Kolb-Archive.digest.vol-du
August 23, 2002 - September 07, 2002
Thanks for this input Jack. I don't think there is a perfect solution for the 2-stroke
problem except to get a 4-stroke. Mine seems to be going strong for now.
I will keep all of you updated if I run into a problem.
What brand of synthetic oil were you using again? Was it 50:1 or 100:1 mix?
Ralph Burlingame
Original Firestar
15 years flying it
Ron & Gang,
This has been and interesting thread. On this one, I believe it is best to follow
the engine manufacturer's recommendation. I didn't and I wish I had. I was
using a synthetic oil and believed what I had seen on the list that de-carb
was not necessary. I pulled my engine over by hand before every flight and I
was continually amazed at compression seemed to be increasing with the hours
on the engine. I looked in the exhaust port and could see some coating on the
head of the piston, but there was plenty of oil on the piston and one could push
on the rings with a wood swab stick and see that they moved. At 57 hours
plus the rear piston seized while climbing out after a take off.
After removing the pistons, I discovered the rings were not stuck in the slots.
They could revolve a little and move side to side a little as one would expect
that they should. The culprit was carbon or other burned oil deposits that
built up under the rings. It also explains why the compression was always good.
The problem was that it got too good. The engine was running hard in the
climb and the upper ring pressed the cylinder wall with more than normal force
because the ring could not compress and move back into the slot in the piston.
This generated more heat and softened the head of the piston, aluminum scuffed
off and the piston seized.
I guess the point I wish to make is that your rings may not be stuck, but you cannot
see what is behind the piston ring, and this is the deposit build up that
will bring you down. The only way to find out if a carbon deposit is there
or not is to remove the rings and look. If you look at 50 and 100 hours and you
find no build up then you may have the right combination of luck, fuel, oil
and what ever other additive that keep deposit build up from under the rings,
and extend your de-carb cycle time.
In my case not following the manufacturer's recommendation, cost me about $500
and a month of flying.
Jack B. Hart FF004
Jackson, MO
Jack & Louise Hart
jbhart(at)ldd.net
Subject: | Re: Escaped Disaster |
> Something to check , during these hot days of late .
> Maybe an oversite on my part , maybe NOT .
> Hope this helps save someone else .
> Attached is a copy of an e-mail sent to customersupport@tnkolbaircraft .
> JJP
JJP/Gang:
Can not send attachments through the Kolb List. However,
you can cut and paste it into the body of the email, or you
can scan it and send it to the photo gallery, address link
below.
If you can't do the above, send it to me and I will post it
on my index page so all can see.
Take care,
Those three wires are the remote keyswith control wires. They allow you to
operate the front panel switches remotely using any normally open momentary
switch mounted in a location convenient for your aircraft.
Oragne wire: "Next/Ack"
Green wire: "Previous"
Blue wire: "Display"
I can send you a copy of the manual page if needed.
John Williamson
Arlington, TX
N49KK, Kolb Kolbra, Jabiru 2200
http://home.attbi.com/~kolbrapilot/
How do you know - well sometimes your will start getting different CHT &
EGT temps. A sign something is going on. We usually check ours about
every 25-50 hours taking a compression test and recording the values
followed by dropping the exhaust manifold and take a peek at the rings. We
also take a small long blade screwdriver and try to move each ring. They
should move a little, major resistance shows there is carbon buildup in the
grooves. While were there we look for funny vertical scrap marks on the
pistons indicating a seizure has occurred some time.
jerryb
>In a message dated 8/23/02 2:51:26 AM Eastern Daylight Time,
>kolb-list-digest(at)matronics.com writes:
> > I flew 11 years having to take my engine apart every 150 hours due to ring
> > sticking
>I was wondering how rotax owners, who find rings that stick, notice that they
>had a problem. Is it something you find visually during annual inspection,
>or when it happens, does it show up immediately as a loss of rpm, or
>roughness in running? How do you know when the rings stick?
>Bob G
>Albany NY
>Bob,
>There is no warning if a ring sticks. The engine will run fine on one
>ring. In my case, I ran it for a long time without checking anything as I
>was new to this. Finally one winter day, I was flying along over the
>frozen lake (luckily) and the rpms dropped off quickly and the EGT went
>beyond 1300F. The engine quit in the air after that and I glided to a safe
>landing on the lake. I tried all afternoon to get it started, but could
>not. Spent the night out there in -5F conditions.
>After taking the cylinders off (at home), I found the bottom ring on the
>rear cylinder stuck. I had the engine overhauled by a 2-stroke mechanic
>and flew another 250 hours on that 377 until I got a good deal on my 447
>that I fly with to this day.
>When I got the 447, I heard about Klotz synthetic oil and Seafoam. I
>inspect the rings on an annual basis and do the treatments. Hopefully, I
>won't have to spend another night on a frozen lake.
>Ralph Burlingame
>Original Firestar
>15 years flying
Subject: | Re: Elevator Stops |
Yes thats the only way I can think of doing it. You will have to drill out
two rivets on each side,, one behined the other and then rivet back the tab.
you can then trim the tab to proper size. I would use something like .060
instead of the .032--it seems too flimsy to me.
Ron
8/23/01 12:37Chris Sudlow
> If the stops are attached I believe they are rivited tabs through the ring
> that contact the elevator mechanism - tabs are placed on the inside of the
> ring & rivited in place.
Hi gang,
On the subject of oil for our ultralights, Koltz in particular, what is
the type of synthetic being used. Is there a different one for our
Rotax?
This Kolb site should be named The Learning Site.
Jimmy Hankinson
912-863-7384
Rocky Ford, Ga. 30455
jhankin(at)planters.net
Kolb Firefly/447/200hrs
Local field, Pegasus/2000/Grass
Airport JYL/Sylvania, Ga.
Subject: | escaped disaster |
It's a good thing my FS II is not computer controlled . It's not
my ( forte' ) . I've been
trying to send a copy of that letter for ??????????? a long time to say
the least . I'll try
e-mail , direct from the scanner . If that doesn't work , I'll re-type
in the a.m.
JJP
I was at Wallmart today. I saw 100% 2 cycle syn oil I think it was penzoil.
a gallon was listing for 18.95. This is the one I used in my 2 cycle Yamaha.
It smokes little run's smooth. Once I have an engine on my M3E this is what
I would buy.
Ron
8/23/02 18:33Jimmy
> Rotax?
Subject: | Cheep Dipole Antenna question |
Boyd or anyone,
I want to make a dipole antenna from RG58 Coax. Is it safe to cut it to
25 inches and see how it works without using an antenna analyzer? Is it
likely to work better than the rubber ducky?
John Jung
Firestar II N6163J
Upper Michigan
I have contacted Klotz two or three times about this. Each time they have
recommended their Ski Craft oil. I questioned them on this as a Jet Ski is a
water cooled engine while my 503 is air cooled. Each time they have assured
me that the Ski Craft oil is the proper oil. If you get any other opinions,
please let us know.
Ron Payne
-------Original Message-------
Date: Friday, August 23, 2002 08:36:13 PM
Subject: Kolb-List: Koltz oil
Hi gang,
Rotax?
Jimmy Hankinson
912-863-7384
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
I guess it's the old fashion way , one letter at a time . My
appologies to all.
The problem / e-mail , that I sent to Linda @ customersupport
TNK , went like so ;
Linda/TNK,
You might want to mention this to the OWNERS . Maybe a design change
is warranted .
While practicing take-off and landings w/ FS II on floats ,this
past weekend , minutes
after landing , during take-off , at lift-off speed ,
the top tail bracing NUT , on the verticle stablizer bolt ( AN3
14A )
came off , allowing the horizontal stablizers to drop , simular to an
F-4 fantom , rendering
the elevators useless .
We ( Charles an old friend and videographer ) was taping at the time
clearly what and how , this happened . Fortunately this happened AFTER
landing . Especially
considering the facts that two minutes prior , at 800 ft and the chute
was disarmed .
I realize that this might be an isolated incidence , but I've obpted
to covert ALL tail bracing
bolts/nuts , to castle nuts and saftey clips .
That nut and bolt assembly has been in place for approx three years
and always trailered . It was very hot that day ( 90's ), maybe the heat
and vibration ,caused
the nyloc nut to fail , hence , castle nut ( s ) and clip ( s ) .
Thanks for your time
Photo : FS II on floats S.E. Ma.
ToGunPI(at)att.net
John J. Peters
Subject: | Re: escaped disaster |
Very good post John. I had already replaced the lower wing nut with a castle
nut and cotter pin. I now will replace all tail wire nyloc nuts with castle
nuts. Thanks for the post
Ron Payne
Date: Saturday, August 24, 2002 08:35:50 AM
Subject: Kolb-List: escaped disaster
appologies to all.
Linda/TNK,
is warranted .
Subject: | Re: finishing tapemessage of Fri, 23 Aug 2002 23:50:00 |
> Terr, Jim and Dondi will tell you....."hard under soft, tape it."
> Mike in WV
Mike/Guys:
Jim and Dondi are always available to help us out when we
get in trouble with our covering and painting. Their toll
free number is:
CALL TOLL FREE 1-877-877-3334
Their web site is:
http://www.aircrafttechsupport.com/
Reference taping the tail section:
The tail section takes a terrible beating over the hours.
Not only do parts of the engine and airframe find their way
to the tail section, but tons of garbage from the engine
exhaust (all that diamond hard carbon from inside), sand,
dust, dirt, rocks off the tires, and just the junk that we
don't see that is in our atmosphere.
If you get to London, KY, next month for the Kolb Flyin,
take a look at the leading edges of the vertical and
horizontal stabilizers on my Mark III. It is easy to see
that Mother Earth and Rotax 912 exhaust have taken its toll
on the leading edges and surfaces of its tail section. The
red Aerothane paint is almost worn through to the yellow.
Ron and others,
I have been using Klotz KL-216 which is the gallon-sized synthetic
snowmobile oil. I'm not sure about the other synthetics. Did you explain
to the dealer that your engine is most similar to a snowmobile engine?
My understanding is their oils are the same except for the flashpoint, so
the watercraft oil may be fine. I would go with the same stuff that I
use.
If you can find a dealer close by, it runs about $17/gallon, otherwise
shipped to your door it's about $130 for 4 gallons.
The price difference between minerals and synthetics will easily be made
up in maintenance costs, so there is really no price difference.
Ralph Burlingame
Original Firestar
15 years flying it
> have recommended their Ski Craft oil. I questioned them on this as a
Jet
> Ski is a water cooled engine while my 503 is air cooled. Each time they
have
> assured me that the Ski Craft oil is the proper oil. If you get any
other
> opinions,
> please let us know.
> Ron Payne
One more thing about Klotz synthetic is that it does not smoke. If there
is smoke out the exhaust, that is an indication the oil has more carbon
and/or ash in it to build on the inside of your engine.
All minerals and some synthetics oils smoke. Engines live a healthier
life if they are nonsmokers.
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> penzoil.
> Yamaha.
> is what
> I would buy.
> Ron
> 8/23/02 18:33Jimmy
> what is
> our
> > Rotax?
> messages.
> 14A )
John J. Peters
John J/Gang:
Glad your episode ended without disastor.
First time I have heard of someone losing a nyloc nut on a
Kolb or any other aircraft.
After the failure, did the bolt remain in the tang? Were
you able to recover it? Were the threads on the bolt in
good shape?
If you did not recover the bolt, how did you determine the
nyloc nut backed off? Seems more probable that the bolt
would break before the nut backed off.
Not doubting your word, but trying to find out what really
happened.
Ron Payne has already decided to change out all his hardware
because of your message. Likely, others will also.
I haven't looked at the reg, but I doubt there is a time
requirement for replacement of nyloc nuts. Mine have been
on the tail section for much longer than three years, as in
your case. There are nylocs employed all over the airframe
on our aircraft. Think we ought to change them all out?
Not me. Not unless they have been removed and replaced a
couple times. As a rule of thumb I see how far I can screw
the nut onto the bolt. If I can get a thread to show, I
chunk it and put on a new one. It is very easy to overpower
the nyloc on a 3/16 nyloc nut once it has been tightened
down and removed. Best rule of thumb for a 3/16 nyloc nut
might be to use it once, remove and toss it, then replace
with a new one.
I feel comfortable with the sytem I use for tail wires. I
use nyloc nuts. The closest I came to losing one was in
Alaska in 1994, when I tried to land on a grass strip that
turned out to be Alaskan Bush. Had the 3/16 bottom wire
bolt installed from right to left. As the tailwires were
drug through the bushes, the 3/16 nyloc nut was being
unscrewed from the bolt. When I finally got the airplane on
the ground, I discovered what had happened. Only a couple
threads holding it on.
To remedy the above, I install the bottom bolt from left to
right. Now when I get into a situation where I am in tall
weeds, brush, bushes, etc, the action of the vegetation
working on the nut will tend to tighten rather than loosen.
Take care,
Ron,
Thanks for the understanding , I hope this helps save future problems
with ALL >
JJP
----- Original Message -----
Subject: Re: Kolb-List: escaped disaster
castle
castle
> Ron Payne
> From: kolb-list(at)matronics.com
> To: Kolb List
> appologies to all.
> Linda/TNK,
> is warranted .
John H
Thanks , and yes the bolt stayed on the tang and the threads are fine .
Excellant question,
you are exactly right , the nut could have split and been pulled off ,
although there are no signs
of that on the threads . And yes I was able to control the plane , as the
rudder is intact , but
the horizontal stabilizers didn't fare so well . The tube to fold and clip
the wings punctured the
stablizers as they were simulating an F-4 fantom . That I can deal with
JJP
> > 14A )
> John J. Peters
> John J/Gang:
> good shape?
> happened.
> with a new one.
> Take care,
> john h
JJP
John J/Gang:
OK. Looks like the nyloc nut came off about the time you
got ready to take off again.
Possibility that this particular nyloc nut was unsat from
the hardware manufacturer. May have been unsuspectingly
installed without the installer realizing that the nut was
no good. The factory boys do not look at every one of
them. In fact, I'd bet very very few of them get looked
at. I have found all types of hardware, AN type, that were
not acceptable for service. Particularly AN bolts. Some
with not enough metal to stamp the hex head. Come out with
a round brad type head. Also got one without threads. Made
a nice pin.
When something happens to an airplane because of a material
failure we want to point the finger at the guy who made the
material. Or in this case the guy that designed the system
for the tail wires. In my opinion, based on a lot of years
and hours flying in front of this same type tail wire set,
the designer's qualifications, and years and hours others
have put on this system, that the system is good, sound, and
perfectly safe.
Now comes the good part. This, of course, is my own
personal opinion, for what it is worth, which probably isn't
much. But it is enough for me to continue flying with my
tail wires attached with 3/16 bolts and nyloc nuts. In
fact, I only landed a few minutes ago, after an hour and a
half flight, in my Mark III with the same configuration. I
do not believe that that nut decided to come off on that
particular flight, whether it was 10 minutes or 10 hours. I
think it has been working on the nut for sometime. The
pilot in command of the aircraft may not have done a
thorough preflight, to include actually looking at each nut
on each of the four positions on the tail wires. If they
had been religiously inspected each pre flight, the
loosening nut would have been picked up.
I don't always look at each of the four nuts in question,
but the ones I don't look at are the ones that I feel with
my finger to insure that I have some threads protruding
through the nut. It is easy to visually inspect the top and
bottom nut, especially the top nut. Have to bend down a
ways to visually inspect the two on the bottom side of the
horizontal stabilizers. So if I can't see it, I can feel
it.
It is easy to get complacent in preflighting the same
aircraft day after day. Especially items that we "know"
ain't gonna come off while we are busy having fun cheating
gravity. Beware, Murphy never rests nor sleeps. He is
always ready to bite you in the ass.
Take care,
PS: Got 1.5 hrs in the heat. Gonna wait til late this
evening and burn some more MOGAS. Too hot to play now.
. It was a very different era, best music and legacy.
> Ron
Yes it was the best and worst of times. Loved it and hated
it....regards...Kirk
John H ,
You are exactly right about the pre-flight on this particular day only ,
because I don't remember looking at that particular bolt & nut with any
scrutiny , However my friend
Charles ( who is an ex helicopter mechanic / pilot ) , says he remembers
going over that
entire tail assembly , the very last time out , which was a testing phase of
this whole set - up.
As for the original installation , it was done by yours truely , and
being a machinist /
tool & die maker for some 40 years , I assure you I'm more than qualified ,
for some of these
tasks . The fact remains that , pre-flighted or not , on that day ,
SOMETHING caused
this to happen . That is all that was being conveyed in that e-mail . Homer
did a great job, but
he has no ability to change physics . If you can fry an egg on a piece of
metal heated by the sun , there may well be enough heat to partially melt /
soften nylon .Enough said !!!
JJP
fine .
> JJP
> John J/Gang:
> a nice pin.
> perfectly safe.
> it.
> Take care,
> john h
Subject: | Re: Cheep Dipole Antenna question |
> From: "John Jung" <jrjung(at)sgmmail.com>
> To:
> Subject: Kolb-List: Cheep Dipole Antenna question
> > Boyd or anyone,
> > John Jung
> > Firestar II N6163J
> > Upper Michigan
John,
From the limited info above I would say that its a final amplifier burner
upper device and not a dipole at all. Richard Pikes antenna is a 1/4 wave
vertical and an excellent choice in my opinion. I would have mounted it on
top so as to not have to bend it and distort the radiation pattern. But it
still works well I'm sure. Simple, cheap and very effective.
Snuffy....WB8ZMY
Subject: | Preflight Inspection |
Gentlemen,
After I torque or just tighten a nut, I put a glob of "Torque Seal"
across the thread-nut interface, or the head-structural interface or the
nut-washer-structural interface, whichever is proper for that fastened
joint. This brightly colored stuff dries to a very brittle substance
that will break off if the nut or bolt starts to come loose. Vibration
doesn't seem to effect it. Neither does rotation of the propeller on
the prop bolts.
During preflight, as I'm walking around, all I have to do is look
for the brightly colored "glob" on each bolt and I know that it is still
at the torque that I last left it. If the glob ain't there, it's
a'commin' loose and needs attention. This helps me perform a detailed
inspection without having to wrench each nut to see if it's tight.
I use it on my PPC and my Kolb with great results. I recommend it
to everyone.
Torque Seal Inspection Lacer
P/N F-900, 1/2 oz squeeze tube
Organic Products Company
PO Box 170428
Irving, Texas 75017
972-438-7321
e-mail: ink(at)opco.com
This stuff comes in several colors. Call or e-mail for a free
sample. You can also get the same tube from Aircraft Spruce for about
$3. The 1/2 oz tube is enough do every joint on a Kolb at least
twice. I've tried several colors, but the orange (which dries red) and
the yellow provide the best visibility for me. The blue dries too
light and isn't easy enough to see. They do tend to dry to a different
shade, so you may have to try a few colors to get one you like.
Give it a try. Anything to help perform a better preflight
provides for greater safety.
Ken W. Korenek
ken-foi(at)attbi.com
Kolb FireStar II, "My Mistress"
Rotax 503, Oil Injected
3 Blade Powerfin
http://home.attbi.com/~KolbraPilot/TX_files/image003.jpg
Six Chuter SR7-XL "Elmo"
Powered Parachute
Rotax 582, Oil Injected
3 Blade PowerFin
http://home.attbi.com/~KolbraPilot/TX_files/image005.jpg
4906 Oak Springs Drive
Arlington, Texas 76016
817-572-6832 voice
817-572-6842 fax
817-657-6500 cell
817-483-8054 home
From: | "Edward Steuber" <esteuber(at)rochester.rr.com> |
Gang,
I just realized we Ultrastar drivers have an advantage with
our propellar ground clearance.....our aerial weed whackers eliminate
any weeds that may cause the nut on the lower tail brace wire connection
from loosening........I could have used that as a selling point when I
sold mine yesterday.......but now I have to rebuild the one in the
hangar rafters....It's gonna start getting cold anyway...
.Hey, BB, how long before I can expect a visit ?
Ed in Western NY
just a comment. at this point I am glad I have the 'old firestar' cause
we have a bold running through the split elevator. always envied the no
bolt fold ups but guess they have an achies heal. I treat both the
bracing wire and the elevator bolt the same, nyloc WITH A SAFETY PIN.
Here is a question for all you engineer types: when you are flying, is
there 'up' pressure on the horizontal fins or 'down' pressure. example,
would they fold up in flight or fall down? sounds silly but got into a
discussion about it and when we were finished, it sounded right both
ways. not telling you which way I voted. (the right way) ted cowan
Kirk and Chris and Group,
Thanks for the tip about Richards antenna. I don't remember seeing his
before. Actually, I was referring to Boyd Young's "cheep dipole
antenna", at: http://www.brigham.net/~byoung/antenna.html
Any comments on the safety of using Boyd's antenna without an antenna
meter? Or should I use Richard's design instead?
