Kolb-Archive.digest.vol-gu
July 03, 2007 - July 19, 2007
      and the pilots don't need proof of training. This in itself will pose a safety
      issue for an airport. I'm sure we will be hearing more about this issue after
      the deadline.
      Ralph B
      Ralph B
      Original Firestar
      20 years flying it
      http://forums.matronics.com/viewtopic.php?p=121964#121964
Subject: Federal Funding
Date: Jul 03, 2007
How does some one determine if a field has received or is receiving federal funding ? Is there a list of fields some place for the public to review?? Mark -----Original Message----- From: Jim Dunn <jim@tru-cast.com> Subject: Re: Kolb-List: Re: Kolb Firefly Per FAA Order 8700.1 Dated 2/9/1996, Chapter 62: In short, if they received federal funds they are supposed to permit Ultralight activity, but they can deny UL if mixing cannot be done safely. Advisory Circular 150/5190-5 of June 10, 2002 is specifically on exclusions. I doubt LAX permits ULs, and rightfully so. 7. OPERATION OF ULTRALIGHT VEHICLES FROM AIRPORTS. A. Aeronautical Activity. Ultralight vehicle operators usually require the approval of airport authorities before conducting operations from an airport. Operation of ultralight vehicles is considered an aeronautical activity much the same as parachute jumping. B. Use of Airports. Federally funded airports must accommodate ultralight operations if this can be done safely. This does not mean that airport authorities must allow ultralights to operate from the runways; rather, the airport should set aside a special location for ultralight operations. It is acceptable for airport authorities to establish policies, including reasonable training requirements, that they believe are necessary to provide safe accommodations to ultralight vehicles. If an airports authorities believe it is unsafe to accommodate ultralights at the facility, they may request Flight Standards input in the assessment of the safety of proposed operations. (1) When assessing the safety of ultralight vehicle operations from airports, the inspector should bear in mind the operating characteristics of ultralight vehicles, the lack of pilot certification standards, and the fact that these vehicles must yield right-of-way to aircraft under all circumstances. If the safety of conventional aircraft operations would be compromised, the inspector should give a negative finding to the Airports Division. When possible, inspectors should assist in developing alternative methods to accommodate ultralight operations. (2) Nonfederally funded airports are not required to accommodate ultralight operations. The FAA has no authority in these situations; however, inspectors should encourage ultralight operators and airport management to consider alternative methods. ----------------------------------------- Ive always heard that if an airport recieves any form of assistance from the gov. in the form of money, they can not disallow any one , who is legal, the priviledge of landing there! Is that the case or not??? ________________________________________________________________________ from AOL at AOL.com. =0 ________________________________________________________________________________
Date: Jul 03, 2007
Subject: Re: Federal Funding
By default, any airport designated as public is required to allow any aircraft to use it's services. This includes ultralights. (If a private airport, designated for public use, has never taken federal or state funding, then they have the right to deny services, but how will you know until you land there?) If a public airport owner can make a case to the FAA to disallow certain aircraft for particular reasons, then portions of or all services can be denied. That information, as far as I understand it, is supposed to be published in the AFD (Airport/Facility Directory) for public use airports, so, if you're at all concerned, then refer to the AFD for the airport you're interested in. -- Robert On 7/3/07, Mark Vaughn wrote: > > How does some one determine if a field has received or is receiving > federal funding ? > > > Is there a list of fields some place for the public to review?? > > > Mark > > > -----Original Message----- > > > From: Jim Dunn <jim@tru-cast.com> > > > To: kolb-list(at)matronics.com > > > > > Subject: Re: Kolb-List: Re: Kolb Firefly > > > Per FAA Order 8700.1 Dated 2/9/1996, Chapter 62: > > > In short, if they received federal funds they are supposed to permit > > > Ultralight activity, but they can deny UL if mixing cannot be done > safely. > > > Advisory Circular 150/5190-5 of June 10, 2002 is specifically on > > > exclusions. I doubt LAX permits ULs, and rightfully so. > > > 7. OPERATION OF ULTRALIGHT VEHICLES > > > FROM AIRPORTS. > > > A. Aeronautical Activity. Ultralight vehicle operators > > > usually require the approval of airport authorities before > > > conducting operations from an airport. Operation of > > > ultralight vehicles is considered an aeronautical activity > > > much the same as parachute jumping. > > > B. Use of Airports. Federally funded airports must > > > accommodate ultralight operations if this can be done safely. > > > This does not mean that airport authorities must allow > > > ultralights to operate from the runways; rather, the airport > > > should set aside a special location for ultralight operations. > > > It is acceptable for airport authorities to establish policies, > > > including reasonable training requirements, that they believe > > > are necessary to provide safe accommodations to ultralight > > > vehicles. If an airport's authorities believe it is unsafe to > > > accommodate ultralights at the facility, they may request > > > Flight Standards' input in the assessment of the safety of > > > proposed operations. > > > (1) When assessing the safety of ultralight vehicle > > > operations from airports, the inspector should bear in mind > > > the operating characteristics of ultralight vehicles, the lack > > > of pilot certification standards, and the fact that these vehicles > > > must yield right-of-way to aircraft under all circumstances. > > > If the safety of conventional aircraft operations > > > would be compromised, the inspector should give a negative > > > finding to the Airports Division. When possible, inspectors > > > should assist in developing alternative methods to accommodate > > > ultralight operations. > > > (2) Nonfederally funded airports are not required to > > > accommodate ultralight operations. The FAA has no > > > authority in these situations; however, inspectors should > > > encourage ultralight operators and airport management to > > > consider alternative methods. > > > ----------------------------------------- > > > Ive always heard that if an airport recieves any form of assistance > > > from the gov. in the form of money, they can not disallow any one , who > is > > > legal, the priviledge of landing there! Is that the case or not??? > > > ________________________________________________________________________ > from AOL at AOL.com. > =0 > > ________________________________________________________________________________
Subject: Noise canceling earbuds update
Date: Jul 03, 2007
Flew the MKIII for while this morning, tried out the noise canceling earbuds, and there was a plus and a minus. The plus was that they really do cancel out the noise. Turning the ANR switch off and on shows that the ANR function removes the deeper rumble of the prop, and part of the engine noise. It makes the engine noise seem smaller and further away, if that makes any sense. For comparison, tried various combinations, just the Flightcoms without the earbuds, the earbuds without the Flightcoms, the earbuds with the ANR turned off, etc., the earbuds knock out about as much noise as the Flightcom headset, but each has a different quality. Once you put the headsets over the ears with the earbuds in, it cuts down the total noise a lot more, as you would expect. I think it is about the same effect you would get if you put in a pair of tapered soft foam hearing protectors, and then put on your headsets. Once you have both the earbuds and the headsets on, turning on the ANR cuts the prop noise out of the mix, and also makes the engine a bit quieter. And since I had my .mp3 player along, plugging it in and adding some Moody Blues to the mix was also a plus... The total amount of aircraft noise making it to my ears was low enough that you could listen to music without having to turn it up much. The minus was that I could not hear the tower, approach or ATIS. Didn't have any friends to yak at, but I suspect that 122.75 wouldn't work either. The earbuds did not allow what was coming out of the Flightcom speakers to make it into my ears. So I think what I will do next is make an adapter plug and jack so that I can unplug the headset/speaker side of the Flightcoms, leave the mic plugged in, and plug the earbuds into the aircraft jack where the Flightcoms normally go and try that. Use the earbuds for aircraft radio audio and see what happens. If I can figure out how to make it work at all, it ought to be quite good. Whoops, better make that adapter with a Y-setup, or the mp3 player will get left out. Can't be having that, ya know... Richard Pike MKIII N420P (420ldPoops) ________________________________________________________________________________
Subject: Re: Kolb Firefly
Date: Jul 03, 2007
AC 103-7 States, in part: b. Use of an Artificial Means to Control Capacity. ( 1) Tanks which have a permanent standpipe or venting arrangement to control capacity are permitted, but may be subject to demonstration of the capacity if there is any reason to doubt that the arrangement is effective. . . . So carrying extra fuel is permitted, so long as it is not usable in flight. As long as the extra fuel is not plumbed into the aircraft fuel system I think you'll be OK. -------- Jim N. Idaho Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122009#122009 ________________________________________________________________________________
Date: Jul 03, 2007
Interesting... I would have never guess the AFD would have listed such info... I'll take a look... Thanks Mark Vaughn -----Original Message----- From: Robert Laird <rlaird(at)cavediver.com> Sent: Tue, 3 Jul 2007 11:55 am Subject: Re: Kolb-List: Federal Funding By default, any airport designated as public is required to allow any aircraft to use it's services. This includes ultralights. (If a private airport, designated for public use, has never taken federal or state funding, then they have the right to deny services, but how will you know until you land there?) If a public airport owner can make a case to the FAA to disallow certain aircraft for particular reasons, then portions of or all services can be denied. That information, as far as I understand it, is supposed to be published in the AFD (Airport/Facility Directory) for public use airports, so, if you're at all concerned, then refer to the AFD for the airport you're interested in. -- Robert On 7/3/07, Mark Vaughn wrote: > > How does some one determine if a field has received or is receiving > federal funding ? > > > > Is there a list of fields some place for the public to review?? > > > > > > > > > > > > Mark > > > > > > > > -----Original Message----- > > > > From: Jim Dunn <jim@tru-cast.com> > > > > To: kolb-list(at)matronics.com > > > > > > > Subject: Re: Kolb-List: Re: Kolb Firefly > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Per FAA Order 8700.1 Dated 2/9/1996, Chapter 62: > > > > > > > > In short, if they received federal funds they are supposed to permit > > > > Ultralight activity, but they can deny UL if mixing cannot be done > safely. > > > > Advisory Circular 150/5190-5 of June 10, 2002 is specifically on > > > > exclusions. I doubt LAX permits ULs, and rightfully so. > > > > > > > > 7. OPERATION OF ULTRALIGHT VEHICLES > > > > FROM AIRPORTS. > > > > A. Aeronautical Activity. Ultralight vehicle operators > > > > usually require the approval of airport authorities before > > > > conducting operations from an airport. Operation of > > > > ultralight vehicles is considered an aeronautical activity > > > > much the same as parachute jumping. > > > > B. Use of Airports. Federally funded airports must > > > > accommodate ultralight operations if this can be done safely. > > > > This does not mean that airport authorities must allow > > > > ultralights to operate from the runways; rather, the airport > > > > should set aside a special location for ultralight operations. > > > > It is acceptable for airport authorities to establish policies, > > > > including reasonable training requirements, that they believe > > > > are necessary to provide safe accommodations to ultralight > > > > vehicles. If an airport's authorities believe it is unsafe to > > > > accommodate ultralights at the facility, they may request > > > > Flight Standards' input in the assessment of the safety of > > > > proposed operations. > > > > (1) When assessing the safety of ultralight vehicle > > > > operations from airports, the inspector should bear in mind > > > > the operating characteristics of ultralight vehicles, the lack > > > > of pilot certification standards, and the fact that these vehicles > > > > must yield right-of-way to aircraft under all circumstances. > > > > If the safety of conventional aircraft operations > > > > would be compromised, the inspector should give a negative > > > > finding to the Airports Division. When possible, inspectors > > > > should assist in developing alternative methods to accommodate > > > > ultralight operations. > > > > (2) Nonfederally funded airports are not required to > > > > accommodate ultralight operations. The FAA has no > > > > authority in these situations; however, inspectors should > > > > encourage ultralight operators and airport management to > > > > consider alternative methods. > > > > > > > > ----------------------------------------- > > > > > > > > Ive always heard that if an airport recieves any form of assistance > > > > from the gov. in the form of money, they can not disallow any one , who > is > > > > legal, the priviledge of landing there! Is that the case or not??? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________ > from AOL at AOL.com. > =0 > > > > > > ________________________________________________________________________ from AOL at AOL.com. =0 ________________________________________________________________________________
Date: Jul 03, 2007
"By default, any airport designated as public is required to allow any aircraft to use it's services. This includes ultralights." These rules were written before Sport Pilot and the FAA has ignored overweight ultralights for many years. Everyone knows that an ultralight is a single seat no more than 254 lbs empty weight, flies no faster than 63mph, and has a 5-gallon fuel capacity. Under the new rules, any aircraft (air vehicle) that doesn't meet this standard should be registered with the FAA. This means all overweight fixed-wings, trikes, and PPC's. After the deadline, the FAA will be able to keep overweight unregistered ultralights out of airports. Already we are seeing signs going up at our airports stating this. If your machine is overweight and not registered after the deadline, your flights may be limited to private fields only. Ralph -------- Ralph B Original Firestar 20 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122020#122020 ________________________________________________________________________________
Date: Jul 03, 2007
I'm sure you're right, Ralph. My statement would be more accurate to have said: "...any airport designated as public is required to allow any FAA recognized aircraft to use it's services. This includes a valid FAR 103 ultralight." BTW, take a picture of one of those new signs and send it to me... I'm really curious! -- Robert On 7/3/07, Ralph B wrote: > > "By default, any airport designated as public is required to allow any > aircraft to use it's services. This includes ultralights." > > These rules were written before Sport Pilot and the FAA has ignored overweight ultralights for many years. Everyone knows that an ultralight is a single seat no more than 254 lbs empty weight, flies no faster than 63mph, and has a 5-gallon fuel capacity. > > Under the new rules, any aircraft (air vehicle) that doesn't meet this standard should be registered with the FAA. This means all overweight fixed-wings, trikes, and PPC's. > > After the deadline, the FAA will be able to keep overweight unregistered ultralights out of airports. Already we are seeing signs going up at our airports stating this. > > If your machine is overweight and not registered after the deadline, your flights may be limited to private fields only. > > Ralph > > -------- > Ralph B > Original Firestar > 20 years flying it > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122020#122020 > > ________________________________________________________________________________
Date: Jul 03, 2007
Mark -- Below is a snapshot of a A/FD entry for an airport just south of me... note the "no touch and go nighttime lngs"... that's a restriction that either they asked the FAA for, or the FAA told them they had to abide by. I've seen other A/FD entries for "No ultralight activities" but can't put my finger on one right now. As I mentioned, if an airport owner can make a good case, the FAA will add the restriction. Sometimes, the FAA sees an issue (like a noise sensitive area) and will compel the airport to comply and will publish it in the A/FD, as shown in this excerpt. ________________________________________________________________________________
Date: Jul 03, 2007
Hmmmmm Does having to Relieve ones self in the worst way qualify as an emergency??? hahahahahaha 8-) Thanks for the example.. Mark Vaughn -----Original Message----- From: Robert Laird <rlaird(at)cavediver.com> Sent: Tue, 3 Jul 2007 1:57 pm Subject: Re: Kolb-List: Federal Funding Mark -- Below is a snapshot of a A/FD entry for an airport just south of me... note the "no touch and go nighttime lngs"... that's a restriction that either they asked the FAA for, or the FAA told them they had to abide by. I've seen other A/FD entries for "No ultralight activities" but can't put my finger on one right now. As I mentioned, if an airport owner can make a good case, the FAA will add the restriction. Sometimes, the FAA sees an issue (like a noise sensitive area) and will compel the airport to comply and will publish it in the A/FD, as shown in this excerpt. ________________________________________________________________________ from AOL at AOL.com. =0 ________________________________________________________________________________
Subject: Re: "Magic Bike" gets Damaged
Date: Jul 03, 2007
Dennis, Your welcome to use our MSN site for the pics. Just join and have at it. Pics load really fast on this site. and it's free! http://groups.msn.com/login_info.msnw?referer=join&ru=http%3A%2F%2Fgroups%2Emsn%2Ecom%2FAerialWorld%2F%5Fjoin%2Emsnw%3F&commname=Aerial%20World -------- Paul Petty Kolbra #12 Ms Dixie 912 UL 70" warp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122031#122031 ________________________________________________________________________________
Date: Jul 03, 2007
Subject: Re: Kolb pre-flight check list
yeah, I know...he's gonna spout some old GA stuff! But regarding oil caps...I've had several GAs, both with small chains on oil caps, and without The without one came off between JAX and TPA. How did I know? Oil all over windscreen, oil temp increasing, oil pressure heading for zero. Made straight in TPA honking 7700. The fix; a pc of chain secured to lg screw-type hose clamp, other end to small hole in edge of cap. regards, Bob N. FireFly 070 Old Kolb http://www.angelfire.com/rpg/ronoy/ ________________________________________________________________________________
Date: Jul 03, 2007
Subject: Oil caps
Okay guys, I can understand scribe lines and check list items, but even these are subject to human error. After several people were killed in Variezes and LongEZs when one or both fuel caps went through the prop, the solution was to attach the caps in such manner that even if the cap comes off it can only go a few inches before it is restrained. Both the fuel cap and oil cap on Meadowlark have a cable restraint. Just something to consider. Rick -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: Mark 3 classic landing speed
Date: Jul 03, 2007
To all, I am still trying to perfect my landings. My current home base is a paved 6000 ft runway. I normally do a "bomber" style landing (i.e. 60 mph with 1 notch of flaps and a slow gradual descent under power). I have flown with John Hauck and his short field, full flaps, grass field landing. What airspeed and flaps do the rest of you Mark 3 Classic pilots use for a "normal" landing? Tim Warlick Mobile, AL BMW R100 Powered Kolb Mark 3 Classic ________________________________________________________________________________
Date: Jul 03, 2007
> (John Hauck) I'm using a Powerfin. (I know what you're probably > thinking, John - that if it were a Warp, it would've just cut that ol' > oil cap in half and kept on spinning without a blink.) Dennis: You are correct. Had you been flying with a Warp Drive Prop, you would still be flying your Magic Bike. Some years ago I put an 18 inch piece of 1.5 inch exhaust pipe through my Warp Drive. Pipe hit the leading edge of one blade. Was climbing out at full throttle when the pipe let go. Put a small ding in the leading edge and produced a new vibration. Flew 10 miles to Wetumpka Airport. Landed, checked the prop, and for other damage, got back in the mkIII and flew 11.2 sm to Gantt IAP. Another short story on my first off field landing in Alaska, 1994. Cut more alder brush with the Warp Drive than a John Deere A with a 6 foot bush hog. No damage to the prop blades, although they did turn green. Alder is a plant similar to mature cotton. Very hard stalk and branches about as big as you little finger. Don't know for sure, but I'd bet a months retirement pay you could have flown back to Sandia East or Double Eagle with a Warp Drive with no problems. Laminated and wooden props will not take the abuse a solid carbon fiber Warp Drive Blade will and keep on flying. That is why I fly with nothing but Warp Drive. john h PS: Now is a good time to upgrade. Daryl will give you $100.00 trade in for your old prop. -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122073#122073 ________________________________________________________________________________
Subject: Re: Mark 3 classic landing speed
Date: Jul 03, 2007
Normal being a runway where length is not a factor - Solo, approach at 55, full flaps, partial power until just before touchdown. With a passenger, approach at 60, full flaps, partial power until just before touchdown. Normal into my place, which is a 750 foot strip that has the touchdown end 20' lower than the top of the strip, with 300' high power lines 2/10 of a mile out from touchdown, and a go-around is not a good option - Engine at idle crossing the powerlines, full flaps, airspeed at 60 solo or two up, aim at the grass 100' before the end of the runway. Round out and goose the throttle when you get that far so you can make it to the runway. (At this point you are flying sort of uphill) The goal is to land and stop in the first 300', but usually I settle for not having anything bent... I always use full flaps for everything so that the airplane will always behave the same every time. Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: Tim Warlick To: kolb-list(at)matronics.com Sent: Tuesday, July 03, 2007 7:27 PM Subject: Kolb-List: Mark 3 classic landing speed To all, I am still trying to perfect my landings. My current home base is a paved 6000 ft runway. I normally do a "bomber" style landing (i.e. 60 mph with 1 notch of flaps and a slow gradual descent under power). I have flown with John Hauck and his short field, full flaps, grass field landing. What airspeed and flaps do the rest of you Mark 3 Classic pilots use for a "normal" landing? Tim Warlick Mobile, AL BMW R100 Powered Kolb Mark 3 Classic ________________________________________________________________________________
Date: Jul 03, 2007
I'm sure you're right, Ralph. My statement would be more accurate to have said: "...any airport designated as public is required to allow any FAA recognized aircraft to use it's services. This includes a valid FAR 103 ultralight." BTW, take a picture of one of those new signs and send it to me... I'm really curious! -- Robert Robert, here's your picture of the warning sign at the Red Wing airport. Here is what it says as it's hard to read with the way the camera took it on the inside of the glass: WARNING Any aircraft operating at the Red Wing Regional Airport not displaying a registration number nor meeting the definition of an ultralight vehicle will be reported to the Federal Aviation Administration for enforcement action. An ultralight vehicle is defined as a vehicle that: Is used or intended to be used for manned operation in the air by a single occupant Is used or intended to be used for recreation or sport purposes only Does not have any U.S. or foreign airworthiness certificate, and: If unpowered, weighs less than 155 pounds, or if powered, weighs less than 254 pounds empty weight, excluding floats and safety devices which are intended for deployment in a potentially catastrophic situation. Has a fuel capacity not exceeding 5 U.S. gallons. Is not capable of more than 55 knots calibrated airspeed at full power in level flight, and: Has a power-off stall speed which does not exceed 24 knots calibrated airspeed. If your ultralight does not meet the above definition, it must be operated in accordance with applicable aircraft regulations. You will be subject to enforcement actions ($1000 civil penalty for each violation) for each operation of this aircraft. Tom Blue, Caretaker Red Wing Regional Airport Ralph B Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122083#122083 Attachments: http://forums.matronics.com//files/airport_warning_sign_148.jpg ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Date: Jul 03, 2007
This "caretaker" sounds fascist IMHO. This is what happens when folks don't speak out. The vast majority of airports are UL-friendly, or at least tolerant. I operate out of PTK (Pontiac, MI, tower-controlled) in GA aircraft, and there are several ultralights based there. The UL guys go out of their way to comply, some even use radios! Ed in JXN MkII/503 ----- Original Message ----- From: "Ralph B" <ul15rhb(at)juno.com> Sent: Tuesday, July 03, 2007 8:35 PM Subject: Kolb-List: Re: Federal Funding > > I'm sure you're right, Ralph. My statement would be more accurate to > have said: "...any airport designated as public is required to allow > any FAA recognized aircraft to use it's services. This includes a > valid FAR 103 ultralight." > > BTW, take a picture of one of those new signs and send it to me... I'm > really curious! > > -- Robert > > Robert, here's your picture of the warning sign at the Red Wing airport. > Here is what it says as it's hard to read with the way the camera took it > on the inside of the glass: > > WARNING > > Any aircraft operating at the Red Wing Regional Airport not displaying a > registration number nor meeting the definition of an ultralight vehicle > will be reported to the Federal Aviation Administration for enforcement > action. An ultralight vehicle is defined as a vehicle that: > > Is used or intended to be used for manned operation in the air by a single > occupant > (Snip) ________________________________________________________________________________
Date: Jul 03, 2007
