Kolb-Archive.digest.vol-av
August 20, 1998 - August 31, 1998
>Will The DAR/FAA want proof of the Pitot/Static/Transponder
>certification before they issue the airworthiness certificate?
>There is only one guy in TLH that does this, and his reputation
>is bad to say the least.
Hi Craig (and anyone else that might be in the area),
I can't answer your question really because I don't have a transponder in my
Kolb. There may be another DAR option that you don't know about though. I used
a guy named Richard Kukucka (pronounced Ka-kuch-ka) out of Enterprise, AL. He
has an IFR Cessna and will fly to you for the inspection. You pay his fuel and
the inspection fee which I don't quite remember. He was great to work with and
I will absolutely use him again when the RV-8 is done. If you want to give him
a call:
334-347-7171 (office)
334-393-9008 (fax)
When I called him initially, he sent me a packet of info to fill out and return
to him. He finished filling out his part, and had it all with him when he came
to do the inspection. No pressure, very laid back guy.
Good luck,
Rusty
Subject: | Re: Panel Labels |
In the may 1998 Sport Aviation page 109 in the craftsman's corner there is a
tip on press on lettering. use clear shelf covering and cut 'windows'
around the lettering. then use a light coat of thinned polyurethane clear
varnish to protect the lettering......
-----Original Message-----
Date: Wednesday, August 19, 1998 9:41 PM
Subject: RE: Kolb-List: Panel Labels
>Could you use some of the rub on letters available at some office supply
>stores? Place I once worked used to do some custom development and used
the
>rub-on letters to spell out switch functions. As long as care was taken to
>spell correctly and keep the letters aligned, it worked pretty well
>(especially when we put on a clear coat of paint/sealer to protect the
>letters from scrapes). Advantages of the method were that different size
>and colors letters were available and letter placement could be adjusted as
>needed.
>> From: owner-kolb-list-server(at)matronics.com
>> [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Larry Bourne
>> Sent: Wednesday, August 19, 1998 12:09 PM
>> To: kolb-list(at)matronics.com
>> Subject: Re: Kolb-List: Panel Labels
>> Yeah, at work ( Ritz-Carlton, Rancho Mirage, CA.) we have the fancy,
>> computerized plaque and badge maker such as you describe, and it does a
>> beautiful job. Unfortunately, I had the panel built, gauges and switches
>> installed before I found out about the labelling requirement. So now I
>> have a need for some small, odd shaped labels. Just don't know if it's
>> feasible on that machine, but it might be worth a try..... See also my
>> response to Ron, bearing in mind "computerized." Thanks for the
>> thought.
>> Big Lar.
>Some cut.
Subject: | Re: Fabric covering material |
39-40,44-47,49,51-53,56-60,63-66,68-69,74-75,77-88
Ron, I will answer your questions "IN CAPS" below:
writes:
>This was originally directed to Ralph Burlingame, but John Jung and
>others with an Original Firestar are also included.
>Ralph, I have a little question that I figure you are the most
>experienced person to ask. As you recall, I also have an older model
Original
>Firestar (1985, kit #015), with all the original building materials,
including
>the cloth to cover it with. I know it is *not* genuine Stits because
it
>doesn't have the Stits stencil every 36" on it. Obviously it is a
>*generic* material, which worked well in the covering and painting
processes.
>My question to you is this: Have you had any problems with the
>fabric being somewhat fragile? By that I mean do you have any problem
with
>the material ripping or tearing? Twice now I have had the material
>actually rip. Yesterday I was putting in a fuel line and ran it through
an
>opening in the material behind the seat. I changed my mind and pulled
it back
>out, and as I did it sort of hung up and the material ripped about 3".
I
>was surprised, and now can't help but wonder if every time something
>either bumps it I will wind up with a tear. I don't like the thought of
>having a small unknown hole in the wing catch the winds during flight
and
>have it open up into a BIG hole causing unknown damage to me and the
plane.
MY FABRIC (STITS) IS 11 YEARS OLD NOW AND I FLY YEAR 'ROUND. AS YOU CAN
GUESS, IT GETS COLD HERE IN MINNESOTA AND I HAVE NOT NOTICED ANY UNUSUAL
TEARS DURING NORMAL USE. THE ONLY TEARS I GET ARE DUE TO KIDS THROWING
THINGS INTO THE GARAGE WHERE THE PLANE IS STORED.
>I was surprised to find that I am unable to reach the instrument panel
>while seated at the controls. If I panel mount my Delcom 960, as I
>originally planned, I won't be able to adjust the frequency or volume,
adjust
>the altimeter, change screens on the GPS. Do you have this problem
also,
>or did you do something to overcome it?
THE ONLY INSTRUMENT I ADJUST IS THE ALTIMETER WHICH IS ADJUSTED BEFORE I
BUCKLE UP. MY GPS RESTS ON MY LEG WITH A LEG STRAP WHICH IS PERFECT FOR
VIEWING AND PUSHING BUTTONS.
>Also, I'm afraid I made my rudder control cables a bit too long
>because can barely reach the pedals while seated.
I HAVE HEARD OF BUILDERS PUTTING IN TURNBUCKLES IN THE RUDDER CABLES FOR
LENGTH ADJUSTMENT. I ADJUSTED MINE SO THE PEDALS ARE ABOUT 90 DEG TO THE
BOTTOM OF THE CAGE. IT'S JUST RIGHT FOR ME AND I'M 5' 10"
>BTW, did you put some sort of stop on the rudder travel?
NO I DON'T HAVE ANY STOPS IN THE RUDDER PEDALS, BUT IT MAY BE A GOOD IDEA
BECAUSE I SEE ELEVATOR ARC-MARKS ON THE RUDDER.
>I couldn't find anything in the plans so I put in a couple of short
1/16'" cables >attached to the horn that operates the tailwheel. The
cables are only about a >foot long and go forward and attach to the
bottom of the small vertical fin at >the bottom of the boom tube. Works
ok.
MY PLANS SHOW THOSE 1/16" CABLES THAT ARE ATTACHED BETWEEN THE RUDDER
HORN AND THE TAILWHEEL ARM.
>I'll send this to the list just in case someone else can offer some
>suggestions.
>Thanks,
>Ron Carroll
>Original Firestar
RALPH BURLINGAME
ORIGINAL FIRESTAR 400+ HRS
Subject: | Re: Loose strut pins |
George,
Do you land on a rough field? I'm thinking this may be inducing the
extra stress that would wear the strut holes more.
Ralph Burlingame
Original FireStar 400+ hrs
><< John,
> Did you ever notice this on your Original FireStar? Believe it or
>not, I'm using the same lift pins that came with the kit 12 years ago.
I
> inspect them and they still look good. I have replaced the main
>clevis pins, but I don't think I needed to do that either. There is
very
>little slop in those holes. This tells me a lot about the load on the
pins.
>If you are seeing that kind of wear, then it appears there might be more
>of load factor in the FS II than on the Original FS. What do you think?
> Ralph Burlingame
> Original FireStar >>
>Ralph/ John ....I have the problem John described on my Firestar KX
>(1992), namely that the strut holes only at the fuselage end of the lift
>struts are elongating, and it is getting worse each year. I don't
think it is
>too bad yet but, I suppose more beefiness such as John hauck described
or a
>small harder bushing would be the answer. How bout you, Dennis, has this
one
>ever come up to you before?....................GeoR38
Subject: | Re: RV-List: Pitot/Static/Transponder certification |
Rats! Sorry, wrong list.
Rusty
I have read about Kolbers gear bending and felt that because I used 3/32 cable
bracing from the axle to the gear socket it would not happen to me, boy was I
wrong. Returning from a cross country I killed the engine at 4k and coasted
the last couple of miles (Old glider habits die hard even with a Firestar Rock
) Luckily I lined up for the field because I waited too late to restart
successfully and arrived on the runway dead stick, a tad slow and on one
wheel. Stretched the wire till half the strands failed and put a real pretty
bend in the leg.
Dick C. St.Louis
Subject: | Re: Landing Gear |
<< I have read about Kolbers gear bending and felt that because I used 3/32
cable
Rock
bend in the leg.
Dick C. St.Louis >>
Bless your soaring heart, Dick, I am the Ol Glider pilot and I know the
passion you have, to cut the engine, ....I used to do it all the time on my
Pterodactyl, but haven't had the guts to do it much on the Kolb. I learned in
New Mexico in Schweitzers and became "comfortable" in the 233 and 126 "oil
can" in '78-80. Was going to take it up here in Ohio when I returned in '80
but everyone I was going to meet to get me started in this area.........got
Killed (killed themselves) ......................a week before I was supposed
to meet them...........................3 times....................3 years in a
row!!!
Well the # 3 has always been significant to me, so I decided that the 4 people
had given up their lives for a purpose directly related to
me..................................so I decided I would get into some
aviation activity that I felt was ............"safe"!! Namely
....................ultralighting!
I still soar with the gaggle whenever I hit a bump and have been successful
staying in the thermal only 3 times here in Ohio....................they are
so few here, .....I actually look for bonfire smoke to fly
through............just to remind me of the thermal "highs" of the far west
where 1000 Ft /min isn't uncommon. I definitely miss that!
GeoR38
Subject: | instrument panel |
From: | bobdoebler(at)JUNO.COM (Robert L Doebler) |
Ron
My instrument was to far away to reach also. So I made an aluminum, one
6" closer.
I positioned a piece of plywood 6" away from, and parallel to the old
panel. Than I laid a yard stick along the side of the nose cone and
marked where it touched the plywood. This gave me the outline of the
panel. (It also gives you a bigger instrument panel). The inside is
pretty much the same as original, but slightly higher for knee clearance.
The new panel I temporarily clamped in place. Put windshield back on and
marked where new instrument panel touched it. This now gave me a templet
for cutting out an aluminum spacer from nose cone to panel. This sheet
aluminum now looks kind of like a large "C". The spacer and panel where
riveted together with counter sunk rivets and .5" X .5" X 1/16" aluminum
angle.
Both the spacer and windshield are now bolted back into the original
mounting holes on the nose cone.
I can now reach instruments easily. I fly in class D airspace and this is
necessary.
Hope this helps.
Bob Doebler
>This was originally directed to Ralph Burlingame, but John Jung and others
>Ralph, I have a little question that I figure you are the most experienced
>person to ask. As you recall, I also have an older model Original Firestar
>(1985, kit #015), with all the original building materials, including the
>cloth to cover it with. I know it is *not* genuine Stits because it
>doesn't have the Stits stencil every 36" on it. Obviously it is a *generic*
>material, which worked well in the covering and painting processes.
>My question to you is this: Have you had any problems with the fabric
>being somewhat fragile? By that I mean do you have any problem with the
>material ripping or tearing? Twice now I have had the material actually
>rip. Yesterday I was putting in a fuel line and ran it through an opening
>in the material behind the seat. I changed my mind and pulled it back out,
>and as I did it sort of hung up and the material ripped about 3". I was
>surprised, and now can't help but wonder if every time something either
>bumps it I will wind up with a tear. I don't like the thought of having a
>small unknown hole in the wing catch the winds during flight and have it
>open up into a BIG hole causing unknown damage to me and the plane.
Ron Carroll,
I know you received several responses to your question about fabric tears. I
believe the advice you received was given too hastily. If your fabric was
not stored in sunlight, and it is the fabric supplied by Kolb with the kit,
it is most likely OK. The raw fabric before it is coated with polybrush,
polytac, or paint, is difficult to rip or tear. But once it is coated with
these products and then receives a clean cut like from a razor blade, the
cut will seem to tear much easier. It is important to properly patch small
tears, and reinforce areas where holes in the fabric need to be used. If you
have any doubt about the integrity of your fabric do a punch test. But even
new fabric can be ripped fairly easily under the right conditions.
Sincerely,
Eugene Zimmerman
PS flying Kolbs since 1982
From: | "Ron Carroll " <ron.carroll(at)WORLDNET.ATT.NET> |
Eugene, I am delighted to hear someone reply sensibly to this question.
You reply agrees totally with my feelings, as well as my local EAA Tech
Advisor.
It is the original fabric furnished with the Kolb kit in 1985, and has been
stored in a black plastic bag since that time. From what I understand,
this material will last almost indefinitely, even outdoors, if properly
finished with Poly-"Stuff". I now have 2-coats of Poly-Brush, 3-coats of
Poly-Spray, and 3-coats of Poly-Tone. I expect the fabric to last longer
than I will, since I'm 66-years old. Its just that the finish seems VERY
fragile when touched by almost anything. A slight bump will leave a ding in
the finish. My tech-advisor says that the paint has to gas-off for quite
some time before it will get tougher. I hope so.
Thanks for your help,
Ron Carroll
Original Firestar
Independence, Oregon
Date: Friday August 21 1998 11:06 AM
Subject: Re: Kolb-List: Fabric covering material
others
Firestar
*generic*
out,
it
>Ron Carroll,
I
you
>Sincerely,
>Eugene Zimmerman
Yikes - shutting down an engine in flight.
I don't fly with a Rotax (don't have a Kolb yet, I'm part of this list
doing research and deciding) but I do have a Cessna 150 and I know I'd have
a potential problem with shock cooling the engine if I did something like
what you described.
I don't know if the Rotax engine would have a similar problem or not but at
first glance I'd think there's got to be something unhealthy happening to
the engine if you stop and start it in mid-flight. If the big fan up front
stops spinning (or back there in the Kolbs) I start sweating.
Brian
Rock) Luckily I lined up for the field because I waited too late to
restart
pretty
bend in the leg.
Dick C. St.Louis >>
Subject: | Re: : Kolb-List: |
RAY
The only m/3 that I know about that is up your way is around the new
orleans way
I think that CLIFF STRIPLING may have the guy's name and ph. #
I do know that cliff went up to OK. city or close to it , you are
doing the right thing try one on for size before you get in your a/c
hope that this is at least some help I will keep looking
RICK LIBERSAT
>Rick, Find me a Mark III within 100/125 miles of Gainesville, FL that
>I can get
>an hours instruction in or at least a ride. I am not looking for a
>free
>bee. I expect to render suitable remuneration.
>I have 2 things left on my check list before putting pen to check: 1.
> Take a flight in a Mark III. It seems like the intelligent thing to
>do before making such an investment. (I have been taking
>refresher/transition training in a Drifter at Herlong Airport near
>Jacksonville, FL) 2. Take a trip to the Kolb factory in
>Phoenixville. I want to take another look at the assembled kit now
>that I am serious. I have been
>kicking the tires etc for the last 3 years at Fun & Sun, but at the
>time
>not really expecting to participate..
>That will teach you to offer assistance!
>have
>like
>what you described.....
Actually, in an UL or light experimental, it can be great fun and good
practice - IMHO. You're right to be concerned about 'shock-cooling' tho.
I don't know about the others but I slowly pull back to idle for at least
a couple minutes before killing the ignition.
Call me chicken but I prefer to do my dead-sticks in the evening after
all the thermals have died out. There's a few million acres of bean
fields along the Verdigris river just a few miles from where I keep the
Flyer. It's perfect for this stuff, miles of beans (or wheat, or spinach,
whatever's in season..) with long, straight, deserted dirt roads through
them. From 3000 or 4000' agl, I can glide for 10 minutes or so with just
the wind whistling through the structure. All the engine noise and
vibration is gone - I love it! I pull my helmet off, take out my
ear-plugs and just enjoy ('course I put the helmet back on before
landing..). The Flyer is not much of a glider but I think I understand
what the attraction is now.
Don't know where that fits into your 'research' but maybe you can find a
place!
-Mick Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
A:
I know I'd have a potential problem with shock cooling the engine if I did
something like what you described.
I womder? For years I raced Enduro bikes and it was not unusual to
have those 250cc 2-strokes screaming in first or second gear in deep mud,
and then stall them in a creek, and unless you got mud into the insides, it
never seemed to hurt them.
Richard Pike
MKIII N420P (42oldpoops)
Brian,
There is nothing to fear about shutting the engine off in flight so long
as it's done properly. By this I mean throttling back slowly to idle and
let it run at idle for a few seconds prior to shutting down. Try it once
on final when you know that you have the runway made (please use good
judgement and at least a 2500' runway). With a little practice you will
be shutting it off in the downwind. It's really alot of fun.
Ralph Burlingame
>have
>like
>what you described.
>but at
>to
>front
>Brian
>Firestar
>restart
>one
>real
>pretty
> bend in the leg.
> Dick C. St.Louis >>
>the finish.
Are you sure you tightened the fabric enough?
Woody
Some men are able to stumble over the truth but are able to pick
themselves up and keep walking as if nothing had happened. (Churchill)
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Hi Richard: It's my understanding that shock cooling is a result of
the different expansion and contraction characteristics of various parts of
the engine under rapid cooling and heating, especially air cooled engines,
and more pronounced with increasing engine size. The big 540 + 550 CID
Lycoming + Continentals are known for it. Water cooled engines operate in
a comparatively stable environment by comparison. I believe that rapidly
cutting the power on a hot engine will cause the rapidly cooling cylinder
to shrink around the still hot piston. Conversley, socking the power to a
cool engine, as in a touch + go landing, will cause a rapidly heating
piston to expand inside a still cool cylinder, and seize it. One of the
main reasons the Subaru engine is becoming so popular is that by virtue of
being water cooled, it is comparatively immune to this. Can anyone
critique me on this ?? I think I'm pretty close. Big Lar.
> From: Richard Pike <rpike(at)preferred.com>
> Subject: Re: Kolb-List: Landing Gear
> Date: Friday, August 21, 1998 8:06 PM
> A:
did
Are you tired about being asked about the wing spar failure on the RV8 yet?
A bud of mine here who builds for a living and has several Grank Champions has
quit building a customers RV8 cause of the problem. The plane is sure nice
however.
Just been reading your stuff for a while.
I talked to Dennis at Oshkosh and they decided thet the 582 is perfect for the
SLingshot, I built the Firestar 2 cause of the cost of the 912 for the
Slingshot and now that it's not the preferred engine I wish I had the
Slingshot.
Just rambling.
Tim in Shreveport Louisiana Firestar 2 N6246L.
Amen.
In Louisiana here I am in a sailplane club with a 222 and a 126. I have had 3-
3 hour flights in the 126 and boy is it neat. I have only done 3 total deal
sticks in my Firestar 2, better put the nose down and land close. I have only
done it above the grass strip and have not done it more cause it's a hassle to
get out to re start.
Just thought your comment was interesting so I would reply.
tim
Amen.
tim
Ron, the fabric that was included with your kit was 1.6oz D104 dacron
which is very light and is the same stuff I have on mine. This fabric has
60lbs/in strength (I checked the Stits manual). I think the fabric they
are using on the new FireStars has a strength of 96lbs/in which is the
2.6oz type. Our fabric is good enough for the Original FireStar, I have
proven that with over 11 years of service, but you may want to do a
puncture test as suggested by the group. There have been occasions where
the tailbracing cable was looped around the upper tang of the fin and
when I folded the tail and left it for a week, it dimpled the fabric on
the stabilizer. That dimple was gone by the end of the flying day, so
it's not a problem. I have ripped out the bottom once when I tried
lifting it up onto a sawhorse. Other than that, I have to say the fabric
is holding up very well.
I can't fly because it's going to rain all day. It's been a good summer
for flying, though. I have flown just about every weekend since June.
Maybe I'll get a chance tomorrow.
Ralph Burlingame
writes:
>question. You reply agrees totally with my feelings, as well as my local
EAA
>Tech Advisor.
>been stored in a black plastic bag since that time. From what I
>understand, this material will last almost indefinitely, even outdoors,
if
>properly finished with Poly-"Stuff". I now have 2-coats of Poly-Brush,
>3-coats of Poly-Spray, and 3-coats of Poly-Tone. I expect the fabric to
last
>longer than I will, since I'm 66-years old. Its just that the finish
seems
>VERY fragile when touched by almost anything. A slight bump will leave
a
>ding in the finish. My tech-advisor says that the paint has to gas-off
for
>quite some time before it will get tougher. I hope so.
>Ron Carroll
>Original Firestar
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
Subject: | Re: Landing Gear/shutting it off |
... clip
Shock cooling is something to account for. Simply run at lower rpms to
go to lower temps before hitting the kill switch. I think my engine is
tighter after shutting it down in flight. I can restart it if I pull
right away, but wait over 20 seconds and even a big hard pull is tough to
get a fast enf pull for start. BTW, i figure "tighter" is quite a bit
different than "siezed". I've looked at my cylinders, etc and they're
still new.
Killing the engine is also something to account for, but not at all a
'yikes' situation, necessarily. In GA we get conditioned into thinking
the engine is always supposed to be making noise. No engine means a
declared emergency, messy pants, etc, etc.
In ULs we go by 'not if but when' it will quit, and therefore, many ULers
have practiced actual engine outs. Like all other learned things in
aviation, it is safe if done in baby steps. Part of the diff with
GA is also that ULs landing out on dirt roads, etc with or without
engine running is more publicly acceptable than a C-150 doing the same.
I'll admit I wouldn't be comfy killing my engine intentionally without
being in easy gliding distance of a usable field. My experience in
difficulty getting a mid-air restart tells me to forget about the engine
and focus on flying the airplane -- er, glider -- if(when) it ever
quits unexpectedly.
I guess the motor-glider guys new all this in the first place.
Ben Ransom
http://mae.ucdavis.edu/~ransom
Hi Rick,
Thanks for your response. A kolb-lister from Ocala, FL (65 miles) has
offered to take me up in his Mark II, which should serve my purpose. All
that remains is to coordinate a date and time. Florida weather being
what it is at this time of the year it may take us a while. Meantime, I
continue to terrorise a FI in his Drifter!
Ray
From: | "Larry & Karen Cottrel" <lcottrel(at)kfalls.net> |
Subject: | removing gap seal |
One of the things that I hate to do when taking my firestar down for
storing is the gap seal between the wings. I have a clear lexan piece that
is velcroed down to the wings. There is also a alum. piece that is bent to
fit the leading edge of the wing and then a bungie cord to make sure it
stays in place and not peel back over the engine. I suspect that it is
pretty standard. Anyway it has always been a pain to take off. There are
grooves and indentions for things like the pull starter and other cables.
The only easy way has been to get a step ladder to get me high enough so
that I can keep it from resticking,( too much trouble) or go to the back
and turn the prop to the verticle and grab the ends on both sides and lift
and pull. I'm of course not real happy about that, because sooner or later
I am going to have to reglue the velcro. This morning after a flight and
coming up on that unpleasant chore it occurred to me that a piece of the
paper towels that I use to clean after a flight could be placed between the
velcro pieces and would make it easy to take off. DUH!!!! Just in case
There are others who are also a little slow- here it is.
Larry
Ben Ransom where have you been man? Out of the country?
Ralph
writes:
>... clip
>but at
>happening to
>front
>to
>is
>to
>still new.
>thinking
>ULers
>same.
>engine
>quits unexpectedly.
> Ben Ransom
In a message dated 8/21/98 11:12:23 PM, larrybiglar(at)earthlink.net wrote:
Water cooling does not guarantee freedom from seizures, it just creates a
different set of circumstances to watch out for. The Rotax 582, for reasons
I cannot fathom, is not shipped from the factory with a thermostat. If you
pull the power on a long glide to final and let the water in the radiator cool
off, then open the throttle suddenly to go around you risk a seizure mode
where the cold water from the radiator rushes into the head and cools, (read
shrinks) the cylinder, just at the time the piston is expanding from the full
power load.
