Kolb-Archive.digest.vol-hg
February 27, 2008 - March 09, 2008
After I calmed down I called the "FDOR" and left a message . The "Lady"
called me back. I told her it was an Ultralight built from junk and salvaged parts
over 10 years ago . She said put that into a letter and send it so I did (
used as much military and Legalese as I could muster up :-) ) Sent it certified
with a really bad photo of the bare cage .... So now that is Behind Me
.Thanks for all the advice ... Dave
Ideas to please picky eaters.
Watch video on AOL Living.
(http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/2050827?NCID=aolcmp00300000002598)
Subject: | Re: Firestar Videos and VG's |
Jack,
There is plenty of evidence to show that home made VG's work, I'm just not sure you are getting the full benefit as you would with landshorter VG's. The only way to know that would be to flight test the difference between home made designs and the landshorter design, which would be a huge amount of work. Joel who owns www.landshorter.com says he has tested the size, and shape of different VG's in a wind tunnel, and optimized his for small experimental sized aircraft. Landshorter VG's can be attached with double sided automobile trim tape, and moved at will, or taken off if you don't like them, Possums came up with this idea and my VG's have been on my plane with double sided tape almost a year now, I have not lost any. Position of VG's is critical to get the desired results, the landshorter VG's specify exact positions, and even on VG kits for certified aircraft, they come with a large template and instructions for exact positioning... So its very clearly important. Attached is a picture of my VG's.
I have spoken to Joel at landshorter several times on the phone, and he is a great
guy that is very technically competent. Joel is an aerodynamics engineer
and sells the VG's on the side. There is not much profit in selling 100 lexan
VG's for 100 bucks, its not a big market. Given the time Joel spends on support
and answering questions, his motivation is clearly to help aviation the community
more than to just make a couple bucks.
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=166567#166567
http://forums.matronics.com//files/ultralightkolbmikezvgsfloridahomestead07_11_2007_176_170.jpg
From: | "beauford T" <beauford173(at)verizon.net> |
Subject: | Tail VG's (formerly Firestar videos & VGs) |
I put them horizontal stab (bottom) about 2 inches forward of the hinge... I
use the wedge shaped homemade ones (a la Shackelford model) made from
aluminum sheet which are larger and more crude than the Landshorter ones...
I put only three to a side spaced 3 inches apart. They definitely add
authority to the up-elevator inputs at landing speeds. Ugly, but they work
like a hooker in fishnets...
Got 'em on the vertical stab also... makes for powerful slips...
...worth what ye paid fer it...
experimental beauford
FF-076
Brandon, FL
----- Original Message -----
Sent: Tuesday, February 26, 2008 8:38 PM
Subject: Re: Kolb-List: Re: Firestar Videos and VG's
where does one place the vg's on the horiz stab?
On Feb 27, 2008, at 9:20 AM, Jack B. Hart wrote:
> I am sure that Landshorter VG's are very effective, but you can save
> about
> $80 -> $90 by making your own.
Yep,
Here is what i did.
Get a couple of 4 foot lexan ell corner protectors from the paint and
wall paper section of your local home improvement place and cut them
to make your own VGs.
http://picasaweb.google.com/imhisson2/VortexGenerators
Cheap Squeek Gene,
Subject: | Re: Tail VG's (formerly Firestar videos & VGs) |
I have not tried VG's on the tail, I never run out of elevator on landing, so I
did not think I needed them. The elevator can be pretty heavy on takeoff with
two people in a short, rough field when Im trying to break ground quickly,
so given the reports from you guys I will try them on tail to see if I can bring
down the stick forces. More rudder authority at slower speeds would really
be nice for crosswinds !
have !!!
http://forums.matronics.com/viewtopic.php?p=166627#166627
I made my latest edition out of .060 Lexan which I bent in the metal brake
then cut with metal shears. Attached with "Goop". I drilled two 1/8" holes
in the bottom of the VG so the "Goop" would get a better grip.
I also roughed up the bottom a bit with a medium sandpaper for better
adhesion. Never lost a VG.
I like your idea better.
Unless one is VERY frugal, the "landshorters" are probably the best way to
go, considering you get the measurements for placement & template.
Howard Shackleford
FS II
SC
Get a couple of 4 foot lexan ell corner protectors from the paint and wall
paper section of your local home improvement place and cut them to make your
own VGs.
**************Ideas to please picky eaters. Watch video on AOL Living.
Shack:
That is a good record.
How about VG'ers?
Never lost a VG.
Howard Shackleford
Subject: | Re: FS II perfomance |
I wonder what you Firestar II drivers are getting for a top speed, straight
& level. I'm getting 82 mph [gps].
503 DCDI
"C" box, 3.41:1 ratio
68" 3 blade Kiev Prop
streamlined struts
heavy plane - 410 [dry]
heavy pilot -270
oh yeah...........a few cheap VG's.
How about your climb rate, if you know it. Will measure mine next time out.
Howard Shackleford
FS II
SC
p.s. Mike Bigelow - What are yours with the HKS?
Subject: | FireStar Cockpit Noise Reduction? |
Hi All,
This subject may have been flogged to death already but I am to a point that if
I cant get the noise level in my Firestar II down to a dull roar I will have
to sell it.
I have measured the inflight cockpit noise during take-off and get about 117db
on a Radio Shack Db meter. ( Not the Highest tech device but at least it gives
a starting point.)
What can a person do to reduce the noise level? (besides glide...) Even at moderate
power settings the noise is still around 115 db or so.
I wear a helmet with a set of David-Clarks that has the Gel ear pads but for others
to hear my radio transmissions, I have to reduce power to less than 3500rpm
to be heard. I have my radio volume cranked up as high as it will go just to
hear other pilots. It can't be doing my hearing very much good.
Help!
Carlos G. [Crying or Very sad]
http://forums.matronics.com/viewtopic.php?p=166684#166684
Subject: | Re: Re: FS II perfomance |
Howard,
My FS II cruises comfortably at about 57 mph, straight & level, no wind.
That requires about 5400 rpm. I've never tried to go all out top speed
wide open yet except taking off. It stalls at 36 mph. I've seen 65 mph
airspeed with a 37 mph gps ground speed, and I've seen 55 mph airspeed
with 85 mph gps groundspeed, depends on the wind. I've heard a lot of
claims of much faster airspeeds speeds and much lower rpms, but that's
the straight bull on mine.
My plane weighs 440 empty, no fuel, I weigh 210. It has the 503 DCDI, 3
blade IVO prop 66". I would like to cut weight on it, but there's
nothing I want to take off. I'm pretty darn happy with it just the way
it is.
Jimmy Young
FS II, N7043P
59 hrs on it & climbing. (my time)
Our good friend Carlos,
Your excessive noise problem is very likely something that can greatly improved
in a couple of ways.
First, I HIGHLY recommend getting a set of "ACTIVE" noise-cancelling headphones.
I emphasized "active" because that is the term used to describe the electronic
noise cancelling system. They have the "passive" style, but that isn't
what you're after.
You can either buy the incredibly expensive Bose, Lightspeed, David Clarks, etc.,
or convert your existing David Clarks.
Here is a link to an outfit that makes an active noise cancelling module for
most headset companies.
http://www.headsetsinc.com/customer_reviews.htm
For less than $200 you can modify your present headset, and have the performance
that meets or exceeds the models that cost a small fortune.
A little background on the active style of noise reduction: Sound is one of
the many waves along the electromagnetic wavelength spectrum. Sound is a little
different from the other examples, like light, x-rays, UV rays, etc, because
sound requires air to help transmit this energy from molecule to molecule, and
so on.
Sound comes to you by way of a sinewave. There are crests and troughs, as seen
in this link;
http://science.hq.nasa.gov/kids/imagers/ems/waves3.html
Now, here is the really amazing and cool part. In a sense, and due to the nature
of the sinewave, you are listening to either a high crest or a low trough
at any given time, and according to the frequency of the sound wave coming at
you. What the electronic headsets do is record the sound coming to it, and play
it back virtually instaneously, where it is EXACTLY opposite of the crest
and trough. In other words, if you were able to look at this new sound wave coming
at you, you would see the original sinewave, and now a NEW soundwave opposite
from the original (essentially a mirror image). There would be a crest...and
an anti-crest, at the same time, and a trough and an anti-trough, etc.
So what you are now hearing is...sound, and anti-sound, at the same moment.
This added feature of "anti-sound" can and does counter-act the "sound", so that
you are left with silence. For the airplane headset company, their mission
is to reduce as much "bad" noise as possible, allowing you to hear only the
deliberate sound from your ear speakers, and virtually all other outside noises
cancelled...literally! It is possible to be in a noisy room and hear nothing.
Not because the sound is muffled, but because the noise is counteracted by
anti-noise, the result of which is silence. Of course, for something as small
as a pair of headphones, you can't achieve such performance, but you can come
close.
BTW, this same exact concept of cancelling out wavelengths in the electromagnetic
spectrum is shown by way of "photo-gray lenses" You've all seen the pair
of glasses that the lenses get dark once they are exposed to direct sunlight,
right? This phenomenon happens because the lenses have microscopic lines cut
into the lenses.
As sunlight (a very specific wavelength) passes through the lense some of the light
is captured and refracted by the microscopic grooves. This shift is just
enough to divert the light and cause it to interact with the unobstructed light.
So, again, you have light wavelengths passing through the lense, and being
counteracted
with "opposite" lightwaves (on the electromagnetic spectrum). The result: no
light (or reduced light). Essentially the light is cancelled by the anti-light,
and the lense becomes dark.
Of couse, photo gray lenses objective is only to reduce light, not eliminate
it, so they place the microscopic grooves at such intervals as to only partially
block some the light passing through, thereby making them "sunglasses". Walk
back into the house, and the effect goes away, because in-door light wavelengths
aren't the wavelengths that these grooves are affected by.
Secondly, you may want to put an additional small muffler on your plane, or build
a new system altogether. I bought a small glass pack muffler for my custom
turbo installation. The muffler was still a little heavier than I wanted,
so I cut it in half. I'm sure you could do a LOT in quietening down the exhaust
noise.
I don't know how your plane is configured, but you may consider installing a
sound deadening material. I purchased a roll of this stuff for my GlaStar, to
be placed against the firewall. I got it at JC Whitney, just look up "sound
deadening".
I am very confident these things will make a world of difference to your flying
pleasure. I especially believe you will find the most improvement with the
noise cancelling headset, followed by the quieter muffler improvements.
I look forward to your progress reports.
Mike Welch
Kolb MkIII
PS. One of the main reasons I chose to use the GEO engine on my MkIII was it's
incredibly low engine noise. Plus, now that I have decided to use a turbo, I
would be willing to bet that this will be one of the quietest MkIII's around.
a starting point.)
> Help!
Climb to the top of the charts!Play the word scramble challenge with star power.
http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink_jan
Subject: | Re: FireStar Cockpit Noise Reduction? |
for others to hear my radio transmissions, I have to reduce power to less
than 3500rpm to be heard. I have my radio volume cranked up as high as it
will go just to hear other pilots. It can't be doing my hearing very much
good.
> Help!
Carlos:
I had to graduate from David Clarks with gel ear seals to an ANR headset.
I have lived in a high noise environment most of my life. During my
military career hearing protection was unheard of. My hearing has become so
poor I had to graduate from passive noise reduction headsets.
With the ANR I can hear and transmit quite well. Without the ANR my ability
to hear and comprehend is nearly zero.
I fly with a DRE6000 headset that works great. Unfortunately, this company
was in business for a short time and is now belly up.
> Mike Welch
> Kolb MkIII
> it's incredibly low engine noise. Plus, now that I have decided to use a
> turbo, I would be willing to bet that this will be one of the quietest
> MkIII's around.
Mike W:
Once you start flying your mkIII you will probably discover the major noise
producing item is the prop.
By producing a very quiet engine, you will be able to hear your prop better.
Forget all those suggestions of (expensive) Active Noise Reduction headsets. Sure
they will help, but nowhere near as good as a pair of good in-ear noise-reduction
headphones like the Shure E2C, which will cost you a tenth as much. Just
pop your ordinary headset over the top, for even more noise reduction and of
course to hold the microphone.
I nearly gave up learning to fly because I suffered tinitus for a week after every
flight, even in a "quiet" aeroplane. Now I fly my noisy Kolb in comfort, with
the knowledge that I have less noise in my ears than even the most expensive
Sennheiser set.
http://forums.matronics.com/viewtopic.php?p=166730#166730
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
Carlos
There are a number of things you can do. Cut the noise at the source or keep
it away from you.
To cut the noise at the source you can add mufflers, intake silencers and
cut prop tip speeds. To cut prop noise you can shorten your prop or get a
larger reduction ratio for your redrive. Most of these things will reduce
your performance. Changing reduction ratios with any prop changes will be
expensive. Find out where the noise is coming from first. With my direct
drive VW I added a muffler and then found it was the prop that made the
noise.
To keep the noise away get a active noise reduction headset with a good
noise canceling mike. I have the noise canceling kit in my Sigtronics
headset and it helps a bunch. To get a additional level of reduction I also
use a set of Sony MDR-EX51PP headphones under my active noise canceling
headset. They are cheap and help a bunch. There are many others that are
good and may work better. Seems like someone even found a inexpensive active
noise canceling set. My set up works so well that I can listen to music at a
low level with a DRE intercom cutting the music for communication and still
no ringing in the ears afterwards.
Rick Neilsen
Redrive VW powered MKIIIC
Sent: Thursday, February 28, 2008 9:17 AM
Subject: Re: Kolb-List: FireStar Cockpit Noise Reduction?
> > Mike Welch
>> Kolb MkIII
>> was it's incredibly low engine noise. Plus, now that I have decided to
>> use a turbo, I would be willing to bet that this will be one of the
> Mike W:
> noise producing item is the prop.
> better. ;-)
> john h
> Mike W:
> john h
Ah, John,
With very little MkIII flying time (read that to be "none"), I wouldn't know
that the prop makes that much noise. But I really do believe I should have a
very quiet engine, and I figured if the prop was a problem, then I would just
install VGs on it.
chuckling
Mike Welch
Helping your favorite cause is as easy as instant messaging.You IM, we give.
From: | "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil> |
<< I cant get the noise level in my Firestar II down to a dull roar I
will have to sell it. >>
Carlos -
I had the same problem in my Mark-III. It was almost impossible to hear
my radio, even with a well-fitting Comtronics helmet with built-in gel
earseal headsets.
The single most effective thing you can do is get yourself a set of ANR
(Active Noise Reduction) headsets. MAN, what a difference they made for
me!
I bought the least-expensive set I could find on the market - LightSPEED
QXC. The cost me about $275. Worth every penny. Sure, there are more
expensive sets on the market, and they may perform better. But just
making the step up to any ANR headset (even an entry-level one) is an
order of magnitude better than any passive set you can buy.