At 07:27 PM 7/3/2007, you wrote: >To all, > >I am still trying to perfect my landings. My current home base is a >paved 6000 ft runway. I normally do a "bomber" style landing (i.e. >60 mph with 1 notch of flaps and a slow gradual descent under >power). I have flown with John Hauck and his short field, full >flaps, grass field landing. What airspeed and flaps do the rest of >you Mark 3 Classic pilots use for a "normal" landing? > >Tim Warlick What I do (especially on a short grass field) is to go ahead and lock my brakes before I touch down. The tires will slide on the grass just fine. On some fields you can't afford a "bounce" or for the plane to "float" or a "go-a-round". The trick is that once the mains touch down there is enough drag that the tail will stay up and the plane will quit flying/floating even at faster landing speeds. Don't worry, there is enough air on the tail to keep you from nosing over, I promise. It also works to stop floating on asphalt. You'll need to learn to steer with you brakes sooner or later anyway. http://video.google.com/videoplay?docid=-8022448200127542755&hl=en ________________________________________________________________________________
Subject: Builders Plans
Date: Jul 03, 2007
I am new to this forum and will be picking up my plane kit this Thursday, July 5th. I am going to build the M3x and install a VW engine. The Kolb people are working with me on the engine mounts with the help of Rick Neilson. I will talk more on the engine situation as things progress. My main concern for now is the plans. Donnie, from Kolb, gave me my set of plans early while they got the kit together. This is not my first plane I will be building, in fact it's the third. The first was a Cozy, wide body Long Ezy, which was strickly a plans built aircraft ( not a kit ). The second was a Glastar. Now the third will be the M3X, that is if I can figure out the plans. I have never seen such a poor excuse for plans as I have been given on this aircraft. They are the most confusing piles of paper I have ever seen. They leave me with a feeling of real concern as to weather the plans can be constructed correctly or not. When I told Donnie about my concerns, he told me that I would catch on. Really nice guy's there at Kolb and I sure don't want to hurt ther feelings as they will bind over backwards to help anyone. Just what am I missing here? Thanks Rick Lewis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122093#122093 ________________________________________________________________________________
Date: Jul 03, 2007
Interesting (if not a little disgusting)... but how, I wonder, does he magically discern the weight of a single-seat UL, not to mention the speed, etc...? And, does he not honor the FAA exemption for UL trainers? There's no mention of that! I'll bet his mistress is named Eva and he wears brown shirts, eh? -- Robert On 7/3/07, Ralph B wrote: > > I'm sure you're right, Ralph. My statement would be more accurate to > have said: "...any airport designated as public is required to allow > any FAA recognized aircraft to use it's services. This includes a > valid FAR 103 ultralight." > > BTW, take a picture of one of those new signs and send it to me... I'm > really curious! > > -- Robert > > Robert, here's your picture of the warning sign at the Red Wing airport. > Here is what it says as it's hard to read with the way the camera took it on the inside of the glass: > > WARNING > > Any aircraft operating at the Red Wing Regional Airport not displaying a registration number nor meeting the definition of an ultralight vehicle > will be reported to the Federal Aviation Administration for enforcement action. An ultralight vehicle is defined as a vehicle that: > > Is used or intended to be used for manned operation in the air by a single occupant > > Is used or intended to be used for recreation or sport purposes only > > Does not have any U.S. or foreign airworthiness certificate, and: > > If unpowered, weighs less than 155 pounds, or if powered, weighs less than 254 pounds empty weight, excluding floats and safety devices which are intended for deployment in a potentially catastrophic situation. > > Has a fuel capacity not exceeding 5 U.S. gallons. > > Is not capable of more than 55 knots calibrated airspeed at full power in level flight, and: > > Has a power-off stall speed which does not exceed 24 knots calibrated airspeed. > > If your ultralight does not meet the above definition, it must be operated in accordance with applicable aircraft regulations. You will be subject to enforcement actions ($1000 civil penalty for each violation) for each operation of this aircraft. > > Tom Blue, Caretaker > Red Wing Regional Airport > > Ralph B > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122083#122083 > > > Attachments: > > http://forums.matronics.com//files/airport_warning_sign_148.jpg > > ________________________________________________________________________________
Date: Jul 04, 2007
I use full flap { flaps have been altered so do not probably give the same effect as standard ones} approach speed of 55mph round out about 50 the air speed will drop off fast from that point and it will settle into a 3 point landing nicely. Landing roll within 200 ft { I have good brakes for short landings} With two heavy bodies aboard I give the numbers all an extra 5 mph .MK111 445 pounds emty and max take off of 1050 pounds . Here in NewZealand it would appear our Ultralight rules are different than you guys. With these weights I am still well within our limits. Chears Tony ----- Original Message ----- From: Tim Warlick To: kolb-list(at)matronics.com Sent: Wednesday, July 04, 2007 11:27 AM Subject: Kolb-List: Mark 3 classic landing speed To all, I am still trying to perfect my landings. My current home base is a paved 6000 ft runway. I normally do a "bomber" style landing (i.e. 60 mph with 1 notch of flaps and a slow gradual descent under power). I have flown with John Hauck and his short field, full flaps, grass field landing. What airspeed and flaps do the rest of you Mark 3 Classic pilots use for a "normal" landing? Tim Warlick Mobile, AL BMW R100 Powered Kolb Mark 3 Classic ------------------------------------------------------------------------- ----- 2/07/2007 3:35 p.m. ________________________________________________________________________________
Date: Jul 03, 2007
Robert, There is no such thing as an unlicensed ultralight trainer after Jan 31, 2008. After that you have to find a Sport Pilot CFI and a certificated LSA. If it's in the aircraft's operating limitations, an E-LSA can be used for training until Jan 31, 2010. After that it will be only S-LSA that can be used for training. Rick On 7/3/07, Robert Laird wrote: > > > Interesting (if not a little disgusting)... but how, I wonder, does he > magically discern the weight of a single-seat UL, not to mention the > speed, etc...? And, does he not honor the FAA exemption for UL > trainers? There's no mention of that! > > I'll bet his mistress is named Eva and he wears brown shirts, eh? > > -- Robert > > > On 7/3/07, Ralph B wrote: > > > > I'm sure you're right, Ralph. My statement would be more accurate to > > have said: "...any airport designated as public is required to allow > > any FAA recognized aircraft to use it's services. This includes a > > valid FAR 103 ultralight." > > > > BTW, take a picture of one of those new signs and send it to me... I'm > > really curious! > > > > -- Robert > > > > Robert, here's your picture of the warning sign at the Red Wing airport. > > Here is what it says as it's hard to read with the way the camera took > it on the inside of the glass: > > > > WARNING > > > > Any aircraft operating at the Red Wing Regional Airport not displaying a > registration number nor meeting the definition of an ultralight vehicle > > will be reported to the Federal Aviation Administration for enforcement > action. An ultralight vehicle is defined as a vehicle that: > > > > Is used or intended to be used for manned operation in the air by a > single occupant > > > > Is used or intended to be used for recreation or sport purposes only > > > > Does not have any U.S. or foreign airworthiness certificate, and: > > > > If unpowered, weighs less than 155 pounds, or if powered, weighs less > than 254 pounds empty weight, excluding floats and safety devices which are > intended for deployment in a potentially catastrophic situation. > > > > Has a fuel capacity not exceeding 5 U.S. gallons. > > > > Is not capable of more than 55 knots calibrated airspeed at full power > in level flight, and: > > > > Has a power-off stall speed which does not exceed 24 knots calibrated > airspeed. > > > > If your ultralight does not meet the above definition, it must be > operated in accordance with applicable aircraft regulations. You will be > subject to enforcement actions ($1000 civil penalty for each violation) for > each operation of this aircraft. > > > > Tom Blue, Caretaker > > Red Wing Regional Airport > > > > Ralph B > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=122083#122083 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/airport_warning_sign_148.jpg > > > > > > > > > > > > > > > > > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Jul 03, 2007
In a message dated 7/3/2007 12:32:52 PM Central Standard Time, ul15rhb(at)juno.com writes: > After the deadline, the FAA will be able to keep overweight unregistered > ultralights out of airports. Already we are seeing signs going up at our > airports stating this. > > If your machine is overweight and not registered after the deadline, your > flights may be limited to private fields only. > > Ralph Ralph, An aircraft that weighs more than 254 with a single seat is not an overweight ultralight. It is an illegal aircraft , if you dont have a license to fly and must be registered. On the other hand if the craft meets ALL requirements for an ultralight then it should be legal as a true ultralight today or after the deadline. The FAA has had the authority ,all along, to keep ( overweight unregistered ultralights) from flying anywhere in the USA . It is my understanding that FAR 103 will not change at all. I see " SPORT PILOT" as the solution to force everyone to comply with the rules that have been in place all along. Do the signs you are refering to address Legal Ultralights? My original comment was pertaining to Legal Ultralights. Ed Diebel
See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 03, 2007
----- Original Message ----- From: Tony Oldman .MK111 445 pounds emty and max take off of 1050 pounds Chears Tony Now thats a light Mk-3 Denny Rowe, Mk-3 470 pounds ________________________________________________________________________________
Date: Jul 04, 2007
Yup, well aware of that, but the sign exists now, so, I was just wondering why the "caretaker" wasn't taking care of -current- UL trainers. On 7/3/07, Richard Girard wrote: > Robert, There is no such thing as an unlicensed ultralight trainer after Jan > 31, 2008. After that you have to find a Sport Pilot CFI and a certificated > LSA. If it's in the aircraft's operating limitations, an E-LSA can be used > for training until Jan 31, 2010. After that it will be only S-LSA that can > be used for training. > > Rick > > > On 7/3/07, Robert Laird wrote: > > > > > > Interesting (if not a little disgusting)... but how, I wonder, does he > > magically discern the weight of a single-seat UL, not to mention the > > speed, etc...? And, does he not honor the FAA exemption for UL > > trainers? There's no mention of that! > > > > I'll bet his mistress is named Eva and he wears brown shirts, eh? > > > > -- Robert > > > > > > On 7/3/07, Ralph B wrote: > > > > > > I'm sure you're right, Ralph. My statement would be more accurate to > > > have said: "...any airport designated as public is required to allow > > > any FAA recognized aircraft to use it's services. This includes a > > > valid FAR 103 ultralight." > > > > > > BTW, take a picture of one of those new signs and send it to me... I'm > > > really curious! > > > > > > -- Robert > > > > > > Robert, here's your picture of the warning sign at the Red Wing airport. > > > Here is what it says as it's hard to read with the way the camera took > it on the inside of the glass: > > > > > > WARNING > > > > > > Any aircraft operating at the Red Wing Regional Airport not displaying a > registration number nor meeting the definition of an ultralight vehicle > > > will be reported to the Federal Aviation Administration for enforcement > action. An ultralight vehicle is defined as a vehicle that: > > > > > > Is used or intended to be used for manned operation in the air by a > single occupant > > > > > > Is used or intended to be used for recreation or sport purposes only > > > > > > Does not have any U.S. or foreign airworthiness certificate, and: > > > > > > If unpowered, weighs less than 155 pounds, or if powered, weighs less > than 254 pounds empty weight, excluding floats and safety devices which are > intended for deployment in a potentially catastrophic situation. > > > > > > Has a fuel capacity not exceeding 5 U.S. gallons. > > > > > > Is not capable of more than 55 knots calibrated airspeed at full power > in level flight, and: > > > > > > Has a power-off stall speed which does not exceed 24 knots calibrated > airspeed. > > > > > > If your ultralight does not meet the above definition, it must be > operated in accordance with applicable aircraft regulations. You will be > subject to enforcement actions ($1000 civil penalty for each violation) for > each operation of this aircraft. > > > > > > Tom Blue, Caretaker > > > Red Wing Regional Airport > > > > > > Ralph B > > > > > > > > > > > > > > > Read this topic online here: > > > > > > > http://forums.matronics.com/viewtopic.php?p=122083#122083 > > > > > > > > > > > > > > > Attachments: > > > > > > > http://forums.matronics.com//files/airport_warning_sign_148.jpg > > "Ya'll drop on in" > > takes on a whole new meaning > > when you live at the airport. > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Helmet choice - with David Clark headphone
Date: Jul 03, 2007
Hi John, I believe David Clark does make a hard helmet for their headsets. The helmet is actually two parts, a soft helmet and a hard outer shell that fits over it. Like all David Clark items, they are good and David Clark is not afraid to tell you that (Price!) For myself I took a standard ultralight type helmet and carefully recontoured the interior to fit the Head Band of my D/C headset. Its not perfect but it fits me and is comforting to know my noggin has a bit of protection should I have a brief period of unwanted excitement. There may be other solutions for your headset/helmet dilemma but, I wouldn't expect them to be cheap. Good Luck Carlos G AKA BaronVonEvil :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122116#122116 ________________________________________________________________________________
Date: Jul 04, 2007
Only running a 503 so that has kept the weight down. Aircraft is used mostly at sea level so performance is still good. Tony ----- Original Message ----- From: Denny Rowe To: kolb-list(at)matronics.com Sent: Wednesday, July 04, 2007 3:44 PM Subject: Re: Kolb-List: Mark 3 classic landing speed ----- Original Message ----- From: Tony Oldman .MK111 445 pounds emty and max take off of 1050 pounds Chears Tony Now thats a light Mk-3 Denny Rowe, Mk-3 470 pounds ------------------------------------------------------------------------- ----- 2/07/2007 3:35 p.m. ________________________________________________________________________________
Date: Jul 04, 2007
Here in NewZealand it would appear our Ultralight rules are different than you guys. With these weights I am still well within our limits. >> Hi Tony, it would be interesting to compare how your rules differ from the USA and the UK rules. Where are you in Kiwiland? Cheers Pat ________________________________________________________________________________
Date: Jul 04, 2007
Just make sure both of you tell the same story >> Hi Paul, I just love your American atitude to the rules. Here, in general, rules are complied with and are considered to be there for a reason. In the States the rules seem to be seen as something to be circumvented if at all possible. Guess it is just an entirely different perspective. Your argument about `Fat Ultralights` wouldn`t get off the ground here. You either comply with the rules and you are a ultralight or you don`t and you are not. If you are not then all the rest falls into place and the least of your troubles will be that no insurance company would pay out in the case of an accident. Thats not to say that the rules don`t get bent a little here and there..... I wish we had a little more of your attitude over here. We are really turning into a `nanny State` and we shalll need a certificate and a crash helmet to get out of bed soon Cheers Pat ________________________________________________________________________________
Subject: twinstar
Date: Jul 04, 2007
I just wanted to give the list a heads up on my newest creation or recreation. My wife Bev and I have almost completed the restoration of an original Kolb Twinstar with the drop down nose cone. It should be completed and ready for sale within two weeks. This should give the new owner time to get an n-number, register it and put the engine of his desire on it in plenty of time for the inspection. (wouldnt the HKS be just about perfect for this!) Everything has been checked and repainted (cables especially). It had a 503 on it but we are selling it as 'parts'. I am just completing the recovering of the wings with stits. It will have silver poly spray and it is the certified cloth for durability (stright from Poly-fiber). The wing is going to be painted insig. white unless someone steps up real quick and wants something else. Being poly tone paint, you could repaint it with any design you chose or stay with the beautiful dark blue fuse and white wings and nose. Has new tires and outside brake drums. Just wanted to give the heads up. A truely classic two seater. Ted Cowan, 334-480-0822. Will send pics off list if you are REALLY interested. Going to go for about $6,000 OBO. ________________________________________________________________________________
Date: Jul 04, 2007
On the coast middle of the South Island { Timaru } a city of about 3500. I operate from the local airport and fly mostly inaudio.The airport has some commercial activity and also carries out flight training with the local aero club and gliding club.No landing fees if you are a club member,no tower. Nearest international airport 100 miles away at Christchurch so we get pretty well left alone. Like most places there are the people that would like to see Ultralights {microlights here } go fly some other place. We all live in hope that those that try and make it difficult { mostly the rule makers} for us will wake up to the fact we ALL enjoy the same passion and just want to fly. It is pleasing to see that the number of Ultralight kickers are on the decline .We have a great country that offers great views from the air. Our rules are basic for now. Max weight 1234 lbs, only one pax, maintain straight and level at 35 mph . Training to be carried out by RAANZ approved instructor,{ Recreational aircraft association NewZealand } different ratings for different control systems and a special rating for pax with a minimum PIC time. Flight test every two years with medical {much the same medical as you would need to drive a heavy truck } Rules have started to become more structured and in line with GA aircraft in that you now need a log book for daily flights one for the prop and another for the engine. You can still carry out your own maintenance but the aircraft needs a permit to fly inspection every 12 months . We do have some no fly zones if flying inaudio. The Kolb is a great aircraft ,its easy to manage has no vices, has great visibility is excellent on short grass strips.I think that our MK111 is the only one flying in NewZealand. There are a few MK2s.Also have a 7/8 scale Sopwith camel . The camel has a 503 in it but I have a 5 cyl radial that fits into it. It has been flown on the radial some time ago. The radial is a Webster Whirlwind. Hope I am not boring any one with this chatter. I just love having my feet off the ground .Also ride a 1961 AJS and have recently restored a Triumph spitfire am now working on a 1935 Morris sports car.Have too many hobbies and not enough time.Keep it safe up there. Cheers Tony ----- Original Message ----- From: pat ladd To: kolb-list(at)matronics.com Sent: Wednesday, July 04, 2007 9:26 PM Subject: Re: Kolb-List: Mark 3 classic landing speed Here in NewZealand it would appear our Ultralight rules are different than you guys. With these weights I am still well within our limits. >> Hi Tony, it would be interesting to compare how your rules differ from the USA and the UK rules. Where are you in Kiwiland? Cheers Pat ------------------------------------------------------------------------- ----- 2/07/2007 3:35 p.m. ________________________________________________________________________________
Date: Jul 04, 2007
I find all this talk about enforcement a little strange. The FAA has never seemed to care about overweight ultralights and I have seen no evidence that they will start after January. The only noise of enforcement that I have heard, has come from people who have a financial interest in SP, and those pilots that buy in to their rhetoric. I have spoken off the record with a two FAA officials, and they have not received any mandate to step up enforcement. Here's my take....... If it looks like an ultrralight, has one seat, 5gal tank, and has a 447 or smaller, the FAA will consider it an ultralight....That is, until you piss off the neighbors, or have an accident that forces the FAA's hand. For instance, if you have an engine out and land in a school yard full of kids, they are apt to nail you to the wall. I think sport pilot is a great solution for guys with two seats, but I intend to keep flying my firestar 1 as an ultralight, As far as the sign at your local airport, that sounds like a place that is already hostile towards the kind of planes we fly, and they are looking for any excuse to get rid of us. I avoid airports that are not ultralight friendly. If they don't want me there, I don't want to be there. Bryan Dever ________________________________________________________________________________
Date: Jul 04, 2007
I have to agree with John H on the Warp drive, worst you would have had to do is replace a blade after landing at your home field. If a powerfin stayed together, the warp would have had a nick, thats it. I started flying my MK III with a Kiev Prop, it is very smooth, beautiful, and efficient, but it is so light it worries me every time I fly it. I finally just coughed up the 1500 bucks and bought a new Warp Drive. The plane may be a bit slower with it, im not sure, but I dont worry about my prop comming apart at the slightest provocation anymore. I read somewhere that if you have a pusher engine, something will eventually go through the prop, its just a matter of when, not if... So I have a new condition Kiev Prop 70 inch prop for sale if anyone is interested. Mike Bigelow -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122205#122205 ________________________________________________________________________________
Date: Jul 04, 2007
planecrazzzy wrote: > > > I'm flying there Thursday morning to get my Transponder Cert. > > $75 for the Transponder & $75 for the Alt Encoder (cheapest I've Found) > > Gotta Fly... > Mike & "Jaz" in MN - FSII / N381PM > . > . > . > . Where did you find a transponder for 75 bucks ? Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122206#122206 ________________________________________________________________________________
Date: Jul 04, 2007
Hi Guys, I havent posted this to the list before i dont think. But I may have after I got over the embarrasment maybe not. But for the Warp drive prop camp here is my story. I built ms Dixie to "ready to cover" stage and ran the 912UL and John H's prop that I bought from him/warp drive and one day on a engine start up test my right wing front attach point pin fell out and the wing folded back into the Warp drive prop. I failed to put the "saftey" clips in the attach pins thinking NO WAY they would vibrate out sitting on the ground. WRONG. End result was a damaged wing trailing edge and a wing that had to be repaired. the 912 had just barley made it to low idel maybe 600-1000 rpm when this happened. Now how many have had a wing go into a spinning prop? it was way more than an oil cap. As for the Warp? one tiny nick in the leading edge and one tiny scratch in number 2 blade. Sent it to Warp and they replaced the nickle edge on the nicked blade and polished the scratched blade, balanced it sent it back with a clean bill of health. I cant speak for other props but i can for a Warp Drive! If any want pics of the bent trailing edge where the 70"er hit the splice joint in the TE ask back copy. It's quite impressive! -------- Paul Petty Kolbra #12 Ms Dixie 912 UL 70" warp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122228#122228 ________________________________________________________________________________
Date: Jul 04, 2007
I have a Powerfin prop also. A few years ago I had a 9/16 * 3 inch bolt go thru the prop in flight. As most good pilots do, I landed at the next available airstrip. I found some damage but decided to try for home which was almost four hunderd miles. I have heard of smaller items causing worse damage on Powerfin props. I also saw all three blades wiped clean off at the hub after a solid strike on a non Kolb fusalage(sp) boom tube. As with everything aviation there are trade offs. The Powerfin prop will give more thrust than a warpdrive, has alot less inertia and will break off if it srikes something substatial instead of causing gearbox or engine problems. I think even a warpdrive pilot would do a prcautionary landing after a propstrike. How rugged do you want the prop to be? Can you live with the trade offs? Rick Neilsen Redrive VW powered MKIIIC -------------- Original message -------------- From: "John Hauck" <jhauck(at)elmore.rr.com> > > > > (John Hauck) I'm using a Powerfin. (I know what you're probably > > thinking, John - that if it were a Warp, it would've just cut that ol' > > oil cap in half and kept on spinning without a blink.) > > > Dennis: > > You are correct. > > Had you been flying with a Warp Drive Prop, you would still be flying your Magic > Bike. > > Some years ago I put an 18 inch piece of 1.5 inch exhaust pipe through my Warp > Drive. Pipe hit the leading edge of one blade. Was climbing out at full > throttle when the pipe let go. Put a small ding in the leading edge and > produced a new vibration. Flew 10 miles to Wetumpka Airport. Landed, checked > the prop, and for other damage, got back in the mkIII and flew 11.2 sm to Gantt > IAP. > > Another short story on my first off field landing in Alaska, 1994. Cut more > alder brush with the Warp Drive than a John Deere A with a 6 foot bush hog. No > damage to the prop blades, although they did turn green. Alder is a plant > similar to mature cotton. Very hard stalk and branches about as big as you > little finger. > > Don't know for sure, but I'd bet a months retirement pay you could have flown > back to Sandia East or Double Eagle with a Warp Drive with no problems. > > Laminated and wooden props will not take the abuse a solid carbon fiber Warp > Drive Blade will and keep on flying. That is why I fly with nothing but Warp > Drive. > > john h > > PS: Now is a good time to upgrade. Daryl will give you $100.00 trade in for > your old prop. > > -------- > John Hauck > MKIII/912ULS > hauck's holler, alabama > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122073#122073 > > > > > > > > > >
Rick Neilsen
> --> Kolb-List message posted by: "John Hauck"
> Dennis:
> You are correct.
> Bike.
> produced a new vi bratio n. Flew 10 miles to Wetumpka Airport. Landed, checked
> IAP.
> little finger.
> Drive.
