 103 compliant.
This is the worst part about not having a reasonable certification
category for fat ultralights. Even with Federal law requiring open
airport access, no airport entity is stupid enf to not require
liability insurance.
Oddly, there is a tidy little advantage to a folding ultralight here.
Some airport policies, such as requirements for insurance, state that
they apply to airplanes kept at that airport. Keeping it at home
might wiggle you past this airport access snafu.
Paying ~$150 to appear legal to the local airport, and have some far out
chance of being covered if you needed it is a good deal, I guess. Still,
it is depressing (at best) to think about signing false statements, and
I myself prefer to just fly out of the back alleys. I keep a good
distance from all the expensive airplanes whenever I'm at real airports.
Sorry for such a gloomy outlook, but i think that it is accurate.
-Ben Ransom
While on the subject of ultralight insurance I would like to know if
there is any difference in insuring an experimental. Coverage available,
cost, etc. Also, does your homeowners cover your plane while your in the
building process?
Mike Watson,
China, ME
My American Family home insurance specifically states that it does not
cover airplanes either during construction or stored in the family home
garage. Ray from Woodbury
> building process?
> Mike Watson,
> China, ME
For my N numbered MK III, I got a quote in Nov 97 from Avemco for
Liability, 100,000. each person, 1,000,000.00 property, annual premium
of 433.00. To add 30,000.00 of Aircraft Damage (Excluding In Motion)
with a 200.00 deductable, Premium went to 784.00. At that time I had 41
hours in the plane, Dan had signed me off on the MK III and filled out
the EAA flight advisor all of which helped reduce the premium, and of
course I have a valid pilots licence and a current medical.
Terry
Thank,s to Cliff, Ralph and Timandjan for their suggestions about
gas drain.I think I will put a fuel valve between the 2 tanks.
I guess I lied last time saying it was the last time for winter flying as
the snow was almost all gone.
Today we had another snow storm. not a big one ( may be 4 inches) but good
enough for some more flying.
Thank,s again Lucien
Larry,
I have an original 377 Firestar and I agree with Ralph as far as it's
ability to carry weight. No problem with having enough power. You may
want to sit in an original Firestar before you travel to Ohio. I am 6'
and wear a helmet. The top of my helmet touches the gap seal unless I
slouch a little. At 6'4", you might be uncomfortable.
John Jung
http://www.execpc.com/~jrjung/
Thank's again Gary for the tip. I am still waiting on the bank for my
loan. Things are looking really good. I am glad that I found Glenn
Rink, who lives right up the road from me. If you recall from the
previous posts, he can build a Kolb with his eyes shut.
Good luck. Rut
>Date: Fri, 13 Mar 1998 19:45:14 -0500 (EST)
>From: Gary Thacker <gthacker(at)mciunix.mciu.k12.pa.us>
>To: rutledge fuller
>Subject: Re: Insurance
>Rutledge
>Sounds like you liked the FireStar in Florida. I have been reading
some
>of your posts. Hope it turns out well for ya. If you remember when I
>told you of the FireStar on Nerd World I too was lookin for one. I am
>also in the process of making arrangements to get the one I just looked
>at home.
>About insurance, I know not of what I seak but....... I read a post
not
>to long ago about some guy's on the list talkin about it. It sounded
>like your Ultralight better be ULTRALIGHT as per 103. Also I heard a
>price of $800 per year. Along with this was the not to binding
aggrement
>that the insurance company will pay off. Like I said just know what I
>heard on the net.
>Good luck
>Gary
>| Gary Thacker | gthacker(at)mciunix.mciu.k12.pa.us
>| Souderton Pa. |
>| | gthacker(at)wsd.k12.pa.us (work only)
priced
>> Get Your Private, Free Email at http://www.hotmail.com
From: | bobdoebler(at)juno.com (Robert L Doebler) |
Regarding Ultralight insurance:
I have a F/S II, registered as an experimental, it costs slightly less
then $100 for $100k liability insurance.
If you have a fat ultralight and fill out Avemco's application honestly,
they won't insure you. If you "fib" about the weight; that's insurance
fraud, that could leave you with no insurance when you need it, or
problems with the law. Neither option sounds like much fun......
