Kolb-Archive.digest.vol-aq
May 14, 1998 - June 03, 1998
Subject: | Re: Mirror Fuel Gage (and rivets) |
> Hey, regarding rivets: If anybody is counting, the change to stainless
> rivets is another little bit where Kolb has made the kits better with
> no fanfare or appreciable price increase. I'm impressed with Jason's
> extra effort to prime each rivet. His trick was a smarter time saver
> than what I did. (I kept a jar of rustoleum and dipped each rivet in
> it before setting.) I didn't even know until now that
> they had changed to stainless. I'm inclined to think stainless is
> overkill except in humid/salty/etc conditions.
Well...maybe not as big a favor as one would suppose. Common steel
is closer to aluminum on the galvanic scale than stainless. Except
for the strength issue, common steels would be preferable. A plated
steel rivet runs about 280# shear and 410# tensile. A stainless
rivet with stainless or common steel stem is about 520# shear and
600# tensile.
J. Baker
Subject: | Re: spring chute |
<< Mine pops out back and to the left, horizontal to the boom tube.The
spring is just in the drouge chute and when that pops it pulls the rest of
the chute out with it. Not as fast as a BRS but it is a simple failproof
mechanical system.
As for the name the plane game how about High Guy or High Inspiration
I like "HighGuy"....how about HighSociety...and play Bing all the
time.....there's a lot to a name....you may start acting different....not to
imply that you are not a member of high society already...of
course!........................GeoR38
<< Group
With all this talk of opposite metal (rivets) and corrosion, with is the
useful life of a FS? Is it something that'll be scrap in 10 or 12 years?
If this is the case, i'm not so sure I would want to invest in same. Any
comments would be looked on with great interest. Thanks.
I recall that the Jap Zero had a galvanic problem so profound that to this day
not one can be found as the plane literally rusted away....could be major
problem...does anyone out there know the story of the
Zero??..................GeoR38
>600# tensile.
Would you happen to know the strength of "Avex" rivits?
Woody
Subject: | Re: 503 rough runner |
>Gentlemen,
>A friend of mine has a FireStar with a Rotax 503, dual carb, dual ignition
>and oil injection. -- A beautiful engine -- It let him down the other day
>and we're trying to figure out what is happening.
>Running along just fine at 5500 rpm when the engine suddenly went to about
>3200 rpm and the throttle had no effect. Fortunately, a safe landing on
>the home airfield was made. Tried a ground run and the same thing happened
>after about 5 minutes of simulated cruise power. Bought a new dual Mikuni
>fuel pump and installed it today. Ground ran the engine and everything
>looked good (except the egts were a little low) and the engine static'd a
>little over 6000 rpm. Brought the power back to 5500 and after about 5
>minutes the rpm SUDDENLY, again, dropped to about 3000 rpm. Mag checks
>were normal. Brought the engine to idle for a while and it then would rev
>up normally. A new fuel filter has been installed as has new fuel lines.
>We all have time to work on the machine tomorrow..... Any suggestions???
>Thanks,
I would look at a defective coil that shorts itself when it warms up.It
could even be a bad coil ground wire not quite making good contact after a
few minutes of vibration
Woody
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Subject: | Corrosion, Rivets, Engines |
I read Jim Gerkin's request to Ben (or someone) on engine angles. I'd be
real interested too. Guess I missed it the 1st time. Also would be very
interested in knowing how some of you went about aligning your engines.
How about after mounting fine tuning adjustments ?? Will appreciate any
thoughts + ideas.
To Dennis: What are your thoughts on dipping the rivets before setting ??
I didn't, had intended to spray the innards after completion with a
commercial corrosion proofing. Now, I'm starting to wonder. Seems like a
good idea. (dipping) Just the thought of someone trying to sell anything
made of copper angles and Aluminum tubes makes my blood run cold. I've
spent most of my life on the ocean. Brrrrrr. It must have been
intimidating on your return from SNF. How many messages were waiting ??
To John Hauck: Thanks for the thought on sloshing the tank. I've read
about it many times and places, and it never entered my mind for my own
tank. After all that work with anti-vibration, I'm 3/4 tempted to wait and
see. I met you at Arlington in (I think) '94. I think you were on your
way back from Alaska. Miss P'fer was a major reason in my ultimate
decision to buy a Mk III. She sat there, solid + purposeful, making all
the others around her look like toys. You courteously, but firmly, refused
my request to climb aboard. Don't blame you in retrospect. Let one, it's
tough to turn others away. Doubt if you'd remember after all this time.
When I ordered mine, seems to me I gave Dennis fits, wanting the taller
gear, etc. Didn't realize then that it was all custom.
Subject: | Re: Trim for Yaw with engine angle |
> (Ben or someone)... Could you please append the explanation of trimming
>for Yaw by angling the engine up or down AGAIN? I promise I will save the
>note this time.
Start by envisioning the mass of air coming from the prop to the vert stab
and rudder as a clockwise swirl (torque). Top half of this air is moving
to the right and bottom half is moving to the left. With the motor shimmed
for the thrust line to point high (sort of the natural no-shim config in a
Firestar I believe), practically all of the prop swirl hitting the vert-stab
is from the bottom half of the prop. Since this air is pushing the
vert-stab to the left you get a right yaw. Shimming the motor mounts to
lower the thrust line angle makes more of the right moving air swirl hits
the vert-stab, resulting in left yaw force.
The swirling prop force, torque, is more dominant at high power settings
combined with slowest airspeed (of the plane), such as max climb type stuff.
At higher airspeed, like in straight and level max throttle, the torque
forces on the vert-stab have relatively less influence. Also note that
P-factor,
which is present at high angle of attack and high power, causes a tendency
to yaw left (on a clockwise swirl like Rotax). On my FS, with equal size
washers under front and back of the motor -- i.e. no thrust line shimming --
she rides straight ahead (ahem! and proud of it) at cruise, and I need
to feed a left rudder on slow speed high power climb. If I try to impress
people by getting to full power blast-offs from paved runways, I get to
full left rudder before getting to full rpm, and I'm still pulling right.
(But this only takes 4 seconds and I'm off the ground at 40 IAS and only
1/2 left rudder ...but I digress) What this really means is that prop
torque is a greater yaw force than P-factor in the FS at least, and it is
convenient that it the two forces are opposite.
PS: When I built my FS I made a point of making sure I put the front
vert-stab mount point a teeny bit to the starboard (as much as 1/16 to
3/32").
This would build in left yaw, which yes, I was chicken to do. I just didn't
want to error to the other side, knowing that most of the prop swirl was
coming
from the lower half. I also built the front mount U shaped cradle maybe
1/16" too wide and used shims in the extra space, allowing me to "adjust"
later if necessary. As a little disclaimer, be careful considering these
two construction ideas; they were not per plans and I may have just lucked
out.
OK, more than you asked for. :)
-Ben Ransom
http://mae.engr.ucdavis.edu/~ransom
Hi all, I am replacing the original Tennessee prop of my FS with an
IVOprop. Rumor has it I should run a 2.5 inch spacer to keep the prop
out of the aileron tubes??
Aiframe 1987 original FS
Engine Rotax 377 with prov 4 and about 25 hrs on it
Your comments appeciated.
To Dennis Souder: Thanks for the nice design. My wings have small
indentations in the leading edges from trailering, hanger rash etc. They
are very shallow but visible to the unaided eye. Any cause for concern?
Thanks all.
BTW...with all this talk of corrosion, my FS with steel rivets has non
visible anywhere. Stored in a trailer in Baton Rouge and now Florida.
The original Firestar doesn't need the spacer if used with the 377
and standard gear box and motor mount. It has 5" of clearance to the
ailerons without the spacer. The Firestar I/II (and some other corrent
designs) need the spacer.
John Jung
Original Firestar 345 hrs
Firestar II N6163J 5 hrs
SE Wisconsin
> snip
Subject: | TwinStar Site Update |
Except for covering, installing new stainless steel control cables, and a
windshield; the TwinStar my partner and I are
restoring is coming together.
Follow the update link to look at photos of the wheelpants
and the standoffs that were made, all the piano hinges for the
elevator, rudder, and ailerons were replaced with clevis pins
and our solution to holding 10 gallons of fuel (worth just going to see
that TS dudes!).
Next update will be a more comprensive page on covering techniques, our
lessons learned,tips and etc.
Follow the TS link below for a look see...Comments good/bad are definetly
invited!
-Mark-
TwinStar Page
<http://www.tcsn.net/mswihart/kolb.htm>
Paso Robles Ultralight Association
<http://www.tcsn.net/mswihart/ul/prua.htm>
AOL AIM Screen Name: SwihartMrk
Bradley, California
From: | "rutledge fuller" <rut007(at)hotmail.com> |
Subject: | Re: Fuel ramblings |
>From: "Russell Duffy" <rad(at)pen.net>
>To: "Kolb list"
>Subject: Fuel ramblings
>Date: Wed, 13 May 1998 10:56:02 -0500
>Hi all,
>I finally finished the new fuel tank installation and eventually might
post some
>pictures of it. I installed a 13.5 gallon under deck boat tank where
the rear
>seat usually is in the SlingShot, and removed the standard jugs. I was
able to
>run my vent outside the cockpit so it doesn't reek like fuel inside
anymore. I
>also managed to install an outside fuel filler at the rear of the cage.
>Previously, it was difficult to fill the tanks on the plane, but now, I
can just
>pour from any gas can. I like it.
>The downside to this is the loss of the rear seat. I don't think I
would have
>ever carried a passenger there, but it was a good place to put my
flight bag
>with tools, tiedowns, spare batteries, charts, etc. Now I have a
large space
>available where the fuel jugs used to be, but there's not much access
to it.
>I also used the time to make some other changes. I went ahead and
replaced all
>my fuel line with auto type hose since I had it out anyway, and I
removed the
>primer system at the same time. Recently, I've been having idle
problems where
>it just slowly drops rpm until it would probably quit. I checked the
choke and
>found that it might have been engaged just slightly, so that was
adjusted to
>give just enough slack to make sure it was off. I set the idle bleed
screws to
>1/2 out each (one was 1/2 and the other was about 3/8 out of the box).
Also,
>the throttle linkage was re-checked for full open and closed on both
carbs, and
>the plugs were changed. I'm happy to say that something on the above
list must
>have fixed the problem, because it runs beautifully now.
>During the fuel line re-routing, I installed a new filter and placed it
parallel
>to the bottom of the main steel tube just in front of the engine. I
don't feel
>really good about the way the fuel flows through the filter. The new
filter is
>clear and rather large, and doesn't fill up as you would expect, rather
it
>varies the fuel level inside depending on the RPM. At idle, there is
barely any
>fuel in the filter, and at full throttle it's about half full. You can
squeeze
>the fuel bulb while the engine is running and make the filter almost
fill up,
>then it's like the fuel stops flowing from the tank until the level
fall to
>where it originally was. I don't understand it, but I bet it's normal.
It
>seems like I've seen the same behavior from
>inline car filters as well. Before this change, I had an opaque white
filter
>and you couldn't see the level of the fuel. Perhaps ignorance is bliss.
I plan
>to re-position the filter vertically (outlet on top) so that the huge
air pocket
>has to go away, but it still seems like the pump isn't keeping the
bowls full.
>Currently, the fuel squeeze bulb is positioned vertically, and it will
be moved
>to horizontal as recommended by some folks. As it is, it seems to work
fine. I
>went up for a short flight yesterday and tested all attitudes and
throttle
>settings (over a private airstrip) with no sign of trouble, but it
still bugs me
>too much to ignore. Any comments would be appreciated.
>Finally, (a sigh of relief from all) a slight retraction. I was
whining about a
>week ago about buying an IVO prop that wasn't "electric ready". It
pissed me
>off because I would certainly have opted for that designation if I had
known
>about it at the time. It dawned on me later that I should have stated
that I
>bought the prop from LEAF, and not from Kolb. Dennis said that they do
inform
>people about the "electric ready" prop if the customer has any interest
in later
>converting to the in-flight adjustable feature.
>Russell Duffy
>SlingShot SS-003, N8754K
>RV-8A building
>rad(at)pen.net
>http://www.pen.net/~rad/
Subject: | Re: rivit strength |
> Woody
Better yet....just run over to their web site...has all the info
you'll need.
http://www.avdelcherrytextron.com/
J. Baker
Subject: | Re: Corrosion, Rivets, Engines |
Guess what? Copper shows up higher in the galvanic scale than 18-8
stainless, type 304 (passive). Guess copper isn't so bad after all.
J. Baker
You don't need the extension for the Original FireStar with the 377 or
the 447, just the new FS I&II.
Ralph Burlingame
Original FireStar
>They
>concern?
>Thanks all.
>Bob
From: | William Hinkelmann <whink(at)mindspring.com> |
Subject: | Touch Me Please!! |
Had more people touch the "Frog" at S&F, figured they would wear the paint
off, well it got thin in places. Thought of putting up a sign "Touch Me
Please" but realized it was not necessary. I enjoyed seeing the reaction
finding out the plane was made of spray foam (Great Stuff). Poly Tone is
eaisy and blends well.
If you don't want your plane touched, leave it in the hangar and lock
the door.
William Hinkelmann
Modified FS-II
North Atlanta, Ga.
Subject: | Re: Rivets and corrosion |
I forget who, but someone makes a spray-on self etching primer. Works real
well. Dries very hard. You can get at a good auto paint store.
Bill Griffin
From: | Cliff and Carolyn Stripling <striplic(at)nationwide.net> |
Subject: | 50 hour engine check |
To all,
Today I pulled off the muffler and exhaust manifold and visually and
manually inspected the pistons, rings, cylinder walls, cylinder head, and
plugs. I "think" (meaning this is the first time for me and I know
absolutely nothing about Rotax engines) everything is OK. I did not have
any noticable up and down play with the rings as I moved the pistons. I had
heard that you should be able to see looseness. It took a hard look to see
any (almost had to imagine) oozing of oil in or out of the cracks above or
below the rings when you raised or lowered the piston. The upper ring
compressed easily when pushed with fingers, the lower ring compressed but it
was harder to do. I also pushed each gently with a blunt screwdriver tip
and got easy movement on each. There was black on the piston top but I
could not scrape off enough of any deposit to indicate any build up. I
wiped the scraped area with an undershirt cloth and got no carbon. The
cylinder walls and what I could see of the inside of the cylinder head were
bright and clean. The only color found at all was on the side of the piston
- a narrow light brown smudge band about 1/4" wide and 1 1/4" across and
3/8" below the lower ring where it looks like exhaust gas discolored it when
the piston first opens to let the gas out. The plugs were oily and a little
gummy around the threads of the outside, the insulator was ash white in
color and dry and the electrode and tip were grey/brown and dry. All the
plugs looked the same. The muffler shock mounting donuts (that I made from
auto parts store ones) were in good condition after 25 hours.
I still need to do other things, but I wanted anyone's thoughts on the
piston rings. Word descriptions are hard to follow, but does it seem like
my rings are OK to this point? Up to now the engine has been running
flawlessly.
Later,
Cliff & Carolyn Stripling Him: Retired Pharmacist
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
and Marble Falls Texas Both: 5th Wheel - RV - Travel
Kolb MKIII - N582CC (43.3 hrs)
____________________|_____________________
___(+^+)___
(_)
8 8
Subject: | Re: 50 hour engine check |
>To all,
I did not have
>was harder to do.
>flawlessly.
>Later,
> ___(+^+)___
> (_)
> 8 8
> I think if it was mine, I'd bolt it back together and leave it alone
for another 25 hours, and then look at it again.
Richard Pike
MKIII N420P (42oldpoops)
Gentlemen,
and oil >injection. -- A beautiful engine -- It let him down the other
day and we're trying >to figure out what is happening.
Thanks to those who responded to our call for assistance. Cliff, Ralph,
Jim, Bill,
Woody and Dave all submitted well thought out suggestions as to what was
happening to the 503.
Yesterday, three of us set out to troubleshoot the engine and were
sucessfull. I wish that I could say the trouble was some exotic problem;
but I can't. It's rather hard to visualize, but the choke cable was the
problem. It was crimpted in one place and the housing was partially broken
in another. Due to the installation and vibration the cable would, on
occasion, pull on the chokes to the carbs and then release them at random
times. Movement in the cockpit exacerbated the problem. The temporary fix
was to just disconnect the choke cable. My friend, George, flew for a
couple of hours yesterday afternoon with no problem and a big smile on his
face. :)
A side note: On most 2 strokes a stuck choke would have made itself pretty
obvious by excessive smoking caused by the rich mixture. In this case,
that didn't happen as this engine uses oil injection. After checking
everything including the primer bulb, as per the suggestions, the clue
finally was the low EGT readings that pointed to an overrich mixture. A
one time wierd problem to be sure! :) Thanks again.
Skip
1984 UltraStar
52,54-58,60-73
Cliff,
>From the way you described the inside of your engine and spark plugs, it
sounds like a normal 2-stroke in good working order. If the both rings
are free, you can run many trouble-free hours before the next inspection.
Before these new low-ash oils came on the market, I was using Valvoline
2-cycle and it took 200 hrs before both rings finally did stick. From my
experience, the bottom ring will stick first then you will have probably
another 50 hrs before the top one goes. When that happens, the engine
with seize. With todays oils, who knows how long one can go? Before
putting it back together why not give it the Seafoam treatment on the
rings? You can buy the spray can (Seafoam Deep Throat) and spray it into
the rings. Let it sit for a few days, put it back together, put in some
old spark plugs (the treatment will foul them) and run it up until the
smoke clears. Put in some new plugs and you have just reconditioned your
engine.
Ralph Burlingame
Original FireStar
writes:
>To all,
>and plugs. I "think" (meaning this is the first time for me and I know
>have any noticable up and down play with the rings as I moved the
pistons.
>I had heard that you should be able to see looseness. It took a hard
look
>to see any (almost had to imagine) oozing of oil in or out of the cracks
>above or below the rings when you raised or lowered the piston. The
upper ring
>but it was harder to do. I also pushed each gently with a blunt
screwdriver
>tip and got easy movement on each. There was black on the piston top
but
>I could not scrape off enough of any deposit to indicate any build up.
>I wiped the scraped area with an undershirt cloth and got no carbon. The
>were bright and clean. The only color found at all was on the side of
the
>piston - a narrow light brown smudge band about 1/4" wide and 1 1/4"
across
>and 3/8" below the lower ring where it looks like exhaust gas discolored
>it whe the piston first opens to let the gas out. The plugs were oily
and a
>little gummy around the threads of the outside, the insulator was ash
white
>in color and dry and the electrode and tip were grey/brown and dry. All
>the plugs looked the same. The muffler shock mounting donuts (that I
>made from auto parts store ones) were in good condition after 25 hours.
>like my rings are OK to this point? Up to now the engine has been
running
>flawlessly.
>Later,
> ___(+^+)___
> (_)
> 8 8
Subject: | flap reflex test results (2) |
(Sorry if this is a repeat. I posted two messages yesterday, and never saw
them, so I'm sending them again)
Hello,
I shortened the push-pull tubes on my SS to allow up to 10 degrees of reflex
(up) flaps. In theory, this should kill off some of the lift/drag of the wing,
and give a bit more speed. It should also raise the stall speed to some degree.
The flap mechanism has 7 notches that the handle can lock into. After
shortening my push-pull tubes, I have the following degrees of flap settings:
(down) 12, 7, 1, (up) 3, 6, 8, 10. I started the flight at the 1 degree down
setting and proceeded to try each of the settings once I got to a good altitude
and location. At each new setting, I got a feel for the controls by making a
few turns, then power off stalls were done. Cruise speed comparisons were made
between the 1 degree down, and 10 degree up settings.
As expected, stall speed increases as the flaps are raised.
40 mph with 12 degrees down flaps
44 mph with 1 degree down flaps
50 mph with 10 degrees up flaps
Unfortunately, I couldn't really document any speed increase at cruise. There
is, however, a large change in pitch trim from one extreme to the other. Adding
down flaps causes the nose to drop, and you have to hold up elevator. Adding up
flaps is naturally just the opposite.
Conclusion. I still can't beat John :-) No really... I plan to play with this
some more, but at first glance, I can't see any real benefit to having reflexed
flaps on our planes. If there was any speed increase, it was too small to
reliably measure, but at higher speeds, it might have been noticeable. The side
effect of raising the stall speed is rarely something you want to do, unless
perhaps to raise the maneuvering speed. (for those without a GA background,
maneuvering speed "Va" is the highest speed you can use full control
deflections, or fly in rough air. At this speed, the wing will stall before the
structural limit of the aircraft is exceeded.)
Rusty (your humble guinea pig) Duffy
Subject: | High fuel consumption (2) |
Hi again,
During the last two flights, I've noticed a much higher than normal fuel
consumption. I used to burn 3.75 gph on my 503 at 5800-6000 rpm cruise, and now
I'm burning more like 4.5 gph. Unfortunately, I can't say when it began, but I
noticed it now because I'm trying to document my new fuel level readings for
accuracy. If I had to name a reason, it would be the high pitch I'm running on
my prop to get better cruise speeds. My static RPM is 6080 currently, and I
cruise from 5800 to 6000 rpm. CHT's are 330 and EGT's are 1000, which is where
they've always been. The plugs were a bit dark when I changed them at 25 hours,
so I imagine this is running a bit rich. Once I get the new exhaust system on,
I'll worry about any fine tuning that may need to be done to the temps. In the
mean time, is there anything else that can cause a sudden increase in fuel
consumption?
Rusty
PS- UPS didn't bring the R&D pipe today, so I guess it will be next weekend
before I can install and start to test it. I've received 2 replies to my
requests for info from users of the pipes, and both were good though one was
admittedly a dealer and biased.
PPS- I'm looking into the possibility that fuel is dumping out the vent line
when the tank is full. It seems possible, but unlikely that I could have dumped
1.5 gallons out in a single flight.
>Bill Griffin
Primer.... a subject near and dear to any RV builders heart :-) I've recently
started using a primer from NAPA auto parts stores. They sell it as #7220, and
it's about $5 a spray can. The color is about medium gray, and it is self
etching. It dries to the touch very quickly, but isn't really so hard until
sometime later. So far it seems to be working out fine. Rumor has it that this
primer is made by Sherwin Williams for NAPA, and it's the same as what SW sells
in their Auto Paint stores for about double the price.
Rusty (I HATE primer) Duffy
Subject: | tank pics, and surprise engine (2) |
(well this is a repost too, is anyone getting these? I sure don't see them)
Hi all,
I finally posted some pictures of the new tank if anyone's interested. They are
at:
http://www.pen.net/~rad/ss_buildpic.htm
Look at the last 4 pictures of the "fuselage" section for (548,547, 542, and
541) .
Also, a special picture for John Russell:
http://www.pen.net/~rad/get_john.htm
Russell Duffy
SlingShot SS-003, N8754K (27.6 hrs)
rad(at)pen.net
Subject: | Re: High fuel consumption (2) |
>Hi again,
and now
Howdy Rusty and Gang:
Two things you mentioned increase fuel burn.
1. Increasing pitch on a 2-stroke increases fuel burn and lowers EGT
because the eng is not consuming as much air as it needs to burn at 1100 or
so. Take a little pitch out of the prop and your egts will come back up
where they belong. For best possible cruise and climb, prop to just bump
red line or a little less at WOT, straight and level flight. This is the
way the eng is designed and set up at the factory to run. The 503 is not a
2-stroke and sometimes two strokes will give you indications that are
exactly opposite of a 4-stroke.
2. Flying around the patch burns about half as much fuel (GPH) as on a for
real bonafide XC. I have no experience with the 503, but the 447 pitched
like indicated above, will burn 3.5 to 3.75 GPH at 5800 - 6000 RPM cruise.
I've had that proven to me over many hours of XC in the Firestar and 447.
3. I still have a difficult time understanding why people want to try and
make gas misers and high pitch low RPM cruisers out of very highly modified
2-stroke engs. 2-strokes got to have fuel and the correct amount of oil to
live, perform, and keep on performing. Loading up on pitch and leaning out
a 2-stroke is not the way to be a continuously happy ultralighter.
4. Again folks, just my own very humble opinion, but it has worked for me
and I am still here to share it with you.
Subject: | primer follow-up |
this
After reading my post on the list (finally), I realized that I'd never tested
this primer for resistance to MEK. I just tried it, and found out that MEK
takes it right off. That means you can't use this primer as a final coat
anywhere you plan to attach fabric. The fabric glue will dissolve it and you'll
have a really big mess.
Rusty
Subject: | Epoxy Chromate Primers (two part) |
Hello again Gang:
Rusty gave a good example of what happens when we try to take too many
short cuts. Most of the time it will prove out to do things the way they
are spelled out in the instruction manual and the covering and painting
manual.
I have found that Stits epoxy chromate and Randolph epoxy chromate (both
two part) get the job done right. Especially in areas where we have to
cement the fabric around a tube such as the inboard rib.
From: | "Brad Houston" <HoustonBW(at)worldnet.att.net> |
I have been lurking hear for 6 or 8 months and enjoy the tips and info I
pick up. I have an Ultrastar with a Cuyuna engine. The carb (a Mikuni
W3-71) needs to be overhauled (hole in one of the floats and seat is not
seating properly). Can anyone assist me in obtaining bowl gasket, floats,
needle and seat. I have called Mikuni in California but I keep getting an
answering machine stating all the lines are busy, leave a message. They
haven't returned my calls. Local motorcycle shop said if I could give them
the "application" name they could probably order parts. Thanks in advance
for any suggestions. Brad
John and all,
How do you define best cruise? I picked 6000 rpm as the maximum that I want to
run continuously. My current cruise is 80 mph at 6000 with a max speed of 92 at
about 6400 rpm. If I reduce pitch to get 6800 at WOT level flight, my 6000 rpm
cruise will drop to about 70. In fact, here's a quote from my flight log when
I
had the prop set closer to what you advise. "Cruise is still about 70mph at
5800 rpm. Maybe 72 mph at 6100 rpm. Flat out at 6690 rpm is 80 mph." As for
climb, I may have lost 100 fpm by adding pitch, but mostly I lost a ton of noise
and vibration.
I don't doubt that your method is considered the best overall way to set these
engines up, but it certainly doesn't give "best possible cruise" in my case.
Perhaps the fact that the SlingShot is far cleaner than the average Ultralight
makes a difference.
>2-stroke engs.
I bet lots of people have a difficult time understanding why anyone would want
to fly around the country in a Kolb :-) Everyone has their own idea about what
they want their plane to be. I'm looking to optimize cruise speed, others want
slow and quiet, etc. The only reason that I was worried about the fuel
consumption is that is seems to have started all the sudden.
Don't take any of this personally John. You know more about 2-strokes than I
ever will. The 503 has been very well behaved, and I'm starting to trust it
more and more, but I just don't think I'll ever be a 2-stroke guy.
Rusty
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
Subject: | Re: flap reflex test results (2) |
EXCELENT DATA COLLECTION RUSSEL BUT I AM BUMED THAT YOU DIDNT GET A FEW
MILES PER HOUR OUT OF THE oops reflexed flaps. Most likely that means
that any gain your getting from the wing is getting wiped out by a
reduced efficency in the rest of the plane due to the more nose down
attitude. If you were able to get a decent guess at your trim attitudes
at each condition that would be interesting to hear. If you are
getting fairly nose down with the 10 degree reflex then you are probably
geting separation on the lower fuselage... you could try putting some
vortex generators just before the break on the bottem!!!!
