Kolb-Archive.digest.vol-ek
July 17, 2003 - - - - , 20-
      is loosened, you will be able to feel when the screw actually engages the
      followers attached to the blades... I would make the changes based on how
      far you move the screw after the cams are contacted by the follower.  Loosen
      the big nut and work the screw back and forth... you'll feel what I am
      talking about.
      Bear in mind, Sir, that the above are the empirical observations of a humble
      goon with extremely limited (about 95 hours) experience with both IVO's and
      ROTAX's... and indeed, with a deeply ingrained distrust of anything 2
      cycle... mine hasn't quite killed me yet, and that's about the exent of my
      credentials...  To quote the old saw, my opinions are worth precisely what
      you paid for them... There are countless others on this list with a lot more
      2 stroke experience than I...  Mebbe some of them will chime in here....
      Good Luck, Sir....
      Beauford
      FF#76
      Brandon, (soggy) FL
      ----- Original Message -----
Subject: Re: Ivo pitch setting
> > In a message dated 7/15/03 8:55:03 PM Central Standard Time, > beauford(at)tampabay.rr.com writes: > > << I suspect that most guys would tell you that after you get the engine > break-in done, tie the tail to something substantial (that you don't mind > getting slightly sandblasted) and just work with the prop pitch screw until > you get it to the desired static RPM at wide open throttle... Screw the > pitch screw IN to INCREASE RPM...... screw it back OUT to DECREASE RPM.... > >> > Snip > > Beauford, > > What did you do about the pitch while breaking in . No problem with over > rev ving > the engine? Did you follow the rotax procedure exactly? > > Ed (in Houston) > > ________________________________________________________________________________
Date: Jul 17, 2003
Subject: Re: 3rd Annual Cajun Fly-in & Camp-out
Tommy, Are you OK? Ive sent two or three emails. Let me know if you are well. Ed Diebel ________________________________________________________________________________
Subject: WING ALIGNMENT AND ATTACHMENT ON MK III X COMPLETE
Date: Jul 17, 2003
Jim, Excellent! Glad the process went smooth as silk! How did the wings fold up? Were there any problems there? Ben R. has a point with his post. I have seen root ribs not built in the wing square, which changed the way the plane is rigged. But, I know that Kolb has made the plane almost fool proof with room to make up for inaccuracy. Tim -----Original Message----- From: Jim Ballenger [mailto:ulpilot(at)cavtel.net] Subject: Kolb-List: WING ALIGNMENT AND ATTACHMENT ON MK III X COMPLETE All I spoke with Ray Brown at Kolb and he told me how he attached and aligned the wings to the Kolbs he built. His method was so simple and seemed the easiest I decided to use it and not what is published in the construction manual. Here is how I did it. First I took the plan measurements on the wing tab and cage tabs for the clevis pin location and carefully measured and drilled the holes before I did anything else. Believe me, it took me a while to work up the courage to drill those holes without putting the wing and cage together first. I then leveled the cage in the roll axis and raised the tail to level the wings in the pitch axis. The next step was to attached the wings with the clevis pins at the spar and then get my distance from the wingtips to the leading of the rudder the same and drill the drag strut fitting. I then raised the wing tips 1.5" to achieve the require dihedral and attached the lift struts. Both wings are at the same angle of incidence and the wing tip to rudder measurement was with in 1/8 " for both wings as well as the lift strut lengths were within 1/8". I also have a digital level that I checked each wing with and both wings were within 1/10 of a degree of each other. I started this at 1p.m. yesterday and finished at 7 p.m. a total of 6 hours. I am completely satisfied with the results and amazed at how smooth it went using Ray's technique. Jim Ballenger Flying a FS KXP 447 Building a MK III X Virginia Beach, VA ________________________________________________________________________________
Subject: Re: WING ALIGNMENT AND ATTACHMENT ON MK III X COMPLETE
Date: Jul 17, 2003
Ben Believe me, I really had to convince myself this was the best way and then go for it. I had and still have doubts this will work for all cases due to the differences you pointed out. However, with that said it worked for me and I am very happy it is over with. What a load off my shoulders. Jim ----- Original Message ----- From: "Ben Ransom" <bwr000(at)yahoo.com> Subject: Re: Kolb-List: WING ALIGNMENT AND ATTACHMENT ON MK III X COMPLETE > > Whoa! > I can see how this would work some, or maybe even a lot of the time, > but all of the time would really surprise me. There are differences in > how cages come off of weld jigs, and to think that the location of the > three points for wing attach (to cage) would match from side to side > seems a lot to ask for. The method would also require pretty similar > root ribs, altho these are smaller parts than the cage, with less > likelihood of height differences that would affect incidence angle. > I'm impressed, but would be too chicken to try this myself. :) > > BTW, on my rebuild, I had the hole in the wing tab, as well as > corresponding holes in the top cage tabs welded closed so I could go > thru the "fun ?" longer process again. > -Ben > > --- Jim Ballenger wrote: > > > > All > > I spoke with Ray Brown at Kolb and he told me how he attached and > > aligned the wings to the Kolbs he built. His method was so simple > > and seemed the easiest I decided to use it and not what is published > > in the construction manual. Here is how I did it. > > > > First I took the plan measurements on the wing tab and cage tabs for > > the clevis pin location and carefully measured and drilled the holes > > before I did anything else. Believe me, it took me a while to work > > up the courage to drill those holes without putting the wing and cage > > together first. I then leveled the cage in the roll axis and raised > > the tail to level the wings in the pitch axis. The next step was to > > attached the wings with the clevis pins at the spar and then get my > > distance from the wingtips to the leading of the rudder the same and > > drill the drag strut fitting. I then raised the wing tips 1.5" to > > achieve the require dihedral and attached the lift struts. > > > > Both wings are at the same angle of incidence and the wing tip to > > rudder measurement was with in 1/8 " for both wings as well as the > > lift strut lengths were within 1/8". I also have a digital level > > that I checked each wing with and both wings were within 1/10 of a > > degree of each other. > > > > I started this at 1p.m. yesterday and finished at 7 p.m. a total of 6 > > hours. I am completely satisfied with the results and amazed at how > > smooth it went using Ray's technique. > > > > Jim Ballenger > > Flying a FS KXP 447 > > Building a MK III X > > Virginia Beach, VA > > > > > > > > > > > > > > > > > > > ===== > http://mae.ucdavis.edu/~ransom > > __________________________________ > > ________________________________________________________________________________
Date: Jul 17, 2003
Tim I haven't tried to fold the wings yet. You may have a good point, they may not rest where they should when folded. I'll let you know when I try to fold them. Jim ----- Original Message ----- From: "Gherkins Tim-rp3420" <rp3420(at)motorola.com> Subject: RE: Kolb-List: WING ALIGNMENT AND ATTACHMENT ON MK III X COMPLETE > > Jim, > Excellent! > Glad the process went smooth as silk! How did the wings fold up? Were there any problems there? > Ben R. has a point with his post. I have seen root ribs not built in the wing square, which changed the way the plane is rigged. But, I know that Kolb has made the plane almost fool proof with room to make up for inaccuracy. > > Tim > > -----Original Message----- > From: Jim Ballenger [mailto:ulpilot(at)cavtel.net] > To: kolb-list(at)matronics.com > Subject: Kolb-List: WING ALIGNMENT AND ATTACHMENT ON MK III X COMPLETE > > > All > I spoke with Ray Brown at Kolb and he told me how he attached and aligned the wings to the Kolbs he built. His method was so simple and seemed the easiest I decided to use it and not what is published in the construction manual. Here is how I did it. > > First I took the plan measurements on the wing tab and cage tabs for the clevis pin location and carefully measured and drilled the holes before I did anything else. Believe me, it took me a while to work up the courage to drill those holes without putting the wing and cage together first. I then leveled the cage in the roll axis and raised the tail to level the wings in the pitch axis. The next step was to attached the wings with the clevis pins at the spar and then get my distance from the wingtips to the leading of the rudder the same and drill the drag strut fitting. I then raised the wing tips 1.5" to achieve the require dihedral and attached the lift struts. > > Both wings are at the same angle of incidence and the wing tip to rudder measurement was with in 1/8 " for both wings as well as the lift strut lengths were within 1/8". I also have a digital level that I checked each wing with and both wings were within 1/10 of a degree of each other. > > I started this at 1p.m. yesterday and finished at 7 p.m. a total of 6 hours. I am completely satisfied with the results and amazed at how smooth it went using Ray's technique. > > Jim Ballenger > Flying a FS KXP 447 > Building a MK III X > Virginia Beach, VA > > ________________________________________________________________________________
Subject: up and away (again)
Date: Jul 17, 2003
It took 2 and a half years but the club plane finally made it into the air. We bought the kit in florida for a club to build. It was promised that all members would help and they did for the first couple months. Then it became a Woody and Andy project. I will not do a club project again lots of support in the beginning but not a lot of follow through. Being the one pushing for a Kolb I felt obligated to finish the project. Last night it flew. Standard Mk 111 with a 582 built to the plans. I could not believe the different feel of the aircraft. The ailerons were light!!!! I could even wag the wings. I have never experienced this on a Kolb before. It was getting dark so I only spent 10 minutes in the air but what a nice flight. I will report on further tests but so far I am incredibly happy with the performance shown in that first flight. One more Kolb in the air and one more waiting beside my hanger for a rebuild. Had a wiener roast here last Sunday about 25 people showed up and we had 4 Kolbs on the field. 3 Mk 111s and my original Twinstar. I hope the photos turn out. ________________________________________________________________________________
Subject: Re: up and away (again)
Date: Jul 17, 2003
> Congratulations. You stated the ailerons were light. Did you drill and > attach per the plan or did you do a modification to the hole location? > I wish I knew what I did. Everything was done acording to plans. Only thing I can see is that the ailerons were reflexed up a bit. On the flying totem pole the ailerons are so heavy I have added spades to try to lighten them. Maybe this weekend I will take it up for a flight and see if it works. Should be going to a michigan fly in on Sat. Hope to see some list members there. ________________________________________________________________________________
Date: Jul 17, 2003
Subject: Uv protection
Kolbers I had an intersting conversation with a PHD ,who works for Eastman Chemicals in East Tenn., a few days ago. When the conversation got around to uv protection; he was quite surprised to discover that such protection on fabric airplanes uses coats of "aluminum paint" to do the job. His point being that excellent(he called it near absolute) uv protection is available in the clear coat that goes over base coat colors in modern auto's. I was distracted and did not get to ask about plasticizers and such. Food for thought! I think that TNK uses auto paints and they tend to crack after a while? I have a 5 year old mini max that was painted this way and except for hangar rash I have not seen any cracks develop in it. Sherwin-Williams Ultra 7000. Applied over poly brush I think. So slick and shiny that it looks like mono cote! I did not build or paint it by the way. Herb ________________________________________________________________________________
Date: Jul 17, 2003
Subject: First Flight Pilot Preparation
Don G, Even if you get lots of Kolb flights at Oshkosh would like to point out the number one correlate to a safe first flight is recency and VARIETY of experience. In addition to as many different Kolb models, suggest you get some refresher dual in a Cessna 150 and an early Champ and a Cub and a PA-28 and a ..... Also go to the EAA website and get hooked up with a Flight Advisor. He/she can give you lots of help and support. I did all of the above for my homebuilt Prospector's first flight even though I am also an EAA Flight Advisor with over 3000 hours and a fair amount of prior test flight experience. Finally, the consensus of the real Kolb experts on the list is to make the early landings with power on. Congratulations on your approaching first flight, I'm jealous. Tom Kuffel Whitefish, MT Building Original FireStar ________________________________________________________________________________
Subject: Re: First Flight Pilot Preparation
Date: Jul 18, 2003
Tom, thanks for those words of advice my friend. and Ill take it as good advice BTW...! I did in fact get a couple of hours in a Phoinex dual last weekend in preparition for this. This weekend, I hope to get thru a Biannual Flight Review in a C-150. (1st one since 86) And hopefully I will get a ride in a 2 seat Kolb in the near future. I Did 30 minutes or so of taxi-testing with it today Not at a strip..but out behind the barn ya might say...not enough room, trees all around.., MAN..that little bird wanted to fly..but I have not done the Cg calcs yet and I will do them at Tommies airpark, where I have a hangar rented and Tom has a good set of scales to do it right ..I am trying to borrow a trailer for the 50 mile trip. .........If it all comes out right...shes ready....and hopefully I will be! http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Date: Jul 18, 2003
Subject: Re: Oshkosh
Gang, I just got reservations for airfare to Oshkosh. Milwaukee Actually. Was it agreed on to meet at the Kolb trailer at 11:00 each day? Has any one started a list of those planning to attend? Ed (in Houston) ________________________________________________________________________________
From: "Rick & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Jul 18, 2003
Woody Do you have any information on that fly-in in Michigan. I haven't heard anything about it or even were it is. Rick Neilsen Redrive VW powered MKIII ________________________________________________________________________________
Date: Jul 18, 2003
Subject: paper model of a Firefly
I s Scott still on the list, or does anyone have his e-mail address? I sent a message to the address shown on the message below it came back. Thanks Merle ************************************************************************************************************ Scott=A0=A0 I went thru the archives and found your message of DEC.16, 1999 about the model Fire Fly.=A0 Do you still have the drawing?=A0 If you do I would sure=20like to have the Drawing. Merle Hargis=A0 in Orlando, Fl. flying ****************************************************************************** ****************************** Scott Olendorf Hi all, If you are done flying for the season and are a little bored or if you are currently building and need a break then I have something for you. It would be especially fun for those building a Firefly but everyone should enjoy it. ftp://members.aol.com/olefirest1/paperfly.jpg This is a paper model of a Firefly. This is great to experiment with paint schemes. It will really fly too! Click on image to get the full size file, save it to disk, then print with a utility that provides a "fit to page" option. It is best to use card stock if you want to fly it. Scott Olendorf Original Firestar, Rotax 377 Schenectady, NY http://members.aol.com/olefiresta ________________________________________________________________________________
Subject: Kolbs in Ontario
Date: Jul 18, 2003
Hi All, I am interested in purchasing an ultralight and would like to get a ride in a Kolb. Does anyone know where I might might accomplish this in Ontario (specifically around Toronto)? I am hoping to find an instructor or someone who will in return for reasonable payment show me what a Kolb feels like to fly in. .................................. F. Otta Toronto, Ontario ________________________________________________________________________________
Subject: Re: Kolbs in Ontario
Date: Jul 18, 2003
Go 200 miles south and I can probably get you a ride in a MK111 and if you wish to make a purchase I am selling my original Twinstar. I live just outside Windsor right on the U.S. border. ----- Original Message ----- From: "Frank Otta" <fotta(at)rogers.com> Subject: Kolb-List: Kolbs in Ontario > > Hi All, > > I am interested in purchasing an ultralight and would like to get a ride in > a Kolb. Does anyone know where I might might accomplish this in Ontario > (specifically around Toronto)? I am hoping to find an instructor or someone > who will in return for reasonable payment show me what a Kolb feels like to > fly in. > > .................................. > F. Otta > Toronto, Ontario > > ________________________________________________________________________________
Date: Jul 18, 2003
I had the brochure here yesterday but can't find it now. I think Ken Feckler is going. Some other guys with a firefly also. If you know those people I will probably see you there tomorrow. Try a web search for Michigan ultralight flyers or something like that. ----- Original Message ----- From: "Rick & Martha Neilsen" <NeilsenRM(at)comcast.net> Subject: RE: Kolb-List: up and away (again) > > Woody > > Do you have any information on that fly-in in Michigan. > I haven't heard anything about it or even were it is. > > Rick Neilsen > Redrive VW powered MKIII > > > works. > Should be going to a michigan fly in on Sat. Hope to see some list members > there.> > > ________________________________________________________________________________
Subject: Wing alignment / Parts alignment
Date: Jul 19, 2003
Hi All, I personally would not try the "drill the hole in the tab first method for rigging the wings. I am currently building a set of seven rib wings for my 86 firestar. I have found some of the parts I've gotten from TNK are not square. Including the steel inboard ribs. Last night tried the fit of the two drag strut braces and the legs are not welded at the correct angle. Meaning I'll have to bend them to make them fit. Sincerely, Ed Bonsell - 86 Firestar ________________________________________________________________________________
Date: Jul 19, 2003
It is up near Flint at Purdy field. Near Duffield Mi west of Flint off I-69. Michigan Ultralight Association is sponsoring it. See ya there. ----- Original Message ----- From: "Rick & Martha Neilsen" <NeilsenRM(at)comcast.net> Subject: RE: Kolb-List: up and away (again) > > Woody > > Do you have any information on that fly-in in Michigan. > I haven't heard anything about it or even were it is. > > Rick Neilsen > Redrive VW powered MKIII ________________________________________________________________________________
Date: Jul 19, 2003
Subject: Oil Injection
Hey Guys, I got my electrical squared away - GPL elec start ,Batt ,Solenoid ,Rectifier and an EIS by Grand Rapids and the Rotax Dual Ducati Keyed ignition......and a couple extra "KILL Switches" just for safety under the seat.... Anyway..... I'm Rigging all my control cables now.....I have a 503 w/ oil injection . I've looked in catalogs where to set the oil injection"ARM" ( they always show a 582 ) So the "LINE" on the arm is spose to "line-up" with the "LINE" on the oil injection "HOUSING" ............... Here's my Question - What is the "DOT" on the "ARM" ??? The cable only travels aprox 5/8" and the "DOT" lines up with the "LINE" on the housing. Gotta Fly... Mike in MN --- Sometimes you just have to take the leap and build your wings on the way down... Gotta Fly... Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail! ________________________________________________________________________________
Date: Jul 19, 2003
Subject: first taxi
G'day Kolbers, finally got the plane up to the runway, unfurled the wings, hooked up those little pipes that make the flappers & flippers move, started it up and moseyed down the grass. Tailwheel authority left something to be desired so at the far end I attempted to take up some more tension on the chains. Those springs TNK includes with the full swivel wheel are junk. Got to head to my favorite hardware store monday. I had already heeded someone's recent advice and replaced the s-hooks with bolts. Having a tailwheel steering failure upon landing and heading into the bushes takes the fun out of a good ride. Lots of debugging ahead but it sure felt good to be driving a taildragger again. -BB ________________________________________________________________________________
Date: Jul 20, 2003
Subject: (no subject)
Hello List, I don't want to do it, but it looks like I may have to. I just got back from Freshmen Orientation at Louisiana Tech. My daughter, who got hooked on flying in my Mark III, wants to pursue a degree in professional aviation. That means big $$$$. It looks like I will need to sell my Mark III to help finance this and pay for her training. Don't want to get into the price and stuff right now. Just looking for tips on selling an experimental. You guys have always had good advice and I'm turning to you again. Liability is always an issue in this sue your own brother world. I've heard of selling plane as parts without an "N" number. Interested in any suggestions or experience. She is a good ship. I built her for long XC's and she is a blast to fly. Once I figure out how to sell her, I'll post an ad with the details. Wish I could win the powerball and keep my little old Mark III. Thanks again, John Bickham St.Francisville, LA Kolb Mark III - 912 189 hours of fun ________________________________________________________________________________
Date: Jul 20, 2003
Subject: Suggestions for selling a good Mark III - it hurts
Hello List, Sorry for the double message - forgot subject line. I don't want to do it, but it looks like I may have to. I just got back from Freshmen Orientation at Louisiana Tech. My daughter, who got hooked on flying in my Mark III, wants to pursue a degree in professional aviation. That means big $$$$. It looks like I will need to sell my Mark III to help finance this and pay for her training. Don't want to get into the price and stuff right now. Just looking for tips on selling an experimental. You guys have always had good advice and I'm turning to you again. Liability is always an issue in this sue your own brother world. I've heard of selling plane as parts without an "N" number. Interested in any suggestions or experience. She is a good ship. I built her for long XC's and she is a blast to fly. Once I figure out how to sell her, I'll post an ad with the details. Wish I could win the powerball and keep my little old Mark III. Thanks again, John Bickham St.Francisville, LA Kolb Mark III - 912 189 hours of fun ________________________________________________________________________________
Subject: Re: first taxi
Date: Jul 20, 2003
Way to go Bob, Glad to hear you are up and running. I replaced my Mk- 3 tailwheel S-hooks with the small split link connectors that you thread shut. It only took a few passes down the strip without the wings on to loose one set of chains and springs because the S-hooks failed. Had the wings been on, the hard left turn that resulted would have been a ground loop. Fly Safe. Denny Rowe ----- Original Message ----- From: Bob Bean <slyck(at)frontiernet.net> Subject: Kolb-List: first taxi > > G'day Kolbers, finally got the plane up to the runway, unfurled the wings, > hooked up those little pipes that make the flappers & flippers move, > started it up and moseyed down the grass. Tailwheel authority left > something to be desired so at the far end I attempted to take up some > more tension on the chains. Those springs TNK includes with the full > swivel wheel are junk. Got to head to my favorite hardware store > monday. I had already heeded someone's recent advice and replaced > the s-hooks with bolts. Having a tailwheel steering failure upon > landing and heading into the bushes takes the fun out of a good ride. > Lots of debugging ahead but it sure felt good to be driving a taildragger > again. -BB > > ________________________________________________________________________________
Subject: Flying
Date: Jul 20, 2003
Kolbers, I put 2.3 hours on the Mk-3 Saturday, 8 take offs and landings, all landings were pretty bad except the last one so I quit. I still have not figured out the jetting just yet but seem to be making progress. I am only pulling 5300 rpm WOT but she is climbing at 800 fpm so its not going to be a problem until I start taking passengers. The lack of revs is a problem with the tuning, not a prop load problem as reducing pitch only gives a few hundred extra revs before the tuning goes out the window. This engine likes to be loaded. I am begining to suspect that the 100LL that I am running may be causing my lack of revs, I have to change the gasket in my ASC gasculator to one that is compatable with auto fuels before I can try pump gas. I am amazed at the slow flight capabilities of the Mk-3, the thing will slow down to powered parachute speeds and hold altitude on absurbly low throttle settings. Its really a nice handling ship all the way around. Denny Rowe Mk-3 N616DR, 690L-70, PA ________________________________________________________________________________
Date: Jul 20, 2003
Subject: MULA flyin
This message is for Darren with the Firestar and the 40 HP Hirth. Woody and I say you there yesterday and in all the action I didn't ask you about the 40 HP Hirth which I am considering. Give us your comments and thoughts on the engine. How many hours do you have on it. I am considering it in place of a 447 on a firefly. Be interested to here from you, and anyone else with experience with the 40 HP Hirth. Regards Wayne F Wilson ________________________________________________________________________________
Subject: Parts Alignment, Drag struts
Date: Jul 20, 2003
For Ed Bonsell and Kolbers in general, If the drag strut braces angle isn't right they probably sent you the wrong parts. I found out they sent me the drag strut braces for a Slingshot after trying mine for fit, all primed and everything. TNK replaced them free of charge. The new ones fit perfectly. Don't cobble up those drag strut braces, they are an important structural part. Give Kolb a shout. Terry Davis FS2, Painting (forever) ________________________________________________________________________________
Date: Jul 20, 2003
Subject: Re: Flying
Are you sure the tach is right? If taking pitch out of the prop is causing the tuning to go silly, then maybe the prop is right, maybe the engine is doing right, and the tach is wrong? Try an optical tach to calibrate your electrical one? Might not be a factor but just a thought. Richard Pike MKIII N420P (420ldPoops) > >Kolbers, >I put 2.3 hours on the Mk-3 Saturday, 8 take offs and landings, all >landings were pretty bad except the last one so I quit. >I still have not figured out the jetting just yet but seem to be making >progress. I am only pulling 5300 rpm WOT but she is climbing at 800 fpm so >its not going to be a problem until I start taking passengers. The lack >of revs is a problem with the tuning, not a prop load problem as reducing >pitch only gives a few hundred extra revs before the tuning goes out the >window. This engine likes to be loaded. I am begining to suspect that the >100LL that I am running may be causing my lack of revs, I have to change >the gasket in my ASC gasculator to one that is compatable with auto fuels >before I can try pump gas. >I am amazed at the slow flight capabilities of the Mk-3, the thing will >slow down to powered parachute speeds and hold altitude on absurbly low >throttle settings. Its really a nice handling ship all the way around. >Denny Rowe >Mk-3 N616DR, 690L-70, PA > > ________________________________________________________________________________
Date: Jul 20, 2003
Hey Guys, While routing the cable to the oil injector , I started thinking about a different linkage to pull the "ARM" from below. Instead of the cable making a BIG LOOP.... I also thought of making another arm that would mount on the opposite side......then I thought...Is their anything wrong with turning the "OIL INJECTION HOUSING" - UPSIDE DOWN ??????? It's just two screws into the pull start housing...... Gotta Fly... Mike in MN Small milestone.... I haven't started it yet , but testing the elec start cranked it over pretty good.(smile) --- Sometimes you just have to take the leap and build your wings on the way down... Gotta Fly... Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail! ________________________________________________________________________________
Subject: Re: Flying
Date: Jul 20, 2003
Roger....This guy posts on the Kolb list...he is the only one of the buch flying with a 2SI 670L. He has something wrong...I wonder if he has called you...he needs some good advice. attached is his last post. Don . ________________________________________________________________________________
Date: Jul 20, 2003
Subject: Re: Oil Injection
In the Rotax manual, if you mount the engine upside down, is there an instruction that says you need to turn the oil pump over 180 degrees? If not, then it probably doesn't matter as long as the holes, gears and everything will line up. Richard Pike MKIII N420P (420ldPoops) > > Hey Guys, > While routing the cable to the oil injector , I started > thinking about a different linkage to pull the "ARM" from below. Instead > of the cable making a BIG LOOP.... I also thought of making another arm > that would mount on the opposite side......then I thought...Is their > anything wrong with turning the "OIL INJECTION HOUSING" - UPSIDE DOWN ??????? > It's just two screws into the pull start housing...... > > Gotta Fly... > >Mike in MN > > Small milestone.... > I haven't started it yet , but testing the elec start cranked it over > pretty good.(smile) > >--- >Sometimes you just have to take the leap >and build your wings on the way down... > Gotta Fly... > > >Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail! > > ________________________________________________________________________________
Subject: Re: one step fwd-two back
Date: Jul 20, 2003
Bob, Great job on the weight, I guess you must have a 582 on your bird, you beat my weight by 8 pounds and I have since added tundra tires to mine. Your plane is sure going to levitate. Denny Rowe ----- Original Message ----- From: Bob Bean <slyck(at)frontiernet.net> Subject: Kolb-List: one step fwd-two back > > It's a good news/bad news story. My empty weight tipped the scales @ 467 > lbs. > -including oil and coolant. That's with a full size brass radiator and > welded-in > 1.00" x .050 steel windshield supports and (smaller) nose bowl supports. > The :( news - the battery will > have to go up front. Calculation shows that I could > just squeek by the empty weight CG with a 20 lb weight stuck up front > of the rudder > pedals. Yuck, not my style. So off with the nose bowl and out with the torch > once more, startin' to suffer from Big Lar Syndrome here. -BB do not archive > > ________________________________________________________________________________
Subject: Re: Flying
Date: Jul 20, 2003
Don, Thanks for the help, I have been talking to Roger and Tom Olenik about my tuning, we seem to be homing in on things but have not hit the magic combo just yet. We'll keep trying and also keep the list posted on the progress. This is a stout powerplant but the database for setting them up is not yet developed to the level of the Austrian engines. Also compounding my tuning is my insistance on running 100LL, most folks use 93 pump gas as the manual calls for 92 octane minimum, but I beleive in using what the FBOs are selling to help support aviation, it is a huge pain in the behind to travel anywhere if you are running pump gas, and besides, the price differance is getting smaller and smaller. Denny ----- Original Message ----- From: Don Gherardini <donghe@one-eleven.net> Subject: Re: Kolb-List: Flying > > Roger....This guy posts on the Kolb list...he is the only one of the buch > flying with a 2SI 670L. He has something wrong...I wonder if he has called > you...he needs some good advice. > attached is his last post. > > Don > > > . > > ________________________________________________________________________________
Subject: Re: Flying
Date: Jul 20, 2003
Good deal Denny, I sure hope ya get it dialed in pard...That is a very strong engine that 670 3cyl. I cant wait to hear how it does. Have ya considered trying 3 mikunis on it...I know its an expense..but they just do so much better on the 2 cyl 2Si and Cuyunas, (or anything else Ive tried them on) than the bings that I figgered that they would do likewise on that 3 cyl. Good Luck Don ________________________________________________________________________________
Date: Jul 20, 2003
Subject: FireFly - Victor 1+ - EAA Chapter 453 Trip
I have been slowly tweaking the propeller on the FireFly to get the engine speed up to Simonini specs, and it has paid off. If I had not been recording the result of trips to the chapter meetings, it would be difficult to believe the improvement between last month and today. I backed off the prop pitch from 13.25 to 12.5 degrees to get the Victor 1+ to turn over 6,000 rpm. Changed the idle pilot jet from a 40 to a 30 to try and reduce low speed fuel dribble from the air cleaner. And I changed the needle to one with a little more taper to try and reduce some EGT peakiness at higher rpms. The same 108 mile round trip was made today on .5 gallons less fuel (4.6 -> 4.1) with an increase in the average ground speed of 4.5 mph (49.1 -> 53.6). And the fuel burn rate dropped from 2.09 gph to 2.03. Engine rpm was increased from 4,600 to 5,200 rpm. 5,200 rpm is as fast as I can run the engine and not push the cooling temperatures above 190 degrees F at altitude. When it gets a little cooler I will run the engine a little harder to see what happens to the fuel consumption and average speeds. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Jul 21, 2003
From: "johnjung(at)compusenior.com" <johnjung(at)compusenior.com>
Subject: Re: Suggestions for selling a good Mark III - it hurts
John and Group, Here is and idea that I wonder about: 1. Wait for the finalization of the new Sport Pilot etc. 2. Remove the N-numbers 3. Sell it with no documentation as "parts". My guess is that the value of experimentals will go up with the new regulations. Also it shouldn't be difficult for a new owner to register a overweight, undocumented "ultralight". And I would hope that without documentation, it would be less likely that someone would sue. Does anyone else have an opinion on this? John Jung ________________________________________________________________________________
Date: Jul 21, 2003
Subject: Re: Kolb-List Digest: 18 Msgs - 07/20/03
