Kolb-Archive.digest.vol-hw
December 08, 2008 - December 19, 2008
Subject: | Re: VG affect on stall |
To insure that the tips keep flying while the root stalls is why I only used VG's
from the wing tips to the inboard end of the flaps. That leaves a good bit
of mid wing to stall first.
I no longer have the drawing, but perhaps brother Cottrell or Beauford has a
copy to send you.
Before I learned a little about my computer, I snail-mailed about 50
drawings. Later, emailed about 200. It got to be too much.
Now, an outfit called _www.landshorter.com_ (http://www.landshorter.com)
has a nice setup for about $100 [so I'm told].
VG's give you the most bang for the buck I can imagine. Worth a C note & a
couple hours.
Howard Shackleford
FS II
SC
In a message dated 12/8/2008 8:08:15 A.M. Eastern Standard Time,
grant_richardson25(at)yahoo.com writes:
Howard,
Do you have a drawing for your Vgs?
**************Make your life easier with all your friends, email, and
favorite sites in one place. Try it now.
Subject: | Re: What is your Altitude loss in a 180 degree turn? |
From: | "grantr" <grant_richardson25(at)yahoo.com> |
That almost seems impossible. How did you only loss 100 feet in a 180o turn?
What I read suggest making a 45o turn at best glide speed to lose the least altitude
in a 180o turn.
http://forums.matronics.com/viewtopic.php?p=218285#218285
least altitude in a 180o turn.
Grant:
You are saying, "45 degree turn" and I think you mean "45 degree bank".
There are a whole lot of varibles when it comes to gliding turns and
altitude loss. The faster you are flying when you begin the glide has a lot
to do with how much altitude will be lost. Also, how aggressive you turn
will make a big difference. A Kolb will turn on its wing tip, or so it
seems when you really honk it around using a lot of up elevator in a steep
bank.
I haven't flown in almost three months. Next time I fly, probably tomorrow,
if I can get the 912 cranked and knock off most of the dust, bug crap, ect,
I'll see what my altitude loss is in a 180 degree turn with a dead stick.
Dead stick will produce less altitude loss than an idling prop.
Good flying weather at hauck's holler, alabama, this afternoon, but I don't
know about tomorrow.
Take care,
At 02:21 PM 12/8/2008, apilot(at)surewest.net wrote:
>You may be able to reduce the altitude loss with practice. My guess is
>that your plane can make a successful 180 degree turn without losing over
>100 feet of altitude. My best in a Cessna 150 was 100 feet and the best
>in a PA-11 Cub was 50 feet. Practicing the technique is a worthwhile effort.
100' and 50' seems awfully low, unless you have a good bit of energy
(speed) at the start... from what starting condition? There's also
reaction time. I figure 250' in my Ultrastar, sudden power loss from a
normal (i.e. low airspeed) climb... I use 300' to be safe.
-Dana
We have enough youth; how about a Fountain of Smart?
My guess is a hastily begun step angle turn would yield the best
results. Less exposure time to drag.
Sure easy to prove but I'm not going to do it today.
BB
> 180o turn?
> the least altitude in a 180o turn.
steep angle (bank)
> BB
>> 180o turn?
>>guess is that your plane can make a successful 180 degree turn
>>without losing over 100 feet of altitude. My best in a Cessna 150
>>was 100 feet and the best in a PA-11 Cub was 50 feet. Practicing
>from a normal (i.e. low airspeed) climb... I use 300' to be safe.
>-Dana
I can do a full turn in a spin and lose less than 300 ft.
See:
http://video.google.com/videoplay?docid=897400447222498104&hl=en
Not a recommended maneuver after and engine failure on takeoff though... :)
-Dana
Hard work has a future payoff. Laziness pays off now.
John,
Yes I meant 45o bank not turn. [Wink] Please do let us know how much you loss
in an engine out 180. I don't have the nerve to kill a perfectly good running
engine yet.
My test was for the purpose of determining how high i would need to be to turn
back to the runway if I had an engine failure on take off.
The 300 feet lost was from entering the turn to exiting wings level. I know it
will take a little more during a turn back due to the fact a 180 will not have
the plane aligned with the runway.
http://forums.matronics.com/viewtopic.php?p=218359#218359
Subject: | Re: El Paso, Texas |
[quote="pj.ladd(at)btinternet.com"]You are both still ugly....
> and that there ain't a Kolb..>>
True!
But we're happy! :D
Skeeter
Dave Rains
N8086T
http://forums.matronics.com/viewtopic.php?p=218363#218363
> I don't have the nerve to kill a perfectly good running engine yet.
> turn back to the runway if I had an engine failure on take off.
> know it will take a little more during a turn back due to the fact a 180
> will not have the plane aligned with the runway.
Grant:
Turning back to the runway kills lot of good folks. This maneuver
introduces a lot more ways to hurt your airplane and yourself.
My first engine out, in a fixed wing, was my Ultrastar. I was so dead set
on getting back to where I had come from, I mushed the little Ultrastar in,
experiencing a very hard landing. Engine quit dead about 100 feet on
takeoff. In my effort to get turned around, I did not see the several
thousand feet of taxiway almost directly in front of me.
Hard maneuvering with a dead engine during an emergency situation makes it
so easy to try to turn harder than the plane will fly, and try to stretch
the glide by slowing down airspeed. All the previous are inviting a stall,
spin accident.