John Jung
>Boyd or anyone,
From: | "vincenicely" <vincenicely(at)chartertn.net> |
Hi Gang,
fine .
> JJP
When my Firestar II was inspected by the DAR many years ago, he objected to
the selection of bolt/lock nut in several places on the plane. The reason is
the section of:
AC 4313-1B/AC43.13-2A Combined (Acceptable Methods and Techniques, and
Practices, Aircraft Inspection and Repair) listed under paragraph7-64-A DO
NOT use self-locking nuts on parts subject to rotation.
The DAR's interpretation was that places where tang's (as well as a few
other places in my Firestar) were located were subject to rotation and were
included in the above limitation. He found it acceptable for me to drill
the AN bolt and add a pin or to replace with regular drilled bolt and
castellated nut.
Vince Nicely
fine .
> JJP
> John J/Gang:
> a nice pin.
> perfectly safe.
> it.
> Take care,
> john h
Me too ! ! ! Thanks ! ! ! Safer Lar.
castle
castle
I did a huge amount of research on this, and I can assure
you............Boyd Young's antenna IS a true dipole, it does NOT fry
finals, and when testing mine I nearly got in trouble for interfering with
the local Approach's instructions to an incoming aircraft...........and I
was using a little handheld, INside a mobile home, with the antenna taped to
the inside of the window. I learned..........when Boyd speaks, I listen.
He knows his stuff. Appreciative Lar.
Subject: Re: Kolb-List: Cheep Dipole Antenna question
> > To:
> > > Boyd or anyone,
to
it
> > > John Jung
> > > Firestar II N6163J
> > > Upper Michigan
> John,
> Snuffy....WB8ZMY
I built one, and Erich Weaver built one, to Boyd's instructions, and used
the meter. Seems to me, the formula will give you a length of just under
25", using 123.00 for a frequency. Using the meter, it will have you cut it
down to about 23" for best SWR. Erich ????? Boyd ????? Is my memory
accurate ?? Lar.
> Boyd or anyone,
> John Jung
> Firestar II N6163J
> Upper Michigan
Vince ,
WELL / NICELY said . I hope that post is archived .
JJP
> Hi Gang,
> fine .
> > JJP
to
is
> the section of:
DO
were
> castellated nut.
> Vince Nicely
> From: "John Hauck" <hawk36(at)mindspring.com>
> To:
> fine .
> > JJP
> > John J/Gang:
> > a nice pin.
> > perfectly safe.
> > it.
> > Take care,
> > john h
John,
Ok, I checked out Boyd's cheep dipole. Yup that's a cheep one and will
work ok. From the sounds of it though, the way he mounted it on the plane
would make it more of a V antenna than a true dipole. A true dipole is one a
half wave length conductor split in the center and fed in the center . When
you start bending those two elements away from a straight line the antenna
becomes something other than a dipole which changes the impedance and
radiation pattern of the antenna. The Impedance can change, the radiation
pattern will change, and of course the inductive coupling with other metal
tubes in the frame of the Kolb will change these factors even more. A true
dipole works best when suspended in space at least one wave length from any
parasitic conductors. Virtually impossible in a Kolb. Also, a dipole is
bi-directional where as a 1/4 wave verticle is omni-directional and not
influenced as much by parasitic elements. A dipole has some gain because of
it's directional characteristics, however. My choice in an aircraft would
always be a omni-directional antenna. You can make a 1/4 wave vertical just
as cheap as the dipole. One of the things to be aware of with the antenna of
Boyds is to keep at least a 90 degree angle in the center. I wouldn't worry
too much about the swr if cut to length he suggests. One thing about his
dipole is that you could play around with it some to improve directional
characteristics. Somebody had stated 120 miles air to air with it on one
watt. I don't doubt that at all. But I bet you that in the direction
opposite the one that they were comunicating in the distance was just a
fraction of that 120 miles. Remember in your old Yagi TV antennas, the
element that the wires are connected to is a dipole. All the other elements
are parasitic elements that capitalize on the bidirectional characteristics
of the dipole. I still give Old Poops antenna my vote. Even if it is just
hanging limp underneath his Kolb belly. hehehe..........snuffy
> John Jung
> >Boyd or anyone,
Ted,
It depends how your plane is trimmed. The best way to find out for your plane
is to fly it at cruise speed and let go of the stick. If the nose goes down,
you have up force on the horizontal stabilizers, and the opposite if the nose
goes up. Due to the high thrust line, these directions may switch as one closes
or advances the throttle.
Jack B. Hart FF004
Jackson, MO
Jack & Louise Hart
jbhart(at)ldd.net
> included in the above limitation. > Vince Nicely
Hey Vince/Gang:
Did the DAR explain what there was and how it rotated or was subject to
rotation?
I think I agree with what you said,,,, but not sure I follow this. However
any aircraft (like a Kolb, certain military aircraft excluded) that has its
center of gravity and center of lift at a point on the main wing,,, the
force acting on the tail (Horizontal Stabilizer) is a **down force**. This
is how they are designed. If it were not so the aircraft would be unstable
and exceedingly dangerous to fly.
In other words if you loose the bracing on the bottom side of the tail you
may notice some flapping around with those surfaces, but the tail will
remain in a deployd position and you will be able to finish your flight. If
you loose your top bracing your aircraft will crash. As the horizontal
surfaces will instantly fold downwards from the aerodynamic loading, you
will nose over and enter a dive. Your only option would be your emergency
chute. Safety or cotter pin all nuts and bolts.....
Ron (CFI and A&P) :-)
8/25/02 6:49John J. Peters
> Now you sound like a very practical pilot , anyone that agreea with ME ,
> must be right , HAAAAA!!!!
> About your question on up vs down pressure on the tail feathers , it
> sounds like a decent argument on
> either side would get your vote .
Well truth is that on certified aircraft you are not allowed to use a nyloc
on any stractural component. There are self locking nuts that can do the
job, better and permanent. But they are not designed to be taken off. I
suppose the nylocs are a compromise. Inserting a safety pin or a safety wire
at the end should be done on any of those that can become a safety of flight
item. I know I will be doing so. Undreds of feet above ground is no place to
begine wondering if that nut will hold. Drilling a small hole at the end of
the shank and inserting a small cotter pin or safety wire is a no brainer.
8/25/02 5:12Ted Cowan
JACK JACK JACK ,
That statement you sent to Ted , couldn't be more incorrect !!!! ( "
If the nose goes down,you have up pressure on the tail ? ) That's
equivelant to saying , " if your losing altitude
you have down pressure on your wings ,i.e. NO LIFT .
IF THE NOSE GOES DOWN , YOU SIMPLY HAVE LESS DOWN PRESSURE ON THE TAIL
JJP
Subject: Re: Kolb-List: nylocs
> Ted,
plane is to fly it at cruise speed and let go of the stick. If the nose
goes down, you have up force on the horizontal stabilizers, and the opposite
if the nose goes up. Due to the high thrust line, these directions may
switch as one closes or advances the throttle.
> Jack B. Hart FF004
> Jackson, MO
> Jack & Louise Hart
> jbhart(at)ldd.net
In general, the interpetatotion is that any time you have a twisting force
on a nut & bolt it myst be mechanically saftied, nylocs don't do that (or
qualify). Nylocs are ok for static aplications. No vibrations or very little
etc.. I doubt I can find any place on a small aircraft that is free from
vibrations. In my certified airplane the only place I have nylocs is on the
antenna base plate, and even on those I applied locktite. :-)
Ron
8/25/02 10:07hawk36(at)mindspring.com
> Hey Vince/Gang:
> rotation?
> john h
Subject: | Aircraft Hardware (Nylocs) and AC43.13-1B |
Hi CPT Ron/Gents:
Guess I'll have to disagree on your broad statement above,
on the use of nyloc nuts, and go with what is in the AC.
Recommend you all check out what the reg states. AC
43.13-1B ACCEPTABLE METHODS, TECHNIQUES, AND PRACTICES -
AIRCRAFT INSPECTION AND REPAIR can be seen at this url:
http://av-info.faa.gov/dst/43-13/
I think Vince is the only one who mentioned the referenced
AC. When one has questions on what is acceptable and what
is not, it pays to go to the reg and check it out. We are
extremely lucky in todays electronic environment to be able
to have free access on the internet to just about any reg or
document that pertains to aviation and home building. This
is the place to determine what is and what is not correct,
THE BOOK.
Ron indicates he is a CFI and A&P. Recommend you take a
close look at AC 43.13-1B. You and the AC do not agree.
We have beaten nyloc nuts to death. My opinion, for what it
is worth is, do it the way the designer indicated, do it
your way, do it the way the DAR indicates, and/or do it any
way you like. I will continue to use nyloc nuts on the tail
wire bracing of my Mark III and any other Kolb aircraft I
build and fly. No one knows how or why the nyloc came off
the tail wires of John J's Firestar. Another reason why I
fly with a ballistic parachute.
The info in the AC hasn't changed much or differ any from
what we were taught back in the 60's on how to preflight
Army helicopters. Two types of lock nuts: All metal and
fiber (or nyloc). All metal for high temps, fiber for temps
up to 250F. Castle nuts and cotter pins for rotating
situations. No need for Loc Tite on a lock nut of either
type. Wasting your time and money. Lock nuts can be used
more than once. There is a table of torque values that
determines if it is a go or a no go. All this info is in
the AC.
Right out of the AC: "DO NOT use self-locking nuts on parts
subject to rotation." Tail wire tangs do not rotate. If
you have rotating tail wire tangs, they be mighty loose
Vern!!!
Here's another quote from the AC:
"Refer to the aircraft manufacturers structural repair
manual, the manufacturers engineering department, or the
FAA, before replacing any nut with any other type."
To me that means to do what Homer recommends.
BTW: CPT Ron, how about introducing yourself to us on the
Kolb List. We would like to know who you are, where you are
from, and what you are building and flying.
My name is John Hauck. I am flying a Mark III. Have built
three Kolbs: Ultrastar, 1984, Firestar, 1986, and the Mark
III in 1991d. Live in Titus, Alabama, and been flying out
of the same grass strip in the cow pasture for 18 years.
Kolbs are my way of "getting high". Some of ya'll will
understand that.
Take care,
john h (hope I don't have a nut loose) :-)
Hi John and all:
> rotation?
I fold my Firestar regularly. Each time the tail is folded, the tangs are
free to rotate owing to whatever forces are on the cable. The hinge bolt
where the tail pieces fold is another point, for example, where locknuts
were supplied wiith my kit and he thought there should be a safety pin or
wire on the nut. There were some others, but I do not recall right off
where they were. In principle, if you never fold your airplane, I suppose
the concern might not apply to the tail pieces.
Vince Nicely
> Vince Nicely
Vince/Gang:
Thanks for the clarification.
In your case, if it was me, I would use castle nuts and
cotter pins. Not nylocs and self drilling the ends of the
bolts for safety pins, etc.
The safety pins are questionable to me. There have been
reported cases of "hair pins" "spring pins" becoming
unattached and lost from the bottom tail wire tang bolt.
Don't recommend using the wing nut and safety pin. Wing nut
is not designed for the application.
I do not fold my airplane, unless it happens during a
crash. :-)
Boyd or anyone,
to cut it to
analyzer? Is it
John Jung
Firestar II N6163J
Upper Michigan
john if you leave it at 25 inches it will be too long....
and if the antenna is not tuned it can harm the radio and
will not perform any better than the rubber duck..... if
you dont want to buy a swr meter... try to find a ham radio
club and see if someone would help you.... to find a ham
radio club go to arrl.org
if you dont want to do that let me know and i will measure
mine and give you the measurements.... that way you will be
closer.
boyd
John,
You are absolutely correct. I tried to be too simplistic and as a result incorrect.
The thing to remember that when you are cruising along in level flight every thing
is in equilibrium. All the forces in the vertical, longitudinal and cross
directions cancel each other out, and the sum of the moments around the center
of gravity also cancel each other out. If the plane is perfectly trimmed, the
pilot can let go of the stick and the plane would continue as before until
some atmospheric disturbance upsets this equilibrium.
Now assume the aircraft is not perfectly trimmed in pitch but perfectly trimmed
in yaw and roll, and that the air through which the plane is flying is perfectly
smooth and quiet. If the nose pitches up on release of the stick, the elevator/horizontal
stabilizer combination lift has been reduced and wing angle attach
increased. Tension in the lower horizontal stabilizer cables will be reduced.
If the nose pitches down up on release of the stick, the elevator/horizontal
stabilizer combination lift has been increased and wing angle of attack
decreased. Tension in the upper horizontal stabilizer cables will be reduced.
Jack B. Hart FF004
Jackson, MO
> JACK JACK JACK ,
>JJP
Jack & Louise Hart
jbhart(at)ldd.net
Vince / Group
If your tangs on your tail wires move while in the folded position "Tighten
Them Up" They should NOT move.
As far as the elevator control pivot bolt goes, the bolt does not move,(or
at least it should not move) the elevator moves on the bolt.
Just my .02 worth
Guy S.
Subject: | Re: Kolb-List Digest: 36 Msgs - 08/25/02 aileron controls |
As someone on the list had done, I tried moving the holes inward on the end
of the torque tube, where the aileron push pull rods connect. The person on
the list moved his in 1". I extended my p-p rods out (keeping a min. 1/4" of
threads into the rod end bearings) and found I could move my holes in 3/4" on
my MK3. If anyone tries this, be sure that when fully deflected, the p-p rod
does not go past center where it connects to the torque tube. If so, it may
become locked or hard to bring ailerons back to neutral. Control stops could
be used also to eliminate this. Anyway I thought I would try this and if I
wasn't happy I would just go back to the original attachment point.
It appears to me, that in flight, stick pressure on the ailerons has been
reduced by about 1/3.
As the other person on the list mentioned, I am not recommending that
anyone on the list make adjustments to their control systems, as I did. All
I am doing is passing along something I did and what the results were.
Fly safe
Bob Griffin
Albany NY
Subject: | Re: Preflight Inspection |
I called this company today. They sell the seal for $1. and some change each
for a minimum of 6 tubes. I ordered the 6 tube minimum. Seems like a good
deal to me.
Ron Payne
> Gentlemen,
> the prop bolts.
> to everyone.
> PO Box 170428
> Irving, Texas 75017
> 972-438-7321
of just under
have you cut it
Is my memory
accurate ?? Lar.
that is close to what i remember. but i should think that
getting it checked is not that hard.... if cut to 23 it
should not fry the radio but would not be as good as it
can. if you take 118 and 136 then take the average you
end up with 127.5 and you should cut the antenna for best
swr at that freq... it will be higher at the ends but
should be within (no fry limits)i was thnking the legnth
was closer to 22.5 inches....for all on the list i will
check.... when i tested my rubber duck it was close to
the fry limits... some of the newer rubber ducks are
better than mine so your milage may vary.
boyd
ps just saw this on the list
Also, a dipole is
not exactly true...... but i can see where it comes
from..... if you can visualize a wire stuck through a hole
in a donut???? the wire is the antenna and the donut is
the radiation pattern..... if the wire is horizontal there
will be a ring of radiation around the wire and if you were
to try to talk to a station some distance from you it would
seem that the best radiation patern would be perpendicular
to the wire in front and back (bi directional) but if
the wire is put in the verticle position the donut is
horizontal and puts out a omni directional pattern. and
the signal would be equal in all directions and
distances..... no flames yet..... the mention of metal
tubes in the cage will cause the signal to look like the
donut has had a couple of bites taken out of
it....(radiation resistance) better signal in some
directions than others.... but i never said it was perfect,
i just said it will work realy good and not cause ANY drag.
From: | "Richard Neilsen" <neilsenr(at)michigan.gov> |
I'm not a mechanic and I will not depend on a 2 stroke anymore but...
When engines are assembled the cylinders are honed and new rings are
installed so that the rings will wear or seat into microscopic grooves
in the cylinders. If you move these rings around in the inspection
process aren't you screwing up the seating of these rings???
Rick Neilsen
Redrive VW Powered MKIII
>>> ulflyer(at)airmail.net 08/23/02 06:43PM >>>
We
They
the
the
jerryb
to ring
> > sticking
that they
inspection,
>Bob G
>Albany NY
>Bob,
as I
went
safe
could
the
mechanic
447
I
>Ralph Burlingame
>Original Firestar
>15 years flying
From: | "Dale Sellers" <dsellers(at)sgtcollege.org> |
The rings in a 2 stroke have dowels in the groves to keep them from moving.
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard
Neilsen
Subject: Re: Kolb-List: stuck rings
Rick Neilsen
We
They
the
the
jerryb
to ring
> > sticking
that they
inspection,
>Bob G
>Albany NY
>Bob,
as I
went
safe
could
the
mechanic
447
I
>Ralph Burlingame
>Original Firestar
>15 years flying
Subject: | Re: oil & tail wire tang bolts |
Group, Listers& Lurkers:
I have folded my Firestar I every time I fly and use the wingnut and spring
pin on the bottom tangs of the tailpost wires. I have NEVER seen the
wingnut loosen up against the spring pin, it always stays finger tight. Tall
grass is a concern, I have found grass stuck in the tang area, and the
spring clip is a preflight check.
I did a 100 hr. decarbon recently on my 40 hp. Hirth, and I have been using
Amsoil 50:1 racing oil. The carbon was not very thick but was rock hard and
very difficult to remove- should have soaked it . There was about a 1/4"
long area of carbon behind the top rings on both pistons, the rest of the
grooves were spotless. I have used seafoam aproximately every 30 hrs. and I
don't believe it works for me. Maybe I would have different results with a
mineral based oil. I am trying Klotz snowmobile techniplate, and will report
back in another 100 hrs.
Darren , FSI , Central MI.
Subject: | Re: cheep dipole |
What happens to the donuts when you bent the wire into a V or some other
convoluted shape? Which of course is being done in this instance. A
perfectly straight or near straight wire 1/2 wave in length, fed at the
center in free space? I'll buy the donuts yeah. Vertical polarization would
also be omni directional relative to earth based stations yes in the case of
a true dipole.......Don't know where the statement was about metal tubes
making it look like a donut came from. Probably deductive distortion. That
won't change antenna radiation patterns however. Inductive coupling will
though. Not a major factor however. The twisting and turning of the dipole
does deplete duality but not the dielectric constant......%}
From: | Gherkins Tim-rp3420 <rp3420(at)motorola.com> |
Kolbers,
Last spring I saw a Firestar II at a local fly-in that the owner opted to replace
lower tail flying wires with 3031 tube pushrod material, basically the same
type of set up for aileron push rods. I'm sure a bit heavier set up, but no
F4 Phantom effect if upper landing wires should come loose as did JJP's.
perfectly safe.
Boyd and other radio guys,
Let add one more potential problem. I have a Firestar instead of a Mark
III and the nose cone is narrower. Would this be a reason not to used
the cheep dipole?
Here is the probem that I am trying to fix. My handheld sits at my left,
just aft of the throttle, in a verticle position. I can reach the
controls and read the display there. But it picks up some interference,
occasionally, and it won't stop unless I touch the antenna or move the
radio slightly. That is why I want to use a remote antenna.
All help is appreciated. Radios are the most difficult part of flying
for me to understand.
John Jung
Subject: | Re: Noise reduction |
Bill is correct. I have a Yaesu VXA-100, and I have had problems transmitting
from a headset while flying. I checked with the Yaesu tech people and I found
that the microphone internal to the radio is not and cannot be disconnected while
one is trying to transmit from a headset. The tech's recommendation was
to plug the mic hole in the front of the hand held with tape etc. I have not
tried it yet but I will. In later Yaesu models, one can program them to turn
off the internal microphone.
Jack B. Hart FF004
Jackson, MO
>Bill.
>A couple things come to mind.
>One, what kind of radio are you using and are you using a hand held and the
>push to talk switch or separate PTT switch. Reason, some radio when keyed
>using the PTT button on the side will turn both the headset mike and the
>hand held mike, causing a lot of background noise.
>jerryb
>> OK Kolbers I need your help again. I need you ideas on how to
>>reduce the noise in the cockpit primarily because of not being able to
>>transmit on the radio. When I built the gap seal I installed a soft pack
Jack & Louise Hart
jbhart(at)ldd.net
Subject: | Re: Flight to Plano, Texas Bill Wisely |
, Clair Buttons
>(Guy's, John is one of the hard core Kolb builders, let's see if we can
>accommodate him. He's a good guy. John has a Kolb MKIII, 2 place. Jerry)
John?? Hmm don't think I ever heard of him. does he fly much ;)
Subject: | Re: Head replacement |
Ken,
I can give you a few answers, but the engine experts will have to
handle the rest.