In a message dated 7/20/03 11:57:02 PM Pacific Daylight Time, kolb-list-digest(at)matronics.com writes: > > > Hello List, > > I don't want to do it, but it looks like I may have to. I just got back > from > Freshmen Orientation at Louisiana Tech. My daughter, who got hooked on > flying in my Mark III, wants to pursue a degree in professional aviation. > That > > means big $$$$. > I would highly recommend a student loan instead of selling your favorite hobby. I put five kids thru college with student loans with no problems. Their attitude changed when they realized they were spending their future earnings. I also have a n Ultra Prop that I am not using. It is a four blade adjustable pusher prop off of a Rotax 503. New cost was $439.00, and was thinking of selling for $300 or best offer. Tom Guidroz Kolb 249 Houma, La. 504-868-1319 ________________________________________________________________________________
Subject: Re: Flying
Date: Jul 21, 2003
Don, Yeah, I have thought about converting to Mikuni carbs, even talked to a fellow from Texas a few years ago who put 28mm VM Mikunis on a 690L he was flying on an S12 Rans, he said it improved performance quite a bit. I have grown to appreciate the ease of working on the Bings over the years and really like the way the float bowls pop right off, they are much easier to make jetting changes than the Mikunis. I guess I am getting lazy in my old age.. Also know that Bing has a 32 mm slide carb available and 2SI sometimes uses them, however enough people have made these big honkers work that I still am holding out hope that I'll get her dialed in. Denny ----- Original Message ----- From: Don Gherardini <donghe@one-eleven.net> Subject: Re: Kolb-List: Flying > > Good deal Denny, I sure hope ya get it dialed in pard...That is a very > strong engine that 670 3cyl. I cant wait to hear how it does. Have ya > considered trying 3 mikunis on it...I know its an expense..but they just do > so much better on the 2 cyl 2Si and Cuyunas, (or anything else Ive tried > them on) than the bings that I figgered that they would do likewise on that > 3 cyl. > > Good Luck > Don > > ________________________________________________________________________________
Subject: Re: FireFly - Victor 1+ - EAA Chapter 453 Trip
Date: Jul 21, 2003
----- Original Message ----- From: Jack & Louise Hart <jbhart(at)ldd.net> Subject: Kolb-List: FireFly - Victor 1+ - EAA Chapter 453 Trip Jack Hart wrote: Changed the idle pilot jet from a 40 to a 30 to try and reduce low speed fuel dribble from the air cleaner. > Jack, I have the same problem with fuel dribbling out of all three carbs at idle speeds, my idle air screws are full lean and I still have dribbles, your post has convinced me to go ahead and buy a leaner set of idle jets, they are expensive little buggers. Denny Rowe Mk-3, 2SI 690L-70 > > ________________________________________________________________________________
Date: Jul 21, 2003
> > >----- Original Message ----- >From: Jack & Louise Hart <jbhart(at)ldd.net> >To: >Subject: Kolb-List: FireFly - Victor 1+ - EAA Chapter 453 Trip > > >Jack Hart wrote: >Changed the idle pilot jet from a 40 to a 30 to try and reduce low speed >fuel dribble from the air cleaner. > > >Jack, >I have the same problem with fuel dribbling out of all three carbs at idle >speeds, my idle air screws are full lean and I still have dribbles, your >post has convinced me to go ahead and buy a leaner set of idle jets, they >are expensive little buggers. >Denny Rowe >Mk-3, 2SI 690L-70 > Denny, I had no trouble replacing the idle jet with smaller ones, and it may be a characteristic of a reed valve engine. I tried to do the same on the Rotax 447 and I could not get the engine to spool up when advancing the throttle. I hope it works for you. I have run out of easy things to do to stop this phenomena. The Victor 1+ still dribbles on the wing and the tail feathers, but I do not believe it is as bad as it was (probably wishful thinking). I believe a short carburetor extension that will allow the mounting of a booster bottle may be the only hope to entirely eliminate slow speed dribble. I have been working on a drawing for the machine shop. But I keep thinking it would be less expensive to just keep washing and cleaning the wing and the tail feathers. A booster bottle will hurt the top end a little, but since I do not run the engine there, I will not miss it. It is supposed to lean the engine out on the lower end and give better fuel flow rates too. I have not flown the FireFly with the modified throttle slide valve that acts like a small booster bottle. Now that the engine is running very well, it may be the time to try it before I take the drawing to the machine shop. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Jul 21, 2003
Hey Guys, Richard , I ordered some more goodies from L.E.A.F. today problem with turning the oil injection housing upside down as long as the reservoir is higher.....He also said when the engine is set-up to run inverted they don't do anything to the oil injector pump....it runs inverted too. Good , that's gonna make a cleaner , lighter installation.... Now all we need is some sorta 90 degree pulley for the carbs , and we could loose those big loops in the rest of the cables.......come on Jack ( Hart ) invent us some of those.... Gotta Fly... Mike in MN , FSII , 503 , IVO , GPL , EIS --- Sometimes you just have to take the leap and build your wings on the way down... Gotta Fly... Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail! ________________________________________________________________________________
Date: Jul 21, 2003
> > Hey Guys, Richard , > I ordered some more goodies from L.E.A.F. today problem with turning the oil injection housing upside down as long as the reservoir is higher.....He also said when the engine is set-up to run inverted they don't do anything to the oil injector pump....it runs inverted too. > > Good , that's gonna make a cleaner , lighter installation.... > > Now all we need is some sorta 90 degree pulley for the carbs , and we could loose those big loops in the rest of the cables.......come on Jack ( Hart ) invent us some of those.... > > Gotta Fly... > Mike in MN , FSII , 503 > >--- Mike, They have already been invented. See: http://www.thirdshift.com/jack/firefly/tube1.jpg I used two bicycle brake cable guide tubes. I believe they are stainless steel with nylon tube inserts. What is nice about them is that you can bend them to what ever shape you want. I use bicycle de railer cables for the throttle and choker because they are a smaller cross section cable and so you can run them through tighter bends. I make sure that the cables are well coated with "lubriplate" grease. In the photo I used just one each for a tight 90 degree bend, but two could be run in series to get up to a 180 degree bend or compound 90 degree bends. You can find these parts at most bicycle shops. If they don't stock them they can order them. To use the de railer cables, one must file the lead plug end a little to get to fit into the throttle slide location hole. The cost of these parts is quite modest. I believe I had to make tube spacer to get them to fit nicely in the sockets underneath the rubber protectors. Another way to do it is to fill the sockets with JBWeld, and drill through from the bottom to re establish the cable hole. Then flip it over and drill out the JBWeld to the correct size to fit the large end of the guide tube. The next time I go up to the airport, I will take some more photos and put up a page about how it was done. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Jul 21, 2003
hurts > I would sell it with a guarantee to kill. Either by poor pilotage, poor construction or poor design. If something happens then you have fulfilled the guarantee. If he doesn't like the guarantee then find someone else to sell it to. >My guess is that the value of experimentals will go up with the new >regulations. Also it shouldn't be difficult for a new owner to register >a overweight, undocumented "ultralight". And I would hope that without >documentation, it would be less likely that someone would sue. > >Does anyone else have an opinion on this? > >John Jung > > ________________________________________________________________________________
Date: Jul 21, 2003
From: "Blackwell, Charlie & Meredith" <wozani(at)optonline.net>
Subject: Brake problem
Hi guys; I have been following the list for a while since I bought a used MKII twinstar, '90 vintage, and am third owner. While replacing the whole landing gear set up I have run into a problem with the brakes. Actually I have found many difficulties, but this one is holding me up for now. They are drum brakes from TNK, a Firestar set with the Azusa wheels and tires. After painting, drilling, and bolting everything together the brakes barely fit into the drums and now require huge effort to turn the tires around. I expected a little brake rubbing, but this is ridiculous. Does anyone have suggestions? Did I miss something here? Charlie Blackwell, NJ ________________________________________________________________________________
Subject: Re: Brake problem
Date: Jul 21, 2003
not sure about your type of brakes, but is it possible you could have the cam in reversed? ----- Original Message ----- From: "Blackwell, Charlie & Meredith" <wozani(at)optonline.net> Subject: Kolb-List: Brake problem > > Hi guys; > I have been following the list for a while since I bought a used MKII twinstar, '90 vintage, and am third owner. While replacing the whole landing gear set up I have run into a problem with the brakes. Actually I have found many difficulties, but this one is holding me up for now. They are drum brakes from TNK, a Firestar set with the Azusa wheels and tires. After painting, drilling, and bolting everything together the brakes barely fit into the drums and now require huge effort to turn the tires around. I expected a little brake rubbing, but this is ridiculous. > Does anyone have suggestions? Did I miss something here? > > Charlie Blackwell, NJ > > ________________________________________________________________________________
Date: Jul 21, 2003
> > > Now all we need is some sorta 90 degree pulley for the carbs , and > we could loose those big loops in the rest of the cables.......come on > Jack ( Hart ) invent us some of those.... > > Gotta Fly... > Mike in MN , FSII , > 503 , IVO , GPL , EIS Go to the bicycle shop and check out those nice little Teflon lined cable guides they use on the new bikes. I use 'em and like 'em. There's a picture at the bottom of this page. http://www.bcchapel.org/pages/0003/pg2.htm Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Jul 22, 2003
Subject: Re: Spiderwebs & strainers
> Anybody on the list ever though about the need for a finger strainer in the > oil injection tank? Well, I'm putting one in mine. Here's why... > I realize that some of the "heatherns" on the list > Richard Pike Richard/All: Glad you made it. You have been having your share of "wakeups". You mentioned the cylinder was in the shop and waiting word on whether an oversize piston was going to be required. But.....you didn't mention if you were going to go with two. I am assuming you will go with two if an oversize is called for. Also, do you think you might have some damage to crank bearings from oil starvation? Hope we don't have any "heathens" on the List, but one never knows. Last but not least, your previous post should be archived, per chance it will save some other unsuspecting soul the same problem you have experienced. Take care, john h ________________________________________________________________________________
Date: Jul 22, 2003
> > >You mentioned the cylinder was in the shop and >waiting word on whether an oversize piston was >going to be required. But.....you didn't mention >if you were going to go with two. I am assuming >you will go with two if an oversize is called >for. The Rotax dealer I bought the engine from said that it was permissible to have one cylinder at standard and one at first over, or one at first over and one at second over, but not one at standard and one at second over. If you know different, let me know now before I button it back up. >Also, do you think you might have some >damage to crank bearings from oil starvation? The crank still had an oil film on it, the wrist pin looked good, the wrist pin bearings normal, no signs of heat anywhere, nothing abnormal at all other than the one piston seized. I think it will be OK, but am open to opinions and suggestions. (Still learning up here in Tennessee...) Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Jul 22, 2003
Richard, I also will thank the carpenter that you had a easy time of it! He or one a his assistants most likely had a finger in that oil tank keeping that bug nest stirred up till you were lined up. Don Gherardini Sales / Engineering dept. American Honda Engines Power Equipment Company 800-626-7326 ________________________________________________________________________________
Date: Jul 22, 2003
Richard, I took the liberty of removing the d not arkive message at the bottom for proper placement of this message for posterities sake. Lord knows you have had your share of excitement with your new 582. I hope you get all the kinks straightened out soon and I share your praise of his guiding hand. Sincerely, Denny Rowe ----- Original Message ----- From: Richard Pike <rwpike(at)charter.net> Subject: Kolb-List: Spiderwebs & strainers > > Anybody on the list ever though about the need for a finger strainer in the > oil injection tank? Well, I'm putting one in mine. Here's why... > > Will Tatham, one of our listers stopped by last Tuesday, we talked Kolbs > for a while and then went flying. Had a good time. Took my daughter flying > later that evening, we were approaching an RC model airplane strip about > ten miles south and the engine seized. Landed w/o incident and trailered it > out Wednesday morning. (Sorry Will, I guess it just wasn't your day to have > an adrenaline rush...) > > The line from the oil tank to the oil injection pump had air in it, removed > the oil injection tank and it wouldn't drain. Dumped the oil out and found > a large gooey mass in it, turned out to be a spider web cocoon. Swollen > with oil, it was about as long and big around as my finger. With the oil > squeezed out of it, it was about 1/10 that size. Apparently it had been > hidden off in a corner of the tank when I got it, and it had resisted > rinsing out with gasoline, blowing out with an air hose, but eventually > turned loose after several week's saturation in oil. And when it found it's > way to the oil orifice, it totally blocked 3 quarts of oil from flowing out > the tube. Wouldn't even drip. > > Anyway, the mag end cylinder is at the machine shop, will know tomorrow > whether I can go back with a stock piston or first oversize. Rest of the > 582 insides still look new. Should be back in the air sometime next week. > With a strainer over the oil port in the tank, which is one of the reasons > why I am posting this otherwise unlikely event to the list, just to alert > others to the possible need to put a strainer over the oil tank pickup > hole. I have never heard of anyone else having any oil line blockages, but > I guess a bug or anything else could cause a similar problem. > > The other reason for putting this on the list is because it gives this old > preacher a chance to brag on my Boss, the Jewish Carpenter. My fault for > using an old used tank with it's hidden problem, but His grace let my > engine blow at the best of all possible times and places. > The previous flight before I took Will up had been to give a local > newspaper reporter her first flight. Wouldn't that have been a nice story > for the paper? > And the next scheduled flight was to give EAA Young Eagles rides on > Saturday morning. Another nasty media event avoided. > And then the engine "just happened" to blow 1/2 mile off the approach end > of a 500' long strip I "just happened" to already be lined up with. Where > helpful people assisted to secure the airplane, lock the place up > overnight, and take us home. > The thunderstorms Wednesday noontime didn't start until after the airplane > was safely back in the garage. > > What are the odds? > > I realize that some of the "heatherns" on the list (that's how we say it in > East Tennessee...) will roll their eyes, shake their heads and question my > intelligence, but I prefer to acknowledge that when it gets that good it > ain't coincidence and it ain't luck, let's just give credit where credit is > due. > Thanks again, Sir > > Richard Pike > MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Jul 22, 2003
> The Rotax dealer I bought the engine from said that it was permissible to > have one cylinder at standard and one at first over, or one at first over > and one at second over, but not one at standard and one at second over. If > you know different, let me know now before I button it back up. > Richard Pike Richard/All: Will not dispute the Rotax dealer's word. However, if it were my engine, I would most definitely bore both to the same dimensions. Rotax two stroke engines, in my day, 1987-1993 (represents many overhauls), were notorious for having a considerable amount of weight difference between two piston assemblies. My engine man, a noted racing engine builder in Montgomery, Alabama, would balance the piston assemblies and match the ports whenever he built an engine for me. This procedure was a tremendous improvement in reducing vibration. I would think there would be a considerable amount of difference between a standard and a 1st over piston assembly, especially turning the rpm we normally turn. john h ________________________________________________________________________________
Date: Jul 22, 2003
From: Eugene Zimmerman <eugenezimmerman(at)dejazzd.com>
John Hauck wrote: > > > Last but not least, your previous post should be > archived, per chance it will save some other > unsuspecting soul the same problem you have > experienced. > > Take care, > > john h > I agree. It should definitely be archived. It will give some solid supporting evidence for all us (idiots) who believe it is better and more reliable to KISS and have elected to remove their oil injection in favor of the old fashioned 50/1 fuel mix. PS The other reason for archiving it is because it shows the advantage of flying with "The Boss", (the Jewish Carpenter). ez ________________________________________________________________________________
Date: Jul 22, 2003
> Anybody got any suggestions where a scale might be borrowed/used that > measures that fine? Or should I build a balance beam and just keep > comparing them? > > Richard Pike Richard/All: Isn't there a lot of stock car and other types of racing in the Bristol, TN, area? Check out some engine builders, race engines that is. Also might be able to find something at one of the motorcycle shops that does race setups and tweeks for motorcycle racing. Other than the above, the local drug store, or a local drug pusher. :-) Take care, john h ________________________________________________________________________________
Date: Jul 22, 2003
Richard, around here, we match balance pistons and other small components with a digital gram/oz postal sclae bought over the internet for 29.95..has a 10 lb capacity, and works like a charm..we have checked it with a triple beam Ohaus and it is dead on.....check ebay Don Gherardini Sales / Engineering dept. American Honda Engines Power Equipment Company 800-626-7326 ________________________________________________________________________________
Date: Jul 22, 2003
Subject: 87 Octane No Lead & 100 LL
A question for those of you who have used both fuels in your two cycle engine. If the engine is tuned in for 87 octane, no lead, what changes can one expect in EGT, CHT, and gph at the same cruise rpm upon switching to 100 octane LL? Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Jul 22, 2003
In a message dated 7/22/03 7:15:51 AM Central Standard Time, rwpike(at)charter.net writes: << ain't coincidence and it ain't luck, let's just give credit where credit is due. Thanks again, Sir Richard Pike MKIII N420P (420ldPoops) >> Richard, I dont say much on this list. Mostly I ask for help. But You leave me no choice. Maybe it has something to do with deny Me & I will deny you. Things dont just happen. There is always a reason. He knew exactly where you were. Flying brings one closer to nature. For some of us, It brings us closer to the Creator of nature. A good report maketh the bones fat. So good to hear you landed without incident. Are you going to be at Oskosh? Ed (In Houston) Do Not Archieve ________________________________________________________________________________
Date: Jul 22, 2003
Subject: Re: 87 Octane No Lead & 100 LL
> If the engine is tuned in for 87 octane, no lead, what changes can one expect in EGT, CHT, and gph at the same cruise rpm upon switching to 100 octane LL? > > Jack B. Hart FF004 Jack/All: Not much difference. May be able to see a tiny drop in EGT at similar power settings compared with 87 octane. I burned many gals of 100LL when I was cross countrying the Firestar and a couple hundred hours on the 582 in the MKIII. john h ________________________________________________________________________________
Subject: kolb firefly
Date: Jul 22, 2003
I've just completed building a Kolb Firefly and have run taxi tests. The ground handling is very squirrly--so much so that I won't fly it. I have checked wheel alignment per manual--neutral no toe in--toe out. Factory suggested slight toe out would help. Toe out adjustment made mild improvment, but not satisfactory. I'm using six inch tires--I've removed brake drums to eliminate any intermittent drag--no change. The configuration of the airplane is per Kolb except I have added about a square foot to the verticle stabalizer. The engine is Hirth 2702 40 HP with three blade prop. Background info--I built a Firestar ten years ago and completed 700 plus landings and over 600 hours of G A tail dragger time. Would appreciate suggestions and comments regarding others experiences with the firefly and its ground handling. I know a couple of Firefly owners who have had no problems.------George Daum gjdaum(at)camano.net ________________________________________________________________________________
Date: Jul 22, 2003
Subject: Re: kolb firefly
> >I've just completed building a Kolb Firefly and have run taxi tests. The ground handling is very squirrly--so much so that I won't fly it. I have checked wheel alignment per manual--neutral no toe in--toe out. Factory suggested slight toe out would help. Toe out adjustment made mild improvment, but not satisfactory. I'm using six inch tires--I've removed brake drums to eliminate any intermittent drag--no change. The configuration of the airplane is per Kolb except I have added about a square foot to the verticle stabalizer. The engine is Hirth 2702 40 HP with three blade prop. > >Background info--I built a Firestar ten years ago and completed 700 plus landings and over 600 hours of G A tail dragger time. > >Would appreciate suggestions and comments regarding others experiences with the firefly and its ground handling. I know a couple of Firefly owners who have had no problems.------George Daum gjdaum(at)camano.net > George, I had similar problems, and below is how I solved it. With the FireFly on a hard smooth surface do the following: 1. Load the seat with about 200 pounds of any thing. 2. Roll the plane forward and backward to settle the gear. 3. Sight the wheel alignment front to back to see if the wheels are parallel. If not get them parallel and go back to #2. 4. Using a level check vertically on the side of each wheel to see if the top is slightly out (away from the fuselage) from the bottom. If not bend the axle, and go back to #2. 5. Practice, practice & more practice. Good Luck. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Jul 22, 2003
I had the same problem on a Ultrastar. The solution to my problem was two fold, The holes in the backing plates, and mounts on the gear did not center the shoes in the drum, it only took a small amount of filling with a rat tail file to solve this problem. The other problem was the drums were not running concentric with the wheels, turning the drum on the wheel helped, but I still have a slight rub as the wheel turns. Hope this helps. Dan Walter ----- Original Message ----- From: "Blackwell, Charlie & Meredith" <wozani(at)optonline.net> Subject: Kolb-List: Brake problem > > Hi guys; > I have been following the list for a while since I bought a used MKII twinstar, '90 vintage, and am third owner. While replacing the whole landing gear set up I have run into a problem with the brakes. Actually I have found many difficulties, but this one is holding me up for now. They are drum brakes from TNK, a Firestar set with the Azusa wheels and tires. After painting, drilling, and bolting everything together the brakes barely fit into the drums and now require huge effort to turn the tires around. I expected a little brake rubbing, but this is ridiculous. > Does anyone have suggestions? Did I miss something here? > > Charlie Blackwell, NJ > > ________________________________________________________________________________
Date: Jul 22, 2003
George, We now have about 20 hours on our FireFly with 6.00-6 tires. We found that alignment is critical, and that zero toe-out worked best for us. We found that it helped to put a lot of slack in the chains that drive the tailwheel. Too much authority on the tailwheel made it easy to overcorrect steering. On landing, I use the technique adopted by old-time tailwheelers, which is to dance on the rudder pedals during roll-out, adjusting the oscillation as required to stay on centerline. This seems to keep me from overcorrecting. For take-off, I find this is not necessary because the Firefly pops off the ground too fast for me to even think about steering. I feel the landing gear is well designed, and it accepts the larger tires okay. As I became more practiced with landings, I found I have less tendency to overcorrect. Keep practicing....yer gonna' love it! Bruce McElhoe Reedley, CA FF#88 > > I've just completed building a Kolb Firefly and have run taxi tests. The ground handling is very squirrly--so much so that I won't fly it. I have checked wheel alignment per manual--neutral no toe in--toe out. Factory suggested slight toe out would help. Toe out adjustment made mild improvment, but not satisfactory. I'm using six inch tires--I've removed brake drums to eliminate any intermittent drag--no change. The configuration of the airplane is per Kolb except I have added about a square foot to the verticle stabalizer. The engine is Hirth 2702 40 HP with three blade prop. > > Background info--I built a Firestar ten years ago and completed 700 plus landings and over 600 hours of G A tail dragger time. > > Would appreciate suggestions and comments regarding others experiences with the firefly and its ground handling. I know a couple of Firefly owners who have had no problems.------George Daum gjdaum(at)camano.net > > ________________________________________________________________________________
Date: Jul 22, 2003
> Are you going to be at Oskosh? > > Ed (In Houston) > > Do Not Archieve Be at Oshkosh? I'll be doing well to make it around the pattern... No, maybe I'm getting old but Oshkosh and Sun 'N Fun are a little to big and a lot too commercial for me any more. You guys go ahead and have fun, I'll just remember it the way it used to be. Besides, I don't need to buy anything, therefore I don't need to go, and I'll see all you guys at Chestnut Knolls in September anyway, so that's good enough. Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Jul 22, 2003
Jack, I agree with John H, there isn't much difference between 100LL and 87, 91 autogas as far as performance or lack thereof.. Autogas is better for a 2-stroke without the lead content. Ralph 447 Rotax writes: > > A question for those of you who have used both fuels in your two > cycle engine. > > If the engine is tuned in for 87 octane, no lead, what changes can > one expect in EGT, CHT, and gph at the same cruise rpm upon > switching to 100 octane LL? > > Jack B. Hart FF004 > Jackson, MO > > > Jack & Louise Hart > jbhart(at)ldd.net > > > > > > > > > > The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Subject: Re: Michigans Thumb
Date: Jul 22, 2003
Just keeping in touch................leaving Naicam, Saskatchewan tomorrow morning for Minnesota & Wisconsin. Won't be long now. Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose N78LB www.gogittum.com ----- Original Message ----- From: "Thom Riddle" <jtriddle(at)adelphia.net> Subject: Re: Kolb-List: Michigans Thumb > > I am new to the Kolb List and would like to meet you when you come through Niagara Falls area. I live in Tonawanda a northern suburb of Buffalo and keep my plane at Buffalo Airfield (9G0), southeast side of Buffalo. If you are planning on viewing the falls from the air, there is now a permanent NOTAM and TFR which dictates and limits the way one can fly over the falls. 3500' min., clockwise pattern, radio announce position etc. etc. etc. > > Thom in Buffalo > > ________________________________________________________________________________
Subject: Re: Trip from Minnesota to Houston
Date: Jul 22, 2003
I'm leaving Naicam, SK tomorrow morning for Evansville & Minneapolis, then Wisc. I can't remember where you live. Are you up for a visit ?? Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose N78LB www.gogittum.com ----- Original Message ----- From: "Gary robert voigt" <johndeereantique(at)qwest.net> Subject: Re: Kolb-List: Trip from Minnesota to Houston > > Robert, that was a great story and i was with you every mile of the way > on the edge of my seat. glad you had a safe trip. > > thanks, > Gary r. voigt > > Robert Laird wrote: > > > > > For those of you who might be interested, over Memorial Day weekend I > > ferried an ultralight, that a friend had just bought, from Minnesota to > > Houston, TX... Here's a link to the story: > > > > http://www.texas-flyer.com/texas-flyer/Minnesota > > > > It's probably trivial compared to what Mr. Hauck is accustomed to, but it > > was quite the adventure for me! > > > > -- Robert > > > > ________________________________________________________________________________
Date: Jul 22, 2003
George, You going probably find the FireFly a little quicker than a FireStar by comparison. I read your other post about using 6 inch wheels, we too are running larger wheels and tires on our FireFly with no problems. One thing I did catch is your comment about having the tail wheel chains loose, nope should be tight, your want authority and not have to fight it wondering about seeking it's own direction. You also mentioned about pumping the rudder pedals, not good either, it's not a peddle car. The FireFly normally is very docile to taxi around - if your having that much problem just taxiing it's either technique or some adjustment. Not sure why you would have added the extra surface area to the tails vert. stab, it's fairly stable and has plenty of rudder authority as was. Will make it more difficult to taxi in cross wind as it will want to weather vane (turn) in to the wind. What type of wheels do you have, the wheel barrow type - if so you may find it advantageous to upgrade the bearing to better quality. The cheap China made ones are and get sloppy and can cause some brake grabbing. I sense your used to a heavier airplane and may either be over controlling or behind the airplane. How long has it been since you flew and flown a tail dragger, how much recent flight time? Tighten the chains back up like they should be. There should be a spring coupled in the chain on each side. http://thirdshift.com/jack/firefly/firefly08a.html (This link illustrating this is from Jack Harts wonder web site) You need the spring to have full rudder authority while not over straining the tail wheel while on the ground in tight turn. Also reduces the wheel from shimmying. If the wheels are aligned and tracking as close as you say the only other things I can think of is the engine thrust alignment - pivoted right or left of center line and angle of the engine up and down. Next do some slow to moderate speed taxi in to the wind with your feet on the floor and just let it roll. Any problem there. I suggest you start by installing the tail control linkage as Kolb calls for. Then take the bird out (be prepared to fly, belt on and gas in tank just in case) and do some slow taxiing. Try it taxiing into the wind with your feet on the floor at a slow and moderate pace - just let it roll. If it does not exhibit any bad characteristics there, get back on the rudder pedals. As you feel comfortable with that, increase speed slightly and work your way up. Note only apply enough power to get it moving and then back off the power so it's slowing down. When comfortable with that then proceed to maintaining just enough power on to keep it rolling but not enough to fly. As you get better acquainted with the airplanes handling characteristics progress to where you lift that tail but make sure your back on the power. If things start happening to fast back on the throttle, feet on the floor, and let the tail down. It will slow down real quickly. Continue this until you feel competent to lift off. When you finally ready give it the throttle and go. You'll be off in no time. When you come in to land don't let it get it to slow during the landing. When they do quit flying they do it suddenly. Just keep a little power on and slowly feel for the ground and back on the power upon contact. I recommend a three point landing in the early stages until you get to know the airplane. As you get comfortable you'll be able better time things, If you have any questions, feel free to email me. The FireFly is not a bad flying airplane. I did not get comfortable until I done some taxiing as described above and then shot two sets of 10 take offs and landings. By the end of that I was pretty cocky and could spot land it. One word of advise that applies to it and most other Kolbs, don't get it to slow when landing. Don't want you to prang the gear. There are those like me that have 8 ( and those that will, and those that will not tell about it. jerb > >I've just completed building a Kolb Firefly and have run taxi tests. The >ground handling is very squirrly--so much so that I won't fly it. I have >checked wheel alignment per manual--neutral no toe in--toe out. Factory >suggested slight toe out would help. Toe out adjustment made mild >improvment, but not satisfactory. I'm using six inch tires--I've removed >brake drums to eliminate any intermittent drag--no change. The >configuration of the airplane is per Kolb except I have added about a >square foot to the verticle stabalizer. The engine is Hirth 2702 40 HP >with three blade prop. > >Background info--I built a Firestar ten years ago and completed 700 plus >landings and over 600 hours of G A tail dragger time. > >Would appreciate suggestions and comments regarding others experiences >with the firefly and its ground handling. I know a couple of Firefly >owners who have had no problems.------George Daum gjdaum(at)camano.net > > ________________________________________________________________________________
Date: Jul 23, 2003
Subject: FireFly Nose Light, New Refueling Method & Air Show Pics
FireFlyers & Kolbers, I reworked my nose light because the original light drew about four amperes. I changed to some bright LEDs to reduce the current. The mod can be seen on the bottom of: http://www.thirdshift.com/jack/firefly/firefly74.html Also, I attended an air show at Cape Girardeau, Missouri, and some photos can be seen at: http://www.thirdshift.com/jack/firefly/firefly97.html And, I found a new gas can that will let me refuel the FireFly without the aid of a funnel, extra tubing or transfer pump. It can be seen on the bottom at: http://www.thirdshift.com/jack/firefly/firefly81.html Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Subject: X-country
