Kolb-Archive.digest.vol-fc
September 20, 2004 - October 31, 2004
      A quick search on Google provided the following:
      SKYSports Online Ordering -> $368
      http://www.ismi.com/airstuff/category.cfm?categoryid=315
      Jack B. Hart FF004
      Jackson, MO
      Jack & Louise Hart
      jbhart(at)ldd.net
Date: Sep 20, 2004
Subject: Re: firestar
In a message dated 9/20/2004 7:29:59 PM Eastern Standard Time, Lynnp@c-gate.net writes: Two more two less? KXP has 7 ribs [same as a Firestar II] as opposed to just 5 on the Firestar. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Sep 20, 2004
In a message dated 9/20/04 6:39:47 PM Eastern Daylight Time, Lynnp@c-gate.net writes: Kolbers, What's the difference between a Fire star and a Fire star KXP? Paul Petty Building Ms. Dixie Kolbra/912UL/Warp do not archive two ribs I have a KX, without the P....therefore I have 5 ribs per wing. The K part means there are a few other minor modifications. One is to the tail fold technique.....I should have had the new K fold technique, but I ended up with the "original" which is a long pin through 3 holes which must line up everytime you insert the pin and safety pin. I ended up with this because I bought the 1st KX made and it was delivered before the plans were finished....soooooo I ended up with an original with a 447 instead of the old 377 as well. I bought mine from Homer in '91. I think it was at Oshkosh or S n F,........... CRS. Was flying it by '92....before it was even painted....and was clearly transparent against the sun, just one coat of clear on it......whew! Bob Morrison of Bristolville, Ohio flew it hands off, first time....only problem was....the engine wouldn't go full throttle for more than 30 seconds...nother story. george Randolph Firestar driver from The Villages ________________________________________________________________________________
Date: Sep 20, 2004
Subject: Re: Fuel Mizer vrs NavMan
A couple of years ago, I had a RANS S12XL with a 503... I installed a NavMan fuel flow meter (which, by the way, I got from BoatersWorld.com for MUCH less than SkySports or any of the other aviation places) and installed the transducer in-line between the tank and the engine. I was careful to make sure that the transducer was cushioned (via foam) from the vibrations of the airframe. Not only did the NavMan perform flawlessly, it helped me detect a partial failure in the check-valve in my electric fuel pump. YMMV, but I was quite happy with it. -- Robert P.S. The installation manual states, "The fuel flow transducer is designed for installation in Coast Guard approved 9.5 mm (3/8") flexible fuel line. The transducer MUST be installed AFTER the main fuel filter. It should be located well away from any area where it will be effected by excessive heat or vibration from the engine. It is preferable to mount the transducer in a vertical position." ... and I followed it to the letter. ________________________________________________________________________________
Date: Sep 20, 2004
Has anyone hooked up the NavMan transducer to an EIS? I'm looking at Catalog # 319860151 for $89.99. Seems to be a nice alternative if it works. Thanks, J.D. Stewart UltraFun AirSports www.ultrafunairsports.com Challenger List and Website administrator http://challenger.inebraska.com Titan Aircraft E-mail List http://groups.yahoo.com/group/Titanaircraft/ > > > A couple of years ago, I had a RANS S12XL with a 503... I installed a > NavMan fuel flow meter (which, by the way, I got from BoatersWorld.com for > MUCH less than SkySports or any of the other aviation places) and installed > the transducer in-line between the tank and the engine. I was careful to > make sure that the transducer was cushioned (via foam) from the vibrations > of the airframe. > > Not only did the NavMan perform flawlessly, it helped me detect a partial > failure in the check-valve in my electric fuel pump. YMMV, but I was quite > happy with it. > > -- Robert > > P.S. The installation manual states, "The fuel flow transducer is designed > for installation in Coast Guard approved 9.5 mm > (3/8") flexible fuel line. The transducer MUST be installed AFTER the main > fuel filter. It should be located well away from any area where it will be > effected by excessive heat or vibration from the engine. It is preferable > to mount the transducer in a > vertical position." ... and I followed it to the letter. ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Metar Wx auto downloads
Mornin' all, just found a neat little utility for auto-downloading current Metar Wx reports off the web. It is at http://www.nirsoft.net/utils/mweather.html You can readily set it up to fetch the reports from the stations you choose, and make it display values in any format you choose. (meters, feet, celsius, centegrade, etc.) Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Sep 21, 2004
Group, I thought that it should be added that the difference between the Firestar and the KXP is more than the number of ribs. There are 3 different Firestars, the "original", the KX/KXP, and the Firestar I/II. Each of the 3 have a different fuselage. The first two are no longer manufactured. The number of ribs has been covered in other posts. John Jung Firestar II N6163J Surprise, Arizona __________________________________ ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Re: : Kolb-List:TNK FLYIN cheap communications
Date: Sep 21, 2004
Subject: Re: : Kolb-List:TNK Flyin cheap communications
In a message dated 9/21/04 1:48:26 PM Eastern Daylight Time, wayne(at)engravers.net writes: > Steve, > > I can talk to myself in flight all I want and it doesn't cost anything. > However, if you're talking about talking to someone else in 1) The same > aircraft, 2) In another aircraft or 3) Possibly someone on the ground, > that's another whole matter altogether. > > Wayne, There are several mfgs that offer small inexpensive systems for bike to bike or rider to passenger conversations. I set up a dealership for products from three of these. I will be bringing them to the TNK Flyin to test out. I plan to give away a few as door prizes. I will let the hard core Kolb drivers tell me what they like best. You would be able to buy them from me or other sources. I plan to offer a special discount to Kolblist types. I will post results after the show. Again you won't have to buy them from me there are other sources but I will try to find the best option that everyone likes and share the info. Steve B WetFly #007 ________________________________________________________________________________
Date: Sep 21, 2004
From: "Gary r. voigt" <johndeereantique(at)qwest.net>
Subject: locate a plane?
Hello guys, this is kolb related because i own a kolb...huh... anyway i'am trying to locate 1946 aeronca chief that my uncle owned when he lived in Alaska..he paid a total sum of 2,000 for it. i have the numbers for it and would like the web site to locate the plane if it has not been destroyed. i would like to purchase it if i could ever find it even though it may be a long shot. i'am pretty good at seeking those antique items out. if i can find a tractor, i can locate a plane. thanks for your help in advance. Gary r. voigt KXP 447 ________________________________________________________________________________
Subject: Re: locate a plane?
Date: Sep 21, 2004
Gary, type in Avitop.com. This web site has a n-number search in the left menu. If you have any trouble, let me know and I will help. Jerry Curtin jcurtin(at)cableone.net ----- Original Message ----- From: "Gary r. voigt" <johndeereantique(at)qwest.net> Subject: Kolb-List: locate a plane? > > Hello guys, this is kolb related because i own a kolb...huh... anyway i'am trying to locate 1946 aeronca chief that my uncle owned when he lived in Alaska..he paid a total sum of 2,000 for it. i have the numbers for it and would like the web site to locate the plane if it has not been destroyed. i would like to purchase it if i could ever find it even though it may be a long shot. i'am pretty good at seeking those antique items out. if i can find a tractor, i can locate a plane. thanks for your help in advance. > > Gary r. voigt > KXP 447 > > ________________________________________________________________________________
Subject: Discovery Wings
Date: Sep 21, 2004
Saw a teaser for Oshkosh highlights on Discovery Wings Thursday @ 8 PM. Caught a glimpse on the promo of what appeared to be a yellow Kolb taking off. Might want to watch if you have the Wings station. Clay Stuart Danville KY ________________________________________________________________________________
From: "Wayne @ Aircraft Engravers" <wayne(at)engravers.net>
Date: Sep 22, 2004
Steve, I was making a joke about using the tin cans and a taught string for communications, I'm all set with my intercom system. Wayne > Wayne, > There are several mfgs that offer small inexpensive systems for bike to > bike > or rider to passenger conversations. I set up a dealership for products > from > three of these. I will be bringing them to the TNK Flyin to test out. I > plan to > give away a few as door prizes. I will let the hard core Kolb drivers tell > me > what they like best. You would be able to buy them from me or other > sources. > I plan to offer a special discount to Kolblist types. I will post results > after the show. > Again you won't have to buy them from me there are other sources but I > will > try to find the best option that everyone likes and share the info. > > Steve B > WetFly #007 ________________________________________________________________________________
From: "M. Domenic Perez" <perezmdomenic(at)plateautel.net>
Subject: Cheap communications
Date: Sep 22, 2004
Steve B. I'm assuming your idea for cheap communication has something to do with the new FRS and/or GMRS radios now available. If you are making yourself informed about these, while you're at it, see if there is a way to patch together for simultaneous use, an aviation radio, a cell phone and the FRS/GMRS radios. I know this sounds excessive, but would be useful anyway. In my case, if I had to give up one of the three, it would be the aviation radio. M. Domenic Perez FS II Vaughn, NM (the boonies, where there is nobody to talk to on an aviation radio anyway) ________________________________________________________________________________
Date: Sep 22, 2004
Subject: Re: on again off again
In a message dated 9/22/2004 1:49:50 PM Eastern Standard Time, lynnp@c-gate.net writes: Kolbers, I got an e-mail from Mark German informing me that he is going to London for the fly in. I can't pass up the chance to look over his Kolbra so I am bending all the rules and will see you all there. Paul Petty There will be four of us flying up to the London Airport [in a Lance]. See you about noon. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Sep 22, 2004
Subject: Firestar II flies with 582
Today, we swapped the tired 503 for a robust 582 on my friend,Chuck Reinert's, Firestarr II. He took her for a short test flight just at dark. I will fly her tomorrow & get some numbers to post. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Sep 22, 2004
jerry, thank you for the info. Gary r. voigt ----- Original Message ----- From: "Jerry Curtin" <jcurtin(at)cableone.net> Subject: Re: Kolb-List: locate a plane? > > Gary, type in Avitop.com. This web site has a n-number search in the left > menu. If you have any trouble, let me know and I will help. Jerry Curtin > jcurtin(at)cableone.net > ----- Original Message ----- > From: "Gary r. voigt" <johndeereantique(at)qwest.net> > To: > Subject: Kolb-List: locate a plane? > > > > > > > Hello guys, this is kolb related because i own a kolb...huh... anyway > i'am trying to locate 1946 aeronca chief that my uncle owned when he lived > in Alaska..he paid a total sum of 2,000 for it. i have the numbers for it > and would like the web site to locate the plane if it has not been > destroyed. i would like to purchase it if i could ever find it even though > it may be a long shot. i'am pretty good at seeking those antique items out. > if i can find a tractor, i can locate a plane. thanks for your help in > advance. > > > > Gary r. voigt > > KXP 447 > > > > > > ________________________________________________________________________________
Subject: cell phone, FRS use in aircraft
Date: Sep 23, 2004
07:02:18 AM >From: "M. Domenic Perez" <perezmdomenic(at)plateautel.net> >Subject: Kolb-List: Cheap communications >Steve B. > I'm assuming your idea for cheap communication has something to do with >the new FRS and/or GMRS radios now available. If you are making yourself >informed about these, while you're at it, see if there is a way to patch >together for simultaneous use, an aviation radio, a cell phone and the >FRS/GMRS radios. I know this sounds excessive, but would be useful anyway. >In my case, if I had to give up one of the three, it would be the aviation >radio. >M. Domenic Perez >FS II I was told that use of a cell phone in any aircraft is illegal, as multiple cell receivers are triggered at once. Could be wrong, and can't remember the source... I have patched my FRS into my intercom and used it to transmit from my Kolb at a couple thousand feet to my wife on the ground over 6 miles away. This was one of the normal no-license low power units. It was loud and clear. Plenty of cords when you get a couple headsets, an intercom, an a/c band radio, and then add a portable cassette/radio or a FRS to the intercomm. FM radio reception is certainly great from a couple thousand feet also. Jim ________________________________________________________________________________
Subject: Re: cell phone, FRS use in aircraft
Date: Sep 23, 2004
The prohibition against Cell Phone use in aircraft is from the FCC not the FAA. See this link for more information. http://wireless.fcc.gov/services/cellular/operations/aircraft.html The airline industry has gone into cahoots with a single Cellular Service to allow this company and only this company to provide Cell Service on the carriers' aircraft. It sounds to me that the technical rationale for banning Cell Phones is a bit Phoney :-) and just another way to create a monopoly that the airlines and service provider benefit from. Thom in Buffalo ________________________________________________________________________________
Date: Sep 23, 2004
Subject: cell phone use
The FCC ban on cell-phone use from aircraft is a very real one, and one they take seriously. I've been told they issued -- and collected -- a $10,000 fine from a corporate aircraft for using cellphones from the air. Obviously, Aircell has gotten a waiver of this rule, probably because they created equipment and used frequencies that do not interfere with ground-bound cellphone use. The basic problem is that if you're even 500' in the air, your cellphone can light up a whole bunch of relay towers instead of just one or two -- and the FCC will know it, if they're paying attention; and they'll come after you if they want to pursue it. Cellphones are convenient, but not worth this much risk, IMHO. Russ Kinne ________________________________________________________________________________
Date: Sep 23, 2004
Subject: Re: cell phone use
Russ and all It occurs to me that standing on a tall hill would have the same effect! 5000 feet in the smoky Mountains for instance. 2000 feet on the Cumberland plateau. So--in many cases , I doubt that they could possibly guess where the transmission came from? Herb in Ky writes: > > The FCC ban on cell-phone use from aircraft is a very real one, and > one they > take seriously. > I've been told they issued -- and collected -- a $10,000 fine from > a > corporate aircraft for using cellphones from the air. Obviously, > Aircell > has gotten a waiver of this rule, probably because they created > equipment > and used frequencies that do not interfere with ground-bound > cellphone use. > The basic problem is that if you're even 500' in the air, your > cellphone can > light up a whole bunch of relay towers instead of just one or two -- > and the > FCC will know it, if they're paying attention; and they'll come > after you if > they want to pursue it. > Cellphones are convenient, but not worth this much risk, IMHO. > Russ Kinne > > > = > = > = > = > > > > > > ________________________________________________________________________________
Date: Sep 23, 2004
Russ, Forgive the question (I used to know more about radio technology), but what would the difference be between using a cellphone at, say, 4000 feet AGL,versus using it on the summit of a similar mountain (like Mt. Diablo in the Bay Area of Northern California)? Thanks, Cory -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of russkinne Subject: Kolb-List: cell phone use The FCC ban on cell-phone use from aircraft is a very real one, and one they take seriously. I've been told they issued -- and collected -- a $10,000 fine from a corporate aircraft for using cellphones from the air. Obviously, Aircell has gotten a waiver of this rule, probably because they created equipment and used frequencies that do not interfere with ground-bound cellphone use. The basic problem is that if you're even 500' in the air, your cellphone can light up a whole bunch of relay towers instead of just one or two -- and the FCC will know it, if they're paying attention; and they'll come after you if they want to pursue it. Cellphones are convenient, but not worth this much risk, IMHO. Russ Kinne ________________________________________________________________________________
Subject: Kolb Homecoming 2004
Date: Sep 23, 2004
------------------------------------------------ Search the web by email! mailto:www(at)web2mail.com adding your search to the subject line like this: search summer vacations ------------------------------------------------ Hi All: > > I have arrived at the Kolb Factory. Travis said I was officially the first > Kolber to get here. Unfortunately, I arrived by truck and 5th wheel instead > of MKIII as I usually enjoy traveling in. > > Had dinner with John Williamson, Gary Haley, and James Tripp last night in > Millbrook, AL. John W and Gary spent the night with James and all three had > planned to takeoff at 0900 this morning from Wetumpka Airport and head this > way, via Rome, GA, Rock Springs, TN, and finally Chesnut Knolls Air > Foundation and the Kolb Factory. > > Hope everyone that can is on their way and has a safe flight/trip to London, > KY. The Kolb gang have the place looking 100%, just for us to enjoy. They > are gracious and generous hosts, indeed! > > I have a digital projector and DVD of pictures of my flight to Alaska that I > will share this weekend. > > Ya'll hurry up and get here son I won't be so lonesome. > > Haven't heard anything from the two Texans and one Alabamian flying up. > > john h > Chesnut Knolls Air Foundation/Kolb Aircraft Factory *************************************** HI All: I sent the above on KOlb's account and it bounced. Anyhow, I'll update a little. It is 1830 at the KOlb Factory. James Tripp, JOhn Williamson, Gary Haley, and Mark German have flown in, in two KOlbras, a Mark III, and a FS2. No one else has flown arrived. Ya'll hurry up and come on down. The place looks great and the Kolb gang are ready for you. john h ________________________________________________________________________________
Date: Sep 23, 2004
I say it's a bunch of baloney! The cell. providers just don't want to give up there roaming charges because your phone just line of sighted back to your home tower. And what about the satellite based phones?? It reminds me of the hospital policies of "No Cell Phones" because it may stop someones life supporting gismose?? But the staff are all carrying and using them. Sort of like politics. You can always believe what you hear! ~ Earl ________________________________________________________________________________
Date: Sep 24, 2004
Subject: Firestar II with 582
Today, we took Chuck Reinert's FS II 582 on a short cross country after re-pitching the prop [rpm's a little too high], & raising the needles a notch [EGT's a little too high]. Chuck can still outclimb me by a LITTLE [not bad for an almost 300 lb. guy]. Cruises at 60 mph @5200 rpm. Time will tell about fuel burn. Looking forward to the TNK Fly-In tomorrow. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: Re: short summer
Date: Sep 25, 2004
My first experience with a redrive, once I got used to it, I like the prop braking effect with a closed throttle.>> Hi All, take pity on an ignorant Limey. What is a `redrive`?. Pat ________________________________________________________________________________
Date: Sep 25, 2004
Propeller speed reduction unit. Bryan Green (Elgin SC) ----- Original Message ----- From: "PATRICK LADD" <pj.ladd(at)btinternet.com> Subject: Re: Kolb-List: short summer > > My first experience with a redrive, once I got used to it, I like the > prop braking effect with a closed throttle.>> > > Hi All, > take pity on an ignorant Limey. What is a `redrive`?. > > Pat > > ________________________________________________________________________________
Date: Sep 25, 2004
Subject: N ew style floats
Good mournijng Why should I install new style floats in my 503 w/bings??? D zollinger FS2,503 T.I.A. ________________________________________________________________________________
Date: Sep 25, 2004
< > Got it!.Thanks Pat ________________________________________________________________________________
Date: Sep 25, 2004
Subject: [ Ellery Weld ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Ellery Weld Subject: Firestar Purchased Used This Summer http://www.matronics.com/photoshare/ElleryWeld@aol.com.09.25.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Sep 25, 2004
Subject: [ Larry Cottrell ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Larry Cottrell Subject: Steens Mountain and the Alvord Desert http://www.matronics.com/photoshare/lcottrel@kfalls.net.09.25.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: TNK trip
Date: Sep 26, 2004
Fellow Kolbers, Well, it was a short visit but well worth the long 18 hrs of driving to get there and back, and getting to place my hands Mark Germans wonderful Kolbra was the greatest! Mark is a super guy and did a super job on his airplane. The attendance was less than last year however I was happy to meet the man that started all this way back in the day. Homer and his lovely wife were on hand and what a joy it was to watch him look upward as John Hauck burned up 5 gallons of fuel soaring above us in the factory fire star. I said to one that" If he don't run out of gas were going to have to shoot him down" A reply from an fellow kolber said "Either way he will grease it" I had no doubt. John Williamson and several others made a nice formation fly over and I can't say enough about TNK hospitality. Dennis (welder) made my new door while Travis and Donnie gave me the new parts that we need to finish MS.Dixie.... To wrap this long post up I wish to thank Matt Drale for this form of commutation and the fine folks at TNK.Also I miss Linda did she leave the company? On a sad note and let me vent a bit.... There were many faces that I have seen before and many that that I comm. with on the internet via instant messaging. One of my internet buddies that I almost see daily had a mishap in his Sling Shot. Yes Wayne Wilson was very lucky to survive an engine out and our prayers are with Wayne for a speedy recovery. Us kolbers are tough bunch.. Woody was pricing a new cage for Wayne gotta luv our bunch ey?!!!!! Hang in there guys.... Love loyalty and respect pp and Ms Dixie ________________________________________________________________________________
Subject: Re: kolb skis
Date: Sep 26, 2004
I used the skis off an old ski mobile and the were perfect. chris ________________________________________________________________________________
Date: Sep 26, 2004
Dan , yes I did , up to 10inches,and that was without a tail ski .firestar kxp 503 single carb . chris ________________________________________________________________________________
Subject: Good news, bad news
Date: Sep 27, 2004
Gentlemen: I and three other pilots had a nice, full flying day yesterday. We left our home airport early and dropped in on Kirk (Snuffy) Smith only to discover he was fogged in. We stopped at an alternate field a few miles away, then continued on our way on a cross-country flight to a cider mill in St John MI that has a nice runway next to it. Unfortunately, about 15 miles from the cider mill, something went through my Ivoprop propellor! I heard the "slap!" and began checking things over. The engine never missed a beat and all seemed fine. I had the other Kolb driver, Mark Gray in his Firestar, do a visual checkout and he was unable to see any obvious problems. Of course, the entire group eagerly scrutinized my plane upon arrival and could find -nothing- missing anywhere. We cleaned up the worst ding with some duct tape carried by Mark Gray, and I was eventually able to get home safely. On the way home, we again tried Kirk's place and found him relaxing by the pond with his family. He also was unable to spot anything missing on my bird. We chatted awhile, enjoying Kirk's company and playing with his son's dog, then made our way home. At this point, my best guess is a bird that I never saw coming. Maybe a meteor? UFO? Anyway, now I have to find the money for another prop. Arrrggghhh! -Ken Fackler Kolb Mark II / A722KWF Rochester MI ________________________________________________________________________________
From: "Edward Steuber" <esteuber(at)rochester.rr.com>
Subject: > Good news , Bad news
Date: Sep 27, 2004
Ken, Stuff happens...I was out with the modified Ultrastar yesterday and had the same thing happen ...a small ding on one blade of my 3 blade Ivo prop...happened at about 300 AGL...nothing missing on the plane and nothing from my pockets.... Ed in Western NY ________________________________________________________________________________
Subject: skis
Date: Sep 27, 2004
Hi All,, we dont get the opportunity to fly from snow in the UK, at least not for the last ten years, maybe longer. However an instructor I know told me that when he was young he visited his girl on the other side of the valley when the snow was deep by tieing the bumpers (fenders?) from his car on his ultralight as ski`s. Cheers Pat ________________________________________________________________________________
From: "Martin Burns" <martin_burns(at)ntlworld.com>
Subject: Throttle conversion
Date: Sep 27, 2004
Hi all, I have recently joined this group, being one of a syndicate of three which has bought a flying Kolb Mk.III. This aircraft has the short wings and is classed as a Group A aircraft in the UK (ie. not a microlight). It is 582 powered and also has the standard single central throttle. Can anyone tell me if there are plans available for converting to two throttle levers? Thanks, Martin Burns Scotland, UK. ________________________________________________________________________________
Subject: Kolb fly-in
Date: Sep 27, 2004