> john h
> PS: Now is a good time to upgrade. Daryl wi ll giv = --&g
Subject: Re: Builders Plans
Date: Jul 04, 2007
Rick, I commonly refer to my plans as the "Comic Book" they look cool but i feel your pain! And wait till you get...refer to page so and so and it's blank! I think the world of the Gang at TNK. I deal with customer service with a ton of vendors and suppliers in my work and I can tell you this, You will not find better people than Travis,Donnie and Brian anywhere! Relax, note areas that you are not sure about and make refrance to what you are missing and i can assure you they will have answers! Here is another tip. See if you can find some older "blue prints" from the old kolb. They were very helpful to me as to the "Concept" of Holmers design. And be sure to worry the shit out of John Hauck and dont cry when he bites your head off and hands it to you on a paper plate! hehe Love you John! Welcome to the Club Rick you will do fine! PS. are you building the "new" mark 3 X that they had at sun-n-fun? and are your the guys that did the 300 mph pass over the TNK factory field in 2003/4? take care -------- Paul Petty Kolbra #12 Ms Dixie 912 UL 70" warp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122231#122231 ________________________________________________________________________________
Date: Jul 04, 2007
Rick Are you getting the MKIIIX with flaps or flaperons? Check the archives for considerable discussion of the differences and advantages. Rick Neilsen Redrive VW powered MKIIIC -------------- Original message -------------- From: "Rick2" <cktman(at)hughes.net> > > I am new to this forum and will be picking up my plane kit this Thursday, July > 5th. I am going to build the M3x and install a VW engine. The Kolb people are > working with me on the engine mounts with the help of Rick Neilson. I will talk > more on the engine situation as things progress. > > My main concern for now is the plans. Donnie, from Kolb, gave me my set of > plans early while they got the kit together. This is not my first plane I will > be building, in fact it's the third. The first was a Cozy, wide body Long Ezy, > which was strickly a plans built aircraft ( not a kit ). The second was a > Glastar. Now the third will be the M3X, that is if I can figure out the plans. > I have never seen such a poor excuse for plans as I have been given on this > aircraft. They are the most confusing piles of paper I have ever seen. They > leave me with a feeling of real concern as to weather the plans can be > constructed correctly or not. When I told Donnie about my concerns, he told me > that I would catch on. Really nice guy's there at Kolb and I sure don't want to > hurt ther feelings as they will bind over backwards to help anyone. Just what am > I missing here? > > > Thanks > > Rick Lewis > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122093#122093 > > > > > > > > > >
Rick
Rick Neilsen
> --> Kolb-List message posted by: "Rick2"
> Glastar. Now the third will be the M3X, tha t is i ics Li
Subject: Re: Noise canceling earbuds update
Date: Jul 04, 2007
Richard I have been flying for about a year with Sony ear buds under my active noise canceling headphones. I have a matched pair for my passenger who doesn't get active noise canceling. I connect them to my intercom and disconnect the headphone ear peices. That way I can hear music but the intercom cuts the music when there is radio traffic and it adds a welcome additional level of noise reduction. The ear buds have sound quality superior to the headphone speakers. Your active ear buds may do a even better job at about the same price. Rick Neilsen Redrive VW powered MKIIIC -------------- Original message -------------- From: "Richard Pike" <richard(at)bcchapel.org> Flew the MKIII for while this morning, tried out the noise canceling earbuds, and there was a plus and a minus. The plus was that they really do cancel out the noise. Turning the ANR switch off and on shows that the ANR function removes the deeper rumble of the prop, and part of the engine noise. It makes the engine noise seem smaller and further away, if that makes any sense. For comparison, tried various combinations, just the Flightcoms without the earbuds, the earbuds without the Flightcoms, the earbuds with the ANR turned off, etc., the earbuds knock out about as much noise as the Flightcom headset, but each has a different quality. Once you put the headsets over the ears with the earbuds in, it cuts down the total noise a lot more, as you would expect. I think it is about the same effect you would get if you put in a pair of tapered soft foam hearing protectors, and then put on your headsets. Once you have both the earbuds and the headsets on, turning on the ANR cuts the prop noise out of the mix, and also makes the engine a bit quieter. And since I had my .mp3 player along, plugging it in and adding some Moody Blues to the mix was also a plus... The total amount of aircraft noise making it to my ears was low enough that you could listen to music without having to turn it up much. The minus was that I could not hear the tower, approach or ATIS. Didn't have any friends to yak at, but I suspect that 122.75 wouldn't work either. The earbuds did not allow what was coming out of the Flightcom speakers to make it into my ears. So I think what I will do next is make an adapter plug and jack so that I can unplug the headset/speaker side of the Flightcoms, leave the mic plugged in, and plug the earbuds into the aircraft jack where the Flightcoms normally go and try that. Use the earbuds for aircraft radio audio and see what happens. If I can figure out how to make it work at all, it ought to be quite good. Whoops, better make that adapter with a Y-setup, or the mp3 player will get left out. Can't be having that, ya know... Richard Pike MKIII N420P (420ldPoops)
Richard
Rick Neilsen
Richard Pike
Subject: Ms Dixie update2
Date: Jul 04, 2007
Sheesh guys Ms. Dixie update1 post grew to 2600 views so lets start over ok? Went to LUL this morning at 5:30am to beat the heat. After last sundays first test flight to work on the 2 Major in-flight problems. 1. was RPM's on the EIS. Sure enough the "tach R/PR" was factory set at 0 and is supposed to be set at 1 for the 912 4cyl. That would explain Charleys 85 mph indacated air speed at 1400 rpm LOL. Second was why the AIS was sitting on 60 mph after we got back to the hangar and full stop. After she cooled off the ASI dropped to zero?????? Well found out what was causing that today.... When I got to the Hangar this morning the ASI was reading 60 mph! Who had been flying our airplane? after i pulled the nose cone i found the static port line to the static circut had been kinked and collapsed due to the heat and the thinwall of the tubing as a result of not enough radius. DOPE! What a first test flight to lose RPM and ASI!!! My only credit has to go to Charley! Damn good seat of the pants flying! -------- Paul Petty Kolbra #12 Ms Dixie 912 UL 70" warp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122245#122245 Attachments: http://forums.matronics.com//files/p7040042_656.jpg ________________________________________________________________________________
Date: Jul 04, 2007
Im still learning, but I have a MK - III Xtra with a 912 S. I used to approach at 60 mph, idle power, and flare and bleed the last bit of speed. Since putting VG's on, it is very confortable to approach at 50 and no need to goose the power in the flare, it keeps flying until stalling at 28 indicated. I could fly the approach at 40, aileron control is good right until the stall, but it is just better to be carrying a little extra speed on approach for normal conditions. For very short field, I would use flaps and drag it in at a very low speed, and chop the power right at the runway, but I would NOT make this normal practice. I would suggest that you learn to land without power, because one day that engine will quit on you when you pull the power back, and you want to be high enough to make the field when that happens. My technique is to stay high, and pull the power to idle for a 60 MPH glide to the runway. That way if the motor quits, it will still be a normal landing for me. No getting caught to low to make the runway no matter what happens. -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122246#122246 ________________________________________________________________________________
Date: Jul 04, 2007
HAHA Rick! Some of us don't need to cut pipe, weeds or cement blocks with their props. Some of -------- Paul Petty Kolbra #12 Ms Dixie 912 UL 70" warp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122252#122252 ________________________________________________________________________________
Date: Jul 04, 2007
> The Powerfin prop will give more thrust than a warpdrive, has alot less inertia and will break off if it srikes something substatial instead of causing gearbox or engine problems. I think even a warpdrive pilot would do a prcautionary landing after a propstrike. How rugged do you want the prop to be? Can you live with the trade offs? > > Rick Neilsen > Hi Rick: Curious about the Powerfin producing more thrust than a Warp Drive. Where did you discover that info? What is the major advantage of less inertia? My Warp Drive is well within the safe operating parameters of Rotax for my 912ULS. I want my prop to be rugged enough to get me home, no matter what the circumstances. During an extreme emergency situation, my least concerns are whether I am damaging the prop, gear box, or engine. I want something to get me to a safe landing spot so I can get "me" back on the ground. I can always repair or replace the mechanical stuff. I have had good luck with the Warp Drive. Seen it demonstrate its toughness and its performance. I can back that statement up with many, many hours of very realiable performance over some very long distances and over some mighty hostile terrain and ice water. Whether or not that other prop produces more thrust than my Warp Drive, I don't care. I get all the thrust I can handle with what I have. ;-) Take care, -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122269#122269 ________________________________________________________________________________
Date: Jul 04, 2007
Tim W: No such thing as "perfect landings". Survivable is more like it. ;-) Approach speed really doesn't matter as long as you have enough that you do not run out of inertia at the bottom when you do a "little" flare. 10 mph over stall works pretty good for me, but I can screw one up at any speed. The main thing for me to remember is LOOK DOWN TOWARDS THE END OF THE RUNWAY AND NOT AT THE GROUND TO SHOOT THE LANDING. If it is a wheels landing, make sure you plant the nose and hold it down. If the tail drops a little when the mains touch, it will balloon and get really interesting. Full stall 3 point landing needs to be done with the mains a few inches off the ground. When it stalls, it is going to drop. The lower the mains to the ground when it drops the easier the landing. I know, I know, you guys with VG's don't have to worry about dropping because the VG's do not allow that type action. ;-) If I get out there and play with the airplane, spend a lot of time doing "stuff", different stuff, shoot a buncha landings, eventually, all this work will come together and I'll start telling the airplane what to do instead of it telling me what to do. Also, I use my flaps all the time. Very seldom do I not use them for landing. Occassionally, use them for getting out of rough, soft, short, high altitude strips. Take care, -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122271#122271 ________________________________________________________________________________
Subject: Re: Kolb Firefly
Date: Jul 04, 2007
Alot of fellas are of course asking this same question, and as for your critera of value, that of course depends soley on the target market you plan to sell into. I understand all the "positives" stated here for registering, and cannot argue with a single one, that is if you intend to sell to a LICENSED pilot. I also have been in this hobby since prior to part 103 and as a dealer for the aircraft that spawned in the begining, the ability to fly one with no license, not have to get inspections and pay all the expenses that go with a FAA registered aircraft were the top of the sales pitch, and the Top of the buyers interests. The Kolb FireFly is an aircraft that has been demonstrated that in CAN be built Part 103 compliant, unlike alot of other single seaters that cannot be built any other way than what we call a "Fat" today. I might project that those "other" Fat's and obviously training exempted 2 seaters have been the ones living on borrowed time for years and they probably need to get registered. Thay are not the subject of this question. A Kolb FireFly is. If a FireFly today weighs 275 lbs empty and has no N-number, it is illegal. If a Firefly weighs 275 empty in 2009 and has no N-number, it is still illegal. It will violate the exact same rule. It will not be breaking a "NEW" rule. ( discounting the float and chute rules, of course) Here are the questions I think need to be answered accurately before a conclusion can be drawn about weather or not we will increase the value of our ultralites by 600 bucks by transitioning them to E-LSA, or will they suddenly be a worthless pile of tube and fabric. Will the market for 103 eligible aircraft cease to exist after 2008? There are No changes to part 103 and Part 103 eligible air vehicles are defined as NOT regulated. (Remember that the entire meaning of part 103 is the description of what the FAA defines as NOT an aircraft, but an unregulated air vehicle) Are most participants in 103 craft today flying them because they just like 254 lb aircraft, or because they dont want to get a pilot license and keep it up.? How much of the potential market will want to buy an aircraft that is regulated by the FAA, and requires all the yearly expense's that will allow them to keep flying? Will the FAA suddenly begin to start sending officers into the feild with scales to determine what a aircraft weighs? Will the FAA begin to train representatives on the details of all the single seat craft marketed in the past as "ultralites"...hmmm..25 years or so back, that could in fact be built under 254 lbs empty, and teach the reps which ones really didnt have a chance? So they can identify them by sight, and not with a set of scales. Some of these questions can be answered pretty obviously, but others cannot. Particularly the questions about how the target market will split. Those are really the keys to the answer, and I wish I knew for sure. I would say this in retrospect. Register it or not, the Financial Hit a builder of a FireFly might or might not take will be likely alot less than the cost of building...less the resale value of any Experimental, Ultralite, HotRod, race car or other Homebuilt toy. So dont fret on it too much! -------- Don G. Central Illinois Kitfox IV Speedster Luscombe 8A http://www.geocities.com/dagger369th/my_firefly.htm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122279#122279 ________________________________________________________________________________
Date: Jul 04, 2007
Perhaps the MKIII Xtra has different elevators and stabilizers than the MKIII Classic that give it more control authority, don't know, but here's what I do know - If I am carrying a full size passenger in my MKIII Classic and shoot the approach at 45 or less, I better not have any flaps down, because there is not enough control authority at that speed to flare. Guess how I know this? Adding back stick just before touchdown changes nothing. Navy carrier arrival, big time. Solo is ok, two up, make the approach at 60. Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Wednesday, July 04, 2007 5:08 PM Subject: Kolb-List: Re: Mark 3 classic landing speed > > Im still learning, but I have a MK - III Xtra with a 912 S. I used to > approach at 60 mph, idle power, and flare and bleed the last bit of speed. > Since putting VG's on, it is very confortable to approach at 50 and no > need to goose the power in the flare, it keeps flying until stalling at 28 > indicated. I could fly the approach at 40, aileron control is good right > until the stall, but it is just better to be carrying a little extra speed > on approach for normal conditions. >> ________________________________________________________________________________
Subject: Prop Comparison
Date: Jul 05, 2007
John Steve Bennet at Great Plains Aircraft told me he did a test of Warpdrive, Ivo and Powerfin props a few years ago. He tried to make it as close to a apples to apples test as he could. The report I got was that Powerfin produced the most thrust followed by Warpdrive then by a larger margin Ivo. He also found that Warpdrive had the most inerita by a wide margin then Ivo then fairly close was Powerfin. Again I'm only telling you what I was told from what I consider a reliable source. I don't have any more details than this. Like you I have only flown one of these props and the Powerfin has server me well. It also has taken some abuse and got me home. I origionally selected the Powerfin prop because it had good thrust performance and maybe more importantly its low inerita. My old VW redrive was incompatible with heavy props. The new redrive appears to tolerate heaver props. Not everyone has the same engine/gearbox as you so others might want or need a lighter prop or more thrust. I'm not tring to talk you into changing props or anyone else. I'm just trying to provide a balance to the prop selection process. I did fly a wood prop on my direct drive VW powered MKIIIC and turned one prop into tooth picks when the prop struck a tree branch were it was about 1/8 inch dia. For that reason I will never own a pusher with a wood prop. Rick Neilsen Redrive VW powered MKIIIC -------------- Original message -------------- From: "John Hauck" <jhauck(at)elmore.rr.com> > > > > The Powerfin prop will give more thrust than a warpdrive, has alot less > inertia and will break off if it srikes something substatial instead of causing > gearbox or engine problems. I think even a warpdrive pilot would do a > prcautionary landing after a propstrike. How rugged do you want the prop to be? > Can you live with the trade offs? > > > > Rick Neilsen > > > > > > Hi Rick: > > Curious about the Powerfin producing more thrust than a Warp Drive. Where did > you discover that info? > > What is the major advantage of less inertia? My Warp Drive is well within the > safe operating parameters of Rotax for my 912ULS. > > I want my prop to be rugged enough to get me home, no matter what the > circumstances. During an extreme emergency situation, my least concerns are > whether I am damaging the prop, gear box, or engine. I want something to get me > to a safe landing spot so I can get "me" back on the ground. I can always > repair or replace the mechanical stuff. > > I have had good luck with the Warp Drive. Seen it demonstrate its toughness and > its performance. I can back that statement up with many, many hours of very > realiable performance over some very long distances and over some mighty hostile > terrain and ice water. > > Whether or not that other prop produces more thrust than my Warp Drive, I don't > care. I get all the thrust I can handle with what I have. ;-) > > Take care, > > -------- > John Hauck > MKIII/912ULS > hauck's holler, alabama > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122269#122269 > > > > > > > > > >
Rick Neilsen
> > Rick Neilsen
> Hi Rick:
> What is the major advantage of less inertia? My Warp Drive is well w ithin the
> Take care,
Subject: Re: Prop Comparison
Date: Jul 04, 2007
Just FWIW, I've flown all these props and my general finding about them is about the same - powerfin F model gives the best thrust, warp drive really close, IVO behind the others. Not rocket science on why, either. The Powerfin F model has the most blade area for a given length, but is also thicker. So, that blade will generate more lift, but at a lower AOA. This makes it not so good on a faster plane, since it "unloads" more at higher airspeeds. This was definitely true on my FS II, my powerfin 68" 3 blade outclimbed the warp drive 68" by a small bit, but unloaded pretty good in the air. The warp drive, though, gives the best overall performance, good thrust but doesn't unload as bad in the air. It has a little less blade area, so blades run at a little higher AOA.. The IVO gives slightly less thrust than the other two, but works great in 2 blades on a fast plane (60mph or more). I'm not 100% sure why this is, though I suspect the blades change pitch in the air, maybe increase in pitch a little once you get up to speed. I have the adjustable pitch medium IVO on my titan and, well, that's the best thing since sliced bread for me prop-wise ;)... But the warp drive is the best prop overall on my FS II.... As for MOI, the warp drive is the highest, followed by the IVO and the powerfin is the lightest. The 912 gearbox, though, supports a pretty high MOI, if I recall my reading in the manuals correctly. I saw a figure around 10,000 kg/in I think... almost twice the figure for the 2-stroke C box.... So you can spin quite a monster on the 912... The main advantage to lower MOI is throttle response. It's quick in any event on the 912, but a low MOI prop like the powerfin vs a heavy one like the warp drive makes a BIG difference here on a 2-stroke... LS [quote="neilsenrm(at)comcast.net"]John Steve Bennet at Great Plains Aircraft told me he did a test of Warpdrive, Ivo and Powerfin props a few years ago. He tried to make it as close to a apples to apples test as he could. The report I got was that Powerfin produced the most thrust followed by Warpdrive then by a larger margin Ivo. He also found that Warpdrive had the most inerita by a wide margin then Ivo then fairly close was Powerfin. Again I'm only telling you what I was told from what I consider a reliable source. I don't have any more details than this. Like you I have only flown one of these props and the Powerfin has server me well. It also has taken some abuse and got me home. I origionally selected the Powerfin prop because it had good thrust performance and maybe more importantly its low inerita. My old VW redrive was incompatible with heavy props. The new redrive appears to tolerate heaver props. Not everyone has the same engine/gearbox as you so others might want or need a lighter prop or more thrust. I'm not tring to talk you into changing props or anyone else. I'm just trying to provide a balance to the prop selection process. I did fly a wood prop on my direct drive VW powered MKIIIC and turned one prop into tooth picks when the prop struck a tree branch were it was about 1/8 inch dia. For that reason I will never own a pusher with a wood prop. Rick Neilsen Redrive VW powered MKIIIC [quote]-------------- Original message -------------- From: "John Hauck" > > > > The Powerfin prop will give more thrust than a warpdrive, has alot less > inertia and will break off if it srikes something substatial instead of causing > gearbox or engine problems. I think even a warpdrive pilot would do a > prcautionary landing after a propstrike. How rugged do you want the prop to be? > Can you live with the trade offs? > > > > Rick Neilsen > > > > > > Hi Rick: > > Curious about the Powerfin producing more thrust than a Warp Drive. Where did > you discover that info? > > What is the major advantage of less inertia? My Warp Drive is well w ithin the > safe operating parameters of Rotax for my 912ULS. > > I want my prop to be rugged enough to get me home, no matter what the > circumstances. During an extreme emergency situation, my least concerns are > whether I am damaging the prop, gear box, or engine. I want something to get me > to a safe landing spot so I can get "me" back on the ground. I can always > repair or replace the mechanical stuff. > > I have had good luck with the Warp Drive. Seen it demonstrate its toughness and > its performance. I can back that statement up with many, many hours of very > realiable performance over some very long distances and over some mighty hostile > terrain and ice water. > > Whether or not that other prop produces more thrust than my Warp Drive, I don't > care. I get all the thrust I can handle with what I have. ;-) > > Take care, > > -------- > ====== =============== > > > [b] -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122309#122309 ________________________________________________________________________________
Date: Jul 05, 2007
Hi Tony, sounds as though you are a busy guy. An AJS and a Triumph. REAL motorbikes. Good on ya. I flew a Blanik out of Auckland and a K13 from Matamata in Jan and Feb 1975. Only got a scrape along the ridge at Matamata as a check flight because with immaculate timing I arrived just as the Nationals , or maybe the World Champs, I forget, were starting. No one really wanted to get involved in anything but the competitions. Understandable. According to my log book I was charged $3 plus 7c a minute. No idea why I made a note of that. Its the only reference to cost in my log books. I have flown a Harvard (T6) out of Hood and flown with Captain Ladd out to Kowai (sp) Island from Auckland. Do you remember Captain Ladd? He ran amphibian charters. "A shower of Spray and we are away" One super evening a guy who was operating an amphibian off the beach in the Bay of Islands took Wendy and I on an hours trip around the Bay. He let me pole it around and fly an approach down to wave top height before taking over just as we touched the surface. Great memories! The plane was supposedly the one which flew under the Auckland Bridge, the one with the Nippon Clip-on. The pilot argued that it was an extended take off run and got away with it. Just missed the Wings over Wanaka, twice, which shows very poor planning but did get a look at the maintenance hangars where they were working on the planes for W over W the following week. Not likely to get to NZ again. I like long distance flying less and less as I get older and my old diving buddy who I visit in Auckland is getting a bit long in the tooth as well but there is a Rotary exchange trip scheduled for 2009 and you never know. I really envy you flying in NZ. Must be one of the best places to fly in the world and everything so close together. Ski in the morning, surf in the arvo and fly in the evening. What could be better? Cheers Pat ________________________________________________________________________________
Subject: Re: Mark 3 classic landing speed
Date: Jul 05, 2007
Yep you are onto it. We do have a bit of fickle weather from time to time that keeps you on your toes.If you find your way over here again please make contact. Irrespective of the time of year there is always something to do. I have only missed one W over W myself. It takes place over Easter and Easter also happens to be about the last good boating weather over here.I happen to camp about 1 hours drive from Wanaka so its a no brainer really.Also about 10 miutes from Omarama I think the World gliding champs are there again this year. Sounds like you have far more experience at this aviating than me. The T6 or Harvard as we know it would have been a fun thing . Ultralights are where I started and apart from poling around a bit in some home builts and cubs that's what I have stuck too.Already have too many other things on the go.I do have plans to travel to the UK just not sure when, I would like to see some maritime history as well as some aviation history. That is the one thing we do not have a lot of {Old history} I do assist in some mechanical work for the local aviation heritage people from time to time.They have some Richard Pierce replicas and engines ,a collection of early ultralights, a Tiger moth and a Chipmunk on display.The debate still go's on as to if he flew before the Right Bros.I did go to Oshkosh in 94 ,now that's a must ,great experience. As for the long in the tooth bit the guy that keeps me honest in the air is about 76 and still training pilots, he also has family in LA so spends some time over there. I hope to have as much go at that age.{ not far away } But I understand where you are coming from its no fun sitting in the back of one of those people movers. The only view is the one straight ahead.Bay of Islands is a great place, just completed a tour of the North Island, would loved to have had some wings with me. The Boss said it was her turn to decide on the holiday so just get over it and follow along. Cheers and keep it safe up there Tony ----- Original Message ----- From: pat ladd To: kolb-list(at)matronics.com Sent: Thursday, July 05, 2007 9:39 PM Subject: Re: Kolb-List: Mark 3 classic landing speed Hi Tony, sounds as though you are a busy guy. An AJS and a Triumph. REAL motorbikes. Good on ya. I flew a Blanik out of Auckland and a K13 from Matamata in Jan and Feb 1975. Only got a scrape along the ridge at Matamata as a check flight because with immaculate timing I arrived just as the Nationals , or maybe the World Champs, I forget, were starting. No one really wanted to get involved in anything but the competitions. Understandable. According to my log book I was charged $3 plus 7c a minute. No idea why I made a note of that. Its the only reference to cost in my log books. I have flown a Harvard (T6) out of Hood and flown with Captain Ladd out to Kowai (sp) Island from Auckland. Do you remember Captain Ladd? He ran amphibian charters. "A shower of Spray and we are away" One super evening a guy who was operating an amphibian off the beach in the Bay of Islands took Wendy and I on an hours trip around the Bay. He let me pole it around and fly an approach down to wave top height before taking over just as we touched the surface. Great memories! The plane was supposedly the one which flew under the Auckland Bridge, the one with the Nippon Clip-on. The pilot argued that it was an extended take off run and got away with it. Just missed the Wings over Wanaka, twice, which shows very poor planning but did get a look at the maintenance hangars where they were working on the planes for W over W the following week. Not likely to get to NZ again. I like long distance flying less and less as I get older and my old diving buddy who I visit in Auckland is getting a bit long in the tooth as well but there is a Rotary exchange trip scheduled for 2009 and you never know. I really envy you flying in NZ. Must be one of the best places to fly in the world and everything so close together. Ski in the morning, surf in the arvo and fly in the evening. What could be better? Cheers Pat ------------------------------------------------------------------------- ----- 3/07/2007 10:02 a.m. ________________________________________________________________________________
Date: Jul 05, 2007
Sounds like you have far more experience at this aviating than me. >> Hi Tony, probably not. Only licenced for gliders and ultralights but I have found most pilots will let you fly if you have any idea at all. I got a ride in a Jet Provost that way. The pilot asked if I flew and when I said only microlights he said `Take her out then` and apart from raising and lowering the undercarriage he didn`t touch the controls until we parked it. Same with a P-51 in Kissimmee, except that the pilot did the takeoff and took the controls for a take off after I had landed it and he changed it to a touch and go. Cheers Pat ________________________________________________________________________________
Subject: Re: Federal Regulations
Date: Jul 05, 2007
Richard Girard, et al; About the best description and explanation of the situation that I've ever heard. Thank you. Would hope that this gets plastered everywhere ANY pilot might see it, regardless of the rating or category. Been flying since 1974. Never held a PPL. Began flying UL's in 1984 (as my USUA affirmation will attest) and will continue to fly UL's 'til I can no longer do so, safely. Again, thanks for one of the best, informative, very easily understood, explanations of the frivolous, dangerous and damaging activities (not to mention illegal) that affect all of the aviation world. Your 'prime example' of the fellow in Seattle was all too easily recognized. About the best commentary I've ever seen, on ANY of the dozen lists, that I lurk/monitor. Blue Skies, George Bass USUA 80399 ________________________________________________________________________________
Date: Jul 05, 2007
Subject: Federal Regulations, WAS Kolb Firefly
Date: Thu, 5 Jul 2007 08:02:54 -0500 From: "Richard Girard" <jindoguy(at)gmail.com> ..................... "WE HAVE A LIST OF THOSE PLACES AND WE WILL BE THERE THE MORNING OF FEBRUARY 1ST, 2008". So much for the theory of what will they do, show up with scales? They don't have to, they can simply seize suspected aircraft and it will be up to the owner to bring the scales and prove them wrong. Don't even bother if the aircraft has a second seat. ..................... Rick and FireFlyers, The following document has been declared as sufficient proof that your FireFly is an ultra light vehicle: http://www.thirdshift.com/jack/firefly/fireflylegal.html I carry a copy to all fly-ins. The front page was signed by an A&E and each page carries his initials. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jul 05, 2007
Subject: Re: Federal Funding
At 11:55 AM 7/3/2007, Robert Laird wrote: > >By default, any airport designated as public is required to allow any >aircraft to use it's services. This includes ultralights. (If a >private airport, designated for public use, has never taken federal or >state funding, then they have the right to deny services... That's where the issue may arise. Many airports are "privately owned for public use", and if these have received no federal funding they can deny landing to anybody, not just ultralights. The airport I used to call home (N04, now sadly closed) was such an airport. It was ultralight friendly, actually friendly to any aircraft that could deal with its 1800' strip, but required prior permission (which was always granted) from ALL transient aircraft. Many small airports were originally WWII training or auxiliary fields. That qualifies as "receiving federal funding" even if the original acquisition was the only dealing with the feds. -Dana -- -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Date: Jul 05, 2007
At 11:15 AM 7/4/2007, flymichigan(at)comcast.net wrote: > >I find all this talk about enforcement a little strange. The FAA has >never seemed to care about overweight ultralights and I have seen no >evidence that they will start after January...I have spoken off the record >with a two FAA officials, and they have not received any mandate to step >up enforcement... Depends on who you talk to. I have heard (secondhand, but from a reliable source) is that the FAA plans to small airports where there has traditionally been lots of ultralight activity and/or complaints and ramp check everything in sight. Not everywhere, they don't have the manpower, but scattered pot shots to make a few examples. -Dana -- -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Subject: Legal FireFly??or not??
Date: Jul 05, 2007
Jimmy, Back to your question about the worth of a "fat" firefly. What would it cost to bring it back under 103 compliance?..add that to the equasion. More than registering it? this is what I think...not what I know..just what I think...maybeee... A legal 103 FireFly might have more value than a non-registered "fat" one. A 503 Firestar that never had a chance of making 254 lbs unless you left the wing off...will be worth more legal as an E-LSA than not. Same with Challengers and 503 Titan I's and so on. There is no "NEW " rule that makes all fat ultralites now illegal,,,they always were. They were all required to be registered as an Experimental before...now there is just a new rule that allows them to be easily "transitioned" to a E-LSA. This is the "manna from above" as just someone mentioned. No hassle...no documentation...dont even have to be the original builder. This is a good thing....make that a GREAT thing. For all those birds that have no chance of making 103. You just need to decide if that FireFly will appeal in the resale market to licensed sport pilots...or non-licensed Ultralite pilots. I am thinking it would be more appealing..therefore worth more...to ultralite pilots. I certainly dont know this for sure....I just think maybee!!!!!! IN fact...all legal 103 craft might just get a boost in the market appeal... maybeeee! -------- Don G. Central Illinois Kitfox IV Speedster Luscombe 8A http://www.geocities.com/dagger369th/my_firefly.htm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122436#122436 ________________________________________________________________________________
Subject: Re: Federal Regulations, WAS Kolb Firefly
Date: Jul 05, 2007
Date: Jul 05, 2007
Subject: Re: Kolb Flyer
At 07:33 PM 6/30/2007, grabo172 wrote: > >Just saw this on TNK website! Any idea on a price? > >http://www.tnkolbaircraft.com/index.html Looks just like every other updated Cessna 150 clone in the LSA rush... you'd think an offering from Kolb would be, well, more "Kolb-ish". -Dana -- -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Date: Jul 05, 2007
Rick This M3X will have the flaps. I will look in the archives, if I can figure out how to get there. Rick [quote="neilsenrm(at)comcast.net"]Rick Are you getting the MKIIIX with flaps or flaperons? Check the archives for considerable discussion of the differences and advantages. Rick Neilsen Redrive VW powered MKIIIC [quote]-------------- Original message -------------- From: "Rick2" I am new to this forum and will be picking up my plane kit this Thursday, July 5th. I am going to build the M3x and install a VW engine. The Kolb people are working with me on the engine mounts with the help of Rick Neilson. I will talk more on the engine situation as things progress. My main concern for now is the plans. Donnie, from Kolb, gave me my set of plans early while they got the kit together. This is not my first plane I will be building, in fact it's the third. The first was a Cozy, wide body Long Ezy, which was strickly a plans built aircraft ( not a kit ). The second was a Glastar. Now the third will be the M3X, tha t is i ics Li > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122458#122458 ________________________________________________________________________________
Date: Jul 05, 2007
In a message dated 7/3/2007 12:32:19 PM Eastern Daylight Time, jim@tru-cast.com writes: ( 1) Tanks which have a permanent standpipe or venting arrangement to control capacity are permitted, but may be subject to demonstration of the capacity if there is any reason to doubt that the arrangement is effective. . . . So carrying extra fuel is permitted, so long as it is not usable in flight. As long as the extra fuel is not plumbed into the aircraft fuel system I think you'll be OK. Oh, if it were only so...... Howard Shackleford FS II SC ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 05, 2007
Kill one, send message to thousands. Old Chines proverb Rick On 7/5/07, HShack(at)aol.com wrote: > > In a message dated 7/3/2007 12:32:19 PM Eastern Daylight Time, > jim@tru-cast.com writes: > > ( 1) Tanks which have a permanent standpipe or venting arrangement to > control capacity are permitted, but may be subject to demonstration of the > capacity if there is any reason to doubt that the arrangement is effective. > > . . . So carrying extra fuel is permitted, so long as it is not usable in > flight. As long as the extra fuel is not plumbed into the aircraft fuel > system I think you'll be OK. > > > Oh, if it were only so...... > > Howard Shackleford > FS II > SC > > > ------------------------------ > See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503>. > > > * > > > * > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Jul 06, 2007
At 10:57 PM 7/5/2007, R. Hankins wrote: >I believe that Sport Pilot was more a response to EAA pressure to allow >thousands of aging pilots to fly without a medical, than an effort at >public protection... There was also pressure on FAA to end "rulemaking by exemption", which was what the BFI program was. -Dana -- -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Date: Jul 06, 2007
Thanks everyone for the feed back on the plans. Donnie and Travis are pretty upset about them also. I can see why there upset sence it's out of there hands and can't change them thereselves. They work so hard with everyone and will go out of there way to make the customer happy but yet here's something out of there control. I know most of you don't live close enough to the factory to visit and get to know them but even when you talk with them at the fly-in's you leave with a good feeling about the plane and Kolb Factory. I've got my kit now and kinda figured out the plans so I'm ready to start. I really don't exspect any problems but I know if I have questions or get confused, I have this forum and the guy's at Kolb. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122491#122491 ________________________________________________________________________________
Subject: Re: Legal FireFly??or not??
