Kolb-Archive.digest.vol-cn
December 01, 2000 - December 15, 2000
In a message dated 12/1/00 7:00:37 AM Eastern Standard Time,
ronormar(at)apex.net writes:
<< I have heard both pros and cons on the EIS system. I would like
to have some comments on this thing to help me decide. Thanks in advance >>
I have the large screen EIS on my Firestar it's great.! There isn't a lot of
room for instruments on a FS; with all the stuff I wanted the EIS was the
only way to go. I like the big red light which tells you instantly if
anything is above where you want to be. I recomment getting the optional
Altimeter & VSI as well as the Outside Air Temp. sensor. I also hooked up a
capacitive-type fuel gage- it's nice to know how much fuel you have. The
cost is less than all the analog gages. Get it!!
Howard "Shack" Shackleford
FS I
SC
Subject: | Re: VHF Transcievers |
Ken and Gang:
Sorry about the url. It is dead.
http://auction.avweb.com/osauction.stm
Went to the AVWEB home page and could not find hide nor hair
of AVWEB Auction. Undoubtedly, they have discontinued it.
Does anyone else know of another aviation oriented site that
has an online auction?
Subject: | Re: To EIS or not To EIS |
Ron; I wouldn't trade my EIS for a ride in the Shuttle. G Aman FS 2 1274 72hrs
Subject: | Re: Ice flying and EIS |
Jack; Up here in the North I wear that much to bed! You gotta dress UP to go
flying In northeast Ohio in December G. Aman FS2 closed cockpit with ducted
heat from engine cooling discharge vents.
From: | "Beauford Tuton" <beauford(at)tampabay.rr.com> |
Subject: | Re: Kolb List, R.I.P.? |
Ditto from Tampa, Duane...Lar is on-target... keep 'em coming. And be
careful out on the big road... I understand there are semis full of ballots
moving at high speed in all directions...
Have not been active on the list because of work...have been doing some 60
hour weeks... also lots of TDY to lousy places... and a good shot of the flu
this week, also... enough puke-bag excuses, though...
I plan to be on leave next Monday and will go work the Fly a little. I put
a lexan trim tab on the rudder a couple of weeks ago and haven't had a
chance to try it... Made a wild guess about the size needed based on other
ones I have seen on Fireflys...we'll see how it goes.
While I'm on here, I wanted to ask some of you Fly drivers about the pitch
trim changes from use of the droop ailerons... Mine really takes a healthy
nose dump when they come down... even one notch... made me wonder whether
there would be enough elevator authority to flare that little pig for a full
stall landing with my flabby 200 lb butt perched out front... The w&b
numbers look well within tolerance, but it feels a tad strange with those
puppies full down...takes lots more elevator to hold the nose up than I
anticipated. I plan to go out and play in the grass to explore that part of
the envelope a little...starting with a full-droop stall series at
altitude... and then working progressively slower wheel landings until we
get down into full stall arrivals...
Anyone out there have any sage observations on the table manners of this
thing with the ailerons down???
Thankee...
Sneezing Beauford in Brandon FL
FF 076
----- Original Message -----
Sent: Thursday, November 30, 2000 9:42 PM
Subject: Re: Kolb-List: Kolb List, R.I.P.?
> Good luck, Duane. Keep the stories coming, it helps keep us lazy-bonses
> inspired. I miss the posts, too.
> From: <MitchMnD(at)aol.com>
> To:
> Sent: Thursday, November 30, 2000 5:13 PM
> Subject: Kolb-List: Kolb List, R.I.P.?
> > Hey Tophera, gerken, Firehawk, Lindy, Hauck, Beauford etc, etc! Did you
> all
> > give up flying or writing :) > sure
> Thankee...
Beauford and Gang:
I got a little time in the Fire Fly.
I experimented with flaperons a little, but found it to fly
so slow without them that I did not make it a habit of using
them. Most of my Fire Fly time was at Oshkosh or Lakeland,
and everyone knows how the wind howls at both places,
especially during the flyins. I felt more comfortable with
roll control with flaperons up. Elevator control, with our
without flaperons (I weigh 185) was never in question.
I think you have the right idea about feeling out your new
airplane though. Do it at altitude. The earth is much more
forgiving at 3000 feet than at 30. Exagerating a little.
1,000 feet is more than enough altitude to check it out.
Take care,
I am trying to stay legal and clothes do not count because they are
attached to me. They keep me warm as I get the plane out of the hangar,
and I get even warmer pulling the rope to get it started. No primer. But
it is fun to fly in cold weather. My Firefly will climb at 1000 to 1100
fpm at 6400 rpm when it is cold. Jumps off in to ground effect at about 27
mph. It makes it all worth while even if I do have to dress for it.
I like driving thirty miles north to fly sixty miles south to my EAA
chapter meetings and to be the only one to fly in because it is too cold to
fly. I drive down to drop gas off so I can refuel and get back to the
hangar. After I get there and the meeting is over the hangar doors come
open and they get in their enclosed planes and fly.
Jack B. Hart FF004
Jackson MO
Jack & Louise Hart
jbhart(at)ldd.net
Subject: | Re: Beauford's flaperons |
Your plan to check it out at altitude will tell you what you want to know.
Get it up high, run in full flaps, and see what it does. Something I find
interesting, the MKIII with full flaps and full power has enough elevator
authority, but none to spare, especially with a good load in the second
seat. How do the other Kolb birds fare in this situation?
Richard Pike
MKIII N420P (420ldPoops)
>Thankee...
>FF 076
>From: "larrybiglar" <larrybiglar(at)email.msn.com>
>To:
>> To:
>> all
Subject: | Kolb List, R.I.P.? |
Hi Beauford,
I have a little time in a FF too. Got you beat by 20 lb. ... but who keeps
track of such things?
I have not had a problem with what you are concerned about. I agree, feel
it out at altitude. Flaperons do make a slightly steeper approach possible
and shorten up your landing a little.
Dennis
-----Original Message-----
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Beauford Tuton
Sent: Friday, December 01, 2000 9:16 PM
Thankee...
FF 076
> To:
> all
I have never used the flaperons. I raised my horizontal stabilizer 1.5
inches to get it to fly with the stick centered at 55 mph indicated. I
replaced the 15 inch chord ailerons with nine inch chord ailerons to be
able to move the stick sideways at 55 mph. Later I moved the aileron tube
push rod bearings in 13/16 on the "T" which gives 20 degree down max. This
increase in mechanical advantage makes the aileron stick forces only
slightly higher than elevator forces at 55 mph. I am using the small
wheels and so I have trouble getting off soft grass fields. To get more
lift and reduce the tenancy that a short wing has for twitchy ness, I have
installed vortex generators. This lets the Firefly fly off into ground
effect at 27 mph, which is 4 mph less than the power off stall speed. I
make 50 mph indicated approaches, and when the field is made, I reduce the
engine to an idle while maintaining the 50 mph. When I flair I am still
doing 50 mph and you can feel the ground effect loading the ailerons. The
plane decelerates rapidly in the ground effect and you must get it down so
that you do not let it fall through the ground effect. This lets you touch
down at 27-28 mph.
The FBO where I keep my Firefly asked me to always fly the 700 agl pattern
as the ga pilots so they have a chance of seeing me in the pattern. I
always fly inside their pattern but it means I make much steeper descents
to the runway.
Jack B. Hart FF004
Jackson, MO
Jack & Louise Hart
jbhart(at)ldd.net
> fly.
> Jack B. Hart FF004
Jack:
You are a man after my own heart. Your rationale is perfect
for an afternoon flight. I would do the same thing in your
situation.
Before our UL club folded, I always flew to meetings. I
usually had to be the first to depart so I could get back to
my cow pasture before dark.
If I don't have my airplane flying I don'td usually go to
the airport. It only takes me a few minutes to fly the 11
miles to the AP. Driving is 25 miles and mucho traffic.
Subject: | Re: anyone out there? |
Finally self-installed my DSL line and got back on the air. Easy-Hah!
Been flying with the guys this afternoon.
Saw the first two about 1,000 feet AGL flying together.
So I went over and joined them while they were climbing in a thermal for
about 10 minutes-round and round,. Then they decided to go over and join
four more of their friends in another thermal; we glided west about half a
mile and started the whole thing again.
So, spent the afternoon following these six buzzards around, hopping from
one thermal to another. These guys are pro's at finding thermals, I think
from looking at them it has something to do with the little fluffy feathers
on their wings. When they glide cross country, they seem to do it in a
line, I guess so at least one has a chance of picking up the some lift.
No one I knew was flying today (at least they were not on the radio), but
had fun with these
critters anyway - and didn't use much gas :)
I agree with the statements that FFs fly so slow that the flaperons
aren't needed. Think Faa made them do it. And there isn't much elevator
left in full flaps. Worse is a go-around. First notch is abt all I use.
bn FF070
And count me among the very satisfied EIS people.
bn FF070
From: | "larrybiglar" <larrybiglar(at)email.msn.com> |
Yah, be wary of those "table manners," amigo. It just might r'ar up and
bite YOU, if you don't mind your manners. Then who would I have to pick on
?? Sounds like you're going about it the right way, though. Keep it up.
Vamoose' mighty mill should be running by Christmas. Can't wait to hear
what it sounds like. Doors and latches are done. Fiddling with gap seal,
and.................back to covering tomorrow. YeeeeeeHaaaaawwww ! ! !
Can't Wait Lar.
From: "Beauford Tuton" <beauford(at)tampabay.rr.com>
Sent: Friday, December 01, 2000 6:16 PM
ballots
Ken, I've talked to several outfits that do computer graphics - one of them
at Copperstate. My understanding is that they print it to mylar or similar,
and you stick it to your plane. Apparently, quite a few people are doing
their trim colors that way. Expense is fairly high, but workable.
Lar.
Second question "Does any one know of a source for aircraft nose
> art, similar to W.W.II fighters, in a decal that can be applied to
> poly-fiber?"
> Ken
> Firestar Builder
> Tucson
> From: "Ron or Mary Payne" <ronormar(at)apex.net>
> To: "Kolb"
> Sent: Friday, December 01, 2000 5:02 AM
> Subject: Kolb-List: To EIS or not To EIS
> > Getting pretty close to making a decision on the instruments for my
> > FireStar. I have heard both pros and cons on the EIS system. I would
> like
advance
> > Ron Payne
> > Gilbertsville, Ky.
From: | "Richard Swiderski" <swidersk(at)digital.net> |
John, Ken & All,
I too have a King KX-99 & it served me well for many years. The
squealch contol went out this year. Called all ove the US & found that all
repair shops send them to one center. They had a $350 minimum charge & said
they couldn't guarantee that it wouldn't be more! They have been bought out
by Bendix & I would guess that they since they don't produce them any more
they are discouraging the owners from fixing them. Beats me!
I looked around & settled on a JHP-500 for $300.
Some tiny little thing just came out, forgot the name, but it fits in the
palm of your hand & was priced right. The guy didn't like it though because
it didn't have a key board to enter data & it was too difficult to use in
flight. So watch out about programability. ...Richard Swiderski
Sent: Friday, December 01, 2000 7:46 PM
Subject: Re: Kolb-List: VHF Transcievers
> > I'd like to get some input on VHF transceivers,
> Ken Broste
> Ken and Gang:
> I have been using a King KX99 handheld since 1989. Easy to
> use. Compatible with intercom and headsets (real airplane
> types). Can still be serviced at Bendix/King.
> However, I see the new family of hand helds cost aprx $100
> less than what it cost to overhaul my KX99.. Yeasu (sp) and
> Icom seem to be dominating the market now days. I have no
> experience with either.
> Might not hurt to look at some of the online aviation
> equipment auctions like AVWEB Auction. I bought a used GPS
> last Spring there. URL is:
> Have fun. Think I'll take a look at what's being
> auctioned. Haven't checked it out in a while.
> john h
Howard,
O.K., if you want to be technical, it was 90 mph plus a 10 mph tailwind.
But I like telling it better the way I did. And it was 100 mph over the
ice (feeling of speed).
But this year I have two carbs. Maybe I'll make a true 100. Do you think
I will be unsafe?
John Jung
HShack(at)aol.com wrote:
> John, I thought Vne was 90mph on a Firestar.
> Howard Shackleford
> FS I
> SC
From: | "Larry & Karen Cottrel" <lcottrel(at)kfalls.net> |
> From: Richard Swiderski <swidersk(at)digital.net>
> To: kolb-list(at)matronics.com
> Date: Friday, December 01, 2000 7:42 PM
> John, Ken & All,
all
I just sent in my Delcom to be repaired. Seems that a spike in voltage
has done it in. I looked on the Delcom webpage and they repair any and all
problems for 75.00 plus 5.00 for shipping. I am impressed. My stupidity
usually cost much more. Other than the little thumb wheels, which really
are not that bad, I am really impressed with the radio. The little sucker
with a good antenna mounted in the plane puts out 6 watts.
Larry
Larry, I've had an old ICOM A-20 for about 10 years. The nice thing about
it is that they will repair it for a MAX charge of $40 -FOREVER! I don't
know if they still make this offer, or if it was just for radios sold back
then. I've only had trouble with it once, they charged me $40, and I had
the same problem a month or two later and they fixed it free.
That is worth something, right?
Ron
From: Larry & Karen Cottrel <lcottrel(at)kfalls.net>
Sent: Friday, December 01, 2000 8:54 PM
> > John, Ken & All,
> all
> Larry
In a message dated 12/1/00 11:13:31 PM Eastern Standard Time,
jrjung(at)execpc.com writes:
<< But this year I have two carbs. Maybe I'll make a true 100. Do you think
I will be unsafe?
John, I defer to your vast experience. I suspect you'll be OK as long as you
don't do any Hi-G pullups.
Two weeks ago, 3 of us Kolb Firestars [and a Challenger] did a long cross
country. On the return trip the weather started closing in, so we decided
to speed it up a little. I can tell you that, at 80 mph IAS,
I began to think about the stresses on that drag strut.
FS I
SC
From: | "MIKE HOUSEWERT" <mhousewert(at)earthlink.net> |
Subject: | MarkIII Questions? |
I am the proud owner of a used Mark III (88 TT) with a Rotax 582 and am
anxious to fly. I will be flying for practice with very experienced ultra
light pilot/owner, but someone who has not flown the Mark III yet.
Q? What has been your experience as far as speed at lift off with only one
person in the plane?
Q? What approach and landing speed?
Q? How do these numbers change with 2 average people (170 lbs each)?
Q? What have been your take off lengths and landings (1 & 2 people)?
I have made a runway on my own property that is 800' long, but has trees
(40-50') at one end and a hill and houses at the other. I have been told
"No problem" with the Mark III w/ the 582. Any comments.
I live in northern Illinois (Rockford area), and am planning to move to
Marco Island, Florida and take my plane. There is an airport off the
island (4-5 miles) where I know I can fly to/from. Anyone in the area with
an ultra light or is there a club?
I sure am enjoying reading all of you guys mail. I am learning allot,
which I really need to do. Thank you
--- MIKE HOUSEWERT
--- mhousewert(at)earthlink.net
--- EarthLink: It's your Internet.
I am looking for suggestions to secure the rubber molding to the short
windshield on my FireStar. It vibrates loose after a few minutes.
Probably an adhesive of some type?
Lloyd
Fullerton, CA
Subject: | Re: MarkIII Questions? |
Don't worry about the speed at lift off with just one person, it's about
40, but it's so quick that you won't even see it go by! Seriously, however,
there are still some things to know about the MKIII's "quirks."
The nose cone tapers, and that makes it odd to know what straight ahead is
until you get used to it. Suggest that before you or your friend flys it,
have someone stand 100' in front of the airplane, and note where on the
dash or windshield your line of sight lines up. That is "straight ahead."
When landing, plan your touchdown accordingly. A yaw string on the
centerline of the windshield helps a lot also, as you get used to the airplane.
For take offs, the high thrust line can have you on your nose if you are on
the brakes and give it too much power. On takeoff, I go to 1/2 power, aft
stick until it gets up to 10 mph or so, then full throttle. Accelerate,
then stick forward so that you don't waddle off prematurely in ground
effect, and then rotate and climb out at around 45.
I make approaches at 55, fly it right down close to the ground, and hold
it just off until it settles. I use however much or little throttle it
takes to maintain 55 at my desired approach angle.
With two people, I still use the same numbers.
I have a strip that is 750' long, on about a 10 degree hill. Takeoff down
hill, land uphill. Solo takeoffs use about 150', dual about 350'.
If you have obstructions at each end, proceed with caution. The MKIII will
do most anything within reason, but it's not Superman.
For landings, you need to get acquainted with the flaps. The MKIII will
float along in ground effect without them. With them, it slows down like a
Quicksilver trying to glide uphill. With full flaps, you can get an
incredibly steep approach angle that lets you get into little short fields,
but until you get experience, there is a tendency (terror, self
preservation) to start to round out and flare way too high. (note all the
bent MKIII landing gear leg posts in the "Archives" section.) Practice full
flap landings only after you get familiar with the airplane, and not at a
field where you have to have them.
As far as taking off with two people from an 800' strip with
obstructions...do-able, but the wind needs to co operating, cool good air,
etc. There will be days when you should not even consider it.
Enjoy.
Richard Pike
>--- MIKE HOUSEWERT
I would use silicon seal. Put your trim on, then lay masking tape around
the Lexan right up to the edge of the trim. Take the trim off, squirt the
silicone into the groove, stick the trim in place and work it down. Wipe
off any excess silicone, and then pull the tape off, let it cure.
2nd choice: 3M Weatherstrip Cement. Use sparingly, very messy. If you get
any on a place where you don't want it, it will be there forever. Yuck.
Richard Pike
>Lloyd
>Fullerton, CA
Subject: | Buzzing Fishermen at 50 feet |
Buzzing fishermen on lakes:
I hate to be a curmudgeon, but admitting to buzzing fishermen at 50 feet may
not impart an impression of responsible flying to our land-bound brothers.
From: | "Dallas Shepherd" <cen23954(at)centurytel.net> |
Mike:
You didn't say how high those tree's were, but 800 feet on a hot summer
day with two aboard would make it awful skinny if they were very tall.
Becareful!
Dallas Shepherd Norfork, Ar.
1300 foot strip, trees on both ends, Mark 111 with a 582, changed to a
Jabiru 2200.
Mike: I now see the trees would be 40 to 50 feet. Statemate still stands.
I approach at 55 indicated, no less, and am about 45 at touchdown, stops
200, to 300 feet depending on load, but hot summer days really eat into your
climb.
Dallas Shepherd
Norfork
Mark 3, with Jabiru
In a message dated 12/2/00 10:28:57 AM Eastern Standard Time,
lrmcf(at)ix.netcom.com writes:
<< I am looking for suggestions to secure the rubber molding to the short
Probably an adhesive of some type? >>
I used a thin film of "GOOP". It's at most hardware stores or Lowe's or Home
Depot.
Shack
FS I
SC
Subject: | Re: Instruments-Artificial Horizon |
Am interested in acquiring an Artificial Horizon for my Firestar I. Is there
anything available that will fit a 2 1/4" hole & runs on 12VDC & maybe
doesn't cost an arm & a leg? Maybe I can find something at S & F...
Shack
FS I
SC
Ralph and Group,
I'll comment on the saftety of flying up to the Vne:
First, I believe that the 5 rib wing versions of the Firestar have a lower
Vne then the 7 rib versions.
Second, I worry more about stresses when flying in turbulance, than ice
flying. Nothing that I do on the controls gives me G forces like summer
thermals or ground turbulence. And ice flying tends to be really smooth,
like when the wind dies on a high pressure summer evening. If I had
turbulence, say from wind over the trees on shore, I would not approach Vne.
I also do not yank on the stick at Vne speeds. I keep everything smooth.
Actually, I keep things smooth all the time. If my plane gets jerked around,
it is because of the rough air, not because of me.
John Jung
Firestar II N6163J
SE Wisconsin
John and others,
When I fly off the ice I don't even come close to Vne speed. I usually
will fly about 35-50 mph 5 feet AGL. This is absolutely the safest flying
anyone can do because an engine failure simply means an immediate landing
on a nice surface with miles of runway ahead of you. If I were to stall
the plane, the tailwheel would contact the ice and the mains would settle
in. I always tell novice pilots to take their first flight off the ice.
There are no crosswinds (can always land into the wind), no obstacles to
hit, miles of runway, and don't have to confine the landing to a runway.
Best of all, there are no thermals to kick you around and screw up the
landing.
See what you southern guys are missing .... (I say this every year)
Ralph Burlingame
Original FireStar
> Firestar II N6163J
> SE Wisconsin
> Ralph Burlingame
> Original FireStar
Ralph and Gang:
What? Frostbite?
I thought your claim of near 100 mph in a firestar might be slightly
optomistic.recent events have caused my to rethink my position. Lifted off
about 8:30A.M.this morning,about 28 degrees showing, but sunny with light
winds. I leveled off at 1000 ft set up 5200rpm showing about 57mph,and headed
south. After about 5 minutes gawking out the window and not paying much
attention to altitude and such, I saw that I had gained another 500 foot, so
I came back on the throttle and gave it a little forward stick. Well, the
nose came down OK but the revs came up too, so I came off the throttle a
little more, then a little more! All I was getting for my trouble was a lot
of slack cable between the handle and the housing. If you're thinking crab
ice and maybe a little nudge on the throttle might break it loose,DON'T.Tried
that and what it gets you is 6300rpm.If you try to maintain altitude you also
get 96mph.Had to let it climb while I made a 180 and headed back to the
airport.Also noted my cabin heater was working super good. I was actually
starting to sweat. Now I'm back at the field at 3200 ft and planning to shut
it off at mid field and hope for the best. Then I tried shutting off one mag
and then momentarily the other to see how long it would windmill and still
restart. About 2 seconds but it was loaded up enough that it took another 2
till it cleared out and started making some thrust, so now I could descend
and keep it under 90mph although it did sound like a Spad with a sick Le Rohn
(that don "t look right} in it. Investigation on the ground yielded these
facts: No carb ice and no problem from the splitter back. But the cable still
would not move from the handle back to the splitter. Water in the housing
from getting caught in a thunder storm last July, on the ground thankfully. I
took the cable off when I got home and blew it out. Just enough moisture to
see on a paper towel but plenty to overcome all the return springs in the
throttle system.Hey,a clean change of Jockeys and we will try again tomorrow
G. Aman FS2 73hrs
Super glue holds it well on mine.