Dennis Kirby
Mark-III Classic, 912ul
Cedar Crest, NM
> Should be under 600 mph tip speed to reduce noise from the prop.
> Ray
Hi Ray:
We've knocked this noise thing around quite a bit over the years. I'd say
it it more prop noise than anything else. Also, I think we can discount
prop tips approaching or exceeding supersonic speeds. The Rotax engines
have already taken that into consideration for us.
I believe most of our noise is the result of a pusher engine configuration
with a prop that must run through air that is not always clean and in close
proximity to the aircraft structure.
I have gotten down to the point where I accept my noisy airplane and try to
take other routes to help make it liveable for long flights. Some of us
have proven that it is not so excessive we can not live in our airplanes for
very long periods of time.
mkIII Noisy beyond imagination.
> me!
> Dennis Kirby
Dennis:
Got your bag packed for MV?
I tried the best Litespeed had to offer when they first came out without
success. Then, last summer, I bought the best that David Clark had to offer
the XL somethings. Neither would work in the mkIII cockpit.
The set that worked best for me was the DRE6000, which unfortunately, is out
of business. Got my fingers crossed my old set will keep on trucking.
mkIII Bag packed for MV 2008.
From: | "Aaron Gustafson" <agustafson(at)chartermi.net> |
I noticed on my FS2 when I changed from the Culver wood prop to an IVO and
had to add the 3" extension that the noise went down considerably and I
think only slightly because of the prop. Before I could not keep the gap
seal in place (would shred) near the prop but getting the prop away from the
TE nearly solved that problem and was where the most of the noise was coming
from I think. Ear plugs and a helmet, it never bothered me, but no radio
installed.
Aaron G.
Sorry Folks:
Looks like I fired a blank.
The real one will follow shortly.
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
I only want to add a couple of things about the noise in a Kolb. A prop
extension will help a lot, all mikes on anr type headsets are directional.
This is where anyone has trouble hearing you transmit. Put the mike on the
other side and see if that helps.
Larry C
Get one of their mods ASAP.
---- The BaronVonEvil wrote:
Hi All,
to sell it.
a starting point.)
Help!
kugelair.com
Do you have a link to the optical cancellation you mentioned. I have not heard
of it before.
what you're after.
so on.
in this link;
close.
into the lenses.
counteracted
noise.
deadening".
Mike Welch
Kolb MkIII
a starting point.)
> Help!
kugelair.com
The problem with VG's on the prop is that you will always have lots of Thrust.
Even after you shut the engine down. You will need to install thrust nualifiers
to keep your airplane from taking off and disappearing into the sky, perpetually
loitering in the heavens.
> Mike W:
> john h
Ah, John,
install VGs on it.
chuckling
Mike Welch
kugelair.com
From: | william sullivan <williamtsullivan(at)att.net> |
I noticed the prop noise exceeded the engine noise while having my Firestar tied
to a tree. Without the wings, as soon as the RPM's got up to about 4000, the
prop started sounding like a helicopter. There is also a spot on the main boom
tube right below the prop that is missing the paint. Maybe the prop tips passing
1" from the tube is generating the "whopping" noise. It is a 66" Warp Drive
2 blade ground adjustable prop. I never went past 4000rpm, as we were worried
about both the tree and the rope. I imagine the noise will be quite a bit
louder when the wings are on, as I have to check for aileron clearance to the
prop.
If the prop is too close to the ailerons, will it give the aircraft a horizontal
trim problem? I have looked a pictures of Firestars with both long (close
to the prop) and short (lots of clearance) ailerons. How much difference is
there in ease of handling, control response, and trim? What would be the recommended
minimum clearance? It doesn't look too difficult to take a couple of sections
out of the aileron, but should I?
Bill Sullivan
Old Firestar
One inch of boom clearance is not very much, I have more on my MK III. The closer
the prop tips are to both the boom and ailerons, the more noise it will
generate.
You should us a prop extension rather than cut out your ailerons for more clearance.
have !!!
http://forums.matronics.com/viewtopic.php?p=166870#166870
Subject: | Re: Rear Spar Attachment questions |
There is very little stress on the rear spar attachment on a Kolb. The forces
involved insignificant compared to what you would find on attach points of the
main spar and the struts. You are correct that the bolt is not as strong in
bending as in shear, but given the little amount of force on a rear spar of a
Kolb, I would not think it would ever make a bolt fail.
You should post some pictures of the place you are talking about, but be aware
and be very careful, some parts of a Kolb are designed to have play in them, and
that tightening them againste each other rather than allowing them to " Float
" freely can cuase fatigue from bending and vibration that will cause something
to fail.
have !!!
http://forums.matronics.com/viewtopic.php?p=166871#166871
Subject: | 912 Engine Oil - to John Hauck |
From: | "Dave Bigelow" <up_country(at)hotmail.com> |
HKS recently put out a factory bulletin regarding fuel and engine oil. In a nutshell,
they say not to use fuel with more than 5% ethanol, and lower than 91
octane. Aviation gas is OK.
They say to only use synthetic automotive oil.
The 4 stroke Rotax and HKS engines share many similarities. In my case, I can
get 89 octane gas with no ethanol. I blend that 3:1 with 100/130 octane avgas
to end up with gas that is above 91 octane. It is known that leaded gas and
synthetic oil are not a good combination, but it appears that HKS owners are locked
in to using synthetic automotive oil.
John, you probably have more 912 time than anyone alive. I know you use avgas
during your cross-country trips, mainly because that is all you can get at many
airports. How have you dealt with the lead/synthetic oil problem?
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
http://forums.matronics.com/viewtopic.php?p=166872#166872
My MK III Xtra was very noisey, the prop noise going into a huge megaphone is a
very good description of the problem. The good news is that the noise can be
fixed, and a Kolb can become pretty quiet.
On my MK III Xtra, I put 1/2 inch ductboard in the Cabin anywhere it faces the
prop, and also under the engine ( Center Section ). Ductboard is rigid, fireproof,
oil and fuel proof on the foil side, and does a fair job of dapening sound.
I installed ductboard inside the lexan rear windows, and closed the back
space of the cage where it goes against the prop. This was so successful in
reducing the noise, that I can now communicate normally in the plane with headsets
and intercomm, I could not before... The plane is now enjoyable to fly
for long periods of time with out fatigue.
I did lose my view to the rear, but it was well worth it. I dont directly behind
me much, and given the choice of having an airplane that I could not fly without
going deaf, and one that is comfortable to fly, losing the rear visibility
is a very good tradeoff.
Second, I do use ANR headsets. The ANR headsets did not work well alone with the
huge roar of noise inside my life sized megaphone of a cockpit, but the headsets
along with the ductboard made noise a Non - Issue in my plane.
I will post pictures soon.
have !!!
http://forums.matronics.com/viewtopic.php?p=166873#166873
Rick N.,
If a person put a mild turbo on that one liter engine, I do not think it would
shorten the life of the engine to any depreciable degree. The turbo I am mounting
on my GEO 1.0L engine is about the littlest turbo you ever saw, in fact,
I bet it is the littlest turbo you ever saw!! It is made by Garrett, the 1544
model, made for engines around 800 to 1000cc range. By its size alone, it couldn't
produce much boost. Besides it's own limitations, I don't want it to put
out too much boost. The stock engine computer can handle barimetric changes up
to 5-6psi (above atmospheric). Meaning, if I limit the boost to 5psi, the O2
sensor and MAP (manifold air pressure) sensor can adjust the fuel flow automatically,
by way of the standard throttle body fuel injection.
Most peoples knowledge of turbos come from automobile applications. In those
situations, the engines are made to be borderline timebombs, sometimes doubling
or tripling the original engines hp and torque rating. I read all kinds of ads
on eBay about people claiming this turbo will produce 20lbs or 30 pounds ,
etc. of boost. For an airplane that would be obscene!! For a dragcar it's really
cool! (for a few minutes)
For those that aren't very familiar with turbos and boost, here is some basics:
A normally aspirated engine has to suck air in as the pistons are on their downstroke.
Atmospheric pressure is 14.7 psi at sea level. As your car engine is
running, the ECU (Electronic Control Unit) computer, by way of the fuel injection,
supplies the perfect amount of fuel at a given atmospherpressure. If you
climb in elevation,,,say, from Long Beach to Denver, the computer senses less
oxygen (by way of the O2 sensor) and leans the fuel to the appropriate amount.
If you happen to drive "down" to Death Valley where you are below sea level,
the the computer richen the fuel level a bit, because atmospheric pressure is
slightly greater below sea level. This ability to adjust the fuel/air ratio is
one of the HUGE advantages of using an auto engine conversion. Especially if
you are going to put a MILD turbo on it. If you want to build a screamer, then
that's another matter, but for a little bit of boost, then things are just fine.
So, what the heck does adding boost do? Here's what:
Remember we said barometric pressure is 14.7 psi. According to the fundamentals
of physics, if an engine is running properly with it's fuel/air ratio, and
it is normally aspirated, and this engine produces....say 100 HP at 3900 rpm.
If you force more air....say about 5 psi, by way of a turbo, and the computer
makes the appropriate fuel adjustment, we will have increased the power the same
amount as the boost percentage of atmospheric...which we said is 1/3 of atmospheric
(we are assuming the 5psi is about 1/3rd of 14.7...yeah, I know, but
it's close) Our power output in this example is now increased by 1/3rd, namely
133 HP. That's a fact, and one of the fundamentals of a "heat engine" (If you
took Thermodynamics in college.) If we add 15 lbs. of boost(which would be 2
atmospheric pressures, our engine will produce TWICE it's original HP output,
and if we give it 30 psi (that would be 3 atmos pressures, etc.)and so on.
But as usual, in physics, there ain't no free lunch, as they say!!! You do not
get every bit of your added boost back in usable performance. Some energy is
used up in turning the turbo (or supercharger, which is a belt driven turbo).
Some energy is lost in the added back-pressure of spinning the turbo. So, you
do lose "some" of the added power, to normal devices and friction, etc. to acheive
this extra power, but you do get to keep the lion's share in raw added performance!!
In my particular application, I have a run-of-the-mill basic grocery getter
GEO Metro engine. About 1000cc, and supposedly puts out about 62 HP. By adding
a small turbo, I should see around 75-80 HP, and about 107 ftlbs. of torque.
The GEO achieves these torque and horsepower figures of performance at about
1000rpm less than a Rotax 912 does.
A quick check of the Rotax 912 performance numbers says the 912UL has about 76
ftlbs of torque @4800 rpm. The 912S has about 96 ftlbs of torque @ 5100 rpm.
The GEO with a turbo (according to GEO Corp.) has 107 ftlbs. of torque at around
3900rpm. By allowing the significantly reduced lower cruise rpm, and corresponding
noise/prop/fuel reduction, this is what I am told by those that have
this setup obtain. We shall see!
If I set my cruise rpm to around 3500 (well into the power band and still possibly
exceeding a Rotax 912S's
maximum torque), the propeller swings @ 1555 rpm( I have a 2.25 to 1 reduction).
By being able to adjust the prop pitch (by way of the Ivo Electric In-Flight
adjustable propeller), this should make a very quiet, fuel efficient, fairly
strong powerplant. This is also how a GEO and turbo combination is able to
claim a fuel burn of about 1.75 gal/hr.
As I have previously said..."we'll see". These are the things I've heard, and
read, and am told by those that have a GEO with turbo. I make no claims until
I experience these results myself.
BFN, Mike Welch
Disclaimer:
This is email is NOT meant to be disparaging to any Rotax owners! If you have
a Rotax, and are happy with it, then I am happy for you. Rotax is a fine engine.
They're the best! You are NOT a fool, a moron, an idiot or any other insulting
name if your opinion and experiences differ from mine. You do not need
to agree with me, nor do you have to buy a GEO engine and try it out. You are
not required to have a contest of a GEO against a Rotax, carried out in ideal
weather conditions. And finally, the opinions stated here are my own, your
mileage may vary, and that's okay by me.
Connect and share in new ways with Windows Live.
http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_012008
Bill,
A prop spacer should help if you don't have one.
Ed FF # 62 ( working on wing)
Subject: | Re: project engine |
Mike,
While you are claiming to be this nice guy that would never say anything bad, you
are are taking any opportunity you can to take a cheap shot at me here on the
list. No matter what you say, your actions speak louder than your words.
There is also a very big difference between opinion and FACT. I dont care much
about your or other peoples opinions, that is up to them. When people dismiss
FACTS and give bad information to others, then you could use any of the terms
in your above post to describe them. People come to this list to get good
information, and it is our responsibility to give them the best information possible.
The only time I have a problem with what some post is when a few individuals
like yourself put list politics, and saving face above giving truthful
and accurate information to the many people that read this list.
Mike Bigelow
have !!!
http://forums.matronics.com/viewtopic.php?p=166879#166879
From: | "Denny Rowe" <rowedenny(at)windstream.net> |
Mike,
individuals like yourself put list politics, and saving face (((((above)))))
giving truthful and accurate information to the many people that read this
list.
> Mike Bigelow
> could have !!!
Mike,
I see the dislexia in this remark.
The comments Jetpilot refers to were well below your accurate information,
not above.
Heck it was even below your signature.
Denny Rowe
Subject: | aileron bellcrank and pulleys |
Kolb guys,
Seeing as how I had laproscopic surgery this past Wednesday (hernia), I
am laid up, being an email vulture. My wife has threatened me with severe
bodily harm if I go out and work on my MkIII today. Sshh!! What she does
n't know won't hurt me, I hope!!
My latest creation is with the aileron control system, a deviation from t
he one designed originally on this plane. Again, my apologies to those tha
t are offended at such a non-original modification( non-OEM). All I can sa
y is, unless your plane is exactly like the plans, don't beat me up too muc
h. I, like Fred Astair, did it MY WAY!!!
Yeah, I know it wasn't Fred Astair, it was Frank Sinatra. I was just see
ing if you were paying attention. Back to my point. As I was saying, I wa
s never a fan of the double hinge design, having to twist the flaps a littl
e to get to the ailerons. I explored a couple of alternatives (hydraulical
ly actuated and Morse cables), but the truth is, the one that seemed to be
the easiest and most standard as seen in "factory iron" is the old tried an
d true pulleys, bellcranks, and cables.
Enclosed find a few photos of my latest modification. I might add this s
ystem is ROCK SOLID!! There is NO slack, the ailerons move effortlessly, a
nd they still retain the quick disconnect ability, for folding wings. All
parts were designed and custom built by me. I used authentic aircraft bell
crank bearings, cable pulleys, cables, turnbuckles, and 6061 T6 aluminum.
The fact is, this is a simple design, and could have quite easily been an
original system in the first place. The main thing is, I still can swings
the wings, same as before.
