Kolb-Archive.digest.vol-he
January 25, 2008 - February 11, 2008
      >>  I have my 447 tuned to get a two gallon to an hour burn
      >> rate and hate to have to change.
      >> Terry -  FireFly #95
Date: Jan 25, 2008
Subject: Re: FAA Grants Extension...
At 10:20 PM 1/24/2008, Robert Laird wrote: > >I'm not suggesting 16-hr repairman courses for E-AB...I'm suggesting that a >kit built E-AB that falls inside the LSA category should be able to be >considered an E-LSA if the builder wants it that way... I wasn't suggesting that, either. I was only saying that any E-AB, even if it falls within the LSA restrictions, may have a less ordinary construction that an approved LSA kit, and less (or no) factory support, so the FAA probably wants a more experienced mechanic than a 16 hour class graduate doing the inspections. Note that the original builder can still get the repairman certificate without _any_ class. That doesn't help subsequent owners, but most builders build for their own use, not resale. -Dana -- If at first you don't succeed, skydiving is not for you. ________________________________________________________________________________
Date: Jan 25, 2008
I don't disagree with "...so the FAA probably wants a more experienced mechanic than a 16 hour class graduate doing the inspections..." Obviously, that's how the FAA feels about it. I'm suggesting that a DAR or FAA inspector who grants, for example, an E-LSA airworthiness certificate to a Kolb MkIII in 2007, should be able to grant an E-LSA airworthiness certificate to a Kolb MkIII in (post-Jan-31) 2008. I don't see any difference or logical or practical reason, except for a mandate on paper. -- Robert On 1/25/08, Dana Hague wrote: > > At 10:20 PM 1/24/2008, Robert Laird wrote: > > > >I'm not suggesting 16-hr repairman courses for E-AB...I'm suggesting that a > >kit built E-AB that falls inside the LSA category should be able to be > >considered an E-LSA if the builder wants it that way... > > I wasn't suggesting that, either. I was only saying that any E-AB, even if > it falls within the LSA restrictions, may have a less ordinary construction > that an approved LSA kit, and less (or no) factory support, so the FAA > probably wants a more experienced mechanic than a 16 hour class graduate > doing the inspections. > > Note that the original builder can still get the repairman certificate > without _any_ class. That doesn't help subsequent owners, but most > builders build for their own use, not resale. > > -Dana > > -- > If at first you don't succeed, skydiving is not for you. > > ________________________________________________________________________________
Subject: Mark III for sale
Date: Jan 25, 2008
I have a Kolb Mark III which has been rebuilt by an A&P who is also a machinist for US Airways, It has been stripped to the metal, powder coated, recovered, and painted. It has a BRS, a custom gas tank with 15+ gal capacity, new panel, etc. It will be almost like new - or better than new in some respects. It has a Rotax 532 (65hp). . It is located in Concord, NC (near Charlotte). I left it there for restoring when I moved to Michigan and I am not going to be able to keep it up here. I've had lots of great flights in it! I added up the cost for a new Kolb Mark III Classic on The New Kolb Company and got a total of $22,000 for the kit including what is on my plane. That is without engine or instruments and without the time and tools needed to build it. $16,900. It is N numbered and makes a great light sport plane! Give me a call if you might be interested. I have pictures available. Jim 1-800-383-1868 Mt. Clemens, Mi ________________________________________________________________________________
Date: Jan 25, 2008
Subject: Re: Regular Unleaded
beauford T wrote: > > Terry: > You are getting about 50% better fuel burn out of your 447 than > I have managed.... Mine burns slightly over three gal/hr with the stock > jets and needle... What jetting are you running and what RPM do you > cruise yours at...? > > Envious beauford > FF076 > Brandon, FL > > ------------------------- > I have my 447 tuned to get a two gallon to an hour burn > rate and hate to have to change. > > > Terry - FireFly #95 > beauford T, I use the 11G2 needle in the second notch from the bottom, standard jets. I typically cruise at 5,000 to 5,200 rpm. Beautiful Amish country side to see around here and I'm in no rush taking in the scenery. I swing a Tennessee two blade wood prop which was stock for the FireFly from the Old Kolb Co. Hope this helps, Terry - FireFly #95 ________________________________________________________________________________
Date: Jan 25, 2008
WhiskeyVictor36(at)aol.com wrote: > In a message dated 1/24/2008 6:35:50 P.M. Eastern Standard Time, > tkrolfe(at)toast.net writes: > > Got 775 hr.s on my FireFly > > > Hi Terry, > > Wow! I know you fly a lot, but that is a lot of hours. When did > you start flying that FireFly? I also use regular grade fuel per > the Rotax 447 operators manual. Also, in NJ, all automobile pump > gas is mandated to contain up to 10% ethanol. So far I haven't > had any problems using it and it does contain ethanol. > Bill, Started flying Aug. 99 . Been trying to make up for lost years!!! I'm a piker compared to my flying buddy, Willie. He has put almost 1,000 on his FireStar in 3 1/2 years! You met him at Homer's. He is the one with the orange wings and tail and is known as the "Candy Man". Terry - Firefly #95 ________________________________________________________________________________
Date: Jan 25, 2008
Subject: The Inspection, or; Please, just shoot me
The inspector just left. He has my airworthiness certificates and will send them to me when I finish up with the short list of problems. He's a nice guy, charged me $40 extra for driving 3 1/2 hours to do the inspections so I wouldn't have to haul the Firestar and the Mk. 3 on an open trailer. The whole bill for both airplanes was $500. I know many DAR's charge that much for one airplane. The last thing I had to do on the Mk.3 was put new batteries in the ELT. The ones that were in it were good to 2010, but I wanted to be extra careful in case he wanted me to activate it. The ELT had been switched off since I started working on the Mk. 3. When I opened it up there was corrosion and liquid goo sliming up the entire battery compartment. Luckily, I had a brand new Ameri-King sitting on the shelf. I bought it for the trike before I read FAR 91.207 carefully and found that it say airplane, not aircraft. He let me go on that one. The passenger warning sticker I had said ...blah, blah, blah..amateur built...blah....instead of light sport aircraft. I actually found that one and pointed it out....Ding! I fixed the missing red line on the new tach. Ding, but fixed. For all the help you all offered with drawings, he still wants a picture of the tail with the N number. Ding. For the Firestar, I called him yesterday to ask if it would be okay to fold it up because the weather was supposed to be an ice storm in the morning. No problem. Folded it up and put it in the carport. No ice storm, but major winds that is still beating the crap out of the wings and tail, and it was impossible to fold it out to read the N number and DEA tag. God only knows how much damage there will be to the fabric, I found two spots where the rubatex padding had blown away and the fabric now has a hole. I have all the polyfiber stuff and a few yards of fabric, just more work. If I had left it in the wind shadow of the house, everything would have been fine. D***. Thank God for the bottle of 18 year old single malt in the pantry. I've had it for two years and it's about 2/3 full. It may be empty in an hour or so. :-) Thanks, to all who sent drawings and suggestions. I didn't want to cut up my plans to use the drawing and it wouldn't fit in my scanner. Okay, I fell much better now, and that bottle of Scotch is calling my name. Thanks again, guys. Rick ________________________________________________________________________________
Date: Jan 25, 2008
rlaird wrote: > I don't disagree with "...so the FAA probably wants a more experienced > mechanic than a 16 hour class graduate doing the inspections..." > Obviously, that's how the FAA feels about it. > > I'm suggesting that a DAR or FAA inspector who grants, for example, an > E-LSA airworthiness certificate to a Kolb MkIII in 2007, should be > able to grant an E-LSA airworthiness certificate to a Kolb MkIII in > (post-Jan-31) 2008. I don't see any difference or logical or > practical reason, except for a mandate on paper. > > -- Robert > Personally, I don't see why FnAA went to the trouble of ELSA at all. I suspect the time-bombed one was simply a pretense to make it all look applicable to UL's and 2-place UL-like "aircraft" as stated in the preamble to the NPRM. But now that we know it's not, I don't see any use whatsoever for the "approved kit" ELSA category - the cost and trouble to the manufacturer is the same if not more and really, SLSA was the real meat of LSA anyway. And you can "downgrade" the certification to ELSA from SLSA as well - that's the only use for the category now that I can see... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160495#160495 ________________________________________________________________________________
Date: Jan 25, 2008
Since the subject has come up, maybe y'all can help an old boater with a question. A few months ago the injectors on my 50 hp 2 stroke outboard fouled and speed was reduced. In the local NAPA store, I saw - among other remedies - a stock of SeaFoam. (sorry, gotta do this) Thinking about the foofahrah on the List about that stuff, but remembering the good things said, I grinned, bought a can and added it to the 19 gal boat tank. Gas was fresh. After about hour, instead of speeding up, all of a sudden the engine bogged right down and quit. Hadta come back in on the kicker motor. I *assume* the seafoam broke some gunk loose that worsened the restricted injectors. My question - will that stuff act as a stabilizer, or should I pour the gas into my VW and put fresh gas with Sta-Bil in the boat tank ?? Will it continue to dissolve the deposits in the injectors ?? Will it hurt the 8 hp 4 stroke kicker motor ?? Haven't had time to get the boat to a shop, so it's gonna sit there for the winter. Lar. P.S. Kolb related in that the answers may help a 2 stroke Kolb-er. Larry Cottrell wrote: > > > >> >> As far as old gas! I usually don't have gas around too long, try to >> fly as much as possible. Have used gas that was 2 to 3 months old >> without any noticeable problem or change of readings. Can't afford >> to through out liquid gold with very expensive mixing oil in it. !!!! > > > You should give some consideration to adding 2 oz of "Sta Bil" per 5 > gallons of gas. It does work and has not harmed anything that I have > ever used it in. I use it in lawn mowers, tractors, rototillers and > Rotax. The difference in the smell of gas with Sta bil and without is > very noticeable. I used to use my "old" gas from the plane in my lawn > mowers or the car. The last time I used some untreated gas that had > been setting in the plane for a too long time in the tractor, I had to > add twice as much fresh gas just to get it to pull its self along. Sta > bil does work and do what it says. > > Larry C > > -- Larry Bourne Santa Fe, NM Building Kolb Mk III "Vamoose" www.gogittum.com www.gogittum.com/blog ________________________________________________________________________________
Date: Jan 25, 2008
At 05:21 PM 1/25/2008, lucien wrote: >Personally, I don't see why FnAA went to the trouble of ELSA at all. I >suspect the time-bombed one was simply a pretense to make it all look >applicable to UL's and 2-place UL-like "aircraft" as stated in the >preamble to the NPRM. Pretty much... though there may well have been a few types in the FAA (who really should get out more) who really believed that we'd all trade our ultralights for LSA's if they'd just shave a few hours off the Private requirements. >But now that we know it's not, I don't see any use whatsoever for the >"approved kit" ELSA category... A few manufacturers will find it useful. Aircraft like Quicksilver (they have an "approved" kit yet?) that can be easily bolted together in a couple of days fit that category (saves shipping costs of an assembled plane from the factory), but that's about it. Hopefully the FAA will realize that they've killed the ultralight training system. When they see how few BFI's go and become CFI's, they'll have to do something. What the industry needs is a new "training exemption" (or write it into the regs): Let pilots with at least a Sport Pilot certificate (so they can already legally carry passengers), flying any LSA aircraft, who get some additional training (like the BFI program), provide primary instruction (for a fee, which ordinarily a SP couldn't do). Not that informal instruction doesn't happen now anyway, but this would legitimize it for the small operators. -Dana -- Mary had a little lamb. The doctor was very surprised. ________________________________________________________________________________
Date: Jan 25, 2008
So Lar, not to change the subject, but what are you going to do with your mark III out at KSAF? Dunno if you ever get out to the airport but I try to keep an eye on it, as I'm out at the airport all the time... I usually stroll by to make sure nothing's hit it or anything's walked off.... Sure would be great to have another flying light a/c out there, only a couple of us at this point. And that plane would be a sight. The controllers just loved the FS II when I had it.... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160510#160510 ________________________________________________________________________________
Date: Jan 25, 2008
It appears that it might start warming up a bit soon, and I'll be out there to start cleaning it up and preparing for a new engine. Anyone want to buy 5 acres with a tremendous view in Yucca Valley, CA ?? Price is dropping for a quick sale. :-) When that sells, the new engine will soon come along. I still need answers to the questions in my original post. Lar. lucien wrote: > > So Lar, not to change the subject, but what are you going to do with your mark III out at KSAF? > > Dunno if you ever get out to the airport but I try to keep an eye on it, as I'm out at the airport all the time... I usually stroll by to make sure nothing's hit it or anything's walked off.... > > Sure would be great to have another flying light a/c out there, only a couple of us at this point. And that plane would be a sight. The controllers just loved the FS II when I had it.... > > LS > > -------- > LS > FS II > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160510#160510 > > > -- Larry Bourne Santa Fe, NM Building Kolb Mk III "Vamoose" www.gogittum.com www.gogittum.com/blog ________________________________________________________________________________
Date: Jan 25, 2008
Dana Hague wrote: > > At 05:32 PM 1/24/2008, Robert Laird wrote: > >> .... it seems to me that if the EAA really wanted to do something >> useful to it's newly minted LSA crowd, they'd petition the FAA so >> that, once a kit plane was finished and gotten it's airworthiness and >> registration, that they then give the builder the option to make it an >> E-AB or an E-LSA (assuming it's within the LSA performance envelope). >> ...If you say you need an A&P to inspect one kind, then >> why is a 16-hour class okay for the other? > > It's hard to guess why the FAA does many things, but in this case I'd > guess that they figured LSA's are slow, simple aircraft, unlikely to do > much damage if they hit anything, with the basic structure originally, > at least, made to some standard... and thus simple to inspect. > > An E-AB, OTOH, can be ANYTHING... bigger, heavier, faster, the potential > to do more damage, an possibly untested structure, so they hold it to a > higher standard. Note that the builder, at least, can get a repairman > certificate (which, if I'm not mistaken, includes the inspection > authority) for that particular aircraft without even taking the 16 hour > class. > > -Dana > -- > "A designer knows he has achieved perfection not when there is nothing > left to add, but when there is nothing left to take away." -Antoine de > Saint-Exup,ry Actually, the 'repairman's certificate' is *only* for inspection (condition inspection) authority. With E-AB, anyone can do maintenance, repairs, and modifications. As far as the A&P requirement for E-AB, that's a logical (hard to believe, I know) response to the recognition that the original builder/repairman certificate holder may not always be around or available. Note that an IA ticket is not required like factory planes; just an A&P ticket. Remember, E-AB rules are decades old; created long before the LSA concept was even a gleam in some EAAer's eye. Charlie ________________________________________________________________________________
Date: Jan 26, 2008
Folks we had that discussion a couple of years ago. What I've done back then is take a bunch of nitrile o-rings and some other rubber parts including silicon and stuck them in a jar of E-85. There has not been any observed degradation in two years. What does it mean, I am not sure but some alcohol does not seem to destroy the regular rubber stuff that we buy in automotive stores. I guess we can start buying viton O-rings during replacements and that would solve the alcohol concerns. Ron (Arizona) ====================== ---- Dana Hague wrote: ============ At 06:57 PM 1/24/2008, Ben Ransom wrote: >Do you have specific concerns wrt ethanol in a 2-stroke? >I've been using 91 octane mogas, sometimes with ethanol. I've not been >aware of any problems other than if gas gets older than a couple months >the engine is hard to start and I don't trust it. I've assumed gas goes >stale mostly because of other ingredients, not ethanol. There are concerns about ethanol's compatibility with rubber parts such as seals, fuel pumps, and carburetor parts. Gas goes stale because some of the more volatile components evaporate out. That's one reason I use avgas in my Cuyuna (that and concerns about alcohol); avgas is much better controlled as to vapor pressure so it stores much better... I believe it's supposed to remain good for 2 years. -Dana -- The gene pool has no lifeguard. -- kugelair.com ________________________________________________________________________________
Subject: Re: speeds
Date: Jan 26, 2008
the Earth sucks.>> Hi Bob, I did hear that helicopters don`t really fly. They are just so damned ugly that the Earth repels them. Cheers Pat ________________________________________________________________________________
Subject: Re: For all 912 users
Date: Jan 26, 2008
[Laughing] -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160546#160546 ________________________________________________________________________________
Date: Jan 27, 2008
In Newzealand I think we use the RON system. I have always either used 91 lead free or avgas or a mixture of both . 500 plus hrs on 503s no problems. Only difference is that the 503 seems to run cooler on avgas and idle a little smoother .No performance difference. Tony MK111 classic ----- Original Message ----- From: "jim" <jim@tru-cast.com> Sent: Friday, January 25, 2008 7:15 AM Subject: Kolb-List: Regular Unleaded > > I was tired of the spills and hassel every time I fueled my Firefly. > After I bought a 100 gal gasboy tanker for fueling my cross-country bird > with regular unleaded, I decided to give regular unleaded a try in the > Firefly to see if I could standardize on one fuel in my hangar. > > Everybody I know uses Premium unleaded (91 octane) auto fuel in the Rotax > 503 engines. The owner of a Rotax Repair Station said he used premium > unleaded fuel, but that regular unleaded (87 octane) meets the Rotax fuel > grade specification. > > The Rotax manual says to use minimum 90 RON fuel. But the RON method of > octane measurement is not used in the United States. In the US, a > different method entirely is used, called the CLC method. The number that > results from this method is the average of the RON octane number and the > MON octane number, so (RON + MON)/2 = CLC octane number. This is the > number that you will find printed on a yellow label on gas pumps in the > United States which indicate (R+M)/2. > > 91 RON octane is equivalent to 87 CLC octane, so the 87 CLC octane of > regular unleaded exceeds the 90 RON specified by Rotax. > > Late last fall and during a couple short flights this winter I used > Regular unleaded with no problems. Does anybody else out there use > regular unleaded? Ever had any problems? > > -------- > Jim > N. Idaho > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160256#160256 > > > ________________________________________________________________________________
Subject: Inadvertent spins
From: "John H Murphy" <mailjohnmurphy(at)gmail.com>
Date: Jan 27, 2008
I've been reading several recent articles about spins. The latest was a piece in the AOPA Pilot written by Barry Schiff (December 07). Has any Kolb owners got themselves into a situation that resulted in a inadvertent spin? Any words of advise on what / how to avoid them? It looks like a spin in a landing situation is non recoverable, ie. fatal? I guess the last question, do any of you practice spins in your Kolb? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160656#160656 ________________________________________________________________________________
Subject: Re: Inadvertent spins
Date: Jan 27, 2008
John: I have practiced spins in my KXP both to the left and right. Recovery is within 1/4 turn with relaxation of back pressure and release of crossed controls. I had to force the plane to get it to spin. I experimented by doing approach stalls while holding increasing amounts of cross control. I was able to get the Firestar to drop a wing this way, but it really didn't want to spin. I had to sharpen the stall break and put in maximum control to get it to go around. When it does spin, it rotates quickly! I should add, that the manual that came with my kit advised against spins. Waiting for the rain and fog to lift......... -------- Roger in Oregon 1992 KXP 503 - N1782C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160667#160667 ________________________________________________________________________________
Date: Jan 27, 2008
I have used both regular and supreme (premium) in my 503. The regular seems to give me a little lower EGT's (about 40-50deg). I use regular when I know the fuel will not be sitting in the tank for an extended period. I use the premium when my schedule is hectic or the weather is iffy and I don't know when I will get to fly next. I fill up after every flight to keep the tank full to prevent condensation. I also use Sta-Bil as Larry C. mentioned. It does a great job; even the left over premix in my empty cans smells fresh after several months. -------- Roger in Oregon 1992 KXP 503 - N1782C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160668#160668 ________________________________________________________________________________
Subject: re: inadvertent spins
Date: Jan 27, 2008
>>>>>>>>>>>>> Has any Kolb owners got themselves into a situation that resulted in a inadvertent spin? Any words of advise on what / how to avoid them? It looks like a spin in a landing situation is non recoverable, i.e. fatal? I guess the last question, do any of you practice spins in your Kolb? >>>>>>>>>>>>>>> I did a few spins during the test phase just to see how it would respond... each time the mark III recovered very nicely, I did not have to go to opposite controls... just relax the controls and it came right out.. at first I recovered at the first sign of the spin.. and progressed to a fully developed spin. All without problems... that day was the first and last day I have ever done spin practice in the kolb..... in order to get into the spin I had to really try to get into one by forcing a lot of rudder at the stall... it would be hard to get into a spin without ignoring the warning signs. I have stalled the kolb many times and if you keep the nose pointing straight with use of the rudder and relax the back pressure when you feel the stall buffeting, you are not likely to spin. Depending on the power setting you will even get some different sounds from the prop as you approach stall. Just keep your speed up and you should not stall to a spin... I hear of pilots that fly base to final at just above stall.... to me that is asking for trouble, low level wind sheers, momentary loss of attention, etc, will cause problems.... these planes will lose their airspeed so quickly in a flair, that I fly fast all the way to the flair. Now if you have to come into a very short field... you would slow down a bit sooner, but anything 1000 ft or more, keep your speed up. The time when you are going to mess up is when you are coming into a field that you have used 1000 times before, you put yourself in kind of an autopilot mode and don't pay as much attention to details as you should... when you are out of your element you will be paying more attention and have a better chance of survival. Now because my plane exited from a spin without issue!!!!! Please don't try it without proper training, safety chute, etc,, your mileage may vary. Stall spins have and will kill pilots flying all makes and models of planes. Boyd ________________________________________________________________________________
Subject: HKS on a Slingshot
Date: Jan 27, 2008
Hello to all, I thought this might be of interest to a lot of Kolb List folks. Friday I was in Florida to see an HKS 700 installation on a Slingshot at Greensky Adventures. Jerry Olenik, the owner of Greensky, took the time to give me a tour and he took the plane up for a loop around the pattern while I watched from his Rotax 377-powered golf cart off the runway. I thought it was pretty impressive. The engine looks and sounds great on that Slingshot, and the winds were up there in the 20 mph range as a cold front had blown thru that morning. Click here to see a few pics. Enjoy! www.flickr.com/photos/jdy12755 Jimmy Young FS II Houston ________________________________________________________________________________
Subject: Re: HKS on a Slingshot
Date: Jan 27, 2008
Hi jimmy great photos looks like a nice installation. The HKS is a great engine I have over 200 hrs flying behind one. -------- GB MNFlyer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160771#160771 ________________________________________________________________________________
Subject: Re: Firestar project
Date: Jan 28, 2008
I would not worry a bit about 15 pounds extra on an ultralight. Sure, there well be many that say " Its not legal " , or " The law is the law ".... etc. etc. But you will see those same people going slightly over the speed limit and not thinking twice about it. 15 pounds is inconsequential given a 254 pound limit. I say only an anal idiot would worry about 15 pounds, lets put this into perspective. Its only 6 % over the limit. If you were driving 58 MPH in a 55 MPH Zone, which is 6 % over the limit, and someone complained that you were speeding, what would you say ??? If you given a ticket for doing 58 MPH in a 55 zone, I guarantee that you would be telling everyone you knew what BS it was to get a ticket for just 3 MPH over... Just about as stupid as worrying about 15 pounds, or 6 % extra on an ultralight no ? As far as safety, you are far more likely to hurt someone else by doing 58 MPH in a 55 Zone in your car than you ever would be to hurt anyone or anything by having 15 extra pounds on an ultralight. So its nothing short of hypocritical for people say " The law is the law ", unless they never break the speed limit by more than 3 MPH, there is far more danger in that. People tend to get super anal when it comes to aviation, and yes they are idiots. In reality if you are the type that is super paranoid, super legal, and worried about causing an accident, NEVER go more than 3 MPH over the limit, because this is something that is far more likely to hurt yourself and others than having 15 extra pounds on your Firestar. Anyone on this list that never drives 3 MPH over the limit ? I didn't think so... Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160801#160801 ________________________________________________________________________________
Date: Jan 28, 2008
In a message dated 1/28/2008 3:34:46 A.M. Eastern Standard Time, orcabonita(at)hotmail.com writes: I say only an anal idiot would worry about 15 pounds I think you are missing the point here Mike, To me, it is not a matter of right or wrong, but rather a challenge. I enjoy the challenge of putting somethng together that performs well and meets the guidelines of a category. Sometimes the FAA gives you limits and sometimes nature or physics does. Now if the category is poorly defined or has loopholes then I have no problem exploiting them. Now is almost 254# like almost not pregnant? The tires almost needed to be replaced / I almost replaced them I hope to have Firefly on Floats #2 less than 338# done for SnF 08, Hope to see you there, Anal and not so bright in Florida, :-) Steve B Firefly 007/Floats do not archive **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Subject: Cable thimbles
Date: Jan 28, 2008
Hi All, I'm making a new set of rudder cables. To those of you that made cables did you leave the ears on the thimbles, or did you cut or grind them off? Thanks, Ed ________________________________________________________________________________
Date: Jan 28, 2008
Subject: Re: Cable thimbles
Cut them off, dress them smooth with a small round file where the cable passes over the cut. Richard Pike MKIII N420P (420ldPoops) Edward Bonsell wrote: > > > Hi All, > > I'm making a new set of rudder cables. To those of you that made > cables did you leave the ears on the thimbles, or did you cut or grind > them off? > > Thanks, > > Ed > > ________________________________________________________________________________
Date: Jan 28, 2008
Ed, I use my Felco F-9 cable cutters to trim the ears. I cut from the inside of the thimble out and there is no burr left to dress where the cable touches. If you haven't made cables before, go to AC 43.13-1B "Aircraft Inspection, Repair and Alteration Acceptable Methods, Techniques, and Practices" pages 7-32 and 7-33 for instruction on how to use Nicopress ovals. Use the proper tool and inspect each swage with the proper gauge. Rick Girard On Jan 28, 2008 7:51 AM, Richard Pike wrote: > > Cut them off, dress them smooth with a small round file where the cable > passes over the cut. > > Richard Pike > MKIII N420P (420ldPoops) > > Edward Bonsell wrote: > > > > > > Hi All, > > > > I'm making a new set of rudder cables. To those of you that made > > cables did you leave the ears on the thimbles, or did you cut or grind > > them off? > > > > Thanks, > > > > Ed > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 28, 2008
I flew my overweight, overspeed, over fuel capacity KXP as an ultralight since 1999. I stayed to the spirit of the law; no brakes, no electric start, empty weight of 292# with a 503. I stayed out of trouble, gave way to GA aircraft in the pattern etc. If not for the sport pilot rule change shining the spotlight on all of us, I probably would still be flying that way. Over time, I made many small changes. I added side doors, a little carpeting, extended range tanks, radio and GPS mounts and battery, new wheels, tires, and brakes. Gradually, I moved further and further away from being an ultralight. When sport pilot came out, I decided to take the opportunity to legitimize my unregistered aircraft and quit looking over my shoulder. It is a personal decision that you must make for yourself. If you are only going to fly around the local patch and nearby non-controlled fields, you will PROBABLY never get checked. If you ever want to take your plane to a fly-in or have a cross-country adventure, your odds of getting caught go up. Just don't kid yourself that you are an ultralight. If you are overweight, or have a top speed over the limit, or a stall speed above the limit, you are flying an unregistered aircraft. It is kind of like driving around without a drivers license. Unless you get pulled over, or have an accident, everyone just assumes you are legal, but it gets tiring keeping one eye glued to the rear-view mirror. -------- Roger in Oregon 1992 KXP 503 - N1782C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160868#160868 ________________________________________________________________________________
