Kolb-Archive.digest.vol-da
July 25, 2001 - August 06, 2001
> Jim G
I knew this guy and he just completed his Singshot this spring, so he is
a relatively new Kolb pilot. I cannot imagine what might have happened
other than his engine may have quit (please see my post on emergency
deadstick landings).
My heart goes out to his family.
Ralph Burlingame
Original Firestar, w447
Subject: | Re: Emergency Landing Practice |
May I make a suggestion?
To practice dead-stick landings pull the engine, slowly, back to idle. Do
NOT turn off the engine. While engine off and engine at idle are not the
exact same thing, they are close enough to practice with. If you turn the
engine off and misjudge the distance, and then can't get the engine to
start, you may be buying new landing gear, to say the least. Please, leave
the engine running. Think to yourself, "Is this a good idea?".
Larry Davis
----- Original Message -----
Sent: Wednesday, July 25, 2001 8:40 AM
Subject: Re: Kolb-List: Emergency Landing Practice
> > Made it out to the airport last week just in time for a hole in our
> > other wise continuing poor weather. The ceiling was down to 1200' and
> > there were no breaks in it so three of us had to be happy with trips
> around
> > the pattern. I was sharing the air with a Champ and a Quicksilver. We
> were
> > all radio equipped so it was good practice in talking, listening,
> > watching and flying. After a few trips around I decided to try a
> simulated emergency
> > landing. The plan was to pick a spot on the turf, reduce the throttle
> to
> > 3,000 RPM, pretending that the engine had died and that the spot I
> picked was
> > the only one available. I was astonished to see how my skill at doing
> > this trick had deteriorated. On the first try the wind made my turn to
> base
> > too late and I had to do some heavy corrections on the final. On the
> > second attempt I was ~ 100' beyond my intended touch down spot. I was
> > humiliated but enlightened. The learning curve came into play and I
> finally
> > made an "8" on the third try. The point is that you can get rusty very
> > quickly on even these very basic maneuvers. No it ain't "like riding a
> bike".
> > Approach stalls have killed many aviators and approaches without power
> > are a very special case. You can bet I'll be doing more of this and
> other
> > such drills a little more often.
> > Duane the plane in Tallahassee, FL, FireFly SN 007, 447, IVO, ~ 100
> > Hrs.
> Duane and others,
> Now you know why there are so many Kolb pilots that bite the dust without
> that kind of practice in a real emergency. Now couple this with some
> panic and white knuckles and you have a recipe for disaster.
> Those practice emergency deadstick landings that you did were great, now
> you might try them under actual conditions by shutting down completely.
> It's still another ball game and after you are successful at doing that,
> it will actually be fun. No kidding.
> I suggest you first shut down the engine on final when you know the
> runway is made, then work your way out a little further each time at a
> higher altitude. Before you know it, you will be a half mile out or more
> and having fun being a glider.
> There are so many Kolb pilots in all their years of flying that have
> never practiced gliding their Firestars in without power. These are the
> guys that will have problems when the real emergency strikes.
> Ralph Burlingame
> 14 years in a Firestar
Just be over a big field (grass if you've got one handy) and make sure
anyone coming in knows what you're doing before you do it.
Helps to have someone on the ground with a radio if you dead stick in
from up high. I've cut my engine off at 11,000 ft MSL
(10,400 AGL) and had a ball gliding down...and no, it doesn't fly
the same at idle.
Subject: | Emergency Landing Practice |
the same at idle.
Shut down at 7000' agl about 8 miles away from field...was gonna restart at
the field or 2500', whichever come first. Was right over the field at 2700'
and just decided to shoot it, deadstick. Glided the pattern and slipped it
hard to spill my extra altitude at the last minute...
I'm glad I did it, cause it is NOT the great unknown anymore...if the Rotax
ever gets quiet, I'll deal with it and go on. But this is definitely a
subject that has 2 sides and I respect the opinions on both...
Jeremy Casey
jrcasey(at)ldl.net
From: | "Gary r. voigt" <johndeereantique(at)uswest.net> |
Subject: | Re: bad news for a Kolb driver enroute to OK... |
I first met chuck at the fathers day flyin at stanton this summer, he
had mentioned to come down anytime and fly with him. I,am sorry i never got
the opportunity. we will truly miss him. my heart also goes out to his loved
ones---
Gary r. voigt
Excelsior, mn.
Jim Gerken wrote:
> I am very sorry to hear about this, and my condolances to any of you who
> knew the man...
> http://www.winonadailynews.com/news/1.php
> Jim G
writes:
> idle. Do NOT turn off the engine. While engine off and engine at idle
are
> not the exact same thing, they are close enough to practice with. If
you
> turn the engine off and misjudge the distance, and then can't get the
engine
> to start, you may be buying new landing gear, to say the least.
> Please, leave
> Larry Davis
Larry and others,
Sure starting out, it's a good idea to bring it back to idle and practice
these landings. But after you have the confidence and practice, the
actual deadstick landings are necessary because when the real emergency
happens, there will be no restarts or pushing the throttle forward to go
around.
The plane does handle different than at idle and remember we are flying
light aircraft not heavy GA planes so deadstick landings are easy IF they
are practiced.
Like Possum, I have gone out a mile and a half from the field and at
2600' agl, shut it down and glided back for a nice touchdown. This takes
practice, but it does make you a much better pilot.
In earlier years, deadstick landings were a natural thing and a skill
that we don't practice as much today because our engines are more
reliable now.
I think it's wise to hang on to this skill and use the boy scout motto,
"Be Prepared"
Ralph Burlingame
Original Firestar, w/447
I also have tried a couple of dead-sticks lateley from 800' & 2200" AGL. My
2 cents is that if you practice them at idle versus prop stopped, I would
add at least 5 mph to your approach during the real thing. Not having the
prop at idle really makes the flare mushy at normal approach speeds. Also,
If you are in a Firestar II with a passenger, I'd plan on adding another
10mph!
Kip Laurie
Firestar II
Atlanta
Subject: | Re: Kolb-List Digest: 07/24/01 |
>>Does any body have the vibes with the
>>more expensive gearboxes with the rubber dampeners? ? . Or belt drives?
>>? Ed in Western NY
Ed, Group:
I have ran 3 diffrent engines on my FS (Cuyuna ulII o2 , 2si 460 f-40 with
2.65:1 box, Hirth 2402 with 2.29:1 box) with the same 64" warp 2 blade
prop, and I believe most of my vibration is engine related. The Hirth runs
with more vibration, but it has more displacement 460cc. vs. 521cc.
Has anyone had any experience with the dynamic balancers that bolt to the
flywheel? Do they work?
Darren Smalec, FS1, Central MI.
Ed. I have looked at the WalMart "aircraft approaved" cable also but
all of the ones I saw, including the ones at the local farm store that
said "aircraft approaved" were galvanized steel. Every aircraft I have
owned had stainless steel cables. I would not use galvanized steel
cables in anything I am sitting in above the ground and our local AI
agrees. For just a couple of pennies more a foot, you can get
stainless steel cable from some of the suppliers like Lockwood or
L.E.A.F. and be sure of its reliability and higher strength. Bob
I changed and went to the next size larger diameter FAA
aircraft approved Wal-Mart cable....No joke,it is aircraft cable from
Wal-mart. Ed in Western NY
From: | "williams brett" <dbwilliams52(at)hotmail.com> |
Reply-To: kolb-list(at)matronics.com
To:
Date: Wed, 25 Jul 2001 09:06:02 -0500
-- Kolb-List message posted by: "Larry Davis"
My two cents,
I'm usually a spectator on the list, however, sometimes I feel compelled to respond.
It's never a good idea to shut down a good engine inflight, especially
if you only have one(all kolbs that I know of). A windmilling propeller actually
causes more drag than a stationary propeller, so you are going to be pretty
close to the deadstick performance or worse with the engine idling. I don't know
of any flight instructor that would suggest you do a dead stick landing for
practice. I've heard some of the guys at the local airport say some of the same
things that I just read on the list. I fly a large multi-engine military propeller
driven aircraft and when we simulate an engine out we actually have higher
Vmc speeds due to the excess drag from a windmilling propeller. I believe
that you are creating an undo risk versus any benefits gained by doing actual
engine-outs in Kolb type aircraft.
writes:
> I believe that you are creating an undo risk versus any benefits gained
by doing actual
Hey Brett,
A light Firestar is nothing to compare with a big airplane and shutting
down the engine is not risky business IF you have a safe place to put it
down.
Glider pilots make every landing deadstick, so why do ultralight pilots
have such a difficult time accepting this as a normal part of their
training? I believe it's because we are not used to shutting down a
perfectly good running engine. It almost seems absurd to do this, but
what will you do when that perfectly good running engine goes silent?
Will you have the necessary skills to save your bacon? Maybe not if you
haven't practiced for it.
Most airplanes can glide, it's up to the pilot to make it glide down to a
safe landing and not fall down and hurt yourself. Am I preaching to the
choir?
It's easier if it's practiced, a real headache if you haven't.
What are you going to do?
Ralph Burlingame
Here's my $.02 on this subject. My instructor forced me to do several engine on
idle landings when I was learning. Definitely important to keept the engine running
during training. Although its not technically "dead stick", but its the
closest, safest thing you can do to practice this. And as we read today, we do
need practice at this. Fortunately, I takeoff from an area that has a large
dry lake bed 20 miles away that is prime for actual "dead stick" landings. I
love that place. The lake bed is like having a landing strip that is infinitely
wide. When I know I will be flying over it, I climb to 10k then shut it down
all the way. Gliding down 5000 feet with no power is UL flying at its best. Then
after the ititial landing. I mark out a "mock" landing strip with my tire
tracks, and to 3 or 4 dead stick landings, trying to nail the numbers. I never
have nailed them. Usually end up slipping and then having too much airspeed to
put it down on the numbers.
One thing to be aware of, also, when dead sticking a taildragger, is that you will
loose control on rollout, when the plane gets to somewhere around 20 mph on
the ground. Landing into the wind will help this, but your real emergency landing
on a dirt road, or wherever selected will not likely be pointed into the
wind.
B.J. Moore, P.E.
Circle Four Farms Development Engineer
ASC Basic Flight Instructor - "The Flyin Moose".
Subject: | Mk-3 Verner install photos |
Hi gang,
I put up a primitive page with some pix of the Verner installation. There a
few minor glitches to be worked out such as determining the "proper" location
for the oil tank. However, it is coming along.
VernerMk-3
Bill George
Mk-3 - Verner 1400 - Powerfin 72
Subject: | Re: Firefly Starting Problem |
Replacing something that worked over time always scares me because I got
something I developed confidence in and am replacing it with a total
unknown that may not last two flights. There are things that wear, get
abused, kicked, what ever, that need to be replaced. Switches though seem
to run in batches, good or bad. Which lot does the replacement fall in?
>I performed my very first unplanned deadstick landing due to a shorted
>on/off switch. I was about 500 ft agl over a very healthy cotton field
>when a smooth running engine spun down to silence. It wasn't in my Kolb
>with the cheap and simple toggle switch, but it happened in a Quick with
>one of the $80 three position switches. It was something that you couldn't
>exactly check for in preflight. Never one hint to the pending failure.
>Might be a good idea to replace it every 100hrs or so.
>Bob
> >Kolbers,
> >Wanted to share today's experience with the engine refusing to fire. Don't
> >want to bore you with the troubleshooting details but the problem turned
> out
> >to be a defective on/off switch. Finally cut the wire and the engine
> >started. Sure was surprised that this was the problem.
> >Gene Ledbetter
> >Cincinnati, OH
> >Firefly 00-2-00018, both canopies, big wheels and brakes, Ivo 2 blade
From: | "Beauford Tuton" <beauford(at)tampabay.rr.com> |
Mr Veith has been a regular on the Kolb list since I first got on it back
in '98... I recall seeing his posts and comments from time to time...he was
one of us... I am saddened with his passing... We have all lost in this...
Beauford
From: "Gary r. voigt" <johndeereantique(at)uswest.net>
Sent: Wednesday, July 25, 2001 11:00 AM
Subject: Re: Kolb-List: bad news for a Kolb driver enroute to OK...
got
loved
> ones---
> Gary r. voigt
> Excelsior, mn.
> > knew the man...
> > Jim G
Try using acetone on two scrap pieces to test it. You can by it by the
quart in paint section or hardware store. It should bond it together real
nice.
>In a message dated 7/19/01 2:56:57 AM Eastern Daylight Time,
>biglar(at)gogittum.com writes:
> > Did anything ever come of this ?? Sure would be nice to know how to glue
> > that stuff. Lar.
>Lar, I sent the following info to William Herren:
> WELD-ON
> 3
> IPS Corp.
> P. O. Box 379
> 17109 S. Main St.
> Gardena, CA 90248
>Sorry, no web site or phone # on the can.
>My friend, Chuck, says the stuff makes a very strong joint. It's thin and
>should be applied with a syringe.
>Howard Shackleford
>FS I
>SC
Subject: | Re: Mk-3 Verner install photos |
Couldn't open it, Bill. It said, "Sorry, can't find that page."
Larry Bourne
Palm Springs, Ca.
Kolb Mk III - " Vamoose"
http://www.biglar.homestead.com/larry.html
Sent: Wednesday, July 25, 2001 3:43 PM
Subject: Kolb-List: Mk-3 Verner install photos
> Hi gang,
a
location
> VernerMk-3
> Bill George
From: | "richard swiderski" <swiderskir(at)earthlink.net> |
Subject: | Re: WalMart wires |
Bob & all,
I too thought stainless was better, but I found out that stainless is
much more brittle & it will fray around pulleys quicker. Unless you are
flying out of salt water, steel cable is a better choice for our
application, especially the UltraStar which has several sharp bends around
small pulleys.
...Richard Swiderski
Sent: Wednesday, July 25, 2001 3:35 PM
Subject: Kolb-List: WalMart wires
Ron,
I have a ICOM A22 - It works find no problem with LCD - If your shopping I
would suggest you check two places. I got mine from Hart Aviation (look it
up on Google). I also done business in the pass with Gulf Coast Avionics
used to be in Tampa.
The thing about the A22 is your can disconnect the battery and it only
about 4-5" high. Warning about Delcoms, I understand you have to use there
special head set adapter. Verify everything I say before you spend you
money. I have a King KX100, I like it the best but its to big for the UL
and only supports an external tickle charge. You can't run it without the
battery and the battery can run down faster than it charges if theres much
traffic on the air.
The A22 when I got mine came with head set adapter. It plugs into the top
of the radio. You could panel mount the head and make up a harness with
panel jacks. Don't forget a push to talk button. You could wire that into
your stick and it connects to a pair of the contacts on the mike jack. The
head set adapter that comes with the radio provides normal size mike and
earphone jack to mate with a headset. It also has a miniature jack to
connect an external push to talk switch. I used the headset adapter in
both our Kolb and our Hawk.
There is another choice out there called Yaesu. Its a new radio on the
market and like ICOM they've been building hand helds for amateur radio use
for years.
Here's a little important thing, if your thinking about using the push to
talk on the side of the radio along with a headset, be aware that on some
(Yaesu) while it will key the transmitter, it opens the mikes on both the
radio and the headset which degrades the quality of the audio due to
additional background noise it picks up.
If you settled on the Delcom you should be able to buy a used one on good
shape and save some bucks. Many buy that radio and then want to sell it
and get another due to the head set adapter issue. I agree with the tray
feature it makes it nice and it may work well for your application. If
you need batteries might I suggest you check out Batteries America. They
sell new batteries and also chargers.
http://www.batteriesamerica.com/
http://www.hartaviation.com/
http://www.gulf-coast-avionics.com/
jerryb
>Beginning to look like Icom is the only game in town. I don't like
>LCD's in bright sun light but I may be old fashioned. Could anyone give
>me the pro's and con's of the IC-A23 Vs the IC-A22. The 23 is only
>about $40.00 more than the 22. I have heard some rumors that the 23 is
>having a few problems. Any one know anything about this? If I go with
>just a com unit, the A-5 has been recommended as the way to go by Larry
>Davis so I guess that would be my choice unless I go with a nav-com.
>Then it is between the 22 and 23.
>Ron Payne
Subject: | Re: repair facility |
While I can't comment directly on experience of using there repair
facility, I did visit their facility and was given the dollar tour. I
found it to be clean and well organized, the staff was very friendly and
courteous, and the Rotax repair techs have been available to answer
questions when I working out a problem with a new engine that came from my
kit manufacturer. Most importantly there staff impressed the most.
While at S&F in 97 I talked to Miss. Aircraft who were manning the Rotax
booth. I also found them to be very curios and knowledgeable.
From business experience I have less confidence in Leading Edge or CPS.
Good Luck.
jerryb
>Dave,
>I just flew down to Lockwood Aviation in Sebring Fl., not sure where
>you are, but was 154 miles from me. They are good workers, and very
>knowledgeable. Phil Lockwood has 18 years in that business and really
>easy to work with. Although a complete rebuild sounds like a lot to
>us, to them it is routine. If you were in the mood to fly down there
>they can slip you in their big hangar and do it all in one day. Or, I
>guess two days with travel. I just got a top end job, and did the
>piston run-in work there in the air around them before I left. I
>helped Shane while he was going between jobs (since they didn't plan on
>more than 2 hours for me) so got a lot of hands on work myself. My pal
>they call the "G-man" works there, and he can help drive you to the
>motel nearby if you stay there ($75/night for Lockwood customers, 2
>nights for $99).
>Other u/l guys just pull the engine from the plane and drive it there
>in their trunk. That will also only take a day. The service shop time
>costs $65 / hour. Call them at 863-655-5100 to talk to Phil or the
>girls and schedule shop time.
>Write or call me for more talk. 386-937-0541
>John & Lynn Richmond :-)
>Palm Coast, Fl.
>Mk3 269LJ, 582, 28 hrs
>958 miles, longest=171
This is an interesting post.
We have two UL's, one a Kolb FireFly and the other a CGS Hawk. Both have
Rotax 477 engine, the Kolb a 66" 2-blade IVO and the Hawk a 64" IVO. They
produce completely different characteristics. The Kolb EGT's want to shoot
up during descent and gets lower fuel consumption than the Hawk. The Hawk
EGT's hold pretty well normal regardless of decent or cruise but appears to
have a little high fuel consumption per hour. Both engines carbs are
jetted the same.
jerryb
>I totally disagree. You want the engine running a little cooler at full
>throttle,
>and a little warmer at cruise. The cooler temps at full throttle enhance
>reliability. The hotter temps at cruise keep the formation of ring mung and
>carbon at a minimum, and improve fuel consumption.
>Setzer's temps are about ideal for safe operation.
>Richard Pike
>MKIII N420P (420ldPoops)
> >Dale Seitzer 447 wrote: > I see 1000 degrees on takeoff, 1100 on cruise and
> >1200 on descents. I do adjust the needle one slot in winter and summer.<
> >Wow, this is unusual. The typical setup is opposite of this and I believe
> >(read believe, not know) it is more important to be at around 1200-1250
> >under full throttle and see things cool off a tad when you get into cruise
> >and descent. This means you have your needle and jet needle setup a little
> >leaner than the burn at full throttle. Ideally, from 3/4 throttle up you
> >would operate between 1150-1250. You could stand to lean out the main jet a
> >size and may also have to also richen the needle by lifting it up a notch.
> >1250 is actually the sweet spot for the highest temp, full throttle.
> Then at
> >cruise if you get it between 1150 and 1200, you are set up purrrfectly. But
> >then again, if it ain't broke, don't fix it. This is just unusual in my
> >experience.
> >B.J. Moore, P.E.
> >"The Flyin Moose" - Maxair Drifter
> >Milford, Utah
From: | "Ed Chmielewski" <edchmiel(at)mindspring.com> |
Hi All,
I had to send Bill's website to myself, then it seemed to work.
Here'tis.
http://members.aol.com/wgeorge737/VernerUpload/index.html
Ed in JXN
MkII/503
Sent: Wednesday, July 25, 2001 11:13 PM
Subject: Re: Kolb-List: Mk-3 Verner install photos
Larry & All,
Depending on an idling engine to get you out of trouble at the last
minurte while practicing "dead sticks" just might get you into more trouble.
Everything is happening pretty fast & having a cold engine sputter while you
are depending on it to get out of a fix is a formula for some serious
trouble.
The trick is to only practice just at the edge of the envelope you are
comforatable in. Eg., cut the engine when you are on a long runway & only a
few feet off the ground & all dialed in. Then when you are bored with that,
cut it off a little bit higher untill you are at a thousand feet. Then when
you are bored with that, cut it off with one 90 degree turn, & then a 180 &
so on.
