Kolb-Archive.digest.vol-eb
December 15, 2002 - January 09, 2003
      engines. Are they good/bad? I'm sold on the 912S. But like to look at
      others. At a recent fly in a man showed up in a homebuilt that looked like a
      Kolb.Well I went over to investigate of course, and noticed he had used a
      Honda 650CBR engine mounted low next to the tail boom and had a chain drive
      set up to a home made spinner shaft using common pillow block bearings. He
      powered the spinner via chain (a very long one) from the countershaft
      sprocket of the motorcycle engine! As he flew off it was very quiet and seem
      to fly very well. I heard others make the comment, "Yeah and he shift's the
      thing while in flight!".
      > Crazy ey?
      > I have some photos if any of you want to see it.
      > Thanks
      > Paul
Date: Dec 15, 2002
Subject: Re: Remote ckokes
In a message dated 12/15/02 4:31:07 PM Eastern Standard Time, rowedl(at)highstream.net writes: > I am going to try to locate shorter lower rate springs tommorow for eack > carb. > Anyone have any other ideas? > > Maybe cut about 2 coils off the existing springs. Shack FS II SC ________________________________________________________________________________
Date: Dec 15, 2002
Subject: Re: Cover Wings
The plans say to rivit the fabric. These planes have flown thousands of hours with this system with good results. I use a system called Hi pec or now its called endura. The fabric is glued to the ribs. I heard once the faa rules and regs don't specify rib stitching if the top speed is under 100 mph. Your choice but if in doubt go by the book. Glue the fabric to the hinges just like you are gluing it to the tubes. Don't be shy with the glue. I have not seen these little slits open up like a carps mouth but I suppose it could happen. Glad you enjoy my ramblings > >Woody, I am also very intersted in your rambling tips!....LOL....I am >finishing building my ailerons and will start asembling for rigging this >week. I have been thinking about covering and so on. >Do you rivet the fab to those skinny little ribs, or do you rib stich em'?? >The riveting idea does seem attractive as a time saver, but that 5/16's rib >tube seems so small that all those holes worry me. >Also, on the idea of something to prevent the scalloping, I sure link that >tip on the wrapping of the bottom fabric way around. I was trying to think >up a way to help support the dabric there and this sounds like a winner..I >had been considering using flat rib lacing across the ribs to accomplish >this, but im sire it would show, as narrow as it is. this seems like a great >idea. If you think up any more tips for us fellas about to the covering >stage..PLEASE ...ramble onward ! > >Don Gherardini >FireFly 098 >http://www.geocities.com/dagger369th/my_firefly.htm > > ________________________________________________________________________________
Subject: BTW
Date: Dec 15, 2002
In case your interested, http://www.harley-davidson.com/PR/ENG/en/new_eng_trans.asp?WebLogicSessionPf06R8qIhz0ArZmm5UoT3KrIyWGfKHo8V0ClkeYCYpoSn08dyfg9|5078166962732252838/181237815/6/7005/7005/7002/7002/7005/-1|-5250543574297404224/181237784/6/7005/7005/7002/7002/7005/-1&bmLocaleen_US ________________________________________________________________________________
Subject: Re: Engines
Date: Dec 15, 2002
Paul, I would luve to see those pics pard...if you can ..email em to me at donghe@one-eleven.net thx pard Don Gherardini Firefly 098 ________________________________________________________________________________
Subject: Re: turnie thingies.
Date: Dec 16, 2002
everyone is looking for the perfect power plant. well, possibly one is in the making. go check out the web sites at: http://airscooter.com and http://aerotwinmotors.com . if the figures are correct about weight, etc, and the man is close on his projected price of $6500 available next year, this is going to revolutionize the industry. going to be hard to beat. my opinion. ted cowan ________________________________________________________________________________
Date: Dec 16, 2002
Subject: Re: BTW
Paul Petty wrote: > > > In case your interested, > No Thanks! I'm afraid my wings would vibrate off :-) -- Earl ________________________________________________________________________________
Date: Dec 16, 2002
<donghe@one-eleven.net> writes: > <donghe@one-eleven.net> > > Woody, I am also very intersted in your rambling tips!....LOL....I > am > finishing building my ailerons and will start asembling for rigging > this > week. I have been thinking about covering and so on. > Do you rivet the fab to those skinny little ribs, or do you rib > stich em'?? > The riveting idea does seem attractive as a time saver, but that > 5/16's rib > tube seems so small that all those holes worry me. > Also, on the idea of something to prevent the scalloping, I sure > link that > tip on the wrapping of the bottom fabric way around. I was trying to > think > up a way to help support the dabric there and this sounds like a > winner..I > had been considering using flat rib lacing across the ribs to > accomplish > this, but im sire it would show, as narrow as it is. this seems like > a great > idea. If you think up any more tips for us fellas about to the > covering > stage..PLEASE ...ramble onward ! > > Don Gherardini > FireFly 098 > http://www.geocities.com/dagger369th/my_firefly.htm Don, It isn't the fabric rivets alone that holds the covering on the ribs, it's the polybrush too. I've seen the fabric removed from a Kolb wing and it is glued very well to the ribs along with the riveting. I've had mine for 16 years and there's no hint of it coming loose. The aluminum fabric rivets and polybrush will do the job just fine. Ralph Original Firestar ________________________________________________________________________________
Date: Dec 16, 2002
Subject: engines n uppness
In a message dated 12/16/02 10:33:21 AM Eastern Standard Time, ul15rhb(at)juno.com writes: > > Paul, > > I'm a 20+ year biker too, but of the rice-burner type. I think a Harley > engine would be much too heavy for a Kolb. There may be other aircraft > where it may be considered a possibility. I've also been flying a > Firestar with a 2-stroke engine(s) for 16 years (377/447). I really don't > understand why many new Firestar builders are thinking about other > engines when there is a proven one right under their noses. The lowly > Rotax 447 is, in my opinion, a very reliable option on a Firestar or > Firefly. I love my little 447 as it is easy to maintain and inspect. It's > simplicity at its best. I'm sure there will be some very good 4-strokes > on the market soon. It would be nice if Rotax made a scaled down 40-50 hp > 912 (and it would be pricey), but until that day comes, the 2-strokes we > have right now are good little engines if they are maintained and the > operators know a few things about using them. > > In the past couple of years in this area, there have been 4 aircraft that > went down with engine problems. These were 4-stroke certified aircraft > engines. Having a 4-stroke engine on a aircraft does not necessarily mean > that it won't quit on you. A 2-stroke engine has about 1/3 the moving > parts of a 4-stroke. Less parts means less to go wrong. Recently a trike > pilot made a 3000 mile flight from Sun-n-Fun to LA on a 2-stroke 503. On > our list, a couple of Firestar pilots made a 4000 mile flight powered > with 2-stroke 503's. For a low-cost engine, what more does a guy want? > > Ralph > Original Firestar > I agree 100% with Ralph. I know how youn's guys LOVE the sound of a Harley and would divorce the wife before the Harley, but the 447 is a very powerful machine that will give you more than enough power for your Firestar or Firefly to the extent that you cannot hold it back on the ground....I have never been able to open the throttle all the way on the ground without losing control of the "stopped" airplane. Come to think of it, I even remember accidently caving in an aluminum wall with my measely 35 HP Cuyunna engine once when I had it mounted on my Pterodactyl. In this day and age, Paul, I really doubt if you can say that power is a problem. Reliability might be, if you don't practice off field landings....don't forget, you are dealing with a 3rd dimension here......up. If not prepared, the "uppness" can kill you because it is convertible to speed and we all know what that can do. George Randolph Firestar driver from Akron ps. don't think I don't know the creativity and joy of freedom of thought that you are going through, however, as I like to invent too even to the extent that I wrote my own. patent for a toy. pps the first aircraft engine weighed 200# with exhaust and mounting and put out 12 Hp Today, the 447 weighs around 65# and puts out 42 HP....are we talkin progress here, or what? ppps since uppness is THE premium in flying, THE enemy is weight...not like on a motorcycle where friction/weight is a premium, ie friend. ________________________________________________________________________________
Subject: Eliminating scalloping, or "troughing" on the wings
Date: Dec 16, 2002
Hi gang, We have a good technique to all but eliminate the "troughing" or scalloping effect on the wing leading edge area. (or if you want a lot of it, we can tell you how to get it too). This is done by a very simple heat shrinking sequence. Steve Green and several others tried this technique and were very happy with it. Give us a call (before you glue the fabric on) and we'll walk you through it. Thanks, Jim & Dondi Miller Aircraft Technical Support, Inc. Poly-Fiber & Ceconite Distributors (Toll Free) (877) 877-3334 Web Site: www.poly-fiber.com E-mail: info(at)aircrafttechsupport.com ________________________________________________________________________________
Date: Dec 16, 2002
Subject: Re: engines n uppness
>George Randolph >Firestar driver from Akron > >ps. don't think I don't know the creativity and joy of freedom of thought >that you are going through, however, as I like to invent too even >to the extent that I wrote my own. patent for a toy. >pps the first aircraft engine weighed 200# with exhaust and mounting and put >out 12 Hp > Today, the 447 weighs around 65# and puts out 42 HP....are we talkin >progress here, or what? >ppps since uppness is THE premium in flying, THE enemy is weight...not like >on a motorcycle where friction/weight is a premium, ie friend. > George, Let's be fair about this. The 447 dressed with carburetor, cooling fan and shrouds, and exhaust system weighs considerable more than 65 pounds. I am pleased that someone loves Rotax engines, because this love enabled me to sell my 447. I am very happy to go to a replacement engine that weighs the same as the dressed 447, which includes electric starter and battery, uses much less gas, puts out more power, and a muffler so quiet that I do not have to turn on my ANR headset, idles below 2000 rpm without complaint or vibration, and follows the throttle without hesitation and holds a constant rpm setting in level flight. This is progress. If the 447 had acted this way, I would not have changed. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Dec 16, 2002
> It isn't the fabric rivets alone that holds the covering on the ribs, > it's the polybrush too. > Ralph Hi Ralph/Gents: Correct me if I am wrong. There usually is some adhesion of the fabric to the ribs with what Polybrush weeps through the fabric. But don't bet your buns on preventing the fabric from billowing should the fabric rivets fail. That little bit of polybrush won't hold it. The way I understand this stuff is the strength comes from cohesion of fabric cemented to fabric with Polytak and Polybrush, depending on what the application is. We don't get cohesion from cementing the fabric to the airframe alone. That's called adhesion. I guess if you wrapped more than a complete wrap around a tube and cemented it on itself it would be cohesion. I have never seen fabric rivets fail, but I have seen a case of rib stitching fail on several inboard ribs, both left and right wing panels, on a Kolb Sling Shot. Also discovered this problem while flying slightly above and to the rear of the Sling Shot. The air stream really pulls the fabric up and away from the wing rib structure. So, do a good job covering and fastening your fabric to those little ribs. Losing the top fabric on a wing is disastrous. Saw this happen to a new Great Lakes during the airshow at Sun and Fun many years ago. Failure was advertised by a tremendous explosion as the fabric departed the wing. Aircraft was at aprx'ly 500 feet. Pilot flew it due west of Lakeland Airport until he was in a relatively uninhabited area, then jumped with his emergency parachute. Broke a leg or ankle, but was otherwise none the worse for wear. He was fortunate enough to be able to hold the airplane straight and level with full left aileron. The Great Lakes was borrowed from the owner to do the airshow. Oops! Take care, john h ________________________________________________________________________________
Date: Dec 16, 2002
Subject: Re: Eliminating scalloping, or "troughing" on the wings
> We have a good technique to all but eliminate the "troughing" or scalloping effect on the wing leading edge area. > Jim & Dondi Miller Jim/Dondi/Gents/Ladies/and everybody else: Homer Kolb liked the shape of the covered Kolb wing sections. If he didn't he would have stuck a sheet metal leading edge on it. Again, my understanding, for what it is worth and that ain't much, was that the scalloping effect helped keep the outboard 5 feet or so of the wings from stalling. I made no overt attempt to keep my wing fabric from being pulled down between the ribs except in the technique I use to heat shrink the fabric. Maybe you can guess how much fun it was to recover a wing after 8 years and try to shrink the fabric to match the scalloping on the old wing. Something to think about. Especially when one hasn't done any fabric work in 8 years. I usually start shrinking at the inboard rib cordwise and out at the bow tip. I pull the fabric pretty good with the iron to initially pull the fabric span wise. Then follow the directions in the manual. I kinda like the scalloping effect. Looks classic to me and it works great in the air too. Take care, john h ________________________________________________________________________________
Date: Dec 16, 2002
> Hi Ralph/Gents: > > Correct me if I am wrong. > > There usually is some adhesion of the fabric to > the ribs with what Polybrush weeps through the > fabric. But don't bet your buns on preventing the > fabric from billowing should the fabric rivets > fail. That little bit of polybrush won't hold it. >snip> > john h John, I think it's a combination of the aluminum rivets and the glue that hold it together. You are right about the Polybrush not having cohesive strength between fabric and metal, but it does hold it tight enough so the rivets don't pull out. What does Jim & Dondi Miller have to say about this? I don't understand how rib stitching can rip apart like that example you mentioned. It's pretty strong isn't it? What about the fabric covered tail sections of the B-29 and other old fighters? Were they riveted or rib stitched? Ralph ________________________________________________________________________________
Date: Dec 16, 2002
> I don't understand how rib stitching can rip apart like that > example you mentioned. It's pretty strong isn't it? What about the > fabric covered tail sections of the B-29 and other old fighters? Were > they riveted or rib stitched? > > Ralph Ralph/Gang: Rib stitching is strong and was around probably long before anyone dreamed up fabric rivets. I think the problem lies with a incorrectly tied knot or some problem that causes a failure in one place and then like dominoes goes up the rib. Rib stitching is done with a continuous piece of thread/line/cord, whatever you call it. Maybe the Kolb Sling Shot was not done correctly. I don't know. The Great Lake Biplane fabric seperated for I know not why also. :-) john h ________________________________________________________________________________
Subject: Vibration
Date: Dec 16, 2002
12/16/2002 05:11:59 PM, Serialize complete at 12/16/2002 05:11:59 PM, Itemize by SMTP Server on HUDOMGW1/HTI(Release 5.0.11 |July 24, 2002) at 12/16/2002 05:12:33 PM, Serialize by Router on HUDOMGW1/HTI(Release 5.0.11 |July 24, 2002) at 12/16/2002 05:12:53 PM, Serialize complete at 12/16/2002 05:12:53 PM I know this topic has been addressed in the past, but it bears repeating. I seeded a new 500 foot landing strip on my farm and have been flying into it all summer. This weekend I rolled out my Firestar, did the pre-flight, warmed her up and taxied to my runway. I powered up and just as I was about to lift off a violent vibration began. I was afraid the nose cone was coming off it shook so bad. I immediately returned and did another extensive check and found nothing. So I decided to go up again. This time as I lifted off with vibration again, I looked down at my wheels and they where shacking in every direction imaginable. Of course as they slowed down and stopped , so did the vibration. The rest of the flight was perfect. I am assuming in the summer with soft grass and soft dirt, the vibration was absorbed. Now with the ground frozen the vibration goes right up the axle. The moral of this story is: Get them damn wheelbarrow bearings the heck out of your wheels! The Flying Farmer ________________________________________________________________________________
Date: Dec 16, 2002
Subject: Re: Vibration
> Get them damn wheelbarrow bearings the heck out of your wheels! > > The Flying Farmer Dwight/Gang: Probably not bearings but the tires you are using. Wheelbarrow and lawn tractor tires are not trued and balanced after they come out of the mold. Also could have been caused by the airplane sitting for a long period of time in one spot. They get flat sided, especially if you live in Yankee Land or someplace where it really gets cold. I used to tough the heel brakes just after take off to stop the vibs and regain my vision. Now, with cheap aircraft tires, I no longer have a problem. Before I got the Air Tracs I used a pound of lead to try and balance the 800X6 tractor tires. john h ________________________________________________________________________________
Date: Dec 16, 2002
In a message dated 12/16/02 2:27:40 PM Eastern Standard Time, jbhart(at)ldd.net writes: > George, > > Let's be fair about this. The 447 dressed with carburetor, cooling fan and > shrouds, and exhaust system weighs considerable more than 65 pounds. > > I am pleased that someone loves Rotax engines, because this love enabled me > to sell my 447. I am very happy to go to a replacement engine that weighs > the same as the dressed 447, which includes electric starter and battery, > uses much less gas, puts out more power, and a muffler so quiet that I do > not have to turn on my ANR headset, idles below 2000 rpm without complaint > or vibration, and follows the throttle without hesitation and holds a > constant rpm setting in level flight. This is progress. If the 447 had > acted this way, I would not have changed. > > Jack B. Hart FF004 > Jackson, MO > > > Jack &Louise Hart > Hey Jack! I never said the 447 was the ultimate engine...only that it compared rediculessly great compared with the early aviation engines. If yours puts out more power at the same weight, uses less gas to do it, uses a better muffler (not a resonator that pulls more hp?) , idles at less than 2000 rpm, then I need to look into it too, provided it has a good track record. My 447 also follows the throttle without hesitation and holds a constant rpm in level flight. As far as the weight is concerned, you're probably correct as I was just guessing from '92 when I built it and I was much stronger then. :-) What engine do you use on your firestar? George Randolph Firestar driver from Akron, Oh ________________________________________________________________________________
Date: Dec 16, 2002
> > > > I don't understand how rib stitching can rip apart like that > > example you mentioned. It's pretty strong isn't it? What about the > > fabric covered tail sections of the B-29 and other old fighters? Were > > they riveted or rib stitched? I think the problem with rib stitching is that we are trying to do it on a round tube. This will be weaker than on a flat surface as there is less area between the needle holes and less rib material to pull down onto. ________________________________________________________________________________
Date: Dec 16, 2002
> I think the problem with rib stitching is that we are trying to do it > on a round tube. This will be weaker than on a flat surface as there is > less area between the needle holes and less rib material to pull down onto. Woody Woody/Ralph/Gents: Don't you think the reinforcing tape is sufficiently strong enough to get the job done? That tape is pretty tuff!!! I tdhink Richard Pike rib stitched his MK III or one of his airplanes. I rib stitched a good bit of the longerons on the rear of my MK III fuselage. 90% of it was blind stitching. A Hell of a way to learn rib stitching. Never had any problem with any of that letting go and most of that area in very near the prop. I think the reason we use fabric rivets rather than rib stitching is because if is an easier, quicker, more durable system for our purposes. I had much rather rivet than stitch. john h ________________________________________________________________________________
Date: Dec 17, 2002
Subject: Re: Second Chanz Chute
When Second Chanz went out of business, all the owners were sort of just hung out there without much support. What I was wondering is , am I one of only a handfull who are using their system yet ,or are there others? My MK3 was the prototype for their soft pack set up in the gap seal. John Dunham had my unit on display at Sun & Fun. I have been flying with mine since 95. Every 3 yrs I take it to a rigger, who inspects the chute and repacks it. Should I have any concern as to whether or not the rocket will work? I guess what I'm asking is, should I be relying on this older system, leave it in as a back up that "may work", or take it out and scrap it? With all the knowledge and experience of list members, I will see what your responce is and decide from there. Fly Safe Bob Griffin ________________________________________________________________________________
Date: Dec 17, 2002
> Should I > have any concern as to whether or not the rocket will work? > Bob Griffin Bob/Gang: Is your system solid fuel or air deployed? john h ________________________________________________________________________________
Date: Dec 17, 2002
I am still using mine, and as long as the nitrogen cylinder's pressure gauge stays where it has been since I bought it, I can't see why it wouldn't still be ready to go. I will be having mine repacked this year also. Richard Pike MKIII N420P (420ldPoops) > >When Second Chanz went out of business, all the owners were sort of just hung >out there without much support. What I was wondering is , am I one of only a >handfull who are using their system yet ,or are there others? My MK3 was >the prototype for their soft pack set up in the gap seal. John Dunham had my >unit on display at Sun & Fun. I have been flying with mine since 95. Every 3 >yrs I take it to a rigger, who inspects the chute and repacks it. Should I >have any concern as to whether or not the rocket will work? I guess what I'm >asking is, should I be relying on this older system, leave it in as a back up >that "may work", or take it out and scrap it? > With all the knowledge and experience of list members, I will see what your >responce is and decide from there. >Fly Safe >Bob Griffin > > ________________________________________________________________________________
Date: Dec 17, 2002
Who repacks them? I also have a Second Chanz with the Nitrogen cylinder . Seems like we should be able to recharge the cylinder also, though mine still reads the same as new. > > I am still using mine, and as long as the nitrogen cylinder's pressure > gauge stays where it has been since I bought it, I can't see why it > wouldn't still be ready to go. I will be having mine repacked this year also. > > Richard Pike > MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Dec 17, 2002
> George, > > Let's be fair about this. The 447 dressed with carburetor, cooling fan and > shrouds, and exhaust system weighs considerable more than 65 pounds. > > I am pleased that someone loves Rotax engines, because this love enabled me > to sell my 447. I am very happy to go to a replacement engine that weighs > the same as the dressed 447, which includes electric starter and battery, > uses much less gas, puts out more power, and a muffler so quiet that I do > not have to turn on my ANR headset, idles below 2000 rpm without complaint > or vibration, and follows the throttle without hesitation and holds a > constant rpm setting in level flight. This is progress. If the 447 had > acted this way, I would not have changed. > > Jack B. Hart FF004 > Jackson, MO > > > Jack &Louise Hart > Hey Jack! I never said the 447 was the ultimate engine...only that it compared rediculessly great compared with the early aviation engines. If yours puts out more power at the same weight, uses less gas to do it, uses a better muffler (not a resonator that pulls more hp?) , idles at less than 2000 rpm, then I need to look into it too, provided it has a good track record. My 447 also follows the throttle without hesitation and holds a constant rpm in level flight. As far as the weight is concerned, you're probably correct as I was just guessing from '92 when I built it and I was much stronger then. :-) What engine do you use on your firestar? George Randolph Firestar driver from Akron, Oh One that seized very early in it's life due to some "teething" problems with a new installation. I don't want to sound critical of Jack cause he is an exception...by all appearances he is a guy who loves to experiment more than fly and obviously has the technological know-how to diagnose problems and come up with solutions and MORE IMPORTANTLY has the time and patience to do it. Buuuuuutttttt I say this for the "newbies" out there that are considering a project and thinking about going against the "herd" and putting an "alternative engine" on their planes...you WILL take considerably longer to build the plane and it WILL take considerably longer to get it right. If you want to fly, DON'T be a trailblazer. If you enjoy tinkering and experimenting more than flying, then get you an alternative engine and have at it. Look at our list "punching bag" Big Lar...if he wasn't so darned creative, he'd have been flying a long time ago... ;-) Jeremy Casey jrcasey(at)ldl.net P.S. If my 503 had been any quicker to accelerate/decelerate when I moved the throttle...it would have had to read my mind to get a head start on me... ________________________________________________________________________________
From: "Christopher Armstrong" <cen33475(at)centurytel.net>
Subject: engines
Date: Dec 17, 2002
Having been working with powersport aviation for 5 years developing an aircraft engine I can tell you that it isnt easy and it is expensive. Our product is 215 hp so it is quite a bit more in every way then an engine for a kolb but developing a sound solution at 50 or 100 hp will be no cake walk either. THe main thing that is difficult is that for aviation engines weight is such a significant factorm that unless it is one of the prime considerations through out the design of the engine the resultant package will be so heavy as to make all the effort in the world a waste of time. The rotax 2 strokes are not bad engines and have a great compromise between weight and reliability. If Rotax would put a good fuel injection system on them you would probably never hear of engine seasures... Still dont know why they havven't done that. till someone with lots and lots of money starts an engine from scratch I think they are going to be the best solution for us. Mark Bierle's radial cam engine and the engine being developed for the skyscooter both have great promise, but do they have the financial backing they need to get them out the door, and take a decent chunck of the fairly small market so that they can be long term players in the business? to do that is around a half million dollar outlay of capital. That isnt a WAG either. it is based on direct experiance at doing this. by the way anybody with some money you want to invest in an aviation business can send it my way! You want to know how to make a million in aviation? Start with 2 million. Topher ________________________________________________________________________________
Date: Dec 17, 2002
> >One that seized very early in it's life due to some "teething" problems >with a new installation. I don't want to sound critical of Jack cause >he is an exception...by all appearances he is a guy who loves to >experiment more than fly and obviously has the technological know-how to >diagnose problems and come up with solutions and MORE IMPORTANTLY has >the time and patience to do it. Buuuuuutttttt I say this for the >"newbies" out there that are considering a project and thinking about >going against the "herd" and putting an "alternative engine" on their >planes...you WILL take considerably longer to build the plane and it >WILL take considerably longer to get it right. If you want to fly, >DON'T be a trailblazer. If you enjoy tinkering and experimenting more >than flying, then get you an alternative engine and have at it. > >Look at our list "punching bag" Big Lar...if he wasn't so darned >creative, he'd have been flying a long time ago... ;-) > >Jeremy Casey >jrcasey(at)ldl.net > Jeremy, You are correct about the time required, but not about the enjoyment. The purpose of "tinkering and experimenting" is to increase flying enjoyment. I call the FireFly upgrade process wart removal, and over the years I have been removing one wart at a time. I built the FireFly to the plans and I discovered first that brakes were a requirement to make me feel comfortable taxiing around other planes. Then I discovered that the ailerons were too heavy for middle of the day or/and cross country flight so I went from 15 to 9 inch chord ailerons and changed push rod location to balance out aileron forces. Added vortex generators to reduce roll twitchyness, and to give better low speed lift after a nose over on grass. Added in cockpit trims for roll and pitch to reduce the energy required to fly. Added strobes and bright nose light to let others know that a stealthy FireFly was in the pattern. At this point I had a FireFly that was a delight to fly, but for only short periods of time due to one last huge wart - high fuel consumption rates. I know that Part 103 was not implemented with the idea of flying ultra light vehicles flying across country. But if one can meet Part 103 requirements and still fly across country what would be the harm? I wanted to increase the enjoyment by being able to fly more than an hour and fifteen minutes with out worrying about running out of gas. This lead to the engine change and it looks like it is going to work out well, but it is much too early to tell. For the most part, I believe in small incremental change because it lets you continue (enjoy) to fly during the whole process of improvement or experimentation and greatly reduces the chance for unexpected events. Each time you get it to fly a little better with less energy on your part the more enjoyable the flight becomes. Right now I have only one more change to make and that is to add fairings to the struts and aileron push rod tubes. This should improve range and speed a little. I was a "newbie" just three/four years ago, but I do have an advantage that I am a retired "newbie" and this FireFly has been a lot of fun. I started the web site so that my children who live several states away could be kept abreast of the FireFly progress. Because of this mailing list, it has been a way to show how one FireFly builder has done it. Has it been worth all the effort? Yes! I don't miss the sore shoulder from heavy ailerons and non electric start, and the I like the quietness and low fuel consumption rates of the new engine. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Dec 17, 2002
> Jeremy, You are correct about the time required, but not about the enjoyment. The purpose of "tinkering and experimenting" is to increase flying enjoyment. I call the FireFly upgrade process wart removal, and over the years I have been removing one wart at a time. I built the FireFly to the plans and I discovered first that brakes were a requirement to make me feel comfortable taxiing around other planes. Then I discovered that the ailerons were too heavy for middle of the day or/and cross country flight so I went from 15 to 9 inch chord ailerons and changed push rod location to balance out aileron forces. Added vortex generators to reduce roll twitchyness, and to give better low speed lift after a nose over on grass. Added in cockpit trims for roll and pitch to reduce the energy required to fly. Added strobes and bright nose light to let others know that a stealthy FireFly was in the pattern. At this point I had a FireFly that was a delight to fly, but for only short period! s of time due to one last huge wart - high fuel consumption rates. I know that Part 103 was not implemented with the idea of flying ultra light vehicles flying across country. But if one can meet Part 103 requirements and still fly across country what would be the harm? I wanted to increase the enjoyment by being able to fly more than an hour and fifteen minutes with out worrying about running out of gas. This lead to the engine change and it looks like it is going to work out well, but it is much too early to tell. For the most part, I believe in small incremental change because it lets you continue (enjoy) to fly during the whole process of improvement or experimentation and greatly reduces the chance for unexpected events. Each time you get it to fly a little better with less energy on your part the more enjoyable the flight becomes. Right now I have only one more change to make and that is to add fairings to the struts and aileron push rod tubes. This should improve range and speed a little. I was a "newbie" just three/four years ago, but I do have an advantage that I am a retired "newbie" and this FireFly has been a lot of fun. I started the web site so that my children who live several states away could be kept abreast of the FireFly progress. Because of this mailing list, it has been a way to show how one FireFly builder has done it. Has it been worth all the effort? Yes! I don't miss the sore shoulder from heavy ailerons and non electric start, and the I like the quietness and low fuel consumption rates of the new engine. Jack B. Hart FF004 Jackson, MO Fair enough...I understand the enjoyment thing...kinda misspoke that one. Main point I was trying to get across was the time issue. I haven't read every word of your website, but I figured you were blessed with a retirement... ;-) (I want one too!!!) cause I know the effort that went into what you've done to that Firefly was at least as costly in time as it was in money and know-how. I made 3 simple (?) changes to my Mark 3 project (new seats, Full Lotus float mounts, and larger fuel tank) and I spent more time designing and fab'ing those changes than building the rest of the plane... Bottom line... if you want to fly, then build it to the plans, go with a "someone's been there already" engine and keep the "creativity" to a minimum. THEN..... put your "creative" juices to work making improvements (like Rev. Pike, Jack, and countless others...) otherwise if you try to add every little idea as your building it...you'll never finish it (at least not till retirement ;-) ) Off Soapbox... Jeremy Casey jrcasey(at)ldl.net ________________________________________________________________________________
Subject: Mark 3 project sold...
