Kolb-Archive.digest.vol-bt
October 30, 1999 - November 18, 1999
GeoR38(at)aol.com wrote:
> In a message dated 10/29/99 2:59:54 AM Eastern Daylight Time,
> motavia(at)olypen.com writes:
> << I guess if it makes you feel
> better, go ahead. 3000+ hrs without them says they are not needed. When
> I check the tourque every 50 hours, it is ALWAYS stable (after the first
> few flights). >>
> whoa!!....what does that mean Mike, during the first few flights after
> torquing it is NOT stable...... I'm glad to hear that you have 3000 hrs
> without locknuts though....my mere 100 hrs sans nuts is paltry......i just
> can't figure out WHY, without any locknut the bolts just don't back out with
> the regular vibration.....got any idea? All I do is paint a little fingernail
> polish on the bolts and check the paint before each flight....for some DUMB
> reason they NEVER backout..... but .....that's the way IVO wants it....
> GeoR38
Subject: | Re: Rate Of Climb Meters |
I agree with you Richard, ROC, is very important in the decision process and
I have found myself in situations just like you mention--ROC tells the story
--will I clear those tress, mountains, clouds whatever. JR
Subject: | Re: Control Hinges |
Cavuontop(at)aol.com wrote:
> In a message dated 99-10-26 1:41:52 PM Eastern Daylight Time,
> rbaker2(at)juno.com writes:
> << Do I paint the control surface hinges before riveting them in place? >>
> I painted my hinges completely before installation with DuPont Centauri.
> Stitts polytone paint doesn't stick well to metal.
To get good adhesion one has to use the procedure specified in the
PolyFiber manual as to preparation of the metal surface. Will then
stick fine. However, PolyTone is not intended for hard surfaces and is
relatively easily scratched if used on metal.
I have heard of this DuPont Centauri, and understand it works very
well. This is much simpler than the above mentioned process, and would
be particularly good for small projects.
gil leiter
MAPLEWOOD, MN
Subject: | RE: electrical problem |
>Did you happen to notice the ammeter while in the air. If it is showing a
>high rate of charge after a 'lap' or two around the pattern, then I'd look
>at your battery. A dying battery will pull a lot of current from the
>alternator. If this is the case, then all the current from the alternator
>will heat up the circuit breaker until it trips.
Batteries with a shorted cell change from a 12v to a 10v battery
and will indeed draw lots of extra current while being "charged"
from a 14v bus. Shorted cells result from a pile-up of flakey,
conductive material shed from the plates . . . which normally
fall harmlessly to the bottom of the cell cavity. Back in the
good ol' days, a deep pile of this flakey stuff would get too
deep and short a cell. There are a few, even more rare failure
modes of the separators between plates that can produce shorted
cells. Shorted cells in modern flooded batteries is extremely
rare and you woul notice it immediately in poor cranking performance
and dim lights with the alternator off. Further, a battery with
a shorted cell is likely to be so old that its useful service
life is long since passed.
Most (99.99%) of battery failures manifest themselves in poor
cranking performance and what appears to be a very rapid recharge
time after the engine starts. The time and amplitude of ammeter
"charge" indication after startup is directly related to the
battery's capacity and internal resistance. As capacity goes
down, resitance goes up and apparent charging time and amplitude
will both go down too.
In the instance under discussion, I don't belive this is the case.
>A friend of mine replaced the left position light after crunching into a
>hanger door. Got the part from the same make and model year complete with
>lamp. Flew several months before going at night. After that flight, he
>noticed the circuit breaker for the nav lights had tripped. Reset the
>breaker and thought nothing of it until the next flight. 'POP'
>He asked me to look into it. We pulled the wingtip and looked for chaffed
>wires; nothing. Looked at the holder, clean. Then looked at the lamp.
>Nothing note worthy. Looked at the right side. Nothing out of the
>ordinary their either.
>Then I noticed something; then left lamp was a 26 watt lamp. The right was
>a 20 watt lamp. Assuming that all nav lights were 20 watts in a 12 volt
>airplane, that makes 5 amps. The nav light breaker is a 5 amp breaker. Add
>6 watts to the mix and you 5.5 amps.
>The circuit breaker would not pop right away. It took about 15 minutes for
>it to get hot enough to trip.
The breaker was undersized . . . the minimum breaker size for nav
lites in a 14v airplane is 7.5 amps. Breakers and wiring used
to plumb the system should be selected with enough headroom
to INSURE NO NUISANCE TRIPS . . . I've written before about
breakers designed to nuisance trip in the form of a 60A breaker
on a 60A alternator . . . the writer has just identified another
one.
(o o)
===========o00o=(_)=o00o=========
< Independence Kansas: the >
< Jurassic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
http://www.aeroelectric.com
In a message dated 10/30/99 12:08:44 AM Eastern Daylight Time,
swidersk(at)digital.net writes:
<< The fact that I hesitated & felt confused for a few seconds
made me doubt myself later. Here is the point of all this: If I had my ROC
meter installed I would not have had an information gap to begin with as I
would
have been clearly monitoring my climb rate from lift off, & there would of
been
no surprises to deal with when I got to that go-no-go decision point. From
that
day forward, I never again considered a ROC meter just a toy. I now see it
as
an instrument that greatly enhances my ability to make critical decisions in
the
spur of the moment. For the benifits it provides me, I can not justify not
having one.
...Richard Swiderski
> In a message dated 10/29/99 3:12:17 AM Eastern Daylight Time,
> Tim.Hrib(at)carefirst.com writes:
> << i think it would be a waste to buy one. same for rate of
> climb indicator, their really unneccesary in an ultralight. >>
> as a former soaring pilot, the second most important instrument to me
(maybe
> third) would be the rate of climb indicator. I love to soar my ul and do it
> whenever there is natural lift! I don't have one but some day I will get a
> variometer!.............. GeoR38
> different strokes ....different folks
Richard....Good story.....been there ....done that too...ie, the moment of
decision....or indecision....as ....sometimes happens....So far, I've been
lucky and always made the right decision, but my good flying buddy Harris,
didn't just a coupla weeks ago.
Some of you may remember that I made a 100 mile 3 legged trip in his N3 Pup
(nice plane) and delivered it to his house by air from Barnesville Ohio to
Bristolville Ohio a coupla years ago.
Well, there will be no more N3 pup to blame "underpowered" on anymore!!
He did very close to what you just described, Richard, only he bought the big
one...or at least the N3 did. It was the first time he ever landed at a
different field from his own (I wasn't there at the time) and on takeoff, he
had to decide to stick with it or abort. He stuck with it too long and ended
up seeing that he wasn't going to make the power lines on the other side of
the paved country road and turned about 45 degrees as he was stalling in and
impacted a ditch first which sheared off his 2 gear as he went sailing on to
the pavement in a shower of sparks and toothpicks as his new prop went from
54 to 6 inches in a losing battle with the asphalt....bounced across the road
at 45 degrees and hit the high ditch on the other side ...his wing hit a
parked pickup and broke a bit of the rear end of it. Now N3 is chrome moly
too and Harris ,my friend the pilot, got out and had not a scratch....in
spite of the fact that one wing was broken off, , the empannage was
disconnected, the fuselage was mangled...except for the cage part or at least
the part where he was.
He was very very lucky!! What happened?? No one really knows, except for the
fact that he was following 2 other uls out of there and may have been
suffering from vortex....it was also a crosswind day and there was a treeline
which probably caused down swirling as he was trying to rise in a 1/2 vw
underpowered airplane when compared to a 447 and a Kolb. We Kolb people are
very fortunate to be powered by minimum 447's. We have the opportunity to
have our own way so to speak with mother nature...up to a reasonable point.
It has been 3 weeks now and I offered him a chance to hop mine yesterday,
which he did and his response was...."your plane is easy to fly!" I need to
stress on him the need to let the plane fly instead of snow plow...which I
think is one of his main problems and may explain why he no longer has a
plane. If he had looked at the variometer (which he didn't have anyway) he
would have seen that he was in stall and should have dropped his nose.
GeoR38
Subject: | Re:Rate Of Climb/Vortex |
> GeoR38
George brings up a good point that I have not seen discussed on the list so
far, and that is vortex from other U/L's. All of us are aware of wake
turbulence from large and heavy aircraft, (or we should be), but Skyhawks,
Cherokees, and even flutterbugs lay down a surprising amount of vortex.
Next time you go flying with another U/L, get 300-500' behind it, and a tad
lower, and find his wake, and play with it for a while. Then picture
finding it by surprise just after rotating on take off, or else while you
are in the flare to land. Just food for thought.
Richard Pike
MKIII N420P (42OldPoops)
Richard, I was making an X TO at VNY in '66 in my old 172. A V Bonanza
had just passed on TO when I taxied onto the rnwy and put the cobs to
'er. I was at gross, maybe more, hot August day. I was just airborne
when I had a 60 roll left, and soon a 60 to the right--at abt 50' I
didn't think a banana could do that, but it did. A UL would've inverted.
bn
Re-posted per Matt's suggeston,
--------- Forwarded message ----------
Date: Sun, 31 Oct 1999 22:32:16 -0500
Subject: Re: Kolb-List: Control Hinges
Gil,
After your and other inputs, I decided that Poly-Tone was not the right
finish for metal parts so, I removed the fuselage tube from the cage and
spent several hours with MEK removing the Poly-Tone (not a lot of fun).
Epoxy primer held up well, but I wet sanded with 400 and then applied
another coat of primer followed with Centauri. I am much happier with
the finish and am now back to where I was 2 weeks ago.
L. Ray Baker
Lake Butler, Fl
Building Mark III, SN 312--N629RB
> is
> would
> gil leiter
> MAPLEWOOD, MN
> Kolb-List:
Subject: | Re: FireFly Speed |
Bruce,
I weigh between 200-205 lbs and am 6ft.3in. My rpms at cruise speed of 55-60
mph were between 5100-5200 rpms. The only rpm area i had to stay out of due
to high temps was between 4,000-4,800rpms.
Any more questions, call,
allen
Subject: | FireFly S/N 08 SOLD |
FireFly S/N 08 was sold on 10/30/99.
From: | "Wally Hofmann" <whofmann(at)eudoramail.com> |
Over the weekend I mounted my voltage regulator below where the fabric sling seat
will be installed. Then I got to thinking... Why the huge cooling fins on
the regulator?
How hot does this baby get? Could it melt the fabric, brand my derriere, and send
me crashing in a ball of flames?
Wally Hofmann
Join 18 million Eudora users by signing up for a free Eudora Web-Mail account at http://www.eudoramail.com
From: | "Bruce E. Harrison" <beharrison(at)lexhealth.org> |
Subject: | Tommy & Carolyn(at)centurytel.net |
Hello Tommy from Louisiana--I have tried to reply to your e-mail but there
must be an error with your e-mail address. Please try again.
Bruce E. Harrison
Wally,
How hot does this baby get? I would say that heat is directly proportional
to the amount of load put on the regulator/rectifier.
Could it melt the fabric, brand my derriere? Don't know.
Send me crashing in a ball of flames? I hope not.
However, as an Aviation Electronics Technician for 29 years, I would suggest
NOT putting it under the seat. Mine is located on the port side of the
engine below the engine shock mount area---plenty of air flows across the
cooling fins and as a side benefit it has a very short wire run from the
Eng. coil outputs to the regulator. Just my .02 worth.
Dennis (Original Firestar)
----- Original Message -----
Sent: Monday, November 01, 1999 11:59 AM
Subject: Kolb-List: Hot Seat ?
sling seat will be installed. Then I got to thinking... Why the huge
cooling fins on the regulator?
and send me crashing in a ball of flames?
> Wally Hofmann
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
I have read about the painting of the boom tube here lately (Ray Baker?)
and had a couple of questions about it. I am famaliar with Dupont Centauri
paint (painted a '71 Karmann Ghia with it about 10 years ago) but wasn't
sure about the primer. Does Dupont sell a Epoxy primer that will withstand
MEK or should I just buy the primer from the Millers (Aircraft Tech.). I
should have bought the primer from the Millers before the Kolb fly-in as
they offered to bring it in their truck and avoid all shipping costs , but I
didn't at the time. Now if I can buy it locally I would rather 'cause I'm
sure having it shipped would be expensive due to hazardous materials fees...
Any ideas???
One other question...What extent did most of you guys go to with the
corrosion protection??? I am having all steel parts powder coated , and I
will epoxy prime and paint the boom tube . What about the insides of the
aluminum surfaces??? The Millers recommended epoxy priming it after
building as a precaution but I wanted the opinion of the list on that area.
If I am going to due that then I will need to slosh the insides of the wing
spars when I do the boom tube in a couple of weeks. As a note here , I
intend to put the plane on a mono float in a couple of years (maybe sooner)
and want it to be protected (but not overkill cause paint has weight...).
What think guys??? John Hauck , your opinion? I figure yours has been all
over in about every kind of enviroment and it's not rusted away , so what
did you do???
Jeremy Casey
Mark 3 under const.
Getting to first solo cross country soon in a C-152...(Hope to not get
lost...)
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Subject: | Re: Dupont paint |
When mine is complete, (soon now, I hope) I plan to treat all the inside
areas with "Corrosion X" or similar. Weighs almost nothing, and is
re-newable. ( Re Do-able ?? ) Big Lar.
Sent: Monday, November 01, 1999 12:45 PM
Subject: Kolb-List: Dupont paint
What is Corrosion X and where can I get some?
Bruce E. Harrison
-----Original Message-----
Sent: Monday, November 01, 1999 3:49 PM
Subject: Re: Kolb-List: Dupont paint
> did you do???
> Jeremy Casey
Jeremy and Gang:
On a very wet Monday afternoon, I pray for sunshine.
So far so good on my MK III. I hear a lot of talk about
outside, but not much inside. One of the first things I do
is put tube seal inside the fuselage tubes, the 4130 cage.
I have been using a can (qt) of Stitts Tube seal since
1984. On the can are directions for amount in CCs per
length of a given diameter tube. I did the Ultrastar,
Firestar, and the MK III. I cut up the fuselage of the
Ultrastar to examine the results, when it was retired. Tube
seal works. No matter how well a joint is welded, it is
likely pin holes exist. Moisture gets in and rust starts.
Tube seal will take care of preventing rust and seal up any
small holes. Also a positive indicator that a weld or tube
has cracked.
I poured epoxy primer inside small parts that were made of
4130 tubing, dumped it out and let it drain and dry.
Aluminum, I didn't try and protect. So far, I do not have
any problems. I do have drain holes at each rib on wings,
ailerons, and elevators. Also holes in trailing edge of
horizontal and vertical stabilizers. I think this helps to
reduce condensation and corrosion of the aluminum parts.
In a float plane environment, especially salt water, I think
max corrosion protection would be advisable.
I have found some dissimilar corrosion on the aluminum lift
strut fairing where I mounted the nickel plated pitot/static
system. Not a structural problem now, but it does look
ugly. Other than that, my MK III is is good shape,
considering it has spent many days outside in the weather.
However, not a lot around salt water.
You'll see ads for it in the flying mags, such as Flying, Nov '99, page 132.
(www.corrosionx.com). It's apparently a kind of wax, dissolved in a
solvent. You spray it inside the wings, etc. "AFTER" all covering and
painting is completed. The solvent carries it into all the little nooks and
crannies, under rivet heads etc., then evaporates, leaving a waxy coating.
I've read good things about it. Lar.
From: Bruce E. Harrison <beharrison(at)lexhealth.org>
Sent: Monday, November 01, 1999 1:18 PM
Subject: RE: Kolb-List: Dupont paint
> Bruce E. Harrison
> To: kolb-list(at)matronics.com
> From: Jeremy Casey <jrcasey(at)mindspring.com>
> To:
I
the
In a message dated 11/1/99 4:41:15 PM Eastern Daylight Time,
jrcasey(at)mindspring.com writes:
<< One other question...What extent did most of you guys go to with the
corrosion protection??? >>
I have recovered a couple of Kolbs, one of them an ultrastar that was
kept semi outdoors for about 10 years. When I pulled the cover off I was
struck by how generally good the aluminum looked. But there was significant
corrosion on the rivet heads and some evidence of aluminum corrosion around
the rivets. When I put my mark 3 together I dipped each individual rivet in
epoxy primer and pulled it wet. Then I would take the remainder of the small
batch of primer and just brush it around. It looks kinda sloppy, but how
many folks look inside your wings?
I didn't bother with the insides of pipes. I had no plans to put my
plane on floats. If I did, especially if it was salt water, I would have
done the insides.
Subject: | Re: Tommy & Carolyn(at)centurytel.net |
Hi, Tommy. I, too have tried to reply to you directly without success. I
have a FS I
and live in SC.
Howard Shackleford
FS I
SC
Subject: | The H section and rivets |
Hi all,
Tim T. here
I am building a mark III and when installing the H section in the wing spar
I noticed
that the H section did not have the six inch reinforcement thick walled tube
in it.
The book says to use 1/2 inch rivets there but the plans does not show this
tube in the H section and calls for 1/8 rivets there. My wings are almost
finished
but this still bugs me.... any thoughts.
second,
Does the little ball in the end of the rivet need to stay in the end after
setting the rivet??
On the drag strut, the three inch spaced rivets at the root end with the
last tube
involved, the 1/2 inch rivets popped out the end balls. Is this a problem or
should I
drill them out and set a longer rivet??
Thanks for reading
Our Best
Tim T.
From: | Dennis & Diane Kirby <kirbyd(at)flash.net> |
Subject: | Vertical Speed Indicator |
Kolb Gang -
Very interesting recent thread on VSIs - to have 'em or not.
Here's another opinion in favor of the instrument, and why:
Flying out of Albuquerque (elev 5380' msl), we have the 10,300' Sandia
Peaks right next to town - a long, constantly sloping ridge, rising from
the local terrain level (about 6000') right up to the Peak. Lots of
great ridge-lift on that piece of geography. (Home of the Sandia Peak
Summer Classic Hang Glider Championships - considered among the top
three best soaring locations in N.America.) And not reserved for just
the hang gliders, either. Little airplanes of all sorts fly along the
Sandia ridge to catch all that 'free lift' and play amongst the updrafts
and sheer cliffs, with always the safety of lower terrain and the
airport right there under one wingtip. I used to do 'ridge flying'
often in my chubby old TriPacer-135 (which was sold to finance my
current Mark-3 project. Good trade.) I'd sometimes see a 2000 fpm rate
of climb ... while already above 11,000 feet! In a TriPacer! So the
point of this bit of rambling is, I'm gonna have a VSI in my finished
Mark-3 because there are few things that match the exhilaration of
seeing (and feeling) 2000 fpm UP registering on a VSI while flying along
at 12,000 feet, above these magnificent mountains.
Dennis Kirby
Mark-3, s/n 300, 75% finished (and itchin' to finish up!)
Cedar Crest, NM
Subject: | Re: The H section and rivets |
From what I remember about that stage of construction, the book gets a
little confusing. There are updates, without removing the old stuff. Also,
you'll want to read ALL of the material sent to you before you build. Some
stuff is scattered here and there, and it's irksome to do a stage, then find
an update, or alternative, later on. Correlate the plans and the books too.
Go through it piece by piece. (Hmmmmm.......... the book says this, and the
plans show that........! ! !) All in all it works real well, and it's a
hell of a plane, but nobody's perfect. That thick walled tube, and
1/2" rivets are for the old aluminum ( I think ) re-inforcement. Doesn't
apply to the newer steel H-beam. These rivets aren't designed to
hold the core after popping. Some will hold it, some won't. I think if you
get a good "mushroom", you'll be in good shape. I've been giving
some thought to using Cherry N or Q rivets for the wing folding attachments
on the ends of the spars, with washers on the inside. Seems like that would
be a high shear application, and those rivets DO hold the core. I'll
bet this gets some of them pawing the dirt. Big Lar.
Sent: Monday, November 01, 1999 6:29 PM
Subject: Kolb-List: The H section and rivets
> Hi all,
> Tim T. here
spar
> I noticed
>Kolb trailer for sale. Enclosed trailer 24' 11" inside, 8'wide 6' 4"
>tall. Steel frame, wood covered. It has a hydraulic ram with a 12 volt
>motor, that you hookup to your battery. It will push up the front of
>trailer, and lower the rear to the ground, for easy loading and unloading.
>It's licensed,and ready to go. I used it to hanger the Firestar, and is
big
>enough, to walk around and work on the plane. For more info e-mail, or
call
>Mike (559-332-2064) Price $ 2500.00
Subject: | LRI Group Buy and Donation to Matt |
Listers,
Jim Huntington has contacted me and expressed his desire to make a donation
to Matt for the RV-List and has asked me if I would run another group buy
on the list and make the following offer:
The usual group buy offer is $670 for the analog LRI unit and $72 for
heater and $20 for shipping which reflects a savings of $123 or 14% over
the usual prices and shipping. Of course as usual the heater would be
optional. If you want the new gauge that was posted on Paul Besing's
webpage at:
http://members.home.net/rv8er/copperst.htm
The cost would be $750 plus the optional heater and shipping described
above. Again this reflects a $123 dollar savings for the whole package.
Now the part about the list contribution Jim would like to make. He will
give 5% of total LRI sales to Matt during this group buy. If we buy 5 or 10
LRI's during this month it can add up to a nice donation. The RV-List is
the only place you can get a discount on the LRI!
Now I know that there has been some controversy about this instrument on
the list but this is not the time to rekindle that thread. Suffice it to
say that Jim is puting together some information and data that was
requested and also has some other testing in the works that he will
announce soon. So let's not look a gift horse in the mouth or bite the hand
that feeds us. You should know if you want an LRI or any other AOA device
and this would be a great time to buy one. I am just thrilled that Jim is
willing to donate to the list in the spirit of "The Builders Bookstore" and
"AAMR/AirCore".
You can contact me at: prober(at)iwaynet.net or (614) 890-6301 if you
have any questions or want to get in on this group buy. Sorry this is so
long.........AL
From: | "Jim Miller" <jim(at)aircrafttechsupport.com> |
Subject: | Hazardous shipping.... |
If we send you quarts or less of anything, (as we are certified to do)
there is no hazardous shipping cost imposed by UPS.
The reason builders choose Polytone for their metal pieces is to get an
exact color and shine match with the fabric. If you want a harder finish,
impervious to fuels, etc, you should use Aerothane. And if you don't want
the "wet look", it can be flattened.
Thanx,
Jim & Dondi Miller
Aircraft Technical Support, Inc.
Poly-Fiber & Ceconite Distributors
(Toll Free) (877) 877-3334
Web Site: www.aircrafttechsupport.com
E-mail: info(at)aircrafttechsupport.com
I mounted my voltage regulator over the weekend. Placed it under where the fabric
sling seat will be installed. Then I got to wondering about those massive
cooling fins on the regulator.
Just how hot does this baby get? Is it going to melt the fabric, brand my derriere,
and send me plumeting to earth in a ball of fire?
--Wally Hofmann
Subject: | Re: Vertical Speed Indicator |
In a message dated 11/2/99 12:05:14 AM Eastern Standard Time,
kirbyd(at)flash.net writes:
<< I'd sometimes see a 2000 fpm rate
Dennis Kirby
Cedar Crest, NM
Dennis, I know the power of 1000'/min but 2000.....Whew.....far out....I
learned soaring in Las Cruzes and El paso in the early 80's and love it...so
I relate...and try to become a part of a rising gaggle whenever the
opportunity.....arises! ..................... GeoR38
From: | "Jeff.Teismann" <JeffTeismann(at)email.msn.com> |
Subject: | Re: Kolb-List Digest: 10/29/99 |
Bruce,
I hesitated to respond to your request because you were looking for airspeed
and rpm at full throttle, which I have only flown at for short periods on
just a couple of occasions. The reason is that with the short FireFly
windshield, the wind blast becomes uncomfortable at high speeds. However,
since you haven't received many other responses, I thought I'd offer my
limited experience:
Normal cruise: 55 mph indicated air speed @ 5,000-5,200 rpm.
Full throttle: 70-75 mph at 6,000 rpm
Notes:
1. Fortunately my airspeed indicator tracks fairly well with my GPS, but
I've never collected data using windspeeds, etc.
2. Actual full throttle for me is about 6,150 rpm static and about 6,300 in
the air, but I'm only at full throttle on take-off. I've never been above
6,000 rpm on straight and level.
3. My FireFly is about 256 lbs. empty, then add 175 lbs. for me, plus gas,
carry-on stuff, etc. and gross wt. is probably about 465-470 lbs.
Jeff
30 hrs. in FireFly
PS: I'm working on putting a full enclosure on this wonderful flying machine
for some cool/cold weather flying. With the full enclosure I expect I'll do
more flying at the higher speeds. If I get any new data results soon I'll
pass them on.