The biggest thing is to memorize the glide angle & then it will not
matter how high you are, you will always know about where you will touch
down (assuming no severe wind conditions.) Always use the same airspeed. I
like about 10mph above stall. If the winds are high, use a steeper
glide path & more speed, insuring you have more altittude than you need on
finial. Then as needed on finial, lose alttitude by doing as many S-turns
as needed &/or some slipping. If you have lots of runway, then come in real
hot & fly it into the ground & after contact use forward stick to glue her
down so a gust won't surprise you.
Develope a routine & stick to it strickly- keep all your variables
constant & always aim for a particular spot & then hone your skills untill
you can hit it every time. If you stay in your comfort zone, carry extra
speed & alttitude with more runway than you need, you will not get into any
serious trouble. Your skill level will improve dramaticlly & you will
greatly improve your odds when (not if) your 2-stroke goes silent & you have
to put it into a tight field with the wind blowing. Instead of fighting
panic, you will be making calm decisions & flying your plane like you've
done many times before. Besides, if dead sticking isn't the purest form of
flying, its at least the purely funnest form of flying. ...Richard
Swiderski
Sent: Wednesday, July 25, 2001 10:06 AM
leave
> Larry Davis
> From: <ul15rhb(at)juno.com>
> To:
> > around
> > were
> > simulated emergency
> > to
> > picked was
> > base
> > finally
> > bike".
> > other
> > > Hrs.
> > Duane and others,
without
> > Ralph Burlingame
Well, you a perty sharp feller, Ed, no matter what they say. Opening your
version worked, so I got to enjoy them, too. Couple of things:
That's a very nice installation, and I sure wish mine was that far along.
Beautiful pictures, too. What kind of camera did you use to take them ??
Have you done a w&b yet ?? I'd be interested in knowing how it came out.
Thanks Lar.
Larry Bourne
Palm Springs, Ca.
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Sent: Wednesday, July 25, 2001 8:18 PM
> Hi All,
> Here'tis.
> Ed in JXN
> MkII/503
> From: Ed Chmielewski <edchmiel(at)mindspring.com>
> To: Ed Chmielewski
From: | "Randy Berry" <sc_bassman(at)hotmail.com> |
Subject: | Kolb Accident On Way to Oshkosh |
I am so sorry to hear of this tragedy ... for the pilot and family ... and makes
me contemplate my own potential fate. I just looked up the places involved
on my MS Expedia. Appears that he had made roughly 112 miles
with about 158 miles to go ... not quite half way. Appears that there were no
major towns or cities (or airports?) on his flight path from St. Peter to Minnesota
City. Wonder how much fuel he had on board .... whether he had a headwind
... and what type engine? What flying experience did
he have overall? In the interest of safety for us all, I'd be interested in hearing
the cause and circumstances ... once determined.
Randy Berry
Kolb Firestar KXP
sn.com
>From: "richard swiderski" <swiderskir(at)earthlink.net>
>To:
>Date: Tue, 17 Jul 2001 01:46:42 -0400
>Larry & All,
>trouble.
>you
>trouble.
>comforatable >
All,
I've had the 447 quit because I let the engine get too cold after a long
idle descent, my learning curve was increased by leaps and bounds. I always
watch the egt on descents and I increase rpm if I feel the temperature is
getting to low and get the egt back up, however, in the landing pattern I
have never had a problem with low egt going to idle in the landing pattern
from rolling off the perch until touchdown. You are not depending on an
idling engine because you should always have the field made anywhere in the
landing pattern, so why cut the engine off? What if a car, cow, deer, other
aircraft, bad approach and a thousand other things occur during your
intentional deadstick. Yes, now you are out of options, you are a glider,
weigh the risks versus benefits. I do this in military flying every day.
My firefly glides like a brick, it's not made to be a glider, if you are
flying a proper pattern you will have the field made if it quits, this is
good airmanship. I always make my landings in the kolb at idle, so I'm
always practicing with no power, again an idling propeller is producing more
drag in-flight because the propeller is attempting to drive the engine so
the performance in-flight is nearly the same as if the propeller was
stopped. You should not shut down the engine intentionally on a single
engine aircraft unless it's doing something bad to you (ie. it's on fire,
severe vibration, and probably many more reasons).
If you fly airmachines long enough Murphy's law will catch you, but
always keep the odds and options in your favor and you might come out on
top. I fly my Firefly agressively but always within my and the aircraft's
limitations. It's the funnest aircraft I've had the priviledge of owning
and flying, it's an aircraft and the same airmanship skills that you learn
as a pilot apply to it the same as any other aircraft. Keep it running.
Brett
From: | "Edward Steuber" <esteuber(at)rochester.rr.com> |
The topic of shutting down a running engine to "simulate" an emergency
is definately not the thing to do.......in a GA airplane ! BUT....we are
not flying GA airplanes. From my own viewpoint with limited experience
in ultralights I am listening very closely to the old "salts"on this
list. My total flight time is considerable and I like to think my best
skill is in careful listening .......others who have flown my Ultrastar
agree that this type of flying is different......more fun ,too! I have
been thinking about shutting down the Cayuna for a simulation , because
flying this engine, I may need the practice for the real thing. In all
fairness to the Cayuna, it has done very well , even when it was running
hot......I may get the courage to shut it down , but not at 10,000 and
four miles out....Easy stages ,first. More like at the runway threshold
at 50 feet as per advice........Ed ...Western NY
From: | "Kottke, Dwight" <dkottke(at)scherping.carlisle.com> |
The fine folks on this list have offered advice on how to repair a ding in
a wooden prop. How about a ding in an Ivo prop?
Dwight Kottke Firestar 377
The Flying Farmer
I use J B weld.
From: Kottke, Dwight <dkottke(at)scherping.carlisle.com>
Sent: Thursday, July 26, 2001 8:27 AM
Subject: Kolb-List: Ivo Prop
in
> The Flying Farmer
Subject: | Deadstickig is dead... |
In the interest of avoiding beating this dead horse some more...let's drop
the deadstick thing. Everyone knows the pros and cons and its now a
personal decision how to do your training...
Next issue.... global warming? What say?
Jeremy
writes:
priviledge of
> owning and flying, it's an aircraft and the same airmanship skills that
you
> learn as a pilot apply to it the same as any other aircraft. Keep it
> running.
> Brett
Hey Brett,
I thought that was very good advice and we should stay well within our
limits of experience and not stretch too far out, otherwise the "real
emergency" could take over.
I will keep this in mind myself because one of the quotes I live by goes
something like this:
"When a pilot thinks he knows everything, the end is not far away"
Ralph Burlingame
Subject: | Re: Kolb Accident On Way to Oshkosh |
writes:
> and makes me contemplate my own potential fate. I just looked up the
> places involved on my MS Expedia. Appears that he had made roughly 112
> miles with about 158 miles to go ... not quite half way. Appears that
> there were no major towns or cities (or airports?) on his flight path
from
> St. Peter to Minnesota City. Wonder how much fuel he had on board ....
> whether he had a headwind ... and what type engine? What flying
experience
> did he have overall? In the interest of safety for us all, I'd be
> interested in hearing the cause and circumstances ... once determined.
> Randy Berry
> Kolb Firestar KXP
> sn.com
Randy and others,
I can answer some of these questions about Chuck Veith's Slingshot.
I met Chuck last fall at the Faribault fly-in and he was very interested
in my Firestar and told me he was building a Slingshot and was close to
finishing it up.
The Slingshot had a 582 (blue head I think) with no modifications except
the IVO prop. Chuck told me TNK didn't seem to know what size prop to
use on it so they sent him a 72" IVO prop.
He had two 5-gallon fuel tanks with a fuel line connecting them on the
bottom. He would fill one and it took 5 or more minutes or more for the
fuel to transfer to the other tank.
At the Fathers Day fly-in at Stanton MN, he started the engine and the
prop would flex enough to strike the rear part of the cage while at idle.
This had happened several times and I told Chuck that he should either
send the prop back for a 66" or cut it down. There was no prop hub
extension and he was considering that.
I saw him again at the Glencoe fly-in about a month later and he cut away
the damaged fabric on lower rear cage where the prop had struck. He did
not modify the prop and it still was 72". I believe he thought it would
be ok to leave it at that length.
He is a new pilot and I'm not sure if he had flown anything else prior to
his Slingshot and I suspect he had no more than 50 hours in the plane. I
can contact Dale Seitzer (also on the list and presently at Oshkosh) for
this information because he was a personal friend of Chuck.
When the crash happened on Tuesday, I looked at the radar after my flight
that morning, and saw rain in the southern part of the state where he was
flying. Since then I've been thinking about the following scenario:
He may have taken off in light drizzle with visibility no more than 5
miles thinking he was heading east toward Oshkosh and would be out of it
soon. After flying for a little more than an hour, he may have been
flying lower and lower so he could maintain visibility with the ground.
The air cleaner may have been getting saturated with water and began
affecting the engine. He was getting very close to the end of his first
leg at the Winona airport and may have thought he could nurse it there. I
suspect that when he knew he wasn't going to make it, he looked for a
field to put it down in. By that time he was probably very low at about
300'. When the engine quit, he may have broken the cardinal rule by
trying a restart (with a pull start in the cockpit) and not flying the
plane. Again this is pure speculation, but knowing he was a very low-time
pilot, there is a great tendency to do this. By trying a restart, he was
distracted and did not see the stall until it was too late. The plane
stalled and he spun in.
My question to the list is this:
Has anyone flown a 582 in heavy rain and had it affect the engine? I
have flown my 447 in light rains and not affected the engine, but I
wonder about the effects of heavy rain.
Ralph Burlingame
Subject: | Re: engine shutdown |
I think shutting the engine down at 50' up on short final might not
be the best place to begin orientation to an unpowered airplane.
I have been thinking about this thread a lot, and I would probably
shut down on a close downwind to a big grass strip for my first
introduction to engine out. That way I would have at least a little
time to get my head regeared. Since I have electric start, I have
shut down before at altitude and then restarted after gliding for
a bit, and the airplane is different (and incredibly pleasant) with
the engine off. But I wouldn't deliberately shut off for the first time
at 50' on a short final.
But who knows? Maybe that would be the best place to try it?
Let us know how it works out.
Richard Pike
If it's small enough, fill it with baking soda, and drop superglue on it.
Sand it smooth and paint it. Workmanship is important, don't cut into
any underlying material.
If it's a big ding, get several old and unbiased fellow pilots to look
at it and tell you whether or not to buy a new prop blade.
Richard Pike
>The Flying Farmer
I used to do it when I knew I had the airstrip made.
Subject: | Re: Deadstickig is dead... |
Herb here
I am fairly sure that an engine out is neutral in contributing to global
warming.
I began my flying carreer in Sailplanes and have had one engine out since
flying my Kolb mk III . On the down wind leg at the local airport. No panic
there!! Just seemed like old times. Water in the float bowls. shame on me!!
Around here; I receive a lot of criticism for climbing out very steeply.
Some say that I will not be able to get the nose down on an engine out. I like
my altitude and I like to get it quickly. Am I asking for trouble?? Herb in Ky
> Jeremy
From: | "Gary Thacker" <gbthacker(at)hotmail.com> |
Subject: | Re: Deadstickig is dead...thumbs |
Herb,
Yes and no. Yep altitude is your friend but you can try to get there to
fast. If you can get the nose down fast enough you won't have a problem at
altitude but. But close to the ground slow speed and steep clime is trouble
for sure. Low altitude nose up near stall and power failure..ouch!!! Classic
no no. Takeoffs and landing I would suspect are THE major cause of accidents
bar non. As you are well aware the attitude of the plane and the lack of
speed in a steep clime at takeoff equals disaster if you loose power.
Everyone is different but I keep my airspeed up a bit on takeoff. This
gives me the control I would need if I had a power failure. "There are no
old bold pilots"
Gary
Souderton,Pa.
>From: Herb Gearheart <herbgh(at)nctc.com>
>Subject: Re: Kolb-List: Deadstickig is dead...
>Date: Thu, 26 Jul 2001 11:35:41 -0500
>Herb here
>global
>warming.
>since
>steeply.
>like
>Ky
>drop
> > Jeremy
Guys!!!
Shutting the power off on a powered plane while still in the air is
definitely against FAA procedures. You will not find that in any "Practical
Test Standards" publication. I have a story about one of my students years
ago who was a glider instructor but had a little powered AP that he flew
back and forth the the field we worked at. Pulled the power on downwind.
Landed just a little short. Major hospital stay and totaled AP.
But then on the other hand, whatever grabs ya!!
Robert Kearbey CFII 1582106
KolbIII
-----Original Message-----
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike
Sent: Thursday, July 26, 2001 11:27 AM
Subject: Re: Kolb-List: engine shutdown
Richard Pike
Ok. I agree! wish I hadn't brought it up again!
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Jeremy Casey
Sent: Thursday, July 26, 2001 7:43 AM
Subject: Kolb-List: Deadstickig is dead...
Jeremy
I don't think it's fair or responsible to speculate, totally guess at what
happened to this unfortunate person. The only one that knows is that person
himself and he's not around to enlighten us about it. Posts like this remind
me of the media--"may have" or "could be" reports are nothing more than total
speculation. Let's quit trying to crawl into the mind of the pilot while not
being there.
I got back from Osh Kosh this morning at 4 am. We have to time it like that
to miss Chicago rush hour traffic. I was at the Kolb tent at noon on
Tuesday but I could not identify anyone from the group there, We have to
work out some way to tell who is in the group or not. The company does not
seem to know anything about us.
I was able to go for a ride in the extra. What a nice plane. Norm was
piloting and we went once around the circuit. I stepped out of the extra
and went right into a kit fox. The extra is a lot more comfortable and
seemed to ride smoother. You have to be real good friends to fly together
in a kitfox. Saw a great looking engine in the main convention grounds. A 2
cycle engine 92 hp designed to fit on a 582 engine mount. They claim 1000
hr tbo. The strange part is they say it gives a 2 gph burn rate. I have a
hard time with that part. Fortunately the importer is in Montreal and I
will be white water rafting near there in a couple weeks so I will go and
verify it myself. total price was 4700 plus 200 for the radiator. None of
this nickle and diming rotax method. I just found out the base price of a
rotax does not include the exhaust or even more chincy the exhaust
manifold. Easy to lowball a price if you charge for the neccessary parts. I
would recomend to anyone to go to Osh for the first few days and miss the
big crowds that will probably be there on the weekend. It's hard to talk to
anyone with 20 people ahead of you waitng to ask questions also. Saw Jim
Miller there but he was busy talking to potential customers so I did not
disturb him just to say hey.
Anyone else going please try to find the engine display. It is near
building B (I think) right around the corner from a yellow banner
advertising a hydrogen fuel cell and electric powered airplane.
I have a MarkIII we have flown for about 130 hours. I am taking helicopter
lessons and want to buy a helicopter. Need to sell the MarkIII.
Specs:
582 engine
Ivo 3 blade elctric prop
Electronic information system
Intercom
Flip Flop Com Radio
Srobe lite
Navigation lites
Matco hydraulic breaks
Winter enclosure kit.
Seat upholstery kit
Complete electrical system and electric start.
Exhaust cabin heat
Always been hangered!
See attached pictures
Still trying to decide what it is worth! But believe that I should ask at
least 16,000.00
From: | "John Williamson" <jawmson(at)dellepro.com> |
I just returned from my first trip to Oshkosh this morning.
Kolb Aircraft and Litespeed Aviation had a great display. Airplanes
looked real good in the pattern.
Ordered my Kolbra on Tuesday.
Links to Airventure 2001 pictures I took:
http://dellepro.dellhost.com/williamson/AV2001.jpg
http://dellepro.dellhost.com/williamson/KolbFF.jpg
http://dellepro.dellhost.com/williamson/KolbFS.jpg
http://dellepro.dellhost.com/williamson/KolbMKIIIXtra.jpg
http://dellepro.dellhost.com/williamson/KolbKolbra.jpg
http://dellepro.dellhost.com/williamson/KolbKolbra1.jpg
http://dellepro.dellhost.com/williamson/KolbKolbra2.jpg
http://dellepro.dellhost.com/williamson/KolbKolbraCockpit.jpg
http://dellepro.dellhost.com/williamson/VisitorMKIII.jpg
John Williamson
Arlington, TX
Kolbra on order.
I have been thinking about Will Uribe's problem with the leading edge
tape on this prop. I have one here for my FireStar that I have not put
together as yet. I e-mailed IVO today and asked if they had any
problems with their props. They said that they had received a batch of
leading edge tapes with poor glue and if one was to come loose, it would
set up a serious vibration. I went out and checked my blades and sure
enough, the tapes are coming loose with them just setting on my work
bench. I called IVO and they are sending me a new set of tapes with the
proper glue for me to install. I now feel that this is just a one off
problem and not a design problem. Anyone with this prop should check
the leading edge tapes to see if they are lifting around the edge.
Ron Payne
Gilbertsville, Ky.
I come from the GA side of things. Two things makes me shiver each time I
read them on the group. Crow hopping and this so called dead stick landing
practice. Both are bold activities. There's old saying that goes "there
are bold pilots and there are old pilots but there aren't any old, bold
pilots." My flight instructor told his students that when I started taking
leans. Its worked well for me for over 30 years.
These things are not video games. If you screw up your going to hurt
yourself and/or your pocket book. A good analogy would be why don't
parachutist practice jumps using there reserve ( A few have and are the
bold exceptions.)
Things to practice -
- emergency procedures - have you really done that - practice on
the ground first.
- learn to clear the engine when practicing simulated emergency
landings,
they been know to spit sputter and quit if you don't clear
them while gliding.
- telling wind direction.
- judge wind and drift - this is a major item most blow.
- be altitude aware - how much altitude above the ground do you have
- know you plane and how much it looses in a turn
- picking the field - judging the terrain - with furrows v/s cross
furrows
don't get caught in having to try to stretch your glide,
you can't,
live today fly again tomorrow - the plane is expendable,
better to break it under control than to splot trying to
extend
your glide to reach a field that you picked to far away.
- how to spiral (corkscrew) down over a field and break out at the
right alitude on final.
- how to judge altitude loss and compensate for wind direction and
strength.
- how to adjust your pattern to make the field.
- proper altitude loosing techniques. (flaps, slips).
- last of all fly the airplane first, then communicate.
- quickly analyze cause and determine if a restart is possible.
- close the throttle - rationale, in most UL's due to drag, you
have to drop the nose
considerably to maintain airspeed, should the engine
restart on a high thrust
line pusher, it rapidly pushes the nose down, if your near
the ground you may
not have time to recover, I heard of this happening more
than once on Kolbs.
This all can do done with the engine running. Not that when the engine
quits, on most UL due to the drag you have to lower the nose quite a bit
which comes the saying "look between your legs and you'll see when your
going to land." The high drag and light weight of UL's doesn't provide
much penetration against wind thus wind greatly impacts glide distance so
recognizing the wind direction and strength is very important in setting up
for a power off landing.
>Richard Pike
This is one of those technical sounding aerodynamics questions that I kinda
hope the resident aerodynamics guy will take (Topher, you out there?)
Regarding these Ivo props with leading edge tapes...they are just stuck on
top of the actual airfoil surface, NOT inlaid like on a Warp drive prop.
Considering that a prop is just an airfoil "flying" in a circle and that due
to the chord of the airfoil being so short(thus making the Reynolds number
of the airfoil so low) wouldn't that make the airfoil susceptible to surface
imperfections, like say for instance a thick (relatively speaking)piece of
stainless steel tape that is just bonded on top of the surface, leaving a
big (relatively speaking) hump at about 30% chord of the airfoil? Seems
that would make a prop alot less efficient?
Topher, what think???
Jeremy "tapeless IVO prop" Casey
jrcasey(at)ldl.net
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Ron or Mary
Sent: Thursday, July 26, 2001 4:26 PM
Subject: Kolb-List: IVO Props
Ron Payne
Gilbertsville, Ky.
Subject: | Oshkosh Pictures |
Sorry the links to my pictures would not work.
Have added them to the first page on my website.
John Williamson
Arlington, TX
Kolbra on order.
Thanks Ralph for that information. As a fellow Kolb driver, I'd be interested
in any further updates. Perhaps we can learn from this terrible tragedy. Thanks.
Randy and others,
I can answer some of these questions about Chuck Veith's Slingshot.Get mo
Well ... perhaps you are right about the speculation .... but I DO think
we should make every attempt to learn the facts about this tragedy ... not to be
critical of anyone, but to possibly avoid the same problems ourselves. That
could have been any one of us up there. I think that's what
this list is all about .... learning and sharing.