Date: Jan 28, 2008
15 pounds is inconsequential given a 254 pound limit. I say only an anal idiot would worry about 15 pounds>> I am all for pushing the limits a bit but if the law says `that is the limit` then that is it. I am sure it must be something similar in the US but here in the |UK the whole point of a weight limit is not that it is dangerous to exceed the limit ot that it will make your flying less safe it is the simple fact that above a certain weight the plane is no longer classed as an ultralight and must then conform to the same rules as GA.. That automatically means that you are no longer entitled to the breaks in the maintenance schedules which are enjoyed by the ultralight category. You will have to pay a `certified` mechanic to carry out anything but the smallest job on the plane The flying medical which for an ulralight pilot here is signed off by your local doctor for about 20 will revert to a full light aircraft category medical by an `approved` doctor and will be around 180/200. . Most important of all is the fact that your insurance will be invalid. Of course if you are the type who habitually drives a car without insurance then there is no point in talking and you should be locked up for the general good of society. The comparison to breaking the speed limit is puerile. Your car license and insurance will not become invalid if you go over 30 mph. The rules and regs governing ultralights have been hard fought for here in the UK and probably in the USA too. Because ultralight pilots generally have stuck to the rules and been professional in their conduct they are now welcomed by nearly all airfields, big and small. That was not the case a few years ago when we were looked on as hairy arsed. bikers of the sky. If the weight limit is too low, and as our planes have become more sophisticated, acquired bigger engines, electronics etc., that may well be so then get the legislation changed, as we have here, not just pretend it doesn`t exist. The FAA isnt going to go away but they could ground everyone with a stroke of the pen. Life is not a box of chocolates. It is more like a jar of jalapenos. Something you eat today may come back and roast your bum tomorrow. Cheers Pat ________________________________________________________________________________
Date: Jan 28, 2008
pj.ladd(at)btinternet.com wrote: > > > I am all for pushing the limits a bit but if the law says `that is the > limit` then that is it. > > Pat Well, if the law says 55, then thats it. Better not drive at 58 MPH, and if due to advances in cars, the 55 limit needs to be changed, then legislation should be introduced, don't pretend it does not exist. Sound familiar ??? You are much more likely to do harm to property and life by speeding than by being 15 pounds overweight in with your ultralight. As for image, no one will ever know if your ultralight is 15 pounds overweight or not, its far easier for others to see you speeding. When you get the emotion of aviation out of the picture and apply the same standard to every day life, its just plain stupid and hypocritical to worry about 15 pounds overweight in an ultralight and then drive 3 MPH over the speed limit or more on a regular basis and think its OK. You seem to have some issues with being consistent, and even more importantly, you are unable to recognize which is more important and more likely to result in damage to property and others, which is the basis for ALL these rules we live by. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160887#160887 ________________________________________________________________________________
Date: Jan 28, 2008
At 07:27 AM 1/28/2008, you wrote: > > >In a message dated 1/28/2008 3:34:46 A.M. Eastern Standard Time, >orcabonita(at)hotmail.com writes: >I say only an anal idiot would worry about 15 pounds The thing is that after Jan 31, your fat ultralight will stand out a lot more that it use to "without N-numbers". Use to be hardly anyone had them, even the two seaters. Now - you will be a lot more conspicuous out there on the tarmac. ________________________________________________________________________________
Date: Jan 28, 2008
Consistent? It appears to me that your talking points are mixing apples with oranges with bananas. I seriously doubt that any of us care whether any of the rest of us are actually Part 103 legal or not, the issue is what happens if you get ramp checked by FSDO and you are not Part 103 legal. The FSDO guy is not going to be interested in your likelihood of doing greater damage to life and property because you are 15 pounds overweight, his job is to enforce the law as written, so IMO, your comparison to driving 15 over the speed limit is irrelevant to the issue. As far as being hypocritical to drive slightly over the speed limit as opposed to being slightly overweight, I could care less if you drive the speed limit or not. Because in the real world that I live in, the rules are written not so much to keep us safe, but to quiet the squeaking wheels. In Sullivan county where I live, the county commissioners determine the speed limits, and any yahoo who lives on a county road and gets a burr under his seat because somebody drives down "his road" faster than he likes, can write his commissioner a letter and get the speed limit lowered to 25 mph. Consequently I live in a county with lots of 45 mph capable roads posted at 25. Do I think the people who drive 40 are hypocrites? No, only the idiot who wrote the letter to his commissioner who drives 40. Do I think the speed limit rules are written to keep us safe? Maybe in your world, around here they are written to pacify Uncle Fester. (And no, I'm not ranting because I got busted ) Do I think folks ought to push the limits on Part 103 regs? Only if they are willing to have a deep wallet if The Man catches them out. In which case, fly it however fat, fast, or far you want, I could care less if your "ultralight" is part 103 legal or not. Which is the impression I got of what the other listers were saying: As long as you're willing to pay the piper, you can dance any way you like. If not, then get legal. And that's not hypocrisy, that's reality. Richard Pike MKIII N420P (420ldPoops) JetPilot wrote: > > > pj.ladd(at)btinternet.com wrote: > >> I am all for pushing the limits a bit but if the law says `that is the >> limit` then that is it. >> >> Pat >> > > > Well, if the law says 55, then thats it. Better not drive at 58 MPH, and if due to advances in cars, the 55 limit needs to be changed, then legislation should be introduced, don't pretend it does not exist. Sound familiar ??? > > You are much more likely to do harm to property and life by speeding than by being 15 pounds overweight in with your ultralight. As for image, no one will ever know if your ultralight is 15 pounds overweight or not, its far easier for others to see you speeding. > > When you get the emotion of aviation out of the picture and apply the same standard to every day life, its just plain stupid and hypocritical to worry about 15 pounds overweight in an ultralight and then drive 3 MPH over the speed limit or more on a regular basis and think its OK. > > You seem to have some issues with being consistent, and even more importantly, you are unable to recognize which is more important and more likely to result in damage to property and others, which is the basis for ALL these rules we live by. > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160887#160887 > > > ________________________________________________________________________________
Date: Jan 28, 2008
"Possums" at 07:27 AM 1/28/2008, you wrote: > > The thing is that after Jan 31, your fat ultralight will stand out a lot more that it use to "without N-numbers". Use to be hardly anyone had them, even the two seaters. Now - you will be a lot more conspicuous out there on the tarmac. They will stand out and it will be difficult to make friends with pilots who have gone though the process as they know who is illegal and may not say anything to cause trouble. When the ultralight pilot that flies that 400 lb machine starts bragging about his pilot skills and how he avoided going through all that "hoop-jumping" is when it will get "testy". -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160896#160896 ________________________________________________________________________________
Date: Jan 28, 2008
>They will stand out and it will be difficult to make friends with pilots who have gone though the process as they know who is illegal and may not say anything to cause trouble. Where is all of this "Follow the rules exactly" attitude coming from all of a sudden? It seems to me that the vast majority of folks flying on the 2 seat exemption were not following the rules for many years. Everyone knew it, nobody cared. How many of the 2 place pilots were using them only for training flights? When I wanted to find an instructor, I called more than a dozen pilots on the exemption list before finding someone actually using their plane to train. Now that the 2 place guys are legal, it seems that many have adapted a different outlook. A 275lb Firestar is no more or less legal after January 31st than it was before. I find it interesting that pilots who decide not to transition are being "cast out" by the same community that have been flying under the radar for years. I truly feel that if the FAA does crack down on fat single place UL's, it will be because of the complaints of pilots that did make the transition, not because the FAA really wants more enforcement. Sad. P.S. I'm sure someone is going to point out that there is no longer such a thing as a fat UL. My answer is...... from a legal stand point, there never was. Bryan D ________________________________________________________________________________
Subject: Big Island Volcano Flights
Date: Jan 28, 2008
Here is a link to some photos I took on two recent cross country flights to Kilauea Volcano on the Big Island of Hawaii in my HKS powered Firestar II. The flights were from my grass strip at the 4,000 foot level of Mauna Kea on the west side of the Island over the 6,000 foot saddle between Mauna Kea and Mauna Loa. It takes about an hour each way with 30 minutes time at the volcano. The whole flight takes 2:30 minutes with 3.5 gallons of gas remaining out of 10 gallons at takeoff. The HKS engine has been running flawlessly - good thing too, if you take a good look at the terrain! The radiated heat from the lava lake feels like standing in front of a fireplace, even at 200-500 feet above the lave pools. Also, some good glider shots, if that interests anyone. http://www.flickr.com/photos/16867421@N07/sets/ -------- Dave Bigelow Kamuela, Hawaii FS2, HKS 700E Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160901#160901 ________________________________________________________________________________
Date: Jan 28, 2008
[quote="indyaviator(at)gmail.com"] > They will stand out and it will be difficult to make friends with pilots who have gone though the process as they know who is illegal and may not say anything to cause trouble. > > Where is all of this "Follow the rules exactly" attitude coming from all of a sudden? It seems to me that the vast majority of folks flying on the 2 seat exemption were not following the rules for many years. Everyone knew it, nobody cared. How many of the 2 place pilots were using them only for training flights? When I wanted to find an instructor, I called more than a dozen pilots on the exemption list before finding someone actually using their plane to train. Now that the 2 place guys are legal, it seems that many have adapted a different outlook. A 275lb Firestar is no more or less legal after January 31st than it was before. I find it interesting that pilots who decide not to transition are being "cast out" by the same community that have been flying under the radar for years. I truly feel that if the FAA does crack down on fat single place UL's, it will be because of the complaints of pilots that did make the transition, not because the FAA really wants more enforcement. Sad. P.S. I'm sure someone is going to point out that there is no longer such a thing as a fat UL. My answer is...... from a legal stand point, there never was. Bryan D > [b] If you read the forward to the original SP NPRM, there were repeated references to "fat-UL" and "fat ultralights" - the recognition being that, though illegal, a "fat-UL" had a kind of status and there was a cottage industry in US light aircraft supporting them. This is really kind of how America works - bad or useless laws tend not to bring on the maximum possible punishment for every concievable infraction and we should be very glad that this is so. Instead, they are eventually amended to be either more appropriate or enforceable (or both). Now, it's interesting that the original writers of SP were actually sensitive to this aspect of "fat-UL"; the original effort was a rule set that was appropriate for this class of aircraft to get legal and have at least some minimal standards of construction, etc., to insure at least some minimal standard of safety. The rule that eventually resulted did NOT turn out that way for a variety of reasons, but it could have if it'd stuck to its original intent. SP was promulgated NOT because of abuse of the existing system or because of problems with public safety, but a) because FnAA did not or could not enforce its own rules and b) apparently because of special interest pressure. History is our best teacher on this and hopefully we'll all learn from it the next time something like this comes around... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160907#160907 ________________________________________________________________________________
Date: Jan 28, 2008
I decided to take the opportunity to legitimize my unregistered aircraft and quit looking over my shoulder. > > -------- > Roger in Oregon Roger H: Exactly the way I felt flying my US and FS. Both were too fat, too fast, and way too much fuel. Always had that nagging, uncomfortable feeling that all was not right. What a tremendous feeling of relief and peace when I registered my mkIII, got a private ticket, and started flying legally. No more looking over my shoulder all the time, or for that matter, any time. john h mkIII ________________________________________________________________________________
Subject: Re: M3X update
Date: Jan 28, 2008
> looks great. Can almost hear you making brrrm-brrrrm noises. > BB Scott and Gang: I echo Beanie Weanie's sentiments also. Looks good. Got to get a look at some of their stuff last year at London. BTW: What are those big things on the little wheels? ;-) john h mkIII - Lover of big soft tires and interesting short, soft fields. ________________________________________________________________________________
Date: Jan 28, 2008
Seems like you're suggesting everyone should be okay with individuals deciding what acceptable risk is, such as driving 58 and/or flying 15 lbs over. Or is it 16, or in reality 25? That might be kinda fun, and then maybe 10gallons and an occasional passenger should be fun too. Perhaps the counter to this is that you are simply asking for common sense. Well that's great too, but I think you gotta admit the UL thing got way out of whack. So rules, with clear definitions, are necessary. I have the impression that most of the aviation community is glad to have the whole thing clarified. The only way to keep it clear is to occasionally ramp check and fine someone "pushing the limits", regardless of whatever their "good judgement" may be. Same non-hypocritical reason I'm glad to see a cop pull over some free spirit (aka fill-in-the-blank) on the road. I also agree with the other comments that I'm tired of flying looking over my shoulder, which in one real example meant my high-minded airport manager could have kicked me out. With an N number he's gotta welcome me just like the King Air. Now that I think is pretty fun. -Ben JetPilot wrote: > > Well, if the law says 55, then thats it. Better not drive at 58 MPH, and if due to advances in cars, the 55 limit needs to be changed, then legislation should be introduced, don't pretend it does not exist. Sound familiar ??? > > You are much more likely to do harm to property and life by speeding than by being 15 pounds overweight in with your ultralight. As for image, no one will ever know if your ultralight is 15 pounds overweight or not, its far easier for others to see you speeding. > > When you get the emotion of aviation out of the picture and apply the same standard to every day life, its just plain stupid and hypocritical to worry about 15 pounds overweight in an ultralight and then drive 3 MPH over the speed limit or more on a regular basis and think its OK. > > You seem to have some issues with being consistent, and even more importantly, you are unable to recognize which is more important and more likely to result in damage to property and others, which is the basis for ALL these rules we live by. > > Mike > > ________________________________________________________________________________
Subject: Re: Big Island Volcano Flights
Date: Jan 28, 2008
> Here is a link to some photos I took on two recent cross country flights to Kilauea Volcano on the Big Island of Hawaii in my HKS powered Firestar II. > -------- > Dave Bigelow Hey Dave B: You gonna have'ta tighten up a bit. Every shot through the windshield indicated you were way out of trim. ;-) Great shots. I am envious. Would like to fly my airplane over that area. In fact, would be fun doing the Hawaiian Islands in a mkIII. john h mkIII ________________________________________________________________________________
Subject: Regular Unleaded
Date: Jan 28, 2008
You guys need to start looking very closely at your fuel suppliers a lot are adding 10% ethanol to there fuel. Recently all of the pantry kangaroo stores in Tennessee started adding 10% to there stores. I am not sure if this is every where they are but they have 1600 stores nation wide. Srglink -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Tony Oldman Sent: Sunday, January 27, 2008 1:12 AM Subject: Re: Kolb-List: Regular Unleaded In Newzealand I think we use the RON system. I have always either used 91 lead free or avgas or a mixture of both . 500 plus hrs on 503s no problems. Only difference is that the 503 seems to run cooler on avgas and idle a little smoother .No performance difference. Tony MK111 classic ----- Original Message ----- From: "jim" <jim@tru-cast.com> Sent: Friday, January 25, 2008 7:15 AM Subject: Kolb-List: Regular Unleaded > > I was tired of the spills and hassel every time I fueled my Firefly. > After I bought a 100 gal gasboy tanker for fueling my cross-country bird > with regular unleaded, I decided to give regular unleaded a try in the > Firefly to see if I could standardize on one fuel in my hangar. > > Everybody I know uses Premium unleaded (91 octane) auto fuel in the Rotax > 503 engines. The owner of a Rotax Repair Station said he used premium > unleaded fuel, but that regular unleaded (87 octane) meets the Rotax fuel > grade specification. > > The Rotax manual says to use minimum 90 RON fuel. But the RON method of > octane measurement is not used in the United States. In the US, a > different method entirely is used, called the CLC method. The number that > results from this method is the average of the RON octane number and the > MON octane number, so (RON + MON)/2 = CLC octane number. This is the > number that you will find printed on a yellow label on gas pumps in the > United States which indicate (R+M)/2. > > 91 RON octane is equivalent to 87 CLC octane, so the 87 CLC octane of > regular unleaded exceeds the 90 RON specified by Rotax. > > Late last fall and during a couple short flights this winter I used > Regular unleaded with no problems. Does anybody else out there use > regular unleaded? Ever had any problems? > > -------- > Jim > N. Idaho > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160256#160256 > > > ________________________________________________________________________________
Date: Jan 28, 2008
Ralph B wrote: > > > . When the ultralight pilot that flies that 400 lb machine starts bragging about his pilot skills and how he avoided going through all that "hoop-jumping" is when it will get "testy". > > I never talked about 400 pounds or two seats, I very clearly said 15 pounds which is 6 %, which is the entire point of what I have been saying. If you cant read a couple numbers and figure out a very simple point, then you are not the brightest bulb in the bunch... The statement that " 15 pounds overweight is going to Stand Out ". A 15 pound ultralight wont stand out any more than the guy going 58 MPH instead of 55 MPH. Can you tell if an ultralight is 15 pounds overweight just by looking at it ? So how does that qualify as " Standing out " ??? So your statement that a 15 pound overweight ultralight would stand out and make everyone look bad is nothing short of ridiculous. Bottom line here , is that only emotional, not so intelligent people get worked up and anal about aviation, while ignoring the fact that they themselves do the same thing on an everyday basis in their cars, where there are far greater risks of hurting someone. Richard Pike wrote: > > > The FSDO guy is not > going to be interested in your likelihood of doing greater damage to > life and property because you are 15 pounds overweight, his job is to > enforce the law as written, so IMO, your comparison to driving 15 over > the speed limit is irrelevant to the issue. > > The traffic laws are written for 55 MPH on some roads, so do you think the cop is going to care if you were only 6 % over, which is 3 MPH, but according to you, his job is to enforce the law as written according to your logic, and use no good judgment. I guarantee you if you got a ticket for going only 3 MPH over the limit, you would be bitching about it and saying how " stupid " the cop was. No difference for the person that has a problem with 6 % over weight ultralight, worrying about an extra 15 pounds its just plain stupid... So maybe some of you should go tell all your friends that drive cars that they are illegal, irresponsible, and making everyone look bad if they go 3 MPH over the posted limit. After all, the law is the law... See what kind of reception you get. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160957#160957 ________________________________________________________________________________
Date: Jan 28, 2008
Subject: A quick overview of how sport pilot came to be
First. The call for a simple class of aircraft with a simple set of rules was made by Paul Poberezny as early as 1954, just after the EAA was formed and just after the experimental amateur built category was established. It's nothing new. This call was issued again in the late 90's. By now U.S. law said that where jobs could be done by private industry they had to be. But how to cast it as something political will could get behind? Nobody cared about using driver's licenses as a medical, nobody cared about "fat ultralights", although the term was around. Nobody cared about the escalating cost of flight instruction. Let them fly cake, or whatever. Then came 09-11-2001 and someone came up with the idea of letting Congress (the opposite of Progress, as Mark Twain noted 100+ years before) in on the "secret". Hey guys and gals, step away from the money buffet for just a second. There are upward of 30,000 aircraft, UNREGISTERED and UNACCOUNTED for, out there SOMEWHERE! Holy Cripes, somebody has to do something. So into this nexus stepped the ASTM. They formed committee F37 and those who stepped up to join were veterans of the hang gliding and ultralight communities. Self regulation had worked reasonably well for those two, why not here? Many of those who joined up also knew there were a bunch of cheap European aircraft waiting just across the pond. I'm not a conspiracy theorist, but that's the reason, the Cessna 120, 140 and 150 were snubbed with the 600 Kg upper weight limit. If they had been included, LSA would have died right there and a big opportunity to make a little cash would have died with it. These same people had also seen the gaggle of Quicksilver clones come and go in the early eighties. They had seen the USHGA create a rating system and an observer / examiner system in the late 70's and ultralight organizations attempt the same with the same results. One guy got a card, rated all his buddies, who rated all their buddies, ad infinitum. So the plan became, first transition the instructors, then the pilots, then the aircraft. We are three days away form the end of that progression now. With the exception of the recently announced extension of the time to get E-LSA certification, provided you started the process by having your aircraft put on the registry by the original date. According to my DAR the deadline for certification is now 1-31-2010, again provided your aircraft is on the registry by midnight Thursday. Many of you have raised the issue of why not having E-LSA extended indefinitely. It was those Quicksilver clones, pure and simple. No more backyard engineers. Want to sell an E-LSA? Now there is an organized plan. FAR 21.191(i)2. First create an S-LSA. Why? Because the two pieces of documentation you have to actually show someone are a flight manual and a maintenance manual. The rest is by the delegation option, unless your aircraft starts hurting or killing a lot of people. Then someone will come knocking to look over your documentation. Notice there is no 51% rule. Leave off the radio knob and let the new owner put it on. You can even give him the screwdriver. It's an E-LSA. Solves a lot of headaches the growth of builder's assistance companies have caused. Why have the option to make an S-LSA an E-LSA, ala FAR 21.191(i)3? Because there will be orphaned fleets. Originally the FAA just wanted to pull their airworthiness certificates if the manufacturer or distributor bit the dust. Talk about watching your dreams turn into a nightmare. Dear Sir, Your airplane is no longer legal, please stop flying it. So that's the reason for that. Most of this has been covered by Earl Lawrence of the EAA, some has been extemporized by me. But it's mostly accurate and you got it for free. What the heck. Rick Girard ________________________________________________________________________________
Date: Jan 28, 2008
Mike, you really need to relax and take more deep breaths - Irrespective of whether or not I think a cop is stupid for writing a ticket if I am only 3 over, his job is to enforce the law, not be a judge. I don't want a cop who acts as judge, because then he might judge to ignore his buddy doing whatever, while he busts some guy (like me) whose look he doesn't like. He might even decide that being judge is not enough, and decide to become the executioner as well. I don't want cops or FSDO guys to be judges, I want them to uphold the law. Years ago, I read that the best way to get rid of bad laws is to enforce them 100%. An enraged populace will then throw out the bums that made them. Which could improve much of what's wrong with this country at present... I really find it amusing that you assume I would tell my friends that drive cars 3 over that they are illegal and irresponsible. I guess you failed to process what I said about local county commissioners, idiotically posted 25 mph roads and Uncle Fester. Or my indifference to those who break idiotic rules as long as they are willing to pay the piper. And that is not hypocrisy, or mere talk. Check the pictures of my non-Kolb toys. Do you really think I worry about 3 over? I act like any rational 61 year old ought to act, and if the Cops find me to be remiss in my actions, (so far so good...) then that's what traffic court is for. PS: Dude, you really need to lighten up. Or maybe fewer Gummy Worms and red Kool-Aid... Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160970#160970 Attachments: http://forums.matronics.com//files/big_bike_large_782.jpg http://forums.matronics.com//files/p1020698_large_146.jpg http://forums.matronics.com//files/p1020693_large_109.jpg ________________________________________________________________________________
Date: Jan 28, 2008
Jetpilot, please don't jump all over Ralph B when he makes an innocent comment about a HYPOTHETICAL pilot in a 400lb 'ultralight' Every reader must know he was kidding about the 400lbs -- we all know what he meant, and he wasn't expecting anyone to take him literally On Jan 28, 2008, at 8:41 PM, JetPilot wrote: > > > Ralph B wrote: >> >> >> . When the ultralight pilot that flies that 400 lb machine starts >> bragging about his pilot skills and how he avoided going through >> all that "hoop-jumping" is when it will get "testy". >> >> > > > I never talked about 400 pounds or two seats, I very clearly said > 15 pounds which is 6 %, which is the entire point of what I have > been saying. If you cant read a couple numbers and figure out a > very simple point, then you are not the brightest bulb in the bunch... > > The statement that " 15 pounds overweight is going to Stand Out > ". A 15 pound ultralight wont stand out any more than the guy > going 58 MPH instead of 55 MPH. Can you tell if an ultralight is > 15 pounds overweight just by looking at it ? So how does that > qualify as " Standing out " ??? So your statement that a 15 pound > overweight ultralight would stand out and make everyone look bad is > nothing short of ridiculous. > > Bottom line here , is that only emotional, not so intelligent > people get worked up and anal about aviation, while ignoring the > fact that they themselves do the same thing on an everyday basis in > their cars, where there are far greater risks of hurting someone. > > > Richard Pike wrote: >> >> >> The FSDO guy is not >> going to be interested in your likelihood of doing greater damage to >> life and property because you are 15 pounds overweight, his job is to >> enforce the law as written, so IMO, your comparison to driving 15 >> over >> the speed limit is irrelevant to the issue. >> >> > > > The traffic laws are written for 55 MPH on some roads, so do you > think the cop is going to care if you were only 6 % over, which is > 3 MPH, but according to you, his job is to enforce the law as > written according to your logic, and use no good judgment. I > guarantee you if you got a ticket for going only 3 MPH over the > limit, you would be bitching about it and saying how " stupid " the > cop was. > > No difference for the person that has a problem with 6 % over > weight ultralight, worrying about an extra 15 pounds its just plain > stupid... > > So maybe some of you should go tell all your friends that drive > cars that they are illegal, irresponsible, and making everyone look > bad if they go 3 MPH over the posted limit. After all, the law is > the law... See what kind of reception you get. > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast > as you could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160957#160957 > > ________________________________________________________________________________
Date: Jan 28, 2008
Oh shit. Leave it to Beaver. Oops, there I go again. ;-) john h john h mkIII - Lover of big soft tires and interesting short, soft fields. ________________________________________________________________________________
Date: Jan 28, 2008
Gang: My reply was not intended to go back to the Kolb List, but it did. As we would say in Vietnam: "20,000 xin loi" which means I am sorry 20 thousand times. Now.........what were we talking about? john h mkIII Oh shit. Leave it to Beaver. Oops, there I go again. ;-) john h john h mkIII - Lover of big soft tires and interesting short, soft fields. ________________________________________________________________________________
Date: Jan 28, 2008
Subject: login ...