You may also notice in the last photo my MkIII Classic to MkIII Xtra conv
ersion is coming along quite nicely. (Are you still paying attention? Read
that last sentence, again.) The side-swinging doors are painted, and ALL l
exan is cut and ready to install, as soon as I finish fabric and paint. (E
nd of March, I hope) Then on to finishing the GEO with turbo installation.
I share these modifications with those of you that have an interest in "n
on-standard" applications. I respect those of you who maintain your desire
to retain your plane "as per plans", if that's your preference. If you d
on't care for my mods, I understand. As Rick G said once This is experimen
tal aircraft." I am the kind of guy that does NOT wince at the amount of w
ork involved to accomplish what I want.
For your perusal and comments, find the following photos.
Mike Welch
MkIII
PS. I have more photos and details if anyone is interested. I can tell yo
u it took a couple of "tries" to get it right. There is some learning less
ons about pulleys a person needs to know. Oh yeah. Parts cost about $200.
08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/9j/4AAQSkZJRgABAAEASABIAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE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/9j/4AAQSkZJRgABAAEASABIAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE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2gAMAwEAAhEDEQA/ANnFegeaGKAExQFgxQAYoEJigAxQAYpgJigAxQAYoGGKBBigBMUAGKAE20AG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Subject: | Re: 912 Engine Oil - to John Hauck |
How have you dealt with the lead/synthetic oil problem?
> Dave Bigelow
Hi Dave B:
Generally, we use a synthetic blend on long flights with a steady diet of
100LL, and shorten the oil change cycle to 25 to 50 hours, or whenever it is
convenient to change oil. John W and I have used Valvoline Durablend
Semi-Synthetic with good results.
With my newest 912ULS I started out with Shell Rotella Full Synthetic, and
have used a 50/50 blend of Rotella Syn and Rotella Organic oil when flying
cross country.
I think I am going to go Shell Rotella Full Synthetic full time this next
year and try to keep tabs on how much lead is left in the bottom of the oil
tank at each oil change. The primary reason for running semi-sythetic is
synthetic does not suspend lead well, and organic oil does a better job of
suspending lead so you can dump it overboard at each oil change.
Lead is heavy and will find little nooks and crannies in the engine and oil
tank to settle and harden. I am told it is a good lube for valve seats, but
will harden and clog oil passages, plus cause accelerated wear on cams
lobes, lifters, rocker arms, ect.
Rotella Full Syn is cheaper than the other synthetics and readily available
at Walmart, which makes it easily obtainable during long cross country
flights. I can also pick up my Fram TG3614 oil filter while shopping
Walmart.
Subject: | Re: Rear Spar Attachment questions |
> You should post some pictures of the place you are talking about, but be
aware and be very careful, some parts of a Kolb are designed to have play in
them, and that tightening them againste each other rather than allowing them
to " Float " freely can cuase fatigue from bending and vibration that will
cause something to fail.
> Mike
Mike B:
I don't know where you got the above info.
My understanding is "play and float" are not designed but rigged into the
Kolbs because of the folding wing capability. They have to be a little
loose and making some hardware which connects less than precise helps in
unfolding and folding the Kolb.
All three of my Kolbs were rigged to fly without folding. That means I
tighten everything down nice and snug. Inititially, because I did put a lot
of time on all my Kolbs in a short period of time, we drilled and welded
bushings in the lift strut fittings so we could snug them up tight. This
prevented elongating the holes and wearing out bolts from vibration. My
mkIII has well over 2,700 hours with no indicated problems with stress
failure because I have a nice tight airplane. In addition, the rear wing
attachments, universals, are snugged up nice and tight. I have to loosen
them up if I intend to fold a wing or remove a wing.
Take care,
john h - Disagreeing with someone's post on the Kolb List does not
necessarily indicate the individual is personally attacking that individual.
Referring to members of the Kolb List, at large, as idiots, stupid, and
dumb, is enough to get the hair up on the back of my neck.
Subject: | Re: project engine |
Mike Welsh,
Last year you gave innacurate information and very wrongly stated to this group
that:
mdnanwelch7(at)hotmail.co wrote:
> It was tubulence!! A GPS's antenna cannot "hone" in on the required
> satelites if it is being shaken all over the place.
Instead of being enough of a man to admit being wrong, you went on to dance around
your first statement in which you were very clear in what you said said,
and very wrong. Everyone can read it all here:
http://forums.matronics.com/viewtopic.php?t=26663&postdays=0&postorder=asc&highlight=gps+hone&start=0
The fact that VG's work is well documented FACT, not an opinion, as you would clearly
like to imply. You want to supress accurate information by calling it
" Opinion ", which is a disservice to this group.
The fact that your last post was nothing but critisizing spelling and resorting
to calling me a " know it all " just shows everyone that you are unable to support
your position with facts. I never claimed to know everything, but I make
it a point to be very knowlegable on the subjects that I write about. I if
I see someone posting bad information to the list, I will point it out.
Your spelling is impeccable, but your aviation knowlege is very limited. Given
you history of being wrong on more important aviation matters, I would suggest
that you join a spelling forum, im sure everyone will benefit from your spelling
knowlege.
Lastly, you are using terms far more offensive than anything I have ever used on
this list. Look in the mirror when you wonder why some people leave, because
you are taking every opportunity to post insulting comments, and use far more
offensive language than I have ever used. Trying to hide it in a bunch of
flowery praise for your friends does not fool anyone, you complaining about me
in the same breath that you do the same and worse makes you nothing short of
a hypocrite.
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=166921#166921
Subject: | Re: aileron bellcrank and pulleys |
Very nice work Mike, I really like that idea ! My ailerons get " Springy " due
to the long torque tubes on the trailing edge of the wing that actuate them
twisting under flight loads. I get maybe 10 degrees or less aileron travel in
the air, while I am getting 30 degrees or more on the ground. Your modification
will eliminate this problem, and keeping the wings foldable, thats just a
bonus.
Being that my plane is already flying, it would be difficult to change to a cable
system, so I am trying a different approach. I am installing spades on the
ailerons to bring down the forces to where the long aileron tubes do not twist
anymore. I really like the idea of having a MK III with light, responsive ailerons.
have !!!
http://forums.matronics.com/viewtopic.php?p=166931#166931
Mike,
There is one thing that worries me in your aileron modification. You have four
long peices of angle aluminum holding a bellcrank that are being loaded with
a bending force. Even angle aluminum does not have great streingth in at that
leingth. The forces on the cable will be several times what the forces are
on your stick due to the mechanical advantage created with the stick, pulling
the bellcrank in with a lot of force. In a situation in the air, where you
pull very hard on the stick , you might have enough force to bend those 4 long
peices of angle aluminum inwards permanently, or at the very least get somewhat
of a give and springy feeling.
I would suggest using some of that same angle aluminum to create a " Triange "
that would make that area many times stronger to bending inwards, and preclude
the possiblity of any springy feeling under load, or even more importantly prevent
those from bending permanently inside the wing. The easiest way would be
to what I have described would be to add two small peices of angle aluminum
as shown in the attached picture. ( Put the same angle aluminum you have been
using where the red lines are, top and bottom. )
have !!!
http://forums.matronics.com/viewtopic.php?p=166938#166938
http://forums.matronics.com//files/aileron_bellcrank_photos_001_132.jpg
> One inch of boom clearance is not very much, I have more on my MK III.
The closer the prop tips are to both the boom and ailerons, the more noise
it will generate.
> Mike
Mike B:
Last flight to Alaska I had 3/4" prop/tailboom clearance with a 72" Warp
Drive.
Replaced the prop with a 70" Warp Drive on my return home, primarily for
noise reduction.
> Mike,
> While you are claiming to be this nice guy that would never say anything
> bad, you are are taking any opportunity you can to take a cheap shot at me
> here on the list. No matter what you say, your actions speak louder than
> your words.
> There is also a very big difference between opinion and FACT. I dont care
> much about your or other peoples opinions, that is up to them. When
> people dismiss FACTS and give bad information to others, then you could
> use any of the terms in your above post to describe them. People come to
> this list to get good information, and it is our responsibility to give
> them the best information possible. The only time I have a problem with
> what some post is when a few individuals like yourself put list politics,
> and saving face above giving truthful and accurate information to the many
> people that read this list.
> Mike Bigelow
Mike B:
This is none of my business and I probably should not respond. However, it
does affect everyone on the Kolb List that reads it.
Since you didn't post a reference, I had no idea what you were talking
about.
Second, it is clear this message is between you and Mike.
Please take this type correspondence bc.
I know, I know, I have a delete key. I was hoping we could get beyond the
delete key, post Kolb stuff, and cease personal judgements.
mkIII - Working on my first cup of coffee. Grey, cold, windy at hauck's
holler, alabama.
John H.
You are correct, I deleted this and my previous message off the forum about 5 minutes
after posting it. Upon reading it after posting, I decided that this
was just turning into a pissing match that was going nowhere, so I have deleted
both my messages in this thread. I would rather talk about building and improving
Kolbs than dealing with stuff like this.
The edit feature does not work for the email part of the list, so just delete the
couple posts and we can get on with the more important business of talking
about Kolbs :)
have !!!
http://forums.matronics.com/viewtopic.php?p=166973#166973
John,
I am not trying to tell him not to tighten the rear wing attachment on the ultrastar,
I am just telling him in general to be very careful and have an understanding
before doing that type of thing. One example is that some people have
wanted to tighten up the front attachment of the horizontal stab, which will
cause failure of the tab over time due to flexing when it cant float free on its
attachment bolt.
Bottom line is that if someone is not sure, then they should not do it until finding
out from someone here on the list or from Kolb.
have !!!
http://forums.matronics.com/viewtopic.php?p=166981#166981
Hi,
I would like to get in touch with Canadian Kolb owner, "C-IDFG"
(pictured on UPAC homepage).
Dave
CYEL
C-IIII
Subject: | Re: FireStar Cockpit Noise Reduction? |
John,
I too was surprised by the MK-3 W/2200 Jabiru prop noise level..Hi tech foams
offered a 1/2 in thick dense foam sound control product, and I lined ALL the
rearward facing plexiglas and the complete center cover top,.spar carry thru,doubled
that piece,and wing root ends.It has foam on the inside of the fabric behind
the seats to the rear of the fuselage.Now with the ANR kits installed in
my 30 year old DC H-10-30's with foam covers and leather bags over the mic's
I can adjust the VOX on the intercom to talk to my passenger at cruise power
settings under 2800 rpm but at full throttle it will open the mics.The ANR kits
from Headsets Inc. @169.00 each were worth it! G.Aman .3iginal Message
Sent: Thursday, February 28, 2008 3:50:19 PM
Subject: Re: Kolb-List: Re: FireStar Cockpit Noise Reduction?
Kolb-List
message
posted
by:
"John
Hauck"
The
single
most
effective
thing
you
can
do
is
get
yourself
a
set
of
ANR
(Active
Noise
Reduction)
headsets.
MAN,
what
a
difference
they
made
for
me!
Dennis
Kirby
Dennis:
Got
your
bag
packed
for
MV?
I
tried
the
best
Litespeed
had
to
offer
when
they
first
came
out
without
success.
Then,
last
summer,
I
bought
the
best
that
David
Clark
had
to
offer
the
XL
somethings.
Neither
would
work
in
the
cockpit.
The
set
that
worked
best
for
me
was
the
DRE6000,
which
unfortunately,
is
out
of
business.
Got
my
fingers
crossed
my
old
set
will
keep
on
trucking.
john
h
Bag
packed
for
MV
2008.
The
Kolb-List
Email
Forum
Use
the
Matronics
List
Features
Navigator
to
browse
the
many
List
utilities
such
as
List
Un/Subscription,
Archive
Search
Download,
7-Day
Browse,
Chat,
FAQ,
Photoshare,
and
much
much
more:
MATRONICS
WEB
FORUMS
Same
great
content
also
available
via
the
Web
Forums!
List
Contribution
Web
Site
Thank
you
for
your
generous
support!
-Matt
Dralle,
List
Admin.
Subject: | Re: Entry-Level ANR Headsets |
> Yessir - I'm planning to attend MV-2008! Lookin' forward to seeing all
> my Kolb friends again!
> At Monument Valley last year, Larry Cottrell was gracious enough to let
> me borrow his DRE-6000 for one flight in my Mark-3, so I could compare
> them to my current set of LightSPEED-QXC ANR headsets.
> Dennis K,
Dennis:
Marv Golden has them for 285.00.
I may try and talk you into letting me fly with yours at MV for comparison
to the DRE6000.
One nice feature of the DRE is the ability to operate the headset from the
aircraft 12VDC electrical system. However, cameras need batteries, and I
carry a battery charger with me for them, so another couple batteries for
the headset would not be that much of a bother.
Reason I am getting info on an alternative anr that works in a Kolb MKIII is
when the DRE bites the dust. I am going to need a replacement and one never
knows when the headset is going to go belly up.
Can anyone give me updated news on a possible "mono-float" being
available for Kolbs?
Dave
Mike B.
VERY perceptive!!
FYI, I was going to do that EXACT reinforcement!! I just hadn't gotten to it,
yet. There is a minor adjustment to the central bellcrank I need to do first.
Once absolutely EVERYTHING is where it should be, then I was going to do any
additional reinforcement bracing, those red lines being the primary braces
I knew I would add. You are two steps ahead of me. I'm getting there.
BTW. When I ordered my angle aluminum from Aircraft Spruce, I didn't know which
thickness to get, so I got the 1/8th" thick angle. OMG, too thick!! This
stuff is industrial duty at this thickness. But still, it needs the reinforcement
at the location you pointed out, regardless of it's thickness, just as a
matter of proper design.
Mike Welch
> Subject: Kolb-List: Re: aileron bellcrank and pulleys
> From: orcabonita(at)hotmail.com
> Date: Fri, 29 Feb 2008 12:15:05 -0800
> To: kolb-list(at)matronics.com
> Mike,
leingth. The forces on the cable will be several times what the forces are on
your stick due to the mechanical advantage created with the stick, pulling the
bellcrank in with a lot of force. In a situation in the air, where you pull
very hard on the stick , you might have enough force to bend those 4 long peices
of angle aluminum inwards permanently, or at the very least get somewhat of
" that would make that area many times stronger to bending inwards, and preclude
prevent those from bending permanently inside the wing. The easiest way would
be to what I have described would be to add two small peices of angle aluminum
> Mike
> Mike
> "NO FEAR" - If you have no fear you did not go as fast as you could have !!!
Shed those extra pounds with MSN and The Biggest Loser!
http://biggestloser.msn.com/
that 20-50 durablend is getting hard to find. I use it in a mix with
another weight in my suzuki.