Sent: Thursday, July 26, 2001 2:51 PM
Subject: Re: Kolb-List: Kolb Accident On Way to Oshkosh
himself and he's not around to enlighten us about itGet more from the Web
HI Gary and list
I appreciate the advice and info. I tend to climb at 45 to 50 mph in my
MkIII. This has been described as too steep by most of the locals. None of them
are savy with this type of plane, however. It has an empty wt of 490 and I weigh
200. Mushes at abt 36. I have never done a real stall with it.
The MkIII is certainly a confidence inspiring plane. Perhaps I have grown
too confident and possibly complacent. Herb
Gary Thacker wrote:
> Herb,
> old bold pilots"
> Gary
> Souderton,Pa.
> >Herb here
> >global
> >warming.
> >since
> >steeply.
> >like
> >Ky
> >drop
> > > Jeremy
From: | Audrey Lewis <audreylewis(at)planters.net> |
Subject: | Firestar II Full enclosure |
Help! Just purchased a used Firestar II with a summer windshield. I did
not get the builders plans with the plane. Would someone on the list email
a copy of the full enclosure plans from their plans book.
Audrey
Sylvania, Ga
FSII,503,108hrs
hey woody sounds like you had a good time. i wish i had of gon but my wife
aunt died the day we were going to go sorry
next year for sure. but i would like to ride you your plane!
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Woody
Sent: Thursday, July 26, 2001 3:52 PM
Subject: Kolb-List: back from Osh
A week or so ago, I sent a pic of the soldering, and talked about
crimping the battery cables. Still having difficulties with gogittum,
after 1 success, so finally gave up and published it thru my old
Homestead site. I used the cable swaging tool to crimp the #6
connectors onto the #6 battery cables. Did a beautiful job - very
solid. Now, as in the pic, I'm going to see if I can get several
smaller ones crimped tightly enuf into a #6 connector for my accessory
circuits. I'll let you know how it works out. Take a look at:
http://www.flyingpics.homestead.com/crimp.html
Larry Bourne
Palm Springs, Ca.
Anyone been to OSK and heard anything of John Hauck? Last word I had he
was lvg western MT for ND on Tuesday. TNK site hasn't been updated in
many days. Should have been at OSK NLT Thurs. Any word appreciated.
Bob N.
Subject: | Seriously questionable flying |
Following from Newspaper:
A Eugene man was arrested this morning after his ultralight aircraft
crashed while
attempting to flee from officers at an Ontario area parking lot.
On June 18, 1999, at approximately 8:55 a.m. (MDT), OSP troopers
observed an
individual land an ultralight aircraft in a parking lot west of Adkin's
Market in Ontario. After landing, the operator, identified as MARK
ALLEN MITCHELL, age 47, taxied over to a nearby Chevron gas station,
filled a gas can and was preparing to take off when he was contacted by
officers.
OSP contacted the Federal Aviation Administration and was asked to
have MITCHELL
standby at the scene until investigators could inspect the ultralight.
At 9:25 a.m. (MDT), as officers were blocking the parking lot to
avoid other traffic from entering the area, MITCHELL attempted to take
off in the ultralight by splitting between two commercial trucks parked
in the lot. While gaining speed, the left wing clipped the front edge
of one of the trucks causing the ultralight to spin around and hit one
of the trailers.
After the collision, MITCHELL was taken into custody and charged
with RECKLESSLY
ENDANGERING ANOTHER PERSON (two counts), ATTEMPTING TO ELUDE AN OFFICER
IN A VEHICLE, and CRIMINAL MISCHIEF SECOND DEGREE . He was lodged in
the Malheur County Jail.
The "Thunder Gull" single seat ultralight aircraft, with a 25 foot
wingspan, was damaged in the crash.
Members of the Oregon State Police Ontario Patrol Office are
completing the
investigation. Ontario Police Department assisted at the scene.
......I do not support this type of flying, but thought it would be at
least interesting to ultralight pilots..
Julian Warren
Eugene, Oregon
Here's another warning for you. We have two guys in a MarkIII buy the farm
- cause engine out - the pilot dropped the nose but left the throttle wide
open position, the engine restarted and being a pusher with a high thrust
line, it pushed the nose down and he didn't have time to recover before impact.
We have also lost a number of pilots by making high angle of attack climb
outs trying to impress on lookers. In several cases they did. The engine
quits and because of there already slow, they don't get the nose down quick
enough causing a stall and crash or the same event happens as above.
>HI Gary and list
>them
>weigh
>Gary Thacker wrote:
> > Herb,
> trouble
> Classic
> accidents
> > old bold pilots"
> > Gary
> > Souderton,Pa.
> > >Herb here
> > >global
> > >warming.
> > >since
> panic
> me!!
> > >steeply.
> > >like
> Herb in
> > >Ky
> > >drop
> > > > Jeremy
Subject: | Rain impact on engines |
Can vouch for the 2-strokes but I can comment on a GA Citabria that has a
air filter on the inlet to the engine carb. I flown it through rain the
took paint of the leading edge of our horiz. stab. We talking rain so
dense it there cats, dogs, frogs, and fish coming down. The engine never
missed a beat on more than one occasion. I hope the two strokes are too
sensitive, when it rains here in Texas, it can rain. (Kiss a wood prop good
bye)
>writes:
>from
>experience
> > Randy Berry
> > Kolb Firestar KXP
> > sn.com
>Randy and others,
>finishing it up.
>Ralph Burlingame
Herb said it all very well!
>Herb,
>old bold pilots"
>Gary
>Souderton,Pa.
> >Herb here
> >global
> >warming.
> >since
> >steeply.
> >like
> >Ky
> >drop
> > > Jeremy
07/27/2001 08:12:05 AM
Ralph asked:
>Ralph Burlingame
Yup, I've flown in heavy rain with no engine problems. I was worried about
the prop mainly, at the time, but it was not damaged (Powerfin). I have an
aluminum fairing in front of the engine which may help keep the magneto end
of the engine drier. The fairing does not seal to the engine very closely
though. I flew for about 20 minutes thru fairly heavy rain one day
returning from my friend Mel Wickre's house. It got quite wet inside my
"fully enclosed" cabin but the engine did not misss a beat. It did sound
quieter during the rain event, curiously.
Slingshot crash...
The Rochester MN paper had an article on Charles Veith's crash, I will type
some of it:
""witness said he saw the airplane flying low at what appeared to be full
throttle. It sounded like he throttled back and it started sputtering and
it died. The engine was quiet, he made about half a circle around the
field. It looked like he banked and went into the field. The aircraft's
nose was badly damaged..."
Also, there was a photo with the fuselage cabin section upside down, engine
in the grass, prop broken to the hub, tail tube rightside up and snapped
off a foot behind the cabin. The bottom side of the cabin nose is smashed
badly upward, gear benty back slightly.
Jim G
Gives the media something to tak about besides Condit.
Richard Pike
>Jeremy
On page 39 in this month's "Experimenter" (August 2001), Cy Galley writes:
To effectively powder coat you must heat to at least 400 degrees for 10
minutes. FAA Advisory Circular (AC) 43.13-1B, Chapter 4 (paragraph 4-54b).
On page 4-13, the paragraph warns you not to reheat 2017 and 2024 alloy
aluminum above 212 degrees F. This will tend to impair the original heat
treatment. Reheating, including the baking of primers, is not acceptable
without subsequent complete and correct heat treatment.
I am now concerned about my fuselage tube which is powder coated. All the
other powder coated parts in kit #1 are steel and should not be a concern.
Please advise,
Clay Stuart
Get plenty of altitude, establish your usual climb speed/angle,
and chop the power.
You'll find out soon enough.
Richard Pike
Your boom tube is 6061. A different alloy altogether. It is tempered to
the T6 condition at the mill. Don't know what the 400 degrees will due to
the T6 condition, but I remember this was discussed several times in the
past...check the archives.
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Clay Stuart
Sent: Friday, July 27, 2001 9:20 AM
Subject: Kolb-List: powder coating
Please advise,
Clay Stuart
Hi Jerry and all
What is a good rate of climb for a MkIII?? Sounds as if this is one habit that
I
need to break---if indeed I am climbing out too steeply. Herb
> >HI Gary and list
> >them
> >weigh
> >Gary Thacker wrote:
> > > Herb,
at
> > trouble
> > Classic
> > accidents
> > > old bold pilots"
> > > Gary
> > > Souderton,Pa.
> > > >Herb here
> > > >global
> > > >warming.
> > > >since
> > panic
> > me!!
> > > >steeply.
I
> > > >like
> > Herb in
> > > >Ky
> > > >drop
> > > > > Jeremy
Herb,
I too like to get my altitude quickly. Being a sailplane pilot as
well I have been on a car tow which pulls the sailplane up like a
kite, in a VERY high angle of climb, had the rope break, and
recover. It is part of training.
A Kolb affords you a high rate of climb while maintaining a
reasonable airspeed. It is called Vy. You cover the least amount of
ground while climbing at this speed. All manufactured aircraft
publish this number. I don't know what that rate is for your
aircraft but it should provide you with a margin of error above stall
that will give you time to get the nose back down. I can tell you
safely, that your best rate of climb will not be just above a stall.
It will be probably be 5-7 knots higher than poweron stall.
Having seen the terrain you fly out of I would also have a couple
landing sites memorized depending on direction you take off. You
could even practice your emergency procedures for these landing sites.
I say, climb baby, climb. Just do it by the numbers.
Bob Brocious
Louisville, KY
Still lookin' for "MY" Mark III
>and chop the power.
>Richard Pike
steeply.
out. I like
Herb in Ky
The plane sounds good and the price sounds cheap. You should have no
problem selling it fast.
>Specs:
>582 engine
>Intercom
>Flip Flop Com Radio
>Srobe lite
>Navigation lites
>Seat upholstery kit
>Exhaust cabin heat
>least 16,000.00
From: | "Roland Lambert" <marotod(at)mindspring.com> |
Does anyone use the 3.47 to 1 gear box(e type) on their Kolbs with a 3
bladed prop?
R.L.
Sent: Friday, July 27, 2001 11:37 AM
> Herb,
> Bob Brocious
> Louisville, KY
> From: Richard Pike <richard(at)BCChapel.org>
> >and chop the power.
> >Richard Pike
> steeply.
> out. I like
> Herb in Ky
Subject: | Hauck in Montana Report |
For the 5th time since Monday, this is an attempt to report on John
Hauck's stay in Montana to the list.
John left Monday morning, July 23 at 10:25AM from Glacier Park
International Airport (KFCA) in NW Montana. He hoped to reach North
Dakota before stopping for the night. There were some mid-layer clouds
in the 60 mile long valley leading to Marias pass which caused some
concern. However this layer was breaking up when John took off and
later I found out the pass itself was severe clear as of 10AM.
John's radio is not repairable this side of the King factory so he has a
borrowed handheld and headset adapter if he wants to talk to the FAA.
The rest of his airplane is performing well with a few very minor
glitches: tailspring tube had loosened as paint wore away under the
mounting bolts heads and nuts, very small oil leak somewhere (of note
only because the engine had absolutely none before) and John regapped
his sparkplugs down to 0.020 from 0.028 which he felt helped the engine
start smoother.
The day given on The New Kolb website for John in North Dakota is
wrong. On Day 23 (Monday) John was here in Montana.
Tom Kuffel
Whitefish, MT
Building Original FireStar
Subject: | Deadstickig is dead...thumbs |
I prefer 60 MPH indicated! any slower doesn't give you enough time to
recover at low altitute should you lose power. Difference between climb
rates at 50 or 60 are almost insignificant.
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Herb Gearheart
Sent: Friday, July 27, 2001 7:07 AM
Subject: Re: Kolb-List: Deadstickig is dead...thumbs
Hi Jerry and all
that I
farm
impact.
quick
> >HI Gary and list
my
of
> >them
I
> >weigh
grown
> >Gary Thacker wrote:
> > > Herb,
to
problem at
> > trouble
> > Classic
> > accidents
of
This
are no
> > > old bold pilots"
> > > Gary
> > > Souderton,Pa.
> > > >Herb here
to
> > > >global
> > > >warming.
out
> > > >since
> > panic
on
> > me!!
> > > >steeply.
out. I
> > > >like
> > Herb in
> > > >Ky
more...let's
> > > >drop
a
> > > > > Jeremy
Subject: | Re: Hauck in Montana Report |
This time you made it. What did you do to get back on ??
Larry Bourne
Palm Springs, Ca.
Sent: Friday, July 27, 2001 9:37 AM
Subject: Kolb-List: Hauck in Montana Report
> start smoother.
> Tom Kuffel
> Whitefish, MT
them
weigh
I have about 20 hr in a Mark III that is 499 lbs., Rotax 503,
and I weigh 180 lbs.
I used to climb out at 50 mph.
The Mk III was very stable and climbed well.
Then one day I did some power off stalls and observed
a very noticable stall break at 45 mph.
I don't climb out at 50 anymore.
I agree with Bob Kearbey, 60 mph climb out.
Do some stalls.
You have to know what the stall speed of your aircraft is.
By the way, isn't your ASI reading low?
chuck
Subject: | John Hauck at OSH |
John arrived at OSH Wednesday, as reported by aero-news at 2AM
Friday--also by Tim Oliver who gets up earlier than I do!
Ol' John is steppin' highern a blind horse in a punkin patch, parked in
the Number One spot in front of the Kolb Barn. Ck
http://www.aero-news.com for complete text and pictures.
Bob N.
http://members.nbci.com/ronoyer
Try URL www.aero-news.net for the article on John.
Jim Hauck
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of bob n
Sent: Friday, July 27, 2001 1:50 PM
Subject: Kolb-List: John Hauck at OSH
Bob N.
>bladed prop?
> R.L.
I do.
http://www.mindspring.com/~possums/
Subject: | Soldering Helper |
I saw a tool somewhere a long time ago. It was a little stand with two
arms on it. On the end of each arm was a little clamp. These arms
could be moved in any direction then locked. When soldering small
terminals onto small wires, the terminal could be clamped with one arm
and the wire with the other. That left both of your hands free to hold
the iron and the solder. Does any one know where I could get one of
these?
Ron Payne
Gilbertsville, Ky.
Subject: | rong, rong, rong |
In case anyone hasn't figgered it out, I made a classic internet
boo-boo.
It's http://www.aero-news.net not .com
At least John got there, in spite of me.
Bob N.
Subject: | Re: Soldering Helper |
Re: them two little hans'----Radio Shack has 'em.
bn
Chuck/Group
I have flown my MkIII at 35 or 6 indicated. Admittely I was not looking at
the gps at the time . This was the basis for my 45 to 50 mph climb outs. I did
not care about the published specs at the time. I only wanted to know when my
machine would quit flying or nearly so. Gps agrees when I am doing 55 to 65
cruise.
I will go back to square one in the next day or so. I will climb to altitude
and do full stalls. Several directions--probably didn't do that before with the
mush experiment. I will try to do higher speed to's also. It may be that I have
been taking off and landing faster than I thought? Gotta be a non linear ASI?
My kolb cannot be 10 mph slower in stall!! Herb
> them
> weigh
> Do some stalls.
> chuck
Bob and all
You have seen my field. Have you flown over this area? Here in south
central Ky there are fields everywhere. I would not fly this type of plane
over hostile terrain. I will leave that to John and the rest!:-)
Well---with a 912 --maybe.:-)
Looks like the reason that I am still here has to do with the mush
/stall test that I did early on. I cranked 10 to 15 mph on to that and
have been using it as my min. It seems that I have an airspeed that is
off on the low end?
I started my flying at the soaring club at Highland-Winett airport east
of St. Louis Mo. Training consisted of flying near stall a lot of the
time. The whole idea was to recognize the symptom and automatically
correct with small nudges
of the elevator . A lot of 60 degree banked stalls also. That was with
the 2-33 trainer and the transision plane the 1-26. They recover very
quickly and with minimum loss of altitude as I recall. Not a full
stall---just to recognize the onset and make the necessary adjustment.
One of the problems that I have is that I have not explored all sides
of the envelope with the Kolb; fully.
Good luck in finding" Your mkIII" . Should be a few come onto the
market this fall at the end of the flying season. Herb
brocious(at)prodigy.net wrote:
> Herb,
> Bob Brocious
> Louisville, KY
> --- Original Message ---
> >and chop the power.
> >Richard Pike
> steeply.
> out. I like
> Herb in Ky
Hi Everyone,
Drove back today. Was at Oshkosh Wednesday and Thursday. Wanted to get a
ride in the Xtra but when I was available they weren't and visa-versa. Met
and talked with Steve Green. He flew up from Tennessee. I saw two other
non-factory Kolbs but did not meet the pilots. Talked a little with John
Hauck. He arrived Wednesday afternoon. What a fantastic trip!! He said he
didn't think he would be making any more "long" flights. Don't know if
he'll feel the same way after some recovery time.
The new Extra has quite a few design changes. All seem to be for the
purpose of reducing the weight to be a legal ultralight trainer. (Center
control stick, flaperons instead of flaps, horizontal stabilizer back to the
old size, etc.) I'm not sure how many of these changes will be incorporated
or if this will be the new "standard" Mark III Xtra. I sense that the
design is still being massaged. Also, the Extra had the doors off and they
say it flys great with no excessive windage in the cockpit.
Steve Green asked me if I had heard about the relocation of the horizontal
stabilizer. I hadn't. The horizontal stabilizer on the new Xtra is
approximately in the center of the fuselage tube. (I noticed John Haucks
was also in the center). My plans call for it to be in line with the top of
the tube. Danny says the factory will advise of the recommended change to
the center. If you're building a Mark III you may want to confirm this with
the factory. I don't know if it applies to every engine/Classic/Xtra
combination or not.
Also, the Verner engine that the factory tested had some problems. The
starter had to be replaced as well as a blown oil seal. The "cogged" belts
had a major problem of stripping the cogs. I know some of you guys are
trying the Verner and you may want to keep an eye on those things. They
were happy with the Jabiru and everyone I talked with had good things to say
about it.
Hope to see some of you at the Kolb fly in. I agree that we need nametags.
I probably walked right by several of you guys at Oshkosh.
Rex Rodebush (Rody)
Did you get the pictures this time? I sent them as an attachment. Everything
looked right when I sent them so I hope you got them. Sent them to your
email address, not the Kolb list.
Bob Kearbey
kearbey(at)jps.net
----- Original Message -----
Sent: Friday, July 27, 2001 6:20 PM
> Bob and all
> off on the low end?
> > Herb,
> > Bob Brocious
> > Louisville, KY
> > >and chop the power.
> > >Richard Pike
> > steeply.
> > out. I like
> > Herb in Ky
A standard way to determine a safe approach speed is to find what the
stalling speed is in flaps up/flaps down and multiply by 1.3. That should
equal a safe approach speed.
Bob Kearbey CFII 1582106
Sent: Friday, July 27, 2001 4:58 PM
> Chuck/Group
looking at
I did
my
65
> cruise.
altitude
with the
I have
ASI?
None of
> > them
and I
> > weigh
> > Do some stalls.
> > chuck
Subject: | Stall Characteristics |
I was out messing around with some accelerated stalls yesterday and
discovered an interesting tendency of my Firestar. If I rolled into a 30-45
degree bank near idle and held altitude to let it stall, it would roll back
towards level at the break, sometimes rather quickly. This worked in both
directions and even with a little rudder towards the direction of the bank.
Is this common? Did Homer incorporate some self-righting aerodynamics?
Ralph...?
Kip Laurie
Firestar II
Atlanta
86 hours since Sept
"Robert Kearbey" wrote:
I agree. However, for high drag airplanes which lose speed quickly, such as
biplanes, it might be 1.5 Vso. A good compromise for the Mk-3 is 1.4 Vso.
Main point is you MUST know your indicated stall speed for reference.
Bill George
Mk-3 Verner Powerfin
CFII 1464036
Subject: | ID Magazine Sales Vendor at Oshkosh/Sun&Fun |
Does anybody have the identify of the vendor and phone number for the
vendor that sold Kit Plane subscriptions in the vendor building at Sun &
Fun or at Oshkosh. I want to renew and would like to order through them.
jerryb
Subject: | Re: Stall Characteristics |
> aerodynamics?
> Ralph...?
> Kip Laurie
> Firestar II
> Atlanta
> 86 hours since Sept
Kip and others,
There are a couple of self-righting capabilities that I can think of in
this situation (and again may I remind you that I am not a formally
trained aero engineer).