I think I will shoot straight ahead, deviating left or right to make the
best landing I can. My primary purpose is to survive with as little damage
to me as possible. The airplane can be repaired or replaced if necessary.
Flying off a "real" airport, always us all of the runway, whether 3,000 feet
or 6,000 feet. At the rate our Kolbs climb, and the speed they climb, there
is generally always room to land if you experience an engine out on takeoff.
From: | "beauford T" <beauford173(at)verizon.net> |
...Brother Davis...
Yessir, the Kleenex Kolb is a FireFly... True, the wing is a tad
abbreviated, but there is an upside -- it rides well in the chop while
the
long-wing sissies are getting the living hell pounded out of them in the
same stuff.
The little Nazi engine is indeed a 447... when it deigns to function, it
climbs the Fly in a sprightly manner, despite my gradually accumulated
bulk. With the IVO pitched for climb and the carb needle jacked up a
notch to keep up with the brutal 65 degree temps we have been
experiencing here in west Fla this past week, I reckon it did at least
800 fpm or so, turning 6350 rpm in the climb...Back in the summer in the
heat, I experimented with setting the prop at a more leisurely 6100 to
see if fuel endurance would improve, but it climbed like a Chevy
Suburban with low tires, so I reverted to the climb pitch setting... We
are both happier there...
The single most noteworthy improvement I see from the VGs on the Fly
wing is the ability to execute a power-off flare in ground effect from a
50 IAS glide without blowing out the bottom like a bowling ball through
a wet newspaper... the VG's add just enough extra lift at that critical
point to make it safe and fun... otherwise, needed 55 in the glide and
mebbe a touch of power at the flare... I predict that you will learn to
really like the drooping ailerons.... I think they make a big difference
in the ground effect operations of this short-winged little airplane.
One thing: You did not mention your height... Am considering hiring a
private contractor with appropriate equipment to sling-load me in and
out of the Fly, despite the fact that I skip breakfast and scrupulously
empty my pockets of car-keys, gas station receipts, excess change,
ball-point pens, the spare Arturo Fuente and the little
remove-before-flight tag from the BRS prior to attempting the dreaded
FireFly mount or dismount. Negotiating one's feet safely around the
windshield, whilst simultaneously suspending one's flabby butt in midair
over the seat with both hands on the siderails and a deeply veined
purple face, is a real crowd-pleaser.... Upon landing, I have been
known to feign illness, or a drunken stupor, and sit quietly in place in
the airplane until the onlookers lost interest and melted away before
attempting it. I don't know how long your legs are, but I recommend you
consider an enlarged windshield cut-out on the right side. Saves public
humiliation.... until one returns home, anyway...
Good luck with your Fly, sir...
bucolic beauford
FF-076
Brandon, FL
----- Original Message -----
Sent: Monday, December 08, 2008 6:34 PM
Subject: Re: Kolb-List: VG affect on stall
Beauford, Did you say you weigh 220 and from your signature FF it
appears that you fly a FireFly is that correct? I weigh about 215 and
am building a FireFly and I was a bit concerned about that short wing !
Before my accident I only weighed 190 and was flying a Firestar with a
503 and that bird had a lot of wing . If what I determined about your
signature is correct , how does it do? do you have a 447? how many feet
per min does it climb at ? Sorry about all these questions but there are
not many people that fly FireFlys on the list especially not " Bloated"
ones . Thank you in advance for any info you could give me . Chris
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Guys, and Cristal,
I have completed the installation of a HKS 700 E to my Firestar II.
Well actually I still have to hook up the tach and install two switches
for the mags and add oil before I can fire it up. I am also waiting on a
quick connect oil drain valve to put on the bottom of the oil tank. It
should be here in a few days.
As you can see there are a pile of wires and stuff all over the top of
the engine, but at least every thing is contained on top of the engine.
I made these pictures small for the band width challenged. If any one
would like more detailed ( larger size let me know and I will send them
back channel)
I purchased the engine from Jerry Olenik of Green Sky Adventures in
Hawthorne Fl. I cannot stress enough how well he has treated me. I am
not by nature and inclination to be mechanically inclined. In fact if I
get grease on my hands I count the whole day as a failure. He took the
time to answer any and all of my questions to guide me through a very
traumatic experience. :-) Jerry has all the parts and modifications
needed to mount one of these engines on a Kolb as well as worked out all
the quirks and little things that you need for the installation. If any
of you decide to go four stroke, you could not do better than Green Sky.
I do think that there should be a "HKS for Dummies" manual since both
Jerry and HKS only hit the high spots and leave some of the other stuff
unexplained. However Jerry never complained when I called for an
explanation of where this or that goes.
The great flying weather has of course departed for regions a lot
further south. ( Yes Beauford, my heart bleeds for you, imagine having
to endure 65 degree weather, how terrible) Perhaps it will get warm
enough to get a few tests in to see the difference between this one and
a 503. I of course will have to do a weight and balance first, but I
hope to have it in the air soon.
Larry C
At 08:11 PM 12/8/2008, you wrote:
>...Brother Davis...
