Kolb-Archive.digest.vol-gf
July 31, 2006 - August 25, 2006
      > the
      > >thrust line two feet and moved the gear back a foot and one half?
      > >As far as not taxiing or flying the FireFly in twenty mph winds, some
      > times
      > >we do not have much choice.  Conditions change when you are out and
      > about.
      > >Jack B. Hart FF004
      > >Winchester, IN
      > _________________________________________________________________
      > http://search.msn.click-url.com/go/onm00200636ave/direct/01/
      Rick Girard
      "Ya'll drop on in"
      takes on a whole new meaning
      when you live at the airport.
From: "Ralph Hoover" <flht99reh(at)columbus.rr.com>
Date: Jul 31, 2006
Subject: Firestar cruise
Now that I am actually flying and have come to the conclusion that the Kolb is an extreemly forgiving aircraft, I find I have a few questions. The plane is a Kolb Firestar KXP 1990 w/503 and standard two blade prop. The first question is as follows: Since cruise speed is 55 MPH on the ASI's (I have two), how might I raise it to say 60 MPH ASI? I would like to do this with the least amount of alteration to the craft as posible. My reason is I will be flying with some friends from my field thaat have a Challenger two place short wing with 503 and a Titon with a 503. The second question that relates to the above is: If I alter something that allows me to atain 60 MPH ASI, will it proportionalty increase my stall , which is at present in still air 40 MPH ASI? Thank you for your views and opinions. And please note, I like the plane "AS IS", but would like to cruise with the other guys closer to their cruise. Perhaps something simple such as two quarter inch washers under the "rats-a-fratz" will take care of the necessary speed gain request. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51236#51236 ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: Firestar cruise
Ralph: | Since cruise speed is 55 MPH on the ASI's (I have two), how might I raise it to say 60 MPH ASI? Here's what I would do. Push the throttle forward. I don't know what rpm you are using to maintain a cruise of 55 mph. All Rotax two strokes like to run 5,800 rpm. Seems like a lot of rpm's to the uneducated. However, this is 75% power, and they like this speed. You may run your engine all the way to 6,500 rpm maximum continuous rpm. It is designed to operate at these speeds. | The second question that relates to the above is: | If I alter something that allows me to atain 60 MPH ASI, will it proportionalty increase my stall , which is at present in still air 40 MPH ASI? Not unless you eat a lot of breakfast before you decide to fly 60 mph. john h mkIII PS: With some experience cross country flying the original FS with 447, and US with Cuyuna ULII02. ________________________________________________________________________________
Date: Jul 31, 2006
Ralph, Are your lift struts streamlined? That's the easiest way to get where you want. A buddy of mine told me he gained 10 mph by streamlining the struts on his Minimax. Try this for quick strut covers. Go to an engineering drawing supply house and get the thickest mylar sheet available on a roll. 10 feet of 36" wide sheet will make four covers. Cut the sheet into 9" wide strips, fold in half and crease. If you can talk the wife out of her sewing machine (or better yet get her to sew it) and use it to close what will be the trailing edge with a zig zag stitch. Slide them over your lift struts and trim to fit. Use a little tape to set their angle of attack and adjust until your happy. I didn't invent this method, another Ralph, Ralph Senter of Seattle made his flying money for a couple of summers at Dog Mtn. selling these to guys who wanted their single surface hang gliders to go a bit faster. Worked great. On 7/31/06, Ralph Hoover wrote: > > > > > Now that I am actually flying and have come to the conclusion that the > Kolb is an extreemly forgiving aircraft, I find I have a few questions. The > plane is a Kolb Firestar KXP 1990 w/503 and standard two blade prop. > > The first question is as follows: > Since cruise speed is 55 MPH on the ASI's (I have two), how might I raise > it to say 60 MPH ASI? I would like to do this with the least amount of > alteration to the craft as posible. My reason is I will be flying with some > friends from my field thaat have a Challenger two place short wing with 503 > and a Titon with a 503. > > The second question that relates to the above is: > If I alter something that allows me to atain 60 MPH ASI, will it > proportionalty increase my stall , which is at present in still air 40 MPH > ASI? > > Thank you for your views and opinions. And please note, I like the plane > "AS IS", but would like to cruise with the other guys closer to their > cruise. Perhaps something simple such as two quarter inch washers under the > "rats-a-fratz" will take care of the necessary speed gain request. > > Ohio Ralph > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=51236#51236 > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Matronics Email List Web Server Upgrade Tonight...
Dear Listers, This evening I will be upgrading the Matronics Web Server hardware to a new Quad-processor 2.8Ghz Xeon system (yes, 4-physical CPUs!) with an Ultra 320 SCSI Raid 5 disk system and 5GB of DDR2 RAM. As with the older system, the new system will be running the latest version of Redhat Linux. Most of the software configuration work is already done for the migration, but I still have to sync all of the archive and forum data from the old system to the new system. I am anticipating about 2 to 3 hours of downtime for me to fully make the transition, although it could be considerable less if everything goes according to plan. The Matronics Webserver will be *UNavailable* from the Internet during the work, and you will receive a time-out if you try to connect during the upgrade. Email List Distribution will be *available* during the upgrade of the Web Server, and List message distribution will function as normal. This represents a significant performance upgrade for the Matronics Web Server and you should notice nicely improved searching and surfing performance following the upgrade! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Jul 31, 2006
If it were me, I would first put fairings around the landing gear legs, I already know that helps. Also the lift struts if they are not presently streamlined. Then I would make all the tubes of the upper fuselage that are in the air flow to be streamlined, including the aileron pushrods. Finally, I would gap seal between the inside edges of the horizontal stab and the fuselage tube, and gap seal the rudder to the vertical fin, and the elevators to the stab. And I bet that would do it with out changing the stall speed a bit, with minimal addition of weight. And the reason I say "If it were me," is because I plan to do all those things to the MKIII this winter. Richard Pike MKIII N420P (420ldPoops) Ralph Hoover wrote: > > Now that I am actually flying and have come to the conclusion that the Kolb is an extreemly forgiving aircraft, I find I have a few questions. The plane is a Kolb Firestar KXP 1990 w/503 and standard two blade prop. > > The first question is as follows: > Since cruise speed is 55 MPH on the ASI's (I have two), how might I raise it to say 60 MPH ASI? I would like to do this with the least amount of alteration to the craft as posible. My reason is I will be flying with some friends from my field thaat have a Challenger two place short wing with 503 and a Titon with a 503. > > The second question that relates to the above is: > If I alter something that allows me to atain 60 MPH ASI, will it proportionalty increase my stall , which is at present in still air 40 MPH ASI? > > Thank you for your views and opinions. And please note, I like the plane "AS IS", but would like to cruise with the other guys closer to their cruise. Perhaps something simple such as two quarter inch washers under the "rats-a-fratz" will take care of the necessary speed gain request. > > Ohio Ralph > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=51236#51236 > > > > > > > > ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: Kolb to be burned at end of flying season
In a message dated 7/30/2006 6:48:23 PM Eastern Standard Time, biglar(at)gogittum.com writes: Hmmm........interesting, and good to know. I was told by several people that it wouldn't support combustion by itself. Calls for more caution, eh ?? Lar. When we rebuilt my FS II, we did the full Stits process & finished with Aerothane. When we tried to burn a sample, it would NOT self sustain. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Jul 31, 2006
I'm wondering why your going to burn the Kolb?? I must of missed something. ----- Original Message ----- From: HShack(at)aol.com To: kolb-list(at)matronics.com Sent: Monday, July 31, 2006 10:26 PM Subject: Re: Kolb-List: Kolb to be burned at end of flying season In a message dated 7/30/2006 6:48:23 PM Eastern Standard Time, biglar(at)gogittum.com writes: Hmmm........interesting, and good to know. I was told by several people that it wouldn't support combustion by itself. Calls for more caution, eh ?? Lar. When we rebuilt my FS II, we did the full Stits process & finished with Aerothane. When we tried to burn a sample, it would NOT self sustain. Howard Shackleford FS II SC ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Radio Noise
What is being used out there to surpress the engine noise coming through the VHF radio's? I am using a ENC headset but still have a lot of noise at high RPM which I suspect is coming from the engine electrical circuits. Is there a product available or do you build a choke circuit. Larry Tasker MKlllx 582 N615RT ________________________________________________________________________________
Date: Aug 01, 2006
Fantastic, Gentlemen, and thank you. Here goes: RPM is between 5,600 and 5,800 RPM at cruise. Struts are streamlined thanks to my predecessor. Gaps between all air foil hinged area are gap sealed, but only on one side. I believe ailerons are on the underside, will need to check if that makes any difference. Rudder is on the Port side. I noted the Preacher stated something along the lines of landing gear legs. What is there are round plastic tubes, who's I.D.'s are slightly larger than the legs themselves. They are the Kolb longer legs. I never remember experiencing the "defined" feeling of cruise when I was flying the Challenger. It sure is noticeable in the Kolb. Plus my Flightstar II climb / descend indication shows precisely where that point is. Sounds like the only thing left is streamlining the legs. Will that make any significant difference? If so, I may do it out of the Mylar initially. Thank you each one, again for your help. And "IS" 55 a typical cruise speed for the Firestar? Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51435#51435 ________________________________________________________________________________
Date: Aug 01, 2006
Ralph, I wonder if you're not over propped? When I put the new blades in my Warp Drive, I got the prop pitch set wrong, big time. The first flight I made the mistake of flying when I should have shut it down. I made it, but the Mk III would barely reach 60 mph and engine RPM was low, in the high 4000's, low. I nursed her around and back to the hangar and took .75 degrees out. Now she could do 70, but climb was still pitiful and RPM was 5300 +/-. Back to the hangar and took another full degree out. The engine reached 6200 RPM, the climb was much, much better (sorry no VSI) and I could get to the top of the green arc on the ASI (90 mph) in level cruise. If your prop is adjustable, I'd back out .5 degrees and see what you get. Barring that, I have a 66 X 28 I can send you to try. Rick On 8/1/06, Ralph Hoover wrote: > > > > > Fantastic, Gentlemen, and thank you. > > Here goes: > RPM is between 5,600 and 5,800 RPM at cruise. Struts are streamlined > thanks to my predecessor. Gaps between all air foil hinged area are gap > sealed, but only on one side. I believe ailerons are on the underside, will > need to check if that makes any difference. Rudder is on the Port side. I > noted the Preacher stated something along the lines of landing gear legs. > What is there are round plastic tubes, who's I.D.'s are slightly larger > than the legs themselves. They are the Kolb longer legs. > > I never remember experiencing the "defined" feeling of cruise when I was > flying the Challenger. It sure is noticeable in the Kolb. Plus my Flightstar > II climb / descend indication shows precisely where that point is. Sounds > like the only thing left is streamlining the legs. Will that make any > significant difference? If so, I may do it out of the Mylar initially. > > Thank you each one, again for your help. And "IS" 55 a typical cruise > speed for the Firestar? > > Ohio Ralph > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=51435#51435 > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Flaps for glide control
I sometimes change the flap setting on my Cessna Skywagon for glide-path control. It works best during the approach segments when the speed is higher. You definitely need to be on the fast side of the power curve - but not all that fast.... On final, when I'm slowing down and bleeding off speed, there's insufficient kinetic energy left for this to be a good control method. While flying slower, slips work better. Incidentally, I generally plan to be a little high to land long, not too high or long, hopefully. Then adjust the terminal approach with slips so as to get lower. That way I've got a little more energy to play with, and if I screw up I won't plant it on the wrong side of the fence. Doing it this way, I can use full flaps as the nominal position, and vary the glide path rather considerably. Won't work in all Cessnas, some won't permit slips with full flaps. Dave Paule Kolb Firestar II for sale, $8,500, 503, strobes, intake/exhaust silencer. Cessna Skywagon, "Big Hammer," absolutely not for sale. Richard Neilsen wrote - Sorry if I get long winded but... I just got my biannual check ride. This is my once every two years ride in a C172. Afterwards I shared my forced landing experience in MKIIIc with him. I started to tell him how I used the flaps to adjust my glide path to get me where I wanted to land (kind of like a negative throttle) and fully retracted them for landing. He stopped me and said you never never raise your flaps on approach. We then got into a heavy discussion about flap usage. He finally conceded that it might work in one of "those" Kolbs but not in a GA aircraft. I obviously need to take him up in my Kolb and should have done it right then in the C172 but at close to $100 per hour it wasn't worth it. ________________________________________________________________________________
Date: Aug 01, 2006
Subject: OSH 2006
Morning Gang: Had a good flight to OSH. First morning out of Gantt IAP put me into some severe weather, thunderstorms, reduced visibility, heavy rain, lightening, and wind. I ducked into Guntersville Airport, Alabama. Made my approach over Lake Guntersville. Beautiful place. During my two hour weather delay, I discovered Bruce's Cafe. Great home cooking, southern style, and inexpensive. They also had scratch made banana pudding. Less than an hour after departing Guntersville, I was circling Mike Schnabel's brand new airstrip in Manchester, TN. Took some photos of it and proceeded to be the first aircraft to land there. Mike did a super job building his strip. A short visit, mostly in the rain, topped off with fuel, courtesy of Mike (thanks again Mike), and I took off in the rain. Once airborne the entire horizon was black, with the exception of one tiny spot of light. Was about ready to dive back into Mike's strip and wait for the front to pass, but decided to take a look at the light spot which turned out to be the hole I needed to get me north. Ran out of energy and daylight at Terra Haute, IN. Ducked into a small airport on the north side called Sky King. Was an open hanger with room for a MKIII among the Cessna's and Pipers. Set my tent up in the hanger to keep the mosquitoes from carrying me off. Next morning I flew without the aid of coffee until I landed at Danville, IL. After topping off the aircraft I headed to town to top off Hauck. My morning flight was perfect. No wind, clear blue skies, and a good airplane under me. Arrived at OSH, promptly did my usual OSH and Sun and Fun arrival procedure: One pass over the field, tight turn around and land. Scott Trask and Mark German were already set up in the UL tie down/camping area. Had a good time at OSH. Saw a lot of old friends and met some new ones. Spent 5 hours flying the UL traffic pattern which resulted in 202 miles across the ground in a circle. ;-) That's $200.00 worth of fuel to go no where. Was going to depart last day of the show, but Saturday morning had a line of thunderstorms coming from horizon to horizon. My tent was dry, no dew Friday night, so I made the decision to head out before the weather arrived rather than take a chance on spending a few days waiting for weather. My second refuel stop was Henderson, KY. Last time I landed here was 1989, on the way home from OSH in my Firestar. I got here late, spent the night, and left the next morning early. The only evidence I had been there was the spot in the grass where I had placed my air mattress. Ten minutes after departing Henderson I caught the profile of a mkIII on the horizon. Wow! What a coincidence. This doesn't happen very often. I pulled up beside him and waved my wings. Tried to contact him on the local unicom freq with no success. About that time I saw where he was headed, a beautiful manicured green air strip in the country. I circled the field, got a wave from the folks on the ground, and landed. Come to find out it was Mike Richardson and his BMW powered mkIII. They were having a little get together at Hal Shoal's (think that is the correct name) and I had landed right in the middle of it. Most hospitable folks I ever met. When I finally got back in my mkIII and departed, my belly was full of delicious BBQ and other home grown veggies and some scrumptious deserts. Fine folks, and Mike has a beautiful fuel injected, BMW powered, mkIII, plus Hal has an immaculate original FS. Got dark on me at Pulaski, TN. Spent the night on the concrete floor of the hanger. No need for a tent, just the sleeping bag and air mattress. No one there when I landed and no one there when I got up the next morning. That meant no fuel either and the weather was marginal. Tennessee is noted for its abundant ground fog in the summer. Waited for a while, took a peak top side, and headed for Gantt IAP. Was on the south side of Cullman Airport, AL, and ran into rain and solid overcast. Turned around and flew back to Cullman. Didn't need fuel, but the FBO was super friendly, gave me the courtesy car and I got a Ultimate Supreme Grand Slam Breakfast at Denny's in Cullman, plus plenty coffee. I was going to try and fly 300 miles without coffee, but now I did not have to. Forty miles from home, in the little mountains SE of Birmingham, AL, the weather continued to plague me with low viz and rain. Jim House, former EAA UL Board member's grass strip was right below me. I circled the field a couple times, woke up all his neighbors, and by the time I taxied up to the hanger, there was a good size crowd there. Had a good visit, got back in Miss P'fer, and was landing at my strip a few minutes later. I have attached a few photos, I only took a few, of the trip. Take care, john h mkIII ________________________________________________________________________________
From: "Dave & Eve Pelletier" <pelletier(at)cableone.net>
Date: Aug 01, 2006
> > Thank you each one, again for your help. And "IS" 55 a typical cruise > speed for the Firestar? > > Ohio Ralph When I had my single seat Firestar the ASI seemed to be "tied" to the tach. What I mean is if I was turning 5500 rpm, I was at 55 mph, 6,000 rpm, 60 mph,etc. I know there's no relation between these two conditions but that's how it was. Oh yeah, it had a 447. Great little airplane. AzDave > > > ________________________________________________________________________________
Date: Aug 01, 2006
Ralph, When I flew an early Firestar with the 35 hp 377, it would cruise true airspeed of 55 mph at only 5,200 rpm and EGTs were fine. It would cruise a good bit over 60 mph at 5800-5900 rpm but was a lot noisier. And this was with a big cannister BRS hanging down in the breeze below the fuselage. However, it did have streamlined wing struts but no leg fairings and the prop was a 60" two-blade IVO. And, it had smallish wheelbarrow tires. Big tires will knock off a couple MPH easily. -------- Thom in Buffalo Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51485#51485 ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: Radio Noise
What you probably need is a filter capacitor of about 4700 uf and a choke coil. Radio Shack used to sell both these items in a kit, but I don't know if they still do. Aso check to see that you've grounded everything per the manufacturers spec. and haven't added any grounds. Join the Aeroelectric list which is also here on Mattronics. On 8/1/06, Cat36Fly(at)aol.com wrote: > > What is being used out there to surpress the engine noise coming through > the VHF radio's? I am using a ENC headset but still have a lot of noise at > high RPM which I suspect is coming from the engine electrical circuits. Is > there a product available or do you build a choke circuit. > > Larry Tasker > MKlllx 582 > N615RT > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 01, 2006
Do you have a cockpit enclosure? There is a world of difference in efficiency between enclosed and open on the Firestar. (You need to pick Vince Nicely's brains on this, he is the Firestar II efficiency expert. Talked to him last night, he was out yesterday in his FSII, thermal sniffing, flew for 3 hours, burned 6 gallons of gas) On our FSII, it has a 582, and runs 55 mph at 5000 rpm. At 5800 rpm, you better to have the nose up and be climbing. Richard Pike MKIII N420P (420ldPoops) Ralph Hoover wrote: > > Fantastic, Gentlemen, and thank you. > > Here goes: > RPM is between 5,600 and 5,800 RPM at cruise. Struts are streamlined thanks to my predecessor. Gaps between all air foil hinged area are gap sealed, but only on one side. I believe ailerons are on the underside, will need to check if that makes any difference. Rudder is on the Port side. I noted the Preacher stated something along the lines of landing gear legs. What is there are round plastic tubes, who's I.D.'s are slightly larger than the legs themselves. They are the Kolb longer legs. > > I never remember experiencing the "defined" feeling of cruise when I was flying the Challenger. It sure is noticeable in the Kolb. Plus my Flightstar II climb / descend indication shows precisely where that point is. Sounds like the only thing left is streamlining the legs. Will that make any significant difference? If so, I may do it out of the Mylar initially. > > Thank you each one, again for your help. And "IS" 55 a typical cruise speed for the Firestar? > > Ohio Ralph > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=51435#51435 > > > > > > > > ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Disaster at Nudie Beach! :(
Learn from this all you lightplane enthusiasts. It deals with Trikes but the lesson is the same...don't push it! I was lucky beyond belief. Hey, I'll try to make this as brief as possible. Here's what happened... Me & a good friend were out flying our Trikes. I have a Kolb too. Typical hot, miserable, muggy, windy, buggie, shitty, deep summer Florida day. T-storms in the vicinity. Why people flock to Florida in the summer eludes me completely. Me, after landing on beach, looking at video camera footage & standing within 1 foot of my Trike with my thumb up my ass & my Trike wing angled to windward...in other words...the wrong way it should've been angled with a T-storm very nearby & the wind already picking up. Continuing with my thumb up my ass & while reviewing video footage of total bullshit...all of a sudden, a gust of wind...Trike falls over & bends the keel tube about 20 degrees off center causing all in-flight supporting wires on that side to have a huge amount of slack. Me, continuing to be stupid, removes all excess equipment, gets in & flies it (I'll fly low in case it falls apart Mike") over water, marsh & trees back to the airport... While flying, for some reason... could it be that the Trike has been sitting outside for 7 years (?) & the weird pressures the wing was having to endure to keep itself flying by the hand of an absolute idiot...the wing fabric on the left side starts coming apart at the left end & continuing inward causing a huge amount of control pressure correction on the right side (Trike aka: hang glider) not to mention enough vibration to almost shake the control bar out of my extremely tight grip. This of course added to my scan of the bent keel, wondering if it was bending further & wondering which was going to happen first, the keel & wing collapsing or was the left wing fabric was going to rip itself to pieces prior to my "very seriously in doubt & getting worse" arrival at the airport. I got lucky. Me, after landing & continuing to be stupid beyond belief, asks my friend Mike, who had just landed & was shaking his head horizontally back & forth like I was totally out of my mind...which I was...if I can fly his Trike back the beach to pick up the junk I had left there to make the takeoff lighter & shorter...the only smart thing I did all day. Another long story short...I crash Mike's Trike on landing & bend the same friggin' keel bar on Mike's!!! My first ever crash in nearly 30 years of flying ultralights. His is much lighter than mine & controls much easier (no excuse). I picked up some really crappy turbulence just as I chopped power & attempted to land. It went sideways on me, I corrected too much, it went the other way, I again corrected too much, was too low, too slow & with the engine at near idle to go around...with his much smaller tires, they dug in the sand & flipped me over onto the nose & the keel bent...the same friggin' keel I bent on mine! Believe it or not, I was going to FLY this f--ker back too but upon inspection, found that his keel was bent in TWO places with one break showing sky on the other side. Taking it apart while sweating my ass off & getting bit to hell by sweat bees, sand gnats etc, I'm bending down trying to figure out why in hell the Trike frame will not collapse (for transport by boat back home...another story). Anyway, I finally find a small piece of velcro holding up the situation...pull it apart & WHAM!...the vertical support post falls down onto my head...on the corner of the square post no less...& creates a gush of blood that Dracula would swoon over as well as a huge gash & an actual DENT in my head. Why I didn't think to get out of the way as soon as I pulled that Velcro is beyond me. Forgetting that Mike had put my cell phone in a pocket of his Trike, I walk & wade a mile down a hot, miserable beach, dripping loads of blood down my face & body & find a young lady with a cell phone & a terror stricken face...could it be because of my condition? I call Mike & you can figure the rest. Did it knock any sense into me....I doubt it. I would continue but it just gets worse.... Bill Catalina...U-2 pilot ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: Control positioning during ground handling
> > I can assure you that prop blast also >hits the horizontal stabilizers, elevators, and rudder of every model, >including the two I have never flown. > John & Kolbers, If this is so, then why there so little pitch control after you open the throttle for takeoff? Why did Homer put that little hoop under the nose? Why do some even move their landing gear forward? If this was true, I should be able to hold the stick back against the stop and be able to advance the throttle aggressively and not put the FireFly on it's nose. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Aug 01, 2006
"When I flew an early Firestar with the 35 hp 377, it would cruise true airspeed of 55 mph at only 5,200 rpm and EGTs were fine. It would cruise a good bit over 60 mph at 5800-5900 rpm but was a lot noisier. And this was with a big canister BRS hanging down in the breeze below the fuselage. However, it did have streamlined wing struts but no leg fairings and the prop was a 60" two-blade IVO. And, it had smallish wheelbarrow tires." Thom, Sounds exactly, except motor size as mine, to the IVO prop. It appears from what you stated above that there are or were two cruise speeds. Is this possible? Like going faster until one exceeds a particular "next level" drag coefficient? Man, that would be pretty great, I just crank that baby wide open and get past the shudder and whammo, past the speed of sound! Seriously, is there a second cruise speed? And Reverend, My cockpit is closed on both sides to the point of door clearance from the wings. It is not closed in the back. And Rick, I am touched deeply that you would let me try one of your props. I do believe that mine is their factory IVO prop, and believe that it is 66 inches. Not sure of the pitch. Will check out when back to the plane. My instructor also indicated that a change in prop would make a difference. There goes my drug money. Soon I wont have any bad habits, my plane sucked up all their monies! Steady as a rock here in Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51577#51577 ________________________________________________________________________________
Date: Aug 01, 2006
Hi Ralph, I have a Firestar II with a 447 and a PowerFin ground adjustable prop. I will never claim to be an expert. At fifty-five mph indicated Im turning about 5000 rpm or so. It seems to me that you should be getting a way better performance from your bird having a 503. Sounds like you must be dragging buckets of cement or something. :D I would begin by rechecking your trims and prop. Reduction ratio will make a big difference as to how your KXP will move along. Verify your tach, it may be reading higher than actual rpms. Also verify your airspeed indicator with a GPS. You could be going faster than you think. Just a few ideas to think about. Best Regards Carlos G AKA The BaronVonEvil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51578#51578 ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: Disaster at Nudie Beach! :(
Not that I will open my eyes to see the "Nudi's on the beach", but where is this topic, I need a good laugh. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51580#51580 ________________________________________________________________________________
Date: Aug 01, 2006
WHOA, RALPH!! What shudder? This is the first I've heard of that. Tell us more about this shudder. It needs to be investigated first and foremost. Mine was smooth as silk up to about 75 mph and then there was no "shudder" but it was getting a little squirrely and very noisy. It was smooth and comfortable at all speeds from 40 mph to about 70, just a lot noisier at the higher speeds than the lower ones. Also, I had a complete enclosure on mine, so if your is open, it won't go as fast as one that is open. Even with an open cockpit and a windshield, I would think you should be able to get 60-65 easily enough with an engine about 37% stronger than mine. When just sight seeing I cruised at 5,200 rpm and 55 mph and burned about 2.6 gph average at that speed. It also climbed at 700 fpm with a 210 lb pilot and ten gallons of fuel, so I know the prop was set for a good compromise between climb and cruise. As one Kolber said, you should maybe look at your prop pitch along with the streamlining efforts. -------- Thom in Buffalo Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51582#51582 ________________________________________________________________________________
Date: Aug 01, 2006
Baron, I have two: one electronic and one mechanical, ASI's as well as two electronic Tach's. Both are on the Flight II and Engine F-1 glass gauges, and are correct. I do however wonder what prop you may be using as there was a conversation on this site and may still be on-going that talks about RPM and ASI. John H. hit the nail on the head about my actual RPM verses ASI, our ring-ding motors do like that 5,500 to 6,500 RPM range. Are your EGT's where they should be? What ASI are you getting from your cruise? I would "assume" (gulp) that the 447 would want the same kind of RPS to run effeciently. And yes, I believe I am dragging a bucket of cement or two. Thats what I want to work out. Not that 55 is a bad speed, but when I fly over the freeway here in Ohio, I'd like to at least match speed. And not the my kolb won't do 85 streight, it isn't the most effecient at doing that. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51587#51587 ________________________________________________________________________________
Date: Aug 01, 2006
Thom, there really isn't any "shudder". What I was eluding to was when man first exceeded the speed of sound, there was a shudder. The plane flew well up to that point and then shook like it was coming apart and then when the sound barrier was broken, it went back to normal. I may have a certain sensitivity to the cruise and also have a gauge telling when I am climbing or dropping or stable. When I pick an altitude in still air and level off, it takes a reduction or increase in throttle to maintain that altitude. For me, it is maintained at 55 and at 5,400-5,600 RPM. From what I read in what you wrote (that'l make your head spin), it seemed that you had a low and a high cruise. I must have misread your post. My comment was both serious as in "are there two cruise speeds?" and If I keep cranking will I "attain" another cruise speed. Now my head hurts and the winds are high here in Ohio and the thermals are aggressive and I haven't had a fix (FLYING..PEOPLE, FLYING), in over a week! Perhaps that's why I not making very much sense. Ohio Ralph with the shakes! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51592#51592 ________________________________________________________________________________
Date: Aug 01, 2006
If this was true, I should be able to | hold the stick back against the stop and be able to advance the throttle | aggressively and not put the FireFly on it's nose. | | Jack B. Hart FF004 Jack B: This subject is getting beaten to death. Aggressive throttle control doesn't have any place in aircraft, rotary or fixed, real ones or UL's. Pilot technique has a lot to do with how well a Kolb behaves. Undoubtedly, you have your way of flying and I have mine. I'm not telling anyone how to fly their airplane. If that is the impression I gave in previous posts, I was wrong. I like to share how I do it, if it works well. If it doesn't, I like to share that too, hopefully someone will learn from it. If not, no sweat. john h mkIII ________________________________________________________________________________
Date: Aug 01, 2006
| And Reverend, My cockpit is closed on both sides to the point of door clearance from the wings. It is not closed in the back. | | Steady as a rock here in Ohio Ralph Ralph: Just a guess, but I would think most of your drag is being produced by your cockpit/cabin configuration. Seems to me like you are flying around in a big suction cup, e.g., the inclosed front and open rear cockpit. The original FS would fly 85 mph WOT straight and level powered by a 447. Cockpit not fully enclosed, but the rear of the fuselage was. On my FS I put a 6 to 8" fairing, made of lexan, on the top of the windshield. This increased airspeed by directing air over the center section. I also flew with 4130 streamlined lift struts. And........my 447's were cleaned up to make a little more power. US flew 85 mph straigh and level, WOT, with a 35 hp Cuyuna. My sharp pointed nose probably helped eliminate some drag sitting completely in the open. I think fabric tension has a lot to do with how well a Kolb flies. When I shrink my fabric, I shrink it until the structure squeals. Check out my mkIII and you will see evidence of extremely tight fabric and bowed edges. Sometimes we don't shrink tight enough, making for a more concave wing bottom and different shape on top of the wing. That surely must slow us down. The FS II does not perform nearly as well as the original FS, in my own humble opinion based on a lot of hours flying both models. Take care, john h hauck's holler, alabama mkIII/FS/US ________________________________________________________________________________
Date: Aug 01, 2006
John, and others; I am amazed, truly amazed that there can be two different extremes that provide the same response from the plane. And as you stated in a previous post, John, "They all fly, very basically, the same way. I can assure you that prop blast also hits the horizontal stabilizers, elevators, and rudder of every model, including the two I have never flown." All pushers, all Kolbs, all tail draggers and with the little difference of side by side, front-back, single, as well as engine size and prop size, they all have the same dynamics of existing physical laws to follow. Forward stick, all the way, back stick, all the way....absolutely amazes me that both can possibly work. This single piece of discussion exceeds any piece of work that I have read (and I have read each and every one from the beginning). How can that be possible? The ONLY way that both methods can co-exist is if : 1). Everyone is talking about something completely different but the same in all outward appearances, like downwind taxiing verses lifting off (going into the wind). Now when I taxi down to position myself for turning around and taking off, and there IS wind, I still am full back stick. AMAZING! 2). Controls are backward, you know lefty-loosie,righty-tighty, or mirror image as in being levitated and looking back at yourself from without rather than within. AMAZING! Did I say AMAZING here in Ohio Ralph? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51600#51600 ________________________________________________________________________________
Date: Aug 01, 2006
Hi Ralph, Here is another thought, when you get a chance please post some photos of your bird in its present state. Sort of do a walk around of your plane so that all us wanna be aerodynamisist can look at your plane. We may be able to spot something here or there that might help you gain the needed speed you desire. ( We promise to ignore the Cement bucket!). My EGT and CHT are right where they should be. I run a 62" PowerFin composite, ground adjustable prop that seems to be just the ticket. I have a 447 with a B box with the 2.59 reduction. Its a pull start engine. Looking forward to the pictures... Best regards Carlos G Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51603#51603 ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Flaps uneven?!?!