Natural pendulum stability below the cg in the vertical plane will try to
level the wings but may not be enough. Depending how much dihedral is
built into the wings could account for more. The slightest amount of
lateral stick movement, opposite to the angle of bank, could be the main
contributor. A pilot would naturally have a tendency to move the stick in
the opposite direction under such conditions and you may have did it
without realizing it.
If that inside wing is in a deep enough stall, I doubt any of the above
would level the wings and the plane would go into a natural spin. Try it
in a steeper bank at a slower speed, but make sure you have lots of
altitude.
I've never tried that stuff myself. I'm satisfied with doing deadstick
landings (oh-oh, I said the "D" word) and flying straight and level
except when an occasional thermal tries to tip me over.
I'm too chicken.
Ralph Burlingame
Original Firestar, w/447
Subject: | Re: Kolb-List Digest: 35 Msgs - 07/27/01 |
why is this turned into "text", I don't have time to mess around with
downloading etc. all I wanted to do is read the normal messages as usual,
seems the Kolb list is getting too involved with itself, just keep it simple.
Don Mekeel
FF002, El Paso, Texas
From: | "Chris Sudlow" <sudlow77(at)earthlink.net> |
Subject: | Re: Emergency Landing Practice |
List,
I had an emergency landing during departure several weeks ago.
I've been training in a MIII while completing mine. After about 8 hours
dual, my instructor and I decided that if we went around 2 - 3 times, if
everything looked good, and we both felt comfortable, I would solo.
We lined up at the end of the 3000' grass strip, checked temps, fuel, & put
in one notch of flaps.
Pushed to full throttle & began the take off roll. When I pulled back to
bring it up, it felt heavy, we skipped once, & then rotated.
At 50 ft I knew it wasn't climbing right. Controls were heavy... At about
80 - 100 feet', I told the instructor we had a problem. I was so distracted
by the handling, I let the plane drift over a road that lies roughly
parallel to the runway. We could see a couple of semis & cars below us. I
gently banked left, told him to take it.
The instructor took the flaps out, put the nose down, & worked the
throttle - we were only getting about 5800 rpm.
We both looked left and right for a field, and it seemed like we chose the
same one. About 1/4 mile long, roughly on our heading, and the rows of corn
going in the right direction.
With nothing else to do, I called airspeed for him - later he said he never
heard me.
Final looked good until we were at about 20 feet. There was a low muddy
depression with what looked like a 2 foot ridge, at what I thought was our
touchdown point. My left arm went up to brace myself on the windshield
support tube - thought we were going to stick & flip. Turns out we went
right over it, my instructor never saw it, and made an excellent landing.
Now we're taxing through 2 foot corn trying to keep the wheels between the
rows. About 400 yards away, we see a truck pull up to the edge of the field,
and a farmer gets out... but that's another story.
We only got 5800 rpm on the 582. I'm told that's about 20% under full power.
When we got back to the hangar, put the plane away. He asked me if I was
alright, I said I was. We talked about going up in the other MIII with the
912, smiled, and decided to go out for beer instead.
I like to think I would have put it down as well as he did - maybe, maybe
not. There's a fair chance I would have damaged the plane or worse. At least
I kept the nose down, and the worst that happened was that things got
mushy - which is dangerously close to stalling, and stalling from 80 feet
leaves little room for options.
Chris
Something that is very apparent in my MKIII power on stalls: they are
preceeded by a very loud cavitation of the prop at it encounters buffeting
air coming off the center section of the wing, especially when carrying a
passenger. Any body else notice this? Makes a great power on stall warning
device, however it is not as apparent when flying solo.
Richard Pike
Hello Builders and Flyers , Has anyone treated the AL. tubing to prevent
corrosion ? If so, with what ? Thanks for the info.
Dave Snyder Long Branch ,N.J. Building FSII
Subject: | Re: Soldering Helper - this might work |
Seems like you could make one with a couple alligator clips, couple screws
and block of wood if that all your using it for. A sheet metal or dry wall
screw through the wire solder/screw terminal hole of each clip mounted to
the upper edge of a short 2x4 laid flat on a surface. Space the clips
where they can touch each other when rotated on the screws towards each
other. I haven't built this but I would think it should work as a third
hand for what you want to do.
jerryb
>these?
>Ron Payne
>Gilbertsville, Ky.
Subject: | Re: MKIII Stalls |
Mine does not do that Richard.
Sent: Saturday, July 28, 2001 3:04 PM
Subject: Kolb-List: MKIII Stalls
> Richard Pike
Thanks Bill, I will accept that.!!
Sent: Saturday, July 28, 2001 8:15 AM
Subject: Kolb-List: Deadstickig is dead...thumbs
> equal a safe approach speed.>>
as
> Bill George
> CFII 1464036
Using the hole in the soldering iron idea worked great for the little D sub
miniature pins, and I've found, now that I've had a little more practice,
that the larger 9 & 12 pin connectors are much easier to handle. Crimp the
middle tabs over the bared wire, and the upper tabs on the insulation, as I
showed in the picture a couple of weeks ago. Then, with the tip of the
soldering iron, lift the connector from behind, and push from above with the
solder. When it starts to get hot, slip a tiny bit of solder onto the tip
of the iron - it'll melt, and wick heat back up into the connector. A
little bit more solder, to soak into the crimp, and it's done. Biggest
thing is to limit the amount of solder you use. You don't need a big ball
of it, to do the job. This morning I did the 6 pins for the strobes this
way, with no holders, and they came out so nice, you can hardly tell they've
been soldered. They snapped smoothly and neatly into the holders, and I
couldn't help but grin. Super Pro Lar.
Larry Bourne
Palm Springs, Ca.
Sent: Saturday, July 28, 2001 2:40 PM
Subject: Re: Kolb-List: Soldering Helper - this might work
wall
Subject: | twinstar for sale |
A former List member "Warren" from Michigan has decided to sell his
Twinstar. I was first to fly this aircraft and it flew quite nice. He asked
me to post this for him. He also has a T trailer (very slick) that he is
going to keep for other projects but if the price is right on it he may
sell it also but not before the Twinstar is sold. Warren is mostly deaf so
you must reach him by emails or Fax as he cannot hear over the phone.
Kolb Twinstart two seat trainer available. Kit purchased in 1986 and
completed in 1999. Fiberglass nose cone with stubby windshield. Single carb,
electric start Rotax 503 with 10 hours TTAE. Engine recently completely
disassembled and renewed by Green Sky, a Rotax dealer. Workmanship and paint
superb. $12,000. SE Michigan, Ann Arbor. Photo on request. Reason for
selling; lost wife of 47 years to cancer, must now realign everything.
Warren Branscomb email wbrans(at)provide.net Fax 734/699-7101.
From: | Brocious Family <brocious(at)prodigy.net> |
Robert,
Still have not seen any pics. But given how far you are from Kentucky I can
safely say I wouldn't be interested. Thank you for the follow up though.
> Specs:
> 582 engine
> Intercom
> Flip Flop Com Radio
> Srobe lite
> Navigation lites
> Seat upholstery kit
> Exhaust cabin heat
> least 16,000.00
From: | "rbaker(at)shop4zero.com" <rbaker(at)ccgnv.net> |
Chris,
Thanks for sharing your experiance. Why didn't the engine develope full
power?
L. Ray Baker
Lake Butler, FL
Mark III, 912,BRS,N329RB.
95% Done, 20% to go
Sent: Saturday, July 28, 2001 2:48 PM
Subject: Re: Kolb-List: Emergency Landing Practice
> List,
From: | Earl & Mim Zimmerman <emzi(at)supernet.com> |
"rbaker(at)shop4zero.com" wrote:
> Chris,
> power?
Why wasn't 5800 rpm enough to get you back to your 3000' strip??
Group,
I was out flying tonight and ran into a Kitfox pilot that also practices
deadstick landings with his Rotax 582. Another good boy scout.
There is one thing I forgot to mention with the crash of Slingshot pilot
Charles Veith. He told me that he never used his flaperons and made all
landings without them. This would increase his actual stall speed and is
possibly another factor that led up to this accident.
What is the approximate stall speed on a Slingshot without the use of
flaperons?
Ralph Burlingame
Subject: | Re: WalMart wires |
There is another parameter you much observe. It is the number of groups
and the number of strands per group, example: 7x7 or 7x19. This impacts
flexibility which can impact life depending upon the application.
jerryb
>Bob & all,
> I too thought stainless was better, but I found out that stainless is
>much more brittle & it will fray around pulleys quicker. Unless you are
>flying out of salt water, steel cable is a better choice for our
>application, especially the UltraStar which has several sharp bends around
>small pulleys.
>...Richard Swiderski
>From: "Bob Singer" <hp2693(at)cmuonline.net>
>To:
>Sent: Wednesday, July 25, 2001 3:35 PM
>Subject: Kolb-List: WalMart wires
> > Ed. I have looked at the WalMart "aircraft approaved" cable also but
> > all of the ones I saw, including the ones at the local farm store that
> > said "aircraft approaved" were galvanized steel. Every aircraft I have
> > owned had stainless steel cables. I would not use galvanized steel
> > cables in anything I am sitting in above the ground and our local AI
> > agrees. For just a couple of pennies more a foot, you can get
> > stainless steel cable from some of the suppliers like Lockwood or
> > L.E.A.F. and be sure of its reliability and higher strength. Bob
> > I changed and went to the next size larger diameter FAA
> > aircraft approved Wal-Mart cable....No joke,it is aircraft cable from
> > Wal-mart. Ed in Western NY
Subject: | www.Kolbpilot.com |
Here is a site with pictures of Kolb people at Osh!
www.Kolbpilot.com
Jon
From: | JIMMY HANKINSON <jhankin(at)planters.net> |
Subject: | Switchs for EGT and CHT |
Have a question for discussion:
I have a FireFly with a Rotax 447, the instrument panel will only hold
so many instruments. I would like to be able to check both EGT and CHT
on each cylinder with one instrument. Only one CHT and EGT is displayed
now.
My question is ------ would a switch that has two inputs,one output,
work by switching between the two inputs work on one instrument?
I have access to a switch that is a double pole double throw, with one
output that I could hook sensors from both cylinders and have a
switchable output to one instrument.
I know that there are instruments that moniter both, just looking for a
reasonable safe way to do this.
If this is thought to work, the rear cylinder EGT and CHT would be
monitored most of the time and the other cylinder checked during flight
by changing switch lever position
This list has been good with my other questions, how about some serious
thought and answers!!!
Jimmy
Firefly #35, 447 Rotax
Rocky Ford, Georgia 30455
Southeast, Georgia
JYL -- Airport
>snip....
>and a farmer gets out... but that's another story. snip....
So how many bushel of corn did you buy.
Subject: | Re: Switchs for EGT and CHT |
Yes, some use one gauge and a switch to switch between two sensors.
However, since we are dealing with microvolts and microamps to operate the
gauges, resistance in the switch contacts or connectors will reduce the
values you will read on the gauge. In other words, use the best switch you
can find and make sure your connections are as good as you can make them.
If space is limited, an EIS unit would, probably, be a better choice than
switching sensors. IMHO
Larry Davis
Sent: Saturday, July 28, 2001 10:40 PM
Subject: Kolb-List: Switchs for EGT and CHT
> now.
> Jimmy
> Southeast, Georgia
> JYL -- Airport
> output, work by switching between the two inputs work on one
instrument?
> one output that I could hook sensors from both cylinders and have a
> Jimmy
> Southeast, Georgia
> JYL -- Airport
My personal opinion on this Jimmy is not to use a switch on the EGT. The
reason the EGT is on the panel is to alert the pilot of a possible
pending seizure in the engine. I don't think you want to be constantly
switching back and forth between the two cylinders to monitor them. Would
you believe I've flown all these years without a CHT? Again, this is my
opinion, but the CHT monitors the fan belt. If the belt breaks, the
engine does not cool and the CHT rises. There aren't too many other
conditions where the CHT is going to rise when the fan is working unless
you are setting a climb record. The fan belt, if adjusted properly, is
extremely reliable. I had one on there for 10 years and it looked better
than the new one I replaced it with.
I think a combo 2-in-one EGT, without the switch, would be fine if you
don't want to spend the money on a CHT. The EGT's will display immediate
results of a pending engine seizure IF the instrument is being monitored.
This means using a switch is not a good idea.
Long before Rotax came out with the EGT plug ports in the exhaust
manifold, we drilled a hole in the "Y" of the manifold. I still use my
377 muffler (14 years old) on my 447 with this hole drilled in the "Y"
and my readings are accurate enough and both cylinders are monitored. All
manifolds today have the plug ports on them, so it would not be a good
idea to plug them and drill a hole, but I mention this because I did it
years ago and have a combination EGT/tach on my panel. It works great and
if the engine is going to seize, I only have one instrument to look at
that gives me the information I need to take appropriate action. Pure and
simple.
These are my opinions and others will have different ones ...... just
like the guys that think deadstick landings in a Firestar are bold and
dangerous. Oops, I mentioned that "D" word again.
Ralph Burlingame
Original Firestar
14 years flying
Subject: | Fwd: METAL TREATMENT |
In a message dated 7/28/01 5:20:47 PM Eastern Daylight Time, TAILDRAGGER503
writes:
<< Hello Builders and Flyers , Has anyone treated the AL. tubing to prevent
Full-name: TAILDRAGGER503
Date: Sat, 28 Jul 2001 17:20:47 EDT
Subject: METAL TREATMENT
I would not use a switch in either of these circuits. You are dealing with
such low current flow that a speck of dust on the switch contacts would
cause a very inaccurate reading and could be dangerous. I think I would do
everything I could to find a location to mount two gauges for each
application or go to an EIS system.
Ron Payne
> now.
> Jimmy
> Southeast, Georgia
> JYL -- Airport
Subject: | Re: Kolb-List Digest: 23 Msgs - 07/28/01 |
> Richard Pike
> MKIII N420P (420ldPoops)
Richard:
My FS1 does this , even at low power settings, although not as loud.
Darren, Central MI , 64" warp 2 blade.
I had the same problem, so I called Westach. They told me that using a
switch is fine, and using different wire than supplied is fine. Doesn't
take a big switch; there's not a lot of current to worry about.
Lar.
Larry Bourne
Palm Springs, Ca.
Kolb Mk III - " Vamoose"
http://www.biglar.homestead.com/larry.html
Sent: Saturday, July 28, 2001 8:40 PM
> now.
> Jimmy
> Southeast, Georgia
> JYL -- Airport
Dear list,
I've been on this list for years but usually in a passive capacity. I'm flying
a Mk2 that I finished in 1998 (bought the kit at Oshkosh in 1988) I have 175
totally trouble-free hours on the plane and engine (503SCSI) I fly the airplane
solo (left seat) and notice a tendency for the airplane to roll left slightly
when I take my hands off the controls. I suspect that this has more to do
ith the fact that I (at 200 lbs) am sitting left-seat in a 380 lb airplane than
the airplane being out of trim. Does anybody else notice this tendency when
flying solo in a 2-seater Kolb and, if so, what have you done to correct this?
Is it possible to correct this by adjusting aileron without having to resort
to a trim tab (or a sand bag in the right seat)?
On another subject, I am flying in Texas where the summer thermals are monsters.
Since my training in flying was mostly in gliders, I like to attempt to soar
my Mk2 when the weather is bumpy (all summer here). Is anybody else on this
list soaring their Kolbs and what mods have you employed in an attempt to "clean
up" the design to maximize efficiency (other than the obvious strut fairings
and wheel pants)? What about the leading edge mod I used to hear about (wrapping
the leading edge with and thin skin of aluminum sheet to get rid of the
scallops)? I would be very interested in hearing from anybody who has done or
is considering se kinds of mods to their Kolbs for the purpose of efficiency.
Steve Kroll
> Is anybody else on this list soaring their Kolbs and what
> mods have you employed in an attempt to "clean up" the design to
> maximize efficiency (other than the obvious strut fairings and wheel
> pants)?
> Steve Kroll
Hey Steve,
When you soar your Mark II, do you shut down the engine? I have heard of
a Canadian pilot soaring a Challenger II and he shuts it off for over an
hour. There are a few advantages that ultralight planes have that might
help make up for the high drag. One is staying centered in the core with
a tighter turning radius, another is slow flight to stay in the thermal
longer. The third, of course, is the lighter weight.
Answering your trim problem, I used to fly a Mark II from the right seat
so you might try that. It's awkward at first, but you get so used to it
that it seems natural.
Ralph Burlingame
Original Firestar
14 years flying
We think it had blow by on the rings, but won't know until it's broken down.
They simply bought a new 582.
From: rbaker(at)shop4zero.com <rbaker(at)ccgnv.net>
Date: Saturday, July 28, 2001 6:39 PM
>Chris,
>power?
>L. Ray Baker
>Lake Butler, FL
>95% Done, 20% to go
>From: Chris Sudlow <sudlow77(at)earthlink.net>
>To:
>> List,
2 people, no climb, we had to put it in.
Date: Saturday, July 28, 2001 8:02 PM
>> Chris,
>> power?
Subject: | Reply about Avweb UL Coverage |
Folks,
I send replies to both Avweb editor and EAA Communications Dept..
Let's hope this does some good. It worked when Paul Harvey made his
descriptive remarks on the air. The more messages they get, the more
pressure on them.
See the article under Top news stories titled "Down on the Farm Avweb
published at the following URL: http://www.avweb.com/
The author describes ultralight as ""Wizard of Oz' winged monkeys."
>Date: Sun, 29 Jul 2001 13:32:03 -0500
>To: editor(at)avweb.com
>From: Jerry Bidle <jbidle(at)airmail.net>
>Subject: Avweb UL Coverage at Oshkosh
>Dear Editor,
>I was happy to see Avwebs coverage of Oshkosh fly-in and especially
>ultralights until I read how they were referred to as "Wizard of Oz'
>winged monkeys." I couldn't belive my eyes. How could any competent
>aviation oriented magazine more degrade this category of aviation.
>Furthermore the author was not disclosed so they may rightly receive the
>just credit they deserve within the aviation community. This short
>article has greatly discredited and caused irreparable damage to the
>ultralight community. For the sake of aviation if Avweb can not be more
>responsible for what it puts in type, please do not cover future Oshkosh
>Airventure or Sun & Fun events.
>Jerry Bidle
>Licensed Pilot "and" Ultralight Pilot/Owner
Subject: | My Reply about Avweb UL Coverage |
I, too gave editor Glenn Pew a coupla whacks--one for the odious
comparison, and two, for lack of coverage on John Hauck's trip.
curmudgeonly yers,
Bob N.
Subject: | Re: www.Kolbpilot.com |
I just get a blank page.
Larry Bourne
Palm Springs, Ca.
Sent: Saturday, July 28, 2001 9:12 PM
Subject: Kolb-List: www.Kolbpilot.com
> www.Kolbpilot.com
> Jon
Sounds good to me. go for it.
In a message dated 7/29/01 9:50:48 AM Eastern Daylight Time, ul15rhb(at)juno.com
writes:
> simple.
> Ralph Burlingame
> Original Firestar
I agree with Ralph, I also have an EGT mounted at the Y on my 447 (KX
Firestar) and although the temps will go into 1250 at that location I have
never had a freezeup
and always watch the EGT while flying to ascertain whether there is a hot
spot happening.....you can always vary the throttle when it gets too
high.....and it is very responsive to what is happening RIGHT NOW ...as
opposed to the CHT which is buried in the mass of the head and plug and takes
longer to respond to a flare up.....whew....I'm gonna have to
breathe....sorry...for talkin so long
Also a switch in this circuit is less than perfect cause the output of a
thermocouple is in the neighborhood of a few milivolts and that has to be a
perfect circuit to make that HUGE NEEDLE move up . Bear in mind that a few
milivolts is only a few Thousandths of a volt...so the energy available to
drive that meter needle up is very small requiring the circuit to have
virtually NO resistance in it.
The point is all switches have some resistance and the saving grace is that
if you use a selector switch that wipes the oxides off the contacts when you
move it the resistance is minimized....but it took you to do it, instead of
having no switch at all which is inherently more reliable.
I gotta quit this
hope that helps, Jimmy.
GeoR38
Subject: | Kolb-List Digest: 35 Msgs - 07/27/01 |
jbowaf in baton rouge (btr) question??
been reading the list for svrl months now. fascinated by the debate over low
n slow, for which these ac seem designed (recreational/sightseeing etc) and
cruising at safe altitude?? but i have scarcely if ever seen a ref to brs
chutes.. what's the deal? did the two guys cruising the west and sw in
their fs' s and john h. not have safety chutes?? seems a rather obvious
necessity for the type of cruising i would envision for these type ac. is
cost the issue or what?? i just dont get it?? tnx
Subject: | Re: Walmart wires |
>I too thought stainless was better, but I found out >that stainless is
>much more brittle & it will fray around pulleys >quicker. Unless you are
>flying out of salt water, steel cable is a better >choice for our
application.