BB
>> Dave Bigelow
> Hi Dave B:
> diet of 100LL, and shorten the oil change cycle to 25 to 50 hours,
> or whenever it is convenient to change oil. John W and I have used
> Valvoline Durablend Semi-Synthetic with good results.
> Synthetic, and have used a 50/50 blend of Rotella Syn and Rotella
> Organic oil when flying cross country.
> this next year and try to keep tabs on how much lead is left in the
> bottom of the oil tank at each oil change. The primary reason for
> running semi-sythetic is synthetic does not suspend lead well, and
> organic oil does a better job of suspending lead so you can dump it
> and oil tank to settle and harden. I am told it is a good lube for
> valve seats, but will harden and clog oil passages, plus cause
> accelerated wear on cams lobes, lifters, rocker arms, ect.
> available at Walmart, which makes it easily obtainable during long
> cross country flights. I can also pick up my Fram TG3614 oil
> filter while shopping Walmart.
> john h
> mkIII
From: | "Dave Bigelow" <up_country(at)hotmail.com> |
Thanks for the feedback, John.
Do you change the filter each time when doing the 25-50 hour cycle, or wait until
the recommended interval?
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
http://forums.matronics.com/viewtopic.php?p=167043#167043
wait until the recommended interval?
> Dave Bigelow
David B:
Change the oil filter each time I dump the oil tank. Hopefully, this will
also help reduce lead in the system.
> BB
Bob B:
Walmart doesn't carry it, but Auto Zone does, as well as other popular auto
parts stores..
From: | "John Williamson" <kolbrapilot1(at)tx.rr.com> |
Since I only fly the Kolbra, I can't comment on anything I don't have first hand
knowledge on.
But I can post videos and pictures of flying a Kolbra.
Comments are not needed or wanted. Just look at the videos.
It can also be seen at:
http://www.youtube.com/watch?v=fpM_-8xuEOw
John Williamson
Arlington, TX
Kolbra, 912ULS
http://home.tx.rr.com/kolbrapilot
http://forums.matronics.com/viewtopic.php?p=167048#167048
Subject: | Re: Re: FS II perfomance |
Jim,
my Firestar,419# 503dcdi ivo3 6100rpm on takeoff would fly 70 mph @5700.Try winding
up that IVO a little.On take off,initial rpm was below 6000 but within 3or
4 seconds was above 6000.You will have to tune the carbs to get 1100-1150 egts
at cruise. but it will go faster than you are currently seeing with a little
tweaking.
----- Original Message ----
Sent: Thursday, February 28, 2008 5:12:07 AM
Subject: Kolb-List: Re: Re: FS II perfomance
Howard,
My FS II cruises comfortably at about 57 mph, straight & level, no
wind. That requires about 5400 rpm. I've never tried to go all out top
speed wide open yet except taking off. It stalls at 36 mph. I've seen 65
mph airspeed with a 37 mph gps ground speed, and I've seen 55 mph airspeed with
85 mph gps groundspeed, depends on the wind. I've heard a lot of
claims of much faster airspeeds speeds and much lower rpms, but that's the
straight bull on mine.
My plane weighs 440 empty, no fuel, I weigh 210. It has the 503
DCDI, 3 blade IVO prop 66". I would like to cut weight on it, but there's
nothing I want to take off. I'm pretty darn happy with it just the way it
is.
Jimmy Young
FS II, N7043P
59 hrs on it & climbing. (my time)
-----Inline Attachment Follows-----
BEGIN:VCARD
VERSION:2.1
N:;Jimmy
Young
FN:Jimmy
Young
TEL;HOME;VOICE:281.499.6298
ADR;HOME:;;3610
Cobleskill;Missouri
City;TX;77459
LABEL;HOME;ENCODING=QUOTED-PRINTABLE:3610
Cobleskill=0AMissouri
City,
TX
77459
EMAIL;PREF;INTERNET:jdy100(at)comcast.net
REV:20080228T101207Z
END:VCARD
Subject: | Re: Kolbra Flying |
> John Williamson
Morning John W:
I did look at the videos. Made me hungry to go flying, soon as the weather
decides to cooperate.
While I was in YouTube I discovered all 16 of your videos, to include one of
Miss P'fer shot at the Kolb Homecoming last year. Thanks for posting it.
http://www.youtube.com/profile_videos?user=kolbrapilot&p=r
Enjoy John W's videos and stay out of trouble. Spring is not far away.
Good Morning John H.,
Would you be kind enough to post the dates for the upcoming Monument Valley Informal
Fly In, please?
I would love to attend, even if it is by way of my big truck, whilst I am on my
way to Missouri to build my shop.
If that is the method I have to use to attend (as I'm moving and happen to be passing
by), at least I will be towing my Kolb on my big flatbed construction trailer.
I don't know if I will be 100% finished at that time, but at least I will be
100% finished with the airframe, paint, and engine. Interior components may still
be being installed.
I am installing an Icom A200 com radio, King KT76TSO transponder, Sigtronics
intercom, Dynon D10A EFIS, and Garmin 296 GPS, with built-in Air Gizmo panel dock.
These items, along with the various fabrication of avionics mounts may take
a little time.
Thanks for the dates,
Mike Welch
MV 08 if kept true to the past,,, will be the weekend after mothers day,,
May 16 - 18
Boyd
Much obliged, Boyd. It appears as though I WILL be there. May not be able to
fly my Kolb quite yet, but can certainly tow my plane on a trailer. As I said,
my plane may be virtually finished, but it's too soon to be guessing the first
flight date. I should be incredibly close, though, by mid-May.
Those dates for the Fly-In are definitely before I can head to Mo. My wife is
still teaching the school kiddies until the 23rd of May. I hope to see you
and all the other guys there.
Best wishes from the south west corner of Utah, Mike W.
Need to know the score, the latest news, or you need your Hotmail-get your "fix".
http://www.msnmobilefix.com/Default.aspx
Subject: | Changing formats |
Kolb guys,
Can anyone tell me how to change the text formatting style I have with this list.
Presently I have the "plain text" style for the emails I send. This style
is incredibly limiting, and if I had the option, I would prefer the "rich text"
version.
I have tried looking into the change myself, but can't seem to find a place that
offers a choice. Yet, I DO see other members that have the "rich text" version.
Mike Welch
Helping your favorite cause is as easy as instant messaging.You IM, we give.
Subject: | Re: Monument Valley |
Valley Informal Fly In, please?
> Mike Welch
Hi Mike W:
Most of us get there on Thursday and depart on Sunday. Normally, we choose
the weekend between Mothers Day and Memorial Day.
This year that falls on 22-25 May 2008.
The Unplanned/Unorganized Kolb Flyin Monument Valley, UT, is just that. No
jobs, no titles, no duties. It is a flyin for Kolb aircraft and we
encourage folks to fly their Kolbs to Gouldings Air Strip at Monument
Valley. However, if you can't flyin, then haul it in. If you don't have a
Kolb, that's alright, fly what you got. Most of us that fly in also camp in
a tent in the Camp Ground at Gouldings, eat our meals in the Restaurant and
Snack Bar at the Service Station. There is a indoor swimming pool, showers,
and the works at the Camp Ground. You can book tours of Monument Valley
with Gouldings for a close up look on the ground. You will be comfortable
if you come in an RV. It is a fair walk from the Camp Ground to the
Restaurant and the airstrip, so bring you hiking boots or bum a ride with
somebody that didn't fly in. We have had people from all over the world
visit us at the Kolb Flyin MV.
Here is Gouldings web site for full info:
http://www.gouldings.com/english/index.htm
We always have a good time meeting new and renewing old friendships. For
some of us this will be the 6th Kolb Flyin we have flown into at MV.
day,,
> May 16 - 18
> Boyd
Boyd:
I did it the opposite way. Looked at May, figured the last weekend was
Memorial Day weekend and picked the previous weekend.
Let's change my dates to Boyd's, unless there is someone that objects.
If you get there a day early, on Thursday, then the early bird date is 15
May and the regular dates are 16-18 May 2008.
Sorry about that.
From: | "Mike & \"Jaz\"" <planecrazzzy(at)yahoo.com> |
Subject: | Format style ( Test) |
Hi Mike,
Just Testing here....This message was sent from
my regular Yahoo email site...where I have all the options to
do like regular mail....
Let's see if the matronics site filters it....
Gotta Fly...
Mike & "Jaz" in MN
PS mailed to - kolb-list(at)matronics.com
Posted: Sat Mar 01, 2008 10:24 am Post subject: Changing formats
Kolb guys,
Presently I have the "plain text" style for the emails I send. This style is
version.
Mike Welch
Buttercup - STOL - Aircraft
http://groups.yahoo.com/group/Buttercup-STOL/
Firestar I&II - STOL - Aircraft
http://groups.yahoo.com/group/Kolb_Firestar/
My Web Site:
http://www.geocities.com/planecrazzzy/Planecrazzzy.html
Sometimes you just have to take the leap and build your wings on the way down...
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
> Sorry about that.
> john h
> mkIII
These dates work better for me. I will plan on being there!!
Mike Welch
Hey Mike!!!
Yes, it came through to me, in BLUE, with large print. I even got to see a picture
of "Miss Lucky Stars, and wait!! Could it be?? The one and only....Jaz??
Awesome. Thanks for your help. Maybe my problem (i know, I have many), but
my problem in THIS case is my email server. I'll try to sign up with a new Yahoo!
account.
Appreciate your help, Mike & Retro
> Date: Sat, 1 Mar 2008 11:38:23 -0800
> From: planecrazzzy(at)yahoo.com
> Subject: Kolb-List: Format style ( Test)
> Hi Mike,
> Gotta Fly...
> Mike & "Jaz" in MN
> [http://forums.matronics.com/templates/Matronics/images/icon_minipost.gif]Posted: Sat Mar 01, 2008 10:24 am Post subject: Changing formats
> [http://forums.matronics.com/templates/Matronics/images/lang_english/icon_quote.gif]
> Kolb guys,
version.
> Thanks,
> Mike Welch
> My Web Site:
Subject: | powder coating little parts |
Kolb group,
Good morning. I was wondering if anyone has ever tried using one of those inexpensive
"powdercoat at home" things? I have seen them advertized for about $50, and then
you buy the
powder color you want. Thank you for your help.
Dudley
Building a MkIII
Looking for last minute shopping deals?
I do believe someone on the Trike list is a bit Jealous..8-) hahahaha
Pulled this off the Trike list this morning...
Abid of Tampabay Aerosports is complaining about=C2-how you KOLBers =C2
are able to show the world what Great! climb out performance you have
And =C2-get away with it.... =C2-I'm =C2-guessing hes refering to =C2
-Sun N Fun hahaha=C2-
Imagine the noise he'd make =C2-if VGs were a standard Option =C2-hahaha
ha 8-)=C2-
Mark
Every year it pisses me off that the Kolb guys which fly nose down=C2-
(due to their AOI)can climb out like the space shuttle without=C2-
breaking the 30 degree max. rule and I get scolded for climbing out=C2-
at anything over 700 FPM at 55 MPH.=C2-
Same here, blue in big print, I think Hillery in Maine uses the same type of print.
I am getting the mail on Cox, maybe it depends on who is the mail server.
Ron (Txaz) >:-)
Yup cox has the same options
---- Mike Welch wrote:
Hey Mike!!!
Awesome. Thanks for your help. Maybe my problem (i know, I have many), but my problem
account.
> Hi Mike,
> Gotta Fly...
> Mike & "Jaz" in MN
> Kolb guys,
version.
> Thanks,
> Mike Welch
> My Web Site:
kugelair.com
Well if I recall correctly he has a business selling trikes
( http://www.tampabayaerosport.com ),
and I guess after all the marketing hype he goes to show a client his trike, and
here comes a Kolb climbing like a bat out of hell. If I recall the fellow is
from Pakistan and he had run in with the Russian that sells the SPG-2 RDU for
the Suzuki engine. Sometimes its very funny in this business.
Ron (Txaz)
Abid of Tampabay Aerosports is complaining abouthow you KOLBers
And get away with it.... I'm guessing hes refering to Sun N Fun hahaha
Imagine the noise he'd make if VGs were a standard Option hahahaha 8-)
Mark
kugelair.com
Subject: | Re: powder coating little parts |
Which two part primer and paint did you have such good results with Ron ? I see
several of them advertised, but don't know which one is best.
have !!!
http://forums.matronics.com/viewtopic.php?p=167281#167281
I had very good results with the 2 part white paint, too, and it's easy
to repair. Seems like I got mine from Jim &
Dondi. Lar.
see several of them advertised, but don't know which one is best.
> Mike
have !!!
This is horrible but I can't remember the Manufacturer. I can see it in my mind's
eye exactly where the cans sit on my work table 1200 miles away from here,
but can't remember the name. However a few years ago we spoke about powder coating
and I did name the epoxy. Somewhere in the library there is a mention of
that manufacturer. I can say this, if you leave the crap in one of those little
clear plastic cups it will melt it. Its some strong stuff and you ought to
use a respirator, I do.
Ron (Txaz)
have !!!
kugelair.com
Subject: | New camera position |
Finally got the vibration out of the wing camera today.
Now when it' gets nice I can shoot some new stuff.
Just wish "Goggle" & "Youtube" didn't degrade the
videos so bad....but they're free.
http://video.google.com/videoplay?docid=-2825309555058763666
Subject: | Re: New camera position |
Looks good... how did you mount the camera to avoid the vibration?
Even my non-flying wife liked your video.
Vimeo is another video sharing site that lets you upload high definition
(1280x720) video.
-Dana
"Next year in Galt's Gulch!"
A friend has one; does good on small parts.
Howard Shackleford
FS II
SC
In a message dated 3/2/2008 9:52:14 A.M. Eastern Standard Time,
airspeedx3(at)yahoo.com writes:
Kolb group,
inexpensive
then you buy the
Dudley
Building a MkIII
(http://www.matronics.com/Navigator?Kolb-List)
(http://www.matronics.com/contribution)
**************Ideas to please picky eaters. Watch video on AOL Living.
(http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/
2050827?NCID=aolcmp00300000002598)
Hey Possum
NICE footage..
But I would like to offer up one suggestion as a PROFESSIONAL Still =C2-Ph
otographer...
When you attached your camera jack up the tail of the plane so that the wing
s AOA
is closer to what you would have when in level flight... That way your foota
ge wont=C2-
look as if your always climbing=C2-or flying on the edge of stall.. 8-)
=C2-
Other than that I enjoyed the clip.... =C2-Are those air scoops I see on t
he side of =C2-your bird?