Date: Jul 06, 2007
Howdy Fellas, If you're selling the Firefly, you can always put the OEM items back on I.e. small tires, minimal instrument panel, etc. Get it legal and include the "extras" with the sale. A firefly built by the books, with attention to the paint especially, should easily fall within limits. Best Regards, Guy Morgan Evergreen Helicopters 2001 Terminal Dr. Galveston, TX 77554 work: (409) 740-0231 cell: (409) 692-2864 ----- Original Message ----- From: "Don G" <donghe@one-eleven.net> Sent: Thursday, July 05, 2007 6:50 PM Subject: Kolb-List: Legal FireFly??or not?? > > Jimmy, > Back to your question about the worth of a "fat" firefly. > > What would it cost to bring it back under 103 compliance?..add that to the > equasion. More than registering it? > > this is what I think...not what I know..just what I think...maybeee... > > A legal 103 FireFly might have more value than a non-registered "fat" one. > > A 503 Firestar that never had a chance of making 254 lbs unless you left > the wing off...will be worth more legal as an E-LSA than not. > Same with Challengers and 503 Titan I's and so on. > > There is no "NEW " rule that makes all fat ultralites now illegal,,,they > always were. They were all required to be registered as an Experimental > before...now there is just a new rule that allows them to be easily > "transitioned" to a E-LSA. > This is the "manna from above" as just someone mentioned. > No hassle...no documentation...dont even have to be the original builder. > This is a good thing....make that a GREAT thing. For all those birds that > have no chance of making 103. > > You just need to decide if that FireFly will appeal in the resale market > to licensed sport pilots...or non-licensed Ultralite pilots. > > I am thinking it would be more appealing..therefore worth more...to > ultralite pilots. > I certainly dont know this for sure....I just think maybee!!!!!! > > IN fact...all legal 103 craft might just get a boost in the market > appeal... > maybeeee! > > -------- > Don G. > Central Illinois > Kitfox IV Speedster > Luscombe 8A > > http://www.geocities.com/dagger369th/my_firefly.htm > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122436#122436 > > > ________________________________________________________________________________
Date: Jul 06, 2007
I couldn't agree with you more. I ordered a Mark III but changed it to the "Xtra" when that design came out. I have the old plans and manual, the later manual and the latest plans. I also have found that the plans have gone downhill. The plans were redone but not improved, they have in fact gone the other way. They have many more mistakes and good tips that were in the previous plans and manuals have been left out. I have also talked the TNK guys about this and apparently it is out of their hands. It's a shame because the original plans and manual were in general very good in my opinion. The good thing is that the guys on the list are very helpful and you couldn't ask for better people to work with than Travis and Donnie at TNK. Rex Rodebush (42 years of mechanical design) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122506#122506 ________________________________________________________________________________
Date: Jul 06, 2007
Having followed and been significantly affected by, "Sport" issues, the most gifted presenter in the world would have a hard time convincing me that the real truth was anything other than the medical AND carrying a passenger. Issues like ".... public protection...." and "....rule making by exemption...." were positions that could be put out for public consumption, but not, IMO, sound arguments for the way it all came down. DL as a validation of the medical requirements to operate anything????????? For those of you who don't know...... I live in Florida! My 2 cents worth! (Which is about all that was left after I jumped through the hoops!) George Alexander Sport Pilot N709FS d-m-hague(at)comcast.net wrote: > At 10:57 PM 7/5/2007, R. Hankins wrote: > > > > I believe that Sport Pilot was more a response to EAA pressure to allow > > thousands of aging pilots to fly without a medical, than an effort at > > public protection... > > > > > > There was also pressure on FAA to end "rulemaking by exemption", which was > what the BFI program was. > > -Dana > > -- > -- > The only correct outcome to an armed robbery attempt is a dead armed robber. -------- George Alexander http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122508#122508 ________________________________________________________________________________
Subject: E LSA vs E AB
Date: Jul 06, 2007
A few years ago I bought an Un-registered Twinstar. To make it legal I got it inspected and N numbered as an Exp. Amatuer Built with the actual builder listed on the documents. Now with the Exp LSA option available, I wondering if there is any way to change the registration to Exp LSA so that I would be able to perform the annuals? Dave Nagy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122561#122561 ________________________________________________________________________________
Date: Jul 06, 2007
Subject: Re: E LSA vs E AB
Dave, The grandfathering rules in FAR 21.191 specifically states that the aircraft must not have been previously certificated. Rick On 7/6/07, davenagy wrote: > > > A few years ago I bought an Un-registered Twinstar. To make it legal I got > it inspected and N numbered as an Exp. Amatuer Built with the actual builder > listed on the documents. Now with the Exp LSA option available, I wondering > if there is any way to change the registration to Exp LSA so that I would be > able to perform the annuals? > > Dave Nagy > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122561#122561 > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Jul 06, 2007
Subject: fuel problem I think?
Hello gang, Looking for information and advice. We have a firestar ll with a 503 rotax, dual ignition, dual carbs, pull start, no battery, Grandson experienced a engine problem which is described as engine rpm=99s dropped off , engi ne was not running rough nor sounded or felt rough when rpm dropped, engine rpms came right back up without engine stopping. He had been airborne about 5 minutes when this happened, He came back in and landed and the engine ran ok after the problem. We checked things over, pulled the carb bowls and things looked o k. He took off and flew about a hour with no engine problem. I later flew abou t a hour with no problem. A few days later I decided to take a little pitch o ut of prop to gain more rpm=99s on take off and after warming up engine and testing mags I took off to experience the same problem he had, but i was at about 300=99 , Rpm=99s dropped a lot to the point I thought it was go ing to quit. It did this about 3 times before I got in back on the runway. It acted to me l ike the engine was running out of fuel and then would get enough fuel to run ok . I checked everything out found nothing wrong and decided to take off again. Engine again had same problemJust like prior takeoff. This convince d me to put it in the hangar and fix the problem. The fuel system is described as follows. I have all nearly new gas lines, plastic, and recommended type, he avy type pulse line. Pulse pump was rebuilt about 40 hours ago, , gascolater sc reen is clean , fuel filter with about 20 hours. Primer bulb was new this spring and has bypass , also a primer in the system. Fuel comes out of the bottom of 2 5gal tanks. Tank filler caps are vented. We are fussy about our fuel and it goes thru a mr funnel when filling the tanks. Carbs rebuilt about 30 hours ago. I have found nothing wrong from inspection except the pulse pum p has no weep hole as recommended, also pulse line does not go below pump to form trap as recommended. So we are going to put on new pump with weep hole and correct the pulse line, new fuel filter and test fly it. I wonder about this also: the pulse pump is about 31=9D about the bottom of the tank s and the length of pulse line is 12=9D long. Pump specs call for maximum ris e of 39=9D.So we are close to the maximumI am considering a electric fuel pump r unning off the engine electrity, not battery and being plumbed in series, not parallel. I know that some recommend the electric pump be installed in para llel, but this is a lot more complicated and messy.and is it really necessar y?? Sorry for such a long post.but thanks for your thoughts and input will let you know what happens. Jim Swan firestar ll 503 michigan ************************************** See what's free at http://www.aol.com . ________________________________________________________________________________
Date: Jul 06, 2007
Thanks Rick! Now I know at least I didn't miss the chance! Dave Nagy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122579#122579 ________________________________________________________________________________
Subject: Re: fuel problem I think?
Date: Jul 06, 2007
Jim, ask yourself, What changed with the plane since your last uneventful flights, did you add fuel? if so, check the source/Quality. In other words, I think that your plan you mentioned in the post is the correct course of action.. Can you extend the fuel hose from the carb, , route the hose extension from there back to a fuel can on the ground under the plane & see if you can get the fuel to siphon back close to the ground? If so, it's probably not the fuel system/& or clogged filter. How about the jetting, ? small piece of dirt that gets released when RPMs/suction drop? & so on. Like I said, I think you`re on the right track already. Jim ----- Original Message ----- From: Arksey(at)aol.com To: kolb-list(at)matronics.com Sent: Friday, July 06, 2007 7:32 PM Subject: Kolb-List: fuel problem I think? Hello gang, Looking for information and advice. We have a firestar ll with a 503 rotax, dual ignition, dual carbs, pull start, no battery, Grandson experienced a engine problem which is described as engine rpm=99s dropped off , engine was not running rough nor sounded or felt rough when rpm dropped, engine rpms came right back up without engine stopping. He had been airborne about 5 minutes when this happened, He came back in and landed and the engine ran ok after the problem. We checked things over, pulled the carb bowls and things looked ok. He took off and flew about a hour with no engine problem. I later flew about a hour with no problem. A few days later I decided to take a little pitch out of prop to gain more rpm=99s on take off and after warming up engine and testing mags I took off to experience the same problem he had, but i was at about 300=99 , Rpm=99s dropped a lot to the point I thought it was going to quit. It did this about 3 times before I got in back on the runway. It acted to me like the engine was running out of fuel and then would get enough fuel to run ok. I checked everything out found nothing wrong and decided to take off again. Engine again had same problemJust like prior takeoff. This convinced me to put it in the hangar and fix the problem. The fuel system is described as follows. I have all nearly new gas lines, plastic, and recommended type, heavy type pulse line. Pulse pump was rebuilt about 40 hours ago, , gascolater screen is clean , fuel filter with about 20 hours. Primer bulb was new this spring and has bypass , also a primer in the system. Fuel comes out of the bottom of 2 5gal tanks. Tank filler caps are vented. We are fussy about our fuel and it goes thru a mr funnel when filling the tanks. Carbs rebuilt about 30 hours ago. I have found nothing wrong from inspection except the pulse pump has no weep hole as recommended, also pulse line does not go below pump to form trap as recommended. So we are going to put on new pump with weep hole and correct the pulse line, new fuel filter and test fly it. I wonder about this also: the pulse pump is about 31=9D about the bottom of the tanks and the length of pulse line is 12=9D long. Pump specs call for maximum rise of 39=9D.So we are close to the maximumI am considering a electric fuel pump running off the engine electrity, not battery and being plumbed in series, not parallel. I know that some recommend the electric pump be installed in parallel, but this is a lot more complicated and messy.and is it really necessary?? Sorry for such a long post.but thanks for your thoughts and inputwill let you know what happens. Jim Swan firestar ll 503 michigan ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Jul 06, 2007
Jim: Whatever else you check, if it were mine, I'd sure be wanting to yank the exhaust manifold off and look at the pistons and rings for signs of scuffing and possible near-seizure... Had similar symptoms with my Nazi 447once... was carboned-up rings which caused it to almost seize. It bogged down, then recovered for a while and ran normally... I flew on home and cleaned the fuel system...Started it cold and it ran OK... on takeoff it bogged again... I looked into the exhaust ports and instantly saw the problem. I was lucky -- got off with new pistons and a carbuerator choke piston... Could have easily cost me my fanny. Just a thought....Worth what ye paid fer it... Beauford Firefly 076 / N173BW Brandon, FL ----- Original Message ----- From: Arksey(at)aol.com To: kolb-list(at)matronics.com Sent: Friday, July 06, 2007 8:32 PM Subject: Kolb-List: fuel problem I think? Hello gang, Looking for information and advice. We have a firestar ll with a 503 rotax, dual ignition, dual carbs, pull start, no battery, Grandson experienced a engine problem which is described as engine rpm=99s dropped off , engine was not running rough nor sounded or felt rough when rpm dropped, engine rpms came right back up without engine stopping. He had been airborne about 5 minutes when this happened, He came back in and landed and the engine ran ok after the problem. We checked things over, pulled the carb bowls and things looked ok. He took off and flew about a hour with no engine problem. I later flew about a hour with no problem. A few days later I decided to take a little pitch out of prop to gain more rpm=99s on take off and after warming up engine and testing mags I took off to experience the same problem he had, but i was at about 300=99 , Rpm=99s dropped a lot to the point I thought it was going to quit. It did this about 3 times before I got in back on the runway. It acted to me like the engine was running out of fuel and then would get enough fuel to run ok. I checked everything out found nothing wrong and decided to take off again. Engine again had same problemJust like prior takeoff. This convinced me to put it in the hangar and fix the problem. The fuel system is described as follows. I have all nearly new gas lines, plastic, and recommended type, heavy type pulse line. Pulse pump was rebuilt about 40 hours ago, , gascolater screen is clean , fuel filter with about 20 hours. Primer bulb was new this spring and has bypass , also a primer in the system. Fuel comes out of the bottom of 2 5gal tanks. Tank filler caps are vented. We are fussy about our fuel and it goes thru a mr funnel when filling the tanks. Carbs rebuilt about 30 hours ago. I have found nothing wrong from inspection except the pulse pump has no weep hole as recommended, also pulse line does not go below pump to form trap as recommended. So we are going to put on new pump with weep hole and correct the pulse line, new fuel filter and test fly it. I wonder about this also: the pulse pump is about 31=9D about the bottom of the tanks and the length of pulse line is 12=9D long. Pump specs call for maximum rise of 39=9D.So we are close to the maximumI am considering a electric fuel pump running off the engine electrity, not battery and being plumbed in series, not parallel. I know that some recommend the electric pump be installed in parallel, but this is a lot more complicated and messy.and is it really necessary?? Sorry for such a long post.but thanks for your thoughts and inputwill let you know what happens. Jim Swan firestar ll 503 michigan ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Jul 06, 2007
Hi mike, thanks for your suggestion of carb ice...but conditons were not conducive for carb ice at time......but yes it is possible....thanks Mike.... jim swan firestar ll michigan ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 06, 2007
Hi JIm, thanks...yur idea about siphon fuel back to a can is a good way to check resistance in fuel line....thanks.... jim swan firestar ll 503 michigan ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 06, 2007
Subject: New FireFly Tail Wheel Spring System
Kolbers, and FireFlyers, I really wanted to get away from the tension spring and to use a clevis spring. I could not find small light weight clevis springs. After several iterations, I have a new system that uses compression springs in a way that is equivalent to clevis springs. The new system can be seen at: http://www.thirdshift.com/jack/firefly/firefly133.html I believe the FireFly responds better to rudder pedal input than before, especially in grass. Shaved off 1.5 ounces. While I was at it I bushed the holes through which the hinge pin bolt passes. I hope you have a good 7/7/07. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jul 06, 2007
Hi Beauford. thanks.... will check pistons...good thought.....jim swan firestar ll 503 michigan ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 06, 2007
Subject: Re: New FireFly Tail Wheel Spring System
In a message dated 7/6/2007 10:12:00 P.M. Eastern Daylight Time, jbhart(at)onlyinternet.net writes: I hope you have a good 7/7/07 Jack, Make that 07/07/07 BV ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 06, 2007
In a message dated 7/6/2007 11:02:20 P.M. Eastern Daylight Time, ElleryWeld(at)aol.com writes: you might try is pulling the slides out of your carbs and raising the needle one notch, usually I do this in the spring of the year Ellery, Do you mean raise the needle, by lowering the clip in the groove? If so, that would allow more fuel mix (richer). I thought it was better to lean out for the summer because there's less air due to humidity. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 06, 2007
Check the squeeze bulb. Larry C ----- Original Message ----- From: Arksey(at)aol.com To: kolb-list(at)matronics.com Sent: Friday, July 06, 2007 8:08 PM Subject: Re: Kolb-List: fuel problem I think? Hi JIm, thanks...yur idea about siphon fuel back to a can is a good way to check resistance in fuel line....thanks.... jim swan firestar ll 503 michigan ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Jul 07, 2007
Have had similar problem , the problem was the air filter. Take the air filter off and see if RPMs come back to normal. If they do give the filter a good clean . The method I use is hot soapy water and then dry out .I find this needs done about every 25 to 30 hours to prevent occurrence If its fuel starvation that will not help but pulling the chock on when the problem occurs will or should momentarily rectify the problem and point you in the right direction. Tony ----- Original Message ----- From: Arksey(at)aol.com To: kolb-list(at)matronics.com Sent: Saturday, July 07, 2007 12:32 PM Subject: Kolb-List: fuel problem I think? Hello gang, Looking for information and advice. We have a firestar ll with a 503 rotax, dual ignition, dual carbs, pull start, no battery, Grandson experienced a engine problem which is described as engine rpm=99s dropped off , engine was not running rough nor sounded or felt rough when rpm dropped, engine rpms came right back up without engine stopping. He had been airborne about 5 minutes when this happened, He came back in and landed and the engine ran ok after the problem. We checked things over, pulled the carb bowls and things looked ok. He took off and flew about a hour with no engine problem. I later flew about a hour with no problem. A few days later I decided to take a little pitch out of prop to gain more rpm=99s on take off and after warming up engine and testing mags I took off to experience the same problem he had, but i was at about 300=99 , Rpm=99s dropped a lot to the point I thought it was going to quit. It did this about 3 times before I got in back on the runway. It acted to me like the engine was running out of fuel and then would get enough fuel to run ok. I checked everything out found nothing wrong and decided to take off again. Engine again had same problemJust like prior takeoff. This convinced me to put it in the hangar and fix the problem. The fuel system is described as follows. I have all nearly new gas lines, plastic, and recommended type, heavy type pulse line. Pulse pump was rebuilt about 40 hours ago, , gascolater screen is clean , fuel filter with about 20 hours. Primer bulb was new this spring and has bypass , also a primer in the system. Fuel comes out of the bottom of 2 5gal tanks. Tank filler caps are vented. We are fussy about our fuel and it goes thru a mr funnel when filling the tanks. Carbs rebuilt about 30 hours ago. I have found nothing wrong from inspection except the pulse pump has no weep hole as recommended, also pulse line does not go below pump to form trap as recommended. So we are going to put on new pump with weep hole and correct the pulse line, new fuel filter and test fly it. I wonder about this also: the pulse pump is about 31=9D about the bottom of the tanks and the length of pulse line is 12=9D long. Pump specs call for maximum rise of 39=9D.So we are close to the maximumI am considering a electric fuel pump running off the engine electrity, not battery and being plumbed in series, not parallel. I know that some recommend the electric pump be installed in parallel, but this is a lot more complicated and messy.and is it really necessary?? Sorry for such a long post.but thanks for your thoughts and inputwill let you know what happens. Jim Swan firestar ll 503 michigan ------------------------------------------------------------------------- ----- See what's free at AOL.com. ------------------------------------------------------------------------- ----- 6/07/2007 6:36 a.m. ________________________________________________________________________________
Date: Jul 07, 2007
Looking for information and advice>> Whats the weather like? Carb ice? Pat ________________________________________________________________________________
Subject: Re: EXPERIMENTAL
Date: Jul 07, 2007
I want to answer the fellow who wondered if he could reregister his experimental twinstar into the experimental light sport catagory. Not according to the rules. I want to say though that the new rules are making us better liars. I dont see why you couldnt just take your n-numbers off, remove the old id plate and serial number and redo the entire thing. you could litterly make up a new serial number, pretend it is a different plane and go through the hoops. I would advise you to get a different DAR though! Not like it is etched in stone. dont know why anyone would want to go through all the trouble but there you have it. lie like hell. (Of course, I wouldnt tell anyone and of course, I wouldnt do it myself. yeah, right.) Ted Cowan, Alabama. ________________________________________________________________________________
Date: Jul 07, 2007
Yep. Definitely would work. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122633#122633 ________________________________________________________________________________
Date: Jul 07, 2007
I had the same problem with a 503 on a quicksilver a couple years ago that I got a good deal on. Tried 3 different carbs, dozens of settings, 3 different fuel pumps, all new fuel lines & filter and a thunderbird dance. It would give 6000 rpms for 2 to 5 minutes then cut back to 1500 to 2000 for about the same. I could stay up with good thermals but not for too long otherwise. Finally pulled the jugs off. The rings were stuck just a little (if there is such a thing) and there were a couple light scuff marks on both pistons. Also the crosshatching on the cylinder walls was negligible to nonexistent. I purchased the next sized up pistons & rings online, had a local machine shop bore the walls to spec & it flew like a new one until I sold it 200 hours later. I assumed then, & still do, that it was partially seizing until it cooled a little then was good to go until it heated up again. I put about 6 or 8 hours & several =98exciting=99 flights on it that way. George From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Arksey(at)aol.com Sent: Friday, July 06, 2007 7:33 PM Subject: Kolb-List: fuel problem I think? Hello gang, Looking for information and advice. We have a firestar ll with a 503 rotax, dual ignition, dual carbs, pull start, no battery, Grandson experienced a engine problem which is described as engine rpm=99s dropped off , engine was plumbed in series, not parallel. I know that some recommend the electric pump be installed in parallel, but this is a lot more complicated and messy.and is it really necessary?? Sorry for such a long post.but thanks for your thoughts and inputwill let you know what happens. Jim Swan firestar ll 503 michigan _____ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . ________________________________________________________________________________
Date: Jul 07, 2007
I'm getting my Experimental-Amateur Built Minimax ready to sell, and I considered this option. The FAA told me that I could not re-register the airplane. I know it would bring a better price if it was E-LSA because the new owner could attend a mechanic's class and sign off on all of his work. Unfortunately, I am sure the FAA would look at my file history and know what I had done. I'll be losing money on Ebay real soon. Rick Nelson On 7/7/07, tc1917 wrote: > > I want to answer the fellow who wondered if he could reregister his > experimental twinstar into the experimental light sport catagory. Not > according to the rules. I want to say though that the new rules are making > us better liars. I dont see why you couldnt just take your n-numbers off, > remove the old id plate and serial number and redo the entire thing. you > could litterly make up a new serial number, pretend it is a different plane > and go through the hoops. I would advise you to get a different DAR though! > Not like it is etched in stone. dont know why anyone would want to go > through all the trouble but there you have it. lie like hell. (Of course, > I wouldnt tell anyone and of course, I wouldnt do it myself. yeah, right.) > Ted Cowan, Alabama. > > ________________________________________________________________________________