Subject: | 2nd time up and how to move about |
Hi all
On my second day of Flying the Firestar I had tremendous success. Some
time with a BFI to get used to 3 axis made all the difference.
Has anyone come up with a good way of getting a hold on the folded plane
to push/pull it around?
I am having a diffucult time figuring out a convient and safe for the
plane method. It just does'nt seem right to grab a hold of the wing tips.
Adam Violett asviolett(at)juno.com
Sec, Treas, Newsletter - K.C. Flyers USUA #81
about 3 hrs. now, Original Firestar
___|___
_________0_________
0----0
Blue Skies & Happy Landings! Adam
I need some advice from any experts we may have on antenna/radio wave
propagation/ signal radiation etc.. I'm going to peel the braided shielding
from about the last 23" of a piece of RG-58U co-ax and try to use it for an
antenna. I plan to thread it through some lexan clips epoxied (sp?) to the
interior of my FireFly Nose cone. The braid that I peel of will be connected
to a ground plane or used as a di-pole. Comments, suggestions appreciated...
Duane Mitchell
Subject: | Re: 2nd time up and how to move about |
Wing tips are it....unless you build a tailwheel dolly.
One of the things you should be doing is bracing the wing root
leading edge tubes with a cross piece.....a section of pvc pipe with
two spaced holes for the tubes works nicely. Prevents a torsional
load from being applied to the rear fuselage wing support tube.
J. Baker
I think a better way would be to put a small gnd plane forward of pedals
and install at BNC jack in it, pointing out or at an angle as great as
90 degrees to the ground straight down as possible. Then make a 23" or
so "whip" out of stiff. hard copper wire and solder it into a BNC plug.
Secure it with epoxy in plug. Can be taken off/replaced easily.Inside,
run RG from ant jack to radio. This is what I plan to do when I get time
from retirement duty!
Epoxying ant flat to nose cone, especially with the dielectric still on
coax may upset the impedance of the antenna. If you had asked me 50
years ago, I could have given a bettermaybe more accurate answer.
EE'49 Grey Baron. Open to better answers.
Grey Baron
In a message dated 8/22/98 8:53:43 PM, you wrote:
<< I am having a diffucult time figuring out a convient and safe for the
Give dennis a call. I had a real problem moving my folded mark three around.
I was afraid I would either scrape the fabric on the leading edge or put a
hole in the fabric on the wing tip. I made a crude sketch of a fork like
thing to stick in the back of the fuse tube and then carry it around by that.
Dennis and Mike, (a thousand thanks to both) considerably improved on my idea
and welded one up for me. IT WORKS GREAT. Call them up maybe you can talk
them into selling you one. The important thing it that it is a real help in
moving a folded plane safely. And it is MUCH easier.
Since you have already built your wings it is a bit more difficult to get
a built in system.What you can still do is uncover the ends of the trailing
edge tubes. When you have the wings folded slip a 1" dia x 2' tube into
these exposed holes and you have a couple nice handles for moving things around.
Woody
I agree with this approach, got for the bulkhead connector that the RG
attaches to that way you have one less connector.
One "trick" I learned a long time ago (not as long ago as Bob, me EE
was 85) is to use a stainless whip cut to proper length to give you a
matched antenna (I assume you are going for a 1/4 wave Mraconi antenna
over a ground plane). Then the trick is to use a diameter of whip the
same size (or larger) than the little pin that forms the "male" part of
the BNC connector. now what you do is throw out that little pin and
turn down (if you used a larger diameter wire or if the same you can
leave it) to the diameter the pin would have been. Now put the
connector together and you have no solder joint or change in diameter to
introduce problems down the road (or reflections for those that are real
picky). I use this trick for my Ham antennas on the car, but up here we
have salt to give us grief all winter.
Adrio
> Grey Baron
writes:
>Hi all
>plane to push/pull it around?
>tips.
Adam
I use a snall 8" triangluar dolly. it has a swivle caster on each point,
and is indented in the center, of which I put the tail wheel in. This
works for hard surfaces. Got it at a hardware store, where
castors/wheels/ and dollies were sold.
For grass surfaces, a guy at our field made a tow bar out of 2 wheels,a
handle and to pieces of angle iron, that come up when pivoted an hook on
to the tailwheel bracket.
Bob D
My gap seal is made with laxan and aluminum leading edge also. I tried
using velcro also, but wasn't satisfied with it either. My fix was to use
a camlock on either side of the leading edge and the gap seal, this holds
the gap seal in position. At the back of the gap seal, I have a piece of
lexan set vertically.This holds it tight to the wing. It is attached at
the top by riveting the lexan together with aluminum angle and aluminum
rivets. The bottom with angle and cam locks. So with a half twist on 4
cam locks, the gap seal pops right off. But can't come off in flight.
Hopes this gives you some ideas.
Bob D
Subject: | Re: removing gap seal |
I just tolerate this as a minor hassle. I've gotten into the habit of
stepping up on the tire, then side cockpit tube to reach back over top of
wing at the engine area. Works fine. I place a rag on the side cockpit
tube to protect its finish. BTW, I've sat up there (facing backward)
with engine at idle to dink around with idle mixture. Not bad ...hmmm, I
wonder how this would be as a flying seat?
Ben Ransom
Subject: | moving fs2 folded |
Adam
I made atow bar that is spring loaded and fits into both
sides of tailwheel cross tube where S hooks go in 1/4
bolts willslid past hooks I can push,pukl,turn the folded
plane.
Duane Zollinger
fs2 75rhs
Yeah, Andrio, the replacing of the original BNC pin is great, but gotta
turn it down=lathe work. I don't have a metal-turning lathe, and have
trouble going to local machine shop that turns BIG stuff and asking for
that teeny work. My suggestion of "back-filling the original cable end
with epoxy fixes the salt-intrusion problem as well making ant very
strong. If it busts, just whip out another. And I'm mindful of impedance
"lumps," also. And what are you doing for CD hash problem? 73s K4JMG aka
Grey Baron aka Bob N.
Hi Adam,
We took an old broomstick about 4 ft. long and drilled a hole to insert
a bolt of
appropriate length and size to fit in the tail wheel housing. We can
guide and push
very effectively. Hope this helps.
Herb
writes:
>Hi all
>tips.
> ___|___
>_________0_________
I would be interested in knowing what this thing looks like. Jeff in
Oviedo.
> From: Cavuontop(at)aol.com
> Subject: Re: Re: Kolb-List: 2nd time up and how to move about
> Date: Saturday, August 22, 1998 9:27 PM
tips.
around.
a
that.
idea
talk
in
From: | Christopher John Armstrong <tophera(at)centuryinter.net> |
HI everybody
My plans for my gap seal are to make it a permanent part of the fuselag
and have it just touch the wings in the flying position with rubber
sealing material. In theory I will be able to fold the wings without
removing the gasp seal at all. the wings will drop down and out, away
from the rubber gasket. If I ever get to that stage I will let you all
know how it works.
I got a job doing CAD drawings for the powersport rotary engine, since
they just moved to Osceola WI, My town, and are setting up for
production, so not much time to work on the plane, but real fun job!
Topher
From: | Erich Weaver 805-683-0200 <sbaew(at)dames.com> |
Subject: | have a Mark III for sale? |
Autoforwarded: false
UA-content-id: 11C8BBB01100
Hop-count: 1
I am looking to buy a Mark III and accompanying trailer. If you have both
or either and are interested, please call or e-mail. If you are near the
the southern california area, thats a plus, but I am willing to travel
for a decent deal.
Erich Weaver
805-683-3337 hm
805-683-0228 wk
sbaew(at)dames.com
leoniron(at)aol.com
Hi Chrisliked your gap seal idea and am looking forward to see it.
Have FireFly
I had three NSU Wankel cars, single rotor, built in '62. Still have the
two rotor RO-80 with two rotors. Fine engine in principle, but early
ones stunk! Grey Baron
Subject: | It mocks me- R&D pipe |
Hello again,
Well, I went to the airport today armed with a pair of 162 jets, and my old
Rotax muffler. The plan was to look at the plugs and see if they really did
look like the engine was running lean. If so, install the larger jets, if not,
re-install the old Rotax muffler. Well, by golly they were almost white, and
I'm probably lucky I (I mean the engine) didn't have a seizure on my last hops
around the pattern.
I proceeded to install the new jets, waited for it to stop raining, then pushed
the plane out and tied it up. With clearing weather, calm winds, and a renewed
hope for extra power, I gave the starter a mighty yank. The rope broke
Russell Duffy
Navarre, FL
Kolb SlingShot N8754K (for sale- bring rope)
RV-8, 80587 (wing skins)
rad(at)pen.net
Hey Gang:
I use an ELT antenna for my VHF. They cost about $25.00, are much lighter
than standard SS aviation VHF whips, and much cheaper.
I have never had a complaint about my ability to xmit, and I receive well,
as well as my infantry, special forces, helicopter pilot ears allow me to.
They come with a bnc connector already attached. Mine has seen more than
1200 hrs and 6 years of hard use with no problem.
They are cut 23-24 inches and tuned for 121.5, so that is close enough for
me since that is the area of the freq band I operate around.
PS: I have about recuperated from my flight to, at, and from OSH. Stayed
busy this year at OSH, only made one trip to the main area, that was
enough. Glad I got to meet a bunch of you guys while I was there, now I
can put faces with emails.
Subject: | Loose pins--Easy fix |
Hi Guys,
Been reading about the loose fitting strut pins. I also took care in drilling
the holes, knowing that it is easy to have a hole get enlarged, especially
using a hand drill. At first the pins seemed to fit really good. Not tight
mind you, but with very little play. But after about 20 flights, they did
become a little looser.
I wanted to tighten it up just a little more and discovered that there are AN
bolts called CLOSE TOLERANCE. I got a few of these, cut off the threaded ends
and chamfered them a little to facilitate getting them into the holes, then
drilled holes for the safety pins. These bolts are just a bit tighter
fitting, in fact on two of them I could hardly get them in, but after a few
times they fit OK. This has effectively eliminated most of the play and it
hasn't gotten any worse since. I fold my wings for storage after every flight
and I just counted up the flights in my log book which now totals 210.
So there is an easy fix, if the loose play isn't too much.
Bill Varnes
Original FireStar 377 @ 280 hrs.
Audubon, NJ
Will the full width permanent gap seal make installing the wing pins
difficult?
Dick C
Subject: | Life with Rotax (sorta long) |
Hi all: Don't know if y'all remember it or not but a while back I wrote about
a problem I was having with my 447. From cruise rpm (56-5800) the engine would
start to loose power and the egt would head toward 1200. Pull back on the
power, let things settle down and the engine would run fine for a while then
do the same thing. First I inspected the entire fuel system. Replaced fuel
filter, primer bulb, rebuilt fuel pump, rebuilt carb, replaced pulse line to
fuel pump. All of this to no avail. Bought and installed a new carb. The old
one came with my original 377 and had plenty of hours on it. Worked great for
an hour then started doing the same thing again. If it ain't in the fuel
system, then the engine must be sucking air. The engine had 260 hrs. on it so
I sent it to Greensky hoping they would find bad crankshaft seals or leaking
case halves. The engine checked out fine. The crank seals looked like they
were getting old and they found one place where the case halves might have
been leaking. Put engine back on the airframe, flew for about 15 min. and it
did the same damn thing! I'd run out of things to do. I was down to the
exhaust and the CDI box. To hell with it, I went to OSH. Came back and, of
course, the engine still didn't work. While at OSK, for lack of anyother idea,
I'd bought a new fuel pump (although I'd rebuilt the old one). So, before
starting to fool with the CDI and muffler, I tried the new fuel pump. IT
WORKED FINE and has been working fine for the four hours.
Moral of the story: I ain't rebuilding no more fuel pumps!!! For $20 or so
dollars I'm going to just buy a new one every year or two. Everything about
the old fuel pump looks good. It just don't work.
This "learning experience" has cost me around $600. But my engine/fuel system
has had a complete overhaul. There's not many things major that I could do to
my A-65 for $600. So I keep telling myself that's it all relative.
Spend that $$$$ and keep flying!!
Bill Griffin
Glad to have my Kolb flying again
Subject: | Fwd: Life with Rotax (sorta long) |
Subject: Life with Rotax (sorta long)
Date: Sun, 23 Aug 1998 23:39:47 EDT
Bill Griffin
You are perfectly correct. Saturday morning I had to make a rapid
descent from 5000' to get below traffic while descending into my strip.
(There is a NASCAR race at Bristol that night, and the Kingairs and Learjets
were flocking in, TRI approach was BUSY, glad I was off). The water temp
never got below 140.
You are correct about a rapidly cooling cylinder shrinking around a
hot piston, however, if you kill the engine completely, and the piston isn't
moving, what will it hurt? Unless there is some reason that it would warp or
distort, why would it hurt it? Comments, anybody?
Once you land, you need to crank it back up and reheat it before you
can take off, I used to practice deadsticks in my Hummer, Rotax 277, and it
took a bit before it was ready for takeoff power.
Richard Pike
Ron
#1:My gap seal is 19.5" wide, roughly .75" overlap onto wing on both
sides.
#2:Aluminum is on leading edge only(over leading edge tube). From the
back bottom edge of aluminum to the front of the curve is 2.25".The rest
is on top of airfoil. The 2 cam-locs are 3" from the edge.
#3: The lexan does not wrap around leading edge. It overlaps aluminum by
1". I should say it goes under the aluminum and is riveted in place with
aluminum rivets every 2".
#4: the bottom piece of lexan extends back from aluminum 11". On the back
of this lexan I have a .75"X.75" X.0625" aluminum angle 14.5" long,
centered approx. 2.5" from both sides. Thru this goes the other 2
cam-locs.
#5:The top piece of lexan extends back 16"(don't forget you need 1 more
inch for overlap) At 12" back from aluminum you have the piece that comes
down and attaches the gap seal top & bottom together. This piece of lexan
is 14.5" long by 7 " high.It is mounted approx. 2.5" from the side of the
top lexan. Using another piece of 14.5" aluminum angle, rivet top of gap
seal and this vertical piece to together. At the bottom of this vertical
piece of lexan, rivet another aluminum angle. This is what the bottom
cam-locs will lock to.
#6: Looking at the gap-seal from the side, it should look like the
airfoil of your wing . With the top portion extending back another 4"
further than the bottom. This is configured for my FS II with my BRS top
side. You may want to do yours differently. But this works for me. If
this isn't clear, give me a call.
Bob Doebler
818-348-7075
Subject: | Some annoyances about the Firestar, and a crash |
Hi, This is Glen Huffaker and I have been reading some of the messages
here for a couple months, I am sorry that my first post to the list will
be about a crash my father, Gene had just last Saturday at Garden Valley
Idaho.
We went with a ultralight club here in Boise, our first X-country with
the Kolb, In the preflight, my dad noticed that the header pipe for the
muffler was cracked slightly, (a 447 Rotax engine, only one joint on the
muffler) someone else looked at it, we thought it would hold, and the
pipe did not have to support anything. I herd that the muffler should
have two joints to reduce the stress and ours looked like it was broke
before and welded at the point where another joint should go. That
would be a simple fix that would have prevented a crash.
It started great, I was the ground crew, and arrived just as they were
touching down. My dad told me the muffler pipe broke clean in half, but
he did not have any problem landing, we knew we couldn't go any further
until we could patch it or fix it. We had some hose claps and wrapped
the pipe with a piece of metal can, it looked like it would hold. He
started it up and made a test run, while I went with someone else for a
loop in their two seater.
when he came around to land, he noticed the CHT was getting high, 1,800.
and he could not control the engine rpm, he landed with low power, right
before the runway in soft dirt, the dirt slowed him quick and the tail
came up, and the whole thing FLIPPED UPSIDE DOWN. I saw it from above,
what the heck, the CG is so far forward that landing on unpaved ground is
difficult if not impossible to keep the tail down. Luckily, he was not
hurt badly, but he'll have to wear a sling for two weeks because he
fractured his shoulder blade bone. The Firestar did well, it sustained
minimal damage to the stitz covering when pieces of the prop shot through
the aileron and wing, no real structural damage, it's built tough.
several people helped lift it up by the wings, and turn it right side up.
Can anyone shed some light on the forward CG problem of the firestar
even with a 150 lb. passenger? And why is it built so you can't land
the darn thing in the grass or soft dirt.
Subject: | Re: Loose pins--Easy fix |
Thanks for the idea. KISS, right ?? Big Lar.
> Subject: Kolb-List: Loose pins--Easy fix
> Date: Sunday, August 23, 1998 8:01 PM
> Hi Guys,
drilling
especially
tight
did
are AN
ends
Subject: | Re: It mocks me- R&D pipe |
Oh Man - - - - After all the suspense and anticipation. You're baaaad
!!! Take it easy with that mighty right next time. Where do you live that
it rains so much ?? Big Lar.
> From: Russell Duffy <rad(at)pen.net>
> To: Kolb list
> Subject: Kolb-List: It mocks me- R&D pipe
> Date: Sunday, August 23, 1998 5:54 PM
> Hello again,
old
did
if not,
and
hops
> around the pattern.
pushed
renewed
> Russell Duffy
> Navarre, FL
> rad(at)pen.net
Has anyone heard anything pro or con about the new ones that are supposed
to be coming available from Germany ?? Power to weight should be great.
That BD-5 outfit in San Diego has what looks like a really good rotary - a
real lightweight screamer, but they want over $10,000 for it. Ouch.
Big Lar
> From: bob n <ronoy(at)shentel.net>
> Subject: Re: Kolb-List: gap-seal
> Date: Sunday, August 23, 1998 5:35 PM
good story....good luck
From: | "Rutledge Fuller" <rut007(at)hotmail.com> |
On the subject of antennas. I am experiencing great reception and
antenna (Rubber Duckie Style) $9.95. Used a BNC adapter to plug the
antenna in. Unsurpassed performance thus far by the other three Kolbs
on the field (IMHO). Just a little engine noise at 6,000 rpm. I
mounted the antenna under the fibergalss nose cone. Dunane is looking
for an internal antenna for loading his craft on his trailer w/o
catching anything.
Rut Fuller 25.5 hours
Tallahassee, Florida
----Original Message Follows----
Date: Sun, 23 Aug 1998 21:00:58 -0500
Subject: Kolb-List: Antennas
Hey Gang:
lighter
well,
to.
than
for
Stayed
Hi Adam and List members.
I wanted to comment on the ground handling of a folded Firestar II.
I made a special T-bar to be able to handle the plane on the ground, and also
strap it on a trailer, with the tail wheel of the ground. This T is made from
squared material, the same as would be used for building an enclosed trailer. (not
sure of what you call this metal, but it is just a standard frame material. Sorry
I'm just a foreigner)
The T has two hooks welded on the T and made from solid bar. They hook around the
gear legs. I used a garden hose to protect the gear legs from the bear metal.
Then the T is laying on the ground under the unfolded aircraft, but hooked on the
gear legs. In front of the stabilizer, there is a pedestal support for the tail
boom, as subscribed in the Kolb plans. On the T just under the pedestal, I do have
two small wheels, to avoid the T from scraping the floor, if inside a hanger,
being rolled straight forward or back.
The T extends under the tail and under the tail wheel, approx. 6" back, where
there is a handle bar, so that you can grip the T and lift the tail up, and walk
with it, with the wings folded. By using the pedestal under the tail boom, you
do
have a better clearance from the ground, to insert the pins for the wing folding.
When folding the wings, I start with connecting the T bar to the landing gear
legs, lift the tail on the support, and then fold the wings. Works great.
The plan is to make a tow bar on two large wheels, where it will lift the T
approx. 3-4" from the ground, so that I do not have to lift it myself. The back
is still good, but I would like to keep it that way for as long as possible.
I hope this explanation of my T bar is clear enough so that you may get the
general idea.
If not, I could get a picture of it and send it to the list, or anyone who is
interested.
Best regards,
Johann G.
Iceland.
> Has anyone come up with a good way of getting a hold of the wing tips.
> Snip.
> ___|___
> _________0_________
> 0----0
From: | "Marino, Frank J (Youngstown ARB)" <Frank.Marino(at)yng.afres.af.mil> |
Russell: is it worth all the aggravation for a couple more horses
galloping in your engine. P.S. get a starter, it's easier. Just messin
with you
Frank
> From: Russell Duffy[SMTP:rad(at)pen.net]
> Sent: Sunday, August 23, 1998 8:54 PM
> To: Kolb list
> Hello again,
> my old
> really did
> jets, if not,
> white, and
> last hops
> around the pattern.
> then pushed
> a renewed
> broke
> Russell Duffy
> Navarre, FL
> rad(at)pen.net
Adam,
This summer, I did the same thing as Herb for my Firestar II. It is
heavier than the original Firestar. For my tow-bar I used a plastic
shovel handel and a length of 1.5" aluminum (for looks), and a bolt with
the head cut off. I use it to pull the plane backward into the hanger.
The only modification to the plane was to tap a tapered pin in the tail
where the S-hook attaches, to allow clearance for the bolt (now pin).
John Jung
> Hi Adam,
> a bolt of
> guide and push
> Herb
Subject: | Full Stalls Still Waiting |
I have been working hard trying to fully stall my newly built Original
Firestar 377. Power off I get burbles at 36 indicated and one wing
begins to drop. I can add oppisite aileron pressure and continue to add
back pressure until full aft at 26 indicated where the plane stays tail
low and simply decends. The same for power on stalls at 5800 rpm.
Burbles start at 32 indicated instead with a more destinct nose high,
tail low at 26 indicated full aft stick and aileron input. I am
currently waiting for another escort to continue tests. I like to have
a buddy in the air with me--security blanket, when I practice these
stalls.
I would like comments and suggestions as well as experiences from
others.
Rutledge Fuller 25.5 hrs.
Tallahassee, Fl.
Rusty,
It is good that you can see the humor in this and even better that
you share it. Thanks and I wish you "better" luck.
John Jung
>Russell Duffy wrote:
snip..
snip..
Subject: | Re: Some annoyances about the Firestar, and a crash |
Glen,
I can't explain what happened but I can shed light on the "nose over"
characteristics of the original Firestar and the Firestar II. As far as
I am concerned, neither plane has a problem. I have handed in the rough,
short of the runway, dragged the gear through soybeans, and hit my
brakes too hard. As long as there is airspeed and the stick is back,
Firestars resist tipping forward very well. If the tires hit some strong
resistance without the stick being back, then there could be a problem.
John Jung
snip...
"Sunny" Florida :-)
Rusty
From: | Stephen Murnyack <murnyack(at)csrlink.net> |
I don't know about anyone else but, I don't think the biggest problem
here had anything to do with forward CG.
Later...
Stephen
Wow Glen:
The decision making process your father used in deciding to fly his firestar
under the circumstances you describe was extraordinarily bad, and displays
many fundamental misuderstandings of how two stroke engines work. First, and
perhaps easiest, you don't fly airplanes with known serious engine problems.
The exhaust system of a two stroke is a critical part of the engine. It's not
like a four stroke where where the muffler just keeps the noise in. The back
pressure in a rotax is key to producing power and controlling temps. The egts
on my mark two went nuts once and I finally traced the problem to a hairline
crack on the muffler that only opened up at temperature.
