Kolb-Archive.digest.vol-bw
January 05, 2000 - January 22, 2000
Seems like that would be cleaner than having the full hinge exposed.
Maybe not, just asking.
I found myself just looking at it today trying to decide what to do next.
Our Best
Tim Townsend
Subject: | Fw: How Many Gallons |
----- Original Message -----
Sent: Wednesday, January 05, 2000 11:23 PM
Subject: How Many Gallons
Me again,
The wife and spent I some time in the CPS catalog today making a
shopping list. We are at $1000.00 before the Polytone.
Do any of you know how many gallons of the final Polytone is needed
for a mark III? Lets say just for the base color. It sure is getting
exciting now.
I can see it all coming together now, what a neet thing to do in your spare
time.
I am also going through Dallas Shepherd's 582, it is in great shape. I am
just
going to replace the rings and lightly hone the cylinders. While I have it
a part
I am thing of painting the complete engine red and all the hardware black.
Carburetor solvent makes it look better than new, Maybe I should leave it.
What do you think?
Our Best
Tim Townsend
Subject: | Re: Fuel tank caps. |
L Ray
I used this clear tygon tuben that I got at home depo it is about 1 1/4 dia.
I slid it over the nozel of my gas can and it was long enough so that the
fill can was outside of the plane ,it workes great
Rick
From: | "Richard Neilsen " <NeilsenR(at)state.mi.us> |
Subject: | Re: Fw: When to Cover |
I followed the instructions and temporally mounting the hinges before covering,
removed, covered, then installed the hinges. I later recovered a flap that had
the hinge installed. I much prefer the looks of the hinges that had been removed
before covering.
Rick Neilsen 20hrs VW powered MKIII
I certainly hope you made some provision to ground everything together.
Using plastic with pouring gas is a very scary and dangerous thing to do.
The resulting explosion, fire could ruin a good flying day.
(Click here to visit our Club site at http://www.bellanca-championclub.com)
-----Original Message-----
Date: Wednesday, January 05, 2000 11:44 PM
Subject: Re: Kolb-List: Fuel tank caps.
>L Ray
dia.
> Rick
Subject: | Re: Fw: How Many Gallons |
I have been told that black painted engines dissipate heat better for
some reason. Anyone have any insight regarding ths point? Would our
engines run cooler if black?
Dan
had the hinge installed. I much prefer the looks of the hinges that had been removed
before covering.
> <<<<<< pins and cover everything being careful around the hinges?
Morning Gang:
When I build, I build the entire airplane, using Clecos and
aluminum rivets when necessary. I want everything rigged
and fit before I start messing with fabric and paint.
The aluminum rivets from the local hardware store were great
for temporarily attaching hinges because they were easy to
drill out prior to covering.
I make sure I do all the wiring and plumbing before
covering, trying to keep in mind, "Am I going to have to get
back in there to repair or replace something after it is
covered." Now is the time to plan on inspection plates,
access holes, etc. Try to make it easy on yourself now and
then further on down the road.
As for covering and painting supplies: I personally would
stick with the professionals, Jim and Dondi Miller. They
are on the Kolb List, provide covering kits for new Kolb
Aircraft, and can and will answer the many questions you
will have when you start covering and painting, especially
if it is your first time. It has been so long since I have
had to cover and paint, I will rely on their current
experitise to get me started and thru completion, when the
time comes.
I have had real good luck covering and finishing Kolbs.
What I learned, I learned from the old Stitts Manual, Kolb
Builder's Manual, and by "getting my hands dirty." Also by
talking to people who had been there and done that, had
already made the mistakes, and by looking at a lot of
airplanes at air shows.
Here is one cardinal rule that you must follow to cover and
finish successfully: What you start with is what you are
going to finish with." What that means is do the very best
you can at every step of the process. If you go to the next
step before you have done every thing you can to smooth and
finish the last step, those boogers are going to be there
when you shoot the last cup of paint. The most important
tool in covering, to me, is the 1100 watt iron and the
little model airplane iron. Learn to use these tools and
use them a lot. Pay attention to detail and don't go to the
next step until you have absolutely done the best job
possible on the step you are presently working on. Don't be
afraid to turn that old iron up high to smooth poly tac and
fabric wrinkles down on larger tubes. The tubes will act as
heat sinks and pull most of the heat away quickly. Enjoy
learning to cover, use all the assets available to you,
especially Aircraft Technical Support, Inc., do a good job,
be proud and enjoy your Kolb.
Cy and Kolbers:
Thanks for the information.
How do we go about grounding our plastic gas tanks, filler
hoses, fuel can, etc.?
Which Kolb are you building, or interested in building?
Subject: | Cooling system pressures |
Pressure is like voltage. You're measuring the "pressure drop" at a
specific point in the cooling system. The caps could be working perfectly
and you can still see 18 psi between the two radiators. I would suspect a
blockage in one of the radiators. You might try bypassing the radiators
(one at a time) and see if the problem "follows" a specific radiator. I
have no experience with Rotax cooling systems but I've seen this type of
problem in cars. Please let us know what you find.
Gordon Arbeitman
gordona(at)us.ibm.com
(512) 838-9714 (voice)
(512) 838-9716 (fax)
Subject: | Any North Georgia members out there! |
Are there any list members in the North Atlanta or Alpharetta, Georgia area?
If so let me know so we can connect. Would like to know where you're flying
from, etc.
Jon Berndsen
Alpharetta, GA
A black object radiates heat at all frequencies of the electromagnetic
spectrum if it is hotter than its surroundings (black body radiation).
Other colors radiate in a more limited spectrum. Thus black objects
radiate more heat.
However, in our engines, heat is mostly dissipated by convection (air
moving over it) rather than by radiation. I don't have any figures, but
I would suspect that heat dissipation by radiation is a very small
fraction of total heat dissipation, especially if there is significant
air movement over the engine.
> Thanks
> Dan
* Bill Weber * Thunder's just the noise *
* Simi Valley, CA * Lightning does the work *
> Cy Galley
I agree that this can be a problem. However, grounding a non conducting
surface will not do anything to solve the problem. Also, keep in mind
that the overwhelming majority of UL gas tanks are made of one polymer
or another.
In the "Mr. Funnel" thread recently, there were those who strongly
advocated grounding the airframe when re fueling. Sounds like a good
idea. When filling your gas can (usually plastic) from the gas pump it
is important to keep the hose nozzel (which is grounded) in good contact
with the side of Mr. Funnel (which is conductive). When pouring gas
into the UL tank from your mixing container I am not sure what you can
do to reduce potential (pun intended) for a problem.
gil leiter
MAPLEWOOD, MN
> Thanks
> Dan
Any material body above 0 K is constantly giving off electromagnetic
radiation. This is what IR (night vision) detectors see. The hotter
the body, the more the peak shifts to the IR. Yes, if the body is black
it will more efficiently give off this radiation. Conversely, if it is
sitting out in the sun exposed to similar radiation it will more
efficiently ABSORB the radiation. To test the effect, sometime feel the
different colored surfaces of aircraft on the flight line. One time I
felt two spots within a couple of inches of one another. One was white,
the other a pale yellow, and they were at significantly different
temperatures.
That said, however, I don't think the "cooling effect" by this method
would be measurable, or at least usefully so.
gil leiter
MAPLEWOOD, MN
removed before covering.
> > <<<<<< > pins and cover everything being careful around the hinges?
> Morning Gang:
I did a similar thing. If the location was convenient for clecos, I put
them in. In some cases however, if clecos are in place one cannot test
movement of ailerons etc due to the obstruction of the clecos
themselves. In this case I took hardware store pop rivets and knocked
the mandrils out. Then inserted them in place and put a narrow band of
filement tape (3M brand, of course ;-) ) over them to hold them in
place. Worked real well, and saved need to drill them out later.
gil leiter
MAPLEWOOD, MN
Typical heat balance losses from an ideal engine that accounts for
all energy in a unit of fuel:
fuel energy equivalent - 5410 hp
total energy lost through exhaust - 2790 hp
total thermal losses - 1020 hp
radiation - 290 hp
conduction to air - 600 hp
conduction to oil - 130 hp
mechanical losses - 300 hp
output brake hp - 1600 hp
J.Baker
> or another.
Providing a current path to ground will solve the problem. Once the
spark jumps, it's all over.....
All that's necessary is to run a conductor from the tank, of
whatever material, to the fueling container and assure that the
airframe is gounded as well.
J.Baker
Subject: | Re: Engines Black |
Bill,
You are exactly right. I Read article where they tested the tempts of
same engines painted different colors. The difference was almost
undedectable. They made the same conclusion you did. ...Richard
Swiderski
> radiate more heat.
> > Thanks
> > Dan
gill,
It is my understanding that all materials can acquire electrostic charges
on their surface. In the case of a "nonconducting" plastic can, the moving
fuel can build up a static charge on its surface untill it builds up enough
potential to jump to the nearest ground. This spark has caused many a
surprising fires. An alligator clip & wire connected to your can, funnel &
frame equalizes the static surface potentials & eliminates the possibility of
the spark. Thank goodness this doesn't happen much in the usually humid FL
weather. I must admit I never have grounded my equipment. I also know there
are many pilots who used "nonconducting" funnels & cans that regrettably
wished they did ground their fueling process. I guess I need to add to my New
Years Resolutin list ...Richard Swiderski
> > Cy Galley
> or another.
> gil leiter
> MAPLEWOOD, MN
From: | "michael highsmith" <firehawk54(at)hotmail.com> |
Hey Gang,
>From: Richard <swidersk(at)digital.net>
>charges
>of fire.
Don't forget, that static electricity can also travel through your body.
If you are touching the fuel can or fuel nossle with your bare skin; ie
hand, you are grounding the fuel container to you. If you then touch and
make continuous bodily contact with your plane as you pour the fuel there
isn't much possibility for a spark unless there is a thundercloud near by.
I do this when fuelling: I pick up the fuel can or nozzle with one hand and
place my other hand on some part of my plane such as the engine or tail
boom, this discharges any potential static build up.
Then I place one hand on the nozzle to guide it to the fill hole. With my
elbow, or head or any part I have bare I can ground again to any part of the
plane before I actually let the nozzle touch the tank or fill hole, once the
nozzle has make contact with the tank or plane in any way I keep it in
continuos contact as I pour. This dissipates any static charge as it occurs.
"No gap, no spark, no fire".
Going flying up to the Maule plant at Moultrie, Ga. again this weekend. I
heard that there were some EAA members up there that has forgotten what they
joined the EAA for. We'll give them a little taste of what flying is all
about. There should be about 10-12 planes.
Some say there is going to be a "Poker Run" and country food.
Firehawk
Subject: | Re: Fuel tank and sparks |
Hey Gang,
>charges
>of fire.
Firehawk
Subject: | coolant overpressure, head gasket? |
Jim<<<Jim/ list:
> I have been following this thread, and wondered, Could a leaking
>cylinder head gasket cause this?
That was one of my guesses too (and it may still be a factor), but it still
asks the question, how can the pressure get to 18 with a 13 psi cap? I
have retorqued the head (nuts didn't move, just clicked), no change. And I
will eventually get down the list far enough to put in a new head gasket if
something else doesn't fix it first. And I will report the eventual fix.
Thanks for the input!
Jim
Havoline has an "Extended Life" coolant available too, which says "silicate
and phosphate-free" . I picked up a gallon at NAPA for $7.50 yesterday.
Says it conforms to newest GM requirements, and is a pretty orange color.
Jim
Subject: | Re: coolant overpressure, head gasket? |
I
> Jim
Jim and Gang:
If I understand your comment above, ref retorquing your
cylinder head, you not may have done the procedure
correctly. As I understand, to retorque a nut or bolt one
must loosen first, then sneak back up on it to the correct
torque. If one doesn't break the bolt loose first, it will
probably be stuck and give a false reading.
A leaking head gasket on a two stroke will let you know in a
hurry it is leaking. I am sure you will get a lot of oil in
the coolant of your cooling system. If no oil is found in
coolant, I personally would not go to the trouble of
replacing cyl head and base gaskets, unless it makes ya feel
better. :-)
Sounds to me like the pressure cap is not releasing
immediately at its rated capacity. For some reason the
release valve is sticking until it gets hotter or until it
gets a little over pressure, or both, to pop it loose.
Don't think any of those caps are precision instruments and
we should probably not expect them to perform perfectly.
If I remember correctly and read your post correctly your
pressure pickup point is between the radiators. If so,
isn't that on the back side of the water pump? Seems that
you could get a lot of variation in pressure on the back
side as the thermostat opens and closes, and rpm changes.
Or without a thermostat installed, pressure fluctuations
from different eng speeds and temps.
I think sometimes we get wrapped around the axle with
instrumentation on ultralight power plants. I personally do
not use a pressure gauge for coolant on the 912, and didn't
when I was flying the 582. If I had coolant pressure
problems I didn't know about it.
I did have leaking shaft seal, happened at OSH 93. Asked
some of the Rotax gurus what I should do. Told me to fly it
home, which I did with no further problem, except drooling
oil reservoir. Changed and upgraded the water pump seals.
Don't think over pressure caused the seal failure, but there
were signs of wear on the shaft. Don't remember if I was
running distilled water back then. I do know I was not
running low silicate antifreeze. Heck, did not know it
existed until last Fall. But remember, this was a 1991
model 582 with about 200 hours on it. I think they have
upgraded this system several time since then.
john h (thinking out loud at hauck's holler, alabama)
From: | "Christopher John Armstrong" <Tophera(at)centurytel.net> |
>fuel energy equivalent - 5410 hp 100%
> radiation - 290 hp
>J.Baker
converting to percentages just for fun
energy HP %
fuel energy 5410 100
exhaust 2790 51.57116451
radiation 290 5.360443623
conduction air 600 11.09057301
conduction oil 130 2.402957486
thermal total 1020 18.85397412
mechanical 300 5.545286506
powerout 1600 29.57486137
totals 5710 105.5452865
So tell me again, why do we send 51% of the energy in the fuel out the
exhaust pipe? not sure where the extra 5 % comes from!
Turbocharge them engines
Topher
>> > <<<<<<> > pins and cover everything being careful around the hinges?
That is the way we did it. Installed every thing, pulled the hinge wires
and then covered. We deviated from the plans a bit and cut small slits in
the fabric and placed the slits over the tabs of the hinges. Looks good with
just the tabs sticking out of the fabric. Of course if the hinge ever wears
out it will be harder to repair but how often do the hinges wear out and by
then it should be ready for recover anyway.
Woody
Subject: | Re: Dual Instruction |
Thanks to Will I received a couple of potential leads for dual instruction.
I originally limited the search to west of the Mississippi River but have
decided to expand the
search area to include the whole US. I really don't like the idea of
jumping in and flying with out some
dual time in something that flies like the Firestar.
For those of you flying a Firestar, what did you take your instruction in
and how was the
transition to the Firestar.
Vic
I don't know if it will work on your engine but one test on an automobile
is to watch the coolant for bubbles at the filler cap before the engine
heats up.
Ron
>Jim<<<
>>Jim/ list:
>Jim
> > radiation - 290 hp
> >J.Baker
> energy HP %
I really thought about doing the math, I really did! But as I was one
finger typing the above, with my feet up on the desk, two cats
asleep on my legs, and the book I got the figures from in one hand,
it was going to be too much of an effort to bring the calculator up
and run the figures.
My error...the 5% extra comes from a supercharger diagram where
the 5% was the mechanical losses from that unit.
Anyway, I was amazed at the exhaust figures when I first ran
across them. What was even more amazing was the small gain
indicated for supercharging.
indicated input before supercharger - 1960 hp
supercharger loss - 60 hp
indicated output after supercharger - 1900 hp
- 300 hp mechanical loss
total output - 1600 hp
While the supercharger actually cost basis output hp, the hp was
available at higher altitudes. I haven't seen a similar diagram for
turbocharging but would suspect it may be better (more efficient)
than the supercharger diagram.
J.Baker
Test
Subject: | Gallons and Covering |
Thank you all,
Man, that is just what I needed to here. All your posts
are very much appreciated. I think with all your blessings
that I will paint my engine red and black cool...
The covering over the hinges thing is still open. I have seen them
both ways and if done right I think it could look good.
Thanks for the tip about Jim and Dondi Miller, They sent me an welcome
and help. I will look into there service for sure.
Our Best
Tim T.
Vic,
I took 2-1/2 hrs dual instruction in a Quicksilver MX. I flew my
FireStar on the first flight and bent the gear legs. Things only got
better with each and every flight. I had never flown a taildragger and
essentially taught myself how to handle it and didn't take long to figure
things out. If the first flights were powered landings (flying to the
ground), they would have been smoother. At the time I was concerned about
pitching moment if I applied power to arrest the sink rate before
touchdown. Don't be concerned, as this is not a problem. Power off
landings need more precision to get the timing of the flare right ......
too early it balloons ..... then drops, too late it bounces. Either way,
this could be a problem in a x-wind and not desirable for a novice.
Stick with the powered landings (3500 RPM) until some time is built.
Just my opinion .........
Ralph
Original FireStar, 13 years flying
writes:
in
>and how was the transition to the Firestar.
> Vic
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Subject: | Re: Kolb-List Digest: 01/06/00 |
My understanding has been that with the Stits/PolyFiber covering, the most
important thing is to protect the fabric from U/V degradation. The silver
paint is reflective, and is proven to do the job. If the black (or other
color) blocks the UV, there shouldn't be any problem, from that aspect
anyway. Main problem (proven) with dark colors, is the heat build-up. Dark
colors absorb heat, light colors reflect it. Anyone who doubts this, has
only to get in and out of a few different colored cars on a hot summer day.
Come visit me next summer if you be a doubter. Palm Springs will make a
believer out of you in a hurry. Again, my understanding is that high temps
are mainly a problem on composite aircraft, since some of the resins start
softening at a fairly low temperature, and THAT could be interesting, to say
the least. Since we don't have that problem, probably the big thing would
be in the comfort level inside. I think I read the same
article on the engine paint, and if memory (??) serves me, it did show that
black radiated the most heat. However, any paint also acted as an
insulator, so the net effect was about zero. Not to be argumentive, but
personally, I prefer light colors everywhere. On metal, so cracks, flaws,
and leaks DO show up, and on fabric to reduce the heat build up, and
increase visibility. LongWinded Lar.
Sent: Friday, January 07, 2000 8:04 PM
Subject: Re: Kolb-List: Re: Kolb-List Digest: 01/06/00
> I was told that white reflects the uv light more than
> darker colors and therefor was longer lasting on
> covered airplanes. Can't wait to get the results of this one.
> I haven't chosen my colors yet either.
> Our best
> Tim T.
A passing thought brought on by the paint thread. A couple of years ago, I
drove to Perris, CA. to look at ultralights, and, hopefully, to talk to the
owners. Didn't work out too well, the few people there were totally
anti-social. Made me feel guilty for bothering them. Back to the point - a
mile or 2 short of the airport, I saw a plane (looked like a Rans S-12) take
off from a field about 1/4 mile ahead of me. It was painted a dark color,
and disappeared against the hills almost immediately. Made a pretty strong
impression on this ole boy. I have also - many times - had difficulty
finding dark colored traffic when in the pattern for landing. Vamoose is
gonna be White. My opinion only. Big Lar.
Drilled one of the elevator hinges to the elevator with the hinge upside
down. When I turned the hinge right side up many of the holes did not line
up perfectly. I re-drilled these imperfect holes and now they are not round
and have some slop, but look like they would rivet together just fine.
But, it is the elevator! So, do I leave well enough alone and use the
original 1/8" rivets, or should I use the larger 5/32" rivets?
If I need to buy 5/32" rivets, I can only find rivets this sze manufactured
by Cherry from "Monel steel". Is this the correct steel rivet to use?
Thanks for your help...
Ian Heritch, Slingshot
Steve
My Fiirestar is black, really get's hot in the summer when I
go to fly-in's and it sit's out all day. A lot of fellow flyers complain
that I'm hard to see if I'm below them,but I'm easily spotted when I
fly above them. Theres a few pictures if you want to click below.
Howard
http://www.hyperaction.net/hping
Hey everyone, got a new string for you. Buddy has a coyote S-5 Rans with a
503 d/carb. They left the plastic fan shroud on with original run-up and
fried rear piston. I was not there to witness damage but now it is apparent
front cylinder must have been scratched too. Only 70 hours on engine. Rear
piston has what I consider to be a lot of carbon and front one also only more
wet looking. We took exhaust off and rear looked good with new hatches but
front looked like it was wearing fast. Had a lot of brown carbon scoring on
exhaust side of piston and could see where they tried to fix scratch in
cylinder wall on intake side. This is tractor prop and cowled. Egs were
low as far as I was concerned, runs about 900 to 1000. CHTs were always up
there 375 to 400 sometimes plus with take off revs. It has also eaten a
cooling belt and has been adjusted several times. There is about two inches
clearance between the fan and firewall. It looks as though it is eating
exhaust heat for cooling. Gonna put a hole or air scoop on top of cowling to
help air flow. My question really is, how bad does a build up of carbon
affect the engine and do you think it will clean the piston and cylinder when
we get the CHs down and raise the EGs? The rings are free at this point. I
realize the best solution is a tear down but other than that, what are the
odds. The engine runs like a champ. Most of the time it is running around
56 to 58 hundred rpms. Plugs came out after 40 hours or more with just a
little carbon and wear. Has anyone put a scoop on a coyote S-5? The engine
is upright by the way. Thanks. G'day Ted
Bill Weber wrote:
> Since black absorbs all radiation, it would also absorb the UV. I would
> expect a reflective coating like silver to provide the best UV
> protections
Interestingly enough, the carbon black in roofing membranes used on flat
roofs
absorbs all the UV in just the top layer of the membrane and protects
the rest of the thickness.
go figure.......
ww
> From: Tim T99
> To: kolb-list(at)matronics.com
> Sent: Wednesday, January 05, 2000 11:02 PM
> Subject: When to Cover
> Man I am getting close. When should I cover what??
> I have every thing built but nothing mounted. Looks like I will need
> to mount and rig all the tail feathers to get everything right and straight,
> and the final riveting (except the attachment gussets) before I cover them.
> My big question is, can I complete all hinge installation then remove the
> Thanks
> Our Best
> Tim Townsend
I prefer to drill the holes and then hold hinges in place with clecos.
One can also buy hardward store pop rivets, knock the mandrils out,
stick them in and hold in place with filiment tape. This works to test
that everything is right. Then take hinges off and cover. Once you
start cover process, complete it. Do not put some coats on and leave
lay around for a long period before next coats. After all coats, put
hinges in place and permanently pop rivet in place.
gil leiter
MAPLEWOOD, MN
Subject: | Re: Elevator hinge |
Morning Gang:
Elevator and rudder hinges do wear out or tangs break and
make them unserviceable. I replaced all elevator and rudder
hinges on the MK III in Sep 99, at 1275.9 hours.
There is a terrific load on the lower rudder hinge caused by
tail wheel springs constantly pulling on the rudder "T".
After a period of time the rivets attaching this hinge will
get sloppy on the tail post. Give your rudder a little fore
and aft push and watch the lower hinge for slop.
Ian and Gang:
If it was my airplane and I was gonna be flying it, I would
double the length of the hinge, use 1/8th inch rivets and
drive on. I am not telling you to do that.
My recommendation to you is call Kolb Co and get their
expert advice.
john h (I always use more hinge than the plans call for)
When I first flew my Anglin J-6, I had a 503 in it with similar clearance
between the fan intake and fire wall, and the cowl (Which was similar to a
Piper Vagabond looking cowl) was intended to ram enough air in to give the
engine something to work with. It didn't. Barely made it around the
pattern without frying the engine. Subsequently made a scoop which hung
down to just below the cowl and ducted the air directly to the engine
cooling air intake, with soft rubber baffles between the engine and duct to
keep it from leaking away. Also made metal ductwork from the cooling air
exit holes in the engine shroud to the exterior of the airplane cowling to
make the heated air all go outside the cowl. CHT's went from 400+ down to
300-325 degrees.
Interesting that you mention that it had eaten the cooling belt and needed
frequent adjustment. Mine did also. I think when you have large heat
buildup inside a cowl, it degrades the belts very quickly, much faster than
normal.
If it was mine, I would clean all the carbon off the pistons and internals,
get them all in unblemished condition, (Called a top end overhaul, trying
to save money on obviously worn/iffy parts is false economy, unless you can
rebuild your airplane /pay your doctor bills cheaper) and cowl and duct
that sucker until the CHT's were down around 325-350 max. And also find a
way to let the hot air escape from the cowl after engine shut down so that
it doesn't sit there and heat soak. I ended up using a louver panel in the
top of the J-6 cowl. (Building supply store, normally fits in the eaves of
the house, under two bucks, under six ounces. Blend it in careful, watch
the cosmetics, it will look factory.)
