Kolb-Archive.digest.vol-hk
April 15, 2008 - April 21, 2008
Subject: | Re: Monument Valley 2008 Photo Contest |
Morning Gang:
Is it that time already? I just got home yesterday.....................
I did a quick scan of some old photos from past flights to MV. I guess my
favorite in this bunch is the one of us all standing under the wing of Miss
P'fer while the rain and wind turn the red dust to red glue. Arizona Dave
promptly drove his BAMH up in front of Miss P'fer, inviting all of us and a
ton of red mud to seek shelter in his motor home. Dave was quite a guy, and
Eve is an angel.
Take care,
hauck's holler, alabama
http://forums.matronics.com/viewtopic.php?p=176966#176966
http://forums.matronics.com//files/_7_809.jpg
http://forums.matronics.com//files/_6_147.jpg
http://forums.matronics.com//files/_5_198.jpg
http://forums.matronics.com//files/_4_537.jpg
http://forums.matronics.com//files/_3_209.jpg
http://forums.matronics.com//files/_2_967.jpg
http://forums.matronics.com//files/_1_208.jpg
From: | "beauford T" <beauford173(at)verizon.net> |
Subject: | Re: tail feathers |
Brother Sullivan:
If I understand you correctly, you pivoted the stainless brackets around
the lower bolt...the one at the bottom of the vertical stab... so that
they point downward, thus gaining additional tension on the cable...
I would suggest you might not want to do this... the primary reason
being that the friction on the bolt head is all that would prevent the
bracket from gradually yielding to the cable tension and pivoting back
around toward the 12 o'clock position... I believe any inspector
would consider this be an unairworthy condition which would slacken the
cable to a dangerous extent....it does not take much slack in the tail
cable to ruin a person's day.... .
If the tail cable will not tighten up sufficiently to "thrum" a nice
"middle G" note, something else is going on... the cable crimp ferrules
are slipping, something is installed backwards, or something could be
bent. The brackets at the top of the stab should point down and the
ones at the bottom bolt should point up. I highly recommend you not
attempt flight with the machine until you have resolved this issue and
have a nice tight cable IAW the Kolb plans, not by misaligning the
brackets.
...worth what ye paid fer it...
Beauford, the aluminum butcher of Brandon, FL
FF 076
----- Original Message -----
To: kolb list
Sent: Tuesday, April 15, 2008 10:17 AM
Subject: Kolb-List: tail feathers
I turned the stainless steel brackets on the lower bolt on the
vertical stabilizer so that they came off the "bottom" of the bolt, and
everything tightened right up. They almost feel like they were made that
way. I would have made them to come off the "top" of the bolt. How are
they supposed to mount?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: Ultrastar speeds |
>I've considered fairing them at some point like you did. A buddy of mine
>has a CNC hot wire cutter for R/C wings, which should make short work of
>shaping the fairings. Did you actually see any speed or economy
>improvements with the fairings?
Dana,
I have not been concerned about top speed. I don't like to fly much faster
than 55 mphi with my head sticking out in the air stream. What I am
interested in is reduced fuel burn rates and increased range.
Jack B. Hart FF004
Winchester, IN
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
That dog that was posing for you looked like the dog that chewed thru your
tent. The doggie grin was from all the food he helped himself to.
Rick Neilsen
Redrive VW powered MKIIIC
Sent: Tuesday, April 15, 2008 11:57 AM
Subject: Kolb-List: Re: Monument Valley 2008 Photo Contest
> Morning Gang:
> Miss
> a
> and
> Eve is an angel.
> Take care,
> John Hauck
> MKIII/912ULS
Subject: | Re: Firestar project |
> Jack,
>I would think with the longer wing, Bills Firestar will meet the math
>requirments of 103. Also, a Firestar fuselage is probably a little wider
>than a Fireflys?
>With a 447 and also meeting the weight and fuel limits, who would bother
>with the equations?
Denny,
If Bill wants to attend a fly-in that includes an air show, there is a
possibility of being ramp checked. In the past this was not much of a
problem, because there were so many little small planes showing up without N
numbers. But this year it will be much different and non N numbered
aircraft are really stick out. If you claim to fly an aircraft that is
103-7 compliant, it is up to you to prove it. This is why Appendix 1,2,3 &
4 are so important. If one fills these out they are considered sufficient
proof for compliance.
If on the other hand, Bill is not going to fly it into a controlled airport
that is sponsoring an air show event, he could get by as do many others.
But since he is making the effort to meet the weight and fuel requirements,
I assumed his goal was for full compliance.
In terms of fuselage width, I have not measured but I believe the FireFly
fuselage width may be greater than that of a FireStar. This was done to
meet FAA requirements for ultra light vehicle design to ensure a slow speed
dragy design. With the larger wing span or lower wing loading, Bill should
have no trouble meeting the stall limit. But with lighter wing loading, a
full enclosure, and a single wing lift strut, he may find it difficult to
remain maximum speed compliant. The drag numbers will be too low and the
447 will be too powerful. There are ways around this. First remove the
full enclosure to increase the drag. Also, one could add a false lift
strut, and/or one could move to a lower hp engine.
Jack B. Hart FF004
Winchester, IN
Subject: | Re: Firestar Project |
> Several of us have made it past the 60 year mark.
> Jack B. Hart FF004
Jack H:
Me too!
Celebrated my 69th BD flying on the first day of Sun and Fun 2008.
I'm not quite as quick as I used to be, but the "desire" is still there.
It is very comforting to strap on the mkIII and fly. Seems like all those
old aches and pains, bum knees and ankle, go away, and I can enjoy the
freedom of flying my Kolb.
I almost made it to 85, but think my last flight will be when I'm
dumped out over the Blue Ridge mtns in a few months.
regards,
Bob N. FireFly 070 Old Kolb
Subject: | Attendees to Monument Valley Sign-Up sheet |
Kolb brethren and sistren (??),
In the spirit of John W.'s request for M.V. photos, I present the list to sign
up, for those and their favorite others, to attend.
Driving in:
1) Mike Welch, with wife, Nancy
Flying in:
1)
Going green? See the top 12 foods to eat organic.
http://green.msn.com/galleries/photos/photos.aspx?gid=164&ocid=T003MSN51N1653A
>> Jack B. Hart FF004
> Jack H:
> Me too!
> john h
> mkIII
Jack and John,
Me Three!
I'm not that far from 80 and plan that I will still be taking the
firefly out of the trailer and enjoying the scenery in SW Ohio when I
reach that goal in 2010.
Gene Ledbetter
Firefly 370 hrs
Subject: | Driving to Monument Valley |
Kolb guys,
Although it is my intention to attend, I have a lot of logistics to contend with
during that timeframe. I still plan on moving to Missouri by June 1st.
Plus, my plane is FAR from being finished. I would have to tow it there, if
I bring it.
After all, does anyone really care to look at a non-flying "Classic to Xtra"
convert?? It'd be a lot easier to leave it at home.....
Mike Welch
Use video conversation to talk face-to-face with Windows Live Messenger.
http://www.windowslive.com/messenger/connect_your_way.html?ocid=TXT_TAGLM_WL_Refresh_messenger_video_042008
Ron:
Maybe you are in the wrong area of aviation.
I'm regulated, I reckon, but not much.
My type flying has few restrictions, especially if I stay out of controlled
airports. I only land in D or higher airpace when it is absolutely
necessary.
Most of my flights, all over our great land, are pretty much alone. I don't
see many airplanes in the air from my point of view.
My days flying in the Army have been over for many, many years. Gone are
the days when it was dictated where, how, and when I could fly. Kinda like
my flying freedom I have been enjoying all these "civilian" retirement
years.
Take care,
Subject: | Re: Attendees to Monument Valley Sign-Up sheet |
to sign up, for those and their favorite others, to attend.
> Driving in:
> Flying in:
> 1) John Hauck, MKIII, Titus, Alabama
Subject: | Re: Driving to Monument Valley |
Xtra" convert?? It'd be a lot easier to leave it at home.....
> Mike Welch
Mike W:
You don't really expect us to answer that question, do you?
If you don't bring it, we'll have to find something else to tear apart.
After all, we have three days to try and stay occupied.
Grading take offs and landings is always a lot a fun as long as we are
really screwing them up. Remember, we have to land to the south and take
off to the north, despite the wind direction or speed. Most of us could
take off to the south, but the hierarchy at Gouldings would probably frown
on that.
If you did, you would not be the first to haul a non-complete Kolb to MV.
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Sent: Tuesday, April 15, 2008 12:57 PM
Subject: Re: Kolb-List: Attendees to Monument Valley Sign-Up sheet
>> Driving in:
>> 2) Larry and Karen Cottrell with numerous dogs
>> Flying in:
> Release Date: 4/14/2008 9:26 AM
Larry C:
You gonna leave the birds, cat, horses, coyotes, jack rabbitts, chickens,
and others, at home?
At 01:20 PM 4/15/2008, william sullivan wrote:
>Found it. The stainless steel brackets got slightly bent in the roll-over.
>I am tone deaf, but they are tight now- a little careful re-bending.
Others have pointed out the danger of re-bending... and besides, any bend
out of shape would probably make them tighter, not looser. If there was
that much stress the cables themselves may be stretched, and/or the
thimbles elongated... you might want to consider replacing the cables _and_
tangs, it's fairly simple and inexpensive to do.
-Dana
Friends help you move. *Real* friends help you move bodies.
Same here... though I'd like to get a tad more cruise speed; 5000 rpm only
gives me 40 mph , the US is pretty draggy.
-Dana
Hello from Minnesota.
I am trying to help a friend find a good used
Kolb FirestarII or MK3. If you know of any
decent Kolbs out side of regular channels like
Barnstormers, please email me.
Jon LaVasseur
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> -Dana
Dana:
All the two strokes I flew used a standard tuned expansion system for
exhaust. That was the Cuyuna and Rotax two strokes.
My preferred cruise rpm was 5,800 for both brands of engines. That's about
75% power. IIRC max continuos rpm was 6,500 rpm for both brands. These
engines were designed to operate continuously up to and including 6,500 rpm.
Both brands seemed to "come up on the pipe" at 5300 to 5500 rpm. At this
rpm band, the engine would not want to settle down, requiring constant
throttle changes to attempt to maintain constant rpm. Above 5500 the
engines smooths out, gets a crisp feel, as they start producing power in
their tuned power range.
I am a firm believer in running engines hard and making them work in their
designed power range. I think this keeps them cleaner and they will last
longer.
Flying around bogged down, producing carbon and loading the crankcase with
oil residue, IMHO is much harder on the two stroke.
At 5800 rpm my US cruised 65 mph with a 50X30 Jim Culver two blade wooden
prop. My FS cruised the same with a 40 hp 447 and a 60X30 Jim Culver two
blade wooden prop.
Both aircraft flew quite well at slow speeds, stalling at 25 mph. However,
like their big cousin, the MKIII, they had a sweet spot that was quicker and
much more comfortable to fly and play.
>about 75% power. IIRC max continuos rpm was 6,500 rpm for both
>brands. These engines were designed to operate continuously up to and
>Both brands seemed to "come up on the pipe" at 5300 to 5500 rpm...
>prop...
Thanks John, I'll have to play some more. I had been thinking 5800 seemed
kind of high, what with the Ultrastar manual talking about 4500 being a
"nice comfortable cruise." 90% of my flying so far has been in the pattern
(I want to get more comfortable with being able to always put it down where
I want to before venturing farther afield), so I haven't had much time to
experiment. Seems unlikely I'll see 65, though, if 5000's only giving me
40 (where my ASI matches a borrowed Hall ASI).
Do you recall what kind of fuel burn you got at 5800? Or what speeds you
used for climb and approach?
-Dana``
We all know that engineers love to play with expensive toys.
Especially when someone else is paying for them.
Just an observation,but how many ultra light pilots also ride motorcycles?Of the
guys I fly with regularly,5 of 7.Ordered my Firestar when I was 60,in 1998,sold
it this year cause the wife said could only have one plane,keeping the MK-3.
Sent: Tuesday, April 15, 2008 11:43:57 AM
Subject: Re: Kolb-List: Re: Firestar Project
>> Jack B. Hart FF004
> Jack H:
> Me too!
> john h
> mkIII
Jack and John,
Me Three!
Gene Ledbetter
Firefly 370 hrs
>motorcycles?Of the guys I fly with regularly,5 of 7...
After several crashes in my teen years I swore off anything with only two
wheels and a motor... I'll stick to SAFER things like ultralights and
antique airplanes!
-Dana
Never write device drivers on acid.
I'll be there with Will. Might be picking up Dennis if he wants.
C175B 180/CS
someone has to keep an eye on you folks!
John, I have cases of new civilian meals, really good. Interested?
Dave.