In your favor I will say that the old style two piece muffler was
prone to all sorts of cracking and the Kolb design for hanging it had to be
executed just right to work well. The only forced landing I ever had in my
mark two resulted from a situation more or less like the one you describe.
The decision to attempt a field repair with sheet metal from a coke
can and some screw clamps was so unspeakably bad I'm amazed that the other
folks you were flying with didn't say something. If I recall correctly
aluminum, depending on the alloy, melts somewhere around 1000 degrees. You
might as well have wrapped your exhaust header with whole wheat bread.
I think everybody on the list tries hard to be polite and
constructive. Please forgive me if I sound like I'm coming down hard, but I'd
count your father real lucky.
Subject: | Re: Full Stalls Still Waiting |
Rutledge,
My suggestion is never use full (or any?) aileron at stall. You are
asking to enter a spin. I was taught to use the rudder to keep the wings
level near stall.
Also your description does not sound like either of the Firestars
that I have stalled. The power on is similar, except I only see a few
miles and hour between burble and stall. The nose only lowers, but not
even to level and it starts climbing again. On power off, the stall
occurs at the same speed, with little or no warning, and the nose drops
significantly. With engine off, there is no warning at all, a
significant drop of the nose. My planes have not had a tendancy to drop
a wing in or near stall.
Here is a guess: If you have a forward CG, you may not have enough up
elevator to get a full stall.
John Jung
> Firestar 377.
snip..
> others.
Hi all, I was looking thru the sept. kitplanes mag. at all the nice
kolbs and saw larry fuller,s plane and was wondering what the 2100D
engine is. thanks, steve ward mark-3
Rutledge,
level near stall.
I would like someone to ellaborate on this more. I am a little
confused.
This is a good point. In either case, I need to spend some more time
expolring the issue in flight. Keep the suggestions flowing.
Thanks.
Rut
Nice idea. I've contemplated it too. One of the hurdles in designing
this is for the downward angle of the wing when it is being unfolded.
When the wing tip is resting on the ground, the bottom of the root rib
is in closer to the fuselage than it would be in the normal wing position.
Maybe this simply requires a bigger piece of rubber for the seal.
Ben Ransom
From: | Charles Henry <chhenry(at)plains.nodak.edu> |
Adam
I just use a 3' length of a tiedown strap and hook the end on the tailwheel
then press on the end of the wing trailing edge tube when lifting the tail
to swing or roll the plane. I just pack the strap and the two 18" pins for
the wing fold fittings when I fly to another airport and there is a chance
it may need to be folded for overnight.
Charles Henry
Hankinson ND
FSI, 130 hrs
John, in reading your letter my attention was drawn to your remark "you may
not have enough up elevator to get a full stall."
Yesterday I finally got the plane somewhat together for the first time. We
started the engine and got into the Rotax break-in procedure. Of course the
high thrust line made the tail try to come up, so I pulled back on the
stick only to see that the elevator BARELY raised about the horizontal.
After the break-in I had my wife hold back on the stick while I pressed
down on the elevator. It EASILY pressed down to level! It was almost like
the cable is made of bungee material. I could not see anything that was
moving, shifting, or bending anywhere. The only thing I can imagine is that
the cables aren't tight enough, but I don't really know how tight to make
them. They seemed quite tight to me when installed. I have some adjustment
left in the turn-buckles, so I'll try that today.
The only other problems I had during the break-in were the engine seeming to
ever-rev. My digital tach read as high as 7400 rpm during the full throttle
portions. If the tach is correct then I will probably have to get a ground
adjustable prop to replace the wood prop (66X28) that came with the kit.
The other problem was the rpm was hard to maintain. It would drift around
and, making changes nearly impossible.
I hated to hear the talk this morning about the two-piece exhaust system on
the older planes. This sounds like the one I have. More problems in the
future?
The last thing I discovered yesterday was that I don't fit in the cockpit.
I've never had everything together before, so didn't realize just how small
the cockpit really is. I'm not tall, just 5'10", but my head, without a
helmet on, sticks into the lower part of the wing (where the gap seal will
go) about 2". I either have to semi-recline, or put a large round hole in
the gap seal. I can't move around enough for good visibility. I was
worried about not being able to reach the rudder pedals, but in the position
I'll have to assume, I have to bend my knees up to keep from pressing too
hard.
Very disappointing! This may not remain in the family too long.
Ron Carroll
Date: Monday August 24 1998 7:11 AM
Subject: Re: Kolb-List: Full Stalls Still Waiting
>Rutledge,
>level near stall.
>John Jung
>> Firestar 377.
>snip..
>> others.
Rut,
Here is what I was taught: When you use ailerons, the "effective"
angle of attack is increased on the wing with the down aileron. The wing
with the up aileron has an unchanged angle of attack. Here is a spin
senerio -> right wing starts to drop (because it is just starting to
stall), stick is moved left to attempt to keep wings level. The
increased "effective" angle on the right wing causes it to stall more,
followed by more left stick, etc., until the right wing is completely
stalled, with the left wing still flying, and the plane rolls over and
spins.
John Jung
>Rutledge Fuller wrote:
> Rutledge,
> level near stall.
> confused.
Subject: | Back on the horse |
Hi y'all
A few have mentioned 'where the heck have you been' ...almost enf to
make me feel missed. :)
A month or two ago I mentioned that I was grounded due to recovery from
ear surgery. I'm happy to report that I'm back on the horse so to speak.
I went up a couple weeks ago and more this weekend. The last I had
flown was 4.5 months previous, and that was the only flight since Feb.
As well, I had had most of the exterior of the engine removed to look
for an air leak that had caused engine failure on both flights 4 and 6
months previous. So, with an engine that wouldn't hum and a pilot that
recently felt accomplished just to walk around the block, this all needed
to be a pretty basic test flight.
I started out running the engine while tethered to my trailer for about
10 minutes. Trying all rpms and rpm changes, all aspects were normal.
That seemed to conclude that the engine failures were caused by a simple
leak in the exhaust manifold (mentioned in previous post), although I
didn't feel really confident in it until after a couple hours of flying
and rpm changes in the same manner it had been quitting.
On the personal side, I'm happier than you can imagine to have gotten
to this point. My flying status before surgery was getting to be,
at best, a marginal situation. I was at risk of having to just throw
in the towel and quit flying, as well as alter some other more normal
activities including my career. (The problem was a balance disorder --the
same thing Alan Shepard had btw.) The decision to have surgery had some
risk in itself, as the medical information available said that surgery
would give me an 85% chance of being normal, or close to it. I have
had many thoughts about the "close to it" and 15% parts. The desire
to get back into my plane definetly was a factor in my drive to find a
medical solution to a disease that still is not very well understood.
This weekend's flying was really getting back into the fun more. I did a
lot of zooming around in some low rolling hills that are free of trees,
power lines, etc. An 8 sq mile playground built for ULs. You can bank
down curving small canyons and come up draws making the cattle skitter.
At sunset you can smell the grass, see the bugs buzz up in front of
you, and kiss the wheels on the weeds as you blast over the next crest.
There's one farm house where the 12 year old kid always runs out to climb
the water tower and wave like a lunatic whenever I romp around over there.
It is really really fun.
Ben 'Glad to be more than hangar flying' Ransom :-)))))
>Rut,
Happy Monday Everybody:
Been reading with interest "roll control thru and during stalls."
I reckon everybody has their way of doing things, as I do. I believe when
Homer Kolb designed his airplanes he put great big barn door ailerons on
them so when he was flying around extra slow and comfortable, like he likes
to fly, he would have complete roll control, right thru and during the stall.
I have found out thru experimentation with the various Kolb aircraft
(playing with them) that if one puts them into a "mush" one has complete
roll control with ailerons. Take the acft to a couple thousand feet or so
(so you have plenty of safety margin), slow down to below flying speed,
hold it there with aft stick, and you will be mushing. If you have as VSI
you will be amazed at how fast your rate of descent is. You will also be
amazed that you can roll the little acft left or right, or hold it wings
level, very easily. You will be amazed that there is only light lateral
stick pressure, what everyone seems to be looking for now days. Try
holding the wings level with rudder only and you will be disappointed that
it does not work well with Homer's acft.
I believe that people that get into approach and departure stalls with
Kolbs simply do not hold enough airspeed margin above stall, don't cross
check airspeed, and/or get way behind the acft. I personally do not fly
near the stall near the ground cause I know I will not have enough altitude
to recover from it and the ground it very hard. I have been known to fly
very low and very slow and I have been bitten by gravity and the ground.
It is a very helpless feeling when you realize that you are no longer
flying and you will not fly before you smack the ground. Most of us have
walked away from these incidents, but unfortunately, many of us have not.
I have to remember this if I want to fly tomorrow.
Kolbs are super little airplanes that are forgiving to a point. I like to
play with my airplane, but at altitude. Mushing is a super way to loose a
lot of altitude in a hurry and those big ailerons will keep the wings level
or help you bank and turn or what ever. When you are ready to stop mushing
and fly, a little forward stick and you are flying again.
A close to the ground stall is psychologically defeating cause to get out
of a stall, you must use forward stick. It is hard to push the stick
forward when you are descending in a stall close to the ground to get the
airplane flying again. It may be physically defeating to push the stick
forward if there is not enough altitude to accomplish the maneuver
successfully.
How I do get carried away. Remember guys this is only john h's personal
opinion, but it has worked and is still working for me. I ain't gonna tell
you what to do. That is your choice.
Ok, I can see that. What should I do about the wing dropping at 36 mph.
call it a stall? What about the rudder to keep the wing level? Sorry
to ask such questions that I should know, but with the 60.5 hour of
private pilot training I have, they never taught this.
"Rut,
spins.
John Jung"
Hi all: The reason you don't use ailerons during a stall is because
they are not effective and the rudder is the only control that is still
effective in a stall, however if you hold the rudder pedal in full right
or full left then you will enter a spin, the ailerons have very little
to do with spins. If you advertantly enter a spin you push the nose full
down push full opposite rudder add full power then gently bring the nose
up to level flight. Thats all for the flight lesson for the day.
Frank Marino
> From: Rutledge Fuller[SMTP:rut007(at)hotmail.com]
> Sent: Monday, August 24, 1998 11:09 AM
> To: kolb-list(at)matronics.com
> Rutledge,
> wings
> level near stall.
> confused.
> up
> Thanks.
> Rut
Subject: | Re: Back on the horse |
edu>
My kind of flying!!!!!!!!!!!!!!
Just got this message. I agree, and I think that this is where I was
during my stall testing. Thanks.
when
on
likes
stall.
> john h
John, I must confess that I find myself inching up on the tach.
4900 now seems kinda low and rumbly. I find 5200 my current rpm
of choice. Maybe another few hundred hours I'll be in the high
5ks too. :-)
Ben Ransom
From: | Russell Savage <rsavage(at)freenet.columbus.oh.us> |
Subject: | speed limiting flaps on a MrkIII |
John,
Are the faps on a Kolb MarkIII speed limiting??
Russ Savage
Columbus, Ohio
A non Kolb owner as of 8/24/98.
Frank,
This is not true. John Jung posted it correctly. Ailerons *can be* very
effective in a stall -- they typically invite a spin during high AOA
and/or slow flight, precisely for the reason John Jung gave. I think
you'll find this backed by any flight training book. However, as John
Hauck said, the ailerons are pretty kind to us during Vmin in the Kolbs.
Rut,
Wing drop at 36 IAS ...call it a stall ...close enf. The main thing is
that you are fully aware how your own plane behaves. Especially homebuilt
planes will differ slightly, one to the other. I usually get a little
rt wing fall off on mine. Also, I don't know why you don't fit in your
plane. I'm 5-11 ...my head is close to the top w/ helmet and butt cushion,
, my feet fit about right at the pedals, but I have adjustment available
to move the pedals closer. Is your plane stock, or modified?
I've been able to get my plane (FS-KXP) into a straight ahead slow mush
stall instead of the more typical nose drop stall as well. I think i
can do this with power off, stick full aft (but it's been awhile), and
I *do* use some rudder to keep wings level. My first reaction to finding I
could do this was "holy cow, and people spend >$30k for Long-Ezes?!! just
for this?!" You will probably find that a more rapid stall entry will
cause the more traditional nose drop stall.
Ben Ransom
Rut,
I can't talk speeds because I don't really know what is going on with
your plane when it indicates 36 mph. Even though John Hauck doesn't
think the rudder works well to keep the wings level, it works for me.
Also, he makes a good point, that the ailerons still give some control
in a stall, but I believe that using full ailerons at stall is pushing
your luck. Why do I think that? Because I have talked to pilots that
have spun in Firestars, seen the wreaks, and watched the pilots, still
limping, one and two years later. My Firestars have never shown me any
nasty stall or spin tendancies, but a few others have not been as lucky.
This is just my opinion, make your own choice.
John Jung
Ron Carroll
Whoops, i see that the "fit problem" came from Ron, not Rut . Sorry about
that.
Also Ron, a note about the elevator and cables. If there is spring or
stretch to your cables, something is wrong with the cable or the routing
or the control horns or the stick mount.
With good cables, cable tension has nothing to do with required stick force.
(obvious i know, but just to be clear).
Cables should be tight enf to be sure they won't cross over each other,
but not be so tight as to cause a binding feel when operating, i.e. they
can and do rest on the fuselage tube part way back to the tail. Not very
exact i know, but something to go on. Most importantly, you should feel
no stretch or backlash when pushing against stick and elevator at the
same time.
Maybe somebody with their plane unfolded can post how much angle up
and down they get in normal elevator travel.
-Ben 'making up for past quiet' Ransom
How many of you have done/practiced spins in your Kolbs?
> -----Original Message-----
> From: John Jung [SMTP:jrjung(at)execpc.com]
> Sent: Monday, August 24, 1998 11:27 AM
> Rut,
> with
> lucky.
> John Jung
> mph.
> Sorry
Subject: | Re: speed limiting flaps on a MrkIII |
>John,
>Russ Savage
>Columbus, Ohio
Russ: Where's your Kolb?
You'll have to check with Dennis Souder or someone who has a published max
speed flap deployment publication. I have nothing in writing. I generally
try to slow down to 70 mph and below to deploy 20 deg or 40 deg flaps. No
need, that I can see to deploy at any faster AS.
Hope that answers your questions and I hope I am the right john to answer it.
>Russ Savage
>Columbus, Ohio
> The faps don't have anything to do with the speed limit. Faps are
only used to signal turns, or when parallel parking.
Richard Pike
>Rut,
>John Jung
Hi John J:
Yes you are right on the first point john j, I believe on all Kolbs, except
Sling Shot, that the ailerons work better in the mush/stall than the
rudder. My opinion only, but again, it works that way for me. I suggest
to satisfiy ones own mind they should do mush stalls controlling roll with
rudder only and then try it again with aileron only. Don't cheat now, and
make sure you have plenty altitude, 1,000 preferably 2,000 plus.
Probably doing any kind of mush/stall maneuver close to the ground is
pushing your luck and one should have their "head space" checked if they
perform these maneuvers close to the ground. I believe full aileron on a
Kolb (minus Sling Shot) is definitely overkill to control roll, unless you
get caught close to the ground in pretty violent winds and get a wing
lifted violently on you by one of their gusts, like turning final, etc.
I also believe that these people who you refer to that are limping and ones
that have been planted because of stalls/spins, were probably close to the
ground, not at one, two, or three thousand feet as I mentioned I prefer to
play and experiment with my Kolb.
I don't recommend anyone do anything especially spins and aerobatic
maneuvers. I do not do aerobatic maneuvers in unaerobatic airplanes
anymore, not since my last one 11 March 1990. I do do spins and have spun
all the Kolbs I have flown except the Sling Shot (and I have never had it
higher than 500 feet and it does not have a parachute installed). I never
intentionally spin one lower than 3,000 feet. My big fat MK III will do a
one turn spin and recover with a 300 foot alt loss (if I do a good one).
My 1985 Firestar would do a half turn spin with eng at idle and fly out of
the spin with the controls still locked in the spin position. With dead
stick the Firestar would spin up like a top and had to be stopped with
opposite rudder and forward stick.
john j, what characteristics does your Kolb demonstrate in the spin, eng at
idle and eng off?
Just my own humble opinion, folks.
In a message dated 8/24/98 1:14:57 PM Pacific Daylight Time,
jason(at)acuityinc.com writes:
<< How many of you have done/practiced spins in your Kolbs? >>
My brother did an intentional three turn spin in the Mark 2 from 1200
feet. He was right over the grass field we fly from. He pulled of it with
700 feet to spare and said that the plane responded beautifully and that it
was a relatively low G manuver. I thought it was a very dumb stunt. A little
old lady down the street called the tower at Trenton and said she saw a small
airplane crash. The cops came. It was not good.
Subject: | Re: spins, was ... |
I personally think spin experience is a good thing, but *ONLY* if you've
first done them with an instructor in at least something similar, and with
all the other common sense admonitions, including a BRS.
I've only done engine idle spins. Entry is quick and slightly inverted
(~110 degrees nose down) so it gets your attention. With my plane and
CG it will stay in the spin if controls held in spin position, and exit
very very easily with normal recovery technique. Have not had nerve to
try w/out engine, not sure I'll go there (intentionally). Have never
gone more than 1.25 turns ...chicken and alive to brag about it.
Did my first FS spins at 4500AGL ...overkill i know... but like the RC
guys say, all first tries should be done at least "3 mistakes high".
I almost got nose bleeds even before kicking the plane around. :-) Best
thing about spin training is they make you devoutly religious about
airspeed. You'll never recover if you get in one accidentally down low.
Never is a long time, and I can't figure how you can spin in and get
away with just a limp.
-Ben Ransom
Please don't go out and try one on account of reading this crap unless
you get in-flight spin instruction first. Call your friendly CFI and
do it in a real, spin certified airplane.
Glen, I agree with the others that cg had nothing to with your dads
accident. Did you say this was an Original FireStar or the new one? If
it was the Original this explains everything because the mains are more
aft. Your low tire pressure and landing in soft dirt can be a setup for
such an accident. Those Originals will not take much resistance under the
mains to put them on their noses. This is something you or your dad were
not aware of and it's a hard lesson to learn. I still will occasionally
put mine on my nose when I'm on fast taxiing after touching down and
turning downwind. The wind will get under the tail and lift it upwards.
Embarrassing when that happens.
Ralph Burlingame
Original FireStar 400 + hrs
>Glen Huffaker and I have been reading some of the messages here for a
>Valley Idaho. We went with a ultralight club here in Boise,
>our first X-country with the Kolb, In the preflight, my dad noticed
>that the header pipe for the muffler was cracked slightly, (a 447
>Rotax engine, only one joint on the muffler) someone else looked at
>it, we thought it would hold, and the pipe did not have to support
>anything. I herd that the muffler should have two joints to reduce
>would be a simple fix that would have prevented a crash. It
>but he did not have any problem landing, we knew we couldn't go any
>further until we could patch it or fix it. We had some hose claps and
>wrapped the pipe with a piece of metal can, it looked like it would
>hold. He
>a loop in their two seater. when he came around to land, he
>noticed the CHT was getting high, 1,800. and he could not control the
>engine rpm, he landed with low power, right before the runway in soft
>dirt, the dirt slowed him quick and the tail came up, and the whole
>thing FLIPPED UPSIDE DOWN. I saw it from above, what the heck, the
>CG is so far forward that landing on unpaved ground is difficult if
>not impossible to keep the tail down. Luckily, he was not hurt badly,
>but he'll have to wear a sling for two weeks because he fractured his
>shoulder blade bone. The Firestar did well, it sustained minimal
>up. Can anyone shed some light on the forward CG problem of
>the firestar
I am most interested in the discussion of using/not using aileron to
correct "wing down" at stalls. After a whole bincha hrs in many
different airplanes (pardon the expression) this thing seems to be just
one more facet of UL flying so new to me. But I'm enjoying the many
tutorials, and hope to save me empenage thru this new-found knowledge.
But I surely "walk" the rudders near a stall, still. Hard for a real old
dawg to break real old habitsI still can hear my instructor of 57
years ago giving me what for! Be careful, though. Grey Baron
Calm down Ron, I'm the same size you are and I find the cockpit
comfortable.
Ralph
Original FS 400+ hrs
writes:
>cockpit. I've never had everything together before, so didn't realize
just how
>small the cockpit really is. I'm not tall, just 5'10", but my head,
without
>a helmet on, sticks into the lower part of the wing (where the gap seal
>will go) about 2". I either have to semi-recline, or put a large round
>hole in the gap seal. I can't move around enough for good visibility.
I was
>position I'll have to assume, I have to bend my knees up to keep from
pressing
>too hard.
>Ron Carroll
Rut,
If you are high enough >1500 feet, stalls are really nothing to fear. I
pull the stick back and I will hear the prop burble in the turbulent air
off the wing root where it stalls first. Then with no wing drop, it falls
off and begins flying again. Nothing to fear.
Ralph Burlingame
Original FireStar 400+ hrs
writes:
>add
>tail
>have
>stalls.
>others.
>Thanks,
>Tallahassee, Fl.
Hey Ben, glad to see you back in the saddle. I really enjoy you comments.
Ralph
writes:
>Hi y'all
>from
>speak.
>that
>needed
>about
>simple
>flying
>--the
>some
>did a
>trees,
>bank
>skitter.
>crest.
>climb
>there.
Subject: | 2 stroke vs 4 stroke weight |
John H, do you remember how much more you airplane weighed when you
changed from your 2 stroke to your 4 stroke? Were there any non engine
related weights added? what engine did you have before your 912?
Boy are Kolbs different. My Firestar 2 is not standard in that I faired in
the engine and added underwing gap seals, but my ailerons are basically
decoration and relatively ineffective, my rudder is the primary wing leveler
in turbulance,as for using ailerons at low speeds I spent 40 years on and off
driving ag aircraft and I work hard to keep that ball centered and the wings
symmetrical. My firestar wiould spin rapidly when I was playing with aileron
droop but normally you have to force it to do it with full stick and at least
3/4 rudder.
DickC
Rutledge, your wings aren't rig quite right, with the right wing
having more incidence that the left and stalling. My original FS has
almost no burble or warning. I stall straight ahead and stays that way
even when built up a deep stall. I see about 31 IAS in a full stall.
good luck!
Original FS
rotax 377
Original
add
tail
have
> stalls.
> others.
> Thanks,
> Tallahassee, Fl.
Captain Robert P. Gross
American Airlines MIA
561-744-8055
Hi Rusty
Man, your luck is as about as good as mine. Hope it gets better
Kent
> difficult?
> Dick C
Put them in before you put it on........
J. Baker
Mistake # 1
Mistake # 2
Effects of mistake # 1
Geeez....big mistake # 3
Lands just fine in soft dirt if you have the appropriate tundra
tires.......and aren't in a hurry to self-destruct.
A lesson for all those in a hurry to go someplace.........
J. Baker
I have made dozens of these and each time I just file it carefully.
Works great. I do have a micrometer to check diameter though (the only
proper tool I use in the process).
Adrio
> > that teeny work.
> Geez.....lathe? How about a drill and emery...or file. Not accurate
> to the thousanth but acceptable. Just make sure the wire is in a
> tube when turning so it doesn't whip and kill you.
> J. Baker
>DickC
Hi DickC and Gang:
This is very interesting. Dick's FS II is the first Kolb I have heard of
that is a rudder and not an aileron airplane. Have you tried flying
without ailerons? I find it very difficult for a short period of time and
then it gets into an impossible situation where the low wing can not be
picked up with rudder. Maybe I am doing something or maybe I am not doing
something right. I don't know.
