Kolb-Archive.digest.vol-bc
November 16, 1998 - November 29, 1998
lindy(at)snowhill.com, kolb-list(at)matronics.com
Subject: Quincy BBQ
Date: Nov 16, 1998
This weekend,Saturday, Novemember 21, we will be having a BBQ at Quincy Airport off of Hwy 12. Due to liaibility issues, this is NOT a fly-in, just a bounch of people interested in aviation getting together and having fun. See you there, Rutledge Fuller (850) 413-8272 ________________________________________________________________________________
From: "F J MARINO" <FMARINO(at)netlink1.nlcomm.com>
Subject: Re: My Engine Rebuild
Date: Nov 16, 1998
Would you consider rebuilding a 582, when its time. I live 15 minutes from Green sky Adventures the oldest Rotax dealer in the USA and maybe having him rebuild but that might be about $1000 or more. How much trouble was it actually to rebuild I'm thinking about going to the Votec for small engine repair to get ready for when my engine goes TU. What do you think. Frank From: Rutledge Fuller <rut007(at)hotmail.com> Date: Monday, November 16, 1998 5:59 AM Subject: Kolb-List: My Engine Rebuild > >It looks like it might stay together, so I will write on the experience. > >Four weekends back I had my engine seize on the rear cylinder in >Colquitt, Ga. I was very happy that Mike Highsmith "Firehawk" had his >two seater so that I could hitch a ride back. I removed my engine from >the airframe and attached it underneath Mike's aircraft so that I could >get it back home to Quincy, Fl. Just kiddin'. I drove two hours back >to Colquitt to get the engine. > >Now on with the story. I removed both pistons. The seized piston was >seized on both intake and exhaust and actually craked the skirt. I >believe that the cause was improperly mixed fuel. I replaced the fuel >pump, crakshaft seals, and piston. I did all the work myself and it >took a little time to collect the right tools. I tried several local >gear pullers to pull the gear off of the PTO side of the crank, I had to >finially give in and purchase the rotax gearpuller at around $60. It >took less than 2 seconds to pull it. It helps to have the right tools. >Next, I had to hone the cylinder for the new piston and rings which cost >$130. I finally gave up and ran to Sears and bought a regular stone >hone (fine). I am still waiting on the flex hone from on of the >Ultralight Suppliers which is on back order. I honed the cylinder until >i got a clearance between 4-5 thou. Bolted it up. Timed the motor >(points ignition) brought the motor to Colquitt, installed it and flew >it back to Quincy 1 hour and 10 minute flight after a breakin period. > >I found that the rear newly honed cylinder ran 80 degrees cooler than >the front. Cruise was 287 cht. I often heard that Rotax sets it's >piston to cylinder clearance tight. I called around and spoke to >several Rotax mechanics and they agreed. After just two or so hours on >the engine, I took the front cylinder off and honed it to the same >clearance of between 4-5 thou and reinstalled it. My engine now runs >between 60 and 80 degrees cooler. I still show 40 degrees difference >between the front CHT and the rear. It was exactly that before the >engine seized. I believe that Rotax now installs a baffle between the >cylinders to evenly cool the heads. My old 377 doesn't. > >So far so good with 86 hours, six since rebuild. I had a blast >rebuilding the engine and feel confident about working on the engine. > > >Comments welcome, > >Rutledge Fuller >Tallahassee, Fl. > > > > > > ________________________________________________________________________________
Subject: Re: Windy
Date: Nov 16, 1998
>The other wing is repairable....its a strange feeling tearing off the skin of that wing... all the work, paint, time and expense that went in to putting it on!! > Mornin Gang: Happy Monday. I can totally empathize with the above statement and situation. I felt the same way when I pulled the hide off the wings of my Ultrastar to rebuild after a wire strike. I guess tearing up airplanes is something I have to accept if I am going to participate in this sport, whether I tear them up, or Mother Nature. I watched two Twin Stars at Florida Flying Gators Airstrip get trashed in Nov 1987. One man made a mistake that took out a brand new airplane, that later became the Sun and Fun Lt Plane Grand Champion 1988. He didn't do it on purpose, just got a little over zealous and made a poor decision. Richard Swiderski was there. In fact that is when I met Richard with his Ultrastar. No one was hurt physically, but there was a lot of mental and financial anguish. I felt for both individuals and thanked God it was not me who made the mistake or who was in the line of fire and had a new airplane broken. I have totaled every airplane I built (three) and rebuilt all three of them at least once. The MK III has had three tail booms. Now that is a job in it's self, just replacing a tailboom. A heap of stainless steal rivets to drill out. If you have to drill out a pop rivet, carbon or stainless steel, take a mandrel that has already been pulled and use it to push the mandrel out of the rivet you intend to drill. Stick it in the hole and give it a tap with a small hammer. Then drill, much easier than trying to drill thru a hardened mandrel end. If the rivet wants to spin, make a little tool with a flat sharp edge, ground out a little to stick under the edge of the rivet head. This will put the brakes on the spinning rivet and allow you to drill carefully. I need to replace elevator and rudder hinges, but procrastinate for the very fact that I hate to get started drilling a zillion rivets. Oh well, one of these days. Later on, john h ________________________________________________________________________________
Date: Nov 16, 1998
Subject: Re: Windy
In a message dated 11/16/98 11:34:26 AM Eastern Standard Time, hawk36(at)mindspring.com writes: << I watched two Twin Stars at Florida Flying Gators Airstrip get trashed in Nov 1987. >> Funny you should mention that. I watched the midair collision of a firestar and a Pteradctyl (?) at hoeseheads new york back when they used to have annual flyins. Both pilots and planes survived. The Kolb guy wasn't looking up and the other guy wasn't looking down. ________________________________________________________________________________
Date: Nov 16, 1998
Frank, These motors are simple. Yours is a little more complex than mine, but anyone with any mechanical skill/understanding can work on them. It took me less than two hours to disasemble and reasemble when I honed the front cylinder. The first teardown took about an actual 10 hours total. Now, on the other hand, I like to work on things. If you are the type that doesn't enjoy this type of one-on-one with your aircraft, I would recommend subing the work. I now have a pretty good understanding of my realiable though. Green Sky comes highly recommended. John H. told me about them, and I have had good technical assistance from their mechanics. I look at it this way: Give a man a fish and he eats for a day, teach a man to fish and he eats for a lifetime. Same goes for engines. I could pay someone to rebuild, but would gain nothing. Learning to rebuild myself gives me the understanding, experience, and ship back and forth, or wait in line to have my stuff worked on. One day I hope to have the same understanding of airframes.... Rutledge Fuller Tallahassee, Fl. From: "F J MARINO" <FMARINO(at)netlink1.nlcomm.com> Subject: Re: Kolb-List: My Engine Rebuild Date: Mon, 16 Nov 1998 10:59:35 -0800 Would you consider rebuilding a 582, when its time. I live 15 minutes from Green sky Adventures the oldest Rotax dealer in the USA and maybe having him rebuild but that might be about $1000 or more. How much trouble was it actually to rebuild I'm thinking about going to the Votec for small engine repair to get ready for when my engine goes TU. What do you think. Frank From: Rutledge Fuller <rut007(at)hotmail.com> Date: Monday, November 16, 1998 5:59 AM Subject: Kolb-List: My Engine Rebuild > >It looks like it might stay together, so I will write on the experience. > >Four weekends back I had my engine seize on the rear cylinder in >Colquitt, Ga. I was very happy that Mike Highsmith "Firehawk" had his >two seater so that I could hitch a ride back. I removed my engine from >the airframe and attached it underneath Mike's aircraft so that I could >get it back home to Quincy, Fl. Just kiddin'. I drove two hours back >to Colquitt to get the engine. > >Now on with the story. I removed both pistons. The seized piston was >seized on both intake and exhaust and actually craked the skirt. I >believe that the cause was improperly mixed fuel. I replaced the fuel >pump, crakshaft seals, and piston. I did all the work myself and it >took a little time to collect the right tools. I tried several local >gear pullers to pull the gear off of the PTO side of the crank, I had to >finially give in and purchase the rotax gearpuller at around $60. It >took less than 2 seconds to pull it. It helps to have the right tools. >Next, I had to hone the cylinder for the new piston and rings which cost >$130. I finally gave up and ran to Sears and bought a regular stone >hone (fine). I am still waiting on the flex hone from on of the >Ultralight Suppliers which is on back order. I honed the cylinder until >i got a clearance between 4-5 thou. Bolted it up. Timed the motor >(points ignition) brought the motor to Colquitt, installed it and flew >it back to Quincy 1 hour and 10 minute flight after a breakin period. > >I found that the rear newly honed cylinder ran 80 degrees cooler than >the front. Cruise was 287 cht. I often heard that Rotax sets it's >piston to cylinder clearance tight. I called around and spoke to >several Rotax mechanics and they agreed. After just two or so hours on >the engine, I took the front cylinder off and honed it to the same >clearance of between 4-5 thou and reinstalled it. My engine now runs >between 60 and 80 degrees cooler. I still show 40 degrees difference >between the front CHT and the rear. It was exactly that before the >engine seized. I believe that Rotax now installs a baffle between the >cylinders to evenly cool the heads. My old 377 doesn't. > >So far so good with 86 hours, six since rebuild. I had a blast >rebuilding the engine and feel confident about working on the engine. > > >Comments welcome, > >Rutledge Fuller >Tallahassee, Fl. > > > > > > ________________________________________________________________________________
Subject: Re: Windy
Date: Nov 16, 1998
John H. wrote: I have totaled every airplane I built (three) and rebuilt all three of them at least once. The MK III has had three tail booms. Sounds quite reassuring, when can we fly. : ) Just kiddin'. I guess that says alot for the structure of the KOLBS in a crash, or the pilotage of John. I think it was probably a little of both. I would like to hear the stories some day John. Rutledge Fuller Tallahassee, Fl. Remember the BBQ this weekend at Quincy. We would like to see you there. I called your brother and invited him. ________________________________________________________________________________
Date: Nov 16, 1998
On Mon, 16 Nov 1998, Rutledge Fuller wrote: > mechanics. I look at it this way: Give a man a fish and he eats for a > day, teach a man to fish and he eats for a lifetime. Same goes for > engines. I could pay someone to rebuild, but would gain nothing. > Learning to rebuild myself gives me the understanding, experience, and > ship back and forth, or wait in line to have my stuff worked on. > A similar point, and this can go both ways of course... If you worked on it yourself, you *know* the degree of quality and care that went into it. BTW, Rut, I'm impressed with your speediness on getting back into the air. I would have spent twice the time just trying to decide what to do. Good job! > >between the front CHT and the rear. It was exactly that before the > >engine seized. I believe that Rotax now installs a baffle between the > >cylinders to evenly cool the heads. My old 377 doesn't. My 447 has this baffle and the rear (PTO) cyl runs ~30 degrees hotter. I ground down the baffle a little bit to allow more cooling air back to the PTO. It made practically no difference, maybe 10 degrees (measured at the typical plug base anyway). Ben Ransom http://mae.ucdavis.edu/~ransom ________________________________________________________________________________
Subject: Re: Windy
Date: Nov 16, 1998
>Rutledge Fuller >Tallahassee, Fl. > >Remember the BBQ this weekend at Quincy. We would like to see you >there. I called your brother and invited him. Hi Rut and Gang: Thanks for the personal invite. I have the B B Q and Quincy on my calendar. Haven't flown into that airport for a while. I like flying down that way, it is where I grew up (TLH) and the turn around point for my first long xc in my Ultrastar in 1984. Time is flying!!! Boy we've gone a long way since those days. Never would have in my wildest 1984 dreams invisioned the flights that my little Kolb airplanes have taken me. They all started with dreams and ended with reality. I'll try to make it to Quincy, weather permitting. john h ________________________________________________________________________________
Date: Nov 16, 1998
Subject: 912 engine problem
I have 912 engine just breaking in. At high RPM developed leaking gas from breather of right carb. Before i take the bowl off what should I look for as being the problem? Thanks for your help. BK ________________________________________________________________________________
Date: Nov 16, 1998
Subject: Re: Windy
Subject: Re: 912 engine problem
Date: Nov 16, 1998
> >I have 912 engine just breaking in. At high RPM developed leaking >gas from breather of right carb. Before i take the bowl off what should >I look for as being the problem? Thanks for your help. > > BK BK and Gang: Breakin was not a requirement back in April 1994 when I started flying my 912. Has that been changed to a breakin procedure like the two cycles? How bad is the leak? Can you see fuel pouring out of the air filter? Or are you getting fuel residue on engine from fuel vapor standoff from the carb? This is a problem with my 912 and significant others I have come across over the years. Problem is caused by airflow over the engine from the prop and from flying. Sometimes it is the right carb, sometimes it is the left, sometimes it is both. A lot depends on how the aircraft is trimmed in yaw. My eng has no oil leaks, but the fuel residue keeps the eng nasty most of the time. How to cure it? Turn the engine around and make a tractor out of it. That is the way the eng was intended to be used, with carbs flying backwards, not forwards. The same or similar bing carb is used on BMW motor cycles with no problem, but they fly backwards. I was having carb problems in Dead Horse, Alaska, temps in the high 20s and low 30s. A German on a BMW rode up the Dalton Highway but had no carb problems. What's the difference? My carbs go one way, his the other. Thought about placing aircleaners in fuselage connected with airtex hose or something similar. Haven't gotten around to that experiment yet. Sorry I can't help any more than the above. It is a good eng. Mine is working on a 1,000 hours (983 hrs as of yesterday). Still performs as well as when it was a young pup. john h ________________________________________________________________________________
Date: Nov 16, 1998
> BK and Gang: Breakin was not a requirement back in April 1994 when I started flying my 912. Has that been changed to a breakin procedure like the two cycles? How bad is the leak? Can you see fuel pouring out of the air filter? Or are you getting fuel residue on engine from fuel vapor standoff from the carb? This is a problem with my 912 and significant others I have come across over the years. Problem is caused by airflow over the engine from the prop and from flying. Sometimes it is the right carb, sometimes it is the left, sometimes it is both. A lot depends on how the aircraft is trimmed in yaw. My eng has no oil leaks, but the fuel residue keeps the eng nasty most of the time. John; Does this mean that "excess fuel from the vapor standoff" is coming forward through the carbs/filters and sucked back all over the engine? And this is considered "normal" for pusher applications because of how the carbs are located? The ram-air entering the carb is not strong enough to keep the fuel vapors from exiting forward trough the airfilters? How to cure it? Turn the engine around and make a tractor out of it. This is not an option for a MKIII Thatis the way the eng was intended to be used, with carbs flying backwards, not forwards. The same or similar bing carb is used on BMW motor cycles with no problem, but they fly backwards. I was having carb problems in Dead Horse, Alaska, temps in the high 20s and low 30s. A German on a BMW rode up the Dalton Highway but had no carb problems. What's the difference? My carbs go one way, his the other. john h Is it possible to turn the intake manifolds around on the engine so that the carb sits on the backside of the manifold and "going backward" same as the motorcycle? The drawings(topview) I am looking at in the CPS catalog suggest that this maybe possible.(I am having a ball with this one!) Frank(wanting a 912 pusher) Reynen MKIII@481 hrs http://www.webcom.com/reynen ________________________________________________________________________________
Date: Nov 16, 1998
Subject: Las Vegas
I am planning to be in Las Vegas around the 23rd of Jan and wonder if there are any Kolb builder flyers in that area. I would like to see what you have and perhaps exchange ideas on our birds, experiences, trailers etc etc. Duane Mitchell, Tallahassee, Florida ________________________________________________________________________________
From: dralle(at)matronics.com (Matt Dralle 925-606-1001)
Date: Nov 16, 1998
Subject: Had to Pass This On...
Hi Listers, Al Mojzisik from the RV-List posted the message below to the RV-List today. Besides making a great point, I thought it was a riot. Hope you do to. Matt Dralle List Admin. From: Al Mojzisik <prober(at)iwaynet.net> Subject: RV-List: FAA BANS RV-LIST FAA administrator, Jane Garvey, announced today in Washington that the RV-List operated by Matt Dralle (On the left coast!) was to be shut down. Citing the 51% rule as the reason for the shut down Garvey explained that with the advent of Vans Quick Build Kits the RV-List offered so much additional assistance to the builders that they no longer met the 51% criteria! "These builders are really pushing the envelope!" Garvey was quoted as saying. "They get all there builder questions answered by one simple E-Mail to this list! They no longer have to spend hours trying to figure out the plans and the manuals supplied by the kit builder. This significantly reduces build time and they make far fewer mistakes. It has taken most of the fun out of being the Administrator and besides, that Dralle guy has nicer hair than me!" She also noted. Rumor has it that Vans also supports the ban because they have noticed that the their sales of replacement parts has significantly decreased since people get advice on how to do it the right way the first time from "one quick question" to the List. We were not able to confirm this rumor however. It was suggested by Moe Colontino that builders supply their serial numbers to the list administrator and if they cross check to a Quick Build serial number then they would not be allowed on the list. Moe also asked that if anyone had a spare empennage and NON-Quickbuild serial number he would be interested in purchasing it. Doug Rozendaal asked the administrator if it wasn't possible that she was just jealous because Matt Dralle calls himself an administrator too? (The List Administrator) To which Garvey replied, "Absolutely not! I can care less what he calls himself! Don't you fly that pink airplane I saw at Oshkosh? We'll have to have a closer look at that machine!" After which Rozendaal withdrew his question. Chet Razer and some others at this point in the meeting asked Ms. Garvey if there was any more beer since they were done flying for the day anyway. To which Ms. Garvey responded that that "was an inappropriate question at such a meeting! " After which Ms. Garvey was bombarded with questions about bolt torque, Extra storage space in RV's, numerous engine questions, and finally some misguided newbie asked her about PRIMER! After tearing her hair out (no wonder Matt's looks better) Ms. Garvey suggested that maybe she better have another look at the RV-List ban and reassess her position. She said she is open to more public input if you don't mention PRIMER! You can contact the Administrator at: http://www.matronics.com/contribution.html Please have your Credit Card ready! Or if you wish, you can send your opinions and a generous check too: Matt Dralle PO Box 347 Livermore, CA 94550 If you even smiled once, won't you contribute? AL Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 17, 1998
Subject: Re: Had to Pass This On...
Was this forwarded to Ms. Garvey? ________________________________________________________________________________
From: "Michael Highsmith" <michael.highsmith(at)worldnet.att.net>
Subject: Re: Engine Vibration
Date: Nov 16, 1998
Hey John, Guess what? The day you pointed out that the hinges on the Ferguson was worn and to me at the time they did look worn, I preceded to disassemble the whole tail section. What I found would have amazed you and the rest of the Kolb gang. I have witnesses that will attest to it. Would you like to know? Well, I won't knock Kolbs because they're really good airplanes and I like flying them and I would recomend them to anyone who want a strong well behaved airplane not to mention I flew a MK3 for some 285 hours. My Mama always told me if I couldn't say anything good about someone ( I believe that goes for most planes) to not say anything at all. NO WEAR AT ALL ON ANY OF THE HINGES ANYWHERE ON THE FERGUSON. I might add that I run the brace wires fairly tight. Even the bolts at the bell crank pivots were like new. Come by anytime and I'll be glad to show you. The spacing you saw in between the hinges was in both directions which was there at initial installation. The hinges are of a double "X" configuration and seem to be very strong in all directions. I did try to find some wear but did not succeed. I also keep them lubricated with a light oil which probably had a lot to do with the lack of wear. You're right in that they did look worn but if they are I can't find it. There is no side play and no up and down play.The Ferguson is by no means a perfect airplane but it satisfies me and I'm the only one that counts. If I ever get 1200 hours on the Ferguson it will be a long time from now. It will probably be retired a lot sooner than that which means the hinges want have a chance to wear out. Lets get back to Kolbs. My friend Jim is looking into buying a Kolb from another friend of mine (Flint Burns AKA Canary). I talked him out of buying a Rans not that the Rans isn't a good plane but it want fold like a Kolb. Then there's the time involved in building while the rest of us is flying. It is the Firestar, the one I flew to Sun-n-Money three years ago when we all had such a good time around your camper.It can stay close to home where the previous owner can stroke it once and a while. We're working on a new private runway community north of P.C. where we will all have a place to take the planes in case of another storm like Opal. 100' of my hanger was blown away in that one. The new runway is in and I have the exclusive right to have a training operation on the field so long as it originates from my lot. I hope to retire there and fly 'til I can't see. This is one sport that crosses a lot of years and friends tend to last a long long time. I hope you will give me a call when you are down again and I hope to take Bob up tomorrow if the wind isn't to strong. FIREHAWK From: john hauck <hawk36(at)mindspring.com> Date: Sunday, November 15, 1998 9:07 PM Subject: Re: Kolb-List: Engine Vibration > >Hi Mike and Kolb Gang: > >Saw this post and thought I would comment a little on the below statement. > > >> >>Remember that the smoother you can make your craft the longer it will last >>because all moving parts wear and dry moving parts wear 300 time faster. I >>have some 545 hours on my plane and there is hardly any appreciable wear >>anywhere. Prop vibration probably accounts for most of the wear on our >>crafts. > >I fly a MK III with more than twice the airframe hours as Mike's Ferguson. >Got a chance to fly a little today and when I put the plane up she had >1216.1 hrs. I agree with the above in part, but since the MK III and the >Ferguson use the same identical elevator control mechanism/horizontal >stabilizer foldup system, I must make a comment reference wear of the >elevator piano hinges. I was down in Panama City, Fl, last month and Mike >graciously agreed to fly an old retired WWII Navy Submariner friend of mine. >I appreciate that Mike. While I was at Mike's airstrip I noticed advanced >wear on the Ferguson's elevator hinges and the rudder hinges. The elevator >hinges wear rapidly because they carry the load from the tail wires combined >with the movement of the elevators. The rudder hinges wear because of >basically the same thing: movement of rudder and downward pull from the >tail wheel steering springs. I have the same problem with my MK III because >both tail sections a very much the same. However, I point out that Mike's >hinges have worn more than mine. Why? Because I use more elevator and >rudder hinge than the plans call for and a lot more than what Mike has on >his Ferguson. I have more hinge to carry the thrust load. > >I'm experimenting with some nylon pads, between the tail boom and the inside >edges of the horizontal stabilizers, to carry the load placed on the hinges >by the tailwires. It seems to work well, however, I need to place a small >piece of stainless sheet metal on the inside edges of the horizontal stabs >to keep from wearing thru the paint and fabric. Now these nylon blocks are >carry the load rather than the hinges. > >So Mike, I think you may have a little appreciable wear. When I discovered >the wear on his plane I pointed it out to Mike so he would be aware of it. >I also shared with him my experiment with the nylon thrust blocks. > >Fly safe, have fun, > >john h > > > > > > > > > > ________________________________________________________________________________
Date: Nov 16, 1998
Hey Richard, It's a 68'' quick ground adjust on a 3 to 1 E box behind a 582. I did have some problems with the set up early on with the prop trying to come apart at the hub. I always caught it in plenty of time though because I use the inspection tape across the gaps between the blades that IVO recommends. It took IVO three new sets of blades before we worked the problems out . He would have given me my money back but I wanted to solve the problem. There were others who had the same set up and the same problems I was having. I've had three of the cams at different times on the end of the torque rods break. THAT WILL WAKE YOU UP especially if your a long way from home. That made it virbrates really bad at high RPMs but at cruise it wasn't that noticable. Anyway I welded a little tit on the cam end and ground it to the right pitch to match the other blades. No vibration. I have broken two of the backing plates, the thin ones that the adjustment screw is threaded through. I asked IVO to send me one of the thick plates like goes on the other side of the prop next to the gearbox. He did with a thin one to hold the adjustment screw. I put the whole thing on with two sets of inspection tape forward and aft across the gaps. I've never had another problem except when I kill really big bugs. Never broke another piece of tape except when I pulled the prop to do a 50 hour inspection. I also torque the prop bolts to 215 inch lbs. and check them@ the recomended intervals. So far the torque stays where it's suppose to and I am happy with the IVO'S smoothness and quietness. I hope this helps. FIREHAWK. ________________________________________________________________________________
Date: Nov 16, 1998
frank haynesdled(at)worldnet.att.net NEW 912 ROTAX FOR APPROX 7370.00 HIS # IS 541-7478817 ................................................................................................................................................................FRANK LOOK THIS UP www.cs.fredouia.edu/~stei0302/www/ultra/clas or fredonia. " " " " " " " " " " " look under the united states ,classified adds under the mounth of oct.1998 Rick Libersat writes: > > > > > > > > > > > >> > > >BK and Gang: > >Breakin was not a requirement back in April 1994 when I started flying >my >912. Has that been changed to a breakin procedure like the two >cycles? > >How bad is the leak? Can you see fuel pouring out of the air filter? >Or >are you getting fuel residue on engine from fuel vapor standoff from >the >carb? This is a problem with my 912 and significant others I have >come >across over the years. Problem is caused by airflow over the engine >from >the prop and from flying. Sometimes it is the right carb, sometimes >it is >the left, sometimes it is both. A lot depends on how the aircraft is >trimmed in yaw. My eng has no oil leaks, but the fuel residue keeps >the >eng >nasty most of the time. > >John; Does this mean that "excess fuel from the vapor standoff" is >coming >forward through the carbs/filters and sucked back all over the engine? >And >this is considered "normal" for pusher applications because of how the >carbs are located? The ram-air entering the carb is not strong enough >to >keep the fuel vapors from exiting forward trough the airfilters? > >How to cure it? Turn the engine around and make a tractor out of it. > >This is not an option for a MKIII > >Thatis the way the eng was intended to be used, with carbs flying >backwards, not >forwards. The same or similar bing carb is used on BMW motor cycles >with >no >problem, but they fly backwards. > > I was having carb problems in Dead Horse, >Alaska, temps in the high 20s and low 30s. A German on a BMW rode up >the >Dalton Highway but had no carb problems. What's the difference? My >carbs >go one way, his the other. > >john h > >Is it possible to turn the intake manifolds around on the engine so >that >the carb sits on the backside of the manifold and "going backward" >same as >the motorcycle? The drawings(topview) I am looking at in the CPS >catalog >suggest that this maybe possible.(I am having a ball with this one!) > >Frank(wanting a 912 pusher) Reynen MKIII@481 hrs >http://www.webcom.com/reynen > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 17, 1998
> >Would you consider rebuilding a 582, when its time. I live 15 minutes from >Green sky Adventures the oldest Rotax dealer in the USA and maybe having him >rebuild but that might be about $1000 or more. How much trouble was it >actually to rebuild I'm thinking about going to the Votec for small engine >repair to get ready for when my engine goes TU. What do you think. Have you ever rebuilt an engine before? Do you have the proper tools? Are you willing to spend the money to buy the special tools and the shop manual? Are you mechanically "handy"? If you have never rebuilt an engine before, go to a motorcycle junk yard, and buy an old rotary valve Kawasaki two stroke engine. Tell the guy you just want it to practice on, it will not need to run after you finish. Get the shop manual for it. You should be able to get both for under $50. Completely dissasemble the engine AND transmission, and reassemble it. If you felt comfortable doing that, and everything made sense, and seems to have fit back together right, now YOU decide if you want to tackle your 582. Either way, it was good experience, and money well spent. If you decide to rebuild the 582, get a GOOD set of snap ring pliers, the magneto puller, the wrist pin bearing tool, and especially the little tool that goes over the end of the rotary valve shaft. Get a good torque wrench. Understand what the book is telling you to do before you do it. If in doubt, ask someone you respect. Get a helper that is patient when it comes time to slip the cylinders back over the pistons. If you can get a helper that has rebuilt 2-strokes before (successfully!), you are ahead of the game. Good luck. Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 17, 1998
Subject: Ivoprop
Is this the Ivo with the quick adjust system, or the type that just has the plain cams screwed to the ends of the rods? I have used the basic system, not the quick adjust, and it doesn't sound like what you are describing. Richard Pike MKIII N420P (42oldpoops) > >Hey Richard, It's a 68'' quick ground adjust on a 3 to 1 E box behind a 582. >I did have some problems with the set up early on with the prop trying to >come apart at the hub. I always caught it in plenty of time though because I >use the inspection tape across the gaps between the blades that IVO >recommends. It took IVO three new sets of blades before we worked the >problems out . He would have given me my money back but I wanted to solve >the problem. There were others who had the same set up and the same >problems I was having. I've had three of the cams at different times on the >end of the torque rods break. Anyway I welded a little tit on the cam end >and ground it to the right pitch to match the other blades. No vibration. I >have broken two of the backing plates, the thin ones that the adjustment >screw is threaded through. I asked IVO to send me one of the thick plates >like goes on the other side of the prop next to the gearbox. He did with a >thin one to hold the adjustment screw. ________________________________________________________________________________
Date: Nov 17, 1998
>John; Does this mean that "excess fuel from the vapor standoff" is coming >forward through the carbs/filters and sucked back all over the engine? And >this is considered "normal" for pusher applications because of how the >carbs are located? The ram-air entering the carb is not strong enough to >keep the fuel vapors from exiting forward trough the airfilters? I think what it means is the air stream is blowing fluel out of the air filters. I have used small conical K&Ns thru out life of eng, minus a couple experiments with 6 inch flat/round K&Ns. Flat filters really messed with carb performance (primarily hesitation during hard acceleration). Ram air screws up fuel mixture calibration with these Bing Carbs. The float bowl chamber has two sources of static pressure: vent tube and one on the inlet lip of the carb. The vacumn chamber reads these two static air sources and throttle setting (intake vacumn) and positions the piston w/fuel needle attached, in the correct position to deliver the correct amount of fuel being demanded by the eng. Stray air pressure or vacumn to the two static ports screws up the carbs mind and eng performance, at times. Right now I live with the following: I connect the two float bowls with one piece of tubing. Mid point of tubing I drilled thru both sides of the tubing vertical as well as horizontal (gives me four 1/8 inch holes). Now both carbs are reading the same static pressure at their float bowl vents. This prevents one carb running at different mixture than the other. This mod seems to work well, but not perfect. Next I have to work on getting good static source to the inlet static ports. Two ways I think I can do that: One way is put the aircleaners in the fuselage out of the airstream, using tubing and one or two air cleaners. Or maybe using tubing and a 90 degree bend to turn the aircleaner perpendicular to the airstream. The other way (and not my idea) I saw in a picture of a trike powered by 912. They had fabricated hoods, same shape as conical K&Ns and a little larger to place over the filters with maybe a 1/2 inch gap all around. These could be metal or fiberglass. I think either way would work. The latter, with hoods, probably be the simplest. >Is it possible to turn the intake manifolds around on the engine so that >the carb sits on the backside of the manifold and "going backward" same as >the motorcycle? The drawings(topview) I am looking at in the CPS catalog >suggest that this maybe possible.(I am having a ball with this one!) > >Frank(wanting a 912 pusher) Reynen MKIII@481 hrs >http://www.webcom.com/reynen Don't think there is enough space to reverse intake manifolds. That was one of my original thoughts. Carb problems on pusher 912 are not overwhelming, just annoying, especially when one invests that much money into an engine. Last year I bought a brandnew 351W Ford eng for $2,000. I could buy five 351Ws for same price as one 912. hehehe Keep 'em flying, john h ________________________________________________________________________________
Date: Nov 17, 1998
Subject: Re:Back issue of "In Flight USA"
I'm trying to locate the Sept & Oct issues of the above mag, They are given away at arpts, FBOs, etc. The issue (don't know which one) has a letter to editor from the well-known CA aircraft designer that el Stupeed Cringley finally went to when he was trying to do the "30 day airplane" build. He really blasted him, saying he (C) had never built a plane, altho in the movie he said he'd done SEVEN, including the slick composite seen flying near Golden Gate BR. The designer gave name of actual bldr! Any help appreciated. GB aka Bob N.freelance writer, FF#70 ________________________________________________________________________________
Subject: Windy
Date: Nov 17, 1998
Hi all- I have been dipping the rivits in Rustolium to prevent calvanic corrosion - don't know if its necessary but I feel better. Anyway I have found that it holds the rivets from spinning when I have to drill the occational...okey, maybe numorous rivets out that I've goofed up. (I wouldn't dip them just for that reason, its messy and slows you down) Peter Craig Malden, MA Mk III (about half finished) (If the rivet wants to spin, make a little tool with a flat sharp edge, ground out a little to stick under the edge of the rivet head. This will put the brakes on the spinning rivet and allow you to drill carefully). I need to replace elevator and rudder hinges, but procrastinate for the very fact that I hate to get started drilling a zillion rivets. Oh well, one of these days. Later on, john h ________________________________________________________________________________
Date: Nov 18, 1998
From: Richard Pike <rpike(at)preferred.com> Date: Monday, November 16, 1998 11:51 PM Subject: Re: Kolb-List: My Engine Rebuild > >> >>Would you consider rebuilding a 582, when its time. I live 15 minutes from Just testing because I did not get any mail last night. ________________________________________________________________________________
Date: Nov 18, 1998
Subject: Wing failures ??