Richard Pike
MKIII N420P (42OldPoops)
Back when I still had my Hummer, I had a couple occasions when I got
similar flak. (And of coures, a Hummer looks a lot more ultra-lighty than a
MKIII). My standard ploy was to ask if they could see the N-numbers on the
fuselage, and when they said yes, tell them; "Well then it is obviously not
an ultralight, is it? Do you ever read the FAR's, or even know what an
ultralight actually is? Or do you just go by what you think it is?"
And then the situation would usually go downhill, but sometimes life's like
that...
Richard Pike
> Big Lar.
>Big Lar and Gang:
>I know what you mean. Done been there and done that. Five
>days out of Titus, Al, June 1994, I had followed the US
>border to San Diego, CA, back to Borrego Springs, and then
>over the mountains thru the smog and down in the ground fog
>of the LA Basin. I was excited about landing at Perris
>Valley Airport. Big SOB chewed my ass out for landing on
>the active runway. Said I was supposed to land on the UL
>runway.
From: | "Waligroski, Greg" <gwaligro(at)ball.com> |
Subject: | Prior to Firestar |
Vic,
I recieved my instruction in a T-Bird before flying the Firestar. Compared
to the Firestar the T-Bird flew with a very heavy feel and sunk like a rock
with the power off. It also kept your feet relatively busy on the takeoff
and rollout to keep it on the centerline, the Kolb takes alot less effort.
So my transition to the Kolb was easy, just anticipated the better glide and
lighter handling and was pleasantly suprised by the better ground handling.
Gregg Waligroski
Colorado
Subject: | Re: john hauk's adventure ... |
Tim and Gang:
Went back and reread my post in response to Big Lar's and
Perris Valley Airport, California. Didn't realize it when I
sent it, but I guess it could be misleading.
Did not mean to mislead you or anyone else, that I had flown
to California, Alaska, and around the border in a Firestar.
That flight was in my MK III. Up until 1990 I did all my
XCs in my Firestar, all the States East of the Mississippi,
plus some west of it, and Canada. Thirty two States in all.
Tim, it is a matter of putting a lot of short legs together
to make one long flight. Just point the nose the way you
want to go and do it. Need to do a little home work first,
but that's about all there is to it. Especially if you fly
a Kolb. :-)
BTW: Before I lost my Firestar I had planned to do a true
circumnavigation of the border of the Continental US the
summer of 1990. No doubt in my mind I could not have
accomplished that one too. We had done our homework and
were ready to go. I built the MK III to make that flight
plus fly the dog leg to Barrow, Alaska, from Seattle, WA. I
was 205 miles short of Barrow, at Dead Horse, Alaska, on the
Arctic Ocean, when I had to make the decision to turn around
and head back. My flight next summer will be to fly to
Barrow, Alaska, and finish up the flight I started in 1994.
These little Kolb airplanes will take you there and get you
back, along with all the gear you must take with you.
A
>and how was the
>Vic
I'm gonna get flac for this one but with caution you can transition
yourself if you have prior flying experience (mine was in a Cessna). Get a
lot of taxi time in it first. Be able to put that sucker any where you want
it at any time. Practice with the tail down and with the tail up. Get
comfortable with the characteristics of you machine. When the time comes,
give it the gas and go play around a bit in the sky and when you wish to
land do not plan to land the first time. If it dosn't feel right take it
around again, no big deal. With practice you will get it lined up and fly it
onto the ground. I usually chop the throttle a couple feet up and hold the
nose up till it lands itself. The tail dragger part becomes a non issue. I
have had to do this with a Kolb flyer, ultra star, Twinstar, Firestar and Mk
111. Caution is the key word and patience either in taxiing or trying to
land. A friend accidentally got airbpourne first time he taxied his
Firestar. He remembered my advice. Took him 3 tries to get back on the
ground. He got over his fear of the taildragger and agreed it was pretty
much a non issue. Not the best way to train but it is possible if there is
no other way.
Woody
I don't want to give the wrong impression. I didn't fly to Perris, I drove
my car. Perris, for those of you unfamiliar with it, is a Huge
skydiving/ultralight center, mainly jumpers. I walked into the ultralight
shed/tie down area, said hello to people I passed, and was totally ignored.
Nice folks, real fun. Walked back past 6000 yuppie jumpers, who also didn't
speak, got in my car and drove home. Never been back. Don't miss it.
Disgusted Lar.
Sent: Saturday, January 08, 2000 8:43 AM
Subject: Re: Kolb-List: Colors
a
not
like
> that...
> Richard Pike
the
> > Big Lar.
> >Big Lar and Gang:
> >runway.
I sent that last before I read this whole thing, John. What a trip ! ! !
I'm really envious. Wish Vamoose was done so I could trail you part way,
but my turn'll come next year. This year will just take me to Utah,
Montana, (certainly, Paul ), Idaho, Washington, and British Columbia. If
you get into this area, give a call. I've covered almost every square foot
in the Western 1/3rd of the country, and up into Canada; I may be able to
make some suggestions. From here, I haven't been to Hesperia yet, but plan
on it soon, to visit Revmaster. I've heard good things about the place. I
can attest to Apple Valley, about 10 - 15 miles north of Hesperia. That's a
real great, old fashioned airport, full of good people, planes, projects,
and a good restaurant. I took my Champ lessons there, and thoroughly
enjoyed it. Lar.
Sent: Saturday, January 08, 2000 8:21 AM
the
> Big Lar.
> Big Lar and Gang:
From: | "Geoff Thistlethwaite" <geoffthis(at)worldnet.att.net> |
Date: Saturday, January 08, 2000 11:21 PM
>>Disgusted Lar.
Know what y'all mean. In the early 90's(93 or 4), having just gotten into
U/L's, I was in Palm Springs doing some trade show work and made an
appointment to get a lesson from the guys at Perris. Had read quite a lot
about the place in U/L Flying magazine. Drove over and walked around the
place a good 45 or 50 minutes and didn't get so much of a nod hello by
anyone there. Didn't get talked to until I announced in the U/L place that
I was there for my lesson. The instructor was busy asking for an advance on
his pay from the owner of the place..... Went up and about 25 minutes into
the lesson the engine dies. Well I had seen the fuel filter sucking air and
had mentioned it to the instructor...no response, 'till the big silence. I
was a lot calmer than him as this would be my 4th or 5th dead stick (another
story) and he said he'd never had one! After we landed I took out my
leatherman tool and started to take the filter off, meanwhile he's whining
about having to walk a mile back to the strip. I blew out the funk, which
looked suspiciously like the remains of a red shop towel, reinstalled the
filter and started the engine. No problem. The instructor flew us back to
the strip and I got no refund on the time unused...and we wonder why some GA
guys look down on our sport!
Geoff "at home with the flu and can't sleep" Thistlethwaite
Subject: | Re: UL Activity around Ft. Myers, Fla. |
Am considering moving to Ft. Myers, Fla. and am seeking info about UL
activity near there.
Howard Shackleford
FS I
SC
Subject: | Re: technical counselor |
Mike and Kathleen Hale wrote:
> Hi list,
> My firestar two is ready for cover and I would like to find a technical
> counselor to look over my work, this would include anyone who knows
> something about these ships. I live on Bainbridge Island, near Seattle, WA.
Hi Mike. Im not a tech Counselor, but I have SEEN a Kolb before :). so
call me if you are ready. I get to Bainbridge a couple times a month at
least.
Mike Brown
Olympic Ultralights
Hey Lar,
If you get Vamoose done by this summer and don't make it through here, there
will be hell to pay. N618HP is coming along slowly, but things should speed up
now that the holidays are over (Of course skiing and snowmobiling could get in
the way). We will definitely be ready for spring flying.
Take care
PaulV
> enjoyed it. Lar.
hey did you guys know there are two brothers at Apex airport in Silverdale
that have firestars?
Lawrence
Sent: Sunday, January 09, 2000 12:21 AM
Subject: Re: Kolb-List: technical counselor
> > Hi list,
WA.
> least.
> Mike Brown
> Olympic Ultralights
Subject: | Mk II performance |
New thread - for all Mk II owners:
My Mk II is about 340lbs empty, with a 503 Single Carb & Single CDI, brand
new GSC 3-blade 60" pitched to 6200 static. With 2 people and fuel - up to
max 750lbs - it just doesn't seem to climb too well. Even on cool days
(30-40) it only gets about 200-300 fpm on climb out (estimated).
I'd like to ask you other mk II owners' performance figures/engine
combinations are.
TIA,
db
I would think free flow to the cooling fan and out the
top of the engine are both critical. Either physical
blockage, such as the firewall, or cowling pressure
direction problems must be accounted for. Whoops, I
just read Richard Pike's msg on this ...sounds like
he's nailed it for you. My side interest in this is
that I've always thought it might be possible to put a
scoop even on a pusher 447 or 503, so long as there
was also some ducting back to the prop to draw the
cooling air back. Goal here may seem cheesy, that is,
wondering if a light molded scoop and backside ducting
could take the place of the weight and power draw of
the standard cooling fan, bearings, belt, etc. If it
could be proven to work, even sawing off some of the
cast part of the engine that supports the cooling fan
area. Think this is all too far out?
> It has also eaten a
> though it is eating
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
Woody and Gang:
For the previous post, thanks for the invite.
I agree with your philosophy for learning to land a Firestar
or any other fixed wing, for that matter.
It is not necessary to land the first attempt, second,
third, or, for that matter, til you run out of gas, the
ROTAX bites the dust, or it gets too dark to see. Fly it to
the ground with or without power. Not necessary to flare,
and stall it in. That will come later.
Most of the bent Kolbs I have seen as the result of first
attempted landing screwups were not maintaining airspeed to
touchdown, i.e., mushing in, or flaring way to high and
falling in. Just fly that little sucker right down to the
ground and hold it there with some forward stick til it gets
below flying speed. With a tail dragger, if you come in hot
and hit hard, the tail comes down, the nose goes up, and you
are flying again. Got to give it some forward stick if it
bounces so you won't break it. Here's where learning to
taxi with the tail in the air comes in to play. You will
feel more comfortable pushing the nose over cause you have
already been there and done that. The normal tendancy is do
nothing or pull back on the stick. If you do you will
probably bend something.
Just remember you do not have to land the first attempt.
BTW: Good post Woody.
In a message dated 1/9/00 1:24:51 PM Eastern Standard Time, bwr000(at)yahoo.com
writes:
<< My side interest in this is
cooling air back. >>
The original Benson Gyrocopter using the Mccullough 4 cyl. 2 stroke 72 HP
engine used exactly the same method you are talking about.
Howard Shackleford
FS I
SC
Subject: | Re: tail dragger flying |
I'm new to tail dragger flying after having flown nose wheel planes previously.
The biggest transition that I experienced is that if you land a tail wheel
plane on its main gear first, then you must keep the tail up. This means pushing
forward on the stick once those wheels touch down and then allow your speed
to drop and the tail to slowly fall. If you allow the mains to touch a little
hard, then the tail will be forced down just by the force of the hard landing,
which means the wings will be generating lift again and up you go. In a nose
wheel plane if you land hard, the nose will be forced down and the lift will
be gone so you stay on the ground with this type plane. The hardest thing
for me to visualize was why that tail dragger bounced so much if I let the mains
touch first. Once I realized that I couldn't allow the tail down until my
airspeed dropped, then I could land the taildragger with not near the problems.
Actually, it wasn't always a bounce as it was me allowing the tail to lower
before my airspeed dropped.
I was trained to do the 3 point landing. In this configuration the object is
to keep the mains off the ground while your speed drops. This is accomplished
by continually pulling back on the stick which lowers the tail. Eventually,
when the gear touches down, you will already be in a high nose situation with
no extra lift to be gained by lowering the tail any further. You land with the
stick all the way back which gives you ground control with the tail wheel once
it touches. This also is the slowest land speed for the plane.
This may not be real clear to everyone since I have trouble expressing myself on
the first draft, but this is a little of my experience in the transition to
learning to fly a tail wheel plane from a nose wheel plane. Hope it helps someone.
An air scoop on a 503 on a MKII has been done with out a fan or belt with
great success. Terry Crook down at Shady Bend, Fl. did this a few years ago.
He was just looking for economy. He got it.
Firehawk
>From: Ben Ransom <bwr000(at)yahoo.com>
>Reply-To: kolb-list(at)matronics.com
>Subject: Re: Kolb-List: Re: rotax 503
>Date: Sun, 9 Jan 2000 10:23:54 -0800 (PST)
> > It has also eaten a
> > though it is eating
>http://im.yahoo.com
Went flying today in PA and got caught in the rain for the first time.
Just wondering what I should watch out for in the rain as far as plane
performance and engine performance, or is it that you just get wet.
Everything seemed fine maybe a little more vibration. Thanks
Subject: | Re: flying in rain |
Thanks Randy
Randy and Gang:
Other airplanes, antenna towers, mountains, trees, and of
course your airstrip. Just kiddin!
Sometimes on XCs I enjoyed a little rain. At 80 mph, rain
will clean all the leading edges of wings, struts, tail
section, prop, and last but not least, the windshield. Rain
blast TDB's (those darn bugs) right off lexan.
Rain will also blast the leading edge off wooden props that
do not have leading edge protection. Also carbon fiber
blades will start to erode after extended flight if they are
not protected. Do not know about Power Fin and Ivo. No
experience, other than rain showers in the traffic patterns
at Lakeland and OSH, with the IVO. Never flown with a Power
Fin, so can not comment.
Have flown in heavy rain with 912 on MK III for extended
periods of time with no problem. Flown thru much rain with
447 on Firestar with no problem, except leaving Sun and Fun
1989. Been punching little rain showers from Lakeland to
about 10 miles south of Crytal River, Florida. The last
little rain shower turned out to be a Florida "frog
strangler". Decided time to put down somewhere cause I was
down to the tops of those tall pines. Flew downwind beside
a dry drainage ditch parallel US 98 to check it out when the
flame started going out. Instead of dragging my off site
landing area, I had no choice but to do a quick left base
and short final into the ditch. It worked out ok. Brand
new GSC two blade fixed pitch wooden prop, unprotected edge,
missing quite a bit of leading edge on both blades, but it
still flew ok and got me back to Alabama. Spent 3.5 hours
in the rain, under the wing, freezing to death, waiting for
the rain to stop and enough ceiling to continue my flight
back to Alabama. Someone reported a plane crash and half
the fire trucks, sheriff's deputies, and ambulances in
Hernando County descended on the scene. I was wet, cold,
and hungry, but no one thought to ask if I needed anything.
They were primarily curious, probably looking for blood.
Sorry I disappointed them. ;-)
Point is, if you fly in enough rain you will eventually
ingest enough water to kill the engine or reduce power
output enough to prevent further powered flight. It takes a
lot of water to do that, normally. Do not recommend taking
off in the next thunderstorm to test my info. I do not fly
in rain intentionally unless I know for sure it is very
light and I can see through the shower to clear air on the
other side.
john h (watching the rain drops fall, all day at hauck's
holler, alabama)
Subject: | Re: Flight to Barrow, Alaska |
YOUR GOING TO BECOME A STATISTIC IN THE NTSB ARCHIVES. I JUST HOPE YOU DON'T
TAKE ANYONE ELSE WITH YOU. GUYS LIKE YOU WHO REALLY THINK THEY ARE REAL
PILOTS FLYING AIRPLANES THAT THEY BUILT AND THAT ARE BETTER THEN ANY FACTORY
BUILT PLANE HAVE AN EGO THAT WILL KILL HIM. (IT'S JUST A MATTER OF TIME) I
HAVE NOTHING AGAINST HOMEBUILTS..I HAVE AN RV-6 THAT I BUILT. BUT THE
DIFFERENCE BETWEEN YOU AND I IS THAT I HAVE A 25000 HRS OF FLYING AND KNOW
BETTER THAN TAKE A GROUP OF PEOPLE WITH ME AND SUBJECT THEM TO YOUR HAIR
BRAINED IDEA OF ALASKAN FLYING. DON'T BELIEVE IN FILING VFR WITH THE FSS JUST
PLANE STUPIDITY. BUT AGREES IT'S A GOOD IDEA WITH THE CANADIANS. NEEDS BRAIN
SURGERY. I HEARD YOU RED NECKS WERE STUPID BUT THIS IS THE FIRST TIME I HAVE
HAD A CHANCE TO WITNESS IT FIRST HAND. i JUST HOPE THE OTHER PEOPLE WHO MIGHT
HAVE INCLINATION OF GOING WITH YOU WILL THINK TWICE AFTER THIS.
CAPT. DR CHAMPION
RETIRED AIRLINE PILOT
CFI.ATP.FAA SAFETY COUNSELOR.
David,
You are probably paying a relatively high price for the small diameter (60")
3-blade propeller ... esp with a single carb. I don't know how you are
estimating your climb, but it would be good to measure it as carefully as
possible. An altimeter and stop watch work very well.
But whatever your climb is now, it will be noticeably better with the 66"
propeller that you really should be using. A 66" 2-blade fixed pitch wood,
a 2-blade 66" Ivo, Warp ... or GSC will all do better that your present
set-up.
Dennis
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of David Bruner
Sent: Sunday, January 09, 2000 12:03 PM
Subject: Kolb-List: Mk II performance
combinations are.
TIA,
db
EXCUSE ME, but how long have you been on the list?
Do you even know what you're talking about?
I'll bet you'd have told Charles A Lindbergh the same thing!
IMHO you're an a**hole, Capt. Dr. Champion. Now kindly get lost!
sincerely,
Date: Sunday, January 09, 2000 5:36 PM
Subject: Re: Kolb-List: Flight to Barrow, Alaska
DON'T
FACTORY
JUST
BRAIN
HAVE
MIGHT
>CAPT. DR CHAMPION
I "MAY" have popped off too quickly on this....kinda knee jerk reaction
sorry if I offended anyone...
Geoff"somtime speak before thinking"Thistlethwaite
From: Geoff Thistlethwaite <geoffthis(at)worldnet.att.net>
Date: Sunday, January 09, 2000 5:51 PM
>sincerely,
>From: AV8TURDON(at)aol.com <AV8TURDON(at)aol.com>
>DON'T
>FACTORY
>JUST
>BRAIN
>HAVE
>MIGHT
>>CAPT. DR CHAMPION
I think he is joking. If he was serious he would have used his real
name. People are always doing bits like this to pull our legs. Usually
it is alcohol related.
Dan
In a message dated 01/09/2000 6:42:46 PM Eastern Standard Time,
AV8TURDON(at)aol.com writes:
<< YOUR GOING TO BECOME A STATISTIC IN THE NTSB ARCHIVES. I JUST HOPE YOU
DON'T
FACTORY
BUILT PLANE HAVE AN EGO THAT WILL KILL HIM. >>
Oh boy! I can hardly wait to hear the responses to this jerk. Let him have
it!
Bill Varnes
Original FireStar 377
Audubon NJ USA
Please use the shift key!!!
Date: Sunday, January 09, 2000 5:52 PM
DON'T
FACTORY
JUST
BRAIN
HAVE
MIGHT
>CAPT. DR CHAMPION
Me Too: But I meant every word. I have to be honest.
Firehawk :-))
Pease don't archive
>To: kolb-list(at)matronics.com ; AV8TURDON(at)aol.com
> >sincerely,
> >DON'T
> >FACTORY
>I
>KNOW
> >JUST
> >BRAIN
> >HAVE
> >MIGHT
> >>CAPT. DR CHAMPION
Man you have one of these guys on the kolb list too??
Over on the Powered parachute list Onelist.com, We also
have a 19,000 ATP named Clyde. He has turned completely around
and can't wait to get out of his DC10 to fly his PPC. And now he
is entering our competitions and winning some of them.
See you can teach an old dog new tricks. Hey Captain, When you loose your
medical probably next year I will build you a ultralight so you can still
fly with us.
Our Best
Tim T.
Sent: Sunday, January 09, 2000 5:33 PM
DON'T
FACTORY
JUST
BRAIN
HAVE
MIGHT
> CAPT. DR CHAMPION
I too started out to alaska from London on the
first of July and went through Lethbridge,Dawson Ck.
and past North Pole, Alaska. I guess the biggest difference
I was on a Motorcycle. This summer,
I will be at TNK to wish you good luck and to see you pull the stick
back.
Howard
I too am a retired airline pilot and I have much respect for John Hauk and
his flying. It is considered in poor taste to send e-mail material in all
caps.
Bill George
Mk-3 582 "C" Powerfin
> back.
> Howard
Howard and Kolbers:
No, the biggest difference is I didn't get muddy, and did
not have the courage to do it on a bike.
Thanks Howard.
From: | "Larry & Karen Cottrel" <lcottrel(at)kfalls.net> |
> Date: Sunday, January 09, 2000 3:33 PM
DON'T
Jeez,
I hate it when people shout at us.
Larry
Subject: | Re: Mk II performance |
>combinations are.
>TIA,
> db
I think this may fall in the "more is not better" catagory. It is harder
to turn 3 blades than 2. Could you find a 2 blade prop and go to the maximum
dia possible? This may help. Do you have a good cruise speed once up to
altitude. Only time I could only make 300 fpm I had a 300 pounder beside me.
Woody
Subject: | wire size to 912 starter |
can anyone on the list help me with the correct size wire to
go to the starting motor on the 912. the installation
manual states wire size of 16@ which is metric, the charts
i have seen only support steady state circuits, not circuits
of short duration.
tnx boyd
Subject: | Re: wire size to 912 starter |
I would suggest at least 10 gauge wires for the battery leads. I am not
sure if it is approved but what is commonly refered to as Monster Cable
is a very flexible multistrand grade. There are generic types available
at any auto stereo installation shop. You should properly solder or
crimp terminals so your resistance is low.
Just my opinion
Dan
>CAPT. DR CHAMPION
To try to assess a pilots skills based on reading his e-mail is not
possible. For you to infer that you can shows you are not competent to
retain your position as an FAA Safety Counselor. If you believe that it is
not possible for anyone with determination to build an aircraft and fly it
on a flight like JH is planning then you are not only technically ignorant
but a coward as well. JH has already safely completed most of the flight
that he is now planning to finish. He has already proven that your
statements are wrong. Your small vision for the future will not slow any
of us with courage and determination down.
In short you make me very glad to be a part of this group and not a part of
yours.
Topher
Project Engineer
Powersport Aviation
If this dork was really an airline pilot, we should all thank the good
Lord that he-she is retired! I think "8-TURD" is pullin our leg. He cant
even compose one whole uninterrupted sentance. And as for the Redneck
remark, I would like him to say that to my face. Im proud to be a
redneck, and Id be right proud to take MR. "Ive done it all" 2 gazillion
hour, CPA,CIA,DNA,LPS,FBI,ATP,CFIII,BS`R, out behind the woodshed and
beat him like a red-headed stepchild (any redheaded stepchildren out
there-disregard the last).
This guy smoked his lunch.
Sure did wake you lurkers up tho! HAH!
Mike "the Redneck" Brown
GRRRRR
> CAPT. DR CHAMPION
The noise is in direct proportion to the brain size. Ties right in with the
IQ of a committee. ( Take the lowest IQ present, and divide it by the
number of members.) Good to hear from you Larry, how was the fly-in ??
Big Lar.
From: Larry & Karen Cottrel <lcottrel(at)kfalls.net>
Sent: Sunday, January 09, 2000 6:36 PM
> DON'T
> Jeez,
> Larry
Tim T99 wrote:
> Gil,
> I have the finishing kit from kolb and will be using polyspray or the
> chemical uv
> blocker. I need to stay under 496 lbs. so will the chemical additive work
> ok.
> My plane will be stored in an enclosed trailer when not in use.
> How good of a job does the additive do?
> Tim T.
If one is REALLY REALLY interested in saving all weight possible, I
would recommend using one coat of PolySpray and using the UV blocker at
recommended strengths in the PolyTone. This should then be adequate if
one uses reason in the amount of time aircraft is exposed to sunlight.