>a private contractor with appropriate equipment to sling-load me in
>and out of the Fly, despite the fact that I skip breakfast and
>scrupulously empty my pockets of car-keys, gas station receipts,
>excess change, ball-point pens, the spare Arturo Fuente and the
>little remove-before-flight tag from the BRS prior to attempting the
>dreaded FireFly mount or dismount. Negotiating one's feet safely
>around the windshield, whilst simultaneously suspending one's flabby
>butt in midair over the seat with both hands on the siderails and a
>deeply veined purple face, is a real crowd-pleaser.... Upon
>landing, I have been known to feign illness, or a drunken stupor,
>and sit quietly in place in the airplane until the onlookers lost
>interest and melted away before attempting it. I don't know how
>long your legs are, but I recommend you consider an enlarged
>windshield cut-out on the right side. Saves public humiliation....
>bucolic beauford
I'm thinking you need the "Geezer Lift Chair" option for you Firefly.
http://www.spinlife.com/Uplift-Technologies-UPEASY-Power-Uplift-Seat-Assists/spec.cfm?productID=73225
From: | "Dave Bigelow" <up_country(at)hotmail.com> |
With the Landshorter VG's installed on my Firestar as recommended by Landshorter,
the stall is more abrubt than without the VG's. Without the VG's there is
no classic stall with a break, but more of a mush that started at 40 mph indicated
airspeed with my Firestar. Slow flight below 40 mph was not possible, and
final needed to be flown at 50-55 mph (power off) to avoid a hard landing during
the flare.
After VG installation, control was rock solid and responsive right down to the
stall, which takes place at about 30 mph wings level unaccelerated. There is
no pre-stall buffet, and the break is distinct, much like that of a sailplane
with laminar flow wing. With VG's, final can be flown as low as 40 mph power
off with sufficient energy to flare without a hard landing.
There is nothing dangerous or radical about the stall with VG's, but it not as
forgiving as without VG's. My recommendation for a low time pilot new to Kolbs
is to get some hours on your new plane without VG's, and then install them after
reaching a reasonable level of proficiency.
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
http://forums.matronics.com/viewtopic.php?p=218396#218396
John,
Thanks for the advice.
I do use the entire runway each time I fly and I don't plan on turning back unless
I have plenty of altitude say 700 + and no other options. Looking at the end
of runway 23 or 27 there are no good options that I would consider safe to
try to land in. Fairly dense tall trees, houses and large power lines! 27 is
3600 feet and 23 is 6000 so I never use 27/9.
Each time I make my departure I am constantly observing the runway left over ahead
of me and any other option to the left and right of me and thinking what
would I do if the engine quit now. I do the same when I am away from the airport
flying over the fields and trees.
I know making that turn under the stress of losing the engine will not be the same
as practicing the turn at altitude.
http://forums.matronics.com/viewtopic.php?p=218397#218397
Larry,
Did you trade in a used engine for the HKS engine or is this a new plane?
It looks nice!
I would like a 4 cycle at some point.
http://forums.matronics.com/viewtopic.php?p=218398#218398
Yes, I traded in a 447 that originally came with the plane when I bought
it in 1997. Without a muffler he gave me 800.00 for the engine. This is
my third engine on the Firestar, and I have 447 hours on the plane. I
sold the 503 to another pilot in Wash.
Another point of interest regarding the change is that I had an EIS
model 2000 which is a two stroke model. I sent it in to Grand Rapids
Tech and they changed it to a four stroke model and supplied the
CHT,EGT, Oil temps as well as the oil PSI for a very reasonable price.
I really liked the 503 and didn't really make the change because I was
afraid that it would fail. It was the fuel consumption that got me. Four
gallons an hour at 64 mph is just not enough to go anywhere, and where I
live every where is a long way off. I made the trip to Texas by putting
an extra 10 gallons of gas in the back seat, but had no room for much
else. If you pencil it out, you will save enough money with the fuel
savings and the rebuild (300 hours if you follow Rotax recommendations)
to more than pay for the HKS. Rebuild on the HKS is 1000 hours. I should
be too feeble to either pass my BFR or get into the plane even with a
"Geezer lift", before it needs the rebuild.
Larry C
Sent: Monday, December 08, 2008 8:39 PM
Subject: Kolb-List: Re: HKS 700 E
Larry,
plane?
It looks nice!
Checked by AVG - http://www.avg.com
12/8/2008 6:16 PM
Turning back to the runway kills lot of good folks.>>
Hi John,
One Christmas Day many years ago when I had been learning to glide for about
a couple of months this happened.
A friend who joined the club at the same time that I did strapped into our
old tandem seat Slingsby trainer. The instructor was in the back and they
were practicing `cable breaks`.
For those with no gliding experience. We were pulled into the air by an old
Allard sports car. The piano wire launch cable broke about every 4th
launch. Learning `cable breaks` was the gliding equivalent of `engine
failure`in the powered flying world.
The last thing anyone heard was the instructor sasying "OK Now Safety above
everything`. The Allard pulled away and the glider trundled down the runway
and into the air. At around 500 feet the instructor pulled the bung and
detached the cable to simulate a cable break. At that point the glider had a
mile of runway ahead and cracking the brakes and landing straight ahead was
the obvious drill. To the surprise of the watchers on the ground, the glider
turned back through 180 degrees. Even then it would have been OK. He could
have landed downwind with no trouble BUT.. when he got abreast of the launch
point he tried to turn back into wind. By this time he was low and was
afraid to put his wing down so he banked slightly and put in a bootful of
rudder, skidded into the turn and of course the inside wing stalled, the
plane dropped into an incipient spin for about 50 feet and dived straight
into the tarmac.