Hi All: Just to let everyone know I made it home safe and sound. Total flight time was 25.3 Hrs. burned 92.5 Gals of fuel and covered 1660 miles. The weather could not have been better. Nice tail wind all the way home on Sun. Left TNK at 8:00am and arrived Forest Lake MN. @ 5:55pm. The Kolbra never missed a beat. On the way back I had time to think of the people and places I had just experianced and how lucky we all are to be able to build a small plane in the basement and someday be able to go on a trip like this. Almost brings a tear to your eye. Would like to thank everyone at TNK Travis and Donnie and Bruce for making us feel welcome. And to all the fellows kolbers for being the greatest! I asked John Hauck if he would like to fly the Kolbra and he did, what an honor it was to watch it fly with a pro like John. It was good to see Paul Petty and to have time to talk about his Kolbra project and have some imput on the repair of his cage. Me and John Williamson finally got our Kolbra's togather to fly. John is a great guy to be with and has good storys. Also can't forget the time I had with Homer talking about building and flying. What a great trip. Thanks again. Mark German Chisago City MN. 912 Kolbra 118.3 Hrs. ________________________________________________________________________________
Subject: Re: TNK trip
Date: Sep 27, 2004
I will be posting more on Waynes accident when I am able to talk to him and find out more details. I will be giving the card that so many of you signed to his wife tonight to take to him. He is supposedly undergoing back surgery tonight. His wife tells me his spirits are high. Paul... It is spelled "EH" not ey. If you're going to talk to Canadians ya gotta speak and write the language. ? > > On a sad note and let me vent a bit.... There were many faces that I have seen before and many that that I comm. with on the internet via instant messaging. One of my internet buddies that I almost see daily had a mishap in his Sling Shot. > > Yes Wayne Wilson was very lucky to survive an engine out and our prayers are with Wayne for a speedy recovery. > Us kolbers are tough bunch.. Woody was pricing a new cage for Wayne gotta luv our bunch ey?!!!!! ________________________________________________________________________________
Subject: Structural integrity
Date: Sep 28, 2004
I am beginning to get a little nervous about the cruise speed of my modified Ultrastar . I now have a total of 20 hours and have confirmed all my numbers many times....5200 RPM yields 75MPH and 2 gallons per hour....5400 gets 80MPH (GPS calm air confirmed multiple times)....this is not suppose to happen on a 35 HP Cuyuna with a single Mikuni carb. I feel uncomfortable making claims like this but they are accurate ...it does stall faster (35mph) than the previous machine... The reason this may be happening is the weight and balance is forward of my last machine. The fuel is now in a seat tank but the engine was moved to the rear by one inch....Will this airframe take this airspeed over time....in a shallow dive and more RPM I can get 100 mph ..... The wings have been modified (advice gleaned from the list ) with the steel ring at the butt of each wing , reinforced drag strut ,and beefed up ribs with aluminum sheet over the last rib for twist at tips. Ailerons (full span original) are very responsive at 60Mph but become heavy at cruise. I know the answer is just run the engine slower but the Rpm fluctuates from 4800 to 5100 . I believe this is a carburetor transition area between the needle and the main jet. I have tried repitching the ground adjustable 3 blade Ivoprop but always come back to 6200Rpm at 55Mph on climbout..The engine runs smoother above 5200 but airspeed gets too high....I know some of you are saying what is the problem with high cruise speeds but I am no aeronautical engineer and need some more advice from some of you experienced Ultrastar guys..... To sum up my question...Do I have anything to worry about pushing this airframe at this speed...originally suppose to fly at 60mph. Ed in Western NY ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Throttle handle
After stopping to chat with some fellow flyers at another strip, as I made my take off and pushed the throttle forward, I felt something give. I was climbing out at about 6000 rpm, not the usual 6500. After I was at a safe altitude where I could look for the cause and make a landing if necessary, I found that the throttle handle had broke where it meets the flat piece that fastens to the cage. I could pull it back but not push it forward. It was still attached but just barely, so I flew back to our home stip and made my best landing yet. I am in the process of shortening it up and hope that it will hold up better. I have noticed that others have done similar changes when veiwing photos of their planes. I just wondered if any one else had the same problem ? Al Bumhoffer, Brand New 1995 FirestarII with 11 hrs Elkton MI __________________________________ ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: Structural integrity
Hi Ed Is it for sale?? :-) Herb in Ky writes: > > > I am beginning to get a little nervous about the cruise speed > of my modified Ultrastar . I now have a total of 20 hours and have > confirmed all my numbers many times....5200 RPM yields 75MPH and 2 > gallons per hour....5400 gets 80MPH (GPS calm air confirmed multiple > times)....this is not suppose to happen on a 35 HP Cuyuna with a > single Mikuni carb. I feel uncomfortable making claims like this but > they are accurate ...it does stall faster (35mph) than the previous > machine... > The reason this may be happening is the weight and balance > is forward of my last machine. The fuel is now in a seat tank but > the engine was moved to the rear by one inch....Will this airframe > take this airspeed over time....in a shallow dive and more RPM I > can get 100 mph ..... > The wings have been modified (advice gleaned from the list ) > with the steel ring at the butt of each wing , reinforced drag strut > ,and beefed up ribs with aluminum sheet over the last rib for twist > at tips. Ailerons (full span original) are very responsive at 60Mph > but become heavy at cruise. I know the answer is just run the engine > slower but the Rpm fluctuates from 4800 to 5100 . I believe this is > a carburetor transition area between the needle and the main jet. I > have tried repitching the ground adjustable 3 blade Ivoprop but > always come back to 6200Rpm at 55Mph on climbout..The engine runs > smoother above 5200 but airspeed gets too high....I know some of you > are saying what is the problem with high cruise speeds but I am no > aeronautical engineer and need some more advice from some of you > experienced Ultrastar guys..... > To sum up my question...Do I have anything to worry about > pushing this airframe at this speed...originally suppose to fly at > 60mph. > > Ed in Western NY > > > > = > = > = > = > > > > > > ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: Cell Phones
In a message dated 9/28/2004 6:35:25 AM Eastern Standard Time, kfackler(at)ameritech.net writes: However, there's absolutely NO WAY I can hear over a cell phone while flying my airplane so it's a moot point, and I'd be surprised if anyone else flying our type of aircraft can. What's all the fuss about? -Ken Lightspeed has a nice ANR headset that has a jack to plug in an adapter cord from your cellphone; works real well. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: Superman
Date: Sep 28, 2004
09/28/2004 12:46:10 PM Greetings all. Check this out: http://www.swissinfo.org/sen/swissinfo.html?siteSect=105&sid=5211114 Ya suppose this will fall under light sport aircraft? Erich Weaver ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: Superman
> > >Greetings all. > >Check this out: > >http://www.swissinfo.org/sen/swissinfo.html?siteSect=105&sid=5211114 > >Ya suppose this will fall under light sport aircraft? > >Erich Weaver > Erich, Only if he converts to a single engine and to fixed landing gear. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Sep 28, 2004
In a message dated 9/28/04 10:29:14 AM Central Daylight Time, HShack(at)aol.com writes: > -Ken > Lightspeed has a nice ANR headset that has a jack to plug in an adapter cord > > from your cellphone; works real well. > > Howard Shackleford > FS II > SC > > Thanks Howard, Lightspeed has a great product, we plan on selling it to our industrial customers. Sorry to All for bringing up the whole stupid cell phone thing, But It would be nice to have an answer by the regs on UL use. Remember, those annoying devices have an OFF switch. Use them when it suits your needs. Steve B WetFly #007 ________________________________________________________________________________
Subject: Kolb/Jabi
Date: Sep 28, 2004
Hi John Williams, I tried to send this to you off list but my post was returned , I had heard that there was an overheating problem with the Jabi on the ground. Your experience seems to confirm this. Do you think some sort of fairing to duct some more air over the engine would help, or is the problem not serious enough to bother with. It doesn`t sound good practice to be running hot all the time but with the 111 extra that I am hoping to build 90 knots will be over the Vne. Pat ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Re: TNK Homecoming 2004
Date: Sep 28, 2004
Jerry The Jabiru is a fairly high RPM engine with out a reduction drive and as such has to turn a small inefficient prop. You are right 85HP is plenty of horsepower but it is thrust that makes a airplane fly. I don't have any experience with the engine other than seeing it fly on John W's Kolbra. What I do have experience with is VW engines. The direct drive VW that I flew for a few years operated at the same RPMs and also requited a small inefficient prop. Granted my VW weighted app. 20 lbs more than the Jabiru and as configured produced 3-4 less HP but that engine was unsuitable for a MKIIIc. My reduction drive VW weighs 8 lbs more than my direct drive VW but produces twice the thrust, climbs twice as well, flies faster, and uses less fuel while turning the same RPMs and about the same HP. The key here, at least for the Kolb MKIIIc, is that you need a large slow turning prop to get good performance. I'm sure if you had a great increase in power you might get sufficient thrust out of a small inefficient prop but you would pay with high fuel burn and likely a heavy airplane. Sounds like another great TNK Home Coming. Another 2-3 weeks and I should be back in the air with a rebuilt engine, redrive bracket, and new lower engine mount. My $.02 Worth Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "Jerry Curtin" <jcurtin(at)cableone.net> Subject: Re: Kolb-List: TNK Homecoming 2004 > > Hello John, My name is Jerry Curtin. I live in Mississippi. Was looking > foward to meeting you at the fly in but was unable to attend. I wanted to > ask you why you changed engines on your plane. I was under the impression > that the 85hp would be more than enough to push you right along. If it was > enough power, do you think another prop would do better as far as top end > and fuel economy. I was thinking of the 120 Jabiru with the airmaster > constant speed prop would push the Mark lll Extra right at vne but keeping > it just below would translate to great fuel economy. Please let me know > what > you think. Thanks for your time, Jerry ________________________________________________________________________________
Subject: Fw: [carolinasportflyers] Carolina Sport Flyers Annual Fall
Fly-in
Date: Sep 28, 2004
Bryan Green (Elgin SC) ----- Original Message ----- From: "John W.Davis" <patches11us(at)yahoo.com> Subject: [carolinasportflyers] Carolina Sport Flyers Annual Fall Fly-in > :~) > Carolina Sport Flyers Annual fall fly-in > October 15th,16th & 17th 2004 > Lee County Airport(52j)Bishopville,SC > http://www.airnav.com/airport/52j > > Food and drinks served all day on Sat 16th by a local church with > all > proceeds going to the church to help with a rebuild. > Any one that flies in will receive a attendance desk plaque > Young eagles rides on Sat 16th > Ultralight/Sport planes on display and flying > Intro flight lessons > Ultralight/ Sportplane dealers > > We will also be doing trophys and ribbons again this year on Sat > 16th. > Farthest Distance Flown > Oldest 2 place > Oldest single place > Best in show > Best 2 place > Best single place > Crowd favorite > > Driving Directions: > From Florence or Columbia,SC > Take I-20 East/West to Exit 116, Take hwy 15 North, Go all the way > through the town of Bishopville, A mobil Home dealership will be on > your right, The next road to your left will be Hwy 341, Turn left, > The airport will be apx 1/2 mile on the right. > > Also we we be selling raffle tickets for some neat prizes. > Thanks to all who came last year and Hope to see you all here again > this year. Pass the word!!!! > > > For more Info: > John Davis > patches11us@y... > > > > Now with Pop-Up Blocker. Get it for free! > http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/jrDrlB/TM > > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/carolinasportflyers/ > > <*> To unsubscribe from this group, send an email to: > carolinasportflyers-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > > ________________________________________________________________________________
Subject: 2003 twinstar
Date: Sep 28, 2004
Hi out there I'm new to the list, I would like to get a fat ultra lite or a plane that will qualify as a sport plane Is a good twinstar with a 503 single carb a good choice for a starter plane. What kind of cruse speed can I expect, I will usually be flying by myself. I have followed klob over the years and have looked at many others. I'm also looking at a challanger but the twinstar looks better to me. Please educate me on the pros and cons of the Klob twinstar. Thanks Tom Yilk Hasting NE ________________________________________________________________________________
Date: Sep 29, 2004
Subject: Re: Disappointed in Discovery
That is exactly why as a local EAA chapter president....I prefer Sun-n-fun.......Bye the way to all of you kolbers if it wasn't for the great guys at Kolb at this last years Florida gathering....I would not be the proud owner of Kobra # 4.... THANKS BRIAN FOR THE FLIGHT IN THE FACTORY KOLBRA...... 14 years in ultralights and experimentals and this one will be the icing on the cake......I have 32 years auto collision and painting, wife has 28 years as corporate aviation specialist in business jets......RETIRED..... Wayne McCullough EAA Chapter 330 (new homepage) ________________________________________________________________________________
Date: Sep 29, 2004
Subject: To Ken fackler
Date: Sep 29, 2004
Thank for the info your wisdom will help me in my decision. Tom Yilk ________________________________________________________________________________
Date: Sep 29, 2004
In a message dated 9/29/04 12:53:43 PM Central Daylight Time, KDJames(at)berkscareer.com writes: > I too was disappointed so I wrote EAA about it. What good it does I don't > know but if you don't let them know ... > > Ken > > I sent an email to Discovery channel with my sentiments, I am also sending one to EAA. I suspect that the EAA was probably the cause of the choices. That is because the main focus at Airventure2004 was on things that we as individuals cannot afford nor did we build. Maybe the EAA is now only interested in fiiling their pocket with money from gate addmission and sales of EAA gifts to non airplane people and you have to have the big fancy stuff to create that draw. OK, I will get off the soapbox now and go back to building my little Firefly and designing floats and landing gear that the average guy can build. Disappointed in EAA Steve B ________________________________________________________________________________
Subject: To Roger
Date: Sep 29, 2004
Thanks for the info, you have told me some of the things I"m looking for. I have been associated with the BMW Motorcycle group for 30 years. I understand what a good group can do for your enjoyment of a sport. If I buy a Klob I hope to see all of you at some time or another. Thanks Tom Yilk ________________________________________________________________________________
Date: Sep 29, 2004
Tom, are you in Hastings, NE? I missed a phone call Sunday night by a couple minutes, and the caller ID had your name on it. Thanks, J.D. Stewart UltraFun AirSports, LLC http://www.ultrafunairsports.com Challenger e-mail list http://challenger.inebraska.com Titan e-mail list http://groups.yahoo.com/group/Titanaircraft/ > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Tom Yilk > Sent: Wednesday, September 29, 2004 1:37 PM > To: klob list > Subject: Kolb-List: To Ken fackler > > > Thank for the info your wisdom will help me in my decision. > Tom Yilk > > ________________________________________________________________________________
Subject: Re: 2003 twinstar
Date: Sep 29, 2004
I enjoy my twinstar. It is powered by the 55 h p Hirth. Expect a cruise of 60-65. I would not take a Challenger. I flew 2 of them last winter and they scared me to death. The Kolb is gentle and a high performer a very unusual combination. The Challenger is aptly named and you will constantly be chasing the wandering front nose all the time. Ignore the comments pointing out that Kolb is a tail dragger. That is only true for the first 50 feet while the tail is down. After that it is a non issue. Kolbs are the most forgiving tail draggers out there. Buy the Twinstar and have a great time. Lets not forget the quick folding of the Kolb. I can do my Twinstar in under 15 minutes. One more unmentioned point about the Twinstar is it's easy entry. Just walk into the frame and sit down. No crawling around and pulling you feet in or any of the other contortions getting into any other aircraft. It is also the best camera plane out there. ----- Original Message ----- From: "Tom Yilk" <bmwon(at)charter.net> Subject: Kolb-List: 2003 twinstar > > Hi out there I'm new to the list, > I would like to get a fat ultra lite or a plane that will qualify as a sport > plane > Is a good twinstar with a 503 single carb a good choice for a starter > plane. > What kind of cruse speed can I expect, I will usually be flying by myself. > I have followed klob over the years and have looked at many others. I'm also > looking at a challanger but the twinstar looks better to me. > Please educate me on the pros and cons of the Klob twinstar. > Thanks > Tom Yilk > Hasting NE > > ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Airport Access
I've recently moved, and am looking for a new home for the Firefly. While it can stay put, I'd rather not have to drive 60 miles each way. I've started checking local airports arounf here (Phoenixville, PA). Perkiomen (N10) looked very promising; close, small and friendly. Today, I called and spoke with the manager, who was real nice untill I said "ultralight". The response was "we don't allow ultralights". If I N-numbered it, he did allow that he'd be willing to "take a look at it." I understand you attract more flies with honey then vineger, and was very polite with him. He said he'd had ultralights crash and people get killed, and he's fielded calls from an angry wife accusing him of having "killed my husband." Also, he says, no matter what happened, even away from the airport, the airport's name "gets dragged into it." I told him I understood, and did not press the issue. He says he just doesn't want any more of "those calls." While I can hardly force him to rent me a hanger, I'd like to know the rules regarding access. My understanding from a scan of the archives is that public airports (registered, not owned...this is a privately owned, public use airport) can not prohibit legal activity. A few questions if any one can direct me: 1. Is there a regulation that is explicit about this? 2. Is it dependent upon them ever receiving federal money? 3. How can I find out if they have received federal monay? Thanks, Chuck ________________________________________________________________________________
Subject: tail support
Date: Sep 29, 2004
Hi, Just got back from a recent trip to the desert, and thought that I might add a cheap and easy way to support the wings of a trailered Kolb. I made the trip to Monument Valley, pulling my Firestar II about 2600 or more miles with the wings hanging off the tail boom. I support the tail boom, but not the wings. Of course the roads were rough and one worries about the wear of all the bumps on the attach points. This time I went to the tire store and got a discarded inner tube. After I had the plane loaded in the trailer I slid the deflated tire under the wings and simply inflated it until I got the support that I wanted. (My lifting device raises the tail wheel off the floor about three inches.) When I got there I took out the valve stem, took the deflated tube out, unloaded my plane and that was that. Cheap and simple. Some of the metal valve caps have the little gismos on them to remove the stem, making it easy to use. regards Larry, Oregon ________________________________________________________________________________
Date: Sep 30, 2004
Outrageous ride! -also check out the guy hanggliding over mt everest in the current kitplanes mag. ->> Hi all, towed up there by a microlight no less. The microlight pilot was one of our (UK) leading fliers with all sorts of records under his belt. The idea was to tow a hang glider over Everest but unfortunately the tow rope broke. The microlight continued his climb and flew over and around the summit. Great stuff. Pat ________________________________________________________________________________
Subject: Tail Post, MK III
Date: Sep 30, 2004
| What happened to her tail? | John Cooley Hi John C/Ralph B/All: I changed the subject line. Discovered a broken lower tailpost a couple hours flight time after return from Alaska. Between oral surgery, Ivan, and cleanup, was not able to get it removed, repaired, recovered, and refinished, prior to the Kolb Homecoming 2004. Attribute the failure to a lot of hours, lot of weight, and a lot of rough fields. Plan to have her flying in time to fly to Lucedale for Ronnie Smith's Annual October Flyin about 15 Oct. This will be the third year in a row I have had to pull the tail section, a major job. Hoping to get it reinforced and beefed up to prevent failure in the future. Primary problem is side loading of the tailpost, which is .035 wall 4130 and no lateral bracing to speak of. Haven't decided, for sure, how we will go about repair, but have been thinking about 4130 strip welded up each side of the lower tailpost to provide lateral strength. We already had two large gussets at the upper rear. The post failed at the bottom of the gussets about 4 or 5 inches above the intersection of the lower vertical stabilizer bottom tube. Fabric did a good job of holding things in place, but would not try to intentionally fly it in its present condition, by any means. Take care, john h PS: Heading down to Evergreen, AL, and SERFI this afternoon, if I get all my stuff done. If not, I will drive down in the morning or maybe late tonight. ________________________________________________________________________________
Subject: Re: Firefly: Tires and nose over tendency/mountain bike brakes
Date: Sep 30, 2004
Gregg Waligroski uses them (hydraulic disk brakes for mountain bikes) on his FS II. After seeing his I've got a set for mine but haven't installed them yet. Dave Paule Boulder, CO FS II (No, still haven't flown it....) > Noticed some deals on Mountain bike brakes on Ebay. Anybody tried them on > our kolbs? I keep trying!!:-) Herb ________________________________________________________________________________
Subject: Evergreen AL
Date: Sep 30, 2004
3.60 ALT_MED Misspelled medication name Hey John H, Mapquest shows two Evergreens. Conecuh & Autauga. Which one is correct? We've got a GTA contest going on this weekend at our place, but maybe I can slip away........ Fly Safely, Doug Lawton Matthews Field & Gliderport Whitwell TN ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Re: Vortex Generators
Glad to hear it Mike! I get reports like this all the time and it's always great to hear from satisfied customers. Keep up that testing, VG's are just the ticket for the UK Approval. Joa www.landshorter.com Silver Fern Microlights Ltd wrote: Hi Guys, I have just purchased and fitted some VGs from Harrison designs, little lexan type, they are fitted to our Xtra demonstrator in the UK. I did the first flight of the test schedule today for gaining approval of these and were very impressed. I decided to choose these over the origional idea of aluminium leading edge cap to get a reduction of stall speed. Prior to fitting, the indicated stall speed was 30kt no flap, 27kt 1 flap, and 25kt full flap. today's test with VG's fitted, at the same weight and height the following was recorded 26kt no flap, 24kt 1 flap, 20kt full flap. The aircraft lifted off at, and flared to a lower speed than without the VG's. So far so good. Mike ----- Original Message ----- From: "PATRICK LADD" Subject: Re: Kolb-List: Throttle conversion > > With > vortex generators, 55 works very nicely two up, and I can fly the approach > at 45 solo.>> > > Richard, > that is really interesting. What sort of vortex generators? How many? Where > and how fitted? > > Pat > > pj.ladd(at)btinterntet.com > ________________________________________________________________________________
Subject: Re: Airport Access
Date: Sep 30, 2004
Chuck, I have had an experience along these lines. We had 4 "ultralights" on the field. Along comes a new City Manager who wanted more tax revenue by having more expensive planes in the hangars. He cunningly rewrote the lease which requires FAA registration and more importantly, liability insurance. Now, I am the only one left because I am have all of the documents. If he tried to run me out, I would probably have a case against him but the others just gave up and went elsewhere. Unfortunately, I just deleted from my "favorites" the portion of the FAA website that talks about the requirements to receive federal funding. I'd say that if you have an "n" number, you should not be discriminated against... Kip http://www.springeraviation.net/ ----- Original Message ----- From: "Comcast" <davis207(at)comcast.net> Subject: Kolb-List: Airport Access > > I've recently moved, and am looking for a new home for the Firefly. > While it can stay put, I'd rather not have to drive 60 miles each way. > > I've started checking local airports arounf here (Phoenixville, PA). > Perkiomen (N10) looked very promising; close, small and friendly. > Today, I called and spoke with the manager, who was real nice untill I > said "ultralight". The response was "we don't allow ultralights". If I > N-numbered it, he did allow that he'd be willing to "take a look at it." > > I understand you attract more flies with honey then vineger, and was > very polite with him. He said he'd had ultralights crash and people get > killed, and he's fielded calls from an angry wife accusing him of having > "killed my husband." Also, he says, no matter what happened, even away > from the airport, the airport's name "gets dragged into it." I told him > I understood, and did not press the issue. He says he just doesn't want > any more of "those calls." > > While I can hardly force him to rent me a hanger, I'd like to know the > rules regarding access. My understanding from a scan of the archives is > that public airports (registered, not owned...this is a privately owned, > public use airport) can not prohibit legal activity. A few questions if > any one can direct me: > > 1. Is there a regulation that is explicit about this? > 2. Is it dependent upon them ever receiving federal money? > 3. How can I find out if they have received federal monay? > > Thanks, > > Chuck > > ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Harley's and Kolbs ....
ya know, i was just at the Hog-Air website.. i wonder if one of those HD engines would work on a MK3? seems like they're loaded with torque and plenty of HP. weight wise, i figure if you can put a 912 or Jab on a MK3 why not a HD engine? ....... tim _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Re: Harley's and Kolbs ....