________________________________________________________________________________ ________________________________________________________________________________ I am considering building a Kolb Firefly or Mk III. I was recently told that the single strut bracing on the wing allows for wing twist and failure. I want to hear from builders and flyers who can give insight or experiences on this ....or other shortcomings. Thanks, I don't want to alarm anybody but I am doing the research by asking you guys to see if this is a valid problem. Steph..... (oo) | :\/: _ _ \ Jon's WWW mail cow gateway. That is to say, the / | MAIL|| \_ ' '`-'`-'/ anonymous prankster. Even though this message was ^^ ^^ could have been generated by anyone in the world. ________________________________________________________________________________
Date: Nov 18, 1998
Hi Rick, I was finally able to decifer all the info you send me including the telephone message and get a message to Dave Haynes regarding this 912 for sale. Thanks so much for your assistance in this Rick! Frank Reynen P.s. I lost your phone # and would have called you back yesterday night. Pls resend it. Please respond to kolb-list(at)matronics.com frank haynesdled(at)worldnet.att.net NEW 912 ROTAX FOR APPROX 7370.00 HIS # IS 541-7478817 ........................................................................... ........................................................................... ..........FRANK LOOK THIS UP www.cs.fredouia.edu/~stei0302/www/ultra/clas or fredonia. " " " " " " " " " " " look under the united states ,classified adds under the mounth of oct.1998 Rick Libersat writes: > > > > > > > > > > > >> > > >BK and Gang: > >Breakin was not a requirement back in April 1994 when I started flying >my >912. Has that been changed to a breakin procedure like the two >cycles? > >How bad is the leak? Can you see fuel pouring out of the air filter? >Or >are you getting fuel residue on engine from fuel vapor standoff from >the >carb? This is a problem with my 912 and significant others I have >come >across over the years. Problem is caused by airflow over the engine >from >the prop and from flying. Sometimes it is the right carb, sometimes >it is >the left, sometimes it is both. A lot depends on how the aircraft is >trimmed in yaw. My eng has no oil leaks, but the fuel residue keeps >the >eng >nasty most of the time. > >John; Does this mean that "excess fuel from the vapor standoff" is >coming >forward through the carbs/filters and sucked back all over the engine? >And >this is considered "normal" for pusher applications because of how the >carbs are located? The ram-air entering the carb is not strong enough >to >keep the fuel vapors from exiting forward trough the airfilters? > >How to cure it? Turn the engine around and make a tractor out of it. > >This is not an option for a MKIII > >Thatis the way the eng was intended to be used, with carbs flying >backwards, not >forwards. The same or similar bing carb is used on BMW motor cycles >with >no >problem, but they fly backwards. > > I was having carb problems in Dead Horse, >Alaska, temps in the high 20s and low 30s. A German on a BMW rode up >the >Dalton Highway but had no carb problems. What's the difference? My >carbs >go one way, his the other. > >john h > >Is it possible to turn the intake manifolds around on the engine so >that >the carb sits on the backside of the manifold and "going backward" >same as >the motorcycle? The drawings(topview) I am looking at in the CPS >catalog >suggest that this maybe possible.(I am having a ball with this one!) > >Frank(wanting a 912 pusher) Reynen MKIII@481 hrs >http://www.webcom.com/reynen > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 18, 1998
Subject: Re: Wing failures ??
Stephen, on pain of my being wrong as usual, here's what Dennis told me when I went to Phoenixville to see and buy a FireFly. I asked why the FF had TWO lift struts, when the other, heavier Kolbs had only one. Answer: to give FF more drag to keep it under 63 mph. I have never heard of a Kolb wing twisting in the wind. I realize others may say I'm wrong, so ask Dennis. GB ________________________________________________________________________________
Date: Nov 18, 1998
> > >I am considering building a Kolb Firefly or Mk III. I was recently told that the single strut bracing on the wing allows for wing twist and failure. I want to hear from builders and flyers who can give insight or experiences on this ....or other shortcomings. Thanks, I don't want to alarm anybody but I am doing the research by asking you guys to see if this is a valid problem. Steph..... Good Morning Steph..... and Gang: Single strut bracing on the wing allows for wing twist and failure..................... If the above were true, there would be a lot of Kolbs out there with failed wings. To start with, we'll get this out of the way quick, Firefly has two lift struts per wing section. I assume you are talking about lift struts although you say "single strut bracing." Wing twist was a way of life with the Ultrastar, but I know of no Ultrastar that had a wing failure because of wing twist. Of course I don't know much, but I have never heard of such. Firestar didn't have wing twist because Homer Kolb and Dennis Souder and the rest of the gang at Kolb Aircraft came up with a much improved mainspar attach system to the inboard rib. Likewise, the remainder of the Kolb line. I invite you to try and twist the wing of my old MK III. Don't worry. The folks on this list that fly Kolbs are not alarmed by what you say. We have a lot of combined experience in the air in all kinds of weather, wind, loads, etc. How this helps you out with your research. John h (getting the pine straw and leaves off the lawn in Central Alabama) ________________________________________________________________________________
Date: Nov 18, 1998
On Wed, 18 Nov 1998 stephen.feldmann(at)qm.phxhs.k12.az.us wrote: > > I am considering building a Kolb Firefly or Mk III. I was recently told that the single strut bracing on the wing allows for wing twist and failure. I want to hear from builders and flyers who can give insight or experiences on this ....or other short comings. Thanks, I don't want to alarm anybody but I am doing the research by asking you guys to see if this is a valid problem. Steph..... Hmmm, I'm sure you'll get a few answers on this one. :) The question about single lift strut is probably the biggest single false rumor I hear about the Kolb from the unknowing. *It is obviously a fair and reasonable question*, but any rumors about this being a weak point in the design are simply from the unknowing or the envious. If you build a Kolb, you easily see the aspects of the internal wing structure that bear wing twist loads. It is clever, light, and very very strong. I only know of one properly built Kolb wing that has ever failed, this one from John Hauck, who was treating the plane more like a Pitts Special. I'm sure he'll chip in here; it was a high time original (5 rib) Firestar always flown extraordinarily hard (any and all aerobatics), and failed just after a hammerhead or something similar. Kolb is the *only* manufacturer who has flight tested one of their planes to the point of structural failure. It failed far beyond stated load limits, was not a wing twist failure, and was even improved upon from that test. Here's an example of the typical rumor on this. A guy I used to fly with scoffed at my single lift strut Kolb. In typical "Unknowing" fashion, this person drilled (4) 3/16" rivet holes 1/3 the way up on points for a 2 gal gas can on each strut!!! What a fool. He assumes the Kolb lift strut is inadequate, but he drills holes and adds a large mass (the filled gas cans) to the middle of a key structural part of his Challenger. I still can't believe it! (I think he decided to go ...ok, simmer down now Ben, Ben Ransom http://mae.ucdavis.edu/~ransom ________________________________________________________________________________
Date: Nov 18, 1998
From: Stephen Feldmann <stephen.feldmann(at)qm.phxhs.k12.az.us>
Subject: wing failures ??
Subject: Time: 10:43 AM wing failures ?? Date: 11/18/98 To Kolb builders & flyers: I am doing some research as I am interested in building a Kolb Firefly, Slingshot or Mk III. I would like to hear about your building experiences (problems/frustrations) and the flight characteristics in general but ..... a concern I have is in the single strut brace on the wings. I was recently told that this is a problem area as it allows wing twisting and possible failure (it allegedly has occurred). I don't mean to alarm anybody especially if it is not a problem but I would like some response from you guys as to the validity of this or other shortcomings. Thanks for your response. Steph..... stephen.feldmann(at)qm.phxhs.k12.az.us ________________________________________________________________________________
Subject: Kolb Wing Twist
Date: Nov 18, 1998
Hi Guys: A previous note on this list indicated that I had a wing failure on my old original 5 rib Firestar. That is absolutely true, but the cause was not from wing twist. It was from 755.0 hours of extremely hard flying, 1000's of aerobatics combined with many long XCs flying overloaded in all kinds of winds and weather. I flew this old Firestar like there was no red lines anywhere. We were always wayyyyyyyy out of the flight envelope and eventually just wore the little airplane out. This was the 1988 Sun and Fun Grand Champion Ultralight and the 1989 Oshkosh Grand Champion Ultralight. This airplane flew in 32 different states and Canada, just me and airplane. I learned from this experience, that nearly cost me my life, that stress is a cumulative thing. My little airplane started out life with a whole number: 1.0. Everytime I stressed her I was subtracting a little from that whole number. Eventually I asked her to do something and she told me very abruptly, "Sorry, can't do it!!!" Live and learn almost turned into die and learn. Thanks Jim Handbury for a reliable hand deployed parachute. john h ________________________________________________________________________________
Date: Nov 18, 1998
In a message dated 11/18/98 12:28:12 PM Eastern Standard Time, stephen.feldmann(at)qm.phxhs.k12.az.us writes: << I want to hear from builders and flyers who can give insight or experiences on this ....or other shortcomings. Thanks, I don't want to alarm anybody but I am doing the research by asking you guys to see if this is a valid problem. Steph..... >> Not that I know of. I have a pretty good handle on the database of Kolb accidents. Structural failure is not on the scope. Crow hopping accidents, engine seizures, first flight/ inexperience related accidents, there are alot of these. There is one "structural failure" but this one is cannot be fairly chaulked up to the Kolb company because the builder failed to install a major structural bolt. If you are going to fly a Kolb it is much more likely that the engine will let you down, not the airframe. ________________________________________________________________________________
Date: Nov 18, 1998
HI Frank, I got this e-mail I think because I am on the Kolb e-mail list. Did you get my e-mail with pictures included? Please let me know. Steve Frank_R_Reynen(at)notes.seagate.com on 11/18/98 10:14:04 AM Please respond to kolb-list(at)matronics.com Subject: Re: Kolb-List: 912 engine problem Hi Rick, I was finally able to decifer all the info you send me including the telephone message and get a message to Dave Haynes regarding this 912 for sale. Thanks so much for your assistance in this Rick! Frank Reynen P.s. I lost your phone # and would have called you back yesterday night. Pls resend it. Please respond to kolb-list(at)matronics.com frank haynesdled(at)worldnet.att.net NEW 912 ROTAX FOR APPROX 7370.00 HIS # IS 541-7478817 ........................................................................... ........................................................................... ..........FRANK LOOK THIS UP www.cs.fredouia.edu/~stei0302/www/ultra/clas or fredonia. " " " " " " " " " " " look under the united states ,classified adds under the mounth of oct.1998 Rick Libersat writes: > > > > > > > > > > > >> > > >BK and Gang: > >Breakin was not a requirement back in April 1994 when I started flying >my >912. Has that been changed to a breakin procedure like the two >cycles? > >How bad is the leak? Can you see fuel pouring out of the air filter? >Or >are you getting fuel residue on engine from fuel vapor standoff from >the >carb? This is a problem with my 912 and significant others I have >come >across over the years. Problem is caused by airflow over the engine >from >the prop and from flying. Sometimes it is the right carb, sometimes >it is >the left, sometimes it is both. A lot depends on how the aircraft is >trimmed in yaw. My eng has no oil leaks, but the fuel residue keeps >the >eng >nasty most of the time. > >John; Does this mean that "excess fuel from the vapor standoff" is >coming >forward through the carbs/filters and sucked back all over the engine? >And >this is considered "normal" for pusher applications because of how the >carbs are located? The ram-air entering the carb is not strong enough >to >keep the fuel vapors from exiting forward trough the airfilters? > >How to cure it? Turn the engine around and make a tractor out of it. > >This is not an option for a MKIII > >Thatis the way the eng was intended to be used, with carbs flying >backwards, not >forwards. The same or similar bing carb is used on BMW motor cycles >with >no >problem, but they fly backwards. > > I was having carb problems in Dead Horse, >Alaska, temps in the high 20s and low 30s. A German on a BMW rode up >the >Dalton Highway but had no carb problems. What's the difference? My >carbs >go one way, his the other. > >john h > >Is it possible to turn the intake manifolds around on the engine so >that >the carb sits on the backside of the manifold and "going backward" >same as >the motorcycle? The drawings(topview) I am looking at in the CPS >catalog >suggest that this maybe possible.(I am having a ball with this one!) > >Frank(wanting a 912 pusher) Reynen MKIII@481 hrs >http://www.webcom.com/reynen > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 18, 1998
Subject: Rotax 912 con rod failure
Nov issue Aviation Maint. Alerts p14 speaks abt above failure.Case broke, oil thrown, exhaust caught on fire. A/C was Diamond 20-A1. No fatalities. Submitter didn't offer any cause.GB ________________________________________________________________________________
From: "Ron Carroll " <ron.carroll(at)worldnet.att.net>
Subject: Re: Kolb Wing Twist
Date: Nov 18, 1998
To John Hauck; John, I can't help but ask you about your Original Firestar. From your statement below you say you did aerobatics with it. In the past couple of days I finally made my first flights with my Original Firestar, and because its sluggish aileron response I would find it hard to believe that aerobatics are possible. If yours flew like mine you surely had huevos grandes, and my hat is off to you. Was it built per the plans or did you have it modified for better performance? Ron Carroll Original Firestar >Hi Guys: > >A previous note on this list indicated that I had a wing failure on my old >original 5 rib Firestar. That is absolutely true, but the cause was not >from wing twist. It was from 755.0 hours of extremely hard flying, 1000's >of aerobatics combined with many long XCs flying overloaded in all kinds of >winds and weather. I flew this old Firestar like there was no red lines >anywhere. SNIP>>>> >john h ________________________________________________________________________________
Date: Nov 18, 1998
Steph, If there was such a problem, Kolb would have gone out of business long ago, and this list would not exist. The only Kolb wing failure that I have even heard about was a compression strut failure on the earliest design of the Ultrastar. The only shortcoming that I can think of is that if you wreak a Kolb, it's probably going to be expensive to repair. John Jung Firestar II N6163J SE Wisconsin stephen.feldmann(at)qm.phxhs.k12.az.us wrote: > > I am considering building a Kolb Firefly or Mk III. I was recently told that the single strut bracing on the wing allows for wing twist and failure. I want to hear from builders and flyers who can give insight or experiences on this ....or other shortcomings. Thanks, I don't want to alarm anybody but I am doing the research by asking you guys to see if this is a valid problem. Steph..... ________________________________________________________________________________
Date: Nov 18, 1998
> >To John Hauck; > >John, I can't help but ask you about your Original Firestar. From your >statement below you say you did aerobatics with it. In the past couple of >days I finally made my first flights with my Original Firestar, and because >its sluggish aileron response I would find it hard to believe that >aerobatics are possible. If yours flew like mine you surely had huevos >grandes, and my hat is off to you. > >Was it built per the plans or did you have it modified for better >performance? > >Ron Carroll >Original Firestar Hi Gang: No mods to the Firestar. Strictly stock except for the longer 4130 heat treated gear legs. Please do not take your hat off to a fool who had no idea I could not get away with flying an airplane to that degree that was not designed for that type flight. My last aerobatic maneuver was 11 Mar 1990. Made a normal takeoff but landed under a canopy, much to my surprise. john h (waiting for an aerobatic airplane to again do aerobatic in) ________________________________________________________________________________
Date: Nov 18, 1998
> >Steph, The only shortcoming that I can think of is that if you wreak a Kolb, it's probably going to be expensive to repair. >John Jung >Firestar II N6163J >SE Wisconsin If that was really important, we'd all still be flying Quicksilver MX's. :) Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 18, 1998
Subject: Longer prop
A while back I mentioned that my comparatively untorquey 532 and it's 2.58:1 B-box was not happy with it's 64" 3-blade Ivoprop. Consequently I have been using it as a 2-blade, and that was not too bad. Sold that prop to a guy with a Buckeye paraplane, and got a 66" 2-blade Ivo. First flight this evening just before dark. WOW!!! No numbers yet for comparison, but first impressions are that acceleration and climbout are 25-30% better. Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 18, 1998
I should change this thread subject line to "Loose Lips ...MINE". On my post about this earlier today, I made reference to John's FS wing failure. He had related that to me as part of a private (him and me) email exchange several months ago, and it was our understanding that it was private info, certainly not mine to make public. So today I screwed up badly. While writing earlier today, I had myself thinking I was repeating a piece of that exchange that was perhaps known history. But I started to realize my mistake more and more as the seconds passed after hitting the Send key. I blew it and my sincerest apologies go to John. There is no way I can undo that send. I just wanted you all on the list to know that I've sucked John into a discussion that might better be left dropped. Worst of all, I slipped and breached a mutual understanding. As a matter of list-serv habits, I realize even more now how oh-so-important it is to review what you say, names you mention, etc, etc. A key piece to the original subject is that these planes are solid but not designed for aerobatics. Kolb says don't do them. John didn't want to talk about it. I'm wishing like heck the subject would die, and after this message I think I won't hit Send on anything for awhile. -Ben 'looking for a deep dark hole' Ransom ________________________________________________________________________________
Date: Nov 18, 1998
> >> >>Steph, >The only shortcoming that I can think of is that if you wreak a Kolb, it's >probably going to be expensive to repair. >>John Jung >>Firestar II N6163J >>SE Wisconsin > >If that was really important, we'd all still be flying Quicksilver MX's. :) > Richard Pike > MKIII N420P (42oldpoops) Hey Guys: I reckon I better comment on John J's very broad statement on expense involved in repairing Kolbs. I find that most of the repairs that are required in normal everyday little crashes, scrapes, rips, and tears, a few bent aluminum tubes, and cracked nose pods, etc., can be fixed with what ya got left over from building, unless it has been a long time since you did your building, but by then you know how to do most of it cheap. Big jobs like rebuilding fuselage, building new wings, or your butt, can get right in yo pocket book. Neat thing about these little planes is that most of the repair work we can do ourselves cause we built these little suckers. For us that have our planes registered EXP, we get the FAA Repairmans Certificate for our particular airplane and can sign off on all our repairs. Don't have to hunt down and a&p to do it for us. Nuff said on that, john h (going to wash off the dirt and leaves I been playing in all day) ________________________________________________________________________________
Date: Nov 18, 1998
From: Cliff / Carolyn Stripling <striplic(at)dfw.net>
>I am considering building a Kolb Firefly or Mk III. I was recently told that the single strut bracing on the wing allows for wing twist and failure. Steph and all, I would say the person who told you that was incorrect. I think the Kolb wing is very strong. I just helped a friend cover his today. It uses a 6" main tubular alum spar, built up ribs and drag strut, steel inner rib and attach points and Stits cover that prevents any twist. A single lift strut is very adequate. The streamlined formed lift strut when lined on the inside with a second tube can function without even the jury strut. The only reason that Kolb uses double struts on the Firefly (I was told by a person within the company) is to add more drag to fit within the Part 103 speed requirements. I have the MKIII (jury strut free) and am very happy. Later, Cliff & Carolyn Stripling Him: Retired Pharmacist (972)247-9821 Dallas Texas Her: Real Estate Broker - Texas and Marble Falls Texas Both: 5th Wheel - RV - Travel Kolb MKIII - N582CC (50+ hrs) ________________________________________________________________________________
Date: Nov 18, 1998
I'm wishing like heck the subject would die, and after this message I think I won't hit Send on anything for awhile. -Ben 'looking for a deep dark hole' Ransom Hi all- I hope I'm not upsetting anyone, especially you Ben, by responding to this thread yet one more time, however one of the most valuable contributions this list makes to me as a Kolb pilot wanna-be is the open and honest sharing of mistakes those of you with much experience have made. By the way, I'm building my Mk III up in a loft at my in-laws place of business. Two gentleman have come up to check it out. Both are GA pilots and both have immediately commented on the impressive construction of the wings. Peter Craig Malden, MA Mk III ________________________________________________________________________________
Date: Nov 18, 1998
Subject: Re: Loose Lips
John is very graciously inviting me back out of the hole. See how long it takes me to get back on the Send key? Really, just -Ben Ransom ________________________________________________________________________________
Date: Nov 18, 1998
Subject: Re: Wing twist - UltraStars
I too had an "early edition" UltraStar that lacked the inboard ring around the end of the tube/spar. I added a ring using chromoly flat bar & plate. Form the flat bar into a ring of 2 halves with the 4ends bent out 90* & drilled (so the 2 halves can be bolted down on the tube.) On each half, I welded 2 tabs, spread equally apart on the edge of the ring. The face of these tabs are perpendicular to the spar & parallel to the edge of ring. This is then bolted & rivoted onto end of spar. then out of the flat plate I cut out an X that connected the 4 tabs & rivoted it to the 4 tabs. All the rivot & bolt holes should be drilled before welding the tabs as the metal will be difficult to drill afterwards. All this can be done with just a 16" hole cut out of the inboard side of the wing. The difference in handling was astounding. It was crisper & rolled much faster. It john hauck wrote: > > Wing twist was a way of life with the Ultrastar, but I know of no Ultrastar > that had a wing failure because of wing twist. Of course I don't know much, > but I have never heard of such. > > Firestar didn't have wing twist because Homer Kolb and Dennis Souder and the > rest of the gang at Kolb Aircraft came up with a much improved mainspar > attach system to the inboard rib. > > Likewise, the remainder of the Kolb line. I invite you to try and twist the > wing of my old MK III. > > ________________________________________________________________________________ Scott.Pierskalla(at)HBC.honeywell.com, dwegner(at)isd.net
Subject: Re: wing failures ??