The pupil was killed outright. The instructor lingered a couple of days and
then died.
No one knows what happened. Presumably the pupil froze on the controls and
the instructor couldn`t over ride him.
Pat
From: | "Jean PILLAUDIN" <jean.pillaudin(at)gmail.com> |
Kolbers,
The time to turn an airplane depends primarily on the bank angle of the turn and
the airspeed being flown. It is a mathematical relationship that is a function
of the tangent of the angle of bank. Attached is an image of a spreadsheet
table I put together to show this relationship at various airspeeds and bank angles.
The first table shows the turn radius (not diameter) in feet for a given
bank angle and airspeed.
The second table uses this data to derive the time in seconds to make a turn of
270 degrees. I used 270 degrees because to get back to the runway you have to
turn 180 to get the right heading but then you are two radii away from the runway
so then you have to keep turning, say another 45 degrees then turn back 45
degrees to get re-aligned with the runway, for a total of 270 degrees of turning.
The third table takes the second tables data and ASSUMING a 600 FPM descent rate,
calculates the loss of altitude in the 270 degree turn.
NOTE: This is not a recommendation for or against turning back to the runway at
any time. It is simply showing the mathematical relationship amongst bank angle,
true airspeed, time to turn and altitude lost in doing so.
Thom Riddle
CFI-SP
Power Plant Mechanic
N1208P RANS S6S, Tailwheel, 912UL
N197BG FS1/447
Scratch any cynic, he said, and youll find a disappointed idealist.
George Carlin
http://forums.matronics.com/viewtopic.php?p=218444#218444
http://forums.matronics.com//files/turnback_182.jpg
I did not use very steep bank angles in the previous table posted so I am posting
another with steeper bank angles, for your amusement and perhaps amazement.
Thom Riddle
CFI-SP
N197BG FS1/447
George Carlin
http://forums.matronics.com/viewtopic.php?p=218446#218446
http://forums.matronics.com//files/steepturnback_329.jpg
From: | "Richard Girard" <aslsa.rng(at)gmail.com> |
Larry, I have an HKS on my trike and I love it, especially the fuel
consumption. Another is the noise level, or rather the lack or it.I strongly
suggest you review section 5 of the Installation Manual with respect to
mounting the oil tank and the caution about the oil cooler mounting.
Rick
On Mon, Dec 8, 2008 at 8:12 PM, Larry Cottrell wrote:
> Guys, and Cristal,
> I have completed the installation of a HKS 700 E to my Firestar II. Well
> actually I still have to hook up the tach and install two switches for the
> mags and add oil before I can fire it up. I am also waiting on a quick
> connect oil drain valve to put on the bottom of the oil tank. It should be
> here in a few days.
> As you can see there are a pile of wires and stuff all over the top of the
> engine, but at least every thing is contained on top of the engine. I made
> these pictures small for the band width challenged. If any one would like
> more detailed ( larger size let me know and I will send them back channel)
> Hawthorne Fl. I cannot stress enough how well he has treated me. I am not by
> nature and inclination to be mechanically inclined. In fact if I get grease
> on my hands I count the whole day as a failure. He took the time to answer
> any and all of my questions to guide me through a very traumatic experience.
> :-) Jerry has all the parts and modifications needed to mount one of these
> engines on a Kolb as well as worked out all the quirks and little things
> that you need for the installation. If any of you decide to go four
> stroke, you could not do better than Green Sky. I do think that there should
> be a "HKS for Dummies" manual since both Jerry and HKS only hit the high
> spots and leave some of the other stuff unexplained. However Jerry never
> complained when I called for an explanation of where this or that goes.
> The great flying weather has of course departed for regions a lot further
> south. ( Yes Beauford, my heart bleeds for you, imagine having to endure 65
> degree weather, how terrible) Perhaps it will get warm enough to get a few
> tests in to see the difference between this one and a 503. I of course will
> have to do a weight and balance first, but I hope to have it in the air
> soon.
> Larry C
Sent: Tuesday, December 09, 2008 7:07 AM
Subject: Re: Kolb-List: HKS 700 E
I strongly suggest you review section 5 of the Installation Manual
with respect to mounting the oil tank and the caution about the oil
cooler mounting.
Rick
Actually I already did and asked Jerry about whether or not to mount
the oil tank above the cooler. He said it was not necessary. I am not
real sure how you could accomplish such a feat with the Firestar?
Larry
> posting another with steeper bank angles, for your amusement and perhaps
> amazement.
> Thom Riddle
Thom:
Are these Kolb numbers, or a generalization?
I'm not surprised at the results of steep bank angles and higher airspeeds.
I believe I mentioned in a previous email, agressive turns take less time
and use less altitude. The problem with that maneuver is attaining and
maintaining the increased airspeed at low altitudes, and how hard can I
crank it around, at very low altitudes, without stalling.
If I get a chance to fly today, I will practice some of this stuff at
altitude to see how it works out.
John H,
The first two tables are mathematical relationships that are independent of the
airplane being flown. This means that the turn radius and time to turn are the
same for any airplane at these bank angle and airspeed combinations. Ever notice
how big a radius it takes to turn a jet fighter flying at high speed? It
takes many miles to turn around at high speed, even in a near 90 degree bank angle.
Ever wonder why gyroplanes (and helicopters for that mater) can turn on
a dime? Because of their very low speed capability. At higher speeds they cannot
turn so quickly or in such short distances. It is pure math.