Date: Jul 08, 2007
Subject: Re:Warp Drive
In a message dated 7/4/2007 6:40:18 PM Central Standard Time, jhauck(at)elmore.rr.com writes: > I have had good luck with the Warp Drive. Seen it demonstrate its > toughness and its performance. I can back that statement up with many, many hours of > very realiable performance over some very long distances and over some > mighty hostile terrain and ice water. > > Hi John H., > > I am in need of a prop , as one of the cams broke on my Ivo . I am sold > on the Warp, but I am concerned that it weighs more than the folks from Rotax > recommend. Did you ever run a warp on any B-box 447? I dont want another > Ivo, but I dont want to overstress the B -box, either. Ed Diebel
Date: Jul 08, 2007
I'm not John, but try a two blade 64" Warp, (or be really conservative and use a 62" two blade Warp) and use only Mobil One synthetic in your gearbox, and you'll probably get by without hurting the gearbox, and you'll probably be very satisfied. I got a couple hundred hours out of my B box with a Warp 66" two blade, but that was with ordinary gearbox lube. A shorter prop and better lube and you ought to do OK. Richard Pike MKIII N420P (42oldpoops) ----- Original Message ----- From: DAquaNut(at)aol.com To: kolb-list(at)matronics.com Sent: Sunday, July 08, 2007 12:05 AM Subject: Re: Kolb-List: Re:Warp Drive In a message dated 7/4/2007 6:40:18 PM Central Standard Time, jhauck(at)elmore.rr.com writes: I have had good luck with the Warp Drive. Seen it demonstrate its toughness and its performance. I can back that statement up with many, many hours of very realiable performance over some very long distances and over some mighty hostile terrain and ice water. Hi John H., I am in need of a prop , as one of the cams broke on my Ivo . I am sold on the Warp, but I am concerned that it weighs more than the folks from Rotax recommend. Did you ever run a warp on any B-box 447? I dont want another Ivo, but I dont want to overstress the B -box, either. Ed Diebel ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 08, 2007
Ed, I may be more than you want to spend but you could always upgrade to a C box. Since it is a stronger box and includes a rubber damper bushing you will end up with a very smooth and reliable alternative. My feeling is that by going to the Warp to avoid prop damage during a strike you may be shifting the weakest link job to the gear box. Steve FF 007 C box on the shelf next to a 2 blade warp waiting for a spare weekend ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: fuel color
Date: Jul 08, 2007
I went to the hanger yesterday to get some empty fuel containers as we were going to town and I want a bit more fuel on hand. I have a clear tank that I use to mix the gas and oil, so I poured out one of the 5 gal containers that I had filled up about 10 days before into the clear container. I was very surprised to see that it was about the same color as it would be when I had mixed in the oil. I got it just over the border in Nev and it has been sealed in the plastic container sitting in the dark in the hanger. I am not intending to put it in my plane just because the color is so strange. It is too darned hot to be walking back home from the places that I fly. I'll burn it in the lawn mower or the quad. I know that we have someone on the list that works with gas distributors, just can't remember who. I have noticed that there is quite a varying color range in gas purchased in different places. My question is- does the color have any impact on the suitability of fuel, and would storing it in individual containers at OAT have an adverse effect, and if so how long would it take to not be usable. I might add that the stuff smells ok. Thanks for the help Larry C ________________________________________________________________________________
Date: Jul 08, 2007
Subject: Re: Warp Drive
In a message dated 7/8/2007 12:29:16 P.M. Eastern Daylight Time, planecrazzzy(at)yahoo.com writes: What's the "Ballpark" price for the Box , Hub, and Prop...? . . . Gotta Fly... Mike & "Jaz" in MN . Mike, $1314.00 for the C box at Airwolf. GULP! but a new B box is worth $810.00 and you can sell your B box. The best time to do this is when you buy a new 447 and opt for the C. Only a few hundred dollars at that point. Bryan M has installed a few of these configurations on Fireflys and they are very smooth. steve ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 08, 2007
In a message dated 7/7/2007 11:25:52 PM Central Standard Time, richard(at)bcchapel.org writes: > > I'm not John, but try a two blade 64" Warp, (or be really conservative and > use a 62" two blade Warp) and use only Mobil One synthetic in your gearbox, > and you'll probably get by without hurting the gearbox, and you'll probably be > very satisfied. I got a couple hundred hours out of my B box with a Warp 66" > two blade, but that was with ordinary gearbox lube. A shorter prop and better > lube and you ought to do OK. > > Richard Pike > MKIII N420P (42oldpoops) > Richard, What tipped you off there was a problem with your B Box at 200 hrs? What is the normal life expectancy of a B Box? And lastly, is it likely to cause a forced landing if the gear box fails? I dont recall of any post on the list involving failed gear boxes. I have ran Mobil 1 Synthetic since day one. Ed Diebel
Date: Jul 08, 2007
I wish that they would bring back the REAL Kolb Flyer.... [Crying or Very sad] Kip -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122771#122771 ________________________________________________________________________________
Date: Jul 08, 2007
Subject: arlington any one
my buddy is driving to Arlington from Florida you cant miss him he is a ultralight hippy with long red hair and the biggest handlebar mustache you have ever seen. he is traveling with a beautiful blond, when you see him please tell him, Malcolm will see him in Oshkosh mal Michigan ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 08, 2007
The bearings spinning in the races and on the shaft was a dead giveaway... before that it had a lot of metal mung around the magnet on the previous two gearbox oil changes, so pulled it apart to see what it was doing. Sent it to CPS, they said it was cheaper to buy a new one than fix it. This was 12 years ago, I was using a 66" two blade Warp on a 532. Since then I have used only Mobil One synthetic and the oil comes out clean, almost no mung on the plug magnet using a 68" two blade Ivo, B box. I think the Mobil One is the ticket. Thanks to John H for the heads-up on that one. Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: DAquaNut(at)aol.com To: kolb-list(at)matronics.com Sent: Sunday, July 08, 2007 5:58 PM Subject: Re: Kolb-List: Re:Warp Drive In a message dated 7/7/2007 11:25:52 PM Central Standard Time, richard(at)bcchapel.org writes: I'm not John, but try a two blade 64" Warp, (or be really conservative and use a 62" two blade Warp) and use only Mobil One synthetic in your gearbox, and you'll probably get by without hurting the gearbox, and you'll probably be very satisfied. I got a couple hundred hours out of my B box with a Warp 66" two blade, but that was with ordinary gearbox lube. A shorter prop and better lube and you ought to do OK. Richard Pike MKIII N420P (42oldpoops) Richard, What tipped you off there was a problem with your B Box at 200 hrs? What is the normal life expectancy of a B Box? And lastly, is it likely to cause a forced landing if the gear box fails? I dont recall of any post on the list involving failed gear boxes. I have ran Mobil 1 Synthetic since day one. Ed Diebel ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: EFIS Units
Date: Jul 08, 2007
Hey Group, Are there any of you flying with any of the EFIS units? I have two Dynon D10A units. One will be installed in my Kolb MkIII, and the other will be as a back-up to my Blue Mountain Avionics EFISOne in my GlaStar. Up to this point my only experience is playing with them on the kitchen table. They sure do look cool, and show virtually instanteous response to movement. For the Kolb, I'm going to have the Dynon D10A EFIS, built-in Garmin 296 GPS, Icom A200 NavCom, and King transponder. For my engine "steam gages", they are in an overhead panel, you just look up to see them. (overhead panel includes gages, ignition switch, clock, intercom and light, and switches to various things) I was curious about anyone else's experience with any EFIS units, 'cause you don't seem to hear much from this group on any of the avionics in their planes. Mike in SW Utah _________________________________________________________________ http://newlivehotmail.com ________________________________________________________________________________
Subject: RE: Overhead Panel
Date: Jul 09, 2007
Sure, I'd be happy to. My feeling was that the area the above your head was blocked by the bottom side of the leading edge of the wing, anyway, so why not make it a place for things you would want fairly close. Funny thing about that "close" business, tho. Back when I was working on my Kolb quite a bit, I built this panel back in 2001. Needed glases to see up close "some". Now, 6 years later, I need glasses to see up close...period! But, I guess that's okay, tho, because the FAA (pilot's license) says I need to have reading glasses with me, anyway. (Actually, I can see, it's just that things are a little blurry.) Back to the panel; gages are self explanatory, ignition switch, clock (from Honda Civic) intercom, aircraft swing down/(and then detach if you want) cockpit light, and switches are for strobes and position lights, avionics master, electric in-flight adjustable prop, etc. Oh, and I have a rather cool DOOR mounted throttle lever. Best to all, Mike in SW Utah >From: "Al & Beth Nicoson" <anicoson(at)wi.rr.com> >Reply-To: >To: >Subject: Overhead Panel >Date: Mon, 9 Jul 2007 07:55:54 -0500 > >Hi Mike, > >Do you have a photo of your design, if so would you please pass it along? > >Thanks, > >Al >- >~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ > Al & Beth Nicoson > anicoson(at)wi.rr.com >~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ > _________________________________________________________________ http://newlivehotmail.com ________________________________________________________________________________
Date: Jul 09, 2007
Subject: Re: EFIS Units
I have a Dynon EFIS D100 (with OAT probe) in my Aerocomp Experimental. I bought it in December 2006. I had some trouble with it and sent it back to Dynon. They replaced its main board and it's been GREAT since then. I really like the TAS & wind readout and the HSI/GPS display. It is also comforting to have 2+ hours of backup battery in case of electrical failure. I am looking forward to the improvements with the [free] new firmware due out any day. Definitely get the brighter screen option ($200). Ground calibration of the magnetic flux detector is critical to accurate heading and wind info (this is easily done). But it's great never having to synch a DG. It is interfaced to my Garmin GPSmap 196 portable with a single wire. Jim N. Idaho Hey Group, Are there any of you flying with any of the EFIS units? I have two Dynon D10A units. One will be installed in my Kolb MkIII, and the other will be as a back-up to my Blue Mountain Avionics EFISOne in my GlaStar. Up to this point my only experience is playing with them on the kitchen table. They sure do look cool, and show virtually instanteous response to movement. For the Kolb, I'm going to have the Dynon D10A EFIS, built-in Garmin 296 GPS, Icom A200 NavCom, and King transponder. For my engine "steam gages", they are in an overhead panel, you just look up to see them. (overhead panel includes gages, ignition switch, clock, intercom and light, and switches to various things) I was curious about anyone else's experience with any EFIS units, 'cause you don't seem to hear much from this group on any of the avionics in their planes. Mike in SW Utah ________________________________________________________________________________
Subject: Re: arlington any one
Date: Jul 09, 2007
I'll be at Arlington next Sat & Sunday, but I'll be in my Aerocomp experimental, not my Firefly. Jim N. Idaho -------- Jim N. Idaho Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122861#122861 ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Subject: Re: RE: Overhead Panel
Date: Jul 09, 2007
Mike/All, In the future, please post pics via the matronics website and guidelines. It won't slow the e-mail down for those of us on dial-up. Thanx! Ed in JXN MkII/503 ----- Original Message ----- From: "Mike Welch" <mdnanwelch7(at)hotmail.com> Sent: Monday, July 09, 2007 10:43 AM Subject: Kolb-List: RE: Overhead Panel > Sure, I'd be happy to. My feeling was that the area the above your > head was blocked by the bottom side of the leading edge of the wing, > anyway, > so why not make it a place for things you would want fairly close. > (Snip) > Oh, and I have a rather cool DOOR mounted throttle lever. > > Best to all, Mike in SW Utah > ________________________________________________________________________________
Subject: Re: Overhead Panel
Date: Jul 09, 2007
The overhead panel is a great idea !!! I have been running out of room also on my pedistol, and dont want anything bigger that would block my view out the front. An overhead is the answer if I ever want to add anything more. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122889#122889 ________________________________________________________________________________
Date: Jul 09, 2007
mdnanwelch7(at)hotmail.co wrote: > > > For the Kolb, I'm going to have the Dynon D10A EFIS, built-in Garmin 296 > GPS, Icom A200 NavCom, and King transponder. For my engine "steam gages", > they are in an overhead panel, you just look up to see them. (overhead > panel includes gages, ignition switch, clock, intercom and light, and > switches to various things) > > > Mike in SW Utah > > _________________________________________________________________ > http://newlivehotmail.com That sounds like a nice setup, just about all the stuff I would want :) With all that modern avionics, why are you still using steam guages ??? The EIS unit is GREAT for engine monitoring. Its more accurate and you dont have to stare at it while flying, the flashing red light with something goes out of limits is better than constantly having to monitor guages. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122891#122891 ________________________________________________________________________________
Date: Jul 09, 2007
I liked this one so much I bought it. ________________________________________________________________________________
Date: Jul 09, 2007
Hi Mike/All Others, I agree with you re: the steam gages idea. I would be better off with an EIS electronic system, but as I said, I started the Kolb back in 2000/2001 and didn't even consider the electronic route, plus I didn't have very much money back then. No real intentions of changing at this point. I got myself in a situation where I couldn't work on the plane for a few years. Then, a year or two ago I made a ton of money, and invested a small fortune in my GlaStar ($90,000 or so). Kolb was still on the back burner. GlaStar moved to the head of the line. Then, another direction change has now caused me to want to sell my Cessna 172, and focus back on the Kolb. Plus, wife says three planes is too many. In the last few days I have virtually finished building my shop and pool in my backyard. I have been "stealing" time here and there, and working on the Kolb. Actually, before I began working on the Kolb, I had to repair the rudder on the GlaStar!!! During my move to SW Utah in December, my glass top picnic table blew off my truck on the highway, flew up in the air and wiped out the top of the rudder as it then exploded into a trillion pieces on the highway. Out of a sense of remorse, I felt the need to repair the rudder before I did anything else, either on the GlaStar OR Kolb. Repaired the rudder! Damn nice job, if I say so myself. Then onto Kolb. I'm having to pay the price for not keeping the Kolb inside all the time. ( mostly kept covered under tarp) My Kolb MkIII was at the point where all I needed to do was cover the tail feathers, and wings. Practically ALL else was finished. Motor/prop was running. Instruments mounted (almost all of them). Pretty much fabric and paint was all that's left to do. Now I have to back waaaay!! up. It'll take me 3 months just to get back to square one. But the REALLY GOOD part is: I have began working on the Kolb again. And in my book, that's always a good thing!! And this time I plan on doing it like they rebuilt Steve Austin in "The SiX Million Dollar Man". "We can build it BETTER! STRONGER! FASTER! Best regards, Mike in SW Utah PS. I do have the EIS for my GlaStar. I have a Electronics International MVP 50. $5000 unit. Can't afford to spend money like that on ALL the planes!! >From: "JetPilot" <orcabonita(at)hotmail.com> >Reply-To: kolb-list(at)matronics.com >To: kolb-list(at)matronics.com >Subject: Kolb-List: Re: EFIS Units >Date: Mon, 9 Jul 2007 10:51:49 -0700 > > >mdnanwelch7(at)hotmail.co wrote: > > > > > > For the Kolb, I'm going to have the Dynon D10A EFIS, built-in Garmin 296 > > GPS, Icom A200 NavCom, and King transponder. For my engine "steam >gages", > > they are in an overhead panel, you just look up to see them. (overhead > > panel includes gages, ignition switch, clock, intercom and light, and > > switches to various things) > > > > > > Mike in SW Utah > > > > _________________________________________________________________ > > http://newlivehotmail.com > > >That sounds like a nice setup, just about all the stuff I would want :) >With all that modern avionics, why are you still using steam guages ??? >The EIS unit is GREAT for engine monitoring. Its more accurate and you >dont have to stare at it while flying, the flashing red light with >something goes out of limits is better than constantly having to monitor >guages. > >Mike > >-------- >"NO FEAR" - If you have no fear you did not go as fast as you >could have !!! > >Kolb MK-III Xtra, 912-S > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=122891#122891 > > _________________________________________________________________ ________________________________________________________________________________
Date: Jul 09, 2007
David, Please post a LINK to pics, so those who are interested can click and view, and those who aren't (esp. those of us on dial-up) aren't hamstrung waiting for a few minutes for pics we don't need/want. Thanks, Ed in JXN ----- Original Message ----- From: "David Key" <dhkey(at)msn.com> Sent: Monday, July 09, 2007 2:13 PM Subject: RE: Kolb-List: Re: Overhead Panel >I liked this one so much I bought it. > > ________________________________________________________________________________
Date: Jul 09, 2007
You can get the EIS for like 700 bucks, I forget the exact price, but its not much. Probably slightly more then the steam guages it replaces. You can see mine in the picture of my MKIII panel attached to this post. This thing is really great. With my luck, I would not be looking at the guages the minute the oil pressure went down, or when the EGT's started to go up. With a bright red flashing light in your face, you know when something goes wrong right away. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122993#122993 ________________________________________________________________________________
Date: Jul 09, 2007
Here is the picture of my panel...... -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122994#122994 Attachments: http://forums.matronics.com//files/kolbmkiiipanelinflight_211.jpg ________________________________________________________________________________
Subject: electric start for 582
Date: Jul 10, 2007
Kolbers, A friend of mine just purchased the funky looking Slingshot that was for sale on Barnstormers. He would like to convert to electric start and also may be in the market for a good used C-gearbox. If anyone has a good used starter for a 582 or C-box, please drop me a line. Denny Rowe ________________________________________________________________________________
Date: Jul 10, 2007
From: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
Nice looking panel, Mike W. As an alternate location for those extra switches that never seem to fit in the stock Kolb instrument panel, I chose the floor pan, just forward of the passenger-side seat. This nearly-vertical section of tin is useable real estate, directly below the passenger's knees. Here, I fabricated a 4"x10" panel onto which is mounted little stuff: the master switch, start button, fuel pump switch, strobe switch, power jacks (3), and the fuse box. The panel is not visible from my seated position in the cockpit; I activate the switches by feel. Dennis Kirby Mark-III New Mexico ________________________________________________________________________________
Date: Jul 10, 2007
Subject: Re: Nauga Field Fly Around - Starhill, LA (latest)
In a message dated 7/10/2007 11:05:23 A.M. Eastern Standard Time, kolbrapilot1(at)tx.rr.com writes: John B and All, You can take Ken Korenek off the list. Can you believe that someone would let work get in the way of flying! do not archive Try offering him a steak. :-) steve ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Firestar II 3 view
Date: Jul 10, 2007
Hi All, I'm looking for a good 3 view of a Firestar II. This is to satisfy the one of the requirements to register my plane under the new ELSA rules. I tried Travis @ Kolb but, oddly enough they said they didn't have one. So I thought I'd try the list to see if someone here might have one from some old sales literature they may have around. My Firestar is for sale and is listed in Barnstormers for those who might be interested. Thanks for you Help Best Regards Carlos G AKA BaronVonEvil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123090#123090 ________________________________________________________________________________
Subject: Re: Firestar II 3 view
Date: Jul 10, 2007
Here is one I used. Jim -------- Jim O'Day Fargo, ND Firestar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123095#123095 Attachments: http://forums.matronics.com//files/kolb_3_view_204.pdf ________________________________________________________________________________
Date: Jul 10, 2007
Hi Jim, Say that looks like it should do the trick. Thank You Very Much. Best Regards Carlos G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123098#123098 ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Chesanning MI Fly-In July 14-15th
Date: Jul 10, 2007
Is anyone going to the fly-in? Is it still on? The weather looks good for Saturday but? Interesting MULA sponsors these events and all the searches that I did point back to the MULA web site and nothing about any of the fly-ins is listed. ________________________________________________________________________________
Subject: Oshkosh 2007
Date: Jul 10, 2007
Who is going to Oshkosh this year? I'm planning to fly in with Scott Trask on Sunday (7/22) or Monday (7/23) depending on weather. Is anyone else flying in? I will be there camping under my wing the whole week as usual Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
Date: Jul 10, 2007
Subject: Re: Chesanning MI Fly-In July 14-15th
Yes it is on for the mula fly inn and I will be there I will also be in seaplane bass at oshkosh come see me there mal ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 10, 2007
Rick, Could you send me information about the fly-in? Jim Minewiser ----- Original Message ----- From: Richard & Martha Neilsen To: kolb-list(at)matronics.com Sent: Tuesday, July 10, 2007 4:27 PM Subject: Kolb-List: Chesanning MI Fly-In July 14-15th Is anyone going to the fly-in? Is it still on? The weather looks good for Saturday but? Interesting MULA sponsors these events and all the searches that I did point back to the MULA web site and nothing about any of the fly-ins is listed. ________________________________________________________________________________
Subject: Re: Oshkosh 2007
Date: Jul 10, 2007
Rick, can you shoot me Scott Trask`s e-mail address, I met him in 1996? & would like to re-contact hiom, thanks, Jim Kmet jlsk1(at)frontiernet.net ----- Original Message ----- From: Richard & Martha Neilsen To: kolb-list(at)matronics.com Sent: Tuesday, July 10, 2007 3:39 PM Subject: Kolb-List: Oshkosh 2007 Who is going to Oshkosh this year? I'm planning to fly in with Scott Trask on Sunday (7/22) or Monday (7/23) depending on weather. Is anyone else flying in? I will be there camping under my wing the whole week as usual Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
Date: Jul 10, 2007
MULA is a ultralight club suffering from growing pains imposed by the sport pilot rule. we have ben holding club fly in events for 20 years. the fact that we didn't advertise this event state wide in every passable publication should make people realize what kind of event we are holding .If anyone wants to know moor about it Please contact a MULA member and ask for the details mal ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: new/old Kolber
Date: Jul 11, 2007
Welcome back to the good side Thom. That looks like a nice plane. We should meet up somewhere in the middle of the state some time. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123239#123239 ________________________________________________________________________________
Subject: Vortex Generators - Flight test report.