Date: Nov 18, 1998
Stephen, I have the 5-rib wing of the Original FireStar and my buddy that I fly with every weekend has the same. He bought a used one and after taking the fabric off, noticed extra drilled holes on the bottom of the main spar, at the H-section, because the builder botched the repair job after an accident. He has checked it over thoroughly, the A/P mechanic that he is, and determined the plane is safe to fly. That FireStar I'm sure has over 400 hrs logged in 12 years with the 447 40 hp engine. He does inspect the spar on a regular basis and sees no problem. My FireStar has 420 hours on it and we both are flying out to AirVenture '99 next summer. If there was a problem with our older FireStars making a trip like that, we definitely would not be doing it. You can expect to see two Original FireStars out there, one with extra holes drilled in a place you wouldn't want them, but then that hefty 5" spar has proven itself on other Kolbs in many compromising situations. Back in my early days when I was learning to fly the thing and I'd have it in a 90 mph dive by not paying close attention to my airspeed and if there was a wing twist problem, I wouldn't be here telling you this. By the way, we both fly without parachutes. I say this not because we are stupid pilots, but because we believe in what we fly is more than adequate to get us there and back again ....... safely. Any more questions? Ralph Burlingame Original FireStar, 447 powered writes: ..... a concern I have >is in the single strut brace on the wings. I was recently told that >this is a problem area as it allows wing twisting and possible failure > (it allegedly has occurred). s or other shortcomings. Thanks for >your response. Steph..... > ________________________________________________________________________________
Date: Nov 18, 1998
> >There is no way I can undo that send. I just wanted you all on >the list to know that I've sucked John into a discussion that might >better be left dropped. Worst of all, I slipped and breached a mutual >understanding. As a matter of list-serv habits, I realize even more >now how oh-so-important it is to review what you say, names you mention, >etc, etc.. > >-Ben 'looking for a deep dark hole' Ransom > >. Gosh John I am afraid the only way to get Ben back for this breach of etiquette is to securely bungey him to your landing gear while you do crow hops. Anyhow since Ben (the mouth) Ransom ;) brought it up what actually happened to the wing in its failure mode. Woody ________________________________________________________________________________
Date: Nov 18, 1998
> >.The only shortcoming that I can think of is that if you wreak a Kolb, it's probably going to be expensive to repair. >John Jung >Firestar II N6163J >SE Wisconsin. I would have thought the opposite. Most of the tubes you can buy at a metal tube store. Most of the steel can be rewelded. If you wreck a Challenger or Quicksilver then you will be paying big bucks. If we can build it we can fix it. Woody ________________________________________________________________________________
From: "Larry Bourne" <larrybiglar(at)earthlink.net>
Date: Nov 18, 1998
Hi Stephen: Can't resist getting my .02 worth in too. I mentioned some time ago to the group that I had to make a choice while building my Mk III. I had enuf money for full radios ( for flying in LA airspace), or a ballistic chute - not both. Chewed my nails some till I built the first wing. Hah ! ! ! Sent the money for the radios. Maybe get the chute later, but I doubt it. If you'd like some numbers, consider this: The main spar is 6" dia. and measures a little over .090 wall. There is a massive steel rib / ring solidly rivetted to the inboard end. 9 more ribs are rivetted on with 10 steel rivets each. An additional 18 half ribs are spaced between the 9 full ribs, and rivetted to the spar and to the leading edge. Full ribs are rivetted to leading and trailing edge spars. That's for each wing. Drag struts are 4 - (four) - thicknesses of thick aluminum tubing, telescoped and steel braced. One of my pilot / builder buddies said "My gosh, you could hang a 172 from those, and they wouldn't even creak." Nuff sed. Just something to get the group going - maybe a little twist - built in - wouldn't be that evil a thing. A little washout might make it almost unstallable, cause the tips would keep flying after the inboard sections were stalled. Course, I understand Kolb's are very mild in the stall anyway. And, thinking about it, you'd probably lose some lift. Any of you engineer types have any thoughts ?? Big Lar. > From: Stephen Feldmann <stephen.feldmann(at)qm.phxhs.k12.az.us> > To: kolb mailing list > Subject: Kolb-List: wing failures ?? > Date: Wednesday, November 18, 1998 10:15 AM > > > Subject: Time: 10:43 AM > wing failures ?? Date: 11/18/98 > To Kolb builders & flyers: I am doing some research as I am interested in building a Kolb Firefly, Slingshot or Mk III. I would like to hear about your building experiences (problems/frustrations) and the flight characteristics in general but ..... a concern I have is in the single strut brace on the wings. I was recently told that this is a problem area as it allows wing twisting and possible failure (it allegedly has occurred). I don't mean to alarm anybody especially if it is not a problem but I would like some response from you guys as to the validity of this or other shortcomings. Thanks for your response. Steph..... > > stephen.feldmann(at)qm.phxhs.k12.az.us > > > > > ________________________________________________________________________________
Date: Nov 19, 1998
Subject: Re:Rotax 447 timing
During my ongoing search for ways to reduce my EGT's I found that the factory- set timing was 2.2 degrees late. Rut Fuller confirmed this observation and worked with me to insure dead-on resetting. Tom Hertz, our resident factory- trained expert, was not so sure we should have reset the factory's timing because he thought they set it electronically at during the factory test run and it was optimized for this particular engine. He reasoned that the standard .086-before-TDC / eyeball-to-reposition-the -transducer method was a field fix and probably not as accurate. My argument is that even if they use a timing light, access for repositioning (tweaking) the pick-up transducer would be a major problem. Yes, the EGTs did apprear to go down slightly after we reset by the "field" method. Here's another thought on EGT probe/gage systems. Are Tempilstick temperature indicators accurate enough to use in varifying calibration ? For folks who don't know Templesticks look and work like color crayons but the marks they make melt at a given temp. It would seem that we could put a Templstick mark on the probe and watch the gage as we apply heat with a heat gun. I bought two of them at a local welding supply ( $8 a pop) but they did not know much about them. I remember that we used them in liquid rocket engine test firings but that was long ago. I am planing to cal the Mfgr today and will report back. Plane Duane in Tallahassee ________________________________________________________________________________
From: "F J MARINO" <FMARINO(at)netlink1.nlcomm.com>
Date: Nov 19, 1998
Just to let you know Steve the Cessna 172 and the 150 and I think all Cessna air craft have only one strut and I'm willing to bet that their wing isn't built nearly as stong as the kolb. The wing on the Kolb is what takes the longest time to build because there is some many gussets and braces to cut and rivet. You need to look at some ones plans of the kolb and you will not worry about wing failure. Frank From: Stephen Feldmann <stephen.feldmann(at)qm.phxhs.k12.az.us> Date: Wednesday, November 18, 1998 10:38 AM Subject: Kolb-List: wing failures ?? > > Subject: Time: 10:43 AM > wing failures ?? Date: 11/18/98 >To Kolb builders & flyers: I am doing some research as I am interested in building a Kolb Firefly, Slingshot or Mk III. I would like to hear about your building experiences (problems/frustrations) and the flight characteristics in general but ..... a concern I have is in the single strut brace on the wings. I was recently told that this is a problem area as it allows wing twisting and possible failure (it allegedly has occurred). I don't mean to alarm anybody especially if it is not a problem but I would like some response from you guys as to the validity of this or other shortcomings. Thanks for your response. Steph..... > >stephen.feldmann(at)qm.phxhs.k12.az.us > > > > > > > ________________________________________________________________________________
Date: Nov 19, 1998
Date: Nov 19, 1998
John, I just recieved my issue of Expermenter and want to tell you that your Kolb looks great, nice job, wish my MKIII looked half as good Frank From: John Jung <jrjung(at)execpc.com> Date: Wednesday, November 18, 1998 1:19 PM Subject: Re: Kolb-List: Wing failures ?? > >Steph, > If there was such a problem, Kolb would have gone out of business long ago, and this list would not exist. The only Kolb wing failure that I have even heard about was a compression strut failure on the earliest design of the Ultrastar. The only shortcoming that I can think of is that if you wreak a Kolb, it's probably going to be expensive to repair. >John Jung >Firestar II N6163J >SE Wisconsin > >stephen.feldmann(at)qm.phxhs.k12.az.us wrote: > >> >> I am considering building a Kolb Firefly or Mk III. I was recently told that the single strut bracing on the wing allows for wing twist and failure. I want to hear from builders and flyers who can give insight or experiences on this ....or other shortcomings. Thanks, I don't want to alarm anybody but I am doing the research by asking you guys to see if this is a valid problem. Steph..... > > > > > > ________________________________________________________________________________
Subject: Re: Rotax 447 timing
Date: Nov 19, 1998
I called CPS about this when I retimed my scdi 447. They said even the factory set engines are sometimes off in their timing. Mine was timed at .070" and seemed run fine. I retimed it to .086" by the "field method" and didn't notice any egt change. Ralph Burlingame Original FireStar, 447 powered ] >because he thought they set it electronically at during the factory >test run and it was optimized for this particular engine. He reasoned that the >standard .086-before-TDC / eyeball-to-reposition-the -transducer >method was a field fix and probably not as accurate. My argument is that even >if they use a timing light, access for repositioning (tweaking) the pick-up >transducer would be a major problem. Yes, the EGTs did apprear to go down >slightly after we reset by the "field" method. > > >Plane Duane in Tallahassee ________________________________________________________________________________
Date: Nov 19, 1998
Subject: lb-List:2-Place Firefly
Hi i was just wondering if the 2-Place Firefly is side by side. If anyone knows just email me back ok. Thanks Scott Southern California ________________________________________________________________________________
Date: Nov 19, 1998
I have no wish to talk for Dennis but I did a lot of analysis on the Kolb before purchasing one. A single strut is not a penalty if the wing is strong enough torsionally and the Kolb defiantly is. Sounds like ignorant folk stories to me, Dick C ________________________________________________________________________________
Date: Nov 19, 1998
HEY DUANE, If you want to get your EGT's down, Load your engine slightly by increasing the prop pitch a little at a time. You can get the temps right where you want them to be on clinbout and then reposition the jet needle to give you your cruise temp. Firehawk. From: MitchMnD(at)aol.com <MitchMnD(at)aol.com> Date: Thursday, November 19, 1998 7:53 AM Subject: Kolb-List: Re:Rotax 447 timing > >During my ongoing search for ways to reduce my EGT's I found that the factory- >set timing was 2.2 degrees late. Rut Fuller confirmed this observation and >worked with me to insure dead-on resetting. Tom Hertz, our resident factory- >trained expert, was not so sure we should have reset the factory's timing >because he thought they set it electronically at during the factory test run >and it was optimized for this particular engine. He reasoned that the >standard .086-before-TDC / eyeball-to-reposition-the -transducer method was a >field fix and probably not as accurate. My argument is that even if they use >a timing light, access for repositioning (tweaking) the pick-up transducer >would be a major problem. Yes, the EGTs did apprear to go down slightly after >we reset by the "field" method. > >Here's another thought on EGT probe/gage systems. Are Tempilstick temperature >indicators accurate enough to use in varifying calibration ? For folks who >don't know Templesticks look and work like color crayons but the marks they >make melt at a given temp. It would seem that we could put a Templstick mark >on the probe and watch the gage as we apply heat with a heat gun. I bought >two of them at a local welding supply ( $8 a pop) but they did not know much >about them. I remember that we used them in liquid rocket engine test firings >but that was long ago. I am planing to cal the Mfgr today and will report >back. > >Plane Duane in Tallahassee > > > > > ________________________________________________________________________________
Date: Nov 19, 1998
Subject: Re: : Kolb-List:2-Place Firefly
FireFly is only one very narrow seat, unless you could find a couple of 75# slim jims. GB ________________________________________________________________________________
Date: Nov 19, 1998
Subject: Washout
> Just something to get the group going; maybe a little twist - built in - wouldn't be that evil a thing. A little washout might make it almost unstallable, cause the tips would keep flying after the inboard sections were stalled. Course, I understand Kolb's are very mild in the stall anyway. And, thinking about it, you'd probably lose some lift. Any of you engineer types have any thoughts ?? > Big Lar. > I put no washout in the wing, but when I built the ailerons, I raised the outboard ends by about 3/4" to give it just a tad of washout. Figured it wouldn't hurt. Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 19, 1998
Subject: Re: Washout
WRT Washout: I wouldn't put any in. As we discussed a few months back, the planes fly/mush along at stall speed without spinning, even with mild aileron action. Although not advised as normal practice, they can even be aileron controlled (roll) while stalling straight ahead. That's pretty stable stall mode flight and I wouldn't fix what ain't broke. -Ben Ransom ________________________________________________________________________________
Date: Nov 19, 1998
> >Just to let you know Steve the Cessna 172 and the 150 and I think all Cessna >air craft have only one strut Cessna 120A/140A have two struts. ________________________________________________________________________________
From: "The Carell/Richard Clan" <jcarell(at)usa.net>
Subject: Kolb Flyer
Date: Nov 17, 1998
I'm looking for info, comments, bad-mouthing, praise, or whatever on the Kolb Flyer twin engined U/L. I can't seem to find anything about it on the net. Your help would be greatly appreciated. Thanks Jerry Carell U/L driver wannabee ________________________________________________________________________________
Date: Nov 19, 1998
Hi Ben: Didn't plan on putting any WO in my wings. (and couldn't now, anyway) Just threw it out for thought and speculation. Thanks for the reply. Also, as far as the building process, I have to admit, I went out the other night and measured and counted. Wanted to be real sure when talking to this group. They know their stuff. I've been building - and building -and and and - - - - It's been fun, challenging, rewarding, ego gratifying, etc. but I'm sorry - I sure wish it was flying. Well, hopefully by next summer. How long have I been saying that ?? Have Fun with your Neat Toy. Big Lar. > From: Ben Ransom <ransom(at)mae.engr.ucdavis.edu> > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Washout > Date: Thursday, November 19, 1998 5:07 PM > > > WRT Washout: > I wouldn't put any in. As we discussed a few months back, the planes ________________________________________________________________________________
Date: Nov 19, 1998
Hi O.P.: Not a bad plan. Can you notice any effect, beneficial or otherwise ?? I learned about the benefits of WO in flying school. Now I'm learning that hang gliders have quite a bit of WO, and on my last lesson I repeatedly found that the stalls were unbelievably mild - even in a turn, and even in a quite steep turn. Believe me, I was really watching. That was Momma Bourne's young son hanging up there, and I may be loco, but I'm most certainly not suicidal, local opinion to the contrary. Big Lar. > From: Richard Pike <rpike(at)preferred.com> > To: kolb-list(at)matronics.com > Subject: Kolb-List: Washout > Date: Thursday, November 19, 1998 4:43 PM > > > > > Just something to get the group going; maybe a little twist - built in - > wouldn't be that evil a thing. A little washout might make it almost > > > I put no washout in the wing, but when I built the ailerons, I raised the > outboard ends by about 3/4" to give it just a tad of washout. Figured it > wouldn't hurt. > Richard Pike > MKIII N420P (42oldpoops) > > > > ________________________________________________________________________________
Subject: Fabric Covering
Date: Nov 19, 1998
Hi Group: A week or two ago, there was some discussion about tightening fabric on wings, and some of the problems that crop up. Last night I was re-reading the Oct. ' 98 issue of Sport Aviation, and toward the bottom of the center column on page 93 is a reference to inter-rib bracing tape. On page 94 is a diagram. Since I'm getting quite close to covering - finally - I listened to you guys, and then read this with great interest. Any commments ?? Seems like this could really help the " wavy ribs " problem, with almost no weight. Or is it that much of a problem. The point was made about the last half-rib, between the last rib and the wing tip as being difficult to hold straight under fabric pressure. Would this hold it straight and true ?? TIA. Big Lar. ________________________________________________________________________________
Subject: Re: Fabric Covering
Date: Nov 19, 1998
From: Larry Bourne <larrybiglar(at)earthlink.net> Date: Thursday, November 19, 1998 09:41 PM Subject: Kolb-List: Fabric Covering > >Hi Group: A week or two ago, there was some discussion about tightening >fabric on wings, and some of the problems that crop up. Last night I was >re-reading the Oct. ' 98 issue of Sport Aviation, and toward the bottom of >the center column on page 93 is a reference to inter-rib bracing tape. On >page 94 is a diagram. Since I'm getting quite close to covering - finally >- I listened to you guys, and then read this with great interest. Any >commments ?? Seems like this could really help the " wavy ribs " problem, >with almost no weight. Or is it that much of a problem. The point was made >about the last half-rib, between the last rib and the wing tip as being >difficult to hold straight under fabric pressure. Would this hold it >straight and true ?? TIA. Big Lar. > > > > > > ________________________________________________________________________________
Subject: Re: Kolb Flyer
Date: Nov 19, 1998
> > I'm looking for info, comments, bad-mouthing, praise, or whatever on the > Kolb Flyer twin engined U/L. I can't seem to find anything about it on > the > net. > > Your help would be greatly appreciated. > > > Thanks > > Jerry Carell > > U/L driver wannabee Hello Jerry, I have over 300 hours in a Flyer. Also have some images of it on my webpage: http://www.angelfire.com/ok/froghair/ Overall, it's a great little plane although it does come-up short on climb-out (~200 fpm max). Aside from that, it handles like a dream, very forgiving but able to handle a pretty stiff wind also. Mine has Solo engines and they require a little more attention than a Rotax but the parts are quite a bit cheaper. If you want to know specifics, ask away... -Mick Get your free, private e-mail at http://mail.excite.com/ ________________________________________________________________________________
Date: Nov 19, 1998
<< A little washout might make it almost unstallable, cause the tips would keep flying after the inboard sections were stalled. Course, I understand Kolb's are very mild in the stall anyway. And, thinking about it, you'd probably lose some lift. Any of you engineer types have any thoughts ?? > Big Lar. > I put no washout in the wing, but when I built the ailerons, I raised the outboard ends by about 3/4" to give it just a tad of washout. Figured it wouldn't hurt. Richard Pike MKIII N420P (42oldpoops) >> I love my Firestar, don't get me wrong, but I think that it could be brought closer to perfection here on earth, If it had wash-out. It would add drag, sure, but it would do just as Lar says, keep the tips flyin when the main wing stalls. Maybe the drag could be compensated for by changing the angle of attack of the horizontal stabilizer to a more flatter angle instead of the LARGE angle presently built in....this also causes drag!.....plus stability of course, , but isn't it nice not to have a wing tip drop off heading for a spin.. The pterodactyl had that washout, and I considered it one of the safest to fly because of it................very docile in spite of having a short chord.......GeoR38 ________________________________________________________________________________
Date: Nov 19, 1998
> >Hi Group: A week or two ago, there was some discussion about tightening >fabric on wings, and some of the problems that crop up. Last night I was >re-reading the Oct. ' 98 issue of Sport Aviation, and toward the bottom of >the center column on page 93 is a reference to inter-rib bracing tape. On >page 94 is a diagram. Since I'm getting quite close to covering - finally >- I listened to you guys, and then read this with great interest. Any >commments ?? Seems like this could really help the " wavy ribs " problem, >with almost no weight. Or is it that much of a problem. The point was made >about the last half-rib, between the last rib and the wing tip as being >difficult to hold straight under fabric pressure. Would this hold it >straight and true ?? TIA. Big Lar. Hi Gang: Been a while since I did any covering, but I doubt if it has changed since I last covered my MK III wings in '92or '93. I was self taught how to cover, dope, and paint fabric covered airplanes. Started in '84 and did a lot of it until the final cover on the MK III. Out of three airplanes I built and finished, two of those planes got the wings covered twice, the MK III had two sets of wings the first few hours of flight. All turned out pretty good. What I learned about covering and painting I got out of the bible "The Stits Manual" and the covering and painting instructions that came with each particular plane kit. I found if I did what Ray Stitts told me to do I would get good results. I did and it worked. I shrink the fabric tight, cause in the winter the fabric will loosen up some when it gets cold, and I do not want loose fabric. I shrink the fabric on the wing before popping fabric rivets. Once the fabric is tight, if a rib has a little curve to it, I can straighten it up thru the fabric. Once it is riveted, I lose that option. Outboard false rib won't go anywhere if it is properly braced before covering and shrinking. It is awfully rewarding to do a good covering job and a lot of fun. Enjoy it while you are learning and when you are doing it, cause when you finish, that part is all over. Don't personally recommend rivets before or during the fabric shrinking process. Gotta go look at the Atlanta and New Orleans sectionals, maybe Jacksonville too, and get ready to go to the BBQ Flyin at Quincy, Fl, Saturday. Gosh, I haven't been anywhere since OSH. Later Gang, john h ________________________________________________________________________________
Date: Nov 19, 1998
> >Hi O.P.: Not a bad plan. Can you notice any effect, beneficial or > Since I have never flown a MKIII with a standard wing, no basis for comparing, but it is very stable in slow flight, and stalls straight ahead, or in turns with no meanness. Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 19, 1998
Subject: Non-Kolb question
Last weekend I bought a 1/2 ownership in a project. An old man in our area was building a customized Mini-Max, and died part way through the project. Here's the interesting part: with only cosmetic changes, and a slightly longer landing gear, he has built it into a scale replica of Roscoe Turner's "Turner Special", a racing plane from the 1930's. Unfortunately, after his death, his daughter threw away a lot of his papers, including the pictures of the original, and it's paint scheme. I have come to respect the talent on this list, and beg your indulgence in this non-kolb item, please e-mail rpike(at)preferred.com if anyone knows any reference resources where I can find the paint scheme. Thanks. Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 19, 1998
> Since I have never flown a MKIII with a standard wing, no basis for >comparing, but it is very stable in slow flight, and stalls straight ahead, >or in turns with no meanness. > Richard Pike > MKIII N420P (42oldpoops) Hi Richard and Gang: Sounds like Richard's MK III non-standard wing has the same flight characteristics as all the Kolbs I have flown. The Ultrasater, Firestar, and MK III all use the same wing section outside dimensions except span. All fly just like Homer Kolb wanted them to fly, gentle with no surprises or bad habits. The Slingshot also shares those wonderful Homer Kolb flight characteristics. Thanks Homer, john h ________________________________________________________________________________
Date: Nov 19, 1998
Subject: Re: 2 Place Firefly
Hi Scott, Have you had an opportunity to look at ? I think you will find that the Firefly is single place only. L. Ray Baker Lake Butler, Fl ________________________________________________________________________________
From: dralle(at)matronics.com (Matt Dralle 925-606-1001)
Date: Nov 20, 1998
Subject: Fall Fund Raiser Contributor List #1...