____
> From: "Bruce McElhoe" <brucem(at)theworks.com>
> Subject: Re: Kolb-List: FireFly Speed
> Fellow Kolbians:
> Can someone tell me the cruise speed and rpm for his Kolb FireFly?
> My partner and I are building a standard FireFly with the Rotax 477, and
we
> hope to keep it at standard weight, 254 lbs. We are having a 3-blade
> propeller carved for us. The prop guy wants to know what our airspeed and
> rpm will be at full throttle and low altitude. (We wouldn't expect to
> actually cruise at full throttle, but this is the data point he uses for
> prop design.)
> We sure would appreciate any real experience you all are getting. Your
data
> will allow us to get the prop carved right away.
> Bruce McElhoe FireFly #88
> Reedley, California
Jeff,
Many thanks for your response to my question about Firefly cruise speed and
rpm. This will help us a lot with prop design.
Perhaps you or others on this list could answer this question about Rotax
engines: Is it usual to operate the Rotax engine at 5000 to 5200 rpm in
cruise? Larger aircraft engines (Lycoming and Continental) specify in their
engine specifications that normal cruise is at 65 to 75 percent of rated
power. I have not seen the same guideline printed in Rotax specifications.
In fact, I have seen no recommendation at all for cruise rpm. The
specifications do say red-line is 6800 rpm.
Does anyone have a suggestion on a good cruise rpm, considering fuel
efficiency and engine wear?
From: Jeff.Teismann <JeffTeismann(at)email.msn.com>
> Jeff
> 30 hrs. in FireFly
Subject: | Re: : Kolb-List:strut camera |
Hi guys,
I hope to mount my 35mm camera to the strut of my firestar. Will the
vibration spoil the pictures? This camera-a Canon AE1 has a fast shutter
speed,1000.With 100 speed film will the pictures be blurry? Any input would
be appreciated.
thanks,
John Bruzan FS2 18.6 hr Chicago
>Jeff,
>cruise?
No not IMHO, unless you want to decarb you engine every 50 hours.
I would suggest you get an ajustable propeller.
Warp drive 1st choice. Ivo, maybe 2nd.
Wood props are not ajustable, and not fixable if they are cut wrong.
I have two hanging on the wall that don't have 10 hours on them.
We use to go through this same thing in the mid 80's when they were not any
"good"
composite props. Just my opinion.
From: | "Gary Thacker" <gbthacker(at)hotmail.com> |
The faster the shutter speed the better. If it were me I would try faster
film. This will only be better if your shutter speeds will go over 1000
though. If you could shock mount the camera a bit that will help a lot.
There is a difference in a buzzin type of vibration and a pulsating kinda
thing. The faster the shutter speed the better the photo in a movement
situation. Larger lens openings will allow faster shutter speeds. In
photos taken past 30 feet put the focus on infinity and just shoot away.
After 30 feet on most lenses focus really doesn't matter as long as it's on
infinity. I would be more concerned about the damage to the camera and the
light sensing equipment in it. That kinda stuff can be the end for cameras.
Gary
>From: Bruzan3(at)aol.com
>Reply-To: kolb-list(at)matronics.com
>Subject: Re: Kolb-List:strut camera
>Date: Tue, 2 Nov 1999 22:47:52 EST
>Hi guys,
>be appreciated.
>thanks,
In a message dated 11/2/99 11:02:16 PM Eastern Standard Time,
possums(at)mindspring.com writes:
<< No not IMHO, unless you want to decarb you engine every 50 hours. >>
Hey, Possum! Are you saying that cruise RPM on a 503DCDI should be higher
than 5200? That's where my FS I with 3 blade Warp loves to run.
Howard Shackleford
FS I
SC
> Dennis Kirby
A point to ponder...
Have you considered the possibility of a Variometer over a VLS?????
It's much faster in action. While your VLS is starting to reach toward the
limits of your actions, the Vario has already reached it...
Most gliders use the Vario for this reason.
Doc
little confusing.
Larry,
The book, plans and tech sheets sent with my kit did not say anything about
them changing the H section from aluminum to steel and show the removal
of the thick wall 6 inch tube in the H section. Your knowing this does put
my
mind to rest about it being missing form my steel wing spar H sections.
Thanks. I just used 1/8 rivets in the center. The rivet thing still hangs in
there.
If the rivet is long enough the end ball will remain, strengthening its pull
out
resistance (I think). I might be worrying about nothing but has any one
considered this?? I am not a straight and level flyer so strength is my
first
concern.
Our Best
Tim T.
tailwind-list(at)matronics.com, lancair-list(at)matronics.com
Subject: | Digital Compass... |
Hi Listers,
I was thumbing through the latest Jameco catalog this evening and happened
across a pretty slick instrument that would seem to be a prefect fit for
your basic homebuilt project, if you know what I mean... ;-) Precision
Navigation Inc. now produces a nifty Electronic Compass Module that, at least
according to the write up, seems like it would work well in an aircraft.
They even mention installations in "RV"s in the application notes, although
I think they are probably referring to the road hogging, stinky diesel
burning variety...
Anyway, I've listed a couple of URL below that give lots of information on
the unit. I'm thinking this could replace either the wet or vertical card
compass in a typical VFR installation? Seems like with a GPS backup, you'd
have plenty of 'directional navigation'. Would the FAA inspector give the
nod? Comments and thought's???
The only bummer is that it doesn't have backlighting, which is just a
plain-old poor-design decision in my opinion.
Glossy Promo
http://www.precisionnavigation.com/navifindermain.html
Brief Feature List
http://www.precisionnavigation.com/navifinder.pdf
Installation and Application Notes:
http://www.precisionnavigation.com/nav_manual101.pdf
Oh, and did I mention its only $75? Yeah, unbelievable. Oh, but they do
have an aircraft version for $3000...
Mild Mannered List Admin. by Day,
Wild Rivet Pounder by Night!
(Well, some nights anyway...)
The following is not my humble opinion- it is a well documented fact:
The Rotax engine was NOT designed to run at 5200 rpm. It HAS to run at
or near 6000 rpm, and somewhere close to 1100 egt to stay clean, and
protect the bearings. At 5200, you are lugging the engine. This is hard
on bearings, builds carbon, and is below the power curve.
We run our flight school engines at 5900 to 6100 cruise. They always go
to TBO without any decarbs, (or repairs of any kind for the most part),
and when torn down for a new crank installation, they rerely need
anything else. We install new seals and wrist pin bearings, hone the
cylinders, and install new rings. Thats it.
Slow running engines are on the bench being decarbed all the time, and
remember that after the carbon gets bad enough, a seizure is right
around the corner.
Why cant you just fly faster?
Otherwise, get a smaller engine. Bet you dont hear that too often, but
you are better off with a smaller engine running at optimum rpm that
with a big engine that is lugging.
Olympic Ultralights
BTDT
Mike, can you provide the documentation to support the need to run the
engine at 6000 rpm for cruise? Running at 5200 doesn't always mean you are
lugging the engine ..... depends on throttle position ( which depends on
prop pitch and other factors ). Just curious. Thanks, Michael
Tim and others,
This past winter when I was installing the H sections in the main spars,
I called the factory about the H section being all 1 thickness as opposed
to 2 as described in the book. I was informed that they had gone to a
heavier steel tubing for the H frame making the dual thickness for a
portion of it unnecessary.
L. Ray Baker
Lake Butler, Fl
writes:
> gets a
> little confusing.
> Larry,
> anything about
> removal
> does put
> my
> sections.
> hangs in
> there.
> its pull
> out
> one
> is my
> first
> concern.
> Our Best
> Tim T.
> Kolb-List:
Yes, Ray, this applies to multiple quart shipments........
Jim & Dondi Miller
Subject: | Re: KOLB TRAILER |
Sent: Tuesday, November 02, 1999 4:14 AM
Subject: Kolb-List: KOLB TRAILER
unloading.
> big
> call
Mike--is your trailer big enough to handle a Mark III?
thanks,
Subject: | Maul type wheel pants |
Does anyone have photos of the Maul-type wheel pant that does not fully
enclose the wheel but adds a fender above and a fariing behind the wheel?
Or does anyone know where on the web I could look for such a picture? I
have heard of these and wish to see a picture to consider if they would be
appropriate for the MKiii.
Thanks.
Jim G
Subject: | Re: Digital Compass... |
Strange ??? I didn't get anything but 2 blank pages. Anyone else ??
Big Lar.
Sent: Tuesday, November 02, 1999 11:07 PM
Subject: Kolb-List: Digital Compass...
> Hi Listers,
least
although
> burning variety...
you'd
> Glossy Promo
> Brief Feature List
> Matt Dralle
Pop rivets are designed for shear loads, not tension. That's why I
mentioned the "Q" rivets, that retain the mandrel. Take a look at all the
stress points; you'll see what I mean. My feeling, not documented, is that
under heavy load the rivets might tend to "walk" a bit in the soft aluminum.
That's why I mentioned putting washers under the Q's. Stainless washers, of
course. With that in mind, I did put washers under the horizontal tail
mounts on the tail boom. The Kolb is designed very tough, I doubt if you'll
have to worry about pulling any rivets - short of some really insane G
loads - in which case something else will probably break anyway. At one
point they took a Kolb, either Ultrastar or Firestar, I'm not sure, and
TRIED to break it, by yanking it out of steep dives. It was almost
impossible, but he finally managed to break the wing spar. So, they
increased the strength of that and related components, and that's what we're
getting the benefit of now. Very rugged planes. Big Lar.
Sent: Tuesday, November 02, 1999 10:08 PM
> little confusing.
> Larry,
about
> my
in
> there.
pull
> out
Subject: | OKAY LET'S GET DOWN TO THE FACTS |
Fact#1 You are reading this!
Fact#2 You probably haven't made your LIST CONTRIBUTION yet!
Fact#3 If you have done Fact #1 and Fact #2 still applies then technically
you are a FREE-LOADER!
Now I know that you probably don't consider yourself a free-loader. Your
neighbor probably doesn't even consider you a free-loader. You have always
paid for everything you ever received. You are a hard worker. You are even
building your own airplane and you paid for every piece of it yourself
right? Well there is still a not so small piece that you probably haven't
paid for yet. (At least not this year) You know that there is at least one
thing that you learned from "The List" that saved you some time, money, or
even embarrassment.(Or in some cases may have caused you embarrassment if
you didn't check the return address!) Any of these things have value and
you should realize the value that the "The List" has for you. Think about
it. For once we have a resource that you aren't getting forced to pay a fee
for. Matt doesn't force anyone to pay for this service to be a part of it.
He TRUSTS us to do our part. What's it worth to you? A buck a month? Two
bucks a month? Three bucks a month?? Now's your chance to thank Matt and
let him know how much you appreciate what he is doing for us. Look at it
like a great interactive aviation magazine that you determine the
subscription price of. NOW is the time to get it done. Just click on the
URL below and have your credit card ready or write that check and get it in
the mail today! After all once it's done you are....
NO LONGER A FREE-LOADER!
To make a SSL Secure Web Contribution using your Visa or MasterCard, have a
look at the following URL:
http://www.matronics.com/contribution.html
To make a Contribution by check, please send US Mail to:
c/o Matt Dralle
Matronics
PO Box 347
Livermore, CA 94551
Well now I have to go clean out all the exploded mice out of my
shop.........AL
(And you say you never learned anything from the list....)
At one
Big Lar and Kolbers:
Let me help you out a little.
When Dennis Souder was very young and adventurous, he
decided to test the Ultrastar, in flight, to destruction.
Figured that would give the Kolb R&D Dept a better picture
of their product than using sand bags. In this case sand
bags probably would not have found the weakness. He did not
break the wing spar, but the left wing drag strut. His buns
were saved by a Jim Handberry, Hand Deployed Parachute.
Lucky for me, I was getting ready to cover the wings of my
Ultra Star when they developed and started shipping the drag
strut braces.
Wanted to clarify that it was not the 5 inch main spar, but
the drag strut that failed. I do not know of anyone who has
been able to cause a main spar to fail in flight. Some have
failed after they tried to fly through utility poles, wind
sock towers, trees, buildings, etc.
Subject: | Test to destruction |
List,
I watched the video of that flight just the other night. It was added at the
end of one of the earlier promo videos. I have been told that Kolb stopped
adding it to the promo's cause they didn't want anyone to get the impression
that the Kolb was capable of aerobatics. It doesn't show the actual
destruction but what it does show is really neat to watch. I know that I
will never even come close to putting my Firestar through the maneuvers that
Dennis S. did on that video.
Dennis in MD.
Sent: Wednesday, November 03, 1999 9:40 AM
Subject: Re: Kolb-List: The H section and rivets
> At one
we're
> strut braces.
> john h
Subject: | Re: Kolb-List Digest: 11/02/99 |
In a message dated 11/3/99 1:58:55 AM Central Standard Time,
kolb-list-digest(at)matronics.com writes:
> Hi guys,
would
> be appreciated.
> thanks,
I don't know abut your struts but mine vibrate pretty good under power. I
shoot pictures out of my Mk2 also but I shoot in the conventional
manner.....(that is..looking through the viewfinder)with good results. Of
course with the (essentially) side mounted stick that I have in the Mk2 all I
have to do is hold the stick with my knee while shooting. I think you'll
get better pictures if you are looking through the viewfinder when you shoot
them. I would, however, love to mount a digital movie camera somewhere so
that I can share my flying experience with some of my friends online.
Steve Kroll Mk2 76hrs
Use a wide angle lens--24m or less. JR
I completed my FireFly in July, 1999 and now have 48 hr. flying on it.
Like Jeff, I haven't flown it at top RPM, only on take off. RPM during take off
is about 6,300. My speed is the same as his, 50 - 55 at 5,000 - 5,200. I'm
swinging the Tennessee two blade 66" prop supplied through Kolb.. I find my
must comfortable cruise speed to be around 5,500 to 5,600 RPM. As Jeff
mentioned, the air buffeting gets a bit much over that speed.
I get great fuel economy with this prop and everyone says it sounds like a GA
plane from the ground. Seems they don't recognize me as a typical ultralight
sound when approaching. I'm am considering putting vortex strips on the prop
also. Any comments on this everone?
Wait till you get to fly this beauty. It's everything advertised and more!
Terry K. FireFly # 95
Quarryville, PA
Bruce McElhoe wrote:
> Fellow Kolbians:
> My partner and I are building a standard FireFly with the Rotax 447, and we
> prop design.)
> We sure would appreciate any real experience you all are getting. Your data
> Reedley, California
Ok. I expected to get jumped when I said "documented", and was not
dissapointed, so will be a bit more careful about that word.
The "well documented" I refer to is over 3000 of my own flying hours,
cruising at 5900 to 6100, with a max level full throttle rpm of not more
than 6400-6450. I am not alone in this. Most experienced Rotax Repair
stations will back me on this.
Reg in Surry BC, was THE Rotax GURU up until his stroke a few years ago
forced him to retire. He had been racing two strokes on carts since the
50`s, and had forgotten more about 2 strokes than you and I will ever
learn. The main thing he tried to get accross to us newbie repair
station guys, was that you could run them too slow, and too fast. Each
engine has its own sweet-spot, where power/efficiency/reliability come
together. He was very adament about this. He rebuilt more engines for
ultralighter`s that the two "well known" rebuilders in the USA combined.
Over 40 years of Reg`s experience was good enough for this newbie in
1993, and it is still on the mark as far as I, and many other high time
U/L pilots are concerned.
I am no GURU, (and in fact, I dont like that word, as too many self
proclaimed experts with little experience attach it to themselves) but I
repair lots of engines that are damaged more by OPERATOR ERROR than
those that are just plain worn out.
Probably 75 percent of repair/rebuilds we do are from lowtime pilots
and people that decided they had a better way of doing it, or were
trying to save gas, or be "nice" to their engine.
There are very few engine failures that can be attributed to faulty
parts produced by Rotax. This will undoubtedly get some people irate,
but if you look for the true cause of the failure, it will more often
than not be related to 1) Poor maintenance practices
2) Operator inexperience- this catagory includes
bad fuel, lousey oil, crummy props, removing
the aircleaners to make it "run better", ect.
3) Not running/flying the engine often enough.
4) Not learning from the experiences of the
"old guy`s" which is usually free.
Ask around to the people that fly for a living, those that rebuild
Rotaxes, those that have been doing it for years, and you will get the
same story (for the most part).
I have nothing to gain(or lose)by passing on my experience, other than
maybe keeping a couple people from wasting the potential of their
engine.
One thing that is a fact: There will ALWAYS be a few people that have to
do it their way. They keep us repair centers in business.
Mike Brown
Olympic Ultralights
Subject: | Re: 6000 RPM--long |
In a message dated 11/3/1999 9:37:05 AM Pacific Standard Time,
JRWillJR(at)aol.com writes:
<< Subj: Re: Kolb-List: 6000 RPM--long
Date: 11/3/1999 9:37:05 AM Pacific Standard Time
Sender: owner-kolb-list-server(at)matronics.com
A>
I tend to agree also that two stroke engines should be run in their top RPM
band to prevent carboning and longest life. If you are jetted out for
continuous ops at 5200 however it should not be to much worse if any. There
is an old saying that two stroke engines like to be run hard--some people
take that as a license to justify flogging the little buggers to death. It
is
true that Rotax recommends a cruise RPM of 5600-6200 and that the ground
static should be 6200 and that max level flight RPM should be 6700-6800. If
not your engine--cannot make maximum power, will over rev or lugg
depending.
One indication that you are way over pitched is that the engine will tend to
be rich and non responsive to jetting changes--if you do not have to change
jets from summer to winter this is an indication you are over propped. Some
people like to over prop thinking that they will set a cruise pitch--like
over drive in a car--thus not having to run their engines so hard. Fact is
if
you make, say, 60 MPH at 5400 RPM but your ground static is only 5800 for
example you are over propped and are lugging the engine badly. You will not
be able to pull max rated power because the engine will not be able to turn
the required RPM to do so. It takes the same amount of horsepower to push
your airplane at 60 MPH regardless of whether you are pitched for 5400 or
6000 at that 60 MPH level flight. Combustion pressure will be higher with
the
lower RPM and more damaging--because you are pulling the same power from the
engine but at different RPM, more power must then be produced per cycle.
People in Rotax circles sometimes equate their power to RPM thus running a
lower RPM must be less harmful to the engine--sorry no free ride. The Rotax
horsepower chart assumes the engine is propped per their
recommendations--when it is then you can get horsepower per RPM off the
chart--when you are not pitched per the specs then you cannot. If we were
dealing with a four stroke we would install a manifold pressure gauge as a
more useful means of setting power--that is why aircraft with cs props
require them--power setting is a result of RPM, prop pitch and fuel flow
which will be indicated via the manifold pressure. Two-stroke engines
unfortunately do not get useful info from a manifold pressure gauge so we
must resort to other means--a fuel flow gauge would be indicative but out of
place in a Kolb. Best thing to do then is set your engine and prop and
aircraft combination up as closely to the recommendations of 6200 ground
static and 6800 max level and then set RPM to produce a reasonable airspeed
of 55 or 60 what ever that RPM might be not to exceed say 6200 or so
continuously and jet out accordingly to get proper EGT and CHT. Your engine
will be better off, produce more power and your take off, climb and max
speeds will be the optimal compromise. xx xxx xxxxxxx. JR, A&P
Sent: Wednesday, November 03, 1999 8:56 AM
Subject: Re: Kolb-List: Digital Compass...
> Big Lar.
> From: Matt Dralle <dralle(at)matronics.com>
> To: ; ;
> > Hi Listers,
happened
> least
> although
> > burning variety...
on
card
> you'd
the
> > Glossy Promo
> > Brief Feature List
do
> > Matt Dralle
> >> Two-stroke engines unfortunately do not get useful info from a manifold
> pressure gauge so we must resort to other means--a fuel flow gauge would be
> place in a Kolb. <<
Listers,
I believe it was the late Molt Taylor, who was dealing with this very issue.
He was attempting to adjust an inflight adjustable prop on a 2-stroke and make
comparisons with other pitch & rpm settings and its effect on fuel consuption.
He needed the load to be constant so he used a pressure gauge in the exhaust
manifold to maintain it. He used a gauge that read in inches of water. An old
airspeed indicator would probably do fine. ...Richard
Swiderski
Sent: Wednesday, November 03, 1999 12:10 PM
Subject: Re: Kolb-List: 6000 RPM
are
Mike, Thanks for the info. I'm also one of those Authorized Rotax Repair
Stations ( which can mean a little or a lot ).I do a lot of teaching to the
people who bring me engines. It' been a long time since I've found a rotax
part that failed wholly because of poor design ( with the exception of the
rotary valve seals in the 532/582 ). Poor maintenance and/or lack of
information were usually the main cause. I'm sure I don't do nearly the
number of engines you do and I can't imagine the good fortune to have had a
mentor like your Reg. That's one of the reasons I enjoy the postings on
this list. I don't always agree with the answers but if you read long enough
you can sift out the answers based on knowledge and experience and those
that just sound good Cheers, Michael
Subject: | Re: Prop Variations |
GA
> also. Any comments on this everone?<<<
Terry,
I inlayed antivortex tips into my ground adjustable 3 blade (and it was wood,
Possum ) Precision Propellor, used .032" 6061-T6, bent it with a 1/4" radius,
epoxied it with JB Weld, & also used 3 SS flush-taper-headed bolts. I got a 12%
increase in static thrust, 12% increase in rate of climb, 12% icrease in fuel
economy & could fly the same cruise speed with about 12 % less rpm, plus it was
a
lot quieter. I didn't measure the before & after db levels. That was on my
UltraStar with a 50" prop. Later, I went to a 60" prop & got an all around 10%
increase as did my buddy who put them on his 60" prop on a gyro.
....Richard Swiderski
Subject: | Flight test to failure |
To All,
Here is part of the article from Dennis Souder.
The second phase of testing consisted of performing basic aerobatic
maneuvers. The UltraStar was tested extensively doing hundreds of loops,
snap rolls, and spins. Whip stalls were preformed at angles up to and
including the vertical (bordering on a tail slide). Typical entry speed for
a loop was 70.75 mph (shallow dive with full power) which produced an
average G-load of 4 1/4 G's at the bottom when exiting the loop. Thus the
limit load of 4 G's was easily substantiated.
Not satisfied by just substantiating our claims, we wanted to determine how
strong the UltraStar really was, and also to determine what speeds would be
required to achieve the higher G-loads. Even having done many loops in the
70-75 mph range, it was a little exciting to achieve the 80 mph + speeds
needed to push the G-meter up to 5 G's (the perceived effect of increasing
speed is not a linear function). To obtain 5 1/2 G's required a full power
dive at approximately a 40 degree angle below the horizon. The 5 1/2 G's
was of much longer duration than typical loops performed at 4 to 4 1/2 G's.
Incidentally, this 90 mph dive and the 5 1/2 G pullout was an exciting ride
even for one accustomed to performing ultralight aerobatics.
At this point, we felt that the UltraStar had been well proven to be as
strong as anything in its class would ever be required to be. There is just
no way that any pilot would ever accidentally get into such a high speed
dive situation (to which would have to be added an abrupt pull out) to get
into such a high G-loading situation. But it was decided to do one more
test to 95 mph. An abrupt and sustained pullout at this speed resulted in
structural failure of the left wing; the drag strut failed and the wing
folded back alongside the fuselage.
The parachute was deployed, and the plane and pilot were brought down
safely. A very gentle (but exciting) landing in a tree resulted in minimal
additional damage to the airplane. The only in-flight damage to the
UltraStar was the left wing which had remained neatly in its folded position
during the decent into the tree. The left wing has since been replaced and
the Ultrastar is once more happily looping and rolling its way through the
sky. The failure showed that the weakest link in the wing to be the drag
strut. In the last high G maneuver it appears that the wing rib in the area
of the center of the drag strut deformed slightly, enough to push the drag
strut out of column, which resulted in a buckling of the drag strut. A steel
brace has sense been added to reinforce the wing rib in this area, (This is
now included as standard in the UltraStar, FireStar and TwinStar), Since the
UltraStar had proven to be as strong as necessary, we did not feel it
necessary to test beyond that point to see what additional strength the
reinforcement would provide.
Hope you enjoyed
Our Best
Tim T.
Thanks for your reply, you have been a great help.
Our Best
Tim T.
Sent: Wednesday, November 03, 1999 8:13 AM
that
aluminum.
of
you'll
we're
> From: T. Townsend <townsend(at)webound.com>
> To:
> > little confusing.
> > Larry,
> about
put
> > my
hangs
> in
> > there.
