Kolb-Archive.digest.vol-ap
April 23, 1998 - May 14, 1998
.007", the rear .003" before adjustment.
Ralph Burlingame
Original FireStar
writes:
>I'm getting closer with my Original Firestar. The engine has never
>been run, and I'm trying to decide if I should go to the expense of
>conversion to CDI. I talked to Airscrew Performance, in Glendale, AZ,
>and they tell me that their CDI conversion idles at zero degrees
>advance and advances to 25-degrees at full throttle. This, they
>claim, gives a very smooth idle as well as the power that goes along
>with advanced ignition, plus never having to adjust points and timing
>forever. Their price is $275 plus freight. The mod must be done by
>them, because it cannot be done by the owner (they don't sell parts or
>kits).
>My question to the list is: are you aware of other companies that do
>this mod or sell kits for the mod? Also, are their prices and features
>comparable to what Airscrew claims for their's? A couple of guys on
>this list have stated that the mod is really not necessary because the
>point ignition on the 377 (and all other older Rotax engines) is
>pretty good, not giving much trouble, and the adjustment isn't too
>tough.
>Ron Carroll
>Original Firestar
>Oregon
Mark,
I bought one of these trailers years ago when I built my original
FireStar. It's a
4'x8' without a tiltable bed. I trailer everytime I fly because I store
it in the garage. I added a 3/4" plywood floor on the bed with wide slots
cut in the front for the FS wheels (It's nose forward). I have another
square hole cut beside the slots to wrap tiedowns around the gear legs of
the plane and through the trailer bed (very secure). I made a pedestal
board with a cradle cut for the fuse tube at the very rear. I lined it
with a piece of rug to protect the tube. The bottom of the pedestal is
hinged with one from a barn-door (a little over-design, but you want it
strong). The wings do hang over by many feet. Underneath the rear of the
trailer bed reinforce it with 2x4. When loading and unloading, the rear
of the trailer must be contacting the ground with a prop under the tongue
and the wheels chocked. The trailer also folds in half and is stored in
this single car garage with the plane. This trailer is made in Taiwan,
but it's now 11 years old. I travel 6 miles to a private strip then I
unload and set up. It serves me well for year 'round flying. The nice
part about this trailer is that it is small and does not take up much
space when folded up.
For a real x-country open trailer talk to Ray Lujon on the Kolb list.
It's the best!
Ralph Burlingame
Original FireStar
writes:
>I'm thinking about buying a utility trailer at Lowe's or Menard's and
>am
>wondering if it could be modified later to trailer a Mark III. The
>available sizes are 4.3' x 8', 5' x 8', and 5.3' x 8' with all the
>beds
>being "tiltable". Obviously, the trailer would have to be lengthened
>to
>accomodate a Kolb. Also I would only be trailering short distances (<
>5
>miles). Has anyone ever tried this?
>Hope to purchase KIT #1 of a Mark III at Oshkosh this summer if Dennis
>will give me a good deal (hope he's listening).
>Mark Rinehart
>"former AF Instructor Pilot and Mark III BFI wanna-be"
Subject: | Re: Propeller Thrust and Trailers |
> Hirth 2704 max RPM 5200, max torque 4750, propped with Warp three
> blade set at 18 degrees pitch, cruising at 60-65 at 3600 RPM,
> Hirth G27 gearbox at 2.55:1. Prop RPM 1400.
> What is the rated HP at your cruise setting and what is your prop
> diameter? It would be interesting to see how eff your warp drive prop
> is.
Probably not that efficient. Just a big engine with good torque.
625cc, 66 in Warp taper blade. The charts say 25 hp at 3600 RPM but
who knows if that's right...torque is 40 lb/ft at 3600 RPM....the
only thing that looks good from the charts is that the fuel
consumption is dead on. The Hirth fuel graphs are made with the
engine loaded to make a specific RPM at full throttle and then load
is added, still at full throttle, and another fuel flow reading is
taken. They intimate I should be getting better partial throttle fuel
rates than I am (3.5 gph) but doesn't look that way.
> I would like to here more about the hirth set up, I have heard so many
> rumours about hirths that it would be nice to hear how a user likes it.
> I still have to choose which of these "engines" to use.
Bottom line in using a Hirth....if you don't want to experiment with
engine/muffler mountings and would prefer a stock set-up, go with a
Rotax, a fine engine. I like mine exceedingly well despite the
rumblings of those who hate them. No ill has come to pass in 120 hrs
of use. I run 100:1 oil, and have from the start. EGT's are kept
high (1100 or better at cruise), CHTs are 320 at cruise.
JB
Subject: | Re: (Fwd) Re: Re[2]: MK-II info. - Brand of Oil Mark |
Prefers
>Cavu had enquired about the selection of oil and de-carbon cycles. My
>reply follows......
> Along with this, I advocate 100:1 oils. Why
>folks are reluctant to use them is anyone's guess.
Great info, makes good sense, thanks. One the thing about 100:1
oils, broke in my Rotax 277 on Amsoil at 50:1, then gradually "weaned" it
back to 100:1. It ran fine, but it rattled. None of us could find any
problems, but it was loose. After we changed the ratio back to 50:1 it got
quiet, and had close to 600 trouble free hours when I sold it.
Question: is it possible that the 50:1 oil ratio is necessary to
attain an adaquite film thickness to keep the bearings within clearance
tolerance?
Richard Pike
MKIII N420P (42oldpoops)
Subject: | Re: Rotax 377 CDI conversion |
>conversion to CDI.
> A couple of guys on
>tough.
>Ron Carroll
>Original Firestar
>Oregon
CDI is great when it works. Points are great when they work. When
points start to go bad, they give ample warning. When CDI goes bad, IMHO
(and experience), you get minimal warning. So I guess it all boils down to...
Do you like surprises? :}
Richard Pike
Subject: | Lubrication education...... |
For those so inclined, here is a tech site worth looking at
concerning oils....
http://www.lubrizol.com/referencelibrary/lubtheory/index.htm
Jim Baker
Pres, USUA Club 104
Frontier Ultralight Aviators
Oklahoma City
From: | "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM> |
Subject: | lubrication experience |
I have used a few different oils in 2-strokes over the years: Penzoil, Honda
stock oil, Yamalube2, Stihl, others... For six years I owned/operated a water-
cooled 250 on an ATV. This machine saw the hardest use you can imagine, even
exceeding the abuse the average chainsaw engine endures. It was asked to run
to competition-levels in 100 degrees F, down to 0 degrees, on ice, in mud, in
rain, crossing rivers submerged, in the sand dunes, and all the while just as
hard as it can be ridden. Many modifications were made to the machine to keep
up with the weaknesses that surfaced. After four years (probably 350 hours),
the compression was measured and engine (top end only) was reworked as
preventative maintenance. Actually the Shop manual requested piston
replacement after 30 hours of "racing use", but who reads those things anyway!?
The compression measured 150 lbs. Before the overhaul, and after break-in of
the new piston/rings/cylinder bored over .010" (same compression!). This
taught me don't use compression readings to judge wear. There was minimal
wear, enough to require the slighly oversized piston after boring and ball-
honing for plateau finish. It also taught me I was definitely using the
correct oil!
This engine was started out new on Honda 2-stroke oil. I bought a case and
returned most of it for credit, it was like waste oil, thick and it burned
like tar, lots of build-up and fouled plugs. Two of us switched to a popular
SYTHETIC "racing" 2-stroke oil sold at the moto-cross tracks and mail order
for about 20 dollars / gallon at that time. We used a 40:1 mix. The experience
with that synthetic oil taught me I'd never go back. I started using it in
everthing (chainsaw, weedwacker, lawnmower, margurita-blender). It has kept
my engines protected and clean for eight years.
I am sorry to report I had to say goodbye to my favorite oil (Bel-Ray MC-1+),
because the price has risen to around 36 dollars / gallon. I have started
using AMSOIL now, also in all the same toys. I have gotten around the high
cost of synthetics by establishing a commercial account with Amsoil, and
ordering it direct (NO, I AM NOT A DEALER), which gets me the lowest cost
available (for what I believe is the highest quality line of lubricants
available).
This was not meant to be a sales pitch, and I agree with whoever said:
"Use what you are comfortable with"
and I would add:
"Don't forget that air filter!!!"
because assuming clean fuel+oil, the only other path into your valued Rotax
combustion chamber is the air passing thru the carb. Keep it clean and you
are buying hundreds of hours of safety.
jim
I have been using Amsoil at about 90:1 ratio for 9 years on 5
different Rotaxes, a 277, (2)377's, a 447 and a 503. I have had no
problems that could have been related to oil. My props and tails do not
get an oil film, but I still need to de-carbon.
John Jung
Firestar For Sale
http://www.execpc.com/~jrjung/
From: | "Rinehart, Mark W." <Mark.W.Rinehart(at)Allison.com> |
What's the width between the main wheels of a Mark III?
Mark Rinehart
System Performance and Controls
Allison Engine Company
Ph: (317) 230-2567
Fax: (317) 230-3691
Email: Mark.W.Rinehart(at)Allison.com
Richard,
You make a very good point here. I like my 503 with dual CDI, but I
don't think that I would give up a single point ignition for a single
CDI.
John Jung
> Richard Pike
Subject: | Trailers, width of Mkiii |
OUTSIDE track width is 78", assuming no extra bends in your gear legs. The
Wheels are 6 inches wide, plus an inch for hyd brakes if present. So inside
might be around 64-66". The reason I mention the gear legs issue is you may
wish to make your trailer usable even on that fateful day you need to haul
home your plane after bending the legs (wish I had done that, damm taillites).
jim
In a message dated 4/24/98 5:49:24 AM Pacific Daylight Time,
Mark.W.Rinehart(at)Allison.com writes:
<< What's the width between the main wheels of a Mark III?
I set my gear lega a little wide. But from the outside edge of the tires it
is 6'6". That could be shortened if youfelt like it.
Subject: | Re: Firestar II vs Original Firestar |
Here is an update on the progress of testing my new Firestar II.
Previously I had said that it didn't seem to be as good as my original
Firestar. Well it is a lot better now that I let the throttle open all
the way. I can't believe that after 10 years of maintaining my own
planes, I made a beginner type mistake on the throttle. Now it is
outperforming the 377 and using only slightly over 2 gph.
I managed to fly in some smooth air and check my airspeeds. The II
stalls at 38 mph true which is 7 mph faster than my original. Does
anyone know how much the stall speed can be reduced by lowering the
ailerons?
The brakes are working better. For some reason, new Kolb drum brakes
seem to work better after they get used for a while. This is my second
set, and neither work good at first.
The biggest problem is noise. I either need better ear protection or
I have to find a way to reduce the noise. I even tried the same Warp
Drive prop that was quiet on the other plane and it was still to loud.
Someone suggested a intake silencer. Any other ideas for noise
reduction? Which are the most significant?
John Jung
SE Wisconsin
Firestar II N6163J
Original Firestar
From: | "merle hargis" <merlepilar(at)worldnet.att.net> |
Subject: | maintenance & repair |
I am looking for a good maintenance & repair manual for Rotax 447 engine
Any suggestions?
Merle from Orlando
>Mark Rinehart
>Ph: (317) 230-2567
>Fax: (317) 230-3691
The width between the wheels of the one in my garage (measured 2" up
from the floor) is 64 1/2".
Richard Pike
>Mark Rinehart
>Ph: (317) 230-2567
>Fax: (317) 230-3691
CORRECTION!!!!! The distance between the wheels of my MKIII:
CENTERLINE to CENTERLINE is 70". My previous post of 64 1/2" is the width
BETWEEN the wheels, inside to inside, but after thinking it over,
reconsidered that the answer I gave was not to the question you asked...?
Hope this makes sense.
Richard Pike
Subject: | Re: maintenance & repair |
Merle,
The CPS (California Power Systems) catalog works for me.
John Jung
> Any suggestions?
> Thanks
> Merle from Orlando
>Any suggestions?
>Thanks
>Merle from Orlando
> The CPS catalog, the LEAF catalog, and some good free stuff at
http://www.ultralightnews.com
Richard Pike
Hi Jim,
The CHT's are 210 degr and the EGT's are 1125-1175 degr @5000rpm cruise,
with an average 75 degr outside temperature in Central California.
Frank R
> I was surprised to
> find only light carbon build up on the pistons and some on the top of the
> trapezoid rings that I removed with a razorblade and vacuum. The cylinder
> head was completely clean and only needed wiping off. At this rate I hope
> to get 300 hrs again before a complete decarbonizing service is required.
> Needless to say that I will continue to use AV-2.
Now, tell us what your EGT's are at cruise.
JB
Less rpm would be quieter, but the 503 powered Firestar II seems to
need 5000 rpm to keep me 15 mph over stall, while the original Firestar
377 flys at 23 over stall at 4500 rpm. Flying too close to stall make me
more uncomfortable than the noise. If I can't solve this problem, I'll
sell the new plane and keep the old.
John Jung
>Richard Pike wrote:
> > I tried a 2-blade Warp Drive prop on the MKIII and it was MUCH
> noisier than the Ivo. (a friend that lives a mile away commented that it
> sounded different and much louder on the day I was testing and wanted to
> know if something was wrong!) Perhaps if I had tried a 3-blade it would have
> been quieter?
> The next best way to reduce noise is run the engine slower.
> (Probably not what you wanted to hear)
> Richard Pike
I like the dual CDI on my 503 is easy starting, idles well, and can
decend at reduced power settings without loading up. I have flown with a
277, two 377's, and a 447, and while they all were good runners, none of
them ran as nice as the 503 Dual Ignition does. And it's not burning
much fuel either.
John Jung
Subject: | Re[2]: oil - What's Seafoam Treatment |
OK, what's the Seafoam treatment?
______________________________ Reply Separator _________________________________
Subject: Kolb-List: Re: oil
Date: 4/23/98 5:49 PM
Richard and all,
I think you guys should check into using Klotz, the all-synthetic oil.
There is a guy that has been using it on his Rotax 377 with prem unleaded
gas and has put well over 300 hrs on it before having it checked. The
teardown revealed very little wear and it was clean. I switched over and
my plugs are the cleanest I've ever seen. I don't bother to even check
them anymore. Using this and the Seafoam treatment should make it very
reliable. I'll keep you posted.
Ralph Burlingame
Original FireStar
writes:
>Out here in the Hooterville Mountains of East Tennessee, most
>all of us have been using Phillips Injex 2-stroke oil for a long time,
no
>seizures, but the rings need cleaning every hundred hours.
>The Phillips distributor has moved out of town, and I was just
>leaving to go buy a case of Pennzoil when here comes this info that it
>also gunks up the rings.
>Once again, it looks like experience may be the best (and only
>reliable) teacher.
>P.S. Can anybody tell me if the MKIII wheels and bearings are
>the same as the Firestar wheels and bearings?
> Richard Pike
Subject: | Re[4]: MK-II info. - Brand of Oil Mark Prefers |
Here's my 2 cents based upon observation only. I lack true experience
comfortable with 2-stokes.
Mark runs his engines at high RPMs. He indicated most people try to
run the Rotax at to low of RPM's and lug/load down the engines. Said
they'll run solid forever at the higher end using good oil and they
stay clean at the high RPM.
He claims he's gets over 1000 hours on his engines without doing
decarboning or other maintenance. Told me about the one seizure he
had (or at least he admits to). Happened on takeoff from a low
altitude airport after rejetting for better performance at high
altitude. Mark typically flies at 12.5K cross country. Claimed even
then it didn't hurt the engine. Said the oil he uses saved it.
Inspected it, rejetted and went on. Never done anything to the engine
after that. If you ever seen the terrain he flies over at his home
base, you put a lot of trust in the engine. There just isn't any good
place to land.
What I seen is keep the RPM's up, use a good quality oil, and keep the
EGT temps up but not so high to cook the engine. The good oil does it
job lubing the engine and the higher EGT temps burn it out and eject
it. He says don't pamper them.
Jerry
Subject: Kolb-List: Re: Re[2]: MK-II info. - Brand of Oil Mark Prefers
Date: 4/23/98 8:29 AM
In a message dated 4/23/98 5:56:03 AM Pacific Daylight Time,
jerryb(at)jmd.ods.com writes:
<< My conversations directly with Mark Brierle indicate just the opposite
regarding the use of Pennzoil. I also have a ThunderGull kit so I
have personally talked to Mark just a few times.
I will gladly stand corrected on the pennzoil point. I have heard from a
number of sources that Brierly runs 503s well beyond the 300 hour tbo
indicated in the manuals. I've also heard from a number of sources that he is
a very smart guy. I'm just too chicken to do anything other than what the
manual says. I have talked with Phil Lockwood about the 150 hour decarbon.
As I recall he wanted something like $150.00 for the service and said that he
thought it made alot of sense not only to check the rings but to do a general
inspection. I think there is some freeplay in the reduction drive that should
be looked at too. Anyway, given that I have a friend who recently paid
$100.00 just to have the battery replaced in his cherokee 6 (he supplied the
battery himself) having a factory authorised guy look your 503 engine over for
that kind of money seems like a good deal. I think we all recognise that 2
strokes are different than lycomings.
I would be very interested in the experiences that other folks in the group
have had with varying from the factory recomended service regime. The problem
with this sort of discussion is that for every guy I talk to who says he uses
X brand of oil and this gas and he's got 500 hours with cylinder walls that
look like new and spotless rings, I run into another guy who says he was using
the same stuff and he seized after 50 hours or even worse, seized during the
break-in. My brother used to talk about taking the 0-360 in his Cardinal to
2500 hours. 500 beyond tbo. Then he had a kid. Just because there are some
lucky folks out there whose engines run great doesn't mean its right for the
rest of us. When I drop my toast in the morning it always lands buttered side
down. I try to fly with that in mind.
writes:
<< always read any where from 1 to 10 knots difference and we have 4 pitot
tubes and 2 static ports the pilot uses what he observes on his airspeed
indicator and this is in aircraft that cost about $37,000,000. This is
the same with the altimeter, three of these also. The bottom line is use
what you see on your aircraft and mark it. The only time airspeed is
important is on take off and landing, if you know what speed your Kolb
stalls at thats important.
FRANK J. MARINO
Chief Loadmaster 773 AS >>
Good thread Frank.............I gotta get at least one ASI....know any source
for me?.....GeoR38
Eugene Zimmerman wrote:
snip
> >John Jung
> >SE Wisconsin
> >Firestar II N6163J
> >Original Firestar
> You might try the prop extention, or spacer to set the prop farther from
> the TE
> of the wing. I beleive you can order them from Kolb or your prop
> supplier.Most of the noise is the prop noise. Ever notice how quiet some
> tracter props are? They turn in clean air with no near by air frame members.
> My quess is that your 377 had more prop clearance to the trailing edge.
> Check it out and let us know.
> EZ
Thanks, Eugene. That is one variable that I was forgetting. I have
an extension on the IVO and with the right length prop bolts, I could
test the extension on the Warp. I'll report on it, if I do.
John Jung
Larry,
Thanks for the tip. Because of your suggestion, I will be ordering
an intake silencer.
John Jung
>Larry Cottrell wrote:
> >Group,
> > Here is what I think is wrong with my Firestar II as it is currently
> >set up. The "quiet" cruise speed is too close to the stall speed. I am
> >comparing it with an original Firestar with a 377. The original can
> >cruise at 23 mph over stall at a "quiet" rpm. If the rpms on the 503
> >powered Firestar II are lowered to the same sound level, I am only 5 mph
> >over stall. The Firestar II currently has a three blade IVO with 62"
> >dia., but I will be testing the same two blade 66" Warp that I used to
> >have on the 377. I will report my findings.
> >John Jung
> John,
> I have a 447 on my firestar II with a 68 IVO prop. The noise is pretty
> bad. I put a intake silencer on it and it made a lot of difference with the
> noise level. It cost me two horsepower they say but it is well worth the
> loss for the quiet. I realize that this isn't what you are saying here but I
> thought that perhaps the reason that you were shutting it down is so that
> your ears weren't ringing. Before I used earplugs and a helmet, and it was
> still loud. I tried a headset with a radio and couldn't hear the tower well
> enough to talk to them. Now a Sig. headset is plenty, no ringing after flying.
> Larry
Group,
Has anyone tried an after-muffler on their Rotax? Is it worth while
for noise reduction?
John Jung
SE Wisconsin
>...I have to find a way to reduce the noise. I even tried the same Warp
This is interesting John, is there much difference in the distance
between the prop and trailing edge of the wing of the FSI compared to the
FSII?
-Mick Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
Subject: | Trailer Decision |
Thanks to all for the input on Mark III wheelbase and use of utility
trailers. Unfortunately, I was unable to find a utility trailer wide
enough to accomodate the Mk III wheelbase of 6 1/2 ft. I was planning
on buying a utility trailer anyway for hauling home improvement items
around and was hoping down the road it might double as an ultralight
trailer. I'll talk to Dennis at Oshkosh about the trailer he's working
on. Thanks again.
Mark Rinehart
"MK III BFI wanna be"
Subject: | Re: Re[4]: MK-II info. - Brand of Oil Mark Prefers |
On Fri, 24 Apr 98 16:53:04 cst jerryb(at)jmd.ods.com writes:
>...He [Mark Brierly] claims he's gets over 1000 hours on his engines
without doing
I passed on replying to this quote the first time but twice posted is
just too much!
Jerry, please remember that the source of your information is coming from
someone who sells a very high performance UL (Titan stretches that
definition quite a bit). I suspect that the target market for Titan is
primarily GA customers who are looking for something that flies like a
172 but costs like a Lawnboy to operate. Alleviating the inherent fear of
2-strokes helps Mark's business. Caveat Emptor! (Buyer Beware!)
IMHO (In My Humble Opinion), anyone claiming 1000 hours without even a
decarbon on any 2-stroke (including weedeaters and chainsaws) is one of
three things:
1) The owner of a defective Hobbs meter.
2) The luckiest person alive since OJ or;
3) Is absolutely telling the truth! (But I'd still like some
corroborating testimony from someone not employed by or related to him.)
I'm not saying it can't be done but it sounds pretty outlandish to me.
I've heard these sort of claims before but they always fade pretty quick
when dragged from the hangar into the light of day.
It's also possible that putting 1000 hours on a 2-stroke engine in a
short period of calendar time, such as a 'demo' plane might, would be
much less hard on it than the way most of us do it, grabbing an hour or
two here and there between trivial things like work, weather, family
obligations, winter, and so forth. Opinions from these type operators
just might be more useful and accurate.
You can forward this to Mark if you'd like, I'd love to learn the secret
of the 1000 hour maintenance-free 2-stroke first hand! Meantime, I'll be
doing the recommended maintenance from the engine manufacturer.
-Mick Fine
Tulsa, Oklahoma
From: | Scott Bentley <Scott.Bentley(at)Bentley.Com> |
Subject: | Pictures from Sun-n-fun |
I've placed 58 pictures on http://scott.bentley.com/sunnfun981 and
http://scott.bentley.com/sunnfun982
There's a picture of Dennis flying the Laser, for example, on
http://scott.bentley.com/sunnfun981/pic00004.jpg
There's a picture of me in the left seat of the Griffin Aerospace Lionheart
(Staggerwing Beech replica) on
http://scott.bentley.com/sunnfun982/pic00025.jpg through
http://scott.bentley.com/sunnfun982/pic00028.jpg
(I did hold is straight and level for a bit and did some shallow turns, but
its a bit of a stretch to say I really flew it.)
In the next few days I'll send a message with information on what's in each
picture, but those with fast internet connections and time on their hands
are welcome to browse...
I'll also say a bit more about the two other aircraft I "flew".
Frank says.....
> Thanks,
> JB
> Hi Jim,
> Frank R
Thanks....
And I maintain that Frank's success is due in large part to
maintaining a high EGT. Those of you who run at 1075 and below
aren't doing your engines any favors.
JB
Jim Baker
Pres, USUA Club 104
Oklahoma City
Subject: | Firestsr II wing rib |
I am currently building the jig for the wing rib and have come across a
problem. The plans show the widest point for the rib at 7 1/16", but I
measure 7 1/4". Since the plans are supposed to be to scale and all the
other measurements seem to be correct I was wondering if this is a miss
print.
I have already e-mailed kolb ,but was hoping to get an answer before
Mon.
THANKS
Subject: | Re: Re[2]: oil - What's Seafoam Treatment |
Jerry,
Seafoam is a gasoline additive made for all types of engines to remove
carbon buildup. It has been around since the '40's and I learned about it
recently. I poured a couple of capfuls into my 377 sparkplug ports and it
belched out white smoke for 10 minutes during warmup. If it's getting rid
of the carbon like it says, I'll be pleased. It says you can add directly
to your gas tank, but this stuff is potent and I don't care to experiment
with it eating the pump diaphragm or anything else. For those of you who
have met Al Reay (he flew the pretty yellow Titan from MN to Sun-N-Fun
this year), he's the guy that told me about Seafoam. He used it
extensively in his Rotax's on his x-country flights. Al is a 2-cycle
engine expert and he wouldn't recommend something he wouldn't use
himself. I'll be using the Seafoam treatment from now on a regular basis.
Ralph Burlingame
Original FireStar
On Fri, 24 Apr 98 17:03:32 cst jerryb(at)jmd.ods.com writes:
>Subject: Re: oil
>Author: ul15rhb(at)juno.com (Ralph H Burlingame) at MAILGATE
>Richard and all,
>unleaded gas and has put well over 300 hrs on it before having it
checked. The
>and my plugs are the cleanest I've ever seen. I don't bother to even
check
>Ralph Burlingame
>Original FireStar
>writes:
>>no seizures, but the rings need cleaning every hundred hours.