What's the secret? Reckon it is the mods?
Subject: | Re: 2 stroke vs 4 stroke weight |
.com>
Hello Jason:
To be honest, I did not weigh the airplane after installation of the 912,
which replaced a 582. I don't think there was more than 25 or 30 lbs at
the most. The 582 had twin radiators, oil tank, and super large standard
rotax exhaust system. The 912 has an oil tank, small single coolant
radiator, oil cooler (small), and small lightweight exhaust system. I used
two pieces of 1/4" X 2" 6061 alum to mount the 912 to the 582 lord mounts.
The change in character of the airplane from 582 to 912 was tremendous.
Reliability went up 100 per cent, no engine outs in nearly 1,000 hours of
912 time. Two eng outs caused by contaminated fuel purchased while on
extended XCs, but not eng related. 582 eng seized at a little over 200
hours. Never determined whaat the actual cause was, other than cold
seizure after take off and climb out and throttle reduction to cruise
setting, wham!!!!! I gladly pay any weight penalty and expense difference
between the two engs to fly the 912 over the 582 in my plane. However, I
put a lot of time on the factory Sling Shot and MK III before they put the
912 on it, and feel comfortable flying them.
OK, Jim, you got me . I reckon I'm used to trying to maintain low VSWRs
at freqs of 440 and 1296mc, and at a bit higher power. Of course you're
right, and I understand putting the loose end of the wire in a pc of
tubing. As an old shade-tree mech (EE and FAA ticket) I bow to superior
knowledge. Maybe I should take a few whips from the wire? Grey Baron
>john h
Should have read, "Maybe I am doing something wrong or maybe I am not doing
something right."
Just a reminder- when you are needing to lose altitude fast, as in Richards
case. The quickest and safest way regarding your plane is the standard GA
maneuver of tight turns until you reach the altitude that you need. I have
to land in the bottom of a canyon whose wall is 1500 feet higher than the
field. It takes two turns at about 5200 rpms to be at the right level to
make my final. No excessive speeds and temps are right where they need to
be for quick response.
Larry
Sorry for chiming in more than my share here, but one other little tidbit
about rudder vs aileron in stall/pre-stall: Since rudder is a primary
input for spin recovery, the habit of using rudder to keep wings level
at stall is helpful in keeping your feet aware that they have a job to
do if it spins. As well, some wierd notion that ailerons will level the
wings in stall (even if true in a Kolb) might kill you an an airplane
that is more temperamental about spin entry or recovery. This known
well by our glider friends ...George?
- Ben Ransom
From: | bobdoebler(at)JUNO.COM (Robert L Doebler) |
writes:
>tidbit
>the
>- Ben Ransom
>YAH! if you used aileron during a stall, it would get you a wrap on the
head. At least from my glider CFI!
Bob Doebler
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Seems to me it's a Revmaster. VW base, direct drive. Big
Lar.
> From: swultra <swultra(at)primenet.com>
> To: KOLB NEWS GROUP
> Subject: Kolb-List: 2100D
> Date: Monday, August 24, 1998 8:13 AM
Good one old poops I laughed my butt off on this one.
Frank
> From: Richard Pike[SMTP:rpike(at)preferred.com]
> Sent: Monday, August 24, 1998 4:42 PM
> Subject: Re: Kolb-List: speed limiting flaps on a MrkIII
> >Russ Savage
> >Columbus, Ohio
> are
> Richard Pike
> MKIII N420P (42oldpoops)
Ben,
Very well said. Now I am satisfied that the subject has been covered
well enough. If a person were to read each of the recent posts on "Full
Stalls" and "spins", they would have some good information on stalling
Kolbs. And that would give them a good basis for making up there own
mind.
John Jung
> - Ben Ransom
Ben Ransom wrote:
snip..
Ben,
I cleaned up my report on the injuries of "spin and crash" pilots to
say that they were limping after a year or two. I didn't mention that
one of them was still using crutches after a year, and a cane after two
years. I also didn't mention the months of painfull theropy that they
went through or the hospitol and medical costs that they incurred. But
maybe these things need to be mentioned once in a while so that none of
us get too casual about flying. I don't want to take any fun out of it,
but I don't want new people to get involved in our sport because we only
painted a "pretty" picture for them.
John Jung
> idle and eng off?
I was taught to reconize a stall and avoid spins. And my training has
worked so far because I have never been in a spin, not even with an
instructor. I do plan to take spin training in the future, though.
John Jung
John/Ben and all: If you read accident reports that are published by
general aviation you will see that most accidents are caused by
stall/spin close to the ground, most are in a turn to final or some
trying to make the runway in a steep turn after engine failure.
Ultralight type flying that we do is for fun and for flying straight and
level slow and to wave at people on the ground. If you go out with the
intent to spin or do aerobatics in an ultrlight type aircraft then your
asking for trouble. That is my nickles worth, inflation you know.
Frank Philosophical Marino
> From: John Jung[SMTP:jrjung(at)execpc.com]
> Sent: Tuesday, August 25, 1998 8:52 AM
> Subject: Re: Kolb-List: spins, was ...
> Ben Ransom wrote:
> snip..
> Ben,
> to
> two
> of
> it,
> only
> John Jung
Ben Ransom is correct in warning against aileron in stalls/spins in
aircraft other than ULs. Unfortunately instructors "now-a-days" don't
teach spins, and therefor how to recover from themyou have to go to
"spin school," and lay out more big bucks for that most necessary
trainingbut as the saying goes "spins happen." It's most comforting to
know that my little FireFly is so foregiving, however many of you
already have (or will get) training/ratings in larger N-numbered A/C
that may not be so docile. Even a C150 doesn't like aileron in stall,
and can/will go over the top before you know it. Also, from my
experience will a 172, 182, 206, Stearman, SNJ, F6F. Never tried a PBY.
Dance on them rudders. Grey Baron
>Adam
>Charles Henry
>Hankinson ND
>FSI, 130 hrs
Dang it I thought I had the easiest lightest way to move things around with
the tubes in the trailing edge method. Charles' idea has me beat. Of course
both of our ideas do need a bit more muscle than a tail wheel dolly but ours
are portable.
Woody
Some men are able to stumble over the truth but are able to pick
themselves up and keep walking as if nothing had happened. (Churchill)
writes:
>... I find it very difficult for a short period of time
>and
>be
>picked up with rudder. ...
This may or may not be of interest to anyone (never stopped me before..)
but my Flyer (1982) behaves exactly the same. Hands-off, it will very
slowly drop the right wing. Countering with rudder only yaws the plane
and raises the nose slightly. The wing drop can be stopped but not
reversed with rudder. If I play with the power, I can eventually reach a
steady state with the right wing low, yawed to the left and slowly
descending. Pretty it ain't and I wonder how/if I would ever "land" it in
the event of loosing aileron control.
My Challenger 2 is exactly opposite, I don't think you could control it
without rudder, not for long anyway. The adverse yaw from it's ailerons
is tremendous compared to the Kolbs I've flown.
-Mick Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
From: | Gary Thacker <gthacker(at)mciunix.mciu.k12.pa.us> |
Subject: | Charles Henrey: 2nd time up and how to move about |
Charles
I saw this post but didn't have your address. I would like to talk to
you about your methiod of movin things around.
Gary
____F i r e S t a r____
___(+)___
(_)
On Tue, 25 Aug 1998, wood wrote:
> >Adam
> >Charles Henry
> >Hankinson ND
> >FSI, 130 hrs
> are portable.
> Woody
Is there a way of gettin the names and e-mail addresses of the members of
the list? I remember at one time we could request a list of the members. Is
this available with the new system?
Gary
___(+)___
(_)
From: | Scott Bentley <Scott.Bentley(at)Bentley.COM> |
Subject: | List of Subscribers |
See http://www.matronics.com/ftp/Archives/Kolb-List.FAQ for instructions.
From: Gary Thacker [mailto:gthacker(at)mciunix.mciu.k12.pa.us]
Is
Gary
Souderton,Pa.
Early flights with my unmodified plane would give some prop noise before stall
but after the fairing and gap seals there is zero warning. I have always been
unhappy with aileron power and flexibility from the stick to the mass balance
weights. Quick stick movement is like a fat dog shaking, everything moves at
its own pace.and not yours. I also experimented with various length pushrods
to find the best aileron position as I could not find a reference to it on my
plans. Some of the positions combined with a slightly off wing gave scary
results. While I am talking ailerons how come the movement differential is
backwards to convention in having more down than up? Any thoughts Dennis?
Dick C
dwegner(at)isd.net
John and Ben,
I know it's important to be aware of the stall/spin and this was
impressed upon me so much that I was fearful of stalling when I began
flying my FS. I have a healthy respect for it, but I can think of a
situation in low and slow flight where
one does not really have to be concerned about stalling at all. This is
called "flying off the deck". In the winter here in Minnnesota, we fly
inches off the frozen lake for miles on end and at very slow speeds
(about 35mph). If the plane does stall, all that will happen will be a
normal landing. This is probably the only exception that I can think of
where low and slow is perfectly safe (and fun) without having to be
concerned with stalls/spins. See what you Southerners are missing out on.
Ralph Burlingame
>Ben Ransom wrote:
>snip..
>Ben,
>to
>two
>of
>it,
>only
>John Jung
From: | "Ron Carroll " <ron.carroll(at)WORLDNET.ATT.NET> |
Subject: | Spongie elevator cable |
Thanks for your interest, Ben. Good to have you back on top, so to speak!
This on really has me stumped. I've had about 10 guys come over and check
it out. They offered little but a questioned look on their faces. The
cables (original cables provided with the kit) are all separate in the boom
tube ( no crossed or twisted cables) and NOTHING *gives* , i.e., stick,
pulleys, airframe or hinges, except that the elevator horn moves
approximately an inch, and returns to the original position when downward
pressure is relieved. The feeling, while pressing down on the rear of the
elevator, is that the cable is made of a heavy duty bungee (probably an
exaggeration).
My EAA Tech-Advisor had me tighten the cables to the point of almost being
able to play a tune on them. In fact, the elevator now does not return to
the down position when the stick is released. I'm afraid this will cause
unnecessary wear on the hinges. I got a short note from someone this
morning who said there is no need for the cables to be very tight. There is
actually no way to put a tension gauge on them because the long span is, of
course, inside the boom tube. Even if I could get to it I wouldn't know
what the tension should be (can't find anything in the manual).
My problem is that I've never seen a Firestar, and know of none I can go
look at and get a feel for. When I post my question to the list I feel
foolish because no one else has had the problem. Maybe there really is no
problem. Maybe they all have this soft feel. ??? I've never had an
ultralight that had this spongie feel, but of course, some were tubes
instead of cables.
The way I found it is when I was doing the engine break-in. The tail wanted
to come up so we pulled the stick back in an effort to hold the tail down.
With the prop blast the elevator would only rise about an inch above the
horizontal. I'm not sure why, or if I would have the guts to try and fly
it. Maybe this is normal, but I don't know. I either need to actually see
one, or have some one place a measured down pressure on the rear edge of the
elevator and measure the amount of droop with the stick secured in the full
up position. With this information I could easily compare mine with
their's.
Again, I thank you for your input, and I'll keep looking. Have FUN!
Ron Carroll
Original Firestar
Date: Tuesday August 25 1998 10:10 AM
Subject: RE: elevator cable problem
>...an afterthought of one more potential trouble area: also check the
> elevator hinges
>Good luck.
>-Ben Ransom
Sorry Ralph but I think that if you can do this over water with floats
strapped on in 90+ degr weather still beats doing this in icy conditions.
Frank (Lotus Float equipped)Reynen MKIII in the sunny warm California
Delta 6 inches above the water @460 hrs
http://www.webcom.com/reynen
Please respond to kolb-list(at)matronics.com
John and Ben,
Ralph Burlingame
You mean frostbite :-)
Rusty (southern boy)
My original flight instructor always warned me not to use the ailerons in a
stall recovery. He expected me to make the mistake eventually and learn the
intended lesson, but to his apparent frustration, I never did. Finally at the
end of a day of stalls in the 152, he gave up and said "I've got the plane. Let
me show you what happens if you use the ailerons". In about a nanosecond, we
were upside down and spinning toward the ground. It was a powerful lesson :-)
Rusty (I'm a rudder guy) Duffy
Subject: | Re: Spongie elevator cable |
Ron,
I briefly read your post and have some idea of your problem. First I must
impress on you: DO NOT ATTEMPT TO FLY your FireStar until we figure this
out. It is not normal for the elevator to feel spongy or have ANY give in
the cables. What I suspect is that you may have a cracked or broken cable
support. Look under the seat and inspect the cable pulley supports for
any cracking. The elevator/rudder cables do NOT need to be super tight.
If you have tightened them too much, this may explain any cracking that
you might see. When I sight down the fuse tube from the rear, I see some
sag in mine. This is normal. The elevator/rudder/aileron controls should
be free in movement without ANY binding or sticking. I believe the
elevator up travel to be about 8" and it is very positive. When the
Original FireStars taxi over rough turf, the bottom cable can be heard
clanking inside the tube if there is no other supports added (I know
there is some type of support that can be added as I have read in the
posts). This is not a problem as I've inspected the cables and see no
wear in 11 years. Let us know what you see.
Ralph Burlingame
writes:
>speak!
>check
>boom
>stick,
>downward
>of the
>an
>exaggeration).
>being
>to
>cause
>There is
>is, of
>know
>go
>feel
>is no
>instead of cables.
>wanted
>down.
>the
>fly
>actually see
>of the
>full
>their's.
>Ron Carroll
>Original Firestar
>From: Ben Ransom <ransom(at)mae.engr.ucdavis.edu>
>To: Ron Carroll
>or
>routing
>the
>> elevator hinges
>>Good luck.
>>-Ben Ransom
Subject: | Re: Stalls and spins |
Well here is my input.
I also was taught to use rudder and very little,
if any aileron. I also Remember in Slow flight
just about 5 mph. above stall that you make
slight turns with rudder only, not by ailerons.
I believe this also was to keep from getting
into a spin cause of the increased drag from
the down aileron.
Just a little from what i remember,
Subject: | Re: control stick position |
has anyone made a fix for the forward stick location straight and
level?
i was thinking of of welding an angled tube at the top to offset it back
about 4"
matt nisbet
firestar
From: | dralle(at)matronics.com (Matt Dralle 925-606-1001) |
Subject: | Please Read - "Was I Unsubscribed?"... |
Listers,
There is a web page available for checking to see if your email address has
been unsubscribed from the List. Any email address removed from the List
because of bouncing email will be shown on this web page along with a
brief explaination of why it was removed. Please Bookmark the following
URL for future reference:
http://www.matronics.com/unsubscribed/bouncing.cgi
Thanks!
List Admin.
Hey Rusty, I know your kidding but we actually get hot out there on that
frozen lake since we are dressed up in many layers of clothes and stuff.
Ralph
Subject: | List Digest Mode... |
Listers,
For those of you that arn't aware of it, there is a 'digest mode' available for
each of the Lists. The digest mode messages consist of the entire day's
messages grouped together into one message and sent as single email at the
end of the day. The description below is from the List FAQ regarding the
operation and subscription process:
(If you are on either the Kolb or Zenith Lists, please substitute the
word "rv" below with either "kolb" or "zenith" as necessary.)
This digest will contain basically the same data that is currently appended
to the archive file. It has all except for the From:, and Subject: headers
stripped out, and includes a message separator consisting of a line of
"underscores (___...)".
combined and sent as a single message to everyone on the digest email list.
To subscribe to the digest list, simply send an email message to:
rv-list-digest-request(at)matronics.com
or
kolb-list-digest-request(at)matronics.com
or
zenith-list-digest-request(at)matronics.com
and put the word "subscribe" in the BODY of the message. No other text
in the body or the Subject field. To remove your email address from the
digest list, simply put the word "unsubscribe" in the body instead.
Now some caveats:
* Messages sent to "rv-list-digest(at)matronics.com" will be forwarded to the
standard email list. In other words, you cannot post messages only to
the digest list.
* If you are subscribed to both the regular list and the digest list, you
will receive the realtime postings as well as the digest at the end of
the day.
* If you reply to the digest email, your message will be forwarded to the
normal list associated with the digest. IMPORTANT NOTE: PLEASE change
the subject line to reflect the the topic of your response!!!! Also,
PLEASE *DO NOT INCLUDE ALL OR MOST OF THE DIGEST IN YOUR REPLY*.
Matt, all you have to do is re-rig the elevator turnbuckles so the stick
comes further back. This is, of course, if you have enough thread left
on the turnbuckle to adjust it backwards.
Ralph Burlingame
writes:
>level?
>back
>about 4"
>matt nisbet
>firestar
Subject: | Re: 2nd time up and how to move about |
Date: Saturday, August 22, 1998 7:57 PM
Subject: Kolb-List: 2nd time up and how to move about
>testing to see why I'm not receiving messages
Ron, I do know this: when I'm running up the engine on the ground at full
power and I have the stick back, the elevator stays all the way up, about
8" from level. There is no sag or droop and I wouldn't want it. I have
never had someone hold the stick in place while I checked the elevator
for movement so I can't say what movement I would see if any.
Ralph Burlingame
> except that the elevator horn moves approximately an inch, and returns
to the >original position when downward pressure is relieved. The
feeling, while >pressing down on the rear of the elevator, is that the
cable is made of a heavy >duty bungee (probably an exaggeration).
>wanted to come up so we pulled the stick back in an effort to hold the
tail
>down. With the prop blast the elevator would only rise about an inch
above
>the horizontal.
> I'm not sure why, or if I would have the guts to try and fly it.
(You know what would happen if you did. Let's get this worked out ....
Ralph)
>Ron Carroll
>Original Firestar
Subject: | Re: Fwd: Life with Rotax (sorta long) |
You have good ideas, Woody. I've always used WD-40 the same way, but yours
is a lot less messy. Thanks. Big Lar.
WD-40 still works the best for cleaning greasy hands, tho'.
> From: wood <richard.wood(at)usa.net>
> Subject: Re: Kolb-List: Fwd: Life with Rotax (sorta long)
> Date: Tuesday, August 25, 1998 9:42 AM
> >I sent it to Greensky hoping they would find bad crankshaft seals or
leaking
> Next time you suspect an air leak try blowing some raw propane out of
> your torch to the suspect areas. If the engine changes speed you have
> located a vacume leak.
> Woody
Subject: | 2nd time up and how to move about |
> From:
> Subject: Re: Kolb-List: 2nd time up and how to move about
> Date: Wednesday, August 26, 1998 12:55 AM
> Well, you got to this end of the country. Let's see if this gets back to
> you. Big Lar.
> > From: barry youngblood <barry(at)hcis.net>
> > Date: Tuesday, August 25, 1998 7:03 PM
> > From: Adam S Violett <asviolett(at)JUNO.COM>
Hi to Ron Carroll: You don't ever want to feel funny about asking a
valid question. It could save your life, and it's one of the great
benefits of a group like this.
In a similar vein, when I went through my flight training ( Cessna 172 ),
my instructor put me through a simulated up elevator cable breakage. Since
our aircraft are trimmed to be nose heavy, this would mean an
uncontrollable dive. Cessnas have an elevator trim wheel connected to a
trim tab on the elevator. Between this and the throttle, I practised until
I could bring it around to short final. Good lesson. However, Kolbs don't
have this, just a single cable back to the elevator horn. With this in
mind, I ran a separate cable from the trim spring to its' own clevis on the
up side of the horn. If one breaks, I've got an option. Paranoia ?? You
bet, but the above exercise made a strong impression. ( As did Barry
Schiff's spin video ) Problem arose when I had the EAA tech advisor come
to check out the mighty project. He's absolutely determined that it's
going to cause elevator flutter. No use Dennis assuring him this won't be
a factor, or that earlier versions had 2 cables going back to a common
clevis. Whaddaya say to a guy like this ?? Also, without his approval, I
don't get the insurance break either, which as it turns out doesn't amount
to a hill of beans. About $25.00. Wish I hadn't bothered, now.
Big Lar.
You guys are right on about NOT flying until this one is figured out! There is
a certain way the cables must crisscross in the tube - check it out for proper
installation. The cables will "clang" in the tube while taxing, or at least
mine always have. One problem I have had. About every 200 hrs I get enough
wear on the rudder cables that the strands begin to sever in the area where
they go through the nylon guides in the middle of the seat. This is hard to
see visually until you twist them slightly. You would think the nylon would
wear before the stainless steel ones do - not the case.
In any case, equal & full up & down elevator must be achieved with very
little "slop" or resistance, or DON'T FLY.
Joe Robberson - Kolb Mark II - 600hrs.
I have the same problem in my Mark II - was thinking of shortening one cable
SLIGHTLY and lengthing the other, then adjusting to proper stick position with
turnbuckles. Joe
Subject: | Re: Charles Henrey: 2nd time up and how to move |
about
>Charles
>Thanks
>Gary
> ___(+)___
> (_)
>My Email address is chhenry(at)plains.nodak.edu
Phone # 701 242 7540
Charles Henry
Hankinson ND
Firestar I 130 hrs
>> >Adam
>> >Charles Henry
>> >Hankinson ND
>> >FSI, 130 hrs
>> are portable.
>> Woody
____________\_/____________
O O
Happy Landings
Charles :)
>Charles:
>I see Gary's post to you about this. I didn't really understand
>your above post to Adam, but you have my curiosity up too. Is the 3'
>length for lifting, or steering, both, or what? I don't get it.
>Thanks in adv.
> Ben Ransom
Hi Ben, Good to see you are doing well and flying again.
The strap with a hook on the end is used to hook the axel of the plane by
the tail wheel and I just loop the strap around my hand and pull on it to
lift the tail. Lifting the strap makes the plane want to move back so you
need to push on the trailing edge of the wing to control the direction that
it moves. Steering is done by pulling the strap to the side. I have put
heatshrink tubing on the hook to keep it from scratching and now have tied a
loop in the strap to make it easier to hang on to. I think (crs) this was a
suggestion of Dennis Souder when I called Kolb to ask how to move it when
folded. I fold and store the plane in a single stall garage each time I fly
so it has about 100 removal and store cycles with no apparent damage from
pushing on the trailing edge tube.
Charles Henry
O O
Happy Landings
Charles :)
From: | "Vince Nicely" <vincenicely(at)intermediatn.net> |
Hi John,
You wrote : >I find it very difficult for a short period of time and
>the>This is very interesting. Dick's FS II is the first Kolb I have heard
of
>without ailerons? n it gets into an impossible situation where the low
wing can not be
This has been a most interesting discussion to see all the differences
between Kolbs.
My Firestar II is mostly a rudder airplane, but it was not always that way.
Let me explain. When first setup as nearly as I could follow the Kolb
builders manual, my airplane gave an unusual rudder response compared to my
GA experience. Specifically, on application of rudder, it would slow, pitch
nose up and eventually could ususally be made to stall if rudder was held
full over. Furthermore, if the airplane was in a bit of a bank, the rudder
alone would not lift the wing or cause the airplane to unbank, but caused
the other responses noted above.
I decided to add more dihedral because that seemed like it had a chance to
make the responses more conventional compared to GA planes which I wanted.