I am hooking up the flap horns and I noticed that both flaps stick up about 1/2 inch higher than the ailerons.... I guess the silver lining is that both sides do it... Any thoughts on this? Has anyone else seen this? Sorry for large pics. ________________________________________________________________________________
Date: Aug 01, 2006
Ralph, My original Firestar cruises at about 60-65 mph at 5,800 with a 503 DCDI. John Murr ----- Original Message ----- Sent: Tuesday, August 01, 2006 7:44 AM > > > Fantastic, Gentlemen, and thank you. > > Here goes: > RPM is between 5,600 and 5,800 RPM at cruise. Struts are streamlined > thanks to my predecessor. Gaps between all air foil hinged area are gap > sealed, but only on one side. I believe ailerons are on the underside, > will need to check if that makes any difference. Rudder is on the Port > side. I noted the Preacher stated something along the lines of landing > gear legs. What is there are round plastic tubes, who's I.D.'s are > slightly larger than the legs themselves. They are the Kolb longer legs. > > I never remember experiencing the "defined" feeling of cruise when I was > flying the Challenger. It sure is noticeable in the Kolb. Plus my > Flightstar II climb / descend indication shows precisely where that point > is. Sounds like the only thing left is streamlining the legs. Will that > make any significant difference? If so, I may do it out of the Mylar > initially. > > Thank you each one, again for your help. And "IS" 55 a typical cruise > speed for the Firestar? > > Ohio Ralph > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=51435#51435 > > > ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: Flaps uneven?!?!
David: There is a lot of down force on the ailerons in flight. If you put pressure on them with you hand, they will drop quite a bit. In this configuration, flaps will help overcome some of the nose down pitch normal with a high thrust line, especially the mkIII and a high powered engine. Mine are adjusted very similar. john h mkIII ________________________________________________________________________________
Date: Aug 01, 2006
On Aug 1, 2006, at 12:17 PM, Richard Pike wrote: > On our FSII, it has a 582, and runs 55 mph at 5000 rpm. At 5800 > rpm, you better to have the nose up and be climbing. Rich, What diameter prop are you guys turning? My 582 FSII 55 mph = 4700 rpm but I sacrificed some climb performance. I have a 72" IVO and a 2.58 B box. Fuel burn = 2.5 gal. per hr. ________________________________________________________________________________
Date: Aug 01, 2006
Man, I don't know what it is but I also feel relieved and at ease. I guess the many problems I am having are really unimportant in comparison. Wow, Thanks Mike. OOooooooo Ralph Hi, oh! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51626#51626 ________________________________________________________________________________
Date: Aug 01, 2006
On Aug 1, 2006, at 5:26 PM, David Key wrote: > I am hooking up the flap horns and I noticed that both flaps stick > up about 1/2 inch higher than the ailerons.... I guess the silver > lining is that both sides do it... Any thoughts on this? Has anyone > else seen this? Bummer, hate when that happens! No easy fix that I know of. ________________________________________________________________________________
Date: Aug 01, 2006
| | | On Aug 1, 2006, at 5:26 PM, David Key wrote: | | > I am hooking up the flap horns and I noticed that both flaps stick | > up about 1/2 inch higher than the ailerons.... | | Bummer, hate when that happens! | | No easy fix that I know of. Hi Gang: I was assuming it was the trailing edges of the flaps that were sticking up higher than the ailerons. Maybe David is talking about where they hang on the hinge line. john h mkIII ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: OSH 2006
| We saw Miss P'Fer several times over Camp Scholler and a few times on the UL | field but I can never quite figure out how to get from the crowd portion of | the UL area to the flight line. | | We did wave at you several times though, John. | | Todd Todd: The UL tie down/camping area leaves a lot to be desired. Places the airplanes as far away from the spectators as possible. To get over to where we camp, one must come through one of the gates on the east side of the flight line, walk around the north or south end of the UL airstrip. I have tried to get the UL powers to be to change the policy and let us tie down so the crowd can see our airplanes, yet also allow us to camp with our airplanes. It is a pain in the butt to have to walk a mile around your elbow to get in and out every time you need something from your airplane. john h mkIII ________________________________________________________________________________
Date: Aug 01, 2006
David, I adjusted the flaps using the threaded connectors on the pushrod ends to get the trailing edges of flaps and ailerons in line. Kolb doesn't use a left hand thread on one end so that it acts like a turnbuckle (at least they didn't on mine) so you have to disconnect one end to adjust them. Also make sure the flap bellhorns are installed per the plans. The guy who built my airplane apparently didn't understand how to align them and when I got a touch of aileron flutter one bellhorn got into my nice new Warp Drive and took out $500 worth of prop blades in short order. Which leads to another suggestion, make sure you install the aileron counter balances. If they didn't come with your kit, call Travis today and order a set. Rick On 8/1/06, John Hauck wrote: > > > | > | > | On Aug 1, 2006, at 5:26 PM, David Key wrote: > | > | > I am hooking up the flap horns and I noticed that both flaps stick > | > up about 1/2 inch higher than the ailerons.... > > > > > | > | Bummer, hate when that happens! > | > | No easy fix that I know of. > > Hi Gang: > > I was assuming it was the trailing edges of the flaps that were > sticking up higher than the ailerons. > > Maybe David is talking about where they hang on the hinge line. > > john h > mkIII > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 01, 2006
Well it was good to see you from a medium distance at any rate. Next year we should have a good solid forward operating base at Camp Scholler so after you walk a mile around the elbow you'll have to come by for some grilled stuff. Todd On 8/1/06 8:24 PM, "John Hauck" wrote: > > > > | We saw Miss P'Fer several times over Camp Scholler and a few times > on the UL > | field but I can never quite figure out how to get from the crowd > portion of > | the UL area to the flight line. > | > | We did wave at you several times though, John. > | > | Todd > > > Todd: > > The UL tie down/camping area leaves a lot to be desired. > > Places the airplanes as far away from the spectators as possible. > > To get over to where we camp, one must come through one of the gates > on the east side of the flight line, walk around the north or south > end of the UL airstrip. > > I have tried to get the UL powers to be to change the policy and let > us tie down so the crowd can see our airplanes, yet also allow us to > camp with our airplanes. > > It is a pain in the butt to have to walk a mile around your elbow to > get in and out every time you need something from your airplane. > > john h > mkIII > > > > > > > > > > > > > > -- Todd Fredricks, DO Flying Fox Services Visit my Blog at www.flyingfoxhangar.blogspot.com Photos Located at http://www.flickr.com/photos/flyingfoxservices/ ________________________________________________________________________________
Date: Aug 01, 2006
Kolbers: Back in FL after a great week in Oshkosh and visiting with some of the Kolb family. Attached are just a few pics of some of them. -------- George Alexander http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51653#51653 Attachments: http://forums.matronics.com//files/oshkosh_06_john_hauck_431.jpg http://forums.matronics.com//files/tnk_fsii_rayhill_442.jpg http://forums.matronics.com//files/tnk_crew_donnie_travis_and_dennis_122.jpg http://forums.matronics.com//files/oshkosh_06_homer_kolb_187.jpg ________________________________________________________________________________
Date: Aug 01, 2006
Excellent adventure, John. Thanks for all of the little the details as we all picture ourselves experiencing the same events that make for such a memorable trip... Kip -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51656#51656 ________________________________________________________________________________
Date: Aug 01, 2006
Got a correction - all this talk about Firestars got the best of me, so I went flying a little while ago. And discovered I remembered my numbers all wrong. My apologies, and here is what it really is. First flight, the prop had too much pitch for this hot air, made the EGT's way too low, but the airspeed/rpm ratio was nice. 4800 rpm= 58mph 4900=60 5000=62 5300=70 5500=75 5700 The tach in the EIS was being silly around 51-5200 rpm, so no speeds recorded there. Landed and took 3/4 of a turn of pitch out of the Ivoprop and tried it again, the airspeed/rpm ratio was not as good, but the EGT's were up to normal. 4600=48 4800=51 5000=55 5200=66 5400=70 5600=75 5800=78 There is not as perfect a correlation between rpm and airspeeds as I would like, the tach in the EIS tends not to settle at any certain rpm, it hops around a bit, (Is this normal?) so there is a certain lack of precision here, but I think you get the general idea. And it has a 68" Ivo 2 blade, and a 2.58:1 gearbox. I don't know what it burns an hour, since I am not the one that usually flies it, but it is more than 2.5 gph. Richard Pike MKIII N420P (420ldPoops) Eugene Zimmerman wrote: > > > On Aug 1, 2006, at 12:17 PM, Richard Pike wrote: > >> On our FSII, it has a 582, and runs 55 mph at 5000 rpm. At 5800 rpm, >> you better to have the nose up and be climbing. > > > Rich, > What diameter prop are you guys turning? > > My 582 FSII 55 mph = 4700 rpm but I sacrificed some climb performance. > I have a 72" IVO and a 2.58 B box. > > Fuel burn = 2.5 gal. per hr. > > > http://www.matronics.com/Navigator?Kolb-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Aug 01, 2006
On Aug 1, 2006, at 7:30 PM, John Hauck wrote: > Maybe David is talking about where they hang on the hinge line. Looks like a hinge line problem to me. Requires removing and reattaching the hinges. This problem happen when rivets are set and are not exactly on the apex of the tubes they attach to. It is very easy to make this mistake. I always first use a few aluminum rivets to attach each hinge and double check the alignment before final riveting. Replace the aluminum rivets with steel when alignment is confirmed. Trailing edge no big problem. ________________________________________________________________________________
Date: Aug 01, 2006
Thanks John and Richard. I have a prop extension so my warp should be fine, but I understand the plans anyway. I do have the aileron counter balances. No instructions with the counter balances. Should I just drill out the outer aileron ends and slide them in then adjust the slide out till the aileron is inline with the bottom of the wing? I'm less than a month away from first flight and closing fast. I'm going to start the engine tomorrow. >From: "Richard Girard" <jindoguy(at)gmail.com> >Reply-To: kolb-list(at)matronics.com >To: kolb-list(at)matronics.com >Subject: Re: Kolb-List: Flaps uneven?!?! >Date: Tue, 1 Aug 2006 19:38:39 -0500 > >David, I adjusted the flaps using the threaded connectors on the pushrod >ends to get the trailing edges of flaps and ailerons in line. Kolb doesn't >use a left hand thread on one end so that it acts like a turnbuckle (at >least they didn't on mine) so you have to disconnect one end to adjust >them. >Also make sure the flap bellhorns are installed per the plans. The guy who >built my airplane apparently didn't understand how to align them and when I >got a touch of aileron flutter one bellhorn got into my nice new Warp Drive >and took out $500 worth of prop blades in short order. >Which leads to another suggestion, make sure you install the aileron >counter >balances. If they didn't come with your kit, call Travis today and order a >set. > >Rick > >On 8/1/06, John Hauck wrote: >> >> >> >> >>| >>| >>| On Aug 1, 2006, at 5:26 PM, David Key wrote: >>| >>| > I am hooking up the flap horns and I noticed that both flaps stick >>| > up about 1/2 inch higher than the ailerons.... >> >> >> >> >>| >>| Bummer, hate when that happens! >>| >>| No easy fix that I know of. >> >>Hi Gang: >> >>I was assuming it was the trailing edges of the flaps that were >>sticking up higher than the ailerons. >> >>Maybe David is talking about where they hang on the hinge line. >> >>john h >>mkIII >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > >-- >Rick Girard >"Ya'll drop on in" >takes on a whole new meaning >when you live at the airport. ________________________________________________________________________________
Date: Aug 02, 2006
-- "John Murr" wrote: Ralph, My original Firestar cruises at about 60-65 mph at 5,800 with a 503 DCDI. John Murr John M, Mine does the same speed at 5200 with a 447 SC and streamlined struts, long windshield. Ralph Original Firestar 19 years flying it N91493 ----- Original Message ----- Sent: Tuesday, August 01, 2006 7:44 AM > > > Fantastic, Gentlemen, and thank you. > > Here goes: > RPM is between 5,600 and 5,800 RPM at cruise. Struts are streamlined > thanks to my predecessor. Gaps between all air foil hinged area are gap > sealed, but only on one side. I believe ailerons are on the underside, > will need to check if that makes any difference. Rudder is on the Port > side. I noted the Preacher stated something along the lines of landing > gear legs. What is there are round plastic tubes, who's I.D.'s are > slightly larger than the legs themselves. They are the Kolb longer legs. > > I never remember experiencing the "defined" feeling of cruise when I was > flying the Challenger. It sure is noticeable in the Kolb. Plus my > Flightstar II climb / descend indication shows precisely where that point > is. Sounds like the only thing left is streamlining the legs. Will that > make any significant difference? If so, I may do it out of the Mylar > initially. > > Thank you each one, again for your help. And "IS" 55 a typical cruise > speed for the Firestar? > > Ohio Ralph > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=51435#51435 > > > ________________________________________________________________________ ________________________________________________________________________________
Date: Aug 01, 2006
Rich, My EIS tack seem to be steady and accurate up to 6400 rpm. Over that it goes nuts and jumps to over 8000 rpm. On Aug 1, 2006, at 9:22 PM, Richard Pike wrote: > There is not as perfect a correlation between rpm and airspeeds as > I would like, the tach in the EIS tends not to settle at any > certain rpm, it hops around a bit, (Is this normal?) so there is a > certain lack of precision here, but I think you get the general idea. ________________________________________________________________________________
Date: Aug 01, 2006
Hi George, Thanks for sharing the picts ! Gene On Aug 1, 2006, at 9:13 PM, George Alexander wrote: > Kolbers: > Back in FL after a great week in Oshkosh and visiting with some of > the Kolb family. Attached are just a few pics of some of them. > > -------- > George Alexander > http://gtalexander.home.att.net ________________________________________________________________________________
Date: Aug 01, 2006
At 04:41 PM 8/1/2006, you wrote: > > >Forward stick, all the way, back stick, all the way....absolutely >amazes me that both can possibly work. This single piece of >discussion exceeds any piece of work that I have read (and I have >read each and every one from the beginning). How can that be possible? Depends on the weather - we always - and I mean "always" check the weather (safety first). ________________________________________________________________________________
Date: Aug 01, 2006
At 02:49 PM 8/1/2006, you wrote: >Bill, > > Talk about a bad hair day!!! > >Anyway, I finally find a small piece of velcro holding up the >situation...pull it apart & WHAM!...the vertical support post falls >down onto my head... creates a gush of blood that Dracula would >swoon over as well as a huge gash & an actual DENT in my head. Why I >didn't think to get out of the way as soon as I pulled that Velcro >is beyond me. > >Did it knock any sense into me....I doubt it. > >I would continue but it just gets worse.... You could be a "Possum" too http://www.mindspring.com/~possums/DeadPossum.jpg http://www.mindspring.com/~possums/ ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: Gas cap
Anyone Know of a source for the gas cap that fits the standard 5- gallon tank other than TNK? Ed ________________________________________________________________________________
Date: Aug 02, 2006
Hi Ed, Would you be interested in a used one or two? I have two old tanks that came out of the Twinstar I sold that has the standard cap with screwed in plug and small vent hole. Later, John Cooley _____ [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of DAquaNut(at)aol.com Sent: Wednesday, August 02, 2006 1:05 AM Anyone Know of a source for the gas cap that fits the standard 5- gallon tank other than TNK? Ed ________________________________________________________________________________
Date: Aug 02, 2006
Subject: For Sale 912ULS
Morning Gang: I have a chance to upgrade my mkIII with a new 912ULS. Therefore, my 912ULS is now for sale. Date Purchased: Feb 2000 Total Time: 1,200 hours Upgrades: Slip clutch High torque starter Recent carb upgrades Will have the gear box pulled and inspected prior to sale. At this time, torsional vibration damper will be reshimmed, as necessary, to bring it into specs. All accessories that come with a new 912ULS will go with this engine; oil tank, voltage regulator/rectifier. Engine produces identical power today that it did when new. Never used any oil. Never quit running for any reason. This engine powered my mkIII to Point Barrow, Alaska, on two separate flights. Also Tuktoyaktuk, North West Territory, Canada, and many flights to the West Coast and back. Engine has crossed the Rocky Mountains many times, pushing the mkIII as high as 15,000 feet. If you are interested in purchasing this 912ULS, please call me: 334-567-6280 (H) 334-315-2621 (C) Or you may email me: jhauck(at)elmore.rr.com The 912UL and 912ULS engines have extraordinary reputations as being extremely reliable. It is not uncommon for a 912 series engine to run well beyond 2,500 hours. If I did not have a chance to upgrade at this time, I would have no qualms to continue flying this engine to 3,000 hours and beyond. I am selling this engine for $7,995.00. john h mkIII ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: For Sale 912ULS
| Therefore, my 912ULS is now for sale. | john h Hello again: Reference sale of my 912ULS, the engine is still mounted on my mkIII. Will be more than happy to demonstrate performance of engine prior to sale. Engine is located in Titus, Alabama, approximately 25 miles north of Montgomery, Alabama. May be able to work out delivery of engine, depending on buyer's location. john h mkIII ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: Flaps uneven- Gas cap
What do some Mark III pilot use for fuel tanks? I was thinking of a fuel cell. Any suggestions? Also, do you have an idea of how long the plastic tanks will last? ________________________________________________________________________________
Date: Aug 02, 2006
Why did Homer put the hoop under the nose cone? Don't know, but I sure do like it. It prevents my nose from hitting when I spin it around by holding one brake and full rudder in case I add too much throttle. Also, it lets me do a full throttle run up which my Geo needs in the winter time to warm up. The nose skid and full brakes will hold it at full power which then lets me set the prop pitch to 6000 rpm for best power climb. I can adjust the pitch during the takeoff roll, but that requires extra attention. ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: stalls
One thing that I like about my Mark III is that when you get close to a stall, it starts acting strange. Kind of like a silent stall warning device that is telling you to get the nose down a little. ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: flap takeoff
My landings are hard too. Everything looks fine and I expect it to settle in on three points. But, it doesn't settle....just drops.......bam. It is worse with no flaps. Carrying a little power makes things much easier, but I prefer power off landings. At 2000 rpms (smooth idle), the thrust is 20 lbs. and I imagine that it simulates the dynamics of a stopped prop landing. Will find out more when I start my ignition off landing practice. ________________________________________________________________________________
Date: Aug 02, 2006
| | My landings are hard too. Everything looks fine and I expect it to | settle in on three points. But, it doesn't settle....just | drops.......bam. APilot: The airplane is landing exactly like any airplane lands. If you are too high when it stalls, it will quit flying, and hit hard. If you place the airplane a few inches off the ground, hold it until it stalls, it will land nice and gentle. At 2000 rpms | (smooth idle), the thrust is 20 lbs. and I imagine that it simulates the | dynamics of a stopped prop landing. Not quite. The slowly rotating prop acts just as though it were a large disc, creating a lot of drag. When the prop is stopped, the only drag experienced is the actual area of each blade. There is a lot of difference between dead stick and engine idling landings. My own personal experience only. However, most Kolbs fly very much alike. john h mkIII ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Round Engines
DEDICATED TO ALL THOSE WHO FLEW BEHIND ROUND ENGINES We gotta get rid of those turbines, they're ruining aviation and our hearing... A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat. Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start. Cranking a round engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a horny mistress. On some planes, the pilots aren't even allowed to do it... Turbines start by whining for a while, then give a lady-like poof and start whining a little louder. Round engines give When you start a round engine, your mind is engaged and you can concentrate on the flight ahead. Starting a turbine is like flicking on a ceiling fan: Useful, but, hardly exciting. When you have started his round engine successfully your Crew Chief looks up at you like he'd let you kiss his girl, too! Turbines don't break or catch fire often enough, which leads to aircrew boredom, complacency and inattention. A round engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the mind! Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights. Turbines smell like a Boy Scout camp full of Coleman Lamps. Round engines smell like God intended machines to smell. P ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Aug 02, 2006
APilot John is right, stabilize your approach and fly it down to just a few inches off the ground and it will settle in nice and smooth. The problem is holding that approach down just till just that right point a few inches above the ground before you flair. If you are used to big general aviation airplanes you will have more problems doing this than any one else because you are used to airplanes that have allot more inertia than a MKIII. Getting a good landing with no power isn't easy. The more flaps you use with no power the more difficult it will be. I can't say this enough till you are used to your airplane "you need to carry power all the way in till you are inches above the ground". Hold the stick steady and cut the power and it will raise the nose all by its self just a bit and settle in nice as can be. Do this till have it down cold. THEN start using less and less power but don't rush this part. I like to land with some power all the time with one notch of flaps. But do what makes you happy and safe. One notch of flap cuts the stall speed a bit and the float in ground effect. Also a Kolb MKIIIc will land with no power (off, stopped, dead) with no flaps just about like it does with some power and one notch of flap. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- Sent: Wednesday, August 02, 2006 2:40 PM > > My landings are hard too. Everything looks fine and I expect it to > settle in on three points. But, it doesn't settle....just > drops.......bam. It is worse with no flaps. Carrying a little power > makes things much easier, but I prefer power off landings. At 2000 rpms > (smooth idle), the thrust is 20 lbs. and I imagine that it simulates the > dynamics of a stopped prop landing. Will find out more when I start my > ignition off landing practice. > > > ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Flying to the 2005 Kolb Homecoming
Aaproaching Fontana Dam, NC, is James Tripp, Millbrook, AL, in his 503 powered Kolb FSII. James and the FS sure look small in front of that big dam. john h mkIIII ________________________________________________________________________________
Date: Aug 02, 2006
When I startred flying my Kolb MkIII, my landings were inconsistent. For the purposes of this missive, inconsistent is defined as, do five landings or less, remove gear legs, straighten same, and reinstall. I'm reeeaaaaal good at straightening gear legs. This went on through the winter and into the spring. I was pretty bummed and one day while I was on the phone with Travis, I told him I was having problems, I just couldn't seem to get my flair right. I would land perfectly once or twice, then WHAM, time to go see Mr. Press again. "You've got to learn to wheel land this airplane and stop trying to three point it. You learn to wheel land this airplane and you'll like it just fine." Travis, I am convinced, is a genius. I dug out my copy of "The Compleat Taildragger Pilot" by Harvey S. Plourde. Whatta ya know, "learn to wheel land the taildragger first, then advance to three point landings". Mr.Plourde's reason? Basically, with the wheel landing, you're more likely to get a landing rather than an arrival. Okay, that's a little terse, but it's the essence. I started working on wheel landings, I bounced a little, but not too bad or too high and I never slammed in again. My landings got smoother. Quite a bit of the improvement was due to my hands and feet slowly evolving from large hams to instruments capable of a bit of delicacy. Now I can truly say that Yesterday, I couldn't spell taildragger pilot, today I are one. Mr. Press is very, very lonely. Rick On 8/2/06, Richard & Martha Neilsen wrote: > > NeilsenRM(at)comcast.net> > > APilot > > John is right, stabilize your approach and fly it down to just a few > inches > off the ground and it will settle in nice and smooth. The problem is > holding > that approach down just till just that right point a few inches above the > ground before you flair. If you are used to big general aviation airplanes > you will have more problems doing this than any one else because you are > used to airplanes that have allot more inertia than a MKIII. Getting a > good > landing with no power isn't easy. The more flaps you use with no power the > more difficult it will be. I can't say this enough till you are used to > your > airplane "you need to carry power all the way in till you are inches above > the ground". Hold the stick steady and cut the power and it will raise the > nose all by its self just a bit and settle in nice as can be. Do this till > have it down cold. THEN start using less and less power but don't rush > this > part. > > I like to land with some power all the time with one notch of flaps. But > do > what makes you happy and safe. One notch of flap cuts the stall speed a > bit > and the float in ground effect. Also a Kolb MKIIIc will land with no power > (off, stopped, dead) with no flaps just about like it does with some power > and one notch of flap. > > Rick Neilsen > Redrive VW powered MKIIIc > > ----- Original Message ----- > Sent: Wednesday, August 02, 2006 2:40 PM > > > > > > My landings are hard too. Everything looks fine and I expect it to > > settle in on three points. But, it doesn't settle....just > > drops.......bam. It is worse with no flaps. Carrying a little power > > makes things much easier, but I prefer power off landings. At 2000 rpms > > (smooth idle), the thrust is 20 lbs. and I imagine that it simulates the > > dynamics of a stopped prop landing. Will find out more when I start my > > ignition off landing practice. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: crosswind
| Kolb Firestar feel is a max mph crosswind that you would attempt to make a | landing. | Jim swan Jim: Anything over 15 mph 90 deg cross wind will certainly overpower the rudder on FS's and other model Kolbs. I know, I know. Some on the Kolb List are doing 90 deg cross wind landings at 25+ mph. Only thing I can say about that is they are a lot more experienced flying in wind than I am. One day I hope to learn their technique. Kolbs usually land slow enough to land most any place, like across the runway at larger airports, to get the nose into the wind. When the wind is honking, I try to get as much of the nose into the wind as I can. Another normal procedure that works well with Kolbs, as it does other airplanes, is to drop the wing on the up wind side and hold it through touchdown. Get a lot more out of your Kolb that way. All the above are my own humble opinions. Don't try them at home. This year at OSH we flew with a 90 deg cross wind at 15 to 18 mph. A lot of mechanical turbulence from the houses, barns, large trees, etc., created an exciting atmosphere for landing. Good practice. Take care, john h mkIII ________________________________________________________________________________
From: "Ralph Hoover" <flht99reh(at)columbus.rr.com>
Date: Aug 02, 2006
John, If Ed isn't, I sure would be, including the gas tanks. how much would you want for them? Mine is origional 1990 production as dated by mfgr on molded bottom. I epoxied a small crack near the right rear corner up near the 5 gal. level. It appears to hold well but I have not been able to find a 10 x 10 x 14 inch heavy walled poly tank as used in the Forestar. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51946#51946 ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Hey Matt!