Date: Jul 23, 2003
Thinking about a 240 mile round trip to a fly-in on sept 12 in my cayuna 430 ultrastar, 6 gal gas,several stops!, have been 10-12 miles away from airport so far, have noticed on landing it does not seem to want to rev back up very easy??. if I do a go around. my other plane is a minimax with a ao84 engine 4cyl-4-stroke,,guess I am just having a rough time getting used to a 2-stroke! any suggestions or comments welcome,ron in still hot west Texas. ________________________________________________________________________________
Subject: Re: X-country
Date: Jul 23, 2003
You would do better flying your mini max to the flying as the cyuna will not warn you when it is ready to burn a piston. how do I know this? From coming out of the sky with no airport under me. The cyuna is a ok engine when it is running. but how did it ever get its nick name killer cyuna Put a 084 on that ultrastar and you will have a very good plane Randy in NC No longer flying the soobydoo Sold it and I miss it -- Original Message ----- From: "ronnie wehba" <rwehba(at)wtxs.net> Subject: Kolb-List: X-country > > Thinking about a 240 mile round trip to a fly-in on sept 12 in my cayuna 430 ultrastar, 6 gal gas,several stops!, have been 10-12 miles away from airport so far, have noticed on landing it does not seem to want to rev back up very easy??. if I do a go around. my other plane is a minimax with a ao84 engine 4cyl-4-stroke,,guess I am just having a rough time getting used to a 2-stroke! any suggestions or comments welcome,ron in still hot west Texas. > > ________________________________________________________________________________
Date: Jul 23, 2003
thanks randy, if i keep it ,it will have a 84 where did yours go? ----- Original Message ----- From: "Mid-State Sandblasting" <plane(at)rtmc.net> Subject: Re: Kolb-List: X-country > > You would do better flying your mini max to the flying as the cyuna will not > warn you when it is ready to burn a piston. how do I know this? From > coming out of the sky with no airport under me. The cyuna is a ok engine > when it is running. but how did it ever get its nick name killer cyuna > Put a 084 on that ultrastar and you will have a very good plane > > Randy in NC No longer flying the soobydoo Sold it and I miss > it > > > -- Original Message ----- > From: "ronnie wehba" <rwehba(at)wtxs.net> > To: > Subject: Kolb-List: X-country > > > > > > Thinking about a 240 mile round trip to a fly-in on sept 12 in my cayuna > 430 ultrastar, 6 gal gas,several stops!, have been 10-12 miles away from > airport so far, have noticed on landing it does not seem to want to rev back > up very easy??. if I do a go around. my other plane is a minimax with a ao84 > engine 4cyl-4-stroke,,guess I am just having a rough time getting used to a > 2-stroke! any suggestions or comments welcome,ron in still hot west Texas. > > > > > > ________________________________________________________________________________
Date: Jul 23, 2003
Subject: Brake problems
Thanks everyone for the suggestions on and off the list. I finally took a small file and sandpaper to the drum pads. By buffing them with sandpaper, reinstalling and turning, you can see the shiny parts where the pads rub. Then I filed and sanded again until they turned pretty well. Seems like it was only by the mounting point for the pads opposite the activating cam. Much better now. Thanks again, Charlie, MKII Twinstar, 503 w/3blade Ivo ________________________________________________________________________________
Subject: Re: Oshkosh 2003
Date: Jul 23, 2003
Godspeed John, Wishing you clear skies and smooth air pard. See you In Wis. http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Date: Jul 23, 2003
how bout a explanation on how you made the paint look like it is waving? ----- Original Message ----- From: "Don Gherardini" <donghe@one-eleven.net> Subject: Re: Kolb-List: Oshkosh 2003 > > Godspeed John, > Wishing you clear skies and smooth air pard. > See you In Wis. > > http://www.geocities.com/dagger369th/my_firefly.htm > Don Gherardini- > FireFly 098 > > > > > ________________________________________________________________________________
Date: Jul 24, 2003
Subject: Fine Scale
Old Poops, <> Almost any firearms reloader will have a powder scale that can measure the weight of a postage stamp. They only need it when they are actually reloading so borrowing it for several days is usually easy. The conversion factor from grains to grams is strange (15.432 grains = 1 gram) but mostly you are looking for equal, right? Use equal lengths of fishing line to hang the part(s) from the pan. Only real problem is this only works for relatively small parts. Tom Kuffel Whitefish, MT Building Original FireStar ________________________________________________________________________________
Subject: Re: Fine Scale
Date: Jul 24, 2003
----- Original Message ----- From: "kuffel" <kuffel(at)cyberport.net> Subject: Kolb-List: Fine Scale > > Old Poops, > > < measures that fine?>> If you are still having problems finding a scale, contact me at my personal email and I will look up a falconer in your area. Guaranteed that they will have a gram scale capable of measuring within a tenth of a gram up to five pounds. Larry Cottrell ________________________________________________________________________________
Date: Jul 24, 2003
Subject: Re: Uv protection
For those of you who are looking into latex paint, here are a couple of sites to check. http://www.lightminiatureaircraft.com/generic34.html Have been using Sherwin Williams Hi Fill primer which fills the weave of fibreglas and then spraying a latex final coat. Currently looking for a clear coat to increase the shine. Bob - Wichita ________________________________________________________________________________
Date: Jul 24, 2003
Subject: Re: Firestar II banks to the right
When my friend, Chuck lets his stick go, his FS II banks pretty hard to the right. Even starting level with full left rudder she still banks to the right. After careful inspection, we can't see any reason for this. I believe the fix is to put a trim tab on the ailerons, but where? Should it be mounted on the bottom of the right aileron & bent down? Shack FS II SC ________________________________________________________________________________
Date: Jul 24, 2003
Hi Ronnie I mine ended up in tenn. The guy that bought it was very happy with it He only flew 150s before he bought it. he had no trouble switching to ultralights. Randy ----- Original Message ----- From: "ronnie wehba" <rwehba(at)wtxs.net> Subject: Re: Kolb-List: X-country > > thanks randy, if i keep it ,it will have a 84 where did yours go? > ----- Original Message ----- > From: "Mid-State Sandblasting" <plane(at)rtmc.net> > To: > Subject: Re: Kolb-List: X-country > > > > > > You would do better flying your mini max to the flying as the cyuna will > not > > warn you when it is ready to burn a piston. how do I know this? From > > coming out of the sky with no airport under me. The cyuna is a ok engine > > when it is running. but how did it ever get its nick name killer cyuna > > Put a 084 on that ultrastar and you will have a very good plane > > > > Randy in NC No longer flying the soobydoo Sold it and I > miss > > it > > > > > > -- Original Message ----- > > From: "ronnie wehba" <rwehba(at)wtxs.net> > > To: > > Subject: Kolb-List: X-country > > > > > > > > > > Thinking about a 240 mile round trip to a fly-in on sept 12 in my cayuna > > 430 ultrastar, 6 gal gas,several stops!, have been 10-12 miles away from > > airport so far, have noticed on landing it does not seem to want to rev > back > > up very easy??. if I do a go around. my other plane is a minimax with a > ao84 > > engine 4cyl-4-stroke,,guess I am just having a rough time getting used to > a > > 2-stroke! any suggestions or comments welcome,ron in still hot west Texas. > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 25, 2003
have you seen it lately, he propped it at half throttle and the rest is as we shall history,he was not in it, no one was hurt cept the kolb and a building ouch!! Item #2424778978 ebay number have a look ----- Original Message ----- From: "Mid-State Sandblasting" <plane(at)rtmc.net> Subject: Re: Kolb-List: X-country > > Hi Ronnie > I mine ended up in tenn. The guy that bought it was very happy with it > He only flew 150s before he bought it. he had no trouble switching to > ultralights. > Randy > ----- Original Message ----- > From: "ronnie wehba" <rwehba(at)wtxs.net> > To: > Subject: Re: Kolb-List: X-country > > > > > > thanks randy, if i keep it ,it will have a 84 where did yours go? > > ----- Original Message ----- > > From: "Mid-State Sandblasting" <plane(at)rtmc.net> > > To: > > Subject: Re: Kolb-List: X-country > > > > > > > > > > > You would do better flying your mini max to the flying as the cyuna will > > not > > > warn you when it is ready to burn a piston. how do I know this? From > > > coming out of the sky with no airport under me. The cyuna is a ok engine > > > when it is running. but how did it ever get its nick name killer cyuna > > > Put a 084 on that ultrastar and you will have a very good plane > > > > > > Randy in NC No longer flying the soobydoo Sold it and I > > miss > > > it > > > > > > > > > -- Original Message ----- > > > From: "ronnie wehba" <rwehba(at)wtxs.net> > > > To: > > > Subject: Kolb-List: X-country > > > > > > > > > > > > > > Thinking about a 240 mile round trip to a fly-in on sept 12 in my > cayuna > > > 430 ultrastar, 6 gal gas,several stops!, have been 10-12 miles away from > > > airport so far, have noticed on landing it does not seem to want to rev > > back > > > up very easy??. if I do a go around. my other plane is a minimax with a > > ao84 > > > engine 4cyl-4-stroke,,guess I am just having a rough time getting used > to > > a > > > 2-stroke! any suggestions or comments welcome,ron in still hot west > Texas. > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: X-country
Date: Jul 25, 2003
I just saw this while browsing ebay. Sorry to say, it tore the hell out of that ultrastar. Shame. -----Original Message----- From: ronnie wehba [mailto:rwehba(at)wtxs.net] Subject: Re: Kolb-List: X-country have you seen it lately, he propped it at half throttle and the rest is as we shall history,he was not in it, no one was hurt cept the kolb and a building ouch!! Item #2424778978 ebay number have a look ----- Original Message ----- From: "Mid-State Sandblasting" <plane(at)rtmc.net> Subject: Re: Kolb-List: X-country > > Hi Ronnie > I mine ended up in tenn. The guy that bought it was very happy with it > He only flew 150s before he bought it. he had no trouble switching to > ultralights. > Randy > ----- Original Message ----- > From: "ronnie wehba" <rwehba(at)wtxs.net> > To: > Subject: Re: Kolb-List: X-country > > > > > > thanks randy, if i keep it ,it will have a 84 where did yours go? > > ----- Original Message ----- > > From: "Mid-State Sandblasting" <plane(at)rtmc.net> > > To: > > Subject: Re: Kolb-List: X-country > > > > > > > > > > > You would do better flying your mini max to the flying as the cyuna will > > not > > > warn you when it is ready to burn a piston. how do I know this? From > > > coming out of the sky with no airport under me. The cyuna is a ok engine > > > when it is running. but how did it ever get its nick name killer cyuna > > > Put a 084 on that ultrastar and you will have a very good plane > > > > > > Randy in NC No longer flying the soobydoo Sold it and I > > miss > > > it > > > > > > > > > -- Original Message ----- > > > From: "ronnie wehba" <rwehba(at)wtxs.net> > > > To: > > > Subject: Kolb-List: X-country > > > > > > > > > > > > > > Thinking about a 240 mile round trip to a fly-in on sept 12 in my > cayuna > > > 430 ultrastar, 6 gal gas,several stops!, have been 10-12 miles away from > > > airport so far, have noticed on landing it does not seem to want to rev > > back > > > up very easy??. if I do a go around. my other plane is a minimax with a > > ao84 > > > engine 4cyl-4-stroke,,guess I am just having a rough time getting used > to > > a > > > 2-stroke! any suggestions or comments welcome,ron in still hot west > Texas. > > > > > > > > > > > > > > > > > > > > This e-mail is intended for the use of the addressee(s) only and may contain privileged, confidential, or proprietary information that is exempt from disclosure under law. If you have received this message in error, please inform us promptly by reply e-mail, then delete the e-mail and destroy any printed copy. Thank you. ============================================================================== ________________________________________________________________________________
Date: Jul 25, 2003
If you put it on the bottom of the right aileron and bend it down, it will push the aileron up, which will push the right wing down, opposite to what you want. Put it on the bottom of the left aileron and bend it down and see what happens. Richard Pike MKIII N420P (420ldPoops) > >When my friend, Chuck lets his stick go, his FS II banks pretty hard to the >right. Even starting level with full left rudder she still banks to the >right. > After careful inspection, we can't see any reason for this. > >I believe the fix is to put a trim tab on the ailerons, but where? Should it >be mounted on the bottom of the right aileron & bent down? > >Shack >FS II >SC > > ________________________________________________________________________________
Date: Jul 25, 2003
just glad no-one was hurt ----- Original Message ----- From: "Rayfield, Bill" <brayfield(at)kcc.com> Subject: RE: Kolb-List: X-country > > I just saw this while browsing ebay. Sorry to say, it tore the hell out of > that ultrastar. > Shame. > > -----Original Message----- > From: ronnie wehba [mailto:rwehba(at)wtxs.net] > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: X-country > > > have you seen it lately, he propped it at half throttle and the rest is as > we shall history,he was not in it, no one was hurt cept the kolb and a > building ouch!! Item #2424778978 ebay number have a look > ----- Original Message ----- > From: "Mid-State Sandblasting" <plane(at)rtmc.net> > To: > Subject: Re: Kolb-List: X-country > > > > > > Hi Ronnie > > I mine ended up in tenn. The guy that bought it was very happy with it > > He only flew 150s before he bought it. he had no trouble switching to > > ultralights. > > Randy > > ----- Original Message ----- > > From: "ronnie wehba" <rwehba(at)wtxs.net> > > To: > > Subject: Re: Kolb-List: X-country > > > > > > > > > > thanks randy, if i keep it ,it will have a 84 where did yours go? > > > ----- Original Message ----- > > > From: "Mid-State Sandblasting" <plane(at)rtmc.net> > > > To: > > > Subject: Re: Kolb-List: X-country > > > > > > > > > > > > > > > > You would do better flying your mini max to the flying as the cyuna > will > > > not > > > > warn you when it is ready to burn a piston. how do I know this? > From > > > > coming out of the sky with no airport under me. The cyuna is a ok > engine > > > > when it is running. but how did it ever get its nick name killer > cyuna > > > > Put a 084 on that ultrastar and you will have a very good plane > > > > > > > > Randy in NC No longer flying the soobydoo Sold it and I > > > miss > > > > it > > > > > > > > > > > > -- Original Message ----- > > > > From: "ronnie wehba" <rwehba(at)wtxs.net> > > > > To: > > > > Subject: Kolb-List: X-country > > > > > > > > > > > > > > > > > > Thinking about a 240 mile round trip to a fly-in on sept 12 in my > > cayuna > > > > 430 ultrastar, 6 gal gas,several stops!, have been 10-12 miles away > from > > > > airport so far, have noticed on landing it does not seem to want to > rev > > > back > > > > up very easy??. if I do a go around. my other plane is a minimax with > a > > > ao84 > > > > engine 4cyl-4-stroke,,guess I am just having a rough time getting used > > to > > > a > > > > 2-stroke! any suggestions or comments welcome,ron in still hot west > > Texas. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > This e-mail is intended for the use of the addressee(s) only and may contain > privileged, confidential, or proprietary information that is exempt from > disclosure under law. If you have received this message in error, please > inform us promptly by reply e-mail, then delete the e-mail and destroy any > printed copy. Thank you. > ============================================================================ == > > ________________________________________________________________________________
Date: Jul 25, 2003
Subject: House Paint
A couple of years or more ago there was and article in I believe Kit Plane about a builder who painted his Challenger with house paint in military Navy colors Yellow, blue, red and white striped tail. He applied with foam rollers and foam brushes. I remember him saying he always got comments on his great paint job. After a few years he said it still looked good and was easy to repair. Does anyone remember this article and what month was it in if possible??? ________________________________________________________________________________
Date: Jul 25, 2003
Subject: Re: House Paint
Wayne, I painted my Firestar with rolled and brushed on polytone. It turned out great and if I have to repair it, no need to haul out a spray gun. I had to roll some trim on a few weeks ago when I repaired a patch on the wing. If polytone is rolled or brushed on, it retains a glossy look unlike a sprayed job. I have a friend who used latex exterior house point on his and it still looks great after many years. Ralph Burlingame Original Firestar, 16 years flying it --- "Wayne F.Wilson" wrote: A couple of years or more ago there was and article in I believe Kit Plane about a builder who painted his Challenger with house paint in military Navy colors Yellow, blue, red and white striped tail. He applied with foam rollers and foam brushes. I remember him saying he always got comments on his great paint job. After a few years he said it still looked good and was easy to repair. Does anyone remember this article and what month was it in if possible??? The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Jul 25, 2003
Subject: Kolb FS gap seals....
Used to belong to this list a few years back but thought I'd post something that may be of use safety wise. A bit of history first..... From the FAA accident site... On August 21, 1999, about 1940 Eastern Daylight Time, a homebuilt Kolb Mark III, N6268A, was substantially damaged after impacting terrain near Scott, Ohio. The certificated private pilot and passenger were fatally injured. Visual meteorological conditions prevailed and no flight plan was filed for the local flight conducted under 14 CFR Part 91. According to witnesses, the pilot had departed from an airstrip located on his property, heading in a southerly direction. The airplane climbed to about 200 feet above the ground, then leveled off. About 3 minutes later, the engine noise began to decrease, "like he was throttling back." The airplane began a left turn, and disappeared from view. The witness then heard the sound of "plastic tearing, and breaking of corn stalks." A second witness, who noticed the airplane after it passed overhead, stated that the airplane made a "weird sound" and descended nose first toward the ground. A resident, located about 1/2 mile southwest of the wreckage, found a part of the airplane in a bean field, and turned it over to the local authorities. A Federal Aviation Administration Inspector later identified the part as a gap seal. The gap seal was an airfoil shaped piece of plexi-glass, used to fill the gap left in- between the wings when they are assembled. The wreckage was retained for further examination. Why post this? This afternoon while chasing some thermals I heard a high pitched whine on takeoff and throughout the climbout. Sounded like the fan belt of the Hirth may have been slipping (a flat/poly belt) but temps were all nominal. Caught some lift to about 1500 and happened to look up at the gap seal and it had started to move forward by about 6 inches...and still going. There probably was no way for it to depart the airframe unless the screws attaching the base section and the top section let loose/ripped out or aerodynamic forces ripped it off...not a pleasant thought and entirely possible. The old Kolb plans called for adhesive backed velcro to hold the Lexan to the wing root fabric surfaces and it worked for about 5 years, even in Oklahoma heat...until today. I've flown without the gap seal before but this was entirely different. Airspeed dropped dramatically and had to point the nose way down to keep at 40mph. Trying to hold the seal back against the wing with left hand, stick and throttle with right hand is no fun. Got down safely but again...it was not fun. The whine sound? That was the rear of the gap seal having risen up to partially obscure airflow into the fan thus the odd whine. I'm rethinking the seal attach and will go completely mechanical. Adhesive velcro sucks, anyway. I would seriously caution anyone that Lexan gap seal held in place with velcro is a BAD idea for the long term. Got away with it for awhile....... Cheers, Jim Baker Elmore City, Oklahoma J.Baker ________________________________________________________________________________
Date: Jul 26, 2003
Tim and group, I don't understand this. It appears to be the opposite of what I have found to be true on my Firestar II and previously on my original Firestar. My experience has been that trim tabs on ailerons do control roll, with hands off, and adjusting the aileron pushrods just moved the stick. John Jung Does it do this under power or at idle??? P factor causing this???? I ask because all a trim tab on the aileron will do is move the stick. If you lower one aileron with a trim tab, you raise the other and they equal out, only moving the stick. A trim tab will just balance each aileron out. A aileron trim tab does not work like a rudder or elevator trim tab. Really the only way this could work is to move one up or down by the pushrod, changing the rigging, but then you mess with the design, affect cruise, pitch etc. <-- ________________________________________________________________________________
Date: Jul 26, 2003
From: "johnjung(at)compusenior.com" <johnjung(at)compusenior.com>
Subject: Re: Firefly Question
Ed and Group, I flew a Quicksilver MX and Sprint before my Firestars. I also got about 30 hours in a Cessna 150, working toward my private pilot, before buying my firest Firestar. My opinion is that the 150 along with the fairly extensive dual trainning was better preparation for the Firestar than the Quicksilvers. I liked the Quicksilvers, but I thought that they really allowed sloppy flying. John Jung ________________________________________________________________________________
Date: Jul 26, 2003
Hi Gang, Tim's answer to this confused me also. My FS II had a roll left tendency that I corrected with a trim tab bent down on the right aileron. This trim tab bent down causes the air pressure against it to push the right aileron up. Since the right aileron is connected to the left aileron via the control linkage it also forces the left aileron down. This counteracts the roll left Adjusting the pushrods has been discussed before and will only change the position of the stick. If you start off with a plane that rolls left and adjust the pushrods to correct this then fly the plane it is still going to roll left the same amount but your stick will be to the right or left of where it was depending on the adjustment made. All this should be in the archives. Take Care, John Cooley Subject: Kolb-List: Re: Firestar II banks to the right Tim and group, I don't understand this. It appears to be the opposite of what I have found to be true on my Firestar II and previously on my original Firestar. My experience has been that trim tabs on ailerons do control roll, with hands off, and adjusting the aileron pushrods just moved the stick. John Jung Does it do this under power or at idle??? P factor causing this???? I ask because all a trim tab on the aileron will do is move the stick. If you lower one aileron with a trim tab, you raise the other and they equal out, only moving the stick. A trim tab will just balance each aileron out. A aileron trim tab does not work like a rudder or elevator trim tab. Really the only way this could work is to move one up or down by the pushrod, changing the rigging, but then you mess with the design, affect cruise, pitch etc. <-- . ________________________________________________________________________________
Date: Jul 26, 2003
Subject: Re: Kolb FS gap seals....
Jim/gang, I use a velcro gap seal on my Firestar and it has been perfect for 4 years. Mine has a mini bungee cord attached to a couple of eyebolts in the rear part so if the velcro ever decided to detach, it would hold it. That bungee also acts as vibration dampener so the gap seal doesn't move up and down. The velcro strips have to be replaced when the adhesive comes loose, but the bungee holds it. The front part is held in place well enough that I cannot see it ever coming off. It's a terrible shame the pilot of that Mark III somehow declared an emergency when in reality he may not have been in danger with the sound of the gap seal flapping. That time I hit a bird, I did not know that I had hit anything. All I knew was the plane was vibrating more than usual and I had to hold right rudder to keep it flying straight. I had lots of places to land under me, but I chose to fly 38 miles home. I could see the underside of the wings were fine and I could turn around and see the tail was intact, and the problem wasn't getting any worse. So I made it home and found the fabric caved in on the last rib, top left wing. The bird had made a glancing blow to the wing in a fast climbing left turn. Ralph Burlingame Original Firestar, 16 years flying it writes: > I'm rethinking the seal attach and will go completely mechanical. > Adhesive velcro sucks, anyway. I would seriously caution anyone > that Lexan gap seal held in place with velcro is a BAD idea for the > > long term. Got away with it for awhile....... > > > Cheers, > Jim Baker > Elmore City, Oklahoma > > J.Baker The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Jul 26, 2003
Ed, I think your referring to a post I made to George. The thing I noticed is people new to Kolbs have a tendency to slow them down to much on the final landing phase on there first few flights. Not sure if its the high incidence of the wing that visually throws them off or that the plane its self slowing rapidly once the nose is raised into a landing attitude but it seems to catch a number of new owner/pilots. When flying a strange airplane for the first few times you should never get it to slow, always come in a little hot under slight power and fly it to the ground, once you make contact, back on the power. You don't try to land a strange plane at full stall on the very first landing. We had a FireStar here on our field that three different people pranged the gear on there first flights. One was the initial test pilot an experienced Kit Fox pilot, second was the owner/student who attempted to do crow hops as taught by his instructor in a different type airplane, last was the owners UL instructor himself. I had warned both the test pilot and the owner/student not to get it to slow on landing the first few flights until they were more comfortable with the airplane. Yep, all three pranged the gear. One thing about the Kolbs, their easy to fix. There's some thing about the Kolb's (FireFly & FireStars) that surface during the final landing phase which seems to catch people asleep at the controls on their first few flights. I contribute it to allowing their speed to get to slow on the final phase of the approach to touch down. As they begin the round out, often high, they find the speed decaying quite rapidly and they can not over come their rate of decent even by adding power resulting in a harder than desired landing. (When behind the power curve, you smack the runway just about the time the Rotax spools up and find yourself sitting there taking inventory) For the first few flights come in carrying a little power while feeling for the runway, at the moment of contact come back on the power. Once you get a few landings you will adapt to the planes characteristics and likely will not have any problems after that. By the way, after the owners instructor bent the gear, the student followed the my advise, same as I gave George regarding the taxing, not to crow hop, and carrying a little power to touch down until he got comfortable with the plane, he hasn't had any problems since. The Kolbs are excellent flyers, their nothing wrong with them but don't get to slow on initial first few flights. Once you start rounding out they slow down. By carrying a little power, it buys you time to think and make a gentle landing. After you get a few landings under your belt, you know how the plane reacts and can anticipate things and back off the need to carry power. After shooting two sets of 10 landing each about hour a part, I could spot land the FireFly. It's a good flyer. jerb > > Gang, > > Anyone have much experience flying a Quicksilver , and then transition > to a >firefly or firestar? Just wondering how much difference there is between >them. I have over 100 hours in a Wizard J-3( Very similar to the Quicksilver). > > I understand the concept of lots of drag & the slow down fast concept > that >is inherent in most all ultralights. The wizard I had , mainly just mushed, >And you would feel a slight buffeting first then it would drop the nose a >little and resume flying again . Ive heard some on this list say that >the Kolbs >gave no warning at all before a stall. To me that is not a good thing. > > Ed (in Houston) > > ________________________________________________________________________________
Date: Jul 26, 2003
In a message dated 7/26/03 7:49:58 AM Eastern Daylight Time, johnjung(at)compusenior.com writes: > Tim and group, > > I don't understand this. It appears to be the opposite of what I have > found to be true on my Firestar II and previously on my original > Firestar. My experience has been that trim tabs on ailerons do control > roll, with hands off, and adjusting the aileron pushrods just moved the > stick. > > John Jung > > > Does it do this under power or at idle??? P factor causing this???? I > ask because all a trim tab on the aileron will do is move the stick. If > you lower one aileron with a trim tab, you raise the other and they > equal out, only moving the stick. A trim tab will just balance each > aileron out. A aileron trim tab does not work like a rudder or elevator > trim tab. Really the only way this could work is to move one up or down > by the pushrod, changing the rigging, but then you mess with the design, > affect cruise, pitch etc. <-- > > > After careful consideration, I followed brother Pike's advice & put the trim tab bent down on the left aileron to counteract the right roll. The tab was about 2" X 7", mounted under the aileron & bent down about 30 degrees. That was too much, as we now had a left roll; I knew then we were home free!. Took about half the bend out & she flies hands-off. Shack FS II SC ________________________________________________________________________________
Date: Jul 26, 2003
In a message dated 7/26/03 9:32:07 PM Eastern Daylight Time, Timandjan(at)aol.com writes: > If you add a trim tab on one aileron, one aileron only, it will move the > opposite one in the other direction the same amount, and at the same time > moving > your stick. Stand by one Aileron, move it up or down, watch the other, it > will > move the same in the opposite direction, you moving it is the same as moving > > it in flight with a trim tab. Now imaging flying, as they are both attached > and > move the same in opposite directions, they will balance out in flight, but > the stick will be off center. The only way to change the rigging is to > lengthen one o the other with the pushrod. But here, you affect the rigging. > I know > it's hard to understand, but I had a friend explain it to me and show me on > his > plane. > > Tim, I think you have it backwards- just changing an aileron pushrod length will not correct a roll situation; it will only change the stick position. However, adding a trim tab to the bottom of an aileron will indeed cause that aileron to reflex up & therefore the other one down. Sure, when this happens, the stick position will change a little, but the plane will also roll in the direction the ailerons are telling it to. I know it works because I just did it. Shack FS II SC ________________________________________________________________________________
Date: Jul 27, 2003
In a message dated 7/26/03 2:39:08 PM Central Standard Time, ulflyer(at)verizon.net writes: << The Kolbs are excellent flyers, their nothing wrong with them but don't get to slow on initial first few flights. Once you start rounding out they slow down. By carrying a little power, it buys you time to think and make a gentle landing. After you get a few landings under your belt, you know how the plane reacts and can anticipate things and back off the need to carry power. After shooting two sets of 10 landing each about hour a part, I could spot land the FireFly. It's a good flyer. jerb >> Jerb, Do you think the pranging problem is aggrivated by the tendancy of general aviation pilots being used to flaring at a distance above the runway and not being aware of how quick the airspeed falls of due to the greater drag in a kolb? Ed (In Houston) ________________________________________________________________________________
Date: Jul 27, 2003
Subject: how to land without bending anything
> Do you think the pranging problem is aggrivated by the tendancy > of general aviation pilots being used to flaring at a distance above > the runway and not being aware of how quick the airspeed falls of due to the > greater drag in a kolb? > > Ed (In Houston) Ed in Houston, Yes, this is a major part of the problem. All ultralights have more drag and less weight than GA aircraft, so pilots have that tendency to pull back on the stick at 10' before trouchdown. I always tell guys to use no more than 1" of flare on the stick. Once the Firestar gets into ground effect, it changes angle of attack and actually flares itself without ANY stick input. An easy way to land a Firestar would be to remember the '40 rule'. Come in at 40mph, 4000rpm, and do nothing to the stick. Keep the power on until it's rolling on the ground. It will land itself without pranging the gear. It may bounce a little but what the heck. This will work in calm conditions only. Once you become skilled, practice greasing it in with a little flare at the right moment. Flare too early, prang the the gear. Flare to late, it will balloon and could get dangerous as airspeed is dropping off. Timing and the amount of flare is everything. No flare is better than flaring at the wrong moment. Ralph Burlingame Original Firestar 16 years flying it The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Jul 27, 2003
Subject: [ Roger Hankins ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Roger Hankins Subject: Kolbs over Crater Lake
http://www.matronics.com/photoshare/RPHanks@aol.com.07.27.03/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jul 27, 2003
Subject: [ Bob Bean ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Bob Bean Subject: MkIII hitch http://www.matronics.com/photoshare/slyck@frontiernet.net.07.27.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jul 27, 2003
Subject: Re: [ Roger Hankins ] : New Email List Photo Share Available!