Date: Dec 17, 2002
I thought I'd drop a note to let the few that know me and my little M3 project know that it will soon have a new owner. After the birth of my second child and the realization that time was now at an ultra-premium and I would be watching this child graduate high school before I finished my Kolb, I have sold it to someone that will finish it and put it to good use. I am definitely a "flyer" more than a "builder" and would rather spend the 2 or 3 hours a week that are free, flying instead of building. I have made a deal on a RANS S7 that will be my little red wagon for awhile and hope to see some of you fellas at some fly-ins soon. (Will definitely be at Sun-n-Fun) I am going to hang around on this list (if for no other reason, to see if Big Lar ever finishes his... ;-0 ) Fly safe... Jeremy Casey BCD Drafting, Inc. jrcasey(at)ldl.net ________________________________________________________________________________
Date: Dec 17, 2002
I missed what went before. What engine did you get that's so much better than the 447? kj ----- Original Message ----- From: "Jeremy Casey" <jrcasey(at)ldl.net> Subject: RE: Kolb-List: engines n uppness > > > > George, > > > > Let's be fair about this. The 447 dressed with carburetor, cooling > fan and > > shrouds, and exhaust system weighs considerable more than 65 pounds. > > > > I am pleased that someone loves Rotax engines, because this love > enabled me > > to sell my 447. I am very happy to go to a replacement engine that > weighs > > the same as the dressed 447, which includes electric starter and > battery, > > uses much less gas, puts out more power, and a muffler so quiet that I > do > > not have to turn on my ANR headset, idles below 2000 rpm without > complaint > > or vibration, and follows the throttle without hesitation and holds a > > constant rpm setting in level flight. This is progress. If the 447 > had > > acted this way, I would not have changed. > > > > Jack B. Hart FF004 > > Jackson, MO > > > > > > Jack &Louise Hart > > > Hey Jack! I never said the 447 was the ultimate engine...only that it > compared rediculessly great compared with the early aviation engines. If > > yours puts out more power at the same weight, uses less gas to do it, > uses a > better muffler (not a resonator that pulls more hp?) , idles at less > than > 2000 rpm, then I need to look into it too, provided it has a good track > > record. My 447 also follows the throttle without hesitation and holds a > constant rpm in level flight. As far as the weight is concerned, you're > > probably correct as I was just guessing from '92 when I built it and I > was > much stronger then. :-) What engine do you use on your firestar? > > George Randolph > Firestar driver from Akron, Oh > > > > One that seized very early in it's life due to some "teething" problems > with a new installation. I don't want to sound critical of Jack cause > he is an exception...by all appearances he is a guy who loves to > experiment more than fly and obviously has the technological know-how to > diagnose problems and come up with solutions and MORE IMPORTANTLY has > the time and patience to do it. Buuuuuutttttt I say this for the > "newbies" out there that are considering a project and thinking about > going against the "herd" and putting an "alternative engine" on their > planes...you WILL take considerably longer to build the plane and it > WILL take considerably longer to get it right. If you want to fly, > DON'T be a trailblazer. If you enjoy tinkering and experimenting more > than flying, then get you an alternative engine and have at it. > > Look at our list "punching bag" Big Lar...if he wasn't so darned > creative, he'd have been flying a long time ago... ;-) > > Jeremy Casey > jrcasey(at)ldl.net > > P.S. If my 503 had been any quicker to accelerate/decelerate when I > moved the throttle...it would have had to read my mind to get a head > start on me... > > ________________________________________________________________________________
Date: Dec 17, 2002
Subject: Second Chantz
John & gang. The unit I am using and have questions about has a solid fuel rocket Bob Griffin ________________________________________________________________________________
Date: Dec 17, 2002
Subject: Re: Second Chantz
> John & gang. The unit I am using and have questions about has a > solid fuel rocket > Bob Griffin Bob/Gents: Yep, I also have one, solid fuel, manufactured in 1992. It is on the sun porch in a box gathering dust. No way to do a "go/no go" test on them. Not much comfort in that. john h ________________________________________________________________________________
From: "Bill Peterson Landscape" <b1bookie(at)purenet.net>
Date: Dec 17, 2002
Airgriff2(at)aol.com writes: > > John & gang. The unit I am using and have questions about has a > solid fuel rocket > Bob Griffin > > Bob.........several months ago I reported that a friend of mine at the airport had his plane parked next to several other planes when his solid fuel rocket went off deploying the parachute. It sounded like a shot gun, and luckly no one was in the direction of deployment. This could have gone off while he was flying and would probably have killed him as the plane was a Quicksilver where the cable gets close to the prop. This was a Second Chantz. I don't know if anyone else on the list has knowledge of this happening to any one else but I wanted to imform you of the possible problem. Hope this helps........Bill > > > > Bill Peterson ________________________________________________________________________________
Date: Dec 17, 2002
Subject: Gascolator
Followed the gascolator thread from last week with interest as I am in the process of installing the fuel system on my Mk111Xtra. Was wondering how effective it would be when using a top fed system as per the Kolb plans. Any comments? Thanks Tom Sabean ________________________________________________________________________________
From: "George Murphy" <geomurphy(at)mindspring.com>
Date: Dec 17, 2002
A good friend of mine deployed a Second Chance Chute a number of years ago when his Firestar's leading edge of his wing folded up. It deployed alright but his bridal cable snapped. My friend did not have that second chance --- he died in the crash that day. Scrap it before someone tries to use it. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Airgriff2(at)aol.com Subject: Kolb-List: Re: Second Chanz Chute When Second Chanz went out of business, all the owners were sort of just hung out there without much support. What I was wondering is , am I one of only a handfull who are using their system yet ,or are there others? My MK3 was the prototype for their soft pack set up in the gap seal. John Dunham had my unit on display at Sun & Fun. I have been flying with mine since 95. Every 3 yrs I take it to a rigger, who inspects the chute and repacks it. Should I have any concern as to whether or not the rocket will work? I guess what I'm asking is, should I be relying on this older system, leave it in as a back up that "may work", or take it out and scrap it? With all the knowledge and experience of list members, I will see what your responce is and decide from there. Fly Safe Bob Griffin ________________________________________________________________________________
Date: Dec 17, 2002
> > Bob.........several months ago I reported that a friend of mine at the airport had his plane parked next to several other planes when his solid fuel rocket went off deploying the parachute. > Bill Peterson Bil/Gents: There is no way for a solid fuel rocket to ignite unless someone has tampered with it, especially if the safety pin is in the hole where it belongs. There is a simple percussion igniter that won't ignite unless the firing pin hits it. Same same the percussion cap on a bullet. Ballistic recovery systems don't fire on their on accord any more than a center fire revolver or center fire rifle. That's my opinion for what it is worth, again not much, but it is mine. :-) john h ________________________________________________________________________________
Date: Dec 17, 2002
> A good friend of mine deployed a Second Chance Chute a number of years ago > when his Firestar's leading edge of his wing folded up. Scrap it before someone tries to use it. George Murphy George/Gents: If that was Aubrey Radford, his parachute, as I understand it, was not equipped with a SS cable, but a kevlar bridal. When the canopy deployed successfully, the kevlar bridal routed itself under the end of the engine mount that still had the sharp edges when it was sheared. Kevlar is extremely tough, but sharp steel and a lot of weight create a tremendous impact on opening shock. The kevlar bridal was cut and seperated. Aubrey died in May or June 1990, two or three months after I had my second save with my Jim Handbury Hand Deployed Recovery System. This system also used a kevlar bridal which compressed the square steel wing/fuselage carry through, ripped through small steel fuselage tubes and wing structure. I also had a very similar routine when deployed from my Ultrastar, same kevlar cable used twice. Aubrey flew hard aerobatics with the assistance of aileron spades which in turn pushed the 5 main rib wing to failure. He knew about my incident, but chose to ignore the warning. I haven't, and it has been nearly 13 years ago this March. The Second Chantz recovery system uses a 3/8" SS cable for the initially which is attached to a kevlar bridal, the suspension lines and the canopy. The current BRS system is same same. If you have a recovery system, train yourself to use it. When the time comes, don't forget you have it. There will be no time to sit and think about what to do next. Ask Dallas Sheppard. It gets real busy real quick up there in those situations. The above is the best I can remember. If I am wrong, please correct me. john h ________________________________________________________________________________
Date: Dec 17, 2002
There is no way for a solid fuel rocket to ignite unless someone has tampered with it, especially if the safety pin is in the hole where it belongs. There is a simple percussion igniter that won't ignite unless the firing pin hits it. Same same the percussion cap on a bullet. Ballistic recovery systems don't fire on their on accord any more than a center fire revolver or center fire rifle I had one of the first BRS systems back in 83. it was electrically fired, not a firing pin type,and blasted out a slug whoose inertia pulled out the chute. I know of one unintentional deployment, which resulted in the slug being sent through a table, a persons thigh and calf and off the floor. my system was replaced with a modified version free of charge shortly after that, and then they came out with the solid rocket version. the old slug versions were never a good idea by comparison, and the electrically fired system was just plan dangerous. topher ________________________________________________________________________________
From: "Richard Swiderski" <swiderski@advanced-connect.net>
Date: Dec 17, 2002
----- Original Message ----- From: "John Hauck" <jhauck(at)sw.rr.com> > > John & gang. The unit I am using and have questions about has a > > solid fuel rocket > > Bob Griffin > > Bob/Gents: > > Yep, I also have one, solid fuel, manufactured in > 1992. It is on the sun porch in a box gathering > dust. > > No way to do a "go/no go" test on them. Not much > comfort in that. > > john h > > I was told by a vendor that tha rocket motors have a virtually 100% fire rate even after sitting for years past the expiration date on a barn shelf. Personally, I can not verify a single motor mafunctionaing. They were built by the military to operate in to scenarios. Anyone elses hear this talk? Richard Swiderski ________________________________________________________________________________
Date: Dec 17, 2002
the old slug > versions were never a good idea by comparison, and the electrically fired > system was just plan dangerous. > > topher topher/Gents: Don't remember the electrically fired systems. I didn't get interested in ULs until about Aug 1983. Could not afford a ballistic recovery system back then. Hard to believe that folks actually marketed a system with electrical firing system. Imagine they were also susceptible to stray radio transmissions, even high powered spark ignitions. Extremely dangerous. john h ________________________________________________________________________________
Date: Dec 17, 2002
Subject: Re: Gascolator
In a message dated 12/17/02 8:40:05 PM, sabean(at)ns.sympatico.ca writes: Followed the gascolator thread from last week with interest as I am in the process of installing the fuel system on my Mk111Xtra. Was wondering how effective it would be when using a top fed system as per the Kolb plans. Any comments? Thanks Tom Sabean>> The only problem is that one can never get anything drained from the bottom of the tank if the pickup is not on the very bottom. I used the original method from the bottom with gromits and also added a gascolator which is below the tanks. This way the tank always drains from the very bottom and then goes into the gascolator which I drain with a curtis drain valve from the bottom. Gets rid of any water. Tim ________________________________________________________________________________
Date: Dec 17, 2002
Why would it make any difference? The purpose of a gascolator is to give the heavier water a place to settle and let the lighter gas continue on down the pipe. The ideal place for a gascolator is the lowest point on the fuel line between the tank and the carb (per Tony Bingelis) but anyplace to let the water drop out is probably going to help. Richard Pike MKIII N420P (420ldPoops) > >Followed the gascolator thread from last week with interest as I am in >the process of installing the fuel system on my Mk111Xtra. Was wondering >how effective it would be when using a top fed system as per the Kolb >plans. >Any comments? > >Thanks >Tom Sabean > > ________________________________________________________________________________
Date: Dec 17, 2002
><swiderski@advanced-connect.net> > > > > > I was told by a vendor that tha rocket motors have a virtually 100% fire >rate even after sitting for years past the expiration date on a barn shelf. >Personally, I can not verify a single motor mafunctionaing. They were built >by the military to operate in to scenarios. Anyone elses hear this talk? > >Richard Swiderski I fired one that was about 6 years old and had been sitting in a lake for 24 hours - just to see what would happen. It worked fine - BRS. ________________________________________________________________________________
Subject: Re: Mark 3 project sold...
Date: Dec 17, 2002
Hafta agree with you.............I'm about built out & would rather be flying, but gotta finish now. Maybe I'll catch up with a few more of you guys this year. SnF is a definite "For Sure." Do not Archive. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose www.gogittum.com ----- Original Message ----- From: "Jeremy Casey" <jrcasey(at)ldl.net> Subject: Kolb-List: Mark 3 project sold... > > I thought I'd drop a note to let the few that know me and my little M3 > project know that it will soon have a new owner. After the birth of my > second child and the realization that time was now at an ultra-premium ________________________________________________________________________________
Date: Dec 17, 2002
> > topher/Gents: > > Don't remember the electrically fired systems. I > didn't get interested in ULs until about Aug > 1983. Could not afford a ballistic recovery > system back then. > > Hard to believe that folks actually marketed a > system with electrical firing system. Imagine > they were also susceptible to stray radio > transmissions, even high powered spark ignitions. > Extremely dangerous. > > john h John and others, Many of the early ones had electronic detonation and had a tendency to detonate with static electricity. Ralph ________________________________________________________________________________
Date: Dec 18, 2002
Subject: Re: Cable connector
In a message dated 12/17/02 10:51:04 PM Eastern Standard Time, Timandjan(at)aol.com writes: > I am building a heater box and need to afffix a push pull tube. What would > work perfect for me is the little u channel piece the Firestar uses to > attach > the throttle cable to the throttle lever. The small piece that has a set > screw uses to clamp down into the cable. > > Anybody have a extra one of these of know where I can get one?? > > From The New Kolb. Also, I was in a go-cart shop yesterday & they had some. Shack FS II SC ________________________________________________________________________________
Date: Dec 18, 2002
Ralph, Was there some kind of toggle or botton to set off the chutes with the electronic detonation system or did it have a regular "T" type handle with a safty pin like the percussion ignition ones? If they both look alike, how do you tell which one you have? Hope that is not a stupid question but I have only seen one type of these ( the one I own). Steve ________________________________________________________________________________
Subject: Rambling on
Date: Dec 18, 2002
Kolbers, There is a lot of money in Aviation...I know ...I put it there ! I have to agree with the thinking that changing to a different engine is a monumental problem compared to something tried and true. Been there not only with experimentals but standard category and restricted category types. I salute you all but I have a theory that I never buy anything unless it's 5 years on the market with a good track record.....keeps me from being a "test" pilot. If every body did what I believe we would all be waiting for the wheel to be invented. And that brings me to my project , the old Ultrastar relic { 18 years old} I have begun rebuilding.....I will give you an update ..... I know some of you are soured (understatement of the year} on the Cuyuna engines but I have found a good engine ,reduction ,propellar combination for the US.... 2SI makes a 2.5 to 1 cog belt drive {reasonably priced} that fits the old UL 202 as well as the new 2SI engines... mate this with the 3 blade 50 inch diameter Warp Drive ground adjustable and you get a good performing combo that eliminates all the resonant vibes and gearbox clatter at lower rpm's. So far it has run on a previously owned US about 100 hours with no problems. I don't have any problems with making an airframe change as long as it is well thought out and I don't use much SWAG ( scientific wild-ass guessing}. The only thing I am changing is the landing gear and the fuselage forward of the back of the seat. I already made a centerline stick with firefly type front end that flew well. There is a picture in the archives if anybody is interested...it was taken before the switch to the cog belt and 3 blade prop. I am planning on changing the gear to fiberglass legs with steel sockets and getting a bit more ground clearance although the last US was OK with the stock gear but with 600x8 tires. I hope to be flying by late spring with 2 other Ultrastars in the area .A new guy to the list just contacted me and has a US that was delivered by Homer...You out there AL ? Ed in Western NY ________________________________________________________________________________
Subject: Michigan trip
Date: Dec 18, 2002
I will be going to Oak Park, right outside of Detroit, over the holidays. Any Kolbs nearby or interesting ultralight airports I could visit while there? Jim Mark III Charlotte, NC ________________________________________________________________________________
Date: Dec 18, 2002
Forgot to ask who manufactured your electric system? john h that was the first thing that BRS came out with. Very quickly they went to the mechanical system. ________________________________________________________________________________
Subject: Re: gascolators message of Tue, 17 Dec 2002 23:56:27
-0800
Date: Dec 18, 2002
The gascolator actively removes the water and other junk from the fuel as it goes past on the way to the carb. so it makes no differance where you draw from, or even if the gascolator is the lowest part of the system, the gascolator bowl is the low part of the gascolator and the water stops there. if it is the low part of the system then the water can get there as it settles out of the gas, which is a good idea and so that is how you should build the system. if you have enough water in the fuel to completely fill the gascolator bowl then the water will continue on to the carb, so a bigger bowl is better. you drain the gascolator of contaminates and water before each flight so you would have to have one big load of water to fill it up. the new water separating filters also work extreamly well, and prevent any possibility of water getting to the carb. they cost 150 and are probably worth it if you leave your plane out in the rain. Topher ________________________________________________________________________________
Date: Dec 18, 2002
-----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of SR3SA2L1(at)aol.com Subject: Re: Kolb-List: Second Chantz Ralph, Was there some kind of toggle or botton to set off the chutes with the electronic detonation system or did it have a regular "T" type handle with a safty pin like the percussion ignition ones? If they both look alike, how do you tell which one you have? Hope that is not a stupid question but I have only seen one type of these ( the one I own). Steve on the BRS there was a little black box with batteries and some LEDs and a button to press to test the system. the fire handle was a t-handle but it simply pulled a mini headset type plug out of a jack, breaking a circuit that fired the system. The instructions said to treat it like a loaded gun at all times, and we did, it scared the crap out of me to press the test button. topher ________________________________________________________________________________
Subject: covering
Date: Dec 18, 2002
From Woody's quote: "I did mine a bit different from the book. I attached the hinges permanently first and then when I covered I put little slots in the fabric where the hinge ears stick out. I think it looks a lot better than sticking the hinges on the outside of the fabric. It is a fast and simple operation to make those little slits as long as you have a new blade in your cutting knife. You will probably change the fabric before the hinges " This sounds good. Any problem with checking the security of the rivets/hinges on your pre-flight with this configuration? Thanks, Clay Stuart Mark IIIXtra S/N21 ________________________________________________________________________________
Subject: gascolator vs top-fed tanks
Date: Dec 18, 2002
12/18/2002 01:02:31 PM >From: tom sabean <sabean(at)ns.sympatico.ca> >Subject: Kolb-List: Gascolator >Followed the gascolator thread from last week with interest as I am in >the process of installing the fuel system on my Mk111Xtra. Was wondering >how effective it would be when using a top fed system as per the Kolb >plans. >Any comments? >Thanks >Tom Sabean Tom, if you are talking about the stock Kolb top fed solution as I built it per the plans, with the fuel fittings drilled thru holes in the TOP OF THE TANKS, and dip tubes running down into the fuel, I will give you an opinion. The above stock solution routes the dip tibes to within 1/2 to 3/4 inch from the bottom of the tanks, giving you a water trap of about a half gallon total in the bottom of the two tanks. This initially works quite well (higher capacity for water than any gascolator) to keep the fuel to the carbs free of the seperated water. However, sooner or later you will want to get the suspected water off the bottom of the tanks. To clean the tank bottoms of the inevitable water and crud, make yourself a "vacuum" from a squeeze primer, some 6-8 feet of fuel hose, and a 2 foot pc of copper tube or similar on the suction end. When the tanks are low anyway (for visibility reasons), stick the copper dip tube into the tank thru the fill cap hole and pump the squeeze primer till fuel flows out, routing it to a gas can. If you can see down into the tank, look in there and steer the copper dip tube around to each corner, collecting the crud and sediment, all the while you will be collecting water even if you can't see it. Do both tanks, taking out a gallon or so. Now you are water free. Do this every few fill-ups. Use the fuel you remove in your car or lawn mower. If you had also installed a gascolator, water removal from the gascolator would be easy and quick, simply open the valve and examine the contents. BUT you would still have some unknown quantity of water possibly collecting in the bottom of your tanks, unless you use the dangling pickup screens on the ends of your dip tubes. Using these danglers or any tank pickup which comes off the bottom of the tank instead of the top practically ensures you will be able to pick up the water off the bottom of the tanks, so it requires a gascolator. Your choice. I don't run a seperate gascolator, I use the tanks as described above, top mounted pickup tubes 3/4 inch from bottom, vacuum clean every few tanks. I fly in Minnesota, very high humidity. Have not had any problems. Jim Gerken ________________________________________________________________________________
Date: Dec 18, 2002
> > Ralph, > > Was there some kind of toggle or botton to set off the chutes with > the > electronic detonation system or did it have a regular "T" type > handle with a > safty pin like the percussion ignition ones? If they both look > alike, how do > you tell which one you have? Hope that is not a stupid question but > I have > only seen one type of these ( the one I own). > > Steve Steve, I'm almost positive the electronic firing parachutes had the T-handle. I'm not an expert on this so you might ask the BRS people about it. Ralph Original Firestar ________________________________________________________________________________
Subject: Re: covering
Date: Dec 18, 2002
> -- Kolb-List message posted by: "Clay Stuart" tcstuart(at)adelphia.net > > From Woody's quote: > > "I did mine a bit different from the book. I attached the hinges > permanently first and then when I covered I put little slots in the fabric > where the hinge ears stick out. I think it looks a lot better than sticking > the hinges on the outside of the fabric. It is a fast and simple operation > to make those little slits as long as you have a new blade in your cutting > knife. You will probably change the fabric before the hinges " > Sounds like a good idea. I would think that it would also re-enforce the hinges and give the rivets a bit more protection from the elements. ________________________________________________________________________________
Date: Dec 18, 2002
Subject: Re: 912S Complete engine package for Kolb
John Russell wrote: > > I have a Kolb SlingShot that I have considered parting out in units. > > Engine package would include-912S with 126 hours, Titan stainless exhaust, > 4" custom prop > extention with 3 blade 72" warp prop and spinner, rotax oil cooler and > coolant radiater, all throttle and choke cables, EIS with harness with > remote switches, basically everything needed in an installation on a Kolb. > > BRS top mount cannister, I will need to check on ratings, 2 years old. > > Complete airframe, beautifully built and never damaged, aerothane finish, > tundra tired, matco brakes, 6" swivel tail wheel. > > Every thing is in excellent shape and well maintained. > > If by chance there is an interest you can contact me off list at > jr(at)rometool.com > Tell me more about the airframe and send some pics if possible.......... ________________________________________________________________________________
Date: Dec 18, 2002
From: "Gary robert voigt" <johndeereantique(at)qwest.net>
When i went to BRS about a year ago i had a system that needed a repack, update to the new model 5 and a repack... i asked them if i could use the old rocket and just go with the repack and update but they said the rocket might not work being it was out of date and old.... they told me when they design rocket fuel they can manufacture it to become stable or unstable for x number of years....if you want a rocket to last 25 years or so you just add a certain ingredient to do so....although they mentioned it would cost thousands more so it would not be practical to do so in this market. yes i was in sales too and they get you one way or another.... they got me for $1469.00 for the repack,update and new rocket....and a little piece of mind...and i would pay anything for that. Gary r. voigt p.s. the lakes were frozen and now are melting and the grass greened up a little today because of the rain. Richard Swiderski wrote: > > ----- Original Message ----- > From: "John Hauck" <jhauck(at)sw.rr.com> > > > John & gang. The unit I am using and have questions about has a > > > solid fuel rocket > > > Bob Griffin > > > > Bob/Gents: > > > > Yep, I also have one, solid fuel, manufactured in > > 1992. It is on the sun porch in a box gathering > > dust. > > > > No way to do a "go/no go" test on them. Not much > > comfort in that. > > > > john h > > > > I was told by a vendor that tha rocket motors have a virtually 100% fire > rate even after sitting for years past the expiration date on a barn shelf. > Personally, I can not verify a single motor mafunctionaing. They were built > by the military to operate in to scenarios. Anyone elses hear this talk? > > Richard Swiderski > ________________________________________________________________________________
Date: Dec 18, 2002
Gary, I did 9 takeoffs and landings out on Cooks Bay this year so far. The ice will be good in January, don't worry. Winter is not over yet. Ralph writes: > > > When i went to BRS about a year ago i had a system that needed > a repack, update to > the new model 5 and a repack... i asked them if i could use the old > rocket and just go > with the repack and update but they said the rocket might not work > being it was out of > date and old.... they told me when they design rocket fuel they can > manufacture it to > become stable or unstable for x number of years....if you want a > rocket to last 25 years > or so you just add a certain ingredient to do so....although they > mentioned it would > cost thousands more so it would not be practical to do so in this > market. yes i was in > sales too and they get you one way or another.... they got me for > $1469.00 for the > repack,update and new rocket....and a little piece of mind...and i > would pay anything for > that. > > Gary r. voigt > p.s. the lakes were frozen and now are melting and the grass > greened up a little > today because of the rain. > > Richard Swiderski wrote: > > <swiderski@advanced-connect.net> > > > > ----- Original Message ----- > > From: "John Hauck" <jhauck(at)sw.rr.com> > > > > John & gang. The unit I am using and have questions > about has a > > > > solid fuel rocket > > > > Bob Griffin > > > > > > Bob/Gents: > > > > > > Yep, I also have one, solid fuel, manufactured in > > > 1992. It is on the sun porch in a box gathering > > > dust. > > > > > > No way to do a "go/no go" test on them. Not much > > > comfort in that. > > > > > > john h > > > > > > I was told by a vendor that tha rocket motors have a virtually > 100% fire > > rate even after sitting for years past the expiration date on a > barn shelf. > > Personally, I can not verify a single motor mafunctionaing. They > were built > > by the military to operate in to scenarios. Anyone elses hear this > talk? > > > > Richard Swiderski > > > > > > _-> > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2002
> Interesting that your hinge rivets have loosened. Snuffy > > For some reason, maybe just my airplanes, but > > occassionally a pop rivet head will seperate on > > the hinges, sometimes I get them on the upper > > vertical stabilizer attachments too. > > john h Snuf/Gang: I didn't say my hinge rivets have loosened. I said "occasssionally a pop rivet head will seperate", i.e., pop off, leaving the stem behind. Guess it could be caused by a number of things, but is not a serious problem. Now, if a hand full of them popped their heads at one time, yep, I would start getting concerned. Only place that I can think of that had lose rivets was lower portion of bottom rudder hinge. I keep a check on those. john h ________________________________________________________________________________
Date: Dec 19, 2002
Subject: Rotax 447 - Victor 1+ Comparison
I have received several requests for information about the Victor 1+ and how it stacks up against the Rotax 447. So I put together a comparison list. It can be found at: http://www.thirdshift.com/jack/firefly/victor_fuel.html In my quest to find a better engine, I visited the local 2 cycle engine guru who sets up motorcycle engines for racing to get a short course on the characteristics of piston port and reed valve induction engines. I was told that reed valve engines, were more economical, idle better, do not load up and are eager to run, and in more general would be more civil than a piston ported engine. Everything the guru told me has been true when it comes to comparing the Victor 1+ with the Rotax 447. The only unanswered question is, is it going to holdup for the long term, and with that I will just have to wait and see. No flying today. A few days ago we were in deep snow, then very high winds, and today it is water. Have a good Holiday! Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Dec 18, 2002
A > > I am building a heater box and need to afffix a push pull tube. What would > > work perfect for me is the little u channel piece the Firestar uses to > > attach I bit of square key stock a hacksaw and some small drills and taps should get you what you want. Or do it the easy way and call Kolb ________________________________________________________________________________
Date: Dec 18, 2002
Back in the eighties a Canadian company called Niagara had a remote deployed chute that had a spring powered drogue chute. Never had to worry about rockets with them. Did not have the same penetrating power as a rocket but they still pulled the chute out okay. I always thought the electrically fired rockets were like an Estes Rocket with a hot wire inside them for ignition. ________________________________________________________________________________
Subject: List test
Date: Dec 20, 2002
Is the list down? I have not got a neww message since mid-day thursday. Denny ________________________________________________________________________________
Date: Dec 19, 2002
Subject: Re: Michigan trip
If you want to cross the river you can visit me and see my "slightly modified" mk111 and a stock Mk111 side by side. Staying on the American side you will find a mk111 -x and a mk11. > >I will be going to Oak Park, right outside of Detroit, over the holidays. >Any Kolbs nearby or interesting ultralight airports I could visit while there? > >Jim >Mark III >Charlotte, NC > > ________________________________________________________________________________
Date: Dec 20, 2002
>Have you ever covered the wing and attached hinges >per the instructions? If not, you ought to try >it. Personally, I think that is the way I do it. I have built or helped build 6 kolbs Recovered or repaired a few more and covered the wings of 3 as per instructions. I like my new way of doing it. Of course that is all personal preference. >. If the rivet >is conveniently covered up, you won't know it. >Maybe that is no big deal for some, but I just as >soon drill them out and replace. I don't know if any of the heads of the rivets holding the ribs on the spars have popped off now or not. There is no way to check that either. Do the math and you will find there are a lot more rivets used that engineering specs would call for. >I also know from practical experience on a lot of >Kolb wings, mine, that I have covered and >recovered, it is extremely difficult to get slit >fits to look anywhere neat enough (for me anyhow) >or for most aircraft judges. The slit fit I am >talking about is the one around the lift strut >tang. Might be even harder to do correctly on all >those hinges. For that tang I usually cut a circle about 5" dia and slit the center. Not actually a slit , more of a long narrow hole that the tang will fit through. Lots of glue and it seems to stay put. After the hinge slits are cut and shrunk I usually take a match and burn off any loose threads. caution is needed at this stage. ________________________________________________________________________________
Date: Dec 21, 2002
Subject: Gascolator
To all the listers who commented on the gascolator issue, many thanks for the insights. I will definitely install one plus make sure I use the squeeze primer method to clean the bottom of the tanks periodically. Thanks, Tom Sabean dna ________________________________________________________________________________
Date: Dec 21, 2002
Subject: Headset question