Topher
<003701bd80db$a2658fc0$0100a8c0@rad.pen.net>
>Hi John,
>I agree with every thing you said except your slip up about a 503 not being
>a two stroke.:)
Hey Guys: I'm going to have to mention to my secretary to start doing a
better job of proofing my e-mails before she xmits them. Hard tgo get good
help these days.
Flew an hour to our UL Club meeting at Wetumpka AP, Alabama. The weather
is dreadful. Never seen it so hazy and humid this time of the year. Could
tell the difference in performance compared to last flt in cool clear dry air.
I agree that 2-strokes need their fill of fuel, but they dont need too
much, the trick is to find a sweet spot for your plane and desired
performance. I am hoping my plane will be able to go places, to do that
I need good speed and range, which means a leaner setting and a higher
pitch on the prop. I will not want to fly patterns all day, or takeoff
from a 200 foot pasture on a regular basis, but be able to land on that
200 foot pasture if I have to. So I am adding flaps to get me into
short fields, not out of them, and if I can fix the problem once down I
can always repitch the prop in the field (Ivo quick adjust) and climb
out of there if I think it is safe. Or I fold up the wings and get a
ride home for the trailer. One thing that John has pointed out is how
the two strokes can get hot at reduced throttle settings due to lack of
airflow. To get a good range with a two stroke it seems like I will
have to run it with an opened throttle but on the lean side of safe
mixture. Cooling the engine with air is a better way to go then to cool
the engine with fuel.
I am schedualed to solo on the next fairly nice day! Winds have been 20
gusting to 30 around here for a few days.
Topher
>Gentlemen,
>Jim, Bill,
Glad you figured it out. This also came in handy for me.I have been having
a lot of trouble getting my John Deere 1954 model M tractor to run I
sandblsted 40 yrs. of gunk off the carb, rebuilt it ,adjusted the valves,New
condenser,coil every thing I could think of untill I read your problem on
the list and the answer pointing to a blocked fuel filter.I don't have a
filter so I gave a blast of air up the fuel line and it has been running
like a charm.Now I can cut the grass on my runway ,dust off my Twinstar and
bore some holes in the sky.
Woody
I'd try for 6500 or 6600 or in-be-tween. Would be interested to see how
that works out.
However, if it works for you, go for it. What works for one may not
necessarily work for another.
What is important is what you are satisfied and comfortable with. That
also goes for your plane. I try to find a cruise that is comfortable for
both of us, if you know what I mean.
release (PO205-101c) ID# 605-45218U5000L500S0) with SMTP
From: | "Vincent Nicely" <vincenicely(at)intermediatn.net> |
but I
for
running on
My experience in testing the fuel consumption on my Firestar II shows that
at higher speeds the fuel consumption rate is very dependent upon the
aircraft speed. If you have increased the average speed of flight, then you
should expect an increase in fuel consumption.
Vince Nicely
Firestar II N8233G (155 hours)
>that works out.
It's a deal John. My current plan is to leave the prop where it is until I get
the R&D pipe installed. I know my static rpm is 6080 now, so it will be
interesting to see how much it goes up with the new pipe. It should go right to
the red line easily I think, then I'll have to add pitch. Once I get it flying,
I'll experiment with different pitch settings to see what that does for climb
and cruise. That should help me decide if an in-flight adjustable prop is worth
the hassle. Somewhere along the line, I'd like to add a 3rd blade to cut the
noise and vibration a bit more.
Well, I'm off to the airport again. I've got to work on my landings today after
embarrassing myself Friday. I'm having a hard time landing slowly without
smashing the tailwheel first.
See ya,
Rusty
>Topher
Well, I don't know if I'm up for the vortex generators, but I suspect you're
right about the reduced efficiency elsewhere. I don't really have an estimate
of pitch attitude changes for the different flap settings, but it seemed like a
lot. This also occurs normally as speed changes. During a full throttle speed
run, the plane pitches down and I'm holding a good bit of down elevator to keep
from climbing. It's almost like flying a helicopter :-)
I've always been baffled by the difference in incidence angles between the wing
and horz stabilizer. The wing is positive, and the stabilizer is negative.
This can't be helping speed much, but I suspect it improves stability. I'd be
curious to know what would happen if you raised the front of the stabilizer, but
I have no plans of trying it. Maybe I'll ask Dennis about it someday.
I have to keep reminding myself not to get carried away in my pursuit for speed
with the SlingShot. The RV-8A will take care of that problem soon enough :-)
Primarily, I just enjoy trying to optimize things. When I run out of stuff to
tinker with, it's time to move on to another project.
fly now,
Rusty
Rusty and all,
I'd be
stabilizer, but I have no plans of trying it. Maybe I'll ask Dennis about
it someday.
I have the adjustable attachments and at some point (not yet) I plan to
cautiously experiment with different incidences. I have 5 sets of holes
spread over about 1.5" with the middle ones being per plans.
John H. might have some comments about that. He has (or had) the same set
up on his MKIII.
Later,
___(+^+)___
(_)
8 8
From: | "Geoff Thistlethwaite" <geoffthis(at)worldnet.att.net> |
Subject: | Re: adjustable attachments? |
Adjustable attachments? Is this something I could or should have on my FSII
or are they only on the MkIII?
Geoff
Hi again,
I bet everyone will be happy when I go back to work tomorrow and you quite
getting 10 messages a day from me :-)
I've had a couple people ask about my new tailwheel, and I realized that I never
posted the pictures after installing it. There are a couple of pictures at:
Look at the last 2 pictures of the "fuselage" section for (536, and 537)
This is the 4 inch diameter "homebuilders special" special tailwheel from
Aircraft Spruce. P/N L-693 is made for a 5/8" round spring, so it has to be
bored out to 3/4" for the SlingShot tail rod. I'm not sure if that's the same
size as other Kolbs. Watch you wallet and CG because this wheel is $223, and it
weighs 2 lbs more than the original wheel. The beauty of it is that it's full
swivel and makes the plane a dream to move around on the ground. Also, it's far
wider than the original wheel, so it doesn't disc the runway as you go :-)
Rusty
SlingShot (29.8 hours)
PS- flew 2.2 hours today and had 4 gallons remaining. I stopped into the
predominately UL and glider airport for a while and answered lots of SlingShot
questions. Even the glider tow plane pilot called on the radio to ask what it
was. Maybe I should get out more :-) At this point, I'm not likely to make the
Jones fly-in because I found out I'm on call that weekend.
Geoff,
It was a non-standard substitute item for the normal "L" brackets that are
supplied for all of the Kolb models. It was only adjustable because I
drilled holes at several levels.
Later,
___(+^+)___
(_)
8 8
Rusty,
it is only weird to have a large nose down incidence on a stabilizer
when you consider that there is downwash from the wing back there. The
tail is lifting down to hold up the cg which is in front of the wings
aerocenter, which is where stability comes from... reduce stability a
bunch and you can get rid of that download on the tail and improve the
performance alot, like the aircraft I worked on for 8 years the F-16.
of course it has triple redundent fly by wire and a 4000 psi hydralic
flight control system to keep it from swapping ends. I really think
that the lower fuslage is separating and the fuslage is making negative
lift at low angle of attack high speed flight, it certainly increases
frontal area as the nose cvomes down. I am not as familiar with the
shape of the SS as I am with the FSII. If I ever get to finish my
airplane it is an area that I am going to work on.
Topher
ID# 607-42492U60000L60000S0) with ESMTP id AAA9643
Can someone tell me the street adress of the Kolb factory please?
From: | Scott Bentley <Scott.Bentley(at)Bentley.Com> |
Subject: | RE: Kolb Factory |
38 Wall Street, Phoenixville, PA 19460. See http://www.kolbaircraft.com/
(though they don't list the street address there.)
> -----Original Message-----
> From: moores [SMTP:moores(at)nbnet.nb.ca]
> Sent: Sunday, May 17, 1998 11:16 PM
> To: kolb(at)intrig.com
> Subject: Kolb Factory
Subject: | Re: Kolb Factory |
>From there web page:
Kolb Aircraft
RD 3, Box 38
Dept. WS
Phone: (610) 948-4136
Fax: (610) 948-6727
Ordering Parts: (610)
948-6294
7:00 A.M. to 3:00 P.M. Eastern
Time
John Jung
snip
Rusty,
We'll miss you. Don't forget to write!
John Jung
Subject: | Modified windscreen |
Group,
This weekend I tried out a different windscreen on my original
Firestar. The guys in Minnesota got me interested in modifying the short
windscreen. They extend it about 6 inches in the center but not at the
sides. I did their modification plus I made mine 2 inches higher. The
results are encouraging. Top speed is about 5 mph faster, so cruise
should be easier. But the really nice thing is that the plane is even
more enjoyable to fly, especially at faster speeds or in steep turns.
Before, the amount of air coming over the top of the winscreen was a
problem. If I turned mu head to check the gas, the wind would try to
take the glasses of my face. Not now. The only down side is that it
increased the stall speed by a couple of mph.
John Jung
Firestar II N6163J
Original Firestar For Sale http://www.execpc.com/~jrjung/
Kolb Group Map http://www.execpc.com/~jrjung/Kolb_Map.html
Subject: | "The Farm" (ie. Kolb Company) |
To all,
Unless things have changed on the road to Kolb, the only distinguishing
landmark is the mailbox with 38 on it. That was back in 1993 sometime. My
wife and I went by to visit before I ordered a MKIII while we were
vacationing in the area. Boy, was I surprised. I drove in the road to the
place (actually a nice farm with a pond) and took a right at the "Y" (left
goes over to Homer Kolb's house) and up to the old "barn". We didn't know
we were at the right place for sure until we saw the little sign over the
door - Kolb Aircraft Company - or something like that. On up the hill
beyond the barn was the modern hanger and behind that the airstrip, but you
don't see that initially.
About the people. We had called ahead that we were coming and I had hoped
to get a ride while we were there. We met Dennis, Barbara, and then Dan who
"shucked off his coveralls" and showed us around the upper floor of the shop
and the hanger. As it turned out the weather was not good enough to fly,
but I got a ride later with Dan at SNF. We didn't go down stairs where the
welding shop was located. We ended up our visit with Dennis who put
everything aside to give me all of the time I wanted to answer questions.
It was an enjoyable day.
Back then (and I assume not much has changed since) the company was run like
one big family. Everyone seemed happy (as evidenced by my experience then
and later with the employees either in person or on the phone) and busily
doing whatever task was at hand. God bless 'em all.
Later,
___(+^+)___
(_)
8 8
Subject: | Modified Windscreen |
<< If I turned mu head to check the gas, the wind would try to
take the glasses of my face. >>
I lost two sets of glasses (one prescription) that way - I hate it when it
does that!
Dennis
Subject: | Re: Modified windscreen |
Jon and group,
>windscreen...
I too am thinking about a "shortie" canopy for my MKIII to go with my "half"
doors. I would appreciate any comments.
The half doors provide plenty of airflow and enough more or less calm air
space in the cockpit - you have to be careful opening a sectional map. They
also allow you to extend your arms into the slip stream and "stretch" and to
take pictures without any obstruction.
I want to continue the rear edge of the half doors across the top by
building a second canopy like the original including the down tubes but also
to include a brace across the top to support the rear edge of the Lexan
between the down tubes (the full canopy was built to be easily removable).
If anyone has any extra down tube material, I am in the market for it.
I am not sure what this modification will do to increase/decrease speeds,
stalls, etc. I do know that it will remove the interfearence between the
canopy and the wing root and allow more air to flow under the center section
of the wing and into the prop. Someone reported that they were flying with
"no" canopy at all so I assume it will be safe enough. I like the open air
feeling in the summer and "more air (as long as it doesn't blast your face)
and less fumes is better". I love my "Kolb Convertable". Maybe a good name
for it - "Cliff's Convertable"... better than "Cliff's Coffin" - a name my
ex-partner in business gave it.
Later,
___(+^+)___
(_)
8 8
Subject: | High Fuel Consumption (2) |
<< During the last two flights, I've noticed a much higher than normal fuel
now
I
on
my prop to get better cruise speeds. >>
It sounds like you have increase the pitch of the prop and still run the same
rpms? If so, that would explain the increase in fuel consumption. To spin a
steeper pitch prop at the same rpm means more power needed, which means more
throttle. Since you don't have a manifold pressure gauge to give bench mark
of power setting, you are probably unaware of how much extra throttle you many
be adding.
If your egt gauge says the same temp, but your plugs are darker, then probably
your egt' s in reality are lower. I encounterd this with experimenting with
props on the Laser, with a couple of props, I thought I was getting a higher
cruise, but I discovered that gas consuption had sky rocketed and indeed, my
egs were lower which meant I was not really getting a higher cruise, I was
just crusing at a higher power setting.
When you overpitch the prop and then add increasing throttle to keep up the
rpms, you get to the point where you are starting to come up on the main jet,
instead of being on the needle where you should be cruising. This will really
gobble the gas.
BTW just heard from a FireStar flyer who had tried new the R & D pipes for
his 503. Initially he called and was a happy camper, but his engine soon
seized within a couple hours. He rebuilt it and it seized again. It was not
a hot seizure as egt's and plugs showed normal temps - nor did an examination
reveal a heat seizure. He has given up on it and going back to the Rotax
exhaust.
Dennis Souder
Pres Kolb Aircraft
Dennis
John,
"The guys in Minnesota" ..... Yep that's us. I'm glad your modified
windscreen did the same for you as it did for us. I didn't notice an
increase in my stall speed though, hmmmm.
Ralph Burlingame
Original FireStar
>Group,
>short windscreen. They extend it about 6 inches in the center but not at
the
>John Jung
>Firestar II N6163J
Subject: | hushacom for sale |
Hate to use this forum for a classified section but here goes.
I bought a Hushacomo intercom and 2 headsets from here from someone else a
while ago and am wanting to sell it now. I paid $175.00 for all, any takers.
It works ok. but I am not using it and thought somebody else might like to
take their turn.
tim
Ralph,
Mine is high and long enough that there is no wind under the gap seal
when I am at a high angle of attack at stall. I can put my hand above my
head and feel no wind. That probably explains the change in stall. I
will use the GPS in calm air to confirm that it is not just a error in
air speed. Thanks for the idea.
John Jung
>Ralph H Burlingame wrote:
> John,
Subject: | Original Firestar |
Ralph, John, and Group:
My original Firestar project should be flying soon. I was curious about
the v speeds that you are using. I have read Ben Ransoms account of
landings in his KXP, but wanted a broader picture on what speeds are
important. A discription of stall, climb out, and landing
characterisitcs would help. I am currently training in a Ferguson.
Also, we are close to the painting stage, and have been tossing the idea
around about using pin stripes on the fabric. Does anyone have any
experience with this, and what is the longievity?
Rutledge Fuller
Subject: | Hi fuel consumption |
Somewhere, sometime, someone wrote:
The last few flights have shown me that the turbulence is the true limit to
cruise speed anyway. I've been slowing down to 70 or so anyway, so I'm not
sure
I can justify installing a questionable muffler just to gain speed I can't
use.
The climb would be nice, but I can re-pitch my prop and get maybe 100 fpm
back
and end up with a top cruise speed that I can actually use. I may call R&D
tomorrow and see if they've shipped it yet, if not, I may just cancel the
order.
I can send it back even if it arrives I guess.
I have flown our SS quite a bit, cruising at 95 mph (with the 912). I don't
recall needing to slow down much for turbulence. I hasten to add that when
crusing fast (trying to get somewhere) I get high ... about 3000 to 7000 feet.
Usually the air is much smoother above 3000 feet. If I am sight seeing I
usually fly 1000 feet or less - but then I am not trying to go anywhere so I
don't try to go fast.
I mention this because if one trys to go fast at low altitude, you do get your
butt kicked pretty good - unless it is a very calm evening.
Dennis
Somewhere, sometime, I wrote:
"BTW just heard from a FireStar flyer who had tried new the R & D pipes for
exhaust."
I received a clarification on the above problem. The engine did suffer from a
lean seizure. However the egt never indicated above 1080 max. The plugs were
very "white" whick indicates high temps. Apparently the normal 100 mm
location for the egt probe (the stock Rotax setup) does not work with the R &
D pipes. This leave unanswered the question of where it needs to be located
to give a correct reference temperature.
Dennis
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
---------- Forwarded message ----------
Ah, good Rusty (the guinea pig), there's hope! We then maybe also have to
wonder if R&D was getting more HP and Torque because the pipe works, or
because they were running lean (and mean). It would be interesting to
hear what R&D recommends for EGT probe distance, and let's hope they
don't just say 100mm is fine. I'd be willing to bet Rotax didn't go
to great trouble figuring out the best possible pipe.
One time I asked a motorcycle guy about carbon plastic mufflers. After
all, the exhaust on a 447 is 15% of the engine weight. The motorcycle
guy said they exist, but when I asked at a local motorcycle shop the
owner looked at me like I was nuts. Anybody ever hear of light weight
2-stroke pipes? Certainly Jim Baker, you must know of a web site for
this too. :-)
-Ben Ransom
From: | "Jim Gerken GERKEN(at)RCHVMX.VNET.IBM.COM" <GERKEN(at)RCHVMX.VNET.IBM.COM> |
Subject: | R&D pipes, are they "better" than Rotax? |
Pipe design is not binary. A two-stroke pipe is a resonant chamber of
specific volume, and specific length. The shorter the length, the higher the
frequency (RPM) the boost will be. The volume relates to the width of the
boost, in RPM range. It should be easy to design a pipe to get a little
more horsepower, but you may not like the idea of an engine with lower
reliability/efficency.The "best possible pipe" is one that trades off operating
speed with horsepower, and provides torque delivery to meet the expected load.
On a propeller load, this means torque increases smoothly to near-max RPM with
no dips. Smoothness is the opposite of peaky. Peaky is more HP at some point
in the powerband, but trouble pulling the load "up the hill" to max RPM.
If you don't understand this, ask a 532 operator about adjustable props.
Peaky engines are more work to drive, because you shift more often to keep
them pulling (they lose torque somewhere else in the powerband). They
are also a tuner's nightmare, because the carb is somewhat linear in its
ability to provide fuel/air, but a peaky engine hits an RPM range and suddenly
wants more fuel. So you have to feed it more (jet richer), and then some
other part of the range will be too rich so your economy drops. If your carb
does not have the ability to provide more flow at the req'd RPM, EGT will rise.
I would rather have a smooth delivery and dependable reasonable RPM, than
a huge boost, because I am driving a prop. If I was driving thru a CVT, like
a snowmobile, I would port and pipe for more maximum (peaky) power, because
the drive train is adjustable to the powerband of the engine, unlike our
props which present a load which is squared by a doubling of the RPM.
So, did Rotax provide the "best pipe" for our application?
Probably pretty close, judging by the published HP/Torque curves,
but I agree that it could be lighter (especially for 500 bucks!)
Could R&D do better? Probably a little, if you can live with the tradeoffs.
If you want more power and you're willing to sacrifice reliabilty, go ahead
and raise the top of the exhaust port 15% and shorten the pipe length by a
few inches and run it 1000 rpm faster. It will scream power, for a while...
I think my wife is starting to get a bit worried about this exhaust testing (I
know I am). I had a message on my answering machine from the seizure victim
this morning, and I'll be talking to him tonight to get the full story. In his
message he emphasized that I should "read the plugs" and not trust the number
from the EGT gauge. I'm guessing that at some point, Rotax just picked a
standard location for the EGT probe, then tested to find out what was a healthy
number to see at that location for their system. I can imagine that the flow
dynamics might be different enough to give different readings at the normal EGT
location, and if that's so, the R&D boys should be able to give a new max temp
to look for. Everyone that's told me about the pipe mentioned that it lowered
their EGT by about 50 degrees. Perhaps it only looks like it went down.
As for the Rotax pipe, I'm sure they made it fairly conservative for reliability
sake, and I'm not sure that it's smart to be messing with it, but I'm also not
sure that will stop me. The power curves that R&D shows are a bit more peaky
than the Rotax figures, but it seems to be a broad enough peak to cover all the
rpm band that I really use.
If I'm going to be happy with the SS, I need more power. At this point, I don't
think I would consider a 2-stroke replacement for the 503. The pipe might get
me by, but I'll wait until after I call this guy tonight to decide whether to
try it. I'll keep you posted.
Rusty
Subject: | Re: Original Firestar |
Rutledge,
My Original FireStar stalls at 20 mph indicated because I have a short
pitot tube and as the AOA gets high, it reads too low. I haven't measured
the stall speed on my GPS, I will do it some day. The actual stall is at
25-28 mph. The best glide speed is 38 mph and my approaches are at 40
mph. I cruise at 55-60 mph and climbout at 40 mph. I could climbout at a
steeper climb angle, but I feel the engine will cool better at 40. I have
had the airspeed up to 85 mph in a dive.
Ralph Burlingame
Original FireStar
writes:
>about
>idea
>Thanks,
>Rutledge Fuller
>Get Your Private, Free Email at http://www.hotmail.com
> this too. :-)
> -Ben Ransom
Gauntlet thrown......
carbon/carbon info
http://www.isc.tamu.edu/~clint/html/CCcomposite.html
Carbon fibre intake reeds
http://carbontech.com/reeds_article.html
Model aircraft composite exhaust systems
http://vvv.com/~falcon/bexhst97.htm
And finally, motorcycle exhaust constructors...including one in
Dallas that works in CF materials.
http://www.micapeak.com/mc/addrs/aexhausts.html
The thing here is....if you've got the money, honey, they've got the
time. It'll be light but it won't be cheap.
Also, if anyone cares, I've written three articles on tuned pipe
fundamentals.... if you like to read tech stuff.
J. Baker
>Rutledge,
Howdy Gang:
I had the unique honor of spending about an hour with Steve Whitman at Sun
and Fun 93. I discovered him on his hands and knees inspecting something
under my airplane. I didn't know who it was until I heard him say
something to his friend. Then I asked if he was Steve Whitman. He got up
and we introduced ourselves. We talked about a lot of things and one of
those was pitot tubes and static air pressure sources. I asked him how he
configured and placed his static pressure source? His reply was he
measured it right out the back of the instrument. Did not worry about
whether the AS indicated 50 and he was going 40, etc. He told me that the
AS would always indicate when it was going to stall at the same indication
whether 80 50 40 35, it didn't matter. It would always indicate the same.
The other thing he pointed out to me was cut the pitot tube at a 45 degree
angle. Then when at high angles of attack the pitot tube is still reading
aprx the same size opening. The result, more accurate stall indication.
> In his
The probe location should reflect reality and is more a result of
experimentation than hard engineering data. I've seen the EGT probe
location out as much as 12" from the piston face in some pipes.
I was really leery when the ad said no jetting changes were needed.
What are the odds......
This is only my opinion.....if I wanted more power, I'd look at a 2si
model 808L-100.....80 hp at 5700.....the problem here is these are
thirsty dudes......7 gal hr at 75%.
J. Baker
RUTLEDGE
I did some pin stripeing on my M III it came out just fine on the
second time around
I started out with masking tape , don't do that use a good grade of
tape so the paint wont bleed under it . good luck !
RICK LIBERSAT
writes:
>about
>idea
>Thanks,
>Rutledge Fuller
Subject: | R&D - Just say no. |
Hi all,
I talked to the guy with the R&D problems and he sounds like a very
knowledgeable 2-stroke kinda guy. It sounds like the EGT readings we live by,
are false security on this pipe, and no new numbers have been provided by R&D.
He also reported some of the peakyness problems that Jim Gerken warned of.
Eventually, this might be a good option when they get all the numbers worked
out, but it probably won't be right for everyone.
So where does that leave our sluggish SlingShot? I'm not going to install the
pipe. It hasn't arrived yet, so I'll call tomorrow and cancel the order if they
haven't shipped it yet. If it shows up, I'll just eat the postage to return it.
I'm keeping my eye out for a suitable 4-stroke engine, and in the mean time,
maybe the 503 isn't so bad.
Taking off my guinea pig hat now,
Rusty
Subject: | 2 stroke miseries |
Hello all: Maybe someone in the group can shead some light on a problem I've
got (or rather my 447 has). Be cruisin' along at say 5800 rpm, engine starts
to run rough, EGT heads toward 1200 degrees, bring the power back to say 4800
RPM, engine clears up, EGT comes down, go back to 5800 and everything is fine
maybe for a short while, maybe for a long while, maybe hours. 'Bout to drive
me nuts! Electronic or fuel problem? Have gone through the entire fuel system
including replacing the carb (old carb from previous 377). Had no problems
after replacing the carb (tried rebuilding it first) until last weekend when
it started the same crap again. Plugs look good, maybe a grunt lean. Something
is leaning the mixture a bunch. When it first started doing this, I checked
the pistons and rings: clean as a whistle (love that Pennzoil!). 447 has just
short of 300 hours on it with no prior problems. Haven't changed prop pitch or
anything.
What sort of problems will a bad CDI unit present? Can a bad CDI cause the
timing to advance? I've been told that the timing is fixed. That the CDI
doesn't advance or retard the spark. That the CDI either works or it doesn't
work. The LEAF catalog shows a CDI tester. Ever used one? Will a mag tester do
the same thing? I haven't taken the flywheel off yet to look for maybe a loose
pick-up. But if something was loose, I don't see how it could be so
intermittent. The LEAF catalog mentions ohm readings but evidently you have to
buy the tester in order to find out what they are. Anybody know?
Or maybe it's a fuel problem. I rebuilt the fuel pump before I replaced the
carb, but it didn't help. Maybe I'll try an entirely new fuel pump. Hell, I
don't know. Feel like I'm running around in circles.
Any available knowledge will be greatly appreciated. I've run out of brain
cells.
Bill Griffin
Frustrated in Alabama
Subject: | Re: R&D pipes, are they "better" than Rotax? |
suddenly
>wants more fuel.
...clip
Jim,
Sounds like the design can get binary! :) (all or nothing performance
instead
of smooth curve) Don't worry, I do get your point, and appreciated the
pipe theory reminder. I'd forgotten some of the concepts involved there.
-Ben
Subject: | stupid thing to do |
Thought you would all like to share the wisdom I gained recently with my
twinstar MKII. I had a cracked exhaust and a local metalwork company
welded it for me. When I got it home some bits were rattling around
inside so I turned it upside down several times until all the bits
seemed to have been ejected. After refitment and about 40 mins flying
the engine seized. I landed in a paddock ok and trailered it home. On
examination lots of what looked like grinding swarf and weld scale were
found in the bores of the 503. I suspect these bits stuck to the inside
of the oily exhaust and were pulled back inside the exhaust by the
reverse power pulse when the exhaust got really hot. The moral of the
story is dont expect a 2 stroke exhaust to only go in one direction,
also if you have any welding done on your exhaust system get it really
hot and blow HP air through to expell any bits!, otherwise a new engine
will be required. I hope some of you learn from my expensive mistake!
Group,
I received my plans/manual a few days ago for the Mark III. It is 4:00 AM and
I'm up thinking about gussets on trailing edges to get a smooth finish. I
tend to fixate and it is going to be a long year of building. In a previous
posting Cliff listed his recommendations for building a Mark III:
13.Extra tools - bench vice, grinder with wire brush, Dremel tool.