Date: Jul 11, 2007
I put Vortex Generators on my Kolb MK III Xtra. I did not want to post just a first impression so I have flown with them for about a months so that I had a chance to really try them out in a lot of different conditions. The VG's have made a different airplane out of the MK III, not just in terms of reducing the stall speed, but in the feel of the plane at lower speeds. It used to feel like an approach speed of 60 MPH was needed to have a good margain of safety and control. Now, 40 on approach feels fine, although I use 50 minimum as a safety factor. Stalls occour at 26 indicated, the plane is not really going this slow, as the GPS shows mid 30's stall with no flaps. I have the traditional seperate flaps and ailerons, and Stalling with flaps seems to be at the same speed as stalling without them, mid 30's. The stall is really a non event, the plane shakes 1/2 second before the nose falls a few degrees nose down, Its so mild that I have a hard time calling it a stall. Full aileron control is maintained throughout the stall, if a wing starts to drop anytime in the stall, a medium amout of aileron input immidately corrects it. I was teaching my wife stalls and of course her first reaction was to jerk the stick back as soon as the nose fell, she abruptly pulled the plane level at 33 indicated a couple times and never got a secondary stall. Yesterday evening, I wanted to see if I could really fly an approach at a very low airspeed, so I went to 2000 feet, went to idle power slowed down to 35 MPH indicated, and put in a huge amount of aileron, banked 45 degrees and roughly jerked the plane around like an idiot, but was not able to get an accelerated stall or felt like I was about to lose it. Landings were a real problem at first, I was in the habbit of landing with no flaps, and with the VG's the plane started to bounce badly on every landing no matter how smooth the touchdown. The airplane would touch down, but there was still enough lift being generated that it would fly again, even with a perfect three point landing... It was worse with a wheels landing. Landing with one notch of flaps totally cured this, im guessing that it pitches the nose down enough that it does not tend to pitch up on a wheels landing, and its going slow enough on a 3 point landing not to fly again. Now I land with flaps every time. The down side is that it cost me some speed, im not sure exactly how much as a changed props at the same time I added the VG's, I lost 8 MPH in cruise with the prop change and VG installation. Im guessing at least 5 of that is VG related. I put the VG 's on with double sided automotive trim tape so that I could take them off if I ever wanted to. Overall im so happy with the way the MK-III flys and feels at slow speeds with VG's, I am more than happy to cruise a bit slower. I used 140 VG's spaced at 2.5 inches apart from the center out to the wingtips. The VG's are in pairs and centered in the valleys of the ribs and face the airstream at a 15 degree angle, and placed at 10 % of the chord of the wing. Attached is a picture of the VG's on the wing, and my panel flying level with 3500 RPM just above stall. Mike Bigelow MK III Xtra 912-S -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123249#123249 Attachments: http://forums.matronics.com//files/kolbmkiiivortexgenerators_208.jpg http://forums.matronics.com//files/kolbmkiiipanelinflight_190.jpg ________________________________________________________________________________
Date: Jul 11, 2007
Might want to rethink the prop change...having flown 2 different RANS S7's with and without VG's and communicating with several that had flown them on Challengers, you're the first I've heard of actually losing cruise speed. A couple of folks thought "maybe a MPH or 2" but really hard to tell. Personally I could not tell any lose of cruise speed. Read an article in Sport Aviation long time ago about a guy that tested VG's on an RV-6 with an articulating pitot-static test boom and everything and got somewhere around 4-5MPH loss...but that was on a 200MPH airplane, so go figure. Your still a good advocate for the VG's...even thinking that the VG's cost you that much cruise speed you were impressed enough with the slow end improvement to leave them on...that says it all. I'd bet a crisp $5 bill that swapping back to the original prop will show the VG's to not have cost you much (if any) on the cruise end... Jeremy Casey The down side is that it cost me some speed, im not sure exactly how much as a changed props at the same time I added the VG's, I lost 8 MPH in cruise with the prop change and VG installation. Im guessing at least 5 of that is VG related. I put the VG 's on with double sided automotive trim tape so that I could take them off if I ever wanted to. Overall im so happy with the way the MK-III flys and feels at slow speeds with VG's, I am more than happy to cruise a bit slower. I used 140 VG's spaced at 2.5 inches apart from the center out to the wingtips. The VG's are in pairs and centered in the valleys of the ribs and face the airstream at a 15 degree angle, and placed at 10 % of the chord of the wing. Attached is a picture of the VG's on the wing, and my panel flying level with 3500 RPM just above stall. Mike Bigelow ________________________________________________________________________________
Date: Jul 11, 2007
At 11:28 AM 7/11/2007, Thom Riddle wrote: > >Scott, > >I first have to build an tail dolly for moving it around in the hangar >behind the Allegro. I'll have to fold and unfold the wings at each flight >so I'm planning on designing a dolly that will hold the wings such the the >wing tips are above the flying wires on the tail so I won't have to fold >the tail with each flight... I LIKE that idea! Gotta see if I can do something like that for my US, if I end up sharing a hangar instead of keeping it in the trailer. 'Course on the US I'd have to partially fold the wings, keeping them outboard of the stabilizer, but same idea. -Dana -- -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Date: Jul 11, 2007
Did anybody see any vortez generators??? :-) > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list- > server(at)matronics.com] On Behalf Of JetPilot > Sent: Wednesday, July 11, 2007 11:21 AM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Vortex Generators - Flight test report. > > > I put Vortex Generators on my Kolb MK III Xtra. I did not want to post > just a first impression so I have flown with them for about a months so > that I had a chance to really try them out in a lot of different > conditions. The VG's have made a different airplane out of the MK III, > not just in terms of reducing the stall speed, but in the feel of the > plane at lower speeds. It used to feel like an approach speed of 60 > MPH was needed to have a good margain of safety and control. Now, 40 > on approach feels fine, although I use 50 minimum as a safety factor. > > Stalls occour at 26 indicated, the plane is not really going this slow, > as the GPS shows mid 30's stall with no flaps. I have the traditional > seperate flaps and ailerons, and Stalling with flaps seems to be at the > same speed as stalling without them, mid 30's. The stall is really a > non event, the plane shakes 1/2 second before the nose falls a few > degrees nose down, Its so mild that I have a hard time calling it a > stall. Full aileron control is maintained throughout the stall, if a > wing starts to drop anytime in the stall, a medium amout of aileron > input immidately corrects it. I was teaching my wife stalls and of > course her first reaction was to jerk the stick back as soon as the > nose fell, she abruptly pulled the plane level at 33 indicated a couple > times and never got a secondary stall. > > Yesterday evening, I wanted to see if I could really fly an approach at > a very low airspeed, so I went to 2000 feet, went to idle power slowed > down to 35 MPH indicated, and put in a huge amount of aileron, banked > 45 degrees and roughly jerked the plane around like an idiot, but was > not able to get an accelerated stall or felt like I was about to lose > it. > > Landings were a real problem at first, I was in the habbit of landing > with no flaps, and with the VG's the plane started to bounce badly on > every landing no matter how smooth the touchdown. The airplane would > touch down, but there was still enough lift being generated that it > would fly again, even with a perfect three point landing... It was > worse with a wheels landing. Landing with one notch of flaps totally > cured this, im guessing that it pitches the nose down enough that it > does not tend to pitch up on a wheels landing, and its going slow > enough on a 3 point landing not to fly again. Now I land with flaps > every time. > > The down side is that it cost me some speed, im not sure exactly how > much as a changed props at the same time I added the VG's, I lost 8 MPH > in cruise with the prop change and VG installation. Im guessing at > least 5 of that is VG related. I put the VG 's on with double sided > automotive trim tape so that I could take them off if I ever wanted to. > Overall im so happy with the way the MK-III flys and feels at slow > speeds with VG's, I am more than happy to cruise a bit slower. > > I used 140 VG's spaced at 2.5 inches apart from the center out to the > wingtips. The VG's are in pairs and centered in the valleys of the > ribs and face the airstream at a 15 degree angle, and placed at 10 % of > the chord of the wing. Attached is a picture of the VG's on the wing, > and my panel flying level with 3500 RPM just above stall. > > Mike Bigelow > > MK III Xtra 912-S > > -------- > "NO FEAR" - If you have no fear you did not go as fast as > you could have !!! > > Kolb MK-III Xtra, 912-S > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=123249#123249 > > > > > Attachments: > > http://forums.matronics.com//files/kolbmkiiivortexgenerators_208.jpg > http://forums.matronics.com//files/kolbmkiiipanelinflight_190.jpg > > > > > > ________________________________________________________________________________
Date: Jul 11, 2007
Very funny, George. Yeah, what airplane?? Also, notice how Mike mentioned in his email how he had his lovely wife in the plane with him, teaching her stalls, no less!!!! Gosh, should we be so lucky to have our wives support us so!! I think it was a sly way for him to brag about having a real sweetheart of a wife. In case Mr. Mike reads this email, do you have any specs/details of the VG's? Where did you get the design, and how far back from the leading edge are they mounted? Appreciate the info, Mike in SW Utah >From: "George Myers" <gmyers(at)grandecom.net> >Reply-To: kolb-list(at)matronics.com >To: >Subject: RE: Kolb-List: Vortex Generators - Flight test report. >Date: Wed, 11 Jul 2007 13:00:55 -0500 > > >Did anybody see any vortez generators??? :-) > > > -----Original Message----- > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list- > > server(at)matronics.com] On Behalf Of JetPilot > > Sent: Wednesday, July 11, 2007 11:21 AM > > To: kolb-list(at)matronics.com > > Subject: Kolb-List: Vortex Generators - Flight test report. > > > > > > I put Vortex Generators on my Kolb MK III Xtra. I did not want to post > > just a first impression so I have flown with them for about a months so > > that I had a chance to really try them out in a lot of different > > conditions. The VG's have made a different airplane out of the MK III, > > not just in terms of reducing the stall speed, but in the feel of the > > plane at lower speeds. It used to feel like an approach speed of 60 > > MPH was needed to have a good margain of safety and control. Now, 40 > > on approach feels fine, although I use 50 minimum as a safety factor. > > > > Stalls occour at 26 indicated, the plane is not really going this slow, > > as the GPS shows mid 30's stall with no flaps. I have the traditional > > seperate flaps and ailerons, and Stalling with flaps seems to be at the > > same speed as stalling without them, mid 30's. The stall is really a > > non event, the plane shakes 1/2 second before the nose falls a few > > degrees nose down, Its so mild that I have a hard time calling it a > > stall. Full aileron control is maintained throughout the stall, if a > > wing starts to drop anytime in the stall, a medium amout of aileron > > input immidately corrects it. I was teaching my wife stalls and of > > course her first reaction was to jerk the stick back as soon as the > > nose fell, she abruptly pulled the plane level at 33 indicated a couple > > times and never got a secondary stall. > > > > Yesterday evening, I wanted to see if I could really fly an approach at > > a very low airspeed, so I went to 2000 feet, went to idle power slowed > > down to 35 MPH indicated, and put in a huge amount of aileron, banked > > 45 degrees and roughly jerked the plane around like an idiot, but was > > not able to get an accelerated stall or felt like I was about to lose > > it. > > > > Landings were a real problem at first, I was in the habbit of landing > > with no flaps, and with the VG's the plane started to bounce badly on > > every landing no matter how smooth the touchdown. The airplane would > > touch down, but there was still enough lift being generated that it > > would fly again, even with a perfect three point landing... It was > > worse with a wheels landing. Landing with one notch of flaps totally > > cured this, im guessing that it pitches the nose down enough that it > > does not tend to pitch up on a wheels landing, and its going slow > > enough on a 3 point landing not to fly again. Now I land with flaps > > every time. > > > > The down side is that it cost me some speed, im not sure exactly how > > much as a changed props at the same time I added the VG's, I lost 8 MPH > > in cruise with the prop change and VG installation. Im guessing at > > least 5 of that is VG related. I put the VG 's on with double sided > > automotive trim tape so that I could take them off if I ever wanted to. > > Overall im so happy with the way the MK-III flys and feels at slow > > speeds with VG's, I am more than happy to cruise a bit slower. > > > > I used 140 VG's spaced at 2.5 inches apart from the center out to the > > wingtips. The VG's are in pairs and centered in the valleys of the > > ribs and face the airstream at a 15 degree angle, and placed at 10 % of > > the chord of the wing. Attached is a picture of the VG's on the wing, > > and my panel flying level with 3500 RPM just above stall. > > > > Mike Bigelow > > > > MK III Xtra 912-S > > > > -------- > > "NO FEAR" - If you have no fear you did not go as fast as > > you could have !!! > > > > Kolb MK-III Xtra, 912-S > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=123249#123249 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/kolbmkiiivortexgenerators_208.jpg > > http://forums.matronics.com//files/kolbmkiiipanelinflight_190.jpg > > > > > > > > > > > > > > _________________________________________________________________ http://liveearth.msn.com ________________________________________________________________________________
Date: Jul 11, 2007
After a bunch of fuss with the tail light on the trailer I saw my good old N197BG drive away with Thom... Take good care of her! Hope you love it as much as I did! But Time for me to move up... MKIII xtra would be a great find when I get ready for the next plane. -Erik -------- -Erik Grabowski Kolb Firestar N197BG CFI/CFII/LS-I Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123281#123281 ________________________________________________________________________________
Date: Jul 11, 2007
I will be flying in sometime Thursday late or Friday early and depart on Sunday. If work doesn't get in the way again. Does anyone know if the New Kolb gang is going to be at Oshkosh? I didn't see anything on their webpage about Oshkosh. Regards, Will Uribe El Paso, TX FireStar II N4GU _http://home.elp.rr.com/airplane/_ (http://home.elp.rr.com/airplane/) ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 11, 2007
Subject: Control Surface Hinges
Hi again, Time to permanently install my hinges. Have read on other lists about bedding the hinges in Epoxy when riveting them on. This makes since to me because you are installing a flat surface to a rounded surface. By bedding the hinge in Epoxy, the stress is spread out over the whole hinge leaf rather then concentrated at the rivet holes. I'm sure this is overkill ( many kolbs are flying successfully without this, for many years) but still makes since to me. My questions are these: Has anyone else done this? How about inservice results? What kind of Epoxy did you use? Considering using J-B Weld, but discovered it is for steel. Would it be appropriate next to aluminum? Would it rust over time or cause galvanic corrosion? Since the steel fillings are embedded in an Epoxy matrix, would it be an issue at all? All thoughts would be appreciated. John Ratcliffe ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Re: Control Surface Hinges
Date: Jul 11, 2007
| Have read on other lists about bedding the hinges in Epoxy when riveting them | on. | | John Ratcliffe John R: As far as I know, there are no problems with piano hinges departing round tubes on Kolbs. Bedding hinges in epoxy is unnecessary, and will cause a serious problem if you ever have to remove a hinge. I have hinges on my mkIII, installed per the plans and instructions, with well over 2,600 hours flight time on them. Have not had any hinge problems concerning looseness. Curious. Were the other lists you have been reading, reference epoxy bedding of piano hinges, Kolb related/ Take care, john h mkIII ________________________________________________________________________________
Subject: VW Update
Date: Jul 11, 2007
Okay guys. I have a couple of VW updates. First, I have installed and have been test flying my new series three reduction drive. As I reported earlier the new redrive is a serpentine belt drive that slips in one direction at low RPMs and absorbs harmonic pulses at higher RPMs. The VW redrive is smooth throughout all RPM ranges and will even idle smooth down 700 RPM. This is a major improvement over the old redrive. Since there is some slippage there is a more limited life to the belts but there is a wear indicator that shows you when it is time to replace the belts. It isn't known yet what the life is but it is at least a hundred hours. The belt change requires the removal of only one bolt, it is a one inch bolt but there is only one. Second, I've been working with Kolb on behalf of Rick Lewis to have Kolb to produce a VW mount for his Mark IIIX. They now have the production jigs to produce this VW mount for other MKIIIs. Hopefully Rick will keep us up to date on his progress. I also hope he will build a bit faster than Big Lar. Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
Subject: firestar prop size?
Date: Jul 12, 2007
Hello everyone. Does anyone know the recommended prop size for a Firestar I with a 447. I am not reaching full RPMs. My plane has a wood 66x33 which I am guessing is my problem. Any ideas? Thanks, Bryan Dever ________________________________________________________________________________
Subject: Re: firestar prop size?
Date: Jul 12, 2007
| Hello everyone. Does anyone know the recommended prop size for a Firestar I with a 447. I am not reaching full RPMs. My plane has a wood 66x33 which I am guessing is my problem. Any ideas? | | Thanks, | Bryan Dever Bryan D: Bryan D: 66X32 was what I was running on my 1986 FS. Not all wooden props are created equal. I also ran a 66X30 Jim Culver prop. The GSC two blade wooden prop that is still hanging around, if I remember correctly, was pitched a little lighter than the 66X30 Culver prop. For me, ideal pitch is WOT, straight and level flight, just bump the redline for max continuous rpm, which is 6,500 rpm for a 447. Will produce the best climb and cruise. john h mkIII john h ________________________________________________________________________________
Date: Jul 12, 2007
> >Hello everyone. Does anyone know the recommended prop size for a Firestar I with a 447. I am not reaching full RPMs. My plane has a wood 66x33 which I am guessing is my problem. Any ideas? > Bryan, If your engine is running fine and you do not wish to purchase a new propeller, make a fixture and start cutting the tips off the propeller. Take no more that a half and inch at a time, and fly with it after cutting to see how it performs. If the engine does not come up to speed take another half inch off. When you get the engine speed where you want it, check the balance. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: Vortex Generators - Flight test report.
Date: Jul 12, 2007
----- Original Message ----- From: "jimhefner" <hefner_jim(at)msn.com> Sent: Thursday, July 12, 2007 8:22 AM Subject: Kolb-List: Re: Vortex Generators - Flight test report. > > Mike, did you put any VG's on the underside of the horizontal stabilizers? > You might want to consider that if not. It might not be a big deal on the > Mk III X but it will help keep the tail from stalling before the main wing > on slow landings. ________________________________________________________________ Just what happens when the tail stalls? Larry C ________________________________________________________________________________
Date: Jul 12, 2007
Subject: Re: Landing Downhill At The Rock House
In a message dated 6/28/2007 4:02:19 P.M. Eastern Daylight Time, jhauck(at)elmore.rr.com writes: Hi Gang: I like this photo. Shows a lot of action and enery. Was landing on the last couple hundred feet, down hill and to the south at Larry Cottrell's Rock House, Jordan Valley, Oregon, May 2007. Better put two of them in there. First is just touching down at the crest of the hill. These photos were taken by John W. Very nice John............... geeeez, I gotta get back to fl and flying again........are you there Rich Swiderski? George Randolph ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 12, 2007
At 12:57 PM 7/12/2007, Larry Cottrell wrote: >Just what happens when the tail stalls? Since the tail normally is pushing down, when it stalls it goes up, the plane noses down, the tail starts flying again, and the plane recovers. This assumes you're not pushing the stick forward and doing negative g's... -Dana -- -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Subject: Re: Jabiru 2 cylinder - is it real
Date: Jul 12, 2007
It's real - seen at Wagga 2006 - but don't know if it will make production. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123512#123512 ________________________________________________________________________________
Date: Jul 12, 2007
John H, Picked info on hinges from the Challenger list. Info was related to loosening Hinges and rivets on some Challenger builds. One gent said he bedded his hinges in epoxy on all his builds and never had one come loose. Only thing related to Kolbs is my desire to build as safe an aircraft as possible. Have never heard of this problem on a Kolb, although I have seen one or two loose hinge rivets on Kolbs for whatever reason. Today I installed one of the hinges on an elevator. After seeing how tight they pulled up to the spar, now don't think epoxy is necessary. With the edge distance specified, there isn't much edge hanging out. Mike, Took your advice and drilled the hinges, but used safety wire instead. Looked like the head of a cotter pin could jam ??? Thanks all for the input. Coming along slower then had hoped, but may be in the air before the end of the year yet. John Ratcliffe ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 12, 2007
Its very possible that the entire speed difference in my Kolb could be related to my prop change, more on this in a differnt post... You definately want the VG's on the wingtips, so that they dont stall before the inner portion. With the vortex generators on the wingtips, better aileron control is maintaned at slow speed and in stalls, which is a huge safety advantege. Having VG's along the entire leingth of the wing is the best thing, I would not want to take some VG's off the wing and reduce the performance I have gained. I would just buy more before I would do that. I did not put VG's on the tail. The tail generates downforce, so when the tail stalls, it goes up... I have not seen any evidence of the tail stalling, I can touch the tailwheel first if I want, which tells me the tail is pushing down (not stalled) at my slowest speeds. VG's on the tail could change its handling though, so if I ever wanted to change the way the plane feels, VG's could make landings easier, or harder. The only way to know this would be flight testing with VG's on the tail... In my case im very happy and dont need VG's on my tail. Every plane is different, so I can definately see that others might benefit from VG's on the tail. I got the VG 's from www.landshorter.com and installed them exactly to their specs 10 % wing chord, 2.5 inches apart, and a very important and critical specification is that they be angled at a 15 degree angle to the airstream. The land shorter Vortex Generators have been optimized in both shape and size, so its well worth spending the 100 bucks to buy 100 of them that are perfect aerodynamically rather than try to make them. Extra VG's are only 1.50 each, so if I ever want to try them on the tail I will just spend 40 bucks and buy more. The VG's are wonderful, and there is absolutely nothing else that one could do to add this much more performance to a Kolb for 100 bucks. Mike Bigelow MK III Xtra Rotax 912-S -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123530#123530 ________________________________________________________________________________
Subject: Kolb Rigging - Flaps and Ailerons
Date: Jul 12, 2007
I have a MK-III Extra with seperate ailerons and flaps. I been doing some adjusting of my flaps and ailerons to try to find the best way to rig them. It seems to me that the bottom of each being flat with the wing in flight would be best combination of speed and low speed capability, but that is just a guess. Maybe having them droop just a bit would help my slow speed handling without hurting my cruise speed to much... What have you guys found ?? Anyone done any testing having the flaps and ailerons rigged slightly up or down, and what is your favorite way to rig your Kolb ? Mike MK III Xtra 912-S -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123537#123537 Attachments: http://forums.matronics.com//files/dsc03990_569.jpg ________________________________________________________________________________
Date: Jul 12, 2007
I hope you get this in time, a friend of mine wants to go, which changes all the weight and fuel and stops. He might be late so I am certian I can't promise anything now. But I hope to get to the flyin. ________________________________________________________________________________
Date: Jul 13, 2007
Hi Larry, A very uncomfortable porpoising at least, if you're lucky. Elevator control reversal and departure from controlled flight, if you're having a real bad day. VG's on the tail may be a bit of overkill, but they wouldn't hurt IMHO. The 2.5-inch spacing seems way overkill, compared to the GA aircraft I've flown with STC'd VGs. Ed in JXN MkII/503 ----- Original Message ----- From: "Larry Cottrell" <lcottrell(at)fmtcblue.com> Sent: Thursday, July 12, 2007 12:57 PM Subject: Re: Kolb-List: Re: Vortex Generators - Flight test report. > (Snip) > Just what happens when the tail stalls? > > Larry C ________________________________________________________________________________
Date: Jul 13, 2007
I changed the subject to Tail Dolly To preclude the need to fold/unfold the tail every flight, I built a simple dolly to hold the tail tube and the wings tilted up to clear the tail wires. Attached are three photos. Thom in Buffalo Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123605#123605 Attachments: http://forums.matronics.com//files/root_tubes_secured_small_433.jpg http://forums.matronics.com//files/firestar_wings_tilted_on_dolly_small_100.jpg http://forums.matronics.com//files/close_up_of_boom_wing_dolly_small_920.jpg ________________________________________________________________________________
Subject: Re: Kolb Rigging - Flaps and Ailerons
Date: Jul 13, 2007
On Jul 13, 2007, at 12:23 AM, JetPilot wrote: > > What have you guys found ?? Anyone done any testing having the > flaps and ailerons rigged slightly up or down, and what is your > favorite way to rig your Kolb ? I adjust them up/down according to the pitch trim desired. ________________________________________________________________________________
Date: Jul 13, 2007
As a starting point it is recommended that you rig them to be slightly down or even with the bottom of the wing while lifting on the control surfaces a bit to take the slack out of the control linkage. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Eugene Zimmerman" <etzim62(at)earthlink.net> Sent: Friday, July 13, 2007 12:50 PM Subject: Re: Kolb-List: Kolb Rigging - Flaps and Ailerons > > > On Jul 13, 2007, at 12:23 AM, JetPilot wrote: > >> >> What have you guys found ?? Anyone done any testing having the flaps >> and ailerons rigged slightly up or down, and what is your favorite way >> to rig your Kolb ? > > > I adjust them up/down according to the pitch trim desired. > > > ________________________________________________________________________________
Date: Jul 13, 2007
Very Cool! Now you can be flying in about 10 minutes... -Erik -------- -Erik Grabowski Kolb Firestar N197BG CFI/CFII/LS-I Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123643#123643 ________________________________________________________________________________
Subject: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint
Date: Jul 13, 2007
Does anyone have experience with any of the Quicksilver aircraft, especially the MX Sprint with respects to how it flys compared to the Kolb Firestar? An ultralight instructor here in Boulder City, NV insists that the Kolb is much more complicated to fly than any of the Quicksilver aircraft. I guess the real question should be: Is the Kolb more forgiving than the Quicksilver??? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123682#123682 ________________________________________________________________________________
Date: Jul 13, 2007
Subject: Re: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint
I have owned Quicksilver aircraft. The quicksilvers have so much drag that they stick close to the airport. They burn up a lot of fuel to just fly. If you actually want to fly somewhere and then get back again go with a Kolb. The kolb is only slightly more complicated to fly but that is only if you are learning. If you know how to fly or once you learn how to fly the Kolb is a much better aircraft and much more enjoyable to fly. Plus you can quickly fold it up and put it away. Dan In a message dated 7/13/2007 4:34:15 P.M. Pacific Daylight Time, jhm9812(at)yahoo.com writes: --> Kolb-List message posted by: "John H Murphy" Does anyone have experience with any of the Quicksilver aircraft, especially the MX Sprint with respects to how it flys compared to the Kolb Firestar? An ultralight instructor here in Boulder City, NV insists that the Kolb is much more complicated to fly than any of the Quicksilver aircraft. I guess the real question should be: Is the Kolb more forgiving than the Quicksilver??? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123682#123682 ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 13, 2007
There's absolutely NO comparison... I owned a Quicksilver 3-axis MXL for a couple of years, and then later flew several Kolb models (and currently own a MkIIIC)... the Kolbs all fly SO much better, much, MUCH stronger, and more balanced and will fly hands-off (assuming they are rigged correctly). They will also fly as slow as a Quick, but will also fly MUCH faster. The difference is night and day. And there is -nothing- "complicated" about flying a Kolb... I find the Quicks more "complicated" since the stick is way off the right, and the instrument panel (on mine) was off to the left. I will say, though, that my Quick -- being my first ultralight -- was probably not rigged as tightly as it could be, but, even so, I can't imagine it being better in -any- of the characteristics than a Kolb. As for being "forgiving"... well, that's a pretty nebulous word... two pilots, each trained how to fly their craft properly, would probably find each plane "forgiving". My $0.02... -- Robert On 7/13/07, John H Murphy wrote: > > Does anyone have experience with any of the Quicksilver aircraft, especially the MX Sprint with respects to how it flys compared to the Kolb Firestar? An ultralight instructor here in Boulder City, NV insists that the Kolb is much more complicated to fly than any of the Quicksilver aircraft. I guess the real question should be: Is the Kolb more forgiving than the Quicksilver??? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=123682#123682 > > ________________________________________________________________________________
Date: Jul 13, 2007
Subject: mk lll kolb for sale in florida....
Hello gang, A fellow i know has a mk lll for sale in florida....anyone interested can call him at 863-990-8186 his name is John Guy....he has lost hangar and is not flying the plane is reason for sale...has no email ...please contact him and not me as I know very little about the plane. jim Swan firestar ll 503 michigan do not archive ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Re: Firestar aileron chord length
Date: Jul 13, 2007
Thom, I measured my ailerons. They taper from 14-7/8" inboard to 11" at the wing tips. I pulled my plans out to double check. The plans call for 14-3/4" inboard and 11" outboard. It looks like the builder of your Firestar and I both screwed up by a few fractions of an inch on the inboard end. Other than that you have bone stock ailerons per the plans for the original Firestar and the KXP. The drawings are dated April of '85 and Aug of '90 respectively. Those big ailerons work great at low airspeeds. Anybody have their plans handy? Are the aileron dimensions different on the FirestarII? Inquiring minds want to know..... -------- Roger in Oregon 1992 KXP 503 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123701#123701 ________________________________________________________________________________
Date: Jul 13, 2007
I guess the real question should be: Is the Kolb more forgiving than the Quicksilver??? If this is the real question, clarify "more forgiving" in what respect???? Kolbs do what you ask of them, within their limitaions. I would imagine the same is true with the Quicksilver. : ) Jim Try Them both, with an experienced pilot/CFI ----- Original Message ----- From: DBforfun(at)aol.com To: kolb-list(at)matronics.com Sent: Friday, July 13, 2007 6:51 PM Subject: Re: Kolb-List: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint I have owned Quicksilver aircraft. The quicksilvers have so much drag that they stick close to the airport. They burn up a lot of fuel to just fly. If you actually want to fly somewhere and then get back again go with a Kolb. The kolb is only slightly more complicated to fly but that is only if you are learning. If you know how to fly or once you learn how to fly the Kolb is a much better aircraft and much more enjoyable to fly. Plus you can quickly fold it up and put it away. Dan In a message dated 7/13/2007 4:34:15 P.M. Pacific Daylight Time, jhm9812(at)yahoo.com writes: Does anyone have experience with any of the Quicksilver aircraft, especially the MX Sprint with respects to how it flys compared to the Kolb Firestar? An ultralight instructor here in Boulder City, NV insists that the Kolb is much more complicated to fly than any of the Quicksilver aircraft. I guess the real question should be: Is the Kolb more forgiving than the Quicksilver??? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123682#123682bsp; --> ===================== ------------------------------------------------------------------------- ----- Get a sneak peak of the all-new AOL.com. ________________________________________________________________________________
Date: Jul 13, 2007
I have flown the quicksilver a little. It is primarily a rudder airplane. The ailerons are there to give a small amount of help to the rudder. You could fly the pattern without them most days. The Firestar is an aileron airplane. The rudder is used most for ground work and much less in the air. The quicksilver also has a much greater dihedral effect. It does not want to stay in a turn. You have to hold left stick and left rudder to stay in a left turn. Release control pressure and the plane will right itself. The Firestar has much less of this effect. It only take a little aileron to initiate a turn and then the stick can be mostly neutralized except for a little added backpressure if you want it. You then add controls the other way when you want to stop turning. A friend of mine is currently making the transition from Quick to Kolb and thought the Kolb was unstable. The plane kept steepening the turn because he was telling it to. When I explained that he did not need to hold the stick over, but only use it to start the turn, the "instability" disappeared and he is now comfortable with steep turns. I don't think a Firestar is any more difficult to fly than a Quick, but they are different. Hope this helps a little. -------- Roger in Oregon 1992 KXP 503 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123705#123705 ________________________________________________________________________________
Date: Jul 13, 2007
Sprin I also owned a kxp but with a 447. what would you rather cut a peace of cake with? a meat tenderizing hammer or a knife? I really liked the kxp over every Quicksilver I ever flew mal ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Is anyone using this 2-cycle oil?
Date: Jul 14, 2007
Hello all: I'm having difficulty getting Pennzoil air-colled 2-C oil locally. This product seems to be similar. Is anyone using this oil? It is priced very similarly to Pennzoil and soulds like it would meet Rotax specs. Any thoughts? Here is a link to the info: http://www.76lubricants.com/NR/rdonlyres/88A1712C-5E21-4311-8039-AC01D27B3C4C/0/76_Airkool_HP_2Cycle_Oil.pdf Thanks, -------- Roger in Oregon 1992 KXP 503 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123738#123738 ________________________________________________________________________________
Subject: Re: Is anyone using this 2-cycle oil?