Dave Rains
N8086T
http://forums.matronics.com/viewtopic.php?p=177079#177079
> -Dana``
Dana:
Thinking it was around 3.0 gph for the 35 hp Cuyuna ULII02 and 3.5 to 3.75
gph for the 40 hp 447.
I climbed at whatever felt good and shot my approaches at about 40 mph.
Thanks, that's about where I am right now. 35 "feels good" on climb and 40
feels right on approach.
It's so much fun to see my airplane skills slowly returning... the PPG's
which I've been flying for the past 7 years are a blast, too, but it's a
completely different skill set.
-Dana
There are 3 kinds of people: those who can count & those who can't.
-Dana
From: | "Steven Green" <Kolbdriver(at)bellsouth.net> |
Subject: | Re: Alternate Firefly engines |
In a message dated 4/15/2008 12:15:52 P.M. Central Standard Time,
jbhart(at)onlyinternet.net writes:
Jack B. Hart FF004
Winchester, IN
Hi Jack,
Have you had a chance to make any progress with the mz 34 . I will
be up for another De-carb in about 18 more hours. I would just as soon install
a different engine at that time. I am still looking at the Kawasaki 340,
and the 1/2 vw, and the mz 34. After 88 hours on the 447 I still cannot keep
the egts below 1200 *, at 4400 rpm, without them going down to 975- 1000* at
cruise. I am to the point now I am going to take a little off of the jet
needle in the area of 4400 rpm if I can ever figure out how to compute where that
is.
Ed Diebel
**************It's Tax Time! Get tips, forms and advice on AOL Money &
Finance. (http://money.aol.com/tax?NCID=aolcmp00300000002850)
In a message dated 4/15/2008 10:43:40 P.M. Central Standard Time,
ElleryWeld(at)aol.com writes:
I wouldn't install a Kawasaki that sure is recipe for some glider time
Ellery in Maine
Ellery,
Just curious as to why you would make a statement like that. Do you
have first hand experience with the Kawasaki? I had a little over 115 hours on
a
440 with zero problems. Never had to mess with jets. Never had to de-carbon
at 50 hours! I could let it Idle for several minutes without it loading up.
It always started easy and ran and idled smoothly. The Kawasaki was the
engine of choice before I ever heard of Rotax. They also have a Nikasil coating
on the piston/ cylinder. What experience have you had with a Kawasaki ?
Ed Diebel
Flying a Kolb outside of the radar scope as it were certainly still has a sense
of freedom. However if you follow the discussions even here much of it is about
regulations and compliance. If you come from the ATV crowd and you start having
to contend with all of that, unless you are a dedicated aviation buff I think
you would have a hard time justfying to yourself the burden to carry if you
want to fly. Ultralights notwithstanding. I see the young folks all the time
and I remember how it was back in the 70's early 70's. The world has changed
a lot and not to the better in aviation.
I can tell one thing there is a shortage of pilots, and its not getting any better.
Even at the bottom feeding jobs they pay real money now, where before you
had to beg them to give you a job. People still want to fly but the hurdles are
tougher now than they were back in the day. I keep telling anyone that asks
me if I were to do it again I would have gone to Law School and made aviation
my hobby. Now by default and because of aviation law is my DE-facto hobby and
aviation is my profession. :-)
---- John Hauck wrote:
Ron:
necessary.
years.
Take care,
kugelair.com
I almost made it to 85,>>
C`mon Bob,
we both have a birthday to celebrate in August..
Pat
Subject: | Handbury parachute |
Question for John Hauck (since I know one saved your butt twice) or anybody
else who knows:
The Handbury hand deployed airframe parachutes... The cable attaches it to
the airframe, but it still has a harness worn by the pilot??? Is that just
so there's a place to put it? Some of your posts, John, mention the
inconvenience of strapping into both the parachute and the plane, so why
not mount it to the plane, perhaps alongside the seat?
I ask because I can maybe get one for a good price, while a modern BRS
would cost more than I paid for the entire airplane, far out of my price range.
-Dana
Smallpox has been largely destroyed - should the virus be given endanged
species status?
From: | william sullivan <williamtsullivan(at)att.net> |
Tony- How much work has been done on your 503? Any problems? How about wear and
tear on the plane? Any bent gear, etc.?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
If you come from the ATV crowd and you start having to contend with all of
that, unless you are a dedicated aviation buff I think you would have a hard
time justfying to yourself the burden to carry if you want to fly. Ron
Ron:
I am a dirt biker, and recently, last December, purchased a Honda Rincon so
Nell can ride with me. We spent two months out West last year for me to
ride the deserts and the Rockies on my dirt bike. I have to drive many
miles to find good places to ride off road.......... More and more areas
are being restricted from ORV's.
I also collect antique tractors, which have absolutely no regulation, and
are my favorite hobby. They cost less to purchase, maintain, and operate.
Like I said in my previous post, I find little regulation flying my MKIII.
I had to have one inspection in 1992, to fly it. Have not had one since.
Had to get a Private Fixed Wing Ticket to fly it in 1990. I get a BFR every
two years, along with a medical by my old country flight surgeon in Clanton,
Alabama. If I want to, I can stop getting the medical and fly on my drivers
license as a Sport Pilot. I fly out of my own airstrip, seldom landing at
regular airports unless I am flying a cross country flight. Flying my own
experimental airplane, I have a Repairman's Certificate. I can sign off on
all work and inspections. Other than the BFR and Medical every two years, I
am pretty much left alone by the FAA, unless I screw up and do something
dumb.
I don't have any inclination to stop flying any time soon. If I did, it
would probably be because I can not afford to keep it fueled, or I get too
old to enjoy flying.
The type of flying you are doing can not compare to the freedom of the type
of flying I do in my Kolb.
Tony:
Brother Jim welded up your fuselage, and I inspected it prior to
shipment in February 1991. My MKIII is M3-011. Your serial number
should be M3-024.
Kolb MK111 serial number M3-24 Delivered Sept 91 and ready to fly
April 93 and 820 hrs work later. { not by me}I purchased the plane with
60hrs TT.503 rotax with about 360 hours on it now and still going
strong.
Tony
Downunder
Subject: | Re: Handbury parachute |
> just so there's a place to put it? Some of your posts, John, mention the
> range.
> -Dana
Dana:
Yes, the Jim Handbury, hand deployed parachute can be worn or attached to
the airframe in a place that will allow hand deployment. In my case, it was
the most convenient location, and the only place left in the aircraft to
stow it.
It would be prudent to have the parachute inspected by a certified parachute
rigger prior to using. These are now very old parachutes. They also
require an annual repack and inspection, but not by regulation because they
are not certified parachutes.
I paid $500.00 for mine in 1984. It saved my life twice before I retired
it. Figure I got my money's worth at $250.00 a pop. ;-)
Date: Tue, 15 Apr 2008 22:23:15 EDT
Have you had a chance to make any progress with the mz 34. I will be
keep the egts below 1200 *, at 4400 rpm, without them going down to 975-
1000* at cruise. I am to the point now I am going to take a little off of
the jet needle in the area of 4400 rpm if I can ever figure out how to
compute where that is.
Ed,
The MZ34 is out of the box and resting on the propeller mounting flange on
the shop floor. The engine mount is done. Right now I am figuring out how
to mount the exhaust system. Also working on how to mount a Mikuni 30 or
24 mm carburetor as I do not understand pumper carburetors. All the steel
has been cut to length for an engine test stand. I have to cut the end
angles so that it can be welded.
I believe I can help you with your needle modification. If you can print
out from:
http://www.thirdshift.com/jack/firefly/firefly121b.html
and reduce the drawing by 50% it will give you a full scale needle drawing
for length. Or each little square is 1/16th of an inch on a side. Also the
drawing shows the needle with the throttle in the closed position relative
to the needle jet. So you should be able to determine which area from which
to remove material.
To start, I would recommend removing material from less than zero to where
the taper starts on the needle. Do not take more than one or two thousands
of an inch off the OD at a time with out a test flight. It may take a half
dozen flights but you should be able to lower the high EGT readings at the
lower rpms, and then to boost the EGT at cruise by dropping the needle a
slot.
Jack B. Hart FF004
Winchester, IN
>the shop floor. The engine mount is done...
Jack, another engine? Did you give up on the Simonini Victor then?
-Dana
I intend to live forever or die trying.
Dana,
No. The Victor is a good engine, but all the numbers indicate the FireFly
should be able to fly very well with a lower hp engine. This is being
proven out in the UK. Early on, I realized that with the Victor 1+, I was
going to be up against the weight limit just like the Rotax 447. The Victor
burns about one gph less than the Rotax 447, but I still wanted more range.
About three years ago I bought the MZ34. I calculate it will reduce the
present empty weight by 45-50 pounds. By dropping down in hp, I can add
weight back and decrease the total drag, and cruise just as fast with a
lower gph rate. This will let me fit a full enclosure so that I can fly all
winter. If I had not been forced to move, the MZ34 would have already been
mounted. But I am still moving dirt to expose the entrance to my walk out
basement shop etc, etc.
The explosion in fuel cost has accelerated the desire to lower the gph rate.
I still plan to warm weather fly with my head out. At 50-55 mph this is
great fun. Presently with the Victor 1+, I feel like I am saving at least
$3.00 to $4.50 per hour over the Rotax 447. With the MZ34 I hope to save
another $1.00 to $1.50.
Jack B. Hart FF004
Winchester, IN
Subject: | 503 Teardown Report |
I have seen a few questions about the 503 on the list lately. I just finished
tearing down my 503 after 452.0 hrs of trouble-free service, so I thought I would
pass along my data.
Pistons:
The pistons were inside the wear limits for diameter, out-of-round, and taper.
The only visible wear was on the intake side of the piston where it slides by
the intake port. In this area some of the textured finish had been worn shiny.
Both pistons showed similar wear. Both wrist pins were slightly discolored.
One of them had a slight wear mark where the hardened washer sits on it. Carbon
on the piston tops was approx .015 thick on the rear piston and 0.010 thick
on the front piston. The spark plugs for the front cylinder also showed less
carbon. This was traced to a slight leak in the front crank seal that was
leaning the mixture to the front cylinder slightly. The resulting difference
in EGT's had grown slowly to 100 deg over the last 20 hrs of operation and was
the main reason for the full tear down. There was also a slight weep of oil
under the front of the engine. The ring end gap was within wear limits and all
rings moved easily in their slots and feel "springy". Ring groove wear was
still within limits.
Cylinders:
The cylinders both measured the same. All areas were within wear limits except
for a narrow band of wear just above the exhaust port. This area stayed inside
maximum diameter, but was worn to the 0.002 out of round limit. They are currently
being bored 1st over.
Heads:
The heads are shiny on the underside except for two thumbnail size dots of carbon
discoloration across from and on opposite sides of the spark plug hole.
Crank:
The crank was near the maximum run out spec of 0.003 on the fan end. I suspect
this may have led to the demise of the crank seal on that end. The only visible
wear was inside the piston end of the connecting rods where the cageless needle
bearings run. The honing crosshatch was worn smooth in a small area area
about 40deg down from the vertical on one side of the con rod bore. There was
some visible corrosion stains on the counter balances, but nothing that looked
fresh or would leave a streak on a white rag.
All in all, I believe the engine could have gone another 100 or so hours if the
front crank seal had not begun to leak. It gave me ample warning signs of brewing
problems, while continuing to run like a swiss watch. The EGT discrepancy
between cylinders was (verified by switching probes) and the oil seep were
clear signals. I am replacing every moving part of this engine: crank, pistons,
wrist pins and bearings, fan bearings, fan belt etc. Total cost for parts
and machining comes to $1780.76 plus return shipping on the crank core. This
gives a rebuild cost of just under $3/hr.
I used the AV-1 oil From CPS for the first 119.6hrs. I did a decarbon at this
point and replaced the wrist pin bearings. The carbon from the AV-1 was hard
as a rock and took many hours of scrubbing to remove. I used Penzoil Marine premium
synthetic blend from wally world with two oz of Marvel mystery oil per
six gallons for the next 325.4 hrs. The last 7 hrs I switched to Penzoil air
cooled with Marvel. I have performed annual carbon inspections and have not needed
to decarbon again.
Sorry for the long post. I hope this info is helpful to someone.
Roger in Oregon
1992 KXP 503 - N1782C
http://forums.matronics.com/viewtopic.php?p=177237#177237
Subject: | Re: 503 Teardown Report |
Roger, thanks for the comprehensive report. You mentioned 100 degree EGT
split between cylinders. Was it 100 at full power and 100 at cruise, or
what?
I ask because I just noticed that my 503 is 100 degrees hotter EGT on one
than the other at full throttle, but only about 35 degrees split at
cruise. I also have oil leaking from the back of the low-time engine
(reportedly 25 hrs since new). I was wondering if this could be the same
thing.