Check out a recent article & Pic. =C2-I submitted to Barnstormers.com
http://www.barnstormers.com/eFLYER/2008/010-eFLYER-FA03-hanggliding.html
Mark=C2-
-----Original Message-----
Sent: Sun, 2 Mar 2008 8:57 pm
Subject: Re: Kolb-List: New camera position
=C2-
=C2-
Finally got the vibration out of the wing camera today.=C2-
Now when it' gets nice I can shoot some new stuff.=C2-
=C2-
Just wish "Goggle" & "Youtube" didn't degrade the=C2-
videos so bad....but they're free.=C2-
=C2-
http://video.google.com/videoplay?docid=-2825309555058763666=C2-
=C2-
============C2-
============C2-
============C2-
============C2-
=C2-
=C2-
>you upload high definition (1280x720) video.
>-Dana
I put it here
http://www.veoh.com/videos/v6316944zRsxJ3ra -
it looks a lot better,
but I had to download a program to be able to watch it in high def.
Don't think many people would be willing to do that.
the plane so that the wings AOA
flight... That way your footage wont
look as if your always climbing or flying on the edge of stall.. 8-)
I am always climbing or on the edge of a stall.8-)
Just set the thing up and guessed at level this time.
>of the plane so that the wings AOA
>flight... That way your footage wont=C2
>look as if your always climbing=C2 or flying on the edge of stall.. 8-) =C2
Subject: | OT (almost): XWind |
IMO much of the pucker factor in Xwind landings comes after the wheels
are on the ground. If you transition to putting the tailwheel down
quickly (thinking the hard part is over), the wing angle has increased
quickly and you gotta be ready with a lot of aileron for the wind that
will catch under the upwind wing, not to mention have your happy feet
ready to keep it from weather-vaning (leading to ground looping).
Here's a recent good video showing the big boys can have the same problem.
http://www.cnn.com/video/#/video/international/2008/03/03/plane.drift.clip.cnn
-Ben
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: OT (almost): XWind |
>-Ben
Ben,
If it had been a high wing Kolb, he could have side slipped it on down and
planted the up wind wheel and kept it straight. If you can keep a Kolb
locked on the center line in a crosswind with a side slip, the landing is a
non event. If you can't keep it on the center line, it is time to make a
straight into the wind landing on a taxiway and hope someone is there to
wing walk you to some safe area.
With a low wing and tricycle gear, he had to crab into the wind to keep
close to the center line and at the last second straighten it out and get
the up wind wing down. Too much to do with too little time to get it done.
They were lucky he got it back off. The Kolb has the advantage that it does
not have much fuselage aft of the main wheels to weather vane.
Jack B. Hart FF004
Winchester, IN
Hi all
Jim here
Not one to brag BUT I get 1000 Fpm climb at 40 mph indicated in my UltraStar
Jim.
UltraStar 503 dcsi
N2613M
In a message dated 3/3/2008 2:50:52 P.M. Central Standard Time,
jb92563(at)yahoo.com writes:
--> Kolb-List message posted by: "jb92563"
Good catch of the day guys......I can barely stop laughing long enough to
hit send. [Laughing]
I'm sure every Kolber just has a big grin right about now.
http://forums.matronics.com/viewtopic.php?p=167450#167450
**************It's Tax Time! Get tips, forms, and advice on AOL Money &
Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001)
From: | william sullivan <williamtsullivan(at)att.net> |
Subject: | Firestar project |
I mounted up one wing per instructions from Dennis at TNK. The only change I
made was to fabricate a forward wing adapter channel, to make up the 2 1/2" difference
between the airframe wing brackets and the wings that are being fitted
to the plane. I chose to make the channel instead of using structural channel.
Structural channel has a sharp outer corner, and a tapered flange. The sharp,
squared corner would not let me get a flush, uniform fit to the old bracket
welded to the inner steel rib. I did not like the tapered flange of structural-
it could start wearing unevenly on the bolt, and the thin part of the taper
was where the load was. I heated and formed a rounded edge channel 2 1/2" wide
x 2 1/2" long with a 1" flange, made out of 1/8" hot rolled flat stock. Three
5/16" bolts secured it to the wing bracket, and when the AOA was right the
last hole for the wing pin was centered nicely on the other flange. I did have
to run a rope out to a tree to hold the wing for
marking- the wind was erratic today, and kept swinging the wing back.
The wing folds right back, but the wing holding bracket supplied by TNK was
not lined up with the new wing's holding tube. The wing's tube was about 9" to
the rear, actually past the end of the fuselage main tube. I took some flat
stock and made a couple of "J" brackets. I welded a 1/2" nut to the back of the
upright of the "J", and cut a piece of 1/2" threaded rod to go through the holding
tube. I padded the "J" brackets with some rubber moulding held on with
plastic ties. Slide one end through, spin the other "J" bracket on, and set the
wing in place. It takes about one minute to assemble, and gives me a lot more
ground clearance than if the wings had fit. No flying weight added, either.
Prop clearance is now about 3" from the aileron. I had to order a couple of longer
aileron control tubes from Travis at TNK- mine were about 2" too short.
All the snow finally softened up to the point where I could clear off the tarp
on the other wing. It is in my living room, and the patches are fewer and
smaller than the first one.
The Pre-Val spray kits are $4.99 at my local NAPA store, and I picked up a
laser digital thermometer from Harbor Freight for about $40.00. Works great.
So far, so good.
Bill Sullivan
old FS
Subject: | Vamoose for Sale |
Folks, the time has come. Ol' Lar is getting ready to retire, and
preparing for a life of traveling. These plans don't have room for more
toys beyond the boat and the camper, so Vamoose has got to go.
For all you want to know about Vamoose, look on my website at
www.gogittum.com and click on the "Building Vamoose" link. You're also
welcome to email me direct at: biglar(at)gogittum.com
I don't want to make this a long, drawn out process, so I'll sell this
complete Mk III Classic for $10,500.00, including the trailer. I have
something over $30,000.00 invested in it. (I stopped counting at
$24,000.00, and that was a long time ago) All that's needed to finish
it is a reduction drive for the engine, (or a different engine) a
battery, and cleaning of the fuel system. Prob'ly will need new fuel
pumps, too. Prop is a 3 blade 72" Warp Drive with nickel leading
edges. Trailer had new tires and fresh packed bearings for the 800 mile
tow from Palm Springs, CA to Santa Fe, NM last year. It towed smooth
and easy at 65 - 70 mph, and could hardly tell it was back there.
The plane is in the trailer and stored at Santa Fe, NM airport. It's
registered as "Experimental" and is numbered "N78LB."
Lar.
P.S. In the near future, Der Bug is also going up for sale. It's a
1969 VW Beetle with the Baja Bug conversion, 2110cc engine, (same as on
Vamoose, but with dual Webers instead of fuel injection) Many, many
upgrades and extras, and I'll sell it for $5,500.00.
P.P.S. Sorry, but I won't be seeing you at Monument Valley this
year. I hope y'all enjoy yourselves up there. It's a great place and I
have a lot of great memories of previous trips.
Subject: | Lost mold strut faring |
From: | "Nelson, Craig" <craig.nelson(at)heraeus.com> |
<> St <> ar <> te
<> d <> a <> st
<> ru <> t <> fa
<> ring for the bottom of the strut today step 1 I applied
food wrap to the fusladge
Step 2 I covered thr spar with paper
Step 3 with masking tape I made the desired shape
Step 4 with gauz and plaster I covered the masking tape
Step 5 removed the plaster part from the plane
Step 6 cleaned it up now it"s ready for the resin and glass
Uncle craig
From: | "KOLB AIRCRAFT" <customersupport(at)tnkolbaircraft.com> |
DAVID, I HAVE NO MORE INFO. AT THIS TIME, BUT WE ARE WORKING ON THE PUDDLE
JUMPER FLOATS FOR THE MARK 3 XTRA RIGHT NOW , IFTHESE WORK OUT GOOD , I
DONT SEE MONO FLOATS IN THE FUTURE, THANKS FOR THE INTEREST IN OUR PRODUCTS
DONNIE AT KOLB.
----- Original Message -----
Sent: Friday, February 29, 2008 6:50 PM
Subject: Kolb-List: Mono-floats
> Dave
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Hi Steve,
I was wondering about your landing in the gravel pit. Apparently
something collapsed, gear leg or what? It did not appear as though the
touch down was that severe, however it was apparent that it was
primarily on one leg. Could you be a bit more specific as to what
failed, and how much damage it did.
Larry C
Larry,
I didn't get the impression it was actually Steve that crashed. I believe he
was just passing along a good video. In fact, If you pull the video up, it mentions
the name Paul Bradicich. One thing I don't quite understand though, is
why he had to crach at the last second. He seemed to have it all under control,
and then Wamm!
I don't want to "Monday morning quarterback this poor fellow, but why not hang
in there for 5 more seconds and at least begin a landing, even if he would have
to plow into something not too far away on the roll out?
Have a pleasant day, Lar. There's a MkIII out in my shop, yelling for me to
get something done today. Adios.
Mike Welch
Subject: Kolb-List: engine out
Date: Tue, 4 Mar 2008 10:22:58 -0700
Hi Steve,
I was wondering about your landing in the gravel pit. Apparently something collapsed,
gear leg or what? It did not appear as though the touch down was that
severe, however it was apparent that it was primarily on one leg. Could you
be a bit more specific as to what failed, and how much damage it did.
Larry C
Hi Larry:
Sorry to hear about your gear leg/axle socket failure. Been there and
done that. The exception was it chose to fail 3,742 miles from home,
Muncho Lake, British Columbia, Canada, 1 July 2000.
I could have prevented this failure had I taken Brother Jim's advice
when we were fabricating gear legs and axle sockets. He wanted to weld
the axle socket to the end of the gear leg. I liked using the gear
leg/axle socket because if was easier to align the main gear. Wish I
had taken his advice.
When we rebuilt the mkIII we welded .120 wall axle sockets to the end of
the 4130 legs. Don't think we will be losing a wheel anytime soon.
If I planned to stick to airports and other civilized environs then
none of this would be a consideration, but I haven't, and most likely
won't.
Larry C
Kolb guys, First, thank you Uncle Craig for the lost mold tips. It w
as very thoughtful of you to go to the trouble toshow us your handywork.
I hope I'm not stepping on Uncle Craig's ideas, but I thought I would menti
on a trick I use when working withmolds for making my own fiberglass parts.
I use joint compound, the stuff they use for taping and texturing walls.
It is cheap, phenominally easy to sculpt,and absolutely falls apart when
exposed to water (meaning it cleans up easy). Similar to Uncle Craig, I'l
l do a basic build-up with tape, thin woods strips, or whatever...just to g
et close. Then, I layer on some joint compound, fairly thick..maybe more t
han 1/2" thick. Let that set for about 24 hours, until it is nice and drie
d out. Then you are ready to start shaping your piece. Your best sculptin
g is done with the drywall sandpaper. It is made of heavy gauze and has ho
les in it, because the joint compound sands so fast you get lots of residue
...quick. They have handheld sanding blocks. They work best. For curves
and the like, just use the sandpaper loosely in your fingers, or wrapped ar
ound a little sponge. Joint compound smooths so fast, you have to be care
ful. You can shape something like a small fairing in a couple of minutes.
If, for some reason you screw up, and sand off too much, no biggie!!! La
yer a bit on, wait a day, and sand it again. Once you get that perfect sh
ape you're after, put a thin coat of epoxy resin only, just to seal it. Af
ter that is cured, rub a couple of coats of hard car wax, or even better, m
old release wax, on the sculpted piece. You can now put a couple of layers
(maybe 4-6) over the waxed sculpted shape and then let that cure. Now ca
refully pry the outer fiberglass shell off the inner shape. You can now us
e the outer fiberglass shell for building a finished product of the part th
at's a copy of what's still on your plane. You'll need a few coats of mold
release wax in the outer shell (the inner surfaces), and you're ready to b
uild your part. Mike Welch PS. Another safe layer to use, at the beginning
of your build-up, that may be quite a bit more resilient than plastic wrap
, is to use aluminum foil. NO resins will eat it away, or otherwise seep t
hrough and get to your plane beneath.
Connect and share in new ways with Windows Live.
http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_0120
08
I don't know how thick you want them, but about 3-4 years ago I ordered new
Y's & they were much thicker than the originals.
Howard Shackleford
FS II
SC
In a message dated 3/4/2008 3:21:15 P.M. Eastern Standard Time,
lcottrell(at)fmtcblue.com writes:
and perhaps I can talk Terry into building me some tougher axle Y's as well.
I would have expected the gear leg to collapse, but the gear leg was OK, the
damn axle Y broke.
From: | Yankin Anbankin <yankinanbankin(at)yahoo.com> |
Kolb gentlemen,
What, with all this talk about steel legs, who am I to not want to jump on
this bandwagon? I found a metal heat treating facility (Industrial Heat Treating,
1-801-363-7318). They quoted me a price to heat gear 4130 steel legs for...$65
to Rockwell 48 hardness.
I just thought I'd pass this along.
BTW, Shapiro Supply seems to have the best prices I could find for chromoly tubing.
They're in St. Louis. Mo. 1-800-833-1259
Hope this helps,
Yankin
MkIII, with soon to be taller steel legs
From: | "Ed Chmielewski" <edchmiel(at)mindspring.com> |
Subject: | Re: Lost mold strut faring |
Hi Craig,
In the future, would it be possible to post a link to the pics?
Hung my dial-up connection pretty bad.
Thanx,
Ed in JXN
MkII/503
From: "Nelson, Craig" <craig.nelson(at)heraeus.com>
Sent: Monday, March 03, 2008 11:11 PM
Subject: Kolb-List: Lost mold strut faring
<> St <> ar <> te
<> d <> a <> st
<> ru <> t <> fa
Uncle craig
Sent: Tuesday, March 04, 2008 1:36 PM
Subject: Re: Kolb-List: X@#$@#%*XX
Hi Larry:
Yeah, I remember that one. Definitely a lot worse than mine, or at
least a bigger pain. I am afraid that I didn't do as well as Bob's
friend though. I threw the wheel as far away as I could, then I had to
go get it and take off the fitting from the gear leg and walk to the
hanger reweld it back together. Then I was able to taxi to the hanger.
At least the ground was soft enough that I didn't point the wheels in
the air. Still getting sick to my stomach though.
Larry
That is good information for those that are thinking about or have made the
ir own parts. You might consider using hot mud (joint compound/drywall mud)
if you make a mistake or sand to much. The hot mud comes in 15, 30, 90 min
. drying times so be ready to apply it when mixed. This way you won't have
to wait
24 hrs for it to cure.
From: mdnanwelch7(at)hotmail.comTo: kolb-list(at)matronics.comSubject: RE: Kolb-L
ist: Lost mold strut faringDate: Tue, 4 Mar 2008 12:49:51 -0800
Connect and share in new ways with Windows Live. Get it now!