14.Methods - I used gussets on trailing edges for a smooth cover and
Polytone paint.
Any input and advice from the group on these two particular items would be
greatly appreciated (especially from John H). I had the pleasure of seeing
John H's Mark III at SnF last month and actually spoke with the legend
briefly. To the inexperienced eye, it looked as if the trailing edges on
Miss P'fer were smooth as glass. I'm guessing John used a bent continuous
outside tube with ribs attached by gussets on his trailing edges. I was awe-
struck by the quality and workmanship that went into Miss P'fer. Then John
casually mentioned that this was his third Kolb and he had learned a lot along
the way. Any input based on the all your individual experiences would be
Thanks in advance,
John Bickham
Sleepless in St. Francisville, LA
Subject: | Re: 2 stroke miseries |
In a message dated 5/19/98 8:30:44 PM Pacific Daylight Time, ULDAD(at)aol.com
writes:
<< Maybe I'll try an entirely new fuel pump. Hell, I
I had a similar problem a few years ago which had me running around in
circles. It turned out I had a hairline crack in the muffler. When things
began to heat up the crack would open and everything would go to hell, engine
would roughen, egts would go up. I'd land and then start it again and it
would run fine. It turned out the crack would only open up when the engine
was at opperating temp. When the engine was cold you couldn't see it. This
by the way is an excellent argument for using the Jet hot process on your
muffler because it will show a black line or soot from any leak. Anyway, good
luck, and take a good look at you exhaust system for leaks.
Subject: | The ULTRASTAR.... |
Hello,
I am a teenager, just jumping into the world of ultralights- I am
currently working on glider certification, and powered in a few years.
On a high-schoolers budget, cost is at a premium...so naturally my
eyes turned toward some older models in which would still be good for a
first-time flyer. Two models have caught my eye...the Quicksilver MX
(who doesn't look into the MX line their first time around huh?) and the
Kolb Ultrastar.
Would the Ultrastar be a relativly easy craft to start out
on??...the MX & Ultrastar look like they're on about the same price
level in the used market...but I have a feeling I would like the
performance of the Ultrastar better.
If anyone has some information & or opinions you could throw my way
I'd appreciate it...in the meantime I 'll be dreaming of the skies..
regards,
Ben Kaufman
Subject: | Re: stupid thing to do |
Problem is, the welder wasn't at fault. It's the nature of the two
stroke to form coke on the inside of the exhaust system...and I'll
bet it was the welding that popped it loose. The only way to get rid
of the coke would be vapor cleaning or...a not so hot way but works
sometimes....heat the entire exhaust can to about 900F and then pour
water into the can inlet. May have to do this a couple of
times....works on the same principle as adding some water to a
running engine to loosen internal carbon/coke deposits...also not a
real good idea but can be done if water use is judicious and engine
is up to temperature.....not really recommended tho.
If there were just a crack in the can, welding shouldn't have punched
a hole thru the can to allow any spatter to accumulate so I'll almost
bet you were "coked".
J. Baker
Subject: | Re: The ULTRASTAR.... |
>Hello,
>Kolb Ultrastar.
Sounds like you are ready to get into the world of aviation.The glider
training will pay off at some later date when you have what is refered to as
a dead stick(That chunk of tree wood behind you stopped spinning).
Go for the Ultrastar.The mx may be nice and forgiving at first but you
will probably want a bit more perfomance later on,probably sooner on.I have
taught a student on an Ultrastar without benefit of a 2 seat trainer and he
had no previous training so don't be scared off by people telling you how
difficult it will be ,even the tail dragger part is really a nonissue with
Kolbs because of the low landing speeds,high drag and low tail weight.Also
the Kolb has a steel frame which I like because I believe it saved my life
once.The wings covered with aircraft fabric which will last a lot longer
than the MX and be a lot cheaper to replace when the time comes.Lets not
forget the one biggest selling point all Kolbs except the Flyer has is the
10 min from trailer to air assembly time.
Woody
Subject: | Ultrastar Engine |
Ok peoples...anyone know what kind of engine they hang on the
Ultrastar???
regards,
Ben Kaufman
Woody,
>Lets not
How many in your ground crew?
Skip
Talked to the guys at Green Sky today about my problem. The engine man there
assured me that timing couldn't be the problem. Either the CDI works or it
doesn't. Said he'd bet me a $100 that I had a case or crankshaft seal leak.
Think I'll take the engine off the airframe this weekend. I'll give the
exhaust a good looking over. I'll pull the flywheel and reduction unit and
look for oil leakage. If it looks like a bad seal, I'll send it in for repair.
If I don't see any oil, I'll probably send it in anyway 'cause I'm all out of
ideas and I'm not gonna get into tearing the engine completly apart. Did a top
end on a 377 once but I don't want to try relpacing the crank. Engine has
nearly 300 hrs. on it anyway. Maybe I'll luck up and find something simple
that I missed before. Can't imagine what though. Thanks for the advice. Now if
I only had a bunch of extra cash laying around to pay for it.
Bill Griffin
Original Firestar/Broken (wore-out?) motor
I had a friend who had his muffler bead blasted. The rag they stuffed in the
end fell out durring the blasting and there were a bunch of beads rattling
around in his muffler. He shook out most of them and then got tired and just
bolted the muffler on. After a twenty minute flight he landed and was
horrified to see that it looked like someone had gnawed his prop and then shot
BBs through his ailerons. The beads had come out, hit the prop and then been
batted through the ailerons.
The seal is a diagnostic possibility. My friend with a chalenger had one go
bad because the belt drive was putting too much of a side load on the end
bearing and heating it up. However, his symptoms didn't sound like yours.
His engine wouldn't idle. It would just die at 2000rpm.
In some cases to trace a crankcase leak , I have used a can of starting
fluid (with engine running) spray around seal areas and if there is a leak
the engine will speed up.
Date: Thursday, May 21, 1998 9:56 AM
Subject: Kolb-List: Re: 2 stroke miseries
go
Look at this one logically.....again,.. are BOTH cylinders reading
high EGT? If so, the center seal may...and this is a reserved
"may"....be leaking. If the center seal isn't leaking the odds are
really against both cylinders being affected by a leaking end seal.
J. Baker
Ben (Kaufman),
Go for the UltraStar, it has a lot more performance than a Quick. As a
novice, do be aware the UltraStar will leap into the air with full
throttle and it could surprise you. I once flew an UltraStar for a friend
and had a ball. He got in and gave it full throttle. He didn't expect it
to jump into the air so quick, so he closed the throttle and it came down
ruining the landing gear. He was a little embarrassed, but learned a
lesson. If you got the machine, you might use less than full throttle
takeoffs until you get the hang of it. This will give you more time to
think and there will be less p-factor pulling the plane to the right.
Remember: always use left rudder on takeoff - no exceptions. When you are
ready for crosswinds you will use "less" left rudder (I had to add this
last part so I wouldn't get so much flack back).
Ralph Burlingame
Original FireStar
>Hello,
>my eyes turned toward some older models in which would still be good for
>a first-time flyer. Two models have caught my eye...the Quicksilver MX
>the Kolb Ultrastar.
>way I'd appreciate it...in the meantime I 'll be dreaming of the skies..
>regards,
>Ben Kaufman
Subject: | Firestar For Sale |
I reduced the price on my original Firestar to $7,000. Who do you
know that wants to buy a Firestar? It's a great plane at a great price.
I want to get my new plane in the hanger for the summer. Pictures and
information are available at my home page:
John Jung
Firestar II N6163J
Original Firestar
SE Wisconsin
Subject: | [Fwd: Renewal of your subscription to the INFINI-D list] |
Delivered-To: lvdi.net-cwest(at)lvdi.net
Subject: Kolb-List: Renewal of your subscription to the INFINI-D list
Thu, 21 May 1998 06:00:11
Your subscription to the INFINI-D list is due for renewal. If you wish to
remain subscribed to INFINI-D, please issue the following command to
LISTSERV(at)UAFSYSB.UARK.EDU at your earliest convenience:
CONFIRM INFINI-D
You will be automatically removed from the list if you do not send a
CONFIRM command within the next 7 days.
PS: In order to facilitate the task, this message has been specially
formatted so that you only need to forward it back to
LISTSERV(at)UAFSYSB.UARK.EDU to have the command executed. Note that while
the formats produced by the forwarding function of most mail packages are
supported, replying will seldom work, so make sure to forward and not
reply.
// JOB
CONFIRM INFINI-D
// EOJ
Subject: | What's this INFINI-D list |
does this have anything to do with the Kolb list, or have we been
spammed.
(Netscape Mail Server v1.1) with SMTP id AAA149
Subject: | Fly-in at Sussex N.J. |
There is a big Fly-in at Sussex N.J. ( FWN ) 22, 23, 24 May.
Ultralights galore and many war stories to be told. My Firestar will be
there if the wind stops blowing! See Ya there. Larry Moore
There is a
big Fly-in
at Sussex N.J. ( FWN ) 22, 23, 24 May. Ultralights galore and many
war
stories to be told. My Firestar will be there if the wind stops
Moore
>one go
>end
>yours.
The 447 on my Challenger suffered a broken crank due to the same cause
BUT (and this is a non-reserved BUT!) it always idled just fine and so I
took that as a reason NOT to blame the seals. This was an expensive
assumption.
Apparently, the leaky PTO seal didn't show itself until higher rpm. The
previous owner had just kept putting bigger and bigger main jets in to
keep the CHT out of the red - he never had an EGT!
Upon tearing into the case, it showed just what you describe, overheated
PTO bearing and seal.
-Mick Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
Subject: | Re: Ultrastar Engine |
>Ultrastar???
>regards,
>Ben Kaufman
They came with a cuyuna ul202 but don't let that limit your selection.
Woody
>Woody,
>>Lets not
>Skip
Three me,myself and I. I am also able to throw in a preflight. That time is
from an untied Kolb Twinstar on the trailer.
Woody
From: | Russell Savage <rsavage(at)freenet.columbus.oh.us> |
Subject: | Aviation Awards Night (fwd) |
Kolb friends,
If anyone is in the Columbus, Ohio area, next week there will be a good
aviation awards program put on by the Ohio State University. There is no door
charge and it sounds like it will be worth attending.
My friend Tom Lusch, an Air Traffic Controller at Port Columbus, thinks this
will be a good program.
Russ Savage
Columbus, Ohio
Date: Sat, 16 May 1998 01:01:56 -0400
Subject: Kolb-List: Aviation Awards Night
Assist in spreading the word...
Date: Fri, 15 May 1998 21:24:26 -0600
Dear Tom,
Once again the Aviation Section at Ohio State is having their
"Student Awards night" at the Fawcett Center for Tomorrow. This year it
will take place on Thursday May 28, 1998 between the hours of 7:00pm and
9:00pm. The main guest speaker will be Captain Denis Bonderud, Chief
Pilot for Federal Express. Capt. Connie Tobias, first woman captain with
USAirways is scheduled to be there also. There will be exhibitors, great
food, door prizes and lots of aviation talk. Tell all of the people on
your E-mail list to be there! Pass it on to other aviation lists as
well.
Thanks, Joe
<< The other thing he pointed out to me was cut the pitot tube at a 45 degree
john h >>
Makes a lot a sense to me, John, ...but then again.....what the heck do I
know...GeoR38....hope to see you at Oshkosh
Subject: | Propellor Forces |
In Ralph's recent message about Ultrastars getting off the ground fast
he said P-factor pulls the plane to the right. No, P-factor on a clockwise
rotating prop (like Rotax) pulls (pushes?) the plane to the left.
However, in Kolbs, P-factor is out-done by the clockwise propwash swirl
striking the tail. This force must be stronger, cuz Firestars *do* pull
right at high power, slow speed, e.g. at take-off roll.
Getting back to P-factor ...just look at the prop when it is horizontal:
the right side (starboard) will be at an increased AOA and the left side
will be at a decreased AOA when the plane itself is at a high AOA. The
greater right side prop AOA yaws the plane left.
This got me to thinkin about the post I made recently about trimming yaw
by shimming the engine thrust line. I was incorrect when I
implied that the prop's clockwise air swirl on the tail was the same thing
as torque. No. Being fuzzy on this, i looked it up, and these are two
different forces. As far as I know, the clockwise air swirl doesn't
have a fancy name. But prop torque is simply the opposite twisting
moment put to the airplane made by its effort to turn the prop clockwise.
If you are on a swivel chair, reach out to a desk to give yourself a spin.
You do spin, but you also pushed the desk. The force on the desk (times
the length of your reach) is analogous to prop torque. Torque tends to
roll the plane left, the same direction as P-factor.
I think the only other prop force --besides the good one, thrust -- is
gyroscopic. I forget which way that turns the airplane when the plane
pitches up or down. It's biggest importance might really be in prop
load bearing design. ? (I've heard that gyro forces are generally
less with 3-blade props compared to 2-blade, but this would also depend
on propellor mass, right?)
Bottom line: Right yaw is the dominant unwanted prop force in a FS (I assume
other Kolbs are the same), so left rudder force is required in slow, high
power maneuvers. Good thing it is that simple or we'd maybe want jet power.
(BTW, i've heard of military jet jocks getting into plenty of trouble,
including fatal spins, when they get back into simple little prop planes,
having forgotten about prop forces.)
-Ben 'being picky again' Ransom
Subject: | Re: Propellor Forces |
>have a fancy name.
FWIW- This is called "spiraling slipstream" in the private pilot manuals.
Rusty (keeping Mr. Picky honest) Duffy
From: | Cliff and Carolyn Stripling <striplic(at)nationwide.net> |
Ben and all,
Now how does that affect the Kolb? The darn thing seems to fly just about
as well a little crooked as straight... within limits obviously. I have
tried to measure whether my speed is better holding enough left rudder to
keep the yaw string (a primary flight instrument in a Kolb) centered or
whether to just let it fly a little crooked with no rudder input. I can
measure no difference with my GPS. I suspect that the increased drag on the
rudder just about equals the off set fuselage (what there is of it). Even
still I make it a habit to try to fly it pretty straight with some left
rudder and always keep my slip string centered in turns. Reason is... I
think it does make a big difference when you are flying near stall, making
turns and otherwise manouvering. A crooked plane (slip/skid) will stall one
wing quicker and everyone knows the rest of that story.
Slips: I guess a slip is a slip is a slip, but to me there is some
difference. When I need to compensate for a cross wind I use the low wing
method so that the Kolb slips downhill on its main wings to the side. I
find that my Kolb slips that way just like a Cessna or Cub... maybe better.
Now if I try a forward slip with cross controls to loose altitude, it just
doesn't work for me. There is no long fuselage to lay over on. It is a
wierd/uncomfortable feeling that I find hard to describe.
Flaps: I am still not using flaps (might as well call them parachutes or
drag/chutes) during landings (not even half flaps), but I do use them on
approach if I find myself too high. Wow! They will get you down "right
now". When Dan gave me a demo ride at SNF a few years ago, he used flaps
(full flaps as I recall) on landing. Being used to general aviation, I
could not believe he was going to try to land that high on approach. He
pulled the flaps and pointed the nose WAY down. Piece of cake... for him.
It sure showed me that light planes fly much differently from the kind I was
used to.
I have heard of some guys using half flaps on take off with Kolbs... not a
good idea I think. I don't think flaps gain you any lift over the drag they
create, especially with a pusher engine that provides no prop blast over the
flap surface. Also Kolbs don't have much mass/inerta and if you loose power
with that extra drag, you might find yourself in a real pickle. I had a
partner in a Cessna who use to pop the flaps after gaining speed on a take
off. I never liked to be with him when he did that. Flaps on a Cessna
(tractor engine) might increase lift vs. drag over the first say 10 degrees
and might help in a soft field or STOL situation, but a Kolb's flaps are 2
notches - plenty and WAY plenty.
Any comments, contrary opinions, or other observations?
Cliff & Carolyn Stripling Him: Retired Pharmacist
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
and Marble Falls Texas Both: 5th Wheel - RV - Travel
Kolb MKIII - N582CC (43.3 hrs)
____________________|_____________________
___(+^+)___
(_)
8 8
Same deal in the SS. I've made a couple of landings using forward slips, but I
just don't think it made much difference.
During my transition time with Dan in the Mark-III, we never touched the flaps.
My normal landing would be a wheel landing with plenty of speed. That's the
same way I handled the SS at first, and I've still never made a landing with
flaps. Obviously, this technique won't get you the short landing distances that
the plane is capable of making. Recently, I've been trying to slow my approach
speed to shorten the landing roll, but I can't seem to make a decent landing
this way. All I ever manage to do is smash the tailwheel into the ground before
the mains get close. The next time I go out, I plan to make some landings with
flaps to see if that helps. Since the flaps cause a significant pitch down of
the nose, it seems that my flare attitude should be reduced as well. Perhaps
I'll be able to keep from burying the tailwheel this way. We'll see.
I have much finer increments of flaperon control on the SS, and I've been
meaning to test climb performance with small amounts of flaps. I've always
suspected that this would improve climb a bit in the SS, but it was always too
much trouble to test, so I never got around to it. Now that I finally have a
VSI installed, I'll probably try it.
As for the yaw forces on the plane, I've never quite figured out the trim on the
rudder. My rudder pedal springs don't really match. They're the same length,
but quite a bit different in tension for some reason. I was going to get new
ones, but found that I usually had to hold right rudder in cruise, so I put the
stronger spring on the right pedal to act as trim. This makes cruise close to
straight. On climb, I hold just a little left rudder, and during steep (fast)
power off descents, I hold quite a lot of right rudder. I've noticed that turns
to the right always require significant rudder to center the ball, where turns
to the left are almost neutral. I suspect that the front of my vertical
stabilizer could stand to be offset to the left a bit, but I'm not sure enough
about it to drill out rivets and make new brackets. So far, it hasn't been a
big problem.
Rusty (new top secret engine in the works) Duffy
I went flying today with my buddy. I landed at his short strip with a
headwind of 10 mph and I was able to land in about 150 feet after
clearing the trees at that end. We then went on to Forest Lake where the
lady who owns the airstrip promptly told us that ultralights were not
allowed there. She let us leave them while we walked into town for lunch
(those tiedowns came in handy). The flight back was very rough and the
landing at Maple Plain was hairy. The wind was gusting from different
directions due to the turbulence, and my yaw string was all over the
place. I had to make a go-around because the wind got me as I was
flaring. I was loosing too much airspeed. I was able to pull off a good
landing on the second try. I'm tired.
BTW, thanks for setting me straight Ben.
Ralph Burlingame
Original FireStar
writes:
>clockwise rotating prop (like Rotax) pulls (pushes?) the plane to the
left.
>swirl striking the tail. This force must be stronger, cuz Firestars
*do*
>pull right at high power, slow speed, e.g. at take-off roll.
Hello all,
I'm waiting for my Mark3 kit to arrive and was just wondering what
some of the speeds with the Mark3 will be. With the 582 what will the
lift off, climb, cruise, approach, and landing speeds be. Also, what do
you all think about the HKS engine. I've been told it isn't producing
the horsepower that they claim.
Just waiting and wondering,
Monte Evans
Dallas, Georgia
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Subject: | Re: Mark III Newbee |
Good luck on your new project. There's a couple of things I found when
building mine that I haven't seen on the group. The biggest thing is a 4"
belt / 6" disk, bench sander with a fine grit belt. Mine is a Delta Mod.
31-460, Type 2. Around $130.00, but it quickly became indispensable.
Seldom use my bench grinder any more. With care you can do fairly fine
polishing, and with a medium belt and some pressure, you can really cut
metal. Also very handy is a snap punch. Don't get the $20.00 one with the
wooden knob on it from Home Depot. They're junk. General Hardware's # 79
snap punch is in the same price range from the same store, and lasts
forever. Takes a little knack to use it right. To pick up the dot from
the punch, try a Black + Decker "Bullet Bit". It has a little tip on it to
act as a starter drill. Much easier to start an accurate hole. Then, when
you have a hole in sheet metal, and want to drill a piece accurately behind
it, e.g. - hinges, try a "Turbomax" bit from Chief Auto Parts. I think
they're made by Irwin, p.n. 73308. They resemble a woodworking Forstner
bit, with a shrouded tip. Otherwise, I have a real bad time trying to pick
the center of the hole for a standard bit. Neither of the above bits holds
up very well on 4130, especially the Turbomax. For 4130 steel, I like the
standard Titanium or Cobalt twist drills. Good luck.
Big Lar.
> From: BICUM <BICUM(at)aol.com>
> Subject: Mark III Newbee
> Date: Wednesday, May 20, 1998 3:03 AM
> Group,
AM and
I
previous
> Polytone paint.
be
seeing
on
continuous
awe-
along
> Thanks in advance,
> John Bickham
Ya'll need to get some HSS #30 acft production bits (6", 12",
etc...)....these work well on alum and steel and last quite a while.
Key is, buy 6 of each and don't try to resharpen them. Chuck them.
Much easier.
J. Baker
>allowed there.
I was wondering how much of a problem this still is? If you own a "true"
ultralight, OK, they can say no...
But if you have an "N" number, are you then an "experimental aircraft" and
then "legal" to fly in to any airfield that allows any other "N" numbered
aircraft? No mater what your plane "looks" like?
If this is the case, it looks like one could buy an ultralight, stick a
larger fuel tank and some other bits on it and all the other stuff that
would add on the weight. Call it experimental and get inspected, put on
that new "N" number and walla, you should be able to land any where you
want. True, or just a dream?
I am considering buying a Firestar in the near future and would not mind
having it certified so that I can land and fly anywhere. Will I still get
kicked off a field? Any good stories?
Cheers from an American in England!
Rod Schack
rt(at)schack.keme.co.uk
www.keme.co.uk/~schack
dwegner(at)isd.net
Subject: | ultralight/lightplane and airports |
Rod,
This airport (Forest Lake) is a privately owned strip that receives
funding from the township. We knew this prior to our flight over there.
Rumor has it that the State of MN was going to buy it and convert it into
an ultralight/lightplane strip.
Here in this state, an ultralight or noncertified aircraft can fly into
any uncontrolled airport owned by the state. This has not always been the
case. Just 10 years ago ultralights were still new and considered
dangerous by the aviation community. Attitudes have changed, and now this
state sees a future in ultralight/lightplane aviation and has plans to
open up an airport dedicated to this segment of aviation.
N-numbered aircraft/lightplanes do have full access to most state
controlled airports even though pilots of heavier aircraft are still
sceptical about all these new fangled flying machines. This past week we
had two fatalities in a 2-place Genesis at an uncontrolled airport where
much of the traffic is larger. One of the pilots onboard was an
experimental test pilot. The engine's drive belt broke on takeoff and
they managed to stall and dive it in. This sort of thing keeps the
skepticism alive even though the pilots may not have had enough
experience in that type of aircraft.
I have a friend who has flown his uncertified lightplane across the
country on many occasions. This guy knows how to fly a lightplane under
all conditions. He does not seem to have a problem entering an airport
using his aircraft radio prior to entry. Not all airports around the
country are ultralight friendly. I'm sure it varies from state to state,
although I don't think there is any state in the nation that outlaws
them, although N-numbered lightplanes can be banned from airports where
the traffic is heavy.
We have privilege to least 10 uncontrolled airports and privately owned
strips in a 40 mile radius around the Twin Cities, and with the help from
our state we may have even more places to fly from.
Ralph Burlingame
Original FireStar
writes:
>>allowed there. (Ralph)
>"true" ultralight, OK, they can say no...
>and then "legal" to fly in to any airfield that allows any other "N"
>numbered aircraft? No mater what your plane "looks" like?
>a larger fuel tank and some other bits on it and all the other stuff
>that would add on the weight. Call it experimental and get inspected,
put
>on that new "N" number and walla, you should be able to land any where
>you want. True, or just a dream?
>mind having it certified so that I can land and fly anywhere. Will I
still
>get kicked off a field? Any good stories?
>Rod Schack
Rod,
The two big concerns about ultralights mixing with general aviation
are: the slow speed and lack of pilot trainning. If you have a pilots
licience, one solved. If you fly a Firstar the second is solved. Even a
377 Firstar can fly 70 mph in the pattern, which is as fast as the
pattern speed for a Cessna 150. In Wisconsin we have over 150 public
airports. In 9 years of flying ultralights, I have never been told that
I wasn't welcome. The biggest reason that ultralighters (that I am aware
of) have been told not to come back, is that they don't know how to fly
an airport pattern.
John Jung
SE Wisconsin (60 miles south of Oshkosh)
I fly to the EAA Fly-In, because it is easier than driving.
>Rod Schack wrote:
snip..
> Rod Schack
Subject: | Re: ultralight/lightplane and airports |
Ralph, Are you saying that the Kolb/Callenger/etc type planes could be banned,
while the C-150's and Tomahawks could still operate? It seems like it would be
difficult to ban my SlingShot and still let a Tomahawk operate, but I can
imagine them trying to stop all GA traffic at a large busy airport.
Fortunately, if it's that busy, I wouldn't want to fly there anyway.
Rusty
> Good luck.
> Big Lar.
Wal-Mart sells them as cheap as anybody. Buy at least a dozen before
you start, and throw them away as soon as they dull. You won't regret it.
Richard Pike
MKIII N420P (42oldpoops)
>From: Ralph H Burlingame
>>allowed there.
>Rod Schack
> If it is a privately owned airstrip, and has received public funds,
they can throw Air Force 1 off, no questions asked. If you have N-numbers,
and they have received public funds to build anything, they can only deny
access for safety reasons, and they have to have a required equipment list.
Normally all that is required is brakes, maybe radios, and in Virginia,
insurance.
Richard Pike
Subject: | Re: Mark3 Speeds? |
>Date: Sun, 24 May 1998 13:04:02 -0400
>To: Monte
>From: Richard Pike <rpike(at)preferred.com>
>Subject: Re: Mark3 Speeds?
>>Hello all,
>> Monte Evans
>> Dallas, Georgia
> I have the MKIII with the 532, and 495 lbs. empty weight. I climb
out at 50, cruise at 50-65, and fly the approach at 55. You can fly the
approach slower, but be careful the bottom doesn't fall out when you go to
flare.
> Stall solo is 28 indicated, dual is 32. Flaps don't change the
stall speed much, but really kill your float in ground effect, and can
steepen your approach tremendously into a short field over an obstacle.
> As far as the HKS engine, I would not use anything less than 65 HP
on the MKIII, unless you and your passenger weigh less than 120 LBS each,
and you build it stripped, to come in at less than 450 LBS.
> Top end so far is around 80, am doing some mods to reduce drag
around the cockpit area, will post results after I find out what difference
they make.
> Richard Pike
Subject: | junk in gasoline |
I just am doing my annual inspection on My Firestar 2, and when I replaced the
fuel lines and drained the tanks i was amazed at how much junk was in the
bottom of the tanks, auto gasoline is sure dirty compared to AV gas. My motor
has 100 hours and 1 year oy flying time.
Just FYI incase you have never cleaned your tanks.
tim
I registered my Firestar 2 experimental just for the reasons listed.
The city airport I fly from does not allow ultra lights and since I have a
registered airplane, I have heard comments but there is nothing they can do as
long as I fly according to the rules.
I have been told that once an airport has ever received and Federal funds,
there is no way they can keep any kind of aviation from using the facility,
with this being true, the ultra light club has addressed the airport board,
but they still say no. No body has pushed this to a point of getting an
attorney, but I wonder what would happen. (kind a sorry on has to resort to
this)
One of the other advantages I see to registering it is that I have liability
insurance.