I have a Kolb MK lll that I am thinking of selling and was wondering what the Kolb-list has to say about it. What is the best way to go about it and what kind of price Might one expect to get? Any thoughts on this would be most appreciated Thanks Bill ________________________________________________________________________________
Date: Jul 27, 2003
No, I don't contribute it to GA pilots. I and the Kit Fox pilot came from GA, the other two, one of which was a UL instructor had similar experiences. You making more of this than it really is. There are some planes you can get sloppy and slide by. This may be the reason the instructor had the problem as he trains in a Quicksilver or something like it and was trying to fly it the same way. If you go about it in the way I explained it, you should not have any problems. The GA pilot and the student afterwards approached it the way I suggested and haven't had any problems since. If you look through the archives there is a history of new Kolb pilots pranging the gear. While I can't fully describe what it is that is different with Kolbs but they land little different. It seems the big problem is allowing speed to bleed off quickly as you start rounding out. In most cases the major damage is to their pride and maybe a gear leg or two. Unless pranged really bad, quite often the legs can be straightened and reused. There not a high cost part to replace. Ed, you'll do just find. When you get near that day review what I suggested in the prior messages and follow it. It takes you from standing still to slow taxi on to fast taxing to running with the tail up. Review it and pay special attention to the part about coming back on the power once it rolling other wise you will fly! And always, if your going to do any taxiing whether you plan to fly or not, have the seat belt fastened and adequate fuel on board just in case if should come off the ground. If it should come off don't panic, and plop it back down. I've seen to many plane busted that way. Just fly the airplane. Note your temps, if everything is green fly around the pattern a couple times this will give you time to settle down and catch up with the plane. Come on around making a longer approach to give time to line up with little power on. Remember the flaps, two notches is all you should need until you get more time in the airplane. Just ease it down and that's all that's all theres to it. jerb > >In a message dated 7/26/03 2:39:08 PM Central Standard Time, >ulflyer(at)verizon.net writes: > ><< The Kolbs are excellent flyers, their nothing wrong with them but don't >get > to slow on initial first few flights. Once you start rounding out they > slow down. By carrying a little power, it buys you time to think and make > a gentle landing. After you get a few landings under your belt, you know > how the plane reacts and can anticipate things and back off the need to > carry power. After shooting two sets of 10 landing each about hour a part, > I could spot land the FireFly. It's a good flyer. > jerb > >> > > Jerb, > > Do you think the pranging problem is aggrivated by the tendancy of >general aviation pilots being used to flaring at a distance above the >runway and >not being aware of how quick the airspeed falls of due to the greater >drag in a >kolb? > > Ed (In Houston) > > ________________________________________________________________________________
Date: Jul 27, 2003
lets see what it looks like! ----- Original Message ----- From: <DC8man2(at)aol.com> Subject: Re: Kolb-List: [ Roger Hankins ] : New Email List Photo Share Available! > > I have a Kolb MK lll that I am thinking of selling and was wondering what the > Kolb-list has to say about it. What is the best way to go about it and what > kind of price Might one expect to get? > Any thoughts on this would be most appreciated > Thanks > Bill > > ________________________________________________________________________________
Date: Jul 27, 2003
Subject: Re: how to land without bending anything
Ralph, & All I know you have far more experience flying Kolbs than I ever will but a FireFly will not flare itself in ground effect and may be misleading advise to inexperienced pilots. You have to fly it thru the landing. Carrying a little power until just before touch down in the beginning is better until they get some landings under their belt. Myself I believe the FireFly is a little more twitchy than the FireSter due to its lighter weight and the shorter wing span quits flying sooner. jerb > > > > Do you think the pranging problem is aggrivated by the tendancy > > of general aviation pilots being used to flaring at a distance above > > the runway and not being aware of how quick the airspeed falls of due >to the > > greater drag in a kolb? > > > > Ed (In Houston) > >Ed in Houston, > >Yes, this is a major part of the problem. All ultralights have more drag >and less weight than GA aircraft, so pilots have that tendency to pull >back on the stick at 10' before trouchdown. I always tell guys to use no >more than 1" of flare on the stick. Once the Firestar gets into ground >effect, it changes angle of attack and actually flares itself without ANY >stick input. > >An easy way to land a Firestar would be to remember the '40 rule'. Come >in at 40mph, 4000rpm, and do nothing to the stick. Keep the power on >until it's rolling on the ground. It will land itself without pranging >the gear. It may bounce a little but what the heck. > >This will work in calm conditions only. Once you become skilled, practice >greasing it in with a little flare at the right moment. Flare too early, >prang the the gear. Flare to late, it will balloon and could get >dangerous as airspeed is dropping off. > >Timing and the amount of flare is everything. No flare is better than >flaring at the wrong moment. > >Ralph Burlingame >Original Firestar 16 years flying it > >The best thing to hit the internet in years - Juno SpeedBand! >Surf the web up to FIVE TIMES FASTER! > > ________________________________________________________________________________
Date: Jul 27, 2003
[Unable to display image] ________________________________________________________________________________
Subject: Question on cuyuna
Date: Jul 27, 2003
have a cuyuna II-02 on my US, where on long final lower rpm's I tried to go around,did not need to just was going to ,, the engine bogged down upon advancing the throttle, did this a couple times real slow and it caught. my other toy is a minimax with a A0-84 4-stroke 4-cyl. don't have any problems with it. Ideas, what is this 2-stroke illiterate doing wrong? ________________________________________________________________________________
Date: Jul 27, 2003
Subject: Re: Question on cuyuna
It is probably either a bit too lean or a bit too rich at idle, I would guess a bit too lean, as that tends to inhibit throttle response when you advance the throttle. Did you try adding power a bit more slowly to give it time to spool up? Sometimes that will work if the mixture is off. If you can richen or lean the idle mixture screw a bit you might try playing with it and see what it does. My guess is it is lean. Also, when you are coming down final and the engine is at idle, but you are gliding, the engine is turning slightly faster than it would be if you were sitting still, that will lean things out a little bit and cause it to hesitate when you add power because you have filled the crankcase with a lean mixture and as soon as you open the throttle everything is lean for a moment until the carb overcomes what is in the crankcase and returns it to proper mixture. But if the carb is a hair lean also, then it all becomes more iffy. Richard Pike MKIII N420P (420ldPoops) > >have a cuyuna II-02 on my US, where on long final lower rpm's I tried to >go around,did not need to just was going to ,, the engine bogged down upon >advancing the throttle, did this a couple times real slow and it caught. >my other toy is a minimax with a A0-84 4-stroke 4-cyl. don't have any >problems with it. Ideas, what is this 2-stroke illiterate doing wrong? > > ________________________________________________________________________________
Date: Jul 27, 2003
thanks that gives me a point to start at, always have to add very slow, temps are A-OK, rpm is good, I'll richen it a small bit and try that.screw in or out , 2-strokes ain''t my thing,and no-one around here knows--------! ----- Original Message ----- From: "Richard Pike" <rwpike(at)charter.net> Subject: Re: Kolb-List: Question on cuyuna > > It is probably either a bit too lean or a bit too rich at idle, I would > guess a bit too lean, as that tends to inhibit throttle response when you > advance the throttle. > Did you try adding power a bit more slowly to give it time to spool up? > Sometimes that will work if the mixture is off. If you can richen or lean > the idle mixture screw a bit you might try playing with it and see what it > does. My guess is it is lean. > > Also, when you are coming down final and the engine is at idle, but you are > gliding, the engine is turning slightly faster than it would be if you were > sitting still, that will lean things out a little bit and cause it to > hesitate when you add power because you have filled the crankcase with a > lean mixture and as soon as you open the throttle everything is lean for a > moment until the carb overcomes what is in the crankcase and returns it to > proper mixture. But if the carb is a hair lean also, then it all becomes > more iffy. > > Richard Pike > MKIII N420P (420ldPoops) > > > > > > >have a cuyuna II-02 on my US, where on long final lower rpm's I tried to > >go around,did not need to just was going to ,, the engine bogged down upon > >advancing the throttle, did this a couple times real slow and it caught. > >my other toy is a minimax with a A0-84 4-stroke 4-cyl. don't have any > >problems with it. Ideas, what is this 2-stroke illiterate doing wrong? > > > > > > ________________________________________________________________________________
Date: Jul 27, 2003
OH!!, one more thing I always carry some power on decent,,done learned that. ----- Original Message ----- From: "Richard Pike" <rwpike(at)charter.net> Subject: Re: Kolb-List: Question on cuyuna > > It is probably either a bit too lean or a bit too rich at idle, I would > guess a bit too lean, as that tends to inhibit throttle response when you > advance the throttle. > Did you try adding power a bit more slowly to give it time to spool up? > Sometimes that will work if the mixture is off. If you can richen or lean > the idle mixture screw a bit you might try playing with it and see what it > does. My guess is it is lean. > > Also, when you are coming down final and the engine is at idle, but you are > gliding, the engine is turning slightly faster than it would be if you were > sitting still, that will lean things out a little bit and cause it to > hesitate when you add power because you have filled the crankcase with a > lean mixture and as soon as you open the throttle everything is lean for a > moment until the carb overcomes what is in the crankcase and returns it to > proper mixture. But if the carb is a hair lean also, then it all becomes > more iffy. > > Richard Pike > MKIII N420P (420ldPoops) > > > > > > >have a cuyuna II-02 on my US, where on long final lower rpm's I tried to > >go around,did not need to just was going to ,, the engine bogged down upon > >advancing the throttle, did this a couple times real slow and it caught. > >my other toy is a minimax with a A0-84 4-stroke 4-cyl. don't have any > >problems with it. Ideas, what is this 2-stroke illiterate doing wrong? > > > > > > ________________________________________________________________________________
Date: Jul 27, 2003
Hi Shack and Kolb drivers After I bought my second hand Fire Star II, I also noticed it banked to the right. On close inspection I was surprised to find the left aileron was full of rain water, with a hot small nail, I burnt a couple of weep holes underneath the back of the aileron and the problem went away. Bill Vincent FireStar II Quinnesec, Upper Peninsula of Michigan HShack(at)aol.com wrote: > > When my friend, Chuck lets his stick go, his FS II banks pretty hard to the > right. Even starting level with full left rudder she still banks to the right. > After careful inspection, we can't see any reason for this. > > I believe the fix is to put a trim tab on the ailerons, but where? Should it > be mounted on the bottom of the right aileron & bent down? > > Shack > FS II > SC > ________________________________________________________________________________
From: "Beauford Tuton" <beauford(at)tampabay.rr.com>
Date: Jul 27, 2003
Kolbers and Kolbettes: Have been following the gap seal thread with interest... The velcro attached rip-stop nylon rag which came with the FireFly kit masquerading as a gap seal lasted about 60 hours before abruptly shredding in the breeze one day, and distributing untold quantities of exceedingly fine nylon fuzz in just about every nook and cranny of the Fly, the Rotax, and various folds and crevices of 'ol Beaufords anatomy which I am far too modest and discreet to discuss in this forum... Suffice it to say that a good nose-blowing did NOT solve the nylon personal hygiene problem.... the fuzz even worked into the fuel system... about the only good thing I can say is that the prop got a good polishing out of the event... Anyway, fer whatever it is worth, I humbly submit to y'all fer consideration the notion that any inanimate part which, if'n it departs the airplane, is capable of causing death, disfigurement or major property damage, sure ought to be attached to a flying machine with something other than just VELCRO, fer pete's sake... After my disgusting nylon episode, ended up building a new gap seal out of .025 aluminum... went ahead and put one inch industrial velcro all the way along the outboard edges, but also rivited on four aluminum brackets... one to each of the four corners of the TRAILING edges of the seal ... I hook two criss-crossed H.D. bungee cords back back around the main spar attach structure to hold it in place with the four trailing edge brackets...it really screws the thing down, yet is pretty easy to work with each time I unfold the airplane to fly it... so far, so good... and it is light, cheap and looks OK... almost like a real airplane part.... (after painting to match the leading edge trim)... Worth what you paid fer it... good luck... (never turn yer back on velcro...) Beauford, The Aluminum Butcher of Brandon, FL FF #076 ----- Original Message ----- From: "Jim Ballenger" <ulpilot(at)cavtel.net> Subject: Re: Kolb-List: Kolb FS gap seals.... > > Jim > I use ty wraps, one on each side of the wing gap seal to hold mine on. I > Jim Ballenger > > To: > Subject: Kolb-List: Kolb FS gap seals.... > > > > > > > From the FAA accident site... > > > > On August 21, 1999, about 1940 Eastern Daylight Time, a > > homebuilt Kolb Mark III, N6268A, was substantially damaged after > > > > > > ________________________________________________________________________________
Date: Jul 27, 2003
In a message dated 7/27/03 7:39:17 PM Eastern Daylight Time, emailbill(at)chartermi.net writes: > Hi Shack and Kolb drivers > > After I bought my second hand Fire Star II, I also noticed it banked to the > right. > > On close inspection I was surprised to find the left aileron was full of > rain > water, with a hot small nail, I burnt a couple of weep holes underneath the > back of > the aileron and the problem went away. > > That's the first thing we checked. Thanks. Shack FS II SC ________________________________________________________________________________
Date: Jul 27, 2003
Subject: Re: 87 Octane No Lead & 100 LL
Not much cyl hd temp difference but exhaust gas temps rose 60 degrees on 87 ________________________________________________________________________________
Date: Jul 27, 2003
Subject: Re: how to land a FireFly without bending anything
> Do you think the pranging problem is aggrivated by the tendancy > of general aviation pilots being used to flaring at a distance above > the runway and not being aware of how quick the airspeed falls of due to the > greater drag in a kolb? > > Ed (In Houston) Ed, Some of the problem may be due to inexperience in flying very light low inertia aircraft. But I believe most of the problem has to do with, as jerb states, not keeping enough speed on final approach and while flairing. After about 350 landings, I never make an approach at less than 55 mph. After the field is made the throttle is closed and the nose pushed down to keep the airspeed at 55+ mph. The reason for this is to make a high energy fast approach so that the FireFly is very responsive to the controls. When one flairs the FireFly at this speed you have about three seconds to get it on down and plant the tail wheel. Keep holding it off and it will settle in very nicely. The main gear will touch at about 25 - 27 mph. This makes for a low energy landing and the potential for bending the main gear is greatly reduced. I have tried the little throttle and touch the main gear first many times. It works best on grass. I have a difficult time with it on hard surfaces were I bounce time and time again. The problem with the main gear first and at higher a speed is that on rough fields the gear is going to take more punishment as the landing roll will be increased. If you drop the tail wheel on first and let the mains settle in, the forward speed, roll out and punishment are minimized. Also, this method is helpful in coping with tall grass and/or water in grass that would case the FireFly to nose over during a wheel landing. You may want to check out: http://www.thirdshift.com/jack/firefly/howtofly.html It explains how I fly my FireFly. One side note: the FireFly has vortex generators and nine inch chord ailerons, so it will fly a little slower and is easier to control roll than most FireFlys. Also, I am using the four inch plastic wheels. This page does not address flaperon usage, but anyone who is new to a FireFly should not be using them, and I have not found any need for them. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
From: "Christopher J Armstrong" <tophera(at)centurytel.net>
Date: Jul 27, 2003
If you add a trim tab on one aileron, one aileron only, it will move the opposite one in the other direction the same amount, and at the same time moving your stick. Stand by one Aileron, move it up or down, watch the other, it will move the same in the opposite direction, you moving it is the same as moving it in flight with a trim tab. Now imaging flying, as they are both attached and move the same in opposite directions, they will balance out in flight, but the stick will be off center. The only way to change the rigging is to lengthen one o the other with the pushrod. But here, you affect the rigging. I know it's hard to understand, but I had a friend explain it to me and show me on his plane. if I can help, give me a call. Tim, If you want to roll the plane you push on the stick and move the ailerons. If you use a trim tab to move the ailerons it changes the roll trim. It is applying a force to the ailerons just exactly like the force that you apply with the stick. Now if you try to change the length of one or both of the aileron push rods it will just move the stick to one side and the ailerons will move both the same direction, causing a pitch trim change but not a roll trim change. I think you have these two things confused. Just to be absolutely clear, aileron trim tabs work just great and are a standard part of probably more then 90% of all aircraft ever built. I think you should pull back your comments in this area, give it some thought and if you still don't get it, go up to your plane and push on an aileron like a trim tab would. Then go push on the stick like you would if you were going to fly and roll, the resulting motion of the ailerons, (and the plane) is indistinguishable. Got it? Topher ________________________________________________________________________________
Date: Jul 27, 2003
Ronnie...remember..on that Mikuni...the screw is an AIR screw...not a fuel screw...and turning it in means less air...RICHER fuel!!! http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098! ________________________________________________________________________________
Date: Jul 28, 2003
thanks don. ----- Original Message ----- From: "Don Gherardini" <donghe@one-eleven.net> Subject: Re: Kolb-List: Question on cuyuna > > Ronnie...remember..on that Mikuni...the screw is an AIR screw...not a fuel > screw...and turning it in means less air...RICHER fuel!!! > > http://www.geocities.com/dagger369th/my_firefly.htm > Don Gherardini- > FireFly 098! > > ________________________________________________________________________________
From: "Bob, Kathleen, & Kory Brocious" <bbrocious(at)hotmail.com>
Subject: Update on "Miss B" Mark III - cracked starter cover
Date: Jul 28, 2003
Folks, While doing my preflight I noticed a very significant crack in an old weld in the aluminum housing that holds the starter gear. I also found a hairline crack on the starter cover plate. I'm checking with the first builder for an explanation of the original weld. When I removed the starter cover plate the piece originally welded fell off in my hand. It appears that the weld had a lot of air in it as there were lots of pock marks that seemed to indicate a poor weld. My plan is to remove the engine and take it to a Rotax Repair Shop a couple hours south in Springfield, Kentucky for thediagnosis and repairs. I think part of the problem was caused by an over tightened starter cover plate. The bad weld didn't help either. This engine was already mated to this frame when I bought it. I've never disconnected an engine and removed it before. I estimate the weight of the engine to be about 105 lbs. Does that sound about right? Any do's or don'ts about disconnecting everything and pulling the engine off? And it was SUCH a pretty day too. Bob N57MB Bob, Kathleen, and Kory Brocious Tenacity Farm Campbellsburg, Kentucky ________________________________________________________________________________
Date: Jul 28, 2003
Subject: Re: Update on "Miss B" Mark III - cracked starter
cover Take the carbs off first, otherwise the temptation to use them to help lift the engine off is overwhelming, and if they pop out, you could drop everything, not to mention messing up the rubber ridge in the carb sockets. Leave the exhaust manifold on, it makes a good handle. Richard Pike MKIII N420P (420ldPoops) > > > >This engine was already mated to this frame when I bought it. I've never >disconnected an engine and removed it before. I estimate the weight of the >engine to be about 105 lbs. Does that sound about right? Any do's or >don'ts about disconnecting everything and pulling the engine off? > > >And it was SUCH a pretty day too. >Bob N57MB >Bob, Kathleen, and Kory Brocious > >Tenacity Farm > >Campbellsburg, Kentucky > > ________________________________________________________________________________
Date: Jul 28, 2003
Subject: Re: Update on "Miss B" Mark III - cracked starter cover
In a message dated 7/28/03 11:22:46 AM Eastern Daylight Time, bbrocious(at)hotmail.com writes: > While doing my preflight I noticed a very significant crack in an old weld > in the aluminum housing that holds the starter gear. I also found a hairline > crack on the starter cover plate. Bob, Is the engine case broken or is it just the starter housing and the cover plate? If it is a mag-end starter on a 582 there are o-rings that are used in the mounting of the starter to the cover. The instructions caution not to mount the starter solid to the cover or it will break. If this is the setup you have and need the documentation for it let me know and I will copy and send it to you. Steven Green N58SG ________________________________________________________________________________
Date: Jul 28, 2003
when I was flying cyunas I always had to goose the throttle and cut back to keep engine from loading up I would do it 3 or 4 times on final Or just cut the throttle back to get a good glide path to the run way. I had a ultrastar and a eagle XL both cyunas would load up on a long final if you just let it idle all the way down to touch down I never could fix it I sold the eagle and put a Subaru on the ultrastar That is the late ultrastar----- Randy P S that engine will get your ultrastar someday, you can count on it Original Message ----- From: "ronnie wehba" <rwehba(at)wtxs.net> Subject: Kolb-List: Question on cuyuna > > have a cuyuna II-02 on my US, where on long final lower rpm's I tried to go around,did not need to just was going to ,, the engine bogged down upon advancing the throttle, did this a couple times real slow and it caught. my other toy is a minimax with a A0-84 4-stroke 4-cyl. don't have any problems with it. Ideas, what is this 2-stroke illiterate doing wrong? > > ________________________________________________________________________________
Date: Jul 28, 2003
no it will not , I am gonna put a ao84 on it. just cause!!! ----- Original Message ----- From: "Mid-State Sandblasting" <plane(at)rtmc.net> Subject: Re: Kolb-List: Question on cuyuna > > when I was flying cyunas I always had to goose the throttle and cut back to > keep engine from loading up I would do it 3 or 4 times on final Or just cut > the throttle back to get a good glide path to the run way. I had a ultrastar > and a eagle XL both cyunas would load up on a long final if you just let it > idle all the way down to touch down I never could fix it I sold the eagle > and put a Subaru on the ultrastar That is the late ultrastar----- > Randy > > P S that engine will get your ultrastar someday, you can count on it > > Original Message ----- > From: "ronnie wehba" <rwehba(at)wtxs.net> > To: > Subject: Kolb-List: Question on cuyuna > > > > > > have a cuyuna II-02 on my US, where on long final lower rpm's I tried to > go around,did not need to just was going to ,, the engine bogged down upon > advancing the throttle, did this a couple times real slow and it caught. my > other toy is a minimax with a A0-84 4-stroke 4-cyl. don't have any problems > with it. Ideas, what is this 2-stroke illiterate doing wrong? > > > > > > ________________________________________________________________________________
Date: Jul 29, 2003
> idle all the way down to touch down I never could fix it I sold the eagle > and put a Subaru on the ultrastar That is the late ultrastar----- > Randy > How has the sooby doo been running. Haven't heard about it in a long time ________________________________________________________________________________
Date: Jul 29, 2003
Your friend explained it wrong. All things being equal the ailerons will find a centered position. This may cause a turn but the ailerons are aerodynamically balanced. If the control tubes are different it will affect the stick position only. Adding a trim tab to an aileron will bring an unbalance into the system which will cause a turn as the ailerons once again try to find an aerodynamic balanced condition. Subject: RE: Kolb-List: Re: Firestar II banks to the right > > If you add a trim tab on one aileron, one aileron only, it will move the > > opposite one in the other direction the same amount, and at the same > time moving > your stick. Stand by one Aileron, move it up or down, watch the other, > it will > move the same in the opposite direction, you moving it is the same as > moving > it in flight with a trim tab. Now imaging flying, as they are both > attached and > move the same in opposite directions, they will balance out in flight, > but > the stick will be off center. The only way to change the rigging is to > > lengthen one o the other with the pushrod. But here, you affect the > rigging. I know > it's hard to understand, but I had a friend explain it to me and show me > on his > plane. > > if I can help, give me a call. > > > Tim, > > If you want to roll the plane you push on the stick and move the > ailerons. If you use a trim tab to move the ailerons it changes the > roll trim. It is applying a force to the ailerons just exactly like the > force that you apply with the stick. > > Now if you try to change the length of one or both of the aileron push > rods it will just move the stick to one side and the ailerons will move > both the same direction, causing a pitch trim change but not a roll trim > change. I think you have these two things confused. > > Just to be absolutely clear, aileron trim tabs work just great and are a > standard part of probably more then 90% of all aircraft ever built. I > think you should pull back your comments in this area, give it some > thought and if you still don't get it, go up to your plane and push on > an aileron like a trim tab would. Then go push on the stick like you > would if you were going to fly and roll, the resulting motion of the > ailerons, (and the plane) is indistinguishable. Got it? > > Topher > > ________________________________________________________________________________
Date: Jul 29, 2003
> While doing my preflight I noticed a very significant crack in an old weld in the aluminum housing that holds the starter gear. I had to reweld the starter housing on my rotax starter also. I figured there was a lot of stress from holding the starter motor out like that. ________________________________________________________________________________
Subject: N616DR
Date: Jan 11, 1980
Del and others, Well I finally caved and gave up on the effort to use 100LL excllusivly in my 690L-70 powered Mk-3. It seemed impossible to read the plugs and the jetting was so off the wall compared to others with the same engine that I figured I had better drain the tanks, put the stock jets back in and start over with pump gas. It really puzzles me as to why my 503 powered Loehle doesn't seem to care weather you feed it 100ll or pump gas, but the 2SI requirs such a drastic tunning change and really does not want to run in hot weather on 100ll. Anyway, it seems like a differant engine with the mogas, I had it up to 5800 rpm last night in level flight and saw 80mph indicated. I could only get 5350 out of it with 100ll and the same prop setting. I still have a lot of tuning to do as it is really rich on the top and the bottom ends. This engine is extreamlly finiky at high temps and humidity, but maybe that will settle down as I get it leaned out. Also saw 900fpm on climbout at around 5450rpm, I can't wait to get her dialed in to see what the climb will be. Today is a honey do day though, Ive got some make up work to do. :-( Denny Rowe ________________________________________________________________________________
Subject: Re: Firestar II banks to the right
Date: Jul 30, 2003
Ours banked to the left. Fix was to put a lexan trim tab on the bottom of the right aileron. So, Chuck's would need the tab on the bottom of the left aileron to raise the aileron a bit and hold the left wing down. > > >When my friend, Chuck lets his stick go, his FS II banks pretty hard to the >right. Even starting level with full left rudder she still banks to the >right. > After careful inspection, we can't see any reason for this. > >I believe the fix is to put a trim tab on the ailerons, but where? Should >it >be mounted on the bottom of the right aileron & bent down? > >Shack >FS II >SC > > ________________________________________________________________________________
Date: Jul 30, 2003
In a message dated 7/30/03 11:11:35 AM Eastern Daylight Time, firestarii(at)hotmail.com writes: > Ours banked to the left. Fix was to put a lexan trim tab on the bottom of > the right aileron. So, Chuck's would need the tab on the bottom of the left > aileron to raise the aileron a bit and hold the left wing down. > > > Oh, yeah. We already did that. Worked real good. Shack FS II SC ________________________________________________________________________________
Date: Jul 30, 2003
Subject: Re: N616DR
sounds good, keep us posted,, i'm really interested in that 690L70 for my twinstar i've noticed that most engines are harder to start on avgas compaired to mogas altho hot start technique is possible to master if you find how it likes to be started,, do not post ________________________________________________________________________________
Subject: gas choices
Date: Jul 30, 2003
Sometimes I feel that if the manufacturer thinks his engine will run best on regular auto gas then perhaps you should use regular auto gas. If it ran best on super or avgas I think that would be their recomendation. It may be hard to believe but sometimes I go with what the manufacturer suggests. ________________________________________________________________________________
Subject: Re: Website
Date: Aug 01, 2003
where did everyone go ? Richard Harris MK3 N912RH > ________________________________________________________________________________
Date: Aug 01, 2003
Subject: Propeller Warning
I have installed some ultra bright red LEDs near the top of the rear fuselage fairing. The whole idea is to try and keep people out of the propeller when the engine is running. Inexpensive and light, and it may keep a kid/adult out of the propeller. It can be seen at: http://www.thirdshift.com/jack/firefly/firefly98.html Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Aug 01, 2003
Subject: UltraStar
Need wings for a ultraStar or plans so I can build some. -- Roger Peterson 206 County Road 375 Sweeny, Texas 77480 Phone:979-647-4946 Cell: 979-487-8356 Fax: 979-647-1158 E-Mail: roger@pmmi-inc.com Bus Home Page: http://pmmi-inc.com Personal Home Page: http://joinme.net/petersons/ ________________________________________________________________________________
Subject: Re: UltraStar
Date: Aug 01, 2003
I have the plans,my email is rwehba(at)wtxs.net also have one ,where is sweeny, tx at,I am in sweetwater get ahold of me at my email! ----- Original Message ----- From: "Roger Peterson" <roger@pmmi-inc.com> Subject: Kolb-List: UltraStar > > Need wings for a ultraStar or plans so I can build some. > -- > Roger Peterson > 206 County Road 375 > Sweeny, Texas 77480 > Phone:979-647-4946 > Cell: 979-487-8356 > Fax: 979-647-1158 > E-Mail: roger@pmmi-inc.com > Bus Home Page: http://pmmi-inc.com > Personal Home Page: http://joinme.net/petersons/ > > ________________________________________________________________________________
Date: Aug 02, 2003
Subject: Throttle
Hey Guys, The oil injection housing wouldn't turn over ( 2 screws ) the 4 screw plate it's attached to would be able to turn over , but I had already mounted the bracket for the throttle splitter. So I made a new "ARM" ,so I could pull it from below without "looping" the cable.... By the way THANKS Richard....I found those 90 degree bends at a couple of bike shops, And my cables LOOK CLEAN & WORK GREAT ! I've got it finished up to the throttle lever.....But the cable angle to the throttle control doesn't look good at all....I think I need to weld a small piece to the throttle lever so I can raise the cable hole "UP" about 1/2 in from where the original hole is to keep it from rubbing on the cable tube and to travel 1 7/8 in without hitting the "Friction Washers" Any ideas....? Thanks again Richard ! Gotta Fly... Mike in MN --- Sometimes you just have to take the leap and build your wings on the way down... Gotta Fly... Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail! ________________________________________________________________________________
Date: Aug 02, 2003
Subject: old firestar
I am trying to restore a 80's vintage firestar and am in need of the assembly pieces make this bird fully enclosed. There is a top bow piece and latch pieces for the lexan to lock in place. Does anyone have any of the pieces that you may want to part with. Kolb sold these as an-add on years ago. Thanks G. Murphy ________________________________________________________________________________
Subject: Ontario Ultralights ?
Date: Aug 02, 2003
Hi All, Does anyone know of any club or group of ultralight pilots in the Southern Ontario region? I'm trying to determine if there are any such groups of people who get together, and of course fly together, in this area. Thanks Frank .................................. F. Otta Toronto, Ontario ________________________________________________________________________________
Date: Aug 03, 2003
If you don't care what kind if UL you fly with then there is : Baldwin CPB5 - where I am based. Brampton - lots there as well Volks/Tottingham - lots there Mazlacks (Spelling) - bunch there as well Where are you located in Toronto ? keep smiling Rob from Richmond Hill Ontario > > From: "Frank Otta" <fotta(at)rogers.com> > Subject: Kolb-List: Ontario Ultralights ? > > > Hi All, > > Does anyone know of any club or group of ultralight pilots in the Southern > Ontario region? I'm trying to determine if there are any such groups of > people who get together, and of course fly together, in this area. > > Thanks > Frank > > .................................. > F. Otta > Toronto, Ontario ________________________________________________________________________________
Date: Aug 03, 2003
From: "Dallas Shepherd" <cen23954(at)centurytel.net>
Subject: Re: Ontario Ultralights ?