In a message dated 12/2/00 8:14:38 PM Eastern Standard Time, ul15rhb(at)juno.com
writes:
<< Nope, flew for 2 hours today and not a hint of frostbite. We wear a
thermal head protector that covers the head and face. >>
Ralph, tell me about this "thermal head protector". The only place I get
cold is the space between my scarf [around my neck] and my Comtronics helmet.
Is it something you can wear with glasses? I need to find something that is
open around the nose & mouth so my glasses don't fog from my breath.
Shack
FS I
SC
Subject: | Re: Kolb-List Digest: 44 Msgs - 12/01/00 |
<<<<4130 Chromoly Steel in its normalized state is not very
flexible. On the other hand, when heat treated to 48
Rockwell, the tube becomes a spring and very flexible.>>>>>
what do you do to heat treat the steel to get to 48
rockwell???? and after you have done it how do you know
if you did it corectly?????
boyd
In a message dated 12/2/00 8:37:29 PM Eastern Standard Time,
geoffthis(at)worldnet.att.net writes:
<< Uh Shack I don't think flying in IMC is recommended in a Firestar.....:) >>
Yeah, I know, Jeff, but twice I have inadvertently gotten into fog/low clouds
and it ain't fun; fortunately, I was able to exit within about 40 of the
longest seconds I've ever experienced.
I'm hoping to find an Artificial Horizon at a reasonable price and hope I
never need it.
Shack
FS I
SC
In a message dated 12/1/00 7:48:38 PM Eastern Standard Time,
hawk36(at)mindspring.com writes:
<< http://auction.avweb.com/osauction.stm
John, I tried and failed to use your URL above...was it goofed up somehow?
GeoR38
> boyd
Greetings Boyd and Gang:
After everything is lined up and drilled, the 4130 is loaded
in my old Dodge truck and hauled up to Birmingham, Alabama,
to a professional heat treating facility. CRS the name of
the place now. I'll have to look in my receipt file back in
1993. I tell them what I have and what I want done to it.
When it is ready, I pick up the parts and a certificate.
Once I noticed some small punch marks on the individual
pieces. This is caused by the testing process, I guess
testing for hardness. Most large towns have heat treating
companies to do the job professionally. It is not an
expensive process, but you know it is done right.
Take care,
this sight is not an auction but you can post clasified ads
for free or look over the ads left by others it is
free. ebay is good if you look at ehe aviation
section. or do a search for what you are looking for.
http://wingsonline.com/avionics.html
boyd
> GeoR38
GeoR38 and Gang:
After I hit the send button on the above msg, I tried the
url and came up empty. Reasearched AVWEB and discovered
there is no mor AVWEB Auction. :-(
In a message dated 12/2/00 9:36:11 PM Eastern Standard Time,
ZepRep251(at)aol.com writes:
<< No carb ice and no problem from the splitter back. But the cable still
I
tomorrow
G. Aman FS2 73hrs
Good Story ...GeoR38 Akron, Oh
I have found that sometimes superglue will make Lexan fill itself with tiny
cracks. Locktite will also. Any chemists on the list? Input? Help?
Richard Pike
I agree with Shack. Things close in awfully fast here in Oregon also, and I
also want one, and hope to never have to depend upon it. It is really a
comfort however when needed.
Julian Warren
Eugene, Oregon
Sent: Saturday, December 02, 2000 6:54 PM
Subject: Re: Kolb-List: Instruments-Artificial Horizon
Firestar.....:) >>
clouds
the
> never need it.
> Shack
> FS I
> SC
Why pay for something you could get for free?
Subject: | Re: Kolb-List Digest: 31 Msgs - 12/02/00message of Sat, |
> Hey, Shack...in a pinch a whiskey compass can double up as an artificial
> horizon or "attitude indicator".
> Hillbilly Mike Shackelford
Hi Hillbilly and Gang:
Have you done any training under the hood using the "whiskey
compass method"?
How effective is this method in a trimmed turn? climbing or
descending turn?
In a message dated 12/3/00 12:17:12 AM Eastern Standard Time,
richard(at)BCChapel.org writes:
<< I have found that sometimes superglue will make Lexan fill itself with tiny
Richard Pike >>
Superglue dries very hard and brittle & will crack when flexed.; the "GOOP"
I recommended is a strong adhesive in a tube about the size of toothpaste
that, when cured, is still flexible.
Shack
FS I
SC
Subject: | Re: Instruments [again]. |
In a message dated 12/3/00 11:13:57 AM Eastern Standard Time, jbhart(at)ldd.net
writes:
<< The compass ball will be centered in a coordinated bank. This means you
could be in a bank and not know it and this is the beginning of an ever
tightening bank by which you will over stress the wings, etc.
From the
From the Fly-UL list, Ken Kennedy says a "Turn Needle" will do the same thing
as an "Artificial Horizon" at a fraction of the cost. Not being familiar
with either one, is this true?
Shack
FS I
SC
> Shack
Shack:
Turn and Bank indicator gives information as the name
implies. It lacks pitch attitude. However, you can fly
partial panel with turn and bank and airspeed indicator.
Can do almost as good with ASI and mag compass or gps. At a
constant power setting from level flight, if AS increases,
you are descending, if AS decreases, you are climbing. If
it is not too rough, the mag compass will tell you if you
are turning, of course if you are not climbing or
descending, and that is a class for a later date. :-)
Best bet is to plan ahead, don't push weather, and stay
legal and VFR. However, it doesn't hurt to know what to do
if you screw up and get caught in IFR conditions.
Take care,
Moving to new address and will have new e-mail address. Will sign up again
within a couple of weeks.
Later,
Harry Wingert
In a message dated 12/3/00 12:29:17 PM Eastern Standard Time,
<< Turn and Bank indicator gives information as the name
partial panel with turn and bank and airspeed indicator. >>
John H., I had already figured out determining pitch by ASI, but I still want
to make sure I understand- Turn & Bank indicator=Turn Needle=Artificial
Horizon [more or less]? In other words, the T&B will help me keep my wings
level [in roll]?? And, if so, does anyone make one that will fit in a 2 1/4"
hole?
Shack
FS I
SC
> hole?
> Shack
Shack and Gang:
Turn and Bank tells you degree of bank and rate of turn.
Aircraft Spruce or any aviation vendor has them available in
12/24V and vacumn driven. They are expensive in Acft
Spruce. Recommend checking out some aircraft instrument
overhaul facilities for pricing and availability.
It is not an attitude indicator. Also something to remember
about attempting to fly in IFR conditions, or getting caught
in those conditions: Unless you have had proper training
and are current flying on the gauges (this is in a
instrument certified aircraft), your chances of survival are
extremely slim. Aircraft, especially UL aircraft, further
reduce the survival rate. Not saying you can not do it, but
not recommended. Twenty four years ago I was an Active Army
Rotary Wing Aviator with a Standard Instrument Ticket. I
have not flown instruments since June 1976. I would not
consider tackling any kind of IFR weather in any kind of
aircraft now.
Take care, fly safe,
PS: Check out the accident statistics for Alaska. Most
accidents in Alaska are contributed to weather.
Duane, all Kolbers, et al..
Haven't had any new Kolb related news to share until this week but always
find your reports of great interest.
The Firefly is still at LiteSpeed while I fit out the trailer for travel.
I've decided to hang the wings near the side walls on long journeys and have
been busy fabricating the bracketry this week. Went to DC for Thanksgiving
with daughter so that week was lost for all Firefly activity.
The weather was bad on Wednesday and Thursday morning was also rotten, but lo
and behold, the sun came out around 2:30pm and I was able to get another 30
minutes in with one touch and go and two full stops before another big black
cloud blew in and made it too cold to continue. OK, Ice Flyers, I know
that you don't think it's ever too cold to fly but I just don't have your
equipment and really don't have an interest in acquiring any yet
The good news is that the engine is breaking in and I was able to climb to
1500 ft on the last flight. You know, I always thought that takeoffs were a
piece of cake and landings were the only part of flying that had a
significant pucker factor. Well, I've quickly discovered that the Firefly is
also capable of giving one a pucker or two on takeoff. I obviously need some
more takeoffs in order to not make each one an adventure. Since I took my
transition training in the Kolbra trainer which has no flaps, I never seem to
remember to use flaps on landing and quite frankly, haven't missed them.
Plan on returning to finish the trailer installation next Saturday and hope
the sun is out for more takeoff experiences.... Also would like to do my
first stalls.
Gene Ledbetter
Cincinnati, OH
Firefly 00-2-00018, both canopies, big wheels and brakes, Ivo 2 blade
Someone yesterday was asking about a good portable radio to use. Our
little group here in NW Missouri are getting the little "personal
radios" that Motorola, Bell South and others are making for group flying
and just around the patch. They have 14 channels, you don't need a
license and most have headphone/external mic jacks. Radio shack has a
neat earphone (like a hearing aid) mic combination that clips on your
collar or where ever. They advertise a two mile range for the radio but
in the air, you get out farther than that. Everyone works off the same
channel and keeps in touch. Wal Mart has the Bell South ones on sale
now for $19.95 and the Radio Shack mic/earphone is $19.95 also. Someone
in the pack always has a avaition portable and keeps the rest informed.
Request a CDROM 1-800-333-3633
OK, I know no one (or only a few) want to hear abt early flying, but
this AH vs compass et al can stand a few words. Certainly, an artificial
horizon would be great, especially in IMC---but there was a time, in the
distant past where few planes had an AH. They were lucky if they had a
so-called *ball bank*, a small upwardly-curved liquid-filled tube with a
teeny ball inside.Then came the so-called *needle*, an upright bar
positioned by a vacuum-driven gyro. So keeping the ball centered, needle
up, and constant airspeed--you are flying straight and level IFR. Called
*needle, ball and airspeed.* With ball still centered, bar leaning one
or two widths, constant airspeed= a nicely coordinated turn---still IFR.
Few modern pilots have either never done N,B,AS, or could in an
emergency. It's kinda demanding, but after some time in IFR, you'll get
a real feeling of accomplishment.
done lecturing
bn
Subject: | Re:FireFly Flaperons, Reflex Angle |
Beauford et al. My FireFly flaperons are reflexed up ~ 3 degrees (measured
through aileron and wing bow centerlines) to keep the nose up and level at ~
60 MPH. I also have an elevator trim tab which measures about 2 x 6" and is
angled down about 15 Deg. It took both of these adjustments to relieve the
back pressure I had to exert on the stick. No other performance
characteristics were effected. I only weigh 150+ LB so I could not figure out
what was making her so nose heavy but this solution seems to have resolved
the problem.
Yes, I do use full flaps on the last part of final, especially when I am
doing engine out (actually idled) practices. The flaperons will reduce your
stall speed and ground roll but bear in mind that this reduction is at the
expense of increased drag and glide angle. When mother earth is coming at you
the tendency is to flair early and drop below that lower stall speed before
you know it. I learned with the engine idling and my hand on the throttle in
case I needed to add some last minute air speed. I plan to maintain this
skill hoping to never use it.
> the problem.
Duane the Plane and Gang:
You are probably suffering more from high thrust line,
rather than be nose heavy or forward CG.
Try this experiment next time you are up in altitude, 1,000
feet or so. In straight and level flight, come back on the
throttle to idle speed. Keep the airplane flying 5 to 10
mph above stall speed. When you have completed this
exercise, come back and tell us what happened. If it has
characteristics similar to the Firestar and MK III, when
power is pulled and airspeed reduced, the nose down tendancy
and requirement to hold aft stick pressure will disappear.
My MK III goes neutral when slowed down to about 5 mph over
stall. Pour the power to her and the nose up trim has to be
cranked back in to relieve the aft pressure on the stick.
Take care,
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
aircraft now.
There are pilots on this list FAR more experienced than I but on this
question of inexperience in IMC conditions I can throw in my $.02 cents
worth. I have a friend that wanted to go to Muscle Shoals, Al. a few weeks
ago and asked me to fly him , (from Columbus, Ga.) Having my 4 month old
private pilot license and looking for a good excuse to go flying I thought
"Great!" Anyhow , I checked with the local FSS and got a good weather
briefing , worked up a flight plan , filed a flight plan and away we went in
a C-172. Well the conditions were kind of interesting. Not a cloud in the
sky , just a "little haze", visibility about 6-7 miles. Well about 30
minutes out viz was more like 3 in my opinion and a quick call to "Flight
watch" confirmed my suspicions...some enroute airports had visibility around
2 or less but destination was clear and 10 miles vis so thought maybe we can
go above it. (The high pressure system we were under and the 3-4 weeks of no
rain meant large amounts of dust and who knows what else choking up the view
and just "sitting" over us with no wind to move it on out.) "Flight watch"
said top of haze at 8000 , so check everything and up we go. Well from
2500-4500 things were about the same , but about 6000 I look down and there
is no ground reference anymore (hadn't had a horizon since takeoff due to no
horizontal visibility) Well the old standard rate 180 turn to get out of
IMC wouldn't help obviously so I got my head in the cockpit and ignored the
white outside. Pull the carb heat , and power back and put the nose down
and set up a nice slow and LEVEL descent. Took a glance outside at about
3000 to see if there was any green below and low and behold there was. Told
my buddy that he was gonna have to drive to Muscle Shoals and made a bee
line back to CSG. All that to say this , yes a couple of gauges can help
you but I'd had hood training recently (private pilot training) and was kind
of "fresh" at it. But have had it demonstrated to me that even with all the
IFR bells and whistles that I was staring at, my inner ear was telling me I
was banking and it took TOTAL CONCENTRATION to ignore it and JUST FLY THE
GAUGES. There should be NO FALSE sense on security because you have some
little needle in your dash that you have any better chance of surviving then
the next guy. I think the number one emphasis needs to be to NOT GET INTO
IMC. In my case the first mistake of the day was getting in the plane.
With my experience level (and no hardcore IFR training , just rudimentary
stuff to pass the hood requirements for private ticket) I had no business
out there with no chance of seeing a horizon for an entire 2+ hour flight
and especially with another fellow in the plane with me. I did see the
error of my ways and make a (late , but still needed) NO-GO decision.
Jeremy "a little wiser now" Casey
P.S. After all this typing it certainly feels like more than $.02 worth...
I have one more comment to say about this instrument. I am going to spend
over $2000 on a Chute for my Xtra. I am going to fly safe, and slow, but if
I ever need it........ same thing!
Julian Warren,
Eugene,Oregon
Sent: Sunday, December 03, 2000 10:41 AM
Subject: Re: Kolb-List: Re: Instruments [again].
want
wings
1/4"
> hole?
> Shack
> FS I
> SC
Subject: | Hello from Oregon! |
Hi Mika,
I thought it was about time to send you an update. I am married, as you
know, to Dayna now and living in Ashland. It is an interesting town not far
from Medford and only about two hours driving time west of Bonanza. Dayna is
in her last year of University to become a music teacher. She is student
teaching this year and the kids love her almost as much as I do.
I am working as a mechanic in White City near Medford. I work for Kodak, the
company that makes all of the film. We make medical imaging film at this
plant. Our biggest product is called Dry-View, a digital X-ray film that is
developed in a dry process machine almost like a copy machine. I took the
job so that I could be in Ashland with Dayna. I decided that since we were
married we should probably live together :-). I am learning a few new skills
and the pay is much better than farming although you can't have a beer while
working. I finally finished my little airplane last year and have been
having a blast flying it around. There is nothing like flying to make you
feel absolutely free. All of life's problems seem so much smaller from 2000
meters above the earth! And at 100 meters you can even smell people's
barbecues when you fly over.
Dad is just getting back from Portland. He has been having some problems
with his heart. He has some blocked arteries and such. He is doing much
better, thank God , since his last surgery.
Danny has bought a business in Klamath Falls. He sprays lawns and gardens
for people and businesses. So far it is doing well, but it keeps him very
business in the summer. In the winter he works at home on the farm. His
girls Hannah(8), Kirsten(6) and Kaylie(3) are growing fast and a lot of fun.
Vera is teaching them gradeschool at home and working part time as a nurse at
the hospital in Klamath Falls.
Linden is still fixing sprinkler pipes in the summer and working in his shop
in the winter. His sons Clinton and Miles are 15 and 13 now. Both of them
are taller than me already (life is not fair!). Helen does all of the book
work for the business and helps Mom with her book work also.
All in all, God has been good to us. How is life going for you? I hope all
is well and you and your wife have a great Christmas season.
Roger and Dayna Hankins
1361 Quincy 3-C
Ashland, OR 97520
USA
RPHanks(at)aol.com
>not recommended.
>worth.
I think this applies here as posted by
Ralph Burlingame 7/21/99? from the list-good read even the 2nd time.
178 Seconds to Live
How long can a pilot who has little or no instrument training expect to
live after he flies into bad weather and loses visual contact?
Researchers at the University of Illinois did some tests and came up
with some very interesting data. Twenty student "guinea pigs" flew into
simulated instrument weather, and all went into graveyard spirals or
roller coasters [attribute to the U of I flight training program??]. The
outcome differed in only one respect - the time required till control
was
lost. The interval ranged from 480 seconds to 20 seconds. The average
time was 178 seconds -- two seconds short of three minutes.
Here's the fatal scenario. . . . . . .
The sky is overcast and the visibility is poor. That reported five mile
visibility looks more like two, and you can't judge the height of the
overcast. Your altimeter tells you that you are at 1500 feet but your
map tells you that there's local terrain as high as 1200 feet. There might
be a
tower nearby because you're not sure how far off course you are. But
you've flown into worse weather than this, so press on.
You find yourself unconsciously easing back just a bit on the
controls to clear those towers. With no warning, you're in the soup.
You peer so hard into the milky white mist that your eyes hurt. You
fight the feeling in your stomach. You try to swallow, only to find your mouth
dry. Now you realize you should have waited for better weather. The
appointment was important, but not all that important.
Somewhere a voice is saying, "You've had it -- it's all over!"
You now have 178 seconds to live.
Your aircraft feels on even keel but your compass turns slowly. You
push a little rudder and add a little pressure on the controls to stop
the turn but this feels unnatural and you return the controls to their
original position. This feels better but now your compass is turning a
little faster and your airspeed is increasing slightly.
You scan your instruments for help but what you see looks somewhat
unfamiliar. You're sure that this is just a bad spot. You'll break out
in a few minutes.
(But you don't have a few minutes left. . .)
You now have 100 seconds to live.
You glance at your altimeter and you are shocked to see it unwinding.
You're already down to 1200 feet. Instinctively, you pull back on the
controls but the altimeter still unwinds. The engine is into the red and
the airspeed, nearly so. You have 45 seconds to live.
Now you're sweating and shaking. There must be something wrong with the
controls; pulling back only moves the airspeed indicator further into
the red. You can hear the wind tearing at the aircraft. You are about to
meet your Maker; you have 10 seconds to live. Suddenly you see the
ground. The trees rush up at you. You can see the horizon if you turn
your head far enough but it's at a weird angle --
you're almost inverted. You open your mouth to scream but. . . . . ..
you just ran out of seconds.
Think about it before you press on into marginal weather
Lucian Bartosik>
> Julian Warren,
Julian and Gang:
Howdy!
I assume you are talking about turn and bank, and attitude
indicators or artificial horizons.
OK. Let me say a couple things and then I will shut up.
:-) I think.
If you want to compare an attitude indicator or turn and
bank with a ballistic recovery parachute, that is ok.
The only training requirement to operate the ballistic
recovery system is to train one's mind to actuate it when
the time comes, to train ones hand or hands to know where
the deployment handle is by actually locating it with your
eyes closed, and to be able to pull the handle when
required. Forgot one of the most important steps in your
check list, first pull the safety pin and flag. And
another, don't forget you have a ballistic recovery system
on board. Be surprised how many fatalities there are with
recovery systems never activated. Have to be able to do it
instinctively.
To fly in actual weather conditions successfully, one must
have extensive instrument training in a instrument certified
aircraft. Once the pilot gets that training, he must stay
current. I know from personal experience I can not fly
instruments, especially solo unless I stay current, or have
a current instrument rated copilot. That was 24 years ago.
Now? I doubt if I could do it again. Don't want to
anyhow.
I personally do not have an attitude indicator or turn and
bank. I feel having those instruments installed may give me
a false sense of capability and prejudice my decisions to
fly or not in less than VFR weather. However, no matter how
you get yourself into actual weather, if you have the
attitude indicator on board, it is operational, and you are
proficient in flying weather with it, you will have a better
chance for survival. If you can not fly actual instruments,
you will not last long.
If for some reason you doubt what I say, go get some hood
time in a MK III with an attitude indicator or a turn and
bank indicator. That's not full panel. That is partial
panel. Try it in a 152 or 172 with full panel. Then try a
little inadvertent IFR. If that doesn't get your attention,
nothing will.
Just my humble opinion.
PS: I guess what I am saying is, just because one thinks he
can do it, does not necessarily make it so!!!
From: | "Ken Broste" <spiritmoves(at)earthlink.net> |
There was a statistic that was brought repeatedly to my attention as I was
working on my private pilot's license. "85% of VFR entries into IMC result
in fatalities." You're asking for an early, a very early death, my
friends.
Sent: Sunday, December 03, 2000 12:07 PM
1/4"
> > hole?
> > Shack
> Shack and Gang:
> aircraft now.
> john h
A turn and bank indicator only gives you rate of turn. It will not tell you
if you are in a 10 degree bank or a 45 degree bank. How many of you if
caught in IMC by some stupid, idiotic action know how many seconds at a
standard rate of turn will put you on a heading 180 degrees from your former
heading? Imagine try flying around inside of a milk jug and all you see
around you is white. Some of you people really scare me.
Sent: Sunday, December 03, 2000 10:27 AM
thing
familiar
> > Shack
> Shack:
> Take care,
> john h
Excellent post, Possum. The best we've had on here for months.