Dear Listers, As promised, please find attached a list of everyone that has made a contribution as of Thursday 11/19/98 in the Fall 1998 List Fund Raiser! If you made a contribution using a company check, be sure to check under that company name if you can't find your personal name. To the best of my knowledge, there is only one name that is missing and that was a cash donation in which I misplaced the envelope. If you sent cash, and your name is missing, drop me an email and I'll make sure that your name is listed on the follow up Contributor List post in a couple of weeks. Well, I must say that this was the most successful Fund Raiser for the Lists to date. I want to thank each and every one you that has made a contribution to support this valuable service. Your generosity has paid for the most recent system upgrades and will support the on going expenses of running the Lists into the coming year. The number of contributing members as a percentage of the total number of members on the combined lists was up by 100% percent this time. There were many 'first time contributors' this time around, and I want to thank them for coming on board! I also want to send a personal and hearty thank you out to my good friend Al Mojzisik for his unrelenting support, encouragement, and creativity on my behalf during this Fall's Fund Raiser. Al, you're a great friend and I thoroughly appreciate all of your help. Thank you! I would also like to thank those of you that posted inspiring words about the List and what it means to you. It would seem that your comments inspired many to make that first time contribution! Many of you included a few words of thanks and encouragement along with your contributions and I appreciated each and every one. I was very moved by the incredible support and friendship each of you have expressed. I have been very inspired by your kind words and appreciation of the long hours I have spent maintaining and upgrading this service. If you were meaning to make a contribution but it slipped your mind, there is still plenty of time to get it in before the next Contributor List posting. As I mentioned above, I will be posting a Follow Up Contributor List in about two weeks to acknowledge the stragglers. Thanks again to *everyone* that made a contribution! *YOU* make this List possible! I'm just here to steer... :-) Matt Dralle List Administrator To make a Contribution with credit card, please go the the special Secure URL: http://www.matronics.com/contribution.html or you may contribute by sending a personal check to: Matt Dralle PO Box 347 Livermore, CA 94551 ================== Fall Fund Raiser Contributor List #1 ===================== John Abell Robert Acker Robert Adams Rudy Albachten III Brent Allen Patrick Allender Edward Anderson John Anderson Aero Electric Connection M.E. Asher James Ashford Kent Ashton Robert Baggett Gary Baker Ray Baker Melvin Barlow Bruce Bell Belted Air Power, LTD Ryan Bendure Peter Bennett Lee Bergner Richard Bibb Dave Biddle Paul Bilodeau Carroll Bird Warren Bishop Stan Blanton Wayne Bonesteel Larry Bowen Bob Bower Eustace Bowhay William Boyd Lewis Bragassa Garrett Bray John Brick Mike Brogley Tim Bronson Chris Brooks James Brown Thomas Brown David Bruner Raymond Bryant Sam Buchanan Bradley Bundy Peter Burrowes Bob Busick Ronald Calhoun Jerry Calvert Louis Cappucci Richard Caummisar Stanley Challgren Don Champagne Tom Chapman Robert Chatham Adrian Chick R.L. Christensen John Ciolino James Clark Buck Clary Dennis Clay John Cocker Edward Cole Steven Cole Moe Colontonio Tony Colucci James Conaway Gary Corde Bill Costello Timothy Cotter James Cowen Thomas Craig-Stearman W.B. Cretsinger Jonathon Croke Thomas D'Aurizio John Darby Jr. William Davis Jr John Devlin Robert Di Meo Donald Diehl John Dralle Joe Drumm Mike Ducote Russel Duffy Sylvain Duford Chuck Dunlap Chris East Brian Eckstein Chris Edwards Martin Emrath Charles England David Faile Jr. Deal Fair Jeff Farrar Peter Ferguson Lanny Fetterman Michael Fiedler Michael Fine Gerald Forrest Carl Franz Clifford Fred Hiatt Mark Frederick Ted French Frank Friedman Leon Friedman Carl Froehlich Terence Gannon Don Gates Robert Gibbons Roberto Giusti Roy Glass Ken Glover Mark Goldberg Chris Good Shelby Gott Gene Gottschalk Jordan Grant Thomas Graumlich Ken Gray Raymond Grenier Rich Grialou Bill Griffin Tony Gunn Ivan Haecker Craig Hagen Robert Hall Steve Hamer Nick Hampton Merle Hargis Denton Harjehausen Ken Harrill Dennis Hart J.C. Hassall Cecil Hatfield Wes Hays Randall Henerson Mike Henney Craig Hiers John Higgins Michael Hilger Vincent Himsl Cris Hinch Joseph Hine Frank Hodson Kelly Hoffer, III John Holmgreen Kevin Horton John Hosack Ken Hoshowski Robert Hughes James Hurd Michael Hurst Interlink Recuiting Jerry Isler Fred Jackson Steven Janicki Bob Japundza Ken Jeens Kenneth Jeens Dick Jennings Keith Jensen Johann Johannsson Stephen Johnson Graham Jones Bill Jonker Scott Jordan Thomas Jordan John Karnes Yohannes Kayir Robert Kellar Patrick Kelley Hal Kempthorne Bernie Kerr L.M. Klimgmuller Jerald Knievel Bruce Knoll Michael Kosta Chris Krieg Dan Krueger Charlie Kuss Mark LaBoyteaux Frank Laczko Sr. Richard Lamb Jim Larsen Finn Lassen Mike Laverty John Lee Philip Lehrke Randy Lervold Tim Lewis Jim Lewman Brian Lloyd Ed Loveday Philip Lozman David Lundquist Lawrence MacDonald Hugh MacKenzie Don Mack Todd Magargle Francis Malczynski Bill Marr Nigel Marshall Audio Mart, Inc Clifford Martin Tom Martin Mark McGee Michael McGee Michael McGee Tedd McHenry Larry McKee Mike McKenna Joel McLaughlin George McNutt Kent Mead Don Mickelson Merle Miller Duane Mitchell Allan Mojzisik Warren Moore John Morrissey Graham Murphy Douglas Murray Thomas Nguyen James Nice Vincent Nicely William Nichelson Jack Noble Rob Norris Robert Noyer Edward O'Connor James Olendorf Tom Olson Jeff Orear Tom Orsborn William Pagan Lyle Pahnke Gary Palinkas John Pasemann Don Pawn Shop Dennis Persyk Eric Petersen Alex Peterson Don Pfeiffer David Pfister Randy Pflanzer Greg Phillips Richard Pick Jim Pickrell George Pinneo Jim Pollard Paul Quick Richard Rathbun D.E. Rayfield Derek Reed Richard Reynolds Paul Riedlinger Rob Rimbold Daniel Ripley Philip Rogerson Doug Rozendaal Carlos Sa Jim Sager Martin Sailer Jr. Andrew SanClemente Cheryl Sanchez Tom Sargent Nate Schiff Doug Shenk Randy Simpson Richard Sipp Bob Skinner Jonathan Smith Philip Smith Shelby Smith David Snyder Gary Sobek Hyun Sook Mazataud Stphen Soule George Stanley Terrel Stern Randall Stevens Bruce Stobbe Cliff Stripling Stan Sullivan Ron Taborek Geoff Thistlethwaite Todd Thompson Mark Todd Jim Van Laak Gert VanDerSanden Gerald VanGrunsven Stanley VanGrunsven Gary VanRemortel Ronald Vandervort Tom Velvick Joe Walker D.L. Walsh John Walsh Terrence Watson Horace Weeks Doug Weiler Jim Wendel David Wentzell Leslie Wentzell Steve White Eric Whiteside James Williams Keith Williams Leslie Williams Lewis Willig Elbert Wills Mike Wills Billy Wilson Denton Wood John Wood Donald Woodley Thomas Wormsley Dale Wotring Charles Young Greg Young Barry Youngblood Rich Zeidman Gary Zilik Ralph Zinkham Zenith Aircraft Company Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
From: "Duncan McBride" <dmcbride(at)indigo.fgcu.edu>
Date: Nov 20, 1998
Well, to be excruciatingly accurate the C120/140 have two struts, and the C140A had a different wing, more like the 150, with only the one strut. There is a great web page at http://www.cessna140.com/ From: skip staub <skips(at)bhip.infi.net> Date: Thursday, November 19, 1998 9:54 PM Subject: Re: Kolb-List: wing failures ?? > >> >>Just to let you know Steve the Cessna 172 and the 150 and I think all Cessna >>air craft have only one strut > >Cessna 120A/140A have two struts. > > > > > > ________________________________________________________________________________
Subject: BRS
Date: Nov 20, 1998
Is there any use to having an ignition breaker in the BRS trigger, so the ignition would be cut if the chute was deployed? Has there ever been an instance where the chute became fouled in the prop? Or worse? ________________________________________________________________________________
Subject: re:non-Kolb
Date: Nov 20, 1998
Richard, Try www.airspacemag.com, it can get you into the National Air & Space Museum. They have Turner's plane and their archives can get you a load of stuff for free or at minimal cost. ________________________________________________________________________________
Subject: Re: BRS
Date: Nov 20, 1998
>Is there any use to having an ignition breaker in the BRS trigger, so the >ignition would be cut if the chute was deployed? Has there ever been an >instance where the chute became fouled in the prop? Or worse? Hi Duncan and Kolb Gang: I have used a hand deployed prcht twice, both times forgot to kill eng. First time was still at full throttle when chute deployed, second time was at idle when deployed. Both times the eng was still idling when we hit the ground (me and the plane). I think I recall a prop fouling a chute. It'll wrap right up in a second. My Brother Jim made me a kill system for my 582 from a Radio Shack Plastic Box and two sets of Ford ign pts. Took some 1/16 lexan hooked to a 1/16 inch cable which was hooked to the bridal loop at the apex of the canopy. The lexan went into the pts which were spliced into a wire from ground to kill wires. When prcht fired, cable pulled lexan out of pts and killed eng. Believe me, unless you are some kind of super cool dude, you won't be thinking of hitting kill switches or anything else except getting your buns safely on the ground. When I replaced the 582 with the 912 I didn't reinstall the kill box because it added to the complexity of removing the center section. Do I really need it? I don't know. It is debatable, but for now I fly without it. john h ________________________________________________________________________________
Date: Nov 20, 1998
Subject: Floats and gross weight
Hi, I'm interested in putting my FireFly on floats; maybe a Full Lotus monofloat. It seems like a Full Lotus Monofloat 1000 would be sufficient, but the FBO at a local airport has a few used and new 1700 and 2000 Full Lotus monofloats which he just aquired and is interested in selling (he doesn't know what he wants for them yet though); would something like that be overkill for the FireFly? If I do this, it would definitely have to be an amphib setup; I don't want to be stuck with land or water, I want to use both... According to Full Lotus' web page, the 1000 and 2000 can be set up for amphib (pricey!!!!! $$$$$$) :-( but the 1700 can not. (Any less costly options here?) My main question though is... I'm already at gross weight for my FireFly. Actually, I'm slightly over, maybe 520-530lbs and I believe the gross weight for the FF is 500lbs. Does adding floats affect the gross weight? Obviously they'd add weight, but I thought maybe they act as a "lifting body" which would offset it... ? Oops, I thought of another question: How does the monofloat attach to the plane? Is there a mounting kit or something that I need to buy from someone? (Kolb?) If so, anyone know what it costs? Ummm, one more question. :-) If I were to get my FireFly on floats, I've played with the idea of registering it as an experimental so that I could build float time (for reduced insurance premiums, etc). Is there any problem with using Full Lotus floats on an Exp. aircraft? Any "gotchas" to look out for here with registering my FF as an Exp floatplane in general? (I am the 2nd owner, and not the original builder.) Any info or advice on any of the above would be greatly apprecated. Thanks! -Jon- ________________________________________________________________________________
Subject: Re: BRS
Date: Nov 20, 1998
Yes, there have been cases where the pilot didn't not turn off the engine before deploying the chute. My own experience: upon inspection of a 2 seater Q/S before I took my first lesson; my friend (experienced pilot, came along to see if I'd puke after the big breakfest he gave me) found on the BFI's plane that the static strap that holds the chute to the frame would have fouled because of the way it was tie-strapped on the vehicle! IMHO ::: Ignition breaker would be nice, but I can for-see the problem will be the propeller windmilling for a few seconds or so...it would have to have a delay of some sort so that prop stops before deployment of the chute... -Mark- From: Duncan McBride <dmcbride(at)indigo.fgcu.edu> Date: Friday, November 20, 1998 8:02 AM Subject: Kolb-List: BRS > >Is there any use to having an ignition breaker in the BRS trigger, so the >ignition would be cut if the chute was deployed? Has there ever been an >instance where the chute became fouled in the prop? Or worse? > > > > > > > ________________________________________________________________________________
Subject: UL: Off Topic: ICQ # Change
Date: Nov 20, 1998
My ICQ number has changed, it is now: 2378095 Please update your contacts lists and sorry for the inconvenience. I have qtalk on both 'puters now....ring me up some time. :) -mark- ASC, EAA, USUA PRUA Bradley, CA ________________________________________________________________________________
Date: Nov 20, 1998
Subject: Re: Floats and gross weight
Jon, I've thought a lot about adding floats too. I haven't decided yet, but I do know that I wouldn't add them unless I could do it for under 80-100 lbs. Even that much added weight is a significant compromise to what used to be a 300 lbs empty weight plane. The other big piece of it is that even without floats, you can land in a ton of places right next to the water. I know that ain't the same, but that and the fact that tundra tires and good gear allows much rougher, shorter landing spots in a variety of places is a valid argument against floats. Then there is the compromised flying attributes of the plane and the added risk of water operations. All that said, I'd still love to have some super light floats and may build them someday. As for the gross weight thing, I'd assume that the float is not a lifting surface, rather, just added empty weight. One thing about registering Exp, I assume then that you would need to get a Seaplane rating. Cost, choke, glug, ... -Ben Ransom ________________________________________________________________________________
Date: Nov 20, 1998
Subject: Re: BRS
I have an engine shut down switch built into my Chute deployment handle mounting. It is out of reach so it won't be accidentally be actuated but it is physically tied to the actuating handle. If the engine is running WOT and the cable gets hung in the prop at least the prop won't have a full power stroke behind it. The BRS reps at Sun-n-Fun liked it but said it was more important to make sure that the rocket, cable and canopy have a clear exit path. Mine is a built in soft pack which means I have to have a door or burst-open hole for exit. I am satisfied that between my carefully designed exit, automatic shut down switch and IVO prop which I think would quickly shear off if it met the cable I'll have a pretty good chance if I ever had to pull that handle. I'm not sure one of those nine pound Warp props would shear as easily. Duane the plane in Tallahassee ________________________________________________________________________________
Subject: Re: BRS
Date: Nov 20, 1998
I've seen several planes with this setup, as a backup. I plan to implement it in my Challenger currently under construction. It's definitely not as good as having a delay to let the prop fully stop, but it is better than deploying the chute into a prop spinning at 2000 rpm. -Rob From: Duncan McBride <dmcbride(at)indigo.fgcu.edu> Date: Friday, November 20, 1998 7:46 AM Subject: Kolb-List: BRS > >Is there any use to having an ignition breaker in the BRS trigger, so the >ignition would be cut if the chute was deployed? Has there ever been an >instance where the chute became fouled in the prop? Or worse? > > > > > > ________________________________________________________________________________
Date: Nov 20, 1998
From: Ben Ransom <ransom(at)mae.engr.ucdavis.edu> Date: Friday, November 20, 1998 9:54 AM Subject: Re: Kolb-List: Floats and gross weight >One thing about registering Exp, I assume then that you would need >to get a Seaplane rating. Cost, choke, glug, ... > Nope! not necessay. You don;t need a seaplane rating to legally fly a experimental plan (or a tail-dragger endoresement, or a mult-engine rating - if your exp. plane falls into these). You will need it to get insurance though. :) ________________________________________________________________________________
Subject: Re: BRS
Date: Nov 20, 1998
> >I've seen several planes with this setup, as a backup. I plan to implement >it in my Challenger currently under construction. It's definitely not as >good as having a delay to let the prop fully stop, but it is better than >deploying the chute into a prop spinning at 2000 rpm. > > -Rob Hi Guys: Do you all really think instantaneous deployment is not as good as having a delay? Not hardly. I can almost guarantee you won't want to be sitting there fat, dumb and happy, waiting for your prop to stop so your chute will deploy. Uh, uh!!!!!!!!!!!! If and when you get in a situation when use of the chute is necessary, it won't be like on a nice Sunday afternoon flight where you have time to decide what to do and nonchalantly do it. Your altitude at the time is a big determining factor, attitude of the acft, is it stable, spinning, flipping, flopping, what ever. It will be a big shock that demands instant action, right now. My first deployment was at 200 feet and 75 mph. Airspeed saved my buns. Second deployment was aprx 500 feet. Not a split second to try and decide what you are going to do, when the acft is in a 90 degree dive screaming out of the sky. I few days before I used my prcht the first time I was in Florida at my brother Jim's house. We we were going to repack the chute. Jim asked me if I had ever practiced throwing the deployment bag. NO! He sat me down on an airconditioner unit with my prcht on and said: "Deploy it!" I did. Several days later I did it again from the seat of my Ultrastar at 200 feet AGL. I also practiced in my mind over and over what I would do if I had the requirement. It was second nature, automatic. Same, Same in the Firestar. I practice reaching for the deployment handle on the ballistic chute in my MK III. I know where it is and I can get it with either hand or both without looking for it. In a wildly spinning tumbling acft it may be more difficult locating and pulling that red handle. Make it second nature to be able to do it without thinking about how you are going to do it. And don't fly with the safety pin engaged. I remember a gentleman at Sun and Fun 1990 who saw a video of my prcht deployment in the Firestar. He said he thought he would put his prcht back in his airplane after he viewed the tape. He had flown with it for 6 months and didn't need it, so rather than carry the extra weight around he took it out. To me the prcht is insurance. I don't know if I'll ever need one again, but if I do and I don't have it, it won't do me any good. I've carried the 21 or 22 lbs of prcht with me since day one in the MK III. Never flown the airplane without it. It is a permanent part of the airplane. I don't realize the extra weight; to me it is not extra. Just a little food for thought, john h (getting anxious to fly to Florida in the morning) ________________________________________________________________________________
Date: Nov 20, 1998
Subject: BRS
Hi Gang I also fly with a BRS on my FSII. I think an old ad said it best. And I quote, " I was once asked if I ever used my parachute. I replyed yes, I use it every time I fly, but I have never had to deploy it. Food for thought! Lanny Fetterman ________________________________________________________________________________
Date: Nov 20, 1998
Subject: A Question already
Hey Kolbers I got my first shipment on MK III, Kit 1, yesterday. Unpacked and checked all the nice shiny tubes. Everything looks OK. The Question: Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL MAILING TUBES?? L. Ray Baker Lake Butler, Fl ________________________________________________________________________________
Date: Nov 20, 1998
Subject: Re: Fall Fund Raiser Contributor List #1...
925-606-1001) DRALLE! YOU BEANHEAD! YOU SPELLED MY NAME WRONG! AAARRRGGHHHHH!!! Richard Pike MKIII N420P (420ldPoops) (Good Thing I didn't send him much!) Dear Listers, As promised, please find attached a list of everyone that has made a contribution as of Thursday 11/19/98 in the Fall 1998 List Fund Raiser! ================== Fall Fund Raiser Contributor List #1 ===================== Richard Pick ________________________________________________________________________________
Subject: Re: A Question already
Date: Nov 20, 1998
cut it up and burn it in the fire place, I put mine in my wood burner in my garage while I was building my MKIII in the winter. That was the only way I could keep GeoR38 from giving me advice, keep it hot and he would leave. Frank From: Ray L Baker <rbaker2(at)juno.com> Date: Friday, November 20, 1998 3:20 PM Subject: Kolb-List: A Question already > >Hey Kolbers >I got my first shipment on MK III, Kit 1, yesterday. Unpacked and >checked all the nice shiny tubes. Everything looks OK. > >The Question: Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL >MAILING TUBES?? >L. Ray Baker >Lake Butler, Fl > > > > ________________________________________________________________________________
Date: Nov 20, 1998
Get your money back! BTW, Check's in the mail Matt. Heh...:) My Footsies are starrting to cold. *sniff* Bradley, CA From: Richard Pike <rpike(at)preferred.com> Date: Friday, November 20, 1998 3:59 PM Subject: Re: Kolb-List: Fall Fund Raiser Contributor List #1... > >925-606-1001) > > DRALLE! YOU BEANHEAD! YOU SPELLED MY NAME WRONG! AAARRRGGHHHHH!!! > Richard Pike MKIII N420P (420ldPoops) > (Good Thing I didn't send him much!) > >Dear Listers, > >As promised, please find attached a list of everyone that has made a >contribution as of Thursday 11/19/98 in the Fall 1998 List Fund Raiser! > > > >================== Fall Fund Raiser Contributor List #1 ===================== >Richard Pick > > ________________________________________________________________________________
From: "Geoff Thistlethwaite" <geoffthis(at)worldnet.att.net>
Date: Nov 20, 1998
Ray, I cut one of mine down by 1/4 length and then cut a slot (about 1/4 of the circumference) out, then I screwed it to the wall and kept all my tubes in it. The cut length allowed the uncut tubes to hang out so I could see what was in there (it was mounted on top of a shelf above eye level, but out of the way) The small piece I just screwed to the wall and put any small cut pieces in so I could see and use them possibly later. Hope this helps. Geoff Thistlethwaite From: Ray L Baker <rbaker2(at)juno.com> Date: Friday, November 20, 1998 5:20 PM Subject: Kolb-List: A Question already > >Hey Kolbers >I got my first shipment on MK III, Kit 1, yesterday. Unpacked and >checked all the nice shiny tubes. Everything looks OK. > >The Question: Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL >MAILING TUBES?? >L. Ray Baker >Lake Butler, Fl > ________________________________________________________________________________
Date: Nov 20, 1998
Think you mean the Mark-3 - it is a two place side by side. Requires a license to fly and built and registered as a experimental. > >Hi i was just wondering if the 2-Place Firefly is side by side. If anyone >knows just email me back ok. Thanks > > >Scott > >Southern California > > > > > ________________________________________________________________________________
Date: Nov 20, 1998
Guys, A rectangular wing will stall in the center area first and this is why you will hear the "burble" in the prop prior to stall. There is no need to add any WO with this type of wing. I'm sure this is exactly why Homer used this design. Ralph Burlingame Original FireStar, 447 powered > > > A little washout might make it almost > unstallable, cause the tips would keep flying after the inboard >section were stalled. Course, I understand Kolb's are very mild in the stall > anyway. And, thinking about it, you'd probably lose some lift. Any >of you engineer types have any thoughts ?? > Big Lar. ________________________________________________________________________________
Date: Nov 20, 1998
> >925-606-1001) > > DRALLE! YOU BEANHEAD! YOU SPELLED MY NAME WRONG! AAARRRGGHHHHH!!! > Richard Pike MKIII N420P (420ldPoops) > (Good Thing I didn't send him much!) > >Dear Listers, > >As promised, please find attached a list of everyone that has made a >contribution as of Thursday 11/19/98 in the Fall 1998 List Fund Raiser! > > > >================== Fall Fund Raiser Contributor List #1 ===================== >Richard Pick Oh geeze, I'm sorry! Fatt Dolly Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
From: "Frank & Winnie Hodson" <fwhodson(at)bigfoot.com>
Date: Nov 20, 1998
> > > > > Hey Kolbers > I got my first shipment on MK III, Kit 1, yesterday. Unpacked and > checked all the nice shiny tubes. Everything looks OK. > > The Question: Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL > MAILING TUBES?? > L. Ray Baker > Lake Butler, Fl I had to cut the shipping tubes with a saw to pieces less than three feet befor the recycling center would accept them as cardboard. Be careful though as this operation claimed first blood on my project. Frank Hodson, Oxford ME ________________________________________________________________________________
Subject: Re: BRS
Date: Nov 20, 1998
>I remember a gentleman at Sun and Fun 1990 who saw a video of my prcht >deployment in the Firestar. He said he thought he would put his prcht back >in his airplane after he viewed the tape. John, Would you be willing to share/loan a copy of this tape for the benefit of us that need to better understand and appreciate this experience?? (I would be happy to pay for handling/shipping costs or provide duplication services or whatever that would make this easy for you) Please excuse me if I am being rude in this regard, but I think I could learn a whole lot from your experience. Forgive me in advance, Jon ________________________________________________________________________________
Date: Nov 20, 1998
Subject: Re: Wing failures ??
Ben I know just what you mean I have said some things on this list that after I sent it made me go to the same deep dark hole, boy sure wish I could have stopped the send message don't stay away so long we enjoy your imput , as well as john h Rick Libersat writes: > > >I should change this thread subject line to "Loose Lips ...MINE". > >On my post about this earlier today, I made reference to John's FS >wing >failure. He had related that to me as part of a private (him and me) >email exchange several months ago, and it was our understanding that >it >was private info, certainly not mine to make public. > >So today I screwed up badly. While writing earlier today, I had >myself >thinking I was repeating a piece of that exchange that was perhaps >known history. But I started to realize my mistake more and more as >the >seconds passed after hitting the Send key. I blew it and my sincerest >apologies go to John. > >There is no way I can undo that send. I just wanted you all on >the list to know that I've sucked John into a discussion that might >better be left dropped. Worst of all, I slipped and breached a mutual >understanding. As a matter of list-serv habits, I realize even more >now how oh-so-important it is to review what you say, names you >mention, >etc, etc. > >A key piece to the original subject is that these planes are solid but >not >designed for aerobatics. Kolb says don't do them. John didn't want >to >talk about it. I'm wishing like heck the subject would die, and after >this message I think I won't hit Send on anything for awhile. > >-Ben 'looking for a deep dark hole' Ransom > > > > > ________________________________________________________________________________
Date: Nov 20, 1998
Subject: Re: 912 engine problem
Frank Glad to help you out .. and sorry about getting back to you so late been working some late hours and when I get home it's late I have to feed the cow's , clean up and lights out, get ready for the next day this little overtime stretch should be over soon keep me informed on the 912 ( 409 ) 786-3611 Rick Libersat writes: > >Hi Rick, >I was finally able to decifer all the info you send me including the >telephone message and get a message to Dave Haynes regarding this 912 >for >sale. >Thanks so much for your assistance in this Rick! > >Frank Reynen > >P.s. I lost your phone # and would have called you back yesterday >night. >Pls resend it. > > > > >Please respond to kolb-list(at)matronics.com > > > > >frank > >haynesdled(at)worldnet.att.net > > >NEW 912 ROTAX FOR APPROX 7370.00 > >HIS # IS 541-7478817 >..........FRANK >LOOK THIS UP >www.cs.fredouia.edu/~stei0302/www/ultra/clas > or fredonia. " " " " " " " " " " " >look under the united states ,classified adds under the mounth of >oct.1998 > > > > > >Rick Libersat >> >>BK and Gang: >> >>Breakin was not a requirement back in April 1994 when I started >flying >>my >>912. Has that been changed to a breakin procedure like the two >>cycles? >> >>How bad is the leak? Can you see fuel pouring out of the air filter? >>Or >>are you getting fuel residue on engine from fuel vapor standoff from >>the >>carb? This is a problem with my 912 and significant others I have >>come >>across over the years. Problem is caused by airflow over the engine >>from >>the prop and from flying. Sometimes it is the right carb, sometimes >>it is >>the left, sometimes it is both. A lot depends on how the aircraft is >>trimmed in yaw. My eng has no oil leaks, but the fuel residue keeps >>the >>eng >>nasty most of the time. >> >>John; Does this mean that "excess fuel from the vapor standoff" is >>coming >>forward through the carbs/filters and sucked back all over the >engine? >>And >>this is considered "normal" for pusher applications because of how >the >>carbs are located? The ram-air entering the carb is not strong enough >>to >>keep the fuel vapors from exiting forward trough the airfilters? >> >>How to cure it? Turn the engine around and make a tractor out of it. >> >>This is not an option for a MKIII >> >>Thatis the way the eng was intended to be used, with carbs flying >>backwards, not >>forwards. The same or similar bing carb is used on BMW motor cycles >>with >>no >>problem, but they fly backwards. >> >> I was having carb problems in Dead Horse, >>Alaska, temps in the high 20s and low 30s. A German on a BMW rode up >>the >>Dalton Highway but had no carb problems. What's the difference? My >>carbs >>go one way, his the other. >> >>john h >> >>Is it possible to turn the intake manifolds around on the engine so >>that >>the carb sits on the backside of the manifold and "going backward" >>same as >>the motorcycle? The drawings(topview) I am looking at in the CPS >>catalog >>suggest that this maybe possible.(I am having a ball with this one!) >> >>Frank(wanting a 912 pusher) Reynen MKIII@481 hrs >>http://www.webcom.com/reynen >> ________________________________________________________________________________
Date: Nov 20, 1998
FIND THE "MOTHER" OF ALL MAIL TO SEND IN IT ! ! ! I left one of mine beside the house for 2 years, and it turned into a huge cardboard coil spring. Big Lar. > From: Ray L Baker <rbaker2(at)juno.com> > To: kolb-list(at)matronics.com > Subject: Kolb-List: A Question already > Date: Friday, November 20, 1998 2:54 PM > > > Hey Kolbers > I got my first shipment on MK III, Kit 1, yesterday. Unpacked and > checked all the nice shiny tubes. Everything looks OK. > > The Question: Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL > MAILING TUBES?? > L. Ray Baker > Lake Butler, Fl > ________________________________________________________________________________
Date: Nov 20, 1998
Yeah, there's always that damn insurance isn't there ?? Big Lar. > From: Rob Reynolds <rfreynol(at)mindspring.com> > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Floats and gross weight > Date: Friday, November 20, 1998 2:41 PM > > > > From: Ben Ransom <ransom(at)mae.engr.ucdavis.edu> > To: Kolb > Date: Friday, November 20, 1998 9:54 AM > Subject: Re: Kolb-List: Floats and gross weight > > > > >One thing about registering Exp, I assume then that you would need > >to get a Seaplane rating. Cost, choke, glug, ... > > > > Nope! not necessay. You don;t need a seaplane rating to legally fly a > experimental plan (or a tail-dragger endoresement, or a mult-engine rating - > if your exp. plane falls into these). > > You will need it to get insurance though. :) > ________________________________________________________________________________
Subject: LEAF email
Date: Nov 21, 1998
Hi, does anyone know Leading Edges e-mail address ?. Do they have a web site ? Thanks, Diego O. (Mark III builder, owner) ________________________________________________________________________________
Date: Nov 21, 1998
Ben, we all say things we regret later, lord knows I said plenty of them on this E-mail site, and I think John is a big enough man to forgive, he probably didn't even think about it. Any way have a beer and forget it. PS my buddy and ole glider pilot GeoR38 knows I'm always sticking my feets in my mouf Frank From: rick106(at)juno.com <rick106(at)juno.com> Date: Friday, November 20, 1998 8:52 PM Subject: Re: Kolb-List: Wing failures ?? > >Ben >I know just what you mean I have said some things on this list that after >I sent it made me go to the same deep dark hole, boy sure wish I could >have stopped the send message don't stay away so long we enjoy your >imput , as well as john h > >Rick Libersat > > > writes: >> >> >>I should change this thread subject line to "Loose Lips ...MINE". >> >>On my post about this earlier today, I made reference to John's FS >>wing >>failure. He had related that to me as part of a private (him and me) >>email exchange several months ago, and it was our understanding that >>it >>was private info, certainly not mine to make public. >> >>So today I screwed up badly. While writing earlier today, I had >>myself >>thinking I was repeating a piece of that exchange that was perhaps >>known history. But I started to realize my mistake more and more as >>the >>seconds passed after hitting the Send key. I blew it and my sincerest >>apologies go to John. >> >>There is no way I can undo that send. I just wanted you all on >>the list to know that I've sucked John into a discussion that might >>better be left dropped. Worst of all, I slipped and breached a mutual >>understanding. As a matter of list-serv habits, I realize even more >>now how oh-so-important it is to review what you say, names you >>mention, >>etc, etc. >> >>A key piece to the original subject is that these planes are solid but >>not >>designed for aerobatics. Kolb says don't do them. John didn't want >>to >>talk about it. I'm wishing like heck the subject would die, and after >>this message I think I won't hit Send on anything for awhile. >> >>-Ben 'looking for a deep dark hole' Ransom >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Nov 21, 1998
Subject: Re: LEAF email
Diego E-mail <info@leadingedge-airfoils.com> Source: Ultralight Flying Magazine L. Ray Baker Lake Butler, Fl ________________________________________________________________________________
Date: Nov 21, 1998
<< -Ben 'looking for a deep dark hole' Ransom > >> Ben....bet you never heard this one before....I wanted to confide a "secret" to a friend of 35years the other day, and when I asked him before telling it to him, if he could keep a secret?.....he said "no". ....................end of dialog.........................GeoR38 ________________________________________________________________________________
Date: Nov 21, 1998
I cut mine up into 3' sections, covered with scrap carpet and made cat scratchers with it.... got 20$ apiece for them........ enough for a pneu. Pop rivet gun.......and some other toys...... ;-) ________________________________________________________________________________
Subject: Time to say Goodbye
Date: Nov 22, 1998
Hello everyone, Richard came and took the SS away yesterday, so it's time to move on. I'd like to thank everyone on the list for all the advice and entertainment I've received over the last couple years. Even though the SS didn't turn out to be exactly what I wanted, I don't consider the time and money to have been wasted. Overall, it was an enjoyable experience, and along the way, I met some great people, and made some lasting friends. Later today, I'll be leaving the list, and also removing the SS pictures from my web site. Will Uribe has volunteered (didn't say no fast enough ) to post some of my pictures as long as there's any interest. I sent him a CD-ROM last week, so he's got them all. Thanks Will. Take care, and I'll see you in the sky when the RV-8 is done. Russell Duffy Navarre, FL RV-8, sn-80587 (tanks) rv8(at)mindspring.com ________________________________________________________________________________
Date: Nov 22, 1998
From: Cliff / Carolyn Stripling <striplic(at)dfw.net>
Subject: Re: Time to say Goodbye
>I'd like to thank everyone on the list for all the advice and entertainment >I've received... Russ, We're going to miss you. It was good visiting with you over dinner (thanks again) when you passed through Dallas. I hope the progress on your RV goes quickly and you are into the air quickly. I flew today for the first time in about 3 months. I couldn't believe it had been that long, but my logbook reminded me. I have little excuse except the building of our house in Central Texas. It only took me one landing to feel comfortable again. I raised the clip on the needles of my carbs one notch and they are preforming perfectly as regards the EGTS... right around 1100 instead of below 1000. All the other gauges are in the optimum range. I noticed that flat out straight and level my rpms were climbing above 6500. I may tweak in a little more pitch on the AQ-IVO. I bought a used ICOM headset adaptor for my ICOM A21 and it works very well. I never could get the intercom (cheap one) that I bought to work properly. Now I will be able to announce my intensions instead of just listen to others. I feel a lot safer now. The traffic at our airport today was busy with usually two or more in the pattern. Pretty soon I will switch over to the full doors and full enclosure as the temps are beginning to turn cooler. Today was cloudless with a 10 mph wind aligned with the runway and mild temps. Perfect. Later, Cliff & Carolyn Stripling Him: Retired Pharmacist (972)247-9821 Dallas Texas Her: Real Estate Broker - Texas and Marble Falls Texas Both: 5th Wheel - RV - Travel Kolb MKIII - N582CC (50+ hrs) ________________________________________________________________________________
Date: Nov 22, 1998
> >Hello everyone, > >Richard came and took the SS away yesterday, so it's time to move on ... >>Take care, and I'll see you in the sky when the RV-8 is done. Rusty, We will miss you and your good sense of humor. When you get that RV reved up, don't forget we have 3,000 feet - plenty for an RV8, come see us sometime - but please watch out for us slow pokes! Dennis Souder Pres Kolb Aircraft PS. did I tell you about the engine literature we just received, something about a twin rotary engine installation with a single drive .... ________________________________________________________________________________
Date: Nov 22, 1998
Russell It has been great to have someone like you on the list thanks for all the advice you gave to me as well as others we will miss you ..........maybe you could peek in every once in a while. Rick Libersat writes: > >Hello everyone, > >Richard came and took the SS away yesterday, so it's time to move on. >I'd like >to thank everyone on the list for all the advice and entertainment >I've received >over the last couple years. Even though the SS didn't turn out to be >exactly >what I wanted, I don't consider the time and money to have been >wasted. >Overall, it was an enjoyable experience, and along the way, I met some >great >people, and made some lasting friends. > >Later today, I'll be leaving the list, and also removing the SS >pictures from my >web site. Will Uribe has volunteered (didn't say no fast enough ) >to post >some of my pictures as long as there's any interest. I sent him a >CD-ROM last >week, so he's got them all. Thanks Will. > >Take care, and I'll see you in the sky when the RV-8 is done. > >Russell Duffy >Navarre, FL >RV-8, sn-80587 (tanks) >rv8(at)mindspring.com > > > > > > > ________________________________________________________________________________
Date: Nov 22, 1998
Date: Nov 22, 1998
Cliff Good for you on your flight I know how it is when you are in the middle of building a house the time seems to flyyyy away well thank you for the offer we may just take you up on it I did get a room at the DRURY INN NORTH DALLAS Rick Libersat writes: > > >>I'd like to thank everyone on the list for all the advice and >entertainment >I've received... > >Russ, > >We're going to miss you. It was good visiting with you over dinner >(thanks >again) when you passed through Dallas. I hope the progress on your RV >goes >quickly and you are into the air quickly. > >I flew today for the first time in about 3 months. I couldn't believe >it >had been that long, but my logbook reminded me. I have little excuse >except the building of our house in Central Texas. It only took me >one >landing to feel comfortable again. I raised the clip on the needles >of my >carbs one notch and they are preforming perfectly as regards the >EGTS... >right around 1100 instead of below 1000. All the other gauges are in >the >optimum range. I noticed that flat out straight and level my rpms >were >climbing above 6500. I may tweak in a little more pitch on the >AQ-IVO. > >I bought a used ICOM headset adaptor for my ICOM A21 and it works very >well. I never could get the intercom (cheap one) that I bought to >work >properly. Now I will be able to announce my intensions instead of >just >listen to others. I feel a lot safer now. The traffic at our airport >today was busy with usually two or more in the pattern. > >Pretty soon I will switch over to the full doors and full enclosure as >the >temps are beginning to turn cooler. Today was cloudless with a 10 mph >wind >aligned with the runway and mild temps. Perfect. > >Later, > > >Cliff & Carolyn Stripling Him: Retired Pharmacist >(972)247-9821 Dallas Texas Her: Real Estate Broker - Texas >and Marble Falls Texas Both: 5th Wheel - RV - Travel > Kolb MKIII - N582CC (50+ hrs) > > > > > ________________________________________________________________________________
Subject: FS-II AND BRS installation
Date: Nov 22, 1998
I have almost finished my soft pack (leading edge) installation. I hate to see my alum-lexan gap seal go in favor of fabric seal. I would like to talk to those that have done something other than fabric. How did you rocket or entire chute pack? ________________________________________________________________________________
Subject: Re: waiver for property owner
Date: Nov 22, 1998
> >Folks, >Searched thru the Kolb-list for info about a waiver that could be signed by >the UL pilot and given to a property owner who's good enough to allow you to >fly from their property. Maybe from some other UL source; but coulda swore >there's a standard form available for such a situation - anyone know if I'm >dreamin or where I could get one? Well, that was clear as mud. Let me try again. The waiver (think I saw it mentioned on this list) is signed by me, the grateful UL owner and given to the property owner and it says something to the effect that I waive all rights to sue him/her for any reason while performing my UL activities on (or from) their property. Still dreamin? David (5/8 Mk II owner) Bruner PS Had my first 2 hrs UL instruction today, courtesy of Jim Spadafora, at Twin Pine Airport (near Trenton, NJ). What a relief: it IS possible to comfortably operate the stick AND throttle in a Mk II. What a gas! Did a bit of field hopping, (3 other UL/Hang Glider fields right nearby!) including the legendary Buzzard's Row. Thanks, Jim ________________________________________________________________________________
Date: Nov 22, 1998
I tucked Rusty's SS into it's new nest today. Rusty is not only a trustworthy & enjoyable person to deal with, he is also a mastercraftsman. There is one serious & persisting problem I will have with his plane: I am forever going to have to refer the endless compiments I'm sure to recieve about the workmanship to Rusty! A man's work is a reflection of his charactor & this SlingShot says a lot about Russell Duffy wrote: > > Hello everyone, > > Richard came and took the SS away yesterday, so it's time to move on. I'd like > to thank everyone on the list for all the advice and entertainment I've received > over the last couple years. Even though the SS didn't turn out to be exactly > what I wanted, I don't consider the time and money to have been wasted. > Overall, it was an enjoyable experience, and along the way, I met some great > people, and made some lasting friends. > > Later today, I'll be leaving the list, and also removing the SS pictures from my > web site. Will Uribe has volunteered (didn't say no fast enough ) to post > some of my pictures as long as there's any interest. I sent him a CD-ROM last > week, so he's got them all. Thanks Will. > > Take care, and I'll see you in the sky when the RV-8 is done. > > Russell Duffy > Navarre, FL > RV-8, sn-80587 (tanks) > rv8(at)mindspring.com > ________________________________________________________________________________
Date: Nov 22, 1998
Subject: Re: FS-II AND BRS installation
I have made several fiberglass fairings /gap seals on my FS2 covering a second chance softback. I used laminated balsa for an exit area as long as the pack opening and about 3/4 width. Make sure that the areas surrounding this exit hole are smooth and snag free. It would be a real letdown to have a successful deployment of a shredded chute. Dick C ________________________________________________________________________________
Date: Nov 22, 1998
writes: > >....Well, that was clear as mud. Let me try again. >The waiver (think I saw it mentioned on this list) is signed by me, >the >grateful UL owner and given to the property owner and it says >something to >the effect that I waive all rights to sue him/her for any reason while >performing my UL activities on (or from) their property. > >Still dreamin? David, I'm at a loss to help with your reference but it sounds like you know what you want the 'waiver' to say - so why don't you just write it? Actually the above couple sentences would probably do. I had to sign a "waiver" to rent my hangar. Upon seeing it, I asked the landlord where she got it. She said she had paid a lawyer a couple hundred bucks to write it up. I compared my copy to a standard lease agreement available for about 50 from any office supply store - virtually identical! The lawyer skinned her for a couple c-notes by taking a standard lease and replacing the word, "contents" with "aircraft." I didn't have the heart to tell her I was flying a "vehicle," not an "aircraft!" -Mick Fine Tulsa, Oklahoma http://www.angelfire.com/ok/froghair Green Country Ultralight Flyer's Organization (UFO) http://www.angelfire.com/ok/gcufo ________________________________________________________________________________
Date: Nov 22, 1998
writes: > >Hello everyone, > >Richard came and took the SS away yesterday, so it's time to move on. .... Rusty, We'll miss your wit and wisdom! If your current project turns out half as well as your last, it should be a show winner. Hope you took all the jabs and ribbing in the spirit it was intended. Good Luck! -Mick Fine Tulsa, Oklahoma http://www.angelfire.com/ok/froghair Green Country Ultralight Flyer's Organization (UFO) http://www.angelfire.com/ok/gcufo ________________________________________________________________________________
Date: Nov 22, 1998
Subject: New List Subscription Form!