In a message dated 9/30/2004 9:17:27 PM Eastern Standard Time, nazz57(at)yahoo.com writes: i was just at the Hog-Air website.. i wonder if one of those HD engines would work on a MK3? seems like they're loaded with torque and plenty of HP. weight wise, i figure if you can put a 912 or Jab on a MK3 why not a HD engine? ....... tim In "Ultraflight Magazine" [last issue], it said the weight was 214 lbs. I think it's too heavy. Said the cost will be $22,000 to $24,000. Too much for me. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: Re: Prop Calculations
Date: Sep 30, 2004
Since there is always some discussion, from time-to-time, regarding propellers & their performance & sizes, I thought I should pass this along (copied from another e-mail list). I hope it doesn't cloud the air anymore, but, may actually help some of us to understand more about some of the equipment we use. ---------------- Begin forwarded message ------------------ I "borrowed" this post, made by Robert Metzler to the Engines-UL group. It is very good. I am trying to determine the absolute best prop for my MZ 202 on the Tiger Cub right now. BlueMax --- In engines-ul(at)yahoogroups.com, Robert Metzler <sleepy6@a...> wrote: Generally, the larger the diameter of the prop, the more efficient it will be. As airspeed increases, efficiency loss becomes less, but, at UL & SP speeds it is very important to use as large a diameter as possible. Of course, you still need clearance at the prop tips, so we have a physical limitation to consider. Be very cautious if a prop supplier recommends a smaller diameter prop. Next, we have to consider the gearbox ratio. As prop tip speed increases, the efficiency gets lower & the prop gets noisier. For reasonable efficiency we want to limit the maximum speed of the prop tips to about 750-800 feet per second, depending on which expert you listen to. Lets be conservative & figure 750 fps X 60 seconds = 45,000 feet per minute. For a 68" prop to turn once, the tips will travel 68" X 3.1417 = 213.6356 inches. 213.6356 inches divided by 12 = 17.803 feet. If we divide 45,000 by 17.803 = 2527.66 maximum prop RPM. If the maximum engine RPM is 6,800, we can divide that by 2527.66 to get a desired gear ratio of 2.69:1. Rotax offers ratios of 2.62:1, 3.00:1, 3.47:1 & 4.00:1 for their "C" box, so we'd choose 2.62:1. Change those figures above to fit your prop diameter. Be very cautious of a supplier that recommends a ratio different from what you calculated. The "C" box has a maximum allowable mass moment of inertia of 6000 KGCM2, which may limit the size of the prop you can use. Ask the prop supplier, what the mass moment of inertia figure is for the prop that he is recommending. Then, ask him if you can return the prop if his figure is wrong. There have been cases of that happening. The prop has to convert the engine HP to thrust by twist- ing the blade so that the blade forces air to the rear. The more twist to the blade (called pitch), the more HP it takes to turn the blade to max speed. The amount of pitch that is required, is determined by the airspeed of the plane. A powered parachute is really slow, so the proper pitch on that prop would be very slight. A Titan, on the other hand, is pretty fast, so it would use more pitch on the prop. If both props were the same dia, the powered parachute engine would over rev, because of the light engine load. More blades would be required to prevent over reving at very low air speeds, very small prop dia, or very large engines. Generally, the fewer the blades on the prop, the more efficient it is. Look around at other ULs. Be very cautious if a prop supplier suggests more blades than you see on similar plane/engine combinations. Some other factors that will affect efficiency of a pusher prop include the amount of the prop disk blocked by the fuselage & the disturbed air flow into the prop from the fuselage & wings. UL prop manufacturers don't publish much info on their props, so we have no way of determining &/or compar- ing the efficiency of their props. We are somewhat at their mercy with their recommendation. They supposedly base their recommendations on past experience with your plane/engine combination, but, sometimes I wonder about that. Ask if you can return their prop if their recommendation is wrong. ---------------- End forwarded message ------------------ I really do hope this is helpful. Sorry about length. Any comments from persons more experienced than I would be appreciated. George Bass P. O. Box 770 Camp Verde, AZ 86322 USUA #30899 --- ________________________________________________________________________________
Date: Oct 01, 2004
George, Thank you for your email. For the first time, I totally understand why and how we determine the proper size prop for an application. This will help me greatly in my decisions on my project. Jerry ----- Original Message ----- From: "George Bass" <gtb(at)commspeed.net> Subject: Re: Kolb-List: Prop Calculations > > Since there is always some discussion, from > time-to-time, regarding propellers & their > performance & sizes, I thought I should pass > this along (copied from another e-mail list). > > I hope it doesn't cloud the air anymore, but, > may actually help some of us to understand > more about some of the equipment we use. > > ---------------- Begin forwarded message ------------------ > I "borrowed" this post, made by Robert > Metzler to the Engines-UL group. It is > very good. I am trying to determine the > absolute best prop for my MZ 202 on the > Tiger Cub right now. > > BlueMax > > --- In engines-ul(at)yahoogroups.com, > Robert Metzler <sleepy6@a...> wrote: > > Generally, the larger the diameter of the prop, the more > efficient it will be. As airspeed increases, efficiency > loss becomes less, but, at UL & SP speeds it is very > important to use as large a diameter as possible. Of > course, you still need clearance at the prop tips, so we > have a physical limitation to consider. > > Be very cautious if a prop supplier recommends a > smaller diameter prop. > > Next, we have to consider the gearbox ratio. As prop > tip speed increases, the efficiency gets lower & the prop > gets noisier. For reasonable efficiency we want to limit > the maximum speed of the prop tips to about 750-800 > feet per second, depending on which expert you listen > to. Lets be conservative & figure 750 fps X 60 seconds > = 45,000 feet per minute. For a 68" prop to turn once, > the tips will travel 68" X 3.1417 = 213.6356 inches. > > 213.6356 inches divided by 12 = 17.803 feet. If we > divide 45,000 by 17.803 = 2527.66 maximum prop RPM. > If the maximum engine RPM is 6,800, we can divide that > by 2527.66 to get a desired gear ratio of 2.69:1. Rotax > offers ratios of 2.62:1, 3.00:1, 3.47:1 & 4.00:1 for their > "C" box, so we'd choose 2.62:1. Change those figures > above to fit your prop diameter. > > Be very cautious of a supplier that recommends a ratio > different from what you calculated. > > The "C" box has a maximum allowable mass moment of > inertia of 6000 KGCM2, which may limit the size of the > prop you can use. Ask the prop supplier, what the > mass moment of inertia figure is for the prop that he is > recommending. Then, ask him if you can return the > prop if his figure is wrong. There have been cases of > that happening. > > The prop has to convert the engine HP to thrust by twist- > ing the blade so that the blade forces air to the rear. The > more twist to the blade (called pitch), the more HP it takes > to turn the blade to max speed. The amount of pitch that > is required, is determined by the airspeed of the plane. > A powered parachute is really slow, so the proper pitch > on that prop would be very slight. A Titan, on the other > hand, is pretty fast, so it would use more pitch on the prop. > If both props were the same dia, the powered parachute > engine would over rev, because of the light engine load. > More blades would be required to prevent over reving at > very low air speeds, very small prop dia, or very large > engines. Generally, the fewer the blades on the prop, > the more efficient it is. Look around at other ULs. > > Be very cautious if a prop supplier suggests more blades > than you see on similar plane/engine combinations. > > Some other factors that will affect efficiency of a pusher > prop include the amount of the prop disk blocked by the > fuselage & the disturbed air flow into the prop from the > fuselage & wings. > > UL prop manufacturers don't publish much info on their > props, so we have no way of determining &/or compar- > ing the efficiency of their props. We are somewhat at > their mercy with their recommendation. > > They supposedly base their recommendations on past > experience with your plane/engine combination, but, > sometimes I wonder about that. Ask if you can return > their prop if their recommendation is wrong. > > ---------------- End forwarded message ------------------ > > I really do hope this is helpful. Sorry about length. > Any comments from persons more experienced than > I would be appreciated. > > George Bass > P. O. Box 770 > Camp Verde, AZ > 86322 > > USUA #30899 > > > --- > > ________________________________________________________________________________
From: "George E. Thompson" <eagle1(at)commspeed.net>
Date: Oct 01, 2004
That has to be a misprint. Thats more than a whole bike costs. Az. Bald Eagle ----- Original Message ----- From: <HShack(at)aol.com> Subject: Re: Kolb-List: Harley's and Kolbs .... > > In a message dated 9/30/2004 9:17:27 PM Eastern Standard Time, > nazz57(at)yahoo.com writes: > i was just at the Hog-Air website.. i wonder if > one of those HD engines would work on a MK3? seems > like they're loaded with torque and plenty of HP. > weight wise, i figure if you can put a 912 or Jab on a > MK3 why not a HD engine? ....... tim > > In "Ultraflight Magazine" [last issue], it said the weight was 214 lbs. I > think it's too heavy. > > Said the cost will be $22,000 to $24,000. Too much for me. > > Howard Shackleford > FS II > SC > > > ________________________________________________________________________________
Date: Oct 01, 2004
In a message dated 10/1/2004 1:16:27 PM Eastern Standard Time, eagle1(at)commspeed.net writes: That has to be a misprint. Thats more than a whole bike costs. Probably is the cost of the whole PPC it comes on. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: Re: Hull insurance on non flying MKIII
Date: Oct 02, 2004
| Sorry to bring this question up again but, | Bryan Melborn sold a used MKIII to someone that is not acurrent pilot but | wants to insure it while it is under repair in a hanger and not being flown. | Any ideas? | | Steve B Steve B/All: Yes, call an insurance company. I have used AVEMCO for my MKIII, and am now using Falcon. Any company that insures airplanes will insure an aircraft in storage, non-flying, building, etc. All ya gotta do is ask them. They want your money.............. john h ________________________________________________________________________________
Subject: Re: 912 engine idle RPM issue
Date: Oct 02, 2004
| I synced the carbs on the 912 today. I also adjusted the idle screws so | that the egts are the same at idle as per Tom Olink. Any ideas? | | Giovanni Giovanni/Gang: Yep. How do you know the EGT indications are correct? I have had good luck setting idle mixture at 1.5 turns out and leaving them there summer and winter. I believe this is what the book indicates. Adjust idle speed with idle adjustment screws after sychronizing. No problem with idle on 912 or 912S. I adjust mine to about 1500 to 1600 rpm. Seems to me you are describing carbs that are out of mixture adjustment. Take care, john h ________________________________________________________________________________
Date: Oct 03, 2004
Subject: Re: Firestar II with 582 results.
We have the Warp Drive prop pitched for 6400 rpm WOT. Top speed has gone from 80 to 85 mph. With a 220 lb. pilot, climb is 1100 fps. At cruise speed of 60 mph [5200 rpm], fuel burn is at the same rate as my 503 poered FS II. I thing TNK should slightly beef up the cage, add a couple braces in the wing, & offer the 582 as a option on the FS II. Seems the way to go for big ol' guys, float operations, short field or high altitude work. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Oct 03, 2004
Subject: [ Al Bumhoffer ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Al Bumhoffer Subject: 1995 Firestar II http://www.matronics.com/photoshare/abum@midmich.net.10.03.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Oct 03, 2004
Subject: First Flight
After 4 years of construction, I flew my Mark3 Xtra for the first time yesterday. Aircraft flew great, was a tremendously satisfying event. My thanks to the many members on this list who helped out with my questions over the years. Couldn't have done it without you. Tom Sabean Mk3Xtra 912/Ivo Prop ________________________________________________________________________________
Date: Oct 03, 2004
Subject: Re: First Flight
tom sabean wrote: > > After 4 years of construction, I flew my Mark3 Xtra for the first time > yesterday. Aircraft flew great, was a tremendously satisfying event. > > My thanks to the many members on this list who helped out with my > questions over the years. Couldn't have done it without you. > > Tom Sabean > Mk3Xtra > 912/Ivo Prop > Tom, Congratulations on bringing your dream to fruition. What a great feeling you must have had when first getting her air born! Terry -FireFly #95 ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: ultralight crash
Its a sad day for me. Dale Cross, of Groves Texas, an old aquaintence of mine who was one of the pioneers in kolb flying, and had numerous awards, Died Saturday, Flying his Kolb Flyer in an exibition. I dont know any of the particulars except witnesses said he took off then the plane rolled to the right and impacted nose down. Maybe John Hauck can find out more than I have. I feel sure others on this list have met or new Dale. He was a swell guy who loved flying, going nowhere, just for the fun of it. I will miss him sorely. Ed Diebel ________________________________________________________________________________
Date: Oct 04, 2004
Subject: (no subject)
I would like to send a photo to Homer of the fly-in. Could some one please e-mail me direct with his street address, in Pheonixville. (please write "Homer ",in the subject line) Thanks Bob Griffin do no archive ________________________________________________________________________________
Date: Oct 04, 2004
> > > Its a sad day for me. Dale Cross, of Groves Texas, an old > aquaintence of > mine who was one of the pioneers in kolb flying, and had numerous > awards, > Died Saturday, Flying his Kolb Flyer in an exibition. I dont know > any of the > particulars except witnesses said he took off then the plane rolled > to the right > and impacted nose down. Maybe John Hauck can find out more than I > have. I > feel sure others on this list have met or new Dale. He was a swell > guy who loved > flying, going nowhere, just for the fun of it. I will miss him > sorely. > > Ed Diebel Ed and others, This is a very sad day. Del Cross has been flying that orange and white twin engine Kolb Flyer for as long as I can remember. He flew at Oshkosh for so many years. Could it be he had an engine out on takeoff and couldn't recover? Ralph Original Firestar Get your name as your email address. Includes spam protection, 1GB storage, no ads and more Only $1.99/ month - visit http://www.mysite.com/name today! ________________________________________________________________________________
Date: Oct 04, 2004
| Its a sad day for me. Dale Cross, of Groves Texas, an old aquaintence of | mine who was one of the pioneers in kolb flying, and had numerous awards, | Died Saturday, Flying his Kolb Flyer in an exibition. | Ed Diebel Good Ed/Gang: Sorry to hear about Dale Cross. I got a phone call from Travis Brown, New Kolb Aircraft, early this morning informing me of the accident and loss of Dale. Travis had no other information other than he had died as the result of a crash of his Flyer. There will probably be a report in the FAA Daily Accident Report, later this morning. We can do a search of TV stations and news papers in the area of Groves, TX, and get more info. Do we have anyone in that area? What event was Dale attending? I have known Dale for many years, but only at Sun and Fun, and Oshkosh. A few years ago, Dale's Flyer was flipped over on its back during a thunderstorm at Oshkosh. Last time I saw him was at Lakeland this year. Take care, john h ________________________________________________________________________________
Date: Oct 04, 2004
| A few years ago, Dale's Flyer was flipped over on its back | during a thunderstorm at Oshkosh. Hi Gang: I should further explain that the Flyer was tied down at the time it flipped over. Dale was not flying it. john h ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: Del Cross
If you type in - www.abc13.com - There is a picture of Dell Cross's Kolb Flyer after the crash. I think his plane was 24or 25 years old. The last time I saw Him I commented to Him he should replace the rusty 1/16 cables to the rudder with new 3/32" ones, but I dont think he felt a need to. Dont know if that was the cause or not. There was an autopsy ordered but Im not sure how to find the results. I think the FAA is going to investigate the crash. Wish I new more. Ed Diebel ________________________________________________________________________________
Subject: Re: harley
Date: Oct 04, 2004
For all of you wishing for the sound of a Harley on your Kolbs - a solution > exists! It's called a Verner. Same two big air-cooled jugs (1400cc), same > RPM range, same throaty sound from minimal exhaust pipes. 165 lbs. Biggest > difference is the Verner's two cylinders are 180 degrees offset from each > other, compared to Harley's 45. But the sound is the same. Even does the > "potato-potato-potato" at idle. How many hundred thousand of them are out there running? Can I stop over to the local Verner dealer and pick up a part in a jiffy? They have a factory in the USA? snuf Do not archive ________________________________________________________________________________
Subject: Re: harley
Date: Oct 04, 2004
Good grief! Dont you have any noise controls in the USA.? > Here in theEurope we have to go to great lengths to REDUCE the noise from > our a/c. Every engine/aircraft/propeller combination has to be measured > according to laid down criteria and if you are too noisy, you don`t fly. Thanks Pat!! Next time I fly over the vast wilderness of England I'll muzzle my Hog. snuf Do not archive ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: Bose
In a message dated 10/4/2004 2:27:26 PM Eastern Standard Time, lynnp@c-gate.net writes: Kolbers, Well... add another 2 grand to the cost of the Kolbra but I will have the Bose AR headsets or at least one in it. Yesterday I got my first ride in Charleys RV8 and he has them in that plane. What a difference they make! So if you want to lose the noise and can drop a grand go for it! Worth every penny. Paul Petty They probably won't be near as effective in your MkIII as in the RV-8. I haven't found anything more effectivre than my LightSpeed QFR Crosscountry with ANR at only about $300. Try the Bose in your plane before you buy. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: Bose
In a message dated 10/4/2004 3:52:47 PM Eastern Standard Time, HShack(at)aol.com writes: They probably won't be near as effective in your MkIII as in the RV-8. Sorry; Kolbra. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: Re: Bose
Date: Oct 04, 2004
I have a Headsets brand of ANR in my Sigtronics headset. They are sold as a user installed kit that fits in most headsets. With my low RPM VW they work super in fact they worked so well that I couldn't hear the engine go to 14,000 RPM when it self districted after the reduction drive failed. They are $160 for the kit. I can't say they will work in a plane with a High RPM engine but they work very well for me. There is only so much any ANR can do, the higher frequencies waves happen faster than thy can be canceled. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: <HShack(at)aol.com> Subject: Re: Kolb-List: Bose > > In a message dated 10/4/2004 3:52:47 PM Eastern Standard Time, > HShack(at)aol.com > writes: > They probably won't be near as effective in your MkIII as in the RV-8. > > Sorry; Kolbra. > > Howard Shackleford > FS II > SC > > > ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: Bose
In a message dated 10/4/2004 8:06:48 PM Eastern Standard Time, N27SB(at)aol.com writes: The Lightspeed cross country is mostly passive, the 3G is mostly active. It is hard to do both because of size constraints. The Bose is mostly active. You will probably have better results with the passive in a 912S, try both. A few days ago, I indicated that if I were rich, I would own the LightSpeed Thirty 3G instead of the QFRXCc, which I currently have. I based that strictly on the product comparison on LightSpeed's website. The Thirty 3G [at $650] shows several db's better active noise reduction than the QFRXCc [at $379]. I was able to actually try the Thirty 3G last Saturday in my FS II. In no way was it nearly as good as my cheaper set. My friend, Chuck Reinert would like to sell his barely used Thirty 3G for $400. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: ANR headsets
In a message dated 10/4/2004 9:04:32 PM Eastern Standard Time, 13brv3c(at)bellsouth.net writes: I still like the Lightspeeds, but realize that they (and likely others) have their limits. If anyone can suggest a good ANR headset that is known to work with a 912S in a pusher design like the Kolb, I'll need a set by about next Summer. When we finish the rebuild of the Mk III float plane & 912ULS install, we'll do a comparison of several headsets & report. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Oct 04, 2004
From: Charles & Meredith Blackwell <wozani(at)optonline.net>
Subject: sport pilot
The USUA has posted some new dates and information received from the FAA if anyone is interested, here is the link: The FAA has revised and added more detail to their Sport Pilot Implementation Timeline. Please see our Sport Pilot page (http://www.usua.org/SportPilot/) for complete details. Charlie, MKII in NJ ________________________________________________________________________________
Subject: ANR headsets
Date: Oct 05, 2004
Not to beat a dead horse about noise and headsets, but has anyone asked the guy's at Kolb what they use? Ken ________________________________________________________________________________
Date: Oct 05, 2004
| I've been lurking here getting info and your comments on the Kolb. I've | flown commercially for around 19 years, all of it in propeller driven | aircraft, and a lot of those are wayyyy noisier than the Kolb. | Garrett Smith Hi Garrett/All: Thanks for speaking out. However, I will have to strongly disagree with your comment reference noise. My MKIII is far noisier than any of the aircraft you reference. Fully enclosed Kolbs are much noisier than open cockpit Kolbs. Beavers, Otters, and 185's are pussy cats compared to UH-1's and other Army turbine powered aircraft. My MKIII is noisier than any Army helicopter I have flown and/or rode in except the CH-47 models. I too have been using David Clark headsets for a long time, since I built my Firestar in 1987. I wore out two sets of H10-40's, and am working on a H10-13.4. Throw in a Sigtronics headset I tried but did not particularly like for a few hundred hours and the Litespeed headset about 10 years ago that did not work with the 912, too. DC's do a good job of passive noise attenuation and some day some one will come up with a good set of active noise attenuation headsets to maybe save a little of my hearing. I suffer not only hearing loss, but experience accelerated fatigue flying in an extremely noisy environment. I do agree that DC has excellent quality control, rapid repair turn around, and are built to last for a long, long time. Take care, john h ________________________________________________________________________________
Subject: Re: Airplane noise: UK vs. US
Date: Oct 05, 2004
Very nicely said, Dennis. I agree with you 100%. Stay with us, Pat, your posts are greatly enjoyed. Lar. Do not Archive. Larry Bourne Palm Springs, CA Building Kolb Mk III N78LB Vamoose www.gogittum.com ----- Original Message ----- From: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil> Subject: Kolb-List: Airplane noise: UK vs. US > > > (Note - I changed the subject line. Discussion originated with talk of > the > "wonderful" sound of a Harley engine on a Kolb. ) > > "PATRICK LADD" wrote: > << Good grief! Dont you have any noise controls in the USA.? > Here in Europe we have to go to great lengths to REDUCE the noise from > our a/c. >> > > and snuf answered: > << Thanks Pat!! Next time I fly over the vast wilderness of England I'll > muzzle my Hog. snuf >> > > Patrick - > > I hope your sense of humor will keep you tuned in, just to see what > happens > next! > > In all seriousness, we understand the benefits of quieter airplanes. > We've > all heard the stories of little airports getting closed down because of > local residents complaining about airplane noise. But, as snuf eludes to, ________________________________________________________________________________
Date: Oct 05, 2004
In a message dated 10/5/2004 8:37:07 PM Eastern Standard Time, jhauck(at)elmore.rr.com writes: If I knew the DC ANRs would work in my airplane, I would order a set to see the results. One of these days. Take care, john h My stepson is sending me a set he wore when he flew helicopters. Will test & report. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Oct 05, 2004
I think I previously made a comment about noise-reducing HS ...my comment was that most (I haven't tried many) noise-reducing HS are primarily designed and sold for use in GA a/c...meaning low rpm 4-6cyl 4 strokes. The noise spectrum of 2 cyl 2 stroke is decidedly different, Try before you buy. Bob N. ________________________________________________________________________________
Subject: Mk3/912: Testing And Tweaking
Date: Oct 05, 2004
Went flying both of the last two evenings. Hazy but calm, just right for continuation of my testing and tweaking my Mk3/912. (1) My oil temp has not been above 140% so I added a 2"x2" temporary air block to the front of the oil cooler to get the temp up to where it would vaporize any water out of the oil. The result was 188% after a good warm up on the ground and little change during flight. This worked so well I will have to remove the temporary block (duct tape) and replace it with something more sophisticated. (2) During low power stall testing the left wing falls first regardless of how I dance on the the rudder peddles or how slow I approach the stall condition. It is not the gentle, straight-forward stall of my other Kolbs but mildly abrupt. I intend to do a precision check of rigging then consider adjusting the left wing cord line. (3) My Aircom hand held radio has served me well using an underside antennas but lately my communications using a rubber ducky have been noisy at best. Tested out my new underside antenna with "5x5" results. I can now hear all that chatter that does not concern me when I turn the squelch way down. (4) 'Took the time to remove the whiskey compass adjustment cover and bring along a non-magnetic screwdriver for the last flight of the day. I flew the four major compass points per my GPS and aligned the whisky to match. Not much to it but now I can depend on that unit too. (5) 'Always wondered if those plastic streamliners on my struts made any real difference. Mine have not been riveted to the strut and sometimes they change position in flight. While flying straight and level I reached down to the root of one streamliner and gave it a twist. Answer: Yes they do. I will now align them for max streamline effect and rivet them in place. 'Next four days I'll be doing family stuff (Brunswick GA), Duane the plane Mitchell, Tallahassee, FL, Mk3/912 ________________________________________________________________________________
Date: Oct 05, 2004
At 09:27 PM 10/5/2004, you wrote: >The noise spectrum of 2 cyl 2 stroke is decidedly different, Try before >you buy. I've tried RAD, DCs, the Lightspeed 15XL, the Lightspeed 20 3-G, and the Lightspeed CrossCountry ANR, and there's no comparison... the CrossCountry ANR works best in 2-cycle ultralights. YMMV. -- Robert ________________________________________________________________________________
Subject: Re: Mk3/912: Testing And Tweaking
Date: Oct 05, 2004
Hi Duane/All: The 912 runs relatively cool. During the winter I by passed the oil cooler completely. It is imperative to run the eng oil tem at 190F or higher to keep condensation and other "stuff" cooked out of the crank case and oil system. Also, there is a tremendous difference between eng temps at 5,000 rpm and higher, and eng speeds below 5,000 rpm. As soon as I would come off cruise rpm, 5,000, eng oil and cyl head temps dropped rapidly. The book says minimum cyl head temps are not important, but I have found the 912 and 912S perform better if the CHT is kept up near 180F and higher. | (1) My oil temp has not been above 140% so I added a 2"x2" temporary air block to the front of the oil cooler to get the temp up to where it would vaporize any water out of the oil. The result was 188% after a good warm up on the ground and little change during flight. This worked so well I will have to remove the temporary block (duct tape) and replace it with something more sophisticated. Duane, do you think the left wing is dropping because you are sitting in the left seat? Try flying and stalling from the right seat and see if that makes a difference. Also, dancing on the rudder pedals has little to do with lifting a wing on a Kolb airplane. Ailerons usually work right through the stall in keeping the wings level. | (2) During low power stall testing the left wing falls first regardless of how I dance on the the rudder peddles or how slow I approach the stall condition. It is not the gentle, straight-forward stall of my other Kolbs but mildly abrupt. I intend to do a precision check of rigging then consider adjusting the left wing cord line. Take care, john h ________________________________________________________________________________