Hey Matt, I noticed when I responded to a subject "Flaps uneven- Gas cap aka Fuel cell" that it gave it a new name in the subject as "gas cap" and created a new subject. This isn't the first time I have seen this, by others as well as myself. Is there something we as posters are doing incorrectly? Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51949#51949 ________________________________________________________________________________
Date: Aug 02, 2006
Per the "how long do they last", On the bottom of almost all blow molded products is a molded in date stamp of some form. Even if the manufacturer's name is not apparent, you should at least see a year and month in small boxes. Mine on the Firestar was produced in June of 1990. It has seen better days. However if you use the proper epoxy for a small crack or hole as a temp fix, it will bond and hold. THe key is finding a epoxy that will attack the poly material, adhering while not breaking down from fuel additives or the different gas configurations. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51951#51951 ________________________________________________________________________________
Date: Aug 02, 2006
Subject: 912ULS Sold
Hi Folks: My 912ULS I advertised on the List this morning is sold. john h mkIII ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: 912ULS Sold
That was easy. Did you sell it to anyone around here? Bill ________________________________________________________________________________
Date: Aug 02, 2006
Hi Bill: You old movie star you............... Saw you twice Channel 12 last night. Did a fine job too. Gentleman over on Johns Island, SC, just south of Charleston, bought it. He is building a MKIIIx. Travis Brown told him about it. He called me this morning. Then called again this evening and said he wanted it. Did not dicker about the price either. john h ________________________________________________________________________________
Date: Aug 02, 2006
Hi Gang: The 912ULS I advertised for sale this morning has sold. Thanks, john h mkIII -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51968#51968 ________________________________________________________________________________
Date: Aug 02, 2006
| You old movie star you............... Gang: As most of you may have gathered by now, the previous post was not intended for the Kolb List. Please disregard. Xin Loi, john h mkIII ________________________________________________________________________________
Date: Aug 02, 2006
My flap problem on the acquired Mark III is that the detentes the flap handle uses have been pretty much destroyed. I can't use them. So I have secured the flaps full up with a hose clamp (not shown). I wonder, since the other Kolb here at TorC Airport has no flaps and I have no other reference, if someone can send me a jpg and or drawings of the appropriate area the handle engages. Can't tell from what's left whether there should be more detentes. A local A&P says he can make one and rivet it over what's left. But he has no idea how many notches there should be, or their spacing. Can someone also provide the measurements and spacing of the... what shall we call them...hooks, flaps detentes, catches...? Thanks, jsf ----- Original Message ----- Sent: Monday, July 31, 2006 8:16 AM > > > Just a further comment on flaps. Those of us that fly the MKIII ________________________________________________________________________________
Date: Aug 02, 2006
If you want to be creative, you can have as many notches as you want...even some reflex, so you don't need as much up elevator trim when you are carrying a passenger - http://www.bcchapel.org/pages/0003/pg3.htm If you are interested, contact me off list, and I'll send you some more pictures tomorrow. Richard Pike MKIII N420P (420ldPoops) john s. flannery wrote: > My flap problem on the acquired Mark III is that the detentes the flap > handle uses have been pretty much destroyed. I can't use them. So I > have secured the flaps full up with a hose clamp (not shown). I > wonder, since the other Kolb here at TorC Airport has no flaps and I > have no other reference, if someone can send me a jpg and or drawings > of the appropriate area the handle engages. Can't tell from what's > left whether there should be more detentes. A local A&P says he can > make one and rivet it over what's left. But he has no idea how many > notches there should be, or their spacing. Can someone also provide > the measurements and spacing of the... what shall we call > them...hooks, flaps detentes, catches...? > Thanks, > > jsf > > ________________________________________________________________________________
Date: Aug 02, 2006
Thank you for the landing advice. Vic in Sacramento ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: Flaps uneven- Gas cap aka Fuel cell
Answer: Yes, I did mean to say fuel cell. A friend of mine thinks that it is very dangerous to have a few gallons of gas behind the seat in case of a crash. He installed a fuel cell in his dune buggy for about $150. The size that he bought will not fit in my Mark III. Seems that most Kolb pilots do not think of this as a danger. ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Check List
Does someone have a check list they can email me? I need one for my preflights and didn't want to start from scratch. Thanks, David ________________________________________________________________________________
Date: Aug 03, 2006
Hi Ralph/Gang, I know one of the tanks is busted. The other may be ok, I'd just have to check. They came out of a Twinstar and have holes in the bottom for the fuel lines. I would give them to whoever wants them. I would be willing to just ship the caps to Ed or whoever if Ed doesnt want them. If someone wanted the tank, if it's any good, I might ask for some shipping cost. Later, John Cooley -----Original Message----- [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ralph Hoover Sent: Wednesday, August 02, 2006 7:56 PM John, If Ed isn't, I sure would be, including the gas tanks. how much would you want for them? Mine is origional 1990 production as dated by mfgr on molded bottom. I epoxied a small crack near the right rear corner up near the 5 gal. level. It appears to hold well but I have not been able to find a 10 x 10 x 14 inch heavy walled poly tank as used in the Forestar. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51946#51946 -- -- ________________________________________________________________________________
Date: Aug 03, 2006
Sounds to me like folks are thinking two different definitions with regard to the term fuel cell. Here is what Merriam-Webster says about "fuel cell". http://www.m-w.com/dictionary/fuel%20cell That is the kind of fuel cell that is supposed to keep our grandchildren from running out of gas when we are long gone. I've heard the fuel bladders like those used in some race cars called fuel cells but that is not standard usage. Of course we have lots of non-standard users of English on this list, so who cares? Thom in Buffalo ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Gas cap aka Fuel cell
Yah, the gadget in that definition is a fuel cell, but the automotive fuel tank replacement is a different thing. Very much a safety item, they're a very good idea. Take a look at another website: http://auto.howstuffworks.com/nascar-safety1.htm Lar. ----- Original Message ----- Sent: Thursday, August 03, 2006 5:07 AM > > Sounds to me like folks are thinking two different definitions with regard > to the term fuel cell. Here is what Merriam-Webster says about "fuel > cell". > > http://www.m-w.com/dictionary/fuel%20cell > > ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Kolb Fuel Tanks
Morning All: Kolb has new 6 gal plastic fuel tanks for $25.00. Same dimensions as old tanks, except a few inches taller. 5 gal tanks are $20.00. This was the price stickers on the tanks at OSH. Call Travis at Kolb and check'em out. john h mkIII ________________________________________________________________________________
Date: Aug 03, 2006
John, Sounds like the aged problem I have also, if one of the tanks is busted. Once they breakdown, there they are. That UV lasts a long time but on mine having the upper area exposed for 16 years does take it's toll. I have an aduquate cap right now. It's not in bad shape. I have found some other tanks, even a 10 x 10 x 24 that would do the job, but the manufacturer doesn't make it with the proper "skin" coating and therefore recoments that it not be used for lawn mower gas tank (wink, wink). I'm not sure how long a life it would have. At $74.00 plus shipping and fill hole kit, I'm not about to experiment. Thanks for your offer, Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52059#52059 ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Re: Kolb Fuel Tanks
John, Your a blessing in more ways than one. Thanks for the information. You have allowed many of us "One hour safe drivers", the dignity and respect of you "Professional Drivers" , by expanding our range! I owe you a big frosted mug cold one. Now I can truly go far and wide and see this vision that they say that the world is truly round. This I have feared as until now, was only to believe that it would be but a dream! Ah, to go past the edge of my pattern without fear of running out of fuel. Now my idiocy will need be better spent on some other stupid mistake. "If there were no other wisdom, than that expounded upon by this man, this day, it would still be the most complete of all my days." Leopold Crasinsky Kinda brings tears of joy to my eyes! Ralph, Jumping for joy here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52062#52062 ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Re: Check List
Someone made this one for my Firestar: It is very detailed. You may add or subtract. I would like to see what others are using and maby come up with a better one. Ohio Ralph Firestar:Preflight Checklist Pitot tube: extended / clear Static Port: clear Lift Strut (lower): pinned / safety clip Wheel / brakes: nut & cotter pin / axle bolts Lift Strut (top): pinned / safety clip Leading Edge: check for dents Wing Tip: aileron counter weight secure Aileron: hinge pins/cotter pins Aileron Control Rod: Pinned / safety clip / bottom bolt & nut Gap Seal: secured Wing Swivels: Bolts / nuts / cotter pins Wing "Main" Pins: pinned / safety clip Exhaust: muffler bolts / springs / safety wire Prop: secure / nicks / spinner / leading edge tape Tailboom: main bolt / nut / check for dents Horizontal Stabilize: front bolt / nut / cotter pin Guide Wires: good tension Elevator Hinges: pins / cotter pins / bolt / nut Elevator Control Cables: Cleviss / bolts / nuts / cotter pins Rudder Control Cables: Cleviss / bolts / nuts / cotter pins Rudder Hinges: pins / cotter pins Tailwheel: springs / bolts /nuts / cotter pin Guide Wire: bolt / castle nut / safety clip Elevator Hinges: pins / cotter pins / bolt / nut Guide Wires: good tension Horizontal Stabilizer: front bolt / nut / cotter pin Tailboom: main bolt / nut / check for dents Aileron Control Rod: Pinned / safety clip / bottom bolt & nut Gap Seal: secured Fuel Pump: fuel lines / pulse line / secured Spark Plug Wires: secured Carburetors: Secure / filters secure / safety wire / fuel lines Oil Injection: tank/ pump/ site gauge / cap secured / safety wire Throttle Cables: secured Lord Mounts: bolts/ nuts / mounting plate Aileron: hinge pins/cotter pins Wing Tip: aileron counter weight secure Leading Edge: check for dents Lift Strut (top): pinned / safety clip Lift Strut (lower): pinned / safety clip Wheel brakes: / nut & cotter pin / axle bolts Fuel Tanks: FULL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52064#52064 ________________________________________________________________________________
Date: Aug 03, 2006
Thanks it's a good start. ________________________________________________________________________________
Date: Aug 03, 2006
Here are some closeups of the mechanism. The detent with the holes in it is bolted on to the flat front part of the original detent piece. The handle is modified by making it longer (easier to pull flaps on, more leverage) and also bent a bit to fit under my lowered windshield. I drilled a hole through the handle tube and welded in a bushing, and then drove a roll pin into the bushing. I located the holes for the various flap detent positions by attaching that piece to where it needed to be, and then scruffing the roll pin up and down on several times, that showed me where the holes could fall in line. Had to do some grinding/tweaking to make everything line up. Finally, I welded a retainer to the handle which bends around to keep the handle from moving very far to the right. You have to tuck the detent piece into place before you put the screws into it. With this system, I have about 3 degrees up, neutral, about three degrees down, 10 degrees down, 20 degrees down, and 30 dgrees down. Not quite as much as Kolb originally had, but that is deliberate. If you have 40 degrees of flaps and have to go around or flare with a heavy passenger, you sort of run out of elevator authority. Having a bit less flaps helps cure that, and it still lands about as short as it did with 40 degrees. Having 3 degrees up reduces the need for as much up elevator trim when carrying a passenger. And when I get light on fuel, 3 degrees down also helps it trim better. Due to differences in airplane weights and pilot weights, your results may vary. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52100#52100 Attachments: http://forums.matronics.com//files/p1000704_medium_621.jpg http://forums.matronics.com//files/p1000696_medium_183.jpg http://forums.matronics.com//files/p1000702_medium_790.jpg http://forums.matronics.com//files/p1000701_medium_510.jpg http://forums.matronics.com//files/p1000707_medium_135.jpg http://forums.matronics.com//files/p1000694_medium_196.jpg http://forums.matronics.com//files/p1000692_medium_173.jpg http://forums.matronics.com//files/p1000700_medium_213.jpg ________________________________________________________________________________
Date: Aug 03, 2006
NeilsenRM(at)comcast.net wrote: > > > I started to tell him how I used the > flaps to adjust my glide path to get me where I wanted to land (kind of like > a negative throttle) and fully retracted them for landing. He stopped me and > said you never never raise your flaps on approach. We then got into a heavy > discussion about flap usage. He finally conceded that it might work in one > of "those" Kolbs but not in a GA aircraft. > --- That technique works very well in GA aicraft also. If you have an engine out and need to glide to the runway, you need to retract the flaps, its the same for a Kolb or a GA aircraft. This guy took what is considered a good rule of thumb ( do not retract flaps on approach ) and applied it across the board, which is just plain stupid. If you are in an emergency situation, and have flaps down for the approach, and the engine quits, retracting the flaps might get you enough extra glide to make the runway. That technique saved my butt once in a Cessna 152. Michael A. Bigelow -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52102#52102 ________________________________________________________________________________
Date: Aug 03, 2006
Richard, Gonna see if my A&P friend can understand it. There's also another A&P here who is a CFI and built a Kolb no-flapper. Will get back to you. Just posted one on mornings brief event. You can probably respond better than anybody. Gracias, jsf ----- Original Message ----- Sent: Thursday, August 03, 2006 10:01 AM > > Here are some closeups of the mechanism. The detent with the holes in it > is bolted on to the flat front part of the original detent piece. The > handle is modified by making it longer (easier to pull flaps on, more > leverage) and also bent a bit to fit under my lowered windshield. > I drilled a hole through the handle tube and welded in a bushing, and then > drove a roll pin into the bushing. I located the holes for the various > flap detent positions by attaching that piece to where it needed to be, > and then scruffing the roll pin up and down on several times, that showed > me where the holes could fall in line. Had to do some grinding/tweaking to > make everything line up. Finally, I welded a retainer to the handle which > bends around to keep the handle from moving very far to the right. You > have to tuck the detent piece into place before you put the screws into > it. > With this system, I have about 3 degrees up, neutral, about three degrees > down, 10 degrees down, 20 degrees down, and 30 dgrees down. Not quite as > much as Kolb originally had, but that is deliberate. If you have 40 > degrees of flaps and have to go around or flare with a heavy passenger, > you sort of run out of elevator authority. Having a bit less flaps helps > cure that, and it still lands about as short as it did with 40 degrees. > Having 3 degrees up reduces the need for as much up elevator trim when > carrying a passenger. And when I get light on fuel, 3 degrees down also > helps it trim better. Due to differences in airplane weights and pilot > weights, your results may vary. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=52100#52100 > > > Attachments: > > http://forums.matronics.com//files/p1000704_medium_621.jpg > http://forums.matronics.com//files/p1000696_medium_183.jpg > http://forums.matronics.com//files/p1000702_medium_790.jpg > http://forums.matronics.com//files/p1000701_medium_510.jpg > http://forums.matronics.com//files/p1000707_medium_135.jpg > http://forums.matronics.com//files/p1000694_medium_196.jpg > http://forums.matronics.com//files/p1000692_medium_173.jpg > http://forums.matronics.com//files/p1000700_medium_213.jpg > > > ________________________________________________________________________________
Date: Aug 03, 2006
Anyone retracting flaps in any part of a flight should remember to do so GENTLY and SMOOTHLY, always watching the airspeed like a hawk. And knowing what your stall speeds are first. Very easy to get into trouble here, but flaps can be milked off to get better glide and range, and can make all the difference when trying to 'stretch the glide' for any reason. You'll glide the furthest with flaps fully retracted. On Aug 3, 2006, at 1:33 PM, JetPilot wrote: > > > NeilsenRM(at)comcast.net wrote: >> >> >> I started to tell him how I used the >> flaps to adjust my glide path to get me where I wanted to land >> (kind of like >> a negative throttle) and fully retracted them for landing. He >> stopped me and >> said you never never raise your flaps on approach. We then got >> into a heavy >> discussion about flap usage. He finally conceded that it might >> work in one >> of "those" Kolbs but not in a GA aircraft. >> --- > > > That technique works very well in GA aicraft also. If you have an > engine out and need to glide to the runway, you need to retract the > flaps, its the same for a Kolb or a GA aircraft. > > This guy took what is considered a good rule of thumb ( do not > retract flaps on approach ) and applied it across the board, which > is just plain stupid. If you are in an emergency situation, and > have flaps down for the approach, and the engine quits, retracting > the flaps might get you enough extra glide to make the runway. > > That technique saved my butt once in a Cessna 152. > > Michael A. Bigelow > > -------- > "NO FEAR" - If you have no fear you did not go as fast > as you could have !!! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=52102#52102 > > ________________________________________________________________________________
Date: Aug 03, 2006
Speaking of which... what's the Vfe (max. flap extend speed) on my MkIIIC? Anyone know? -- R On 8/3/06, russ kinne wrote: > > Anyone retracting flaps in any part of a flight should remember to do > so GENTLY and SMOOTHLY, always watching the airspeed like a hawk. ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Cruise, now I know!
Apologies to the board on my "cruise" speed. It appears that I took certain liberties not applicable to the flying world. The word "cruise" means: sail, journey, travel, coast, motor, speed and glide. That is according to the "Word and Works" software word processor on my computer. Under THAT set of meanings, my Firestar I KXP 503 DIDC with 66 inch wooden two blade prop and plane weighing in at 354# empty, with a 220# driver will 'CRUISE" at 80-85 MPH ASI flat flying (no descend or climb) and without any winds. You-all see, I was under the impression that 'CRUISE" was the speed at which an aircraft (in our case) flies with designed attitude and is the (excuse me golfers) "sweet spot" in the engine rpm range, being most efficient regarding EGT and CHT while consuming the least amount of fuel (economy mode), and not requiring ANY back-stick or forward-stick. I am sadly (actually happily) mistaken. My Firestar can flat lick the drawers off any other Kolb out there (with the same engine ), except the ...............WELL THERE AIN'T ANY KOLB, equally equipped that I can't beat. So forget my previous winnings. Now if anyone else with a Kolb Firestar equipped with a 503 DIDC and 66" prop wants to have theirs as fast, let me know. However, If I was correct in my previous assumption, then I will probably need some help. Fastest in all of Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52124#52124 ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Fw: Proof Of Global Warming
Date: Aug 03, 2006
Subject: Re: Cruise, now I know!