Three degrees of dihedral makes my Firestar II able to fly all day without
touching the stick. Slight rudder inputs provide all the roll controll that
is needed. It can be brought out of a fairly steep (say 20-30 degree) bank
with rudder alone. It has just about neutral spiral stability, i.e., when
put in a bank it will approximately hold or slightly lower the bank angle
without control inputs.
When my plane is stalled, the rudder is very effective at lifting a wing (or
in the other direction for putting it into a spin). I have not tried the
ailerons near stall, so can't comment until I fly it again. However, I
might not want to start using the ailerons because if it became a habit I
think that can complicate
the stall situation in many GA aircraft which I fly some times. Also, I
understand that in some aerobatic aircraft, at least, flat or knife-edge
spins are initiated by how the ailerons are held at spin entry.
At any rate, it would appear from my experience the details of setup can
make some difference in how they fly.
Vince
Date: Monday, August 24, 1998 11:21 PM
in
leveler
>>DickC
>Hi DickC and Gang:
of
wing can not be
>john h
Hey ain't nothin better than good old dish soap for lifting off those
greasy stains. Just watch them commercials to see my point.
The propane idea works great on cars too. With all them little hoses now
it dosnt take much to knock one off and not see it. propane will find it.
Woody
If all the guys can't find any thing sloppy or missing in the control
system I would say you have inferior cables. You have eliminated all other
parts of the system so the only thing left is the cable. Try new cables. But
first swap the cables around so the stick works backwards (pull back go
down) If you get proper function now you know that the one cable is
bad,probably a break in the center wire that you can't see. By the way how
does the elevator feel when you push the stick forward is it still spongy?
Woody
>backwards to convention in having more down than up? >
Dick
The differential in aileron movement has to do with the angle of the
aileron control horn as mounted in the aileron leading edge tube. If a
line through the pin in that horn and the aileron hinge axis is parallel to
the aileron, the aileron deflection should be symmetric.
Ron
Dick C
All our aircraft we have built have more up than down - which is the way it us
supposed to be. Don't know how you get more down than up. Take some pix of
your plane and send it to me. I''ll take a look.
Dennis Souder
Pres Kolb Aircraft
From: | "Jon P. Croke" <joncroke(at)CompuServe.COM> |
touching the stick. <
Very interesting!!
Does anyone know offhand how much dihedral is built into the stock
configuration of the Firestar???
Jon
Dennis, I am embarrassed by my question. A few seconds with a pencil and
paper shows that you are correct. I suppose its aging optics or maybe a
slight down reflex on my ailerons combined with the sloping upper surface that
makes the movement look opposite the facts. I do have one more question
though as its come up recently on two new Kolbs (you have to be selling a LOT)
. Initial positioning on the ailerons, should it be parallel to the upper
surface or the lower or in-between. Thanks for replying, I will try and
remove my foot from my mouth this evening.
Dick C
<< Initial positioning on the ailerons, should it be parallel to the upper
surface or the lower or in-between. >>
It should be parallel with the bottom surface. Actually, you may even want to
droop it a slight amount to compensate for the bit of flex and accumulated
play in the linkage. If you have someone hold one aileron while you lift up
on the opposite aileron you will see what I am refering too. With it drooped
a bit as it sits on the ground, it will not be reflexed when flying.
Additionally, you can adjust one way or the other a couple degrees to help
trim the aircraft.
Dennis Souder
Pres Kolb Aircraft
Subject: | Re: Life with Rotax (sorta long) |
<< Put engine back on the airframe, flew for about 15 min. and it
did the same damn thing! I'd run out of things to do. I was down to the
exhaust and the CDI box. To hell with it, I went to OSH. Came back and, of
course, the engine still didn't work. While at OSK, for lack of anyother
idea,
I'd bought a new fuel pump (although I'd rebuilt the old one). So, before
starting to fool with the CDI and muffler, I tried the new fuel pump. IT
WORKED FINE and has been working fine for the four hours.
Moral of the story: I ain't rebuilding no more fuel pumps!!! For $20 or so
dollars I'm going to just buy a new one every year or two. Everything about
the old fuel pump looks good. It just don't work.
This "learning experience" has cost me around $600. But my engine/fuel system
has had a complete overhaul. There's not many things major that I could do to
my A-65 for $600. So I keep telling myself that's it all relative.
Spend that $$$$ and keep flying!!
Bill Griffin
Glad to have my Kolb flying again >>
Bill, don't feel too bad, I had a similar experience..........my name is
George, and that makes me curious....(hopefully it stops at that ..cause
Curious is a monkey)!. When I received my Firestar components I looked them
over with great detail, including my mikuni fuel pump. I'm an almost , but not
quite old fart, and upon occasion, need to rub my eye, whenever they get
strained...............well, a good friend of mine , Bob Morrison volunteered
to take my plane up (447 Rotax) and the engine quit after 5 minutes and 250ft
alt. he landed ok and and we found that the gas tank cap did not have a clear
vent hole which we cleared. He took off again and got to 350 ft , engine quit
again, and after landing, dead stick of course, we found that there were a lot
of bubbles in the fuel line and tightened up the clamps. He took off again,
got to 450 ft. , engine quit again and he landed and exclaimed..."this ain't
fun anymore George," and decided I better fix it, before it flies again.
I replaced all kinds of stuff just like you, with the exception of sending it
to Jerry Olenik, of Green Sky (which is just a few miles a way from me), I ran
it many times tied to a tree, and it would always quit after running full
throttle for a minute or so.
In desperation, I took the mikuni fuel pump apart again and found one
of my eyelashes in it, ( I knew it was mine as GeoR38 was written on the side
of it)
Removal of the eyelash has allowed me to fly with that fuel pump for 6 years
without a hitch, ......but don't tell Bob.
My moral is different from yours...........don't open up your fuel pump AND
rub your eye...................you can do one but not the
other....................................GeoR38
I think my Firestar KX won't spin.................probably cause It knows it
would scare me...............................GeoR38
<< As well, some wierd notion that ailerons will level the
- Ben Ransom >>
Good point Ben, but there is some unusual thread going on here..............JH
and others have said that the MK III ( I have a Firestar) creates extra lift
one or 2 notches on the flaps and just drag on the "full" notch, If I am
deducing right. This sounds very much like a combination "higher lift wing" on
the first notch or so (accompanied with its increase in drag) and a spoiler on
the full flap condition. ..........gliders have spoilers and ailerons , but
usually not flaps............some do have flaps and use them just as described
about what I'm concluding the Mk III does...........read and heed Frank
M.........you think you have such a wonder "machine" in your MkIII and it
turns out to be merely a high powered wonderful "glider"........a matter of
point of view I suppose......Also , gliders have long wings and Kolbs have
short , high lift "fat" wings.
I hope the water is now sufficiently
opaque....................................GeoR38
>writes:
>>and
>>be
>-Mick Fine
Thanks Mick:
I was ready to drop this thread. I felt I was the only one who had any
idea how Homer's airplanes fly. Yep, every Kolb I have built, Ultrastar,
Firestar, MK III, and everyone I have flown, have the same flight
characteristics, as you describe. Can't comment on Sling Shot, cause I
haven't had a chance to go out and do some really enjoyable fling with it.
From: | Erich Weaver 805-683-0200 <sbaew(at)dames.com> |
Subject: | need a Mark III ride |
Autoforwarded: false
UA-content-id: 11C8D5360400
Hop-count: 1
Im a new pilot considering purchase of a Mark III for further training to
BFI status. Like the Kolb because of easy breakdown and setup from
trailer. Problem: Dont want to buy one without having actually flown in
one. Is there anyone out there in my neck of the woods that I could hook
up with to get a ride in one? Willing to pay a reasonable price for the
service.
Thanks for your consideration. Im located in southern california.
Erich Weaver
sbaew(at)dames.com
From: | Cliff and Carolyn Stripling <striplic(at)dfw.net> |
Subject: | Flaps on take offs??? |
To all,
>deducing right.
I would venture to say that even 1 notch of flaps on the MKIII produces
about as much drag (if not more) as lift considering it is a pusher. Two
notches (full flaps) almost certainly produces more drag than lift.
Some guys talk about using 1 notch of flaps on a short or soft field take
off like is recommended on a Cessna and other tractor general aviation
airplanes. I have not tested it personally, but I would bet that any flaps
actually make for longer take off runs under any circumstances. Anybody out
there that has actually measured distances using or not using flaps on take
offs? Any opinions or observations?
Later,
Cliff & Carolyn Stripling Him: Retired Pharmacist
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
and Marble Falls Texas Both: 5th Wheel - RV - Travel
Kolb MKIII - N582CC (50.5 hrs)
Subject: | Re: Full Stalls Still Waiting |
Vince: Very interesting. I only have experience with wings rigged to
Homer's standards. By increasing dihedral, have you decreased performance?
How much increase in inches to get 3 degree increase in dihedral measured
at the outboard rib?
>Jon
Howdy Gang:
Homer told me the only reason he put any dihedral in the wings is because
without dihedral the straight wings looked as though they were drooping.
He added CRS a tiny bit just to keep the airplane looking nice. He said
there is much more performance in straight wings thaan in wings with
dihedral. However, straight wings have to be flown all the time. But they
are fun to fplay with.
Subject: | Undelivered Mail |
Hi Group: I'm a little puzzled here. ( What else is new ?? ) I got a
kickback on undelivered mail, on the message to Woody, and the one to Ron.
Apparently Woody's got through, since he answered it. Duh. Did the one to
Ron about the elevators go through, too ?? Big Lar.
From: | "Marino, Frank J (Youngstown ARB)" <Frank.Marino(at)yng.afres.af.mil> |
George, or GeoR38, I want to commend you on the upgrade you did on you
FS or FX or what ever you call that? the two Mcoy.035 model airplane
engines you put on there really sound good and the performance is so
much better than the 1938 washing machine motor you had on there, maybe
some day you will keep up with my MKIII.
Frank M----
> From: GeoR38(at)aol.com[SMTP:GeoR38(at)aol.com]
> Sent: Wednesday, August 26, 1998 11:12 PM
> - Ben Ransom >>
> extra lift
> am
> wing" on
> spoiler on
> , but
> described
> Frank
> it
> matter of
> have
writes:
<< This weekend's flying was really getting back into the fun more. I did a
It is really really fun. >>
Great news - I'm happy for you!
Dennis
From: | Charles Henry <chhenry(at)plains.nodak.edu> |
>Jon
I believe that the instructions call for the wingtip raised 1" from level
and if the wing is about 13.5' that is about 1/3 of a degree.
The 3 degrees dihedral mentioned in another message would raise the wingtip
over 8".
Charles Henry
To all the Kolbers out there, After 40 years in the military
service 6 with the 82 airborne and 34 with the air force I am retiring
acutually getting booted out. So this week will be my last nickles worth
of input to the Kolb news until I get on line with my home computer
since I can't use my goverment computer anymore. I got a lot of good
information from this e-mail except for GeoR38's and his stinkin glider
info. Keep the information flowing.
Frank Marino
Ron,
I checked the elevator on my Firestar II last night. It moves 8
inches up and 10 inches down. Then I tied the stick back and checked for
"sponginess" by pressingdown on the most aft corner with my thumb.
Reasonable pressure would lower it 2 inches. Pushing hard with my thumb
lowered it 3 inches. Just to be clear, 3 inches lowered is still 5
inches above a position "in line" with the horizontal stabilizer. I
don't know if mine is right, but I do know that it flys well and has no
problem with needing more elevator control. I hope that this helps.
Jon,
The plans call for 1 inch at the wing tip. I believe that translates
into zero degrees, when rounded to the nearest degree.
John Jung
> john h
Hi all
Seventeen years ago I built and flew a Weedhopper model C with the
original Chiota engine. Top speed 40, stall speed 17, no alerions, only
a stick for rudder and elevator, a throttle, and kill switch. I
estimate I flew it about 300 hrs (no hr. meter) over three years before
I sold it. It was a very stable plane to fly. Rudder input would
result in a momentary skid and then a nice banking turn. Release rudder
pressure and the plane would skid or settle back to level flight. The
wings had lots of dihedral. My MK III which was the quick build kit,
which means it was rigged at the factory requires me to fly the plane.
It appears to have little dihedral. Rudder input alone does affect the
banking slightly but rudder input alone would never get me out of a
steep turn. My MK III will settle back to level flight from a shallow
turn when I realese aileron pressure, but anything more than a shallow
turn requires aileron pressure to return to level flight. Maybe if the
holes in the wing struts wear I will have more dihedral and a more hands
off plane. :) But who wants to fly hands off? That's no fun! It would
also seem to me that more dehedral would result in less lift.
Terry Swartz
102 hrs. since 10/10/97 sign off.
>Terry Swartz
Terry:
I theeenk I screwed up by putting bushings in the lift strut fittings. Now
I won't have the luxury from inlarged holes to increase dihedral and fly
hands off. I told Bro Jim not to weld those darn bushings in there.
john h:
Terry Swartz:
The reduction of lift in changing a wing from 0 degrees to 3 degrees
dihedral in level flight is the cosine of 3 degrees = 0.999. Doubt if
we could detect such a change.
Also of interest regarding wing geometry: According to John Roncz, a
rectangular wing can be made to develop the "optimum" eliptical loading
with less than 3 degrees twist. Sure would have made it cheaper to
build Spitfires. Suspect the twist is nonuniform however.
Tom Kuffel
Subject: | Re: Flaps on take offs??? |
Hello Gang:
I do not have any scientific evidence of what I am about to say, OK. But I
do have a few hours in the MK III, mine and Kolb Aircraft's. I do fly
extremely heavy at times, and I do use my flaps on almost every landing and
on t/o when the situation calls for it. I do fly out of unimproved, muddy,
uncut, dirt, grass, and sand strips.
My MK III starts stalling about 40 MPH indicated clean, 38 with 20 degrees,
and around 36 with 40 degrees of flaps. In critical situations the slower
I can land the quicker I can stop. The slower I can fly and the quicker I
can loose altitude will and has saved my buns and the acft's getting into
extremely small areas surrounded by tall trees and power lines. On
landing, I use them to maintain proficiency on their capabilities, plus it
puts less wear and tear on the airframe to land slower and shorter.
Taxiing an acft on the ground, especially rough ground, puts terrific loads
on it.
One or two notches of flaps do not make for longer ground runs. I have
accidently taken off with full flaps on MK III and Sling Shot, usually at
Lakeland or Oshkosh, and the acft hops right off the ground.
Primarily, I use one notch, 20 degrees, to t/o rough, soft, short fields,
generally with obstacles at the departure end. Depending on the situation,
t/o with flaps drooped, or what I prefer (learned from the Alaska Airmens
Manual) Start ground roll with full throttle, at about 30 mph indicated,
snatch in full flaps, 40 degrees, and the MK III will pop right up out of
the mud, tall grass, extremely rough surface, sand, rocks, or what have
you. Immediately, but slowly go to first notch, 20 degrees, climb out
clear of obstructions, and slowly release flaps to clean configuration.
The advantages of this type t/o: Get unstuck from rough field early,
slower airspeed higher angle of climb, while maintaining the acft in a more
level attitude. The flaps pull the nose over.
On the way home from Oshkosh this year I spent the night at Darel Stoole's
ultralight strip in Washington, Indiana. It was raining when I landed just
at dark and it rained until the next morning at 1030 when I departed for
Alabama. My MK III was full of fuel, 150 lbs, camping gear, clothes, and
equip. Winds favored a take off the the east which was up hill. Strip
bordered by tall corn on the right and telephone lines and railroad on the
left. Felt like there was just enough width to clear my wingtips. Turf
strip was soft, wet, soggy (standing water in places) and up hill. I used
the 30 mph, snatch full flaps method of t/o. If I had not had that
capability I would still be waiting for the strip to dry out and the wind
to reverse directions.
I get the impression from some of the posts I read that flaps are there to
hang from the wing and aren't really good for anything except scare you
when they allow the acft to make rapid altitude losses and screw up
landings and landing gear by making you land high.
I firmly believe they are a tool that adds tremendous capability to an
already high performance STOL acft. I couldn't learn how to use them if I
had left them in the up position all the time. I had to experiment a
little at a time to learn to get the "goodie" out of them.
Suffering from diarhea (sp) of the mouth again, but it was the oly way I
could explain what I felt need to be said, on my part, about flaps.
PS: The stall figures above, are at altitude, out of ground effect. In
ground effect, as in landing, these numbers will be reduced even more.
Also in t/o's.
Thanks, John. It is nice to be have something to compare mine with. The
way I have mine adjusted is with a LOT of up, and not much down. I figure I
usually use more up elevator than down, unless I'm practicing my inverted
low level fly-by routine ;-)
Ron Carroll
Original Firestar
Date: Thursday August 27 1998 6:07 AM
Subject: Re: Kolb-List: Spongie elevator cable
>Ron,
>John
Subject: | Spongy elevators |
Hi Ron Carroll
Congratulations! I assume you have finished covering and painting if you're
now running in the engine.
Your spongy elevator problem is very interesting and after thinking about it
for a while, I agree with Ralph B. and others that it would seem to be a
broken cable strand.
However, if that's not it, check this out. The original FireStar uses a
different elevator control system than the KX/P and FireStar I/II. The
elevators use a horn (an 'L' shaped 4130 steel weldment consisting of a flat
piece welded onto a tube) which fits into the aluminum leading edge tube of
the elevators themselves. During rigging of the tail, you are to install (8)
staggered pop rivets in each, to secure these in place. You do have these
installed don't you? Otherwise the horns may be slipping inside of that tube.
And also, the flat part of the horns must lie firmly in against the elevator
control mechanisim, with a pin inserted, to secure the elevator horns to the
control mechanisim. There should be no excessive play here either.
I noted that you were concerned that excessive cable tension would cause the
hinges to wear out, but the hinges won't be affected because the cable tension
load is carried by the 1/4" bolt that the elevator control mechanisim pivots
on. The elevator horns are just going along for the ride in their respective
seated positions. But I also agree that it is not neccessary to have
excessive tension on the cables.
This almost seems like a puzzle or a quiz of some sort, so be sure to let us
know what you eventually find out.
Bill varnes
Original FireStar 377
Audubon, NJ
PS My FireStar is about 1 hour away from home and I hate to drive that
distance unless I am going to fly. We've had poor weather and now it's about
to get worse with Bonnie coming up the coast. But as soon as I can, I intend
to get down there to double check my elevator action and I'll let you know.
Subject: | Re: : Kolb-List:elevator travel , FireFly |
A while back I measured the elevator and hor.stab angles. H. stab, plane
sitting on level hangar floor, was 6 degrees up, using aircraft surface
bubble level. Elevator all the way down was 22 degrees. up was 14
degrees.
Stick throw was about 11" at top of stick.
Don't know what good these figures will do in helping find out about the
Elevator Problem.
grey Baron
Subject: | Re: wd: Re: Kolb-List:elevator travel , FireFly] |
Date: Thu, 27 Aug 1998 17:15:09 -0400
Subject: Re: Kolb-List:elevator travel , FireFly
degrees.
Elevator Problem.
grey Baron
Jon,
I also added "extra" dihedral when I built mine 11 years ago. The plans
called for 1" from level at the last outboard rib. I added 2-5/8" which I
think is perfect. The angle could be calculated since you know the length
of both sides.
Ralph Burlingame
Original FireStar 400 hrs
writes:
>chance to
>wanted.
>without
>Very interesting!!
>Jon
dwegner(at)isd.net
Ron Carroll,
John J. and I have 8" up elevator from neutral and that's plenty. If you
have more than that, you will be flying with a lot of forward stick and
it will be hard to reach sitting back in the seat.
I just got off the phone with my A&P buddy who has an Original FireStar.
Two things he had to say about your FireStar: 1) the fabric will tear
easier from LE to TE (or visa versa) on the wing due to its "bias ply",
but it will not tear easily in the other direction along the wing. 2)
this may seem like a "dumb question", but he asked if you had your
elevator LE rivets installed in the elevator horn? There are about 6
rivets staggered around the horn. Also, there was an update on all
Original FireStars to add a 2-1/2" aluminum gusset plate on the inboard
section of the elevator where the 5/16" tube meets the LE tube. This can
be added on the outside of the fabric like I did to mine. This adds
strength to the elevator-to-horn area. The gusset plate can be polished
to look good. Did you find any "give" in the pulley supports under and in
back of the seat? Lastly, take the elevators and move them in opposite
directions to see how much play there is between them. I have about an
inch of play which is probably normal. I hope this helps.
Ralph Burlingame
writes:
>The way I have mine adjusted is with a LOT of up, and not much down. I
>figure I usually use more up elevator than down, unless I'm practicing
my
>inverted low level fly-by routine ;-)
>Ron Carroll
>Original Firestar
>From: John Jung <jrjung(at)execpc.com>
>To: kolb-list(at)matronics.com
>>Ron,
>>for "sponginess" by pressingdown on the most aft corner with my thumb.
>>thumb lowered it 3 inches. Just to be clear, 3 inches lowered is still
5
>>no problem with needing more elevator control. I hope that this helps.
>>John
Subject: | Re: Spongie elevator cable (Dangerous) |
>Ron Carroll
>Original Firestar
Ron,
Please, not much down elevator can be very dangerous in certain situations.
Example, A sudden engine out during a steep climb out. You'll need all the
down elevator you can get like right now. People have "bought the farm" in
this kind of situation. Excessive up elevator will never do you any good as
you will simply stall the wing.
Concerned,
Eugene
Frank,
Hurry back! I hope retirement (the next phase in your life) is as much
of a kick for you as it has been/is for me.
Retired April fools day 1989
L. Ray Baker
Lake Butler, FL
>Frank,
>L. Ray Baker
>Lake Butler, FL
Dittos from me!
Retired New Years Eve 1984
And can't figure out how I ever had time for work
Ron Carroll
Two excellent thoughts on the matter, Eugene. Thanks!
Ron Carroll
-----Original Message-----
Date: Thursday August 27 1998 6:27 PM
Subject: Re: Kolb-List: Spongie elevator cable (Dangerous)
I
>>Ron Carroll
>>Original Firestar
>Ron,
>Concerned,
>Eugene
Ralph & John, I will readjust my elevator travel to 8" up, like yours are.
When sitting in it I have do have to reach out a ways to get the stick.
Uncomfortable!
Yes, all the staggered rivets have been properly installed, but I had no
knowledge of the inboard gusset plate. If you could sometime (no hurry)
give the dimensions I'll ad it to the outside, as you suggested.
Your A&P buddy's thoughts on the fabric tearing would answer my question,
because that is exactly what happened. Maybe I'm really not nutz?
Thanks again, Ralph, you have always been there for me when I needed help.
Gratefully,
Ron Carroll
Scott.Pierskalla(at)HBC.honeywell.com ;
dwegner(at)isd.net
Date: Thursday August 27 1998 5:32 PM
>Ron Carroll,
>Ralph Burlingame
> writes:
>my
>>Ron Carroll
>>Original Firestar
>>>Ron,
>5
>>>John
Subject: | Re: Undelivered Mail |
>Hey big Lar
I just got 2 messages bounced back to me.They made the list but one
member had his message bounce back to me.
Woody
From: | "Rutledge Fuller" <rut007(at)hotmail.com> |
Subject: | Puttin on the hours! |
Whew! I took off Tuesday and Wednesday to do some X-Country. Put on
7.2 hours in a day and a half. I have had my Firestar flyable for four
weeks and have racked up a total of 34.4 hours.