Richard Swiderski
I agree with Richard.
The stainless cable looks nice but it cost three times as much as
galvanized at ACS and is not as strong (2000 vs 1760 for 1/8 th 7x19
cable).
Danny Bradshaw
Firestar 503 54hrs.
McBee S.C.
PS. The tube supporting the seat back on my plane is also bowed and has
hairline cracks on each side.
have
In a message dated 7/25/01 11:48:57 PM Eastern Daylight Time,
swiderskir(at)earthlink.net writes:
> Your skill level will improve dramaticlly & you will
> greatly improve your odds when (not if) your 2-stroke goes silent & you have
> to put it into a tight field with the wind blowing. Instead of fighting
> panic, you will be making calm decisions & flying your plane like you've
> done many times before. Besides, if dead sticking isn't the purest form of
> flying, its at least the purely funnest form of flying. ...Richard
> Swiderski
Hear Hear Richard.....Um witcha buddy
GeoR38, the ol glider pilot....flew for years with no engine at all
but have a lotta respect for power lines....even though i NEVER hit one
besides it was in the desert of ol El Paso
Akron Oh
Check your tech manuals. The cht does more than tell you if your belt
breaks. A 2 cycle engine is not just air cooled it is fuel cooled. The cht
will give you a good solid reading on what is happening to your engine if
it is an air cooled powerplant. Use this to select or adjust your jets. The
egt is to variable and can change in a moment giving false or temporary non
destructive highs. Use the cht to fly by and the egt to diagnose problems
along with the spark plug colour. The kindly people at Skysports who have
been in the instrument business for years would rather you buy only a cht
rather than an egt if you can only buy one.
This applies to aircooled engines. I do not know the procedures for
water cooled.
Subject: | Re: Kolb Accident On Way to Oshkosh |
In a message dated 7/26/01 12:52:11 AM Eastern Daylight Time,
sc_bassman(at)hotmail.com writes:
> I am so sorry to hear of this tragedy ... for the pilot and family ... an> d
makes me contemplate my own potential fate. I just looked up the place> s involved
on my MS Expedia. Appears that he had made roughly 112 miles
> with about 158 miles to go ... not quite half way. Appears that there we> re
no major towns or cities (or airports?) on his flight path from St. Pe> ter to
Minnesota City. Wonder how much fuel he had on board .... whether> he had a
headwind ... and what type engine? What flying experience did
> he have overall? In the interest of safety for us all, I'd be interested> in
hearing the cause and circumstances ... once determined.
> Randy Berry
> Kolb Firestar KXP
> sn.com
I just came back from Oshkosh and was amazed at the newscasts there that
spoke of around 10 lives lost en route to Airventure this year...couldn't
hardly believe it ... but I didn't know that one of them was a Kolb...I never
did get a chance to open up that story cause the web site had changed stories
to removal of porn from the streets of Winona by the time I went there on the
tube.
GeoR38
Don't take this as the only or the best way to solve your trim issue but
have you considered a bungee cord trim. Take a small dia. (3/16-1/4")
bungee cord, grab it in the center and twist it. This should form a loop
with both ends on the side (like a O with a line on the bottom). Put this
over your control stick. Locate a point on each side of the stick to
attach the bungee cord. To adjust the trim, start with stick so its held
in the center position (neutral) position. Slide the cord around the stick
to hold it in the necessary position to hold the wings level in
flight. Note, the bungee cord allows you to over ride the stick with
little pressure for normal control inputs.
Performance wise realize you are dragging an aileron so it will add a
slight bit of drag but no more than if you held the stick by hand.
You could also add a trim tab to the proper aileron.
Question: Does the plane have any tenancy to turn with the wings level?
>Dear list,
>flying a Mk2 that I finished in 1998 (bought the kit at Oshkosh in 1988) I
>have 175 totally trouble-free hours on the plane and engine (503SCSI) I
>fly the airplane solo (left seat) and notice a tendency for the airplane
>to roll left slightly when I take my hands off the controls. I suspect
>that this has more to do ith the fact that I (at 200 lbs) am
>sitting left-seat in a 380 lb airplane than the airplane being out of
>trim. Does anybody else notice this tendency when flying solo in a
>2-seater Kolb and, if so, what have you done to correct this? Is it
>possible to correct this by adjusting aileron without having to resort to
>monsters. Since my training in flying was mostly in gliders, I like to
>attempt to soar my Mk2 when the weather is bumpy (all summer here). Is
>anybody else on this list soaring their Kolbs and what mods have you
>employed in an attempt to "clean up" the design to maximize efficiency
>(other than the obvious strut fairings and wheel pants)? What about the
>leading edge mod I used to hear about (wrapping the leading edge with and
>thin skin of aluminum sheet to get rid of the scallops)? I would be very
>interested in hearing from anybody who has done or is considering se kinds
>Steve Kroll
I don't see it a as rather obvious necessity. Some people have more
faith in the strength of the Kolb airframe. Some newbies think the chute
should be thrown if the engine stops. Everything is a matter of choice and
personal opinion. If you feel safe in the Kolb design then fly naked. If
unsure and wish a little more security dress it up with a chute. It is well
worth it for your piece of mind.
In a message dated 7/26/01 10:43:12 AM Eastern Daylight Time, jrcasey(at)ldl.net
writes:
> In the interest of avoiding beating this dead horse some more...let's drop
> the deadstick thing. Everyone knows the pros and cons and its now a
> personal decision how to do your training...
> Next issue.... global warming? What say?
> Jeremy
> you are good Jeremy!
In a message dated 7/26/01 11:01:34 AM Eastern Daylight Time,
ul15rhb(at)juno.com writes:
> My question to the list is this:
> Has anyone flown a 582 in heavy rain and had it affect the engine? I
> have flown my 447 in light rains and not affected the engine, but I
> wonder about the effects of heavy rain.
> Ralph Burlingame
> I have flown my 447 KX Firestar in totally saturating rain with no hint of
> ill effect...as a matter of fact I was amazed at the "exploding" raindrops
> on the full windsheild.... the drops never stayed on the Lexan...the drop
> would hit and explode and disappear! I felt sorry for the guy flying the
> pterodactyl ahead of me...he was soaked to the bone!
Jimmy,
Westach are the people that build the analog type gauges. If Larry says he
talked to them and they said it's OK to use a switch no problem. Good
quality switch would be good with good connections to the wire.
They make dual CHT and EGT gauges. The can be obtained with either dual
CHT, or dual EGT, or one of each in single gauge. There is also a 3-1/8"
quad unit available but I think I would stay with the duals unless
needed. I got much more in our FireFly panel than you so your not even
getting tight. Good source for duals are Sky Sports, Lockwood, Aircraft
Spruce. I would stay away from Star Discount.
Note, if you can afford the EIS, you will not be sorry. It may cost you a
little more. Call Grand Rapids Tech. sob a little. PS get the large
size. The have a remote push button option (used to be free) where you can
hook up remote button to switch between displays if you can't reach the
display. We don't use it since all the values for the Tach, both CHTs and
both EGTs are on one screen.
>Lar.
>Larry Bourne
>Palm Springs, Ca.
>From: "JIMMY HANKINSON" <jhankin(at)planters.net>
>To: "KOLB LIST"
> > now.
> > Jimmy
> > Southeast, Georgia
> > JYL -- Airport
Sent: Thursday, July 26, 2001 12:50 PM
Subject: For Sale
Specs:
582 engine
Intercom
Flip Flop Com Radio
Srobe lite
Navigation lites
Seat upholstery kit
Exhaust cabin heat
least $18,000.00
Subject: For Sale
Specs:
582 engine
Intercom
Flip Flop Com Radio
Srobe lite
Navigation lites
Seat upholstery kit
Exhaust cabin heat
least 16,000.00
pictures are an attachment.
> group, I got the site once, very nice pictures but a cranky server---
> tried to go from one of the page's links and got stuck. >
You are right about that 'cranky' server. The server master has now
corrected the problem and it is back on the air!
Try again: www.kolbpilot.com
Jon
near Green Bay
Subject: | Re: FW: For Sale |
When trying to sell on the list it is a good Idea to tell us your location.
1.4 and hitting a ( energy depleting ) wind sheer at the
time of flair........... well 1.4 Vso just wasnt
enough.... been there.... done that.... but i am stil here
to where the tee shirt..... just need to get the tee shirt
and i will be set..
boyd
Thanks Woody. I am in Oroville Ca.
Sent: Sunday, July 29, 2001 8:06 PM
Subject: Re: Kolb-List: FW: For Sale
helicopter
location.
The leading edge skins idea has been batted back & forth several times, and
there should be plenty in the archives. The consensus each time has been to
forget it............seems to do more harm than good. Lar.
Larry Bourne
Palm Springs, Ca.
Sent: Sunday, July 29, 2001 8:26 AM
Subject: Kolb-List: Re: Kolb-List Digest: 23 Msgs - 07/28/01
> Dear list,
have 175 totally trouble-free hours on the plane and engine (503SCSI) I fly
the airplane solo (left seat) and notice a tendency for the airplane to roll
left slightly when I take my hands off the controls. I suspect that this
has more to do ith the fact that I (at 200 lbs) am sitting left-seat in a
380 lb airplane than the airplane being out of trim. Does anybody else
notice this tendency when flying solo in a 2-seater Kolb and, if so, what
have you done to correct this? Is it possible to correct this by adjusting
aileron without having to resort to a trim tab (or a sand bag in the right
seat)?
> Steve Kroll
Subject: | redundant fuel system |
Guys,
I read an article in the latest issue of ULTRALIGHT FLYING magazine about
redundant fuel systems. I know this has been discussed many times over
the years, but I have a different approach that I would like to get some
opinions on.
I don't have a rectifier on my electrical output, so instead of getting
an electrical boost pump, I thought of using another Mikuni single pump
in parallel to the other one as a backup. Both pumps would run
continuously and would share the common pulse line with a "Y" and both
inputs and outputs would be in parallel.
A dual mechanical pump would not serve the purpose, because they share a
common diaphragm.
I need some comments.
Ralph Burlingame
Original Firestar
14 years flying
Subject: | Re: Kolb-List Digest: 40 Msgs - 07/29/01 Engine out |
In a message dated 7/30/01 2:51:29 AM Eastern Daylight Time,
kolb-list-digest(at)matronics.com >
Well, saturday, someone was watching over me again on one of my rutine
flights. After a local 15 min. flight, I approached the field.and watching a
gyro taxing for takeoff, I turned base & final. On final the gyro took the
active and I announced my go -a -round. I banked left, added about 3/4
throttle, and about 15 to 30 seconds later it was as if someone applied a
choke to the engine (which I don't have). The 618 got slower & slower and
then quit. As this was happining I was shoving the nose over and banking
towards the field. I needed to pull up and go from 55 mph to 50 to clear
trees on the edge of the field. I then lowered again and questioned as to
whether I was going to clear the corn on the edge of the field. During all
of this, I managed to make 2 radio announcements. At this point I needed to
bank hard right because there was not room to land crossways. Luckily the
gyro saw me approach over the trees with a still prop and aboarted his
takeoff. I did manage to land ok at an angle across the grass, runway , and
then a small field that had just been cut by the neighboring farmer. It was
so close that a fellow pilot pulled two corn leaves out of my outboard
aileron hinge. If I was 20 ft. further away from the airport when this all
happened, I would have either been in the trees with my ballistic chute 1/2
open or in the corn field. It started ok on the ground (not as easy as
usual) and ran fine on a full runup with the tail tied down.. In flight I
had all normal readings. Water 150, egt 1050 in cruise, 1200 climbout, 15
gal fuel. As the engine was dying down, I had only time to "FLY THE PLANE"
and didn't look at instruments. I just thanked God for how the day came out
and put the plane away. Now I'll start going over it with a fine tooth comb,
as nothing obvious showed up ?
Safe Flying
Bob G Upstate NY
Not sure about it, but I've read not to do what you suggest. The pulse line
should not be shared, I was told. It divides the pressure and suction to
two low a level. That's what I was told, anyway.
Larry Davis
-----Original Message-----
ul15rhb(at)juno.com
Sent: Monday, July 30, 2001 9:48 AM
Subject: Kolb-List: redundant fuel system
Guys,
opinions on.
common diaphragm.
Ralph Burlingame
Original Firestar
14 years flying
From: | "Wood, John T." <woodjt(at)spawar.navy.mil> |
You have an interesting idea. Does the engine pulse produce enough pressure
to drive two pumps? If on one of the pumps fail and it is due to some sort
of leakage, will are the pulse energy take the path of least resistance and
neither will then work?
From: ul15rhb(at)juno.com [mailto:ul15rhb(at)juno.com]
Sent: Monday, July 30, 2001 7:48 AM
Guys,
opinions on.
common diaphragm.
Ralph Burlingame
Original Firestar
14 years flying
I'm listening to all of this, but not hearing about the engine side of
things. Forget about if you should do them or not, let everyone decide
for themselves, I'm worried about causing more of a REAL problem for
the engine than I have with the SIMULATED emergency.
Meaning.....what water and EGT temps are you guys dropping to in these
idle-ing in approaches? We know siezures are much more imminent with
the chill, but where do you draw the line? Wouldn't key OFF be better
since the cylinders wouldn't have the chilled water constantly around
the hot pistons? (until key ON again with power to make more heat and
keep the momemtum up for siezure prevention).
Nobody wants a $200 to $400 bill for siezed piston repairs, so where is
the balance? How are you doing this with the threat of siezure?
- perplexed in Palm Coast -
--- ul15rhb(at)juno.com wrote:
> Group,
> practices
> pilot
> all
> is
> of
> flaperons?
> Ralph Burlingame
John & Lynn Richmond :-)
Palm Coast, Fl.
Mk3 269LJ, 582, 41 hrs
1,400 miles, longest=270
http://phonecard.yahoo.com/
From: | "Kottke, Dwight" <dkottke(at)scherping.carlisle.com> |
Ralph and fellow Kolb brethren. The twin cylinder two stroke Rotax (or any
other brand) engine actually has two sources of vacuum to run a fuel pump.
You have two separate crankcases on each twin cylinder engine. Back in the
early snowmobile days Yamaha had a vacuum line running from the crankcase to
each combo carb/fuel pump. This could be done on today's Rotax, but you
would have to tear it down, drill a hole in the case, press in a barbed
fitting and then you would have two separate vacuum source's to run two
separate pumps. What would happen when one pump fails in an ultralight
plumbing application stills needs to be questioned. Has anyone given this a
try?
Guys,
opinions on.
common diaphragm.
Ralph Burlingame
Original Firestar
14 years flying
Dear John
I have misplaced your email address.Please send it to me.
From: | Andrew Gassmann <agassmann(at)earthlink.net> |
Subject: | Re: vortex generaters |
>Rick: Last October you sent me the measurements and drawings of the vortex
>generaters. I misplaced them and hope you still have the information and
>would do it again. I'm ready to try them. Thanks
>Dallas Shepherd
>Norfork, Arkansas
>Mark 3/2200 jabiru
This web page, and following, shows the installation and dimensions of the
vortex generators on a very nice Firefly.
http://www.thirdshift.com/jack/firefly/firefly17.html
Andy
Subject: | Re: Ultrastar for sale |
Mark
Just found your msg again after returning from Oshkosh. Sorry I'm so
behind in my e-mail. Had a great trip to the Islandsand Australia.
Sorry to hear of Charlies incident. Is he OK?
Seen Jewell and others from Wanamingo at Oskosh. Been enjoying the
Aventura alot. Took a trip to sisters and freinds cabins up north with
it. Also go on a flyin fishing trip every other night or so to a small
lake near here.
Bruce
From: | "Dave Stroberg" <dgstro(at)albemarlenet.com> |
Subject: | FirestarII amphibian for sale |
Listers,
There is a very nice 1996 FirestarII amphibian for sale in northeastern
North Carolina. Equipped with 503DCDI, 10gal fuel, Full Lotus monofloat
with removable wing sponsons, Ivo 3 blade, electric start, ASI, VSI,
dual CHT, single EGT/RPM, compass and extra set of wheels. Always
hungered, 126 hrs AF, 65 hrs E. Contact: Dave Stroberg, 252-264-2240 or
e-mail. Photos available.
Fly safe,
Dave
Kolb trivia:
a couple weeks ago, our EAA chapter was giving Young Eagles flights to a
bunch of kids from Northern Ireland that were in the states as part of the
"Ulster Project." (If you have an "Ulster Project" in your town, EAA Young
Eagles rides are something they will love!)
Anyway, when the Irish kids saw the MKIII, they promptly dubbed it the "Wee
Wasp."
Homer, what you started...
Richard Pike
For a Kolb, a chute is a function of engine reliability and terrain you
have to fly over. The airframe is as good as any GA aircraft. But in East
Tennessee, (trees trees and more trees) with an old (but apparently
reliable- so far) Rotax 532, a chute is not a bad idea.
Richard Pike
An adjustable trim tab on the right aileron is an easy fix.
Straight back when carrying a passenger, down when solo.
I added some streamlining this last winter. Top speed did
not change, but the RPM's needed to maintain a given speed went down.
Richard Pike
>Dear list,
>seat)?
>Steve Kroll
Richard,
That's hilarious.
Chris
Date: Monday, July 30, 2001 8:38 PM
Subject: Kolb-List: Wee Wasp
>Kolb trivia:
>Wasp."
>Richard Pike
Subject: | Mark III Extra Fuel Tank |
I am up against it now.... I was just notified by New Kolb that they
will no longer ship the 19 gallon gas tank:
"Regarding the 19 gallon gas tank, we will not ship it. We will refund
your
money for it.
The reason it will not be shipped is because our General Manager does
not
like the design. He does not feel that this tank would perform as well
as it
should. He was concerned about possible fuel starvation under certain
circumstances. The bottom line is that he does not feel that this
19-gallon
tank would not perform as we anticipated so we will not offer it
anymore.
I realize that you were looking for more fuel capacity. Unfortunately we
have no alternative to offer but the stock 5-gallon tanks.
I am sorry,"
Since I will be using a VW Engine I do not feel there would be a problem
with fuel starvation. However this fact is not going to get me the tank
that I purchased with my kit.
Is there anyone on the list that knows of a source for a 17-19 gallon
fuel tank that would fit my Xtra?
Thank you in advance!
Julian Warren
Eugene, Oregon
Hey Kolbers,
Can you combime the ELT antenna with the com antenna with a Y BNC connector
? Rather than having two seperate antenna's. Is this acceptable for FAA
inspection ?
Has anyone tried this. Your comments are appreciated. Thanks.
Hans van Alphen
Building MarkIII Extra
BMW powered.
Subject: | Kolb Accident On Way to Oshkosh |
I was a friend of Chucks--we went to high school together--I am a year
older. We were to meet at Oshkosh and camp together in the UL area--Chuck
was excited and looking forward to the adventure. I wondered where was
Chuck--there were rumers of lots of accidents--so we went to the FAA
building and Asked about N56CV--Chuck was born in 1956 and his initials
were CV--I learned of the death on Wittman Field--It was very surreal being
in that high energy place with all the positive and smiling people and
learning the depressing news--I just sat arpound the rest of the show.
Chuck was an experienced pilot--he was a part owner of a GA plane he kept
at Mankato airport. His uncle and some cousins also flew--he had been a
licensed pilot for almost 20 years and he was extreemely proud of building
the plane and was amazed at the performance. He packed up the plane and
practiced takeoffs with the full load on a 95 degree day--he said he would
have never flown in a GA plane like that. He said it handled great. He
had the standard 10 gallon tank and a spare 10 gallon tank on the jump seat
with a facet pump to transfer fuel. The plane was inspected by the
officials and the Kolb flyers around here gave it another inspection and it
was a solid plane. The last time I talked to Chuck he said he was leaving
Mankato at about 1:00.
Chuck had flown off the 40 hours over a month ago. Chuck did not were a
helmet.
The plane was taken to Eden Prairie for examination.
It sounds like several things went wrong. 1. Engine out--by it self this
should not be a fatal event. 2. Failure to land safely. Either he had
something jam his controls, or he landed in a cornfield or very rough area
or he stalled at altitude and could not recover. His landing gear were
bent and it was found upside down. Even that event is surviveable.
Everytime I saw Chuck He had a smile on his face--he was a good man.
I will never forget Chuck.