Sent: Sunday, December 03, 2000 10:02 PM
Subject: RE: Kolb-List: Re: Instruments [again].
> >not recommended.
> >worth.
> 178 Seconds to Live
> was
> be a
mouth
> in a few minutes.
> Lucian Bartosik>
From: | "Gary r. voigt" <johndeereantique(at)uswest.net> |
Subject: | trailer condensation |
I orderd a new 24' haulmark enclosed trailer this past
summer for my fs1, ( I feel like I'am in heaven) the plane
spent most of the time in the garage while I was near
completion of the project and sometimes in the trailer when
I did not want my poor pickup to get wet when it rained.
Here in minnesota it has started to get cold, the firestar
has been in the trailer for about 1 month of fairly cold
weather and when I opened the trailer for the first time in
over a month the engine was covered in ice crystals and the
outside of the gas was also iced-up. my guess is there is no
circulation in the trailer, I have no vents or windows in
this trailer and it's exterior is aluminum with some wood
trim on the inside. I have several questions.
#1 will this cause premature rusting on the 447 and
internal parts of the engine.
#2 Do you think I'am also getting moisture in the tank
because of the outside of the tank is in ice crystals.
#3 I would like to hear your comments on what you think
I should do to prevent this from happening. should I vent
the ceiling or maybe put a lightbulb or heat lamp over the
engine. I don't like that idea myself. so if you have any
suggestions please let me know, I don't care if you live in
hawk holler alabama or or the north pole, your opinion or
vote counts, or does it, hehehe.
thanks,
Gary r. voigt
firestar kxp 0 hrs-----still waiting for a couple more
inches for my 3 mile runway and may use every foot of it.
Subject: | Re: trailer condensation |
Gary,
I am with you, I think ventilation is a significant issue. I have a
hinged door in my floor with the hole screened in, and I mounted my 2
windows as close to the ceiling as possible. When I park the trailer, I
crack the windows & open the trap door. Extreme heat is avoided & the
temperature stays normalized when cold & condensation is kept to a minimum.
...Richard
From: "Gary r. voigt" <johndeereantique(at)uswest.net>
Sent: Sunday, December 03, 2000 10:04 PM
Subject: Kolb-List: trailer condensation
> thanks,
> Gary r. voigt
Gary,
I am in the process of getting my steel trailer foamed. I used painted
roof steel (24 guage I believe) for the covering on my trailer. It really
did not sweat, even though it did not have any ventilation at all. A friend
made his trailer out of aluminum and his just pours the water off it. Even
though mine does not sweat, the foam will improve it both winter and
summer. They tell me that 1/2 of foam will stop the sweats. Supposed to be
done tomorrow. Will let you know what it cost. And yes the water will raise
hell with everything.
Larry
You said it, John. Absolutely ! ! ! I had about 2 hrs total hard IFR time,
about 5 yrs ago, with 2 different instructors, in Washington state. After
the 1st few seconds.............total disorientation. The biggest & most
amazing thing I found was............"But I just looked at that thing, how'd
it get so far off so fast".............without feeling anything, and
bringing it back took a mighty correction. Don't fool with it ! ! ! I flew
into what I thought was a strip of haze near Sequim, Wa., in the same time
period, and it turned out to be a fog bank. After about 10 sec. or so, ( in
an IFR equipped C-172 ) I started a standard rate turn to make a 180 back
out. Watching VERY carefully, it probably took less than 2 minutes to come
around and back to clear air. Seemed like forever, and I was wound up
tighter than a $2.00 watch, cause I KNEW what trouble I was in. If you
want a real education, go to a flight school, and buy an hour on the
simulator with an instructor. You'll get respect in a hurry.
Wiser Lar. Palm Springs, CA.
Sent: Sunday, December 03, 2000 11:07 AM
1/4"
> > hole?
> > Shack
> Shack and Gang:
> aircraft now.
> john h
> From: Ken Broste <spiritmoves(at)earthlink.net>
> Date: Sunday, December 03, 2000 6:26 PM
. " Some of you people really scare me."
Perhaps somewhere I misread the original question, or failing that I am
attritibuting the author of the original question with at least as much
"intelligence" as I believe that I myself have. I assumed that the author
wanted the particular instrument as a hedge, not so that he could practice
IFR flying in his firestar. It seems to me to be like saying "because some
one wants a ballistic chute he is going to practice arobatics".
Words are either tools where we learn, or weapons where we intentionally
hurt!
Larry "can't we all just get along" Cottrell
I think you're right, Larry. My feeling for the comments on this was of a
concern from everyone who reponded, to try and help someone from making a
potentially terrible mistake. Sure made a good thread, didn't it ??
Lar.
From: "Larry & Karen Cottrel" <lcottrel(at)kfalls.net>
Sent: Sunday, December 03, 2000 7:56 PM
> hurt!
In four words...."You won't be sorry." I'd like to know what
negatives you've heard? I really like my unit, saves space, is
accurate, never failed, easy to read, etc.......
J.Baker
In a message dated 12/3/00 10:54:24 PM Eastern Standard Time,
lcottrel(at)kfalls.net writes:
<< " Some of you people really scare me."
hurt!
Larry "can't we all just get along" Cottrell >>
I believe I was the original author, & no, I don't "intend" to fly in IFR
conditions. I do intend to get some tools to help me if I do in-advertently
get into those conditions again.
Yeah, I have read the "178 second " thing several times. I have seen a 30
minute video on the subject. I studied the long thread about the Kennedy
accident. we've hanger talked for hours about the subject. I've been told
that a big gold chain, held between the thumb & forefinger will do the job.
Also, a cup of coffee. A "slip indicator". A boat compass.......By way of a
small knowledge of physics, I recognize instantly that some of these may not
work!!
I intend to find an instrument that, with some training, just might save my
bacon if I somehow get into a fog bank. I'm trying to find out from the list
what that instument should be, will it fit my panel, & where do I find one I
can afford?.
FS I
SC
In a message dated 12/3/00 11:10:20 PM Eastern Standard Time,
jlbaker(at)telepath.com writes:
<< > I have heard both pros and cons on the EIS system. I would like
The biggest "con" I have ever heard against the EIS is that if it fails
you've lost most of your instruments [I would still have my ASI & Compass].
I can fly my plane safely without any instruments- can't everyone?
Shack
FS I
SC
Subject: | Needle, Ball, & A.S. |
I have been watching the thread on flying into inadvertent IFR with interest.
I am removing the fuel pressure gauge from my MKIII, and have been
thinking of getting a needle & ball to fill the hole.
The reason for doing this is because on my trip back from New Kolb
this last September, I was at 7500' over a solid deck that was pretty thick.
Droning along that way for 100 miles gave me lots of time to ponder how
well I could maintain a heading and keep the wings level with just the
GPS and the whisky compass if the 532 laid down and died on me.
Or to put it another way, how long could I fool around with the airplane until
I had to go ahead and fire the chute...
I think I am in the market for a 2 1/4" needle and ball. It would at least
give
me something to do while gliding quietly down through the murk...waiting
to pull the little red handle...
Richard Pike
Larry..again I like your comments! I am IFR rated but have only flown under
the hood for years. I don't trust my aircraft with no radar, and it always
bothers me that other planes may be in the area. I do like to be rated for
letting down through the clouds though when coming in from Bend to Eugene
over the mountains. No problems and many holes in my worst trip, but I was
checking instruments. I second everyone comments on not attempting to fly
IFR until and unless you are licensed. White knuckles and cold sweats never
were a thrill to me.
Julian Warren
Eugene, Oregon
Sent: Sunday, December 03, 2000 7:47 PM
time,
how'd
flew
in
come
you
> From: "John Hauck" <hawk36(at)mindspring.com>
> To:
> 1/4"
> > > hole?
> > > Shack
> > Shack and Gang:
> > aircraft now.
> > john h
That was my original interpretation also guys.... good comment!
Julian Warren,
Eugene, Oregon
> hurt!
From: | dixieshack(at)webtv.net (orie shackelford) |
Subject: | Re: whiskey compass use. |
Before we get too involved with the whiskey compass and its uses I
probably should make my initial comment a little clearer. In the event
of unexpected IMC whether smoke fog over water cloud or whatever, the
whiskey compass can aid you in staying wngs level and pitch level by
observing the ball in the kerosene. Even in an "ever tightening"
co-ordinated turn the ball will be turning. Wings level would be shown
by the attitude of the ball in the window as would pitch. I did not
intend to suggest that anyone use the liquid compass intentionally as a
substitute only as an emergency substitute. I was caught in some
early morning fog that was raising from a wooded area in central Florida
and could see that it was localized. I was flying a 7AC at the time
with the door off. Upon entering the fog I first found it to be
heavier than expected. I then lost all sense of time, altitude,
attitude and which way was up. My father-in-law had mentioned the
liquid compass thing years earlier and I thought of that although I had
a T&B idicator. I watched that little "level" suspended in front of me
and it served its purpose in two ways. Gave me a focus for my fright
and by keeping the ball on a constant heading and in the same unmoving
position in the housing kept me from getting into anything near an
unusual attitude. My first and only with spatial disorientation. I
don't think the FS and I will be getting into that stuff. I'm tooo
Chicken.
Hillbilly Mike
Ralph has hot blood--he will be sweating when the others will still be
cold. I flew twicw already off skis and twice off wheels because the snow
was inconsistent. I wear long underwear, 2 socks, insulated boots, under
shirt, long sleeve shirt, sweat shirt, insulated jacket, snowmobile suit,
head / warmer, helmet liner, snowmobile helmet, cotton gloves, snowmobile
mittens adn I do get cold so you fly for 30-60 minutes and then take a
break. I get cold but never to the point of frostbite. I get stir
crazy if I don't fly periodically.
This Saturday it was 11 degrees at 8 AM but it was clear and light wind 2-4
mph from the south. The was no road spray so my Firestar did not get
dirty on the 13 mile trip to the airfield. I usually get fully dressed
before set up because it helps me get good and warm first. The little
pins and hardware is harder to work in the cold air but it warmed up to
about 28 degrees by noon when I flew. One must also be careful setting
up in snow--a dropped pin can be lost quickly so I carry spares. John
Glynn in a GT400 took off just as I was rolling up and by the time he
returned I was ready for engine start. We agreed to make a circuit
between Benson Airport John Peltons (Our Minnesota Ultralight Assc
President) Place and Northern Lights Airpark.
After a long warm up and normal taxi and take off we headed North. I had
to slow up to 4600-4800, 55 mph to stay even with the GT400 (503 engine),
we saw two other ultralights flying near the frozen lakes on the way. We
landed at Benson, a 1200 foot grass runway, about 25 minutes later. John
said he was cruising at 5100 rpm and 55 mph. We saw 2 vintage Cessnas
come in for landings and talked to 2 glider pilots on the ground.
We then took off for John Peltons--John later said he was going to push his
throttle a little higher--6100 rpm to get more than 65 mph. 65 mph means
5200 rpm in my plane so we were cruising nicely. On the trip a Beech
Twin came within 100 feet above John--they are fast and a Cessna 152 came
from behind along side me and then peeled off (show off).
John could not land--I learned later his throttle cable was frozen at 6100
rpm. The colder higher altitude (1200 agl) and the higer speed cause his
cable to freeze with water turning to ice. John lead us back to home base
at a good clip but we were going into the sun so there was a bit more
warmth. I saw John continue to fly around the area while I set up for
landing--John continued to fly around close to the ground. Later I
learned he was still trying to get the throttle back when suddenly, in the
warmer layer of air, the engine went to idle. He was at about 200 feet
agl but kept control and after making sure it was working right came in for
his landing. The trip was 1.2 hours and I used 2.5 gallons of fuel--John
used almost 5 gallons.
As I was taxing back to my trailer I went trough some deep snow on a little
incline and tipped it on its nose. I had to get out push the plane through
the snow and thenget back in to taxi back.
The air was a little bumpy and there was alot of air traffic but it was
clear and the snow on the ground was pretty and the plane flew great. I
love this plane--lots of performance and good clean fun.
Dale Seitzer
Sent: Saturday, December 02, 2000 11:58 AM
Subject: Re: Kolb-List: Ice flying
Hey Ralph,
Sounds like fun but my blood is much too thin for that kind of flying, hell
when it gets below 40 degrees I put on my thermal undies.....
Geoff Thistlethwaite
I use a think called Baclava , $ 14.99, it is a thinner stretchy fabric
over the top of the head and much thicke insulated fabricfrom nose level in
front around the head--it may be too thick to wear under a head set -- it
is designed to wear under full face helemts. The fabric extends down the
front sides and back like the old dickys. Dale Seitzer
helmet.
is
Shack
FS I
SC
From: | David Leister <dleister(at)graftononline.net> |
Subject: | ALNOT for slingshot |
Hi. Group:
I work for the FAA at Cleveland Center. An ALNOT came out to all
sectors on the lookout for a N97MS
Slingshot experimental. I'll type it out just the way is came across the
printer.
W1 ALNOT N97MS TYPE SLINGSHOT EXPERIMENTAL DEPARTED WV29 AT 03 1900Z
ROUTE AND DESTINATION UNKNOWN. ANY INFORMATION CONTACT ZOB AMIC AT
440 774- 0426 ZOB CP/040119.
Usually we see a message a little later stating they found the aircraft at some
airport. But this time I never heard or
seen a message saying that it was found.
Does anybody know about this aircraft. Just curious.
David Liester
Mark III 912
Wellington, OH
Richard, What instrument are you referring to?
Mike H.
Subject: | Disappearing Ultralightes |
I think all the instruments and gadgets put on these light planes to
make them safer will definitely do just that: they will be so heavy they
won't be able to leave the ground.
Light planes are not meant to be flown in marginal weather. Too many of
us are letting them slowly evolve into G.A. planes. Light=Safety
Listen to John Hauck, he didn't make it this far not knowing what he is
talking about.
Bill Vincent
Firestar II
Quinnesec, Upper Peninsula Michigan
From: | GEORGE ALEXANDER <gtalexander(at)att.net> |
> Shack
> FS I
> SC
Shack:
I have had very good luck with stuff from Wear Guard (
http://www.wearguard.com ).
As for the head covering I got what they call a "Micro
Fleece Hood - Style 1972". Currently going for about $13.
I wear it under a regular headset and a Comtronics helmet. I
wear glasses and the oversized skydiver goggles.
(Inexpensive, light, flexible and vents on the side to
minimize fogging up.)
The features I like about this hood are that it is fairly
thin, but effective at keeping the wind off and the face
opening is elastic enough that when really cold, I pull it
up over the nose (no small task) and under the goggles. The
material and weave wick the moisture to the outside. It is
long enough to tuck the tail in my turtle neck. If not
quite so cold that I don't mind a little wind in the face, I
can drop the opening down below my chin or anyplace in
between that I need. I have used others from camping
stores, outdoor stores, etc... but picked this one up when I
ordered other cold weather gear and have been satisfied with
all of it.
Good Luck!
George Alexander
http://gtalexander.home.att.net
From: | "William Herren" <wmdherren(at)hotmail.com> |
Subject: | Re: ALNOT for slingshot |
Database shows the aircraft as built by Michael S Miller
Rt 2 Box 397f
Albright WV 26519
Any Lister Know of this plane/pilot?
>Subject: Kolb-List: ALNOT for slingshot
>Date: Mon, 04 Dec 2000 12:07:18 -0500
>Hi. Group:
>printer.
>1900Z
>David Liester
>Mark III 912
>Wellington, OH
Hi Kolbers,
I tried the skis on my FSII sunday and what a trip! I never considered myself
a cold weather person but this could change me for good. We took off in
around 5 inches off snow,went about 20 miles and landed at Grob field (wisc)
what a breathtaking sight! The whole airfield was pure white with only deer
tracks across it.OAT on the ground was 30 and at altitude 26 (compliments of
my EIS OAT option love that EIS) I used aftermarket snowmobile racing
skis,plastic,light and strong. As much as I would love to be flying over the
mountains and desert with Will U. and Dave Rains (great pics) the snow flying
is really something to behold.As soon as the lakes freeze up i hope to do
some lake skimmimg like Ralph B. and John Jung. I would strongly urge
everyone on this list to install some skis immediately,find some snow and
play in the snow!
Enjoy,
John Bruzan FSII EIS BRS 503 SCDI Chicago flying out of Aeropark,wisc
I guess I should have said "Turn and Bank."
The old mantra of "Needle, Ball, and Airspeed" was the thing
we were taught for partial panel in IMC. If you have an old
fashioned turn and bank indicator (needle and ball), and an
airspeed indicator, you can maintain straight and level flight
in IMC. Or a controlled descent, wings level, straight ahead.
Years ago, the old style turn and bank indicators were driven by
a venturi hung on the side of the airplane. Needed no electric system.
Worked when nothing else did. I still want one.
Richard Pike
MKIII N420P (420ldPoops)
>Mike H.
Subject: | Re: Needle, Ball, & A.S. |
Your money would be better spent getting some training flying under the
hood.
----- Original Message -----
Sent: Sunday, December 03, 2000 9:57 PM
Subject: Kolb-List: Needle, Ball, & A.S.
interest.
thick.
until
> give
> Richard Pike
Subject: | Re: To EIS or not To EIS |
I cannot understand why so many pilots are gung ho on the EIS displays. If
this one system goes down you have lost all your engine and flight
instrumentation. Why put all your eggs in one basket? Am I missing
something?
Sent: Sunday, December 03, 2000 9:24 PM
Subject: Re: Kolb-List: To EIS or not To EIS
> > to have some comments on this thing to help me decide. Thanks in
advance
Compass].
> Shack
> FS I
> SC
I will go to great lengths to avoid even the possibility of coming close to
IMC even to the point of landing in a field and waiting it out. If you want
to prepare yourself for this possibility and blaze your way through the
milk, please get some training under the hood from an instructor. It will
be money well spent. It is not as easy as it sounds.
Sent: Sunday, December 03, 2000 9:17 PM
practice
some
> hurt!
in-advertently
told
job.
of a
not
> work!!
my
list
I
> can afford?.
> Howard "Shack" Shackleford
> FS I
> SC
Well then, come on, John...............how 'bout some pics of your ice and
snow ( brrrr ) flying ?? You're not gonna let Will & Dave have all the fun
are ya ?? I dunno - sounds neat & fun alright, but I paid my dues
snowcatting in Northern Idaho 20 yrs. ago. Fun, you bet, but migawd we got
cold. With lotsa beer, a snort or 3 of Old Loudmouth, a burning tire to
home in on, and a midnight party out in the 20 below night, we survived, but
I......don't......think.......that
all.......would.......be.......the........best........idea.........here.....
....! ! ! Sober ( now ) Lar.
Sent: Monday, December 04, 2000 6:36 PM
> Hi Kolbers,
myself
(wisc)
deer
of
the
flying
> play in the snow!
> Enjoy,
A/C Spruce shows a 2 1/4" turn & bank - for $639.00 - but no small AI.
Tried just now to access www.falcongauge.com , but was told I'm not
authorized to go there. Hmmmm............wonder why they advertise it in
KitPlanes, then ?? Good Luck. Big Lar.
Sent: Monday, December 04, 2000 6:43 PM
Subject: RE: Kolb-List: Needle, Ball, & A.S.
EIS is a dandy toy, and does it all, quite well. Kris Henkel, in 1000 Palms
has finished his Tornado, and has an EIS installed, and I gotta admit, it's
a fine looking outfit. Also, just as in a stock Mk III or in a FireStar,
gauges just won't fit. Me ?? I just think a panel full of gauges
looks sexy as hell ! ! ! Logical ?? Naw, but I sure like my panel.
Old Fashioned Lar.
Sent: Monday, December 04, 2000 6:50 PM
If
Gary, My FS2 LIVES in a trailer but I have never seen condensation on it. It
does get out of the trailer about 3 or 4 times each month, but how can you
have any more moisture than the relative humidity when you seal it in?G.Aman
FS2 in humid Ohio.
In a message dated 12/4/00 9:58:46 PM Eastern Standard Time,
spiritmoves(at)earthlink.net writes:
<< I will go to great lengths to avoid even the possibility of coming close to
be money well spent. It is not as easy as it sounds. >>
There is a remote possibility that after this long thread about IMC that I
may actually come off as sounding dumb, but I'm going to enjoy it because I
hate unexplained abbreviations! After all the dialog about it, I'm sure it
must have something to do with IFR (now there I go) but I can not deduce what
it might mean other than IMMACULATE CONCEPTION....and I'm not even Catholic.
Could one of you funny talkers out there help me in my mire of total
ignorance or maybe just let me continure to ferment and wallow further.
GeoR38
Ken,
If the EIS were to quit, what do you really need to get safely on the ground?
For me it is just an airspeed indicator, and possibly a GPS.
Since having an EIS, there is no going back. I have seen the light. : )
John Jung
Firestar II N6163J
SE Wisconsin
> something?
Good question, all I know is I'am going to put in a vent and maybe some
insulation.
thanks,
Gary r. voigt
> FS2 in humid Ohio.
From: | "Ed Chmielewski" <edchmiel(at)mindspring.com> |
Sent: Monday, December 04, 2000 7:27 PM
close to
want
will
I
> GeoR38
IMC = Instrument meteorological conditions (fancyspeak for IFR)
Ed in JXN
MkII/503
From: | "williams brett" <dbwilliams52(at)hotmail.com> |
IMC means "Instrument Meterological Conditions". VMC means "Visual
Meterological Conditions". These two abbreviations refer to the conditions
of the atmosphere. IFR is of course "Instrument Flight Rules", which is the
rules and regulations a pilot operates under during flight. IFR flight can
occur under "IMC" or "VMC". In the Air Force we are required to file and
fly IFR to the maximum extent possible.
I usually am just a reader of the list. I fly/own 2 light aircraft one
of which is a Firefly, and fly C-130's for the Air National Guard. I enjoy
this list immensely and glean a lot of knowledge from the posts from you
guys with a lot of technical, as well as, flying expertise in the Kolb
aircraft. However, the discussions about inadvertent IMC have compelled me
to post this on the list. I will be direct and to the point.