Date: Jul 14, 2007
When it comes to asking opinions on oil to use, you open a whole can of worms.Ask 10 people get 10 different opinions. I have always used castrol TT or its replacement Castrol super. I have put up over 500 hours on two different 503s without having a bearing fail. One of the engines did stick the top ring but was easily freed up.Cylinders have not been scuffed.After freeing the top ring this engine was still in-service at 800 hrs. There are a lot of people using Pennzoil in this part of the world but I personally have seen no evidence that they out last any other oils. I have seen engines with stuck rings and others ,mostly early 582s with run bearings that have been on Pennzoil.Also 582s with run bearings on almost any type of oil that's available.The other thing to look at is the price you pay for some of these oils, if you are going to rebuild your engine at say 500 hours the extra cost of some oils will have exceeded the cost of the rebuild. I think its a personal choice thing if you believe one oil is giving you better protection than another then stay with it. Who can put a price on piece of mind when in a steep climb with a passenger over some unfriendly country just after take off. If the replacement oil meets the specs and you are happy to fly with it then I see no reason that it will not perform as well ,just keep an eye on the CHT and EXT temps if these are different than what you are used to { higher } then I would change back. Just my $00:02 worth Tony from down under MK111 classic ----- Original Message ----- From: "R. Hankins" <rphanks(at)grantspass.com> Sent: Saturday, July 14, 2007 7:24 PM Subject: Kolb-List: Is anyone using this 2-cycle oil? > > Hello all: > > I'm having difficulty getting Pennzoil air-colled 2-C oil locally. This > product seems to be similar. Is anyone using this oil? It is priced very > similarly to Pennzoil and soulds like it would meet Rotax specs. Any > thoughts? Here is a link to the info: > http://www.76lubricants.com/NR/rdonlyres/88A1712C-5E21-4311-8039-AC01D27B3C4C/0/76_Airkool_HP_2Cycle_Oil.pdf > > Thanks, > > -------- > Roger in Oregon > 1992 KXP 503 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=123738#123738 > > > -- > 4:08 p.m. > > ________________________________________________________________________________
Date: Jul 14, 2007
My first UL was a quicksilver MX super, an older design which was the aerobatic version in the MX series (though I trained in a 2-place sprint). But I pretty much agree with the comparisons made by the rest of the guys. The really significant differences flying-wise are the tailwheel aspect and the lack of dihedral in the Kolb over the stock sprint. If you have no tailwheel time in anything, you have to get used to that (just holding the nosewheel off the ground in your trike gear does NOT prepare you for tailwheel as some guys might think ;)). Fortunately, the Kolb is the best tailwheel trainer in existence - besides being pretty docile, the prop is up on the wing in the back and out of the way of any possible prop strikes. What more could you ask for in a tailwheel plane? ;) The other thing I remember having to get used to was the lack of roll coupling with the rudder as someone else mentioned. I've got over 100 hours in my FS II and sometimes still don't keep my turns completely coordinated. The lack of dihedral though has so many other advantages, though, I'd recommend removing it even on the quicksilver (which mark smith can help with). Otherwise, the transition should be pretty easy. First time I went around the patch in my FS II I remember it was very similar to flying my quick regarding inertia and etc.... The other advantage of the Kolb is ease of maintenance. It's strut-braced and uses the Al tube for the fuselage, a simpler design than the tube structure of the quick. All I've had to do on my FS II so far is replace the rudder and elevator cables (old ones had 500 hours on them and were fraying at pully block under the seat) apart from putting the new engine on it. PS. speaking of those cables, if you ever do need to replace them do NOT use stainless steel cable - you'll start getting broken strands at the pully block in about 20 hours (you should see the logbook for my plane with my attempt at this). Call Travis and get the galvanized cable from Kolb.... I still don't know why this happens, I suspect the small size of the pullies breaks the stainless though the angle doesn't exceed the suggestion in AC 43.13. In any case, the galvanized cures that problem..... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123747#123747 ________________________________________________________________________________
Date: Jul 14, 2007
Well, I'll say what I always say about 2-stroke oil.... The brand isn't that important, the important thing is the service grade. Rotax now recommends the API TC spec oil be used in the 2-strokes. Before there was a TC spec, though, they recommended TCW-III grade oil. Both of these oil grades will lubricate a 2-stroke, though the TC rating is more strenuous. The original owner of my FS II used the Walmart marine oil in that 503, which went more than 500 hours. the motor was still developing full power and ran fine at the time I took it off (I only replaced it becuase it was rotting away). I use the air cooled pennzoil too, but I have the save availability problems as you and will likely switch to the locally available TCW-III oil when I finish this last case of pennzoil I have.... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123749#123749 ________________________________________________________________________________
Date: Jul 14, 2007
Roger Stick your zip code in the box...Herb http://www.pennzoil.com/products/outdoor/2cycle_aircooled.html writes: > > > Hello all: > > I'm having difficulty getting Pennzoil air-colled 2-C oil locally. > This product seems to be similar. Is anyone using this oil? It is > priced very similarly to Pennzoil and soulds like it would meet > Rotax specs. Any thoughts? Here is a link to the info: > http://www.76lubricants.com/NR/rdonlyres/88A1712C-5E21-4311-8039-AC01D27B 3C4C/0/76_Airkool_HP_2Cycle_Oil.pdf > > Thanks, > > -------- > Roger in Oregon > 1992 KXP 503 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=123738#123738 > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 14, 2007
> >Roger > > Stick your zip code in the box...Herb > >http://www.pennzoil.com/products/outdoor/2cycle_aircooled.html > Better yet: http://oilstore.stores.yahoo.net/penaircool2c.html And they will deliver it right to your door. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jul 14, 2007
Thay oil will be fine for your Rotax. Denny Rowe Mk-3 PA ________________________________________________________________________________
Date: Jul 14, 2007
Pennzoil seesm to tbe the universal standard oil for Rotax engines, however, there remains a small pocket of resistance in Northeast Tennessee which has been using Phillips Injex since 1983 with no failures yet. (Probably close to 3,000 hours of Rotax/Phillips Injex time) So if you can't find Pennzoil, and Phillips is available, you might want to try it - PS - it doesn't leave as greasy a soot as Pennzoil does, for what that's worth - Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: "R. Hankins" <rphanks(at)grantspass.com> Sent: Saturday, July 14, 2007 3:24 AM Subject: Kolb-List: Is anyone using this 2-cycle oil? > > Hello all: > > I'm having difficulty getting Pennzoil air-colled 2-C oil locally. This > product seems to be similar. Is anyone using this oil? It is priced very > similarly to Pennzoil and soulds like it would meet Rotax specs. Any > thoughts? Here is a link to the info: > http://www.76lubricants.com/NR/rdonlyres/88A1712C-5E21-4311-8039-AC01D27B3C4C/0/76_Airkool_HP_2Cycle_Oil.pdf > > Thanks, > > -------- > Roger in Oregon > 1992 KXP 503 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=123738#123738 > > > ________________________________________________________________________________
Subject: propeller balance?
Date: Jul 14, 2007
Hi, I am trying to get Possum's video camera to the point that I can use it, but vibration is killing me. Due to the enclosure I have to hard mount it to the frame up by the nose cone. I have it as solid as I can and braced as well. Even with the camera stabilization there is noticeable vibration. John H and John W helped me set my blade angle when they were here, but I painted the tip to get it ready for its Air worthy inspection. I suspected that I got a bit more paint on one tip than the other, so I rigged up this set up to balance it. Spraying paint on what appeared to be the lightest tip until it balanced out. Every thing was level as well. If my methods are correct then the vibration (still more there than I would like) is not going to go away. Blades were rechecked and are still right on for angle. The blades were set in varying positions and did not move from setting. Larry C ________________________________________________________________________________
Subject: Re: propeller balance?
Date: Jul 14, 2007
I got some good movies from my Kolb, but used a non-solid mounting method. If I remember right, you have a Firestar? So maybe you can use this? If not, it was free... If you have the hoop skid for underneath the nose cone like the MKIII does, you can use that, because that is what I used. I hose clamped about a 3' length of aluminum tubing to the nose hoop, kinda close to the fuselage, extending toward the front beyond the hoop. The hose clamps were twisted up, but it was still good and solid. Then you take another slightly shorter piece of tubing and suspend it just below the first tube, ahead of the hoop, by hose clamping short lengths of bungee cord to each tube, so that the second is parallel to the first and just below it, supported by the bungees. Now you attach whatever you are using for a camera bracket to the lower tube. The camera is now vibration-free and hanging just ahead of the hoop. You want the tubes long enough to stabilize the camera so that it can't wig-wag or twist in the wind. I had to add a bit of nose up trim, but not bad. It looks like the pits but it works. Just don't nose over on landing... Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: Larry Cottrell To: kolb-list(at)matronics.com Sent: Saturday, July 14, 2007 2:36 PM Subject: Kolb-List: propeller balance? Hi, I am trying to get Possum's video camera to the point that I can use it, but vibration is killing me. Due to the enclosure I have to hard mount it to the frame up by the nose cone. I have it as solid as I can and braced as well. Even with the camera stabilization there is noticeable vibration. John H and John W helped me set my blade angle when they were here, but I painted the tip to get it ready for its Air worthy inspection. I suspected that I got a bit more paint on one tip than the other, so I rigged up this set up to balance it. Spraying paint on what appeared to be the lightest tip until it balanced out. Every thing was level as well. If my methods are correct then the vibration (still more there than I would like) is not going to go away. Blades were rechecked and are still right on for angle. The blades were set in varying positions and did not move from setting. Larry C ________________________________________________________________________________
Subject: Fw: propeller balance?
Date: Jul 14, 2007
Thanks for the tip Mr Pike, but I don't have a hoop. Here is how I have it mounted on the plane. I think that without having it shock mounted I am going to get this vibration. Perhaps a three blade would be smoother, but I guess I will never know. Larry ________________________________________________________________________________
Subject: Kolb Mark III X - trailering/storage experience
Date: Jul 14, 2007
Does anyone here use a trailer to haul/store their MK III X? The reason I ask is that I have a 24 foot trailer (Haulmark) that I'm trying to figure out if it would fit a MK III X? The limiting factor appears to be the inside wheel wells. It fits my Kolb Firestar II fine. When John Williamson was in town recently with his Kolbra, we measured it from the nose tip to the back of the wheels. It just would not fit inside. I would not be able to get the door closed and the Kolbra wheels were just to wide. The length by the way appears to be fine. Even though they call it a "24" foot trailer, it actually is a bit longer. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123829#123829 ________________________________________________________________________________
Subject: Firestar 1 - control cables rubbing elevator torque tube
Date: Jul 14, 2007
On my FS 1, when the elevator is moved in the nose up direction, well past neutral, the rudder control cables rub on the top side of the elevator torque tube. I plan on putting a sacrificial wear strip there to keep it from wearing into the torque tube more than it has. So far, not much more than the paint is worn off. My question is, is this normal on the FS 1? Or is it built wrong. Any ideas will be welcome. Thom in Buffalo Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123832#123832 ________________________________________________________________________________
Date: Jul 14, 2007
Subject: RE:propeller balance?
Gents, Is it a requirement to paint the prop tips or just a safe thing to do? John Ratcliffe ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 14, 2007
Subject: Re: Kolb Mark III X - trailering/storage experience
John H Murphy wrote: > > Does anyone here use a trailer to haul/store their MK III X? The > reason I ask is that I have a 24 foot trailer (Haulmark) that I'm > trying to figure out if it would fit a MK III X? The limiting factor > appears to be the inside wheel wells. It fits my Kolb Firestar II > fine. When John Williamson was in town recently with his Kolbra, we > measured it from the nose tip to the back of the wheels. It just > would not fit inside. I would not be able to get the door closed and > the Kolbra wheels were just to wide. The length by the way appears to > be fine. Even though they call it a "24" foot trailer, it actually is > a bit longer. > How much 'swing' do the gear legs have if you pick up the plane & take the weight off the wheels? If you get enough motion so that the gear is now narrow enough, you could use ratcheting tiedown straps or a small come-along to narrow the gear for transport. It's been done with other homebuilts. Charlie ________________________________________________________________________________
Subject: Warp Drive phone number or web address?
Date: Jul 15, 2007
John H, anybody, I need Warp Drives phone number, Google gets me nothing but dealers who don't answer their phones. Denny Rowe ________________________________________________________________________________
Subject: warp drive phone #
Date: Jul 15, 2007
Never mind, found it in the archives, first time for everything I guess. Denny ________________________________________________________________________________
Date: Jul 15, 2007
No no Richard, it's Klotz synthetic is the oil of choice for the Rotax 2-stroke. There's very little wear with this oil and it's super clean inside and on the plugs. Ralph B -------- Ralph B Original Firestar 20 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123920#123920 ________________________________________________________________________________
Date: Jul 15, 2007
I'm not that rich. Went to the Klotz webpage, and the cheapest Klotz 2-cycle oil I could find was $11.41 a quart. So unless you have some inside connection, I think I'll stay with Phillips Injex at $2.36 a quart, thanks anyway. And that's delivered to my door, if you buy a case at a time, the local distributor delivers it for free. Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: "Ralph B" <ul15rhb(at)juno.com> Sent: Sunday, July 15, 2007 12:23 PM Subject: Kolb-List: Re: Is anyone using this 2-cycle oil? > > No no Richard, it's Klotz synthetic is the oil of choice for the Rotax > 2-stroke. There's very little wear with this oil and it's super clean > inside and on the plugs. > > Ralph B > > -------- > Ralph B > Original Firestar > 20 years flying it > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=123920#123920 > > > ________________________________________________________________________________
Date: Jul 15, 2007
Klotz and all oils are getting expensive like gasoline. I buy the Klotz in bulk from the local dealer for $22/gallon and it lasts a long time. Ralph B -------- Ralph B Original Firestar 20 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124004#124004 ________________________________________________________________________________
Date: Jul 15, 2007
At 02:36 PM 7/14/2007, you wrote: >Hi, > I am trying to get Possum's video camera to the point that I can > use it, but vibration is killing me. Due to the enclosure I have to > hard mount it to the frame up by the nose cone. I have it as solid > as I can and braced as well. Even with the camera stabilization > there is noticeable vibration. I always had the same problem when I hard mounted it to the frame. You could always duck tape it to your head or I've found - most of the vibration goes away when you turn you engine off, albeit for a short while. ________________________________________________________________________________
Date: Jul 15, 2007
Subject: mula fly in was OK
the mula fly in was postponed till Sunday we had a good turn out but the weather could have ben better Saturday was defiantly going to be a bust, another good reason for a moor grass roots approach, malcolm ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Re: Warp Drive phone number or web address?
Date: Jul 15, 2007
I need Warp Drives phone number Denny Rowe 1-800-833-9357 ________________________________________________________________________________
Date: Jul 15, 2007
I have tried putting a bit of stiff foam under the camera, wind has been blowing too hard to make it fun, so I am biding my time waiting for a bit of calm. I have a Sony High 8 camera, so I had a lot of batterys that fit the camera. Most of them will last the Sony for as much as four hours. Man that thing eats batteries like candy. I had hoped that I would be able to smooth the plane out with balancing the prop. It is balanced but there is still enough vibration that it over powers the stabilization feature. I stuck the camera to the side of my headset, and got a great view of the hinge in the windscreen and the heater tube. I am a bit afraid that the duct tape would pull out my whiskers when I took it off. :-) Not only that, I find that I am a good pilot in that my head any eyes are scanning all over the place and I get a bit seasick when trying to watch the video. Larry ________________________________________________________________________________
Date: Jul 16, 2007
From: "Larry Cottrell" <lcottrell(at)fmtcblue.com> ............I had hoped that I would be able to smooth the plane out with balancing the prop. It is balanced but there is still enough vibration that it over powers the stabilization feature. .......... Larry, What you are seeing is the effect of torsional firing impulse on the air frame. As the propeller moment of inertia increases it becomes more difficult to speed or slow the propeller. The causes the firing impulse to be transmitted back to the crank shaft, to the crank case, mounts and finally to the air frame. If you wish to see less vibration, mount a lighter lower inertia propeller. You may be able to fool the camera by changing vibration frequency. Reduce engine speed and at some speed the stabilizer should be able to keep up. Just hope that it is a sustainable flight engine speed. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: Mk 3 steel main gear legs
Date: Jul 16, 2007
Rich, Do you still have the gear legs? Denny ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Friday, February 02, 2007 8:36 PM Subject: Re: Kolb-List: Mk 3 steel main gear legs Colder than a well digger's knee caps here, I woosed out last night, but got a picture today. Still in TNK tape and factory insert up to here lines. Rick On 2/1/07, Denny Rowe wrote: Are "these" ----- Original Message ----- From: Denny Rowe To: kolb-list(at)matronics.com Sent: Thursday, February 01, 2007 2:50 PM Subject: Re: Kolb-List: Mk 3 steel main gear legs Are this legs for a Mk-3 Classic? Do you still have them? Pic? Denny Rowe rowedenny(at)windstream.net ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Saturday, January 27, 2007 11:44 AM Subject: Kolb-List: Mk 3 steel main gear legs When I was in the midst of main gear straightening caused by my horrible landing technique, I thought the way out was TNK's steel gear legs. Now that I am pretty happy with my landings, I know I'm not going to install them. $350 for the pair, plus shipping. Rick -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. href="http://www.matronics.com/Navigator?Kolb-List"> http://www.matronics.com/Navigator?Kolb-List href="http://forums.matronics.com"> http://forums.matronics.com ------------------------------------------------------------------------ Date: 1/26/2007 11:11 AM href="http://www.matronics.com/Navigator?Kolb-List"> http://www.matronics.com/Navigator?Kolb-List href="http://forums.matronics.com"> http://forums.matronics.com ------------------------------------------------------------------------- - Date: 1/31/2007 3:16 PM http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ------------------------------------------------------------------------- ----- 2/1/2007 2:28 PM ________________________________________________________________________________
Date: Jul 16, 2007
Yep, still on my "parts I'll use someday" rack. Rick On 7/16/07, Denny Rowe wrote: > > Rich, > Do you still have the gear legs? > > Denny > > ----- Original Message ----- > *From:* Richard Girard > *To:* kolb-list(at)matronics.com > *Sent:* Friday, February 02, 2007 8:36 PM > *Subject:* Re: Kolb-List: Mk 3 steel main gear legs > > Colder than a well digger's knee caps here, I woosed out last night, but > got a picture today. Still in TNK tape and factory insert up to here lines. > > Rick > > On 2/1/07, Denny Rowe wrote: > > > > Are "these" > > > > ----- Original Message ----- > > *From:* Denny Rowe > > *To:* kolb-list(at)matronics.com > > *Sent:* Thursday, February 01, 2007 2:50 PM > > *Subject:* Re: Kolb-List: Mk 3 steel main gear legs > > > > Are this legs for a Mk-3 Classic? > > Do you still have them? > > Pic? > > Denny Rowe > > rowedenny(at)windstream.net > > > > > > ----- Original Message ----- > > *From:* Richard Girard > > *To:* kolb-list(at)matronics.com > > *Sent:* Saturday, January 27, 2007 11:44 AM > > *Subject:* Kolb-List: Mk 3 steel main gear legs > > > > When I was in the midst of main gear straightening caused by my horrible > > landing technique, I thought the way out was TNK's steel gear legs. Now that > > I am pretty happy with my landings, I know I'm not going to install them. > > $350 for the pair, plus shipping. > > > > Rick > > > > -- > > Rick Girard > > "Ya'll drop on in" > > takes on a whole new meaning > > when you live at the airport. > > > > * > > > > href="http://www.matronics.com/Navigator?Kolb-List"> > > http://www.matronics.com/Navigator?Kolb-List > > href="http://forums.matronics.com"> > > http://forums.matronics.com > > * > > > > ------------------------------ > > Date: 1/26/2007 11:11 AM > > > > * > > > > href="http://www.matronics.com/Navigator?Kolb-List"> > > http://www.matronics.com/Navigator?Kolb-List > > href="http://forums.matronics.com"> > > http://forums.matronics.com > > * > > > > ------------------------------ > > Date: 1/31/2007 3:16 PM > > > > * > > <http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com* > > > > > > > -- > Rick Girard > "Ya'll drop on in" > takes on a whole new meaning > when you live at the airport. > > ------------------------------ > Date: 2/1/2007 2:28 PM > > * > > > * > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: Kolb Mark III fuel tanks
Date: Jul 16, 2007
Does anyone know where to buy 8 gal. plastic fuel tanks to replace the standard 5 gal ones? I know Kolb is selling 6 gal replacements but have heard there are some 8 gal ones out there. Thanks for the help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124072#124072 ________________________________________________________________________________
Subject: Re: Kolb Mark III fuel tanks
Date: Jul 16, 2007
I dont know the website, but 8 gallons would be great if they drop right in. I have been wanting to put two 10 gallon tanks in my MK III Xtra, but it will require cutting the current tubing and welding a new frame for them to sit in, so I have been putting it off. There is plenty of room for two 10 gallon tanks or even bigger just by redoing the frames they sit in... If I could just buy 8 gallon tanks that would drop right in, it would be so easy I just might do it. If you do find them let us know where you can get them. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124078#124078 ________________________________________________________________________________
Date: Jul 16, 2007
I dont know the website, but 8 gallons would be great if they drop right in. I have been wanting to put two 10 gallon tanks in my MK III Xtra, but it will require cutting the current tubing and welding a new frame for them to sit in, so I have been putting it off. There is plenty of room for two 10 gallon tanks or even bigger just by redoing the frames they sit in... If I could just buy 8 gallon tanks that would drop right in, it would be so easy I just might do it. If you do find them let us know where you can get them. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124077#124077 ________________________________________________________________________________
Subject: Re: FS 1 First Flight questions
Date: Jul 16, 2007
Rick, If what you suggest leans the mixture at mid-range (it will), then the EGT's would go up, no? Thom in Buffalo Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124123#124123 ________________________________________________________________________________
Date: Jul 16, 2007
try raising the clip one notch (lowering the needle and leaning the midrange) and monitor CHT and EGT. CHT should go up and EGT should come down. Isn't this backwards? If his CHT's are high now in midrange, it would seem to follow that he needs more fuel to cool it down. Larry C ________________________________________________________________________________
Date: Jul 16, 2007
The trim problem you are having is from flying a high thrust mounted pusher airplane, that is normal for that plane. The more thrust you have, the more the plane will tend to pitch down. Take off the power, and the airplane goes up. This has nothing to do with the thrust angle, its easier than that. All you need to trim the elevator to fly straight and level with cruise power and speed. My MK III has a spring trim system, I just put in some nose up trim for level flight at cruise power setting. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124125#124125 ________________________________________________________________________________
Date: Jul 16, 2007
I had a friend that was going to build a model helo blade balancer... it was to consist of an accelerometer and a processor that would take all the guess work out of balancing the prop.. I found when balancing a helo blade.. You could static balance it like you did in the photo.. But when it was spinning up to speed it still needed some fine tuning. I used a wrap of electrical tape at the mid blade ( the cg of the blade) and tried it to see if it was worse or better.. Then adjusted it from there. either more or less tape on that blade or the other.. I will try and see if my friend built something he could market or sell me and find out how much $$$ Boyd ________________________________________________________________________________
Date: Jul 16, 2007
Larry, The condition Thom quoted was low CHT's and high EGT's with the prop pitched correctly. Since the aircraft is new to Thom, the first thing to verify is that everything is set up stock and the easiest thing to check, in my humble opinion, is the needle setting and the correctness of the needle setup. Also, he says the temps are all good when at WOT. This suggests that the main jet is stock or very close to it. All the things I listed should be checked immediately after purchase on any engine carrying Bing carbs and annually thereafter to insure that the needle is protected from vibration damage. All but one of my aircraft engines came with some portion of the vibration preventatives missing or installed incorrectly. The 582 I inspected at Sun n Fun had damage to both needles, one almost to the point of failure. When that happens the fire goes out. So, my idea was, why not do the easy inspection of a known problem area first, make sure all the jetting is stock and move on from there, once it's certain everything is up to snuff? Even if you have to replace every piece I mentioned, it's only about $50 a carb, so it's probably the cheapest potential life saving repair you'll ever do, too. Rick On 7/16/07, Larry Cottrell wrote: > > > try raising the clip one notch (lowering the needle and leaning the > midrange) and monitor CHT and EGT. CHT should go up and EGT should come > down. > > Isn't this backwards? If his CHT's are high now in midrange, it would seem > to follow that he needs more fuel to cool it down. > Larry C > > * > > > * > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Jul 16, 2007
I guess my logic would be that there is less fuel being burned on the way out the exhaust port making the EGT go down or remain unchanged. Rick On 7/16/07, Thom Riddle wrote: > > > Rick, > > If what you suggest leans the mixture at mid-range (it will), then the > EGT's would go up, no? > > Thom in Buffalo > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=124123#124123 > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Jul 16, 2007
|I guess my logic would be that there is less fuel being burned on the way | out the exhaust port making the EGT go down or remain unchanged. | | Rick Rick/Richard: My experience with 2 strokes has been: 1-Unload the prop, EGT goes up. 2-Load the prop, EGT goes down. How did I discover this? Watching the EGT on my Ultrastar in 1984, as I pulled the nose up and loaded the prop, and pushed the nose over and unloaded the prop. 3-Lean it midrange, EGT goes up. Richen it up in midrange, EGT goes down. 4-Full throttle is same as midrange. Finally, I don't worry about CHT, except to keep it under the red line. My experience and opinion only. The two stroke operates best when it is pitched to turn max continuous rpm, WOT, straight and level flight. I find the EGT will be right in the ball park, and one will experience the best climb and cruise with a prop that is not "in flight adjustable." I prop my boats the same way as I do my airplanes. Gives me the best "out of the hole" and cruise performance. For what it is worth, john h mkIII ________________________________________________________________________________
Date: Jul 16, 2007
Thom, Your carb needle is set at the second from the bottom, o-ringed in place and under the cup. I put it there a few weeks ago. I've been researching the EGT for the last year, and if you notice in the Rotax manual for the 447, they don't give an EGT spec... just a CHT. I've even talked to a few Rotax repairman about it and they say as long as the CHT is OK, you are pitched for 6500 RPM at WOT, that's OK. With that advice and the manual not having the EGT limit for the 447, I felt confident in the engine. When it all comes down to it, it is what YOU feel comfortable with. Hope that helps a little. (at least about where your needle is set) -------- -Erik Grabowski N????? CFI/CFII/LS-I Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124219#124219 ________________________________________________________________________________
Date: Jul 16, 2007