So if you need insurance, go experimental, or make sure it's Far 103
legal-
build a firefly
Bob Doebler
Subject: | West Coast Fly-In Update |
The web site for the West Coast Fly-In is up on the net.
As for the vendors, clubs, and pilots who want me to add
information or make corrections, please shoot (or flame)
me some e-mail my way.
I have an info packet availible that I will mail for free
that covers everything from accomadations, wine tasting,
antique shops, area factoids, to whats hot in agriculture
out here on the central coast. :)
-Mark-
West Coast Fly-In '98 May 1-3
<http://www.tcsn.net/mswihart/ul/pruaflyin.htm>
updated: 3/15/98
<http://www.tcsn.net/mswihart/kolb.htm>
Paso Robles Ultralight Association
<http://www.tcsn.net/mswihart/prua.htm>
From: | "Ron Christensen" <SPECTRUMINTERNATIONAL(at)classic.msn.com> |
Hi Dennis:
It's just great that you understand that the hands of God are carrying you
safely through your experiences.
Ron Christensen
MK III 1/2
N313DR
Your wrote - - -
I am
Very Sincerely,
Someone asked, "What's a Laser?", a while back. Well, you could dig out
a July 1991 issue of Experimenter, or look here:
http://www.execpc.com/~jrjung/laser.jpg I have been playing with my new
Casio camera.
Sorry, juno users. There is always the library. :-)
John Jung
Original Firestar & Firestar II
<< I have a Question for you FIRESTAR owners. Using a 377 Rotax for the
powerplant..How large a person could this combination of plane/power handle
safely. I wonder if a fellow 6'4" and 230 pounds would have a problem? I
haven't bought the plane yet but I might soon. It is in Ohio and I am in N.J.
Larry Moore >>
Lauren, I am in Warren Ohio and let a 230 lber taxi my Firestar (447) and he
moved one inch and the plane tipped over on its nose and we had a big laugh!
No consideration was given to actually flying it though.................GeoR38
Well if you get your insurance policy out and read it, it probably
will tell you in one form or another.
I am amazed of the number of people who don't look past the front page
or even open the envelop it comes mailed in.
Most specifically they address other vehicles and aircraft, materials,
and parts. My boat parked in my yard was covered, but my motor cycle
stored in my garage wasn't.
My policy actually referenced aircraft and aircraft part were not
covered.
but you motor cycle isn't.
Sorry Charlie, not this year. You can purchase a policy from a
company like Avemco, but grab your shorts. I couldn't believe what
they wanted for a 10K to cover a kit sitting in my house. I could
have a 10K stereo system, or furniture not problem, it would be
covered under the contents clause, but not an aircraft kit. Who
defines aircraft and vehicle.
Apparently what happens in the industry is no company can hold total
liability for all loses so they sell portions of their risk. The
companies that buy these do not like airplanes or strange things as
baggage on the policy as they pose increased or unfamiliar risk.
This places more liability on the initial underwriter which they
usually will not assume.
I got into this when trying to insure my RV-6 kit while it was under
construction at my home. All I wanted was protection of the kit value
in the event of lost due to fire or storm. Other coverage I thought
was important was vandalism then theft. Often when they rob a house,
they will set it on fire in an attempt to cover their tracks or two
simply for spite vandelise things that look like may be valuable to
the occupant. That part concerns me.
Good luck, let us know how you fare on this topic.
Jerry Bidle
____________________________ Reply Separator _________________________________
Subject: Kolb-List: Insurance
Date: 3/14/98 2:31 PM
building process?
Mike Watson,
China, ME
From: | Wayne Welsh <flight(at)mail.on.rogers.wave.ca> |
Looking for Charlie Sharpe. I believe he is a member of this email
group. If your out there Charlie give me your address.
From: | "Geoff Thistlethwaite" <geoffthis(at)worldnet.att.net> |
I am building a Firestar 2 and would like to know which size BRS to get,
also any ideas or comments as to mounting would be very helpful
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
Hello kolb builders,
I unpacked and examined my wings (I have not covered them yet) after
moving from michigan to western wisconsin and found a small ding in the
wing spar... right in the area of the lift strut. It looks like the
moving van guys dropped a buckle from the straps or something onto it.