Had to learn to resize some pictures. They are attached. The one with the instruments should be big enough to enlarge and read the ASI and the GPS as well as the two Glass engine and flight gauges. Man, I love thoses things. The last one or first one with the white buildings is the world famous Poultry #4 layer. Chicken City where the chickens lay 3 eggs every two days. Somehow they made a deal with the cock to crow even in the dark. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52126#52126 Attachments: http://forums.matronics.com//files/dscf0958_medium_711.jpg http://forums.matronics.com//files/dscf0947_medium_726.jpg http://forums.matronics.com//files/dscf0945_medium_194.jpg ________________________________________________________________________________
Date: Aug 03, 2006
Man, A piece of History that really shouldn't be put on a plane and flown. It's an origional John Hauck. The history of that engine should be at the Smithsonian, it's priceless. And a MOVIE STAR was interested in it. That should add value. I heard that it's John Travolta! I could be wrong. Ohio Ralph, pickin-an-a-grinnin here in Ohio! Why would John Travolta want a 912, other than the Hauck once owned it, and it could only appreciate in value? Afterlaa doesn't John Travolta have a couple jets? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52130#52130 ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Sport Pilot written test passed
Gentlemen: I took the Sport Pilot written exam this afternoon and passed it. Next step, finding someone with the correct form for the SP Student Pilot certificate. Onward! -Ken Fackler Kolb Mark II / A722KWF Rochester MI ________________________________________________________________________________
Date: Aug 03, 2006
Do not know the correct speed for flaps on my MkIIIC, but I don't even try to pull on full flaps above 50 ias. Not sure that I would have the strength at 55 or more. Vic ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Check List
David, I picked this one up off of someone's website I don't remember who's.... Hope it helps.. Mike -----Original Message----- [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of David Key Sent: Thursday, August 03, 2006 12:52 AM Does someone have a check list they can email me? I need one for my preflights and didn't want to start from scratch. Thanks, David ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Kolb
This is my first message to the Kolb list. I have been lurking on this list for quite some time. I would like some info on the location of a Hot Box in a Firestar11. Also, battery location so that I can send the information to Hot Box. For my harness. I am looking for the dimensions for a motor base plate for a 503 or to purchase one if anyone has one. Is it better to ground to the battery or to the aircraft frame? Do I need to do a weight and balance before installing the battery? Hope this message makes it to the list. Thanks for all the good reads and ideas. Tim Duffney Hibbing Minnesota PS. To John Hauck tried to hook up with you at Oshkosh to pick your brain and introduce you to a friend, I was the guy on the black motorcycle that waved at you Wed evening. ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Sport Pilot written test passed; taxiing downwind
Gentlemen: Sport Pilot Test I took the Sport Pilot written exam yesterday and passed with a 100%. Next step is getting the student pilot cert followed by a few hours doing checkride prep. Taxiiing Downwind With all due respect to Bro' Hart, if I had used his recommendations for control positioning to answer some of the questions, I would not have gotten a perfect score. The SP written expects that your answers to questions such as these will reflect these procedures: Taxi upwind = elevator up Taxi downwind = elevator down Upwind crosswind = aileron on the side the wind is coming from is up Downwind crosswind = aileron on the side the wind is coming from is down Synopsis: When taxiing upwind position the controls TOWARD the wind; when taxiing downwind position them AWAY from the wind. If you do something else in your particular aircraft, that's up to you, and I won't argue or debate with anyone about it. However, if you want to PASS the written exam, you need to answer the way the FAA says you should. Note: The above is consistent with a PP ground school I took 20+ years ago as well as all the instruction I've ever received from CFIs over the years, including the local taildragger "expert". -Ken Fackler Kolb Mark II / A722KWF Rochester MI ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: Kolb
Here is a link to some installed pictures of the battery and hotbox in a FSII. http://www.bcchapel.org/pages/0003/FSII%20Hot%20Box.html Ground the battery to the airframe, and ground the engine to the airframe. If you put the battery where we have ours, or anywhere close to the rear seat, it will work out ok because it will be close to the cg. Richard Pike MKIII N420P (420ldPoops) Duffney wrote: > This is my first message to the Kolb list. I have been lurking on this > list for quite some time. I would like some info on the location of a > Hot Box in a Firestar11. Also, battery location so that I can send the > information to Hot Box. For my harness. I am looking for the > dimensions for a motor base plate for a 503 or to purchase one if > anyone has one. Is it better to ground to the battery or to the > aircraft frame? Do I need to do a weight and balance before installing > the battery? Hope this message makes it to the list. > Thanks for all the good reads and ideas. > > Tim Duffney > Hibbing Minnesota > > PS. To John Hauck tried to hook up with you at Oshkosh to pick your > brain and introduce you to a friend, I was the guy on the black > motorcycle that waved at you Wed evening. ________________________________________________________________________________
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Date: Aug 04, 2006
Subject: Re: Another Check List
I think this checklist came out for the GT 400/500. Can certainly be adapted for a Kolb. Arty Cabin Ignition OFF Strobe switch ON Master switch ON Check strobe FLASHING Strobe switch OFF Master switch OFF Loose objects SECURE Hobbes REECORD Fuel tank cap SECURE Chute release pin REMOVE Rear Compartment Fuel shut-off valve ON Fuel level CHECK Fuel filter CHECK FOR DIRT AND SECURITY Wiring harness SECURE Fabric buckles SECURE, TOP AND BOTTOM Side zipper CLOSED Left Wing Left brake line CHECK FOR BUBBLES Main left wheel tire CHECK INFLATION Lower surface fabric CHECK Upper surface fabric CHECK Left wing tie-downs DISCONNECT Aileron hinges and control fittings CHECK Flap hinges and control rod CHECK Strobe SECURE Wing zipper CLOSED Empennage Rudder hinges SECURE Rudder control cables, nuts, pins SECURE Elevator hinges SECURE Elevator push rods, nuts, pins SECURE Internal tube fittings SECURE Fabric NO DAMAGE, TIGHT Tail Strobe SECURE Tail tie-down DISCONNECT Engine (503 dual carb) Propeller bolts & nuts CHECK Propeller condition CHECK Muffler SECURE, CHECK SAFETY WIRES Spark plugs TIGHT Spark plug caps SECURE Engine temp wires SECURE Right Wing Flap hinges and control rod SECURE Aileron hinges and control fittings SECURE Right wing tie-down DISCONNECT Upper surface fabric CHECK Lower surface fabric CHECK Main right wheel tire CHECK INFLATION Right brake line CHECK FOR BUBBLES Strobe SECURE Wing zipper CLOSED Nose Pod CHECK FOR CRACKING Nose wheel CHECK INFLATION AND SECURITY Nose wheel brake CHECK CONDITION & OPERATION Pitot tube OPENING CLEAR Before Engine Start Preflight inspection COMPLETE Seats, belts, shoulder harn. ADJUST & LOCK Helmet CHIN STRAP SECURE Fuel shut off valve ON Radios, electrical equipment OFF Strobes OFF Brakes TEST & SET Engine Start Prime AS REQUIRED Throttle SLIGHTLY OPEN Propeller area VISUAL CHECK Master switch ON "Clear Prop" CALL Choke HOLD ON AS NEEDED Ignition switch ON (release on start) Throttle ADJUST TO IDLE A 2,000 RPM Strobe switch ON (Radio) (REPORT START TAXI) Before Take-off Brake SET Controls check REE AND CORRECT Flaps SET Instruments SET Gas and fuel valve CHECK LEVEL AND VALVE OPEN Throttle TO 4,000 RPM Left & right sparks CHECK FOR RPM DROP Throttle IDLE Engine instruments, ammeter CHECK Engine temps CHT, EGT CHECK Strobe ON (Radio) (CALL) Final scan 360 DEGREE TRAFFIC CHECK Brakes RELEASE After Take-off Wheels BRAKE TO STOP WHEEL SPIN Before Landing Cabin SECURE LOSE OBJECTS Harness and helmet SECURE Slow flight SET FLAPS IN WHITE ARC Approach speed 40 MPH (Radio) (CALL DOWNWIND, BASE & FINAL) After Landing Flaps NEUTRAL Strobe, master and key OFF Hobbs RECORD Fuel FILL Chute pin INSTALLED Tie downs SECURE www.LessonsFromTheEdge.com "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Aug 04, 2006
Subject: I lead a charmed life
Despite needing to get on the road for CA, it was too nice to not take one more ride around the pattern. "Normal preflight, aux tank on pump, taxi out." "Pretty cross, but nothing I haven't handled before." "Maybe I should taxi up to the flag, and make sure I'm not adding a downwind component." "I can always take off from half field, 1200 feet is enough for a Kolb." "Doesn't look like enough to be a problem, NBD, why waste the runway?" "Okay, Into the wind, controls set, start feeding in throttle." "Engine sounds normal, tail up, looks good, continue nice smooth pull back." "ENGINE RPM DROPPED, LAND, LAND, LAND". "What the F***, over?" Settle in nicely, roll out and begin turn back up runway." "Engine dies, oh great, here I sit smack dab in the middle of the runway" "Fiddle about with throttle, engine starts, won't go over about 3000 RPM, WTFO?" "Engine dies again, get out, check engine pull up throttle cable boots and check cables, looks good, straighten out tail wheel." "Try engine, starts right up, accelerate normal, taxi back." "Add throttle to get up slope to the yard, engine dies again." "Roll backward down slope, thank goodness for that full swivel tailwheel." "At least I'm out of the way, sit for a moment cursing, try engine, engine starts, throttles normally, taxi up slope and back to hangar." "Okay, let's have a look, hmmm, no fuel in line north of fuel pump, no fuel in line north of filter, line south of filter full of fuel." "Crap. Put it away, rebuild fuel system when I get back, add electric boost pump." "The runway behind you, the gas still at the FBO, the altitude above you, my ex wife." Yesterday I was finally getting comfortable with flying low. Cruising along the Arkansas River at 150', trees for 1/4 mile on either bank. Engine sang her usual sweet siren song, "depend on me, depend on me". Bitch. I wonder if she knows my ex wife? -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: I lead a charmed life
Said: "hmmm, no fuel in line north of fuel pump, no fuel in line north of filter" and: "Yesterday I was finally getting comfortable with flying low. Cruising along the Arkansas River at 150' trees for 1/4 mile on either bank" and then this: "depend on me, depend on me..." First, Brother of the sky, it sure appears that "Someone" is looking out for you. At 150 feet above river with trees on both sides, and 1/4 miles away, (do the math, and you will see why I say that), unless your amphibious, somebody up there Loves you. I also found, not by personal example, but by another, that engines especially don't like being called disrespectful names. Be nice to your motor and it will be nice to you. I will send you a photo or two of a duel fuel manifold system yjay my Instructor and I put together for just those occasions, when your not feeling really fresh. I personally believe that in spite of your determination to fly with something possibly amiss, that some "authority" took over past common sense. I know, there isn't very many individuals more stubborn than me, and I will MAKE IT FLY ^%$#%^76 , cause that's what I want NOW! The very best thing you have to consider is that your here and the plane is still complete and you vented among your peers. I love you man!! (In the male bonding way). Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52301#52301 ________________________________________________________________________________
Date: Aug 04, 2006
Ralph, One small correction, after she quit, all thoughts of flying today were gone. I know when to take a hint and listen to those short hairs on the back of my neck. I'd have left her shut down, but I didn't want to put myself in cardiac arrest pushing and pulling her 1/2 a mile back to the house. The Rotax is gonna have to learn the lesson the Vibraglide knows. "Don't screw with Daddy, he has wrenches and will take you apart and put you in a box." Who knows, maybe the Rotax got wind of my plan to replace her with a Jabiru. Gotta be more secretive, I guess. Rick On 8/4/06, Ralph Hoover wrote: > > > > > Said: > "hmmm, no fuel in line north of fuel pump, no fuel in line north of > filter" > > and: > "Yesterday I was finally getting comfortable with flying low. Cruising > along the Arkansas River at 150' trees for 1/4 mile on either bank" > > and then this: > > "depend on me, depend on me..." > > First, Brother of the sky, it sure appears that "Someone" is looking out > for you. At 150 feet above river with trees on both sides, and 1/4 miles > away, (do the math, and you will see why I say that), unless your > amphibious, somebody up there Loves you. > > I also found, not by personal example, but by another, that engines > especially don't like being called disrespectful names. Be nice to your > motor and it will be nice to you. > > I will send you a photo or two of a duel fuel manifold system yjay my > Instructor and I put together for just those occasions, when your not > feeling really fresh. > > I personally believe that in spite of your determination to fly with > something possibly amiss, that some "authority" took over past common sense. > I know, there isn't very many individuals more stubborn than me, and I will > MAKE IT FLY ^%$#%^76 , cause that's what I want NOW! > > The very best thing you have to consider is that your here and the plane > is still complete and you vented among your peers. I love you man!! (In the > male bonding way). > > Ohio Ralph > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=52301#52301 > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 04, 2006
Subject: RE: flap speed
Speaking of which... what's the Vfe (max. flap extend speed) on my MkIIIC? Anyone know? -- R >>>>>>>>>>>>>>>> Years ago kolb told me that if you could pull it.. it was ok to use.... ( no limit other than vne) I posted mine at 70 Also they wanted me to make sure there was a triangle gusset welded to the flap torque tube where the actuating arm is attached... if the arm does not have a gusset.( early models) put one on. Boyd ________________________________________________________________________________
Date: Aug 04, 2006
"David Key" | | I didn't know I had titan exhaust. There's a little room near the boxes David: Those little black boxes cost 700.00 a piece to replace. When I was running the Titan exhaust system I wrapped that area of the tube that was closest to the black box with fiberglass exhaust header wrap. Secured both ends with hose clamps. Did that fix work. Reckon so. Never had an ign problem. john h ________________________________________________________________________________
Date: Aug 04, 2006
| Maybe you could tell me how you mounted your | coolant overflow bottle. | | Vic Vic: Used a nalgene plastic bottle (the kind most little cafes use for mustard and catsup. Welded up a little aluminum bracket with tabs to mount to the two 6mm taped holes in the back (opposite prop) of the gear box. Used a couple tie wraps to secure the bottle to the bracket. john h ________________________________________________________________________________
Date: Aug 04, 2006
Hi Vic/John, I just happen to have a picture that shows the bottle in question. Took the picture in 2004 when John was at Octoberlite fly-in at Ronnie Smith's. Hope it helps. P.S. Hope the picture is not too big for the dial-up folks. I've converted to Hughes satellite service and things are much better and more expensive. Later, John Cooley | Maybe you could tell me how you mounted your | coolant overflow bottle. | | Vic -- ________________________________________________________________________________
Date: Aug 04, 2006
Quote: "P.S. Hope the picture is not too big for the dial-up folks." Well John Cooley, Have John Hauck Tighten that Bolt below the black hose with the Blue "T" fitting 1/4 turn more and I did notice several specs of material in that 2 micron filter! Ha, HA! That picture blowed up so big I needed two days to see it all! Ha! Ohio Ralph, P.S. is that "Full Scale"? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52425#52425 ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: Kolb
A Man could eat off of any part in your plane, it's so clean. And talk about workmanship, Outa this world. I'll be sending my Firestar in a box here in the next several weeks for you to make purty like yours. Anal, man absolutely anal! And, thats a good thing. Amazed Ralph in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52426#52426 ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Coolant Recovery Bottle and Mount
Changed the subject line to reflect what we are talking about. Forgot to mention, I used a couple 582 radiator shock mounts which have 6mm studs on them, to screw into the rear of the gear box. Then mounted my recovery bottle and mount on the two shock mounts. Was it necessary to use the shock mounts? Not sure. But since I had them, I used them. Also acts as a thermal barrier between gear box and bottle. Take care, john h mkIII ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: Firestar cruise
My Firestar II is happiest in the 45-60 mph range. You can push it above that, but it doesn't fly as comfortably in the upper range near the red line - also the miles per gallon goes down at the higher speeds. At 60 mph (5,000 ft density altitude), the 503 turns about 5,500 rpm. My bird is a stock open cockpit model with windscreen and no strut fairings. -------- Dave Bigelow Kamuela, Hawaii FS2, Rotax 503 DCDI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52447#52447 ________________________________________________________________________________
Date: Aug 04, 2006
John Cooley wrote: >Hi Vic/John, > >I just happen to have a picture that shows the bottle in question. Took the >picture in 2004 when John was at Octoberlite fly-in at Ronnie Smith's. Hope >it helps. > >P.S. Hope the picture is not too big for the dial-up folks. I've converted >to Hughes satellite service and things are much better and more expensive. > >Later, >John Cooley > > > Truncated! > ------------------------------------------------------------------------ > This message exceeded the Maximum Message Size set in Preferences, so > we have only downloaded the first few lines from the mail server. > > Click here > > to download the rest of the message. > ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: Fuel tank filler line
Hi Mike S: To transfer fuel from the can to the aircraft I use 6 feet of 1" OD X 7/8" ID vinyl hose. Can pick it up at anything large hardware store, or try Lowes, Home Depot, etc. Been using this system since I learned about it from a friend who flew an S-1 Pitts. Was walking by his hanger one day, where he was standing off from the airplane, holding the gas can up and transferring fuel from can to tank via the 1" hose. Wish I knew how much fuel I have transferred this way. john h mkIII ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Date: Aug 04, 2006
Subject: Coolant bottle.
Hi John, Thanks for the downsizing. I can BARELY see that tiny bottle! (Just joking. It's still huge!) Ed in JXN MkII/503 ----- Original Message ----- Sent: Friday, August 04, 2006 6:49 PM > Hi Vic/John, > > I just happen to have a picture that shows the bottle in question. Took > the > picture in 2004 when John was at Octoberlite fly-in at Ronnie Smith's. > Hope > it helps. > > P.S. Hope the picture is not too big for the dial-up folks. I've converted > to Hughes satellite service and things are much better and more expensive. > > Later, > John Cooley ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: Coolant bottle.
I'll repeat a previous offer..........if you're unsure of the size of a picture you want to attach, email it to me in whatever size, I'll reduce it for you and email it back. No more frustrated people on dial up. I like to put them at 1000 pixels wide for easy viewing, and compress them to 50-75 kb for easy downloading. I can really sympathize - I was on dial up the whole 4 weeks I was on vacation last month, and it was really frustrating. Sure glad I'm back on high speed. Sure wish I was back on vacation. It's easy to set your computer to reject any email over a size you choose. If you missed the directions last time, email me off List, and I'll give you a step by step. While on vacation, I limited my computer to nothing larger than 250 kb, and it was much better. Even 250 takes quite a while on dial up, but you can set it anywhere you want. Lar. ----- Original Message ----- Sent: Friday, August 04, 2006 7:31 PM > > > Hi John, > > Thanks for the downsizing. I can BARELY see that tiny bottle! > > (Just joking. It's still huge!) > > Ed in JXN > MkII/503 > > > ----- Original Message ----- > Sent: Friday, August 04, 2006 6:49 PM > > >> Hi Vic/John, >> >> I just happen to have a picture that shows the bottle in question. Took >> the >> picture in 2004 when John was at Octoberlite fly-in at Ronnie Smith's. >> Hope >> it helps. >> >> P.S. Hope the picture is not too big for the dial-up folks. I've >> converted >> to Hughes satellite service and things are much better and more >> expensive. >> >> Later, >> John Cooley > > > http://www.matronics.com/Navigator?Kolb-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Aug 05, 2006
Subject: Re: Coolant Recovery Bottle and Mount
To John H.&C. Thats the kind of help that makes this list great! Thanks Personally I love those large files, that way I can really check Johns crappy workmanship. ( Ha, Ha, Ha) Only problem is I already bought the stock Rotax gold plated platinum overflow and it won't fit. I was going to use those same screw holes in the gearbox for a bracket to support the bottom of that type of exhast. I noticed a lot of wear at the junction of muffler to pipes (used system low time). Any comments on this from anyone? Vic MKIIIX 912UL Maine -- ________________________________________________________________________________
Date: Aug 05, 2006
Subject: Re: Kolb
Mike, "also sounds like you need a GPS ," The GPS that I have is a Garmin E-Map. An old system that works well with chips and Map Source programs. It has a database with the "Roads and Recreation" software. It allows me to download my trps, upload trips, leave crumbs and display (on the computer Map Source program) altitude, speed (ground) distance, etc. Pretty amazing for what it is. And, It has all the existing airfields shown, including many private backyard sites. see picture's below. these are from todays flights for 1-3/4 hours. Really great till them thermals came along. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52583#52583 Attachments: http://forums.matronics.com//files/dscf1049_medium_184.jpg ________________________________________________________________________________
Date: Aug 05, 2006
Subject: Wing strut fairings
wing strut fairings. From the instructions it isn't clear to me if I should rivet the fairings every inch. I know I'm supposed to start off 6 inches from the ends. Is there someone that knows if I'm suposed to rivet every inch? Thanks, David ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: Wing strut fairings
I never riveted by fairings. They seem to fit fairly tight. Maybe I should. Vic ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: stalls
"As the nose drops, you ease the stick forward while adding power to arrest the descent.">> Hi, that may be fine on an exercise when you are expecting a stall but pretty useless in real life. `Stick forward and opposite rudder` is all you really need. Forget the engine, it is the wing that stalls and as with most things lowering the angle of attack will sort it out. In fact unless you are entering a really viscious stall a slight release of back pressure wil do. Talk to a glider pilot. Incipient spins and stalls form a major part of the training. Glider pilots spent the majority of their time in rough thermals, steeply banked and teetering on the edge of a stall because you climb faster that way. On the appraoch the low and slow final turn is a particularly dangerous spot because the wind gradient may well give a difference of 10 knots difference in windspeed beetween the wing tips on a long sailplane wing. If you are near the stall the up wing may be just above the stall but the lower wing could stall and quit flying. Turning `flat` because you are too close to the ground is worse as your outside wing will speed up and tend to rise while the inside wing will slow down and could stall. Classic spin entry. With the Kolbs shorter wing the effect is not so pronounced but a similar situation is present. Cheers Pat do not archiv ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Flight Star vs Mark III Classic
I flew a Flight Star a few years ago and now I am flying my Mk III. As I remember, the Flightstar was a very nice flying airplane with light controls. My Classic seems stiffer. Anyone, have comments on the comparisons. Also, has anyone bothered to measure the glide ratios and minimum sink numbers without power? Vic in Sacramento ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: Control positioning during ground handling
When I use to fly my PA-11 and the wind was down the runway, I use to add power and forward stick. As soon as the tail came up, it was ready to fly. If the wind was from the side, I would hold the stick back to put pressure on the tail wheel until the rudder would hold it straight. I think that my Mk IIIC will be the same, but have yet to build enough confidence to do crosswind practice. Vic in Sacramento ________________________________________________________________________________
Date: Aug 06, 2006
| but if you just hold the stick loosely (figure of speech) in the | neutral position and lo and behold, the tail comes up exactly when it is | supposed to and a gentle back pressure sends you skyward. For me this method | works in all situations even in stout cross winds. | | You really don't have to "over fly" a Kolb and you don't have to second | guess it. Hi Chris M: That's the way I have been doing it for years. Let the Kolb fly with a little input to let it know what and where you want to go. john h mkIII ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Trip North
Morning Gang: Departing hauck's holler very shortly for a road trip north to Homer Kolb's. Have not been to Homer's since I came through that way in 1994, on my way around the country in the mkIII. Will have a chance to see the 1985 OSH Grand Champion Ultralight, a refurbished Kolb Firestar. Might even talk Homer into flying it around the patch. However, the primary purpose of this trip, in addition to visiting the Kolbs, is the Rough and Tumble Steam and Gas Engine Show at Kinzers, PA, about 30 miles west of Homer's. As some of you all know, Homer has been a John Deere tractor collector for many years. Fortunately or unfortunately, the tractor bug bit me a couple years ago. This bug causes a terrible disease called "tractor fever". It is incurable. This trip will keep "tractor fever" in remission for a short period of time. I will take my lap top and cell phone with me, 334-315-2621. Planning an op stop in Winchester, VA, either on the north or south. Will inform Grey Baron of ETA when I can confirm it. Hope to see some of my PA friends while at Homer's. Take care, john h hauck's holler (remote), alabama ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: Trip North
John, If you swing West on your way home and pass near Pittsburgh., drop me a line and try to stop in and RON here. Neither of my birds are flying this year (or last) :-( but they are available for inspection. I have a great little Farmall Cub with the Woods belly mower. I'll make sure to have a few acres available for your mowing pleasure. :-) Ought to be enough of a fix to get you right for your trip back to "Hanks"ville. I'll even have a dirt bike available for an off road fix too. Denny Rowe, Mk-3 690L-70, Loehle Sport Parasol 503 SI. Leechburg ,PA Home 724 845 1431 Cell 724 882 6788 Lindas cell 724 882 2751 ----- Original Message ----- Sent: Sunday, August 06, 2006 10:13 AM > > Morning Gang: > > Departing hauck's holler very shortly for a road trip north to Homer > Kolb's. Have not been to Homer's since I came through that way in > 1994, on my way around the country in the mkIII. > > Will have a chance to see the 1985 OSH Grand Champion Ultralight, a > refurbished Kolb Firestar. Might even talk Homer into flying it > around the patch. > > However, the primary purpose of this trip, in addition to visiting the > Kolbs, is the Rough and Tumble Steam and Gas Engine Show at Kinzers, > PA, about 30 miles west of Homer's. As some of you all know, Homer > has been a John Deere tractor collector for many years. Fortunately > or unfortunately, the tractor bug bit me a couple years ago. This bug > causes a terrible disease called "tractor fever". It is incurable. > This trip will keep "tractor fever" in remission for a short period of > time. > > I will take my lap top and cell phone with me, 334-315-2621. Planning > an op stop in Winchester, VA, either on the north or south. Will > inform Grey Baron of ETA when I can confirm it. > > Hope to see some of my PA friends while at Homer's. > > Take care, > > john h > hauck's holler (remote), alabama > > > -- > > ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: Kolb
The new Gps systems are sure great I have a 295 Garmin color moving map now alot more features than the older models, more info is good to have Ellery ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: Flight Star vs Mark III Classic
Vic, Where are you in Sacto? I'm up in Corning for the repairman maintenance class at Rainbow Aviation. I have weekends off and would love to talk Kolbs. Rick On 8/6/06, APilot(at)webtv.net wrote: > > > I flew a Flight Star a few years ago and now I am flying my Mk III. As > I remember, the Flightstar was a very nice flying airplane with light > controls. My Classic seems stiffer. Anyone, have comments on the > comparisons. Also, has anyone bothered to measure the glide ratios and > minimum sink numbers without power? > Vic in Sacramento > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 06, 2006
Stock, it is stiff in roll, but a simple aileron bellcrank mod is very effective. http://www.bcchapel.org/pages/0003/pg7.htm Richard Pike MKIII N420P (420ldPoops) APilot(at)webtv.net wrote: > > I flew a Flight Star a few years ago and now I am flying my Mk III. As > I remember, the Flightstar was a very nice flying airplane with light > controls. My Classic seems stiffer. Anyone, have comments on the > comparisons. Also, has anyone bothered to measure the glide ratios and > minimum sink numbers without power? > Vic in Sacramento > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2006
John, I, like Planecrazzy Mike appreciate your heorics and your advise. However, Mike and I differ in teh fact that If you pass central Ohio, (like Columbus area) during meal time, I'll let you buy me a steak! You and I could proctice soluting each other and I polish some brass buckles and streighten my gig line for you. Whoo........................., to the unindated, that sounds dirty. Sorry John, Just send me (after signing) the check Mike is sending you. You don't need any more money, you'l just buy more "green" stuff. Ohio Ralph, fasting for the big day, here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52834#52834 ________________________________________________________________________________
Date: Aug 06, 2006
Starts tomorrow and runs through the 27th. Rick On 8/6/06, Richard Pike wrote: > > > Stock, it is stiff in roll, but a simple aileron bellcrank mod is very > effective. > http://www.bcchapel.org/pages/0003/pg7.htm > > Richard Pike > MKIII N420P (420ldPoops) > > > APilot(at)webtv.net wrote: > > > > I flew a Flight Star a few years ago and now I am flying my Mk III. As > > I remember, the Flightstar was a very nice flying airplane with light > > controls. My Classic seems stiffer. Anyone, have comments on the > > comparisons. Also, has anyone bothered to measure the glide ratios and > > minimum sink numbers without power? > > Vic in Sacramento > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 06, 2006
"Hey Ralph, I'm guess'n you were born in "Babble-on"...He he he " No son, I was born in a mess-kit at the end of WW-II (the big one), and some of that rubbed off of me when I was a drill Sergeant! My purpose was to remove the rough edges from snot nosed kids! He He! After they riffed me, I moved to babble-on, wherest I was able to meet the nice respectable, kind, appreciative, educated individuals such as yourself. But thank you for the kindness!.........Now get down and give me 50! Ralph "Fallin-in" in Ohio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52860#52860 ________________________________________________________________________________
Date: Aug 06, 2006
Subject: New Incoming Message Size Limit Implemented...
Dear Listers, Due to a number of requests to limit the size of incoming posts to the Lists because of the recently added enclosure feature, I have add a new filter that will limit the total size of any given message posted to the List. I have initially set the limit to 2MB and we'll see how everyone likes that. If a member attempts to post a message that is greater than the set limit, they will receive an email back indicating that their message wasn't posted to the List and why. Also included in the message will be the current size limit and how large their message was. Some might say that 2MB is still too large, but its a place to start... Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: New Incoming Message Size Limit Implemented...