Dear Listers, After a full weekend's work, I've come up with a really nice new List Subscription web page. The page allows you to Subscribe, Unsubscribe, and Search for your email address on any of the Email Lists. Subscribes will still require Administrator Approval, but the page should really go a long way to making the overall process much smoother for everyone. The standard Majordomo email method is still available, but I strongly recommend to everyone that they use the web page excluseivly. I have also made some rather extensive modifications to the text trailer appended to each of the messages posted to the List. I've added a number of web site URLs that should answer many of the questions I seem to get daily. I know the trailer is a little on the long side, but its great reminder for everyone, and I filter it out before appending messages to the Archive. Please have a look at the new List Subscription Form and maybe see if you can locate your address using the search capability. The URL for the new Subscription Form is: http://www.matronics.com/subscribe There are a few other permutations of the "subscribe" portion or the URL that will work as well, for example "unsubscribe", "subscription", etc. But these all take you to the same page, so just remember the URL shown above. Enjoy, Matt Dralle List Administrator Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 23, 1998
<< I am forever going to have to refer the endless compiments I'm sure to recieve about the workmanship to Rusty! A man's work is a reflection of his charactor & this SlingShot says a lot about >> Now THAT is a genuine compliment!!..........We're all gonna missya Rusty................GeoR38 ________________________________________________________________________________
Date: Nov 23, 1998
I'm not a Kolb owner but thanks a lot for the very helpful informations from you. I've just started flying and dreaming a Kolb of my own. (RV-8 is too much for me and out of my reach) It was you that I've decided to build a Kolb. Thanks again. Moo-Jung Chu (from Korea) > Russell Duffy wrote: > > > > > Hello everyone, > > > > Richard came and took the SS away yesterday, so it's time to move on. I'd like > > to thank everyone on the list for all the advice and entertainment I've received > > over the last couple years. Even though the SS didn't turn out to be exactly > > what I wanted, I don't consider the time and money to have been wasted. > > Overall, it was an enjoyable experience, and along the way, I met some great > > people, and made some lasting friends. > > > > Later today, I'll be leaving the list, and also removing the SS pictures from my > > web site. Will Uribe has volunteered (didn't say no fast enough ) to post > > some of my pictures as long as there's any interest. I sent him a CD-ROM last > > week, so he's got them all. Thanks Will. > > > > Take care, and I'll see you in the sky when the RV-8 is done. > > > > Russell Duffy > > Navarre, FL > > RV-8, sn-80587 (tanks) > > rv8(at)mindspring.com > > > ________________________________________________________________________________
From: "Larry Bourne" <larrybiglar(at)earthlink.net>
Date: Nov 23, 1998
Sorry to see you go Rusty. I've enjoyed your input - and output. I'll add my voice to those who say " check in and say hello from time to time." Big Lar. > From: Russell Duffy <rv8(at)mindspring.com> > To: Kolb list > Subject: Kolb-List: Time to say Goodbye > Date: Sunday, November 22, 1998 2:57 PM > > > Hello everyone, > > Richard came and took the SS away yesterday, so it's time to move on. >rv8(at)mindspring.com > > > > > > ________________________________________________________________________________
From: "Beauford Tuton" <beaufordw(at)worldnet.att.net>
Subject: Re: BEUFORD???
Date: Nov 23, 1998
Woody, Ray, et al. Am still alive and more or less, in operation... Thanks for asking... Sent Ray a separate note a little earlier when I came across another one from him... I am methodically working my way through the half-million or so e-mails which have accumulated while I was out foolin around at the office for the last month or so... 'Ol Saddam has us in high gear at work, and I haven't had much chance to even do the eat - sleep - change drawers routine to acceptable standards, much less fool around with the pile of dacron and aluminum refuse heaped in the garage... (good thing I still wear O.D. drawers...) In late October, I finally got some fabric on the horizontal tail surfaces and the rudder... This modest progress was compromised, however, by the fact that my current Bride insisted upon leaving the garage door cracked about a foot, so that her worthless little fuzz-butt cat could go in and out... When I finally managed to get out there to do some work this weekend, I learned that the result of that particular intellectual shortfall has been the apparent adoption of my garage as some sort of high-performance proving ground for exotic feline waste distribution and advanced hydraulic experimentation... and it was evident that at least a dozen or so of the more advanced participants had some bizarre affinity for anything with Ray Stits' name or logo on it.... Particularly the Polyfiber already installed on the stacked-up tail parts... There also seemed to have been a great deal of interest in settling the matter of ownership of the large roll of dacron fabric still under the worktable...it was "marked" virtually from end to end with such a thoroughness, and to such a depth, that a reasonable person would have difficulty buying the notion that this result could have possibly been the result of random actions by uncomprehending dumb animals... In my mind's eye, I could just see the little buggers lined up waiting their shot, each with a little number clutched in his paw, while the furry little foreman directed each, in turn, to the precise location called for in the master plan.... Long story short... The neighbors were treated to the sight of yours truly, on his flabby belly and bony knees in the driveway scrubbing what they probably thought was the longest piece of cheap white carpet they had ever seen with soap and hot water... Most of the obvious stench has abated... although I have now fully reconciled myself to the fact that no machine bearing the distant but unmistakable essence of feline territorial imperative is ever going to grace the big winner's circle at Oshkosh, I guess I need to reassure the cat lovers on the list that no harm came to the 'ol Lady's little fop of a long-haired cat over this... I do admit, however, that I went ahead and cleaned a couple of toilets with him while I had him all lathered up from doing the dacron on the driveway... But I went ahead and dried him off and put him out in the back yard... Did you know those little suckers get about a yard across after 15 minutes on the permanent press setting? He still won't come when I call, but he does stay in the yard when I go outside with food, now.... I cannot see inside the tail pieces, and I absolutely refuse to peel off the fabric and do them again... I washed them out as best I can. I reckon we will now subject 'ol Ray's epoxy primer to a long-term test by a solvent vastly more formidable than mere MEK.... Last night I dreamed I was taxiing down a ramp at high speed, closely pursued by a huge pack of dogs... (sigh...) Pray for peace... these hours are killin' me... Beauford (the aluminum butcher of Brandon....) still buildin' FF #76 From: wood <richard.wood(at)usa.net> Date: Saturday, October 31, 1998 10:20 PM Subject: Kolb-List: BEUFORD??? > >> >>PS Has anyone heard from that old bald feller, Beuford Tuton recently? I >>spotted the wife sticking some kind a package ( looked like a food item) in >>the mail. Don't know who she sent it to, but I am a little worried about >>Mr. Tuton! >> >> > > I was wondering that myself. I need a good Beuford story. > > > > Woody > > Some men are able to stumble over the truth but are able to pick >themselves up and keep walking as if nothing had happened. (Churchill) > > > > > > > ________________________________________________________________________________
Date: Nov 23, 1998
On Sun, 22 Nov 1998, Russell Duffy wrote: > Hello everyone, > > Richard came and took the SS away yesterday, so it's time to move on. I'd like Congratulations Rusty (and to you too Richard). It's odd, but I'm just a little bummed by this finally happening. I'm real glad for you though; nice to get on with the show. I see from Dennis' note that the their potential market. I can now tell you too, that yes, Bill Hollmann did/does have a Continental O-65 he'd sell. They're heavy though, so it never woulda made a good option. Anyway, good luck getting Build Time on the RV. I'll race you someday. :) -Ben Ransom ps: Went flying yesterday. Sorta murky and cold out. Buzzed the usual local spots, but otherwise nothin special. Good to get a little flying in before the long hours of tea time and visiting, just sitting on my hands. (i don't know the first thing about playing cribbage, not even how to spell it) ________________________________________________________________________________
Subject: Quincy, Florida, Flyin and BBQ
Date: Nov 23, 1998
Happy Monday Morning, Had a good time this weekend. Flew down to Quincy, Florida, for their get-to-gather. Sat morning I got up at six, the OAT was 35F. Ugh!!! Too cold for an old fart to go flying around the countryside without an ECU (environmental control unit) or in our terms, a heater. By eight it had rapidly risen to 38F as I loaded Miss P'fer and got ready to fly. Took a little coaxing to get the 912 to start and run, the enrichers weren't up to snuff for the cold damp air. I bought a new Wal-Mart 14 amp battery last month and it did its job. No need for a jump start. God blessed me with a good day and we were off the ground at 0830, winging our way southeast. I had to stop after an hour and check out the back of a hanger in Clayton, Al, then another hour and I was landing at Quincy. They had a good turnout for the flyin, Kolbs overwhelming all other brands of ULs and Exps. Mike Highsmith and Richard Lovell from Panama City, Florida, were there when I arrived. Both previous Kolb owners, both have decided to fly "other" brands of acft. The Quincy boys had the grills hot and smoking. I sampled some of the best venison sausage I had ever eaten followed by a delicious cheeseburger. Compliments of the Quincy gang. Got to see Ruts "original" Firestar, that brought back some memories of the 80's, and Dwayne's Fire Fly. Both good looking airplanes. My Brother Jim met me at the airport and later took me to St Marks for a delicious fried shrimp, oyster, and Grouper dinner. Thought I had died and gone to heaven. Overslept Sunday morning and got back out to the airport for a noon takeoff for Hauck's Holler. It was misting rain, and cool. The airport was almost deserted. We poured 5 gal of 93 octane in Miss P'fer for insurance, then gave a gentleman, who was flying a two place Quicksilver a short demo flight in the MK III. Needless to say, after getting out of the Quick, he was impressed with the MK III and is going right out and buy one. hehehe I gave him a good flight and the 912 performed first class. With two up and almost 20 gals of fuel, plus my gear in the gear locker, Miss P'fer was climbing 1300 to 1500 fpm. She made me proud of her. However, I think we were taking advantage of the nice east wind reflecting off some rising terrain. I didn't tell him that. Did some steep approaches, couldn't see his eyes, but I bet they were wide open when I initiated the first one. I tapped the vsi with my finger, he didn't have a headset, to show him it had pegged at 2500 fpm rate of descent and 65 mph. What a performance. Couldn't haul her to a stop as quickly as I would have liked to cause the800X6's had turned into skis on the wet grass. Off Quincy and with a pit stop at Clayton, Al, again, was touching down at Gantt International Airport in less than two hours. Not bad for an UL to fly 176 miles. I still had over 10 gals fuel when I landed. I could have made the flt down and back, with play flying at Quincy, and had a five gal reserve, but why take a chance on wind, weather, or some other act of God or Rotax or "Murphy." Had a great time and look forward to the next. john h (trying to get started in Central Alabama) ________________________________________________________________________________
Date: Nov 23, 1998
<< I see from Dennis' note that the their potential market. >> What does this mean? or is this a joke about Russ?.......................GeoR38 ________________________________________________________________________________
Date: Nov 23, 1998
> their potential market. >> > > > What does this mean? or is this a joke about > Russ?.......................GeoR38 Weak attempt at humor. -Ben ________________________________________________________________________________
Date: Nov 23, 1998
<< I have almost finished my soft pack (leading edge) installation. I hate to see my alum-lexan gap seal go in favor of fabric seal. I would like to talk to those that have done something other than fabric. How did you rocket or entire chute pack? >> Bruce, I have a Second Chantz soft pack mounted between the wings. The rocket motor, which is about 1.5" in diameter, points straight up and sticks out about 3" above the center section. The center section gap seal is made up of lexan, with a piece of aluminum at the leading edge spar, as was explained in one of Kolbs newsletters. I cut a round hole in the top lexan for the rocket motor to protrude through. I then cut the top lexan to form a trap door, which is about 6" wide and 12" long, big enough for the chute to be pulled through. The trap door is made by cutting two slits 12 " long, fore and aft, about 6" apart, and one slit going across at the aft end, connecting the two 12" slits. The cross slit must intersect the center of the rocket hole, so that the cable is free to pull out the chute, which would then force open the trap door. The 'hinge' of the trap door is simply the lexan 'bending' and is located at the leading edge of the door. Once the door is cut into the lexan, you have to secure it in the closed position, because the natural tendency is for it to spring open, due to the curvature of the lexan gap seal. I just used some tape to hold it closed. The rocket motor has plenty of force to overcome this light restriction. The lower part of the gap seal is harder to describe. On my Original FireStar, there is a U shaped tubing (a hoop) above my head. First I pop riveted a piece of aluminum sheet on top of that, on which I set the soft pack chute. Then I cut out most of the lower part of the lexan gap seal, so the cut out resembles the hoop in shape, but still leaves an edge resting onto the edge of the hoop plate. It just doesn't cover the central part where the chute is sitting. In other words, the bottom part of the lexan gap seal covers the bottom surface of the wing, but only extends onto the hoop plate, reaching in about 3/4" all the way around, for support. Now it gets even more difficult to explain the rest of the job. I cut another piece of aluminum, about 2" wide, in the shape of the hoop plate, with the outside edges even with the previous mentioned hoop plate. Then I cut another piece of lexan, about 1" wide to the same shape as the 2" aluminum, except it is 1" smaller on the outside dimension. Both sort of resemble a horseshoe shape. These were pop riveted together (sandwiched) onto the aluminum hoop plate. This made a groove about 1" in width all the way around on the outside edge, for the lower part of the gap seal to slide into and keep it from interferring with the chute pack. This permits me to easily install and remove the gap seal, which I have to do since I fold the wings after each flight. The gap seal is held in place with velcro at several locations. Any questions? Bill varnes Audubon, NJ Original FireStar 377 ________________________________________________________________________________
Date: Nov 23, 1998
Subject: Re: Engine vibration-The answer is:
<< I've got just a little over 300 hours on my Original FireStar with a 377 Rotax. It has been performing really good until now. During the past two flights I noticed a strange vibration. It still seems to develop full power on climb out, but after reaching altitude, when I throttle back, it vibrates thru the airframe and just doesn't sound right. >> CARBON. Too much of it. After removing the engine assy, I took it home to disassemble it in my shop. I thought for sure it was going to be something serious, such as the gear box or crankshaft. I had already checked the wooden prop for tracking and balance. The gearbox had clean oil and no sign of metal found on the drain plug magnet. The ignition timing was within .004" of the prescribed .086" BTDC. As soon as I removed the cylinders I saw that the piston domes were "thickly" covered with carbon. My last decarboning was done less than 60 hours ago and I didn't think it would accumulate that much in that time. But it did. I cleaned it all up, installed new gaskets, and took it back to the airport. One flight around the field and Yeaaaaaa, its sounding good again. Thanks to all who responded with suggestions on what it might be. It gave me things to look at before dismantling. So lets see, I guess I'll go and get me some of that SeaFoam! Thanks again all, for your help. Bill Varnes Audubon NJ Original FireStar 377 ________________________________________________________________________________
Date: Nov 23, 1998
> >> >CARBON. Too much of it. After removing the engine assy, I took it home to >disassemble it in my shop. I thought for sure it was going to be something Hi Bill and Kolb Gang: Just curious about all that carbon. I never experienced carbon buildup and never decarboned a Rotax 2 cycle eng during my two cycle career (except during rebuild). I reckon I just blew the carbon right out of them as I flew. However, I never babied my two strokes, never cruised less than 5800, and yes I did take them on nice long XCs often. I think long XCs at a respectable power setting of at least an hour or more are necessary to keep these little hornets happy and clean. In addition, every now and then, mine got a shot of Marvel Mystery Oil in the fuel tank. I have noticed with regularity that my 912, as well as the two strokes, that are flown only locally playing around the patch, tend to get lazy and lack that sharp crisp feel that they should have. They get to where they don't want to idle smoothly and just get plain lethargic. I can go on a descent XC and the first landing I can tell the difference. Just like giving them a good enema. Cleans them out. On this flt to Quincy, Florida, I put 16 oz Marvel Mystery Oil in 25 gal (twice the recommended oil) and after a couple hours she was back to her old self. More power and much smoother. Not trying to sell MM Oil, but I have used it since 1964, when I purchased my first new Honda 305 Super Hawk. Used to put a cap full in every tank. Did it do any good? Back then I don't know, but I use it now in a 351W marine engine, Dodge Cummins diesel, Kubota diesel, Onan 4 KW generator, and the 912. Besides, it smells good!!! john h (Hauck's Holler, Alabama, and Gantt International Airport, Alabama (all 750 feet of it) ________________________________________________________________________________
Date: Nov 24, 1998
Subject: Covering System
Hello Kolbers, I haven't been to active in this list but have definitely read alot of good advice. Our MkIII is coming along nicely, we have all of the tail pieces built and temporarily installed on the fuselage tube (It looks like a huge lawn dart). I ran across some information last summer concerning covering and would like some opinions. There is a company in Ennis, Montana called "Aircraft Finishing Systems" that sell a water born finishing system. ________________________________________________________________________________ chemicals. Has anyone heard of this ? Their Email address is afs(at)3rivers.net if anyone would like the information. Also I have been playing with a web page of our building progress if anyone would like to take a look and make some comments. It can be found at http://www.digisys.net/users/paulv/kolb.htm Happy ThanksGiving PaulV ________________________________________________________________________________
Date: Nov 23, 1998
Hi, I'm interested in putting my FireFly on floats; maybe a Full Lotus monofloat. It seems like a Full Lotus Monofloat 1000 would be sufficient, but the FBO at a local airport has a few used and new 1700 and 2000 Full Lotus monofloats which he just aquired and is interested in selling (he doesn't know what he wants for them yet though); would something like that be overkill for the FireFly? As a rule of thumb use a float system that has a bouyancy of twice the gross weight of your plane including the amphib weight and mounting hardware. If I do this, it would definitely have to be an amphib setup; I don't want to be stuck with land or water, I want to use both... According to Full Lotus' web page, the 1000 and 2000 can be set up for amphib (pricey!!!!! $$$$$$) :-( but the 1700 can not. (Any less costly options here?) My experience with the MKIII on floats is to stick with Lotus Floats since they absorb more impact force than rigid floats and the tubes are easy to replace. I would not pinch on the float cost but would look for someone that can make a home build amphib system. My experience with the Lotus amphib system has been less than satisfying. My main question though is... I'm already at gross weight for my FireFly. Actually, I'm slightly over, maybe 520-530lbs and I believe the gross weight for the FF is 500lbs. Does adding floats affect the gross weight? Obviously they'd add weight, but I thought maybe they act as a "lifting body" which would offset it... ? The amphib system of a Lotus Mono float weighs about 35 lbs. Float weighs around 45lbs and mounting hardware should be 15 lbs. Total added weight 95 lbs. It all adds to the gross weight and drag coefficient of the plane.It requires 25% more Hp than std engines for decent water take-off and climb performance due to the added drag and weight. As far as "lifting their own weight", the stall speed of my MKIII with duals appears not to be affected by them compared to what other MKIII owners have reported but I believe that once in the air, weight is weight! Oops, I thought of another question: How does the monofloat attach to the plane? Is there a mounting kit or something that I need to buy from someone? (Kolb?) If so, anyone know what it costs? Although there are Kolbs with monofloats around I do not know of anybody selling a mounting kit. If you can build a Kolb, attaching a monofloat is not that difficult.The amphib hardware and mounting hardware all should be combined in a single design.Kolbs also require a retractable waterrudder for decent turn control on 10MPH+ wind conditions while taxiing on the water. Ummm, one more question. :-) If I were to get my FireFly on floats, I've played with the idea of registering it as an experimental so that I could build float time (for reduced insurance premiums, etc). Is there any problem with using Full Lotus floats on an Exp. aircraft? Any "gotchas" to look out for here with registering my FF as an Exp floatplane in general? (I am the 2nd owner, and not the original builder.) This has already been answered correctly. BTW, when I registered my MKIII as an amphib,the FAA inspector had checked their records to make sure I had a float licence before coming out to inspect it. Any info or advice on any of the above would be greatly apprecated. I personally think that monofloats with sponsons on Kolbs or any other UL look ugly and it is difficult to get into the cockpit and use the plane around other boats and docks but if all you use it for is to beach it maybe you are ok with it. Frank Reynen MKIII@485 hrs on dual amphip Lotus Floats http://www.webcom.com/reynen -Jon- ________________________________________________________________________________
Date: Nov 23, 1998
Subject: A couple quick questions
How far should the pitot tube extend from the airplane? Has anybody connected the static ports on the carburators together on the 912 engine? What did you do with oil canister vent? And finally has anybody had any trouble with the throttle linkage, not getting enough travel in the cable to make the linkage move its full length(From idle to full throttle) ________________________________________________________________________________
From: "Michael Highsmith" <michael.highsmith(at)worldnet.att.net>
Subject: Re: Engine vibration-The answer is:carbon ?