>>it also gunks up the rings. Once again, it looks like experience may be
the >>best (and only reliable) teacher.
>> Richard Pike
From: | "Henry C. Wortman" <hwortman(at)mail.datasys.net> |
The last several times I have noticed that my battery seems unusually
hot after flying. The power plant is a 503 DCDI. Is this normal? The
lower part of the battery seems to be the hottest almost to the point of
not being able to hold your finger on it.
What was the weather like when the fatality occurred at F&S? I was
there on Sunday and they were flying in pretty stiff xwinds. They
finally put up the red flag after a slight mishap.
Subject: | Looking for Russell Duffey |
Hey Russell: Want to ask you something about your Slingshot but can't find
your e-mail address. Post it here and I'll write you. Thanks.
Bill Griffin
Montgomery Al.
Original Firestar
From: | Clive Hatcher <CliveHatcher(at)compuserve.com> |
Subject: | Events - Denver, CO |
Hi All,
Does anyone know of any Kolb or Ultralight fly-ins / events in the Denver=
CO area around May 16 thru 19 ?
I shall be on a short visit to USA in May and would like to have a look a=
t
the lighter end of aviation on your side of the " The Pond ".
Clive Hatcher,
Twinstar III - G - MYLN
Thurning, Peterborough (70 miles north of London), England.
From: | "Russell Duffy" <rduffy(at)servecom.picker.com> |
Subject: | Re: Looking for Russell Duffey |
> Bill Griffin
Hi Bill,
I'm hiding up here in Cleveland, OH for a few weeks at a company training
course. You would think they would eventually learn that I'm
untrainable (as my wife has). Anyway, my normal e-mail address is
"rad(at)pen.net" and is being forwarded to my company account
"rduffy(at)svc.picker.com" while I'm up here. Either will work, but the
rad address is probably preferred in the long run.
As for SS questions, ask away. Hopefully, it'll be something I can
answer from memory, since I don't have the plans or plane here to
look at. I joked about flying it to Cleveland, but wouldn't really
consider that. One day I'll fly the RV-8A up here though :-)
Rusty
Budgetel Inn
216-442-8400 rm-302
Back on April 20 I said that I would disassemble and examine my removed wheel
bearings. The balls and the outer race ball tracks were not too bad, although
far from the nice bright polished surfaces that they had when new. The ball
tracks in all the inner races were trashed and very much widened toward one
side of the race. The original track width was about .160 inches while the
new trashed track was about .200 wide and about to run off the available
race width in the direction of the wear.
If the wear had gone much farther I would have had the same type of
catastrophic failure that Bill Varnes wrote about on March 31 when he
reported, small inner race moved inward to center of axle.
My personal conclusions are: 1. Next time the axle nuts need be tightened I
am going to conclude the bearings are going bad. 2. Next time I pull a wheel
and hand check the in place bearings I am going to be carefully checking for
axial play of the inner race relative to the outer race.
Seems to me that there is no reason that wider flanged bearings (yes I know
they would add weight) of the same ID/OD could be used. Perhaps something
with two rows of balls and thus much more capacity/durability. I know that I
should get off my duff and contact some bearing houses. Just keep hoping
someone else has already done the work.
Chris Wayland
PS. Southern CA weather on 17 and 18 April was just gorgeous and I got 4 hrs
of flying time.
><< Where did you get the 6800 rpm number? Max hp. is at 6500rpm and max
Howdy Gang:
Here's what has worked b est for me since I started building and flying
these things in 1984:
I prop an airplane just like I do a boat. If the red line is 6800
rpm, then I will adjust the pitch until I can achieve 6800 rpm, WOT,
straight and level flight. This gives me best climb and best cruise
performance from the engine and my EGTs will remain within the green arc.
One exception is with the 912, which is redlined at 6800 for five
minutes and 6500 for continuous duty. I prop it for 6500 to 6600 rpm,
straight and level flight, WOT. Again, this gives me best climb and cruise.
john
Subject: | Sun-n-fun pictures w/ index |
Here is a description of some of the pictures I took at Sun-n-fun. The
unidentified ones are of planes or areas on which I don't recall the
details, or subjects somewhat duplicative with identified photos.
http://scott.bentley.com/sunnfun981/pic00001.jpg is John Hauck's Mark III
http://scott.bentley.com/sunnfun981/pic00004.jpg is Dennis in the Kolb Laser
http://scott.bentley.com/sunnfun981/pic00005.jpg is Homer Kolb behind the
Laser cage
http://scott.bentley.com/sunnfun981/pic00006.jpg is John Hauck's instrument
panel
http://scott.bentley.com/sunnfun981/pic00007.jpg is John Hauck's control
assembly and radio mount
http://scott.bentley.com/sunnfun981/pic00008.jpg Terry Swartz and his wife
http://scott.bentley.com/sunnfun981/pic00009.jpg Bill Martin and Doug Lack
in front of the Kolb cages
http://scott.bentley.com/sunnfun981/pic00014.jpg A Seawind. Their factory
is about 5 miles from Kolb
http://scott.bentley.com/sunnfun981/pic00018.jpg the Baby Belle Helicopter I
flew in (and flew momentarily)
http://scott.bentley.com/sunnfun981/pic00019.jpg one of the used parts marts
http://scott.bentley.com/sunnfun981/pic00020.jpg one of the kitbuilt
helicopters (theirs was not flying at the show)
http://scott.bentley.com/sunnfun981/pic00022.jpg Doug in front of a "Sky
Arrow"
http://scott.bentley.com/sunnfun981/pic00023.jpg a Fisher Classic, I think
http://scott.bentley.com/sunnfun981/pic00024.jpg inside the "flying RV"
kitplane (I forgot the name of the company)
http://scott.bentley.com/sunnfun981/pic00025.jpg Doug with Pushy Galore
http://scott.bentley.com/sunnfun981/pic00026.jpg The Griffin Aerospace
Lionheart, with Larry French (their President,) and Gordy their test pilot.
http://scott.bentley.com/sunnfun981/pic00027.jpg Gordy and me and the
Lionheart
http://scott.bentley.com/sunnfun982/pic00001.jpg The Buckeye Powered
Parachutes booth
http://scott.bentley.com/sunnfun982/pic00002.jpg The Titan Tornado that Doug
and I later flew in
http://scott.bentley.com/sunnfun982/pic00003.jpg Me looking at the Titan.
The photographer later complained that I didn't warn HIM to suck in his gut
before taking pictures...
http://scott.bentley.com/sunnfun982/pic00004.jpg preflight orientation for
the Titan
http://scott.bentley.com/sunnfun982/pic00006.jpg Dan in the company Mark
III, another unidentified craft on the ground, me in the Titan in the air
http://scott.bentley.com/sunnfun982/pic00009.jpg Doug taking off in the
Titan. Its fast, but it doesn't climb like a Kolb...
http://scott.bentley.com/sunnfun982/pic00012.jpg Dining facilities for the
ultralight / light plane area
http://scott.bentley.com/sunnfun982/pic00015.jpg Warbird flight line
(the next several pictures are of various warbirds)
http://scott.bentley.com/sunnfun982/pic00021.jpg the GlaStar wing folding
mechanism
http://scott.bentley.com/sunnfun982/pic00023.jpg this Zodiak looks a lot
like the Laser to me...
http://scott.bentley.com/sunnfun982/pic00025.jpg this time I actually flew
in (and briefly flew) the Lionheart
http://scott.bentley.com/sunnfun982/pic00027.jpg a good overall Lionheart
Last week I was looking for a replacement for my rivet gun that finally gave
out. While at Sears I found a Drill Guide used for automatic exact centering
of tubes for repetitive drilling and exact depth control. Needless to say I
had to get it.
http://members.aol.com/guillermou/71.jpg
BTW: On my way to work I stopped by Tim Loehrke's neighborhood and bummed a
ride on his FireStar II. His airplane flies great. I took some pictures and
added them to my web page, just click on Tim Loehrke's airplane picture.
I wore my integrating sound level meter while flying in Tim's FireStar II and
it register an average level of 118.5 dB(A). The problem with this
measurement was my camera strap kept hitting the mic so I have to redo the
measurement some other time.
Just for reference:
140 Decibels, immediate danger to hearing, Jet engine at take off or a
gunshot.
125 Decibels, pain threshold, air raid siren, firecracker.
120 Decibels, hearing damage in 7 minutes, rock concert, sandblasting.
115 Decibels, hearing damage in 15 minutes, baby's cry, jet ski.
110 Decibels, hearing damage in 30 minutes, Snowmobile from drivers seat.
Wear your hearing protection!!!
Will Uribe
http://members.aol.com/WillU/index.html
Not normal. It doesn't matter whay kind of powerplant it is, if the
battery is too hot to touch, you could have a problem. Check the system with
a voltmeter and make sure the regulator/rectifier is not putting out enough
to push the battery up to more than 14.5 volts.
Richard Pike
Mick,
One thousand hours on a Rotax? Let's get this man (Mark B.) to tell us
first hand if the oil and high rpms is the secret. I'm interested!
Ralph Burlingame
Original FireStar
>without doing decarboning or other maintenance. I passed on replying to
this >>quote the first time but twice posted is just too much!
>from someone who sells a very high performance UL (Titan stretches
>that definition quite a bit). I suspect that the target market for
>Titan is primarily GA customers who are looking for something that
>flies like a 172 but costs like a Lawnboy to operate. Alleviating the
>inherent fear of 2-strokes helps Mark's business. Caveat Emptor!
>(Buyer Beware!)
>of three things:
>him.)
>quick when dragged from the hangar into the light of day.
>or two here and there between trivial things like work, weather,
>family obligations, winter, and so forth. Opinions from these type
>operators just might be more useful and accurate.
>secret of the 1000 hour maintenance-free 2-stroke first hand!
>Meantime, I'll be doing the recommended maintenance from the engine
>manufacturer.
>-Mick Fine
>Tulsa, Oklahoma
Hi all,
I did some painting on my FS this weekend and ran into a
problem, I painted the tail and the fiberglass parts. The
fiberglass parts turned out great with a nice gloss finish, but
the fabric parts has a dull finish, it almost looks like it
soaked into the fabric. I have three coats of poly brush
(1-brushed 2-sprayed) and four coats of poly spray, I'm using
aero-thane white (combination of glacier and insignia) has
anyone run into this, or know what I'm doing wrong?
Cal
I can't argue with the Grand Old Man of distance flying but in my
experience If I decrease the pitch to give a higher rpm then my top speed
goes down.If I increase pitch the climb decreases but the cruise increases.
What causes me to observe this?
Woody
I don't know about Rotax engines but in a car it often means the
regulator is gone and it is overcharging the battery.
Woody
From: | "Frank, Christie & Frank Hodson" <fchodson(at)bigfoot.com> |
Subject: | Hey Scott Bentley... |
I am trying to get a message straight to you. What's the secret? Every
message that I send gets denied. I had some thoughts concerning your
Sun-N-Fun pictures. Thanks.
Franklin E. Hodson III
fchodson@bigfoot.com | http://www.bigfoot.com/~fchodson
Subject: | mounting pulse fuel pump |
After reading one of the better Ultralight pages (Ultralightnews.com) and
finding reference to mounting the pulse fuel pump so the pulse port fitting
faces downward, I went back to the Rotax Engines Installation manual. Rotax
recommends the same thing: mount the pump the "flat way, with the pulse port
facing downward". I did not mount mine this way, I mounted it the way the
drawing #11 in the Kolb plans shows, with the pulse port fitting facing
sideways. Apparently the pulse port fitting has a small pin-hole in it and
this is supposed to allow drainage of any accumulating oil. If this oil
cannot escape it may cause pump failure (I am paraphrasing from the references)
Am I correct to assume that most of us followed plans and the pumps are
working OK even though they are mounted on their sides? Or are most of you
using the pumps as Rotax recommends?
I am considering remounting, is it worth it? Does anyone have an experience?
jim
Subject: | URL problems with my Sun-n-Fun pics |
You're internet provider does not yet have the new stuff for
scott.bentley.com (my vanity URL.) Or something else went wrong.
You can replace scott.bentley.com with saturn.bentley.com/scott, as in
http://saturn.bentley.com/scott/sunnfun981/pic00010.jpg
I would appreciate (direct, not post) comments from anyone else with the
same problem
Please include whatever you know about your internet provider.
> -----Original Message-----
> From: Larry Davis]
> Sent: Sunday, April 26, 1998 8:16 AM
> To: Scott Bentley
> Subject: Re: Pictures from Sun-n-fun
> Hi,
> I tried to visit your site several times but Netscape says "The server
> does not
> have a DNS entry". Is there something I did wrong?
Subject: | Re: URL problems with my Sun-n-Fun pics |
Copies to: "'Kolb builders'"
Subject: Kolb-List: URL problems with my Sun-n-Fun pics
Scott,
Works fine this morning. Great pictures! Thanks for putting them up.
> same problem
> > From: Larry Davis]
> > To: Scott Bentley
> > Hi,
> > does not
Larry Davis
Marion, Indiana
ldavis(at)netusa1.net
http://www.netusa1.net/~ldavis
(Netscape Mail Server v1.1) with SMTP id AAA172
There was a discussion on the cutting of Lexan awhile ago, but I
didnt see the outcome. I want to shorten my windshield/conopy on my
Firestar. Unless there is another way to get into and out of the plane
with my long legs without cutting and shortening the lexan, I am going
to shorten it by cutting. Perhaps a piano hinge and pop rivits might
solve the problem. Any comments from the throng?? Larry in Sussex w/
Firestar @ 3N5
on the
cutting of Lexan awhile ago, but I didnt see the outcome. I want
to
shorten my windshield/conopy on my Firestar. Unless there is
another way
to get into and out of the plane with my long legs without cutting and
shortening the lexan, I am going to shorten it by cutting. Perhaps
a piano
hinge and pop rivits might solve the problem. Any comments from
the
throng?? Larry in Sussex w/ Firestar @
3N5
Subject: | Painting your airplane with a roller. |
To those of you who painted some or all of your airplane with a roller,
did you use 2 coats of polytone?
Subject: | Re: After-muffler |
John,
I installed an aftermuffler when I originally build the MKIII with the 582
and used it for about 30 hrs before removing it permanently. Did not notice
much difference from inside or from ground.
If you are still interested in one after reading this, I will make you a
good deal on it.
Frank Reynen
http://www.webcom.com/reynen
Group,
John Jung
SE Wisconsin
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
Subject: | Re: Painting your airplane with a roller. |
How many of you actually did this? I am considering it myself.
Ron
Original Firestar
Date: Monday April 27 1998 7:45 AM
Subject: Kolb-List: Painting your airplane with a roller.
Subject: | Re: Re[6]: MK-II info. - Brand of Oil Mark Prefers |
On Mon, 27 Apr 98 12:51:25 cst jerryb(at)jmd.ods.com writes:
>I agree with you if he's actually pulling those hours he's pushing it.
> The fact
>is he really getting those hours.
Again, I'm not saying it's impossible but I would consider Mark's
experience to be very much the exception and not the rule. Most operators
I know would have done 10 decarbons and 2 major overhauls (top and bottom
end) in 1000 hours.
>...My self I still don't like the 2-strokes. Just too much tweaking and
>to many
>things influence a engine out. I also have a problem with the
>frequent need to
>take things a part. When you disturb things like bearings, your never
>know how
>long you got.
Actually, decarboning doesn't disturb the bearings (unless you count the
wrist-pin bearings). Yes, it does kill an afternoon or two (if you work
as slow as me) but it's really not as big a job as some folks make it out
to be.
>Say what you may I'll trust a 4-stroke VW engine much more than a
>mucked with
>2-stroke.
Jerry, I'm not trying to rain on everything (really!) but I wouldn't
count on getting 1000 hours out of a VW either! 4-strokes have been known
to quit also, often for the same reasons that 2-strokes do. Proper
maintenance is still an absolute necessity. I agree, given a choice, we'd
all rather be flying 4-strokes. Trouble is, the added weight and expense
just can't always be justified.
-Mick Fine
Tulsa, Oklahoma
>>mucked with
>>2-stroke.
Jerry, Don't sell 2 stroke engines short. Probably the harshest
enviornment that an engine can operate in is not on an airplane, but in a
salt water enviornment as an outboard boat motor. Modern outboards are
darn near "bulletproof" falling short of 4 strokes only in specific fuel
consumption.
Skip
1984 UltraStar with a (dare I say it?) a Cuyuna engine :)
Jason,
Yes rolled mine on and I did use two coats of polytone with UV blocker in
the paint. I then rolled on some trim w/o the UV blocker.
Ralph Burlingame
Original FireStar
writes:
>roller did you use 2 coats of polytone?
Mick,
The distance between the prop and trailing edge of the wing 2.5
inches on my Firestar II and 5 inches on my original Firestar. The IVO
uses a 2.5 inch spacer that increases the distance to 5 inches. It
would
be interesting if someone with a sound level meter, like Will Uribe,
would sort out some of these sound differences.
John Jung
>Mick Fine wrote:
writes:
Warp
loud.
the
> FSII?
> -Mick Fine
> Tulsa, Oklahoma
If I ever get a chance to measure different props on my travels I'll let you
know. I'll be in Tuscaloosa and Gadsden, Alabama next month.
Will
<< The distance between the prop and trailing edge of the wing 2.5
would
John Jung
>Mick Fine wrote:
writes:
Warp
loud.
the
> FSII? >>
From: | bobdoebler(at)juno.com (Robert L Doebler) |
--------- Begin forwarded message ----------
Subject: Kolb-List: paint
Date: Sun, 26 Apr 98 21:38:40 -0500
Hi all,
Cal
Call
I found out the more coats I put on mine, the glossier ( to a point) it
became. But this gets more expensive and heavier, So it boils down to a
judgement call.
Bob Doebler
--------- End forwarded message ----------
>IVO
>would
> John Jung
Ok, leaping ahead a little, we can (maybe?) assume that the spacer
reduces the noise level. Now we need an engineer type to tell us why the
gyroscopic effects of displacing the prop plane 2.5" axially will trash a
Rotax gearbox. Where has Ben been (sorry) anyway?
-Mick Fine
Tulsa, Oklahoma
>Mick,
>would
> John Jung
I have installed a Ivo spacer between my three blade Warp drive and my C
drive and have notices a considerable reduction in sound.
My original clearance was only 1.5 inches! I purchased a 2.5 inch prop
extension from Ivoprop. An Ivoprop is thinner than a Warp drive therefore
the bolts that they supplied were too short. I needed 8 X 150 mm bolts.
The longest metric bolts that I could find were 130 mm long. I went to a local
skidoo / seadoo dealer and he found the required bolts in his part's book.
The part no. is:
BOMBARDIER
732 601 054
VIS-SCREW-HEX
U.S.A.
Kim Steiner
Saskatchewan Canada
Reach me by ICQ. My ICQ# is 4551867 or,
* Page me online through my Personal Communication Center:
http://wwp.mirabilis.com/4551867 (go there and try it!) or,
* Send me E-mail Express directly to my computer screen
4551867(at)pager.mirabilis.com
For downloading ICQ at http://www.icq.com/
For adding similar signatures to your e-mail go to:
http://www.icq.com/emailsig.html
Brian "Kim" Steiner
Or, you could have ordered them from Metric Screw and Tool Co.,
Wakefield, MA 1-800-METRIC-1.
Available in either property class 8.8 (116,000 psi tensile) or 10.9
( 150,000 psi...which is closer to AN grade 6).
Lots of other stuff, too.
Jim Baker
Pres, USUA Club 104
Oklahoma City
Subject: | Antanna location |
Sear Sir:
Kolb mark III I am wondering where is a good location for the aircraft
radio antanna?
Where is a good location for a CB antanna?
>From Ron
n8xxo@rural-net.com
Subject: | Much improved Sun-n-Fun pictures page |
Thanks entirely to the volunteer efforts of Franklin E. Hodson III (
fchodson@bigfoot.com | http://www.bigfoot.com/~fchodson),
I now have some HTML and an index on http://scott.bentley.com, including all
the pictures I took at Sun-n-Fun
It now works much better for dial-in users, is organized, etc. - looks like
a real web page. You can get an overview without downloading each picture.
If I wasn't so lazy I'd do this kind of thing all the time...
From: | "Marino, Frank J (Youngstown ARB)" <Frank.Marino(at)yng.afres.af.mil> |
Subject: | RE: Re[6]: MK-II info. - Brand of Oil Mark Prefers |
MAN!!! you guys are depressing me about 2 stroke engines, I'm thinking
I might not ever want to fly my MKIII again. I don't like 2 strokes
either but I was just starting to feel some what comfortable with it and
now I don't know.
FRANK J. MARINO
> From: mefine1(at)juno.com[SMTP:mefine1(at)juno.com]
> Sent: Monday, April 27, 1998 4:38 PM
> To: kolb(at)intrig.com
> Subject: Re: Re[6]: MK-II info. - Brand of Oil Mark Prefers
> it.
> > The fact
> operators
> bottom
> end) in 1000 hours.
> and
> >to many
> >frequent need to
> never
> >know how
> >long you got.
> the
> work
> out
> to be.
> >mucked with
> >2-stroke.
> known
> we'd
> expense
> -Mick Fine
> Tulsa, Oklahoma
> Get completely free e-mail from Juno at http://www.juno.com
> Or call Juno at (800) 654-JUNO [654-5866]
Subject: | Re: Much improved Sun-n-Fun pictures page |
Group
Depending on which software package you are using to for e-mail, mine is
Eudora Pro, the internet address for
Scotts photo's won't work. A comma "," was added to his address in the
sentence for punctuation. My software package takes e-mail addresses and
highlights them so that I can just click on it and it'll take me
there...well it bombs with that comma.
Just remove the comma at the end of his address and everything works out
sweet.
Ron
Ron Reece Return: rcreec(at)most.fw.hac.com
Raytheon Corp.
Ft. Wayne IN
Subject: | Scott's Pictures |
Thanks for the pics of Sun-N-Fun. By the way, is the "Sky Arrow" the
aircraft that crashed?
Mark Rinehart
Subject: | RE: Firestar II vs Original Firestar |
I don't have a sound meter, but I can tell you that subjectively it makes a
HUGE difference.
I ran the IVO on my Mk II for about 2 years before I installed the spacer.
Like on your Firestars, the prop-to-trailing-edge distance went from 2.5
to 5 inches.
I'd have to say the cabin noise was cut about in half.
-Steve
Group
Just to get this right. Someone like myself, with ambitions of using a
503, can also use this spacer and reduce noise? How much does this little
puppy cost? And it won't have adverse effects of the engine, RIGHT????
Raytheon Corp.
Ft. Wayne IN
Subject: | FW: Painting your airplane with a roller. |
Ralph, I should have asked this in my first message: how many gallons
of paint did you use for your base color?
> From: ul15rhb(at)juno.com [SMTP:ul15rhb(at)juno.com]
> Sent: Monday, April 27, 1998 5:50 PM
> Subject: Re: Painting your airplane with a roller.
> Jason,
> in
> Ralph Burlingame
> Original FireStar
> writes:
When changing to a longer prop spacer does the CG move back? Would I need to
recalculate the weight and balance?
Will Uribe
From: | "Anderson, Jim L NWP" <Jim.L.Anderson(at)nwp01.usace.army.mil> |
You guys crack me up. Since I've been flying UL's (OK fat UL's),
I've seen more crap in the air that people are trying to kill themselves
with. Most failures from 2-strokes are fuel starvation or conditions
caused by people "tweaking" the carb polishing ports and otherwise
modifying a stock engine. If you do that you are stupid and will likely
have an engine out. I wouldn't put a 4 stroke on my UL (OK fat UL)
because performance would suffer (KOLB has an HKS for sale). 2-strokes
love to be ran hard, under load just like a diesel engine. I have
2-stroke diesels in my 40ft. yacht with 4500 hours (DET 6V53) they are
good for 10,000 hrs, I desert and motocross raced my Husky 250WR, and
NEVER seized an engine, in fact, I NEVER seized an engine racing my
other 2-stroke racers over a 15 year period. You are a lot better off
with a rotax on your UL than a modified auto engine any day. Humans
love to screw with things and that tends to get us killed. When it
comes to planes- Don't think you are a better engineer than the factory
guys; don't think you can super tune your engines-stick to stock
jetting; use good fuel and oil. Few failures are catastrophically
related to the engine (exclude carbs, fuel pumps, etc.). don't buy junk
and try to fly it. If you've got to modify something keep it inside the
cockpit. Finally shut up and go flying (and stay off this stupid
computer-you're starting to get secretary ass)......Jim "trying to
unsubscribe to the Kolb gang but getting messages that say I'm not
subscribed-help me get out" Anderson.
[SMTP:Frank.Marino(at)yng.afres.af.mil]
Sent: Tuesday, April 28, 1998 5:04 AM
To: kolb(at)intrig.com; 'mefine1(at)juno.com'
Subject: RE: Re[6]: MK-II info. - Brand of Oil Mark
Prefers
thinking
strokes
with it and
now I don't know.
FRANK J. MARINO
Prefers
pushing
> it.
> > The fact
Mark's
Most
> operators
and
> bottom
> end) in 1000 hours.
tweaking
> and
> >to many
the
> >frequent need to
your
> never
> >know how
> >long you got.
count
> the
you
> work
make it
> out
> to be.
than a
> >mucked with
> >2-stroke.
wouldn't
been
> known
Proper
choice,
> we'd
and
> expense
> -Mick Fine
> Tulsa, Oklahoma
Subject: | prop spacer, question of Warp and Ivo prop users... |
For those of you who use Warp Props: My Powerfin prop mounts by putting the
six bolts thru the prop hub and threading them into the threaded holes in the
Rotax hub of the "C" drive. There are then lock nuts on the engine side of
the rotax hub. Is this how Warp and Ivo props are mounted?