If you enter IMC conditions in an aircraft with fully functional IFR
instrumentation, but do not have the proper instrument training (and
currency), you WILL NOT survive the encounter! Not probably, not maybe, YOU
WILL NOT MAKE IT. Second if you have the proper training, and are current
in flying IMC, but the aircraft is not properly equipped for IFR flight,
again, you will not survive your encounter with IMC.
Discussion should focus on, never getting close to IMC conditions in an
improperly equipped aircraft, ie. most Kolbs that I am familar with.
Needle, ball and airspeed, is difficult under the best of circumstances and
is a emergency procedure. I guarantee, that if you are relying on some of
the techniques I've read on this list to get yourself out of a "pinch" you
will not survive.
The NTSB (www.ntsb.gov/Aviation/months.htm) accident website contains
all aviation accidents in the US since the early 80's. Take any month and
look for a C-150 or 172 or PA-anything and look at fatal accidents and a
large majority of these are the result of a private or student pilot
entering IMC. Read the reports and hopefully it will take away any
illusions about theories or techniqhes of flying into weather without: 1)
proper training 2) instrument proficiency and currency 3) a properly
equipped aircraft ( fully functional attitude indicator, pitot-static
instruments, etc.)
I know this is strong language, but felt that this is necessary to post
on this list. Please focus on never putting yourself into a position of
ever getting close to IMC. Please take this in the context and spirit that
it is intended. Please continue to fly safe and I look forward to meeting
you guys. I am going to fly my Acro Sport to Lakeland this year and camp
with my father and buddies from the airport I hang out at.
Sincerely Brett Williams
If the EIS goes tango uniform(military lingo for quits), so what. The engine
will still run and the airplane will still fly.
I installed the EIS because I have a bad habit of enjoying the scenery and
not giving the instruments my full attention. But when that big red light
comes on my attention is drawn back to the instrument panel.
One time my EIS was reading a fuel flow of 10.5 GPH. Need less to say the
red light came on in less then an hour warning me of low fuel. I knew I had
more fuel then what the EIS was reading because Dave flew behind me and
checked the fuel tanks. The erroneous reading was because I had programed
the EIS for a 4 stroke not a 2 stroke engine.
Without the EIS It would be impossible to mount two CHTs, two EGTs gages, an
altimeter, vertical speed indicator, fuel flow indicator, RPM, Outside air
temperature, Hobbs meter and a fuel gage onto the FireStar's limited panel
space plus a compass & airspeed indicator.
http://members.aol.com/guillermou/232.jpg
The only reason I could think of not wanting to "put all your eggs in one
basket" is if you built an airplane to fly in IFR weather, then you would use
the EIS as a back up.
Hope this helps you understand a little bit better,
Will Uribe
El Paso, TX
VFR only FireStar II
but working in Arlington, TX for 3 weeks.
In a message dated 12/4/00 9:53:40 PM Eastern Standard Time,
> I cannot understand why so mshowing any pilots are gung ho on the EIS
> displays. If
You know, my eyes just aint what they used to be---
Dave
-----Original Message-----
Date: Monday, December 04, 2000 11:03 PM
engine
snip
had
I agree with you. I prefer good analog gauges. A number on a screen
doesn't provide you with any visual reference to the number. OK I guess if
your real smart, but I don't want to think about it. A good GPS provides
much of the information needed and augments the gauges. For me, a better
system.
Dave Rains
FireStar 2
El Paso
(made the Wilcox fly-in)
Date: Monday, December 04, 2000 8:11 PM
Palms
>Old Fashioned Lar.
>From: "Ken Broste" <spiritmoves(at)earthlink.net>
>To:
>If
From: | "MIKE HOUSEWERT" <mhousewert(at)earthlink.net> |
Brett,
THANK YOU!!!!!!!! for the explanation and being so blunt. I am new at this
game and very much appreciate the advice.
Mike H.
Subject: | Mark-3 aileron trim ? |
This may have been beaten to death in the past.
I know that John H flies from the right seat in order to compensate for the
engine torque. My Mark-3 is setup to be flown from the left seat (heel
brakes). I have to hold a pretty hard right aileron to maintain level
flight. Other than installing a cockpit adjustable trim control, has anyone
devised a clever way to deal with this? It would have to be cockpit
adjustable to compensate for passengers of various weights.
Ron
Sent: Tuesday, December 05, 2000 5:53 AM
Subject: RE: Kolb-List: IMC
> Brett,
this
> Mike H.
Subject: | Re: Mark-3 aileron trim ? |
Check out the picture and explanation at
http://www.bcchapel.org/pages/0003/pg6.htm
It is not cockpit adjustable, it is ground adjustable.
When you add or subtract a passenger, you always do it on the ground,
(At least I hope you do!) so a ground adjustable tab is OK. KISS is good.
If the page is insufficient, I can give more details off list.
Richard Pike
>Thanks,
>Ron
> A good GPS provides
> Dave Rains
Mornin Dave and Gang:
I like analog also. Probably, because that is all I have
ever used. My flying was over in the Army about the time
the Black Hawks came on line. Instrument panels started
changing with them. Didn't they have "thermometer" type
gauges?
I puchase my gauges, other than ASI, Alt, VSI, anywhere they
are good quality and cheaper. I never have liked Westach.
Proved unreliable most of the time. Maybe they have
improved them in the last ten years since I had them mounted
in the Firestar. Most of my engine gauges are marine. For
the 912 and 912S, gauges with greater ranges than normal
(cyl head temp and oil temp to 300F) can be found reasonably
priced at speed shops, Auto Zone, Car Quest, Summit Racing,
etc. I have gauges with well over 1400 hours on them.
Marine tachs for 12 pole alternators work great in 503's and
582's. Cost $50 to $60. Most now have a rotary switch on
the back to dial in a multitude of different pole alternator
combinations. Flight instruments can be purchased from
aircraft instrument overhaul facilities. Find your self
some old "cores". They used to give 25 or 30 dollars core
credit.
> A good GPS provides
How about expanding on this a little. About all I can get
out of my GPS that augments gauges is heading (mag
compass). Altitude is not reliable. Scratching my head,
but that is all I can think of now. What else? :-)
My Firestar panel had the following instruments and gauges:
ASI
Altimeter
"G" Meter
Hobbs (hr mtr)
Mag Compass
Slip/Skid
Tach
Combination CHT/EGT
My MK III has:
"G" Meter
ASI
Tach
Altimeter
VSI
Hour Meter
Oil Pressure
Oil Temp
Cyl Head Temp
Volt meter
Mag Compass
All swithches and circuit breakers
Mag switch
Having not flown the airplane since 1 Jul 00, it is
difficult to remember all the stuff.
I fly the EIS in the factory Sling Shot, but not comfortable
with it. Don't get me wrong. Nothing wrong with it, just
not to my personal liking.
Take care,
> engine torque. Other than installing a cockpit adjustable trim control, has
anyone
> Thanks,
> Ron
Ron and Gang:
That was one of the reasons I fly from right seat. The
primary reason was to take advantage of dual control sticks
and single throttle in normal center location. I started
out with 582, prop turns clockwise, so sitting in right seat
helped counteract torque effect. I learned from flying the
old factory MK III "Fat Albert", that flying left seat with
582 required a lot of right stick pressure to maintain level
flight. Then I installed 912, turns counterclockwise.
Ugh! Figured I would have a problem with left roll, but flt
test indicated no problem.. Pulled the 912 out and replaced
it with 912S. Oops! Now I have a tendency to roll left.
Not much, but enough to make it difficult to stay on
course. Solved that with a piece of bungee cord anchored
with a loop around the right side of dual control mount on
one end and a double rapped loop around the control stick.
Both loops are secured with 1/2" SS hose clamps. Makes it
quick and easy to make initial installation adjustment,
which is neutral when the loop is slipped to the bottom of
the stick. I increase right roll trim by sliding the loop
up the stick. Only takes a little to do the job. No sweat!
Take care,
Brett,
Excellent post. I hope that we hear more from you.
John Jung
> snip.......
Hi Gang:
My last msg read:
Should have read:
Solved that with a piece of bungee cord anchored with a loop
around the right side of the dual control mount on one end
and a double wrapped loop around the control stick. Both
loops are secured with 1/4" SS hose clamps.
So solly,
Good post big guy---HOpe to see you soon at anson co.
allen bellamy
This is the information I was looking for. Is there perhaps a picture
on-line showing the arrangement? I'm not too creative, and would like to
get it right the first time.
I'm sending this directly to you so that everyone on the list won't know how
dumb I am.
Catcha later,
Ron
Sent: Tuesday, December 05, 2000 7:58 AM
Subject: Re: Kolb-List: Mark-3 aileron trim ?
the
control, has anyone
> > Thanks,
> > Ron
> Ron and Gang:
> Take care,
> john h
Ron,
Your comment went to everyone including me. I feel the same way you do
because I am just getting into this. I was hoping someone would give some
definition to all of these letters, and it happened without me asking. But
now everyone has read my email and know that I too am very dumb about allot
of these things. Don't feel you are the Lone Ranger.
Mike H.
...Without the EIS It would be impossible to mount two CHTs, two EGTs gages,
an
space plus a compass & airspeed indicator...
OK, lets see here, I'll be installing a two-stoke with pull start...
From the Wicks catalog:
$80 - 2" dual CHT with senders
$85 - 2" dual EGT with senders
$115 - 3" altimeter 0-10,000 ft
$200 - 2" VSI
$60 - 2" tachometer
$50 - OAT
$30 - Hobbs
fuel flow - n/a at Wicks
fuel gage - turn around and look at the tank.
(fuel gages are computer calculated by the EIS)
$120 - 3" airspeed
$10 - compass
$750 total with a crowded panel. You could spend more for smaller gages or
omit some gages to spend less.
From the Kolb website:
$804 - EIS (not including wiring but I didn't include it above either)
$10 - compass
$814 total with a simple panel. Although I could spend up to $1,400 total
with a four-stroke and electric start.
This is a estimation as I have not yet built my panel. Does this accurately
compare with the actual costs?
Robert Haines
SlingShot
Murphysboro, IL (I've moved)
> dumb I am.
> Catcha later,
> Ron
Ron:
No such thing as a dumb question..................well, most
of them aren't dumb. hehehe :-)
Since you sent this to the List I will respond to the List.
I used some bungee cord someone had given me a long time
ago. I think it is about 3/8 or 7/16 inch in diameter.
Simply made a loop around a piece of existing tubing in the
dual control system, or somewhere on the right of the
control stick position, then locked the loop in place with a
1/4 inch wide SS hose clamp. Took the other end of the
bungee and made two wraps around the base of the control
stick, pulling the bungee tight enough to take out the
slack, but also keep it in the neutral position. Secured
that loop with a 1/4 inch wide SS hose clamp.
Now, to pick up the left wing and take pressure off the
stick, I simply slide the double loop up the stick far
enough to accomplish the desired amount of forced trim. If
I need to readjust my initial setting, loosen the hose clamp
and shorten or lenthen the bungee as required to get its
initial adjustment correct.
After I was satisfied it was like I wanted it, I cut some
heat shrink tubing about an inch long and shrunk it on each
end of the bungee. If you don't finish the end of the
bungee, it will come apart.
Sorry, I do not have any pics. When I get rich I will have
a nice digital camera. Then I will have the capability to
show you what I am talking about.
Take care,
http://members.aol.com/firestartwo/gps2.jpg
http://members.aol.com/n8754k/larry.jpg
Sent: Monday, December 04, 2000 8:27 PM
close to
want
will
I
what
Catholic.
> GeoR38
Well , I spent $504 dollars for an EIS without Altimeter. Add another $150
for the Altimeter function , and your $120 separate Airspeed and your up to
$774. Which is very comparable to your crowded panel and mine will flash an
idiot light at me for all kind of important reasons...and it is EXTREMELY
accurate (Have you tried to read the little needle on a 2" EGT scale from
that panel down there below your knees?) And are the gauges that you are
quoting "temperature compensated" (That thread was run long and hard a
while back) The cheapest "temp compensated" EGT (or pyrometers) that I know
of are the Micro-1000's and the dual egt is $95 bucks with no probes. So
make sure your comparing apples to apples when you compare prices.
Anyway , to each his own...You make your decision and pay your money.
The "eggs in one basket" thing is an issue on a IFR bird , but on a knock
around the patch VFR plane? Naaaaaaw , The engine will keep running and
forward speed still makes the wings fly , so that's a non-issue.
America is great...everybody can have an opinion....WAIT , I WANT A RECOUNT
ON THAT!!! ;<)
Jeremy
P.S. The price I quoted was for all probes and a pre-wired harness. And
(Sorry Norm) it didn't come from TNK. I won't even mention the type of UL
that its going on...I'd get laughed off this list. And any listers that
know (Ted Cowan...) keep QUIET!
an
$200 - 2" VSI
$60 - 2" tachometer
$50 - OAT
$30 - Hobbs
$120 - 3" airspeed
$10 - compass
$10 - compass
Robert Haines
SlingShot
Good Post, Brett, I think it was needed and I hope it hit home to all our
friends.
From: "williams brett" <dbwilliams52(at)hotmail.com>
Sent: Monday, December 04, 2000 11:06 PM
Subject: Kolb-List: IMC
conditions
the
can
one
enjoy
me
YOU
an
and
> will not survive.
contains
> instruments, etc.)
post
that
Do they make gauges for ultralights that read out air speed in mach numbers?
Sent: Tuesday, December 05, 2000 8:43 AM
> > A good GPS provides
> > Dave Rains
> gauges?
> credit.
> > A good GPS provides
> ASI
> Altimeter
> "G" Meter
> Hobbs (hr mtr)
> Mag Compass
> Slip/Skid
> Tach
> Combination CHT/EGT
> My MK III has:
> "G" Meter
> ASI
> Tach
> Altimeter
> VSI
> Hour Meter
> Oil Pressure
> Oil Temp
> Cyl Head Temp
> Volt meter
> Mag Compass
> Mag switch
> Take care,
> john h
For those you using needle oriented gages will find it really helpful to take
the time to put red lines on the face of the gages showing the maximums
allowed. I spent several hours cleaning the faces of the gages, carefully
applying masking tape to define the redline then painting it on with bright
red model airplane paint. Don't try fingernail polish many of them are
translucent and don't give good definition. The pay off here is that with a
quick glance you can spot an impending problem and that warning may give you
a little planning time before things really start to go wrong.
Duane the plane in Tallahassee, FL, FireFly 007, 447, Ivo
Me too. If I wanted to go with the "glass cockpit" look I would be
building a Lanceair instead of a Firestar.
Sam Cox
Cute: Put it on the list.
In a message dated 12/5/00 1:08:04 AM Eastern Standard Time,
dbwilliams52(at)hotmail.com writes:
<< I know this is strong language, but felt that this is necessary to post
Sincerely Brett Williams >>
Hey! Brett, if this list has purpose, it can't get any more significant than
your letter. I thought it was important enough to save permanently to my
files for future reference right along side Possum's 178 second story. I
think we are talking about flying without visual reference and discovering
the absolute danger of it without the proper instrumentation and training and
currency. When I first learned to fly gliders in El Paso ...actually New
Mexico, Las Cruces, they always told me never to ride the thermals right up
into the forming clouds. But they only said that it was due to the probable
turbulence up there. After your thread, I have another possible reason never
to follow the thermals into the clouds....I do try to fly the thermals even
here in Ohio whenever possible even with my Firestar. The main difference is
that you look for gaggles of birds instead of small forming clouds..
Thanks again for your response....it is a classic!
GeoR38
Akron, Oh
From: | "Christopher John Armstrong" <Tophera(at)centurytel.net> |
If
> something?
EIS is accurate and very reliable. the gauges that you can buy are very
inaccurate without extensive setup and are very hard to read with any
accuracy. EIS has a warning system that allows you to set limits then
alerts you when the limits are reached with a large warning light. it is
very easy to miss one of several little black vibrating needles that climbs
up over 1600 deg. EGT for a few seconds when you pull the throttle or
whatever. EIS is lighter then the gages, it is probably cheaper. it is
smaller. it is easier to read. if it goes out you either already have an
engine failure or you fly home and land without instruments, but the point
is it doesn't go out.
Topher
>If
>> something?
>EIS is accurate and very reliable. if it goes out you either already have an
You forgot to add:
Void where prohibited. Some assembly required. Batteries not included. Wash
colors separately. Contents may settle during shipment. Use only as
directed. No other warranty expressed or implied. Do not use while
operating a motor vehicle or heavy equipment. Postage will be paid by
addressee. Subject to CAB approval. This is not an offer to sell
securities. Apply only to affected area. May be too intense for some
viewers. For recreational use only. No animals were injured or killed
during the making of this production. If condition persists, consult your
physician. No user-serviceable parts inside. Freshest if eaten before date
on carton. Subject to change without notice. Times approximate. Simulated
picture. No postage necessary if mailed in the United States. Please remain
seated until the ride has come to a complete stop. Breaking seal
constitutes acceptance of agreement. For off-road use only. As seen on TV.
One size fits all. Many suitcases look alike. Contains a substantial amount
of non-tobacco ingredients. Colors may, in time, fade. We have sent the
forms which seem right for you. Slippery when wet. For office use only. Not
affiliated with the American Red Cross. Drop in any mailbox. Edited for
television. Keep cool; process promptly. Post office will not deliver
without postage. List was current at time of printing. Return to sender, no
forwarding order on file, unable to forward. Not responsible for direct,
indirect, incidental or consequential damages resulting from any defect,
error or failure to perform. At participating locations only. Not the
Beatles. Penalty for private use. See label for sequence. Substantial
penalty for early withdrawal. Do not write below this line. Falling rock.
Lost ticket pays maximum rate. Your canceled check is your receipt. Add
toner. Place stamp here. Avoid contact with skin. Sanitized for your
protection. Prices may vary in Alaska and Hawaii. Be sure each item is
properly endorsed. Sign here without admitting guilt. Slightly higher west
of the Mississippi. Employees and their families are not eligible. Beware
of dog. Contestants have been briefed on some questions before the show.
For instructions in English press 1 now. Limited time offer, call now to
ensure prompt delivery. You must be present to win. No passes accepted for
this engagement. No purchase necessary. It only takes an hour a week.
Processed at location stamped in code at top of carton. Some shrinkage of
garment may occur. Formatted to fit your TV screen. Use only in a
well-ventilated area. Keep away from fire or flames. Replace with same
type. Approved for veterans. Booths for two or more. Check here if tax
deductible. Some equipment shown is optional. Price does not include taxes.
No Canadian coins accepted. Not recommended for children. Prerecorded for
this time zone. Not intended for human consumption. Reproduction strictly
prohibited. No solicitors. No alcohol, dogs or horses. No anchovies unless
otherwise specified. Restaurant package, not for resale. Keep back five
hundred feet. List at least two alternate dates. Open other end. First pull
up, then pull down. Dear Mom, Send money. Call toll free number before
digging. Driver does not carry cash. Some of the trademarks mentioned in
this product appear for identification purposes only. Se hablamos Espanol.
Objects in mirror may be closer than they appear. Record additional
transactions on back of previous stub. Unix is a registered trademark of
AT&T. Do not fold, spindle or mutilate. Shirts and shoes required. No
transfers issued until the bus comes to a complete stop. Package sold by
weight, not volume. Your mileage may vary. Lane ends, merge left. This
supersedes all previous notices. Emergency exit only. In God we Trust...all
others pay cash.
Edited for content.
Subject: | Fw: My friend is gone |
FYI Fly safe guys.
Sam Cox
Sent: Tuesday, December 05, 2000 8:08 PM
Subject: UL: My friend is gone
> I am sad to share with this group the passing of a fellow pilot and my
dear friend Mike Miller, after two days of searching, his body was found
among the wreckage of his Kolb Slingshot. I understand that most of you did
not know Mike but I'm sure you know someone like him, always happy, a big
smile to greet you and there to help you in anyway that he could.
I am not sure if anything can be learned from this based on what is known
at this time , what I can tell you is Mike was a PP with 20 years of flying
and over 200 hrs. in this plane. he was found not more than 7 miles
from the airport in a ravine, but the plane was so broke up that it would
have been hard to see from the sky. A witness was finally found, he stated
that Mike had made a couple of passes in to the ravine and on the way out of
the second pass the engine sputter and than quit at which time the plane
went nose first back in to the ravine. The witness thought nothing of it at
the time because it looked like something Mike had done many times in that
area. Please keep in mind that I'm a novice and these are my thoughts, the
engine was the rock solid 912 and the first thought might have been water in
the gas and a frozen fuel line? is carb icing a possible cause? Whatever
the cause it seemed like fuel starvation and he had just filled up before
he left according to the records. I don't in anyway want to start a flame
war but one of the other pilots that had flown this plane said simply if it
ever lost power it simply would not fly, its short wing span plus the fact
it seemed a little tale heavy may have contributed to the crash. I believe
Mike knew this and when the engine quit he pointed straight at the ground
hoping to get enough air speed to flatten
it out and than just let it stall into the trees. He must have never got
enough speed to get it to fly because it hit the ground nose first and with
all the trees around only managed to clip one limb. Please forgive
this
newbie's thoughts, they are solely my own and that's ok because maybe it was
for me, my way of dealing.
dusty
>> A good GPS provides
>Intertainment
Dave Rains
Subject: | Re: Fw: My friend is gone |
Group,
I would like to offer my own ideas of what we might learn from this accident:
1) Accidents happen. If we fly we risk an accident.
2) Flyin low increases the risk. Our engines may not quit very often, but they
do quit, and if you are low when it quits, you have big trouble.
3) It the engine quits, the stick must be put forward without hesitation, or
you risk a stall. If you stall while you are low, you probably wont recover.
I still fly low at times, but only over places that I could land, and I try to
remember the increased risk and not do it too much.
John Jung
Firestar II N6163J
SE Wisconsin
snip....
I am going to buy a GPS for my Kolb and would like to read some comments
regarding several different models, if anyone has them.