I made a sturdy chip board box and had the wings hanging in a sling but
I didnt put a top on it... Any ideas as to how to fix this. Would
putting a small fiberglass or carbon fiber patch on it be helpful, you
could still see through fiberglass and look for cracks. I am no
structural engineer but I think that a patch could work if I had someone
to tell me ho many plies to put on it.
Topher
Depending on how deep the "ding" is you can just use some emery cloth
and polish it out. Start with 200 grit and go to 400 grit then finish
with scotchbrite and only sand in the direction of the spar. The good
news is, it is on the top of the spar which is loaded in compression and
not in tension. There will be no way to check for cracks after the wing
is covered except to cut a hole in the top of the wing. If the "ding"
is so deep that you have to remove a lot of material to get to the
bottom of it, it would probably be best to ask a local aircraft
sheetmetal guy to take a look at it and recommend what to do. I do not
think putting a composite patch over it is the solution. My 2 cents
worth.
> From: Christopher John Armstrong [SMTP:tophera(at)centuryinter.net]
> Sent: Monday, March 16, 1998 9:51 AM
> To: psi(at)pivot.net
> Cc: kolb(at)intrig.com
> Subject: wing spar
> the
> but
> someone
> Topher
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
When you fly, you generally have lots of time to think about things.
I can't see spoiling that by always having to think about a polished
ding or patch on a very critical area. I guess by asking here you are
looking for the right way to do it, and all I'm saying is that i'd really
try to err on the conservative side here. The bit about watching for
cracks ignores the possibility of sudden, complete buckling which seems
more likely to me than slow progressive failure.
Some questions remain:
1. Does the moving company owe you for the damage?
2. What are the dimensions of the ding? (small is in the eye of
the beholder)
3. How much is a new spar?
4. What are your resale considerations?
-Ben Ransom
Topher
Reguarding nick/dent on spar: sounds like a question I would ask Dennis
Sauder at Kolb
Bob Doebler
Regarding BRS parachute: The BRS 750 (or whatever they call it now)
falls into the F/S II spects. As BRS had not designed a mount for the
F/SII when I ordered mine, 3 years ago, they said they were planning too.
Suggest you call BRS and ask for tech support. Their number is
612-457-7491 or e-mail BRSchute(at)AOL.com . They can give you the part
numbers for the mounting brackets. Although when ordering your chute, the
BRS dealer only needs to know your make and model, this is kind of a
backup to make sure they send you the right stuff.
There are many different thoughts on where the best place to mount the
chute is. I myself prefer above the gap-seal, just in front of the
engine. Just be aware of engine cooling. Good luck, have fun flying.
Bob Doebler
I would have an experienced Kolb builder take a look. What you have
could range from "forget it" to "real trouble". Patching and / or sanding
it out may make it look better but I doubt it will improve the integrity
of the structure. Cracking may be on the inside of the spar , that is the
convex side of the ding. This may be difficult to examine but not
necessarily impossible. Ray from Woodbury
writes:
>... a small ding in the
the
>it.
Just to be clear, the ding is in the spar (5" tube) and not the
leading-edge (1.5" tube) correct?
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
> Thanks
Geoff,
My Firestar II has a BRS soft pack 750# chute located in the gap
seal. It was designed for the Firestar I/II by BRS. I like having the
chute in that location. I changed spacers on the installation in order
to not lose head room and allow an aluminum gap seal to wrap fully under
the chute. My own one piece design for the gap seal was used. I have
digital pictures of the installation it they will help.
John Jung
Subject: | FW: FW: wing spar |
I believe he would need an inspection port in the top of the wing to
look at a ding in the top of the spar. I don't know if it is OK to put
these snap in covers in the top of the wing. I guess he could put one
in the bottom and then use 2 mirrors to view the top of the spar.
> From: Cavuontop [SMTP:Cavuontop(at)aol.com]
> Sent: Monday, March 16, 1998 9:02 AM
> To: jason(at)sluggo.acuityinc.com
> Subject: Re: FW: wing spar
> << There will be no way to check for cracks after the wing
> is covered except to cut a hole in the top of the wing. >>
> Not so. The descripton of the covering process in the manual does
> not
> decsribe it but there is a way to put inspection holes in the bottom
> surface
> of the wing that you can cut open when you need to and then put on a
> simple
> cover when you are done looking. See the stitts book for a
> description. I
> put a whole mess of these little rings in my wing. You never know
> when you
> migh suspect some serious problem which turns out to be nothing and
> you will
> have saved youself a major recovering job.