This is something I kindof wonder about, since they tell you to use a bolt
bearing the load on the shank, not the threads. In this case, I am using
the strength of the bolt quite poorly.
The reason I ask is if I should decide to try a prop spacer to reduce noise,
I expect the stress on these bolts WILL increase. And the redrive will see
more stress also, as I will be giving the propeller forces a longer leverage
arm to use against the redrive. If this is working OK for Warp props, it
will work just fine for Powerfin, at 2/3 the mass. I will be calling the prop
manufacturer for some input too.
Thanks again guys...
Subject: | Re: prop spacer, question of Warp and Ivo prop users... |
Warp is mounted the same way....except on the Hirth, the gearbox hub
is rounded on the back so nuts are not used. I've drilled the bolt
heads for safety wire.
How so? Is the bolt threaded all the way to the head (bad) or is it
a partial thread/shank type (good)? Primary factor is to not bottom
out the bolt threads in the hub plate....the bolt MUST be under
tension. The primary load carrying forces on the prop/ prop hub is
the frictional loading between the two....not the bolts...they are
there only to provide the necessary friction loading.
See above.
Assuming the prop is out of balance, does not track correctly, or
vibrates excessively (assymetric loading...the reason I avoided IVO
props)...the above is true. If the prop dynamically and statically
balances, tracks true, and is torsionally stiff enough to resist
bending, the only other force acting will be gyroscopic forces which
may have an effect on bearing life.
Jim Baker
Pres, USUA Club 104
Oklahoma City
No W&B problem with moving the prop back 2.5 inches, unless your are
already pushing the limit. (like 36.99%)
John Jung
> Will Uribe
From: | george_eagle(at)webtv.net (George Thompson) |
Where can we buy this Seafoam? It seems a painless way to decarbon a two
stroke. I am sure there are other flyers that would be interested in
trying it. The Bald Eagle.
Blue Skys and Tail Winds
> Hi all,
Cal:
Sounds like you may have an overspray problem. Aerothane and other two
part polyurethanes are very supseptible to blush or overspray. If that is
the case, the best remedy I found was another coat of polyurethane and
protect anything that's already painted from the overspray to prevent
blush. That charactgeristic caused much labor intensive masking to protect
what had already been painted.
Ok guys
The rotary forces are increased by the squared distance of
extension,so you can see that the gyro effect is multiplied many times by
the extension. (not a engineer)
dave r
>Will Uribe
Subject: | Re[2]: After-muffler |
I just read something a few weeks ago about noise reduction. I can't
recall where it was but it indicated you would get much more noise
reduction using a intake silencer than the optional muffler (exhaust
silencer).
Jerry
Subject: Kolb-List: Re: After-muffler
Date: 4/27/98 10:50 AM
John,
good deal on it.
Frank Reynen
Group,
John Jung
SE Wisconsin
Subject: | Re: cutting Lexan.. |
Maybe we should trade planes. I have short legs and because of that I
can't straddle the side to get in and out of the FireFly. With the
short windshield I had to call for the ground crew to bring the ramp
truck (a cement block).
They got tired of carrying the block around so my partner decided to
put on the full enclosure. I can now get in and out. We now looking
at making a windscreen something in between the two. Now if I could
figure out how to land the thing. Reminder: order nose cone from
Kolb.
As for cutting Lexan, I found it cuts real easy with a good pair of
tin snips. I have a nice pair of (new aluminum handle) old style tin
snips. I also used the aviation type snips although because of the
jaws serrated edge they leave a little rougher edge. After cutting I
touch up the edge with a file and a Scott Brite pad. Works for me.
Don't try cutting Plexiglas with them, I think it would shatter.
Jerry Bidle
Subject: Kolb-List: cutting Lexan..
Date: 4/27/98 9:32 AM
There was a discussion on the cutting of Lexan awhile ago, but I didnt see
the outcome. I want to shorten my windshield/conopy on my Firestar. Unless
there is another way to get into and out of the plane with my long legs without
cutting and shortening the lexan, I am going to shorten it by cutting. Perhaps
a piano hinge and pop rivits might solve the problem. Any comments from the
throng?? Larry in Sussex w/ Firestar @ 3N5
cutting of Lexan awhile ago, but I didnt see the outcome. I want to
shorten my windshield/conopy on my Firestar. Unless there is another way
shortening the lexan, I am going to shorten it by cutting. Perhaps a piano
Larry Cottrell reported reduced sound with the intake silencer. My
questions for Larry or anyone else are:
1) Is there any interference with folding a Firestar II with the single
or dual (carb) intake silencer?
2) Is extra hardware needed to mount it when used on a single carb? CPS
warns about them going through the prop.
John Jung
> silencer).
> Jerry
Subject: | Re: Firestsr II wing rib |
TWORMSLEY(at)postoffice.worldnet.att.net writes:
<< I am currently building the jig for the wing rib and have come across a
other measurements seem to be correct I was wondering if this is a miss >>
Be careful of high humidity in your area....my plans grew too .....so I baked
them in the oven and re tacked them.....................GeoR38
Or get some of the edging channel from JC Whitney or other
automotive, snowmobile, plastics distributor. Has metal grip clips
on the inside so you just push it on the edge and it stays. Chrome,
black, white......
Jim Baker
Pres, USUA Club 104
Oklahoma City
George,
You can get it at many auto parts stores. There is a store chain here
called Fleet Farm that has it.
Ralph Burlingame
Original FireStar
Thompson) writes:
>two stroke. I am sure there are other flyers that would be interested in
Subject: | Re: FW: Painting your airplane with a roller. |
Jason,
I used about 3 gallons as I recall. I built in '86.
Ralph Burlingame
Original FireStar
writes:
>> Jason,
>>blocker in the paint. I then rolled on some trim w/o the UV blocker.
>> Ralph Burlingame
>> Original FireStar
>> writes:
Subject: | Re: Antanna location |
>Sear Sir:
>radio antanna?
>>From Ron
The radio antenna will work fine either up on the gap seal in front
of the engine, or below the fuselage about 2' behind the main gear. You will
have to curve the antenna back horizontal to keep it off the ground, but it
will still work ok. Either way, make sure that there is a sheet of thin
aluminum at least as big as a pie plate where the antenna is attached for a
ground plane, or the antenna will not work very well.
A good location for a CB antenna is on your pickup truck. Tell your
cheap friends to buy aircraft radios so that you will not have to bother
with lugging around a CB radio just on their account. :)
And on the subject of radios: radio communication techniques are a
source of both great frustration and great amusement to controllers.
Saturday I had the following exchange on the frequency:
"1964Zulu, Tri-City Approach."
"64Zulu, say aircraft type."
(Shucks...I wanted so bad to see a twin engine
Mooney...maybe tomorrow?)
Richard Pike
>now I don't know.
Out in the carport is a 1953 Feathercraft aluminum runabout with a
1953 Elgin 40 HP 2-cylinder, 2 cycle engine on it. I bought it from the 2nd
owner who bought it from the original owner in 1957. The 2nd owner never had
the head off, and I have never had the head off, runs like a watch. A
reliable 2-cycle.
Aircraft engines (Continental, Lycoming, etc.)are remarkably
reliable. Other engines are less so.
BUT THAT'S NOT IMPORTANT!!! If you fly an airplane that stalls at
70, and crosses the fence at 90, you HAVE to have a reliable engine. If you
fly an airplane that stalls at 30 and crosses the fence at 50, plan your
overflight to avoid hostile terrain, and you can land anywhere, with only
inconvenience.
One of the guys in our chapter owns what is apparently the prototype
503 Drifter with a 440 Kawasaki on it. (It is a disaster, Duct tape, hose
clamps, angle iron braces...) He flew it all one year with stuck rings , and
out of sheer contrariness, wouldn't overhaul it. He had several forced
landings a month, and only fixed it when everyone refused to fly with him
anymore.(got tired of fetching the trailer) He never bent the airplane, he
only annoyed people.
But he proved a point. Even the most unreliable ultralight
engine/aircraft is safe and doesn't get bent if you fly with the assumption
that it can get quiet most any time.
Richard Pike
Subject: | Intake silencers |
Had an intake silencer on my 277, and also on the 503. On the 277, a
minor loss of power top end, better fuel economy, MUCH quieter.
On the 503, power loss unacceptable,(heavy airplane) had to remove
it. Don't know how much horsepower involved, but was running a 66" Warp
Drive, turning 6400 static. Took the silencer off, installed the stock K&N
filter, rejetted, and turned 7000 static, same pitch.
Repitched to 6400. Bought the dual carb kit, and turned 7200, same
pitch. Repitched to 6400.
Airflow=Horsepower. If you feel like you have more power than you
need or want, an intake silencer will reduce noise and fuel consumption. But
they can be tricky to get the jetting right.
Richard Pike
Hi,
I ansered Johns query about the silencers but forgot to include the list
so I will do it again. I have a single carb silencer, and do not have any
trouble in folding the wings. It has a pivot point in the fitting so it
moves easiely enough that if the wing does contact it, it rotates without
causing a problem. I did safety wire it to the engine, there are tabs to do
so on it. The wire is long enough so that it can still move. It takes that
nasty irratating whine out of the engine that seems to make most people
angry. Most comment on how it is much quieter than they expected.
I forgot to mention the difference in jetting. CPS recommends a drop of 10
thousands in jet. I used a 155 so I installed a 145 and it was right on. I
do believe that I lost a bit of horsepower but even though I'm starting from
4300 altitide and both the plane and I am fat it is still acceptable.
(engine is 447)
Larry
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
Hay this sounds really dangerous to me. The reason Ivo can get away
with the spacer is because their props are very light and flexible,
resulting in very low gyro (inertial) forces. Warp drive props are
heavy and stiff, resulting in very large inertial forces. At the least
I would not do it withou the written permission from warp drive. If you
loose a prop you will be really unhappy about it, especially if it
decides to drop down and cut your tail boom off!
Topher
ON MY SLINGSHOT WITH A 582 AND A 3-BLADE WARP TAPERTIP PROP
I HAD 2.0" OF PROP CLEARANCE HORIZONTALY TO THE REAR OF
THE FAIRING ON THE BACK OF THE CAGE. I WAS UNCOMFORTABLE
WITH THE 2.0" , UNLIKE THE SPACER THAT COMES FROM IVO WHERE
THE SPACER AND PROP RELY ON THE PROP BOLTS FOR ALIGNMENT,
I MADE A 1.75 LONG SPACER TO ACCEPT THE 1.00" BOSS ON THE
GEAR BOX FLANGE AND MACHINED A 1.00 BOSS TO FIT THE PROP
HUB. ALSO A SLIP FIT ON THE 6-8MM PROP BOLTS TO HELP TORSIONAL
LOADS. I NOW HAVE ABOUT 35 HOURS USING THE SPACER. I DID HAVE
MY PROP OFF AROUND 30 HOURS AND CHECKED PROP BOLTS FOR
STRAIGHTNESS AND THEY WERE OK. JUST THOUGHT I WOULD SHARE
WHAT I HAVE DONE.
JOHN RUSSELL
3-BLADE
WARP TAPERTIP PROP
HORIZONTALY TO
THE REAR OF
I WAS
UNCOMFORTABLE
SPACER THAT
BOLTS FOR
ALIGNMENT,
THE
1.00" BOSS ON THE
BOSS TO FIT
THE PROP
PROP BOLTS TO
HELP TORSIONAL
HOURS USING THE
SPACER. I DID HAVE
CHECKED PROP
BOLTS FOR
THOUGHT I
WOULD SHARE
WHAT I HAVE DONE.
&nbs=
p;  =
nbsp;
JOHN RUSSELL
George,
To use the Seafoam here's what you do:
1) Take out one spark plug and bring that piston to TDC.
2) Add 2-4 capfuls in that cylinder.
3) Let it sit for a few days.
4) Put a used plug in the treated cylinder.
5) Start it up and run at about 4000 rpm once it's warmed up.
6) When it quits blowing white smoke out the exhaust, it's ready.
7) Put a new plug in the treated cylinder.
9) Repeat steps 1-7 for the other cylinder.
Please Note: The Seafoam will foul the plugs. Use some old plugs during
the treatment then put in new ones after the treatment. I have tested it
for the above method. The instructions say that you can add to your gas
tank, but I would NOT do it because you do not know what it will eat up.
Keep it in the cylinders only.
Ralph Burlingame
Original FireStar
Thompson) writes:
>Went looking for seafoam this morning and the third parts house had
>some. The 'Car Quest" chain had it. I will give it a try sometime
>next week. Thanks for the info. George.
Does anyone remember what IVO's minimum clearance is? I had the same
interference point as John, but since I have an IVO, I had to use the
extension AND tilt the engine forward substantially to make the prop
clear the fairing by something close to what IVO requires. Tilting
the engine was what Kolb did as well. I'm just trying to remember
what I used for spacing, to see how closely it compares to John's.
Did you have to tilt your engine John? How about passing along some
numbers (cruise, climb, etc.) when you get a chance. Inquiring
(bored, away from home) minds want to know.
Rusty (still stuck in Cleveland) Duffy
writes:
>with a
>1953 Elgin 40 HP 2-cylinder, 2 cycle engine on it....
I could mention my 1960 Starcraft with a '59 Johnson 'Super Seahorse' 35
on it and that I've had it 12 trouble free years but there are some who
start whining when the topic gets away from strictly Kolb stuff, so I
won't.
-Mick (so CB users are 'cheap' huh? -I resemble that remark!) Fine
Tulsa, Oklahoma
Skip,
What I would suggest is to use "Seafoam Deep Throat" in the spray can.
Put in some old plugs and tie the plane down. Pull off the air cleaner
and start it up. Run at a high idle and spray the Seafoam into the carb
with the straw provided. (Please stay away from the prop). Spray until
the engine bogs down and finally quits. Let the treatment work for a few
days if possible. Start the engine and run until it quits blowing out
smoke. Install new plugs and the air cleaner then go for it.
Ralph Burlingame
Original FireStar
writes:
>Ralph,
>>up. Keep it in the cylinders only.
>For those of us that have engines that have spark plugs pointing down
>(as opposed to your engine installation) pouring Seafoam upwards
presents
>a problem. What do you suggest?
>Skip
From: Russell Duffy <rduffy(at)servecom.picker.com>
Date: Wednesday, April 29, 1998 6:56 PM
Subject: Kolb-List: Re: PROP SPACER
RUSTY,
YES, USING 5/8" SPACER UNDER ENGINE PLATE AT REAR
I ENDED UP WITH 2.0" CLEARANCE.
CRUISE @ 5700 85MPH
CRUISE @ 6000 90MPH
FULL THROTTLE 105-108MPH
I'M SEEING AROUND 1300-1500 CLIMB SOLO @ 60-65MPH.
I'M PLANNING ON THE JONES LITE FLYIN MAY 9&10 , HOW
BOUT YOU. LAST YEAR I THINK 8 FROM OUR GROUP MADE
IT DOWN AND CAMPED . THERE WAS AROUND 50 CRAFT
SHOW UP. GOOD FOOD.
JOHN
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
Subject: | Jones Lite Fly-In |
SHOW UP. GOOD FOOD.
JOHN
I was around when the final count was made at the Jones Lite Fly-In last
year...63 planes at the biggest point. Looks like there will be a good Kolb
representation this year. John Hauck is intending to come, now John Russell
with his Slingshot is coming and there is a local guy with a Firefly. If
the Southern Flyers club comes up from Ashford, Al. and all points south
then Kolb might outnumber the local Challengers!
Thought I would post the info again for anyone who might have lost
it...sorry for using the bandwidth to those not interested.
Jeremy Casey jrcasey(at)mindsping.com
This is a post for anyone in the central Alabama, central Georgia area.
There is a fly-in planned on May 30 at Jones Field. The organizer is the
regional Challenger dealer named George Travis Phone# 334-742-9922 (for
info.). The field is located in Smith Station, Al. (approx. 20 miles wnw of
Columbus, Ga. (CSG)) The GPS coordinates for the gadget guys out there are:
Lat N32-30 Long W85-05
Other pertinent info is...
Elevation 440' msl
Runway 05-23 - 2000' grass
power lines both ends
Fly pattern to north of field
I picked this out of my August 97 archive of Kolb listserver info:
>From Jon Steiger:
JS> A FireFly builder told me that, with the IVO prop, I should have a
JS> spacer in front of the prop, because the prop blades are designed to
JS> flex 5 inches, and the tips could hit the back of my wings. True, or
JS> not a problem?
>From Russell Duffy:
RD> True. Dennis told me that the 5" flex that IVO mentions comes during
RD> startup and shutdown, not really during normal running. During the
RD> break-in of my 503 (not on a FireFly), I couldn't really see much flexing
RD> during the run, but I made sure I had 5" clearance just in case. Get the
RD> spacer if there's any doubt.
-Ben Ransom
Howdy Guys:
If there is any doubt in anyone's mind about Ivo props flexing during start
up, just go back there and take a look while someone else starts the eng.
At the Dealers Showcase at Lakeland, Dick Rayhill couldn't get the Firestar
started, and time was growing short for us to fly, like next. I just
happened to be sitting to the side of the aircraft to get a good view of
the start sequence. The blades on the aircraft look like sphagetti when
they are turned. I would definitely go with an extension.
Sun and Fun 94, I flew the Mk III with new 912 and Warp Drive tapered blade
prop to Lakeland. Sometime during the trip, I got a blade strike from one
or more blades during startup. Hit and dented the rear of the left flap
leading edge tube, putting a nice dent in it. I wasn't sure when the
strike occurred, so I very carfefully flew back to Alabama, and a friend
turned me a nice extention for my prop.
Again, my own experiences.
via SMTP by pop-proxy03.primenet.com, id smtpd024527; Thu Apr 30 12:30:37 1998
CB,s are cool because you don't half to give big brother $95 to operate
them ..... steve
Subject: | Re: Kolb: RAIDOS |
>them ..... steve
Howdy Steve: I think you are a little behind the times. FCC requirement
for aircraft station license is no longer in effect, unless you decide to
fly to a foreign country. I think I would gamble on not having a current
license going into Canada, I don't recall ever being asked to produce one
when I went thru their customs.
VHF radio has gotten me out of a jamb more than once. In 1989, on a flight
up the Shenendoa (sp) Valley early one morning, I got caught on top with no
ground in sight, except the tops of the mountains on each side of the
valley. I punched in Roanoke Regional Airport VOR (VOR is in the middle of
the field) and headed that way. I was flying a UL Kolb Firestar. When I
got over the field there was a nice hole right over the runway. I called
the tower, indicated I was caught on top in a VFR ultralight and requested
permission to land. Permission granted as I spiraled down thru the hole
and on to a gigantic runway. Just prior to touchdown the engine quit.
Tower told me to turn off at next taxiway and contact ground. I told them
to wait a minute, I had to get out and restart the engine. Permission
granted again. I spent half a day waiting for the weather to lift, but I
was safe.
Could not have done that with a CB.
Subject: | generator for 503 |
Group
Does the 503 have a built in generator for electric type stuff (strobe,
radio, ...)?
Raytheon Corp.
Ft. Wayne IN
From: | "Richard neilsen" <neilsenr(at)state.mi.us> |
Subject: | Dual Stick MKIII |
Kolb has announced a option for dual control sticks for the MKIII. Has
anyone seen them? Did anyone see it at Sun and Fun? Did anyone get any
photos.
Subject: | Ron Reece : generator for 503 |
Subject: Kolb-List: generator for 503
Date: Thu, 30 Apr 1998 15:14:14 -0500
Group
radio, ...)?
Yes, but you will need to buy a dc regulator, usually around $50-60.
Bob doebler
Ron Reece Return:
Raytheon Corp.
Ft. Wayne IN
Thanks, that's probably about right for me as well. Originally, I
had no clearance, then I added the 5/8" spacer under the engine, and
the 2.5" prop spacer to get close to 5" clearance for the prop tip.
> CRUISE @ 5700 85MPH
> CRUISE @ 6000 90MPH
I hate you :-)
Hey John, you planning to camp from the 9th to the 30th :-) I'm
still hoping to make the 30th, but I can't really say for sure yet.
I'm already trying to think of ways to slow your SS down to match
mine. It'll be cheaper and easier than installing a new engine :-)
Rusty
Subject: | Re: Dual Stick MKIII |
Richard,
See-> http://scott.bentley.com/sunnfun981.htm
and specifically -> http://scott.bentley.com/sunnfun981.htm
for pictures of John Hauck's installation.
John Jung
>Richard neilsen wrote:
> Kolb has announced a option for dual control sticks for the MKIII. Has anyone
seen them? Did anyone see it at Sun and Fun? Did anyone get any photos.
Date: Thursday, April 30, 1998 9:44 PM
>> CRUISE @ 5700 85MPH
>> CRUISE @ 6000 90MPH
>I hate you :-)
>Rusty
>HEY RUSTY, I'M ALL SCREWED UP ON THE DATES, IF THE
FLYIN IS ON THE 30TH , OUR NEWS LETTER IS NOT CORRECT.
(PLANNING ON CAMPING 1-NIGHT-I HOPE)
JOHN
, IF THE
John... don't come yet! 2 1/2 weeks is a long time without a shower! (No
showers on site!)
Elevation 440' msl
Overnight camping available with electricity and toilet.(No showers.)
This was typed right off of the printed flyer that they handed out
Testing 123
Testing 123
via smtpd (for www.intrig.com [206.54.183.49]) with SMTP; 2 May 1998 11:05:42 UT
(Netscape Messaging Server 3.0) with SMTP id AAA23887;
Subject: | Re[2]: PROP SPACER |
Can't comment on the blade flex but I can comment about the distance
commented that they added the spacer to increase the distance between
the trailing edge of the wing and the prop. According to him this
improved performance as it put the prop in cleaner air.
This is too important to trust to here say. Build it to plans and
consult the factory if in doubt.
______________________________ Reply Separator _________________________________
Date: 4/30/98 12:02 PM
>From Jon Steiger:
JS> not a problem?
>From Russell Duffy:
-Ben Ransom
(Netscape Messaging Server 3.0) with SMTP id AAA23888;
I'm confused. There appears to be two different but closely related
topic being discussed here.
Are we talking about the prop extension to set the prop back farther
from the trailing edge of the wing or put a spacer under the rear of
the engine to increase the distance (space) between the tip of the
prop and the boom tube.
I can't recall the exact distance but if I recall right but on our
FireFly were got less than 1" (1/2" comes to mind) between the tip of
the prop and the boom tube.
Jerry
Date: 4/30/98 8:45 PM
> CRUISE @ 5700 85MPH
> CRUISE @ 6000 90MPH
I hate you :-)
Rusty
<< But he proved a point. Even the most unreliable ultralight
Richard Pike
MKIII N420P (42oldpoops) >>
HEAR! HEAR.... Richard...I agree with you all the way.....I'm almost tempted
to say...."quietness is next to godliness".....but no sense in overdoing
it.....
.GeoR38 the ol soaring pilot!!!
<< Could not have done that with a CB.
john h >>
John, you're good.....looking forward to meeting you at Oshkosh......GeoR38
Subject: | Fly-in breakfast |
FYI
EAA Chapter 540 will have their annual fly-in breakfast at Smoketown
airport on May 24 starting at 8:00 AM. Rain date is May 25. Smoketown
airport is in Southeastern PA about 8 mi South of Lancaster Airport and
about 30 mi. West South West of the Kolb Factory. Smoketown is in the
heart of the Amish county so come on over and enjoy!
Terry
MK III 77.8 hrs. just got my Repairmans certificate for my MK III.
Subject: | PROP SPACER/ extension |
Guilty as charged. There are 2 methods used to get the required prop
clearance on a SlingShot, but this may be the only model where this
is done.
First is the normal prop extension that spaces the prop farther from
the gearbox. Everyone is pretty familiar with this.
Second is a spacer that's placed under the rear engine mounts to tip
the engine forward. On a SS, there's a (roughly) vertical aluminum
fairing that closes up the rear of the cage. It's not quite parallel to
the prop as you might expect it to be when viewed from the side.
If you bolt an engine to the mounts on a SS without tipping the
engine forward, you find that the smallest clearance between the
prop and airframe occurs between the tip of the lower blade of the prop
when it's positioned vertically, and this fairing. Tipping the
engine forward moves the lower tip of the prop to the rear, away from
the fairing.
Hopefully, this will clarify what we were talking about.
Rusty (one more week in Cleveland) Duffy
Subject: | engine conversion ? |
Hi all,
For some crazy reason, I'm actually considering upgrading the engine
on my SS from the 503 to something larger. The minimum increase
would be to a 582, but alternatives are also being considered.
I guess my question is about the cost. What would be the cheapest
way to go from my current 503 (new a year ago with 25 hours now) to a
582? Should I just sell the 503 complete, then buy a 582 complete?
Are there enough interchangeable parts (gearbox, carbs, ignition,
etc) to be worth trying to buy just the bare engine from someone like
LEAF, perhaps with a trade in of mine? Sure wish I had my LEAF
catalog with me here in Cleveland.
Anybody heard from the 2SI Twinpack SlingShot recently?
Any other recomendations for a suitable engine ?
Rusty (It's John's fault) Duffy
Subject: | Original Firestar |
The discussion about extensions and spacers makes me wonder what the
original Firestar builders did in this regard, if anything. Perhaps it is
not necessary?
Also, I'm in the covering stage now and had directed the following question
to Ralph Burlingame. However, he was unable to help because he did not have
the problem on his. So, John, and any other Original owners, how did you
cover the cage just below the vertical aileron push rod? When the stick is
pushed left this push rod protrudes below the bottom of the cage. If I
cover the bottom, without some sort of provision, the bottom end of the push
rod would go through the bottom covering material. How did you handle this?