I have a Telex headset that I bought several years back which looks bad but seems to work the best. When I use this one in my system ( PTT switch on my Icom handheld radio) it works great in the kolb. I can also hear myself in the headset when I transmit. When I use my brand new Sigtronics headset I can;t hear myself in the headest when I trensmit. I have a third Pilot headset that I also can't hear my voice. I believe all three mics work because I have tested them by using them in my portable intercom system. Any body have any ideas why the 2 don't seem to work? Should'ne I be able to hear my own voice in each headset as I transmit? My set up is a Icom handheld with a standard PTT that I cut off the switch and added a small switch to the end of the stick. Works awsom with my Telex so I know it works fine. Thanks Tim ________________________________________________________________________________
Date: Dec 21, 2002
Subject: Re: Headset question
> Try increasing the sidetone volume on the radio. Hold "Talk" and push the "up" > arrow on the radio (check your manual). > Ken Ken/Gang: Do you know if that will work on an ICOM A3? Also, does anyone know how to increas volume above and beyond what it is capable of with the volume knob? The older I get the deafer I get, or the deafer I get the older I get. Anyhow, I have difficulty at times hearing radio traffic. Usually, towers and most aircraft are loud enough, but sometimes individual radios do not put out enough volume for me to understand what they are saying. john h ________________________________________________________________________________
Date: Dec 22, 2002
Oh yeah ... if you want to call me try 519978 0926 I should be home most of the holidays. There is also an original Twinstar for your viewing pleasure. If you want to cross the river you can visit me and see my "slightly modified" mk111 and a stock Mk111 side by side. Staying on the American side you will find a mk111 -x and a mk11. ________________________________________________________________________________
Subject: no mail
Date: Dec 23, 2002
Where did everyone go? ________________________________________________________________________________
Subject: Re: no mail
Date: Dec 23, 2002
Hi Richard, They must be shopping. I know if you live in the deep south your not flying unless your John Hauck. Later, John Cooley ----- Original Message ----- From: "Richard Harris" <rharris@magnolia-net.com> Subject: Kolb-List: no mail <rharris@magnolia-net.com> > > Where did everyone go? > > ________________________________________________________________________________
Date: Dec 23, 2002
Subject: no mail
No progress on der Kolb? Me neither, not even a trip to Ace Aircraft Supply. A mediocre performance at my senior bowling league my only venture out. I'm still looking for a really nice coolant recovery tank, someone on the Geo list suggested a bicycle water tank. After watching the news about that Predator unmanned plane going down (1500 lbs/85mph) I got to wondering why the military couldn't save a few $mil by adapting one of the better off-the-shelf ultralights or kit planes to do the same job? -BB do not archive ________________________________________________________________________________
Subject: a funny
Date: Dec 23, 2002
It's slow and not much chat so I decided to insert some funny stuff to cheer up the list folks... hope ya find em amusing! Happy Holidays...... pp....... ________________________________________________________________________________
Subject: santa
Date: Dec 23, 2002
Hang in there folks...... better weather ahead Happy Holidays pp.. Santa Claus, like all pilots, gets regular visits from the Federal Aviation Administration, and the FAA examiner arrived last week for the pre-Christmas flight check. In preparation, Santa had the elves wash the sled and bathe all the reindeer. Santa got his logbook out and made sure all his paperwork was in order. He knew they would examine all his equipment and truly put his flying skills to the test. The examiner walked slowly around the sled. He checked the reindeer harnesses, the landing gear, even Rudolf's nose. He painstakingly reviewed Santa's weight and balance calculations for sled's enormous payload. Finally, they were ready for the checkride. Santa got in and fastened his seatbelt and shoulder harness and checked the compass. Then the examiner hopped in carrying, to Santa's surprise, a shotgun. "What's that for?!?" asked Santa incredulously. The examiner winked and said, "I'm not supposed to tell you this ahead of time," as he leaned over to whisper in Santa's ear, "but you're gonna lose an engine on takeoff." ________________________________________________________________________________
Subject: Better weather
Date: Dec 23, 2002
I thought I was being picked on up here in the NE the way the weather's been. Sounds like most of the country is having similarly poor flying conditions. According to our local forecast, tomorrow is looking like "a good day to fly." We're supposed to have winds -under- 5mph the entire day. Unfortunately, the temperature isn't going to be much higher. Actually, it's going to soar into the upper 20's! Whoo hoo! Anyway, I'm going to get as much time in tomorrow as I can stand. Who knows when the weather is likely to break again? The forecast has snow and gale force winds ripping right back in on Christmas morning. Wish me luck, and Happy Holidays! -Ken Fackler Mark II / 503 Rochester MI ________________________________________________________________________________
Date: Dec 23, 2002
Subject: Re: santa
Thanks Paul. I needed that laugh more than you know. Do not archieve ________________________________________________________________________________
Date: Dec 24, 2002
No new photos posted in 15 days ? I guess everyone is overwelmed with the holidays ? Merry Christmas to all on the "list" & hope you have a great new year! Fly Safe Bob Griffin ________________________________________________________________________________
Subject: fire extinguishers
Date: Dec 24, 2002
Kolbers, Anyone have any suggestions on a good source for an affordable fire extinguisher for my Mark-3. I want a good one, and a good price if possible. Merry Christmas to all, Denny Rowe ________________________________________________________________________________
Subject: Dennis Souder
Date: Dec 24, 2002
Guys, I need to contact Homer or Dennis Souder, does anyone have their phone number? Dennis Rowe ________________________________________________________________________________
Date: Dec 24, 2002
Subject: Re: Better weather
Ken, 20 degrees F is looking good here in mn. i fly in this all the time with a short winshield and even 10 to 15 F sometimes... just gotta dress warm. i'am going to a full enclosure soon. HAPPY HOLIDAYS!!! Gary r. voigt "Fackler, Ken" wrote: > > I thought I was being picked on up here in the NE the way the weather's > been. Sounds like most of the country is having similarly poor flying > conditions. > > According to our local forecast, tomorrow is looking like "a good day to > fly." We're supposed to have winds -under- 5mph the entire day. > Unfortunately, the temperature isn't going to be much higher. Actually, it's > going to soar into the upper 20's! Whoo hoo! Anyway, I'm going to get as > much time in tomorrow as I can stand. Who knows when the weather is likely > to break again? The forecast has snow and gale force winds ripping right > back in on Christmas morning. > > Wish me luck, and Happy Holidays! > > -Ken Fackler > Mark II / 503 > Rochester MI > ________________________________________________________________________________
Date: Dec 24, 2002
Subject: Re: fire extinguishers
12/24/02 6:02rowedl(at)highstream.net > Anyone have any suggestions on a good source for an affordable fire > extinguisher for my Mark-3. I want a good one, and a good price if possible. ========================== Any Halon extinguisher would work. the one in my airplane is from Sutherland, a knock off of the Home Depot. Just make sure its Halon and you'd be alright. ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Subject: The Night Before Christmas
Date: Dec 24, 2002
The Night Before Christmas - Aviation Style =============================================== 'Twas the night before Christmas, and out on the ramp, Not an airplane was stirring, not even a Champ. The aircraft were fastened to tiedowns with care, In hopes that come morning, they all would be there. The fuel trucks were nestled, all snug in their spots, With gusts from two-forty at 39 knots. I slumped at the fuel desk, now finally caught up, And settled down comfortably, resting my butt. When the radio lit up with noise and with chatter, I turned up the scanner to see what was the matter. A voice clearly heard over static and snow, Called for clearance to land at the airport below. He barked his transmission so lively and quick, I'd have sworn that the call sign he used was "St. Nick". I ran to the panel to turn up the lights, The better to welcome this magical flight. He called his position, no room for denial, "St. Nicholas One, turnin' left onto final." And what to my wondering eyes should appear, But a Rutan-built sleigh, with eight Rotax Reindeer! With vectors to final, down the glideslope he came, As he passed all fixes, he called them by name: "Now Ringo! Now Tolga! Now Trini and Bacun! On Comet! On Cupid!" What pills was he takin'? While controllers were sittin', and scratchin' their head, They phoned to my office, and I heard it with dread, The message they left was both urgent and dour: "When Santa pulls in, have him please call the tower." He landed like silk, with the sled runners sparking, Then I heard "Left at Charlie," and "Taxi to parking." He slowed to a taxi, turned off of three-oh And stopped on the ramp with a "Ho, ho-ho-ho..." He stepped out of the sleigh, but before he could talk, I ran out to meet him with my best set of chocks. His red helmet and goggles were covered with frost And his beard was all blackened from Reindeer exhaust. His breath smelled like peppermint, gone slightly stale, And he puffed on a pipe, but he didn't inhale. His cheeks were all rosy and jiggled like jelly, His boots were as black as a cropduster's belly. He was chubby and plump, in his suit of bright red, And he asked me to "fill it, with hundred low-lead." He came dashing in from the snow-covered pump, I knew he was anxious for drainin' the sump. I spoke not a word, but went straight to my work, And I filled up the sleigh, but I spilled like a jerk. He came out of the restroom, and sighed in relief, Then he picked up a phone for a Flight Service brief. And I thought as he silently scribed in his log, These reindeer could land in an eighth-mile fog. He completed his pre-flight, from the front to the rear, Then he put on his headset, and I heard him yell, "Clear!" And laying a finger on his push-to-talk, He called up the tower for clearance and squawk. "Take taxiway Charlie, the southbound direction, Turn right three-two-zero at pilot's discretion" He sped down the runway, the best of the best, "Your traffic's a Grumman, inbound from the west." Then I heard him proclaim, as he climbed thru the night, "Merry Christmas to all! I have traffic in sight." MERRY CHRISTMAS TO ALL ________________________________________________________________________________
Subject: the other funny
Date: Dec 24, 2002
This is the one that did'nt make it enjoy Happy Holidays > hillbilly went hunting one day in Oklahoma and > bagged three ducks. He > > put them in the bed of his pickup truck and was > about to drive home when > > he was confronted by an ornery game warden who > didn't like hillbillies. > > The game warden ordered to the hillbilly to > show his hunting license, and > > the hillbilly pulled out a valid Oklahoma > hunting license. > > > The game warden looked at the license, then > reached over and picked up > > one of the ducks, sniffed its butt, and said > > "This duck ain't from Oklahoma. This is a > Kansas duck. You got a > > Kansas huntin' license, boy?" The hillbilly > reached into his wallet and > > produced a Kansas hunting license. The game > warden looked at it, then > > reached over and grabbed the second duck, > sniffed its butt, and said > > "This ain't no Kansas duck. This duck's from > Arkansas. You got a > > Arkansas license?" The hillbilly reached into > his wallet and produced an > > Arkansas hunting license. The warden then > reached over and picked up the > > third duck, sniffed its butt, and said This > ain't no Arkansas duck. This > > here duck's from South Carolina. You got a > South Carolina huntin' > > license?" > > > Again the hillbilly reached into his wallet and > brought out a South > > Carolina hunting license. The game warden was > extremely frustrated at > > this point, and he yelled at the hillbilly > "Just where the hell are you > > from?" The hillbilly turned around, bent over, > dropped his pants, and > > said > > "You tell me, Your the expert." ________________________________________________________________________________
Date: Dec 24, 2002
Subject: MERRY CHRISTMAS KOLB LIST!!!
MERRY CHRISTMAS EVERYONE!!! Hope you get everything you are wishing for this season. even the non-kolb owners who lurk the list like i did a few years ago...maybe you will find a new kit under the tree this year. and most of all lets thank the lord for our health and pray for those who are less fortunate than us and become healthy soon. if we don't have our health we have nothing. God bless and have a safe CHRISTMAS!!! Gary r. voigt Excelsior, mn. ________________________________________________________________________________
Date: Dec 24, 2002
Subject: Re: The Night Before Christmas
Ed, i loved it. Gary r. voigt Ed Chmielewski wrote: > > The Night Before Christmas - Aviation Style > =============================================== > > 'Twas the night before Christmas, and out on the ramp, > Not an airplane was stirring, not even a Champ. > The aircraft were fastened to tiedowns with care, > In hopes that come morning, they all would be there. > > The fuel trucks were nestled, all snug in their spots, > With gusts from two-forty at 39 knots. > I slumped at the fuel desk, now finally caught up, > And settled down comfortably, resting my butt. > > When the radio lit up with noise and with chatter, > I turned up the scanner to see what was the matter. > A voice clearly heard over static and snow, > Called for clearance to land at the airport below. > > He barked his transmission so lively and quick, > I'd have sworn that the call sign he used was "St. Nick". > I ran to the panel to turn up the lights, > The better to welcome this magical flight. > > He called his position, no room for denial, > "St. Nicholas One, turnin' left onto final." > And what to my wondering eyes should appear, > But a Rutan-built sleigh, with eight Rotax Reindeer! > > With vectors to final, down the glideslope he came, > As he passed all fixes, he called them by name: > "Now Ringo! Now Tolga! Now Trini and Bacun! > On Comet! On Cupid!" What pills was he takin'? > > While controllers were sittin', and scratchin' their head, They phoned > to > my office, and I heard it with dread, The message they left was both > urgent > and dour: "When Santa pulls in, have him please call the tower." > > He landed like silk, with the sled runners sparking, > Then I heard "Left at Charlie," and "Taxi to parking." > He slowed to a taxi, turned off of three-oh > And stopped on the ramp with a "Ho, ho-ho-ho..." > > He stepped out of the sleigh, but before he could talk, > I ran out to meet him with my best set of chocks. > His red helmet and goggles were covered with frost > And his beard was all blackened from Reindeer exhaust. > > His breath smelled like peppermint, gone slightly stale, > And he puffed on a pipe, but he didn't inhale. > His cheeks were all rosy and jiggled like jelly, > His boots were as black as a cropduster's belly. > > He was chubby and plump, in his suit of bright red, > And he asked me to "fill it, with hundred low-lead." > He came dashing in from the snow-covered pump, > I knew he was anxious for drainin' the sump. > > I spoke not a word, but went straight to my work, > And I filled up the sleigh, but I spilled like a jerk. > He came out of the restroom, and sighed in relief, > Then he picked up a phone for a Flight Service brief. > > And I thought as he silently scribed in his log, > These reindeer could land in an eighth-mile fog. > He completed his pre-flight, from the front to the rear, > Then he put on his headset, and I heard him yell, "Clear!" > > And laying a finger on his push-to-talk, > He called up the tower for clearance and squawk. > "Take taxiway Charlie, the southbound direction, > Turn right three-two-zero at pilot's discretion" > > He sped down the runway, the best of the best, > "Your traffic's a Grumman, inbound from the west." > Then I heard him proclaim, as he climbed thru the night, "Merry > Christmas > to all! I have traffic in sight." > > MERRY CHRISTMAS TO ALL > ________________________________________________________________________________
Date: Dec 24, 2002
Hey all you "Easterners" (that would be anyone who lives east of California), perhaps you are not aware of the latest NASA research that shows a little typhoon in Florida is the least of your concerns! When "The BIG One" (earthquake to you "Easterners") hits in California, the state is of California is not going to slide into the Pacific - everything east of the Sierras are going to slide into the Atlantic. We are going to be an island out here, but don't worry, I'll try and call you to give you all enough time to get the Kolb into the air. Carry extra fuel on board. Fly west. If the big one hits on the 25th, look out for UFO with one red stobe mounted on the nose cone of the leading tractor mounted power unit. FAA is looking for him about the improper lighting and "other matters". If you see him in flight tell him he doesn't have to worry though because they said they are from the FAA and they are here to "help" him. Merry Ho Ho to all! Steve ________________________________________________________________________________
Date: Dec 24, 2002
Subject: Test
>Sent: Saturday, December 07, 2002 2:05 AM >Subject: Fw: Eye Test for Pilots > >EyeTestf.gif > > >Pilot's Eye Test > >This is very difficult test. It is a test given to Airline Pilots >to see how observant they are in order to pass their FAA Medical. >Follow the directions carefully and take your time. >See if you are as good as our top airline pilots. > > >FIND THE DIFFERENCES BETWEEN THE TWO PICTURES > >There are seven differences between the two photographs, >the second of which has been very cleverly touched up... > >Take a look at the first and memorize it - > >Then look at the second... you'll be surprised at how difficult it is to >find them all... >Good luck... Go slow and study the first one before going on! > > >EyeTestf.jpg > > >Now look at the second photo and find the differences. > > >EyeTestf1.jpg > > >Hope you passed !!! > > ________________________________________________________________________________
Date: Dec 24, 2002
Gary, Where are you, and why are you still THERE??? Richard Harris MK3 N912RH Lewisville, Arkansas ----- Original Message ----- From: "Gary robert voigt" <johndeereantique(at)qwest.net> Subject: Re: Kolb-List: Better weather > > Ken, 20 degrees F is looking good here in mn. i fly in this all the time > with a short winshield and even 10 to 15 F sometimes... just gotta dress warm. > i'am going to a full enclosure soon. > > HAPPY HOLIDAYS!!! > Gary r. voigt > > "Fackler, Ken" wrote: > > > > > I thought I was being picked on up here in the NE the way the weather's > > been. Sounds like most of the country is having similarly poor flying > > conditions. > > > > According to our local forecast, tomorrow is looking like "a good day to > > fly." We're supposed to have winds -under- 5mph the entire day. > > Unfortunately, the temperature isn't going to be much higher. Actually, it's > > going to soar into the upper 20's! Whoo hoo! Anyway, I'm going to get as > > much time in tomorrow as I can stand. Who knows when the weather is likely > > to break again? The forecast has snow and gale force winds ripping right > > back in on Christmas morning. > > > > Wish me luck, and Happy Holidays! > > > > -Ken Fackler > > Mark II / 503 > > Rochester MI > > > > ________________________________________________________________________________
Date: Dec 24, 2002
Subject: Open cockpits.
For those flying in open Kolbs, just finished my full enclosure on my Firestar 2 and heat after almost 200 open hours of flying. Now I can extend my winter flying here in virginia. Flew it for the first time this week, it's like a new airplane. the sound sure is different and it's weird to be in out of the wind. Kind of more like flying in a spam can but it sure is neat. The heat is awsom. It snowed today, hope to go flying off the snow on Xmas day for a first. Dry and warm. Merry Xmas. Tim ________________________________________________________________________________
Date: Dec 24, 2002
Subject: Re: Open cockpits.
Tim, can you send me some pics of your enclosure, also what type of heat did you go with. thanks, Gary r. voigt Timandjan(at)aol.com wrote: > > For those flying in open Kolbs, just finished my full enclosure on my > Firestar 2 and heat after almost 200 open hours of flying. Now I can extend > my winter flying here in virginia. Flew it for the first time this week, > it's like a new airplane. the sound sure is different and it's weird to be in > out of the wind. Kind of more like flying in a spam can but it sure is neat. > The heat is awsom. > It snowed today, hope to go flying off the snow on Xmas day for a first. Dry > and warm. > > Merry Xmas. > > Tim > ________________________________________________________________________________
Date: Dec 25, 2002
I too would like to see pictures or the enclosure and see details of the heating system. Thanks in advance. ________________________________________________________________________________
Date: Dec 26, 2002
Subject: Re: Season's Greeting
Skis--Skis--Where are the skis ??? Albany, NY. 19.2" of snow Christmas day. OH yea, it was a white Christmas !!! Bob Griffin ________________________________________________________________________________
Date: Dec 26, 2002
Subject: FSII Full Enclosure
Hello FS owners, did anyone design and build their own canopy or is the kolb design good enough and worth the money. Thanks Ron ________________________________________________________________________________
Date: Dec 26, 2002
Subject: Rotax 503
Hello all Removed carbs turn crank to TDC can see vertical scrtch marks on cyl. wall . cause for alarm????? FS2 ________________________________________________________________________________
Date: Dec 26, 2002
Subject: Re: Rotax 503
How deep? How many? Which wall (s)? Any idea how caused? (Where are the circlips? Where they belong?) One cylinder or both? How about the piston (s)? Rings? Coloration? Heat apparent? (The devil is in the details) Richard Pike MKIII N420P (420ldPoops) > > Hello all > Removed carbs turn crank to TDC can see >vertical scrtch marks on cyl. wall . > cause for alarm????? > FS2 > > ________________________________________________________________________________
Date: Dec 26, 2002
Hello, i have have got some also.....about 7 or 8 on each cylinder, looks like about .0005" to .0015" deep...hard to tell. all i know is i either let a few pieces of aluminum shavings fall when i was installing and drilling for my muffler brackets or i did this on a cold seizure in the winter by not letting it warm up enough. i have been flying like this and have not had any problems but i do monitor closely. i will probably have this honed out at the time when i overhaul. EnaudZ(at)aol.com wrote: > > Hello all > Removed carbs turn crank to TDC can see > vertical scrtch marks on cyl. wall . > cause for alarm????? > FS2 > ________________________________________________________________________________
Date: Dec 26, 2002
Subject: Covering the Cage
Hello fellow builders, is it crucial to remove the tail boom to wrap the covering around the part of the cage where the tail boom fits into the cage ? Or can that part be glued with the tail still attached? Thanks Ron ________________________________________________________________________________
Date: Dec 26, 2002
Subject: EBAY!!! LAZER & MARK11
Hello fellow flyers...this might be a good deal for somebody who wants a kolb lazer (3 kits) and also a kolb mark11 on ebay!!! check it out. thanks, Gary r. voigt http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&item=1875621589 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&item=1875443786 ________________________________________________________________________________
Date: Dec 26, 2002
Subject: Re: FSII Full Enclosure
> >Hello FS owners, did anyone design and build their own canopy or is the kolb >design good enough and worth the money. > >Thanks >Ron Check my pod in the photoshare archives (T Bird). It took time and a bit of money but I like it. ________________________________________________________________________________
Subject: kit bill of sale
Date: Dec 26, 2002
Kolbers, I have hit a speedbump on the highway to registering my Mk-3. My kit was originally bought in 92 by a fellow who was unable to complete it. I bought it at nearly the point of a quik-build kit in 97 and have since nearly completed it." I know that its been a long time, but I have a young family." The FAA now tells me I need to submit the original bill of sale from Kolb to Gerry Heffner the original owner, and also that my handwritten note from Gerry describing the sale to me in 97 is not a sufficient paper trail. They were kind enough to supply me with two Bill of Sale forms (AC 8050-2) to complete the required paper trail, but I have not been able to locate Mr Heffner as he has since moved, and how can Kolb help me now that they have changed hands? How was that for a run on sentence? I have Gerrys original invoices from each of the subkits, powder coating, and Matco brakes, but the Feds say these are of no use. Any suggestions on how to get this mess fixed fast, or does anyone know Gerry Heffner from Hazleton PA and can tell me where to find him? Denny Rowe Mk-3 N616DR Leechburg,PA ________________________________________________________________________________
Date: Dec 27, 2002
Subject: Re: kit bill of sale
> >Kolbers, >I have hit a speedbump on the highway to registering my Mk-3. >My kit was originally bought in 92 by a fellow who was unable to complete it. >I bought it at nearly the point of a quik-build kit in 97 and have since >nearly completed it." I know that its been a long time, but I have a young >family." >The FAA now tells me I need to submit the original bill of sale from Kolb >to Gerry Heffner the original owner, and also that my handwritten note >from Gerry describing the sale to me in 97 is not a sufficient paper >trail. They were kind enough to supply me with two Bill of Sale forms (AC >8050-2) to complete the required paper trail, but I have not been able to >locate Mr Heffner as he has since moved, and how can Kolb help me now that >they have changed hands? How was that for a run on sentence? >I have Gerrys original invoices from each of the subkits, powder coating, >and Matco brakes, but the Feds say these are of no use. >Any suggestions on how to get this mess fixed fast, or does anyone know >Gerry Heffner from Hazleton PA and can tell me where to find him? >Denny Rowe >Mk-3 N616DR >Leechburg,PA You might try these Gerry Heffner 1 South Church St. Hazleton, PA 18201 717-455-1508 CAN DO Inc The building is located two-tenths of a mile from Route 309, four miles from Interstate 81 and 11 mi. from Hazleton Airport. "This building shows better than anything in the county," said Gerry Heffner, SEDCO vice president. ________________________________________________________________________________
Date: Dec 26, 2002
Subject: [ Paul Petty ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Paul Petty <ppetty@c-gate.net> Subject: Honda power plant http://www.matronics.com/photoshare/ppetty@c-gate.net.12.26.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Dec 27, 2002
That is no longer a good phone number, I also tried it with that areas new area code which is (570) and that was no good also, I believe it gave me the chamber of commerce or somthing like that. Thanks anyway, Denny ----- Original Message ----- From: possums <possums(at)mindspring.com> Subject: Re: Kolb-List: kit bill of sale > > > > >Kolbers, > >I have hit a speedbump on the highway to registering my Mk-3. > >My kit was originally bought in 92 by a fellow who was unable to complete it. > >I bought it at nearly the point of a quik-build kit in 97 and have since > >nearly completed it." I know that its been a long time, but I have a young > >family." > >The FAA now tells me I need to submit the original bill of sale from Kolb > >to Gerry Heffner the original owner, and also that my handwritten note > >from Gerry describing the sale to me in 97 is not a sufficient paper > >trail. They were kind enough to supply me with two Bill of Sale forms (AC > >8050-2) to complete the required paper trail, but I have not been able to > >locate Mr Heffner as he has since moved, and how can Kolb help me now that > >they have changed hands? How was that for a run on sentence? > >I have Gerrys original invoices from each of the subkits, powder coating, > >and Matco brakes, but the Feds say these are of no use. > >Any suggestions on how to get this mess fixed fast, or does anyone know > >Gerry Heffner from Hazleton PA and can tell me where to find him? > >Denny Rowe > >Mk-3 N616DR > >Leechburg,PA > > You might try these > > Gerry Heffner > 1 South Church St. > Hazleton, PA 18201 > 717-455-1508 > CAN DO Inc > > The building is located two-tenths of a mile from Route 309, four miles > from Interstate 81 and 11 mi. from Hazleton Airport. > "This building shows better than anything in the county," said Gerry > Heffner, SEDCO vice president. > > ________________________________________________________________________________
Date: Dec 27, 2002
From: Duncan McBride <duncanmcbride(at)comcast.net>
I bought my first kit from the old Kolb, and all the rest from new Kolb. When it came time to register the plane, new Kolb provided me with a bill of sale. The information needed on the bill of sale isn't a lot - just the date and the recipient's name. New Kolb might give you one made out to Mr. Heffner. I'd call them to start. Good luck, Duncan ----- Original Message ----- From: <rowedl(at)highstream.net> Subject: Kolb-List: kit bill of sale > > Kolbers, > I have hit a speedbump on the highway to registering my Mk-3. > My kit was originally bought in 92 by a fellow who was unable to complete it. > I bought it at nearly the point of a quik-build kit in 97 and have since nearly completed it." I know that its been a long time, but I have a young family." > The FAA now tells me I need to submit the original bill of sale from Kolb to Gerry Heffner the original owner, and also that my handwritten note from Gerry describing the sale to me in 97 is not a sufficient paper trail. They were kind enough to supply me with two Bill of Sale forms (AC 8050-2) to complete the required paper trail, but I have not been able to locate Mr Heffner as he has since moved, and how can Kolb help me now that they have changed hands? How was that for a run on sentence? > I have Gerrys original invoices from each of the subkits, powder coating, and Matco brakes, but the Feds say these are of no use. > Any suggestions on how to get this mess fixed fast, or does anyone know Gerry Heffner from Hazleton PA and can tell me where to find him? > Denny Rowe > Mk-3 N616DR > Leechburg,PA > > ________________________________________________________________________________
Date: Dec 27, 2002
Hello Denny, I recently registered my Kolb Firestar II with the FAA, and when through the same thing. My quick build kit was purchased by one man in 1996 and sold to another man in 1998. I purchased the parts in 2002 and did most of the assembly. When I originally filled out the 8050-88 form I checked the box that said (more than 50 percent of the above aircraft was built from a kit). The FAA came back with the same thing they told you, and I proceeded to acquire the necessary bill of sales. I contacted both the previous owners and TNK Company. I met with frustration, TNK Co. was willing to cooperate and issue the correct bill of sale with the correct SN of my plane, but problems occurred with the first owner. So what I did was; Get a new 8050-88 form, filled it out with the box checked (more than 50 percent of the above aircraft was built from miscellaneous parts and I am the owner, get it notarized, write a letter to the FAA telling them I made a mistake when I filled out the original form, send all the paper work together to the FAA, and please register my aircraft. They contacted me within two weeks and said they would register my aircraft. Lloyd, Central Florida Firestar II N-70EL rowedl(at)highstream.net wrote: > > Kolbers, > I have hit a speedbump on the highway to registering my Mk-3. > My kit was originally bought in 92 by a fellow who was unable to complete it. > I bought it at nearly the point of a quik-build kit in 97 and have since nearly completed it." I know that its been a long time, but I have a young family." > The FAA now tells me I need to submit the original bill of sale from Kolb to Gerry Heffner the original owner, and also that my handwritten note from Gerry describing the sale to me in 97 is not a sufficient paper trail. They were kind enough to supply me with two Bill of Sale forms (AC 8050-2) to complete the required paper trail, but I have not been able to locate Mr Heffner as he has since moved, and how can Kolb help me now that they have changed hands? How was that for a run on sentence? > I have Gerrys original invoices from each of the subkits, powder coating, and Matco brakes, but the Feds say these are of no use. > Any suggestions on how to get this mess fixed fast, or does anyone know Gerry Heffner from Hazleton PA and can tell me where to find him? > Denny Rowe > Mk-3 N616DR > Leechburg,PA > ________________________________________________________________________________
Subject: Pulse pump cracks warning
Date: Dec 27, 2002
12/27/2002 10:02:21 AM Kolb guys, here's a heads-up warning for you to check out on your fuel pump. I was rebuilding my Mikuni dual pulse pump last week and noticed it had cracks in the casting. The cracks were on the cover side casting which has the pulse port pressed into it. This pump is of 1996 vintage. On this "old style" pump the pulse port fitting presses straight into the surface of the cover casting, in the middle. The cracks I found were forming radially (out from the center where the fitting was pressed into it), there were three or four cracks, they were visible on the inside of the pump only, and one of them may have lost some material in the form of a small flake of aluminum or two. Obviously, I decided to replace the pump. A quick look at the Leaf catalog revealed that the small picture in the catalog may have been showing a slightly different design, which had the pulse port pressed into the side of a cast boss on the cover, instead of into the center of the cover. The "new style" pump was also found in three forms at local snowmobile/watercraft dealerships last week. They had a generic one, one for certain models, and the Skidoo dealer had one with the small (0.015" diameter !!!) hole drilled into the pulse port fitting. But all three were of the "new style" pulse port fitting location. And, like I said above, I think what Leaf is selling now is of the "new style". The cracks I found were not evident on the outside surface of the pump, so I found them only when I was attempting a rebuild of the pump. They had apparently not propagated through the metal, so were not leaking vacuum. One of them may have flaked a small bit of aluminum. At some point the cracks may have come thru to the outside, and the pump would then have leaked vacuum and so would become weak or quit pumping. I suppose that the cracks may have let the pulse fitting loosen up also, although I did not detect it on mine. I have posted pictures to Matronics Pictures Page, and they may be up in a few days. One shot shows the pump cover, inside view, cracks visible. The other shot shows the old pump in the foreground, and the new style pump in the background, both outside (fully assembled) views. I would suggest you take a quick look at your pump, and if it is the old style, and anywhere close to a rebuild anyway, order a new one. Be sure you get a new style one, like the photo will show. I think Leaf is selling the new style, and gets 29 bucks for them. A rebuild will not fix the cracks potential, you need the new style casting. Of course you need the pump with the tiny hole in the pulse port for Rotax engines. I drilled mine with a number 78 drill. Jim Gerken ________________________________________________________________________________
Subject: Re: [ Paul Petty ] : New Email List Photo Share Available!