Date: Aug 06, 2006
On Aug 6, 2006, at 7:49 PM, Matt Dralle wrote: > Some might say that 2MB is still too large, but its a place to > start... WHAT! ! ! ? ? 2MB ??? per message on a slow phone line??? Sorry Matt, Totally useless filter in my opinion. How about 150 KB ? ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Fuel tank filler line
Date: Aug 06, 2006
Subject: Trip North
Hi John, In a week, I will also be taking a trip north to Fredericksburg, VA. The last two weeks I worked at the John Deere factory in Des Moines, Iowa. Regards, Will Uribe FireStar II El Paso, TX _http://members.aol.com/WillUribe/mv/_ (http://members.aol.com/WillUribe/mv/) (mailto:jhauck(at)elmore.rr.com) However, the primary purpose of this trip, in addition to visiting the Kolbs, is the Rough and Tumble Steam and Gas Engine Show at Kinzers, PA, about 30 miles west of Homer's. As some of you all know, Homer has been a John Deere tractor collector for many years. Fortunately or unfortunately, the tractor bug bit me a couple years ago. This bug causes a terrible disease called "tractor fever". It is incurable. This trip will keep "tractor fever" in remission for a short period of time. I will take my lap top and cell phone with me, 334-315-2621. Planning an op stop in Winchester, VA, either on the north or south. Will inform Grey Baron of ETA when I can confirm it. Hope to see some of my PA friends while at Homer's. Take care, john h hauck's holler (remote), alabama ________________________________________________________________________________
Subject: Kolb Mark III for sale
Date: Aug 06, 2006
Hi Everyone, Kind of a sad day. I will be selling my Mark III Classic. I am purchasing a Flight Design CTSW. I have truely had a great time flying my Mark III and it was my first experience with the 912uls engine. The 912s is the only way to go. Other than one minor problem it has never given me an ounce of trouble. If you know anyone that is interested then you can see my add on Barnstormers. This plane was built by Dwane Woods and his brother. Some of you may know them and they are excellent builders and pay a lot of attention to detail and spared nothing on extras as they built. This Kolb was 2002 Grand National Champion at Sun & Fun. Custom aerothane paint, BRS 1050 chute, EIS, ASI, ELT, compass, G-meter, Icom 10 channel radio, intercom, Garmen 195 GPS, fused hot box, new 6x6.00 tires, self sealing tubes, beefed up landing gear, Matco brakes, clear "D" cell, balanced ailerons, trim, G5 grip, 3 blade Warp Drive prop, 16 gals. fuel (3.5 hrs.), 2 fuel pumps, Navman fuel flow meter, TNK adjustable horizontal stabilizer bracket, full swivel tailwheel, Registered ELSA (N515AB), TT A&E 780 hrs. $28,500 If you are interested give me a call @ 520-574-1080 Tucson, Az I will always stay in contact and continue to meet all of the Kolb people as they have been a wonderful and informative group. That being said I don't take delivery of my CTSW until Dec. 1, 2006. So until my Kolb sells it's time to fly. I will also keep you informed about how the CTSW flys. Thank All of You, Roger Lee -------- Roger Lee Tucson, Az. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52985#52985 Attachments: http://forums.matronics.com//files/img_0059_150.jpg http://forums.matronics.com//files/img_0050_110.jpg http://forums.matronics.com//files/img_0057_139.jpg http://forums.matronics.com//files/img_0051_744.jpg http://forums.matronics.com//files/img_0063_151.jpg ________________________________________________________________________________
From: "Domenic Perez" <perezmdomenic(at)plateautel.net>
Subject: Control Stiffness
Date: Aug 07, 2006
My ailerons were very stiff my first few flights when I first bought my FS II. Come to find out a little lubrication in the "u-joints" assembly on the lower end of the stick made a world of difference. Also, make sure the tightness of the nuts and bolts on those u-joints is just right. M. Domenic Perez FS II Vaughn, NM ________________________________________________________________________________
Date: Aug 07, 2006
To transfer fuel from the can to the aircraft I use 6 feet of 1" OD X 7/8" ID vinyl hose. >> Hi , did I miss something? Does the can have a spout which the hose fits over? Otherwise how does the hose attach to the can? Cheers Pat do nor archive ________________________________________________________________________________
Date: Aug 07, 2006
I use the same arrangement, red poly tank with loop handle, vinyl hose fits perfectly over the stub on the tank cap. As I remember, the tank had some kind of a self-venting device on it which I removed to clamp the hose on. I drilled a very small hole in the handle for the vent. My tanks are in the standard MkIII location so I don't have to lift far for gravity to do the job. BB On 7, Aug 2006, at 4:29 AM, pat ladd wrote: > To- transfer fuel from the can to the aircraft I use 6 feet of 1" OD > X--7/8"- ID vinyl hose.- >> > - > Hi , > - > did I miss something? Does the can have a spout which the hose fits > over?- Otherwise how does the hose attach to the can? > - > Cheers > - > Pat > - > do nor archive ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Auto gas line
Hello all. I remember to have read about the usage of the black automotive gas lines with non-premix gas ... My question is: Can these automotive line be safely used with pre-mixed (using 50:1 Penzoil for 2 stroke air cooled) . I have to replace all the lines in my Twinstar MK II and would like to use this type of line if it is safe ... Thanks ! Nol Bouhard Twinstart MKII Rotax 503 -- ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Re: Auto gas line
I use fuel-injection line that is compatible with all fuels with any mixes: SAE 30R9 (one popular mfg is Gates). Also, check out Areoquip FC332... http://www.hosexpress.com/hose/socketless/FC332.htm -- Robert On 8/7/06, Noel Bouchard wrote: > > Hello all. > > I remember to have read about the usage of the black automotive gas > lines with non-premix gas ... > > My question is: Can these automotive line be safely used with pre-mixed > (using 50:1 Penzoil for 2 stroke air cooled) . > > I have to replace all the lines in my Twinstar MK II and would like to use > this type of line if it is safe ... > > Thanks ! > > Nol Bouhard > Twinstart MKII > Rotax 503 > > > -- > > ________________________________________________________________________________
Subject: Ms. Dixie update
Date: Aug 07, 2006
Hi Kolbers, As of yesterday Ms. Dixie's wings are covered and back home. Had one scarey moment on the interstate when a semi passed pops at a high rate of speed and cut over in front of him [Shocked] the wings and the rig they were riding on tried to take flight! Other tan that they had a nice ride home. Couple of things for the archives and future builders or folks covering that I ran into.... first was the covering kit I bought from ATS aka Jim Miller. It's a tad over kill. I would recomend Jim as a point of purchase but not the covering "Kit" as per say. The "kit" is put together by TNK and lacks certain items and has to much of others. For an example one will need, or at least it's easier to have some 4" "bias" tape for the wing tip bows. I cant Imagine trying to get a smooth edege with the supplied 4" tape that came with the "Kit". Next is the fabric rivets. I was not happy with the ones that came from Jim. Although they are "certified" and used on alot of airplanes..the guy who coached me in my covering didnt like them and had some that were much nicer. the edeges of these rivets were rounded and pulled into the reinforcing tape much cleaner. If anyone is at this stage and wants part numbers for the rivets let me know. http://groups.msn.com/AerialWorld/kolbra012.msnw?Page=1 This is where I upload building photos these days so book mark this link and check back ofton for updates. I cant seam to find the spell checker so what you see is what you get! Take care -------- Paul Petty Kolbra #12 Ms Dixie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53212#53212 ________________________________________________________________________________
Date: Aug 07, 2006
I stock and sell Areoquip Fc332 in all sizes call for prices @ 601-782-4506 ask for Paul. Get the good stuff! Special prices for my kolb brothers and sisters [Wink] -------- Paul Petty Kolbra #12 Ms Dixie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53214#53214 ________________________________________________________________________________
Subject: Re: Oskosh
From: "Ralph Hoover" <flht99reh(at)columbus.rr.com>
Date: Aug 07, 2006
FANTASTIC! Thank you, whoever took them. I do however have a concern or three: The "mounting " method of that cow appeared somewhat unique. Would someone like to explain that method. I realize you just left Hooters and all the booze, but still, that is somewhat an unorthodox method. Right front leg seems very unconventional. Oh, well. I dare not dwell. The line about the most poluted area in the nation, I found rather unusual from a Californian. Is that really true? Can you recall the altitude you were flying when you took the picture of the Presidential heads. I know that in reality, they are only 30 feet across total, and when I traveled there by motorcycle, was really let down. I somehow expected something larger. So by all outward appearances, you were about 100 feet off the ground? Lastly, Never mock "Wall Drugs" or their distant calling with sineage every 30 feet from Chicago. As an x-biker, I looked forward to finding that place just to get the free glass of water. I didn't recall the fly-over of Sturgis, S.D. Could that be perhaps because after Bike week, they take the cardboard walls back down, whilst sweeping up the drunks? Thank you so much for thoses pictures and the captions. What a wonderful bunch of aircraft in one location. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53236#53236 ________________________________________________________________________________
Subject: MERFI
Date: Aug 07, 2006
MERFI Mid-Eastern Regional Fly-In Marion Ohio August 26th and 27th 8:00 A.M. untill 5:00 P.M. See Flier below jpg file Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53240#53240 Attachments: http://forums.matronics.com//files/newsad450_106.jpg ________________________________________________________________________________
Subject: FireStar II flying the US- Mexican border
Date: Aug 07, 2006
Greetings Kolb fan, It has been raining way too much here in the desert southwest so I thought I would do a little recon over the Rio Grande this past Sunday. Below is a link to a short video I took during the flight. Be advised the file is 4.92 MB so dialups need not view it. http://members.aol.com/ELPEAA125/border.WMV Regards, Will Uribe FireStar II El Paso, TX http://members.aol.com/willuribe/mv/ ________________________________________________________________________________
Subject: Re: FireStar II flying the US- Mexican border
Date: Aug 07, 2006
Nicely done, Will. One a these days................ :-) Do not Archive. ----- Original Message ----- From: "Guillermo Uribe" <WillUribe(at)aol.com> Sent: Monday, August 07, 2006 7:08 PM Subject: Kolb-List: FireStar II flying the US- Mexican border > > Greetings Kolb fan, > It has been raining way too much here in the desert southwest so I thought > I > would do a little recon over the Rio Grande this past Sunday. > Below is a link to a short video I took during the flight. > Be advised the file is 4.92 MB so dialups need not view it. > http://members.aol.com/ELPEAA125/border.WMV > > Regards, > Will Uribe > FireStar II > El Paso, TX > http://members.aol.com/willuribe/mv/ > > > ________________________________________________________________________________
Date: Aug 07, 2006
Pretty cool, Will. :) -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53262#53262 ________________________________________________________________________________
Date: Aug 08, 2006
Will, I'm impressed! Probably I use that too much. But I am. I know that you are dealing with thermals as I am watching the "Step away from the string"! Hey, in the video, you had that "schreec sound" as your wheels touched the asphalt. We dont' get that with grass! You do good, my man. I would be interested in your camera mount. I have a Canon ES190 with 440 digital zoom and would be really interested in how and where you mounted yours. I have often looked at the "wing support tab". Not sure how well that would work. See, we could trade video's; in the winter, you could send me really "hot" videos of desolation and heat, and I could send you pictures of the ground covered with snow, to the point I would have no idea where the field is. That would cool you off. How about it. And Mikie, I hope this isn't percieved as Babbalon. You know where that "Babble-on " came from in the Bible don't you? Ohio Ralph.......really hot here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53429#53429 ________________________________________________________________________________
Date: Aug 08, 2006
Hi Ralph, I had a gusting cross wind to deal with when landing. Normally I like to land long and touch down mid field to avoid a long taxi. It was not my intention to touch down where I did but since I was being blow away from center line I figured it was time to land. A short while ago someone posted a picture of a Kolb with a camera mounted on the side of the fuselage using a RAM mount. I wish I can remember who posted it so I can give him credit for the idea. I already had the RAM mount so when I saw the picture I had to try it out on my next flight. Erich Weaver of California mounts his camera on the wing support tab, take a look. http://gtalexander.home.att.net/cam_mount.html Regards, Will Uribe FireStar II El Paso, TX -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ralph Hoover Sent: Tuesday, August 08, 2006 12:13 PM Subject: Kolb-List: Re: FireStar II flying the US- Mexican border Will, I'm impressed! Probably I use that too much. But I am. I know that you are dealing with thermals as I am watching the "Step away from the string"! Hey, in the video, you had that "schreec sound" as your wheels touched the asphalt. We dont' get that with grass! You do good, my man. I would be interested in your camera mount. I have a Canon ES190 with 440 digital zoom and would be really interested in how and where you mounted yours. I have often looked at the "wing support tab". Not sure how well that would work. See, we could trade video's; in the winter, you could send me really "hot" videos of desolation and heat, and I could send you pictures of the ground covered with snow, to the point I would have no idea where the field is. That would cool you off. How about it. And Mikie, I hope this isn't percieved as Babbalon. You know where that "Babble-on " came from in the Bible don't you? Ohio Ralph.......really hot here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53429#53429 ________________________________________________________________________________
Subject: Re: Oskosh
Date: Aug 09, 2006
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Aug 09, 2006
Subject: FireFly Propeller Wash Over Horizontal Tail Surfaces
> >Well, maybe. I'm not convinced, but I have to admit I don't really know. >I've never thought it was necessary to "tease the throttle forward". I >don't JAM it forward, but that's out of respect for the engine, not concern >about nosing over. Empirically, it would be easy enough to determine >whether the prop wash extends down as far as the elevator or not, just by >getting down on your hands and knees immediately behind a Kolb with the >engine running. I'm going to guess you will get a faceful of wind. :) > Lee, John H. and FireFlyers, It has been HOT and so I took some measurements to determine what the true case would be for the FireFly. Then I tufted the horizontal tail surfaces to see the direct airflow over the stabilizer and elevator. I found out that John H. was correct in that the propeller wash does contact the horizontal tail surfaces on the FireFly. At maximum up elevator, 14.3% of the elevator area is hit by propeller wash. At the neutral position, 1.8% of the elevator area is hit by the propeller wash. I tufted the tail to see if these numbers were reasonable and they are. How it was done can be seen at: http://www.thirdshift.com/jack/firefly/firefly129.html If you are interested in checking out your plane, I would recommend using a fishing rod with a foam fishing bobber attached. This way you can readily feel the difference between entrained air and direct propeller wash. It is much simpler than tufting. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Aug 09, 2006
Subject: Re: FireFly Propeller Wash Over Horizontal Tail Surfaces
Date: Aug 09, 2006
Jack, You did it again!!! Thanks for sharing your information with us. I always look forward to seeing what your doing and the innovative solutions you bring to problems or questions. I noticed that you have raised the horizontal stab above factory specs as have I. I got a cleaner flight by doing so with out doing trim tabs. I have mine 5/8" above standard, what is yours? I know this is dependent on the pilots weight being a factor and the speed at which you cruise. For me, I have found the sweet spot on my FireFly. For Richard, concerning sealing the gap between the stab and boom, would an air dam made out of lexan along the inside edge of the stab work as well? Let us know how you make out with this. Terry - FireFly #95 ________________________________________________________________________________
Date: Aug 09, 2006
On Aug 9, 2006, at 1:32 PM, Terry wrote: > For Richard, concerning sealing the gap between the stab and boom, > would an air dam made out of lexan along the inside edge of the > stab work as well? I thought about gluing a strip of foam rubber to the boom tube. The up elevator seems plenty effective enough as it is on my Firestar, but a Mark III with two up may find some definite advantage with the gap sealed. Perhaps I'll wait till someone finds a noticeable advantage with this gap sealed. Gene ________________________________________________________________________________
Subject: Firestar II HKS Conversion
Date: Aug 09, 2006
I've been working with Jerry Olenick of Green Sky Adventures over the past month or so to determine the feasibility of converting my Firestar 2 from Rotax 503 power to HKS 700E power. After lots of tape measure work and study of the engine drawings, plus a number of pictures and emails back and forth, we believe the conversion can be done without modification of the orginal Firestar engine mounts. I ordered the engine today, and it should arrive sometime in the next month or so. Assuming the conversion works OK, Jerry will produce a kit to sell with the HKS that will be designed specifically for the Firestar 2. Since the HKS has worked out quite well as a direct replacement for Rotax 582's on other ultralights, there is some possibility that the HKS could be used on the Mark III and Slingshot also. If there is interest here on the Kolb List, I'll periodically post pictures and progress reports. Let's keep questions and comments on the List, rather than private emails. I have a question for the "conversion master", John Hauck, if he will be so kind as to post that he's seen this thread. -------- Dave Bigelow Kamuela, Hawaii FS2, Rotax 503 DCDI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53795#53795 ________________________________________________________________________________
Subject: Re: Firestar II HKS Conversion
Date: Aug 10, 2006
Just found out that John Hauck is on his way to PA. Here's the question: Does the Rotax 912 conversion on the Mark III involve a higher thrust line than the original Rotax 582 design? If so, how many inches, and was the pitch trim change appreciable? The HKS Firestar conversion will involve a higher thrust line than that of the 503. -------- Dave Bigelow Kamuela, Hawaii FS2, Rotax 503 DCDI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53998#53998 ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Aug 11, 2006
Dave When you put a different engine on a Kolb you will want to mount it so that it has a minimum amount of clearance between the prop tips and the fuselage tube. When I first mounted a direct drive VW on my MKIIIc I had a fairly high thrust line but because it was direct drive turning the prop at a extremely high prop RPM (3200-3600) it didn't produce enough thrust to be a problem. When I later switched the engine to a reduction drive VW I used the same engine mount but the reduction drive placed the prop 5 inches higher. With the higher prop and the increased thrust the pitch trim got so bad that I had to drastically reduce the forward CG limits. I would literally run out of up elevator with high thrust levels at lower airspeeds. A missed approach with its lower airspeed, hi thrust and flaps wow. A go around would involve raising the flaps and gaining airspeed before climbing. Also I always had to add power slowly on the ground. A basis for comparison is that most engines on MKIIIs are set up to have around 2-3 inches of prop clearance. On my first redrive engine I had 7 inches of clearance with a 72" prop. My new redrive VW engine has a new lowered engine mount that brings the clearance down to 2 inches with a 72" prop. In summary the lower the thrust line the better these Kolb fly. The HKS on a Firestar II could cause you problems with a higher thrust line. You say it is higher. How much higher? An inch or two may not be too bad but if that engine produces allot more thrust than a 503 you may want to be careful. When you make these kinds of changes you become the designer and things like CG ranges may be completely different. Again this information is worth just what you paid for it. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "Dave Bigelow" <up_country(at)hotmail.com> Sent: Thursday, August 10, 2006 10:57 PM Subject: Kolb-List: Re: Firestar II HKS Conversion > > Just found out that John Hauck is on his way to PA. Here's the question: > Does the Rotax 912 conversion on the Mark III involve a higher thrust line > than the original Rotax 582 design? If so, how many inches, and was the > pitch trim change appreciable? > > The HKS Firestar conversion will involve a higher thrust line than that of > the 503. ________________________________________________________________________________
Date: Aug 11, 2006
Thanks for the feedback, Rick. The HKS gearbox can be mounted in an up or down position just like the Rotax. If I mount it with gearbox down (2.58:1 ratio), I have to raise the engine 3 inches higher than the Rotax 503 to get 1.5 inches of clearance with a 66 inch prop from the fuselage tube. I don't want any less than 1.5 inches clearance, and don't like the idea of raising the HKS 3 inches. If I mount the HKS with the gear box up (3.47:1 ratio), I can keep the HKS at a reasonable height on the mounts, but end up with a thrust line 4.75 inches higher than the Rotax 503 thrust line. I'm looking at a 3 blade 70 inch prop. I believe there will be more thrust than the 503 produces, but not a lot more. Here's a link to the Green Sky Adventures web site. There's a world of information on the HKS and lots of pictures of other ultralights using the HKS. http://www.greenskyadventures.com/EnginePricing/HKS/home.htm -------- Dave Bigelow Kamuela, Hawaii FS2, Rotax 503 DCDI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54026#54026 ________________________________________________________________________________
Subject: Twin Kolb
Date: Aug 11, 2006
Whatever happend to this plane? http://www.recpower.com/KOLB-1f.jpg How did it fly? Any information on this? >From: "Dave Bigelow" <up_country(at)hotmail.com> >Reply-To: kolb-list(at)matronics.com >To: kolb-list(at)matronics.com >Subject: Kolb-List: Re: Firestar II HKS Conversion >Date: Fri, 11 Aug 2006 01:37:45 -0700 > > >Thanks for the feedback, Rick. The HKS gearbox can be mounted in an up or >down position just like the Rotax. If I mount it with gearbox down (2.58:1 >ratio), I have to raise the engine 3 inches higher than the Rotax 503 to >get 1.5 inches of clearance with a 66 inch prop from the fuselage tube. I >don't want any less than 1.5 inches clearance, and don't like the idea of >raising the HKS 3 inches. > >If I mount the HKS with the gear box up (3.47:1 ratio), I can keep the HKS >at a reasonable height on the mounts, but end up with a thrust line 4.75 >inches higher than the Rotax 503 thrust line. > >I'm looking at a 3 blade 70 inch prop. I believe there will be more thrust >than the 503 produces, but not a lot more. > >Here's a link to the Green Sky Adventures web site. There's a world of >information on the HKS and lots of pictures of other ultralights using the >HKS. http://www.greenskyadventures.com/EnginePricing/HKS/home.htm > >-------- >Dave Bigelow >Kamuela, Hawaii >FS2, Rotax 503 DCDI > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=54026#54026 > > ________________________________________________________________________________
Date: Aug 11, 2006
Hi Bill, I use a Panasonic digital palmcorder model No. PV-GS200 with a Leica lens, saves the digital video on tape and also saves 2.3 mega pixel still pictures on a 1 GB memory card. The reason I liked this camcorder is it has a 3 CCD image sensor system that handles color the same way as broadcast equipment before they went to high definition cameras. This picture was taken from the video, notice "La Migra's" watch tower on the lower right hand corner, they are keeping our borders safe from terrorist. The tower is enclosed like an airport control tower with air conditioning and tinted windows. It is mounted on a trailer and can be moved any where along the border. It uses hydraulics to raise and lower it. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Vincent Sent: Thursday, August 10, 2006 6:57 PM Subject: Re: Kolb-List: FireStar II flying the US- Mexican border Hi Will The video was great! I am curious what is the model/make of the camera you used. Was it a digital camera or a digital video camera? Sorry if you already answered this question ... been having computer problems. Thank you Bill Vincent Firestar II Upper Peninsula of Michigan Do Not Archive ----- Original Message ----- From: "Guillermo Uribe" <WillUribe(at)aol.com> Sent: Monday, August 07, 2006 9:08 PM Subject: Kolb-List: FireStar II flying the US- Mexican border . > Be advised the file is 4.92 MB so dialups need not view it. > http://members.aol.com/ELPEAA125/border.WMV > > Regards, > Will Uribe ________________________________________________________________________________
Date: Aug 11, 2006
Subject: Big Tennessee Fly-In Near Murfreesboro Sat August 12
Big Tennessee Fly-In Near Murfreesboro Sat August 12 Near Murfreesboro Salem Road Field Summer Fly-In forwarded From: Herb Gayheart ............. Salem Road Field Summer Fly-In Its time again for the 3rd annual Summer Fly-In hosted by the Salem Road Field Flyers This years event will be held on Saturday August 12, 2006 This is a Saturday fly-in with the field open for overnight camping on Friday and Saturday nights. While no competitions are scheduled, you never know what will come up on the spur of the moment. Drawings throughout the day for prizes. We will also be providing a sandwich lunch and Goulosh dinner on Saturday and Pancake breakfast on Sunday morning. Bring the spouse and the kids. The kids love our cable slide and cargo net and tire swing. Make sure to register for the prizes to be given away 2000x 80 grass runway (6 & 24) surrounded by open hay fields. Hanger phone is (615) 286-4239 Directions................. Driving: From Murfreesboro and I-24 go north on Highway 231 to about mile past Highway 452 (superspeedway highway). Turn right on Simmons Bluff Road. Follow for about 4 miles and turn right on Salem Road. Go over the one lane bridge and after about 1000the driveway is on the left. Watch for the orange sign and the wood fence down both sides of the driveway. The address is 1925 Salem Road. >From Lebanon and I-40 go south on Highway 231 about 9 miles. Turn left on Simmons Bluff Road and follow direction above. Flying: We are 4.7 miles and 102 east of the Fall Creek Airpark. We are 11.7 miles and 030 NNE of Murfreesboro Airport. We are 30.9 miles and 031 NNE of T-Top Airfield. For those with a GPS we are at N3601.492 W08616.295 Calm wind runway is 24. Left hand pattern. Field elevation is 615. CTAF 122.7 Windsocks are at both ends of runway and flag on NE corner of big hangar. ________________________________________________________________________________
Subject: Fw: sensing problem
Date: Jun 11, 2006
----- Original Message ----- From: john s. flannery Sent: Sunday, June 11, 2006 10:10 AM Subject: sensing problem Another problem on the Mark III, Gas gauge shows 1/4 full regardless of the two jugs being half full or quarter full. The screws here are loose in whatever nuts retain them and don't know if this total unit should lift off. Since screw is loose, probe is also not a tight contact. As you can see not much care has been taken with this part of the bird. Suggestions? Thanks, jsf don not archive ________________________________________________________________________________
Subject: Re: Fw: sensing problem
Date: Aug 11, 2006
Hi John, Is it a float or capacitance system? Do you have a manual for it. Looks like the wiring needs to be replaced at a minimum. Can you pull the unit out and inspect it? That's what I would do to see if it can be repaired or you need to replace it, IMHO. Guy Morgan Galveston, TX Firefly ----- Original Message ----- From: john s. flannery<mailto:jsflan(at)valornet.com> To: kolb-list(at)matronics.com Sent: Sunday, June 11, 2006 12:37 PM Subject: Kolb-List: Fw: sensing problem ----- Original Message ----- From: john s. flannery<mailto:jsflan(at)valornet.com> To: a jsf Sent: Sunday, June 11, 2006 10:10 AM Subject: sensing problem Another problem on the Mark III, Gas gauge shows 1/4 full regardless of the two jugs being half full or quarter full. The screws here are loose in whatever nuts retain them and don't know if this total unit should lift off. Since screw is loose, probe is also not a tight contact. As you can see not much care has been taken with this part of the bird. Suggestions? Thanks, jsf don not archive ________________________________________________________________________________
Date: Aug 11, 2006
The arm could be stuck. Take your guage out. Then move the arm up and down. If your fuel guage moves then your arm was probably stuck or the short is on the sender side. If the guage doesn't move when you move the arm then your short is on the guage side. If you replace the guage then go with one with numbers near 30-250ohm. I forget the exact numbers but those are real close. >From: "john s. flannery" <jsflan(at)valornet.com> >Reply-To: kolb-list(at)matronics.com >To: >Subject: Kolb-List: Fw: sensing problem >Date: Sun, 11 Jun 2006 10:37:13 -0700 > > >----- Original Message ----- >From: john s. flannery >To: a jsf >Sent: Sunday, June 11, 2006 10:10 AM >Subject: sensing problem > > >Another problem on the Mark III, Gas gauge shows 1/4 full regardless of the >two jugs being half full or quarter full. The screws here are loose in >whatever nuts retain them and don't know if this total unit should lift >off. Since screw is loose, probe is also not a tight contact. As you can >see not much care has been taken with this part of the bird. Suggestions? >Thanks, > >jsf > >don not archive > > ><< Kolbgasgauge35kb_8716.jpg >> ________________________________________________________________________________
Date: Aug 11, 2006
| I found out | that John H. was correct in that the propeller wash does contact the | horizontal tail surfaces on the FireFly. | | Jack B. Hart FF004 Thanks Jack B: Really had no reason to BS you about prop wash and tails, hehehe. Just goes to show you I have learned something about the airplanes I have been fly for a while now. john h Candy Hill RV Park, Winchester, VA (where they have more rules than the Army. Nell said it is because we are so close to Wash, DC. ________________________________________________________________________________
Date: Aug 11, 2006
and Slingshot also. | | If there is interest here on the Kolb List, I'll periodically post pictures and progress reports. Let's keep questions and comments on the List, rather than private emails. I have a question for the "conversion master", John Hauck, if he will be so kind as to post that he's seen this thread. | | -------- | Dave Bigelow Hi Dave B: Don't know about the "conversion master" handle, but I have read your email. john h mkIII ________________________________________________________________________________
Date: Aug 11, 2006
| Just found out that John Hauck is on his way to PA. Here's the question: Does the Rotax 912 conversion on the Mark III involve a higher thrust line than the original Rotax 582 design? If so, how many inches, and was the pitch trim change appreciable? | | The HKS Firestar conversion will involve a higher thrust line than that of the 503. | | -------- | Dave Bigelow Dave B: I am a firm believer in getting the thrust line as low as possible. I am running a 72" three blade Warp with 3/4" clearance between prop tip and tail boom. Most of you all will think I am off my rocker, as usual, but that is ok. With more than 1,000.00 hours in this configuration, I think I am flying safely. Higher thrust lines kill power and reduce performance, especially getting off the ground. Takes a lot of nose up pitch to overcome high thrust. Would think it much better to raise the engine and lower the thrust line. No difference between mounting 582 and 912, if I remember correctly. Again, pitch trim is governed by thrust line and hp. Talked with Gerry Olenik at Oshkosh. He briefed me on your participation. john h mkIII ________________________________________________________________________________
Date: Aug 11, 2006
| Hey John, | Thanks to your adventures and pictures of flying around... | and your advice during my building.... I,m now enjoying a little of it myself | Mike in MN Hi Mike: Wow! What an offer. Without a doubt I know you mean what you say. Thanks my friend. john h mkIII ________________________________________________________________________________
Subject: The New Kolb Aircraft Company Homeconing 2006
From: "John Williamson" <kolbrapilot2(at)comcast.net>
Date: Aug 11, 2006
I don't want anyone to forget that TNK Homecoming 2006 is on 22-24 Septermber Fly-In, Drive-In or Ride-In, you will have a great time. Pass the word to your flying friends and those that might be interested in buying a Kolb. I plan to get there on Thursday afternoon and will be available for anyone that needs or wants a Flight Review on Friday and Saturday. Contact me off-list for details on a Flight Review. -------- John Williamson Arlington, TX Kolbra, 912ULS http://home.comcast.net/~kolbrapilot1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54233#54233 ________________________________________________________________________________
Subject: Xtra question
Date: Aug 11, 2006
How is the thing between the windshield and the gap seal attached? Rivets I bet but I'd like to know. Thanks, David ________________________________________________________________________________
Subject: Flight Review
Date: Aug 11, 2006
Are you giving the flight review in your plane? Are you able to endorse my log book? If you are a flight review in your plane would really help me. My flying skills have been getting dull while I've been building. What do you charge? David ________________________________________________________________________________
Date: Aug 11, 2006
> am running a 72" three blade Warp with 3/4" clearance between prop > tip and tail boom. Most of you all will think I am off my rocker, as > usual, but that is ok. With more than 1,000.00 hours in this > configuration, I think I am flying safely John, Thanks for the info - I was thinking that 1.5 inches clearance from the tail boom would be about as close as I would be comfortable with, but you can't argue with success...... I spoke to Jerry Olenik today, and changed the HKS order to an A gear box (2.58:1) mounted down. That way, I should be able to use my 66 inch Powerfin two blade prop, and still have more than 1/2 inch clearance from the tail boom. Should be an interesting comparison between the two engines, since I'll be using the same gear ratios in a similar engine and prop RPM range. -------- Dave Bigelow Kamuela, Hawaii FS2, Rotax 503 DCDI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54307#54307 ________________________________________________________________________________
Subject: Re: Xtra question
Date: Aug 12, 2006
You're right. Rivet the fairing to the wing gap seal. Mine took a great deal of fiberglass work to fit properly. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54337#54337 ________________________________________________________________________________
Subject: Prop stepped bushing
Date: Aug 12, 2006
I went to install my prop for the first time the other night and the stepped bushing that goes in the 912IULS hub would only go in to the second step. I have not mic'd it yet but it does not look like it will fit. I wanted to check with some else before I tried to force them in and damage the hub. I have too much money invested in this eng. Better to ask a stupid question than plunge ahead. Has any one else had this problem? I e-mailed TNK Friday but have not heard from them yet. Rick Pearce Mark 3 amphib. ________________________________________________________________________________
Date: Aug 12, 2006
On my Xtra this piece is riveted to the gap seal/greenhouse and then velcroed to the wings. The entire assembly comes off for wing folding opening up the whole top of the airplane. Larry MKlllx / 582 Nice looking airplane ________________________________________________________________________________
Date: Aug 12, 2006
Dave John obviously gets away with 3/4" clearance but be very careful cutting that clearance any further. There is a lot of gyroscopic forces acting on that prop as you go thru turbulence. Make sure with any engine mounting that the engine can't flex on its mount enough to have a prop strike on the fuselage tube. Rick Neilsen Redrive VW powered MKIIIc ----- Original Message ----- From: "Dave Bigelow" <up_country(at)hotmail.com> Sent: Friday, August 11, 2006 10:57 PM Subject: Kolb-List: Re: Firestar II HKS Conversion > > >> am running a 72" three blade Warp with 3/4" clearance between prop >> tip and tail boom. Most of you all will think I am off my rocker, as >> usual, but that is ok. With more than 1,000.00 hours in this >> configuration, I think I am flying safely > > > John, > Thanks for the info - I was thinking that 1.5 inches clearance from the > tail boom would be about as close as I would be comfortable with, but you > can't argue with success...... I spoke to Jerry Olenik today, and changed > the HKS order to an A gear box (2.58:1) mounted down. That way, I should > be able to use my 66 inch Powerfin two blade prop, and still have more > than 1/2 inch clearance from the tail boom. > > Should be an interesting comparison between the two engines, since I'll be > using the same gear ratios in a similar engine and prop RPM range. > > -------- > Dave Bigelow > Kamuela, Hawaii > FS2, Rotax 503 DCDI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=54307#54307 > > > ________________________________________________________________________________
Date: Aug 12, 2006
Subject: Re: Engine mount
Subject: What a God I serve!