Subject: | Re: Puttin on the hours! |
Rut,
34 hours in a month? Wow! Do you have a card that says "HAVE
FIRESTAR, WILL TRAVEL"?
John Jung
Ron
I checked my MarkIII last night for "sponginess" after reading this
discussion and found the following.
Free play due to bolt between elevator horn and elevator control horn is
approximately 1/2" at the trailing edge of the elevators. This is
consistent with Ralph Burlingame measurement of 1" of differential movement
between elevators.
If I hold the stick ridged and have someone push on the elevator trailing
edge they can cause slack to form in the return cables when they reach
approximately 2 inches. The cables limit the further deflection when
approximately 3 inches are reached. There was no movement in the control
horn coupled to the stick or the push pull tube pivots at the extreme
deflection of the elevators. This last assessment is subjective because I
could not hold the stick still very well against the forces from the elevator.
One more sample for comparison
Ron
You are about as lucky as a friend who restored a Carrera and got it back in
the air the end of May. Since then he has racked up about 110 hours.
Lucky guys, I'll get even, but who know when?
Ron Carroll
Original Firestar
Date: Friday August 28 1998 4:43 AM
Subject: Kolb-List: Puttin on the hours!
Hi John,
>john h
A very reasonable question. Sorry I didn't think to include that information
the first time.
I raised the outer tip of the wing 10" above the inboard edge. This turns
out to be about 3.5 degrees I think. By the way, on my Firestar II that
means the lift struts needed to be 2-1/4" longer than the standard setup.
Because my plane is folded in storage, I can't easily measure at the
outboard rib at this time, but it will be about 9" or a little more.
You are right that I have given up a little performance. At the time, I
made some estimates and as I recall it was a trivial amount. The amount of
dihedral was not optimized, either. Because I had to purchase parts to make
the new lift struts, I made them at the longest I could imagine would be
needed so they could be shortened if needed. I liked the way it flew with
the 2-1/4" longer strut and did not experiment further.
As you can imagine, the wings are noticeably canted up. Some have wondered
if this is a problem in a cross wind with getting the wind under the wing
and raising it. I have set the plane sidewise to an 11 knot wind on an
airport ramp to see what happens. Then by trying to lift the up-wind and
down-wind wing tip, I decided the wind at 11 knots puts little lift on the
up-sloped wing.
Vince
Hi Gang:
Sounds like a young fellow I knew about 14 years ago. hehehe
Sorry I could join you. We'll get together soon.
Vince Nicely wrote:
Vince:
Have you had an opportunity to fly a Kob rigged to standard dihedral so you can
compare the flying qualities of both systems?
Would be interested to hear flight characteristics both ways.
I have no experience flying any acft with dihedral.
Subject: | Instruments for FS I |
After taking my USUA dual instruction and soloing, I decided after careful
consideration that my plane would be a FS I. After a short search for one
with low time and near-by, I was lucky enough to get a call from a gentleman
in Winston-Salem, NC who had a 95% completed FS ll for sale because of bad
health.
I bought the plane & trucked it back to SC. During the trip a box of parts
contacted the wing & it got a 6" rip chord-wise, on top, between the last rib
& wingtip. Could this be sewn up with a big curved needle & thread & then a
dacron strip glued over the seam & then painted, or what??
Am about to order instruments & am considering installing the following, L to
R:
EIS Digital w/ dual CHT, dual EGT, Tach, Hour meter
& some other stuff
ASI
ALT
COMPASS
Oh, yeah... I will install a 503DCDI w/ Elec. start. Can I fit all of that on
my panel?
Best source to get the EIS? Maybe direct from the manufacturer?
What brand for the rest? I see a bunch of different brands in UL Flying Mag.
& would like to know best bang for the buck.
Elec. starter... a friend has the GPL unit a swears by it, and I like the
idea of being able to also keep my pull-start. Any comments??
I'm thinking of using a Warp Drive 2 Blade Prop w/ the nice Hub; anybody got a
better idea?
If anyone has any suggestions regarding this plane I will certainly appreciate
them. Nota lot of Kolb owners this neck of woods to talk to.
Hope to be in the air within 30 days.
Howard Shackleford [Shack]
FS l
Lexington, SC
Subject: | Re: Instruments for FS I |
In a message dated 8/28/98 5:43:25 PM Pacific Daylight Time, HShack(at)AOL.COM
writes:
<< w/ dual CHT, dual EGT >>
Dual EGT and dual CHT are the key guages for preventing seizure. Seizure is
the principal thing that makes rotax engines stop when you don't want them to.
Guages are cheap insurance.
>careful:
Howard, regarding keeping the rope starter with electric start. Don't let
that be a factor in deciding what type of starter to get. You will find
that with the rope starter, it is impossible to restart a 503 while in
the pilots seat. And if your battery is dead before you fly, so that you
can't use your electric start. Than that problem should be resolved
before you fly anyway.
My 2 cents worth
Bob Doebler
To all,
I just saw the new (new to me at least) video that Kolb company has produced
to promote their different designs. It was about 23 minutes long. There
was a lot of good flying footage showing the best utility of each design as
well as some very good footage of builders/flyers recommendations presented
very sincerely and honestly about the planes and the company. Construction
and materials details were discussed with each design. It made me want to
build one all over again.
Later,
From: | "Larry & Karen Cottrel" <lcottrel(at)kfalls.net> |
Not necessarily so---- I got the one that keeps the rope, I like it.
Redundency is good on occasion. I hadn;t flown mine in a long time and I
use the (18 amp) battery to power my gas pump. Ran the battery down, rope
starter allowed me to fly. The charging system does quite well. It was much
like driving yur car to charge the battery. Its hard to get someone to push
start one of those suckers."-)
Larry
> From: Robert L Doebler <bobdoebler(at)JUNO.COM>
> Subject: Re: Kolb-List: Instruments for FS I
> Date: Friday, August 28, 1998 6:54 PM
> >careful:
> My 2 cents worth
> Bob Doebler
From: | "Frank & Winnie Hodson" <fwhodson(at)megalink.net> |
SHACK:
Congratulations on your choice of aircraft! About the repair of the six
inch rip: follow the STITS/POLYFIBER repair routine as outlined in the
covering manual. BTW if you order the polyfiber practice kit you will
probably have sufficient materials to complete the repair correctly.
One source for these is Aircraft Spruce East @ 1-800-831-2949
The Polyfiber practice kit is about $20 and probably includes the "How To"
manual, if not the manual will cost another $5 approx.
Frank Hodson, Oxford ME
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
Howard,
Take Frank's advice on using Stits patching methods. It is discussed
in the Stits manual that came with the kit. Needle and thread is worse
than useless here. I had a hangar (garage) mishap before my plane was
completed, which put a similar tear in my wing. I was able to patch it
so that I'm the only one that can find it. I used several iterations
of spraying polyspray and sanding around the patch edge to feather it in.
BTW, on your other choices, all look good to me. I personally would not
add the weight of a starter and battery on a 503. They rope start easily
and there is very little point in starting from the pilot's seat unless
you're on floats. Save those pounds for STOL performance! I have the
Warp prop with AL hub. I've been happy with it altho never flew anything
else on this plane to compare to. I've been told that a wood prop is
1-2 lbs lighter, and sometimes I've wondered if I woulda been happy just
getting wood. By now I rarely change prop pitch. For the 'money is no
object' prop, look at PowerFin.
Ben Ransom
http://mae.ucdavis.edu/~ransom
Subject: | Electric Starters and 2-strokes |
edu>
Howdy Ben and Gang:
If you want to have a restart capability in the air, I highly recommend a
"self comencer" as my old Ultrastar buddy, now deceased, Ed Davis used to
say. Reasons:
a. If you would like to play around at altitude, engine off, get a starter.
b. If, by chance, you should loose the eng at idle on a approach to final
and you see you are a little short, it is nice to be able to reach over,
hit the starter, and fly over the fence rather than thru it. Had it happen
in the Firestar at Roanoke Regional AP, Va, in 1989. Lucky I had all that
pavement under and ahead of me. Had to get out of cockpit in the middle of
this huge runway and restart to taxi tiedown.
My first eng off landing in the Firestar was not planned. Brand new acft
with a in seat, in air, restart capability. Shut down at 3,000, glided to
2,000, restarted with the trusty pull rope. That was great, could never
done that in the Ultrastar. Always had to land and get out and retart.
Climbed to 5,000 this time. Shut down, what a blast, glided to 2,000, time
to restart, eng cold as ice, noway, first eng off landing in the outback.
Luckily, I had planned for a possibility of no restart and was flying over
a nice sized hay field.
I think the added weight of the starter and battery will be like the 21 lb
prcht I have flown with since the first flight of my MK III. It is part of
the airplane, I don't know the added weight is there. It is convenient, it
adds to safety.
My own personal opinion, with much humility. hehehe
Subject: | Warp Drive vs Wood Props |
Hello again you all:
Just a quick word on Warp Drive and wooden props. I have used both quite
extensively. The ultimate combination on my Firestar was an original Jim
Culver two blade woode prop with inlaid polyurethane edge. It was a
perfect match up for my eng and airplane. CRS the pitch and diameter.
Only problem I ever had with this prop was common to most wodd props:
Balance. I made it a habit to paint all my naturally finished wood props
with flat black spray can paint. This covered those occassional digs from
FOD flying off the airplane and thru the prop. Easy to do and looked good
enough to win two grand champ awards and S&F and OSH.
My favorite prop to date is my Warp Drive prop. I flew the first for
around 600 hours and then put an 18 inch piece of 1 inch exhaust pipe thru
it at WOT. It dinged the blade (one) and that was all. It was a sponsored
prop so I sent it back for them to study (and the hub) and they sent me a
new one, which has over 600 hours on it. Had I not been sponsored for the
prop I would have gotten out the JB Weld, patched, sanded, and painted flat
black, and kept on flying. I am tough on airplanes and tough on props. If
you read my article about the 1994 flight you know what I am talking about.
I have never had to retorque or rebalance either of three Warp Drive Props
I have owned (had one on the MK III when I was powered by 582). It takes a
lot of irritating little problems out of flying. I do recommend the nickle
leading edge for rain and debris errosion of the carbon fiber blade. It
ain't nickle tape, it is molded in nickle sheet metal. If Warp Drive
didn't sponsor me with props, I'd buy one. They have a lifetime warranty.
Beautiful day in sunny Alabama, but it is too hot to play with Miss P'fer
today, maybe late this evening.
>Hi John,
>>john h
>the first time.
>up-sloped wing.
>Regards,
>Vince
Vince,
How has the extra dihedral affected cross control, like a side slip? Does
the rudder now overpower the ailerons?
EZ
Subject: | Re: Kolb Dihedral |
John H,
Please see comments below. I would be interested in how the experience I
relate below sounds compared to the variety of Kolb airplanes you have
flown.
Date: Friday, August 28, 1998 1:00 PM
Subject: Kolb-List: Kolb Dihedral
can
Yes. I flew my Firestar II for the first 39 hours rigged with the standard
dihedral, i.e., wing tips raised 1". I took a ride in the factory Mark III
several years ago, but really got no feel for it in a short ride. Have no
other experience in Kolb airplanes.
The airplane was tested for flight characteristics according to the
suggestions of Vaughn Askue in his book, "Flight Testing Homebuilt
Aircraft". I worked through his suggest procedures systematically, and by
the time I got to testing dihedral and such the airplane was otherwise
trimmed and flying according to expectations. I noted two undesirable
characteristics in the standardly rigged airplane. Below are some quotes
from my test notebook describing the behavior while it was fresh in my mind.
(N8233g) Firestar II With Standard Dihedral- Wing tips up 1":
Dihedral Effect. "As the plane begins to roll (left or right), a small
rudder input can correct the roll. However, if much rudder control is
needed, the input of rudder adds significant drag, the nose of the plane
comes up and the plane slows. Then, the roll will stop. However, if the
stick is pushed forward and speed is maintained, then the rudder is
effective in stopping the roll even at relatively large bank angles( say
30-45 degrees)" These notes remind me that I found the rudder effective at
controlling roll if I compensated for the extra drag. The notes do not say,
and I can not remember if it would recover to unbanked without aileron
input.
Spiral Mode. Askue says: "Spiral stability is the tendency for an airplane
to change its angle of bank in a turn". My notebook says of the Firestar
II, " When put in a shallow turn in either direction, the turn tends to
tighten with neutral controls. The amount of bank will double in about 10
seconds." Askue labels this as strongly unstable (divergent) and suggests
it is unacceptable because of what might happen if you were distracted at
certain phases of flight. Further more he suggests the main fix is to
increase dihedral.
Because the control pressures in the Firestar II are light and most of us
naturally use all three controls together, I suspect most people, including
myself, will not notice the above tendencies unless they both have a
carefully trimmed airplane and put it through the hands-off test
procedures.
(N8233G) Firestar II with 3.5 degrees Dihedral - Wing tips up 10"
Dihedral Effect: With the airplane trimmed, the rudder will cause the
airplane to bank and unbank in either direction without touching the stick.
The rudder works like this in all normal flight conditions up to at least 30
degrees, but I have not tested how it works in a steep bank. However, large
rudder inputs still noticably increase the drag, but they are not needed for
normal flight.
Spiral Stability: N8233g now maintains its bank angle or may slowly
decrease the bank angle with neutral controls.
I find that with the increase dihedral, N8233G will fly all day with only
throttle and rudder inputs and with hands off the stick. With hands on the
stick, it is little if any different than before the dihedral was changed.
For those who have flown Cessna airplanes, the directional stability and
rudder control are very similar to those of a Cessna 152 or 172.
>john h
Hope this makes sense. I welcome any comments or questions.
Vince
Eugene,
See below:
Date: Saturday, August 29, 1998 2:04 PM
Subject: Re: Kolb-List: dihedral
>EZ
I have noticed no effect on cross wind landings. I have landed in upto 10
kts directly across grass runway with no problem and did not need nearly
full rudder.
I do not have a good before and after comparison for slip to lose altitude
so can only comment on with dihedral. The rudder can overpower the aileron.
I can use full aileron and full rudder. Then, when the direction starts to
drift, I back off the rudder a little.
Do you use slips much other than cross wind landings? Do you find them
effect for losing extra altitude? I have not used them much, but perhaps I
should practice.
Vince
Vince and Gang:
Yourexperience flying the standard rigged Firestar sounds right to me. How
do you maintain pitch control when you are flying hands off in your
airplane? Is it stable in pitch as well as roll?
My MK III keeps me flying it all the time, however, there are certain
conditions where I can get it trimmed up in pitch, as in a climb, or
descent, and it will fly hands off, but no way will it recover from any
divergent roll from wings level more than a few degrees, and then iffy.
I don't mind this and have flown many XC hours, some over very boring
terrain, having trouble staying awake, even with an unstable airplane.
Probably get a good nap with a stable one. hahaha
I would like to fly a kolb with a lot of dihedral to feel the difference.
I maight like it.
Maybe Dennis Souder will have some comment on dihedral and Kolbs.
Thanks for your input, Vince. I appreciate it.
Subject: | BRS parachute mounting info |
re: Kolb 1997 Firestar II
A friend without access to the internet is a builder and flyer of the Firestar
II. He is interested in adding a BRS chute to his aircraft.
1. Which model is best for him given the following restrictions?
2. How would it mount? He is restricted to a maximum of 15" above the aircraft
as the Kolb is trailered, with the wings folded, to the flying site. Also,
as the wings are unfolded and folded each time he flies he is concerned with how
the chute would mount in the wing gap and still leave access for the pin installation
and removal each time the wings are unfolded and folded.
Any input for his followup and investigation would be helpful.
Thank you,
Chuck
(__) ,---------. NOTE: The preceding message was sent via Jaek and
(oo) | :\/: _ _ \ Jon's WWW mail cow gateway. That is to say, the
/-------\/_/ : :: :: : ) person who sent this message could in fact be an
/ | MAIL|| \_ ' '`-'`-'/ anonymous prankster. Even though this message was
^^ ^^ could have been generated by anyone in the world.
Please keep this in mind. Thank you! --Jaek (smit2204) and -Jon- (stei0302)
Thank you,
Chuck
Hello again,
First I'd like to say- get a starter, get a starter, get a starter!!!!! I will
never own another engine that must be started with a rope. I wish Ben had been
here to show me how easy it was to start my 503 today :-)
Now, onto the R&D news. As you may recall from my last message, after
installing larger jets in the carbs, I attempted to start the engine when the
rope broke. Today, I replaced the rope and hauled the plane outside to assume
the position (tied to a tree).
For some reason, the engine was very hard to start. Not only did it not want to
start, but the rope seemed like it took about twice the effort I'm used to. I
finally pulled a plug out of each cylinder to make sure there wasn't any extra
friction, and everything seemed fine. Once I put the plugs back in, a few more
yanks was all it took to get continuous noise.
Did the new jets give me the extra power I was looking for- silly question- of
course not. Today's static rpm was 6260, which is a whole 10 rpm more than the
stock Rotax muffler gave. The plugs looked just about perfect after the run, so
I can't imagine that I'm off by much on the jetting. I didn't even bother to
fly it. I also noted that the dead spot between 4300 and 5200 rpm was worse
than before.
What does this all mean? Probably the end of flight for my SS. I'm currently
planning to remove the engine for sale, drain the fuel, and fold the plane up in
the corner of the hanger. Either I'll find someone that wants to buy a
"SlingShot project" minus engine and registration for $9k, or I'll just plan to
get back to it with another engine after the RV-8 is finished.
Russell Duffy
Navarre, FL
Kolb SlingShot N8754K (no longer airworthy)
RV-8, 80587 (tanks-Yuck)
rad(at)pen.net
Subject: | Mojave, Ca. Kolb builer/pilot |
I need assistance in contacting a young man who lives/lived in Mojave, Ca., worked
at Advanced Composites, and flies to Kernville, Ca. from time to time. A
local Kolb builder/flyer would like to make contact to set up joint flights in
the Kolb's.
Any help would be appreciated.
Chuck
Subject: | Re: The end (R&D) |
> ...What does this all mean? Probably the end of flight for my SS. I'm
>currently
>plane up in
>the corner of the hanger. ....
Rusty,
C'mon man! You've still got a very nice aircraft. You're just kickin'
yourself in the a** because you spent some "discretionary funds" on an
experiment that doesn't seem to be producing the desired results at the
moment.
I'm not sure but didn't you crank-in some more pitch on your prop? If so,
your'e moving more air with the static RPM being about equal to what the
stock exhaust was but maybe I'm confused(?).
Of course it could be I'm overly optimistic - having sold my C2 today!
The new owner flew it to it's new home in Wichita and I just talked to
him on the phone, he and I are both very happy. Owning a Challenger is
like owning a boat, one of the happiest days of your life is the day you
sell it!
-Mick Fine
Tulsa, Oklahoma
http://www.angelfire.com/ok/froghair
Green Country Ultralight Flyer's Organization (UFO)
http://www.angelfire.com/ok/gcufo
Subject: | Re: BRS parachute mounting info |
My friend has same plane with a VLS 750.... it's a beautiful thing!
Howard Shackleford
SC
Subject: | Re: QD Pi [FS l] |
Hi, List. Thanks to everyone who responded to my inquireys about tear in
Stits, instruments, props, & electric start.
Since my good wife, Judy, was kind enough to pay for my new FS I, it will be
known from here on as "QD Pi", my wife's pet name. It's the least I can do....
After spending most of the day in near 100 degree heat at my airfield doing a
lot of hanger flying, I have concluded the following:
1. I'm a lucky man; found new friend at airport who will fix my rip in wing
[properly] including paint,etc. in about 2 hours.
2. Will go with Westach instruments except engine management by EIS
3. Will probably go with GPL Elec, starter , maybe Christmas.
4. Will use Warp Drive 3 Blade taper tip. I am a big 'ole guy & value STOL
more than speed.
5. I will BRS with VLS , maybe Father's Day.
6. I will have brakes with the hand lever instead of the heel deals.
7. I will send my muffler off to be coated with some exotic material but I
will not put on an R & D pipe.
8. I will probably go with a "C" Box, but I don't know what ratio with the 3
blade & what diameter.
Inputs appreciated...
FS l
Lexington, SC
From: | "Beauford Tuton" <beaufordw(at)WORLDNET.ATT.NET> |
Subject: | Bewildered (again) in Brandon |
Kolbers:
Whilst most of you are obviously out soaring like eagles and scurrying back
and forth between your aircraft and your PC to trade electrifying stories of
aeronautical prowess, or to argue the finer, more arcane, technical
niceties of Kolbesque aeronautical engineering, I feel compelled to point
out that there are some numbers of us miserable wretches out here
a'sufferin....
Some of us poor S.O.B.s is still a'sittin in the middle of the garage floor
in a pile what appears to be smashed-up aluminum lawn furniture, sweatin'
like pigs, swattin' at a perpetual cloud of gnats, fending off occasional
PMS-driven attacks into the garage from our ol' ladies demanding we clean up
this crap immediately, droolin' juice from yesterday's dried-out cigar onto
the now battered and fuzzed-up plans, marveling at artfully welded parts
that never seem to exactly fit, and trying (without success) to remember
exactly what day it was that it finally dawned on us that this airplane
building fit had assumed FULL control of what we had heretofore laughingly
referred to as our lives..."
As the more astute among you might have suspected by now, I gotta little
problem here, (am beginning to show the early signs of minor frustration,
gotta get a grip...) and I was hoping that one of you gents who had
successfully negotiated this particular process might be kind enough to help
me out with a bit of technical advice....
Building Firefly #76... The drag strut end fittings are too large in
diameter to slide into the drag strut tubes... Using my aerospace quality
precision (made in Hanoi, but passed off as Chinese) dial calipers, I make
the inside diameters of the two 1 x .125 drag strut tubes to be .750 in....
The outside diameters of the two end fittings which are supposed to slide
lovingly into the tubes are approximately .800 and .925 respectively...
(yep, they are different...)
I'll bet some of you are thinking, " that goon probably mixed up the
elevator horns with the drag strut fittings..." Naw, the goon checked that
first...... both of the ones in the elevators are the same size and fit
snugly into their respective .875 x .035 tubes... and besides, the plans
don't mention anything about different specifications for the two sets of
parts...
I tried to call the factory Saturday, but I was too late to catch anyone
there... So I thought I would throw this out to the collective wisdom of the
Kolb mafia and see if one or more of you would take pity on me and give me
an idea of how to handle this....Has anyone else experienced this? If so,
how'd you deal with it? Dennis, you out there...? Meantime, I'll just
open another warm beer and crawl off into the corner to gnaw on the assembly
manual binding some more... I'm beginning to like it....
thanks fer listenin'
Bill Tuton
Brandon,FL
Subject: | Re: Bewildered (again) in Brandon |
<< . So I thought I would throw this out to the collective wisdom of the
Bill Tuton
Brandon,FL >>
Bill, don't you dare give up!!!.....................and to think that when I
look back to '91 when I built my Firestar, I actually tell people it was one
of the happiest periods of my life....of course, I had the opportunity to
build it to the tune of Garth Brooks making his mark on history with "Low
Places"...............maybe that was really the reason for my fondness of the
period........or maybe my tubes actually did slip "lovingly" into one
another...............I can only remember the successes, I guess, and my
Firestar is still a real ramification of that singular effort that I will
always be proud of............. GeoR38
Subject: | Re: spins, was ... |
<< George, or GeoR38, I want to commend you on the upgrade you did on you
Frank M---- >>
I merely ask you , Frank, .....what's wrong with 1938?...............GeoR38
<< To all the Kolbers out there, After 40 years in the military
Frank Marino >>
Frank.......I'd like to say , I hate to see you leave us ............but I'm
afraid all this means is I will see MORE of you at the hangar..........we love
ya buddy........GeoR38
Chuck,
My Firestar II has the chute in the gap seal and it is only slightly
more difficult to insert the pins. It doesnt't take longer than 10
minutes to fold though.