I have not seen actual data, but would be reluctant to TOTALLY depend on
UV blockers for protection (no silver). As I best recall, there is a
discussion of this in the PolyFiber manual.
gil leiter
MAPLEWOOD, MN
Okay, my two cents. I dont want to offend anyone but you all should take
this man's opinion in stride. How many of you have had people tell you you
were nuts, crazy or suicidal? That remark about scooters from Hawks was
cool. I was told how crazy I was when I took my BMW 750 out west from
Michigan the first time. People said these things were made for around the
park, not galavating all over the country-side. I did the West Coast thing
three times, twice solo. I want you to know that requires a great deal of
courage, planning and you gotta be a little nuts. Boredom is the biggest
thing. Hawk knows that. You have to like your own company and like Hawk
told me, two people cannot agree to anything very long. As far a us
ultraliters, I guess we are crazy to fly these things but we are not
suicidal. These big-jet-jocks dont really understand what it is we do and
why. They sit back with their auto pilot on and say, wow, that is another
hundred hours I have flown. I would love to have him beside me on a little
hundred miler we occasionally go on. It would terrify him. Can you imagine
the thoughts and terror involved in the first channel crossing in England?
Those planes did maybe ten miles an hour and they did not even havea good
tape to hold them together. Our people have invested time and thought into
our game and now the industry is evolving (sic) into a pretty organized, well
manered group. These imaginative people have presented us with the solutions
to countless problems. The safety factor with the materials and training
have gone on to surpass the safety records of the "spam cans". To condemn us
all because one faction feels we are committing suicide, is not rational.
People like Hawk share their experiences and feelings with us because our
world needs the professionals and people to look up to. Without them, we
would still be flying rag and tubes and not go farther than around the block.
I really am saying that the old adadge, put your money where your mouth is
or my favorite "Lead, Follow, or get the Hell out of the Way" is the bet you
can do. If you have not tried it, dont knock it. Enough. Some people just
deserve to think again what their mouth has done. You go Hawk. Take the
rest of us with you in spirit. If we should die doing this, so be it, it
will be with a smile on our face. By the way, been riding motorcycles most
of my life and I think they are dangerous. G'day Ted
From: | "Johann G. Johannsson" <johann.g(at)centrum.is> |
Hi Vic and list members.
I just like to give you some information on how I with little flying
experience, learned to
fly my Firestar.
My few lessons started with 2 hrs in a Challenger II, back in 1994. This was my
first time
ever in an ultralight. At that time I had started building my first Firestar
II. I knew what kind of an aircraft I wanted to own and fly, but I have to
admit that this first time experience in an ultralight scared me a little. I
assume it did with most of us.
Only after a few minutes and the first landing (trainer landed) I was hooked.
This was the greatest fun of flying ever, for me. The airfield was Bob Lee's
grass strip airport in Florida.
My next training was in 1996 on a Drifter at Herlong airport in Jax. Fla.I had
5 hours of training in this plane. This was the best training for me, because I
was close to completion of my second Firestar II.These were mostly take-offs
and landings. I never got to fly the first Firestar I built, except for one
forced landing after a crow attempt. That is a another story, told before on
the list.
The trainer here was Gary Lapierre, and his landing method was to come in high
approx. 500 feet, and chop the power and dive to the landing spot, keep a
constant speed of 65 to 70 Mph. and then level off at approx. 5-10 feet and let
the plane flow in ground effect, until speed bled of. It was a safe method,
but later I changed the method to come in at 3500 rpm and 50 Mph, then chop
power at 5-10 feet and let the speed bleed of.
I am still at the initial stage of flying eperiance, so until I get more
experience, I will do what gets me safe on the ground all the time. Later I
will try the three point landing method and full stall.
My advice as a beginner in flying the Firestar is. Start with no wind. Just get
off the ground with full power and the tail wheel off the ground as soon as
possible. Hold it on the ground until 50 Mph, and then climb to a safe
altitude, but stay close to the field for emergency landings, and get to feel
the plane for as long as you need. Then do a few low passes to the landing
spot, but be careful when you increase throttle again for the climb out. The
thrust line is high, so you will get a nose down pitch when increasing the
throttle.
When coming in for the landing, just fly the plane to the ground with 3-3500
rpm and 50 Mph speed all the way down to ground effect or 5-10 feet and then
level off and cut power. No need to flare. It will just sit down on its own.
Hope this will help you in your first flight in this great flying machine.
Sorry for a long letter.
Best regards from Iceland.
Johann G. Firestar II 50 hrs.
> and how was the
> Vic
Woody,
Why deviate from the plans at all? How did you get a 1 inch fabric to fabric
cement area with the hinges in the way?
chris
Date: Friday, January 07, 2000 2:34 PM
Subject: Re: Kolb-List: Fw: When to Cover
>>> > <<<<<<remove the
wires
with
> Woody
Subject: | Re: 22,000uF capacitor |
>> My electronics friends tell me that a 22,000 uf/25 volt capacitor is huge.
>> I ended up using a 2,200uf/25 volt capacitor.
>> I have absolutely no alternator hum in my radio.
>The capacitor is not for eliminating hum in your radio, but to protect its
>input circuits from too big differences of voltage.
I presume we're talking about the capacitor shown on Rotax
wiring diagrams. It's connected directly across the output
of the alternator's rectifier/regulator assembly.
The unlike the automotive 3-phase systems, output of the Rotax
alternator is from a single phase winding and is MUCH
noisier. The capcitor is intended to reduce the noise
by providing some electrical inertia between the widely
spaced pulses of energy from the alternator's rectifier.
>It's a kind of voltage regulation, and it also helps the output
>transistor of your regulator to work not too far from the same voltage.
>If you switch all your gadgets on (radio, landing lights, strobe, etc) with
>a 22,000uF capacitor, you will be surprised to see - with a scope - how
>far from flat is the bus voltage.
Not a quantified statement. 3-phase alterntors have a peak-peak
ripple on the order of 5% of the dc output rating. E.g. a 14
volt system has about 700 mV peak to peak. A single phase alternator's
ripple is 100% of output, E.g, with no filtering provided by either
battery or a capacitor, the ripple from a 14v output machine
is 14v pk-pk.
There are thousands of airplanes flying single-phase alternators
with NO capacitor using only the battery for smoothing and
getting satisfactory results. Some PM alternators will run
with NO battery on line IF you include the capacitor in the
system . . . don't know if the Rotax system operates this way.
>Remind your electronic friends that the more amps they draw the bigger the
>capacitor should be.
The general rull of thumb for 60 Hz power supplies is 1,000
uFd per amp of power supply capacity. Applying the same rule
to the 18A Rotax alternator puts the 22,000 uFd device right
in the ballpark.
>Also put in series with this capacitor a 12V - 20W bulb : if the capacitor
>goes short, you will protect your regulator, keep your 12V power, and also
>immediately know it. At power on, when the cap is discharged, the bulb will
>shortly illuminate : you know the capacitor is OK.
NOT a good idea. The capacitor does it's job by looking as
if it were a dead short to the AC voltages on the system.
ANY device connected in series with the capacitor raises
it's equivalent series resistance value and degrades it's
ability to do the job. A 10A fuse is a good idea . . . capacitors
rarely short but it's not impossible. Better to open a fuse
that blow the end out of the capacitor . . . they stink
and are really messy.
>Electrolytic capacitors are fragile, the best place for them is not under
>a cowl, with heat and vibrations, so I think a bulb is a good protection.
>It's better than a fuse because it shows you immediately if the capacitor
>is OK or not.
Capacitors rated for operation at 85 degrees C are standard.
Further, they don't have to be big either. A 33,000 uFd,
16 volt device can be had with an envelope of 1.4" diameter
and 2.13" long. You want a computer grade device with 10-32
screw terminals. These have the lowest internal resistance
and are most suited for attaching the fat wires used to wire
the alternator system.
If there's enough interest in this part, I'll add them to
our inventory and website catalog. They'll cost about $15.00
each.
http://www.aeroelectric.com
Subject: | Re: cooling the rotax 503 |
Might be worth a try. A lot of the early ultralights used Zenoah 250
engines in pusher configurations, and none of them had any cooling
arrangements, they just hung out in the free air.
Back when I had the Hummer, I had a recoil starter spring break in the
Rotax 277, the recoil pulley began to unwind internally, and the cable got
out to where it knocked a bunch of fins off the cooling fan. Vibrated like
mad, but ran OK. Landed at a convenient airport, took off the cooling
shroud, fan, etc, crunk it back up and took off. Climbed right up over the
runway to see how hot it would get, but it stayed below 350. (That was
always a cool running engine anyway) Flew home with no problems. I figured
that since the guys with the Zenoah 250's on their Hummers could do it,
maybe I could too.
I think you have a good idea. I bet the engine would also be quieter with
out the whistle of the cooling fan.
Richard Pike
Back before I bought my MKIII, I got to go for a ride in a MK II. It had a
SCSI Rotax 503, and a 3 blade Warp Drive prop, I think either 62" or 64",
but not sure. It was a bare bones airplane, climbed out very well with two
190 pounders, and maintained level flight at 5,000 RPM. Do not remember
rate of climb, but it seemed very normal. At the time, I still had the
Hummer, and it climbed at 500 FPM, and the J-6, and it climbed solo at 700
FPM. The MK II with the two of us "felt" to be about the same. My
impression of the 503 on that airplane was that it was sufficient.
I would go with Dennis' advice and try a 66" two blade adjustable prop, I
think it will help a lot.
Richard Pike
>combinations are.
>TIA,
> db
Morning Bruce and Kolbers:
Hope everybody is still here. I am. ;-)
Let me see if I can satisfactorily answer your questions:
I have better luck with Bassett Hounds and airplanes than I
do with wives. After two attempts I have been single for
going on 19 years. However, I do have a fine gal friend who
supports my aviation habit, and has for the last 11 years.
I use no support system as such. Already stated I have
never used a ground support team on any flight. I go
strictly solo, me and the airplane and what I can carry with
me. Strap hangers, in the form of passengers, other
aircraft, and a ground crew, would seriously slow me down.
Not only would I have to do what I normally do solo, but I
would also have to keep track of everybody else, and when I
get miserable I do not want to have to listen to my
copilot's complaints too. I can handle what I encounter by
myself just fine. :-)
I take a set of plugs, a little safety wire, tools, nylon
tie wraps, electrical tape, assortment of nuts, washers,
bolts, set of tie downs, things that I may drop and loose if
I have to work on something.
If I had to recover my airplane with a trailer, there is one
available among my airplane buddies at home. I think I
could send out an all points bulletin on the Kolb List and
find a trailer most anywhere in the country, Canada, and
Alaska. Most FBOs have flat beds with primary mission of
recovering aircraft.
I have a handheld King KX99 VHF mounted in the aircraft.
Before that an STS, and before that I didn't have a radio in
the Ultrastar. The VHF makes life easier and safer. It
gives me the choice of going into controlled airfields, even
those that require a mode c transponder that I am not
equipped with. Controllers are not inhuman, most aren't
anyhow. If I have a problem and need to land, I tell the
controller and request permission to land. I landed my
Firestar at Roanoke, Va, Regional Airport in 1989, with the
tower's blessing, when I got myself caught VFR on top and
the only hole I could find was directly over the airport.
Told them what my problem was and they cleared me to land.
Think that airport was Class C airspace.
I use an old Garmin 55AVD GPS with North American Jeppesen
Database. Bought it at Sun and Fun 93, and updated in
1997. Up until that time my navigation was mag compass and
sectional.
When I cross country I accept the fact that I can loss my
airplane and I may get hurt or even worse. Once I accept
those facts, I am ready to fly. My insurance to cover me on
my flight north of the Brooks Range and up as far as Barrow,
Alaska, cost over $1,800 in 1994. That would pay to haul my
airplane out by helicopter if I went down away from the
highway. In sparely populated areas of Canada and Alaska it
pays to fly the highway, the recommended VFR route, clearly
marked on the Sectionals. Well, there is only one to Alaska
and one to Dead Horse/Prudhoe Bay. Then from Dead Horse to
Barrow is 205sm over tundra and water. That is a lot of
miles to fly with no forced landing areas, even if we do not
factor in the rapidly changing, unforgiving weather of the
North Slope and the Polar Ice Cap.
All long cross country flights are simply a series of short
legs put together over a period of time. Learn to fly the
short legs and you can safely fly anywhere, if you put your
heart into it.
From: | "Bruce E. Harrison" <beharrison(at)lexhealth.org> |
Subject: | UL Activity around Ft. Myers, Fla. |
Imagine you planning to move, just when I got the coordinates for
Trenton/Edgefield County programmed into my Garmin GPS38. If you need
someone to babysit your airplane while you make arrangements, I'm here for
you.
Bruce E. Harrison
-----Original Message-----
Sent: Sunday, January 09, 2000 2:02 AM
Subject: Re: Kolb-List: UL Activity around Ft. Myers, Fla.
Howard Shackleford
FS I
SC
Subject: | Flight To Barrow, Alaska |
CAPT. Donald Richard Champagne
Dear Sir:
I appreciate your post to the Kolb Builders List this
evening reference my intended ultralight flight to Barrow,
Alaska. I am humbled that a gentleman with your experience,
expertise, and position in the Federal Government, would
sincerely want to help me make my flight a success.
Although you came on a little strong, well, I am used to
that. I spent my 24 year Army career in Airborne Infantry,
Special Forces, and Army Aviation units. I was always a
member of the "elite" back then. "Toughness" and
"intelligence" was our trademark. I hang out with the elite
on the Kolb Builders List now.
I didn't start flying civilian aircraft until 1984, and
those were ultralights that I built. I finally got a
private ticket in 1990, to fly the new two place ultralight
I was building that would be registered experimental. You
understand, I wanted to be absolutely legal. I picked up a
few pointers going through Army Rotary Wing Flight Training
in 1968, about flying helicopters and a few more the 12
months spent flying AH-1G Cobras with Co D, 101st Avn Bn,
101st Airborne Div out
of Phu Bai, RVN, in 1969 and 1970.
I got to fly some when I returned to the States, after RVN,
then the Army put me out to pasture. You know, the reason I
started building ultralights was so I could fly again. To
me flying is flying, whether a little wide open ultralight
or a fully IFR UH-1H, or an AH-1G, loaded to the gills to
kill, with a VNE of 190 kts/221 mph. Heck, I like 'em all,
even powered parachutes. Anything that flies has a place in
the sky, as far as I am concerned.
I am just a "grass roots" aviator. Started my flying career
at the late age of 29, almost 32 years ago. I learned to
fly TH-55 helicopters in Primary Flight Training which
included
many day and night cross country flights just like I make
today, pilotage and DED reckoning, sectional and mag
compass. BTW: VNE and cruise for the TH-55 for us students
was 55 kts, same as the speed limit on US ultralights. I do
have the luxury of a GPS that makes crosscountry flight in
ultralights a lot safer, but only got it 6 years ago.
As an FAA Safety Counselor I want to make sure that you do
not go unrewarded for your personal concern for the safety
of my friends and for myself. Please send me the email
address of your boss so I can pass on my appreciation to him
directly for your concern and help. Snail mail address will
be ok, but would rather save the postage and envelope. ;-)
Again, thanks for your professional assistance.
JOHN R. HAUCK
Major, Infantry
US Army Aviator, Retired
PS: I noticed under you Pilots Certification that you are
listed as ATP and Flight Engineer, rated in single and
multiengine land. Couldn't find anything reference CFI or
FAA Safety Counselor. I also noticed your Class II medical
expired April 1999. BTW: Congratulations on completion of
your RV-6, N767DC. Have you flown it yet? If not, good luck
on your test flight. It is a great feeling making the first
flight in an airplane you built in the basement. I know, I
have done it three times, not counting test flights for
friends. Data base is not up to date on your RV6 either.
Doesn't specify Airworthiness Certificate Type. Take a look
at mine. This is the way it is supposed to look:
N-number : N101AB
Aircraft Serial Number : M3-011
Aircraft Manufacturer : HAUCK JOHN R
Model : KOLB MK III
Engine Manufacturer : BOMBADIER
Model : ROTAX (ALL)
Aircraft Year : 1991
Owner Name : HAUCK JOHN R
Owner Address : 255 COOSA RD
TITUS, AL, 36080
Registration Date : 12-Apr-1991
Airworthiness Certificate Type : Experimental
Approved Operations : Amateur Built
Don: Notice everything is current below:
Name : HAUCK, JOHN ROSS
Pilot's Address : 255 COOSA RD
TITUS, AL, 36080-2532
Date of Medical : Apr, 1998
Class of Medical : 3
Pilot Certificates : Private Pilot
Ratings : Single Engine Land
FAA Region : Southern
Subject: | Kolb-List Digest: 01/09/00 |
List:
It's obvious that an ATP does not necessarily a pilot make...(no offense to
Bill and other ATPs on this list.) The only thing wrong with responding to
this acid bath of a post is that we get to see it over and over.
Steve Kroll
by mtiwmhc07.worldnet.att.net (InterMail v03.02.07.07 118-134)
with SMTP id" <20000110182312.HMYH1891(at)webmail.worldnet.att.net>;
Subject: | Re: Flight To Barrow, Alaska |
> Dear Sir:
LOL
LOL HARDER
> JOHN R. HAUCK
> Major, Infantry
> PS: I noticed
ROTFLOL
OW! YOUR KILLING ME!
WHEEWW, wiping tears from my eyes....
pretty damn good for a "redneck"
Thanks John, I needed that!
Hope I get to meet ya at Sun n Fun. If not, Good Flying on your trip!
and keep posting!!
Subject: | Re: prop balance |
Date: Monday, December 27, 1999 3:44 PM
Subject: Kolb-List: prop balance
On a wood prop yes.
>I bought the prop balancer from CPS, and balanced the prop tip to tip. The
>next step they say is to balance the hub in the opposite direction to
>achieve this I have to add a 3/8 by 1 7/8 long steel slug between two of
the
>mounting holes of the prop. Is this the proper way of doing this. thanks
Subject: | Re: Fw: When to Cover |
>Woody,
>chris
I deviated cause I think it looks better having the most of the piano
hinge covered rather than hanging onto the trailing edge. I do not
understand the last question or you did not understand my method. I wrapped
the trailing edge like anyone else only I have these little tabs sticking
out for the hinge wire. The fabric still wraps around the tube with more
than an inch of overlap.
Woody
>Gil,
>chemical uv
>ok.
>Tim T.
If it stored in a trailer how much UV will it be exposed to? I had a Vector
covered in dacron painted with house paint. Sat outside for 8 years
unprotected and when I scrapped the whole thing the fabric was still strong.
Woody
HEY HOW COME I DIDN'T GET A REAL NASTY LETTER WHEN I SUGGESTED WE COULD
TRANSITION OURSELVES IN KOLBS IF THERE WAS NO ONE AROUND TO HELP OUT. I
WROTE THAT LETTER BEFORE JOHN DID SO I WANT AN EQUALLY DUMB LETTER FROM YOU.
YOU CAN EVEN THROW A DUMB CANADIAN JOKE IN IF YOU WANT.
WOODY
From: | "Richard Lecki" <FlyingR(at)glasscity.net> |
Are you kidding....those airline pilots are the worst students you can ever
train how to fly for real....slow reactions to anything, no clue what rudder
is...you name it....and the worst thing is they think they could fly....just
ignore that jerk because that is nothing you can do about it....he won't
change... Richard, Firestar II
----- Original Message -----
Sent: Sunday, January 09, 2000 9:05 PM
> fly with us.
> Our Best
> Tim T.
> From: <AV8TURDON(at)aol.com>
> To:
> DON'T
> FACTORY
I
KNOW
> JUST
> BRAIN
> HAVE
> MIGHT
> > CAPT. DR CHAMPION
In a message dated 1/10/00 2:01:25 PM, FlyingR(at)glasscity.net writes:
<< Are you kidding....those airline pilots are the worst students you can ever
is...you name it....and the worst thing is they think they could fly. >>
Ta ta ta ta Richard. Be careful about generalizing; particularly from a small
sample. I spent a great portion of a long career instructing pilots; light
planes to jets. Here's some insight.
I have had students with a GA background that were so god in transitioning to
jets that it watered my eyes. I have also had GA students that, to be kind,
weren't so good. But-- the same was true for ex military and airline types.
Some fantastic and some not so good and many average in performance. When all
was said and done I found NO correlation between background and potential for
learning to fly a fast, complex airplane. BTW, rudder can be a very necessary
control in a jet.
BTW, after not flying even a light plane for many years I managed to
transition myself from the jet to the Mk-3. No bent landing gear, no nuthin.
I wouldn't recommend it but it was the only way it could practically be
accomplished.
So, lets not let "Captain America" get us in a pissing contest over things we
all agree on. Like, how great our planes are, the true fun of flying and the
camaraderie we enjoy.
Best regards,
Bill George
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
I have a friend interested in getting a Kolb . He is a capable builder but
is considering buying used if the chance presented itself. Any aircraft
known to be for sale , let me know off list , and thanks in advance.
Jeremy Casey
P.S. ANY KOLB is a possible go with him....(Firefly to M3 , don't
matter...)
The proper way is to have CPS make you a new one.My Tennessee was out side to
side almost 2 ounces. I sent it back, they (REWORKED) it. Its balanced but
it lost 20% or better of its low end bite and will run nearly red line on
climb out if I don't pull the throttle back. It won't load the engine so my
cyl head temps just break 200. Ask them to try again.
> What's the N number jackass?
> chuck "likes to play with obvious trolls" cullen
Chuck and Kolbers:
The N number was in the email I sent to the List and to Don
Champagne this morning. Let's take it easy.
If you feel like retaliating, starting a flame war, or what
ever, maybe you need to do it bc and not on the List.
Interesting tidbits from you folks saying the fan
ain't needed. I guess Rotax puts them on to protect
from the average flier who isn't trying to optimize
every last ounce of weight and performance. But it
looks to me like very worthwhile gains are to be had.
I think there is a free lunch here, not from bending
the rules of physics, but geez, just consider the drag
on the standard un-cowled Rotax perched on top of an
ultralight. In addition there is the totally
non-aerodynamic cooling air entry and exit on our
glorified snow-mobile engines. I see the potential to
cut the total engine drag by at least 1/2, stay about
equal in cooling drag, get the 5 HP fan power back to
the big fan that makes us GO, and net a 5 lbs total
weight savings. And just to tease this a little
further, in my mind, finding 3 places to save 5 lbs,
and it is not out of the question to bring a 447 FS
over to the FAR 103 scale and say neener neener to my
not-so-favorite airport manager (and then take off at
1400 fpm).
Now if I could just get that plane back in flying
shape to play with that idea.
-Ben Ransom
> the temps within limits. Even after landing and taxi
> the temps were
> only about 50 deg higher than normal.
> ducting
> of
> it
> the
> fan
> There's no free lunch since the scoop drag will
> offset any power
> gains. I ran some figures on my fan and concluded
> that it drew
> about 6 hp at full chat and 4.7 at cruise. It
> doesn't take much
> surface area to equal that hp amount.
> J.Baker
http://im.yahoo.com
Subject: | most visible color |
On the subject of most visible color
i have flown radio controlled airplanes for years and the
easiest color to see (for me) in just about all types of
background is bright yellow, it reflects most all of the
light and still stands out against clouds and snow mountains
boyd
Subject: | Re: most visible color |
Man I will agree to that.
Most of my RC's are yellow also.
Tim T.
Sent: Monday, January 10, 2000 11:27 PM
Subject: Kolb-List: most visible color
> boyd
Subject: | Re: Kolbs for sale |
I Have a Fire Fly with about 35 hrs. on a Rotex 447 Engine, and airframe. I
have a heart problem that docter says will not get any better is reason for
considering selling. It is based at Bob Lee airport in Deland Florida. Housed
in a enclosed trailer [single axle]. Has a ramp door which makes it very easy
to take out and put back in. Firefly and trailer $15,000.00. Made from a
quick build kit, steel parts are powder coated. Fire star wheels and heel
brakes, full enclosure, EIS
engine monitoring system. Never damaged. Flys nearly hands off. If
interested my name and address are: William c. Redfield 166 Leisure World
Dr. N. Debary Florida 32713. Phone 407-668-6694 E-Mail
redfield(at)bitstorm.net
> Jeremy Casey
> matter...)
Subject: | Re: ST. Elmo EAA 1209 Fly-In |
Date: Monday, January 10, 2000 10:27 PM
Subject: Kolb-List: Re: ST. Elmo EAA 1209 Fly-In
>Jay Stevens from ST. Elmo,
What state might this be in?
Barry
Subject: | BRS over Barrow, Alaska? |
John H. and others,
What an awesome adventure flying to Alaska in a Kolb. Captian Americas concern
for your safety has brought a good question to my mind. Do you use a BRS type
recovery system in your mk3 or would you rather use that amount of gross weight
for other stuff like supplies and survival gear. I would think that flying over
hostile terrain, a BRS would be a nice option to use if needed. Maybe if you
had to land in some trees, it could slow down your crash speed?