Ron Carroll
Original Firestar
Independence, Oregon
Subject: | Re: engine conversion ? |
>Hi all,
>582?
>Thanks,
> I have not tried one yet but have heard from 3 different sources
that the R&D Aerosports tuned exhaust systems actually perform as
advertised. If true, your 503 would make 62 HP @6500 rpm and 10 lbs more
torque at cruise. Why don't we all encourage you to gamble, ah, invest your
money in one and then let the rest of us know how it works?
Their ad is on page 10 of the May Ultralight Flying , their phone # is
715-355-0536. For a 503, it is $350 for plain steel, and $495 for
stainless.
Also they claim 82 HP for the 532, and if my wing/windshield mod
doesn't give me the performance I expect, (3 more weeks and it will be ready
to test) I will be letting all of you know how well their pipe works on the
water cooled Rotax.
Richard Pike
Subject: | Re: Original Firestar |
>not necessary?
Keep in mind that the front-back clearance issue is mostly for IVO propped
engines cuz of the IVO flexibility. I'd check w/ IVO or KOlb, but just
for grins, a quick tape measure look at mine in the garage looks like there
is about 4" front-back clearance. (Mine is a KXP and i believe is the same
as an original FS in this area.) As for shimming rear engine mounts up or
down on all Firestar models (i think), there are 2 purposes: 1. clear the
fuselage boom by at least 1" and 2. yaw trimming. Yes, yaw trimming.
(Details of this have been mentioned previously but ask if you missed that.)
The orig FS and KX/KXP are the same in this respect too. Yes, the vertical
aileron pushrod does protrude thru the bottom of the cage covering where it
ties to the lower bell-crank. To make a neat and sturdy hole in the bottom
covering, I used a "C" shaped piece of plastic and just folded the fabric
back over it (to the inside) with Polytac. I cut the C piece from a 3"
inspection port ring. (These inspection ports are a ring and aluminum cap,
cost about nothin, available at AC Spruce.) Basically I just used covering
technique as if this were an inspection port, but without the aluminum cap.
The other option is to not make a hole and only make right turns. :-)
-Ben Ransom
>Hi all,
I sure don't want to say anything that might jeapordize your RV8 budget,
but ...
If a 2SI Twinpack has any merit in this discussion I would also think
HKS should be considered. And, should I muck this up further by
mentioning the word Hirth?
Rusty, you just gotta get outa Cleveland ...that place is making you crazy.
Take deep breaths, then change your daydreams over to which engine to get
for your RV8, even if you've already decided. :-) I'm partly serious here
because my guess is that any 2-stroke beyond a 503 is still just a 2 stroke,
but with more parts to break than a 503 has. So much time down the 2-stroke
rat-hole that you'll never get to build your other plane.
-Ben 'sour on 2-strokes' Ransom
Subject: | Re: (Fwd) Re: engine conversion ? |
> stainless.
Pity I don't get the Ultralight Flying magazine. This sounds quite
interesting, but I'm not sure it's the answer to my problems. If I
had some re-assurance that the engine would tolerate the added power,
I'd send them a check in a heartbeat. I'll have to think about this
some more, and probably give them a call to get some info.
I also recall hearing of a company in Ft. Walton Beach, FL (30
minutes from my house) that makes a higher hp carb for the 503. This
falls in the same category of products.
I'm mostly looking for cruise speed, but it has to be reliable. My
home airport has very few options for a damage free landing if the
engine quits during the first/last few minutes of a flight. I'm not
sure I really want to be pushing the engine beyond it's design
limits.
Rusty (Dang that John) Duffy
In a message dated 5/2/98 8:56:37 PM Pacific Daylight Time,
rpike(at)preferred.com writes:
<< What would be the cheapest
>582? >>
To my way of seeing things the cheapest way to get into a 582 is to get a
used one. All of the major service centers have used engines for sale. At
one point I talked to Phil Lockwood of locwood aviation about getting a
rebuilt older 582 that had been brought up to date with all of the
improvements. The price was a substantial discount.
go for it russel it is way cheeper and easier then a whole engine swap,
besides curious readers want to know!
Topher
Hi Rusty: the carb from Ft. Walton is an Altimizer. Try www.altimizer.com.
Bill Griffin
Subject: | Fuel tank grommets |
Hello fellow Kolb folks: The fuel tank grommet in the bottom of the fuel tank
of my original FS is leaking. Gotta change it. Do these things just pull out?
Sure hope so. Can't do anything to the fuel tank w/o tearing the fabric off
the cage! Got a new grommet from Kolb Co. last week.
Bill Griffin
>limits.
Know what you mean. I only need a LOT of horsepower for about 30
seconds, then back to normal.
One of our local pilot/engineers has covered up all the
aerodynamically dirty spots on his Firestar II, and it cruises fast. Wish I
could get him on this bbs. Will give him a call, and see if he will e-mail you.
Richard Pike
Called Vince up and asked him about more speed for the SS. He said
that his Firestar II will easily cruise at 80 with less than full throttle,
if he runs a lot of prop pitch. He has a dual carb 503 with the GSC prop.
But he said takeoffs and climbout are awful with that much pitch in the
prop. He has modified his FS II with fairings, cuffs, etc, but he said that
the SS incorporates most of what he has done, so no real help there. Sorry.
Richard Pike
MKIII N420p (42oldpoops)
Subject: | Re: Fuel tank grommets |
Hi Bill,
Bummer about the fabric. My jugs (I can't really call them tanks)
are hard to get to, but at least I don't have to mess with the
fabric. You might want to consider getting a new jug, and putting
the grommet in the top like all the newer Kolbs seem to be. Maybe
that would help you avoid the fabric work next time. Just a thought.
Rusty
From: | "Scott Olendorf" <olendorf(at)empireone.net> |
tank
out?
off
I had the exact same problem. It took me about 1 hour to reach down under
the tank and replace that sucker. I actually have 2 of those very close
together, one is for a fuel site line. You will have to reach in from
behind the seat with some pliers and yank. Have some Band-Aids handy. I
just recovered my Firestar and left the fabric off behind the seat so I can
remove the gas tank in the future.
Scott Olendorf
Original Firestar with Rotax 377
Schenectady, NY
Date: Sunday, May 03, 1998 10:50 PM
Subject: Kolb-List: Re: Fuel tank grommets
>tank
>out?
>off
Oh, just remembered. I also was able to rotate the tank upside down first.
The hard part was removing and replacing the hose clamps. Use a socket
wrench on those. Not a fun day.
Scott Olendorf
Schenectady, NY
Dear Kolb friends,
I have a friend who's looking at an Ultrastar (I beleive this is how it's
called. It's the Kolb with the high tail boom and single engine behing the
pilot) to buy it. I haven't seen the airplane yet but I have offered
assistance in inspecting it. Is there anything you guys may now about that we
should look for in this particular aircraft?. If you have experience with the
aircraft, what do you think of it?.
Christian Martin
Date: Sunday, May 03, 1998 11:34 AM
Subject: Kolb-List: (Fwd) Re: engine conversion ?
your
# is
>> stainless.
>limits.
>-SORRY RUSTY,
I TALKED TO THE GUYS WITH R&D AT SUN & FUN, AND
THE GRAPH I SAW DID NOT INCREASE RPM, IT APPEARED
TO ME THAT THEY HAVE SPENT ALOT OF TIME ON A DYNO,
AND HAVE COME UP WITH A PERFECTLY TUNED EXHAUST.
I BELIEVE THERE ORIGINAL BACKGROUND WAS SNOWMOBILE
ENGINES.
JOHN
From: | "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM> |
Subject: | Rusty's need for speed |
Rusty have you considered the benefits of an in-flight variable pitch prop?
I know they are expensive, but I think it is the answer to your needs. I hate
to steer anyone toward the IVO product, but there isn't much choice.
I know a guy with a Titan, 503 and IVO electric adjustable, and it seems to
work great, with adequate take-off and incredible range.
If it doesn't satisfy, I know this great newsgroup you can advertise it
for sale on... You can't loose much more than a couple hundred dollars on it
if you keep it looking good, compare that to an engine swap.
Have fun in Cleveland..., isn't that the home of the Rock and Roll museum?
> ENGINES.
> JOHN
Dear Troublemaker :-)
Thanks to everyone for their comments, but at this point, I'm
leaning toward a bigger fix. I just don't think the 503 will be
enough engine regardless of the hot rod tricks.
The R&D pipe looks good from the ad that Will sent me, but I think I
wouldn't be comfortable using the extra power continuously during
cruise. For climb, it would be great since that's a fairly brief
event that the engine would likely withstand.
An in-flight adjustable IVO is something that I had in mind from the
beginning. I'm still wondering how much good it would do. I've
heard people swear by, and AT them.
Currently, I'm thinking a 582 with the R&D pipe would be pretty nice.
I'm looking into the cost of swapping now. I might try adding the
in-flight adjustable feature to my current prop to see how much good
that really does. If I move up to a 582, I'll just order a 3rd blade
for my prop and trim them to the appropriate length. An electric
starter would be nice too. Many options to consider.
Thanks again,
Rusty
Subject: | Re: Ultrastart Info |
Chm12345 wrote:
> Dear Kolb friends,
> Christian Martin
Dear Christian,
I wish I could point out all the experience I've got with this particular
aircraft. But I just soloed in it this past Saturday. Bought it from my BFI.
He's a person I'd trust with my life (and did). After 5 flights, my vast
experience says this plane is a winner! It's solid in the air and found
landings were much easier than when crow hoppin. BFI's name is Steve Wallace,
email nette(at)crawdat.com. I'm sure he'd be able to give you much more
valuable information.
Good luck to your friend.
Don Martin
Subject: | Re: FW: Fly-in breakfast |
Scott Bentley wrote:
> The message I sent that bounced...
> > Cc: Doug Lack
> > Subject: RE: Fly-in breakfast
> > I'll try to be there. Doug: You want to fly out with me?
> > Terry: I presume you saw http://scott.bentley.com/sunnfun981/pic00008.jpg
Yes, I enjoyed the photos!
> > Did you have to go to Allentown to get your certificate? I still don't
You may find this hard to believe but my certificate was hand delieverd
from the Harrisburg office. A friend of mine knew one the the guys at
the FAA office and mentioned my application was coming through. This
FAA guy said he had something else to do in Smoketown so he picked it up
and brought it down and I met him there. I had it within two weeks of
application. Actually, the whole Experimental aircraft process worked
very well. FAA sent me all the forms I needed in one package in the very
beginning with samples filled out and all the instructions for N number,
Airworthiness, Amateur-Built Statement, Repairmans, etc, etc.
See ya at Smoketown.
From: | Cliff and Carolyn Stripling <striplic(at)nationwide.net> |
Subject: | Humor attempt concerning !!!!POWER!!!! |
To all,
The ever ongoing never ending persuit of POWER !!!!! More is better!!! I
think I will re-engine...
My wife and I just got back from the drag races. Those cars reach over 300
mph in about 4 seconds and darned near break your ear drums doing it... even
with your ears stuffed with stoppers. I have never heard such a noise. It
goes right through your bones. The acrid smoke of tire rubber and who know
what kind of exhaust fumes. Really bad stuff to breath. ...but exciting
it is!!!
Anyway, perhaps one of those engines would fit on my Kolb. I would have to
put a training wheel about half way back on tbe boom to prevent the tail
spring from being bent and about a ton of counter weight in the nose. Of
course, I would have to beef up the main gear and engine mount, install a
huge fuel tank, an accelerometer and mach meter and maybe a blast diverter
at the take off end of my airport. Hot dang, the excitement and rush it
would provide. Give me MORE POWER!!!
Actually, the 582 already pushes my head back deep into the seat cushion
(small exageration here) as it accelerates to takeoff in 3 or 4 seconds and
then transitions to an extroidinary climb (the kind of course only a Kolb
can do... and the people who see it say... Ooooooooh!!!) to pattern altitude
even before reaching the end of the runway. To then power back and float
around the pattern to approach and land (and if needed assistance of the
barn door - elevator like - put it on the ground right now - flaps).
Nah! On second though, I have enough power.
Later,
Cliff & Carolyn Stripling Him: Kolb MKIII - N582CC (43.3 hrs)
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
Both: 5th Wheel - RV - Travel
____________________|_____________________
___(+^+)___
(_)
8 8
Subject: | Re: Humor attempt concerning !!!!POWER!!!! |
<< To all,
think I will re-engine... >>
Sounds like Tim "the toolman " Taylor to me. Uhhhh! Ahhhh! Uhhhh! MORE
POWER!!!
Bill Varnes
Original FireStar
(with anemic 377 power)
Audubon, NJ
From: | TSherret <TSherret(at)PrismSolutions.com> |
Subject: | RE: Humor attempt concerning !!!!POWER!!!! |
Perhaps a used steam catapult from a decommissioned carrier would suffice.
http://www.chinfo.navy.mil/navpalib/ships/carriers/g-washington/gw-cats1.jpg
> From: Cliff and Carolyn Stripling [SMTP:striplic(at)nationwide.net]
> Sent: Monday, May 04, 1998 12:10 PM
> Subject: Humor attempt concerning !!!!POWER!!!!
> To all,
> 300
> even
> It
> know
> it is!!!
> to
> and
> altitude
> Later,
> ___(+^+)___
> (_)
> 8 8
I've never had to replace the tank grommet on my Original FireStar. They
do pull out because I really had to push it in there when I put it in.
You may consider either leaving the rear section of the cage uncovered,
like I did, or cover just the bottom half like the FireFly. In either
case cut off the ducktail and the steel plugs used to support the
aluminum ribs on the cage. I used a dremel tool with a cutting disk to
cut the steel. It cuts through like butter and you can get in close.
Ralph Burlingame
Original FireStar
>fuel tank of my original FS is leaking. Gotta change it. Do these things
just
>pull out? Sure hope so. Can't do anything to the fuel tank w/o tearing
the
>fabric off the cage! Got a new grommet from Kolb Co. last week.
>Bill Griffin
Be prepared to fly the time off again.
Ron
Date: Monday May 04 1998 8:32 AM
Subject: Kolb-List: Re: (Fwd) Re: engine conversion ?
>> ENGINES.
>> JOHN
>Thanks again,
>Rusty
(Netscape Mail Server v1.1) with SMTP id AAA237
Subject: | original firestar |
Hello Kolbers..I got another question for you. I recently brought
an original Firestar home and in setting it up from its folded state I
notice that there is an awful lot of play in the connection of the strut
to the fuselage and also to the wing for that matter. When I put in the
pin and secure with the safety pin, there still is probably 1/4 or 3/8
inch fore and aft of the pin. Is this normal or should there be a
bushing to take up the play there. At such a critical connection point
I want to find out before attempting even a hop. Thanks Larry in
Sussex - original Firestar
another
question for you. I recently brought an original Firestar home and
in
setting it up from its folded state I notice that there is an awful lot
of play
in the connection of the strut to the fuselage and also to the wing for
that
matter. When I put in the pin and secure with the safety pin,
there still
is probably 1/4 or 3/8 inch fore and aft of the pin. Is this
normal or
should there be a bushing to take up the play there. At such a
critical
connection point I want to find out before attempting even a hop.
Thanks Larry in Sussex - original
Firestar
Subject: | Re: kolb: cutting cables easier. |
writes:
>I have always used a swiss made cable cutting tool called FELCO C7
>with excellent results. The ends are square with absolutely no
>fraying and no need for tape. Cost, around $45. Ray Lujon
>_________________________________________________________________Hi Gang
A little slow in offering this note. Yes, the FELCO C-7 is an excellent
tool for cutting cable. Cost today at "Wicks" is $47.55. However, if
you belong to an EAA Chapter generally someone has this type of tool you
can borrow. Ray Lujon is right on the money.
This past weekend EAA Chapter had their annual Pancake Fly-In breakfast.
The weather gods where not in our favor. Aircraft fly-in's were from
close by, but one was a Kolb Firestar - owner/builder/pilot Ken Mancus
with close to 500 hours flying time. We had a GREAT 2 days meeting new
and old friends just taking flying!!
Mon May 4, 1998
Bob Cooper
Malaga, NJ
Owner pilot of Pazmany PL-4A and a Kolb wanna-be.
Subject: | Re: original firestar |
Larry,
My original Firestar is the same and has 345 hours, including 0.8
hours tonight, so it should be O.K.
John Jung
Original Firestar For Sale http://www.execpc.com/~jrjung/
> strut to the fuselage and also to the wing for that matter. When I
> put in the pin and secure with the safety pin, there still is probably
> 1/4 or 3/8 inch fore and aft of the pin. Is this normal or should
> there be a bushing to take up the play there. At such a critical
> Thanks Larry in Sussex - original Firestar
Christian,
There are several Ultrastars in my area (SE Wisconsin) that I have
been aware of. They have spent much more time being repaired then being
flown. I believe that the design is unforgiving for pilots with less
than necessary experience. They are much more difficult to repair than a
Quicksilver. Their pilots claim that they are great flyers, and some
prefer their flight characteristics to Firestars. I my opinion, they can
be good planes for the right pilot, but the right pilot probably knows
what an Ultrastar is, and is willing to accept it's limitations.
John Jung
>Chm12345 wrote:
> Dear Kolb friends,
> Christian Martin
Larry,
I made aluminum bushings for the bottom struts on both sides. You could
go to a hardware store and find some 1/4" nylon bushings and cut them to
length. Do the same for the 5/16" clevis pins on the cage holding the
wings. This will keep the pins from backing out to the safety rings (you
guys are using rings, I hope, instead of the safety clips that came with
the kit).
Ralph Burlingame
Original FireStar
writes:
>strut to the fuselage and also to the wing for that matter. When I put
in
>the pin and secure with the safety pin, there still is probably 1/4 or
3/8
>Thanks Larry in
Christian,
I had a chance to fly an UltraStar once and it's a very nice plane. It's
drag is lower than you would think and has a good cruise because the
pilots profile is inline with the engine's drag. It's very light and does
it climb! The day I flew it, the thermals were active and I got up to
3000' agl and didn't think I was ever going to come down. The Hall
airspeed indicator read 60 mph. I agree with John Jung about flying one,
they are a higher performance ultralight and should to be flown like one.
I wish the factory still made them along with the Original FireStar.
Ralph Burlingame
Original FireStar
>Christian,
>being flown. I believe that the design is unforgiving for pilots with
less
>a Quicksilver. Their pilots claim that they are great flyers, and some
>can be good planes for the right pilot, but the right pilot probably
knows
>John Jung
>>Chm12345 wrote:
>> Dear Kolb friends,
>>it's called. It's the Kolb with the high tail boom and single engine
>>behind the pilot) to buy it. I haven't seen the airplane yet but I have
offered
>>about that we should look for in this particular aircraft?. If you have
experience
>>with the aircraft, what do you think of it?.
>> Christian Martin
>Larry,
>the kit).
>Ralph Burlingame
>Original FireStar
> Years ago, the local Hummer dealer had a ring snatched out by a twig
while taking off from a grass strip. Rings are better than safety pins, but
can be improved by wrapping them with a 3" long strip of electrical tape.
Let about 1" hang out in the breeze, and you can easily unwrap it when you
get ready to disassemble. Makes it almost impossible for them to be knocked
out, and doesn't look too tackey.
Richard Pike
via smtpd (for www.intrig.com [206.54.183.49]) with SMTP; 5 May 1998 07:32:52 UT
(Netscape Messaging Server 3.0) with SMTP id AAA17797;
Subject: | Re[2]: kolb: cutting cables easier. |
If you have a Dremel tool (high speed electric motor) they work great.
Use one of the ".020 thick abrasive blades. Wear goggles, only one
set per customer.
Don't forget to put your second backup ferrule on before cutting.
1. Mark the cable where you want to cut it.
(Hint - those copper wire clamps used to connect large copper
wires together work very well for holding the cable in position
during the swaging operation)
2. Wrap a short piece of masking around the cable centered over the mark
Cut at through the masking tape and the cable.
The masking tape prevents the cable from fraying while cutting - the
blade kind of lightly welds the small wires together if you do it
right.
3. Peel the remaining tape off.
Time for ice tea.
Jerry
Subject: Kolb-List: Re: kolb: cutting cables easier.
Date: 5/4/98 8:36 PM
writes:
Mon May 4, 1998
Bob Cooper
Malaga, NJ
(Netscape Messaging Server 3.0) with SMTP id AAA17796;
Subject: | Re[2]: (Fwd) Re: engine conversion ? |
The problem the ThunderGull guys have had with the in flight
adjustable is the vibration from the Rotax shakes the electric motors
apart. They tried a different motor and thought they had it licked
but as a while it had problems also.
Some inspectors will reduce you test time if you already had some time
on the airplane. Expect anywhere from 10-25 hours.
Jerry
Date: 5/4/98 8:19 PM
Ron
-----Original Message-----
>> ENGINES.
>> JOHN
>Thanks again,
>Rusty
Subject:Richard Pike's modifications
>water cooled Rotax.
Richard, does your mod to the windshield/wing attempt to reduce the drag?
If so, please post results after testing, including photos if you can, a few
of us want to cruise faster.
Thanks!
Subject: | Re: Firestar II vs Original Firestar |
Group,
Last night I answered one more of my questions about the differences
in the original Firestar and the II. Stall speed. I had thought that the
II stalled 7 mph faster than the original. I retested the original last
night in very calm, smooth air, with a GPS, and the real difference is 3
mph.(35 vs 38) My Firestar II weighs more, has 10" clipped off each
wingtip and has the II's smaller ailerons, so 3 mph is reasonable. Next,
I will be testing the full windscreen on the II.
John Jung
Firestar II N6163J 4.8 hrs
My original Firestar is coming along nicely (thanks to guys like John &
Ralph). Will finish covering very soon and start painting. Next comes the
blah, blah, blah . . .
The time for christening will be here and I can't help but wonder what some
of you guys call your planes. I've always liked "By George" (GeoR38), and
I'm pretty sure many others have names and tales of how the name came about.
Right now my top candidate name is "Cumulus Bimbo", but may get some other
ideas from the list.
Ron Carroll
Original Firestar
From: | "friend(at)bright.net" <dczolling(at)email.msn.com> |
Subject: | engine insturments |
Hello
I would like comments on who makes agood electronic
engine monitor dual CHT/EGT ,TACH.
Thanks in advance Duane FS2
From: | "Russell Duffy" <rduffy(at)servecom.picker.com> |
Subject: | Re: engine insturments |
The Grand Rapids EIS unit is great IMO. It's a bit more expensive
compared to the essential instruments, but it gets to be a better
value when you consider all the other features it gives you. Perhaps
the best part is the small size for all you get. Mine is currently
providing- dual EGT, dual CHT, Tach, Engine hours, Flight timer,
Fuel gauge (using aux input). There are other functions built in,
but you have to have the sensors. Also, you can get optional
features like fuel flow, and ASI/VSI. The only gripe I have with the
unit is that you can't customize the main screen that you view during
flight. They give you several options that include several
parameters each, but it always seems to end up showing something
you aren't using, like coolant temp, or OAT. Nevertheless, I like
it, and will likely use on in the RV as well.
Rusty (only a few more days) Duffy
From: | "rutledge fuller" <rut007(at)hotmail.com> |
If anyone is interested, I have a BRS 4 UL1 (out of date $690 for BRS to
upgrade/repack to a BRS 5) that I would like to sell. Price nego. I am
going to upgrade to the BRS 5 UL2 Leading Edge Softpack for the
Firestar. This model is supposed to fit under the gap seal. Does
anyone out there have this model. Any comments for me before purchase?
I would also be interested in any used gap seal softpacks 750 lbs.
chutes.
Hello Kolbers..I got another question for you. I recently brought an
original
still is probably 1/4 or 3/8 inch fore and aft of the pin. Is
this normal or should there be a bushing to take up the play there. At
such a critical connection point I want to find out before attempting
even a hop. Thanks Larry in Sussex - original Firestar
Larry,
The front-back slop is "normal" for the lift-strut-to-cage, but like
others have replied, I also use bushings. I cut my bushings from
5/16" AL tubing, works great.
I don't know why Kolb made such a wide space in the cage receiving end
for the lift strut. Maybe the clevis pin is way stronger than
necessary
anyway, and the wide gap is just something that didn't get refined for
production. Although the wide gap is obviously strong enf, it is
not ideal aesthetically (or from an engineering stand-point), and
bushings
are an easy fix.
On the lift-strut-to-wing clevis fitting, there is no play in the
per-plans
design. Kolb has taken care of this with the steel piece bolted onto the
wing tang.
Ralph: On the main-spar-to-cage you mention that your bushings keep the
pins
from riding out against the rings. I don't see how, unless you mean
that
the pins can simply ride out to the point of pushing the bushings
against
the rings. I'm not sure this is any better except that soft bushings
(such
as nylon or rubber?) would be softer against the rings. Could you
please
clarify?
And to anyone, over the years I've heard several people say that rings
are
better than Clevis safety clips, yet so far as I know, Kolb still ships
with
safety clips. For this reason I personally have stayed with the safety
clips. I've replaced them with new clips at about 100 hours to be on the
safe side. As for changing to rings, I know it is possible to go buy
rings
that "look right", but they may be a lousy alloy meant for nothin much
more
than your keys. How do you know they are good enf to hang your hide on?
(I once bought a set from LEAF, and just didn't like the looks of
them.)
-Ben Ransom
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
I have a BRS-5 UL-2 chute from my Pterodactyl. I called BRS to see what I
need to mount it on my Original Firestar and the parts come to $281, plus
freight. WOW! The parts are for mounting it behind the seat, not in the
gap seal area. I could mount it in the gap seal area for next to nothing.