Date: Dec 27, 2002
Veddy Interesting......................yessss. Kinda neat. Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose www.gogittum.com ----- Original Message ----- From: "Email List Photo Shares" <pictures(at)matronics.com> Subject: Kolb-List: [ Paul Petty ] : New Email List Photo Share Available! > > > A new Email List Photo Share is available: > > Poster: Paul Petty <ppetty@c-gate.net> > > > Subject: Honda power plant > > http://www.matronics.com/photoshare/ppetty@c-gate.net.12.26.2002/index.html > > > -------------------------------------------- > > o EMAIL LIST PHOTO SHARE > > Share your files and photos with other List members simply by > emailing the files to: > > pictures(at)matronics.com > > Please view the typical Share above and include the Description Text > Fields as shown along with your submission of files and photos. > > o Main Photo Share Index: > > http://www.matronics.com/photoshare > > -------------------------------------------- > > ________________________________________________________________________________
Date: Dec 27, 2002
This is interesting. It appears the FAA is trying to make the supporting sale documentation retroactive for the sale of kits and airplane parts for years back before they began this ridiculous paper trail requirement. No one years ago used FAA bill of sale forms for transferring ownership of a kit. Completed FAA registered aircraft but not kits. Secondly, who passes on the original sale paper work to a kit they bought. My belief is to pass on as little paper work as I can with my name on it that might show any connection to the kit for liability reasons. jerb > >That is no longer a good phone number, I also tried it with that areas new >area code which is (570) and that was no good also, I believe it gave me the >chamber of commerce or somthing like that. > >Thanks anyway, >Denny > > >----- Original Message ----- >From: possums <possums(at)mindspring.com> >To: >Subject: Re: Kolb-List: kit bill of sale > > > > > > > > > >Kolbers, > > >I have hit a speedbump on the highway to registering my Mk-3. > > >My kit was originally bought in 92 by a fellow who was unable to complete >it. > > >I bought it at nearly the point of a quik-build kit in 97 and have since > > >nearly completed it." I know that its been a long time, but I have a >young > > >family." > > >The FAA now tells me I need to submit the original bill of sale from Kolb > > >to Gerry Heffner the original owner, and also that my handwritten note > > >from Gerry describing the sale to me in 97 is not a sufficient paper > > >trail. They were kind enough to supply me with two Bill of Sale forms >(AC > > >8050-2) to complete the required paper trail, but I have not been able to > > >locate Mr Heffner as he has since moved, and how can Kolb help me now >that > > >they have changed hands? How was that for a run on sentence? > > >I have Gerrys original invoices from each of the subkits, powder coating, > > >and Matco brakes, but the Feds say these are of no use. > > >Any suggestions on how to get this mess fixed fast, or does anyone know > > >Gerry Heffner from Hazleton PA and can tell me where to find him? > > >Denny Rowe > > >Mk-3 N616DR > > >Leechburg,PA > > > > You might try these > > > > Gerry Heffner > > 1 South Church St. > > Hazleton, PA 18201 > > 717-455-1508 > > CAN DO Inc > > > > The building is located two-tenths of a mile from Route 309, four miles > > from Interstate 81 and 11 mi. from Hazleton Airport. > > "This building shows better than anything in the county," said Gerry > > Heffner, SEDCO vice president. > > > > > > ________________________________________________________________________________
Subject: Re: Pulse pump cracks warning
Date: Dec 27, 2002
Dear Jim Gerken and all other Kolbers: Jim , may I ask how your pump is mounted? I've been warned that failure to install the pump with some kind of shock mounting, that is, insulating it from both engine and airframe vibration, can cause pump failure including cracking. On that note, my pump is not currently "mounted" at all. Rather it's attached with a combination of tie wraps and safety wire; it sort of dangles. Now I'm not all that happy with the arrangement but lack the engineering ability to design anything. Therefore, I'm asking anyone who's interested to post and/or send direct to me (kfackler(at)ameritech.net) suggestions for how to mount a pump that avoids the problems mentioned above. Please keep in mind that for your suggestions to do me any good (read: for me to understand them) they have to be in words of one syllable or less! Also, it would be preferable if it didn't require fabrication as I only have access to hand tools. Thanks in advance for any and all thoughts and suggestions! -Ken Fackler Mark II / 503 Rochester MI ----- Original Message ----- From: "Jim Gerken" <gerken(at)us.ibm.com> > Kolb guys, here's a heads-up warning for you to check out on your fuel > pump. I was rebuilding my Mikuni dual pulse pump last week and noticed it > had cracks in the casting. ________________________________________________________________________________
From: Kirby Dennis Contr ASC/TM <Dennis.Kirby(at)kirtland.af.mil>
Subject: Re: Fire Extinguishers
Date: Dec 27, 2002
Denny - On your question about which fire extinguisher is a good choice for a Kolb, Cap'n Ron's advice is good - go with Halon. I bought the little 14-oz unit from Aircraft Spruce. Nice and compact. Cost $47. Comes with a mounting bracket which I fastened to the floorpan of my Mark-3 on the far-right side. Out of the way of anyone's feet, yet within easy reach if needed. Good little piece of insurance. Dennis Kirby N93DK, Verner-powered, in Cedar Crest, NM ________________________________________________________________________________
Subject: Re: Covering the Cage
Date: Dec 27, 2002
<< ... is it crucial to remove the tail boom to wrap the covering around the part of the cage where the tail boom fits into the cage ? Or can that part be glued with the tail still attached? >> Ron - I devised a way to cover the cage without the tailboom attached, and it worked out fine. Reason: I wanted to finish as much of the pod/cage as possible before attaching the tailboom so it would still fit in my one-car garage. Once the tailboom is attached, it is too long to fit in the garage. Here's how I did it: I took a piece of 6-inch diameter PVC pipe, about 6 feet long, and attached it temporarilly to the cage of my Mark-3. Once installed, about 2 feet of it stuck out aft of the cage. I then covered the cage. Just don't glue the fabric to the PVC when you form it around the PVC tube. When everything was done (covered, painted, engine installed, interior & instruments installed, etc.), I removed the "surrogate" boom tube and installed the real one. The fabric fit around the real tube perfectly. Hope this helps ... Dennis Kirby Verner-powered Mark-3 in New Mexico ________________________________________________________________________________
Date: Dec 27, 2002
Subject: New Hirth motor
I just noticed this new Hirth engine. http://www.recpower.com/3701.htm The Hirth is looking more and more as the engine of choice for my M3X, It aint too far off price wise from the Jabiru. But the 2 cycle p/w ratio is vary atractive. I doubt anyone here has any experience with this new mill, but I would apreciate any comments on either this or the F30 (ES), 85-100hp motor. :-) ________________________________________________________________________________
Date: Dec 27, 2002
Richard They are just under the exhaust port and extend down about1.5 in. no wider than the exhaust port on both ports 90 deg. from rist pin, piston is not scored. TIA Duane Z ________________________________________________________________________________
Date: Dec 27, 2002
Subject: Re: Chilly Vest - Look, John Hauck
John, can you tell me how to find the Chilly Vest? Thanks Howard Shackleford FS II SC ________________________________________________________________________________
Date: Dec 27, 2002
Subject: Re: New Hirth motor
> > >The Hirth is looking more and more as the engine of choice for my M3X, It >aint too far off price wise from the Jabiru. But the 2 cycle p/w ratio is >vary atractive. I doubt anyone here has any experience with this new mill, >but I would apreciate any comments on either this or the F30 (ES), 85-100hp >motor. :-) I fly a Hirth 2703 and a friend has a 2706. I have a Hirth f30 in the basement waiting for a project to install it on. Kitplanes did a write up on the f30 about 6 months ago. It was very favourable and there were no complaints at all. ________________________________________________________________________________
Date: Dec 28, 2002
Subject: Re: Cold weather gear for hands
writes: > > > Are there any suppliers for gloves similar to this vest? What with > long > undies and the little chemical footwarmers, the only place I really > get cold > is my hands. I bought a pair of gloves that are supposed to be > heated > "electrically" by batteries, but even wearing them AND using the > chemical > handwarmers, my hands, especially my stick hand, get very cold. > That's the > part of me that's the most limiting in terms of time in the air > during cold > weather, I'd say. > > Any suggestions, folks? Being from Minnesota and flying without an enclosed cockpit, the secret to staying warm is dressing in layers. This traps air between the clothing layers and insulates the body. Keeping the body warm will keep the hands and feet warm. Here's what I put on when going flying in sub freezing temperatures: Over the underwear with jeans, wear a long thermal underwear shirt then a summer T-shirt (usually the Kolb), then a thick sweatshirt, a windbreaker (Kolb), outer winter snow pants and jacket (Columbia). On the feet wear two pairs of socks then wool socks and insulated snow boots. For the hands, ordinary insulated ski gloves are the best. A good snowmobile suit with thermal underwear would be another option. I was flying off the frozen lakes the day after Christmas and was plenty warm in temperatures that were about 25F. I was so warm that I was sweating at times. Ralph Original Firestar ________________________________________________________________________________
Date: Dec 28, 2002
Leather gloves with the army type wool glove inserts fit tight and insulate nicely. Dave ________________________________________________________________________________
Date: Dec 28, 2002
Subject: FSII Seat belts
Does anyone know if the front and rear seatbelt harness are exactly the same for the FireStar II ? Ron Laklew ________________________________________________________________________________
Date: Dec 28, 2002
12/27/02 20:06woody > > >> >> >> The Hirth is looking more and more as the engine of choice for my M3X, It >> aint too far off price wise from the Jabiru. But the 2 cycle p/w ratio is >> vary atractive. I doubt anyone here has any experience with this new mill, >> but I would apreciate any comments on either this or the F30 (ES), 85-100hp >> motor. :-) > > > I fly a Hirth 2703 and a friend has a 2706. I have a Hirth f30 in the > basement waiting for a project to install it on. Kitplanes did a write up > on the f30 about 6 months ago. It was very favourable and there were no > complaints at all. > ========================================= Thanks Woody. ________________________________________________________________________________
Subject: Digital cameras
Date: Dec 28, 2002
Kolbers, John and Wills posts with the great photos has got Linda and I thinking about getting a digital camera. I would like one that could be mounted on the airframe and remotely triggered, hopefully under $250. Also, where can I find info on how you guys post these jpg photos for people to click on, this is one of the best features of this list, you know, the thousand words saying. Thanks, Denny "really internet challenged" Rowe Mk-3 final assembly Leechburg PA 2SI690L-70 N616DR ________________________________________________________________________________
Date: Dec 28, 2002
I have to have a lot of hand protection since my hands are getting peripheral neuritis as well as Raynauds Phenomenen (just means hands get very cold at even 60F) so I use a combination of heavy sno-mo gloves after first putting on thin silk(?) fairly tight-fitting inner gloves. They look like black silk hose, but help (me) a lot. When I was at Thule AFB in early '50s, we had double gloves and mittens and huge white felt boots, called Mickey Mouse boots--only good for dry snow. Bob N. ________________________________________________________________________________
Date: Dec 28, 2002
Subject: FSII BRAKES
Happy New Year Kolbers, Has anyone installed disc brakes on the Azusa wheels ? If so, what kind. Are the drum brakes just as light ? Dave ________________________________________________________________________________
Subject: warm hands
Date: Dec 28, 2002
Hi Kolbers, Another idea from my motorcycling. Harley Davidson offers a heated vest,gloves,pants and socks. I have not tried the system myself but a bro of mine bought one and says it works great! Has a thermostat to control the amount of heat you want and the whole thing is a thin inner liner type. I have seen him blast past me with temps in the 20's (and that's cold for this part of the country) and smile and ride on. Works off the bike battery. Kinda pricey though I think 400 bucks for the whole package Later pp ________________________________________________________________________________
Subject: Where to find
Date: Dec 28, 2002
Here is where to find and view the heated goodies! Happy shopping! pp http://www.harley-davidson.com/browse/browse_products.jsp?WebLogicSessionPg4kpEuF2PMr4UdoSTKmbCCypMKC5gsiOf7vQ1GMO2p9nulriknp|7108742062797707381/181237815/6/7005/7005/7002/7002/7005/-1|7080022102207006712/181237802/6/7005/7005/7002/7002/7005/-1&FOLDER%3C%3Efolder_id5766611&bmUID1041114276587 ________________________________________________________________________________
Subject: Toasty Mosty correction
Date: Dec 28, 2002
Kolbers, After looking at the website I guess my bro just bought the vest and gloves.......... Heated jacket liner: $220.00 dollars Visa debit card Heated Vest liner: $180.00 dollars Visa debit card Heated Pants liner: $165.00 dollars Visa debit card Heated Gloves: $165.00 dollars Visa debit card Heated Socks: $79.00 dollars Visa debit card Thermostat: $59.00 dollars Visa debit card Watching your cheap buddy freeze his ass of next to you.... Priceless.............. From experience Harley Davidson products are of the utmost in quality. Their products really are top notch. If you notice every thing except for the thermostat has the HD logo witch stands for Hundred Dollar!!! Fly safe $ warm $$$$$$ pp ________________________________________________________________________________
Subject: errrrrrrgggg
Date: Dec 28, 2002
Try this for the site on heated clothing www.harley-davidson.com then go to motorclothes then heated gear pp ________________________________________________________________________________
Date: Dec 28, 2002
Subject: Re: warm hands
http://www.gerbing.com/Pages/gloves.html $139 http://twomorrowssupply.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=TMS&Product_Code=LG-20&Category_Code=ACC $25 http://www.weatheraffects.com/6301.htm $37 http://www.motorcycleapparel.net/Merchant2/merchant.mv?Screen=PROD&Store_Code=MA&Product_Code=WD&Category_Code=Widder+Lectric+Heat+Apparel $79 From google.com Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Dec 28, 2002
Subject: Re: UL: GPS
Costco (Price Club) has a nice deal on a Magellan Sportrak Pro with cig pwr plug, case, windshield suction cup mount and CD for mapping--$290 with a mail in rebate of $100. Also a handy battery/starter pkg with chgr, air compressor(!), cables--$60. Bob N. ________________________________________________________________________________
Date: Dec 28, 2002
I have a similar problem, to wit, compromised circulation due to diabetes. My hands, too, get cold at temps much higher than normal folks and completely irrespective of my overall body confort. Can you provide any info on a source for the gloves you mention? -Ken ----- Original Message ----- From: "bob n" <ronoy(at)shentel.net> > I use a combination of heavy sno-mo gloves > after first putting on thin silk(?) fairly tight-fitting inner gloves. ________________________________________________________________________________
Date: Dec 29, 2002
Subject: Engine De-rating and Bearing Life
A couple of months ago there was a thread "Rotax operating speeds". While researching and working on the comparison between the Rotax 447 and Victor 1+, I ran across some Timken bearing info. I calculated out what would be the expected change in bearing life for the Victor 1+ by reducing top engine speed from 6,000 rpm to 5,200 rpm (38 hp). Using Simonini's expected total before overhaul time of 600 hours, I found that the bearing life would be extended to a little less than 1,800 hours. If you would like to see the calculations, they can be seen on the bottom of: http://www.thirdshift.com/jack/firefly/victor_fuel.html This pretty well indicates that if one wants to increase engine reliability, the easiest thing one can do is to stay away from prolonged flights at high engine rpm. More snow. See you next year. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Subject: landing gear legs
Date: Dec 29, 2002
Can anyone on the list tell me what the wall thickness is on 4130 steel landing gear ? I am thinking of building a dolly , and thought 4130 of similar thickness should work fine. Thanks for your time and help . TopGunPI(at)att.net FS II on Floats S.E.Ma. ________________________________________________________________________________
Subject: kolbs for sale
Date: Dec 29, 2002
Here are a couple of Kolbs for sale! http://www.aerotraderonline.com/adsearchprocess.html ________________________________________________________________________________
Date: Dec 29, 2002
Subject: [ Jim Gerken ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Jim Gerken Subject: Fuel pump defect found! http://www.matronics.com/photoshare/gerken@us.ibm.com.12.29.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Dec 29, 2002
Subject: [ William George ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: William George Subject: Mk-3 For Sale http://www.matronics.com/photoshare/wgeorge@mountainmeadowranch.com.12.29.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Subject: Elevator deflection?
Date: Dec 29, 2002
What is the degree of deflection upwards and downwards that one should see in you elevators? ________________________________________________________________________________
Date: Dec 29, 2002
Dave (TAILDRAGGER503(at)aol.com <http://us.f402.mail.yahoo.com/ym/Compose?To=TAILDRAGGER503@aol.com&YY=6 5970&order=down&sort=date&pos=0&view=a&head=b> ) I have been using a disc brake system on my FS2 that is lighter than the drum brake system. There is a picture on the photoshare list dated August 11. Gregg Boulder,CO FS2/503/ 2v2 http://home.attbi.com/~fly3g/index.htm ________________________________________________________________________________
Date: Dec 29, 2002
Subject: Help! 503 on a MKIII?
I need an answer Muy Pronto if posssssible... My trusty old Rotax 532 got terribly sick today, but lingered long enough to get me back to the airport gracefully from about 4 miles out. (There's good sermon material in there, but that's for another time...) Reason for failure so far unknown, that's not a priority at the moment. In order to get the airplane home tomorrow from 25 miles away, a friend has loaned me an old style 503, complete with everything, even the right prop for that engine, a wooden Tennessee Propellors 60" 2 blade. Question: I have always used a prop extension before because of the flexibility of the IVO, but with a rigid prop, 1996 version MKIII, can the extension be omitted? Will the wood prop clear everything safely? Because if it will, then I don't have to fiddle around with figuring out the correct repitch to use on my IVO. (I have the old style IVO, stack the shims, restack the shims - etc.) I want to use the wood prop if possible to get it home before the weather goes down. Thanks. Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Dec 29, 2002
Subject: Re: Help! 503 on a MKIII?
> Question: I > have always used a prop extension before because of the flexibility of the > IVO, but with a rigid prop, 1996 version MKIII, can the extension be > omitted? Will the wood prop clear everything safely? Because if it will, > then I don't have to fiddle around with figuring out the correct repitch to > use on my IVO. > Richard Pike Hi Richard/Gang: Glad you made it. Also, if it had to happen, glad it waited until today. Stopped by to visit Richard last Friday late. We went for a short orientation flight around his AO. Great place to fly. Beautiful area. Enjoyed my flight and am proud to say we had power from takeoff to landing. Richard, back in the old days of fixed pitch wooden props on Kolbs, we didn't know the definition of prop extensions. I would think you would be alright without one. I flew my MK III and 582 with a Warp Drive Fast Taper Prop for a while without extension and no stikes. Also flew the GSC 3 blade wooden prop with the 582 on my MK III. Take care, john h ________________________________________________________________________________
Subject: Re: Elevator deflection?
Date: Dec 29, 2002
Kenny, My Mark-3 manual calls for 9.75 inches minimum measured at the aft most tip of the elevator, it says it's OK to have a little more. This is a 1992 manual. Don't know what the firestar or firefly would be. Denny Rowe ----- Original Message ----- From: Kenny <kenandmona(at)earthlink.net> Subject: Kolb-List: Elevator deflection? > > > What is the degree of deflection upwards and downwards that one should > see in you elevators? > > ________________________________________________________________________________
Date: Dec 29, 2002
I am getting a 24 degree downward deflection and upward deflection is no problem. My elevator horn posts going out to the elevator post contacts the boom a little sooner than I'd like. May go in with some emory cloth and smooth out some of the little burrs that might be hanging me up. Thanks Denny I may give Kolb a phone call in the morning before I go to work. > [Original Message] > From: <rowedl(at)highstream.net> > To: > Date: 12/29/2002 8:49:17 PM > Subject: Re: Kolb-List: Elevator deflection? > > > Kenny, > My Mark-3 manual calls for 9.75 inches minimum measured at the aft most tip > of the elevator, it says it's OK to have a little more. This is a 1992 > manual. Don't know what the Firestar or firefly would be. > Denny Rowe > ----- Original Message ----- > From: Kenny <kenandmona(at)earthlink.net> > To: Kolb List > Subject: Kolb-List: Elevator deflection? > > > > > > > > What is the degree of deflection upwards and downwards that one should > > see in you elevators? > > > > > > ________________________________________________________________________________
Subject: Kolb for sale
Date: Dec 30, 2002
Here's another Kolb up for sale, this one on ebay: Item # 1876011906 ________________________________________________________________________________
Date: Dec 30, 2002
Subject: Transponder
I have 16 hours on my Mark III, and I'm contemplating the future when I fly off the restriction. I'm going to need a practical (cheap) solution to flying into Class C airspace, and would sure appreciate some advice. Are used transponders a generally safe bet? Reconditioned? Even the sold as-is units seem to command a good price, so either they hold their value because they are pretty reliable, or else there are a lot of guys like me willing to take a chance to save a few bucks keeping the prices up. What's been y'alls experience? A related issue - where am I going to put the thing in my teeny little panel? I'm thinking of a console I can bang my knee on, or an overhead I can bang my head on.... ________________________________________________________________________________
Date: Dec 30, 2002
Do you want to limp or see stars??? Jeremy -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Duncan McBride Subject: Kolb-List: Transponder I have 16 hours on my Mark III, and I'm contemplating the future when I fly off the restriction. I'm going to need a practical (cheap) solution to flying into Class C airspace, and would sure appreciate some advice. Are used transponders a generally safe bet? Reconditioned? Even the sold as-is units seem to command a good price, so either they hold their value because they are pretty reliable, or else there are a lot of guys like me willing to take a chance to save a few bucks keeping the prices up. What's been y'alls experience? A related issue - where am I going to put the thing in my teeny little panel? I'm thinking of a console I can bang my knee on, or an overhead I can bang my head on.... = ________________________________________________________________________________
Subject: Re: Transponder
Date: Dec 30, 2002
You can get a microair transponder for about $1200 US that uses a 2 1/4" hole for mounting. http://www.mcp.com.au/microair/category4_1.htm Cy Galley - Bellanca Champion Club Newsletter Editor & EAA TC www.bellanca-championclub.com We support Aeroncas ----- Original Message ----- From: "Jeremy Casey" <jrcasey(at)ldl.net> Subject: RE: Kolb-List: Transponder > > Do you want to limp or see stars??? > > Jeremy > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Duncan > McBride > To: kolb-list(at)matronics.com > Subject: Kolb-List: Transponder > > > > I have 16 hours on my Mark III, and I'm contemplating the future when I > fly off the restriction. I'm going to need a practical (cheap) solution > to flying into Class C airspace, and would sure appreciate some advice. > Are used transponders a generally safe bet? Reconditioned? Even the > sold as-is units seem to command a good price, so either they hold their > value because they are pretty reliable, or else there are a lot of guys > like me willing to take a chance to save a few bucks keeping the prices > up. What's been y'alls experience? > > A related issue - where am I going to put the thing in my teeny little > panel? I'm thinking of a console I can bang my knee on, or an overhead > I can bang my head on.... > > > > > > ________________________________________________________________________________
Date: Dec 30, 2002
A streamlined pod on the wing strut to hold a radio stack would be cool.... I checked the archives, and of course found some useful posts. I should have done that first. I think I'll find out what the nearby avionics shops can provide in the way of reconditioned used gear. Maybe work on a deal for a panel mounted radio at the same time. King, Narco, and Cessna gear seems to enjoy a healthy used market. We'll see. ----- Original Message ----- From: "Jeremy Casey" <jrcasey(at)ldl.net> Subject: RE: Kolb-List: Transponder > > Do you want to limp or see stars??? > > Jeremy > > > A related issue - where am I going to put the thing in my teeny little > panel? I'm thinking of a console I can bang my knee on, or an overhead > I can bang my head on.... > > ________________________________________________________________________________
Date: Dec 30, 2002
This is where mine goes! Will attach picture. Bob ----- Original Message ----- From: "Duncan McBride" <duncanmcbride(at)comcast.net> Subject: Kolb-List: Transponder > > I have 16 hours on my Mark III, and I'm contemplating the future when I fly off the restriction. I'm going to need a practical (cheap) solution to flying into Class C airspace, and would sure appreciate some advice. Are used transponders a generally safe bet? Reconditioned? Even the sold as-is units seem to command a good price, so either they hold their value because they are pretty reliable, or else there are a lot of guys like me willing to take a chance to save a few bucks keeping the prices up. What's been y'alls experience? > > A related issue - where am I going to put the thing in my teeny little panel? I'm thinking of a console I can bang my knee on, or an overhead I can bang my head on.... > > ________________________________________________________________________________
Date: Dec 30, 2002
Watch out for old Cessna radios--most are junk! Transponders, which are all TSOd, do hold their value...and used with tag, are OK. They have to be ckd every two years--look for that. Bob N. old GA guy for 56 years ________________________________________________________________________________
Subject: BRS for a Mark-3
Date: Dec 30, 2002
Kolb Friends - I made the decision to install a BRS on my M3-Classic. Since I must fold/unfold the wings (and hence, remove the gap seal) for each flight, I'm polling the list for which type of 'chute to install. The canister or softpack? It will be the 1050-lb rated BRS. Thanks for any suggestions ... Dennis Kirby Cedar Crest, NM ________________________________________________________________________________
Date: Dec 30, 2002
Subject: Re: BRS for a Mark-3
If I couldn't fully enclose the softpack so the gap cover could fit over it with a tear-through cover where the rocket would fire, I think I'd opt for the canister, mounted above the gap cover - only a few small slots would have to be cut in the cover to fit. The canister is about the size of the 912's oil tank anyway, so it would have some company... What I did was buy the 1050 VLS, and it wouldn't fit inside the cover - now I have a huge hole in the gap cover where the VLS sticks through, and I think it leaks a lot of lift up and around the VLS. I'm thinking of some kind of neoprene seal or something to close the gap but still let the chute fire. Now I wish I had mounted the VLS higher, above the level of the gap cover, so there would only be two small slots for the mount instead of a big hole. Might as well have bought the canister, because I don't think there is any less drag the way the VLS is mounted. The best arrangement would be to fully enclose the soft pack in a permanent gap seal - if you need to fold the wings, modify the gap seal at the sides to allow access to the spar pins and clearance for folding. These things are easier to think of than to do, of course. Good luck. ----- Original Message ----- From: "Kirby Dennis Contr ASC/TM" <Dennis.Kirby(at)kirtland.af.mil> Subject: Kolb-List: BRS for a Mark-3 > > Kolb Friends - > I made the decision to install a BRS on my M3-Classic. > Since I must fold/unfold the wings (and hence, remove the gap seal) for each > flight, I'm polling the list for which type of 'chute to install. The > canister or softpack? It will be the 1050-lb rated BRS. > Thanks for any suggestions ... > Dennis Kirby > Cedar Crest, NM > > ________________________________________________________________________________
Date: Dec 30, 2002
Does the inspection that merits the yellow tag serve for the biennial check, too, or is that something else? ----- Original Message ----- From: "bob n" <ronoy(at)shentel.net> Subject: Re: Kolb-List: Transponder > > Watch out for old Cessna radios--most are junk! Transponders, which are > all TSOd, do hold their value...and used with tag, are OK. They have to > be ckd every two years--look for that. > > Bob N. old GA guy for 56 years > > ________________________________________________________________________________
Date: Dec 30, 2002
Tag or work order must state passing biennial, dated, signed by tech/shop. The basic test is done by either putting an antenna test box enclosing the tpdr, or more crudely, putting a test ant near the ship's ant. This results in an additional test of the coax and ship ant. The test ant connects to tpdr test set. In the shop they use a special tpdr test set that couples/plugs into the tpdr ant output jack. They measure rec. sensitivity, mode decoding accuracy, reply pulse train for pulse spacing and pulse shape, bracket spacing, code generation, and pwr output. If you have an encoding altimeter, it gets ckd both pneumatically (pressure alt ck) and reply pulse train, again for pulse characteristics, and correct pulse coding of alt vs pulse train. In a former life I did design work on the first IFF tester--UPN-4&6 as well as the grandfather of the present beacon system. Bob N, ________________________________________________________________________________
Date: Dec 30, 2002
Seem to be more grandfathers building these days than any other group. Guess we have the time and more importantly, the money. When I started to fly, used to fly the four course ranges. How old does that make me? Bob G. ________________________________________________________________________________
Date: Dec 30, 2002
Subject: Re: Mk III Radiator
12/30/02 11:57Dave & Eve Pelletier > > > Hello Kolbers > > I have a MK III and the original radiator couldn't hack it for summertime > flying in southern Arizona, so we replaced it with an automotive type. Works > jess fine, thank ewe, never getting over 180 degrees even on the hottest days. > But now I'm flying in Prescott (5200') in the winter. Flew for a couple of > hours on the 27th with the outside temp around 50 degrees. The water temp > never quite reached 130 degrees. Question is, is there a problem here with > the engine not getting hotter than this? It ran real fine but I'm a bit > concerned as to whether or not I should install a thermostat. If so, what do > you guys recommend? (By the way, I have a used 582 radiator for sale.) > Happy Holidays > Arizona Dave > > > Well 130 is low but not bad, the most important temp would be your CHT. If they are runing within the normal range I would be happy. I can't think of any problems right off in the crank area with temps in the 130's, in fact the opposit. ________________________________________________________________________________
Date: Dec 30, 2002
12/30/02 14:41Duncan McBride > Does the inspection that merits the yellow tag serve for the biennial check, > too, or is that something else? ============================== It means that the unit was inspected and it complies with the FAA/MFG specs for its operational envelope. In other words the unit works no worse than a brand new unit. The biennial chack simply means that the unit is still within specs, normally as installed in the airplane. ________________________________________________________________________________
Date: Dec 30, 2002
12/30/02 16:36RFG842(at)aol.com > When I started to fly, used to fly the four course ranges. > > How old does that make me? > > Bob G. ================= Thats before my time, I'd say 1940's you'r probably in your 70's? :-) ________________________________________________________________________________
Subject: Re: MKIII on a FSII trailer?