>1. Should any sort of "gasket goop" be used or is the gasket all naked and
>alone the the proper way to go?
naked and clean with a new gasket
>2. This is an older 503, single ignition, only four bolt holes in the head.
>I have the torquing specs, but am unclear of the pattern and process to
>tighten them and have come to understand this is critical. Anyone care to
>explain in words of one syllable or less?
Experts needed here. I'm not sure if you can do only one head at a time.
I would think you could but the torque specs are not written that way.
>3. Does a head replacement require a break-in period? If so, what is it and
>how is it done?
No
>4. While the head is off, what else should I be looking at and for? Please
>bear in mind I have no knowledge of engines. For example, I had to ask
>somebody what "the PTO side" meant.
I can't think of anything, but someone probably will.
John Jung
Jack,
Would you know if the Yaesu Aviator Pro II has the mic hooked up like
that? Mine has not worked very poorly with a headset.
John Jung
while one is trying to transmit from a headset. The tech's recommendation was
George,
That is good news. Now I think that we are getting somewhere. So, did
you use an antenna meter and what length did you use? Is the center at
the top, with the center wire going down one side and the sheilding
going down the other side? Do I have the picture correct?
John Jung
George Alexander wrote:
>John et al:
>I have an original Firestar and use the cheap dipole taped to the inside
>(top) of the nose cone. Works far better than the rubber ducky even when the
>RD was mounted vertically outside the cone.
>George Alexander
John,
I believe yours can be programmed to shut down the internal microphone.
If you check the menu under "Set" you should find a setting under the name "IMI"
that lets you turn it on or off.
Jack B. Hart FF004
Jackson, MO
>Jack,
>John Jung
Jack & Louise Hart
jbhart(at)ldd.net
Jack and Group,
My Yaesu is the VXA-120 and I did find the program place that could turn
off the internal mic. It was already off. So, I hope that the external
antenna that I am working on makes the difference.
John Jung
John Jung wrote:
>Jack,
Hey Ken
I don't know for sure but I would tighten the bolts diagonally (top,
bottom right, left) in 25 lb increments (25 - 50 - 75 etc>) The general
theory to any head torqueing is to start in the center of a head and work
out to the ends evenly. While the head is off look at the cylinders for
unusual scuff marks or scratches. In case of trouble I may be in your area
on the weekend to visit the Renaissance festival. Let me know if you need help.
Subject: | Re: Noise reduction - try 199 dollar ANR's |
P M Condon wrote:
> Buy some 200 dollar ANR's and enjoy
> life. Call Lightspeed's 800 phone number and ask for the factory
> rebuilds.
Mr. Condon,
Today, I ordered the only one they had in stock. thanks for the tip.
Ken W. Korenek
3 Blade Powerfin
Powered Parachute
3 Blade PowerFin
817-572-6832 voice
817-572-6842 fax
817-657-6500 cell
817-483-8054 home
Ken W. Korenek
817-572-6832 voice
817-572-6842 fax
817-657-6500 cell
817-483-8054 home
Hi Ken and Gang,
I had a similar problem with my FS II if I understand you correctly. I
always had to hold the stick to the right as the plane wanted to bank to the
left a little bit. I put a trim tab bent down in the middle of the right
aileron. That took care of my problem.
If you lengthen the aileron adjustment tube it will only make your control
stick off center as the ailerons will still be in the same position while
flying.
The other option, and I believe that I saw this suggested here on this list,
is to modify the universal joint where it attaches at the back side of the
wing. Specifically what was described was to drill the hole off center on
the half of the universal joint that attaches to the cage so that he back
side of the wing is lowered slightly thereby changing the angle of attach
slightly and giving more lift.
For the back pressure on the stick problem, I think the solution most folks
use is to slightly raise or lower the ailerons by adjusting both aileron
tubes equally. This neutralizes the forces so you don't have to hold the
stick back. I think you would need to raise the ailerons slightly if your
having hold back stick.
Someone please correct me if I'm wrong on any of this. (Wouldn't be the
first time)
I'm sure you will get plenty of other ideas from the wealth of knowledge on
this list.
Later,
John Cooley
FS II #1162 122 hrs
> Hey Kolbers!
> The new wings seem to perform well, but I've noticed that in really
> smooth air, the left wing will fall if I let go of the stick.
> What's the best way to correct this problem? Put a trim tab bent
> up on the left aileron or just lengthen the left aileron adjustment
> tube?
> I have some adjusting to do- I have to hold more stick back pressure
> than I like and the left wing falls slightly, but other than that, "My
> Mistress" climbs and cruises better than I thought she would.
> Ya'll got any suggestions?
Subject: | Re: FireStars in the St. Louis area |
Does anyone have the name and telephone or e-mail number of the Kolb owner
that has the engine in the nose? I would like to talk to him.
Steve
Subject: | control linkage change |
inward on the end
when asking about the amount of threads that should be left
in the rod end bearings i was told that 6 full threads
inserted was the minimum safe number.... not sure how that
responds to 1/4 inch
boyd
instead of a Mark
not to used
the cheep dipole?
at my left,
reach the
interference,
or move the
of flying
John Jung
not sure why you have to touch the radio or antenna.....
but for the cost of the dipole it would be worth a try.....
a bnc connector and 5 to 7 ft of coax should not put
anyone in the poor house.
there is another way to change the antenna to fit in a
smaller space..... wrap it around a wooden dowell. so it
kind of looks like a spring and tape it there....... i have
not tried this and not sure if you would need it to be
longer or shorter but it should work..... they make ham
radio antennas out of a slinky toy. when installing the
dipole keep the center part of the antena as close to
vertical as possible... that is where the greatest curent
is located.... the ends can go horizontal if needed.. i
guess we could try a loop antenna..... the process would
be the same but start with twice the amount of bare wire
aprox 45 for the brade and 45 for the center conductor.....
solder the ends together and wrap the wire around the nose
cone..... with the coax connector on the side it is a
verticle polerazation..... on second thought it would
probably be too long at this frequency to fit properly.
the loop antenna will give you better signal forward and
back with less signal to the sides.
boyd
somewhere. So, did
center at
sheilding
John Jung
the center of the dipole should be on the side.... center
going up and braid going down.
boyd
Subject: | Engine mounted on nose |
Here are some more pictures I took of this one of a kind Kolb. Looks like the
wings, landing gear and the tail section is all thats left of the Kolb
everything else was redone.
http://members.aol.com/willuribe/f04.jpg
http://members.aol.com/willuribe/f03.jpg
http://members.aol.com/willuribe/f02.jpg
http://members.aol.com/willuribe/f01.jpg
Will Uribe
El Paso, TX
FireStar II N4GU
C-172 N2506U
http://home.elp.rr.com/airplane/
John, Ken & gang:
John is almost right. Adjusting just one pushrod will eventually change
the position of both ailerons. The pressure on the two ailerons will try to
equalize, moving the stick neutral and repositioning both ailerons either
reflexed up or drooping down. The trim tab is the way to go, however, it
does not sound like you would need much of one or much of a bend. I had to
hold right stick on my Fire Fly and used a tab to correct. Tab was made to
Kolbs plans, spanned two bays (three tubes) and had a 30 degree bend.
Shortly after take off I realized I was in trouble. It took two hands on
stick to keep level. I was real glad to get down without destroying plane
or myself. I took all the bend out of the tab now and the FF flies just
fine. If you only notice the wing drop with hands off, that is very close,
you might consider just letting it go that way. (my .02 worth.
Steve Spence FF 013, building Mk3X
Auburn Hills, MI
Subject: Re: Kolb-List: Trim
> Hi Ken and Gang,
the
control
> flying.
list,
folks
> first time)
on
> this list.
> Later,
> John Cooley
> FS II #1162 122 hrs
> > Hey Kolbers!
> > tube?
From: | "JCBuckeridge" <buckeridge1(at)mindspring.com> |
Subject: | FireStars in the St. Louis Area |
The fellow with the VW in the nose of the FireStar is Bill Bronson. He
writes the column in the EAA Experimenter
magazine. If you ask really good questions you might get published. Try
this:
onehalfvwguy(at)worldnet.att.net.
Subject: | Re: cheep antenna |
Concerning the problem of making antennas (not antennae as the media
says) physically shorter:
There are two ways. One is to place a coil (inductance) in series with
the bottom (fed end) of the antenna. The other way is to place a
capacitor at the top end. The latter is not as good, from a construction
basis, since it entails placing a circular disc (or circular array of
wire spokes) on the very end of the antenna. The two methods are,
respectively, bottom loaded and top loaded.
During the CB days (urgh, I'm gonna call LD on the Porcelain Phone) the
problem of mounting a 27 mHz whip on a car, meant an antenna many feet
long. Of course the same for hams operating in the 10-11 meter band. So
to get a shorter antenna, a large coil was inserted in the bottom end of
the antenna-- sometimes in a plastic can, other as a coil wound around
the bottom few inches of the whip. The top loading disc was rarely seen.
At this late date in my life I no longer have such test equipment such
as a Field Strength Meter or a Standing Wave meter/bridge to perform
accurate tests of antenna efficiency, I believe I can safely say that
all this micro-measuring, SWR-nulling of antennas is both unnecessary
and wasteful of hours that should be spent in Just Flying. Ain't gonna
fry no finals with these LP handhelds. If your radio xmtr is so powerful
that it may lie down and croak unless it "sees" a SWR of 1.0000, you
ain't flyin' a UL---even a FAT ONE, you're drivin' a beeg one.
licensed ham since '50, bootlegger before, flyin' before all that
Bob N.
Subject: | Re: control linkage change |
Only 3 threads are normally required. :-)
8/27/02 12:40b young
I am getting kinda confused on this. Are we talking about a regular coaxial
cable with a center + lead, and the shield is the (-)?
And what is a dipole?
I am pondering wheather I should build an integrated antenna while I am
building the rest.
Ron
8/27/02 13:00b young
> boyd
The Kolb Yellow Book of Diagrams that came with my MKIII states on page 7,
"Aileron Push-Pull Tubes" that the rod end bearing insert (threaded
portion) should go up into the rod end bearing at least 1/4".
Many female rod end bearings have little inspection holes drilled into the
side of the shank. Insert a bit of safety wire into the hole, and if you
don't hit the end of the threaded rod, then the threaded rod isn't in deep
enough.
If you have an Aircraft Spruce catalog, or any catalog that shows the
tables of various female rod end bearings, they indicate how far up the
inspection hole is from the end.
The bearing that accepts a 10/32" threaded rod has the inspection hole at
5/16" depth.
1/4" rod has it at 5/16" depth.
5/16" rod has it at 13/32" depth
3/8" rod has it at 15/32" depth
7/16" rod has it at 17/32" depth
1/2" rod has it at 19/32" depth
So that's how far in I would want the threaded rod to go. Amen?
Per AC 43.13, concerning locknuts:
A threaded bolt or screw, if it has a rounded or chamfered end, should
extend at least the full round or chamfer through the a fiber or nylon
locknut. Flat end screws, bolts or studs should extend at least 1/32"
through the locknut.
And per AC 43.13 concerning turnbuckles:
On a turnbuckle, where the threaded portion of the cable eye or fork is
exposed, no more than three threads are allowed to be showing.
Richard Pike
MKIII N420P (420ldPoops)
Anyone out there have an Ultra Star with brakes? I have the brakes (4 1/2"
internal) mounted to the wheels and welded a flange to the axle and mounted
the backing plates. Everything works fine. I want to attach the cables to
heel pedals. Any one done that? If so how did you do it? I'm thinking of
taking the large rudder pedals and modifying them so that they look like the
ones on a Fire Star only with the pedal part facing inward and attaching the
rudder cables to the pedal verticals. Then, construct some smaller pedals
to work on the same tube that the rudder pedal work on and attach the brake
cables to them with the cable end/adjusters mounted to the floor. This way
I will have differential braking. Opinions? Anyone got a better way?
Dale Sellers
Georgia Ultra Star
bend.
been experimenting with a trim tab with good
results....... my mk III rolled slightly to the
right.... had to hold about 1 to 2 bounds on the
stick.... i built the tab to cover 1 bay... the metal was
.025 alum.. measured 12.75 x 3... it was bent along the
long axis at the 1 inch mark... the 1 inch side was
riveted to the ribs. with the 2 inch side extending...
the bend was such that the end of the 2 inch side was 1/2
inch above a flat surface while the 1 inch section was held
down flat. we determined that the bottom side of the
aileron would be the best side to install with the bend
going down... my plane rolled to the right so we
installed it on the left wing. we taped it on with duct
tape and went for a ride and i could go for minuets at a
time hands off.... sometimes rolling to the right and
sometimes to the left when going through different air
patterns. the other mod i did was to double the
dihedredral in the wings... before i had negative roll
stability.... now it is neutral.... if working it up
again i would increase the dihedral a bit more and get
positive roll stability. to look at it you cant tell the
difference.
boyd
regular coaxial
while I am
building the rest.
Ron
ron look at this link
in an ideal world the braid and center conductor should be
straight.... in the kolb it ends up in more of a
L shape but it works just fine.
boyd
Subject: | Rod_end thread requirement |
It's very simple. Female rodends have sight holes across the chank to check
for proper thread length.
If you can look through the holes or push a thin wire (paperclip) through it,
there are NOT enough threads engaged. That's what the FAA or other inspector
does.
Herb
Dale,
On my old US, I mounted the 2 brake cylinders on the side of the cage.
Used 2 levers side by side that could be easily actuated with palm of hand.
Since I used a motorcycle throttle on the joy stick, I always had my left
hand free to work the brakes or flaperons.
...Richard Swiderski
Subject: Kolb-List: Brakes
1/2"
mounted
to
of
the
the
brake
way
> Dale Sellers
> Georgia Ultra Star
From: | Earl & Mim Zimmerman <emzi(at)supernet.com> |
> > Could you get a few more pictures of the FS with the engine in the
> nose?
> > That looks neat, but sure leads to a lot of questions.
> Yea like does (or how) it flies? ....what about the CG?
> Curious,
> Geoff Thistlethwaite
I think this is the same plane in the taxi mode. -- Earl
http://vulaorg.hostme.com/pictures2/engines/fourstar1lgbronsonvw.jpg
Subject: | rotax sticker shock |
I received my first ever Rotax parts today from Lockwood. I had never
needed parts before and since I needed the parts no matter what I just
ordered them over the phone without asking the price. That was a shock.
$18 for 2 washer halves, $30 for 2 rubber buffers. I don't mind a guy
making a profit but there has to be a limit. Are these high prices or
normal? Got me by the short hairs and think they can squeeze all they want?
All this talk about de carbonizing engines and small teardowns for
inspections has me wondering if anyone ever checks out their gearboxes. My
drive system is at 140 hrs and there were no outward signs of a problem. A
bit of airtime and I would have been a glider pilot. Lucky it happened on
the ground
Subject: | Re: rotax sticker shock |
From: | Richard Carlisle <rrcarl(at)concentric.net> |
Have you priced a new engine lately? Major price increase as of 8/1/02.
I've heard the the 912 had a $2000 price increase. On the other
hand...Rotax parts have always been notoriously high.
Ross
> From: Woody <duesouth(at)govital.net>
> Reply-To: kolb-list(at)matronics.com
> Date: Wed, 28 Aug 2002 21:00:24 -0400
> Subject: Kolb-List: rotax sticker shock
> the ground
Is there any way to price shop for those rotax parts on the Net?
Has anyone figured an easy method of keeping the control cables from fraying
before and after swaging. I had a mizerable time today with those cables
fraying, finally I soldered the tip ends so I can run them through.
Any ideas out in Kolb Land?
8/28/02 18:00Woody
> the ground
List
Gotta say; I think that the half vw engine is mounted on the front of
a highly modified Ultrastar?? Herb in Ky
writes:
> in the
> > nose?
> > Curious,
> messages.
Subject: | Re: frayed cables |
Are we talking about the 3/32" cables that go to the rudder and elevators?
Richard Pike
please some info on"2SI"
vnz hallam uk///
Air Craft Spruce sells a small cable cutter. It works like a set of wire
cutters but has curved jaws. This is what I used on all my cables and it
cuts a clean end on the cables with no fraying. Don't remember what it costs
but as far as I can remember it was not expensive.
Ron Payne
Date: Thursday, August 29, 2002 12:16:53 AM
Subject: Re: Kolb-List: frayed cables
Richard Pike
fraying
From: | "Geoff Thistlethwaite" <geoffthis(at)charter.net> |
When I made up my rudder and elevator cables I purchased this cable cutter
and it did an excellent job of making a good clean cut. But to help keep all
the little wires where they belong my uncle had me wrap one layer of masking
tape around the cable at the cut point and cut the wire with the tape being
left on both cut ends. I had no more problem with the cables fraying as I
threaded the swags on....
hope this helps
costs
> Ron Payne
> Richard Pike
> fraying
WillUribe(at)aol.com wrote:
> Here is a picture of another Kolb with the engine on the nose.
> http://vulaorg.hostme.com/pictures2/earlyplanes/kolbtractor.jpg
I think that this one is the Kolb Co. TwinsStar prototype, and that is
Homer in the left seat. -- Earl
From: | "Tom Olenik" <olenik-aviation(at)buyitsellitfixit.com> |
What would you like to know?
2SI currently has 4 basic engines available. There is the 430FE-35 which is
a direct decendant from the Cuyuna 430. Like the Rotax 503, it has
undergone a lot of improvements over the years though.
There is the 460F-35 which is really close to the same as the 430FE-35
except no electrical system, a larger bore, and a lighter weight, lower
output exhaust system. This is the engine that Skystar is using on the
Kitfox Lite and Aeroworks is using on the Aerolite 103. Personally, I would
go with the 430FE-35 for $100 more and 5 pounds, you get an electrical
system and about 3 more HP.
Then there is the 460L-46 which is a two cylinder, piston ported, liquid
cooled 2-stroke which puts out about 46 HP at 6250RPM. It comes standard
with single carb and electric start although a prototype of a manual start,
dual carb version has just been finished and will be tested in coming
months. This engine uses the same bottom end as the 430FE and the 460F.
The 690 and the 460L both share the same top end only the 460L is 2
cylinders and the 690 is 3.
The 690L-70 is a three cylinder, piston ported, liquid cooled 2-stroke that
puts out 70 hp at 6250 rpm. It also comes standard with electric start and
has 3 Bing 54 carbs.
The biggest problem that I hear about the engines on any kind of a regular
basis is getting them jetted right when you first start out. They usually
get sent out pretty rich.
They are also working on a dual carb kit for the 460F-35 and 430FE-35 to put
them up over 40hp and I am working on getting the job of flight testing that
engine on my powered parachute design when completed, but again that is a
ways off yet.
If you have any questions, please let me know.
Tom Olenik
Olenik Aviation
http://www.buyitsellitfixit.com/rotax.htm
http://www.buyitsellitfixit.com/2si-engines.htm
Vincehallam(at)aol.com
Subject: Re: Kolb-List: rotax sticker shock
vnz hallam uk///
Yes, thats right 3/32, they keep fraying on me. :-)
8/28/02 20:23Richard Pike
Sorry I see that 2si word being talked about like it is a real option.
As an old timer I remember the 2si when it was sold under another name
"Cyuna". It was a early leader in the untralight engine business when it
was able to run under load for more than 30 minutes without seizing.
Then Rotax started selling engines it disappeared from the market over
night. At one point the company that now sells the 2si had a twin engine
package so that when one engine seized you could limp home on the
remaining engine. They may have fixed their product but one would think
the price would increase if it was as any good. If it sounds too good to
be true, it might be.
I really don't want to fly a 2 stroke and I will not pay the inflated
cost of a Rotax, Lycoming, or Continental engine. I have been flying VWs
on my Kolb for four years and am getting close to a good alternative to
these high priced engines. I'm in the process of trading my reduction
drive from Gene Smith. I don't know the cost yet (it may be free) but I
will be changing the reduction ratio to a 1.66 to 1 reduction instead of
my 1.6 to one and it will also have .5 inch lower thrust line. My
problem is the prop is a bit too large to get a good speed range. I have
tried lowering the pitch on the prop so that I get 3700 on take off but
then the engine will go over 4300 at high throttle (below red line) but
just too fast and is too busy for my tastes. Last night I flew with a
pitch setting where I was getting 3100 on take off and 3800 WOT at 83MPH
actual. I flew around at 3100RPM on the engine 1937RPM at the prop doing
73MPH actual. The engine just purred and the noise level was so low that
I shut off the ANR on my head phones and then took them off. It was
still noisy but tolerable about like a Cessna 172. This pitch setting
will be my traveling pitch. The new reduction ratio will at the very
least increase the engine RPMs by 100RPM and hopefully give me better
climb at higher pitch settings. The lowered thrust line will help the
pitch down problem that I get with heaver passengers. I have added
weight to the tail for flying with heavy passengers but I really don't
want to add weight when I'm already heavy.