I realize the 'potential' hazards of a top mounted chute becoming entangled
with a collapsed wing (any other considerations?), but it sounds like most
Kolbers have them there. If it is mounted behind the seat it has to
penetrate the Poly Fiber covering on the cage when deployed. Maybe there
should be an 'exit' door in the side of the cage. Also, I would have to
provide access to it for maintenance and inspections.
I'm just trying to get a feel for what to do before I finish covering the
cage (sorry, Ralph, I'm covering the rear too)
Ron Carroll.
Ron and group:
I spoke at length with Dan from BRS yesterday afternoon. Between the
two mounting options for the Firestar, he recommended the softpack gap
seal mount to me. I specifically asked about folded wings using this
mount. He did not feel that this was a problem.
Any comments?
>From: "Ron Carroll " <ron.carroll(at)worldnet.att.net>
>To: "Kolb mail list"
>Subject: BRS chute
>Date: Tue, 5 May 1998 08:30:13 -0700
what I
plus
the
nothing.
entangled
most
there
to
the
>Ron Carroll.
Subject: | Engine instruments... |
I have had good luck with the cheap Skysports instruments. They are mounted
in a 1/8" aluminum panel, shock mounted to the fiberglass nose. I lost one
EGT sending unit (of course), and a ground wire broke on the engine from
vibration, otherwise all is well. The EIS looks cool and I like the alarm
features, but I am a proponent of simplicity and I like the idea that if I
get a bad instrument after the warranty period, it will cost less to replace
the discrete analog units than starting over with a new 600 dollar EIS
(probably less to replace one instrument than to repair EIS, if repairable).
Also, I see what I want at a glance, the instruments I've chosen.
Be sure to provide some vibe isolation for whatever you choose, it will prolong
the life greatly.
I have the softpack in the gap seal, and I think it is the best
chute installation for a Firestar.
John Jung
> chutes.
Ron,
I used to worry about an 'exit' for the chute too, until I whatched
one deploy through three layers of fabric at Oshkosh. It went through
the dacron like it was tissue paper.
John Jung
>Ron Carroll wrote:
>snip
>snip
> Ron Carroll.
Subject: | Re: Engine instruments... |
Well, let's shoot this one down....quickly. Talked to Greg, owner of
Grand Rapids, on 5/5/98. Out of 2000 + units sold, two have come back
for repairs. One of those involved an LCD failure from suspected
extreme cold. The other was a component failure. And, get this....to
date, Greg has only charged one....that's uno, ichi, .....person $40
for a repair that was self-inflicted by the owner (he opened the case
to do his own mods and didn't quite get it right....fried the unit,
as a matter of fact).
So.....make your choice.
Jim Baker
Pres, USUA Club 104
Frontier Ultralight Aviators
Oklahoma City
Subject: | Instruments, warranty... |
That is GREAT! This Greg is really trying hard to get and keep your business
at this early stage of his product's life. I am impressed.
I hope he can keep it up for you. I wonder how long he can stay in business
doing out-of-warranty repair for free? Hopefully for as long as you own your
plane. That would be really cool. Guess I should've bought one. Thanks for
"shooting me down".
From: | Scott Bentley <Scott.Bentley(at)Bentley.Com> |
kolb(at)intrig.com
Subject: | RE: Instruments, warranty... |
Golly, I guess I'm the one in 2000, since I did in fact return mine...
But I enthusiastically endorse Grand Rapids Technology. They've been great.
> From: Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM
> [SMTP:GERKEN(at)RCHVMX.VNET.IBM.COM]
> Sent: Tuesday, May 05, 1998 3:55 PM
> Subject: Instruments, warranty...
> business
> business
> your
> for
> "shooting me down".
Subject: | Re: Name that plane |
Ron,
How about "Sweet Fifteen" since it's serial #15, isn't it?
Ralph B.
writes:
>& Ralph). Will finish covering very soon and start painting. Next comes
>the blah, blah, blah . . .
>some of you guys call your planes. I've always liked "By George"
(GeoR38),
>and I'm pretty sure many others have names and tales of how the name
came
>about. Right now my top candidate name is "Cumulus Bimbo", but may get
some
>other ideas from the list.
>Ron Carroll
>Original Firestar
Subject: | covering you rear |
Ron (Carroll),
I didn't cover the rear portion of my Original FireStar cage for a number
of reasons. If you do cover, it will give you more drag because the area
along the sides and in back of the seat acts like a parachute to capture
air if the cockpit is left open. This explains in part why my 377 pushes
it along at a 60 mph cruise.
The other reasons are: saves weight, access to the tank, inspection of
the cage and aileron linkage, I can see the tank for positive fuel
management, I can see behind me while in flight, and I never have to
replace the covering when it gets worn out from being saturated with
spilled fuel. Nice benefits, huh?
Ralph (just trying to be safe) Burlingame
Original FireStar
Richard,
I've never had one come out or even look like it was going to come out in
all the years I've been flying this off of grass. I setup and take it
down everytime I fly too. You do remember the post about the safety clip
that did come loose. Which would you prefer?
Ralph Burlingame
Original FireStar
writes:
>a twig while taking off from a grass strip. Rings are better than safety
>pins, but can be improved by wrapping them with a 3" long strip of
electrical
>tape. Let about 1" hang out in the breeze, and you can easily unwrap it
when
>you get ready to disassemble. Makes it almost impossible for them to be
>knocked out, and doesn't look too tackey.
> Richard Pike
Ben,
Without a bushing of some sort on the main 5/16" clevis pins, they will
back out no matter which way you install them. The bushing is mainly to
keep the pin centered in the cage so your safety is in the middle of the
pin rather than toward the end of it. I can see the end of the clevis
pins and the safety rings in flight and it's somewhat disturbing to see
the clevis pins backed out to the safety ring w/o the bushing. Maybe it's
just a psychological thing, but a bushing makes me feel safer.
I think if you stick with the stainless steel rings you can't go wrong.
Original FireStar
writes:
>the pins from riding out against the rings. I don't see how, unless you
mean
>that the pins can simply ride out to the point of pushing the bushings
>against the rings. I'm not sure this is any better except that soft
bushings
>(such as nylon or rubber?) would be softer against the rings. Could you
>please
>clarify?
>are better than Clevis safety clips, yet so far as I know, Kolb still
>ships with safety clips. For this reason I personally have stayed with
the
>safety clips. I've replaced them with new clips at about 100 hours to
be on
>the safe side. As for changing to rings, I know it is possible to go
buy
>rings that "look right", but they may be a lousy alloy meant for nothin
much
>more than your keys. How do you know they are good enf to hang your
hide
>on?
>(I once bought a set from LEAF, and just didn't like the looks of them.)
>-Ben Ransom
From: | Jhann Gestur Jhannsson <johann.g(at)centrum.is> |
Hi Kolbers.
I have been asked by a fellow ultralighter here in Iceland to try to
find him a used Rotax 447 engine from USA.
Does anyone on the list have or know of any such engine for sale?
Thanks in advance,
Jhann G.
Iceland.
From: | "Henry C. Wortman" <hwortman(at)mail.datasys.net> |
The following link is about an ultralite fatality between Savannah &
Hinesville, GA. that occured last Sunday.
http://www.savannahnow.com/stories/050498/LOCpilotcrash.html
Dear Kolb friends,
Greg (the guy that manufactures the EIS) has treated me so well I fell
obligated to write this comment.
I have an EIS in my Firestar and I absolutely love it. Not only that, I had
initial problems with my instrument readings, and Greg sent me a new one just
because it would be easier to diagnose the problem (it was later found taht
the problem was the voltage rectifier/regulator and not the instrument). After
fixing the problem, the instrument has worked great so far. My instrument
includes all engine monitoring stuff, standard with the EIS, plus the
altimeter, rate of climb reading and fuel level (I have the rear bulkhead
covered with fabric). This is really a nice way to go in the tiny Firestar
panel if you want all this instrumentation. I'm sure that if the instrument
needs to be repaired, he'll charge you the minimum required. I noticed he
takes great pride in his instrument so he won't rip you off. I also bought my
airspeed indicator, fuel level probe and BRS from him.
No, I don't own stock in his company (chuck) but I'm truly pleased with having
him supply me this items. If you buy his instrument, I recommend you call him.
Chris Martin
>Ron Carroll
>Original Firestar
Hi Ron,
Glad you're nearing the [blah, blah, blah ...] stage. :)
My $.02 on the naming: I'd stay away from names with a personally
derisive although humorous slant. It just seems a bad idea to give
"anti-ultralighters" more material than they come up with on their
own.
-Ben 'no plane name' Ransom
Subject: | Trying to locate Lowell Metz (fwd) |
Forwarded to the list:
---------- Forwarded message ----------
Date: Tue, 5 May 1998 21:20:43 EDT
Dear Kolb friends,
I'd like to get in touch with Lowell Metz. If anyone knows his e-mail address
I'd like to rely him this note.
In any case Lowell, if you [are a member of] this list, it is you the one that
needs to be congratulated for your achievement in Sun'n Fun. Your Firestar is
truly a work of art, and now that it has Holmer's signature, it's even an
original. Please let me know your e-mail so that we can stay in touch. I got
your phone call. What a joy and surprise, thanks.
For those who don't know Lowell's Firestar, it is painted like a Monarch
butterfly and it is truly spectacular. He achieved "Reserve Grand Champion"
status at SnF. Way to go !!.
Chris Martin
Heres one for Dennis
If any one knows you do.Don't be shy we need the info. What are the
main causes of crashes in Kolbs and what structual failures have occured
(not counting the famous test pilot who went out to pull the wings off an
Ultrastar.)
Dick
Woody
by PM04SM.PMM.MCI.NET (PMDF V5.1-10 #27036)
Hello Group: Well, I lost my service with MCI on 4/28. After a LOT of
thrashing and roaring around, and many hours on hold, I finally got hooked
back up a few minutes ago. This is the last - and final - issue in a long
string of frustrations and angry-vations with MCI. Tonight I'll hook up
with Earthlink and Hotmail. Mean-while, when I checked for new mail after
all this time, there were just 15 messages. 15.....huh !! Then I realized
they were all from 4/28/98. Last one was John Jung at 9:02 AM about Dual
CDI Rotax. A call to MCI on the cell phone resulted in a 45 min. hold,
followed by a dial tone. Aaaaarrrrrgggghh !!!! Does anyone know if the
missing messages can be accessed through Majordomo, or somewhere - anywhere
I really enjoy the interplay on our group, and hate the idea of all that
gone down the tube. Help !! Big Lar
I don't know if this is true, but FWIW I have heard that some FAA inspectors
don't like the safety pins and insist on rings.
Tom King
124 King Dome Road
Our name is King, our house is a Dome, and it's OUR road!
Date: Tuesday, May 05, 1998 5:03 PM
Subject: Kolb-List: Re: Rings
>Richard,
>Ralph Burlingame
>Original FireStar
>writes:
>electrical
>when
>> Richard Pike
>Get completely free e-mail from Juno at http://www.juno.com
>Or call Juno at (800) 654-JUNO [654-5866]
The EIS seems like a wonderful bunch of gages all wrapped in a very small
package but you do give up some advantages in the bargain. If the power
fails, ALL the gages fail. Same for the display and probably a few other
"single component failures" would result in the loss of all.
It does sound like the unit is very reliable 'tho and after all, it's not
like anyone will be using it for IFR flight (well, maybe I assume too
much!). My only problem with electronic gadgets is that I've made my
living with them (computers) for nearly 20 years now (forgive me, Ron
Carroll). There's an old saying, "Familiarity breeds contempt."
There's also an old flying adage, "Trust Your Instruments."
But my personal favorite is a line from an old movie, "Open the pod bay
doors HAL! ....HAL!!!"
Bernoulli and Newton have done ok by me. Bill Gates on the other hand....
-Mick ("Lightening BAD ..Fire GOOD!") Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Hi All: My new e-mail address is larrybiglar(at)earthlink.net
ex-biglar(at)MCI2000.com Big Lar.
>Richard,
>Ralph Burlingame
>Original FireStar
Ralph, I am using the safety pins that came with the kit, but they
are rusty, and need to be replaced. It is time for the stainless steel rings
and electrical tape!
One other more cynical consideration: a stainless steel ring wrapped
with about three turns of electrical tape is less likely to be "adjusted" by
stupid or malicious passers-by, and the condition is evident at a glance,
while the safety pin clip is easier to open, and to be open, but still in
the clevis pin. We DO live in evil days...
Richard Pike
In a message dated 5/5/98 7:06:50 PM Pacific Daylight Time,
richard.wood(at)usa.net writes:
<< What are the
main causes of crashes in Kolbs and what structual failures have occured >>
In my experience the far and away most common cause of Kolb crashes is
stupidity. Remember, there is a huge unreported reservior of incidents that
merely result in close calls and bent gear legs.
I know of no reported structural failures in Kolbs that aren't also
enmeshed with builder stupidity. The one I like best was a Kolb builder who
apparently forgot that big-ass bolt that goes through the wing spar and holds
the steel fittings for the lift strut. All that held the lift strut to the
wing was the three pop rivets. He is reported to have flown for several
minutes . . . .
Remember that the average kolb product probably flies less than 40 hours
per year. So its not likely that the fleet as whole is going to have alot of
metal fatigure problems. From my perspective the big long term problem is
dissimilar metal corrision on aircraft which were not primed.
Hello All: Well, changing the grommet wasn't the monster that I thought it
would be. Fastened a pair of vice grips on the fitting, closed my eyes and
pulled hard. POP! When I built the plane, I only covered the upper half of
the back bulk head. Made a velcro attached cover for the bottom half, so I had
no problem getting to the thing. it's just that fooling w/the "unremovable"
gas tank worries me.
As for the thread on safety rings: since I don't trailer my Kolb, I bushing-up
everything and bolted it all together. Makes your airframe tighter and seemed
to make a difference to me.
Bill Griffin
Subject: | Re: Name that plane -Reply |
Try this - You name it after your wife. Then when you want to use family
funds for the airplane you say nothings too good for ......
My $.02 worth Rick Neilsen VW powered MKIII - still land bound.
some
and
about.
other
>Ron Carroll
>Original Firestar
Hi all,
My proposed fuel tank change would involve adding an electric pump
(4.5 psi max pressure) to the system. The easiest way to add it would
be inline with the pulse pump, but I'm pretty sure that's not really
recommended. If memory serves, a regulator is supposed to be used
if you do that because of the possibility of overpressurizing the carb inlet.
I'm just curious- has anyone tried doing this without a regulator?
Did it cause any problems? I don't really see how any serious
overpressure can occur, and it would be nice to reduce the number of
potential leaky fittings. I'd probably have to run the electric pump
all the time because I don't have an electric starter. After all,
what good would a backup pump be if you can't restart in air.
Unfortunately, even as I plan this new fuel tank and in-flight IVO
prop, I realize that I'm not doing my lack of performance any good.
Between the extra 3.5 gallons of fuel, pump, battery, and IVO motor,
I guess this will add about 30 lbs. An electric starter would be
nice too. Maybe I'd better find a bigger engine first.
Weighing the options (Ha!)
Rusty
In a message dated 5/6/98 2:17:10 PM Pacific Daylight Time,
rduffy(at)servecom.picker.com writes:
<< The easiest way to add it would
This is question I put some work into. The pressure regulator
recomendation comes from the folks at CPS. When I was setting up my fuel
system I had a series of talks with them that left me rather unimpressed. The
principal problem is this there are about 6 different kinds of in line facet
pumps with differing through puts and pressures. And if you don't know the
part number you can't tell them apart. The guys I spoke with at CPS were
completely uninformed about this. The other key thing you need to know is the
maximum pressure that the needle valve in the carb is supposed to be able to
handle. That number is, as I recall, 7 psi. If you buy the pump which CPS
wants to sell you which, if my recall is correct, puts out 4.5 psi you
probably don't have much a margin of safety and should have a pressure
regulator to prevent the pump from overpowering the needle valve. I dug a
little deeper and found that the smallest pump facet makes puts out about 1.5
psi.
So I bought the smallest facet pump and put it in line. The big question
is will the engine driven pump by itself be able to draw fuel through facet
pump and up to the carb. My plan is to use the facet pump on take off and
landing, just like a GA plane. I can blow air through the facet pump so I
figure the fuel will go through as well. I dunno. I'm going to run my engine
for the first time soon and will report. I'd welcome comments from the group.
I suppose the alternative would be to install a T upstream and downstream from
the pump and send a hose around it.
>Hi all,
>Rusty
Rusty and all:
My Firestar w/pt ign 447 had 18 gal alum tank, pulse pum on engine and
Facet elec pump for boost and back up. I had no battery, but the elec pump
kept me out of trouble. Before I ran this setup I lost a fuel pump at 100
feet at the end of a 3000 ft toilet paper cutting spree at the Flight Farm,
in Monterey, NY, in 1989. Had I had the elec pump, I would not have lost
the eng.
The Mark III has the same facet mounted pump under the fuel tank and has
performed well with the 582 and 912. This pump has 1131 hours and still
keeps on pumping. I have never used a regulator and never had a problem
with fuel overpressure.
I use the pump on t/o and landing, and when I am at low altitudes where I
would not have time to react to a main fuel pump failure.
I have enough time in the Sling Shot now, that at Lakeland this year there
was no real transition period from the MK III to the SS as in the past. I
flew it very hard all week primarily in very turbulent wind conditions.
Very seldom got below 6000 rpm and spent most of the time around the
pattern, which seems like 20 miles, at 6200 to 6600 rpm. This was a new
582, had 1,5 hrs on it when I started flying. EGTs were a little high, up
near 1200 and 1250, but each day saw them come down a little, until the end
of the week they were running about 1100 to 1150. New cables stretched
some during the week and the carbs got out of sync, but Bill Martin
graciously sync'd them back up for me and the EGTs which had gotten 100 deg
apart, then came back together pretty close, within 25 to 50 deg of each
other.
I missed flying the SS with 912 at Oshkosh last year, but Dennis said that
it didn't perform that much better than the 582. The 582 seems to be a
real good match for the SS and I wouldn't recommend flying it with anything
less if you want to have a lot of fun with a really fine fun loving
airplane that still maintains Homer Kolb's nice flt characteristics.
Should be a good flyin at Jones Light airstrip, Smiths Station, Al; the end
of the month. If you are in the Southeast or anywhere else for that
matter, come on out.
See you there.
john
Richard,
Yes we do live in "evil days" and this is why at a fly-in event where my
plane is surrounded by people, I see that all the rings are in place
before I fly. This reminds of a time when a buddy of mine had kids
yanking on the lift struts thinking it was a jungle gym. He was furious
when he saw that! Another common one is for kids to blow into the pitot
tube to see if their buddy sees it register in the cockpit.
Ralph Burlingame
Original FireStar
writes:
>wrapped with about three turns of electrical tape is less likely to be
"adjusted" >by stupid or malicious passers-by, and the condition is
evident at a
>glance, while the safety pin clip is easier to open, and to be open, but
still
>in the clevis pin. We DO live in evil days...
> Richard Pike
Johann,
There is one documented case where the safety clip came out in flight. I
believe it was on the flap and the landing was uneventful. One more
problem is that it can open up (the one on the tail-bracing) if it snags
in grass or other debris while taxiing. The rings are easier for me to
put on and I think they are safer because it's like a key-ring, it would
have to be physically moved around the ring circumference to come off.
The safety clip is under constant spring tension to keep it in place.
Just one more thing to go wrong.
Ultralights are safe if you know how to fly them and take care of them.
Ralph Burlingame
Original FireStar
writes:
>Hi Ralph
>I am new to the Kolb aircraft and flying it, so I am curious to know
>why you do not recommend the safety clips from Kolb?
>Have there been any accidents or does the safety pin damage anything?
>Please inform me of your experiance, because we up here in Iceland are
>still in the pioneer stage and would appreciate any information to
>prevent accidents or injury in our sport. It is difficult enough as
>is, to convince the authority that ultralights are the safest way of
>flying.
>Best regards from Iceland
>Jhann G.
Russell Duffy wrote:
> Hi all,
Rusty
I installed an electric fuel pump below the gas tanks on my MK III
w/912. It was the low pressure one, as I recall, 2.5 was max psi. When
you figure the amount of pressure required to push the fuel up to the
engine and the output of the engine driven pump, I was still below the
max pressure rating of the carbs. I have the EIS system which I really
like with a fuel pressure sensor installed after the engine fuel pump.
What is interesting is I see no different in fuel pressure with one or
both fuel pumps. The electric pump by itself does register on the EIS
but is very low. I confirmed the electric pump will get the fuel to the
engine by removing the fuel line and extending it a couple feet above
the engine. It does the job and certainly doesn't over power the carbs.
Terry
Yep, that seems to be a valid concern. I'm already worried since I'll
be running a longer fuel line to the new tank in the back seat area,
so the resistance of the flow through the electric pump (not running)
would be even more to worry about.
My plan is to put a 13.5 gallon tank in the back seat and ditch the
jugs, but I've also thought of keeping one of them. I could leave
the current fuel system as is, and use the electric pump to transfer
fuel to the jug as needed. There are some good and bad points with
this plan as well though.
BTW- I can almost hear Dennis groaning now when he hears me
whining about the fuel setup again :-)
Rusty (slowest SlingShot in the world) Duffy
Subject: | Minimum power for SS |
I've had this same conversation with Dennis. For the record, he
tried to talk me out of the 503, but I thought I knew better (when
will I learn). You can't say the SS doesn't fly OK with the 503, but
it just doesn't have the right personality. Remember when you could
by Mustangs with 4 cyl engines.... same thing. Looking back on it, I
can't believe I got the 503, because I've always been a "more power"
kinda guy.
Still trying to work it out.
Rusty (last night in Cleveland-yeah)
via smtpd (for www.intrig.com [206.54.183.49]) with SMTP; 7 May 1998 00:26:54 UT
(Netscape Messaging Server 3.0) with SMTP id AAA13357;
Subject: | Re[2]: Engine instruments... |
I'll have to agree with this. My partner and I are more than pleased
easier to read and also has larger display size.
It has worked great and earned it's keep while doing the engine break
in. That red light would quickly tell you if the temps were exceeding
the thresholds you preset. Works great.
Does Grand Rapids Technologies have a email address by chance. We got
the OAT probe and would like to see if he could modify it to put the
temp on the base screen since we don't have any AUX options.
Jerry (Happy EIS Camper) Bidle
Subject: Kolb-List: Re: Engine instruments...
Date: 5/5/98 8:53 PM
Dear Kolb friends,
Chris Martin
>Date: Wed, 06 May 1998 17:10:17 -0500
>To: rduffy(at)servecom.picker.com
>From: john hauck <hawk36(at)mindspring.com>
>Subject: Re: Fuel pumps
>Bcc: Kolb Builders List
>In-Reply-To: <199805062113.RAA03247(at)servecom.picker.com>
>>Hi all,
>>Rusty
>Rusty and all:
the eng.
other.
end of the month. If you are in the Southeast or anywhere else for that
>See you there.
>john
inlet.
from
Hey Gang:
Unless your system is any different than mine (see msg I sent to Rusty
Duffy and the List a few minutes ago), it'll work. Been flying with facet
and eng driven pump on Firestar/447 and MK III/912. Never had a problem.
Any questions? give me a shout.
john
>inlet.
Gents,
What is wrong with adding a passive pressure regulator in series with the
fuel pump?? It'll prevent overpressure and smooth out the fuel pump
pressure pulses (not a problem as far as I know). I first used a pressure
regulator on a McCollough O-100 used on a Bensen gyrocopter in 1965.
Worked well. I use a pressure regulator on my 1970 Porsche 911-T to this
day. ("T" doesn't signify turbocharged) The 2 tripple barrel carbs like
it. :) FWIW, the Mikuni fuel pump runs the Cuyuna just fine. :)
Skip
1984 UltraStar
from>the pump and send a hose around it.
I have my Facet pump and the Mikuni pulse pump side by side on
adjacent brackets with a t-fitting above and below, then feeding into a
regulator.
I run the Facet continuously. The first time I ever set up this type
of plumbing system, it seemed complicated. Now I wouldn't do it any other way.
Richard Pike
Larry,
About a year ago I found the Kolb list archives and saved the file in my
bookmarks for future reference. I just retrieved the url for you and
when I tried to bring it up, I got a "not found on this server"
response. The URL is (was) listed as: www.intrig.com/kolb/list/
See if you or anyone else can bring it up. It is of tremendous
reference.
John Hanson
Downingtown, PA
So John, I take it you have the pulse pump and Facet pump in series?
Another twist on this: I've generally thought that, when taking off,
landing, or flying low, those are the last times I want to change
anything on the engine, including fuel supply rate or pressure. Me
thinks that if it has been running fine for 30 minutes, don't change
anything for the next critical 1 minute. So, I've let this logic
(or bad logic?) keep me with only the single pulse pump.
I've also heard that the pulse pumps are incredibly simple in how
they function. Any comments from you all on known rate of failure?
John, you had one quit on you. Did you determine the cause of pump
failure? How old was it? Is it reasonable to assume that if the
pulse pump is rebuilt every couple years that it is extremely
reliable?
This discussion has renewed my thoughts about adding a Facet pump and
therefore also a small battery, but i need more convincing -- and am
open to it -- that they are worthwile.
-Ben Ransom
Subject: | Messages, Fuel Tanks |
Thanks, John Hanson for the try on my lost messages. I tried the address
you sent me, and came up with the same result. Anyone else ???