Garmin StreetPilot Color Map
Garmin Pilot III
Any others that you may be very happy with & why.
Thank you
Mike H.
--- MIKE HOUSEWERT
--- mhousewert(at)earthlink.net
--- EarthLink: It's your Internet.
Subject: | GPS altitude feature |
Dave and Group,
I keep reading that the GPS altitude is not reliable. It is for me.
Since I added my EIS with altitude, I have compared the altitude of the
EIS with my Garmin 12XL. They seem to stay within 40 feet or so, most of
the time within 20 feet. With pressure changes, the GPS may be more
accurate after an hour or so.
John Jung
Firestar II N6163J
SE Wisconsin
Dave Rains wrote:
> >> A good GPS provides
> >Intertainment
> Dave Rains
Subject: | Re: GPS altitude feature |
> John Jung
John and Gang:
GPS altitude reporting is unreliable for me and my GPS. I
am not speaking for everyone's. However, I have an old 8
channel Garmin 95XL. My 55AVD prior to the 95XL was also 8
channel and also unreliable in altitude.
Scratching my head,
> >Intertainment
> Dave Rains
Dave and Gang:
Good morning.
Working on my second cup of coffee.
Thanks for the info. Had forgotten about "entertainment."
I do tend to play with the GPS as I get bored on long XC's.
Keeps me from prematurely wearing out my gauges. :-)
John,
Which GPS do you have? Which one do you wish you had if different than the
one you are using?
"Kolb List"
John Jung,
I have been reading your e mails and just read your address is SE
Wisconsin. Where are you? I am in Belvidere, IL, which is right next to
Rockford.
Also, which GPS do you have? Which one do you wish you had if it is
different than the one you are now using?
I have a KOLB Mark III, which I have flown twice with other pilots, once in
Wilminton, NC, and the second with Brian from Lite Speed Aviation (Builders
for The New Kolb Company) in Kentucky. Since I got my plane back 2 weeks
ago, I have not been able to fly because of weather. I am going to get
some experience with a seasoned ultra light pilot before I try solo.
If you are close enough, you may want to "fly in" sometime to my strip. I
have 800', runs north/south, trees at the south end about 40-50' tall,
pattern would be left hand and land heading north.
Talk with you soon.
PS I tried sending this directly to you at your address (jrjung(at)execp.com)
and it came back as "undeliverable". Do I have your correct direct e mail
address?
Mike H.
Mark III
--- MIKE HOUSEWERT
--- MIKE HOUSEWERT
Mike,
I am very satisfied with my Garmin Pilot III. I have used it for 2 years on
many trips. It is small, yet I can push the buttons in choppy air, and the
display is large enough. Most pilots mount their GPS in some kind of
holder....I prefer to let it rest in my lap.
Bruce McElhoe FireFly #88
Reedley, Calif.
> Garmin Pilot III
> Thank you
> Mike H.
John H and Group,
You might have hit on why people see such a difference in GPS altitude
accuracy: The 8 v.s. 12 channel technology. 12 channels do a lot of
thing better than 8. I used to have a Garmin 45 (8 channels) but it's
been so long that I forgot about using less that 12 channels.
John Jung
> > John Jung
> John and Gang:
> john h
> John Jung
Kolb Folks:
Don't get the wrong idea about 8 channel GPS capability. I
did my 1994 flight with the 55AVD. Used a Commant passive
antenna mounted on top of the center section. Never lost
coverage once during the entire flight.
For the 2000 flight I updated to a used, in new condition,
95XL 8 channel. I will use this GPS for my 2001 attempt to
fly to Barrow, Alaska. I have no qualms using it. The
major difference between 8 and 12 channel is the ability of
the 12 channel to acquire satellites quickly and in areas
that are not direct line of sight. The 8 channel has to see
in order to receive. I find that no problem, even in the
far north, in mountains, where the angle of sight to the
satellite is very low to the horizon. I think we have more
satellites now than we did in 1994, plus we did away with
the built in degradation.
Now for the sales pitch! Naw, just kidding. But if someone
is interested in my 1993 Garmin 55AVD with Jeppesen Data
Base, updated and over hauled by Garmin in 1997, ready to
hook up to your aircraft battery, let me know. I will sell
it. My current GPS is a 1994 Garmin 95XL. Basically the
same GPS with some added info features. Both are worn on
the thigh with a two inch velcro strap. It is not in the
way. Is easy to see and operate. Takes up no premium panel
space. :-)
Take care, pray for warmer weather,
I too would like to respond to the previous comments regarding this aviator's
untimely death. My condolonces are with his family.
Having flown for over 12 yrs, beginning in gliders and becoming a commercial
glider pilot, I have the upmost respect for altitude. After all, there's no
engine to save you. I went from gliders to ultralights, getting my BFI and
enjoyed introducing people to the joy of flying. Altitude was and still is
one of my pet peeves. You can hardly get enough of it.
Recently I've come full circle, purchasing a Grob 109A Motorglider with a
glide ratio of 30-1. At 2,500 feet, I still feel low. I want to be able to
get to adjoining airports should my engine quit unexpectedly.
All of us should put safety paramount in our flying and with ultralights,
each preflight is an annual of sorts and should be conducted as if our life
depends on it which it does. If you fly low, fly low over terrain that you
can land in, not crash in should an engine fail and remember that the glide
ratio in ultralilghts is very, very low and the more altitude the better.
Lets all of us fly safely and encourage the same of our fellow pilots if we
see unsafe movements about us.
Allen Bellamy
John & group,
Do all GPS's give altitude? For example does the Garmin Color Street Pilot
give altitude and would one want this for an airplane?
Thank you,
Mike H.
--- MIKE HOUSEWERT
> Mike H.
Mike and Gang:
Check out this web site:
http://www.garmin.com/
Got bunches of info on all Garmin GPS's here.
I prefer having the capabilities of the aviation GPS,
primarily for airfield info because I like to XC outside my
local area.
In a message dated 12/6/00 8:03:47 AM Eastern Standard Time,
jrjung(at)execpc.com writes:
<< I keep reading that the GPS altitude is not reliable. It is for me. >>
Since the government relaxed the rule about the required error in GPS', mine
is very accurate. Check yours again, John [Hauck].
Howard Shackleford
FS I
SC
Subject: | Harry Reasoner and Helicopters |
Hi Gang:
Just for a little change of pace, here is a description of
helicopters by Harry Reasoner. This is dedicated to all
helicopter pilots, especially VN era Army helicopter
pilots. And you UL pilots thought you had your hands full
keeping your UL in the air. :-)
"The thing is, helicopters are different from planes. An
airplane by
it's nature wants to fly, and if not interfered with too
strongly by
unusual events or by a deliberately incompetent pilot, it
will fly. A
helicopter does not want to fly. It is maintained in the air
by a
variety of forces and controls working in opposition to each
other,
and if there is any disturbance in this delicate balance the
helicopter stops flying; immediately and disastrously. There
is no
such thing as a gliding helicopter.
This is why being a helicopter pilot is so different from
being an
airplane pilot, and why in generality, airplane pilots are
open,
clear-eyed, buoyant extroverts and helicopter pilots are
brooding
introspective anticipators of trouble. They know if
something
bad has
not happened it is about to."
Harry Reasoner, February 16, 1971
Well, maybe UL pilots are more like helicopter pilots and
airplane pilots. hehehe I love it.
PS: Now you know why I am different. :-)
> Howard Shackleford
Howard and Gang:
Mine too. In all areas except altitude. I would never bet
my ass on the accuracy of indicated altitude on my GPS, even
after the upgrade by Uncle Sam.
Subject: | Re: Harry Reasoner and Helicopters |
Hey Gang:
Gotta start proof reading my stuff.
This:
Should have read:
"Well, maybe UL pilots are more like helicopter pilots than
airplane pilots."
Makes a difference doesn't it?
I found some information that may be of interest.
In the December 2000, Ultralight Flying Magazine, page 25, in Dan
Johnson's Flight Report of the Phantom X-IE;
Dan says quote: " Like most electronic gizmos, you must learn how to
properly use the EIS, but it delivers alot of information in an easy
read format. My only complaint with electronic instruments is that you
can't simply shoot a quick glance; you must spend the second or so to
read the number shown and interpret. In some cases you must switch to a
different screen to see other readings. Contrarily, a set of analog
gauges that are well designed and organized can supply details with the
briefest of looks. I was given the instructions to turn the EIS system
off before shutting off the engine."
I hope this will be helpful.
Bill Vincent
Firestar II
Quinnesec, Upper Peninsula of Michigan
Hey Will - who's this goofy looking guy?
And is that an ultralight engine or a drag racer?
From: | "larrybiglar" <larrybiglar(at)email.msn.com> |
Watch it mister. 2500 miles might not be far enuf ! ! ! Besides, it's an
ultralight drag race engine. What happened to that video ??
Good Lookin' Lar.
Sent: Wednesday, December 06, 2000 8:49 PM
Sorry to use the List, but no choice...............R. Harris, your
address isn't working. Please email me off List. Lar.
>Good Lookin' Lar.
We are having "technical troubles" with the next video, like the "Rocket"
thing.
Example: Is it illegal to shoot "buzzards " with a paint ball gun.
In Georgia - "buzzards " are apparently an endangered species/protected
species.
Why?: I guess because they eat carrion/dead animals on the roads.
Therefore you cannot "shoot" them.
And what, as Bill Clinton might say, - what does "shoot them" mean?
They don't seem to mind it too much. Makes them funny colors-
But as you know, I wouldn't want to break the rules.
Two good reasons to use EIS. Your Ultralight will vibrate more in the air and
on the ground more than a heavy airplane. You can literally shake an analog
instrument to death.Secondly,you can actually see and read the EIS display's
big numbers. I don't know how you could install all of the gauges to perform
all of the functions in the panel space provided in a Firestar, that the EIS
offers you. The warning light system alone is so valuable in a 2 stroke that
I could make no other choice logically.G.Aman FS2 75hrs
Zep Rep and Gang:
I was headed for bed, but will have to make a comment or two
on this msg.
Any reasonable measure of shockmounting the instrument
panel, same same real airplanes, will insure long life for
quality analog instruments. Mine have well over 1400 hours
on them.
I reckon if I shook hard enough, I could shake anything
apart, or even to death.
> big numbers.
I can actually see the big needle and dials on my analogs.
> offers you.
I installed all the gauges in the Firestar that I needed for
safe, reliable VFR flight. Plus some I didn't need. Did
not require all the available functions of the EIS.
How many engines have been saved by gauges and EIS's? The
warning light is not going to save your engine. All it does
is tell you that a parameter you set has been exceeded.
Usually by the time we realize there's a problem, the engine
has already seized or come apart. I have yet to have the
gauges save an engine, if it was a seizure or catastrophic
failure. Well, I only seized one twice, in about a 15
minutes time span. If it is going to seize or have a
catastrophic failure, it will probably happen in a blink.
Won't matter if you have digital or analog instrumentation.
I say, to each his own. I fly with little round gauges, you
fly with a black box. :-) If they didn't help, or if I
didn't think they helped, I wouldn't fly with them. :-)
and
I agree and "I" was an (analog) kind of guy.
Quick scan the panel and you knew "basically" what was going on.
EIS was a "numbers" kind of thing.
Totally different. Tried to break it after I bought it.
Set the light to come one when it shouldn't---it did and it works.
Wasn't sure I could still trust the light. ---so set so other traps for it.
It passed with flying colors. Honest to God, this thing is going to replace
75% of our instruments.
And it should. It's better. Hell it only takes about 1 or 2 days to
completely convert to it. IMHO
User-Agent: Microsoft-Outlook-Express-Macintosh-Edition/5.02.2022
Subject: | Winter flying--ice flying |
Hi, eh! (for those down south that's "Hi Y'all")
I want to make a comment about some of my experiences of flying in the
wintertime. For a number of years I've been flying off of skis and really
enjoy it. I combine my flying with ice fishing. I fly into some remote
lakes and always have snowshoes and other equipment with me. The snowshoes
are just in case I have to make my own runway to get off the lake.
Hopefully, I'll never have to walk out.
The skis I made are really wide and work really well in deep snow. They
disperse the weight evenly. For example, I landed on the lake (50 miles
north) where there tends to be heavy snowfall. The plane did real well. I
stopped, stepped out of the plane. As soon as I did, I sank down into the
snow, over my knees and half of it was slush. But the plane stayed right on
top of that whole mess. I worked hard, playing in the slush to put two
holes in to fish, but got skunked--only a nibble. The daylight hours are
pretty short up here, so there's not much time to fly.
I rarely have gotten cold when I fly in the winter. Once I flew when it was
six below and sunny and have almost fallen asleep in the cockpit. I've
always said "fur and feathers for warmth." I have a down suit and muskrat
hat. Works for me! Normally our temperatures average teens and twenties.
Makes it nicer.
One thing I have to do with my 912 engine is I have to cover up the oil
reservoir and the radiator with an insulated blanket to get the oil temp up.
Merry Christmas to all from the Great White North (a.k.a the U. P.--eh!)
Scott Trask N38ST
Iron Mountain, MI
P.S. (I'm hoping to organize a winter fly-in up here on a lake and roast
weenies over a fire this winter.)
Scott, Do you have an engine pre-heater? Larger Battery because it is a 4
cycle engine? Do you use a thinner oil? My skis are made from old
wooden water shis, what are your skis made from?
Dale Seitzer
on
was
Makes it nicer.
up.
Scott Trask N38ST
Iron Mountain, MI
Subject: | Re: Winter flying--ice flying |
> Scott Trask N38ST
> Iron Mountain, MI
Scott:
Send me date, time and coordinates, please. :-)
Morning Gang:
I have my analog OAT stuck outside the front door so I can
see that it is 33 deg at hauck's holler, alabama, at 0825
this morning. Cold for me, but warm for Scott Trask and
most of you guys up north.
Was reading this morning's AVWEB on the internet, comes out
twice weekly now. If you want it sent to your email address
the url is:
http://www.avweb.com/signup
I haven't had time to look through them, but there are 36
aviation quizes at this location:
http://www.avweb.com/toc/brain.html
They look like they might be good for us ultralight pilots
too. Some of them are IFR related, but most have to do with
weather minimums, METAR (weather coding and abreviations),
radio procedure, Class D airspace, medicals, etc.
Take care,
Two more things about EIS. The Company was incredible when I called them with
a question regarding a Charging problem. It took them 1 min. to determine I
had a bad voltage regulater. They even had a very high quality one they sold
me to replace it and I got very quickly. No long holds on the phone so you
can talk to someone who doesnt know anything and cant help you. They
inadvertantly sent me the wrong diameter EGT probes for my exhaust I called 8
months after I bought it and they sent me the right ones that same day, just
on my word that I would return the old ones ! Talk about service. The second
thing is that the more time your allowed to scan for traffic instead of
focusing on the gauges, the safer your flying. We here about pilots these
days so transfixed on there "Glass cockpit" and focused on there GPS that
they lose there situational awareness. With the EIS, you can choose when to
check your numbers like when your away from traffic. Keep It Simple-the EIS
does that. Kris Henkel
John H,
I agree with you 99% of the time and you have my respect. But this time I feel
that you are leading the wrong way.
You said "The warning light is not going to save your engine. All it does is tell
you that a parameter you set has been exceeded."
If the light is telling the pilot that his EGT limit has been exceeded, he has
time to pull back on the throttle and/or stop diving before the dangerous, engine
killing limit is exceeded. This is most important part of the EIS, and the one
thing that analog gauges cannot do. In my 503 Firestar, all it takes to exceeded
the EGT is to let the plane dive without reducing the throttle enough. In
turbulent air, this can happen without being noticed. It is unlikely that a pilot
with analog EGT gauge would notice that his EGT has exceeded the limit in time
to
save the engine. Haveing a light turn on to get the pilots attention, maybe 20
degrees before the danger point, gives the pilot a chance that he would have had
with an analog EIS. I am not saying that analog gauges don't help. They just don't
help as much as an EIS does.
John, please re-read what you wrote last night, below. To me, you made a good case
for having an EIS without admitting that they are better. If you had used an EIS
to any extent, you would know that EGT's to not go up "in a blink". It would only
seem like a "blink" because there was no problem the last time the gauges were
scanned, and the engine quit before the next time they were scanned.
John Jung
Firestar II N6163J
SE Wisconsin
John Hauck wrote:
> snip....
Subject: | 582/618 temperatures |
Not being used to flying water cooled engines, I am not sure what temps I
should expect, especially during this cold time of year.
I am currently seeing about 100 degrees for water, 200 for CHT, and 1000
for EGT.
I want to set the EIS to alarm when certain unknown temps are reach, but not
sure at what point the various temps are getting too high.
If these temps are too low, how do some of you bring them up. Probably hard
to obstruct the radiator with a pusher configuration with the possibility of
something coming loose and going throough the prop??
Ron
Subject: | Re: Kolb List, R.I.P.? |
Hello Gene,
It was really good to hear from you. You are on the right track in your test
phase flying. One test objective at a time. There is an EAA video on "First
Flights in Your Ultra /Light Plane". If you don't already have a copy you
should be looking for one. Also, I don't do any engine out simulations, steep
turns, stalls , etc., at <1,500' AGL.
You did not mention if you have a parachute. I know they are not sure things
but at least they keep your mind busy while your falling.
I brought mine home Monday and am the process of installing a sound deadening
panel behind my seatback. I am also going to add a storage pouch for my
camera. When finished I will take her down to the strip near our Ochlockonee
Bay townhouse. It is on the sectionals as Wakulla Co Airport, Panacea, FL.
When I was there last week about 6 Challengers and one Kolb came in and
stayed overnight. Right now there is probably more activity there than at
Quincy. I'll keep you posted.
Duane
Subject: | SLINGSHOT PILOT CRASH |
If you have the 2001 copy of the new CPS (California Power Systems)
catalog, the cover is that of a person flying a red Kolb Slingshot through
a mountainous/valley. Does anyone know who this is? I hope it is not the
pilot recently crashed his Slingshot is a "mountainous valley".
Mike H.
--- MIKE HOUSEWERT
I have been discussing Props, Clearance, Noise level, and Flaps.
From the information I have gathered it seems that the prop can create quite
a bit of sound due to it because of its proximity to the flaps. If that is
true could the flaps be shortened any and not be detrimental to the handling
of aircraft. I also understand not much flap is used unless you are landing
at a short field. I was thinking of moving them a little further away from
the prop area.
I am looking for a good source for Wheel Pants for my Mark III Xtra. I want
to cut any drag that I can. I see some really nice ones on your pictures
and would like to know where you got them.
Julian Warren,
Eugene, Oregon
I did a spell check but I am a lousy proof reader. It should read bungee
cord. You got me good. Gotta start proof reading my stuff.
Merle
I have been in some third world countries where using the can was
a bit more challenging than normal, but I'll have to admit,
I have never used a dung-y cord....
And (I'm almost afraid to ask) what kind of passengers do you
normally carry, that the dung-y cord compensates for?
(Even though the wife and I are both Old Poops,
and should know such things, this one has us baffled!)
Richard Pike
My search engine turned this up:
Dungy: See Coach, Tony, Tampa Bay Buccaneers.
(Also formerly of JXN.) ;-)
Ed in JXN
MkII/503
Gentleman, Allow me to introduce myself, My Name is Russ Widman. I'm a Kolb
Mark III builder. I've just completed my aircraft after 6 and a half years,
and when you see it you will understand what the hell took me so long. I
live in New Jersey and the past few weeks the temp has been cold. Real cold,
but I'm not about to wait till spring to enjoy my new airplane. Last Sat I
took my Mark III out for its eighth hour of flight. I flew for one hour at
2500 ft and my OAT was reading 24 degrees. My toes were freezing but my face
was in a warm tropical breeze. My day job is a designer/modelmaker and for a
living I build prototype models. I decided to take the time to solve the
problem of cabin heat as simply and cleanly as possible, and I believe I
have. I have created a heat exchanger that slides over the standard Rotax
582 muffler which I believe is the same muffler for the 503, and maybe 447's.
It only works as well as the cabin is sealed, but this weekend I will test
it again after addressing several of the leaks I have found. My prototype
is working so well I have ordered enough material for 15 units and am getting
quotes from a local shop to build packages for me. If anyone has questions
or would like to see photos, contact me so you can enjoy your winter like I'm
going to. Contact me at N112KC(at)AOL.com. This weekend I hope to have aerials
available of my plane which can be viewed through my home page. Check it out.
Russ Widman
N112KC(at)AOL.com
Subject: | Re; Cabin heat for my Mark III |
Russ Widman
N112KC(at)AOL.com
Dear list:
I have a quad egt/cht 3 1/4" guage (one egt/cht for each carb), airspeed
indicater, 270 sweep tach, compass, and altimeter. These fit well into my
shock mounted firestar panel. I like having needles to look at because it
is easier to see the rate of change than on a digital readout. I have no
trouble seeing if the temps are getting close to redline or heading in that
direction in a hurry. I have only 60 hours on my gauges (46 since April) but
they have been very reliable so far. I took my UL training in a two place
beaver 550 with digital tach and altitude gauges and wasn't happy with them.
I guess it comes down to personal preference.
Just bought a Magellan 315 GPS last week. So far I'm very happy with it. It
is simple to use and agrees quite well with all of my instruments including
altitude. It has never been more than 20 feet different. I hang it around
my neck on a shoestring and grab it with my throttle hand when needed. It
was on sale at Bi-Mart for $129 and I couldn't resist getting myself an early
Christmas present. Many of the more expensive units have a few more bells
and whistles, but really don't give you a whole lot more USABLE information.
I do a lot of hunting and hiking and wanted something to pack along in the
woods that would also work well in the firestar. No gripes so far.
Went out yesterday and was pleased to find the 35 surface temps turned to 55
or so about 2000 ft AGL. Saw three NICE bucks on Grizzly peak up in the
snow. Flew for 1.2 hours, all the way up to 8000 feet and still only used
2.2gals of gas. I love this winter air!
Big Lar, You have the coolest exhaust I have ever seen on an ultralight! I
hope your plane flies as good as it looks! Keep up the good work.