> pull
> > out
In a message dated 11/3/99 12:14:46 AM Eastern Standard Time, irena(at)ccis.com
writes:
> Dennis Kirby
Doc >>
thanks Doc, I didn't even know the difference...variometer is the only
instrument I ever heard of and is what I'll probably get anyway as a result
of my glider days and ....yes....they were very responsive! ............
GeoR38
Subject: | Re: Flight test to failure |
Sorry about that. I thought it was the spar that had failed.
Red-Faced Lar.
Sent: Wednesday, November 03, 1999 5:29 PM
Subject: Kolb-List: Flight test to failure
> To All,
just
Thanks everyone,
I am now confident that my wings are very strong and I am building it right.
Our Best
Tim T.
Sent: Wednesday, November 03, 1999 6:48 AM
> Tim and others,
> L. Ray Baker
> Lake Butler, Fl
> writes:
> > gets a
> > little confusing.
> > Larry,
> > anything about
> > removal
> > does put
> > my
> > sections.
> > hangs in
> > there.
> > its pull
> > out
> > one
> > is my
> > first
> > concern.
> > Our Best
> > Tim T.
> > Kolb-List:
I am a photojournalist and do a lot of aviation photography besides flying. I
have mounted cameras on all kinds of airplanes, many ultralights and many
others. I have mounted it on all of my airplanes and have some wonderful
photos, some things about mounting the camera I have learned.
I always mount the camera with either a bogen multi clamp, or a home made
mount using brackets I have made. The mount on the cameras are a regular 1/4
-20 thread so making a mount is easy, I always also undo the camera strap and
rap it around some part of the airplane and reattach it to the camera, use
lots of duct tape to tape the strap down also to keep it from moving in the
wind and causing the wind to turn the camera. Triggering the camera is with a
hard line, (ie the new cameras that use a switch instead of an old cable
release, or I use a radio trigger. The hard line is better, one less thing
hanging in the wind.
The lens choice is according to where the camera is mounted, ie how far out
on the wing and how wide of a lens is needed to get the framing you want. I
usually use a 14mm which on Firestar 2 mounted near the end of the strut
makes a photo showing all the nose and tail.
Exposure can be set to automatic, or usually I set it manually, exposing for
a sunny photo and I make sure to fly so the sun illuminates my face, cockpit,
etc. I also find that a steep turn banked towards the ground makes more of an
interesting photo than blue skies. Unless you are on top of broken clouds,
etc., or upside down in some of my aerobatic photos.
2 more things, use gaffers tape (expensive duct tape) and tape down the
aperture ring, and focus ring. Another thing I have found is that on fast
aircraft, you must completely tape up the camera to keep the wind/pressures
from the camera. The pressure differences on the back film plane is what
makes the photos not sharp, not the vibration. I usually shoot at 500/th
second which will stop everything fine. I once did a shot on a Pitts, and all
the images where he was pulling g's were out of focus. The pressure caused
the back of the camera and film plane to move slightly, causing all the
photos to be blurry, I have lived and learned.
I have a lot of these photo I would be glad to email if anybody is interested
to take a peek. Lots of my Ultralights including my firestar 2.
Sorry for rambling, but I love this kind of photography and have done this
set up for most of my friends so they have awesome photos for their walls.
tim
Subject: | Re: WD40 and Powder Coating |
My gosh, look for Kolbs falling out of the air. Haven't seem any yet.
Chrome Moly been used in airplanes for a long time and for many years was
only gas welded which means it gets very hot. Some manufacturers
(certified airplane) even heat treat their engine mounts to reduce stress
caused from welding and cooling. This means getting it dull red hot and
cooling it down slowly. I think it will take the temps it would be exposed
to in the powder coating process.
Only problem I see with power coating is if you prang it and have to weld
on it you have to burn off the existing powder coating the in area being
welded. Since the plane may not be totally disassembled, you would have to
live with a good epoxy primer and top coating. So just don't prang it.
Our FireFly has been running with a good coat of Stits epoxy primer. Only
problem with it is it changes to a cream color over time. Put a top coat
over it.
Aggressive sand blasting is likely to cause more damage. Make sure your
coater understands that the tubing is very thin wall and not to use
excessively coarse grit. Some of these palaces are used to doing thick
automotive cages and headers and can get carried away.
So for it,
jerryb
I like the powder coating but Kolb price is just that pricey. Check for
local source.
>Hello Gang:
> Got a question I would like to know if any of you have experienced. I
>plan on having my fuselage cage and all other metal parts powdered coated at
>a local shop. I have been bead blasting the small metal parts and then
>spraying them with wd40 to prevent them from rusting till I get ready to
>carry them to the shop. I thought (first mistake) that the solution that the
>parts are dipped in before powder coating would clean them well enough. I
>have since talked to the shop owner about this and he says that the wd40
>won't come off properly in the dipping stage. Does anyone know what the best
>way to clean wd40 off is. I tried lacquer thinner and it seems to work, but
>you really can't tell for sure. Any suggestions would be appreciated.
> One other thing I would like to know is about powder coating the
>fuselage tube. I know Kolb powder coats them from the factory but, the guy
>that owns M-Squared ultralights says that the heating stage of the powder
>coating process (approx 400 degrees) will kill the strength of the tube.
>What gives? Is he wrong or is there different ways to powder coat?
>Thanks,
>John Cooley
>building FS II
Hey Mike.
Yes, Reg was a crusty ol fart, but dang he was good with a two stroke.
He used to say the only time he ever screwed up on a rebuild was when I
took my first 582 to him and he broke his hard and fast rule of never
letting the customer watch or help during a "for real rebuild", and let
me watch(and help). Well, he (and I)forgot to tourque the flywheel, and
the proverbial poop hit the fan when I started it up.
Actually, I dont do too many rebuilds anymore. There just isnt much
money in it, and I get pissed when they take em out and run them out of
oil or water. Just part of the game I know, but I guess I`m getting
old. Too many years in the Coast Guard trying to do PERFECT work, and
now people look at you funny and say yer being anal because perfect work
isnt important in the 90`s.
Do you ever wonder about the guy that brags about having 27 forced
landings without a bent plane, then you ask him how many hours he has
flown, and he says something like ... "25"!!!!!! ?????
OK, back to lurk.
do mot archive
> are
Subject: | Re: Hazardous shipping.... |
Is there any extra precautions you have to take spraying areothane's? I
have heard that anything with "thane" on the end you better have air
supply. The story goes after your done your get a beer and sit down and
watch the game on TV and your gone before the games over.
>Thanx,
>Jim & Dondi Miller
We got a 2-1/4" electric variometer in our FireFly and our Hawk. I love
it. The variometer is the same thing they use in gliders and it very
sensitive. Were running 1K/ft/Min. Sold my Sky Sports - Cost varies from
$240-260. There are available for connection to 12 volt electrical system
or equipped with a 9-volt battery holder for those that don't have
electrical systems like gliders.
jerryb
> Dennis Kirby
> Cedar Crest, NM
There was one written up a while back that some one was using in plane and
found to be very accurate and dependable. They were having problems with
magnetic interference with a whiskey compass and tried it as a last resort.
Cost was reasonable and worked well. Anybody happen to see the write up
and recall what it was in.
jerryb
>Hi Listers,
>burning variety...
>Glossy Promo
>Brief Feature List
>Matt Dralle
Mike,
Don't be to hard on your self, after all, your kind is what made this sport
what
it is to day. I will have another beer with you and go back to lurk also.
Our Best
Tim T.
Sent: Wednesday, November 03, 1999 11:23 PM
> Hey Mike.
> OK, back to lurk.
> Mike
> do mot archive
the
you
> > are
depends on
the
rotax
the
had a
enough
Hey Jerry,
The subject we were warning about the temps involved in powder coating
was the tail tube, not the cage. The gage can handle all the heat of
powder coating no problemo`. It`s the tail tube that should not be put
to heat. That would be risky at best.
Powder coating is starting to get some hard looks from airplane
manufacturers as it is hard, and does not have much flex to it, so it
can crack with the flexing of the airframe, letting corrosion in at the
weld joints where it flexes(and where you DONT want corrosion).
Something to consider.
Any airframes I do from now on will be painted, and even that paint will
have a touch of flexative in it. It also helps prevent nicks and chips a
bit better than hard paint.
> over it.
> So for it,
> jerryb
> local source.
> >Hello Gang:
> >Thanks,
> >John Cooley
> >building FS II
Subject: | Re: mounted camera |
Tim--I would like to see some of your pics. JR
I have a bunch of stuff I need to get rid of. E-mail me if you need more
info.
Sky-West David 60 hp 4-stroke engine
Several 3-blade Warp Drive props
Several 3-blade Powerfin props
Rotax 532 with B drive
VSI
Cheers, Michael
You're absolutely right about the fresh air breathing source!!
PS: baseball or soccer?
Jim & Dondi Miller
Sent: Thursday, November 04, 1999 12:38 AM
Subject: Re: Kolb-List: Hazardous shipping....
Subject: | Kolb: Hard Starting |
I recently experienced another spell of hard starting on my FireFly's 447 and
as previously reported used a quick shot of starter fluid. I knew this stuff
was volatile and had no lubrication so I was careful to use a minimal amount.
The engine started and ran great but this was a test, not something I would
do as a standard procedure. After reviewing the possibilities I concluded
that my trouble might be the result of using old fuel. I have always kept a
spare 5 gallons on hand, (sitting in a steel building, under the broiling
Florida summer sun) while busy with other obligations. The fuel already in
the tank also sat for a week or so before I used it. I now realize that
keeping gas on hand during periods of infrequent flying amounts to aging
(degrading) it before use. The mix in the tank was at least a month old,
maybe two. I drained every drop out of the tank, line and carb bowl and
refilled with fresh-from-the-pump 92 octane. I was astonished when she
started on the first pull and has done so on a dozen later occassions. Take
heed fellow bird-men, no more old fuel in my machine!! Duane the plane in
Tallahassee
From: | "Ron C Reece" <rcreec(at)ftw.rsc.raytheon.com> |
Subject: | Re: Kolb: Hard Starting |
MitchMnD(at)aol.com on 11/04/99 09:32:30 AM
Please respond to kolb-list(at)matronics.com
Subject: Kolb-List: Kolb: Hard Starting
I was wondering if one used an additive ( can't recall a name for it, but used
to keep fuel good over long periods of time) when storing fuel if that would
keep fuel in a good enough condition for flying?
Ron Reece
Tail done
L. Wing done
>Take heed fellow bird-men, no more old fuel in my machine!! Duane the plane
in
>Tallahassee
Subject: | Painting Fuselage |
Mornin Kolbers:
I always paint fuselage. I use Stitts Aerothane. The
aerothane goes on after tube seal inside the tubes, prep
with phosphoric acid etch and Scotch Brite Pads, 2 part
epoxy primer, and finally aerothane. I try to use light
colored primer to avoid changing the final color of the
aerothane.
Lot of work but had done a good job over the years.
Subject: | Fuel & galvanized pipe |
Hi Gang,
I am in the process of rigging a fuel caddy to fuel my Mk-3. To facilitate
connection of a Goldenrod filter I had to use a two galvanized reducers and
couplers. Total length of the galvanized parts is around 8 inches. The rest
of the parts are plastic and brass and the nozzle is aluminum.
Is there any problem with using galvanized material with gasoline?
Bill George
Mk-3 582 Powerfin
From: | "Brian Hale" <AccessToData(at)email.msn.com> |
Mike Brown, if you run your engine at these rpm's, doesn't fuel consumption
go way up? I have a Firestar I with a 447. if I run at 5000 rpm, I burn
right around 3 gph. If I go above that then I start to burn considerably
more fuel.
Brian Hale
Firestar I
Sacramento, CA.
Sent: Tuesday, November 02, 1999 11:24 PM
Subject: Re: Kolb-List: Re: Kolb-List Digest: 10/29/99
For my benefit, how do you get tube seal inside the tubes? Do you drill a
tiny pin hole? Also, does this acid etch have a brand name that paint stores
might recognize?
> The
epoxy primer, and finally aerothane. I try to use light>
but used
would
> Ron Reece
> Tail done
> L. Wing done
There is a material called Stabil (spelling) which I believe can be
purchased at WalMart and such places that will stabilize the fuel for
extended storage. I have had no experience with it, but have been told
by various mechanic types that it works well in lawn mowers, chainsaws,
weed trimmers, etc.
Tom
Subject: | Re: Camera mounting |
Hi guys,
shutter
would
be appreciated.
thanks,<<<<<<<<<<
John,
I would be very careful mounting a delicate piece of equipment on a
vibrating airframe.
I rubber mounted a RCA 8mm camcorder to the wing fold fitting on my
right wing, flew it for 10-15 min., AND, it never was the same again!!
(Funny psychedelic colors !!)
Darren Smalec, FS1,104or so hrs., on 3rd engine, 2nd camcorder
Subject: | Re: Painting Fuselage |
> might recognize?
Hi Bruce and Gang:
I use 1/8 hole and closed end alum pop rivets. I get my
supply of large syringes and needles from my Vet. Has the
CCs marked on the syringe to make dosage easier. Many times
tube seal can be injected while building, using a hole meant
for something else other than tube seal.
Naval jelly rust remover is a form of phosphoric acid.
However, I like to use full strength phosphoric acid cut in
half with tap water. Jim and Dondi Miller have it bottled
up with the Poly Fiber logo, I am sure.
Bill, I think that the trailer is big enough, the only question i would
have, would be the the lenth of the plane, when it is folded. Inside the
trailer is 24' 10". Check the lenth, and get back to me. Mike
> From: Bill Davis <csearch(at)nb.net>
> Subject: Re: Kolb-List: KOLB TRAILER
> Date: Wednesday, November 03, 1999 5:42 AM
> From: sk8er <sk8er(at)inreach.com>
> To:
> unloading.
is
> > big
> > call
> thanks,
> Bill
In a message dated 11/4/99 1:07:19 PM Eastern Standard Time,
smald(at)shianet.org writes:
<< Darren Smalec, FS1,104or so hrs., on 3rd engine, 2nd camcorder
Hey, Darren! How come 3 engines in only 104 hrs.?
Howard Shackleford
FS I
SC
> might recognize?
> > The
The procedure of phosphoric acid, followed by chromic acid, followed by
epoxy primer and finish color is for aluminum, and insures good adhesion
to the coatings.
The use of Tube seal was originally developed for welded 4130 tube
fuselages. It's nature is that it will wick through pinholes in the
welds and congel on prolonged contact with the air and seal the holes,
thereby preventing more moisture laden air from entering. It is
installed by drilling 1/8" holes in each independent tube and inserting
the tube seal via a hypodermic syrenge (usually forget the needle as it
is too small for such a viscous liquid). Hole is sealed by use of
closed end pop rivets.
gil leiter
MAPLEWOOD, MN
I'm getting into this a little late, but here are some
of my thoughts anyway...
I have found the best luck in just holding the camera.
There are disadvantages, mostly related to extra care
needed to also fly safely while taking pictures, but
it is do-able. One of the tricks is to get the camera
ready before the shot, and also, you don't have to
hold the camera right up to your eye for the shot.
Get good at it before taking pictures down low, and
even then, especially then, Be Careful! Almost an
aside, I like a 75-150mm zoom and asa 200 film. Nice
additions would be autofocus and motor-drive, but I am
emotionally and financially stuck on my 1972 Olympus
OM-1.
I have experienced getting light leaks in my camera
from vibration, simply by setting it down in the
cockpit for part of a flight, so mounting it to the
airframe without good shock absorption would probably
present similar problems, if not also damage to the
camera over time. I have had interests and minor
experience in mounting a video camera to the airframe.
This again was nixed by vibration, and in this case,
the vibration prevented the camera auto-focus from
locking on an image. Boy would it be nice to have a
helmet-cam like the parachutists. Just think of the
gun footage that would provide. I tried a side mount
to my helmet but that stunk too -- just too darned
awkward to have the side weight, and I didn't want to
add another 3 lbs to the other side to counter
balance; picture helmet squashed down on my head too
far to see where I'm going. :) But I digress. My
main point is that it is nice to hold the camera
simply so you can point it at whatever, and your body
is a good shock absorber for it. A helmet mount would
be even better as it frees your hands, but there's
that durn wing overhead and removing that ain't so
good for pictures or flying.
-Ben Ransom
PS: If you are going to hold the camera, remember
your priorities.
PPS: Many of my flying pics are at:
http://mae.ucdavis.edu/~ransom
> From: Ron C Reece <rcreec(at)ftw.rsc.raytheon.com>
> > Ron Reece
> > Tail done
> > L. Wing done
> weed trimmers, etc.
> Tom
I used to have frequent hard starting due to old fuel, especially in the
winter months when they add "stuff" to it. Sometimes it would be bad in
less than a month. I don't remember having a hard start problem due to
fuel since I switched to avgas about 18 months ago. More expensive and
you have to check your plugs more frequently due to lead deposits, but
it sure saves on the arm, not too mention the headaches when the *!#@$
thing just will not start!!
* Bill Weber * Thunder's just the noise *
* Simi Valley, CA * Lightning does the work *
Subject: | Kolb-list: trim question |
Hello kolb flyers and builders I've bought a firestar 11 the guy I
bought it from weight 150 and had to add some nose weight to get the
C.G. right, but you had to hold some back pressure on the stick. Over
time he took the weight out still had to hold some back pressure.
Now here's where I come in I weight 240 now I'm wanting to get the
plane to trim out a little better I'm holding a lot of back pressure
and it not just at full power at 5000 rpm if you let the stick go its
like going over the hill on a roller coaster.I know the first thing to
do is a weight and balance but if Im in range can I move the front
of the tail down a little or I'm I just going to have to put a trim
tap on it .One more thing how much up do you need in the elevator.
Any help would be apperciate.
George
Subject: | hard starting - comments by an observer |
I don't mean to butt-in, but since you're already
using avblend (100LL, I suppose), I thought I might
mention something to reduce lead-fouling problems.
Personally, I'd remain clear of WalMart Stuff ....
Unless it carries National Backing of well qualified
source. I've seen motor oil and engine fuel
(gasoline) blended at various refineries and -enven
though "they try", the follow-up QualityControl may be
"not risking your life on ....."
I have been putting AVBLEND in my crankcase (TCM 0-200
in a C-150) for years - I fly about 100 hours/year and
have never had any lead deposits problems through the
last three annuals. This is impressive because the
0-200 is a "cool" running engine (i.e., engine doesn't
get hot enough to keep lead vapor from condensing on
it's way down the bore (during combustion) and out the
pipes (during exhaust) .... I know, I know, you're on
a 2-stroke, but keep reading - at least for a little
while, ...... (2) maybe you could locate some 80LL
instead of 100LL ... the lead content would be much
less. (3) there is an additive "PRIEST" -I believe
that is added in oz. quantities to the fuel tanks of a
piper driver I know, and he (as usual ... ) swears by
it ... I rode to FnS '98 and AvVent'99 and engine
never missed a beat.
some thoughts, hope you don't think I'm a butt-in-sky,
and maybe you appreciate me expressing my thoughts.
ps, i'm retired from raytheon, engineering &
construction, Phila area
> > ----- Original Message -----
> > > Ron Reece
> > > Tail done
> > > L. Wing done
> I believe can be
> > weed trimmers, etc.
> > Tom
> it would be bad in
> More expensive and
> lead deposits, but
> of fine Aircraft
> Avionics, and by the generous Contributions of
> List members.
> Matronics:
> Kolb-List:
> Archive Search Engine:
> http://www.matronics.com/search
> Archive Browsing:
> http://www.matronics.com/other
Ben
Good to know you are still lurking. Hope you are making progress on getting
your bird in the air again. The Kolb is an excellent aerial platform. There
was a piece on the Discovery Wings channel about the fellow in New Mexico
that used a no-fairing Mk-2 to shoot spectacular scenics. He did use the gyro
stabilizer though and a Pentax 67.
I have obtained some nice aerials from my MK-3, some with 35 and some with a
high(er) resolution digital. If you don't need anything more that 9X prints
the digitals are actually pretty good. I have done professional video work in
the past and decided I would check the Sony VX-1000 as a hand held in smooth
air. The video is acceptable, but you really need the gyro stab for that kind
of work.
I do have a Pentax 67 and plan to use it the next time winds, light, etc.,
are perfect. My little web page has some shots that were done with a handheld
digital still camera.
George's Kolb Pg.
Bill George
MK-3 582 Powerfin
Bruce,
The FireFly with a 447 should do about 75 to 76 mph full power. That would
have been at about 6600 rpms with wide open throttle. The prop was a
2-blade Ivo 66" dia. The last time I flew that fast I was racing Dick
Rahill (greybeard) who was in the FireStar. It was not a smooth day and the
turbulent air flow around the windshield sucked my glass off when I turned
slightly to see if I was beating him. That was a costly race!
Dennis Souder
-----Original Message-----
Sent: Wednesday, October 27, 1999 10:14 PM
Subject: Kolb-List: FireFly Speed
Fellow Kolbians:
prop design.)
Reedley, California
Bruce,
The speed I had given in my previous email were from memory. I looked it up
and I found the following numbers: 78 mph at full power and the cruise speed
at 6000 rpm was 63 mph. Static rpm was probably around 6400. I don't have
the full power top speed rpms recorded, but they were probably at least 6600
and may be a bit higher.
These were measured with GPS with several averaged runs back and forth over
the same track in relatively calm air. So the numbers are probably pretty
accurate.
A 2-blade wood prop would probably do a bit better for top speed. Ivo's
progressively become more inefficent at higher speeds. I learned this with
careful measuring of the Laser speeds. The IVO is definitely not the way to
go for faster aircraft. (I am refering to the Ivo's normally used on 2
strokes - not the Magnum.) For the speeds of the FireFly, FireStar and
Mark-III, the Ivos are great. For the SlingShot and Laser, the Warp or
wooden prop is a much better selection.
Hope this helps.
Dennis Souder
Hope this helps.
Sent: Thursday, November 04, 1999 9:10 PM
Subject: RE: Kolb-List: FireFly Speed
Bruce,
Dennis Souder
Hi guys,
Thanks for all of the photo feedback I am waiting for the motor drive to
arrive so i don't have to advance the film manually. It is too easy to get
distracted messing with the camera especially at least for a Kolb yearling
such as myself. A friend from the field I fly from made the back cover of
the experimenter this month. His name is Steve Rewolinski. I fly out of
AeroPark in Sussex Wisconsin. They do aero-tows of hangliders (also in the
experimenter magazine) from there.
Bill Genteman does aero-tows in a Mark 3. He has a web site Aero-Wing.com.
Really a great operation.Kolb put a picture of my plane on their website in
their Oshkosh 99 section and it was great to trailer it to the show but
flying in next year will be the ultimate thrill. Or maybe Sun n Fun! EAA
also has a skiplane fly-in i think in January.
Possum Yearling, John Bruzan FS2 18.6hr Chicago
>Hope this helps.
>Dennis Souder
Hey Dennis
you still here I thought you gave up on us.
Woody
Subject: | Re: FireFly Speed |
Dennis,
Many thanks for the data on FireFly speed. Wow!..that's a fast little
machine. Sounds like a good race...bet it got your adrenaline up.
I'm pleased and honored to receive this info from the designer
himself....thanks again.
Reedley, Calif.
would
the
> Dennis Souder
Subject: | Re: Powder Coating |
somebody wrote:
Okay, Gang, now you got me worried.
This recent thread about powder coating the aluminum tailboom, and how
the heat involved in the process could weaken the structure really got
my attention, because MY tailboom is powedercoated. (Airplane, a
Mark-3, is 75% complete. Not flown yet.) This was an option offered by
the Kolb factory when I bought my kit (year and a half ago). I would
like to think that Kolb had done their homework and concluded that a
one-time exposure to 400 degrees F (as happens in the powder coating
process) would not degrade the structural integrity of the 6061 alum.
Otherwise, they wouldn't offer it as an option. Any thoughts?
Dennis Kirby
s/n 300
Cedar Crest, NM
kind
>of work.