Date: Dec 30, 2002
Hey John, Hated to see that Jeremy was selling his plane but glad to here it went to a worthy person. Hope you enjoy it thoroughly. Bill Woods Protect your PC - Click here for McAfee.com VirusScan Online ________________________________________________________________________________
Date: Dec 30, 2002
CaptainRon wrote: > Well 130 is low but not bad, the most important temp would be your CHT. If > they are runing within the normal range I would be happy. I can't think of > any problems right off in the crank area with temps in the 130's, in fact > the opposit. Captain Ron/Gents: Was wondering if Captain Ron's comments were based on experience with the 582 or with GA aircooled engines? Maybe Arizona Dave should check his operator's manual for the 582 and see what coolant temps should be. If that doesn't work, and no one else has anymore words of wisdom, recommend contacting Kodiak Research (Rotax) and get their official operating limits (green arch). Watercooled engines (in general) that do not get up to recommended operating temps usually do not produce optimum power, nor do they do a good job of burning fuel. Take care, john h ________________________________________________________________________________
Date: Dec 31, 2002
Hi Dennis and All, There was a thread a while back about not mounting the chute between the wings because it could be trapped by the wings if there is a structural failure and the wings folded upwards. I don't know what Kolb recommends for your plane but they told me to mount mine on the boom tube so it would fire down and back. You may want to ask them before you buy as their answer may influence which type of mount and pack system you need. Steve ________________________________________________________________________________
Date: Dec 31, 2002
Subject: Message Bouncer for Spam
Folks, I stumbled upon a piece of software that performs a filter and will "bounce" email messages based upon criteria which you can control. You run it and it down loads a list of your mail messages and provides at status as normal, spam, or possible spam. If your getting much Spam, this is the thing you want. It shareware type distribution with a request for a very moderate registration fee of $20, well worth it. You can get it at the following URL.: jerb
http://www.mailwasher.net/ ________________________________________________________________________________
Date: Dec 31, 2002
Why do you need a trasponder? I fly under Charlotte's Class B airspace and into towered airports all the time without a transponder. I checked with the local FSDO and they said the electrical on a Mark III is too small to require a trasnponder. Check the archives for more on this. Jim Mark III Charlotte, NC ----- Original Message ----- From: "Duncan McBride" <duncanmcbride(at)comcast.net> Subject: Kolb-List: Transponder > > I have 16 hours on my Mark III, and I'm contemplating the future when I fly off the restriction. I'm going to need a practical (cheap) solution to flying into Class C airspace, and would sure appreciate some advice. Are used transponders a generally safe bet? Reconditioned? Even the sold as-is units seem to command a good price, so either they hold their value because they are pretty reliable, or else there are a lot of guys like me willing to take a chance to save a few bucks keeping the prices up. What's been y'alls experience? > > A related issue - where am I going to put the thing in my teeny little panel? I'm thinking of a console I can bang my knee on, or an overhead I can bang my head on.... > > ________________________________________________________________________________
Date: Dec 31, 2002
I installed a canister BRS on my Mark III on top. I had to cut the gap seal a little but it works ok. Jim Mark III Charlotte, NC ----- Original Message ----- From: "Kirby Dennis Contr ASC/TM" <Dennis.Kirby(at)kirtland.af.mil> Subject: Kolb-List: BRS for a Mark-3 > > Kolb Friends - > I made the decision to install a BRS on my M3-Classic. > Since I must fold/unfold the wings (and hence, remove the gap seal) for each > flight, I'm polling the list for which type of 'chute to install. The > canister or softpack? It will be the 1050-lb rated BRS. > Thanks for any suggestions ... > Dennis Kirby > Cedar Crest, NM > > ________________________________________________________________________________
Date: Dec 31, 2002
> >Why do you need a trasponder? I fly under Charlotte's Class B airspace and >into towered airports all the time without a transponder. I checked with the >local FSDO and they said the electrical on a Mark III is too small to >require a trasnponder. Check the archives for more on this. This was a mystery to me, so I spent a lot of research time figuring this out. The FARs say: a transponder is required inside the Mode C veil for CERTIFIED aircraft with an electric system. Since our ultralights are not CERTIFIED, they don't have to meet the requirement EVEN IF THEY HAVE A POWERFUL ELECTRICAL SYSTEM. I'm still not 100% sure if this "loophole" applies to experimental N-numbered aircraft, but I'm *pretty sure* it applies as well since experimentals are not certified by the FAA. So, you don't HAVE to have one to operate in the Mode C veil... however, if you plan on going into Class D, C, or B airspace, you'd better have one. -- Robert ________________________________________________________________________________
From: "Rick & Martha Neilsen" <neilsenrm(at)cs.com>
Date: Dec 31, 2002
I have been flying my Experimental (registered N numbered) MKIII without a transponder from under a Mode C vail for 5 years. I have requested and receive on a annual basis a waver to do so. I wrote a simple letter to the control tower requesting the waver and indicated that my electrical system would not safely handle the load of a transponder. No questions, augments, or hassles, and its legal. Another option. Rick Neilsen Redrive VW powered MKIII -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Robert Laird Subject: Re: Kolb-List: Transponder ________________________________________________________________________________
Date: Dec 31, 2002
Subject: Radiator
Hi, I've put a few rows of duct tape at the" top" of the cooling fins , it helped to hold some of the heat. I did it til the temp was a little hotter.... then I pulled some back off....it works. Mike in MN FSII (close to the end of my fabric stage) - snip>>> I have a MK III and the original radiator couldn't hack it for summertime flying in southern Arizona, so we replaced it with an automotive type. Works jess fine, thank ewe, never getting over 180 degrees even on the hottest days. But now I'm flying in Prescott (5200') in the winter. Flew for a couple of hours on the 27th with the outside temp around 50 degrees. The water temp never quite reached 130 degrees. Question is, is there a problem here with the engine not getting hotter than this? It ran real fine but I'm a bit concerned as to whether or not I should install a thermostat. If so, what do you guys recommend?--- Sometimes you just have to take the leap and build your wings on the way down... Gotta Fly... ________________________________________________________________________________
Date: Dec 31, 2002
Subject: Re: Trailer building
Trailer Toters Im in the final stages of building my Firefly trailer and was hoping for some advice on level trailer heights. Maybe some warnings of what I should look out for. It is enclosed and guestimated to weigh around 1500 lbs. I decided To go with a single torsion axle . It is almost a replica of Duane da Planes. Mine is minus any windows. I was going to use 13" wheels But I started thinking it might ride better on 15" tires. What is the lowest trailer height I could use & not have to worry too much about dragging the rear all the time? Opinions? Ed Diebel ( Firefly ready for engine , waiting for trailer to get finnished) HAPPY NEW YEAR ALL!!!!!!!! ________________________________________________________________________________
Date: Dec 31, 2002
From: "Gary robert voigt" <johndeereantique(at)qwest.net>
Subject: air vents!!!
ok guys, now you can help me make a decision on nap vents. i'am going to install some snap vents on my kolb kxp single place and would like to know to if i should go with 2" or 3"?... tapered or flush mount? wicks aircraft has some nice ones on page 55 in there catalog. please let me know the pros and cons on these..... i don't want to be sweating next summer with my full enclosure. thanks in advance, Gary r. voigt HAPPY NEW YEAR EVERYONE!!! ________________________________________________________________________________
Subject: Re: air vents!!!
Date: Jan 01, 2003
Hello Gary, and all I have the 3" snap vents on my Firestar which I installed last summer and I do really like them, they are the one that are flush mounts, really easy to install and really gave me all the air I needed, but not quite enough on a hot summer day but better than nothing. maybe a pair would be better. I just have one installed on the lower left of my lexan windshield. I think if I would install another one on the other side it would help more. Happy New Year everyone!!!! Joel Reed 84 Firestar Lancaster Co, Pa > ok guys, now you can help me make a decision on nap vents. i'am > going to install some snap vents on my kolb kxp single place and would > like to know to if i should go with 2" or 3"?... tapered or flush mount? > > wicks aircraft has some nice ones on page 55 in there catalog. please > let me know the pros and cons on these..... i don't want to be sweating > next summer with my full enclosure. > > > thanks in advance, > Gary r. voigt > > HAPPY NEW YEAR EVERYONE!!! > > ________________________________________________________________________________
Date: Jan 01, 2003
Go with at least four 3" vents, plus a way to suck out the hot air. I had four 3" vents last summer, and it was not enough. I will be modifying things shortly, as last summer was intolerable at midday. You might want to think about using reflective film on the top part of your windshield, or some other way to reduce the "Enclosed Kolb Greenhouse Effect." Richard Pike MKIII N420P (420ldPoops) > > > ok guys, now you can help me make a decision on nap vents. i'am >going to install some snap vents on my kolb kxp single place and would >like to know to if i should go with 2" or 3"?... tapered or flush mount? > >wicks aircraft has some nice ones on page 55 in there catalog. please >let me know the pros and cons on these..... i don't want to be sweating >next summer with my full enclosure. > > > thanks in advance, > Gary r. voigt > > HAPPY NEW YEAR EVERYONE!!! > > ________________________________________________________________________________
Date: Dec 31, 2002
Good idea....................in a camper supply store I've seen a thin, tinted plastic film that sticks to the window, kinda like those little oil change reminders some shops put in the corner of your car's windshield. Peel it off, and re-stick it where you want it. Might be handy. Shady Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose www.gogittum.com ----- Original Message ----- From: "Richard Pike" <rwpike(at)preferred.com> Subject: Re: Kolb-List: air vents!!! > > Go with at least four 3" vents, plus a way to suck out the hot air. I had > four 3" vents last summer, and it was not enough. I will be modifying > things shortly, as last summer was intolerable at midday. You might want to > think about using reflective film on the top part of your windshield, or > some other way to reduce the "Enclosed Kolb Greenhouse Effect." > > Richard Pike > MKIII N420P (420ldPoops) > > > > > > > > ok guys, now you can help me make a decision on nap vents. i'am > >going to install some snap vents on my kolb kxp single place and would > >like to know to if i should go with 2" or 3"?... tapered or flush mount? > > > >wicks aircraft has some nice ones on page 55 in there catalog. please > >let me know the pros and cons on these..... i don't want to be sweating > >next summer with my full enclosure. > > > > > > thanks in advance, > > Gary r. voigt > > > > HAPPY NEW YEAR EVERYONE!!! > > > > > > ________________________________________________________________________________
Date: Jan 01, 2003
Date: Jan 01, 2003
Date: Jan 01, 2003
Happy New Year to all! I was pulling a travel trailer with a duel axial and blew one of the tires while going down the freeway on a steep hill I didn't even know it until someone driving next to me let me know I had a problem. If that had been a single axial trailer I not only would have instantly known I had a flat tire but would also have had the opportunity to see what a barrel roll looks like from the front seat of a van and if we had survived that we would have gotten to experience the joys of having to replace all of the damaged vehicles. I now think of that second axial like I do my parachute - cheap insurance for something I don't want to have to replace. Before that incident I never even thought about the issue. Food for thought. Steve ________________________________________________________________________________
Date: Jan 01, 2003
> ok guys, now you can help me make a decision on nap vents. > Gary r. voigt Gary/Gang: I have two 3 1/4" round snap vents in the fully inclosed MK III. They work fine. In the Summer in the SE it is hot, not matter if you have two or 22 vents, or no doors at all. I keep the doors open during ground ops and climb for cooler air when flying. I initially bought the NASA vents to be "cool", but they were not the $40+ I paid for them. They got returned for the round snap vents. We had the same two snap vents on the TH-55 Hughes Helicopters during flight school 1968. Winter flew with doors on and summer off. Did not make any difference what the temps were. Take care, john h ________________________________________________________________________________
Date: Jan 01, 2003
> Go with at least four 3" vents, plus a way to suck out the hot air. > Richard Pike God Morning Richard/Kolbers: Happy New Year!!! I thought about going with 4 vents for the 2001 flight to Alaska. However, decided to stay with two. In two days flying I was in much cooler country, across the border, and didn't need them. Been flying the same set up for so long I am used to it. Getting to old to change now. :-) In reference to the "way to suck out the hot air", will approach this one cautiously. I have 5 inch lightening holes in the center section bulk head plus the tail boom to exhaust hot air. Up until 2000 I flew with no seals on the entrance doors. Used some of the 3M book binding tape to seal both doors. Did not realize until after I had done it how much cool air was coming in through the hinge line. In addition, it also helps keep some of the rain out of the cabin. Note: I said some. Rain seems to find its own source of entrance and usually drips on me. john h ________________________________________________________________________________
Date: Jan 01, 2003
OK Where do we buy the 3" snap vents? How much? Denny ----- Original Message ----- From: John Hauck <jhauck(at)sw.rr.com> Subject: Re: Kolb-List: air vents!!! > > > > ok guys, now you can help me make a decision on nap vents. > > Gary r. voigt > > Gary/Gang: > > I have two 3 1/4" round snap vents in the fully > inclosed MK III. They work fine. In the Summer > in the SE it is hot, not matter if you have two or > 22 vents, or no doors at all. I keep the doors > open during ground ops and climb for cooler air > when flying. > > I initially bought the NASA vents to be "cool", > but they were not the $40+ I paid for them. They > got returned for the round snap vents. > > We had the same two snap vents on the TH-55 Hughes > Helicopters during flight school 1968. Winter > flew with doors on and summer off. Did not make > any difference what the temps were. > > Take care, > > john h > > > > > > > ________________________________________________________________________________
Date: Jan 01, 2003
> >Good idea....................in a camper supply store I've seen a thin, >tinted plastic film that sticks to the window, kinda like those little oil >change reminders some shops put in the corner of your car's windshield. >Peel it off, and re-stick it where you want it. Might be handy. >Shady Lar. > >Larry Bourne You can get some stuff at auto supply stores too - tinted window film. It doesn't have any adhesive on it though, but is like those "oil change reminders", sort of clings to the windshield until you move it. I cut two circles, one about 7 inch diameter, and one about 6 inch. stick one on top of the other. On short or long trips, I can keep most of sun out of my face while I can still see through the "Spot". Easy too move and seems to cling without hurting the windshield. ________________________________________________________________________________
Date: Jan 01, 2003
> Where do we buy the 3" snap vents? > How much? > Denny Denny/Gang: Try any of the aircraft parts supply houses. Less than $5.00 unless inflation has gotten to them. The instruction call for a 3 1/4" hole, or something in that vicinity. I have found that if I go about 1/16" or so smaller than what is called for the vents work better. If the holes are too large the vents don't stay put. Also, if drilled as spec'ed, vibration will soon enlarge the holes enough to loosen thing up. john h ________________________________________________________________________________
From: "Dave & Eve Pelletier" <pelletier(at)cableone.net>
Date: Jan 01, 2003
A suggestion for the tongue jack. My trailer has a drop down rear door and I had clearance problems when taking the Kolb in or out. The problem is when the front wheels (or back if you nose it in) start down the door to the ground and the tail wheel is still in the trailer. The clearance between the end of the trailer and the bottom of the folded wings becomes very small and if you're not careful, hangar rash results. My solution was to get rid of the standard tongue jack and weld on a "Bulldog" brand tongue jack - 7,000 capacity. The nice thing about this jack is you pull a pin and it telescopes down to the ground. Reinsert the pin, and then you crank it up - can get the nose of the trailer a lot higher, thereby reducing the angle between the door and the floor of the trailer. I cut the long crank handle off and shortened it and welded a 5/8" socket so the radius is much shorter and easier to crank. Also, a 5/8" socket on my cordless drill runs it up and down. Works pretty good. Arizona Dave ----- Original Message ----- From: <DAquaNut(at)aol.com> Subject: Re: Kolb-List: Trailer building > > Trailer Toters > Im in the final stages of building my Firefly trailer and was > hoping for some advice on level trailer heights. Maybe some warnings of what > I should look out for. It is enclosed and guestimated to weigh around > 1500 lbs. I decided To go with a single torsion axle . It is almost a > replica of Duane da Planes. Mine is minus any windows. I was going to use 13" > wheels But I started thinking it might ride better on 15" tires. What is > the lowest trailer height I could use & not have to worry too much about > dragging the rear all the time? Opinions? > > Ed Diebel ( Firefly ready for engine , waiting for > trailer to get finnished) > > HAPPY NEW YEAR ALL!!!!!!!! > > ________________________________________________________________________________
Subject: MK III Radiator
Date: Jan 01, 2003
Hi Guys, Thanks for the advice on my radiator. Now I've got some ideas I can try. Arizona Dave ________________________________________________________________________________
fulltimer03(at)yahoo.com, rgintina424(at)yahoo.com, herbpenney(at)msn.com, kolb-list(at)matronics.com, rckotow(at)dmv.com, molly.moyle(at)astrazeneca.com, PHUNTER(at)prodigy.net, pnshate(at)dejazzd.com, jks(at)netcarrier.com, reno(at)neainc.com, Tburns(at)wsd.k12.pa.us, weyoder-pnw(at)erols.com, wayne.russo(at)verizon.net
Subject: Fwd: Fw: The Talking Dog thumbs
Date: Jan 01, 2003
> > > This guy sees a sign in front of a house: "Talking Dog for Sale." He >rings > > > the bell and the owner tells him the dog is in the back yard. > > > > > > The guy goes into the back yard and sees a mutt sitting there. "You >talk?" > > > he asks. > > > > > > "Yep, that's me," the mutt replies. > > > > > > "So, what's your story?" > > > > > > The old hound looks up and says, "Well, I discovered my gift pretty >young > > and > > > I wanted to help the government, so I told the CIA about my talent, >and >in > > no > > > time they had me jetting from country to country, sitting in rooms >with > > spies > > > and world leaders, because no one figured a dog would be >eavesdropping. >I > > was > > > one of their most valuable spies eight years running. I couldn't tell >you > > how > > > many wars I helped prevent. "But, the jetting around really tired me >out, > > > and I knew I wasn't getting any younger and I wanted to settle down. >So >I > > > signed up for a job at the airport to do some undercover security >work, > > > mostly wandering near suspicious characters and listening in. I >uncovered > > > some incredible dealings there ... and was awarded a batch of medals. >"Had > > a > > > wife, a mess of puppies, and now I'm just retired." > > > > > > The guy is amazed. He goes into the house and asks the owner what he >wants > > > for the dog. "Ten bucks and he's yours," the owner says. > > > > > > "But this dog is amazing!" the guy exclaims. "Why on earth are you >selling > > > him and why so cheap?" > > > > > > > > > "He's such a liar," the owner says. "He didn't do any of that shit." > > > > > > > > > ________________________________________________________________________________
Date: Jan 01, 2003
Dave, good idea ...i know what you mean...my kolb goes in nose first and if i do not lift the tail up i would also get hanger rash....i did not build my trailer but i bought it new.... i selected the one with a 4' beaver tail (at the end of course) and it works great!!! also reduces the angle. thanks, Gary r. voigt Dave & Eve Pelletier wrote: > > A suggestion for the tongue jack. My trailer has a drop down rear door and > I had clearance problems when taking the Kolb in or out. The problem is > when the front wheels (or back if you nose it in) start down the door to the > ground and the tail wheel is still in the trailer. The clearance between > the end of the trailer and the bottom of the folded wings becomes very small > and if you're not careful, hangar rash results. My solution was to get rid > of the standard tongue jack and weld on a "Bulldog" brand tongue jack - > 7,000 capacity. The nice thing about this jack is you pull a pin and it > telescopes down to the ground. Reinsert the pin, and then you crank it up - > can get the nose of the trailer a lot higher, thereby reducing the angle > between the door and the floor of the trailer. I cut the long crank handle > off and shortened it and welded a 5/8" socket so the radius is much shorter > and easier to crank. Also, a 5/8" socket on my cordless drill runs it up > and down. Works pretty good. > Arizona Dave > ----- Original Message ----- > From: <DAquaNut(at)aol.com> > To: > Subject: Re: Kolb-List: Trailer building > > > > > Trailer Toters > > Im in the final stages of building my Firefly trailer and was > > hoping for some advice on level trailer heights. Maybe some warnings of > what > > I should look out for. It is enclosed and guestimated to weigh around > > 1500 lbs. I decided To go with a single torsion axle . It is almost a > > replica of Duane da Planes. Mine is minus any windows. I was going to use > 13" > > wheels But I started thinking it might ride better on 15" tires. What > is > > the lowest trailer height I could use & not have to worry too much about > > dragging the rear all the time? Opinions? > > > > Ed Diebel ( Firefly ready for engine , waiting for > > trailer to get finnished) > > > > HAPPY NEW YEAR ALL!!!!!!!! > > > > > ________________________________________________________________________________
Date: Jan 01, 2003
Fellows... you all had very good ideas and i'am going to go with the 3" flush mount ones. one comment about the heat is i should have bought the tinted lexan if it comes that way but i like to take some pics now and then & i thought this might be a detriment to the view. also John can you tell me if the binding tape is riveted to the hinge...i'am about to install the hinge and was thinking of just putting a long piece of flexible plastic that i got with enclosure for the hinge, i'am not sure what this is for but i assume it is for some type of sealant for door or hinge. thanks in advance, Gary r. voigt John Hauck wrote: > > > Where do we buy the 3" snap vents? > > How much? > > Denny > > Denny/Gang: > > Try any of the aircraft parts supply houses. Less > than $5.00 unless inflation has gotten to them. > > The instruction call for a 3 1/4" hole, or > something in that vicinity. I have found that if > I go about 1/16" or so smaller than what is called > for the vents work better. If the holes are too > large the vents don't stay put. Also, if drilled > as spec'ed, vibration will soon enlarge the holes > enough to loosen thing up. > > john h > ________________________________________________________________________________
Date: Jan 01, 2003
> > What is the lowest trailer height I could use & not have to worry too much > > about > > dragging the rear all the time? > My official open Kolb trailer has enough room between the wheel support plates and the road to put a piece of 2x4 under it. It looks scary but I seldom drag it. Only time was driving around the hill at TNK last sept. ________________________________________________________________________________
Date: Jan 01, 2003
Subject: INSTALLING THE SIDE BOW FOR ENCLOSURE!!!