Try Woody at duesouth(at)govital.com . He should know more fliers in =0D area.=0D Dallas Shepherd=0D Norfork, Ar=0D =0D -------Original Message-------=0D =0D From: kolb-list(at)matronics.com=0D Date: Saturday, August 02, 2003 10:49:08 PM=0D Subject: Kolb-List: Ontario Ultralights ?=0D =0D =0D Hi All,=0D =0D Does anyone know of any club or group of ultralight pilots in the Southern=0D Ontario region? I'm trying to determine if there are any such groups of=0D people who get together, and of course fly together, in this area.=0D =0D Thanks=0D Frank=0D =0D =2E..................................=0D F. Otta=0D Toronto, Ontario=0D =0D =0D =0D =0D =0D =0D =0D =2E ________________________________________________________________________________
From: "John Williamson" <kolbrapilot(at)comcast.net>
Subject: Oshkosh 2003 Update
Date: Aug 03, 2003
Hello Kolb Aviators and Builders, I got home from Oshkosh Friday evening. It was a relatively uneventful trip except for the spectacular scenery and a challenging airstrip. I have now landed the Kolbra in all of the lower 48 States. I got to fly with a great group of pilots: -- John Hauck, Kolb Mark III -- Scott Trask, Kolb Mark III, put me up in his house and let me use his "airstrip" -- Rick Neilsen, Kolb Mark III -- Lloyd Cudnohufsky, Kit Fox These guys put up with me and made the flight leg into Oshkosh even more memorable. While at Scott's place, Aaron Gustafson flew his nice blue and yellow FireStar in for use to check out. I also got to visit with Bill and Anna Vincent. Bill flies a FireStar. The flight was met at Oshkosh by Mary Jones (Editor of the 'Experimenter' magazine) and an EAA photographer. They took photos and later conducted an interview about my trips in the Kolbra. We were also greeted by Ray Brown of TNK and treated very generously. The whole crew at TNK was great as usual. While at the Ultralight area at Oshkosh I got to meet: John and Kathy Jung, John flies a FireStar. Larry and Judy Gitt, Larry flies the only other customer built Kolbra in the world. Tim Bjork. who is building a FireStar 2. Several others that I am sorry to say I have forgotten their names. Here are the stats for this trip: Distance: 2580.2 nm (3280 sm) Flight time: 39 hours 36 minutes Max ground speed: 112.9 knots (129.9 mph) Average ground speed: 65.2 knots (75 mph) Landings; 23 I have just completed updating this trip on my website, so please visit and look at the photos. If you find a broken link, please send me an email and let me know. http://home.comcast.net/~KolbraPilot4/KOSH.htm John Williamson Arlington, TX Kolb Kolbra, N49KK, Jabiru 2200, 440 hours http://home.comcast.net/~kolbrapilot ________________________________________________________________________________
Date: Aug 03, 2003
Subject: Kolb Mk III "max.flap extension speed-full flaps"
I have a Kolb Mk III (582). Does anyone know the max. speed for flying with the flaps fully extended? ________________________________________________________________________________
Subject: Re: Kolb Mk III "max.flap extension speed-full flaps"
Date: Aug 03, 2003
I don't believe that you want to do more than 60 mph. larry ----- Original Message ----- From: "John Raeburn" <raeburn(at)snowhill.com> Subject: Kolb-List: Kolb Mk III "max.flap extension speed-full flaps" > > I have a Kolb Mk III (582). > Does anyone know the max. speed for flying with the flaps fully extended? > > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2003
Yes there are. If you are going, ask at the UPAC AGM being held in a couple weeks. ----- Original Message ----- > > > Hi All, > > Does anyone know of any club or group of ultralight pilots in the Southern > Ontario region? I'm trying to determine if there are any such groups of > people who get together, and of course fly together, in this area. > > Thanks > Frank > > .................................. > F. Otta > Toronto, Ontario > > --- ________________________________________________________________________________
Date: Aug 04, 2003
Subject: Re: 447 rotax oil
> >Listers, > What's a top notch oil to use in a Rotax 447 sc engine? Thanks! Kirk > Forbidden topics: Politics, Religion and Oil. ________________________________________________________________________________
From: "Dolores and Mike" <mikedoloresa(at)adelphia.net>
Subject: New and Kolb
Date: Aug 04, 2003
Hi folks, I've been interested in ultralights since first looking into them 10yrs ago. I'm now going to purchase one(about time!)and need advice. I just went to Oshkosh AirVenture 2003(a must see!) to check out whats new in ultralights and found IMO Kolb's aircraft some of the best UL's there. I have also been considering Challenger,Phantom,Quicksilver and Aerolite. As far as FAR Part 103 UL's and a newbe who would like to be satisfied with his UL's performance capabilities long after his 'begginers' stage, would the Firefly be my best choice or would you folks suggest another aircraft initially? Thanks for your help,I really appreciate it. Mike ________________________________________________________________________________
Subject: Re: lever
Date: Aug 04, 2003
s. The first disadvantage would be getting in and out > over it. That goes into the "next year" category guys, I've got to get > a life here. > It gets better. You can position the throttle past fully closed when you get in and bring it up to position after you get comfortable. ________________________________________________________________________________
Subject: Re: Hauck tracks
Date: Aug 04, 2003
More Hauck Tracks.... This morning I said goodbye to a real ambassador for Kolb aircraft...John Hauck stopped by here in central illinois to give me a familiarization ride in his Kolb. He dropped in sunday nite on his way south from OshKosh...overnited here and after breakfast he basically eliminated all my questions on the particulars of handleing a Kolb airplane. I am forever grateful to John for his out-of-the-way effort...something I could not seem to get TNK company to do for me. I feel a awful lot better now about my upcoming maiden voyage in my newly completed FireFly, and my wife is a lot less worried about my antics also! God Bless you John Hauck, and may you have smooth air and clear skies ahead of you for all the miles you put behind you in the beautiful and Unique Miss P'Fer. thankyou very , very much. come back again next time your around, and dont keep Bailey waiting too long! http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Subject: fly-in
Date: Aug 04, 2003
In carolinasportflyers(at)yahoogroups.com, "John W.Davis" <patches11us@y...> wrote: Carolina Sport Flyers will be having there 3rd annual Fly-In on October 17th,18th and 19th 2003 at the Lee County Airport in Bishopville,SC http://www.airnav.com/airport/52j With Sat 18th being the main day. Food and Drinks will be serverd on Sat 18th. Fly-in or drive in. Dealers for U/L and light sport planes will be there. We will have a ride to and from motels,gas station or what ever you will need. Camping on the airport will be permited at the time of the fly- in but Sorry No hookups at the airport. We had a great turn out last year 19 ultralights and around 9 GA airplanes and hope to see each and everyone who attended last year there again this year. Be safe, have fun and thank the good Lord for letting us fly. Everyone is welcome. SEE YA SOON. Bryan Green (Elgin SC) ________________________________________________________________________________
Subject: Re: New and Kolb
Date: Aug 04, 2003
Mike and Dolores.....or was that Dolores and Mike?.. Anyway.. As you probably already know..the FireFly is highest performing airplane that can be built under 254 lbs. (that I know of)...but really its not 103 legal either because of its speed.... You mentioned that are new...well, new to Ultralights..or new to aviation in general?... If you are already an expierienced GA pilot..then the FireFly is for you....with instruction in a another kolb 1st... If you have no stick time in any aircraft, then the FireFly will be harder to handle than any of the other choices you mentioned... naturally because of its performance. All the other choices you listed are fine airplane choices.With the Challenger taking the most time to build of those...it will take more time than a FireFly...with the others taking less... As a newbie FireFly owner myself...I can say that it was easy to build...far easier than I thought it would be. (it is my 5th ultralite built) check out my website from the below link for some building pics to give you an idea what it takes...and then check out Jack Harts advanced builders website. If you have some friends who you will be flying with....you might consider building an airplane than has a similiar performance envelope as theirs..its a real drag to be flying a Quicksilver at 40 mph when all you buds are cruiseing at 60 !!.....or cruising at 70 in your Firefly making circles all the time when you Buds are all traveling at 45! these are the simple ramblings of a new FireFly owner! and probably not worth too much. http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Date: Aug 04, 2003
> >Mike and Dolores.....or was that Dolores and Mike?.. > >Anyway.. > >As you probably already know..the FireFly is highest performing airplane >that can be built under 254 lbs. >(that I know of)...but really its not 103 legal either because of its >speed.... > Don and Mike, Just because a FireFly will fly faster than 63 mph does not mean that it does not meet 103 requirements. What is important is that the FireFly meets basic design requirements. They are weight at or below 254 pounds empty, five gallon fuel capacity, a 447 engine requires a calculated FireFly drag factor of at least 12.5, and a wing loading of about four pounds per square foot with flaps. If all of these requirements are met under AC 103-7 Appendix 1, 2, 3 & 4, you are defined as legal no matter how fast your FireFly will go in level flight. There is some wiggle room in drag factor calculations, but with a 447 one must fly with your upper body exposed, and one cannot fair in the landing gear legs. But if one used a 33 hp engine, one could completely enclose the cockpit area, fair in the landing gear legs and the tires plus other items as well. Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Aug 04, 2003
> >Mike and Dolores.....or was that Dolores and Mike?.. > >Anyway.. > >As you probably already know..the FireFly is highest performing airplane >that can be built under 254 lbs. >(that I know of)...but really its not 103 legal either because of its >speed.... Don & Mike, I hit the wrong key and sent the reply early. If you would like to see the calculations required to determine if your FireFly meets Part 103 regulations, you can view a sample of what I put together for my FireFly at: http://www.thirdshift.com/jack/firefly/fireflylegal.html I asked an A&E to sign the front cover, and I carry a copy with me when I go to air shows. You have to prove that the FireFly meets the requirements, and this is considered as proof. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
From: "Frank Reynen" <frank_reynen(at)ix.netcom.com>
Subject: Re: Kolb-List Digest: 11 Msgs - 08/03/03
Date: Aug 04, 2003
Mike, After my second trip and rip I took a thin alum. plate about 3 inch square and drilled a hole in the middle for the cable housing to pass through and glued this plate on the inside of the cabin fabric using Politone glue and then cut out a 5 inch square piece of HS-90 and glued it over the plate I have tripped over the cable many more times but never again encountered a rip. Hope this helps. Frank Reynen Kolb mkIII /912 on Lotus floats www.webcom.com/reynen > the cables to the carbs would work good at getting a tight enough bend to run > the brake cable up the axle and avoid the dreaded "TRIPPING , RIPPING , LOOPS" > ...... I know there are others that have ripped their fabric too..... > I'm working on installing an airspeed indicator right now..... but > I'll be changing over the brake cable soon. One good thing is , the cable will > be shorter so it can be done with just a little cutting of the existing set-up....just > thought I'd share the Idea. > > Gotta Fly... > Mike in MN FSII 503 injected,3-66"IVO > ,GPL ,EIS > ________________________________________________________________________________
Date: Aug 05, 2003
Thanks Don, I would consider myself a newbie since it's been 10yrs ago that I ran out of money before completing my pilots license. I like the idea that the Firefly will keep my interest as my flying skills advance. I was thinking of a 'quick build' kit if not purchasing a pre-owned model. But then again building it myself(with help I'm sure)sounds like a great way to be thoroughly familiar with ones aircraft. Thanks for the link and your reply,I appreciate it. Mike ----- Original Message ----- From: "Don Gherardini" <donghe@one-eleven.net> Subject: Re: Kolb-List: New and Kolb > > Mike and Dolores.....or was that Dolores and Mike?.. > > Anyway.. > > As you probably already know..the FireFly is highest performing airplane > that can be built under 254 lbs. > (that I know of)...but really its not 103 legal either because of its > speed.... > > You mentioned that are new...well, new to Ultralights..or new to aviation in > general?... > > If you are already an expierienced GA pilot..then the FireFly is for > you....with instruction in a another kolb 1st... > > If you have no stick time in any aircraft, then the FireFly will be harder > to handle than any of the other choices you mentioned... naturally because > of its performance. All the other choices you listed are fine airplane > choices.With the Challenger taking the most time to build of those...it will > take more time than a FireFly...with the others taking less... > > As a newbie FireFly owner myself...I can say that it was easy to build...far > easier than I thought it would be. > (it is my 5th ultralite built) > > check out my website from the below link for some building pics to give you > an idea what it takes...and then check out Jack Harts advanced builders > website. > > If you have some friends who you will be flying with....you might consider > building an airplane than has a similiar performance envelope as theirs..its > a real drag to be flying a Quicksilver at 40 mph when all you buds are > cruiseing at 60 !!.....or cruising at 70 in your Firefly making circles all > the time when you Buds are all traveling at 45! > > these are the simple ramblings of a new FireFly owner! and probably not > worth too much. > > http://www.geocities.com/dagger369th/my_firefly.htm > Don Gherardini- > FireFly 098 > > ________________________________________________________________________________
Date: Aug 05, 2003
Thanks Jack,great info,I appreciate it. Mike ----- Original Message ----- From: "Jack & Louise Hart" <jbhart(at)ldd.net> Subject: Re: Kolb-List: New and Kolb > > > > >Mike and Dolores.....or was that Dolores and Mike?.. > > > >Anyway.. > > > >As you probably already know..the FireFly is highest performing airplane > >that can be built under 254 lbs. > >(that I know of)...but really its not 103 legal either because of its > >speed.... > > Don & Mike, > > I hit the wrong key and sent the reply early. > > If you would like to see the calculations required to determine if your FireFly meets Part 103 regulations, you can view a sample of what I put together for my FireFly at: > > http://www.thirdshift.com/jack/firefly/fireflylegal.html > > I asked an A&E to sign the front cover, and I carry a copy with me when I go to air shows. You have to prove that the FireFly meets the requirements, and this is considered as proof. > > Jack B. Hart FF004 > Jackson, MO > > > Jack & Louise Hart > jbhart(at)ldd.net > > ________________________________________________________________________________
Date: Aug 05, 2003
Subject: cracked muffler
During rutine preflight I noticed a discoloration from exhaust on the front of my muffler where the pipe attaches to it. Looking closer, I found it to be cracked around the outside of the weld. It seemed to be cracked most all the way around except an 1/8" here and there still holding things together. My 618 is mounted on lord engine mounts which allows it to vibrate quite a bit and the muffler is mounted with rubber mounts which makes a fairly solid connection to the plate to which it is mounted. What I'm trying to say is the engine moves alot and the muffler does not. This may have contributed to the cracking ? I was wondering if any of you on the list have used more of a shock mount on your mufflers, or are they all pretty much mounted with the rubber grommets? The muffler, y, and elbow had benn recoated over the winter, so all the connections were free and coated with never sieze. Thanks in advance for any comments. Fly safe Bob Griffin ________________________________________________________________________________
Date: Aug 05, 2003
Subject: Re: cracked muffler
This in not terribly unusual for Rotax mufflers. Several of the locals (including me) that use a sidemount muffler have eventually had some sort of cracking along the outside of the cone curve or where it joins the muffler or both at once. I think this is partly from mounting loads but more from the pressure pulses going around the curve in the cone and concentrating repeated stresses along the outside weld as they make the curve. It was partly for that reason that I went to the rear mounted (Quicksilver) style pipe on my MKIII. Mounting the muffler closer to the engine's center of motion reduces vibratory stress on the attachments and joints, and the straight cone receives less concentrated pulse stresses along just one weld. As part of this modification I changed the attachments to eliminate the standard springs and the worry that they might break and go through the prop. Hopefully, these mods will improve reliability. Pictures available at http://www.bcchapel.org/pages/0003/pg2.htm Richard Pike MKIII N420P (420ldPoops) > >During rutine preflight I noticed a discoloration from exhaust on the front >of my muffler where the pipe attaches to it. Looking closer, I found it to be >cracked around the outside of the weld. It seemed to be cracked most all the >way around except an 1/8" here and there still holding things >together. My 618 >is mounted on lord engine mounts which allows it to vibrate quite a bit and >the muffler is mounted with rubber mounts which makes a fairly >solid connection >to the plate to which it is mounted. What I'm trying to say is the engine >moves alot and the muffler does not. This may have contributed to the >cracking ? >I was wondering if any of you on the list have used more of a shock mount on >your mufflers, or are they all pretty much mounted with the rubber grommets? >The muffler, y, and elbow had benn recoated over the winter, so all the >connections were free and coated with never sieze. > >Thanks in advance for any comments. >Fly safe >Bob Griffin > > ________________________________________________________________________________
Subject: 447 rotax oil
Date: Aug 05, 2003
Ok guys thanks! Looks like Pennzoil air cooled is my choice. Got a lot to learn about these 2 strokes now. Kirk ________________________________________________________________________________
Subject: Thank you Mr. Pike
Date: Aug 05, 2003
I did a test flight of the totem pole today and I can not believe the difference in handling. I took Padre Pikes idea of moving the aileron control rods inward an inch. Almost feels like power steering. In it's original configuration I could hardly move the ailerons. Much harder than a standard MK111. I would recomend this mod to anyone. Perhaps only moving 3/4 inch would be enough. Before you do it be aware that you will have to lengthen the aileron rods but if you are almost bottoming out at the fitting then it will just be a matter of unscrewing the fitting a bit. I noticed another peculiarity on the Club plane last week while doing more testing. It flys straight. No left turn tendancy. What the heck did I do wrong Light ailerons and no left turn. It can't be a Kolb :) Just got back from Osh. I am beginnning to remove my 582 and ready to install my Jabi. Should be fun. ________________________________________________________________________________
Date: Aug 05, 2003
Subject: New To List Like It Already
Hi all ... I have a Firestar KX and am kearning more and more ... Any one have a Video from an in plane camera showing Landing procedures ??? Thanks ... Dave ________________________________________________________________________________
Date: Aug 05, 2003
Subject: Need Gear Leg :
( Any one out there have A 1-1/4 Firestar II Leg for sale ....... Thanks ... Dave ________________________________________________________________________________
Date: Aug 05, 2003
Subject: Flight to Oshkosh
Hi All: Got home, after 11 days, from my flight up through Michigan, the UP, Oshkosh, corn and bean fields of Illinois, the mountains and trees of Tennessee and Alabama. My timing, by chance of course, could not have been better. Ten miles north of Gantt International Airport I hit rain. Luckily, it was the tail end of a big thunderstorm and rainstorm that was on its way south out of my area. Landed about 1800. That's 6 o'clock PM, National Guard time. Departed home at noon 25 Jul. RON Kolb Factory, London, KY. Flew 10,000 to 12,000 feet ASL for most of the flight to take advantage of a 10 to 15 mph tailwind, rather than a headwind. 26 Jul, flew to Mentone, Indiana. Stopped briefly to visit the Popular Rotorcraft Convention. Was a fish out of water amongst the rotor heads, so departed for Michigan after a couple hour, or less, visit. Found Rick Nielsen's airstrip west of Lansing with no problem. Wind was blistering out of the west, so decided to take a rain check on landing there. After buzzing his house two or three times, got no response, and headed for Linden, MI. Had RON'd Linden in my Firestar in 1989. Hoping, expecting, to see the same airport I had flown out of, did not happen. The old T hanger I slept in with my Firestar had been bulldozed. The old "character" airfield was undergoing a makeover into a new air park. Considered staying at Linden for the night. Not a living soul around. Decided to see if I could find Kirk "Snuffy" Smith's airstrip. Shortly thereafter, I found Snuffy's airstrip, where I RON'd. Snuf was not at home, but it was nearing darkness, so decided this was a good secure place to stay amongst the mosquitoes. A short flight up the road on 27 Jul got me to Gaylord, where my Primary I instructor pilot in Army Rotary Wing School lives. He kicked me out of the next for my very first solo in a Hughes TH-55 (Mattel Mecherscmidt) helicopter. 28 Jul was a short 60 mile flight to St Ignace, MI. Upon arrival I discovered John Williamson's airplane and tent. John was still in the sack, but a flew orbits above the airport got him out of the tent and on to his feet. If you read John's recent email of the trip, you know the rest of the story as far as Oshkosh. Just used a protractor to compute the miles we flew along Whitefish Bay and the south shore of Lake Superior: approximately 120 miles of low level, on the deck, mostly over crystal clear water, flying. Had a great visit with Scott Trask and friends. A couple more flights through this AO and I will be a true "red neck" Uper. I love the area and the people. Departed Oshkosh for Sullivan, IL, Sunday about 1550 (2:50 o'clock NG time), ten minutes before they closed Whitman Field for the daily airshow. After refueling at my regular stop, Jolliet, IL, I was on again/off again flying to Sullivan or home. Depended on how severe the rain storms and thunder storms were. Dodging in and out, and around them, I finally got clear sailing into Shelby County Airport, IL. RON with Don G and family. Got up early, drank coffee and BS'd, ate breakfast and BS'd, flew Don in the Mark III and BS'd, until we finally got refueled and I was on my way south again. Stopped off at Lake Barclay State Park Airport so I could eat a great meal at the lodge. They have telephone, dial "0" for the desk, and a van will be there shortly to pick you up and take you to lunch. From Lake Barclay to Lawrenceville, TN, for fuel. Then another two hours and I was landing in the rain at Gant International about 1800. A great flight, 36 hours total. Aprx'ly 2,700 sm and 180 gal of fuel (estimate). Miss P'fer ("P" fer plane) and the ROTAX 912S performed impeccably the entire flight. I'm old fashioned and my pictures will take a few days to get developed. When the get back I will post for your edification and hopefully, your enjoyment. Take care, john h Titus, Alabama ________________________________________________________________________________
Subject: Oshkosh
Date: Aug 05, 2003
I AM Back from Oshkosh as well. Most interesting things for me were the Ultravair, a 1/3 corvair ultralight engine. Somewhat similar to a 1/2 VW but lighter and with a bit more power, but probably a bit more work to do to convert it. www.ultravair.com and the 8 cylinder radial cam RADCAM engine being developed by Earthstar aircraft designer Mark Bierely. It is projected to make 60 HP and weigh around 65 pounds ready to run. It should have decent fuel burn as well due to the high piston dwell at top dead center that the cam profile provides. http://www.rad-cam.com/ Also a really amusing VTOL craft was on display. I predict a very short first flight ending in a spectacular upside down landing and massive carnage. (Well it looks like it is unstable and uncontrollable in hover anyway) http://www.amvaircraft.com/ and then there was the startubes that were installed on the rotorway helicopter engines that did some magic to the fuel vaporization and improved engine power and reduced fuel flow. www.startube.com (this website is locked up right now.... I assume they will fix it when they get back from Oshkosh. Got to see one ultralight crash on the road at the north end of the runway, have not heard how the pilot is, anybody know? Topher ________________________________________________________________________________
Subject: Oshkosh
Date: Aug 05, 2003
Pilot and large passenger walked away. From my vantage point, it looked like he was mushing the whole way out of the runway. Fortunately, he was good enough to plant it on the road instead of the house on one side and the vehicles on the other side. Did you see the factory CGS Hawk break its gear and finish its landing on its belly minutes after the first crash? Chuck was pretty torqued that the demo pilot didn't use flaps for that landing. J.D. Stewart UltraFun AirSports http://www.ultrafunairsports.com FlyChallenger E-mail list and Website Administrator http://challenger.inebraska.com TitanAircraft e-mail list http://groups.yahoo.com/group/Titanaircraft/ > > > > > I AM Back from Oshkosh as well. > > Got to see one ultralight crash on the road at the north end of the > runway, have not heard how the pilot is, anybody know? > > Topher > ________________________________________________________________________________
Subject: full flap sped
Date: Aug 04, 2003
I have a Kolb Mk III (582). Does anyone know the max. speed for flying with the flaps fully extended? =============================================== i asked kolb the same question and was told that if you could pull the handel it is safe to fly. as for me i generaly fly at 70 with full flaps. boyd ________________________________________________________________________________
Subject: Oshkosh
Date: Aug 05, 2003
Pilot and large passenger walked away. From my vantage point, it looked like he was mushing the whole way out of the runway. Fortunately, he was good enough to plant it on the road instead of the house on one side and the vehicles on the other side. Did you see the factory CGS Hawk break its gear and finish its landing on its belly minutes after the first crash? Chuck was pretty torqued that the demo pilot didn't use flaps for that landing. I was on my bike headed out the gate and heard it then turned around to see it. Took a picture if anybody is interested. Watched the emergency guys for a few minutes and then headed down to the forums to here Burt Rutan talk. Missed the hawk splat. The previous day there was a trike on an amphibious boat that did a roll over. That plane head a coaxial counter rotating prop on it on a 582 engine. Took a picture if anybody is interested. Not sure what the point is of having two props on one engine but may increase static thrust a bit. They have a web site: www.ramphosusa.com Topher ________________________________________________________________________________
Date: Aug 05, 2003
Subject: Re: full flap sped
I had my Mark 111, w/582, marked at indicated 70mph, or below. Dallas Shepherd Norfork, Arkansas -------Original Message------- From: kolb-list(at)matronics.com Date: Tuesday, August 05, 2003 02:26:17 PM Subject: Kolb-List: full flap sped I have a Kolb Mk III (582). Does anyone know the max. speed for flying with the flaps fully extended? =============================================== i asked kolb the same question and was told that if you could pull the handel it is safe to fly. as for me i generaly fly at 70 with full flaps. boyd . ________________________________________________________________________________
Subject: head set
Date: Aug 05, 2003
Hey guys I'm looking for a head set and push to talk button (for stick) I have an Icom, what and where do you recommend? Bryan Green (Elgin SC) ________________________________________________________________________________
Date: Aug 05, 2003
From: Eugene Zimmerman <eugenezimmerman(at)dejazzd.com>
Richard Pike wrote: > > > So - you like it better than prune juice & Metamucil? > > Richard Pike > MKIII N420P (420ldPoops) > The preacher's way with words calling Klotz and Seafoam a bunch of Bull Poop : ) ________________________________________________________________________________
Subject: 3 River Flyin
Date: Aug 05, 2003
Rick, The Fly-in you were asking us (Woody and myself) about at Oshkosh is in Three Rivers, Mich. on Labour Day weekend. The url to the info is : http://www.aerosports.org/Docs/who.htm Andy Bondy ----- Original Message ----- From: "Rick & Martha Neilsen" <NeilsenRM(at)comcast.net> Subject: RE: Kolb-List: up and away (again) : : Woody : : Do you have any information on that fly-in in Michigan. : I haven't heard anything about it or even were it is. : : Rick Neilsen : Redrive VW powered MKIII : : : : : : : : : ________________________________________________________________________________
Date: Aug 05, 2003
writes: > The preacher's way with words calling Klotz and Seafoam a bunch of > Bull > Poop Gene, Use what you want. I have seen the difference between synthetic oil and mineral Pennzoil on another 447 in an Original Firestar like mine. My 447 will continue using Klotz synthetic with an occasional Seafoam treatment. No doubt about it. I like the idea of it running reliably well for many years to come :) Ralph Burlingame Original Firestar 16 years flying it The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Aug 06, 2003
Subject: Re: head set
I got something called lightspeed. it came with a patch for a push to talk. I got the momentary button (the push to talk button) at radio shack and put it in myself. it works great. my icom is a icom sport. mark southern mn ________________________________________________________________________________
"Kolb-List Digest List"
Subject: Re: Headsets
Date: Aug 06, 2003
Brian , I highly recommend the Lightspeed Solo headsets from Aircraft Spruce. And the push to talk switch from Radio Shack soldered to a telephone cord and superglued in the top of the stick. Hans van Alphen Mark III Xtra Bmw powered 106 hours. > > > Hey guys I'm looking for a head set and push to talk button (for stick) I have > an Icom, what and where do you recommend? > Bryan Green (Elgin SC) > ________________________________________________________________________________
Date: Aug 06, 2003
ul15rhb(at)juno.com wrote: > > I like the idea of it running reliably well for many years to come :) > > Ralph Burlingame > Original Firestar > 16 years flying it Me too, But I run Wal Mart. Flying 2 strokes since 1980 with no engine seizure. : ) ________________________________________________________________________________
Date: Aug 06, 2003
Subject: Kolb / Oil Also Landing Gear & Skid plate
For Oil Lockwood Recommends Pennzoil 2stroke AIR COOLED ... DAP Has it here for about $1.20 enough for 3 gallons ... How many of u guys have snapped off your landing gear ? How about putting a Skid plate under the fuselage to protect it ... My buddy snapped his gear off a few years ago so go easy on the flames : ) Does anyone have any Gear legs for sale ? ________________________________________________________________________________
Date: Aug 06, 2003
Subject: Re: Misc...