I bought the plane last fall and only have about 20 hours on the low-time
Rotax 503. It's my first Rotax so I'm not very familiar with it.
. . . This was traced to
a slight leak in the front crank seal that was leaning the mixture to the
front cylinder slightly. The resulting difference in EGT's had grown
slowly to 100 deg
In a message dated 4/13/2008 9:03:55 P.M. Eastern Daylight Time,
donghe@one-eleven.net writes:
Hey..I just checked out the Sun-n-Fun Newsletter at the website..And I wanna
Congratulate our own brother Steve B, and Brian M for their Grandchampion
Win on the FloatFly!...way to go men!
All, here is a shot of the 2008 SnF UL Grand Champ.
Steve B
Firefly 007/Floats
Firefly 0040/ Floats 2008 SnF Grand Champion UL
**************Need a new ride? Check out the largest site for U.S. used car
listings at AOL Autos.
(http://autos.aol.com/used?NCID=aolcmp00300000002851)
finished tearing down my 503 after 452.0 hrs of trouble-free service, so I
thought I would pass along my data.
> Roger in Oregon
Roger:
Make sure you get it back together in time to fly at Larry's next month.
john h - Patiently waiting for time to depart for MV.
Greetings from Minnesota.
I probably shouldn't enter the attach photos in
the contest because I didn't actually take them.
They were taken by Arty Trost at MV in 2007.
These and other pictures from last year remind me
of a magnificent place, a great time and some
really neat people.
John W, if I win the $10,000.00 first prize, I'll
share it with Arty.
Jon L
John:
I would have it together already if I had not done business with CPS in California.
They backordered a bunch of stuff, after telling me it was in stock. I
found out when things didn't arrive. The wrist-pins they sent me had fingerprints
rusted into them. They suggested "scotch brighting" the rust off and then
using them. (No I'm not kidding!) Needless to say I sent them back and have
ordered all backordered items elsewhere. I will not conduct business with them
again. I thought that I could save time because they are only two shipping
zones away, but ended up adding two weeks to my rebuild. Doh! My advice to anyone
on this list is to avoid CPS like the plague.
If all goes well, I will have two weekends to run-in and test-fly before heading
to the Rock House. Lord willin' and the creek don't rise I'll make it!
Roger in Oregon
http://forums.matronics.com/viewtopic.php?p=177284#177284
Jim:
The difference between EGT readings did vary with throttle setting. I was always
able to find a spot in the upper to middle cruise range where they would get
within 40-50 degrees or so. The oil leak began as part of a drop every few
hours and was starting to streak back along the bottom of the engine the last
couple of hours. If all I ever did was fly the pattern or around farm fields
and flatlands, I would have put this off 'til November, but desert canyons and
coastal mountain ridges are not very forgiving. My advice is "when in doubt,
change it out." At my wife's suggestion I am going to start putting away a little
each month for an engine rebuild fund. If the 503 lasts long enough, I
may be able to switch to an HKS somewhere down the road.
Roger in Oregon
http://forums.matronics.com/viewtopic.php?p=177286#177286
Bill S:
Based on your statement below, I feel you are getting into this way over
your head.
Changing the length of the tailboom, shortening it, will change a docile
Kolb into one that is nearly unmanageable.
Changing aerodynamics and control systems to suit your fancy for an
airplane you have never flown, especially when you have never flown a
Kolb and, I understand you are also a low time pilot who has not flown
in nearly 40 years, is not recommended. As long as I have been building
and flying Kolbs, I don't make changes in these areas, because I want to
live to fly tomorrow.
Changing a Kolb "to suit your fancy" or "squeezing it down to fit the
mission" may well quickly bite you in the ass. It is not "a broad
playing field".
Probably be to your best interest to have a reliable individual with a
lot of knowledge of building and flying Kolb aircraft carefully inspect
your Kolb before you ever make a decision to commit aviation in it.
Good luck with your project,
To me, the basic current Kolb design is eminently suitable for
modifications. You can make them lighter, shorter, streamlined, open
cockpit, doors, control mods (Hi! Mike), shape wings and tail to suit
your fancy, re-power easily, and you name it. Or, like me, squeeze it
down to fit the mission. It's a broad playing field, all on the same
design.
Bill Sullivan
They suggested "scotch brighting" the rust off and then using them. (No
I'm not kidding!) >
> Roger in Oregon
Roger:
Great news!
I quit doing business with CPS and LEAF many, many years ago for very
similar reasons.
Recommend South Mississippi Light Aircraft, Ronnie Smith, Lucedale, MS. He
can probably get stuff to you all as quickly as any of the other ROTAX
service centers.
Ellery:
The MKIIIx was manufactured by TNK. Give Travis a call. He should be
able to run down the history on that kit.
I have M3X 00 2 00011 is there info in this number that will tell me
anything about this kit like when it was manufactured
Ellery in Maine
The only work carried out on the 503 is the work that I have carried out
and that has been mainly service checks.
Engine has been stripped twice for de-carb. Carb needles replaced as old
ones had nearly worn through and rubber carberator boots replaced
because of signs of cracking in originals . Engine due for another pull
down now.
The only other iteam thats needed attention is the exhaust bracket that
runs from the head to the muffler started to crack around the head nuts.
I include a check of this as part of pre flight before every flight.
There have been no other problems.
No bent gear legs. The only thing that may need attention in the next 50
hrs or so is there is some cracking starting to appear in the lexan in
the odd place were it has been riverted .
Tony
To: kolb list
Sent: Wednesday, April 16, 2008 11:43 PM
Subject: Kolb-List: Tony's Kolb
about wear and tear on the plane? Any bent gear, etc.?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
>should be able to fly very well with a lower hp engine...
What do you think the HP reduction will do to your takeoff and climb
performance?
-Dana
Give a man a fish and he will eat for a day. Teach a man to fish and he
will sit in a boat all day drinking beer.
Quote
Sounds like you are burning very clean. I have a question regarding the Marvel.
Is the 2 oz of Marvel substituted for 2 oz of the Pennzoil in the mix, or added
in on top of the 50 to 1 mix?
Dwight
http://forums.matronics.com/viewtopic.php?p=177341#177341
Dwight:
I add the Marvel in addition to the 50:1 mix of two stroke oil. I can't say for
sure that the Marvel is what kept my engine clean, but I can state with confidence
that it didn't do it any harm.
Roger in Oregon
http://forums.matronics.com/viewtopic.php?p=177354#177354
capedavis(at)yahoo.com wrote:
> Roger ,A kxp with a 503 aint that a great combo .Mine was a 1990 I finished
it in 92 and flew it for 10 years ! a short ground roll and then straight up
what a joy . Wish I still had her. Chris
It is a great combo! That is what I meant by hoping I'm still flying it at 60.
I hope to have built a two seater by then, but don't want to give up the KXP.
I want my KXP to last 'til I'm 60 and then some.
Roger in Oregon
http://forums.matronics.com/viewtopic.php?p=177356#177356
You can make them lighter, shorter, streamlined, open cockpit, doors,
control mods (Hi! Mike), shape wings and tail to suit your fancy,
re-power easily, and you name it. Or squeeze it down to fit the mission.
It's a broad playing field, all on the same design.>>
Hi Bill,
I am sure someone with a lot more Kolb experience than me will guide
you away from your chosen course.
I do have a bit of experience in other planes and I can only regard your
`make it shorter, make it lighter philosophy` with concern. Sure there
are things you can do. Doors, re engine etc., but messing with the basic
design by changing the shape and size of flying surfaces and shortening
the fuselage is playing with fire unless you have a good grounding in
aeronautics. You may finish up with a plane which fulfils the parameters
but it won`t be a Kolb. So instead of having a plane with a tried and
tested history you will have a one off machine which may or may not be
any good. Why reinvent the wheel?
.<< A lot of them (rules) are pure nonsense. For example, allowing
30 extra pounds for floats when a life jacket would do the same thing>>
I don`t think that the object of fitting floats is to support you in the
water in the case of a crash. To equate a lifejacket with floats shows
a tendency to confuse apples and oranges.
I realise that in the States you have a much more cavalier attitude to
rules and regs than we rather `button down` Brits and I applaud that ,
but it seems that you are planning to take things a bit far.
The old building adage is `Measure twice and cut once` To that I would
add `Think three times`
Good luck,
Cheers
Pat
From: | "Denny Rowe" <rowedenny(at)windstream.net> |
Pat,
Please understand Bill is talking about all the variations in Kolb
models (ie: Mk-3 to Slingshot to Kolbra to X-tra, or the many Firestar
models to Firefly) as well as many of the listers slight departures from
stock. NOT about doing all these mods to his personel plane.
John H and yourself are missing his point of how flexable the basic Kolb
design has proven to be. As Bill stated more than once, he has no plans
of doing any major changes to his own bird. He is only pointing out the
obvious flexability of Homers creation.
Denny Rowe
Sent: Thursday, April 17, 2008 5:16 AM
Subject: Re: Kolb-List: Firestar project
Hi Bill,
your `make it shorter, make it lighter philosophy` with concern. Sure
there are things you can do. Doors, re engine etc., but messing with the
basic design by changing the shape and size of flying surfaces and
shortening the fuselage is playing with fire unless you have a good
grounding in aeronautics. You may finish up with a plane which fulfils
the parameters but it won`t be a Kolb. So instead of having a plane with
a tried and tested history you will have a one off machine which may or
may not be any good. Why reinvent the wheel?
the water in the case of a crash. To equate a lifejacket with floats
shows a tendency to confuse apples and oranges.
would add `Think three times`
Good luck,
Cheers
Pat
Checked by AVG.
4/16/2008 5:34 PM
Subject: | Firestar project |
Jeremy- My stainless steel cable brackets do not look like the ones in the pictures
you sent. Mine have one hole in each end. I will replace, just in case.
Re: Tail boom length- mine is a foot shorter than a regular Firestar. With
the original wings- about 25' 4", supposedly the handling was great. The former
owner had nothing but praise for it. Somebody mentioned trim tabs- My original
right wing has one, I think about 3" x 6",but I can't tell how much of a bend
in it. No tabs on the tail.
I will have an opportunity to do a side by side check of both a Firefly and
a Firestar. And also get the builder/pilots to do the same on mine. There are
a couple of very experienced people at the club.
Here is where some of the fun comes in: Trying to guess what kind of handling
performance it has, relative to a "stock" Firefly or Firestar. Anybody want
to try for some experienced speculation? The length is 19'- shorter than either
model. Wingspan is about 27' 4". Engine is what appears to be a stock 447,
with a 2 blade Warp Drive prop, pitch unknown. The wings are located 2 1/2" farther
to the rear than stock. Leverage on the controls appears to be stock.
Comments, anyone?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
Denny:
I may be missing Bill S's point in that one msg, but I consider
relocating wings 2.5 inches aft of the prescribed position, and
shortening the tailboom, major changes.
The second tailboom in my MKIII was shortened one foot. Luckily I did
not have to fly it long before it was time to change to the correct
standard length. I would never have thought that one change would
affect the flight characteristics of my MKIII, but it did, adversely...
I'm not an aeronautical engineer, but seems to me that moving the wings
back 2.5" and moving the tail section forward by what ever the tail boom
was shortened, will drastically influence the flight characteristics of
whatever model Kolb Bill S intends to fly.
Kolb design has proven to be. As Bill stated more than once, he has no
plans of doing any major changes to his own bird. He is only pointing
out the obvious flexability of Homers creation.
Denny Rowe
Subject: | 582 muff Brackets |
John H, Richard Pike, And anyone else that has , or had a 582 on a
MK-3C, how have you guys mounted your mufflers & with what type of
brackets without a Bracket cracking problem? (If any) Have you mounted
them above the exhaust manifold, with angle alum. like the 503 plans in
the MK-3 manual? ( If so , what thickness & dimensions) ??
Or with the brackets that LEAF & Lockwood sell that bolt to the side of
the engine under the exhaust manifold, & if so, can you do that & the
muff still clear the wing gap seal? (which I will still fly with)
Thanks, Jim, Cookeville, TN,
Self grounded ' til I eliminate this problem.
(I don`t do Crack)
was wondering, with the advent of the alky in our gas of late, could we
ofset the cylinder 'wash-down' of oil from alcohol by adding marvel oil to
our gas. I know it says not to put additives into our gas but it might help
a little. what do all you experts think? Ted Cowan, Alabama Slingshot 912
UL
Subject: | Re: 582 muff Brackets |
Jim K:
I used whatever came in the kit for muffler mount on the 582. Think it
was a 4130 system designed and manufactured by old Kolb that bolted to
the side of the engine. Been to long to get a clear picture in my mind.