Gents, I'am about to install the side bow for the enclosure and on my fs kxp 1 model but i do not have the gussets on the frame and need to order a nut plate from wicks, however the 1990 copyright drawings that i got from tnk co. don't show a good picture of how to install this arrangement... it says to make a steel gusset out of .063 aluminum and rivet it to the steel frame with 4 rivets, i can see how this should be done but i'am uncertain which way the gusset & nut plate should face...should i install this from the outside of the fabric or the inside of the frame, confused.... could someone send me some pics or a close-up of this arrangement so i can see how all this goes together. i gotta get this thing in the air again... my last flight was in late august and the ice is here for winter flying, today it is light winds...grrrrr. thanks in advance for your help...could not have done it without you guys. Gary r. voigt ________________________________________________________________________________
Date: Jan 01, 2003
> also John can you tell me if > the binding tape is riveted to the hinge...i'am about to install the hinge > Gary r. voigt Gary/Gang: I installed book binding tape after hinge installation and on top of them. Easy enough to do and has lasted a couple years now. john h ________________________________________________________________________________
Date: Jan 01, 2003
Thanks to all who who responded to my Trailer questions: Now that I have made some final decisions I will need to find the least expensive place to purchase some F78 -14 trailer Tires. Thanks Again to All Ed Diebel ________________________________________________________________________________
Date: Jan 02, 2003
Subject: Re: Antenna
I don't have the part numbers. It's a BNC bulk head connector mounted to a aluminum panel installed between the pilots feet which also serves as a floor board in our case. The plate also serves as antenna ground plane. We have a FireFly - had to drill a hole in the nose cone to connect the external antenna to the connector. A step drill works great for this purpose and making 1/4" holes or larger through thin material. I made the antenna from a piece of music wire soldered to the center conductor of a male (center pin) BNC connector. One note, music wire rust - not sure if you can solder stainless other than silver soldering. The antenna is installed on the under side of the nose cone. It is some where around 20-21" in length and bent at about 6-8 inches from the connector to form an approx. 45 degree angle. ----------------+-------------- \----------- The antenna just twist locks onto the external side of the bulk head connector. The coax from the radio has a like connector and connects to the internal (pilot) side. I used Ethernet coax cable for the radio couple reasons. It has a stranded center conductor which reduces center conductor breaking and I can buy it preconnectorized in short lengths. It has proved to work just fine. (Note know what coax cable your using, there are different impedances, example CATV cable is 75 ohm, there are some RG-8 cable of 53-54 ohm, aviation com radios use 50 ohm variety which Ethernet cable is. On my Hawk we did it a little different. Got a whip from Radio Shack (long wire with ball on the end) - and a holder which is a short round shaft with a hole in it to accept the end of the whip and a set screw in the side. You shouldn't have to buy an expensive kit, everything cost about $10. The other end has a female UHF connector. A male UHF-female BNC adapter (connector) screws on it to provide a BNC connection for connection of the radio coax cable. The whip is bent like above. Both seem to work equally well. If you need it I can go to the airport and verify the distance from the connector where we bent the whip and get a close length. We used a SWR meter to fine tune the antenna length to get a good match between the transmitter and the antenna to reduce reflected power. Most hams have one that will work for the 120 MHz range. Your handheld radio on a good day on puts out 4-5 watts peak-peak so most will handle the wattage. If you have any further questions or need more detail, let me know. jerb >Can you give me the number of the bulk head connector used in your antenna >installation. > >Is this a Radio Shack part? > >Jimmy Hankinson >912-863-7384 >Rocky Ford, Ga. 30455 >jhankin(at)planters.net >Kolb Firefly/447/240hrs >Local field, Pegasus/2000/Grass >Airport JYL/Sylvania, Ga. ________________________________________________________________________________
Date: Jan 02, 2003
Rubber torsion axle is the only way to go.Aluminum ramp door it lot lighter. Thanks to all who who responded to my Trailer questions: Now that I have made some final decisions I will need to find the least expensive place to purchase some F78 -14 trailer Tires. Thanks Again to All Ed Diebel --------------------------------- ________________________________________________________________________________
Subject: kit bill of sale "Continued"
Date: Jan 02, 2003
Kolbers, Thanks to everyone who offered suggestions on the string I started a couple weeks ago "kit bill of sale", extra Kudos go to Lloyd O'Dell. Lloyd suggested going the "more than 50% built from miscellaneous parts route" on my 8050-88 form, instead of the kit built route. After trying in vain to contact the previous owner of my Kolb (PARTs)"grin", I gave the aircraft registration office another call today and floated Lloyds idea to them. There response was "no problemo". My response was "Hallelujah" So tommorow I hope to get myself, my Kolbs co-owner Jay Swagger, and our FAA forms down to the notory and get this thing moving again . Hopefully this tact will get it done. Right now my suggestion to anyone who buys a kit, AKA miscellaneous parts from a previous owner is this. Do not register your aircraft as being built from a kit, instead list it as being built from parts. This simplifys the paper trail you need to construct for the Feds. If you look at all the receipts from the parts you buy in addition to the original kits, this is what we pretty much all do anyway. Thanks Lloyd! Wish me luck, Denny Rowe Mk-3 N616DR near completion, maybe next month Leechburg, PA ________________________________________________________________________________
Date: Jan 04, 2003
I got this from a contractor who works out doors during the winter. He says, put on a pair of medical gloves (steal them at your next visit to a Doctor's office) and then put your gloves over them. He says the latex gloves keep the warmth from your hands inside them. I haven't tried this but maybe someone will try it. kj ----- Original Message ----- From: <TAILDRAGGER503(at)aol.com> Subject: Re: Kolb-List: Cold weather gear for hands > > Leather gloves with the army type wool glove inserts fit tight and insulate > nicely. > > Dave > > ________________________________________________________________________________
Subject: Hows the 532 From old Poops
Date: Jan 04, 2003
Richard, How are you doing with the failure analysis on your Rotax? We need somthing technical quick, we are suffering from lack of info exchange. :-) Linda has me hanging light fixtures, how boring. Denny ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: Slow time
> I have decided to attempt to stiffin the wings due to the warpage created by the ailerons....I am thinking of adding a lift strut to the rear "spar" and adding some reinforcment to the full ribs.....any ideas? > Ed in Western NY Morning Ed/Gang: My old Ultrastar, March 1984, had needed the Firestar mod on the inboard wing rib, i.e., the ring rather than the two small tubes sticking into the main spar top and bottom. Also needed a couple more ribs, maybe 7 instead of 5. Would not hurt to reinforce nose and tail of the main ribs with 1/2" and 3/4" aluminum angle. Homer designed the Ultrastar, as he did all his airplanes, for slow flight. To me, the Ultrastar was one of the best slow flyers. Mine would fly at 25 mph indicated on the venturi operated Winter ASI. As long as the needle was on the 25 mph tick mark, she was flying. If it got a needle width off the mark, it was mushing. Those big barn door flaps would control roll right through the mush/stall. Did it so well, many folks clobbered them in, right to the ground, in a full mush. Saw that happen on three seperate occassions. Pilots walked away unscathed but embarassed. I think I would experiment by cutting the aileron cord in half. Might even be able to go shorter than that on the aileron cord, and still be in full roll control. john h PS: Got some flight time in yesterday, after I changed oil in the 912S. Plan on getting some more this afternoon when it warms up a bit. Temps were 50F on the ground and 40F at 3000 feet. Should be warmer today. If it warms up too much, I will have no excuse for not washing the London, KY, mud and Gantt Int AP dust and cow crap off Miss P'fer. She flew well hauling mud, dust and manure yesterday. ________________________________________________________________________________
Subject: transporting a Firestar
Date: Jan 05, 2003
Hi, I am in the process of buying a 1990 Firestar. It is located in the State of Washington, and I live in Colorado. I also purchased a enclosed trailer to transport it in. My question is will I do any damage to the Firestar by transporting it 1200 miles with the wings folded? Should I remove the wings and fasten them somehow inside the trailer? I just want to be sure that I arrive in Colorado without damaging the plane. Any help in this matter would be greatly appreciated. I am to pick it up the 16th of January, so if I need to do anything special, I need to get started on it ASAP. Frank Pruitt fpruitt(at)earthlink.net ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Being flying almost every day for the last two weeks
Greetings, For the last two weeks I have been helping a friend put together (not build) an X-Air so when we start getting into each others way we just go flying. http://members.aol.com/cesaru/ I think Raul, in December, put about 40 hours on his Firestar. This is a picture of Dave Rains and Raul flying formation, I took the picture with a zoom lens. http://www.members.aol.com/willuribe/pic01.jpg Kolb country http://www.members.aol.com/willuribe/pic02.jpg First question; The picture was taken this past Saturday. 2nd question; The picture was taken over Soledad Canyon on the New Mexico-Tejas border. 3rd question; No cold feet, we are in the desert south west and where the state doesn't charge us taxes on our airplanes or ultralights. The picture was taken from the side where the sun doesn't shine that is why the snow has not melted but the sun was keeping us warm. ----- Original Message ----- From: "Ken Korenek" <ken-foi(at)attbi.com> Subject: Re: Kolb-List: Re: Kolb-List Digest: 2 Msgs - 01/03/03 > > WillUribe(at)aol.com wrote: > > > > > http://members.aol.com/uguribe/pic01.jpg > > > > Will Uribe > > El Paso, TX > > FireStar II N4GU > > C-172 N2506U > > Will, > >=A0=A0 Three questions;=A0 when was the picture taken, where was the picture > taken and how cold were your feet? ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: transporting a Firestar
Frank, The problem with transporting the Firestar that great distance is the weight of the folded wings on the fiberglass or aluminum tailwheel rod. This supports the tailwheel and if it cracks or breaks, the wings will get damaged. If you don't want to remove the wings from the plane, you can unhitch them, swing them out a bit, and use foam underneath to secure the top and bottom of the outboard ends to the trailer sides. Don't forget to secure the tailwheel or it with slide into the wings on the first turn. Another option is to keep the wings hitched and support the fuselage tube in a cradle lined with foam or carpet secured to the bed of the trailer. This last method is how I trailer mine to the local field. Be very careful when hitching and unhitching those wings as they are very prone to damage. If they are dropped or allowed to scrape on the pavement it will be very visible when the plane is ready to fly. There are many Firestar wings that have been damaged this way. Using foam canoe mounts on the leading edge is very useful. Ralph Original Firestar writes: > > > Hi, > > I am in the process of buying a 1990 Firestar. It is located in the > State > of Washington, and I live in Colorado. I also purchased a enclosed > trailer > to transport it in. My question is will I do any damage to the > Firestar by > transporting it 1200 miles with the wings folded? Should I remove > the wings > and fasten them somehow inside the trailer? I just want to be sure > that I > arrive in Colorado without damaging the plane. Any help in this > matter > would be greatly appreciated. I am to pick it up the 16th of > January, so if > I need to do anything special, I need to get started on it ASAP. > > > Frank Pruitt > > fpruitt(at)earthlink.net > > > > > > > > > > ________________________________________________________________________________
Date: Jan 05, 2003
Ralph, Thank you very much for the information. Sounds like I could have done some damage to the plane had I just driven away. I think that I will do the fuselage tube cradle, as that would seem to protect the tailwheel assembly Frank -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of ul15rhb(at)juno.com Subject: Re: Kolb-List: transporting a Firestar Frank, The problem with transporting the Firestar that great distance is the weight of the folded wings on the fiberglass or aluminum tailwheel rod. This supports the tailwheel and if it cracks or breaks, the wings will get damaged. If you don't want to remove the wings from the plane, you can unhitch them, swing them out a bit, and use foam underneath to secure the top and bottom of the outboard ends to the trailer sides. Don't forget to secure the tailwheel or it with slide into the wings on the first turn. Another option is to keep the wings hitched and support the fuselage tube in a cradle lined with foam or carpet secured to the bed of the trailer. This last method is how I trailer mine to the local field. Be very careful when hitching and unhitching those wings as they are very prone to damage. If they are dropped or allowed to scrape on the pavement it will be very visible when the plane is ready to fly. There are many Firestar wings that have been damaged this way. Using foam canoe mounts on the leading edge is very useful. Ralph Original Firestar writes: > > > Hi, > > I am in the process of buying a 1990 Firestar. It is located in the > State > of Washington, and I live in Colorado. I also purchased a enclosed > trailer > to transport it in. My question is will I do any damage to the > Firestar by > transporting it 1200 miles with the wings folded? Should I remove > the wings > and fasten them somehow inside the trailer? I just want to be sure > that I > arrive in Colorado without damaging the plane. Any help in this > matter > would be greatly appreciated. I am to pick it up the 16th of > January, so if > I need to do anything special, I need to get started on it ASAP. > > > Frank Pruitt > > fpruitt(at)earthlink.net > > > > > > > > > > ________________________________________________________________________________
Subject: Help
Date: Jan 05, 2003
I am spending much of my time now just trying to figure out what to do next on my Mark IIIXtra. Maybe I can stir up some action on this list. Otherwise, I will start my Lexan installation and fabric covering next. First for Bill Futrell, have you moved to FL yet? I noticed your test message on the board. My question to you is on attaching the Xtra doors. There are no instructions on my plans on the hole drilling or hardware to connect the tabs on the doors with the welded tubes on the fuselage. A second question for Bill and Richard Pike, how did you handle the area of the bow between the top of the windshield and the gap seal? Somewhere in the archives, a mention was made of rubber strip and aluminum piece from Kolb to finish this area. I am planning a fixed gap seal with some soundproofing under it (and behind the seats). For Steven Green, I would like some more details on your aluminum fuel tank (could you send me pictures?). Steven, you recently mentioned that you would get the BRS VLS model instead of the canister if you had it to do over again. I am wondering if there is any significant overall aerodynamic gain with the VLS, since the engine just behind it is so "dirty". The VLS is slightly more expensive and has a 4 year repack vs. 6 yrs for the canister. Since my gap seal will be fixed like Richard Pike's, maybe I can make a fairing in front of the canister and alongside the engine to have less drag. But then do you worry about restricted airflow around the engine and overheating? Thanks in advance, Clay Stuart Danville KY 2 yrs building ________________________________________________________________________________
Date: Jan 05, 2003
From: "Dallas Shepherd" <cen23954(at)centurytel.net>
Frank: What ever you do, don't take those wings off and lay them flat on the=0D trailer. Doesn't work. The cradle on the fuselage is the best and protection on=0D the leading edge of the wings at the ends. I transported a challenger from=0D Seattle to Arkansas and the vibration of the road worked everything loose =0D as you couldn't put enough pressure on the wings without damaging them=0D to counter the road vibration. Something big and spongy under the wheels=0D boxed in will help too. Straps over the wheels or axels to hold them down agains =0D the foam helps a lot. Frequent checks as the vibration is really bad. Lots =0D of tie downs. =0D Dallas Shepherd=0D Norfork, Arkansas =0D =0D -------Original Message-------=0D =0D From: kolb-list(at)matronics.com=0D Date: Sunday, January 05, 2003 10:40:11=0D Subject: Re: Kolb-List: transporting a Firestar=0D =0D =0D Frank,=0D =0D The problem with transporting the Firestar that great distance is the=0D weight of the folded wings on the fiberglass or aluminum tailwheel rod.=0D This supports the tailwheel and if it cracks or breaks, the wings will=0D get damaged. If you don't want to remove the wings from the plane, you=0D can unhitch them, swing them out a bit, and use foam underneath to secure=0D the top and bottom of the outboard ends to the trailer sides. Don't=0D forget to secure the tailwheel or it with slide into the wings on the=0D first turn. Another option is to keep the wings hitched and support the=0D fuselage tube in a cradle lined with foam or carpet secured to the bed of=0D the trailer. This last method is how I trailer mine to the local field.=0D Be very careful when hitching and unhitching those wings as they are very=0D prone to damage. If they are dropped or allowed to scrape on the pavement=0D it will be very visible when the plane is ready to fly. There are many=0D Firestar wings that have been damaged this way. Using foam canoe mounts=0D on the leading edge is very useful.=0D =0D Ralph=0D Original Firestar=0D =0D =0D writes:=0D > =0D > =0D > Hi,=0D > =0D > I am in the process of buying a 1990 Firestar. It is located in the =0D > State=0D > of Washington, and I live in Colorado. I also purchased a enclosed =0D > trailer=0D > to transport it in. My question is will I do any damage to the =0D > Firestar by=0D > transporting it 1200 miles with the wings folded? Should I remove =0D > the wings=0D > and fasten them somehow inside the trailer? I just want to be sure =0D > that I=0D > arrive in Colorado without damaging the plane. Any help in this =0D > matter=0D > would be greatly appreciated. I am to pick it up the 16th of =0D > January, so if=0D > I need to do anything special, I need to get started on it ASAP.=0D > =0D > =0D > Frank Pruitt=0D > =0D > fpruitt(at)earthlink.net=0D > =0D > =0D >=0D >=0D > =0D > =0D > =0D > =0D > =0D > =0D =0D =0D =0D =0D =0D =0D =0D =0D =2E R0lGODlhFAAPALMIAP9gAM9gAM8vAM9gL/+QL5AvAGAvAP9gL////wAAAAAAAAAAAAAAAAAAAAAA AAAAACH/C05FVFNDQVBFMi4wAwEAAAAh+QQJFAAIACwAAAAAFAAPAAAEVRDJSaudJuudrxlEKI6B URlCUYyjKpgYAKSgOBSCDEuGDKgrAtC3Q/R+hkPJEDgYCjpKr5A8WK9OaPFZwHoPqm3366VKyeRt E30tVVRscMHDqV/u+AgAIfkEBWQACAAsAAAAABQADwAABBIQyUmrvTjrzbv/YCiOZGmeaAQAIfkE CRQACAAsAgABABAADQAABEoQIUOrpXIOwrsPxiQUheeRAgUA49YNhbCqK1kS9grQhXGAhsDBUJgZ AL2Dcqkk7ogFpvRAokSn0p4PO6UIuUsQggSmFjKXdAgRAQAh+QQFCgAIACwAAAAAFAAPAAAEEhDJ Sau9OOvNu/9gKI5kaZ5oBAAh+QQJFAAIACwCAAEAEAANAAAEShAhQ6ulcg7Cuw/GJBSF55ECBQDj 1g2FsKorWRL2CtCFcYCGwMFQmBkAvYNyqSTuiAWm9ECiRKfSng87pQi5SxCCBKYWMpd0CBEBACH5 BAVkAAgALAAAAAAUAA8AAAQSEMlJq7046827/2AojmRpnmgEADs ________________________________________________________________________________
Date: Jan 05, 2003
In a message dated 1/5/03 11:56:25 AM Eastern Standard Time, fpruitt(at)earthlink.net writes: > . I think that I will do the > fuselage tube cradle, as that would seem to protect the tailwheel assembly > > Frank > > Don't do just the cradle; get a big roll of foam [I used an "egg-crate" foam mattress] & put it under the LE of the wings about 2' in front of the tailwheel to take most of the load off the fold bracket. Also, nail or screw 2 X 4 blocks front, back, & sides of the main wheels with some strapping or ropes under the blocks & over the axle fittings to immobilize the wheels. Also, immobilize any "extras" such as boxes so they don't get against your lovely Firestar & knock a hole in your wing [don't ask]. Don't drive too fast & check your load every 100 miles or so. Good luck Shack FS II SC ________________________________________________________________________________
Subject: Winter flying fun
Date: Jan 05, 2003
My daughter was visiting for the holiday and agreed to come out and shoot a few pictures for me the other day, and heeeeeeere they are! http://www.hiperlightaircraft.com/kolb/winter_fun -Ken Fackler Mark II / 503 Rochester MI ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Rotax 532 mystery clearing somewhat
"Curioser and curioser said Alice..." Pressure checked the crankcase - perfect. Only thing left to check was the rotary valve timing, - guess what? Did you know a Rotax 532 will still turn 4,700 RPM with the rotary valve timing retarded 115 degrees? So now I know where the gremlin is hiding, it's time to pull the cases open, examine the rotary valve shaft and gears and figure out why and how the thing jumped time. Anybody with any similar occurances? Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: Help
>A >second question for Bill and Richard Pike, how did you handle the area of >the bow between the top of the windshield and the gap seal? Somewhere in >the archives, a mention was made of rubber strip and aluminum piece from >Kolb to finish this area. I am planning a fixed gap seal with some >soundproofing under it (and behind the seats). Not applicable to my current situation, but originally I used a rubber molding channel, extended the windshield past the metal loop by about 3/4", and glued on a rubber piece, Aircraft Spruce part # 05-01300, top of page 126 in the 2001-2002 catalog. It closed the gap up. > >Since my gap seal will be fixed like Richard Pike's, maybe I can make a >fairing in front of the canister and alongside the engine to have less drag. > But then do you worry about restricted airflow around the engine and >overheating? Make it out of balsa wood, use it to fair the air around the engine smoothly. If it is a water cooled 582 or similar, don't worry about it, cooling is from the radiator, not ambient airflow. As long as there is some airflow, it will be fine. Be careful if you fully cowl it, the exhaust gives off tons of heat, that is the only problem. My J-6 was fully cowled, the big Rotax muffler was the only problem, the engine was fine fully cowled, Vince Nicely's Rotax 582 Sonerai is fully cowled, very tight, and cools great. Richard Pike MKIII N420p (420ldPoops) > >Thanks in advance, >Clay Stuart >Danville KY >2 yrs building > > ________________________________________________________________________________
Subject: Test
Date: Jan 05, 2003
This is my 2nd test today. I seem to have been bumped from the List. Tried re-subscribing this morning, but still no results, and my 1st test didn't come thru. If I AM coming thru, could someone please email me off List ?? Thanks. Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose www.gogittum.com ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: Test
> >This is my 2nd test today. I seem to have been bumped from the >List. Tried re-subscribing this morning, but still no results, and my 1st >test didn't come thru. If I AM coming thru, could someone please email >me off List ?? Thanks. Lar. > It's still not working Lar, but keep trying!! >===================================================================== ________________________________________________________________________________
From: "Beauford Tuton" <beauford(at)tampabay.rr.com>
Subject: Re: Test
Date: Jan 05, 2003
I didn't get it either, Lar... Right after Possum didn't get it.... Hope this helps... Beauford ----- Original Message ----- From: "possums" <possums(at)mindspring.com> Subject: Re: Kolb-List: Test > > > > >This is my 2nd test today. I seem to have been bumped from the > >List. Tried re-subscribing this morning, but still no results, and my 1st > >test didn't come thru. If I AM coming thru, could someone please email > >me off List ?? Thanks. Lar. > > > > > It's still not working Lar, but keep trying!! > > >===================================================================== > > --- ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: Test
Biglar--sumthin wrong w/ yer address! Tried you off line and bounced BN ________________________________________________________________________________
Subject: Lightweight stove
Date: Jan 05, 2003
Lightweight Stove While this application is intended for lightening equipment for camping it is also extremely suitable for Ultra lights, or survival equipment, since every ounce counts. My stove and pot with lid weighs in at 8.5 oz. The stove burns Denatured Alcohol, and will burn for approximately 30 minutes on one fluid ounce of fuel. Boiling 2 cups of water in eight minutes. That will allow you to cook for instance "Top Ramen", or coffee for that matter. The cost for this little jewel is $.10 cents. It is made by cutting two soda cans and sticking them together. One is cut about a 1/8 inch from the bottom. The other is cut about 2 inches from the bottom of the other can. The smallest bottom is placed "bottom up" on a flat surface. ( I prefer to "JB weld" the two together, to make sure that they do not leak) Then the biggest "bottom" is placed "bottom up"over the first. Then pin holes are punched around the edge of the upturned bottom, I use a thumb tack. A hole is placed in the center of the upturned bottom for a filler hole. Make it small enough that a screw can cut threads into it. This will allow you to plug the filler hole after you have filled the stove. A piece of 1/4 inch hardware cloth about two inches wide, a piece of "flashing" the same size, two paper clips and you are in business. The hardware cloth is coiled to fit the bottom of your pot, paper clips hold it to size, the flashing is then put inside the circle to keep the wind from blowing your flame all over. The pot sets on top of the hardware cloth, with your stove inside the hardware cloth. Fill your stove, reinsert the screw plug, pour the cavity on the top of the stove full of fuel, light it up. The stove has to have the fuel heated for it to turn to vapor so that it will light and burn. This is the function of the fuel on top. Once the fuel is heated it will cause the vapor to come out the holes around the top and make a nice hot cooking fire just like a regular gas stove. Once it has started burning, you will have to let it burn out. While I would like to tell you that I thought of the whole thing by myself, that would be untrue. It is borrowed from a friend that helps the Boy Scouts with their camping trips and activities. I do not know just where it originates, but I do know a good thing when I see it. Try it you will be amazed. You will notice that I "made" a jig to do my cuts. You can of course do the cuts with a pair of scissors, however scoring the can with a cardboard cutter until the can begins to separate is a much cleaner method. JB Weld will alleviate this requirement however. I will post pictures to the Photo share for those that would like to see it. Larry ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: Winter flying fun
Nice pics Ken. If I may make a suggestion crop and enlarge the important parts of the pic before posting them. It is a lot easier and faster for us dial up modem guys to see them. I'll have to get over and see your Kolb in person some day > >My daughter was visiting for the holiday and agreed to come out and shoot >a few pictures for me the other day, and heeeeeeere they are! > >http://www.hiperlightaircraft.com/kolb/winter_fun > >-Ken Fackler >Mark II / 503 >Rochester MI ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: geo
> >Woody and kurious kolbers, yes, as far as I know--and a lie-down four >banger too. -Only one caveat, you would have to rig your own mount. >When I bought my redrive Jeron (Raven) persuaded me to use the >upright since they had everything designed and ready to go. Since both >versions stop about the same amount of air, the only advantage would be >a possible lower thrust line if you use a shorter prop. -BB I think the lie down 4 just looks "neater". What was your total cost to get this drive system ready to go? ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Re: Lightweight stove
Larry I would like to see a picture of this device. Were do I access photoshare? Thanks Ron W ________________________________________________________________________________
Subject: Sunday outing
Date: Jan 05, 2003
A few of us went for a fruitshake via ultralight today to "Robert is Here <http://lafa.com/Photos/Robert%20is%20Here/001.jpg> " Had to land in a dirt field and taxi through ploughed fields to get to the place. http://lafa.com/Photos/Robert%20is%20Here/005.jpg http://lafa.com/Photos/Robert%20is%20Here/006.jpg Kolb to Kolb pics taken on the way home: http://lafa.com/Photos/Robert%20is%20Here/008.jpg http://lafa.com/Photos/Robert%20is%20Here/010.jpg ________________________________________________________________________________
Date: Jan 05, 2003
> > Larry > I would like to see a picture of this device. > Were do I access photoshare? > > > Thanks > Ron W > I just posted them to the photo share tonight. They should show up soon, or if you can't wait I can email them to you off list. I have reduced them to email size. Larry ________________________________________________________________________________
Date: Jan 06, 2003
Subject: Re: geo
>> >> >> For my 1 liter 3 cyl, about $3000 total including the cut down pan /dry sump, remote tank, mounts, redrive, exhaust, bought separately-carb, radiator. Raven strongly recommends the geo fuel injection and they're right. It's just that I'm a knothead and had to design a carb system of my own. I don't have any illusions about it being a super powerhouse, I don't need that. Just a nice easy starting, smooth running , very reliable and low maintenance mill. Once it's finished I just want to fly, not fix.-BB >> >> > > I think the lie down 4 just looks "neater". What was your total cost to >get this drive system ready to go? > > > > ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
I purchased a Facet pump to supplement the Rotax's pulse pump. My problem is no matter where I locate the pump it will not prime the lines to the Carburetor. In a test of the pump outside the system, the pump appears to push the gas just fine. The instructions talk about air in the system may keep the pump from priming. If this is the case how can the facet replace the squeeze bulb? How does the facet pump differ from the squeeze bulb in pushing the fuel through the air filled lines? I have check out the archives. Did not find a solution to my question. John Wood Firestar N670JW ________________________________________________________________________________
Date: Jan 06, 2003
Subject: Re: Facet Pump
The Facet needs to be at the lowest point in the system, and gravity fed. If your fuel line exits your tank from the top, you may be up the creek. Richard Pike MKIII N420P (420ldPoops) > >I purchased a Facet pump to supplement the Rotax's pulse pump. My problem is >no matter where I locate the pump it will not prime the lines to the >Carburetor. In a test of the pump outside the system, the pump appears to >push the gas just fine. The instructions talk about air in the system may >keep the pump from priming. If this is the case how can the facet replace >the squeeze bulb? How does the facet pump differ from the squeeze bulb in >pushing the fuel through the air filled lines? I have check out the >archives. Did not find a solution to my question. > >John Wood >Firestar N670JW > > ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
I have a Facet on my MK III mounted below the gas tanks and my fuel lines exit from the top of the tank. It has worked fine from day one. Terry -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike Subject: Re: Kolb-List: Facet Pump The Facet needs to be at the lowest point in the system, and gravity fed. If your fuel line exits your tank from the top, you may be up the creek. Richard Pike MKIII N420P (420ldPoops) > >I purchased a Facet pump to supplement the Rotax's pulse pump. My problem is >no matter where I locate the pump it will not prime the lines to the >Carburetor. In a test of the pump outside the system, the pump appears to >push the gas just fine. The instructions talk about air in the system may >keep the pump from priming. If this is the case how can the facet replace >the squeeze bulb? How does the facet pump differ from the squeeze bulb in >pushing the fuel through the air filled lines? I have check out the >archives. Did not find a solution to my question. > >John Wood >Firestar N670JW > > ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
John, do you have the pump installed below the fuel tank? If I remember correctly, when I installed mine that was one of the installation requirements. I think that air in the line BEFORE the pump can be a problem, but after the pump they shouldn't be. At least, in my set-up air in the line after the pump hasn't impeded the flow. Peter I purchased a Facet pump to supplement the Rotax's pulse pump. My problem is no matter where I locate the pump it will not prime the lines to the Carburetor. ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