Date: Nov 23, 1998
Bill, I'm glad it wasn't something serious but did you clean the prop? Please forgive me but what kind of prop was it? I've never heard of carbon causing vibration enough to be able to tell it in flight. I learn something new in this sport everday. What a gas. Something to put in the book. FIREHAWK. -----Original Message----- From: WVarnes(at)aol.com <WVarnes(at)aol.com> Date: Monday, November 23, 1998 2:08 PM Subject: Re: Kolb-List: Engine vibration-The answer is: > > ><< I've got just a little over 300 hours on my Original FireStar with a 377 > Rotax. It has been performing really good until now. During the past two > flights I noticed a strange vibration. It still seems to develop full power > on climb out, but after reaching altitude, when I throttle back, it vibrates > thru the airframe and just doesn't sound right. >> > > >CARBON. Too much of it. After removing the engine assy, I took it home to >disassemble it in my shop. I thought for sure it was going to be something >serious, such as the gear box or crankshaft. I had already checked the wooden >prop for tracking and balance. The gearbox had clean oil and no sign of metal >found on the drain plug magnet. The ignition timing was within .004" of the >prescribed .086" BTDC. As soon as I removed the cylinders I saw that the >piston domes were "thickly" covered with carbon. My last decarboning was done >less than 60 hours ago and I didn't think it would accumulate that much in >that time. But it did. I cleaned it all up, installed new gaskets, and took >it back to the airport. One flight around the field and Yeaaaaaa, its >sounding good again. > >Thanks to all who responded with suggestions on what it might be. It gave me >things to look at before dismantling. So lets see, I guess I'll go and get me >some of that SeaFoam! > >Thanks again all, for your help. > >Bill Varnes >Audubon NJ >Original FireStar 377 > > ________________________________________________________________________________ by matronics.com (8.8.8/Matronics-1.2) id TAA22211
Subject: Re: Quincy, Florida, Flyin and BBQ
Date: Nov 23, 1998
Hey John, Glad to hear you made it home okay. Richard and I left about 9:30 while we still had a high ceiling. The prediction was for more rain down in P.C.. We both had things to do today and had to get home. Sorry to have missed you. Rut took us to breakfast early in down town Quincy. We picked up some gas for our trip home. When we got back Rut, his girlfriend (Deana) and I got to go up in the QS that belong's to Charles Davis. He's an ASC- BFI .Boy did that bring back memories when I use to train in my QS. Not a good X-C machine but a great trainer. The food and company was terrific and I must congradulate Rut on his first gathering. He's only been doing the UL thing for a few short months and he has already accomplished more than most UL pilots do in their entire flying life. "Way to go Cowboy, YEE-HA". Richard, Rut, Deana and myself took over the FBO after everyone left that night, made a pot of coffee and watched every movie we could find that had airplanes ,collected by the local EAA chapter. Then we watched " Independence Day " again because it had airplanes in it. The rain had been light all afternoon as you know. When we finally called it a night , Richard decides to take his sleeping bag and sleep in the FOB on the couch. The minute I get comfortable in my tent the rain started and didn't let up for five hours. It was nice and not to cool. The water repellant I got from Wally World did the trick on my tent because I hardly got a drop inside and sleep like a log for most of the night. I can tell Richard's days are numbered when he sets up his tent and then takes the warmth of a cozy coach inside just because of a little rain. To bad I didn't think of it first. But then he's only 71 years young with 2000 hours in UL's. I guess he's entitled. For those who don't know Richard Lovel (AKA Bluebird) my wingman. He started flying UL's sometime after he retired from the Airforce, where I might add, he drove recovery boats to pick up downed drones and lots of other assorted things from the waters south of the Florida panhandle. He flew a QS 'til he wore it out then a Fire Star 377 but couldn't wear it out after some 800 or so hours, no rebuilt engine either. He was looking for something with more room back before the FSII came and settled on the clipped wing Challenger. You wouldn't believe how much stuff he can get in there. He probably would be flying the FSII if he had known it was only one year away. Never the less he has 800 hours already on the Challenger and it's still going strong. This guy just loves to fly. If there is any chance to fly on any given day he will be in the air if it's only to fly the pattern. He says this is his last airplane but our friend John Wayland is about to bring his new Sling Shot on line to taunt him a little. Finally he will beone of the slow one in the group for a change. He'll have a lot to think about on those long X-Cs we are planning. Texas, Arizona, Indiana, Kitty Hawk to name a few. He is a world of information on X-Cs and where to go and what to avoid, but most of the time you have to ask , maybe it's because he feels it's more fun to discover things for the first time on your own rather than knowing the end of the story before you get there. He want let you get into trouble but he will let you experience flying the way he and John W. did a few years ago. Hopefully I can join them again in their quest to cover every square foot of the southeast with a UL. Anyway we got home alright. Ran into a little rain and low vis. just west of Clarksville and had to descend to 1000' but no problems. It was right after I sat down at P.C. that the rain came in earnest. We'll do it again next year. Maybe more can fly in, as it was I am glad we all had a safe flight and a very good time. FIREHAWK -----Original Message----- From: john hauck <hawk36(at)mindspring.com> Date: Monday, November 23, 1998 11:52 AM Subject: Kolb-List: Quincy, Florida, Flyin and BBQ > >Happy Monday Morning, > >Had a good time this weekend. Flew down to Quincy, Florida, for their >get-to-gather. > >Sat morning I got up at six, the OAT was 35F. Ugh!!! Too cold for an old >fart to go flying around the countryside without an ECU (environmental >control unit) or in our terms, a heater. By eight it had rapidly risen to >38F as I loaded Miss P'fer and got ready to fly. Took a little coaxing to >get the 912 to start and run, the enrichers weren't up to snuff for the cold >damp air. I bought a new Wal-Mart 14 amp battery last month and it did its >job. No need for a jump start. God blessed me with a good day and we were >off the ground at 0830, winging our way southeast. I had to stop after an >hour and check out the back of a hanger in Clayton, Al, then another hour >and I was landing at Quincy. > >They had a good turnout for the flyin, Kolbs overwhelming all other brands >of ULs and Exps. Mike Highsmith and Richard Lovell from Panama City, >Florida, were there when I arrived. Both previous Kolb owners, both have >decided to fly "other" brands of acft. > >The Quincy boys had the grills hot and smoking. I sampled some of the best >venison sausage I had ever eaten followed by a delicious cheeseburger. >Compliments of the Quincy gang. Got to see Ruts "original" Firestar, that >brought back some memories of the 80's, and Dwayne's Fire Fly. Both good >looking airplanes. > >My Brother Jim met me at the airport and later took me to St Marks for a >delicious fried shrimp, oyster, and Grouper dinner. Thought I had died and >gone to heaven. Overslept Sunday morning and got back out to the airport >for a noon takeoff for Hauck's Holler. It was misting rain, and cool. The >airport was almost deserted. We poured 5 gal of 93 octane in Miss P'fer for >insurance, then gave a gentleman, who was flying a two place Quicksilver a >short demo flight in the MK III. Needless to say, after getting out of the >Quick, he was impressed with the MK III and is going right out and buy one. >hehehe I gave him a good flight and the 912 performed first class. With >two up and almost 20 gals of fuel, plus my gear in the gear locker, Miss >P'fer was climbing 1300 to 1500 fpm. She made me proud of her. However, I >think we were taking advantage of the nice east wind reflecting off some >rising terrain. I didn't tell him that. Did some steep approaches, >couldn't see his eyes, but I bet they were wide open when I initiated the >first one. I tapped the vsi with my finger, he didn't have a headset, to >show him it had pegged at 2500 fpm rate of descent and 65 mph. What a >performance. Couldn't haul her to a stop as quickly as I would have liked >to cause the800X6's had turned into skis on the wet grass. > >Off Quincy and with a pit stop at Clayton, Al, again, was touching down at >Gantt International Airport in less than two hours. Not bad for an UL to >fly 176 miles. I still had over 10 gals fuel when I landed. I could have >made the flt down and back, with play flying at Quincy, and had a five gal >reserve, but why take a chance on wind, weather, or some other act of God or >Rotax or "Murphy." > >Had a great time and look forward to the next. > >john h (trying to get started in Central Alabama) > > > ________________________________________________________________________________
Date: Nov 23, 1998
John, Thanks for the detailed trip reports with all the flying detail. It helps to keep me fired up and building. L. Ray Baker Lake Butler, Fl ________________________________________________________________________________
Subject: Re: A couple quick questions
Date: Nov 23, 1998
Pat: Check the archives. Just talked about most of that stuff. john h ________________________________________________________________________________
Date: Nov 23, 1998
Well, now we know how to find ole Beauford when we want him. ( Do we really ?? - - - now ?? ) On a warm day, sight across the tops of the wings. His'll be the one with the air shimmering over it. Hoo Boy. Years ago, an old Tom jumped through the partly open window of my work truck on a Palm Springs summer day. Thank Ford for seamless rubber floor mats, and Pine Sol for their product, and who-ever builds heavy scrub brushes for theirs. At 50 mph with the windows open it wasn't too bad. Only took a few weeks to finally dissipate. Good Luck, Beauford. With a porous fabric, it must've been something else. Big Lar. ---------- > From: Beauford Tuton <beaufordw(at)worldnet.att.net> > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: BEUFORD??? > Date: Monday, November 23, 1998 12:23 AM > > > Woody, Ray, et al. > Am still alive and more or less, in operation... Thanks for asking... Sent > Ray a separate note a little earlier when I came across another one from > him... I am methodically working my way through the half-million or so > e-mails which have accumulated while I was out foolin around at the office > for the last month or so... 'Ol Saddam has us in high gear at work, and I > haven't had much chance to even do the eat - sleep - change drawers routine > to acceptable standards, much less fool around with the pile of dacron and > aluminum refuse heaped in the garage... (good thing I still wear O.D. > drawers...) > > In late October, I finally got some fabric on the horizontal tail surfaces > and the rudder... This modest progress was compromised, however, by the fact > that my current Bride insisted upon leaving the garage door cracked about a > foot, so that her worthless little fuzz-butt cat could go in and out... When > I finally managed to get out there to do some work this weekend, I learned > that the result of that particular intellectual shortfall has been the > apparent adoption of my garage as some sort of high-performance proving > ground for exotic feline waste distribution and advanced hydraulic > experimentation... and it was evident that at least a dozen or so of the > more advanced participants had some bizarre > affinity for anything with Ray Stits' name or logo on it.... Particularly > the Polyfiber already installed on the stacked-up tail parts... There also > seemed to have been a great deal of interest in settling the matter of > ownership of the large roll of dacron fabric still under the worktable...it > was "marked" virtually from end to end with such a thoroughness, and to such > a depth, that a reasonable person would have difficulty buying the notion > that this result could have possibly been the result of random actions by > uncomprehending dumb animals... In my mind's eye, I could just see the > little buggers lined up waiting their shot, each with a little number > clutched in his paw, while the furry little foreman directed each, in turn, > to the precise location called for in the master plan.... > Long story short... The neighbors were treated to the sight of yours > truly, on his flabby belly and bony knees in the driveway scrubbing what > they probably thought was the longest piece of cheap white carpet they had > ever seen with soap and hot water... Most of the obvious stench has > abated... although I have now fully reconciled myself to the fact that no > machine bearing the distant but unmistakable essence of feline territorial > imperative is ever going to grace the big winner's circle at Oshkosh, I > guess I need to reassure the cat lovers on the list that no harm came to the > 'ol Lady's little fop of a long-haired cat over this... I do admit, > however, that I went ahead and cleaned a couple of toilets with him while I > had him all lathered up from doing the dacron on the driveway... But I went > ahead and dried him off and put him out in the back yard... Did you know > those little suckers get about a yard across after 15 minutes on the > permanent press setting? He still won't come when I call, but he does stay > in the yard when I go outside with food, now.... > I cannot see inside the tail pieces, and I absolutely refuse to peel off the > fabric and do them again... I washed them out as best I can. I reckon we > will now subject 'ol Ray's epoxy primer to a long-term test by a solvent > vastly more formidable than mere MEK.... Last night I dreamed I was > taxiing down a ramp at high speed, closely pursued by a huge pack of dogs... > (sigh...) > > Pray for peace... these hours are killin' me... > Beauford (the aluminum butcher of Brandon....) > still buildin' FF #76 > -----Original Message----- > From: wood <richard.wood(at)usa.net> > To: kolb-list(at)matronics.com > Date: Saturday, October 31, 1998 10:20 PM > Subject: Kolb-List: BEUFORD??? > > > > > >> > >>PS Has anyone heard from that old bald feller, Beuford Tuton recently? I > >>spotted the wife sticking some kind a package ( looked like a food item) > in > >>the mail. Don't know who she sent it to, but I am a little worried about > >>Mr. Tuton! > >> > >> > > > > I was wondering that myself. I need a good Beuford story. > > > > > > > > Woody > > > > Some men are able to stumble over the truth but are able to pick > >themselves up and keep walking as if nothing had happened. (Churchill) > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Pull the trigger
Date: Nov 23, 1998
Hey Ben, now you don't have to feel like the lone stranger. I just composed my message to Beauford, and started highlighting the areas to delete, to shorten the message. Instead of clicking " Cut ", habit took my fingers to the " Send " button. Well, it's gone. Kinda reminds me of the Seagram's Ad years ago. Showed some loose rifle ammunition, with one empty laying beside them. Said something to the effect of "once you pull the trigger, no power on earth can bring it back." We have sort of the same thing, with a little less drastic consequences. Let he who is without sin - - - - - - - Big Lar. ________________________________________________________________________________
Date: Nov 23, 1998
You Bet ! ! ! Me too, John - it helps keep us sorta wannabe's working. We're not true wannabe's cause we ARE working on the solution - aren't we ?? Just seems like sometimes the solution's a long, long time in coming. Fantasizing and day-dreaming, and sitting in the seat making vroom-vroom noises is great, but it does help knowing that the fortunate few are out there DOING IT. Yeah. Big Lar. ---------- > From: Ray L Baker <rbaker2(at)juno.com> > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Quincy, Florida, Flyin and BBQ > Date: Monday, November 23, 1998 8:00 PM > > > John, > > Thanks for the detailed trip reports with all the flying detail. It > helps to keep me fired up and building. > L. Ray Baker > Lake Butler, Fl > > > ________________________________________________________________________________
From: "Christopher John Armstrong" <Tophera(at)centuryinter.net>
Subject: Re: by Rusty, and a crash report
Date: Nov 23, 1998
Rusty, too bad you feel the need for speed, have fun in the new hot rod. Enjoyed your contributions greatly. Tonight an 80 year old guy crashed into a tree on a longer then he though final cause he says he was blinded by the setting sun. the tree he hit was about ten feet from a house! Maybe he should take a look at the altimeter from time to time if you are flying blind! Anyway he walked away from the crash and didnt complain of any injuries, but now the news says he is in surgery with internal injuries in critical condition. If you ever crack up your plane make sure you get a checked out by a DR. even if you think you are only a little sore. My wife had a lady come walking into her ER the other day 36 hours after a car crash complaining of a sore neck... the xrays revealed a hangmans fracture and she was a small wrong move from death or at least paralysis! Get checked out, and dont fly into trees! Topher -----Original Message----- From: Larry Bourne <larrybiglar(at)earthlink.net> Date: Monday, November 23, 1998 2:24 AM Subject: Re: Kolb-List: Time to say Goodbye > >Sorry to see you go Rusty. I've enjoyed your input - and output. I'll add >my voice to those who say " check in and say hello from time to time." > Big Lar. > >---------- >> From: Russell Duffy <rv8(at)mindspring.com> >> To: Kolb list >> Subject: Kolb-List: Time to say Goodbye >> Date: Sunday, November 22, 1998 2:57 PM >> >> >> Hello everyone, >> >> Richard came and took the SS away yesterday, so it's time to move on. > >>rv8(at)mindspring.com >> >> >> >> >> ________________________________________________________________________________
From: "Ron Christensen" <SPECTRUMINTERNATIONAL(at)email.msn.com>
Subject: Re: A Question already
Date: Nov 23, 1998
From: Ray L Baker <rbaker2(at)juno.com> Date: Friday, November 20, 1998 3:22 PM Subject: Kolb-List: A Question already >Hey Kolbers Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL MAILING TUBES?? >L. Ray Baker >Lake Butler, Fl ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Hi Ray; One more idea for you to consider; I cut mine in half length-wise. During the construction process, I placed one of the halves on top to the fuselage tube. It was a great way to protect the tube from dings over my 4-1/2 year construction cycle. Ron Christensen MKIII1/2 ________________________________________________________________________________
Date: Nov 24, 1998
-----Original Message----- From: Dennis Souder <flykolb(at)epix.net> Date: Sunday, November 22, 1998 8:51 PM Subject: Re: Kolb-List: Time to say Goodbye >Dennis Souder >Pres Kolb Aircraft > >PS. did I tell you about the engine literature we just received, something >about a twin rotary engine installation with a single drive .... > I guess he's really gone to have missed this bit of humor! But seriously though, UL motors may be their Achilles heal for a lot more folks than just Rusty. The caution to keep an emergency landing site in view constantly, that it's not IF but WHEN the motor dies, is a huge disadvantage to the UL community. I saw a Wankel display at Oshkosh - very interesting. Expensive! Had a 60hp twin rotor mounted in a go kart, but never saw it run. They also had a static display with a prop setup which seemed to work OK, but the whole prospect looked a bit premature. And very expensive! I guess that, and weight, are the main reasons 2cycles rule. Wonder about that BMW boxer conversion I've heard about... David (another Rusty lamentation) Bruner ________________________________________________________________________________
Subject: Ultimate Solution
Date: Nov 24, 1998
Ray.... I figure one of the longer cardboard shipping tubes ought to hold a minimum of three hundred cats if they are put in there properly.... i.e. at high velocity..... I have the first few candidates for this undertaking at hand here on the premises should you care to pursue this experiment... Bill ________________________________________________________________________________
Date: Nov 24, 1998
Subject: Kolb pictures?-wing floded
Hi, there, Where can I find Kolb pictures - especially Mk-III- with wings folded? With the trailor is better. Thanks, mjc ________________________________________________________________________________
Date: Nov 24, 1998
Subject: Re: Kolb pictures?-wing floded
In a message dated 11/24/98 8:39:57 AM Eastern Standard Time, mjc(at)etri.re.kr writes: << Where can I find Kolb pictures - especially Mk-III- with wings folded? >> see http://members.aol.com/cavuontop/collect/index.htm ________________________________________________________________________________
Date: Nov 24, 1998
>Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL MAILING TUBES?? >It was a great way to protect the tube from dings... Ron and all, Excellent suggestion. I wish I had done that. Later, -- Cliff & Carolyn Stripling Him: Retired Pharmacist (972)247-9821 Dallas Texas Her: Real Estate Broker - Texas and Marble Falls Texas Both: 5th Wheel - RV - Travel Kolb MKIII - N582CC (50+ hrs) ________________________________________________________________________________
Date: Nov 24, 1998
Subject: Re: 2-stroke reliability
On Tue, 24 Nov 1998, David Bruner wrote: > But seriously though, UL motors may be their Achilles heal for a lot more > folks than just Rusty. The caution to keep an emergency landing site in > view constantly, that it's not IF but WHEN the motor dies, is a huge > disadvantage to the UL community. I don't think it is exactly huge. Definetly a factor, but 2-strokes can be kept pretty reliable. Main thing required is knowledge of what they want, and then the diligence to treat them right. 2-strokes are sorta dirty, loud, need oil added to gas, and deliver unwanted vibration to plane and pilot. With all that, and an ultralight's ability to land in little space means reliability isn't the top of the disadvantage column as far as I'm concerned. Of course I may change my tune when mine decides to go quiet again someday. Ben Ransom http://mae.ucdavis.edu/~ransom ________________________________________________________________________________
From: "Duncan McBride" <dmcbride(at)indigo.fgcu.edu>
Subject: Garage Fit
Date: Nov 24, 1998
I'm beginning to sweat whether I can get a folded Mark III in my garage. II only have 83'' with the garage door up. According to the brochures, I'd be ok with a 582 and a two-blade prop, but how about a 912? The brochure lists a three-blade with the 912, but would a two blade stick up as high as a three blade, even if the two-blade was a few inches greater in diameter and the engine had to sit an inch or two higher? Could any of you with a 912 tell me what prop you're using, how much clearance you have from prop tip to fuselage tube, and the total height? Many thanks. ________________________________________________________________________________
Subject: Re: Garage Fit
Date: Nov 24, 1998
>ok with a 582 and a two-blade prop, but how about a 912? The brochure lists >a three-blade with the 912, but would a two blade stick up as high as a >three blade, even if the two-blade was a few inches greater in diameter and >the engine had to sit an inch or two higher? Could any of you with a 912 >tell me what prop you're using, how much clearance you have from prop tip to >fuselage tube, and the total height? Many thanks. Duncan and Gang: I use a 70" dia 3-blade prop on my MKIII/912. Don't know what the boom clearance and total height is. Have to go to airstrip and measure. Two blade prop would give you a lot more clearance than 3-blade. My 912 is about an inch lower and 1/2 inch further forward than the factory mounts. Next time I go to Gantt Int AP I will try and remember to take a tape measure and get the info for you. john h ________________________________________________________________________________
Date: Nov 24, 1998
Duncan You should make it. My 912 MKIII with a 70" warp drive would just make it and my garage door is 83" high as well. Turn one blade straight down and the others will be a little lower. Terry Duncan McBride wrote: > > I'm beginning to sweat whether I can get a folded Mark III in my garage. II > only have 83'' with the garage door up. According to the brochures, I'd be > ok with a 582 and a two-blade prop, but how about a 912? The brochure lists > a three-blade with the 912, but would a two blade stick up as high as a > three blade, even if the two-blade was a few inches greater in diameter and > the engine had to sit an inch or two higher? Could any of you with a 912 > tell me what prop you're using, how much clearance you have from prop tip to > fuselage tube, and the total height? Many thanks. > ________________________________________________________________________________
Date: Nov 24, 1998
Pat Kegebein wrote: > > How far should the pitot tube extend from the airplane? I purchased a L-shaped pitot/static tub from Aircraft Spruce and mounted on the bottom of the nose cone near the nose skid. It works great. > Has anybody > connected the static ports on the carburators together on the 912 > engine? What did you do with oil canister vent? Ran a vent line to the back of the engine between the engine and the motor mount. > And finally has > anybody had any trouble with the throttle linkage, not getting enough > travel in the cable to make the linkage move its full length(From idle > to full throttle) No trouble with throttle linkage. Be sure you have the throttle lever for the 912 since it works opposite of the 2-strokes. > > ________________________________________________________________________________
Date: Nov 24, 1998
michael.highsmith(at)worldnet.att.net writes: << For those who don't know Richard Lovel (AKA Bluebird) my wingman. >> Michael, Loved your story about Richard. My wingman is Kenny Mancus. He is 73 years of age and will go flying at the drop of a hat. Has a KXP with 600+ hours since spring of 92. One time I got up real early and flew over his house. He came running out, never looked up to see who it was, just jumped in his car and raced to the airport. He almost beat me back there. It was going to be a windy day, so rather than set his plane up for such a short flight, I asked him to take a ride in mine. What a joy it was to see the smile on his face. Bill Varnes Audubon NJ Original FireStar 377 ________________________________________________________________________________
Date: Nov 24, 1998
michael.highsmith(at)worldnet.att.net writes: << Bill, I'm glad it wasn't something serious but did you clean the prop? Please forgive me but what kind of prop was it? I've never heard of carbon causing vibration enough to be able to tell it in flight. I learn something new in this sport everday. What a gas. Something to put in the book. >> Hi Michael, The prop is a Tennessee, wood, 66 X 30, clean it after each flight, looks like new. Had checked tracking and balance before removing engine and both were good. I usually cruise at 4800 to 5000 RPM with this prop (to keep up with my buddy who has a KXP 447 with 66 X 32 and turns 4500 most of the time). My CHT about 250 and EGT indicates 1100, sometimes lower. Plugs are a nice light chocolate brown color, so mixture appears to be not overly rich. But apparently something is making lots of carbon. I'm using Castrol Super snowmobile oil @ 50:1 I know the reccomended prop for this engine is 66 X 28, but when I originally got my kit it had a 66 X 32 prop and I flew with that one 3 years. And I turned less RPM, in the 4200 to 4500 range The EGT then was really low, in the 900 to 1000 range. It didn't seem to make as much carbon, but it did make it and I decarbon every winter when its to cold to fly. I mostly use Amoco fuel, but have also used others on occasion. Guess I'll have to start experimenting to see if I can reduce the carbon buildup. Funny thing is, it only gets on the piston dome. The heads are clean! Bill Varnes Audubon NJ Original FireStar 377 ________________________________________________________________________________
Date: Nov 24, 1998
On Mon, 23 Nov 1998, john hauck wrote: > hehehe I gave him a good flight and the 912 performed first class. With > two up and almost 20 gals of fuel, plus my gear in the gear locker, Miss > P'fer was climbing 1300 to 1500 fpm. She made me proud of her. However, I > think we were taking advantage of the nice east wind reflecting off some Hey John, Sounds like one of those fun trips that keeps a smile on your face for several days. I didn't realize a 2 up loaded MkIII would climb so well. Hmmmm, you got me thinking too. I'm not really seriously thinking of getting into another airplane yet, but last night I read an old review on the Avid and Kitfox. I've wondered how they stack up as competitors to the Kolb MkIII. The review article was not kind to either the Avid or the Kitfox, but it was perhaps written from a standpoint of someone used to a hands-off XC cruise plane. Most of us I guess prefer the lighter controls and a little yankin and bankin once in awhile. Any/all comments on these three planes? Ben Ransom http://mae.ucdavis.edu/~ransom ________________________________________________________________________________
Date: Nov 24, 1998
From: Cliff / Carolyn Stripling <striplic(at)dfw.net>
Subject: Flying & Stuff