The third table, ASSUMES a 600 FPM descent rate. This table depends upon that assumption.
If your airplane descends at a different rate then the altitude loss
numbers will differ linearly. In other words if your airplane descends at say
450 FPM then the altitude loss will be 3/4 of those in the table shown for a
Thom Riddle
CFI-SP
N197BG FS1/447
George Carlin
http://forums.matronics.com/viewtopic.php?p=218459#218459
My Aeronca chief, when experimenting this series of turns, would eat
up a lot of energy in a hurry.
It wasn't very good without the prop helping it around. Straight
ahead glide wasn't too bad.
The MkIII, to my pleasant surprise, seems much happier in a steep
turn. I gave demo rides
this past summer to a couple of young lads and did steep bank turns
to show what a small circle we could turn.
The extra passenger load made little difference. Pretty amazing.
BB
>> so I am posting another with steeper bank angles, for your
>> Thom Riddle
> Thom:
> airspeeds. I believe I mentioned in a previous email, agressive
> turns take less time and use less altitude. The problem with that
> maneuver is attaining and maintaining the increased airspeed at low
> altitudes, and how hard can I crank it around, at very low
> at altitude to see how it works out.
> john h
> mkIII
Ever wonder why gyroplanes (and helicopters for that mater) can turn on a
cannot turn so quickly or in such short distances. It is pure math.
> Thom Riddle
Thom:
Helicopters are much more adept at making 180s than fixed wing. The primary
reason, rotary wing aircraft build rotor rpm in turns. The tighter the
turn, the more rotor rpm. Sometimes it took quite a bit of collective to
prevent overspeed and maintain rotor rpm in the green. Very low speeds
during autorotation will prove hazardous to your health in a helicoper. The
Army helicopters I flew were amazingly agile. They handled quick turns and
steep bank angles quite well.
> The MkIII, to my pleasant surprise, seems much happier in a steep turn.
> I gave demo rides
> this past summer to a couple of young lads and did steep bank turns to
> BB
Bob B:
You are quite right.
It took a pretty good sized passenger in the the factory MKIII to get into
an accelerated stall during demonstrations. That, of course, was in the
clean configuration, no flaps.
During a demo in my mkIII a few years ago at Lakeland, I blanked out the
elevators during a hard pull up with full flaps. Would not do it clean, but
with full flaps, the elevators went away. This caused me to be a lot mor
cautious during steep approaches and landings with full flaps.
(those demo turns were WITH power) :)
BB
> eat up a lot of energy in a hurry.
> BB
>>> Thom Riddle
>> Thom:
>> low altitudes, and how hard can I crank it around, at very low
>> john h
>> mkIII
John H,
You bring up a good point. The tables I posted assume 1 G flight because the original
question was about turning back with engine out. In a descending turn without
power or attempt to hold altitude it is easy enough to maintain 1 G or
less.
What gets a lot of airplane pilots in trouble is pulling back on the stick during
a power out descending turn in the vain hope that some magic will be performed.
The vast majority of CFIs and the FAA pubs teach that Gs increase in high
banked turns. Of course this is true if you are maintaining altitude. In a power
out situation any attempt to maintain altitude in an airplane will eventually
result in exceeding the critical angle of attack and a stall. The trick to
quick descending power out turns in an airplane is maintaining 1 G or less loading.
If this is done you can get turned around pretty quickly at slow speeds.
Load it up with back stick and you are asking for a stall/spin fatality.
Thom Riddle
CFI-SP
N197BG FS1/447
George Carlin
http://forums.matronics.com/viewtopic.php?p=218470#218470
Hi gang,
I learned to fly in a J-3 back in 1946, we were taught to go straight
ahead if we had engine failure on take off...later on i had a engine fail on
takeoff in a J-3, I never thought about trying to turn around to the runway which
was a farm field. I went about straight ahead into a pasture and the plane
was ok, I was lucky to have that field there, I had veered slightly to the
right on take off because there was a woods straight ahead, good thing i did.
You need to remember stall speeds go up in turns. I wonder how many on
this list have made a 180 on take off after losing a engine and survived and
if so from what altitude? I also wonder how many have stalled and crashed or
killed themselves trying it? As for me if I lose a engine on my firestar on
take off I will go straight ahead no matter what unless i have 6 to 7 hundred
feet. Hope this info saves someone's life....
jim swan FS ll 503
michigan
Hi Jim S:
Good to hear you are still alive and kicking in the cold country, or have y
ou migrated with the other snow bird from Michigan to Florida?
Your IP probably knew what he was talking about. Not much has changed from
then to now. Gravity is still in charge.
mkIII-Too windy to fly today, especially after a 2.5 month lay off. 67F
ahead
jim swan FS ll 503
michigan
>that assumption. If your airplane descends at a different rate then the
>altitude loss numbers will differ linearly. In other words if your
>airplane descends at say 450 FPM then the altitude loss will be 3/4 of
>those in the table shown for a 600 FPM descent rate.
Without checking the numbers, it looks right. However, I question the
assumption of a constant 600fpm descent rate. In a steep turn, the descent
rate will increase quite a bit.
Of course, there's also reaction time, and time to push the nose down, roll
into the turn, roll back out, and flare, which all must be factored into
the real world scenario.
-Dana
The gene pool could use a little chlorine.