When it was inspected by the FAA, they were very interested and loved the
plane. In fact at first they wondered whey I did not fly it as an ultra light,
makes you realize just how much they do not pay attention to 103.
Enough of a book, but I love having it registered experimental.
Subject: | Re: junk in gasoline |
Same here Tim. When I removed the jugs to install the new tank, I found all
kinds of stuff in the bottom of the jugs. Fortunately, the top mounted fuel
tubes that Kolb has been using don't quite go all the way to the bottom of the
tank. I always figured that would keep me from picking up water and crud that
fell to the bottom. Dennis is a crafty devil, maybe he planned it that way :-)
Rusty
Subject: | Re: Slipping (was prop forces) |
>Ben and all,
assume
power.
My point was to iron out some technical wrinkles in previous posts,
mine included. (I think we can all be proud of a list with great
information instead of some net-based stuff that is full of
misinformation.) As for 'how good it flies, i agree, it would be
impossible to discern any differences in speed/drag due to minor yaw
trim changes. I wouldn't chase the yarn except during practice to
see how sloppy my turns have gotten.
Forward slips: They may not feel like leaning a conventional fuselaged
plane on its side, but i know they are effective on a FS. The evidence
for this is how much increased forward stick is required to maintain
airspeed during a slip. In fact, I cannot keep a sustained full rudder
slip without running out of forward stick travel, or airspeed! :0
Besides this hard evidence, it seems clear from the look of things that
a slip really does waste altitude pretty well. I really love hangin it
sideways, targeting a spot landing, and ideally, do that every landing.
(Bleeding a little excess altitude is so much better than wishing you
had a little more.) Fun!
Anybody who's flown both the FS and the Mk II and III Kolbs: do you
feel slipping is less effective in the bigger II and III? (Could be
with greater wing area i spose.)
-Ben Ransom
Subject: | Re: legal Forces |
>Rod,
I haven't been that lucky. I went out of my way to ask my local Fed funded
airport about any special patterns, etc. This was 3 months before I even
finished construction. He not only uninvited me, he flatly told me
ultralights were not allowed. His policy is illegal, and the FAA has
verified that to me and to him. But there is so much "City Hall BS",
and the FAA is busy with other things, that the policy still stands
there. I fly there on wknds when mr slick-boy-airport-manager is not
around, and have become friends with the GA pilots.
I think that in general, you are bound to find airport access problems
flying an ultralight. This may be rare, but indeed a hassle, even if your
plane is FAR103 legal. If you are not FAR103 legal, you may be required
to show proof of insurance -- at least at your homebase airport. This is
what truely puts you in a legal predicament. (I'm reluctant to push for
FAR103 rights at my local airport, cuz when they are forced to allow me
legitimate access, they will also force me to buy insurance, which i
can't legally do.) If you register it Experimental, they may want to
sneer at you, but will change their tune the minute they see the N-number.
-Ben Ransom
Rod and all,
Interesting subject. Anyone out there, correct me if I am wrong in any
details... The "experimental" operating limitations say one should not fly
over densely populated areas or in congested airways. I think the intent of
this is obvious - stay out of "B" airspace (unless you have the proper
equipment) - keep to the suburbs and countryside. You are bound to follow
all pertinent rules but otherwise can enjoy the system of ATC as any other
plane and you must identify yourself as "experimental" to any air traffic
control tower.
In the U.S., public airports should not be able to restrict you if you are
"N" numbered and otherwise legal in the eyes of the FAA. I have had no
trouble at all, but on the other hand, I seldom fly into any and none that
have a tower. My radio is still blinky (in transmission) and I don't want
to stress out or give any tower personnel an ulcer. I use private (allowing
public access) or public non-towner airports (there are plenty of them
around here) or those where I am welcome by the actual owner. Again, I have
had no trouble with anyone... so far. With the confusion of what is UL and
what is otherwise in the minds of some, I can see how problems could and do
occur.
My story... The only exception was the airport where I hanger my plane. It
is a private airport (but allowing public access). They did not want me to
"test" my plane there, especially first flight. They also wanted me to have
"liability" insurance. I could not get "any" insurance during the first 10
hours at any price. They had just had a fatal accident (a light
experimental plane) and were paranoid about another at the time. I found
myself in a catch 22. Ultimately, I was reluctantly allowed to test and fly
from there (as said by the board "if I kept my nose clean" - boy did I "not"
feel welcome) without any restrictions thanks in large part to my landlord
who darned near climbed up on the table and screamed and hollered about
their restricting my flying rights and his loss of ability to earn income
from his hangers. It was quite a meeting. The bottom line was while
privately owned (through a property owners association and airport board,
etc.) they did allow public access. Another plus was that I hangered there.
What good is a hanger if you cannot fly?
Oh well, as the world squirms.
Later,
___(+^+)___
(_)
8 8
Monte and all,
Something I failed to tell you is that my indicated ASI speeds are about 10
mph high on the low end and 15 mph high on the upper end. Seems like most
Kolb guys report having ASI's that read higher than actual. A few have
reported the opposite. Just be sure to nail your "indicated" stall speed
down ASAP and don't get in the mind set that your "indicated" speeds will
register perfect as the stated actual speeds in the company literature. As
in my case my ASI was reading 45 mph stalls (about 35 actual). Boy was I
surprised when the stall break came 10 mph early. The lift off speed is a
fair indication if you do runway flights, otherwise you probably should
carry plenty of "indicated" speed and do an approach to stall with at least
a couple of thousand (better 3K) feet of altitude on your first flight. I
got within 5 mph of my stall speed during climb out on my second flight when
I was not paying close attention... trying to notice and mentally record
EGT's, water temps, rpms, and a host of other "new" flying
characteristics... a little slower and I could have been one of those
stories you hear about. "Well he just took off and was turning left in the
pattern when his left wing dropped and..." It happens all to often with
all kinds of planes. That is another reason why I put the red slash across
my ASI at 5 mph above my indicated stall and keep telling myself that IS my
stall speed. I may have a problem some day, but I don't want it to be a
stall/spin.
Later,
___(+^+)___
(_)
8 8
Rusty,
Take a look at the Class B airspace (large airports). You won't find any
ultralight/lightplanes there, but you will see N-numbered C-150's or
other types like them.
Ralph
>>where the traffic is heavy.
>banned, while the C-150's and Tomahawks could still operate? It seems
like it
>would be difficult to ban my SlingShot and still let a Tomahawk operate,
but I
>can imagine them trying to stop all GA traffic at a large busy airport.
>Rusty
Tim,
I've drained my tanks every year except this year. The reason I didn't is
because I never see anything in the tank. I think most of the
contamination is not from the gas station, but rather from how the fuel
is stored or from the fuel transfer. I try to keep my gas as clean as
possible by storing my transfer funnel in a plastic trash bag and all my
fuel in "UL only" gas containers. In the UK all microlight fuel is
filtered before going into the tank which isn't a bad idea. This is
another good reason for a large fuel filter, just in case. One more
thing, try to buy your gas from a new station that is used frequently.
Ralph Burlingame
Original FireStar
>replaced the fuel lines and drained the tanks i was amazed at how much
junk >was in the bottom of the tanks, auto gasoline is sure dirty
compared to AV >gas. My motor has 100 hours and 1 year oy flying time.
>tim
Subject: | Re: My Nnumbered |
Tim,
If you have a FireStar II, wouldn't you have to N-number it with the 2
seats? I suppose you could fly it as an ultralight trainer under USUA
exemption. I'm really surprised to hear that FAA inspector even mention
flying it as an ultralight!
Be careful, the FAA is up to date on all the ultralight aircraft and
whether they are capable of carrying two people or not. We had a
representative of the FAA at our last safety seminar and he was one very
knowledgable guy on ultralights. He knew exactly what a Kolb FireStar was
and many others.
Ralph Burlingame
Original FireStar
>have a registered airplane, I have heard comments but there is nothing
they
>can do as long as I fly according to the rules.
>funds, there is no way they can keep any kind of aviation from using the
>facility, with this being true, the ultra light club has addressed the
airport
>board, but they still say no. No body has pushed this to a point of
getting
>an attorney, but I wonder what would happen. (kind a sorry on has to
>resort to this) One of the other advantages I see to registering it is
that I have
>liability insurance. When it was inspected by the FAA, they were very
>interested and loved the plane. In fact at first they wondered whey I
did not fly it >as an ultralight, makes you realize just how much they do
not pay attention to >103.
Hi Gang
As I was helping my friend Andy build his MK111 I took videos of all the
important processes.This being my 3rd Kolb I had a good idea on how they go
together.Now I have all this video tape and I was wondering if there would
be an interest in a "how to video" for building a Kolb.Since all Kolbs go
together in much the same way this should help all builders.What do you
think should I spend a lot of time editing the tape to make the video or
just keep it for my own records.I estimate it will be over 2 hrs long and
priced in the usual $30 range.
Woody
>Hi Richard,
> Thanks for the reply. What is the difference between the 582 and
>the 532? Another question, do you have the electric start or think it
>is necessary on the 582? I don't plan to get my engine till I'm ready
>for it because of the warranty. Hope you don't mind all my questions.
> Thanks again,
> Monte
> The 532 is the predecessor of the 582. It has single ignition with
points, the biggest noticable difference is the power band. The 582 has a
much flatter torque curve, and is not as "pipey".
I have electric start, and love it. If you are planning to get a
Rotax engine with the Ducati ignition system, you need to know the Ducati is
a little reluctant to make sparks below 300 rpm. One the other hand, you
might be able to pull the starter rope better than most, and may not need an
electric starter.
> Richard Pike
>>insurance.
>> Richard Pike
>Richard, I don't get what you mean:
>Privately owned and received public funds... <-- I thought they were required
>to allow N-numbered (and FAR103) access, unless there are proven safety
>reasons. Why do you say they could deny AF1?
>-Ben Ransom
> SCREWED UP AGAIN !!!!!!! I meant to have the word "not" between
the words "has" and the word "received" in the first line.
Failure to proof read?
Let me start over: If it is a privately owned airstrip and has NOT
received public funding, they don't have to let anybody in they don't want
to. If they HAVE received public pork, then it gets more complicated, and if
you are arbitrarily refused access, it might be worth your trouble to drop a
letter detailing specifics to your local Airports District Office.
Richard Pike
>Rusty,
>Ralph
>like it
>but I
>>Rusty
Could be that the GO/NO GO gauge is called a transponder?
Richard Pike
Richard.Dewitt(at)HBC.honeywell.com
Richard,
Do you believe that a transponder would be the deciding factor? The FAA
knows that mixing lightplane traffic with heavies would spell out
disaster and I agree. When landing in a jetliner, the last thing I would
want to see (if I could) would be some dinky ultralight even remotely
close to our approach. Would you want to fly your lightplane in Class B
airspace? No thanks.
Ralph Burlingame
Original FireStar
>writes:
> Richard Pike
>>Rusty,
>>any ultralight/lightplanes there, but you will see N-numbered C-150's
or
>>Ralph
>>>writes:
>>>be banned, while the C-150's and Tomahawks could still operate? It
>>>seems like it would be difficult to ban my SlingShot and still let a
Tomahawk
>>>operate, but I can imagine them trying to stop all GA traffic at a
large busy
>>>airport. Fortunately, if it's that busy, I wouldn't want to fly there
anyway.
>>>Rusty
dwegner(at)isd.net, lnachtwe(at)isd.net
Richard,
Hmmmm, maybe I do have a right to fly into Forest Lake after all.
Ralph Burlingame
Original FireStar
writes:
>NOT received public funding, they don't have to let anybody in they
don't
>want to. If they HAVE received public pork, then it gets more
complicated,
>and if you are arbitrarily refused access, it might be worth your
trouble to
>drop a letter detailing specifics to your local Airports District
Office.
> Richard Pike
> found all
> fell to the bottom.
Except for the water problem , why not use a filter in the tank. The
most useful type is the one with the wire mesh screen and the coiled
wire around the outside. Mine resides on a short section of
urethane tubing attached to the aluminum stand pipe. Stops bug crud
then goes thru the normal filter anyway.
J. Baker
To all,
Good idea. I also sump the tanks with a siphon made from a piece of 5/16th
alum tubing, a squeeze bulb and fuel tubing into a milk jug. You can
navigate the aluminum tube all around the bottom of the fuel tank. I suck
up about 1/4 gallon on each side, let it sit awhile, check for water/trash
and decant all but a little back into the tanks. I do this before each flight.
While checking and cleaning the fuel bowls of the carbs at 50 hours, I found
no deposits in the bottom or anything on the screens and my fuel filter
"looks" clean.
Later,
___(+^+)___
(_)
8 8
>Date: Mon, 25 May 1998 10:52:06 -0500
>To: Cliff and Carolyn Stripling
>From: john hauck <hawk36(at)mindspring.com>
>Subject: Re: junk in gasoline
>In-Reply-To: <1.5.4.32.19980525151336.006730f8(at)dfw.net>
>Ciff:
>Know what those little cylindrcal screens are for in the float bowls?
>They are to keep air bubbles out of the main jet sumps. W/O them the fuel
mixture could lean out.
>john h
>Date: Mon, 25 May 1998 10:08:13 -0500
>To: ul15rhb(at)juno.com (Ralph H Burlingame)
>Subject: Re: ultralight/lightplane and airports
>In-Reply-To: <19980525.084408.7975.0.ul15rhb(at)juno.com>
>References: <1.5.4.32.19980525035917.0068a37c(at)preferred.com>
>>Richard,
>Yep:
>And we have lost some good ultralighters from wake turbulence from large
aircraft. I am uncomfortable at Lakeland flying in the vicinity of large
aircraft, especially warbirds, that fly just above the UL pattern. Wake
Turb and Wing Tip Vortices are invisible. Can't see them til they hit you.
It gets pretty exciting flying the Sling Shot up or down through UL turb
and prop wash in the pattern, much less a real heavy. Ya'll be careful
around those big planes.
>john h
>Date: Mon, 25 May 1998 10:22:58 -0500
>To: jlbaker(at)telepath.com
>In-Reply-To: <199805251403.JAA18533(at)telepath.com>
>References: <000c01bd873e$d63bb040$0100a8c0@rad.pen.net>
>>> found all
fuel
of the
crud that
>>> fell to the bottom.
>Happy Memorial Day Gents:
>Let's not forget our military and the guys who paid the ultimate price so
we can enjoy the feeedom to build and fly our planes.
>Jim, the filter in the tank is a "finger strainer". Every fuel tank
should have one. It prevents a larger pice of crud from stopping up the
outlet pipe of the fuel line. Has wire mesh (usually brass wire) finger on
threaded fitting. I got mine in Miss P'fer. On the other hand, the fuel
tank in my old Sea Ray does not. There is a clump of sealer that fell into
the tank fill hose. Occasionally, that piece of crud partially blocks the
outlet and the old 351W starts loosing power, starving for fuel. If it had
a finger strainer on it, wouldn't even know I had a problem.
>john h
Subject: | Follow Up Question? |
Thanks to all for helping me figure the ultralight Vs the "others"
question.
If I could follow up with another...
Is it possible to buy a complete and flying used ultralight, then
somehow get it certified as experimental, but make it so that you can do
your own inspections, repairs and the like?
I would think this might involve completely disassembling the original
aircraft and then rebuilding it by your own hands. Then, adding the
bits on to make it legally experimental and with you as the builder.
I want to buy used, but also do not want to need to pay someone else to
do my annual and the like.
Cheers!
Rod Schack
the
ultralight Vs the "others" question.
another...
flying used
ultralight, then somehow get it certified as experimental, but make it
so that
you can do your own inspections, repairs and the like?
completely
disassembling the original aircraft and then rebuilding it by your own
hands. Then, adding the bits on to make it legally
experimental and
want to need
to pay someone else to do my annual and the like.
Cheers!
Rod Schack
Does anyone use a variometer on their ultralight? I'm interested in the
least expensive unit required to do serious soaring in an ultralight. I
noticed units priced from $340 to $167, from non-electric dial to
electric beepers that fit inside a helmet. Any recommendations from
actual experience???
Hi Gang -
Here in the east, we recently had an airport owner take the position that
the ultralight could stay. However, all aircraft based at the field, had
to carry $500,000.00 liability insurance. Have you called an insurance
company requesting that much liability ?
I think you will find that the best amount you can find is $50,000.00.
However, with an N number the aircraft will be insured as a homebuilt.
My Pazmany PL-4A is insured at $500,000.00 an annual cost of $187.00. I
have added aircraft damage - non-flight at $144.00 - total $331.00. -
In any event the ultralights relocated to another friendlier airfield.
And guys - when you live in the land of no people - attitudes are better!
Kolb wanna-be
Bob Cooper
Newfield, NJ
writes:
>>Rod,
>aviation
>a
>that
>aware
>funded
>even
>your
>required
>is
>for
>me
>N-number.
>-Ben Ransom
Subject: | Re: Follow Up Question? |
Rod,
You've got the right idea. It's called the 51% rule. You have to be able to
prove that more than 51% of the aircraft was amateur built in order to register
it in the "experimental-amateur built" category. The original builder could
assist you in registering the plane, but it's unlikely that they would want to,
and it wouldn't be exactly what you're after anyway. You personally, have to be
the builder to get the repairman's certificate.
Your plan of disassembly should work. Just make sure that you document
everything. Take lots of pictures along the way, and be certain to get shots of
the most disassembled condition. It would probably be wise to inform the local
FAA office, or your local DAR (designated airworthieness representative) of your
intentions before you start. Deciding exactly how much 51% is becomes
subjective, and their opinion is ultimately going to be the one that counts.
All that being said, I would be reluctant to disassemble anything that was good
to start with. If you drill out a good rivet, then replace it, you'll probably
have something that isn't quite as good as it was before. It's difficult to
drill out a steel rivet without doing any damage to the hole. Hopefully, you
can negotiate this with your inspector.
Good luck,
Rusty
SlingShot (31.4 hrs)
Is it possible to buy a complete and flying used ultralight, then somehow get it
certified as experimental, but make it so that you can do your own inspections,
I would think this might involve completely disassembling the original aircraft
and then rebuilding it by your own hands. Then, adding the bits on to make it
I want to buy used, but also do not want to need to pay someone else to do my
Cheers!
Rod Schack
Hi all,
I did a few experiments today based on some of the recent topics. This was in
an underpowered SlingShot.
1- Using partial flaps for climb.
I only have two notches of flaps in my current configuration. They are 7
degrees, and 12 degrees. Adding 7 degrees seems to help my climb rate, but not
enough to be worth doing it. 12 degrees showed a notable loss of climb rate.
Tests were done at the normal best climb speed of 58 mph.
2- Forward slips.
I made several descents with and without slipping the plane. Speed was kept at
60 mph for all tests. Normal rate of descent for my plane is 700 fpm in this
condition, and slipping didn't change it any that I could measure. When
slipping, I held the plane at a pretty severe angle, but this still wasn't max
slip. It just isn't the same as a GA plane. I'm used to being able to hear all
the extra wind resistance of the fuselage, but the SS is just an egg, and I
guess it doesn't much matter which way it travels. There must be some extra
drag, but not enough to really use.
3- Flaps for a better slow landing.
No help here. It's a good thing I picked an empty airport to practice at,
because some of my landings were downright ugly. I can make a smooth landing if
I land , but when I try to come in at less than 60 mph, either the tail hits
first when trying to flare, or the mains hit hard and I bounce. Sometimes both
:-) The problem is obviously the pilot, because I've watched Dennis and John
Hauck make impossibly short landings in the factory SS. I guess I'll just have
to practice some more, or get John H. to come down here and show me how to fly
my plane.
4- SS landing gear test.
Yep. It takes a real beating :-)
Rusty
SlingShot (31.4 hours and about 3 good landings)
Subject: | Re: slips and flaps |
just have
fly
>my plane.
Hey Rusty: When one is showing off one must pick a day at Lakeland with a
25 kt headwind for landing. Anybody can land short in those conditions.
John,
I use an electric one that was designed for hang gliders. It runs
all year on a 9 volt battery, and is usually strapped to the wrist. I
strap it to my leg (no more panel space). It has a lcd display and is
very sensitive. The cost is $300+ new, but I bought mine used.
John Jung
What is the name of your insurance company? I want to talk to them
about insuring my plane.
John Jung
Firestar II N6163J 6.4 hrs
>robert w. cooper wrote:
snip
snip
> Kolb wanna-be
> Bob Cooper
> Newfield, NJ
>Richard,
>Ralph Burlingame
>Original FireStar
I totally agree about getting into wake turbulence. However, class B
airspace is positive control airspace. Everyone has to be under ATC control,
and separation standards between small vs. large, small vs. heavy, large vs.
heavy, B757's, etc. are a controllers soup sandwich. However, I suspect you
are better off in class B with positive separation than in class C, or class
D airspace with pseudo separation. (green-between)
I have no plans to be in class B or C airspace anytime soon. But if
I did, I would call ATC and tell them the 4 W's:
Who I is; What I is, Where I is, What I want. And then I would
toodle along the same way I usually do: listening to all the traffic they
talk to, and trying to figure out where it is even before they call traffic
for me. And looking for the one they forget.
Richard Pike
My wife gave me a Makiki Electronics Vario in 1984 for my Hummer. I
still have it in the MKIII. It uses a vacuum flask with two little pith
balls that float up for lift or sink. it is not fancy, but seems sensitive.
It cost $75 in 1984, don't know if they are still in business.
Makiki Electronics
P.O. Box 629
Kauula, Hi. 96717
808-293-9348
This data is off the instrument, don't know if it is still good.
Richard Pike
<< I went flying today with my buddy. I landed at his short strip with a
allowed there. She let us leave them while we walked into town for lunch >>
Ralph....I have a firestar KX and have a rough time landing in less than 750
ft....so I bought brakes that am installing now ( boy are they heavy...from
Kolb) ....but I'm only expecting to get my landings down to 450 or
so...GeoR38 the ol fast landing glider pilot!
John,
I took that little screen filter out of the float bowl years ago and have
never had a problem.
Ralph Burlingame
Original FireStar
writes:
>>Ciff:
>>fuel mixture could lean out.
>>john h
Who do you have your ins. with ? On my M/III I used Nation Air
insurance agency
in Dallas ,Tx. with the same liability as you . and mine is higher
I may have to think about changeing ,
RICK LIBERSAT
writes:
>Hi Gang -
>that the ultralight could stay. However, all aircraft based at the
>field, had to carry $500,000.00 liability insurance. Have you called
>an insurance company requesting that much liability ?
>homebuilt. My Pazmany PL-4A is insured at $500,000.00 an annual cost
>of $187.00. I have added aircraft damage - non-flight at $144.00 -
>total $331.00. -
>better!
>Kolb wanna-be
>Bob Cooper
>Newfield, NJ
>writes:
>>>Rod,
>>aviation
>pilots
>Even
>>a
>>that
>>aware
>>funded
>>even
>problems
>>your
>>required
>This
>>is
>>for
>>me
>>N-number.
>>-Ben Ransom
Subject: | General MK-III flying thoughts |
Hi everyone-- I'm Larry Fuller and just got on the Kolb net a few weeks
ago. I fly an unusual Mark III. Mine has a Revmaster 2100D engine,
Rocky Mr. Engine instruments along with a UMB AIS, Altm, Compass, an IVO
3 bladed propand a BRS. To date I have ~ 33 hours logged. It has been
an education. I have had a private, SEL rating since the late 1950's and
have logged ~1200 hours.
My instrument package has the RS-232 interface and I log a lot of the
engine data, on my lap top computer, while the tests are going on--
makes it a lot easier to analyze when I'm not busy flying my test plan.
I guess I really should say that I'm flying a Mark III Heavy. My first
flight was exciting due to an out of trim condition. I installed the
aileron trim tab that Dennis recommends and All is well now.
The biggest problem that I have had was a sticking AIS, this resulted in
some hard landings until I found out what was happening with the AIS.
UMB replaced the unit under warranty. I've also had landing gear
problems-- bent even with good landings. I redesigned the gear and have
a 4130 sleeve inside the fuselage tube and a heat treated 6150 spring
steel rod external. The gear now has ~ 12 hours on it and it is doing
fine.
My current test plan is two parts, (1) fine tune the prop pitch and (2)
continue increasing the weight to the maximum.
I replaced the passenger seat with a 1/2 inch Alum. plate to mount the
weights and the computer system-- Oh yes I programmed the lap top to
display the instrument data as bar graphs that change colors with the
change in temp. etc. I'm trying to develop a decent display that won't
wash out in direct sun light.
Others have mentioned problems with water in the fuel tanks-- keep them
full all the time on the ground! No condensation or very little this
way.
Other Kolb flyers have mentioned the "tail wheel banging", been there -
done that. I got tired of what was happening on landings and went back
to the old weight and balance and started weighing the tail, started with
the level position and lowered it 3 inches at a time and re weighed it at
each interval. What an eye opener! The weight shift is significant when
the tail starts to drop. I now make sure that I don't start the flair
until I'm 2 to 3 feet off the ground and I usually come in "Hot" and pull
the power off and push the nose over just as the wheels touch.
More later--
Larry Fuller
George,
I used to land hot too and eat up a lot of runway until I watched the
Kolb factory pilot land that FireStar inside of 150 feet or so. The
secret is to slow the approach down to 40 mph with some power (about
3000rpm) then at about 20 feet from touchdown close the throttle and get
the timing of the flare just right. As soon as the speed begins to drop
off, pull back on the stick and it will slow down as if you had brakes
(induced drag of the wing). In a wind, I carry about 5 mph more on
approach.
Try to work on complete power off landings (at idle) from 500 feet. Then
when you gain confidence in your landings, shut it off from 500 feet.
Being a glider pilot, I'll bet you could soar that ultralight and make
power-off landings every time.
I once shut it off at 2600 feet and a mile and a half out. I glided back
and made a good landing. Not only was it fun, but I learned quite a bit
about the glide of a FireStar and how to make it land short. I know those
Rotax's are reliable, but you never know.
Ralph Burlingame
Original FireStar
>than 750 ft....so I bought brakes that am installing now ( boy are they
>heavy...from Kolb) ....but I'm only expecting to get my landings down
to 450 or
Subject: | Kolb: Junk in gasoline |
Hi guys,
Been reading all the postings about water (and other junk) in the fuel. I
have the Dial-A-Jet installed and one of the side benefits is that any water
that might get into the float bowl is immediately siphoned out by the DAJ and
injected into the carb airstream to be burned? and disposed of. Don't think
it will take any junk through though because the tubing is of the small 1/8"
size.
Bill Varnes
Original Firestar
377 power
Subject: | Re: slow landings |
Ralph and all,
I wish I had gotten my glider license. It would have given me more
confidence in a possible engine out. My total hours are only about 250
since the '70's. Thank goodness I have about 60 hours of recent time. I
have to keep telling myself... the first thing you do when you hear silence
is to push the stick FORWARD... then evaluate the situation. The elevator
is mis-named isn't it? Didn't "Stick and Rudder" call it the speed control
and the throttle the altitude control? ...or am I remembering some other
instructional flying book or just dreaming.