Hi Rick: What's happening with your plane ?? I've been looking forward to
seeing that happy message by now. BTW - I'm calling mine "Vamoose". No
wife, so what's a guy gonna do ??
My .05 on fuel - I got the factory 16 gal. Aluminum tank when I ordered my
Mk III, and it is beautiful. Very nicely done, however I've seen many
problems in the past with solid mounted Al tanks cracking under vibration.
It's possible these won't do that, but didn't want to take a chance.
Bought a 12" square of 1/8" gum rubber, and a length of fairly heavy wall
surgical tubing. Wrapped pieces of sheet around tank mounting area of
frame, reamed out the mounting holes, and put tubing over the bolts, with a
washer of gum at each end, backed up by a steel washer. Result - you can
pull or push on the tank, and it will move about 1/4". More than that, it
backs up against the bolts + washers. May have made extra work for
myself, but I absolutely cannot see that thing cracking. Big
Lar.
writes:
>my plane is surrounded by people, I see that all the rings are in
>place before I fly. This reminds of a time when a buddy of mine had
>kids yanking on the lift struts thinking it was a jungle gym. He was
>furious when he saw that! Another common one is for kids to blow into
>the pitot tube to see if their buddy sees it register in the cockpit.
>Ralph Burlingame
>Original FireStar
A few of us went to a local airshow (not a fly-in) several years ago. The
'Airboss' wanted the UL's to fly a couple laps around the pattern during
the show so we had to attend the 'pilot briefing' at 9:00AM sharp. It was
kinda neat being in the same briefing with Patty Wagstaff, Jim Yonkin and
others. Usually, if UL's get invited at all it is for 'static display'
only. Anyway, we exited the briefing room and strolled back to our
planes. When I got within 100 yards of the Flyer, I could see two hefty
little boys one about 4 and the other maybe 6 sitting, one on each wheel
pant. Mom and Dad were standing in front of the plane, taking pictures.
Apparently they had ducked under the bright red tape around the parking
area and ignored the signs on each plane saying, 'Look but Please Don't
Touch.'
I'm a pretty quiet guy by most accounts but I covered that 100 yards in
about 2 seconds shouting at Mommy and Daddy to "Get those boys the hell
off my airplane!!" Mom, Dad, the 2 boys, and me were all very surprised
at my outburst and I tried to diffuse the situation by explaining that a
wheel pant was just too light a structure for even a small boy to use for
a seat. Well, that seemed good enough for Dad but Mom just had to turn
around and reply with, "Well I sure wouldn't fly in that g__damn thing if
it's THAT flimsy!..." A better man would have just let it pass but I
snapped back with something like, "Nobody asked you to lady, but I flew
it here and I gotta fly it home so just stay the f__k away from it!" I
turned toward Dad at that point expecting him to take a swing but he just
turned, lifted the tape for his sweetie and they walked away (I was
pretty glad too, he probably had 80 lbs on me - and she had at least 40).
It still bothers me, I expect that those boys were turned away from
aviation entirely on my account. I'm sure it wasn't their idea to pose on
my wheelpants for the photo-op any more than it's their fault they have
idiots for parents. The truth is that our type of aircraft are not big
and threatening like 'real' airplanes and people just aren't intimidated
by them. I don't think 'evil' is nearly as scary as just common
'stupidity.'
-Mick Fine
Tulsa, Oklahoma
> -Ben Ransom
A little input. I added a Facet electric pump in parallel to the pulse pump on
my Rotax 503, dual carb, engine. I picked up the fuel feed with a "Y" after the
fuel filter and "Y'ed" after the pulse pump output to both carbs. Many hoses
and clamps. "Basket of snakes" is what I call it. Works great! The electric
pump picked up the fuel from the tank and filled the lines and carbs in about 3-
5 seconds. The Bing 54's handle the pressure without any problems. No
pressure regulator is needed as the electric pump pressure is only 2 1/2- 4 1/2
lbs. This is the pump from Aircraft Spruce #40105 for $28.25. Good for takeoffs
and landings although you can leave it on all the time. A little noisy when dry
but quietes when pumping fuel.
Hope this helps,
Larry Davis (Challenger 1 "Songbird")
Marion, Indiana
ldavis(at)netusa1.net
http://www.netusa1.net/~ldavis
From: | "W.B.Whitehead,Jr." <behead(at)linknet.net> |
Subject: | ROTAX RAVE VALVES |
HI,
DOES ANYBODY KNOW HOW TO SET THE RAVE VALES ON A 618.THE ADJUSTMENT IN
QUESTION IS THE RED ADJUSTERS ON THE RAVE VALVE COVERS.THANKS
BENNY WHITEHEAD
E-MAIL:behead(at)linknet.net
Subject: | Fuel pumps again, questions to John on failure |
>the eng.
Was this the older style single outlet Mikuni pump, or the current dual-outlet
type? Was it equiped with the pulse-fitting bleeder hole, as they are now?
Was it mounted with the pulse-port downward, as recommended?
Thanks for the info, it may reduce my to-do list.
>-Ben Ransom
Ben:
The pumps are in series.
Pump failure due to "no name" diaphram purchased from LEAF many years ago.
Be sure when you overhaul pump that you are getting mikuni parts. Pumps
are extremely reliable. Biggest problem is not pump, but tubing which
carries crankcase pulses to pump. Overtightening metal hose clamps and
"old age" (deterioration) of the tube.
I guess fuel pump redundancy is similar to parachutes: Don't need it until
I need it, and I may never need it.
The Facet pump will operate right off the voltage reg/rec. Don't really
need to haul around a battery dedicated for the pump. I bought the last
pump for my Onan generator at Western Auto on the Puralator rack. They
package it under the Puralator name but if you look closely you will see
Facet stamped on the pump. The package also indicates operating pressure,
about 3.5 psi.
>Richard,
>Maybe I missed something here. Are the fuel pumps (pulse and electric)
>"valved" such that fuel cannot backflow through them? Otherwise it
>appears a failure of either pump would allow the fuel to loop back
>throught the failed pump and you wouldn't acheive any pressure.
>Gregg Waligroski
>FS2
> Correct. Both pumps have check valves and are one way. I suppose a
major internal collapse of the guts of either could void the check valve,
but I think bad a failure is unlikely.
Richard Pike
MKIII N420P (42oldpoops)
> reference.
Well, it was... Arond the time of the Christmas holidays last year,
the archives were accidentally deleted. And I never restored them...
The archives exist, unfortuantly not in a online form.
The list will probably be moving in the next month or so, and the
new provider will more than likely provide online access to the
archives (past & present) via the web.
So .... bear with me until I can move the list.
Jeff R. Stripling
jstripli(at)io.com
(512) 252-3053
John Hauck wrote:
Pumps are extremely reliable. Biggest problem is not pump, but tubing
which carries crankcase pulses to pump. Overtightening metal hose clamps
and "old age" (deterioration) of the tube.
AMEN! I use a pulse line made by inserting a length of soft 1/4"
aluminum fuel tubing inside a length of blue CPS urethane 1/4" fuel tubing,
with flex-relieving curves at each end, and enough slack that the aluminum
should not bend and work harden. I clamp the urethane to the aluminum in
several places so that even if the aluminum should crack, the pressure
pulses are mostly confined inside the aluminum tube, and everything is
confined inside the urethane tube.
The aluminum keeps the pulses "solid" , and also keeps the crankcase
heat from the pulses away from the urethane.
I like it, but have not seen anyone else doing anything similar.
Opinions?
Richard Pike
Subject: | Fuel pulse pump, improvement to pulse line |
Richard provided:
Sounds like a great idea to "stiffen" the tubing. Questions; Does the alum.
line go inside of the Blue Urethane? And does the Urethane still go all the
way from the crankcase to the pump (no splices, right?)?
Gleaned from others' input to my question last week about proper orientation
of the pulse pump mounting and the bleeder hole: Keep an eye on the pulse
line, if you see oil collecting in it you may have a blocked bleeder hole.
Thanks for the idea!
jim
Subject: | Dart II Radair ELT question |
A long time ago I bought a Dart II Radair ELT that I'm thinking on installing
on my FireStar. My Piper Colt partner told me it maybe obsolete as far as the
FAA goes. Does anyone know if this ELT model is still legal?
Will Uribe
Building a Fire Star II
http://members.aol.com/WillU/index.html
Piper Colt, Hanger Queen
http://members.aol.com:/pa22108
Subject: | please don't touch |
Mick,
That was an excellent story. I think a guy does have to hold his temper,
though, because some of these kids (and adults) just don't understand the
"whys" of light planes. My son moved a CAF Corsair elevator up and down
when he was little guy. One of the CAF guys got upset and set a poor
impression on him that lasted for years. That certainly is not what the
CAF wanted to do, but that's how it turned out. What really "gets" me is
that at some of these fly-in events they have the aircraft roped off with
the usual "please don't touch" signs and the ultralights out where people
can walk around them. If I am with my FireStar at such an event, I will
allow the kids to get in and out of the cockpit, under my supervision,
and let people move the control stick. They get a kick out of that and I
see no harm in it. I just have to watch them closely so they don't get
carried away. By the way, ultralights do get stolen occasionally and all
they have to do is flip the kill switch to "on" and pull the starter
rope. It may be more difficult for a potential thief to steal mine
because I have the kill switch turned upside down so it doesn't look like
a switch. This is not the reason I originally did this, that's another
story. Let me know if you want to hear that one.
Ralph Burlingame
Original FireStar
>The 'Airboss' wanted the UL's to fly a couple laps around the pattern
>during the show so we had to attend the 'pilot briefing' at 9:00AM
>sharp. It was kinda neat being in the same briefing with Patty
>Wagstaff, Jim Yonkin and others. Usually, if UL's get invited at all
>it is for 'static display' only. Anyway, we exited the briefing room
>and strolled back to our planes. When I got within 100 yards of the
>Flyer, I could see two hefty little boys one about 4 and the other
>maybe 6 sitting, one on each wheel pant. Mom and Dad were standing in
>front of the plane, taking pictures. Apparently they had ducked under
>the bright red tape around the parking area and ignored the signs on
>each plane saying, 'Look but Please Don't Touch.'
>in about 2 seconds shouting at Mommy and Daddy to "Get those boys the
>hell off my airplane!!" Mom, Dad, the 2 boys, and me were all very
>surprised at my outburst and I tried to diffuse the situation by
>explaining that a wheel pant was just too light a structure for even a
>small boy to use for a seat. Well, that seemed good enough for Dad but
>Mom just had to turn around and reply with, "Well I sure wouldn't fly
>in that g__damn thing if it's THAT flimsy!..." A better man would
>have just let it pass but I snapped back with something like, "Nobody
>asked you to lady, but I flew it here and I gotta fly it home so just
>stay the f__k away from it!" I turned toward Dad at that point
>expecting him to take a swing but he just turned, lifted the tape for
>his sweetie and they walked away (I was pretty glad too, he probably
>on my wheelpants for the photo-op any more than it's their fault they
>have idiots for parents. The truth is that our type of aircraft are
>not big and threatening like 'real' airplanes and people just aren't
>intimidated by them. I don't think 'evil' is nearly as scary as just
>common 'stupidity.'
>-Mick Fine
>Tulsa, Oklahoma
Subject: | What to expect??? |
John,
You might let the kolb list know what to expect if you bring a show plane to
SNF or Osh. I met you at SNF while I was nosing (but not touching) around
your plane about 3 years ago. You were very nice on that occasion and
answered all my questions. I have always wanted to take my Kolb to one of
the big events and would like to know what to expect.
Later,
___(+^+)___
(_)
8 8
John and Ben,
These are very good questions about auxiliary fuel pumps. I have one more
question:
Which way is better to connect the auxiliary pump, in series or parallel?
I think the Mikuni pumps are very reliable because there really isn't
much to go wrong except the check valves. The diaphragm doesn't move much
and simply vibrates back and forth with pulse pressure from the pulse
line. If the diaphragm did crack, it would give warning because I flew
with one and made a successful landing with power. I rebuilt my pump with
a diaphragm I got from one of the aftermarket places and noticed it was
not the mylar type that was in the original Mikuni pump. I put it in the
pump with some reservations and took off after a good runup. The engine
ran rough and I felt a kicking in the seat on takeoff. I kept the
throttle at midrange or it would have quit. When I landed, I noticed the
weep hole was leaking fuel. When I took the pump apart, I saw a cracked
diaphragm. It was hard to see and I suspect that it somehow got creased
and caused the leak. The pump is reliable, but for $20 bucks why not
change it out every 200 hours.
For the pulse line I use standard auto fuel line. It really cannot be
beat and a hose clamp is necessary to keep it tight. By doing this I
never have to worry about the pulse line collapsing or the clamps cutting
into the line. BTW, if you see bubbles in the fuel line, the screw type
auto clamps will do the trick. If you are using them on UL fuel line,
then clamp them over a piece heat shrink tubing or something like that
(black electrical tape?) to keep them from cutting into the line.
Ralph Burlingame
Original FireStar
writes:
>>>where I would not have time to react to a main fuel pump failure.
>>>and therefore also a small battery, but i need more convincing -- and
am
>>-Ben Ransom
>Ben:
>The pumps are in series. Pump failure due to "no name" diaphram
purchased >from LEAF many years ago. Be sure when you overhaul pump that
you are >getting mikuni parts. Pumps are extremely reliable. Biggest
problem is not >pump, but tubing which carries crankcase pulses to pump.
Overtightening >metal hose clamps and "old age" (deterioration) of the
tube. I guess fuel pump >redundancy is similar to parachutes: Don't need
it until I need it, and I may >never need it. The Facet pump will operate
>really need to haul around a battery dedicated for the pump. I bought
the
>last pump for my Onan generator at Western Auto on the Puralator rack.
>They package it under the Puralator name but if you look closely you
will
>see Facet stamped on the pump. The package also indicates operating
>pressure, about 3.5 psi.
>john h
Subject: | Need help.fuel problem |
Hi and thanks for reading this message.
I have a "new" 1987 firestar with a Rotax 377 with about 20 hours
total time airfram and engine.
Problem...
Bubbles in the fuel line from the pump to the carb. I have rebuilt,
changed fule lines, clamps, and finally a new pump from rotax with no
help. Bubbles start at about 4000 rpm. The engine runs fine but the
bubbles concern me. Everything in the fuel system is new exept for the
fitting at the bottom of the tank. Nothing worked. The guy at Rotax
says there should be no bubbles. BTW, the pump is mounted on the egine
block as specified, and is insulated from heat via 4 nylon washers.
The pump get a little warm (maybe 100F) but not hot. After a flight
there is a bubble four inches long in the line between the pump and
the carb while the engine is idling. I am reasonably certain that the
fittings ae not leaking, as no bubbles are vivible in any other fuel
lines when the engine is running.
Your suggestion are needed....Thanks
Bob Gross Jupiter, FL
Captain Robert P. Gross
American Airlines MIA
561-744-8055
<< 'm just curious- has anyone tried doing this without a regulator?
what good would a backup pump be if you can't restart in air. >>
I've used a Purolator pump plumbed in parrellel with the pulse pump on a Mark
III for 120 hours - no regulator - so far no problems. The fellow I sold the
plane to has another 10 hrs on it - no problems so far. Only use the elec.
pump for T.O.
Pete Krotje
Subject: | Re: please don't touch |
writes:
>.... If I am
>with my FireStar at such an event, I will allow the kids to get in and
>out of the cockpit, under my supervision, and let people move the
>control stick. They get a kick out of that and I see no harm in it. I
>just have to watch them closely so they don't get carried away.
I do the same - when I'm right there with the plane. Unfortunately, none
of us volunteered to miss the briefing to watch our planes. We wrongly
assumed the red tape and signs would do the job for the half hour we were
absent. Still, I reacted very poorly and have regretted it ever since.
I think there's a difference in the public's attitude depending on what
kind of event it is. If they pay to get in, they feel (rightly) they are
owed something, I'm not sure that includes family photos on my wheelpants
but... Non-flyers who come to a free 'fly-in' seem to have much more
respect than those who pay to see an 'airshow.' I suppose some of them
feel cheated if no one has crashed by the end of the day.
The original point of this thread is still important, preflight your
aircraft VERY carefully at any public event. You never know what's gone
on behind your back!
BTW - I use the safety pins (AN416-1), not the split rings (no AN
designation that I can find) and have never found one open, broken, or
stolen -but I always check.
-Mick Fine
Tulsa, Oklahoma
Subject: | Re: Need help.fuel problem |
>Problem...
> I am not a big fan of mounting the fuel pump on the engine block,
(even with isolators)and it is possible that the bubble accumulation is
vibration induced. If possible, can you mount the pump off the block?
Richard Pike
via SMTP by pop-proxy01.primenet.com, id smtpd028889; Thu May 7 22:48:27 1998
Subject: | Hirth F30 Engine |
Does anybody know someone who runs Hirth F30 engine on
Mark III or any other aircraft? Need their experience.
Thks,
Edward
Subject: | Re: Dart II Radair ELT question |
What is this about the "legality" of an elt. if it works why can't you use it?
pete
(Netscape Mail Server v1.1) with SMTP id AAA159
Goodmorning Kolbers from Sussex N.J. Is a 50:1 gas/oil mixture ok
for a Rotax 377 with 70+ hours on it. I just got the Firestar with a
377 and I want to keep a good eye on the fuel that goes in it. Larry
original Firestar " CHEAP THRILL "
Goodmorning Kolbers
from Sussex
N.J. Is a 50:1 gas/oil mixture ok for a Rotax 377 with
70+
hours on it. I just got the Firestar with a 377 and I want to keep
a good
eye on the fuel that goes in it. Larry original
Firestar
" CHEAP THRILL "
From: | Cliff and Carolyn Stripling <striplic(at)nationwide.net> |
Bob and all,
I had to double up on the hose clamps at the fuel pump because the stubs out
to the nipple on the pump (at least on the dual carb one for the 582) are
smaller than the interior diameter of the fuel tubing except at the
retaining ring. The hose clamp would allow fuel and air leaking if you
jambed the hoses up against the fuel pump and away from the retaining ring
allowing leaking underneath. Pulling the hose away from the pump causes
them to snug up against the raised ring around the stub. I now have a hose
clamp behind that ring AND on top of that ring. That prevents movement of
the hose (and from it coming off) and provides a positive seal around the
ring itself. Don't know if that could be your trouble, but it was mine.
Later,
Cliff & Carolyn Stripling Him: Kolb MKIII - N582CC (43.3 hrs)
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
Both: 5th Wheel - RV - Travel
____________________|_____________________
___(+^+)___
(_)
8 8
From: | "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM> |
Subject: | Re; Need help on fuel system |
An area that leaked air into my system was the primer bulb. The bulb was
assembled with band clamps that were not tight enough to hold out air (they
were the kind that are crimped on with a special pliers and non-adjustalbe).
I replaced them with worm-drive calmps and cranked 'em down carefully so the
check valves were not crushed. I don't like it this way but it is the best I
can do for now. Hope this helps...
Subject: | SlingShot performance |
Hi all,
After much debate, I've decided that swapping engines on my SS would be too
expensive, and would take up too much of my potential RV building time. Also, I
really want to gain some climb performance along with cruise speed, and I can't
see any way of doing that without adding power, so here's what I decided to do.
1- I ordered one of the R&D pipes today. They seem convinced that there's no
added danger to the engine, and they're very confident about the performance
improvement over stock. I ordered the mild steel version for $350, and the
mounting kit for $72.95. He hopes to have one built for me and ready to ship by
next Tuesday, so maybe I'll have it before the weekend. It sounds like the only
mounting problem might be the oil reservoir. Currently, it's mounted to the aft
piece of angle that holds the muffler. A full report will follow.
2- I tried to order an in-flight adjustment upgrade for my IVO, but found out
that it isn't so easy to do. It seems that they had problems with the torsion
rod cams coming loose when using the in-flight adjustment option, so they came
up with a fix. The fix involves using a new cam and modifying the end of the
torsion rod to fit it. Unfortunately, this requires you to send the blades to
IVO to have them re-worked unless you somehow knew to specify "electric ready"
blades when you originally ordered the prop. Now let's see a show of hands- How
many people were ever asked if they wanted their blades to be "electric ready"?
At least they don't charge you any extra to rework the blade, but it's
frustrating to have to send the prop away for a couple weeks right after I get
back in town.
Maybe I'll fly the plane as much as I can this week, then send the prop away
when the exhaust arrives. While it's gone, I can make my fuel tank change, and
add the exhaust.
Russell Duffy
SlingShot SS-003, N8754K
RV-8A building
rad(at)pen.net
http://www.pen.net/~rad/
Subject: | Pensacola Fly-in |
Hi again,
I just got a flyer in the mail about a fly-in at Coastal Airport in Pensacola,
FL. It's being sponsored by the local UL club "Lite Blue Angels" on the weekend
of May 23rd and 24th. I won't demonstrate my poor typing skills by trying to
put all the info in this message. They give two contacts for info: Jim Hassell
(850-453-5180) and Ian Garnham (850-456-3533). If anyone wants a copy of the
flyer, send me a fax number and I'll try to get it to you.
Rusty
Have you tried the standard automotive stainless steel fuel line screw
clamps? I think the plastic rachet clamps just don't clamp tight enough
on the pump. I had bubbles in the line going into the carb for years with
no engine problems. After finally trying out the auto clamps, the bubbles
disappeared. Use some tape or shrink tubing to clamp them over the fuel
lines so they don't cut into them.
I would also take the pump off of your engine. It may vapor lock on a hot
day. You don't need to find a place to mount it. I have mine supported by
the fuel line and the heavy-duty pulse line (auto fuel hose). It works
out well with some cable ties to keep it in place. This arrangement is
probably the best for the pump since it sees almost no vibration. I never
got around to making a mounting bracket for it.
Ralph Burlingame
Original FireStar w/377
writes:
>total time airfram and engine. Problem...
Subject: | Re: Hirth F30 Engine |
> Thks,
> Edward
Go to...
http://www.dejanews.com/home_ps.shtml
and query HIRTH F30 and you'll get plenty of folks to e-mail.
Jim Baker
Pres, USUA Club 104
Oklahoma City
> Ralph Burlingame
Brackets are really easy. Get a couple of the MS21919 loop type
cushioned clamps big enough to fit 'round the large tube just under
the engine. Two screws or bolts of appropriate length, a couple
short sections of aluminum tube to use as spacers to hold the pump
away from the clamps and self locking nuts. You're done and there's
no drilling, bending, etc..
_______---_________
______ |_|________
|o|
Jim Baker
Pres, USUA Club 104
Oklahoma City
Thanks Jim, I'll put 'em in.
Ralph
writes:
> _______---_________
> ______ |_|________
> |o|
>Jim Baker
>Pres, USUA Club 104
>Oklahoma City
>pete
> Be careful talking like that. before you know it, you'll be using
"FAA" and "reasonable", and similar words in the same sentence.
Richard Pike
TRI ATCT, Kingsport, Tn.
<< The time for christening will be here and I can't help but wonder what some
Ron Carroll >>
Ron, I have additional motivation to name my wonderful Firestar "By George! "
as I have a little toy glider selling company called "AeroToys by George!"
and it was convenient to call MY PLANE that I BUILT in my own garage by that
name. I love it and everything else that is fiesty enough to fly and feel that
(as an electrical engineer givlng even a wire a name) that EVERYTHING should
be important enough to have a name.......if, of course, .... the item
is......important enough!!! Do you think that your Firestar is important
enough?........................................GeoR38
Subject: | Re: original firestar |
<< As for changing to rings, I know it is possible to go buy
rings
more
them.)
-Ben Ransom >>
Ben, I have the same concern about rings,.....I have them on my key ring and
they seem to spread and let my Keys go where ever the key wants to
go.....maybe I should try a safety pin on my keyring for a suitable
comparison.......but I'm sure the pocket would snag and have to be
resewn.............................GeoR38
<< I realize the 'potential' hazards of a top mounted chute becoming entangled
Ron Carroll. >>
Ron...I can speak to this too, as By George has the softpak chute mounted
UNDER the boom right behind the point of attachment to the cage. It is aimed
to fire horizontally , slightly down and back to clear the plane if the wing
falls off, or sumpin, related to my overtaxed scratchpad memory in
checlisting. It is well under the gas tank and should not cause an in air
explosion upon use!!!.....As far as I know , I'm the only one in the world who
would be audacious enough to consider such an unusual mounting technique, but
.....I'm curious George................................GeoR38
<< Ultralights are safe if you know how to fly them and take care of them.
Ralph Burlingame
Original FireStar
Who would have ever thunk it?!.......but I say this all the time .....even to
the tune of implying they are SAFER than GA cause everything is out in the
open ......for eyes that should
be!................................................GeoR38
From: | Frank Metcalfe <fmetcalf(at)ix.netcom.com> |
You might what to try to pressurize your fuel line system and check
around line connections with some dishwashing soap and check for bubbles
at the connections. The bubbles should not cause a problem becouse they
are asorbed by the fuel bowl. But it could be a indaction that trouble
is comming and should be addressed. If you do pressurize the fuel system
only use about 5 to 10 psi.
> Problem...
> 561-744-8055
> DO YOU YAHOO!?
> Get your free @yahoo.com address at http://mail.yahoo.com
Subject: | Re: GAS/OIL MIXTURE |
gas/oil mixture ok for a Rotax 377 with 70+ hours on it. I just got the
Firestar with a 377 and I want to keep a good eye on the fuel that goes
in it. Larry original Firestar " CHEAP THRILL "
I'd just go with the mix ratio specified by the oil manufacturer. It
varies.
For example, I've used Penzoil (40:1), then tried AV-2 (50:1) and settled
on
Duralube (40:1).