Sorry this was so long but that 2 stroke 2si thing got me going.
Rick Neilsen
>>> CaptainRon(at)theriver.com 08/28/02 11:57PM >>>
Well 2si is certainly an option. if I recall correctly their max output
is
70hp. At my summer density altitude of 8000 ft at ground level that
engine
only puts out about 53 Hp. I don't know how well the M3E does on 53 Hp
at
gross weight. Its fairly heavy p/w ratio at 19# per hp. I have flown
worse
but it has never been fun. And this kolb is about fun for me. :-)
I would like to add that if I were at near 0 MSL the 2si would
certainly be
first choice for me.
Subject: | Re: Kolb-List Digest: 24 Msgs - 08/28/02 |
>>Has anyone figured an easy method of keeping the >>control cables from
fraying
>>before and after swaging. I had a mizerable time today Any ideas out in
Kolb Land?
Use a small piece of thin tape and wrap the cable before cutting, be sure
it is not under your swedge.
>>I would like to add that if I were at near 0 MSL the 2si would certainly
be
If you haven't, do an archive search on 2SI before you get your wallet out!
Darren, FSI, 2702 Hirth, Central MI.
The easiest way to get a good clean cut on 1/16" or 3/32" cable is with a
hammer, an anvil, and a cold chisel. For your anvil, get any flat fairly
heavy substantial piece of metal. I currently use an old sheet metal dolly,
but in the past have used the side of an axe head or the side of a
splitting wedge for the anvil. Make sure the cold chisel is sharp. You can
wrap the end of the cable with tape, but a little practice normally makes
that unnecessary. Lay the cable on the anvil, (If you don't have a helper
to hold the cable still, a swatch of duct tape will hold the cable still on
the anvil) position the chisel, and strike the chisel sharply with the
hammer. Nine times out of ten, it will be perfect on the first shot. Even
if it takes a second lick, it still will not fray. Try it, you will
probably like it better than using a cable cutter.
Richard Pike
I actually prefer the power to weight ratios that 2 strokes offer, but I
would not fly a 2SI or Hirth. Too many horror stories out there...and too
many first hand experiences.
The price point really is not a valid argument for the 2SI or Hirth. A
comparable engine to Rotax is only slightly less money. Not enough to be a
test pilot for the engine manufacturer.
The 430FE-35 which I assume is roughly comparable to the Rotax 447 goes for
$2713 with gear box as per Tom's web site. We just bought a new 447 last
week for $2800 with gearbox.
Ross
Ross,
That gearbox is comparable to a Rotax type C and for the 46 hp engine and
under, their belt drive works great and is just as reliable as a type B
gearbox. It runs very smooth, is easy to preflight and save a bunch of
weight and cost. It has turned out to be a very good drive and then the
cost is $2373 compared to $2800. If you look at the 460L-46 at $2914 with
gearbox and electric start, compare that to a single carb 503 with type C
drive and electric start at $4371. Or compare a 690L-70 with electric start
and gearbox at $4194 compared to the 582 with C drive and electric start at
$5724.
The real cost savings though, is in the parts. A piston assy for a 2SI
430FE-35 including rings and wrist pin is just $68. A 447 piston with rings
is $173 and that does not include the wrist pin. So you are looking at a
1/3 of the cost for a piston. A complete seal and gasket set for any of the
2SI engines including the 3 cylinder 690 is less than $40. A seal and
gasket set for a 582 is $158. A cylinder head for a 430FE-35 is $74. A
cylinder head for a Rotax 447 is $141. So the real savings comes in
maintenance. It is also only about 2/3 the labor charge at most places to
have overhaul work done on a 2SI engine. At least that is how I charge.
You guys have always been the test pilot for Rotax engines. They are always
making little changes to stuff without telling us. Most of the time it's
insignificant, but I know for a fact that Rotax has never done any flight
testing of any engine besides maybe the certified 912's and that was done
more by their distributors than anyone else. Contrary to your beliefs, 2SI
does have significant changes or engine mods flight tested before release to
the public. There is a prototype of the 460L dual carb now done and ready
for first ground tests then flight tests. I am talking with them about
doing the flight testing for a dual carb kit and exhaust systems for the
460F-35 and the 430FE-35.
It is true there are stories out there about people with problems, but if
you dig deep enough you will find that those problems were caused by
ignorance or neglect on the part of the operator in most cases. I hear
Rotax horror stories every day on the phone, but that does not make Rotax a
bad engine. Every engine will have problems if not treated right, and most
problems stem from not treating them right.
So if you dig a little deeper, you might have a change of heart. I looked
into these problem for about a year and a half before I decided to get
involved with these engines. At the bottom of all the problems I was
satisfied that there was no major fault with the engine. At least not any
that could not be solved with competent tech support. Rotax is my bread and
butter and what puts food in the mouths of my kids, but I think 2SI really
has something in their current engines.
I am embarrassed by the prices I have to charge for some Rotax parts at
overhaul. It makes me look bad and doesn't make me any more money because
my cost is high too. I think if I can save the customer a few dollars with
a good product and still make about the same, then it is a good deal for
both of us. I think that is possible with the 2SI engines. That doesn't
work if the product is no good, but I think the product is a good one in
this case.
Tom Olenik
Olenik Aviation
-----Original Message-----
Carlisle
Ross
I am glad that you said that. Life aint long enough to learn all the things
that other people already know. So good input and advice is apreciated. :-)
8/29/02 8:35Richard Neilsen
> Rick Neilsen
> is
> engine
> at
> worse
> certainly be
That's true...Actually that's true of anything that is not certified. There
is strength in numbers though, and there are a ton of Rotax engines flying.
I went through this debate in my head 2 years ago trying to save money over
Rotax. I found that Rotax has the least percentage of failures based on
engines sold and generally the happiest customer base.
Rotax has proven themselves in the field just based on the number of engines
flying and the number of repeat customers. The extra engine cost is nothing
compared to putting the plane in the trees because of an engine failure.
I know there is no guarantee that a 503 will not burn down, but
statistically there is a better chance that one of the others will burn down
first.
Ross
Subject: | Firestar Enclosure? |
Fellow Kolbers,
Does Kolb have a full enclosure for the Firestar II? I know the Firefly has
one but was not sure about the Firestar.
Thanks in advance for your replies,
Allen
Subject: | Re: Firestar Enclosure? |
Allen,
Yes, they do. The rear is flexable material and attaches with velcro. I
didn't know the Firefly had one.
John Jung
ALLENB007(at)aol.com wrote:
>Fellow Kolbers,
>Allen
----- Original Message ----- From: <<A HREF="mailto:ALLENB007(at)aol.com">ALLENB007(at)aol.com>
Subject: Kolb-List: Firestar Enclosure?
> Fellow Kolbers,
has
> Allen
Sure can and the best part it's easy to remove for summer flying.
Take a look
http://home.elp.rr.com/airplane/Camarillo.jpg
This is a picture of how it comes right out of the box from Kolb.
http://members.aol.com/willuribe/166.jpg
Will Uribe
El Paso, TX
FireStar II N4GU
C-172 N2506U
Regarding the gear box, what engine and prop are you running (make, length,
number of blades) and what ratio on the gear box. Just curious.
jerryb
>the ground
I cut the cables using a Dremel tool and abrasive wheel. I wrap the cable
at the point I want to cut with 3M blue low adhesive tape. Cut thru the
tape and the cable. Seems to slightly melt the ends together and don't
fray nearly as easy afterwards using this method.
To make the final cuts, get cable pulled taunt, put your ferrules on both
if your using two, hold the cable taught with the electricians wire clamps
(can't recall their strange name, you know the copper thingy with the
slotted bolt and the nut), Nico press the ferrules, check with a
gauge. Now trim the cable ends by wrapping a piece of tape around the
loose cable end near the ferrule, shove a piece of thin stainless steel
about .008 to .015 thick x 2" x 4" (.008 works really good) under the loose
end until it stopped by the ferrule. Use the Dremel tool and cut the loose
end approx. 1/16"-1/8" from the ferrule. Your done. (If your haven't
figured out the stainless steel is used to prevent from nicking or cutting
into the taught cable. Don't use aluminum, you can cut thru it to easy,
the SS is tuff. Practice on a scrap piece a few times.) You can dab a
little paint on the end stub and taught side of the cable as a slippage
indicator. If the paint disappears, inspect the ferrules closer for
slippage. This method has worked great for us.
Jerryb
>8/28/02 18:00Woody
> > the ground
Makes those Kangaroo engines (Jabiru) sound better all the time.
jerryb
>Ross
> > the ground
I think it comes down to how much it will cost you after purchase to kept
the Hirth or 2Si running while the Rotax chugs on not to say something
can't happen to a Rotax. Those after sale freight, parts, and repair
charges add up fast.
jerryb
>Ross
Tom,
Thanks for the input about 2SI because I recently acquired one to
add to my collection of Cuyuna's. I have over 100 hours on the first
Cuyuna UL202 and it still is running well . It has the cog belt drive
with the 3 blade Warp drive and it seems happy with this combination.
Should I be looking at decarboning or more drastic maintenance
at this time ( 100 hrs.) on the Cuyuna.
When I first started running this engine I had a lot of trouble
with jetting the carb because of ignorance and inexperience but once I
became educated, it runs fine. I think a lot of Cuyuna stories can be
explained by the operator doing his own maintenance and overhauls. I
understand Cuyuna support was not very accessible through the country at
that time . Besides , this list did not exist nor did the
internet......
And I understand many operators of that period did not have
EGT's or CHT's to monitor ...I can't imagine trying to run even a Rotax
under those handicaps .
I am still a new guy in ultralights and I do take advice but
I am beginning to think the Cuyuna may have been getting a bit of bad
publicity.
And thanks to all of the experienced Cuyuna drivers that
have helped me with advice and encouragement.
Ultrastar Ed in Western NY
( lookout, it's about to blow anytime now ! )
The UL202 will go a very long time in most cases before you would need to do
anything major. As long as you keep fresh gasoline in it and a decent oil
the 500 hour teardown is pretty realistic. Of course, if it takes 15 years
to get that many hours, you'll probably have to do something sooner. It's
just like the Rotax in that respect. A 10 year old engine will need more
maintenance per hour than a 3 year old engine.
What carb are you running on your UL202?
Tom Olenik
Olenik Aviation
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Edward Steuber
Subject: Kolb-List: 2SI
Tom,
internet......
publicity.
Subject: | Kolb flying characteristics |
I have noticed here or on some other forum mention of the "different"
flying characteristics of the Kolb line. Could someone brief me on what
that means. I'm new to UL, have a private license but no medical, and
am looking to buy or build something that'll get me off the ground
again. Thanks in advance.
Dave Miller
From: | "Dave Stroberg" <dgstro(at)albemarlenet.com> |
Subject: | Re: Kolb flying characteristics |
Hi Dave,
I have a FirestarII amphibian and about the only difference I can tell about
"flying charastics" is... at cruse, if you chop the power the nose will
pitch up. If you firewall it at curse the nose will pitch down. Normal
changes in power have very little effect on the pitch. The pitching is due
to the high thrust line of the prop and where it's located. Other than that
it's one of the most fun things you can get hold of to fly.
By the way, mine is for sale. Started a MarkIII project.
Fly safe and good luck on finding something.
Dave
Subject: Kolb-List: Kolb flying characteristics
> Dave Miller
You seem to have a good method. For the present I am done with the bracing
wires. As I mentioned earlier I used a chiesel taping the ends first. I have
used two ferrules per wire end. I thought I saw that somewhere in the
instructions. I used the Dremel tool with the cutting wheel 2 days ago, but
it took too much time. the sharp chiesel technic is really fast and fun. As
the wire just snaps off when you hit the chiesel with a sharp blow. I
sharpened the chiesel to a knife edge before I started, , and once more half
way through. I used the side of a bucking bar as the envil.
Did you do your control cable for the elevator and rudder at the same time,
or did you waite until the cage came?
Oh yes I used shrink tube on the ends of the remaining wire as protection
and slippage marker. I don't expect any slippage *ever* on the cable with
two ferrules per side. :-)
> Jerryb
>> 8/28/02 18:00Woody
>>> the ground
Hi,
The more informed we are the better - please do cross post relevant info.
Steve
"Engines-Ul(at)Yahoogroups. Com" ,
"Kolb-List(at)Matronics. Com" ,
"Titanaircraft(at)yahoogroups. com" ,
"Powerchutes(at)Yahoogroups. Com"
Subject: | Rotax 912's Burning Oil? |
Hi guys,
Does anyone have a 912 or know someone who has a 912 that is burning oil?
How much in how long Engine model and serial #? Let me know.
Tom Olenik
Olenik Aviation
We did our rudder cables before covering the cage. If I recall right (boy
that was a long time ago 1997) we did the cables for the tail components
after they were covered. One thing to watch out for, when you use the
Dremel with an abrasive wheel to cut things, be careful to have something
to catch the part being cut off so it doesn't land on any fabric. We now
have a drain hole on the belly when I was trimming the instrument shock
mount studs. Oop's - frown by my partner.
jerryb
> > Jerryb
> fraying
> >> 8/28/02 18:00Woody
> want?
> gearboxes. My
> problem. A
> >>> the ground
Subject: | Driving to London |
This is for Florida and South Georgia Kolbers,
I am planning to driving from Tallahassee to London for the gathering at
the end of September but I dread that long drive. If any of you want to come through
Tallahassee or meet on I-75 and share the ride (gas costs) please contact
me off line.
Duane the plane, Tallahassee, FL, FireFly SN 007, 125 Hrs, Mk3/912 in the shop.
Subject: | 1986 twinstar c of g |
> I'm nearing completion on a 1986 twinstar and have a couple of questions
regarding weight and balance. Where would the datum line be and what are the
c of g limits? Any information would be greatly appreiciated.
Sandy
Yeah I never heard of a Rotax ever failing. One thing I noticed about
2si is that they recommend a 40/1 oil ratio. Most pilots with them have
been running 50/1 like the rotax boys with less than admirable reliability.
As always use the manufacturers recommendations in an attempt to get good
performance.
Subject: | Re: 1986 twinstar c of g |
Well and this is in general. The datum can be anywhere. I would suggest the
tip of the nose, as all values measured from there would be positive. As far
as Cg limits are, I wouldn't know.
8/30/02 19:10Sandy Hegyi
> Thanks
Subject: | cheep antenna results |
Group,
After two years of frustration with a radio, I can finally report
success. As of last night, I am for the first time, getting reports that
I can be heard clearly. What it took was a variation of Boyd's "cheep
dipole antenna". In order to keep the antenna mostly verticle, in a
Firestar nose cone, it is wraped around a piece of neopreme fuel line.
Thanks go mostly to Boyd, but also to Kirk, George and Larry for their
help and encourament on this problem. The rubber duck antenna on my
Yaesu was useless in a my Rotax powered Firestar. An example of the
difference is that with the dipole antenna, I can receive four weather
stations instead of just one.
John Jung
Subject: | Simple instrument panel |
Group,
Two years ago, I sold my instrument panel, and replaced it with a new
one using an EIS. As regular readers already know, I have been very
pleased with the EIS. But until last night, my website still showed the
old panel. While doing some aerial photography, last evening, I finally
took a picture of the panel. See it on my wed page:
http://jrjung.0catch.com/Inflight.html
John Jung
Firestar II
UP of Michigan
If you have never heard of a Rotax failing, you haven't been around very
long or have not been listening very carefully. About half of my income
comes from Rotax engines failing in flight. The other half is partial
failures and just regular preventative maintenance.
I used to be in a position to see the majority of warranty claims on Rotax
engines as well. I don't know why people accept those failures as normal
while pointing fingers at other engines as having problems?
I don't care who makes it, a two stroke engine is prone to failure. Even
503's seize pistons, and have crankshafts fail on them with relatively low
time. I see it all the time. I think sometimes other engines are somehow
held to a higher standard.
Tom Olenik
Olenik Aviation
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Woody
performance.
>jerryb
I am using a GSC 3 blade wood prop. I would rather have a 2 blade
warp. I think it is about 63 dia and I did not figure out the ratio. This
is the unit that was being used on the plane when I bought it so I have not
thought to change anything.
It seems the half washers wore out allowing the cup springs to apply
a very strong force to the center race on the bearing. This caused the
center race to fail. Hard to check for but if you pull the gearbox cover
off and you find a spring force behind it then you can assume it is the
half washers that gave up and the internal bearing needs replacing. Has
anyone else had this problem? Tom can you enlighten us?
I also built a new motor mount last week. It is 2 strips of Aluminum 3
x 13 x 1/4. The motor is bolted to them length wise. Holes are drilled to
mount these to the rubber mount Extra holes are drilled for the rubber
mounts. My modification allows for moving the motor 1" or 2" toward the
tail. Cost nothing and replaces any prop extension I may have wanted to buy.
You missed the sarcasm in my last posting. I agree with everything you
said in the last post. Every one says all other engines are no good because
some one had one once and it failed. I think it is because every Rotax
expert out there tells the non Rotax pilots how to adjust their engines. My
HIrth runs a head temp that would make a Rotax pilot faint. If I run it to
a Rotax temp range it will carbon up and not get full power. A 2si pilot
will seize an engine if he uses a 50/1 oil ratio when the mfg. recommends
20% more oil. If anyone knows of a Hirth or 3 cyl. 2si boat anchor some one
wants to throw away let me know.
From: | "Christopher Armstrong" <tophera(at)centurytel.net> |
John, can we see a picture of that new antenna while your adding things to
the web site? sounds like a great variation.
Topher
Subject: | John Jung dipole |
John,
What was the SWR on the antenna? Kirk
Ok, I guess I did miss the sarcasm. I've found that I always have to note
when I'm being srcastic in my e-mails. I don't think the 40:1 vs 50:1 has
as much to do with problems as the prop loading issue. It seems that all
the guys that just run them and forget about them are the ones that have
thier engines properly loaded. They gues having problems with jetting and
tuning are the ones that are loading the 2SI engine at the same RPM as the
Rotax and it just does not work.
I'll take any Cuyuna or 2SI engine that anyone doesn't want also.
Tom Olenik
Olenik Aviation
Subject: RE: Kolb-List: rotax sticker shock
> I started flying 37 years ago, have owned 6 other airplanes and U/L's and
> can't think of any other flying machine I'd rather have.
> (For under 50K)
> Richard Pike
Richard/Gents:
Same here, except I am a late bloomer. Didn't solo until
1968.
I fly my Mark III cause it satisfies all my aviating
desires. This is good. I won't have to build something
else as long as I am happy with Miss P'fer.
One comment refer stable aircraft. Homer builds airplanes
to squeeze out performance, over designing for stability.
My understanding is we lose some performance when we
increase stability. That is why we have a straight wing (on
a tiny bit of dihedral for aesthetic purposes only). My
Mark III is very unstable. I have to fly it all the time.
There are short periods when it will fly hands off, but it
is not inherently stable. If it was stable I would have a
hard time trying to stay awake on long cross countries. :-)
A good source informs me that Homer is playing around with
an old Firestar and exploring some of the realm of greater
dihedral. Maybe I will find out this Fall, if I can squeeze
a flight in up Pennsylvania way.
How far is Kirk Smith's airstrip from Homer? Kirk, send me
the coordinates for your airstrip. Thinking about heading
up that way.
Take care,
While extolling the virtues of our Kolb Ultralight's to a fellow aviator, he
asked a question that I couldn't answer. Told him I would look it up and
get back to him. Haven't been able to find any information in any of the
paper work I received from Kolb and no one else seems to know either.
The question is -" what is the glide ratio of our Kolbs"? If anyone out
there has some information on this I would appreciate an answer.
Also for you 447 drivers. Check your muffler mount brackets! I just had
to replace one of mine for second time with 160 hr.'s on it. No more
aluminum for me, I replaced them all with steel angle. The little bit of
weight gain is worth the security of knowing my muffler won't be exiting
through the prop. That would tend to ruin my day!