I have to admit that I fear an engine out. I know that 2-cycles are not
that reliable... especially meaning when they quit, they quit, with little
or no warning. You know the old addage ...it is not if but when... I
always do try to fly the pattern as if my engine could quit anytime. I
always try to approach with about 3K rpm (does that equivicate to an engine
out in your opinion?) vs. a stopped prop so that if I loose it I will be
able to make the field. I always make my approach a bit high for the same
reason... and for that reason I sometimes have to pop a little flaps on
approach to kill the extra altitude them dump them before short final and
flare. I doubt if I will ever intentionally shut it down. Silence is NOT
"golden" to me. I like the ERRRRRRR! ...so comforting for chicken little...
On the subject of shortening landings, I usually use up about 600' because I
come in fast (ideally 10+ mph over stall) and usually decide at the last
minute whether to wheel land or transition into a 3-point. I would like in
time to become more proficient and use the flaps and land as you have
indicated. It looks great to see it done right... like in the Kolb video
and at the airshows by the real pros. It is just going to take time. You
screw it up just once and you might bend your gear at the very least. I
didn't put a "butt sled" (sheet of aluminum under the seat for protection)
in my plane either. "Humor" attempt there...
Later,
___(+^+)___
(_)
8 8
Subject: | RE: My Nnumbered |
I have just spent the last 2 months going through this with the Norfolk,
NE
airport. It started out with no one even knowing what the proper airspace
was for OFK (the airport manager is new). Once we found that out, (Surface
Class E), I had all sorts of conflicting stories about what we could do with
it and who's in charge. I finally got to the right person at the
Minneapolis Center (500 miles away), and all he needed was a signed
agreement between the club and us. I expect to have that signed over this
noon hour. What started out as "no ultralights" has ended up with us having
our own UL flight park at the North end of the airport. They're going to
mow us a couple of strips and eventually allow us to build our own hangars
out there.
Have all your ducks in a row when you go through the process, and stress
safety always. They'll be impressed. We require all of our pilots to have
a pilot's rating from one of the 3 orgs, or demonstrated ability (for
old-timers who were flying before the orgs existance). We're thinking of
requiring helmets for all ULs also.
J.D. Stewart
NCF Communications, Inc. http://www.ncfcomm.com
Northeast Nebraska Flying Club
http://www.users.ncfcomm.com/nnfc/index.html
> The city airport I fly from does not allow ultra lights ...
> facility,
> airport board, but they still say no. No body has pushed this to a point
of getting an
> resort to
> this)
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
Fear is healthy, but really, a controlled engine out isn't too big a
deal if you do it on a long strip, and right after a series of engine
idle landings where you do hit your spot. Aim for 1/3 down a 2000 foot
strip in calm wind for starters.
Being comfy with STOL landings is a very nice benefit of a Kolb -- allows
you to fly into many off-the-beaten-path places -- this especially in
the lightest wing-load models. I think the 'trick' to getting down to
short landings is to mentally focus on sticking the nose into the dirt
(cement/whatever); i.e. don't really flare till 10' off the ground,
~10mph above stall. For really tight ones where there are obstacles,
and/or if there is wind, carry some power and fly it slow onto the
spot -- a la carrier hook landing. If you really do flare at the last
couple seconds, it only takes a couple seconds (obviously), so you must
feel pretty automatic with how much stick to pull without underflaring
or ballooning. Getting good at short landings could come in handy if
(read when) the above engine-out thing ever bites. I also *know* that
going from heavier planes to being good at this feels very unnatural.
Now, i feel i should add the standard disclaimers:
-be careful
-progress to this in small increments
-don't blame me
-etc, etc
-Ben Ransom
Hi Larry: Very interesting project. I believe several of us may be interested
in your engine choice. Are you using a PRSU on you Revmaster or is it direct
drive? How much does the engine/drive weigh? How does performance compare to
582/912 installations? Is your line of thrust changed much from that of Rotax
installations?
Bill Griffin
MKIII/EA-81(one of these days/years)
Subject: | USUA mag this month |
To all,
I just read this month's mag. There are ads (actually a whole column) for
two Kolbs in there that look very interesting. One is a MKIII with lots of
expensive goodies for $12.5K. Another is an unfinished Firefly for $2K or
so less than invested. Interesting ads. If I were a wannabee...
Kolb got a blurb about the re-intro of the Laser Kit and etc. I would like
to see the MKIII refinements up close and in person - esp. the spring gear.
Later,
___(+^+)___
(_)
8 8
Subject: | Re: pre covering questions |
Ron,
To add fuel, I use a hose on the end of the filler spout and stand in
back on the right. I lift the tank up next to the carburator. All my
camping gear could be loaded without access to the back. I do have a
velcroed panel to access the chute (under the tank), and I use it to
stuff a small pillow next to the chute. The fuel sight opening can be
cut out later if you want as with an access door, so go ahead and cover
it per the plans (like mine).
John Jung
>Ron Carroll wrote:
> Bill & John, I am about ready to cover my cage and want to pick your brains
> one more time.
> I have heard from a couple of guys about how their cages are covered. Some
> include no covering on the rear half of the cage, and others completely
> cover the cage. An obvious question is, if the cage is fully covered, what
> is the best way to put fuel in the tank? Also, from what you have told me,
> John, you manage to get a lot of camping gear somewhere in the rear. How do
> you manage to access the area? Zippered or Velcroed doors/panels? If so,
> where did you place them, and what are they made of?
> Also, the old question of seeing the fuel level. I think John said he just
> turns his head, but can you see the whole tank with the front of the rear
> cage covered? I am reluctant to put holes in the tank and the cage cover
> for a clear tube sight gauge, but other than an electronic gauge I may have
> no other option. Or do I?
> You guys will be happier than I when this is finally completed, so that I
> can leave you alone.
> Thanks for any help you can offer,
> Ron Carroll
> Original Firestar
47,49,51-55,57,59,61,63-64,66-80
Cliff,
I believe it was "Stick and Rudder" that stated the throttle is altitude
control and the stick is the speed control. It took awhile for me to
accept this, but if all pilots believed it maybe there would be fewer
accidents.
My 2-cycle has been very reliable (knock on wood). The rule: "always stay
within gliding distance of a suitable landing field" has been violated
just yesterday when I flew about 5 miles over the open waters of Lake
Minnetonka. Man, do I have confidence in that little 377! Is it my
imagination, or are 2-cycles getting more reliable? I haven't heard
about a Rotax engine failure in months. Maybe it's the new oils?
Cliff, you are a wise man keeping altitude on your approaches.
Ralph Burlingame
Original FireStar
writes:
>Ralph and all,
>250 since the '70's. Thank goodness I have about 60 hours of recent
time.
>I have to keep telling myself... the first thing you do when you hear
>silence is to push the stick FORWARD... then evaluate the situation.
The
>elevator is mis-named isn't it? Didn't "Stick and Rudder" call it the
speed
>control and the throttle the altitude control? ...or am I remembering
some
>other instructional flying book or just dreaming.
>not that reliable... especially meaning when they quit, they quit, with
>little or no warning. You know the old addage ...it is not if but
when... I
>I always try to approach with about 3K rpm (does that equivicate to an
>engine out in your opinion?) vs. a stopped prop so that if I loose it I
will
>be able to make the field. I always make my approach a bit high for the
>same reason... and for that reason I sometimes have to pop a little
flaps
>on approach to kill the extra altitude them dump them before short final
>and flare. I doubt if I will ever intentionally shut it down. Silence
is
>NOT "golden" to me. I like the ERRRRRRR! ...so comforting for chicken
>little...
>because I come in fast (ideally 10+ mph over stall) and usually decide
at the
>last minute whether to wheel land or transition into a 3-point. I would
>like in time to become more proficient and use the flaps and land as you
have
video
>You screw it up just once and you might bend your gear at the very
least.
>I didn't put a "butt sled" (sheet of aluminum under the seat for
>protection) in my plane either. "Humor" attempt there...
>Later,
> ___(+^+)___
> (_)
> 8 8
writes:
>Rod,
>there. Rumor has it that the State of MN was going to buy it and
>convert it into an ultralight/lightplane strip.
Good for little HHH! (Just beware of politicians bearing gifts!) :-)
I rely (once again) on faulty memory but it was my understanding that the
manager of any 'uncontrolled' airport, regardless of whether it had ever
received federal funds or not, had the authority to forbid any activity
he deems "unsafe" to general aviation at his airport. This includes;
glider operations; sky-divers; and even balloon launches. Ask any of
these other groups how much freedom they have to operate from the airport
of their choice.
FAR Part 103 refers to ultralights simply as 'vehicles' (not aircraft).
This implies you have about as much right to operate from their property
as a 10 year-old with a go-cart. But then, how much do you pay in
registration and fuel fees?
I flipped through the FAR's and can't find the chapter and verse (so
maybe it don't exist) but that's what I was taught. Even so, we don't
have much trouble here in Okie-land anyway. Most of the small airports
are unmanned and others barely stay open selling fuel. The operators seem
glad to have ANYTHING drop in (so to speak) from time to time even if
you only buy a soda and shoot the bull for a while.
-Mick Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
(InterMail v03.02.03 118 118 102) with SMTP
From: | "Geoff Thistlethwaite" <geoffthis(at)worldnet.att.net> |
After following this thread and seeing what problems others have had I can't
believe how lucky we got it here in St. Landry Parish. When UL's first
showed up there was some skepticism especially from the FBO, but after a few
months and he took a look at how much fuel he was selling skepticism turned
to enthusiasm.
Now one of the UL pilots is on the airport commission, and we have our own
area at he airport.
Now if I could just get them to let us put in a couple of grass runways(that
concrete just eats tires).
-----Original Message-----
Date: Tuesday, May 26, 1998 11:32 PM
Subject: Kolb-List: Re: ultralight/lightplane and airports
>writes:
>>Rod,
>of their choice.
>-Mick Fine
>Tulsa, Oklahoma
>Get completely free e-mail from Juno at http://www.juno.com
>Or call Juno at (800) 654-JUNO [654-5866]
From: | "rutledge fuller" <rut007(at)hotmail.com> |
I live in Tallahassee, Florida. We have a local airport that does NOT
allow ultralights PERIOD. I know the FBO very well. As a matter of
fact I completed 60.5 hours of private pilot training out of this
airport in the Piper Tramahawk. The airport currently has little life
to it. I don't see how they can survive. It would sure be convient for
me to hanger my aircraft here. Heck, I would be spending money
purchasing fuel etc. Many of the local pilots would also like to breath
some life into this uncontroled airport as well. But..... We now have
to make the drive to Quincy, Florida to their uncontroled airport. This
place is alive with everything. It is a growing and prospering
business. We have gliders, ultralights (Three Kolbs, soon four), and
parachuting, etc. One big happy family. It is sad to see airports
become abandoned due to poor management. This is what I see anyway.
Opportunity abounds in many uncontroled airports, to bad they have
blinders on.
(Netscape Mail Server v2.01) with SMTP id AAA144
Hello again Kolbers... As I recall, not too long ago, the topic of
trim tab placement was discussed. I find there is a need for elevator
trim on my Firestar. Also I recall there was someone with Pictures of
the tab and placement, etc. Can we go over this again and I will pay
more attention this time. Incidently, I have been flying mine a great
deal and feel quite comfortable in the new bird. Thanks
Larry in Sussex N.J. Original Firestar 377 Powered
Hello again
Kolbers... As I
recall, not too long ago, the topic of trim tab placement was
discussed. I
find there is a need for elevator trim on my Firestar. Also I
recall there
was someone with Pictures of the tab and placement, etc. Can we go
over
this again and I will pay more attention this time. Incidently, I
have
been flying mine a great deal and feel quite comfortable in the new
bird.
Firestar 377
Powered
----Original Message Follows----
Date: Wed, 27 May 1998 10:50:12 -0500
From: Cliff and Carolyn Stripling <striplic(at)nationwide.net>
Rut,
You say you know him well. Apparently, you mean by that that you think
he
is very stubborn in his ways and not likely to be interested in making
any
changes. If that is not the case, you might approach him with some of
your
ideas. You never know - nothing ventured, nothing gained.
Good luck,
Cliff & Carolyn,
No, actually he is not completely opposed to the idea. He has much to
gain. The owner and the FBO are two different people. The owner lives
in New York and is an attorney who I hear is unapproachable. I am going
to continue to push the issue some with the locals. I hate to see an
airport go to waste. This airport currently has only two operable
aircraft based at the field. (That I am aware of)
I have visions of developing flight schools, ultralight instruction,
maybe even an ultralight dealership. Big Dreamer....
The only reason ever given, was the VOR near the field offers an
instrument approach down to 700 ft. When I was flying solo in the
PA-28, I frequently came into contact with GA idiots w/o radios who
wouldn't even acknowledge other traffic in the pattern. These folks are
more of a danger than the ultralight pilots that I know. Oh Well.
I feel that is our duty as pilots to continue to develop future pilots
by creating interest in aviation. If pilot certification and interest
diminishes, our sport (way of life) might be compromised by the
Bureaucrats. What would happen if we didn't have organizations like the
USUA, AOPA, ect. to look out for our interest? The only reason that
they exist is because of us. If we fail to exist, then we loose our
voice to government. The world would be left with commercial pilots.
I hope that this makes sense. Maybe I am making a mountain out of a
mole hill.
This is true. However, the law also states that final authority is
held by the FAA as determined by the local FAA District Office. Anybody
who doesn't agree with the local airport manager has the right to ask
the FAA to come in to review the situation, and the local management
-- whether public or private -- must abide by the FAAs ruling. Typically,
bringing in the FAA results in ULers and management working something
out with the FAA acting as referree. Airport Management has no choice
in FAA involvement if they have *ever* had their fingers in the Federal
money cookie jar. Good law IMO. Now if everybody could just agree on
what an UL really is; I mean in practice, not just what's in FAR103.
-Ben Ransom
> of their choice.
Around here most of us UL and Xperimental types fly out of a small
uncontrolled county airport. Several years ago we had an "undersirable" move
on the field who stirred up a couple of spam-can drivers who never liked UL's
anyway. Messed up our nice little airport! All caused by one UL guy that
nobody would want and a couple of GA guys that would bitch about anything. The
" real airplane" guys went to the "red-neck want-a- be -politicans" (my
opinion) on the city council who decided that they would regulate the airspace
around the airport. The FAA got word of this and informed the city (from what
I understand) that the airspace was their jurisdiction and that the city would
be liable for anything that happened if they stuck their noses in it. WHOA!!
JUMP BACK!! The mayor said to forget it, she didn't want to hear another word
about the airport! Since then all the ass-holes have either left or shut up,
the city has built 3 rows of brand new enclosed hangars, and let us put in a
grass UL strip in addition to the grass runway and paved runway that we
already have. In short, everything is back to it's original "let's go to the
airport and have a good time" status.
UL's, Xperimentals, and GA's can co-exist at uncontrolled airports but you've
got to have respect for the FARs and each others right to fly SAFELY. Let me
rephrase that: flying is not a right, it's a privilege. You don't have the
right unless you do it safely and with respect for others.
Enough of that: let's go fly!
Bill Griffin
Original FS/ Corbin Baby Ace
From: | "william f. davis" <custom_search(at)compuserve.com> |
Subject: | Engine Overhaulers |
Hello All--
Anyone have any ROTAX independent engine overhaulers they can recommend
that are not connected with ROTAX? I am tyring to gather some independen=
t
information regarding the 912 and 582 engines. Thanks.
Bill Davis
Mark III builder
McKeesport, Pa (near Pittsburgh)
From: | "CHRISTOPHER DAVIS" <cdavis2(at)capecod.net> |
Lauren and all ,I don't know what KOLB is offering for a trim tab ,but I
installed one from Rans on my KXP and it works smooth as silk , I cut it
down a bit to about 14inches and its infinitely adjustable it operates
with a wheel and I can fly hands off at any power setting. I think I
paid about 115 dollars for a very complete easy to install kit. I hope
this isn't sacrilege! CHRIS
To: KOLB
Date: Wednesday, May 27, 1998 10:03 AM
Subject: Trim Tab
of trim tab placement was discussed. I find there is a need for
elevator trim on my Firestar. Also I recall there was someone with
Pictures of the tab and placement, etc. Can we go over this again and I
will pay more attention this time. Incidently, I have been flying mine
a great deal and feel quite comfortable in the new bird. Thanks
HTML//EN">
for a trim
tab ,but I installed one from Rans on my KXP and it works smooth as silk
, I cut
it down a bit to about 14inches and its infinitely adjustable it
operates
paid about
115 dollars for a very complete easy to install kit. I hope this isn't
sacrilege! CHRIS
Hello again
Kolbers... As
I recall, not too long ago, the topic of trim tab placement was
discussed. I find there is a need for elevator trim on my
Firestar. Also I recall there was someone with Pictures of the
tab and
placement, etc. Can we go over this again and I will pay more
great deal
Original Firestar
377 Powered
release (PO205-101c) ID# 605-45218U5000L500S0) with SMTP
From: | "Vince Nicely" <vincenicely(at)intermediatn.net> |
I have a Kolb Firestar II. A couple of years ago, I added a cockpit
adjustable elevator trim system which I have used for the last ~125
hours. Essentially, I hand made a trim lever to have a push-pull action
on two cables. The cables run through two flexible guides which fasten
to the cross piece between the landing gear. The cables attach to
springs which in term attach to the cable ends. This works very well
and gives me ability to trim at any speed between about 40 and 80. This
may be more elaborate than the fixed trim you were asking about, but
thought I would mention for your consideration. Can tell you more if
you are interested and have questions.
Vince
To: KOLB
Date: Wednesday, May 27, 1998 2:05 PM
Subject: Trim Tab
HTML//EN">
couple of
years ago, I added a cockpit adjustable elevator trim system which I
have used
for the last ~125 hours. Essentially, I hand made a trim lever to
have a
push-pull action on two cables. The cables run through two
flexible guides
which fasten to the cross piece between the landing gear. The
cables
attach to springs which in term attach to the cable ends.
This works
very well and gives me ability to trim at any speed between about 40 and
80. This may be more elaborate than the fixed trim you were asking
about,
but thought I would mention for your consideration. Can tell you
more if
Vince
Hello again
Kolbers... As
tab and
great deal
Original Firestar
377 Powered
Subject: | 503 for old-yeller |
Dennis,
For the sake of completeness, I guess I should ask if you're interested in
taking my 503 in trade for the yellow FS. I understand that you would only be
offering used-wholesale price for it, but that still might work out to be a
desirable trade for me. I really hate advertising and selling stuff. No
problem if your not interested.
BTW- I thought about it some more, and I do want the 618. It'll go a long way
toward flying enjoyment for the next couple years. Just say the word when it's
ready.
Rusty
> I hope this isn't sacrilege! CHRIS
It's only sacrilege if you fail to post a picture of it. What did you say the
URL was :-)
I've been thinking about a better trim system as well. I used a spring with
different holes to adjust the tension, but I can't do it in flight. I'd be
interested to see your setup.
Rusty (maybe not the slowest SS in the world for long) Duffy
writes:
>....I feel that is our duty as pilots to continue to develop future
pilots
>the USUA, AOPA, ect. to look out for our interest? The only reason that
>mole hill.
Makes GOOD sense to me. It's encouraging to read stuff like this. Sounds
kinda like what someone I know might have said a few years ago, before he
got old and lazy.
On a sadder note, my wife pointed out a piece in the paper this morning.
Seems that another nearby airport is biting the dust. Hatbox field in
Muskogee, Oklahoma (yes, the town Mighty Merle made famous) is going to
be closed and converted to a 'sports complex' (softball and soccer
fields).
For years, Hatbox was home to a very popular annual fly-in. It was always
a well attended event and was where I first laid eyes on a real Kolb in
1988 or 89. The last fly-in was about 5 years ago, the FBO shut down a
couple years back and the field has been used to store aircraft
confiscated by the feds (read - DEA) since then.
Our club is having a 'fly-out' to Hatbox this saturday. There's a nice
restaurant called Jasper's within a mile or so and we'll go there for
lunch. We did the same about a year ago and had a big turnout and a good
time. This was planned months ago but now it looks like it will probably
be the last.
-Mick Fine
Tulsa, Oklahoma
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Hi Gang: Just hadda get my 2 cents worth in on insurance. "Vamoose"
isn't airborne yet, and 'tho I talked to my agent about flight insurance.,
I don't remember details. However, something I didn't realize was
available is builders' insurance. Since mine will be N-numbered, I'm not
sure if this will apply to ultralights, but it would be worth a call. I
have a policy thru Avemco ( Mike Sauder - 1-800-638-8440 ) that is for the
construction phase only. Covered value, which must be document-able, is
$25,000.00. No deductible for loss due to fire, lightning, explosion,
vandalism and total loss. P.D. is a token $200.00. This policy also pays
up to $15.00 per documented hour of labor to assemble or reconstruct your
insured aircraft. Since builders claims of time spent could vary wildly,
Mike says they would probably go with the manufacturers estimate of time
required to reach your stage of construction. Premium is $ 280.00 per
year. Since I rent Cessnas from 2 local schools, I took the advice
of Flying Mag. and bought a renters' policy to fill in the gaps in the
rent-ors policy, and to CMA. Don't have it handy right now, but I believe
the premium is around $185.00 a year. Food for thought. Big
Lar.
From: | Scott Bentley <Scott.Bentley(at)Bentley.Com> |
Subject: | Virtual Visit to Kolb Factory... |
> I flew into the Kolb factory yesterday morning and took some pictures...
> http://scott.bentley.com/aerial52798/pic00008.jpg is the factory with my
> Mark III (N628SB) in the foreground.
> http://scott.bentley.com/aerial52798/pic00009.jpg is the outside of their
> hangar.
> http://scott.bentley.com/aerial52798/pic00010.jpg is a sorta blurry
> picture of the shipping area (is your Rotax there?)
> http://scott.bentley.com/aerial52798/pic00011.jpg is Bill Martin, Mike
> Horvath, and Dennis surrounding the Laser jig.
> http://scott.bentley.com/aerial52798/pic00012.jpg are some of the metal
> fabrication machines.
> http://scott.bentley.com/aerial52798/pic00013.jpg is Jake cutting tubing.
> http://scott.bentley.com/aerial52798/pic00014.jpg is the carefully
> inventoried cages awaiting sale.
> http://scott.bentley.com/aerial52798/pic00015.jpg is Bill Martin's
> "Welders hand" holding some high-tech laser-cut wheel parts.
> http://scott.bentley.com/aerial52798/pic00016.jpg is Bill, Mike, and
> Dennis discussing engineering decisions for the Laser. The factory Mark
> III is in the background.
> http://scott.bentley.com/aerial52798/pic00017.jpg is another angle on the
> Laser.
> http://scott.bentley.com/aerial52798/pic00018.jpg is the factory Firestar
> Unfortunately, we didn't think to take any aerial pictures of the complex
> and airstrip, which is where Homer Kolb still lives and is very pretty.
> I'll post them after the next trip...
via SMTP by pop-proxy03.primenet.com, id smtpd007277; Thu May 28 08:47:09 1998
I am just about to cover my wings on my mark-3. Someone posted an idea
about puting handles inside the wing tips to help in folding. what is
the exact placement of these handles and any pic,s. I also have a
question?.My subscription to U/L mag ran out last year and diden't here
that Jim Lee of Lakeland U/L died. I am sorry to here about this, I had
talked to jim on the phone and ordered a duel throdel set up from him
for my mark-3. what happened? Thanks Steve Ward
To All (intentionally this time)
Oops! I guess the top secret engine security has been breached. It's true, I'm
looking into getting a 618 for the SlingShot. I had planned to wait until the
deal was complete before I mentioned it, but I seem to have made a boo boo and
sent the previous message to the list rather than to Dennis privately.
Rusty (stop me before I e-mail again) Duffy
Subject: | Re: Engine Overhaulers |
I had a 582 crankshaft completely rebuild for an excellent price by
Airscrew Performance in Arizona that I recommend and they seem rather
independent from any Rotax affiliation.The repaired crank has 125 hrs on it
since and still running smooth.
Tel ( 602) 931-6667. They also advertise in the Ultralight Flying Magazine
from USUA.
Frank Reynen MarkIII@430 hrs
http://www.webcom.com/reynen
Hello All--
that are not connected with ROTAX? I am tyring to gather some independent
Bill Davis
Mark III builder
From: | Jhann Gestur Jhannsson <johann.g(at)centrum.is> |
Hi all Kolbers.
I have a problem up here in Iceland. Need you help. I have about 10 hrs.
on my Firestar II and no hard landings or rouch landing spots, a
bearingin the landing gear broke and caused the wheel to brake.
This was the inner bearing, so the bolt for the axle broke and the axle
twisted a few turns inside the gear leg attachment, and totally ruined
the brake cable.
This was something I did not expect after only 10 hrs. of flying and a
few landings.
I noticed a few days ago on the list that Ben Ransom and Wood, were
writing about replacing the wheel bearings. Was there something wrong
with the ones supplied by Kolb?
I have looked everywhere in Iceland for these type of bearings to fix my
problem but they do not have anything except in metric sizes.
Can anyone assist me in finding a good bearing, and also help me to
prevent this from happening again, with some different setup.
According to the plans, there should be no spacer inside the wheel rim,
between the two bearings, but to avoid this from happening again, this
could be a solution??? Any comments from Dennis Souder would be greatly
accepted.
Best regards from Iceland, where the weather is finally getting too
good,to be waiting for parts.
Jhann G.
Subject: | Completions reminder |
I sent my letter to Kitplanes yesterday, with photo and description of Kolb.
Remember, June 10 deadline. Here is a copy of the offer from Dennis:
Kitplanes Completions:
Just a note from KITPLANES magazine. They are looking for aircraft to list in
their September completion issue. Last year they had 100 or more airplanes
listed. They are looking for brief letters and color photos from builders.
They say that this has become one of their more favorite columns. In addition
to seeing your pride and joy published in Kitplanes, you have a chance at
winning a Bendix-King KLX-1000 GPScom (about $1,400 worth), the lucky winner
will be selected from those who submitted a completion report during the year.
Also Kolb will toss in a pair of hats, a pair of T-shirts and our newest video
for each published completion. Also, be prepared for some telephone calls of
those curious about your craft, and there may be some offers to purchase as
well! (You can request them to not list your phone or address.)
Time is short. Your completion report must be in by June 10, 1998.
Completions may be typed or hand written, but not emailed - Kitplanes not set
up to handle that yet. Air to air photos are not required or encouraged.
Send to:
KITPLANE Completions
8745 Aero Drive, Ste. 105
San Diego, CA 92123
GET THAT ROLL OF FILM DEVELOPED AND PUT YOUR BEST PRINT IN THE MAIL TODAY!
jim
Steve,
I added handles to my wings using 5/16" tubing and bending it like this:
__ __
I used two 1/2" rivets at each end to rivet into the bowtip of the wing.
The handles are located about halfway down the chord. I polished them
before riveting them in. They are very handy when folding the wings.
Ralph Burlingame
Original FireStar
> Thanks Steve Ward-
I don't have any pics but what I did is I kept the rear spat tube open on
the end.When the wing is folded I put a piece of 1" tube in these holes and
lift and walk away.Now when I helpeed a friend build his MK111 we made a
simple slide mechanism where the 1" tube slides into a pvc tube permanently
mounted in the rear spar. When required this tube can be slid out for moving
and slid back in for flying so if you are ever caught in the middle of a
corn feild and have to walk out the handles are in the wing not back at the
hanger.