-Dana
Hi Larry I think your going to like the HKS I know I really really like mine, have
300+ hrs on it in the Kitfox and per my calculations its paid for vs the 582
I replaced, the cost of operation is 1/2 the cost vs the 582.
GB
MNFlyer
Flying a HKS Kitfox III
http://forums.matronics.com/viewtopic.php?p=218509#218509
Stall speed vs bank angle is widely misunderstood. Many CFIs regurgitate what they've
been taught and what they've read in FAA publications without fully understanding
it. What most have been taught is that "Stall speed increases with
increased bank angle." What they are not taught, but is true nonetheless, is that
this statement is true ONLY if there is an increase in G loading, which is
the case if you are trying to maintain altitude and airspeed. If you maintain
1 G loading when banking steeply(by descending at the proper rate), the stall
speed does not increase. The only way to maintain 1 G load while banking steeply
and turning is by descending while turning.
The "Stall speed increases with increased bank angle." adage probably came about
as an over simplification because it is easier to teach and is a good idea as
a point of safety when teaching new students. Unfortunately, that is as far
as most pilots, CFIs included, ever dig into the physics.
If you are comfortable with experimenting, consider sometime climbing to an altitude
of at least 2,500' AGL, do clearing turns then reduce the power to idle,
put the nose down and hold your normal approach speed. and start banking to
your favorite side, BEING SURE TO HOLD YOUR NORMAL APPROACH SPEED THROUGHOUT this
maneuver, continue increasing the bank angle until your maximum comfort level
and notice how quickly you are turning. You should also notice three other
things. 1) You are NOT experiencing higher than 1 G loading, like you would at
high bank angles with power and maintaining altitude. 2) You are not stalling.
3) Your descent rate and turning rate increase as you increase the bank angle
while holding a constant airspeed.
While descending, gently roll to wings level attitude with coordinating rudder
maintaining your normal approach speed (do this without increasing G load). Complete
this maneuver by no lower than 1,500' AGL because that is the minimum legal
altitude for maneuvering flight.
The most important thing to get from this is that the increased G loading from
maintaining airspeed AND ALTITUDE while increasing bank angle is responsible for
the increased stall speed. Maintain 1 G load at your normal approach speed
by descending and you can bank quite steeply without increasing the stall speed.
If you start to pull back on the stick while you are steeply banked you will
be increasing the G loading which WILL result in a higher stall speed.
PLEASE NOTE: I am NOT recommending you do this anywhere near the ground or in a
real engine out event. I'm merely trying to clear up a common misunderstanding
about the relationship between bank angle and increasing stall speed.
I fully expect to get an argument so go ahead and flame away.
Thom Riddle
CFI-SP
N197BG FS1/447
George Carlin
http://forums.matronics.com/viewtopic.php?p=218511#218511
or in a real engine out event. I'm merely trying to clear up a common
misunderstanding about the relationship between bank angle and increasing
stall speed.
> Thom Riddle
Thom:
Not from me. I'm too tired. ;-)
Didn't know anyone was disagreeing with you.
I believe we went through this not too long ago. Tom Kuffle was part of
that discussion, IIRC.
I've learned through the years I can get away with a lot of stuff in a Kolb
if I keep my airspeed above stall speed. It is a terrific little airplane.
Don't think I would try and fly some of the other light aircraft like I do
my Kolbs.
mkIII - Waiting for the thunderstorms to hit.
I think the main reason the turn back is not encouraged is "human error"
It is a lot harder to get in trouble (stall/spin) if you keep gliding straight.
In the stress of turning back to soon or low there is a very high probability that
a pilot will attempt to stretch the glide by adding back pressure and thus
entering a stall/ spin.
If something doesn't feel quite right apply forward stick!
Here is a great article covering the turnback:
http://www.auf.asn.au/magazine/turnback.html
http://forums.matronics.com/viewtopic.php?p=218529#218529
Subject: | The turn-back following engine failure article |
Just reposting the article for the list.
http://forums.matronics.com/viewtopic.php?p=218530#218530
>what they've been taught and what they've read in FAA publications without
>fully understanding it. What most have been taught is that "Stall speed
>increases with increased bank angle." What they are not taught, but is
>true nonetheless, is that this statement is true ONLY if there is an
>increase in G loading, which is the case if you are trying to maintain
>altitude and airspeed. If you maintain 1 G loading when banking steeply(by
>descending at the proper rate), the stall speed does not increase. The
>only way to maintain 1 G load while banking steeply and turning is by
You are correct; stall speed increases with bank angle in a level
coordinated turn. BUT... If you maintain 1g in a coordinated banked turn,
then the aircraft must accelerate downwards at an acceleration
corresponding to the 1 minus the cosine of the bank angle times 1G. In the
case of the 60 banked turn, you either pull 2g's or you pull 1g and
accelerate down at 1/2g... so your vertical speed increases by 16 fps (960
fpm) every second. So, to using an airspeed of 50 mph and 60 bank,
according to the chart you posted earlier it takes 6 seconds... but at the
end of those 6 seconds your rate of descent has increased to 5760 fpm and
you've lost an additional 288' of altitude.
-Dana
In the 60's people took acid to make the world weird. Now the world is
weird, people take prozac to make it normal.
Subject: | Re: Beauford is the expert on VG's ! |
Beauford:
I don't know about that. First tour in VN my medic took great delight in g
iving me some daily penicillin shots, in the butt, for something like VG.