List memebers, what is the general opinion about ballistic recovery systems? Is
it a "Dont leave home without it" thing or is it "I would rather have a lower
gross weight and dont think I need one". Also, what do you guys fear would be
the #1 reason that you might need to use a BRS. "Engine out over a forrest?",
"Structual failure like a wing strut bolt falling out?" Is there anybody on the
list that has had to use a BRS? I would love to here your storie.
I'm sure this has been hashed over before but since I'm a new guy, would you
please be kind enough to offer some fresh opinions.
Thanks in advance.
Rod Vacura
My biggest argument for a BRS is propeller related. I think the Kolb
airframe is sound enough. To fly with power you must spin something fast
and one of my greatest concerns is failure of the prop causing damage to
the boom tube or ailerons. Muffler springs, loose carbs., gap seals or
something coming from the pilot's jacket may upset a reliable yet
uncertified prop. Other than that, a bad preflight may be cause for BRS
usage.
Kip Laurie
N111KX FS-705
Atlanta
Sent: Tuesday, January 11, 2000 8:55 AM
Subject: Kolb-List: BRS over Barrow, Alaska?
John H. and others,
concern
type
weight
over
you
systems? Is
lower
be
forrest?",
on the
you
Thanks in advance.
Rod Vacura
I can only respond for myself: I would gladly accept the relatively small
weight and drag penalty of a BRS canister on the boom or in front of the
engine in exchange for the peace of mind gained. The fact that I flew 150
hours in a Firestar without one was simply due to the extra cost. If a Kolb
FS kit costs approximately $10,000 and a BRS costs $1500-2500, you do the
math. A BRS becomes a significant investment %-wise. It is insurance.
Expensive insurance, but not to the few who've had to use one. The BRS
website keeps statistics and descriptions of real life incidents. It makes
very interesting reading.
On your second question, I never worried about a structural failure on my
Kolb. If you've ever assembled a Kolb at the field and preflighted it, just
think about how many pieces and parts you check for tightness, locknuts,
safety clips in the wing pins, lift struts, etc. There is a very real
potential to forget something, get distracted by something else, be in too
much of a hurry, etc. Just ask yourself: How many of us have put a cup of
our favorite beverage on top of the car, opened the door, jumped in, started
up and been halfway down the street before wondering where "that drink" got
to? A BRS is protection against that kind of thing, as well as the remote
possibility of a nut coming off a bolt due to vibration, a safety clip not
being clipped all the way, and so on.
I use a checklist, and like Santa I check it twice. No incidents in 150
hrs., but one time I took off, got halfway through the pattern when I
smelled gasoline fumes. This was definitely not normal, so I looked over my
shoulder at the tank and realized I hadn't put the gas cap back on. Some
fuel had sloshed out of the 5 gal. tank (which I had squeezed 5.5 gal. into)
and was merrily evaporating. The gas cap had fallen down into the cage,
fortunately, and had not tried to go through the prop. I don't remember if I
was in a hurry, or whether friends were there videotaping my flight, or
what--but I sure enough forgot an important detail.
If you can possibly afford it--get the BRS. The regulations make an
allowance for the extra weight and it is well worth it. Work is slow and I'm
long-winded today.
Bruce E. Harrison
< Do you use a BRS type recovery system in your mk3 or would you rather use
that amount of gross weight for other stuff like supplies and survival gear.
Is
lower
be
forrest?",
"Structual failure like a wing strut bolt falling out?">
From: | "Brain Kim Steiner" <steiner(at)spreda.sk.ca> |
Just one thing to consider before removing a fan, I have a 582 that requires
constant airflow over its rads to keep it
cool. This becomes a problem when I taxi for extended periods as in going
downwind on a runway before turning around
and taking off. If your runway is close to your start out point you should
not have a problem. A friend of mine has a fan cooled 447 on a firestar and
has no heating problems with extended ground movements, I wish I could say
the same about my
Mark 111 with a 582.
Kim Stener
Saskatchewan, Canada
PS I have found a number of offensive postings this last week. Threats
of taking someone out back and beating the crap out of them is just a bad as
some of the original posts that started this flame war. Lets get back to
some useful information on this list. Someone wondered about how many have
left this list over the flame war, I was almost one of them.
Sent: Monday, January 10, 2000 11:14 PM
> 1400 fpm).
> -Ben Ransom
> > the temps were
> > ducting
> > of
> > it
> > the
> > fan
> > offset any power
> > that it drew
> > doesn't take much
> > J.Baker
> http://im.yahoo.com
Subject: | Re: BRS over Barrow, Alaska? |
Rod and Kolbers:
Yes, I use a ballistic parachute, a Second Chantz in the
center section, designed by myself and John Dunham in 1990.
I built a mockup center section for the MK III, sent it out
to John for him to fabricate a parachute pack try to fit
into the airfoil shaped space that was not being used for
anything else. John sponsored me with the parachute which
in turn sold over 300 parachutes for him. My Brother Jim
and I were just now chatting on icq about my parachute. We
need to shake it out, inspect for uv damage, and repack. We
believe the dual primed firing system for the solid fuel
rocket and the rocket fuel are still serviceable.
Using the parachute in event of power out over very hostile
terrain is an option. Those trees out on the west coast are
a little taller than what we have in the SE.
I am a firm believer in parachutes. All my assignments in
the Army were Airborne, except when I was flying
helicopters. Parachutes work and I know that. They save
lives. They are insurance. If you do not have one
installed when you need it, you ain't got no insurance.
Your choice.
Anything mechanical has the possibility for failure, samo
samo pilots make mistakes.
Am not worried about wing coming off my plane.
I have two documented saves with the same Jim Handbury hand
deployed parachute, 1985 and 1990. When I get some time and
get in the mood I will share those two events with the
List. I carry two Catapillar Club Cards in my wallet
presented to me by Switlik Parachute Company for the two
parachute saves in an emergency from an aircraft in flight.
Like I said earlier, I believe in parachutes, they save
lives. And I can break about anything, especially
airplanes. hehehehe
john h (Still here because of a $500.00 parachute used
twice. That's $250.00 a save. Cheap insurance.)
From: | "Michael Sharp" <mlsharp_1(at)hotmail.com> |
You Go John!!!!
At least on this trip you won't be shot at! Unlike the trips you made with
SOG HUH????
Keep the pointy end forward and the shiny side up...
mike
>From: "geoffthis(at)worldnet.att.net by mtiwmhc07.worldnet.att.net
>(InterMail v03.02.07.07 118-134) with SMTP id"
>Subject: Re: Kolb-List: Flight To Barrow, Alaska
>Date: Mon, 10 Jan 2000 18:23:11 +0000
>mtiwmhc07.worldnet.att.net (InterMail v03.02.07.07 118-134) with SMTP id
> > Dear Sir:
>LOL
>LOL HARDER
> > JOHN R. HAUCK
> > Major, Infantry
> > PS: I noticed
>ROTFLOL
>and keep posting!!
Subject: | BRS pros and con |
Hi Rod and others,
I have never had a BRS on my FireStar in the 13 years flying it. There
are arguments pro and con with the use of one. I have friends that work
for BRS so I won't say anything negative about the product. I think it's
a great idea and I didn't get one for this reason: I stored the plane in
my garage where my kids had access and feared something happening to
them. After flying all these years without one, I believe the only way I
could lose control would be if I became incapacitated and couldn't get
down safely or if I left out one of the pins or safety rings upon setup.
After thinking about both of these situations, I figured the risk is low
and chose not to get one. There are a couple of situations that I have
heard about that have bothered me. One of them was the test
pilot/engineer on the Cumulus project that deployed a BRS prior to the
crash that killed him. If there was one guy that a BRS should have saved,
this would be it because BRS (the company) was in close contact with this
project. There have been a couple of situations where the BRS bridle
cable came loose and became tangled in the prop without deploying. One
them was in a Kolb which caused the engine to rip from its mounts. The
BRS was not at fault but the cable ties holding the bridle in place had
deteriorated due to UV exposure. The only incident that I can recall
where a BRS was deployed and saved the pilot, in this area, was a hang
glider whose support cable was worn where it couldn't be easily
inspected. The cable broke, he deployed the BRS and it saved his life.
This incident was in the early years when the BRS company had just
started. The ultralights of today are structurally sound compared to
those designed in the early days (as we all know), so the thought of a
bolt coming out or the main spar folding is highly unlikely. So is a BRS
needed? I haven't ever needed one, but maybe I should reevaluate this as
my plane ages.
Ralph
Original FireStar, 13 years flying
>is there anybody on the
>would you please be kind enough to offer some fresh opinions.
> Thanks in advance.
> Rod Vacura
Subject: | Re: Dual Instruction |
I had dual instruction in a Rans S6II--the Firestar is easier to
fly--landings and take offs due to slower landing speeds. The heavier two
seaters tolerance of turbulence is much better than the Firestar. I also
had several hours in a tail wheel Talon--good experience and worth the
effort. Do not focus on the number of required hours--you and your
instructor will know when you are ready. I had my Firestar before I
started training and I soloed in my machine. Two months after I soloed and
many hours I went back for a refresher hour to check on some technique
questions. I soloed in September and have flown every weekend, but one,
since that time.
USUA has a list of instructors and ASC (found through EAA Ultralights) has
a much larger list of potential instructors. You can find them on the
web.
Good Luck, Dale Seitzer
I originally limited the search to west of the Mississippi River but have
decided to expand the
search area to include the whole US. I really don't like the idea of
jumping in and flying with out some
dual time in something that flies like the Firestar.
For those of you flying a Firestar, what did you take your instruction in
and how was the
transition to the Firestar.
Subject: | Information on St. Elmo Alabama |
St. Elmo Airport
Aprox 7 miles south of the Mobile Regional Airport, Mobile Alabama.
About as far south in Alabama as you can get.
Some of us locals will probably camp out Friday night and Saturday night.
The fly in will be Saturday the 25th March. We are planing to have a saftey
simanar Saturday night and then a fly away breakfast Sunday morning for those
that chose the camp out Saturday night.
AV8REXP(at)aol.com
In a message dated 1/11/00 10:51:24 AM Eastern Standard Time,
beharrison(at)lexhealth.org writes:
<< If you can possibly afford it--get the BRS. The regulations make an
allowance for the extra weight and it is well worth it. >>
On the other hand, unlike my skinny friend Bruce, I am a big ol' guy and and
I don't feel my FS I
needs to haul that extra 20 lbs or so. Actually, after over 115 hours of air
time I really don't feel the need for one. I do extra careful pre-flights, I
don't fold my wings[any more], and I very seldom fly anywhere I can't land.
If I ever lose 50 lbs and get rich I may buy one.
Howard Shackleford
FS I
SC
Subject: | BRS insurance company |
"All my assignments in
helicopters."
OK John, I give up! How do you fly helicopters without being airbourne?
Heh, Heh, just kidding! I couldnt pass that up.
Kolbers; Everybody has different reasons for wanting, or not wanting a
chute. I have had one on my trainers for 3000+ hours now, and have never
needed it. Yet. As John says, we have some wicked timber out here that
will foul up yer day if you go into it, lots of water, and for the most
part, unlandable terrain. I had a Beech Musketeer rear end me mid-air a
few years ago, and was stuck to him in-flight long enough to consider
the chute. Problem was I didnt know HOW tight we were stuck together.
The last thing I wanted was to land in the same place as a Beech full of
fuel. So I didnt pull it. Glad I didnt.
We dont fly over water unless in the floatplane, we DO NOT fly over
timber unless altitude will allow a glide to a LANDABLE spot of ground.
We stay out of the Olympics for the most part also. An engine failure in
the Olympics is pretty close to a death sentance. (if you survive the
crash, the mountian lions will eat you :)
So why do I always use one? Same reason I buy life and car insurance,
only a chute is LIFE insurance. What you buy every month for 40 bucks is
DEATH insurance.
Chances are if you are vigilant about preflights and fly as you should,
you will never have a problem. BUT....
I DONT leave home without one. My wife NEVER whines when I buy a chute
for a new plane. We wont talk about the plane itself!
Oh yeah, I sell BRS, and this aint no ad. Im retired and if I had to
live off what I make doing U/L stuff, I would have starved long ago.
Cheers, Fly safe!
Olympic Ultralights
I have a 377 engine that will idle fine at the start of the day, but after
flying for about 1 hour when coming in for a landing and I chop the throttle
it will shut off. I have to turn up the idle screw to get it back to 2200
rpm. Has anyone ever had the idle screw vibrate out a little while flying
or any idea's. The engine runs good while flying Thanks
Subject: | where is Olympic Ultralights located? |
I cant find a web site,directions, hours, or phone number!
Lawrence
Silverdale,Wa
Subject: | Re: BRS pros and con |
Ralph H Burlingame wrote:
> Hi Rod and others,
> my plane ages.
> Ralph
Ralph, one of the most common reasons given for a BRS is the posibility
of a midair. Remember, no matter how careful and watchful one is if the
OTHER guy is not watching he can get you. Remember the recent event in
which a Piper (low wing blocking down visibility) landed on top of a
Cessna (high wing blocking upward visibility) ? This can happen at
altitude also. Years ago two friends of ours were killed near Holman
field in a midair in which the circumstans and configuration of the
aircraft blocked each others view of the other.
A second is loss of engine over totally unlandable area. My view is
that this never should happen to a responsible pilot, but we all know
that there are those who indeed do fly over areas where they cannot
possibly safely land.
Third reason is metal fatigue. This is always a possibility.
gil leiter
MAPLEWOOD, MN
BRS--no thanks--(1)Midair collision--doubtful that a BRS would be of much
value in most such events, (2)landing on unlandable terrain--I would rather
land in a controlled crash than dangling from a parachute completely out of
control.(3) Metal fatigue(?) as in structural failure??--try some
preventative maintenace and an actual preflight/postflight inspection
procedure and stay within the flight envelpoe for the aircraft. Each to their
own but they seem heavy, costly and of dubious value--just my opinion and not
attacking anyone. I would much rather invest inan actual parachute and if the
airplane catches fire I am going away from it. My Kitfox has no BRS, my RV4
will have no BRS but will wear a chute during aerobatics. JR
From: | "michael highsmith" <firehawk54(at)hotmail.com> |
I don't know if anyone else has said this but in my opinion it sounds like
you could use a little more fuel in the mixture at idle especially after it
gets hot. Try turning the air screw in to make the mixture richer a little
at a time until it keeps running at the desired rpm after you get it hot.
Maybe 1/8 turn in at a time. Shouldn't take more than 1/4-3/8 at the most.
If this doesn't work or it gets worse take the idle jet out and clean it
like you have never cleaned it before. Tee nity holes don't take much to
plug up. Then start over again with the air screw.
Firehawk
>From: "Randy" <yamaha(at)cvn.net>
>To: "Kolb"
>Subject: Kolb-List: low idle
>Date: Tue, 11 Jan 2000 17:44:33 -0500
>throttle
Wally Hofmann wrote:
> I've got a free ticket on Southwest burning a hole in my pocket and am thinking
about going to Sun and Fun. Never been there or Oshkosh.
> Any suggestions on which two days would be the best and places to stay and/or
avoid. I would arrive in Orlando and rent a car.
Been there a couple of times.
You will absolutely love it.
Choose Sun 'n Fun over Oskosh.
Very different attitude.
Finding a place to stay is tough.
Avoid opening weekend.
I'd suggest going Mon through Thursday.
Orlando is the only place I've ever been
where you pay a toll to get out of the airport.
Done Sunday. Never again.
Again, you will absolutely LOVE it!
ww
Subject: | Re: Kolb-List Digest: 01/11/00 |
Somebody needs a real life story about a BRS recovery. Okay, I belong to the
Southern Ultralite Flyers Association and one of our members was flying a
Cobra, rag and tube with only spoilers on top for ailerons. The rudder was
spring loaded and one of the cables broke at about 1000'. It immediately
spun out of control like a leaf falling from a tree. No chance for recovery.
He pulled his BRS and it fouled on the prop or tail surface, one. He was
still spinning hard. The chut did not deploy fully but he came down into the
trees and the trees opened up (hard wood) and he went down towards the
ground. The canopy caught the top of the tree and (as God had intended) the
shroud lines were 75' long and the tree was 85' tall. It stopped him 10'
short the ground and hung there. There was virtually no damage to the
aircraft except for the firemen loading his plan on a tanker broke a tube.
There you have it. His life was spared and he is listed on the BRS save
chart. I was there and saw it and just knew I had talked to this man for the
last time. I by the way was flying a Cobra also and this sent chills down my
spine. When I sold the Cobra I kept my BRS and installed it on my Kolb
Firestar under the belly on the main tube. It is covered in stits for
weather and airstreams like it was not there. Hope I did not bore anyone
with a real story about a real friend. He, by the way went on to buy and fly
a Firestar although he has not had much experience lately. G'day Ted
Subject: | We're digging out of the rubble . . . |
Our offices and shop have been in turmoil for the past
week. We've had a contractor in working on our basement walls
stabilizing them and fixing leaks. Everything is pulled out
from the walls and we've got boxes stacked everywhere! The
final inspection is today and we'll be putting things back into
working order as soon as we can get at it . . . leaving 6:15 am
tomorrow to do a weekend seminar in Oregon!
Dee and I will be working to catch up as many orders as we
can before we leave. It's going to be a little while before
we're back to normal as there's much "stuff" that has to
be put back where it belongs. I'll be taking a ton of e-mail
messages with me on the laptop and will try to catch up
on our list-server activities while we travel.
Subject: | looking for software . . . |
Given that many of our brothers in aviation are also plugged
into cyber-products, I thought I would inquire on the lists
about recommendations for some shopping cart software.
I've looked at several packages . . . there are dozens
that e-mail a detailed and properly totaled order. Problem
is that it would be just as convenient if it were faxed to us;
we still have to re-keypunch data into the invoicing and
packing list.
Are any of you aware of an integrated package that ties
website orders to the office data base so that we don't
have to re-enter information already entered by the customer?
It's really easy to make mistakes during the transcription
process . . . Thanks!
>Large value electrolytics have significant self inductances ie. impedance to
>high frequencies. The Rotax regulator is a switching device which shorts
>half cycles to ground every now and again (on low load) and produces high
>frequency, high voltage spikes in so doing. (This is the cause of most RF
>interference). This combination can easily exceed even the 25v value for
>very short periods. Whatever, a 16 volt cap. blows up nicely after a very
>short time - and very spectacular too. Been there.
Not sure about the Rotax regulator but all of the PM
alternator regulators I've opened now use a full wave bridge
rectifier with a silicon controlled rectifier in two
legs to provide SERIES switching for control of output.
This is in contract with older SHUNT switching regulators
popular on small motorcycles of decades past. In
any case, it's not voltage spikes that eat the
capacitor but ripple current at the 2x the AC output
frequency of the alternator.
A number of my customers have blown some rather
small capacitors (1.2" x 1.5") rated at 22,000 uFd
and 25v with small solder terminals intended for
mounting to an etched circuit board. These capacitors
are NOT suited to this task at ANY voltage rating.
. . . the capacitors I recommend are the so called
"computer grade" electrolytics with fat, 10-32 threaded
screw terminals. I believe the smallest one I could
offer was on the order of 1.3" x 2.5" and have a
ripple current rating of well over 10 amps.
It immediately
> still spinning hard. G'day Ted
Ted and Kolbers:
That was at Slocomb, Alabama, wasn't it? I remember the
incident. It was Sunday morning, Spring or early Summer
1993, I was packing up my tent, loading my MK III, to fly
back to Gantt International Airport (my cow pasture
airstrip). I looked up when I heard the parachute mortar or
rocket fire. If I remember correctly had a hard time
finding James in the woods. When we did, he had the biggest
smile I have ever seen on his face. On my departure for
home I flew over the crash site. James was lucky. A couple
hundred feet from where he landed was a pond with many dead
pines in it. Just the trunks remaining, about 10 to 20 feet
sticking out of the water. Glad he didn't land there.
In a message dated 1/12/00 2:00:00 AM Central Standard Time,
kolb-list-digest(at)matronics.com writes:
forrest?"
on
> the
The only thing I would consider serious enough to use the chute would be
structural failure that rendered the aircraft uncontrolable. Otherwise, I
would fly the airplane and try to avoid obstacles until the last second.
Steve Kroll
> << Just one thing to consider before removing a fan, I have a 582 that
> requires
> downwind on a runway >>
> i always wondered if using a radiator with an electric fan from a
small
> car would work. ya know the fan is controlled by a thermostat..........
tim
That sounds like a good idea. If anyone tries to add extra weight to the
mounting brackets that hold the rads
an extra brace should be installed to prevent excessive rad bracket flexing.
I have had bracket fracture problems du to adding a cowling around the back
side of one of the rads. This cowling collects warm air and sends it into
my cockpit for winter flying. I made this cowling form .032 aluminum sheet
and did not think it added any significant weight to the rad. After two rad
bracket cracks at about 25 hours apart, I installed a brace from under one
of the cylinder head nuts to the top of the rad bracket. This was installed
about 100 hours ago --- no more broken rad brackets. I made the brace from
a short length of 4130 tubing, did a bit of welding and bending, then
painted it gray to match the aluminum color of the rad brackets. It blends
in and is seldom noticed buy the average person.
Kim Steiner
Subject: | Re: BRS pros and con] |
Yo! I'm with you man. Piecing an airplane together with parts from Ace
Hardware tm, performing uncoordinated flight or flying an inherently unstable
plane would probably warrant a BRS. In any case I would be inclined to remain
earth bound. Wearing a pack, on the other hand, makes more sense to me as
well.
What ever you do, do it well.
doitdave
Get your own FREE, personal Netscape WebMail account today at http://webmail.netscape.com.
>My Brother Jim and I were just now chatting on icq about my parachute. We
I think it proably will, at least the rocket. I sunk one in the water
couple of years ago.
The chute was six or seven years old, so we fired it off later that week,
after the
water drained out. Turned the chute around backwards so the rocket would
have to pull it up "opened". It worked like a champ-even after being in
that muddy lake for 24 hours-that says something for BRS!
Subject: | Re: Fabric Patches |
Hi Guys,
Does anybody know if I can do poly fiber repairs in cold weather? I do not
have access to a heated hangar and I have to make some small cosmetic repairs
for the FAA inspection . Will poly brush and poly tone dry at forty degrees?
Any input will be helpful.
John Bruzan
FS II N25029
20.8HR and
learning
P.S.Mr Hauck,the things you do are the stuff that dreams are made of.
Please keep us posted!
Subject: | Relay From Lindy |
Evening Kolbers:
The following is from Lindy. He is having a problem posting
to List. He is receiving mail but his posts keep getting
thrown back at him:
Having problems posting to Kolb list--changed all
settings--one message-and nothing but rejects--I read the
Kolb Traffic daily.Field
Modification to cooling system with extended life
anti-freeze-and mixing 2 cycle air cooler oil w/Amsoil
85-140 gear lube-changed
cap--no vent hole-working on 582--to date.
John,
Living in the cold northwest, and doing most aircraft building during
the slow season(winter) All the planes I built were covered in 30 to 45
degree weather. (the Polytac has to be warmed up in the house to pour
it, then I thin it with acetone.)
One winter before I had heat in the shop, I had a Merlin to rebuild, so
I used a 55 gallon drum turned upsidedown, with holes in the top and
bottom, and had my cutting torch stuck in the bottom hole. As long as I
stayed within 3 feet of the barrel, I could work without hypothermia.
Talk about desperation.....
Go ahead and do yer patches.
Olympic Ultralights
Bruzan3(at)aol.com wrote:
> Hi Guys,
> Thanks,
> John Bruzan
> FS II N25029
> 20.8HR and
> learning
Subject: | Re: Flight to Barrow, Alaska |
Brother Mike sent me a little note mentioning John's
plans and that being the fun kind of flying we get to
do. I realized I better look back at the Kolb list
and see what I had missed. Wow. I know how hard it
is for fast airplane drivers to understand the safety
we get in being able to land in the boonies, call home
on the cell phone, and sack out for the night. It
goes against everything that has become their
definition of safe flying (25000 hours of dials,
knobs, autopilots, FSS on the other end of the horn,
and the absolute need for long straight pieces of
pavement).