My fuel tank exits from the top, but the fuel line then goes down to below the base of the tank before entering the pump. This ensures the required positive (gravity fed) pressure to the pump at all times. Provided the line remains primed, it makes no difference if your line comes out of the top or bottom of the tank. IMHO, if you use plastic tanks, top is better than bottom as it eliminates the chance of leakage. Peter Volum -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Subject: Re: Kolb-List: Facet Pump The Facet needs to be at the lowest point in the system, and gravity fed. If your fuel line exits your tank from the top, you may be up the creek. Richard Pike MKIII N420P (420ldPoops) > >I purchased a Facet pump to supplement the Rotax's pulse pump. My problem is >no matter where I locate the pump it will not prime the lines to the >Carburetor. In a test of the pump outside the system, the pump appears to >push the gas just fine. The instructions talk about air in the system may >keep the pump from priming. If this is the case how can the facet replace >the squeeze bulb? How does the facet pump differ from the squeeze bulb in >pushing the fuel through the air filled lines? I have check out the >archives. Did not find a solution to my question. > >John Wood >Firestar N670JW > > ________________________________________________________________________________
Date: Jan 06, 2003
Subject: Re: Oil injection
I have a pump from a 503 that has never been used. Give me an email at dama(at)mindspring.com for more deatls. Thanks, Kip ________________________________________________________________________________
Date: Jan 06, 2003
Subject: Facet Pump
OK, I obviously missed it on that one - question: Will the Facet draw the fuel up, over and down to itself and then keep the flow going, or does it need to have fuel in the lines to itself (primed) before it starts to work? Richard Pike MKIII N420P (420ldPoops) > >I have a Facet on my MK III mounted below the gas tanks and my fuel lines >exit from the top of the tank. It has worked fine from day one. > >Terry > >-----Original Message----- >From: owner-kolb-list-server(at)matronics.com >[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike >To: kolb-list(at)matronics.com >Subject: Re: Kolb-List: Facet Pump > > >The Facet needs to be at the lowest point in the system, and gravity fed. >If your fuel line exits your tank from the top, you may be up the creek. > >Richard Pike >MKIII N420P (420ldPoops) > > >> >>I purchased a Facet pump to supplement the Rotax's pulse pump. My problem >is >>no matter where I locate the pump it will not prime the lines to the >>Carburetor. In a test of the pump outside the system, the pump appears to >>push the gas just fine. The instructions talk about air in the system may >>keep the pump from priming. If this is the case how can the facet replace >>the squeeze bulb? How does the facet pump differ from the squeeze bulb in >>pushing the fuel through the air filled lines? I have check out the >>archives. Did not find a solution to my question. >> >>John Wood >>Firestar N670JW >> >> > > ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
I think it will. I don't remember priming the lines the first time I fired mine up and I have never run it out of gas, thank goodness. I did change the plumbing one time, so I had the lines disconnected and I didn't do anything special to get it pumping again. Terry -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike Subject: RE: Kolb-List: Facet Pump OK, I obviously missed it on that one - question: Will the Facet draw the fuel up, over and down to itself and then keep the flow going, or does it need to have fuel in the lines to itself (primed) before it starts to work? Richard Pike MKIII N420P (420ldPoops) > >I have a Facet on my MK III mounted below the gas tanks and my fuel lines >exit from the top of the tank. It has worked fine from day one. > >Terry > >-----Original Message----- >From: owner-kolb-list-server(at)matronics.com >[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike >To: kolb-list(at)matronics.com >Subject: Re: Kolb-List: Facet Pump > > >The Facet needs to be at the lowest point in the system, and gravity fed. >If your fuel line exits your tank from the top, you may be up the creek. > >Richard Pike >MKIII N420P (420ldPoops) > > >> >>I purchased a Facet pump to supplement the Rotax's pulse pump. My problem >is >>no matter where I locate the pump it will not prime the lines to the >>Carburetor. In a test of the pump outside the system, the pump appears to >>push the gas just fine. The instructions talk about air in the system may >>keep the pump from priming. If this is the case how can the facet replace >>the squeeze bulb? How does the facet pump differ from the squeeze bulb in >>pushing the fuel through the air filled lines? I have check out the >>archives. Did not find a solution to my question. >> >>John Wood >>Firestar N670JW >> >> > > ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
Thanks for the responses to my Facet problem. I have tried the pump both above and below the tank and it still did not work. That is what prompted me to seek advise from the experts. Based on your responses it seems that I might have a bad pump. I purchaed the lowest pressure pump. Maybe I need more pressure to overcome the air in the lines? John Wood Firestar N670JW -----Original Message----- From: Terry [mailto:tswartz(at)hydrosoft.net] Subject: RE: Kolb-List: Facet Pump I think it will. I don't remember priming the lines the first time I fired mine up and I have never run it out of gas, thank goodness. I did change the plumbing one time, so I had the lines disconnected and I didn't do anything special to get it pumping again. Terry -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike Subject: RE: Kolb-List: Facet Pump OK, I obviously missed it on that one - question: Will the Facet draw the fuel up, over and down to itself and then keep the flow going, or does it need to have fuel in the lines to itself (primed) before it starts to work? Richard Pike MKIII N420P (420ldPoops) > >I have a Facet on my MK III mounted below the gas tanks and my fuel lines >exit from the top of the tank. It has worked fine from day one. > >Terry > >-----Original Message----- >From: owner-kolb-list-server(at)matronics.com >[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike >To: kolb-list(at)matronics.com >Subject: Re: Kolb-List: Facet Pump > > >The Facet needs to be at the lowest point in the system, and gravity fed. >If your fuel line exits your tank from the top, you may be up the creek. > >Richard Pike >MKIII N420P (420ldPoops) > > >> >>I purchased a Facet pump to supplement the Rotax's pulse pump. My problem >is >>no matter where I locate the pump it will not prime the lines to the >>Carburetor. In a test of the pump outside the system, the pump appears to >>push the gas just fine. The instructions talk about air in the system may >>keep the pump from priming. If this is the case how can the facet replace >>the squeeze bulb? How does the facet pump differ from the squeeze bulb in >>pushing the fuel through the air filled lines? I have check out the >>archives. Did not find a solution to my question. >> >>John Wood >>Firestar N670JW >> >> > > ________________________________________________________________________________
Date: Jan 06, 2003
> I think it will. I don't remember priming the lines the first time I fired > Terry Terry/Gang: I use and have used the Facet pump in several applications: Rotax 447 (auxilary) 582 " 912 " 912S " Onan 4 kw generator (primary) Ford 351W marine engine (auxilary) All have been self priming. The Onan pulls fuel from an aux tank in the front of my Dodge/Cummins truck bed to the rear where the Onan is permanently installed. No problems with any of them other than salt water corrosion in the boat and that was because of the location I picked out to install it. Lesson learned. :-) Don't buy a no name look alike product from JC Whitney and expect it to perform like a Facet. I have already done that and learned the hard way. Facet also sells under the Purolator brand name. john h (Got out and exercised Miss P'fer this weekend. 1.4 hrs Sat and 4.1 hours Sun. Felt good!) ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
Stay with the low pressure so you don't overpower the float valve. Terry -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Wood, John T. Subject: RE: Kolb-List: Facet Pump Thanks for the responses to my Facet problem. I have tried the pump both above and below the tank and it still did not work. That is what prompted me to seek advise from the experts. Based on your responses it seems that I might have a bad pump. I purchaed the lowest pressure pump. Maybe I need more pressure to overcome the air in the lines? John Wood Firestar N670JW -----Original Message----- From: Terry [mailto:tswartz(at)hydrosoft.net] Subject: RE: Kolb-List: Facet Pump I think it will. I don't remember priming the lines the first time I fired mine up and I have never run it out of gas, thank goodness. I did change the plumbing one time, so I had the lines disconnected and I didn't do anything special to get it pumping again. Terry -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike Subject: RE: Kolb-List: Facet Pump OK, I obviously missed it on that one - question: Will the Facet draw the fuel up, over and down to itself and then keep the flow going, or does it need to have fuel in the lines to itself (primed) before it starts to work? Richard Pike MKIII N420P (420ldPoops) > >I have a Facet on my MK III mounted below the gas tanks and my fuel lines >exit from the top of the tank. It has worked fine from day one. > >Terry > >-----Original Message----- >From: owner-kolb-list-server(at)matronics.com >[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike >To: kolb-list(at)matronics.com >Subject: Re: Kolb-List: Facet Pump > > >The Facet needs to be at the lowest point in the system, and gravity fed. >If your fuel line exits your tank from the top, you may be up the creek. > >Richard Pike >MKIII N420P (420ldPoops) > > >> >>I purchased a Facet pump to supplement the Rotax's pulse pump. My problem >is >>no matter where I locate the pump it will not prime the lines to the >>Carburetor. In a test of the pump outside the system, the pump appears to >>push the gas just fine. The instructions talk about air in the system may >>keep the pump from priming. If this is the case how can the facet replace >>the squeeze bulb? How does the facet pump differ from the squeeze bulb in >>pushing the fuel through the air filled lines? I have check out the >>archives. Did not find a solution to my question. >> >>John Wood >>Firestar N670JW >> >> > > ________________________________________________________________________________
Date: Jan 06, 2003
> I purchaed the lowest pressure pump. Maybe I need > more pressure to overcome the air in the lines? > > John Wood John W/Gents: I am no Facet expert, but pressure regulation does not seem to be your problem. If you are unsure about the pump, pull it out, plumb it with a pick up and discharge hose. Wire it up and see if, in fact it will pump fuel. You can raise it and lower it depending on how much hose you plumb to it for your experiment. I assume the pump is operating (getting the rattatatta noise) but not self priming and pumping fuel from the discharge line. Someone indicated the pump would shut off when it reached the regulated pressure. None of my Facets shut down at that point. They continue to operate even after reaching regulated pressure point. Make sure you have not air leaks in your lines. john h ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 06, 2003
I didn't have to prime the first time on my set-up either. Even if the auxiliary Facet pump wasn't self-priming, wouldn't the fuel line self-prime as a result of the main pump doing its work during the initial cranking? This may take some time the first time, but after that the lines would remain primed and the Facet pump would do its job from the start. Before changing pumps to a higher pressure model make sure you check the engine manual so you don't exceed the maximum pressure it is designed to work with. You don't want gas to start spewing out. Peter -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Terry Subject: RE: Kolb-List: Facet Pump I think it will. I don't remember priming the lines the first time I fired mine up and I have never run it out of gas, thank goodness. I did change the plumbing one time, so I had the lines disconnected and I didn't do anything special to get it pumping again. Terry -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Richard Pike Subject: RE: Kolb-List: Facet Pump OK, I obviously missed it on that one - question: Will the Facet draw the fuel up, over and down to itself and then keep the flow going, or does it need to have fuel in the lines to itself (primed) before it starts to work? Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Subject: Aileron and flap hinges
Date: Jan 06, 2003
Greetings I am in the process of mating the ailerons and flaps to the recently completed wings. The manual on the subject seems straight forward but does anyone have any hints that will aid in the needed accuracy of hinge placement? Thank you ahead of time. Dick Neitzel Sayner WI Mark III neitzel(at)newnorth.net ________________________________________________________________________________
Date: Jan 06, 2003
John and All, You may want to consider adding a pressure regulator to your fuel system when you are adding an electric aux fuel pump. Steve ________________________________________________________________________________
Date: Jan 06, 2003
> You may want to consider adding a pressure regulator to your fuel system when > you are adding an electric aux fuel pump. > > Steve Steve/Gents: I personally have not found a pressure regulator necessary in any of the applications I have used the Facet as an aux pump. john h ________________________________________________________________________________
Subject: Re: Aileron and flap hinges
Date: Jan 06, 2003
Dick, Take a look at how I did it on the wing attachment page of my web site...it is page 3 or 4. To get the 3 hinges EXACTLY even with each other on my firefly, I made some tblocks of aluminum, with a hole the size of the hinge pin just where the print calls for it. Then cut an extra long section of hinge pin and stick it thru the hinge, and the "t block"..this was you keep the prescribed distance from the trailing edge to the aileron and they all 3 will be just right. when I was finished, those hinges moved like they were on bearings....perfect, with no a hint of binding. http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini Firefly 098 ________________________________________________________________________________
Subject: Paul Poberezny Visit
Date: Jan 06, 2003
For any of you Listers in or near SE Michigan this week: ----- Original Message ----- From: "Troy Toelle" <ttoelle(at)eaa.org> Subject: Paul Poberezny Visit EAA Chapter 1413 proudly presents: PAUL POBEREZNY For 30 years he said "airplane, sir" as he served his country as a pilot, flight instructor and mechanic. He holds all seven military pilot wings. The roots of EAA began with Paul's collection of airplane parts from crashes and junked aircraft, which he turned into a museum in the family basement. EAA's first fly-in was in Milwaukee in 1953. Paul served as president until 1989, when he was named chairman of the board. During that time, EAA had grown from a basement operation into a worldwide organization with more than 100,000 members. Paul has more than 30,000 flight hours in over 400 types of aircraft, including more than 170 homebuilts and 15 of his own design. Saturday, July 24, 1999 Paul was inducted into the National Aviation Hall Of Fame in Dayton, Ohio. Thursday January 9, 2003 - 7:30pm Michigan Aviation Oakland County International Airport PLEASE JOIN US FOR THIS HISTORIC NIGHT For more information please e-mail mikeo(at)eaaptk.org Or visit our website at www.eaaptk.org ________________________________________________________________________________
Date: Jan 06, 2003
From: Duncan McBride <duncanmcbride(at)comcast.net>
I have a facet pump that sits even with the bottom of the plastic tanks. I run the line out the top of the tanks and down in a loop below the bottom of the tanks and into the pump. From there the line goes up about 30 inches to the mechanical pump. It primed the mechanical pump and carbs just fine. With the gas turned off ( valve between the tank and the facet pump) the facet clicks pretty loud - when I turn on the gas it clicks quieter until the pressure comes up then it gets a little quieter still, but you can still hear it ok. Have you disconnected the fuel line between teh carbs and the mechanical pump to see if the facet is pumping fuel through the mechanical pump? ----- Original Message ----- From: "Richard Pike" <rwpike(at)preferred.com> Subject: Re: Kolb-List: Facet Pump > > The Facet needs to be at the lowest point in the system, and gravity fed. > If your fuel line exits your tank from the top, you may be up the creek. > > Richard Pike > MKIII N420P (420ldPoops) > > > > > >I purchased a Facet pump to supplement the Rotax's pulse pump. My problem is > >no matter where I locate the pump it will not prime the lines to the > >Carburetor. In a test of the pump outside the system, the pump appears to > >push the gas just fine. The instructions talk about air in the system may > >keep the pump from priming. If this is the case how can the facet replace > >the squeeze bulb? How does the facet pump differ from the squeeze bulb in > >pushing the fuel through the air filled lines? I have check out the > >archives. Did not find a solution to my question. > > > >John Wood > >Firestar N670JW > > > > > > ________________________________________________________________________________
Date: Jan 06, 2003
Subject: Re: Vamoose On-Going
> > >$%*#@ Chinese tap is just .002 larger than standard, >and when I felt it get tight in the 1st hole, I stopped, and started >checking. Glad I did ! ! ! This is one place where maximum strength is of >utmost importance, and sloppy threads don't get it. Gosh Lar I would have just got the old hacksaw out (new blade) and just hacked an eighth off the end of each bolt and touched it up with a file. Perhaps just grinding the threads off the first eighth on an inch would be enough. Probably 5 minutes each. I got faith in ya pal. Put me down for late summer of 04 for first flight. ________________________________________________________________________________
From: "Richard Swiderski" <swiderski@advanced-connect.net>
Subject: Re: UltraStar Wing Mod
Date: Jan 06, 2003
Ed, I looked into the options of stiffening my ol US wings also. The trailing edge tube is only .028" thick. It probably wouldn't take the stress. John's suggestion about stiffening the inboard edge of the main spar is what I did. It made such a huge difference that I didn't even consider doing anything more. I described the process in the archives. If you can't find them, call me, 352-307-9009 Regarding landing gear, I found that large diameter, thin wall chromemoly steel tubing with a bungie cord supension was the lightest way to go & still have the strength you need. They were abused & kept comming.back for more You can see it at the website John posted http://lafa.com/Photos/Robert%20is%20Here/006.jpg. also checkout the nose job, It weighed only a coupl of lbs as it was out of stitz & thin aluminum tube They were abused & kept comming.back for more >>>> I have decided to attempt to stiffin the wings due to the warpage created by the ailerons....I am thinking of adding a lift strut to the rear "spar" and adding some reinforcment to the full ribs.....any ideas? Of coarse, I am trying to keep the weight down but may have created a "fat one" already with Azusa brakes and modified landing gear with fiberglass 1.25 inch rods. To stay legal I may have to forget all instruments except engine gauges and forget the fiberglass nose fairing. The new seat tank is heavy too , and with 6 gallons the legal issue is comprimised anyway....... Ed in Western NY > > > > ________________________________________________________________________________
Date: Jan 06, 2003
> >Dick, >Take a look at how I did it on the wing attachment page of my web site...it >is page 3 or 4. > > >http://www.geocities.com/dagger369th/my_firefly.htm > >Don Gherardini >Firefly 098 Great workmanship and great web site. Kinda puts my rude and crude ways to shame. ________________________________________________________________________________
Date: Jan 06, 2003
Subject: Re: The Stork
> John, where is this picture taken? Is he an active pilot? I lost track > of him, Last I heard he was down miami way. Sentimental Richard Richard/Gents; Know what you mean. 15 years ago I was chasing that little Ultrastar around the Gator Ultralight Strip with my little Firestar. Richard didn't know I existed. I tailed him for 15 minutes, then let him see me. I might add, I was right on his tail too. He was flying around the area north of the field. There was an antenna tower up there. In the area where HWY 27 and the interstate interset, IIRC. I was flying from Alabama to Miami in Nov 1987, and return. A 1,500 mile flight, round trip. My first extra long flight. A couple weeks prior, I had flown from Alabama to Lake City, FL, for the North Florida Airshow. That was my first overnight flight. Was a test to see if I had everything I needed to get the job done. That was about a 600 mile round trip. Those two flights were the beginning of many more ultralight flights over the years. At that time I had no idea that I would ever fly to Alaska. Six years later I landed at Dead Horse/Prudoe Bay, Alaska. Still amazes me............... john h ________________________________________________________________________________
Date: Jan 06, 2003
Subject: Ivo prop repair
I have been chatting with Ivo prop about repairing a chip in my prop blade. They said the best is to use a polyester resin for the repair. I a wondering if anybody out there has advice/experience on how to use and buy a polyster resin. How is it purchased? I am familiar with epoxy and fiberglass resin, but when they say a polyetser resin, what exactly do they mean? Maybe the fiberglass resin is just that?? Thanks Tim ________________________________________________________________________________
Subject: Re: Ivo prop repair
Date: Jan 06, 2003
My experience with fiberglass and resin is woodenboat related. There's two resins that are used with fiberglass. One is epoxy and the other is polyester. Poly is cheaper but it doesn't stick to wood as well and isn't impervious to water like epoxy is. The bad rap that fiberglass covered wooden boats get is due mostly to poly resin delaminating from the wood. Did IVO specifically say not to use epoxy? From what I've read on the boat building websites you can put epoxy over polyester but NOT the other way around. I wonder if epoxy weighs more the poly. Maybe a weight/balance problem? I'd think it would have to be a pretty big "chip" to throw the weight off. Just thinking out loud... Hugh ----- Original Message ----- From: <Timandjan(at)aol.com> Subject: Kolb-List: Ivo prop repair > > I have been chatting with Ivo prop about repairing a chip in my prop blade. > They said the best is to use a polyester resin for the repair. I a > wondering if anybody out there has advice/experience on how to use and buy a > polyster resin. How is it purchased? I am familiar with epoxy and fiberglass > resin, but when they say a polyetser resin, what exactly do they mean? Maybe > the fiberglass resin is just that?? > > Thanks > > Tim > > ________________________________________________________________________________
Date: Jan 07, 2003
How about the old baking soda and crazy glue repair? Hasn't it been discussed on this list in the past? Or maybe it was FLY-UL? Good for small nicks, don't know how big is the nick in question. Bob N. ________________________________________________________________________________
Date: Jan 06, 2003
Actually there are three resins commonly used in the home built aircraft, Epoxy, Polyester, and Vinyl Ester. There are two types of Polyester resin, one which contains wax for single coat or the finishing layup. The wax rises to the surface and facilities sanding. The other does not contain any wax and stay a little tacky. It is used for multiple layups (layers) - last layup would use the one which contains wax to allow finish sanding. See Aircraft Spruce - they can provide you with the correct material for your application. A small quart kit will cost around $20. How big of nick do you have? I have heard of using baking soda mixed with super glue as a filler for small nicks. If you have a larger especially deep nick better use the resin. Below is the web site link I have for them - it appeared to be down at this time, try it later and see what happens. http://www.aircraft-spruce.com/ jerb > >My experience with fiberglass and resin is woodenboat related. There's two >resins that are used with fiberglass. One is epoxy and the other is >polyester. Poly is cheaper but it doesn't stick to wood as well and isn't >impervious to water like epoxy is. The bad rap that fiberglass covered >wooden boats get is due mostly to poly resin delaminating from the wood. > >Did IVO specifically say not to use epoxy? From what I've read on the boat >building websites you can put epoxy over polyester but NOT the other way >around. I wonder if epoxy weighs more the poly. Maybe a weight/balance >problem? I'd think it would have to be a pretty big "chip" to throw the >weight off. > >Just thinking out loud... >Hugh >----- Original Message ----- >From: <Timandjan(at)aol.com> >To: >Subject: Kolb-List: Ivo prop repair > > > > > > I have been chatting with Ivo prop about repairing a chip in my prop >blade. > > They said the best is to use a polyester resin for the repair. I a > > wondering if anybody out there has advice/experience on how to use and buy >a > > polyster resin. How is it purchased? I am familiar with epoxy and >fiberglass > > resin, but when they say a polyetser resin, what exactly do they mean? >Maybe > > the fiberglass resin is just that?? > > > > Thanks > > > > Tim > > > > > > ________________________________________________________________________________
Date: Jan 06, 2003
> If you have a larger especially > deep nick better use the resin. > Below is the web site link I have for them - it appeared to be down at this > time, try it later and see what happens. > http://www.aircraft-spruce.com/ > jerb Jerb/Gents: Think I'd go down to Wal*Mart, buy a small epoxy kit, two little tubes, one of resin, one of catalyst, for a couple bucks. I use JB Weld on the Warp Drive. I have used epoxy on wooden props, the baking soda super glue process. They all work well. A $20.00 kit might be an overkill for a nick or two. :-) john h ________________________________________________________________________________
Date: Jan 07, 2003
Found a decent tap at work, so borrowed it for a day, and tapped out the holes this afternoon, and set the bolts in. Still a little shy, so tapered 1/8" of the end of the bolts, and torqued them down with red loc-tite. Looks like great minds run in the same circles. Still left over 1/2" of solid threads holding, but I don't like those shallow socket heads. There's also 4 steel pins locating that part, as well, so I doubt if it'll go anywhere. I was a little off in the difference in size of those 2 taps, too. Something to keep in mind when doing critical work. Pics of both going on photoshare in a couple of minutes. C'mon, Matt ! ! ! Gogittum Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose www.gogittum.com ----- Original Message ----- From: "woody" <duesouth(at)govital.net> Subject: Re: Kolb-List: Vamoose On-Going > > > > > > > >$%*#@ Chinese tap is just .002 larger than standard, > >and when I felt it get tight in the 1st hole, I stopped, and started > >checking. Glad I did ! ! ! This is one place where maximum strength is of > >utmost importance, and sloppy threads don't get it. > > > Gosh Lar I would have just got the old hacksaw out (new blade) and just > hacked an eighth off the end of each bolt and touched it up with a file. > Perhaps just grinding the threads off the first eighth on an inch would be > enough. Probably 5 minutes each. > I got faith in ya pal. Put me down for late summer of 04 for first flight. > > ________________________________________________________________________________
Date: Jan 07, 2003
Subject: Re: prop repair/protection
Im about to run a wooden one piece two blader at 6000 rpm on my kids hovercraft [lots of dirt in the air].Anybody got a contact or specification /part number for a good prop tape ?? we used to use it on rolls royce turbo props in the far east,and I thought it was a bit mickey mouse then, but now.......... Vnz ________________________________________________________________________________
Subject: Re:Facet pump priming
Date: Jan 07, 2003
Flyboys, The initial priming of the Facet pump requires you to remove the carburator bowl or the fuel line to the carburator. The float in the carburator, if full, will not let the air out of the fuel line. DO NOT use a high pressure pump or you will flood your carburator, all you need is 31/2 to 4 psi. Hope this helps. Hans van Alphen Mark III Xtra BMW powered 90 hours. N100MX ________________________________________________________________________________
Date: Jan 07, 2003
I am petty much at the same stage. finished one wing and then came the holidays, and have done very little. Will be getting full steam into it now that the world is back to normal. My advice is that you use the spacer between the spars the 3/4 inch that is called for. make sure both spars are aligned parallal to each other. Once thats done place the hinges and mark them as to where they are in most contact with the apars. You want the rivets right in the center of the contact area so they give you max strength. You can use a piece of L tube to mark a straight line on the spars if you need to, to make sure the hinges are straight. That last part I figured out after I was done with the first wing. I use an X hinge design of my own invention (as far as I know), so marking them to be straight got to be important. :-) Other than that it will work fine even if its slightly misaligned, especially the Kolb designed hinges, it even does on my wing. I had to lube it a bit to get the sqweeks out of it. But it is one rugged rigid and strong hinge. Unlike those seemingly chinzy factory design, the x hinges are none compressionable which was one of the things that got me worried about the Kolb design. Yes John H. I know that you have flown 67.19 gazzilion hours with yours, and never a problem. :-) ============== > > Greetings > > I am in the process of mating the ailerons and flaps to the recently completed > wings. The manual on the subject seems straight forward but does anyone have > any hints that will aid in the needed accuracy of hinge placement? > > Thank you ahead of time. > > Dick Neitzel > Sayner WI > Mark III > neitzel(at)newnorth.net > > ________________________________________________________________________________
Date: Jan 07, 2003
How long is the prop? The RPM sounds kind of high for a prop - efficiency goes down if you turn them to fast also they can make a heck of a noise if the tips are breaking the speed of sound. jerb > >Im about to run a wooden one piece two blader at 6000 rpm on my kids >hovercraft [lots of dirt in the air].Anybody got a contact or specification >/part number for a good prop tape ?? we used to use it on rolls royce turbo >props in the far east,and I thought it was a bit mickey mouse then, but >now.......... > Vnz > > ________________________________________________________________________________
Subject: Arrived in FLA and it's another world
Date: Jan 07, 2003
Kolbers, Since I live in Cincinnati and fly my Firefly out of Waynesville, and since the December weather was definitely not conducive to flying, I am happy to report that my trailered Firefly and I arrived in Florida last week and will be in a beachhouse at St. Teresa near Panacea until after SunNFun in April. Duane the Plane will be moving his Firefly down to Panacea this week so that we can fly the beaches together. I dropped the Firefly off at the Panacea airport last week and flew on Friday, Sunday and Monday. Friday was especially great with little wind, 60, and full sun. A fellow who has a new house with hangar just across from where my trailer is parked has just finished a Mark III XTRA with VW power. It's been flown one time and he pranged it just a little on the first landing. A new landing gear leg and a little fiberglas work on the nose and it will be good as new. We spent last Thursday at the Quincy airport where we did weight and balance on Duane's new Mark III. It's a little tail heavy so he will cut about 5 inches off the tailwheel extension shaft and add about 10 pounds of lead forward of the rudder pedals. This should put him right where the weight and balance should be for a light pilot. I will keep pressing Duane until he marks the last few items off the list so he can get it in the air. Flew from Panacea to Quincy airport and did a little motoring around the field there with Duane who just did the 150 hr Rotax inspection. Oddly enough, Duane needed to replace the rings and so he is going thru the breakin thing. Hauck, come on down and we can fly someplace together. As I said earlier, I'll be in a beach house at St. Teresa until March 15 before going south to visit friends near Tampa, then on to SunNFun before returning to Cincinnati.... I have room at the beachhouse and you know that Duane has room at the townhouse. Gene Ledbetter Cincinnati Firefly 144 hrs and climbing ________________________________________________________________________________
Date: Jan 07, 2003
Subject: kolb?
Hello: I am new to the list, and looking for info. I fly an RV, and really like a light, responsive control system. Am interested in a light, low, slow plane, and think maybe Kolb is a good choice, but have never flown in one. I tried to work out a demo ride at Oshkosh last summer, but could not do so. The "other brand" that I did fly did not feel very responsive. Which light plane is most responsive? Which Kolb model is best for a very short strip? Is a 500 -600 foot strip practical? Am looking at the Firefly or Firestar. Single seat is ok, or if two seat, I prefer tandem seating. How does the required building time compare between these two? What engine has proven best from standpoint of performance and reliability? It is probably apparent that I come from the world of Lycoming and do not know the Rotax world at all, but would appreciate your advice. Thanks. Jimmy hillstw(at)aol.com (Oklahoma) ________________________________________________________________________________
Date: Jan 07, 2003
Ivo said that the Polyester resin is preferred, epoxy is second and things like JP weld is third. Polyester is the first because they said it's the hardest. Tim ________________________________________________________________________________
Date: Jan 07, 2003
I have used the super glue/baking soda solution for a small nick on a Powerfin. Works fine. When I was doing RC aircraft, there was a product called micro-balloons. It was extremely light and mixed with epoxy to fill gaps. It was also easy to sand for shaping after it dried. Don't know if it is still available or it may be under a different name now. Bill ________________________________________________________________________________
Subject: Re: kolb?