how do you get registered so i can "login" to the Kolb website? .............. tim Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Jan 28, 2008
> You gonna have'ta tighten up a bit. Every shot through the windshield > indicated you were way out of trim. Looks like you caught me standing on rudder to get pointed right for the pictures, John. I've got ground bendable trim tabs on all three controls, and she flies hands off (feet off too) with yaw string centered at cruise power. Should have known there would be "eagle eyes" on the list. [Wink] -------- Dave Bigelow Kamuela, Hawaii FS2, HKS 700E Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161020#161020 ________________________________________________________________________________
Date: Jan 29, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: Firestar project
I guess I stirred the pot a little. Here is what I'm trying to do. After looking very closely at the Firestar, I got the impression that the previous owner was a little slack on his maintenance. Castle nuts with no cotter pins, safety wire missing, a bunch of bent spare landing gear, the ASI static hose had fallen off- he commented the speed reading was 20mph off, and so forth. I would rather make my own mistakes, than wonder about what I haven't found. So, if I have to thoroughly go over it, I may as well get as close to legal as common sense dictates. If there is a conflict between law and common sense, go with the common sense. I am going to be training on a grass field, so the soft turf tires are going to stay. No reason to get hurt over a couple of pounds weight. Same thing for the full enclosure- no distractions. The ten gallon tank is eventually going to be replaced, as I don't like the color of the plastic- looks too old. Do these things get brittle? The gas cap did, and I fixed it with some hot glue. It will be replaced with a five gallon, when convenient. One thing no one mentioned regarding weight- I am about 170 dressed, and my wife is about 50 pounds heavier. I would think the powers that be would be more interested in whether the gross weight is being exceeded instead of a couple of pounds over. Luckily, the Firestar is capable of the difference. Next question- The Mark III pictures (nice) show the tail wheel being about at the center of the rudder. A picture of Ellery's showed about the same. Mine is much closer to the rear of the rudder. Since mine has to be re-worked (a little twisted, and worn cable hole) should I shorten the strut, or does it matter? The tail wheel is all worn on the left side. By the way, when I was in the trucking business, we worried more about "Was it safe", more than "Is it a couple of pounds over". Bill Sullivan (old Firestar) ________________________________________________________________________________
Date: Jan 29, 2008
Subject: Firestar
My wife reads this, so before I get in trouble- she is only 35 pounds heavier than me. I had to say that so I can live to finish the Kolb. Regarding the difference between English regulations and American regulations- we have a slightly different attitude towards government here- check King George III's notes on that. No offence, but we just think like that and it works. Bill Sullivan, hoping to be still here after the wife reads this. ________________________________________________________________________________
Date: Jan 29, 2008
Bill, The FAA set some max and stall speed limits for the ultra light vehicle as well as fuel capacity and empty weight limits. The last two are easily verified on the ground, where as, the speed limits are not. To get around this problem the FAA came up with a set of design conditions, so that if they were met, you can fly above both speed limits and remain legal. They published these design conditions as AC 103-7 Appendix 1, 2, 3 & 4. I have filled out a copy of these documents and carry them with me to fly-ins. If the FAA wants to ramp check my FireFly, they are considered sufficient proof that it is legal. If you would like to review the documents, they can be found at: http://www.thirdshift.com/jack/firefly/fireflylegal.html On the subject of illegal flying I am neutral. I have known pilots who have let their medicals lapse or who have lost there medical and continue to fly. They fly from pastures and non-controlled airports. Most everyone knows who they are, and no one says a thing because everyone knows they are going to get old too. The ultra light vehicle is a way out for these folks. The pilots I worry about are high confidence low hour pilots, who like low and slow. Some of their rank will be lost no matter what they fly or their licence status. Fly safe, Jack B. Hart FF004 Winchester, IN Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 29, 2008
Hi Bill, First of all, not your fault about what this has turned into, you asked a very legitimate question and as much as we might bicker, no one is going to hold you responsaible ! I'm glad you are going to do what is right for you, and keep your plane as strong as you need it. The 10 gallons is a bit much, and a very obvious violation in both the letter and spirit of the law, I would change that. Exceeding something by 6 % is nothing, exceeding by 100 % is another matter :) Of course, Richard Pike will probably want to take the gas out of your new tank, and if it is a pint over 5 gallons, tell you to change it as you are still illegal hahaha. Anyways, do what is safe, but keep your plane strong and durable, trying to shave to much weight off leads to shortcuts that can be dangerous. As far as the tailwheel, call Kolb and ask them what it is supposed to be. I know some people cut the long tailwheel strut shorter on the MK III, but I would never do that. That tailwheel rod is the shock absorber for the tial of the plane, shortening it will subject the tail, and its support structure to much more shock loads on the ground and could eventually make something more important fail. I have an extra tail rod if mine ever bends.... Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161082#161082 ________________________________________________________________________________
Date: Jan 29, 2008
> ... The ten gallon tank is eventually going to be replaced, as I don't like the color of the plastic- looks too old. Do these things get brittle? The gas cap did ... Bill Sullivan (old Firestar) Yes, the gas tanks get brittle. When I cracked the cap on my tank I thought that if the cap is brittle the tank must be too. I tested it by pushing my thumb on the top corner and it went right through. So absolutely replace it. Do you still have the fiberglass tailwheel rod? You probably do especially if your tailwheel is wearing on one side. If you do I would suggest you get an aluminum rod and replace it. You will need to heat the steel to soften the epoxy to remove the old one. I have the original blueprints and manual if you need some info I can photograph some sections and send them to you. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161090#161090 ________________________________________________________________________________
Date: Jan 29, 2008
Richard Pike wrote: > > > I don't want cops or FSDO guys to be judges, I want them to uphold the law. > Richard Pike > MKIII N420P (420ldPoops) Richard, Worrying about 15 pounds over in an ultralight is about as uptight as you can get. As far as cops go, judgment is an essential part of their job, I'm glad most are fair and reasonable. If cops charged people for every non consequential way in which we broke the law, be it 3 MPH over, signaling for 4.8 seconds instead of 5, this world would be a horrible place to live. Thank god most cops don't think like you do. I think anyone reading this thread can now see where you are coming from. So if you believe the smallest inconsequential transgression should be prosecuted, and if you believe that everyone driving 58 in a 55 zone should be cited and prosecuted, then by all means make sure your ultralight is not even one pound over weight, and also while you are at it, do a precise measurement of the capacity of the gas tank, after all, the sides might have bulged, and the new capacity might be one pint over 5 gallons, which would be about 6 % over, and after all, the law says a capacity 5 gallons no more ! Richard, whenever you ride in a car with your friends, make sure you start telling them that they are breaking the law and should slow down if you see them going 3 MPH over the speed limit, you might learn something by their reactions :). Learn some judgment and common sense, its important in life, and even more important in flying .... Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161092#161092 ________________________________________________________________________________
Date: Jan 29, 2008
> As far as the tailwheel, call Kolb and ask them what it is supposed to be. I know some people cut the long tailwheel strut shorter on the MK III, but I would never do that. That tailwheel rod is the shock absorber for the tial of the plane, shortening it will subject the tail, and its support structure to much more shock loads on the ground and could eventually make something more important fail. I have an extra tail rod if mine ever bends.... > > Mike Mike B: I like a short tail wheel strut. Much more positive control on the ground. To top that off, I don't use the 7075 aluminum rod, but .120" 4130 heat treated to RC48. Probably more gentle on the tail section than the standard Kolb buggy whip aluminum rod. Yes, I have torn up the tail section more times than I would like to admit, because it is a major job to remove and repair. I don't believe the short stiff tail wheel strut is responsible for the failures, but the 100+ lbs of weight on the tailwheel caused by shifting my main gear 8" forward. Plus..........a lot of hours in more than ideal "putting green" conditions. We've got the tail section problem corrected and have not had any problems back there in many, many hours. As far as recommending some one break the law and encourage new guys to fly illegally, I do not agree with that. I feel the Kolb List is not the correct place to coach folks on how to successfully fly illegal airplanes. Might be a good idea to take this kind of correspondence back copy. If you all disagree with me, fine, but that is the way I feel about the situation. In nearly 40 years flying professionally and flying Kolbs, I don't recall approval of exceeding limits or busting regs by Army or civilian authorities. Do I always fly around like Miss Goody, Goody Two Shoes? Not hardly, but I ain't gonna encourage anyone else to do it. Have fun, fly safe. Take care, john h My mkIII - Flying legal for the past 16 years, 2,734.0 hrs. Plan on putting a lot more hours on her. My US and FS - 1,520.0 hours flown illegally. Other's legal and illegal Kolbs - Have to dig out the log books for that...................... ________________________________________________________________________________
Date: Jan 29, 2008
you might learn something by their reactions :). Learn some judgment and common sense, its important in life, and even more important in flying .... > > Mike Thanks, Mike B: I am going to take your advice to heart. john h mkIII - The new, mellow guy on the block. ;-) ________________________________________________________________________________
Date: Jan 29, 2008
Even if the ultralight is 15 lbs overweight and you seem happy flying on 5 gallons of fuel, more power to you. As for me, I like the idea of being able to carry the extra 6 gallons so I can be go places. Can't do that in a legal ultralight or one that's already 15 lbs overweight, unless you've got your fuel stops very carefully planned. Therein lies the difference between a legal machine and an illegal one. -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161124#161124 ________________________________________________________________________________
Subject: Re: Winston Churchill's definition of a fanatic
Date: Jan 29, 2008
If you don't like the subject, then don't join in on the discussion. It is very obvious that you are unable to defend your position with any kind of logic or reason, so now you are resorting to posting a pure personal attack in hopes of distracting everyone from what we are discussing, and turning this into nothing but bashing and ugliness. What you are trying to do here is very obvious... And very distasteful. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161125#161125 ________________________________________________________________________________
Date: Jan 29, 2008
Range has nothing to do with the subject we are talking about. If you read my first post on this subject, I said that having an N number would be the best way to do it, but this is NOT a discussion on if William should N Number his plane or not. This is TWICE in a row that you have obviously not read, and been unable to follow the very simple idea of this whole thread. Why would anyone listen to a guy that cant grasp a simple concept, and posts answers that do not apply to the subject at hand ? Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161128#161128 ________________________________________________________________________________
Date: Jan 29, 2008
All, I am impressed that this particular Firestar is so close (15lbs) to the UL limit of 254. I say go for it, put in a five gallon tank and take out everything you can and see if you can get it legal, maybe lighter wheels, brakes? and tires are in order. Other than fuel and weight, all Firestars should be Part 103 legal so give it a good effort and see if you can get it legal. Denny Rowe, 475 pound Mk 3, N616DR ________________________________________________________________________________
Date: Jan 29, 2008
Denny: I think the problem is the FS is way too fast and will not fit the matrix to make it a legal UL even if it only weighs 254 or less, and has 5 gal fuel capacity. The FF barely makes it, and only because of the matrix. Main reason the FF has two lift struts per wing panel, to increase the drag component. john h mkIII I say go for it, put in a five gallon tank and take out everything you can and see if you can get it legal, Denny Rowe, 475 pound Mk 3, N616DR ________________________________________________________________________________
Date: Jan 29, 2008
> Range has nothing to do with the subject we are talking about. If you > read my first post on this subject, I said that having an N number would > be the best way to do it, but this is NOT a discussion on if William > should N Number his plane or not. This is TWICE in a row that you have > obviously not read, and been unable to follow the very simple idea of this > whole thread. Why would anyone listen to a guy that cant grasp a simple > concept, and posts answers that do not apply to the subject at hand ? > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you > could have !!! > > Kolb MK-III Xtra, 912-S > > > Mike, It makes me very nervous that someone of your disposition is flying jets. Range has everything to do with the legal, illegal debate and this Firestar project. Now lets see if you can grasp a simple concept. Denny ________________________________________________________________________________
Date: Jan 29, 2008
John H, If the Firefly with its short wing fits the 103 matrix, I would think a light Firestar with 6 more feet of wing and a 447 or 377 would fit. Surely that much more wing has more drag than an extra 4 foot long wing strut they add to make the Fly compliant? Someone want to do the math for this one? Denny ________________________________________________________________________________
Date: Jan 29, 2008
What about going the other way round and shorten the Firestar's wing to Firefly dimensions? You might have to resort to.........VG's (oh dear lord, to think what his might bring to the discussion :-) ) to get the 24 knot CAS requirement, but you would sure be losing weight. Just a PBI, no real thought or math calc's put into it. Rick On Jan 29, 2008 1:47 PM, Denny Rowe wrote: > > John H, > If the Firefly with its short wing fits the 103 matrix, I would think a > light Firestar with 6 more feet of wing and a 447 or 377 would fit. > Surely > that much more wing has more drag than an extra 4 foot long wing strut > they > add to make the Fly compliant? > Someone want to do the math for this one? > > Denny > > ________________________________________________________________________________
Date: Jan 29, 2008
-----Other than fuel and weight, all Firestars should be Part 103 legal so give it a good effort and see if you can get it legal. Denny Rowe, 475 pound Mk 3, N616DR Whoops,I should have wrote all 377 and 447 powerd Firestars in the above, obviously a 503 powered Firestar would not make compliance.Denny ________________________________________________________________________________
Date: Jan 29, 2008
> >John H, >If the Firefly with its short wing fits the 103 matrix, I would think a >light Firestar with 6 more feet of wing and a 447 or 377 would fit. Surely >that much more wing has more drag than an extra 4 foot long wing strut they >add to make the Fly compliant? >Someone want to do the math for this one? > Denny, If Bill is serious about this, he can change to a 28 hp engine and save at least 40 pounds. With an engine change the wing loading will be less than the FireFly, so it will have no problems meeting stall speed requirements. If Bill's Firestar has a 447 mounted and he changes engines, he will be giving up enough hp so that he can fly with reduced drag and not exceed the max speed requirement. To run the numbers, all one has to do it to follow: http://www.thirdshift.com/jack/firefly/fireflylegal.html Taken from that page: 40 hp max, the FireFly total drag factor must exceed 12.4 38 hp max, the FireFly total drag factor must exceed 11.8 28 hp max, the FireFly total drag factor must exceed 8.7 To get Bill's Firestar to comply with upper speed limit one would have to knock off 3.7 drag units from my FireFly. Drag Unit Reduction from FireFly Single strut per wing => 0.8 Go to full enclosure => 2.0 Larger wing drag =>-0.25 Fair landing gear legs => 0.4 ------ Total Reduction 2.95 This would give total drag factor of 8.6 which is very close to 8.7. Bill may have to leave fairings off the landing gear legs. According to this his Firestar should top out at 55 knots. I have found this graph to be conservative, so I expect it would do better than this. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 29, 2008
[quote="jindoguy(at)gmail.com"] What about going the other way round and shorten the Firestar's wing to Firefly dimensions? You might have to resort to.........VG's (oh dear lord, to think what his might bring to the discussion :-) ) to get the 24 knot CAS requirement, but you would sure be losing weight. Just a PBI, no real thought or math calc's put into it. Rick > [b] Rick That is the worst idea I have heard to date, why would you shorten the wings, and make the airplane more dangerous by increasing wing loading and stall speed ? Now you have an airplane that is easier to stall, and impossible to slow down as much as before in a forced landing. So you are suggesting that Bill go to many hours of work to make a more dangerous airplane, in order to lighten it a couple percent, or lighten Only a total fool would do something like that. I have seen pure stupidity on this list before, but this is one of the worse suggestions I have seen to date. I can just see Rick and Richard in a position of authority. " Sir, your plastic fuel tank has bulged and it now holds 5.25 gallons, and 5 gallons is the limit, so I am going to have to violate you.. " Or sir, you were doing 58 MPH in a 55 MPH zone, so I am going to write you a citation... To anyone reading this thread now or in the future, don't make your plane more dangerous, or make it handle worse, or harder to fly than it needs to be. This is a prime example of people that can read a rule, but can not use good judgment and will sacrifice safety in pursuit of chasing an arbitrary number by a couple percent. We have to much of this kind of stupidity and poor judgment in the world as it is. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161173#161173 ________________________________________________________________________________
Date: Jan 29, 2008
Subject: Re: Firestar project
I have a very good friend who has the amazing ability to misunderstand and misconstrue anything said to him. Are you a relative of his? Richard Pike MKIII N420P (420ldPoops) JetPilot wrote: > Of course, Richard Pike will probably want to take the gas out of your new tank, and if it is a pint over 5 gallons, tell you to change it as you are still illegal hahaha. > > Mike > > - ________________________________________________________________________________
Date: Jan 29, 2008
jbhart(at)onlyinternet.ne wrote: > > > Denny, > > If Bill is serious about this, he can change to a 28 hp engine and save at least 40 pounds. With an engine change the wing loading will be less than the FireFly, so it will have no problems meeting stall speed requirements. If Bill's Firestar has a 447 mounted and he changes engines, he will be giving up enough hp so that he can fly with reduced drag and not exceed the max speed requirement. > > Jack B. Hart FF004 > Winchester, IN Since when do they go test fly ultralights while doing ramp checks to see what the max speed of the ultralights are ? Your suggestion is nothing short of irresponsible. Most people must be reading this and laughing at you, they just aren't as willing to pout out your bad suggestion in public suggestion as I am. Having more power = more options available when things go bad, which means more safety. Steeper climb = More altitude and more options if the engine quits at the end of the runway. Only an anal retentive person without a ounce of good sense would suggest putting to small an engine on a firefly to chase a couple percentage points in numbers. This would make the plane underpowered, very substandard in climb, and more dangerous than it needs to be just to slow it down a little. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161178#161178 ________________________________________________________________________________
Date: Jan 29, 2008
> > That is the worst idea I have heard to date, why would you shorten the wings, and make the airplane more dangerous by increasing wing loading and stall speed ? Now you have an airplane that is easier to stall, and impossible to slow down as much as before in a forced landing. So you are suggesting that Bill go to many hours of work to make a more dangerous airplane, in order to lighten it a couple percent, or lighten Only a total fool would do something like that. I have seen pure stupidity on this list before, but this is one of the worse suggestions I have seen to date. > > I can just see Rick and Richard in a position of authority. " Sir, your plastic fuel tank has bulged and it now holds 5.25 gallons, and 5 gallons is the limit, so I am going to have to violate you.. " Or sir, you were doing 58 MPH in a 55 MPH zone, so I am going to write you a citation... > > To anyone reading this thread now or in the future, don't make your plane more dangerous, or make it handle worse, or harder to fly than it needs to be. This is a prime example of people that can read a rule, but can not use good judgment and will sacrifice safety in pursuit of chasing an arbitrary number by a couple percent. We have to much of this kind of stupidity and poor judgment in the world as it is. > > Mike With fear of stepping into someone else's fight...so all these Firefly's with the shorter wings are BAD? Seems that a little higher wing loading is a good, shall I say GREAT thing sometimes...like when there is a little turbulence and/or thermal activity...by your reasoning we should all be flying gliders...so they would have good engine out characteristics ;-) That is a great characteristic, just not the only one to consider in these great big balls of compromise that we call airplanes...(or "vehicles" for you Part 103 folks...;-) Jeremy "clip-wing Firestar/Slingshot wannabe" Casey http://www.kilocharlie.us/superfly.htm ________________________________________________________________________________
Date: Jan 29, 2008
Ok, I give up. I tried my best to explain the difference between dealing with the law and the consequences of breaking it and my indifference to what any of you choose to do about it, and that has been (deliberately?) misconstrued. I tried to point out (tongue in cheek) that I deal with idiot 25 mph speed limits on 45 mph roads as I think best, am willing to take the responsibility of getting busted for doing so, and even posted a picture of my crotch rocket, and that has been (deliberately?) misconstrued. Proverbs 26: 4 tells us "Do not answer a fool according to his folly, lest you also be like him. " The next verse, Proverbs 26:5 says "Answer a fool according to his folly, lest he be wise in his own eyes." Guys, I am done with trying to fulfill verse 5, and I leave it to you to figure out how best to deal with verse 4. The MKIII is coming into the garage tomorrow, some more mods to the fuselage area, try to improve the airflow around the fuselage upper rear, just ahead of the radiator, add a taper at the back end of the fuselage, see if cleaning up that little flat area about 10" ahead of the prop arc will do anything. Fix a glitch in the radio, different intercom, etc. Also bought myself a Hall wind meter, will be pulling off the VG's, attaching the Hall to a lift strut, getting it pointed straight into the relative wind at stall, and shooting some videos through stall to see what this MKIII actually stalls at, power on and off, with and without flaps, and satisfy myself as to just what she does. Then put the vg's back on and do it all again. If I come up with anything worth sharing, I might check back in this summer. It's been a great ride, fair skies and tailwinds to you all, Richard Pike MKIII N420P (420ldPoops) JetPilot wrote: > > [quote="jindoguy(at)gmail.com"] > What about going the other way round and shorten the Firestar's wing to Firefly dimensions? You might have to resort to.........VG's (oh dear lord, to think what his might bring to the discussion :-) ) to get the 24 knot CAS requirement, but you would sure be losing weight. > Just a PBI, no real thought or math calc's put into it. > > Rick > > > >> [b] >> > > > Rick > > That is the worst idea I have heard to date, why would you shorten the wings, and make the airplane more dangerous by increasing wing loading and stall speed ? Now you have an airplane that is easier to stall, and impossible to slow down as much as before in a forced landing. So you are suggesting that Bill go to many hours of work to make a more dangerous airplane, in order to lighten it a couple percent, or lighten Only a total fool would do something like that. I have seen pure stupidity on this list before, but this is one of the worse suggestions I have seen to date. > > I can just see Rick and Richard in a position of authority. " Sir, your plastic fuel tank has bulged and it now holds 5.25 gallons, and 5 gallons is the limit, so I am going to have to violate you.. " Or sir, you were doing 58 MPH in a 55 MPH zone, so I am going to write you a citation... > > To anyone reading this thread now or in the future, don't make your plane more dangerous, or make it handle worse, or harder to fly than it needs to be. This is a prime example of people that can read a rule, but can not use good judgment and will sacrifice safety in pursuit of chasing an arbitrary number by a couple percent. We have to much of this kind of stupidity and poor judgment in the world as it is. > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=161173#161173 > > > ________________________________________________________________________________
Date: Jan 29, 2008
> > Denny, > . With an engine change the wing loading will be less than the FireFly, so it will have no problems meeting stall speed requirements. > Jack H Jack, I would think that a Firestar that is this close to 254 pounds would already have a slower stall speed and lighter wing loading than a Firefly with its much smaller wing area. I doubt the engine size would need to be reduced to achieve legal UL speed limits on paper as long as the few pounds could be removed elswhere. Sincerely, Denny ________________________________________________________________________________
Date: Jan 29, 2008
> >Since when do they go test fly ultralights while doing ramp checks to see what the max speed of the ultralights are ? Your suggestion is nothing short of irresponsible. Most people must be reading this and laughing at you, they just aren't as willing to pout out your bad suggestion in public suggestion as I am. Having more power = more options available when things go bad, which means more safety. Steeper climb = More altitude and more options if the engine quits at the end of the runway. > >Only an anal retentive person without a ounce of good sense would suggest putting to small an engine on a firefly to chase a couple percentage points in numbers. This would make the plane underpowered, very substandard in climb, and more dangerous than it needs to be just to slow it down a little. > >Mike > Mike, This has been a discussion about what can be done to make a Firestar a legal ultralight vehicle. As my right, I have posted my opinion and you have posted your opinion of my opinion, which is your right. I believe Bill is capable of deciding for him self as to what he wants to do with my post. You do not understand. I don't care if people laugh at me or not. I have more faith in numbers than suppositions. The numbers, based on existing wing and power loading, say that a Firestar can fly very safely with only 28 hp. Your incessant claim of a requirement for power tends to lead me to believe you use it as a crutch for your lack of adequate piloting skills or your discomfort in flying in very very light aircraft. I find your heaviness, to use one of your terms, "anal". Please lighten up, drink a beer with a friend, find some companionship, or find medical help. Just for your info, I have a 27hp MZ34 sitting on the table in my shop. Today I finished the computations to see how the cg change in mounting it. Even with a bulk head mount off the back, the cg moved forward and just one inch. I believe it will cut close to 50 pounds off the FireFly. I will add some weight back with a full enclosure so I can do more winter flying. If and when it gets done, the FireFly will remain a true ultralight vehicle. It will continue to be as safe as the person who flys it. In answer to your question, during a ramp check a pilot of an ultralight vehicle has to prove that the unregistered aircraft he is flying is an ultralight vehicle. The FAA has deemed that a properly filled out AC 103-7 Appendix 1, 2, 3 & 4 is sufficient proof. Once again, Mike have a nice day and fly safe. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 29, 2008
At 03:20 PM 1/28/2008, you wrote: >At 07:27 AM 1/28/2008, you wrote: >> >> >>In a message dated 1/28/2008 3:34:46 A.M. Eastern Standard Time, >>orcabonita(at)hotmail.com writes: >>I say only an anal idiot would worry about 15 pounds > >The thing is that after Jan 31, your fat ultralight will stand out a lot >more that it use to "without N-numbers". Use to be hardly anyone had them, >even the two seaters. Now - you will be a lot more conspicuous out >there on the >tarmac. Let me reply to my own post - That is, if you are 15 pounds overweight and don't have N-numbers, you are going to "stand out" in the crowd now - more that before, and if you don't have N-numbers you are more likely to be ramped checked after Jan 31st. Not that the 15lbs is any worse than we've all been doing for the past 20 years, but when we all were doing it and nobody had N-numbers - you were a lot less likely to be questioned. ________________________________________________________________________________
Date: Jan 29, 2008
Subject: "clip-wing Firestar/Slingshot wannabe"
In a message dated 1/29/2008 4:43:37 P.M. Eastern Standard Time, 1planeguy(at)kilocharlie.us writes: "clip-wing Firestar/Slingshot wannabe" Thanks for posting the pictures Jeremy, How short are you going on the wings What kind of struts what kind of engine What is that frame hanging from the ceiling? Steve B Firefly 007/Floats with small unsafe wings (-: do not archive **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 29, 2008