Have shot several hours of video out of a Firestar with a helment mounted
"HitachiVM-HL100LA"
Hi-8 Viedo camera. The camera seperates from the monitor and is a 1 1/2
inch cylinder and about 2 1/2 inches long, wieghs about 5 ounces. Can be
mounted on your helment or wing folding bracket (it has 12 ft extension to
the control panel). It also has the image stablizing chip, but the chip
will not take all the vibration out of the viedo unless you damping it
someother way, like mounting it on you helment, or cutting way back on the
RPMS. I mount the 4" monitor and controls on a knee board. The helment has
a LCD bow-sight(deer hunting stuff) that leaves a red dot image in the
center of the frame, kind of like a heads-up display I guess. The Firestar
full enclosure was a great platform for shooting, with a low instrument
panel and no cross bars, doors to get in the way when you are panning
another ultralight across you path. I can't see out of my right eye anyway,
so I usually mount the camera over that side "Robocop" style. Plan on
shooting more with the Possummobile. Kind of pricey, cross between
professional and consumer equipment. More at
<http://www.mindspring.com/~possums/>
Subject: | Re: hard starting - comments by an observer |
Prist is an additive use to control microbial growth in turbine fuel. I
have no idea what effect it would have on gasoline! Here at the local
airport it is mixed at the rate of one gallon of prist to 1,000 gallons
of jet A
Tom
Subject: | Back in the garage |
Howdy Bill,
For awhile, I've barely been even lurking; busy and
somewhat taking a break. I've just started getting
back to my plane. I told an old list friend (Rusty) a
couple weeks ago that I had started to rebuild, but I
was lying ...all I had done was cleaned off my
workbench. So now I've really started. Drilling out
a bunch of rivets, etc. Starting is the hard part.
I've got a lot of respect for all those of you who
have gone back to damaged pride-and-joy and rebuilt
it.
-Ben Ransom
Interesting that you mention Molt Taylors use of an exhaust pressure gauge. I
went to an antique tractor show last Saturday and I saw a beautiful brass
gauge--it was an exhaust pressure gauge. I guess these were used on some old
time tractors. Excellent observation of Molt's experiments and a good idea
you had too. JR
I would have to check on the use of Prist in gasoline aircraft--I am pretty
sure it is approved for use in Turbine fuel only. Why are you wanting to put
Prist in your fuel --it is an antimicrobial additive because of the way water
can remain entrained in jet fuel bacterial growth is a problem. It also helps
reduce freezing of jet fuel systems where the entrained water freezes out on
screens and filters etc. TCP by the way may be used in the Rotax 912 but is a
big NO! in the two-stroke engines. JR
My stock Mkiii folded fits inside my 24' x24' garage (which really measures
23' inside).
Width is 78 inches from outside main wheel to outside main wheel.
Hope this helps...
Jim
Subject: | SOME READING ENTERTAINMENT |
The Hangar Of Rebirth
I have built 3 airplanes now, or is it 5 ?? Therefore, I am wise and
great of expertise and no longer make mistakes. Is that not so ??
Well, there is the odd exception as when I destroyed a simple seat pan by
drilling holes in all the wrong places and compounding that by cutting a
seat belt slot in entirely the wrong place..
I had some sheet stock cut-offs lying around, so I just cut a new one and
set off for my local airport, there to use a shear and bending brake.
Once inside, and my job done in short order, I had time to look around and
talk to the brethren builders and rebuilders, for this was the house of
Beavers reborn.
What a place of wonder, inspiration, admiration and sadness..for here lay
the broken and twisted bodies of several airplanes that once plied the
airways of the world as they were meant to.
Two examples, side by side, were a Beaver badly broken, lying next to one
fully reborn and soon on its way out the door.
When I suggested that the broken ship was a great challenge to rebuild, my
friend said, "not at all,..you should see the two we just finished,..they
were really disasters". But you wouldn't know it now.
I have seen ships that were helicoptered out of Viet Nam, markings still
there , and bullet holes still ripping the skin...Ships shot out of the
skies of Colombia, rescued by men who love this airplane and work to see 50
year old airplanes born again.
On a stand nearby was a radial engine, fresh and clean and new again, going
into a Beaver with a fresh new paint job and glorious in all its new finery.
I understand that some big names like Harrison Ford and Kenny G have had
Beavers rebuilt to the nth degree for them.....seems that others still love
this grand old bird too.
This is a big bird..even on the water, you must climb up stairs to get
aboard,...the prop and cowling stand above your head and you enter a
separate door to get into the front office. Oh ! that I could loose one
from the dock, hit the starter and see that shiny prop tick over and fire up
the radial that shakes itself like a dog coming out of the water, throttle
up, and not being able to hear your co-pilot for the roar as the prop tips
break the barrier of sound, and a rooster tail the size that hydroplanes
make follow us up river until we break free and climb away over the green
ocean.
Thanks to these craftsmen who smile a quiet knowing smile when I cry
about my little boo-boo, these wonderful wrecks are coming back and giving
us the joy of sight and sound of radials and bushplanes, because they aren't
made anymore.
I left the hangar, the smell of oil and gas and paint, the special smell of
airplanes that is a narcotic I am shamelessly addicted to, and drove to the
river to see old/new Beavers plying the waterways and making the sounds I
came to hear...a very nice day in all.
Somewhere out there, in the nether regions of the world, the jungles and
the
war zones, former and present, lie the remains of these birds and others,
and sometimes those who flew them to their end there, the rescuers are
looking for them, looking in earnest, and if they can be found, they will be
returned home from whence they came, and cared for and mended and given life
again.
Wouldn't it be grand if we could do the same for all the lost ones we yearn
to see again ?
Until then, let us remember all, wish them well...and give... Thanksgiving
These musings by Buster are just another one of the many reasons the
RV-List is such a great value. Whether it's technical information, help
with finding something you need, or just reading a neat aviation related
story.....the List has it all! What a great place to spend a few minutes
each day. How about doing your part today?
You will feel much better for it! I know I did.........
c/o Matt Dralle
Matronics
PO Box 347
Livermore, CA 94551
I had a mouse explode in my box of electrical connectors and splatter all
over my digital compass.......now I have to search the archives for a good
aluminum cleaner.......Oh yeah, about the mice coming back as cockroaches,
let's not go there!!!!! AL
From: | "michael highsmith" <firehawk54(at)hotmail.com> |
Subject: | Re: 6000 RPM--long and pressure gauges |
I've been told that pressure gauges will not work on 2 strokes to find the
most power as on a 4 stroke. It has something to do with the pressure wave
moving back and forth in the chamber at different rpms so the probe would be
useless in only one place.?????
Firehawk
>From: JRWillJR(at)aol.com
>Subject: Re: Kolb-List: 6000 RPM--long
>Date: Fri, 5 Nov 1999 03:10:24 EST
>I
>old
>you had too. JR
Mornin Kolbers:
Thought I would share some info on Rotax engines and 100LL.
I got to do quite a bit of 2 stroke XC in the late 80s and 4
stroke XC in the 90s. The only difference, that I know of,
between the 2 stroke then and now is CDI. Wish we had had
that back then. Biggest headache was chasing point gap/ign
timing. If I put a lot of hours on the old point ign 447 in
a short period of time the micarta pivot bushing, not
necessarily rubbing block, would wear making ign timing
impossible. Also had problem with ign coils vibrating loose
in their mounts. See, you guys have it made now with
improved CDI. Now back to the subject.
Always burned 100LL when XC with the 447. Never fouled a
plug, but 447 was run at 5800 to 6200 rpm all day long.
Also, plugs were changed frequently before they had a chance
to lead foul.
In 1994, burned 957 gal of fuel in 41 days, in the 912.
More than 900 gal was 100LL. At aprx 75 hours on a set of
plugs I at least one plug would lead foul. Indication would
be a small thump sparadically in the airframe. A quick mag
check during cruise would verify that it was an ign
problem. Next landing, pull plugs, clean with pin knife,
needle, straight pin, safety wire, blow out, replace and
keep on flying. Never had a plug foul on mo-gas in the
912. Flew a set of plugs in the 912 for 225 plus hours.
Installed new plugs and saw no difference in performance.
Book says change plugs at 100 hour intervals.
As far as I know, 100LL never damaged any of my engines, 2
or 4 stroke. My 912 now has 1,087.3 hours, as of yesterday,
with no problems, to speak of. Will fly this same eng to
Barrow, Alaska, next June, if it will make it. ;-)
In fact, will be flying MK III and 912 just like they were
on the 1994 17,400 mile flight, except for the added hours.
I don't see any performance difference whether burning
mo-gas or 100LL.
Subject: | Re: Rotax and 100LL |
> john h
Sorry Gang:
The above should have been 200 hours plug change interval,
not 100 hours.
Subject: | Protecting steel from corrosion |
Mornin' John!
Poly-Fiber has a new process for steel tubing:
Protect the steel as soon as possible right after blasting within an hour or
two max.
Immediately before priming, (even if you don't blast) wipe bare areas with
Poly-Fiber C-2200 Metal Surface Cleaner, to remove all traces of oil,
grease, and contamination. Wipe dry with a clean rag, NOT a shop towel.
Then prime with Poly-Fiber EP-420 Epoxy Primer.
We found that if you use phosphoric acid etch on steel, you will form a
corrosion (rust) layer right away before you can get a primer on it.
If you have any questions, please don't hesitate to call.
Jim & Dondi Miller
Aircraft Technical Support, Inc.
Poly-Fiber & Ceconite Distributors
(Toll Free) (877) 877-3334
Web Site: www.aircrafttechsupport.com
E-mail: info(at)aircrafttechsupport.com
I was having problems starting my 447 Rotax if it sat for a few weeks
during bad weather. Sometimes as many as 20 pulls on the rope @%*&/
!~`$*. At
Sun-N-Fun a few years ago I bought a plunger type primer and since the motor
starts on tke first pull 95% of the time
I was looking through my stuff that I got with My MKIII rebuild project and
found 12v linear actuator that was used to raise and lower the amphib gear
on the Full Lotus floats. I don't plan on using it and it works well. I also
have the mounting brackets. Anyone interested?
Cheers, Michael
From: | "Scott Olendorf" <olendorf(at)earthlink.net> |
Subject: | Lotus Mono Float |
Hi, anyone have a mono float Lotus FL1000 they want to get rid of? I any
going to put a float on my original model Firestar if I can get enough info
on how to do it. So if anyone has done it, let me know.
Scott Olendorf
Original Firestar, Rotax 377
Schenectady, NY http://members.aol.com/olefiresta
Subject: | Re: Back in the garage |
In a message dated 11/5/99 12:53:12 AM Eastern Standard Time,
bwr000(at)yahoo.com writes:
<< but I
it.
-Ben Ransom >>
Glad to see you back in the thicket again Ben, I particularly miss your
perspicasiousness......bet you didn't even think you had any.....Hah! GeoR38
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Kolb offered it to me as an option too, Dennis, but they wanted way too much
money, so I had mine done locally - 2 1/2 yrs ago. I believed then, and
now, that they had done their homework too. Some time since then we all got
onto a similar thread, and it all came out as OK and approved. I can't
remember now who found what, but I'm sure going to go through it again.
Big Lar.
Sent: Thursday, November 04, 1999 9:05 PM
Subject: Kolb-List: Re: Powder Coating
> to heat. That would be risky at best.>
> Dennis Kirby
> s/n 300
> Cedar Crest, NM
Subject: | Vertical speed in MPH |
List,
This was disturbing to me. I calculated the vertical speeds in MPH.
Not a good thing in down drafts. Have you wondered why it took
you so long to get to 10,000 ft.
Here it is
100 feet per min.......... 1.136 MPH
200 fpm........................ 2.272 MPH
300 fpm........................ 3.409 MPH
400 fpm........................ 4.545 MPH
500 fpm........................ 5.681 MPH
600 fpm........................ 6.818 MPH
700 fpm........................ 7.954 MPH
800 fpm........................ 9.090 MPH
900 fpm........................ 10.227 MPH
1500 fpm...................... 17.045 MPH
2500 fpm...................... 28.409 MPH
4000 fpm...................... 45.454 MPH
10,000 fpm................... 113.636 MPH
50,000 fpm................... 568.181 MPH
200,000 fpm................. 2272.727 MPH
Our Best
Tim T.
A new experience!
Last week it was quite windy up in these parts, but I was anxious to fly and
the wind was directly down the runway. The windsock was indicating anywhere
from 10 to 20, depending when you looked!
I took off and climbed quickly to 1000 feet and realized I was actually
going no where fast. I glanced at the GPS and realized I was only moving at
about 10 mph over the ground with an IAS of 60. SO, I thought, is it
possible.... I reduced the throttle to give a 50 IAS and YES... I hit 0 on
the GPS. And it was so SMOOTH, no bumps, which I woudl normally feel on a
windy day like this.
Just for the heck of it, I stood at 0 mph on the GPS for 10 MINUTES at 1000
AGL with a steady 50 IAS. My airspeed reads about 5 high, so I guess you
could say I had a steady sustained wind hitting me at 45mph!!
Of course, it was important that I had the nose aimed right into the wind to
make this happen, but you know, it kinda wanted to aim that way whether I
liked it or not! It was just so strange to sit above my house without
moving an inch for so long, effortlessly. So this is what a helicopter is
like??!!
I think I appreciate that if I ever take a long Xcountry that its possible
to burn a lot of fuel without making any headway if the destination is in
the wrong direction to a strong wind. But the most difficult part was
circling around and descending for landing.... the wind really played havoc
with the plane esp since going sideways is not natural... but I landed
without incident and wondered just how fast the GPS would have read IF I had
gone full throttle (70 IAS) in the same direction of the wind!
Jon
Greenbay FS 50hrs
>A new experience!
Next time carry up a fishing line & a cold beer and lower it down to your
friends on the ground-always impressed mine.
You must live in Kansas--what you describe is a normal day. I have landed
near verticle with zero wheel roll. JR
Jon you should have slowed down and flown backwards we do it all the time
here on cape cod ,sometimes on purpose sometimes not!! as for flying
sideways not being natural ? it ain't?? christopher d
From: | "Bruce Steinhagen" <bsteinhagen(at)itol.com> |
Jon, I may have been up in the same wind. My top speed (GPS) was 89mph.
> From: Jon Croke <joncroke(at)itol.com>
> To: kolb-list(at)matronics.com
> Subject: Kolb-List: Hovering
> Date: Friday, November 05, 1999 6:30 PM
> A new experience!
and
anywhere
at
on
1000
to
> like??!!
possible
havoc
had
> Jon
> Greenbay FS 50hrs
Subject: | Elevator travel on the MKIII |
Hello everyone,
We've started rigging the tail on our MKIII and have a question
concerning the elevator travel. The book says "9-3/4" up and down travel
minimum. A little more than 9-3/4" is ok, but not too much." We have
more than 9-3/4" both ways and are wondering what some of you have for
travel both directions before we build stops.
Thanks in advance
PaulV
Hey Jon, interesting story, especially for a 50hr FireStar pilot! I've
never got my GPS to show 0 mph although it's been quite low. Flying in
these winds are ok if
it's smooth, but when you come down and try a x-wind landing or get hit
with
all the turbulence off the trees, it does get hairy. I will carry an
extra 10mph on
approach to maintain control. Be sure to get the tail on the ground
before losing
a lot of airspeed so it doesn't go off the runway.
It's definitely too windy to fly when the rudder is at the stops and the
plane wants to go off the runway while taxiing. At a fly-in last year
(Stanton Airfield, MN), I had to ask a volunteer out of the crowd to hold
my upwind wing as I taxied out to the runway. The takeoff roll was all of
5 feet and it was a sloooooow ride home.
Ralph Burlingame
Original FireStar, 12 years flying
>0 on the GPS. And it was so SMOOTH, no bumps, which I woudl normally
feel
>on a windy day like this.
>Jon
> Greenbay FS 50hrs
Subject: | The 'Connection's Website is Down . . . |
Our website server has been down intermittantly for the past
several days. Seems that some folk can access it while others
cannot. When this all started, I was able to access it through
our normal cable-modem service and had FTP access as well. Now
it seems to be down 100%. Trying to find a website service tech
on a weekend is about as difficult and finding your doctor.
I've got several calls working to the local and corporate
support numbers.
(o o)
===========o00o=(_)=o00o=========
< Independence Kansas: the >
< Jurassic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
http://www.aeroelectric.com
From: | Dallas Shepherd <cen23954(at)centuryinter.net> |
John:
I have the Jabiru ordered, but run into a snag when it was found none of
the new ones delivered had the oil plug on the side. Can't change the
oil on a kolb if its on the bottom. Glad they dicovered that. The prop
I'm going to use is a Warp drive two blade tapered,58", ground
adjustable. This is recommended by Pete Krotie of Great Lakes Light
Planes in Wisconsin. I have ordered everything through him. I am also
installing a EIS monitor for the Jabiru. Pete is coming down to install
all of this with me.
He runs a Jabiru on his Titan Tornado, which he sells, and it
really drives that Titan. Cruise is around 115 mph. Won't see that
with the Kolb. Pete thinks about 80 to 85. He uses the Warp Drive.
Pete had built a Kolb Mark 111 before the Titan, he sold the Kolb,
but its for sale by that party now, who is getting a Titan. Wants to go
faster I guess.
Dallas Shepherd
Builders:
I know there has been a lot of discussion on different angle of attack (AOA)
systems on the web. The mounting method of my systems are currently being
modified to a much "better looking" method. If you are interested in the EM
aviation RiteAngle systems, and have any questions regarding an installation
in your particular aircraft, or about the system itself, please view my
website at http://www.riteangle.com Go to "Frequently Asked Questions"
and then fill out the easy to use inquiry form or e-mail me direclty at
elbie(at)aol.com You can be assured that I do not use the information I
receive from you for anything except giving you an honest answer, usually
within a work day unless I am out of town at a Fly-In.
The RiteAngle 1a is discontuined, with the RiteAngle Basic replacing it at a
lower cost and improved display. This system is for basic primary aircraft
with no flaps. The RiteAngle II systems were designed to fill a need for a
system with the ability to set each LED individually as desired for your
aircraft and also (IIa version) have corrections for four (4) seperate flap
positions. . These two safety features I don't believe any other
manufacturer's angle of attack system has. Audio warning available with each
system.
Since the first RiteAngle 1a system was sold in Jan. '96 and introduced at
Sun n Fun that year, I consider it a compliment that many other
manufacturer's systems are now using the LED display for their easy to
understand "ladder of light" indications and reliability. Costs range from $
250.00 for the RiteAngle Basic version to $ 595.00 for the RiteAngle IIa
version.
Thanks for your time, an please Fly the Safe Angle !
Fly the Safe Angle with the RiteAngle
Elbie Mendenhall EAA 38308
EM aviation
Owner
Dallas, Who has Pete's Mark III? I know someone who might be interested.
This guy is 6'4" 275lb. He's tried my FS-2 for size, with poor results.
I've suggested a side-by-side UL converted to center-solo controls. I
don't know how difficult that would be, but these big guys still want to
fly!
> From: Dallas Shepherd <cen23954(at)centuryinter.net>
> To: Kolb-list
> Subject: Kolb-List: Jabiru
> Date: Sunday, November 07, 1999 9:10 AM
> John:
> faster I guess.
> Dallas Shepherd
Bruce:
Try www.hometown.aol.com/eaau141. Thats the EAA club web page and its
on it. Some others too, but well equipped with a high price, but nice.
Pete's E-mail is gllplanes(at)aol.com. The club has a nice web page with
lots of info.
Dallas
Anybody have any good suggestions for seats in a MKIII? Mine came with the
webbing type with a life preserver for a seat cushion ( it was on floats ).
I'd like something that looks a bit better.
Cheers, Michael
i had a custom upholstery shop make mine, on a 1/4 thick plywood. About
125.00 for one seat. A little expensive but looks nice.
I used Empi dune buggy seats, with foam padded covers. Cost $168.00 for the
pair, weigh about 6 lb. for the pair. Have pics if you like. Big Lar.
Sent: Sunday, November 07, 1999 7:26 PM
Subject: Kolb-List: Seats
floats ).
> Cheers, Michael
From: | "Bruce E. Harrison" <beharrison(at)lexhealth.org> |
I had the same experience. Because of the high placement of the engine on a
Kolb in relation to the tank, it can take quite a while to pull fuel up the
line. I got tired of popping off the float bowl and filling it with fuel to
get the engine to pop off and pull some fuel. The plunger was great because
you could see fuel come up the line and you could be assured the float bowl
was full.
I originally had a ball-type hand pump on the fuel line, but threw it away
after experiencing fuel starvation problems in flight. I took the in-line
hand pump off and tried to blow through it . Even when oriented the right
direction that in-line pump was a tremendous drag on the system. Adding the
plunger-type primer allowed me to go with a fuel system with no resistance
other than gravity.
Bruce E. Harrison
Subject: | THE MEANING OF VOLUNTARY |
Hello Guys and Gals,
Lets have a little discussion on what the meaning of VOLUNTARY is. Webster
has it as:
1. Brought about by one's own free choice; given or done of one's own free
will; freely chosen or undertaken.( 2. 3. 4. 5. have to do with
manslaughter, muscles, and agency.) 6. Supported by contributions or
freewill offerings; not supported by the state.
"Voluntary implies the exercise of one's own free choice or will in an
action, whether or not external influences are at work."
Every April 15th I always feel like I am being FORCED to pay for a lot of
things I not only don't believe in but that are outright against a lot of
what I do believe in. Sure a lot of my tax dollars go to things I use and
things I believe in and given the CHOICE I always say I would pay for those
even if I weren't forced to.Unfortunately I don't have the opportunity to
prove that. I HAVE to pay for all of it! Like it or not.
Well that brings us to the Matronics Lists. Here we have a service that we
use in one way or another. Whether you read it for the entertainment value
or the technical content or the flying information or the occasional
controversies, the point is you still read it. By being subscribed there
must be something of interest here that has a value to you. This is your
chance to prove that you would pay for those "services" that you use
without being "forced" to pay. In this way you have the freedom to "price"
out what your own "tax rate" should be. The freedom to pay for exactly what
you feel you use. Of course, if you give a little extra it is appreciated,
but giving SOMETHING is the whole point. To be counted in the LOC (List of
Contributors) at the end of the fund raiser is an honor! It doesn't say how
much you gave, it just says you gave. It says you care and you are willing
to carry a part of the load. It gives you a chance to prove to yourself and
others that you would pay for what you use and believe in without being
FORCED to pay for it all. Of course if you don't give at all, you may not
be the person you think you are. VOLUNTARY means........................YOU!
Please give something today if you haven't
already..............................
To make a SSL Secure Web Contribution using your Visa or MasterCard, have a
look at the following URL:
http://www.matronics.com/contribution.html
To make a Contribution by check, please send US Mail to:
c/o Matt Dralle
Matronics
PO Box 347
Livermore, CA 94551
Next we may delve into what the meaning of "is" is. uh......maybe not! AL
Larry:
Have tried unsuccessfully to find an EMPI web site or some
place to locate "dune buggy" seats. Will you send me the
url for EMPI or a dealer? 1-800 number or what ever? Also,
would like to see your installation of seats, and possibly
dimensions of seats.
Thanks in advance.
> john h
Sorry Gang:
After two years on the internet am still learning. This
should have gone bc.
One of my most interesting flights involved high winds like you described.
For several years I had attended an annual fly in at the State Line
Ultraport in NC as a spectator. After I finally had my own Firestar, I was
DETERMINED to make the 2 1/2 hour cross-country flight and wow the
appreciative masses. Comment: Never put yourself in a situation where you
HAVE to go anywhere in an UL. You tend to take more risks and push the
envelope.
Afternoon showers delayed my departure Friday evening till I only had a 3
hour window to complete the flight. Once aloft I realized there were strong
winds above 2000 feet, and gusty winds below that. I tried flying high and I
tried flying low and realized I just wasn't making my usual progress.
Naturally I kept going. Stopped for fuel and to phone my flight following
friends of my progress. Forty-five minutes after leaving Rock Hill, SC, I
could still see the airport behind me in the distance. I knew I was only a
few miles from the grass strip at York, but I just couldn't buck the wind
anymore and dusk was only minutes away. I estimate the wind was 20 mph,
gusting to 30 or more. The exciting part began when I accepted the
inevitable and wheeled around to return to Rock Hill. (Good decision) My 60
mph cruise speed plus the tailwind resulted in a "rocket ride" that I won't
soon forget. I was at 800 agl and got to watch the trees, high tension
lines, and fields zoom by me. Felt like I was in an F-16. Landed fine at
Rock Hill and tied down with heavy duty straps. Winds were high all that
weekend so I drove to the fly-in AGAIN! Even so, the old saying still holds:
"It is better to be down here, wishing you were up there, than to be up
there, wishing you were down here."
Bruce E. Harrison
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
Well , I went another route...I called and ordered a pair of seats from Rans
that come out of the S-6S. They are a aluminum tubing frame with upholstery
, map pockets behind the seat backs and everything. I originally was going
to weld a set of seat runners into the cage to carry them but have decided
to use a machined aluminum bar (6061-t651 3/4X3/4). It looks really slick
and weighs practically nothing. (When its done I will tell you how much
"nothing" weighs..have access to a postal scale..) The machining is neat
but fast (the alum. is soft compared to the tool steel my buddy is used to
working on..it pays to have friends with machine
shops...hehehehe)...pictures in a few days.