Dale Seitzer
Sent: Wednesday, July 25, 2001 11:50 PM
Subject: Kolb-List: Kolb Accident On Way to Oshkosh
I am so sorry to hear of this tragedy ... for the pilot and family ... and makes
me contemplate my own potential fate. I just looked up the places involved
with about 158 miles to go ... not quite half way. Appears that there were no
major towns or cities (or airports?) on his flight path from St. Peter to Minnesota
City. Wonder how much fuel he had on board .... whether he had a headwind
he have overall? In the interest of safety for us all, I'd be interested in hearing
Randy Berry
Kolb Firestar KXP
sn.com
Subject: | Re: Mark III Extra Fuel Tank |
The Overton's boating accessories catalog shows a tapered tank that looks
like it was designed to fit into the tapered area right behind the seats of
an Extra. It is 30" across the front, 18.5" across the back, 20" front to
back, and 9.5" tall. Don't know if it will fit or too big.
They also show a 19 gallon tank that is 18" tall, 14" wide, and 18.5" front
to back.
They show a 15 gallon tank that is 16.5" wide, 12.5" tall, and 17.5" front
to back.
I have 15.5 gallons on my MKIII with a 532, and that is about right for me.
Richard Pike
>Julian Warren
>Eugene, Oregon
From: | "J.D. Stewart" <jstewart(at)inebraska.com> |
Cabelas has a bunch of boat tanks that include fuel senders. A lot of
Challenger guys are using them instead of the stock tanks. They come in a
lot of different capacities and sizes.
http://www.cabelas.com/texis/scripts/store/+/CatalogDisplay/displayPOD/CabFA
LL1998/CabFALL1998AUASAD/IB251D
J.D. Stewart
Internet Nebraska-Norfolk
http://www.inebraska.com
UltraFun AirSports
http://www.ultrafunairsports.com
Challenger Owners E-mail list and Website Administrator
http://challenger.inebraska.com
> From: owner-kolb-list-server(at)matronics.com
> [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Julian Warren
> Sent: Tuesday, July 31, 2001 12:46 AM
> To: Kolb List
> Subject: Kolb-List: Mark III Extra Fuel Tank
> your
> money for it.
> not
> as it
> 19-gallon
> anymore.
> I am sorry,"
> Julian Warren
> Eugene, Oregon
Never "Y" transmitters (comm radio and ELT) together on the same antenna.
One acts like a load on the other. The ELT antenna can be a simple rod
antenna and can be "hidden" in the back of the airplane.
Larry Davis
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Hans van
Alphen
Sent: Tuesday, July 31, 2001 8:28 AM
Subject: Kolb-List: Re:ELT ANTENNA
Hey Kolbers,
inspection ?
Hans van Alphen
BMW powered.
The MarkIII Extra went on a diet--it lost almost 100 lbs. Now has center
stick, sling seats, less luxury, smaller aelerons and flaperons instead of
flaps --they are trying to get it down to 496 lbs--the original Extra was
too heavy. The new Kolbra has an enlarged door opening. The New Kolb
Co was not interested in having John Haucks plane in their area. Miss
P'fer was moved to right in ftront of the UL BArn and was a very popular
plane--I saw people running up to it because they recognized it--I saw John
getting his picture taken with dozens of people--I had the privelege of
helping to tie down and camping next to John for 3 days--we shared the food
we brought and heard some great stories from a true gentleman.
Dale Seitzer
Sent: Thursday, July 26, 2001 3:08 PM
Subject: Kolb-List: Oshkosh 2001
I just returned from my first trip to Oshkosh this morning.
Kolb Aircraft and Litespeed Aviation had a great display. Airplanes
looked real good in the pattern.
Ordered my Kolbra on Tuesday.
Links to Airventure 2001 pictures I took:
http://dellepro.dellhost.com/williamson/AV2001.jpg
http://dellepro.dellhost.com/williamson/KolbFF.jpg
http://dellepro.dellhost.com/williamson/KolbFS.jpg
http://dellepro.dellhost.com/williamson/KolbMKIIIXtra.jpg
http://dellepro.dellhost.com/williamson/KolbKolbra.jpg
http://dellepro.dellhost.com/williamson/KolbKolbra1.jpg
http://dellepro.dellhost.com/williamson/KolbKolbra2.jpg
http://dellepro.dellhost.com/williamson/KolbKolbraCockpit.jpg
http://dellepro.dellhost.com/williamson/VisitorMKIII.jpg
John Williamson
Arlington, TX
Kolbra on order.
jawmson(at)dellepro.com
Julian
Do you really want to go this way after what KOLB told
you?
THKOLB has given you their honest opinion and warning
of possible problems that could be "life threating"
under the right circumstances. REMEMBER, They are the
experts on that plane.
I will let you make the call as to whether or not you
should proceed with the 19 gallon tank.
However, I can tell you that I also am building a
MK3/xtra and got my 19 gallon tank, exactly the same
as THKOLB sells, at a marine store. It was called a
"bow Tank". I can take a look at it this weekend to
see who the Manuf. was and the model number. I might
still have the receipt,I bought it locally.
It was apx. 1/2 the kolb price which was a fair
mark-up by Kolb in my opinion, because they put in a
lot of design effort and also provided a install kit
and instructions. Of course you will have to make your
own inst. kit IF you go this way. You also have to cut
two frame members just behind the seats to put the
tank in place (per the KOLB instructions)These tubes
are then spliced back together with larger diameter
tubing acting as sleeves.
IMPORTANT!!!
Again let me caution you that I AM NOT supporting it's
use but am only giving some info IF you chose to
continue down this path (as I have).
I don't want anyone on this list to read about either
of us in an accident report some day due to a problem
caused by this tank.
Regards, and please give this a lot of thought.
Ed
MK3/X
Dallas Tx.
> New Kolb that they
> it. We will refund
> your
> money for it.
> not
> as it
> feel that this
> 19-gallon
> not offer it
> anymore.
> tanks.
> I am sorry,"
> for a 17-19 gallon
> fuel tank that would fit my Extra?
> Julian Warren
> Eugene, Oregon
> through
> Matronics!
From: | "Randy Berry" <sc_bassman(at)hotmail.com> |
Thank you for the update, Dale. I, too, have lost aviation friends, so know the
feeling ... and feel this loss as well of a fellow Kolber :-(
Sent: Tuesday, July 31, 2001 9:43 AM
Subject: RE: Kolb-List: Kolb Accident On Way to Oshkosh
was excited and looking forward to the adventureGet more from the Web. FREE MSN Explorer download : http://explorer.msn.com
Cylinder head temp (CHT) guages are also useful for measuring minimum
temps--Phil Lockwood said air cooled rotax engine should not be given full
throttle if less than 200 degrees CHT.
Dale Seitzer
instrument?
> Jimmy
> Southeast, Georgia
> JYL -- Airport
Jimmy,
It is certainly true having two double instruments, a quad instrument or
an EIS is a better solution than switching. However, if you do decide
to use a switch one aspect hasn't been mentioned. Because of the low
voltages involved (millivolts, not microvolts) you need to switch *both*
leads from each sensor. In other words, two double pole double throw
switches (one for the two CHT leads and one for the two EGT leads) or
one four pole double throw switch.
For the same reason you need high quality contacts. Any good
electronics supply company will have 4p-2t rotary switches with gold
flashing contacts. I have a 4p-4t switch like this on my homebuilt to
monitor all four cylinders of its Lycoming. But such a switch will take
up the same room as a second dual guage.
Tom Kuffel
Whitefish, MT
Building Original FireStar
Hans,
The short answer is no.
If the ELT is turned on it will probably damage the front end of the com
receiver.
Both ends of an aircraft radio cable should have an impedance (fancy
word for resistance to alternating current such as radio frequency
energy) of 50 ohms. Doing what you propose will make all three units
(the com radio, the ELT and the antenna) have an impedance of 25 ohms at
the far end of each units' cable. This will degrade performance both
transmitting and receiving.
Turning on the com tranmitter will probably, only probably, not harm the
ELT unless you have the expensive kind where you can plug in a headset
to both talk and listen.
Don't know but no radio shop would think it a good idea.
Do keep us informed about your motor. New engines are always a topic of
interest on the list.
Tom Kuffel
Whitefish, MT
Julian
Since my original reply I have located my 19 gal.tank
info and receipt. (I had hidden it so my wife would
not find it. This is an important step when building a
plane.)Always remember--hide all receipts!!
If you don't, your story that the plane only cost
$5000 will be exposed.
The 19 gallon tank that Kolb WAS using is manufactured
by --MOELLER MARINE PRODUCTS
801 N SPRING ST.
SPARTA TN. 38583
TEL#-931-738-8090
The model number is #32819
They only sell through distributors but can tell you
of one in your area. The distributer will likely not
sell direct either but will tell you a dealer in your
area. This may not be a stock item for your dealer and
they will order it. I had some trouble with my dealer
in that he could not find this model in his catalog
but we went back to the Dist. and he helped him order
the right tank.
Tank comes with Stewart Warner sending unit and S.S.
hold down straps. I have not figured out a way to use
these in my installation. Maybe you can do the Brain
work and let me know what you come up with??
I will take the lazy way out and let you blaze this
trail.
I also bought some fuel tank inlet hose and a cap
assembly that I am thinking of mounting on the outside
of fuse cage. No real plan as yet however.
Ed
Mk3/X
Dallas,Tx.
> New Kolb that they
There are small thin flexible antennas available for ELT applications.
>Hey Kolbers,
>inspection ?
>Hans van Alphen
>BMW powered.
Subject: | Not receiving all list posts |
Greetings,
Yesterday I received 3 posts and today only one post from the Kolb list. They
are replies from other posts I didn't get.
Are other AOL users having the same problem? If so they probably will not
get this post.
Will Uribe
El Paso, TX
FireStar II
http://home.elp.rr.com/airplane/
Subject: | Re: Emergency Landing Practice - Eng Temps |
I don't take off until my cylinder heads are at least 200 degrees F, period.
Once running the entire engine warms up, case, cylinders, heads and
all. On an air cooled engine it unlikely you should experience any seizure
as long as the engine is still running. If you shut down you have lost
that heat source but it should still take time to cool the entire mass as
the heat slowly dissipates.
Not that familiar with the water cooled Rotax's but I would think again
that once the mas is warmed up, it will not cool it down that fast or to
the point of being a seizure issue as long as the engine is still
running. If you shut it down, the heat of the mass would be absorbed by
the water but the water since the engine is stopped is not flowing, would
stay trapped around the cylinders. However if stopped, the cylinders and
the engine mass would begin to slowly cool, but should not be an immediate
cool down.
Shutting the engine down for gliding is more of an issue since yes it can
totally cold soak. We have a motor glider using a 912 in a hangar down the
way from us. If I recall right the owner stated he has to restart the
engine and allow it to warm up before applying any high power settings for
that very reason.
Subject: | Re: Kolb-List Digest: 18 Msgs - 07/30/01 |
of getting
single pump
in parallel to the other one as a backup.>>>>>>>>
it would not be hard to put in a rectifier........go to your
local electrical suply and but a full wave bridge
rectifier, making sure it will handle the current load,
put in a small batery and then install an electric pump...
boyd
Hi Gang:
I returned to the nest at Gantt Int AP at 1315, 30 July
2001. Thirty days on the road and 134 flight hours to fly
to Point Barrow, Alaska, down to Washington State, across
the US to Oshkosh, and almost due south to Titus, Alabama.
Off the top of my head I flew 21 of the 30 days. That is
about 6.4 hrs per day for the 21 flt days, or 4.5 hrs per
day for the duration of 30 days. My estimate prior to the
flt was 130 hours total. Remember that I flew 4 hrs for
free the day I had to back track to Weyburn, Saskatchewan,
to retrieve my forgotten bag and water bottle. I still have
not totaled my fuel burn or what it cost to purchase that
fuel. However, it should be about 670 gals. I bought 3 qts
of Mobil I 100% Synthetic 15w50 oil and a filter in North
Pole, Alaska, for an oil change.
The flight to Barrow was a complete success. The most
enjoyable to date, with the exception of getting sick on my
return to the lower 48. I left a trail of toilet paper
across the mountains and plains as I coughed and blew my
nose. I was surprised on several occassions to see toilet
paper stuck to lift struts, gear legs, tail wires, tail
wheel, and horizontal stabilizers. I am still coughing and
blowing the snoz. :-)
The 10 yr old MK III and her new Rotax 912S performed
impecably. All my gear worked as intended. The Chilli Vest
was worth the purchase price and more when time for it to be
used arrived. It is virtually weightless, draws a very
minimal amount of 12VDC power, and keeps the old body warm.
Everyone I met along the way was kind and supportive to this
old man and his little home built airplane. The few that
knew little or nothing of our way of flight, were ignored
when they made their unqualified comments about what my
airplane looked like. :-) About the best comment was made
by an Eskimo gentleman driving a water truck or a honey
wagon in Anuktuvak Pass, Alaska, within eye range of the
North Slope, "I like your airplane!" he shouted to me with
the biggest smile possible, as he slowly drove past the
airstrip, his upper torso and left arm out the window of the
truck, waving grandly.
My heartfelt thanks and gratitude for everyone's help to
make this flight possible and a success. Just knowing you
all were here at home waiting to find out where I was, how I
was doing, and where I was going, was enough to keep me
going. We showed all the non-believers that little
airplanes built in basements can accomplish goals that
larger, "sophisticated" GA and experimental airplanes only
dream about. :-)
Thanks again for you support.
john h and N101AB (Miss P'fer)
Hey Bob G, great flying, bet you needed an underwear change
Don Mekeel, FF oo2, El Paso, Texas
Subject: | Gotta Go--Gotta Go--Gotta Go!!!! |
I am sure most of you have seen that commercial. It was made about me.
Has anyone installed a relief tube in a Kolb? If so, I would like some
details. I intend to install one in my FireStar if I can figure out how
to do it.
Ron Payne
From: | "Richard Neilsen" <neilsenr(at)state.mi.us> |
Food for thought . I originally planned on one of the larger fuel tanks for my
VW powered MKIII. I have found that my engine burns app. 3G/Hr which gives me
2hrs. of flying time with a comfortable reserve. I find that for 99% of the flying
I plan on this will be enough of a fuel capacity. Also after 1.5 hours of
flying I find that my butt, or my head being squeezed by my head phones, and/or
my blatter starts objecting.
From the safety stand point its always recommended that you FILL the fuel tank/s
after each flight to minimize condensation. My VW powered MKIII weighs in at
554lbs. and is going to have 30lbs added for a reduction drive. I'm no light
weight and I will be enough over gross weight with two people on board without
flying around with an extra 50 lbs. of fuel. If take a trip I will load up extra
fuel tank/s in the passenger seat and/or one of my storage compartments.
My .02 cents worth
Rick Neilsen
VW Powered MKIII
>>> edgmills(at)yahoo.com 07/31/01 11:54AM >>>
Julian
> period. Once running the entire engine warms up, case, cylinders, heads
and
seizure
as
Jerry and others,
In a similar fashion, for the good boy scouts out there, if a practice
deadstick landing is initiated, slowly bring the throttle back and hold
at idle for 5 seconds before shut down. This is to prevent thermal shock
to the engine.
Did I say that "D" word again?
Ralph Burlingame
Original Firestar
14 years flying
> local electrical supply and put a full wave bridge
> put in a small battery and then install an electric pump...
> boyd
Thanks Boyd, here's an answer that a friend gave me that is interesting:
What happens when a pump fails? I will assume for now that the diaphram
ruptures.
I will also make another assumption: the pump works on both positive and
negative pulses from the engine.
IF the above two assumptions are true, it would seem to me that if the
diaphram on one pump fails, then the pulse from the engine would no
longer operate the other pump since the pulse would have nothing to push
or pull against on the failed pump. Check valves are not an option since
the pulse is both positive and negative.
No matter what kind of parallel pump scheme is used, both fuel lines need
check valves to prevent reverse flow through the no-operating pump.
Personally, I think that rectifying the output of your electrical system
and running an electric boost pump would be the best way to do it. One
could even go so far as to add a pressure sensor to the fuel line of the
pulse pump, and have the boost pump operate only when needed (very handy
for cold starts!). A by-pass switch could be added to run the boost pump
continuously.
Doug
Ralph Burlingame
Original Firestar
14 years flying
I think I speak for a bunch of folks when I say "Good Job"...now take a
break...you deserve it!
Jeremy Casey
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Hauck
Sent: Tuesday, July 31, 2001 3:05 PM
Subject: Kolb-List: Safe at Home
Hi Gang:
dream about. :-)
Subject: | Re: Not receiving all list posts |
Not on aol, Will, but for comparison, I got 14 messages from the List
between 8:00 AM & 1:30 PM today. Seems like I miss one from time to time,
as well. Lar.
Larry Bourne
Palm Springs, Ca.
----- Original Message -----
Sent: Tuesday, July 31, 2001 11:09 AM
Subject: Kolb-List: Not receiving all list posts
> Greetings,
They
> get this post.
> Regards,
> Will Uribe
> El Paso, TX
> FireStar II
Subject: | Re: Gotta Go--Gotta Go--Gotta Go!!!! |
Some people with incontinence problems wear the bags that attach for day use. This
may be the application for you.
Or you could go with the home made version. These are called pee tote tubes. Head
on down to the local medical supply store and get some surgical tubing. You'll
need to expand a coupe of sizes from discharge size to fit YOU. Some guys
use sawed off mini bottles. Some claim they need coke bottles. Drill a hole through
your floorpans to push the surgical tubing through. Don't set food on your
tail feathers anymore after you start using this device. Getting this to fit
yourself right is the key. You will look very stupid dismounting your plane
while wearing this device. Almost alien. :-)
Or you could simply hold until you can land!
B.J. Moore, P.E.
Circle Four Farms Development Engineer
ASC Basic Flight Instructor - "The Flyin Moose".
>>> ronormar(at)apex.net 07/31/01 01:42PM >>>
to do it.
Ron Payne
From: | Eugene Zimmerman <eugenezimmerman(at)dejazzd.com> |
Subject: | Re: Safe at Home |
John Hauck wrote:
> Hi Gang:
snip
Congratulations John,
I admire your courage and your persistence. Hope your soon feeling better.
Eugene Zimmerman
Ron,
This is too easy! Grab an old pc. of most any kinda hollow stuff---like
a pc of hose. Diameter depends upon yer GPM output, but even small stuff
works OK 'cause you're gonna, with any luck at all, have a partial
vacuum (neg pee press) in the overboard line. Next "find" a funnel of
the correct size--correct is a personal thang. Stick the hose into the
end of the funnel, or vice versa, according to the respective sizes.
Drill/punch a hole near the rim of the funnel. Form a hook outa a scrap
of old bare copper house wiring--other end (called bitter end in the
Senior Service) you put thru hole in funnel and bend closed. Make a loop
outa a TyWrap at some convenient place to hang the funnel. Leave enough
slack in the input end so that it can reach to somewhere near the middle
of the seat.
Now route the tubing overboard thru a neat hole cut in the belly fabric.
Good to cement a cloth grommet around hole for chafing protection--and
chafing is quite painful. Run hose down right gear leg (less splatter
this way) and secure near axle with a hose clamp. Before tightening the
clamp, insert one end of a 90 degree elbow in end of hose, AND POINT IT
AFT--BACKWARDS--TO THE REAR, or you'll be sorry.
Next week I'll tell you how to use it.
Oh, I fergot. As with many things, there are more than one use for this
device. When working on the brakes, it makes a great interphone. Just
blow on the proper end when you want the other guy to "pick up." This
same system was used on many ships--hence the term: Get on the Blower.
Bob N.
http://members.nbci,com/ronoyer
Well - chaulk me up as another customer screwed by Airstar. And man talk
about rude!! WOW!
Mark
behind in my e-mail. Had a great trip to the Islands and Australia.
charlie is fine, he is rebuilding it, and is almost done.
lake near here.
I want one, maybe when my house is paid for in a few years.
by then I should be able to get a used 912 to put on it.
and get a sport pilot license if it goes through.
mark
I want to thank each of you who sent me input into my fuel tank
problem. It was very much appreciated.
Installing my fuel injection system tomorrow. Hopefully will have it
running this week. I am not going to be able to furnish thrust figures
until I get the scales. I will know however about my reduction drive
and prop combination, and how quickly I can achieve 3800 RPM indicated.
If I can generate 90 hp it should be generating about 5# per hp
according to local AP.
Julian Warren
Eugene, Oregon
Subject: | Re: redundant fuel system |
Hello fellow Kolbers,
Here is my experience with the subject at hand. I have two pulse pumps
installed on my Firestar with 377 Rotax. They both share the same pulse
line plumbed as close possible to the engine pulse port. One is a single
carb pump and the other is a dual carb pump. The single pump is plumbed
to draw fuel from the bottom of the tank and into the carb as usual.