-Ben Ransom
http://mae.engr.ucdavis.edu/~ransom
There are two of us. I mounted mine low also.It is a Niagra spring load
Chute and being the only place to really put it on my Twinstar I figured it
would keep it out of the way of stuff if the wing folded.The bridle cable
may tangle in something and set me down a a strange angle but I will still
be alive.
Woody
Ben,
Wouldn't you want to use 50:1 recommended by Rotax? It seems the 40:1 may
cause premature ring sticking. I have read the rich mix would cause the
engine to run hotter, just the opposite of what you would think. I know
of some cases where the pilot wanted to "baby" the engine by using a rich
mix and ended up with a seizure. I think all the oils today have good
enough lubricating properties that a 50:1 mix is more than adequate
lubrication for the Rotax engine.
I buddy and I flew 150 miles today around the Twin Cities metro area. We
had a great time! I use Klotz all synthetic 50:1 and he uses Pennzoil
50:1.
Ralph Burlingame
Original FireStar
>>the Firestar with a 377 and I want to keep a good eye on the fuel that
>>goes in it. Larry original Firestar " CHEAP THRILL "
writes:>
varies. For >example, I've used Penzoil (40:1), then tried AV-2 (50:1)
and settled on >Duralube (40:1).
>-Ben Ransom
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
Hi all
Is there a reason not to just use auto fuel line hose for the entire
fuel system? It sounds like it is a sturdier type of tubing from what
you all are saying, and you can use the auto type clamps on it without
cutting into it. What is the reason for using the Ultralight type
tubing instead?
TOpher
<< Larry original Firestar " CHEAP THRILL " >>
Now!!....THere's a GOOD name!!!......................................GeoR38
Hi, I new to the list,, just wondering could someone tell me the difference
between a Firestar KXP and a regular Firestar?
Jerry Deckard
Jerry Deckard
>tubing instead?
I was planning to use all automotive type lines in my ongoing tank upgrade, but
since I decided not to add the electric pump, it turns out that I can use
everything just as it is. Probably, the first time I actually have to replace
some line, I'll switch to automotive type and all screw clamps. The biggest
advantage I see to the UL type, is that you can see the fuel. This allows you
to watch for air bubbles which could give you early warning of a leaky
connection.
Rusty
From: | "CHRISTOPHER DAVIS" <cdavis2(at)capecod.net> |
Hi Kolbers . I'm new to the list ,Iwas flying a firestar KXP on floats
untill the crows around the pond Ifly from discovered they could poke holes
through the fabric,and being the way crows are they prceeded tomake 39 holes
from the size of a dime to the size of a dog food can in my wings. I patched
them up to finish the flying season but they look like hell!! so,I amabout
to recover them but I have doubts about what to do about the fabric rivets
on the wings as I remember the ribs are quite smalltubing and drilling out
the rivets and replacing the m with the same seems like it could be a mess
has anybody done this job? I have concidered making new holes, rib
stiching,? I emailed kolb for help with this question,twice but recieved no
reply?Glad I found you guys!HELP! chris
-----Original Message-----
Date: Sunday, May 10, 1998 9:16 AM
Subject: Kolb-List: KXP
>Jerry Deckard
Chris,
I'm sure that one could use the auto fuel line for UL's. It's actually
better because it will last so much longer. The reason it's probably not
used is because it weighs more per foot. That may be the only reason.
It's ideal for the pulse line since it will clamp tighter and the wall
rigidity will not allow it to collapse.
Ralph Burlingame
Original FireStar
writes:
>Hi all
>tubing instead?
>TOpher
I have recovered my wings and used the same ribs. The fabric rivets are
large head aluminum ones and can easily be drilled out without enlarging
the rib holes. Since the holes are already drilled for you, use a pin to
find them through the fabric once it's covered.
Ralph Burlingame
Original FireStar
writes:
>holes through the fabric,and being the way crows are they prceeded
tomake 39
>holes from the size of a dime to the size of a dog food can in my wings.
I
>patched them up to finish the flying season but they look like hell!!
so,I
>amabout to recover them but I have doubts about what to do about the
fabric
>rivets on the wings as I remember the ribs are quite smalltubing and
>drilling out the rivets and replacing the m with the same seems like it
could be >a mess has anybody done this job? I have concidered making new
holes, rib
>recieved no reply?Glad I found you guys!HELP! chris
Here's a post from a regular kind-of-guy in this group, Ben Ransom. Here
he explains the differences in models and gives you a Kolb history
lesson. I fly the Original FireStar that has a 5 ribs/wing.
Ralph Burlingame
Original FireStar
KX and KXP models followed the original FS.
KX had slightly lower cockpit sides and long skinny wind screen. KX
could still make 254lbs with Rotax 447 if built on a diet.
KXP was same but with 7 ribs/wing (+2 false upper ribs per section)
and most KXPs also had heavier landing gear legs. KXP with
stronger wing could handle Rotax 503 but no way make 254 lbs
KX/KXP were replaced with current FS I and II models. Cockpit is
stretched a bit, big enf for jump seat (in II) or baggage (in I).
A FSII is generally registered as Experimental category as far
as I know. Wings are same as KX/KXP except I and II have slightly
shorter span ailerons and require aileron counter-balances.
- There are other minor differences.
- Both I and II have windscreen similar to original FS.
- FS I can be flown FAR103 with Rotax 277 (ouch), but better to
go for a FireFly.
-Ben Ransom
http://mae.engr.ucdavis.edu/~ransom (KXP pics)
writes:
>difference between a Firestar KXP and a regular Firestar?
>Jerry Deckard
via smtpd (for www.intrig.com [206.54.183.49]) with SMTP; 10 May 1998 23:02:52 UT
(Netscape Messaging Server 3.0) with SMTP id AAA23869
Subject: | Re[2]: GAS/OIL MIXTURE |
I have a lawn mower with one ratio, a weed wacker with another, and
boat motor with even another. (Looks like a tank farm) Would you not
use the mix ratio recommended by the manufacturer.
More oil in my opinion I would think would have a tendency to carbon
up the rings faster.
Jerry Bidle
______________________________ Reply Separator _________________________________
Subject: Kolb-List: Re: GAS/OIL MIXTURE
Date: 5/9/98 8:42 PM
Ben,
50:1.
Ralph Burlingame
Original FireStar
writes:>
>-Ben Ransom
From: | William V Rayfield <rayfiwv(at)mail.auburn.edu> |
kolb folks,
Time to paint the wings!
I would like to know what some of you did in order to support the wing
while painting it (primarily at the tips). I prefer not to drill a hole in
the tip so it could rotate and I could paint both sides in one sitting.
Other option is letting one side dry and just flip after it dries. Let me
know what some of you did. Thanks
Also:
Does anyone know if there are any of the old Ultrastar decals
around? If not, maybe where I could get a good look at one to have
something similar made up? I like the logo and would like to create
somthing similar for our plane and our trailer. Thanks
Bill Rayfield (Co-owner "new" Ultrastar with Don Rayfield)
"I'd rather be lucky than good"
Mech. Engr. Student
Auburn University
"War Eagle"
HI FRANK
HOW DID THE AULX. GAS TANK WORK OUT
Could you get a number so that I could give them a call I would like to
look at the tank ,
also do you have any pictures of your tank area, all of my tank ideas
start out like gang busters and after a while they sizzle down to well
maybe this is not just the way I wanted it to turn out. Do you , or
anyone on the KOLB LIST know of someone
who has got one of the KOLB 16 \ 17 gal. tanks . I sure need more
fuel cap.
Rick Libersat
writes:
>FYI, I just looked at my 582 top end @430 hrs TT and removed the
>cylinder
>head and exhaust system to inspect for carbon buildup after 120 hrs
>SMOH. I
>use AV-2 exclusively (from CPS) in the injection system. I was
>surprised to
>find only light carbon build up on the pistons and some on the top of
>the
>trapezoid rings that I removed with a razorblade and vacuum. The
>cylinder
>head was completely clean and only needed wiping off. At this rate I
>hope
>to get 300 hrs again before a complete decarbonizing service is
>required.
>Needless to say that I will continue to use AV-2.
>Just received my BRS-VLS-900 unit and will use my own brackets to
>attach it
>to the frame and place it as low as possible and as far forward into
>the
>gapseal as it can go.The rocket attachment has been moved to the side
>of
>the box which is very inconvenient and I may attach it separately to
>the
>frame tube. The gapseal will get a hinged section in the middle with
>the
>hinge attached to the aluminum leading edge. This section will cover
>the
>VLS and rocket laucher completely but it will have a 2" bulge at the
>rear
>end. Has anybody seen an actual launch of a BRS? Is there a heat
>exposure
>to the gastanks approx 1ft below the rocket during the lanch? I will
>ask
>BRS about this also and maybe have to build a blastshield to direct
>the
>flame to the rear.
>Frank Reynen MKIII@430 hrs
>http://www.webcom.com/reynen
> Out here in the Hooterville Mountains of East Tennessee, most
>all
>of
>us have been using Phillips Injex 2-stroke oil for a long time, no
>seizures,
>but the rings need cleaning every hundred hours.
> The Phillips distributor has moved out of town, and I was just
>leaving to go buy a case of Pennzoil when here comes this info that it
>also
>gunks up the rings.
> Once again, it looks like experience may be the best (and only
>reliable) teacher.
> P.S. Can anybody tell me if the MKIII wheels and bearings are
>the
>same as the Firestar wheels and bearings?
> Richard Pike
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
Subject: | M-III aux fuel tank |
Hey Rick, I can't help but answer your request. I have a friend with a
Mark-III, and he made a VERY nice 18-gallon tank for it. It fits under the
Boom-tube, just behind the seat. he has it plumbed in so that he pumps fuel
from it to the main tanks with an electric pump. If you want I'll see if I
can get more info and possible a couple of pictures of it for you.
Ron Carroll
Original Firestar
Independence, OR
Date: Sunday May 10 1998 7:34 PM
Subject: Kolb-List: Re: oil /VLS
>HI FRANK
>look at the tank ,
>fuel cap.
>Rick Libersat
>writes:
>>cylinder
>>SMOH. I
>>surprised to
>>the
>>cylinder
>>hope
>>required.
>>attach it
>>the
>>of
>>the
>>the
>>the
>>rear
>>exposure
>>ask
>>the
>>flame to the rear.
>>all
>>of
>>seizures,
>>also
>>gunks up the rings.
>>reliable) teacher.
>>the
>> Richard Pike
Subject: | Re: painting wings |
This may not be to much help I used the wing tip strobe , tied s/s
wire around it ,then on the other side of the wing the ( inboard )
where the tang is tied it with s/s wire then tied the two to the rafters
up in barn the leading edge was just about waist high this made it easer
on the painter. good luck , and DON'T FORGET to use a good mask
RICK L.
writes:
>kolb folks,
>hole in
>sitting.
>me
>Also:
>Mech. Engr. Student
>Auburn University
>"War Eagle"
Subject: | Re: M-III aux fuel tank |
Rick, I have some good news and some bad news. I just called my friend
regarding the tank he made for his M-III. I was wrong when I said it was
18-gallons. What it actually is is an 8-gallon aux tank, and with the two
main tanks he has 18-gallons total. Sorry about that!
However, if you are still interested I will give you his phone number in
Salem, Oregon. He is a very nice guy and feels good about your interest.
His phone # is (503)581-5062, and his name is Ron Gilbertson. He said he
would bring his pictures over for me to scan if you still want them.
Ron Carroll
Original Firestar
Date: Sunday May 10 1998 8:28 PM
Subject: Kolb-List: Re: M-III aux fuel tank
>RON
>That would be great I just got off the phone with a friend of mine up in
>ILL.
>I always go back to him because he always has good ideas.He had to get
>rid of his
> M III on the count of his medical . RON please send me what you can
>,even a phone # if your buddy DON'T mind talking to an old texas boy
>THANKS again for the help.
>RICK LIBERSAT
> writes:
>>a
>>under the
>>pumps fuel
>>if I
>>Ron Carroll
>>Original Firestar
>>Independence, OR
>>From: RICK M LIBERSAT <rick106(at)juno.com>
>>To: Frank_R_Reynen(at)notes.seagate.com
>>Cc: kolb(at)intrig.com
>>Subject: Re: oil /VLS
>>>HI FRANK
>>to
>>>look at the tank ,
>>ideas
>>well
>>>fuel cap.
>>>Rick Libersat
>>>writes:
>>>>cylinder
>>>>SMOH. I
>>>>surprised to
>>of
>>>>the
>>>>cylinder
>>>>hope
>>>>required.
>>>>attach it
>>>>the
>>side
>>>>of
>>>>the
>>>>the
>>>>the
>>>>rear
>>>>exposure
>>will
>>>>ask
>>>>the
>>>>flame to the rear.
>>most
>>>>all
>>>>of
>>>>seizures,
>>just
>>it
>>>>also
>>>>gunks up the rings.
>>only
>>>>reliable) teacher.
>>are
>>>>the
>>>> Richard Pike
Chris,
Welcome to the list.
I'm sure you could get away with drilling out the rivets several times.
Use the same size drill as the rivet (1/8") and try to use a drill speed
and pressure that prevents the rivets from spinning. As you get the heads
drilled off, the rest of the rivet will practically punch thru. I would
NOT drill extra holes anywhere -- e.g. for new rivets -- as this
*significantly* weakens things.
What kind and size floats do you have? I'm also interested in how the
plane performs with them on the water and in the air.
-Ben Ransom
(Kolb Firestar KXP) http://mae.engr.ucdavis.edu/~ransom
Subject: | Wing handling, for painting and beyond... |
Bill:
I installed a fitting in each wing tip trailing edge tube. It allowed an
attachment point for hanging for painting as you asked. The fitting also
makes it possible to lock the ailerons in position for trailering and lock
the two wing tips at the trailing edges together for trailering. If you
never trailer this is not a big deal to you, but it sure tightens things up.
Imagine a pc of lite-walled steel tubing of proper size to fit into the
trailing edge tube. A fender washer was ground down to fit inside one end,
and gas welded in place. The other end was closed up with another fender
washer, left full diameter, so once weled on it forms a flange. Drilled
thru the fender washers to enlarge the IDs to accept a leftover pc of 5/16
4130 from the kit (this size tube has a 1/4" inside diameter). This tube was
welded in and the whole thing primed and rivetted in place in the wing tip.
To use it I put a long pip pin into it, thru an extra pc of flat iron that
is one foot long, to hold the wings together. When painting I did similar
with a pc of scrap flat, wired to ceiling.
It probably sounds like a lot of work and it did take about two hours but
it has since paid back many times. I covered over all but the 1/4" hole so
you'd have trouble noticing it unless you knew what you were looking for.
The two fittings together weigh 8 oz.
An idea I learned from Cliff Stripling, was to add a barn-door handle on the
INSIDE of the wing-tip bow, about at the center, and fabric cover around and
thru it. It provides a VERY convenient hand-hold for folding and handling
of the wings later. In other words, the barn-door handle riveted in place
inside the bow-tube allows you somewhere to attach the fabric to so that you
can get your hand around the actual bow tube for a handle. (Did I explain
that OK Cliff?)
Jim
Dear Kolbers,
Survived another Sun-N-Fun:
Finally back from SNF. If you are looking to an email response from me on
some question - please re-send it. I was delayed in my return due to the
breakdown of my van engine on the way to SNF. Had to have the engine rebuilt
in FL. Thanks to one of our good Kolb builders from Orlando, I got a good tip
on an excellent place to have the work done.
Emergency Power:
There is some truth to the circulating story about using the Laser (on the
trailer being pulled behind my van) to provide the power to get off the I4
where the van engine had failed. One version I heard circulating was that the
vehicle was going so fast that it started the airplane engine by accident!
At 5000 rpm the 582 in the Laser will push a full size van with trailer, with
prop in the windshadow of rear of van at approx. 30 mph on the level. It was
somewhat awesome to see the number of heads turned at the gas station when
pulling in with the roaring of the 582 & prop.
Kitplanes Completions:
Just a note from KITPLANES magazine. They are looking for aircraft to list in
their September completion issue. Last year they had 100 or more airplanes
listed. They are looking for brief letters and color photos from builders.
They say that this has become one of their more favorite columns. In addition
to seeing your pride and joy published in Kitplanes, you have a chance at
winning a Bendix-King KLX-1000 GPScom (about $1,400 worth), the lucky winner
will be selected from those who submitted a completion report during the year.
Also Kolb will toss in a pair of hats, a pair of T-shirts and our newest video
for each published completion. Also, be prepared for some telephone calls of
those curious about your craft, and there may be some offers to purchase as
well! (You can request them to not list your phone or address.)
Time is short. Your completion report must be in by June 10, 1998.
Completions may be typed or hand written, but not emailed - Kitplanes not set
up to handle that yet. Air to air photos are not required or encouraged.
Send to:
KITPLANE Completions
8745 Aero Drive, Ste. 105
San Diego, CA 92123
If you have any more questions on this let me know.
Sincerely,
Dennis Souder
Pres Kolb Aircraft
At 1
>I'm wid ya 100 % Woody......does yours just pop straight down under spring
>power?...I have the same confidence about the alive part
>too!!..................GeoR38
> Mine pops out back and to the left, horizontal to the boom tube.The
spring is just in the drouge chute and when that pops it pulls the rest of
the chute out with it. Not as fast as a BRS but it is a simple failproof
mechanical system.
As for the name the plane game how about High Guy or High Inspiration
Woody
Subject: | Re: Wing handling, for painting and beyond... |
Murphy's Law strikes again!
I read all these neat ideas *after* I just finished covering one wing.
Drat!
I suppose I could still do the other wing and *try* attaching it to
something when folded, right?
Or I could put a handle in one wing, and make it easy to handle one side
when folding.
Ron Carroll
Original Firestar
From: Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM <GERKEN(at)RCHVMX.VNET.IBM.COM>
Date: Monday May 11 1998 4:57 AM
Subject: Kolb-List: Wing handling, for painting and beyond...
> Bill:
up.
was
the
and
you
>that OK Cliff?)
> Jim
From: | "Wayland, William C." <wcw2573(at)eagle.sbeach.navy.mil> |
Subject: | FireStar Wheel Bearings |
My FireFly has the standard FireStar wheels. About 4 weeks back I put in a
spare set of the old design General 1 3/8 x 5/8 flanged bearings. They
lasted only about 10 takeoffs and landing before needing replacement. I was
a bit shocked by this. About a week ago I called Kolb to order new
bearings. Was told they were out of stock but P/N is 499502H and to try
local bearing distributors. Kolb rep did not know bearing mfg. off hand but
said that this was a bearing with a snap ring in lieu of flange and better
than the earlier flanged type.
I contacted Applied Industrial Technologies of Long Beach, CA (562) 437-2201
for price and availability. They said that 499502H was an obsolete New
Departure bearing (some may still be available) but three substitutes were
available. Fafnir 202PPG27 at $11.97; BCA 202FFLB at $12.72; and General
90502-88 at $9.53. I think they told me that all were U.S. made and equally
good. But when I got the General bearings they were marked "CHINA" on the
seals.
Bearings installed yesterday just fine with a tad bit of polishing to the
axles and the use of Locktite bearing sealant to take out the slight
looseness between the bearings and wheels. Did not get a chance yet to fly
with them but will let the list know how they work out.
Chris W.
>kolb folks,
I spent a lot of time trying to figure an easy way to hang my wings
while I painted.I ended up using the air frame on one end(suitably masked
off) and I kept the trailing edge spar open on the end. Putting a piece of
1" tube into the spar I was able to rig the wing to stand 90* to the
airframe in a vertical position so I could walk around it and paint.On mine
I kept the spar end open so I can continue using the removable 1" tubes as
handles when I am moving my Twinstar around when it is folded. When building
a mark 3 we made up handles that stay in the spar and telescope out when we
need handles for moving it about with the wings folded. You will see the
wisdom of this idea as you try moving your aircraft around by holding the
fabric on the wing tip.
Woody
Subject: | EQUIPMENT FORSALE |
I AM DIVESTING MYSELF OF MY TWINSTAR BY THE END OF THE MONTH.ANYONE NEED ANY
PARTS AT A GOOD PRICE LET ME KNOW AT RIVARD(at)MACOMB.CC.US
AS OF NOW PLANE IS COMPLETE INCLUDING BRS-4, RADIO EQUIP,TRANSPONDER,HELMETS
ETC.
BOB
Jim and all,
>that OK Cliff?)
> Jim
Exactly, but it is not my original idea. I copied a Kolb I saw down at SNF
several years ago. Those hand holds are very handy when unfolding the wings
and for lifting the entire folded tail section of the plane by the handles
in the wing tips rather than by the tail spring. You have to hammer the
attachment points of the handles to match the curvature of the bow tube and
I used 3 rivets at each attach point. After covering I wrapped the exposed
bow tube inside the handle location with nylon cord. I positioned the
handles so that there is no distortion of the lower surface of the wing and
only a slight sink in the upper surface near the hand hold.
Later,
Cliff & Carolyn Stripling Him: Retired Pharmacist
and Marble Falls Texas Both: 5th Wheel - RV - Travel
___(+^+)___
(_)
8 8
Better to use a #30 drill....and slightly wobble the bit as you
drill..will keep the rivet from spinning in the hole.
J. Baker
Subject: | Re: FireStar Wheel Bearings |
>seals.
I change bearings on machinery quite often as part of my
job.Unfortunately I have little faith in bearings made in Asian countries.
This is not a blind predjudice but an observed fact. Others may have had
better luck with asian bearings but this has been my experience.
Woody
ID# 607-42492U60000L60000S0) with ESMTP id AAA20015
Subject: | Still with the Mark III Questions |
Is the "normal" or standard Kolb seat, a hammock seat? (ie cloth stretched
on a frame)?
If you use the Upholstery option, is there a difference in the seat (ie
aluminum like the floor)?
>>seals.
This jives with my experience too. Many of the "great deal" hardware and
tools from a place in California called Harbor Freight are junk from China.
Even the metal alloy they use for things such as a bench vice turns out to
be junk IMO.
As for bearings, one possibility is to find out who the wheel manufacturer
is and call them for bearings. I think Kolb has maybe switched to using
wheels from Azusa Engineering. I had bought my wheels directly from them
(which was a misdirected idea on my part -- i'll spare you the details :) )
and also went back to them for wheel bearing replacement. The important
aspect is to get sealed bearings instead of pressed bearings. Sealed,
sometimes referred to as "precision" bearings, make the pressed bearings
seem like a really bad joke. Sealed come with or without a snap ring, and
this is a non-issue for Azusa wheel installation, as the bearings simply fit
into a recess in the wheel hub and can't go anywhere because of the axle
flange on the inside and the castle nut on the outside. (I ended up
getting bearings with provision for snap ring, installed them fine, and
threw out the snap rings.)
Azusa's is in Covina, CA and their phone number is (818) 967-4167. They'll
want to refer you to a resailer. Besides all this, i believe the bearings
are very very standard and you could order them anywhere if you supply OD,
ID, and width.
-Ben Ransom
Ron,
I made a handle out of 5/16" tubing for each wing. I added this on after
it was covered and painted. As with all my exposed aluminum, I polished
it. Sure is nice for wing folding and loading/unloading from my trailer.
Ralph Burlingame
Original FireStar
writes:
>Drat!
>side
>when folding.
>Ron Carroll
>Original Firestar
Fellow Kolbers,
I'm ready to purchase a strobe, or anti-collision light (required for
expermental's in 98 FAR?). Is there a definite (written) statement, etc. as to
which color shows up better in the daylight hours, red or white ? Or are
strobes only white......?
I have had discussions with many pilots on this issue, and it seems that
everyone has there own opinion. I really dont care one way or the other on the
color...... but I sure would like to hear your advise.
Rich Bragassa
Mk III 85 % complete
Miami, Fl.
lrb1476(at)aol.com
Subject: | Re: Strobe color |
>Fellow Kolbers,
Not aware of any legal requirement for a specific color. But based
on 25 years of looking at airplanes out the tower window, day or night, I
would recommend white.
Richard Pike
TRI ATCT, Kingsport Tn.
Hi Gang -
Some more thoughts on AC43 -
There may be some among us who remember CAM 18?? - Then the FAA came
along and it was revised to AC 43.13-1A - not sure of year but suspect it
was in the 60's. My CAM 18 first is dated 1953.
Revisions where made over the years, with the latest being 1988. I
understand AC43 is now in revision.
In any event - all publications have information helpful to building and
providing safe airframe practices - and do I dare say aircraft? Above
all safety is top priority if its for any flying machine or aircraft.
Remember to keep your speed up on final!
Bob Cooper - kolb wanna be - now a Pazmany PL-4A owner/pilot
Newfield, NJ
Subject: | Re: SmithRich-MK 3 For Sale Questions |
Post to BB c/o SmithRich
I fumbled and lost you address
Yes plane is available w/o engine etc, Please give me your e-mail address and
your phone # and I'll be glad to call and fill you in on the particulars.
Russ AMAV8R(at)aol.com
Subject: | Ordered Mark3 today |
Hello everyone,
Just wanted to let everyone know that I went to Phoenixville today
and ordered my Mark3. Want to thank Dan at Kolb for answering all my
questions and let you all know that I'm sure I will have a lot more.
Looking forward to recieving my kit and any info on what engines you
guys have on your Mark3's. Thanks, Monte Evans
Dallas, GA
Subject: | Rivets and corrosion |
Hi All,
I have been looking at a few different projects lately and some are
quite appealing. Being a newcomer to ULs I am trying to learn as much as
I can and I have the impression that building one's own aircraft is one
of the best ways to learn.