John Jung
Firestar II N6163J 53.9 hrs
SE Wisconsin
>ceekstrand(at)lightspeed.net wrote:
snip...
Also, as the wings are unfolded and folded each time he flies he is
concerned with how the chute would mount in the wing gap and still leave
access for the pin installation and removal each time the wings are
> Thank you,
> Chuck
Subject: | Re: Dihedral Effect |
<< Also of interest regarding wing geometry: According to John Roncz, a
Tom Kuffel
as an afficiondo of the Great One (war)....I read somewhere that it took 3
times longer to build a Spitfire than an ME-109. ..........both very hi
performance craft!!....GeoR38
Bill,
If I remember corectly, I had to drill out my drag struts so that the
end piece would slide in. I recall it being a 3/4 inch drill, but I may
be wrong. It would be nice if the plans would give us a warning about
things like that. Sorry about the problem, but I did enjoy reading your
post.
John Jung
Firestar II N6163J
<< Jon,
of both sides.
Ralph Burlingame
Original FireStar 400 hrs >>
For stability, I also added 1 inch to each side...........hey!, can't
hurt!............GeoR38
<< Ron,
Concerned,
Eugene
"Already happened to me in a different airplane.....I
agree.....100%................GeiR38
Mick
Congrats - finally got rid of it. Does this mean the Kolb TS project will
speed up? Finished painting house yesterday!! Next project? To get back in the
air. Joe
John:
I considered drilling out the drag strut tubes, but thought that would
possibly weaken them too much, given the fair amount of material which would
have to come off the walls... that would be especially troublesome on the
one receiving the .935 inch (the larger of the two) fittings... I don't
have any feel for how much of that .125 wall thickness is actually required
to meet design loads... but I suspect almost all of it....
thanks for your thoughts; I may well end up doing exactly as you suggest...
Date: Sunday, August 30, 1998 4:46 AM
Subject: Re: Kolb-List: Bewildered (again) in Brandon
>Bill,
>post.
>John Jung
>Firestar II N6163J
George:
Naw, I ain't planning to give up... I wouldn't give my Bride the
satisfaction of watching me clear all this mess out of the garage.... just
so she could put her car back in there...
Actually I am fairly well along... everything is built and I'm to the point
of trying to hang and align the wings on the cage.... that's when I came
across this little inconvenience with the end fittings...which I am sure
will work out when I get a little more information...
By the way, congratulations on your retirement from the military... that's
an honorable thing for a man to do with his life and 40 years is sure one
helluva commitment. Hope retirement is good to ya.
Date: Sunday, August 30, 1998 3:58 AM
just
assembly
> Bill Tuton
> Brandon,FL >>
I
one
the
<< Building Firefly #76... The drag strut end fittings are too large in
(yep, they are different...) >>
Hi Bill,
You are correct, there are two sizes: the larger dia for the elevators, and
the smaller for the drag strut.
We ream the aluminum drag strut tubes supplied in the kit for the drag strut
fitting to fit properly. Either your drag strut was not reamed or you put the
reamed end at the outboard end.
Probably the best fix at this point is for us to make you a custom set of drag
strut fittings that will fit your tube. If this seems the best to you, let me
know and we'll send them out.
Sorry for the frustration this has caused.
Dennis Souder
Pres Kolb Aircraft
Hello again,
will
been
Ours usually starts in 4-5 pulls. I have heard from many who say it starts
with the first pull if you install a primer.
to
Possibly you installed a nylon rope instead of dacron. Nylon is like a bungee
cord, esp when used to replace a starter cord in a 503!
Oh no, Rusty - you didn't have to trade in your stock Rotax muffler system for
the R & D, did you??
Hang in their Rusty - don't give up the ship yet!!
Dennis Souder
Pres Kolb Aircraft
Just returned from a great little fly in at Tommy George's fly park a few
miles south of Springfield Illinois. I recommend it for next year. Our trip
there took 3 hours because of headwind and a thirsty Phantom requiring several
stops, the benefit is that you meet the nicest people on the way. A hundred
mile trip is my max but Gary Youngblood was there all the way from Kentucky
(How do you do that Gary ?) . I returned home the same evening with a non
stop flight of 1.7 hours and 5 gallons! One strange thing was that I stayed
at 3500 on the return trip to get smooth air but was suprised when passing
about 15 miles downwind of St.Louis when it got real rowdy until I was past
it. I suppose city's act like trees on a bigger scale out here in the
flatlands?
Dick C
Hey Bill,
If you're trying to cheer me up, it's working :-)
Rusty
>moment.
I'm just facing the fact that the SS isn't what I want to spend my time and
money on right now. Even if the R&D pipe had worked out to be everything it
claimed to be, I still wouldn't be happy. It's time to move on.
Yes, I added pitch, but this brings the prop back to a known point where I have
data from the Rotax system.
Glad to hear the deal went through.
Rusty
This may be true, but I took the original rope (not the skinny one included with
the SS kit) as a comparison. I also tried to compare the stretch from the
original to the new one. Either way, no more ropes for me.
I still have the original muffler, but what purpose would it serve to re-install
it? I'm bored with the plane in it's current configuration, and I'm unwilling
to spend the time and money to change it. Selling the plane with engine won't
get any more money since nobody really wants a 503 on a SS, and it will probably
open me up to more liability if I sell a complete "airworthy" plane. I can sell
the engine, pack up the airframe, then decide what to do with it while I'm
working on my RV-8. This still sounds like the most reasonable plan to me.
Rusty
Mornin' Dennis...
I should have known I would screw this up if there were any way an adult
human could do so... For whatever it's worth, the other ends of the drag
struts came pre-cut at an angle to fit against the spar at the lift-strut
fitting, so I son't believe I am working with the wrong end of the tubes...
As a matter of fact, both inboard tube ends do show signs of having been
reamed, but according to the better quality caliper and superior skills of
my retired civil engineer neighbor, they are only reamed out to .758. In
contrast, he measures the smaller of the two uninstalled fittings I have
here to be .803 outside diameter (with epoxy primer).
I would appreciate the custom fittings; I don't have the equipment to ream
the tubes out any further and I suspect that grinding on these 4130 fittings
is a non-starter for several good reasons... will ship them back to you.
One other question... Am still puzzled and trying to sort out the fittings
installed in the elevators, because I would be concerned about leaving an
undersized one in an elevator... They both seem tight and absolutely
identical in appearance. Looking through the holes drilled for the hinges,
I can see no significant gap between the outer aluminum tubes and the
fittings on either elevator. As an experiment, I then tried to fit the
larger of the two remaining uninstalled fittings (it measures .835 O.D.,
not .935 as my original message typo indicated) into the other end of the
.875 x .035 elevator tube and it isn't even close to going in... the
aluminum elevator tube mikes at .804 inside diameter, roughly what one would
expect subtracting the total.070 wall thickness from the .875 outside
diameter... Anyway, I plan to leave the two steel fittings installed in
the elevators, as is, unless you can see a reason to remove them... Based on
what I can observe, I wouldn't know which one to drill out anyway...
Thanks for your rapid response and kind offer... appreciate the fine
service... I think it's time to go mow the lawn and contemplate my
insignificant place in the universe...
best regards, I remain,Sir, yr hmbl svt....
Date: Sunday, August 30, 1998 10:14 AM
writes:
make
in....
>Hi Bill,
strut
the
drag
me
>Dennis Souder
>Pres Kolb Aircraft
Hello, Shack! My wife gave me a FireFly (Kolb) for our 50th wedding ann.
Looks like there are still a lot of GOOD women out there. At 75 I wanted
to stay legal after 56 years of flying (lost med) so am stuck with a 254
rocket. You'll really like the EIS. I have an airspeed and compass,
that's all you need with the EIS. No BRS as the Kolb is built like a
Brick SHouse, and I'm a reasonably good ( = quite a few hrs, accident
free) pilot.My heel brakes kinda bug me as I have VERY wide feet, so
land pigeon-toed!
Looks like you got it all planned out quite well. And you'll be as happy
as a sane person can get!!! And I like your usage of Good Wife, it's
mine too. Comes from Middle English.
Regards, Grey Baron
Hell, Rusty.... I left out most of the good part.... In addition to the
minor airplane business I lightly brushed over in the earlier note, I got a
prostate big enough to put license plates and turn signals on and drive to
work.....It tosses and turns in a manner totally independent of what I do at
night... (ain't slept 50 consecutive minutes in over five years)... The
computer is screwed up down at the Mr Greenlawn place and on Thursday while
no one was home, the stupid bastards rolled in here unannounced and
re-re-fertilized the smoking remnants of my so-called lawn for the third
time in three weeks... a man could roast a hotdog over my grass right now...
it stinks like a EPA superfund site, is turning the color of a peroxided
hooker's hairdo, kills cats before they can walk completely across it, and
it's all gonna have to be resodded... ($2,200...again)... While pondering
all this, my hoodlum son (the younger) and his bovine, loudmouth bride
gleefully informed me Friday night that they just lost their lease (again)
and we are once again about to be graced with their presence in the back
bedroom for an indeterminate period... AND my airplane is all over the
garage floor...
Now let me get this straight.... you sent off for the wrong muffler and
then your rope broke...? and for this you are gonna park a fully
functional, put-together, magnificent Kolb airplane in the corner, sell-out
and sulk.... forever???
Pull yerself together, man.... What if some civilian were to see you like
this......?
Bill (the aluminum butcher of Brandon) Tuton
Date: Sunday, August 30, 1998 11:39 AM
floor
up
onto
>Hey Bill,
>Rusty
Folks, I have an unused, never installed , rear enclosure wrap for a MK- 3
I need to sell, . I don`t Know what a new replacement goes for, But it
ought to be worth $20. 00+ Shipping to someone. !st response gets it ,
thanks . Jim
Subject: | Re: Kolb Dihedral, etc |
Vince,
I'm very impressed. I thought I was methodical about test flying my
plane, but compared to you I was a total hack. Good, useful notes!
Rusty,
I think you should save weight on your RV-8 by using a rope starter!
Make sure it is dacron, and maybe 1/2" diam. You may need pulleys or
maybe a wind up spring. :)
Seriously everybody, I think John Hauck's suggestion to use electric
start is obviously wise as a conservative approach. Having had engine
failure at idle on approach, I appreciate the "over the fence" instead of
"thru the fence" motivation for electric start. However, I personally
want to keep my weight within FAR103 "I wish" range, and will admit that
in general I am overly picky about adding any weight at all. I (try to)
fly every approach a bit high and slip away the excess. Hopefully this
will keep me out of the fences. I slowly come to idle at altitude to make
sure it will behave there, and rev it periodically during idle as well.
Obviously there are other engine-out scenarios where a starter won't save
your bacon anyway. Hope i won't embarrass myself now and report tomorrow
about "engine out/ fences hurt". This is a personal call whether you want
the convenience, in-flight start capability, and weight of electric start.
One other thing about rope starting... one of the best simple tips I've
heard (also on this list) was to blow on the little holes of the plastic
float bowl breather tube. Pushes fuel right in there, and she starts 1st
or 2nd pull. (haven't tried climbing up there to blow on it in flight :))
Anyway this trick has kept me from feeling compelled to spend my allowance
on a real primer.
Vince, your mention of rudder causing yaw and nose up, requiring forward
stick to maintain flying speed is same for me. Throw in a little
opposite aileron, and that's a slip. I run out of airspeed and forward
stick travel if I try to hold full rudder slip -- not a problem, just
a characteristic. This is similar to what you report about "rudder can
overpower aileron".
Beauford,
garage part gets in your blood and eventually (somehow?) becomes half
the fun ...well, maybe 1/3 :). Someday your lawn furniture will fly,
so hang in there.
-Ben Ransom
Subject: | North Florida Fly In Oct.24, 98 |
Kolbers, FYI
4th Annual Fall Air Festival 9 AM 10/24/98
Flying 10 Airport (OJ8), Jonesville, FL (Crow hop west of Gainesville)
Sponsored by Kitty Hawk Aviation and EAA chapter #98
Free airplane rides for kids under 12 yrs. R/C model airplane demo.
Williston Skydivers. FSS pilot seminars
Food and beverages available.
Newberry Road (FL 26) SW from Gainesville to flashing yellow light at
County Road 241 (NW 170th St) south approx 2.5 miles to SW 42nd Ave (lime
rock road to left) follow back to airport.
Noticed there is a Twinstar based at Flying 10.
L. Ray Baker
Lake Butler, FL
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Hey, Bewildered - - - - - This is probably academic at this point, since
it sounds like Dennis is working it out for you. ( Wish he'd send me that
motor mount, tho' ) Just for interest value, though, rather than taking
off metal - and thereby weakening an extremely critical part - what about
swaging the end slightly, to open it up enough to accept the fitting ??
Thoughts, anyone ?? Big Lar.
Hi Group: This isn't about Kolb's, but is about flying. A new
experience yesterday. ( Sat ) Went to a hang-glider/para-glider group in
San Bernardino and took a tandem lesson in a paraglider. What an
incredible ride. Launch at 4000', with a good breeze and 110' air. Lots
of lift. Took about 6 steps to get airborne, and hit lift right away. On
a 70 min. flight we got up to 8150' , which is apparently some kind of
local record for a tandem 'chute with a 200# passenger. A very solid +
secure feeling for anyone used to Ultralights. Would probably be a little
rough psychologically for a non-pilot, since you're hanging right out
there. A little bumpy, but all in all very comfortable and enjoyable.
Probably the nicest part was the almost total silence. Holding speed down
to about 12 - 15 mph makes normal conversation easy, with just a slight
rush of wind. If you like to fly, give it a try. Not that expensive, and
really gives a different view-point. Big Lar.
Still slooooowwllly working on that engine.
From: | "Vince Nicely" <vincenicely(at)intermediatn.net> |
John and others,
>Vince and Gang:
I rigged a spring loaded elevator trim under the seat on my firestar II. A
home made lever beside the seat on the left is used to adjust the tension on
the push/pull (door return springs from local hardware) springs attached to
the turnbuckles on the stick. With this simple rig, I can trim to speeds
between about 50 and 70-75 mph which is the range I use.
I had the chance to do some flying today. Because we had been discussing
this, I tried to compare the rudder induced roll and the aileron induced
roll. With modest rudder input, the roll is about as strong as with full
aileron. For example, I used rudder to roll into about a 30 degree bank to
the right and then reversed rudder to roll to about 30 degrees to the left
all with hands off the stick. The 30 right to 30 left took about 5 seconds.
I flew along a small river for many miles about 500 ft AGL. The plane was
trimmed about 55mph. I followed the river without touching the stick by
simply using rudder to bank to follow the river. Ocasional throttle
adjustments kept me in about a 100 foot altitude range. Then I needed to
turn from heading of about 210 to 360 to head home. Added right rudder to
initiate bank and left rudder to roll out on heading. Added throttle to
climb about 1000 feet to clear some mountains. In about 1 hour, I touched
the stick 1 time to aid in adjusting the elevator trim to adjust the speed
slightly. Because of the high pusher prop, throttle adjustments cause some
change in the trimmed speed. I didn't worry about that small change, but it
can be trimmed out if one wants. I really enjoy this kind of slow-low flying
with arms folded and watching the scenery pass below.
Vince
Hi Bill, The man I bought my FF #7 from had the same problem to the point
where he sold it to me. I got his nice collection of elevator and drag strut
fittings along with the kit. He had been working with the factory but was
unable to come up with a tight fit on either. There was considerable
difference in the tube sizes. You are doing the right thing by going to Kolb
because I think they are not able to control the exact diameter of the tubing
provided by their supplier. They should send you one (or two) that fits
because you are not the first to have the problem.
Don't get discouraged. Every truly great project seems like a total loss at
some point in it's development.
Two of us went for a 20 minute hop to a friendly grass strip this morning.
Mine scrambled up and blazed through the air like a homesick hornet. We were
there and back before we knew it. Great adventure.. Stay with it... Duane
From: | "Scott Olendorf" <olendorf(at)empireone.net> |
Date: Sunday, August 30, 1998 1:54 PM
Subject: Re: Kolb-List: Kolb Dihedral, etc
>overpower aileron".
I have found this to be true also. I have to release rudder to get the nose
down then apply rudder again to resume the slip. It's nice to know that this
just isn't my imagination and is a normal behaviour.
Scott Olendorf
Original Firestar, Rotax 377
Subject: | Re: South Ga. Fly-In |
October 9, 10, 11; 1998 Fri., Sat., Sun.
Thomasville, Georgia Fly-In
Located 35 miles North of Tallahassee, Florida
Lets see how many Kolb's can be there. Before we buy another microlight
(currently have a Challenger), I'd like to fly in a Kolb.
If you have one for sale, be sure and be there.
Thomasville is known as the Quail Capital of the World. Come back in
November for hunting. Check the city out at www.rose.net
>Kolbers:
Remind the ol'lady its keeping you out of the pubs and cat houses
Seems to me you have .025 - .080 of wall thickness you shouldn't have. I
had a mislabled tube and had to turn down a fitting, I've had tubes with a
tapered hole down the middle. Your numbers are to far off for any reworking.
Get ahold of Dennis to figure this one out.
Try some salsa with that it gets even better
Woody
Some men are able to stumble over the truth but are able to pick
themselves up and keep walking as if nothing had happened. (Churchill)
Thanks, Duane... good info. I'm not about to quit... these are nice little
airplanes and I want one...
appreciate your help...
Date: Sunday, August 30, 1998 6:52 PM
strut
Kolb
tubing
at
were
Duane
Woody:
thanks for the reply... I have a childlike faith that Dennis can come up
with the right size fittings, now that he knows the inside diameter of the
drag struts... It must be tough trying to cope with the variations in
materials from various suppliers...
FYI, that .925 was my typo... I corrected it in a later e-mail to
Dennis...shoulda been .825, but it was still bigger than the other one and
both are bigger than the holes they need to go into...
Salsa does help...
"...a Hun alive, is a war in prospect...." Churchill, May, 1938
"...a naked sheriff makes for a slow posse...." James Coburn, Water Hole
#3, circa 1966
Date: Sunday, August 30, 1998 9:13 PM
>>Kolbers:
floor
up
make
in....
I
reworking.
assembly
> Woody
From: | "Ron Carroll " <ron.carroll(at)WORLDNET.ATT.NET> |
Woody, the control cable that came with my kit was galvanized. I screwed
up a cable and I had to buy an 20' piece of stainlesssteel cable to
replace it with, and used the new cable for the down elevator control. I too
was curious about whether or not they had the same spongie feel so I swapped
them, and I get the same feeling with either up or down.
I have no play or give anywhere in the control system that could possibly
account for the feeling, so I talked an aeronautical engineer into giving
his opinion. He thinks that the stretch is normal for the length of the
cable and the leverage of the elevator vs. the control horn.
I guess I just tighten it up and live with it.
Ron Carroll
Original Firestar (seized rear cylinder during engine break-in)
Date: Sunday August 30 1998 6:11 PM
> I don't want to be a pest but could you tell me how the elevator feels
>when you give it full down stick .Is it still spongy?
> Woody
From: | Erich Weaver 805-683-0200 <sbaew(at)dames.com> |
Subject: | Re: Mojave, Ca. Kolb builer/pilot |
Autoforwarded: false
UA-content-id: 11C8F4E53900
Hop-count: 1
I cant help you with the name of the person you were looking for, but I
would also be interested in contacting him. I continue to look for
someone in the southern california area willing to give me a flight
intro. in the Mark III. Anyone out there.....?
Give Michael S. Michalski a call, he gives Ultralight Flight Instruction in a
Kolb Mk III, Lancaster, Ca. dry lake bed. e-mail is> msm000(at)aol.com
His web page is
http://members.aol.com/msm000/index.html
Hope this helps
Will Uribe
Building a FireStar II when ever I'm in town.
http://members.aol.com/WillU/index.html
In a message dated 8/30/98 8:44:17 PM Mountain Daylight Time, sbaew(at)dames.com
writes:
From: | "Jon P. Croke" <joncroke(at)CompuServe.COM> |
Subject: | FIRST FLIGHT News!! |
Greetings to all:
Thanks in part to the many contributors on this list, I made my very first
flight in my Firestar II this evening!
It was without reservation a most incredible experience.
Of course, it was a long road to this point. After countless delays in
construction over a 3 year period (!), and after an initial disaster with
an earlier first flight attempt, today's success did come with a price!! A
couple of months ago, I was attempting crow hops after completing the
plane. I had read the last 3 years worth of advice in this very forum
regarding the pros and cons of crow hops vs just taking off. Mostly
because I was just plain scared to make the maiden flight... I decided to
go with the crow hops. Fifteen minutes into this exercise, I flipped the
plane on its back after catching a wheel in some high grass. The controls
were very unresponsive at the slow speeds and you can imagine the feeling
in my gut after performing this manuever.... wrecked the plane and never
got to fly it! Never again. After replacing the nose and a gear leg.....
I headed to KOLB central and spent a few hours with Dan, the flight
instructor. No problem at all 'mastering' basic maneuvers in the Mark III.
Very valuable to have this experience... so as not to mix it up with the
feel of my limited experience in a C-172 (dont have my license, but have
reached the solo stage).
So today was the day... I was still really scared to take off.... all
psychological Im sure... but I powered up and pulled the stick..... would
this thing fly??? Didnt you wonder this when you took your completed plane
up for the first time??? Maybe I had put the wings on backwards!!! Or worse
the prop... There were a million reasons not to trust this..... Maybe it
would just flip over for no reason and end up on its back again..... I was
scared.... But...... No surprises.... It went up.....and up.. It was
soooo thrilling to fly for the first time in this plane..... Now... could I
land???
Once again, I was pleasantly surprised.... maybe beginners luck... but it
came down soo smoothly.. a little bounce but so uneventful... and I parked
it for the day because it was time for a new pair of pants.... just
kidding.
So the moral of my story is this for those of you who will someday fly you
Kolb for the first time.... NO crowhops...I think you're asking for trouble
and Ill show you what can happen (or just order a second nose cone and
some gear legs in advance-- they now come specially packaged as the 'Crow
Hop experimenters Kit' from you nearest Kolb dealer ; -) ) Get some time
with a Mark III or the like.. (taking a lesson from Dan at Kolb was fun and
rewarding... a very nice no nonsense guy) and... ENJOY!! Now these words
of wisdom have previously been posted in this list... Im just repeating
them with my endorsement.
Great thanks to the many contributors to this forum that kept my interest
up for over 2 YEARS of building... thats a long time and a lots of
messages..... lots of great advice and insights into the many aspects
invovled with building/flying. That first flight is a big 'hump' to
cross... Hey Dennis: your plane really flies...... I guess thats not
news.... I mean it flies even with ME at the controls... I wasnt sure of
that til today.
One technical note/question... What seemed odd was that in my turns it
seemed that I was being pulled out of my seat... too much rudder?? my
little slip/skid indicator basically did not move so it was hard too tell
if that was it.... but it was strange to feel that 'pull' that strong....