Terry K. FireFly #95 - 163 hr.'s
Subject: Re: Kolb-List: Kolb flying characteristics
> up that way.
I'm in Michigan John. But you are sure welcome to stop in. Everybody is.
Got 2000 feet of weeds, I even mow sometimes, LOL, lots a room to camp or
use the old travel trailer, got tools, vehicle to run to town in, shower,
fuel cans ( plastic and metal LOL) , no control tower unless you count the
deer blind. GPS 43* 10.8' N 83* 21.1' W ..........9/27 .......look out
for deer and turkeys on the runway.
Subject: | Re: John Jung dipole |
Kirk,
I don't have a way to check SWR, so I went without it. If you get up
this way, bring you equipment and we can find out.
John Jung
Kirk Smith wrote:
>John,
Subject: | Re: spiral dipole |
Topher,
I would rather get an antenna analyzer on it or at least more testing
done before I offer it as an example. It is basically Boyd's dipole (24
inches of striped coaxial with the center conductor pulled out through
the shielding), except it is wrapped around 18 inches of gas line with
the unmodified coaxial cable exiting at the middle. The center wire
wraps 9 inches one way while the shielding wraps 9 inches the other way.
All held together and in place with duct tape. What would we do without
duct tape?
John Jung
>Topher
> a flight in up Pennsylvania way.> Take care,
> john h
John and others,
I built my Original Firestar with more dihedral than what is in the
plans. Mine has 2-5/8" from level at the last rib and the plans were at
1". Having flown many other Firestars, mine is slightly more stable in
roll, but I still have to fly it all the time unless I'm flying in calm
conditions or smooth air.
Ralph Burlingame
Original Firestar
15 years flying it
Subject: | Space Station Supernova |
Hi! I thought you'd be interested in this story from Science@NASA: During the first week of September, the space station will emerge from Earth's shadow just before sunrise over several major US cities, including Washington DC, Philadelphia and San Francisco. The spacecraft, suddenly brightening like a supernova, will be worth waking up to see. http://science.nasa.gov/headlines/y2002/28aug_sunrise.htm?friend
In a message dated 8/22/02 3:33:36 PM Eastern Daylight Time,
hawk36(at)mindspring.com writes:
<< Just got back from changing the oil, 100% synthetic Mobil I,
in my old 912S. Flew over to the local airport, Wetumpka,
to wash it. About 2 miles and 2,000 feet out of my
airstrip, I realized that the last thing I should have done,
but didn't, was tighten the inlet and outlet oil lines to
the oil tank. I had hand tightened them, got out of
sequence, and went to something else before I grabbed the
wrench and snugged the two collar nuts up. I quickly did a
180, headed for Gantt International Airstrip, with one eye
constantly on the oip pressure gauge and the other eye
looking for forced landing areas. When I landed both lines
were still on, but loose and leaking. I was lucky this
time. No matter how long one has been maintaining and
flying, there is still room for error. Murphy never rests.
Take care,
Don't know for sure, John, but I think this is exactly what happened to Jim
Lee at sun n fun when he bought the big one....he turned to try to tighten
one of them, which I think actually fell off during take off. He was from
Sharon, pa and had built the Kolb for someone whose name started with B and
was doing a test flight for his customer down there when it
happened...crashed on land near the seaplane place.
George Randolph
Firestar driver from Akron, O
Subject: | Re: (no subject) |
Terry,
My Original Firestar is has a glide ratio of about 9:1. I do not have the
rear cage covered.
Would you believe I use 1" x 1/8" aluminum brackets (bought at the
hardware store) for the muffler? It all has to do with the amount of
stress that is built into the bracket. Before I straightened this problem
out, I had cracked muffler brackets after just 20 hours of flying.
Eventually the muffler will end up cracking if the stress is not
relieved. Had that happen too a number of years back.
Those smaller brackets have over 200 hours on them without any cracks. I
must have got it right this time.
Ralph Burlingame
Original Firestar
15 years flying it
> aviator, he
> up and
> of the
> either.
> out
> just had
> more
> bit of
> exiting
Subject: | Re: Flight to Plano, TexasBill Wisely , |
Clair Buttons
John Hauck wrote:
> Will need MOGAS.
John,
I can't stand it any more. I've got to know- What is "MOGAS?"
Hook, line and sinker Ken
Ken W. Korenek
ken-foi(at)attbi.com
Kolb FireStar II, "My Mistress"
Rotax 503, Oil Injected
3 Blade Powerfin
http://home.attbi.com/~KolbraPilot/TX_files/image003.jpg
Six Chuter SR7-XL "Elmo"
Powered Parachute
Rotax 582, Oil Injected
3 Blade PowerFin
http://home.attbi.com/~KolbraPilot/TX_files/image005.jpg
4906 Oak Springs Drive
Arlington, Texas 76016
817-572-6832 voice
817-572-6842 fax
817-657-6500 cell
817-483-8054 home
mogas=MOtor GAS vice AViation GAS
Subject: | Re: escaped disaster |
In a message dated 8/24/02 7:16:50 PM Eastern Daylight Time, TopGunPI(at)att.net
writes:
John H ,
You are exactly right about the pre-flight on this particular day only ,
because I don't remember looking at that particular bolt & nut with any
scrutiny , However my friend
Charles ( who is an ex helicopter mechanic / pilot ) , says he remembers
going over that
entire tail assembly , the very last time out , which was a testing phase of
this whole set - up.
As for the original installation , it was done by yours truely , and
being a machinist /
tool & die maker for some 40 years , I assure you I'm more than qualified ,
for some of these
tasks . The fact remains that , pre-flighted or not , on that day ,
SOMETHING caused
this to happen . That is all that was being conveyed in that e-mail . Homer
did a great job, but
he has no ability to change physics . If you can fry an egg on a piece of
metal heated by the sun , there may well be enough heat to partially melt /
soften nylon .Enough said !!!
But if memory serves me, nylon melts at a very high temperature...if it was
truly nylon...about 550 degrees F....George Randolph
Subject: | force on horizontal stab |
In a message dated 8/25/02 9:44:20 AM Eastern Daylight Time, TopGunPI(at)att.net
writes:
<< Hi Ted,
Now you sound like a very practical pilot , anyone that agreea with ME ,
must be right , HAAAAA!!!!
About your question on up vs down pressure on the tail feathers , it
sounds like a decent argument on
either side would get your vote . I hope when the hammer dropped you were on
the down side !!
I would think in an emergency situation , a pilot in comand could bring the
bird home with NO attached cables
UNDER the horizontal stabalizers , ( before anyone gets on my case , this is
only theory , DO NOT , try this
at home ) . now that the pot is stiring , I WILL LEAVE THE BUILDING .
I agree....because of the vectors for control on any well balanced
airplane....CG in front, CL (center of lift) behind on the wing....about a
third back from the LE causes a moment causing the nose down attitude which
requires the force on the horizontal stab to be ....Down! If you are tail
heavy, however, I wouldn't give a dime for this argument! A good test would
be the answer to the question...."do you have to trim up or down for level
flight? such will determine the force on the horizontal stab without trim.
George Randolph
Subject: | Re: force on horizontal stab |
A real easy test *proving* that down force is the normal force on the
horizontal stabilizer is to detach the bottom braces and do a quick 2 feet
leap in ground effect. If my contraption was finished I would do it in a
heart beat, and in fact would take it around the pattern. There is always
down force on the tail, unless one is doing some very quick pitch changes.
8/31/02 21:46GeoR38(at)aol.com
> writes:
> << Hi Ted,
> the down side !!
> George Randolph
Ralph,
Thanks for the reply on the glide ratio!. I imagine it might be less for
the FireFly since it has less wingspan and area. Wish I had some
data on this.
How were you able to relieve the stress on your muffler brackets?
Thanks, Terry K.
Subject: | Getting Bounced From Matronics Lists... |
Dear Listers,
I have two programs I run regularly to purge the various Matronics email
lists of bad email addresses. I referred to these as my Email Weasels and
there is a daily version that is run automatically every night at midnight
and there is a and a monthly version that I run by hand at roughly 30-day
intervals.
The Daily Weasel grinds through the 8 to 10mb of bounced email that is
generated each day looking for obvious things like "user unknown", "host
unknown", and other things that usually mean the user's email address
doesn't exist any longer. The Daily Weasel has been purging 5 to 10 email
addresses each night.
The Monthly Weasel gets more serious about the task and sends a single
message to each list member with specially generated headers and content
information. Any bounces or replies to these messages are considered
errors and the email address is eligible for purging. This program is
particularly useful for "weaseling out" email addresses that are actually
being forwarded to by another email address that is subscribed to a List
and otherwise would not be identifiable. The Monthly Weasel purges roughly
100 nonexistent email addresses each month when it is run.
To check to see if your address has been removed by either of the Email
Weasel programs, you can check the Weasel Status Web Page at the following URL:
http://www.matronics.com/unsubscribed
If you find your email address on the Weasel List, but are certain that
everything is working fine now, simply go the Matronics Subscription page
and resubscribe your address. No harm, no foul. The subscription URL is:
http://www.matronics.com/subscribe
That all having been said, I've noticed that the Daily Weasel may have been
getting a little too aggressive in purging addresses recently and a number
of people have written asking if and why they'd been dropped from the List.
A couple of months ago I rewrote the Daily Weasel program to include a
wider variety of errors and more aggressively purge. One of the new purge
criteria that I added seems to occur a fair amount of the time (Connection
Deferred) even though the address is really okay.
As of today, I've removed the Connection Deferred criteria from the Daily
Weasel Rule set and this should decrease the number of "false positives"
and unnecessary unsubscribed.
Again, if you get unsubscribed by either of the Email Weasel utilities,
simply go to the subscription page and resubscribe:
Best regards,
Matronics Email List Admin.
They that can give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety.
Benjamin Franklin
Historical Review of Pennsylvania, 1759
Subject: | Re: Getting Bounced From Matronics Lists... |
Hey Mat considering your skills with comnputers do you also do web pages?
Subject: | Re: rotax bullitins |
> Whats the Rotax address to go to for the sign up?
> Larry King
Laryy/Gang:
It was on the stuff you sent back to the Kolb List. :-)
http://www.rotax-owner.com
You can also download parts, repair, and operators manuals
for all the Rotax line here. If not I have another url for
that.
Subject: | Re: Just went flyin' |
Friend John,
You are a prince among men!
And the best to you,
Bob N.
> Bob N.
Gray Baron/Gents:
Darn! Forgot about Bob N. I usually fly right through
Winchester, VA, on my flights from Alabama to the NE.
Always land and take a break there. All my prior flight up
that way in ultralights, which go back to 1988 in the
Firestar, I have landed and taken a break at Winchester AP.
I didn't Know Bob then, but now I got me a buddy to spend
some time with when I am in his AO.
Been thinking, just got back from a last light 1.5 hr
flight, while I was flying about, "Why not make a real
flight out of this one up to London, KY." From London to
Winchester to Homer's, then back to Dallas/FW, El Paso,
Phoenix; or direct route from PA to AZ. From Phoenix to El
Paso to DFW to hauck's holler. If I did that route going to
Phoenix, I could claim all that mileage flown to get there
and pick up the "guy that flew the furtherest to get to
Copper State Fly-In". hehehe
Mark III is doing good, as well as the 912S. I am happy
when they are happy.
Take care,
PS: Anybody generally along the routes I described let me
know if you want to get some lunch or say howdy or
whatever. Just day dreaming about this trip now. I have to
take someone up to North Georgia and NC to see the Fall
leave the first week of October, so that kinda puts the end
to a combined flight all over creation and back. However,
this is the way these things get started. The 17,400
mile/41 day flight in 1994, started off as a dream, and it
came true.
DO NOT ARCHVIVE
From: | "Fackler, Ken" <kfackler(at)ameritech.net> |
Subject: | How much is too much? |
Due to cross-threading the spark plug, I recently had to replace one of the
heads on my Kolb's single-ignition 503. I'd never done it before but the
process went fairly smoothly. I ran the engine a bit today (on the ground)
including some short taxiing and it felt good, sounded good, and the temp
stayed down, so I'm figuring I'm okay so far.
However, when I had the head off, the piston did have a black build-up on
it, which I assume is carbon. I don't expect it to look factory new, so
here's my question to all you engine gurus. How much carbon is too much and
how can you tell?
Thanks!
-Ken Fackler
Mark II
Rochester MI
Subject: | Annual inspection procedures and documentation |
I was wondering if any of you have, and would be willing to share, written
procedures or checklists that you follow for you Kolb? I bought this one and
got virtually no docs with it, pretty much just the engine manual.
Unfortunately, Kolb didn't buy the rights to the Mark II and consequently
don't offer any direct support for it. I'd be interested in copies of any
Mark II or II or IIIx docs since I'm assuming they'd be most applicable.
However, I'd certainly be interested in hearing from or seeing any others as
good ideas can come from virtually anywhere.
Naturally, I'd prefer email, which saves time and money, but if you have
hard copy that you're willing to share, I'd be willing to reimburse you for
copy and postage costs.
-Ken Fackler
Mark II
Rochester MI
There's a fellow at my airport who's just recently put a Firefly up. It
seems to fly pretty well. The other night when he landed for the last time,
I was working on my Mark II and decided to take a break for a chat. When I
walked up, I placed my hand on his propellor hub spacer, the thing just
after of the gear box. It seemed quite warm, which led me to wonder about
the gear box itself. While it wasn't hot enough to burn you instantly, like
a muffler, it was uncomfortably hot. When I inquired about lube, he showed
me that he was using a synthetic.
Is it "normal" for the gear box to heat up and, if so, how much?
Does anyone here have any thoughts about this guy's use of a synthetic?
-Ken Fackler
Mark II
Rochester MI
Subject: | Hangar rash fixes |
Dear Kolbers:
I have a minor scuff on the leading edge, just left of the gap seal. It's
about an inch and half long and perhaps a quarter inch wide. It's not bad,
but it's unsightly. May I request any recommendations for a good tape
product to use on this?
-Ken Fackler
Mark II
Rochester MI
Subject: | Re: How much is too much? |
In a message dated 9/1/02 9:26:22 PM Eastern Daylight Time,
kfackler(at)ameritech.net writes:
> how can you tell?
> Thanks!
> -Ken Fackler
> Mark II
Ken,
If I remember correctly the manual says 0.5mm which is about .020". To check
you can clean a spot the width of a feeler gauge and lay the 0.020" feeler
gauge in the cleaned area then lay a straight edge on the feeler gauge at the
edge and compare to the thickness of the carbon. This can be done through
the exhaust port on a 582 with a little patients.
Steven G.
> Ralph,
> less for
> data on this.
> Thanks, Terry K.
Terry,
The Firefly glide ratio would be smaller.
For the muffler brackets, all you have to do is bolt down the two
brackets that bolt into the head spacers with the muffler attached to the
manifold and springs in place. Look to see exactly where the two 3/4"
muffler holes would go into the side of the bracket that attaches to the
first two (this is the bracket that is parallel to the side of the
muffler). Mark the holes in that side bracket. Drill out the 3/4" holes
for the muffler rubber donut, remembering that accuracy will relieve the
stress if the holes in the muffler and side bracket are aligned.
I hope this made some sense ......
Ralph
Subject: | 582 start up, oil purge |
The gear box is back together now. I am ready to try a start up again.
How do I insure that there is adequate oil to start? Is there a purge
procedure for the oil pump. I have 100/1 oil mix ( not synthetic) in the
gas tank to help out. I sure want to try it out tomorrow (Monday). All
advice appreciated.
Subject: | Re: Gear box lube |
Ken,
I use synthetic gear oil in my gearbox and noticed that it runs cooler
than the usual heavy duty gear oil. You might ask this guy what type of
synthetic oil he is using. I hope he's not using synthetic motor oil.
That might explain the heat problem.
Normally after a long flight, the gearbox will get hot on either mineral
or synthetic gear oil, but it should not be too hot to the touch.
I'm referring to the A and B gearboxes only.
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> It
> last time,
> When I
> just
> about
> instantly, like
> showed
> synthetic?
> -Ken Fackler
> Mark II
> Rochester MI
> messages.
In a message dated 8/29/02 11:52:21 AM Eastern Daylight Time,
smald(at)shianet.org writes:
be
A lot of the stuff about 2SI is OLD....but the engine is different now....and
....I suspect that a lot of the OLD stuff was caused by abuse.
I had one on my pterodactyl back in '83 to 90 and had good luck with it in
spite of my exhaust resonator on it .....Boo for me...part of the abuse bit I
was talking about. Another abuse thing was the early ULs which used Cuyuna's
didn't have EGT's. Mine certainly didn't! So how was I to know about loading
and the difference between lean and rich?? About hot and cold exhaust!!??
Just like everyone else, I overheated the engine and would actually cause a
freezeup. I did it twice and made a quick decision about Cuyunna, when in
reality, I should have been evaluating myself.
A fella by the name of Bob Morrison told me a lotta stuff that was true
about them, but if you don't have an egt, there is no way to monitor
them...or any other engine for that matter.
Knowing what I know now, I look back on the Cuyunna days fondly and am amazed
that it performed as well as it did in hot or cold, rain or snow. And that
was with a belt drive to boot!!
George Randolph
Firestar driver from Akron Oh
In a message dated 8/31/02 11:48:57 AM Eastern Daylight Time,
tkrolfe(at)epix.net writes:
my measured L/D is 9.5 to 1 (during engine idle)
George Randolph
KX firestar driver from Akron, Oh
From: | "Frank Reynen" <frank_reynen(at)ix.netcom.com> |
Subject: | Re: 582 start up, oil purge |
Woody,
If you have purged the air from the inlet to the pump with the screw at the
top of the pump then the next thing to do is to remove one sparkplug per cyl
and crank the engine with the airfilters removed at WOT(wide open trottle)
for 10 seconds and look through the carbs into the intake bore where the oil
lines are connected and observe oil coming out of both ports.
Continue cranking untill you see oil coming from both lines before starting
the engine. The extra oil in the gas is insurance for the next couple of
hours to allow all air to be purged from the injection system.
Frank Reynen MKIII 706 hrs
Subject: Kolb-List: 582 start up, oil purge
> advice appreciated.
Well i would want to know the ambiant temp before I would think/suspect a
problem. Ambiant temp has a lot to do with heat dissipation. If it was 85f
and the box was 145f. Then I would swag that this would be normal. In other
words was the gear box warmer than the rest of the engine?
9/1/02 19:25ul15rhb(at)juno.com
George
What is your IAS when flying your best L/D?
Jim Ballenger
FS KXP 447
Virginia Beach, VA
Subject: Re: Kolb-List: (no subject)
he
> George Randolph
Hey George,
What happened to your Cuyuna and pterodactyl and cuyuna? Do you know? I
have the engine from a wrecked one that came from Bob Morrison's place
several years ago.
Tom Olenik in NE Ohio
Olenik Aviation
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of GeoR38(at)aol.com
be
out!
now....and
I
amazed
George Randolph
From: | Duncan McBride <duncanmcbride(at)comcast.net> |
Subject: | Mark III airspeeds |
I'm about to finish up the little things and get the Mark III ready for inspection.
I need to mark the airspeed indicator with green and red arcs for the normal
operating range and redline. I was going to put the redline at 100mph, and
run the green from 100 down to 42 or so for the estimated flaps up stall speed.
Is there a need for a yellow arc somewhere in the red and green? Also is
there a maximum speed for deploying the flaps, or can I put the white arc all
the way up to 100mph?
Finally, how do you mark the little metal placard with the id number and other
stuff? I was going to call trophy shops tomorrow - is that the way to go? Thanks
in advance
By the way, there was some discussion a few weeks ago about the use of castle nuts
and cotters on bolts that are used as pivots - on the elevator and rudder
control horns and such. My EAA tech counselor told me the DARs around here would
call me on it, so I'm going to change them out. I've seen nylocs on control
horns stay tight for years and years, but if that's what they want, I'm castellating...
Subject: | Re: Mark III airspeeds |
arcs for the normal operating range and redline. Duncan
McBride
Hi Duncan/Gang:
Here is how I did my Mark III:
100 mph Red Line
80 to 100 mph Yellow Arc (Clean Air)
40 to 80 Green Arc
35 to 60 White (Flap deployment)
Didn't do a good job on my placard, but engraved with an el
cheapo electric vibrator engraver. Got me through
inspection.
Captain Ron,
Yes ambient temps do play a part in heat dissipation of the gearbox, but
since I ran mineral gear oil for many years, I know when the gearbox is
running cooler and other pilots have noticed a difference too in their
own machines. As I always say, "Do what works for you, it's your engine".