Just a thought here on alcohol.My tester is a test tube with graduations on it
.Fill to about 1 inch with water,add fuel to the top line and shake.The water
line has 3 or 4 marks above it marked in percentages of alcohol.That water line
rises according to the amount of alcohol in it after it sets a minute or two.It,s
a Briggs & Stratton fuel tester.If I put a pint of water in 5 gallons of
fuel ,shook it up ,let stand then poured it thru a water separating funnel,would
it effectively remove the alcohol,without removing any additives or change
anything else?
Sent: Wednesday, April 16, 2008 8:39:01 PM
Subject: Kolb-List: Re: 503 Teardown Report
Quote
Dwight
Subject: | Emergency Parachute |
From: | "grantr" <grant_richardson25(at)yahoo.com> |
John Hauck I noticed in another post that you have deployed an emergency parachute
twice during your flying time.
What were the reasons for the deployments?
My plane dose not have a emergency chute on it. I am considering getting a BRS
for it .
Has anyone else had to deploy an emergency chute?
Are there any other cheaper options that BRS besides the hand throw chutes? I would
be scared that a hand throw chute might get caught on the prop or something
else if it was just tossed out by hand.
http://forums.matronics.com/viewtopic.php?p=177404#177404
From: | "Kirby, Dennis CTR USAF AFMC MDA/AL" <Dennis.Kirby(at)kirtland.af.mil> |
Dennis Kirby
Cedar Crest, NM
I've heard of doing that, but by draining off the separated water first with a
siphon. Maybe then pour thru the Mr Funnel to get the last little bit.
BUT, heres the problem the way I see it. The ethanol is put there not just as
a filler (to make the tree huggers and corn farmers happy) but it also boost the
octane. So lets just say the basic mix of 10% ethanol enhanced fuel is maybe
only 84? octane before they mix in the ethanol. The ethanol brings the octane
up to the min requirement of 87 without using lead or other more expensive
additives to the blend. When you remove it, the octane is going back down, plus
you have 9/10 of the gallon of fuel you paid for, and a mess to dispose of.
Anyone out there in the refinery business that could shed some light on this?
Dwight
http://forums.matronics.com/viewtopic.php?p=177424#177424
Thanks!
Sent: Thursday, April 17, 2008 7:40 AM
Subject: Re: Kolb-List: 582 muff Brackets
Jim K:
it was a 4130 system designed and manufactured by old Kolb that bolted
to the side of the engine. Been to long to get a clear picture in my
mind.
Jim, call Bryan at 606 682 3388. He makes a very nice aluminum plate system.
steve
In a message dated 4/17/2008 8:24:02 A.M. Eastern Standard Time,
jlsk1(at)frontiernet.net writes:
John H, Richard Pike, And anyone else that has , or had a 582 on a MK-3C,
how have you guys mounted your mufflers & with what type of brackets without a
Bracket cracking problem? (If any) Have you mounted them above the exhaust
manifold, with angle alum. like the 503 plans in the MK-3 manual? ( If so ,
Steve, I just talked to Bryan, he didn`t have anything, nor info for me,
only dealing with 912's
Thanks anyway, Jim
Sent: Thursday, April 17, 2008 1:17 PM
system.
steve
Need a new ride? Check out the largest site for U.S. used car listings
at AOL Autos.
Sorry, I just figured out that you were talking about a 582.
steve
In a message dated 4/17/2008 3:03:36 P.M. Eastern Daylight Time,
Thanks anyway, Jim
steve
_jlsk1(at)frontiernet.net_ (mailto:jlsk1(at)frontiernet.net) writes:
Need a new ride? Check out the largest site for U.S. used car listings at
_AOL Autos_ (http://autos.aol.com/used?NCID=aolcmp00300000002851) .
(http://www.matronics.com/Navigator?Kolb-List)
(http://www.matronics.com/contribution)
Bill S:
Don't know that aft cg bends gear legs. Was more prone to believe that
was a pilot's responsibility.
You all may be right about somebody changing aft CG. This this came
through with a box of bent LG legs.
Bill Sullivan
Bill S:
That's great!
How much time does he have in a Kolb?
Don't know that a B-52 pilot has much in common with a Kolb pilot. ;-)
These are the guys that usually have all the qualifications, but end up
breaking the Kolb.
Good luck.
I have a brother-in-law who is qualified all the way up to a B-52,
and he is itching to flight test it.
Bill Sullivan
Subject: | New engine package, ( FireFly alternate maybe) |
Gents,
I dont know if you went down to the Sun'n'fun Gala, and even if you did you might
not have paid much attention to the runner-up to Steve's FloatFly...The second
place winner was a Buckeye powered parachute with a v-twin 32 hp generac
industrial engine on it. This is the the same kind of airframe that won the inovation
award, and something else at OshKosh last summer with the Honda V-twin
on it. I have been closely watching these guys and they are making great strides
at bringing 4 stroke industrial engines into our sport. I have spoken with
Ralph at Buckeye personally many timies over the last year, and I can tell you
he is definately going to offer this as an engine package to the entire market.
Right now...he is very close.
Let me give you some of the details on this generac package.
993cc v-twin 4 stroke. (this engine will go 2500 hours at 3600 rpms men)
PolyV belt reduction of his own design, and it looks like very high quality.
Tennessee prop. (it is swinging a 74 incher on the chute, 36 pitch I think)
Eletric start!
Static thrust numbers are in excess of 300 lbs!at 3800 rpms...This is more than
a 447 with a 2.58:1 and a 60 inch
Fuel consumption is 1.5 gallon per hour. (Industy rating for generator application)
and I am certain it is very close.
Electric start Engine, prop,reduction unit and mufflers are right at 100 lbs.
At this time, the engine is NOT modified, it is stock, so the TBO for its industrial
application will be the same.
He told me just this week he thinks he will be able to deliver the whole package
to market for about 3500 bucks.
Now, I dont know if a FireFly could stand a 100 lb powerplant package and still
make 254lbs....but I do know for certain it will fly with the weight..and fly
very well. A FireStar should be a jewell with this package.
Some of you have heard me preach before that the industrial v-twins are soon to
be a viable powerplant for our sport, and that time is very quickly approaching!
Fuel consumption will allow ranges like we have never seen before on 5 gallons...the
noise is so much less than we are used to it is unbelievable...and
electric start. Not to mention the price will be half what a rotax package will
cost, and the way Rotax is going...likely alot less than half very soon. Most
of us would never even have to consider an overhaul.....not in 2500 hours, thats
more than a lifetime for 99% of the ultralites
It has also been said that the sport pilot rule has killed the ultralight market
by so many in the industry I cannot count em all. Well, I challenge that reasoning.
I believe it is the Cost...Rotax engines have doubled in price in the
last few years, and I believe this is the biggest reason. If a manufacturer could
take 30% off an ultralite plane/engine cost to the customer, this might be
the biggest boost the market could get, and with this package...well, these developments
just might be the revival of the part 103 aircraft market. here is
another prediction...the first company that designs an aircraft around a V-twin
powerplant package and gets it to market, will have a huge success in sales!
Buckeye has done this with their DragonFly PPC and I hope someone does it with
a fixed wing.
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
http://www.geocities.com/dagger369th/my_firefly.htm
http://forums.matronics.com/viewtopic.php?p=177521#177521
Subject: | Re: New engine package, ( FireFly alternate maybe) |
same throw; side by side, .All the current small industrial v=twins are designed
this way
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
http://forums.matronics.com/viewtopic.php?p=177528#177528
>pictures you sent. Mine have one hole in each end.
The Ultrastar has the brackerts with one hole in each end. You make the
cables up with three washers under each bracket, then you remove washers as
necessary to align the surfaces and tension the cables.
> Trying to guess what kind of handling performance it has, relative to a
> "stock" Firefly or Firestar. Anybody want to try for some experienced
> speculation? The length is 19'- shorter than either model. Wingspan is
> about 27' 4". Engine is what appears to be a stock 447, with a 2 blade
> Warp Drive prop, pitch unknown. The wings are located 2 1/2" farther to
Obviously you MUST make sure the balance is correct, relative to the
wing. Then, it'd guess it might be a bit livelier in pitch and yaw than a
stock plane, and you may have less elevator and rudder authority. Also it
may need greater wing incidence, or lower tail incidence, to fly hands off
at the same trim speed.
-Dana
A common mistake that people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete fools.
At 06:30 PM 4/17/2008, william sullivan wrote:
>I have a brother-in-law who is qualified all the way up to a B-52, and he
But how much ultralight and/or Kolb time does he have?
My brother in law used to fly F-15's and F-106's, and now flies GA and
trains people to fly L-39's on the side. I would NOT let him fly my
Ultrastar without some ultralight dual time.
-Dana
Jim,
This was the muffler mount that came from Kolb for the 582 muffler. The
rubber bushings between the red brackets and the muffler bracket were
good for about 100 to 150 hours.
Steven Green
Etowah, TN
Sent: Thursday, April 17, 2008 8:20 AM
Subject: Kolb-List: 582 muff Brackets
of the engine under the exhaust manifold, & if so, can you do that & the
(I don`t do Crack)
Don
there is a Valley Engineering Big Twin with redrive on a Kolb Twin
Star . Dick Starks wife flys it.. Kansas City Dawn Patrol. Generac
engine I think..? Herb
At 07:15 PM 4/17/2008, you wrote:
>Gents,
>did you might not have paid much attention to the runner-up to
>Steve's FloatFly...The second place winner was a Buckeye powered
>parachute with a v-twin 32 hp generac industrial engine on it. This
>is the the same kind of airframe that won the inovation award, and
>something else at OshKosh last summer with the Honda V-twin on it. I
>strides at bringing 4 stroke industrial engines into our sport. I
>have spoken with Ralph at Buckeye personally many timies over the
>last year, and I can tell you he is definately going to offer this
>Eletric start!
>is more than a 447 with a 2.58:1 and a 60 inch
>generator application) and I am certain it is very close.
>for its industrial application will be the same.
>whole package to market for about 3500 bucks.
>package and still make 254lbs....but I do know for certain it will
>fly with the weight..and fly very well. A FireStar should be a
>are soon to be a viable powerplant for our sport, and that time is
>very quickly approaching! Fuel consumption will allow ranges like we
>have never seen before on 5 gallons...the noise is so much less than
>we are used to it is unbelievable...and electric start. Not to
>mention the price will be half what a rotax package will cost, and
>hours, thats more than a lifetime for 99% of the ultralites
>ultralight market by so many in the industry I cannot count em all.
>Well, I challenge that reasoning. I believe it is the Cost...Rotax
>engines have doubled in price in the last few years, and I believe
>this is the biggest reason. If a manufacturer could take 30% off an
>ultralite plane/engine cost to the customer, this might be the
>these developments just might be the revival of the part 103
>aircraft market. here is another prediction...the first company that
>designs an aircraft around a V-twin powerplant package and gets it
>to market, will have a huge success in sales! Buckeye has done this
>with their DragonFly PPC and I hope someone does it with a fixed wing.
>Don G.
>Central Illinois
>Kitfox IV Speedster
>Luscombe 8A
>Read this topic online here:
In a message dated 4/17/2008 8:18:25 P.M. Eastern Daylight Time,
Gents,
might not have paid much attention to the runner-up to Steve's FloatFly...The
second place winner was a Buckeye powered parachute with a v-twin 32 hp
generac industrial engine on it. This is the the same kind of airframe that won
the inovation award
Don, I took a good look at it. Very nice job. Two problems for the
firefly, first it sounds about 15 to 20 lbs too heavy. Second, most belt drives
do
not offer enough extension and the thrust line is a bit high. A gear
reduction usually solves this issue but the 4 stroke harmonics drive the gears
nuts.
I wish them luck. We need some alternatives in the UL area.
Steve B
Firefly 007/Floats
Here is a video of a legal eagle with the big twin
http://www.youtube.com/watch?v=Kn_tnVaQXdo&feature=related
You can see a few more of the plane here.
http://www.youtube.com/user/HartAero
www.culverprops.com has a few videos of the kolb twinstar flying with the v twin
http://forums.matronics.com/viewtopic.php?p=177553#177553
At 09:26 PM 4/17/2008, william sullivan wrote:
>John- Brian (my brother-in-law) has flown just about everything. I am
>almost certain he has never flown a Kolb. I do know that he has experience
>on light (if not ultralight) aircraft...
Bill, it's not the same thing. 400 hours in Taylorcafts did NOT prepare me
to solo a Quicksilver, and Cessna (what I originally learned in) time would
have prepared me even less. 400 hours in the T-Craft and a few hours in
the (two seat) Quicksilver DID prepare me to solo my Kolb... and my Kolb
was less of an unknown, as I had seen it fly before in its current
configuration. There's also the matter of tailwheel time, does your
brother in law have any?