Date: Aug 12, 2006
Went down today. What a loving God I serve! Wind was out of the North East, Landing on a field East. Building (hanger) blocked the air, wind went out from under me. Plane was traveling 50 at 1180 ASL, field is 1,140 ASL. Approximately 100 feet from edge of strip. Probably (?) applied power while slightly (?) pulling stick back. BOOM! Pictures attached. First: God thank you for covering my, you know what. Second, Thank you Homer Kolb for the cage and the sissy bars. Third, Thank you Andy Humphrey, Instructor for instilling the right things to do, even if I didn't apply them all at the same time. Total damage, not including engine which will be checked out for crank damage; prop, sissy bars, underwear (just kidding), Pitot tube! That's right, no wing damage, no tail end damage, no nose damage (fiberglass),no tube damage, or landing gear, OR CAGE damage, thank you Homer, a little soy beans, a very small amount of pride (don't have much of that left, thank you Jesus), Chute did not deploy, thanks to the builder for putting it underneath rather than on top, and lastly, no physical damage! Soy field usage: 40 feet total for landing! Removed wings, turned over, pulled back into hanger. Looked over for additional damage, found none. Will go over with instructor next week and check closer. When I got out the gas tank discharged slowly all 6 gallons of fuel: mags off, power off, fuel pump off. Remove camera, cell phone, car keys, and asked myself: " wonder what it's gonna cost to get back in the air"! Not: "wonder what somebody would give me for this piece of &^%$%@$#". Instructor said, "Proof, that I will fly again, and again, and again"! Now need to find cheap new 66" x 3/4 wood prop, old one is on office wall AND on hanger wall , next to instructors old Avenger's prop! Exceeding my ability here in Ohio, but learning more each time Ralph! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54424#54424 Attachments: http://forums.matronics.com//files/40_foot_landing_009_small_208.jpg http://forums.matronics.com//files/40_foot_landing_002_small_197.jpg http://forums.matronics.com//files/40_foot_landing_004_small_615.jpg http://forums.matronics.com//files/40_foot_landing_001_small_786.jpg ________________________________________________________________________________
Date: Aug 12, 2006
Date: Aug 12, 2006
Subject: Re: What a God I serve!
Ralph, Glad to hear you're in one piece and the Firestar, too. If that 66 X 28 prop I offered will help you get back in the air, it's yours to use. I'm 1900 miles away, but my girl friend can have it at Fedex in the morning. Let me know if that will work and send your address. Rick On 8/12/06, Ralph Hoover wrote: > > > > > Went down today. What a loving God I serve! > > Wind was out of the North East, Landing on a field East. Building (hanger) > blocked the air, wind went out from under me. Plane was traveling 50 at 1180 > ASL, field is 1,140 ASL. Approximately 100 feet from edge of strip. Probably > (?) applied power while slightly (?) pulling stick back. BOOM! > > Pictures attached. First: God thank you for covering my, you know what. > Second, Thank you Homer Kolb for the cage and the sissy bars. Third, Thank > you Andy Humphrey, Instructor for instilling the right things to do, even if > I didn't apply them all at the same time. > > Total damage, not including engine which will be checked out for crank > damage; prop, sissy bars, underwear (just kidding), Pitot tube! > > That's right, no wing damage, no tail end damage, no nose damage > (fiberglass),no tube damage, or landing gear, OR CAGE damage, thank you > Homer, a little soy beans, a very small amount of pride (don't have much of > that left, thank you Jesus), Chute did not deploy, thanks to the builder for > putting it underneath rather than on top, and lastly, no physical damage! > > Soy field usage: 40 feet total for landing! Removed wings, turned over, > pulled back into hanger. Looked over for additional damage, found none. Will > go over with instructor next week and check closer. > > When I got out the gas tank discharged slowly all 6 gallons of fuel: mags > off, power off, fuel pump off. Remove camera, cell phone, car keys, and > asked myself: " wonder what it's gonna cost to get back in the air"! Not: > "wonder what somebody would give me for this piece of &^%$%@$#". > > Instructor said, "Proof, that I will fly again, and again, and again"! > > Now need to find cheap new 66" x 3/4 wood prop, old one is on office wall > AND on hanger wall , next to instructors old Avenger's prop! > > Exceeding my ability here in Ohio, but learning more each time Ralph! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=54424#54424 > > > Attachments: > > http://forums.matronics.com//files/40_foot_landing_009_small_208.jpg > http://forums.matronics.com//files/40_foot_landing_002_small_197.jpg > http://forums.matronics.com//files/40_foot_landing_004_small_615.jpg > http://forums.matronics.com//files/40_foot_landing_001_small_786.jpg > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 12, 2006
David: I checked today on the MkIIIx that shares hangar space with me. You were right, it's rivets. -Ken ----- Original Message ----- From: "David Key" <dhkey(at)msn.com> Sent: Friday, August 11, 2006 8:28 PM Subject: Kolb-List: Xtra question > How is the thing between the windshield and the gap seal attached? Rivets I > bet but I'd like to know. > Thanks, > David > > ________________________________________________________________________________
Subject: Yellow Firestar owner?
Date: Aug 13, 2006
I went to a Fly-In at Dart Field (D79) in south western NY Saturday and as I was departing, I saw a yellow Kolb Firestar arriving. If I had not had to get back home, I'd have landed again and talked to the guy. It was not Ed Steuber or Bob Bean. Their Kolbs are neither Firestars nor yellow. Does anyone on the list know who owns a yellow Firestar in western NY or northwestern PA? Thom in Buffalo ________________________________________________________________________________
Subject: Re: Yellow Firestar owner?
Date: Aug 13, 2006
Tom, I sold a Firestar to a guy in upper Pa . two years ago, not sure exactly where he lived but his name I believe was Louie Slyder. Attached is a picture of the plane On Aug 13, 2006, at 6:44 AM, Thom Riddle wrote: > > I went to a Fly-In at Dart Field (D79) in south western NY Saturday > and as I was departing, I saw a yellow Kolb Firestar arriving. If I > had not had to get back home, I'd have landed again and talked to > the guy. It was not Ed Steuber or Bob Bean. Their Kolbs are > neither Firestars nor yellow. > > Does anyone on the list know who owns a yellow Firestar in western > NY or northwestern PA? > > Thom in Buffalo > > ________________________________________________________________________________
Date: Aug 13, 2006
Mike, That is a great (watch his head swell now) idea. It didn't initially register but when it did, WOW! That is simple and does the job. Thanks. I have only one question, clear venting. How do you know or make sure in your walk around that the vents are clear of (here's that word) Mud Daubers, spider webs, or faunta and/or floura? I would be most interested in doing what you did, if I can be confident that the system can breath, or I might have traded a one time problem for an everytime problem. Thanks again Mike. P.S. here are a few more pictures of the plane up close and personal. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54576#54576 Attachments: http://forums.matronics.com//files/40_foot_landing_018_small_928.jpg http://forums.matronics.com//files/40_foot_landing_011_small_845.jpg http://forums.matronics.com//files/40_foot_landing_003_small_548.jpg ________________________________________________________________________________
Date: Aug 13, 2006
On Aug 12, 2006, at 4:24 PM, Ralph Hoover wrote: > > Went down today. What a loving God I serve! > > > Total damage, not including engine which will be checked out for > crank damage; prop, sissy bars, underwear (just kidding), Pitot tube! > > That's right, no wing damage, no tail end damage, no nose damage > (fiberglass),no tube damage, or landing gear, OR CAGE damage, thank > you Homer, a little soy beans, a very small amount of pride (don't > have much of that left, thank you Jesus), Chute did not deploy, > thanks to the builder for putting it underneath rather than on top, > and lastly, no physical damage! WHAAAT ! ! ?? So little damage with a total flip (on the ground) is unheard of ! ! ! Just don't EVER try that again! Ya hear now? ;^) ________________________________________________________________________________
Subject: Re: Fuel Tank Vent
Date: Aug 13, 2006
I have included a link to a Pneumatic muffler that I used on my fuel tank vent that is routed to the bottom of the fuselage. http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=1809701&PMT4NO=10617314 Steven Green How do you know or make sure in your walk around that the vents are clear of (here's that word) Mud Daubers, spider webs, or faunta and/or floura? > > I would be most interested in doing what you did, if I can be confident that the system can breath, or I might have traded a one time problem for an everytime problem. ________________________________________________________________________________
Date: Aug 13, 2006
Try bits of kitchen sponge in the end of the vent lines. If that's too shade tree mechanic for you (couldn't help myself guys), you can find crankcase vents designed to mount to hose with cool chrome fittings at your local Harley dealer. Rick On 8/13/06, Steven Green wrote: > > > I have included a link to a Pneumatic muffler that I used on my fuel tank > vent that is routed to the bottom of the fuselage. > > http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=1809701&PMT4NO=10617314 > > Steven Green > > > How do you know or make sure in your walk around that the vents are clear > of (here's that word) Mud Daubers, spider webs, or faunta and/or floura? > > > > I would be most interested in doing what you did, if I can be confident > that the system can breath, or I might have traded a one time problem for > an > everytime problem. > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: Fule tank vent
Date: Aug 13, 2006
You can use aquarium air diffusers for vent filters, they are cheap and disposable and plug right in to vent size tubing. They come in a varity of sizes and styles (the glass bead ones work well). ________________________________________________________________________________
Date: Aug 13, 2006
You an also tape a small piece of screen 'wire' -- fibreglass or nylon, usually -- over the end of the vent tube. Secure it with filament (strapping) tape & it will last for a few years. Can also check vent lines for blockage by blowing into them. Can feel if solidly blocked of if you're just blowing against a little tank pressure. Lo-tech maybe but it worx. On Aug 13, 2006, at 7:11 PM, Richard Girard wrote: > Try bits of kitchen sponge in the end of the vent lines. If that's > too shade tree mechanic for you (couldn't help myself guys), you > can find crankcase vents designed to mount to hose with cool chrome > fittings at your local Harley dealer. > > Rick > > On 8/13/06, Steven Green wrote: > Kolbdriver(at)bellsouth.net> > > I have included a link to a Pneumatic muffler that I used on my > fuel tank > vent that is routed to the bottom of the fuselage. > > http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=1809701&PMT4NO=10617314 > > Steven Green > > > How do you know or make sure in your walk around that the vents are > clear > of (here's that word) Mud Daubers, spider webs, or faunta and/or > floura? > > > -- > Rick Girard > "Ya'll drop on in" > takes on a whole new meaning > when you live at the airport. ________________________________________________________________________________
Subject: Re: Fule tank vent
Date: Aug 13, 2006
How about the little fuel filters like the ones in chainsaw or weed whacker fuel tanks? I think they are called finger filters and they work perfectly for keeping insects out of the vent lines. Denny Rowe, Mk-3, PA ________________________________________________________________________________
Subject: Sunday evening at the Kolb Farm
Date: Aug 13, 2006
Happy Campers! ________________________________________________________________________________
Date: Aug 13, 2006
Admiring Dan Walter's Ultrastar! ________________________________________________________________________________
Date: Aug 13, 2006
Wonderful hanger flying by the Hauck! ! ________________________________________________________________________________
Date: Aug 13, 2006
And you should have heard that'n ! ________________________________________________________________________________
Date: Aug 13, 2006
Watch This ! Terry, Homer, Jim , and John,,,,,,, Ready, get set ,,,,,, Go! ________________________________________________________________________________
Date: Aug 13, 2006
And then there is the option to use a cover with a "Remove Before Flight" streamer or even the little spring loaded cover that's used on some GA aircraft. On 8/13/06, Denny Rowe wrote: > > How about the little fuel filters like the ones in chainsaw or weed > whacker fuel tanks? I think they are called finger filters and they work > perfectly for keeping insects out of the vent lines. > > Denny Rowe, > Mk-3, PA > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 14, 2006
Thom, ive been following the Kolb & Titan list for quite a while now, and was just wondering what you're flying now? Best regards, Dave Culver ________________________________________________________________________________
Date: Aug 14, 2006
Date: Aug 14, 2006
Thom, the Allegro sure is a beautiful looking plane. I think i heard you mention once what your'e flying, but had no idea what it looked like. You had me curious as to what you went to after the titan. Thanks for the response and the nice picture. Safe flying, best regards. Dave Culver ( Please don't archive) ________________________________________________________________________________
Date: Aug 14, 2006
On Aug 14, 2006, at 8:32 PM, Thom Riddle wrote: > Where is Smoketown? http://www.airnav.com/airport/S37 ________________________________________________________________________________
Subject: Re: Sunday evening at the Kolb Farm
Date: Aug 15, 2006
Gene, Bill, Ron, et al: When I got the original message, as has been the case in many of Gene's postings w/images, two files per image are shown. One that appears to be compatible with MAC/Apple machines and another for PC/DOS machines. Have had no problems opening the PC image file listed. Unfortunately, I saved the images and dumped the messages and for whatever the reason, can't find Gene's original msg in the forum. Bill, the PC vs Apple issue would be consistent with the error message that you get if you are using a PC machine. Eugene Zimmerman wrote: > Hi Bill, > The pictures are all JPEG files. The only reason I can think of for > them not opening is that the file names may be too long for your > browser. > If you would like I could try renaming the files and send them to > your personal address. > > I am curious to know if anyone else was unable to open the picts? > > On Aug 14, 2006, at 8:48 PM, Bill Vincent wrote: > > > > > Hi Eugene > Sorry, but I can't open your pictures, we get a box that states: > File does not have program associated with it for performing this > (open) action. > > --- -------- George Alexander http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54900#54900 ________________________________________________________________________________
From: "Eugene Zimmerman" <etzim62(at)earthlink.net>
Date: Aug 15, 2006
Ok, I apologize for the redundancy but for the sake of the people who could not open the pictures the first time I'll try again by posting them on the BBS forum interface. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=54901#54901 Attachments: http://forums.matronics.com//files/5_163.jpg http://forums.matronics.com//files/4_144.jpg http://forums.matronics.com//files/3_101.jpg http://forums.matronics.com//files/2_793.jpg http://forums.matronics.com//files/1_102.jpg ________________________________________________________________________________
Subject: Alternate engine possibility for Firestar or Firefly
Date: Aug 15, 2006
Hello all, I ran across this today on the web. I don't know anything about it, but I thought I would pass it along. http://www.rotary-xr40.com/ Jason MKIIIC BMW R100 (finished and FAA approved, just trying to find the best place to test fly it) Portland, OR ________________________________________________________________________________
Subject: Re: Alternate engine possibility for Firestar or Firefly
Date: Aug 15, 2006
Interesting. Single cylinder with reduced vibration, rotary. Single carb. I do however wonder the fairness of the 'efciency rating against the 503 DIDC (which I have of my firestar), as being 4 GPH. Appears to be a very inifficient RPM and speed for the test aircraft with the 503. Dont know. Radiator and electric start at 55 #. Pretty impresive. "Phantom X-1, 260 lb pilot and 30 lbs of fuel". Thats a heavey duty pilot, even from my standards (220#). Guess with all that it might be close to 4 gph. If the pilot is the same one in the picture on your opening page, he has too have a huge butt, caues he is about average in build. I do have a question. How do you "derate an engine from 52 hp to 40 hp? If its based on rpm, then I understand, even though I could rev engine past the rated RPM. Soyfused (verses Cornfused, which I would probably be dead by now), in Ohio Ralph! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=55016#55016 ________________________________________________________________________________
Date: Aug 15, 2006
yup got em this time thanks ----- Original Message ----- From: "Eugene Zimmerman" <etzim62(at)earthlink.net> Sent: Tuesday, August 15, 2006 6:49 AM Subject: Kolb-List: Re: Sunday evening at the Kolb Farm > > > Ok, I apologize for the redundancy but for the sake of the people who > could not open the pictures the first time I'll try again by posting them > on the BBS forum interface. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=54901#54901 > > > Attachments: > > http://forums.matronics.com//files/5_163.jpg > http://forums.matronics.com//files/4_144.jpg > http://forums.matronics.com//files/3_101.jpg > http://forums.matronics.com//files/2_793.jpg > http://forums.matronics.com//files/1_102.jpg > > > ________________________________________________________________________________
Date: Aug 16, 2006
Bill/All For an EXCELLENT photo visit to several of the past Kolb farm get togethers I recomend you check out Geo Alexander's photos. http://home.comcast.net/~kolbplanes/ Thanks George, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=55146#55146 ________________________________________________________________________________
Date: Aug 16, 2006
Bryan and I saw this at SnF the last two years in a row. It really has a potential for the Firefly. I would love to put one on the Firefly Floatplane, BUT, It's exhaust configuration does not lend itself to a pusher application. You can probably work around it but have been waiting to see how the engine works for a while. It has a really nice alternator and starter at less weight than a 447. Maybe the importer will come up with a pusher configuration. Steve Firefly 007 on floats ________________________________________________________________________________
Subject: corroded gas gauge
Date: Aug 17, 2006
Not into endorsements but found a product which might help someone. The fuel gauge was totally corroded when I pulled it. Found EVAPORUST AT Autozone under ten bucks and also with a rebate until December of this year. Soaked gauge overnight and cleaned up beautifully. Not sure gauge works... have to rewire...still a problem there, but this cleaned up nicely. Can't believe either that something labeled Environmentally safe actually works. Now need to know about unusual wraps from CHT sensor wire near muffler, and if with sensors, there should still be washers under the sparkplugs. jsf ________________________________________________________________________________
Subject: Re: corroded gas gauge
Date: Aug 17, 2006
----- Original Message ----- From: john s. flannery . Now need to know about unusual wraps from CHT sensor wire near muffler, and if with sensors, there should still be washers under the sparkplugs. jsf Yes you do. I asked that very question at the LSA maintenance school that I just attended at Corning, Ca. Larry, Oregon ________________________________________________________________________________
Date: Aug 17, 2006
Thanks Larry, Thought maybe the washers were causing or would cause a problem. Do you still anneal washer after cleaning plugs as we did with spamcans? I bought, but haven't installed a replacement CHT sensor. Did get gauge to rise sporadically with the old, but it was always 100 degrees below the other with equal heat. So new one goes in when I get back out to hangar. j ----- Original Message ----- From: Larry Cottrell To: kolb-list(at)matronics.com Sent: Thursday, August 17, 2006 11:20 AM Subject: Re: Kolb-List: corroded gas gauge ----- Original Message ----- From: john s. flannery . Now need to know about unusual wraps from CHT sensor wire near muffler, and if with sensors, there should still be washers under the sparkplugs. jsf Yes you do. I asked that very question at the LSA maintenance school that I just attended at Corning, Ca. Larry, Oregon ________________________________________________________________________________
Date: Aug 17, 2006
----- Original Message ----- From: john s. flannery To: kolb-list(at)matronics.com Sent: Thursday, August 17, 2006 2:00 PM Subject: Re: Kolb-List: corroded gas gauge Thanks Larry, Thought maybe the washers were causing or would cause a problem. Do you still anneal washer after cleaning plugs as we did with spamcans? I guess the rest of the list is on vacation or something, but about your question, if it was me I would throw away the old plugs and buy new ones. I believe that 25 hours is the recommended interval. Larry,Oregon ________________________________________________________________________________
Date: Aug 17, 2006
Subject: prop repair
This from another list: (no, I didn't do it!) I made a hard landing tonight (PPC) and my Ivo prop nicked my upper strut. I have another strut but one blade on the prop has a slightly damaged tip. It looks like it is delaminated slightly. I heard that super glue and baking soda would fix it. If anyone knows how, please post ASAP. I want to fly Saturday. I suspect tip repairs aren't the same as a small nick. Any replies will be forwarded. regards, Bob N. http://www.angelfire.com/rpg/ronoy/ ________________________________________________________________________________
Subject: Re: prop repair
Date: Aug 18, 2006
I strongly encourage you to contact Ivo for a consultation. I've found them to be very helpful. ----- Original Message ----- From: Bob Noyer To: kolb-list(at)matronics.com Sent: Thursday, August 17, 2006 11:24 PM Subject: Kolb-List: prop repair This from another list: (no, I didn't do it!) I made a hard landing tonight (PPC) and my Ivo prop nicked my upper strut. I have another strut but one blade on the prop has a slightly damaged tip. It looks like it is delaminated slightly. I heard that super glue and baking soda would fix it. If anyone knows how, please post ASAP. I want to fly Saturday. I suspect tip repairs aren't the same as a small nick. Any replies will be forwarded. regards, Bob N. http://www.angelfire.com/rpg/ronoy/ ________________________________________________________________________________
Date: Aug 18, 2006
Hi Bob, If it were mine and the damage is not too extensive I would cut both tips on a twenty degree angle as per Terry Frantz / Jack Hart . They both give reports of excellent results in performance AND NOISE REDUCTION. An example of the tip profile can be seen at ,,,,,, http://www.top-flite.com/accys/topq5000.html Gene On Aug 17, 2006, at 11:24 PM, Bob Noyer wrote: > This from another list: (no, I didn't do it!) > > I made a hard landing tonight (PPC) and my Ivo prop nicked my upper > strut. I have another strut but one blade on the prop has a slightly > damaged tip. It looks like it is delaminated slightly. I heard that > super glue and baking soda would fix it. If anyone knows how, please > post ASAP. I want to fly Saturday. > > I suspect tip repairs aren't the same as a small nick. Any replies > will be forwarded. > > regards, > Bob N. > http://www.angelfire.com/rpg/ronoy/ > > > www.matronics.com/Navigator?Kolb-List _- > www.matronics.com/contribution _- > =========================================================== ________________________________________________________________________________
Date: Aug 18, 2006
Date: Aug 18, 2006
Huh? What? On Aug 18, 2006, at 8:28 AM, George Myers wrote: > > ________________________________________________________________________________
Date: Aug 18, 2006
Dave and Group, I, also, have an interest in the HKS. I just didn't want to be the first one to put one on a Firestar. So, I will be following your reports on this project. I've been away from my Firestar for the summer, but I'll be back in a few weeks, and ready to start flying and working on it again. -------- John Jung Firestar II N6163J Surprise, AZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=55565#55565 ________________________________________________________________________________
Date: Aug 18, 2006
> I made a hard landing tonight (PPC) and my Ivo prop nicked my upper Super glue is useless for delaminations but is perfect for nicks in the blade. With a file clean out all loose material and smooth any bulged edges. Put a couple teaspoons of baking soda in a shallow container so you can easily pinch a hefty finger of it. With the nick as level as you can get it, carefully wet the surface of the nick with super glue and immediately sprinkle on enough baking soda to completely dry it. Careful, it will dry instantly. On wood props in particular make sure to wet every nook & cranny. A layer of masking tape on each side under the nick will keep any overflows from sticking to the blade. Continue wetting and sprinkling until the patch is slightly wider and taller than the nick. Then file it down to match the prop. Works on wood or composite. George ________________________________________________________________________________
Date: Aug 18, 2006
At 08:25 PM 8/18/2006, you wrote: > >My memory may be failing me on this but it (my memory) is currently >telling me that I was taught in A&P school to REPLACE the spark plug >washer with the CHT thermocouple ring, not stack them. When I asked >why (which I did a lot), I was told that if you do not, the reach or >the location of the spark gap would be different from the design distance. That is what I've always done - 503 dual-carb CDI - 700 hours. Plugs ..every 25 hours, whether they need it or not. Just the cost of doing business. http://www.mindspring.com/~possums/ PS ---- I use the expensive plugs too, so it hurts (just a little). "So ....did you jump son? Yeah Dad .... just a little!" You know the joke. ________________________________________________________________________________
From: "Wayne T. McCullough" <blackbird754(at)alltel.net>
Subject: E-mail changing
Date: Aug 19, 2006
My e-mail has been changed to blackbird754(at)windstream.net Thanks, Wayne McCullough ----- Original Message ----- From: "John Jung" <jrjungjr(at)yahoo.com> Sent: Friday, August 18, 2006 1:55 PM Subject: Kolb-List: Re: Firestar II HKS Conversion > > Dave and Group, > > I, also, have an interest in the HKS. I just didn't want to be the first > one to put one on a Firestar. So, I will be following your reports on this > project. > > I've been away from my Firestar for the summer, but I'll be back in a few > weeks, and ready to start flying and working on it again. > > -------- > John Jung > Firestar II N6163J > Surprise, AZ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=55565#55565 > > > ________________________________________________________________________________
Date: Aug 19, 2006
Subject: Re: S.P. Practical test
Congraulations on your Sports Pilot License. Way to GO !!!! Can you tell some of us who haven't taken the Practical test what to expect ? Thanking you in advance. Stephen Firefly Alabama ________________________________________________________________________________
Date: Aug 19, 2006
Subject: S.P. Practical Test
Stephen and All, The test was brutal, we started at 9 am. and finished at 3 pm. The oral part lasted for four hours, we took a half hour lunch break then flew for an hour, then a half hour of paper work. My brain was drained when we were finished. The examiner asked at least two guestions from each standard, however he was VERY fair. If my answer didn`t please him, he kept dragging out information from me until he was satisfied. He zeroed in on air space, we spent about an hour looking at a sectional map, he would point to something on the map, and have me tell him everything I could about that air space. If I said that I could not fly in a certain airspace with a S.P. rating, he wanted to know if I could fly under or over it. As it is an open book test I spent a lot of time finding the answers in the FAR`S. The flight test consisted of everything listed in the standards, once again he was very fair. Before the flight he told me the standard is not perfection, as long as the outcome of the maneuver was never in doubt. I guess that is a judgement call on his part. It is my opinion that the examiner can make you or break you , I was lucky to find a good one. Lanny Fetterman F.S. II N598LF ________________________________________________________________________________
Date: Aug 19, 2006
Subject: New Subject : sling Shot qualities
Guys Anyone have an opinion on the flying qualities of the Slingshot? I have found a quick build kit. Thanks Herb in Ky Ps Flew my Firefly abt 137 miles out and back to a flyin at Hodgenville Ky today.. Accompanied by another Firefly owned by Mike Thompson.. Unfortunately we were the flyin.. Weather kept all the other fliers in the coop. I arrived home just before thunderstorms moved through... :-) Felt as if I was flying through 1% milk all day! ________________________________________________________________________________
Date: Aug 19, 2006
Subject: Field Locations
Group, Trying to compile a list of friendly fields in Tn.,Ky.,Al. any GPS#, contact info, field conditions would be great! Kind of like the Frapper site but, more useable. Please e-mail info direct to me off list. Thanks, Wade FS2 --------------------------------- ________________________________________________________________________________
Subject: Trailering a Kolb
Date: Aug 19, 2006
Kolbers: Finally got around to putting up pictures of the trailer setup that I use to store and transport my Firestar II. (Finally..... shoemaker's children and all that stuff.) Go to: http://gtalexander.home.att.net and then click on "Trailering a Kolb" Although I say so in the web material, in case you miss it, I want to acknowledge those that contributed to this being a good alternative to enclosed hangar space. Mike Shackelford built the trailer. Much of the design came from Richard Swiderski's trailer with Mike adding many neat features. Trailer is solidly built, yet not terribly heavy. It did well by the Firestar moving from WV to NJ (365 miles) and then from NJ to FL (1250 miles). Contributing to features/changes since I have had it are my two neighbors at Airport Mantee... Chris Mallory and Beauford Tuton. To all these guys..... I thank you. The contributions by all of you allow me to pull up to the trailer, off load the plane, put it together, do a thorough preflight, don my gear and be ready to go in 30-35 minutes. (That assumes no one is around who wants to chat.) Similarly, if I had to get it out of there (as in hurricane evacuation), I could have the FS secured for travel in the trailer and the trailer up on its wheels and ready to roll in a couple of hours. (Since I leave the trailer at the airport all the time, it is strapped down to anchors similar to mobile homes and the wheels removed to get it lower to the ground making it easier to roll the plane on and off.) Again, thanks to the contributors. On a side note, in the process of putting this stuff up, discovered that I had inadvertantly wiped out Dennis Kirby's material when I put Larry Cottrell's. I apologize to Dennis. Stuff's getting harder to keep up with. If any others have trailer material that they want up on this site, please feel free to contact me. -------- George Alexander http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=55812#55812 ________________________________________________________________________________
Subject: Melted D-Cell batteries
Date: Aug 19, 2006
I put the batteries in the ELT and the ELT didn't work. I started working on something else and after a few hours went back to the ELT and there was a liquid all over it. Upon inspection it looks like at least one battery sprug a leek. So do I have bad batteries? A short? I'm 99% sure I put them in the right way. Should I put another set in the same way? Thanks, David Key >From: WADE LAWICKI <wlawicki(at)yahoo.com> >Reply-To: kolb-list(at)matronics.com >To: kolb-list(at)matronics.com >Subject: Kolb-List: Field Locations >Date: Sat, 19 Aug 2006 19:15:22 -0700 (PDT) > >Group, > Trying to compile a list of friendly fields in Tn.,Ky.,Al. any >GPS#, contact info, field conditions would be great! Kind of like the >Frapper site but, more useable. > Please e-mail info direct to me off list. > Thanks, > >Wade FS2 > > >--------------------------------- ________________________________________________________________________________