Anyway, yep, all except one insulting reader knows
what this is about -- real independence, freedom,
adventure, seeing the beatiful sights roll by at
60mph, and meeting some interesting folks along the
way. With your experience, and your own realization
that still, experience doesn't guarantee safety, you
are the right stuff for this kind of thing. I'll
join the rest of the group in wishing you the best in
planning and enjoying your adventure. It is something
for us all to imagine, and wonder about perhaps even
doing ourselves someday. Try to ignore the
occassional fluff. I guess it is good to see a sample
of how many people here and elsewhere are with you on
this.
-Later,
Ben Ransom
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
Morning Kolbers:
Wish I could fly as well as some of you express yourselves
on this List. I appreciate you supporting me, doing and
attempting to do a few things that ordinary airplane drivers
will never know exist, let alone experience for themselves.
I have been accused by one, of over confidence, stupidity,
and influencing young aviators on this List to go out and
attempt to fly well over their heads. When I share with you
my experiences, I always try to emphasize my mistakes as
well as what I accomplish. I in no way am trying to tempt
low time pilots to do the same things I do before they are
ready. I am not an airline captain, business jet driver,
corporate pilot, or spam can aviator. I am an ultralight
pilot that has flown helicopters in the Army and fixed wing
aircraft (primarily ultralights except for about 20 hours in
a Cessna 152 to get a Private License). That means the
hours I have accumulated since Sep 1968, have been with me
on the controls all the time (no autopilot), even flying IFR
in Huey's. My military and civilian flight time has been
snuggled up close to Mother Earth (low altitude). I like to
enjoy flying and experience what God has given us all to
appreciate, the beauty of our world.
On long cross countries, especially those in sparsely
populated areas of the South West, mountains and big timber
in California and up the West Coast, Canada, and Alaska,
there is a big risk factor involved in accomplishing these
flights. Many times they are extremely difficult, wind,
rain, turbulence, fog, low ceilings, etc. I can not always
keep a forced landing area within gliding distance. If I
did I could not finish the flight. I have to accept the
fact that I may lose my airplane and other serious
consequences. I get cold, hot, hungry, thirsty, tired,
bored, extremely lonely, scared, confused, wet, and
miserable at times. I have to accept this. But for the
most part I experience what few have or ever will. I am
humbled that I have the opportunity make these flights. I
am also grateful to experience beauty beyond compare,
something I can not bring home with me in pictures or
video. One has to be there and experience it in person.
I have said this before and I will say it again. I make
these flights to show others (GA type aircraft, ect.) what
we can accomplish safely in our little airplanes, that they
(real airplane drivers) will most likely never experience.
We have the capability of landing very slowly in confined
areas when the need arises. We can put down in hayfields to
wait out thunderstorms or bad visability. We can land and
ask directions if we get lost, before we run out of gas. We
can flight follow with someone at home, not necessarily
FSS. I have always flight followed with my brother Jim when
I do long XCs. If he does not get a call from me within 24
hours, he knows my approximate route of flight and where I
was the last time I checked in. Local flights at home, I
always let someone know where I am going to fly. I never
want anyone to think that I fly carefree in a hap hazard
manner with complete abandon for cardinal rules of safe
flight. I love to fly and have a lot of fun doing it, but
in order to fly tomorrow, I must fly safely today.
I am not an expert, never claimed to be. I sure as Hell do
not know it all cause I learn something new almost every
day. I also learn from your mistakes, young and old
pilots. I share my experience, strengths and weaknesses,
and hope, with you all so you won't have to make the same
mistakes I have growing up in this young sport. I am an
ultralight pilot who flies a fat two place ultralight that
is registered experimental to make it legal for me to fly.
The "N" numbers on the tailboom in no way change the
character of my airplane. Still flies the same way. Only
difference is I have to have a license, physical, and BFR,
every two years.
Fly safe and thank everyone for your kind words.
> Ben Ransom
John with all the complicated stuff I have on this machine -I figured
out this solution to kolb list rejects----before I send message I hit
format-change to plain text.Note --Only rejects I ever get is from kolb
list-hopefully this will fix problem.
I spent a least a day changing all type of settings and zero--reason I had
to reply to your e-mail traffic on net.
Fog-heavy again this morning-Panama City bunch will try to get off Sat
morning at first light-we will be waiting at Waldan Field--probably will
only fly the South Georgia leg--skip flying to Dawson for pancakes.Flight of
3---Hawk Arrow,Rans S-6,my Mark 3
Do you think it would be appropriate for me to use the Kolb Handle that
Homer and Barbarba gave me? Do not want to start any lpi----ng contests as I
remember firestar 1 being rolled on take-off.
That should get a response to this test message.
Lindy
LA-Lower Alabama
Former Leader Kolb Demo team Southeast United States-Old Kolb Company
Mark 3 # 043--
From: | Dallas Shepherd <cen23954(at)centuryinter.net> |
Flew my Mark3 with the Jabiru 2200 for the first time tuesday. Flies
different then with the 582. Don't have any airspeed figures yet
because I was concentrating on the handling. Had to hold right rudder
all the time above 2300 rpms and I also had to put in some trim to keep
the nose up. Never had to do either with the 582. Lots of new sounds
came in and made me nervious until I realized I hadn't flown this plane
that fast before. Could only get to 2800 rpms as I had too much pitch
in the prop. Its a Warp Drive 58" tapered prop. I have tweaked the prop
back some and put a piece of trim on the rudder. Haven't tried them to
see what happens. I don't think my airspeed indicater is too accurate
so will have to get my gps going. That engine really moves it though.
Stall was the same, about 42 mph if you could belive the indicater,
same as with the 582. I found I was landing faster on the two landings
I made, have to get use to those lower rpms. More later.
Dallas Shepherd
Norfork, Ar.
Subject: | Re: Jabiru Engine |
> Dallas Shepherd
> Norfork, Ar.
Dallas:
Congartulations. Know you have a big grin on your face
now. Keep up posted. It is the first Jabiru on a MK III
isn't it?
Dallas,congratulations.I am eagerly looking forward to a report on
your new motor.I bet we all are.Installation, performance, comparison
impressions.
Take your time and enjoy.This is big time.I've seen the motor and
it is one of the cutest anywhere.Do a little write up and photo set and
sell it to kitplanes? Don't mind me. All the best.
John H.
As far as I know, its the first Jabiru on a Mark 111. John Norris is in
the process of building a Mark 111, and he is putting Jabiru on it when
its complete. He has the engine now, but still looking for the right
propeller.
Dallas Shepherd
From: | "Frank & Winnie Hodson" <fwhodson(at)bigfoot.com> |
> From: owner-kolb-list-server(at)matronics.com
> weather? Will poly brush and poly tone dry at
> forty degrees?
Dear John:
I have personally tested the process to zero degrees (F) without
experiencing any difficulties. Even the drying time doesn't seem to extend
unreasonably.
Frank Hodson, Oxford ME
FS II N6399J
John ,after the crows got through with my
John , After the crows got through with my KXP in the fall of 98 I patched
over thirty holes in weather just shy of a snow storm , looks kind of
"country" but its still flying! Polytone and 2inch finishing tape I dont
know what the book says but I would patch away . Chris Davis Cape Cod Ma.
14degrees and blowing 40mph
Does anyone have dates of Fun-and-Sun????
FS
KY
>Bill
>FS
>KY
April 9-15
Bill, Re the dates for Sun 'n Fun, Try their web site at www.sun-n-fun.org.
They usually have dates, maps, fly-in advisories and other useful info for
planing your visit.
If you want to get a good camping spot you sometimes have to go a day or two
early (and pay full price for those days, Ouch! ). You may want to consider
going when the crowds thin out after that first big weekend. If you plan to
stay in a near by motel you are already too late. You may have to stay closer
to Tampa or Orlando but the drive and getting in the gate are usually not bad
after the first weekend.
Good luck however you go, Duane the plane in Tallahassee
From: | "Christopher John Armstrong" <Tophera(at)centurytel.net> |
Subject: | landing gear legs of ti |
Hi folks,
Sonex aircraft manufacturers are having a $50 off sale on their Ti landing
gear legs. The 24 13/64 inch legs are down to $225.00, and the longer legs
34" are down to $300 per pair. The 16 inch tail spring is still $50. For
those of you considering an alternative gear these are supose to be
fantastic. they are 1.125 inches in diameter and are used on an aircraft
that has a gross weight of 1050.
Topher
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
OK guys, here we go. I finally started covering the rudder of this thing
the other day, and found it to go a "little" better than I expected, though
I think I'll be high for 2 weeks from the MEK fumes. This with a fan
blowing. ( It wasn't really THAT bad, honest.) Today I was applying the
re-inforcing tape, figured out how to make it go smoothly around the rivets
at the ends of the ribs, and life was sweet. Then Murphy shook his head,
and everything went to hell. 1st - the tapes over the ribs went on
smoothly, then I ran a 2" pinked tape up the front tube of the rudder; over
the hinge holes, and find that it has to stretch to lay smoothly over the
forward edge of the ribs and rivets. Only way I could do it was to snip a
little on each side of the rivet, and that leaves a tiny gap. Is this OK,
or is there a better way ?? 2nd - trying to iron the whole mess smooth at
225 deg. as in the R&R video didn't work very well. He says in the video
that you'll have to turn the iron up surprisingly high. Well I did, to
250+, and all laid down smoothly except for the excess poly-brush, which
smeared up into streaks and little balls. Is there a practical way to
smooth these back out ?? Also noticed quite a bit of drag on the iron. Is
this normal ?? I was using the little finishing iron. You sure have to
watch where you've been when coating with the clear poly-brush, don't you ??
Re-coating a "done" area doesn't work too well - more smears. Any
assistance will be gratefully accepted. Lost Lar.
Larry Bourne wrote:
> Hello
225 is really all that you need to smooth little bumps and small bubbles. It
just softens the poly brush a little so everything can lay smooth. As far as the
tapes on the tail feathers, at the shop we never bothered it's a waist of time.
The rib ends do cause a real problem with the tapes. Just my 2 cents.
Regards:
While I'm focussed on covering the rudder, here's an idea for those who
haven't started yet. The rudder horn is rivetted on the inside of the
front tube, and the fabric has to be slit to slip down over on each side.
So far, fine. Of course, me being me, I slit too much in the wrong places,
and it looked like rats chewed it open, till I put the patches over them.
Problem is, the curved piece that rivets on to the tube has a sharp edge
that sticks up just a little above the fabric on each side, leaving a ridge
that I think may be a problem spot for chafing in the future, so I put an
extra layer of re-inforcing over those few inches. Since it's all painted,
and was covered when I noticed this, I said "phooey," (or something) and
kept going. If I were going to do it over, I would file those edges down
smooth, and slightly below the fabric, to eliminate any potential problem,
and improve appearance. Helpful Lar.
Thanks for the reply John. The 1st side, I started at one end and glued it
down till I reached the other end. Kinda fought the rivets into submission.
Kinda. On the 2nd side, spread poly-brush from rivet to rivet, laid the
strip into it and let it set up a bit. Then cut the ends to length, slit
the ends to just short of the rivets, spread the glue and they pretty well
flowed down. Nice and smooth and quick and easy. I'll try (tomorrow)
the lower heat, slowly over the smears, and see what happens. I'll try the
teflon coated big iron this time. What hurts is that I found where a
piece of something got under a tape, right out in plain sight and made a
lump. Tiny lump, but it shows and I didn't like it, so took my pocket
knife, (razor sharp) and slit the tape to try and scrape the lump out. As I
said, razor sharp, and my shiny new rudder now has its' 1st patch on it.
Wiser Lar.
Sent: Friday, January 14, 2000 7:39 PM
Subject: Re: Kolb-List: Covering
> Larry Bourne wrote:
> > Hello
It
as the
time.
> Regards:
> John
video
Subject: | More and More Covering |
Hope you guys don't get tired of all this. I was re-reading the Kolb book
just now, and it says something about rivetting the fabric to the horizontal
stabilizer to prevent "drumming." Video doesn't say anything about that, or
at least, I haven't seen it yet if it does. I know I have to rivet the
fabric to the tops of the wings, but on the tail too ?? Has anyone else
done this ?? Where on the tail ?? Confused Lar.
Subject: | Re: More Covering |
BTW you might remember to burn the holes where your rivet holes etc. are
located before you put the finishing tape over them. They are kind of hard
to find with two layers of fabric over them.
Muchas Grassy Ass, I will.
Sent: Friday, January 14, 2000 9:22 PM
Subject: Re: Kolb-List: More Covering
Subject: | Re: More and More Covering |
Since I didn't want to drill any rivit holes in my skinny little tail ribs.
I just threw a couple rib stitches in the middle of the various empennage
ribs, work the knots around until they are inside the fabric, and covered
the resulting little bumps with a short section of tape. Easy.
Richard Pike
MKIII N420P (42OldPoops)
Pick spots with a big gap between front and back tubes, and tie things
down. As long as it looks right, it will be.
Richard Pike
Maybe it wasn't the finishing tape, now that I think about it. I forgot to
burn some of the holes before I put the first coat of silver on. Had lots
of fun trying to find all those little rivet holes in the trailing edge
after that. You would be suprised how quickly you can forget all these
little things. Sorry
>the other day,
When you start ironing, Poly Brush is not too friendly. And the more heat,
the less friendly. Sometimes it helps to try to iron places over tubing
without sliding the iron. You kind of put it where you want it and then
rock it around, and then pick it up and move it to another spot and rock it
and work it without sliding it to get the fabric to fit down around the
rivits and bumps. Obviously that does'nt work out on the open expanses of
fabric, just around the little ticky places.
Practice on the underside of places where cosmetics are not so important,
save the top side for when you get the hang of it.
Richard Pike
> Wiser Lar.
The "lump" is what is called a gel slug. When PolyTak is poured into a
small can and applied with a brush, what is on the side and edges of the
can starts to set up. This gets on the brush and ends up as lumps as
the PolyTak is applied to the structure and then ends up under the
fabric. This is the kind of thing I said might require slightly higher
temps, and application of significant pressure from the iron.
Gel slugs were the bain of my existance when covering until I learned
something from my PolyFiber dealer. He uses a small bottle to store
the PolyTak in, and to apply it to the structure. It is similar to the
ketchup bottles one sees in restraunts, and has a long pointed spout on
the top. The one I use is a Revlon bottle and works great. Because
the bottle is closed except for the small hole in the end of the spout
it does not harden up. It is necessary to remove the excess from the
tip after it has set for a while, but this is minor. I have filled the
bottle and let it set around for days without the material inside even
starting to harden. Much better than filling a can and having to clean
up can and brush after every session.
To apply PolyTak to the structure one simply points the spout at the
spot, move along while squeezing LIGHTLY on the bottle. Lay out a bead
about 18" long, and then spread it out over the surface with the
finger. I keep a wipe rag looped through my belt like a big to quickly
wipe the finger on after this operation. If the structure surface is
vertical, one first puts the tip of a finger on the surface, puts the
spout against the finger, and then moves both finger and spout along the
surface. The finger acts as a dam and allows the PolyTak bead to be
laid down without running down. Again, quickly spread the bead into the
required thin layer, press fabric in place and proceed to the next
section. Do not attempt to do too large a length at once. One
warning. Clean the end of the spout frequently. Wipe with rag, and
sometimes poke it open with small wire (length of 1/16 welding rod works
fine). If spouts starts to clog up you will find that adhesive will not
come out with LIGHT pressure on the bottle, and then when you
instinstive increase pressure it will SPURT OUT all over everything.
This technique works great.
gil leiter
MAPLEWOOD, MN
If finishing tapes are applied to significant curves life is easier if
one uses bias tape. In using bias tape remember that it shrinks in
width when pulled in the long direction. I would not use clear
PolyBrush except for it's intended use (inside of cockpit areas, etc),
just too hard to see. After applying a tape the PolyBrush often has a
accumulated in places along side of the tape. One should work on this
with the tip of a small brush and reducer or MEK. Just lightly touch
the areas of the buildup and smooth it out.
The "...little finishing iron..." is VERY unstable in temp and varies
over a LARGE range as it cycles on and off. I would not use it for
anything but small areas that are difficult to get at with a regular
iron. All of the PolyFiber coatings soften at 225 F, and at 250 F do
much more than soften. After the PolyBrush has been applied there
should be no need for using the iron except for using the tip on the
tape edges. Sometimes one has to use the sole of the iron on areas
where the fabric goes over the leading/trailing edges to smooth down
bubbles, wrinkles, etc. In this case it is often necessary to use
higher temperature because of the heat sink effect of the aluminum, and
to press HARD to get lumps out. Using 250 on parts of tape will cause
shrinkage, which one does not want. Sometimes as later coats (spray
coat of PolyBrush or PolySpray are applied there might be some slight
lifting in isolated spots of pinked "ears". At this point direct
contact even at 225 can cause a mess. In this case use a thin sheet of
Teflon under the iron. After application of heat in this manner, do
not move the Teflon until it cools down - requires patience as it takes
a bit of time.
gil leiter
MAPLEWOOD, MN
You are talking of course about "rib stitching". One of the methods of
preventing the fabric from pulling up is pop rivets. This is absolutely
ncessary for the wings, and sometimes for the tail members. If the
airframe manufactures manual says to do the tail members, then they
should certainly should be done. Reinforcing tape (NOT THE SAME AS
FINISHING TAPE!!) should always be used when rib stitching, otherwise
the fabric can tear through from the rivet heads. This would be done on
ribs of the tail members.
gil leiter
MAPLEWOOD, MN
> Richard Pike
Nothing at all wrong with rib stitching instead of pop rivets. It is
still necessary, however to use reinforcing tape to prevent tear out.
gil leiter
MAPLEWOOD, MN
I don't understand this. Application of rib stitching (actual
stitching, PK screws, Martin clips, pop rivets, etc) are applied after
the brush coat of PolyBrush (or FIRST coat of whatever system one is
using). From what I am reading it appears that you did this AFTER the
silver coats?
gil leiter
MAPLEWOOD, MN
Had lots
I certainly hope you didn't put rivet holes in the trailing edge to rivet
the fabric. This area should have been wrapped around and then a tape glued
over it. If your have placed rivet holes in the trailing edge, I would
question the strength of your flying surface. I would further check with
Kolb. Drilling holes in structures where none are necessary bothers me.
(Click here to visit our Club site at http://www.bellanca-championclub.com)
-----Original Message-----
Date: Saturday, January 15, 2000 12:39 AM
hard
hard
>silver coats?
I was talking about the airleron, rudder & elevator hinge holes that are
covered up by the fabric, maybe I wasn't that clear.
HEY LARRY, send me your address again and I'll send you a Sq. yard of the
"teflon"
that Gil Leiter is talking about. It is really neat stuff when you'r
ironing the
tapes. I ironed my whole wings from top to bottom after I sprayed the last
coat of Ploybrush with the "teflon" layed over them. Gives them a shiny
smooth finish even before you silvercoat or paint them.
It's sunny here-going flying. Possum
Subject: | 1999 List of Contributors #2! |
Dear Listers,
Below is the final List of Contributors for 1999 as promised. Again, I
would like to thank everyone that made a generous contribution in 1999
to support the continued operation of these email Lists. Your support
directly makes the quality and quantity of this service possible.
Thank you!
EMail List Administrator
RV-4 Builder, #1763 - N442RV
=================== 1999 List of Contributors #2 ====================
Adamson, Arden
Allender, Patrick
Anonymous from MN
Asher, M.E.
Baxter, Rob
Bell, Doug
Bendure, Ryan
Bergh, David
Berrie, Robert
Blake, J.I.
Boucher, Michel
Bragg, Medford
Briegleb, Ross
Brietigam, Charles
Broomell, Glenn
Brusilow, Michael
Chatham, Robert
Clary, Buck
Coats, Lonnie
Cook, Craig - Golf Instruments Co.
Cooper, James
Cribb, William Jr.
Crosby, Harry
Dane, Bill Von
Dziewiontkoski, Bob
Ellenberger, Mike
Embree, Roger
Faatz, Mitch
Fasching, John
Gibbons, Robert
Glauser, David
Gold, Andy -Builder's Bookstore 10%
Gregory, Steve
Grenier, Raymond
Guarino, Michael
H., Harold - E.P.M.AV Corp
Hale, Brian
Hunt, Wallace
Johnston, Leroy
Jordon, Don
Killion, Clay
Klingmuller, Dr. L.M.
Magaw, David
Mains, Ralph
Maltby, Michael
Martin, Cliff - Martin Metal Fab
Mazataud, Hyun Sook
McBride, Duncan
McDonald, James
Mendenhall, Elbie - E.M Aviation
Mitchell, Duane
Morley, Harold
Peck, Phil
Pessel, Garnett
Rodebush, James
Ross, Jonathan
Schmidt, John
Scully, William
Smith, Steven
Spence, Stephen
Triff, Wes
Wagoner, Richard
Weaver, Brian
Wiegenstein, John
Wiley, Robert
Wilson, Donald
Big Lar,
I have been lurking the thread on covering. I may be a couple of steps
ahead of you in the covering process, sort of. You are ahead of me on
the finishing tape.
To get back to your original question, the blue prints show 3 rivet holes
in the horizontal brace of the vertical stabilizer. I think this is what
is referred to in the third paragraph on page 51 of the builders manual.
I think the same applies to the horizontal stabilizers also. The prints
are out in the work shop and I am too lazy to go check. Also, it is
getting cold. Down to 48 already. Only got up to low 60"s today, and
breezy.
I have covered the tail feathers, flaps and ailerons. I have brushed on
one coat of Poly-Brush on the elevators. I then decided to finish all
the covering and apply all the coatings on them in one operation. This
way I can align the work shop for the job at hand and save on the number
of clean up operations.
I started out following the procedures shown on the tape for the 1st
couple of assemblies. I ended up spending a lot of time smoothing the
wrinkles out of the edges. I switched to applying a couple of coats of
Tak to the tubing, letting it set up and then pressing the fabric into it
and applying MEK and caressing it lovingly with thumb and finger. Using
this procedure I got them smooth enough to require practically no
smoothing (ironing).
When it came to attaching the overlap, I again applied 2 coats of Tak on
top of the first layer of fabric, let it dry and then attached only the
very end/edge of the fabric using a solder brush cut off to about 3/8 of
an inch to apply just enough Tak to secure. This leaves most of the
overlap area free to move. Next I trimmed and fitted the ends. I then
shrank just enough to take out all the slack. The overlap being fastened
only at the very edge pulls down smooth over the 1st layer. I then
finished up the ends. Finally whip out the MEK, thumb and finger, to
finish Taking the overlap area. You end up with a really nice overlap
and practically no wrinkles.
I am starting on the cage now. It has occurred to me that I have to go
thru the entire process including painting the cage as the next step.
Once I attach the vertical stabilizer, turning the cage over to paint the
bottom will be extremely difficult. Or, can you lay on the ground and
spray paint up? I am planning to pull the landing gear and roll it over.
Have you discovered as I did that after you cover these parts, they are
much harder to store? My narrow minded wife says NO! not in the living
room! I am not going to cover the wings until I can put them on the
plane as I finish them.
BTW I used Gil's catsup bottle Tak dispenser. Works great!.
Possum: Where do you buy the Teflon sheets? What is it known as? (ie.
Brand name or product name).
L. Ray Baker
Lake Butler, Fl
Building Mark III, SN 312--N629RB
Hi Guys,
Just to let you know, the poly fiber patches worked out just fine today in 35
degree weather. I also touched up the paint and installed a static line for
the airspeed indicator.It was reading 10-20 mph too high so I hope this will
help. Maybe the wind will slow down next weekend so i can check it out
Thanks for the tips,
John Bruzan FSII EIS,BRS,503 21hr Chicago
The teflon I used is not exactly the same as the kind they use in the
covering classes (couldn't find that stuff), but seems to be just as good.
It is sold by "Aircraft Spruce" under "Vacuum Bagging Supplies" and called
"Non-Porous Teflon Coated Release Fabric". Part Number P/N 01-14840.
Really made for composite lay-ups. Works great with you iron. Your iron
will be your best friend by the time you get through covering your plane.
Cost about $10.00 a sq. yd. last time I bought it. Doesn't seem to wear
out so you don't need but one or two sq. yds. At the most!
I cut a 6-in. x 36-in. strip to lay over my finishing tapes to iron down
the edges every time I sprayed another coat of something over them, if you
know what I mean. You can iron over Polytack, Polybrush, Silvercoat and
even paint (if you're careful) with this stuff. You will still have to be
careful with you heat settings on your finishing tapes. This stuff's so
slippery you can lay a piece of it on the top of your wing and it will
slid off if you don't tape it down.