Subject: | Re: FS II perfomance |
On Sat, Mar 01 - 5:36AM, Gary Aman wrote:
>>>Jim,
@5700.Try winding
up that IVO a little.<<<
Well, I did, and what a difference it made. #1, this is all new stuff to
me, learning as I go, don't know #$%# about it. I dialed up the prop
adjuster screw a couple of turns and went out for a flight. I turned it
the wrong way, found that out by taking off and watching the rpms race
to over 6800, flew around and landed, barely maintaining 50 mph. Back to
the hanger and went the other way with the screw. Took off again and the
rpms were 5950 to 6050 range on climb out, then went to maybe 6150-6200
at full throttle when I leveled off.
I flew down to Bailes Field in Angleton, about 20 miles away, and
immediately it was obvious this was a good change. My airspeed was 65
-70, at about 5500-5700 rpm, and was 60 plus even down to around
5000-5200 rpm. I felt like I got a new plane! It has never cruised at
these speeds. Tried a few steep climbs, would hit 6150 rpm at FT with
700' per minute rate. I've never been able to cruise my plane in the
4700-5000 rpm range before, it just simply wouldn't maintain altitude.
It does now, easily. A 10 mph increase makes a really big difference in
the feel of this plane, and I already loved it. Even coming in on
approach, I now have to chop more power to get to 50 mph. I didn't have
time to really put it to the test and make all the proper notes as to
egt's, cht's, etc., that will be my weekend project. I know 65-70 mph
airspeeds are not fast, but in this plane it feels like I'm in a rocket!
Gary, thanks for the advice.
Jimmy Young
FS II, N7043P
Houston, TX
Just a thought. I've used Durabond 90 in the construction business. Its
drywall compound you mix yourself. It dries completly in 90 min.
I thought you had to take off the plaster or drywall mold to lay up the
first fiberglass. I can't seem to get the sequence right in my mind.
Vic
N740VP
Mike Welch
PS. Another safe layer to use, at the beginning of your build-up, that
wrap, is to use aluminum foil. NO resins will eat it away, or otherwise
seep through and get to your plane beneath.
Larry,
Welcome to the stupid stunt club, or as you put it, Kolb PILOT Quit. As BB mentioned
I had a similar incident last August, fortunately at BB's place, and not
3700 miles from home as was John H's. It has been way too cold in these parts
to do any work on the FS in a frigid hangar but will get back to work on it when
upstate NY spring arrives... in another couple of months :-(.
Thom Riddle
N221FA Allegro 2000 912UL
N197BG FS1/447
Believe nothing, no matter where you read it or who has said it, not even if I
have said it, unless it agrees with your own reason and your own common sense.
- Buddha
http://forums.matronics.com/viewtopic.php?p=167810#167810
John W may burn more Avagas than you, not sure.
> John Bickham
Hi John B:
Thanks for the info.
Lead is a problem we are going to have to contend with if we cross country
and burn 100LL.
I'll have to change oil more often, and may have to go to 50/50 mix or
Rotella Dino and Full Syn. If you can't find it bottled by Shell, then
blend it yourself. That is what they do. Nothing magic.
why not hang in there for 5 more seconds and at least begin a landing, even
if he would have to plow into something not too far away on the roll out?>.
Hi Mike,, I thought the same but it seems that what happened was that he
touched the left wing tip. Shame, he had made a good job of it unti then
Pat
Subject: | Re: Vamoose for Sale |
Ol' Lar is getting ready to retire, >>
Hi Lar,
very sorry to hear that Vamoose is going in preparation for your
retirement. I find it difficult to think that you are that age. From the way
you tore up and down the rocks when you took Wendy and I out during the
Monument Valley trip last year I would have said you had a good few years
to go yet.
I hope your proposed travelling will get you to the UK at some point, in
which case you know where there is bed and board at exceptionally good rates
plus some lovely country to fly over and a great coastline to explore.
Thanks again and good wishes from Wendy and myself.
Cheers and good Luck my friend
Pat
I do use dry wall plaster in making lost mold techniques along with
paper..on this mold I used gauze and it worked out very well.. I also
use clay to do little fixes-- after the plaster is shaped to the final
contours and ready for composite I seal the surface with a dental
separator used to make dentures and then the residual plaster can easily
be rinsed away with water. After the part is removed from the plaster
and trimmed the surface is smoothed and prepared for paint.
Uncle craig
Hi Vic,
Generally, to make a fiberglass part you have to make a mold. Usually, this
mold is destroyed in order to get out your finished fiberglass part. That's
why they refer to it as "lost mold".
In most situations to make a custom fiberglass part the sequence goes something
like this; (let's continue the fairing for the wing struts)
1) protect the background structure from any mess you do. Uncle Craig suggested
using plastic food wrap. His suggestion was very appropriate, because the
mold material he was using was fabric and plaster of paris. That stuff isn't
corrosive or harmful, just mainly messy. If you make a mold out of fiberglass,
then you'll need to use something more durable. I suggested aluminum foil.
Regardless of the specific product, you don't want to screw up your airplane
underneath all the mess.
2) Not is the time to begin the basic build up. Tape is a good idea. Flat
wood strips and a glue gun, urethane carving foam, etc. The idea is to begin
to shape the final product, and your very rough shape needs to be reasonably firm.
3) Now comes the sculting part. At this point, you want the final product to
be as smooth and perfect as you can get it. I suggested dry wall compound,
other's have suggested the rapid set joint compound. I've never used it, but
if it is easy to sculpt...why not?? (I've got an idea it's pretty close to the
ingredients of plaster of paris) You can use modeling clay, joint compound,
bondo....whatever you want. The point is you want to layer some on, and then
sand your fairing to be as smooth and flawless as you can.
4)At this point you're happy that what you have built looks awesome!! It was
easy to shape and contour, but structurally it just a bunch of junk underneath.
If you were to paint it the same color as your plane, it would LOOK like a
beautiful fairing. Now is the time to make your "LOST MOLD". Whether you use
plaster of paris, or fiberglass can depend on the size of the item being made.
Certainly fiberglass will have a bit more flex than plaster. But, for small
one-off parts, plaster of paris might be the best choice.
Coat the sculpted shape with wax, so that the mold doesn't stick to it. Several
layers of wax won't hurt! Then mix up a good amount of plaster of paris
and cloth strips. Begin by laying on these strips to the fairing, and using
a popcycle strip, spoon, etc., make sure you don't trap any bubbles of air against
the surface. These will be holes in your mold. Continue carefully laying
up all the strips of cloth drenched in plaster.
5) I would highly recommend making your "lost mold" MUCH bigger and longer than
you think (maybe an extra 1 1/2" in all directions). You'd be surprised how
much trimming you need to do to your finished part. If you don't allow for
this cosmetic trimming, you may add a ton of extra work to get it to look good.
6) After letting your mold set frimly, whether it is plaster or fiberglass,
carefully pry it away from the sculpted fairing. This is going to be the point
where you wished you put on more releasing agent. It is surprising how much
that female mold wants to stick to the shape you made. If you greatly underestimate
that release agent, you may find the only way to get the two pieces apart
is with a claw hammer.
7) If you managed to successfully seperate your "lost mold", you shouldn't need
too much cosmetic work on the inside. Once you feel you've dressed up the
inside, coat it a few times with mold release wax. Then cut many (as in a LOT)
small strips of fiberglass cloth.
Mix an appropriate amount of resin + 50% more, since running low in the middle
of your project isn't smart, and do the similar job of whetting the strips,
and laying them in, being conscientous to remove any bubbles.
Here, watch this...it's essentially what we're after. Just realize that this
mold in the video is significantly better quality than what we may need for just
one part...
http://howtofiberglass.wordpress.com/2007/11/20/video-how-to-make-a-fiberglass-mold/
Hope this helps give you an idea to do some fiberglass experimenting. It really
is fun!!!
Mike Welch
I thought you had to take off the plaster or drywall mold to lay up the first
Vic
N740VP
Mike Welch
PS. Another safe layer to use, at the beginning of your build-up, that may be
Never miss a thing. Make Yahoo your homepage.
Bill, and group,
My apologies if my posts are screwing your computer up. Sorry. About a week
ago someone posted a video of a car vs a jet. When I tried to view the video
it went "nuclear" on my computer. It must have brought a virus with it. My
computer would not log on to the internet. It would not work worth a darn!!
All kinds of crap rained down on my system!!
After someone posted a response a response about the video, I gave it a try
once again, and this time all appeared well, that's why I konw it was a car vs
a jet.
It seems we are contantly battling computer problems from people that do it
ON PURPOSE!!! Damn, I can't tell you how angry that makes me, that these lowlife
SOB's do it deliberately!!
But, if I was somehow included in this latest infection, I do apologize.
Mike Welch
Subject: | Re: shaped parts |
I use the lightweight sheet rock patch material that Lowes and Home Depot sells.
It sands easily. If I have a large part, I rough cut blue foam and then fill
the exterior with the sheet rock patch and sand. On flat sections, I use aluminum
foil tape for strength. Other hint is to make sheet metal parts, you can
use aluminum flashing backed with blue foam and rivet where necessary. I extended
my trailing edge of the wing tips and tested them to 100 mph. You could
overwrap with fabric, but it is not necessary. My custom winglets of lexan
with extended wing added up to 6 lbs. and it now a delight to fly with rudder
only (hands off). Stall speed is down to 36 mph (with VG's) Will try to get slower
with elevator gap seals and underside VG's.
Bummer on the mishap Larry. :(
How can I determine if I have the "beefed up" part?
Here is a pic of mine -
http://myweb.cableone.net/oday/Kolb/Wheel%20Brake.jpg
Thanks.
Fly safe.
Jim
Jim O'Day
Fargo, ND
Firestar II
http://forums.matronics.com/viewtopic.php?p=167893#167893
Hi Folks:
My post is directed to all of us and no one in particular.
Maybe I am wrong, but I think this is still the Kolb List, isn't it?
Stuff like fixing computers, races between cars and planes, unless maybe
it is a race between a car and a Kolb, don't fit Matt Dralle's
guidelines for the Kolb List.
I know it is still winter and folks are bored. Not much traffic to pass
cause folks aren't flying much, or building much.
However, if we allow ourselves to begin drifting from what the Kolb List
was and has been for many years, I think it might drift away.
Nope, I am not the "hall monitor" or the "list police". Just one member
of the Kolb List among many.
Mike- My computer is okay.
> Jim
Jim:
Call Kolb. Ask them what wall thickness they are using for the new beefed
up gear leg/axle sockets.
Get out the calipers and go from there.
Looks like yours may be thin wall stuff.
<> In a few hours from start to finish custom farings
Uncle craig
Att: Larry Cottrell- I think I'm misunderstanding something important. Did you
break the "A" frame behind the seat, or the fitting at the lower end of the
landing gear leg? I need to check mine- old age.
Bill Sullivan
old FS
Just for what it's worth (and John H and W's opinions will trump what I say here
if different due to their far longer experience):
I've always gone by the manufacturer's requirements in terms of weight and service
grade in the various motors I've owned over the years.
This means, first, any specific recommendations followed by the general recommendation
on API service grade. I.e. Rotax has a list of specific oils they like
you to use so I try to find one of those first. Then, if none of those are available,
I look for a substitute and make sure it meets or exceeds the API service
grage and weight requirement.
Then synthetic or semi depending on the leaded issue....
I.e. I currently use the valvoline 10w-40 and note that the API service grade is
now up to SL/SM on that oil. Rotax says at least SF or SG so the SL/SM oil far
exceeds the minimum required API grade for the motor.
Nice thing about the API grading system is their newer grades always include all
the lubrication requirements of the previous grades, so you know using a later
grade will still meet (and in fact exceed) the lube abilities of the earlier
grade.
I've been running semi-synthetic all the time since that way I can put 100LL in
on an occassional basis and not have to worry about it. I change the oil/filter
when the dipstick starts looking gnarly regardless of hours or at 50 hours
whichever comes first.
Works for me so far,
LS
LS
FS II
http://forums.matronics.com/viewtopic.php?p=167939#167939
>Hi Lar,
>very sorry to hear that Vamoose is going in preparation for your retirement.
Me too..... Sorry I never got to meet you in person.
I know we almost got together once or twice.
Feel like I know got to know you after all these years anyway
from looking at your web site and talking to you on the Kolb site.
If you're ever down South - "come see us"
Stan
Hi All,
After reading all the helpful suggestions I now have a plan. I have ordered a propeller
hub extension from Saber Mfg in TX. The prop will be moved back 3" to
reduce tip noise.
Next I will be fabricating some filler panels to provide a physical barrier between
the engine and the cockpit. On the panel side that faces the engine will
have a soft acoustic material to reduce the noise further.
Finally, I will close off the cockpit with a bit more lexan windscreen material
to minimize my exposure to engine noise.
Hopefully, My dear sweet wife will get me an ANR headset on my birthday/Fathers
Day/Xmas to complete the noise reduction process.
I have tried the panel idea already and have had some sucess using just cardboard
held in place with duct tape. The next step is to replicate the cardboard
panels in foam and fiberglass to have some lightweight but stiff panels as the
final product.
As the process evolves, I will try and keep everyone posted.
Best Regards
Carlos G
http://forums.matronics.com/viewtopic.php?p=167940#167940
Subject: | Re: Computer woes |
At 01:40 PM 3/5/2008, you wrote:
>Bill, and group,
He's got dial up, so if you send anything over a "100 kb" picture, it takes
a long time to download. He doesn't have a choice of whether to download
it or not on his system - it just takes "however long it takes". Some
people can't get DLS yet.
It's better to send a smaller picture to the "email list". Try to
send it as a JPEG & resize it to
100 kb or less. That is plenty big enough for all of us. Here is a 84
kb picture
just for an example.
Take your kid to work day:
Ah so thats why the Captain about messed up Christmas hahaha 8-)
Sent: Wed, 5 Mar 2008 10:12 pm
Subject: Re: Kolb-List: Computer woes
Bill, and group,
=C2-
=C2- My apologies if my posts are screwing your computer up.=C2-
Sorry.
picture, it takes
download
takes". Some people can't get DLS yet.
list".=C2- Try to send it as a JPEG & resize it to
Here is a 84 kb picture
[Image Removed]
><http://webmail.aol.com/34865/aol/en-us/Mail/get-attachment.aspx?uid=1.19016776&folder=New+Mail&partId=4>[Image
>Removed]
>Supercharge your AIM. Get the
><http://download.aim.com/client/aimtoolbar?NCID=aolcmp00300000002586>AIM
>toolbar for your browser.
Good........ see he "removed" the image, so we don't have to download it again.
Good boy.
Subject: | Re: axle fittings |
The fitting at the end of the gear leg.
Larry C
To: kolb list
Sent: Wednesday, March 05, 2008 7:14 PM
Subject: Kolb-List: axle fittings
important. Did you break the "A" frame behind the seat, or the fitting
at the lower end of the landing gear leg? I need to check mine- old age.