Date: Aug 19, 2006
Subject: Re: Melted D-Cell batteries
David, Before you do anything I'd think that last 1% would be worth determining. On 8/19/06, David Key wrote: > > > I put the batteries in the ELT and the ELT didn't work. I started working > on > something else and after a few hours went back to the ELT and there was a > liquid all over it. Upon inspection it looks like at least one battery > sprug > a leek. So do I have bad batteries? A short? I'm 99% sure I put them in > the > right way. Should I put another set in the same way? > Thanks, > David Key > > > >From: WADE LAWICKI <wlawicki(at)yahoo.com> > >Reply-To: kolb-list(at)matronics.com > >To: kolb-list(at)matronics.com > >Subject: Kolb-List: Field Locations > >Date: Sat, 19 Aug 2006 19:15:22 -0700 (PDT) > > > >Group, > > Trying to compile a list of friendly fields in Tn.,Ky.,Al. > any > >GPS#, contact info, field conditions would be great! Kind of like the > >Frapper site but, more useable. > > Please e-mail info direct to me off list. > > Thanks, > > > >Wade FS2 > > > > > >--------------------------------- > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: a question
Date: Aug 20, 2006
Being a new guy, my question is concerning an aircraft similar to a Kolb. Can anyone tell me about an airplane called the Ferguson FX -4-2? I would appreciate any comments regarding the aircraft. thanks, bob ________________________________________________________________________________
Subject: Re: S.P. Practical Test
Date: Aug 20, 2006
As it is an open book test I spent a lot of time finding the answers in the FAR`S.>> Hi , it sounds as though the test was pretty thorough and I am glad I shall not have to take it. However, is it really a useful test if you are allowed to look up the answers? In the cockpit you have to KNOW the answer, now, if say you have to divert and the field you need is in controlled airspace of some sort. It seems on the face of it further easement of exam standards which started with the introduction of multi choice answers which gave the examinee a one in three chance of being correct even if they had no idea at all. What do others think? Cheers Pat -- ________________________________________________________________________________
Date: Aug 20, 2006
Subject: Re: Kolb-List Digest: 13 Msgs - 08/19/06
>From Bob _Erb-bserbjr(at)aol.com_ (mailto:Erb-bserbjr(at)aol.com) Subject- Sport pilot test I have built and am flying a Firestar II with a Rotax 503. I have been preparing for the Sport pilot exam and feel comfortable with all the maneuvers except the forward slip to a landing. Is it possible to perform this maneuver the correct way in a Firestar? Every time I try it, the plane turns in the direction of the aileron input, the nose wants to come up, not enough down to push the nose down and the plane makes a funny noise like the ailerons are fluttering but they are not. There does not seem to be enough rudder authority to straighten the flight path. Any ideas as to what I am doing wrong or should I tell the examiner the plane is not designed to do forward slips. I have recently had 15 hours of flight training in a Champ in preparation for the exam and I have no problems Forward slipping that plane. Thanks for the help-Bob ________________________________________________________________________________
Date: Aug 20, 2006
Subject: 42 Practical test standards
Pat and all, I was tested on 42 standards during the oral segment of the test. Airspace was only one standard that I was required to know and understand. I was told that I must score 100% on the oral part of the test, that one wrong answer would fail me. ( I don`t know if that is an FAA rule or a rule that my examiner developed on his own, but that was the gun I was under.) While I felt I knew most of the answers, I was not going to risk a failure by giving a wrong answer. So I referred to the FARS. better safe than sorry! I studied more for this test then any test in my entire life, including my college days. The Federal Aviation Regulations/ Aeronautical Information Manual has 1004 pages of information in it. How can any human being be expected to commit that much information to memory? "Easement of the exam standards" I don`t know because this is the only FAA rating test I have ever taken. Flying is a hobby for me, not a vocation. On that premise, I feel this test was difficult enough, and I learned plenty in the process. Did I learn everything contained in the FARS, hardly. Pat, when you have time, would you please post a brief review of the test you took. that you are comparing to the S.P. test, I would be interested in the differences. P.S. I love my FSII, however I took the flight test in a Skyboy. What an aircraft that is! There might be something good behind the doors opened by getting the SP rating. Lanny Fetterman FSII N598LF ________________________________________________________________________________
Date: Aug 20, 2006
Patt, I believe what the FAA is trying to address with the SP practical test is the level of ignorance and misinformation common in the ultralight community. From what I gather it is no more difficult than the test I took for my PPL. In the example you give, the solution is not to be fumbling about in the cockpit trying to look up FAR's, it is to plan your flight before hand, so you know the airspace into which you venture. On 8/20/06, pat ladd wrote: > > > As it is an open book test I spent a lot of time finding the answers in > the > FAR`S.>> > > Hi , > it sounds as though the test was pretty thorough and I am glad I shall not > have to take it. > > However, is it really a useful test if you are allowed to look up the > answers? In the cockpit you have to KNOW the answer, now, if say you have > to divert and the field you need is in controlled airspace of some sort. > > It seems on the face of it further easement of exam standards which > started > with the introduction of multi choice answers which gave the examinee a > one > in three chance of being correct even if they had no idea at all. > > What do others think? > > Cheers > > Pat > > > -- > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: Re: a question
Date: Aug 20, 2006
Rick, although there are obvious similarities between makes, I have to respectfully disagree on some points. #1 are the myriad pushers out there that went for a single boom tail. BB Bob B/Gang: Bill Ferguson, designer of the Ferguson aircraft, showed up at Sun and Fun 1991, with an airplane he called the Ferguson or Fergy. Looked a lot like the mkIII kit he purchased from Homer Kolb with the exception of wings and changes to the main fuselage cage. From the tip of the tailboom to the tip of the rudder, the Fergy looked exactly like the mkIII Homer Kolb had on display at S&F 2001. Ferguson had not bothered to change the tail boom and tail section. Rather than call this a Ferguson modified Kolb mkIII, Ferguson took credit for the entire airplane. This troubled Homer Kolb tremendously. He and the old Kolb crew had spent many hours and days designing a folding tail section that is still being produced today by TNK. Yes, I agree, a lot of airplanes look alike. But in this case, it went much further than resembling a mkIII. In my own opinion, the Fergy is not near the aircraft the mkIII is. I base this on my own personal observations of many of Ferguson's airplanes. However, my most convincing observation is the flight history, or should I say the crash history of a close friend's two Fergys. In both crashes, my friend was injured. In the second crash, which occurred more than a year ago, my friend is still recuperating from a near death crash which broke many bones in his body and the body of the passenger. First thing I look at in any airplane I plane to fly is crash worthiness. The environment we fly is mighty unfriendly at times, and no one is immune to gravity. I have survived several serious crashes in Homer Kolb's airplanes. I have survived each of them with no injury. Guess that's one of the reasons I feel more comfortable in my mkIII than any of the other designs out there. john h mkIII PS: Returned from Spring City, PA, last night. Had a great visit with Homer and Clara. Also was treated to the flyin of local Kolbs which has already been discussed on this List. It was my pleasure to be able to visit with these great guys. ________________________________________________________________________________
Date: Aug 20, 2006
Hi Bob, The plane nearest a Kolb mk III with a nose wheel might be a Rans S-12 Airiale. It is a capable aircraft and is also well supported by the folks at Rans. The S-12 also features a chrome moly steel cage in its structure. I have flown one here locally and it seems to be well behaved. Not having flown a Kolb Mk.III, I cannot offer a comparison. Good Luck with your inquiries... Best Regards Carlos Grageda Firestar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=55930#55930 ________________________________________________________________________________
Date: Aug 20, 2006
| It is a capable aircraft and is also well supported by the folks at Rans. The S-12 also features a chrome moly steel cage in its structure. | | Best Regards | Carlos Grageda | Firestar II Carlos: Best check out the Rans S-12 fuselage. I think you will find their 4130 fuselage is actually a 4130 tube shallow tub. Look closely and you will see that all upright tubes are aluminum. Most of the accident photos I have seen involving RANS S-12's results in this part of the fuselage failing down and forward on top of the pilot and passenger. Having never flown an S-12, can not comment on its flying characteristics. However, I have heard some of the earlier Rans S12's had a problem with empennage stability. john h mkIII ________________________________________________________________________________
Date: Aug 20, 2006
Subject: Re: Spark Plugs
As I understand it, if you put on both the spark plug washer and the ring for the CHT, there will be exposed threads at the bottom of the tapped hole for the plug. If anyone ever puts in a plug without both, the threads on the plug will hit the now carboned up threads in the tapped hole. You can end up stripping out the tapped hole in the head, or dump loose carbon chunks into the cylinder, neither of which is a good thing. In addition, you reduce the heat lost to the head by the plug, as there is less surface area in contact with the head, giving you a hotter running plug with the strong possibility of detonation. Again, not a good thing. Larry the MicroMong guy -- ________________________________________________________________________________
Date: Aug 20, 2006
There is a good reason that Kolb's don't have a nose wheel: they don't need one. I know, I checked. Here are a couple pictures I made this afternoon, went out to the hangar and pulled the MKIII nosewheel assembly off the wall and took a few pictures to convince the unbelievers. I attached it to the underside of the nosebowl, and I used the same screws that went through into the steel subframe and normally attach the nosebowl. Pitot & static air stuck out the front, with extensions coming up through the nosebowl to attach the lines to. Didn't steer, didn't figure it needed to, just wanted it to track straight ahead. I made this when I first built the MKIII, and mostly it was because I was using a 532 that I was unsure of, out of a 750' airstrip. So when I got to the top of the hill, I locked the brakes, began to advance the throttle, and gave it a little forward stick. It obediently rocked up on the nosewheel, I went to full throttle and let'er howl for about 25 seconds. Figured if she was gonna' blow, give it a good chance to do it on the ground and not over the creek. Then release the brakes, ease back on the stick, and I was off, having departed in a tricycle gear MKIII. After the engine got about twenty hours on it, I decided the engine was trustworthy (or at least to the extent that a 532 is ever trustworthy) & took the nosegear off. I did miss the wise cracks though. "Is it a nose dragger or a tail dragger?" "I dunno, I'm still trying to decide..., maybe a few more hours..." Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=55937#55937 Attachments: http://forums.matronics.com//files/p1000749_medium_369.jpg http://forums.matronics.com//files/p1000748_medium_152.jpg http://forums.matronics.com//files/p1000746_medium_108.jpg ________________________________________________________________________________
Date: Aug 20, 2006
I owned and flew an S12XL for over two years. The empennage issue was addressed and for older models they have a retrofit fix. The cage structure is probably not as strong as a Kolb... the pilot is a lot more vulnerable in the RANS. The S12XL flies wonderfully. If you fly it solo, you can get away with a 503, but for 2-up, you'll need at least a 582, and a 912 would be much, much better. Compared to a Kolb MkIII, the overall mass of the S12XL feels heavier, but the flight controls are about the same. The S12XL cockpit/seat was a bit more comfortable than the Kolb I have, so I'm trying to figure out how to improve that element. I now own a MkIIIc with a 912S. If I had to have a tricycle gear aircraft, it would definitely be the S12XL. But I have my tailwheel endorsement and the Kolb, in my opinion, is a better aircraft, by just a bit. -- Robert On 8/20/06, John Hauck wrote: > > > | It is a capable aircraft and is also well supported by the folks at > Rans. The S-12 also features a chrome moly steel cage in its > structure. > | > | Best Regards > | Carlos Grageda > | Firestar II > > Carlos: > > Best check out the Rans S-12 fuselage. I think you will find their > 4130 fuselage is actually a 4130 tube shallow tub. Look closely and > you will see that all upright tubes are aluminum. Most of the > accident photos I have seen involving RANS S-12's results in this part > of the fuselage failing down and forward on top of the pilot and > passenger. > > Having never flown an S-12, can not comment on its flying > characteristics. > > However, I have heard some of the earlier Rans S12's had a problem > with empennage stability. > > john h > mkIII > > ________________________________________________________________________________
Date: Aug 20, 2006
The Fergy I saw looked more like a Mark II than a Mark III. I guess the Fergy "inventor" didn't make enough money to buy the Mark III or else there would be a new Fergy model. Who knows maybe he's saving up for an Xtra so there's still hope for a new Fergy design. ________________________________________________________________________________
Date: Aug 20, 2006
David, The thing that started this whole "question" thing of mine, relates to an article in the August 2006 issue of Ultralight Flying. The article, which is a full page, talks about the Fergy FX-4-2 a 2 seat LSA candidate. I've had several people answer my question and a couple that made me wish, I had closed my mouth. Thanks, bob >From: "David Key" <dhkey(at)msn.com> >Reply-To: kolb-list(at)matronics.com >To: kolb-list(at)matronics.com >Subject: Re: Kolb-List: Re: a question >Date: Sun, 20 Aug 2006 19:18:13 -0500 > > >The Fergy I saw looked more like a Mark II than a Mark III. I guess the >Fergy "inventor" didn't make enough money to buy the Mark III or else there >would be a new Fergy model. Who knows maybe he's saving up for an Xtra so >there's still hope for a new Fergy design. > > ________________________________________________________________________________
Date: Aug 20, 2006
Don't take it personally, no one means anything and appreciate the frankness. If anyone is keeping score they'll know I've ask my share of questions everyone else knew the answer to. Hey, I'd consider a Fergy if the price was dirt cheap. I think the used market for knock offs is very very weak so expect a huge depreciation if you buy one of these and factor it in from the get go. I've never heard someone say I've just got to have a Fergy because it looks just like a Mark II, an old discontinued Kolb design. ;-) Wait there are two Fergies Barnstormers now, they want 18k for them!!! Ok if they get 18k for those, I'm all wrong and I don't know what the hell I'm talking about. One guy has a 503 and he's asking 17.5!!! GET REAL, it's worth 7k. One thing for sure, if I was selling a Kolb now I'd put it in both the Kolb and Fergy categories. As for the nose wheel thing, I assume you haven't flown the Kolb tailwheel-fly it first, you'll love it and you'll get to be a cool tailwheel pilot. ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Date: Aug 21, 2006
Hi Richard, Why exactly should we offer up knowledge of cheap knock-offs? Last I looked, this is the KOLB list. As for 'crusty socks', now I know why my mouse acts funny. Thanks!! Ed in JXN MkII/503 (Real) ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Sunday, August 20, 2006 1:59 PM Subject: Re: Kolb-List: a question Oh please, "don't ask that question"? If this forum isn't for the dissemination of knowledge about Kolb aircraft or copies of it, what is its use? I admit I sometimes wonder if it's actually for the rantings of pre adolescent boys who haven't taken up masterbation yet, but that's just my take. Bob, ask away, you'll soon learn who has knowledge to share and who has crusty socks. On 8/20/06, BOB BROCKMAN wrote: I was not aware that there were certain questions that coludn't be asked. I saw the article in the August 2006 issue of Ultralight Flying and wanted to know how the two aicraft compare. The other people may have ripped of Kolb. I don't know. Thats not the question. I have read the information on this group for month's. Its good for the most part but, when one person gets bent out of shape over a question.... You are entitled to you opinion. bob ________________________________________________________________________________
Date: Aug 20, 2006
Could the answer be : because it is polite and doesn't cost a thing to be nice. The question was asked in innocence and really did not deserve a violent response. Guidance would have been much more productive. Just a thought! Larry, Oregon ----- Original Message ----- From: Ed Chmielewski To: kolb-list(at)matronics.com Sent: Sunday, August 20, 2006 10:22 PM Subject: Re: Kolb-List: a question Hi Richard, Why exactly should we offer up knowledge of cheap knock-offs? Last I looked, this is the KOLB list. As for 'crusty socks', now I know why my mouse acts funny. Thanks!! Ed in JXN MkII/503 (Real) ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Sunday, August 20, 2006 1:59 PM Subject: Re: Kolb-List: a question Oh please, "don't ask that question"? If this forum isn't for the dissemination of knowledge about Kolb aircraft or copies of it, what is its use? I admit I sometimes wonder if it's actually for the rantings of pre adolescent boys who haven't taken up masterbation yet, but that's just my take. Bob, ask away, you'll soon learn who has knowledge to share and who has crusty socks. On 8/20/06, BOB BROCKMAN wrote: I was not aware that there were certain questions that coludn't be asked. I saw the article in the August 2006 issue of Ultralight Flying and wanted to know how the two aicraft compare. The other people may have ripped of Kolb. I don't know. Thats not the question. I have read the information on this group for month's. Its good for the most part but, when one person gets bent out of shape over a question.... You are entitled to you opinion. bob ________________________________________________________________________________
Date: Aug 20, 2006
Some years back, I saw a number of Fergusons at Cartersville airport in Georgia. I went to a EAA or ultralight meeting (can't remember which) there were some negative comments about the Kolbs and sort of a jealous attitude toward the Ferguson. I asked a couple of questions and got put down. Anyway, I eventually chose the Kolb Classic Mk III, it flies very nice and I am quite proud of it. Is it better than some other airplanes? To me it is one of the very best for enjoying the beauty of flight and it seems very forgiving. Mine is not very fast, but it sure is pleasant. Vic in Sacramento ________________________________________________________________________________
Date: Aug 21, 2006
Hi Larry, Sorry if my response was percieved as 'violent'. (WTF??) Was meant as a direct answer. I don't see the need to inform on poser aircraft of which I have no knowledge. If that's too 'violent', so be it. I guess feel-good PC skills aren't my specialty - thank GOD! Must be the crusty mouse... Ed in JXN HTG MkII/503 ----- Original Message ----- From: Larry Cottrell To: kolb-list(at)matronics.com Sent: Monday, August 21, 2006 12:42 AM Subject: Re: Kolb-List: a question Could the answer be : because it is polite and doesn't cost a thing to be nice. The question was asked in innocence and really did not deserve a violent response. Guidance would have been much more productive. Just a thought! Larry, Oregon ----- Original Message ----- From: Ed Chmielewski To: kolb-list(at)matronics.com Sent: Sunday, August 20, 2006 10:22 PM Subject: Re: Kolb-List: a question Hi Richard, Why exactly should we offer up knowledge of cheap knock-offs? Last I looked, this is the KOLB list. As for 'crusty socks', now I know why my mouse acts funny. Thanks!! Ed in JXN MkII/503 (Real) ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Sunday, August 20, 2006 1:59 PM Subject: Re: Kolb-List: a question Oh please, "don't ask that question"? If this forum isn't for the dissemination of knowledge about Kolb aircraft or copies of it, what is its use? I admit I sometimes wonder if it's actually for the rantings of pre adolescent boys who haven't taken up masterbation yet, but that's just my take. Bob, ask away, you'll soon learn who has knowledge to share and who has crusty socks. On 8/20/06, BOB BROCKMAN wrote: I was not aware that there were certain questions that coludn't be asked. I saw the article in the August 2006 issue of Ultralight Flying and wanted to know how the two aicraft compare. The other people may have ripped of Kolb. I don't know. Thats not the question. I have read the information on this group for month's. Its good for the most part but, when one person gets bent out of shape over a question.... You are entitled to you opinion. bob s.com/Navigator?Kolb-List ________________________________________________________________________________
Date: Aug 21, 2006
Hi Team. I'm with you Larry. A smile and a kind word don't cost much!!! Happy Landings, Noel ----- Original Message ----- From: Larry Cottrell To: kolb-list(at)matronics.com Sent: Monday, August 21, 2006 4:42 PM Subject: Re: Kolb-List: a question Could the answer be : because it is polite and doesn't cost a thing to be nice. The question was asked in innocence and really did not deserve a violent response. Guidance would have been much more productive. Just a thought! Larry, Oregon ----- Original Message ----- From: Ed Chmielewski To: kolb-list(at)matronics.com Sent: Sunday, August 20, 2006 10:22 PM Subject: Re: Kolb-List: a question Hi Richard, Why exactly should we offer up knowledge of cheap knock-offs? Last I looked, this is the KOLB list. As for 'crusty socks', now I know why my mouse acts funny. Thanks!! Ed in JXN MkII/503 (Real) ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Sunday, August 20, 2006 1:59 PM Subject: Re: Kolb-List: a question Oh please, "don't ask that question"? If this forum isn't for the dissemination of knowledge about Kolb aircraft or copies of it, what is its use? I admit I sometimes wonder if it's actually for the rantings of pre adolescent boys who haven't taken up masterbation yet, but that's just my take. Bob, ask away, you'll soon learn who has knowledge to share and who has crusty socks. On 8/20/06, BOB BROCKMAN wrote: I was not aware that there were certain questions that coludn't be asked. I saw the article in the August 2006 issue of Ultralight Flying and wanted to know how the two aicraft compare. The other people may have ripped of Kolb. I don't know. Thats not the question. I have read the information on this group for month's. Its good for the most part but, when one person gets bent out of shape over a question.... You are entitled to you opinion. bob s.com/Navigator?Kolb-List ------------------------------------------------------------------------- ----- 18/08/2006 ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 28 Msgs - 08/20/06
Date: Aug 21, 2006
I usually dont answer to such as what has been posted on the Ferguson. J. Hawk was referring to my good buddy who has had two fergs and I gotta answer this as honestly as I can. I have probably more knowledge of this plane than most of you on the list (obviously). I am not going to defend the stealing of ideas but lets face it, if people hadnt stollen ideas, enhanced them, worked them out, we would only have one airplane available - the wright aircraft. Now, Ferg took an idea (which was originated by mr kolb and redesigned some of it, streamlined some of it and cheapened some of it. What he came out with was a light, well constructed similar aircraft. (many planes fold tails as the kolb). (many planes fold wings as the kolb). Now, my problem with the plane is it is structually unsound. I mean, when it crashes, it comes apart, litterly. The same thing happens to any plane that is mainly constructed with alum. (crash a challenger once -- whoa, toothpics). Now, this plane has gone through many changes and it does resemble a kolb but not that much. It has a different airfoil, wing built totally different; wing tips different; tail section IS different, folding design change; wider flatter fuse; many different things. I cannot for by any spread of the imagination say this looks like a kolb. It is a great flyer *(how many of you have actually flown one?) I have. It doesnt need a 912 to push it. Now, as I said earlier, I am not defending this company but they as you or any other person or company, has the right to build a plane. You have the right to take the best of all and make it the best for you. Look at most of the -- I will call them - plastic LSPs out there. Same mold. Same fuse, wing, tail. who stole it from whom? Quit this petty garbage of bad mouthing a plane expecially if you really dont have any knowledge on it! Get out there an check it out. If you like a plane buy it. It is your opinion that counts. You will always be welcome to fly next to my great Kolb SlingShot. My opinion. Thanks. Ted Cowan, Alabama ________________________________________________________________________________
Subject: Discussing other planes on the Kolb list.
Date: Aug 21, 2006
My opinion, I find nothing objectionable about discussing another companys planes as long as the discussion is kept in some way related to, and in comparison with Kolb planes. I believe competition is a good. We all like to get the most bang for our buck. I am of the opinion that Kolb has nothing to fear and much to gain by being compared with other companies and their products. A persons defensive attitude merely evidences his insecurity about the actual merits of the Kolb Company and their products. I believe a defensive attitude is a negative advertisement for Kolb. I believe telling the truth about Kolb planes AND about Kolbs competition is what the kolb list should be all about. The more I learn about Ferguson the better I like my Kolb. On Aug 20, 2006, at 2:13 AM, BOB BROCKMAN wrote: > Being a new guy, my question is concerning an aircraft similar to a > Kolb. > Can anyone tell me about an airplane called the Ferguson FX -4-2? > I would appreciate any comments regarding the aircraft. > > thanks, > > bob > http://www.matronics.com/Navigator?Kolb-List_- > ============================================================ _- > forums.matronics.com_- > ============================================================ _- > ============================================================ _- > contribution_- > =========================================================== ________________________________________________________________________________
Date: Aug 21, 2006
"what does a flashing red light mean?" then you shouldn't be allowed to go to the book. But if the question asks "How much time do you have to report an accident?" then you should since in the "real world" you'd have time . I haven't taken my practical test yet - plan to within the next month >> Hi , Point taken. Good luck with the test. Cheers Pat -- ________________________________________________________________________________
Date: Aug 21, 2006
Subject: Re: 42 Practical test standards
Date: Aug 21, 2006
Pat, when you have time, would you please post a brief review of the test you took. that you are comparing to the S.P. test, I would be interested in the differences.>> Hi Lanny, I was not `having a go`,or comparing your test with anything which we have here and I respect you for undertaking such a task, I was referring to the general dumbing down process we have here. I know that when I took exams either at or just after leaving school (we are talking the forties here) it was expected that the examinee produced an answer to a question from his memory. Later this changed to questions to which the examinee could choose from 3 or more supplied answers. With a one in three chance of being right even if you had never studied the subject student passes increased. Reflecting great credit on the teachers, who, surprise, surprise, had pushed for the change. Being able to look up the answers during an exam seemed on the face of it just another step in the watering down process. In the UK it is government policy that everyone should be able to go to University. They built Universities and then had to fill them so they lowered the standards. They deny this of course but that is what most people believe. Consequently instead of Universities taking the educated cream of the crop and educating them further, free, which I believe should be the way, they now take many who do not have the ability or the application to benefit from the opportunity and make them pay. Many leave before completion of their courses and many take soft options like media studies, social studies and the like and finish up with a degree as a social worker. Lord help us. Engineers, chemists, science based courses are way down the list. The tests here for an ultralight license are pretty much the same as for a PPL. A flying test, meteorology, air law, etc.Its all a long time ago and like the car drivers test which I took at 18, I would not like to have to do it again.. A radio license is an option and you are illegal if you operate one (even a hand held) without having passed the test Cheers Pat. -- ________________________________________________________________________________
Date: Aug 21, 2006
From: "Dave & Eve Pelletier" <pelletier(at)cableone.net>
Subject: Emailing: HPIM0907, HPIM0908, HPIM0909, HPIM0910, HPIM0912
Date: Aug 21, 2006
Guys, Here are some pics of my little invention - "The Spider." Best control lock I've seen yet. When in place and tightened, it feels like the control stick is welded in place. The MV guys liked it and some copied it. Someone modified the design but the modification didn't work as well as the original (heh, heh, heh - sorry, I couldn't resist.) I works a lot better than a seat belt and just takes a minute more to install. If you make one, a key point is to cut a groove in the PVC at each place the rings go, otherwise the rings will tend to flop over. If you make both the fore and aft straps adjustable, then you can set the elevator where you want it, up or down. Mine isn't adjustable so the elevator is locked in neutral. One of these days I'll change forward strap to an adjustable one. AzDave Aw what the hell, go ahead an archive. ________________________________________________________________________________
Date: Aug 21, 2006
Subject: Re: Emailing: HPIM0907, HPIM0908, HPIM0909, HPIM0910, HPIM0912
Dave -- You should use standard stainless steel plumbers straps and then you could use this D-Ring Bracket: http://scubagear.stores.yahoo.net/004136.html With the D-Ring Bracket, you not only will not "capture" the d-ring (i.e., it will move freely), but you won't risk hurting the PVC. I use these in diving all the time. -- Robert On 8/21/06, Dave & Eve Pelletier wrote: > > > Guys, > > Here are some pics of my little invention - "The Spider." Best control > lock I've seen yet. When in place and tightened, it feels like the control > stick is welded in place. The MV guys liked it and some copied it. Someone > modified the design but the modification didn't work as well as the original > (heh, heh, heh - sorry, I couldn't resist.) I works a lot better than a > seat belt and just takes a minute more to install. If you make one, a key > point is to cut a groove in the PVC at each place the rings go, otherwise > the rings will tend to flop over. If you make both the fore and aft straps > adjustable, then you can set the elevator where you want it, up or down. > Mine isn't adjustable so the elevator is locked in neutral. One of these > days I'll change forward strap to an adjustable one. > > AzDave > > Aw what the hell, go ahead an archive. > ________________________________________________________________________________
Date: Aug 21, 2006
Great idea. Simple and easy to pack into a small space. I'm going to make one and keep it stowed in my KXP. Thanks for the info. -------- Roger in Oregon 1992 KXP 503 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56199#56199 ________________________________________________________________________________
Subject: Almost Done!!