Oh, changed the Tagline in case anyone was interested in your project. steve In a message dated 1/29/2008 4:43:37 P.M. Eastern Standard Time, 1planeguy(at)kilocharlie.us writes: "clip-wing Firestar/Slingshot wannabe" **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 29, 2008
In a message dated 1/29/2008 8:08:22 A.M. Eastern Standard Time, williamtsullivan(at)att.net writes: One thing no one mentioned regarding weight- I am about 170 dressed, and my wife is about 50 pounds heavier. I would think the powers that be would be more interested in whether the gross weight is being exceeded instead of a couple of pounds over. Luckily, the Firestar is capable of the difference. HI BILL SULLIVAN, Does the above comment indicate that you might take your wife along as a passenger??? Or were you just talking about the difference in weight if she were to pilot it? I had previously answered your original thread directly to you, but I'll post this one for all to read. Just for every one's information: On June 30, 1989 I purchased a FireStar kit from old Kolb. The specification list that came with the advertising brochure states the following: Wing Span 27' 8" Wing Area 149 sq ft Length 20' 3" Length folded 21' 3" Height 5' 8" (same folded) Width (folded) 66" Load factor 4+, 2- Reduction unit Rotax integral gearbox with vibration damper Propeller 66 X 28 Fuel Capacity 5 gal Rate of climb 1,000 FPM Weight 264 lbs * Engine Rotax 377 Take off distance 100 ft (grass) Top speed 63 MPH (Partial enclosure) *Needs parachute to be legal ultralight. My kit came with the main landing gear legs only 1" in dia., where they went into the airframe. The axle holder was a light weight welded piece using small plastic wheels with no brakes. The windshield was a short one, about 1/3 coverage, and the center section cover was fabric, with a zipper to secure the two halves. Bill Varnes Original Kolb FireStar Kit price on 6/30/89 $5695 included engine!!! Audubon NJ Do Not Archive **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 30, 2008
Subject: FAR 103.3 Inspection requirements
Folks, I didn't write them, but like Joe Friday always said, "The facts, ma'am, just the facts." (a) Any person operating an ultralight vehicle under this part shall, upon request, allow the Administrator, or his designee, to inspect the vehicle to determine the applicability of this part. (b) The pilot or operator of an ultralight vehicle must, upon request of the Administrator, furnish satisfactory evidence that the vehicle is subject only to the provisions of this part. Here's where you can find them: http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=60fc6b3fd47a0364348d812a785969a7&rgn=div5&view=text&node=14:2.0.1.3.16&idno=14 Rick ________________________________________________________________________________
Date: Jan 30, 2008
I would think the powers that be would be more interested in whether the gross weight is being exceeded instead of a couple of pounds over. >> They are in the UK, which is why the limiting weight for an ultralight here is the MTOW. For calculation purposes there is a standard weight for the pilot and passenger. Cheers Pat ________________________________________________________________________________
Date: Jan 30, 2008
At 11:59 PM 1/29/2008, Ron wrote: >First how will they tell if your craft is obese? >They can't unless you tell them or let them. You need to understand that >your craft is your private property and they have no right to weigh it >without your permission... I wish it were so: =A7 103.3 Inspection requirements. (a) Any person operating an ultralight vehicle under this part shall, upon request, allow the Administrator, or his designee, to inspect the vehicle to determine the applicability of this part. (b) The pilot or operator of an ultralight vehicle must, upon request of the Administrator, furnish satisfactory evidence that the vehicle is subject only to the provisions of this part. -Dana -- A rolling stone .... kills worms ________________________________________________________________________________
Date: Jan 30, 2008
The FAA set some max and stall speed limits >> Really? You have max speed limits?. Here we have many ultralight types with top speeds over a 100mph. One making 130 I believe. Stall speed is the main performance regulator, 35. Cheers Pat ________________________________________________________________________________
Date: Jan 30, 2008
At 07:06 AM 1/30/2008, pj.ladd wrote: >The FAA set some max and stall speed limits >> >Really? You have max speed limits?. Here we have many ultralight types >with top speeds over a 100mph. One making 130 I believe. Stall speed is >the main performance regulator, 35. Pat, for "true" ultralights the maxes are 24 knots stall and 55 knots level flight at WOT... but the Part 103 regulations are so loose (including no license or registration) that there are many advantages to this category, IF you can meet the 254 lb empty weight limit. For "Light-Sport Aircraft" (comparable to your microlight category) it's 1320 lbs empty, 45 knot stall and 120 knot max. -Dana -- For every new foolproof invention there is a new and improved fool. ________________________________________________________________________________
Date: Jan 30, 2008
check King George III's notes on that. >> Hi Bill, I liked that. We do have a different attitude here than in the US. Long may it continue, for both of us. To some extent I think it is a function of the size of the US. There are lots of places in the States where I am sure you could get away with minor infrigments of regulaions all your life. We are just too small for that to work. Unfortunately the more people that exist in a confined space the more regulation it takes to co exist. We have just introduced a virtual regulation free category for a/c weighing less than 115Kg which is rather like your ultralight rules and it will be interesting to see what that produces. Our `microlight` category rules are stringently drawn where it matters, MTOW and stall speed being paramount. The MTOW weight has been raised steadily as things have progressed and we have moved closer to parity with the rest of Europe. It is rather like yacht racing .If you want development in a certain directio then you change the rules .By defining waterline length, the sail area, etc. This approach has seen many microlights here with top speeds around and above 100 mph with 2 up with a 11 litre per hour fuel burn,when crjuising.They still retain the slow speed handling and stall characteristics which keep the planes within the flying capabilities of the average low hours pilot.The new Dynamic has been clocked at 120kt at 5500rpm and on properly calibrated runs at 131kt . Pretty nifty.Mind you it is priced at =A367,650 for the 912 version plus =A33000 for the 912S ready to fly which is a bit salty for my taste. Bucking the system of course takes place with minor things but it is not too difficult in the event of a crunch (Which WILL be investigated) to calculate if you were overweight on take off. If you were. Your insurance will be invalid on the plane, yourself, any 3rd party involved. So if you go down in a field and kill somebodies Aberdeen Angus Prize Bull you, or your widow, will have a lot o money to find. Cheers Pat ________________________________________________________________________________
Date: Jan 30, 2008
Everybody keep talking- I'm learning! Thanks for all the information. My wife would be flying alone. It is only a single seat. This is an old Firestar, and I still haven't found a serial number. I suspect it is an early one. The landing gear legs measure 1" where they go into the socket. It has a two blade 66" Warp Drive prop, no brakes, full enclosure, minimal instrumentation, a BRS, full size wings, and 15-6.00x6 tires with tubes on tubeless aluminum rims. No flaps or flaperons. Fiberglass tailwheel strut with about a 4" plastic wheel. Ten gallon tank. The tank is going to be switched out to 5 gallon, and that should save a pound or so. Someone said the original had Azusa nylon wheels with 4" tires. Does anyone know the weight savings by switching? Keep in mind that this is my first aircraft project, and I find it an intellectual challenge to trim weight, as well as a lot of fun. I need all the advice you can give me. I do not have the current knowledge or experience to work the numbers. I didn't mention a couple of things. It came through with 2 sets of struts- one set of round aluminum that I believe are original; and a second set that are streamlined steel(?) that are twice as heavy, but I didn't stick a magnet to yet. I'm using the round ones for the weight. Extra speed does not matter. Range does not matter- only local flying is anticipated, an hour or so at a time. Safety in handling is a priority- our first ultralight. Another question- The wings have three holes at the front attachment point for changing the angle, and the former owner recommended the middle hole. Any opinions? Another thing to keep in mind is that I am not an engineer. My background is more of welding and fabricating with heavy steel. That is why I'm having fun with all this, and my back hasn't hurt doing it. Love the Kolb, even without getting it off the ground! Bill Sullivan antique Firestar ________________________________________________________________________________
Date: Jan 30, 2008
Bill S: What is your aviation background, i.e., flying experience? I know you said you planned only to fly locally for an hour at a time. I said the same thing before I flew my first Kolb 24 years ago. That lasted two weeks and I had begun my cross country career. Another thing to remember. Take a look around and see how many folks are flying with Azusa nylon wheels. Probably not more than a couple out of the thousands that have been sent out with kits over the many years Kolb has been producing kits. There is a reason for that. They are built light and weak. Brakes, I flew without them for several years. Even did a flight from Alabama to New York State and back without them. However, it was a pain in the ass and brakes, later on, made my aircraft much, much safer. Guess it all depends on what you want. If you are like most of us, you will want to improve your airplane and not degrade it attempting to reduce weight. As far as meeting the FAR 103 requirement of 254 lbs, that one is going to be extremely tough to make with a Firestar. You can go to a smaller, lighter engine. The FS was designed to fly on 35 hp. It will probably fly on half that. I think you will be degrading performance and the fun of flying a sporty airplane. Good luck, john h mkIII Another thing to keep in mind is that I am not an engineer. My background is more of welding and fabricating with heavy steel. That is why I'm having fun with all this, and my back hasn't hurt doing it. Love the Kolb, even without getting it off the ground! Bill Sullivan ________________________________________________________________________________
Date: Jan 30, 2008
Subject: Re: FAR 103.3 Inspection requirements
Thanks for the quote. Heck I don't remember seeing that before, Not surprising as I have yet to operate under FAR 103 however still even though its worded vaguely (shall, upon Request, allow the Administrator, or his designee ) and of course on purpose that way. None of us have given away any of out constitutional rights. I rather contest that later in court if they want to than to have them bust me right there and then on a real violation. What happens if I deny their request, what can they do? Has anyone ever got busted? It also does not give a time frame as to when one must comply with the request, what happens if I say "come back next week I don't have time for it right now" and then fly off? Where do I even have to tell them who I am or any other information? I agree its better to be within the rules than to have to put up with the Gestapo but we do have the choice of not having to. Remember its a rule not a Law! Ron (Arizona) =========== ---- Richard Girard wrote: ============ Folks, I didn't write them, but like Joe Friday always said, "The facts, ma'am, just the facts." (a) Any person operating an ultralight vehicle under this part shall, upon request, allow the Administrator, or his designee, to inspect the vehicle to determine the applicability of this part. (b) The pilot or operator of an ultralight vehicle must, upon request of the Administrator, furnish satisfactory evidence that the vehicle is subject only to the provisions of this part. Here's where you can find them: http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=60fc6b3fd47a0364348d812a785969a7&rgn=div5&view=text&node=14:2.0.1.3.16&idno=14 Rick -- kugelair.com ________________________________________________________________________________
Date: Jan 30, 2008
Ron I appreciate your position. We live in the Land of the Free -- we're free to tangle with the Feds in court, go up against their M OST talented lawyers, have them jerk us around for several years until we've spent all our money and a whomping big bunch of time (during which we can't fly at all) and then lose the case. Count on it. A disgusting situation but there it is. In my very amateur opinion On Jan 30, 2008, at 10:58 AM,Ron wrote: > > Thanks for the quote. > Heck I don't remember seeing that before, Not surprising as I have > yet to operate under FAR 103 however still even though its worded > vaguely (shall, upon > Request, allow the Administrator, or his designee ) and of course > on purpose that way. None of us have given away any of out > constitutional rights. I rather contest that later in court if they > want to than to have them bust me right there and then on a real > violation. > What happens if I deny their request, what can they do? Has anyone > ever got busted? > It also does not give a time frame as to when one must comply with > the request, what happens if I say "come back next week I don't > have time for it right now" and then fly off? Where do I even have > to tell them who I am or any other information? I agree its better > to be within the rules than to have to put up with the Gestapo but > we do have the choice of not having to. Remember its a rule not a Law! > > Ron (Arizona) > > =========== > ---- Richard Girard wrote: > > ============ > Folks, I didn't write them, but like Joe Friday always said, "The > facts, > ma'am, just the facts." > > (a) Any person operating an ultralight vehicle under this part > shall, upon > request, allow the Administrator, or his designee, to inspect the > vehicle to > determine the applicability of this part. > > (b) The pilot or operator of an ultralight vehicle must, upon > request of the > Administrator, furnish satisfactory evidence that the vehicle is > subject > only to the provisions of this part. > Here's where you can find them: > > http://ecfr.gpoaccess.gov/cgi/t/text/text-idx? > c=ecfr&sid=60fc6b3fd47a0364348d812a785969a7&rgn=div5&view=text&node=14 > :2.0.1.3.16&idno=14 > > Rick > > -- > kugelair.com > > ________________________________________________________________________________
Date: Jan 30, 2008
Subject: Kolb-List Fat Firestar ROTAX GURU
Hi all ... Kinda getting a little terse around here .... Hopefully we all can step back and take a deep breath ... My Firestar IS now legal ... now I have to go to school to keep it so :-( and now "the man" knows way more about me and my little plane than I ever Intended ! Kinda like when we have to surrender our cash and guns ... God dont let Hillary win ... I have asked and gotten some good information but need spicifics on firestar strutts need actual info on making streamlined adjustable strutts ... also need info on a provision 8 377 case can I mate it to a provision 4 gearbox somehow can I still use the points ignition can I use a provision 4 crankshaft ... Also can I use a 447 top end on the cases ...? Thanks! Dave ************** Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 30, 2008
Subject: Re: "clip-wing Firestar/Slingshot wannabe"
In a message dated 1/30/2008 1:44:58 P.M. Eastern Standard Time, 1planeguy(at)kilocharlie.us writes: Have a 503 to put on it but am trying to talk myself into the HKS. Sounds good, did you make provisions for the added weight of the HKS? Steve B Firefly 007/Floats do not archive **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 30, 2008
> A disgusting situation but there it is. Russ K: What is disgusting about breaking the law, trying to beat the rap, spending all your money doing it, and have the Feds eat you for lunch? Seriously, if you break the law, Part 103, which in my opinion is spelled out so that even I can understand it, you gonna pay the consequences. I don't see anything vague about the FAA asking to inspect my unregistered airplane and me complying. I flew heavy ULs for a while, was not comfortable doing it, and experienced a great sense of relief when I started flying my experiemental homebuilt that was legal with inflight hull and liability insurance. Previously, I was flying with no insurance because I was illegal and none was available for an unregistered airplane. Cost much more to fly now, but probably a lot cheaper in the long run. Take care, john h mkIII ________________________________________________________________________________
Date: Jan 30, 2008
I agree with what John H said. I flew my fat UL in 2005 and was always worried about having a forced landing in a bean field and some good Samaritan calling 911 and the sheriff showing up with the next call to the FAA. I know the rules, I would get penalized with a suspension and having to answer the violation question forever on insurance applications. I parked it till I was able to get legal and what a relief. I fly now with the hope someone does call 911 if I have a forced landing. They can help haul me or my plane out of the field, depending on what gets damaged. Fly safe. Jim -------- Jim O'Day Fargo, ND Firestar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161425#161425 ________________________________________________________________________________
Subject: Cleaning up a Mark-III
Date: Jan 30, 2008
From: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
Richard Pike wrote: << The MKIII is coming into the garage tomorrow, some more mods to the fuselage area, try to improve the airflow around the fuselage upper rear, ... see if cleaning up that little flat area about 10" ahead of the prop arc will do anything. >> Kolb Friends - I was thinking of trying to make improvements in this area as well. I, too, built my Mark-III with the upper half of the rear fuselage pod open. I believe this contributes to a large chunk of the overall drag on my plane. Earlier Mark-IIIs (like Hauck's) had fabric all the way up to the bottom of the wing, like the Firestar. This configuration seems like it would be less draggy, as the airflow coming around the fuselage sides would follow a more streamlined and uniform path toward the prop. On my Mark-III, the airflow spills around the aft edge of my doors, separates, and (I'm sure) crates turbulent eddy currents (which equals gobs of drag) in that whole area aft of the cabin. This was one of the design improvement goals that New Kolb set out to achieve with the Xtra, I've been told. Would it help reduce drag by simply adding a flat panel to each upper side of the fuselage cage, to keep the airflow moving? I'm thinking of using 1/16" Lexan, attached using Adel clamps to the cage tubes in that area. Somebody on this List once said that the biggest ways to increase our Kolbs' performance is to concentrate efforts on ways of reducing drag. This fuselage panel thing seems to fall in that category. Opinions? Thanks - Dennis Kirby 912ul, Powerfin-72, in Cedar Crest, NM ________________________________________________________________________________
Date: Jan 30, 2008
Over the years, there have been a few incidents and accidents involving fat ultralights near my old field. If the sheriff is called out, he always calls the faa. He says it is their call whether it is an airplane or an UL. The FAA usually shows up and looks at the pile of tubes and fabric and says "ultralight, no investigation" They never weigh them. If it has one seat, 5 galon tank and looks like an ultralight...case closed. They don't want to do the paperwork. That said, if the plane crashed somewhere it shouldn't be, like downtown or a schoolyard, I am sure they would nail you to a cross. If you crash an N numbered plane, isn't there always an investigation? Bryan D > I parked it till I was able to get legal and what a relief. I fly now > with the hope someone does call 911 if I have a forced landing. They can > help haul me or my plane out of the field, depending on what gets damaged. > > Fly safe. > > Jim > > -------- > Jim O'Day > Fargo, ND > Firestar II > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=161425#161425 > > ________________________________________________________________________________
Date: Jan 30, 2008
Subject: RE: Firestar project main spar attachment
William, I pulled out my Firestar's assembly manual and checked the Final wing rigging and lift struts section (pages 32 and 33 on my manual, dated 1985, yours could be different). There is no mention of three holes, just a single 5/16" hole. There is an admonition to "maintain a healthy edge distance" when drilling this hole. Perhaps this was a homegrown modification that gained traction later on, I don't know. In general empty holes are considered a place for cracks to start in aircraft structures. Do you have any precision measuring capability? It would be good to know just how much distance there is between the edges of holes and the distance from each hole to the edge of the fitting. This area is in compression during normal flight, but in a negative G situation there is a possibility of a shear tear out when this area is loaded in tension. This would be subject to just how much material is there. I do not have 5 rib wing drawings, just the 7 rib. It shows the pin center to edge as 5/16" or a .156" (5/32") edge margin. By contrast Boeing specifies a default .35 edge margin unless otherwise shown on the drawing. This is one you might want to give the factory a call on and get their blessing. Rick P.S. The pic is of the right wing attachment on mine. - Show quoted text - ________________________________________________________________________________
Subject: Re: Cleaning up a Mark-III
Date: Jan 30, 2008
> Earlier Mark-IIIs (like Hauck's) had fabric all the way up to the bottom > of the wing, like the Firestar. > > Dennis Kirby Dennis: Sorry, but mkIII's have always be designed and kitted with the lower half of the rear fuselage covered. Seemed to me to be an ideal place to put a big fuel tank and get some use out of that big empty space. We ended up with a nice 25 gal useable aluminum tank. Nope, that is an original Hauck design change, not Kolb. john h mkIII ________________________________________________________________________________
Date: Jan 30, 2008
Progress- I took off the tailwheel bracket in order to change the wheel and straighten the clevis glued to the fiberglass strut. The clevis had been glued on twisted, and the tail wheel was badly worn on one side. I heated the clevis to soften the glue, and it went bang and gave a small jet of flame. Luckily, I was wearing glasses and was off to one side. I twisted it gently and let it cool down. Worked great. The tailwheel axle was held in by two aluminum rivets. It was also rusted in place. I turned down and cut a 7/16" clevis pin into a bushing driver, heated the axle brackets, and it slid out. Cleaned it up with a Dremel. Travis at Kolb has it in stock. I have to repair the tubing where the steering cables attach. They were almost worn through. Lots of detail work on something this old. I also have to cut off the aluminum sleeve that holds one wheel on, with a cotter pin through it. Siezed up on the steel axle. Travis is sending some tube stock. Tip on jacking: This plane has tubular axles. Stick a lon 5/8" bolt in the back of the axle, and use an old Chevy truck jack. This is the jack with an internal screw, and has a drop-down hook plate. Works great. Only problem was that the ice was slowly melting. and the jack was sinking. I am jealous of all you indoor plane fixers. Bill Sullivan ________________________________________________________________________________
Date: Jan 30, 2008
Nope! john h mk III If you crash an N numbered plane, isn't there always an investigation? Bryan D ________________________________________________________________________________
Subject: 912ULS Mag Drop
Date: Jan 30, 2008
Gang: My idea of why the mag was dropping was correct. After oiling the throttle clevis's, changing spark plugs, with no improvement, I played with the enricher at 4000 rpm while performing the mag check. Indication was lean condition at 4000 rpm. Today, despite the wind and cold, I got the needles raised a notch, which puts the clip in the bottom groove of the fuel needles. It worked. Now I am a happy camper once again. Proves not all 912 engines are created equal. I never encountered this problem with my last 912ULS. Didn't get to test fly because it was getting late by the time I finished up. These new generation Bing carbs are much easier to get to the top innards of the carb to get at the fuel needles. The older ones were a little more work intensive. Always feels good to get those little problems solved. john h mkIII ________________________________________________________________________________
Date: Jan 30, 2008
Dennis, My MKIII is also open behind cabin on the upper part. I discussed closing it in with Mr. Kolb at TNK and what he thought the difference would be. He thought the advantage would be very little for aerodynamics. If I ever do any work in that area I will probably still close it in for the cargo space. John H. and I flew within sight of each other for about 13 hours last May. Both planes are Kolb Mark 3s with 912Ss and a lot of differences otherwise . I used 0.25 - 0.5 gph less than he did. I realize this is apples and oranges but I tend to agree with Mr. Kolb that enclosing the back is not going to make a big difference in aerodynamics. John H. We should have done a side by side full throttle run and compared top speeds. Maybe next time! Steven Planning to fly this Sunday evening > Earlier Mark-IIIs (like Hauck's) had fabric all the way up to the bottom > of the wing, like the Firestar. This configuration seems like it would > be less draggy, as the airflow coming around the fuselage sides would > follow a more streamlined and uniform path toward the prop. On my > Mark-III, the airflow spills around the aft edge of my doors, separates, > and (I'm sure) crates turbulent eddy currents (which equals gobs of > drag) in that whole area aft of the cabin. This was one of the design > improvement goals that New Kolb set out to achieve with the Xtra, I've > been told. > > Would it help reduce drag by simply adding a flat panel to each upper > side of the fuselage cage, to keep the airflow moving? I'm thinking of > using 1/16" Lexan, attached using Adel clamps to the cage tubes in that > area. > > Somebody on this List once said that the biggest ways to increase our > Kolbs' performance is to concentrate efforts on ways of reducing drag. > This fuselage panel thing seems to fall in that category. Opinions? > Thanks - > > Dennis Kirby > 912ul, Powerfin-72, in > Cedar Crest, NM > > > ________________________________________________________________________________
Date: Jan 30, 2008
In a message dated 1/30/2008 7:05:46 A.M. Central Standard Time, williamtsullivan(at)att.net writes: Someone said the original had Azusa nylon wheels with 4" tires. Does anyone know the weight savings by switching? Bill, You should save a minimum of 2 lbs going to 4" Azusa from 6 " Azusa. Very likely More especially if your 6" wheels are of the aluminum variety. Personally ,even though I have the 4 " wheels, the 6'' wheels are my preference as far as handling goes. Ed FF62 **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 30, 2008
At 05:51 PM 1/30/2008, you wrote: >Over the years, there have been a few incidents and accidents >involving fat ultralights near my old field. If the sheriff is >called out, he always calls the faa. He says it is their call >whether it is an airplane or an UL. The FAA usually shows up and >looks at the pile of tubes and fabric and says "ultralight, no >investigation" They never weigh them. If it has one seat, 5 galon >tank and looks like an ultralight...case closed. They don't want to >do the paperwork. > >That said, if the plane crashed somewhere it shouldn't be, like >downtown or a schoolyard, I am sure they would nail you to a cross. Here's my experience: Have an incident where the sheriff is called out. He calls the FAA and tells them that the pilot says it is an ultralight. Look's like it's made of tubes & fabric. They tell the sheriff to tell the pilot that they "won't be coming out", no investigation. However: The next day the FAA calls me and the conversation goes something like this: Mr. Sullivan, I am Mr. ___ with the FAA and am calling about your incident in the lake yesterday. Yes Sir Mr. Sullivan, where is your plane right now? Sir, it's in my dad's barn in Powder Springs (about 20 west of Atlanta). Directions follow. Mr. Sullivan, where are you right now? About 15 miles north of there in Kennesaw. Mr. Sullivan I would like you to meet me there in 45 minutes. Yes Sir. ----------------- Since I've seen this all before, I managed to strip all the fabric off the entire plane "before he ever called". Also removed & moved the fuel tank/tanks. Removed and disassembled the engine, chute, seat etc. The wings were twisted anyway, as was the cage. The engine (600 hrs) was full of water along with the bearings etc. So it wasn't that big a deal. He came - he looked - he said "yeah, I guess it was an ultralight". Took some pictures and went back to Atlanta. No matter what they say - you crash it & they will come, at least here. I've seen this happen twice. They are very professional though. ________________________________________________________________________________
Date: Jan 31, 2008
Sorry to hear about the wetter than planned end to the flight, but I am assuming everyone was OK. I found the post very interesting. We've all heard stories about investigation/enforcement, but I have not heard many first hand accounts of how the process works. This brings up a question that has been in my mind thru this and the previous (un-named here) thread - How many of us have seen "ramp checks" first hand? Is this common in some parts of the country? Do they ever weigh planes? I'm not saying it is OK to break the rules if they are not enforced - I'm just curious about how the system works. Dan G. Tucson 503 F2 (yes, it is a legal ELSA as of September last year) possums wrote: > Here's my experience: > Have an incident where the sheriff is called out. He calls the FAA and > tells them that the pilot says it is > an ultralight. Look's like it's made of tubes & fabric. They tell the > sheriff to tell the pilot that they "won't > be coming out", no investigation. > > However: > The next day the FAA calls me and the conversation goes something like > this: > > Mr. Sullivan, I am Mr. ___ with the FAA and am calling about your > incident in the lake > yesterday. > > Yes Sir > > Mr. Sullivan, where is your plane right now? > > Sir, it's in my dad's barn in Powder Springs (about 20 west of > Atlanta). Directions follow. > > Mr. Sullivan, where are you right now? > > About 15 miles north of there in Kennesaw. > > Mr. Sullivan I would like you to meet me there in 45 minutes. > > Yes Sir. ________________________________________________________________________________
Date: Jan 31, 2008
Seemed to me to be an ideal place to put a big fuel tank and get some use out of that big empty space. We ended up with a nice 25 gal useable aluminum tank.>> Sounds a great idea John. Wish I could get away with that over here. What did it do to your weight and C of G? Pat ________________________________________________________________________________
Date: Jan 31, 2008