Not to long ago, on the list, I read about the issue of corrosion,
particularly when dissimilar metals are involved. I was under the
impression that the rivets used in the assembly process were made of a
hard aluminium alloy and that this problem would not be an issue. Now
I'm a bit concerned that if/when steel rivets are used, what might look
like a nicely preserved aircraft might have serious structural problems
that could only be discovered if one decides to recover the structure.
Hopefully my worries are not founded and the rivets used ARE in fact
aluminium, so at least the wings and most large surfaces would not be
subject to this type of corrosion and the only danger spot would be
wherever steel parts are attached to aluminium parts. Still this
dissimilar metal issue has started me wondering about the wisdom of
restoration versus the security of building brand new.
Here (Montreal area), humidity is quite high all year and winter brings
the overuse of salt on the roads which I'm sure finds its way into
almost anything that's close enough to any kind of major road or
highway.
I hope I'm overreacting here and that things aren't so bad, but any
thoughts on this will be appreciated.
Guy,
Subject: | Mirror Fuel Gage |
I fly my FireFly wearing both helmet and goggles. The goggles along with a
bit of a back problem makes twisting around to check the tank's fuel level a
problem. I purchased at Pep Boys one of those small rectangular convex
mirrors (1.4 X 2.2 inches). I cut four slots in both the top and bottom of
the mirror's plastic frame for two tie wraps. At the slots in the bottom of
the of the frame the tie wraps just come out and loop back into the frame.
Using the two tie wrap ends at the top of the mirror frame along with the
adhesive pad that comes on the back of the frame I mounted the mirror high
up on the cockpit side wall just behind my left shoulder. Now a downward
glance over my shoulder lets me clearly see the bottom half of the
translucent tank.
Chris W.
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
Subject: | LASER KIT PRICES? |
Dennis,
Laser is a great looking bird! Wanted to know more..
Didn't make Sun-n-Fun but saw Scott Bentley's pictures that he
posted. Has Kolb established any kit prices, plan to do so? What are
the specs. ? Haven't seen anything yet just wondering what you can tell
us.
Jeremy Casey jrcasey(at)mindspring.com
Dennis,
Laser is a great
Didn't make
Sun-n-Fun but saw Scott Bentley's pictures that he posted. Has
Kolb
established any kit prices, plan to do so? What are the specs.
us.
Jeremy
Casey
jrcasey(at)mindspring.com<=
/DIV>
Subject: | Re: Ordered Mark3 today |
Monte and all,
>engines you
When I first saw your post I saw Dallas and thought, "Great - another
project nearby". Then I saw Georga... We have 6 Kolbs of various models
around this area. All but one are flying and it might be by late summer
sometime.
Engines... I have the Rotax 582 with B gear box and 3 bld IVO quick adjust
prop. I think that power train combination is perfect and the power is more
than plenty for the MKIII. I seldom run my engine more than in the low to
mid 5K rpm range except on take off and climb.
You are going to have a great time building your Kolb. The number of hours
required are fairly stated at 500, although you could do it in maybe 300 the
second time around or you could spend 800 if you are a real detail freak. I
did mine in an estimated (I didn't log every hour - not fun for me - and I
didn't log or count dream time) 450-500 hours and it took about a year. I
did my share of mods too.
Recommendations:
1. Powder coat whether factory or by someone local.
2. Get built-in larger fuel tank. Pricy but worth it. 10 gallons equals
about 120+- miles with 1.5 - 2 gallons reserve... not enough IMO.
3. Your choice on brakes. I have cheap ones - just adequate - hydraulic are
much better but pricy. Lots of talk about bearings lately. Mine are
holding up OK so far.
4. Get full enclosure.
5. Make your own interior. Pepboys auto carpet (color co-ordinate) and a
1X4 arm board attached with U clamps. Get an outdoor cushion company to
make some comfortable airy custom seat cushions at around $20 each.
6. Build shock mounted instrument panel.
7. Build half doors for summer. Easy to do... and cool.
8. Buy prebuilt wing ribs.
9. You don't need electric start on a 582.
10.You don't need a battery (unless electric start or you just want one) as
the engine can power instruments, strobe, radios, etc.
11.MKIII's tend to be tail heavy so watch added weight aft of the CG.
12.Ballistic chute - your call - I have a soft pack in the wing gap seal.
13.Extra tools - bench vice, grinder with wire brush, Dremel tool.
14.Methods - I used gussets on trailing edges for a smooth cover and
Polytone paint. I used 4-flap hinges (made from 2 flap stock). I lined my
lift struts and did not use jury struts.
That's about all I can think of right now. Have fun!
Later,
___(+^+)___
(_)
8 8
Subject: | Re: Rivets and corrosion |
Sorry but almost all the rivets are Stainless Steel, so dissimilar corrosion can
be a problem. If you're building new, you can dip the rivets in primer before
installing them as some folks have done, but I'm not sure this will stop the
problem entirely. I didn't prime anything but the steel parts on my SlingShot
and I live on the Gulf Coast of Florida where humidity is off the scale and all
our salt is from the ocean. I figured the SS will have a structural lifetime of
at least 10 years, and that's good enough for me.
BTW- don't even think about substituting aluminum rivets without approval from
Kolb, which I doubt you'll get. I think the stainless rivets are much stronger
than aluminum, and you would compromise the strength by substituting.
Rusty
SlingShot flying
RV-8A building
Subject: | FW: Rivets and corrosion |
I poked each and every rivet into a piece of cardboard and then sprayed
the ends with zinc chromate primer. I'm sure some was scratched off
when the rivets were put into the drilled holes, but I figure it was
better than nothing.
> From: Russell Duffy [SMTP:rad(at)pen.net]
> Sent: Wednesday, May 13, 1998 7:41 AM
> To: Kolb mailing list
> Subject: Re: Rivets and corrosion
> corrosion can
> primer before
> stop the
> SlingShot
> scale and all
> lifetime of
> approval from
> stronger
> Rusty
> SlingShot flying
> RV-8A building
All very good advice! However, item 14 leaves me a little confused. It
states, "I used 4-flap hinges (made from 2 flap stock). I lined my
lift struts and did not use jury struts. " I'm not clear on what "4-flap
hinges" or "2 flap stock" means. Also, what does "lined my lift struts"
mean?
Ron Carroll
Original Firestar
From: Cliff and Carolyn Stripling <striplic(at)nationwide.net>
Date: Wednesday May 13 1998 7:43 AM
Subject: Kolb-List: Re: Ordered Mark3 today
>Monte and all,
>>engines you
>sometime.
more
the
I
>Recommendations:
are
>Later,
> ___(+^+)___
> (_)
> 8 8
Subject: | Re: Mirror Fuel Gage |
Which brings about another question directed to the Original Firestar
owners:
With the cage of the Original Firestar nearly fully covered, how do you
check your fuel level while in-flight?
I gotta kill these problems before I get too far along (about to cover the
cage)
Ron Carroll
Original Firestar
From: Wayland, William C. <wcw2573(at)eagle.sbeach.navy.mil>
Date: Wednesday May 13 1998 7:13 AM
Subject: Kolb-List: Mirror Fuel Gage
a
of
>translucent tank.
>Chris W.
In a message dated 5/13/98 6:33:09 AM Pacific Daylight Time, samten(at)cam.org
writes:
<< I was under the
hard aluminium alloy and that this problem would not be an issue. >>
Wrong. The older Kolbs used cadmium plated steel rivets. The newer ones use
stainless. I got my kit in 94 and was one of the first with stainless rivets.
Hi all,
I finally finished the new fuel tank installation and eventually might post some
pictures of it. I installed a 13.5 gallon under deck boat tank where the rear
seat usually is in the SlingShot, and removed the standard jugs. I was able to
run my vent outside the cockpit so it doesn't reek like fuel inside anymore. I
also managed to install an outside fuel filler at the rear of the cage.
Previously, it was difficult to fill the tanks on the plane, but now, I can just
pour from any gas can. I like it.
The downside to this is the loss of the rear seat. I don't think I would have
ever carried a passenger there, but it was a good place to put my flight bag
with tools, tiedowns, spare batteries, charts, etc. Now I have a large space
available where the fuel jugs used to be, but there's not much access to it.
I also used the time to make some other changes. I went ahead and replaced all
my fuel line with auto type hose since I had it out anyway, and I removed the
primer system at the same time. Recently, I've been having idle problems where
it just slowly drops rpm until it would probably quit. I checked the choke and
found that it might have been engaged just slightly, so that was adjusted to
give just enough slack to make sure it was off. I set the idle bleed screws to
1/2 out each (one was 1/2 and the other was about 3/8 out of the box). Also,
the throttle linkage was re-checked for full open and closed on both carbs, and
the plugs were changed. I'm happy to say that something on the above list must
have fixed the problem, because it runs beautifully now.
During the fuel line re-routing, I installed a new filter and placed it parallel
to the bottom of the main steel tube just in front of the engine. I don't feel
really good about the way the fuel flows through the filter. The new filter is
clear and rather large, and doesn't fill up as you would expect, rather it
varies the fuel level inside depending on the RPM. At idle, there is barely any
fuel in the filter, and at full throttle it's about half full. You can squeeze
the fuel bulb while the engine is running and make the filter almost fill up,
then it's like the fuel stops flowing from the tank until the level fall to
where it originally was. I don't understand it, but I bet it's normal. It
seems like I've seen the same behavior from
inline car filters as well. Before this change, I had an opaque white filter
and you couldn't see the level of the fuel. Perhaps ignorance is bliss. I plan
to re-position the filter vertically (outlet on top) so that the huge air pocket
has to go away, but it still seems like the pump isn't keeping the bowls full.
Currently, the fuel squeeze bulb is positioned vertically, and it will be moved
to horizontal as recommended by some folks. As it is, it seems to work fine.
I
went up for a short flight yesterday and tested all attitudes and throttle
settings (over a private airstrip) with no sign of trouble, but it still bugs me
too much to ignore. Any comments would be appreciated.
Finally, (a sigh of relief from all) a slight retraction. I was whining about
a
week ago about buying an IVO prop that wasn't "electric ready". It pissed me
off because I would certainly have opted for that designation if I had known
about it at the time. It dawned on me later that I should have stated that I
bought the prop from LEAF, and not from Kolb. Dennis said that they do inform
people about the "electric ready" prop if the customer has any interest in later
converting to the in-flight adjustable feature.
Russell Duffy
RV-8A building
rad(at)pen.net
Ron,
I remove the shoulder strap, and turn myself to the left to see
through the slot for viewing the tank while trying not to move the
control stick. Then I turn back and straighten the plane out, because it
is never going the same direction as before I turned. Some people use a
mirror mounted in the right spot. My method is difficult, but I only use
it after I have been flying for over 1 1/2 hours. And one check is
enough to comfirm the fuel burn and make a decission as where to land.
John Jung
> owners:
> cage)
> Ron Carroll
> Original Firestar
>Hi All,> I have been looking at a few different projects
Good timing Yesterday I was getting some old tubing down to use it on my
new project and I had to remove some old fittings that were rivited on.The
rivits were ugly as heck,corroded and making a mess of the tube. I tried
breaking the rivits off with no luck and finally drilled them out.There is a
slight ring around where the rivit head was that may be removed with
vigorous sanding.There was no other sign of bimetal erosion. I believe that
these rivits were still safe but if I were recovering and saw them I would
drill them out.
Woody
>It
>mean?
Ron and all,
I copied the 4 flap hinge from the "Fergie" - a beefed up knock off design
of the Kolb. You make them by melding two 2-flap hinges by cutting off
every other link of the hinge. The result is a hinge with 4 attachment
points around a single hinge pin that provides more stability for the two
parts the hinge connects. It is a mod that I liked and copied. I will say
that it took a lot of time to modify and the extra hinge material was
expensive. The result though is a very stiff and strong connection. The
only negative is that it might have increased the friction in the hinges.
Aileron activation is rather heavy in flight vs the elevators. Even though,
I think that is pretty common for the MKIII.
Lined lift struts are like stock except there is a full length internal
aluminum sleeve tube from one end to the other and it is sandwitched between
the strut and the weldment attach points on each end. It adds enough
stiffness to the strut that the jury strut can be eliminated. It was
described in one of the Kolb newsletters a year or so ago.
Later,
___(+^+)___
(_)
8 8
Another alternative.....sure wish I'd seen these before I built.
Check out the Rans hinges.....two sections that slip over the tube
during construction and use an AN bolt as the hinge. Very
slick....very easy installation.
J. Baker
From: | "Scott Olendorf" <olendorf(at)empireone.net> |
I have a clear piece of gas line running from the bottom of the tank to the
steel tube near left arm and then up to top of tank. I can easily see fuel
level without turning my head too much.
Scott Olendorf
Original Firestar with Rotax 377
Schenectady, NY
From: Ron Carroll <ron.carroll(at)worldnet.att.net>
Date: Wednesday, May 13, 1998 11:24 AM
Subject: Kolb-List: Re: Mirror Fuel Gage
>owners:
>cage)
>Ron Carroll
>Original Firestar
>To: 'kolb(at)intrig.com'
>Subject: Mirror Fuel Gage
a
>a
of
>of
>>translucent tank.
>>Chris W.
I have just removed the fabric from my wings. Probably about 10 years old
and kept outside for several years. Lots of the rivets are rusted and I am
replacing all rivets that show any rust with stainless steel.
By the way, does anyone know of a good paint in a spray can that can be
used to prime the steel wing parts. One that doesn't dissolve in MEK. I
ran out of epoxy primer and just need enough to do wings.
Scott Olendorf
Schenectady, NY
Date: Wednesday, May 13, 1998 11:40 AM
Subject: Kolb-List: Re: Rivets and corrosion
>writes:
><< I was under the
use
rivets.
Subject: | fuel rambling part 2 |
Hi again,
Today, I re-routed my new fuel system again. This time, I made the squeeze bulb
horizontal, and the fuel filter vertical with the outlet on top. I figured this
would guarantee that the filter would fill up completely and stay full. Despite
my powers of logic, this isn't how it works. Now, the filter is half empty all
the time (or half full for you optimists), but at least I can't squeeze the bulb
with the engine running anymore so I know the carb bowls are full. It must be
all right because I flew it almost 2 hours today. I even made the daring bay
crossing again :-)
Another thing I tried today was a reflexed flap setting. I gave myself two
notches worth of reflex on the flap handle by shortening the push pull tubes
yesterday. This amounts to only about 3-4 degrees at the most. I found that it
makes a big diff in trim of the plane as expected, but after about a dozen
stalls with and without the reflex, I couldn't tell any diff in stall speed.
Unfortunately, there's no diff in cruise speed either. I'll probably add some
more reflex and see how it goes. I'd like to get rid of my elevator trim spring
if possible, and I'm still hoping for some extra cruise.
I'll be installing a VSI tomorrow in place of my G-meter. I think I can get a
lot more use out of the VSI, especially with all my upcoming exhaust testing.
I
posted a message on one of the newsgroups about the R&D pipe, and got one
response from a guy that has one on his trike used for glider towing. So far,
he said he has 10 hours on it and had a noticeable improvement in performance.
He also reported that carb jetting didn't change.
See ya later,
Russell Duffy
SlingShot SS-003, N8754K (25.9 hours)
rad(at)pen.net
Mine are the regular steel rivets. I have Original FS kit #49. The rivets
have not rusted and our climate in MN is humid in the summer. The rivets
in the fuse have been exposed to a little road salt spray, but I try to
keep them covered with polish. They show no signs of rust after 11 yrs.
The salt air on the coast may be a completely different situation. I
wished I have received the stainless ones with my kit.
Ralph Burlingame
Original FireStar
>samten(at)cam.org
>writes:
>> I was under the impression that the rivets used in the assembly
process >>were made of a hard aluminium alloy and that this problem would
not be an >>issue. >>
>ones use stainless. I got my kit in 94 and was one of the first with
stainless
>rivets.
Noticed a blurb today on beefing the aileron hinges on the MKIII.
Here's another way to do it.
Get a few extra sets of the stainless steel hinges that are used on
the front of the horizontal stab. After you have all the other aileron
hinges on and everything, and are satisfied with the movement, then do this:
Take 4 of those L-shaped stainless steel hinge parts, and bolt them
together with an AN-3 bolt, just like on the front of the stab.
Stick this assembly up between the aileron and wing trailing edge,
with the bolt/hinge part on the bottom. The hinge line of the AN-3 bolt
should be in line with your normal aileron hinge line.
Take 4 hose clamps, and clamp things just tight enough to keep
things still, and adjust, and work the aileron. When everything moves
smoothly with no binding, tighten the hose clamps, and check it one more
time. If it is still smooth, and the action is satisfactory, drill and rivit
with 3/16" stainless rivits. That bad boy is rigid, and eliminates all the
flex normally associated with the flat aluminum hinges.
Richard Pike
MKIII N420P (42oldpoops)
Subject: | Trim for Yaw with engine angle |
(Ben or someone)... Could you please append the explanation of trimming
for Yaw by angling the engine up or down AGAIN? I promise I will save the
note this time.
Thanks again...
P.S. My Garmin 12XL came back from repair today. They replaced it with a
completly new unit. My original one was 5 months old, version 3.51, had
the shutdown problem and all of a sudden it lost all my waypoints. The new
one is version 4.00 and contains a new feature: a database of cities. I have
already found all the near-by towns in it, including two of them that are
under 500 people! I am a very satisified Garmin customer, service almost
as good as Kolb Co.!
Group
With all this talk of opposite metal (rivets) and corrosion, with is the
useful life of a FS? Is it something that'll be scrap in 10 or 12 years?
If this is the case, i'm not so sure I would want to invest in same. Any
comments would be looked on with great interest. Thanks.
Ron Reece Return: rcreec(at)most.fw.hac.com
Raytheon Corp.
Ft. Wayne IN
<< Group
There are still lots and lots of Ultrastars still flying and the last one of
these was sold about 13 years ago. Actually a number of the older Flyers
still flyin and some of these go back 18 years. Also lots of 13 year old
FireStars still flying. The figure of 10-12 years seems overly pessimistic.
The one I'm going to be watching is a new ultralight that just came on the
scene that uses alumimum tubing with copper elbows tying it together. Talk
about dissimiliar metals!!!
Dennis Souder
Pres Kolb Aircraft
><< Group
>Dennis Souder
>Pres Kolb Aircraft
Dennis
Glad to here that my thoughts were not correct (re. 10 to 12). I hope you
didn't take things the wrong way, I wasn't trying to flame the FS or any
other Kolb product. The thread on dissimilar metals business just made me
a little nervous and I had to ask.
I have read that Ben and a couple of others have dipped there rivets prior
to insertion, does this help with corrosion?
Thanks for setting me straight and calming my fears.
Raytheon Corp.
Ft. Wayne IN
Subject: | Longevity of Kolb Aircraft |
Howdy Guys and Gals:
My old flying buddy and hangar mate, MSG Ed Davis, US Army Retired, now
deceased, built a Ultrastar in 1985. I flew it the last time in Jun 87.
It sat in his hangar until the first of the year when it was sold to a
friend who refurbished it a little. Structurally, everything was sound
except the carbon steel rivets in the lift strut fittings. I was also
concerned about rivets in the wings and tailsection, but after inspection
they proved to be sound. Ed' US flew last week at the age of 13 and after
resting earth bound for 11 years. Nothing was done to protect it, but a t
hanger with an open front. The Cuyuna UL II O II was gone thru and it runs
like a new one.
I personally use "tube seal" in my chromoly tubes, especially the airframe,
and have on all the airplanes I have built. Unfortunately, I broke the
first two before I had a chance to see if it really helped. Only kidding.
The Ultrastar was kept in the cow pasture in the open with a strand of
barbed wire around it to keep the cows away from it for more than a year.
Once when I broke it and had to cut some tubes to replace, the inside of
the tubing was clean and free of rust. On the other hand a tube which
didn't get tube seal was damp and rusty inside.
My MK III airframe is seven years old and I don't think it necessary at
this time to try and put a as of date on it. I started using SS rivets
long before they became popular to use with Kolbs. My 1986 Firestar was
completely constructed with SS rivets.
Didn't mean to run on at the keyboard like this. So solly,
Subject: | Re: Mirror Fuel Gage (and rivets) |
>John Jung
I like to check more often. I almost always check about 5 minutes out
after taking off and also periodically after that, just to feel comfortable
that fuel is disappearing at about the right rate. You never know when
"Murphy is my co-pilot". My tank is a normal install except that it is
~7" higher, but I don't think this is a factor in ease of checking.
Anyway, it seems a relatively easy squirm maneuver to check fuel, well
worth the piece of mind. For back problems, hmmm, mirrors, added
tubing for sight gauge?
Hey, regarding rivets: If anybody is counting, the change to stainless
rivets is another little bit where Kolb has made the kits better with
no fanfare or appreciable price increase. I'm impressed with Jason's
extra effort to prime each rivet. His trick was a smarter time saver
than what I did. (I kept a jar of rustoleum and dipped each rivet in
it before setting.) I didn't even know until now that
they had changed to stainless. I'm inclined to think stainless is
overkill except in humid/salty/etc conditions. Especially if the plane
is stored inside, and the rivets dabbed w/ epoxy before covering (as
recommended in plans), I think the plane should last a very long time.
Another thought (i've always got more)... remember also that Stits
covering tends to hold the structure tight, which inhibits
vibration as well as corrosive evils.
-Ben Ransom
-Ben Ransom
You could use Rustoleum spray primer, then a coat of latex. I used
a latex brand "ToughCoat" that was fine with moderate doses of MEK, and
completely fine for PolyTac. (Many other primers would do, but this
is just one that is commonly available in aerosol cans.) Also, brushing
on primer can work easily, and for the wings, there is practically no
steel to show even if there were tiny brush strokes left behind.
-Ben Ransom
Subject: | Re: 503 rough runner |
Gentlemen,
A friend of mine has a FireStar with a Rotax 503, dual carb, dual ignition
and oil injection. -- A beautiful engine -- It let him down the other day
and we're trying to figure out what is happening.
Running along just fine at 5500 rpm when the engine suddenly went to about
3200 rpm and the throttle had no effect. Fortunately, a safe landing on
the home airfield was made. Tried a ground run and the same thing happened
after about 5 minutes of simulated cruise power. Bought a new dual Mikuni
fuel pump and installed it today. Ground ran the engine and everything
looked good (except the egts were a little low) and the engine static'd a
little over 6000 rpm. Brought the power back to 5500 and after about 5
minutes the rpm SUDDENLY, again, dropped to about 3000 rpm. Mag checks
were normal. Brought the engine to idle for a while and it then would rev
up normally. A new fuel filter has been installed as has new fuel lines.
We all have time to work on the machine tomorrow..... Any suggestions???
Skip
41-42,44-51
Skip,
The same thing happened to me a few years back. I was using one of those
tiny paper fuel filters and it clogged up on me. Before changing it I had
changed the pump, plugs, and fuel. Have you ran the engine since changing
the fuel filter? If not it may run fine now and you will never know what
caused the problem. My engine (377), ran fine on the ground, but after 5
min in the air, it lost rpm and the throttle had no effect. Eventually
the filter will clog all the way and starve the engine. You may have got
a hold of some bad gas. Another problem may be a partially clogged primer
bulb. It should be bypassed with fuel line around it just in case.
I use a large paper filter that can be purchased at most auto stores and
I change it annually. Using those tiny ones is asking for trouble. I
hope this is the problem since it's an easy fix.
I wouldn't recommend flying it until you find out what caused it. I hope
you still have that old filter.
Ralph Burlingame
Original FireStar
writes:
>Gentlemen,
>ignition and oil injection. -- A beautiful engine -- It let him down
the
>other day and we're trying to figure out what is happening.
>about 3200 rpm and the throttle had no effect. Fortunately, a safe
landing
>on the home airfield was made. Tried a ground run and the same thing
>happened after about 5 minutes of simulated cruise power. Bought a new
dual
>Mikuni fuel pump and installed it today. Ground ran the engine and
>everything looked good (except the egts were a little low) and the
engine
>static'd a little over 6000 rpm. Brought the power back to 5500 and
after about
>5 minutes the rpm SUDDENLY, again, dropped to about 3000 rpm. Mag
>checks were normal. Brought the engine to idle for a while and it then
would
>rev up normally. A new fuel filter has been installed as has new fuel
>lines. We all have time to work on the machine tomorrow..... Any
>suggestions???
>Thanks,
>Skip
Guy,
The only aluminum rivets are those that attached the fabric. But I
have had the chance to observe a few old Ultrastars and an early
Firestar during rebuilding and I didn't observe any problem with the
rivets. I did see corrosion on steel that was not adequately protected,
but not at the rivets. I live in Wisconsin with plenty of salt used on
the roads during the winter, but IMO, the salt would not be an issue
unless the plane was hauled on an open trailer during the winter, or
used as a floatplane on salt water.
John Jung
Firestar II N6163J
Original Firestar For Sale -> http://www.execpc.com/~jrjung/
> Tetreault wrote:
> Hi All,
> highway.
> Thanks,
> Guy,
> Dennis Souder
For those who want to research the issue here are some informative
sites.
http://www.mcnallyinstitute.com/04-html/4-1.html
http://www.zenithair.com/kit-data/ht-87-1.html
http://www.stusteel.com/galvseri.htm
http://wuarchive.wustl.edu/edu/arts/metal/TOC/material/corros.txt
http://www.assda.asn.au/pickling.html
The interesting thing is that the rivets (usually made of 304 series
stainless) are much closer to aluminum, galvanically, in the active
state and farther away when in the passivated state......but that's
not something you can control.....all your SS will acheive the
passivated state unless you build and fly in an inert atmosphere.
J. Baker
April 23, 1998 - May 14, 1998
Kolb-Archive.digest.vol-ap