Jeremy Casey
jrcasey(at)mindpsring.com
http://jrcasey.home.mindspring.com/home.htm
P.S. Rans planes never impressed me ..but there seats are comfy!!! Go
figure...I guess it's all the recumbant bike seats they make..practice makes
perfectr
the
Lar.
>Larry:
>Thanks in advance.
>john h
I have a pair of fiberglas seats I got from Pape Enterprises in El Cajon, CA.
Cost about $90 a piece. Haven't had a chance to install them yet. I am
considering clamping an aluminum plate with anchor nuts to the tubing and
bolting the seat to it.
Pape phone is 619-449-9720 E-mail john@pape-ent.com
Bill George
Mk-3 582 Powerfin
From: | Cliff / Carolyn Stripling <striplic(at)tetric.com> |
I had seats made by a company in Dallas, Tx. that makes seat pads for
outdoor furniture. The plasticized woven material breathes (no hot spots
in the summer) and is completely washable. The pad has a foam core and is
wrapped with some sort of white pillowy material before being stuffed into
the casing. Comes in many colors to co-ordinate your color scheme. I gave
them the dimensions, the color and the thickness I wanted and they did a
really good job for $25/each. I highly recommend that kind of seat cushion
for looks and comfort. It will not float though.
Something else you might consider is buying a piece of light weight "auto"
type carpeting (sold in several colors) sold at the auto stores. It is
enough to line your cockpit by tucking between the tubes and Stits on the
sides, over the center console (under an arm rest of course) and behind the
seats (fastened with velcro) and even enough for the floor boards. I held
down the floor board piece with a covering of Lexan on the forward part
(The Lexan also provides a good heel slide for your shoes) to keep them
from digging into the carpet.
Later,
Cliff & Carolyn Stripling
801 Avenida Serena, Marble Falls, Texas 78654
Vista Del Rio (Central Texas Hill Country)
(830)693-9333 (voice) -7633 (fax)
> AVIATION 101
> Takeoff's are optional. Landings are mandatory.
> If God meant man to fly, He'd have given him more money.
> If you push the stick forward, the houses get bigger, if you pull the
> stick back they get smaller.
> (Unless you keep pulling the stick back --then they get bigger again.)
> Flying is not dangerous; crashing is dangerous.
> It's better to be down here wishing you were up there, than up there
> The propeller is just a big fan in the front of the plane to keep the
> pilot cool. Want proof? Make it stop; then watch the pilot break out into
> a sweat.
> Speed is life, altitude is life insurance. No one has ever collided
> with the sky.
> It's best to keep the pointed end going forward as much as possible.
> The only time you have too much fuel is when you're on fire.
> Flying is the second greatest thrill known to man .... Landing is the
> first!
> Every one already knows the definition of a 'good' landing is one from
> which you can walk away. But very few know the definition of a 'great
> landing.' It's one after which you can use the airplane another time.
> The probability of survival is equal to the angle of arrival.
> Always remember you fly an airplane with your head, not your hands.
> Never let an airplane take you somewhere your brain didn't get to five
> minutes earlier.
> You know you've landed with the wheels up when it takes full power to
> taxi.
> Those who hoot with the owls by night, should not fly with the eagles
> by day.
> A helicopter is a collection of rotating parts going round and round
> and reciprocating parts going up and down -- all of them trying to become
> random in motion. Helicopters can't really fly -- they're just so ugly
> that the earth immediately repels them.
> Young man, was that a landing or were we shot down?
> Learn from the mistakes of others. You won't live long enough to make all
> of them yourself.
> Trust your captain .... but keep your seat belt securely fastened.
> Any pilot who relies on a terminal forecast can be sold the Brooklyn
> Bridge. If he relies on winds aloft reports he can be sold Niagara
> Falls.
> Good judgment comes from experience and experience comes from bad
> judgment.
> Aviation is not so much a profession as it is a disease.
> There are three simple rules for making a smooth landing:
> Unfortunately, no one knows what they are.
> The only thing worse than a captain who never flew as copilot is a
> copilot who once was a captain.
> Be nice to your first officer, he may be your captain at your next
> airline.
> Any attempt to stretch fuel is guaranteed to increase head wind.
> A thunderstorm is never as bad on the inside as it appears on the
> outside. It's worse.
> Son, I was flying airplanes for a living when you were still in liquid
> form.
> It's easy to make a small fortune in aviation. You start with a large
> fortune.
> A male pilot is a confused soul who talks about women when he's
> flying, and about flying when he's with a woman.
> A fool and his money are soon flying more airplane than he can handle.
> Remember, you're always a student in an airplane.
> Keep looking around; there's always something you've missed.
> Try to keep the number of your landings equal to the number of your
> takeoffs.
> You cannot propel yourself forward by patting yourself on the back.
> There are old pilots, and there are bold pilots, but there are no old,
> bold, pilots!
> Things which do you no good in aviation: Altitude above you. Runway
> behind you. Fuel in the truck. Half a second ago. Approach plates in the
> car. The airspeed you don't have.
> Flying is the perfect vocation for a man who wants to feel like a boy,
> but
> not for one who still is.
> Asking what a pilot thinks about the FAA is like asking a fireplug
> what it thinks about dogs.
> Being an airline pilot would be great if you didn't have to go on all
> those trips.
> Gravity never loses! The best you can hope for is a draw!
>vv
From: | Erich Weaver 805-683-0200 <sbaew(at)dames.com> |
Due to limited dashboard space on my Mrk III, Ive been using a "Tiny
Tach" for monitoring of RPM. Its not working consistently. The tach
relies on a wire that is wrapped several times around one of the spark
plug wires, resulting in an induced current that is interpreted by the
tach. Ive tried re-wrapping that wire several times, and changing the
number of coils around the spark plug wire(2-5 times), but still get
inconsistent readings - i.e., sometimes it appears to be working well
(around 1200 to 5800 rpm from idle to WOT), but mostly readings are about
1/3 low. Ive got a Rotax 912; maybe this thing has a problem with
four-strokes? Anybody else out there using the Tiny Tach on a 912 or
other 4-stroke?
thanx
Erich Weaver
Well Group, I got into such a tangle with this, I thought I'd better reply
to everyone. Apparently the kid who told me "Empi" had his wires crossed.
Seats were made by Whittier Upholstery, in the L.A. area. Tried to call and
their phone is disconnected. Empi seats are apparently pretty flimsy.
'Course, these guys at Indio Dune Buggy are pro desert racers, and need
rugged stuff. Desert Motorsports here in Palm Springs referred me to the
BugPak #7520 fiberglass seat shell for about $50.00, and the #8013
breathable cover (black only) for about $30.00. Seat looks like mine, in
the picture. If you get the shell, I'd suggest having a local upholstery
shop stitch up a cover for you, to make sure you get what you want. BugPak
is at 1-714-979-4990. In Desert Motorsports' shop they have a really
great custom seat on display, that is just about perfect. He let me bring
it home to try it out, and it just don't fit. Too big, by far. Heavy too,
at 12#, but I was willing to suffer that for the comfort, for the drivers'
seat anyway. Spendy at $160.00 ea. but I was ready with the cash. My, it
was comfy, and solid. Too bad it's so big. I rough measured the space
available, and he's checking with the builder for me, (it's a custom
off-road racing seat) to see if something can be made; also to see if it can
be made with aluminum frame for lightness. It's been a busy morning.
Guess this is why they call me Stub-Bourne. Big Lar.
Sent: Monday, November 08, 1999 6:42 AM
Subject: Re: Kolb-List: Seats
the
Lar.
> Larry:
> Thanks in advance.
> john h
I'll be real interested in replies to this, too. My tach uses 4 wrap around
induction pick-ups, and I'm very interested in having it work properly.
Big Lar.
From: Erich Weaver 805-683-0200 <sbaew(at)dames.com>
Sent: Monday, November 08, 1999 10:39 AM
Subject: Kolb-List: Re: tiny tach
> other 4-stroke?
> thanx
> Erich Weaver
Thanks for all the feedback on the seats. Now I have another problem ... I
need a serviceable 582 case. Just the case. Anyone have one sitting around
in the "ya never know pile"?
Cheers ( but not so cheerful ), Michael
<< Well , I went another route... >>
Me, too. 'N I copied it from Possum. You oughta try a desk chair - the kind
with a seat base for your butt and an independent section for your back.
Possum's got a real nice (expensive) base and back piece, whereas, mine is a
$24 (on sale from Office Depot) but sure is comfortable. Mostly lightweight
and only small modifications to attach the base to the Kolb seat frame. Seat
back is more problematic but can be done.
ulflyer
From: | Robert L Doebler <robertdoebler(at)juno.com> |
around
Big Lar.
-I'm using a "tiny Tach". on my 503, was told when I ordered it, that
there were two kinds. One for "points", and another for DCI. Told them it
was a dci ignition. Been working fine for me.
Bob Doebler F/S II-503
Subject: | Re: Kolb-List Digest: 11/07/99 |
It seems, from looking at the pics of the Mark III that it has no dihedral.
Are there any problems with handling because of a "straight" wing?
Joe Baker
To Ben Ransom and others:
I've been working quietly on the MkIII rebuild for about 6 months. It is going
well. Covered both wings during the past two weekends. Already rebuilt and
repaired elevator, flaps and aileron. Lots of hours invested when it seemed like
finishing was a long way off. What remains? Spray a little poly spray followed
by poly tone and a few odds and ends like a new set of engine gauges.
It's worth the effort. It is looking good now! The worst part was drilling out
thousands of rivets and puttin in the new stuff. I don't envy you that Ben. As
someone told me on this list when I was getting started; buy a dozen Black and
Decker 1/8 inch drill bits and have at it. Looking forward from six months ago
it
looked like a long, long road. Looking back, it seems like time flew by. Hope
you can be looking back and saying "that wasn't so bad after all" soon.
Anybody out there recommend EGT and CHT gauge brands. Looking in the LEAF catalog
the gauges are pretty cheap. Are they worth buying? Other catalogs seem to be
more expensive. Maybe I'm comparing apples to oranges.
Thanks, Bil
> << but I
> it.
> -Ben Ransom >>
> Joe Baker
Joe and Kolbers:
Don't think so. Haven't found any in the last 1,322.7
flight hours.
john h (still enjoying hell outta my old MK III)
BTW: Installed a SS exhaust system from Titan Aircraft.
The old 912 with 1,090+ hours gained 100 rpm in climb from
the exhaust system I bought from Progressive Aerodyne.
Hey Gang: Shoulda read the above before I hit the send
button. Let me try again. Got a 100rpm improvement with
the Titan exh over the exhaust sys from Progressive
Aerodyne. Been climbing out at 60 mph and 5300 now it will
turn 5400 at 60 mph.
Bil,
I've had bad luck with Westberg gauges and do not recommend them....they
don't hold up well in vibration. I recently bought Micro-1000 gauges from
Aircraft Spruce. EGT and CHT dual gauges are $100 each plus probes....not
cheap. I haven't installed them yet, but they look very nice. They claim
to tolerate vibration. Japanese made, I think.
Bruce McElhoe FireFly #88
Reedley, Calif.
catalog
to be
> Thanks, Bil
Subject: | Re: Mkii dimensions |
Sent: Friday, November 05, 1999 7:24 AM
Subject: Kolb-List: Mkii dimensions
measures
> 23' inside).
> Hope this helps...
Jim--thanks for your reply. Please give me an idea of what you are asking
and your location. Thanks, Bill
Subject: | AIRPORT BUMPER STICKERS |
Bumper stickers seen at local airports:
1. I don't suffer from insanity, I enjoy every minute of it. I'm building
my own airplane!
2. If ignorance is bliss, you must be really happy. Now is the time to
make your contribution.
3. Yes, Jesus is coming ... everyone look busy. Start pounding rivets!
4. And so my therapist said, "You need a hobby" so here I am at the airport!
5. I used to have a handle on life, but it broke. So I ordered a Zenith kit.
6. Don't take life too seriously, you won't get out alive. So make your
contribution really big!
7. WANTED: Meaningful overnight relationship. Need to be able to read plans.
8. You're just jealous because the voices only talk to me. And they say
the Kolb is the only way to fly!
9. BEER: It's not just for breakfast anymore. (This one was on Chet's car)
10. I got a gun for my wife, best trade I ever made. Now I can buy a
Rocket kit without consulting her.
11. So you're a feminist...Isn't that cute! (No comment!)
12. Beauty is in the eye of the beer holder. No wonder so many RV's have
been completed!
13. Earth is the insane asylum for the universe. And airports are where
they keep the really hard cases!
14. To all you virgins..thanks for nothing. Unlesss you are a good bucker!
15. I'm not a complete idiot, some parts are missing. (On my bumper)
16. Earth first...we'll mine the other planets later.
17. How can I be overdrawn, I still have checks! (So write one to Matronics!)
18. I'm just driving this way to piss you off. (At least until you make
your contribution!)
19. Out of my mind. Back in five minutes. Out in my shop.....back in 2
years.
20. Keep honking, I'm reloading.
21. Sometimes I wake up grumpy; other times I let him sleep. (On wifes car)
22. I want to die in my sleep like my grandfather ... not screaming and
yelling like the passengers in his car. (Who didn't make a contribution!)
23. God must love stupid people, he made so many. Good thing none that I
know are pilots.
24. The gene pool could use a little chlorine.
25. Change is inevitable, except from a vending machine or my kit supplier!
26. It IS as BAD as you think, and they ARE out to get you. And you will
contribute to Matronics!
27. I took an IQ test and the results were negative. So I sent a check for
a (Choose one: RV, Kolb, Zenith, Rocket) kit. Or substitute : "So I bought
a YAK"
28. It's lonely at the top, but you eat better and fly faster!
29. Give me ambiguity or give me something else. But PLEASE, no plastic
airplanes!
30. We are born naked, wet and hungry. Then things get worse. We get into
aviation!
31. A dirty mind is a terrible thing to waste. It could be spending hours
pouring over plans!
32. Always remember you're unique, just like everyone else. Well, like
everyone else in aviation anyway!
33. Lottery: A tax on people who are bad at math. Like all pilots who are
also bad at finance too!
34. Very funny, Scotty. Now beam down my clothes.
35. Consciousness: that annoying time between mental lapses and another
work session on "the kit"!
36. Be nice to your kids. They'll choose your nursing home. So why leave
them anything...send it to Matronics.
37. 3 kinds of people: those who can count & those who can't. Oh yea, and
those who build and those why buy finished, and those who choose tail
draggers and those who choose nose draggers, and, and ..........
38. Ever stop to think, and forget to start again? Thats when it's time to
deburr!
39. Diplomacy is the art of saying 'Nice Plane!' with a straight face to a
spamcan owner just before you open the hanger door where your RV is kept!
40. So many idiots, so few clearances for take-off.
c/o Matt Dralle
Matronics
PO Box 347
Livermore, CA 94551
If you would just make your contribution you could put a stop to all this
foolishness! AL
I wouldn't give up my EIS.
> From: Bil Ragsdale <bilrags@world-net.net>
> Subject: Re: Kolb-List: Back in the garage
> Date: Monday, November 08, 1999 8:51 PM
going
and
seemed like
followed
drilling out
Ben. As
Black and
months ago it
Hope
LEAF catalog
to be
> Thanks, Bil
> > << but I
> > it.
> > -Ben Ransom >>
GeoR38
Can you give me the address either snail or e will do.
Geoff
Date: Tuesday, 9 November 1999 12:18
Subject: Re: Kolb-List: Re: Kolb-List Digest: 11/07/99
>john h
> Thanks
> Geoff
> >john h
Geoff:
Titan Aircraft
2730 Walter Main Road
Geneva, Ohio 44041
(440) 466-0602 voice
(440) 466-7550 fax
titan(at)suite224.net
Hope this helps you out.
How are things in New Zealand? You guys getting ready for
summer and we are getting ready for winter.
Am in the serious planning stages of a return flight to
Alaska with ultimate destination of Barrow, northernmost
point in the North American Continent. Was 205 sm short of
that goal 5 years ago. Believe I can make it this time. Am
shooting for a mid June 2000 departure. This trip will be
considerably shorter than the last one, aprx 8,500 sm
compared to 17,400 sm.
Gordon:
Sorry about the L, I thought it was 141. When you get to the site,click
on members list and equipment for sale. I looked at it again last night
and there are several Titans and a blue Kolb Mark 111, plus some
earphones. There isn't a price on the Kolb, so you would have to call
Tony about it. It was built about the time I built mine and I ordered
it in "94", finished it in "96". Pete Krotje built it and I believe
Tony is his brother. Pete's Titan is for sale for $23,000 with a 80hp
Jabiru engine on it. It goes fast.
Dallas
Gordon: Checked it again and click on Members Items for sale, that will
give you some nice pictures of the planes, prices, except the Kolb, and
some of the equipment. Tony is not Pete's brother, Ben is. Kolb is
owned by Tony Van Kampen, phone 920 982 3117. He bought a used Titan.
Hope this gets you there.
Dallas
Group,
Regarding the Tiny Tach, I had mine mounted on the instrument panel,
and discovered that mine didn't like the long run of wire. I mounted it
behind me on the left side of the cage, lost about 5-6' of wire, and it
worked better.
Darren Smalec, FS1, 460 F-40
Subject: | . . . I think it's working. |
Seems our website engineer decided that a change
of directory names for our website was in order.
The change was done without telling us anything
about it and it seems to have caused our difficulties
for the past 4 days. Seems some folk could get in
while others (including yours truly) could not.
Don't understand everything I've learned about this
problem but I think it's working now.
If anyone has trouble accessing our homepage at
. . . . I'd like to hear about it.
Thanks for your patience and help. By the way, this
problem had NO EFFECT on our e-mail system and any
orders in work were not at risk.
(o o)
From: | "William Herren" <wmdherren(at)hotmail.com> |
Subject: | Re: Boom in San Antonio |
Had a quick thought of you when I got my Experimenter mag today. On the
table of contents page and page 25 there is a red Kolb N51KA and it took a
few seconds to remember that yours is N51SK. I still hope to get over for
the boom. I dinged my truck and need to pay for that before I start the
rebuild.
>From: N51SK(at)aol.com
>Reply-To: kolb-list(at)matronics.com
>Subject: Re: Kolb-List: Re: Boom in San Antonio
>Date: Wed, 24 Mar 1999 00:49:34 EST
>In a message dated 3/23/99 9:00:26 PM Pacific Standard Time,
>wmdherren(at)hotmail.com writes:
><< Has San Antonio become a Boom town? I am looking for a boom for an
> Ultrastar. 0.50" wall 5" dia. 6063 is called for on the plans but I'd
> get the 6061 T6 if I could find it. Actually I talked to a place in
> Houston that might have it. Where did you find some? Are you native to
> SA? I was an Army Brat and lived in SA during WWII and again when POP
> went to Korea (after that war). Grad from Alamo Heights in 57. After
> grad from A&M I was at Lackland in 62 and made my first solo at Stinson
> Field the 8th day after my first lesson. Couldn't fly on the 7th - the
> inst. went on an X/C. Lots of luck with the rivet drilling. If they
> are SS you need help! BILL HERREN
> >>Hey Bill...
>I've got one with a ding in it I'd let go cheap....got a staple shot in it
>when it was packed for shipping...it's the right size...just got the ding
>Steve K. Mk2
Subject: | Re: Guages: Was back in the garage |
Bil and all,
Thanks for the encouragement. Even after barely
starting it's not looking as formidable.
I have Westach gauges. Had a problem with CHT once
and Westach fixed it quickly and either free or
inexpensive. I like the look of round gauges on the
panel, and they are probably a little cheaper than an
EIS, but for functionality EIS is the absolute best
option. If you factor in the possibility of an EIS
alerting you to an engine malfunction, EIS is then
also way cheaper than anything else too.
I'll probably keep my round gauges. Have always
thought about adding my own warning buzzer circuitry
to them ...a symptom of the 'do-it-yourself' disease.
-Ben
>john h
????? That dosn't seem to be an improvement to me.
Woody
> >john h
> Woody
Woody, Woody:
How come???
>> >john h
>> Woody
>Woody, Woody:
>How come???
>john h
Johnny Johnny Johnny
I'm not the smartest critter around but if the engine has to turn faster
to go the same speed I would not think it an improvement. Would there be a
corresponding increase in rate of climb to account for this increase in RPM?
Woody
I think we agreed on our mutual preference for gauges some time ago Ben.
Just like the look of 'em. I hope I'm on the right track with mine, cause
like you, I've got Westbergs, and that message the other day made my blood
run cold. Like you, I've had excellent service from Westberg in the past,
but would prefer not to have problems in the future. When I built my panel,
I was more worried about the expensive radios being hurt by vibration, so
built a complete panel to carry radios, gauges, switches and all, and
mounted the whole 9 yards on 12 of the Cessna rubber panel mounts from A/C
Spruce, so that it kind of floats. Why 12 mounts ?? Cause I started with
6, and they drooped under the weight. Didn't figure they'd last long. Kept
adding them till it "looked good," and still had easy movement. Hope that
saves my delicate instruments. Hang in there Ben, and good luck.
Big Lar.
Sent: Tuesday, November 09, 1999 12:40 PM
Subject: Re: Kolb-List: Guages: Was back in the garage
> Bil and all,
OK guys, up and at 'em. I just got off the phone from talking with the (now
retired) owner of the flight school in Port Angeles that taught me to fly.
Got on to the subject of corrosion proofing, and he told me of some
experiments he and others tried a while back; and we may need some help with
this. Now..........they took a product called "something" 50, and sprayed
it in 1 wing of a 180 on floats. (Or maybe 1/2 of the airplane) Then used
LPS-3 in the other wing, (or other 1/2 ), loaded it on the back of a
commercial boat and hauled it to Alaska. Dumped it in the ocean, and used
it for fish spotting, etc. for quite a period of time. He says the LPS-3
was far superior. It leaves a yellow film on the structure, and needs a
solvent to be removed. Leaves a "wax" coating. When removed after several
years, the structure looked brand new ! ! ! Also, it's apparently
available in auto parts stores for around $20.00 a gallon, so it's far
cheaper than the alternatives. He doesn't remember what the "something" was
in the 50, nor the mfgr of the LPS-3. They never tried Corrosion X.
I'll start checking this weekend, but in the meantime, does any of this ring
any bells for anybody ??
LPS 3 is a powerful corrosion preventative. You guys are going to have C--p
dripping out of everything. What you building anyway? The Y3K Kolb? Do Not
Archive. JR
Gentlemen:
Like you I have had basically decent luck with Westberg gauges. My
problem is the lousy push on connectors. My gauges survive the vibration OK,
but my connectors often fall off. I try to crimp them artfully as I can, and
I push them on firmly, but they still come off now and again. It is very
distressing to look at one side of my egt gauge with the needle lying limp at
the bottom and wonder whether the connector has fallen off, or whether I have
a real problem. Cripes, this is an airplane, every important connection
ought to have some positive way of locking it down, rather than relying on
friction. What are the thoughts of the group?
In a message dated 99-11-10 9:57:03 AM Eastern Standard Time,
rcreec(at)ftw.rsc.raytheon.com writes:
<< I don't know what type of connectors are on that gage, or what gage you are
speaking of but, are the terminals solderable? Are they thermocouple wires?
Which gage?
All of the westberg gauges have the smooth bayonette connectors. They are
little male shaped stems, no threads, no provision for attaching anything
mechanically to them. The female side is a split metal tube that slips over
the male stem with a provision to crimp the wire into it at the back.
Guys, I used #22 gauge wire (stranded) from the thermocouple cable
soldered to the instrument connector leaving plenty of strain relief for
the wire. The connector slides on tight (crimp it with a needle-nose
pliers prior to installation). The stranded wire then needs to be secured
to the fiberglass nose so it won't hang from the connectors. Never had a
problem and my panel is not isolated for vibration dampening. Would you
believe the instruments have held up all these years? (they are from
CPS).
Ralph Burlingame
>Gentlemen:
>My
>vibration OK,
>can, and
I bundle all my wires into small "mini bundles" for lack of a better
word, then those are all zip tied to small aluminum tabs bolted on to
the back side of the screws holding the guages in. This "pulls" the
harness towards the instruments, and we have yet to have a wire fall
off. You could probably use a tiny drop of Loctite Clyndrical locking
compound (green) on them if you dont bundle your wires. I doubt it would
affect the current flow.