I don't know who's ahead of what at this point Ray. I'm about to peel off
the perimeter tape for the 3rd time tomorrow morning. I tried a combination
of straight tapes on the straight portions, and bias cut on the bends.
Twice. Ugly ! ! ! Bias worked fine on the curves, but neither seems to do
too well at molding around the rivets at the ends of the ribs - front and
back. Strange, cause the tapes I laid over the ribs yesterday molded right
around the ends by making a small split. These perimeter tapes are giving
me fits. I tried the teflon coated big iron at 225, and it worked much
better. I'll try wiping the smears off with MEK tomorrow. The chunk under
the tape was a tiny sliver, and the patch looks............OK. The little
globs of poly-brush melted down fine at 225. Possum was right - the holes
are hard to find under 2 layers. Gil, I'm printing out your messages for
permanent, on the spot references. Thanks much, EVERYBODY, for the help and
advice. I know it'll go, but what a bitch of a job. Some of you seem to
enjoy this............brrrrrr ! ! ! Masochism reigns. Thanks all - we'll
give 'er 'ell tomorra. Little Lar.
----- Original Message -----
Sent: Saturday, January 15, 2000 3:59 PM
Subject: Re: Kolb-List: More and More Covering
> Big Lar,
> the finishing tape.
Hell, I enjoy watching you do it.
Subject: | Re: 1999 List of Contributors #2! |
Matt,
I'm not concerned about the listing, but since I'm not on the list I want to
be sure you did receive my check back near the 2nd week of November. It has
been processed by the bank and I want to be sure it got to you and not
someone else. Just checking (no pun intended).
Charlie Kirtland
Thanks all - we'll
Lar, I am a Challenger builder and am not intimately knowledgeable as to
the minute details of Kolb construction. I do not have a real clear
picture of the area with "...rivets at the ends of the ribs." You might
be trying to accomplish too much. It is very difficult to get the
fabric to lay perfectly flat and closely match a rivet head. Usually
there will be a small bubble around the rivet. Will all look nice and
smooth, but there will be a small area around the rivet head where the
fabric DOES NOT contact the structure. Sometimes one can make it better
with the tip of the iron, but there are limits.
gil leiter
MAPLEWOOD, MN
Subject: | Confusion Over "List of Contributors"... |
Hi Listers,
I'm really sorry for the confusion over the most recent posting of the
List of Contributors #2. List #2 contained only the contributor names
*since* the List #1 was posted. So, if you weren't on List #2, you were
likely on List #1. Below are URLs to each of the LOC #x postings.
Again, sorry for the confusion. I should have made it more clear in
the verbiage.
Thanks to everyone,
Email List Admin.
============================= LOC #1 and #2 ================================
List of Contributors #1 - 1999
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=29144?KEYS=list_of_con?LISTNAME=Homebuilt?HITNUMBER=2?SERIAL=11144111847?SHOWBUTTONS=NO
List of Contributors #2 - 1999
From: | Matt Dralle 925-606-1001 <dralle(at)matronics.com> |
Subject: | Re: (Whoops) Confusion Over "List of Contributors"... |
>Okay, here are the *real* URLs. Sorry...
>Matt Dralle
>Email List Admin.
>http://www.matronics.com/searching/getmsg_script.cgi?INDEX=53146?KEYS=list_
>of_con?LISTNAME=Homebuilt?HITNUMBER=1?SERIAL=11144111847?SHOWBUTTONS=YES
Subject: | Re: (No, Really - Here are the URLs) Confusion Over "List of |
Contributors"...
Geeze, I can't seem to type today. Here are the *real*, *REAL* URLs.
Sorry for so many posts... Ack
Email List Admin.
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=53146?KEYS=list_of_con?LISTNAME=Homebuilt?HITNUMBER=1?SERIAL=11144111847?SHOWBUTTONS=NO
Larry,
My memory is a little slow to kick in sometimes. When it did, I checked
the archives and found this little gem. I plan to give Jim a call when I
get ready to start on the tapes.
Ray
Match: #3 Message: #13762 From: "INFO" <info(at)aircrafttechsupport.com>
Subject: Finishing tapes........ Date: Dec 29, 1999
Hi to the list, and HAPPY HOLIDAYS to all of you!!
About those finishing tapes..... the main reason for taping all fabric
edges is to give a "plywood" or "sandwich" effect. This helps to insure
strenth and integrity to the fabric edges.
I have some techniques for applying the tapes, that almost eliminate the
need for cutting "darts" or wedges in the fabric or tapes when you're
attempting to make them lay down over such protrusions as "Holmer's
bumps",
as well as ideas for taping the edges of the control surfaces.
Here's an open invitation to all of you to call me anytime toll free to
talk
these techniques over!!
We do this stuff everyday here at Millertime airport, if any of you are
in
the area, give us a call & come on over!!
Jim & Dondi Miller
Aircraft Technical Support, Inc.
Poly-Fiber & Ceconite Distributors
(Toll Free) (877) 877-3334
Web Site: www.aircrafttechsupport.com
E-mail: info(at)aircrafttechsupport.com
B. Young.
Yes, the propeller is turning much faster with the direct drive, thats
what I understood when I question the small 58" prop. I haven't flown
since the first flight and I have repitched the prop and put a trim on
the rudder, results are yet to come. Been having too much wind and by
the time I got around today, its rain. The most I have gotten out of
the engine was 2800 rpms, had too much pitch. Sure did push it
though.I'm looking for around 3200rpms at full throttle. Its getting
off the ground with 23 to 2400rpms so watch those fast taxi's unless you
have plenty of room. I just about kissed the tree's at the end of my
run way when it took off. I gave it a ground loop, mild one, and it
stopped with no problem. I had it back on the ground, but was going too
fast for the brakes.
Dallas in Norfork,Ar.
The propeller is a Warp Drive 58" tapered.
Dallas
>Been reading about your Teflon sheet comments in the Kolb group. When using
>this stuff, does it affect your iron settings much. I mean, do you have to
>increase the setting a certain amount when you put the Teflon between the
>iron and the fabric? Which might mean I gotta calibrate the iron for two
>applications?
No you don't have to reset your iron. This stuff is thin, like wax
paper know you might think this is stupid, but I drilled a hole through my
small iron (model iron) just a little bigger than the rivet heads, near the
"pointy end" and tapered the bottom out smooth with a "step drill" (the
small iron is soft metal).
You can rotate the iron around the rivets to shrink the fabric. Helps a
"little" bit. Didn't hurt the iron.
You know that if you set your iron too high, it will shrink your
finishing tapes into all kind of weird shapes.
As far as Irons. Here's what I did.
1. Go to Sears or somewhere they will take stuff back-buy 3 different irons.
2. You can't tell which one will "hold" the best temp. by the price.
3. Buy yourself one of those "pocket thermometers" (you know, those little
"round things") from Aircraft Spruce or from a model shop.
4. Calibrate the irons-see below.
5. Keep the best one (the one that really "holds the temps.) and take the
others back-"you wife didn't like them".
6. Calibrate your irons with the candy therms and cross-check with the
"pocket therm",
mine matched almost exactly.
7. Now before you use your iron each time, set the "pocket therm" on the
iron turned upside down of course. It only takes about 15 seconds
to check it & no silicone to
wipe off every time.
P.S. you can really spend too much time on this if your're not careful, but
the only thing most people are ever going to see is your covering job and
your paint.
From: | "Beauford Tuton" <beaufordw(at)worldnet.att.net> |
Subject: | Less covering.... more welding |
Hey Lar:
How'd the covering go on the horiz. stab...? You were going to attack it
today, weren't you?
I got your squirrel note, but couldn't help but notice the omission of any
mention of the covering... silence is scary...
I have a separate question I've been mulling over in the sodden mush which
passes for my mind, and I thought you, or one of the other Kolbers, might
have some knowledge/inputs which could help....
I wanna buy a welder... a real one... not another one of the little
straight AC "buzz boxes" like I've blown holes in various cars, farm gear,
bystander's clothing, small animals, etc. with in years past, but a real,
no-joke sophisticated machine...
To start with, I gotta build a superstructure on this trailer chassis I'm
having built to haul around my so-called airplane... As any real,
testosterone oozing, specimen of Guyneedmoretoolus Americanae can instantly
see, there is opportunity here....a bit of daylight... a TOOL opening...!
"But Honey, just think of all the things I'll be able to build and fix for
YOU after we get up on the farm..."
It strikes me that I would need a welder to do all of the following:
--- Weld mild steel from about 20 gauge sheet up thru at least
one-quarter inch stock
--- weld galvanized materials
--- occasionally weld aluminum sheet...
There are a number of nifty little 100 to 130 amp MIG wirefeed gizmos on the
market which claim to do all the above, but here's my question....(s):
Can these DC MIG wirefeed welders also handle 4130 chromalloy for
aircraft purposes? I seem to recall that 4130 was always gas welded... What
does Kolb use to build their 4130 cages and fittings...? If MIG works OK
on thinwall 4130 tube, are there any special requirements or techniques
needed... Does MIG burn holes through .028 or .035 tube at low amperages...?
Does one need argon, or special alloy wire...?
Lotsa questions... lotsa ignorance on this end... I figure I oughta get
some answers before I make a mistake and get a welding unit that won't fix
this glorified lawn chair I built if'n I roll it up into a ball one fine
mornin'...
Whaddya think?
Beauford, the aluminum and dacron Butcher of Brandon
Still hacking away at FireFly #076
Get a the small 100/130 Miller or Lincoln Mig welder, they cost in the $500
to $600 range. They are small, handy, portable, operate off 110 vac and
will do everything you describe except the aluminum. Forget the no-name
buzz boxes you describe they are a poor substitute.
In the hands of the unpracticed, yes it will blow lots of holes in .035
tubing. It does take a lot of practice for such welding - but novices don't
do well with a torch either without practice. A TIG is easier to weld thin
wall tubing with - you have better heat control, but plan on spending a lot
more money. Don't plan on a lot of 1/4" thick steel either with the 100/130
machines.
Dennis
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Beauford Tuton
Sent: Sunday, January 16, 2000 7:31 PM
Subject: Kolb-List: Less covering.... more welding
Hey Lar:
today, weren't you?
mornin'...
Whaddya think?
Subject: | Re: Less covering.... more welding |
Dennis:
Thank you for the response...
Leading contender so far is the Lincoln WeldPack 155, which runs off 230V
and seems to offer a fair compromise between cost and capability....
The missing piece was performance on 4130 tube... I reckon a man needs some
practice, 'eh...?
Thankee,
Beauford
Sent: Sunday, January 16, 2000 8:51 PM
Subject: RE: Kolb-List: Less covering.... more welding
$500
> to $600 range. They are small, handy, portable, operate off 110 vac >
Hey Lar>
the little
> Beauford
Beauford and Kolbers:
The best aircraft welder I know lurks on this List. In
fact, he has welded, modified, fabricated, straightened,
replaced, spliced, bent, cut, and ground, on ever aircraft I
have built, flown, and broken. BTW: That covers all
three. Some more than others.
Contact me bc and I will give you his email, or maybed you
can pull him out into the open and get him to pass on some
of his expertise on the List.
> >applications?
> "pocket therm",
> your paint.
Some really excellent ideas here.
One thing to watch for when calibrating your iron. I have been told
that some (many?) of the new irons now being sold have a "safety"
feature to protect you from your own stupidity. If it is in the
horizontal orientation without movement for a set period of time, it
will automatically shut off. This is in case one is ironing shirts and
leaves the iron sitting on the shirt while going to the phone, etc.
Would be good for that purpose but would present problems when doing a
full calibration for covering purposes. Should be obvious if you get
this kind, as after a bit the temp would only go down rather than cycle
between a high and a low.
Incidentally, in case one does not know it, leaving the iron sitting on
polyester fabric without movement presents no problems at all. The heat
shrink apropriate for a given temperature occures almost instantly when
hit with that temp. Continued exposure to that temp will do absolutely
nothing more.
gil leiter
MAPLEWOOD, MN
gil leiter
MAPLEWOOD, MN
Subject: | pressure test the 582 |
Has anyone on this list pressure tested a 582 to check the crankcase seal
integrity? I need to know what details are involved (I understand the
general method), due to the presence of the rotary valve. I'd like to
pressure check the fornt and rear crankcase hsections independently, if
that's possible...
Machines are cruel to me this week. If I don't miss my guess I have the
mag-end bearings and seal out on a 100-hour 582. symptoms are : front
cylinder EGT 100 degrees warmer than rear at any RPM above idle, subtle
low-frequency vibration in airframe and prop has been eliminated as source
of vibe, power still unaffected.
Checked;
plugs changed, all four coils firing
disabled the HAC, plugged carb vac port
gearbox checked for play, changed oil, no metal particles found
examined cyls for carbon buildup, seemed pretty clean, will be checking
rings tonite thru exhaust ports
prop methodically balanced (each of 3 blades weighed, cg found to be equal
on all 3, weight added at cg on 2 blades, static check last)
carbs dismantled, needles tite and same, floats checked, bowls dumped,
screen in place. sync'ed mechanically
EGT connections checked OK, cannot swap senders due to rust of senders in
manifold, will work more on this
no visible leaks anywhere on engine or gearbox
Plan:
may swap carbs
eliminate fuel pump diaphram as possible leak source (powered by front
crankcase, right?)
pull exhaust, examine rings for freeness
pressure check crankcase
get EGT senders out and swap them
send for a 582 rebuild how-to video (any suggestions?)
pray (probably too late for this project)
Bruce, buy the Jabiru.
Jim
Subject: | Re: Kolb-List Digest: 01/15/00 |
Try this on a scrap of tubing that has some straight and some curve.
When applying finish tape cut a piece of tape about 6 inches longer than the
surface to be covered.
Mark the center line, length wise,of the tape with a soft pencil.
Paint the apex of the straight portion of the tube with a thin line of glue.
Let it tack.
Place the tape on the apex of the tube using the pencil line as a guide.
Activate the glue by painting the pencil
line. Do not do the curved portion at this time but glue down the tape on
the straight portion on both sides of the curve. Stop about 2 inches before
the curve starts on each side.
When set, glue down both side of the tape on the straight portion again
stopping about 2 inches before the curve starts. Let it set.
Now iron the curved portion until it fits nicely. That little iron the
model airplane builders use works great.
The tape should fit almost as thought it was glued down. Take your time and
work top and bottom of the tube.
Glue down the curved portion by painting thought the tape and working glue
beneath the tape with your brush.
By they way, I don't use bias tape. I found it harder to work with than
using the above method.
From: | "Thompson, Todd" <todd.thompson(at)dsl.net> |
Rather than teflon - which is hard to find - you can use parchment paper.
This is "baking paper" you can find in the local Grand
Union/Stop&Shop in rolls and works great as a barrier from your iron.
Subject: | coolant pressure problem, conclusion |
To follow-up with everyone on the coolant-pressure thing, three items I am
fairly sure of at this point:
ONE:
A wise man wrote me and pointed out that it is common for the pressure in
the cooling system to be higher than cap rating until the initial opening
of the cap. (My interpretation of what he said is:) The cap rubber seal
disk gets pressed down by the cap spring and is warmed by the coolant
naturally and softens to mate quite well, then the engine is shut down and
vacuum in the system forms, further pulling the cap down and holding it
there while it cools, sort of "glueing" it in place. So, the next day you
warm up the engine and the pressure has to overcome the cap spring, AND the
pressure (apparently 2-4 lbs additional judging by my experience) of the
cap seal "glued" to the radiator neck. Different caps may act differently
due to different rubber compounds. Coolant type and additives may also
affect this situation, I think.
I verified this by putting a generous coating of Triflow on the cap seal,
and the next operation of the engine produced normal cap pressure, no
warmup peak. I then did an experiment with a crude Teflon seal disk I
made. The Teflon worked well too, no stickyness but my quick design did
not include the small vacuum-relief valve which allows coolant to flow back
into the system after cooldown. I will keep working toward producing a
full-featured Teflon solution, and do some long term tests on it.
TWO:
The use of the non-silicate antifreeze (and distilled water) seems very
important. I will be switching soon. Experience seems to be showing that
the RV shaft seal problem will be minimized with it. I am also looking for
some Prestone water pump lube additive (even though the guys at NAPA say
that "all new coolant has it in there already"), it may help the seal stay
more pliable, less sticky. And I will change coolant at least yearly.
THREE:
I modified one of my caps to produce a lower spring pressure. I did this
by simple bending of the spring, and now have a cap that produces 12 psi
working pressure in my system now, as opposed to 15 psi it used to produce
(my measurement point adds 2 psi of static "head" to the actual system
working pressure). Summer heat may prove I need more pressure to maintain
cooling capacity, we'll see. But the point is, I can choose the pressure
it runs by carefull spring tuning. More experimentation. Maybe have a
summer and a winter cap. Easy to change. Maybe I won't feel the need to
change, if the Teflon seal disk works out. It is the peaks I am worried
about. When they get to 18-19 psi, I get worried.
Rotax Company, are you listening?
Jim
>will automatically shut off. Should be obvious if you get
Gil's right-make sure you don't buy one of those automatic shut off irons.
If the "beeps" don't drive you crazy, the temp. fluctions will.
Dallas: I have a 56X43 Props Inc. wood prop I got for my Jabiru because no
one made anything with a medium chord profile in composite. Now Ivo has a new
medium chord prop which is very well suited for the Jabiru. Mine is not even
running yet but my research suggests (Prince props) 54X43 wood prop ! Now
thats small. I plan to get the Ivo as soon as I wear out the wood one in the
rain or rocks. Shouldnt take too long. Kris Henkel
Titan builder
Subject: | Re: coolant pressure problem, conclusion |
Forgot to mention Havoline also makes extended life--the water pump
lubricant is approx. ($6.92) $7 with tax.--available at Wal Mart.
Lindy
Don't sell the wood prop short. They have been used for years on airplanes
with minimal maintenance. Wood props can be optimized in the twist to make
them more efficient. Composites hawe a compromised twist, sort of one size
fits all. I flew a wood prop for years with no maintenance except to
rebalance every couple years when I would refinish it with new varnish.
Woody
>> "pocket therm",
gosh I just went to the nearest garage sale and picked one up for 2 bucks.
Wife used to get pissed when I would gum up her good one. I used my cht
guage to check the temp and went at it. I think if you put on the fabric
too snug to begin with it will affect the final project more than if the
iron wanders a bit on the temps. Ever hear of someone not being able to use
the final heat setting on the fabric because the airframe was starting to
bend under medium heat? I bet everyone on the list has had experienced that.
This is worse than having inconsistant heat control. It was recommended to
us to put an extra 2" tube under the fabric as we were covering the wing and
then slide it out after. Makes a real baggy fit but it shrinks right down
and you can use the final heat setting where the fabric will set properly
and drum tight.
Woody
Looking for the best deal on a BRS VLS 500 system anybody know who to call
thanks
From: | Erich Weaver 805-683-0200 <sbaew(at)dames.com> |
At the time I ordered my VLS-500, I found very little difference in
prices between the suppliers for a brand new one. I guess you could
always check the Ultralight want ads fo someone who wants to part with a
pre-purchased (but "unused") one, but these seem to be rare.
I believe I got mine from airstar discount sales (1-800-247-7827)and
saved a litle bit over Aircraft Spruce et. al. Probably the most
significant thing you can save on is sales tax, provided you are ordering
from out of state, etc so check on that too.
Im not sure of the current status, but there was a very long wait when I
ordered mine. Look into this at the time of ordering. Some distributors
have standing orders from BRS for specific chutes, and you may be able to
save time by having them alter their existing order from BRS. For
example, if their existing order is for 3 canister models, BRS can easily
change one of them to a VLS rather than fill the cannister order first,
and then have a second order for your VLS. That request for an order
change will have to come from the distributor however, so it may require
some brown nosing. Did I make that all clear?
The installation instructions from BRS that I got for a Mrk III simply
wouldnt work on mine, and I ended up devising my own installation. Thats
OK with BRS, as long as you send them pictures to review so they can
approve it and give you your 1-year warranty. I also had to extensively
modify my wing gap seal. Nothing seems to be easy when it comes to
completing your ultralight, especially when you are waiting for that
first flight.
Good luck. If I can do it, everybody can.
Erich Weaver
> Erich Weaver
Erich and Gang:
I think the biggest change for my MK III and the 2d Chantz
was to add one rib to make a bay for pack tray, then cut a
door in the lexan for the chute to exit and a little round
hole for the rocket nose to stick out the top.
It has been a long time so I maybe suffering from CRS and
illussions again.
Woody,
A thought on props. A composite prop will shatter into broom straw
if it hits something solid, like the ground, whereas the wood is much
stronger and will resist the sudden stop. The engine torque would most
likely damage the gear box or twist the crank shaft causing expensive
engine repair.
Just a thought...
FS
Ky
> engine repair.
> Just a thought...
> Bill
> FS
> Ky
Evening Bill and Kolbers:
Don't know where you got your thoughts from, hehehe, but I
think you have them backasswards as we say down here in
Alabama, or you might just be 180 degrees out.
I have experience destroying wooden props, but so far have
been unable to destroy my Warp Drive Solid Carbon Fiber
Prop. Through the years as my wooden props hit the ground
in the Ultrastar, as all kinds of FOD fell off the aircraft
and went directly to and thru the prop, the wooden blades
readily came apart. On one occassion a GSC 3 blade wooden
prop came apart on its own accord. I didn't have to coax it
to splinter.
On the other hand, I cut more Alaska brush on one aborted
landing than the county right away crew cut in a week. Only
damage, lotsa green stuff on the leading edges of all three
blades, and the leading edges of everything on the airplane
that got drug thru that stuff. Another time I put a 1 1/2
inch piece of steel exhaust pipe with one 180 deg bend and
one 90 bend thru the Warp Drive at full throttle over
Prattville, Alabama. Hope it did not hit anyone after it
got batted back up and under the bottom of my "gold plated"
Rotax 912 radiator. I flew about 15 miles to Wetumpka
Airport and landed, fearing the worst. I had some
vibration, but could not feel anything else the matter while
flying. Upon inspection I found one blade had a chunk out
of the leading edge, tiny little place, about like putting a
small screw or washer thru a wooden prop. Fired it up and
flew another 11 miles to my airstrip with no problem. Would
not want to try those tests again with any other prop,
bushes and exh pipe, and don't really want to do it with a
Warp Drive either. I do not know of any UL prop that would
have gotten you home afterwards, safely.
One more thing about a Warp Drive. I witnessed a Rans S-12,
912 powered, Warp Drive 3 blade prop, no wings attached, but
everything else that was supposed to be there was in place,
except pilot, depart the front of a hangar where it was
being worked on at WOT. Looked like a dragster blasting
across the airport towards the east perimeter of pines. A
couple hundred feet before it impacted the trees it hit a
berm about 2 or 3 feet high, went airborne, rotated nose
down so that the prop blades were horizontal. The blades
hit a pine about 15 feet off the ground. One blade cut
halfway thru a 6 to 8 inch diameter pine tree trunk before
it broke off at the hub. That's tough. Luckily, no one was
hurt except the owner's pride and pocket book.
john h (get to see all kinds of exciting things flying ULs)
Hey Guys,
I do know that a roll of toilet paper will shatter a wooden prop into
thousands of pieces & tear the engine off your frame.
Just a bad memory... Richard Swiderski
BILLBEAM(at)aol.com wrote:
> Woody,
> engine repair.
> Just a thought...
> Bill
> FS
> Ky
Subject: | Re: PPC Fw: WHY AIRPLANES ARE BETTER THAN WOMEN |
WHY AIRPLANES ARE BETTER THAN WOMENJust for fun.
Tim T.
; ChrisE
Sent: Monday, January 17, 2000 11:07 PM
Subject: PPC Fw: WHY AIRPLANES ARE BETTER THAN WOMEN
An airplane will kill you quickly...a woman takes her time.
Airplanes like to do it inverted.
Airplanes can be turned on by a flick of a switch.
An airplane's thrust to weight ratio is higher.
An airplane does not get mad if you "touch and go".
An airplane does not object to a preflight inspection.
Airplanes come with manuals.
Airplanes have strict weight and balance limits.
You can fly an airplane any time of the month.
Airplanes don't come with in-laws.
Airplanes don't whine unless something is really wrong.
Airplanes don't care about how many other airplanes you have flown.
When flying, you and your airplane both arrive at the same time.
Airplanes don't mind if you look at other airplanes, or if you buy airplane
magazines.
It's OK to use tie downs on your airplane.