Date: Oct 05, 2004
I believe the issue here becomes the environment the headsets are used in, throaty lower RPM 4-strokes or screaming high pitch high RPM 2 & even 4 strokes. When I stopped at the Lightspeed booth at Sun & Fun a year ago, they recommended their passive headset. They were very assertive the active noise reduction units would not work well in a UL Rotax type environment. I found the lower priced $149 unit to be a little muffled, the $199 was much clearer and crisper while at the same time being more comfortable. It uses the same speaker as in there more expensive units. jerb > >Hi Everyone: > >I've been lurking here getting info and your comments on the Kolb. I've >flown commercially for around 19 years, all of it in propeller driven >aircraft, and a lot of those are wayyyy noisier than the Kolb. Dehavilland >Single-Otter, Beaver, C-185, Twin Otter and other piston airplanes. My >input on the headset issue will be limited to the brand names I have tried >and have heard my colleagues talk about and use. I have spent my entire >career in between the David Clark headsets, and have used their ANR headsets >on a number of occasions and feel they are one of the best. My reasons are, >DC makes a robust unit that will stand up to hard use, they have been around >a long while and the quality control of the headset components is equal to >or better than others I have tried. If, when, I buy another, it will most >likely be the David Clark ANR headset. > >A number of friends have the Bose headset and LOVE them, light weight, >comfort, good noise attenuation and quality sound are all the qualities they >liked. They are a bit lighter than the DC, and a bit more comfy, but I am >used to the DC. The BOSE is more expensive than the DC by a significant >margin, so you'll have to do your due diligence and decide how much you want >to spend. > >I have tried a number of other headsets, during an evaluation with a company >I used to work for, but felt that these units weren't robust enough for the >torture they receive on a daily basis during commercial use. > >As I mentioned above I like the DC because it's tough, reasonably priced, >and DC has been around for a long time and they back their product. > >I hope my comments help, I will add that the evaluation I was involved with >was about 4 years back, so headsets have probably improved since then, and >hopefully the price has come down. > >Regards, >Garrett Smith ________________________________________________________________________________
Date: Oct 06, 2004
> >I think I previously made a comment about noise-reducing HS ...my >comment was that most (I haven't tried many) >noise-reducing HS are primarily designed and sold for use in GA >a/c...meaning low rpm 4-6cyl 4 strokes. >The noise spectrum of 2 cyl 2 stroke is decidedly different, Try before >you buy. > >Bob N. > Kolbers, I used a Lightspeed 15XL ANR head set with the FireFly with Rotax 447 engine mounted. The head set did a good job, and helped make one hour flights much less tiring than before I used them. Then I mounted the Victor 1+. It is a quieter engine due to water cooling and a very effective muffler. With the Victor 1+ the ANR head set knocked out too much of the low frequency noise, and I could hear the reed valves clicking or slapping. On hour flights I found this irritating. Because the engine was so much quieter, I returned to a passive headset so the low frequency sound would mask the reed valve slap. I have an advantage of flying without a full enclosure. I may get beat up by noise from the rear, but I do not get reflected noise off the inside of the enclosure. So, ANR headsets may work a little better under open cockpit conditions. Another thing that has helped reduce cockpit sound pressure has been the change from a two to a three blade propeller. With two blades set at 19 degrees, they both pass by the wing trailing edge at about the same time which give a couple of "Whumps" per propeller rotation. With the three blades set at 13 degrees this changes to six much smaller "Whumps". The propeller sound frequency is up but the amplitude is down, and it is the amplitude over time that wears you out. Also streamlining the struts removed a low frequency strumming like that of a bass viol during flight. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Oct 06, 2004
Subject: Paying the bills
Pat A friend of mine came back from a flight to Canada and a few days later a bill for several hundred dollars came his way from the Canadian Gov.. Use of Air Traffic control resources. He was billed for each use of their facilities--either on the ground or in the air. How about the light aircraft group. Do you have to pay also?? Herb in Ky > pj.ladd(at)bt.internet.com do not archive ________________________________________________________________________________
Date: Oct 07, 2004
From: "George E. Myers Jr." <gmyers(at)corridor.net>
Subject: Twinstar Documentation
Hello Kolb owners, My name is George and I have recently joined your esteemed ranks with the purchase of a Twinstar. What I can gather from searching the archives is it is a late 80's model. The uncertainty arises from the fact that no documentation came with it. None, zip, zilch! And other than a bent wing & broken axle it is in great shape. I plan on repairing the wing & recovering the entire plane but I need a construction manual, and a user manual if possible. If anybody out there has one I could beg, borrow, or purloin I would be forever grateful. Of course I would happily chip in the necessary bucks too. Thanks George E. Myers Jr. San Marcos Tx. http://geohome.sytes.net gmyers(at)corridor.net ________________________________________________________________________________
Date: Oct 07, 2004
Welcome George, Have you asked TNK about the documentation? The Twinstar was a little before their time, but there's a chance they can still provide documentation. The SS I just purchased didn't come with any documentation either, and TNK was happy to provide a builders manual, and plans at a reasonable cost. In fact, they just arrived today. Cheers, Rusty ________________________________________________________________________________
Date: Oct 08, 2004
Subject: RE: Twinstar Documentation
Hello Kolbers, Thank you all for your help. From the reply's I've received I have determined that I have a Twinstar MKI or "Straight Twinstar" the original 2 seater. I still haven't located any docs but from the responses so far I feel certain some will turn up. I have also located a supplier for the tubing (Dillsburg Aero Works) who has the really thin walled stuff that's on this one. Thanks again dudes George George E. Myers Jr. San Marcos Tx. http://geohome.sytes.net gmyers(at)corridor.net ________________________________________________________________________________
Subject: Re: Twinstar Documentation
Date: Oct 08, 2004
Let me dig around a bit later and I will see if I can find the info. What part do you need to know about? ----- Original Message ----- From: "George E. Myers Jr." <gmyers(at)corridor.net> Subject: Kolb-List: Twinstar Documentation > > Hello Kolb owners, > My name is George and I have recently joined your esteemed ranks with the > purchase of a Twinstar. What I can gather from searching the archives is it > is a late 80's model. The uncertainty arises from the fact that no > documentation came with it. None, zip, zilch! And other than a bent wing & > broken axle it is in great shape. I plan on repairing the wing & recovering > the entire plane but I need a construction manual, and a user manual if > possible. If anybody out there has one I could beg, borrow, or purloin I > would be forever grateful. Of course I would happily chip in the necessary > bucks too. > Thanks > > > George E. Myers Jr. > San Marcos Tx. > http://geohome.sytes.net > gmyers(at)corridor.net > > ________________________________________________________________________________
Subject: Heavy Alerons & Flapps
Date: Oct 09, 2004
Things seen to be slow today so.... Over the years I have been hearing people talk about heavy ailerons and what they have done to fix the problem. More recently one mentioned that they had to slow down to lower their flaps. Also I have noticed in the Kolb demonstrators that the ailerons get heavy at higher speeds. I haven't changed the cord of my control surfaces nor have I changed the leverage with reduced aileron movement but my controls have a lighter feel. When I built my flaps and ailerons I used a product, sold by Aircraft Spruce, called trailing edge material Instead of the stock 3/16" trailing edge. I used this trailing edge material for streamlining reasons. It tapers to less than 1/16" at the trailing edge of my flaps and ailerons. I don't know that I have any less drag and I don't know for sure that this is the cause for the lighter controls but everything else in the control system is 100% stock. Also I can't understand how this might effect the control forces. Maybe these stock cord control surfaces aren't deflecting as much air as those with the 3/16" trailing edge but they seem to be just as effective and they take less force to use. Maybe some of our less aerodynamic challenged members can shed some light or throw water on this. Rick Neilsen Redrive VW Powered MKIIIc ________________________________________________________________________________
Subject: Re: Heavy Alerons & Flapps
Date: Oct 09, 2004
How many have tried spaces on Kolb ailerons? Is that a structural possibility, or problem? Jimmy ----- Original Message ----- From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> Subject: Kolb-List: Heavy Alerons & Flapps > > Things seen to be slow today so.... > > Over the years I have been hearing people talk about heavy ailerons and what they have done to fix the problem. More recently one mentioned that they had to slow down to lower their flaps. Also I have noticed in the Kolb demonstrators that the ailerons get heavy at higher speeds. I haven't changed the cord of my control surfaces nor have I changed the leverage with reduced aileron movement but my controls have a lighter feel. When I built my flaps and ailerons I used a product, sold by Aircraft Spruce, called trailing edge material Instead of the stock 3/16" trailing edge. I used this trailing edge material for streamlining reasons. It tapers to less than 1/16" at the trailing edge of my flaps and ailerons. I don't know that I have any less drag and I don't know for sure that this is the cause for the lighter controls but everything else in the control system is 100% stock. Also I can't understand how this might effect the control forces. Maybe these stock cord control surfa! > ces aren't deflecting as much air as those with the 3/16" trailing edge but they seem to be just as effective and they take less force to use. Maybe some of our less aerodynamic challenged members can shed some light or throw water on this. > > Rick Neilsen > Redrive VW Powered MKIIIc > > ________________________________________________________________________________
Date: Oct 09, 2004
At 10:35 AM 10/9/2004, you wrote: > > >Things seen to be slow today so.... > >Over the years I have been hearing people talk about heavy ailerons and >what they have done to fix the problem. More recently one mentioned that >they had to slow down to lower their flaps. Also I have noticed in the >Kolb demonstrators that the ailerons get heavy at higher speeds. I haven't >changed the cord of my control surfaces nor have I changed the leverage >with reduced aileron movement but my controls have a lighter feel. When I >built my flaps and ailerons I used a product, sold by Aircraft Spruce, >called trailing edge material Instead of the stock 3/16" trailing edge. I >used this trailing edge material for streamlining reasons. It tapers to >less than 1/16" at the trailing edge of my flaps and ailerons. I don't >know that I have any less drag and I don't know for sure that this is the >cause for the lighter controls but everything else in the control system >is 100% stock. Also I can't understand how this might effect the control >forces. Maybe these stock cord control surfa! >ces aren't deflecting as much air as those with the 3/16" trailing edge >but they seem to be just as effective and they take less force to use. >Maybe some of our less aerodynamic challenged members can shed some light >or throw water on this. > >Rick Neilsen >Redrive VW Powered MKIIIc http://www.mindspring.com/~possums/Xhingestrailingedge.jpg http://www.mindspring.com/~possums/HINGESML.jpg http://www.mindspring.com/~possums/ailermod.jpg Covered without the bumps using trailing edge material also. Have counter balance weights and 2 inch narrower ailerons all the way down. Just this narrowing allowed me to put extra 2 inches of throw in the "bell crank", so when you think "turn left" you have already turned. Moved the holes "in" instead of "out". They are still not heavy like the old ones were. ________________________________________________________________________________
Date: Oct 09, 2004
At 04:49 PM 10/9/2004, you wrote: >Moved the holes "in" instead of "out". They are still not heavy like the >old ones were. Should have said - moved the holes "out" instead of "in" This way the stick has to be moved much less to move the ailerons. I have the old controls - inside and back of the cockpit - not under the boom tube. ________________________________________________________________________________
Date: Oct 09, 2004
Excuse the typo. Meant to say "spades", not "spaces" ----- Original Message ----- From: "jimmy and jo ann" <hillstw(at)jhill.biz> Subject: Re: Kolb-List: Heavy Alerons & Flapps > > How many have tried spaces on Kolb ailerons? > Is that a structural possibility, or problem? > > Jimmy > ----- Original Message ----- > From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> > To: > Subject: Kolb-List: Heavy Alerons & Flapps > > > > > > > Things seen to be slow today so.... > > > > Over the years I have been hearing people talk about heavy ailerons and > what they have done to fix the problem. More recently one mentioned that > they had to slow down to lower their flaps. Also I have noticed in the Kolb > demonstrators that the ailerons get heavy at higher speeds. I haven't > changed the cord of my control surfaces nor have I changed the leverage with > reduced aileron movement but my controls have a lighter feel. When I built > my flaps and ailerons I used a product, sold by Aircraft Spruce, called > trailing edge material Instead of the stock 3/16" trailing edge. I used this > trailing edge material for streamlining reasons. It tapers to less than > 1/16" at the trailing edge of my flaps and ailerons. I don't know that I > have any less drag and I don't know for sure that this is the cause for the > lighter controls but everything else in the control system is 100% stock. > Also I can't understand how this might effect the control forces. Maybe > these stock cord control surfa! > > ces aren't deflecting as much air as those with the 3/16" trailing edge > but they seem to be just as effective and they take less force to use. Maybe > some of our less aerodynamic challenged members can shed some light or throw > water on this. > > > > Rick Neilsen > > Redrive VW Powered MKIIIc > > > > > > ________________________________________________________________________________
Subject: Quiet props
Date: Oct 09, 2004
I found out today how to have a very quiet prop. The key holding the flywheel sheered and turned my Mark III into a glider. Fortunately, I had just turned a close left base and just glided in for one of my best landings ever! Jim Mark III Charlotte, NC ________________________________________________________________________________
Subject: fall flight
Date: Oct 09, 2004
My flying buddy and myself took off about 10 am to a place called Zim MN. It's about a half an hour flight. The air was great, cool but great. The temp was probably 40 degrees when we took off. The water bomber that's based in Hibbing was doing some practice flights just south of where we landed. That big old bird is impressive. We left Zim about noon. There was lots of thermal action. I didn't expect that much but it was fun for awhile. Went back up about 4:30. Still bumpy but we haven't been able to fly because of the weather so it was perfect by me. I hadn't been up since Sept. 30Th. My buddy didn't stay up long though. I got 3 hours total in for the day. I ran out of sunlight. What a fantastic day. I took a few pics but my camera was set at 5.0 so I won't post any. I was told that the wind will be back up to the 20's again tomorrow. BUMMER Do not archive. Dan Charter FS1 ________________________________________________________________________________
Subject: Re: fall flight No. 2
Date: Oct 10, 2004
Don't let'm hurt your feelings, Pat. I'd rather have an adrenaline ride like that than be in any church anytime. Lar. Do not Archive. Larry Bourne Palm Springs, CA Building Kolb Mk III N78LB Vamoose www.gogittum.com ----- Original Message ----- From: "PATRICK LADD" <pj.ladd(at)btinternet.com> Subject: Re: Kolb-List: fall flight No. 2 > > < MN. > It's about a half an hour flight. The air was great>> > > Hi All, > I am glad you had a great flight. This is what happened to me. > Sunday morning, 9 o clock. Beginning of October. UK. There was a fly in at > Henstridge, about 30 miles away.The main wind indicator in the area is the > smoke from the cement factory chimney about 8 miles away across the valley > from my home . Known as `Smoky Joe`. The smoke was going straight up. > Great! > I rang Henstridge for joining instructions. Direction of circuit, QFE > etc., ________________________________________________________________________________
Date: Oct 10, 2004
Subject: VG's
I put 90 of these little things on my wings and flew yesterday. I didn't expect them to do a lot - so I put them on with the double stick tape so I could remove them later. They're clear lexan and the tape matches my wing color - so you don't really notice them. I was very impressed - and am going to leave them on. On take off I can point the nose up almost 35 degrees and hold the air speed just over 30 mph and it seems to just hang on the prop, and it really does knock about 4 or 5 miles off your stall speed. Impressed Possum possums wrote: Would like to order a set of you generators. How do I do it?? Harrison Designs, LLC Thanks, I look forward to your order! You're going to LOVE my VGs! Joa <http://www.landshorter.com>www.landshorter.com ________________________________________________________________________________
Subject: Challengers
Date: Oct 10, 2004
| I think that has protected the | potentially weak nose wheel, as I have had no trouble. | Pat Hi Pat/All: Generally, in the US, one can always tell a Challenger pilot by the cast, on the right leg, left leg, or both legs, that extends from his toes to his waist. Does Challenger still attach the nose gear to the fuselage with two stainless hose clamps? Seems that in most instances where a hard landing is involved, the nose of the aircraft is wiped off back to the pilots knees. Do they still use the cable between the gear legs to keep them from over extending? Does that have an adverse affect on landing in an unimproved area, i.e., tall grass, weeds, and small brush? or is the aircraft restricted to improved grass strips? Take care, john h ________________________________________________________________________________
Date: Oct 10, 2004
Subject: Re: genetrators
At 01:11 PM 10/10/2004, you wrote: >Hi, > Did you really put 90 on the wings??????????? Must have been a tongue > in cheek typo. Did you also order them rather than make them? The ones > that I have were made by the shackelford instructions. Although I only > have them on the ribs, there are only 8 per wing. It seems to accomplish > the same thing. >Larry Yes I did - actually 44 on each wing - that is what the template called for - two between each false rib - so I just followed the instructions. They are pretty small and don't have any sharp pointed edges like the "homemade" ones do. ....But they cost a dollar apiece - airplane stuff cost more - right? http://possums.photosite.com/vgs/ ________________________________________________________________________________
Subject: Re: Challengers
Date: Oct 10, 2004
> Hi Pat/All: > > Generally, in the US, one can always tell a Challenger pilot by the > cast, on the right leg, left leg, or both legs, that extends from his > toes to his waist. > > Does Challenger still attach the nose gear to the fuselage with two > stainless hose clamps? Seems that in most instances where a hard > landing is involved, the nose of the aircraft is wiped off back to the > pilots knees. > > Do they still use the cable between the gear legs to keep them from > over extending? > > Does that have an adverse affect on landing in an unimproved area, > i.e., tall grass, weeds, and small brush? or is the aircraft > restricted to improved grass strips? > > Take care, > > john h > > ________________________________________________________________________________
Subject: First flight in a used Firestar II
Date: Oct 10, 2004
Well, I finally flew the Firestar II that I bought from Ed Babovec last May. The plane is a product of the Old Kolb Company. He'd built the Firestar (nicely, I should add) and put the first 52 hours on the plane before I bought it. In case you wonder why I hadn't flown it before this, about all I can say is that between my work, which is irregular and demanding, the fickle weather, and the short sailing season here in Colorado, it was finally time now. The plane has a 503, with the intake and exhaust silencers. It still has the mechanical brakes and the steerable but not full-swiveling tailwheel. It also has a 2-blade wooden prop, 66" in diameter. As recounted earlier on these pages, the airplane is tail-heavy. I weighed 160 pounds, including my helmet and knee board, and still needed 45 pounds of lead ballast to get the center of gravity to 20.62 inches, which works out to 33.8% of the 61" chord length. The aft CG limit is 21.35", according to the plans I bought in 1966, so that gave me a slight bit of margin. I put this lead under the seat cushion, lashing it on securely with some marine cord that I'd actually gotten for my sailboat. According to the earlier plans that came with the plane, the CG aft limit is 23.68". Evidently, somewhere along the way, the aft CG limit changed rather drastically. In any case, my actual center of gravity location was a good one for this flight. As mentioned previously some months ago, I plan to sweep the wings back about 2 degrees with a simple bracket. This will shift the aerodynamic center aft and I won't need the lead ballast any more. My gross weight was right at about 600 pounds. The day was calm and gorgeous. Real pretty. I took off and climbed to 2,700 feet above the airport, did a little familiarization airwork and stalls, and landed. The airplane's airspeed indicator certainly read low most of the flight. I didn't carry a GPS along on this first flight, and didn't bother timing my path over the ground. But I really doubt that the stall speed is 10 mph at full power, or 18 mph at idle. At 50 mph indicated it wouldn't climb. That brought up another issue: climb performance seemed fairly dismal regardless of the speed I flew. Of course, I was relying on the tach, but it reached redline at full throttle and 45 IAS, which is reasonable. The maximum rate of climb I observed (didn't time it) was about 450 feet to the minute. Please bear in mind that my density altitude was probably about 7,500 feet here in Boulder, Colorado. The local airport is at 5,300 feet. And yes, I felt that this was quite poor climb in these conditions. What do you think? It will be interesting to evaluate different props, as well as correct the airspeed indicator. I had heard this airplane in the air before I bought it, and it was relatively quiet. From the cockpit, it was noisier than I'd like. A bit of a surprise: the intake and exhaust silencers help me to be a good neighbor but don't help me directly. Still, maybe they do; I've never flown one of these without those silencers. Maybe it's worse. Next time I'll wear hearing protection. As for its flying characteristics, about all I can say is that it's a lot different than my Cessna 180 Skywagon, Big Hammer. A lot different. The controls give good feedback as to the airspeed, but there's little warning before the gentle stalls. Visibility up and out to the sides is blocked by the leading edge of the wing. That and the center of gravity would have been improved if the cockpit had been moved forward, a non-trivial factory change. The visibility was reduced considerably by various reflections on the inside of the full windshield. I found that the rudder pedals were a bit farther forward than fits me, and the heel brake pedals were very awkward. My Firestar does have speed stability, as well as large pitch changes with power changes. I didn't make turns tight enough to explore the maneuvering stability, and didn't try any of the standard lateral-directional maneuvers except for gentle turns. The airplane flew fine, and seemed entirely adequate, as far as I took it. To properly give thanks, I'd need to list names from here to some place past the end of your patience. Ed, of course, and Gregg Waligroski deserve special thanks. Dave Dooley, not on this email forum and not a Kolb pilot, does too. Many of the regular contributors to this have helped out immensely with their advice, sent here and thereby broadcast generally. They didn't know that they were helping me, but they did. To everyone, many, many thanks. Dave Paule FS II (that I've finally flown) Cessna Skywagon, Big Hammer Boulder, CO ________________________________________________________________________________
Date: Oct 10, 2004
Subject: FIRESTAR II WANTED
A friend is looking for a clean, well built, flying Firestar II with a low time 503 DCDI. We are near Edgefield, SC & would like something no more than 250 miles from there. Please email details & price. Photos would be good, too. Howard Shackleford hshack(at)aol.com [803]359-1136 FS II SC ________________________________________________________________________________
Subject: Re: First flight in a used Firestar II
Date: Oct 11, 2004
Congratulations, Dave. Hopefully I won't be too far behind you. (now watch the b.s. fly :-) ) Slowpoke Lar Do not Archive. Larry Bourne Palm Springs, CA Building Kolb Mk III N78LB Vamoose www.gogittum.com ----- Original Message ----- From: "David Paule" <dpaule(at)frii.com> Subject: Kolb-List: First flight in a used Firestar II > > Well, I finally flew the Firestar II that I bought from Ed Babovec last > May. > The plane is a product of the Old Kolb Company. He'd built the Firestar > (nicely, I should add) and put the first 52 hours on the plane before I > bought it. ________________________________________________________________________________
Date: Oct 11, 2004
Subject: Sport Aviation Expo
No one has brought this up, any one planning on attending the U.S. Sport Aviation Expo 2004 Thursday, October 28 - Sunday , October 31, 2004 Sebring Regional Airport http://www.sport-aviation-expo.com/ ________________________________________________________________________________
Date: Oct 11, 2004
In a message dated 10/10/2004 6:41:22 AM Eastern Standard Time, pj.ladd(at)btinternet.com writes: What was that smell. Fuel! I look down and there is fuel swilling round my boots. Where did that come from?. A fuel line must have shaken loose. Good job the engine didn`t stop. I checked. Nothing loose. All fuel lines secure, fuel tank top screwed up tight. I can only think that the fuel came back up up from the tank through the breather hole while I was being put through natures tumble dryer. I have flown in bumpy conditions but that had never happened before. I considered driving to Henstridge instead of flying, but I just couldn`t face it. I went home. I am glad you had a pleasant flight. Cheers good story Pat, you are a good story teller, but, indeed, that is not too rare for a Brit. George Randolph The Villages, Fl ps I start my 1st story telling class this week....seriously ________________________________________________________________________________
Date: Oct 11, 2004