Subject: | CB Communication |
This probably has been discussed before. I am interested in two-way
communication between two or more Kolbs in close proximity while in
flight together. Is it legal to use Citizen Band? Is it feasible? I
notice in the SkySports catalog they advertise the following.....Patch
cord-Radio Shack CB COM927....$79. Nothing about the transciever. Radio
Shack has an under the car dash transceiver unit that incorporates an
optional weather channel with plug-in for mike, headset and antenna. It
operates off 12 volts DC. It would appear to me that the Comtronics
helmet and headset unit would be compatible. I would appreciate comments
from those in the know. I have no experience in this area. Ray from
Woodbury
Subject: | Re: CB Communication |
writes:
Yes, it is feasible. Legal? ...Uh, I hope so, I've had one in the Flyer
for years. Around here, several ULers use CBs on channel 1. Its a very
handy thing to have, I can usually talk to another airborne UL as much as
40 miles away. Air to ground is nice too, I can talk to the wife when
she is running "ground crew" and we're on the way to or from a fly-in.
There can be a problem trying to use a CB with a headset tho. Usually,
the impedence of the mic on a headset will not match what the CB needs.
The easiest fix is just to use the hand mic on the CB (also helps you
keep track of which radio you're on ..most FAA types don't go for the,
"breaker, breaker", "good buddy", or "10-4" type lingo). The output from
the CB can usually go directly to the speakers of the headset or through
an input jack of a com-box.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
I was cleaning thru a directory and found a nostalgic message
left over from some chat between John Hanson and I last summer.
Thought I'd pass it along...
> I once was honered by the request of my boss to entertain for his prenupt
> party. I flew next to it throwing streamers made of crate paper rolled
> up on a small dowel for weight. Worked pretty nicely -- several 200
> foot streamers of red, purple, etc. One caught on the vert stab and I
> carried it for several minutes, not even knowing it. I also was given a
> box of 500 paper helicopters (made by others out of half sheets of paper
> folded to flutter down when tossed, generally intended to be done by
> kids in their backyards.) Each of these had something written on it for
> the party below, and just one something to do with getting a kiss from
> either the bride or groom (choice of recipient :-) ). Anyway, the sight
> of my tossing these was even better from the ground than the streamers as
> I'm told it was a sudden big burst of color out of the plane. I darn
> near lost the box i held them in, but clutched it tight for fear of
> loosing it to the prop. I finished off by zooming in low over the
> empty lot near their party, with all the kids running around grabbing
> the paper helicopters. I poured 3-4 pounds of rice overboard and it
> rained down on some of them. They loved it and I was Flying Stud #1 at
> the wedding next night! Even the new 70 yr old conservative Chinese
> in-laws thought it was cool. I found grains of rice in my plane for
> weeks afterward.
> -Ben
Thanks Mick........ Could you be more specific as to your CB transceiver,
brand etc. Ray
From: | Jhann Gestur Jhannsson <johann.g(at)centrum.is> |
> Thanks
Hi Geoff, and kolb flyers,
I just built a Firestar II and I installed a VLS 750 in the gap between
the
wings. I preferred this type of box do to less drag on my airframe.
BRS inc. do have a mounting hardware for the Firestar for this place of
installation. I made some changes to forward fastener. A "S" shaped
hook
is bolt under the VLS box in the front and hooks under the steel spar,
where
the wing is connected to the cage. I welded a 2" extension to the "S"
shaped
hook and drilled an additional hole in the VLS box, which is now bolted
in two
places instead of one before.
The reason for this change, was to move the VLS box forward away from
the engine.
I am using the Rotax 503 dcdi engine, and the space between engine and
rocket for
the VLS is approx. 3 1/2".
On the rear mounting, I added some shims, to level the VLS box.
I did send some pictures to BRS, to get their approval for the changes I
made.
The release handle is positioned on the left, beside the pilot's seat.