For "Light-Sport Aircraft" (comparable to your microlight category) it's 1320 lbs empty>> Hi Dana, I think our new sub 115Kg category will closely approximate your ultralight. Not completely uncontrolled but much more so than our usual `microlight`spec. Our `microlights` are still well below the Sports category weight. My Xtra has to be below 950lbs MTOW. Fascinating how different countries have dealt with this problem. Some have specified empty weight some MTOW some countries do not allow flight above a certain height some do not allow it below a certain height. Switzerland allowed no microlights at all until last year. Spain had no legal microlights a few years ago but there were plenty flying. The legal spec was so tight that no one could possible fly. Apparently all applications to fly microlights finished up on the desk of a guy in the Spanish equivalant of the FAA and he was a microlight pilot himself. He just `lost` them. Apparently in Australia until a short time ago there were many pilots with no pilots licence because they lived on large homesteads and and learned to fly in the same way that they learned to drive a car. Their Dad taught them. They were never `official` beacause they flew on and over their own land and never landed at a `proper` airfield. However when they began to fly from their own homesteads to the neighbours, and then on to the next one, and the next, in increasing numbers the authorities lowered the boom on them. Good while it lasted though. No more posts from me for a couple of weeks as I am off to supposedly `sunny` Tenerife in the morning. In fact Tenerife has rain and high winds forecast for at least the next few days. Warm though, in the 70`s so that will be OK Cheers everybody Pat ________________________________________________________________________________
Date: Jan 31, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: Firestar project
Pat, thanks for the information on the latest developments over there. I am new to this, so the term "ultralight" means something different to all of us. Keep the info coming. As far as the three mounting hole at the front of the wings, they appear to have a lot of stock around them. They are tarped in the back yard, and when the weather is good I will get some measurements. Too windy yesterday. They appear to be well made and cared for, and I don't know why they were for sale- no damage except for 4 small (under 2") holes in the ailerons from shipping damage. They are 5 rib. Some stray weight can be taken off them, like an antenna mount, and something that I think is a fancy tie-down attachment. Paint and fabric is very nice. The Millers are sending a patch kit. By the way- I weighed it with wood strips on the rudder and elevator, and an unknown weight of gas in it, maybe 4-5 gallons. Also, the wind was blowing. And the scale read differently every time I bounced it. I just wanted a rough idea how much to trim. Now I'm waiting for weather or parts. Bill Sullivan ________________________________________________________________________________
Subject: Re: 912ULS Mag Drop
Date: Jan 31, 2008
John Hauck wrote: > Gang: > > My idea of why the mag was dropping was correct. > > After oiling the throttle clevis's, changing spark plugs, with no > improvement, I played with the enricher at 4000 rpm while performing the mag > check. Indication was lean condition at 4000 rpm. > > Today, despite the wind and cold, I got the needles raised a notch, which > puts the clip in the bottom groove of the fuel needles. It worked. Now I > am a happy camper once again. > > Proves not all 912 engines are created equal. I never encountered this > problem with my last 912ULS. > > Didn't get to test fly because it was getting late by the time I finished > up. > > These new generation Bing carbs are much easier to get to the top innards of > the carb to get at the fuel needles. The older ones were a little more work > intensive. > > Always feels good to get those little problems solved. > > john h > mkIII Sounds to me more like just some variation in the carbs rather than an engine difference? I've encountered the same thing with the bings on my 2-strokes. Same jetting and atmospheric conditions, but still slightly different resulting mixtures from motor to motor. I just adjusted them as needed.... The bings on the 912 seem to work really well. The plane originally lived at 1500' MSL and now lives at 7000' MSL; all I had to do was put the vent lines into the air filters and lean out the idle mix about 1/2 turn to get a proper looking plug.... BTW, the enrichener is a great debugging tool like you said - I used it to diagnose a carp-in-carb problem after a recent fuel line change. Saves a lot of time and head-scratching ;) LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161543#161543 ________________________________________________________________________________
Date: Jan 31, 2008
My .02... My personal preference nowadays is to be legal and that's always what I suggest to others. OTOH, I try not to be anal retentive about the R&R's especially if they keep me completely grounded with a perfectly good flying machine. I like many of us flew illegally for a long time - I don't regret it because I feel that I used my best judgment and flew only good equipment. But these days I simply prefer to be legal for both safety and "Da Man" reasons. Much as I hate to say it, it's really quite true: many of the R&R' we fly under nowadays came about because someone flew an airplane into the ground. This especially applies to airworthiness; I hate to think of how much of AC 43.13 came about because of crashes and etc. Good designs like the kolb, titan quicksilver, RV, etc are safe designs because someone got in the things and found the bugs. A lot of what has been discovered over the years then comes down to us partially in the regs and partially in AC's like 43.13. Even weight limits have a little sanity to them, the idea behind them being the greater the "commanded kinetic energy" the more qualified the pilot should be. Finally, while I think R&R's can be a good thing, I don't want to live in a police state either. I'd hate to think that the max punishment for the most minimal infraction will always come about and I'll probably always resist that. I'll still bend regs as necessary to insure the safety of the flight or even to enhance the quality of my flying experience within what I consider to be reasonable bounds. But that's just me. As for part 103, that's still being hashed out all these years later and I can see both sides of it. LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161555#161555 ________________________________________________________________________________
Subject: Re: Firestar project main spar attachment
Date: Jan 31, 2008
FWIW, standard design practice is to have a MINIMUM edge distance, measured from the center of the hole to the nearest edge, greater than or equal to 1.5 x hole diameter. For a 5/16 diameter hole the closest edge distance from the center of the hole, according to standard practice, would be 15/32" (.47"). Also important is that there be no sharp edge, nicks etc, where stresses concentrate. Will it fail if slightly less than .47"? Probably not due to design safety factors built into "standard practice". Thom in Buffalo ________________________________________________________________________________
Date: Jan 31, 2008
Being legal is good, and most of us make every effort to follow the spirit of the law. But good judgment and safety must always your primary concern. I have never been ramp checked, these guys talk about Ramp checks, and maybe if you are flying into Oshkosh or Sun and Fun, or some other event you might get ramp checked, but chances are very low that it will you will ever get checked at the small airports that most ultralights fly out of. The other thing you need to take into account is they are probably not going to be weighing planes without cause while doing ramp checks, has anyone ever been weighted in a routine ramp check ??? ( not event related, but standard run of the mill ramp check ) I seriously doubt it... If you have 10 gallons of gas (double the limit), or 2 seats (double the limit), that will stand out like a sore thumb, and is likely to get your a violation on a ramp check, just like driving 110 MPH in a 55 MPH zone will draw attention on the highway (double the limit).... In the case of your single seat statistic, with a 5 gallon tank and a single seat, will not likely generate any any unwanted attention. No one is going to be able to look at you plane and say "its 15 pounds overweight"... So don't let some self righteous individuals tell you to go to an undue amount of work or make your plane less safe, by degrading the performance due to being 6 % overweight. I'm sure since this thread started, every one of these guys has driven 3 MPH over the speed limit. The problem here is, these guys have taken a position publicly on this list, and they are not about to let a new guy like me or anyone else point out that what they are suggesting is nothing short of stupid. We are very fortunate that Richard and a couple others here are not in positions of authority. I can see it now, " sir, you were doing 58 in a 55 zone, I am going to give you a ticket " or " Sir, your plastic fuel tank has bulged and now holds 5.25 gallons of gas, which is 6 % over the limit, I am going to have to violate you ". It does not matter how much they say " the law is the law ", or how how many "reasons" they give, worrying about 3 MPH, or .25 gallons, or even worrying about 15 pounds extra on an ultralight is just plain stupid and anal. How many of these guys do think actually tell their friends to slow down and start self righteously preaching " the law " when they drive 3 MPH over the speed limit using all the same arguments they have been using here in this thread. I'm sure the response they would get would be something to the effect of "stick it where the sun don't shine" or " get out of my car "... Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161566#161566 ________________________________________________________________________________
Date: Jan 31, 2008
It is pretty well known that a longer wingspan results in better performance. By making the wingspan shorter, you will most likely... Reduce Climb Rate Reduce the Glide Ratio Poor performance at high altitude density Very probably reduce cruise speed Increase Takeoff and landing distances Increase stall speed You reduce a lot of safety margins by reducing the wingspan of the plane. There will be some advantages like higher roll rate and a couple others, it might not be worth all the bad effects shorter wings will have. You should research what you are dong and the effects before you do this. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161575#161575 ________________________________________________________________________________
Date: Jan 31, 2008
Lucien, How did you run the vent lines into the Air Filters. Can you post some pictures of that ? I have one vent that is spitting out some fuel, and I would rather not have it going all over the engine. Anyone seen what causes a vent line on the 912-s to spit some fuel, its not much, I cant see it, but its enough to discolor and leave a gooey discoloration where it hits the cylinder. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161579#161579 ________________________________________________________________________________
Date: Jan 31, 2008
Subject: Hmmmmm
*RADAR'S REPLACEMENT? MAGNETIC FIELDS TRACK AIRCRAFT<http://www.avweb.com/eletter/archives/avflash/1043-full.html#197048> * New technology now being studied in Europe can track aircraft by detecting tiny changes in the Earth's magnetic field, according to a recent report in ICTWeb<http://cordis.europa.eu/ictresults/index.cfm/section/news/tpl/article/BrowsingType/Features/ID/89466>. Structures that cause "shadows" for today's radar systems -- a problem for ground surveillance at large, sprawling airports -- do not impair the magnetic field detectors. Recent tests of the system<http://www.ismael-project.net/>in Greece and Germany showed that it could detect 100 percent of the passing aircraft, and pinpointed their location to within 7.5 meters [25 feet], a level of accuracy comparable to most existing air traffic management systems, says researcher Haibin Gao. The system uses an array of small, cheap sensor units, which could be as small as a coin in the future. They can be installed at the entry and exit points of each runway, and would be affordable even for small airports. ________________________________________________________________________________
Date: Jan 31, 2008
The weight of the HKS is about 25 to 30 lb more than a 503 depending on accessories like starter, oil injection gearbox type etc. The HKS is a 60 hp engine thus 8 more than a dual carb dual ignition 503 burns 3 gph running it at 5700 rpms and has electric start a very quiet ignition and alternator (minimal noise in the radio) and starts almost instantly, has a 800 TBO. GB -------- GB MNFlyer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161581#161581 ________________________________________________________________________________
Date: Jan 31, 2008
JetPilot wrote: > Lucien, > > How did you run the vent lines into the Air Filters. Can you post some pictures of that ? I have one vent that is spitting out some fuel, and I would rather not have it going all over the engine. > > Anyone seen what causes a vent line on the 912-s to spit some fuel, its not much, I cant see it, but its enough to discolor and leave a gooey discoloration where it hits the cylinder. > > Mike I'll try to get some pics of what I did ASAP. I used some brass barbs from Lowes to make the fittings, the type used to splice tubing. Barbs on each end with a small ridge in the center. I then drilled holes in the back of the air cleaners, cleaned out the debris and pushed the fitting in up to the ridge. I also smeared a little silicone adhesive to help hold it and seal up any possible leaks. Then pushed the vent lines onto the exposed barb. This leaned out the top end to where it was supposed to be even as high as 10,000' MSL, it was running a little rich at full throttle before that. If you're getting fuel spitting out of the vents, you probably have something plugged up in the carburettor somewhere or it's possible the carb is running over. My 2-stroke Bings would sometimes spit fuel out of the vents if they were running over or needed cleaning. The outside of the carburettor should be totally dry as should the vents...... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161583#161583 ________________________________________________________________________________
Date: Jan 31, 2008
There is a big difference between being 300 Pounds + and trying to pass your plane off as an ultralight, and being only 15 pounds overweight... I have never seen a ramp check, or known anyone that has had a ramp check. I'm sure it happens, but how many get weighed in a standard run of the mill ramp check ( non event or air show related ). Its all about good judgment, if you are a bit overweight, don't fly your ultralight into an ultralight event where there is likely to be ramp checks, and likely to be weighed. If you are so far overweight that it is obviously not plausible as an ultralight, get an N Number... But 15 ( 6% )pounds overweight is a non issue in most cases. Seems that there is a lack of common sense and good judgment by some on this list. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161588#161588 ________________________________________________________________________________
Date: Jan 31, 2008
Subject: Re: Ramp Checks, was Re: Firestar project
At 12:14 PM 1/31/2008, JetPilot wrote: >I have never been ramp checked, these guys talk about Ramp checks, and >maybe if you are flying into Oshkosh or Sun and Fun, or some other event >you might get ramp checked, but chances are very low that it will you will >ever get checked at the small airports that most ultralights fly out of. Seems I've heard of ultralights being weighed at ramp checks at major fly-ins, but I don't know if it was random or only if an airplane "looked" heavy. For most pilots, any thorough ramp check would likely only be if you piss somebody off, usually by what I call "impolite flying". Or, if you're flying to or from an airport that tolerates but doesn't quite "welcome" ultralights, a complaint about some offense (whether real or imaginary) might precipitate a check. An example is the airport I'm on a waiting list for hangar space at. It's 1/3 the distance from my house compared to the ultralight friendly airport I'm currently flying from... the airport owner allows ultralights (though only if the pilot has a license), but the FBO owner hates ultralights and wants no part of them on "his" airport. So far the airport owner's policy goes, but on one occasion the FBO told the pilot of a [registered] Quicksilver GT-400 "the first time I have to go around because you're too slow on final, you're out of here!" Wouldn't be too hard to picture a guy like that calling the FAA and reporting an "overweight" ultralight. -Dana -- Black holes are where God is dividing by zero. ________________________________________________________________________________
Date: Jan 31, 2008
JetPilot wrote: > There is a big difference between being 300 Pounds + and trying to pass your plane off as an ultralight, and being only 15 pounds overweight... > > I have never seen a ramp check, or known anyone that has had a ramp check. I'm sure it happens, but how many get weighed in a standard run of the mill ramp check ( non event or air show related ). > > Its all about good judgment, if you are a bit overweight, don't fly your ultralight into an ultralight event where there is likely to be ramp checks, and likely to be weighed. If you are so far overweight that it is obviously not plausible as an ultralight, get an N Number... > > But 15 ( 6% )pounds overweight is a non issue in most cases. Seems that there is a lack of common sense and good judgment by some on this list. > > Mike Mike, You can't always tell if it's an ultralight or not. Does this look like an ultralight to you? How much do you think it weighs? Ralph -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161598#161598 Attachments: http://forums.matronics.com//files/at_lydia__162.jpg ________________________________________________________________________________
Date: Jan 31, 2008
In a message dated 1/31/2008 12:35:30 P.M. Eastern Standard Time, orcabonita(at)hotmail.com writes: It is pretty well known that a longer wingspan results in better performance. By making the wingspan shorter, you will most likely... Yes Mike, but, What if the wing you are starting with is too long? You are assuming that the original Firestar wing is "The Right Length". As I understand it the original Firestar has almost as much wing area as Your MKIIIX. By your logic you would have to increase your wingspan to almost 60 feet. As far as a longer wing being better, It depends what the mission is. By virtue of the fact that I fly my Firefly with 60 # of float all the time, I Am 60# over weight of a standard Fly. Performance is tremendous. At one point Bryan and I thought about increasing the wingspan a tad but after flying the stock configuration for two years I see no reason to do so. As far as: Reduce Climb Rate ----------- Climbs at over 800 fpm with Floats Reduce the Glide Ratio ----------- Doubt it Poor performance at high altitude density ---------- flies nice at 8000 ft Very probably reduce cruise speed ----------doubt it Increase Takeoff and landing distances ------------Takeoff on Glassy water 150 ft/ Lands on less Increase stall speed ---------------- You might be right here, but the current stall is fine I am not trying to give you a hard time here Mike but it is pretty hard to beat the package that Dennis S and the crew put together. I suggest that you try the stew before you add Salt, The Chef may have gotten it right. Steve Firefly 007/Floats do not archive **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 31, 2008
> If you're getting fuel spitting out of the vents, you probably have something plugged up in the carburettor somewhere or it's possible the carb is running over. > > My 2-stroke Bings would sometimes spit fuel out of the vents if they were > running over or needed cleaning. > > The outside of the carburettor should be totally dry as should the > vents...... > > LS Lucien: Probably that carb plugging up the works and causing the carbs to spit fuel. ;-) john h mklIII ________________________________________________________________________________
Date: Jan 31, 2008
> I have one vent that is spitting out some fuel, and I would rather not > have it going all over the engine. > > Anyone seen what causes a vent line on the 912-s to spit some fuel, its > not much, I cant see it, but its enough to discolor and leave a gooey > discoloration where it hits the cylinder. > > Mike Mike B: You probably have a fuel vapor stand off problem, rather than a float chamber static port blowing fuel on your engine. All engines, two and four stroke, have a little cloud of fuel vapor that stands off the intake of the carb. I don't know why gasoline engines do this, but they do, from a 2 hp B&S to my old 85 hp Ford Flat Head V8. These I can vouch for because, as a kid, I experimented with them. Rotax two strokes are set up to blow the fuel vapor stand off out the air filter because they are oriented perpendicular to the air stream. If you are running conical air filters, they are more supceptible to blowing the fuel vapor off the mouth of the carb and onto your engine since it is a pusher and the aircleaner is sitting right out there in the front of the engine. Sometimes the flat cake pan K&N air filters will cure the problem, but in my case, a pair of air filter covers did the job nicely. I also route the float chamber static tube into the cover between it and the air filter so it will read the same satic pressure as the static port on the lip of the carb. Take care, john h mkIII ________________________________________________________________________________
Subject: Re: Hmmmmm
Date: Jan 31, 2008
Rich In time this could means we just plug in the airport identifier ( CIA) and l et the magnet drag us onto final ? hahahaha Just make damn sure the window =C2-reads to and not from or you could be f aced with one Heathy Head Field hahahahahaha Mark Interesting Technology Rich 8-) -----Original Message----- From: Richard Girard <jindoguy(at)gmail.com> Sent: Thu, 31 Jan 2008 9:07 am Subject: Kolb-List: Hmmmmm RADAR'S REPLACEMENT? MAGNETIC FIELDS TRACK AIRCRAFT New technology now being studied in Europe can track aircraft by detecting tiny changes in the Earth's magnetic field, according to a recent report in ICTWeb. Struc tures that cause "shadows" for today's radar systems -- a problem for ground surveillance at large, sprawling airports -- do not impair the magnetic field detectors. Recent tests of the system in Greece and Germany showed that it could detect 100 percent of the passing aircraft, and pinpointed their location to within 7.5 meters [25 feet], a level of accuracy comparable to most existing air traffic management systems, says researcher Haibin Gao. The system uses an array of small, cheap sensor units, which could be as small as a coin in the future. They can be installed at the entry and exit points of each runway, and would be affordable even for small airports. ________________________________________________________________________ aol.com ________________________________________________________________________________
Date: Jan 31, 2008
Please just drop it. As the lists DH, "Designated Hitman", :-) you just refuse to quit. You make it sound like others are suggesting we turn our wing struts down in a lathe in order to make our planes lighter. Dennis Rowe ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Thursday, January 31, 2008 12:14 PM Subject: Kolb-List: Re: Firestar project > So don't let some self righteous individuals tell you to go to an undue > amount of work or make your plane less safe, by degrading the performance > due to being 6 % overweight. I'm sure since this thread started, every > one of these guys has driven 3 MPH over the speed limit. The problem here > is, these guys have taken a position publicly on this list, and they are > not about to let a new guy like me or anyone else point out that what they > are suggesting is nothing short of stupid. > > We are very fortunate that Richard and a couple others here are not in > positions of authority. I can see it now, " sir, you were doing 58 in a > 55 zone, I am going to give you a ticket " or " Sir, your plastic fuel > tank has bulged and now holds 5.25 gallons of gas, which is 6 % over the > limit, I am going to have to violate you ". > > It does not matter how much they say " the law is the law ", or how how > many "reasons" they give, worrying about 3 MPH, or .25 gallons, or even > worrying about 15 pounds extra on an ultralight is just plain stupid and > anal. > > How many of these guys do think actually tell their friends to slow down > and start self righteously preaching " the law " when they drive 3 MPH > over the speed limit using all the same arguments they have been using > here in this thread. I'm sure the response they would get would be > something to the effect of "stick it where the sun don't shine" or " get > out of my car "... > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you > could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=161566#161566 > > > -- > 1/30/2008 8:51 PM > > ________________________________________________________________________________
Date: Jan 31, 2008
>> BTW, the enrichener is a great debugging tool like you said - I >> used it to diagnose a carp-in-carb problem after a recent fuel line >> change. Saves a lot of time and head-scratching ;) >> >> LS BB/Gang: Yea, how did the carp get in there? If he won't plug up a carb, nothing will. john h mkIII ________________________________________________________________________________
Date: Jan 31, 2008
JetPilot wrote: > > It is pretty well known that a longer wingspan results in better performance. By making the wingspan shorter, you will most likely... > > Reduce Climb Rate > Reduce the Glide Ratio > Poor performance at high altitude density > Very probably reduce cruise speed > Increase Takeoff and landing distances > Increase stall speed > > You reduce a lot of safety margins by reducing the wingspan of the plane. There will be some advantages like higher roll rate and a couple others, it might not be worth all the bad effects shorter wings will have. You should research what you are dong and the effects before you do this. > > Mike From: "John Hauck" <jhauck(at)elmore.rr.com>
Date: Jan 31, 2008
> Probably that carb plugging up the works and causing the carbs to spit fuel. > ;-) Gang: Blew that one, didn't I. Misspelled "carp". Drat'it. john h mkIII ________________________________________________________________________________
Date: Jan 31, 2008
Wow Ralph, that looks like a skinny FS! ...... I guess 254# My builders manual advised that my FS would not make the 103 weight unless built with a free air cooled Rotax motor, light fabric, minimal paint, no brakes, plastic wheels ...... bottom line it was not happening. I don't know of any ramp checking going on at fly-ins, but I know the FAA investigates anytime a plane has a un-planned off the airport or bad airport landing. If you have flying credentials (ie: Pilots license) be prepared to be grounded if you ruled to be in violation of the FAR's. By the way, I have been "ramp checked" twice. They checked the AC documents and mine. The 1st time was awful, the second was no problem with lessons learned from the first time. Neither were done at my home field but when I was traveling. (both were in factory made planes) If you want the details, send me a note. Mike, I get your point that it is OK to be kinda fat as long as you carry the weight well. If it looks like a duck, quacks like a duck; it is a duck. I guess we have a different opinion here. The reality is if my plane looks to fit the 103 rule, and I want it to "pass" as a UL, I must be willing to produce false documentation and tell lies. I have an aversion to both. You can build a legal UL, but a 255# airplane without a registration is called an unregistered A/C. You can call it whatever you want, but it does not change anything. I am glad I had the opportunity to get my fat little FS set up as an E-LSA. It was not UL 103 legal, never would be, and after the SP rules were a reality, there was no more gray area to hide in. Fly safe, Jim -------- Jim O'Day Fargo, ND Firestar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161629#161629 Attachments: http://forums.matronics.com//files/kolb_72007_medium_131.jpg ________________________________________________________________________________
Date: Jan 31, 2008
Ralph, it depends on how technical you want to be and how much you know about that tank. If it holds more than 5 gallons, not much more, but more, is enough to kick on the "Not an Ultralight" Light. Per AC 103-7, 19. *Maximum Fuel Capacity of a Powered Ultralight Vehicle*. The maximum fuel capacity for a powered ultralight vehicle is 5 U.S. gallons. Any powered ultralight with fuel tank(s) exceeding this capacity is ineligible for operation as an ultralight vehicle. a. *Determination of Fuel Capacity*. The total volume, including all available space for usable and unusable fuel in the fuel tank is the total fuel capacity. The fuel in the lines, pump, strainer, and carburetor is not considered in a calculation of total volume. b. *Use of an Artificial Means to Control Capacity*. (1) Tanks which have a permanent standpipe or venting arrangement to control capacity are permitted, but may be subject to demonstration of the capacity if there is any reason to doubt that the arrangement is effective. (2) A temporary, detachable, or voluntarily- observed method for restricting fuel capacity, such as a "fill-to" line is not acceptable. That tiny area above the 5 gallon line on the tank could be a tip off to a "by the book" inspector. He or she has only to look at the tank and ask you to demonstrate the capacity. I'm not an inspector, I have no vested interest in the ultralight argument. At the "Air Festival" in Wellington, KS last September two "volunteers" from the Wichita FSDO showed up, in addition to the fellow who was assigned to the show (and really hacked off the guy who was assigned, I might add), and started ramp checking. The president of my EAA chapter was one of those given a "stern warning" by these two. His offense? The gas tanks on his RV-6 weren't properly labeled. On Jan 31, 2008 12:24 PM, Ralph B wrote: > > > JetPilot wrote: > > There is a big difference between being 300 Pounds + and trying to pass > your plane off as an ultralight, and being only 15 pounds overweight... > > > > I have never seen a ramp check, or known anyone that has had a ramp > check. I'm sure it happens, but how many get weighed in a standard run of > the mill ramp check ( non event or air show related ). > > > > Its all about good judgment, if you are a bit overweight, don't fly > your ultralight into an ultralight event where there is likely to be ramp > checks, and likely to be weighed. If you are so far overweight that it is > obviously not plausible as an ultralight, get an N Number... > > > > But 15 ( 6% )pounds overweight is a non issue in most cases. Seems that > there is a lack of common sense and good judgment by some on this list. > > > > Mike > > > Mike, > > You can't always tell if it's an ultralight or not. Does this look like an > ultralight to you? How much do you think it weighs? > > Ralph > > -------- > Ralph B > Original Firestar > N91493 E-AB > 21 years flying it > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=161598#161598 > > > Attachments: > > http://forums.matronics.com//files/at_lydia__162.jpg > > ________________________________________________________________________________
Date: Jan 31, 2008
It does not matter how much they say " the law is the law ", or how how many "reasons" they give, worrying about 3 MPH, or .25 gallons, or even worrying about 15 pounds extra on an ultralight is just plain stupid and anal. >> Oh Yeah! And how does `Well officer, I only shot him a little bit` sound as a defence. Cheers Pat (away for the next two weeks) ________________________________________________________________________________
Subject: Your minimum hp take off and climb?