Hey John , did you carry all your oil with you in your" 2 cycle days"..... > Mike in MN Mike/All: With the Firestar/447 and Mark III/582 I had 12 quarts of Pennzoil for aircooled engines on board. That's about 3 gals. Even then, on flights to New England and the long way to Oshkosh, I had to scrounge engough oil to get back to Alabama. I ran Wal*Mart two stroke oil in the 582 for a while. Stock piled some and have about 5 or 6 gal left over. Will take 27 years to use that much oil in a weed eater. :-) Take care, john h ________________________________________________________________________________
Date: Aug 06, 2003
Thanks Mark Bryan Green (Elgin SC) ----- Original Message ----- From: <Mhqqqqq(at)aol.com> Subject: Re: Kolb-List: head set > > I got something called lightspeed. it came with a patch for a push to talk. > I got > the momentary button (the push to talk button) at radio shack and put it in > myself. > > it works great. my icom is a icom sport. > > mark > southern mn > > ________________________________________________________________________________
Date: Aug 06, 2003
Thank you Hans, thats two votes for the Lightspeed. Bryan Green (Elgin SC) ----- Original Message ----- From: "Hans vanAlphen" <hva(at)bellsouth.net> Subject: Kolb-List: Re: Headsets > > Brian , I highly recommend the Lightspeed Solo headsets from Aircraft > Spruce. And the push to talk switch from Radio Shack soldered to a > telephone cord and superglued in the top of the stick. > Hans van Alphen > Mark III Xtra > Bmw powered > 106 hours. > > > > > > > Hey guys I'm looking for a head set and push to talk button (for stick) I > have > > an Icom, what and where do you recommend? > > Bryan Green (Elgin SC) > > > > ________________________________________________________________________________
Date: Aug 06, 2003
I have the Lightspeed Cross-County (ANR) and the Solo.... My passengers (poor things) use the Solo and I use the Cross-Country. The ANR is probably a "minimal" ANR, but it's VERY noticeable, and VERY nice to have, especially for cross country flights. As for the Solo, I've never had a passenger complain, so I supposed they're okay, too! But I'd go for the Cross-Country headset. The ANR doesn't quiet everything, but it takes that edge off. -- Robert At 06:45 PM 8/6/2003, you wrote: > >Thank you Hans, thats two votes for the Lightspeed. >Bryan Green (Elgin SC) >----- Original Message ----- >From: "Hans vanAlphen" <hva(at)bellsouth.net> >To: ; "Kolb-List Digest List" > >Subject: Kolb-List: Re: Headsets > > > > > > Brian , I highly recommend the Lightspeed Solo headsets from Aircraft > > Spruce. And the push to talk switch from Radio Shack soldered to a > > telephone cord and superglued in the top of the stick. > > Hans van Alphen > > Mark III Xtra > > Bmw powered > > 106 hours. > > > > > > > > > > > Hey guys I'm looking for a head set and push to talk button (for stick) >I > > have > > > an Icom, what and where do you recommend? > > > Bryan Green (Elgin SC) > > > > > > > > > -- cell: 713-503-2949 -- fax : 425-928-3369 -- web pages: http://www.rlaird.net http://www.texas-flyer.com ________________________________________________________________________________
Date: Aug 06, 2003
I really like my ultra com ________________________________________________________________________________
Date: Aug 06, 2003
Thanks Robert I'll check them out also. Bryan Green (Elgin SC) ----- Original Message ----- From: "Robert Laird" <rlaird(at)cavediver.com> Subject: Re: Kolb-List: Re: Headsets > > > I have the Lightspeed Cross-County (ANR) and the Solo.... My passengers > (poor things) use the Solo and I use the Cross-Country. The ANR is > probably a "minimal" ANR, but it's VERY noticeable, and VERY nice to have, > especially for cross country flights. As for the Solo, I've never had a > passenger complain, so I supposed they're okay, too! But I'd go for the > Cross-Country headset. The ANR doesn't quiet everything, but it takes that > edge off. > > -- Robert > > > At 06:45 PM 8/6/2003, you wrote: > > > >Thank you Hans, thats two votes for the Lightspeed. > >Bryan Green (Elgin SC) > >----- Original Message ----- > >From: "Hans vanAlphen" <hva(at)bellsouth.net> > >To: ; "Kolb-List Digest List" > > > >Subject: Kolb-List: Re: Headsets > > > > > > > > > > Brian , I highly recommend the Lightspeed Solo headsets from Aircraft > > > Spruce. And the push to talk switch from Radio Shack soldered to a > > > telephone cord and superglued in the top of the stick. > > > Hans van Alphen > > > Mark III Xtra > > > Bmw powered > > > 106 hours. > > > > > > > > > > > > > > > Hey guys I'm looking for a head set and push to talk button (for stick) > >I > > > have > > > > an Icom, what and where do you recommend? > > > > Bryan Green (Elgin SC) > > > > > > > > > > > > > > > > > -- cell: 713-503-2949 > -- fax : 425-928-3369 > -- web pages: http://www.rlaird.net http://www.texas-flyer.com > > ________________________________________________________________________________
Date: Aug 06, 2003
i had the same problem with cracking exaust pipes untill i used urethane mounting bushings to keep flexing & vibration down to a minumn. ________________________________________________________________________________
Date: Aug 07, 2003
Some people out there, including me, would argue that the original Firestars were the best-flying of all the Kolb models. The original Firestars are still out there flying and doing what Kolbs do best. >From: "Dolores and Mike" <mikedoloresa(at)adelphia.net> >Reply-To: kolb-list(at)matronics.com >To: >Subject: Kolb-List: New and Kolb >Date: Mon, 4 Aug 2003 14:16:22 -0700 > > > >Hi folks, I've been interested in ultralights since first looking into them >10yrs ago. I'm now going to purchase one(about time!)and need advice. I >just went to Oshkosh AirVenture 2003(a must see!) to check out whats new in >ultralights and found IMO Kolb's aircraft some of the best UL's there. I >have also been considering Challenger,Phantom,Quicksilver and Aerolite. As >far as FAR Part 103 UL's and a newbe who would like to be satisfied with >his UL's performance capabilities long after his 'begginers' stage, would >the Firefly be my best choice or would you folks suggest another aircraft >initially? Thanks for your help,I really appreciate it. > > > Mike > > ________________________________________________________________________________
Date: Aug 07, 2003
Subject: Lorance airmap 100
Hi Gang, Decided to junk my GPS 12 after it lead me astray. I asked around at our Eaa Chapter meeting and several recommended the above. I checked Ebay and you can buy one for $226.00. You can also call JA Air at 1-800-323-5966 and have one shipped with the power card for $229.00 thru UPS. You could also bed on one and probably get it cheaper. Go to Lorance site and you can down load the manual free. Tom Guidroz-Kolb MK III 259 Houma La. ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 16 Msgs - 08/06/03
Date: Aug 07, 2003
From: "Mike Pierzina" <planecrazzzy(at)lycos.com> Subject: Kolb-List: Misc... Hey Guys, Thanks for the reply Frank , sounds like the way to patch those rips....but what is HS-90 ??? Stits Poly fiber covering fabric HS-90X used for all your Kolb wing, tail and cabin covering. Sorry for the omission. Frank Reynen ________________________________________________________________________________
Date: Aug 07, 2003
Subject: Re: Lorance airmap 100
Tom -- I've had one for a couple of years, and I'm _very_ happy with it. The screen is small, but it's sharpness almost makes up for that. The features -- particularly the aviaiton-specific features -- are top-notch. You should enjoy it! -- Robert At 03:47 PM 8/7/2003, you wrote: > > Hi Gang, > >Decided to junk my GPS 12 after it lead me astray. I asked around at our Eaa >Chapter meeting and several recommended the above. I checked Ebay and you can >buy one for $226.00. You can also call JA Air at 1-800-323-5966 and have one >shipped with the power card for $229.00 thru UPS. You could also bed on >one and >probably get it cheaper. Go to Lorance site and you can down load the manual >free. > >Tom Guidroz-Kolb MK III 259 >Houma La. > > -- cell: 713-503-2949 -- fax : 425-928-3369 -- web pages: http://www.rlaird.net http://www.texas-flyer.com ________________________________________________________________________________
Date: Aug 07, 2003
BTW, if you ever want to, ahem, "share" the database upgrade, let me know. They're kind of pricey. -- Robert P.S. Check out my website when you get a minute: http://Texas-Flyer.com >Tom -- > >I've had one for a couple of years, and I'm _very_ happy with it. The >screen is small, but it's sharpness almost makes up for that. The >features -- particularly the aviaiton-specific features -- are >top-notch. You should enjoy it! > > -- Robert At 03:47 PM 8/7/2003, you wrote: > > Hi Gang, > >Decided to junk my GPS 12 after it lead me astray. I asked around at our Eaa >Chapter meeting and several recommended the above. I checked Ebay and you can >buy one for $226.00. You can also call JA Air at 1-800-323-5966 and have one >shipped with the power card for $229.00 thru UPS. You could also bed on >one and >probably get it cheaper. Go to Lorance site and you can down load the manual >free. > >Tom Guidroz-Kolb MK III 259 >Houma La. ________________________________________________________________________________
Date: Aug 07, 2003
Subject: Magellan Meridian series GPS
Guys, Another great but cheap ($200) GPS is the Magellan Meridian series. I have the Gold model and it's not only easy to use, but has the whole map of the US stored in it's memory along with all the airports. The mapping feature shows what's under me as I'm flying along. The screen is bigger than most of them with better resolution showing cities/towns, airports, highways, RR tracks, lakes, and points of interest. A CD can be ordered for finer detail of city and residential streets or topographical maps. Batteries last 14 hours and can plug into a 9-35 volt external power source. I use a 9.5vdc external rechargeable battery with the internal "AA" batteries as a backup. I love it and the price is right. Ralph Original Firestar 16 years flying it The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Subject: Re: Magellan Meridian series GPS
Date: Aug 07, 2003
Hello Ralph I've recently purchased a older Firestar I (about 89) with approx. 200 hrs. I am looking at adding a full enclosure before winter. If you have any suggestions or advice please let me know and send me a picture of your bird if you have one. I am attaching one of mine. Fly safe and have fun. Bryan Green (Elgin SC) ----- Original Message ----- From: <ul15rhb(at)juno.com> Subject: Kolb-List: Magellan Meridian series GPS > > Guys, > > Another great but cheap ($200) GPS is the Magellan Meridian series. I > have the Gold model and it's not only easy to use, but has the whole map > of the US stored in it's memory along with all the airports. The mapping > feature shows what's under me as I'm flying along. > > The screen is bigger than most of them with better resolution showing > cities/towns, airports, highways, RR tracks, lakes, and points of > interest. > > A CD can be ordered for finer detail of city and residential streets or > topographical maps. > > Batteries last 14 hours and can plug into a 9-35 volt external power > source. I use a 9.5vdc external rechargeable battery with the internal > "AA" batteries as a backup. > > I love it and the price is right. > > Ralph > Original Firestar > 16 years flying it > > The best thing to hit the internet in years - Juno SpeedBand! > Surf the web up to FIVE TIMES FASTER! > > ________________________________________________________________________________
Date: Aug 07, 2003
Dont know what happen to the pic but here it is again. Bryan Green (Elgin SC) ----- Original Message ----- From: "bryan green" <lgreen1(at)sc.rr.com> Subject: Re: Kolb-List: Magellan Meridian series GPS > > Hello Ralph I've recently purchased a older Firestar I (about 89) with > approx. 200 hrs. I am looking at adding a full enclosure before winter. If > you have any suggestions or advice please let me know and send me a picture > of your bird if you have one. I am attaching one of mine. Fly safe and have > fun. > Bryan Green (Elgin SC) > ----- Original Message ----- > From: <ul15rhb(at)juno.com> > To: > Subject: Kolb-List: Magellan Meridian series GPS > > > > > > Guys, > > > > Another great but cheap ($200) GPS is the Magellan Meridian series. I > > have the Gold model and it's not only easy to use, but has the whole map > > of the US stored in it's memory along with all the airports. The mapping > > feature shows what's under me as I'm flying along. > > > > The screen is bigger than most of them with better resolution showing > > cities/towns, airports, highways, RR tracks, lakes, and points of > > interest. > > > > A CD can be ordered for finer detail of city and residential streets or > > topographical maps. > > > > Batteries last 14 hours and can plug into a 9-35 volt external power > > source. I use a 9.5vdc external rechargeable battery with the internal > > "AA" batteries as a backup. > > > > I love it and the price is right. > > > > Ralph > > Original Firestar > > 16 years flying it > > > > The best thing to hit the internet in years - Juno SpeedBand! > > Surf the web up to FIVE TIMES FASTER! > > > > > > ________________________________________________________________________________
Date: Aug 07, 2003
ALL attachments are stripped. Send Picture off list. ----- Original Message ----- From: "bryan green" <lgreen1(at)sc.rr.com> Subject: Re: Kolb-List: Magellan Meridian series GPS > > Dont know what happen to the pic but here it is again. > Bryan Green (Elgin SC) > ----- Original Message ----- > From: "bryan green" <lgreen1(at)sc.rr.com> > To: > Subject: Re: Kolb-List: Magellan Meridian series GPS > > > > > > Hello Ralph I've recently purchased a older Firestar I (about 89) with > > approx. 200 hrs. I am looking at adding a full enclosure before winter. If > > you have any suggestions or advice please let me know and send me a > picture > > of your bird if you have one. I am attaching one of mine. Fly safe and > have > > fun. > > Bryan Green (Elgin SC) > > ----- Original Message ----- > > From: <ul15rhb(at)juno.com> > > To: > > Subject: Kolb-List: Magellan Meridian series GPS > > > > > > > > > > Guys, > > > > > > Another great but cheap ($200) GPS is the Magellan Meridian series. I > > > have the Gold model and it's not only easy to use, but has the whole map > > > of the US stored in it's memory along with all the airports. The mapping > > > feature shows what's under me as I'm flying along. > > > > > > The screen is bigger than most of them with better resolution showing > > > cities/towns, airports, highways, RR tracks, lakes, and points of > > > interest. > > > > > > A CD can be ordered for finer detail of city and residential streets or > > > topographical maps. > > > > > > Batteries last 14 hours and can plug into a 9-35 volt external power > > > source. I use a 9.5vdc external rechargeable battery with the internal > > > "AA" batteries as a backup. > > > > > > I love it and the price is right. > > > > > > Ralph > > > Original Firestar > > > 16 years flying it > > > > > > The best thing to hit the internet in years - Juno SpeedBand! > > > Surf the web up to FIVE TIMES FASTER! > > > > > > > > > > > > ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Oshkosh
Date: Aug 07, 2003
I'm finally back from Oshkosh. I wanted to leave Monday morning early but was delayed till almost airshow time by fog. I then got caught in school craft county for most of the day on Tuesday by fog. Wednesday also fogged me in Gaylord till almost 11AM. Then there was a big thunder storm that sat over my runway most of the evening on Wednesday so I landed at a nearby strip and retrieved my plane this morning. I flew 20.2 hours from Grand Ledge Michigan to Oshkosh and back. There were two times I had to back track or divert due to weather for a total of 120miles. I burned 81.5 gallons for a average fuel burn of 4.03 gallons per hour. The VW ran super the whole way without skipping a beat even over Beaver Island. The trip was wonderful. The flight from Iron Mountain to Oshkosh was a experience that I will NEVER forget. I flew with three other Kolbs and a Kitfox the 120 miles on a morning that was perfectly smooth. We dropped down to 300 AGL for approach to Oshkosh and blasted in at 75mph single file. I was forth in line watching John Hawk then John Williamson then Scott Trash ahead of me bouncing around in each other's wake for a fly by of the Ultralight strip and then in for a landing. Wow what a blast. My face really did hurt from a ear to ear grin. Thank you Scott for hosting the get to gether at you place in what really is gods country. And thanks to everyone I flew with for a super experience. Rick Neilsen Redrive VW powered MKIII ________________________________________________________________________________
Date: Aug 07, 2003
From: "Blackwell, Charlie & Meredith" <wozani(at)optonline.net>
Subject: intercom/radio
For my radio setup, which performs very well, I got all the parts from CPS (California Power Systems, www.800-airwolf.com). The Ultra-com headsets are comfortable and quiet, the Ultra-com II intercom is both battery powered and can be connected to the plane power supply. I got a comtronics patch cord with push to talk switch that performs well. The catalog has a list of radios that they work with (looks like over 70 choices). I use it with a Vertex standard pro V radio for good results. Only change I plan on is the shielded spark plug covers and maybe wires if needed. Much of my flying is near or into busy airports. Last thing anyone needs is more complaints of ultralights not communicating in the pattern. Seems like there are enough places we are not welcome already. Charlie Blackwell, MKII in NJ ________________________________________________________________________________
Subject: Re: Oshkosh
Date: Aug 08, 2003
Richard...Good to see you home safe and sound... It certainly was a pleasure meeting you and chatting at OshKosh. best of luck to you and yours! Don Gherardini Sales / Engineering dept. American Honda Engines Power Equipment Company 800-626-7326 ________________________________________________________________________________
Subject: headset
Date: Aug 08, 2003
Thanks for all the input from everyone on my headset question. I went with a package from RAD electronics will let you know how it works out. Bryan Green (Elgin SC) ________________________________________________________________________________
Date: Aug 08, 2003
Subject: I'm off the fence!
Greeting Kolbers, Traveled to Oshkosh last week and bought a Mark 3 Xtra! After six months of research and endless e-mails to Linda at Kolb, I was ready to see and fly the Xtra. The flight went great, with no surprises (thanks, Norm). Had the pleasure to meet some of you folks on this list: John Hauck, John Williamson, Rick Nielsen, Don Gherardini, Terry and your wife Pat (sorry, I don't recall your last name) and several other whose names I don't recall. You guys were so very helpful, offering your experience and vast knowledge of all things Kolb, and I appreciate all of you putting up with my endless questions and picture taking of your planes! Visited with the crew at Kolb, hanging around all week, peppering everyone with endless questions, and they were very friendly, helpful AND patient :-) My thanks to everyone! Through this process I decided to go with the ailerons and flaps, instead of the flaperons, on the Xtra cage, and planning to run the 912S. I can't wait to start on kit #1 which should arrive in three weeks or so! For now I'm looking at air powered rivet guns, and other tools to get my little garage ready. -Jim ________________________________________________________________________________
Subject: Re: I'm off the fence!
Date: Aug 08, 2003
Welcome aboard Jim. Denny Rowe Mk-3, N616DR, 2SI 690L-70, Leechburg PA ----- Original Message ----- From: Jim Clayton <jspc78(at)yahoo.com> Subject: Kolb-List: I'm off the fence! > > Greeting Kolbers, > > Traveled to Oshkosh last week and bought a Mark 3 > Xtra! After six months of research and endless > e-mails to Linda at Kolb, I was ready to see and fly > the Xtra. The flight went great, with no surprises > (thanks, Norm). Had the pleasure to meet some of you > folks on this list: John Hauck, John Williamson, Rick > Nielsen, Don Gherardini, Terry and your wife Pat > (sorry, I don't recall your last name) and several > other whose names I don't recall. You guys were so > very helpful, offering your experience and vast > knowledge of all things Kolb, and I appreciate all of > you putting up with my endless questions and picture > taking of your planes! Visited with the crew at Kolb, > hanging around all week, peppering everyone with > endless questions, and they were very friendly, > helpful AND patient :-) My thanks to everyone! > Through this process I decided to go with the ailerons > and flaps, instead of the flaperons, on the Xtra cage, > and planning to run the 912S. I can't wait to start > on kit #1 which should arrive in three weeks or so! > For now I'm looking at air powered rivet guns, and > other tools to get my little garage ready. > > -Jim > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2003
Subject: how much is enough
I am in the process of restoring a tired firestar. It needs to have the wings recovered since they are over 15 years old and the original builder failed to silvercoat before spraying the final coat of paint. I do not have the construction instructions and am having to sorta "wing it" on the how and what to do. Does anyone know how much fabric and related materials (rivets, tape etc) is required for two complete wings only. If anyone has an old set of instructions that are no longer needed I would be interested in purchasing them from you. Thanks, George Murphy ________________________________________________________________________________
Subject: Re: how much is enough
Date: Aug 09, 2003
Hello George I recently bought a early Firestar and got the instructions with it. Send me your address of list and I will photo copy and send to you. If you have a pic of your plane send it to. Bryan Green (Elgin SC) ----- Original Message ----- From: "george murphy" <geomurphy(at)direcway.com> Subject: Kolb-List: how much is enough > > I am in the process of restoring a tired firestar. It needs to have the > wings recovered since they are over 15 years old and the original builder > failed to silvercoat before spraying the final coat of paint. I do not have > the construction instructions and am having to sorta "wing it" on the how > and what to do. Does anyone know how much fabric and related materials > (rivets, tape etc) is required for two complete wings only. If anyone has > an old set of instructions that are no longer needed I would be interested > in purchasing them from you. Thanks, George Murphy > > ________________________________________________________________________________
Subject: plans
Date: Aug 09, 2003
Who was it that needed the ultrastar plans, you bought the wrecked one? get in touch with me. ________________________________________________________________________________
Date: Aug 09, 2003
Subject: Slingshot Wanted
Wanted - Kolb Slingshot in any stage from unstarted Kit to flying airplane. Please contact Wayne with details. Thanks Wayne wfwilson1(at)yahoo.ca 519-736-0577 ________________________________________________________________________________
Subject: Puddle Jumper Floats
Date: Aug 09, 2003
I have a newly restored 1986 Kolb Twinstar that flies just great. Somehow thru some wheeling and dealing I came into possession of a pair of Puddle Jumper amphib floats and am wondering if anyone has ever installed them on a Kolb and how they worked. ________________________________________________________________________________
Date: Aug 10, 2003
Subject: New Engine for FireStar
Hey Kolbers! Got a question for you guys. I'm thinking about a new engine for my FireStar so that I can keep up with John Williamson's Kolbra. Any body ever thought about putting a Rotax 582 on a FireStar? I'll bet that extra 15 HP would really do some good! I have the gross weight to spare... I always heard that the structure couldn't handle the torque, but now I find that the upper tube that supports the engine and absorbs the torque is the same for all the Kolb models- FireStar has the same cage top that the Mk3 and Kolbra use. The lower cage structure is a bit different but the inboard wing attach and drag strut geometry is also the same. A 582 with a 3:1 gearbox would allow a bigger prop to turn slower- quieter and better performing. I've never heard of a 582 on an FS, but what would be the pitfalls? You guys have any opinions on this? Ken Korenek St Louis, Mo Firestar # 438 95 hours ________________________________________________________________________________
Date: Aug 10, 2003
Subject: Re: New Engine for FireStar
> Got a question for you guys. I'm thinking about a new engine for > my FireStar so that I can keep up with John Williamson's Kolbra. > Ken Korenek Ken/All: If I wanted to cruise with John W's Kolbra, I would buy a Kolbra or an equivilent aircraft that was designed to cruise in the 80 to 90 mph range. Check VNE on your Firestar. I don't know what it is, but bet it is less than a MK III or Kolbra. Firestar has a 7 main rib wing. I think when you got on the Kolb List you had a 5 rib wing. Went through a lot of discussion on your decision making process to come up with the 7 rib wings. I broke my 5 main rib wings. john h ________________________________________________________________________________
Date: Aug 10, 2003
have you thought about a AO84 surplus engine?? http://groups.yahoo.com/group/surplusengines?yguid=138616889 ----- Original Message ----- From: "Ken W Korenek" <kenkorenek(at)charter.net> Subject: Kolb-List: New Engine for FireStar > > Hey Kolbers! > > > Got a question for you guys. I'm thinking about a new engine for > my FireStar so that I can keep up with John Williamson's Kolbra. > > Any body ever thought about putting a Rotax 582 on a FireStar? > I'll bet that extra 15 HP would really do some good! I have the gross > weight to spare... > > I always heard that the structure couldn't handle the torque, but > now I find that the upper tube that supports the engine and absorbs the > torque is the same for all the Kolb models- FireStar has the same cage > top that the Mk3 and Kolbra use. The lower cage structure is a bit > different but the inboard wing attach and drag strut geometry is also > the same. > > > A 582 with a 3:1 gearbox would allow a bigger prop to turn slower- > quieter and better performing. > > > I've never heard of a 582 on an FS, but what would be the pitfalls? > > > You guys have any opinions on this? > > > Ken Korenek > St Louis, Mo > > > Firestar # 438 > 95 hours > > > > > ________________________________________________________________________________
Date: Aug 10, 2003
From: "johnjung(at)compusenior.com" <johnjung(at)compusenior.com>
Subject: Re: Flying? Maybe? A Kolb.
David and Group, ---> then today a fella - who flies Thundergulls told me they (Kolbs) ground loop easily and to be careful.<-- We have a number of Titan/Thundergull pilots flying in the Midwest. They show up at distant fly-ins almost as often as Kolbs. I have polled them about why they chose a Thundergull over a Kolb, and the usual answer is that they like the ground handling of a nose wheel plane. They worry about ground loops and nosing over. In my opinion, some Titan/Thundergull pilots have an inordinate fear of taildraggers, and don't understand that Kolbs are not like most taildraggers. John Jung ________________________________________________________________________________
Date: Aug 10, 2003
Subject: Re: Kolb list trackware/trojans/data mining
I use it its great ... Dave ________________________________________________________________________________
Date: Aug 10, 2003
I use Adaware once a week....it always finds a few hidden programs that are running recording and sending data to who knows who..makes me mad as heck... Richard is giving good advice men...download and run Adaware , its a great program. the first time i ran it it discoverd something like 65 programs that were sending info out ...so be ready! ________________________________________________________________________________
Subject: FireFlys Maiden Flight!
Date: Aug 10, 2003
Mission accomplished! Today I flew the Firefly...or "FlagFly" as some of you have started to call her!....WOW...what a beauty...perfect handleing....no bad habits , Just as you told me John Hauck! I had trim tabs ready to mount....but I threw em back in the toolbox as it just does not need any! First time was gonna be a few crowhops..but it cliombed out so dang fast...I just went around...landed a tad hard with one bounce..went around again and 2nd landing was a little better....3rd landing I greased her in..probably lucky, but dang I was so proud I stopped and taxi'd over to the hanger where the lookers were and got out to see if anything had loosened up...and of course to hear the compliments from the gallery....back up for a little cruise...Airspeed indicator is way off and thats the only gripe I could write down... all you Kolber's were right, this is one Dandy little airplane...special thanks to John H for the check ride, and all of you fellas for the sharing of knowledge that has no doubt contributed to a perfect first flight! http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Date: Aug 10, 2003
> > > >Check VNE on your Firestar. I don't know what it >is, but bet it is less than a MK III or Kolbra. > > > Vne is 90 MPH. I don't intend to go above that speed. The question is about structural capability. Are the cages on Firestars the same as MK3's and Kolbrs's in the area of the engine mounting tube? If so, then why can't a 582 be safely fitted to a FireStar? Steve posted a response about a conversation with Dennis Souder that vibration was a bigger concern than reacting the torque. I'm not sure I understand that at all. A larger diameter prop, properly balanced and turning slower will produce less vibration and the 582 under the load of that prop will be smoother as well. As far as Vne goes, I've got a sports car that will do 160 mph, but I don't go over the Vne of 70 mph. But, I sure get to 70 fast. A 582 would sure make a FireStar a crotch-rocket. It would get to Vne quickly, but I still wouldn't exceed it. I'm toying with the "experimental" aspect of this hobby... Ken ________________________________________________________________________________
Date: Aug 11, 2003
Ken, Why not just run a 3.47 to 1 C gearbox on a 503 with a 72 inch two blade such as a Powerfin or Warp Drive. Or maybe even an in-flight adjustable IVO. This would maximize your performance without the added complexities of a liquid cooled engine. Would also keep it in the Homer recommended power range. The 503 powered Firestars that I have seen seem to really haul the mail. Denny ----- Original Message ----- From: Ken W Korenek <kenkorenek(at)charter.net> Subject: Re: Kolb-List: New Engine for FireStar > > > > > > > > > >Check VNE on your Firestar. I don't know what it > >is, but bet it is less than a MK III or Kolbra. > > > > > > > Vne is 90 MPH. I don't intend to go above that speed. > > The question is about structural capability. Are the cages on > Firestars the same as MK3's and Kolbrs's in the area of the engine > mounting tube? > > > If so, then why can't a 582 be safely fitted to a FireStar? > > > Steve posted a response about a conversation with Dennis Souder that > vibration was a bigger concern than reacting the torque. I'm not sure > I understand that at all. A larger diameter prop, properly balanced > and turning slower will produce less vibration and the 582 under the > load of that prop will be smoother as well. > > As far as Vne goes, I've got a sports car that will do 160 mph, but I > don't go over the Vne of 70 mph. But, I sure get to 70 fast. A 582 > would sure make a FireStar a crotch-rocket. It would get to Vne > quickly, but I still wouldn't exceed it. > > I'm toying with the "experimental" aspect of this hobby... > > > Ken > > ________________________________________________________________________________
Subject: Firefly.
Date: Aug 10, 2003
I"ve just completed a Firefly in which I installed a Hirth 2702 -40 HP engine. This engine turns slower than a Rotax 447 by 1000 RPM. It has a 2.59 reduction gear. The engine obviously produces more torque. In taxi tests the airplane pulls to the right so much that I have to cut the power to stay on the runway. I have 100 hours on the engne whch I flew in my firestar. I may be getting too much "P" factor. I would like to hear from anyone who has used the Hirth 2702 in a Fireflyand if they have experienced any problems. Thanks-- George Daum ________________________________________________________________________________
Subject: Re: FireFlys Maiden Flight!
Date: Aug 10, 2003
Ed, Since you mentioned weight an balance and gap seal..lemme share some stuff with you.. weight an balance...today before flight test.. with 2.5 gallons of gas and me.... had 225lbs on left main...231 on right main..47 on tailwheel...( something close to these numbers..I forgot the sheet i used in the hangar when I came home.so this is memory , but the percentages of chord i remember well because it cause me some concern.) figured to 33% of chord...a little aft of what I had hoped for...but within the 20% to 35% spec.....then I looked at the plans agan and discovered they used 64 inches for chord...checked with a tape and mine measured 62.5...hmm....re-figured and cam out to 34.7%....dang...I just hate to be on the edge...so ..crow hops only today....BUT....when it flew out so quick and climbed so fast..I had to go around....and NOT with a lot of forward stick either...now I know this does not sound like it should be correct...but this is how it was...dang thing just flew fine.! So i went around again...and then again...I am not gonna change a thing for now! Wing Gap seal I used .018 stainless with an 3/8ths alum angle rivet to edges underneath to sit align with wing root sides. velcro'ed down on all edges, and safety wired from alum angle to cage on rear end of angle. inspiration for this style of gap seal came from this forums advice. so Since you are at this stage..I thought I might share this with you.. http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Date: Aug 11, 2003
Ken and Group, Although I wouldn't recommend it, I have seen a 582 running on an original Firestar. One problem that I see on a Firestar II is W&B. Most are already at or near the aft limit with a 503. Also, if I were thinking about it, I would want to get Dennis Souder's input. How fast are these guys cruising? My Firestar can cruise at 75 - 80 with it's 503. And that is pitched for best climb. There are ways to make a 503 go faster. A company in Wisconsin makes a perforance exhaust that can add some hp. Pitching your prop for cruise can help. The large windscreen makes a difference, as well as side panels for the back seat. John Jung ________________________________________________________________________________
From: dixieshack(at)webtv.net (Mike and Dixie Shackelford)
Date: Aug 11, 2003
Subject: Possum
Possum, could you send your phone # to my email address ?? I'll be in your area in a couple of days. Lar. Do not Archive. ________________________________________________________________________________
Date: Aug 11, 2003
Subject: Re: Possum message of Sun, 10 Aug 2003 23:56:18
>Shackelford) > >Possum, could you send your phone # to my email address ?? I'll be in >your area in a couple of days. Lar. Do not >Archive. Lar who? Not "the" Larry? Not "gogittum" Larry? ________________________________________________________________________________
Date: Aug 11, 2003
Ed.... Empty weight was 302lbs...which I'm happy with... extras included 6.00x6 tires and alum wheels..strut fairings..electric fuel pump...wet cell battery(from small ATV) gps and mount, alum storage compartment in cage behind tank..left side switch panel..battery box..extra rib braces and bow reinforcements, and polyspray uv coat..abnd who knows how much extra weight in paint! After thinking an awful lot on just where the aft weight is...id say that the paint on the tail is responsible for most of it...there is alot more tail surface to cover with paint than one would think, and the CG changes dramatically by just leaning forward in the seat..for instance...while on the scales with me in it, I leaned forward til my head hit the full enclosure windscreen, and tailwheel weight went from 47 to 41, and the % of cord changes by several % just doin this. Tail wheel arm measurement is 172.5, so a pound or 2 here makes a whole bunch of difference. Don ________________________________________________________________________________
Date: Aug 11, 2003
Subject: Re: Firefly.