I can also say that I am running an "all-synthetic" engine and it is
doing quite well actually.
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> think/suspect a
> was 85f
> In other
> mineral
> messages.
writes:
> George
> Jim Ballenger
> FS KXP 447
> Virginia Beach, VA
On the Original Firestar the best L/D glide is at 38mph. I have an open
cockpit with the glide ratio at 9:1, and this was with the engine idling.
The L/D would improve slightly under dead-stick conditions.
Ralph Burlingame
Original Firestar
15 years flying it
The placard I used on my fuselage tube was very thin aluminum and self
adhesive. It is so thin I typed the numbers with a regular type writer and
it looks like the numbers were stamped on. I purchased the placard from
Aircraft Spruce & Specialty Co
Will Uribe
El Paso, TX
FireStar II N4GU
C-172 N2506U
other stuff? I was going to call trophy shops tomorrow - is that the way to
go? Thanks in advance
Subject: | Re: More Dihedral |
writes:
> My FSII isn't flying yet... but I put a little extra dihedral in my
> wings for stability too...
> Glad to hear I'm not alone, I've been wondering if its going to
> SLOW my cruise slightly.
> Oh well, I'd rather have it more stable.
> Gotta Fly...
> Mike
No Mike, the added dihedral will not slow down your cruise speed at all.
Technically, it should raise the stall speed slightly. By the way, more
dihedral in the wings makes the Firestar look a little better too.
I might add that my Firestar cruises a little faster than most (65mph
because I left the rear cage uncovered - no parachute effect from the
open cockpit), and the added weight of the auxiliary fuel tanks ahead of
the cg. For more info on why the added weight makes it fly faster, go to
the archives under "nose heavy Firestar".
Ralph Burlingame
Original Firestar
15 years flying it
Subject: | Re: Kolb Mk 111 flight incident. |
> Is there any reason why the solid rod type cables like those used on
> outboard motor controls are not used on our Kolbs? No chance of kinking a
> cable with them as the cable does not come out of the housing. Only a solid
> rod.
> Ron Payne
Ron/Gents:
I have no problem with the current set up. We have been
using it since the beginning. For me, in the Ultrastar,
1984.
I have seen the throttle cable kink on other Kolb aircraft.
Primary reason is incorrect installation in the first
place. Also could be weak carb piston spring(s), dry cable
(no lube), attempting to put too much bend in the cable
housing, etc. On dual carb setukps with
combiners/connectors, could be binding in here because of
lack of lube, corrosion, snags in the housing, etc.
I am guessing, but here's why Homer Kolb went with the
current set up:
1. Cost
2. Weight
3. The Bing/Mikuni carbs only need a one-way pull. Marine
control cable are designed for push/pull.
I am a boater and vaguely familiar of marine control
cables. Commonly called Morse Cables, they use a semi rigid
housing and a hard single wire (not necessarily a cable).
From experience with boats, these also break.
Good luck on your search for the perfect throttle
cable/setup.
Do it the way you like. That is the option available to
builders of home built aircraft.
Take care,
I am new to ultralight. I hold a commercial license and have 2000
hours (mostly military) but have not flown in some time. I started
looking into flying recently and have had trouble getting started. When
I say I want to do so I am told (reasonably) to get a medical first. But
I have had open heart surgery and a stroke. These are not as bad as you
would assume. You wouldn't know it if you saw me. But the first medical
examiner with whom I spoke said no. (There are exceptions for those
pre-conditions but I haven't followed up on that yet.)
Instead it occurs to me that ultras sound good and should avoid all
that bumf. So I'm starting a serious look at them. I'll be glad to
listen to anyone with any advice but in particular I'm planning a
research trip and here is my itinerary. Is there kit builder in the
general area I have missed?
Carlson, East Palestine, Ohio, CGS Broadview Heights, Ohio; New
Kolb Aircraft, London, KY; Titan Aircraft,1419 State Rt. 45
S.,Austinburg Oh. 44041; My trip is by car and obviously includes Tenn,
Ky, and Ohio. Pa would be good too.
Kevin Jones
Hi Lar just came back from your web site. I particularly looked at Building
Wings. As I am done with the tail I have just started on the wings. I
noticed that you placed your wings on a table. Is there any reason that a
wing cannot be built between two stands? This is how i have set up my spar.
I have done nothing yet except alodine the spar. So if there is a compelling
reason not to build it free standing as I have, please let me know.
Ron (FHU)
9/2/02 8:26Larry Bourne
"Building Vamoose. You'll have to hand
> make the hook-ups, but that's not too difficult. Gogittum Lar.
> Larry Bourne
> Palm Springs, Ca.
> Kolb Mk III - " Vamoose"
> http://www.gogittum.com
Ralph
Thanks for the info.
Jim
Subject: Kolb-List: glide ratio
> writes:
> > George
> > Jim Ballenger
> > FS KXP 447
> > Virginia Beach, VA
> Ralph Burlingame
> Original Firestar
> 15 years flying it
Subject: | Throttle cable kink |
I forgot to mention I also replaced the piston cable splitter because it got
some sand in it and couldn't throttle up to full RPMs.
Will Uribe
El Paso, TX
FireStar II N4GU
C-172 N2506U
I had the same thing happen to me, also replaced the cable. After firing up
the engine I couldn't throttle back.
Take a look
http://members.aol.com/cesaru/KolbFSII/259.jpg
----- Original Message ----- From: "John Hauck"
Subject: Re: Kolb-List: Kolb Mk 111 flight incident.
> current set up:
> 1. Cost
> 2. Weight
Subject: | Re: Kolb Mk 111 stall characteristics. |
I would like to see if there are any particular stall characteristics for
the larger Kolbs. In particular I would like to know if there is a break
during a stall to one side or the other. I find the discussion on dihederal
very interesting, which in turn made me wonder if there should be a need to
dial in some washout on the wings. This is the perfect time for me to do it.
As I am just about to start. A wash out is a slight difference between the
angle of incidence at the wing root and tip. Normally needed to tame sharp
stall breaks.
9/2/02 8:42John Hauck
> 1984.
You missed out on a big controversy over that a while back. Both methods
work well, and adherents of each method wouldn't do it any other way. The
archives must be full of pro's and con's. I like the big table to keep
everything solid and square, put tools on, and crawl around on, etc, for the
whole building process - not just the wings. Others prefer the sawhorse
method for the easier movement around it, under it, thru it, etc. I &
archives don't work together very well, so I can't tell you where to look,
but I'm sure some of those on the List can point you at the right threads,
so you can make up your own mind. I have a couple of full size pics
of the push/pull throttle hook-up I made, and sent them directly to Ron,
since, for some reason, I can't Photoshare. Hafta find out about that, but
meantime, if people are interested, Ron could Photoshare them for me.
(???????) One of the pics also shows the left side throttle lever I built.
Lar.
Larry Bourne
Palm Springs, Ca.
Building
Ron/Gang:
I haven't found the "sharp" stall break on any Kolb. Maybe
I'm looking in the wrong place.
I think Homer did an excellent job designing the airfoil and
the Kolb wing. No requirement for improvements in this
area. If someone doesn't like what this wing does, they
need to build another make airplane.
This is a super STOL wing. That is what Kolbs do best. Not
a high speed aircraft. Can't have it all, STOL and high
speed. Me anyhow.
In a message dated 9/2/02 6:22:29 AM Eastern Daylight Time,
ulpilot(at)cavtel.net writes:
<< George
Jim Ballenger
FS KXP 447
Virginia Beach, VA >>
my IAS is 40 now that I weigh 220, but it was 37 when I was 25 # lighter....I
tried faster and slower in all cases and 37 - 40 seemed to get me the
farthest with the least drop....but my engine was always idling....I have a 3
blade IVO pitched to give max rpm of 6600 RPM on climb....seems to give the
best results for combination of cruise and climb....I have pitched it so much
that I almost didn't clear the trees after 2000 ft. Of course if I could get
enough altitude my speed would have been way up there.....I think. Best and
USUAL L/D is always around 9-9.5 for me.
George Randolph
KX Firestar driver from Akron Ohio
the ol glider pilot
Subject: | Re: : Kolb-List:Bob Morrison |
In a message dated 9/2/02 9:19:06 AM Eastern Daylight Time,
olenik-aviation(at)buyitsellitfixit.com writes:
<< Hey George,
several years ago.
Olenik Aviation
http://www.buyitsellitfixit.com/2si-engines.htm >>
I sold the whole shebang to a fella from Maryland for $2600 back in'90. My
whole purpose was to upgrade to the UL of my choice considering that Bob went
through his divorce and I might have lost my hangar space so I went for the
best fold feature in the industry with my Kolb purchase in '91.
I think that wreck you got was owned by 2 guys that wanted to fly but didn't
want to learn at the direction of someone else....I never met them but every
time they flew it (I think they took turns) they would bend or break
something until one of them finally broke more than the pterodactyl, namely
his leg....they gave up after that. I never met them, but I would always see
their "effort" up agin the wall at the side of the hangar. There was a
Chinook and a Rotex? around there also.
George Randolph
I'm the guy who started in UL because of Bob Morrison and his mall show in
'81.
dunno where he is now....great guy...LOVES flying...may be in Florida...dunno
bout Betty n the kids either....great gal....sad story.
KX Firestar driver from Akron Oh.....bob was first to fly my Kolb....what a
great story that is!! I learned a LOT!!....and he suffered a bit...but only
mentally
In a message dated 9/2/02 12:14:06 PM Eastern Daylight Time,
kevin-jones(at)snet.net writes:
<< Instead it occurs to me that ultras sound good and should avoid all
Kevin Jones >>
They are all around me and are all great companies. I almost picked a CGS
because of proximity but I wanted wing fold. Also the position of the engine
is lower and almost in the cockpit with my ....head! That's an obvious
concern but the noise is another and the size of the CGS prop is
limited...hence no Kolb climb.
The Titan is a beautiful plane made by the people who started out building
CGS. My only concern there is price and short chord between wing and tail.
Kolb is much longer and therefore more forgiving in pitch. I have had
floppydos in my pterodactly that almost put me upsidedown due to vortex of
ANOTHER UL OR TREELINE!! I have always been impressed with Carlson who just
died as a result of testing his new Storch...but I have much respect for his
ideas...which were many. And his construction techniques were
formidable...very professional looking to me. But no wing fold, as I recall.
They all fly, but the "little things" mean a lot (geez, maybe I'll write a
song) and after 10 years I still don't covet another as I did with my
pterodactyl.
George Randolph
ol glider pilot from Akron, Ohio
KX Firestar
In a message dated 9/2/02 12:33:50 PM Eastern Daylight Time,
CaptainRon(at)theriver.com writes:
stall breaks.
> 1984.
If I had my druthers, I would put a little washout in my wings as the
pterodactyl had, but it is a major design change and may not be a good idea.
The stall of the Kolb is almost as forgiving as the pterodactyl which had
loads of washout but it was really just a flying wing and maybe required it
for stability....dunno....just a thought.
George Randolph
Subject: | Kolb Mk 111 stall characteristics. |
for
dihederal
to
it.
the
sharp
stall breaks.
CaptainRon,
Washout is needed on tapered wings and high aspect ratio wings...not low
aspect ratio wings like our Kolbs. The washout in a wing actually
degrades performance because a airfoil only has 1 angle of attack where
it is "MOST" efficient. When the wing is twisted you can NEVER get the
whole wing at the most efficient angle. The low aspect ratio wing will
always stall inboard end first due to the wingtip vortices actually
rolling back over the rear-outboard section of the wing and keeping it
"working". Topher can surely explain the particulars. Anyway, it is
something not to be trifled with unless you have the know-how and a
reason. And unless the reason is to degrade the performance of the
Kolb, I'd suggest leaving it alone...
Just my $.02 worth...
Jeremy Casey
jrcasey(at)ldl.net
George
Thanks for the info. It fits nicely with what Ralph emailed. I will keep
it in mind when the engine goes dead. It happened last year to me coming
back from a fly in. I was at 2000' AGL and 10 miles from my base airport.
Fortunately for me, Al Carpenter trained me well in the late 80's in the art
of ultralight flying as I picked my spot and flew the plane just like he
taught me. I used 45 mph IAS then and noticed with a still prop my glide
was alot longer. The only damage was minor scrape to the nose cone belly
and a bent pitot tube.
Jim Ballenger
FS KXP 447
Virginia Beach, VA
Subject: Kolb-List: L/D
> << George
> Jim Ballenger
> FS KXP 447
lighter....I
a 3
the
much
get
and
> George Randolph
> the ol glider pilot
Subject: | Re: Annual inspection procedures and documentation |
Hi Ken,
The attachment is a Word document I got from the EAA website and modified
for my use on the Kolbra. If you can open it, I can send it in webpage
format.
John Williamson
Arlington, TX
N49KK, Kolb Kolbra, Jabiru 2200, 54 hours.
http://home.attbi.com/~kolbrapilot/
From: | "Bob, Kathleen, & Kory Brocious" <bbrocious(at)hotmail.com> |
Kolbers,
I'm nearing completion of my Mark III. I've got to find a way to secure the battery
behind the passenger seat. Can I just use an old motorcycle battery box?
Bob, Kathleen, and Kory BrociousTenacity Farm
Campbellsburg, Kentucky
Kevin,
You may want to consider the Kolb FireFly which is a legal ultralight,
or look into a future Sport Pilot License. (http://www.sportpilot.org/).
I believe that no medical will be necessary, except what is needed for
a drivers license.
John Jung
Kevin Jones wrote:
> I am new to ultralights.
Subject: | Database & Stall Characteristics. |
Don't for get about the database located at http://www.springeraviation.net/
for a list of builders and flyers willing to share information.
As for stalling, I mentioned a few months ago how my Firestar II rolls to
level during a banking stall, both directions, even with some rudder in the
direction of the turn! The wings are perfectly flat. Thanks Homer...
Kip
Firestar II
Atlanta
Subject: RE: Kolb-List: Kolb Mk 111 stall characteristics.
> for
> dihederal
> to
> it.
> the
> sharp
> stall breaks.
> CaptainRon,
> Jeremy Casey
> jrcasey(at)ldl.net
Captain Ron,
The Kolbs have a rectangular wing that stalls in the center before the
tip stalls. This is a good thing because there is a natural stall warning
sound built into the wing. Just before the stall begins, the air ahead of
the engine becomes detached and the turbulence makes a 'burble' sound in
the prop. This is the stall warning. If you ignore this sound, the nose
will fall over and the plane will begin flying again if the stick is held
neutral or more forward. It may drop about 50 feet. If the wing has a
tendency to roll (not hands off), it may fall off in that direction
during the stall.
There is no need to build washout into the wings. Build them as flat as
you can and things will be fine.
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> characteristics for
> break
> dihederal
> need to
> to do it.
> between the
> sharp
> stall breaks.
> > 1984.
> messages.
All three of my Kolbs stalled very gently then went right back to flying. One other
characteristic that should be pointed out is mushing with loss of altitude
while flying near the critical angle of attack. I was amazed to see my ROC showing
a 500'/min loss of altitude during stall testing of my FireFly. She had
no tendency to do a tail slid but she sure was in a deep mush.
This is why we land at a speed well above stall if you have power and be
sure to keep enough glide speed to prevent mushing if you have to land without
power.
Duane the plane, Tallahassee, FL FireFly SN 007, Mk3/912 in the workshop
(while I finish moving into a new home, jeez what a job!).
Well like you I went to the archive a few days ago to look for something,
and got lost in there reading things that had nothing to do with what I
wanted to see. Got so confused that i forgot what I was there to begin with,
still can't remember a damm thing. :-)
Boy I gotta give it to you building your craft within those narrow confines.
Hats off. :-)
9/2/02 9:38Larry Bourne
Thanks for the answere, placing just a slight bit of a washout should not
degrade much if anything in terms of performance, but would improve stall
substuntially, at least thats the theory. There is a slight loss of average
lift by the reduced angle of incidence but can easily compansated by
increasing the angle of attack which is at the pilot's discretion, if one
needs a bit more climb. It should however guarantee an inboard stall first,
and thus a very benign stall break or just a mush. Well I have not decided
what to do yet. As I have a few differing opinions. Life aint simple. :-)
9/2/02 13:00GeoR38(at)aol.com
> stall breaks.
>> 1984.
> George Randolph
Thank you exactly the answere I needed. I figured if I needed to I could
play a bit with that. :-)
But if its fine then its better to just leave it alone,, on this first one
anyway. I have already decided and bought the material to build me another
set of Horizontal stabilizers while I waite for kit 2 to arrive. These ones
will be all metal and mostly bonded. Just figured it would be more
cactus/brush resistant out here. My best estimate indicates that they will
be only a 1/4 pound heavier per wing.
9/2/02 18:43ul15rhb(at)juno.com
> Captain Ron,
> during the stall.
> Ralph Burlingame
> Original Firestar
> 15 years flying it
> writes:
>> characteristics for
>> break
>> dihederal
>> need to
>> to do it.
>> between the
>> sharp
>> stall breaks.
>>> 1984.
>> messages.
>Woody,
Thanks Frank. I was able to taxi a bit last night. The engine started
right up and ran great. Unfortunately the air speed and egt did not work. I
also had a flat tire 1000 ft down the runway. Kolbs sure get heavy after
awhile. A couple small repairs and I may even get this bird in the air.
Gents,
I'm finishing up my Mark III after wresting with a needed correction on the right
wing. There are two things I would appreciate some suggestions on. I'm working
on anchoring the battery down. Can I just use a motorcycle battery box or
is there something else that would do?
The other issue is, the previous builder had attached the rear of the sling seat
to the cross member with well-tied rope. This made it pretty much impossible
to do an adequate preflight to check the turnbuckles and cable ends for the elevator
and rudder. Is there something you use that allows you to open and close
that section and still provide good support for the back of the sling?
98% Mark III, "Miss B" (N57MB)
Why not? As long as "secure" is the operative word...
Richard Pike
MKIII N420P (420ldPoops)
Dp Not Archive
> Kolbers,
> battery behind the passenger seat. Can I just use an old motorcycle battery
> box?
> Bob
> Tenacity Farm
Subject: | ROTAX Technical Information |
> CPS has a manual you
> can buy that shows you the pattern! Call 800-air-wolf!
> Tracy B.
Tracy/Gang:
How about technical info directly from ROTAX for free!
Go to this url for ROTAX Technical Information and Manuals
that can be downloaded from the internet for free:
http://www.kodiakbs.com/tiintro.htm
On the left hand side of the page is a list of about
everything you need for two and four stroke ROTAX engines,
from jetting carbs, to installing engines, parts manuals,
operators manuals, line and heavy maintenance.
I, for one, would rather get the info free from the original
source than have to pay good money from one of our high
priced UL parts suppliers.
For your info,
A friend of mine, after going through the same experience as you, said "If
you have a choice between moving and suicide, give it careful thought."
kj
Subject: Kolb-List: Kolb stalls
Subject: | Re: Morse Style Cables For Throttle Control |
Very interesting Post. Doug, do you consider the throttle cable arraignment
that is supplied with the Kolb kits (FireStar as this is the only one I am
familiar with) to be more reliable than the Morse type? I am sure that a
push pull tube arraignment would be better but the bicycle brake cable seems
to leave a lot to be desired. If you were to bring the throttle back to idle
rapidly as in the case of an unsuspected up draft or anything that takes you
by surprise, you can kink the cable before the throttle springs have time to
take over.
Ron Payne
-------Original Message-------
Date: Tuesday, September 03, 2002 09:36:11 AM
Subject: Kolb-List: Morse Style Cables For Throttle Control
I would be a bit cautious about using Morse style cables for "throtle" or
"control surface" control unless you were going to "religiously" replace
them on a very regular basis.
> I am sure that a
> take over.
> Ron Payne
Ron/Gents:
If you are "sure that a push pull tube arrangement would be
better, but the bicycle brake cable seems to leave a lot to
be desired", then why don't you put the Morse type cable in
your airplane.
If you are quicker than the carb spring retarding the
throttle, stay out of "unsuspected up drafts", or "anything
that takes you by surprise". Just kidding with you Ron.
Again I will state my observations, experiences, and
feelings about the Kolb throttle system which is standard
throughout all models and has been in use since before I
started building Kolbs in 1984. They work, are reliable,
and safe.
In over 1,700+ on my Mark III, I have changed out the
throttle cables once. The only reason I changed them out
then was because I was going to fly to Barrow, Alaska. With
no hard information on time to replace, I went ahead and
replaced them. Probably 500 hours would be a good time to
change out throttle cables. I have never had a throttle
cable failure, but I have broken a throttle lever. Does
that count?