P.S. Sorry for sending my Christmas mail to the list a few days ago. It was
supposed to go to a friend in Finland!! OOPS! Merry Christmas to you too
Rev. Pike! I think OP stands for Outstanding Pastor, not Old Poops :-)
P.P.S. If you want to know what is in the fuel you are buying (alcohol etc.)
just ask for the MSDS (material safety data sheet) at the station. They are
required by the EPA to provide you with the information. Your tax dollars at
work.
So long for now...
Roger in Ashland, OR
From: | "Ken Broste" <spiritmoves(at)earthlink.net> |
Why has not general aviation scrapped their analog gauges in favor of one
unit giving instrumentation on all facets of the flight and mechanical
operation of their craft?
Sent: Thursday, December 07, 2000 1:50 AM
> and
analog
display's
perform
EIS
that
it.
replace
Sounds like you had a lot of problems with your EIS!
Sent: Thursday, December 07, 2000 8:32 AM
with
I
sold
called 8
just
second
to
EIS
Subject: | Important stuff! |
Being from Arizona, you Yankees are giving me the shivers flying in that
cold stuff. I don't know if I could handle flying in anything below 32F.
I admire your gumption and stamina.
I'd like to bring to everybody's attention something of great
importance. The Tucson Ultralight club has just lost out on a great
opportunity, supposedly with the cooperation of the Tucson Airport
Authority and the city of Tucson to lease for $1/year, 160 acres for use
as an ultralight airpark west of town in a relatively isolated area.
The proposal has been turned down and deemed unacceptable because of
behavior of some ultralight pilots, no one will ever know who, hotshot
behavior of "buzzing" earthlings who were just minding their own
business. We have run up against a brick wall. Please let's practice
responsible flying wherever you may be. It will reflect on all of us.
My cow has died so I don't need
any of your bull!
No need, they have more panel space to fit all them gauges. Also it's more
practical to keep GA airplanes, flown by different pilots, standard so they
don't get confused.
In a message dated 12/7/00 11:14:10 PM Eastern Standard Time,
Ken,
One reason that general aviation has not changed, is thar the EIS is not legal
in their planes. They have so many rules and laws that are difficult to change
that general aviation cannot keep up use technology.
John Jung
In a message dated 12/7/00 8:16:51 PM Pacific Standard Time,
<< Sounds like you had a lot of problems with your EIS!
>>Ken: My letter states I had a problem with the Voltage Regulater, not the
EIS unit . There is no Voltage Regulater in the EIS and I wouldnt call
getting the wrong diameter "Hose Clamps" for the exhaust a "Problem". Kris
Subject: | Re: Re; Cabin heat for my Mark III |
Russ,
Welcome to active portion of the Kolb list. Thanks for offering the heater info
and I look forward to seeing pictures of your plane when you get them on your
web site. I am thinking about adding a rear enclosure and heat to my Firestar
II, so I am interested in what you have done.
John Jung
SE Wisconsin
> Mark III builder.
snip....
Subject: | Permanent Gap Seal |
Anybody out there mount their gap seal permanent, if so, how did you arrange
for removal/insertion of the clevis pins for main spar attachment, trying to
figure where to cut and allow my hand to reach in and put that sucker in!
Photo's would be a big help! Also tryin to figure the seal between the
windshield and the gap seal, ordered the sheet metal and the rubber piece
from Sue at TNK.
___!___
Bill Johnston Jr
Building Mark III Classic
Harpers Ferry, WV
Subject: | Re: 582/618 temperatures |
A water cooled Rotax ought to run at least 140 degrees. Takes offs too
cold can cause cold seizure of the engine. Aim for 140 to 180. If you
let it get real cold in a descent, ease the power back in gradually to
let it heat back up gradually and safely.
I do not have a CHT. IMHO, EGT's should be 1075-1150 for a 582. NOTE:
Cross check all EGT gauges with plug readings. Gauges lie, plugs don't.
The older 532's could be run hotter, I run mine 1150-1200, pulled the exhaust
manifold off earlier this week, piston top and cylinder head carbon free,
rings loose and clean, one small area of one exhaust port has an area
of carbon buildup about 1/4" wide, 3/4" long. Oil is Phillips Injex, and have
quit using Seafoam (groan, here we go again!) and started using OMC
Quicksilver carbon remover, 1 ounce to 6 gallons of premix.
Raise the temperatures by blocking the radiator on it's front side with
something
that will not hurt the prop if it comes off. I don't block my radiator, but
iff'in I did...
Why not use an old piece of Naugahyde, secure it to the front side of the
radiator with tie wraps, poked through the fabric and the radiator fins and
looped
back. If it comes off, it might (?) successfully go through the prop w/o
damage.
(Try not to find out)
(If this doesn't work, I do accept public abuse...)
(Don't send me the bill for your prop)
(If the Naugahyde melts all into your radiator, could you post pictures so
that
the rest of us can enjoy them?)
Richard Pike
>for EGT.
>Thanks,
>Ron
California Power Systems. They have 3 sizes, get the big ones
1-800-AIRWOLF. Also Aircraft Spruce sells pants.
Richard Pike
>Julian Warren,
>Eugene, Oregon
In a message dated 12/8/00 9:04:00 AM Pacific Standard Time,
richard(at)BCChapel.org writes:
I would never presume to contradict the redoubtable Mr. Pike. I
observe, however, that the current Rotax recommended minimum operating
temperature for a 582 is 155 f. For most folks with the stock Kolb
recommended Rotax top mounted twin radiators getting that temperature with an
oat of less than 60 f will require blocking off a portion of the radiator. I
use duct tape. Simple. Easy off and on. I have been meaning to make a
little chart showing how many strips of duct tape are needed at what oat.
I'll get around to it someday. At an oat of 40 f I have had to block off
almost all of one of the radiators to keep the water temps in the right range.
Mark R. Sellers
Kolb Twinstar Mark III
N496BM
From: | "Jeremy Casey" <jrcasey(at)mindspring.com> |
What rubber piece???
Jeremy
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of
WingManBill2(at)aol.com
Sent: Friday, December 08, 2000 10:30 AM
Subject: Kolb-List: Permanent Gap Seal
from Sue at TNK.
___!___
Bill Johnston Jr
Harpers Ferry, WV
> briefest of looks
I disagree with this whole comment. I have been working for Powersport
Aviation developing the fuel injection map for the Powersport engine, and
have been using various gages for egt and O2 sensors, oil water baro
everything. Analog gages can not be read with any accuracy with the
briefest of looks. this is something that people say about them all the
time and it is just not so. To get a decent number out of an analog EGT
gage you must look at it very carefully and see where the tip of the needle
is. A brief look will maybe give you egt to + or - 20 degrees. I dont feel
that is accurate enough even for just monitoring purposes. The whole point
of the EIS is that you do not have to monitor all those gages. The computer
does it and if any value is out of bounds it lights up a big red light to
let you know to check out the motor. so you get accuracy and warnings. you
do not need to get the information in the briefest of glances, which doesn't
work well anyway.
Topher
Subject: | Re: To EIS or not To EIS |
They are coming in the new aircraft, but to do so costs them tens of
thousands of dollars because every part in the instrument has to be
certified. And because GA doesn't do it is a bad reason for safety minded
folks to not choose to use a clearly superior system if it is available. GA
is the most hindered part of our society. the technology in a GA plane is
almost unchanged for over 40 years, due to the double whammy of ridiculous
over regulation and huge lawsuits.
Topher
Will you guys quit about EIS and or analog gauges (gages) , I built my MK3
and put a 912 on because I wanted to.. I also put a EIS system in it because
I wanted to.. I would have put a 277 on and one halls air speed indicator.
if I wanted to... that's the thing about our sport , you can do it like YOU
want to... So just put what you want on or in YOUR airplane and enjoy....
Richard Harris
Lewisville , AR. MK3 SN M233
N912RH
----- Original Message -----
Sent: Sunday, December 03, 2000 10:09 PM
Subject: Re: Kolb-List: To EIS or not To EIS
> > I have heard both pros and cons on the EIS system. I would like
> > to have some comments on this thing to help me decide. Thanks in
advance
> In four words...."You won't be sorry." I'd like to know what
> negatives you've heard? I really like my unit, saves space, is
> accurate, never failed, easy to read, etc.......
> J.Baker
From: | "Geoff Thistlethwaite" <geoffthis(at)worldnet.att.net> |
From: "Christopher John Armstrong" <Tophera(at)centurytel.net>
Sent: Friday, December 08, 2000 4:37 PM
Subject: Re: Kolb-List: EIS SYSTEM
> > briefest of looks
> everything.
Powersport engine??
info please Topher....
Well, guess I can't argue with that kind of logic. How about weight?
Ever sat in an Airbus cockpit? Seems like they are headed that way. Do not
archive
Subject: | Re: EIS vs Needles |
In a message dated 12/7/00 11:11:31 PM Eastern Standard Time, RPHanks(at)aol.com
writes:
<< Rev. Pike! I think OP stands for Outstanding Pastor, not Old Poops :-)
etc.)
at
work.
So long for now...
Roger in Ashland, OR >>
Roger...I didn't know that.....so that is what the 40.9 cent tax in
Akron,Ohio goes for!
and I use MSDS sheets all the time....but didn't know it was required by law
for gasoline...thanks....GeoR38
From: | "Ron or Mary Payne" <ronormar(at)apex.net> |
Subject: | Powerspote engine |
What is a Powersport engine and is there one that will fit on a FireStar? I
have read so many reports on the list about Rotax two strokes failing that I
am getting paranoid. I seams like they are falling out of the sky like rain
drops. Is the failure rate of a Rotax two stroke higher than other engines
used in out type of aircraft?
Ron Payne
FireStar II builder
Gilbertsville, Ky.
Richard,
I don't think you understand what this discussion is all about.
It is not about personal choice, it is about lowering risk, and increasing
safety.
That is why it is worth our time. If it weren't, I, for one, would not waste my
time on it. I also have no problem with someone deciding that they do not need
to increase their safety. What I do have a problem with, is someone making that
decision without all the information. That is what this list is about: Sharing
information to make the building and flying of Kolb airplanes easier and safer.
John Jung
Firestar II N6163J
SE Wisconsin
snip.....
Subject: | Re: Powersporte engine |
Two strokes do demand a much higher level of owner savvy than 4 strokes.
But: I think a lot depends on your perspective. Having come out of the bad
old days of "motorized hang gliding", the possibility of an off field forced
landing does not particularly worry me. Having flown in front of a Mac 101,
forced landings were a way of life. (Have Fun! Meet New People!)
I would love to have an engine with the reliability of a 108 HP Lycoming,
the Rotax 912 probably comes close. But I can't afford that. I have about
15% of the cost of a 912 invested in my old 532, and it seems to be doing
just great. I don't know the real odds, but if there is a one in 10,000 chance
of a 912 quitting on you on any given flight, a well maintained two stroke
probably has a one in 2,500 chance of quitting.
I can live with those odds. But I won't fly at night either...
On the other hand, a 912 that is merely fed enough oil, gas and otherwise
ignored,
might possibly (?) have a one in 500 chance of quitting on any given
flight. (?)
A two stroke treated that way will probably have a one in 25 chance of
quitting.
And IMHO, that is the basis of the "two-stroke failure rate problem"
Caveat: Not all two stroke failures are owner related; Rotax has from time
to time,
released some screw ups. For instance: Early 582's had much more fragile cranks
than later ones, according to the guru at LEAF.
And I had a local friend get a new-in-the-box 277 with no wrist pin
circlips installed.
It continued to run long enough to get him home even after the wrist pin
had dug a
1/4" groove in the side of the cylinder wall. Found it on tear down. Go figure.
4 strokes are great. Two strokes are satisfactory, but you gotta' treat
them right.
Richard Pike
MKIII N420P (420ldPoops)
>Ron Payne
>FireStar II builder
>Gilbertsville, Ky.
Subject: | Re: Kolb-List Digest: 24 Msgs - 12/07/00 |
In a message dated 12/8/00 2:00:56 AM Central Standard Time,
kolb-list-digest(at)matronics.com writes:
> aileron trim ?
I'm flying a Mk2 and it's tendency to roll left is noticable also. I intend
to install right aileron trim (fixed) as I fly only solo. will let you know
how it works
Steve K
Hey Scott....fax me a pastie will ya?
Steve
Subject: | Powersporte engine |
You've all probably heard all the great 912 comments from John H. and others
, well here's one more. Local guy just north of me has a Rans S-7 w/ a 912.
He is a flying son of a gun and has put 1400+ hours on this motor in approx.
3 or so years. Including flights to Canada from Georgia and all states east
of Miss. I believe (or darn close to it.) Anyway 1400+ hours with no
maintenance (not ignored just checked over and nothing required...). I am
not counting oil changes and spark plug changes , as that is just upkeep.
Anyway he developed a leaky water pump a few weeks ago and decided to tear
it down and have a look see. Replaced the pump and mic'ed everything else
and found everything to be WELL WITHIN tolerances! Just decided to put it
back together and fly it! It still uses no oil, never drips a drop. I
would go as far to say (and he did as well) that there are NO Lycoming or
Continentals that could claim to be that trouble free. Yea their
recommended TBO might be 2400 hours but you'll put regular maintence into
them (accessories , mag replacements , etc....I have seen mags go out on an
o-235 in 20 hours that were certified rebuilds! That will make you glad it
has 2!) My $.02 worth...yea it's pricey , but if your gonna really fly the
thing then the 912 gets real cheap over the long haul (less fuel consumption
, no oil-mixing , EXTREMELY longer time between rebuilds as compared to
2-strokes...) Not knocking 2-strokes cause they have there place as some
designs just can't tote the weight of a 912 or the like...just given credit
where credit is due. Everybody bad mouths Rotax but they at least did the
912 right for sure!
Jeremy Casey
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike
Sent: Saturday, December 09, 2000 10:37 AM
Subject: Re: Kolb-List: Powersporte engine
chance
ignored,
flight. (?)
quitting.
to time,
cranks
circlips installed.
had dug a
figure.
them right.
Richard Pike
I
I
rain
>Ron Payne
>FireStar II builder
>Gilbertsville, Ky.
From: | "Paul Riedlinger" <priedlinger(at)triad.rr.com> |
Can anyone tell me what the normal high end EGT should be on a Rotax
912UL. I have heard opinions from 1350 to 1600. I have searched the
manuals from beginning to end and can't find any reference to the proper
numbers.
Any help would be appreciated.
Paul Riedlinger
paulried(at)ornaprod.com
The Ornamental Group Of Companies
> back together and fly it! It still uses no oil.....
Most think the hallmark of a quality four stroke aviation engine is
it's lack of oil use. Not so. Accellerated upper cylinder wear will
quickly negate the savings in added oil. Just ask yer friendly
Continental or Lycoming repair shop....
J.Baker
In a message dated 12/9/00 1:10:38 PM Eastern Standard Time,
jrcasey(at)mindspring.com writes:
<< Everybody bad mouths Rotax but they at least did the
912 right for sure! >>
I don't badmouth 2 cycle Rotax....I have been using one since 1992 and have
NEVER had an engine out....and I abused it for a coupla flights before I got
my EGT too....I'd swear the needle read 1400 a coupla times, before I knew
where it shoulda been. And I have had experience with Cuyunnas too and had 3
engine outs between '83 and '91. But I didn't even have an egt on that so I'm
sure that I caused them ( had a resonator on the exhaust which really added
hp out capacity)...so the fault was mine....It was ok, as I just suffered a
coupla broken gear on the pterodactyl on takeoff!....never knew those
fibreglas axles could bounce so high when i mushed in from 15 ft!! Passed the
first bounce cause the gears shared but when I found I had no control
whatsoever after bouncing up 7 ft...I mean straight up...the puppy came
straight down at an angle and loaded up one side of the axle and Broke it
....cost me all of $25 to repair in them days...."90 - 91.
No, I don't badmouth Rotax at all....I'm amazed!
GeoR38
Akron, Oh
It's my understanding that this is a result of the different characteristics
of water and air cooled engines. My T'Bird now, and the Saab before it,
never ( I didn't stutter ) use any oil between my self-imposed 3000 mile oil
changes. T'Bird is close to 70,000 miles now, and I'm not kidding. It uses
less than a quart per 3000 miles. Saab started using a little more, WAY
over 100,000 miles. Air cooled engines run much hotter, and have a far
greater range of operating temps overall. This requires larger clearances,
to accomodate expansion and contraction, which will pass more oil, as well
as a tendency to burn more of that oil, at those higher temps. 912 heads
are water cooled, and run much cooler. As I say, this is my understanding
only. Have at 'er. Big Lar.
Sent: Saturday, December 09, 2000 7:06 PM
Subject: Kolb-List: 912.....
> J.Baker
Maybe I should re-phrase that before someone jumps on
me..................the Bird uses oil all right, but I've never seen it go
as much as a quart low before the 3000 mile change. Lar.
Sent: Saturday, December 09, 2000 7:52 PM
Subject: Re: Kolb-List: 912.....
characteristics
oil
uses
clearances,
> From: "Jim Baker" <jlbaker(at)telepath.com>
> To:
> > J.Baker
> El Paso >>
>Are Naugas like snipes....I admit to almost hunting for them once as a
>child....I was told that I almost caught one too.
>GeoR38
The Society for the Preservation of the Nauga
60 Hunters Ct.
Amelia, Ohio 45102
Subject: | Re: Prop Bolt Torque on Ivo |
Can anyone please tell me the proper torque for those 8.8 metric bolts as
used on the Ivo prop? My Wingman somehow over-torqued & broke one. $6
each......
Shack
FS I
SC
Subject: | Re: Powerspote engine |
215 hp aircraft conversion of the Mazda 13B rotary engine. weights 325
pounds.
Ivoprop mounting bolts are torqued @ 200 inch pounds.
Did he use 200 foot pounds instead? (Ouch!)
Richard Pike
>each......
>Shack
>FS I
>SC
I don't guess it will fit on a FireStar. 325 lbs.
Sent: Sunday, December 10, 2000 12:06 AM
Subject: Re: Kolb-List: Powerspote engine
> pounds.
John , I completely agree with you about sharing information , however this
thread had gotten to the point of bickering , and mine is better than yours
syndrome ....
R Harris MK3 SN M233
N912RH
Sent: Saturday, December 09, 2000 6:10 AM
> Richard,
> safety.
waste my
need
that
Sharing
safer.
> John Jung
> Firestar II N6163J
> SE Wisconsin
> snip.....
Paul , Rotax is mostly silent on 912 EGT < I think because if you keep the
CHT where it should be the EGT will be in line .
Having said that I do monitor my EGT but just because the EIS has a place
for it.. ( will regret saying EIS ) and my alarm is set for 1800 deg..
Also the placement of the probe in the exhaust pipe has a lot of bearing on
indicated. temp. A difference of as little as 1/2 inch will change the
reading 200 deg . Rotax has a monitoring system they sell for the 912 ,
they say the probe should be 4 1/2 inches from the exhaust valve , and give
a warning at 1700 deg , and a alarm at 1800deg .
This is where I came up with my numbers , everyone I have talked to ,
that is suppose to know all about 912s are not concerned about EGT .
Hope this helps
R Harris MK3 SN M233 N912RH
> numbers.
> Paul Riedlinger
Subject: | Archive not working? |
Hello list,
Anyone else having problems with the matronics archive web page? I'm getting
the equivalent of a busy signal.
I'm trying to research the best best to purchase an oil pressure sender for a
912. See my tale of woe below if interested.
I have had a string of bad luck with the oil pressure sender on my 912.
First off, on my first static engine run the plastic knurled knob that holds
the instrument wire on came off, hit the prop and shot back through the
fabric on my cage. So now I get to learn how to patch areothane. This has
been a real learning experience to say the least.
So being smarter than the average bear, I decided to switch to a nyloc metric
nut instead of the plastic knob. In my effort to make sure it was tight and
had a couple of threads showing to make sure the nyloc had a bite, I broke
off the threaded terminal on the sender. I lost my religion (only for a
brief second).
So now I am shopping for a new sender. Have you ever had to replace the oil
pressure sender on your old 912? I pretty sure I can find a VDO (0 -10 bar)
1/8 NPT somewhere in Baton Rouge. The only question I have is on the
original one there was a brass cup fitted on the engine side of the sender.
Not sure why that is there and what purpose is serves. the Leading Edge
catalog has them priced at close to $200.00. I know it is a $40.00 part if I
can find the right one.
Any help, again, is always appreciated.
John Bickham
St. Francisville, LA
Mark III - 912
N308JB
Subject: | Re: Archive not working? |
Not to make fun of your unfortunate and expensive mishap...
But simply to add fuel to the fire of "2-stroke vs. 4-stroke..."
What's an oil pressure sender? What's oil pressure?
My ol' 532 ain't got any of those things...
And now that I've made you mad...
go to http://www.summitracing.com
go to search, under parts, select gauges, senders & acc.
under manufacturers, select VDO
They sell a 1/8" NPT unit for $23.95,
Part # VDO-360003
Phone # 1-800-230-3030
You could probably talk to them on the phone and see if it
sounds like it would fit, or just buy it and try it, see if it works.
Good luck.
Richard Pike
>912.
>John Bickham
>Mark III - 912
>N308JB
Water cooling is a really poor substitute for upper cylinder
lubrication.......... ; )
> It uses
> over 100,000 miles.
The fact that they do use some oil is good. Using none is very
much worse.
J.Baker
Subject: | Rotax alternative |
I am looking into the BMW R-100 motorcycle engine. I have read that
they are being used a little in England and more in South Africa. It
makes 74 hp at around 5400 rpm and weighs in at about 155 pounds
complete. The good part is that the motorcycle transmission is a bolt
on unit so you don't have to mess with that. With an adaptor, the Rotax
"C" gearbox bolts up to it and you don't need any special "tricks" to
get it to work on a pusher type ultralight. They've been run hard on
motorcycles for years. I have a local machine shop available to me and
as soon as I can locate an engine, I will go to work on the adaptor.
One is available through a web site for $450 and the coupler for $450
but I think it can be made cheaper.
prospective Slingshot builder
Why pay for something you could get for free?