You'll probably have to feed the throttle in slowly as speed increases during takeoff. We found this to be true with our FireFly with a Rotax 447. While you can hold it, it's much easier just to continue to increase power as your speed increases during the takeoff run. Once you get to the speed where your rudder is more effective, you can go to full power. We find it kind thrilling when you kick in the afterburner and away you go. jerb > >I"ve just completed a Firefly in which I installed a Hirth 2702 -40 HP >engine. This engine turns slower than a Rotax 447 by 1000 RPM. It has a >2.59 reduction gear. The engine obviously produces more torque. In taxi >tests the airplane pulls to the right so much that I have to cut the power >to stay on the runway. I have 100 hours on the engne whch I flew in my >firestar. I may be getting too much "P" factor. I would like to hear >from anyone who has used the Hirth 2702 in a Fireflyand if they have >experienced any problems. >Thanks-- George Daum > > ________________________________________________________________________________
Date: Aug 11, 2003
Subject: Re: Firefly.Hearth Vs. Rotax
I have a question does the hearth turn in the opposite direction from the Rotax ? ' Cause my firestar sure seems to pull to the Left ... Dave ________________________________________________________________________________
Date: Aug 11, 2003
Subject: FireFly Who made Fairing / GAP SEAL
Somewhere I saw a great fiberglass gap seal / Ramair for engine/fairing anyone know who made this ? Dave ________________________________________________________________________________
Subject: NPR segment on ultralights
Date: Aug 11, 2003
08/11/2003 11:58:14 AM On Sunday, NPR broadcast a segment on Arty Trost and her ultralight adventures - You can hear a replay from their website: http://www.npr.org/display_pages/features/feature_1386557.html There was also a short segment about ultralights on CNN during Oshkosh. Nice to see some favorable press coverage. Regards to all. Erich Weaver ________________________________________________________________________________
Date: Aug 11, 2003
Subject: :
) spelling Thanks guys ! Youall made my day .... I really should check a wee bit closer ...lol Dave ________________________________________________________________________________
Date: Aug 11, 2003
Maybe you need to strap that BMW to the top - it should really turn then. jerb > >I have a question does the hearth turn in the opposite direction from the >Rotax ? ' Cause my firestar sure seems to pull to the Left ... Dave > > ________________________________________________________________________________
Date: Aug 11, 2003
Some Hurths I know didn't turn for very long at all. jerb 8 ) > >I have a question does the hearth turn in the opposite direction from the >Rotax ? ' Cause my firestar sure seems to pull to the Left ... Dave > > ________________________________________________________________________________
Date: Aug 11, 2003
Subject: Re: Airmap 100
At 04:59 PM 8/11/2003, you wrote: > > Hey Guys, > I forgot who it was that told us about the airmap 100 > at only 229.00 > But, THANKS !!! I've been eyeing that thing for quite a while.... I > called them up to find out if they were some kind of " > RETURNS or SECONDS " .....their brand NEW , So I had to jump on > it..... The power cord cost me 10.00 more....still, what a deal. They're selling them so low because there are two new models coming out ... one, the AirMap 500, is already out, I believe. The other one, the AirMap 1000, will be out late this year. Both have bigger screens, use non-proprietary memory cards for the databases, and will use WAAS if found. Luckily, the lawyers did NOT succeed in intimidating Lowrance for the obstructions databases are still there, thank goodness! Both models are shown on the Lowrance web site. I've had an AirMap 100 for 2 years and love it. -- Robert ________________________________________________________________________________
Date: Aug 11, 2003
Hey, John, Thanks for the response. Do you know if that 582 configuration is still flying, who did it, where it is and how I can reach that person? I'd go to some trouble to reach him. The weight and balance may not be an issue at all. The 503 UL DCDI weighs in at 69 pounds and the 582 is only 60.4 pounds; from the Rotax Operators' Manual each a dry weight and without exhaust or radiator. When I built my Powered Parachute, the radiator, hoses and water weighted in at a little over 10 pounds, so the operating weight of the 503 and the 582 is roughly the same. Strategic placement of the radiator will actually help the aft CG problem. How do you get a 75 to 80 MPH cruise out of your 503 powered FireStar? With a fresh wax job, nearly empty fuel tanks, wheel pants and me half starved, mine will only do 85 at WOT. I went to a lot of trouble to calibrate my airspeed indicator, so I know for sure I'm going slower than you. What's your beauty secret? Ken Korenek FireStar #438 N104KK johnjung(at)compusenior.com wrote: > >Ken and Group, > >Although I wouldn't recommend it, I have seen a 582 running on an original Firestar. > >One problem that I see on a Firestar II is W&B. Most are already at or near the aft >limit with a 503. > >Also, if I were thinking about it, I would want to get Dennis Souder's input. > >How fast are these guys cruising? My Firestar can cruise at 75 - 80 with it's 503. >And that is pitched for best climb. > >There are ways to make a 503 go faster. A company in Wisconsin makes a perforance >exhaust that can add some hp. Pitching your prop for cruise can help. The large >windscreen makes a difference, as well as side panels for the back seat. > >John Jung > > > > ________________________________________________________________________________
Date: Aug 11, 2003
> > Some Hurths I know didn't turn for very long at all. > jerb 8 > ) > Ya know I keep hearing stuff like that but when I ask for examples there are none. I can't imagine ever hearing about a Rotax quitting. Just not possible I guess. Them Hirths just give up every 5 minutes. I own a magic Hirth and so does a friend. Both keep running smoothly. Must be a lot of these magic HIrths out there because I haven't heard a first hand account of a Hirth just giving up and failing. HIirth and Rotax both turn the same direction. ________________________________________________________________________________
Date: Aug 11, 2003
Subject: olb-List:Hearth Vs. Hirth
Boy was I tired when I posted thay one : ) still cant figure out why the firestar pulls to the left ... Dave ________________________________________________________________________________
Date: Aug 12, 2003
Subject: Re: FireFly Gap Seal
Jerb, I was speaking of the gap seal between the wings & above the pilot. Ed (in Houston) ________________________________________________________________________________
Date: Aug 12, 2003
Subject: Re: FireFly Chute
Jerb, I hate to sound dumb, but I have a BRS chute. It is called a soft pack. Is that similar to a VLS? Also is your seal made of fabric or aluminum. Bill Tuton sent me some good pictures of his nicely painted aluminum gap seal. I think he has the cannister BRS. I want to use aluminum if I can. I think I heard where someone put a hinge on the aluminum gap seal on a firestar. Im going to explore that . I just dont want to rig it up and it not work IF I ever needed it. Ed (in Houston) ________________________________________________________________________________
Subject: Re: : Kolb-List:Hearth Vs. Hirth
Date: Aug 12, 2003
----- Original Message ----- From: <BMWBikeCrz(at)aol.com> Subject: Kolb-List:Hearth Vs. Hirth > > Boy was I tired when I posted thay one : > ) still cant figure out why the > firestar pulls to the left ... Dave Dave, I would think the left turn tendancy under power would be expected from the engine and props P factor. Just like a General Aviation aircraft needs right rudder to keep it straight especially on climb out. What I can't figure out is why my Mk-3 needs left rudder to fly straight under power, seems bass ackwards to me. The pusher configuration and gearbox should give us the same effect as a tractor mounted non reduction engine. Wouldn't you think? Sincerely, Denny (cornfused and sick of rain) Rowe Mk-3 N616DR, 2SI 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Aug 12, 2003
Don, What a beautiful job you have done on you aircraft and congratulations on your first flight. I was at the Kolb fly in last fall and saw what you had on the trailer and all of those parts in boxes. What a transformation ! "IT's ALIVE". Fly Safe Bob Griffin ________________________________________________________________________________
Date: Aug 12, 2003
> I would think the left turn tendancy under power would be expected > from the engine and props P factor. Just like a General Aviation > aircraft needs right rudder to keep it straight especially on climb > out. Partially...and the fact that the rotational vortex of the pusher is clockwise (looking from aft of acft) thus impinging vertical stab on right causing left rudder application to compensate. Notice that the plans never call for vertical stab offset and then take a look at other gerneral aviation aircraft's vertical stab and you'll see the off set designed into the aircraft. I asked Kolb about this when building but was waived off from incorporating any offset. Should have done it anyway. J.Baker ________________________________________________________________________________
Date: Aug 12, 2003
Notice that the > plans never call for vertical stab offset and then take a look at other > gerneral aviation aircraft's vertical stab and you'll see the off set > designed into the aircraft. I asked Kolb about this when building but > was waived off from incorporating any offset. Should have done it > anyway. > > J.Baker J. Baker/All: Check the Kolb List Archives. Probably find info on my experimentation with offset leading edge, vert stab. For many years tried to get old Kolb to do the experimentation to save the drilling and riveting of my airplane. After about 850 hours of flying about a half bubble out, I decided to bite the bullet and do my own. Tried 3/4 inch and finally 1 3/8 inch offset. Helped some. Many hours later discovered the offset was useless and shortened the life of the upper vertical stabilizer tremendously. How did I find out? Lost my one rib bay wide trim tab on takeoff. MK III did a great big yaw to the left. When I landed I discovered the rudder trim tab missing. That told me the mod to the vert stab was ineffective. Started experimenting with rudder trim tab again. Started out 3 rib bays wide. Too much, overkill. Cut down to 2 rib bays wide. Ahhhhhhh............just right!!! First time I ever flew my MK III without a lot of right pedal to offset left yaw tendancy. I believe as a result of the offset, the vert stab came apart on two occasions in short succession. john h ________________________________________________________________________________
Subject: wings
Date: Aug 12, 2003
I am buying a Fire star one with five rib wings and 377. when I looked at it and we folded the wings I heard something rolling around inside the wing(maybe rivets). There is no inspection panels in the wings but they look good, what can some of you more experienced Kolbers tell me about this? Bryan Green (Elgin SC) ________________________________________________________________________________
Date: Aug 12, 2003
Subject: wings
Bryan, Just this past weekend I removed the covering from a 1985 Firestar with the 5 rib setup and found several things that were rolling around in there. There were sounds coming from the tubes that sounded like B-Bs. It was just pieces of zillions of rivets that come apart when it was first built(Normal). Then I found outboard braces connecting the wing-bow had come apart on both wings where a one rivet attaches it to the spar. I also found that these pieces had been loose for a long time because they had vibrated against another tube brace and practically cut it in half. If you tap the underside of the outboard tips of your wings and hear a metal-to-metal sound you may have the same problem. I found several pop tops from 1985 and they were most probably Budweiser. Then there were the dirt dobbers mud nest. Now if they come loose you will hear a real racket that doesn't sound quite like the rivet sound. If you really want see inside the wing just pull back some fabric at the inboard wing bracket where it attaches to the cage. You can see a lot from one end looking down to the other end. If you see an old beer can or something that doesn't belong in there, better suspect broken parts and a world of grief. From experience, George Murphy -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of bryan green Subject: Kolb-List: wings I am buying a Fire star one with five rib wings and 377. when I looked at it and we folded the wings I heard something rolling around inside the wing(maybe rivets). There is no inspection panels in the wings but they look good, what can some of you more experienced Kolbers tell me about this? Bryan Green (Elgin SC) ________________________________________________________________________________
Subject: Re: wings
Date: Aug 12, 2003
It's probably rivits or stones picked up through the front spar tube as it was being moved with the wings folded. ----- Original Message ----- From: "bryan green" <lgreen1(at)sc.rr.com> Subject: Kolb-List: wings > > I am buying a Fire star one with five rib wings and 377. when I looked at it and we folded the wings I heard something rolling around inside the wing(maybe rivets). There is no inspection panels in the wings but they look good, what can some of you more experienced Kolbers tell me about this? > Bryan Green (Elgin SC) > > ________________________________________________________________________________
Subject: Re: Travelin' Lar...... message of Sun, 10 Aug 2003 23:56:18
Date: Aug 12, 2003
Looks like I will be in your neck of the woods buying a car next week. When ya getting home. ________________________________________________________________________________
Date: Aug 12, 2003
Subject: Landing Gear Spindle Specs
I am in the process of rebuilding my firestar lading gear the spindles mic out .625 but the inside dimensions of the bearings are .750 and a sleeve was used are there spindles available which are .750 or as I am planning buy correct bearings that do not require a spacer ... Dave ________________________________________________________________________________
Subject: Re: wings
Date: Aug 12, 2003
Thanks George maybe if I find A beer can it will at least be a lite beer. Bryan Green (Elgin SC) ----- Original Message ----- From: "george murphy" <geomurphy(at)direcway.com> Subject: RE: Kolb-List: wings > > Bryan, Just this past weekend I removed the covering from a 1985 Firestar > with the 5 rib setup and found several things that were rolling around in > there. There were sounds coming from the tubes that sounded like B-Bs. It > was just pieces of zillions of rivets that come apart when it was first > built(Normal). Then I found outboard braces connecting the wing-bow had > come apart on both wings where a one rivet attaches it to the spar. I also > found that these pieces had been loose for a long time because they had > vibrated against another tube brace and practically cut it in half. If you > tap the underside of the outboard tips of your wings and hear a > metal-to-metal sound you may have the same problem. I found several pop > tops from 1985 and they were most probably Budweiser. Then there were the > dirt dobbers mud nest. Now if they come loose you will hear a real racket > that doesn't sound quite like the rivet sound. If you really want see inside > the wing just pull back some fabric at the inboard wing bracket where it > attaches to the cage. You can see a lot from one end looking down to the > other end. If you see an old beer can or something that doesn't belong in > there, better suspect broken parts and a world of grief. > From experience, George Murphy > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of bryan green > To: kolb-list(at)matronics.com > Subject: Kolb-List: wings > > > I am buying a Fire star one with five rib wings and 377. when I looked at it > and we folded the wings I heard something rolling around inside the > wing(maybe rivets). There is no inspection panels in the wings but they look > good, what can some of you more experienced Kolbers tell me about this? > Bryan Green (Elgin SC) > > ________________________________________________________________________________
Subject: Re: wings
Date: Aug 12, 2003
Thank you Woody. Bryan Green (Elgin SC) ----- Original Message ----- From: "Woody" <duesouth(at)govital.net> Subject: Re: Kolb-List: wings > > It's probably rivits or stones picked up through the front spar tube as it > was being moved with the wings folded. > ----- Original Message ----- > From: "bryan green" <lgreen1(at)sc.rr.com> > To: > Subject: Kolb-List: wings > > > > > > I am buying a Fire star one with five rib wings and 377. when I looked at > it and we folded the wings I heard something rolling around inside the > wing(maybe rivets). There is no inspection panels in the wings but they look > good, what can some of you more experienced Kolbers tell me about this? > > Bryan Green (Elgin SC) > > > > > > ________________________________________________________________________________
Date: Aug 12, 2003
Subject: Re: wings
My wings do the same thing ...In Florida its gotta be Dirt Daubbers .... guess I should put some kind of plug in those open tubes .................................................... Dave ________________________________________________________________________________
Date: Aug 12, 2003
I know someone with a used 582!! MEM FSII ________________________________________________________________________________
Date: Aug 12, 2003
Congratulations! You have a mighty fine bird. I really enjoy mine. Many happy flights. Merle > > > Mission accomplished! > Today I flew the Firefly...or "FlagFly" as some of you have started to call > her!....WOW...what a beauty...perfect handleing....no bad habits , Just as > you told me John Hauck! I had trim tabs ready to mount....but I threw em > back in the toolbox as it just does not need any! First time was gonna be a > few crowhops..but it cliombed out so dang fast...I just went around...landed > a tad hard with one bounce..went around again and 2nd landing was a little > better....3rd landing I greased her in..probably lucky, but dang I was so > proud I stopped and taxi'd over to the hanger where the lookers were and got > out to see if anything had loosened up...and of course to hear the > compliments from the gallery....back up for a little cruise...Airspeed > indicator is way off and thats the only gripe I could write down... > > all you Kolber's were right, this is one Dandy little airplane...special > thanks to John H for the check ride, and all of you fellas for the sharing > of knowledge that has no doubt contributed to a perfect first flight! > > http://www.geocities.com/dagger369th/my_firefly.htm > Don Gherardini- > FireFly 098 > ________________________________________________________________________________
Date: Aug 12, 2003
Yea, and I know someone with a perfectly good set of 5 rib wings in storage! Ken Korenek N104KK MEMATUZAK(at)aol.com wrote: > >I know someone with a used 582!! > >MEM >FSII > > > > ________________________________________________________________________________
From: "John Williamson" <kolbrapilot(at)comcast.net>
Subject: Who are you people?
Date: Aug 12, 2003
Fellow Kolb List posters, If you post to this list please follow the guidelines set up by Matt Dralle dralle(at)matronics.com. The following is what is requested and posted each month to this List: ****************************************************************************** Kolb-List Usage Guidelines ****************************************************************************** - Keep your signature brief. Please include your name, email address, aircraft type/tail number, and geographic location. A short line about where you are in the building process is also nice. Avoid bulky signatures with character graphics; they consume unnecessary space in the archive. For those of us that don't personally know you it is very helpful in our evaluation of your input if we know who or what you are and what you are doing. John Williamson Arlington, TX Kolb Kolbra, N49KK, Jabiru 2200, 440 hours http://home.comcast.net/~kolbrapilot ________________________________________________________________________________
Date: Aug 12, 2003
Subject: parts list for 1985 Firestar
Does anyone have a copy of the parts list for a 1985 Firestar. I have a Xerox copy but It is unreadable. I am having to replace several tubes and AN nuts and bolts. I would appreciate a copy e-mailed to me and then I may be able to enlarge it enough to read. My offline E-mail is geomurphy(at)direcway.com Thanks, G. Murphy ________________________________________________________________________________
Date: Aug 13, 2003
Subject: Fwd: UL: Airport theft
>X-eGroups-Return: >sentto-371046-46345-1060751111-ulflyer=verizon.net(at)returns.groups.yahoo.com >X-Sender: mark(at)ultrapilot.com >X-Apparently-To: FLY-UL(at)yahoogroups.com >To: FLY-UL(at)yahoogroups.com >X-Mailer: Yahoo Groups Message Poster >From: "Mark A. Carter" <mark(at)ultrapilot.com> >X-Originating-IP: 67.123.145.65 >X-Yahoo-Profile: fly_ultralight >Mailing-List: list FLY-UL(at)yahoogroups.com; contact >FLY-UL-owner(at)yahoogroups.com >Delivered-To: mailing list FLY-UL(at)yahoogroups.com >List-Unsubscribe: >Date: Wed, 13 Aug 2003 05:05:10 -0000 >Subject: UL: Airport theft >Reply-To: FLY-UL(at)yahoogroups.com > >This past weekend the Turlock Airpark, in Turlock California >experienced a burglary. The TV, VCR and TV stand were stolen from >the club house. Additionally, John Fletcher had 5 radios and some >other items stolen from his office. > >Be on the look out for anyone attempting to sell Yaesu / Vertex hand >held radios! > >If you have any information please contact John Fletcher at >Fletcher's Ultralights 209-667-4397. > > >ADVERTISEMENT ><http://rd.yahoo.com/M=259538.3705203.4965331.1261774/D=egroupweb/S=1705065618:HM/A=1712983/R=0/SIG=11u38u3s2/*http://hits.411web.com/cgi-bin/hit?page=1374-105951838331032>730954.jpg >7309a6.jpg > ________________________________________________________________________________
Date: Aug 14, 2003
Subject: slow progress
Kolbers, a pic of my plane made it to the owner's album at the TNK site. Getting back to it, I had to iron out an ignition bug, everything seemed ok so yesterday taxi tests resumed. Then I started getting off idle hesitation and roughness, don't know whether it was the extreme humidity or something physical but if it doesn't clear up I'll disassemble the carb for a looksee. Had it to flying speed with some long crowhops, handled very well, no surprises or squirllyness. Nothing scheduled today but a hot air balloon ride this evening with a toast to Montgolfier at the landing. -BB do not archive ________________________________________________________________________________
Date: Aug 14, 2003
Can't win for losing, can we ?? I'll be on the road for at least another 2 weeks. What are you buying, and where is it ?? Can you stall them for a bit ?? Lar. Larry Bourne Palm Springs, CA Kolb Mk III - Vamoose N78LB www.gogittum.com ----- Original Message ----- From: "Woody" <duesouth(at)govital.net> Subject: Re: Kolb-List: Travelin' Lar...... message of Sun, 10 Aug 2003 > > > Looks like I will be in your neck of the woods buying a car next week. > When ya getting home. > > ________________________________________________________________________________
Subject: Rotax lighting coil
Date: Aug 14, 2003
Hello, Does anyone know where I can get a used lighting coil for my Rotax 447? This disappointing search is made necessary by a Key West Control regulator that failed and burned out my lighting coil. The Key West regulator is a shunt-type regulator that reduces the output voltage by drawing so much current that it pulls down the voltage from the coil. Well, my regulator overheated, turned black, shorted internally, then drew so much current from the lighting coil that it fried the coil too. I suggest we stear clear of Key West regulators....a new lighting coil costs $340...too expensive to take the risk. My FireFly was really smokin'! Bruce McElhoe FireFly #88 12 hrs TT Reedley, California ________________________________________________________________________________
Date: Aug 14, 2003
75 Rolls. 69000 miles. This is my vacation time so I will be flying to L.A.(commercial) and driving it home. Should be a nice trip ----- Original Message ----- From: "Larry Bourne" <biglar(at)gogittum.com> Subject: Re: Kolb-List: Travelin' Lar...... message of Sun, 10 Aug 2003 > > Can't win for losing, can we ?? I'll be on the road for at least another 2 > weeks. What are you buying, and where is it ?? Can you stall them for a > bit ?? Lar. > > Larry Bourne > Palm Springs, CA > Kolb Mk III - Vamoose N78LB > www.gogittum.com > > ----- Original Message ----- > From: "Woody" <duesouth(at)govital.net> > To: > Subject: Re: Kolb-List: Travelin' Lar...... message of Sun, 10 Aug 2003 > > > > > > > > Looks like I will be in your neck of the woods buying a car next week. > > When ya getting home. > > > > > > ________________________________________________________________________________
Date: Aug 14, 2003
Subject: [ George Murphy ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: George Murphy Subject: Tube Support for Kolb http://www.matronics.com/photoshare/geomurphy@direcway.com.08.14.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject:
Date: Aug 14, 2003
Looking to purchase a Mk111 within California Rob ________________________________________________________________________________
Date: Aug 14, 2003
Subject: Re: Rotax lighting coil
> >Hello, > >Does anyone know where I can get a used lighting coil for my Rotax 447? > >This disappointing search is made necessary by a Key West Control regulator that failed and burned out my lighting coil. The Key West regulator is a shunt-type regulator that reduces the output voltage by drawing so much current that it pulls down the voltage from the coil. Well, my regulator overheated, turned black, shorted internally, then drew so much current from the lighting coil that it fried the coil too. > >I suggest we stear clear of Key West regulators....a new lighting coil costs $340...too expensive to take the risk. > >My FireFly was really smokin'! > >Bruce McElhoe FireFly #88 12 hrs TT >Reedley, California > Bruce, It would not hurt to put a 10 to 12 ampere fuse in series with the lighting coil. It is good insurance that no matter what regulator you are going to use and if it fails, you will not have to put out another $300+ for a lighting coil. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Aug 14, 2003
> >Does anyone know where I can get a used lighting coil for my Rotax 447? > > > >This disappointing search is made necessary by a Key West Control regulator that failed and burned out my lighting coil. The Key West regulator is a shunt-type regulator that reduces the output voltage by drawing so much current that it pulls down the voltage from the coil. Well, my regulator overheated, turned black, shorted internally, then drew so much current from the lighting coil that it fried the coil too. > > > >I suggest we stear clear of Key West regulators....a new lighting coil costs $340...too expensive to take the risk. > > > >My FireFly was really smokin'! > > > >Bruce McElhoe FireFly #88 12 hrs TT That must be what my regulator is on my 447 but can't find a number or name on it.. I put a 10 amp breaker in front of it and it still trips. Fortunately my lighting coil is still good but I'm getting the Rotax regulator. Kirk ________________________________________________________________________________
Subject: Re: order
Date: Aug 14, 2003
Paul Good choice. I haven't flown a Kolbra but I had a chance to fly next to John Williamson's super Kolbra into Oshkosh. It appears to be a fast super flying airplane. I will be available at any point to assist in your quest to install a VW on that bird. The first thing I will need to say is that you will be much happier with the completed airplane if you modify the engine mount to allow the VW engine to mounted lower. My VW on my MKIII is mounted over the stock Rotax mount on the cage. This causes the prop to be much higher than ideal. I currently have seven inches of clearance between the prop and the boom tube with my 72 inch prop. I took some photos of a MKIII extra at Oshkosh that had the cage modified to except a Raven GEO engine with a lower mounting (with some modifications the VW would fit nicely) that I can send you if you like. Also I talked to the guys at Kolb about a custom mod. to the cage if I decided to update to a MKIII extra with a better VW mount. They seemed agreeable if I sent drawings of what I wanted. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "Paul Petty" <ppetty@c-gate.net> Subject: Kolb-List: order > > Hi Kolbers, > Been a while since I've posted a remark. Fact is I've been waiting on the money from the sale of the Harley. Well it comes in tomorrow and I spoke to Linda at TNK factory and signed the release forms and are going to send them the check for my very own Kolb. Finally decided on the King Kolbra! Going with a VW for first engine. So if any care to share thoughts on that fire for effect! > ________________________________________________________________________________
Subject: Hirth
Date: Aug 14, 2003
There is a long post on the Texas flyer web site about a Hirth that seized the crank. The post doesn't specify Hirth so I enquired. Indeed it was a Hirth. I suspected Hirth when the post said the mfg. provided a "FREE" crank. That doesn't sound like Rotax now does it. Bill in Lousyana http://wwwTexas-flyer.com/Texas-flyer/ ________________________________________________________________________________
Date: Aug 14, 2003
Subject: Re: Hirth
At 05:26 PM 8/14/2003, you wrote: > >There is a long post on the Texas flyer web site about a Hirth that seized >the crank. The post doesn't specify Hirth so I enquired. Indeed it was a >Hirth. I suspected Hirth when the post said the mfg. provided a "FREE" >crank. That doesn't sound like Rotax now does it. Bill in Lousyana >http://wwwTexas-flyer.com/Texas-flyer/ Bill and all -- Yes, it was a Hirth engine, and the crank did fail in flight causing the forced landing. But Hirth replaced the crank and the pilot (my brother) has had over 100 happy hours with it so far with zero problems. I'd say, give 'em the benefit of the doubt since they did replace it gratis and it hasn't given any problems since. If I had to buy an ultralight engine right now, I'd *also* be looking at the HKS because I think a 4-stroke engine is better at longevity and fuel consumption (plus it's not throwing all that nasty oil into the air). I don't know much about the HKS besides the published specs, but I'd like to learn. Anyone know much about it? -- Robert P.S. You forgot a period in the URL... this one will work: http://Texas-Flyer.com ________________________________________________________________________________
Subject: Too much clearance to boom tube?
Date: Aug 15, 2003
08/15/2003 11:07:34 AM >From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> >Subject: Re: Kolb-List: order >Paul >Good choice. I haven't flown a Kolbra but I had a chance to fly next to John >Williamson's super Kolbra into Oshkosh. It appears to be a fast super flying >airplane. I will be available at any point to assist in your quest to >install a VW on that bird. The first thing I will need to say is that you >will be much happier with the completed airplane if you modify the engine >mount to allow the VW engine to mounted lower. My VW on my MKIII is mounted >over the stock Rotax mount on the cage. This causes the prop to be much >higher than ideal. I currently have seven inches of clearance between the >prop and the boom tube with my 72 inch prop. This caught my attention. What is wrong with too much clearance? I have read between the lines that the Kolbs with higher props are running in cleaner air, and so gain some efficiency. I understand that the thrust would also cause a pitch change. Is there any other reason? I ask because I am at the stage of determining the overall height of my new setup; BMW r100/"C"box/66"or 68"Powerfin on Kolb Mkiii. Any and all input is welcome. Thanks! Jim Gerken ________________________________________________________________________________
Subject: Re: Too much clearance to boom tube?