How does your plane climb in comparison to Gregg Waligroski's? It is about the same configuration so should be a good comparison. >From: "David Paule" <dpaule(at)frii.com> >Reply-To: kolb-list(at)matronics.com >To: >Subject: Kolb-List: First flight in a used Firestar II >Date: Sun, 10 Oct 2004 18:57:34 -0600 > > >Well, I finally flew the Firestar II that I bought from Ed Babovec last >May. >The plane is a product of the Old Kolb Company. He'd built the Firestar >(nicely, I should add) and put the first 52 hours on the plane before I >bought it. > >In case you wonder why I hadn't flown it before this, about all I can say >is >that between my work, which is irregular and demanding, the fickle weather, >and the short sailing season here in Colorado, it was finally time now. > >The plane has a 503, with the intake and exhaust silencers. It still has >the >mechanical brakes and the steerable but not full-swiveling tailwheel. It >also has a 2-blade wooden prop, 66" in diameter. > >As recounted earlier on these pages, the airplane is tail-heavy. I weighed >160 pounds, including my helmet and knee board, and still needed 45 pounds >of lead ballast to get the center of gravity to 20.62 inches, which works >out to 33.8% of the 61" chord length. The aft CG limit is 21.35", according >to the plans I bought in 1966, so that gave me a slight bit of margin. I >put >this lead under the seat cushion, lashing it on securely with some marine >cord that I'd actually gotten for my sailboat. > >According to the earlier plans that came with the plane, the CG aft limit >is >23.68". Evidently, somewhere along the way, the aft CG limit changed rather >drastically. In any case, my actual center of gravity location was a good >one for this flight. > >As mentioned previously some months ago, I plan to sweep the wings back >about 2 degrees with a simple bracket. This will shift the aerodynamic >center aft and I won't need the lead ballast any more. My gross weight was >right at about 600 pounds. > >The day was calm and gorgeous. Real pretty. > >I took off and climbed to 2,700 feet above the airport, did a little >familiarization airwork and stalls, and landed. > >The airplane's airspeed indicator certainly read low most of the flight. I >didn't carry a GPS along on this first flight, and didn't bother timing my >path over the ground. But I really doubt that the stall speed is 10 mph at >full power, or 18 mph at idle. At 50 mph indicated it wouldn't climb. That >brought up another issue: climb performance seemed fairly dismal regardless >of the speed I flew. Of course, I was relying on the tach, but it reached >redline at full throttle and 45 IAS, which is reasonable. > >The maximum rate of climb I observed (didn't time it) was about 450 feet to >the minute. Please bear in mind that my density altitude was probably about >7,500 feet here in Boulder, Colorado. The local airport is at 5,300 feet. >And yes, I felt that this was quite poor climb in these conditions. What do >you think? > >It will be interesting to evaluate different props, as well as correct the >airspeed indicator. > >I had heard this airplane in the air before I bought it, and it was >relatively quiet. From the cockpit, it was noisier than I'd like. A bit of >a >surprise: the intake and exhaust silencers help me to be a good neighbor >but >don't help me directly. Still, maybe they do; I've never flown one of these >without those silencers. Maybe it's worse. Next time I'll wear hearing >protection. > >As for its flying characteristics, about all I can say is that it's a lot >different than my Cessna 180 Skywagon, Big Hammer. A lot different. The >controls give good feedback as to the airspeed, but there's little warning >before the gentle stalls. Visibility up and out to the sides is blocked by >the leading edge of the wing. That and the center of gravity would have >been >improved if the cockpit had been moved forward, a non-trivial factory >change. The visibility was reduced considerably by various reflections on >the inside of the full windshield. I found that the rudder pedals were a >bit >farther forward than fits me, and the heel brake pedals were very awkward. > >My Firestar does have speed stability, as well as large pitch changes with >power changes. I didn't make turns tight enough to explore the maneuvering >stability, and didn't try any of the standard lateral-directional maneuvers >except for gentle turns. The airplane flew fine, and seemed entirely >adequate, as far as I took it. > >To properly give thanks, I'd need to list names from here to some place >past >the end of your patience. Ed, of course, and Gregg Waligroski deserve >special thanks. Dave Dooley, not on this email forum and not a Kolb pilot, >does too. Many of the regular contributors to this have helped out >immensely >with their advice, sent here and thereby broadcast generally. They didn't >know that they were helping me, but they did. To everyone, many, many >thanks. > >Dave Paule >FS II (that I've finally flown) >Cessna Skywagon, Big Hammer >Boulder, CO > > Check out Election 2004 for up-to-date election news, plus voter tools and ________________________________________________________________________________
Subject: RE: First flight in a used Firestar II
Date: Oct 11, 2004
How does your plane climb in comparison to Gregg Waligroski's? It is about the same configuration so should be a good comparison. ----------------- I don't know... haven't talked with him yet. He's got that 3-blade Kiev Hot-Prop, if I remember the name of it right. I don't have a full climb performance profile yet, so it is possible that I simply might not have the right speed dialed in yet. Perhaps the range of speed for which it climbs is narrow, especially with the airspeed indicating so low. Also, I have the intake and exhaust silencers, and he doesn't. However, I think his plane may fly at a higher weight than mine. Dave Paule Boulder, CO FS II (and I've finally flown it) ________________________________________________________________________________
Date: Oct 11, 2004
Subject: Re: Landing Challenger aka crosswind opn
I've landed my FireFly several times at 45 to the local 150' wide rnwy, and once almost crosswise. Usually there's a lot of wind, so I can get stopped before the grass at edges. Local rules don't allow operation on/off the grass-- it's pretty rough there anyhow. Bob N. ________________________________________________________________________________
Date: Oct 11, 2004
----- Original Message ----- From: "PATRICK LADD" <pj.ladd(at)btinternet.com> Subject: Re: Kolb-List: Challengers > Just been talking to my dealer and he has been experimenting with vortex > generators on the Xtra he is building and has concluded that they are > worth > the effort. Stalling speed lowered by about 5knots > pj.ladd@btinternet > Hi Pat, I used the V/G's of shacks design on my Original Firestar > before I started the rebuild and they lowered the stall about 5 kts. The > plane broke crisply without much warning. You might want to put them on > your horizontal stabilizer as well to make sure you have enough elevator > authority when landing at the lower speeds without power. I did not do > this and wheel landings were fine but full stall at minimum airspeed I > did not have enough elevator to get fat a** in a landing configuration > (working on the fat a** part). I probably will not put them back on because the way Hormer designed it with the new brakes from Brother Jim I should be able to land in a small pea patch as is (and it's much easier for my daughter to wash ). As for the Challengers I learned to fly ultralights in one and fly someone elses every chance I get, but would not buy one over a Kolb. JMHOFWIW Bryan Green Elgin SC Firestar I 19LBG 377 BRS > > > ________________________________________________________________________________
Subject: Reflections
Date: Oct 11, 2004
The reflections inside the full windshield were distracting yesterday when I flew my used Firestar for the first time. Anyone got any suggestions for getting rid of them? Um, without taking the windshield to an optics lab..... Thanks! Dave Paule FS II ________________________________________________________________________________
Subject: Re: Reflections
Date: Oct 11, 2004
| The reflections inside the full windshield were distracting yesterday when I | flew my used Firestar for the first time. | | Anyone got any suggestions for getting rid of them? Um, without taking the | windshield to an optics lab..... | | Thanks! | Dave Paule | FS II Dave/All: They all have reflections. I think the secret is not to concentrate on the reflections, but look outside the aircraft where you are flying instead. Reflections inside my fully enclosed MKIII cockpit are particularly annoying at night. Primarily because I do not have a glare shield. However, since I have accepted the fact that night flying in a MKIII for pleasure is not necessarily worth the risk, I don't fly at night unless I get caught out and can not get back before dark. Without redundant systems for landing lights, instr panel lgts, etc., it just is not worth the risk. Take care, john h ________________________________________________________________________________
Date: Oct 11, 2004
: Monday, October 11, 2004 7:56 PM Subject: Re: Kolb-List: Reflections > > | The reflections inside the full windshield were distracting > yesterday when I > | flew my used Firestar for the first time. > | > | Anyone got any suggestions for getting rid of them? Um, without > taking the > | windshield to an optics lab..... Just try to wear dark clothing, its the pants, shoes and socks that seem to cause most of mine. Larry ________________________________________________________________________________
Date: Oct 11, 2004
Subject: Tachometer w/double the rpm output
Can anyone help here? I have a Rotax 447 with Ducati single ignition. I purchased a tachometer from Aircraft Spruce, specifying this engine and ignition setup. The tach I received has the following id on the box: part number TA023, 3 1/8" Tach 8000 RPM Dual. The tach has a user modification for single or dual ignition, which is a small wire loop on the back. The diagram that came with it says for single ign., keep the wire loop intact. For dual ign., cut the wire loop. I connected the gray wire and a ground wire from the engine per Rotax wiring instructions. Since I have single ign., I did not cut the wire loop. But during operation, the tach appears to be indicating double the RPM (ie, at idle of about 2000 it shows 4000+) and with any increase in RPM, about half throttle, maybe 3500 RPM, the tach goes to the limit of 8000. I called Aircraft Spruce for advice and they referred me to the manufacturer (who I believe is just an importer/distributor because the tach is made in China), a company named Walltrube? The fellow I spoke to didn't have a clue. The box also has information stamped on it saying 916A Tach 3 1/8" Universal and another # T3-001U. So far, I am inclined to think that this tach is Universal, in that it may be used for either Points or Ducati ign. and the user modification of cutting the wire changes it from single to dual ign. I guess I'll cut the wire to see if that corrects the reading, but it may be hard to reconnect because it is very small and short, so I'll wait to see if anyone has a suggestion as to why I might be getting the double RPM output reading. Bill Varnes Original FireStar Audubon, NJ ________________________________________________________________________________
Date: Oct 12, 2004
Subject: Lucedale, Ms
Just wanted to let whoever wants to know that a bunch of our southern flyers group out of florida are going to Lucedale and Bev and I also. Taking my lit'l SlingShot and the RV. Leaving Wednesday morning and returning Sunday. Hope to see all there this weekend. Drop by for hotdogs. Our lot in life is to feed people. Would not miss it for the world. My baby is one year old this year. Not in diapers any more. ted cowan, alabama. ________________________________________________________________________________
Date: Oct 12, 2004
on 10/11/04 11:14 PM, Larry Cottrell at lcottrel(at)kfalls.net wrote: > > : Monday, October 11, 2004 7:56 PM > Subject: Re: Kolb-List: Reflections > > >> >> | The reflections inside the full windshield were distracting >> yesterday when I >> | flew my used Firestar for the first time. >> | >> | Anyone got any suggestions for getting rid of them? Um, without >> taking the >> | windshield to an optics lab..... > > > Just try to wear dark clothing, its the pants, shoes and socks that seem > to cause most of mine. > Larry > > > > > > It may be clumsy but a black sort of lap-robe should work. ________________________________________________________________________________
Date: Oct 12, 2004
Subject: Re: Tachometer w/double the rpm output
Bill, Cut the wire on the tach and that will solve your problem. The same thing happened on mine. Ralph Original Firestar 447 Ducati single ignition > > Can anyone help here? > > I have a Rotax 447 with Ducati single ignition. > > I purchased a tachometer from Aircraft Spruce, specifying this > engine and > ignition setup. The tach I received has the following id on the > box: part number > TA023, 3 1/8" Tach 8000 RPM Dual. The tach has a user modification > for > single or dual ignition, which is a small wire loop on the back. > The diagram that > came with it says for single ign., keep the wire loop intact. For > dual ign., > cut the wire loop. > > I connected the gray wire and a ground wire from the engine per > Rotax wiring > instructions. Since I have single ign., I did not cut the wire > loop. But > during operation, the tach appears to be indicating double the RPM > (ie, at idle > of about 2000 it shows 4000+) and with any increase in RPM, about > half > throttle, maybe 3500 RPM, the tach goes to the limit of 8000. > > I called Aircraft Spruce for advice and they referred me to the > manufacturer > (who I believe is just an importer/distributor because the tach is > made in > China), a company named Walltrube? The fellow I spoke to didn't > have a clue. > The box also has information stamped on it saying 916A Tach 3 1/8" > Universal and > another # T3-001U. So far, I am inclined to think that this tach is > > Universal, in that it may be used for either Points or Ducati ign. > and the user > modification of cutting the wire changes it from single to dual > ign. > > I guess I'll cut the wire to see if that corrects the reading, but > it may be > hard to reconnect because it is very small and short, so I'll wait > to see if > anyone has a suggestion as to why I might be getting the double RPM > output > reading. > > Bill Varnes > Original FireStar > Audubon, NJ > > > = > = > = > = > > > > > > Now includes pop-up blocker! Only $14.95/ month - visit http://www.juno.com/surf to sign up today! ________________________________________________________________________________
Date: Oct 12, 2004
Subject: Re:Reflections
David and Group, Here is what I did to minimise the problem of reflections: I painted the dash and about everthing else in the cockpit flat black and added black carpeting. I also wear a black jacket in cool weather. All this works well. But last spring, at Monument Valley, I carried my camera on a photographic flight, and not thinking, wore a white T-shirt. The reflections of that T-shirt ruined more than half my photos. John Jung _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Oct 12, 2004
At 08:57 AM 10/12/2004, you wrote: > >David and Group, > >Here is what I did to minimise the problem of >reflections: I painted the dash and about everthing >else in the cockpit flat black and added black >carpeting. I also wear a black jacket http://possums.photosite.com/Black/ I did the same thing - because of the pictures and also because I don't like to see the reflections. Everything forward of the seat cross bar is flat black. Also have a hood over my instrument panel and put fabric on the inside side panels front of the cross bar - also painted black. Don't wear light colored pants or light colored long sleeve shirts. Also wear a black glove on my right hand. But when it's hot I take the windshield off - lots of fun that way. ________________________________________________________________________________
Subject: Re: trailing edge
Date: Oct 12, 2004
Pat Yes the trailing edge material is used instead of the 5/16 .035 tubing. Note! This stuff weighs 12 oz per ten feet and 5/16 weighs 5 oz per ten feet so you will need the aileron balance weights. It is called "Trailing Edge" part number 03-48900 at Aircraft Spruce. It is stronger and eliminates the scalloping you see on the trailing edge of most Kolbs. I do feel that my controls are lighter but I don't have any way of measuring the difference. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "PATRICK LADD" <pj.ladd(at)btinternet.com> Subject: Kolb-List: trailing edge > > Hi all, > someone on the list recently had used some material called `trailing edge` > which had eased the aileron heaviness. > Can you tell me if this was used INSTEAD of the Kolb supplied material or > added to the rear of the trailing edge just to improve the streamlining. ________________________________________________________________________________
Date: Oct 12, 2004
I have gotten so that I don't see the reflections in my full enclosure MKIII while I'm flying. I do see those reflections in all my photos. I took a short photography class and the instructor suggested the following, lock the focus at infinity, set the exposure to under expose at least one stop, use a polarizing filter to eliminate the reflections, and a UV filter to reduce the haze. I ordered the filters and will try these things when my airplane is flying again. It looks like the 1st snow will get here before I get in the air again but hopefully I will be flying before all the fall colors are gone. AND definitely before Lar. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "David Paule" <dpaule(at)frii.com> Subject: Kolb-List: Reflections ________________________________________________________________________________
Date: Oct 12, 2004
How is the trailing edge attached. Possums posted some photos that looked like they were welded on. George At 10-12-2004, you wrote: > > >Pat George E. Myers Jr. San Marcos Tx. http://geohome.sytes.net gmyers(at)corridor.net ________________________________________________________________________________
Date: Oct 12, 2004
The trailing edges are attached with pop rivets. The trailing edge material is shaped somewhat like a V spread the V slip the ribs part way in and rivet. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "George E. Myers Jr." <gmyers(at)corridor.net> Subject: Re: Kolb-List: trailing edge > > > How is the trailing edge attached. Possums posted some photos that looked > like they were welded on. ________________________________________________________________________________
Date: Oct 12, 2004
Subject: Balloon tires on Firestar II
I am looking for an easy solution to what I thought would be a easy modification. I have a 98 vintage Firestar that I purchased used. I just started soloing the plane about a month ago. I have no general aviation experience so it took a lot of instruction to get to this point. Anyway, I am enjoying the Kolb and am thankful that the local Ultralight EAA chapter ( 115 ) advised to start with a Firestar. It is a very nice flyer compared to my instructors plane. I have made several changes and there is just one last project I would like to complete. I bought a set of Azusa Cast 6X4 wheels and 18 / 800 X 6 balloon tires. I will always work off of grass and want something that will be forgiving if I get a tire in a rough field. I have 4 1/2" drum brakes. The Firestar 5/8" axle has a flange welded onto it to mount the brakes. The standard wheels are wheelbarrow type. The new cast wheels are about an inch too wide to fit on the axles. I could get them to work if I took the brakes off but don't want to do that. The vendor said that the Azusa plastic wheels would work but he didn't recommend them with the balloon tires because the bearings could not take it. I called Kolb and they can send me the axle and the flange separately so that I could weld the flange so that the cast wheels will fit but the axles have to be heat treated after welding. That would be a long drawn out procedure to do all the sending back and forth and waiting. Has anyone put big tires on a Firestar before? Is there a simple solution? Thanks for your help. Larry Duncan in Mountain Home, AR. ________________________________________________________________________________
Subject: Re: Balloon tires on Firestar II
Date: Oct 12, 2004
| Has anyone put big tires | on a Firestar before? Is there a simple solution? Thanks for your | help. Larry Duncan in Mountain Home, AR. Hi Larry/Gang: Some years ago I tried 800X6 tires on my original Firestar. I felt they were a little too much and replaced them with 15.00X6X6's. The 15.00X6X6's did a good job for me. I never heat treated any axles on my FS. If by chance I bent them enough to require realignment, it was readily done by bending the back to the point they were supposed to be using a 6' piece of galvanized water pipe that would slip over the axle after the gear leg and axle were placed on something to block it up. This system worked great. Take care, john h PS: Some of us are running 8.00X6's on our MKIII Classsics and Kolbras with good success. However, the best tires, I have found, are aircraft tires and not the ones sold by the UL parts houses. The McCreary Airtracs are trued and balanced prior to leaving the factory. They are also rated for 120 mph. The garden shop variety are not trued or balanced and are for slow speed off road only. ________________________________________________________________________________
Subject: Fw: [carolinasportflyers] Carolina Sport Flyers Annual Fall
Fly-in
Date: Oct 12, 2004
Bryan Green (Elgin SC) ----- Original Message ----- From: John Davis Subject: [carolinasportflyers] Carolina Sport Flyers Annual Fall Fly-in Note: forwarded message attached. John W.Davis-AFI Bishopville,SC Carolina Sport Flyers patches11us(at)yahoo.com HI-LO Ultralight-Sport Planes ADVERTISEMENT a.. To visit your group on the web, go to: http://groups.yahoo.com/group/carolinasportflyers/ b.. To unsubscribe from this group, send an email to: carolinasportflyers-unsubscribe(at)yahoogroups.com ________________________________________________________________________________
Subject: Floats
Date: Oct 13, 2004
I think someone at the Kolb Fly-in said the float development was stopped because the cost and complexity was getting out of hand. You might want to give them a call to make sure. Rex Rodebush From: robert bean <slyck(at)frontiernet.net> Subject: Re: Kolb-List: Re:Reflections Speaking of swimming... has TNK arrived at a pricetag for their MkIII amphibious floats? They sure look like an attractive option. ________________________________________________________________________________
From: Kirby Dennis Contr MDA/AL <Dennis.Kirby(at)kirtland.af.mil>
Subject: Breaking Cable Splitters
Date: Oct 13, 2004
Kolb Friends - I'm having problems with the cable splitters on my Mark-III. Seems the ends are breaking free from the splitter body. I'm referring to the little nipple ends that the cable housings fit into - one on the bottom, two on top. The whole assembly is aluminum, and I thought those nipple ends seemed somewhat fragile when I first installed them. Sure enough ... they're breaking off the splitter body. Is this common? Is there a solution to fix? I'll likely order new ones, but can I prevent a reoccurance in the future? Many thanks - Dennis Kirby Verner, Powerfin-72 in New Mexico ________________________________________________________________________________
Subject: Re: Breaking Cable Splitters
Date: Oct 13, 2004
Dennis/Gang: | Is this common? First I have heard of it. Is there a solution to fix? Still not quite sure what the problem is and why it is happening. Just took a look at a couple I have on the bench that were probably used with my 582 10 years ago. Looks like it would be pretty difficult to break one. Got some pictures of the problem? Take care, john h ________________________________________________________________________________
Subject: skyboy
Date: Oct 13, 2004
kolbers just stumbled on a web sight for sky boy aircraft . Anybody know any thing good or bad about them . Anyone flown one thanks just curious ,similar too mk three in cofig . chris ________________________________________________________________________________
Subject: Re: skyboy
Date: Oct 13, 2004
Used to be a Skyboy aircraft located at the Rimrock airport. Owner seemed to have a lot of difficulty keeping it flyable (couple of minor mishaps, I think). That owner sold it before he had it a year. Elevation there was 4k, so it might have been a bit underpowered (had a 912). I remember a lot of comments about it when it arrived, and a lot of thank you's when it finally left. Noone wanted to see it again. Sorry if this is a bit vague, but, it is mostly due to 2nd & 3rd-hand comments. None of which came from the owner, just others who are based on the field. Also, this is from a year or two ago, maybe there have been some improvements. George Bass USUA #30899 --- ________________________________________________________________________________
Date: Oct 13, 2004
Subject: Re: skyboy
Do a search on the UL list. The plane seems to had it share of incidents, more than one would expect for the number of units in the field. Investigate it much more thoroughly before jumping in. jerb > >kolbers just stumbled on a web sight for sky boy aircraft . Anybody know any >thing good or bad about them . Anyone flown one thanks just curious >,similar too >mk three in cofig . chris > > ________________________________________________________________________________
Subject: Sebring Sport Aviation Expo
Date: Oct 13, 2004
I am making plans to drive to Sebring on the 28th or 29th of Oct. 'Looks like it's going to be a major event. Hope to see George Randolph, Richard Swiderski, Beauford T., Steve Boetto et al while I am there. How's about it guys ? Duane the plane Mitchell, Tallahassee, FL, Mk3/912, 12 hrs ________________________________________________________________________________
Date: Oct 13, 2004
Subject: Re: skyboy
At 04:58 PM 10/13/2004, you wrote: > >kolbers just stumbled on a web sight for sky boy aircraft . Anybody know any >thing good or bad about them . Anyone flown one thanks just curious >,similar too >mk three in cofig . chris My friend has one... he let me fly it once... it has a 582. It was a bit too "GA-ish" for me, too enclosed... I prefer the wide-open air. For the short time I flew it, I didn't notice any negative characteristics (I flew it from the left seat) other than being a bit cramped. -- Robert ________________________________________________________________________________
From: "Edward Steuber" <esteuber(at)rochester.rr.com>
Subject: SKYBOY
Date: Oct 14, 2004
I usually don't bad mouth anybody's aircraft cause some pilots take it real personal....Everything Beauford said is correct about the 582 Skyboy. A friend of mine owns one here in Western NY and I flew it with the owner...I am 210# and he has to be close to that...cool day.... flys like it is very overloaded.....it really needs 125-150 hp. Just bought an old wrecked CGS HAWK for a rebuild this winter...right after the Agcat (business first ), Stinson L5,and 2 Cassutt Racers ......suppose to be a long winter....may get them finished if the winter lasts into 2006 and it sounds like it may. And for all you young guys joking about us seniors ...........Youth is wasted on the young! Ed in Western NY ________________________________________________________________________________
Subject: Good Service
Date: Oct 14, 2004
I ordered a Matco tailwheel assembly, the T-6 model, through Chief Aircraft on Tuesday. I didn't request any special shipping. Today, Thursday, it arrived. These are drop-shipped from the factory in Utah. Great service! Dave Paule FS II Boulder, CO ________________________________________________________________________________
Date: Oct 14, 2004
----- Original Message ----- From: "PATRICK LADD" <pj.ladd(at)btinternet.com> Hi Patrick/Gang: | Which brings me to the scare stories on this list about landing the Kolb. People who have difficulty landing Kolbs are low time inexperienced pilots. They may have thousands of hours in "other" type aircraft, but not much in Kolbs. | It won`t flare, wheel it on, keep the speed up, take the flaps off etc., buy a | spare set of u/c legs, I bend the axles straight with a piece of water pipe` | was one quote. I don't have any problem flaring, stalling three point landings, full flaps, engine off. Most Kolb pilots do not have a problem landing them. They are a piece of cake. I have straightened axles on the Ultrastar and Firestar using a piece of water pipe. Also straightened gear legs with hydraulic press. I am an aggressive pilot. I fly in and out of fields normal airplanes don't fly. Always have since I started flying these little Kolbs summer of 1984. | Has anyone really looked at this? Is the problem real or imagined? All Kolbs | or some specific models? The problem is not the airplane, but the pilot. |One of the test pilots | `arrived` hard enough to blow a tyre. Still no deformation. What is going | on? You tell us. I have never heard of a Kolb blowing a tire until your email. I have had some terribly hard (crash) landings. Never blown a tire, even the old golf cart, garden type tires. Kolb pilots that have problems landing Kolbs, are probably hesitant to land with full flaps, with or without power, probably do not practice using them, probably will never learn to use them. They are a tremendous asset to the safety and survivability of the Mark III. I don't care too much about the flaperons on the SS, FF, or MKIIIX, but I love my 20 deg and 40 deg flaps on the MKIII. Would not leave home without them. The more you use them the more familiar and comfortable you get with them. Same same engine off (completely or idle power) landings. Then......when you need them, it all comes naturally. Sorry, no tests. I thought this wasn't a graded exercise. :-) Take care, john h ________________________________________________________________________________
From: "Richard Swiderwski" <rswiderski(at)earthlink.net>
Date: Oct 14, 2004
Hey Duane, I won't be going to Sebring, but I'd sure like to. I'm 2 miles off I-75 so give me a call as you are passing by & maybe I could fix you up with a cup of coffee and a short break. 352-307-9009. ...Richard Swiderski -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of H MITCHELL Subject: Kolb-List: Sebring Sport Aviation Expo I am making plans to drive to Sebring on the 28th or 29th of Oct. 'Looks like it's going to be a major event. Hope to see George Randolph, Richard Swiderski, Beauford T., Steve Boetto et al while I am there. How's about it guys ? Duane the plane Mitchell, Tallahassee, FL, Mk3/912, 12 hrs ________________________________________________________________________________
Date: Oct 14, 2004
Subject: Re: Powder Coating 6061-T6 Alum.