To all, I got in a hour or so today after I changed out the half doors for the full doors and enclosure. I felt like I was in a spam can again... almost. The visibility was limited with some foggy scud clouds and the overcast was at 1.5K' - 2K'. The wind was not a big factor. I don't think I would have flown in unfamiliar territory today, but I know that area very well so up I went. I did a circuit at my home airport and then flew over to a lakeside airport about 15 miles away to practice on their grass field. On the way over, I checked the GPS against the ASI to see if changing the doors had made any difference in the indicated readings... no difference, but still way off actual... no matter. I have been careful to try to run my rotax at least 5800 rpm (as suggested by J.Hauck). That "putts" me along at about 70 mph... depending on how trimmed out I am and how rough the air is. Today, the air was relatively stable considering all the cloud activity... no sunshine to cause convection currents I guess. When I got back to my home airport I made my first 1/2 flaps landing. I was pretty high on final and rather than just dump the altitude with the flaps then retract before landing I just left the flaps deployed. I kind of liked the extra drag and shorter float they provided. Now that I have over 50 hours, I will begin to experiment with them some. I checked the main wheels and they needed tightening... one side only 1/8 turn, the other 3/8 turn... to bring them back to "non-wobble" "not-tight" snug. I also tightened the cable brakes a little. I needed a little more stopping power. After all the talk about hinges, I oiled mine a little. Talk about quick light ailerons now... sure, dream on... I discovered a screw up on my part and I have no idea how long I have been flying this way. The last time I loosened up the wing gap seal (probably to take off the rear enclosure last spring) I failed to slip the hold down hook into the tube that holds the center rear portion of the gap seal down. I have been flying that way for awhile with no problem. I could see where the hook had rubbed paint off the tube and where the gap seal had risen up to touch the muffler (I have an aluminum plate there to protect the Lexan from melting) and other engine parts, but the rear springs did their job as well as the "hook" and held everything in place. I gave the radio some more use today and I am very satisfied with the clear reception from other aircraft. I feel I am transmitting pretty well now, but so far have only tested once. Whatever... nobody was complaining today. Enclosing the Kolb does reduce the decibels due to wind noise... maybe even the engine a little and probably helps my transmissions. Shielding the plug wires helped some I know... no more stacato noise rising and falling with the rpms. Getting a good headset adaptor made all the difference. I am a happy camper... -- Cliff & Carolyn Stripling Him: Retired Pharmacist (972)247-9821 Dallas Texas Her: Real Estate Broker - Texas and Marble Falls Texas Both: 5th Wheel - RV - Travel Kolb MKIII - N582CC (50+ hrs) ________________________________________________________________________________
Date: Nov 24, 1998
Am I top assume that your kits came in some giant mailing tube mine came ina a wooden crate that i cut into three 16 inch by four foot shelves that adorn my shop to this day . Chris -----Original Message----- From: Larry Bourne <larrybiglar(at)earthlink.net> Date: Saturday, November 21, 1998 12:56 AM Subject: Re: Kolb-List: A Question already > >FIND THE "MOTHER" OF ALL MAIL TO SEND IN IT ! ! ! > > I left one of mine beside the house for 2 years, and it turned into a >huge cardboard coil spring. Big Lar. >---------- >> From: Ray L Baker <rbaker2(at)juno.com> >> To: kolb-list(at)matronics.com >> Subject: Kolb-List: A Question already >> Date: Friday, November 20, 1998 2:54 PM >> >> >> Hey Kolbers >> I got my first shipment on MK III, Kit 1, yesterday. Unpacked and >> checked all the nice shiny tubes. Everything looks OK. >> >> The Question: Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL >> MAILING TUBES?? >> L. Ray Baker >> Lake Butler, Fl >> >> ________________________________________________________________________________
Subject: Re: Time to say Goodbye
Date: Nov 24, 1998
Russell hey you can't leave ,as good as the RVs are nothing compares to that kolb departure !!! fair winds chris -----Original Message----- From: Russell Duffy <rv8(at)mindspring.com> Date: Sunday, November 22, 1998 6:35 PM Subject: Kolb-List: Time to say Goodbye > >Hello everyone, > >Richard came and took the SS away yesterday, so it's time to move on. I'd like >to thank everyone on the list for all the advice and entertainment I've received >over the last couple years. Even though the SS didn't turn out to be exactly >what I wanted, I don't consider the time and money to have been wasted. >Overall, it was an enjoyable experience, and along the way, I met some great >people, and made some lasting friends. > >Later today, I'll be leaving the list, and also removing the SS pictures from my >web site. Will Uribe has volunteered (didn't say no fast enough ) to post >some of my pictures as long as there's any interest. I sent him a CD-ROM last >week, so he's got them all. Thanks Will. > >Take care, and I'll see you in the sky when the RV-8 is done. > >Russell Duffy >Navarre, FL >RV-8, sn-80587 (tanks) >rv8(at)mindspring.com > > ________________________________________________________________________________
Subject: Re: FS-II AND BRS installation
Date: Nov 24, 1998
Dick I have a second chanz wing gap soft pack also and am wondering what are youdoing about the run out on the rocket , shute pack ???? mine is two years over the original repack time. chris -----Original Message----- From: Frcole(at)aol.com <Frcole(at)aol.com> Date: Sunday, November 22, 1998 10:21 PM Subject: Re: Kolb-List: FS-II AND BRS installation > >I have made several fiberglass fairings /gap seals on my FS2 covering a second >chance softback. I used laminated balsa for an exit area as long as the pack >opening and about 3/4 width. Make sure that the areas surrounding this exit >hole are smooth and snag free. It would be a real letdown to have a >successful deployment of a shredded chute. >Dick C > ________________________________________________________________________________
Date: Nov 24, 1998
In a message dated 11/24/98 11:49:55 AM Eastern Standard Time, ransom(at)mae.engr.ucdavis.edu writes: << With all that, and an ultralight's ability to land in little space means reliability isn't the top of the disadvantage column as far as I'm concerned. Of course I may change my tune when mine decides to go quiet again someday. >> I agree 100%, and even minimize ithe impact of quietness more, and certainly do not consider "engine quiet" as a curse. Actually I consider the engine as an extra "assist" to the already glorious feature of flying !! It is a matter of perspective...GeoR38 the ol "glider pilot" note: I checked out my L/D recently and found that the best I could muster was 7.9:1 with the engine at idle and airspeed of 42 mph approx.To me flying an ultralight is the same as a glider except with engine assist and I'm always looking for a place to land, which everyone should always do even in GA ....unless they are flying by the engine.....boo! ________________________________________________________________________________
Date: Nov 24, 1998
Gentlemen, I would someday like to see a study done on 2-cycle vs 4-cycle reliability. I think at this point in history, the 2-cycle would really give some startling aviation statistics as far as trouble-free hours for the amount of time flown. Carbon buildup will always be the downfall of these engines, but now that we all know about Seafoam and other such additives, these little hummers could really tip the scales on the fours. I'm impressed with all the hours flown by you guys and others using the 2-cycle. The four cycles do fail too, even those expensive Lycomings, because they have many more parts that go wrong. Maybe there is something to be said for simplicity ....... it means reliability. Ralph Burlingame Original FireStar, 447 powered >Definetly a factor, but 2-strokes can be kept pretty reliable. Main thing >required is knowledge of what they want, and then the diligence to treat them >right. 2-strokes are sorta dirty, loud, need oil added to gas, and deliver >unwanted vibration to plane and pilot. With all that, and an ultralight's ability to >land in little space means reliability isn't the top of the disadvantage >column as far as I'm concerned. Of course I may change my tune when >mine decides to go quiet again someday. > >Ben Ransom >http://mae.ucdavis.edu/~ransom > > ________________________________________________________________________________
Date: Nov 24, 1998
You can turn the 2-bladed prop horizontal when its stored and give you a lot more clearance for height. Ralph blade stick up as high as >a three blade, even if the two-blade was a few inches greater in >diameter and the engine had to sit an inch or two higher? ________________________________________________________________________________
Date: Nov 24, 1998
Try near carbon-free Klotz synthetic snowmobile oil KL-216. You won't need to change plugs for a year. Exceptionally clean! Ralph Burlingame Original FireStar, 447 powered > >michael.highsmith(at)worldnet.att.net writes: > ><< Bill, I'm glad it wasn't something serious but did you clean the >prop? > Please forgive me but what kind of prop was it? I've never heard of >carbon > causing vibration enough to be able to tell it in flight. I learn >something > new in this sport everday. What a gas. Something to put in the book. >>> > >Hi Michael, > >The prop is a Tennessee, wood, 66 X 30, clean it after each flight, >looks like >new. Had checked tracking and balance before removing engine and both >were >good. I usually cruise at 4800 to 5000 RPM with this prop (to keep up >with my >buddy who has a KXP 447 with 66 X 32 and turns 4500 most of the time). > My CHT >about 250 and EGT indicates 1100, sometimes lower. Plugs are a nice >light >chocolate brown color, so mixture appears to be not overly rich. But >apparently something is making lots of carbon. I'm using Castrol >Super >snowmobile oil @ 50:1 > >I know the reccomended prop for this engine is 66 X 28, but when I >originally >got my kit it had a 66 X 32 prop and I flew with that one 3 years. >And I >turned less RPM, in the 4200 to 4500 range The EGT then was really >low, in >the 900 to 1000 range. It didn't seem to make as much carbon, but it >did make >it and I decarbon every winter when its to cold to fly. I mostly use >Amoco >fuel, but have also used others on occasion. Guess I'll have to start >experimenting to see if I can reduce the carbon buildup. Funny thing >is, it >only gets on the piston dome. The heads are clean! > >Bill Varnes >Audubon NJ >Original FireStar 377 > > > ________________________________________________________________________________
Date: Nov 24, 1998
> >I'm beginning to sweat whether I can get a folded Mark III in my garage. II >only have 83'' with the garage door up. Don't fold the wings up, take them off. I take the wings completely off my MKIII when ever I need to put it in the garage for maintainance, etc. You are only pulling out one more bolt, it is no big deal. It adds maybe 5 minutes more when I put it back together. I have made a couple racks that hang from the garage roof, and just put the wings in them. Heres how they work: Get a 6' length of 2 1/2" or 3" pvc and hang it from the ceiling in a level attitude about 10" below the ceiling. This is the support for one end of the wing. Put a screw eye in a rafter and tie a heavy cord to it. Get a 6' length of 2 1/2" or 3" pvc and hang it from the cord at one end. Put another screw eye in the ceiling at the other end of where the pvc will go when you swing it up level. Put a loop of cord in the screweye. When you carry the wing in, ease one end of the wing over the level hanging tube. Then go to the other end of the wing, where the pvc is hanging vertically, and swing it up level to support the wing, and slip the loop over the end of the pvc tube. Done. Caution! Stits paint does not resist abrasion for beans. Don't slide or scrape the wing along the pvc, or it will rub through the paint. Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 24, 1998
Subject: Re:Prop clearance
Anybody out there know what the minimum recommended clearance is between the prop & the fuselage tube is? Thanks, ---Richard Swiderski PS: How about it you 912 owners, what's the distance from the center of your prop to the fuselage tube? ________________________________________________________________________________
Date: Nov 24, 1998
. The four cycles do fail too, even those expensive Lycomings, >because they have many more parts that go wrong. Maybe there is something >to be said for simplicity ....... it means reliability. > >Ralph Burlingame >Original FireStar, 447 powered Well Kolbers: Reliability is relative whether two or four stroke. If it is running it is reliable. If it ain't it is unreliable. Most of the problems I have had with either type eng was my making, or failure to check what someone else did. Two stroke was sparkplug wire falling off inverted Cuyuna, paper fuel filters, fouled spark plug. 912 only quit when I got a couple gals of water with 10 gals of gas and I failed to drain fuel prior to takeoff. Course the eng didn't stop on the ground, it waited til I was most vulnerable, a couple hundred feet in the air in a hard climbing turn. Was able to get her turned 360 deg and land where I had just departed. Lake Texoma, Texas, last Jun, got the first ten gal of fuel from new fuel tank, filter, pump, hose and nozzle. Was lucky, didn't lose eng until about two hours eng time after refueling. Fuel filter packed up completely with debris, shut off fuel supply and eng twice. Lucked out and got it on the ground again successfully. Only time the 912 everstopped in 985+ hours. Had a 582 seize, never determined cause. This type failure bothers me more, when it comes to reliability, than flying with the 4 stroke. Haven't heard of any 4 stroke siezures. This 582 seizure gave me no warning signs, feel, sound, or instrument readings, no clues that it was impending. I still fly 2 strokes and don't sit on the edge of the seat when I fly them. They have given me good service and reliability. One of the biggest factors to fly a 4 stroke is economy of fuel, oil, sparkplugs, and teardowns. If one flies enough it will make up the difference in purchase price with economy. Yes, if it is mechanical it may break, no matter what it is. Was taught in flight school to always have a forced landing area in site. Still an important safety factor. john h ________________________________________________________________________________
From: "Larry Bourne" <larrybiglar(at)earthlink.net>
Date: Nov 24, 1998
Are you sure you're building a Kolb ?? Most of mine came in four 6" cardboard tubes, and one box. And inside those cardboard tubes were an awful lot of aluminum tubes. And inside the box was the best $200.00 I ever spent - the prebuilt wing ribs. The fuselage ?? came in a 3 sided plywood shelter (??), but that was months later. Big Lar. ---------- > From: CHRISTOPHER DAVIS <cdavis2(at)capecod.net> > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: A Question already > Date: Tuesday, November 24, 1998 5:06 PM > > > Am I top assume that your kits came in some giant mailing tube mine came > ina a wooden crate that i cut into three 16 inch by four foot shelves that > adorn my shop to this day . Chris > -----Original Message----- > From: Larry Bourne <larrybiglar(at)earthlink.net> > To: kolb-list(at)matronics.com >> I got my first shipment on MK III, Kit 1, yesterday. Unpacked and > >> checked all the nice shiny tubes. Everything looks OK. > >> > >> The Question: Now that it is empty WHAT DO I DO WITH THE "MOTHER" OF ALL > >> MAILING TUBES?? > >> L. Ray Baker > >> Lake Butler, Fl > >> > > ________________________________________________________________________________
Date: Nov 24, 1998
As an interesting aside on 2-stroke reliability, Duane Cole's video, "VFR tips for all pilots", has an interesting segment wherin the Ol' Master Hisself advises that he always flys evaluating the terrain ahead so that given the choice, he has a good flat field within gliding distance in case his Expensive Genuwine Certified Aereoplane Engine quits. And he says he normally alters his flight path right and left to give himself an out just in case. Maybe that puts things in perspective? Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Subject: 2-stroke reliability
Date: Nov 24, 1998
-----Original Message----- From: GeoR38(at)aol.com <GeoR38(at)aol.com> Date: Tuesday, November 24, 1998 9:11 PM Subject: Re: Kolb-List: 2-stroke reliability > >In a message dated 11/24/98 11:49:55 AM Eastern Standard Time, >ransom(at)mae.engr.ucdavis.edu writes: > ><< With all that, and an ultralight's ability to land > in little space means reliability isn't the top of the disadvantage > column as far as I'm concerned. Of course I may change my tune when mine > decides to go quiet again someday. >> snip >....unless they are flying by the engine.....boo! That's easy for you flatlanders to say. Around here it's mostly granite clouds and forests. David (but I'll find out fer sher when I get up there) Bruner ________________________________________________________________________________
Date: Nov 24, 1998
Hey Bill, Well, being you cleaned your prop but it's a wood prop, when did it get wet or when was the last time a front came through your place or did you leave the prop vertical the last time you flew before you noticed the vibration? It's funny how one answer can lead to a whole lot more questions ain't it? I don't know about the snowmobile oil your are using but I bet if you were to switch to Pennsoil 2 cycle air cool oil and run it a little harder it wouldn't have a carbon problem. I use to the same problem with a different brand that works great in a lot of other engines but I always had a carbon problem too. Then I called John Hunter at Lockwood to find out what they used in their 582's. He told me that Rotax recommends Pennsoil (air cooled) in all there aircraft engines regardless of whether it was air cooled or liquid cooled because of the way they are run ( long periods of sustained and steady RPMs and similiar temps). This was after my brother had put some 800 hours on a Lazair with the 9.5 HP Rotax's using Pennsoil with out a rebuild. Then there was my wingman Richard who has always used the oil and has never had a problem. I wasn't satisfied with the evidence that they gave me either. I had to try something different also. Guess what ? I was decarboning every 100hours or less. I probably should have done it at 50 hours. I have 250 hours since the top end (this is where I started using Pennsoil) and it is still going strong without a decarboning. I don't have any of the other problems that goes along with carbon buildup either like hard cranking from the rings being stuck on the pistons and smoot black plugs, which I had to change a lot more often. Richard had even gotten to the point that he would not even crank his plane around me until he was sure I was cranked. I spent many times hand proping while he held my plane. We've not had to hand prop but once and that was from a dead battery since I switched. I am convienced it was the switch to Pennsoil. I also use the injection system that is still set from the breakin. How many hours do you fly and how often? Did you know that wood props absorb water and that it can migrate to one end? I have a wood prop I use as a spare. In case of emergency only. I know it is as balanced as I can get a wood prop but compared to my IVO it can't hold a candle to the smoothness or quietness. The whole plane benefits from the lest amount of vibration that can be run. That old wood prop liked to have beat me to death on our trip to Nulltown, In. last year while the IVO was being repaired. After that trip I decided to stay home if I couldn't have the IVO. I know there are pros and cons to all of this and would like to hear from the rest of you. Who knows there might be something out there you are using with great results and we would all benefit from it. All for now. Thanks for the return. Firehawk. -----Original Message----- From: WVarnes(at)aol.com <WVarnes(at)aol.com> Date: Tuesday, November 24, 1998 3:42 PM Subject: Re: Kolb-List: Engine vibration-The answer is:carbon ? > >michael.highsmith(at)worldnet.att.net writes: > ><< Bill, I'm glad it wasn't something serious but did you clean the prop? > Please forgive me but what kind of prop was it? I've never heard of carbon > causing vibration enough to be able to tell it in flight. I learn something > new in this sport everday. What a gas. Something to put in the book. >> > >Hi Michael, > >The prop is a Tennessee, wood, 66 X 30, clean it after each flight, looks like >new. Had checked tracking and balance before removing engine and both were >good. I usually cruise at 4800 to 5000 RPM with this prop (to keep up with my >buddy who has a KXP 447 with 66 X 32 and turns 4500 most of the time). My CHT >about 250 and EGT indicates 1100, sometimes lower. Plugs are a nice light >chocolate brown color, so mixture appears to be not overly rich. But >apparently something is making lots of carbon. I'm using Castrol Super >snowmobile oil @ 50:1 > >I know the reccomended prop for this engine is 66 X 28, but when I originally >got my kit it had a 66 X 32 prop and I flew with that one 3 years. And I >turned less RPM, in the 4200 to 4500 range The EGT then was really low, in >the 900 to 1000 range. It didn't seem to make as much carbon, but it did make >it and I decarbon every winter when its to cold to fly. I mostly use Amoco >fuel, but have also used others on occasion. Guess I'll have to start >experimenting to see if I can reduce the carbon buildup. Funny thing is, it >only gets on the piston dome. The heads are clean! > >Bill Varnes >Audubon NJ >Original FireStar 377 > > ________________________________________________________________________________
Date: Nov 25, 1998
SNIP > >Was taught in flight school to always have a forced landing area in site. >Still an important safety factor. > >john h > Good Post John, One question, with all the cross country flying you do, how religious do you follow this principle? I'll admit I compromise at times. Eugene > > ________________________________________________________________________________
Date: Nov 25, 1998
In a message dated 11/24/98 10:35:05 PM Eastern Standard Time, hawk36(at)mindspring.com writes: << Had a 582 seize, never determined cause. This type failure bothers me more, when it comes to reliability, than flying with the 4 stroke. >> John: You get alot of respect on this list and you deserve it. But let me offer the following. Again, it is NOT my intention to give you a hard time. Several years back at lakeland I was doing my annual tour of the certified rotax repair guys' tents. Every year I go talk to these guys and ask them about the failure modes they have seen in different engines, principally 582 and 503 because that's what I fly. My experience is that engine rebuilders are a much more reliable source of good information about failures than pilots themselves. Anyway, the guy from Greensky (I think) offered to sell me a brand new freshly rebuilt 582 which he said had something like 5 hours total time on it. I said gee, why was it rebuilt after such a short time? The guy knew I was a Kolb pilot, and he sorta shuffled his feet and said well, one of your better known kolb pilots seized it up. I said jeez, how did he do that? The guy replied, well, this pilot thought that Marvel mystery oil was good stuff, so he put a little in the gas. That worked out good so he decided to put a little in the injection oil. Well what most folk don't know is that marvel mystery oil is mostly solvent and perfume with a little high grade lubricant. The pilot put in enough that it screwed up the oil/fuel ratio and he seized the engine due to lack of lubrication Anyway, he said that guy was you. PLEASE DON"T ANYBODY SHOOT ME!!!! I'M JUST REPEATING WHAT I WAS TOLD. However, even if this story isn't true (which I repeat it may not be) there is a lesson to be learned from it. We are all tinkerers or we wouldn't build our own planes. Every kolb owner has customized his plane to some degree and as his own way of doing things. This is fine except that there are limits to how far we can deviate from "doing it by the book." There is a whole category of accident which happens in this category of plane which doesn't happen in GA planes. Example: a guy a my field with an early firestar found his plane to be nearly uncontrolable after he changed the frame tubing around and moved the gas tank to "make it look cooler." When do you think the last time was that happened with a c-182? My point here, and I think I'm in agreement with John, is that when it comes to operating Rotax engines most of our wounds are self inflicted. ________________________________________________________________________________
Date: Nov 25, 1998
>>Was taught in flight school to always have a forced landing area in site. >>Still an important safety factor. >> >>john h >> > > >Good Post John, > >One question, with all the cross country flying you do, how religious do >you follow this principle? >I'll admit I compromise at times. > >Eugene Hi Eugene: I wish I could say I religiously follow the principle of having that forced landing area in sight, but I get complacent and find my self in situations where I would most definitely be the loser is I lost an eng. I have never lost an eng when I expected it. It always comes as a complete surprise. In the days of 2 stroke flying I practiced what I preached. I think the fact that the 2 stroke quit more frequently made a better pilot out of me. Also in those days my XC flying was done with mag compass and sectional. That also made a better pilot out of me. Today with the GPS I get lazy because it is so reliable. I try to keep up with my progress on the sectional most of the time. Coming out of Kankakee, Illinois, to Joliet and Oshkosh this year I lost the GPS. Shocked me right back into the real world in a flash. I had to fly pilotage and dead reckoning to Joliet before the GPS decided to cooperate. After I got settled down to busy, I realized I had been missing out on some good flying. All I had to do was watch my airspeed and altitude, read my sectional and follow my route on the ground, as I cross checked the mag compass. I wasn't worried about ground speed, ETA, or staying precisely on course. Given the choice though, I'll fly with the GPS as primary nav aid. It saves time, gives me a lot of emergency options, and makes my XCs safer, which translates to more longevity and the opportunity to continue flying. john h ________________________________________________________________________________
Date: Nov 25, 1998
><< Had a 582 seize, never determined cause. This type failure bothers me >more, > when it comes to reliability, than flying with the 4 stroke. >> > > >failures than pilots themselves. Anyway, the guy from Greensky (I think) >offered to sell me a brand new freshly rebuilt 582 which he said had something >like 5 hours total time on it. I said gee, why was it rebuilt after such a >oil/fuel ratio and he seized the engine due to lack of lubrication Anyway, he >said that guy was you. Hi Gang: I think you are talking about Gerry Olenik, owner of the oldest Rotax dealership in the US. I've done business with him for years, however, Gerry didn't get involved with my 582, except to sell me pistons, rings, and gaskets to rebuild it. I had over 200 hours on this eng, flying to Lakeland, Homer's in Pa, and Oshkosh. This was a new eng I got from Homer when I built the MKIII. Flew it the same way during its entire life, with Marvel Mystery Oil since day/hour one. Seems to me, if it was the MMO that caused the seizure, it would have happened early on. Put about 1200 hours on my Cuyuna and 447s, all with that shot of MMO. The 582 is the first and only 2 stroke I have ever seized, including a fist full of MX bikes, outboard motors, and my weed eater. I swapped the 582 for the 912, but I went south instead of north to do it. I dealt with Ronnie Smith. I guess stories like this are part of the little bit of notoriety I have gained over the years. I think I mentioned in a recent post that I doubled up on MMO for my flight to Quincy, Fl, and return. The 912 has ingested a lot of that stuff over the hours, also my Dodge Cummins Diesel, Onan generator, and the 351W eng in the old Searay. I swear by it. I wonder if it would work on my arthritis??? hehehe Did you guys know if you keep a four stroke eng bogged down, running below the power band, that it will carbon up, get cranky, lazy, and weak? Don't you know how much better the old buggy runs after you take it out on the Interstate and blow that sucker out for an hour or so. Two stroke engs are just like deem 4 stroke engs when it comes to getting clogged up with carbon and gunk. I read on this list of making these poor little engs fly around at 4500 to 5000 rpm their entire life. Then when they get gunked up with carbon, cannot figure out what they are doing wrong to cause this terrible condition. It is pretty simple to me, it is your left hand, the one you have on the throttle. The rotax 2 stroke is not a tractor (farm) eng, it is a high performance, high rpm eng that spends its entire life loaded/going up hill all the time, even when it is idling. It has an expansion chamber exhaust system that is designed to make the eng efficient, both power and economy, somewhere after 5300/5400 rpm. I always found with the 2 stroke (Cuyuna, 447, 582) that they all like to run 5800 rpm cruise. At this rpm they are smoother and the internals will stay significantly cleaner. OK, I can only talk, with experience, about 2 strokes up thru the early 90's, but I bet they haven't changed all that much since then. Just my own thoughts and experiences friends. This ain't the gospel, but it has worked for me, and it is still working. If it changes, I'll let you know. john h (Hauck's Holler, Alabama, still got those leaves and pinestraw to rake up, ugh!) ________________________________________________________________________________
Date: Nov 25, 1998
On Tue, 24 Nov 1998, David Bruner wrote: > That's easy for you flatlanders to say. Around here it's mostly granite > clouds and forests. > Good point David. The typical terrain around my area makes it easy to fly a 2-stroke. I'm not sure I'd have the nerve to fly most of the time over mostly unlandable terrain. Another little point about keeping an emergency landing field in site: One of the things I find a little bit of a game is to keep track of the good em fields that go behind you. When I give myself the quick pop quiz of "alright! where is the best spot?!", i often find I select something and a few seconds later realize a far better spot is right behind me within easy glide. Makes me pay attention ...until the day dreaming takes over again. Day dreaming requires higher altitude, and sometimes it is easier just go up to get that bigger margin of comfort. Ben Ransom http://mae.ucdavis.edu/~ransom ________________________________________________________________________________
Date: Nov 25, 1998
Subject: cringley alert!
If you want/need to waste three "hole" hours tonight, punch up PBS to get cringley's "IDEAS" of how the internet works. If he's no better at this than he was at building a plane in 30 days, then we'd all better turn our computers off. GB ________________________________________________________________________________
Date: Nov 25, 1998
Subject: Re: BEUFORD???