-Dana
Help, I've fallen up and I can't get down
There is a FS II based at our field that had the tail boom shortened by 6"
by the original builder. It flies fine ; can't really tell any difference.
I am not advocating such a change, just telling what I know.
Howard Shackleford
FS II
SC
In a message dated 4/17/2008 6:33:37 P.M. Eastern Daylight Time,
williamtsullivan(at)att.net writes:
I do understand the implications of changes to the basic design.
John,
You are right about the wing movement. You got me by the short hairs
when it comes to why and how the previous owner would move the wings
that much.
Denny
Denny:
wings back 2.5" and moving the tail section forward by what ever the
tail boom was shortened, will drastically influence the flight
characteristics of whatever model Kolb Bill S intends to fly.
Denny Rowe
Checked by AVG.
4/16/2008 5:34 PM
Steve,
The issues you point out are definitely concerns. These guys have overcome the
4 stroke pulses by using that belt drive, and a really slow prop speed that shouldn't
work according to what I was taught in school...but it does with that
big prop.
I have been considering what I was taught about tip speed and prop efficiency and
so on now for a year since I started paying attention to this deal, only to
come to the conclusion that either the books were wrong, or the propcarvers have
become magicians!
They believe they are going to get good life. The Honda powered machine at Oshkosh
now has alot of hours on it, with no belt problems, abiet, the Generac is
larger and more powerful, so it will have a stronger pulse. Time will show.
What the powerplant needs is a new airframe designed around it just as they are
putting it together, to support slow turning 74 or 76 inch prop to optimize the
thrust, and make the components last along time.
I didnt know Dick Starks had a Valley v-twin on a twinstar...sound interesting.
This assembly from Buckeye should not be confused, and only barely compared with
Valley's Generac offering. The workmanship is superb, and the engine is NOT
modified. AND it gets alot more thrust.
Jeez....if only Dennis was still designing airplanes......(grin)
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
http://forums.matronics.com/viewtopic.php?p=177566#177566
> Submit your photo from past Monument Valley trips
Well, I don't exactly qualify, not having been there . . . Yet, but it looks like
an awe inspiring place and this is my favourite view of it.
Check out ; http://antwrp.gsfc.nasa.gov/apod/ap071225.html
David.
http://forums.matronics.com/viewtopic.php?p=177579#177579
Don, You hit the nail on the head.
steve
In a message dated 4/17/2008 11:36:58 P.M. Eastern Daylight Time,
are putting it together, to support slow turning 74 or 76 inch prop to
optimize the thrust, and make the components last along time.
Subject: | Re: Acme Gravity Catapult |
Greetings Henry !
Was just reading an article in the April issue of ' Kit Planes' which reminded
me of your post on Kolb List Aug ' 07, re operations out of your short sloped
strip on the slopes of Haleakala, Hawaii. Now you've probably got it ' pinned
down' by now but this article may be of interest to you anyway. It's a simple
DIY glide-slope guidance device that virtually anyone could build and might just
be worth your trouble to investigate.
It's actually based on the 'Inner Glideslope Indicator System' that the space shuttle
uses as it transitions from its (something like) 18 degree glide/plummet
after re-entry into the final approach phase profile, and that, in turn, was
based or developed from the system the navy uses for carrier landings, so the
system has quite some heritage. It just needs to be adapted to Kolb approach
profiles to work.
It's basically a ' ball and bar' arrangement where something like a round trash
can lid painted a bright colour is mounted on a pole to the side of the strip
just ahead of and adjacent to the touch down point and facing towards, and thus
visible from, the approach area. A little further back (about 24 ft mentioned
in this article) and mounted lower than the aforementioned trash can lid, another
really high tech device, like a piece of corrugated roofing iron, also
painted a bright but contrasting colour, is mounted horizontally and at a calculated
level somewhat lower than the trash can lid in such a way that when the
said trash can lid and the corrugated iron bar are in alignment as you are on
approach, then it equates to the desired approach gradient to the touch down
point and thus helps overcomes the false allusions of sloped terrain that is also
in your vision. If, on approach, the trash can lid appears above the corrugated
roofing iron then your ' too low' on profile and if it's below the roofing
iron your ' too high'. Fine tuning is done by simply moving the trash can lid
up or down the pole a little bit to suit your desired approach profile.
If you've got access to a copy of Kit Planes it might be worth the read anyway.
David.
http://forums.matronics.com/viewtopic.php?p=177586#177586
From: | "Arran Addington" <Arran.Addington(at)state.tn.us> |
Subject: | Aluminum Cleaning |
Hello Everyone,
I am finally getting around to working on the MkIII kit that I purchased this past
fall. It was bought in 1992 and partially assembled before it was put in a
trailer and sat for a number of years. Jim Kmet who is on the list and lives
near me in Tennessee came out and helped me verify that it was in rig, and that
there were no major issues.
I am at the point where I will soon be thinking about covering the wings and tail
feathers. My concern, and the question to the group is how to clean the aluminum
on these parts before I cover. They don't have any real corrosion, just
some light white in some parts, but mainly dust and dirt. I would really like
to make sure that once I cover them, I won't have to worry about them for a long
time (even though I am planning on installing inspection plates).
My thought is to use "Corrosion X" inside the big tail boom and wing spars, but
I really want to know how to clean up the external surfaces for the long term
without damaging them. I am interested in hearing the wisdom of the group. I
appreciate everyone's help.
Sincerely,
Arran J. Addington
Transportation Planner
Office of Local Programs
Suite 600, James K. Polk Building
505 Deaderick Street
Nashville, TN 37243-0341
voice: 615-253-8526
fax: 615-741-9673
Subject: | decarbon check advice |
I need some advice as to what it is I'm looking for on a decarbon
checkon a 503 DCDI. I've got the exhaust port open, and I see two very
clean looking piston skirts. The piston tops have a little carbon build
up on top, not much. The underside of the heads are very clean and
shiny. Regarding the rings, they lok clean to me, but I can't get them
to "move" very easily, more so because I'm afraid I'll break them than
anything else. I only see one ring, maybe about a 1/2" down from the
top. There is another possible ring right at the top, not sure. What is
the best way to check their movement, and what with?
Thanks -
Jimmy Young
FS II
Subject: | Firestar Project |
WE have a fairly new Kolb Owner in O'Brian Fl
Very High Time Navy Pilot ... First Kolb Flight was a real White Knuckle
Experiance for him !
Have Your Brother In Law Get Some Dual in a taildragger Ultralight FIRST !!!
How do I know this ... "Personal Experiance"
Dave
Need a new
ride? Check out the largest site for U.S. used car listings at AOL Autos.
I have been working with Larry at Valley Eng.on my direct drive Generac.
It will be installed in an ultrastar in a month or so.The belt reduction
version turns too big of a prop,DD is about 54". Hopefully the weight
will be the same as the Cuyuna with 5 more HP.Mark in Florida
Subject: | Re: decarbon check advice |
Jimmy Young wrote:
> I need some advice as to what it is I'm looking for on a decarbon checkon a
503 DCDI. I've got the exhaust port open, and I see two very clean looking piston
skirts. The piston tops have a little carbon build up on top, not much.
The underside of the heads are very clean and shiny. Regarding the rings, they
lok clean to me, but I can't get them to "move" very easily, more so because
I'm afraid I'll break them than anything else. I only see one ring, maybe about
a 1/2" down from the top. There is another possible ring right at the top,
not sure. What is the best way to check their movement, and what with?
> Thanks -
> Jimmy Young
> FS II
There are two rings, the lower one is a regular "square" compression ring and the
one at the top is a Dykes type ring.
To check for free movement, center the two rings in the exhaust port and then carefully
rotate the crank. You should see oil squeeze out of the ring gaps, and
the piston should move microscopically while the rings stay put.
Generally, the rings begin to stick at the gap, tho, which you can't see from the
exhaust port. That starts at about 100 to 150 hours usually, depending on how
often and how rich the motor is run....
LS
LS
FS II
http://forums.matronics.com/viewtopic.php?p=177679#177679
From: | "Bill Rayfield" <Bill_Rayfield(at)southwire.com> |
OOO, keep us posted - I'm interested in that setup!
The information contained in this communication is the property of Southwire Company
and intended only for the use of the addressee.
The information contained in this communication is the property of Southwire Company,
may contain confidential or proprietary information, and is intended only
for the use of the addressee. The unauthorized use, disclosure, forwarding,
or copying of this communication or any part thereof, is strictly prohibited
and may be unlawful. If you have received this communication in error, please
notify the sender immediately by return e-mail and destroy this communication
and all copies thereof, including all attachments.
Subject: | Re: Emergency Parachute |
If you want to know about how many BRS saves there have been, you should look here:
http://brsparachutes.com/files/Documents/Lives-Saved.pdf
If you want a chute on your plane, you should just spend the money and get the
proven, quality system BRS sells. If you try to get to cheap, you may end up
spending money and effort on something that wont work in many situations.
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=177696#177696
Subject: | Re: tail feathers |
I would not fly with a Rebent tang. I had seen and was going to post the same
AD that jeremy was talking about on the RANS airplanes, but he beat me to it.
The AD on the rans planes are for the same tangs our Kolbs use.
A Rans has two tail wires, you would probably live if one broke, but Rans has still
seen fit to send out an AD for this. A Kolb has one set of wires on the
tail, if one breaks you will die. I think all Kolbs should do the inspection
for cracks in the tangs as outlined in the AD from Rans.
Flying with rebent tangs is just asking to die, you might as well put a gun to
your head and pull the trigger. Its that serious.
have !!!
http://forums.matronics.com/viewtopic.php?p=177702#177702
> ="How tight are the support cables for the horizontal stabilizer supposed to
be? Mine seem a bit slack. The plan got flipped in a storm, so I may not be looking
at the right parts- I don't have another Kolb around to compare with.
> Bill Sullivan
> FS/KX/447
> Windsor Locks, Ct.
I know that if the tail wires aren't tight enough, the tang will wear through the
thimble prematurely. Once they reach the cable, you know what might happen.
I wouldn't fly a plane that had the tangs bent once then bent in another direction
or re-bent.
Ralph
Ralph B
Original Firestar
N91493 E-AB
21 years flying it
http://forums.matronics.com/viewtopic.php?p=177721#177721
>version turns too big of a prop,DD is about 54 . Hopefully the weight will
Mark, please DO keep us posted! I have the Cuyuna in my US and it's
running great, but improved fuel economy sure would be nice...
If it's 60 lbs and 35HP that'd be REALLY amazing!
-Dana
Just to make the AD very clear, they are saying to check the tangs for CRACKS,
not wear. I would check the bend itself for cracks while looking at the tang,
but the AD is saying to check around the bolt holes for cracks where there is
less material and the tang is being loaded in bend. If you tighten the tail
wires to tight, it can cause these cracks form as per this AD. You need to get
the wire tension tight, but not to tight either... To tight can be even more
dangerous than not tight enough due to cracks and sudden failure.
have !!!
http://forums.matronics.com/viewtopic.php?p=177734#177734
Dave put multi engines on a Kolb Firestar :) Great idea, but there was interaction
between the props that produced to much vibration.
have !!!
http://forums.matronics.com/viewtopic.php?p=177736#177736
http://forums.matronics.com//files/ultralightkolbdavetwinengine_169.jpg
>look here:
>the proven, quality system BRS sells. If you try to get to cheap, you
>may end up spending money and effort on something that wont work in many
>situations.
A BRS is like many things; you balance the cost vs risk vs reward. In my
own case, if I wouldn't fly without a BRS then I couldn't fly... a new BRS
costs significantly more than my airplane cost, thus a lower priced
alternative was an interesting option (that, this time, didn't pan out).
Now, I know that a hand thrown chute (the same kind I was looking at) save
John Hauck's ass twice and Dennis Souder's once, but two of those (they
admit) were deliberately abused aircraft (aerobatics) leading to structural
failure. Structural failure is EXTREMELY rare in a properly designed,
constructed, and maintained aircraft.
As for the list of BRS "saves"... I have no doubt that a BRS _has_ saved
lives, and for flight test of a new aircraft it _definitely_ makes sense,
but I'd credit about 25% of that list as being valid "saves". Component or
structural failure or midair collision, yes. Failure during aerobatics in
a plane not designed for same, that's pilot error. Ditto "loss of
control". Engine failure, 90% of the time (probably 99% of the time in
slow airplanes like we fly) you're better off flying it in under control
than popping a chute and surrendering yourself to the ride.
Some of the items on the list are really weird. "Fuel leaking"...
"installation of improper propeller"... and perhaps the strangest, "struck
obstacle on landing approach" at 25'... THAT's a BRS emergency???