Date: Jan 07, 2003
> Hello: > I am new to the list, and looking for info. > I fly an RV, and really like a light, responsive control system. Am > interested in a light, low, slow plane, and think maybe Kolb is a good > choice, but have never flown in one. Jimmy, I have been flying my Long-EZ for the past six years, and I too like responsive controls. I recently completed a FireFly and have about 4 hours on it. I'm sure there are a lot of pilots in this group with far more hours and far more authoritative opinions about their Kolb, but here's mine.... You will like the responsiveness of the FireFly. Controls are quick and just what you would expect. Because it can fly so slowly and turn so tightly, there is a flight regime that is new to us.....with soft controls in slow flight and a tendency to overbank in a very steep turn (The inside wing is barely moving!) I find this new regime to be a lot of fun. > > Which light plane is most responsive? > Jimmy, I can't answer that one....I've flown only the FireFly. > Which Kolb model is best for a very short strip? Is a 500 -600 foot strip > practical? When I get a little better with short-field landings, I'm sure 500-600 feet would be plenty for the FireFly. The Rotax 447 gives that little plane a lot of power, and it leaps right off the ground in about 150 feet. My landings still take a lot more...but I expect better. Am looking at the Firefly or Firestar. Single seat is ok, or if > two seat, I prefer tandem seating. > How does the required building time compare between these two? > > What engine has proven best from standpoint of performance and reliability? > > It is probably apparent that I come from the world of Lycoming and do not > know the Rotax world at all, but would appreciate your advice. > > > Thanks. > Jimmy > hillstw(at)aol.com > (Oklahoma) I'll have to leave the rest of your questions for others. Regards, Bruce McElhoe FireFly #88 Reedley, Calif. > ________________________________________________________________________________
Date: Jan 07, 2003
Vince, I used stainless steel tape from NAPA on a wood prop & it worked fine. You can cut it with scissors & also notch it if you are following a curve. Richard Swiderski > > Im about to run a wooden one piece two blader at 6000 rpm on my kids > hovercraft [lots of dirt in the air].Anybody got a contact or specification > /part number for a good prop tape ?? we used to use it on rolls royce turbo > props in the far east,and I thought it was a bit mickey mouse then, but > now.......... > Vnz > > ________________________________________________________________________________
Date: Jan 07, 2003
What material is the prop actually made of? That could significantly impact the preference of one over the other for strength and bonding. jerb > >Ivo said that the Polyester resin is preferred, epoxy is second and things >like JP weld is third. Polyester is the first because they said it's the >hardest. > >Tim > > ________________________________________________________________________________
Date: Jan 07, 2003
Subject: Prop Nicks
If you haven't used it before, remember to be very careful with MEK. It's nasty stuff. One drop in the eye and it's gone. Larry the MicroMong guy ________________________________________________________________________________
Date: Jan 07, 2003
Personally, I'm an epoxy fan for most everything, but if Ivo built the prop, and Ivo says "Use Polyester;" then I'd use polyester. For just a bit of it, try taking your prop to a body shop. Bondo is polyester, and it can be colored to match. Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose www.gogittum.com ----- Original Message ----- From: <Timandjan(at)aol.com> Subject: Re: Kolb-List: Ivo prop repair > > Ivo said that the Polyester resin is preferred, epoxy is second and things > like JP weld is third. Polyester is the first because they said it's the > hardest. > > Tim ________________________________________________________________________________
Date: Jan 07, 2003
In a message dated 1/7/03 1:42:41 PM Eastern Standard Time, Timandjan(at)aol.com writes: > Ivo said that the Polyester resin is preferred, epoxy is second and things > like JP weld is third. Polyester is the first because they said it's the > hardest. > > Tim > Tim, My advice is to do whatever Ivo recommends. You should be able to get polyester resin with hardener at the local auto parts store. It should be finishing resin which allows the surface to dry tack free. I would not use laminating resin, it stays tacky. Here is an address to a site that has a lot of info about the different resins and reinforcements. http://www.fibreglast.com Steven Green ________________________________________________________________________________
From: "Jim and Phyllis Hefner" <hefners_tucson(at)hotmail.com>
Subject: Facet Pump
Date: Jan 07, 2003
Hi John, I think I met you at Copperstate in Oct. I assumeyou live in San Diego and owna yellow Firestar ? I own the yellow/green trimmed Firefly. We chatted a few times at CuState. Interestingly enough, I recently completed doing the same thing onmy FF. I bought the 2.5-4.5 PSI Facet pump and installed it in parallel with my pulse pump. My pump is mounted about 1/2 way down the level of my tank and I draw off the top of the tank. I put a fuel shut-off valve right after where I tee'd the line off to the new pump, which I close after I fly to prevent syphoning of fuel and air in the elec pump circuit, like I get in the pulse pump part of the circuit.Do you get air in the lines ofyour pulse pump circuit like I doafter a few days of downtime? If so, you will need to get that air out and the Facet won't helpdo thatand I'm not sure the pulse pump can self prime if there is enough air in the loop - onlya primer bulb can help that. Once the Facet loop primes the carb, the floats are full and you won't be able to get the air out of the pulse pump loop, even with a primer bulb... I found that out the hard way. You might want to try putting ashut-off valvein the pulse pump loop (assume you have no primer bulb and bypass loop with the new setup)to keep it from draining back to the tank, creating air in that part of theloop - the opposite of what I do, not having a battery to run the Facet with until the plane is running. With the shut-off valve open, I use the primer bulb a squeeze or two to make sure the facet loop is primed up to the T before the carb, then I close the shut-off valve, isolating the facet loop and then hit the primer bulb 4-5 times to get the air out of thepulse pumploop and fill the carb bowl and close the float valve.Once I start the engine, I flip on the facetswitch so they are both operating in parallel during flight. I havehad acouple cases of engine running fine on start-up, good warming up, I get in, strap in and get ready to taxi, only to have the engine sputter and die when I try to give it throttle, which it never did before adding the new pump loop.It usually restarts without problem anddoesn'thesitates again. I suspect some air is still somewhere in one of the loops and ends up in the carb after a little run time, causing it to die. Just a choke restarts it and no repriming is needed, soI'm not real sure what is going on yet, so I have been doing some extra warm-upto see if it isgonna sputter. I pulled the pulse line off the pulse pump to make sure the Facet had enough pressure to run the 447 with no pulse pump operating. Ran it at 3000 rpm5+ minutes to make sure it wasn't running on fuel in the bowl and everything was fine. I then flipped the Facet switch off and in about a minute, the engine died. I've made 2 100+ mile flights in the past 3 wks (140miles last Sat) and everything was fine with the setup once warmed-up. The lowest pressure pump works fine on the 447. Think you have a dual carb 503 if I remember right, but that pressure should work for dual carbs as well. Good luck getting the priming problem fixed. Hope to see you again at Copperstate next year. If anyone else on thelisthas experienced what I described during warm-up after installing a parallel electric pump loopand figured out what the cause was and implemented a fix, please let me know.... gives me an uneasy feeling when I go out there for the first take-off...Once the rpm's are up, there is not hesitation... just hesitates to respond to throttle from idle and then dies, which it never used to do. Jim Hefner FF022, Tucson, AZ From: "Wood, John T." <WOODJT(at)SPAWAR.NAVY.MIL> Subject: RE: Kolb-List: Facet Pump -- Kolb-List message posted by: "Wood, John T." Thanks for the responses to my Facet problem. I have tried the pump both above and below the tank and it still did not work. That is what prompted me to seek advise from the experts. Based on your responses it seems that I might have a bad pump. I purchaed the lowest pressure pump. Maybe I need more pressure to overcome the air in the lines? John Wood Firestar N670JW ________________________________________________________________________________
Date: Jan 07, 2003
Subject: Facet Pump
> > >Hi John, I think I met you at Copperstate in Oct. I assumeyou live in San >Diego and owna yellow Firestar ? I own the yellow/green trimmed Firefly. >We chatted a few times at CuState. Interestingly enough, I recently >completed doing the same thing onmy FF. I bought the 2.5-4.5 PSI Facet >pump and installed it in parallel with my pulse >pump.=================================================================== I'll be darn if I didn't miss the whole "Facet Pump" thing altogether. Been driving these flying lawn chairs since 1983 - been thru the Cyhuuuna - ouchh!, Rotax 377, 447, and now the 503 thing and still have not had a pulse pump fail yet - 2,000 hours + or -. I know it happens, guess I should get with the whole redundant /"Spaceshuttle/system". ________________________________________________________________________________
From: Kirby Dennis Contr ASC/TM <Dennis.Kirby(at)kirtland.af.mil>
Date: Jan 08, 2003
<< If anyone else on thelisthas experienced what I described during warm-up after installing a parallel electric pump loopand figured out what the cause was and implemented a fix, please let me know.... gives me an uneasy feeling when I go out there for the first take-off... Jim Hefner, Tucson, AZ >> Jim, and other Facet users - The Facet pump is designed to allow fuel to continue flowing thru it when it is turned off or failed. This allows you to install the Facet in SERIES with your other fuel pump, rather than in parallel. And this makes plumbing the fuel system lines simpler - fewer loops and tees to potentially trap air pockets. Dennis Kirby Mark-3, Verner-powered in New Mexico ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 08, 2003
Hi Jim, Good to hear from you. That was my yellow firestar at Copperstate. I thought this years Copperstate was the best I have attended. I met a lot of great folks and ran in to a few of the regulars. My whole thing with the facet pump was simply to build redundancy in my system. Before I can actually test any of the implementation suggestions however, I have to get a prop for my plane. I was checking the prop and found the bolt hole had gotten oversized. It is at IVO right now being checked out. I built a new fiberglass fuel tank which can hold 16 gallons. If you remember, I had three fuel tanks. I wanted to simplify the process. I needed the three tanks because the distance between Copperstate and Yuma put me on the edge of legal fuel requirements. Fortunately there was a tail wind in both directions and I probably could have made the jump without the extra tank. Now I have enough fuel in a single tank to get me between fuel stops with out worry. This got me to looking at the whole fuel system design and see if there was a way to build some redundancy into the system as well. All the things you mention on trying to prime my system, I am experiencing. They are all good suggestions and I appreciate the responses that I have received regarding the subject. Primer bulb, no primer bulb, facet pump above, below and some where in between, feed from the top and feed from the bottom. In your case you have your facet pump in parallel with the pulse pump. on a single carb systems that may be feasible. On a dual carb system the mechanics of setting it up is beyond me. I haven't decided yet whether to leave the primer bulb in or not. The shut off valve suggestion for the fuel line sounds like a good idea for both safety and functionality. Your mentioning that the fuel drains back into the tank over time, I have observed and using a shutoff valve my help to keep the system primed during non use. When I finally get an opportunity to check out my fuel system, I will let you know what works for my system. -----Original Message----- From: Jim and Phyllis Hefner [mailto:hefners_tucson(at)hotmail.com] Subject: RE: Kolb-List: Facet Pump Hi John, I think I met you at Copperstate in Oct. I assumeyou live in San Diego and owna yellow Firestar ? I own the yellow/green trimmed Firefly. We chatted a few times at CuState. Interestingly enough, I recently completed doing the same thing onmy FF. I bought the 2.5-4.5 PSI Facet pump and installed it in parallel with my pulse pump. My pump is mounted about 1/2 way down the level of my tank and I draw off the top of the tank. I put a fuel shut-off valve right after where I tee'd the line off to the new pump, which I close after I fly to prevent syphoning of fuel and air in the elec pump circuit, like I get in the pulse pump part of the circuit.Do you get air in the lines ofyour pulse pump circuit like I doafter a few days of downtime? If so, you will need to get that air out and the Facet won't helpdo thatand I'm not sure the pulse pump can self prime if there is enough air in the loop - onlya primer bulb can help that. Once the Facet loop primes the carb, the floats ar! e full and you won't be able to get the air out of the pulse pump loop, even with a primer bulb... I found that out the hard way. You might want to try putting ashut-off valvein the pulse pump loop (assume you have no primer bulb and bypass loop with the new setup)to keep it from draining back to the tank, creating air in that part of theloop - the opposite of what I do, not having a battery to run the Facet with until the plane is running. With the shut-off valve open, I use the primer bulb a squeeze or two to make sure the facet loop is primed up to the T before the carb, then I close the shut-off valve, isolating the facet loop and then hit the primer bulb 4-5 times to get the air out of thepulse pumploop and fill the carb bowl and close the float valve.Once I start the engine, I flip on the facetswitch so they are both operating in parallel during flight. I havehad acouple cases of engine running fine on start-up, good warming up, I get in, strap in and get ready to taxi, only to have the engine sputter and die when I try to give it throttle, which it never did before adding the new pump loop.It usually restarts without problem anddoesn'thesitates again. I suspect some air is still somewhere in one of the loops and ends up in the carb after a little run time, causing it to die. Just a choke restarts it and no repriming is needed, soI'm not real sure what is going on yet, so I have been doing some extra warm-upto see if it isgonna sputter. I pulled the pulse line off the pulse pump to make sure the Facet had enough pressure to run the 447 with no pulse pump operating. Ran it at 3000 rpm5+ minutes to make sure it wasn't running on fuel in the bowl and everything was fine. I then flipped the Facet switch off and in about a minute, the engine died. I've made 2 100+ mile flights in the past 3 wks (140miles last Sat) and everything! was fine with the setup once warmed-up. The lowest pressure pump works fine on the 447. Think you have a dual carb 503 if I remember right, but that pressure should work for dual carbs as well. Good luck getting the priming problem fixed. Hope to see you again at Copperstate next year. If anyone else on thelisthas experienced what I described during warm-up after installing a parallel electric pump loopand figured out what the cause was and implemented a fix, please let me know.... gives me an uneasy feeling when I go out there for the first take-off...Once the rpm's are up, there is not hesitation... just hesitates to respond to throttle from idle and then dies, which it never used to do. Jim Hefner FF022, Tucson, AZ From: "Wood, John T." <WOODJT(at)SPAWAR.NAVY.MIL> Subject: RE: Kolb-List: Facet Pump -- Kolb-List message posted by: "Wood, John T." Thanks for the responses to my Facet problem. I have tried the pump both above and below the tank and it still did not work. That is what prompted me to seek advise from the experts. Based on your responses it seems that I might have a bad pump. I purchaed the lowest pressure pump. Maybe I need more pressure to overcome the air in the lines? John Wood Firestar N670JW ________________________________________________________________________________
From: "Christopher Armstrong" <cen33475(at)centurytel.net>
Date: Jan 08, 2003
The Facet pump is designed to allow fuel to continue flowing thru it when it is turned off or failed. This allows you to install the Facet in SERIES with your other fuel pump, rather than in parallel. And this makes plumbing the fuel system lines simpler - fewer loops and tees to potentially trap air pockets. Unfortunately the pulse pump we use is not really designed for use inline and its failure modes (though quite rare if you tune them up every year) allow fuel underpressure into the pulse line and into the crank case of the engine making the engine so rich it would probably quit. I am probably going to plumb mine in series anyway as it seams like the best overall solution since the failure rate of the pulse pumps when tuned up each year is very low... but, it an't perfect. With parallel i you have the possibility of check valves failing. Topher ________________________________________________________________________________
Subject: Facet Pump
Date: Jan 08, 2003
The facet instructions say to mount it with the outlet pointed upwards at a 45 degree angle. not sure if your doing that already, or if it really matters much but that is called for in the instructions. ________________________________________________________________________________
Date: Jan 08, 2003
> > >The Facet pump is designed to allow fuel to continue flowing thru it when it >is turned off or failed. This allows you to install the Facet in SERIES >with your other fuel pump, rather than in parallel. And this makes plumbing >the fuel system lines simpler - fewer loops and tees to potentially trap air >pockets. Luckily, I have a fuel flow meter on my ultralight, and I had a Facet in series with my pulse pump... I started noticing a dramatic drop in flow to my carburetors a day not too long ago. To make a long story short: I played with it enough to figure out that the feature, "allow fuel to continue flowing through it when it is turned offor failed", had failed, and the pump had become a restriction. I bypassed the pump to see if that would solve the problem, and it did. So, I can guarantee to you that putting it in series IS a point of failure... I usually believe that simpler is better, but no longer in this case: plumb it in parallel. -- Robert ________________________________________________________________________________
Date: Jan 08, 2003
> Unfortunately the pulse pump we use is not really designed for use inline > and its failure modes (though quite rare if you tune them up every year) > allow fuel underpressure into the pulse line and into the crank case of the > engine making the engine so rich it would probably quit. > Topher Topher/Gents: The check valves inside the Mikuni pump and the diaphram are all one piece. Normally, a check valve in the pump will fail before the diaphram. I, personally, have not heard of any diaphrams spring leaks and killing two stroke engines. Basically, they are of a very similar design as the engine driven pumps on your auto or on our Rotax 912s. I have operated my fuel system in series with excellent results. john h ________________________________________________________________________________
Date: Jan 08, 2003
Subject: Re: Facet Pump
> Luckily, I have a fuel flow meter on my ultralight, and I had a Facet in > series with my pulse pump... I started noticing a dramatic drop in flow to > my carburetors a day not too long ago. > -- Robert Robert/Gents: Was the Facet still operational? Did it pump fuel when on? Or did one of the two one way valves in the Facet stick? How often and how long did you operate the Facet? john h ________________________________________________________________________________
Date: Jan 08, 2003
>Robert/Gents: > >Was the Facet still operational? Did it pump fuel >when on? Or did one of the two one way valves in >the Facet stick? How often and how long did you >operate the Facet? The Facet was the original pump (plane built in '97), and it was still functioning when this occurred. In other words, when turned on, the Facet still provided fuel... it was still pumping. But when off, the check valve apparently was stuck, thus causing a restriction that impaired the flow. I typically would only use the Facet to "pressure up" the system prior to starting, then it would be turned off after the engine started. It was, of course, there as an emergency backup if the mechanical pump failed. I've replaced it with a new Facet pump, but now plumbed in parallel. -- Robert P.S. When this problem first manifest itself, it caused me my very first true engine out emergency landing. I was on take-off, at about 50 feet, when the engine quit. I was lucky that there is a 2000-foot long field directly at the end of the turf runway -- not even a fence, just a swale, separates it -- so I just pointed my nose down (hard!) and did a textbook dead-stick landing. After I landed, I turned on the Facet pump (not because I knew what the problem was at that point, but because that's my normal mode of start up), and the engine fired right up. I taxi'd back to the runway -- it was a bit bumpy, but not bad -- and decided I'd try it again. (You see, I thought I had bumped the throttle off on my own!) In all the excitement, I forgot to turn the Facet pump off. I did a normal take-off, and was watching the flow meter when I realized that the aux. pump (the Facet) was still on. As soon as I switched it off, I noticed the fuel flow meter showed numbers a lot lowered that was normal. If I set up a cruise at about 90%, it only took about 2 minutes before the restricted flow couldn't keep up with the fuel use, and the engine started to sputter. This is how I figured out it was a fuel flow problem. It took a lot longer for me to narrow it down to the Facet pump. BTW, don't get me wrong about the Facet... I love it! I just (now) think it should be plumbed in parallel. ________________________________________________________________________________
Date: Jan 08, 2003
Subject: [ Larry Cottrell ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Larry Cottrell Subject: Lightweight Stove
http://www.matronics.com/photoshare/lcottrel@kfalls.net.01.08.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 08, 2003
Subject: [ Larry Bourne ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Larry Bourne Subject: Vamoose' Re-Drive http://www.matronics.com/photoshare/biglar@gogittum.com.01.08.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Subject: Facet
Date: Jan 08, 2003
Here is another suggestion, this is what I am using. Put a check valve McMaster-Carr part number 7775K11, $ 9.97 in parallel with the Facet so if the Facet fails or is switched off, the series Mikuni impulse pump will pull through the check valve. The cracking pressure of this valve is 1/3 psi, not much restriction there. Denny ________________________________________________________________________________
Date: Jan 08, 2003
Subject: [ Richard Pike ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Richard Pike Subject: 532 crank gear slippage http://www.matronics.com/photoshare/rwpike@preferred.com.01.08.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 08, 2003
A new Email List Photo Share is available: Poster: Larry Bourne Subject: Taps http://www.matronics.com/photoshare/biglar@gogittum.com.01.08.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 08, 2003
A new Email List Photo Share is available: Poster: Larry Bourne Subject: Taps http://www.matronics.com/photoshare/biglar@gogittum.com.2.01.08.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 08, 2003
A new Email List Photo Share is available: Poster: Larry Bourne Subject: Vamoose' Re-Drive http://www.matronics.com/photoshare/biglar@gogittum.com.1.01.08.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 08, 2003
> I typically would only use the Facet to "pressure up" the system prior to > starting, then it would be turned off after the engine started. It was, of > course, there as an emergency backup if the mechanical pump failed. > > I've replaced it with a new Facet pump, but now plumbed in parallel. > > -- Robert Hi Robert/Gang: Seems I use my Facet a little differently than you do. I use it as a primer pump to fill the carb float bowls for startup after the airplane has been sitting for a prolong period. However, I leave mine own and do not turn it off until about 1,000 feet AGL, depending on where I am flying. It is turned on again when I get below 1,000 feet AGL. That way, if my engine driven pump should fail on takeoff or landing, or when I am flying close to the ground, I most likely will not lose the engine. If I remember correctly, and John Williamson can correct me if I am wrong, we left both the main and boost fuel pumps on all the time, except when making a fuel pump check. Without a fuel pressure gauge it is difficult to do. We pulled the circuit breaker on the boost pump and watched for a slight drop in pressure. With the engine running of course. When we pushed the circuit breaker back in, the fuel pressure should go back to whatever normal fuel pressure was. I would like to have a fuel pressure gauge for checking the pumps, but don't really want to run fuel lines up to the instrument panel. However, there have been several times when a fuel pressure gauge could have alerted me to an impending engine out if I had had one installed and was cross checking it. Looking at it that way, seems like it would be more of a help than a safety factor having one installed and operating. I always have run my main and boost pumps in series, both two and four cycle engines. I recommend keeping it simple. If you had had your boost pump on on takeoff, you may not have had to experience an engine out and forced landing. john h ________________________________________________________________________________
Date: Jan 08, 2003
Hi Gang: I was referring to a UH-1 or AH-1G below. Got to start proof reading this stuff: > If I remember correctly, and John Williamson can > correct me if I am wrong, we left both the main > and boost fuel pumps on all the time, except when > making a fuel pump check. Without a fuel pressure > gauge it is difficult to do. We pulled the > circuit breaker on the boost pump and watched for > a slight drop in pressure. With the engine > running of course. When we pushed the circuit > breaker back in, the fuel pressure should go back > to whatever normal fuel pressure was. john h ________________________________________________________________________________
Subject: Re: Facet
Date: Jan 08, 2003
Whoops, scratch that part number, the correct number is 7775K51, this one has the Viton seat that holds up to fuel. The other number I gave has the Buna rubber seat. ----- Original Message ----- From: <rowedl(at)highstream.net> Subject: Kolb-List: Facet > > Here is another suggestion, this is what I am using. > Put a check valve McMaster-Carr part number 7775K11, $ 9.97 in parallel with the Facet so if the Facet fails or is switched off, the series Mikuni impulse pump will pull through the check valve. The cracking pressure of this valve is 1/3 psi, not much restriction there. > Denny > > ________________________________________________________________________________
Subject: RE: Facet Pump
Date: Jan 08, 2003
From: Wood, John T. (woodjt(at)spawar.navy.mil) Date: Wed Jan 08 - 7:14 AM John wrote: "My whole thing with the facet pump was simply to build redundancy in my system." John, that is exactly what my intention was. Pretty cheap insurance ($30) I felt, vs picking cactus out of my ass due to a $20 pulse pump failure, and I know they are pretty reliable if maintained. I have seen the online debates on putting them in series vs in parallel and read Mike Stratman's articles on this topic. Since I was doing it for redundancy vs easier priming, I went with parallel. After looking at my mounting options, I found a perfect spot to mount the pump on a 45o angle as the Facet instructions called for, and then I routed the new fuel line up the angled motor mount cage member, near the carb, where I T-spliced it in. I wasn't worried about mounting the pump below the surface of the tank. I always refill my tank when I'm done flying, so the fuel level is always higher than the pump when it sits for days, plus I shut-off the fuel valve to that loop after flying, so it never gets any air in the input side of the pump. Since these pumps are rated for 1000's of hrs, I turn it on and leave it on during the entire flight. I know a guy with a QuickSilver that went to the trouble of putting a fuel pressure guage on his dash, so if he sees the pressure drop, he will then turn on his electric pump that is mounted in parallel with his pulse pump. I don't want to be constantly looking at a guage and hoping to see it drop in time before my bowl runs dry, so I chose not to go that route. With pull start that is not easy to do in a FF, that's not a great solution. Looking at EGT's periodically is enough for me. I like to look at the scenery more than guages. I'll be interested to hear from you when you get yours done to see what you end up doing that works. Your prop situation is also interesting.... will be interesting to hear what IVO concludes. Take care, Jim Hefner Tucson, AZ FF022 ________________________________________________________________________________
Date: Jan 08, 2003
> >Personally, I'm an epoxy fan for most everything, but if Ivo built the prop, >and Ivo says "Use Polyester;" then I'd use polyester. For just a bit of it, >try taking your prop to a body shop. Bondo is polyester, and it can be >colored to match. Lar. Lots of filler in bondo. That may reduce the strength. It is hard to find small quantities of polyester resin so epoxy in the tubes may be the best way and is recommended by warp. ________________________________________________________________________________
Date: Jan 08, 2003
Subject: Re: [ Larry Bourne ] : New Email List Photo Share
Available!
1/8/03 15:08Email List Photo Shares > > > > A new Email List Photo Share is available: > > Poster: Larry Bourne > > Lists: Kolb-List,Ultralight-List > > Subject: Vamoose' Re-Drive > > http://www.matronics.com/photoshare/biglar@gogittum.com.01.08.2003/index.html > >=========================== Hey lar this is what I get when i click on your link.. ******The requested URL /photoshare/biglar(at)gogittum.com.01.08.2003/index.html was not found on this server. Apache/1.3.22 Server at www.matronics.com Port 80******* ________________________________________________________________________________
Date: Jan 08, 2003
Subject: Hinges
I am about to finish the flapron hinge installation. However the plans do not call for hinges to be installed at the root of the flapron. As I have not looked any further than what i am doing in the plans, I am wondering if there is additional bracing on the Flapron Torque tube/spar. My question is what keeps it from warping or bending when the pilot dials in ailron deflection? Has anyone placed hinges at the root od the torque tube/spar? Thanx ________________________________________________________________________________
Subject: Hinges
Date: Jan 08, 2003
the wing root rib has a hole in it that a bolt welded to the flapperon horn goes through, forming the root hinge. you do not need an additional hing there. ________________________________________________________________________________
Subject: Re: [ Larry Bourne ] : New Email List Photo Share Available!
Date: Jan 08, 2003
Looks like something boo-boo-ed on the 1st try. I only sent 2, and they came thru fine on the 2nd try. Lar. Do not Archive. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose www.gogittum.com ----- Original Message ----- From: "CaptainRon" <CaptainRon(at)theriver.com> Subject: Re: Kolb-List: [ Larry Bourne ] : New Email List Photo Share Available! > > 1/8/03 15:08Email List Photo Shares > > > > > > > > > A new Email List Photo Share is available: > > > > Poster: Larry Bourne > > > > Lists: Kolb-List,Ultralight-List > > > > Subject: Vamoose' Re-Drive > > > > http://www.matronics.com/photoshare/biglar@gogittum.com.01.08.2003/index.htm l > > > >=========================== > > > Hey lar this is what I get when i click on your link.. > > > ******The requested URL > /photoshare/biglar(at)gogittum.com.01.08.2003/index.html was not found on this > server. > > Apache/1.3.22 Server at www.matronics.com Port 80******* > > ________________________________________________________________________________
Date: Jan 08, 2003
In a message dated 1/8/03 4:25:39 PM Eastern Standard Time, rlaird(at)cavediver.com writes: > This is how I figured out it was a fuel flow problem. It took a > lot longer for me to narrow it down to the Facet pump. > > BTW, don't get me wrong about the Facet... I love it! I just (now) think > it should be plumbed in parallel. Robert, Was this on a hot day? And is your pulse pump much higher (vertically) than your electric? Steven G. ________________________________________________________________________________
Date: Jan 08, 2003
At 10:20 PM 1/8/2003, you wrote: > >In a message dated 1/8/03 4:25:39 PM Eastern Standard Time, >rlaird(at)cavediver.com writes: > > > This is how I figured out it was a fuel flow problem. It took a > > lot longer for me to narrow it down to the Facet pump. > > > > BTW, don't get me wrong about the Facet... I love it! I just (now) think > > it should be plumbed in parallel. > >Robert, >Was this on a hot day? And is your pulse pump much higher (vertically) than >your electric? Steven -- No, it was a cool day, probably low 60's (well, that's cool for Houston!). And yes my pulse pump is higher, but only by an inch or two. The restriction it was causing was consistent and repeatable over a 2 week period. -- Robert ________________________________________________________________________________
Subject: Re: Hinges
Date: Jan 08, 2003
Ya Captian Ron, thats how my fireFly is. The root rib is made of Chromemoly and it has a tab on the trailing edge with a 5/16th hole in it. The Aileron horn that slips into the leading edge tube of the Flaperon has a bolt that fit into this hole. The Manual mentions that no nut is needed on this bolt, as the P-hinges capture lateral movement of the Flaperon. Im not real familiar with a Ultrastar, but I have seen pics of your landing on the so-called Stork, and I really like them alot. Any chances of drawings/prints existing of that gear? Don Gherardini http://www.geocities.com/dagger369th/my_firefly.htm FireFly 098 ________________________________________________________________________________
Subject: Re: Hinges
Date: Jan 08, 2003
Captain, I Just checked my web site, and on page 3, you can view this trailing edge tab on the root rib http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini FireFly 098 ________________________________________________________________________________
Subject: US Mods
Date: Jan 09, 2003
Thanks go to Richard Swiderski and Jpohn Hauck for the advice on stiffening the Ultrastar wings . I now am going to put the steel ring on the end of the tube and stiffen the full ribs with some aluminum angle. I have been busy trying to add a Firefly type front end to the Ultrastar rear with the modified integral gear sockets and I am confident I can make it work. I may also use another idea of Richards to build the nose fairing from rib tubing and dacron . Light is better.... Over the years I have discovered that when I was younger I thought I was "blazing new trails " but soon realized I was usually on a well worn path. Somebody else has already got the correct answer to your problem....and this list is it....thanks Guys ! ________________________________________________________________________________
Date: Jan 09, 2003
Subject: Re: Hinges
1/8/03 19:09Christopher Armstrong > you do not need an additional hing > there. ================== Thanks :-) ________________________________________________________________________________
Subject: Re:Facet
Date: Jan 09, 2003
> >The restriction it was causing was consistent and repeatable over a 2 week >period. >> > -- Robert Hey Robert, do you use a fuel filter before and after the facet pump...??? If no filter is used before the pump it could be dirt causing the problem. On the BMW I use 2 Facet pumps in series, with fuel filters before and after. Hans van Alphen Mark III Xtra BMW powered 90 hours ________________________________________________________________________________
Date: Jan 09, 2003
Subject: Re:Facet
> > > > >The restriction it was causing was consistent and repeatable over a 2 week > >period. > >> > > -- Robert > >Hey Robert, do you use a fuel filter before and after the facet pump...??? >If no filter is used before the pump it could be dirt causing the problem. >On the BMW I use 2 Facet pumps in series, with fuel filters before and >after. > >Hans van Alphen >Mark III Xtra >BMW powered Yes, a filter is in-line before the pump... not sure why you'd have an additional one after the pump, though, unless you're expecting pump parts to spontaneously implode and flow through the tubing! If blockage were the problem, you'd think it would impair the pumps ability to pump, but when it was on, it pumped just fine. That implies that the check valve was somehow faulty, and that there was no blockage from dirt. However, it's not impossible that dirt is the cause of the check-valve not working properly. Who knows. Brother Hauck certainly has been a guiding light for me, so I suppose running the pump all the time is the real solution (the stated 6000 hours of life in the pump is about 60 years of flying time for me!). However, I'm uncomfortable with that because my flow rate is higher (based on my fuel flow meter) when I use the Facet pump than when I just use the mechanical pump alone... I would think it should be the same. So I wonder if I'm getting overflow (i.e., wasting fuel) when I use the Facet all the time? (It's the low-pressure Facet.) -- Robert ________________________________________________________________________________
Date: Jan 09, 2003
Subject: Re:Facet
> On the BMW I use 2 Facet pumps in series, with fuel filters before and > after. > > Hans van Alphen Hans/Gents: Good idea! I am configured with filter after the Facet and before the engine driven pump on the 912S. The facet had no problem pumping a ton of garbage, enough to completely block fuel filter and shut down the engine a few years ago. I do have a finger strainer ahead of the fuel tank outlet for the big stuff. john h ________________________________________________________________________________
Date: Jan 09, 2003
Subject: Re:Facet
> However, > I'm uncomfortable with that because my flow rate is higher (based on my > fuel flow meter) when I use the Facet pump than when I just use the > mechanical pump alone... I would think it should be the same. So I wonder > if I'm getting overflow (i.e., wasting fuel) when I use the Facet all the > time? (It's the low-pressure Facet.) > > -- Robert Robert/Gents: The instruments we use in our airplanes are not absolute, especially fuel flow meters. I don't have a flow meter in my airplane, but do have one in the boat. It was designed and built by Flo-Scan. Gives me a good idea of how much fuel my 351W is burning or not burning. But it has proven to be not totally accurate. I believe your engine would be the first to let you know if you were in fact getting overflow when the Facet is energized. I bet it is a false reading at the flow meter. john h ________________________________________________________________________________
Date: Jan 09, 2003
Subject: Re: Hinges
Re: FireFly aileron hinge. Coupla years ago, when being judged at EAA fly-in, the judge said I had to put a nut on the welded bolt!! Did so, and awarded First Place, ULs. Pays to have yer nuts tight. Wasn't even safetied, but judge was pleased at making a Uler toe the line. Bob N. 070 FF ________________________________________________________________________________
Subject: RE:RE:Facet
Date: Jan 09, 2003
> On the BMW I use 2 Facet pumps in series, with fuel filters before and > after. > > Hans van Alphen Hans/Gents: Good idea! I am configured with filter after the Facet and before the engine driven pump on the 912S. The facet had no problem pumping a ton of garbage, enough to completely block fuel filter and shut down the engine a few years ago. I do have a finger strainer ahead of the fuel tank outlet for the big stuff. john h John/ others, I put my filter before the pump in both pulse and electric pump loops, thinking I didn't want the garbage going thru either pump, causing it to malfunction. Since I change the filter yearly, I was thinking I am throwing away all the garbage. Putting it after the pump seems to expose the pump to some collection of garbage over time that is not removed when you change the filter.... probably not a big deal, but my reason for putting the filters before the pumps. My assumption is that the gargage is coming from the tank, not the pump. Another question about serial pumps vs parallel if I may. I think of the pulse pump, with no other pump in the picture, as having 0 pressure (actually negative pressure when pumping from the tank) on the input side of the pump and outputting 4lbs for discussion purposes. It seems to me by putting an electric pump in series with the Mikuni pulse pump, the pulse pump input pressure now becomes lets say 4.5 lbs, not 0. I'm not an expert on Mikuni pumps, but it seems to me it would either take 4.5lbs in and do nothing, outputting 4.5lbs, or it would take 4.5lbs in and increase it 4lbs (or something in between). Whereas, in a parallel connection, there is always 0 lbs input pressure to both pumps and both outputs of 4lbs and 4.5lbs, with the carb seeing the higher of the two pressures (4.5lbs), which is closer to the normal output pressure of the 2 pumps. Has anyone tried measing this effect with a fuel pressure guage in the line? If the Mikuni has a max output pressure of 4lbs, no matter what the input pressure is, then the carb sees the same pressure whether the pump is working or not. What I don't know is if having 4lbs pressure on the input side of the Mikuni pump diaphram would have any affect on its longterm durability.... there's definitely a difference in the 2 setups, unless I'm all wet in my thinking, which is highly possible! I know the serial approach works, so I suspect the Mikuni doesn't add to the pressure, but effectively does nothing. The other thing I have noted in the discussion is that many folks only use their electric pumps for priming, take-off and landings, so durability may not being fully understood due to a small sample. With my setup, it is on all the time after startup until shutdown. Since I was unsure of the effect of having a constant input pressure, close to the pump output pressure, on the Mikuni pump, which normally sees 0, I decided to go parallel. I wanted to add redundancy, not detract from the reliability of the one pump I have been using. Seeing Stratman's articles only showing parallel connections seemed to make sense to me, not changing the input pressure of either pump. I know we have beat this subject to death, but I haven't seen any discussion on the technical differences the pump sees and what longterm affect it might have. I'm curious about your or others thoughts on this. Thanks much! Jim Hefner Tucson, AZ FF022 ________________________________________________________________________________
Date: Jan 09, 2003
Subject: Re: RE:RE:Facet
I > know we have beat this subject to death, but I haven't seen any discussion > on the technical differences the pump sees and what longterm affect it might > have. I'm curious about your or others thoughts on this. > > Thanks much! > Jim Hefner Hi Jim/Gents: I don't know what the pressures are after both pumps in series. I know it works. Would be interesting to get a pressure reading with Mikuni alone and when Facet is operational. I would guess there would be 3 to 4 psi. I don't think pressure from the facet pump degrads longevity the Mikuni or any other engine driven pump, like the one on the 912S. If you can imagine what the diaphram is doing over the course of a flight, the Watusi. Those crank case pulses are working out on the little diaphram. I have proven over time that the system works for me, in series, with both 2 and 4 stoke systems. I'm happy with my set up. john h ________________________________________________________________________________
Subject: Re: Hinges
Date: Jan 09, 2003
Rut Roh.....Sorry Captain Ron....as usual, Im mixed up!....got you confused with a Capt Bob of Ultrastar fame!...I apoligize for the mixup. A few days ago a couple a guys were talking about an UltraStar that used to belong to a member here, they posted a pic of an unusual landing gear config made of moly-tubing with a bungee suspension that gave a 'Stork-like" look to that bird.
December 15, 2002 - January 09, 2003
Kolb-Archive.digest.vol-eb