Said if I stayed out of the village I wouldn't have to take the shots.
Never had to take them again, so.....you may be right. Once you get'em you
become immune.
I didn't get to fly today. Weather was kinda cruddy and very windy.
Went over to Gantt International Airport anyhow. Decided to drag the strip
and smooth out the cow pies. While I was down by the hanger I checked out
my bird. Darned rat has been back in it while I was on my trip. He ate t
he right shoulder harness. Cut'em right off the bulkhead. Also got the ri
ght seatbelt. Looks like it went through a buzz saw. While he was at it,
he or she checked out a couple wires. Cut the 12vdc wires to my ANR headse
t and my Chillie Vest. That is all I could find damaged. Hopefully, he di
dn't get back in places and cut wires and hydraulic brake lines like he did
a couple years ago.
Time to call my friendly Falcon Insurance Agent and see what to do next. ;
Anyway, strongly recommend you look into the new vaccine once you get ov
er your current problem...recommend you look for someone else to pass it al
ong to...talk to Hauck...he hasn't had VG yet...
beauford
Apparently, this 180 turn is a matter of interest to many with differing opinions.
Certainly, most of what has been written here is true and is appreciated.
Many of us pilots fly differently and were taught in a variety of ways. I believe
the important point of all of this discussion is for the individual pilot
to know his limits and fly within them. Learning to do an efficient and safe
180 degree turn is worth the time, effort and gas, in my opinion. The most
efficient procedure may seem radical, but can be done safely if it is practiced
at altitude on a regular basis. Amelia Reid taught me the science of the turn
(some on line may have heard of her.....she was a very good instructor).
Back to the point. A pilot who practices and knows his ability should base his
decisions on what he can do and not what some say is possible. In a Cessna 150
my first tries resulted in altitude losses of up to 600 ft. I lost an engine
at 35 feet in a Kasperwing and had to do a 180 to
a!
void obstacles. My effort was about 10 degrees short and bent a nose wheel. Thank
goodness the Kasper is a slow flying airplane.
Subject: | Re: The turn-back following engine failure article |
fuel in the bowser?
let us not dwell upon that condition.....
BB
Just reposting the article for the list.>>
Thanks for that, Grant. Very good article.
I think there is a good case to be made that all pilots should start their
training in gliders. By the time they have gone solo they will have done
more take offs and landings and experienced more engine failures (cable
breaks) than the average power pilot will experience in his first 5 years
flying.
Just a thought
Pat
Hi gang....These pictures rest my case...;-)>>
Great pics. Is the smoke generator part of the airodynamics test
programme?
Pat
Not being able to afford a lawyer as good
as he could hire with his doctor's income, she lost the business>>
Hi Dana,
Life is damned unfair sometimes. Specially when litigation is involved. Sad
story
Pat
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
>flying.
Pat,
I believe this is good advice. It helps to overcome the tendency to hold
back on the stick to extend a flight. I remember when I was solo and
realized what I thought at the time was too low and too far away to make it
back to the airport. I had to force my self to let the stick go forward so
that I could increase ground speed. I made it with altitude to spare, and
after that, I never had one time I never had any problems with letting the
stick go forward.
Simulated rope breaks were great, and one learned to drop the nose and kick
it around in a hurry. One advantage in a glider is that you did not have to
worry about the airspeed indicator, as you could gage air speed from the
wind noise.
With the FireFly, I have had only one 180 back to the landing strip. The
447 iced up on takeoff. At about 250 feet the engine started to droop and I
kicked it around and luckily made a down wind landing is spite of turning
down wind. The second engine droop came here in Indiana on a very hot day.
Even though I was at a much higher altitude, I did not elect to return to
the airport as the VSI indicated I was in an area of high sink. Instead, I
headed for a corn stalk field and landed cross wind in with the rows close
to a house and road.
These procedures can be practiced at altitude, so that you can experience
the sudden deceleration and discover the importance of pilot reaction time.
Also one can get comfortable with making a tight bank at fairly low speed
with the nose seemingly pointed at the ground and the gentle leveling of the
wings and pull up. Also, one should practice during cold and warm weather to
experience the different handling characteristics.
As someone else has said, it is all about good energy management.
Fly Safe!
Jack B. Hart FF004
Winchester, IN
Subject: | JH's "Darned rat" vandal |
--- MIME Errors - No Plain-Text Section Found ---
A message with no text/plain MIME section was received.
The entire body of the message was removed. Please
resend the email using Plain Text formatting.
HOTMAIL is notorious for only including an HTML section
in their client's default configuration. If you're using
HOTMAIL, please see your email application's settings
and switch to a default mail option that uses "Plain Text".
--- MIME Errors No Plain-Text Section Found ---
Subject: | Re: JH's "Darned rat" vandal |
From: | "cristalclear13" <cristalclearwaters(at)gmail.com> |
undoctor wrote:
> > [b]Went over to Gantt International Airport anyhow. Decided to drag the strip
out
ate t
the ri
it,
headse
he di
he did
> > a couple years ago.
> > [/b]
> John, gang,
> Here's the Kolb part. I learned that if you sprinkle moth balls on the floor
around any place the mice can access your vehicle, they won't go through the
smell and your vehicle's safe. Of course the down side is enduring the smell
of the moth balls. Without regard to the imminent risk of folks asking the age-old
burning question, "Do you know how to smell moth balls?", this info could
prevent a lot of mice from trespassing on a lot of Kolbs.