For that matter, my own Ultrastar took a parachute ride. The original
owner had an engine out at 3000' directly over his home airport...
panicked, and deployed the chute (another one I wouldn't count). The plane
went into power lines, blacking out the local area, resulting in
ultralights being banned from that airport. Another guy bought and rebuilt
the wreck, whereupon it passed through two more owners before getting to me.
-Dana
Blow your mind, smoke gunpowder.
At 04:02 PM 4/18/2008, william sullivan wrote:
>Curiosity question- I know Homer Kolb experimented with various designs.
>There was even a reference to a multi-engine design. Did he ever
>experiment with a bi-plane version? The only plane mentioned today that is
>a lot different than today's production versions is the Ultrastar.
>Apparently there are a lot of them still flying. When did the Ultrastar go
>out of production? Does anyone know if Homer still has some radically
>different version on paper, tucked in a drawer, that never even hit
>prototype? I can't see a man like him letting his ingenuity retire.
Well, there was the Kolb Flyer (predecessor to the Ultrastar) which looked
like an US with two 14HP Solo engines mounted on a short crossbar where the
US engine is. I think there were a few even simpler aircraft
earlier. Later, there was the Kolb Laser, a conventional low wing tractor
airplane of which only a couple of examples were ever built. Never heard
of a Kolb biplane.
-Dana
Jim,
There is another ring about 1/16th from the top.I use a popcicle stick to push
in on the rings.To see a little oil squeeze out would be best,but free movement
is essential.There is considerable tension by the rings against the cyl walls,got
to push a little.How many hours on it,and is it oil injected?
----- Original Message ----
Sent: Friday, April 18, 2008 10:23:22 AM
Subject: Kolb-List: Re: decarbon check advice
> Thanks -
> Jimmy Young
> FS II
LS
LS
FS II
At 06:10 PM 4/18/2008, Mike Welch wrote:
>Awesome as the idea may be, to have a new twin-engined Kolb (especially a
>twin-engined Xtra), if I'm not mistaken, this could NOT be flown under
>Sport Pilot Rules.
> You would need a regular pilot's license, with a multi-engine
> endorsement...
The old twin engined Kolb Flyer was 103 legal, needing no license at all...
-Dana
Hard work has a future payoff. Laziness pays off now.
>very clean looking piston skirts. The piston tops have a little
>carbon build up on top, not much. The underside of the heads are
>very clean and shiny. Regarding the rings, they lok clean to me, but
>I can't get them to "move" very easily, more so because I'm afraid
>the top, not sure. What is the best way to check their movement, and what with?
> Thanks -
> Jimmy Young
Is it time to decarbon? I've got way over 700 hours without doing it,
but I run mine pretty regular. "What you should see is oil ooze in
the ring groove if you rock
the piston up an down with the prop".I would buy a compression tester
at you local auto parts dealer for
about $20 as an additional way to test weather your rings are sticking.
If you've got a starter, it works great. Mine still has 120 psi on
both cylinders, believe it
or not.
Also read this article.
http://www.800-airwolf.com/pdffiles/ARTICLES/part47.pdf
Subject: | expert in everything |
Ron;
I don't interact very often on the Kolb list, just read and chuckle.
Ron, It seems that you give a bunch of advice in areas that you have no
experience, or you fail to state your experience in certain subjects, i.e.
parachutes.
As to parachutes, what is your experience factor on this subject? Are you
getting a rebate from BRS so you promote their product?
There is more than one solution to a recovery parachutes than BRS.
There is nothing wrong with a hand deployed parachute. It eliminates the
malfunction of a mortar. If the individual
using that item rehearses how he is going to deploy it. That is the
paramount item in a hand deployed parachute. Same with a BRS or any other
recovery
parachute. How many on this list has every went through emergency procedures
of when and how they will deploy a parachute. I will bet you that most have
never considered rehearsing the procedure. Just take for granted that piece
of nylon will save their butt.
Hand deployed or mortar deployed, the individual has to know when to deploy
and how. It should be second nature to grab the deployment handle without
even looking. I also bet you if some of the folks on this list was sitting
in their airplane and you told them to deploy their recovery parachute, they
would have to sit there and think a few seconds of where the hell the handle
is, Seconds wasted is altitude. I think that a person should rehearse this
until it is second nature to them.
For a mortar actuated recovery parachute, the activating handle should be in
easy reach, in case G loads from a catastrophic failure should incur they
could overcome the G forces generated by the failure.
Hand deployed, is simple, it is either attached to your chest or in a very
close proximity to the pilot. On hand deployed I would suggest throwing the
deployment bag down and out from the airplane. This will keep it away from
most areas where it could get entangled. Also, you have more force in
strength throwing it down and away.( This method saved my brothers butt on
two occasions) Yes, I packed both of them.
Unlike silk prior to WWII which was sensitive to the environment and had to
be handled with kid gloves, thanks to DuPont that created a nylon fabric for
parachutes that is almost indestructible. Very few things will cause nylon
to go south, acid, direct sunlight. Age is really not a factor on a
parachute made of nylon that has been properly cared for. The biggest thing
I see with recovery parachutes is the bridle, if it is a synthetic material
exposed to the sun, that is always an iffy question of whether or not it
will hold the load on deployment. Ultra violet rays works on all man made
synthetic materials and it is undetectable by eye ball whether the item has
deteriorated or not. I would suggest using a wire cable.
Experience with parachutes, I have a wee bit. I jumped out of airplanes for
over 20 years, certified military parachute rigger,was involved with
development of several parachute systems and many other air item systems. I
have over 2000 parachute jumps ranging from 500 feet to 43,500 feet. ( that
is higher than most of you have ever flown commercial).
Don't get me wrong I am not blowing my horn, just hope that I can give a
hint to the folks on this list that a parachute whether hand deployed or
mortar, regardless of how it is deployed and used properly will save your
bacon. But, you have to be the one to be able to deploy it properly. That
comes from practicing how to properly deploy it.
Of course, Murphy may have something to say about!
Jim Hauck
The Older better looking Brother To John H
If I sent this under the wrong name, I apologize.
Jim Hauck
Subject: | Re: Re: decarbon check advice |
Lucien, Gary, & Possums-
My engine has 190 hrs., oil injected, & elect. start (someone asked). I
do have movement on the rings and oil flows when they are pressed, so
I'm calling it good. Thanks for the tips.
I'm going to a 2-stroke engine class early in May at S. Miss. Light
Aircraft, hopefully will learn most of what I'll need to know.
Jimmy Young
FS II, 503 DCDI
Houston
Subject: | Re: expert in everything |
Of course, Murphy may have something to say about!>>
Hi John,
have you seen the clip on Youtube of the chute deploying just as a
weightshift leaves the ground? Enough to make you wonder.
Chutes are almost non existant over here. I used to have one on my old
Thruster but didn`t continue when I swithched to the Challenger. I don`t
think I have ever seen one fitted in the UK. On the other hand I believe
that they are mandatory in Germany.
Cheers
Pat
If, on approach, the trash can lid appears above the corrugated roofing
iron then your ' too low' on profile a!pproach.
This reminded me of my `flight` in a 737 simulator.
I was supposed to be landing at very late evening in poor visibility at
Gatwick and there was an arrangement of three lights one above the other at
the left of the runway. These in combination indicated the glideslope. I was
doing reasonably well although the `flight` illusion was complete and I was
sweating like a bull as I thought of the consequences of a crashing an
airliner and killing all those passengers.
I had the lights all lined up and was on track for a spot on landing when I
glanced at the instruments and fouind that I was at 400 feet with 5 miles to
run (those are probably not the correct figures) To someone whose usual
landing technique is turn left at the elm tree, one notch of flap and close
the throttle that was mindblowing. I totally lost my nerve, yanked back the
control column and hit full throttle.
We landed in a nerve shattering crash on the end of the runway with the
whole sim shaking like a rat in a terriers jaws.
I was astonished to find later that in spite of landing the plane in a heap
I scored the best landing. Out of 8 participants I was the only one to hit
the runway at all.
When the hostess comes around your flight asking if anyone can fly a plane
because the crew are all dead from food poisoning, keep your mouth shut.
Cheers
Pat
> Hi John,
> Cheers
> Pat
My .02 on the chute,
The biggest con of the chute is what the original poster alluded to - actual deployment
and descent to the ground can't be actually practiced in the air.
The lifeblood of emergency procedures is actual practice of them in the air in
the airplane. Engine-outs, unusual attitudes and so forth; all of these we can
go up in the airplane and practice under actual conditions.
Emergency procedures that can't be practiced or even simulated to any degree aren't
worth very much - as we know in an actual emergency training takes priority
over thinking the situation through.
So I personally don't see a large value to fitting the ballistic chutes to our
planes, particularly to good designs like the ones we fly. There is a remote possibility
that the chute could save your life in a very extreme circumstance,
but because of the very small likelihood of encountering such a situation, I
personally don't think it's worth 3000 bucks.
3000 bucks will buy lots of maintenance items, as well as gas for practicing flying
the plane in more "simulatable" emergency scenarios like engine-outs and
such.
Again, JMHO,
LS
LS
FS II
http://forums.matronics.com/viewtopic.php?p=177854#177854
From: | TheWanderingWench <thewanderingwench(at)yahoo.com> |
Subject: | Re: Kolb-list 2008 MV Photo Contest |
> share it with Arty.
> Jon L
WOW! I almost hope Jon wins the first prize. BUT -
if the judges aren't prejudiced because this shot is
of my Drifter :>) at the 2006 disorganized MV fly-in,
then I'll have to share the prize money with Doug
Nelsen, who took this photo.
Wish I was going to be there this year, but I won't.
I'll have to depend on the Cottrells, John Williamson
& John Hauck to bring lots of good photos back to the
Rock House.
Arty Trost
Maxair Drifter
Sandy, Oregon
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
Subject: | Re: Firestar Project |
Dave , I dont know if we have met but I am an experienced Kolb pilot who also lives
in O'Brien Fl. for about 3months a year . 22004 117Th drive ,and I am building
a new Firefly in my New Quonset hut Hanger . Good advice you gave that guy
but if he cant find a two place ultralight to get time in I recommend he get
some time in a Switzer 233 a glider really teaches what Flight is all about
. Chris
From: "BMWBikeCrz(at)aol.com" <BMWBikeCrz(at)aol.com>
Sent: Friday, April 18, 2008 9:35:37 AM
Subject: Kolb-List: Firestar Project
Very High Time Navy Pilot ... First Kolb Flight was a real White Knuckle Experiance
for him !
Dave
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Nice thought, certianly something to think about as you watch the houses on
the ground get bigger. But seriously, you are forgetting the rest of the
formula. I fly sans windshield. If I take a bird in the face the plane may be
perfectly functional but I might be flying blind. No way to land that sucker.
There are other situations when a chute would help of which an engine out is
not on my list. There was an excrllent article a few years ago in Sport
Pilot.
Steve
FF #007/floats
FF #040/floats SnF 2008 UL Grand Champ
In a message dated 4/19/2008 12:52:04 P.M. Eastern Standard Time,
lstavenhagen(at)hotmail.com writes:
our planes, particularly to good designs like the ones we fly. There is a
remote possibility that the chute could save your life in a very extreme
circumstance, but because of the very small likelihood of encountering such a
situation, I personally don't think it's worth 3000 bucks.
flying the plane in more "simulatable" emergency scenarios like engine-outs
and such.
Again, JMHO,
LS
If twin engines pose a classification problem, how about a single engine driving
two props ?
David.
http://forums.matronics.com/viewtopic.php?p=177875#177875
http://forums.matronics.com//files/april07_026a_165.jpg
> actual deployment and descent to the ground can't be actually practiced in
> the air.
> air in the airplane. Engine-outs, unusual attitudes and so forth; all of
> these we can go up in the airplane and practice under actual conditions.
> degree aren't worth very much - as we know in an actual emergency training
> takes priority over thinking the situation through.
> such a situation, I personally don't think it's worth 3000 bucks.
> practicing flying the plane in more "simulatable" emergency scenarios like
> engine-outs and such.
> Again, JMHO,
> LS
Lucien:
Anyone that can fly a Kolb can land it in an emergency situation without
power. Of course, parachutes are not for that type emergency.
My first save was a catastrophic failure of the upper aileron bell crank in
my US, October 1985. Before the use of my parachute for the first time, my
attitude was much the same as yours. I can handle the situation, plus this
is a factory welded kit and it has never happened before. Guess I was a
little wrong in that respect, but right in having another way to save my
life. Kolbs do not fly long without aileron control.
Second catastrophic failure was even more of a surprise than the first.
Failure of leading edges of both wings on my FS 4.5 years later. Sure, I
flew aerobatics in the FS, as well as the US. However, all within the
authorized stress envelope of the aircraft. The wing was the last thing we
ever thought would fail. Without the same old Handbury parachute, my flying
career would have been permanently ended March 1990.