The dual pump is plumbed to draw fuel from the top with the line going
through the fuel cap with a clunk and screen reaching to the bottom of
the tank. The one outlet line is plumbed with a shutoff valve and teed
into the carb line. The other outlet line is plumbed with a shut off
valve back into the top of my main fuel tank. I open this valve to
transfer fuel in flight from auxiliary tanks to my main tank by
switching fuel caps with the clunk and screen and drawing fuel from the
auxiliary tanks.
With this system I can run with one or both pumps supplying the fuel to
the engine, except for while I am transferring fuel from one tank to
another, then I am running on only one. With this system I have carried
approximately 18 gal of fuel in five separate containers.
I was astounded at the rate of fuel transfer this set up can produce at
cruise rpm.
My response to the concern about what happens when one pump fails, The
only pump failures I have seen are when the small flapper valves go bad
and malfunction. The flow of the functioning pump I believe will be more
than adequate to supply the engine, and two valves would need to go bad
at once for fuel to back feed from the operating pump back through the
bad pump into the tank. As far as a catastrophic failure of a diaphragm
vacuum leak. I've never seen one.
For maximize pump performance keep pulse lines as short as possible and
as smooth a flow path as possible for maximize pulse wave.
I am not recommending anyone try this. It is just my experience and I am
happy with the results. It does introduce additional hazards while flying.
Eugene Zimmerman
From: | "Beauford Tuton" <beauford(at)tampabay.rr.com> |
Btrother Hauck...
Well done, Soldier...
Beauford
> Hi Gang:
Subject: | Re: Gotta Go--Gotta Go--Gotta Go!!!! - Reqmts |
With a project of this importance we need to make sure we all the
requirements identified and documented.
Is this to service a single gender or both?
You will need to be available for measurements and test fitting during the
engineering process - if you not be available then casts will be required
during the engineering phase.
Will a holding tank be utilized or will the could seeding process be deployed.
Lots of liquids (beer) will be required on hand during the prototype ground
and in flight test.
Please add or expand upon requirement which make have been missed:
>to do it.
>Ron Payne
>snip... You will look very stupid dismounting your plane while wearing
Oh man, I could just imagine that happening .... just think if vacuum from
the slip stream made it where you couldn't get it off and then the swelling
takes over .....
Subject: | Re: gotta go.... |
As I posted abt a year ago, I found that it didn't pay getting the plane
captain peed with you. Had a slight case of reversed-direction belly
outlet.
Bob N. wwii
Hi Julian I want to tell you about that tank that Kolb was selling. I
bought one had it here and did not like it and took it back and advised them
not to sell it any more. The point about fuel starvation is in my opinion is
where the fuel pickup was located I could see picking up air at times when
you are gettin low on fuel. Also they were recommending not using more than
14 or 16 gal I think. It was heavy , you had to cut out a section of the
frame between the seats to get it in there. I did not like it at all,there
was no baffles in it and there should have been because it was so large and
flat.
So I now have the two 5 gal tanks and will stay that way until something
better comes along.For long cross country trips I plan on straping a 6 gal
tank in the pass seat with a fuel pump straped to it that I can turn it on
and it will be connected to one of the tanks. So all I have to do is flip a
switch and it will put 6 gal in the tanks in flight. That will give me14
gal of useable fuel. And the two 5 gal tanks is a good system.
But if you want that tank that Kolb was selling you can get it from
Overtons boat supply.It is on page 99 and the part number is 30524 for
$129.00.I would advise against it.
Some day I will probably have someone build me one,maybr Kolb will start
offering one made out of aluminum.
Hope this helps. Keep In Touch
Bill Futrell
Sent: Monday, July 30, 2001 10:46 PM
> your
> money for it.
> not
> as it
> 19-gallon
> anymore.
> I am sorry,"
> Julian Warren
> Eugene, Oregon
From: | "rbaker(at)shop4zero.com" <rbaker(at)ccgnv.net> |
Listers,
I have been holding up with this question until everyone recovered from
OSH.
Weighed "HOW MUCH! (I failed to hide the invoices) with the following
results. Total weight 599.5. On the heavy side but no surprise with
BRS, ELT, 912 and wheel pants, 10 oz. strobe on tip or horizontal
stabilizer and 3 lb. tail wheel replacement for Kolb tail wheel.
As I weigh in at 167 pounds, I will be carrying 40 pounds on the floor
of the passenger side -16". According to page 68 of the builders manual
this does not appear to be too far off. With my self, 120 pound wife
and a full load of fuel on board, we are in good shape at 32.5% and
950.5 pounds.
The empty (No fuel) weights are Right Main 264, Left Main 262,
Tail Wheel 73.5. Backing into the pilot/passenger Distance by a
second weighing with the pilot on board, gives distance of -1.3". I
would be interested to know how these distances and weights compare with
others.
Measuring from the propeller to the nearest point (Flap Tube) I find 7"
of clearance. The prop is mounted on a 4" Rotax extension. I am
wondering if I should consider slightly longer motor mounts to move the
912 forward a couple of inches.
All comments and input solicited and appreciated.
L. Ray Baker
Lake Butler, FL
Mark III, 912,BRS,N329RB.
Not quite ready for FAA
Hello,
Can anyone tell me what aluminum alloy to order to replace a bent landing
gear?
Thanks in advance,
Tim Barry
Firestar KXP
Tucson, Arizona
From: | "Frank Reynen" <frank_reynen(at)ix.netcom.com> |
Julian,
I added a 6 Gall PE marine tank behind the two-5 Gallon std tanks and all
are connected up to a common manifold.
The marine tank is a smaller tapered bowtank and fits nicely in the
triangular area in the back of the cage. It is sold at West Marine and other
places for use in small fishing boats with outboard motors and cost about
$35.00.and weighs about 7 lbs installed with the saddle included.
The top of the tank is even with the other tanks and since it is flatter
than the std tanks, it will empty first and there is no need for an
additional fuel sender.
The tank has a visual fuel level indicator on the top so you can see how
much fuel is in the tank before you take off. The tank can be filled
directly via the top fill opening or via the other tanks which is usually
the way I fill it.
The saddle that holds the tank is strapped to the boom tube with 4-heavy
duty hose clamps.The tank fits just through the upper side opening of the
cage when the regular tanks are removed and you only need to remove the
3/8"center rod from the rear of the cage to the back of the cross tube that
runs behind the fuel tanks to get it in there.
And since all the fuel is divided into three individual tanks, there is no
worry about fuel sloshing.
Frank Reynen
MKIII/912/Full Lotus @ 635 hrs
http://www.webcom.com/reynen
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Sent: Tuesday, July 31, 2001 10:33 AM
Subject: Re: Kolb-List: Mark III Extra Fuel Tank
Sorry,
I forgot to mention in my other post that this 3-tank arrangement can be
viewed in my website ,below, under "Tech Info " and "912 reverse carb
installation" side picture.
From the desk of C D Patterson
On an Island in the Pacific
Absolutely necessary to examine all requirements [g] Seriously, check the
Kayakers sites and supplies, devices are available for both needs, and could
surely be adapted .
/cdp
I think I'll watch YOU blow on that "bitter end." Yuk yuk. Now,
seriously, I had that same problem while driving, up till last Nov. Had to
go frequently, and only a bit at a time, like an ounce or 2. And it had to
be RIGHT NOW ! ! ! Frustrating, aggravating, & uncomfortable. While
travelling, it's not convenient to stop every 15 - 20 minutes, so I worked
out a deal that worked well for a solo driver; not sure about a
pilot............great caution would be necessary. In a 20 oz pepsi bottle,
cut a hole 1/2 way up the side, large enuf to 'dangle' in. Wear warm up
pants with the crotch slit, for easier access. Before you laugh, it doesn't
show when standing, or walking. When 'relieved', empty it into a 1 liter
pepsi bottle - the bigger one with the large mouth, and put the cap on it.
You don't want the one with the hole in the side to tip over...........not
even a little bit. I wasn't going to say anything, but it looks like
solutions are getting graphic, so this's mine...........it works, and with
no tubes, or whatever. First couple of times, it's pretty awkward, then it
smooths out with practice. If any ladies are reading this, and get
offended, please................that's not my intent. I know full well -
only too well - what a tremendous problem this can be, and this solution
works. Uh..........No............Sorry.............No Pictures this
time. Cured Lar.
Larry Bourne
Palm Springs, Ca.
Sent: Tuesday, July 31, 2001 2:47 PM
Subject: Re: Kolb-List: Gotta Go--Gotta Go--Gotta Go!!!!
> Ron,
> of the seat.
> Bob N.
I have the 16 gal aluminum tank sold by TOK. I can send pics and
measurements, if you like. Lar.
Larry Bourne
Palm Springs, Ca.
> your
> money for it.
> not
> as it
> 19-gallon
> anymore.
> I am sorry,"
> Julian Warren
> Eugene, Oregon
From: | "Edward Steuber" <esteuber(at)rochester.rr.com> |
The relief tube problem can be "safely" accomplished by employing the
use of a small 2" venturi that ,properly placed in the slipstream,will
direct the relieved liquid in a positive removal to a new environment .
Try to accomplish this task in remote areas or we all may be looking at
a new issue to battle in our fight to be
legitamized......Hmmmmm.......My troublesome neighbor has a pool under
the approach end of my runway.......Ed in Western NY
From: | "Michael Sharp" <mlsharp_1(at)hotmail.com> |
Sporty's Pilot shop used to sell a H.E.R.E. (Human Element Range Extender)
Even had an adapter for the ladies....
If memory serves, a bottle with tubing and an "adapter" for the
equipment.....
they are online...
mike
Listers,
Sporty's Pilot Shop used to sell what they called a H.E.R.E. (Human
Element Range Extender), now they call it "Little John". 32oz.
capacity, $4.95, can be adapted for either gender. (Autopilot anyone??)
Fly safe,
Dave
You need to post a picture of that arrangement for all to see.
Richard Pike
MKIII N420P (420ldPoops)
>Julian,
There is another solution, but it takes a lot longer to implement.
Several years ago I was diagnosed with a prostate gland that
was starting to have problems, and it was creating the need to
go more and more often. Had to get up several times during the
night, trips in the car were a hassle, etc.
A friend of mine suggested taking Saw Palmetto herbal extract
and it has turned things around. It is like being 18 again, at least
in the "gotta go" department. During the annual medical exam,
when the Dr. gives the dreaded "finger wave", he says the prostate
has apparently returned to normal. (Sorry for the graphics, but what
we really want is a solution, and this is my bona fide experience)
It takes a while before you notice any improvement, at least six months.
Apparently it stimulates growth of healthy tissue?
I have been taking it for about ten years now, 1 pill a day.
It may not help everybody, but what have you got to lose?
Richard Pike
From: | "Dallas Shepherd" <cen23954(at)centurytel.net> |
All you have to do is practice peeing in a reclining position
in a Kolb. Could be a problem?
Dallas Shepherd
Norfork, Arkansas
Mark 3/jabiru 2200
Sent: Wednesday, August 01, 2001 5:10 AM
> equipment.....
> they are online...
> mike
>BMW Powered
>Tom Kuffel
>I don't know the answer to your question but I sure would like to know more
>about your BMW power.....
>Geoff Thistlethwaite
Hey Tom, Geoff and Listers,
Yes I am building a Mark III Extra with a BMW motorcycle engine. My
obsession with the BMW started when I met Charles Kondas at Sun-n-Fun 3
years ago, where he held a seminar on the subaru conversion. He had used the
BMW on his Avid, but since it was a tractor application, he had trouble with
cooling in his cowling and gave up on the project. But he stated that it
would be an excellent engine for a pusher. I was hooked on the BMW engine
from that point and was determined to make it work.
I bought a used engine and ran it on a test stand. Then I went out shopping
for an airplane to put it on. And ofcourse the Kolb MarkIII was the choice.
So last year I went to Sun-n-Fun and saw the new Mark III Extra. I was sold
and ordered the fastbuild kit. I thought I was a pioneer untill I found out
on the internet that these engines are flying all over europe and
south-africa, at least 40-50 BMW's on all kinds of ultralights,kites,
pushers and tractors. They even sell the adapter plates to mount the Rotax C
gearbox to the BMW. I have mounted the stock engine which is 60-hp to see
how it flies, it can be modified to 78-hp.
See www.airdale.com/bmw_engines.htm for more details and pictures.
I am adding a centrifugal clutch to the rotax C gearbox for easy starting
and idling at 800 rpm, quiet and smooth.
I hope to have it flying in 2 or 3 months, I am almost ready for covering.
We'll keep you updated.
Hans van Alphen
Jupiter, Fl.
N100MX
General aviation freighters employ the venturi system but my A&P friend told
me they promote corrosion where ever the liquid sprays on the tail.
He had to replace some panels and was not very happy working in those areas.
Will Uribe
El Paso, TX
FireStar II
In a message dated 8/1/01 7:39:28 AM Eastern Daylight Time,
esteuber(at)rochester.rr.com writes:
rbaker(at)shop4zero.com" wrote:
Hi Ray,
Your numbers sound about right. After installing the Verner I have the
following zero fuel weight numbers: 258, 270 and 75 for a total of 603
pounds. I have a real tailwheel with tempered 4130 strut, fiberglas bucket
seats on aluminum seat pans, steel gear legs, ELT, panel mounted radio and
full set of engine gauges. These measurements were made with a calibrated
Roadrunner scale set - very accurate.
With my 218 pounds of pork on board the CG comes in at 34.9%. At max gross
and full fuel it is 28.7% As you know, 20% to 37% is the allowable CG range.
If I can ever find some simple seats to install my airplane will lighten up a
bit.
Bill George
Mk-3 Verner Powerfin
> about rude!! WOW!
Sorry to hear you were burned also!
I just got off the phone with the Adv. Editor of Ultralight Flying
Magazine. I told him I had sent a letter to his Editor about the way I was
treated by Airstar and didn't think they should allow this kind of
advertiser in their magazine. He said he hasn't seen my letter yet, the
Editor has been away at Oshkosh, but they have received other complaints
about this guy. He also said that they have been trying to make contact
with this outfit with no success, Surprise, Surprise!!
I have also contacted the editor of Kitplanes magazine and told her of my
experience. If the rest of the guy's that have been burned by this outfit
would contact these publications, maybe they would stop accepting their
advertisement and keep others from having a similar experience. I've told
them that I feel they owe their readers and subscribers to not allow this
type of fraud.
Terry FireFly #95 Quarryville, PA
From: | "William Herren" <wmdherren(at)hotmail.com> |
Valley Engineering of Rolla, Missouri, has purchased Culver Props
-inventory, design rights and name and is relocating to 19975 County Road
8280, Rolla MO, 65401 Phone 573/762-2882. That's from Aug Sport Aviation
Mag. Bill in Lousyana
Ray and Gang:
Kolb MK III, SN: M3-011, empty weight 630 lbs aprx.
Max gross at take off, full fuel and gear: between 1,000
and 1,200 lbs.
Fuel tank: 5052 alum sheet by .052, welded, cross baffled.
Ultimate/useable capacities: 25 gal/25 gal.
Two longerons were cut and bolt plates welded on to permit
installation and removal of tank. Has worked with no
problems for 10 yrs and 1,600 hrs.
On top of 150 lbs of fuel I add about 125 to 150 lbs of gear
in the rear cargo hole under the fuel tank, some in and
under the seats, and the rest in the nose of the nose pod
and in Miss P'fer's bag on the deck in front of the left
seat.
I weigh about 175 lbs. Have no cg problems in this
configuration, whether full or nearly empty fuel. Have
flown this aircraft in all configurations that I can think
of with no negative handling characteristics that could be
attributed to a problem with acceptable cg. Had the same
experience with my Firestar and 18 gal alum tank, gear, and
me.
The Kolb design is remarkably tolerant to cg changes and the
most forgiving fixed wing aircraft I have flown. One of the
reasons I stick with it. Satisfied with what I am flying.
Have not found a suitable replacement to take its place.
Take care,
Subject: | Re: Kolb-List Digest: 48 Msgs - 07/31/01 |
I don't have time ffor downloading this message nor the inclination. I call
it up to read, not downloading etc. I'm about one step from cancelling you
out.
Don Mekeel FF002
El Paso, Texas
HUH? Having a bad day?
Jeremy
DMe5430944(at)aol.com
Sent: Wednesday, August 01, 2001 2:31 PM
Subject: Kolb-List: Re: Kolb-List Digest: 48 Msgs - 07/31/01
out.
Don Mekeel FF002
El Paso, Texas
Subject: | cherry grove anual fly-in |
the 9th annual cherry grove central airpark flyin is on aug. 26th starting
at noon or so.
the cherry grove airpark is about 20 miles north of rochester mn in a small
town called wanamingo. the air field is 2 miles south of wanamingo, for
radio users we use. 122.9 or CB radio ch. 20.
I hope to see everyone from the southern minnesota area there. driving is
also welcome.
Mark
open twinstar
wanamingo mn
Subject: | Re: landing gear |
>Hello,
>gear?
7071 t6 I believe
Please don't!!!!
Forgive us!!!!
We'll try to do better!!!
ROTFL!!!!
>out.
>Don Mekeel FF002
>El Paso, Texas
writes:
> Hello,
> landing
> gear?
> Thanks in advance,
> Tim Barry
> Firestar KXP
> Tucson, Arizona
Tim,
I checked and it's 7075 T6 tapered gear. There used to be the thinner,
short gear for the Firestar and the wider heavy duty type for the
Twinstar and Mark II, III. I took the sleeve out of my Firestar gear
socket and used the heavier gear leg. I did not cut them off and my
Firestar sits up higher on the nose and I can make full stall landings
with them.
Ralph Burlingame
Original Firestar
14 years flying
I have bent mine twice and put them in a press and straightened them. Does
real nice. They weren't bent double ya understand but pretty bad. I called
the Kolb factory to rreplace them and they told me to straighten them. I was
worried about fatigueand cracks but no cracks showed and it has not been a
problem.
Sent: Wednesday, August 01, 2001 3:27 PM
Subject: Re: Kolb-List: landing gear
> >Hello,
> >gear?
> 7071 t6 I believe
Subject: | Mark III large fuel tank |
I also ordered the large tank but TNK keep telling me it was recalled &
being redisigned. Talked with Danny at Oshkosh last week and got the same
news as Julian did. Danny seemed to be more concerned with the extra weight
of the tank rather than fuel starvation when I talked with him. He said to
contact TNK for a refund.
Thanks to all for the good information on other tank options.
Rody in Cincinnati
Richard,
Did you get my second message that there is a picture of this tank setup in
my website?
Look under "Tech Info" and "912 reverse carb installation "and the first
picture shows the three tanks.
If you want more info, let me know.
Frank
Sent: Wednesday, August 01, 2001 10:26 AM
> Richard Pike
Thanks to all who responded. My bent gear was not too bad. Maybe 10-15
degrees. I tried to bend it back with a hydrolic press and it exploded! Have
since done some inquiring and have been told that the 7075T6 alloy is very,
very strong but at the same time is brittle and it showed. I have since
ordered a replacement from Kolb. I got a quote locally for machining in the
taper. That was cheap, the aluminum stock however was $50. Kolb is selling
it for $45 and it is already tapered.
Moral of the story is if you bend a gear, I think it needs to be replaced.
My gear is 24 inches and 1 1/8" diameter and tapers to 7/8". Is that the old
gear or the new heavier duty version?
Thanks again,
Tim Barry
Firestar KXP
Tucson, Arizona
Yah, tried that..........didn't work for me. I went the surgery route, and
it worked very well, but went thru a lot of un-necessary pain & misery. If
anyone's contemplating that, email me off List, and I'll tell you what to
watch for. Had I only known....................... Do not
Archive.
Larry Bourne
Palm Springs, Ca.
Kolb Mk III - " Vamoose"
http://www.biglar.homestead.com/larry.html
Sent: Wednesday, August 01, 2001 10:40 AM
> Richard Pike
So, Cancel then. One day, maybe you'll learn what the delete key is for.
Adios, M.F.
Larry Bourne
Palm Springs, Ca.
Sent: Wednesday, August 01, 2001 11:31 AM
call
> out.
> Don Mekeel FF002
> El Paso, Texas
Kolbers, cleaning up old , chipped cage tubing... go to a plumbing
supply and buy what is called a "plumber's roll" of sandcloth. get
both 120 and 220. Do a half-wrap and do the shoeshine boy stroke.