Subscribe: powerchutes-subscribe(at)onelist.com
Unsubscribe: powerchutes-unsubscribe(at)onelist.com
Web Page: http://www.powerchutes.com
Hearme Chat: http://www.powerchutes.com/popup_simple.html
The news that the caps stick a little after sitting is
enlightening. Part of my preflights will be to remove the cap and
replace. This should prevent the opening spike.. Thanks.
> >> "pocket therm",
> and drum tight.
> Woody
Keep in mind that at 375 F polyester starts to relax and loosen. Go a
bit above that and it will deteriorate and rapidly lose strength. You
might not immediately notice it until the day you stress it a bit in a
sharp pull up, etc. You really do want to be sure that at the 350 F
setting it will not approach he upper allowable limit when at the high
end of the cycle.
As for installing the fabric too tight, this is certainly possible.
PolyFiber manual, says to allow "about an inch of slack" as I recall.
Your idea of putting some kind of "spacer" in place sounds good to me,
since it is difficult to estimate visually. I prefer to do an
additional heat shrink step at 325 instead of going from 300 directly
to 350 for just that reason.
gil leiter
MAPLEWOOD, MN
Subject: | Re: water pressure |
Yup, that would probably work. You will get a little coolant coming out
dribbling down your arm though. Its too bad we can just pull a tab that is
connected to the internal disk (while cap is fully installed), pull up to
pop the seal without removing the cap. Hey, it seems like some car rad
caps had this, a lever that removed rad pressure.
Jim
Dell Vinal on 01/18/2000 05:58:30 AM
Please respond to kolb-list(at)matronics.com
cc:
Subject: Kolb-List: water pressure
Subject: | Re: pressure test the 582 |
>that's possible...
If you buy a tester from CPS, it comes with various sized rubber plugs. You
have to remove the rotary valve and then you block off the intake opening
behind the rotary valve with a plug to seal up that cylinder. If you don't
remove the rotary valve, it leaks air around it. Three of us in the chapter
split the cost and each share the tester. The CPS tester works quite well.
If you get one, go ahead and make up a metal brace to hold the intake plug
in place and then just keep it in the box for next year. You can angle it
across the rotary valve cavity to hold the plug, and anchor it with the
regular bolts. We use a small sheet of rubber to cover the exhaust port,
and back it up with a metal backer plate to keep it from flexing. A tester
is a worthwhile investment. The crankcase on my 532 had never been split,
and had a small leak ever since new down in a corner behind the mag, not
bad enough to affect the EGT's, but just enough to keep the mag cavity a
little oily. Found it right away with the tester.
Richard Pike
Just a word to the wise: two years ago, just before heading to Oshkosh, I
ordered new crankseals, exhaust springs, and points for my 532, and one of
the wingmen ordered a helmet/headset combo for his Drifter from Airstar
Discount sales. The helmet arrived with no liner, he made a phone call, and
the liner arrived separate, obviously broken and crudely taped back
together with strapping tape. He sent the whole mess back and demanded a
new one, got it just before we left. Several of the exhaust springs I got
were obviously used, stretched and sacked out. The letter I sent requesting
replacements or a refund was unanswered. The seals were not Rotax parts, I
used them anyway, and changed them as soon as I got back from Osh. They
were in the process of coming apart, the rubber in the middle of the seal
had detached from the metal. The points went bad in route with less than 14
hours on them.
Save your money when you can, but inspect your parts closely...
Richard Pike
>Erich Weaver
Subject: | Oil pump-arm return |
HI Gang,
Had problem with oil pump metering arm not returning completely when throttle
was retarded to idle. Found that the pump itself had some slight internal
friction at half way point. Since replacement parts are not available, I
purchased a new pump and cable.
After installation and adjustment the problem still exists. In fact it's
worse. Apparently the spring on the arm is not strong enough to overcome the
slight friction in the cable. I have tweaked the tab where the adjuster
mounts to improve the angle of cable to arm to no avail.
I suspect this problem is common and perhaps goes unnoticed by some. I'd be
interested to know the results of others doing the following simple test:
1. With throttle at idle, check the position of the arm. It should be at the
mark if you have set up to factory spec. If you have set up to CPS's Mike
Strattman's recommendation the throttle should be at the 3000 rpm point when
the marks line up. (Don't know why he recommends that.)
2. Go back to cockpit and cycle the throttle from idle to full and back. Now
check the position of the arm. If it is not aligned with the mark you have
the same problem as I do. Give it a little tweak with your finger and it'll
go back to the mark.
I have the oil injection cable with a 24 1/2 inch sheath going to the 3:1
splitter. Carb cables return to idle OK. Cable makes a vertical turn of
around 190 degrees from splitter to oil pump.
Bill George
Mk-3 582 "C" Powerfin
>Woody,
>engine repair.
>Just a thought...
>Bill
>FS
>Ky
If you have a prop strike on a Kolb you have a lot more to worry about
than engine damage. I would have thought the wood prop would have shattered
better. Any prop strike calls for a tear down.
Woody
Subject: | Re: Oil pump-arm return |
WGeorge737(at)aol.com wrote:
> HI Gang,
we had this question up on this list some time back. i did a check on
our club's rans s-6, and i found the same problem. i then started the
engine with the plane tied down and performed the same test cowling off,
and had no problem. seems like the vibration from the engine makes the
cables less prone to sticking. our engine/plane/cables have about 600
hrs on them. makes sense to keep the cables well lubricated though.
ole
Subject: | Fw: BUG Ultralight Seminar in Real Video this Saturday |
Info--see web site at end of message to check your system
Lindy
LA-Lower Alabama
Sent: Tuesday, January 18, 2000 11:22 AM
Subject: BUG Ultralight Seminar in Real Video this Saturday
> You asked for it, you got it! This weekend's Ultralight Safety Seminar
> presented by the Bluegrass Ultralight Group (BUG) will be webcast live in
> Real Video. For those that can't come in person, tune in starting 9 AM
EST
> this Saturday for the all-day event. You won't be able to win any of the
> 100+ great prizes we're giving away, and you'll miss out on networking
with
> all the ultralight pilots that come from half a dozen states, but you will
> receive the benefit of our top-notch speaker lineup! If you can't be
here,
> please join us on-line!
> I recommend visiting our web page at http://www.cvb-1.com/BUG to test your
> Real Player installation...it does require a recent version of the player.
> All up-to-the-minute details about the seminar can be found there.
> Blue skies,
> -dave
> ps. Please forward this message to other pilots who may be interested!
> David Hempy -- USUA Region 6 Representative
(KY-IN-MI-OH)
> ASC Trike BFI #BKY56 -- FAA Aviation Safety Counselor -- EAA
#456510
> -- www.davidhempy.com --
(c)2000,DBH
> Views expressed are not those of ASC, FAA or USUA unless explicitly
stated.
> This message brought to you by the UL-Reps mailing list.
> This post is in no way representative of or affiliated with
> the United States Ultralight Association.
> For more info, please write to
Subject: | pressure test 582 |
crankcase seal
understand the
valve. I'd like to
>pressure check the fornt and rear crankcase sections
independently, if
>that's possible...<<<<<<
a pressure test may prove to be good while a vacuum test may
show a leak. been there and done that on a snowmobile
engine. pull a vacuum test
boyd
From: | "William Herren" <wmdherren(at)hotmail.com> |
There's a good article in EAA's Experimenter mag Jan 2000 "Meet Homer Kolb"
that I hope all Kolb listers get to see. Bill in Lousyana
Hi Kolbers:
One of my good friends and fellow Kolb Sling Shot pilot,
Ronnie Collins, suffered injuries yesterday afternoon when
he inadvertently backed into the three blade Warp Drive Prop
as his 582 idled for warmup. He was checking something
under the left wing. With his attention diverted, he backed
into the moving prop. Luckily, he received serious
lacerations to the rear of his right tricep without breaking
any bones or any permanent nerve damage. He was hit with
three blade tips before being knocked to the ashphalt.
Another of our friends was in the area with a cell phone.
Shortly, an ambulance arrived and took Ronnie to a local
hospital where surgeons to put him back together again. I
believe Ronnie was released and sent home late this
afternoon. When I talked to him this afternoon he had some
words of wisdom for all aviators. No matter how long you
have been flying do not take anything for granted. A
moments lapse of attention can get one into a lot of
trouble. Always be aware of a rotating prop when moving
around the outside of the aircraft. Best yet, do not move
around the aircraft if the prop is in motion.
Ronnie gave me permission to share his experience with you
all in hopes that his misfortune might prevent someone else
from suffering the same tragedy.
From: | "Geoff Thistlethwaite" <geoffthis(at)worldnet.att.net> |
John,
your friend is very very lucky (relatively speaking) to have been *backing*
into the prop.
Hope he has a speedy recovery.
Date: Tuesday, January 18, 2000 11:09 PM
Subject: Kolb-List: Prop Strike
>Hi Kolbers:
>john h
From: | "michael highsmith" <firehawk54(at)hotmail.com> |
Hey George and gang:
I have oil injection on my 582 also. I never have had a problem with it in
900 hours. I use a cable system and splitter that I designed for my
particular purpose. I wanted the shortest cable length possible to eliminate
cable slap. All injectors have the detent in the arm movement because of the
change in oil supply ratio of the pump. It changes from 70 to 50/1 at this
point. I suggest that your problem is like you suspect, in your injector
cable or the splitter. I have found that all cables are not alike. Some have
plastic sleeves some do not. The cable housing must have a liner of some
type in order for the cable to move with the least amount of friction then
your problem will most likely go away.
Just my experience and my opinion of things that have worked for me.
A group of us flyers, 14 in all, made a fly'round this past weekend.
I traveled 511 miles
8.3 hours flight time
landed 9 times at 5 different places
Firehawk
>throttle
>Bill George
Subject: | Re: pressure test 582 |
I will try that, thanks! I will have to remove the RV assembly first
though. Pressure test worked OK, loss was about 3/4 psi per minute from
9psi to 5 psi, then held 5 psi. I don't know if that's good or bad. I
will try the vac test next, after I get my hands on a Rotax flywheel
puller.
Jim
b young on 01/18/2000 07:33:15 PM
cc:
Subject: Kolb-List: pressure test 582
crankcase seal
understand the
valve. I'd like to
independently, if
boyd
Subject: | 582 pressure, tools |
Well I did the 582 crankcase pressure-leak test last night. I put 9psi
into the fuel pump pulse port, with the carb sockets plugged, the exhaust
ports blocked with rubber gaskets, and spark plugs installed. Results:
Leakage at the rate of 3/4 psi per minute, from 9 psi to 5 psi, it held 5
psi. Is this good or bad? While doing this test, the coolant pressure
gauge was also monitored and showed no increase, so the head gaskets must
be OK.
Someone suggested doing a vacuum test also. I will be able to do that
tonight. That one will require the removal of the RV assembly. I have 22
inches of vacuum available, hopefully that is enough.
I guess to put this issue to rest I need to pull the flywheel and coils, in
order to spray soapy water on the front seal and actually see leakage in
the form of bubbles. Once I get that far, the engine will be about
half-way dismantled. Boy it is depressing to take stuff apart. The Rotax
tool list needed is growing.
Anyone have Rotax tools for sale, collecting dust?, quick money!
Jim
From: | "Richard Neilsen " <NeilsenR(at)state.mi.us> |
As I was listening to all this good covering info I remembered a small thing I
did on my plane.
I looked at a lot of Kolbs before I built mine and decided I didn't like the looks
of the leading edge of the wing were it transitions to the much smaller wing
tip tube. Also the leading edge of the rudder to the top loop/ trailing edge.
In every case I built a light gage aluminum faring that tapers from the large
tube to the smaller tube. The faring is made from a small piece of sheet aluminum
riveted to the larger tube. It serves only as a cosmetic effect and eliminates
the end of the leading edge tube from being the stress point on the fabric.
Rick Neilsen VW powered MKIII 20hrs.
Just finished a 4 into 1 exhaust system and am working on rejeting my Weber carbs.
The OAT temps just peaked above 20 degrees for the first time in a week so
I was able to get a test run in yesterday.
Agree on any prop strike callilng for tear down. My Power Fin hit the dirt
at WOT, and shattered all three blades. Tear down revealed no damage to
engine or gear box. A wooden prop is more ridged and I believe I would
have needed expensive repairs.
FS
KY
John, You need to write a book on all these thrills. Sounds to me like
you are a cat with few lives left. HA.
Mine was a Power Fin prop. Perhaps they are different composition. All
I know is that I came up with three little Whisk Brooms attached to the
hub. It looked like strands of fiberglass. D. Day tore the engine down and
gave it an A++. I had expected a crank or gear box parts at least.
I did a little tree trimming with the same prop in the back yard. I was
watching
the wing tips and not paying attention to the limbs above. The neighbors
thought
I had bought a new type lawn mower from Tim Allen on Home Improvement.
Oh well, thats part of the learning experience. Just that some lessons are
more
expensive than others.
FS
KY
Bill,
Is the arm sticking when the motor is running or when stopped?
With the motor stopped, and the lever pulled up to the WOT position, the
internal crank connected to the lever is up and in contact with the springloaded
piston. The resistance felt maybe the oilpressure buildup that is not released
due to the valve cylinder not turning and opening the the outlet channel which
can only be done by the motor running or cranking. ie, the piston and valve are
temporarely out of phase and the pump will correct this as soon as it and the
motor starts running again. The position and amount of sticking will depend on
where the pumpcycle was when the engine stopped.
This pump and lever design will only function correctly when the engine is
running.
If the lever does not return to the idle position with the engine off and the
trottle moved to the idle position after engine stop, this is due to the
internal spring loaded piston not catching up with the lever position untill
the engine starts up again.
WARNING: Do not change this external spring!
The external spring has to be weak so that it does not interfere with the
internal spring's function which is to insure the full pump stroke during every
cycle.
Frank Reynen MarkIII@565 ser#022
Subject: Kolb-List: Oil pump-arm return
HI Gang,
Bill George
>boyd
Rubber seals hold pressure one way better than others. Sort of like a one
way valve. The seal is installed to hold pressure in the crankcase. Lowering
the pressure in the case will force atmospheric pressure past the seals
(approx 14 lbs pressure).
If the seals are holding 5 lbs I would say they are good. You should not
pump up past 7 lbs.
Y'ALL WRITE BACK NOW YA HEAR?
>pump up past 7 lbs.
I don't know where that last bit came from. Could there be another virus
going around? People read that on the end of my emails they are going to
think I am John Hauck.
>pump up past 7 lbs.
Sorry, it's me again. It was just my daughter foolin around with the
signature settings of the email program. Scared me for a moment.
Woody
In a message dated 1/19/00 9:39:33 AM, Frank_R_Reynen(at)notes.seagate.com
writes:
<< Is the arm sticking when the motor is running or when stopped?
springloaded
are
running. >>
Frank
Thanks for the info. You are probably one of the few folks on the planet who
have actually taken this thing apart to see how it works. Thank goodness.
I see it on preflight. Of course the engine was at idle when it was last shut
down. I have never looked at it with the engine running.
I do know that the new pump arm was totally free before I installed it and
the engine has not been tuned over yet, so it doesn't have any residual
pressure inside. I remember reading a post on this subject (don't even know
which list it was on) where a guy mentioned the problem to a Rotax factory
rep and the rep told him to "put a rubber band on it."
Got a small light spring today and tomorrow I'll pout it over the cable end
to see how it works. Will let y'all know.
Bill George
In a message dated 1/19/00 11:08:41 AM, Frank_R_Reynen(at)notes.seagate.com
writes:
<< There are only alignment marks on the lever for idle(3000rpm) and full
throttle
positions to insure that the pump output is properly slaved to the throttle
control. >>
Frank
Do you set yours at 3000 rpm or at idle? Mine idles at about 2200.
Bill George
Subject: | Get a server with a hard drive |
Never mind,
www.onelist.com
None of the hassles.
From: Matronics Technical Support 925-606-1001 <support(at)matronics.com>
Sent: Thursday, January 20, 2000 2:50 AM
Subject: Complete Digest Text Found in Your Post...
> You have included all or most of the Engines-List's Digest Post text in
your
> reply to the List. This is not recommended and your message has not
> been forwarded to the List. In the future, please edit your reply
> text to include only the portion you are directly responding to.
> Thank you,
> Matt Dralle
> Engines-List Administrator
> [This is an automated response.]
Well, here's the latest. I improved the caps over the carb sockets to make
a better seal and now the 582 seems to hold air a lot better. It leaked
from 7psi to 5psi in about six minutes, and then held 5psi much longer, was
still 3psi three hours later. Also held 20" H2O vacuum for an hour (that's
only 3/4 psi but it is all my pump will produce). Considering all the
little places the air pressure could be escaping, I considered this to be
quite good, but I have never done a pressure test before, so: I called a
local Rotax snowmobile dealer/mechanic to ask one of their techs "how much
leakage is normal if the front seal is out", but they don't ever do
pressure checks at all ! so he did not know what is normal for leakage
rate. He stated "if there is any leaking oil from the mag end, pull it
apart and put seals in it and check bearings carefully". I might make
another call to Ed Wilson and Co. at Leaf. It appears that the crankcase
leakdown test may only identify moderate to major leaks, not small leaks.
That is unfortunate, if it could detect minor leaks better it could be a
good early-warning diagnostic. Also, from this experience I would say the
EGT indication is more valuable in detecting trouble early. So, if you're
buying instruments, put your money in the EGT.
How about it, ANY ROTAX TOOLS FOR SALE OUT THERE?
Bruce,Thanks, I will call you to meet up and maybe borrow/rent your
flywheel puller. I gotta get a look in that mag end I guess. Hopefully
will see oil oozing out while under pressure check, then splitting the case
will seem worthwhile.
Jim
Bill,
The full throttle position needs to align with the wide open marks on the pump
arm as the main cable adjustment.
The pump arm was configured to match with the Bing carbs slider movement by
Rotax since they deliver the carbs together with the engine originally .The
design of the pump slaving is such that only one point can be successfully
aligned and that should be the WOT position. The idle position is more like a
checkpoint and only needs to be close. This is only there in case you have
different carb setup IMHO.
I remember on my 582 setup that at 2200rpm, the arm was slightly past the idle
mark alignment with the cable tight and I saw many times that the arm had not
returned to this spot after shutting engine down but I was not concerned by it.
Frank Reynen MKIII@565hrs
Subject: Re: RE: Kolb-List: Oil pump-arm return
writes:
throttle
control. >>
Frank
Bill George
Subject: | Re: Kolb-List Digest: 01/19/00 |
of like a one
crankcase. Lowering
past the seals
You should not
pump up past 7 lbs.
during the compression cycle the crankcase is pulling a
vacuum to pull new air and fuel in from the carb. during
the power cycle the crankcase is pressurized getting ready
to pump the fuel and air into the cylinder. so both a
pressure and vacuum test are needed. if the seal holds
pressure but wont hold a vacuums the mixture will go lean.
boyd
>boyd
It will be sucking from the point of least resistance. That big hole the
carb fits on. there would not be that much sucked past the seals to worry
about if you consider the ratio of intake port size to max clearance around
a seal.
Woody
In a message dated 1/20/00 8:43:15 AM, Frank_R_Reynen(at)notes.seagate.com
writes:
<< The full throttle position needs to align with the wide open marks on the
pump
aligned and that should be the WOT position. >>
Frank,
Good to know. I tried the spring thing today but by now the cable had a teeny
kink in it from all of the offs and ons. Tomorrow I have to trek to the big
city so plan to visit a motorcycle shop and see if I can find a higher
quality cable with less friction. After I removed the cable I checked the arm
again and it freely returns. Will keep all posted.
Bill George
I have found that bicycle shops sell a 1/16"cable that is very
smooth and slides very well.
I replace the ends that come on it with the cable ends that
CPS sells.
Richard Pike
MKIII N420P (42OldPoops)
>Bill George
From: | "Gary r. voigt" <johndeereantique(at)uswest.net> |
ok, here we go. I have been monitering the kolb list
for about eight months now and find it very informative.
I'am non-flyer, non-buyer at the present time. however I
have been looking at the kolb firestar for about just over a
year now and I must admit I'am very impressed with this
heavy ultralight. probably because all the good story's john
h. writes and everyone else. here are my thoughts. I
contacted the kolb co. in phoenixville, pa. oct. of 1998 and
requested the info. pack on all the kolb ultralights. I
received it shortly and looked over the price sheets on the
firestar single seat version. looking under ordering
details, one of the bullets states prices effective for
aircraft purchased after july 15th, 1998. I thought ok,
thats normal. the firestar package I was looking at was kit
#1: contains wings and tail; $2,995.00; kit #2; polyfiber
covering; $495.00: kit #3: fuselage cage & ect. $3,050.00:
for a subtotal of $ 6,540.00; I was going to get the 503
engine which at the time was $3,505.00 for a grand total of
$10,045.00. I thought ok, thats reasonable and in the
ballpark for the ultralights that are on the market today.
but here is what I'am frustrated about after visiting the
new kolb aircraft co. at oshkosh this past summer. after I
obtained some new price sheets and brochoures because mine
were outdated somewhat, (takes me awhile to make a decision
ya!!! know) so after looking and comparing prices from year
to year, I found out this. the same firestar prices I looked
at in oct. of 1998, were quite a bit different than the
prices of july at oshkosh 1999. only nine months had passed
but the new kolb co. had evolved. prices that is. now; kit
#1; wings and tail; $3,299.00 up $300.00 from last year; ok
I can live with 9.89% inflation; ouch!!!. now they have two
airframe kits instead of two hm!!! whats missing. the 503
engine this year is $3,775.00; up $270.00 from eight months
ago. again increase of almost 10.2%. now as far as the
covering goes I think I have to order that from R&R I
believe, at a cost of $495.00 for the firestar. I which is a
wash because kolb deducted that off the list. my $10,045.00
ultralight is now going to run me $10,768.00 and I have to
get chute, gauges, paint, ect. which I can understand but at
these increases I better buy it fast, who knows what the
future holds for prices. all I know is maybe there
distribution centers or if they order direct from
manufactures has raised there prices, or maybe not. I don't
want to stick my neck out too far but I think holmer was a
simple man and it has gotten in the hands of big business. I
can't blame them I would do the same if it were my co. too.
if the aircraft sells then you adjust your price
accordingly, thats what drives the price. I will still
probably order a firestar soon, I have put it off long
enough. I hope I have not offended anyone affiliated with or
on this list. ok, let the comments begin.
lar I like reading your postings. how ya!!! comin on
the covering.
gil, I enjoy reading your technical information.
thanks,
Gary r. voigt
excelsior, mn.
list for about eight months now and find it very
informative. I'am non-flyer,
non-buyer at the present time. however I have been looking
at the kolb
firestar for about just over a year now and I must admit
I'am very impressed
with this heavy ultralight. probably because all the good
story's john
contacted the kolb
co. in phoenixville, pa. oct. of 1998 and requested the
info. pack on all
the kolb ultralights. I received it shortly and looked over
the price sheets
on the firestar single seat version. looking under ordering
details, one
of the bullets states prices effective for aircraft
15th, 1998. I thought ok, thats normal. the firestar package
I was looking
at was kit #1: contains wings and tail; $2,995.00; kit #2;
polyfiber covering;
$495.00: kit #3: fuselage cage ect. $3,050.00: for a
subtotal of
$ 6,540.00; I was going to get the 503 engine which at the
time was $3,505.00
for a grand total of $10,045.00. I thought ok, thats
reasonable and in
the ballpark for the ultralights that are on the market
today. but here
is what I'am frustrated about after visiting the new kolb
aircraft co.
at oshkosh this past summer. after I obtained some new price
sheets and
brochoures because mine were outdated somewhat, (takes me
awhile to make
a decision ya!!! know) so after looking and comparing prices
from year
at in oct.
of 1998, were quite a bit different than the prices of july
at oshkosh
1999. only nine months had passed but the new kolb co. had
evolved. prices
that is. now; kit #1; wings and tail; $3,299.00 up $300.00
from last year;
ok I can live with 9.89% inflation; ouch!!!. now they have
two airframe
kits instead of two hm!!! whats missing. the 503 engine this
year is $3,775.00;
up $270.00 from eight months ago. again increase of almost
10.2%. now as
far as the covering goes I think I have to order that from
RR I believe,
at a cost of $495.00 for the firestar. I which is a wash
that off the list. my $10,045.00 ultralight is now going to
run me $10,768.00
and I have to get chute, gauges, paint, ect. which I can
understand but
at these increases I better buy it fast, who knows what the
future holds
for prices. all I know is maybe there distribution centers
or if they order
direct from manufactures has raised there prices, or maybe
not. I don't
simple man and
it has gotten in the hands of big business. I can't blame
them I would
do the same if it were my co. too. if the aircraft sells
then you adjust
your price accordingly, thats what drives the price. I will
still probably
order a firestar soon, I have put it off long enough. I hope
I have not
offended anyone affiliated with or on this list. ok, let the
comments begin.
lar, I like reading your postings. how ya!! comin on
the covering.
gil, I enjoy reading your responses on technical
information.
thanks,
Gary r. voigt
excelsior, mn.