Subject: | Re: Kolb-List Digest: 22 Msgs - 12/09/00 |
on 12/10/00 1:58 AM, Kolb-List Digest Server at
kolb-list-digest(at)matronics.com wrote:
> ____________
> From: N51SK(at)aol.com
> Subject: Kolb-List: Re: Kolb-List Digest: 24 Msgs - 12/07/00
> Steve
Hi Steve
I got your pasty here, ready to fax it. But I discovered I don't have your
fax number, so I'm eating it as I type. Boy, is it good! When the
weather's nasty, eat a pasty. Where have you had a pasty before? Have you
been up in the U.P. recently. Where are you from? Gotta go!
Cold weather flyers
I have a number of question that was asked of me what I do to my 912, and my
skis etc. I wrote it down I'll get my wife to type it. LATER
Scott Trask
Iron Mt. MI
Please unsubscribe
Harry Wingert
From: | "Duncan McBride" <duncan.mcbride(at)worldnet.att.net> |
Subject: | Electric problem |
I'm putting together a Mark III with a 912 UL, and I've been following Bob
Nuckoll's suggested wiring scheme, with the overvoltage module and relay.
I've pretty much followed Figure Z-7 in his appendix, except instead of
using a 22AWG fuse link to provide power to the alternator side of the
master switch I just used a place from the bus. I used a 5amp fuse, and
what's started to happen is that after turning on and off the master four or
five times, the fuse blows when the master is switched off. I happened to
notice it because I was standing right over the bus when I switched off the
master and I saw the flash when the fuse blew. Is a five amp fuse too
small, or is something happening that shouldn't? I'm using a 5amp circuit
breaker between the bus and the switch, like in the drawing, but it has
never opened. I'd like to make sure everything is ok before I just use a
bigger fuse. Thanks in advance.
In a message dated 12/9/00 11:46:59 PM Eastern Standard Time,
possums(at)mindspring.com writes:
<< Kolb-List message posted by: Possum
> El Paso >>
>GeoR38
60 Hunters Ct.
Amelia, Ohio 45102 >>
Hey...wait a minute....that's close to home ....I ....think......GeoR38 do
not archive
In a message dated 12/10/00 1:39:08 AM Eastern Standard Time,
<< voprop mounting bolts are torqued @ 200 inch pounds.
Richard Pike
>each......
>Shack >>
Could that possibly be 12 times too high?? GeoR38
I had misplaced the June and August 2000 Experimenter magazines. June 2000
had the Mark IIIXtra on the cover and August 2000 had an extensive article
about the plane. I emailed EAA a request to order back issues and Mary
Jones from EAA emailed back that they had extra issues laying around and
that she would sent them to me for gratis. Sure enough, just a few days
later, they arrived in the mail the same day as the December 2000 issue.
The December issue has an article on building forms for bending tubing. I
don't know if it is available online or not. It gives a mathmatical formula
for making a form to bend the tubing around. He recommends using sand
inside the tubing before bending, if the diameter to thickness (D/t) is over
15. It looks like a good method for construction, but I don't believe the
curves on the Kolb are critical enought to need the mathmetical formula,
just the general idea and approximate radii.
I am picking up kit #1 for my Mark IIIXtra next week. I have a question
about flattening the ends of the tubing. Using a vise seems rather slow.
Has anyone found something more efficient. I have thoughts of altering an
old shotshell reloader that I no longer use to flatten the ends. I assume
it doesn't take a great force to flatten the tubing, and I could use the
lever on this press to replace the vise. I would somehow construct a stop
to limit the cam travel to 3/16" above the base.
I live only 60 miles from the Kolb factory. They have asked if they can
visit me on occasion and get my input on the building process. They said
that my feedback would help them improve things. I told them that I would
be honored to do that. Also, I hope that they will give me feedback about
my construction. I just warned them that my construction will be slow since
I have only a few hours a week to work on my plane. They sounded OK with
that. Maybe they will even fly their factory plane into my 600' grass strip
sometime.
Clay Stuart
Danville KY
From: | "Lawrence M. Rice" <tailwind5(at)juno.com> |
Don't think I'd use naugahide for a radiator cover that might go through
the prop, that stuff's awful dense!
Larry
In a message dated 12/10/00 5:19:45 PM Eastern Standard Time, GeoR38(at)aol.com
writes:
<< << voprop mounting bolts are torqued @ 200 inch pounds.
Did he use 200 foot pounds instead? (Ouch!) >>
No, he used a torque wrench he was unfamiliar with and expected a LOUD click-
he didn't hear the soft click.
By the way, all the torque wrenches at our field read "Foot pounds" only; do
you divide inch pounds by 12 to get foot pounds, and do you multiply foot
pounds by 12 to get inch pounds?
Shack
FS I
SC
> safety.
> John Jung
John and Kolbers:
Been out of the loop for the last four days. Trying to
catch up on a wash tub full of emails.
I have heard a lot of real good comments about digital
instruments, particularly EIS. Everything has been pro. I
have yet to hear anything on the con side of the
discussion. If there is nothing to discuss that is negative
with regard to the EIS, then undoubtedly you all have
discovered a perfect product. :-)
One pound of force applied to the end of a 12" wrench would give you 12
inch pounds, or one foot pound of torque.
Therefore: one foot pound equals 12 inch pounds, 6 foot pounds equals 72
inch pounds, 12 foot pounds equals 144 inch pounds, etc.
(I wasn't sure I remembered it right, so I looked it up in one of
Bingelis's books)
Richard Pike
>Shack
>FS I
>SC
From: | "Larry & Karen Cottrel" <lcottrel(at)kfalls.net> |
Subject: | Re: Heaters again |
I have just completed a heater that works off the cooling air from the
shroud. It uses a 2 1/4 inch "scat" tube to carry the heat to the cabin,
has a extruded hinge from Aircraft Spruce, and is controllable from the
cabin to regulate the heat entering the cabin. It will not overheat the
engine, since you can configure it to allow all the cooling air to escape
if need be. If anyone is interested I will forward pictures of the heater
and the tool required to make it.
Larry
K.falls,Or
In a message dated 12/10/00 10:39:45 PM Eastern Standard Time,
lcottrel(at)kfalls.net writes:
<< If anyone is interested I will forward pictures of the heater
and the tool required to make it. >>
Larry, I would be interested.
Shack
FS I
S C
> them right.
> Richard Pike
Richard and Gang:
Rotax 2 cycle engines as well as 4 cycle engines are
extremely reliable. Very seldom, in my limited knowledge,
does an engine fail catastrophically. My own experience:
PTO crankshaft bearing failure resulting in engine
(Cuyuna)seizure (1985).
Wristpin bearing failure (Rotax 447 cageless bearings).
Flew it and the Firestar from Lakeland to home strip, low
power, but still flying.
582 seizure, act of God. Haven't really figured that one
out yet, but has to do with going from full power climb to
cruise, thermostat opening, cooling cylinder liners quicker
than the pistons, running out of cyl wall clearance. Locked
up tight (1993) after flying the same procedures for the
last 225 hours. Who knows?
The reason I listed the above experiences is to point out
how realiable these two strokes are. Of the three engine
failures, only two put me on the ground, "right now." These
failures were most likely defective parts and/or design.
Now, I have had a bunch of engine failures that put me on
the ground. But most were caused by operator problems. In
the early days we had a big learning curve on a lot of
things. Inverted Cuyunas spit plug wires. I didn't know
that until mine dropped one and put me on the ground. Paper
element fuel filters will plug with a few drops of water in
them. I had 5 or 6 engine failures on takeoff from my strip
in the same afternoon until I finally figured out what the
problem was. Shorted wires. Plugged primer bulbs with
silicone seal balls. Pin holes in "pulse lines." Broken
throttle levers. Water in fuel. Dirt and debris in fuel.
Spark plug electrode seperating in a high priced NGK B8EV
over Grand Island, NY, resulting in engine failure, broken
landing gear and socket. Hitting the mag switch while
wearing mittens and not realizing it until too late. And
there's a lot more if I could remember them.
The 912 served me well for 1,135 hours of hard flying and
hard performance. I had two engine failures with it. First
was a lot of water in the fuel. Second was a lot of dirt
and debris in the fuel, clogging the fuel filter.
So, you see, the 2 and 4 strokes that I have used since
1984, have a good track record. Most of the failures were
my fault.
I read the FAA Accident Briefs on the internet every
morning. A lot of accidents are caused by engine failures
in GA airplanes. A lot by fuel starvation. A lot by
catastrophic failures of cyls, crank shafts, magneto's.
Most, by far, are broken landing gear or landing gear up. I
know about broken landing gear. :-)
In the early days of Sun and Fun, and Oshkosh, we had a lot
of engine failures during the shows. Now a days, maybe one
every once in a flyin, but not very often.
Just some thoughts to share with my friends,
I just bought a torque wrench calibrated in in-lbs at Sears. It was on sale
for about $50.
Gene Ledbetter
Cincinnati, OH
Firefly 00-2-00018, both canopies, big wheels and brakes, Ivo 2 blade
> J.Baker
Hi Jim and Gang:
Maybe that is true for Continental and Lycoming engines.
For 912's it doesn't seem to be a problem. Eric Tucker
shared this tid bit with me last January at the 912 School
in Lucedale, Ms:
"Rotax has yet to sell a replacement cylinder for a 912.
Some of the 912s have over 3,000 hours on them. This is in
11 years and over 7,000 912s produced and being used. That
was as of Jan 2000."
I can understand why Cont and Lyc make that claim. They
both use a lot of oil. :-)
Larry
K.falls,Or
Hey Larry....maybe that will lengthen my flying season here in Akron, Oh
....please forward to GeoR38(at)aol.com ....and thanks in advance
In a message dated 12/10/00 10:39:53 PM Eastern Standard Time,
<< Therefore: one foot pound equals 12 inch pounds, 6 foot pounds equals 72
Bingelis's books)
Richard Pike
you're right .... I hope!....cause that's what I've been teachin to
adults....
GeoR38
In a message dated 12/10/00 10:57:50 PM Eastern Standard Time,
hawk36(at)mindspring.com writes:
john h >>
Good post John....it appears you should write a book....I wanna buy it!
GeoR38
In a message dated 12/11/00 12:09:45 AM Eastern Standard Time, GeoR38(at)aol.com
writes:
Hey, Lar!! Neat heater, but I don't know what I'm looking at [the tool].
What does it do?
Shack
FS I
SC
The tool will make the body of the heater, bending the flat piece of 7 1/2
x12 inch flat alum into the c shape. It will also bend the cover piece
too. If this isn't explained in the letter to Ron, Perhaps I had better go
back and do so.
Larry
> From: HShack(at)aol.com
> To: kolb-list(at)matronics.com
> Subject: Re: Kolb-List: Re: Heaters again
> Date: Sunday, December 10, 2000 9:20 PM
GeoR38(at)aol.com
> writes:
> What does it do?
> Shack
> FS I
> SC
Maybe we should look at it from the other way 'round. Not so much how much
the air cooled needs, but how much it wastes. I think it's pretty well
established that modern auto engines use very little oil. My T'Bird is
certainly not unique, according to other people I've talked to. Obviously
that little bit is sufficient, because they almost universally go 150,000 or
more miles before needing rings, etc. The Lycomings and Continentals, ( and
VW's ) use far more oil, due to burning it, than they really need for
lubrication. Anybody ?? Big Lar.
Sent: Sunday, December 10, 2000 10:17 AM
characteristics
> > It uses
> > over 100,000 miles.
> much worse.
> J.Baker
> Please foward pictures of your heater.
> Thanks
> Jim Ballenger
Jim and Gang:
Not to take any smoke away from the aircraft heaters, and
there are several discribed on the list in the last couple
years, a short time ago John Russell, Sling Shot
driver/builder, posted a msg about his new Chilli Vest. It
is in the Kolb List Archives:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=24054508?KEYS=heated_vest?LISTNAME=Kolb?HITNUMBER=2?SERIAL=14333212500?SHOWBUTTONS=YES
Kim Steiner up in Saskatchewan, Canada, sent this post
reference electric heated seat cushion:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=23378641?KEYS=heated_clothing?LISTNAME=Kolb?HITNUMBER=1?SERIAL=14311010009?SHOWBUTTONS=YES
Dell Vinal discussed making some homemade electric gear to
stay warm:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=23371058?KEYS=heated_clothing?LISTNAME=Kolb?HITNUMBER=2?SERIAL=14311010009?SHOWBUTTONS=YES
I have received my Chilli Vest that I intend to use as my
aircraft heater, just like John Russell is doing now. I
talked to John this morning. He is still happy with the
performance of his Chilli Vest. He has not shivered nor
have his teeth chattered since he started flying with it
last month. Can not wait to try mine out. It is very thin,
light, and looks professionally done. Draws very little
current, based on my test in the basement with the 5 amp
Quick Start foil battery. Saw very little battery deletion,
about .5 volt in 20 to 30 minutes use, most with the system
adjusted to max performance.
The major advantage of the vest is its simple installation.
Two wires to your battery, or 12V DC regulated aircraft
power. I believe it will work without a battery installed.
It should. Draws less power than a radio and electric fuel
pump. I operated these two items, plus strobe lights on the
power system of my old 447 without battery. The more items
one installs on an engine and aircraft, the more "stuff" one
must fly with. The more "stuff" one flies with the more
stuff to go wrong. :-)
My own thoughts about the matter of staying warm and flying
an unheated aircraft. I look forward being able to stay
comfortable in below freezing weather next summer on my
flight north. You better believe I will have back up
clothing on board to supplement the electric heat should it
go belly up. :-)
Take care,
From: | Mike Housewert <mhousewert(at)earthlink.net> |
Hi Guys,
I took this heater (or lack of heat) seriously and decided to go to Florida.
Decided last Wednesday, got some cheap tickets, and am now walking on the
beaches of Marco Island, temperature today was 80. The only problem is that
I do not have may airplane. I told my wife today would have been perfect.
I called back to my son in Northern Illinois (near Rockford) and it is a
blizzard. Ten inches on some on the ground, still snowing like crazy, wind
chill 30-40 below. I really feel bad that I am here - that is -without my
plane. If I had the plane here I would not have to worry about a heater.
Maybe AC?
Sorry, just had to rub it in a little. I will be back to the frozen tundra
late next Sunday.
Mike H.
------Original Message------
Sent: December 11, 2000 10:47:31 PM GMT
> Thanks
> Jim Ballenger
Jim and Gang:
stay warm:
go belly up. :-)
Take care,
Subject: | Aeroelectric response |
Hey, Bob Nuckolls was quick with some help with my blowing fuse phenomena.
Turns out a fusible link is less quick to blow than the fuse, and I'd need
something strong enough to force the breaker to open anyway. But it might
be that the overvoltage relay coil is causing enough surge to reach the fuse
limit when the power is cut. I'll try a diode as he recommends for other
contactors and see if that works, but change out the fuse for a link anyway.
His catalog is back up on his web site BTW. And there is a new list on
the matronics server dedicated to the Aeroelectric Connection. All this has
been a tremendous help to me, so if you have the plane nearly built but are
wondering how to hook it all up, you should check it out.
"kolb-list(at)matronics.com"
paul and the list
the egt temps on the 912 are as follows
noninal 800 c 1470 f
max 850 c 1560 f
the temps listed come out of the 912 ul installation
manual [ 10.1 ] the readings should be taken 2.76 inches
down stream of the exh.flange
also in the operation manual ( i think that is where i
found it ) it says upt o 1620 f during take off for very
short periods. if you would like chapter and verse.
let me know and i will look it up
boyd
Subject: | 912 Mark-III For Sale |
Beautifully customized Rotax 912 powered Mark-III for sale.
Located central PA
Call Sam: (717) 483-6254
asking $23,000
Hi,
As I mentioned earlier I was having my trailer foamed inside. The guy
charged me $1.00 a foot for a total of 237.00 I guess that isn't too bad
considering. It will help with the heat in the summer too. Since I used the
painted "roofing" tin it really did not condense water like some of them,
but the heat reduction would be worth it alone.
Larry, KFalls,Or
Unless the laws of physics and metallurgy have been suspended
for the Rotax four strokes, the same principles apply.
Which is indeed a fine stat but tells nothing of the actual oil use of
those engines involved. Dollar to a doughnut they use some oil and
it doesn't have to be massive quantities, either.
Sure do because that's the way they're set up, by design.....
J.Baker
snip....
> lubrication.
Has more to do with piston clearance and design parameters. The
Lyc and Cont are designed to use oil, not much mind you, but they
aren't designed to use zero oil. The VWs I've owned were not really
any worse in oil useage than the water cooled Subarus, essentially
the same sort of flat-four engine design. They were very much
worse in bearing wear because of the lack of an oil filter which
eventually opened up all the clearances much faster than could
have been the case with a filter (Ford tests showed an 800%
improvement in bearing wear just by using a filter...).
J.Baker
> J.Baker
Jim and Gang:
When I left home on my 1994 flight, I had a spare quart of
oil on board. By the time I got to North Pole, Alaska, I
had flown 100 hours. It was time for an oil change. I
bought two qts of Mobile I Synthetic to go with the quart I
brought with me. Never had to add oil between 100 hour
change intervals for the first 1,000 hours. Based on the 95
hours I have on the 912S, won't be necessary to take spare
oil on XCs. Correct me if I am wrong, but if I remember
correctly, piston to cylinder clearance on the 912 is .001
inch. That is pretty snug. The 912 is a clean engine,
seldom will one find one that has an oil leak.
I reckon the 912 is designed not to use a lot of oil. :-)
Subject: | Its good to be back! |
Kolbers,
I have been off the air due to on going technical problems with my
computer and ISP. Tried to go with a new ISP but failed to get
connected through two weeks of trying. Finally gave up yesterday and
went back with Alltel, still have some bugs to work out but managed to
get online tonight.
My Mark-3 is progressing, got the fuel system and master cylinder
installed. Decided to remove the floor trays for trimming and hard coat
anodizing, should improve their looks and durability. I am in the
middle of fabricating the door latches, should be done by the end of the
week.
Sould be removing the enclosure soon so covering prep can ensue.
Hope all is well with you all.
Denny
Subject: | MEK proof markers? |
Does anybody have any suggestions on a way to mark powdercoated tubes
that will not wipe off with MEK?
I need to mark the location of my enclosures P-clamp mounts so that I
know where to slot the fabric for the clamps after the fabric is glued
to the fuselage. I figure I'll be able to see the marks on the tubes
through the unpainted fabric and cut the slots accordingly.
Denny
rowedl(at)alltel.net
. "Correct me if I am wrong, but if I remember
john h"
Yes. I think water cooled engines are usually tighter than air cooled
engines which have to account for a much
greater temperature range and thermal expansion.
Rody in Cincinnati
Wow --that's alot of money. For $23,000 one could choose alot of planes or several
different styles of planes. Dale Seitzer
Sent: Tuesday, December 12, 2000 8:06 PM
Subject: Kolb-List: 912 Mark-III For Sale
Located central PA
asking $23,000
Subject: | Re: 912 Mark-III For Sale |
Yes, it is a lot of money, but he's probably got close to $30,000 into it,
plus all the labor of building it. Looks like kits are a labor of love,
cause you sure won't get rich building them. Big Lar.
Sent: Wednesday, December 13, 2000 5:45 AM
Subject: RE: Kolb-List: 912 Mark-III For Sale
or several different styles of planes. Dale Seitzer
> From: Dennis Souder
> Located central PA
> asking $23,000
Subject: | Re: MEK proof markers? |
Use a pencil or epoxy paint with a small brush.
> Rody in Cincinnati
Rody and Gang:
Rotax wanted an aircooled engine, but discovered they
couldn't keep CHT in the green without the addition of
water cooling. So the 912 is a combination of liquid cooled
heads and aircooled cylinders. The greatest overall cooling
factor is oil cooling. The close tolerances between
cylinder and piston are the result of using NIKASIL coating
and no steel or cast iron cylinder liners. I previously
guessed at the new "piston to cylinder" clearance, .001
inch. I was wrong. The book indicates .000 to .0008 for
new assembly. Now that is close. :-)
The Rotax Operators Manual indicates acceptable oil
consumption for the 912 is 1 quart in 10 hours. Based on my
personal experience operating 912/912S, if my engine burned
1 quart or oil in 10 hours, I would be a little concerned.
Is it?
If you have a strong stomach, think about how much your plane has REALLY
cost you bottom line after all the trips to Home Depot, orders from Aircraft
Spruce, etc...
I bought Kolb's old demo plane (Fat Albert) in flying condition at Sun-N-Fun
two years ago for $17,500 and thought I wouldn't have to spend too much on
it to get it completely restored. That was about $7,000 ago (not counting
$2,500 for a trailer and not counting the value of my time) and my shopping
list still includes "little" things like an ELT, Nav/COM, Mode C
Transponder...
Depending on what Dennis' friend's plane includes and what condition it is
in, $23,000 could very well be a bargain. If Dennis says it's "beautifully
customized", you can believe it is.
I think that any time you buy a plane or a boat, even if you pay cash up
front in full, it is still just a "down-payment".
Peter
Located central PA
asking $23,000
From: | Mike Pierzina <planecrazzzy(at)yahoo.com> |
I think I could make a heater using a small propane tank & torch attachment w/
auto start (craftsman) ....the tank is small but it will burn for a long...long
time...,some ducting & some kinda box to contain the flame using some sorta
ram air control and alota tinkering.... I live in Minnesota so I've been giving
it some thought, I fly Cessna during the winter months , because my FS II isn't
finished yet , (kit # 2 was just shipped.......Yippie !!!! )
Well, Gotta Fly...
Subject: Re: Kolb-List: brrrrrrr
Guess I'd better stop bitching about my hot summers. You guys really get it
bad in the winter, while we sit here with 60 - 70 degree days, and 40 - 50
deg. nights. Toasty Lar.
Sent: Tuesday, December 12, 2000 10:13 AM
Subject: Kolb-List: brrrrrrr
> ---------------speaking of heaters---they don't make em good
> enough for this stuff. Good day for a project if you have a nice shop.