Date: Aug 21, 2006
Almost done the DAR can't see it till Sept 8th!! I wanted to do the first flight labor day. The pic was huge (1.6meg), I shrunk it down and saved it as a .GIF (300k) hope that worked. John W. came by and took a look a while ago. Everything was going smoothly for the first 5 minutes, then he ask me to give him a note pad and leave the hangar while he stayed and inspected my plane. 90 minutes later he had 65 things to do better!!! I'm done with his list, greatfull for it, and ready to fly. ________________________________________________________________________________
Date: Aug 21, 2006
Subject: Re: Almost Done!!
That is a pretty airplane...congrats ________________________________________________________________________________
Date: Aug 21, 2006
David that is one beautiful plane. Bravo. On 8/21/06, David Key wrote: > > Almost done the DAR can't see it till Sept 8th!! I wanted to do the first > flight labor day. The pic was huge (1.6meg), I shrunk it down and saved it > as a .GIF (300k) hope that worked. > > John W. came by and took a look a while ago. Everything was going smoothly > for the first 5 minutes, then he ask me to give him a note pad and leave > the > hangar while he stayed and inspected my plane. 90 minutes later he had 65 > things to do better!!! I'm done with his list, greatfull for it, and ready > to fly. > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 22, 2006
Re: DAR's list of things to do. What sort of things were mentioned? It might be helpful for all of us Kolb pilots. ________________________________________________________________________________
From: "Ralph Hoover" <flht99reh(at)columbus.rr.com>
Date: Aug 22, 2006
Dave, that is one heck of a sturdy stick holder. I gotta ask, however, how hard is the adjustments to make while in flight? That is a poor mans auto-pilot, is it not? Ha, Ha! Why a man would have to be mighty skinny to fit between some of them belts and adjusting in flight would be scary, but some of you guys can "fly and chew gum" at the same time. I keep biting my lip! Ralph gotcha right here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56375#56375 ________________________________________________________________________________
Date: Aug 22, 2006
David, My Firestar will be parked outside you house for the next several months. Do you think you can make it look that purty? There are some fantastic flying machines on this site and yours is at the top. I too want to see better quality photo's and some details of the cabin. Ohio Ralph Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56376#56376 ________________________________________________________________________________
Subject: Re: Discussing other planes on the Kolb list.
Date: Aug 22, 2006
Eugene, "The more I learn about Ferguson the better I like my Kolb. " I believe one of the posters on this site says the same thing about people and his dog! Ha,Ha. Man, seriously, some of these people need to sit down with their shrink and discuss what is really bothering them. I think they could walk away a lot less troubled and a little nicer to their fellow man. I have discovered in my few short 61 years of life, we need all the friends and people on our side we can get in this world. Its shrinking day by day! My old enemy's are coming back around. And some of them have become my friends. I'm not certain if I changed since then or they have. Ralph, hiding somewhere in Ohio. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56380#56380 ________________________________________________________________________________
Subject: 912ULS Gearbox Checkup
Date: Aug 22, 2006
Hi Gang: Flew down to South Mississippi Light Aircraft this morning to have the gearbox inspected. Passed with flying colors. No wear after more than 1,200.0 hours. In fact, we could not shim it up any tighter than it was approximately 450 hours ago when I had the slip clutch installed. Bearings and gears looked new. Flew 360 sm in 3.9 hours. Not bad for a 15 year old fat ultralight. Take care, john h mkIII ________________________________________________________________________________
Date: Aug 22, 2006
Subject: One of them dreaded questions
I'm currently in California getting my LSA repairman maintenance rating. This afternoon we were doing some fabric work and the instructor pulled out a wing from a crashed Ultrastar. My first reaction when looking at the wing root fittings was shock. Compared to my Mk III and Firestar it seemed the swivel and the spar follow through fitting had been installed backward. Donnie at TNK couldn't answer my question (you don't have TNK on speed dial?) and we both agreed if anyone could it would be John H. After some reflection I think everything might be per Homer, but I'm still interested in learning the answer. Thanks guys, Rick -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: One of them dreaded questions
Rick... I'm not sure this is what you're asking about, but the Ultrastar wing pivot s on the front fitting, not the rear fitting like all the other Kolbs do... David On 8/22/06, Richard Girard wrote: > > I'm currently in California getting my LSA repairman maintenance rating. > This afternoon we were doing some fabric work and the instructor pulled o ut > a wing from a crashed Ultrastar. My first reaction when looking at the wi ng > root fittings was shock. Compared to my Mk III and Firestar it seemed the > swivel and the spar follow through fitting had been installed backward. > Donnie at TNK couldn't answer my question (you don't have TNK on speed > dial?) and we both agreed if anyone could it would be John H. After some > reflection I think everything might be per Homer, but I'm still intereste d > in learning the answer. > > Thanks guys, > Rick > > -- > Rick Girard > "Ya'll drop on in" > takes on a whole new meaning > when you live at the airport. > > -- "Attitude is everything ~ pick a good one"... ________________________________________________________________________________
Date: Aug 22, 2006
Rick... I forgot, there's some pictures here of the folded Ultrastar wing... *www.frugalbee.com/.../body_kolb_ultrastar.html*<http://www.frugalbee.com/. ../body_kolb_ultrastar.html> David On 8/22/06, Richard Girard wrote: > > I'm currently in California getting my LSA repairman maintenance rating. > This afternoon we were doing some fabric work and the instructor pulled o ut > a wing from a crashed Ultrastar. My first reaction when looking at the wi ng > root fittings was shock. Compared to my Mk III and Firestar it seemed the > swivel and the spar follow through fitting had been installed backward. > Donnie at TNK couldn't answer my question (you don't have TNK on speed > dial?) and we both agreed if anyone could it would be John H. After some > reflection I think everything might be per Homer, but I'm still intereste d > in learning the answer. > > Thanks guys, > Rick > > -- > Rick Girard > "Ya'll drop on in" > takes on a whole new meaning > when you live at the airport. > > -- "Attitude is everything ~ pick a good one"... ________________________________________________________________________________
Date: Aug 22, 2006
David, Like I said, I figured it was per Homer even though it looked so odd at first glance. Just trying to expand my knowledge base. The link doesn't work, but thanks for responding. On 8/22/06, David Lehman wrote: > > Rick... > > I forgot, there's some pictures here of the folded Ultrastar wing... > > *www.frugalbee.com/.../body_kolb_ultrastar.html*<http://www.frugalbee.com /.../body_kolb_ultrastar.html> > > David > > > On 8/22/06, Richard Girard wrote: > > > > I'm currently in California getting my LSA repairman maintenance rating . > > This afternoon we were doing some fabric work and the instructor pulled out > > a wing from a crashed Ultrastar. My first reaction when looking at the wing > > root fittings was shock. Compared to my Mk III and Firestar it seemed t he > > swivel and the spar follow through fitting had been installed backward. > > Donnie at TNK couldn't answer my question (you don't have TNK on speed > > dial?) and we both agreed if anyone could it would be John H. After som e > > reflection I think everything might be per Homer, but I'm still interes ted > > in learning the answer. > > > > Thanks guys, > > Rick > > > > -- > > Rick Girard > > "Ya'll drop on in" > > takes on a whole new meaning > > when you live at the airport. > > > > > > > -- > "Attitude is everything ~ pick a good one"... > > * > =========== =========== =========== =========== =========== > > * > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: Matt Dralle, List Admin.
Date: Aug 23, 2006
Matt, Are you aware that some reply messages sent to this Kolb list are not being posted to the list for some reason? ? ? ? ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: Matt Dralle, List Admin.
At 05:34 AM 8/23/2006 Wednesday, you wrote: > >Matt, > >Are you aware that some reply messages sent to this Kolb list are not >being posted to the list for some reason? > >? ? ? Can you forward me so examples off-list. I'm not finding any posts from your email address "etzim62(at)earthlink.net" that haven't been posted. Matt Dralle Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Aug 23, 2006
Date: Aug 23, 2006
Here'e the correct link http://www.frugalbee.com/Kolb_Ultrastar/fold4686.JPG >I forgot, there's some pictures here of the folded Ultrastar wing... >www.frugalbee.com/.../body_kolb_ultrastar.html ________________________________________________________________________________
From: Kirby Dennis Contr MDA/AL <Dennis.Kirby(at)kirtland.af.mil>
Subject: Ground Loop
Date: Aug 23, 2006
Dear Kolb Friends - In the spirit of sharing one's misfortunes for the benefit of others, I offer this story that happened to me earlier this summer. I experienced my first ground loop! Following a normal warmup and taxi to the runway, I was ready to take the active and go. The wind was directly across the runway from the left, at approx 10 knots (45-degree droop angle on the windsock at our airport). Not unusual; I've done 12-to-15 knot crosswind takeoffs many times before in my Kolb. Three seconds after giving it full power, I glanced back at the windsock. Horror! It was rigidly horizontal. In the next second, I felt the violent gust hit my Mark-III, which instantly pivoted 90 degrees to the left as we weathervaned into the wind. (Which I found out later was a 32-knot gust, as recorded at our airports DigiWx system.) The instantaneous result was, due to the sudden turn, the left wheel came up and the right wingtip dragged on the ground - the classic ground loop. Whee! Back at the hangar, and following VERY close inspection, the only damage that resulted was torn fabric on the aileron tip, at the aft/outboard corner. Hinge line is straight, trailing edge spar is straight, every member of the aileron structure is straight. No damage except for fabric. Gotta love the robust design of these Kolbs! I've since repaired the fabric and have flown my Mark-III - no problems. I like to think I learned something worthwhile from the experience that's worth passing on to you all. For this scenario, I should have waited 15 or 20 minutes before launching, as there were scattered rain clouds in the area; one, particularly close to the airport. The aberrant gust that got me was from one localized cell that was within 5 miles of the airport. Although clear skies beckoned in the other direction, I should have let that little rain cloud pass over the airport, rather than try to get out ahead of it. And so, Pat L and Ohio Ralph (recently), and all you other Kolbers with similar past histories of battle damage (Muncho Lake comes to mind), it is with honor that I join your esteemed ranks. But like Hauck once said: "You can't break 'em if you don't fly 'em!" Dennis Kirby Mark-III, 912ul, "Magic Bike" Cedar Crest, New Mexico http://www.w3.org/TR/REC-html40">
Dear Kolb Friends –
In the spirit of sharing one’s misfortunes for the benefit of others, I offer this story that happened to me earlier this summer.  I experienced my first ground loop!
Following a normal warmup and taxi to the runway, I was ready to take the active and go.  The wind was directly across the runway from the left, at approx 10 knots (45-degree droop angle on the windsock at our airport).  Not unusual; I’ve done 12-to-15 knot crosswind takeoffs many times before in my Kolb.
The instantaneous result was, due to the sudden turn, the left wheel came up and the right wingtip dragged on the ground – the classic ground loop.  Whee!
I’ve since repaired the fabric and have flown my Mark-III – no problems.  I like to think I learned something worthwhile from the experience that’s worth passing on to you all.  For this scenario, I should have waited 15 or 20 minutes before launching, as there were scattered rain clouds in the area; one, particularly close to the airport.  The aberrant gust that got me was from one localized cell that was within 5 miles of the airport.  Although clear skies beckoned in the other direction, I should have let that little rain cloud pass over the airport, rather than try to get out ahead of it.
And so, Pat L and Ohio Ralph (recently), and all you other Kolbers with similar past histories of battle damage (Muncho Lake comes to mind), it is with honor that I join your esteemed ranks.  But like Hauck once said:  “You can’t break ‘em if you don’t fly ‘em!”
Dennis Kirby
Mark-III, 912ul, “Magic Bike”
Subject: Re: Ground Loop
Date: Aug 23, 2006
Yah, but you broke yours the easy way. Good on you, Dennis, it could have been a lot worse. Lar. Do not Archive. ----- Original Message ----- From: Kirby Dennis Contr MDA/AL To: kolb-list(at)matronics.com Sent: Wednesday, August 23, 2006 2:23 PM Subject: Kolb-List: Ground Loop Dear Kolb Friends ' In the spirit of sharing one=92s misfortunes for the benefit of others, I offer this story that happened to me earlier this summer. I experienced my first ground loop! Following a normal warmup and taxi to the runway, I was ready to take the active and go. The wind was directly across the runway from the left, at approx 10 knots (45- ________________________________________________________________________________
Date: Aug 23, 2006
I'm at a loss for words..... BB On 23, Aug 2006, at 2:51 PM, George Myers wrote: > > ________________________________________________________________________________
Date: Aug 23, 2006
Yes Dennis, you are one of the most highly esteemed out there. I am glad very little damage was done and you jumped back in the saddle again. I do not like the "double edged" problem we have with these planes. If you add enough weight to keep them down along the ground, they never get the hankerin to get off the ground. On mine, I am getting the IVO prop late this week, making a breather line like "Plaincrazzy" made, need to make a new gap seal out of Lexan. Then tie the tail, crank it up and see if anything comes off or vibrates loose. Also, I need to make a new sissy bar system. The old one most assuradly saved me considerable bucks and repair. I ain't leaven home again without one! Probably two to three weeks before I get back up. Mornings and evenings are in the 50's and 60's here in Ohio. Hate to miss that cool air. I know thsi is a tad away from the Kolb info, but you did use the John H. name and I felt we could all use a laugh. Look at picture below. And NO, IT AINT A KOLB! Sorry about hurtin feelins. Ohio Ralph, cantankerous as all get out here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56807#56807 Attachments: http://forums.matronics.com//files/120624_dl1_medium_149.jpg ________________________________________________________________________________
Date: Aug 23, 2006
Yes Dennis, you are one of the most highly esteemed out there. We need to have some special badge or patch for those "hardy young men" in their flying machines! I am glad very little damage was done and you jumped back in the saddle again. I do not like the "double edged" problem we have with these planes. If you add enough weight to keep them down along the ground, they never get the hankerin to get off the ground. On mine, I am getting the IVO prop late this week, making a breather line like "Plaincrazzy" made, need to make a new gap seal out of Lexan. Then tie the tail, crank it up and see if anything comes off or vibrates loose. Also, I need to make a new sissy bar system. The old one most assuradly saved me considerable bucks and repair. I ain't leaven home again without one! Probably two to three weeks before I get back up. Mornings and evenings are in the 50's and 60's here in Ohio. Hate to miss that cool air. I know this is a tad away from the Kolb info, but you did use the John H. name and I felt we could all use a laugh. Look at picture below. And NO, IT AINT A KOLB! Sorry about hurtin feelins. Ohio Ralph, cantankerous as all get out here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56811#56811 ________________________________________________________________________________
Date: Aug 23, 2006
Yes Dennis, you are one of the most highly esteemed out there. We need to have some special badge or patch for those "hardy young men" in their flying machines! I am glad very little damage was done and you jumped back in the saddle again. I do not like the "double edged" problem we have with these planes. If you add enough weight to keep them down along the ground, they never get the hankerin to get off the ground. On mine, I am getting the IVO prop late this week, making a breather line like "Plaincrazzy" made, need to make a new gap seal out of Lexan. Then tie the tail, crank it up and see if anything comes off or vibrates loose. Also, I need to make a new sissy bar system. The old one most assuradly saved me considerable bucks and repair. I ain't leaven home again without one! Probably two to three weeks before I get back up. Mornings and evenings are in the 50's and 60's here in Ohio. Hate to miss that cool air. I know this is a tad away from the Kolb info, but you did use the John H. name and I felt we could all use a laugh. Look at picture below. And NO, IT AINT A KOLB! Sorry about hurtin feelins. Ohio Ralph, cantankerous as all get out here in Ohio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56812#56812 ________________________________________________________________________________
Date: Aug 23, 2006
| I know thsi is a tad away from the Kolb info, but you did use the John H. name and I felt we could all use a laugh. | | Ohio Ralph, cantankerous as all get out here in Ohio! Ralph/Gang: Gosh! I didn't know John Deere made an airplane that looks like a Titan. john h mkIII (Strictly Kolb, with a tad of Hauck thrown in.) PS: Just now got home, after dark, from dragging the airstrip for mines. Darn cows have been working overtime. I hit one when I landed yesterday on return from Ronnie Smith's. Thought I had not done much damage, until I got out, and the bottom of the fuselage is covered with cow crap................... ________________________________________________________________________________
Subject: Re: ebay firestar?
Date: Aug 23, 2006
| Does anyone recognize this bird? It looks like the Fuse cage has been | hacked up, doesn't look too safe.. | | Mike Mike/Gang: That's a Twinstar with an add on wind screen. Not hacked up.. Wasn't much up front to begin with. john h mkIIII ________________________________________________________________________________
Subject: anyone know anything about this one?
Date: Aug 23, 2006
http://cgi.ebay.com/Home-Built-Ultralight-Plans-build-your-airplane-3000_ W0QQitemZ200019729570QQihZ010QQcategoryZ26441QQssPageNameZWDVWQQrdZ1QQcmd ZViewItem ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: anyone know anything about this one?
Well, it looks like a ripoff of a couple of popular designs, the Flightstar, for one. Ask yourself if you can get it built and inspected by Jan 31, 2008 if you want to fly it as an LSA. After that, it'll be a very expensive lawn ornament, unless you want to license it as amateur built experimental. On 8/23/06, ron wehba wrote: > > > http://cgi.ebay.com/Home-Built-Ultralight-Plans-build-your-airplane-3000_W0QQitemZ200019729570QQihZ010QQcategoryZ26441QQssPageNameZWDVWQQrdZ1QQcmdZViewItem > > * > > > * > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 23, 2006
_____ From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, August 23, 2006 9:53 PM Subject: Re: Kolb-List: anyone know anything about this one? Well, it looks like a ripoff of a couple of popular designs, the Flightstar, for one. Ask yourself if you can get it built and inspected by Jan 31, 2008 if you want to fly it as an LSA. After that, it'll be a very expensive lawn ornament, unless you want to license it as amateur built experimental. On 8/23/06, ron wehba wrote: http://cgi.ebay.com/Home-Built-Ultralight-Plans-build-your-airplane-3000_W0Q QitemZ200019729570QQihZ010QQcategoryZ26441QQssPageNameZWDVWQQrdZ1QQcmdZViewI tem http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com http://wiki.matronics.com -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: Kolb Serial Numbers
Date: Aug 23, 2006
Does anyone know the significance of the number stamped on the rear of the root tube on the Mark 3. Are they serial numbers? Are the numbers in series? Did they start at 1? What was the last one sold from Old Kolb in Pennsylvania? Just curious Steven Green Mark III # 1151 ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: Kolb Serial Numbers
Mine was very close to being the last one, if not the last to come from Phoenixville, Pa. I got the three airframe kits from Pa, but got the enclosure and the motor mounts from New Kolb in Ky, so I was in the transition. When I heard about the sale and transition, my first reaction was to wonder how things were going to work out, but New Kolb treated me good. I bought it on March 14, 1995, all three kits, including the Sun-N'-Fun promotion of all the ribs pre-built for the bargain price of $6,765. (Airframe only, I already had an engine and instruments) The number on the end of the root tube is M3-215. Richard Pike MKIII N420P (420ldPoops) Steven Green wrote: > > Does anyone know the significance of the number stamped on the rear of > the root tube on the Mark 3. Are they serial numbers? Are the > numbers in series? Did they start at 1? What was the last one sold > from Old Kolb in Pennsylvania? > > Just curious > > Steven Green > Mark III # 1151 > * > > > * ________________________________________________________________________________
Subject: Re: 912ULS Gearbox Checkup
Date: Aug 22, 2006
On Aug 22, 2006, at 7:35 PM, John Hauck wrote: > Flew 360 sm in 3.9 hours. Not bad for a 15 year old fat ultralight. Wow! That is an average of 92.3 mph. Twenty mph tail wind both ways? Or did you mean 4.9 hours? ________________________________________________________________________________
Date: Aug 23, 2006
John, I have put fully synthetic oil in my 912. I want to do xc's and plan on using more 100LL than I'd planned. Next time I change my oil can I just fill the tank up with semi-synthetic or do I need to empty all the fully synthetic out of the radiator and hoses and tank then refill everything with semi? Thanks, David >From: "John Hauck" <jhauck(at)elmore.rr.com> >Reply-To: kolb-list(at)matronics.com >To: >Subject: Re: Kolb-List: ebay firestar? >Date: Wed, 23 Aug 2006 20:12:48 -0500 > > >| Does anyone recognize this bird? It looks like the Fuse cage has >been >| hacked up, doesn't look too safe.. > | >| Mike > >Mike/Gang: > >That's a Twinstar with an add on wind screen. > >Not hacked up.. Wasn't much up front to begin with. > >john h >mkIIII > > ________________________________________________________________________________
Date: Aug 23, 2006
Not hard to do cruising 85 to 90 mph! Actually, I did have a little help from the wind going and coming. -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56883#56883 ________________________________________________________________________________
Date: Aug 23, 2006
I wanted to use exhaust header wrap near the electricial components on the engine. As I understand the Rotax 921 EGT runs normally at 1472, maxing out at 1652. As I check the diffrent exhaust wraps it seems they only goes to continuous of 1000. For example: http://cgi.ebay.com/ebaymotors/White-Fiberglass-Exhaust-Kart-Racing-Header-Wrap-15ft_W0QQcmdZViewItemQQcategoryZ107068QQihZ008QQitemZ180020610788QQrdZ1 Do I need to keep looking? Thanks, David ________________________________________________________________________________
Subject: 912 Oil
Date: Aug 23, 2006
Next time I change my oil can I just fill | the tank up with semi-synthetic or do I need to empty all the fully | synthetic out of the radiator and hoses and tank then refill everything with | semi? | Thanks, | David Hi David: I don't think so. I used to switch back and forth from full to semi-synthetic. Now that I cross country more the locally fly, I run Valvoline Durablend Semi-sythetic most all the time. Hot weather I run 20w50. Cold weather 5 or 10w40. Based on the condition of my gearbox during yesterday's inspection, I think my Durablend is doing a good job. john h mkIII PS: I changed the subject to reflect the content of this post. ________________________________________________________________________________
Date: Aug 24, 2006
In a message dated 8/23/2006 4:26:28 P.M. Central Standard Time, Dennis.Kirby(at)kirtland.af.mil writes: And so, Pat L and Ohio Ralph (recently), and all you other Kolbers with similar past histories of battle damage (Muncho Lake comes to mind), it i s with honor that I join your esteemed ranks. But like Hauck once said: =9CYou can=99 t break =98em if you don=99t fly =98em!=9D Dennis, Sorry to hear of you misfortune. Glad it wasn't worse. Ed Diebel Firefly # 62 Do Not Archieve ________________________________________________________________________________
Date: Aug 23, 2006
They went a little longer than that. I couldn't remember for sure, but I do know I got my kit from TOK, so dug out my sales invoice. It's dated 10-14-96 for Serial # M3-274. I went out with a flashlight just now, and the number on the end of the root tube is M1124. I've found the cause of my problems with the redrive, and have been fighting for 1 1/2 weeks with a local machine shop to build a spacer the way "I" want it........not the way they think they want to make it. "If" I can get that idiot to trim it to fit tomorrow, I could have Vamoose started again this weekend........but I won't bet on it. I go back to the guy for try #4 tomorrow. Unfortunately, he's the only game in town, and I've already paid him $110.00 for the thing......before I realized it wouldn't work. Grumble. Lar. ----- Original Message ----- From: "Richard Pike" <richard(at)bcchapel.org> Sent: Wednesday, August 23, 2006 7:50 PM Subject: Re: Kolb-List: Kolb Serial Numbers > > Mine was very close to being the last one, if not the last to come from > Phoenixville, Pa. I got the three airframe kits from Pa, but got the > enclosure and the motor mounts from New Kolb in Ky, so I was in the > transition. When I heard about the sale and transition, my first reaction > was to wonder how things were going to work out, but New Kolb treated me > good. > I bought it on March 14, 1995, all three kits, including the Sun-N'-Fun ________________________________________________________________________________
Subject: 912 Exhaust Wrap
Date: Aug 23, 2006
| | Do I need to keep looking? | Thanks, | David David: I bought my exhaust header wrap from Summit. Have no idea what the temperature rating was, but it worked for 5 years with no problems. I think any automotive header wrap will work just fine. Four stroke EGT's run very high. john h mkIII ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: 912 Exhaust Wrap
Date: Aug 24, 2006
I bought my exhaust header wrap from Summit. >> Hi , what is this, and what does it do? I have never heard of it. Chers Pat -- ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 33 Msgs - 08/23/06
Date: Aug 24, 2006
the picture of the John Deere published on the web site link is one of our members of the Southern Flyers Ultralight Asociation. His call sign is "flying farmer". Ted Cowan, Alabama. He has had a challenger and a Kolb Mk II. Hard to satisfy a farmer I guess. He has a Hearse engine on it and it is very underpowered. ________________________________________________________________________________
Subject: 2SI 690 L70
Date: Aug 24, 2006
Has any one ever installed a 2SI 3 cylinder in a MKIII? I have been looking at a MK III with a 503 which is great for solo but I know where I can get a low time 2SI three cylinder cheap. Where would I get the mount? I think there is a dealer in Southern Ill but I do not recall who it is or where they are located. Rev Chuck ________________________________________________________________________________
Date: Aug 24, 2006
One of the Titan exhaust tubes comes very close to the ignition modules on the 912UL and 912ULS. The exhaust header tube wrap helps protect the modules from the heat, especially on the ground. -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56947#56947 ________________________________________________________________________________
Date: Aug 24, 2006
On Aug 24, 2006, at 7:12 AM, pat ladd wrote: > > Hey Pat, Is that a question or a statement? ________________________________________________________________________________
Date: Aug 24, 2006
| the picture of the John Deere published on the web site link is one of our | members of the Southern Flyers Ultralight Asociation. Ted C: Is that Doyle L? john h mkIII ________________________________________________________________________________
Date: Aug 24, 2006
On Aug 24, 2006, at 7:38 AM, tc1917 wrote: > He has a Hearse engine on it and it is very underpowered. Do that mean it will take longer to get to the grave site? ________________________________________________________________________________
Subject: Re: 2SI 690 L70
Date: Aug 24, 2006
Rev Chuck you are thinking of ZDE ....in flatrock illinois Roger Zerkle Roger Zerkle E-mail Address(es): zde(at)frtci.net He supports the 2SI engines and has lots of parts. If you need anything, I have several also..including an new/unused 0-time 690L engine. These engines have been installed on MK-III kolbs...( wake up Dennis)and a brother right here on this list. Tell Zerkle Honda Don sent ya! -------- Don G FireFly#098 http://www.geocities.com/dagger369th/my_firefly.htm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=57092#57092 ________________________________________________________________________________
Date: Aug 24, 2006
Yes Don I am talking about ZDE. Do you recall their website? Thanks I forgot their name. what parts do you have? Is your 690L new or rebuilt? How much? I would be looking for anyting that I need to make it work. Also is it a good choice motor for Kolb MK III? I hear good things aboiut this motor from those who has used them. Rev Chuck ----- Original Message ----- From: "Don G" <donghe@one-eleven.net> Sent: Thursday, August 24, 2006 4:50 PM Subject: Kolb-List: Re: 2SI 690 L70 > > Rev Chuck > > you are thinking of ZDE ....in flatrock illinois > > Roger Zerkle > > Roger Zerkle > E-mail Address(es): > zde(at)frtci.net > > He supports the 2SI engines and has lots of parts. > If you need anything, I have several also..including an new/unused 0-time > 690L engine. > > These engines have been installed on MK-III kolbs...( wake up Dennis)and a > brother right here on this list. > > Tell Zerkle Honda Don sent ya! > > -------- > Don G > FireFly#098 > > http://www.geocities.com/dagger369th/my_firefly.htm > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=57092#57092 > > >
July 31, 2006 - August 25, 2006
Kolb-Archive.digest.vol-gf