It does a great job of clean-up of both mill glaze, that chipped white
stuff originally put on, and surface rust. I'm trying rustoleum's satin
indoor-outdoor spray can furniture paint on the tubes. looks good
so far. It comes in a satin green (zinc chromate look-alike) white,
black, and a funky looking maroon. If you weld near it, it doesn't
blister up and look nasty. ...for what it's worth....BB
This reminds me...............I went to the local US Rental a couple of
weeks ago, and asked about scales, strain gauges, etc. They looked at me
like I'd grown antlers, or something. Soooo................no scales.
Sorry guys, but for once, I didn't forget.
Larry Bourne
Palm Springs, Ca.
Sent: Tuesday, July 31, 2001 5:28 PM
Subject: Kolb-List: Fuel Tank
> Julian Warren
> Eugene, Oregon
Sure would like to see them .
Thanks Larry
Bill Futrell
Sent: Wednesday, August 01, 2001 12:15 AM
> Larry Bourne
> Palm Springs, Ca.
> From: "Julian Warren" <jgw300(at)webolium.com>
> To: "Kolb List"
> > your
> > money for it.
> > not
> > as it
> > 19-gallon
> > anymore.
> > I am sorry,"
> > Julian Warren
> > Eugene, Oregon
If you are going to have to glue any fabric on these tubes, be sure and run
a test to see if the glue raises the paint. I touched up a few spots on my
cage with rustoleum as I didn't want to mix up a batch of epoxy for just a
little job. When I applied
Poly-Tac to these spots, the paint blistered up and I had to remove all of
it and re-apply epoxy.
Ron Payne
Sent: Wednesday, August 01, 2001 8:38 PM
Subject: Kolb-List: tube prep
Hey Ray,
If you can bring that dead weight forward you can save a lot of weight, if
you bring it forward by 20 inches you only need 2 lbs.
Hans van Alphen
Building Mark III Extra
BMW powered
>I will be carrying 40 pounds on the floor of the passenger side .......-
>L. Ray Baker
>Lake Butler, FL
I believe the fabric adhesive will melt the paint and the fabric will not
stick. One must use automotive or airplane paint that has a hardener added
to it.
Dale Seitzer
Sent: Wednesday, August 01, 2001 8:39 PM
Probably thought you were a drug dealer just starting out.
Cotton bale scales - like a big brother of the fish weighing scales. I
don't know where people get them but I have seen them. Don't get the
"thrust" scales from Aircraft Spruce, leaked oil all over - poor workman
ship on there vendors part.
jerryb
>Larry Bourne
>Palm Springs, Ca.
>To: "Kolb List"
> > Julian Warren
> > Eugene, Oregon
sanders, welders, filers and grinders....ok, I checked out that
rustoleum
furniture paint. It's been on about a week. I did the old lacquer
thinner
solubility test and it's remarkably resistant. After some rubbing with a
soaked rag a little color did transfer, but I'm quite satisfied with the
result. ---thanks for prodding me into it however. Mind you, I'm not
talking about the regular glossy stuff. It sure beats the orig coating
that
easily flaked off the tubes when scraped with the edge of a scewdriver!
---Also, back in my mental archives, I remember doing an Aeronca
gear leg assy with rustoleum clean metal primer and baking it in my
wife's oven (don't remember the setting) but that stuff wouldn't come
off with anything. Amazing my wife didn't kill me..it sure stunk.
Bob B., minor brain damage, mkIII N3851E
Check it with Poly Tac. Or maybe MEK. Lacquer thinner will not lift
rust-o-leum. I took a scrap piece of metal, painted it with rustoleum and
let it set for about a week. I then glued a piece of fabric on it with
Poly-Tac and let it set for 2 to 3 days. I then pulled on the fabric and it
peeled off with very little effort and the paint was blistered. After that
I dabbed a little Poly-Tac on the areas of the cage that I had used
rustoleum on and the paint immediately blistered and loosened from the
tubes. I hope you don't have the same problem. Let the list know how this
comes out.
Ron Payne
Sent: Thursday, August 02, 2001 3:43 PM
> rustoleum
> thinner
> that
Subject: | UL Parts Supplier |
Folks,
I'm must be having a mid-life crisis. I looking to develop something to
earn a living rather than consulting. Someone once told me you can make a
small fortune in the aviation business. just start with a large fortune. I
going to try to reverse the process.
I've always dreamed of being in the mail order business. I seek your
comments as input to determine if you feel there is adequate desire for
another UL parts supplier. Based upon the comments I've seen about Airstar
Discount's service and yet they've still in business, I should not have any
problem doing better than them.
My objective would not to be a one stop shopping center, but rather cater
to unique, special, or commonly needed products.
Example: Good quality inexpensive power switches, wire and cable, maybe
strobe lights, pitot, fuel, and pulse tubing, clamps, fuel valves, EIS
Systems, Tie down kits, oil by the gallon/case, special tools, etc.
I would rather stay out of instruments or engine parts if possible. Would
rather carry more unique items and fill in the voids that exist.
What about assembling or building kits for individuals or manufacturers?
I'm interested in any ideas you may have whether they be aviation, or UL
oriented or not. Any product, items, services, reference material, etc.
you may think of.
Please email your personal comments direct to:
Jerry Bidle
They do make an emergency relief bag which works well. They have moisture
absorbing crystals making them almost spill proof. There a little
expensive for frequent single use but can save the day when the old head
winds start blowing. They can be stowed almost anywhere until
needed. Every boy scout should have one in there UL.
>time. Cured Lar.
>Larry Bourne
>Palm Springs, Ca.
>From: "bob n" <ronoy(at)shentel.net>
>To:
> > Ron,
> > of the seat.
> > Bob N.
If you stick a post in the ground and bolt a bell crank to it then
connect the aircraft to the top end via a chunk of rope and the bottom end
pushing on a bathroom scale it should give you an idea what is happening
with the thrust.
Subject: | Re: Gotta Go--Gotta Go--Gotta Go!!!! - Ice |
* * * UL PILOT SPECIAL ALERT * * *
A special alert has been issued by the FFA warning Ultralight Pilots that
flying behind and especially below aircraft operated by Ron Payne may
experience unforeseen sporadic rain showers. Numerous reports have been
received including the sighting of yellow ice falling to the ground. Much
like the unexplained phenomena reported several years ago of falling blue
ice, the FFA does not recommend anyone consume the yellow ice.
You know what they say about great minds running in the same circles ??
They shall be known as Big Wheels ! ! ! In all seriousness, at
the hotel we have really excellent scales with large faces, and I've been
thinking..................about a 3:1 ratio should be about right, and a 2 x
6 on edge should be strong enuf to hold the pressure. If you set it up with
the plane hooked 2 ft from the pivot point, and your scale set 6 ft from the
other side of the pivot, you'd have your 3:1 ratio, so that a 450 lb pull
from the plane - assuming 90 - 100 hp - would give a 150 lb reading on the
scale...............just about mid-range, which is just right.
Imaginative Lar.
Larry Bourne
Palm Springs, Ca.
Sent: Thursday, August 02, 2001 4:22 PM
Subject: Re: Kolb-List: Fuel Tank
me
> with the thrust.
Hey Kolbers,
Y BNC connector
acceptable for FAA
inspection ?>>>>
to make the answer short NO now for the long
answer NOOOOOOO
for the realy long answer during transmiting the
impedance load for either of the radios would not be
corect. in short it would burn up the final power
transistors...... use 2 antennas
for cheep and easy check out
http://www.brigham.net/~byoung/antenna.html .....
with 1 watt radio i have talked over 120 miles... the signal
report i got back was good signal with background
noise. there are splitters to run 2 or more recieve
only devices on 1 antenna, but not 2 transmit
devices.... well i take that back..... but you dont have
the space or the weight allowance.
boyd
Subject: | Re: THRUST TESTER |
Hey Larry and listers,
Ordered a 100 lbs. hanging scale(#43045-0ana) and a rope hoist (#36849-0vga)
from harbour freight for a total cost of $20.98 The rope hoist should give a
ratio of 6:1 on the 100 lbs scale and is easy to hook up to a
tree........Let you know the results.
Hans van Alphen
building Mark III Extra
BMW powered.
with
the
>Imaginative Lar.
end
>> with the thrust.
Just a test to see if this list is up and running. Have not seen much
Kolb stuff in the last few days.
Sounds good from here. Good Luck.
Larry Bourne
Palm Springs, Ca.
Sent: Friday, August 03, 2001 7:27 AM
Subject: Kolb-List: Re: THRUST TESTER
(#36849-0vga)
a
> Hans van Alphen
> BMW powered.
> with
> the
the
> >Imaginative Lar.
> end
happening
> >> with the thrust.
Just a reminder that I keep a database of over 140 Kolb builder/flyers to
anyone who wants a copy or to be included. I may have it on a website as
early as next week. Please reply to dama(at)mindspring.com .
Kip Laurie
Atlanta
Firestar II
eastatlantaflyers.com
Hi Ron it is up and running. How are you doing?
Sent: Friday, August 03, 2001 2:32 PM
Subject: Kolb-List: test test
Bob and all
There is a two part primer available from your local PPG auto paint
store. Quart and a half for 26 bucks plus tax. Saves shipping and hazardous
material charges. The color is battleship gray. This is their cheapest
two part. Quart of paint and a pint of hardener. This was enough for my
Sonerai Fuselage. They also carry some of the aluminum prep elixirs.
Alodine,brightners etc.
TNK uses PPG poly urethane paints as I recall.
BTW; stopped by TNK on Wed. and got word of a new toy that they are
planning on building with another co.. Composite fuse and metal wings. A
Canadian design called the Pelican. I think that Ultravia Aero Int. has had
it in the markplace for some time. Kolb plans to distribute kits in the
states and to build the complete plane for the new Sport Pilot class
license when it comes to pass. I guess that you fellows who went to Oshkosh
saw it?? www.ultravia.ca . Herb
From: | JIMMY HANKINSON <jhankin(at)planters.net> |
A friend of mine has a Firestar with two five gallon tanks, one placed
behind the other.
There is a line from both tanks to a "Y" and then to the fuel pump. How
can he gets both tanks to empty at the same rate without siphoning one
from the other and the front tank not vented.
Jimmy
Firefly #35, 447 Rotax
Rocky Ford, Georgia 30455
Southeast, Georgia
JYL -- Airport
Subject: | 1990 Firestar KX |
Hi all,
I am new to the list and just recently bought a Firestar (KX I think). At
least a portion of it was bought in 1990 and built by 94 or so. I was
wondering if anyone had any manuals or documentation that they could copy or
fax to me. I have tried "The NEW Kolb Company". They don't have anything
that far back.
Gary
Newbee UL'r
Subject: | www.Kolbpilot.com |
Additional Osh photos have just arrived at
www.Kolbpilot.com
Drill a hole in the top of each tank and stick one piece of fuel line
in the holes so that it reaches the bottom of each tank This u shaped tube
will be a self start siphon that will keep the tanks balanced.
For whatever reason your friend does not want to vent the front tank
directly, the fact remaines that if you want to empty the fuel from it by
gravity at the same rate , you must allow air to enter in the top at the
same rate as the rear and you can do this as woody says but keep the lines
short to 1'' inside the tank so that the top connection acts like a vent
connection equalizing the air pressure.
Frank Reynen MKIII/Lotus floats
Sent: Friday, August 03, 2001 9:41 PM
Subject: Re: Kolb-List: Gas tanks
From: | "Mike Pierzina" <planecrazzzy(at)lycos.com> |
Has anybody ever hear of anybody with a 582 on a Firestar? I was wondering if
thats what it would take for full lotus floats (DUAL) and a passenger, as long
as the Vne wasn't exceeded....or would all that be just to much weight affecting
the Va ? Gotta Fly...
Get 250 color business cards for FREE!
http://businesscards.lycos.com/vp/fastpath/
Subject: | Re: Kolb Database |
Please add me to your list. Bruce Harrison, Firestar II, 2000 model from
TNK, Rotax 503 DCDCDI, 66" 2-blade Ivoprop, no BRS. Columbia, SC
> builder/flyers to
> website as
> Kip Laurie
> Atlanta
> Firestar II
Drop the lines to the bottom of the tank. Do not get a tight seal on the
inlet holes ( A vent is needed somewhere in the fuel system or no fuel will
flow) and as the fuel is drawn from one tank a low pressure area will be
formed in the tube causing the fuel to flow as a siphon and balance out the
2 tanks. The 2 tanks need to have some kind of venting.
From: | "richard swiderski" <swiderskir(at)earthlink.net> |
Hans,
The coefficient of resistance with a 6:1 pulley will be so high that you
will not get a realistic value on your reading. The bellcrank idea would be
better using a 6:1 ratio to put you in the middle range of the 100lb scale.
.> ----- Original Message -----
> From: "Hans van Alphen" <HVA(at)bellsouth.net>
> To:
> (#36849-0vga)
give
> a
> > Hans van Alphen
> > BMW powered.
> > with
from
> > the
pull
> the
> > >Imaginative Lar.
then
bottom
> > end
> happening
> > >> with the thrust.
Subject: | How are HP and Torque related |
I been reading some post on the UL list about engine HP. Due to there
being so many opinions I'm confused of what to believe. I know there are a
few old timers with solid knowledge of this topic on the Kolb so I seek
there wisdom.
Question:
1. Where is the rated HP measured of a Rotax engine - crank shaft or
output flange of a redrive gearbox?
2. When a redrive is used example 2:1 (gear box out is 1/2 RPM of the
engine crank)
Does the HP remain the same or is it doubled at the redrive output shaft?
Does the torque remain the same or is it doubled at redrive output shaft?
3. If you put a 2:1 redrive on say a 4-cylinder VW -
4. This has to due with EGT temps and prop load on an engine -
If EGT are low does the engine need more or less prop load -
note I under stand other things impact EGT temps, so does prop load
Dennis had a saying that went some what to the effect of Grass green side
down,
it also had to other items of which one was prop pitch as it related to
engine EGT temps, any one have a copy of it -
jerryb
Subject: | Re: How are HP and Torque related |
Assuming a healthy, correctly jetted engine, EGT's will normally go too
high when prop load is insufficient, and may go too low when prop load is
too great.
There is more detail on the web page
http://www.bcchapel.org/pages/0003/pg11.htm
Richard Pike
>jerryb
Subject: | Compass Refill? Wing and Strut pins |
Thread-Topic: Compass Refill? Wing and Strut pins
Thread-Index: AcEdwLdjRrJQJWl0SA68S3O0I+cdTw==
From: | "Waligroski, Gregg" <Gregg.Waligroski(at)pantellos.com> |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Subject: | Re: Compass Refill? Wing and Strut pins |
Sorry, wrong language for this planet
Subject: | RE: Compass Refill? Wing and Strut pins - REPOST |
Thread-Index: AcEdwLdjRrJQJWl0SA68S3O0I+cdTwAHOkpg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: | Re: RE: Compass Refill? Wing and Strut pins - REPOST |
hey, Gregg--yer repost makes everything....can't find the word, but it
ain't Clear!
Subject: | Some Questions ... |
Hi
I'm new to the list, and have been sitting on the sidelines for a few days -
just watching :-)
I'm hoping someone can answer a couple of questions for me ...
1 I'm seriously considering buying a Kolb Slingshot or similar, and wondered
if anyone here in Scotland/UK owns one - are they even legal "over here" ?
2 Are there any reviews available on line for the Slingshot?
3 I couldn't find an FAQ anywhere - is there one?
4 While I ponder the purchase, it would be fun to try a virtual flight, but
I couldn't find a model for x-plane - anyone know of one? If not, are there
any 3-views (dimensional) and some flight data available for the range of
Kolb A/C, so I can roll my own?
TIA
Best regards
Neil
NKY - No Kolb Yet =;-)
Neil D. Gillies Tel: +44 (0)1383-823489
SeaGull Technologies Fax: +44 (0)870-0543622
11 River View Mobile: +44 (0)771-4330793
Dalgety Bay, Fife neil@sea-gull.demon.co.uk
Scotland KY11 9YE http://www.sea-gull.demon.co.uk
Brother Pike...
IMHO, your web page is a masterpiece of clearly stated, concise 2-cycle
wisdom...(a scarce commodity...)
As far as I am concerned, a printed copy of same ought to be included in the
box of every Rotax double banger shipped. You, Sir, have performed a great
service to we 2-cycle duffers out here who are trying to make these things
run consistently... I, for one, am most grateful.
Now, having said that, what do I do if after 8 hours since new, my back plug
is covered with hard, baked on crud, while the front one looks like one of
the too-hot, too-lean gray ones in the lower left corner of the plug
photos...? I have squared up the carb on the low-time engine (447) very
carefully... the CDI ignition is timed... the compression is equal between
the two cylinders... What precise effect does tilting the Bing slightly have
on the distribution of fuel between the two... can slight tilting be used as
a means of balancing the flow? If so, which way?
Sigh...
Your Humble Student,
Beauford (still soaking in Seafoam) of Brandon FF#076
Sent: Sunday, August 05, 2001 11:55 AM
Subject: Re: Kolb-List: How are HP and Torque related
> Richard Pike
Subject: | Re: WANTED: FRESH FIRESTAR I/II |
A gentleman at our field is looking to buy a Firestar I/II. It should be a
late model, low time [less than 100 hours], well built craft. Should have a
503 DCDI, and be within 500 miles of SC.
Electric start, brakes, & Warp Drive prop would be a plus.
Email me off list.
Howard Shackleford
FS I
SC
Gang
I am looking for a rebuildable Kolb or an unfinished kit. Herb in Ky
> Email me off list.
> Howard Shackleford
> FS I
> SC
Subject: | Re: RE: Compass Refill? Wing and Strut pins - |
REPOST
"Waligroski, Gregg"
This is a reply to your second post. As you can see it no better than the
first. When encoding are you using or do you have encryption enabled?
jerryb
Haven't seen any replies to this...............c'mon you guys, help the guy
out ! ! ! The only part I'm fairly sure about, is part of the re-drive
question. As I understand it, using a 2:1 re-drive will give you twice the
torque - less friction losses - at 1/2 the prop rpm. Lets you swing a
bigger, slower prop, which is more suited to our type of plane. Small,
fast, direct drive props belong on small, fast planes. Not sure how this
affects horsepower - I think it stays the same - but the torque is what
turns the prop, & drives the plane.
GoGittum Lar................................zero-ing in
on engine start with my mighty ( I hope ) VW with re-drive.
Larry Bourne
Palm Springs, Ca.
http://www.gogittum.com
Sent: Saturday, August 04, 2001 10:46 PM
Subject: Kolb-List: How are HP and Torque related
> there wisdom.
> Question:
> engine crank)
> down,
> jerryb
What would cause a difference of 100-150 degrees between front and rear EGT?
Jim
Mark III
Charlotte, NC
> too great.
> Richard Pike
> >jerryb
Try this for a simple explanation:
A 2-to-1 redrive reduces the RPM by two and doubles the torque. Since
horsepower is work times speed, the redrive causes the torque to double but
at half the speed. Therefore, horsepower stays the same. "You can't get
something for nothing." Actually, since the redrive has friction losses,
there's a little loss in horsepower.
Larry Davis
http://home.indy.rr.com/challengerul/airplane.html
Sent: Monday, August 06, 2001 2:23 AM
guy
the
in
> Larry Bourne
> Palm Springs, Ca.
> From: "jerryb" <ulflyer(at)airmail.net>
> To: "Kolb-List"
a
> > there wisdom.
> > Question:
> > engine crank)
shaft?
shaft?
shaft?
shaft?
side
> > down,
> > jerryb
Subject: | Whiskey Compass question Repost Repost |
Thread-Topic: Whiskey Compass question Repost Repost
Thread-Index: AcEectwXvwNAEdTeSTGYaaPLg6qp6w==
I received a message that my original post and repost have gone bad so I
have posted it yet again. Sorry to the for yet another repeat...
Getting my Firestar ready for flight again I hope. Doing some
maintenance and have a few questions.
My "whiskey" compass has drained down over time so the compass no longer
floats. Other than using JD what is the correct fluid or acceptable
fluids to use to refill my compass?
I want to replace all 6 of my wing and strut attachment pins and can't
find my Kolb plans since the move to Houston. What is the correct
MSxxxxx number for the clevis pin type? Is the easiest thing just to
order from the Kolb Factory or does anyone know of a good Houston area
MS parts store?
Gregg Waligroski
Houston, Texas
In a message dated 8/6/01 3:30:19 AM Eastern Daylight Time,
biglar(at)gogittum.com writes:
> > there wisdom.
> Horsepower is always Torque X Speed X a constant, therefore.....
> Question:
> This is a good question....GR
> > engine crank)
July 25, 2001 - August 06, 2001
Kolb-Archive.digest.vol-da