Bill Sullivan
old FS
3/5/2008 6:38 PM
http://www.belfasttelegraph.co.uk/news/world-news/article3487916.ece
Yeah I don't even thin John H could have landed that one,
After looking at it again, I take that back. I think John could have done
a "cross runway" touchdown at WOT and landed going backwards.
He was a "Whirlybird" pilot anyway. I have done that myself on sandbars
off St. Simons Island. 35 mph head wind (smooth a silk) - let's see who can
land on the shortest sandbar at low tide. Winner gets free drinks,
2nd place goes
into the saltwater and has to scrub his plane down "big time". All
the rest of the pussys
pay.
Possum, your language ! ! ! Tsk tsk
tsk............. Lar. do not
archive.
> After looking at it again,* I take that back.* I think John could have
> done
> who can
> land on the shortest sandbar at low tide. Winner gets free drinks, 2nd
> place goes
> into the saltwater and has to scrub his plane down "big time". All the
> rest of the pussys
> pay.
We HangGlider types fly the smooth sand dunes when the winds are blowing 25
to 30
and are able to top land like a Sea Gull on a fence post...
We'll set up our approach behind =C2-our chosen landing spot then slowly
=C2-push out to stop
=C2-our forward progress then hover =C2-over =C2-the due...
We =C2-pull in to adjust for changes in wind Velocity so to stay in front
of=C2-the Rotor=C2-
which is often just behind us then slowly=C2-push out to settle to=C2-th
e top of the due.....
=C2-If it looks like well over shoot we simply=C2-pull in=C2-the bar a
nd dive out into the lift band=C2-
of the ridge and make another attempt..
We can also launch =C2- from the prone =C2-position never using our legs
to launch ...
We lay prone and with the aid of the strong wind and your buddies, they fly
you
like a kite to the dues edge and push you off into the vertical lift band an
d away you go...
Lots of fun when our East winds Kick in the early spring and late fall...
Mark
Sent: Wed, 5 Mar 2008 11:11 pm
by: possums
have done
backwards.
sandbars
can
place goes
All the rest of the pussys
pay.
Thanks Larry. I think I do have the thin ones. I also have some bent gear legs
that came with the plane-3?- that maybe could be straightened. They are aluminum.
Right now, the plane has one bent leg. The other side has a much stiffer
leg- the taper starts further down. I have new legs of the lighter type that
will be installed. I asked TNK about putting steel legs on, and they advised me
to stay original because a hard landing could transmit the shock up to the main
frame- maybe causing very expensive problems. Very good advice from TNK, as
I am very inexperienced. Like 40 years out of practice. When in doubt, go with
the factory advice. Yes, they do want to sell parts- but not unless they have
to. I have to check the "A" frame for cracks while I'm in there. There is also
a skid plate on the nose, so I think one of the former users was in the habit
of rough landings.
Bill Sullivan
old FS
l
In a message dated 3/5/2008 9:55:56 P.M. Eastern Standard Time,
grageda(at)innw.net writes:
Hi All,
a propeller hub extension from Saber Mfg in TX. The prop will be moved back
3" to reduce tip noise.
Carlos,
Sounds like you bought #2 of 2 prototypes that Saber cut for me. I have not
run mine yet but unless they re cut it you will have to make some custom
washers. the clearance next to the inner hub is too tight for the bolt head.
They could cut the inner spool to a smaller OD but they did not want to reduce
it.
I bought some aluminum washers from ACS and knocked the edge off on the belt
sander.
The reason for all the washers is because I used long enough metric bolts so
as to have a grip long enough to all the way through the hub.
steve
On my old Firestar, the tube thickness of the axle fittings appears to measure
.0625. This is approximate, due to light rust, paint, etc.
Larry- can you take the calipers to your broken one? John H. measured .0650.
My axles also seem to have RTV in the socket- Is this standard practice?
Bill Sullivan
old FS
With the paint and other stuff on mine the measurement comes out to
.067, so I would venture that .065 would be correct.
Larry C
To: kolb list
Sent: Thursday, March 06, 2008 5:31 AM
to measure .0625. This is approximate, due to light rust, paint, etc.
measured .0650.
practice?
Bill Sullivan
old FS
3/5/2008 6:38 PM
Possums,
That is priceless!
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 3/5/2008 10:16:32 P.M. Eastern Standard Time,
possums(at)bellsouth.net writes:
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
I'm going to ask a stupid question. Why the extra step of the lost mold? Why
don't you just form the composite on the plane?
Rick Neilsen
Redrive VW Powered MKIIIC
Donnie at Kolb sent me a note, the "beefed up" parts have .120 wall thickness.
Jim
Jim O'Day
Fargo, ND
Firestar II
http://forums.matronics.com/viewtopic.php?p=168047#168047
> Rick Neilsen
Mr. Rick,
Excellent question. I guess in some case, especially where outer surface appearance
isn't that important, you could do that.
However, when making most items to be installed on your Kolb airplane, you want
them to have the high quality and beauty that Uncle Craig creates. In order
to get that level of perfection, you pretty much need to build that "perfect"
part, in position, on your plane......and then copy it (with the "lost mold",
and then recreate it.
Here's why; If you do all that "rough" build up, like with tape, or wood strips
or plaster, or whatever you choose to use, you have is the approximate shape.
Say you go ahead and add some smoothing agent, like the joint compound, or
bondo, of carving foam, etc., and you've shaped your fairing....real nice.
Ok, so now you start the fiberglass for the finished piece. Remember, the really
nice surface is on the INSIDE of your layers of fiberglass, not the outside.
But, let's continue. So if we put a few layers of fiberglass on the outside,
and once it's cured, pull it apart. You will find you have something that
is similar in shape as your build-up, but, boy, is the outside in rough shape.
You will have to sand, and sand, and sand, on, and on. And I'm here to tell
you, fiberglass impregnated with resin is darn near rock hard. Shaping after
the fact is a living nightmare!!!! It will be the same process you just went
through, making that "perfect shape" on your plane, only this time you won't
be smoothing bondo, or joint compound, you be trying to smooth....well, glass!!!
Even though making a "lost mold" is a lot of work, and on the face of it, APPEARS
to be double the effort, it really isn't. You will spend much more time
trying to enhance the appearance of the shortcut method.
Another very big difference between the proper mold method, and the quick "lay
on some fiberglass layers" method is weight. Think about it. If we make our
sculptured shape flawless...on the plane...in position, and then make a thick
rigid mold, whatever we build on the inside is going to be just as flawless
(on its outer surface...the important surface). We can probably get away with
as little as 2-3 coats of glass. This piece will be virtually perfect, needing
only very minor and easy edge trimming. Lightly sand and then paint.
But if we try to get away with 2-3 coats of an outside build, the piece will
have all kinds of flex and give as we try to make it "perfect". We'll need 5-7
coats of material, to have the necessary rigidity to sand the heck out of it.
While I understand your logical question, the industry standard is to build a
mold of a "finished product", then recreate that finished product INSIDE the
mold. BTW, not all mold are "lost". Obviously, many molds are built to withstand
the ability to make hundreds of copies. (bathtubs, , boats, etc) That is
why the release agent is so critical. It leaves to mold unharmed by trying
to pry out your beautiful artwork.
Best regards, Mike Welch
I can shape the piece with plaster make the contours perfect. The
plaster sometimes gets up to 1 inch thick. The part ends up one layer of
s glass one layer of carbon and one layer of s glass extremely light and
not much filler to smooth it out.
Uncle craig
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard &
Martha Neilsen
Sent: Thursday, March 06, 2008 9:25 AM
Subject: Re: Kolb-List: Lost Mold
Why
Rick Neilsen
.Lost mold means just that. The mold is lost when the part is made. I
make a positive mold out of tape to get the basic shape then the plaster
is used to make the mold strong enough to remove from the plane.. More
plaster is used to get the proper contour of the part .. Then I apply
separator to the plaster called Aislar a dental denture material in
dentistry it is call tin foil substitute used to fill the pours plaster
so acrylic does not stick to it. Then I wax the plaster form and apply
the layers of glass and resin, when this sets up I remove the part from
the mold. The plaster brakes up on removal because it is not strong
enough to stay in one piece when removing the part.( lost mold it is
only good for one part) Then I fill the weave of the cloth with filler
and paint it
Uncle craig
<> My <> t <> ra
<> il <> ke <> r
<> dolly
Uncle craig
From: | "Travis Brown (Kolb Aircraft)" <travis(at)tnkolbaircraft.com> |
Craig A great job ,looks awesome.
Travis @ Kolb
Sent: Thursday, March 06, 2008 2:25 PM
Subject: Kolb-List: dolly
<> My <> t <> ra
<> il <> ke <> r
<> dolly
Uncle craig
Uncle Craig,
Very nice looking dolly.
Coincidentally, while folding my wings on my MkIII yesterday, and pushing it
to the backyard, I told my neighbor who was helping me push it, I was going to
build THAT exact thing...a dolly.
You just saved me the trouple of designing one. I hope you don't mind, but I
have to build one just like yours.
Mike Welch
ps. Keep the ideas coming. Soon, we'll have tons of awesome looking Kolbs, courtesy
of your ideas.
Larry- .065 should be the new one. Is that the one you broke? I measured mine
again, and mine is definately thinner than that.
Bill Sullivan
old FS
I saw this video about a year ago and actually talked to the individual that landed
at this site. He did catch a small tree that turned him around. It was
a Phantom and he had very little damage to the landing gear. I was impressed
that he found a site to put it into at all.
Steve G
http://forums.matronics.com/viewtopic.php?p=168122#168122
Subject: | Re: Botched UltraStar Landing Assessment |
Seems like the Woman in the video made it happen through creative negative thinking!
She just knew it would happen. To me it seems that the landing gear was
week because the landing didnt seem to be that ruff nor did it seem like he
stalled in in.
Steve
http://forums.matronics.com/viewtopic.php?p=168123#168123
> Seems like the "Fly it On" technique is the way to go instead of trying
to force it down without sufficient speed or power.
> Ray
Ray:
I agree with you to a point.
Without sufficient flying speed, one does not have to try to force it down.
It does that all by its self. Seemd the pilot stalled the aircraft high.
<> -- <> -- <> -O
<> ri <> ginal Message-----
Sent: Thursday, March 06, 2008 12:28 PM
Subject: Fire star
Milo tim's plane
Uncle craig
Subject: | FW: Fire star/more picks |
-----O <> rigi <> na <> l
<> Me <> ss <> ag
<> e-----
Subject: Fire star
Milo tim's plane
Uncle craig
At 03:24 PM 3/6/2008, jb92563 wrote:
>What did this guy do wrong on landing his UltraStar to cause gear collapse?
>Review this short video clip:
>[URL]http://www.youtube.com/v/0hqEBYcFp4k"
>type="application/x-shockwave-flash" wmode="transparent" width="425"
>height="355"[/URL]
>I think he might have been going a little fast and high and chopped to
>much power and came down hard.
>Seems like the "Fly it On" technique is the way to go instead of trying to
"Kolb Quit."
But seriously, he slowed it up too much, too high, and dropped it
in. Common ultralight newby error.
-Dana
"Gold cannot always get you good soldiers, but good soldiers can always
get you gold"-- Niccolo Machiavelli
Subject: | Botched UltraStar Landing Assessment |
That's It, That's the Kolb drop on film! Do you realize the significance of
getting the elusive Kolb drop on film?! Wow.
Subject: | Re: FW: Fire star/more picks |
What a GORGEOUS pair of Kolbs!!!
Green with envy in CT
> <> Me <> ss <> ag
> <> e-----
> From: Nelson, Craig
> To: 'kolb-list(at)matronics.com'
> Subject: Fire star
> Milo tim's plane
> Uncle
> craig .JPG>
Subject: | Re: FW: Fire star |
In re Milo Tim's plane --
Beautiful pix of a beautiful plane! -- but (me being an incorrigible
jokester) -- doesn't that look like a couple bales of pot in the
cockpit on pic #1 ?? -- sorry 'bout that --
Russ
On Mar 6, 2008, at 8:05 PM, Nelson, Craig wrote:
> <> -- <> -- <> -O
> From: Nelson, Craig
> Subject: Fire star
> Milo tim's plane
> Uncle
> craig .JPG>
Dave,
You've got me laughing MAO.. Now, THAT was funny!!!
Mike Welch
Subject: RE: Kolb-List: Botched UltraStar Landing Assessment
Date: Thu, 6 Mar 2008 19:35:44 -0600
That's It, That's the Kolb drop on film! Do you realize the significance of getting
Don't pay too much attention to this post, as I've never even piloted
a Kolb -- but it sure looks to me as though the TAIL stalled, and
caused a sudden nose pitch-down. Which ANY aircraft can and will do
when it's slowed down too much.
Very bad if it's too near the ground.
Feel the aircraft out AT ALTITUDE. Fly safe!
>> collapse?
>> [URL]http://www.youtube.com/v/0hqEBYcFp4k" type="application/x-
>> shockwave-flash" wmode="transparent" width="425" height="355"[/URL]
>> chopped to much power and came down hard.
>> trying to force it down without sufficient speed or power.
> "Kolb Quit."
> -Dana
> always get you gold"-- Niccolo Machiavelli
>height="355"[/URL]
"Kolb Quit."
-Dana
From: | "George Alexander" <gtalexander(at)att.net> |
Too many previous hard landings and/or a bungee gave way?????
Just an opinion ma'am.... not necessarily the facts.
George Alexander
http://gtalexander.home.att.net
http://forums.matronics.com/viewtopic.php?p=168165#168165
Should have been able to take that little drop. A part must have
been ready to fail.
I've dropped my (600 lb empty) MkIII lots of times at least that hard
with no damage.
-tis a stout bird.
BB
>> Ray
> Ray:
> it down. It does that all by its self. Seemd the pilot stalled the
> aircraft high.
> john h
> mkIII
Tim & Craig
Wow they are super. You have got to get these planes to Oshkosh. I can see
the judges now which one do we give the best LSA award to?????
I'm trying to work in a trip to Mesa around the time of Monument Valley.
Hope to see both flying.
Rick Neilsen
Redrive VW powered MKIIIC
Sent: Thursday, March 06, 2008 8:05 PM
Subject: Kolb-List: FW: Fire star
<> -- <> -- <> -O
Subject: Fire star
Milo tim's plane
Uncle craig
Thanks, Jim. That definately makes mine the older parts.
Bill Sullivan
old FS
Mike, Stupid Question # 2
Would the finished fairing have a larger ID than the plaster mold (1st
build up)?
Seems like you would have to extend the finished fairing out beyond the
edges so it would meet the strut cover or whatever it contacts. How is
that done if your doing a layup inside your mold?