Woody
Subject: | Re: Covering orig FS fuselage |
Hi Ron,
Sorry for the delay in answering your question. Been busy moving my plane
from one airport to another. I covered my Orig FS as per Kolbs instructions.
The cage is completely covered except for the top and a small triangular
opening at the lower rear were the boom tube enters. Also, I modified the
bulkhead behind the seat slightly by bringing the fabric down and around the
gear leg structure, leaving an upside down V opening there. This was someone
elses idea, but a good one, because if you drop the fuel tank cap into the
bottom, you can simply reach behind the seat to retreive it. Well, maybe not
that simple, but it is a lot easier than trying to reach down from the top,
because the only way to do that is to fold, or remove, a wing. Even then it
is a long reach to the bottom.
I put fuel in the same way as John Jung explained, that is, I attach a piece
of plastic hose about 24" long to my fuel can spout which easily reaches the
tank from the right rear, next to the carb. I'm using a 2 gal can so I don't
have to hold too much weight up over my head.
I have no method of checking the fuel level in flight, so I very carefully
monitor my fuel burn rate. (I'm sure you recall the scuttle about my Dial-A-
Jet and 1.6 GPH at 4500 RPM.) With the 5 gal. tank, that gives me about 3
hours endurance. Recently I went on a 142 mile round trip cross country
flight. Because this was a fly-in breakfast and I didn't want to take all day
to get there, I cruised at a higher setting of 5200 RPM and my burn rate went
up to 2.44 GPH. It took me 1.5 hr to get there (71 mi) and before returning I
installed 3,5 gals. of fuel. I've often wondered if one of those capacitance
fuel monitors would be reliable and acurate, but have no experience with them.
I built a baggage support board behind the seat where I can carry two, 2 gal,
cans of extra fuel. I also have a duffle bag that lays on top of the two cans
which contains the refuling hose, some tools, a soda and jacket, etc. I only
carry these items when I think I'll need them, not on every flight. Many
times I'll only carry one can of fuel. It all depends on how far I intend to
go AND what the winds are forcasted, because a head wind can create havoc with
your progress over the ground.
Once the cage is covered, it is impossible to remove the fuel tank. I have
often wondered if it would be possible to take that 45 degree angled cross
tube on the bulkhead behind the seat and someway make it removable. Then
maybe the fuel tank could be removed thru that space. Kolb says the tank can
be inverted to replace the grommet and I have done it a couple of times, but
it's sort of like a puzzle and only works a certain way.
Ron, I'm getting a little long winded here but hope this will help you decide
how you want to cover it. And please feel free to bother me with more
questions.
Bill Varnes
Original FireStar
377
From: | "Ron Christensen" <spectruminternational(at)email.msn.com> |
Subject: | Re: legal Forces |
Hi All:
Just today, I received the following quotation for my never-before-flown
MKIII 1/2:
* Liability $500,000 each
occurrence
* Bodily injury/property damage $100,000 each passenger
* Medical payments $5,000 each passenger
* A/C physical damage (hull) $30,000 including "in motion"
* Hull deductible $100 not in motion
$500 in
motion
Annual Premium: $1,798.00 ! ! What do you think of this ? ?
Ron Christensen
MKIII 1/2
N313DR
Chino, CA airport
Date: Monday, May 25, 1998 1:49 PM
Subject: Kolb-List: Re: legal Forces
>Hi Gang -
>Kolb wanna-be
>Bob Cooper
>Newfield, NJ
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
Sell it!
From: Ron Christensen <spectruminternational(at)email.msn.com>
Date: Thursday May 28 1998 9:50 PM
>Hi All:
>MKIII 1/2:
>occurrence
> $500 in
>motion
>Ron Christensen
>MKIII 1/2
>N313DR
>Chino, CA airport
>From: robert w. cooper <pl4coop(at)juno.com>
>Cc: kolb(at)intrig.com
>Subject: Re: legal Forces
>>Hi Gang -
>>Kolb wanna-be
>>Bob Cooper
>>Newfield, NJ
Subject: | Re: Wheel Bearings |
>Hi all Kolbers.
Johann,
Sorry about your bearing trouble. When I bought my KXP back in 93 I
ordered it without wheels cuz I wanted to fret about which size, etc.
I eventually ended up buying wheels elsewhere, to no advantage.
In any case, as I recently posted, just get sealed bearings (sometimes
called 'precision' ) instead of stamped bearings. Order based on OD,
ID, and width. For simplicity you could check w/ Kolb. Originally
I had stamped bearings and altho they are bad, they lasted at least 50+
hours, not something like 10. Don't know if that means you have some
other problem such as alignment or grit/rust in there that caused early
failure. Hope metric vs English doesn't keep you grounded too long.
Good luck.
-Ben Ransom
Hi Dennis:
Is the Kolb Aircraft logo - like the one on a Kolb hat/cap available as a
patch? I would really like to have a few "Kolb Aircraft" patches to apply
to a jacket or shirt or whatever. I suspect that some of the other Kolb
flyers would also be interested in purchasing patches. If you made the
patch a bit "tall", then those who have N-numbered airplanes could also have
their N-number applied to the patch. Please advise - and thank you.
Ron Christensen
MKIII 1/2
N313DR
So. Calif.
Subject: | Re: Experimental |
Rod and all,
>I am considering buying a Firestar in the near future and would not mind
>having it certified so that I can land and fly anywhere. Will I still get
>kicked off a field? Any good stories?
Interesting subject. Anyone out there, correct me if I am wrong in any
details... The "experimental" operating limitations say one should not fly
over densely populated areas or in congested airways. I think the intent of
this is obvious - stay out of "B" airspace (unless you have the proper
equipment) - keep to the suburbs and countryside. You are bound to follow
all pertinent rules but otherwise can enjoy the system of ATC as any other
plane and you must identify yourself as "experimental" to any air traffic
control tower. >>
We have an airport close by that has a real bad attitude toward ultralights.
Yes they have received tons of federal money to improve the facilities. One
time Dan landed there and they rushed out in a truck and pulled across in
front of him on the taxi way to keep him from going any further. I forget
whether they were armed or not :-)
And this was with our N-numbered Mark-III. We stay clear of them for the most
part, but do a touch and go occasionally, just to irritate them.
Dennis
I too have done several 5' agl fly-by's at the other anti-ul airport near
me. I agree, it is nice to get that momentary feeling of "So There!!".
The odd thing is, just being in the pattern constitutes a problem
(according to them) with regard to speed differences, but as far as
I can tell, it is completely legal. At least it is at this airport
(Class D). A real awnry cuss ULer in a barely flying Pterodactyl raised
hell there 11 years ago. With this nut representing ULs it wasn't too
hard for the FAA to side with the county and agree that ULs presented a
safety problem. At this place the airport manager would call the county
sheriff if a UL landed, and he had the FAA document that could put you
in jail. Too bad, the place is pretty sleepy and the county wishes
it was a money maker instead of a money drain.
-Ben 'i wanna move to the sticks' Ransom
Subject: | Experimentals, ULs, airports |
I can understand why airport managers would not want any non-insured aircraft
or vehicle using their facility. People are sue-happy and willing to blame
everybody else for their own mistakes (not all people, but society in general
today). This is more of the same problem General Aviation is having: Liability
limitations, or lack of them. Airport managers are scared, I've seen it and
I can't say I blame them. Until people realize that somebody actually pays
the bills for their million-dollar settlements, things will continue to worsen.
If an aircraft or vehicle has been registered, it generally means it is being
operated by a licensed pilot. Also, apparently depending on State law, it is
required to have liability insurance. It is tough to get liability insurance
without a pilot's certificate, I beleive. At that point, the a/c should have
access to any and all public airports providing it has the proper equipment
for safety reasons. Lack of ability to maintain a certain speed should not
be a reason for safety concern. Mixing with "heavy" traffic is, although
while training in a Beech I routinely flew with 727s and C5s in training.
I guess if I could paint my Kolb to look 30 years old, it wouldn't make
other people as nervous.
The catch to registering is that once registered the A/C must be maintained
by the A&P or Repairman's Certificate holder. And State tax is payable, and
yearly registration is required and the insurance requirement...
So it is a big leap just to be able to fly into an airport, choose carefully.
Did we ever get the name of the insurance co. that Bob Cooper has the nice
low rates with? I would like to compare too! Thanks!
jim
most
Before I started on the SS, I considered a FireFly very seriously. As part of
my decision, I went to all the small airports around and asked if UL's were
welcome. The answers ranged from "Absolutely not", to "there's no rule against
them, but we don't like it". Since everyone thinks the SS is an UL, I also have
plans to irritate a few places quite legally. The most unfortunate victim is
going to be a paved airport in Milton FL. I'm on the waiting list for a city
owned hanger there. The FBO owner will NOT be pleased :-)
Rusty
via smtpd (for www.intrig.com [206.54.183.49]) with SMTP; 29 May 1998 20:17:21 UT
(Netscape Messaging Server 3.0) with SMTP id AAA21202;
If Kolb doesn't have them there is a outfit that attends S&F each year
and sets up in the UL area. They specialize in patches and would
probably do they for a fair price.
Actually I thought you should get a Kolb hat when you buy a kit or
make your first flight. Haven't got mine yet, hint, hint.
______________________________ Reply Separator _________________________________
Subject: Kolb-List: Kolb Logo
Date: 5/29/98 11:40 AM
Hi Dennis:
Ron Christensen
MKIII 1/2
N313DR
So. Calif.
Unfortunately, it is actions like these that have earned the ultralight
community the reputation that it has. It will strengthen the GA pilots
already poor opinions of us as a group. We need to nurture, not discourage,
a healthy relationship with those who share our skies.
Besides, ANYTHING other than take-off and landing maneuvers while inside an
airport traffic area is against the FARs and should be avoided. I strongly
oppose the infamous "high speed pass" operations, especially while I, or
any other small aircraft which has a small profile (therefore difficult to
see), is in or near the pattern. I've already had a close call, and try to
discourage foolhardy antics in or around the pattern.
For what it's worth,
Ron Carroll
Original Firestar
Date: Friday May 29 1998 1:13 PM
Subject: Kolb-List: Re: Experimental
the
>most
of
against
have
is
city
>Rusty
Subject: Re: Trim Tab
Hi Vince..Sure I would like to hear more about the trim Tab and
control. Sounds pretty good to me. Thanks Vince for the interest.
First, I will describe the mechanical details of my cockpit adjustable
elevator trim control. Because that was only a small part of the project
of trimming on my Firestar II, I will provide some additional detail
below just in case you are interested.
My Firestar Elevator Trim System
I will provide a word picture. Perhaps it will work best if you sketch
the parts as I describe them. Of course, the word picture may be so
muddled you can't do that. If it seems a little confused, just ask and I
will try improve it. I just went out an looked at what I did and
hopefully this describes what I found so you can understand it.
PARTS LIST (More detail below)
1 Flanged Base Plate for Mounting the Control Handle - 0.035" 4130 Steel
or equivalent
1 Pair control cables about 4-1/2 feet each (from 1 10ft Bowden Cable -
Aircraft Spruce PN 05-15500, p143 in Catalog)
1 1/4" bolt + elastic self locking nut (I used ordinary hardware)
2 3/16" bolts+ elastic self locking nuts (I used ordinary hardware)
2 5/16" bolts + elastic self locking nuts (I used ordinary hardware)
1 9"x1-1/2" piece of 0.065 Al sheet
2 1/2"x2"x0.035 sheet steel
1 1/2"x3"x0.035 sheet steel
2 Screen Door Closure Springs (Rudder springs would likely work, perhaps
better)
Soldier
1 small hose clamp
about 1/2 dozen large 1/4" washers
3 1/4"id x 1-1/4"od nylon washers
MORE DETAIL ON THE PARTS
Base Plate
The raw base plate is 7"x6". Cut out a 1/2" square at each corner. Bend
the 1/2" edge over to make a flange around the plate. Soldier or weld
the corners. Now you have a 5"x6" flat plate with a 1/2" flange around
it( for stiffness). Draw a line 1" from the short edge across the plate.
2-1/2" from the bottom (i.e., in the middle) drill a 1/4" hole. This is
the location to mount the control handle. Draw another line 1/2" from
the other edge and parallel to the first line. At both 1" above and
below the center of the plate and on the line, drill 3/16" holes. This
provides a place to fasten the ends of the two Bowden Cable housings
described below. Decide where you will mount the base plate in your
cockpit and provide suitable fixtures to enable mounting. Mine is
mounted through the bottom edge to the floor pan which is plywood in my
plane.
Control Handle
The 1-1/2" piece of Al sheet is drilled with a 1/4" hole centered and 2"
from one end. This hole is used to mount the handle on the plate. A
combination of metal and nylon washers are used to space the handle from
the plate and tension the handle's motion. Also on the center line, a
5/16" hole is drilled both 1-1/2" above and below the 1/4" hole. These
holes provide the location to attach the heart of the Bowder Cable which
is a 0.078" wire.
The Control Cable Housing
Cut two pieces of Bowden Cable Housing each about 4' long. At one end of
each, fold the 1/2" x 2" piece of steel sheet symmetrically about the
housing. Soldier one folded sheet to each housing. Now, one end of each
cable housing is fixed in this way. Drill a 3/16" hole in each folded
sheet. These holes provide for fasten the housing loosely to the base
plate. The other end of both housings are fastened together and about 1"
from each other to a single piece of 1/2"x3"x0.035" steel by folding one
end of the sheet around each housing and soldiering in place. This
provides for a means of fastening the joined end to a frame member under
the seat. Use a hose clamp to fasten the 1"x1/2" flat sheet between the
housings to the frame.
Control Cables (0.078" Steel Wire)
Each piece will be about 5' or less in length. One end of each is bent
and folded to make a safety pin like clasp. This is used to hold one end
of the spring. Thread the wire through the housing. Drill each 5/16"
bolt so that the wire will clear the handle when inserted through the
hole in the bolt with the bolt through the handle. Thus, when the nut is
tightened on the bolt, it clamps the wire in place; yet, the bolt is
free to pivot in the handle.
At this point, you can see that as the handle is pivoted about its
center, one wire tightens its spring and the other loosens the same
amount.
Finally, The Springs
The folded end of the cable is fastened to one or more sections of
spring (in parallel if multiple springs). The other end of the spring is
fastened to the elevator shackles or thimbles (your choice). I used 2
pieces of 4-1/2" spring on each of elevator up and down. They are
tensioned so that each is just totally relaxed at the end of travel of
the trim system.
Other Issues
At least one concern with spring trim systems is the potential to induce
flutter in the control surface. I have tested my system for both static
and dynamic response. There is no tendency to induce flutter at any
speed. Of course, you will need to do similar testing if you make a
system for your plane.
TRIMMING MY KOLB FIRESTAR II
My Firestar II flew fine the first time with light and responsive
control. I have never flown another Kolb airplane, so I do not know how
they handle. However, I began a systematic examination of control
response in mine. To make a long story short, the plane flew fairly
quickly into a left spiral when hands off the controls. Furthermore, it
responded to rudder inputs unconventionally compared to the GA aircraft
I had been flying. So, I decided upon some changes.
First, I added a little fixed trim tab to the rudder and trimmed out
yaw. I used a yaw string placed about 2 feet in front of the canopy
because I found the airflow over the canopy to be very sensitive and a
little tricky on string placement.
Next, I added a little fixed trim tab on one aileron. Then I trimmed out
the last tendency to roll.
Then, I added cockpit adjustable elevator trim to control the attitude.
Finally, I found the plane to have negative stability to spiral
behavior. That is, if I placed it in a bank, it tended to bank more
steeply, and quickly too. This tendency was observed for either left or
right bank. I wanted neutral or positive spiral stability. That is, I
wanted the plane to either hold its bank or gradually return to straight
flight. My conclusion was that a little more dihedral in the wings would
be just the ticket. Then came some calculations, a few measurements on
the GA aircraft at the local airport, some guessing, and finally
deciding how to build new struts that could be shortened systematically
to take out dihedral a little at a time without starting from scratch
each time. I decided to start my tests with 3 degrees of dihedral which
translates into, as I recall, raising each wing tip 9" from level. That
compares to 1", I believe, by the standard rigging. The struts needed to
be lengthened about 2-1/4". I built the struts, flew the plane and loved
it. The plane has very slightly positive spiral stability, i.e., it
debanks very slowly on its own. Now the rudder input gets a response
very similar to a Cessna 152 or 172. At that point I stopped
experimenting.
With these adjustments, the plane can be trimmed to speed between about
40 or 45 and about 75 or 80. It flies hands off just great with slight
rudder inputs to get heading changes. On a calm day, you can ride along
and it flies itself. After a friend told me some small planes can be
controlled by body movements, I tried it. On a calm day, I can initiate
and stop a bank by leaning sidewise and can initiate and stop slow
climbs and dives by leaning forward and backward. What fun! When I want
to have my hands on the controls, it is about like when I first flew it.
Vince Nicely
Firestar II (N8233G with 155 hours)
HTML//EN">
Subject: Re: Trim
Tab
Hi
Vince..Sure I
would like to hear more about the trim Tab and control. Sounds
pretty
good to me. Thanks Vince for the interest. Larry in
Sussex
N.J.
adjustable
of
trimming on my Firestar II, I will provide some additional detail below
just in
sketch the
parts as I describe them. Of course, the word picture may be so muddled
you
can't do that. If it seems a little confused, just ask and I will try
improve
it. I just went out an looked at what I did and hopefully this describes
what I
4130 Steel
or equivalent
Aircraft Spruce PN
05-15500,
p143 in Catalog)
hardware)
hardware)
hardware)
perhaps
better)
Soldier
1 small hose clamp
Base Plate
each
corner. Bend the 1/2" edge over to make a flange around the plate.
Soldier
or weld the corners. Now you have a 5"x6" flat plate with a
1/2"
flange around it( for stiffness). Draw a line 1" from the short
edge across
the plate. 2-1/2" from the bottom (i.e., in the middle) drill a
1/4"
hole. This is the location to mount the control handle. Draw another
line
1/2" from the other edge and parallel to the first line. At both
1"
above and below the center of the plate and on the line, drill
3/16" holes.
This provides a place to fasten the ends of the two Bowden Cable
housings
cockpit and
provide suitable fixtures to enable mounting. Mine is mounted through
the bottom
edge to the floor pan which is plywood in my plane.
Control Handle
centered
and 2" from one end. This hole is used to mount the handle on the
plate. A
the
5/16"
These holes
provide the location to attach the heart of the Bowder Cable which is a
0.078" wire.
of
about the
cable
sheet.
These holes provide for fasten the housing loosely to the base plate.
The other
end of both housings are fastened together and about 1" from each
other to
a single piece of 1/2"x3"x0.035" steel by folding one end
of the
sheet around each housing and soldiering in place. This provides for a
means of
fastening the joined end to a frame member under the seat. Use a hose
clamp to
fasten the 1"x1/2" flat sheet between the housings to the
frame.
bent and
folded to make a safety pin like clasp. This is used to hold one end of
the
spring. Thread the wire through the housing. Drill each 5/16" bolt
so that
the wire will clear the handle when inserted through the hole in the
bolt with
the bolt through the handle. Thus, when the nut is tightened on the
bolt, it
clamps the wire in place; yet, the bolt is free to pivot in the
handle.
center,
one wire tightens its spring and the other loosens the same amount.
spring (in
parallel if multiple springs). The other end of the spring is fastened
to the
elevator shackles or thimbles (your choice). I used 2 pieces of
4-1/2"
spring on each of elevator up and down. They are tensioned so that each
is just
totally relaxed at the end of travel of the trim system.
Other Issues
induce
and
dynamic response. There is no tendency to induce flutter at any speed.
Of
course, you will need to do similar testing if you make a system for
your
plane.
control. I
have never flown another Kolb airplane, so I do not know how they
handle.
However, I began a systematic examination of control response in mine.
To make a
long story short, the plane flew fairly quickly into a left spiral when
hands
off the controls. Furthermore, it responded to rudder inputs
unconventionally
compared to the GA aircraft I had been flying. So, I decided upon some
changes.
yaw. I
used a yaw string placed about 2 feet in front of the canopy because I
found the
airflow over the canopy to be very sensitive and a little tricky on
string
placement.
out the
attitude.
behavior.
That is, if I placed it in a bank, it tended to bank more steeply, and
quickly
too. This tendency was observed for either left or right bank. I wanted
neutral
or positive spiral stability. That is, I wanted the plane to either hold
its
bank or gradually return to straight flight. My conclusion was that a
little
more dihedral in the wings would be just the ticket. Then came some
calculations, a few measurements on the GA aircraft at the local
airport, some
guessing, and finally deciding how to build new struts that could be
shortened
systematically to take out dihedral a little at a time without starting
from
scratch each time. I decided to start my tests with 3 degrees of
dihedral which
That
needed to be
loved it.
The plane has very slightly positive spiral stability, i.e., it debanks
very
slowly on its own. Now the rudder input gets a response very similar to
a Cessna
152 or 172. At that point I stopped experimenting.
about 40 or
45 and about 75 or 80. It flies hands off just great with slight rudder
inputs
to get heading changes. On a calm day, you can ride along and it flies
itself.
After a friend told me some small planes can be controlled by body
movements, I
tried it. On a calm day, I can initiate and stop a bank by leaning
sidewise and
can initiate and stop slow climbs and dives by leaning forward and
backward.
What fun! When I want to have my hands on the controls, it is about like
when I
first flew it.
Vince Nicely
Ron and all,
It's possible that I gave you the impression I was planning to do something
improper to irritate these airports. I'll assure you that isn't the case. I'm
a licensed pilot, and my SlingShot is properly N-numbered as an experimental
aircraft. I installed and use a radio in the pattern at all times even though
it isn't required in most places.
I can't help it if the ignorant people at these FBO's think I'm an UL. Truth be
told, I defend the rights of UL pilots at these airports at every opportunity.
I think most GA pilots would welcome UL's in the pattern as long as they
understand and follow the rules of the pattern as you suggest. Unfortunately,
many GA pilots don't follow the rules so well either.
Rusty (not a UL pilot) Duffy
>Ron Carroll
>Original Firestar
Subject: | [Fwd: Experimental] |
Ron-
I agree with you 100%!
As a GA pilot as well as UL, I have been welcome at many airports where
UL types were generally unwelcome. I was told that much of the UL
traffic at these airports displayed antics or an unprofessional attitude
towards flying, use of traffic patterns etc. It is my opinion that it
is our duty to promote proper behavior, especially at airports where our
presence is undesirable. You can catch more flies with honey than you
can with vinegar.
RSM
Ron-
where UL types were generally unwelcome. I was told that much of the UL
it is our duty to promote proper behavior, especially at airports
where our presence is undesirable. You can catch more flies with honey
than you can with vinegar.
RSM
From: "Ron Carroll " <ron.carroll(at)worldnet.att.net>
Date: Fri, 29 May 1998 13:42:41 -0700
Ron Carroll
Original Firestar
the
>most
of
against
have
is
city
>Rusty
Hi gang
I guess my video idea would not be such popular idea judging from the
response.I will still put all the info on one tape and I will let Bill Davis
and Hangerman have a copy.I just won't spend the time trying to do a
professional editing job.
Woody
From: | Cliff and Carolyn Stripling <striplic(at)nationwide.net> |
To all,
There is enough responsibility for all of aviation. Everyone can site
examples. On the other hand, I have seen the mix of all (with the exception
of heavy commercial that fly in different space) work out fairly well around
here.
I only get a little scared when the warbirds buz the field. They always
feel they have to strafe something... just joking guys! I can picture one
of them running up my tail. I always monitor the airport frequency for
annoucements and look every which way I can. Thanks goodness they usually
make their passes a little higher than I do. One of the nicest things about
flying a UL or light plane is that you have plenty of time to watch out for
others and time to stay ahead of your plane... time to really relax and
enjoy not "too" slow and not "too" low.
The aerobats meet about once a month on Sunday... a good time to let them
have it. I was foolishly putzing around the pattern one of their meeting
days and they were taking turns in the aerobatic box with quite an audience
watching from below. Their airport patterns are not "typical". While I was
on my downwind leg two of them could spiral in for a landing... on base leg
another could land. One even cut me off (or so I thought at the time, but in
actuality he had plenty of time/room). I had him in my sights for a few
seconds though... It is a different perspective to see Pitts and Suka...
(the Russion one) and other really high performance planes from the air.
Trying to fly safe and stay out of the way,
Cliff & Carolyn Stripling Him: Retired Pharmacist
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
and Marble Falls Texas Both: 5th Wheel - RV - Travel
Kolb MKIII - N582CC (43.3 hrs)
____________________|_____________________
___(+^+)___
(_)
8 8
Subject: | Antena placement and what kind ?? |
I just bought a Icom A22 radio and would like to find out different ways
you mount antenna and what kind of antenna,s you use.I have a 1991
Firestar kxp.
RON
I think that is to high, you may want to get a quotation with less A/C
physical damage. Just a thought.
Rick
On Thu, 28 May 1998
writes:
>Hi All:
>never-before-flown
>MKIII 1/2:
>occurrence
>motion
>$500 in
>motion
>Ron Christensen
>MKIII 1/2
>N313DR
>Chino, CA airport
>>Hi Gang -
>>Here in the east, we recently had an airport owner take the position
>that
>>the ultralight could stay. However, all aircraft based at the field,
>had
>>to carry $500,000.00 liability insurance. Have you called an
>insurance
>>company requesting that much liability ?
>>I think you will find that the best amount you can find is
>$50,000.00.
>>However, with an N number the aircraft will be insured as a
>homebuilt.
>>My Pazmany PL-4A is insured at $500,000.00 an annual cost of $187.00.
> I
>>have added aircraft damage - non-flight at $144.00 - total $331.00. -
>>In any event the ultralights relocated to another friendlier
>airfield.
>>And guys - when you live in the land of no people - attitudes are
>better!
>>Kolb wanna-be
>>Bob Cooper
>>Newfield, NJ
Subject: | Re: Antena placement and what kind ?? |
Charles
I have a Icom A-21 on my M III I put the antenna on the nose cone
next to the skid hoop . I has done a very good job at that location .
good luck on your's
Rick Libersat
writes:
>ways
>1991
>Firestar kxp.
<< just bought a Icom A22 radio and would like to find out different ways you
mount antenna and what kind of antenna,s you use.I have a 1991 Firestar
kxp
I used a flexible fibreglass antenna from Advanced Aircraft Electronics and
taped it to the inside of the nose cone on my MK III. Worked very well and
was out of sight.
Pete Krotje
Subject: | Re: Mix of traffic |
>To all,
Snip
The close call that I mentioned in an earlier letter was with one of these
ex-military pilots who thinks they are still over some south sea island.
There were four of us ULs approaching the pattern at my home airport, and I
announced our position and intention on the radio. I heard the FBO tell
someone to "Be advised, there are ultralights in the pattern". There was no
response to the announcement.
We were at 500' AGL and I was the lead plane, and had just completed my
crosswind and turned downwind. The UL behind me had just crossed the
centerline, and the other two hadn't reached the centerline yet. All of a
sudden there was three T-34s blowing smoke about 100' blow us doing a show
off pass with smoke bellowing out. Just as they came to the end of the
runway (right between the 2nd & 3rd UL in our formation) they pulled up
sharply and did a 3-way smoke display. Had any of the ULs been over the
runway at the time we would have had a very nasty accident. They knew we
were there, but ignored it. They then proceeded to do an aerobatic maneuver
in the traffic pattern area, strictly against the FARs.