For the gap seal, I used the nylon gap seal from Kolb, with the velcro.
Some minor changes were here. I cut approx. 3" of the bottom end,
because the gap
seal does not extend as far back on the top as it should, due to the VLS
box.
This mounting is easy and works great.
I flew my Firestar last week on a frozen lake, close to Keflavik
airport, and the
temp. was around 20 deg F.
I had just completed the full enclosure, the day before, and I did not
notice
the cold air that chilling day. The winds were calm, sunny and not a
single worry
in the world except flying my ultralight safely. (Still learning after
only 3 hours
flying and enjoying my Kolb Firestar). The only thing I noticed during
the flight,
was the mid range temp got a bit high, so I need to move the clip on the
needle
to the lower position (richer fuel mixture), and maybee increase the
prop pitch.
Any commtents would be appreaciated if this is an incorrect solution.
After a long winter weather and the only thing close to flying, is when
reading
the story's from the flyers on this mailing list, you tend to get over
excited about
the few days you get to fly during the winter time in Iceland.
I hope the installation idea will help.
Best regards, and thank you for a great list.
Jhann G.
Iceland.
writes:
>transceiver, brand etc. Ray
Mine is a very compact Radio Shack model that's been out-of-production
for a long time. Fortunately, an identical radio came with my C2 but
doesn't go with it!
Most newer compact CBs have up/down buttons for channel selection. Even
if there's a knob, it probably just deflects to the right or left to
change channels then returns to center. The problem is that when the
power is turned off, the radio goes to channel 9 which is supposed to be
for emergencies only. Many times some other pilot has said, "what channel
were you guys on? I was hollerin' like mad and nobody would talk to me!"
only to be embarassed when we look in his plane and see the red neon "9"
on the channel display.
Any CB that works on the ground will work fantastic in your UL, provided
you can get a low SWR with the antenna installation. I bought my radio in
a garage sale for $5. I'd look for one with a rotating channel knob.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
Chris,
If it makes you feel any better, the guy I fly with has extra drilled
holes on the bottom of his FireStar wing spar at the drag strut plate. He
bought his 1985 FS built and I know the history of this plane. It has
been wrecked twice, seriously. My friend has removed the covering and
inspected the workmanship. It isn't perfect. Those extra holes are
disturbing, but I told him to keep an eye on the top of the fabric. If
the spar were to ever weaken, it would start to bend and the loose fabric
would be the first tell-tale sign of it. You should see this plane. It's
a beauty from the outside. We both are planning a long summer of flying.
I really don't think there is much to worry about. Remember, the chomaly
steel H-section is also installed there. It would take a lot of drilled
holes/dents to really weaken that spar.
I dropped a rachet on my fuselage tube when changing my gearbox oil
(dumb, I know). I put a nice ding in the tube. I don't worry, because the
H-section is also installed in that spot too.
I wouldn't do anything to it except add an inspection hole in that area
where you can insert a dental mirror to look at it occasionally.
Ralph Burlingame
Original FireStar
writes:
>the
>but
>someone
>Topher
>-Mick Fine
If the guy using the CB lingo has a transponder, the controller will
take a subtle revenge.
In the aircraft data block, which the computer generates and tags
the aircraft with, you always have the callsign, and the airspeed. If the
airplane has mode-C, you have an altitude readout.
There is also a function called "scratch-pad". This allows the
controller to make notations like: "HXA" (slow experimental airplane),
"C172" (chickenhawk), "PA28" (cherokee), etc.
If you use CB lingo, your scratch-pad note may say; "RDNK"
(redneck), "JERK", "DODO", etc. This warns the other controllers of what
they will have to deal with...
Enjoy.