Subject: | Re: Cockpit Heater |
time...
Mike and Gang:
Might keep you hotter than you desire. That torch would
make a good pilot light for five or more gallons of
gasoline. :-(
The main reason I have a master switch is to prevent, as
much as possible, something igniting gasoline, should I
break my airplane.
Take care,
From: | "Clive Hatcher" <clive_hatcher(at)lineone.net> |
Bob and Gang,
There are a few BMW conversions in the UK, I think that they usually
go for the R-110 But the conversion would be the same. I have seen no
problems reported with reliability but the air cooling has given a few
initial headaches on some installations. Nothing that careful ducting
hasn't sorted out as far as I am aware.
There is a company producing a complete conversion kit and if you like
I will try to get some details.
Clive. Mk III / 582 UK
> Africa. It
> adaptor, the Rotax
> "tricks" to
> run hard on
> available to me and
> coupler for $450
> Bob
In a message dated 12/13/00 2:05:24 AM, rowedl(at)alltel.net writes:
Denny>>
How about wax markers!!!
Saw something at Costco that may be interesting: box of chemically
heated hand gloves, 40 pcs (20 pair?) $20. Uses a type of catalytic
reaction. Gets to 135F. Don't know how long a glove keeps on heating.
bn
Denny when I was recovering an the fuselage of a Champ I used red thread to
mark in a similar situation, and pulled the treat very easily at the proper
time.
Julian Warren
Eugene, Oregon
Sent: Wednesday, December 13, 2000 3:16 PM
Subject: Re: Kolb-List: MEK proof markers?
> Thanks,
> Denny>>
attachment w/ auto start (craftsman) ....the tank is small but it will burn
for a long...long time..
You bet!
Gee! And to think I always worry about smoking on long trips!
P.S. I always throw the butts out the left side and down - 503 dual carb.
From: | "Ashley & Margaret Johnston" <Jabiru.nz(at)xtra.co.nz> |
Todays questions and opinions expressed in the comparisons of Rotax and
0360's have missed to mention the very successfull Jabiru Engines that
are a meaningfull attempt to bridge the gap. That is to produce an
Engine of modern technology yet retain the basics, as near as possible,
to the traditional power and torque requirements and yet retaining the
direct drive principle. To this end the Jabiru 3300 cc-- 120 hp, is
approximately similar weight to a fully equipped Rotax 912. The Jabiru
2200cc 80 hp being 50 lbs lighter than a fully equipped 912.
With the advent of Global Marketing and the Internet, the US market
place is now able to take full advantage of proper competitive
marketing, backed by factory warranty (two hundred hours or one) year
and parts service. Presently I am able to deliver these engines to most
Customs destinations Worldwide (excluding UK) Current prices are:-
Jabiru 3300cc 120 hp @ $9670 US
Jabiru 2200cc 80 hp @ $6630 US
Other products
A large range of FFKits POA
Microair Radios and Transponders are available (with Engine purchases
only) POA
Kindest regards and a very Merry Christmas
Ashley Johnston
Jabiru New Zealand (064) 3 302 7197
The ducting I put on mine FireStar works pretty good. Don't know about sub
zero weather, but with an outside temp of 36, my cabin stays about 70. Of
course this is dependent on how hard the engine is working, and those long
descents can get chilly.
Dave
El Paso
Date: Wednesday, December 13, 2000 3:58 PM
Subject: Re: Kolb-List: Cockpit Heater
for a long...long time...
>Mike and Gang:
>gasoline. :-(
>break my airplane.
>Take care,
>john h
Of
> Dave
Dave and Gang:
Wouldn't that be true for any type of heater being driven by
an air cooled engine?
The 912 cools off fast at power settings below my normal
cruise of 5,000 rpm. However, if what my buddy John Russell
says is true, then that little electric vest will be
efficient at all power settings, if it doesn't electrocute
me.
Hey Gang
I feel like I know all you guys on the list, I have been lurking out
here
for probably over a year. I fly a 912s slingshot out of NW Georgia, I am
by nature, a cold natured person, I wanted to fly some this winter, so I
looked at some options as far as a heater, what I ended up with is the
electric vest John Hauck has mentioned. It's kinda pricy, but this is one
of the best investments I have made. What I wear on a day that is around
20 deg., I wear the vest over a sweat shirt then I will wear a light weight
jacket (windproof works best to help hold heat in), the heated vest actually
helps warm the blood, keeping my feet and hands warmer than if I did not
wear the vest. Before I had the vest, I would bundle up with layers of
clothes
to keep warm, almost to the point it was hard to manuver my body around.
I looked at heating the cabin, which would be nice, but for me I really did
not
want all the added stuff required to have heat. Oh well, I just felt
compelled
to share my experiance with the vest.
John R
The site I found the BMW engine info is
"airdale.com/bmw_engines.htm". The person to contact is Steve Winder
In a message dated 12/14/00 11:11:11 AM Central Standard Time,
hp2693(at)netzero.net writes:
From: | "Richard Neilsen" <neilsenr(at)state.mi.us> |
I have been considering ALL my options and have considered the BMW engine, it looks
real good. It is a proven reliable engine in a motorcycle. There are a few
other sites that have a reduction unit that is designed for this engine. They
will sell a complete package including a prop. The final concern that changed
my mind against the BMW is that it would be a engine that would need to run
at high RPMs and power kind of like a Rotax 2 stroke with twice as many moving
parts. The BMW in a motor cycle doesn't see high RPM and power for any lenght
of time. It MIGHT be a reliable engine in this mode but would I be any happier
with a screaming 4 stroke than I would be with a screaming 2 stroke???
I'm currently looking for a reduction drive for my VW that will allow me to turn
the same 2500-3600 engine RPMs but turn a three bladed 72" prop at app. 2000
RPM.
Rick Neilsen
VW powered Kolb MKIII
Lansing Michigan
>>> hp2693(at)netzero.net 12/14/00 12:11PM >>>
> From: John Hauck <hawk36(at)mindspring.com>
> Date: Thursday, December 14, 2000 7:32 AM
> Of
long
> > Dave
> Dave and Gang:
John and gang,
Well it would be true if the heater is powered by the outside air going
over the muffler. However the one that I built is powered by the belt
driven fan that cools the cylinder heads. That does not stop even when the
engine is idled. It is slowed but still not stopped. As for the vest, I am
sure that it is a great help, and if I lived in the deep south I am sure
that it would be enough. My poor ole butt and legs get pretty chilled even
if the rest of me is warm. More than once I worried that I would be too
stiff to make my landings properly. I just picked up a "Dr Shoals" back
massager with infra red heat. I intended to give it to the "ole Lady" for
christmas, but am at the moment reconsidering. It is 12 volt and might be
handy if the stewardess was too busy to give me a inflight massage.
Larry
The fella that is sort of my flying mentor has been working on a RV 4,
putting the finishing touches on it. It is almost completed, and is going
to be a beauty. Anyway the subject of a swr meter to check his radio came
up. He wanted to use the meter that the Railroad uses to check it. That was
not possibile, so I got a chart for him on what lengths to cut the antenna
for which ever freq. he wanted. What is new about this discussion is the
antenna that he got from Aircraft Spruce. It is a copper strip that has a
conector on it that is applied like a piece of tape to the bubble of the
cockpit. You just cut it off with a pair of scissors, tape it where you
want and you are in business. For instance 22 1/4 for 124mhz which would be
the center of most of the aircraft freq. here. If the reception on the
ground and in the garage is any indication it will serve him quite well. Oh
I almost forgot- cost is $12.00
Larry, Kfalls,Or
> Larry
Larry and Gang:
Living in the "Heart of Dixie" is the reason us southern
boys need all the heat we can get. We're accustomed to
living a leisure life in cut-off Levi's, T-shirts, and going
bare footed. Then when the temps get down in the 30s and
40s we can't hardly stand it. So you see, we have to have
more heat than you pop-cycles from up North. :-)
Seriously, I think age has something to do with it also.
I have no reason to doubt John Russell's report on the
Chilli Vest. If he says it works when it is cold, then by
golly it works. That's why I broke my piggy bank and got me
one too. Although I have not had a chance to use it, I look
forward to the day I can, and I hope the weather is still
cold. If I am too late for cold weather when Miss P'fer
gets going again, then I will have to do my testing above
the Arctic Circle this summer.
That is, if I make it that far. :-)
I think it great that everyone is coming up with ideas and
fabricating equipment to make our sport more enjoyable and
to increase the amount of time we can fly comfortably.
Nothing worse than sitting in the cockpit of ones little
airplane, so cold you can not possibly be enjoying all the
crystal clear, smooth air, because your feet are numb and
the feeling is long gone from the "pinkies."
You all have come up with some good ideas for both aircooled
and watercooled systems. Do not get me wrong. Just because
I don't run over to the hangar and put one on my airplane
does not mean I am knocking your particular system. If I
ask questions that have not been answered, same thing. Not
trying to shoot you all down. Want to find out more of what
you have going.
I personnal have all the "stuff" I want on my aircraft.
John Russell found the Chilli Vest, did a little testing and
told me he was happy with it. I like the idea, primarily
because it was simple, extremely small, required the
connection of two wires to the aircraft battery, and output
could be controlled. I did a simple test in my cold
basement after I got mine. Hooked it up to an ATP Red 5 amp
battery with digital multimeter attached. After aprx 30
mins, most of it at max power, the little battery had
dropped aprx .5 volts. I think my electrical system can
handle that. The vest is very thin, light, and not
noticeable while wearing. You all will be the first to know
if it doesn't work as advertised when you hear my teeth
chattering from Alaska next summer. BTW: The Chilli Vest
is designed to be worn while riding motorcycles. The
designer and the vest are from GB. Not the best weather in
the world. If it works on a bike, it should work well
inside an enclosed cockpit.
Don't ever forget, experimental is the name of our game.
That is what it is all about.
>golly it works.
Just got mine this afternoon.
Will test it Sunday - after the rain stops.
Looks really neat. Feels great, weighs nothing.
Thinking about getting my Dad one for Christmas. I hate to see him on his
tractor cutting grass, like last winter, all bundled up and suffering while
cutting his five acres. And besides he is as old as "Hawk".
> possum
Possum and Gang:
Alright!!! We are gaining ground. Now we have three Chilli
Vest Converts.
OK. All the Chilli Vest gang over there. Aircooled
(heated) guys over on the other side. Watercooled (heated)
dudes back over there.
Anybody know who is winning? whining? hehehe :-)
With all this product development and testing, we should all
stay warm this winter, I hope.
PS: One good thing. Everybody knows we will get a valid
test report from unbiased Possum whose Dad is almost as old
as I am.
>as I am.
That's right!
P.S. I always looked up to you as a "Father" figure.
BTW: They are already sending "me" the AARP mailings.
You can fabricate a heater in an evening if your engine is fan cooled. It
doesn't affect cyl head temps more than 30 degrees or so. Just make a
collector to fit over the cooling air exhaust ports on top of the shroud next
to the holes for the spark plugs (on a 503 anyway).My collector terminates
into a 2" tube (brass "P" trap left overs) facing forward with 2" scat tubing
from there down inside the cockpit past the seat on the floor ending at my
left heel.Thats about 6ft of tubing but it still feels warm to the touch even
on 10 degree days. If you get creative closing up the cockpit you can fly
without gloves on.G.Aman FS2 W/heat
Subject: | Cabin heater #5 , is that hot enuff for you.... |
OFFICIAL RULES OF THE AIR
1. Every takeoff is optional. Every landing is mandatory.
2. If you push the stick forward, the houses get bigger.
If you pull the stick back, they get smaller. That is,
unless you keep pulling the stick all the way back,
then they get bigger again.
3. Flying isn't dangerous. Crashing is what's dangerous.
4. It's always better to be down here wishing you were up
there than up there wishing you were down here.
5. The ONLY time you have too much fuel is when you're on
fire.
6. The propeller is just a big fan in front of the plane
used to keep the pilot cool. When it stops, you can
actually watch the pilot start sweating.
7. When in doubt, hold on to your altitude. No one has ever
collided with the sky.
8. A 'good' landing is one from which you can walk away. A
'great' landing is one after which they can use the
plane again.
9. Learn from the mistakes of others. You won't live long
enough to make all of them yourself.
10. You know you've landed with the wheels up if it takes
full power to taxi to the ramp.
11. The probability of survival is inversely proportional
to the angle of arrival. Large angle of arrival, small
probability of survival and vice versa.
12. Never let an aircraft take you somewhere your brain
didn't get to five minutes earlier.
13. Stay out of clouds. The silver lining everyone keeps
talking about might be another airplane going in the
opposite direction. Reliable sources also report that
mountains have been known to hide out in clouds.
14. Always try to keep the number of landings you make equal
to the number of take offs you've made.
15. There are three simple rules for making a smooth landing.
Unfortunately no one knows what they are.
16. You start with a bag full of luck and an empty bag of
experience. The trick is to fill the bag of experience
before you empty the bag of luck.
17. Helicopters can't fly; they're just so ugly the earth
repels them.
18. If all you can see out of the window is ground that's
going round and round and all you can hear is commotion
coming from the passenger compartment, things are not at
all as they should be.
19. In the ongoing battle between objects made of aluminum
going hundreds of miles per hour and the ground going
zero miles per hour, the ground has yet to lose.
20. Good judgment comes from experience. Unfortunately, the
experience usually comes from bad judgment.
21. It's always a good idea to keep the pointy end going
forward as much as possible.
22. Keep looking around. There's always something you've
missed.
23. Remember, gravity is not just a good idea. It's the law.
And it's not subject to appeal.
24. The three most useless things to a pilot are the altitude
above you, runway behind you, and a tenth of a second ago.
Gotta Fly...
> Remind us where you purchased the vest. There may be other > converts.
Michael and Gang:
Try this url:
http://www.sargentcycle.com/ChilliVest.htm
Has all the info on the vest, to include prices and ordering
info. I ordered mine one day, and a day or two later it was
here in Alabama. They are shipped out of Jax, Florida.
> but if I remember
Snugger than you know...the .001 should be .01 and is mm, not
inch, so that works out to .00039 inches. Squeek! At least that's
what Rotax advertises in the engine's literature.....
If the growth rates can be kept together clearances need not be too
far apart. Lyc and Cont both use a steel cylinder and an alum
piston so rates are not as controlled as with similar metallurgies.
J.Baker
Subject: | General Information |
I created a Web-site to let builders and those interested in airplanes
enjoy a few minutes. I intend to keep creating on this site using photos
and information furnished by you people. I am also creating a 3-ring binder
of this information in various categories, which I will also give those
interested. There is not money involved in this site. I created it on a
free server, and I will update it when new information is received.
Let me know what you think about it, and how might I improve it to make it
more interesting.
Just thought of a good addition to the site. A category for pictures of all
the members of this list. By your airplanes, or projects, or just by
yourself. I know I would like to see who I am talking to.... even though it
is over the internet.
http://jgw300markiiixtra.homestead.com/Introduction~ns4.html
Julian Warren
Eugene, Oregon
> J.Baker
Jim and Gang:
This info is straight from the shop manual:
Piston to cylinder clearance (new) 0.000 to 0.020 mm
0.000 to 0.0008 inches
Wear limit is 0.13 mm
0.005 inches
Date: Thursday, December 14, 2000 1:38 PM
I'm building a Firestar ll with a Rotax 503 DCDI and need some advice on
instruments. Do I use a dual EGT or is a single ok? If single which
cylinder is the best location for the probe? How long of a probe lead do
I need to get to the panel? On tachs-- does the Rotax have the "Ducatti"
ignition? Hope someone can straighten me out on this. And hey, the
weather in Lakeland has been brutal too. 86 deg. on Monday--can you
frigging believe that?
isn't finished yet , (kit # 2 was just shipped.......Yippie !!!! )
> Well, Gotta Fly...
> From: "larrybiglar"
> From: "slyck"
In the Challenger family many use the ultra simple (and cheap) "Zank
heater". Simple 4" dryer hose(s) stuffed (and safetied, of course) into
the air outlets of the 503 and run forward to the cabin. Works great,
and many in our area fly all winter.
gil leiter
MAPLEWOOD, MN
Did those of you that are interested in engines,
notice the post from Ashley Johnston on Thursday?
I know the list is growing tired of my questions and
request for engine recommendations but "I just can't
decide!"
I have been interested in the Jabiru since seeing it
at the Kolb fly-in. I was a little pushed back by the
price however. Ashley's price is around $6600-6700.
That is reasonable for me!
I actually called him and had a very pleasant and
informative conversation with him.
He is in New Zealand and can be reached by dialing
011-643-302-7197.
Who is the "guy among us" that already has a Jabiru?
I remember that he had a full tholtle problem after
takeoff and suggested some changes, I would like to
get his opinion now that he has the bugs workee out.
Ed Mills
Mk-3/xtra
Dallas Tx.
Subject: | Re: General Information |
Sent: Friday, December 15, 2000 12:53 AM
Subject: Kolb-List: General Information
binder
> more interesting.
all
it
> Julian Warren
> Eugene, Oregon
75r,
My first recommendation would be the EIS. If you don't want an EIS, the at
least get dual EGTs.
John Jung
75r wrote:
> From: 75r(at)msn.com
> snip.....
From: | "Kottke, Dwight" <dkottke(at)scherping.carlisle.com> |
I'm new to this site and I'm not sure how someone is to post a question,
so I'm just going to give it a shot.
I have a Firestar and I'm looking for plans for a total enclosure and how
to fab my own ski's. Can anyone help?
Sent: Friday, December 15, 2000 8:14 AM
Subject: Re: Kolb-List: General Information
binder
> more interesting.
all
it
> Julian Warren
> Eugene, Oregon
Subject: | Re: Jabiru engines |
> Ed Mills
Ed and Gang:
Couldn't find any info on Ashley's Jabiru Company. What is
his background? How about his relationship with the Jabiru
Factory? How does he and the US Jabiru rep interface? If
you have a warranty problem, will Ashley take care of it in
NZ or is the US rep gonna take care of you?
A few questions I would want answered if I was considering
an engine purchase from Ashley.
From: | "Dallas Shepherd" <cen23954(at)centurytel.net> |
Hi Ed Mills:
I'm the guy with the Jabiru 2200 that had the throttle problem. I doubled
the fastener's on the throttle cable. A new end, and then drilled the end
of the bolt the throttle cable passes through, threaded that and put a screw
in to hold it. I like my jabiru very much, even though I never had any
trouble with the 582 in 105 hours with it. I'm just not mechanic enough to
tinker with the two cycle engines that seem to need a lot of tender loving
care. I feel more secure with the four cycle over this very rough terrain I
live in. Its beautiful, but very few places to set down. The eighty horse
engine gives me a lot more torque and more power all the way around. I have
a 1300 foot grass strip with trees and power lines at the ends and hot
summer days with two people made it kinda hairy on take offs. The jabiru
handles this much better. I have about fourty hours on it right now. The
don't likes on it is the carbrurater set up. It only has one clamp to hold
all that weight up. I noticed on the Kolbra at the Kolb fly-in that they
had a different set up and used two clamps. Mark at Jabiru West was there
and said he would send me a new coupling, but I never heard from him. He
did give me a hat and shirt. I would like to have the new coupling. I
safetyed the carbrurater on with wire holding it in, and up. Others have
said they didn't have a problem in this area, but mine fell off, while on
the ground, and it was hard to keep it in place. Safty wire cured that.
The other thing is reading the oil dip stick. Its hard to see and you need
the Kolb in a level position to be correct. When you fill it to the max
line, it blows it out , so I keep it a little low. I see you live in Dallas,
Texas, why did you forget me.
Dallas Shepherd
Norfork, Ar.
Mark 3 with a Jabiru
Welcome to the list Dwight! You might want to search the archives, you
might come up with something. What model of Firestar do you have??
Dennis
http://www.aero-sports.com/bb
----- Original Message -----
From: "Kottke, Dwight" <dkottke(at)scherping.carlisle.com>
Sent: Friday, December 15, 2000 10:48 AM
Subject: RE: Kolb-List: General Information
how
> From: Howard Ping [mailto:howard.ping(at)gte.net]
> From: jgw300 <jgw300(at)netzero.net>
> To:
photos
> binder
a
it
> > more interesting.
> all
though
> it
> > Julian Warren
> > Eugene, Oregon
For all you guys that like to tinker, has anyone thought about using propane
or LNG for an UL engine? Of course it what have to be a 4 stroke or would
it? Do you think oil injection would work? I wonder what the burn rate
would be and how long would the 5 gal. of propane or LNG last.
Dennis ( yep I followed a truck on base today that ran on LNG)
It was built in 1992, has a 377 Rotax on her. I bought it used this summer
and now have 22 hours on it. It's now time for a canopy and some ski's so I
can continue to fly. It's getting cold and snowy up here in Minnesota.
P.S. I've been told by other Kolb owners to get ride of the wood prop on
it. Any suggestions for a better prop? Also looking to upgrade to a 437 or
503.
Sent: Friday, December 15, 2000 11:50 AM
Dennis
how
> To:
photos
> binder
a
it
> > more interesting.
> all
though
> it
> > Julian Warren
> > Eugene, Oregon
Hi, Dallas, I read your message and I'm wondering if you still have your
old 582 sitting around gathering dust. I'm looking for one to upgrade to.
From: Dallas Shepherd [mailto:cen23954(at)centurytel.net]
Sent: Friday, December 15, 2000 11:23 AM
Subject: Kolb-List: Jabiru
Hi Ed Mills:
Dallas Shepherd
Norfork, Ar.
The Jabiru post got my interest also. Does anyone know what kind of thrust this
engine would produce on a Kolb???
The reason I ask is my 75HP direct drive VW turning a 60" prop produces a unacceptable
150lbs. of thrust. The same engine with a reduction drive turning a slow
turning three bladed 72" prop is reported to produce 300+ lbs of thrust. Another
VW turning a slower turning 84" two bladed prop does get 400+ lbs. of thrust
'I have seen the result".
December 01, 2000 - December 15, 2000
Kolb-Archive.digest.vol-cn