As you can guess, these antics are my pet peeve. They are dangerous to
anyone else in the immediate area, and it doesn't take much brain power to
fly past at 200+mph, trying to impress bystanders with their talents. Also,
as you said, radios are not required, either by us in ULs or any other GA
plane, i.e., antiques without electrical systems. We may be low on the
right-of-way list, but our lives are just as important as anyone else's.
I am also a GA pilot and once came up suddenly on an ultralight flying at
the GA pattern altitude over an uncontrolled airport. UL pilots, as well as
GA pilots must be aware that ULs have a VERY slight profile, making them
pretty hard to see by other traffic. We have all gone on a cross country
and lost sight of one of our buddy, in spite of the fact that we know he is
there somewhere. See and be seen, or don't fly where they are. GA doesn't
generally fly at 500', and that's where the fun is.
Enough said, I've worn myself (and you (and the subject)) out.
Ron Carroll
Original Firestar
Hi there Charles: I use an ICOM A-21 (the older model). Mounted a whip antenna
under the nose cone and it works just fine. You can get them from WAG Aero or
make your own. Put plenty of bend in it (45 degrees or more) so you don't
break it off when you lift the tail to move the plane backwards. The aluminum
floor plate makes a good ground plane. Or even simpler (and cheaper) just put
a BNC connector and use the rubber duckie antenna that came w/the radio.
That's what I did on my Corbin. Put it on top of the center section. I have a
friend who did the same thing with his A22. Stuck it on top of his Cub. They
fine and have plenty of range. Evidently you don't need a ground plane either.
The other day I was at an airport about 50 mi. away from home base with the
rubber duckie and was able to clearly receive xmissions from home airport.
Didn't try talking back though. By the way, when in the FS, I carry the rubber
duckie antenna anyway. That way if need be I can use the radio away from the
airplane.
Bill Griffin
>the most part, but do a touch and go occasionally, just to irritate them.
Someone replied:
Observation: Touch and go's are pretty normal at this airport and most
others. Nothing unusual, discourteous, unsafe, foolhardy, or illegal with a
touch and go.
I think the point was missed: Even normal by-the-book operations will not be
acceptable to those who have biases against ultralight type aircraft.
Back in days of yore, when the little Cubs and Taylorcrafts with their
little flat engines were coming on the scene, some of them were held in
similiar disrespect by the owners of the "real" macho aircraft with big
round engines.
There was a great Star Trek episode about prejudice, you trekies out there
will no doubt remember the men with half of their faces white on one side,
and the other half black - divided right down the center. Captain Kirk
couldn't understand the basis of their prejudice against one another - they
seemed identical. Then one pointed out that the others were black on the
left side of the face where he was black on the right side! Great stuff!
Prejudice will always exist - it always finds new and novel ways of raising
it's ugly head. Wait till the rocket propelled cowboy boots are introduced
- ultralights might not look so bad then; who knows ultralighters,
themselves, might even start looking down their noses at the rocketbooter crowd.
Dennis Souder
Pres Kolb Aircraft
Hi Guys -
One last question to ask the insurance company - when will insurance take
effect?
I'm an olde taildragger pilot. I called AVEMCO to insurance my Pazmany
PL-4A. We worked through the cost, and my options, then was advise
they could not insure until I had flown 5 hours on the aircraft.
Therefore, end of discussion. Since I could not purchase insurance until
I had accumulated 5 hours I just took a chance and when flying - finally
I called back after 10-15 hours and insured the aircraft. Good Luck!!
Bob Cooper
Newfield, NJ
From: | William Hinkelmann <whink(at)mindspring.com> |
Handles on the wingtips work great. Use the wingtip bow as the actual
handle the bent tube is on the inside of the bow.
Went to Marathon Key after S&F a couple of years ago. All gates were
locked, but "Socially Engeniered" my way on. Flew in the AM and PM. On my
way out I asked about UL's. Was told they were not allowed per the County.
I dont think they even saw me. Sometimes I dont even see Myself.
Went to Sugarloaf Key and asked permission - No!! UL's --
Don't ASK! -- Don't TELL
William Hinkelmann
Modified FS-II
North Atlanta, Ga.
Subject: | Re: Experimentals, ULs, airports |
Dear Kolbers,
There's always a way to fly, if you join forces. I'm a new member of EAA
Ultralight Chapter 103 (LAFA...Light Airplane Flyers Assoiation) here in
Miami, Florida. I'm 3/4 finished on the MK lll and the club has been very
helpfuf to me in the past 6 months of building.
The original club members are very orgainized. We have the FAA come to our
meetings, as a result all of us are on first name basis with all of them. As
an example my EAA tech is also the FAA guy who will come out and sign off my
plane....very neat.
We fly from a full services county airport that has given us our own field
and a small building (they maintain everything) and our own air space, and
pattern. I would suggest contacting the EAA for support and advice, relating
to your problem. Also I'm sure the guys at LAFA would be happy to give you
some advice.
Look us up at http://www.lafa.com
Good Luck,
Rich Bragassa
MK lll
lrb1476(at)aol.com
Miami, Fla
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
My experiance has been that the guys out there flying the expensive
twins are the ones who fly straight in approaches and land against the
wind sock all the time. And they fly so fast that you dont see them
till they are right there. I turned base to final the other day and
checked that the runway was clear. I then was concentrating on the
touchdown point and when I started to flair looked up to the far end of
the runway to see two big props churning away as a twin came at me on
landing rollout, against the windsock. I added power and went around
right over the top of him. he was never in the pattern. probably was
below 500 feet for the last couple of miles of his 100 knot approach.
He was counting on his radio, which I didnt have for that flight. If
you are N-numbered you can and should go into any non-class B airspace
you want and you should not take any shit from anybody. if you're an
ultralight you have as much right to land in any uncontrolled airfield
that recieves federal funds as a GA or experimental craft. so go ahead
and do it, but follow the FAR's exactly and be a better pilot then these
GA morons like I described. If they give you a hard time report them,
the rules are on your side.
How do you all feel about strobes? I think we should all have them.
Topher
Subject: | Airports and ULs |
Hello Gang:
A popular question for me is where do I land and where do I get gas when I
am XC'ing ULs. The answere is always the same, at airports. Way back in
the very early days I would land on highway right of ways, vacant lots,
parking lots, hay fields, etc., to buy auto gas and save money. Very
nearly busted my butt on one occassion. Convinced me that the money saved
was not worth the risk involved in landing off site.
I reckon I have landed in about as many different airports, both controled
and noncontrolled, as anybody else, in ULs (registered and not registered),
all over the US, Canada, and Alaska. I got some static in 1988, from a
line boy at Pottstown/Limerick AP, Penn, about my traffic pattern (I flew
left hand and they fly righthand). Seems it was my first trip to Penn and
I could not find Homer's airstrip. So I landed at P/L to use the phone to
get directions.
Tallahassee Comercial Airport, first long XC in my Ultrastar, 250 miles one
way. Got verbally attacked and threatened with arrest if I did not trailer
my UL off the premises. While gent was inside calling the sheriff, I was
on my t/o roll, headed for Quincy, Fl. This was Dec 84. Several years
later in a Firestar equipped with VHF radio, I was welcomed with open arms.
This is a private airport purchased and built by a couple right after
WWII, 1945. They receive no federal funding. The lady runs the UNICOM
like a control tower. Or did until she became ill some years ago. You got
the info you needed when you called in to land or t/o.
Quesnel, BC, was questioned as to UL status after I landed and was cleared
by FSS as Experimental 101AB. Soemplace in Connecticut at controlled field
was questioned by airport manager after given clearence to land, refuel,
etc., whether I was an UL or not, even though I wass pointing to the N
numbers on the tailboom. Explained I was experimental, N numbered, and
licensed. AP Manager was dense to regs, or just acting that way to bug me.
Noone ever bothered me in Alaska. I love the way they fly there. Noone
bugged me about my UL, no matter where I landed. I liked that.
Other than these few times in 14 years of serious XC'ing around the North
American Continent, I have been welcomed to all airports, controlled and
uncontrolled. I normally do not land at controlled airports unless I have
a good reason to. i.e., fuel, food, restroom, weather, etc. I stay clear
of Class B airspace, fly under, around, and over, all the rest. I fly like
I belong there and were flying a Bonanza, King Air, 206, or what have you.
I fly abreviated patterns, but what is suggested in the FARs. I try not to
bring attention to myself by doing something dumb and foolish, unless I
have a good audience, JUST KIDDING!!!!!
I have had good rapport w/local FBO since 84, and three different managers.
I introduce myself and let them know me and my airplane. I am also very
fortunate to have a good area to fly here in central Alabama, and a damn
good Kolb airplane.
Just got back from a little flyin over at Jones Light Airfield, near
Columbus, Ga. Had a good turnout, except for my home UL club. Didn't see
John (Sling Shot) from Rome, Ga, and Rusty (SS) from Florida. Only one
other Kolb there, a local Firestar.
Trip home was a delight at 6500 feet, just above the clouds, 60 F, and a 10
MPH tailwind. Nice and smooth, wanted to keep on going. 1141.5 hours on
the airframe/908 hours on the little 912.
crowd.
>Dennis Souder
>Pres Kolb Aircraft
Who the heck do you think are going to buy those boots? I'll be first on
the list
Woody
I have shopped around locally for someone to copy the Kolb logo - - I found
a guy who can do it by scanning the image from a letter head. He wants ~$65
for the set up and then he will sell a hat, shirt or whatever at his
standard prices. I just don't want to pay a setup charge since Kolb
obviously has already done so in order to have their hats produced.
You are absolutely correct, it would be great customer relations for a cap
to be shipped with each kit. I think that if you ask Dennis real nice,
he'll send one to you. I have found much nicer hats then the standard Kolb
issue, but beggars should not be too fussy, hummm?
Ron Christensen
-----Original Message-----
From: jerryb(at)jmd.ods.com <jerryb(at)jmd.ods.com>
Date: Friday, May 29, 1998 1:17 PM
Subject: Kolb-List: Re: Kolb Logo
>Subject: Kolb Logo
>Author: "Ron Christensen" at
MAILGATE
>Hi Dennis:
have
>Ron Christensen
>MKIII 1/2
>N313DR
>So. Calif.
>Dennis
One thing I will hate to give up in a couple years when I retire is
my FAA/DOT I.D. card. I have only pulled it twice in 25 years, but it makes
a great "attitude adjuster" for morons like you are obviously dealing with
here...
Richard Pike
MKIII N420P (42oldpoops)
Hi all of you
I signed on about a week ago and have found this "kolb(at)intrig.com" to be
very informative and entertaining.
I am retired an want to get back to flying again (used to be GA). I have
a Lazair that is being covered for me with Pioneer engines. However, I
would very much like to get hold of a used, older, 2-place Kolb (with
trailer kit, if possible). Do any of you know of any in British
Columbia, Alberta, Saskatchewan, northern Montana or northern Idaho or
even northern Washington? I live in Grande Priairie, AB which is west/n
west of Edmonton.
Hope to hear from someone (or more!?)
Thank you
Gerald
Subject: | Moron? OUCH! That hurt! :-< |
To all,
>here...
Sorry, I forgot how to make a "sad" smiley face. Aside from the point being
made... How do you win friends and influence people? Call them names...
from afar. A Duh!!!!!
Should I send this to 400-500 people I ask myself a dozen times? Why not...
Cliff (the fool, the idiot, the imbecile, the unwashed, and "fixin" to put
on his "thick" skin to shed the rath that might fall upon him soon) Stripling
___(+^+)___
(_)
8 8
Subject: | Re: Moron? OUCH! That hurt! :-< |
Right on, Cliff!
Ron Carroll
Original Firestar
From: Cliff and Carolyn Stripling <striplic(at)nationwide.net>
Date: Sunday May 31 1998 8:39 AM
Subject: Kolb-List: Moron? OUCH! That hurt! :-<
>To all,
>>here...
being
not...
Stripling
> ___(+^+)___
> (_)
> 8 8
Subject: | Strobes and lights? |
Speaking of strobes...... I've been meaning to add some because my plane is
just about invisible in the haze, and we've got tons of military traffic here.
At one time, I read that we were rated number one in the nation for
near-midairs.
Anyway, I've looked at the magnum streamlined wingtip strobes. It seems like
they would be a good choice for our planes. Since I'm incapable of doing
anything the way it's supposed to be done, I was wondering if it would be
possible to use these as strobes and position lights.
A few questions:
1- Do they offer colored (red and green) lenses? If not, do the clear ones come
off easily so they can be dyed or painted?
2- Is there a provision for using 3 lights rather than two? I could always just
put a plain white light facing the rear I guess.
3- Probably a better question, has anyone seen position lights that would be
easy to mount on the Kolb?
Naturally, what I'm thinking about is night flight capability. I don't really
have any plans to launching out into the night with the SS, but it would give me
the ability to sneak in just after dark if needed. This would extend my
afterwork flying time quite a bit.
Russell Duffy
SlingShot SS-003, N8754K
rad(at)pen.net
http://www.pen.net/~rad/
Subject: | Used 503 to a good home |
Hi all,
It looks like my 618 deal is going to become reality soon. If it does, I'll be
selling the 503 package to one of our lucky listers. This would be essentially
a full 503 package like you would buy from Kolb, and will likely include the 66"
2-blade IVO prop. According to Dennis, all the mounts are the same, so the
engine would literally drop into place for any Kolb model. With any luck, I'll
find someone close enough to come get it, so it won't even have to be taken
apart (carbs, muffler, oil injection reservoir).
The engine is a 15 month old 503 DCDI, and has 33 hours on it now. The price
will depend on what ends up being included in the package, but I'm thinking of
something in the low $2k range for everything.
Let me know if you're interested.
Russell Duffy
Navarre, FL (near Pensacola)
Right on Topher!
Strobes are great, but I have found they do essentially nothing to aid
visibility in daylight. Only really worthwhile in dusk or really cloudy
conditions. Also, allowing us to fly 1/2 hr before sunrise, 1/2 hr
after sundown are the best parts of the day.
- Ben Ransom
Subject: | Big Insurance News |
I was kinda slow getting to this month's UF! magazine. Boy
what a surprise tho! AVEMCO announces they will not turn
away FAT ultralights. They will consider applicants on a
case by case basis and write policies as they deem appropriate.
AVEMCO says they feel that certain minor weight gains such
as wind-screens or brakes often push ultralights over 254 lbs
but not necessarily make the vehicle a bad insurance risk, and
in many cases might make it a lesser risk.
It seems good news that an insurance company finds it good
business to underwrite these outlaw vehicle/aircraft/whatever_we_are.
It is nice to see a big company acknowledge up front that fat ULs
are everywhere. One could view this as AVEMCO becoming the fat
UL pilot's accomplice in crime. Can't imagine how AVEMCO's
legal counsel sleeps well with this scenario. It also seems like
this could be presented to FAA and ARAC103 as a vote of confidence
that fat ULs are safe. Of course I don't yet know what the premiums
look like.
Also of interest was the letter from USUA Pres John Ballantyne.
USUA wants ARAC103 to be stripped of most references to ultralights,
the primary group it was meant to address when created in 1993.
(And even 1993 is really *after* the failed effort to increase FAR103
weight.) For quite a while now, USUA has been mad at the ARAC103 swing
toward heavier Sport Aircraft (1200lbs gross), which by now blows right
by any improvement in regulations for slightly fat 103 types. I agree
w/ USUA, this really stinks!! It is especially rotten, when AVEMCO
now will insure a fat 103, and as well, the safety statistics show
fat 103 to be working well, and to boot, FAA accepts fat UL in practice.
But somehow ARAC/FAA is still trying to re-invent the totally failed
sport pilot and sport aircraft category under the guise of helping ULs.
Comments?
-Ben Ransom
Subject: | Re: Big Insurance News |
>look like.
I hate to be my normal cynical self, but I bet the "bottom line" of Avemco's new
attitude was brought on by the bean counters. They finally realized that they
were losing out on a large segment of the aviation market. It might be keeping
the lawyers awake, but you can bet the accountants are sleeping well :-)
As for the UL weight limits, I have to admit that I hope the rules get changed
at some point so the SS could be considered an UL. If I ever loose my medical,
it would just be a matter of sending in the registration and peeling off the
numbers.
Rusty
Subject: | need IVOptop help. |
Hi all,
I just bought a new Ivo. It is three blade at 66 inch diameter. I would
like to hear from you as to whether I should run two blade or three
blades. I know I must cut down the diameter for three blade operation,
but don't know diameter works best.Please share with me your thoughts
and experiences.
A/C 1987 original FS
Rotax 377 prov 4 with 2.58:1
Sea level warm wx ops (florida)
From: | Gary Thacker <gthacker(at)mciunix.mciu.k12.pa.us> |
Subject: | FireStar GPS Ant. |
I would like to use my Garmin 45 in my FireStar II. Since I haven't
tried it yet I thought I would ask. Will the thing work with the little
stub ant. that is mounted on the GPS or do I need one mounted to the
airframe somewhere? I know I can just try it and find out but the plane is
there and I am here thinkin. I was plannin to rig up somethin to go around
my leg to mount the GPS to. I know this isn't new tech. but do you have
any suggestions as to puttin such a thing together?
Gary
| Gary Thacker | gthacker(at)mciunix.mciu.k12.pa.us |
| Souderton Pa. | |
| | gthacker(at)wsd.k12.pa.us (work only) |
Subject: | Re: FireStar GPS Ant. |
No problem at all using the stub antenna. Remember, this thing is looking up,
and there isn't anything significant between it and the sky. Lexan and a few
tubes from the wings won't even phase it's reception.
I don't know about the leg wrap, but here's a picture of how I mounted my Garmin
55-AVD in the SlingShot.
http://www.pen.net/~rad/ssdc422.jpg
Good luck,
Rusty
Subject: | Re: need IVOptop help. |
Hi Bob,
My Ivo prop was cut down from a 68" that I bought from a friend. I ran it
as a 68" first on my Original FireStar w/377 engine. The prop came too
close to the fuse tube (less than a half an inch as I recall), so we cut
an inch off each tip. I made an aluminum L-bracket that was clamped to
the tip to get the same amount cut off each blade. Before cutting off, I
did try it in each configuration. I could not get the 3-blade to rev over
5900rpm on the 377 and it seemed hard to start, so I switched to the
2-blade and have used it that way ever since. Ivo claims the 2-blade is
more efficient and will give a better cruise. I climb 900'/min with a
55-60 mph cruise. I'm happy with it.
Ralph Burlingame
Original FireStar
>Hi all,
>diameter. I would
>and experiences.
>Thanks
>Bob
Gary,
The GPS will work fine with the built in antenna in the FS II. I put
sticky-back velcro on the back of the GPS and made a nylon strap that
also velcros around my leg. The GPS is then pressed to the velcro strap
on my leg and is at the ideal angle for reading. If your FS II is open
cockpit, loop the carrying handle around your leg first before attaching
it to the velcro.
Ralph Burlingame
Original FireStar
writes:
>little stub ant. that is mounted on the GPS or do I need one mounted to
the
>plane isthere and I am here thinkin. I was plannin to rig up somethin
to go
>around my leg to mount the GPS to. I know this isn't new tech. but do
you
>have any suggestions as to puttin such a thing together?
>Thanks
>Gary
Subject: | moron explanation? |
>Date: Sun, 31 May 1998 00:05:58 -0400
I think I once again failed to express myself correctly, and
offended someone. The reference to "morons" in the text below was to
stuffed shirt
bureaucrats that try to throw us light plane drivers off public use
airports. I guess I was rude, next time I'll just say; "stuffed shirt
bureaucrats" instead. Thanks for the "heads up" on the etiquette. rp
P.S. Surely you didn't think I was referring to the dude doing touch & go's?
My reference to pulling the FAA I.D. card was on an obnoxious airport manager
a number of years ago. It's a kind of long war story, and if I make it to
Oshkosh this year, and if you like war stories, ask me about it. rp
>To: DLSOUDER(at)aol.com
>From: Richard Pike <rpike(at)preferred.com>
>Subject: Re: Experimental
>Cc: kolb(at)www.intrig.com
>>Dennis
here...
> Richard Pike
My sugestion is to use two of the blades at 66". You can get the
spacers and convert it. A three blade would have to be cut down too much
for a 377.
John Jung
>Bob Gross wrote:
> Hi all,
> and experiences.
> Thanks
> Bob
medical,
>numbers.
>Rusty
Hey Guys: Some where in the back of my CRS riddled mind I remember reading
that one can not transform a registered airplane into an unregistered
ultralight. Can't remember where I read or heard it, but it sure rings a
bell. Might be worth checking out before it spoils one's plans.
Anxious to see and hear the performance of the SS with the 618. Should
turn a 503 slug into a real race horse. Good luck with it.
Gary,
Here is an idea. I made mine out of an archery arm protector and a
safety belt and a few pieces of thin bungee. Later, I made one from
velcro but it didn't work as well, so I swithced back to the original.
John Jung
> Thanks
> Gary
> | Souderton Pa. | |
Subject: | Re: Strobes and lights? |
here.
Hey Guys: It's me again. I highly recommend spending the bucks, if you
want to be a night flyer and have good anticollision lights, for a Whelan
system like the set up that has been operating on my MK III for 1142 hours
w/o a problem. Set weighs about the same or less than UL junk and they
backup what they sell with good service and a fully tested product.
I went the UL route on my other two ULs with "mickey mouse" strobes, and
spent most of my time on the phone with the manufacturer trying to figure
out how to keep them operating.
I'm too lazy to get up and get the number of my system, but has pos,
strobe, and tail light on each wing tip, thus eliminating the requirement
to wire and figure out how to mount the taillight.
ps: I get no cut from Whelan if I sell a system. hehehe
Gary
I use my Garmin 90 in the M III with the stub ant. and I have no
problem at all receving all 8 satellites on my unit
I am sure that you will have the same results, with no problems. Good
luck
RICK
writes:
>little
>plane is
>around
>have
>Thanks
>Gary
>| Souderton Pa. |
writes:
<< I would like to use my Garmin 45 in my FireStar II. Since I haven't
any suggestions as to puttin such a thing together? >>
I have a Garmin 38 which works perfectly just rubber banded to the stick which
puts the antenna pointing up and right under the windshield of my Firestar
KX....do it :-) ..GeoR38
Subject: | Strobe lights-- I'm cheap |
Hi all,
The subject of strobe lights has been kicked around-- I purchased two 12v
auto strobes from JC Whitney and fabed wing tip mounts. The units that
I used have a magnetic base which were discarded and mounted the lights
using a piece of angle alum. and a flat plate. Noise filters have to be
installed in the 12v circuit to keep the "hash" out of the radio.
I also mounted two Hal. lights under the nose for landing and taxiing. --
The landing lights are visable even in day light.-- Was very glad to have
them one day when an Air National Guard C130 and I were sharing the same
air space. He was climbing out bound on a radial to the Filmore VOR-- I
pushed the nose over and made an immediate 90 degree turn. That was the
day that I really realized just how slow my Mark III really is!
One other thing-- the Nav lights, red and green, are required for night
flying. Which one goes on which wing tip? Just remember that red is a
shorter word than green and the short words go together i.e. red - left
and green right.
enough for tonight-- heading for Colorado in the morning.
Larry Fuller
I'm looking for a set of TwinStar decals can anyone help?
-Mark-
help?
-Mark-
I checked into this before I ever started this adventure. You can de-register
your plane by returning the registration to the FAA along with a letter. I
believe you have to tell them some reason such as "no longer airworthy", "sold
for parts", etc. Once you do this, you would have to go through the whole
inspection process again to get it re-registered. That makes it impossible to
switch back and forth easily.
Rusty
Bob Cooper, can you tell us what your insurance Co., agent, phone number...
is so we can get a quote? It sounds like you're getting a good rate.
Thanks...
jim
From: | "rutledge fuller" <rut007(at)hotmail.com> |
the most
near
Remember, do unto others like you would have them do unto you. I really
do not think that these tactics will help us gain access or popularity
with such airports. As a matter of fact, it gives these guys even more
to bitch about. They may also share these stories with other airport
managers. (Even though you are performing legal manuvers) It's kind of
like one step forward and two steps back. Those few minutes of "So
There!!", might someday cause our extinction.
Rut (Just making an observation) Fuller
Good Job Ron, I see you beat me to the punch.
Rutledge Fuller
----Original Message Follows----
discourage,
an
strongly
or
to
to
Ron Carroll
Original Firestar
for
the
>most
near
There!!".
part
of
were
against
also
have
victim
is
a
city
>Rusty
From: | Scott Bentley <Scott.Bentley(at)Bentley.Com> |
Subject: | Antennae from Advanced Aircraft Electronics |
I did the same thing, with the same good results.
> From: PKrotje(at)aol.com [SMTP:PKrotje(at)aol.com]
> Sent: Friday, May 29, 1998 10:22 PM
> To: segarcts(at)qtm.net; Kolb(at)www.intrig.com
> Subject: Re: Antena placement and what kind ??
> and
> and
> was out of sight.
> Pete Krotje
Subject: | Advanced Aircraft Electronics flexible Antennae |
They apparently do not have a web site, but see:
http://www.chiefaircraft.com/Aircraft/Antennas/AAE.html
http://www.aircraft-spruce.com/spruce/pages.cgi/page385
I had some problems with the Aircraft Spruce site, but if you fiddle with
it, you'll find what they charge, I suspect.
I did an altavista search
http://altavista.digital.com/cgi-bin/query?pg=q&q=%22advanced+aircraft+elect
ronics%22&stq=10&c9k starting with a simple http://altavista.digital.com/
and entering "Advanced Aircaft Electronics" with the quotes, and found what
I was looking for in seconds...
> From: Ron Carroll [SMTP:ron.carroll(at)worldnet.att.net]
> Sent: Monday, June 01, 1998 10:58 AM
> To: Scott Bentley
> Subject: Re: Antennae from Advanced Aircraft Electronics
> Does "ADVANCED AIRCRAFT ELECTRONICS" happen to have a website? I'd be
> interested in this myself.
> Ron
> >> and
> >> and
> >> was out of sight.
> >> Pete Krotje
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
> near
Yeah, you're right about do unto others. But, at the risk of beating
this to death, let me clarify a little. At one airport I ventured a
5'agl pass after a month or so of flying elsewhere. Next time by I
did a touch and go or 2. Then later, bold enf to land. Six months
later I'm operating out of there all the time on wknds including setup
from trailer, and had become friends with many GA pilots. No one had
a problem except the moron/stuffed_shirt_beaurocrat who runs the place,
and he was never ever there. Come to think of it, those adjectives (and
worse) were used by the GA guys! So there the adage 'nothing ventured
nothing gained' applies.
At the other airport, the "several passes" description i used is
an exageration (sorry). I've only done 3-4 over a couple years, and
there was no one else around at the time. The 'so there!' was really
only felt by me. That airport needs to have their FAA restriction to
ultralights revisited. If enf ULers got together, it could be done.
Somewhere between 'do unto others' and 'don't take no shit from anybody'
there is an answer.
-Ben Ransom
Topher:
A couple of thoughts regarding your message:
* In order to land at any airport, it is VERY WISE to have a radio.