Thanks to all
Jon (near Greenbay, WI)
Bill,
Jerry Bidle here. We build our FireFly #17. I don't seems to recall any
problem on ours with the drag strut fittings. They and the tubing matched.
I would reference the plans and verify what size tubing it says it should
be. Sounds like to me they shipped you a part that may belong to a
FireStar. You know what that means, call the factory and have them ship
you out one or two of what you should have. Verify you have the correct
tubing (diameter and wall thickness).
Also check how many feet of the tubing you have for the wing struts. They
sent us 1 long piece and 1 short piece. The longer lenght in only long
enough to get 2 lenghts of the required lenght, not 3 so we had only enough
material for only 3.
Since our wings are closed up I can't get into measure the fittings but
again refer to the tubing size on the plans. I suggested to Dennis they
need more detail drawing for identification of the steel parts.
Good luck,
Jerry Bidle
snip....
>parts...
>Bill Tuton
>Brandon,FL
That really sounds GREAT !!! Good for you, my envy is showing.
Big Lar.
> From: Vince Nicely <vincenicely(at)intermediatn.net>
> Date: Sunday, August 30, 1998 2:38 PM
> John and others,
> >Vince and Gang:
was
> Vince
From: | William V Rayfield <rayfiwv(at)mail.auburn.edu> |
Rusty and all,
I spoke with a guy from Jones Lite field this weekend. He has a Clipwing
Challenger 1 with a 447 and recently put a R&D pipe on it. He originally
needed a new prop to get more RPMs. He bought the pipe figuring he could
get the power with a little less $. Well, $400 later, he has lost 8mph
cruise and top speed, no gain in RPMs or power, and has a very peaky
engine (RPM gaps as Rusty described). He is trying to send it back since
they guy at R&D said he'd pay back if he wasn't satisfied. Apparently the
info. being distributed about these pipes isn't accurate.
Bill Rayfield
"I'm not smart, but I sure am slow!"
Mechanical Engineering Student
Auburn University
"War Eagle"
On Sat, 29 Aug 1998, Russell Duffy wrote:
> Hello again,
to
I
so
> than before.
in
to
> Russell Duffy
> Navarre, FL
> rad(at)pen.net
Bill,
I only removed about .010 with the drill. Don't even consider
drilling out enought to make both parts fit. Call Kolb and get the right
parts, first. Then if you have a slight clearance problem, you may need
to drill.
John Jung
Ben writes:
> By now I rarely change prop pitch. For the 'money is no object' prop,
> look at PowerFin.
I just checked the Powerfin pricelist page at
http://www.everett.net/users/expat/order.htm
The price listed for the three-blade 66" with hub and all hardware and
pitch-setting tool is still $430, the same as it
was when I purchased it two years and 53 operating hours ago.
How much does the similar (3-bl, adjustable, ~66") Warp product cost? My
recollection is, it was higher than 430.
Ben, I bet you were thinking of the SPORT PROP which, last time I checked, was
over 700 bucks (3-blade, gnd-adjust).
Has anyone recently received a price on the AirPlast props? If so, can you
post details please?
I am curious because they seem to be built for Ultralights, but marketed only
in Europe.
Jim Gerken
Bill,
Can't help you with the building stuff, but it sounds like I should
gather the troops and fly to Brandon. We could take you up in one of
the two seaters to put you back into perspective.
Best O' Luck,
Rutledge Fuller (37.2 hrs in exactly one month)
Looking for any excuse to X-Country!
----Original Message Follows----
From: "Beauford Tuton" <beaufordw(at)WORLDNET.ATT.NET>
Subject: Kolb-List: Bewildered (again) in Brandon
Date: Sun, 30 Aug 1998 02:01:25 -0400
Kolbers:
back
stories of
point
a'sufferin....
floor
sweatin'
occasional
clean up
onto
laughingly
frustration,
help
quality
make
in....
slide
that
of
parts...
the
me
so,
just
assembly
Bill Tuton
Brandon,FL
I thought that Thomasville was the weekend of the 17th?
Date: Sun, 30 Aug 1998 20:32:04 -0400
Subject: Re: Kolb-List: South Ga. Fly-In
From: | Cliff and Carolyn Stripling <striplic(at)dfw.net> |
Subject: | Re: FIRST FLIGHT News!! |
Jon and all,
Gotta be more specific about that feeling... I am no expert with Kolbs, but
I have a hunch... I felt a similar feeling the first couple of hours I flew
a Kolb and have more or less eliminated it with the help of a yaw string.
>My little slip/skid indicator basically did not move so it was hard too tell
Slip/skid won't indicate just a yawed attitude as far as I know. Get you a
piece of black thread 5" long and tape it to the center of the canopy. On
the centerline up the canopy where the string would be when flying straight
put a tiny piece of black tape as a marker. In a pusher and especially in a
plane that has no fuselage to speak of, the yaw string can tell you a bunch
about what is happening with your plane. You can't tell any other way when
you are flying... except that funny odd feeling that something is not
entirely "all right" that you can't quite describe.
I think the "odd unusual" feeling you are having has to do with is flying
yawed and making turns from or in that attitude... which is very common
(mine at least) in a Kolb (with no fuselage to speak of). Having the yaw
string will help you keep it straighter. Note I say straighter... 'cause I
don't think it is necessary to be absolutely straight - just close. Flying
completely straight requires a good bit of rudder sometimes and I think the
drag of the rudder is greater than the drag of flying a little crooked. It
is not any big deal with me... as long as I am in the ball park.
You will find yourself using some left rudder a lot of the time - some more,
some less. I have a habit of leaving the weight of my left foot on it all
of the time with about 1" depression of the lever. Probably ought to get a
trim tab, huh?, but I don't want to mess up the lines of the pretty rudder.
Entry into left turns requires some rudder. Entry into right turns requires
none. That is the case with my MKIII. Single place Kolbs might fly different.
Any comments welcome.
Congrats on the first flight!
Cliff & Carolyn Stripling Him: Retired Pharmacist
(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas
and Marble Falls Texas Both: 5th Wheel - RV - Travel
Kolb MKIII - N582CC (50.5 hrs)
"So the moral of my story is this for those of you who will someday fly
you
trouble
'Crow
time
with a Mark III or the like.. "
I couldn't agree more. Crow Hops are for the BIRDS! Fly the damn thing
and setup for a good approach.
Rut Fuller
Tallahassee, Fl.
Bill and Gang:
I have been watching with interest the pursuit of power with after market products.
IMHO Rotax puts about as much performance in their engines (2 stroke) as they can
and
still keep them reasonably reliable. To me an airplane engine can be compared
to an
industrial duty engine that must put out close to its maximum power most of its
usable
life. We would not think of putting a torquey, highly modified engine, to work
trying to generate emergency power for a facility. I want something I can rely
on to
keep me flying. Would not want to fly with a motocross engine, not very high anyhow.
I haven't heard anything good about this pipe, but that doesn't make it so. I
may be
wrong though.
Must be a different story with the 912, 912S, and the 914. All three models use
the
same basic engine components and increase output by increasing displacement or
turbo-charging. If Rotax feels confident about increasing hp on this engine, then
I
feel confident that my old 912 (at the bottom of the performance ladder) should
keep
on going if I keeep on feeding and taking care of it properly.
Just rambling around in Central Alabama,
William V Rayfield wrote:
> Rusty and all,
> Bill Rayfield
> Auburn University
> "War Eagle"
Jon,
Congratulations on that first flight. I missed that kind of
excitement with mine because I had been flying an original Firestar for
3 years before flying the Firestar II that I built. Also, welcome to the
"fast growing" Wisconson Kolb group. This summer at the all state
ultralight fly-in, Kolbs out numbered all other manufacturers. I look
forward to see your plane at a future fly-in.
John Jung
SE Wisconsin
Subject: | Chicken Little here - old and not bold. |
To all,
I would advise anyone getting a couple of hours in a Kolb two place before
making their first flights. I got 10 hours dual in a J3 Cub (for bi-ennial
and tail wheel endorsement) and 2 hours dual in a MK II before I took my
first flight. The Kolb flew a LOT differently (not more difficult, just
different and I can say that about all the other planes I have flown as
well) than the Cub and doesn't fly like any other kind of plane I ever flew
(Cessna, Piper, or T6). I needed every bit of that instruction because I was
a low time pilot (150 hrs) and it had been 11 years since I had flown
anything. I keep saying it (the Kolb time especially) was the best money I
ever spent and the best insurance you can buy. Do it even if you have to
make a special trip up to Phoenix, Pa. and fly with Dan.
Later,
Bill,
It occured to me that you measured over the epoxy primer. I masked
mine off before painting with epoxy, because there was no room for the
epoxy. Also, the reason that I had to drill the tube is that I used new
tubing rather than a Kolb part. I didn't even know that they reamed the
parts. But it is consistant with the way Kolb takes care of most all of
the difficult things, leaving the fun for us builders.
John Jung
Firestar II N6163J
SE Wisconsin
Subject: | Slip/Skid Indicators and Yaw Strings |
Morning Gang:
Slip/Skid Ind and Yaw String should give same
info, whether you are slipping or skidding in a
turn. Step on the ball to center and get in trim,
or step on the rudder pedal opposite direction of
string to center and trim aircraft.
I use a yaw string temporarily to cross check my
slip/skid indicator to insure it is mounted level
with the roll axis of the airframe. Most accurate
I have found and cheapest.
A slip/skid indicator should also be mounted so
vertical axis of gauge is perpendicular to your
horizontal line of flight. In other words, the
sucker should be straight up and down.
I believe if you feel you are being pulled from
the seat you are skidding, trying to make flat
turns, but you may also get the same sensation if
you are slipping. I'll have to go fly and see for
myself of the slipping side.
johh h
Subject: | Kolb flying formations |
Group,
Last evening I got a chance to fly with a couple of other Kolbs. One
was an Ultrastar, the other an original Firestar, and mine is a Firestar
II. We decided to fly to a small airport about 20 miles away. I hadn't
been there for about 8 years, so I figured I would follow them. One of
the others had never been there, and the third guy had been there this
year. Also no radios. Off we went until without any real discussion of
altitude, speed, or flying positions. The first problem we had was
keeping in visual contact. Keeping the other two planes in sight didn't
mean that they could see me, because of the high wing blind spot. Then
the leader circled back, the other went into a climb and I lost sight of
both. It took me 2 to 3 minutes to find them and even then they kept
changing directions, circling around. I couldn't imagine what they were
doing. Finally we all got going again in generally the right direction.
After a while, they seemed to be going too far to the west, so I pulled
out my GPS and took my own course to the airport. They kept me in sight
and we all landed. We had a good laugh talking about the unorganized
formation that we had just flown. What had happened is the leader was
depending on his GPS and the batteries had gone dead. He was looking for
someone else to take the lead, therefore all the circling. We discussed
the problems with maintaining visable positions and had a much better
flight back. Flying with other planes is fun, and flying with other
Kolbs is even more fun. Oh, I should add, we cruised at 55 mph and 1,500
AGL.
John Jung
Firestar II N6163J
SE Wisconsin
John Jung
From: | "Christopher John Armstrong" <Tophera(at)centuryinter.net> |
Congrates! I have been building for 5 years and have only gotten about
halfway! I am a firm believer in getting away from the ground on first
flights as the ground is very hard!
As far as the floating in turns you might be inadvertently entering some
forward stick in the turn with the side stick. you probobly want to be
pulling back some t maintain lift in the bank, so pull some stick in the
turn and see if that helps.
topher, now on a pentium II 400 mhz graphics monster!
where are all those kolb pictures I couldnt upload on my antique Mac!
-----Original Message-----
Date: Monday, August 31, 1998 12:08 AM
Subject: Kolb-List: FIRST FLIGHT News!!
>Greetings to all:
>land???
>kidding.
>that til today.
>Thanks to all
Subject: | Covering the Wings MKIII |
I am covering the wings on my MKIII and at 250 degrees the ribs took on
a noticeable bow. I stopped at that heat but am wondering if having a
curve in the ribs is OK. Any comments?
In a message dated 8/29/98 11:06:45 PM Pacific Daylight Time,
beaufordw(at)WORLDNET.ATT.NET writes:
<< Has anyone else experienced this? >>
Yes. The same thing happened to me on my mark 2. I wound up paying a machine
shop to ream out the bushing the fitting went into. It was a real pain in the
butt. The other similar problem I had was welding residue inside of tubes
that the manaul wanted me to put other things into. Welcome to the wonderful
world of homebuilt aircraft.
Subject: | Re: Kolb flying formations |
It makes the flight a LOT more enjoyable to agree on flying positions.
Low wingers should be slightly below, high wingers above, all within
a couple hundred feet altitude, and usually flying in a line more or
less wing to wing (with ample spacing) is easiest. Fooling around to
keep track of where everybody is is annoying and can be dangerous.
To be really good, agree on a wing wobble signal to mean "landing
and I'll catch up " and a yaw wobble to mean "landing, need help".
Finally, trading phone numbers seems really over-cautious, but if you get
somewhere and somebody aint there, it is nice to be able to check if they
made it *somewhere*. I went on one of these disorganized XCs 2 years ago
and one guy was unaccounted for for 24 hours. He was lucky he survived,
and it all started by him getting lost. BTW, if somebody has a GPS, that
doesn't make them Charles Lindbergh. You might ask them if they have the
destination and waypoints keyed in, as well as ...uhhhhh batteries?!!
My experience is the GPS guys only have "their favorite" destinations
keyed in, and the Dead Reckoning guy has the specific route mapped out
to a T. BTW, DeadReckoning assisted by a GPS to hit waypoints right on
and exact edges of controlled airspaces is kinda fun.
Ben Ransom
UA-content-id: 11C8FA3A3800
Hop-count: 1
Thanks for the tip regarding Mike Michalsky, but Ive contacted him and he
indicated he does not own a Mk III - he has another Kolb model. I guess
he might coceivably be the Kolb builder that the original e-mail was
asking about though.
Any other southern California Mk III owners out there???
The date posted Oct. 9, 10, 11th is correct for the Thomasville
Fly-In. To confirm call the airport at 912 225-4313. We are giving
ample notice so you can make your plans to attend.
> From: John <redhill(at)rose.net>
> To: kolb-list(at)matronics.com
> CC: jajvann(at)hotmail.com
> Reply-To: kolb-list(at)matronics.com
Subject: | Re: Chicken Little here - old and not bold. |
May I ad a big AMEN to getting a few hrs at Kolb! I had to drive 200
mi, but every mile was worth it. I've got more than few hrs in a lot of
much bigger aircraft, but Dan knocked all of that outa me! Take-offs
about the same as a high-performance AC in slo mo, S&L ordinary enough,
but those diving-to-the-deck landings were A Lot Different. Dan is a
mighty fine instructor (unpaid ad!) and most certainly worth the price
and the trip. Better than buying gear legs, nose cones and plaster for
body casts. GB, flying my FF on my 75th BD today.
Pee Ess. Put a plexi trim tab on the "lovely" ruddersaves a lot of
footwork.
From: | Ben Ransom <ransom(at)mae.engr.ucdavis.edu> |
Subject: | ASI on a full enclosure FS |
One of my big aggravations has been a totally loused up ASI since adding
side panels to my FS. The pressure drop inside the cockpit "sucks" in
terms of screwing up what used to be an ASI very close to TAS.
Well yesterday I tried a new location for static source and GOT IT!!!!
Even better, it is without any gory construction agony or mess. There are
little clam shell openings on each side of the fiberglass nose cone where
it overlaps the front 10" of Stits covered sides. I used a nylon T
from the static port to 1/4" plastic tubes to each side, ending inside
these pre-existing clamshell openings.
My indicated stall speed has moved up from 28 to 35. I only roughly
cross checked that w/ GPS so don't really know yet how accurate the low
end is, and don't really care, because 35 was very repeatable. I think
probably 35 might be more correct than 28. BTW, while checking this I
did the full aft stick controlled straight flight thing. It's wierd.
Anyway, 50 and 60 indicated is just 2 mph faster than TAS, and 70-75
indicated is ~4mph faster than TAS. A little too windy to be positive,
but it was very very close. Hallelujah! Without a trusty ASI I had
fallen off in my ability to do a slow short final to a short spot landing
...had just been coming in conservatively fast, then holding it off for
lots of runway length until it touched down. No finesse in that.
-Ben Ransom
A new completion FS was damaged badly near here last week, in large
part due to the unexpected behaviour of an R&D pipe.
He was on a narrow strip (another mistake), and got fouled up when a
change in yaw occurred due to the engine fading in tht 4000 rpm dead
band, and then yawing back when it hit upper rpm. (This was on a high
speed taxi test.) Caught a sage brush, then a wing tip. He'll need
to do cage repairs from ripped out landing gear on one side, plus re-do
outboard portion of a wing. He's sick about it, almost literally.
I guess we're all pretty clear on R&D by now, eh?
Ben Ransom
http://mae.ucdavis.edu/~ransom
Chris, re ur old Mac. What model, $, location. My 85 yr old sister has a
bad case of SadMac and may need another CPU. I'm at
ronoy(at)shentel.net thnx Bob N. aka Grey Baron
From: | "Wayland, William C." <wcw2573(at)eagle.sbeach.navy.mil> |
After much searching for a local source of this stuff I happened to be in
San Diego last week and called all three of the Car Quest / Southern Auto
Supply stores. Got two "never heard of it" and one "got plenty". Hit was
the store at 7832 Armour St. San Diego, CA 92111 (619) 277-4896 at $2.99
per pint can. Bought 6 cans and plan to give some to friends with ULs.
Chris Wayland, FireFly s/n 008
Seized my engine during the break-in. I guess I failed to watch the temps
close enough. Besides, it was over-revving, i.e., engine rated 35 hp @
6500 rpm, but full throttle showed 7400 rpm with the original Culver prop
(66 X 23 ). I realize that I was careless in not shutting down the engine
when this occurred, but I goofed. What should the static rpm be with this
engine/prop? Could it have been *cavitating* ?
My question is in regard to a couple of posts from a while back about buying
pistons at somewhere around half price from a Ski-Doo dealer, if you have
the Ski-doo model numbers, etc. Can anyone refresh my memory on this?
Ron Carroll
Original Firestar
Subject: | Re: Rotax pistons |
In a message dated 8/31/98 11:26:54 AM Pacific Daylight Time,
ron.carroll(at)WORLDNET.ATT.NET writes:
<< My question is in regard to a couple of posts from a while back about
buying
the Ski-doo model numbers, etc. Can anyone refresh my memory on this? >>
Ron: Are you stil under the rotax warranty? If you are you can just toss
it in their lap.
>it in their lap.
I don't think I'd mention that 7400 rpm thing :-)
Rusty
> Ben Ransom
Ben and Gang:
I agree wholeheartedly. Learn pilotage and DR before you get addicted to the
GPS. Then when you start using the GPS, keep the sectional out and follow along
on it.
On the way to OSH took off from Kankakee, Illinois, Frank Beagle's home base, and
my GPS would not acquire satelites. So immediately to DR (dead reckoning) in an
area that ain't DR friendly with a guy who has become lazy with his navigation
and
left it all up to the GPS for too long. I found out quick I couldn't fly direct
to Joliet cause I didn't have tghe heading and my mag compass never has been much
good except for finding the rising and the setting sun. I luckily had the
Kankakee River that would take me to the big 4 lane highway which ran right beside
Joliet AP. A minute or two before I landed at Joliet, the GPS decided break was
over and started working again. Greatest thing going for XCs, but can get pme
om
trouble if depended on too much.
ONe thing I noticed real quick, I didn't have that constant feeling of checking
the ground speed, cross track error, etc. All I had was the compass, ASI, and
terrain features. Took a lot of hurry out of XC'ing. Hadn't had that feeling
for
a while.
Rambling again,
Ron,
I used a 66 X 28 on my 377 after I took the Warp off. It came from
Kolb and was the recommended prop for the 377. It wouldn't allow the
engine to rev more than 6,000 static. The over-reving was probably your
problem. 6,500 should be used as MAX static rpm.
John Jung
writes:
Do you mean to type 66 x 32?? A 66 x 23 would certainly overrev. A 66 x 32
may or may not overrev depending upon how much it varied from the norm. You
also might want to check your tach - getting a backup reading from a light
tack would be helpful. You static rpm should be between 6000 and 6400.
You may need more than pistons, the cylinders can get oval when heated too
much, this needs to be corrected.
Dennis Souder
Pres Kolb Aircraft
From: | bobdoebler(at)JUNO.COM (Robert L Doebler) |
Jon
If you want to know if your turns are quartenated(sp). take it from an
old glider driver. Use a yaw string. Tape about 4" of yarn on the lower
portion of your windshield, right in the middle. If you are yawing in a
turn, the taped end of the string will point to the rudder petal you need
more of.
<< We had a good laugh talking about the unorganized
someone else to take the lead, therefore all the circling. >>
Reminds me of a similar incident Bill Martin, one of the Kolb crew, and I had
one time on our way to a local fly-in about 40 miles away. We took off in our
UltraStars and enjoyed an extraordinarily beautiful flying morning. I was
following Bill's lead as we meandered over the countryside, not bothering too
much about where we were because I was just following Bill. After an
appropriate length to time I saw Bill point to an airport below. We circled,
checking it out, and then landed. I didn't think this airport was our
destination so after engines were turned off, I asked Bill where we were. He
replied, I don't know, I was following you!
Dennis Souder
Subject: | Re: Spongie elevator cable (Dangerous) |
>Thanks,
>Ron Carroll
I wished I lived down in your neck of the woods I'd like to see this. Keep
checking there has to be something.
Woody
Subject: | Re: Covering the Wings MKIII |
Do you mean the ribs curve from tip to root? You may be able to bring it
back by ironing the concave side of the bend to shrink this side and even
things up.
Did you try to tighten the fabric by hand as you put it on? It should be
somewhat loose so you can shrink it to the max allowed by the fabric to "set"it.
Woody
>>it in their lap.
>Rusty
I think they will know.
Woody
Thanks Rutledge...
I appreciate the kind offer, and would dearly love a ride in one of the two
seaters... but rest assured, my Bride of roughly 33 years has an uncanny
ability to instantly snap me back into the reality of precisely where I fit
into the cosmos... as well as retuning my sense of appreciation for why I am
in it, about every 30 minutes or so.... give or take.... It gives a man a
sense of... well... belonging... ya know??? It also keeps my nose in THE
KIT...
Never fear, I'm gonna make this assortment of junk and rags into an airplane
if it takes all night...
Thanks for the note... will take a raincheck on the kind offer for the
missionary visit...
i can do this..... choke.... sob!
Date: Monday, August 31, 1998 9:04 AM
>Bill,
>Best O' Luck,
>To: "kolb List"
>Kolbers:
>back
>stories of
>point
>a'sufferin....
>floor
>sweatin'
>occasional
>clean up
>onto
>laughingly
>frustration,
>help
>quality
>make
>in....
>slide
>that
>of
>parts...
>the
>me
>so,
>just
>assembly
>Bill Tuton
>Brandon,FL
<< Now let me get this straight.... you sent off for the wrong muffler and
this......? >>
you forgot the Wild Rabbit ran away with your shoes!!!................GeoR38
August 20, 1998 - August 31, 1998
Kolb-Archive.digest.vol-av