I have been advised by some "engineer-types" that powder coating [process] weakens 6061-T6 Aluminum because of the heat. I had my lift struts & fuselage boom tube powder coated before I found this out; been a little worried about it. Now, I read on TNK website that they offer powdercoating on their boom tubes; should I feel better???? Howard Shackleford FS II SC ________________________________________________________________________________
Date: Oct 14, 2004
From: Eugene Zimmerman <eugenezimmerman(at)dejazzd.com>
Subject: Re: Kolb Fly-in Photos
Hi Tom, Welcome to the Kolb list. This list is probably the best group of Kolb builders and owners you are going to fine anywhere. It is your most helpful source of information along with the factory about anything relating to Kolb aircraft. As concerning a reliable comparison of the Kolb's vs. competitive aircraft, I am not aware of any attempts to officially objectively compare various ultralight/sport aircraft. Of course pilots have been comparing and competing their planes since the Wright Bros. The mags. give flight reports on various planes and Kolb has always had good reviews but I have never seen an actual comparison. Kolb enjoys stellar reputation in the ultralight/sport aircraft community. Kolb planes may not be the best at everything but they are outstanding in everything and unexcelled in some things. For example, All Kolb planes are unexcelled in their ease to fold the wings for storage saving many owners tons of money on hanger rent fees. Kolb planes enjoy an excellent reputation for short take off and steep climbs and along with their short landing capability. Their responsive controls are an industry standard of comparison. I have been flying Kolb planes since 1982, let me see thats 22 years,(wow! and I aint old yet) and I have not been disappointed with them ever. Im not sure about a Mark III owner near Allentown but dont be surprised if someone takes you up on your offer. How about it folks any body near Allentown PA with a Mark III? Gene Tom O'Hara wrote: > Gene-- I got your email from the photos that you had placed on the net > regarding the Kolb fly-in. I have been flying for some 40+ years and > actually grew up in Oshkosh. The last 22 years flying has been a > commercial ticket for LTA. However, lighter than air is heavy as hell > and my back is turning 58 next week! Have been considering trading the > balloon in for an ultra light/sport and the Kolb Mark III extra kind of > caught my eye. > > Haven't found the factory to be very responsive- although haven't tried > to get too much info from them. However, is there an owners group and > listing where I might find an owner near Allentown, PA? Would consider > trading some Kolb time for some balloon time. Is there a reliable > comparison of the Kolb's vs. competitive aircraft? How long have you > been flying a Kolb-- and your opinions?? You know all the normal stuff > one needs to know both pro/con > > Thanks for your time. > > Tom O'Hara ________________________________________________________________________________
Date: Oct 14, 2004
> > >Which brings me to the scare stories on this list about landing the Kolb. It >won`t flare, wheel it on, keep the speed up, take the flaps off etc., buy a >spare set of u/c legs, I bend the axles straight with a piece of water pipe` >was one quote. >Has anyone really looked at this? Is the problem real or imagined? All Kolbs >or some specific models? Sounds like fish or war stories. Who would raise the flaps while landing - the reason for using flaps is to add drag to permit a steeper approach without increasing speed and to reduce your landing (stall) speed - slower equates to less roll out and quicker deceleration thru the phase from touch down to slow taxi. It is a common occurrence for new Kolb pilots to bend a one or both gear legs early on by allowing the plane to get to slow as they round out thus resulting in it dropping in hard. Unless they are bent real bad they usually can be straighten out on a hydraulic press two or three times before being replaced. Been there done that. Deflates your pride as your taxi your crippled ship back to the hangar. The biggest problem with the new pilots is allowing it to get to slow as once you start bringing the nose up, Kolbs bleed speed off quite quickly. The gear on a FireStar at our field has been bent three times, once by the co-builder on the first flight, then by the owners instructor, then by owner himself. The all fell into the same trap that I had warned them about, don't get it to slow during the flare until their more familiar with the airplane. One they each had learned that lesson they had no further problems there after. jerb ________________________________________________________________________________
Subject: HAC Carb
Date: Oct 14, 2004
I need a compensation chamber for a HAC carburetor. Anyone have a chamber they are willing to sell? Vic ________________________________________________________________________________
Date: Oct 14, 2004
Howard, You have to specify powder coating paints that require lower cure temps. Most powder coatings are cured at 325-375F for 12-20 minutes, metal temperature. Actual oven temperature may need to be substantially higher to get the metal to temp in a reasonable amount of time and I'll bet that the temps vary from shop to shop. 6061-T6 has an ultimate tensile strength of 45,000 psi at 75 degrees F, 42,000 psi at 212 degrees F, 34,000 psi at 300 degrees F and goes down to 19,000 psi at 400 degrees F (roughly half...) (Source: Mil-Hdbk-5 & Metals Handbook, 2nd ed.) From a web site specializing in Powder coating (http://my.execpc.com/~davewrit/Powder.html): A metallurgist friend told me a few years ago that things like aluminum wheel spindles should not be powder coated. He explained that aluminum billet material (6061-T6 ?) changed crystal structure at a critical temperature around 410 degrees F (as I recall). The thrust was that the heating step would adversely affect the strength of the material. Non-structural components would be OK, but not something that "holds the spokes on". The metallurgist is correct. Products like wheel billets, scuba tanks, etc. can be powder coated, but only with powders which cure below peak metal temperature of 300 degrees F. The magic temperature is about 275F. The crystalline realignment at 400 degrees F causes the previous ductile aluminum to become brittle. Imagine the catastrophe when an 80 cu. ft. scuba tank explodes under 3000 psi pressure after an unauthorized powder coat (this actually happened). To my knowledge, all Aluminum wheels and other strength critical aluminum components are powder coated with these cooler curing powders. <> Heating Al alloys above this temperature causes a granular rearrangement of the metallurgical structure resulting in a significant change of bulk properties. The tensile strength of the metal is dramatically lowered, much like a stress relief anneal on a steel piece would do. The resultant metal is not as strong, nor will pressure vessels made of such treated aluminum (e.g., scuba tanks) hold near the pressure that they were originally rated for. Since wheels are essentially load-bearing structures, they should never be heated like this unless the alloy is known to tolerate it well. This lends itself to aluminum airplane parts as well- you might see what the cure temps were and then see if re-heat treating your boom tube and lift struts are possible. I think your worries are well founded. You should contact TNK and see what process they use. Further research is necessary before you fly 'em... Ken Korenek BSME UT Arlington, 1985 Vought Aircraft Industries Dallas, Tx. HShack(at)aol.com wrote: > >I have been advised by some "engineer-types" that powder coating [process] >weakens 6061-T6 Aluminum because of the heat. I had my lift struts & fuselage >boom tube powder coated before I found this out; been a little worried about it. > > > ________________________________________________________________________________
Date: Oct 15, 2004
by: HShack(at)aol.com > > I have been advised by some "engineer-types" that powder coating [process] > weakens 6061-T6 Aluminum because of the heat. I had my lift struts & > fuselage > boom tube powder coated before I found this out; been a little worried > about it. > > Now, I read on TNK website that they offer powdercoating on their boom > tubes; > should I feel better???? > > Howard Shackleford > FS II > SC > > Howard, My Mk-3 has a powdercoated boom tube, fuselage, and aluminum struts. PowderCraft, the old Kolbs source for powdercoating did it all. Don't worry, be happy. Denny Rowe, Mk-3 N616DR, PA, 2SI 690L-70 ________________________________________________________________________________
Subject: Ski's
Date: Oct 15, 2004
FYI Couple of threads ago someone was asking about ski for a Kolb, Just saw ski's on ebay, for a Kolb Ken ________________________________________________________________________________
Date: Oct 15, 2004
Gene I have the wings and tail of a MKIII X and finishing details before buying Kit two ( need more money :-) It would be great to meet another local pilot and have someone look over my shoulder and my kit and maybe bum a ride or two :-) any and all can contact me at this site or info below Ken James Drafting Design Technology Instructor Berks Career and Technology Center East Campus 3307 Friedensburg Rd. Oley, Pa. 19506 610-987-6201 Ext. 3532 Kdjames(at)berkscareer.com -----Original Message----- From: Eugene Zimmerman [mailto:eugenezimmerman(at)dejazzd.com] Subject: Kolb-List: Re: Kolb Fly-in Photos Hi Tom, Welcome to the Kolb list. This list is probably the best group of Kolb builders and owners you are going to fine anywhere. It is your most helpful source of information along with the factory about anything relating to Kolb aircraft. As concerning a reliable comparison of the Kolb's vs. competitive aircraft, I am not aware of any attempts to officially objectively compare various ultralight/sport aircraft. Of course pilots have been comparing and competing their planes since the Wright Bros. The mags. give flight reports on various planes and Kolb has always had good reviews but I have never seen an actual comparison. Kolb enjoys stellar reputation in the ultralight/sport aircraft community. Kolb planes may not be the best at everything but they are outstanding in everything and unexcelled in some things. For example, All Kolb planes are unexcelled in their ease to fold the wings for storage saving many owners tons of money on hanger rent fees. Kolb planes enjoy an excellent reputation for short take off and steep climbs and along with their short landing capability. Their responsive controls are an industry standard of comparison. I have been flying Kolb planes since 1982, let me see thats 22 years,(wow! and I aint old yet) and I have not been disappointed with them ever. Im not sure about a Mark III owner near Allentown but dont be surprised if someone takes you up on your offer. How about it folks any body near Allentown PA with a Mark III? Gene Tom O'Hara wrote: > Gene-- I got your email from the photos that you had placed on the net > regarding the Kolb fly-in. I have been flying for some 40+ years and > actually grew up in Oshkosh. The last 22 years flying has been a > commercial ticket for LTA. However, lighter than air is heavy as hell > and my back is turning 58 next week! Have been considering trading the > balloon in for an ultra light/sport and the Kolb Mark III extra kind of > caught my eye. > > Haven't found the factory to be very responsive- although haven't tried > to get too much info from them. However, is there an owners group and > listing where I might find an owner near Allentown, PA? Would consider > trading some Kolb time for some balloon time. Is there a reliable > comparison of the Kolb's vs. competitive aircraft? How long have you > been flying a Kolb-- and your opinions?? You know all the normal stuff > one needs to know both pro/con > > Thanks for your time. > > Tom O'Hara ________________________________________________________________________________
Subject: 5 Rib FireStar Wings
Date: Oct 15, 2004
Kolbers: I have a really nice set of 5 rib Firestar wings just setting in my hangar and I am about to stuff 'em in the dumpster. They've got less than 30 hours on 'em and were built by Brian back when he was Lightspeed Aviation. Gotta' get rid of 'em one way or the other- they're in the way! Somebody make me an offer! Ken Korenek Arlington, Texas Kolbers: I have a really nice set of 5 rib Firestar wings just setting in my hangar and I am about to stuff 'em in the dumpster. They've got less than 30 hours on 'em and were built by Brian back when he was Lightspeed Aviation. Gotta' get rid of 'em one way or the other- they're in the way! Somebody make me an offer! Ken Korenek Arlington, Texas ________________________________________________________________________________
Date: Oct 15, 2004
I have experience in only one Kolb, the early Firestar, and none of these things you mentioned that others warn of seem to apply to this airplane. I have been a GA pilot since 1966, flying Piper Cubs to Mooneys and just got into UL types three years ago. I found the transition to UL types to be a non issue, this includes owning a Zenith CH701, early Firestar, and Titan Tornado, in that order. I've also flown a Flightstar II (underpowered), a Fergy II (poor imitation of a Kolb Mk II), Challenger once (was enough), and a Hawk (nice but not a Kolb). The early FireStar is a piece of cake to fly with no bad habits in the air. The well known nose over tendency is the only "gotcha" which can be avoided with a little knowledge and experience, and nearly eliminated with longer gear legs. How other Kolbs fly is unknown to me from personal experience. However, unless a pilot has flown several different types of aircraft, his credibility in comparing aircraft handling characteristics may be suspect. A pilot with experience in many kinds of aircraft(including those you know well) plus the kind you are building is the best source for flying and ground handling comparison. Thom in Buffalo ________________________________________________________________________________
Subject: Re: 5 Rib FireStar Wings
Date: Oct 15, 2004
interested in a trade, what do you need, parts, plans ect or $.gotta go now i'll check email this afternoon,over to the west in sweetwater ----- Original Message ----- From: <kkorenek(at)comcast.net> Subject: Kolb-List: 5 Rib FireStar Wings > > Kolbers: > > I have a really nice set of 5 rib Firestar wings just setting in my hangar and I am about to stuff 'em in the dumpster. > > They've got less than 30 hours on 'em and were built by Brian back when he was Lightspeed Aviation. > > Gotta' get rid of 'em one way or the other- they're in the way! > > > Somebody make me an offer! > > Ken Korenek > Arlington, Texas > > Kolbers: > > I have a really nice set of 5 rib Firestar wings just setting in my hangar and I am about to stuff 'em in the dumpster. > > They've got less than 30 hours on 'em and were built by Brian back when he was Lightspeed Aviation. > > Gotta' get rid of 'em one way or the other- they're in the way! > > > Somebody make me an offer! > > Ken Korenek > Arlington, Texas > > ________________________________________________________________________________
Date: Oct 15, 2004
I too have had concerns over powdercoating 6061-T6. However, after 33 years in auto collision and painting, I checked with local Gulfstream engineers. The powdercoating process must not exceed 325 degrees for over a 30 minute period. I agree that this will change the properties of the aluminum. Wife retired after 28 years of Corporate Aviation....thus easy access to VERY knowledgeable persons....LOL. Kolbra 4 building.... Wayne McCullough EAA 330 ________________________________________________________________________________
Date: Oct 15, 2004
Will trade for $$ !! ;>) Ken -------------- Original message -------------- > > interested in a trade, what do you need, parts, plans ect or $.gotta go now > i'll check email this afternoon,over to the west in sweetwater > ----- Original Message ----- > From: > To: > Subject: Kolb-List: 5 Rib FireStar Wings > > > > > > Kolbers: > > > > I have a really nice set of 5 rib Firestar wings just setting in my hangar > and I am about to stuff 'em in the dumpster. > > > > They've got less than 30 hours on 'em and were built by Brian back when he > was Lightspeed Aviation. > > > > Gotta' get rid of 'em one way or the other- they're in the way! > > > > > > Somebody make me an offer! > > > > Ken Korenek > > Arlington, Texas > > > > Kolbers: > > > > I have a really nice set of 5 rib Firestar wings just setting in my hangar > and I am about to stuff 'em in the dumpster. > > > > They've got less than 30 hours on 'em and were built by Brian back when he > was Lightspeed Aviation. > > > > Gotta' get rid of 'em one way or the other- they're in the way! > > > > > > Somebody make me an offer! > > > > Ken Korenek > > Arlington, Texas > > > > > > > > > > Will trade for $$ !! ;) Ken -------------- Original message -------------- -- Kolb-List message posted by: "ron wehba" interested in a trade, what do you need, parts, plans ect or $.gotta go now i'll check email this afternoon,over to the west in sweetwater ----- Original Message ----- From: <KKORENEK(at)COMCAST.NET> To: Subject: Kolb-List: 5 Rib FireStar Wings -- Kolb-List message posted by: kkorenek(at)comcast.net Kolbers: I have a really nice set of 5 rib Firestar wings just setting in my hangar and I am about to stuff 'em in the dumpster. They've got less than 30 hours on 'em and were built by Brian back when he was Lightspeed Aviation. G otta' get rid of 'em one way or the other- they're in the way! Somebody make me an offer! Ken Korenek Arlington, Texas Kolbers: I have a really nice set of 5 rib Firestar wings just setting in my hangar and I am about to stuff 'em in the dumpster. They've got less than 30 hours on 'em and were built by Brian back when he was Lightspeed Aviation. Gotta' get rid of 'em one way or the other- they're in the way! Somebody make me an offer! Ken Korenek Arlington, Texas ugh the Contributions onics.com/photoshare ________________________________________________________________________________
Subject: FSII for Sale
Date: Oct 15, 2004
Greetings... The buyer for my Firestar failed to get his purchase monies together after several months (!) so my plane is back on the market. I am selling it because of another plane project that awaits completion. I think I am offering an excellent price for a factory quickbuilt in good condition.. I would love to sell it before winter is upon us... I will not 'give' it away... but am definitely a 'motivated' buyer, as I would love to finish my other plane. Someone will be getting an excellent deal! Also, do not forget that the Rotax exchange program for the 503 is available til the end of the year (not that there is aything wrong with my engine, but it does offer yet another option to obtain a brand new engine at a good price!) In a nutshell: 1995 Firestar II factory quickbuild from the 'original' Kolb (Dennis S), 503 DCDI with 180 hrs (decarboned and re sealed at 125hrs), electric start, IVO 3 blade, hydraulic brakes, full enclosure, stits professionally covered by Kolb, custom open trailer, tundra tires. Half dozen photos and more details at www.JonCroke.com then click on picture for more pictures What I learned from first buyer that fell thru: first come, first served... no 'holding'....(unless you buy it!) If you want to make an offer, just ask... worse case I would only say no, thanks! But, even if I accept your offer, until you show up, check it out, and pay, the plane is still available! Will be happy to answer all questions, either email (direct) or phone, please visit website before asking questions! If I were richer man, I would not let this plane go... but I'm not complaining... can't sleep in 2 beds, can't fly 2 planes! Jon Brussels, Wisconsin (90mi NE of Oshkosh) ________________________________________________________________________________
Date: Oct 15, 2004
Are the wings covered? I really dont know what to offer you and I dont want to make you mad, have you got any pictures of them and some kind of idea what the shipping would be Ellery Batchelder Original Firestar KX ________________________________________________________________________________
Date: Oct 15, 2004
Subject: Del Cross info needed!
Hi all, My father in law has become friends with Del in the last few years and he bought a original Kolb like his and rebuilt it. He recently flew it for the first time after a total rebuild. He met Del years back and after speaking to him and finding this plane through Del he bought it to tinker with. He has been flying and building for years. Likes my Kolb and thought it would be fun. Anyways, he finally flew it for the first time a few weeks back and bought a new crank for the Solo engines from Del, I spoke to him the other night and he told me about the recent purchase and said he was going to call him tonight. I told him the bad news (I was hoping I could avoid it but with the emminant phone call to his wife I needed to say something) Anyways, my long winded question is does anybody have more information about his accident. My father in law is asking? Thanks, Tim Firestar2 250 hours. ________________________________________________________________________________
Subject: Re: Sebring Sport Aviation Expo
Date: Oct 15, 2004
|Seems to me that the UL | organizations would want to get together and do such a thing! The swans | go to San Juan Capistrano and the Harleys go to Sturgis in South | Dakota(north?) so where do the eagles go?? :-) Frugal Herb in Ky Herb/Gang: The eagles go to Monument Valley, Utah, each year in May. We had our "second annual, unplanned, unorganized Kolb flyin" last May. It, like the first one, was a total success. Ask anyone who attended. The air is clean, clear, and all the support for flyin folks is right there at Gouldins. No extraneous BS. Just Kolbs, flying, eating, and more Kolbs. I eagerly await next years "third annual unplanned, unorganized Kolb flying". Take care, john h PS: Got the camping gear out on the living room floor. Getting my clothes and other stuff together to fly to Lucedale, MS, for the flyin. Miss P'fer flew today, for the first time in over a month. Didn't realize how long it had been until I checked my log book. Test flight went well, repairs really stiffened up the lower tailpost. She stalled, with 20 gals of fuel on board, at 40 clean, 35 with 20 deg of flaps, and 33 with 40 deg. Not bad for that weight. Think I need some of those vortex generators? Might help tote that 10 lb tail wheel around. :-) ________________________________________________________________________________
Date: Oct 15, 2004
Subject: Left Side Flaperon Control for FireFly
FireFlyers, I finished installing a continuosly variable flaperon control on the FireFly. It is made from a modified heavy duty camera tripod elevation mechanism. The control handle is located on the left side behind the rear seat cross tube. I can reach it by dropping my hand from the throttle down through the gap between the seat and the left side of the fuselage. Since one cannot see it, I have mounted a flaperon position indicator on the instrument panel. It seems to work well. Currently, at the zero setting the flaperons seem to be a little bit re flexed. This is indicated by excessive stick movement before one can pick up a wing. As the flaperons are extended, this slop goes away and if one moves the stick even the smallest amount, the FireFly rolls quickly. I need to lengthen the aileron push rod tubes a little. The new system can be seen at: http://www.thirdshift.com/jack/firefly/firefly116.html It has taken some time to get this done, but now I will be able record stall speed and elevator angles during 50 mphi final landing approaches for given flaperon settings. Also, I should be able to test roll stability during cross wind take off and landings with increasing flaperon deployment, and to find the best flaperon position for take off and landing the FireFly in the three point configuration. This is going to be fun and it will be great to adjust the flaperons with my right hand on the stick. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Oct 15, 2004
In a message dated 10/14/2004 10:27:17 PM Eastern Standard Time, beauford(at)tampabay.rr.com writes: BTW, there is an article about the EXPO on page 10 of the new Sport Pilot mag for October... Sez the event will be a significant "hands-on information source" to bring together all of the suppliers and customers interested in LSA and the Sport Pilot bit.... Sez also that, due to the unexpected demand, they have had to increase the EXPO exhibit spaces from 70 to 105, and that no less than His Excellency Lord Tom Poberezny himself is going to lead a reinforced gaggle of EAA royalty to the big event... Admission is to be $8 a day for EAA members, and $10 for non-member heathen... If the EAA gets its paws into this operation, I'm sure it won't take long for 'em to run it on up to the $25 a day we have all come to know and love at Lakeland.... and the place will come to be overrun with $200K airplanes and slick lookin' dudes in monogrammed polyester jump suits, gold chains and Porsche sunglasses... and they will hasten to remove all the water drinking fountains and open up numerous EAA stands selling $4 bottles of water and $5 hot dogs.... sigh.... Am I starting to sound a tad bitter...? naaaaah... couldn't be.... time to crawl back into my garbage can.... Beauford FF#076 Brandon, FL Do Not Archive Of course I agree with you 100% Butcher, as I always do....boy wouldn't it be great if we could get water to be only.....say....$1.00 a bottle at SnF? Talk about success...whew! George Randolph Firestar driver from The Villages Fl ________________________________________________________________________________
Date: Oct 16, 2004
Subject: sharp Looking floats
I was very impressed in that float setup my self and then disapointed to find out they are not avaliable , but I am looking for plans to build a set of aluminum floats with retracts myself Ellery Batchelder Jr Levant Welding & Machine Original Firestar ________________________________________________________________________________
From: "Kelvin Kurkowski" <kkurkow(at)chase3000.com>
Subject: Re: FSII for Sale
Date: Oct 16, 2004