I think you are making a big deal out of a system that is
perfectly reliable and safe.
My 2 cents for what it is worth. Not much. :-)
Now Kolb Brothers, don't get excited cause I have expressed
my opinion. However, if you doubt that a system in your
airplane that you are building is not safe and reliable,
then by all means come up with something better that you
will feel comfortable with. With more than 4,000 hours in
Kolb aircraft, I feel comfortable with what Homer Kolb
provided for me to build and fly.
Take care,
There have been two posts in the last two days about the Kolb system failing
I once asked a so called expert about his opinion of Ballistic Parachutes.
He said that if he thought the plane was going to crash that he would not
fly it so he didn't need one. I think he wore a seat belt though. Didn't ask
him why. Seems to be the same kind of logic here.
Ron Payne
Date: Tuesday, September 03, 2002 03:01:49 PM
Subject: Re: Kolb-List: Morse Style Cables For Throttle Control
> I am sure that a
seems
idle
you
to
> take over.
> Ron Payne
Ron/Gents:
your airplane.
> Ron Payne
Hi Ron/Gents:
If I remember correctly, there have been two posts to the
Kolb List reference throttle cable crimping.
One was by Will Uribe and his incident happened some time
ago. I think he said it was caused by a cable splitter that
malfunctioned. Had a burr or something inside that caused
it to hang up.
I forget what the other cause was, but I believe it was
operator induced, lack of maintenance, or improper routing.
Do not believe the design of the throttle cable system was
the cause of the failure.
I think the reason Big Lar uses a morse type cable is
because of the VW conversion system he is using. I don't
know what Richard Neilsen is using on his VW conversion.
Your example of the gentleman that flew without a parachute
because he did not think he was going to need one surely
wasn't me. My "logic" on that subject is, "I hope I don't
need one again. But if I do, I will have one."
You statement that my logic is the same kind that the "lack
of parachute" gentleman was using is way off base. In fact,
I take that as a personal attack, but we can get that part
of it straightened out if we see each other at London, KY,
in a couple weeks. :-) hehehe PLEASE NOTE THAT IS A SMILEY
FACE AND I AM LAUGHING..........................
Ron may need to take a close look at the throttle actuating
system as it was designed, then ask some questions on why it
failed in these two instances. I don't think we need to
replace a system mearly because something didn't work. If
we did, we would all be replacing two stroke engines and a
pile of 4 stroke engines. Let's look at what we might be
doing wrong.
What is/are Ron's specific questions on the throttle system
and maybe some of you all experts out there can answer them
for the benefit of Ron and the rest of the gang.
I think it is important not to take the Kolb List too
seriously. Let's lighten up a bit. After all, we are
communicating in a very basic mode that lacks much, if any,
manner to let the reader know where we are coming from and
what our intent is. One of the easiest things on an email
List to do is take the wrong intent that the writer is
trying to get across. Does that makes sense? I don't
know. Been weed eating and cutting too much grass today in
this Alabama heat.
If you get right down to a throttle problem with Kolb
aircraft, the major problem in the past was using 1/16 inch
cotter pin to attach the throttle cable clamp to the
throttle. I know of quite a few instances where the cotter
has worn through leaving the hapless pilot throttleless.
I drill mine out to take a 3/32 AN clevis pin. Never had
one of these fail. I usually find them at Sun and Fun.
Take care,
>that count?
>john h
When I first built my MKIII, I had one throttle quadrant on the left
fuselage wall, next to my left hand, and another on the right wall, right
where the passenger would have it beside their right hand. It was a bit
much, and I took it out. But as part of that arrangement, I had a cable
adjuster in the cable sheath to the rear of the airplane and it laid on the
lower rear floor. Apparently, while washing out some dirt that had gotten
in, I got water in it, and it got real tight after about two years. Took it
apart, and the cable had gotten rusty in the sheath. You got to keep that
stuff dry!
Redid the system to make it more waterproof, and I check it every year.
There was a MKII around here that was sold for scrap a while back, one of
the locals had a throttle cable break while on base leg and then he tried
to stretch the glide and stalled. He took out the localizer antennas as he
cartwheeled through them. (That's how I know about Kolb ribs breaking at
the fabric rivit holes) The feds were not pleased. But he walked away.
Don't know what caused the throttle cable to break.
Richard Pike
Anyone else out there have an opinion of Hauck? Would like to hear from you.
Most of the time I agree with him. That's as good as anybody else gets.
On those occasions where I don't necessarily agree with him, I still figure
that anybody with 4,000 hours in a Kolb is entitled to express their
opinion. I have about a third that many hours, and I'm not shy about
expressing my opinion.
If the time ever comes along that he says something that is flat out wrong,
I'll jump him. So far, so good...
Richard Pike
Ron Payne
> Richard Pike
Richard/Gents:
If you jump me, you won't be getting a cherry. If I am
wrong, it won't be the first time. :-)
If you don't like what I say. Hit the delete button.
I am not on the Kolb List to win a popularity contest. I
get paid a tremendous amount of
money...................NAW!!!!!! I don't get any money for
the time I spend on here sharing my mistakes, experiences,
short cuts, Kolb life time secrets. I also learn a great
deal about my airplanes from you all. I'm here cause I want
to, maybe, help someone else from making the same mistakes
that I made while growing up with these little Kolb
airplanes. But if you want to pay the price, go ahead.
Richard, thanks for stating your opinion like a man. I
respect you Brother.
Take care,
PS: Can learn a lot about people on this list too. I like
that. I got my degree in Sociology................
you.
I think he's OK. No facades with John. What you see is what you get.
Straight shooter. .........Snuffy
From: | "vincenicely" <vincenicely(at)chartertn.net> |
Subject: | Re: Kolb flying characteristics and Wing Dihedral |
Hi Gang,
In a recent message:
> > dihedral.
I have a Firestar II on which I have set substantially more dihedral (10
inches high at each wing tip) than is usual. The flight is very stable and
the rudder provides much different control than is observed on the standard
rigging. There is a discussion of this and answers to questions in the
archive from a couple of years ago under my name.
Vince Nicely
Firestar II 315 hours
> arraignment that is supplied with the Kolb kits (FireStar as this is
the only
> one I am familiar with) to be more reliable than the Morse typ
> Ron Payne
Ron and others,
I am using the same simple throttle cable supplied with my kit that is
over 15 years old. It has seen hundreds of takeoffs and landings and is
working as well as the day I installed it. No frays, kinks, or other
problems. I like it that way.
The movement back and forth should be smooth without any rubbing or
stiffness. I have mine as direct as possible to the carb. The only tight
bend is at the top where it makes a 'U' into the carb. If the cable wants
to kink at the lever, there are too many bends in the routing and
friction is overcoming the spring action in the carb.
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> failing
> Parachutes.
> would not
> Didn't ask
> Ron Payne
Ron and others,
I have taken my elevator and rudder cables out to inspect them numerous
times over the years. Yes I have used a magnifying glass with rag and
twisted the cable, against the winding, where it runs over the pulleys.
No frays, kinks, or other problems. I like it this way. One year I got
them twisted and they were crossing over each other and touching inside
the boom tube. It was about a 4 months before I saw this in a thorough
preflight. I took them out, re-inspected them and they were fine.
Ralph Burlingame
Original Firestar
15 years flying it
Hi Kolbers,
I have been dreaming of going cross country with my Firestar and
have been wondering a few things which would be necessary, one of the
most important is (of course) fuel. I understand that I can put AVgas
in my plane, so I can just go to a airport along my way to fuel up, but
my concern is how is the best way to measure oil to mix with the gas? I
would like to hear your methods of how some of you do premix gas while
on cross country. Thanks, I would appreciate any help.
Joel Reed
84 Kolb Firestar w/377
Manheim, Pa
Hi Ron,
It happened to me once and I wouldn't change the throttle system because of
that.
You have to understand we get a lot of sand storms here in the Southwest and
even thought we try to plug up any cracks in the hanger where the sand gets
through will still get our airplanes covered with sand. I also taxi and
sometimes land on the sand or dirt.
The reason my cable failed was because sand got into the splitter and was not
letting the carburetor spring do it's job so when I pulled back on the
throttle the cable didn't side back in when I pulled the throttle. I didn't
realize it was the splitter until one time I had to abort a take off because
I couldn't get full RPM's. The sand finally gummed upped the works inside
the splitter and was binding big time.
Sand gets into everything so what ever type to throttle system you install,
I'm sure sand will get into it if you live in this part of the country.
It also happened to my C-172 but I'm not going to call the Cessna system a
bad system, but I'm sure others are entitled to their opinion.
Will Uribe
El Paso, TX
FireStar II N4GU
C-172 N2506U
http://home.elp.rr.com/airplane/
----- Original Message ----- From: "Ron or Mary" <<A HREF="mailto:ronormar(at)apex.net">ronormar(at)apex.net>
failing
ask
> Ron Payne
I have broken a throttle cable before, or almost broken one
( down to the last wire on the cable) and it was only 3 years old.
You guys might want to buy a can of this stuff from CPS.
You can lubricate your cables without taking them off the carbs.
Part # 7435
CABLE LUBER SYSTEM - $17.95 One can will last a life time.
"Prevent cable freezing and extend cable life by lubricating cable with the
"Cable Luber" system. Special precision machined lube block allows ease
of lubrication between cable and housing without removing the cable.
Just attach the Cable Luber to either end of the cable and insert nozzle
from aerosol can. Specially designed seals in block force lube down
inside cable housing. A must for the serious mechanic. Cable Life Aerosol
lubricates and rustproofs moving parts even at temperatures far below -50
degrees
http://www.mindspring.com/~possums/
In a message dated 9/3/02 8:56:06 PM Eastern Daylight Time, ul15rhb(at)juno.com
writes:
> the only
> > Ron Payne
During a routine maintenance on his Firestar II, my friend Dave found that
all the strands of his throttle cable except one had rusted in two. The
location was about a foot from the throttle lever, which is the lowest point
of the cable.
It appeared that while washing the Firestar he had inadvertently let water
get into the cable [several times]. He changed to stainless steel.
Shack
FS II
SC
I took an old oil bottle (quart size) and cut the bottom out. Stick the
neck down into the gas tank opening. Guesstimate ahead of time how much gas
I will pump, figure out the amount of oil I will need, and then while
holding the hose nozzle with one hand and putting the gas into my home made
funnel/oil bottle, I pour the oil into the gas stream with the other hand.
I make sure I get all the oil in before I get done pumping gas. Not a
perfect system, but so far, so good.
Richard Pike
>Hi Kolbers,
> Joel Reed
> Manheim, Pa
> Joel Reed
Hi Joel/Gents:
I was lucky enough to do a lot of long cross countries in my
Firestar.
My method was to estimate how much fuel it was going to take
to fill the tank. Compute the correct amount of oil. Dump
it into the fuel tank. Push (rock) the airplane back and
forth for a minute or two. Top it off with 100LL and be on
your merry way. If I was between 40 and 60 to one, I was
happy, and so was the 447.
On one occassion at Norwich, NY, airport, I forgot to shake
up the oil before and after I topped off. At about 100 feet
in the air I started losing power, noticed a lot of smoke,
pulled on the enricher and had enough power to land with
power. What happened was, the fuel pump sucked the
straight, or nearly straight, oil off the bottom of the tank
and filled the carb float bowl. In turn this was leaning
out the mixture. By pulling on the enricher I was able to
get enough fuel through all that oil to keep the engine
producing power.
Scared me enough not to make that mistake again.
I did have a sight gauge. I had flown enough to know within
a tea cup how much fuel it would take to top off. If you
get a chance to spend several weeks or months with your
airplane, flying cross country every day, you will be able
to guesstimate very closely how much fuel it is going to
take. Also the hour meter helps narrow down the amount of
fuel burned.
I don't have to add oil any more, except every 100 hours at
oil changes. Usually take 2.5 qts to burn up 500 gal of
fuel. Not bad. And never have had to add oil between
changes. Except when I forget to tighten the oil lines on
the oil tank. :-)
Take care,
> the oil tank. :-)
> john h
Gang:
Did a little figuring after I punched the send button. 2.5
qts of oil and 500 gal of fuel equals 6.25 gal fuel per 1 oz
oil. Not a bad return. For you guys that want to do 100 to
1 fuel to oil ratio in your two strokes, I do 800 to 1 in my
old 4 stroke. This is one of the ways we start changing
that curve and making up the difference in price between a
582 and a 912. When you start throwing in the price for
spark plugs, the 912 uses 8 ea in 200 hours (I have pushed
them to 225 hrs with not problem), it evens out the
difference even more. A while back I figured out that if
one flies 1,000 hours in the 912 he will make up the
difference in purchase price of the 582, based on oil, fuel,
and spark plugs. The 912 burns 4 gph at 5000 rpm. My 912S
burns 5 gph at 5000 rpm. My 582 burned 5.5 gph at 5800 rpm
(normal cruise).
If you don't follow the above. OK. Please delete and
continue on with your lives.
Take care,
Nice figurin' there John.
hhham did we forget per chance,, da factoring in the OH? :-)
9/3/02 20:55John Hauck
> (normal cruise).
Forget where I saw it maybe A/S. Some cables nowdays are ss in a Teflon
sleeve. I think my prop cable is one of them.
9/3/02 21:04Kirk Smith
> Naw, but thanks! Just trying to come with an easy way to avoid having to
> check throttle cables for wear. Heh, another idea would be to use the
> throttle cable for a vhf antenna and save some weight. Could call it
> Snuffy's subliminal modulation detector. hehehe......snuf
Ya' know, I'm no Mechanical Engineer, but, these aircraft engines must be
using a ton of gas for cooling.
My 2000 Ford Expedition, 5.4L V-8, 4x4, pulling a 5x8 Uhaul @ 70mph, gets
15mpg. That's 4.67 gph, pushing/pulling a couple of tons around.
This hit me when I was running up I-95 earlier this year, that I was feeling
crummy about the same gph that a 912 flyer overhead would be calling people
on the radio to brag about.
Just scratching my head.
Subject: Re: Kolb-List: X-country,
> > (normal cruise).
Subject: | Morse Style Cables For Throttle Control |
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ron or Mary
Yea, he's a doer, not a talker. But if you can get him talking...and
then shut up and listen, you'll learn something. I've had the pleasure
of meeting him in person several times and he even flew over to my
backyard strip once to look over my "DE"-constructing of the world's
longest build time of a Kolb. He pointed out a couple of things that he
didn't like and didn't mince words about it. You want to know the funny
thing...even when he told me he didn't like something to my face I
didn't take it personal. It was advice coming from someone who just
didn't want someone repeating his mistakes. Remember that email doesn't
convey facial expressions and inflections in your voice that would
otherwise tell the whole story of what you were saying and why you were
saying it...
That's my opinion...
Jeremy Casey
you.
> Hi Kolbers,
> the most important is (of course) fuel. I understand that I can put
> AVgas in my plane, so I can just go to a airport along my way to fuel
up,
> but my concern is how is the best way to measure oil to mix with the
> gas? I would like to hear your methods of how some of you do premix
gas
> while on cross country. Thanks, I would appreciate any help.
> Joel Reed
> Manheim, Pa
Joel and others,
There are two tanks that fit nicely behind the seat that will carry 3
gallons apiece. This will give you a total of 11 gallons onboard,
assuming that you have a 5 gallon main tank. I built a bench-style shelf
many years ago that rests on the two cross members and over the control
cables. It's easy to make and is held in place with only two hose clamps.
The 3-gallon auxiliary tanks will be your premix tanks and allow for more
accurate measurement of the fuel to oil ratio.
Measure out a 50:1 oil ratio, by carrying along a baby bottle that shows
ounces on the side. Draw a line to the 7.7 ounce mark with a Sharpie
permanent ink pen. This will be the ratio for the 3-gallon tank. The 11
gallons will give you a range of about 160 miles total, but the range for
one leg of your journey is determined by the 5 gallon main tank which is
about 85 miles in calm air.
This means that you would have to plan each leg of your flight to within
70 miles to allow for headwinds and reserve. Fill your 5-gallon tank with
a 4-foot piece of neoprene hose that is coiled up in a plastic trash bag
stored under the seat. One end of the hose will fit nicely on the end of
each 3-gallon spout.
As you can see, traveling across country on a 5-gallon main tank is not
easy. This is why John Hauck used more than a 5-gallon main tank on his
trips around the US in his Firestar with a 447 engine.
I usually plan my trips with 50-mile legs, which will allow me to get out
and stretch and have more than enough fuel to account for winds.
To get a quick estimate on how much oil will be needed for the trip,
divide the total miles by 20 to get the amount to fuel used (the 377 and
447 engines get approximately 20 miles per gallon). Divide this number by
50 to get the amount of oil needed in gallons. For long trips I carry a
full gallon of synthetic oil stored under the seat, enough for 1000 miles
(not easy to find Klotz around).
Aviation fuel will work ok in the engine and I have used it when I cannot
get auto fuel. There have been times, where folks at airports have either
loaned me a car or given me rides into town to get fuel or I have hiked.
One guy told me I could use his truck and said that it was the grey one
'over there' with the keys in the ignition. I ended up taking someone
else's truck. We both had a laugh when I got back :)
Good luck and have a fun safe trip when you decide to do some cross
country flying. It's adventure at its best. Just ask John Hauck, Richard
Pike, and many others who have taken long trips in their Kolbs.
Ralph Burlingame
Original Firestar
15 years flying it
I think I would tend to agree with the folks that believe Homer did it right
the first time around. Keeping the cables clean and dry and more
importantly, routing the cables properly, will probably take care of 99.9%
of the problems associated with throttle cables. I don't think that routing
was the cause of any of our "Morse style" cable failures because we tried
several different methods of routing as well as the throttle quadrants on
several of the boats are by different manufacturers. They always break
within an inch of two of the same place, inside the jacket out of view, on
the boats and the Quicksilvers. I broke another one yesterday on one of the
Mastercrafts.
For the other .1%, practice your engine off, dead stick landings regularly
and replace the cables every so often. Remember Murphy's law, "if it can,
it will".
If I ever come across a better cable arangement, I'll let you know. A
teflon or phenolic inner coating on a jacketed stainless steel liner with a
solid core stainless cable sounds like a great idea. Any one got one laying
around they want to get rid of? ;
Fly Safely,
Doug
take over.
Ron Payne
Subject: | September/October I'll Be Flying!!! |
Kolbers:
Good news!!! Looks like I am getting into the serious
planning stage of a flight to London, KY; Homer Kolb's
(maybe, I haven't been invited yet :-); back to hauck's
holler, AL; then D/FW, TX; El Paso (where I may or may not
find Will and Dave at home); and Phoenix, AZ, (Copper State
Regional Fly-In); and return to Alabama.
Shouldn't take more than 3 days out and 3 day back,
depending on the weather and how long I dilly dally along
the way.
Got to get some new sectionals (they do change quite a bit,
quite often), update my little black book of phone numbers
and locations, double check that my Mark III is ready for
the flight (I think she is now, but it is about time to
change plugs), and start getting my own gear together.
I can update my old Garmin 95XL from the internet for $35.00
(that was last year's price), to insure my Jepsen Data Base
is correct. That's kinda neat being able to do that. Used
to take forever to order on the phone, then wait for them to
send me a floppie. My really old Garmin 55 had to be
shipped back to the factory for them to update the data
base. Really long and a lot more expensive.
Guess I better start praying for good weather for the flight
period. I believe I can get Brother Pike to help me out a
little in that department. I need all the help I can get.
On a real serious long distance flight, I usually do not
stop and socialize much. Most of my time is spent flying,
sleeping, and eating. I don't sit still, well, in one spot
for very long. Usually, my needs are pretty much met at the
airports where I land, or near them, and with what I take
with me on the airplane.
However, I am trying to learn how to slow down, after 63
years (the Gray Baron still refers to me as young'n).
So........if I find some of you along the way, maybe we can
sit down have a cup of coffee, a meal, and swap opinions of
each other.......ahhhhhhhhhhhhh! I didn't mean to say
that. Just kidding. All this is getting to be a "Payne in
the ass" anyhow. Take it easy Ron. Again!!!! Just
kidding. You know, trying to lighten up a bit. Can't stand
to get too serious, life is too damn short for that.
Everybody have a good day. Looking forward to seeing and
visiting with "everyone" at London, and along the way.
hauck's holler, alabama
Doug,
If a little care is taken to ensure there is proper cable routing and lubrication,
Homer's solution works. It is very easy to take the nut off the throttle
bolt pivot, and to pull the throttle by hand to see if the throttle return spring
can retard the throttle properly. A bit of "Lubriplate" grease works wonders
on reducing the friction between the cable and the housing. To save weight,
I have been running steel cables for the throttle and choker in small aluminum
tube housing for the last two years and I have had no problems.