Beauford, You did it again! Made me laugh out loud. I'm gonna have to stop reading your posts at work. John Jung ________________________________________________________________________________
Date: Nov 25, 1998
> >Another little point about keeping an emergency landing field in site: One >of the things I find a little bit of a game is to keep track of the good >em fields that go behind you. When I give myself the quick pop quiz of >"alright! where is the best spot?!", i often find I select something >and a few seconds later realize a far better spot is right behind me >within easy glide. Makes me pay attention ...until the day dreaming >takes over again. Day dreaming requires higher altitude, and sometimes >it is easier just go up to get that bigger margin of comfort. > >Ben Ransom Right on, Ben: You can't beat altitude for that added bit of safety. If I have to cross "bad stuff" I get altitude. One point to remember if the fire goes out, choose a good forced landing area and get set up to land in it. If you see a better one and you have a lot of altitude and plenty of time (and this area you know you have made) then change, but it is usually much better to select the site and land in it. Bill Griffin, on this list will probably more than happy to tell you what can happen if one is not decisive. There ain't no go-a-rounds, john h ________________________________________________________________________________
From: "Michael Highsmith" <michael.highsmith(at)worldnet.att.net>
Date: Nov 25, 1998
Hey Ben. If you guys are Kolbers does that make me a Ferber? Amen on the bigger picture Ben. I can relate from my on experience that an engine out at altitude is a lot more forgiving than one at low altitude. The options are much better and you have time to think, what the best coarse of action is. That difference in time can make the difference in whether or not you make it or break it. In my training course , I try to instill into my students to always have a spot picked out within the cone that the airplane always sits on in flight. The outer edge of the cone is at a 45* angle down from the plane. It may be overkill for some pilots but this will usually work on any airplane. I believe in the "WHEN NOT IF " saying about engines, all of them. Just the other day a student pilot an his instructor had to put down on a county road north of here because the Lycoming in the C-150 quiet. Funny thing is I had to practice emergency approaches on that same road when I went for my private. I'm getting like John about this stuff. It's almost addictive. I wonder if there is a support group for E-mail addicts on the "Internet". All for now. Firehawk. P.S. I definantly agree with the MMO that John uses. I use it from time to time as a gas additive. Sure helps to keep thing clean along with Pennsoil. But I don't mix the two, something a Pennsoil Rep. said one time " It may or it may not mix but do you want to take the chance?'' I think he was refering to outside temperatures and the way the viscosity is different in the two oils not readily mixing. -----Original Message----- From: Ben Ransom <ransom(at)mae.engr.ucdavis.edu> Date: Wednesday, November 25, 1998 10:43 AM Subject: Re: Fw: Kolb-List: 2-stroke reliability > >On Tue, 24 Nov 1998, David Bruner wrote: >> That's easy for you flatlanders to say. Around here it's mostly granite >> clouds and forests. >> >Good point David. >The typical terrain around my area makes it easy to fly a 2-stroke. >I'm not sure I'd have the nerve to fly most of the time over mostly >unlandable terrain. > >Another little point about keeping an emergency landing field in site: One >of the things I find a little bit of a game is to keep track of the good >em fields that go behind you. When I give myself the quick pop quiz of >"alright! where is the best spot?!", i often find I select something >and a few seconds later realize a far better spot is right behind me >within easy glide. Makes me pay attention ...until the day dreaming >takes over again. Day dreaming requires higher altitude, and sometimes >it is easier just go up to get that bigger margin of comfort. > >Ben Ransom >http://mae.ucdavis.edu/~ransom > > ________________________________________________________________________________
Subject: Inspection holes in fabric
Date: Nov 25, 1998
I am just wrapping up the covering of my MKIII and was wondering where I should install inspection rings to be cut out if needed. I was going to put one where the drag strut meets the steel rib, but other than that I cant think of where else I might need one. Any input would be helpful. ________________________________________________________________________________
Date: Nov 25, 1998
Subject: Re: Inspection holes in fabric
In a message dated 11/25/98 3:26:32 PM Eastern Standard Time, jason(at)acuityinc.com writes: << wondering where I should install inspection rings to be cut out if needed. >> I installed inspection rings in each bay between the ribs on the wing, alternating them fore and aft, and put one near the strut attach and two on the inboard flat edge of the wing. Its simple and easy to do and could save you huge headaches in the future. ________________________________________________________________________________
Date: Nov 25, 1998
Me too! I printed this last one and took it with the wife on a trip into town (This is a long way from where I live). I had her read it out loud to me. She could hardly believe it. I have a separate folder on my email for saving these! Jon -----Original Message----- From: John Jung <jrjung(at)execpc.com> Date: Wednesday, November 25, 1998 6:03 PM Subject: Re: Kolb-List: BEUFORD??? > >Beauford, > You did it again! Made me laugh out loud. I'm gonna have to stop reading your >posts at work. >John Jung > > ________________________________________________________________________________
Date: Nov 25, 1998
On Wed, 25 Nov 1998 Cavuontop(at)aol.com wrote: > > << wondering where > I should install inspection rings to be cut out if needed. >> > > > I installed inspection rings in each bay between the ribs on the wing, > alternating them fore and aft, and put one near the strut attach and two on > the inboard flat edge of the wing. Its simple and easy to do and could save > you huge headaches in the future. > I take it that you installed the rings but not the holes & covers? If holes & covers, that seems like a lot to me. On the other hand, I think there should be *some* holes and covers to be able to look inside. I installed 2 rings/holes/covers on each wing: - 1 on the bottom of each wing where the lift+drag struts join the main spar -- a key spot to be able to get a visual on at annual. I just love to look at that home-made AL box where they join cuz it is so impressive how you can get so much strength out of thin AL (!). Also, I could get a wrench on top of the big spar bolt if I needed to (or somebody with small hands could). - 1 on each wing root just behind the main spar to peek in on the drag strut and it's steel braces. For the wing root, you could cut it and patch it annually but rings seem more the right way to do it. Ben Ransom http://mae.ucdavis.edu/~ransom ________________________________________________________________________________
Date: Nov 25, 1998
In a message dated 11/25/98 5:06:39 PM Eastern Standard Time, ransom(at)mae.engr.ucdavis.edu writes: << I take it that you installed the rings but not the holes & covers? >> I just installed the rings. If I need to I will I will cut them open and put in a cover. Perhaps at my first annual I will cut open the hole by the lift strut to check. The big benefit to the rings is that if you ding your wing you can cut open a nearby hole and see how bad the damage is without having to take all the cover off. ________________________________________________________________________________
Date: Nov 25, 1998
>Don't fold the wings up, take them off. I take the wings completely off my >MKIII when ever I need to put it in the garage for maintainance, etc. You >are only pulling out one more bolt, it is no big deal. It adds maybe 5 >minutes more when I put it back together. >. > >. Yes but why? I have never pulled the wings for storage and have never found a reason to pull them off except when I did a bit of welding to the frame. Every thing fits so neat on the Kolb removing the wings adds another potential for damage. Even removing the wings the height will remain the same. Woody ________________________________________________________________________________
Date: Nov 25, 1998
<< ....unless they are flying by the engine.....boo! That's easy for you flatlanders to say. Around here it's mostly granite clouds and forests. David (but I'll find out fer sher when I get up there) Bruner >> David, what I meant by "flying by the engine" was disregarding some common sense dealings with the hard spots, namely the ground, or other hard barriers. For instance, when you fly near the "granite" (mountain, hill) it would be adviseable to stay on the windward side to take advantage of the prevailing air currents for lift, just in case the engine did quit. Instead of coming in for a landing at a constant 1.3 degree declination like a GA plane might at a big airport, stay high enough to always be able to pick an alternate landing point , until you finally clear the final impediment or barrier such as telephone lines before "aiming at the ground" or slipping to the ground. Yes you will land hotter and longer but always safer.(unless of couse you blast yourself into the woods at the other end of the too short runway!!) I think I hate that when that happens. Know the wind strength and direction at all times to be able to estimate how far you can glide if the engine quits now....no, I mean ....now. My L/D is 7.9:1 on an engine idle ( therefore it is probably better than that when the prop stops completely), therefore I can go almost 8 miles on a dead day if I'm up one mile, and that is like money in the bank for engine failure. ..................GeoR38, the ol glider pilot ________________________________________________________________________________
Date: Nov 25, 1998
Hi Gang: I can't stand it any more ! ! ! I know this is a subject jump, but when I read that comment by David Bruner, I instantly flashed to an old " Far Side " cartoon. Scene is an airliner cockpit flying through the clouds, looking past the pilots, and out the windshield at a mountain goat standing in the clouds. The pilot is saying to co-pilot, " saaay, wait a minute." You KNOW what's going to happen next. I would really love to know where to find that goofy thing. I've looked through quite a few of his collections, and haven't hit it yet. Big Lar. ---------- > > > That's easy for you flatlanders to say. Around here it's mostly granite > clouds and forests. > > David (but I'll find out fer sher when I get up there) Bruner > >> > > ________________________________________________________________________________
Date: Nov 25, 1998
> >>Don't fold the wings up, take them off. I take the wings completely off my >>MKIII when ever I need to put it in the garage for maintainance, etc. You >>are only pulling out one more bolt, it is no big deal. It adds maybe 5 >>minutes more when I put it back together. >>. >> >>. > > Yes but why? I have never pulled the wings for storage and have never >found a reason to pull them off except when I did a bit of welding to the >frame. Every thing fits so neat on the Kolb removing the wings adds another >potential for damage. Even removing the wings the height will remain the same. > >Woody > > Potential for damage is the key word. Met a guy that trailered his Kolb all over the place, and he said if he had to do it over again, he would have made his trailer so that the wings hung on the sidewalls. Seems that the leading edges are so close to the ground when it is folded, that they can readily drag when you go over a hump, or where a ramp meets the trailer. His leading edges were kinda beat up. I am glad I did not provide for my wings to fold, so that I am not tempted. Besides, empty weight is 513, with 15 gallons of fuel, it is over 600 pounds. Trying to push that across the back yard to the garage would wipe the Old Poops out. It is heavy enough with the wings off. Besides, the only time I put it in the garage is to do maintainance. And the wings would be in the way. Richard Pike MKIII N420P (42oldpoops) ________________________________________________________________________________
Date: Nov 25, 1998
WISHING all of you delightful friends the very nicest Thanksgiving ever. Be well and content with your loved ones on this day and always--ken and judi in Alaska ________________________________________________________________________________
Date: Nov 26, 1998
Subject: Thanksgiving
One tradition in my family is, as we sit down at the feast, for each person to have the opportunity to say what they have this year for which they are especially thankful. For me, one of the most wonderful gifts this year is God's gift of flight, and perhaps the chance to appreciate the world in a way in which very few folks will ever be able to experience. Blessings to all, and best wishes for safe flying in the "Kolbische Flugzeug." Paige Straley ________________________________________________________________________________
Date: Oct 28, 1998
Subject: Garage fit
Duncan I have a MK111 with rotax 912, ivo 3 blade groung adj prop installed. The height with one blade centered stright down is 81 inches. Wings when folded are app same height as top of cage. Hope this helps. Bob Mk111 95% N350RB ________________________________________________________________________________
Date: Nov 26, 1998
Subject: Re:Far Side Cartoon
BIG Lar The cartoon is in "Beyond The Far Side," fourth printing (mine) Nov '83, Lib Congress 83-71765. Co-pilot says to Pilot: "Sat...What's a mountain goat doing way up here in a cloud bank?" I'd send you, via FailMail, a cy if you want. Need FM address. Grey Baron ________________________________________________________________________________
Subject: Quincy BBQ
Date: Nov 26, 1998
I don't know what I was thinking about when I said Rut's friend was named Deana, it's not.That is my daughters husbands old girlfriend's name- hummm. Rut's girlfriend's name is Jeanie. I hope I didn't call her Deana at the BBQ and if I did I appolagize for being brain dead. Rut, you will pass this along for me, please "grovel- grovel''.Gee one would think that with 12 brothers and sisters and about 85 nephews and neices I could remember names. Now lets see, who am I suppose to be sending this to? Oh yea Kolb/list Thanks FIREHAWK -----Original Message----- From: Tusky(at)aol.com <Tusky(at)aol.com> Date: Thursday, November 26, 1998 7:48 AM Subject: Kolb-List: Thanksgiving > >One tradition in my family is, as we sit down at the feast, for each person to >have the opportunity to say what they have this year for which they are >especially thankful. For me, one of the most wonderful gifts this year is >God's gift of flight, and perhaps the chance to appreciate the world in a way >in which very few folks will ever be able to experience. > >Blessings to all, and best wishes for safe flying in the "Kolbische Flugzeug." > >Paige Straley > > ________________________________________________________________________________
Date: Nov 26, 1998
Subject: Re: Engine vibration-The answer is:carbon ?
michael.highsmith(at)worldnet.att.net writes: << Hey Bill, Well, being you cleaned your prop but it's a wood prop, when did it get wet or when was the last time a front came through your place or did you leave the prop vertical the last time you flew before you noticed the vibration? It's funny how one answer can lead to a whole lot more questions ain't it? >> Hi Michael, I know what you mean about moisture in the prop. I fold the wings for storage after each flight and the prop is always placed horizontal, so it shouldn't get out of balance from that. Besides, balance was one of the first things I checked. I just might take you up on the suggestion of using Pennzoil. I had originally started using that oil, then the Castrol became easier to get locally, and its a good oil, but maybe it is part of my problem. Trouble is, if I change too many things, I'll never know for sure which made the difference, if any change at all. And it takes at least 40 maybe 50 hours before a decarbon is needed. I had about 60 when I noticed the problem. <> Well I'm sort of retired, so I fly about twice a week, depending on the weather. First year, 1994 I only flew 30 hrs. Since then averaging about 70 hrs per year, and now have 305 hrs. on it. I'd even fly more often, but I have to drive 35 miles to the airport. That takes 1 hr each way due to traffic and back roads. Then it takes me 1/2 hr to set up, fuel up ,etc. Then another 1/2 to tear down and clean up, etc, So I usually don't go unless I can fly at least one hour or longer. Been on several cross country trips of 1-1/2 hrs. each way. Thanks for your input FIREHAWK. Bill Varnes Audubon NJ Original FireStar 377 ________________________________________________________________________________
Date: Nov 26, 1998
On this list, I have been reading a lot about cold seizures, hot seizures and the eventual recognition for the inevitability of failure with our 2-stroker's. I'll preface what I wish to ask with: In this area, the east kern portion of the upper desert of southern california, there has been no known seizures. I know of one person with a firestar & 447, who waited until he had 632 hours on the engine before he broke it down. He only found some minor scratches in the aft piston area. My question is this: What oil are you using in your mixture's. I would like to know if there are any seizures using the av-2 oil? Thank you Richard of Boron ________________________________________________________________________________
From: "Ron Carroll " <ron.carroll(at)worldnet.att.net>
Subject: Tailwheel rod replacement
Date: Nov 26, 1998
When I built my Original Firestar I wasn't aware of the aluminum replacement for the fiberglass tailwheel rod. However, now that I am flying it I see that the replacement is needed because the tailwheel flexes sideways when turning. My question to the group is: What is the best way to remove the epoxied-in fiberglass rod? Naturally, I don't want to damage the lower fin in doing so. The use of heat is out of the question so I assume I'll have to cut off the rod near the lower fin and drill a pilot hole as close to center as I can. Then follow that with progressively larger drills. Is there some other way? Thanks, Ron Carroll Original Firestar ________________________________________________________________________________
Date: Nov 26, 1998
Subject: Sudden Engine Noise - better take a closer look
Here's a little thing that happen to one of the guys on our field as described by my partner. They had a fly in the area on one of the most beautiful days I've seen in a long time. Crisp with radiant blue sky, little wind and I had to leave on a flight that afternoon so couldn't attend. My partner flew our FireFly in and had a great day. Gene, one of our buddies on the field missed out on the fly in. Seems he suddenly developed noise in his engine (a 447). Later found out that one of the brand new spark plugs had broken off some porcelain near the electrode. Put a new plug in and the noise went away for a little while. He ended up pulling the cylinder and found the broken hunk of porcelain in the cylinder. It had beaten up the piston top, which he smoothed with a dremel tool. He's ready now to test fly it. Talk about luck. Jerry Bidle ________________________________________________________________________________
Subject: Re: Sudden Engine Noise - better take a closer look
Date: Nov 26, 1998
--> >Gene, one of our buddies on the field missed out on the fly in. Seems he >suddenly developed noise in his engine (a 447). Later found >out that one of the brand new spark plugs had broken off some porcelain near >the electrode. Put a new plug in and the noise went away for a little >while. He ended up pulling the cylinder and found the broken hunk of >porcelain in the cylinder. It had beaten up the piston top, which he >smoothed with a dremel tool. He's ready now to test fly it. > >Talk about luck. > >Jerry Bidle > Happy Thanksgiving Kolbers: Jerry, I don't really know how lucky your buddy is. If a piece of porcelain beat up the top of the piston, it had to have something to beat on, and that would be primarily the cylinder head, and possibly the top ring. Depending on the severity of the damage to the top of the piston, I might have considered replacing it with a new one. Dremel tool equates to grinding and grinding equates to loss of mass and weight. Might prove to be a problem. I used to balance my pistons, rings, wrist pins and bearings. There was always enough difference in their weights to make a difference in the vibration level of the 447 and 582. Just food for thought. john h (full of smoked turkey in Hauck's Holler, Alabama) ________________________________________________________________________________
Date: Nov 26, 1998
Hey Bill, Sounds like you got it under control. If you call the Pennzoil people they will put you in touch with some one in your area. 70 hours a year, huh. I can see you are a dedicated flyer when you have to drive all that way and then set it up.I must be one of the few that is only 5 minutes from my plane. I use to live 10 minutes but that was to far and it took too much time to get to the airport. So I built me another house closer and then sold the other one. Now I,m thinking about building a house on a new runway north of here where I can just walk out the back door and get in the plane and go. I dream a lot too. Bill, I have a wood prop that I use as a spare and another that I have on my Fisher 202. I have never been able to balance them satisfactorily. Would you mind telling me how you do that ? I bet there are a lot out there that would like to know. I've used prop balancers and they don't seem to give me the balance I am looking for. There is always this low frequency vibration that can only come from the prop. I guess I'm spoiled by the smoothness of the IVO. I was out flying around this afternoon just checking that bolt I torqued for maintenance, I am just amazed sometimes how good it feels to be able to fly. It was so smooth and no one else around. John H. mention that he uses Marvel mystery oil in his mechanical things, I do too, mostly the Gas add treatment. My Dad used it in all his machines too, way back in the 40's and 50's when we used to run a sawmill in Southeast Georgia. I was only 4 or 5 years old when I was introduced to it. We had our share of break downs but they weren't usually from the engines we ran. I remember when my brothers bought the old sawmill from Dad they used the same old Red Seal power unit flat head 6 cylinder, gas ) that ran the mill originally. That was some 20 years later. After a little cleaning and adjusting the old thing could be hand cranked in one throw. It came with a built in crank handle just like the old Model As. I remember being so small that I could hang on to the crank and it would only move as the compression leaked down. Man to me that was a long time ago. The old place we grow up is a car lot and a mall now. I used to fly my U- control plane where the mall parking lot is. Listen to me rattle on. We were talking about planes. I hope that one day we can all met from time to time. It can happen. So many stories to tell and so little time to tell them. Later FIREHAWK PS Bill is the Castrol you use a TCW-3 or a TC oil? -----Original Message----- From: WVarnes(at)aol.com <WVarnes(at)aol.com> Date: Thursday, November 26, 1998 11:00 AM Subject: Re: Kolb-List: Engine vibration-The answer is:carbon ? > >michael.highsmith(at)worldnet.att.net writes: > ><< Hey Bill, Well, being you cleaned your prop but it's a wood prop, when did > it get wet or when was the last time a front came through your place or did > you leave the prop vertical the last time you flew before you noticed the > vibration? It's funny how one answer can lead to a whole lot more questions > ain't it? >> > >Hi Michael, > >I know what you mean about moisture in the prop. I fold the wings for storage >after each flight and the prop is always placed horizontal, so it shouldn't >get out of balance from that. Besides, balance was one of the first things I >checked. I just might take you up on the suggestion of using Pennzoil. I had >originally started using that oil, then the Castrol became easier to get >locally, and its a good oil, but maybe it is part of my problem. Trouble is, >if I change too many things, I'll never know for sure which made the >difference, if any change at all. And it takes at least 40 maybe 50 hours >before a decarbon is needed. I had about 60 when I noticed the problem. > ><> > >Well I'm sort of retired, so I fly about twice a week, depending on the >weather. First year, 1994 I only flew 30 hrs. Since then averaging about 70 >hrs per year, and now have 305 hrs. on it. I'd even fly more often, but I >have to drive 35 miles to the airport. That takes 1 hr each way due to >traffic and back roads. Then it takes me 1/2 hr to set up, fuel up ,etc. >Then another 1/2 to tear down and clean up, etc, So I usually don't go unless >I can fly at least one hour or longer. Been on several cross country trips of >1-1/2 hrs. each way. > >Thanks for your input FIREHAWK. > >Bill Varnes >Audubon NJ >Original FireStar 377 > > ________________________________________________________________________________
Date: Nov 26, 1998
Hey Jerry , My brother had a relief valve that use to come on the little 185-9.5 HP Rotax, break off and go through the top end. It did the same thing by imprinting itself all over the piston top and the bottom of the head. He did the same thing that Gene did. It ran another 400 hours before he finally stopped flying for medical problems. He has the little engine that could. FIREHAWK -----Original Message----- From: Jerry Bidle <jbidle(at)airmail.net> Date: Thursday, November 26, 1998 2:30 PM Subject: Kolb-List: Sudden Engine Noise - better take a closer look > >Here's a little thing that happen to one of the guys on our field as >described by my partner. > >They had a fly in the area on one of the most beautiful days I've seen in a >long time. Crisp with radiant blue sky, little wind and I had to leave on >a flight that afternoon so couldn't attend. My partner flew our FireFly in >and had a great day. > >Gene, one of our buddies on the field missed out on the fly in. Seems he >suddenly developed noise in his engine (a 447). Later found >out that one of the brand new spark plugs had broken off some porcelain near >the electrode. Put a new plug in and the noise went away for a little >while. He ended up pulling the cylinder and found the broken hunk of >porcelain in the cylinder. It had beaten up the piston top, which he >smoothed with a dremel tool. He's ready now to test fly it. > >Talk about luck. > >Jerry Bidle > > ________________________________________________________________________________
Subject: Re: Tailwheel rod replacement
Date: Nov 26, 1998
Hey Ron, The last time I checked a steel drill still cuts epoxy better than steel. So go for the steel drill deal. Should take it right out without harming the tube. FIREHAWK. -----Original Message----- From: Ron Carroll <ron.carroll(at)worldnet.att.net> Date: Thursday, November 26, 1998 12:17 PM Subject: Kolb-List: Tailwheel rod replacement > >When I built my Original Firestar I wasn't aware of the aluminum replacement >for the fiberglass tailwheel rod. However, now that I am flying it I see >that the replacement is needed because the tailwheel flexes sideways when >turning. > >My question to the group is: What is the best way to remove the epoxied-in >fiberglass rod? Naturally, I don't want to damage the lower fin in doing >so. The use of heat is out of the question so I assume I'll have to cut off >the rod near the lower fin and drill a pilot hole as close to center as I >can. Then follow that with progressively larger drills. Is there some >other way? > >Thanks, > >Ron Carroll >Original Firestar > > ________________________________________________________________________________
From: "Frank, Christie & Frank Hodson" <fchodson(at)bigfoot.com>
Subject: Torque For Engine Mounts...
Date: Nov 26, 1998
Happy Thanksgiving everyone... I happily spent it with my family in Maine...skipped the football this year to help my dad install a 503 Rotax on his FireStar II project (he's dreaming that he will fly it before snow arrives!! It would be a safer bet to put the 503 into his snowmobile!!) We ran into a few questions...There is no suggestion on what to torque the nuts to on the aluminum plate that attaches to the crankcase, or the bolts/nuts that go through the Lord Mounts. I read all pertinent material a thousand times and I couldn't find any #'s...So has everyone else just tightened it all up until you feel like it will stay connected in flight, or is there some magical ft/lb # that we should be aiming for? I'm a silent reader in this email list...but all of your tips/helps and "banter" are all appreciated. Franklin E. Hodson III fchodson@bigfoot.com | http://www.bigfoot.com/~fchodson OR http://members.tripod.com/fchodson ________________________________________________________________________________
Date: Nov 26, 1998
Subject: Re: Torque For Engine Mounts...
For torque on regular nuts and bolts (steel on steel) you can look in a good repair manual (such as chiltons, or for you engineers out there, "Machinery Handbook") and it will have recommended torque tables. Remember, a bolt and nut is actually a clamping device, so the torque is specified to obtain the maximum practical clamping force without straining the bolt shaft (or threads) beyond the yield point of the particular alloy. For accurate work, oil threads before torqueing. Paige Straley ________________________________________________________________________________
Date: Nov 26, 1998
Ron, I replaced mine years ago by taking a propane torch and very carefully heating it up and then using a vise grips to twist it and pull it out. My lower fin did get burned a little, so I had to repatch and repaint it but it will come out with some heat. BTW, I've been flying off the replacement fiberglass rod for about 10 years. Ralph writes: > > >When I built my Original Firestar I wasn't aware of the aluminum >replacement >for the fiberglass tailwheel rod. However, now that I am flying it I >see >that the replacement is needed because the tailwheel flexes sideways >when >turning. > >My question to the group is: What is the best way to remove the >epoxied-in >fiberglass rod? Naturally, I don't want to damage the lower fin in >doing >so. The use of heat is out of the question so I assume I'll have to >cut off >the rod near the lower fin and drill a pilot hole as close to center >as I >can. Then follow that with progressively larger drills. Is there >some >other way? > >Thanks, > >Ron Carroll >Original Firestar > > > > > List Support Contributions: >http://www.matronics.com/contribution > > > ________________________________________________________________________________
Date: Nov 26, 1998
> >For accurate work, oil >threads before torqueing. > >Paige Straley > You shouldn't oil threads before torqueing. Every manual or how to book I've seen specifies to torque with dry clean threads. Also--two days ago I had to heli-coil a cylinder tie down stud on an O-200 that had apparently been torqued while oily or over torqued. The original threads just pulled out of the case. Tom King ________________________________________________________________________________
Date: Nov 26, 1998
Talk about a fast response ! ! ! They told me you were a pretty fine feller, now I see it's true. Thank you very much. I think the cartoon is hilarious. Big Lar. Larry Bourne 7 Harrison Cathedral City, CA., 92234 760-324-7646 ---------- > From: bob n <ronoy(at)shentel.net> > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re:Far Side Cartoon > Date: Thursday, November 26, 1998 8:35 AM > > > BIG Lar > > The cartoon is in "Beyond The Far Side," fourth printing (mine) Nov '83, > Lib Congress 83-71765. > > Co-pilot says to Pilot: "Sat...What's a mountain goat doing way up here > in a cloud bank?" > > I'd send you, via FailMail, a cy if you want. Need FM address. Grey > Baron > > > > > > > ________________________________________________________________________________
Date: Nov 26, 1998
Tom, I hate to get argumentive, but I've built quite a few engines, and have always read to " Make sure threads are clean and lightly oiled. Torque to spec with a quality torque wrench." Never, ever had any problems. A small thing to try is to thoroughly clean a head, block, and bolts. Torque one down dry, and focus on how it feels as the pressure comes on. The next one, LIGHTLY oil it with a light oil such as zoom spout, which is a 10 wt non-detergent turbine oil, or 3 in 1. NOT WD-40 ! ! ! Torque it down. You can literally feel the difference. Try it, you'll like it. Big Lar. ---------- > From: Thomas L. King <kingdome(at)tcac.net> > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Torque For Engine Mounts... > Date: Thursday, November 26, 1998 8:54 PM > > > > > >For accurate work, oil > >threads before torqueing. > > > >Paige Straley > > > > You shouldn't oil threads before torqueing. Every manual or how to book > I've seen specifies to torque with dry clean threads. > > Also--two days ago I had to heli-coil a cylinder tie down stud on an O-200 > that had apparently been torqued while oily or over torqued. The original > threads just pulled out of the case. > > Tom King > > > > > > > > ________________________________________________________________________________
Subject: Torque specs
Date: Nov 26, 1998
Hi Group: I forgot to say that oiling threads works well, but the last few engines I've built, I've used Bostick Anti-seize lubricant - lightly. Torques down smoothly and years later comes loose without binding. Works especially well on exhaust manifold bolts. Haven't had any problems I can think of with coming loose prematurely. Big Lar. ________________________________________________________________________________
Subject: 2 stroke motors
Date: Nov 26, 1998
Hi All: For all this time I've been reading engine diagnosis notes with some interest. Most of my experience has been with 4 stroke engines, but for 7 years in Idaho I felled timber with a Stihl 051 AV chain saw. I realize it's not a Rotax, but it is ( was ) a 2 stroke. You may believe me when I say we ran those motors VERY hard. No danger of crashing, just grab the spare saw and fix the 1st one that night. What I remember tallies for the most part with what I read here. One way or another, seems like we spent an awful lot of time fiddling with those little Bing carburetors. ( Bing I think, made in Ireland at any rate ) Probably the second most severe problem is one I don't recall seeing much of here. That is a main seal sucking air, especially the drive side. As it started, the symptoms could drive you crazy, very hard to pin-point. As it worsened, it would get more serious. On a large tree, 4or 5 or more feet thick, which makes for a long, hard pull, it could suck enough air to lean it out, overheat and seize the piston. Also seems like that was about the only time we did seize up. Is this a problem on Rotaxs ?? Or have they figured a way around it ?? Just noodling. Big Lar. ________________________________________________________________________________
Date: Nov 27, 1998
I agree with Larry Biglar about his suggested experiment--try the difference with an oiled thread and a non-oiled thread. One problem is that you can't really de-oil metal without washing it very thoroughly. For the non-oiled test, wash with really hot water and a strong detergent ("Dawn" brand picks up mineral oils best, in my experience), dry with a paper towel and follow with an acetone rinse. There is a difference, and you can measure it! Agree also with Biglar on anti-sieze, especially in high temperature connections where the oil will cook off, and also on steel bolts threading into aluminum. Paige Straley ________________________________________________________________________________
"chuck waller"
Subject: Fw: Tis the season, take a good belt !
Date: Nov 27, 1998
-----Original Message----- From: Samuel Cox <lightflyer(at)email.msn.com> Hempy) ; EPML46A(at)prodigy.com ; ULPilot(at)navix.net ; USUAHQ(at)aol.com ; apsman(at)netheaven.com ; bencole(at)mindspring.com ; capella1(at)flash.net ; dhempy(at)1weather.com ; dvsev(at)aol.com ; knafsngr(at)micron.net ; lclem(at)erols.com ; lightflyer(at)email.msn.com ; lindy(at)snowhill.com; ; fly-ul ; Ultralight Flying Magazine Date: Tuesday, November 24, 1998 10:18 PM Subject: Tis the season, take a good belt ! > Tis the Season, Take a Good Belt! > One of the things that I notice at fly-ins is that many ultralights do >not have shoulder >harnesses installed and some that do have them installed improperly. Even >in the