Date: Jan 31, 2008
What is the minimum hp for take off and climb in a Kolb? http://picasaweb.google.com/imhisson2/MinimumHp ________________________________________________________________________________
Date: Jan 31, 2008
Much as I hate to say it, it's really quite true: many of the R&R' we fly under nowadays came about because someone flew an airplane into the ground. >> Thats what happened in the UK. We had a good thing going which the authorities treated merely as an extension of hang gliding. Then there were a series of fatalities and Authority swooped. Luckily we had Anne Welch, a long time gliding enthusiast who had helped fight the CAA to keep the gliding movements training, safety, licensing etc in its own hands. She realised that the microlight movement was in a similar position to gliding in the 30`s and became the Chairman of the fledgeling organisation. She did to a great extent what she and her husband had done for the Gliding fraternity and kept us `comparitively` rule free.. Pat ________________________________________________________________________________
Date: Jan 31, 2008
Hey=C2- If =C2-they can make rules WE the people didnt vote for why can WE the peo ple make them earn their Pay checks? ahahahaha Hmmm Now =C2-I wonder how many feet of Tubing i'll need to make 5 Gallons hahahahaha 8-) Mark -----Original Message----- From: Richard Girard <jindoguy(at)gmail.com> Sent: Thu, 31 Jan 2008 2:28 pm Subject: Re: Kolb-List: Re: FAR 103.3 Inspection requirements Ralph, it depends on how technical you want to be and how much you know abou t that tank. If it holds more than 5 gallons, not much more, but more, is en ough to kick on the "Not an Ultralight" Light. Per AC 103-7, 19. Maximum Fuel Capacity of a Powered Ultralight Vehicle.=C2- The maximum fuel capacity for a powered ultralight vehicle is 5 U.S. gallons. Any power ed ultralight with fuel tank(s) exceeding this capacity is ineligible for op eration as an ultralight vehicle. =C2-=C2-=C2- a. Determination of Fuel Capacity. The total volume, incl uding all available space for usable and unusable fuel in the fuel tank is t he total fuel capacity. The fuel in the lines, pump, strainer, and carbureto r is not considered in a calculation of total volume. =C2-=C2-=C2- b. Use of an Artificial Means to Control Capacity. =C2-=C2-=C2- =C2-=C2-=C2- (1) Tanks which have a permanent stand pipe or venting arrangement to control capacity are permitted, but may be su bject to demonstration of the capacity if there is any reason to doubt that the arrangement is effective. =C2-=C2-=C2- =C2-=C2-=C2- (2) A temporary, detachable, or volunt arily- observed method for restricting fuel capacity, such as a "fill-to" li ne is not acceptable. That tiny area above the 5 gallon line on the tank could be a tip off to a " by the book" inspector. He or she has only to look at the tank and ask you t o demonstrate the capacity. I'm not an inspector, I have no vested interest in the ultralight argument. At the "Air Festival" in Wellington, KS last September two "volunteers" from the Wichita FSDO showed up, in addition to the fellow who was assigned to t he show (and really hacked off the guy who was assigned, I might add), and s tarted ramp checking. The president of my EAA chapter was one of those given a "stern warning" by these two. His offense? The gas tanks on his RV-6 were n't properly labeled. On Jan 31, 2008 12:24 PM, Ralph B wrote: JetPilot wrote: > There is a big difference between being 300 Pounds + and trying to pass yo ur plane off as an ultralight, and being only 15 pounds overweight... > > I have never seen a ramp check, or known anyone that has had a ramp check. =C2-I'm sure it happens, but how many get weighed in a standard run of th e mill ramp check ( non event or air show related ). > > Its all about good judgment, if you are =C2-a bit overweight, don't fly your ultralight into an ultralight event where there is likely to be ramp ch ecks, and likely to be weighed. =C2- If you are so far overweight that it is obviously not plausible as an ultralight, get an N Number... > > But 15 ( 6% )pounds overweight is a non issue in most cases. =C2-Seems t hat there is a lack of common sense and good judgment by some on this list. > > Mike Mike, You can't always tell if it's an ultralight or not. Does this look like an u ltralight to you? How much do you think it weighs? Ralph -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161598#161598 ________________________________________________________________________ aol.com ________________________________________________________________________________
Date: Jan 31, 2008
Good luck Bill, its nice to be appreciated. . i have no opinions about holes in spars. There are plenty on the list who are really very expert indeed. You will have to sort out which ones they are. Whatever you do, don`t believe them all. Some are , shall we say, not so clewed up as others. cheers# Pat. ________________________________________________________________________________
Date: Jan 31, 2008
JetPilot wrote: > > Being legal is good, and most of us make every effort to follow the spirit of the law. But good judgment and safety must always your primary concern. > > So don't let some self righteous individuals tell you to go to an undue amount of work or make your plane less safe, by degrading the performance due to being 6 % overweight. > Mike I should add that Mike touches on a good point here, and an area where I'd willingly bend the regs (though I still wouldn't openly suggest this to others). There are cases where rules aren't appropriate and can actually impair safety. the deal with part 103 weight is, arguably, one of them. I.e. removing good metal wheels or a safety belt in order to get at or below 254lbs. In a case like this I'm with Mike - being a "little bit pregnant" is the prudent thing to do because it's a safety issue for the plane. But that's just me and how I work..... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161674#161674 ________________________________________________________________________________
Date: Jan 31, 2008
John Hauck wrote: > >> BTW, the enrichener is a great debugging tool like you said - I > > > > used it to diagnose a carp-in-carb problem after a recent fuel line > > > change. Saves a lot of time and head-scratching ;) > > > > > > LS > > > > > > > BB/Gang: > > Yea, how did the carp get in there? If he won't plug up a carb, nothing > will. > > john h > mkIII Oops, sorry about the carp.... no fish involved but "crap" for sure...... That's where I learned to finally sand down the sharp edges on any barbed fittings during a fuel line change... and to thoroughly flush the new assemblies before installation and otherwise be operating-room clean when messing with fuel lines...... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161675#161675 ________________________________________________________________________________
Date: Jan 31, 2008
Subject: Re: Cable thimbles
Richard Girard wrote: > Ed, I use my Felco F-9 cable cutters to trim the ears. I cut from the > inside of the thimble out and there is no burr left to dress where the > cable touches. > If you haven't made cables before, go to AC 43.13-1B "Aircraft > Inspection, Repair and Alteration Acceptable Methods, Techniques, and > Practices" pages 7-32 and 7-33 for instruction on how to use Nicopress > ovals. Use the proper tool and inspect each swage with the proper gauge. > > Rick Girard > > On Jan 28, 2008 7:51 AM, Richard Pike > wrote: > > > > > Cut them off, dress them smooth with a small round file where the > cable > passes over the cut. > > Richard Pike > MKIII N420P (420ldPoops) > > Edward Bonsell wrote: > > > > > > > Hi All, > > > > I'm making a new set of rudder cables. To those of you that made > > cables did you leave the ears on the thimbles, or did you cut or > grind > > them off? > > > > Thanks, > Guy's, Why are you cutting off the ears on your thimbles when making cables? Am I missing something here? I didn't have any problem making up my cables with the ears of the thimbles intact. Is there some mechanical advantage to removing them and if so, why do they make them with the ears in the first place? I found that they keep the nicopress sleeve at the proper distance from the loop to prevent pinching. Willing to learn!! Terry - Firefly #95 785 hr.'s ________________________________________________________________________________
Date: Jan 31, 2008
> > Why are you cutting off the ears on your thimbles when making cables? Am I missing something here? I didn't have any problem making up my cables with the ears of the thimbles intact. Is there some mechanical advantage to removing them and if so, why do they make them with the ears in the first place? I found that they keep the nicopress sleeve at the proper distance from the loop to prevent pinching. Willing to learn!! > > Terry - Firefly #95 785 hr.'s > AC 43.13 says you can trim the ears if needed and I always do - I've found the thimble can be held in place more firmly this way and the cable is in firmer contact with the thimble ends where they go into the swage. I made some fairly ok loops with untrimmed ends, but they always were a little loosey-goosey compared to trimmed ones...... and I'm ultra-paranoid about thimbles popping out of cable ends especially on control cables... had it happen, so..... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161692#161692 ________________________________________________________________________________
Subject: Re: Your minimum hp take off and climb?
Date: Jan 31, 2008
Bob, Perhaps he is just doing a "go around", rather than a take off. It would probably take a 40 Horse Rotax to get that kind of altitude in that short a distance with a Firefly, Whada ya think? ; ^) On Jan 31, 2008, at 3:12 PM, Eugene Zimmerman wrote: > What is the minimum hp for take off and climb in a Kolb? > > http://picasaweb.google.com/imhisson2/MinimumHp > > ________________________________________________________________________________
Date: Jan 31, 2008
The ears on a cable thimble are a vestige of the days of the five tuck splice. I find that leaving the ears on always makes the loop about the thimble loose. Cutting off the ears pulls the thimble ends together when the Nico sleeve is swaged. Try both methods and use the one that you like. Either is acceptable. Rick On Jan 31, 2008 6:02 PM, TK wrote: > Richard Girard wrote: > > Ed, I use my Felco F-9 cable cutters to trim the ears. I cut from the > inside of the thimble out and there is no burr left to dress where the cable > touches. > If you haven't made cables before, go to AC 43.13-1B "Aircraft Inspection, > Repair and Alteration Acceptable Methods, Techniques, and Practices" pages > 7-32 and 7-33 for instruction on how to use Nicopress ovals. Use the proper > tool and inspect each swage with the proper gauge. > > Rick Girard > > On Jan 28, 2008 7:51 AM, Richard Pike wrote: > > > > > Cut them off, dress them smooth with a small round file where the cable > > passes over the cut. > > > > Richard Pike > > MKIII N420P (420ldPoops) > > > > Edward Bonsell wrote: > > > > > > > > > Hi All, > > > > > > I'm making a new set of rudder cables. To those of you that made > > > cables did you leave the ears on the thimbles, or did you cut or grind > > > them off? > > > > > > Thanks, > > > Guy's, > > Why are you cutting off the ears on your thimbles when making cables? Am > I missing something here? I didn't have any problem making up my cables > with the ears of the thimbles intact. Is there some mechanical advantage to > removing them and if so, why do they make them with the ears in the first > place? I found that they keep the nicopress sleeve at the proper distance > from the loop to prevent pinching. Willing to learn!! > > Terry - Firefly #95 785 hr.'s > > * > > * > > ________________________________________________________________________________
Date: Jan 31, 2008
At 07:58 PM 1/31/2008, Richard Girard wrote: >The ears on a cable thimble are a vestige of the days of the five tuck >splice. I find that leaving the ears on always makes the loop about the >thimble loose... Or you could just do five tuck splices instead of nico's on all your cables... :) -Dana -- "Very funny, Scotty. Now beam down my clothes." ________________________________________________________________________________
Date: Jan 31, 2008
Subject: Re: Not really kolb related
Ray, You mentioned Bernoulli...is that the same gent that furnishes only maybe 10% of the wing's lift? I'm a firm Newton guy! regards, Bob N. FireFly 070 Old Kolb http://www.angelfire.com/rpg/ronoy/ do not rchive ________________________________________________________________________________
Date: Jan 31, 2008
Subject: Minimum horsepower take off?
Eugene, Or maybe the glider was just taking the horse out fer a run, like a dawg ona leash? regards, Bob N. FireFly 070 Old Kolb http://www.angelfire.com/rpg/ronoy/ do note archive ________________________________________________________________________________
Date: Jan 31, 2008
On Jan 31, 2008, at 9:06 PM, russ kinne wrote: > No time for this foolishness! Sorry Russ, Ya could have fooled me. You took the possum's bait. What moves your plane forward, the wheels or the prop? ________________________________________________________________________________
Date: Jan 31, 2008
That would be the blood donor method, thanks, but no. ;-) Rick On Jan 31, 2008 7:19 PM, Dana Hague wrote: > > At 07:58 PM 1/31/2008, Richard Girard wrote: > >The ears on a cable thimble are a vestige of the days of the five tuck > >splice. I find that leaving the ears on always makes the loop about the > >thimble loose... > > Or you could just do five tuck splices instead of nico's on all your > cables... :) > > -Dana > > -- > "Very funny, Scotty. Now beam down my clothes." > > ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Subject: Re: FAR 103.3 Inspection requirements
Date: Jan 31, 2008
Mike, Ramp checks are like car accidents: they happen when you least expect. I admire the restraint of 99% of the Kolb list. Your pomposity in answering some of the recent posts is tiring at best. Reminds me of what my Dad used to say, "An empty wagon makes the most noise". Please quit the insults and the patronizing tone. Your constant derision ("Seems that there is a lack of common sense and good judgment by some...") is insulting and immature. Try and listen to some of the responses, and take them to heart. 100 other pilots can't all be wrong.... At any rate, I've had ramp checks at small, uncontrolled airfields as well as large airports, and know of other airman who have been imposed upon likewise. Have had the boys show up unannounced in a corporate flight department, and in a local small-town FBO. But then, that's been over the course of 30+ years of flying. And the feds ARE concerned about W&B, as well as all other required aircraft documentation. I even had one Fed ask to be taken up, until I asked how he'd be paying for the trip around the pattern. The big thing about being at proper weight is as much about insurance and liability as legality. Try having even a tiny scrape with an aircraft, the insurer will try and prove you violated some reg, forget about the Feds. Had a bird strike a couple years ago, the insuring agent asked 10 times the questions as the FAA guys. Ed in JXN MkII/503 ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Thursday, January 31, 2008 12:50 PM Subject: Kolb-List: Re: FAR 103.3 Inspection requirements > > There is a big difference between being 300 Pounds + and trying to pass > your plane off as an ultralight, and being only 15 pounds overweight... > > I have never seen a ramp check, or known anyone that has had a ramp check. > I'm sure it happens, but how many get weighed in a standard run of the > mill ramp check ( non event or air show related ). > > Its all about good judgment, if you are a bit overweight, don't fly your > ultralight into an ultralight event where there is likely to be ramp > checks, and likely to be weighed. If you are so far overweight that it > is obviously not plausible as an ultralight, get an N Number... > > But 15 ( 6% )pounds overweight is a non issue in most cases. Seems that > there is a lack of common sense and good judgment by some on this list. > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you > could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=161588#161588 > > > ________________________________________________________________________________
Date: Jan 31, 2008
Hey Bob, Yeah, soggy Newtons (fig?...) aren't much fun. Ed in JXN ----- Original Message ----- From: Bob Noyer To: kolb-list(at)matronics.com Sent: Thursday, January 31, 2008 9:02 PM Subject: Re: Kolb-List: Re: Not really kolb related Ray, You mentioned Bernoulli...is that the same gent that furnishes only maybe 10% of the wing's lift? I'm a firm Newton guy! regards, Bob N. FireFly 070 Old Kolb http://www.angelfire.com/rpg/ronoy/ do not rchive ________________________________________________________________________________
Date: Feb 01, 2008
Good timing on trimming the cable ears. I was just fixing the tailwheel assembly. and one of the steering cables had the thimble all crumpled and twisted. The bare cable had worn a groove in the tube almost all the way to the edge. I brazed a couple of washers on the tube, and would have put the thimbles back the way they were. Nice save, guys. John- your carb problem is actually a malfunctioning bilge pump. Check it, and the carp won't get up to the air filter. Bill Sullivan ________________________________________________________________________________
Date: Feb 01, 2008
Rick Dip the strand ends on solder before you start to splice. Less colorful but more comfortable. On Jan 31, 2008, at 10:05 PM, Richard Girard wrote: > That would be the blood donor method, thanks, but no. ;-) > > Rick > > On Jan 31, 2008 7:19 PM, Dana Hague wrote: > > At 07:58 PM 1/31/2008, Richard Girard wrote: > >The ears on a cable thimble are a vestige of the days of the five > tuck > >splice. I find that leaving the ears on always makes the loop > about the > >thimble loose... > > Or you could just do five tuck splices instead of nico's on all your > cables... :) > > -Dana > > ________________________________________________________________________________
Date: Feb 01, 2008
I imagine any kind of fish in your carburetor could be a problem! ----- Original Message ---- From: lucien <lstavenhagen(at)hotmail.com> Sent: Thursday, January 31, 2008 3:17:36 PM Subject: Kolb-List: Re: 912ULS Mag Drop John Hauck wrote: > >> BTW, the enrichener is a great debugging tool like you said - I > > > > used it to diagnose a carp-in-carb problem after a recent fuel line > > > change. Saves a lot of time and head-scratching ;) > > > > > > LS > > > > > > > BB/Gang: > > Yea, how did the carp get in there? If he won't plug up a carb, nothing > will. > > john h > mkIII Oops, sorry about the carp.... no fish involved but "crap" for sure...... That's where I learned to finally sand down the sharp edges on any barbed fittings during a fuel line change... and to thoroughly flush the new assemblies before installation and otherwise be operating-room clean when messing with fuel lines...... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161675#161675 ________________________________________________________________________________
Date: Feb 01, 2008
Ralph B wrote: > > JetPilot wrote: > > There is a big difference between being 300 Pounds + and trying to pass your plane off as an ultralight, and being only 15 pounds overweight... > > > > I have never seen a ramp check, or known anyone that has had a ramp check. I'm sure it happens, but how many get weighed in a standard run of the mill ramp check ( non event or air show related ). > > > > Its all about good judgment, if you are a bit overweight, don't fly your ultralight into an ultralight event where there is likely to be ramp checks, and likely to be weighed. If you are so far overweight that it is obviously not plausible as an ultralight, get an N Number... > > > > But 15 ( 6% )pounds overweight is a non issue in most cases. Seems that there is a lack of common sense and good judgment by some on this list. > > > > Mike > > > Mike > > You can't always tell if it's an ultralight or not. Does this look like an ultralight to you? How much do you think it weighs? > > Ralph Well this is a fat ultralight that looks skinny because I left the covering off the rear part of the cage. This is one of the earliest Firestars (S/N #49), and was designed to be an ultralight. Even with a parachute that would give it another 24 lbs, it still would not have made the 276 lb weight limit. I have since added a bigger engine (447), streamlined struts, bigger wheels, nice seat cushion, strobe lights, and still has the 5-gallon main tank. It doesn't have brakes and weighs in at 319 lbs. Looks can be deceiving. It's an aircraft with a tail number. -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161815#161815 ________________________________________________________________________________
Subject: Re:
Date: Feb 01, 2008
Mike, Most of what you say are the effects of shortening the wingspan are true, except for the slower cruise speed. This argument raged on for quite a while on the Titan Yahoo Group. Most of the Tornados come with the 23.5' length wing. The one I had was the 20' wing. I had told the group that my Titan with 20' wing and 80 hp 912UL was as fast or faster than the more common ones with 23.5' wing and 100 hp 912ULS. This created all kinds of arguments with explanations why a shorter wing could not possibly be as fast as the longer wing. The basis for the arguments was that due to the shorter wingspan, the angle of attack would have to be greater to support the same weight at a given speed, and thus be more draggy than the longer wing. There is a smidgeon of truth in that but the effect of the tiny bit higher AOA is much smaller than the REDUCED drag due to the shorter span. I finally go the opportunity to do a side-by-side comparison with a 23.5' wing Tornado w/ 912ULS engine vs. my 80 hp short wing Tornado. Flying weight were within 30 lbs of the same. It turns out that my Vh was identical to the other's Vh. We both had in-flight adjustable props and set them for 5500 rpm at full throttle. My 80 hp short wing was the same speed as the 100 hp long wing. Also, mine did not have wheel pants and the other did. Thom in Buffalo ________________________________________________________________________________
From: "KOLB AIRCRAFT" <customersupport(at)tnkolbaircraft.com>
Subject: Re: Kolbra price list
Date: Feb 01, 2008
LUCIEN, SORRY TO BE SO LATE WITH MY REPLY, BUT SEND ME YOUR ADRESS AND I WILL SEND YOU A PRICE SHEET ON THE KOLBRA THANKS DONNIE ----- Original Message ----- From: "lucien" <lstavenhagen(at)hotmail.com> Sent: Monday, December 31, 2007 9:54 AM Subject: Kolb-List: Kolbra price list > > Hi all, > > Er forgive my ignorance, but does anyone have a current price sheet for the Kolbra handy? I can't seem to find one on the kolb factory site, though there appears to be one for the MK III and the others. > > Doing some thinkin, pencil pushin and calkeelatin and need a detailed price list before my 6th grade education runs out of steam. > > Just show me where to click on the site (or just email Travis)? > > Thanks, > > LS > > -------- > LS > FS II > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=155164#155164 > > ________________________________________________________________________________
Subject: ramp check
Date: Feb 01, 2008
How many of us have seen "ramp checks" first hand? Is this common in some parts of the country? >>>>>>>>>>>>>>>>>>>>>>>>>>>>> I was visiting with an old sage,,, he had been flying since he was a pup, His dad used to run the airport which he took over.... Anyway,,, he said that the only time he was ever ramp checked was at monument valley, a faa sort was on vacation, and wanted to be able to write off the vacation expenses, so did a bit of work while he was away from the office. Boyd ________________________________________________________________________________
Subject: Test Flight
Date: Feb 01, 2008
Gang: Turned out to be a beautiful day after all. Sun is shining, a little windy, and the temp is 49F. I got the mag drop problem solved couple days ago. Prior to that, had been experiencing a little abnormal vibration, i.e., a vibration that had not been there before. Suspect the lean in mid-range condition was probably contributing to that also. Murphy is a slick character. All this started after I returned from out West after an absence of two months. The mkIII had stood silently waiting to fly since the first of October, three months prior. Before I flew I pulled the gear box, resealed it, which meant pulling the prop. Changed the oil and filter, and away we went. About the same time the weather had gradually gotten colder. Each time I flew it, I was detecting a slight mag drop on one side, while also feeling a little vibration in the airplane that had not been there before. Really got the old imagination working, but in the wrong direction, until I started experimenting with the enricher. I ran out of day light when I raised the needles to the last notch, but did get to do a couple mag checks. The 912ULS got crisp and light, just like she always has. Hopefully, I got rid of the vibration, but if not it may be a blade out of pitch a tad. That will also do it and is most likely the gremlin. Hope not cause I don't want to repitch in the cold. However, wouldn't hurt to lighten the pitch just a little to get a little more rpm out of it on takeoff and back up to hitting the red line at 5,500 rpm during WOT, straight and level flight. That'll have me zipping along at 95 mph WOT, cruising at 85 mph. That's fast enough to get me anywhere I want to go in the North American Continent. Take care, john h mkIII ________________________________________________________________________________
Subject: Re: ramp check
Date: Feb 01, 2008
I've been ramp checked only once. I was delivering our Cherokee 140 we sold to its new owner in French Valley, California. After an IFR night flight landing at Hays, KS (home of Rans Aircraft) the FAA rep greeted me after shutting down in the tie-down area. His only interest was paperwork for the airplane. He was not interested in my paperwork, medical and pilot certificates, only the airplane, which were all in order. Quick and painless and the FAA rep was very courteous and cordial. Thom in Buffalo -------- Thom Riddle N221FA Allegro 2000 912UL N197BG FS1/447 -------------------- Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. - Buddha Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161923#161923 ________________________________________________________________________________
Date: Feb 01, 2008
Subject: VG 's
The February 2008 issue of EAA Sport Pilot & Light-Sport Aircraft, has an article about the Savage, which is shown on the front cover. The article is written by Dan Johnson and in it there is a favorable reference to using VG's. Might be of some interest to those that are putting them on Kolbs. Bill Varnes Original Kolb FireStar Audubon NJ **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 01, 2008
At 07:18 PM 1/31/2008, you wrote: >It's not the prop blast. The plane is pulling itself through the >air. The only thing different than a normal takeoff is the >rotational speed of the wheels. The rest of the plane doesn't know >it is on a belt. > >Bryan D If your plane was on an 8,000 ft runway and had a 100 mph tailwind pushing it 100 mph down the runway, Could you take off down wind. Of course you could. Same difference. ________________________________________________________________________________
Date: Feb 01, 2008
if a 100 mph wind is pushing you 100 mph your airspeed is 0 I don't think y ou'd go very far.> Date: Fri, 1 Feb 2008 18:41:32 -0500> To: kolb-list@matr onics.com> From: possums(at)bellsouth.net> Subject: Re: Kolb-List: Re: Not rea outh.net>> > At 07:18 PM 1/31/2008, you wrote:> >It's not the prop blast. T he plane is pulling itself through the > >air. The only thing different tha n a normal takeoff is the > >rotational speed of the wheels. The rest of th e plane doesn't know > >it is on a belt.> >> >Bryan D> > If your plane was on an 8,000 ft runway and had a 100 mph tailwind pushing> it 100 mph down t he runway, Could you take off down wind. Of course you> could. Same differe ==> > > ________________________________________________________________________________
Date: Feb 01, 2008
On Feb 1, 2008, at 6:41 PM, possums wrote: > If your plane was on an 8,000 ft runway and had a 100 mph tailwind > pushing > it 100 mph down the runway, Could you take off down wind. Of course > you > could. Same difference. Nope Not me! I'd die of a heart attack long before I reached flying speed. ________________________________________________________________________________
Date: Feb 01, 2008
At 07:02 PM 2/1/2008, you wrote: >if a 100 mph wind is pushing you 100 mph your airspeed is 0 I don't >think you'd go very far. > I guess I should have said that - "could you take off if you used your throttle"? ________________________________________________________________________________
Date: Feb 01, 2008
If your plane was on an 8,000 ft runway and had a 100 mph tailwind pushing it 100 mph down the runway, Could you take off down wind. Of course you could. Same difference. That would mean your speed THROUGH THE AIR would be zero? How could a takeoff be possible? Are you saying the plane would accelerate to 140 or so? Then it might take off, if the wheels stayed together -- On Feb 1, 2008, at 6:41 PM, possums wrote: > If your plane was on an 8,000 ft runway and had a 100 mph tailwind > pushing > it 100 mph down the runway, Could you take off down wind. Of course > you > could. Same difference. ________________________________________________________________________________
Date: Feb 01, 2008
I don't care if you could take off, it's the taxiing into position I'd like to see. Rick G. On Feb 1, 2008 6:06 PM, Eugene Zimmerman wrote: > > > On Feb 1, 2008, at 6:41 PM, possums wrote: > > > If your plane was on an 8,000 ft runway and had a 100 mph tailwind > > pushing > > it 100 mph down the runway, Could you take off down wind. Of course > > you > > could. Same difference. > > Nope > Not me! > > I'd die of a heart attack long before I reached flying speed. > > ________________________________________________________________________________
Date: Feb 01, 2008
A friend of mine was ramp checked just last weekend. Here is his story: **************************** Dennis (I didnt catch his name) of the FAA was there to oversee the waiver received to fly the MIA balloon they tether each year. After I landed he immediately approached to check me out. After showing his Federal ID, he asked to see my pilots license, aircraft registration and the airworthiness paper. There was no problem at all with our meeting. He did what was expected and I had all my ducks lined up. He was friendly , so was I and we chatted a bit. End of story - Karey. -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161988#161988 ________________________________________________________________________________
Date: Feb 02, 2008
Subject: covering
I only covered my FSII up to the top of the fuel tanks. If you only have the short windshield, covering up to the wings will cause a lot of drag, I would think. With a full enclosure, it wouldn`t be as big of a deal. Covering up to the wings will make it harder to add fuel and may cause a problem with fumes in the cockpit. To each his own, however, I like the way I covered mine. My 2 cents worth. Lanny FSII N598LF ________________________________________________________________________________
Date: Feb 02, 2008
Subject: Re: Winter flight/ streamlined struts
I know I picked up about 6mph just by streamlining the struts. That is a lot of drag - a round tube that long as opposed to a teardrop shaped strut. There is almost nothing better you can do to a stock plane to lose drag that streamlining the lift struts. Plus - I lost the weird vibration and worry of watching the lift struts go thru their little "shake rattle & roll" routine out there. I'm sure it didn't hurt anything, but I just didn't like it. Jeremy could do the math for you. I just know that it works. ________________________________________________________________________________
Date: Feb 02, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: Firestar Project
Open question for everyone. I have to repair about five small holes in the ailerons. I brought the wing into the living room. I ran Ellery's test of using MEK to double check the finish. Mek would not dissolve the paint, but did dissolve the vinyl glove I was wearing. The paint is Aerothane. I have the book and kit from the Millers, but I would appreciate any and all tips on repairs. I have to use a brush for all stages, as I have nowhere safe to spray isocyanates. The neighborhood is too close to risk airbornes. I am now going down to the drug store for latex gloves. The guy at the hardware store thought his were latex, but they weren't marked. Luckily I only got a couple of pairs. I hope I got the right color- Madrid Red. I don't care what kind of light I used before ordering, there were four really close reds. Bill ________________________________________________________________________________
Date: Feb 02, 2008
It's all relative. If you're flying cross country & your 80mph airplane gets a 20 mph tailwind, you're going 100 over the ground, right? Just translate that to flying really close to the ground, as in your takeoff roll. As you bring the power up, the prop will make you accelerate in the relative wind. You'll still take of at the same *airspeed*, but you'll have a really high groundspeed. That's why we are taught to take off into the wind instead of downwind. Charlie David Key wrote: > if a 100 mph wind is pushing you 100 mph your airspeed is 0 I don't > think you'd go very far. > > > Date: Fri, 1 Feb 2008 18:41:32 -0500 > > To: kolb-list(at)matronics.com > > From: possums(at)bellsouth.net > > Subject: Re: Kolb-List: Re: Not really kolb related > > > > > > At 07:18 PM 1/31/2008, you wrote: > > >It's not the prop blast. The plane is pulling itself through the > > >air. The only thing different than a normal takeoff is the > > >rotational speed of the wheels. The rest of the plane doesn't know > > >it is on a belt. > > > > > >Bryan D > > > > If your plane was on an 8,000 ft runway and had a 100 mph tailwind > pushing > > it 100 mph down the runway, Could you take off down wind. Of course you > > could. Same ======================= ________________________________________________________________________________
Date: Feb 02, 2008
To answer Richard Girard's question about the hole margins on my forward wing attachment point- the front attachment point appears to be a fabricated piece of junior "I" beam, just under 3" high. The 3 holes are no closer than 1/4" to the edge, and spaced about 1/2" apart. The web is about 5/32" thick, as are the upper and lower flanges. The flanges are about 1 1/8" wide. This appears to be plenty of stock for the purpose. I don't know why- maybe the builder had trouble setting the wing angle, or simply wanted them adjustable. I can't tell by looking at or in the holes which one was commonly used. I don't think that it would make a lot of difference, as long as both sides are set the same. Bill ________________________________________________________________________________
Date: Feb 02, 2008
It's good to hear that I'm not the only one with that vibration. How did streamlining the struts get rid of the vibration - did you use the extruded aluminum struts? If so, where is the best place to buy those for a Firestar II? I am also considering using the PVC covers that Craig mentioned - would they help with the vibration? Where is a good place to get those? Thanks much Dan G. 503 F2 Tucson possums wrote: > I know I picked up about 6mph just by streamlining the struts. > That is a lot of drag - a round tube that long as opposed to > a teardrop shaped strut. There is almost nothing better you can > do to a stock plane to lose drag that streamlining the lift struts. > Plus - I lost the weird vibration and worry of watching the > lift struts go thru their little "shake rattle & roll" routine out there. > I'm sure it didn't hurt anything, but I just didn't like it. > Jeremy could do the math for you. I just know that it works. ________________________________________________________________________________
Subject: Re: Regular Unleaded
Date: Feb 02, 2008
Six months ago I called the Distributor for Exxon/Mobil in Coeur d'Alene, Idaho and the owner confirmed they do not add ethanol locally for Exxon/Mobil stations. He did say thay added 10% to the regular for a local independent gas station and sold it as mid-grade at the same price as their regular. Adding a minimum of 10% gets them tax breaks and they are able to sell the oxygenated regular as mid-grade for the same price as their regular unleaded. He said fuel with 10% ethanol or more is required to be labeled at the pump in Idaho. He also said nobody in his area (N Idaho) adds -------- Jim N. Idaho Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162143#162143 ________________________________________________________________________________
Date: Feb 03, 2008
Subject: Re: Firestar Project
Bill, for refinishing, if you're in a relatively warm area, so the paint will flow before it sets, use a foam roller to apply enough coats to satisfy your eye that it has completely covered the primer. Let it dry and use wet or dry sandpaper to remove any stippling and polish with compound to match the local area. Rick On Feb 2, 2008 9:56 PM, william sullivan wrote: > To answer Richard Girard's question about the hole margins on my forward > wing attachment point- the front attachment point appears to be a fabricated > piece of junior "I" beam, just under 3" high. The 3 holes are no closer than > 1/4" to the edge, and spaced about 1/2" apart. The web is about 5/32" thick, > as are the upper and lower flanges. The flanges are about > 1 1/8" wide. This appears to be plenty of stock for the purpose. I don't > know why- maybe the builder had trouble setting the wing angle, or simply > wanted them adjustable. I can't tell by looking at or in the holes which one > was commonly used. I don't think that it would make a lot of difference, as > long as both sides are set the same. > Bill > > * > > * > > ________________________________________________________________________________
Date: Feb 03, 2008
Bill, should have added it's the little 3" foam roller you want. They can be found at any box store and have a nice radius on the edge so the paint feathers out. Also a warning, if you use Smooth Prime be sure to use adequate protection for skin and respiratory contact unless you are absolutely sure you aren't sensitive to the cross linker. My friend Wayne has gotten so sensitive to it he had to farm out the priming of his LongEZ and even then broke out in blisters whenever he came in contact with any that wasn't completely cured. It could be dry to the touch yet still outgassing and he would get a reaction. Rick On Feb 3, 2008 8:57 AM, Richard Girard wrote: > Bill, for refinishing, if you're in a relatively warm area, so the paint > will flow before it sets, use a foam roller to apply enough coats to satisfy > your eye that it has completely covered the primer. Let it dry and use wet > or dry sandpaper to remove any stippling and polish with compound to match > the local area. > > Rick > > > On Feb 2, 2008 9:56 PM, william sullivan wrote: > > > To answer Richard Girard's question about the hole margins on my > > forward wing attachment point- the front attachment point appears to be a > > fabricated piece of junior "I" beam, just under 3" high. The 3 holes are no > > closer than 1/4" to the edge, and spaced about 1/2" apart. The web is about > > 5/32" thick, as are the upper and lower flanges. The flanges are about > > 1 1/8" wide. This appears to be plenty of stock for the purpose. I don't > > know why- maybe the builder had trouble setting the wing angle, or simply > > wanted them adjustable. I can't tell by looking at or in the holes which one > > was commonly used. I don't think that it would make a lot of difference, as > > long as both sides are set the same. > > Bill > > > > * > > > > * > > > > > ________________________________________________________________________________
Date: Feb 03, 2008
I cleaned up the first hole. Only trouble was I didn't use a sharp enough scribe- I was afraid to damage the fabric. Now that I know, it will go easier. Foam roller is a good tip- I think I have one. I just started getting the live version of the List. Got tired of waiting. Bill ________________________________________________________________________________
Date: Feb 03, 2008
At 12:45 AM 2/3/2008, you wrote: How did streamlining the struts get rid of the vibration - did you use the extruded aluminum struts? No - I just had some metal (T6061 I think) bent for me at a shop with an 8 foot brake. Had them cut it to shape, then roll both edges a little to partially go around the strut. After that - bend it in the break. I riveted it on the struts and with the rolled edges, it fits pretty tight. Been on there for 10 years. It stopped all the vibration and hardly weighs anything. But there are all kinds of ways to do it. Many are more aerodynamic than mine, but most weigh a lot more. I would think that they all would stop the vibration. ________________________________________________________________________________
Date: Feb 03, 2008
Subject: Kolb-List Rotax E Box
What motors will an E Box fit provision 8 only or will it fit a provision 4 .... Thanks ! Dave ************** Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548) ________________________________________________________________________________
Subject: New use for ladders. You got to see this!
Date: Feb 03, 2008
http://www.pouduciel.com/ http://pouchel.aliceblogs.fr/blog/constructeurspouchel (http://www.putfile.com/pic.php?img=7608061) (http://www.putfile.com/pic.php?img=7608054) (http://www.putfile.com/pic.php?img=7608062) (http://www.putfile.com/pic.php?img=7608058) (http://www.putfile.com/pic.php?img=7608057) Wish I could read it! I think it french. This is just amazing! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162261#162261 ________________________________________________________________________________
Subject: Re: New use for ladders. You got to see this!
Date: Feb 03, 2008
and a video http://www.youtube.com/watch?v=ZsFKowEzSiw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162263#162263 ________________________________________________________________________________
Subject: Re: Now I know what I want for Christmas.
Date: Feb 03, 2008
All of that modern tech and look what they still use. A glass tube bank indicator. Gotta love it. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162265#162265 Attachments: http://forums.matronics.com//files/glass_cockpit_309.bmp ________________________________________________________________________________
Date: Feb 03, 2008
Subject: login ....
at the Kolb website on the homepage there's a spot where you can login and i "assume" chat with whoever is online. i also assume you need to be registered to be able to login. my question is - how do i get registered? how do i get a password? ........... tim Looking for last minute shopping deals? ________________________________________________________________________________
Subject: Re: login ....
Date: Feb 03, 2008
Hi Tim This is not really a chat room but a forum for posting ideas and questions about Kolbs. To join you just go to the login feature at the top of the Matronics page and sign up. You enter your own password. Once you log in you can post messages onto the Forums. When you first log in you will see all the forums for the different Aircraft, and Cars too. Then you just select the one you want to enter and go... Hope This Helps Carlos G Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162276#162276 ________________________________________________________________________________
Date: Feb 04, 2008
I started patching the small holes in the wings. I did as Ellery recommended, and my only comment is to make sure the scribe is sharp, and drag at an angle. I was worried about the strength of the Dacron, so I was cautious at first. Also, I had never used the MEK for anything and did not know the evaporative rate. Turns out it is not a worry. I trimmed torn material from the hole with a small pair of scissors, and used a pad of paper towel about 2" square and 4 layers thick for the MEK. It takes a couple of minutes to soften the glue, so be patient. I used a pocket knife with a rounded blade to pick the paint off. First hole went slow, and the other two went right along. I put the glue on the wing and let it set up, held the patch in place and moistened with MEK on one end. Let it harden, stretch, and keep going. I love this stuff. Another tip- let somebody else take the candy thermometer out of the packaging. Then you can blame them when it drops on the floor. Bill Sullivan ________________________________________________________________________________
Subject: 912 maint.
Date: Feb 04, 2008
For those who may have missed this: http://www.aero-news.net/news/sport.cfm?ContentBlockID=e712b936- da94-4396-966c-1d4757aa58b6&Dynamic=1 BB ________________________________________________________________________________
Subject: Re: covering
Date: Feb 04, 2008
mdnanwelch7(at)hotmail.co wrote: > Bart, > > I just recently covered my fuselage, and only covered up to the top of the tanks. I am going to finish the rest of the way up to the bottom of the wings with thin Lexan. FYI, I have a full enclosure MkIII. > > How did you enclose the back area of your MK III, the flat area in the back that faces the prop. Can you post some pictures ? I have enclosed mine, but am still planning on fairing the back end with aluminum like John H did on his. That big flat area has to be creating some drage and maybe even disturbing the airflow for the tips of the prop in that area. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162312#162312 ________________________________________________________________________________
Date: Feb 04, 2008
Not Kolb related but this is a takeoff on the French "Flying Flea" or 'pou de ciel' design from way back, 30's? Website is spelled pouduciel and pouchel; dunno where 'putfile' comes in Ladders is a joke, if it ever flew the wind-noise would be fearsome! On Feb 3, 2008, at 10:38 PM, grantr wrote: > > > http://www.pouduciel.com/ > http://pouchel.aliceblogs.fr/blog/constructeurspouchel > > (http://www.putfile.com/pic.php?img=7608061) > (http://www.putfile.com/pic.php?img=7608054) > (http://www.putfile.com/pic.php?img=7608062) > (http://www.putfile.com/pic.php?img=7608058) > (http://www.putfile.com/pic.php?img=7608057) > > Wish I could read it! I think it french. > > This is just amazing! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=162261#162261 > > ________________________________________________________________________________
Date: Feb 04, 2008
Mike, For the moment I just wrapped the end of the fuselage with fabric. Since my engine/prop is removed, I don't know the clearance for building a fairi ng, yet. My intention is to build either an aluminum or fiberglass fairing, once t he prop is replaced. To be honest, I'm not real sure how much clearance th ere should be, between the fairing trailing edge and the prop blades. Any recommendations, you'ze guys?? Here's an "expertise" question for the really smart guys. I know the con ventional wisdom for building a fairing at the rear of the fuselage (the 6" wide flat area) would be to make it simetrical...in other words, just make a "vee", centered on the flat area. BUT!! Has anyone given any thought to off-setting the trailing edge of the fairing significantly to one edge? Like this artist's rendition (ha ha): I I I I Fairing --> I I I I I I I I I I I ___<_____ How did you enclose the back area of your MK III, the flat area i n the back that faces the prop. Can you post some pictures ? > > I have enclosed mine, but am still planning on fairing the back end with aluminum like John H did on his. That big flat area has to be creating some drage and maybe even disturbing the airflow for the tips of the prop in th at area. > > Mike ________________________________________________________________________________
Date: Feb 04, 2008
Well, so much for my "artist's rendition!! This "rich text" email style evidently doesn't allow me to type figures in a clear area of the page. (It just slides everything over to the left. What I was trying to portray was a "vee" fairing that had the trailing edge even with one side...not in the center. My thinking is, as a propeller swings close to the fairing it may slam air against one edge of the fairing. But if one edge was canted to one side, creating a "more" sloped edge slightly ahead of the blades, it would seem to me this would be a more logical design. Let me try to show this idea once more. I'll use dots, to keep from having averything slide against the left. This would be an overhead view, looking down on the propeller swinging past the fairing. ......I.......I ......I......I ......I.....I ......I....I ......I...I ......I..I ......I.I ......I . . -------<--<--<--<--<-- _________________________________________________________________ Need to know the score, the latest news, or you need your Hotmail-get your "fix". http://www.msnmobilefix.com/Default.aspx ________________________________________________________________________________
Date: Feb 04, 2008
My thinking is, as a propeller swings close to the fairing it may slam air against one edge of the fairing. Mike W Mike W: Seems like some 4130 tabs welded to the rear verical fuselage tubes would have been ideal for attaching a sheet metal or fiberglass fairing. Already got the fabric on though. ;-( I had mine covered, flown 100 hours, when the fabric fairing I had originally designed and fabricated got beat to death by the prop. I didn't have any choice but drill the vertical tubes to rivet the aluminum fairing in place. Don't forget the tube seal. Mine has performed well. I think I would design and build the tail fairing straight. Over the years I have done a lot of experimentation with stuff, attempting to overcome adverse yaw in the mkIII. Of all the experiments I have done, an oversized rudder trim tab works best. All the other stuff was a waste of good time and effort. john h mkIII ________________________________________________________________________________
Date: Feb 04, 2008
Interesting idea, makes sense that there will be rotating air just in front of the prop at that point, offsetting to one side would compensate for that. How much, it could be a lot, or barely measurable, I have no idea. I don't know if I would want to answer all the questions about why I built the back of my airplane is " Crooked " [Wink] Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162348#162348 ________________________________________________________________________________
Date: Feb 04, 2008
Subject: Trailer suited for transporting a Mark lll Classic.
I have purchased a Kolb Mark lll in Florida and have to haul it to the Eastern part of Canada. Interested in buying a trailer to transport this craft. Know of anyone who might have a suitable trailer (preferable a box style) located on the east coast of the U.S. ________________________________________________________________________________
Subject: Re: Trailer suited for transporting a Mark lll Classic.
From: "John H Murphy" <mailjohnmurphy(at)gmail.com>
Date: Feb 04, 2008
I believe the Haulmark 24' trailer will do what you want. You should be able to get one on the East Coast for under $7K. My Firestar fits great in mine with 6 or more feet to spare. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162362#162362 ________________________________________________________________________________
From: "Aaron Gustafson" <agustafson(at)chartermi.net>
Date: Feb 04, 2008
I need to get a pair of MK3 wings and a tail section from North Carolina to Michigan. If anybody is traveling that way, let me know. Maybe we can benefit each other somehow. Aaron Gustafson Iron Mountain MI > I have purchased a Kolb Mark lll in Florida and have to haul it to the > Eastern part of Canada. Interested in buying a trailer to transport this > craft. Know of anyone who might have a suitable trailer (preferable a box > style) located on the east coast of the U.S. ________________________________________________________________________________
Subject: Kip Laurie Around???