For those who would like to switch, bicycle shops sell or can order Teflon covered,
and stainless steel brake and shifter cables. One can find various cable
housings too. Murphy can be held at bay by checking the throttle return rate
once in a while and by re lubricating the cable.
Jack B. Hart FF004
Jackson, MO
>Mastercrafts.
>it will".
>Fly Safely,
>Doug
Jack & Louise Hart
jbhart(at)ldd.net
John,
If you head to Homer Kolb's, assuming he still lives at Phoenixville PA, I
would be right on your way. You would be welcome to stop for a meal, bed,
shower, or whatever, as long you come by when I'm in town. I keep my MK III
912 at LNS (Lancaster PA) or you could land at Smoketown Q08, I live half
way between. Or if you let me know when you go to Homers, I might buzz up
there. You may not remember but we met at Sun-N-Fun several years ago.
http://scott.bentley.com/sunnfun981.htm
Terry Swartz
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Hauck
Subject: Kolb-List: September/October I'll Be Flying!!!
Kolbers:
>>x-country
The way I've done it in the past is one of two ways. First, I bungee'd on
the necessary containers and measuring devices. Secondly, I stashed pre-mix
along the route. Of course, in my Mark II, I'll just throw an empty can and
stuff into the passenger seat! ;-)
-Ken Fackler
Mark II/503
Rochester MI
> take.
Gee, what's wrong with marking the tank? That's what I've always done and
the way my Mark II is now.
-Ken Fackler
Mark II/503
Rochester MI
> -Ken Fackler
Ken/Gents:
I don't see anything wrong with marking the tank.
In my case, marking the tank won't do me any good. My tank
is behind the middle bulk head. I had the same arrangement
with the 18 gal aluminum tank in the original Firestar.
Used a site gauge for a fuel gauge. Worked perfectly, is
pretty simple to assemble and is almost Murphy proof. Never
had a problem with either the one in the FS or the MK III,
but always leave a little room for Murphy. The 25 gal
aluminum tank in the MK III is made of 3/8 ID tygon clear
fuel line. Two 90 deg fittings that are used for the Kolb
plastic tank fittings. There is a large neoprene washer
that is used with this fitting. I don't use the fitting
though. The small end is pushed through the bulkhead top
and bottom where it is plumbed into the top and bottom of
the fuel tank. Marked off with black tie wraps every gal.
When it gets to 3 gal remaining I use a red tie wrap because
this is the last place I can see the fuel to get a reliable
reading. I try to be on the ground refueling when I get to
the 5 gal mark.
Sure. John is one of the most helpful and reliable sources of information
on this list. I always pay attention to everything he posts. I hope I put
together as capable an airplane as he has done, and I hope to fly it half as
many hours he has safely documented. If in doing so, I can pass along a
tenth as much to this list as he has done, I would feel very proud.
E-mail is a tough way to get to know someone, and nobody can perfectly
express themselves all the time. But just ask a question about building or
flying a Kolb, however, and John will help you any way he can. My Mark III
will turn out better than I could have built it on my own, due to his advice
over the last couple of years.
Just my opinion.
you.
writes:
> done and the way my Mark II is now.
> -Ken Fackler
> Mark II/503
> Rochester MI
Ken, marking the tank and estimating how much gas is needed for a fill is
not accurate enough. Not only that, but if oil is being added to the main
tank directly, it is not getting mixed properly. On a cross country trip,
the last thing you want to fail is the engine.
Ralph Burlingame
Original Firestar
15 years flying it
Hi Guys,
Anyone know what the sink rate of the Firestar and Firestar 2 is at max gross
weight (at best power off L/D glide speed)?
Steve
John,
Where did you find room to stuff an 18 gal fuel tank in an original FS? What
weight were you flying at when fully loaded ( what did you modify to handle
the extra weight?)?
Steve
Steve/Gang:
Brother Jim made a mock up of card board to fit the area
behind the bulkhead and above the center longeron. After we
got that to fit, then fabricated a 5052 alum, .050 tank. We
had not idea how much it would hold until after it had been
welded up. Size was just right for the 447 that burned 3.75
gph at cruise of 5800 to 6000 rpm. Gave me about the same
duration then as I have now with the 912S and 25 gal tank.
What
> the extra weight?)?
Not sure what the gross weight was, but it was much greater
than design gross weight.
I did not modifications to handle the extra weight, other
than fuselage and landing gear mods. The 5 rib wings failed
at 755 hours, after many long, fast, and heavy trips. On
top of that did thousands of aerobatics during the life of
the airplane. Was the leading edges of both wings that
failed, pulling the noses of the main ribs up and back to
the main spar. Same same both wings.
I survived cause I had a Jim Handbury hand deployed
parachute and a Higher Power that was looking out for my old
hide. That was 12 and a half years ago. Have not done an
aerobatic maneuver in a Kolb aircraft since then.
From: | "Christopher Armstrong" <tophera(at)centurytel.net> |
> producing power.
Today, since I am still unable to get anywhere closer to finishing my plane
due to other projects (Jennifer 1, Bobby 5 and Caitlin 8 to name 3) I
decided to put some fogging oil in the 503. well I pulled the filters and
gave each carb a good shot, with the throttle propped open with a clamp.
gave the cord a couple of good yanks. on the last yank the engine started
and ran roughly for about 10 seconds! Plane was not tied down or anything
as there was no fuel in it. was still in my workshop actually with about an
inch of prop clearance to the ceiling! And since the wiring harness is off
it for mods there was no way to ground the ignition. If Anbody out there is
thinking of pulling some fogging oil threw their motor ya might wanta
disconnect the spark plug wires if the electrical harness is off.
Who would have guessed a 2 stroke could run on fogging oil? Have ya noticed
that you learn alot about what not to do by doing, but ya ussually learn
what to do from others.
Topher
From: | "Fackler, Ken" <kfackler(at)ameritech.net> |
Ralph et al:
I certainly agree about the problem with mixing. I thought the idea that
someone else posted about shaking the plane was interesting but frankly felt
very unsure about my ability (I'm fat and out of shape and not very strong)
to do that successfully. Up till now anyway, I've always found some way to
avoid trying to mix in my main tank.
-Ken Fackler
Mark II/503
Rochester MI
9/4/02 20:46John Hauck
> On
Well you had my attention on that one John. :-)
Do you have any photo's that you may care to share of those wings, and the
failure mode. Its interesting that the leading edge is what gave away.
By the way the identifier for Copper State Fly In is (A39).
This Saturday I will be up there helping to put up one of the buildings,,,
got no idea what, but we (EAA) are going to put up a building for ya'all.
Ron(FHU)
9/4/02 22:14Christopher Armstrong
> Topher
Any damage?
Ron(FHU)
> For someone who is considering getting into ultras that's a cautionary
> tale. I'll still do it if possible but with extra care.
> kj
kj/Gents:
I might emphasize, this was not a design defect in the
airplane, but operator defect in the pilot. I understand
the pilot had to work for 755 flight hours to initiate and
accomplish that "short field" landing.
Might help some of our aspiring aerobatic pilots to make the
best decision when it comes time, whether to do or not to do
aerobatics in any aircraft that is not designed and built to
perform aerobatic maneuvers.
Some of us learned the hard way.
From: | "James, Ken" <KDJames(at)berkscareer.com> |
Ouch is all I have to say!
Ken
Gang:
John Jung gave me a few pointers on correctly uploading to
my index page so that Netscape as well as IE folks can
open. I think this url will work:
http://hawk36.home.mindspring.com/Firestar/FS%20021190.JPG
Thanks John J.
Legal eagles, getting near that time where I have to stick some ugly
markings on the bird......browsing through some of my pictoral archives,
I notice that many have somehow avoided applying the 2" experimental
lettering at both entrances (MkIII) per the FAR regs. What's the
loophole? I like the door glass method, but initially I won't have
any . -BB
> any . -BB
BB/Gang:
The requirement, as I understand it and the way I did mine,
is to have the EXPERIMENTAL located so that it can be seen
upon entering the aircraft. I applied my to the bulkhead
behind the seats.
My first set of doors has "experimental" on each door
bottom. I like a single one on the bulkhead better.
My inspector had no problem with "experimental" on the struts. (see
http://www.springeraviation.net/chatthooch.html ) I have no structure to
put them on the fuselage though:)
Kip Firestar II
Atlanta
Subject: Kolb-List: markings
> any . -BB
The reg says the word EXPERIMENTAL has to have visible from each entrance .
Leading edge of the wing (front of the gap seal area) would suffice, or
across behind the seats if you have a place, would also comply.
Richard Pike
>any . -BB
I need a Rotax ball bearing for a 618, engine part
#932-330 special part #16101-Z--it is for the water
pump side of the rotary valve shaft. The tech doing
the rebuild ordered the complete set from LEAF but did
not inventory the shipment and it was back ordered.
He has checked Lockwood and California Powr Systems
Airwolf but no one has the part. Any ideas of who
might have the part?
Dale Seitzer
http://finance.yahoo.com
Subject: | Re: 618 Rotax Parts |
Try South Mississippi Light Aircraft.
Great company to buy from, they always ship quick and don't gouge you for
shipping like some of the California places.
Subject: | Need some help from my friends! |
I'm getting ready to fly my Mark3/912 for the first time
and could sure use some advice from some of
you "seasoned veterans". Having never flown a tail
dragger before, I've been taking lessons in a
Citrobria... just to get current.
My instructor asked me several questions about my plane
that hopefully a few of you could help me with:
1. What are the power settings and airspeeds you use for
landing?
2. Does it land better with a 3-point or wheel landing?
3. What is the glide like ratio @ gross?
4. How does it fly compared to a Cub?
Any other tips or advice would certainly be appreciated.
After 4 years of building... I think this thing is about
ready to fly!
Charles White
Houston, Texas
From: | "Richard Neilsen" <neilsenr(at)michigan.gov> |
Subject: | Re: Need some help from my friends! |
I will answer a few of your questions and a few you didn't ask.
Hopefully a 912 driver will jump in with RPMs.
1st A Kolb tail wheel is a non problem with the low landing speeds and
the main gear as far aft as they are the handling will feel more like a
nose gear airplane than a tail dragger.
The biggest problem you will have is that the Kolb will loose speed in
a heart beat. Even in a cub you will start you flair a 50 ft, you don't
do this in a Kolb. My recommendation is that you maintain some power on
landing app. 20-30% till you touch ground. Do not use full flaps till
you have 100 landings. You can use one notch of flaps to cut the float
on landing. Set up your approach at 50-60 MPH closer to 60 when heavy
and/or low on power. With your general aviation experience you will find
your self flaring way too high. You need to fly your plane down to 3ft
before you flair. The 20-30% power on landing will make your Kolb fly
more like cub landing with no power. Prepare your self for a panoramic
view of the ground coming up at you a whole lot faster than you are used
to.
My $.02 worth
Rick Neilsen
Redrive VW powered MKIII
>>> c.f.white(at)att.net 09/06/02 10:47AM >>>
landing?
ready to fly!
Charles White
Houston, Texas
Good advice Richard. The #1 problem that I've seen over the years, is the
guy that is used to flying heavier planes wanting to flare early and
coming down hard, bending the gear. Throttle back but not to idle and fly
it right down to the ground with a neutral stick and 1" of flare on the
stick (no more) and it will land itself in calm air.
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> and
> like a
> in
> don't
> on
> till
> float
> heavy
> find
> 3ft
> fly
> panoramic
> used
> to.
> My $.02 worth
> Rick Neilsen
> landing?
> ready to fly!
> Charles White
> Houston, Texas
> messages.
Have you checked your local SeaDoo/SkiDoo dealer? You never know, some of
those part numbers are the same, or maybe it can be cross referenced off
the microfiche.
Richard Pike
>Dale Seitzer
A good source informs me that Homer is playing around with
an old Firestar and exploring some of the realm of greater
dihedral. Maybe I will find out this Fall, if I can squeeze
a flight in up Pennsylvania way.
john when i rebuilt i added a bit of extra dihedrial and my
mkiii went from neg to netural roll stability. the plans
call for 1 1/2 inches at each tip and i went 3 inches at
each tip.. i can tell no diverence in performance.
boyd
From: | "Tommy & Carolyn" <TommyandCarolyn(at)centurytel.net> |
Subject: | 4th Annual Cajun Wings & Wheels Fly-in & Camp-out |
Subject: 4th Annual Cajun Wings & Wheels Fly-in & Camp-out
WHEN: September 27, 28 & 29
WHERE: Allen Parish Airport Oakdale, Louisiana
L42 N30-45-19 W92-41-30
WHO: Cenla Escadrille EAA Chapter 614 & the
Southwest Louisiana Ultralight Aircraft Club
FEATURES: Good food, Cajun music & much more, including
free shuttle service to Louisiana's premier
resort
casino, the Grand Casino Caushatta.
FEES: Free
FMI: Joel Johnson, Airport Manager
318-215-0090 or 337-639-4328
airport1(at)centurytel.net
I could use some advice.
Shortly ( within 5 minutes) after take off this afternoon, the front EGT
took a nose dive. Went from normal to about zero. No loss of power or
vibration so I suspect it is either the gauge or the connection from the
probe to the guage.
I quickly got back on the ground and reversed the probes with still no
reading on the front EGT.
I don't know if this is related or not, but I have noticed an increase
in rpm on one side when I did the mag check.
Any ideas?
Thanks.
Jim
Mark III with 503 DCDI
Sounds like a bad gauge. Take a reading of the gauges where the probes
connect, with an ohm meter. Front and rear Gauges should read the same. Tap
the gauge and shake it to see if the reading changes. Will the rear gauge
read both probes ok?
As long as we're on the topic of EGT, what's "normal" for Kolb Mark II with
the single ignitiion 503?
-Ken Fackler
Mark II/ 503
Rochester MI
> EGT
> Jim
Jim,
I had that very same thing happen to me and it turned out to be the EGT
sender on the muffler. I replaced it with another one and it was fine.
The original one read high and I was happy to see the new one reading
normal! It had me fooled for years before it finally went to zero on
takeoff one day.
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> II with
> -Ken Fackler
> Mark II/ 503
> Rochester MI
Not sure about the 503, but the 447 is 860-1080 degrees. I looked in the
manual.
Ralph Burlingame
Original Firestar
15 years flying it
Jim,
Can you be a little more specific on what you actually done where when you
stated you reversed the probes. It leaves a lot to interpretation.
jerryb
>probe to the guage.
>Any ideas?
>Thanks.
>Jim
Jim,
Try moving the leads to the rear guage and see if the front probe is
working. If it is, try the rear probe leads on the front guage and it
should tell you that the guage is bad.
John Jung
> took a nose dive.
Well stated Richard.
Charles and All,
Not sure the relevance of the Cub question would have unless you had prior
flight experience in Cubs to compare against.
The biggest problem I've seen with people new to Kolbs is they get them to
slow and drop them in, ending in a hard landing and bend a gear leg or
two. Keep your airspeed up, if your a little fast on landing it won't
hurt, they slow down fast and they don't fly very long if to
slow. Carrying a little power until touch down is good advise until you
get the feel of the plane.
As an ex Citabria owner, don't try to use the bottom of the Kolb wing for
basing pitch attitude, the Kolb have a lot of incidence in the wing and it
will look like you very nose high but your actually not.
I was very uncomfortable with our FireFly until we took it to a sod field
with no traffic and a 3000 ft runway. I made slow taxi runs holding it
straight and then making slight S turns (at slow speed). As I became
comfortable with that I progressed to making faster straight taxi runs,
burst of power to get the speed up some then back on the power. That
progressed to high speed tail up runs coming back on the power just enough
to keep the tail up but not enough to fly. After a few of those I felt I
had good control I power to it and took off. (No crow hops, makes you have
to do to much too fast and has led to a number of planes being busted by
trying these.)
NOTE: any time you do any taxiing, whether you plan to fly or not, ALWAYS
have enough fuel on board to fly for a while just in case it should get off
the ground. Last if it does, fly it, don't panic and plop it back down or
you surely will bust it.
Fly it staying within gliding distance of the airport. Do circuits above
the normal GA pattern altitude monitoring your engine instruments. After
your build a little confidence that its going to stay running, while at
attitude, try bringing back the power to see that it will keep
running. (Recommend doing this on down wind leg of the circuit as it sets
you up for a landing if the engine should stop, you would just have to
adjust your decent rate for a proper approach.) Slowly reapply power and
return to a safe altitude, now do a power off no flap stall, note the
airspeed indication when the stall breaks, repeat with the amount of flaps
used in a normal landing configuration, say 2 notches. Don't recommend
full flap landings until your more acquainted with the airplane.
Landing practice.
Take your time, set up a good approach. A good approach is primary
ingredient to a good landing. What I did was shoot a couple approaches but
not with the intention of touching down. This got me more acquainted with
the plane as I got near the ground and what level flight looked like, do
not get slow. Next I shot 10 landing in normal landing configuration. The
first 5 or six were full stop, the remainder were touch and goes slowing to
a near stop and then taking off. The first few I was very nervous, by the
8th-10th I had good control of things. Took a break, then went back and
shot 10 more. By the time I got done with the second group of 10, I was
getting the point of being cocky, able to spot land the plane exactly
where I wanted it.
jerryb
>to.
>My $.02 worth
>Rick Neilsen
>landing?
>ready to fly!
>Charles White
>Houston, Texas
In a message dated 9/6/02 10:38:27 PM Eastern Daylight Time, ul15rhb(at)juno.com
writes:
> manual.
> Ralph Burlingame
> Original Firestar
> 15 years flying it
Those EGT temps. are the same listed in the manual for the 503 as "normal";
many of the 'guru's" on this list advocate running them a little hotter.
Who's right, or does it matter as long as we don't exceed 1200 degrees?
Shack
FS II
SC
> Shack
Shack/Gents:
Who is running precision EGT Gauges? Are these gauges
calibrated? Do you really know if the indicated temps are
correct? Are you gonna gamble on an engine and an airplane,
plus the possibility of your butt on a Westach gauge? Are
the manufacturers lying when they publish the green arc for
EGT? Do the "guru's" know what they are talking about? How
much "real" experience do the "guru's" have? Is not 1200F
the red line for EGT? Is that where you want to be
operating?
Just thought I would toss in some more questions. :-)
Jerry,
I took the probes off at the exhaust and moved the front to back and vice
versa. Still the guage showed no reading on the front EGT which makes me
think it is the guage.
Jim
Subject: Re: Kolb-List: EGT
> Jim,
> jerryb
> >probe to the guage.
> >Any ideas?
> >Thanks.
> >Jim
> Any ideas of who
>Dale Seitzer
bearings and seals are stock items. Check your yellow pages for bearings
and give them a call. The original bearing will have a number on it like
6304. If not give them the dimensions and they can find the right bearing.
Guys,
As we all know, the spark plugs tell the real story, but if the EGT is
running beyond 1300 degrees, this is a case for some real concern. A
badly calibrated gauge or sender could not be this far off. EGT temps are
for reference only but in an earlier post, 1200 deg was a normal
operating temp with the original sender. Did not know at the time that it
was bad from the beginning.
When I installed this 447 engine and ran it for the first time on the
ground, it was approaching 1300 deg on the EGT at full power. The engine
had been 'pickled' in 2-stroke oil and after running it for a half hour,
the EGT's came down to normal for that sender (1200 deg).
Ralph Burlingame
Original Firestar
15 years flying it
writes:
> "normal";
> hotter.
> degrees?
> > Shack
> Shack/Gents:
> operating?
> messages.
> Jerry,
> vice
> makes me
> Jim
Jim,
No need to move the senders, just switch wires on the back of the EGT
gauge(s) and see if the front and rear readings follow (the one that
reads zero will move to the opposite side of the gauge or to the other
gauge). If they do, it's a bad sender. If they don't, it's a bad gauge.
Ralph Burlingame
Original Firestar
15 years flying it
When your spark plugs are no darker than dark brown, and no lighter than
light brown, that's what you want. Whatever the EGT gauge indicates under
those conditions is normal.
Richard Pike
>writes:
>> manual.
>> Ralph Burlingame
>> Original Firestar
>> 15 years flying it
>Shack
>FS II
>SC
From: | "Chris Sudlow" <sudlow77(at)earthlink.net> |
Charles,
I transitioned from cessnas to kolbs with an instructor. Kolbs are very
August 23, 2002 - September 07, 2002
Kolb-Archive.digest.vol-du