Date: Aug 15, 2003
You can't have too much clearance (I only meant to use clearance as a reference point) but you can have too high a thrust line. It is much more than just a pitch change. With full power and lower speeds, too high a thrust line will overpower the elevator and not allow you to climb. I go over and over it in my head if I land with flaps and I have to go around I MUST raise the flaps first before adding power or the high thrust line will drive me into the ground. Now the thrust of the BMW may not be as much of a problem since you are only turning a 66-68" prop. My 2180cc redrive VW swinging a three bladed 72" F Powerfin has a really large impact on pitch. Generally speaking, the lower the thrust line you can get the better these (non ultra star) Kolbs will handle. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "Jim Gerken" <gerken(at)us.ibm.com> Subject: Kolb-List: Too much clearance to boom tube? > > > >From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> > >Subject: Re: Kolb-List: order > > > > >Paul > > >Good choice. I haven't flown a Kolbra but I had a chance to fly next to > John > >Williamson's super Kolbra into Oshkosh. It appears to be a fast super > flying > >airplane. I will be available at any point to assist in your quest to > >install a VW on that bird. The first thing I will need to say is that you > >will be much happier with the completed airplane if you modify the engine > >mount to allow the VW engine to mounted lower. My VW on my MKIII is > mounted > >over the stock Rotax mount on the cage. This causes the prop to be much > >higher than ideal. I currently have seven inches of clearance between the > >prop and the boom tube with my 72 inch prop. > > This caught my attention. What is wrong with too much clearance? I have > read between the lines that the Kolbs with higher props are running in > cleaner air, and so gain some efficiency. I understand that the thrust > would also cause a pitch change. Is there any other reason? I ask because > I am at the stage of determining the overall height of my new setup; BMW > r100/"C"box/66"or 68"Powerfin on Kolb Mkiii. Any and all input is welcome. > Thanks! > > Jim Gerken > > ________________________________________________________________________________
Date: Aug 15, 2003
> Generally speaking, the lower the thrust line you can get the better these > (non ultra star) Kolbs will handle. > > Rick Neilsen Rick/All: I agree. And include perform. Increased thrust on my MK III and a 72 inch 3 blade Warp Drive prop caused me concern on my initial takeoffs during testing of the new 912S engine. I cut the 72" prop down to 70" and still can get into a situation, especially noticeable on pavement, where the airplane wants to stick to the pavement during early stages of takeoff. At these speeds with an inch or so lower thrust line and 80 hp, I did not encounter this quirk. When time comes for new engine mounts, the 912S will be lowered to within 3/4 to 1" of the tailboom, engine off. It makes that much difference. Imagine a long handle attached perpendicular to the tail boom, and you have a picture of what is happening when you pour on the coal. Thrust is trying to push the nose down and pull the tail up. Another good example of high thrust line degrading performance is an inside loop with an original Firestar. Full power loops were more difficult than partial power. Pulling the nose up into a loop after accelerating through a dive sacrifices a lot of airspeed at WOT. Come back on the power and she will go up and over the top with no problem. BEWARE: My airplanes don't fly like this since I wore out the wings of the Firestar 13+ years ago. john h ________________________________________________________________________________
From: "Jim and Phyllis Hefner" <hefners_tucson(at)hotmail.com>
Date: Aug 15, 2003
Bruce, all I've got 150hrs on my Key West, which is driving 2 self contained strobes, an elec fuel pump, 2 20w landing lightsand a bunch of instruments and have never had the first problem, so you must have gotten a lemon or had a wiring problem... haven't heard of other problems with them... probably should search the archives before concluding we all should steer clear of them... did you have a fuse installed? ....shouldn't have burned out your lighting coil.... I have a 15a fuse on mine. Jim Hefner Tucson, AZ FF#022 Rotax 447, IVO 66" 2-blade, BRS-750, 150hrs TT (105 -my hrs) -- Kolb-List message posted by: "Bruce McElhoe" mcelhoe@cvip.net Hello, Does anyone know where I can get a used lighting coil for my Rotax 447? This disappointing search is made necessary by a Key West Control regulator that failed and burned out my lighting coil. The Key West regulator is a shunt-type regulator that reduces the output voltage by drawing so much current that it pulls down the voltage from the coil. Well, my regulator overheated, turned black, shorted internally, then drew so much current from the lighting coil that it fried the coil too. I suggest we stear clear of Key West regulators....a new lighting coil costs $340...too expensive to take the risk. My FireFly was really smokin'! Bruce McElhoe FireFly #88 12 hrs TT Reedley, California ________________________________________________________________________________
Date: Aug 15, 2003
Let's take a market survey. I had suggested to Mr. Kuntzleman the strobe manufacturer that he seriously consider producing a voltage regulator that puts out more than the 1-3 amps most others do with exception of the Key West which can source 10 amps. He suggested his hot box which has the same 3 amp capacity limit. Haven't heard a thing about it since. So how many would purchase a regulator that could handle 10 amps and what would you be willing to pay. Understand that it would likely require a switching supply versus a analog linear design. This might push the unit cost up a little more than the Key West. Another product I was considering would be light weight aluminum wrench sized to fix the nut on the IVO quick adjustment mechanism. Being small and light they would be good to carry with you. Any one interested? jerb > >Hello, > >Does anyone know where I can get a used lighting coil for my Rotax 447? > >This disappointing search is made necessary by a Key West Control >regulator that failed and burned out my lighting coil. The Key West >regulator is a shunt-type regulator that reduces the output voltage by >drawing so much current that it pulls down the voltage from the >coil. Well, my regulator overheated, turned black, shorted internally, >then drew so much current from the lighting coil that it fried the coil too. > >I suggest we stear clear of Key West regulators....a new lighting coil >costs $340...too expensive to take the risk. > >My FireFly was really smokin'! > >Bruce McElhoe FireFly #88 12 hrs TT >Reedley, California > > ________________________________________________________________________________
Date: Aug 15, 2003
Subject: Book Binding Tape - Another Alternative
Folks, Below is message posted on the UL list. It provides information about an alternative UV resistant tape that maybe an alterative to the book binding tape for use on Kolb control surface gap seals. jerb >X-Sender: ken.kennedy(at)sympatico.ca >X-Apparently-To: fly-ul(at)yahoogroups.com >Organization: RCAF RETIRED >From: Ken Kennedy <ken.kennedy(at)sympatico.ca> > >While on the subject of Lazairs, this is to remind Canadian Ullies to >attend the UPAC AGM this weekend, where Lazairs will be featured. You >will be able to recognize me by my Fly-UL Tshirt and the BIG smile >caused by the arrival of my very first grandchild yesterday morning >(BOY! both are fine). If all goes well, I will be arriving in a two seat >Carrera and camping overnight. > ><<
http://www.upac.ca/>http://www.upac.ca/> > >I don't know much about Lazairs and Tedlar, however I seem to recall >that tape deterioration was/(is?) a problem. I just received my July Lee >Valley Gardening Tools catalog. In it, they hype their UV Resistant Clear >Tape. FMI; > ><<http://www.leevalley.com/home/main.asp>http://www.leevalley.com/home/main.asp>, >jump to item# PM215 > > From the website; > >"UV-Resistant Tape PM215 C$6.50 U$4.75" > >"This is an excellent transparent tape for outdoor use." >"Made from UV-resistant plastic and UV-resistant acrylic adhesive, it >won't break down in the sunlight and is perfect for patching greenhouse >plastic (it's waterproof and will outlast the greenhouse plastic >itself), taping windows or bundling products for outdoor storage." > >"Unlike most other tapes, the adhesive will not come off the tape and >stick to bundled items even when left outdoors in full sunlight for a >year or more." > >"2" x 100' roll. Although it looks green in the roll it is virtually >clear when applied." > >PER ARDUA AD ASTRA > > >UV-Resistant Tape >PM215 $ 6.50 ________________________________________________________________________________
Date: Aug 15, 2003
Jim, & All Which side is your fuse, the lighting coil side of the regulator or the DC output side? I have one plane with 150 hours and another with 105. No problems so far. There are a large number of these units in use and I haven't seen any track record to indicate there is a problem. I would prefer an active regulator but need something that can handle more than the 1-3 amps typical of the others models on the market. The reason I desire the active regulator is the shunt regulator places a large load upon the engine all the time while the active would only load the engine by the amount of electrical power being demanded. It's like driving your car while riding the brake pedal. I am running a radio, GPS, EIS, dual head strobes, and (2) 35W driving lights on a wig-wag flasher (a neat little device) as recognition lights. jerb > > >Bruce, all > >I've got 150hrs on my Key West, which is driving 2 self contained strobes, >an elec fuel pump, 2 20w landing lightsand a bunch of instruments and have >never had the first problem, so you must have gotten a lemon or had a >wiring problem... haven't heard of other problems with them... probably >should search the archives before concluding we all should steer clear of >them... did you have a fuse installed? ....shouldn't have burned out your >lighting coil.... I have a 15a fuse on mine. > >Jim Hefner >Tucson, AZ >FF#022 Rotax 447, IVO 66" 2-blade, BRS-750, 150hrs TT (105 -my hrs) > >-- Kolb-List message posted by: "Bruce McElhoe" href="http://lw9fd.law9.hotmail.msn.com/cgi-bin/compose?curmbox=F000000001a=e084d4bda659a76f0afdbab4f3703f23mailto=1to=mcelhoe@cvip.netmsg=MSG1060931500.28start=2478979len=21300src=type=x">mcelhoe@cvip.net > >Hello, > >Does anyone know where I can get a used lighting coil for my Rotax 447? > >This disappointing search is made necessary by a Key West Control >regulator that >failed and burned out my lighting coil. The Key West regulator is a shunt-type >regulator that reduces the output voltage by drawing so much current that >it pulls down the voltage from the coil. Well, my regulator overheated, turned >black, shorted internally, then drew so much current from the lighting coil >that it fried the coil too. > >I suggest we stear clear of Key West regulators....a new lighting coil costs >$340...too >expensive to take the risk. > >My FireFly was really smokin'! > >Bruce McElhoe FireFly #88 12 hrs TT >Reedley, California > > ________________________________________________________________________________
Subject: Getting there
Date: Aug 15, 2003
Kolbers, After being ground bound for two weeks by weather and chores, I got a chance to fly my Mk-3 again tonight. The latest prop and carb adjustments have it closer to where I want it. I put .8 hours on her and actually left the pattern and flew over to my neighborhood to show it off. My friend Don Stroble christened my airstrip by being the first to land here. I got a nice surprise when I flew over and saw him in my old Pterodactyl setting in the middle of the strip with my family gathered around it. I am not yet ready to land the Kolb in such a tight spot so I just circled and than flew over to some friends houses and put on a little airshow for them. Had two more landings that were just the way I like em and than called it a day. All in all it was a very satisfying flight. Denny Rowe Mk-3 N616DR, 2SI 690L-70, 8.3hrs, Western PA ________________________________________________________________________________
Date: Aug 15, 2003
> >Jim, & All >Which side is your fuse, the lighting coil side of the regulator or the DC >output side? > Jerb, To save the lighting coil, the fuse needs to be placed on the lighting coil side of the regulator. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Aug 16, 2003
Subject: FireStar II
I am looking for a complete set of plans for a FireStar II. I have not called Kolb yet to see if they will sell them, but thought I would first check the group to see if there were any avialable. -- Roger Peterson 206 County Road 375 Sweeny, Texas 77480 Phone:979-647-4946 Cell: 979-487-8356 Fax: 979-647-1158 E-Mail:
roger@pmmi-inc.com Bus Home Page: http://pmmi-inc.com Personal Home Page: http://joinme.net/petersons/ ________________________________________________________________________________
Subject: Drag strut brace / Quality of parts
Date: Aug 16, 2003
Hi All, I'm building a set of 7 rib wings for my 86 Firestar. About a month ago I posted a message saying I had a problem with the quality of parts supplied by TNK. Why don't I start at the beginning. I bought all the steel parts from TNK. When they arrived I finished off the rough edges and painted them with epoxy paint. First the H sections were so far out of square they couldn't be used. They had to be sent back. The inboard wing ribs were next. They too were not square and had to be sent back. When the replacements arrived one was ok, the other one had the drag strut brace tube welded in at the wrong angle. That went back. The replacement had the same problem. The drag strut tube was welded off to the side and down from the correct angle but is barely acceptable. So a month ago I go to install the drag strut and find the legs on the short drag strut brace are too long to fit properly and they were welded a few degrees off from the correct angle. I mentioned this on the list and a member suggested I send them back because they probably go to the firefly wing. Well, I got the same ones back with a note saying if the legs are too long they should be cut to the correct length by the builder. How would I know if they were too long until I arrived at this stage of assembly? Does this mean I can't paint all the pieces at one time? I have to adjust and paint each piece one at a time as I go? Cutting the legs is not a problem, but shouldn't they be the same length on every wing? The only way I can install this brace is to bend it so it doesn't hit the rib next to and bend it out of shape. The Quality of parts I've gotten from TNK is crap compared to what I got when I first built it, Sincerely, Ed Bonsell / 86 Firestar. . ________________________________________________________________________________
Date: Aug 16, 2003
Subject: Re: Drag strut brace / Quality of parts
> The Quality of parts I've gotten from TNK is crap compared to what I got when I first built it, > > Sincerely, > > Ed Bonsell / 86 Firestar. Ed/All: Wish I could fix it for you, but that ain't my job. You message would probably be best sent to The New Kolb Aircraft Company, rather than the Kolb List. I don't know that we can help you out with Kolb company/customer relations problems. Personally, I don't see a big problem with drag strut braces. I got one of the first sets of braces in 1984 for my Ultrastar. I had to bend slightly and trim to fit back then. Same for my Firestar, and for my Mark III. There's going to be a fair amount of pulling caused by the welding process, especially on a piece like a drag strut brace where two long legs are welded on one end. As far as screwing up your priming and painting sequence, guess you'll have to live with that. The rest of us probably did also. Don't get me wrong, if New Kolb Aircraft is sending parts that are less than acceptable/serviceable, send them back and get replacements. If we do that enough, maybe they will get the hint. If you send them a nice email, letter, or call Ray Brown, they'll also get the message. I know for a fact Ray Brown wants all Kolb customers to get what they pay for. There have been some personnel changes made recently, especially in the welding shop. This may account for some parts not being up to your specs. Over the last 19 years of dealing closely with old and new Kolb, I have sent my share of goodies back for replacements. I don't think one regime is any better or any worse than the other. Take care, john h ________________________________________________________________________________
Date: Aug 16, 2003
Subject: Re: 582
would like to know if there are any really successfull installations of the 582 with the twin radiators in back or is it better to remount them to the front of the engine or is it better to get an aftermarket radiator and rig it in front of the engine? Seems the threads I kept hearing were of failures and how difficult it is to keep them cool. Are they worth the extra horsepower to have to mess with this? I have just aquired a slingshot and have a 582 with an E box and need to mount the water system in a couple of weeks or month. You can email me separate with pics if you would respond. I suppose there are applications where they work and not work depending on the situation. I think a slingshot would be easier for the motor to push through the air compared to a MkIII but what do I know. I have checked the archives and there doesnt seem to be a lot out there. I need input!! thanks. (I would rather have a BMW 1100 with a C on it but what the heck. I dont want to be an engineer or a test pilot in any case. Thanks for the response. By the way, mine is number 30, last one the factory produced. Got a classic! Ted Cowan, Alabama ________________________________________________________________________________
Date: Aug 16, 2003
Subject: Re: 582
Ted, There are some pictures on my website of my rear mounted radiators and the air scoops to aid cooling. http://hometown.aol.com/sgreenpg/58SGKOLB.html Steven ________________________________________________________________________________
Date: Aug 16, 2003
Subject: Rivet guns
Does anyone ever use an air-powered rivet gun? I would like to buy one but need some advice from any of you that might have used one. Does anyone have a brand name of a good one? Also does anyone know how much total fabric it takes to cover a Firestar? G. Murphy / 85 Firestar / Alabama ________________________________________________________________________________
Subject: Re: Rivet guns
Date: Aug 16, 2003
I can make you a very good deal on an air powered revit gun. It is a Harbor freight gun and was used to build my Firestar II. Will sell it for half price and you pay the shipping. George in Arizona ----- Original Message ----- From: "george murphy" <geomurphy(at)direcway.com> Subject: Kolb-List: Rivet guns > > Does anyone ever use an air-powered rivet gun? I would like to buy one but > need some advice from any of you that might have used one. Does anyone have > a brand name of a good one? Also does anyone know how much total fabric it > takes to cover a Firestar? > > G. Murphy / 85 Firestar / Alabama > > ________________________________________________________________________________
Date: Aug 16, 2003
Subject: Rivet Gun??
Gentlemen, I am in need of some sort of air powered rivet gun to put my Firestar back together. Does anyone have any experience using one of these things? Any advice on pros and cons would be appreciated, and if anyone has a preference on a brand name that would be helpful too. How many yards of fabric are needed to recover a Firestar? G. Murphy 85 Firestar Alabama ________________________________________________________________________________
From: "Larry or Judy Gitt" <gittj(at)earthlink.net>
Subject: John willianson
Date: Aug 16, 2003
Has anybody heard from John Williamson lately , I sent him an E mail with no reply . It's been a week or so. John if you read this, I sent you some pictures also plus some Drawings too Larry --- Judy Gitt --- gittj(at)earthlink.net ________________________________________________________________________________
Date: Aug 16, 2003
Subject: Re: 582
I would try Steve Green's mod for the twin radiators. I tried a single radiator in front of the engine and was very displeased, especially if you get stuck at the end of the runway behind someone, the thing will overheat, there is no prop airflow to keep it cool at idle. It is also less effective in flight, because it hurts your climb. (Picture a big square spoiler in the middle of the wing, in front of the engine.) Suspect that the twin radiators at the mag end of the engine on a Kolb would overheat in the same way. The same radiator that didn't work in front of the mag was very effective mounted at the trailing edge of the wing on the underside. (Top of the radiator was even with the lower edge of the wing, it was behind the fuselage tubing.) Don't know if the Slingshot will allow a radiator to be mounted in the center section below the wing or not, but you get great airflow there, and also good ground cooling. Pictures of my radiator here, click on "Adding a heater" and also "Need for Speed" http://www.bcchapel.org/pages/0003/kolb.htm Richard Pike MKIII N420P (420ldPoops) > >would like to know if there are any really successfull installations of the >582 with the twin radiators in back or is it better to remount them to the >front of the engine or is it better to get an aftermarket radiator and rig >it in front of the engine? Seems the threads I kept hearing were of >failures and how difficult it is to keep them cool. Are they worth the >extra horsepower to have to mess with this? I have just aquired a slingshot >and have a 582 with an E box and need to mount the water system in a couple >of weeks or month. You can email me separate with pics if you would >respond. I suppose there are applications where they work and not work >depending on the situation. I think a slingshot would be easier for the >motor to push through the air compared to a MkIII but what do I know. I >have checked the archives and there doesnt seem to be a lot out there. I >need input!! thanks. (I would rather have a BMW 1100 with a C on it but >what the heck. I dont want to be an engineer or a test pilot in any case. >Thanks for the response. By the way, mine is number 30, last one the >factory produced. Got a classic! Ted Cowan, Alabama > > ________________________________________________________________________________
Date: Aug 16, 2003
I have an air powered gun I bought from Harbor Freight and it works fine. Bryan Green (Elgin SC) ----- Original Message ----- From: "george murphy" <geomurphy(at)direcway.com> Subject: Kolb-List: Rivet guns > > Does anyone ever use an air-powered rivet gun? I would like to buy one but > need some advice from any of you that might have used one. Does anyone have > a brand name of a good one? Also does anyone know how much total fabric it > takes to cover a Firestar? > > G. Murphy / 85 Firestar / Alabama > > ________________________________________________________________________________
Subject: Re: Rivet Gun??
Date: Aug 16, 2003
George, There are really 2 choices for new pnematic rivit guns....you have a Huck gun...(Huck brand) and its gonna set you back from 1800 to 3500 bucks! depending on the model....ya ..you read that right..them zeros belong there..or..ya buy an oriental copy...like the harbor freight/central pneumatic oriental jobs...they are all about the same quality. and they will last much longer than one airplane...and from 49 to 89 bucks depending on how good a shopper you are. http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Date: Aug 17, 2003
Don, I appreciate your advice. Did you mean to say a Hauk gun?? I think those guns are semi or fully automatic. Think I will go for the Harbor Freight type. Thanks, G. Murphy /85 Firestar/ Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Don Gherardini Subject: Re: Kolb-List: Rivet Gun?? George, There are really 2 choices for new pnematic rivit guns....you have a Huck gun...(Huck brand) and its gonna set you back from 1800 to 3500 bucks! depending on the model....ya ..you read that right..them zeros belong there..or..ya buy an oriental copy...like the harbor freight/central pneumatic oriental jobs...they are all about the same quality. and they will last much longer than one airplane...and from 49 to 89 bucks depending on how good a shopper you are. http://www.geocities.com/dagger369th/my_firefly.htm Don Gherardini- FireFly 098 ________________________________________________________________________________
Date: Aug 17, 2003
I was curious what side Jim had a fuse on since he stated he has had no problems. Reason I asked Jim was due to thinking about this a little and the way the shunt regulator works, it could draw a bit of current to pull down the lighting coil. Has anybody seen a fuse block that mounts similar to a terminal strip that can hold say 1-5 automotive style fuses. jerb > > > > >Jim, & All > >Which side is your fuse, the lighting coil side of the regulator or the DC > >output side? > > > >Jerb, > >To save the lighting coil, the fuse needs to be placed on the lighting >coil side of the regulator. > >Jack B. Hart FF004 >Jackson, MO > > >Jack & Louise Hart >jbhart(at)ldd.net > > ________________________________________________________________________________
Date: Aug 17, 2003
> > Has anybody seen a fuse block that mounts similar to a terminal strip that > can hold say 1-5 automotive style fuses. > jerb > Jerb, I have had great customer service from: http://bandcspecialty.com/parts.html They have several fuse holder solutions which I use. Jon near Green Bay www.joncroke.com ________________________________________________________________________________
Date: Aug 17, 2003
Jerb, I do not believe the Key West is a shunt type regulator. I believe it must be a switching type because it does not reject much heat. I was quizzed about my regulator installation, and so I put mounted a thermistor on the back of it and ran the engine. The temperature on the back side of the regulator only came up a few degrees. For a fuse, I used the "U" shaped automotive fuse in an in line holder. They can be purchased at Radio Shack or any automotive parts store. This let me save some weight by mounting the fuse right on the engine and bundle it with other wires. Jack B. Hart FF004 Jackson, MO > >I was curious what side Jim had a fuse on since he stated he has had no >problems. Reason I asked Jim was due to thinking about this a little and >the way the shunt regulator works, it could draw a bit of current to pull >down the lighting coil. > >Has anybody seen a fuse block that mounts similar to a terminal strip that >can hold say 1-5 automotive style fuses. >jerb > > >> >> > >> >Jim, & All >> >Which side is your fuse, the lighting coil side of the regulator or the DC >> >output side? >> > >> >>Jerb, >> >>To save the lighting coil, the fuse needs to be placed on the lighting >>coil side of the regulator. >> >>Jack B. Hart FF004 >>Jackson, MO >> >> >>Jack & Louise Hart >>jbhart(at)ldd.net >> >> > > Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Aug 17, 2003
Subject: Noseover Tendancy - Kolb
> If I had it to do over..I probably would have left off the nose brace....I > have not had any problems keeping her nose out of the dirt....I think that > maybe it is more likely that a 2 seater has more trouble nosing over with > the extra weight of 2 people..or maybe alot more horses than I have cause > Don Don/All: Probably excellent pilot technique. A few years ago at Sun and Fun I put the factory Fire Fly on its nose. Was a matter of high hp or two folks up front. Turned downwind to taxi back for takeoff and she came right up on the nose. The grass was dry, the wind was blowing hot on my tail, the idle was set too high, and the darned Fire Fly would not slow down and stop. Well, finally it stopped. But when you have the whole world of ultralighting gawking at'cha, it seemed forever. I have also put the old factory MK III on its nose while taxiing to a stop, with tailwind. Not to forget my Firestar which got on its nose a few times. However, with the Jim Hauck modification to the main landing gear on Miss P'fer, after 12 years, she has never been on her nose, although given the chance many times over a lot of hours. Only reason I have not put the Kolbra on its nose is lack of flight time, .5 hrs. However, I have seen a very high time pilot do it, but it took some effort on his part to get it up there. :-) Take care, john h ________________________________________________________________________________
Date: Aug 17, 2003
George, There are brand name pneumatic rivet puller but you will find that most builders including the Van RV aircraft builders use the ones sold by Harbor Freight or Northern Tool. They work just fine. In use you can adjust the compressor regulator output pressure to control the amount of force of the pull. There are times when you want a gentle pull, others when you just want to get on with it. A rapid pull can cause it to jump a little thus causing you to dig into the fabric when pulling rivets on the wing. We also used it at lower pressure to do dimpling in sheet metal parts when building an RV. Works good.... Here's the links for both companies. Search under rivets, riveters, or rivet pullers. http://www.northerntool.com/ Northern a while back had a good price on the riveter but since has dramatically increased their prices. http://www.harborfreight.com/cpi/ctaf/headsearch.taf?function=Search I found the $53 rivet is more than adequate for the work being done. http://www.harborfreight.com > >Gentlemen, I am in need of some sort of air powered rivet gun to put my >Firestar back together. Does anyone have any experience using one of these >things? Any advice on pros and cons would be appreciated, and if anyone has >a preference on a brand name that would be helpful too. How many yards of >fabric are needed to recover a Firestar? > >G. Murphy 85 Firestar Alabama ________________________________________________________________________________
Date: Aug 17, 2003
Subject: Cryptic info in message header
George, What's the cryptic info in the header of your message. jerb > >Gentlemen, I am in need of some sort of air powered rivet gun to put my >Firestar back together. Does anyone have any experience using one of these >things? Any advice on pros and cons would be appreciated, and if anyone has >a preference on a brand name that would be helpful too. How many yards of >fabric are needed to recover a Firestar? > >G. Murphy 85 Firestar Alabama > > ________________________________________________________________________________
Date: Aug 17, 2003
Subject: Cage welding ??? Help
If a repair is needed to a small tube in the cage what is the preferred method of welding ? MIG (flux core or inert gas?)/ acetylene (what rod ??) thanks ! Dave ________________________________________________________________________________
Subject: Re: Cage welding ??? Help
Date: Aug 17, 2003
Dave, Acetylene or Tig welding is preferred on 4130 steel. Stay clear of Mig welding, I have been told it can be done but is on the bottom of the list. Do you like to read? 1. http://www.tinmantech.com/html/4130_aircraft_chromemoly_tubin.html 2. http://home.hiwaay.net/~langford/sportair/ Charles ________________________________________________________________________________
Subject: Re: Cryptic info in message header
Date: Aug 17, 2003
Hi George I have a air Rivet Gun that I will be glad to let you use so that you do not have to go out and buy one. I will have to try and remember who has it right now. let me know if you still need one. Randy In NC Sold the soobydoo, now flying a leohle spad Xlll ---- Original Message ----- From: "jerb" <ulflyer(at)verizon.net> Subject: Kolb-List: Cryptic info in message header > > George, > What's the cryptic info in the header of your message. > jerb > > > > > >Gentlemen, I am in need of some sort of air powered rivet gun to put my > >Firestar back together. Does anyone have any experience using one of these > >things? Any advice on pros and cons would be appreciated, and if anyone has > >a preference on a brand name that would be helpful too. How many yards of > >fabric are needed to recover a Firestar? > > > >G. Murphy 85 Firestar Alabama > > > > > > ________________________________________________________________________________
Date: Aug 17, 2003
Jack, The Key West is a shunt regulator according to the manufacturer I spoke directly with, a branch of the Titan operation. It's a simples design that works but I feel a switcher would be required for a high current output alternative due to the changing voltage level and frequency as RPM changes. Did you fly it while doing your temperature test or just a burst of high power? Did you vary the power loading? jerb > >Jerb, > >I do not believe the Key West is a shunt type regulator. I believe it >must be a switching type because it does not reject much heat. I was >quizzed about my regulator installation, and so I put mounted a thermistor >on the back of it and ran the engine. The temperature on the back side of >the regulator only came up a few degrees. > >For a fuse, I used the "U" shaped automotive fuse in an in line >holder. They can be purchased at Radio Shack or any automotive parts >store. This let me save some weight by mounting the fuse right on the >engine and bundle it with other wires. > >Jack B. Hart FF004 >Jackson, MO > > > > > >I was curious what side Jim had a fuse on since he stated he has had no > >problems. Reason I asked Jim was due to thinking about this a little and > >the way the shunt regulator works, it could draw a bit of current to pull > >down the lighting coil. > > > >Has anybody seen a fuse block that mounts similar to a terminal strip that > >can hold say 1-5 automotive style fuses. > >jerb > > > > > >> > >> > > >> >Jim, & All > >> >Which side is your fuse, the lighting coil side of the regulator or > the DC > >> >output side? > >> > > >> > >>Jerb, > >> > >>To save the lighting coil, the fuse needs to be placed on the lighting > >>coil side of the regulator. > >> > >>Jack B. Hart FF004 > >>Jackson, MO > >> > >> > >>Jack & Louise Hart > >>jbhart(at)ldd.net > >> > >> > > > > > > >Jack & Louise Hart >jbhart(at)ldd.net > > ________________________________________________________________________________
Date: Aug 17, 2003
Hi Dave and Gang, I'm not a welding guru or any such thing and have very little welding experience, but have tried to study up on the subject due to the fact that I wanted to do the John/Jim Hauck special landing gear on my MK III. The best method of welding 4130, in my opinion from the info I have read and talked to knowledgeable people about, is TIG welding. Here is a couple of links with good info on the subject. The first one is http://members.eaa org/home/homebuilders/building/welded/articles.html and you can go to this site http://www.tigdepot.com/faq.html and find some good info or buy what you need. The owner of the second site is known as "Mr TIG" and has some impressive credentials. Here is an excerpt from the web page, "With over 30 years experience, Wyatt Swaim is known throughout the world as the leading expert in the TIG Welding Industry. Wyatt began his welding engineering education at Cowley County College in Arkansas City, Kansas. Concentrating his career towards the Aerospace and highly technical industries, he worked for Boeing in Wichita before moving to San Diego. He then honed his skills at General Dynamics, Amatek Straza and Chemtronics, while furthering his education at San Diego State University. Wyatt founded Hi-Tech Welding Services Inc. 18 years ago and funneled his energies towards building a complete production facility geared towards providing the highest level of welding, R&D, welding engineering, and metallurgy to high technology industries. This facility includes TIG, Plasma and Electron Beam Welding, as well as Non-Destructive Testing, X-Ray and Penetrant Inspection. I'm sure MIG welding is more than acceptable on the small tubing and I have been told some of the major kit makers use MIG on the whole frame because it is faster. Not sure about the acetylene/O2 rods, but I do remember seeing them in the Aircraft Spruce catalog. Later, John Cooley -------Original Message-------
July 17, 2003 - - - - , 20-
Kolb-Archive.digest.vol-ek