Richard Pike
MKIII N420P (42oldpoops)
>Woodbury
>I just installed a cb and a aircraft radio in my FS II. I found a antenna
at Radio Shack that was designed to mount on the back of the unit. I liked
it because it had a 90 bent into it so that I could mount it to a plate that
I installed on the bottom of the cage under the seat. Cost 9.95, they also
have a panel mount so you can use a short rg 58 cord to it and not throw off
your SWR. I got a Y phono plug and have both my Delco radio and the CB
patched into my headset. It works well with one exception and that is the
mike picks up all the engine noise and about the only way that anyone can
understand me is for me to idle back to 4000 rpms. What I need to do is make
a patch cord tied to a two position switch that will allow me to use my
noise cancelling mike on the headset. One way to Delco the other to CB. I
picked up a Midway CB that measures one X 5 X 6 and has a ear phone plug in
the back. On sale for 29.00
Larry
Subject: | RE: CB Communication |
Hi Ray;
Once upon a time, there were 3 of us flying UL "airplanes" and we always
communicated together in flight using hand held FM business band radios. Of
course, we couldn't/didn't fly into "real" airports. We had the headset and
boom mike in our headset cabled to a connector that plugged into the radio.
It worked great. I once used a CB radio the same way. The important
consideration is the ability to connect your headset/microphone to the radio.
Ron Christensen
MK III 1/2
N313DR
From: owner-kolb(at)intrig.com on behalf of Raymond L Lujon
Sent: Monday, March 16, 1998 9:39 AM
Subject: Kolb-List: CB Communication
Woodbury
kolb(at)intrig.com
Hi Frank:
Glad to hear you have your dual controls finished ! ! Are you satisfied
with the results??
Ron Christensen
MK III 1/2
N313DR
From: owner-kolb(at)intrig.com on behalf of Marino, Frank J (Youngstown ARB)
Sent: Thursday, March 12, 1998 11:33 AM
Subject: Kolb-List: RE: Flight Characteristics
FRANK J. MARINO
>Dear Henry,
>More seriously:
>but
>right
>superior.
>Challenger down.
>lot of airplanes.
>Hope this helps!
>Dennis Souder
>Pres Kolb Aircraft
Subject: | wing spar ding details |
Thanks Ralph and all for the ideas about my spar.
The ding is on the top of the spar about an inch forward and 1.5 inches
inboard of the bolt that holds the lift strut bracket on. It is less
then 1/4 by 1/8 inch abrasion, and there is a just barely perceptable
dent around the abrasion that is ~3/8 inch around. The very middle of
the dent is ~1/16 inch deep. Being so close the the steel inside the
wing I would figure that the load is being carried by the steel there,
but what do I know?
I will take a picture of it and zap it too Dennis and see what he
thinks. I havent heard of carbon and aluminum corosion problems, I
would probably go with s-glass anyway cause you can see through it. I
had planned inspection ports in this area anyway because it is the most
likely place for trouble on the wing I think.
Topher
From: | "Wayland, William C." <wcw2573(at)eagle.sbeach.navy.mil> |
Subject: | FireFly Stick Forces |
After buying a FireFly from its original owner / builder I asked my friend
Dave to inspect and test fly the FF. Dave is an ultralight instructor, GA
pilot, and a jet engine mechanic with lots of flying experience. This was
the first Kolb he had an opportunity to fly and he really put it through its
paces. He flew it for 1 1/2 hours and made about 12 landings. His
conclusion was that it was a great UL. He warned me that it was rather
close coupled and that coordinated turns would take some learning given my
previous experience being mostly in a Hurricane.
He did find one thing he did not like, which I believe applies only to the
FireFly with its VERY large flaperons. The control stick forces to move the
flaperons were very high, particularly when rolling out of a turn. The
original owner, Tom, had shortened the stick height above the pivot point
from its original 15 to 13 inches to facilitate getting in and out of the
cockpit. When I called Tom on this point he said that his modification had
not increased the forces noticeably, and yes they are high. After flying
the FF myself for 3 1/2 hrs I decided that, for me at least, the stick
needed to be longer, much longer.
I bought some one inch OD aluminum tubing that was a close slip over fit
with top of the stick. Slid it over the stick top and fixed it in place
with epoxy and two CRES pop rivets. Finished it off with white heat shrink
tubing (to match the white paint job) and a slip over white plastic top cap.
The stick top is now 18 inches above the pivot point. I love what this has
done to reduce the stick forces and don't find that this has made getting in
and out much harder.