> my $10,045.00
I just wish that everyone understood the time-value-of-money. The
dollar you have today isn't what it was worth yesterday, and will be
worth less tomorrow.
J.Baker
From: | "Larry Bourne" <larrybiglar(at)earthlink.net> |
Well thanks Gary, sometimes I think maybe I talk too durned much, but nobody
seems to bitch too much, so maybe they're all more patient than I expected.
I thoroughly enjoy, and appreciate Gil's input too. He makes a lot of
sense, along with several others. Now, if I could only remember to TAKE
that advice. One Lister came up with the idea of using a squeeze bottle for
the poly-tak, and that sounds like a real winner. I intended all week to
liberate a couple of them from work, suffered various brain farts and
attacks of cranius rectitis, and forgot all about them. Now I have to go
buy them, and try it tomorrow. Question.......when brushing poly-tak, put
on 2 coats, let them dry, put the fabric in place, and re-activate the 'tak
with MEK, right ?? Works wonderfully well, you bet. But, with the squoze
bottle, do you need 2 coats, or just 1 thicker coat ?? Tomorrow, ( my
weekend is Fri. and Sat., then go in at 4 PM to Midnight on Sun. and Mon.),
I plan on giving Vic's method of running finishing tape around the curves a
try. Brilliant Lar went ahead and did the rudder 1st., which turns out to
NOT be the proper sequence, and did fine - may I say Great ! ! !, ?? - until
it came time for the finishing tape. I cut my own bias tape, folded it in
1/2, for a center line, and glued about a 1/4" around the perimeter of the
curves, while stretching it tight, and let it dry. Then heated up the ole
iron, and had at it. It had back at me, and taught me a little respect.
Yes, you really do have to make the bias tape lots wider, and it looks much
better if you taper the ends to fair it into the regular tapes. Then when
shrinking it, be VERY careful ! ! ! Using the stir stick, like in the
video, didn't work till I got the jack knife after it and tapered it down
thin. My steam iron has holes that just happen to perfectly fit the
rivets - thanks Possum - so I didn't have to drill the little iron. Works
good, but I've still got some interesting little creases, folds, and wows
around the curves that just don't cut it and will NOT come out. Think I'm
gonna have to re-do them, and boy do I hate to, after all that fussing and
fuming. Something like 10 hr. to cover the rudder through 1st coat of
poly-brush. The right horiz. stab. went beautifully, till I started ironing
it today after work, and realized I'd forgotten the re-inforcing tape on the
edges of the gussets. Aaaarrrggghhhh ! ! ! Tom Margrave, who did such a
beautiful, professional job on his FireFly is coming over this weekend to
see if he can help me salvage some of it. Cross your fingers for me.
That's about enuf ! ! ! I started this to say thanks for the compliment,
and look what it led to. Those who know what they're doing, please bear
with me. It just might help those coming up on this job, cause it ARE a
miserable S.O.B. Mekky Lar.
From: Gary r. voigt <johndeereantique(at)uswest.net>
Sent: Thursday, January 20, 2000 7:58 PM
Subject: Kolb-List: kolb prices
> at the kolb
> I'am very impressed
> story's john
> contacted the kolb
> info. pack on all
> the price sheets
> details, one
> I was looking
> polyfiber covering;
> subtotal of
> time was $3,505.00
> reasonable and in
> today. but here
> aircraft co.
> sheets and
> awhile to make
> from year
> at in oct.
> at oshkosh
> evolved. prices
> from last year;
> two airframe
> year is $3,775.00;
> 10.2%. now as
> RR I believe,
> run me $10,768.00
> understand but
> future holds
> or if they order
> not. I don't
> simple man and
> them I would
> then you adjust
> still probably
> I have not
> comments begin.
> the covering.
> information.
> thanks,
> Gary r. voigt
> excelsior, mn.
did on my plane.
To Gary and List
Upon reading your post Gary, I was reminded of some thoughts I had while
rebuilding my MkIII a couple of years ago. I priced out most of the things I
needed to see if it was better to build or buy. I found that I could build ribs
for 17 bucks or buy them from Kolb for 27. I chose the latter as I only needed
about 8 of them. The main spar tube I needed is no longer available from Dillsburg
in the 6 inch size so I ordered it from Kolb also. I don't believe it was any more
costly than it would have been from Dillsburg. The larger point is that ; if it
cost 10,000 bucks to buy, it probably cost 5,000 to manufacture. In small
quantities this is reasonable, it seems to me.
Lastly, I am astonished that there are no, plans only, knock off's of any of
these designs!! Legal of course, Pod and Boom design. The spar and ribs from
Carlson aircraft are available to all and are perfectly good for these airspeeds.
The firefly,firestar fuselages are simplicity in themselves and could be welded
up
for$ 400 to $600 in raw materials. I think that $6000 would get it done. All up.
Herb
> the covering.
> thanks,
> Gary r. voigt
> excelsior, mn.
>any of
>airspeeds.
>welded up
>up.
>Herb
I think you are right. One of the locals stalled in a MKII several
years ago and cartwheeled it, tore it up pretty good, walked away.
The remains were hanging up on his hangar wall, and could have
been purchased for a fair price before I bought my MKIII.
Would have needed one whole wing, boom, and a cage from scratch.
Other wing usable, tail usable.
But the amount of work involved in building from almost scratch,
and the price of the MKIII kit, persuaded me to go with new.
The kit was a jewel. A pleasure to build. But covering and finishing?
Big Lar is expressing very well how that goes...
Richard Pike
This approach was worked out by Jim Droemeyer, PolyFiber dealer out of
Belle Plains, MN.
First, the re-activate procedure is only for areas where it is not
possible to apply the second coat of PolyTak and immediately push the
fabric in place while working the PolyTak up through the weave. Example
might be if one wants to stick the fabric to the ribs (this, of course,
does NOT eliminate the need for rib stitching or other mechanical means
of holding fabric to top of ribs). Another example would be when one is
covering with an envelope, such as an aileron cover that is pre sewn and
slips over the surface like a sock. In these cases one has to apply two
good coats to the surfaces, put fabric in place, and then re-activate
with MEK. Again one should carefully work the adhesive up through the
fabric by rubbing it into place.
For other areas one should first apply a coat and let it dry. Then
apply a wet coat and work the fabricx into place. Don't try to do too
much at one time. The beauty of the bottle approach is that the layers
of PolyTak are usually much smoother than if brushed on, and will have
far fewer "lumps" which would have to be worked out with the iron later.
> Tomorrow, ( my
I suggest marking a center line with a #2 pencil instead of folding. A
#2 pencil or a chalk line will NOT blead through and cause a problem,
but a pen would certainly be a problem. Believe there was an article in
EXPERIMENTER about a simple device a guy made to center line mark tapes.
Yes, one should taper the ends to fair in and fasten these down with
PolyTak. After this is dry one can pull and stretch the bias tape as
required.
> Then when
> ----- Original Message -----
gil leiter
MAPLEWOOD, MN
In a message dated 1/20/00 5:25:45 PM, rpike(at)preferred.com writes:
<< I have found that bicycle shops sell a 1/16"cable that is very
CPS sells. >>
Did try one of those Richard but couldn't get the cable to take solder. Of
course I don't have a solder pot and was trying to do it with a propane
torch.
Got a tip from a fellow lister that Lockwood sells a far superior cable for
the oil injection. Will check it out.
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
I don't
>the covering.
> thanks,
> Gary r. voigt
> excelsior, mn.
Gary,
My friend I am here to let you know that all that's good in this world
is not lost and there are still good honest folks out there in the world.
The owners of NEW Kolb are just such people....
I was up in London, Ky for the fly-in at TNK last year and had a long talk
with Travis , their parts guy and he was telling me about the changes they
had made to the kits , and from what I remember they put more improvements
in the kit then they did extra money...Those fellows aren't in that business
to make tons of money , remember the old adage..."It's easy to make a SMALL
fortune in aviation , first you have to start with a BIG fortune...." (you
get the idea...)
From what I remember...
ALL kits come with completely pre built wing ribs now (Old Kolb used to
charge $150-$200 for this option alone depending on the kit (I know the
Mark3's were $200 pre built...))
The old automotive seat belt is gone...standard (ALL kits I think... New
Mark 3 for sure cause I got them...) they have replaced the little auto
belt with a beefy 4 point (Hooker-style if you are famaliar with Hot
Rods...) restraint system.
The little narrow tailwheel is gone (on the M3 I don't remember about the
other kits on this one...) They have replaced it with a beefy full swivel
model that Aircraft Spruce sells for about $220. (Memory again , I don't
feel like looking it up right now)
So if you do the math they have put about $500-$550 worth of new stuff in
the kit (Mark 3 kit at least) and only added about $300 bucks on the price.
Anyway what I'm saying is that don't sound like "BIG BUSINESS" to me. Just
some guys putting out a great product at reasonable prices...
Send them a check...you won't regret it.
Jeremy Casey
Happy Mark 3 parts owner....(you have a WHAT in the basement????)
P.S. I don't get a commission from 'em and remember that I am working from
memory and might be wrong (by a little..) on the prices quoted but with no
intent to mislead...
yah de da de da de da (insert varoius legal disclaimers here...you know
what they are...)
Found an exploded view of the oilpump in my SEADOO shopmanual which is identical
to the one in the Rotax 582 UL.
http://www.webcom.com/reynen/oilpump.html
A The right horiz. stab. went beautifully, till I started ironing
So you forgot the tapes.Whatcha gonna do. rip off the fabric and put new
stuff on? Don't worry about it. If one of those gusset corners wears through
in time put a small patch on it (good chance it won't ever wear through). If
it gets real bad in a few years recover it then. You will probably have some
hanger rash on it by then and it won't seem as important. I must have done
something wrong, I enjoyed the covering process.
Woody
Lar,
I use 2 coats of Tak. The 2nd fills in any missed spots when I smooth
out the first. I figure it is better to get a little too much on instead
of missing a spot. Working Tak down into the fabric does not seem to go
too well .
Put the first shrink on the bottom this morning. I did think to put
anti-chafe tape on the member running length wise from front to back.
You might want to consider it.
L. Ray Baker
Lake Butler, Fl
Building Mark III, SN 312--N629RB
Hey Bill,
You might want to find a good quality Bicycle Shop for the cables. I find
all the cables I need for every application at ours here at the beach. Real
good ones with the plastic inner linner and heavy duty outer casing. Got
over 900 hour on the throttle and oil pump cables. They still work like new.
I have checked them 3 times in the last three years and found them to have
no appreciable wear.
It just what I would do for me. Only my opinion based on experience.
Firehawk
>arm
>Bill George
Saw a pal of mine today who runs a bicycle shop. Asked him if they had some
with teflon inner sleeves. He said they did. Will give it a shot.
Subject: | Brakes & Dual Controls |
Here's a couple questions relating to MK III options:
Costs aside, could someone give me the pros and cons of the single control
stick versus the dual control stick option?
Also, the pros and cons of the drum brake system versus the hydraulic disk
brake option?
Makes sense to me. An earlier message has me kind of bothered; I used the
2 coat, re-soak w/ MEK on 2 sides of the horiz. stab. It worked
beautifully, very smooth and even - much better than on the rudder, where I
used the brush it / stick it method. Woody's message gives hope, kind of
what I hope to hear Tom say tomorrow - put patches OVER the trouble spots.
I also have some 2.7 ?? oz. fabric I saved from the seminar 3 yrs ago.
Should be able to make some good, heavy duty re-inforcing patches from that
if necessary. Put them on the outside, since I forgot them on the inside.
Right ?? Right ! ! ! Ray, you put the anti-chafe tape on the
front to back member of what ?? Lar.
Sent: Friday, January 21, 2000 9:54 AM
Subject: Re: Kolb-List: kolb prices
> Lar,
> too well .
> L. Ray Baker
> Lake Butler, Fl
Subject: | Re: Brakes & Dual Controls |
Can't speak for the brakes, but I have some exp. with sticks in a Mk III, a
Champ, an S-12, and a Sirocco. Also have made lots & lots of vroom vroom
noises while sitting in Vamoose. A friend in Orange County, CA. has a Mk
III that he hand crafted twin sticks for. They come stock in the S-12.
Both planes were VERY awkward to get in and out of, since you're sitting so
low, and with your feet extended. The Champ wasn't so bad, cause you're
sitting up, more like in a chair. Getting in the back seat of the Sirocco
was so bad, the stick was the least of my problems. In all 4, it seemed
like the stick travel was limited by my thighs, and I'm not an overweight
person. Not too much, anyway. ( 6', 200# ) I built a left side throttle
for my Mk III, (which isn't hooked to anything, yet ), and it's great for
backyard attack missions. Now, then.............set the tail up on a couple
of milk crates, to simulate flying angle, and taking the center mounted
stick in my right hand, and the throttle in my left, the feeling is amazing.
Can't wait to fly it. With my arms at my sides, and hands comfortably at
rest on their respective grips, it feels very natural, and I have full
movement of the stick. It's going to be an interesting feeling when I come
in for my 1st landing, later this year. ( For how many years have I been
saying that ?? ) I experimented with a piece of foam pipe insulation on
the aileron torque tube, for an armrest, and it WILL be made permanent.
Very Comfy. DayDreamer Lar.
Sent: Friday, January 21, 2000 5:49 PM
Subject: Kolb-List: Brakes & Dual Controls
Subject: | Re: : Kolb-List:Anti-chafe tape |
The First Kolb I built, I put anti-chaf tape on every thing that looked
like it needed it + everything that the class said to put it on. Not
necessary.
You can spend a little more time polishing down tose edges,
gussets-whatever and not use near as much Anti-chafe tape. Then your plane
doesn't end up looking like the "Revenge of the Mummy".
On a related note, is it really necessary to stitch the fabric to the
ribs on an ultralight? In my case a Minimax. Perhaps a simplified system
has be devised other than relying on the Polytak alone.
Dan
>Lar,
>too well .
Took the class from Aircraft Spruce 3 years ago. Was advised to put a coat
of "Poly Bush" over the raw aluminum before coating it with "Poly Tak",
because the Poly-Tak dries so brittle and the Poly Brush doesn't. The Poly
Brush helps to hold the Ploy Tak to the metal-I guess. The instructor said
this was a "requirement" for leading edges on experimentals with a VNE of
over 120 mph, especially over plywood. Maybe it doesn't matter so much on
our planes, but doesn't take that much time.
I meant put them on the trouble spots if they wore through in later years
but what the hell if you want to patch them now go for it. Just remember a
round patch has no corners to lift off.
Woody
Chomping at the bit today, wanting to have at it, and waiting for Tom to
look over my laughable attempts at covering. ( Sorry, Beauford - I think I
should call myself the fabric butcher of SoCal ) So, got into the lexan for
the quarter panels behind the doors, and around & under the center gap cover
between the wings. Keep in mind that I built gull wing doors for Vamoose,
and am making the center cover permanent. The entire cabin will be enclosed
and sealed. Both ideas are courtesy of Ron Christensen, and really look
good - almost worth the huge amount of extra work. If any newbies out there
want to see pics of those doors, let me know, and I'll e-mail them direct.
I'm told that TNK has a pic of Ron's plane on their web-site. Anyway,
months ago, I had the wonderful idea of using plexiglas for making the
patterns for the lexan. Cheaper right ?? Don't believe it. Plexi is
useless. Slant a look at it, or, heaven forbid, touch it, and it cracks and
splits in every direction. Until you TRY to break it, of course. Then it
turns to steel, and a sledge won't move it. So, went after a scrap of lexan
with a coarse wood cutting blade in a sabre saw, and cut a nice even 1/16"
(! ! !) sliver off the side of it. Beautiful. Should be Really good with
a fine toothed blade. Then clamped a piece in the vise, and went after it
with my industrial heat gun. 1300 worth. Don't even think about getting
this thing near any fabric. It took quite a bit of heat, and quite a while,
but that stuff bent into as neat a 90 bend as I've ever seen. Clear as a
bell through-out too. I have in mind rolling the front edges, so the doors
close smoothly on them, and rolling the back edges of them and the doors, to
smooth things out, and maybe have a little less wind noise. At the very
least, it'll look good. Made the patterns out of light poster board this
time, transferred them to the lexan sheets, and tomorrow will cut them out
on dad's neighbor's band saw - only because it's so much smoother, and
easier to handle. On the gap seal / center cover, I tried
paint thinner on that stuck on paper - remember ?? - and it sorta came
loose, a little of it, with much soaking, and much swearing, much waiting,
and much paint thinner. Not real practical, and stinks something awful.
Can't find goo-gone at the local Wal-Mart, though they say they have it.
I'll try again tomorrow. Big Lar.
Now, that there is a heck of an idea, Poss, I like it. How well does the
'brush stick to Al, compared to 'tak ?? Anyone ?? Tomorrow, I think I'll
run an experiment and see. Many Thanks. Lar.
Sent: Friday, January 21, 2000 8:05 PM
> >Lar,
> >too well .
coat
Poly
I can't say for sure but in my experience with Lexan I would not use Goo
Gone anywhere near it. Put the lexan in a garbage bag with the mineral
sprits so it has plenty of time to soak in and loosen the adhesive.
They may have changed goo gone since I last used it but I think it will
fog and/or craze Lexan and Lucite.
Sometimes warm soapy water is a safe alternative.
Good luck
Dan
Long as I'm in gear and going, with the TV turned off, here's a couple more.
Most of you know, (all of you, now) that I'm using a VW engine with re-drive
on Vamoose. I went for dual exhausts, with mufflers parallel to the engine
and pointing straight back. Looks REAL good, and don't mention weight,
please - they're not that much heavier. I have pics of that too. Anyway,
turns out the mufflers are so close to the intakes, that the fuel injectors
won't fit. Weeeelll, they fit, but the fuel lines would be pressed against
the muffler. Detrimental, yes ?? I have a picture in the CB Performance
book that's apparently a copy of a page out of a Lucas book. Pic is of what
they call a "Type 3" injector, and is about 2/3 the height of the others.
Does anybody know anything about these ?? Or any real stubby injector
that'll fit GM or Bosch intakes ?? Or with a 90 degree fuel line connector
?? Hope you can help. The local NAPA dealer just went kinda glassy eyed
on me. "Wassa paht numbah ??"
Vamoose has been under construction for 3 years and a bit
now, and number N78LB has been reserved for about 1 1/2 or 2 yrs, just for
me. Today I got a form from the Riverside County, CA. Assessors office,
wanting to know all about my aircraft, that I haven't bothered telling them
about. Bothered ?? I didn't know I was supposed to, Honest Officer.
Mailman brings the damndest things, doesn't he ?? Disgusted Lar.
Ogay. Standing by. Thanks.
Sent: Friday, January 21, 2000 8:30 PM
Subject: Re: Kolb-List: More Lexan
> Good luck
> Dan
>To Gary and List
while
ribs
needed
Dillsburg
any more
if it
any of
airspeeds.
welded up
All up.
>Herb
When I sunk my last Kolb Firestar in a nearby lake, I waited a few months
and bought the following:
Back-half of the dreaded "Ferguson" cage the had only been "tack" welded,
5" wing spars, set of kolb ribs (had to rebuild 2/3s of them because of the
drag strut), about half of the hardware, had my old nose cone and stick,
some of my old hardware was still good, got the rest of it off a wrecked
Firestar II... all for $500. Had to build a "wooded jig" to fabricate the
front half of the cage to fit the back half and "tack welded it (copied the
angles of my old Firestar except a little wider). I can't weld, a least
not good enough for the cage, so paid a Lockheed welder for that - $600.
New 503 dual carb, instruments, fabric, turned own landing gear, BRS chute,
Etc. Etc. ....I still got over $12,000 (I quit counting after that) and a
heck of a lot of time in this thing. Go figure.
<http://www.mindspring.com/~possums/>
Well, Woody, Ya see, uh..............I've kinda already wore some little
holes over some of the rivet heads with my tender handling of the iron.
Uh................ Sheepish Lar.
Sent: Friday, January 21, 2000 8:12 PM
Subject: Kolb-List: chaff
spots.
> Woody
You'll get a lot more holes when you start to sand the Poly Spray/Silver
coat, if you use it.
Here's a hint. Before you sand anything on your plane-tape over all the
stringers, rivet heads, ribs etc. with 1/2 in. masking tape. It only takes
a second to cut thru the fabric when your sanding, no matter how careful
you are..
I use 3M sanding pads and not sand paper. Comes in Medium, Fine and Ultra
fine-and used it wet. Used it on the Silercoat and the paint when applying
another color or coat.
Hey I'll mail you the Teflon Monday-I found it today, I think you'll like
it, as picky as you are.
No body said this would be cheap and it appears you didn't consider how
long it had been since the last price increase. You complain because they
raised the price, yet you had the opportunity to buy it at that price but
didn't then have the gull to complain. Hey it happens. Their suppliers
raise their prices and they have to pass it on to the customers. Hey it's
not like their not honoring their price. Did you approach them for the
old price, if they happen to be slow and hungry, they might have taken it.
They might have met you half way? Kolb had kept quality in their material
and taken care of things when there was a problem. They have a good proven
airplane and are still in business to take care of you after the sale.
Many others are not. You can't keep the doors open if your losing money.
I would rather pay a few bucks more and keep them in business and have down
stream support and parts when I need them.
Happy with my FireFly,
jerryb
>the covering.
> thanks,
> Gary r. voigt
> excelsior, mn.
Prices. Airplanes. That must be in Websters under
example of synonyms.
A few have posted some inexpensive finds for a cage or
rebuilding. I guess the $500 cage somebody mentioned
was in ref to materials only. Right now I'd happily
pay $500 for a replacement cage, or a good repair to
mine. But as in most things, materials are not the
most expensive part!! I've gotten my KXP cage all
stripped down, ready for repair from the blow over
last May. I've planned on taking it to a local A&P
welding guru, but thought I'd first check with TNK --
after all a repair there would presumably be to
original dimensions and done well. I finally called
TNK this week. They don't do repairs. New FS cage is
$2700, and they don't know if the current model FS
cage would fit the KXP wings and fuse tube. I know
I'm whining a little here -- I could ask a few people,
notably Dennis, if the FS I/II cage would work with
the KX wings etc, but I was a little low after finding
out: a) no repairs b) no plans to give me some key KX
cage dimensions, and c) the big price of a cage'. No
doubt about it; we (slightly) older owners took a bit
of a hit in the company change. (Admittedly there are
probably pluses too.)
I'll let you all know how things look after doing more
checking around, but I am serious about the interest
in a cage -- if anybody knows of an inexpensive option
for a KX/KXP cage in good shape, I'm interested.
On a slightly different topic, but tied in by the
keywords 'price' and 'airplanes' :) I must admit I've
been spending a lot of time thinking lustful thoughts
about other aircraft. I've memorized the specs,
performance, and prices of RVs, Kitfoxes (IV, V, now
VI), the Glastar (talk about $$$!), and peeked at a
few others such as Murphy Rebel and Avid. Much of
this is driven by the recent new possibility that I'll
pass that FAA Medical. The airplane pricing only gets
worse. I'm willing to accept that to some level, as I
am hopeful to eventually move into more airplane
(still want slow capability, but also interested in
more on the high end -- over 110 cruise sounds nice).
If I pass the medical, I will probably sell my KXP.
My abilities as a scrounger will have to get much
better if I'm going to be able to find some "deals" to
get my plane rebuilt for a price that doesn't soak all
the fun out of it. Go ahead, cheer me up.
BTW, not that I expect you to still be reading Lar,
but time heals -- I don't recall the covering as being
so bad at all. :) Hey Lar, if you can weld, I can
cover.
-Ben Ransom
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
Wow ! ! ! I could sure see about learning in a hurry ! ! !
Hot Rod Lar.
P.S. 'Course I'm still reading. Still owe you one too. You know what they
say about good intentions. Hang in there, Ben. Like you said a long time
ago - one piece at a time.
Sent: Friday, January 21, 2000 11:29 PM
> cover.
> -Ben Ransom
January 05, 2000 - January 22, 2000
Kolb-Archive.digest.vol-bw