We don't need to actually practice parachute deployment in the air to
receive valuable familiarization and training. It can be done in the
cockpit of the airplane. Know how to grab and pull the handle with your
eyes closed without thinking about it. When the time comes to use it, do
not hesitate. Time is altitude. Altitude is safety. No matter what
altitude, use it if you are no longer in control of the aircraft.
To think there is not a catastrophic failure in the future of your Kolb or
any other aircraft is pretty naive.
Even though the odds of ever using a parachute in a catastrophic event are
pretty damn slim, when the time comes to use one and you felt it was too
expensive to purchase, and you don't have one, will probably really piss you
off. Don't worry about screaming all the way to the ground, you'll be so
damn scared no sounds will be emitted. If you are like me, you are
thinking, "I don't believe this is happening to me." and "Damn, I don't
believe this is happening to me again."
I have hauled an expensive piece of equipment with me for nearly 3,000
hours, and have not needed it.
If that 10 cent 3/16 bolt on the bottom flying wires breaks, or the nut
comes off, I have a way to offset the problem.
Take care,
PS: No matter how reliable your aircraft, a midair will ruin your day, with
or without a parachute. Could possibly save your life though.
The tail wires have a single function and purpose. They hold the vertical and horizontal
stabilizers in constant relative position, so that don't flap like bird
wings. The wires should be tight enough to perform this function without any
wobble and no tighter, for reasons already expressed by others.
Thom Riddle
N221FA Allegro 2000 912UL
N197BG FS1/447
Believe nothing, no matter where you read it or who has said it, not even if I
have said it, unless it agrees with your own reason and your own common sense.
- Buddha
http://forums.matronics.com/viewtopic.php?p=177876#177876
A good alternative to mortar powered chutes are the ones made and sold by these
folks in BC, Canada.
http://www.ultralight.ca/recovery/default1.htm
They have a lot of good accessory products and at one time also made the GSC System
wooden props. I understand they sold the prop business to one of their ex-employees
who now runs it. I had their mechanically actuated in-flight adjustable
prop on my Tornado. Very good prop in my experience.
Thom Riddle
N197BG FS1/447
- Buddha
http://forums.matronics.com/viewtopic.php?p=177879#177879
Lucien, I disagree with your statement "Emergency
to any degree aren't worth very much." (In relation
to the value of a parachute.)
A friend of mine had structural failure on his Tierra
ultralight when flying @ 1500' AGL and pulled the
handle of his BRS chute. He had never "practiced" -
but he had no trouble in getting the parachute to
launch. Came down on the tail with no injury to
himself - just scared to death. It made me a believer
in emergency chutes. Just another form of insurance,
which I hope I'll never have to use.
Since I'm pretty small - I have only 15 lbs. over the
much-written about 90 lb. weakling! - I've often
wondered if I'd have the strength to pull the handle
and launch the chute on my Drifter. But it's way too
expensive for me to try it out, and friends have
assured me that the adrenalin rush will give me the
strength of 10 when it comes to pulling that handle!
Arty Trost
Maxair Drifter
Sandy, Oregon
> poster alluded to -
> > the air.
> through.
> worth 3000 bucks.
> well as gas for
> > Again, JMHO,
> > LS
> Lucien:
> emergency.
> control.
> can be done in the
> No matter what
> the aircraft.
> you felt it was too
> like me, you are
> and "Damn, I don't
> me for nearly 3,000
> breaks, or the nut
> Take care,
> john h
> mkIII
> life though.
> browse
> Un/Subscription,
> FAQ,
> Forums!
> Admin.
Helen Keller
Lucien,
You beliefs about parachutes and emergencies are very misguided. Emergency procedure
like engine out landings are complicated with a lot of variables and must
be practiced to be done correctly. Stall / Spin recovery also requires skill
and technique that should be practiced.
Pulling a handle on a chute is not something that needs to be practiced to be done
successfully. Pull the handle and it comes out, not a lot of skill involved.
The chute is going to deploy by itself once the handle is pulled, the technique
I use to pull pull that handle, how hard or how fast I am going to pull
the handle is not going to change a damn thing, the chute come out the same...
BRS Chutes have been a huge success in Cirrus aircraft. There are also over 200
saves listed on:
http://www.brsparachutes.com/files/Documents/Lives-Saved.pdf
If someone is unable to grasp the concept of pulling a big red handle just because
there is no way to practice it, they should probably not be flying.
have !!!
http://forums.matronics.com/viewtopic.php?p=177925#177925
two props ?
> David.
There is always someone out there that will try something very stupid, and driving
2 props with a single engine is definitely one of them. It just adds complication,
and increases chances of failures, while offering no safety advantage.
The whole idea of twin engines is to be able to fly the plane if one engine quits,
even if the second engine results in an extended glide, you have something...
With a single engine and two props, you have every disadvantage of complication,
and asymmetrical thrust and with no advantage of two engines.
have !!!
http://forums.matronics.com/viewtopic.php?p=177928#177928
Subject: | MV Photo Contest |
I was rummaging through my files and found this one of MV. Do not know what
year, but it was taken from my MKIII by me.
johnh
JetPilot wrote:
> Lucien,
> Mike
Heh... I usually get hate mail when I mention my viewpoint on the chutes, this
time followed suit nicely....
As for the ongoing discussion of the chute, I'm going to stop at this point to
avoid the inevitable jousting that will surely break out. Instead, I'll refer
anyone interested to the yahoo groups, such as Fly-UL, where there have been very
extensive threads on the pros and cons of the ballistic chutes. Most of them
eventually got out of hand and the end, but still contain lots of valuable
reasoning on both sides.
LS
LS
FS II
http://forums.matronics.com/viewtopic.php?p=177940#177940
Subject: | Re: Aluminum Cleaning |
I'm a newbie/lurker here, but just be sure NOT to use Simple Green. It eats aluminum.
I'm in the Army and we have had problems where guys have uses Simple Green
to clean their weapons, and then have it corrode the aluminum bottom receiver.
FWIW
"The LORD is a warrior; the LORD is his name." Exodus 15:3
http://forums.matronics.com/viewtopic.php?p=177946#177946
>over 200 saves listed on:
I don't dispute that BRS's have saved lives, but about 3/4 of the "saves"
on that list are NOT situations where a chute should have been
used. "Engine failure" (except in very rare situations) is not a reason to
use a chute, and there is NO excuse for "loss of control". As for the
Cirrus, the chute is standard equipment because the aircraft has no
demonstrated spin recovery (the "book" spin recovery is "pull the
chute"). The Cirrus is a fairly hot ship; lots of fairly low time pilots
with too much money buy one, get into trouble, panic, and pop the chute.
As for practicing, PG and HG pilots regularly do it. The pilot sits in his
harness suspended from something overhead, and practices reaching for the
chute and throwing it while an instructor swings and spins him around to
disorient him. If it's a "reserve repack" clinic, the pilot actually
throws the chute, then the riggers repack them at the end of the day.
Still... that rocketless Canadian one looks interesting. I've emailed
asking for more info and pricing.
-Dana
"Makers of oils will assure you their lubricants will last the life of
the transmission. This may be true, but that life can be longer if you
change the oil.
>driving 2 props with a single engine is definitely one of them. It just
>adds complication, and increases chances of failures, while offering no
>safety advantage...
It's not stupid at all. Well, it would be if you were doing it for safety
reasons but that's not the point. You _don't_ do it for safety reasons;
you do it due to space constraints, where you don't have room for a single
propeller large enough to be efficient. That's why the Wrights did it;
with limited HP they turned two absurdly large slow turning props, which is
what got them such good efficiency. I can see it being a good idea on a
plane like the UltraStar, where prop ground clearance limits the kinds of
fields you can operate from.
Of course it would totally screw up the wing folding...
-Dana
change the oil.
Well maybe Mike, but this is NOT one of them. It is neither 'stupid' nor 'very
stupid' (Nb. Your adjectives seem always to be way too strong). What it is, is
the result of entrepreneurial spirit and technical expertise complete with the
funds to follow up on it.
This application was flown on a proof of concept aircraft, the German FK11 (see
attached photo), and while it did not go into production, this was because of
other commitments stifling the project and not because of failure of the concept.
It worked ! The idea was to get the props working in the cleanest air possible
in a pusher application rather than directly behind the fuselage/wing area
with all the conflicting air-flows there that negatively affecting performance
and increasing noise levels.
Wrong, some applications require two props to absorb the power, eg; the Russian
Tupolev Tu-95 'Bear' one of the fastest subsonic aircraft flying today. but on
the application I showed, it was for efficiency reasons, not power absorption.
The reason for this layout I described above. A good reason !
Granted, this is one of the benefits of twin engine flying, even if, as you say,
the second, or remaining engine only "takes you to the scene of the accident"
[Wink]
Well, that assumes engine failure being the one and only problem. What if a drive
belt fails, it's happened right ? In this case the other prop will still be
receiving power giving you further options that a single prop plane would not
have. That seems like an advantage to me. You might well have to improve rudder
authority in such a case, eg. Larger vertical stab or (dare I say) VG's, but
if that's so, I don't see it as a disadvantage.
As to application to a Kolb, it might be possible. Someone had gone to the trouble
to install twin engines but had consequential problems. This just might work.
Someones curiosity might be satisfied by trying it. Who knows, that's all
I posted it for.
Safe flying
David.
http://forums.matronics.com/viewtopic.php?p=177972#177972
http://forums.matronics.com//files/fk_11_photo_1_194.jpg
this message is from Bob, transcribed by his daughter, Susan
"I am presently in Univ of Virginia hospital. Cannot walk or use legs.
To all that had an interest in the Firefly- I can't send more info or
pictures at this time.
When I get home I'll try to answer questions and requests for
pictures. I appreciate
your patience.
Bob"
Bob!
Sure hope you're out of the hospital soon (front door!)
The medics have made enough money; you don't need to support them
any more
Hang in thar, pard
Russ
> or pictures at this time.
> your patience.
> Bob"
Bob , I'm not much of a praying man but in your case I will say you are in my prayers
. Chris
Sent: Sunday, April 20, 2008 5:59:20 PM
Subject: Kolb-List: Bob N
your patience.
Bob"
Subject: | Re: MV Photo Contest |
> Can you land on one of the Bigger ones ?
> Mike & "Jaz" in MN
Mike:
At one time, there was a dirt strip on top of one of the larger mesas. You
can still see the old remains of it.
Would be possible to land on top of many of them, but should you have a
problem, would not be a nice place to be.
Thanks for declaring me the MV 2008 Photo Contest Winner. Please send check
for $10,000.00 to hauck's holler, alabama. Put my name on it. Post Master
at Titus Post Office knows where I live.
Here is a good web site and photos with captions of this gentleman's flights
across the US in a 1939 Cub.
This is very much Kolb related. This is the view John W and I have when we
strike out to get from here to there.
Some of the airports and people in the photos are folks and airports I have
visited with during my travels in the Kolb MKIII.
http://www.vintageflying.com/
Subject: | soloed a Kolbra today |
This was another one of those memorable days when a guy makes a significant event
happen in life. I got to solo my new Kolbra today after some good coaching
from Mark German, the builder/previous owner. Mark decided to sell it and with
my years of Firestar experience, I soloed after less than an hour of transition
training. Before buying, Mark told me that it's a "Firestar on steroids". Well,
he was right. It's still a slow enough airplane for me to handle, yet get
me someplace that would take forever in a 447 powered Firestar, with the reliability
of the 912 engine. What a great day here in Minnesota. It got up to 74
degrees. Yippeee!
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
21 years flying it
Kolbra 912UL
N20386
0 years flying it
http://forums.matronics.com/viewtopic.php?p=178063#178063
Subject: | Re: soloed a Kolbra today |
> This was another one of those memorable days >
> Ralph
> Ralph B
Ralph B:
I'll have to agree with you. I flew your airplane several years ago. Flies
like a big ole baby.
Now you won't have any excuse for not flying out to MV, down to the Kolb
Homecoming, Homer's Father's Day Flyin, John Bickham's Nauga Field Flyin at
Star Hill, LA. We'll be looking for you.
Take care,
PS: What is Mark building to replace the Kolbra?
From: | william sullivan <williamtsullivan(at)att.net> |
Subject: | Kolb List: Bob N. |
Hang in there, Bob. We're all pulling for you.
Bill Sullivan
> Homecoming, Homer's Father's Day Flyin, John Bickham's Nauga Field Flyin at Star
> Take care,
> john h
> mkIII
Well John, I'm not quite retired yet, so I may have to wait a bit. Mark is building
a 912S RANS S7.