Date: Feb 04, 2008
Hey Kolbers, Is Kip Laurie from Atlanta area still on the list. Tried his website and got nothing. Wanted to download some of his beautiful in-flight pictures. If anyone has any info, let me know, Tim Gherkins FSII ________________________________________________________________________________
Date: Feb 04, 2008
Subject: Re: Ultrastar Update
At 05:31 PM 2/4/2008, jb92563 wrote: >Ran it at full throttle for a few minutes and observed about 1425 EGT and >420 CHT. Not sure what normal would be....any ideas? Max CHT should be 400F Max EGT should be 1275F Best power EGT is 1200F The EGT probe is supposed to be 1" from the manifold flange gasket. You really only need gauges in the #1 (rear) cylinder (unless you're running dual carbs) as that one runs hotter. Mine is located farther away, where the two pipes join, and reads higher... but the CHT is lower, the engine runs OK and the plugs look fine so I tend to distrust the gauge. -Dana -- To Be Old And Wise You Must First Be Young And Stupid ________________________________________________________________________________
Subject: MK3 parts
Date: Feb 04, 2008
I'm looking for some parts to put together a MK3. Here are a few questions if anyone can guide me. 1. Is there any place other (cheaper) than Kolb to get a fuselage tube? 2.Has anyone done a major repair on a cage and have any info or sugestions. Or should I build one from scratch? Anyone have any info on tubing diameters and thicknesses 3. I believe there have been some gear leg options other than the 7075 stock ones. Tell me if you can. 4.Are there some places better than others for obtaining Polyfiber products ie. fabric, paint etc. I built a FS2 in 95 and put 440 hours on it. Last June I flew my scratch built Zenith 601 but I miss being able to look straight down so gotta build! I appreciate any help you can give me 'on list' or private agustafson(at)chartermi.net Aaron Gustafson Iron Mountain Michigan ________________________________________________________________________________
Date: Feb 04, 2008
Subject: Re: MK3 parts
Aaron, I've looked for the 6" diameter tube used on the Mk.3 without success. I had to buy a 5" tube for another pod and boom airplane in 2006. Got it from Wick's, it was $400(!!!), and I stopped and picked it up as I was coming back from a trip so there was no packing or shipping. 5" was also the biggest size Wick's carried. Just checked their 2008 catalog and 5" is still $32.84 a foot and it's still the largest they carry. Rick On Feb 4, 2008 7:40 PM, Aaron Gustafson wrote: > agustafson(at)chartermi.net> > > I'm looking for some parts to put together a MK3. Here are a few questions > if anyone can guide me. > > 1. Is there any place other (cheaper) than Kolb to get a fuselage tube? > 2.Has anyone done a major repair on a cage and have any info or > sugestions. > Or should I build one from scratch? Anyone have any info on tubing > diameters > and thicknesses > 3. I believe there have been some gear leg options other than the 7075 > stock > ones. Tell me if you can. > 4.Are there some places better than others for obtaining Polyfiber > products > ie. fabric, paint etc. > > I built a FS2 in 95 and put 440 hours on it. Last June I flew my scratch > built Zenith 601 but I miss being able to look straight down so gotta > build! > > I appreciate any help you can give me 'on list' or private > agustafson(at)chartermi.net > > Aaron Gustafson Iron Mountain Michigan > > ________________________________________________________________________________
Date: Feb 04, 2008
Hey Guys: Check with Travis at Kolb. 5 and 6 inch tubes in prime condition are very difficult to obtain by TNK. Most of it get dinged during rough handling and shipping. Once they were close to shutting down because the quality of the tubing was not good enough for building airplanes. The tubing is used primarily for irrigation pipe. It is tough and last a long time for the farmer. Some of their 5 and 6 inch tubing is not of cosmetic and commercial quality for kitting, but satisfactory quality for Kolb aircraft. My mkIII has three 6" blem tubes for tail boom and main spars. Seem to be working well, despite some minor dings and dimples here and there. Maybe you can get Travis to give you a reduced price on some of this tubing. Worth a phone call. john h mkIII Aaron, I've looked for the 6" diameter tube used on the Mk.3 without success. Rick ________________________________________________________________________________
Date: Feb 04, 2008
Thanks for the idea and especially the photos. That's a very ingenious solution- light and simple, and looks like you get 90 percent of the benefit of a full airfoil. That would be perfect for my purposes. Seems like that would also be a slick way to streamline the aft end of the aileron torque tubes (like Jack Hart did on his Firefly), provided there is enough prop clearance. Dan G 503 F2 Tucson possums wrote: > No - I just had some metal (T6061 I think) bent for me at a shop with > an 8 foot brake. > Had them cut it to shape, then roll both edges a little to partially > go around the strut. After that - bend it in the break. I riveted it on > the struts and with the rolled edges, it fits pretty tight. Been on > there for 10 years. > It stopped all the vibration and hardly weighs anything. But there are > all kinds of > ways to do it. Many are more aerodynamic than mine, but most weigh a > lot more. > I would think that they all would stop the vibration. ________________________________________________________________________________
Date: Feb 04, 2008
Mike, For aerodynamic purposes, it's best to minimize the transition angles that the air has to follow - if the angle is too great, the air flow will separate (as in wing stall) and you will loose the benefit of the fairing. In the case below, the angle on the right side might be a bit steep, depending on how long your fairing is. For a given length, the shallowest angle would be achieved by a symmetrical fairing. When I worked on pneumatic aircraft systems, we tried to keep angles of sharp transitions (i.e. the angle from one surface to the next along a streamline) to less than 7 degrees, but that was probably conservative. The prop clearance you need highly depends on the prop. The IVO prop needs a lot of clearance because it flexes so much. (I think they recommend at least 5"). Also, as you pointed out, the airflow near the prop is somewhat complicated, so I think you would want some separation in order to minimize vibration due to interaction of the prop and airframe. Dan G 503 F2 Tucson Mike Welch wrote: > What I was trying to portray was a "vee" fairing that had the trailing edge even with one side...not in the center. My thinking is, as a propeller swings close to the fairing it may slam air against one edge of the fairing. But if one edge was canted to one side, creating a "more" sloped edge slightly ahead of the blades, it would seem to me this would be a more logical design. > >Let me try to show this idea once more. I'll use dots, to keep from having averything slide against the left. >This would be an overhead view, looking down on the propeller swinging past the fairing. > >......I.......I >......I......I >......I.....I >......I....I >......I...I >......I..I >......I.I >......I > ________________________________________________________________________________
Date: Feb 04, 2008
Subject: Firestar project
Another item for beginners: I heat shrank 3 patches today, each about 6" square. My first time on this. Even without coatings, they are nice and tight- they feel just as good as anywhere else on the aileron. I used a Black and Decker iron, and calibrated with a candy thermometer. I didn't have heat sink compound, so I used a pad made of a folded bath towel covered by 4 layers of paper towels. I angled it so that the tip of the thermometer was against the iron, and almost no air got in. Worked great, but I was cautious and kept the heat a couple of degrees low. I found out the number scale on the iron has nothing to do with the temperature. Ironed with the tip only, and took my time. First shrink smoothed out the glue and edge real nice, and tightened up quite a bit. Second time got it nice and firm. Nothing to be afraid of, but take your time. Took a little over an hour, working casually. Can't work on it Tuesday, life is getting in the way. Keep the advice coming guys- I do appreciate it very much. Bill ________________________________________________________________________________
Date: Feb 05, 2008
At 07:25 PM 2/4/2008, jb92563 wrote: >Are those numbers the Max from Cuyuna manual, or from your own engine? > >I guess looking at the plugs should give an idea to what is happening as well. > >I wonder if a couple minutes running is enough to get an indication on the >plugs? Ray, the numbers I gave are from the Cuyuna manual. I don't know how much running time is necessary to read the plugs, but it can't hurt to have a look. Also check what main jet is in your carb, and where the needle is; you might need to go bigger and/or move the needle clip down. -Dana -- "Very funny, Scotty. Now beam down my clothes." ________________________________________________________________________________
Date: Feb 05, 2008
Ray: Are you running the correct prop pitch? Two stroke tuning in an airplane is based on correct prop loading as the number one item. If it is incorrect, everything on down the line, jets, needles, and plugs, with also be incorrect. I find the best way to get an unknown engine back in line is put everything in the carb back where it belongs, and insure jetting and needles are correct size. Also insure the spark plug is the correct heat range. Insure the correct prop and pitch is installed. For a Cuyuna ULII02, I believe that would have been a Jim Culver 50X30. That was a perfect prop for the US with ULII02. Hope you all are operating those engines with air filters. john h mkIII > Sounds like I am running to lean if those numbers are right. > Are you using a filter on your carb? > > -------- > Ray ________________________________________________________________________________
Date: Feb 05, 2008
I wish Craig would sell the wing strut fairings, and even more so, the big engine cowl he made !!! I would be first in line for that. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162539#162539 ________________________________________________________________________________
Date: Feb 05, 2008
> I seem to recall that the Ul202 engine was succeptible to case > leaks..Needed re torqueing once in a while.. A very old engine model at > any rate..15 years old or older? Herb Herb: The ULII02 was a good engine. Had CDI ign, which was much easier to maintain than the point ign Rotax's. If one did not retorque the cylinders every 100 hours or more, they were prone to leak at the cylinder base gasket. This was probably caused by the small amount of metal that remained after the engine cases were lightened from the 430 to the ULII02. In an US the engine had to be dropped from the engine mount to get at the bolts to torque them. Because of the extra work involved, most of us would fly them until they started leaking, then end up replacing cyl base gaskets and head gaskets. Never had any big problems with the ULII02, but was plagued with little ones that were annoying and would occasionally put one on the ground. It was all a big learning curve, getting out of turbine powered helicopters that had lots of folks and lots of money available for parts and repairs, into a little two stroke that had to be maintained by a guy anxious to fly more than anxious to spend all time on the ground fixing stuff. john h mkIII ________________________________________________________________________________
Date: Feb 05, 2008
John Yeah! I am old and good also...:-) I had a UL202 on the US that I had... Very surprised at the ease of starting.. Nearly fell backward, expecting to have to pull and pull and pull .. Started just about the time I pulled the rope a foot or so.. Ran strong. Herb At 04:50 PM 2/5/2008, you wrote: > > > > I seem to recall that the Ul202 engine was succeptible to case >>leaks..Needed re torqueing once in a while.. A very old engine >>model at any rate..15 years old or older? Herb > > >Herb: > >The ULII02 was a good engine. Had CDI ign, which was much easier to >maintain than the point ign Rotax's. > >If one did not retorque the cylinders every 100 hours or more, they >were prone to leak at the cylinder base gasket. This was probably >caused by the small amount of metal that remained after the engine >cases were lightened from the 430 to the ULII02. In an US the >engine had to be dropped from the engine mount to get at the bolts >to torque them. Because of the extra work involved, most of us >would fly them until they started leaking, then end up replacing cyl >base gaskets and head gaskets. > >Never had any big problems with the ULII02, but was plagued with >little ones that were annoying and would occasionally put one on the >ground. It was all a big learning curve, getting out of turbine >powered helicopters that had lots of folks and lots of money >available for parts and repairs, into a little two stroke that had >to be maintained by a guy anxious to fly more than anxious to spend >all time on the ground fixing stuff. > >john h >mkIII > > ________________________________________________________________________________
Date: Feb 05, 2008
At 10:37 AM 2/5/2008, jb92563 wrote: >Sounds like I am running to lean if those numbers are right. >Not sure how to tune it for richer, would the needle clip go in the next >lower notch to make it more rich? >Or do I change needles to make it richer.....lower needle number is richer? >I'll take a look and see what needle number I am running tonight. >Dana, what needle number are you running? >Are you using a filter on your carb? Ray, yes, it sounds like it's lean. Moving the needle clip down makes the needle go up, which makes it richer... but only in the midrange. I don't know what needle number I have; I don't think many people change them. Full throttle mixture is controlled by the main jet, which _does_ need to be changed according to the seasons or altitude: ULII-02, Cuyuna exhaust, Mikuni VM32 carburetor Altitude 8000 250 240 230 220 210 6000 270 260 250 240 230 4000 290 280 270 260 250 2000 310 300 290 280 270 Sea Level 330 320 310 300 290 Temp. =B0F 0-20=B0 20-40=B0 40-60=B0 60-80=B0 80-100=B0 Mine had a 300 main jet, which I changed to a 310 for winter flying (below 40=B0 and it's too cold to fly!). On a couple of hot days last summer, I stuck with the 300 jet (all I had at the time) but I had the needle clip in the top notch. -Dana -- The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson ________________________________________________________________________________
Date: Feb 05, 2008
try this site. http://www.metalsdepot.com/products/alum2.phtml?page=rndtube&LimAcc=%20&aident Now I am not sure that its any cheaper than Kolb or that it is the right wall thinkness, it may be thicker. If you are going to weld your own H brace then it doesn't matter and you will get a stronger and a bit heavier Tube. Ron (Arizona) =========================================== ---- Richard Girard wrote: ============ Aaron, I've looked for the 6" diameter tube used on the Mk.3 without success. I had to buy a 5" tube for another pod and boom airplane in 2006. Got it from Wick's, it was $400(!!!), and I stopped and picked it up as I was coming back from a trip so there was no packing or shipping. 5" was also the biggest size Wick's carried. Just checked their 2008 catalog and 5" is still $32.84 a foot and it's still the largest they carry. Rick On Feb 4, 2008 7:40 PM, Aaron Gustafson wrote: > agustafson(at)chartermi.net> > > I'm looking for some parts to put together a MK3. Here are a few questions > if anyone can guide me. > > 1. Is there any place other (cheaper) than Kolb to get a fuselage tube? > 2.Has anyone done a major repair on a cage and have any info or > sugestions. > Or should I build one from scratch? Anyone have any info on tubing > diameters > and thicknesses > 3. I believe there have been some gear leg options other than the 7075 > stock > ones. Tell me if you can. > 4.Are there some places better than others for obtaining Polyfiber > products > ie. fabric, paint etc. > > I built a FS2 in 95 and put 440 hours on it. Last June I flew my scratch > built Zenith 601 but I miss being able to look straight down so gotta > build! > > I appreciate any help you can give me 'on list' or private > agustafson(at)chartermi.net > > Aaron Gustafson Iron Mountain Michigan > > -- kugelair.com ________________________________________________________________________________
Date: Feb 06, 2008
Subject: Re: 5 in. Tubing - Reposting a old Post - Might be useful
>Date: Wed, 05 Sep 2001 00:53:52 -0500 >To: kolb-list(at)matronics.com >Subject: Re: Kolb-List: 5 in. Tubing >Sender: owner-kolb-list-server(at)matronics.com >Reply-To: kolb-list(at)matronics.com > > >If I recall right the source they used for the larger dia. tubing was an >aluminum company in AZ. Yes it was irrigation pipe. I used to have the >name of it and the source of the rivets they used. As for strength why >change what has withstood the test of time and proven its self to >work. Kolb are good airplanes, why mess with what isn't broke. > > > > >Just wanted to make a couple comments about the 5 in. boom / spar tube that > >comes up every so often, I believe the tube referred to as Irrigation pipe > >is 6063-T8 and not T6 , I have a couple 10 ft. lengths and took a sample to > >work for a simple tensile break test, sample was 5 in. O.D. X .050 in. wall > >and it broke at between 37,000 and 41,000 PSI, not too bad for water pipe . > > The cost of this pipe or tube is approx. $5.00 per ft. and it is sold in > >20 ft. lengths , Wick's was mentioned as a source , they sell 5 in. X .065 > >wall for approx. $20.00 per ft. and weight is 30% more also,comes in 12ft. > >length. > > Am not an engineer but have always wondered why the Kolb > attach point for > >wing / strut was at the mid point of wing panel and not at 66% as most AC > >are located, would appear that H section would allow spar to elongate under > >heavy load , have also thought that H section could be extended to a length > >of 36 or 40 in. and made into a truss to spread load over larger area. > > Guess one can"t argue with success but after smashing some of this tube > >to pieces , it still looks fragile . > > Thanks for listening > > Phil Lohiser > > EAA 12873 > > ________________________________________________________________________________
Date: Feb 06, 2008
Ron wrote: > try this site. > > http://www.metalsdepot.com/products/alum2.phtml?page=rndtube&LimAcc=%20&aident > > Now I am not sure that its any cheaper than Kolb or that it is the right > wall thinkness, it may be thicker. If you are going to weld your own H > brace then it doesn't matter and you will get a stronger and a bit heavier > Tube. > > Ron (Arizona) Ron others, The 6 inch tubing on that web sight has a wall thickness twice as thick as the tubing on my Mk-3, (1/8 ") not only would the H sections not fit inside, but the weight differance would be pretty substantial. I have to think using that as a tail tube would move your CG pretty far aft. I would stick with what Homer came up with. Denny Rowe ________________________________________________________________________________
Date: Feb 06, 2008
I got a new tail wheel from Kolb, and put it in the tail wheel carrier. When I tried to put the carrier in the suspension yoke, the wheel hits the lower flange of the yoke. I will have to grind the flange to fit, and install the pivot bolt from the bottom up. There is enough stock, so strength is not a problem. Then I will have to re-install the wheel and axle shaft. The new wheel appears to be the same as the old- casting marks, etc. Maybe the builder turned the wheel down to fit? Does the builder have to make the carrier from scratch, out of tubing? Mine appears to be well made, maybe factory. Were the original wheels five inch, or smaller? Anyone know? Bill Sullivan ________________________________________________________________________________
Date: Feb 06, 2008
I just looked at the picture that was posted of the Ultrastar, photo taken from the rear. I noticed that it has the same tail wheel brackets I have on the Firestar, but has a different wheel. It has a red wheel, and more room. Mine is black, and fresh from Kolb- a five inch. Is the red one stock, and what diameter is it? Bill ________________________________________________________________________________
Date: Feb 06, 2008
> Now I am not sure that its any cheaper than Kolb or that it is the right wall thinkness, it may be thicker. > > Ron (Arizona) Ron: Can do much better with Travis, plus receive the correct size. Looks like the thinnest wall is .125 which is twice the that of the Kolb tail boom. john h mkIII ________________________________________________________________________________
Date: Feb 06, 2008
Thanks to all who replied. I found that indeed the best deal and the proper stuff is directly from Travis at Kolb. I will go there. Thanks again! Still looking for a cage , Damaged etc. Or a complete aircraft, wrecked or what ever and cheap. Maybe one that's in someone's way! Aaron G. ________________________________________________________________________________
Date: Feb 06, 2008
> > >In the meantime, here are some pics. > Ray, Looks like your Ultrastar has negative dihedral. Should make it a fun aircraft to fly. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Feb 06, 2008
Subject: Re: Firestar project
Bill, Looks like a scooter wheel. Here's a pic of the stock one from my Mk.3 . Rick On Feb 6, 2008 7:05 AM, william sullivan wrote: > I just looked at the picture that was posted of the Ultrastar, photo > taken from the rear. I noticed that it has the same tail wheel brackets I > have on the Firestar, but has a different wheel. It has a red wheel, and > more room. Mine is black, and fresh from Kolb- a five inch. Is the red one > stock, and what diameter is it? > Bill > > * > > * > > ________________________________________________________________________________
Date: Feb 06, 2008
Sent too soon. It's 5" in diameter, fine print says it's made in Sherbrooke, Quebec, Canada. You can see the clearance to the swivel bolt. I measured the TW on the FS and it's the same as this. Rick On Feb 6, 2008 9:10 AM, Richard Girard wrote: > Bill, Looks like a scooter wheel. Here's a pic of the stock one from my > Mk.3. > > Rick > > > On Feb 6, 2008 7:05 AM, william sullivan wrote: > > > I just looked at the picture that was posted of the Ultrastar, photo > > taken from the rear. I noticed that it has the same tail wheel brackets I > > have on the Firestar, but has a different wheel. It has a red wheel, and > > more room. Mine is black, and fresh from Kolb- a five inch. Is the red one > > stock, and what diameter is it? > > Bill > > > > * > > > > * > > > > > ________________________________________________________________________________
Date: Feb 06, 2008
From: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
Dan G wrote: << It's good to hear that I'm not the only one with that vibration. How did streamlining the struts get rid of the vibration >> Dan, and other interested Kolbers - Airflow downstream of any strut with circular cross section creates an eddy current called a "Von Karmann street." This flow phenomenon is an eddy that curls back and forth in alternating directions, similar to what you see in the stream of smoke rising from a cigarette. You can also see the Von Karmann street effect in rivers that meander along a flat countryside - the water course appears to curl alternately from one direction to the other. In airflow, these rapidly-oscillating eddy currents translate into a vibration, and this is what we encounter with un-streamlined struts. Dennis Kirby Amazed to even remember this stuff since my Aero-101 courses 25 years ago, in Cedar Crest, NM ________________________________________________________________________________
Date: Feb 06, 2008
Hey Dennis, How's the rebuild going?? Taken any photos lately? What's the timeframe to getting your plane back in the air? Mike Welch MkIII> Subject: Kolb-List: Re: Winter flight/ streamlined struts > Date: We MDA/AL" > > > > > Dan G wrote: << It's good t o hear that I'm not the only one with that> vibration. How did streamlining the struts get rid of the vibration >>> > Dan, and other interested Kolber s -> > Airflow downstream of any strut with circular cross section creates an> eddy current called a "Von Karmann street." This flow phenomenon is an> eddy that curls back and forth in alternating directions, similar to> what you see in the stream of smoke rising from a cigarette. You can> also see the Von Karmann street effect in rivers that meander along a> flat countrys ide - the water course appears to curl alternately from one> direction to t he other. > > In airflow, these rapidly-oscillating eddy currents translate into a> vibration, and this is what we encounter with un-streamlined strut s.> > Dennis Kirby> Amazed to even remember this stuff since my Aero-101 co =================> > > _________________________________________________________________ Helping your favorite cause is as easy as instant messaging.-You IM, we g ive. ________________________________________________________________________________
Date: Feb 06, 2008
Before MV. john h mkIII How's the rebuild going?? Taken any photos lately? What's the timeframe to getting your plane back in the air? Mike Welch ________________________________________________________________________________
Date: Feb 06, 2008
I got the tailwheel assembly all together. Had to grind the lower strut pivot, and install the pivot bolt up from the bottom. I had to grind the head of a grade 8 bolt to round it off for wheel clearance, and cut a screwdriver slot in it. The steering cables were no problem, and I put some tension on the wheel shimmy springs. First coat of Poly Brush on the aileron patches. Wish I had cut the fabric a little straighter. The new wings appear to be a newer design than the old ones, or a little different. The previous owner had never tried to fold the wings. The new wings came in with a shorter distance between the attachment points. He took a blank extended "u-joint" and drilled the holes to fit. Mounts fine, but did not fold. Turns out the old ones had front and rear holes on the same plane, and the new ones were mounted with the rear lug mounted with a vertical bolt. The new wings also seem to be sturdier at the rear attachment- fatter hardware. I will fit and change the wing attachments when I have better weather. Does anyone know when they switched dimensions and hardware? It might help me date this thing. Bill sullivan ________________________________________________________________________________
Subject: my old muffler
Date: Feb 07, 2008
After 21 years of flying, I'm going to finally have to replace the single jointed muffler on the engine. It's been welded twice before and now it's cracked again. I have a new double-jointed muffler and never put it on for two reasons. One, it has two EGT sender ports and I don't want to add another EGT gauge on my panel. Second, the muffler end goes straight out instead of the exhaust pointing up like this one does. I'm afraid the exhaust gases going out could weaken the fiberglass Ivo prop, over time, as the prop is only a few inches from the end of the muffler exhaust (I don't have a prop extension). What I can do, is get the curved part cut out of the old muffler and welded on to the new one. That takes care of that problem (or I could get a prop extension). I thought about tying the EGT senders together. Has anyone else done this? I don't see any problem with this. If one sends out more voltage than the other, it would respond on the single EGT instrument I have, thereby indicting a high EGT if either of the cylinders are too hot. -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162832#162832 ________________________________________________________________________________
Date: Feb 07, 2008
Subject: Re: my old muffler
Hi Ralph, I had the same issue on EGT -- originally one probe at the Y and one gauge. Later determined I much preferred knowing EGT separately, so put in a second probe. My solution to leaving it one gauge was to add a small switch. I mounted it just under the throttle. Fwd is the fwd EGT probe, middle is a neither, Rear is the rear EGT probe. I made myself the habit of leaving that switch in the rear position, other than when checking front EGT, to avoid inadvertently switching my ignition switch from fwd to rear (OFF) instead. My ignition sw is bigger and mounted a foot in front, but brain farts happen. Overall the solution has worked well, although that is also with the recognition that a digital EIS with alarm thresholds woulda been best. -Ben Ralph B wrote: > > After 21 years of flying, I'm going to finally have to replace the single jointed muffler on the engine. It's been welded twice before and now it's cracked again. I have a new double-jointed muffler and never put it on for two reasons. One, it has two EGT sender ports and I don't want to add another EGT gauge on my panel. Second, the muffler end goes straight out instead of the exhaust pointing up like this one does. I'm afraid the exhaust gases going out could weaken the fiberglass Ivo prop, over time, as the prop is only a few inches from the end of the muffler exhaust (I don't have a prop extension). What I can do, is get the curved part cut out of the old muffler and welded on to the new one. That takes care of that problem (or I could get a prop extension). > > I thought about tying the EGT senders together. Has anyone else done this? I don't see any problem with this. If one sends out more voltage than the other, it would respond on the single EGT instrument I have, thereby indicting a high EGT if either of the cylinders are too hot. > > -------- > Ralph B > Original Firestar > N91493 E-AB > 21 years flying it > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=162832#162832 > > > ________________________________________________________________________________
Date: Feb 07, 2008
I thought about a switch too, but if the engine gets hot, it will do it when the switch isn't switched. I'm going to try and "Y" the two senders together and use a cig lighter to see what happens. This seems the easiest way to do this without adding another gauge. -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162840#162840 ________________________________________________________________________________
From: "Jim Pook (Infosat)" <jimpook(at)ncns.infosathse.com>
Subject: Float & fuel tank info.
Date: Feb 07, 2008
I am seeking any information you folks may have for MKIII's on floats, particularly mono floats. Several years ago there was an outdoor (nature show) which included a white Kolb MKIII with a mono float arrangement. I think it may have been about Kodiak Bears in USSR?? I have an original MKIII Sn#035 and live in Yellowknife NT Canada. I purchased it in the spring of 1991 from Holmer. All the metal work is done and covering completed on the small parts but I have yet to cover the wings or cage. It was inspected by our MOT in 1994 and the next inspection due is pre-flight (my intensions are to register it as a Canadian "Homebuilt"). I bought it as a single guy, have since got married, had kids, ect. I'm back "into it" again and hope to make all the parts become one soon! Lately I have purchased an (unused) original 912 UL and plan to use it. I am aware of the issues of the particular engine, however, I would like to know what is done to increase the fuel capacity? I am toying with the idea of a wing tank. Between drag strut and main spar of the innermost 2 ribs would provide 20 gallons or so. Wing folding will seldom if ever be required. Has anyone ever done this? Regards, Jim Pook ________________________________________________________________________________
Date: Feb 07, 2008
I thought about a switch too, but if the engine gets hot, it will do it when the switch isn't switched. I'm going to try and "Y" the two senders together and use a cig lighter to see what happens. This seems the easiest way to do this without adding another gauge. >>>>>>>>>>>>>>>>>>>> Put in a small timer with a double pole, double throw relay,,, and have it go from one to the other every 10 sec or so. You could have it light a led to indicate front or back reading. Boyd ________________________________________________________________________________
Date: Feb 07, 2008
ElleryWeld(at)aol.com wrote: > You could buy a double in one gauge for you EGT that way you wont have to cut another hole in your panel Just a thought I thought about that too, but I have a dual tach and EGT. If I get a dual EGT, I will have to make a hole for another tach. -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162858#162858 ________________________________________________________________________________
Date: Feb 07, 2008
Subject: Sunday, in VA or NC
I'm going to be in the Richmond/Virginia Beach, Virginia area on business this weekend, and I have Sunday free... are there any Kolb drivers out there that would let me ride right-seat/rear-seat on local flight? If no takers, then I'll do the tourist thing and head down to Kitty Hawk and the Wright Museum. -- Robert, Texas Kolb driver ________________________________________________________________________________
Date: Feb 07, 2008
Wouldn't connecting the two wires together show the average of the temps, not the maximum of either? I don't think that will work. Just use the one egt hole and plug the other one. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162936#162936 ________________________________________________________________________________
Subject: login ...
Date: Feb 08, 2008
i want to be able to login to the Kolb website. obviously it require s a login id and a password. my question is - how do you get a password? .. ..... tim _________________________________________________________________ Climb to the top of the charts!-Play the word scramble challenge with sta r power. http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink_ja n ________________________________________________________________________________
Date: Feb 08, 2008
If they are in parallel they should show an average. BB On 7, Feb 2008, at 11:33 PM, olendorf wrote: > > Wouldn't connecting the two wires together show the average of the > temps, not the maximum of either? > > I don't think that will work. Just use the one egt hole and plug > the other one. > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://KolbFirestar.googlepages.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=162936#162936 > > ________________________________________________________________________________
Date: Feb 08, 2008
Tim I was told by Kolb that that was for some "administrative use only". Not for customers. ??? Aaron ----- Original Message ----- From: tim hrib To: kolb-list(at)matronics.com Sent: Thursday, February 07, 2008 11:39 PM Subject: Kolb-List: login ... i want to be able to login to the Kolb website. obviously it requires a login id and a password. my question is - how do you get a password? ....... tim ------------------------------------------------------------------------- ----- Climb to the top of the charts! Play the word scramble challenge with star power. Play now! ------------------------------------------------------------------------- ----- 2/7/2008 11:17 AM ________________________________________________________________________________
From: "KOLB AIRCRAFT" <customersupport(at)tnkolbaircraft.com>
Date: Feb 08, 2008
TIM, IZEK WILL SEND YOU THE INFO. YOU NEED THANKS DONNIE ----- Original Message ----- From: tim hrib To: kolb-list(at)matronics.com Sent: Friday, February 08, 2008 12:39 AM Subject: Kolb-List: login ... i want to be able to login to the Kolb website. obviously it requires a login id and a password. my question is - how do you get a password? ....... tim ------------------------------------------------------------------------- ----- Climb to the top of the charts! Play the word scramble challenge with star power. Play now! ________________________________________________________________________________
Date: Feb 08, 2008
On 7, Feb 2008, at 11:33 PM, olendorf wrote: > If they are in parallel they should show an average. Wouldn't connecting the two wires together show the average of the temps, not the maximum of either? I don't think that will work. Just use the one egt hole and plug the other one. > > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://KolbFirestar.googlepages.com > Thanks Scott and others. You are right, it will show an average. I will drill a single hole and plug the two other EGT ports. This worked for 21 years on the other muffler and will work here too. -------- Ralph B Original Firestar N91493 E-AB 21 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162986#162986 ________________________________________________________________________________
Date: Feb 08, 2008
Subject: E-Box on firestar
Any one Running An E-Box on a firestar How far would the Engine have to be moved forward to make up for the added 15 pounds ? Are "Ultra Props" any good ? Dave pilot of the "sofa king" ************** Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548) ________________________________________________________________________________
Date: Feb 08, 2008
Subject: Re: E-Box on firestar
Dave, Compare an Ultraprop to any other prop you've ever seen. That should answer your question. Rick On Feb 8, 2008 8:16 AM, wrote: > *Any one Running An E-Box on a firestar > > How far would the Engine have to be moved forward to make up for the added > 15 pounds ? > > Are "Ultra Props" any good ? > > Dave pilot of > the "sofa king"* > > > ************** > Biggest Grammy Award surprises of all time on AOL Music. > ( > http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548) > > > * > > * > > ________________________________________________________________________________
Date: Feb 08, 2008
Rick: Isn't an Ultraprop a plastic straight blade prop? No twist in the blade? Gets to a certain point in airspeed and hits a brick wall? No more speed? My comparison is the Ultraprop is a "dog" compared to other props. Sorry, can not remember the correct terminology for built in blade twist. Somebody help me out. john h mkIII Dave, Compare an Ultraprop to any other prop you've ever seen. That should answer your question. Rick ________________________________________________________________________________
Date: Feb 08, 2008
Tim, Look at URL near bottom of Kolb site, "The Kolb-List Email Forum. Clk on http://www.matronics.com/Navigator?Kolb-List. Down to Subscribe. Wasn't too hard? regards, Bob N. FireFly 070 Old Kolb http://www.angelfire.com/rpg/ronoy/ ________________________________________________________________________________
Date: Feb 08, 2008
other props. Sorry, can not remember the correct terminology for built in blade twist. Somebody help me out. john h mkIII John, The word is Helex, I think. Without the helex or twist built in, the prop has a narrower sweet spot where it performs well. Denny ________________________________________________________________________________
Date: Feb 08, 2008
Yep, that would be the one. Rick On Feb 8, 2008 11:19 AM, John Hauck wrote: > Rick: > > Isn't an Ultraprop a plastic straight blade prop? No twist in the blade? > Gets to a certain point in airspeed and hits a brick wall? No more speed? > > My comparison is the Ultraprop is a "dog" compared to other props. > > Sorry, can not remember the correct terminology for built in blade twist. > Somebody help me out. > > john h > mkIII > > > Dave, Compare an Ultraprop to any other prop you've ever seen. That should > answer your question. > > Rick > > > * > > > * > > ________________________________________________________________________________
Subject: 503 on MK-3
Date: Feb 08, 2008
Anyone with 1st hand experience. What are the pros or cons of a Rotax 503 on a MK-3. Should I consider it or is it too small? I want to know what to shop for. Plane will only be used for local site seeing and fun , mostly with a passenger(325# pilot & co-pilot total). Aaron Gustafson ________________________________________________________________________________
Date: Feb 08, 2008
Subject: Re: Good light 4 stroke Alternative for Kolbs
At 02:40 PM 2/8/2008, jb92563 wrote: > >This looks like a good engine alternative for Kolbs. > >-4 Stroke >-Weight 100 lbs >-55-65 Hp... And the engine is??? -Dana -- Artificial intelligence usually beats real stupidity. ________________________________________________________________________________
Subject: Re: 503 on MK-3
Date: Feb 08, 2008
Yep, 1st hand experience here. I had a 65 MPH cruise ( indicated), single pilot, I weigh 200 lbs, took a 250 lb passenger up once. it did it, but I wouldn`t do it regularly. for local flights solo, it it fine. There was a post not long ago about this same topic, & I`m sure there are VERY different opinions. mine was fine, but if you want to go longer distances, & or regularly flying dual, you may want at least a 582. Jim ----- Original Message ----- From: "Aaron Gustafson" <agustafson(at)chartermi.net> Sent: Friday, February 08, 2008 5:06 PM Subject: Kolb-List: 503 on MK-3 > > > Anyone with 1st hand experience. What are the pros or cons of a Rotax 503 > on a MK-3. Should I consider it or is it too small? I want to know what to > shop for. Plane will only be used for local site seeing and fun , mostly > with a passenger(325# pilot & co-pilot total). > > Aaron Gustafson > > > ________________________________________________________________________________