Mike Brown
Olympic Ultralights
Cavuontop(at)aol.com wrote:
> Gentlemen:
Like Ralph, I just add a little crimp to the female
end before pushing in onto the instrument male end,
and leave the wire bundle secured by tie-wraps to
something more solid. No vibration isolation needed.
Sorry about getting us started on a mispelled subject
line. ...bad for the archive search. :-/
-Ben
Hi Ben et al. A few years ago I purchased some slightly cheaper dual CHT and
dual EGT gages that were made in china. Saved a few bucks and bought a lot of
head aches. Previously and from now on I will be using West Tachs. They
answer their phone and know what they are talking about. I believe they are
located in Sonoma CA. Their gages are also imported but they work and I'm
sure the West Tach stands behind them if they don't. I avoided some trouble
by making all of the probe-to-gage connections and testing them by heating
the probes prior to final installation of the wires. It was a lot easier to
work on the instrumentation before the fabric was on too. Good luck Ben. We
need you back in the air and on-line. Duane the plane in Tallahassee
Subject: | Re:Exhaust Pressure Guage |
Kolbers,
Someone commented about my report of Molt Taylor using a pressure gauge in
the exhaust to measure a 2 strokes power output. He said that since the
resonant exhaust waves change so much that it would make little sense to use a
gauge there. In fact the changes are so fast that an average would appear on
the gauge, and the higher the pressure, the more load the engine is experiencing
at that moment. The reading would be more analagous to torque than to
horsepower. Sorry this is a little late in response.
...Richard Swiderski
Subject: | WELL IT'S WORKING ! |
Well you guys, It's working. I had the opportunity to have a chat with MATT
today and discovered that a LOT of you ARE contributing. That is a lot of
you compared to past fund raisers. We are doing well but with about 2000
people on the lists the vast majority of you are still sand bagging. (or is
that lurking?) Well although just lurking is fine and I can understand it,
I still think it would be nice if you would recognize at least the
entertainment value of this list and get that contribution in now. I know,
I know, SOME of you have a really, really good reason NOT to contribute
and for those I'm sure I speak for everyone when I say that I hope
your next PAROLE HEARING is more successful. But for those of you who
still have access to a valid credit card or your bank still honors your
checks, make that contribution NOW.... There's never been a
better time! AL
c/o Matt Dralle
Matronics
PO Box 347
Livermore, CA 94551
list-homebuilt ,
list-kolb ,
list-lancair ,
list-seaplane ,
list-tailwind ,
list-zenith
Greetings,
I have a limited supply of tie wrap strimg in 500yd spools I am
interested in selling. It is the flat braded, coated aircraft type that
will not come untied easily. I will sell if for $12 per spool shipping
included. If you are interested, contact me off the list. I also have
other products I offer. If you provide your US Postal address I will
send you a set of my flyers.
Warren Gretz
Gretz Aero
Mine telling who the supplier of the poor quality gauges was so we all
don't get stung by the same outfit. If they sell junk then they should
reap the crop they sow.
of
Tim T. here
I am looking for the perfect engine for my Mark III. What do you think about
the VW conversions?? And does any one have an engine
for sale, any brand?
Our Best
Tim T.
I suspect that by "perfect" you mean cheap as there is nothing perfect about
a VW engine. In my opinion the perfect engine, but not cheap, would be the
912S followed the "mighty" but still not perfect 582. JR
I'd lost the original piece on Adel clamps but a helpful
builder pointed me to another site where it was republished.
I've captured the article and reposted it at:
http://home.kscable.com/aeroelectric/articles/adel.html
(o o)
T. Townsend
I have an 80hp Jabiru on order and when it gets here I will have a
Rotax 582 for sale. I fly a Mark 111. The Rotax has 102 hours on it
after I flew this morning. Have had no problems in that 102 hours.
Reason for the switch--I wear two hearing aids, want less noise. I have
a short grass strip with wires at one end and trees on the other and
want more climb in warm weather with two people. I am at the edge of the
Ozark National Forest and there are few flat places around here. I am
looking for more reliability in the Australia certified engine. I'm not
sure what a 582 with that many hours is worth.
Dallas Shepherd
Norfork, Arkansas
Guys,
I happened to stumble across a potential problem with the type of fuel
line that I installed prior to my trip to Oshkosh. I bought some
pink-colored urethane fuel line through one of the aftermarket dealers
and replaced my 10 year old blue urethane (which was still very flexible)
with this stuff. I noticed the wall thickness of the pink tubing was
greater so some of the plastic clamps would not ratchet fully closed as
they had on the blue tubing. After my return flight, I noticed a gas
leak on the garage floor underneath the plane. I thought this was odd
(duh), so I checked the tubing and saw that it had become less flexible
and had shrunk in diameter loosening the clamps. I replaced the tubing
and I could not believe how brittle it had become in such a short period
of time. I called the dealer about this and they said this is a first and
sent out new tubing free of charge. At least they were nice about it.
From now on, it's the blue urethane and nothing else.
I burned 100LL for part of my trip. Do any of you guys know if that may
have affected it? This was the first time using avgas in my Rotax.
Ralph Burlingame
Original FireStar, 12 years flying and still learning
Subject: | Re: Tie wrap string |
Please send me a list of what you have
Thank you,
John Bruzan
133 e. Gregory
Mt Prospect,IL60056
Subject: | Re: Engine for sale |
I'm very interested in the engine & would like to talk to you. My pager is
800-652-3546, or call me at home - 630-898-8151.
Thanks.
chris sudlow
-----Original Message-----
Date: Thursday, November 11, 1999 1:17 PM
Subject: Kolb-List: Engine for sale
>T. Townsend
>Dallas Shepherd
>Norfork, Arkansas
Subject: | Re: pink fuel line |
In a message dated 99-11-11 6:17:55 PM Eastern Standard Time,
ul15rhb(at)juno.com writes:
<< I noticed the wall thickness of the pink tubing was
they had on the blue tubing. >>
My understanding is that the pink tubing is for the pulse line for the fuel
pump. It's stiffer and does not absorb the energy of the pulse.
Subject: | Navaid and DG tracking . . . |
>I installed the Navaid device in N40VX and am generally satisfied with the
>performance. It tracks the SL-70 Apollo GPS well, although at first I
>wasn't sure that it did. The manual is not too good, and it took me some
>time to realize what I had to do to get it tracking.
>I would be grateful in Navaid would provide the ability in the device to
>track on a ground path, as if it was tracking on a heading bug on the DG.
>This would seem to be a fairly straightforward feature, and I am surprised
>that it doesn't seem to be possible with the unit I have..
See website at http://www.porcine.com/
You can purchase a coupler that will take the
heading bug output from a DG and steer your
wing leveler with it.
(o o)
I have flown the 582 and 503 for 135 hrs. in PPC's and am
just looking for something different. Maybe good ol Rotax is
the way to go.
Our Best
Tim T.
----- Original Message -----
Sent: Thursday, November 11, 1999 2:34 AM
Subject: Re: Kolb-List: VW engines
about
I am interested!!
Where do you live? I live in Lebanon MO. also in the Ozark mountains.
In fact we flew our PPC's over Lake of the Ozarks today. You can
contact me at townsend(at)webound.com about your 582.
Our best
Tim T.
Sent: Thursday, November 11, 1999 1:06 PM
> T. Townsend
> Dallas Shepherd
> Norfork, Arkansas
I don't know how "perfect" anything is going to be, but for an economical
alternative, the VW has some real advantages. Most are set up for direct
drive, and for that, the Great Plains version is very hard to beat. My
understanding is that most Vdub failures are from using the wrong
crankshaft, and/or prop hub, followed by valve problems. The Great Plains
crankshaft with Force One prop hub, is just about unbreakable, and by doing
regular valve adjustments, you would be in pretty good shape. Just like any
other engine...............you gotta do your maintenance, and take care of
it. There are at least 2 on the list flying direct drive Vdubs, (2180cc),
and they report performance with pilot only to be about the same as a 912
with pilot and passenger. Not too bad, considering they're about 1/4 the
price. (I'm talking about flying, complete, all up) So far, I'm the only
one I know of that's building a VW with a redrive, and it's not flying yet,
so all is still speculation and hope. Sounds like you're looking seriously
at that 582, but keep the Vdub in mind for the future. There's a lot (! !
!) of them flying out there in Sonerais, KR's, Dragonflys, etc., and they're
doing a real good job. Big Lar.
Sent: Wednesday, November 10, 1999 11:16 PM
Subject: Kolb-List: VW engines
> Tim T. here
about
> Our Best
> Tim T.
Thanks Larry,
I am still considering all options. There is a guy doing VW conversions
In Rolla, MO. so I am going to see what he is offering.
Our Best
Tim T.
Sent: Thursday, November 11, 1999 11:10 PM
doing
any
(2180cc),
yet,
seriously
they're
> From: T. Townsend <townsend(at)webound.com>
> To:
> > Tim T. here
> about
> > Our Best
> > Tim T.
I run 100LL in my 582 when ever I go on a cross-country. Looking for auto
fuel is to much trouble. I have found no adverse affects. JR
I have a 912 for sale 200 Hr.. No reasonable offer refused
bwf(at)emailmn.com
612 545-8722
Esp. to jbidle, Re: which Mfgr made the bad (a little cheaper) EGT Gage. I
bought the gages during a Lakeland pilgramage one year and didn't get them
installed on my FireFly untill the next so the reciept I needed was
systematically lost. I bought them from LEAF who also sells the good ones I
should have bought. The manufacturer cleverly left their name off of the
instrument. I thought they were Westach and called them. They said it was not
theirs and that I was not the only one having troubles with these units.
Since I didn't have the receipt I just threw it in the junk box and ordered a
Westach which has never failed.
Two added tips on gages: I use the nylon/set screw terminal strips sold by
Radio Shack to make the thermocouple extension connections. The set screws
can be backed off for trouble shooting and the conection is really good when
they are tight. I have never had one back off from vibration. We are dealing
with millivolts here and good connections are an absolute necessity. Also my
next instrument panel will be be designed using the square gages because when
all the gage holes were cut for the round clamp-in type the panel was pretty
flimsy. It think the four screws around each dial would help stiffen the
panel.
Subject: | Re: Navaid and DG tracking . . . |
>I don't have a bug on my DG, and was hoping that the Navaid could
>simply track on a heading. Don't see why not.
How would it sense what heading you were on? It needs
an electrical signal from a device designed to drive
the pointer in a CDI instrument (deviation from
a radial or ground track) or from a device like
heading bug on gyro (deviation from heading).
The Navaid has only a rate sensor (like a
turn coordinator) that deduces heading deviation
by multiplying degrees-per-second turn by seconds
and then working to keep that value "zeroed".
Rate devices and the electronics that integrate their
signals drift, hence variable degrees of ability
to hold a true heading with respect to the earth.
Even if you had a heading bug on the gyro, it too
will drift, abeit more slowly than a rate-based
device, unless it is magnetically slaved to the
earth.
(o o)
W. George:
They are including the adaptor mount with the engine. The dealer is
having it made with measurements from his Kolb he sold, but is still in
his EAA club.
Dallas
Subject: | Re: Alternative engines |
Tim,
You might want to chaeck out Raven Redrive at http://www.raven-rotor.com
They offer 3 & 4 cyl 4 stroke engines from the Geo Metro car with their own
conversion packages. I've bought one that I'll be putting on my Sling Shot &
there's another guy putting one on his MkIII. ....Richard Swiderski
T. Townsend wrote:
> Thanks Larry,
> Our Best
> Tim T.
> From: Larry Bourne <larrybiglar(at)earthlink.net>
> To:
> doing
> any
> (2180cc),
> yet,
> seriously
> they're
> > To:
> > > Tim T. here
> > about
> > > Our Best
> > > Tim T.
Subject: | Static port for ASI |
For about the last three months I have been trying to find a good set up for
my ASI static port and finally think I have it solved. I have tried the
Stearman type, one side port, plopping the static tube hose in the cockpit
floor and numerous others but none of them gave me a reasonable and
repeatable reading throughout the speed range. I finally drilled 1/8" holes
on both sides of my nose cone and made up two special fittings that are
epoxied on the inside of the nose cone to interface the drilled holes with
1/4" tubing. A 1/4"ID interconnected tube is "T"ed to the ASI inlet. The
fittings are made from 1" Lexan discs with holes in the center and around
their perimeter. A plastic 1/4" elbow was glue-gunned to the disc using the
perimeter holes for mechanical grip. The epoxy shared these holes for the
same purpose. The fittings also allow the connection to be as nearly flush
with the inside of the nose cone so they won't get knocked of during heavy
use of rudder peddles. Note: during development of this part the glue gun
joint failed a twisting test after 20 minutes in the deep freezer before the
perimeter holes were incorporated in the final design. Old test engineers
never die... as long as they have a challenge. Duane the plane in Tallahassee
Subject: | Re: Static port for ASI |
In a message dated 11/12/99 1:03:36 PM, MitchMnD(at)aol.com writes:
<< I finally drilled 1/8" holes
on both sides of my nose cone and made up two special fittings >>
Duane,
Where are the holes located, i.e. front to back and top to bottom position??
Have you flight tested the installation yet?
Bill George
Mk-3 582 Powerfin
Subject: | Muffler bracket failure. |
This message is for fellow FireFly'ers. I just experienced a failure of
the forward muffler bracket mounted to the engine head after approx. 48
hr. of operation. The 1 1/4" alum. angle sheared off at the outside of
the support post nearest the muffler.
Thank God I happen to be checking the the isolation bushings for wear
when I noticed the break. It's hard to see the brackets standing on the
ground. I was standing on a stool to check the bushings because I
noticed they where deforming from their normal position.
I built the brackets according to the design and material provided by
Kolb. Is there a problem with this design that should be known? My
friend who was my mentor and inspector during the construction phase,
had the same thing happen at 30 some hours on his FireFly. I thought
that might have been a fluke.
After evaluating the situation I decided to replace the 1 1/4"x 1/8"
alum. brackets with 1" x 1/8" folded steel angles. The additional
weight seemed worth it to me. I also made my own isolation bushings
from shock absorber bushings which I cut to suit. These bushings are
stiffer than the soft bushings provided with the kit and I'm not
experiencing the creep and distortion that I had before. The rear
isolation bold had cut through the old rubber bushing and was contacting
the alum. bracket to which the muffler is attached.
Is it just me, or have other FireFly'ers had as similar problem?
Terry K
Subject: | Re: Muffler bracket failure. |
I have FF#70, and had to make new cross pcs., mainly so I could get a
plug wrench down on the plugs wothout hitting the upturned edge of the
L pc. I got new L angles, but could only find 1.5x1.5 instead of the
1.25 stuff. Turned them so that the upright side was to the rear. of
course had to make new head bolt holes, and egg-out a crescent-shaped
area for the plug. A little work where they went up to the fore/aft pc
with the bushings. No sign of fractures. bn
What kind of prop were each of you running?
Any significant vibration?
@ idle?
@ cruise?
Our FireFly has 110 hours no cracks yet but be sure I looking at it
tomorrow. Any thing you two might had done differently in common to both
airplanes?
jerryb
FireFly
>Terry K
Question - what will be the expected impact to take performance - run &
lift off, climb?
>I am interested!!
>Our best
>Tim T.
>To: Kolb-list
>> T. Townsend
>> Dallas Shepherd
>> Norfork, Arkansas
912 - "Geo" there expensive!
Subject: | JPI vs. Matronics Settlement Reached... |
Dear Listers,
After seven months of negotiations, JP Instruments, Inc. and Matronics
have reached a mutually agreeable settlement. As most of you are aware,
in February of this year, JP Instruments, Inc. alleged that Matronics'
use of the trademark "FuelScan" with its aircraft fuel management system
infringed upon JP Instruments, Inc's trademark "Scanner" for engine
temperature indicators. JP Instruments, Inc. requested that Matronics
discontinue the use of the "FuelScan" mark. After considerable
negotiations, we have come to an agreement whereby JP Instruments, Inc.
will purchase the FuelScan trademark and, if necessary, assist in paying
the cost of Matronics' adoption of a new trademark. Matronics will
continue to sell and market its aircraft fuel management system under
the FuelScan trademark until a phase-out period of up to one year is
completed. This will allow Matronics time to sell out its current stock
of units marked with the FuelScan trademark and to develop a new
trademark.
While negotiations have been a bit trying at times, I would like to say
that I am satisfied with the outcome, and feel that JP Instruments, Inc.
has treated Matronics and me fairly in this matter. Furthermore, I
would encourage you to consider JP Instruments for your aircraft
avionics in the future as they manufacture an excellent product line.
Finally, I would like to thank everyone from around the world for their
support and consideration in this matter. I was quite moved by the
support - both financial and in the form of letters and comments - that
builders and pilots provided me and my company during this time. I
never felt alone during this period, and so very much appreciated the
encouragement from thousands of my friends! Thank you so very much!
Best regards,
President, Matronics
Subject: | Re: Back in the garage |
Duane,
Regarding your instrument mounting do you have spacing for a 2-1/4"
instrument bezel. One of our airport buddies had a couple which I believe
came from Sky Sports. The looked good and looked like they would work well.
jerryb
not
ordered a
when
>panel.
Subject: | Re: JPI vs. Matronics Settlement Reached... |
Matt,
It's great to hear that you and JPI have reached a settlement that you are happy
with. I appreciate your recommendation and kindness towards JPI afterwards.
I for one will always have a little black mark next to the name JPI for the
lawsuit. Sorry, but that's just the way I feel about companies who sue over minor
issues. A bunch of lawyers make some money and the public has not been well
served over the issue. the settlement must have been good for you to be so
good natured over all this.
Subject: | twinstar mk1 & mk2 MTOW |
hi, i'm new to the list and i'm contemplating buying a mk1 and convert
it to some sort of mk2.
i need to know the max take off weight of these ac. and if there is any
structural difference between these two marks other than the enclosure.
ole
norway
Subject: | Re: twinstar mk1 & mk2 MTOW |
> ole
> norway
by the way: i'd like to know at what g-load ratings these mtow figures
are given at.
ole
Terry,
I had my side muffler bracket fail where the bolt wore a channel through
the top of the bracket. This was under the rubber isolation mounts so I
couldn't see it. It must have been this was for a long time and the only
way I discovered it was because I was inspecting everything for my trip
to Oshkosh. After I made a new bracket, the engine idle became smoother.
Ralph Burlingame
>of the forward muffler bracket mounted to the engine head after approx.
>48 hr. of operation. The 1 1/4" alum. angle sheared off at the outside
>of the support post nearest the muffler.
>Terry K
Bill George: The static port holes are located on the sides of the nose cone.
They are 6" from the trailing edge of the nosecone and 6" up from the bottom
surface of the nosecone. The objective was to get them out of any major
turbulance and keep the outside of the port flush with the surface. I had
tried using a fabric rivit through a small hole in one side and the result
was very unreliable ASI readings. I'm not sure whether it was the the rivit
protruding out into the passing air or the fact that I had it only on one
side. Hope this helps... Duane the plane in Tallahassee
jbiddle: My FireFly instrment panel has 2" dual EGT, dual CHT, tach and 3"
ASI and ALT plus a Hobbs engine timer. The EGT,CHT and tach are all clamp-in
and during installation I was concerned about that thin dash material not
being strong enough. I have had no failures inthat area but if I build
another plane I plan to try to see if I can make those four-screw gages keep
the dash more ridged. Duane Mitchell, FireFly SN 007 ( I didn't pick that
number ! )
MitchMnD,
brother, i've had nothing but problems with accurate airspeed since i
enclosed my firestar. with the shorty windshield the airspeed indicated
accurately. with the cockpit enclosed the airspeed shows about 15 mph too
slow , i know this because i gotta hall hanging off a lift strut. with the
static vented to the inside as before doesn't work. installed a pitot/static
out the nose, still not accurate. it seems that with the cockpit enclosed
accurate airspeed indication is hard to get. trying to get the airspeed
accurate is really pissin' me off. ............. tim
>ole
>norway
I fly a twinstar.I once flew with a 300lb guy beside me that gave almost
500lb of extra takeoff weight. I would not do it again. I now limit my
passengers to 220 lbs. More than this I have a hard time keeping the nose
from digging into the ground as I apply throttle. Once off the ground the
little Twinstar performed quite well with the big guy in it but it sure was
hard getting that first foot of altitude under me.
Woody
Interested in free energy? Try http://geocities.com/ResearchTriangle/lab/1135
Subject: | Ear drumming/vibration? |
Hi list members.
I have been experiencing ear drumming when flying my Firestar, from the
first hour of flight. I am using the 3 blade Ivo prop with 2 1/2" spacer
and a Rotax 503 DCDI engine.
The ear drumming is constant, but worst at 5200-5500rpm.
After reading the mail from Ralph Burlingame today, where he describes a
failure of the side muffler bracket. He made a new bracket, which
caused the idle to become smoother. Also have been having problems with
the engine idle.
Is this because of less vibration? Could this be causing my ear
drumming.
Or is it the Ivo prop? Could it be out of balance?
I am using a good headset/helmet, but no matter how I press the ear cups
to my ears or turn my head, the vibration is always there.
I have mentioned this problem on the list before, but I could not find a
cure for my problem, with all the suggestions from the list members, but
I noticed a few days ago, that the IVO prop was on the subject list, and
then this possible cause from Ralph.
I hope you can help.
Johann G.
Iceland.
Firestar II 45 hr.
Subject: | Re: Ear drumming/vibration? |
Some of the newer Ivo's have a mechanism that supposedly changes the
pitch of all blades at once. Get a bubble protractor or angle checker and
make sure all are at the same pitch. If that is not the problem, since you
are using the 3 blade Ivo, pull one blade out (don't forget the little
inserts, they only cost $5 US each)and convert it to a 2 blade for test
purposes and see what happens. If the drumming goes away, it is some kind
of interaction between the airflow of the airplane and the prop. If the
drumming changes frequency or RPM at which it begins, it is probably still
prop related. Where is your exhaust pipe outlet relative to the prop? If it
is real close, are the exhaust pulses interacting with the prop?
Richard Pike
MKIII N420P (42OldPoops)
>Hi list members.
>the engine idle.
>drumming.
>Johann G.
>Iceland.
>Firestar II 45 hr.
Johann,
When you speak of vibration, there will always be some vibration. The
question is whether the vibration is acceptable or not. You may want to
try this simple experiment the next time you're up: Set your cruise at
the rpm range that gives you the drumming sound, 5200-5500, and feel the
airframe for excessive vibration. It's hard to explain what might be
"excessive", but this might help determine if it's coming through the
airframe. If you have a full enclosure, maybe the pressure changes are
setting up by a resonant frequency that hums in your ears. I do know this
rpm range will vibrate more than at full power. Another phenomenon that
I've noticed over the years is that a quartering tailwind from the left
rear will sometimes set up a vibration in the airframe that is more
noticeable than usual. Like Richard (Old Poops) has suggested, try
switching to a 2-blade, it won't cost you anything. What's puzzling about
it is that a 3-blade is supposed to be smoother running than a 2-blade
prop.
Ralph Burlingame
writes:
>Hi list members.
>the first hour of flight. I am using the 3 blade Ivo prop with 2 1/2"
>spacer and a Rotax 503 DCDI engine.
>Johann G.
>Iceland.
>Firestar II 45 hr.
Johann, another thing that I remembered after I sent my first response
out is that a prop needs to clean and free of bugs. A dirty prop will
produce more vibration. I know this is a "no-brainer", but there are a
number of guys that complain about vibration when really that's all it
is. Be careful when cleaning the Ivo prop, any water or cleaning liquid
that gets under the stainless prop tape will cause an "out-of-balance"
condition that would make it worse until it spins itself off.
Ralph Burlingame
writes:
>Hi list members.
>Johann G.
>Iceland.
>Firestar II 45 hr.
My latest static port system seems to work just great. What I am most
concerned with is repeatability. I want to be really sure that I keep my
flying speeds above stalling during turns, on final and near touchdown. I do
my best to train the seat of my pants but knowing the instrument is reliable
assuring. I am suspicious of the 70 MPH shown at 6,000 RPM but I can live
with some inaccuracy in the top range as long as it is is solid in the mid
and lower range. With the full canopy my FireFly stalls at 34 MPH (no
flaperons). Approach turns are done at 50 and best glide is about 55
according to my ROC. Duane the plane in Tallahassee.
Tim: I know how you feel. I also started having instrument troubles when I
installed my full canopy and have fiddled with this problem for months. I
went over my experiences in an earlier post but the bottom line is as
follows: I drilled 1/8 " holes in the middle of the flat area of both sides
of the nosecone. I epoxied home made fittings on the inside of the nosecone
to connect these holes to each other and to the ASI. It turned out to be the
best of about 8 different trys. I am still working on interfacing the static
line with my altimeter. The port on the back of the instrument doesn't wasnt
to unscrew and I of course I can't really see it while it is in the panel.