Chris W
Chris Wayland
DSN 873-7111
(562) 626-7111
(310) 987-8504 Pager
>Date: Tue, 17 Mar 1998 10:03:25
>To: "Ron Christensen"
>From: Kim Steiner <steiner(at)spreda.sk.ca>
>Subject: RE: CB Communication
>>Woodbury
There is a lot of information on the web, just type "cb radio" in your
favorite search engine. I had the same questions that you have about a year
ago when I first installed my CB in my Mark 111. I posted a question about
CB's on Dejay news and received some excillent replyes from CB enthusiasts.
Some of the tricks that I learned were:
- Use a centre loaded or a fiberglass aireal about 3 or more feet long.
- Mount it about one foot in front of the vertical stabalizer on the tail
tube.
- Use 22 feet of good quality cable to connect your aireal to the radio,
Excessive cable should not be placed in a round loop. Roll it up and tye
it together in the middle so that it kind of looks like a figure 8.
Excessive noise from ignition wires can be reduced by using shielded cabe
for your kill switch, Radio Shack sells microphone cabe that is sheilded
and is supposed to work ok (I have not tryed it).
- Keep kill switch wires away form all cb wires.
- Ground your cb to the Kolb frame with a short heavy wire.
- Connect your cb directly to your battery.
- Tune your arial.
- Use the external speaker jack on your cb to feed your headset, you will
have to install a resistor to lower the volume of your headset, your
headset will be very loud without one and it may blow if the cb volume
is turned up. Try a 1000 ohm resistor and go up or down from there to get
the volume right.
- I just use the cb microphone for transmissions.
I am an amature when it comes to cb operation. I received the above
information from a variety of sources. If someone finds errors whith the
above info please reply back to the list.
Brian "Kim" Steiner
Saskatchewan, Canada
BME
writes:
>radio,
>tye
This argument is to HAM's and CB'ers what "crow-hopping" is to UL'ers,
you'll find good arguments for both sides.
The theory behind using a certain length of coax is that for a given
frequency and antenna line resistance, the cable will be "harmonically
balanced" (not to be confused with the harmonic balancer on your Chevy).
For the guy in his basement trying to talk to Singapore, this might make
a very small improvement but (IMHO) in an UL (or car for that matter),
carrying the extra weight of a coil of coax is just not worth it. Run the
coax as needed then leave an extra 8 or 10 inches at both ends in case
you need to replace a connector or two in the future (cable breaks
usually happen right at the connectors).
Just happens I use a 3' center loaded fiberglass whip on the Flyer. The
stainless wire "stinger" is adjustable (slides in or out about 3/8") to
set the SWR. Its mounted on the boom tube (overhead on the Flyer) just
behind the wings. The C2 has a steel center load antenna about 2' long
also with adjustable whip. Its mounted between the wings at the front
spar. Both rigs have a low SWR and work great. I'll probably use the
radio and antenna off the C2 on the Twinstar, I don't think the extra
length antenna makes much difference either.
-Mick Fine
Tulsa, Oklahoma
mefine1(at)juno.com
To Whomever
You asked me to respond to you, so here goes.
You mentioned "you just don't get it do you", regarding putting "kolb"
in my letter for your search engine.
First, my apologize for not always doing so. My flying buddy died a
short time ago and I guess I've not been as diligent as I should have
been, when
I input to this site.
However, wouldn't a polite reminder, rather than a sarcastic reply be
more in order? Speaking of sarcasm, I have always found that differences
of opinion and constructive criticism have a way of stimulating dialog,
while sarcasm has a tensity to reduce it.
Case in point, in talking to two builders in the last month, they
mentioned that they would like to input data to the site, but "some of
those guys are really vicious".
So if we are really trying to encourage dissemination of information
on
Kolb aircraft lets lighten up. Otherwise we may just be shooting
ourselves in the foot!
Again, just my 2-cents worth:
I'm outta here
Bob Doebler
I am usually pretty good about following what is being talked about on
this group, but this e-mail total lost me. I would like to add that
this is the most civil and generous bunch of people I have ever seen on
a e-mail group, the noise ratio is extremely low.
> From: bobdoebler(at)juno.com [SMTP:bobdoebler(at)juno.com]
> Sent: Tuesday, March 17, 1998 2:35 PM
> Subject: Kolb
> To Whomever
> "kolb"
> been, when
> differences
> dialog,
> information
> on
February 26, 1998 - March 17, 1998
Kolb-Archive.digest.vol-am