(not processed: message from trusted or authenticated source) Jon, tried to email you offlist, and got back a delivery failure. Can you get me a correct email and a phone number? I have a friend looking for a Kolb, I'll get him your information. Thanks Kelvin K ----- Original Message ----- From: "Jon Croke" <jon(at)joncroke.com> Subject: Kolb-List: FSII for Sale > > Greetings... > > The buyer for my Firestar failed to get his purchase monies together after > several months (!) so my plane is back on the market. > > I am selling it because of another plane project that awaits completion. > > I think I am offering an excellent price for a factory quickbuilt in good > condition.. I would love to sell it before winter is upon us... I will not > 'give' it away... but am definitely a 'motivated' buyer, as I would love to > finish my other plane. Someone will be getting an excellent deal! Also, do > not forget that the Rotax exchange program for the 503 is available til the > end of the year (not that there is aything wrong with my engine, but it does > offer yet another option to obtain a brand new engine at a good price!) > > In a nutshell: 1995 Firestar II factory quickbuild from the 'original' > Kolb (Dennis S), 503 DCDI with 180 hrs (decarboned and re sealed at 125hrs), > electric start, IVO 3 blade, hydraulic brakes, full enclosure, stits > professionally covered by Kolb, custom open trailer, tundra tires. > > Half dozen photos and more details at www.JonCroke.com then click on picture > for more pictures > > What I learned from first buyer that fell thru: first come, first served... > no 'holding'....(unless you buy it!) If you want to make an offer, just > ask... worse case I would only say no, thanks! But, even if I accept your > offer, until you show up, check it out, and pay, the plane is still > available! > > Will be happy to answer all questions, either email (direct) or phone, > please visit website before asking questions! > > If I were richer man, I would not let this plane go... but I'm not > complaining... can't sleep in 2 beds, can't fly 2 planes! > > Jon > Brussels, Wisconsin (90mi NE of Oshkosh) > > ________________________________________________________________________________
From: "Silver Fern Microlights Ltd" <kiwimick(at)sfmicro.fsnet.co.uk>
Subject: VG's in the UK
Date: Oct 16, 2004
Hi all not sure if this will post as I have not had any from the list for several days now. Have just finished testing these little babies and have managed to get the stall speed down to 34 Kt at 431kg from the initial 37 Kt. Kiwi ________________________________________________________________________________
Date: Oct 16, 2004
Subject: Re: Floats MK2
In a message dated 10/16/2004 11:34:55 AM Eastern Standard Time, biglar(at)gogittum.com writes: You might want to check out the Full Lotus amphibious floats. They have some very unique and useful features. Frank Reynen on this List has a set on his Mk III Classic, and loves them. Lar. Do not Archive. Full Lotus floats, 12'6", on Robert Broadwell's MkIII have worked out really well. We adapted "QT" amphibious gear. That setup worked well with 1 person on board of about 190 lb., 2 up made it difficult to get off the water [this with a 582]. Unlike Frank Reynen, we did not fit any rudders or tailwheels to the rear of Robert's floats; steering on terra firma is via the original tail wheel. On water- anticipate & use short blasts of the throttle. We think the new 912uls we are about to install will solve the "gittin' off" problem. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: XTRA
Date: Oct 17, 2004
Have not been getting any lists for the last few days, so just checking to see if this works. Kiwi ________________________________________________________________________________
Subject: Re: VG's in the UK
Date: Oct 17, 2004
| Have just finished testing these little babies and have managed to get the stall speed down to 34 Kt at 431kg from the initial 37 Kt. | | Kiwi Kiwi/All: Was that clean for with full flaperons? Test flew my old MKIIIc last Fri, after repairing and replacing the tail section. With 20 gal (120 lbs) fuel she was stalling at: 35 kts clean. 30 kts 20 deg flaps. 29 kts 40 deg flaps. Stall tests conducted at 2,500 feet ASL without vortex generators. Wondered what it would do with VGs? Take care, john h PS: You are coming through in hauck's holler, alabama, loud and clear. ________________________________________________________________________________
Date: Oct 17, 2004
| Was that clean for with full flaperons? | | Test flew my old MKIIIc last Fri, after repairing and replacing the | tail section. With 20 gal (120 lbs) fuel she was stalling at: | | 35 kts clean. | | 30 kts 20 deg flaps. | | 29 kts 40 deg flaps. Gang: The above should have read, "Was that clean or with full flaperons?" 35 kts is 40 mph 30 kts is 35 mph 29 kts is 33 mph Take care, john h ________________________________________________________________________________
Date: Oct 17, 2004
Just a note... use double sided carpet tape (Home Depot, etc) and trim around each VG with a razor knife (stick about 20 VGs down to your tape while it's still on the roll and cut around them with the razor knife and then take them off one at a time with a small pair of smooth jawed needle nosed pliers and apply them to the wing using the template for guidance). If you want a belt-and-suspenders approach you can put *thin* 2' wide clear packing tape over the double-stuck-taped-VGs either with small pieces on each side or with one long piece with slits cut in it for the sails to stick up through. The trick is to not let any of the tape get in front of the forward part of the VG and trip the boundry layer early. You want the VG to do it's job efficiently. You also want all your tapes (double-stick and/or packing tape) to be nice and thin. Oh, don't skimp on the tape- use a good brand like 3M. Joa www.landshorter.com Richard Pike wrote: (Just what you need- another winter project...PS - use duct tape to attach them for a trial run, that way if you don't like what you get, you are no --------------------------------- ________________________________________________________________________________
Subject: flight report Mk3/912 vs Rans S-6/582
Date: Oct 17, 2004
Rolled the Mk3 out early this morning, gassed her up, did my preflight and was in the air by 8AM. That 66 Deg morning air sure helped my climb rate. 'Flew Northwest up one of the rivers that feed Lake Seminole. I had heard that this stream was feed by fresh water springs and was interesting to see from the air. It was all true and the visibility was great. The 912 purred all the way. When I got back to the field it was fairly busy but I got in the pattern with the rest and we all got down with no problems. During a chat with my friend Rut Fuller and I mentioned that I was still getting used to the 912 after flying my FireFly. He offered to take me up in a Rans S-6 to show me how easy they are to fly. Takeoff was a non-event but when I tried some turns I found that the Rans was really different. Other than flunking turn coordination, level flight and maintaining a heading I did fine. Trading the Kolb quadrant throttle for the Rans/GA pull-twist throttle was no help. The different rudder function would also take some getting used to. This little jewel was fast though, she went to 110 MPH S&L with no hesitation. Generally it was a very GA-like experience. Post flight check on the 912 the throttle doubler link end fitting was found to be loose by several turns. I put some thread lock on it and screwed it tight. It had not effected throttle action but needed fixing. Duane the plane Mitchell, Tallahassee, FL, Mk3/912, 14.2 Hrs ________________________________________________________________________________
Date: Oct 17, 2004
Subject: Re: Trenton Flyers Halloween Fly-In
All are invited to our fly-in on Saturday, 10-30-04. If it fly's, it's welcome. OK, you can drive in if you must...... Food, gas, candy drops, bonfires, etc. Welcome to camp the whole weekend. Edgefield County Airport, Trenton, SC 6J6 N 33 44. 21 W 081 49.17 Com 122.9 Questions? Howard Shackleford hshack(at)aol.com FS II SC ________________________________________________________________________________
From: "Dan Viet Newspaper" <info(at)danviet.com.au>
Subject: Thank you for your email
Date: Oct 17, 2004
Thank you, We have received your email. It will be attended to as soon as we possibly can. Have a nice day! Cam on ban, Chung toi da nhan duoc email cua ban. Chung toi se hoi dap trong thoi gian som nhat. Chuc ban mot ngay vui ve. Tuan bao Dan Viet. (This is an auto reply message) ________________________________________________________________________________
Date: Oct 18, 2004
Thank you for the info Ellery ________________________________________________________________________________
Date: Oct 18, 2004
Subject: Headsets revisited
Recieved my David Clark headset from my stepson; did a comparison check on our 210 mile round trip to the Carolina Sport Flyers Fly-In at Bishopville, SC. They are model H10-56HXL; they have ANR & are designed for helicopters. They felt comfortable & were effective at noise reduction, both passive & active. They look good in you airplane [for those concerned with "image"]. However, they were no more comfortable or effective than my Lightspeed QFR Cross Country's. The QFR is less bulky & much lighter. The QFR seems to be more effective at noise reduction on a Rotax 503 powered Firestar II. The David Clarks are priced at $683.33 in the Aircraft Spruce catalogue; the Lightspeeds list for $375.00 & can be found at $275.00. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: FireFly New Flaperon Control Report
Date: Oct 18, 2004
| Flew down to Painton, MO from K02 to the Chapter 453 - Fall Picnic | yesterday. | Jack B. Hart FF004 Jack H/Gang: Thanks for sharing your flight. Enjoyed the well done video. Reference flaperons: I do not know if the Fire Fly flaperons will return to their neutral postion or not. However, the my MKIII flaps fly at aproximately 10 degs down when not locked into position. Take care, john h ________________________________________________________________________________
Subject: Visit With Kenneth Reeves/Kolbra Builder
Date: Oct 18, 2004
Hi Gang: A wayyyyyyyyyyy back in the West Central Alabama woods, on the other side (west) of the Alabama River and the east side of the Tombigbee River, there is a neat little airstrip nestled in the woods and hills, exactly 116 miles from Gantt IAP. That little airstrip runs right down the ridge line. At one end is the start of a very nice steel hanger sitting on a concrete pad. James Tripp and I flew from Lucedale to Kenneth's place to check out his operation. While we were there Kenneth fed us a good ole Alabama lunch, then we looked at and talked Kolbra. Discovered how many airplanes had been in and out of Kenneth's airstrip........two (2). That's right. Miss P'fer was the first and James' FSII was the second. He's got a couple trees he needs to cut to make this a very nice light plane paradise. I must say it is intimidating to land into a short field with 100 ft plus trees on the departure threshold. Especially, when one is loaded with 20 gal of fuel, my gear plus Dan Horton's and Bill Griffin's. Seems when your airplane will not carry much more than a toothbrush, Miss P'fer volunteers to tote their stuff for them. James and I got in and got out with no problem though. Kenneth is doing a good job on his Kolbra. I hope it will not disappoint any of you aviation engineer types if he incorporates a little "hauck" in his Kolbra. Well, the factory had already added a little "hauck" in there before Kenneth's kit was delivered. Ya'll take care, john h MKIII - 2,252.4 hours 912ULS - 906.5 hours Miss P'fer's pilot - Way past TBO............. ________________________________________________________________________________
Date: Oct 18, 2004
Subject: Cable info
Hey Guys, Thought you might be interested in this.... http://www.homebuiltairplanes.com/forums/showthread.php?s=&threadid=679 I'll keep this in mind if I change cables some day.... Gotta Fly... Mike in MN - Aircraft Spruce cables My Web Site: http://www.geocities.com/planecrazzzy/Planecrazzzy.html Sometimes you just have to take the leap and build your wings on the way down... Gotta Fly... -- ________________________________________________________________________________
Subject: Re: XTRA
Date: Oct 18, 2004
| I'm new to this Lolb list and just saw this request to be on the Kolb-List | XTRA. I am building an Xtra and want to be on a list of those who have | contrsucted or currently constructing an Xtra. | Please let me know. | John Abbott Hi John A/All: Welcome to the Kolb Builders List. You are at the right place. There are Kolb MKIII Xtra builders and flyers on this List. Relax, enjoy, tell us a little about yourself, where you are from, etc., and join the Kolb family. Take care, john h MKIIIc/912ULS Titus, Alabama ________________________________________________________________________________
Date: Oct 18, 2004
See ya there may be flying a mark III. Bryan Green (Elgin SC) ----- Original Message ----- From: <HShack(at)aol.com> Subject: Kolb-List: Re: Trenton Flyers Halloween Fly-In > > All are invited to our fly-in on Saturday, 10-30-04. If it fly's, it's > welcome. OK, you can drive in if you must...... > > Food, gas, candy drops, bonfires, etc. Welcome to camp the whole > weekend. > > Edgefield County Airport, Trenton, SC 6J6 > N 33 44. 21 W 081 49.17 Com 122.9 > > Questions? > > Howard Shackleford hshack(at)aol.com > FS II > SC > > > ________________________________________________________________________________
Date: Oct 19, 2004
Subject: Still looking for Firestar II for sale
Low time, pretty, hangared, within 250 miles of Trenton, SC [6J6]. This for a friend. Howard Shackleford FS II SC ________________________________________________________________________________
Subject: Re: XTRA
Date: Oct 19, 2004
It is reassuring to be among those who have walked the "Xtra" way before me. I'm from Midland, MI, built a Challenger II ( few it 74 hrs) and sold it to a guy that had more money then brains. I decided to join a Piper Warrior Club, looking for a new experience, but 200+ hours later I must confess that I missed the true romance of flight. There is just something indescribably special about flight in a light aircraft. After a year of researching the market and sorting out my "needs and desires", the Kolb Xtra was the only aircraft that met or exceeded all of the 14 criteria that were essential to me. A trip to London, KY to evaluate the company and its personnel confirmed my decision. Frankly, I've been a "silent" reader of the Kolb-list emails for the last 2 months.... I sense a very positive, respectful and supportive spirit among the members. It is great to be among you. ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: XTRA > > | I'm new to this Lolb list and just saw this request to be on the > Kolb-List > | XTRA. I am building an Xtra and want to be on a list of those who > have > | contrsucted or currently constructing an Xtra. > | Please let me know. > | John Abbott > > Hi John A/All: > > Welcome to the Kolb Builders List. You are at the right place. There > are Kolb MKIII Xtra builders and flyers on this List. > > Relax, enjoy, tell us a little about yourself, where you are from, > etc., and join the Kolb family. > > Take care, > > john h > > MKIIIc/912ULS > Titus, Alabama > > > ________________________________________________________________________________
Date: Oct 19, 2004
Subject: XTRA
John/everyone: Welcome John. There are a bunch of us building Xtras, and a number of finshed planes. You might also find many similarites with the Mark 3 Classic (particularly if you build the Xtra with flaps). There is a huge wealth of experience with all these folks, so feel free to ask. BTW, I've finally put some of my construction photos up on my website: www.quantumwrench.com/Kolb.htm It's far from finished so please bear with me. Comments welcome....I hope ;-) Jim Clayton California Mark-3X, 912ULS.....Building www.quantumwrench.com/Kolb.htm -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Abbott Subject: Re: Kolb-List: XTRA It is reassuring to be among those who have walked the "Xtra" way before me. I'm from Midland, MI, built a Challenger II ( few it 74 hrs) and sold it to a guy that had more money then brains. I decided to join a Piper Warrior Club, looking for a new experience, but 200+ hours later I must confess that I missed the true romance of flight. There is just something indescribably special about flight in a light aircraft. After a year of researching the market and sorting out my "needs and desires", the Kolb Xtra was the only aircraft that met or exceeded all of the 14 criteria that were essential to me. A trip to London, KY to evaluate the company and its personnel confirmed my decision. Frankly, I've been a "silent" reader of the Kolb-list emails for the last 2 months.... I sense a very positive, respectful and supportive spirit among the members. It is great to be among you. ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Re: Primer
Date: Oct 19, 2004
Herb I don't know any thing about this product. Have you tested it with MEK? The reports are that anything sort of epoxy based primer kind of melts when Poly Fiber products are applied over regular primer. Some day if I can ever find a welder I will need to prime my rebuilt motor mount. I recently priced the Poly Fiber Primer and wow it has gone up since the last time I bought Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: <herbgh(at)juno.com> Subject: Kolb-List: Primer > > Hey Fellows > > Just bought my second can of Etching Primer at Advanced Auto. $4.99 > each. Seems to work well. Careful--it goes on pretty thick. > Lite green. Herb in Ky ________________________________________________________________________________
Date: Oct 19, 2004
Subject: Re: Primer
Rick Nope. I know that it will soften or melt. It is a single part primer. About the same as the spray cans that are sold by Aircraft Spruce. Handy for small parts. Not for use where Poly Tack,Spray ,Brush or Poly Tone are to be used. Or Mek or acetone. Joy stick, gear legs, lift struts--things like that. I used a two part primer on the cro molly airframe, root ribs, lift strut attach tabs(firefly). Herb writes: > > > Herb > > I don't know any thing about this product. Have you tested it with > MEK? The > reports are that anything sort of epoxy based primer kind of melts > when Poly > Fiber products are applied over regular primer. > ________________________________________________________________________________
Date: Oct 20, 2004
Subject: Re: Primer
Instead of Stits Epoxy Primer, use Randolph Epoxy Primer. Aircraft Spruce gets $67.80 for the Stits, the Randolph Epibond (white) goes for $49.75 and is just as good. And Jim and Dondi sell Randolph as well as Stits. Richard Pike MKIII N420P (420ldPoops) > > >Herb >I recently priced the Poly Fiber Primer and wow it has gone up since >the last time I bought > >Rick Neilsen >Redrive VW powered MKIIIc ________________________________________________________________________________
Date: Oct 20, 2004
Subject: XTRA
Hi John W/all, I did show you some of those pics at MV last year. And I have made some significant progress since then, but haven't posted the latest pics on the site yet. I have finished the first wing, and have cut, cleaned, alodyned, and epoxy painted 95% of the parts for the second wing. The wing mods I chose have added much time to the build, but I am very happy with the outcome, and as I mentioned on the website, I've only added 9.8 lbs per wing. So John, the short answer to your questions is....I think so ;-) Bringing my plane to MV in the spring is on my mind, and I sure hope I can put all together, do the testing and fly out there. Last year was a great time and I won't miss it next time. Jim Clayton California Mark-3X, 912ULS.....Building www.quantumwrench.com/Kolb.htm -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Williamson Subject: RE: Kolb-List: XTRA Hi Jim, It seems I have seen some of the photos on your website before. Are you going to be ready for Monument Valley 2005? John Williamson Arlington, TX ________________________________________________________________________________
Subject: Mk3c/912 flight report
Date: Oct 21, 2004
During a preflight yesterday I noticed that my Mk3c/912 flaps were a little below the flat bottom side of the wing. I evened them up, adjusted them up about 3 Deg and took her for a test hop. Her straight and level IAS @ 4800 rpm went from 65 to over 70. The left wing no longer stalls first and the 3000 rpm stall speed is ~39 mph, down from about 45 mph. With all this improvement I was looking forward to better control during landings. The throttle was reduced as I joined the pattern and everything was cool until I found that the rpm could not be reduced below 3000 rpm. It was a hot landing and I had to do some braking but it was no big problem. In one of my previous postings I described how I found that one of the end caps on my throttle splitter had unscrewed and that I screwed it back in with threadlock. This effectively shortened the throttle control cable and in my fail-go throttle system the throttle could not be fully closed. The result was not evident during the preflight run-up because the engine had not warmed to full running temperature and appeared to return to idle normally. I thought about going around the pattern again and killing the engine periodically (a le Rhone engine) but decided that was unnecessary. Never stop learning. Duane the plane Tallahassee, FL, Mk3c/912 ________________________________________________________________________________
Subject: Re: Mk3c/912 flight report
Date: Oct 21, 2004
| During a preflight yesterday I noticed that my Mk3c/912 flaps were a little below the flat bottom side of the wing. I evened them up, adjusted them up about 3 Deg and took her for a test hop. Her straight and level IAS @ 4800 rpm went from 65 to over 70. The left wing no longer stalls first and the 3000 rpm stall speed is ~39 mph, down from about 45 mph. | Duane the plane Tallahassee, FL, Mk3c/912 Hi Duane/All: Where do the flaps fly at cruise speed? Most MKIII's, that I have flown, tend to push the flaps down 5 or 10 degrees from level with the wing when in flight. You can test this by pulling the flap handle out of the notch and let it seek its on position to fly when not locked in. I can understand the cruise speed increasing, but I can not understand how raising flaps would decrease stall speed by 6 mph. If anything, it should have gone the other way, increasing stall speed. Take care, john h ________________________________________________________________________________
Date: Oct 21, 2004
Something I have tried to do is get my flaps and my ailerons to be exactly in line with each other when I am flying solo, and the airplane is at straight and level hands free trim. My thinking is that if all the control surfaces are right in line with each other, there ought to be less drag than if one or the other of any of them is up or down a bit. I expect that this would give minimum drag, but cannot prove it with any hard numbers, any improvements -if any- are pretty subtle. Having everything all aligned just seems like that would be the way to go. Perhaps at our low level of wing loading, it doesn't make as much difference as it would on a heavier or faster aircraft? Comments? Richard Pike MKIII N420P (420ldPoops) > > | During a preflight yesterday I noticed that my Mk3c/912 flaps were >a little below the flat bottom side of the wing. I evened them up, >adjusted them up about 3 Deg and took her for a test hop. Her straight >and level IAS @ 4800 rpm went from 65 to over 70. The left wing no >longer stalls first and the 3000 rpm stall speed is ~39 mph, down from >about 45 mph. > | Duane the plane Tallahassee, FL, Mk3c/912 > >Hi Duane/All: > >Where do the flaps fly at cruise speed? Most MKIII's, that I have >flown, tend to push the flaps down 5 or 10 degrees from level with the >wing when in flight. You can test this by pulling the flap handle out >of the notch and let it seek its on position to fly when not locked >in. > >I can understand the cruise speed increasing, but I can not understand >how raising flaps would decrease stall speed by 6 mph. If anything, >it should have gone the other way, increasing stall speed. > >Take care, > >john h > > ________________________________________________________________________________
Subject: Re: Mk3c/912 flight report addenda
Date: Oct 21, 2004
John, Richard, Robert et al, I left several important facts out of yesterday's report (it was late). After raising the flaps up ~3 Deg. I was able to drop two notches off of my nose-up trim. I also used my mirror to check the position of my elevators while cruising at 4800 rpm and 70+ mph and saw that the elevators were flat-level in line with the horizontal stabilizers. I suspect that the flap adjustment allowed better trim, reduced drag and improved performance. Duane the plane Mitchell, Tallahassee, FL, Mk3c/912, 15 hrs ________________________________________________________________________________
Date: Oct 23, 2004
Subject: Re: FireFly New Flaperon Control Report
> >Reference flaperons: I do not know if the Fire Fly flaperons will >return to their neutral postion or not. However, the my MKIII flaps >fly at aproximately 10 degs down when not locked into position. > FireFlyers & John, The weather has been terrible since last Sunday. It cleared a little this afternoon and so I made a dash for the airport. The wind was blowing 20+ but it was right down the runway. The unstable air made it a good test day to see what would happen if I loosened the friction ring on the flaperon control slide. After loosening the friction lock, I flew for about five minutes and the flaperon position remained constant. If I drooped the flaperons they stayed where they were put. I made a landing approach, and again they stayed fixed. But as soon as I hit the ground and started to taxi, they started to droop. The action of the stick to handle the wind, no pressure under the wings, rough taxiway and aileron weight (no counter balances) caused them to droop. I am going to hook a bungee cord to the rear end of the slide in an attempt to balance out flaperon weight. Then I will take another test fight to see if the flaperons will float back up from being down. By balancing them less friction will be required to hold them into the desired position. Because the weather has been so bad, I have been working on the radio problem. I found that my microphones are working, but they have insufficient output to drive the radio. I have ordered some pre-amps kits that may solve the problem. So may be in another week or two I will have the problem solved. One must remain optimistic. I have been trying to solve this problem for five years. I have found another less expensive throat microphone that works better (greater noise rejection) on my digital voice recorder. With the pre-amp, I hope I can use it on my radio too. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Subject: Lexan Glue
Date: Oct 23, 2004
Kolbers... What are some suitable glues for fixing lexan to lexan...? Will acetone work? I'm trying to reinforce windshield attachment points... Thankee... Beauford FF #076 Brandon FL ________________________________________________________________________________
Subject: Running a 912S without a prop?
Date: Oct 23, 2004
Greetings, I'm still cleaning out all the crap in my garage so I can bring the SS home for rebuild. I would like to run the engine periodically, to make sure it stays healthy, but I need to have the prop off to get it in and out of the door (unless I can find a two blade prop). Will it hurt anything to crank the engine without a prop, and run it at 2500 rpm or so for a few minutes? Obviously, I'll have to watch the temps since there isn't going to be much airflow. Thanks, Rusty ________________________________________________________________________________
Subject: Re: Running a 912S without a prop?