More later. Duane the plane in Tallahassee
Unfortunately noticing that you wish for solid readings at low speeds, ASI
are notoriously inaccurate at low speeds and improve in accuracy as speed
increases. The physics are not complicated but I am not going there (ex high
school teacher). JR
I think some of the drumming is caused by dirty, disturbed air flow around
the cabin area. The propeller is seeing an asymmetrical condition that may
set up an oscillation or rhythmic flexing, a flutter of sorts. The IVO being
one of the most flexible propellers I have ever seen may well be fluttering,
Think of it this way--the prop blades slice through the disturbed air flow
getting struck with different vector air loads and then slam into clean air,
the prop loads up and flexes as it produces lift and then it slams back into
the dirty air and partially unloads--back and forth over and over. Hope the
Styrofoam has a good fatigue life. Seems a stiffer propeller might be in
order. While normally a three blade propeller is smoother the observation by
other Kolb listers that two blades are smoother on their airplanes makes
sense in this light--three blades pass through the disturbed air/clean air
interface more times per revolution than would a two blade prop so less
drumming. I have to say that the Kolb belonging to my friend has the nosiest
cabin I have ever been in but most of it is fixable as the Kolb I flew in
several years back was only slightly more noisy than my Kitfox. Try a
Lightspeed headset--sucks the noise right out of your head!, and you will
still be able to hear the propeller come apart when the Styrofoam gives up.
JR, ask me about when my spinner went through my prop last weekend!
Take the airplane up and perform a series of stalls under the same
conditions, i.e. power settings, configuration and deceleration rate. You
will find a number that you can then use as a reference for everything on up
the scale. Be aware that you are getting a stall speed for 1 G. The stall
speed will, of course, go up in a turn and any time you put some G on the
airplane. Approach speed for example will be 1.3 times the stall speed in
light winds.
To determine its accuracy you can use a GPS. Fly a triangular pattern or fly
upwind/downwind legs. Do this at some safe speed above stall, at normal
cruise power and at max cruise. Record the averaged numbers for each speed
and you will have a good handle on your ASI.
Bill George
Mk-3 582 Powerfin
Seems like a lot of work. Whats the matter with the old tried and true
method of adding another pito type tube under the original but this one has
a closed end and holes drilled in the side. Are we trying to reinvent the wheel?
Woody
>In the OCTOBER issue of Sport Aviation is a notice about a new ignition
>device which the company Aqualytic Technologies of Sandpoint, ID
>believes is capable of replacing magnetoes and other types of ignition
>systems. It screws into a standard spark plug hole. It incorporates
>a small precombustion chamber containing a catalyst that ignites
>the engines fuel/air mixture.
>It produced normal power on 87 octane and 100 LL avgas and picked up
>75 rpm using Jet -A in a Continental O-200 ! If this is thrue and
>if it would be a STC, or equal, this is a dream for us in Europe
>with our expensive avgas.
>Any comments ?
Be SKEPTICAL . . . seems this idea was floated as SBIR grant
with NASA for last year. First phase grants are generally for
one year with a potential for follow-on work several years
later. Phase I is generally $100,000 while phase II grants
of $600,000 are possible. The thing to watch for is the
awarding of a Phase II grant.
Did a quick search of the 'net and found the following
URL's that refer to to the Aqualytic ignition product.
http://sbir.gsfc.nasa.gov/SBIR-abstracts/98/sbir_html/980715.html
http://www.cda.net/stories/1998/Oct/29/S474456.asp
http://www.coe.isu.edu/engrg/ethanol.html
I recall dozens of stories about 60+ mpg carburetors, ignition
systems that boost power/mileage by umpteen percent, fuel processing
systems offering amazing "improvements" in performance, etc.
One guy even made national news about 40 years ago selling
a tablet that would convert a tank of water into a fuel
suitable for running your car.
Don't get me wrong. I wish this guy all the success that the
laws of physics are willing to let him have. However, just because
an agency of the US Government chooses to spend $100,000 on
any sort of program does not lend credance to its value.
I can think of $60M that is largely going down the tubes right
now on the AGATE program . . . but that's another story.
Keep your eyes and ears open, stroke the web with your favorite
search engines from time to time and see what happens. In
the mean time, I would be very cautious about offers to buy
any stock in the company . . .
(o o)
===========o00o=(_)=o00o=========
< Independence Kansas: the >
< Jurassic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
http://www.aeroelectric.com
Sirs:
Please remove my address from your list as I find the communication of
little or no help. All I really want to do is let Kolb owners know I
want to buy a twinstar but this has eluded me thus far!
Subject: | Ear drumming help |
Hi list members.
Thank you for the help on my ear drumming problem.
Richard Pike: My IVO prop is the ground adjustable and all the pitch
should be the same. But I will check the pitch with an angle checker. I
will definitely try using only two blades.
The exhaust outlet is facing back to the prop with 9" space between.
This could be interfering the airflow around the prop. Maybe a 90 angle
at the end of the exhaust could cure this?
Ralph Burlingame: I have been keeping it clean, but the exhaust soot
does tend to build up fast around that area on the prop. The ear
drumming is still there after I clean the prop, but I notice that a
clean prop does run smoother.
Every small thing can add up to create this acoustic problem in my ears.
I will check for the vibration in the airframe on my next flight.
Mark: My Firestar has the full enclosure, but I do not use the plastic
cover around the rear seat, supplied by Kolb. I did try it and it did
not make any difference.
JR: I am sure that all the disturbed air around the back of the cage
will cause some flexing and vibration of the propeller, and also when
the propeller passes the trailing edge of thewing, but I am so surprised
that no one else has experienced this same problem on their Kolb
Firestar.
I know that there are some out there with the same configuration as I am
using, i.e. Rotax 503 and the IVO prop 3 blade. with full enclosure.
What is a Lightspeed headset?
JR: Please tell us about the spinner problem you experienced last
weekend.
Thank you again for all the support.
Johann G.
Iceland.
Firestar II 45 hr.
In a message dated 11/14/99 2:16:46 PM Eastern Standard Time,
duesouth(at)iname.com writes:
wheel?
woody,
i have a pitot/static tube sticking 6" out the nose of my firestar.
why 6"? per kolb. the static tube is above the pitot tube. not accurate. i've
tried it with the static tube out in the wind and i've tried it with a cover
over the static tube to keep it out of the wind. still not accurate, 15 mph
too slow. i've got the trusty hall meter hanging off the lift strut so i can
depend on that. its frustrating flying along with the airspeed showing 30 mph
and the hall meter showing 45 mph . my kingdom for a solution to this problem
. .............. tim
In a message dated 11/12/99 8:39:56 PM Eastern Daylight Time,
tkrolfe(at)epix.net writes:
<< The 1 1/4" alum. angle sheared off at the outside of
Terry:
Your experience is not a fluke, the exact same thing happened to me on
the muffler mount for the 503 on my mark 2, at roughly the same total time in
service. I was at first concerned about Kolb's design, but in closer
inspection I saw that the crack had propagated from a nick left when I
drilled the hole in the bracket material. I refabricated the part in the
recomended aluminum material and deburred the drilled holes and polished them
to be sure they were very very smooth. Inside the hole and on the surface.
That same part has been in service now for over 300 hours without further
cracking. My guess is that your muffler bracket was drilled and left rough.
Subject: | Re: Ear drumming help |
Gosh, I thought everyone had heard of Lightspeed headsets. It is an ANR type
headset that is very effective at removing low frequecy drumming and they are
relatively inexpensive--try the 15K for a few flights and I bet you like--do
you have a radio and intercom? I suspect most have the drumming you speak of.
JR
Install aproper pitot static system. Come of the static port with polyflow
tubing--run a length of it out your tailboom and somewhere near the aft end
put a static port or perhaps even leave it open in the tube. Somewhere before
it goes into the tailboom "Y" off it with a "T" fitting and perhaps run it to
the bottom of your pod with another length of polyflow tubing. The idea is to
reference ambient pressure for your ASI static port and the "Y" arrangement
will allow discrepancys to balance out--small ones anyway. Static left open
in the cabin--forget it--my friend has been having the similar problem--he
thinks he has been cruising at 70MPH and I keep telling him my airpseed when
along side him is showing 55/60 at best. My airspeed has been calibrated and
is reasonably accurate in that speed range. GPS is good for calibration but a
timed triangle of known size is better. Do not forget to get your stall
speeds etc with the new arrangement--they could be very different. JR
Woody: I call the pitot tube with the static tube attached "the Stearman
type". Yes I tried that several iterations back but it required another 1/4"+
hole in the nose adjacent to the existing pitot tube hole. For the test I
taped a piece of 1/8" tube from the static tube at the nose around the side
and up into the back of the ASI. Maybe the static tube was too close to the
pitot tube or the whole rig did not stick far enough out into the undisturbed
air but the readings were all way too high. The overall amount of work
required to arrive at the final solution was of course more than I expected
but the final hook-up was fairly easy. I was hoping to save somebody from
going through the development phase as I did.
I just read my previous post and found it garbled. It should have said I am
now trying to hook the altimeter up to the static system but can't get the
static port plug fitting off of the back side of the altimeter. Any ideas out
there ?
Acting on this thread I gave my 477 muffler bracket a close up inspection
this afternoon. I found that after 50 hours the rear grommet bolt was loose
enough to allow the washer to turn freely and the front one was not much
tighter. I also noticed that the washer under the nut was in contact with the
aluminum bracket. This is an 1 1/4" washer and being in contact could allow
some of that 6,000 ~ vibration to be transmitted to the bracket. There were
no cracks in the bracket. I have packed some smaller washers in my truck and
will order some new grommets in the morning.... Is this a great list or what?
I did not read the first message on this subject so I do not know what
kind of drive you are using. If you are using a C drive that is an
older version it may have a rubber donut that is too hard. Some of the
earlier ones came with a rating of 75, I replaced mine with a 55. I
have forgot what the rating meant other than a hardness rating. I have
a much quieter and smother running 582 with C drive after changing the
rubber donut.
Kim Steiner
Saskatchewan, Canada
"John G." wrote:
> Hi list members.
> Firestar.
> weekend.
> Johann G.
> Iceland.
> Firestar II 45 hr.
>wheel?
>Woody
That is what I am using, and it has been trouble free from day one.
Richard Pike
Fellow Kolbers,
Those of us that fly "legal" ultralights without an N-number have different
operating rules than GA airplanes. Unfortunately, Part 103 regulations are
not always in plain English. Can someone enlighten us on interpreting the
FAR (103.17) that requires prior authorization for ultralights to fly
"...within the lateral boundaries of the surface area of Class E airspace
designated for an airport"?
I expect this regulation refers to surface-based Class E airspace (used to
be called a control zone) and not to transition areas that are Class E also
Subject: | Re: Airspace Rules |
Norfolk, NE's airport is surface class E, and I went through the same
thing with our ultralight club. It's best to approach the airport manager,
and with his blessing, go to the airport authority, and get theirs also. We
had to go to the Minneapolis Center for our authorization to fly ULs here,
but they went on the recommendation of the manager and board, so it was
relatively painless. So it's best to have all your ducks in a row before
you ask. It took us about 2 months to get it all done. I can scan our
request (actually sent on the Airport Authority's letterhead :>) and the
FAA's response letter and send to you privately if you like.
J.D. Stewart
NCF Communications, Inc.
http://www.ncfcomm.com
UltraFun AirSports
http://www.users.ncfcomm.com/ultrafunairsports
Challenger Owners Website and e-mail list administrator
http://challenger.maverick.net
NE Nebraska Flying Club
http://www.users.ncfcomm.com/nnfc
ICQ # 22494032
Fellow Kolbers,
different
are
also
Bruce McElhoe wrote:
> Fellow Kolbers,
It does indeed refer to surface area Class E airspace. This is
designated by a segmented magenta circle around the airport, and in this
case Class E airspace goes all the way to the ground. This means that
there is some sort of ATC facility at the field, and that there is some
(usually small) chance of IFR arrivals or departures. The facility is
often merely automated weather information. Note that any time this is
not in operation, the surface Class E goes away and Class E has a floor
of 700 AGL with the airport surface Class G.
As far as the meaning of elements of Part 103, most ambiguos things are
clarified in AC 103-6 and AC 103-7 (particularly the latter).
gil leiter
MAPLEWOOD, MN
From: | "Waligroski, Greg" <gwaligro(at)ball.com> |
On the thread of static ports and locations. I have a FS2 with a semi
enclosed cockpit and what has been an accurate airspeed indication over most
of the speed range (as verified with a GPS). The pitot source is the
typical tube sticking right out of the center of the nosepod and inflight
actually appears to point down slightly. The static is a 1/4" aluminum tube
that sticks down through the nosepod on the left bottom just ahead of the
most forward steel cage member. An inch below where it exits the nosepod it
curves aft paralell to the nosepod surface for about 2". On the 2" section,
2 x 1/8" holes are drilled into the side of the tube about 1" from the very
end. The end of the 1/4" tube is open and on the inside it is hooked into
the static port of the airspeed and altimeter via some fuel tubing. It
seems to work fine and I credit the installation to the builder Bruce
Harrison. I think I have sketches I can email to anyone who requests.
Gregg Waligroski
Boulder, Colorado
Subject: | Re: Flux remover |
>Here's an unsolicited tip for you and everybody building the microencoder.
>Don't use flux remover. The stuff that I had from Radio Shack in the can
>with the little brush on the end just smears stuff around and makes a big
>mess. After talking with RMI, I used lacquer thinner (the same ole stuff
>you clean your spray can out with, I used medium drying, but they say any
>kind is OK). You REALLY flush the board with this, and the flux comes off
>easily. The only caution is to not leave the stuff on there for very long
>(don't let it soak). Then just blow it off the surface.
I'll let you all in on another "secret" board cleaner product.
Wall-Mart stocks a carburetor cleaner that's like most of the
other carburetor cleaners . . . lacquer thinner in an aerosol
can. Of the three brands in my local store, they range in price
from $2.50 down to $0.88 . . . as near as I can tell, they're
all the same stuff . . . We buy the 0.88/can by the case and
have been using it for board cleaning for the past 15 or so
years.
Wash off liberally then use hair dryer on LOW to evaporate both
thinner and WATER that shows up as condensed humidity when the
board cools under evaporation of the thinnner.
(o o)
list-aviation ,
list-avionics ,
list-beech ,
list-cessna ,
list-ez ,
list-glasair ,
list-homebuilt ,
list-kolb ,
list-lancair ,
list-piper ,
list-rocket ,
list-rvcanada ,
list-seaplane ,
list-tailwind ,
list-warbird ,
list-yak ,
list-zenith
Subject: | Heated Pitot Tubes |
Greetings to the List,
I just received a new supply of heated pitot tubes. They are the
PH502-12CR (this used to be called the AN5812), and the AN5814-1. Both
styles of these pitot tubes are 12 volt and only come in a chrome
finish. The PH502-12CR has only the dynamic source for the air speed
indicator, but the AN5814 has a heated static source as well and it
looks good. I sell the PH502-12CR for $135 and the AN5814 is $199.
I also sell the mounting bracket kits to hold the pitot to your
aircraft. These are also available in the same chrome finish as the
pitot tubes to make a beautiful installation. These mouning bracket kits
come with all the parts needed for the installation and come with some
detailed instructions and photos of the process. This kit will work on
either a metal airplane or composite. The price of the mounting bracket
kits is $105.
All of my prices INCLUDE shipping in the US.
I have other products that may be of interest to you. If you would like
a set of flyers on my products, provide me with you US Postal Mail
address and I will send you a set.
Warren Gretz
Gretz Aero
3664 East Lake Drive
Littleton, CO 80121
303-770-3811
gretz_aero(at)h2net.net
This question came up at one of our EAA chapter meetings one night, and
since we meet in the control tower, it was pretty easy to sort out. We just
called the watch desk at ATL center and asked the Chief Controller. Then we
did the same thing with ZID, Indy center and asked the same thing. Similar
answer. Most class E airspace will underlie either an approach control or
center airspace. If it is center airspace, just call them on the
appropriate frequency and ask. We don't have anything like that at TRI, so
have no opinion on what various other approach controls might say, the
local Supervisor demurred from having an opinion, but calling on the
frequency and asking is always the easiest way, it doesn't require the
controller to make long term commitments.
Richard Pike
>Fellow Kolbers,
Subject: | Re: Heated Pitot Tubes |
Hey Kolbers and Big Lar:
We better hurry and get us one or two of these heated pitot
tubes for our Kolbs. Now, I wonder if they would double for
cabin heat also??? :-)
john h (Recuperating from 4 days of pleasant flying on the
Gulf Of Mexico with a real nice group of people. Maybe Mike
Highsmith will give us an after action report on our long
weekend. We did nothing more than fly, eat, and sleep. Got
up early and went to bed early. Weather was nearly
perfect. Everybodies airplanes performed their best and
nobody got hurt.)
From: | "Christopher John Armstrong" <Tophera(at)centurytel.net> |
mph
problem
Are you sure the problem isnt with the AS gauge itself... If you used a 6"
pitot static system it should provid good data.
I would have the gage calibrated.
Topher
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Cool ! ! ! Thank you, but why didn't you ever answer my battery question
?? Big Lar.
From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com>
Sent: Monday, November 15, 1999 4:19 PM
Subject: Kolb-List: Re: Flux remover
microencoder.
Ahoy, Defy me eh mate. Well shiver me timbers but last time I went flying
there was this phenomena called wind. Whether you perform your calibrations
with the GPS or a stop watch along two way straight line or around a triangle
of approx 5 miles or so per side you still have to account for the wind but,
alas mate, waves are not our concern lest we crash into the deep briney. Blow
me down. JR
Aye JR such a fool i am to assume that if you were comparing flying speeds
with a wing man that you would be dealingwith the same wind speeds!Live and
learn , Chris
Larry
I used the L shaped pitot/static tube from A/C Spruce on my MK III, and it
has been very accurate for me whether the cabin was partially open or fully
enclosed. It is mounted under the nose cone and extends 2 to 3 inches in
front of the nose guard that is used on the MK III. Keep it simple.
Terry
On Tuesday, November 16, 1999 3:10 AM, Larry Bourne
[SMTP:larrybiglar(at)earthlink.net] wrote:
> John, you really know how to hurt a guy dontcha ?? I'm watching this
pitot
> tube mess with dismay, cause I bought (long ago) the L shaped
pitot/static
> tubes from A/C Spruce. Now, from watching all this, I really doubt if
> they're gonna be long enuf to get out ahead of the compression zone in
front
> of the nose.
Hi Brian,
I am using the old B drive 1:2.58. Hope to replace it someday with the E
drive with electric starter.
Thanks for your help,
Johann G.
Iceland.
> rubber donut.
> Kim Steiner
Thanks for the good news. What a relief. Lar. Do not
Archive.
Sent: Tuesday, November 16, 1999 6:30 AM
Subject: RE: Kolb-List: Heated Pitot Tubes
> Larry
fully
> Terry
From: | "Bruce E. Harrison" <beharrison(at)lexhealth.org> |
Chris:
To what do you attribute the longevity and "clean" running of your 503. Oil?
Mixture? Jetting? Clean living? Luck?
Bruce E. Harrison
Sent: Monday, November 15, 1999 7:46 PM
Subject: RE: Kolb-List: Static port for ASI
Subject: | Re: Kolb-List Digest: 11/15/99 |
If you haven't yet covered you Kolb make sure you check out Aircraft
Finishing Supply in Ennis Montana. http://www.aircraftfinishing.com
They have a water based system that you use inside without all the harsh
fumes.
I just got back from one of their weekend schools and I am going to finish
my Kolb using their system. The school is well worth the cost.
Rocketman
Subject: | Instrument Panel |
Big Lar,
What material did you use for the instrument panel that you mounted on
the $50 worth of Cessna shock mounts? How much did you cut out of the
fiber glas panal? One large hole or individual holes for each
instrument/radio?
I am planning something on the same order.
L. Ray Baker
Lake Butler, Fl
Building Mark III, SN 312--N629RB
Hello Kolb List
I would like to know what oil and filter you all are
using on 912 with clutch,no Im not putting it on my firestar.
FS2 503 120hr
Duane zollinger rittman oh
Vic, if this is the stuff called System 3 or System III, I would suggest you
be careful. I bought a crashed Kolb and have just repaired the dings. Along
the way I had to repair (actually lengthen) a wing tip. All I wanted to do
was to replace the wing tip fabric. To repair poly-fiber you must remove all
the finish down to the poly fiber and poly tack the new fabric in place over a
rib that you then rib stitch (or rivet down). I couldn't get the stuff off.
Result? I had to completely recover the wing.
I now have to make some repairs to the fuselage fabric. I'm sure not looking
forward to completely recovering that also.
I tried to get to the aircraftfinishing.com web site but can't get through.
If you find out how to make fabric repairs that are acceptable to poly fiber
I'd sure like to know about it. Could save me a load of dough and time.
Thanks, Bil
> fumes.
> Rocketman
Subject: | Aircraft Finishing System |
<http://www.aircraftfinishing.com >>
AFS is not System III. I've been to two of their hands-on workshops and
it appears much easier to repair than Poly-Fiber. Virtually all of our
local EAA chapter members who restore antique aircraft have switched to
AFS from Poly-Fiber (both methods use the same fabric by the way).
Paul VonLindern and Henry Hoye are locals building a Mk 3. Their total
prior experience was one AFS weekend workshop and their first time
results are showplane quality. I'll be using AFS if/when I ever get to
covering my Firestar.
Tom Kuffel
Whitefish, Montana
PS: If the trunk lines by Ennis are anything like the "infrastructure"
in this part of the state try to be patient with their website. It's
not their fault if it's slow.
Subject: | Re: Instrument Panel |
Can I send pictures to a juno address ?? Seems like I heard about a problem
with them. Basically, I cut the fiberglass away, and left about a 1" or so
rim, to have something to attach to. Then made a practise panel out of
white fiberglass wall panel, and cut dummy instrument faces out of
posterboard, and used those to shift around and figure out arrangement.
Wound up making 2 of those. Cut the real panel out of .060 aluminum sheet,
and had a local shop give it a face of wood grain formica. Looks real good
and I don't have to worry about varnish. The finished panel is very stiff,
and is reasonably light. Regular hole saws worked fine for the holes, but
you MUST use a drill press, and take your time. A retired Canadian
machinist friend showed me the trick of coating the cutting teeth with
paraffin wax every few seconds of cutting. Keeps the teeth cleaner, easier
to clean, and cutting is MUCH faster, smoother, and cleaner. I can't thank
him enough. Freehand practise holes in scrap were a disaster, use the drill
press and clamps. I'm very glad I experimented first. Biggest hassle was
getting everything lined up nice and square, and all those screw holes even
and square, etc. 'Bout went cross eyed, and the further I got, the more I
worried about making a boo-boo. Then you get to wire the awful thing, and
make wiring diagrams, and such. Whooo-eee, would I hate to have to do that
over again. Got LOTS of pics if you wanna see 'em.
Sent: Tuesday, November 16, 1999 10:31 AM
Subject: Kolb-List: Instrument Panel
> Big Lar,
> instrument/radio?
> L. Ray Baker
> Lake Butler, Fl
Subject: | digital compass info 3rd try |
Larry & gang,
I'm having trouble sending this out, sorry if this is a duplicate.
Found the catalog! Its called "Heartland America", 1-800-229-2901,
www.heartlandamerica.com The below compass is item # PC-9100, cost is
$49.99, free
shipping. It also has a timer mode. ...Richard S
Richard wrote:
> Larry, I looked high & low & even under & can't find that catalog.
Don't
> remember the name either. Sky Vision has it for $95 & Damark
(800-328-31000)
> has it for $69.99, called Co-Pilot LC, item # B-40360-708585. It does
have
> backlighting. It has 1 degree increments, not 1/2. If I find the
other catalog
> I'll post it. ...Richard S
> Larry Bourne wrote:
> > Which catalog ?? I just looked in Cabela's Fall '99 book, and they
only
> > show the "Brunton" for $79.99. It looks real good,
but................!
> > What a co-incidence. Last Saturday, I met John Woods from San Diego
at
> > Borrego Springs, and was really admiring his Firestar. He's done a
show
> > quality job all the way through, including the trailer. Among the
many
> > things to admire was the digital compass, which I hadn't really
thought much
> > about. He's very pleased with his, and spoke highly of it; got me
thinking
> > about it; now look at the thread we've had going the past couple of
days.
> > Great minds, eh ?? Big Lar.