Note: 10 layers of glass mat ( video), if I used that much my part would
weigh 100 lbs. and be an inch thick.
Vic
N740VP
If you can still see out your house windows you didn't shovel as fast as
you could have.
Hi Vic,
Again, nice observation. If you shaped a perfect fairing (on your plane), and
you took a mold off that perfect fairing, and then you built your part on the
inside of that mold, your finished part (fairing) would be slightly smaller,
not larger.
With this understanding, that your part will be slightly smaller (by the width
of you glass layers) you may want to build up your sculpted prototype, with
extra tape, etc.
This is especially important if you are building something that has an opening,
like our fairing. Our fairing has two area of interest...the part that fastens
to the fuselage. A tiny bit smaller, or bigger would never be noticed.
But the part that has a hole, that slips up the wing strut, won't fit unless you've
made that opening a little oversize". No doubt, Uncle Craig allowed for
this.
I know it seems to get a little confusing, but if you take into consideration
that male, female, male, undersize, oversize, etc., etc. changes, it really isn't
hard.
Example, if I were to make that exact same part as Uncle Craig made, I would
wrap the wing strut with...oh, about 3 layers of duct tape, since duct tape is
"close" to the thickness of fiberglass cloth. 3 layers of tape gives you room
for 3 layers of glass. So, now, when you build a mold around that wing strut,
the hole in your mold will be oversize. Right? Therefore, when you start
putting in the layers of fiberglass, or carbon fiber, inside your mold....you
will be closing in on that original wing strut diameter (prior to the duct tape).
The portion of the mold near the fuselage doesn't matter if it's 1/6"-3/32" smaller,
you'd never know. But the part of your fairing that needs to slide up
and down the wing strut won't fit, unless you accomodate for it.
The video of mold making was just that....only the mold. That's why the 10 layers.
He was making a mold, not the finished part. With this mold he made,
he can now apply plenty of mold wax, then gel-coat, and then 3-4 layers of cloth
(whether it is carbon fiber, E glass, S glass, etc.) Because his mold is 10
layers thick of fiberglass, it should last for years, and hundreds of "take-offs".
Mike Welch
Would the finished fairing have a larger ID than the plaster mold (1st build up)?
Seems like you would have to extend the finished fairing out beyond the edges so
it would meet the strut cover or whatever it contacts. How is that done if your
Note: 10 layers of glass mat ( video), if I used that much my part would weigh
Vic
N740VP
If you can still see out your house windows you didn't shovel as fast as you could
have.
utterly gorgeous..... and ...........love that vent!!
George Randolph
Firestar driver from the Villages, Fl
Thanks Mike. By jove I think I've got it Finaly
Vic
N740VP
At 11:36 AM 3/7/2008, Mike Welch wrote:
> This makes me wonder about the UltraStar frame you have, Ray. As I
> said, I know of an UltraStar frame that was assembled with rotten quality
> control. I have NO doubt that this plane would likely have crashed, if
> it were ever finished and flown.
A factory frame? First I've heard of this, and it naturally makes me
nervous. What were the problems, what should i look for?
-Dana
Welcome to the Federal Bureau for Reducing Bureaucracy!
UltraStars don't have bungees, just a rigid gear, not even the spring steel
gear of the later Kolbs... the only shock absorption is the tires, so you
have to land it gently. I watched the previous owner of my plane break a
gear in a landing that looked no harder than the one on Youtube (to my
friend's credit, it was a dead stick landing during his first solo in the
plane... he got it onto the runway but had no speed left).
-Dana
> -Dana
While not stock set-ups, I personally know of 3 different Ultrastars that had bungee
suspension systems on their mains.
The attached images are of a very highly modified one (used to belong to Richard
Swiderski of this group) with a bungee system.
Sorry I don't have images of the other two.
George Alexander
http://forums.matronics.com/viewtopic.php?p=168364#168364
http://forums.matronics.com//files/dsc03959_bungee_468.jpg
http://forums.matronics.com//files/dsc03959_600_medium_121.jpg
>had bungee suspension systems on their mains.
>Richard Swiderski of this group) with a bungee system.
Ah yes, the "stork" UltraStar. I've heard of US's being modified with
FireStar gear, too. The problem is, you have to add the height to insure
adequate prop clearance when the gear compresses. The previous owner of my
plane just installed much larger, soft tires... but then it wouldn't fit in
the trailer so I had to go smaller again... and land carefully.
-Dana
I don't trust a government I can't shoot back at.
From: | Charlie England <ceengland(at)bellsouth.net> |
Subject: | Re: Changing formats |
Mike Welch wrote:
> Kolb guys,
> Can anyone tell me how to change the text formatting style I have with this
list. Presently I have the "plain text" style for the emails I send. This style
is incredibly limiting, and if I had the option, I would prefer the "rich text"
version.
> I have tried looking into the change myself, but can't seem to find a place
that offers a choice. Yet, I DO see other members that have the "rich text"
version.
> Thanks,
> Mike Welch
Hi Mike,
I'm about a week behind on reading emails. Did you get an answer to your
question? If not, what email software are you using? The menu items are
set up differently in the various programs, so you need to specify what
you're using to get an answer.
I use SeaMonkey (a combination of Firefox web browser & Thunderbird
email client). In SeaMonkey, at the options bar on the top of the screen
you click Edit>Preferences> then under the Mail & Newsgroups category
you click Send Format. From there, you pick how you want to send the
email (plain text, HTML, both plain & HTML, etc).
Be aware that some email servers will strip off any HTML even if you
send it that way. Also, sending anything other than plain text often
results in garbage characters embedded in the receiver's display of the
message.
If you're using Outlook (Ugh) and have MS Office on the computer, you
can set it up to use MS Word to compose emails. I'd have to check on how
to do it next week at work, where I'm forced to use Outlook. Be aware
also that Outlook, if you don't have an effective firewall & virus
checking, along with the most current bug fixes, is very vulnerable to
hackers when you're on a broadband connection.
Does anyone here need to have their gearbox refitted with the new gear set under
the Rotax AD?
Roger Lee
Tucson, Az.
http://forums.matronics.com/viewtopic.php?p=168475#168475
Subject: | Re: Gearbox Recall |
Nope.
Had mine done several weeks ago at South Mississippi Light Aircraft by
Ronnie Smith.
gear set under the Rotax AD?
Roger Lee
>From planecrazy...You said:
>> You should probably take a "pinch" of bite outa yer prop...
Straight and level flight with full throttle should hit 6500...( got
VSI ? )
You'll still see your faster cruise....
but you'll also have better climb out...<<
Mike,
Actually, I did just that this morning, took some pitch back out. My WOT
rpms are about 6300. That pitch change increased the egt temps up to
1040 - 1070 range, as they were in the mid 900's. I will keep it there
for a few more flights and watch the temps as the weather warms up. And
yes, I do have a vertical speed indicator, on the EIS and the GPS. The
increased change in cruise speed is really nice.
With regard to which way to adjust the prop, I'll never forget that
after going the wrong way the first time. A while back, I also learned
the hard way about which way to adjust the elevator trim..... Thanks for
the input.
Jimmy Young
FS II - N7043P
Houston, TX
I have a pic of an ultrastar with the alum legs that someone might be
interested in. I crunched the originals in an engine out so I rebuilt them
with the plans from a friend and they were fabulous. I could not believe
how much it changed the landing characteristics. wow, great. much better
than the original. This uses the old style very small firestar gear legs.
I have the plans and pics if anyone is interested in it. Ted Cowan.
At 08:35 AM 3/9/2008, tc1917 wrote:
>I have a pic of an ultrastar with the alum legs... This uses the old
>style very small firestar gear legs. I have the plans and pics if anyone
Ted, does this require welding on the cage or does it just bolt to the
original attachment points?
-Dana
HAL 9000: Dave. Put down those Windows disks, Dave. DAVE!
Hi Ted
Jim here.Im very interested in this modification. Can you please email me
more pictures and the plans
In a message dated 3/9/2008 7:39:46 A.M. Central Daylight Time,
tc1917(at)hughes.net writes:
Will- This is "off List", as it is a little long. On web search, enter Kolb Firefly,
and scroll down to "My Firefly". At the bottom of any page, click on "flight",
and follow the links to his brother's site, and then to an "in the cockpit"
video called "Around the Patch". Go to full screen, and turn the volume up.
I don't remember the guy's name, but you will love it. It takes a minute to
load, but well worth it. His article on building one is full of tips.
Bill Sullivan
old FS
The Old Kolb sold this modification....My US had it...bolt on...no
welding... Herb
>>old style very small firestar gear legs. I have the plans and pics
>the original attachment points?
>-Dana
Subject: | New Aluminum alloy? |
Has anyone tried or has any experience with 7068 aluminum alloy. I am wondering
about its suitability for gear legs on the Kolb among other things.. Seems to
be a new alloy.
Ron Txaz
Subject: | Re: Firestar Videos and VG's |
Most of that testing has already been done for you. Landshorter recommends that
VG's be placed 11 % of the chord back from the leading edge of the wing.
Just as important as the distance from the leading edge is the angle of the VG
into the wind so that it creates effective vorticies without stalling and creating
to much drag, which is 15 degrees into the wind. These numbers are not
Kolb specific, but they work well in most of our class airplanes. A lot of people
have used landshorter VG's at the recommended positions on Kolbs with great
results. My results were so good, and my plane flys so well that its not
worth my time moving the the VG's around to different positions.
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=168595#168595
Just installed my new anr set in my military helo style helmet. I had
to salvage parts to set it up originally and then I put the new parts
from this company in. what a difference. I had harmonics and noise I
just could not get away from. padded between the wings and behind my
seats. better but still had to have the radio turned almost all the
volume I could get. Took my little slingshot up this morning and wow,
wow, wow. Went zoom zoom and wow wow. I could not believe the
differnce. I had to turn the radio down to less than half!! Mostly
could only hear the prop wherrring. Talked to a hand set on the ground
at about five miles and closer and could hear perfectly. The ground
reported it clearer with it turned on than off. Great. That my
friends, only cost me $202.00 delivered. Maybe I wont loose my hearing
as soon now. Best money I ever spent. Ted Cowan, Alabama
Here is the web site if anyone is curious.
http://www.headsetsinc.com/
Glad you like it Ted. Converted my old DC 10-60 headset many years ago and the
difference it makes is huge. Nowadays I am using top of the line Telex Stratus
something or other with 50 total decibels anr reduction. I set next to a fellow
that has Bose and we swapped it around. The telex ANR and we both agreed is
quieter than the Bose and a few hundred bucks cheaper. It seems to me that the
claim that if they start with top of the line passive headset and then add an
ANR gizmology to it makes for the best combination and best noise reduction.
Ron
txaz
---- tc1917 wrote:
Just installed my new anr set in my military helo style helmet. I had to salvage
parts to set it up originally and then I put the new parts from this company
in. what a difference. I had harmonics and noise I just could not get away
from. padded between the wings and behind my seats. better but still had to
have the radio turned almost all the volume I could get. Took my little slingshot
up this morning and wow, wow, wow. Went zoom zoom and wow wow. I could
not believe the differnce. I had to turn the radio down to less than half!!
Mostly could only hear the prop wherrring. Talked to a hand set on the ground
at about five miles and closer and could hear perfectly. The ground reported
it clearer with it turned on than off. Great. That my friends, only cost me
$202.00 delivered. Maybe I wont loose my hearing as soon now. Best money I
kugelair.com
I see there is a Ad on a rotax . Which gear box or engine does this affect and
where do you find this information.
Vern
http://forums.matronics.com/viewtopic.php?p=168624#168624
Yah, feel like I know you, too, Possum. It's been 10 years now. I
still have the video tape you sent, and still enjoy it and laugh at it
from time to time. I've met a lot of good folks all over the continent
from the List in my travels over those years, and met many more at MV.
It's been a good time.
The Deep South visit I cancelled on the List a couple of weeks ago is
probably back on again. Circumstances have changed again, and the
problems in Canada are resolved, so I might just head East in June for
Lousy-ana's Atchafalaya Swamp, Okefenokee, and at least Central
Florida. We'll see. If I do go, I'll make a run up to (shudder)
Atlanta from Okefenokee, just for you. :-) I'd really like to find
some real swamp crawlers to take me out into that area and get wet and
dirty chasing snakes and 'gators and gar and turtles. :-) It's always
better with someone who really knows the area. I did send an email a
while back hoping to get an answer from that guy who said he lived just
north of Okefenokee, but never heard back from him. Lar.
>> Hi Lar,
>> retirement.
> Stan
Vern:
Go to Rotax Owners Club and do a search for SBs for the 4 strokes,
published January 2008:
http://www.rotax-owner.com/
I'd post the url for the specific page, but there is none.
affect and where do you find this information.
Vern
At 05:32 PM 3/9/2008, you wrote:
>Vern:
><http://www.rotax-owner.com/>http://www.rotax-owner.com/
>john h
>mkIII
See if this works
Subject: | Rotax Oil Penzoil |
Anyone running "aircooled" oil in thier watercooled motors I want to use my
left over fuel from flying in my outboard motor ...Dave
It's Tax
Time! Get tips, forms, and advice on AOL Money & Finance.
Subject: | Re: Firefly video |
>Kolb Firefly, and scroll down to "My Firefly". At the bottom of any page,
>click on "flight", and follow the links to his brother's site, and then to
>an "in the cockpit" video called "Around the Patch". Go to full screen,
>and turn the volume up. I don't remember the guy's name, but you will love
>it. It takes a minute to load, but well worth it. His article on building
The direct link is http://www.dgmodels.rchomepage.com/aroundthepatch.zip .
-Dana
What has four legs and an arm? A happy pit bull.
Hi All,
I posted this to make sure everyone checked the Rotax gearbox AD. I had to do mine.
I can do yours as I am an authorized and certified Rotax service center.
Rotax has a new class certification process since Jan. 2008. If you need it done
let me know as I have a new batch of gear sets coming in this week. I can up
my order by Monday morning if need be. I have a 1 day turn around if shipped
to me and a 2.5 hr. turn around if you fly in.
Roger Lee
Tucson, Az.
http://forums.matronics.com/viewtopic.php?p=168668#168668
Subject: | Re: Rotax Oil Penzoil |
Won't hurt a thing.
Do you know that Penzoil just relabels some of their products for marketing. No
change in actual formula. Talk to the marketing guys and they'll tell you there
is a difference. I have talked to the engineer's at Penzoil group and they
say BS they just relabeled. And I'm sure if you talk to other people you will
hear everything in between.
Roger Lee
Tucson, Az.
http://forums.matronics.com/viewtopic.php?p=168669#168669
marketing. >
> Roger Lee
Which products and what new labels?
February 27, 2008 - March 09, 2008
Kolb-Archive.digest.vol-hg