Obviously at a controlled airport, it is a must. At an uncontrolled airport
it is a matter of mutual safety. As you wrote, you didn't have radio
contact when landing at the airport when the twin aircraft was
landing/rolling out against the sock. Glad you are still around to write
about your experience ! !
* For flying in Class B or Class C airspace, I'm sure you know that a
transponder and altitude reporter are required in addition to a radio. My
new MK III 1/2 has all the necessary equipment to fly in the Los Angeles
area. I costs a bit of money, but I feel it is a safety issue here because
of the heavy density of air traffic.
Ron Christensen
From: Christopher John Armstrong <tophera(at)centuryinter.net>
Date: Saturday, May 30, 1998 1:41 PM
Subject: Kolb-List: Re: Mix of traffic
>Topher
Subject: | Kolb:engine mount vibs |
Has anyone flying a MKIII with 582C 3:1 with 3 blade 66"IVO feel engine
vibration in the airframe from 4800-5800 rpm and inspected the Lord mounts
for partial collapse, especially the front unit on the exhaust side. This
unit sees the combined loads of the torque, weight and propellor force
offset and makes occasional solid contact with the mounting bracket as
indicated by the markings on the bottom surface of the bracket. I have 2
washers in the front and 4 washers in the back units installed and the IVO
2 1/4"prop spacer for prop clearance and have already rotated the mounts
once before,several years ago when first noticing the contact marks
although I did not feel the vibration at that time. The scenario is as
follows; up to 4800 rpm no contact at all due to low torque and propforce
and running smooth; 4800 to 5800 rpm intermittend contact between the
bracket and the solid part of the mount sending engine vibrations through
the airframe; 5800-6300 solid contact and lowering airframe vibration
slightly.
Can this be caused by other engine/prop problems. The EGT and CHT are in
the normal range and max RPM is 6300 so uneven carburation is not suspect
at this time. TTAE including prop is 432 hrs.
Frank Reynen MKIII@432 hrs
http://www.webcom.com/reynen
Subject: | Re: Kolb:engine mount vibs |
This sorta sounds familiar, on my slingshot around 4800-5400 rpm
I was getting a vibration and a noise, come to find out it was the fabric
vibrating against a horizontal tube at the rear of the cage.
From: Frank_R_Reynen(at)notes.seagate.com <Frank_R_Reynen(at)notes.seagate.com>
Date: Monday, June 01, 1998 1:37 PM
Subject: Kolb-List: Kolb:engine mount vibs
>slightly.
Ben,
Ten years ago I landed at a state owned uncontrolled airport just to see
what was up. Most of the GA pilots there had never seen an ultralight and
they were very skeptic. Today, this airport is 30% ultralight/lightplane
and I have seen a complete turnaround in attitudes toward these aircraft.
This airport continues to be one of my best places to fly.
Ralph (be nice, fly right) Burlingame
Original FireStar
writes:
>place, and he was never ever there. Come to think of it, those
adjectives
>(and worse) were used by the GA guys! So there the adage 'nothing
ventured
>anybody'
>there is an answer.
>-Ben Ransom
Dear Anyone:
Is any one out there building a firefly?? If so let me know how far along
you are and we'll talk. I'm waiting on my kit #1 and will be starting
sometime in July. don't make me re-invent the wheel let me know what your
doing that works and what doesn't.
I'm considering a Hirth 2702 for a power plant. Any comments??
Brian in Washington State
>Return-Path:
>X-Authentication-Warning: www.intrig.com: bin set sender to
owner-kolb(at)intrig.com using -f
>X-Lotus-FromDomain: SEAGATE@INTERNET
>To: kolb(at)intrig.com
>Date: Mon, 1 Jun 1998 10:21:01 -0700
>Subject: Kolb:engine mount vibs
>Sender: owner-kolb(at)intrig.com
>slightly.
>Date: Mon, 01 Jun 1998 17:54:43 -0500
>To: Frank_R_Reynen(at)notes.seagate.com
>From: john hauck <hawk36(at)mindspring.com>
>Subject: Re: Kolb:engine mount vibs
>In-Reply-To: <88256616.0058CAB3.00@sv-gw1.stsv.seagate.com>
>Hi Frank:
>If I didn't tell you before, you have a nice web page, airplane, and home.
I like your set up on the water. I too live on the water, Lake Jordan, 25
miles north of Montgomery, Alabama.
>Sounds to me like eng mt vibrations. I had and have the same anoyance.
Not really a problem, just the way the system works. Don't have that
problem on lesser HP engs, or I didn't with the 447 on my Firestar.
>I have my eng rigged a little different from you. I also had the 582
rigged just like the 912. In order to get the line of thrust more in line
with the bottom of the wing, I raised the front of the eng 5/8 inch, and
left the rear even, with no spacer. It works well that way. I use a warp
drive fast taper 3 blade prop and a home made 2 3/4 in spacer (I think it
is 2 3/4). If I read your e-mail correctly, you raised the rear of the eng.
>I use a 1 3/4 or 2 inch fender washer under the 5/8 inch spacer. This
prevent the eng thrust and torque from burying the spacer down in the Lord
mount. I have had the right front mount come apart after 800 or 900 hours.
Keep your eyes on them. Make that part of your preflight.
>Fly safe,
>john h
Brian,
I'm curious. Why a Hirth 2702?
Also, where are you in Washington?
John Jung
>Brian Copple wrote:
> Dear Anyone:
Question:
Does the 1/2 hr. before sunrise and 1/2 hr. after sunset with strobes
apply to N- numbered Experimentals? I have not been able to find that
it does.
Terry
loudy
> - Ben Ransom
writes:
>reading
>rings a
Quoting from Advisory Circular 103-7, paragraph 15a states:
"If your ultralight has been issued an airworthiness certificate, you
cannot operate it as an ultralight vehicle under Part 103. An ultralight
cannot be operated interchangeably as a certificated aircraft and an
ultralight vehicle."
But, paragraph 15b states:
"If you want to operate your ultralight under Part 103, you must turn in,
to the issuing authority, any airworthiness certificate currently issued
for the craft."
...Go for it, Rusty (when/if the time comes)!
-Mick Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
writes:
>..... Can't imagine how AVEMCO's
More premiums of course! Money is a barrister's valium (and viagra, and
prozac, and...). It was most likely one of these soleless vermin who
convinced Avemco that it was stupid to cut themselves out of 80-90% of
the UL market on account of something as trivial as Federal Regulations.
Oops, did I say 'soleless vermin'? I meant 'savy business advisor.'
> It also seems like
>look like.
Another slant is: how hard will a 'real' pilot go after the first guy who
sticks a 'fat' ultralight in the side of his parked Cardinal (especially
when he finds out it was insured by the same people he's been writing BIG
checks to for all these years)?
Not that I'm paranoid (that only applies if it ain't true right?) but,
I'd read the fine print with an electron microscope. Could be you'll get
sold down the river if you ever make a claim. Even so, if your 'incident'
injures an 'innocent third party', I'd bet any compensation you get from
Avemco would be a drop in the settlement bucket by the time the fat lady
sings.
I hope it doesn't come to this but one of my many fears is that someday,
there'll be a 'high profile' UL incident that the media will pick-up and
shake like a doll in a pit bull's mouth. We live in such a reactionary
climate nowadays that were this to happen, public opinion (dictated by
the media) would demand swift and thoughtless action by FAA. A court case
with high stakes might be the perfect vehicle for abolishing Part 103
altogether.
Of course, it could be I'm just watching too many 'X-Files' again. Does
anyone have Johnny Cochran's number?
-Mick (just doing my part to rain on the parade) Fine
Tulsa, Oklahoma
Avemco's new
they
keeping
FWIW, you are correct. AVEMCO was not shy about coming right out and
saying they know they have been turning away a huge market. Good ol
USA capitalism to the rescue. I hope it works.
Gotta love some of those soleless vermin! :)
-Ben
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
>Tulsa, Oklahoma
Great point!!! My wife just had our first baby 7 weeks ago and all the
bills are starting to come in now...and I have been enlightened as to the
millions of ways the insurance companies can weasle out of paying legitimate
claims!!! I think the electron microscope examination should be standard an
ALL insurance policies before you send them your hard earned money.
My $.02 worth...and it probably ain't worth what you payed for it...
Jeremy Casey jrcasey(at)mindspring.com
Subject: | RE: Mix of traffic |
No, it doesn't. Unfortunately, experimentals are bound by the same rules
as factory-built planes for required equipment. To fly between sunset and
sunrise, we need position lights, anti-collision lights, and (according to
my local MIDO) an engine-driven electrical system to keep it all going.
-Steve
(N-numbered Mk II)
From: | "Rinehart, Mark W." <Mark.W.Rinehart(at)Allison.com> |
FAR Part 103.11 states that an ultralight vehicle may be operated 30 min
prior to sunrise and 30 min after sunset if it has an operating
anticollison light visible for at least 3 statute miles. My question is
what constitutes an "anticollision light"? Does a rotating beacon count
as well as strobes? Also, can these lights be run off the engine or
must I have a complete electrical system including battery?
Mark Rinehart
"MK III BFI wanna be"
I was flying a Champ GA plane at the time, so this was not an ultralight
issue. it was uncontroled and the main issue is that the guy did a
straight in... the single most dangerous and illegal thing you can do at
an uncontroled, radio optional strip. same thing happened to me years
ago but I had already landed and a twin did a touch and go! I was
forced to turn off the side of the runway. As he went buy at 80 knots I
pointed at the windsock. As far as flying an ultralight type
experimental in class c or b, you can have it, dodging 747's or even
737's is not the stong point of these planes!
Topher
Subject: | Transponder waiver rule... |
To all,
...an engine-driven electrical system to keep it all going.
That statement brings to mind the waiver under FAR sec. 91.215 (b.3) to fly
within the 30 N mile airport listed in Appendix D, Sect 1 of that part
provided such operations are conducted, etc...
My airplane does not have an engine-driven electrical system, therefore can
operate under the FAR provision of this section without such equipment
(meaning mode C transponder).
That allows legal operations from my home airport which is within 30 N miles
of a big airport terminal and almost under the B space "inverted wedding
cake" above.
I know the waiver is to protect and allow older or simpler planes (Cubs and
the like such as our kind of light plane that can hardly afford or need the
equipment in the airspace that they fly in) to operate from airports or in
the airspace near the big terminals.
Later,
___(+^+)___
(_)
8 8
>Question:
>it does.
>Terry
> Nope.
Richard Pike
Subject: | "ENGINE-DRIVEN ELECTRICAL SYSTEM" |
If you say you don't have the engine-driven electrical system,
what do you call the lighting coil with Rotax regulator? Or are you
not using a regulator? If you don't have electric start, and don't need any
power except for instruments, maybe you are using that tiny Radio Shack
diode regulator method to get your 12 volts for your tach and water temp gauge?
I want to say the same thing you are saying (no electrical, no X-ponder).
Thanks, jim
From: | William V Rayfield <rayfiwv(at)mail.auburn.edu> |
Hey gang,
I'm looking for someone in Georgia or Alabama area that gives instruction
in a MarkIII or a Ferguson. It won't be long before my father and I are
ready to solo and fly our own plane. We're getting instruction in a Challenger
II
and realize it is much different than a Kolb. We would just like a little
exposure to a similar aircraft before taxiing and crow-hopping our own.
preferably, we'd like to find someone around middle Alabama/Georgia. Any
help would be greatly appreciated-thanks
Bill Rayfield
"I'd rather be lucky than good"
Mech. Engr. Student
Auburn University
"War Eagle"
writes:
>Hey gang,
>instruction
>are
>Challenger II
>little
>own.
>Any
>Bill Rayfield
>Mech. Engr. Student
>Auburn University
>"War Eagle"
Hi William -
If you travel into the South Jersey area, there is a fellow at Millville
Airport that provides
instruction in a 2 place Kolb. I'm not sure of the model.
Bob Cooper
Newfield, NJ
From: | "CHRISTOPHER DAVIS" <cdavis2(at)capecod.net> |
I don"t know about instruction in your area but I have this to say about
crow hopping a kolb, If you can fly an airplane , forget crow hopping ,if
you do it it willprobly be the most difficult flying you ever do in a Kolb
! Isay just give her a through preflight get in an fly away ,The landings
are apiece of cake from a nice relaxed , did I say "relaxed" final compared
to trying to get a kolb back on the ground when all it wants to do is
CliiiiiiiiiiiB!!!!!!! been there, Chris D.
From: William V Rayfield <rayfiwv(at)mail.auburn.edu>
Date: Tuesday, June 02, 1998 6:18 PM
Subject: Kolb-List: instruction
>Hey gang,
Challenger II
>Bill Rayfield
>Mech. Engr. Student
>Auburn University
>"War Eagle"
>Wood,
>how do you mount the PVC tubes, isn't there rivets in the rear spar for the
>hinges in the way?
>Also how do you keep the 1" tubes from sliding out in flight?
>Geoff Thistlethwaite
You need to install the pvc before you rivit the last rivits in.Locate
where the rivits will hit the pvc and then drill the pvc to a 1\4 "dia.
clearance There is no real strength needed to hold this pvc.To hold the
handle in we heated the pvc and gave it a slight bend. This gave enough
friction so we don't worry about it coming out in flight.Be sure none of the
rivit botttoms hit the handle tube.
Woody
Subject: | Re: "ENGINE-DRIVEN ELECTRICAL SYSTEM" |
> Thanks, jim
Jim and all,
You are right about "what do you call...". It certainly is an "engine
driven electrical system" but it stops at the engine's instrument needs. I
use the regulator and capacitor system. The way I understand it the FAA
allows such a source to supply only the "engine instruments" as if the
definition of an electrical system does not include those items. I operate
the nav/com and GPS off a motorbike battery that I take home to recharge. I
can find nowhere in the FARs where "an engine driven electrical system" is
defined. I could be "full of it". I don't know. Anyone out there of
authority have any input?
Later,
___(+^+)___
(_)
8 8
> Thanks, jim
Jim and all,
Later,
___(+^+)___
(_)
8 8
In a message dated 6/2/98 4:38:23 PM Pacific Daylight Time,
cdavis2(at)capecod.net writes:
<< f you can fly an airplane , forget crow hopping ,if
Amen. I have seen the gear wiped of Kolb products a number of times in
this scenario. The beginner staggers along at the edge of a stall without
ever really getting a sense of the attitude the plane really flies in. I have
said this before, but it bears repeating
: guys sit in their Kolbs while they are building them and get the impression
that the attitude that the aircraft is in on the ground is the same thing as
the level attitude. Have a friend pick up the tail unil the bottom of the
wing is level with the ground. You will be surprised how high the tail is and
how low the nose is.
>> Thanks, jim
>Jim and all,
>Later,
Evening Cliff:
I'm not an expert and I don't have any references in front of me, but IMOHO
I think you will have a hard time convincing anybody other than my bassett
hound, Ernie, that you don't have an electrical system, if you are powered
by any Rotax eng. If you are flying in front of a 582 you are equiped with
a 12 pole, AC generator or alternator. That is an engine driven electrical
system.
I wish we could get away with it, but I don't think so. I don't need a
transponder but occassionally, but when you need it it would be nice to
have. Most ARSAs and TRSAs will let you in if you call one hour prior, and
sometimes if they aren't busy and the right guy is on duty he will pick you
up on radar and vector you in. But when you really want to come in, the
tough ones say no.
JIM
If my memory serves me right the meaning of electrical in the eyes of the
FAA
is . ELECTRICAL ... VOLTAGE THAT IS PRODUCED BY MEANS OF AN EXTERNAL
DEVICE AS ALTERNATOR , anything which is outside of the engine, our
rotax's are producing power from within .
Rick Libersat
>therefore can
>need any
>Shack
>temp gauge?
>X-ponder).
> Thanks, jim
writes:
>..... We're getting instruction in a
>Challenger II
Congrats Bill,
Don't take this as an endorsement to go on without 'training in type.' By
all means, get some dual in a Kolb if possible but if you and your dad
can handle the Challenger, you should have no problem in the Kolb. This
is just from my own observation but you'll probably be amazed (and
relieved) at the improved lateral stability. In other words, expect to do
much less with the (properly designed) rudder on the Kolb :-) Much less
adverse yaw from the ailerons also.
Otherwise, the performance numbers should be pretty close. Trust me on
this 'tho, it is much harder to transition from a Kolb to a Challenger -
at least it was for me! The Challenger demands that you stay much further
'ahead of it' than the Kolb - IMHO.
I think Cavu has a good theory about crow-hopping. Getting used to the
attitude of the plane while it's in the garage as opposed to it's flight
attitude maybe why some have been bitten while crow-hopping. I did it,
learned from it, gained confidence in myself and in my plane from it, and
never felt in danger while doing it (or after) but I have heard about
many who come to regret it. I dunno...
-Mick Fine
Tulsa, Oklahoma
Subject: | Re: Virtual Visit to Kolb Factory... |
Scott,
Thanks for taking the time to post the "Virtual Visit". I finally
took the time to view the pictures and it was very interesting.
John Jung
> One of our locals had one in a Fisher Classic up until yesterday.
Had about 4 hours on it, kept running hot, partial seizure on one cylinder.
Sent the piston back to (?) whoever he got it from. They reportedly did
something to it (?) and sent it back to him, said it was OK. Seized over the
departure end of the runway, had enough altitude to get back, but not enough
to miss the earth-mover pan that was parked alongside the runway. Admittedly
he was not knowledgeable on 2-strokes, and surely has a poor opinion of them
by now...
That was the first one in the area, not a good start.
Richard Pike
I would suspect the IVO prop
Russ
Good choices all around.
Russ
>Hey gang,
See if you can track down Glenn Rinck in Grand Ridge , Florida. He
can probably tell you who can do it.
Richard Pike
>Mark Rinehart
>If it's an ultralight, it can be run off anything you want, as long as it
flashes, winks, twinks, or whatever for 3 miles visibility.
Richard Pike
I have about as little authority as anybody I know of, but I
remember reading that the definition of an "engine driven electrical system"
includes the engine, an electrical supply source, and a starter. The
question came up back when the mode C veil thing came up for all the TCA's a
number of years ago. I suspect that you would find the info in the rationale
for a reg that sometimes precedes a reg, and it would be the reg that covers
the imposition of the mode C veil for TCA's, but I don't have ready access
to that one right now.
Richard Pike
>Jim and all,
>Later,
> ___(+^+)___
> (_)
> 8 8
From: | "Richard neilsen" <neilsenr(at)state.mi.us> |
Subject: | "ENGINE-DRIVEN ELECTRICAL SYSTEM" -Reply |
The regulations are rather all inclusive on this point but the local tower
has the authority to interpret these regulations. If you have or want to
use a strip under a class C airspace, give it a try and ask. If you
request a exemption and give them a reason they just might approve it. I
know of exemptions that were approved by saying that they can't afford to
install a transponder or the electrical system can't safely handle a
transponder. Note these exemptions were under the vail of the airspace and
outside the area that goes to the ground. Also you will have to file for a
renewal once a year but if you don't gather any negative P.R. the renewal
is reported to be a sure thing.
My $.02 worth.
Rick Neilsen VW powered Kolb MKIII - still no first flight
Subject: | Re: Used 503 to a good home |
tried to send this just to Russell Duffy but it didnt work, so every
body else nevermind...
I will be wanting to buy an engine in about 6 months but that might be a
littl too long for you. I am near Minneapolis so It would require
shipping. Any more details available about the engine? which gear box?
Standard carbs? are your going to send the engine mounts, throttle
cables choke etc. etc. etc. since I dont have any of that stuff. I
think saving a thousand bucks might get my wife to free up the funds
sooner as opposed to later ;-)
Topher
From: | "Ron Carroll " <ron.carroll(at)worldnet.att.net> |
I don't believe that you will find that a straight-in approach is illegal
anyway in the regs, but may not be recommended. Sometimes, when traffic
permits, it is much easier for larger planes to do a straight-in because
they require such huge turning areas. They turn base so far out that it
almost turns out to be a straight-in.
Enough of that, now I have a question for the group. I am having trouble
finding the exact "page & chapter" in the FAA Regs to support my pet peeve,
perhaps someone can help.
PET PEEVE: High speed, low level passes ( Just showin' off ! )
I recently had a fairly close call while in the landing pattern at my home
airport. I was returning home in an ultralight flight of four, doing a
crosswind for downwind and had announced our intentions prior to entering
the crosswind. The noise of my plane made it hard for me to hear my radio,
but I did hear the FBO announce to someone, "Be advised, there are
I, in the lead plane, had passed the centerline of the runway and was on a
left downwind. The second plane had just passed the centerline and was
turning downwind, and the other two planes were coming up on the centerline
when three T-34s, flying in formation, came zooming down the centerline at
about 50' AGL, doing probably 200 mph. At the end of the runway they did
an airshow type pullout into a starburst, barely missing out ultralight
flight of four.
As far as I can determine, this is an illegal use of the airport landing
pattern area, but I can't quote the exact FAR to prove it. I said that the
maneuver is considered an aerobatic maneuver, but was shut down with the
reply that aerobatic maneuvers do not include low low=level, high speed
passes. The hazards are obvious, not just to ultralight traffic, but to
any and all other traffic in the pattern, especially those without radios.
With no radio (not a requirement) there is no way for them to know of our
presence, or for us to know of their intent.
If, in fact, this is an illegal use of the airport traffic area I would like
to write a letter to the FAA, identifying the dates, times and N-numbers of
the planes involved. I probably wouldn't make friends, or influence people
by writing such a letter, but if it would eliminate the hazard, and possibly
save a life, I would get involved.
Any help, or recommendations would be appreciated.
Ron Carroll
Original Firestar
Independence, Oregon
Date: Tuesday June 02 1998 7:55 AM
>issue. it was uncontrolled and the main issue is that the guy did a
>an uncontrolled, radio optional strip. same thing happened to me years
>Topher
Subject: | high speed passes, pet peeve |
To Ron --
Go ahead and send the letter. Even if a high speed pass is not
considered aerobatic, the star burst manuver would be, in my opinion; a
rapid change in attitude and direction. And the fact that they did the
pass and manuver in a traffic pattern without permission or radio
contact may in itself be a violation as with air show rules/regs. I do
not know which regs this would fall under, but this definitely VIOLATES
SAFETY, and this is what the regs are all about.
Jim
To Ron --
Even if a
high speed pass is not considered aerobatic, the star burst manuver
would be, in
my opinion; a rapid change in attitude and direction. And the fact
that
they did the pass and manuver in a traffic pattern without permission or
radio
I do not
SAFETY, and
Jim
Subject: | rotax 503 to a good home |
Russell, I have been unable to contact you at your e-mail address. I'm
interested in your 503. Can you supply me with the specifics of the engine.
Jeff Wilde in Orlando Fl.
Subject: | PET PEEVE: High speed, low level passes |
Ron Carroll's pet peeve is a violation of FARs:
"91.119 MINIMUM SAFE ALTITUDES: GENERAL
Except when necessary for takeoff and landing, no person may operate an
aircraft below ...
(c) ... 500 feet above the surface ... closer than 500 feet to any
person, vessel, vehicle, or structure."
also the starburst at the end of the low speed pass violates one and
possibly two FARs:
"91.303 AEROBATIC FLIGHT
No person may operate an aircraft in aerobatic flight --
(d) below and altitude of 1,500 feet ...
...aerobatic flight means an intentional maneuver involving abrupt
change in an aircraft's attitude, an abnormal attitude ..."
"91.307 PARACHUTES ...
(d) Unless ... wearing an approved parachute ... no pilot [except solo
or training in most situations] may execute an intentional manuever that
exceeds --
(1) A bank of 60 degrees ...
(2) A nose-up or nose-down attitude of 30 degrees ..."
Ron, having said all this, I would urge you strongly to *not* get the
FAA involved in this situation. The last thing most ultralight pilots
should want to do is get into a finger pointing contest with other
segments of aviation over strict compliance with FARs. (I'm working
very hard to keep my original Firestar below 254 lbs but ...) Besides,
it is in no-one's interest to encourage the FAA bureauracy into strict
enforcement. Their recent zero-tollerance fiasco caused more safety
problems than even the FAA claimed to fix.
Might I suggest a better approach would be to contact the nearest EAA
Warbirds Chapter and enlist their support to get the safety message to
the offending pilots. An attitude of concern rather than anger is more
likely to yield positive results. We ask the general populace to accept
additional risk so we can enjoy flying over their homes. We also must
accept additional risk near airports so others can enjoy aviation. Not
to minimize the danger of your situation but I've had many more near
misses while instructing at FAA controlled airports than anywhere else.
That doesn't mean I felt it would be productive to "report" the
offending controllers. Simply making them aware of the problem was
sufficient.
Tom Kuffel, CFI, EAA Flight Advisor, etc.
Subject: | 503- please stand by |
Hi everyone,
After all the responses to my 503 engine (potential) sale, I figure I should go
into the used Rotax business. Pity I didn't think to make it a bidding process
First, thanks to everyone that expressed interest, but at this time, I've got
way more interested people than engines. I apologize for not responding
personally to the last few that wrote, but this week has been MRI hell and I
haven't had a chance to keep up with my e-mail. In fact I've only had about 3
hours of sleep over the past 72 hours.
Second, I'm still waiting for word on the 618 deal. The guy who owns currently
owns it, still hasn't fully decided to sell it, though an answer is expected any
day.
Sorry to get everyone worked up over this. I had no idea there would be such a
demand for a used 503. In retrospect, I should have waited until the 618 deal
was final before posted the 503 sale info.
Stay tuned
Russell Duffy
RV-8A under construction (despite the prototype crash)
Subject: | Re: PET PEEVE: High speed, low level passes |
>exceeds --
Well said. I agree 100%. It ain't a good idea to go start pointing the
finger at everyone else's violations of the regs. None of us are perfect
in the UL community. Besides I like to do flybys and I fly an unorthodox
pattern most of the time. I believe the reg on airport operations suggests
procedures rather than setting the rule in concrete.
From: | "Ron Christensen" <spectruminternational(at)email.msn.com> |
Topher:
You are 100% correct about the dangers of straight in approaches at an
uncontrolled airport. Your stroy illustrates why I believe a radio is
essential equipment these days for approach to ALL uncontrolled airports.
At least you have some hope to have advance warning, and to be aware of the
reckless nuts you have twice encountered - of course assuming they broadcast
their intentions, locations and movements.
I have been flying C150s and C172s in Class B and Class C airspace here in
the Los Angeles area, and really enjoy it ! ! The radio procedure is
great, and for me, essential arrows for my private pilot quiver. My MKIII
is equipped so that I can continue to fly here, and I expect my air speed
will be nearly as fast as a C150. Actually, as you know, one does not have
to dodge 747s, etc. because ATC does a masterful job of advising of traffic,
thus proper separation is not too difficult to maintain. To each his own,
hummm?
Ron Christensen
Date: Tuesday, June 02, 1998 7:52 AM
>Topher
I think Tom's advice is EXCELLENT ! !
Ron Christensen
Date: Wednesday, June 03, 1998 11:30 AM
Subject: Kolb-List: PET PEEVE: High speed, low level passes
>aircraft below ...
>possibly two FARs:
>exceeds --
>sufficient.
May 14, 1998 - June 03, 1998
Kolb-Archive.digest.vol-aq