Date: Oct 23, 2004
Will it hurt anything to crank | the engine without a prop, and run it at 2500 rpm or so for a few minutes? | Rusty Hi Rusty/All: IIRC from the last 912 school I attended, not recommended to run 912, especially 912ULS, without the prop, which is an integral part of the flywheel "effect" system. If the engine is properly pickled for storage, there is no need to run it periodically. To back up this info, go to the Rotax web site, download and read the Shop Manual. All the info is in there. Take care, john h ________________________________________________________________________________
Subject: MKIII Flight Report (touch down speeds)
Date: Oct 23, 2004
Hi Gang: My turn to do a flight report. There are some "pig trail two track" roads through the cotton fields just west of Speigner Lake and Draper Prison. Been using them for off field landings since the days of the Ultrastar. On the way home from Wetumpka Airport, I short four landings, two to the east and two to the west. With 10 gal fuel and pilot on board, no cargo, I consistently touched down at 30 mph indicated. Normally, I do not look at the ASI at touch down, but yesterday was a good day to do it. I surprised myself when I did the first landing with my eye on the ASI until the mains touched the ground. Right on 30 mph. Had to go back up and do it three more times to insure I was seeing what I was seeing. Really made me proud of my big fat old bird. She is quite the gal. And did it with out the aid of vortex generators. With more than 20 gals on board this afternoon, I shot another landing in the same place, but it was turbulent and I couldn't get settled down enough just prior to touch down to keep an eye on the ASI. However, it was somewhere between 30 and 35 mph. The slowwww landings were with 40 deg (two notches) flaps, throttle closed, eng rpm 2,000. Take care, john h ________________________________________________________________________________
Date: Oct 23, 2004
Subject: Re: Lexan Glue
Here's a page of somebody gluing Lexan to Lexan with Shoe-Goo http://www.misbehavin-rc.com/pit-lane/body-strengthen/g-body-strengthen.asp And here's another, same idea, more details. http://www.hobbyworks.com/default.cfm/Content/fullarticle/hs/Home/ID/14 Richard Pike MKIII N420P (420ldPoops) > >Kolbers... >What are some suitable glues for fixing lexan to lexan...? Will acetone work? >I'm trying to reinforce windshield attachment points... > >Thankee... > >Beauford >FF #076 >Brandon FL > > ________________________________________________________________________________
Date: Oct 23, 2004
Subject: Re: MKIII Flight Report (touch down speeds)
At 09:51 PM 10/23/2004, you wrote: > >Hi Gang: > >My turn to do a flight report. > >There are some "pig trail two track" roads through the cotton fields >just west of Speigner Lake and Draper Prison. Been using them for off >field landings since the days of the Ultrastar. > >On the way home from Wetumpka Airport, I short four landings, two to >the east and two to the west. Right on 30 mph. Had to >go back up and do it three more times to insure I was seeing what I >was seeing. Really made me proud of my big fat old bird. She is >quite the gal. And did it with out the aid of vortex generators. Yeah...... but I ain't got no flaps. I got the VG's though. Possum - fly with the buzzards take a "paintball gun" just for fun. ------------------------------------------------------ Kolbers... What are some suitable glues for fixing lexan to lexan...? Will acetone work? I'm trying to reinforce windshield attachment points... Beauford ------------------------------------------------------- Will acetone work? - No Try "Googling" this stuff. I've used something like it years ago to extend a lexan windshield. It works kind of like PVC cement. Melts the stuff together. -------------------------------------------------------- "Acrifix 192" Cadillac Plastics http://kimmershow.com/fileTamer/news%20report%20from%20Iraq.wmv ________________________________________________________________________________
Date: Oct 24, 2004
IIRC from the last 912 school I attended, not recommended to run 912, especially 912ULS, without the prop, which is an integral part of the flywheel "effect" system. If the engine is properly pickled for storage, there is no need to run it periodically. john h --------------------- Thanks John. I was guessing that it wasn't a good idea. I can't see how it would hurt the engine, but I'm afraid it would damage the gearbox. On the other hand, we do this all the time with the Mazda engines and planetary redrives. I guess what I need then is a 2 blade prop. Has anyone ever seen a 912ULS with a 2 blade prop? I need to call IVO and Warp, and see what they have to say. Thanks, Rusty ________________________________________________________________________________
Date: Oct 24, 2004
Subject: Glue
Hey Butcher, I would think " Super Glue" would work... I use "Super Jet" ( medium viscosity )....any Hobby store... I usually buy medium...If I want it THINNER , I use acetone to cut it. Gotta Fly... Mike in MN SNIP<<<<<<<<<<<<<<<<<<<<<>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Kolbers... What are some suitable glues for fixing lexan to lexan...? Will acetone work? I'm trying to reinforce windshield attachment points... Thankee... Beauford FF #076 Brandon FL My Web Site: http://www.geocities.com/planecrazzzy/Planecrazzzy.html Sometimes you just have to take the leap and build your wings on the way down... Gotta Fly... -- ________________________________________________________________________________
Subject: Vibration
Date: Oct 24, 2004
Been test flying my Xtra for about 5 hours now. Things are progressing well but I still have some fine tuning to do. Originally had a 3 blade Ivo on the 912 but was getting a noticeable vibration from 4000rpm all the way up to 5000rpm. Smooth above and below that range. Switched to a 3 blade 70" taper tip Warp Drive and it is smoother but there is still a vibration around 4500rpm. Vibration is not apparent during full power run on the ground. Anyone else had this problem? Thanks, Tom Sabean ________________________________________________________________________________
Date: Oct 24, 2004
Hi John I see that you can carry 20 gal of fuel, what tanks do you have?. Kiwi ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Subject: Kolb-List: MKIII Flight Report (touch down speeds) > > Hi Gang: > > My turn to do a flight report. > > There are some "pig trail two track" roads through the cotton fields > just west of Speigner Lake and Draper Prison. Been using them for off > field landings since the days of the Ultrastar. > > On the way home from Wetumpka Airport, I short four landings, two to > the east and two to the west. With 10 gal fuel and pilot on board, no > cargo, I consistently touched down at 30 mph indicated. Normally, I > do not look at the ASI at touch down, but yesterday was a good day to > do it. I surprised myself when I did the first landing with my eye on > the ASI until the mains touched the ground. Right on 30 mph. Had to > go back up and do it three more times to insure I was seeing what I > was seeing. Really made me proud of my big fat old bird. She is > quite the gal. And did it with out the aid of vortex generators. > > With more than 20 gals on board this afternoon, I shot another landing > in the same place, but it was turbulent and I couldn't get settled > down enough just prior to touch down to keep an eye on the ASI. > However, it was somewhere between 30 and 35 mph. > > The slowwww landings were with 40 deg (two notches) flaps, throttle > closed, eng rpm 2,000. > > Take care, > > john h > > > ________________________________________________________________________________
Subject: Re: Vibration
Date: Oct 24, 2004
| Switched to a 3 blade 70" taper tip Warp Drive and it is smoother but there is still a vibration around 4500rpm. Vibration is not apparent during full power run on the ground. | Anyone else had this problem? | Tom Sabean Tom S/All: I have used Warp Drive Props exclusively since Sep 1993. For the most part, Warp Drive Props do not have balance problems. However, if all two or three blades are not set at the same pitch, annoying vibrations will result. Insure all three blades are the same pitch before going any further. Next, some 912 and 912ULS engines and gearboxes will get a harmonic vibration at certain rpm as a result of loose shims in the gear box torsional vibration dampner. Insure the dampner is shimmed as tight as permissible. If you have a 912ULS engine of the older variety, prior to "slip clutch" and "high torque starter", would be a good idea to upgrade to these items. Most, if not all, vibrations in my system disappeared after upgrading to the slip clutch. What kind of prop extension are you running? A poorly built extension could add to you vibration problems. Let us know what you find out. john h ________________________________________________________________________________
Date: Oct 24, 2004
| Hi John I see that you can carry 20 gal of fuel, what tanks do you have?. | | Kiwi Hi Kiwi/All: I have been using a Jim Hauck 25 gal fuel tank since day one. Bro Jim fabricated an aluminum tank for me when we were building my MKIII Feb 1991. 25 gal ultimate, 25 gal useable. Can squeeze the last drop out of it. Take care, john h ________________________________________________________________________________
Date: Oct 24, 2004
Thanks John, I might have to look at doing the same on our new Xtra demonstrator or maybe fit a third tank in somewhere. Kiwi ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: MKIII Flight Report (touch down speeds) > > | Hi John I see that you can carry 20 gal of fuel, what tanks do you > have?. > | > | Kiwi > > Hi Kiwi/All: > > I have been using a Jim Hauck 25 gal fuel tank since day one. Bro Jim > fabricated an aluminum tank for me when we were building my MKIII Feb > 1991. 25 gal ultimate, 25 gal useable. Can squeeze the last drop out > of it. > > Take care, > > john h > > > ________________________________________________________________________________
Date: Oct 24, 2004
Subject: Re: Lexan Glue Wrap-Up
In a message dated 10/24/04 12:28:04 PM Central Standard Time, beauford(at)tampabay.rr.com writes: << Tomorrow when the plastics supply house over in Brandon opens, I'll go get some ME glue in a tube, as John suggested. Meantime, i'm goin' back out in the garage and roll some more of that Shoe Goo... Worth what ye paid fer it... Beauford FF#076 >> Beauford, I know Im late in the game, but I was in Home Depot the other day and they had some kind of glue for plastics. It said ,all, plastics. It was 2 part. The first part you put on the pieces to soften em up, then you apply the other part on them & then assemble. It might work. What about the all purpose glue for plastic pipe? Let us know the outcome, Ed(in Houston) ________________________________________________________________________________
Date: Oct 24, 2004
Kiwi, I'm building an Xtra and have been looking for way to increase the feul capacity. Do know what has been done in the past? John ----- Original Message ----- From: "Silver Fern Microlights Ltd" <kiwimick(at)sfmicro.fsnet.co.uk> Subject: Re: Kolb-List: MKIII Flight Report (touch down speeds) > > > Thanks John, > I might have to look at doing the same on our new Xtra demonstrator or > maybe > fit a third tank in somewhere. > > Kiwi > ----- Original Message ----- > From: "John Hauck" <jhauck(at)elmore.rr.com> > To: > Subject: Re: Kolb-List: MKIII Flight Report (touch down speeds) > > >> >> | Hi John I see that you can carry 20 gal of fuel, what tanks do you >> have?. >> | >> | Kiwi >> >> Hi Kiwi/All: >> >> I have been using a Jim Hauck 25 gal fuel tank since day one. Bro Jim >> fabricated an aluminum tank for me when we were building my MKIII Feb >> 1991. 25 gal ultimate, 25 gal useable. Can squeeze the last drop out >> of it. >> >> Take care, >> >> john h >> >> >> > > > ________________________________________________________________________________
Date: Oct 24, 2004
At 08:52 AM 10/24/2004, you wrote: >I guess what I need then is a 2 blade prop. Has anyone ever seen a 912ULS >with a 2 blade prop? I need to call IVO and Warp, and see what they have to >say. I use an Ivo Magnum 2-blade prop on my 912ULS -- Robert ________________________________________________________________________________
Date: Oct 24, 2004
I use an Ivo Magnum 2-blade prop on my 912ULS -- Robert ----------------------- Good to know. Are you happy with it? Thanks, Rusty ________________________________________________________________________________
Date: Oct 24, 2004
At 08:29 PM 10/24/2004, you wrote: > > >I use an Ivo Magnum 2-blade prop on my 912ULS > > -- Robert >----------------------- > >Good to know. Are you happy with it? Rusty -- In a word, yes... ...but, I've also been spoiled because, on a different aircraft, I had an Arplast 3-blade prop, and those have GOT to be the best props in the world... It had the most powerful thrust I ever felt, and it was so quiet I could cruise without ear protection. But they are pricey little cusses. To be honest, though, I don't know if Arplast makes one that would be suitable for a 912ULS... I had mine mated to a Rotax 503. -- Robert ________________________________________________________________________________
Date: Oct 25, 2004
Hi Tom and gang, I had a vibration also that was puzzeling at one time. You say you get a vibration in flight & not on the ground. It may be related with airflow and not the engine. Look for the possibility of something else that could be vibrating such as gap seals, farings, velcro, BRS straps, eng accessories, etc. that could be vibrating from air flow. Mine was more like a "sound", that went away when I reduced the eng rpm. I thought that was related to the engine. What happened was that the velcro had come loose around the lexan area over the ballistic chute. The lexan was vibrating as a result of air flow and as I reduced rpm the plane slowed and the noise went away. I bet if I had tried a run up on the ground, nothing would have shown up. I may be way off but wanted to mention it anyway. Good luck. Fly Safe Bob Griffin ________________________________________________________________________________
Date: Oct 25, 2004
>...but, I've also been spoiled because, on a different aircraft, I had an >Arplast 3-blade prop, and those have GOT to be the best props in the >world... It had the most powerful thrust I ever felt, and it was so quiet >I could cruise without ear protection. But they are pricey little cusses. > >To be honest, though, I don't know if Arplast makes one that would be >suitable for a 912ULS... I had mine mated to a Rotax 503. > > -- Robert > Robert, One of my hangar mates flys a Magni Gyro. It is powered with a Rotax 914UL and an Arplast three blade propeller. He has about 600 hours on it with no problems related to the engine/prop combination. Jack B. Hart FF004 Jackson, MO Jack & Louise Hart jbhart(at)ldd.net ________________________________________________________________________________
Date: Oct 25, 2004
Jack -- Thanks for the note.... If I ever get a job, I'll aspire to buy one for my 912ULS, someday! -- Robert At 04:09 PM 10/25/2004, you wrote: > > >...but, I've also been spoiled because, on a different aircraft, I had an > >Arplast 3-blade prop, and those have GOT to be the best props in the > >world... It had the most powerful thrust I ever felt, and it was so quiet > >I could cruise without ear protection. But they are pricey little cusses. > > > >To be honest, though, I don't know if Arplast makes one that would be > >suitable for a 912ULS... I had mine mated to a Rotax 503. > > > > -- Robert > > > >Robert, > >One of my hangar mates flys a Magni Gyro. It is powered with a Rotax 914UL >and an Arplast three blade propeller. He has about 600 hours on it with no >problems related to the engine/prop combination. > >Jack B. Hart FF004 >Jackson, MO > > >Jack & Louise Hart >jbhart(at)ldd.net > > ------------------------- EZ Dock Texas Gulf Coast Office Phone: 281-752-9096 Cell Phone: 713-503-2949 Fax: 425-928-3369 Web : www.EZDockTexGulf.com EMail: robert(at)EZDockTexGulf.com Personal web pages: http://www.rlaird.net http://www.texas-flyer.com ________________________________________________________________________________
Subject: Waynes accident
Date: Oct 25, 2004
Sorry for the delay in getting the info back to the list. I know some of you are wondering about the Slingshot accident last month. Wayne says the engine started losing power with the 582 and he tried to make it back to my strip but realized he was not going to make it and opted for a bean field not far from his home. He reports the Slingshot glides like a homesick crowbar. All went well except for the last moments when he said he did not have enough back stick to flair. He continued his descent right into the ground. The frame took a lot of the shock and even the seat rails were bent down., the boom tube ring was torn off the boom. The cage is a total write off, not a single straight tube. Wings and tail are in perfect condition. Wayne did not make it through in as good condition. He broke his sternum (chest bone) and 3 vertibrae in his back were converted to mush. He is still in the hospital and will be for a few more months with lots of intensive therapy. His spirits are good and he is talking of rebuilding. He really enjoyed getting the card signed from all the guys at the homecoming last Sept. Thanks to all that signed it for him. The engine still turns freely by hand, maybe to freely. The only problem I can see is that it did not seem to be using much oil. Would that cause the slow loss of power after about 45 min of flying? Any other ideas. Temps were in a normal range. ________________________________________________________________________________
Date: Oct 25, 2004
Subject: Re: Waynes accident
Woody, A few years ago there was another 582 powered Slingshot that crashed killing its pilot under the same type of conditions. The guy was on his way to Oshkosh for his first trip in that plane. The engine quit and he glided for quite awhile in a hilly area with very few landing options. He happened to change his mind at the last minute for another landing area and stalled it in a sharp bank. Dove it in hard. I would almost be willing to wager that it quit when he was throttling back on his approach to a local airport. Two stroke's will do that if the idle is not set high enough or it has "loaded up" from a long descent. It has happened to me a few times. I always say, don't close the throttle on a 2-stroke engine unless it's on final. They say to "fly the plane", but if it quit because of this and there was enough altitude, I'd be tempted to give the starter rope a tug. I can't remember if he had an electric starter or not but if it did, I'm sure he pushed the button a few times before giving up maybe distracting him enough to use up valuable time looking for a suitable landing area. Ralph > > Sorry for the delay in getting the info back to the list. I know > some of > you are wondering about the Slingshot accident last month. > Wayne says the engine started losing power with the 582 and he > tried to > make it back to my strip but realized he was not going to make it > and opted > for a bean field not far from his home. He reports the Slingshot > glides like > a homesick crowbar. All went well except for the last moments when > he said > he did not have enough back stick to flair. He continued his descent > right > into the ground. The frame took a lot of the shock and even the seat > rails > were bent down., the boom tube ring was torn off the boom. The cage > is a > total write off, not a single straight tube. Wings and tail are in > perfect > condition. > Wayne did not make it through in as good condition. He broke > his > sternum (chest bone) and 3 vertibrae in his back were converted to > mush. He > is still in the hospital and will be for a few more months with lots > of > intensive therapy. His spirits are good and he is talking of > rebuilding. He > really enjoyed getting the card signed from all the guys at the > homecoming > last Sept. Thanks to all that signed it for him. > The engine still turns freely by hand, maybe to freely. The only > problem > I can see is that it did not seem to be using much oil. Would that > cause > the slow loss of power after about 45 min of flying? Any other > ideas. Temps > were in a normal range. > > > = > > = > = > > > > > > Now includes pop-up blocker! Only $14.95/ month - visit http://www.juno.com/surf to sign up today! ________________________________________________________________________________
Date: Oct 26, 2004
Good Morning Ralph, I'll take that wager ;-) Just kidding. Here is whats on the NTSB web site about that SlingShot I think your talking about. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: The loss of engine power due to fuel starvation caused by a blocked, unsecured, fuel vent line. Contributing to the accident was the pilot's failure to maintain adequate airspeed during the forced landing which resulted in an inadvertent stall at a low altitude. TESTS AND RESEARCH The engine was shipped to Leading Edge Airfoils, Lyons, Wisconsin, for a test run and further inspection. The engine was test run on October 16, 2001, and was witnessed by a FAA inspector and representatives of the engine manufacture. The engine was configured with the original aircraft's fuel filter, fuel pump, gascolator, and pulse pump. The original propeller was damaged during the accident and a test propeller was utilized for the test run. No carburetor jet adjustments were made prior to the test run. The engine was mounted on a test stand and started without any anomalies. The engine developed full power at 6,500 rpm during the full throttle test. Both ignition systems functioned without any anomalies. No anomalies were found with the engine or its related systems that could be associated with any pre-impact condition. http://www.ntsb.gov/ntsb/brief2.asp?ev_id=20010803X01594&ntsbno=CHI01LA237& akey=1 Regards, Will Uribe El Paso, TX but working In Oklahoma City FireStar II N4GU C-172 N2506U http://home.elp.rr.com/airplane/ > Woody, > > A few years ago there was another 582 powered Slingshot that crashed > killing its pilot under the same type of conditions. The guy was on his > way to Oshkosh for his first trip in that plane. The engine quit and he > glided for quite awhile in a hilly area with very few landing options. He > happened to change his mind at the last minute for another landing area > and stalled it in a sharp bank. Dove it in hard. > > I would almost be willing to wager that it quit when he was throttling > back on his approach to a local airport. Two stroke's will do that if the > idle is not set high enough or it has "loaded up" from a long descent. It > has happened to me a few times. ________________________________________________________________________________
Date: Oct 26, 2004
Subject: Back in the air
Greetings Kolb fans, After waiting for almost a year I finally got my Medical, it is only good until April of next year. Then I will need my Doctor to send them a letter on how I'm doing with half a stomach. I have no idea what that has to do with flying but if I want to keep doing it, I have to do what they say. I flew my FireStar the day after a got my medical and also last weekend. I must say after a year of not flying it was a joy to go up. The FireStar is performing just like new after 209 hours. Now I have to get an annual inspection on my Cessna 172 so I can take it flying. Regards, Will Uribe El Paso, TX but working in Oklahoma City FireStar II N4GU C-172 N2506U http://home.elp.rr.com/airplane/ ________________________________________________________________________________
Date: Oct 26, 2004
Will, The FAA found an unsecured vent line that may have caused the fuel starvation. I doubt that was the cause of the engine quitting, because a vent line will move around under vibration. The pilot flew it for at least 40 hours without any problems in this area. I still think that it was the classic 2-stroke case of the engine quitting at idle after running in cruise for a time. A month prior to the accident, I watched him start it up and the Ivoprop was striking the back side of the cage because was too large a diameter for the plane. It was idling very slow. Ralph Original Firestar 17 years flying it > > Good Morning Ralph, > I'll take that wager ;-) Just kidding. > Here is whats on the NTSB web site about that SlingShot I think your > talking > about. > > The National Transportation Safety Board determines the probable > cause(s) of > this accident as follows: The loss of engine power due to fuel > starvation > caused by a blocked, unsecured, fuel vent line. Contributing to the > accident was > the pilot's failure to maintain adequate airspeed during the forced > landing > which resulted in an inadvertent stall at a low altitude. > > TESTS AND RESEARCH > > The engine was shipped to Leading Edge Airfoils, Lyons, Wisconsin, > for a test > run and further inspection. The engine was test run on October 16, > 2001, and > was witnessed by a FAA inspector and representatives of the engine > manufacture. The engine was configured with the original aircraft's > fuel filter, fuel > pump, gascolator, and pulse pump. The original propeller was damaged > during the > accident and a test propeller was utilized for the test run. No > carburetor jet > adjustments were made prior to the test run. The engine was mounted > on a test > stand and started without any anomalies. The engine developed full > power at > 6,500 rpm during the full throttle test. Both ignition systems > functioned > without any anomalies. > > No anomalies were found with the engine or its related systems that > could be > associated with any pre-impact condition. > > http://www.ntsb.gov/ntsb/brief2.asp?ev_id=20010803X01594&ntsbno=CHI01LA23 7& > akey=1 > > Regards, > Will Uribe > El Paso, TX but working In Oklahoma City > FireStar II N4GU > C-172 N2506U > http://home.elp.rr.com/airplane/ > > > > Woody, > > > > A few years ago there was another 582 powered Slingshot that > crashed > > killing its pilot under the same type of conditions. The guy was > on his > > way to Oshkosh for his first trip in that plane. The engine quit > and he > > glided for quite awhile in a hilly area with very few landing > options. He > > happened to change his mind at the last minute for another landing > area > > and stalled it in a sharp bank. Dove it in hard. > > > > I would almost be willing to wager that it quit when he was > throttling > > back on his approach to a local airport. Two stroke's will do that > if the > > idle is not set high enough or it has "loaded up" from a long > descent. It > > has happened to me a few times. > > > = > = > = > = > > > > > > Now includes pop-up blocker! Only $14.95/ month - visit http://www.juno.com/surf to sign up today! ________________________________________________________________________________
Date: Oct 26, 2004
Subject: Slingshot
Chuck Veith had an intermittent engine failure due to fuel starvation--he had the 2 5 gallon tanks plumbed together per plans and had a vent tube running down the site of the tanks but it was unsecured and periodically made contact with the neoprene the tanks rest on and sealed the tanks not allowing fuel to flow. According to witnesses they heard the plane engine quit and then start again--it probably did not die completely. I imagine the planes was jostling a bit and it came unstuck and then became attached again blocking air and fuel from flowing. I apologise if this sounds too anti Kolb but I worry that the design is not as safe as other kolbs. How many Slingshots were built? How many crashed? How many are still flying regularly? There are many popular planes that do not glide well--the Wittman Tailwind is a fine plane but the pilots know they must plan well ahead incase of an engine out. Regarding engine stoppage in flight, the number one reason is fuelusually some sort of blockage some where along the path--it does not need to be a complete blockage to have a hazardous result. It is unfortunate when any pilot is injured in an rough landing--I hope he heals quickly. Slingshot pilots should practice engine out landings to keep sharp. They fly very differently from the MArk III and Firestars. Dale Seitzer Subject: Re: Kolb-List: Waynes accident From: ul15rhb(at)juno.com Woody, A few years ago there was another 582 powered Slingshot that crashed killing its pilot under the same type of conditions. The guy was on his way to Oshkosh for his first trip in that plane. The engine quit and he glided for quite awhile in a hilly area with very few landing options. He happened to change his mind at the last minute for another landing area and stalled it in a sharp bank. Dove it in hard. I would almost be willing to wager that it quit when he was throttling back on his approach to a local airport. Two stroke's will do that if the idle is not set high enough or it has "loaded up" from a long descent. It has happened to me a few times. I always say, don't close the throttle on a 2-stroke engine unless it's on final. They say to "fly the plane", but if it quit because of this and there was enough altitude, I'd be tempted to give the starter rope a tug. I can't remember if he had an electric starter or not but if it did, I'm sure he pushed the button a few times before giving up maybe distracting him enough to use up valuable time looking for a suitable landing area. Ralph ________________________________________________________________________________
Date: Oct 26, 2004
Subject: Re: Slingshot
Dale, I don't see that you are anti-kolb in your reply. The Slingshot has a lot more wing loading with the shorter wing and I'm sure it sinks like a brick. It's like a 20' wing Titan, if the engine quits, it's going to come down quicker. Do you remember if Chuck had an electric start on it? Did he have a radio and announced his approach? How far was the area he came down in from the airport? Didn't we say that he could have glided to it? Engine problems in a Firestar is one thing, but a lot more serious in a Slingshot. This is why I would want a Jabiru or 912 on one. Ralph -- dale seitzer wrote: Chuck Veith had an intermittent engine failure due to fuel starvation--he had the 2 5 gallon tanks plumbed together per plans and had a vent tube running down the site of the tanks but it was unsecured and periodically made contact with the neoprene the tanks rest on and sealed the tanks not allowing fuel to flow. According to witnesses they heard the plane engine quit and then start again--it probably did not die completely. I imagine the planes was jostling a bit and it came unstuck and then became attached again blocking air and fuel from flowing. I apologise if this sounds too anti Kolb but I worry that the design is not as safe as other kolbs. How many Slingshots were built? How many crashed? How many are still flying regularly? There are many popular planes that do not glide well--the Wittman Tailwind is a fine plane but the pilots know they must plan well ahead incase of an engine out. Regarding engine stoppage in flight, the number one reason is fuelusually some sort of blockage some where along the path--it does not need to be a complete blockage to have a hazardous result. It is unfortunate when any pilot is injured in an rough landing--I hope he heals quickly. Slingshot pilots should practice engine out landings to keep sharp. They fly very differently from the MArk III and Firestars. Dale Seitzer Subject: Re: Kolb-List: Waynes accident From: ul15rhb(at)juno.com Woody, A few years ago there was another 582 powered Slingshot that crashed killing its pilot under the same type of conditions. The guy was on his way to Oshkosh for his first trip in that plane. The engine quit and he glided for quite awhile in a hilly area with very few landing options. He happened to change his mind at the last minute for another landing area and stalled it in a sharp bank. Dove it in hard. I would almost be willing to wager that it quit when he was throttling back on his approach to a local airport. Two stroke's will do that if the idle is not set high enough or it has "loaded up" from a long descent. It has happened to me a few times. I always say, don't close the throttle on a 2-stroke engine unless it's on final. They say to "fly the plane", but if it quit because of this and there was enough altitude, I'd be tempted to give the starter rope a tug. I can't remember if he had an electric starter or not but if it did, I'm sure he pushed the button a few times before giving up maybe distracting him enough to use up valuable time looking for a suitable landing area. Ralph Now includes pop-up blocker! Only $14.95/ month - visit http://www.juno.com/surf to sign up today! ________________________________________________________________________________
Subject: Slingshot
Date: Oct 26, 2004
I apologise if this sounds too anti Kolb but I worry that the design is not as safe as other kolbs. How many Slingshots were built? How many crashed? How many are still flying regularly? Dale Seitzer ---------------------------- Hi Dale, No need to apologize, but I would have to disagree that there's anything significantly less safe about the SS. The stall speed is a bit higher than the other Kolbs, but the structure is also a bit stronger. In general, I think we could say that risk tends to go up with performance, and the SS is a higher performance Kolb, so there may be just a bit more risk. I'm guessing that's why Kolb makes more than one model :-) I would sure rather have an engine failure in the SS than my RV-3. Cheers, Rusty (maybe the only person who's owned two SS's) ________________________________________________________________________________
Date: Oct 26, 2004
|I apologise if | this sounds too anti Kolb but I worry that the design | is not as safe as other kolbs. How many Slingshots | were built? How many crashed? How many are still | flying regularly? | It is unfortunate when any pilot is injured in an | rough landing--I hope he heals quickly. Slingshot | pilots should practice engine out landings to keep | sharp. They fly very differently from the MArk III | and Firestars. | Dale Seitzer Hi Dale/Gents: Thanks for your comments. Why do you worry about the Slingshot design not being as safe as other Kolbs? Airplanes do not fly below stall speeds, no matter what make, model, or design. I have flown a few Slingshots, finding nothing, as pertains to safety, to worry about, when compared to other Kolb models. The most recent two accidents, you all have been discussing, seemed to have been caused by pilot inattention to adequate airspeed. Easiest time to get slow on airspeed is in an actual engine out/emergency situation. Looks like both these aircraft were stall/crash accidents. The old red Slingshot, first one Kolb brought to Oshkosh, stalled clean at 40 mph indicated, same as my MKIII. It had 22 foot wing span, but flew, to me, like all the rest of the Kolb models, especially the Firefly, which is a baby Slingshot with the same wingspan. Not only Slingshot pilots, but ALL PILOTS, should stay current by practicing engine out landings. No need to be surprised when the time comes. I have not found any of the Kolb models fly any different from each other except for maybe weight and roll rate. Take care, john h ________________________________________________________________________________
Subject: Fuel Tank Vents
Date: Oct 26, 2004
I changed the subject line. Food for thought. Fuel tank vent lines also need to be screened to keep out insects or have temporary plugs with remove before flight flags attached. I had my pitot tube plugged with insects during the build process. I keep temporary plugs in every thing that is critical that isn't covered with screens. My fuel tank vent is in my remote fuel filler cap. The cap doesn't lend its self to being insect plugging and it gets checked frequently. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "robert bean" <slyck(at)frontiernet.net> Subject: Re: Kolb-List: Slingshot > > Truly unfortunate that Chuck had such serious injuries due to a simple > matter of venting. > While building mine, and reading some posts on the subject, I glued a > small plate on > the inside of the belly fabric below my tanks with a pipe tapped hole > in it. > There is a barb fitting screwed into it and vinyl tube up to the top of > the tank. > My only concern was having positive air pressure at the orifice. It > worked out ok. ________________________________________________________________________________
Subject: Fuel tank vent lines
Date: Oct 26, 2004
Thanks for reminding me that the fuel vent lines on my plane should be checked for clogging. I used the standard blue 1/4' fuel line tubing for the vent