Date: Feb 08, 2008
Two friends of mine...Rans S12's ..one with a 503 and the other 582... The 582 delivered better fuel mileage...Herb At 07:48 PM 2/8/2008, you wrote: > >Yep, 1st hand experience here. I had a 65 MPH cruise ( indicated), >single pilot, I weigh 200 lbs, took a 250 lb passenger up once. it >did it, but I wouldn`t do it regularly. for local flights solo, it >it fine. There was a post not long ago about this same topic, & I`m >sure there are VERY different opinions. mine was fine, but if you >want to go longer distances, & or regularly flying dual, you may >want at least a 582. Jim >----- Original Message ----- From: "Aaron Gustafson" > >To: >Sent: Friday, February 08, 2008 5:06 PM >Subject: Kolb-List: 503 on MK-3 > > >> >>Anyone with 1st hand experience. What are the pros or cons of a >>Rotax 503 on a MK-3. Should I consider it or is it too small? I >>want to know what to shop for. Plane will only be used for local >>site seeing and fun , mostly with a passenger(325# pilot & co-pilot total). >> >>Aaron Gustafson >> >> >> >> > > ________________________________________________________________________________
Date: Feb 08, 2008
Subject: Re: Firestar Project Tailwheel
In a message dated 2/6/2008 8:11:58 A.M. Eastern Standard Time, williamtsullivan(at)att.net writes: Mine is black, and fresh from Kolb- a five inch. Hi Bill, I believe those 5 inch wheels were originally used on snowmobiles. They're called bogey wheels and are used to support the snowmobile track as it rotates. Makes for a nice light tail wheel, but it does cut a groove into soft turf. I was thinking about installing two wheels side by side for more support. Kinda like a Dually (Dualie?) pick-up truck! Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Feb 08, 2008
Aaron No question for the cost of a 503 or less put a redrive VW on it. You get 912 performance, 4 stroke reliability and low cost. I flew in a 503 powered MKIIIC with another guy the total human weight was 375-400. It did surprisingly good but not what you would want if your going to fly in and out of UP strips like Scott T. strip. Also, you have the opportunity to make a Kolbra or a MKIIIX. Depending on you mission either one would be a better choice. The down side of a Kolbra is that it is two narrow for the VW mount. New Kolb will weld up a MKIIIX cage with a VW mount. Food for thought. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Aaron Gustafson" <agustafson(at)chartermi.net> Sent: Friday, February 08, 2008 6:06 PM Subject: Kolb-List: 503 on MK-3 > > > Anyone with 1st hand experience. What are the pros or cons of a Rotax 503 > on a MK-3. Should I consider it or is it too small? I want to know what to > shop for. Plane will only be used for local site seeing and fun , mostly > with a passenger(325# pilot & co-pilot total). > > Aaron Gustafson > > > ________________________________________________________________________________
Date: Feb 09, 2008
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of BMWBikeCrz(at)aol.com Sent: Friday, February 08, 2008 7:17 AM Subject: Kolb-List: E-Box on firestar Any one Running An E-Box on a firestar How far would the Engine have to be moved forward to make up for the added 15 pounds ? **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 09, 2008
HI Bill. Jim VanGarsse here. I'm using a plastic lawnmower wheel on my Ultra Star. Its as light as the bogie wheel and is 4 times wider it works great. Jim VanGarsse Ultra Star 503 DCSI N 2613M **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 09, 2008
I have a wheel from ACS only used about a month (put on a Matco swivel) that I will sell for 1/2 price($15). It even comes with the fork for $5 more. This was not on a Kolb but is a good wheel w/ bearings. ACS p/n 06-03600. It looks like the picture in the lower right in the catalog. http://www.aircraftspruce.com/search/search.php Says 6x1.5 on wheel. 6" O.D. Contact me off list for picture Aaron G. ----- Original Message ----- From: KolbFlyerJim(at)aol.com To: kolb-list(at)matronics.com Sent: Saturday, February 09, 2008 6:18 AM Subject: Re: Kolb-List: Firestar Project Tailwheel HI Bill. Jim VanGarsse here. I'm using a plastic lawnmower wheel on my Ultra Star. Its as light as the bogie wheel and is 4 times wider it works great. Jim VanGarsse Ultra Star 503 DCSI N 2613M ------------------------------------------------------------------------- ----- Who's never won? Biggest Grammy Award surprises of all time on AOL Music. ------------------------------------------------------------------------- ----- 2/8/2008 10:06 AM ________________________________________________________________________________
Date: Feb 09, 2008
Subject: Anyone in Southern Texas
Any Kolbs in Southern Texas? I may be out here for some time, and wondering if there are any Kolbs down by Mcallen, Brownsville Texas area. This is a nice place to fly around in. Much nicer than southern Arizona, a great variety of visuals from Gulf water to desert to Farmland to rivers. It passes by too fast from the front office of a twin, but would be perfect for a UL, or any Kolb. Ron (Texas) ________________________________________________________________________________
Date: Feb 09, 2008
Subject: Re: Anyone in Southern Texas
Hello Ron I have a restored Twinstar with a 582 that I'll be glad to show you around San Marcos in. (Between Austin & San Antonio on IH 35.) Weather permitting of course. And if you just wanna stop in & swap lies I'm at: George E. Myers Jr. 1500 IH 35 South San Marcos, TX 78666 512-353-4860 Quoting Ron : > > Any Kolbs in Southern Texas? > I may be out here for some time, and wondering if there are any Kolbs down by > Mcallen, Brownsville Texas area. This is a nice place to fly around in. Much > nicer than southern Arizona, a great variety of visuals from Gulf water to > desert to Farmland to rivers. It passes by too fast from the front office of > a twin, but would be perfect for a UL, or any Kolb. > > Ron (Texas) > > ________________________________________________________________________________
Date: Feb 09, 2008
The HKS 4 stroke engine looks like much better design, more refined, and advanced engine for basically the same price... HKS has been around for a while now, and looks like a stable, growing company... Without parts, your engine is a pile of metal, why would anyone risk an off brand engine, with less development and reliability, when a proven engine like the HKS is available at the same price ??? Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163186#163186 ________________________________________________________________________________
Date: Feb 09, 2008
The question you need to be asking yourself is not IF the plane will fly with a 503, you need to ask yourself if it will be any fun to fly with a 503. Flying an underpowered plane and running the engine full out most of the time is definitely not as fun or rewarding, or as safe as flying a plane with a proper amount of power. Just because it you can do it does not mean you would want to. It all comes down to money, if you are able, get the 912-S, it is by far the best engine to put on a Kolb MK III. Work overtime, do whatever it takes to put the best engine you can afford on that plane, it will make the difference between having a plane that is fun and enjoyable to fly, and building a plane you never really like. If you cannot afford the 912-S, I would look for a used one. If not that, I would look at the VW Rick talks about, if not that, I would look at the 582. If you cant afford at least the 582, I would not build the MK III. If I was stuck with nothing but a 503, I would build a firestar-II which is smaller, lighter, and will give acceptable flight performance with a Rotax 503. -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163189#163189 ________________________________________________________________________________
Date: Feb 09, 2008
Hi All, Is there anyone in our group that can stop by Henderson NV and take a look at this engine up close and get pictures to post here? It would be good if there was bit more info regarding this engine besides what the manufacturer's web page. As far as engines go it would be nice to have some more four stroke alternatives out there. Yes HKS has been around for awhile but even they were new at one time. I imagine the same things being said about them regarding if they are going to be around or if they are just another flash in the pan. If BRP /Rotax would get off their duff and offer the ETEC fuel injection system on their a/c engine line I think it would greatly improve its reliability. I just doubt that this will ever happen. Best Regards Carlos G Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163190#163190 ________________________________________________________________________________
Date: Feb 09, 2008
A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb with a 200lb pilot steep enough, & at plenty of "feet per minute" to get out of a SHORT strip. I would not call that underpowered. : ) Jim ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Saturday, February 09, 2008 2:57 PM Subject: Kolb-List: Re: 503 on MK-3 > > The question you need to be asking yourself is not IF the plane will fly > with a 503, you need to ask yourself if it will be any fun to fly with a > 503. Flying an underpowered plane and running the engine full out most of > the time is definitely not as fun or rewarding, or as safe as flying a > plane with a proper amount of power. Just because it you can do it does > not mean you would want to. > > It all comes down to money, if you are able, get the 912-S, it is by far > the best engine to put on a Kolb MK III. Work overtime, do whatever it > takes to put the best engine you can afford on that plane, it will make > the difference between having a plane that is fun and enjoyable to fly, > and building a plane you never really like. > > If you cannot afford the 912-S, I would look for a used one. If not that, > I would look at the VW Rick talks about, if not that, I would look at the > 582. If you cant afford at least the 582, I would not build the MK III. > If I was stuck with nothing but a 503, I would build a firestar-II which > is smaller, lighter, and will give acceptable flight performance with a > Rotax 503. > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you > could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=163189#163189 > > > ________________________________________________________________________________
Date: Feb 09, 2008
Ray I never did hear what engine you were talking about. Do you have a web site, name or anything? Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Saturday, February 09, 2008 3:44 PM Subject: Kolb-List: Re: Good light 4 stroke Alternative for Kolbs > > The HKS 4 stroke engine looks like much better design, more refined, and > advanced engine for basically the same price... HKS has been around for > a while now, and looks like a stable, growing company... > > Without parts, your engine is a pile of metal, why would anyone risk an > off brand engine, with less development and reliability, when a proven > engine like the HKS is available at the same price ??? > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you > could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=163186#163186 > > > ________________________________________________________________________________
Date: Feb 09, 2008
> > A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb with a > 200lb pilot steep enough, & at plenty of "feet per minute" to get out of > a SHORT strip. I would not call that underpowered. > : ) Jim I really hate to have to reply to this thread, but keep in mind that this guy is asking a pretty serious question that will affect him for a long time, good choice or bad one. There was quite a lengthy thread on this same subject that should be in the archives, so he might go there. I live at 4000 feet, so that probably colors my opinion on the matter. Sea level might possibly be enough difference to make a 503 acceptable to a Mark III. If it is built light enough a 503 would push it around, but it wouldn't be as exciting a performer as a Mark III with 100 horsepower. I had a Mark III that had a 582 on it and sold it because to my thinking it was a dog and not as much fun to fly as my Firestar II. I guess that I have finally gotten old enough that I am not interested in OK, I want it to be the best that it can be, the first time. With a 582 the Mark III, will give you about the same performance as a Firestar with a 503. You are going to burn about 1 to 2 gallons more per hour to go the same speed. A 582 is going to cost you somewhere around $6000 and up. A 912 is somewhere around $14000 now I think. Rebuild time for a 582 is listed as 300 hours, compared to a rebuild time for a 912 is three to four times as long. Fuel burn is less than the 582 as well. The Mark III with a 912 is a "serious" airplane, any of the other engine choices leaves you with a "patch" type of airplane that you have problems going any distance due to the speed and fuel consumption. Not saying that it isn't possible, I am merely saying that for my self, I wouldn't do it on the cheap. I think if you pencil it out, over the long run a 912 would cost less than going with a two cycle engine. It is not my intention to belittle any ones choice of engine. If it suits you then that is all that is necessary. Just trying to fuel thought and give the guy the information to make a choice. Larry C ________________________________________________________________________________
Date: Feb 09, 2008
Thanks to all who have written. All comments are taken well. I don't want a dog but neither do I need a cruiser. I have a Zenith 601 for going places regionally. What I want now is a more around the patch fun flier. So I can keep an eye on the neighborhood and make sure no one else has more junk than me. It'll probably hardly ever get more than 50 miles from home. I have about ruled out the 503 though from the comments I have received thus far. This was what I wanted to hear. So I thank you for your perspectives and I'd still like to hear from others. Aaron >> >> A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb> >> > It is not my intention to belittle any ones choice of engine. If it suits > you then that is all that is necessary.> ________________________________________________________________________________
Date: Feb 09, 2008
I use a grocery cart wheel and change out the plastic bearings, about $8 and the same hub width but the bearing surface is around 1 inch. usually found cheap in a ditch near a grocery store or damaged behind the store. : ) Fly Safe, Wade Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163215#163215 ________________________________________________________________________________
Date: Feb 09, 2008
Too much plumbing would be necessary for the average guy. Howard Shackleford FS II SC In a message dated 2/9/2008 4:26:52 P.M. Eastern Standard Time, grageda(at)innw.net writes: If BRP /Rotax would get off their duff and offer the ETEC fuel injection system on their a/c engine line I think it would greatly improve its reliability. I just doubt that this will ever happen. **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 09, 2008
My FS II w/ 503 DCDI cruises at 65 mph; how in heck is a heavier, less- streamlined plane going to cruise at the same speed without running at 6000 rpm all the time? At least get the 582; 912 better. Howard Shackleford FS II SC In a message dated 2/9/2008 6:38:27 P.M. Eastern Standard Time, lcottrell(at)fmtcblue.com writes: A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb with a > 200lb pilot steep enough, & at plenty of "feet per minute" to get out of > a SHORT strip. I would not call that underpowered. **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 09, 2008
Sounds like a FSII would suit you better. A fantastic flyer with a 503. Howard Shackleford FS II SC In a message dated 2/9/2008 7:04:05 P.M. Eastern Standard Time, agustafson(at)chartermi.net writes: don't want a dog but neither do I need a cruiser. I have a Zenith 601 for going places regionally. What I want now is a more around the patch fun flier. So I can keep an eye on the neighborhood and make sure no one else has more junk than me. It'll probably hardly ever get more than 50 miles from home. I have **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 10, 2008
I just sold my FS2 11 months ago. 440 hours on it all mine. It flies great with a 447. Better than a 503 IMHO. ----- Original Message ----- From: HShack(at)aol.com To: kolb-list(at)matronics.com Sent: Saturday, February 09, 2008 9:36 PM Subject: Re: Kolb-List: Re: 503 on MK-3 Sounds like a FSII would suit you better. A fantastic flyer with a 503. Howard Shackleford FS II SC In a message dated 2/9/2008 7:04:05 P.M. Eastern Standard Time, agustafson(at)chartermi.net writes: don't want a dog but neither do I need a cruiser. I have a Zenith 601 for going places regionally. What I want now is a more around the patch fun flier. So I can keep an eye on the neighborhood and make sure no one else has more junk than me. It'll probably hardly ever get more than 50 miles from home. I have ------------------------------------------------------------------------- ----- Who's never won? Biggest Grammy Award surprises of all time on AOL Music. ------------------------------------------------------------------------- ----- 2/9/2008 11:54 AM ________________________________________________________________________________
Date: Feb 10, 2008
Thanks George I printed the message out and I''ll check out San Marcos see how far off it is. I got my Beech Sierra out here with me so I may give you a call once I find my bearings out here, basically I need a sectional for San Marcos area. Sure would like to move out here, after 20 years out in AZ I am ready for a change in scenery at the very least. Having my Kolb M3X out here in flying status is going to be great. Ron (Arizona) ======================================= ---- gmyers(at)grandecom.net wrote: ============ Hello Ron I have a restored Twinstar with a 582 that I'll be glad to show you around San Marcos in. (Between Austin & San Antonio on IH 35.) Weather permitting of course. And if you just wanna stop in & swap lies I'm at: George E. Myers Jr. 1500 IH 35 South San Marcos, TX 78666 512-353-4860 Quoting Ron : > > Any Kolbs in Southern Texas? > I may be out here for some time, and wondering if there are any Kolbs down by > Mcallen, Brownsville Texas area. This is a nice place to fly around in. Much > nicer than southern Arizona, a great variety of visuals from Gulf water to > desert to Farmland to rivers. It passes by too fast from the front office of > a twin, but would be perfect for a UL, or any Kolb. > > Ron (Texas) > > -- kugelair.com ________________________________________________________________________________
Date: Feb 10, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: Firestar
Rick- When my 5" wheel is installed, I had about 1/8" clearance, after grinding some off the lower strut flange, installing the pivot bolt from the bottom up, and grinding the bolt head into a round head screw with a slot. I wonder if mine is really old, and they used a 4" or 4 1/2" wheel originally. Bill ________________________________________________________________________________
Date: Feb 10, 2008
This is not the Hexadyne P-60, but the Aero-twin. On paper, the P-60 looks good, but it is a radial mounted engine instead of bed mounted. The Aero-twin looks REALLY good, but that $10k price [w/ all the necessary goodies] for an un-tried engine [at least on a Kolb] is a bit much. If I's rich I'd get an HKS. Looks like I'll just de-carb the old trusty 503................................ Howard Shackleford FS II SC This looks like a good engine alternative for Kolbs. -4 Stroke -Weight 100 lbs -55-65 Hp at 4200-4900 rpm -Turbo Charged option(65hp) -Fuel Injection -CDI Ignition -Dual Spark plugs per cylinder -Cheap $6,900 -Availability & Parts in USA, Henderson NV. -Dry Sump design **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 10, 2008
The BaronVonEvil wrote: > Hi All, > > > Yes HKS has been around for awhile but even they were new at one time. I imagine the same things being said about them regarding if they are going to be around or if they are just another flash in the pan. > > > Best Regards > Carlos G Not true, it is not at all the same situation. When the HKS came out, there was no good, reliable, light aircraft designed 2 cylinder engine available on the market, then trying something new made sense. Also the HKS design is very good for reliability and aircraft use, NOT so with the Aero Twin. Now, the HKS is available, proven reliable, and in use on many types of aircraft for the same price as the new engine... So why be the test case with an inferior engine, when the reliable, proven HKS is available at the same price ? If you took the time to look at the manufacturers website, there are plenty of pictures of the engine from many angles. Given what I see of the pictures, the design of the Aero Twin is inferior to the HKS, I would not want one, to many mistakes and compromises in their basic design to make it a good airplane motor. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163312#163312 ________________________________________________________________________________
Date: Feb 10, 2008
I found out the other day, from Travis at Kolb, the latest price for a Rotax 912 is $21,000. So much for a reasonable price engine from them. There engines are good but NOT that good. [Rolling Eyes] Rick Lewis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163385#163385 ________________________________________________________________________________
Date: Feb 10, 2008
It looks like they anticipated our genius politicians "rebate" BB On 10, Feb 2008, at 8:05 PM, Rick Lewis wrote: > > I found out the other day, from Travis at Kolb, the latest price > for a Rotax 912 is $21,000. So much for a reasonable price engine > from them. There engines are good but NOT that good. [Rolling Eyes] > > > Rick Lewis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=163385#163385 > > ________________________________________________________________________________
Subject: the elusive 4 stroke alternative
Date: Feb 10, 2008
Wheat futures have been bumping on $15 too. We have to face an across the board shrinkage in the dollar. (hmmm, wonder why they call it INflation?) I have maybe $3500 in this Rube Goldberg propulsion. -Plus about $15,000 worth of my cheap labor. Runs fine but the problem is finding the perfect prop. I'm still looking. BB DSCN0916.JPG
Subject: Re: the elusive 4 stroke alternative
Date: Feb 10, 2008
Hey Bob, Thanks for the WARM photo on a COLD night. Colder tonight in Eastern PA than Juneau Alaska. On Feb 10, 2008, at 8:31 PM, robert bean wrote: > Wheat futures have been bumping on $15 too. We have to face an > across the board shrinkage in the dollar. > (hmmm, wonder why they call it INflation?) > > I have maybe $3500 in this Rube Goldberg propulsion. -Plus about > $15,000 worth of my cheap labor. > Runs fine but the problem is finding the perfect prop. > I'm still looking. > BB > > > DSCN0916.JPG > > >
Date: Feb 10, 2008
captainron1(at)cox.net wrote: > Thanks George > I printed the message out and I'll check out San Marcos see how far off it is. I got my Beech Sierra out here with me so I may give you a call once I find my bearings out here, basically I need a sectional for San Marcos area. Sure would like to move out here, after 20 years out in AZ I am ready for a change in scenery at the very least. > Having my Kolb M3X out here in flying status is going to be great. > > Ron (Arizona) > San Marcos is on the San Antonio sectional. It's a really nice airport with a whole lot of concrete. It's generally UL-friendly or was a year ago when I left, except for a few grouches here and there. And of course the aviation folks who live in central and south TX are the finest guys and gals in the whole world you'll ever meet; I've shaken George's hand a few times and in fact he owned my old quicksilver ultralight for a while. As for central TX, I finally had to leave because I couldn't physically handle the summers anymore. 100+F temps, 80+ humidity and 15+ mph SE winds every day for 4 months without a break were finally too much for me as I started approaching middle age. So if you love very long stretches of unreal heat and humidity and don't mind gusty winds just about every day, it's great ;). As I said, the aviation guys and gals really make up for the rotten climate there. I did a lot of flying out of San Marcos, including most of my never-finished instrument rating training. There's lots of good flying around there when the wind is down runway 13.... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163407#163407 ________________________________________________________________________________
Date: Feb 10, 2008
JetPilot wrote: > > > Not true, it is not at all the same situation. When the HKS came out, there was no good, reliable, light aircraft designed 4 stroke 2 cylinder engine available on the market that was suitable for very light aircraft, at that time trying something new made sense. Also the HKS design is very good for reliability and aircraft use, NOT so with the Aero Twin. > > Now, the HKS is available, proven reliable, and in use on many types of aircraft for the same price as the new engine... So why be the test case with an inferior engine, when the reliable, proven HKS is available at the same price ? If you took the time to look at the manufacturers website, there are plenty of pictures of the engine from many angles. Given what I see of the pictures, the design of the Aero Twin is inferior to the HKS, I would not want one, to many mistakes and compromises in their basic design to make it a good airplane motor. > > Mike It also appears as if the Oleniks are working on a mount for it for the Kolb, as there's a slingshot with an HKS on it for sale by them on barnstormers. The Oleniks are smart guys and do good work, so I'm sure they're going to come up with a reliable mount. The HKS looks like the best contender for that gap between the 503 and the 912 which is currently occupied by the 582 and some other 2-strokes. The clever thing they did with the HKS is made the operating RPM's and gearbox ratios very similar to the 582 and its gearboxes. So you're not in totally unknown territory when it comes to prop selection and operating rpm etc..... I still think it's a bit heavy for something like the FS II, though it does seem to work. It looks tailor-made for something like the Slingshot tho.... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163410#163410 ________________________________________________________________________________
Date: Feb 10, 2008
Subject: Re: Ultrastar Update
Date: Feb 10, 2008
A 503 will give you outstanding performance on a Firestar!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Chris ----- Original Message ---- From: JetPilot <orcabonita(at)hotmail.com> Sent: Saturday, February 9, 2008 3:57:18 PM Subject: Kolb-List: Re: 503 on MK-3 The question you need to be asking yourself is not IF the plane will fly with a 503, you need to ask yourself if it will be any fun to fly with a 503. Flying an underpowered plane and running the engine full out most of the time is definitely not as fun or rewarding, or as safe as flying a plane with a proper amount of power. Just because it you can do it does not mean you would want to. It all comes down to money, if you are able, get the 912-S, it is by far the best engine to put on a Kolb MK III. Work overtime, do whatever it takes to put the best engine you can afford on that plane, it will make the difference between having a plane that is fun and enjoyable to fly, and building a plane you never really like. If you cannot afford the 912-S, I would look for a used one. If not that, I would look at the VW Rick talks about, if not that, I would look at the 582. If you cant afford at least the 582, I would not build the MK III. If I was stuck with nothing but a 503, I would build a firestar-II which is smaller, lighter, and will give acceptable flight performance with a Rotax 503. -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163189#163189 Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Feb 10, 2008
Subject: Kolb Laser?
Looking in some old Experimenter magazines a friend gave me, I see some pictures of "Homer Kolb and his latest design, the Laser", a nice looking low wing plane. I'd never heard of this aircraft before; whatever happened to it? 1990 was a very good year for Kolb, with an Ultrastar as the Grand Champion Light Plane, a Firestar as the Grand Champion Ultralight (!), and another Ultrastar (built by a guy I knew in college, small world!) as Reserve Grand Champion Ultralight. Interesting how many Firestars were passed off as "ultralight" back then... -Dana -- I only drink to make other people more interesting. ________________________________________________________________________________
Date: Feb 10, 2008
Subject: Re: 447 exhaust temperarures
Group, I am still plagued with too high of exhaust temps. I have tried different jet needles needle jets and main jets but there seems to always be a hot spot between 4000 and 5200 rpms. Question what is the minimum exhaust temp that is recommended for the Rotax 447 ? On climb out with the 170 main jet i am seeing 1000*. At other rpms, egts will get to 1150 or 1175. Will it hurt anything if I run it with the EGTS at 1000* I have it propped for 6250 static and the heads are at 350 *or so most of the time. This 447 is such a royal pain. I am thinking of getting one of those in flight adjustable carb mixture controls if I can. Ed Diebel FF # 62 **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Feb 10, 2008
Thanks, I flew / fly freight out of Dallas and Houston so I know about the b'chin' heat and humidity. Got used to it but never did like taking a shower with a set of new cloths and 35 minutes later being ready for another shower and another set of new cloths. I think with the breezy Kolb it won't be as bad. But I deffer to others about that. :-) Still like it better out here than Arizona which among other things with the influx of Califruties is turning into Taxzona. Oh less I forget you ain't seen no winds till you been to Arizona. Dry wind that floats all the allergens most of which have yet to be discovered by science, but very discoverable by our immune system. Ron (Temporarily in Texas) =============================== ---- lucien wrote: ============ captainron1(at)cox.net wrote: > Thanks George > I printed the message out and I'll check out San Marcos see how far off it is. I got my Beech Sierra out here with me so I may give you a call once I find my bearings out here, basically I need a sectional for San Marcos area. Sure would like to move out here, after 20 years out in AZ I am ready for a change in scenery at the very least. > Having my Kolb M3X out here in flying status is going to be great. > > Ron (Arizona) > San Marcos is on the San Antonio sectional. It's a really nice airport with a whole lot of concrete. It's generally UL-friendly or was a year ago when I left, except for a few grouches here and there. And of course the aviation folks who live in central and south TX are the finest guys and gals in the whole world you'll ever meet; I've shaken George's hand a few times and in fact he owned my old quicksilver ultralight for a while. As for central TX, I finally had to leave because I couldn't physically handle the summers anymore. 100+F temps, 80+ humidity and 15+ mph SE winds every day for 4 months without a break were finally too much for me as I started approaching middle age. So if you love very long stretches of unreal heat and humidity and don't mind gusty winds just about every day, it's great ;). As I said, the aviation guys and gals really make up for the rotten climate there. I did a lot of flying out of San Marcos, including most of my never-finished instrument rating training. There's lots of good flying around there when the wind is down runway 13.... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163407#163407 -- kugelair.com ________________________________________________________________________________
Date: Feb 10, 2008
Ed, Do you have an adjustable pitch prop? Actually 1000* degrees F is OK - go to much above that and I would start getting concerned. High EGT's often indicate you might need to load the engine a little more by increasing your prop's pitch. We set our new 447's to 5900 static (tail tied down full throttle) and get about 6000-6100 RPM on full throttle on takeoff. A little more pitch isn't going to hurt anything. Try it and see what it does. What's the EGT numbers doing when you pull back power some such as on final. For some reason I noticed that FireFly's have a tenancy to peak EGT's when power is reduced some, not completely on final. It's been so long since I touched our old Kolb FireFly, I can't recall what jets and needles we ran in it - I know for sure we changed the original main jet. There was a post about a needle to use to reduce high mid-range EGT take a look at it. I got the needle but hadn't tried it. jerb At 10:16 PM 2/10/2008, you wrote: >Group, > > I am still plagued with too high of exhaust temps. I have tried > different jet needles needle jets and main jets but there seems to > always be a hot spot between 4000 and 5200 > rpms. Question what is the minimum exhaust temp that is > recommended for the Rotax 447 ? On climb out with the 170 main > jet i am seeing 1000*. At other rpms, egts will get to 1150 or > 1175. Will it hurt anything if I run it with the EGTS at 1000* I > have it propped for 6250 static and the heads are at 350 *or so > most of the time. This 447 is such a royal pain. I am thinking of > getting one of those in flight adjustable carb mixture controls if I can. > > > Ed Diebel FF # 62 > > >---------- >Who's never won? ><http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548>Biggest >Grammy Award surprises of all time on AOL Music. > ________________________________________________________________________________
Subject: Slingshot from Olinik's with HKS
Date: Feb 11, 2008
I have an interesting story and question regarding the Slingshot for sale with the HKS. For those that do not know about it, it is the former Kolb factory demo plane, that was sold with the 912 to someone without enough tailwheel time, and was "cartwheeled" in a ground loop, requiring a wing replace and other unknown damage-- at least that is what the owner in Alabama told me when he had it listed without an engine a little over a year ago, but was very sketchy about the details. It looked great in pictures, but I thought it was not worth the 16 hour drive in person only to be disappointed. I have seen too many Kolb's after being repaired that I would not own with hard to notice, hidden damage. Now for the question, does anyone have 1st hand knowledge of the repairs? It just so happens that I called and talked to Jerry about putting a HKS on this very plane when it was for sale last year, which is probably how it came about that he found it. Now that it's all together, I find that I may again be interested that the hard work is done. Dreaming and freezing in Wisconsin Tom McCarthy N441TM, Original Firestar, 377, 530 hours N514TM, Zenith 601 HD, 912ul, 130 hours ________________________________________________________________________________
Subject: Wing AOA on Kolb MK III?
Date: Feb 11, 2008
Why is the Kolb MK III wing set at 9 degrees positive when the plane is set level for the weight and balance? Does the plane fly with a 9 degree AOA in level cruise? I guess this is confusing to me because I build radio controlled airplanes and I set the wings and horizontal stabilizers at 0 degree AOA in relation to the fuselage and thrust line. These fly fine. I have experimented with raising the AOA of the wing and it doesnt seem to make much difference other than changing the trim settings. I know the faster you fly the wing has to lower AOA and the slower the AOA increasing until about 14 to 16 degrees before a stall occurs. 9 degrees seems fairly close to the stall AOA. What would happen if the wing was readjusted on the Kolb to have a Lower AOA? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=163454#163454 ________________________________________________________________________________
Subject: Redrive VW on Kolbs Update
Date: Feb 11, 2008
Wow that is a ridicules price. I have to believe that this is a engine package not just the engine and also might be the 100HP 912. The last price I heard from the US distributor in November and it was $18,000 for the 100HP engine only. The important thing is that the 912 series engines are way over priced. The redrive VW is a virtual match for the 912 series. The engine Rick Lewis is putting on his plane has the potential of out performing the 100HP rotax if he chooses to. The reliability could suffer with high power continues usage but only time will tell where significant reliability suffers. My air-cooled heads tend to over heat when pushed for very long above 80HP. I have an article being scheduled for the April issue in the EAA's Spot Pilot & Light-Sport Aircraft Magazine. It is called "Quest for Affordable Power". The timing couldn't be better. I talk about the VW engine package being $10,000 less than the 80HP rotax. Based on this new price, the difference will be much greater. I'm also pushing Great Planes Aircraft and New Kolb to communicate and maybe offer a engine package. The only remaining part that isn't off the shelf is an exhaust system that I'm try to get someone to produce it. I'm still trying to tune a prop for best overall performance. Last year I choose to pitch my prop for cruise performance at 3200 RPM. My climb out was in the 3400-3500 range depending on speed. The ideal climb RPM would be around 3800 RPM where climb rates would be spectacular with maybe 20 more HP. The Redrive VW even with the current prop and pitch is close to 912 performance. I have had the prop cut down by an inch to 71 inch diameter and will report the results when I get back to Michigan in the spring. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Rick Lewis" <cktman(at)hughes.net> Sent: Sunday, February 10, 2008 8:05 PM Subject: Kolb-List: Re: 503 on MK-3 > > I found out the other day, from Travis at Kolb, the latest price for a > Rotax 912 is $21,000. So much for a reasonable price engine from them. > There engines are good but NOT that good. [Rolling Eyes] > > > Rick Lewis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=163385#163385 > > > ________________________________________________________________________________
Subject: Re: Wing AOA on Kolb MK III?
Date: Feb 11, 2008
Grant, that is close to the cruise angle. Sure looked funny to me too at first, sort of plowing through the air. The SS has a different setup. I wonder at what angle the CG is checked on it? The main reason for the angle in cruise is the shape of the leading edge. -The most forward point is near the bottom of the wing surface. On most common GA wings like the Clark Y and the Aeronca NACA 4412 the leading edge has a much larger radius so the streamlining into the wind results in a more level angle. I'll guess that taping a large radius cuff (1/2 slice of foam pipe insulation) on a Kolb leading edge would result in a faster cruise. BB On 11, Feb 2008, at 8:50 AM, grantr wrote: > > > Why is the Kolb MK III wing set at 9 degrees positive when the > plane is set level for the weight and balance? > > Does the plane fly with a 9 degree AOA in level cruise? > > I guess this is confusing to me because I build radio controlled > airplanes and I set the wings and horizontal stabilizers at 0 > degree AOA in relation to the fuselage and thrust line. These fly > fine. I have experimented with raising the AOA of the wing and it > doesnt seem to make much difference other than changing the trim > settings. > > I know the faster you fly the wing has to lower AOA and the slower > the AOA increasing until about 14 to 16 degrees before a stall > occurs. 9 degrees seems fairly close to the stall AOA. > > What would happen if the wing was readjusted on the Kolb to have a > Lower AOA? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=163454#163454 > > ________________________________________________________________________________
Date: Feb 11, 2008
\Grant asked: > Does the plane fly with a 9 degree AOA in level cruise? Yes, maybe a little less. Grant also asked: > What would happen if the wing was readjusted on the Kolb to have a Lower > AOA? If you lowered the angle of insidence of a Mk-3s wing you would have to go a lot faster to take off and land as you would not have enough angle of attack to rotate at the Mk 3s low stall speed without dragging the tail. Also the horizontal tail angle would have to be changed accordingly, and you would be flying around with your nose higher in the air to get the wing back to the correct AOA. Homer got it right, these planes are a nice balance for light, low speed flying. > > > Denny Rowe, Mk-3 N616DR > ________________________________________________________________________________
Date: Feb 11, 2008
A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb with a 200lb pilot steep enough, & at plenty of "feet per minute" to get out of a SHORT strip. I would not call that underpowered. : ) Jim Maybe at sea level... try it on a warm summer day at 7000 ft... while on a cross country,,,, you will be wising for a 912 or 912s also if you want to sell it,,,, which plane would sell better... the 912 cost more but operates for less, by the time you put on 1200 to 1500 hours,,, they cost
January 25, 2008 - February 11, 2008
Kolb-Archive.digest.vol-he