grabo172 wrote: > > Thom, > > Your carb needle is set at the second from the bottom, o-ringed in place and under the cup. I put it there a few weeks ago. > > I've been researching the EGT for the last year, and if you notice in the Rotax manual for the 447, they don't give an EGT spec... just a CHT. > > I've even talked to a few Rotax repairman about it and they say as long as the CHT is OK, you are pitched for 6500 RPM at WOT, that's OK. > > With that advice and the manual not having the EGT limit for the 447, I felt confident in the engine. > > When it all comes down to it, it is what YOU feel comfortable with. > > Hope that helps a little. (at least about where your needle is set) > > -------- > -Erik Grabowski > N????? > CFI/CFII/LS-I > That's exactly how the local 447 drivers around here do it. Jet and Prop by the book and forget the EGT. ~ Earl ________________________________________________________________________________
Date: Jul 17, 2007
If EGT is okay at full throttle and too high at cruse that means your main jetting is good and needle too lean. Check the holes in sides of needle jet tube if they have a build up that will cause a lean mixture even if your needle is set in the correct clip setting. You can use a toothpick to clean the holes or a piece of wire then blow out with air. Worth a try, very easy to do. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124337#124337 ________________________________________________________________________________
Date: Jul 17, 2007
Not necessarily. See here: http://www.bcchapel.org/pages/0003/pg11.htm Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: "tlongo" <tlongo(at)tampabay.rr.com> Sent: Tuesday, July 17, 2007 10:03 AM Subject: Kolb-List: Re: FS 1 First Flight questions > > If EGT is okay at full throttle and too high at cruse that means your main > jetting is good and needle too lean. ________________________________________________________________________________
Subject: Two Stroke Prop and Carb Tuning
Date: Jul 17, 2007
| Not necessarily. See here: | http://www.bcchapel.org/pages/0003/pg11.htm | Richard Pike Richard P: How do you do a spark plug check? john h mkIII PS: I changed to subject line to be more in line with what is being discussed. ________________________________________________________________________________
Date: Jul 17, 2007
Sprin At 06:40 AM 7/14/2007, lucien wrote: > >My first UL was a quicksilver MX super, an older design which was the >aerobatic version in the MX series (though I trained in a 2-place sprint). > >But I pretty much agree with the comparisons made by the rest of the guys. >The really significant differences flying-wise are the tailwheel aspect >and the lack of dihedral in the Kolb over the stock sprint. I expect to fly my US pretty soon... with about 10 hours in a Quick (not counting the weightshift Quick I damn near killed myself in) and 400 hours in a Taylorcraft (so the tailwheel doesn't worry me), anything I should bear in mind on my first flight in the US? >...The lack of dihedral though has so many other advantages, though, I'd >recommend removing it even on the quicksilver (which mark smith can help with). Along with a Super (I miss doing aerobatics) that's something I'd like to fly (a Mark Smith Quickalike, I mean)... the Quick I was flying was bone stock, beat up and sloppy, pretty much a pig. -Dana -- -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Subject: Re: Two Stroke Prop and Carb Tuning
Date: Jul 17, 2007
How DO I it, or how SHOULD I do it? There's a difference you know... I have always heard that the ideal way to do it is to be running your engine at the RPM & loading you want to check for, leave it there for a couple minutes, and then turn the engine off and then check it. Since there is a difference in prop loading in flight than on the ground, that would mean being right above a suitable strip to chop the engine, glide down, and then pull the plug out and look at it. That should be the ideal to give you an unadulterated reading. Probably running it at the RPM you wanted on the ground would actually work close enough in practice. The way I do it is I leave my plugs in long enough for them to be distinctively colored (at least 15 hours) and then take them out and look at them. (blush, kicks dirt with foot) Which tells me if the engine is running consistently too lean, (whitish-gray) consistently too rich, (black) or more or less right. (brown) And since the stock Rotax specified jetting gives me temps right around 1050-1100, and the plugs are a medium brown, I actually can't remember the last time I did a plug check. Probably the last time I actually did a genuine, hard core, do-it-right-or-else plug check was with a Rotax 277 in the Hummer about 24 years ago. But thanks for asking... Richard Pike MKIII N420P (420ldPoops) PS - this is probably the best description of how to do it- http://dirtbike.off-road.com/dirtbike/article/articleDetail.jsp?id=332655 ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Tuesday, July 17, 2007 11:35 AM Subject: Kolb-List: Two Stroke Prop and Carb Tuning > > > | Not necessarily. See here: > | http://www.bcchapel.org/pages/0003/pg11.htm > | Richard Pike > > > Richard P: > > How do you do a spark plug check? > > john h > mkIII > > PS: I changed to subject line to be more in line with what is being > discussed. > > > ________________________________________________________________________________
Date: Jul 17, 2007
| I have always heard that the ideal way to do it is to be running your engine | at the RPM & loading you want to check for, leave it there for a couple | minutes, and then turn the engine off and then check it. Since there is a | difference in prop loading in flight than on the ground, that would mean | being right above a suitable strip to chop the engine, glide down, and then | pull the plug out and look at it. | | Richard Pike Richard: That is the way I did it. Past tense. Haven't done one in a while. I long while. Normally, the engineers that design and build these things know what they are doing. Two strokes are unique when combined with an airplane. Suddenly we have a propeller and prop loading. ;-( For most of us folks down here near sea level and up to 1,500 or 2,000 feet, that Rotax two stroke is jetted, timed, and equipped with the correct heat range spark plug to do the job, with nothing for the pilot/builder to do but dial in the correct pitch to load the prop. Always the same for me. WOT, straight and level flight, just bump the red line which is max continuous rpm for me because I fly with a prop that is not inflight adjustable. This will put my egt and cht right in the green arc on a Rotax two stroke, and other brands also. 912UL and 912ULS it is 5,500 rpm Rotax two strokes is 6,500 rpm Pushing the EGT redline to squeeze more power and less fuel burn is also pushing the engine failure factor with a two stroke, IMHO. john h mkIII ________________________________________________________________________________
Sprin
Date: Jul 17, 2007
anything I should | bear in mind on my first flight in the US? | | | -Dana Dana: A couple things: 1-Don't forget to fly the airplane. 2-Ultrastars do not fly below the stall speed, even though they will fly in a mush at a rapid rate of descent. 3-Gravity is not prejudice. Most folks that have trouble with an Ultrastar usually do so on landing. They are not accustomed to sitting out in the open, in front of the wing, get the airplane in a below stall speed mush, and spready the gear. Have personally witnessed this process several times over the years. Take care and have a fun flight. john h mkIII ________________________________________________________________________________
Date: Jul 17, 2007
| If you do not have a primer, sell your EGT gauge and get one. Just | kidding ,,,,,,, but do get one. | | These EGT gauges are notoriously inaccurate. | | Gene Z Gene: You can get the same results, in flight, with the enricher. Not only on the two strokes, but it also works on the 912 series engines. Old fashioned, using the enricher on all my engines. john h mkIII ________________________________________________________________________________
Subject: Mushy control stick
Date: Jul 17, 2007
Hey gang, After Charleys first flight in the Kolbra the only complaint he had was mushy responce from the stick. Well we figured alot of this is his lack of time in a Kolb type aircraft and his comparing it to the RV8 or even the jets he flys on a regular basis. After John H stopped by and it was discussed we or John rather found some movement in the control tube that sticks out the back and connects to the aileron push pull tubes. Right away we all agreed "There is your mush". Then it was suguested that more support be added back there. I started thinking of a way to fix this. To back up a bit remember than we changed the configuration of this area by running the control rod through a nylon bearing and making it fixed at the aft point. This leaves about 8" of the 4130 tube un-supported. However I got to really thinking about the steel tube and thought hmmm man there is no way that the 4130 steel tube is "flexing" that much. Now here is my thinking.. I am thinking that because the control tube is supported by a ridgid mount aft vs the slider for the flaperons, the flex or mush is coming from the lack of support at the other end of the control tube up near the rubber U-Joint. This makes perfect sence to me now that I think about it. The rubber U-joint is supported less than 3" in front but nothing of support to maybe 4' aft. This would make alot of stress on the U-joint and explain the flexing. Any of you guys think Im on the right track here? As soon as I can get back to the airplane and have some help I will confirm this therory and report back. The only reason for this post about this issue is this.... Other Kolbs with flapperons when the flapperons are extended may encounter the same mushy feel. might want to get a buddy to hold the aileron and another to move the stick side to side and watch the movenent at the U-Joint to see if the tube is trying to warp up/down or sideways. If my theroy is confirmed I will make a nylon bearing and mount it to the tail boom up close to the U-Joint to prevent this flexing. -------- Paul Petty Kolbra #12 Ms Dixie 912 UL 70" warp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124453#124453 ________________________________________________________________________________
Date: Jul 17, 2007
This looks like a nice 10 gallon tank for replacement of the Kolb Fuel tanks. http://www.air-techinc.com/prod_cat_item.asp?categoryID=fueltanks&typ=exclusives&ID=1080 -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124474#124474 ________________________________________________________________________________
Date: Jul 17, 2007
Hey John, I believe your $.02 on the subject will probably buy as much as mine, :-) except perhaps at higher power settings. The enricher becomes decreasingly effective as the throttle is opened. In fact one reason some people have difficulty starting a cold engine using the enricher is because they open the throttle too far for the enricher to be effective. The enricher works different than a choke. I know I'm preaching to the choir with you. Gene, On Jul 17, 2007, at 2:36 PM, John Hauck wrote: > > > | If you do not have a primer, sell your EGT gauge and get one. > Just > | kidding ,,,,,,, but do get one. > | > | These EGT gauges are notoriously inaccurate. > | > | Gene Z > > Gene: > > You can get the same results, in flight, with the enricher. Not only > on the two strokes, but it also works on the 912 series engines. > > Old fashioned, using the enricher on all my engines. > > john h > mkIII > > ________________________________________________________________________________
Date: Jul 17, 2007
| I believe your $.02 on the subject will probably buy as much as | mine, :-) except perhaps at higher power settings. | The enricher becomes decreasingly effective as the throttle is opened. | | In fact one reason some people have difficulty starting a cold engine | using the enricher is because they open the throttle too far for the | enricher to be effective. The enricher works different than a choke. | I know I'm preaching to the choir with you. | | Gene, Gene: Reason I shared my little bit of info is because it worked with me and the 912UL. Did not feel like it was running as crisp as it should at 5,000 rpm cruise. Had had a problem with this same engine on my flight to Deadhorse, AK, in 1994. Was still working on the problem with less than ideal performance at cruise in colder climates. After I got back home, I experimented a lot trying to come up with a fix. While on a cross country flight to Mobile, AL, I got the idea to pull on the enricher. When I did, cruise speed increased 200 rpm. When I got back home, I pulled the carb piston, raised the needles a knotch, and my cold weather and warm weather midrange problem was solved. Wish I could have figured that out in Alaska. I would have made Point Barrow in 1994 instead of 2001. BTW: After I raised the needles in the 912, I checked the enricher at cruise rpm and the engine lost 200 rpm, indicating the enricher was making it go over rich. I might add, the 912 is tuned very close to max lean in midrange. Does not take much more leaning to piss off the 912 and make it act up. Definitely gets the pilots attention. I realize the enricher is not a choke. That is why I never had a need for primers. Never had a problem starting pull start, electric starter two strokes, and four strokes, using the correct procedure for starting. Do it right by the book and it works for me. john h mkIII ________________________________________________________________________________
Subject: Re: Mushy control stick
Date: Jul 17, 2007
When I first started flying my FS II, I noticed the stick was rather "springy" in the aileron direction. It isn't what I'd call mushy, but definitely springy... Once I started relaxing and looking around a bit, I took it up and did some full-deflection wing rocking to get an idea of the aileron response. I noticed the ailerons hardly defected at cruise even with the stick against the stop to either side. I think some of the spring is twisting of the torque rod between the stick and the bellcrank in the back that attaches to the pushrods. Probably the rest is absorbed elsewhere, just in the general play in the aileron linkage. I don't think there are long portions of unsupported rod, but there might be towards the back.... So some of the flexing you're having could just be the tube itself? That's my only quarrel with the plane at all, and even so with gap seals on the ailerons there's still a good bit of aileron control. Otherwise, I love the design of the ailerons. Very simple and virtually no maintenance. No linkages, pullies or pushrods in the wing anywhere, it's all outside the plane for easy inspection and lubrication, etc. LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124515#124515 ________________________________________________________________________________
Date: Jul 18, 2007
Just FWIW, The same methods appear to work at high density altitudes as well. I fly at about 7000' MSL where I live, the DA is frequently as high as 9000' even in the morning. Basically, the only change I've had to make to the 503 on my FS II is a leaner main jet as per the Rotax jetting chart. Virtually everything else is the same except a very slightly higher rpm needed to maintain altitude at my cruise speed and of course a noticeable improvement in fuel economy. Oh, and a much crappied climb rate, but it's still as good as the local spam cans.... ;) LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124538#124538 ________________________________________________________________________________
Date: Jul 18, 2007
I have the same springy feeling in my MK - III Xtra. There is a lot of aileron deflection on the ground, but in the air the ailerons dont deflect that much even with stick deflection. In my case, all the linkages are steel, well supported, and have almsot no play. I do have the seperate flaps and ailerons though, and im sure most of my "SPRINGY" feeling is comming from the aluminum tubes on the wing that go out to the aileron. There must be 6 feet of aluminum tube there before it gets to the aileron, and 6 more in the aileron itself... That could cause a LOT of spring like twist. There is not much I can do about this exept go to a thicker tube, but that would involve a lot of work and given the leingth of it, some springy feeling would always be there. I am going to add aileron spades to the counterweights to take much of the air loads resistance off the ends of the tubes and prevent it twisting so much. That should make for much lighter and more pleasant aileron forces. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124540#124540 ________________________________________________________________________________
Date: Jul 18, 2007
I should mention, speaking of control forces, that my FS II has the lightest forces in all axes of any plane I've flown so far.. The compromise there is it doesn't have huge amounts of control, but of course then again, it's not a Pitts and wasn't designed to be... ;) My titan tornado, for example, has vastly more control, but the stick is a lot heavier in comparison, even with the spades on the ailerons..... I also kicked around some thoughts of modifications of the aileron system on the FS II to take out some of the flex and give more deflection. But that would put me in test pilot territory, with new unknowns as far as additional stress on the ailerons, hinges and possibly even the wing panels and who knows what else........ Also, since the Kolb has been flying for a long time as-is, I figured it's all working as designed. So I haven't messed with it. I still haven't flown in the big Kolbs yet, so I don't know how they are as far as amount of control available and etc. A couple friends of mine in TX have an older MK III and I noted the same flexing in the ailerons. But they fly that plane in conditions I wouldn't think of going up in in my FS II, so.... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124552#124552 ________________________________________________________________________________
Date: Jul 18, 2007
How do you think the wingtip vortices will interact with those spades? Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Wednesday, July 18, 2007 9:44 AM Subject: Kolb-List: Re: Mushy control stick > > I have the same springy feeling in my MK - III Xtra. There is a lot of > aileron deflection on the ground, but in the air the ailerons dont deflect > that much even with stick deflection. In my case, all the linkages are > steel, well supported, and have almsot no play. I do have the seperate > flaps and ailerons though, and im sure most of my "SPRINGY" feeling is > comming from the aluminum tubes on the wing that go out to the aileron. > There must be 6 feet of aluminum tube there before it gets to the aileron, > and 6 more in the aileron itself... That could cause a LOT of spring like > twist. There is not much I can do about this exept go to a thicker tube, > but that would involve a lot of work and given the leingth of it, some > springy feeling would always be there. I am going to add aileron spades > to the counterweights to take much of the air loads resistance off the > ends of the tubes and prevent it twisting so much. That should make for > much lighter and more pleasant aileron ! > forces. > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you > could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=124540#124540 > > > ________________________________________________________________________________
Date: Jul 18, 2007
From: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
<< ... at the other end of the control tube up near the rubber U-Joint. >> Paul - Rubber U-Joint? I've not heard of this design feature. (It's not on the M-3 Classic.) Is this unique to the Kolbra? Why would the designers want to "soften" the control transmissions between the control stick and the ailerons? Dennis Kirby ________________________________________________________________________________
Date: Jul 18, 2007
Maybe take Kimberly's advice and reflex the ailerons a bit. That might help a lot with the control forces. J.D. > My titan tornado, for example, has vastly more control, but > the stick is a lot heavier in comparison, even with the > spades on the ailerons..... ________________________________________________________________________________
Date: Jul 18, 2007
Richard, I have thought quite a bit about the wingtip vorticies affecting spades on the tips, and I have come to concusion that I have no idea :) I think the only way I will ever know is to try it. I will bolt the spades onto the counterweights so that I can take them off if I dont like the results. Threre is a possibility of the ailerons going hard over if the spades are to big or the vorticies are a big probelm, so I will start out with small ones to see how they act and make them bigger until the releive enough of ths stick pressure. I will also flight test it by flying a foot off the runway and progressively faster speeds to get an idea of what they will do. Lucien, The aileron forces on the MK III Xtra are very heavy, much heavier than on a Cessna 172. I could live with even normal forces, but not the very heavy forces needed to make a turn. The Kolb is not designed to roll fast, and I dont want it to, but I do want to be able to turn the plane without a huge amount of effort. I have thought about wing twist and fatigue of the panels, and I plan to fly the plane within its limits, I just want it to be pleasant and easy to fly. Durring the building phase, I got some good advice from John Hauck and streingthened the wing structure with angle aluminum along the ribs, before and behind the spar. This should make my MK III much more resistant to any fatigue and twisting from aileron forces. Attached is a picture of the wing before covering. Reflexing the ailerons might reduce the aileron forces some, but it is a horrible way to do it. The proper term for reflexed ailerons is "Spoilerons", meaning the ailerons are also acting as spoilers. It may make it a bit easier to roll, but relfexing the ailerons also kills lift, increases stall speed, and makes the wing less efficient. I dont want any of these bad side effects in my plane. Michael Bigelow -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124565#124565 Attachments: http://forums.matronics.com//files/ultralightmikekolbbuildpictures073_113.jpg ________________________________________________________________________________
Date: Jul 18, 2007
Find an excuse to get to NE Tennessee & stop by Indian Springs airport and I'll let you fly mine. Light ailerons and all. Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Wednesday, July 18, 2007 11:32 AM Subject: Kolb-List: Re: Mushy control stick The aileron forces on the MK III Xtra are very heavy, much heavier than on a Cessna 172. I could live with even normal forces, but not the very heavy forces needed to make a turn. The Kolb is not designed to roll fast, and I dont want it to, but I do want to be able to turn the plane without a huge amount of effort. ________________________________________________________________________________
Date: Jul 18, 2007
Mike: The weakest, most flexible part of the Kolb wing is the bow tip. You plan on turning the aileron counterbalance weight into a spade at the weakest, most flexible point, outboard of the wing tip. Might want to think on that a bit. Also, the counterbalance weight attachment was not designed nor intended to have increased torsional loads. Remember, every time you change one thing, it will affect several more in the chain. If it were me, I would look at the geometry of the aileron control from stick to aileron. To get a little more, or a lot more mechanical advantage, it is pretty simple to change the arm length of a bell crank or horn to more effect with less effort. All Kolbs inherently load up the ailerons at speeds over 50 to 60 mph. You ain't gonna change that unless you cut the cord of the aileron in half. Then you lose low speed aileron authority which, to me, is extremely important. Much more important than light stick force at higher speeds. At lower speeds it is easy to move the stick from stop to stop, when it is really needed should you get caught in violent winds and want to be on the ground more than in the air. At higher speeds one does not have to deflect the aileron but a tad to make the aircraft roll. A little rudder input helps. Also a little patience. Like has been said, you ain't flying a Pitts Special. If you are interested in doing snap rolls and aileron rolls then you might need a whole buncha aileron at higher speeds. Kolbs are not to be compared with Cessna 172's, Piper Warriors, Challengers, Titan Tornados, ect. They have very little in common. Kolbs do things differently than most airplanes. Yet, they are very easy to fly and very forgiving, if you don't turn into a design engineer and screw it up. john h mkIII ________________________________________________________________________________
Date: Jul 18, 2007
At 11:32 AM 7/18/2007, you wrote: > >Richard, > >I have thought quite a bit about the wingtip vorticies affecting >spades on the tips, and I have come to concusion that I have no idea :) One of the guys we used to fly with put spades on a Firestar, but he put them in the middle of the ailerons ( I think). John H might remember. ________________________________________________________________________________
Date: Jul 18, 2007
here is the U-Joint. -------- Paul Petty Kolbra #12 Ms Dixie 912 UL 70" warp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124609#124609 Attachments: http://forums.matronics.com//files/p1210049_164.jpg ________________________________________________________________________________
Date: Jul 18, 2007
| here is the U-Joint. | | -------- | Paul Petty That is a rubber dust cover, not a rubber universal joint. john h mkIII ________________________________________________________________________________
Date: Jul 18, 2007
here is the old U-Joint. ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 18, 2007
| wow! never knew there was a tiny U-Joint in there. Looked them up in AC spruce. | Paul Petty Did you look at the prices??? john h mkIII ________________________________________________________________________________
Date: Jul 18, 2007
John Hauck wrote: > Mike: > > The weakest, most flexible part of the Kolb wing is the bow tip. You > plan on turning the aileron counterbalance weight into a spade at the > weakest, most flexible point, outboard of the wing tip. Might want to > think on that a bit. Also, the counterbalance weight attachment was > not designed nor intended to have increased torsional loads. > > All Kolbs inherently load up the ailerons at speeds over 50 to 60 mph. > You ain't gonna change that unless you cut the cord of the aileron in > half. > > john h > mkIII You are correct that it would put more stress on the bow tip, that could be a problem. The other answer would be to put a spade in the middle of the aileron underneath the wing, which is probably a better solution and gets rid of any unknowns like tip vorticies. Thanks for that advice, it will be a lot of extra work, but if I do this I will put standard spades in the middle of the ailerons. I was wondering why my Kolb was heavy on the ailerons while Richard reports his to be light. I am cruising pretty fast with the 912-S, that is probably why they are stiffening up quite a bit. Mike Bigelow -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124648#124648 ________________________________________________________________________________
Date: Jul 18, 2007
WillUribe(at)aol.com wrote: > here is the old U-Joint. > > > > > Get a sneak peek of the all-new AOL.com (http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982). Wonderful.. this is what's on my FS II's linkage... Mine's a pre-TNK FS II finished in 98..... So, is this a joint that has hazards and needs replacement or ? LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124682#124682 ________________________________________________________________________________
Date: Jul 18, 2007
jstewart(at)inebraska.com wrote: > Maybe take Kimberly's advice and reflex the ailerons a bit. That might help > a lot with the control forces. > > J.D. > > Hey JD, I thought about it when I read Kimberly's post, but I'm actually used to the feel of it now and the plane flies perfectly the way it is. I think the ailerons ride a hair bit up in the air already anyway... I'm going to look at that next time I'm up. Sorry guys for the brief titan exchange - JD is the seller/builder/co-designer of my titan and builder extraordinaire... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124684#124684 ________________________________________________________________________________
Date: Jul 18, 2007
I think it is just not as precision as what they are currently using. On the other hand, it only needs to work in a Kolb, not in a watch... Richard Pike MKIII N420P (420ldPoops) ----- Original Message ----- From: "lucien" <lstavenhagen(at)hotmail.com> Sent: Wednesday, July 18, 2007 8:26 PM Subject: Kolb-List: Re: Mushy control stick > Wonderful.. this is what's on my FS II's linkage... Mine's a pre-TNK FS II > finished in 98..... > > So, is this a joint that has hazards and needs replacement or ? > > LS > > -------- > LS > FS II > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=124682#124682 > > > ________________________________________________________________________________
Date: Jul 18, 2007
Richard Pike wrote: > I think it is just not as precision as what they are currently using. On the > other hand, it only needs to work in a Kolb, not in a watch... > > Richard Pike > MKIII N420P (420ldPoops) > > --- Ok, just curious if it was an AD that I needed to call Kolb about or something like that... The plane has about 500 hours on it and hasn't seemed to have problems with this joint, so I was just wondering if it was something that just hadn't been updated but needed to be..... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124706#124706 ________________________________________________________________________________
Subject: For Sale
Date: Jul 19, 2007
Just wanted to let you all know I have completed restoration of the Classic Kolb Twinstar. It has no engine so you may install your choice. An HKS would be great I would think. Plenty of time to register it. It has drop down nose cone for ease of entry and two nice seats with lap/shoulder harness. Has canister 2nd Chance Chute and easy installation if you want. It is white and blue. Folds easily. New tires and breaks. Everything is ready for your engine and registration. I have reg. kit available. Dont have to tell you about the Kolbs, you know better than I. If you like open flying, this is the bird for you. New Stits with poly spray and white wings. Have penty of pics. $6000 OBO. Ted Cowan, Alabama 334-480-0822. Call or email for pics. This plane, your engine, cheap great flying. Will consider delivery. ________________________________________________________________________________
Subject: Re: Starhill-Nauga Field Fly Around 2007
Date: Jul 19, 2007
Kolbers and Kolbettes: Finally got settled in back home enough to comment on the Nauga Field Fly Around. As a "drive in" participant, I would have to echo John W's words about what a good time it was. The Bickhams (John and Sandy .....mostly Sandy) did a great job of taking care of those who came. Their friends and family who came were equally as gracious. Sample of pictures attached. (You'll notice that there is no closeup of Bruce C. He claimed to be in a witness protection program or something like that.) -------- George Alexander http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124745#124745 Attachments: http://forums.matronics.com//files/nauga_field_sf_landing_112.jpg http://forums.matronics.com//files/nauga_field_sf_take_off_526.jpg http://forums.matronics.com//files/nauga_field_flyers_150.jpg http://forums.matronics.com//files/bruce_c_204.jpg http://forums.matronics.com//files/david_k_148.jpg http://forums.matronics.com//files/john_w_850.jpg http://forums.matronics.com//files/john_h_525.jpg http://forums.matronics.com//files/john_b_179.jpg http://forums.matronics.com//files/gary_h_849.jpg http://forums.matronics.com//files/nauga_field_134.jpg ________________________________________________________________________________
Subject: flasher for landing lights
July 03, 2007 - July 19, 2007
Kolb-Archive.digest.vol-gu