> > From: Richard <swidersk(at)digital.net>
> > To:
> > Sent: Wednesday, November 03, 1999 5:02 PM
> > Subject: Re: Kolb-List: Digital Compass...
> > > Listers, I seen one in a sportsman catalog for $49, it read in 1/2
degree
> > > increments, it even automatically compensated for any disturbances
due to
> > iron
> > > obects ect., it stored the tracking data & allowed you to back
track &
> > find your
> > > way home, its format was like a compass card that gave an analog
> > and also
> > > a digital readout. I thought is was backlighted but not sure on
that. I
> > might
> > > ask Santa for it for Christmas. ...Richard
> > > WillUribe(at)aol.com wrote:
> > > > Greetings
> > > > Last weekend I updated my builder's log and also added more
pictures of
> > > > Dave's FireStar. You can see a picture of his panel, it has a
digital
> > compass.
> > > > Will Uribe
> > > > http://members.aol.com/WillU/index.html
> > > > Will.U(at)voicestream.net
> > > > El Paso, TX but working in Arlington, TX... wishing I was home
building
> > my
> > > > FireStar.
Subject: | Re: Digital Compass... |
Fantastic. Thank you Richard. I was all set to spend $80.00 for the
Dunton. Lar.
Sent: Monday, August 16, 1999 6:50 PM
> Larry & gang,
$49.99, free
>Hey,
>Don't forget about the Beach Run if the weather is good. Let me know so I
>can make arrangements. We may have a pile show up.
>Firehawk
Tell us how the "Beech Run" turned out, sorry I missed it.
Big Lar,
Thanks for the input. Please send any available pictures. For a mere
$30 per year Juno adds the ability to send and receive attachments.
L. Ray Baker
Lake Butler, Fl
Couple of things kind of have me going right now. #1, I'm running out of
stalling on covering my plane, so got out this old iron, and started to
calibrate it. Guess I've got about 5 or 6 hours now, hovering over that
awful thing, and still only 1/2 done. Temps don't seem to stay put, or be
repeatable. Is there a simple way to do this ?? #2, as many of you know,
I'm building Vamoose on a 7' x 40' screened porch on a mobile home in a
retirement/snowbird park. Snowbirds are now in town. Recently moved the
plane into the driveway, to have room to spread the wings, and ran into an
unforeseen problem. These 'birds, mostly Canadians, and really great,
sociable people have been following this mighty project with great
interest - many bringing friends and visiting family by to show off the
local nut. Last weekend, I had it 1/2 in the driveway, 1/2 in the street,
with the wings up, and starting to install the center gap cover (??) seal
(??). Anyway, the between the wings cover. I'm installing it permanently,
ala Ron Christensen, and running into a fair tangle. Time consuming too.
Anyway, soon had a procession of curious people hearing the word, and coming
to take a look. Being a motor mouth myself, (has any one noticed ??) you
can imagine how much work got done. Sure was fun though. One ole boy,
a retired hot dog (! ! !) salesman from Seattle, got to looking at the tail
end of it, where I've started mounting the folded wing attachment points,
and wanted to know what the h--- is this. When I told him, he said
something like, why don't you make a shaped and padded bar to fit on the
steel tube that holds the aluminum tail wheel support bar. Set the leading
edge of a wing on each side of it, and it'd be much more solid and secure
than the pin and socket we have now. It'd hold the wing a lot higher off
the ground too. Makes sense to me. How about you ???? #3, I want to
install my radio antenna the way Erich Weaver did - inside the nose cone
ahead of my feet, with the excess length sticking out of a grommeted hole in
the top of the nose. It is FAR and AWAY the very best installation I have
seen, and I'm gonna copy him. It even gives a good place to tie your yaw
string. Erich's already said OK, and I say thanks. For a ground plane, I
have a large piece of heavy aluminum foil that I plan on gluing to the
entire lower portion of the nose cone. My questions are: will the foil be
sufficient for a good ground plane, and does the antenna have to actually be
mounted solidly on the ground plane, or can it sit on a bracket several
inches above it ?? The fancy rudder trim assembly I invented is pretty
much in the way of a simple installation of the antenna. As a
parting "by the way", I ordered the prop, and exhaust system this morning.
Another 1000 dollar bill gone. That's 26 of them now, and prob'ly 1 more to
go. This is starting (??) to hurt. Well, that's more than enough B.S. for
now. Later all. Big Lar.
Subject: | Re: digital compass info 3rd try |
You're in good shape, Richard. Came thru all 3 times. Lar.
Sent: Tuesday, November 16, 1999 8:02 PM
Subject: Kolb-List: digital compass info 3rd try
> Larry & gang,
I'm glad you brought up this question Bruce, as I've
often wondered about it too. From the responses here,
is it an accurate summary to say that flying an
ultralight in Class E, regardless of it's floor level
( ground, 700, or 1200agl) requires prior
authorization? I guess I'd also like to know if there
is any communication requirement for other light
aircraft (is that FAR 91?). Maybe from flying in
small planes (cessnas, etc) with friends, I get used
to the idea that Class E doesn't matter, i.e. do what
you want. On the other hand, maybe that's exactly the
sort of thing that irritates the GA rated folks. My
only lame justifictions have been that a) my Kolb
doesn't appear on radar any different than a Cub (i.e.
they can't know I'm breaking the rule), and b), flying
thru E space at 1000 agl seems like a small sin if it
is a safer gliding altitude for me and I know the area
is very uncrowded and very good vis. Also, there is
the c) aspect to my reasoning -- that is, I've never
asked anyone before right now if that actually is
against the FARs. Is it?
-Ben Ransom
> > Fellow Kolbers,
> ultralights to fly
> airspace. This is
> that there is some
> Class E has a floor
> ambiguos things are
> latter).
> gil leiter
> MAPLEWOOD, MN
> through
> Settlement...
> http://www.matronics.com/jpi.html
From: | "michael highsmith" <firehawk54(at)hotmail.com> |
Well guys, you just wouldn't have believed it. I'm still basking in the
after glow of 4 days in the air with people that are as much fun to be with
as you think it could get. Of course I think, that every time we do the
Beach Run it can't get any better, then it does.
John H (Hawk 36)(Kolb MKIII)called on Wed. Said he'd be here Thur. PM. I
met him in the air that afternoon right over the beach banner port as he was
coming in over West Bay from the North. After a few gigs and jives and tag
the tail of the new dog, Hawk 36 did a low pass and came around for a short
field landing on our 900' strip to the north over 100' tall trees. "Don't
forget about landing on the west side of the middle" I thought, ups too
late. Hawk 36 beat and frammed right down the roughest part where the banner
planes always beat it out. No problem though with those big 850 tires pretty
"Ms. Pfer" wears, once down she was stuck. I'm right behind in my Ferguson
FII (Firehawk). I land a little to the west where it's slightly smoother.
Hawk 36 finds his spot and I pull up to my hanger space. It must have been
4:00 by this time. "Hey, how in the world are you? I'm so glad you could
make it. Trip go okay? What's with this not having a radio? We'll get you
one while your here". We began to unload Ms. Pfer. After John unloaded his
house, his bed, a week of cloths, and the kitchen sink, I began to wonder
just how he got all the stuff in there to go all the way to Alaska and back.
We stuck some of it in the hanger and loaded the rest in the pick-up truck.
Now it was time to relax by the pool at my place, and wait for Cindy (my
best 2/3s part) to get home from work (as we say around here, "Someones got
to do it") so we can go to Uncle Ernies on beautiful St. Andrews Bay for
dinner. The night was clear the temperature was perfect at Uncle Ernies and
the smooth water on the bay told us we were in for a good day to fly on
Friday. After that meal, and "The Temple of DOOM" on home theater, it is
time to get some sleep. 1st Day
Are you salivating yet?
More later, Firehawk
Subject: | Re: Aircraft Finishing System |
Tom Kuffel wrote:
> < stuff called System 3 or System III .. repair poly-fiber you must remove
> all the finish down to the poly fiber .. couldn't get the stuff off ..
> Ennis Montana .. http://www.aircraftfinishing.com >>
Where did you get the idea that to repair PolyFiber covered aircraft
that "...you must remove all the finish down to the poly fiber..."?
You don't have to remove ANYTHING at all. Just scuff the surface in the
area of the damage, apply fabric patch with PolyBrush (NOT PolyTac),
heat shrink fabric loose areas, and then apply the same coats as the
rest of the structure had. Can be easily rubbed out to blend in the
repaired area with the old. Could'nt get it off? What were you using,
water? If one does want to get it off it wipes off VERY easily using
MEK.
The above applies to PolyTone as the final color coat. If you used
AeroThane as the final color coat than that changes everything.
AeroThane, like ALL cross linked urethanes is no longer soluable and
cannot be removed. It is also much more difficult to repair.
gil leiter
MAPLEWOOD, MN
The above
> authorization?
NO! ULs have to have authorization to fly in surface area Class E, but
no authorization is required to fly in "regular" Class E. Between
airports the floor of Class E airspace is usually 1100 AGL. As one
approaches a non towered airport the floor drops to 700 AGL. Such
airports are marked with a broad magenta band, "hard" on one side and
"fuzzy" on the other. Below all such Class E airspace is Class G
airspace.
If a non towered airport has dashed magenta band (as opposed to the
broad magenta band) then it is Surface Area Class E, and goes all the
way to the ground. Here we must have authorization. Surface area Class
E exists because some sort of ATC facility is available at the airport
and some IFR traffic might be present. This is often merely automated
weather reporting facility.
In the midwest and west most of the airspace between airports is Class G
except for the Class E airways. In the eastern part of the US this
airspace between airports is almost all Class E, and the Class G
airspace has a ceiling of 1100 AGL.
What is the difference between Class E and Class G? The only difference
is that Class G has very loose weather minimums, and Class E has more
strict weather minimums. This relates to greater visibility and
required distance from clouds because there might be some IFR traffic.
> -Ben Ransom
Communication is not required except in Class D or higher. HOWEVER, it
is certainly good practice (and appreciated by all) to have and use a
radio in the vicinity of a non towered airport. Identify yourself and
your intentions.
To really learn about airspace I strongly recommend the airspace video
put out by King.
gil leiter
MAPLEWOOD, MN
> gil leiter
Gil and Kolbers:
Repairing aerothane hasn't been that difficult for me. If
you break your airplanes often enough you get a lot of
practice. ;-) After crashing thru a big red oak tree in
1992, it required more than 20 patches to repair the
fuselage fabric alone. You still have to look hard to find
them.
I use round patches and mask for doping and painting in a
square or rectangular pattern. Scuff sand the aerothane
surface after trimming the area to be patched in a round or
oval pattern. Make sure the patches are aligned in relation
to the airframe. Makes them less noticeable. Be sure and
mask the area to be sanded. Allow plenty of overlap. Use
pinking shears to cut the patch after lightly ironing the
patch material to get the wrinkles out. Use "Polytac" to
cement the patch. Use care to mask and cover areas other
than the patch to prevent overspray from ruining the gloss.
Take your time. It will take several days to go thru the
process to completion, but you will be happy with the
results.
I have never had a patch on aerothane pull loose, large or
small, and they all look pretty good.
Big Lar asks:
<<#3, I want to
hole in
have
yaw
plane, I
foil be
actually be
inches above it ??>>
Al foil can serve as a ground plane but there are difficulties. The
braided end of the cable must be connected to the ground plane at the
vertical element but Al foil is very difficult to solder. Copper foil
would be easier if you can find some. Be sure to keep metal as far away
from the upper end of the vertical element as possible. The ground
plane acts as a mirror to generate the "missing" half of your vertical
antenna. The farther away from the ground plane the vertical element
starts the worse the performance. No hard and fast rule but more than
an inch or so would be detectable. And the farther away you start the
more you will need a balun to suppress unwanted current on the shield
braid. Suggest you visit Jim Wier at the RST site for more
information: http://www.rst-engr.com He also sells nifty ferrite
toroids which do a great job as a balun.
Tom Kuffel, AL7AU, FCC Commercial 1st Class Phone
Subject: | Poly-Fiber repairs |
A1-type: MAIL
Bil wrote:
I tried to get to the aircraftfinishing.com web site but can't get through. If
you find out how to make fabric repairs that are acceptable to poly fiber I'd
Thanks, Bil
Bil,
If you contact Jim or Dondi Miller at Aircraft Technical Support they will be
glad to give you the answers you need. They are distributors for poly-Fiber
and very knowledgeable about the product as it applies to the Kolb planes. I
have made several calls with lots of questions, each time they were very
friendly and helpful. Their # is 877-877-3334 .
Steven
Building MKIII/582
N58SG (reserved)
Subject: | Re: Kolb-List Digest: 11/16/99 |
Tom is correct. This is not system III. I didn't ask but I would guess it
is not compatible with Poly-Fiber but I you should never mix systems. I
have done Poly-Fiber and while it works great, I would have to wait until
Summer to cover my Firestar. With AFS I will be able to cover in my closed
heated garage. I highly recommend the class. It is well worth the money.
Rocketman
The FAR's are online at www.faa.gov.
I agree with Gil.
If it's class E airspace "designated for an airport" you need
permission from the "ATC facility having juristiction" to
fly through there.
chuck
Subject: | Re: Poly-Fiber repairs |
Call up Polyfiber and ask for their new covering manual. It does not cost
much and is an excellent resource. Basically reppairs for Polyfiber are no
different from the Acceptable Methods and Practices of AC43-13 with some
exceptions. Certain types of holes, tears, punctures may be repaired by
overlaying a patch with Polybrush without sewing unlike standard repairs. JR
Subject: | DON'T WAIT ANY LONGER! |
If your waiting for that ultimate post that will either:
A) Make you finally feel guilty enough to contribute.
B) Make you laugh so hard you give up and pull out your credit card.
C) Make a contribution in hopes that these pleas will just go away.
Well DON'T wait any longer......It just isn't going to happen. I have been
watching and waiting for something interesting to be posted like Matt's
ride last year in Brian Lloyd's YAK and subsequent picture of a hairy
Pillsbury Doughboy to make fun of but it just hasn't materialized. The list
has been VERY active with things like bolt lengths, engine horsepower,
gyro's, new web sites and flux removal.
Now this stuff would give Steve Martin or Robin Williams a hard time to
find material in. (Anyone want to take a stab at making an aileron
bellcrank post funny?) Well I'm reading all these and it comes to
me......this is what the lists are all about. Exchange of information. I
read a couple of posts of new guys getting information that will help them
make a decision about the airplane they choose to build and how to equip
it. On the RV-List I learned how control surfaces on B-767's can be
operated independently of each other and when and when not to remove solder
flux from an electronic project.
My point is that there is a ton of stuff that we are all learning from ALL
of these lists. All you have to do is read it. You also have the added
capability of asking questions if there is something you don't understand
and getting a timely answer from someone for clarification. This HAS to be
worth something to you. It should be. Why not dig deep right now and figure
out what that amount is? I'm sure can can come up with some figure. Well,
write it down and divide it by twelve and take a look at what it would cost
you per month for all that entertainment/information/insight. It's really
not all that much is it? Please click on the secured URL below or write a
check out right now and know that you have been instrumental in making all
of this possible. Thanks for reading this and sorry I couldn't think of
anything better to write but I need some seed material..............AL
To make a SSL Secure Web Contribution using your Visa or MasterCard, have a
look at the following URL:
http://www.matronics.com/contribution.html
To make a Contribution by check, please send US Mail to:
c/o Matt Dralle
Matronics
PO Box 347
Livermore, CA 94551
Ben,
As I see it, the response from Gil Leiter is right on. There are two kinds
of Class E airspace. The surface-based kind requires prior authorization to
enter -- gotta' call 'em on the radio. The other kind is in airways (floor
is 1200 AGL) and transition areas (floor is 700 AGL) -- these areas are free
for us to use without radio contact, as long as visibility is 3-miles.
> authorization?
No. You need to call in only for "surface-based Class E" -- shown on the
charts as bold dashed magenta line (eg.,Yuba Co. airport & Red Bluff).
The fuzzy magenta line around Yolo Co. airport is a transition area, and
means you need 3-miles visibility above 700 AGL (elsewhere 1 mile is enough
below 1200 AGL) -- An important distinction during these hazy valley days.
I understand that GA aircraft are not required to have prior authorization
to enter surface-based Class E airspace -- though as a matter of practice
they generally do broadcast their intentions.
>flying
Two answers: If you are flying at 1000 AGL outside a transition area (where
the floor of Class E is 1200 AGL) then it is perfectly okay to fly (you are
in Class G), and you only need 1-mile visibility and clear of clouds. If
you're inside a transition area (enclosed by a fuzzy magenta line on the
chart) then at 1000 AGL you are above the 700 AGL floor and it's okay as
long as you have 3-miles visibility and 2000 ft from clouds. No radio
contact is required in either case.
I'm glad this discussion came up -- I like the confidence that comes from
having to think it through.
BTW, we are moving smartly toward the day our Firefly gets going. Thanks
for your advice on wheels and tires. I found a couple of evenly worn
6.00 -6 Aeronca tires that weigh a little less than the balloon tires you're
using. I thought we might try those on the Azusa metal wheels. .
Good luck with your renovation.
Bruce McElhoe FireFly #88
Reedley, Calif.
Subject: | Re: Ground plane mat'l for antennas |
As Tom K says, Al is hard to solder to, and copper hard to find. Here's
two sources of copper sheet/foil: try a better class roof/guttering firm
for small pcs. of sheet stk--a bit heavy tho. Or try a craft
shop/stained glass supplier for thin stuff. I don't mean using a zillion
strips of the foil I put around stained glass construction!
bn old ham, old mech, really old pile-it
Subject: | Re: Calibrating That Iron |
Larry, Most irons are notoriously unreliable, ie, they do not repeat the same
tempt for the same setting. Consumer Reports said that the Black & Decker
K-Mart Special was among the best in that regard. I used a Radio Shack product
that is used to paste heat sinks to electronic components to paste my
thermometer to the iron & eliminated any doubt due to conduction. The gooey
white paste just wipes off. ...Richard
Subject: | Calibrating That Iron |
Another way was suggested in the Poly-Fiber manual which I found worked very
nicely.
Obtain the mercurcy candy type thermometers - PolyFiber has one they sell.
It looks like a regular thermometer except it is calibrated for a higher
temperature range. Lay a comfortably thick stack of paper towels on your
workbench, lay the thermometer on the towels and carefully set the iron on
top of that. Place the iron so you can read the 200+ degree range without
moving the iron. Now just set the iron to a setting and wait for awhile to
see where it stabilizes. Adjust if necessary and wait for it to stabilize
again. By trial and error, you'll soon be where you want to be.
If you pay close attention, you'll see the temperature will vary a
significant amount as the iron thermostat cycles on and off. Not much you
can do to about that, the iron will also be doing this as you are ironing.
Adjust so the range is centered about the setting you desire.
Normally, I'll set the iron back on the thermometer as I am using it to make
sure the temps stays where it is supposed to be. Never can tell when you
might accidently bump the thermostat.
Dennis
-----Original Message-----
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard
Sent: Wednesday, November 17, 1999 7:00 PM
Subject: Re: Kolb-List: Calibrating That Iron
same
product
know,
permanently,
coming
boy,
tail
leading
in
I
be
be
morning.
to
for
>nicely.
>temperature range.
How about digging into the box of parts you will someday call an airplane
and dig out the cht. Wouldn't this make a good thermometer for calibrating
the iron.
Woody
Subject: | Ist half Day 2; Beach Run |
Friday morning came John and I had breakfast on the tenth fairway.(I live
at the Hombre Golf Course). Eggs and eggs, toast and coffee. I had a little
work to do before we could get in the air. I called a new buddy that lived
up the county to ask to borrow his radio for Hawk36 while he was down for
adjustments with his new Firestar II. He agreed. We would have to fly up
there and retrieve it, some 20 miles north. Around 10:00 or so we departed
for O.E. Moon's new place where he has only had planes fly in or out for a
few weeks, mostly us. Me and my wingman Richard was the first to do so.
2500' of dirt with a little grass on it but it was smooth and packed.
The air was smooth and cool. Hawk36 followed me because he didn't have a
clue where I was going. Our cruise was around 80-85 mph. We headed north to
Crystal Village so I could show Hawk36 where I was going to move my
operation next year if I can get the hanger up and the economy holds strong.
We circled around the air strip and then headed for O.E.'s some 15 miles to
the east. That's what we call him too, OE. Short little guy 5' about 70
years and 125 lbs. But he has the heart of a Bull. If he thinks he can do it
you better get out of the way cause OE is coming through.
After landing I introduce John to OE and OE invites us into his big and I
mean BIG hanger. 55'x120'with a roof height of 19' for a Firestar II. Hawk36
thinks he can land in it. He also has about a dozen cars in all stages of
reconstruction, his Firestar II folded out, a big laundry and sewing room,
tools of all kinds and his travel trailer with the owning out just so Ms
Shirley (OE's wife) will feel at home. We except a soft drink then sit and
talk a spell. OE gave us his radio and it hooked right up to Ms Pfer's
holder and power cord.
It's time to head for the Creek as Richard would say when he's ready to
fly. So we did just that. We took off for Sandy Creek Airpark where Jim
(Yellow Jacket-YJ who flies a Firestar II) and we think Richard (Bluebird-BB
who flies a Challenger CWS) is waiting for us. It turned out that Richard
was still at home waiting for Ted (White Lighting-WL who flies a Firestar)
to show up from Opelika, AL.
John and I were on our way south when YJ came on the Radio and told us about
BB's delay. YJ would come on down to pick us up for some lunch at Arbie's in
down town Callaway. YJ lives just north of the Creek and we usually fly
right over his place so he knows when to pick us up.
Sandy Creek airpark runway is so smooth most of the time it's like a big
green strip of carpet. Nice taxiways, nice homes, nice EAA hanger, and lots
of hungry All-jaws. (You know the little set of wings with the big set of
teeth that bite and run but you don't know you've been bit until you see the
blood running down your arm from your unconscious scratching). By the
millions, makes me itch all over just thinking about it.
We park and head for the protection of the hanger where one of our EAA
members is working on his Mini Max. Jim comes up and we head for town and
some lunch before we can head out for a test beach run in the afternoon.
Head 'm up and move 'm out to Arbie's we go.
We'll try to do so more tomorrow, and I'll try to finish before I leave on
our next XC to Gator Field down near Clermont, Fl. this weekend for their
annual banquet and Fly-in. You sure you can't go with us John? Rut's Mom is
going to put us up.
>Big Lar asks:
><<#3, I want to
>hole in
>have
>Tom Kuffel Replies
Hey guys, I have used a "Radio Shack" rubber duck antenna ($7.95) hooked up
to a "Del.Com" hand held radio ($160.00) for 4 years.
The antenna is made for an automobile "FM" stereo. Last week I picked up &
talked to a guy in Dalton GA.(60 miles north of me and some guys in
Phoenix, Alabama (80 miles South of me) - we talked about the "Beech Run"!
And how we thought it would be "too foggy" to go down there. The point
is-you don't have to spend a lot of money or time up-front on your radio
equipment "before" your plane is in the air. I do have an aluminum ground
on the bottom of the nose cone.
Subject: | Re: Ist half Day 2; Beach Run |
Hey, did you guys land at the "light house"
<http://users.erols.com/lthouse/csgtr.htm.> or not?
Subject: | Re: Beach Run, again |
Hey, did you guys land at the "light house"?
<http://www.mexicobeach.com/apalachicola/lighthouse.html>
> nicely.
Calibrating to the center of the range is OK for the lower temperatures.
However, when calibrating for the 350 final temperature this could be a
big problem. Remember that at about 375 bad things start to happen to
polyester. First, the fabric will start to loosen at about this
temperature, and a bit higher it will start to decompose. If the iron
is cycling over a significant range the UPPER end of the range could put
it uncomfortably close (for me, at least) to the temps where problems
could take place. Keep in mind also, that the range over which it
cycles is most likely NOT constant over a wide temperature span.
Solution if cycle range is large? Get a better iron! How do you know
if a potential candidate is indeed a better iron? Sorry, but I have no
idea. Best bet is to find some other user who has found an iron that is
reasonably stable and buy the same model.
gil leiter
MAPLEWOOD, MN
> Dennis
Me too. I just keep the thermometer on the papertowels all the time - gives
me peace of mind.
Date: Wednesday, November 17, 1999 6:47 PM
Subject: RE: Kolb-List: Calibrating That Iron
very
>nicely.
make
>Dennis
>From: owner-kolb-list-server(at)matronics.com
>To: kolb-list(at)matronics.com
>same
>product
gooey
be
>know,
an
October 30, 1999 - November 18, 1999
Kolb-Archive.digest.vol-bt