Ralph
Ralph B
N91493 E-AB
21 years flying it
Kolbra 912UL
N20386
0 years flying it
http://forums.matronics.com/viewtopic.php?p=178071#178071
Subject: | Re: Monument Valley 2008 Photo Contest |
From: | "John Williamson" <kolbrapilot1(at)tx.rr.com> |
Rules will be strictly adhered to in order for a winner to declared.
See the first post in this thread.
Photos have to be posted in this thread as a replay.
Photos have to be taken by the submitter.
If you submit more than one photo, the blind judge will through out the extra photos
he can't see.
John Williamson
Arlington, TX
Kolbra, 912ULS, 1580 hours
http://home.tx.rr.com/kolbrapilot
http://forums.matronics.com/viewtopic.php?p=178088#178088
http://forums.matronics.com//files/wj2_100_2061_125.jpg
Hi all Jim here
I'm thinking of selling my Ultra Star. Any suggestions or comments?
Jim VanGarsse
**************Need a new ride? Check out the largest site for U.S. used car
extra photos he can't see.
> John Williamson
John W:
Here are a few more photos from MV.
I have included one of the Judge, himself, flying his beautiful, sleek,
nimble and powerful Kolbra over the skies of Utah during one of our many
flights to that area of the country, hoping it may sway his decision for
best photo.
However, since the Judge has also contributed a photo, doubt any of us have
a chance at winning.
http://home.elmore.rr.com/jhauck/MV/
John H and All,
To keep the Contest as open as possible, I have hired the best Judges that a small
amount of money can buy. Oops, I mean hire.
Although the unveiled and blatant attempt to gain favor by submitting such a beautiful
photo is appreciated, my hired Judges were not swayed one way or the other.
The bar has been set very high for this Contest folks, so post your best and good
luck.
(I had to use the dictionary for some of those words)
John Williamson
Arlington, TX
Kolbra, 912ULS, 1595 hours
http://forums.matronics.com/viewtopic.php?p=178129#178129
http://forums.matronics.com//files/wj3_100_2062_398.jpg
Subject: | Flew my Kolb Mark II Twinstar for the 1st time this morning! |
From: | "cristalclear13" <cristalclearwaters(at)juno.com> |
WOOOOOOOOOOOOOO
HOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!
What a blast!!!!!!!!!!!!
I got back from Tennessee last night. Went up to visit Jim Kmet and get an endorsement
(Thank you so much Jim!!! You're a GREAT instructor!!). I couldn't
wait to get up this morning and fly "Merry Dawn". Only got to fly for 15 minutes
and do one take-off and landing though because I had to go to work! :(
I CAN'T WAIT to go again. WOW!!!! :D
Cristal
Mark II Twinstar
http://forums.matronics.com/viewtopic.php?p=178148#178148
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Subject: Kolb-List: Re: Monument Valley 2008 Photo Contest
Since the earlier photo that was submitted from this address was for Karen,
I am still able to enter. My submission is below. Taken in 2004 from a
Firestar II.
Larry C
That dual prop setup on a small gas engine is nothing short of stupid, overly complicated,
prone to failure, and dangerous. The setup pictured does NOT compare
to a large turboprop or hugely powerful engine where counter - rotating propellers
would be beneficial, not even in the same league.
A setup similar to this was used on the wright flyer, but we have learned a lot
since then, I would question anyones intelligence that would suggest that something
is a good idea just because the wrights used it, that just shows poor judgment.
The fact that the single engine into a dual prop setup in the picture has never
been used in any significant numbers should clue you in to the fact that it is
not practical or even a good idea. Its not rocket science, there is no excuse
for anyone involved in building and flying airplanes to not be able to figure
this one out.
have !!!
http://forums.matronics.com/viewtopic.php?p=178169#178169
>overly complicated, prone to failure, and dangerous. The setup pictured
>does NOT compare to a large turboprop or hugely powerful engine where
>counter - rotating propellers would be beneficial...
But those _weren't_ counterrotating as far as I can tell (though they were
on the Wright Flyer). Furthermore, except for having two props, belts,
bearings, etc. (none of which are particularly prone to failure compared to
the engine itself) it's no more complicated than a single propeller belt
redrive.
>a lot since then, I would question anyones intelligence that would suggest
>that something is a good idea just because the wrights used it, that just
I didn't hear anybody say it "was a good idea just _because_ the Wrights
used it". I simply pointed out one of the reasons why the Wrights used it
(maximizing propeller disk area in the space available), which could still
make sense today.
>never been used in any significant numbers should clue you in to the fact
>that it is not practical or even a good idea.
Now, that's just a dumb statement, which could be applied to ANY idea
that's not yet widespread. If we all believed that there would be no new
ideas. It may well be true (almost certainly IS true) that dual props from
a single engine doesn't make sense most of the time, but that doesn't mean
that it NEVER makes sense.
-Dana
Never vote for a politician who has to borrow a gun to go duck hunting
David Lucas,
Do you know the diameters of the two three bladed props used and the power of the
engine in the picture you posted? This would be more efficient if longer two
bladed props were used to increase disk area. To do that, this mount would
have to place the props behind the ailerons on a Kolb.
Also, it looks like the props are turning the same direction, but the belt tensioners
are on the same side of the frame. If this is so, one belt is being tensioned
on the loaded side. This is not generally a good idea.
As configured in the photo, I doubt that this set up would be any more efficient
on a Kolb than one larger diameter prop.
Compare the disk area of a 66" prop (13,685 sq.in.) to that of two 50" props (15,707
sq.in. total) and you can see that not much is gained. The added weight,
increased complexity and decreased efficiency of two smaller props v.s. one
large one will likely outweigh any improvements from better airflow or the slight
increase in disk area.
In short, I think this is a bad idea and I haven't used the word stupid anywhere.
I do have to admit it looks very cool though.
Roger in Oregon
1992 KXP 503 - N1782C
http://forums.matronics.com/viewtopic.php?p=178189#178189
anywhere. I do have to admit it looks very cool though.
> Roger in Oregon
Hi Gang:
Brother Jim and I have had a lot of ideas over the years. Many were never
carried through based on lack of time and money.
One of Jim's better ideas was to build a pusher with twin tailbooms with
enough space inbetween to swing a nice size prop. This concept could be
single of twin engine. Would bring the thrust line down behind the center
of mass where it belongs.
I have oftened wondered what a rocket ship a Kolb would be with a thrust
line in the center of mass. Closest Homer ever came was the US. It
performed more like a tractor than the high thrust line pusher that eats up
a lot of the profits before they can be spent on thrust.
Roger. No, sorry, I haven't the spec's on the prop size, you'll just have to
make an educated guess based on other items in the photo that may be familiar.
The engine, however, is the 80 HP 3 cylinder, turbocharged, injected, FADEC
controlled, liquid cooled engine that was developed for the 'Smart Car' by Mercedes
Benz. The engine is a great little unit, but Smart have recently swapped
to a Japanese engine for overseas sales due to the strength of the Euro. Pity,
it had great potential for aero conversions. It met or exceeded most Rotax
912 performance figures so I'm told, especially economy and with auto gas at around
US$ 9.00 / gallon over here thats quite an important factor. Yes US$ 9.00
per Gallon !
Mike, A lot of earlier, not so successful, ideas are having a second life due
to advances in technology. The Kevlar beams holding the prop mounts being an
excellent example. Years ago the only option would have been something like a
steel/metal frame which would have been too heavy.
Jules Verne (Feb 8, 1828 Mar 24, 1905) wrote about space, air, and underwater
travel before navigable aircraft and practical submarines were invented, and before
any means of space travel had been devised. Now a significant number of
his ideas are just 'status quo'. All it took was increased technology. Got to
keep an open mind about these things and be willing to have a second look instead
of just slamming the door shut.
David.
http://forums.matronics.com/viewtopic.php?p=178201#178201
Y'all;
I personally think that a new subject line should be used instead of
Homers name with this trivial crap that is being spouted about dual
props, etc.
Don't be surprised if you see a new dual engine legal ultralight emerge
in the near future. Less that 250 lbs. There is one in the works.
Jim Hauck
Y'all;
That will be a dual motored ultralight, not dual engine.
Jim Hauck
Mike Bigelow is frequently short of tackfulness. So, in order to help tell his
story, GEICO has asked me to help .......
Dual propellers seem like a good idea at first, but their true value hasn't yet
been discovered. That's a nice shirt you are wearing.
History has progressed since the earlier examples of this idea. A wise aviator
would want to adhere to sound engineering principles, and approach this method
prudently.
this one out.
Although excellent working examples of this design may be rare, one wouldn want
to be cautious before further recommending using this product, without proper
research. Care for some tea and cookies?
Mike Bigelow
Sounds works to brag about. They give off an air of excitement!
Mike Welch
I am glad I could help.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Subject: | sound design principles |
My previous email was truncated and messed up. Not by me. But, you get the idea.
Mike Welch
How about this one.
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
Drifter taking aim at..... ME!!!
Rick Neilsen
Redrive VW Powered MKIIIC
I love this one, the dial up guys might not.
From: by0ung(at)brigham.netTo: kolb-list(at)matronics.comSubject: RE: Kolb-List:
Re: Monument Valley 2008 Photo ContestDate: Mon, 21 Apr 2008 14:03:45 -0600
How about this one.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Subject: | Re: expert in everything |
At 04:13 PM 4/21/2008, jb92563 wrote:
>Last time I checked with them a couple years ago, it was a couple hundred
>or 3 less than a BRS....not much difference to make it worthwhile over a BRS.
I guess not much has changed:
>RPS 525 is $ 2450 plus shipping
>It weighs 16 lbs
>Repacking interval is every 5 years and it can be done by a rigger, does
>not necessarily have to come back to us.
>Delivery is 4 - 6 weeks from confirmed order date. All orders are
>confirmed by a deposit of $ 1000 before we will proceed with the order.
Yikes, that's only $50 less than I paid for my plane... including
trailer! 'Fraid the budget doesn't run to it right now...
-Dana
In general, liberalism consists of A & B getting together to see what
they can make C do for poor old D.
At 01:46 PM 4/21/2008, R. Hankins wrote:
>Also, it looks like the props are turning the same direction, but the belt
>tensioners are on the same side of the frame. If this is so, one belt is
>being tensioned on the loaded side. This is not generally a good idea.
I noticed that as well. Actually, it looks like there are backside idlers
on BOTH sides of the belts, presumably to move the belts closer together
behind the frame. Still not a good idea (to have a backside idler on the
tension side).
>In short, I think this is a bad idea and I haven't used the word stupid
>anywhere. I do have to admit it looks very cool though.
You may well be right (that it is a bad idea in this application). That
doesn't mean it would _always_ be a bad idea.
-Dana
Growing old is inevitable, but we can stay immature indefinitely.
Subject: | Re: Flew my Kolb Mark II Twinstar for the 1st time this morning! |
From: | "cristalclear13" <cristalclearwaters(at)juno.com> |
You would have heard that WOO HOO from the FBO twice...once when I landed and again
when I got out of the plane. I was not only excited...I was THRILLED! That
thing jumped off the ground like a grasshopper and climbed like there was
no tomorrow.
When I got out to the hanger this morning and got her ready to fly, I was so nervous.
The plane HAS flown before, but not after we did so much to get her ready
for the airworthiness inspection, and not with me as PIC (student pilot still
and having only solo'd a Cessna 150). So I primed her, pulled the choke and
cranked her up...she died after I put the choke in (seems to happen when I
haven't cranked her in a while and when it's a little cold). So I tried to crank
her again and she wouldn't start. Then I tried to crank her again and my
battery must have gotten low by then. So there I sat thinking I wasn't going
to fly it today. And this morning looked to be the only good time to fly this
week (no winds). So I sat in her and chair flied for a bit and then decided
to try to crank her again (with a little prayer) and she cranked right up and
ran beautifully. So I WAS going to get to fly her today AFTER ALL! :D I taxied
out to the runway, got a dragonfly passenger along the way. Here's the
look on the dragonfly's face at 2500ft --> [Shocked]
I'm using a handheld radio and I was about 2000 ft up and I heard someone but I
mostly heard
static. I hear things fine on the ground at the airport. Do I need an extension
for the antenna maybe?
Cristal
Mark II Twinstar
http://forums.matronics.com/viewtopic.php?p=178264#178264
re: spring launched vs rocket launched recovery chutes
Saving $300 is worth... $300. Another payoff is that you don't have to pay HAZMAT
fees when shipping. A high quality spring launch is pretty much murphy proof.
I'm not selling them and have never owned one but if it every comes time for me
to replace my BRS, it will be with the spring-launched one.
Thom Riddle
N221FA Allegro 2000 912UL
N197BG FS1/447
Believe nothing, no matter where you read it or who has said it, not even if I
have said it, unless it agrees with your own reason and your own common sense.
- Buddha
April 15, 2008 - April 21, 2008
Kolb-Archive.digest.vol-hk