John,
Does this mean the valerian didn't work or did the smell/effect wear off while
you were roaming the countryside?
Cristal
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=218741#218741
Last year,
I had a similar situation where a rats or a few got under the hood of my truck
and cut a few wires to the computer shorting it out. They had a massive amount
of figs piles high on my intake cover. The truck was running a 6 cylinders barely
and the ABS system failed.
I had to have the ABS and computer replace at a cost of $1200.
Shortly after this they got back in a cut my alternator wire twice. 1st time I
had to be pulled 16 miles to a shop to have a new wire made since it was cut right
at the connector.
2nd time i made it back home and the truck died in the yard. Wire was easy to fix
this time.
This year I killed 9 mice in my attic. I have no Idea how they got there.
The cheap victor snap traps with peanut butter on them will kill them 99% of the
time.
Moth balls don't work that well. They still get in my landlords vehicle despite
him putting mothballs around the truck. He has to leave the hood open with mothballs
on the engine to keep them out.
If you don't have pets, Timick (spelling?) a granular pesticide used by farmers
will kill the rats almost instantly. It is however very toxic and potent in
smell.
I keep my Kolb in a 8.5X 24 foot Haulmark car hauler. No rats can get it it!
You can alway install a cat in your hangar. They are pretty efficient rat killers
if you don't over feed them.
http://forums.matronics.com/viewtopic.php?p=218743#218743
Hi all. I got the mouse nest out of my tube, cleaned up the corrosion, finished
my annual inspection and re-mounted my Rotax after Gerry Olenik from Green Sky
Adventures did some maintenance on it for me. I have seen several brag on
him so I will also brag. He did a great job, was very knowledgeable and helpful.
With the help of a friend we determined that my choke has not been closing all
the way. If I manually move the cable back where it splits into the two cables
it'll close and run fine. My friend suggested doing away with the choke and
just using a priming system. I've gotten used to the choke and am thinking perhaps
I could just replace the cables.
P.S. Gave my dad a quick ride around the pattern and he LOVED it of course. What
fun!
Cristal Waters
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=218755#218755
> John,
> while you were roaming the countryside?
> Thanks,
> Cristal
Cristal:
Don't know. I probably should have dumped the whole bottle of valerian
capsules in the boom tube, sprinkled several boxes of moth balls around the
tailwheel, main wheels, and some inside.
Not a good feeling to open the door and see your airplane chewed up.
Especially the second time around. ;-(
I put out two big sticky pads for rats, some Decon rat poison, and a box of
moth balls in front of and below the boom tube inside the cockpit. Hope it
works before I have my seat belts and shoulder harnesses replaced.
mkIII - Slightly chewed on.
> Victor also makes an electronic rat assasination machine >
> bloodthirsty beauford
Beauford:
I like that idea.
Gonna got to Lowes tomorrow and see if I can find me one of them. Put it
right by the tailwheel. I am sure they are getting in the airplane via
tailwheel and tailboom.
I have one of those electronic mouse killers. I had a medium sized mouse that
I was trying to kill, and put a camera by the trap. He went in, got zapped, jumped
back out and never went near it again.
The electronic Rat Killer is a great idea, its just not strong enough to work all
the time.
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=218783#218783
List
FWIW - rats & mice W ILL get 'in' anywhere, no matter what you put up
as a barrier. Most often the tailwheel area. Electric zappers do
work, but get the biggest one you can. It would be fairly easy to
make one self-resetting; there was one like that a long time ago.
Shoved the dead ones over into a sealed & concealed container &
readied itself for the next one. Rats are smart-- if they see a dead
one they may stay away.
Rat/mouse urine is very corrosive to alum. Most expensive to repair
too.
Peanut butter is a good bait. But if you use a Havahart trap with a
1/2" wire mesh, mice will enter, trip it, eat the bait & then squeeze
out thru the 1/2"mesh.
I had a boa constrictor as a pet for years, NO mice/rats in the
house. But I realize that's not a solution for everyone.
Good luck.
PS Don't let them get near Viagra! -- no telling what would happen.
> Beauford:
> I like that idea.
> Put it right by the tailwheel. I am sure they are getting in the
> airplane via tailwheel and tailboom.
> john h
> mkIII
Ok, here's my solution... worked EVERY time.... Got a large
bucket... really large, and tall... made of plastic so the sides were
slippery... Bucket has to be big enough and deep enough for about at
least 8 inches of water, 8 inches between the water and the rim, and
slippery enough so a mouse/rat can't climb out.
I stuck a chair next to the bucket, filled the bucket half way with
water, put a 2x4 that went out over the bucket and then put a weight
on the 2x4 so it became, essentially a steady diving board.
Then I took a 6" x 6" piece of plywood, put it on the water, then put
on it a couple of bits of dry dog food... the really smelly kind.
The mice/rats would climb out on the diving board, drop down to the
plywood to get the dog food, the plywood would immediately tump over,
and the mouse/rat would swim to exhaustion and drown. Obviously,
making sure the mouse/rat can't climb back out is critical, as is
making sure the water level/plywood is far enough away so they -have-
to drop down to to get it.
Worked flawlessly, every time. I once got rid of a whole family that
way, one each day.
-- R
On Wed, Dec 10, 2008 at 7:25 PM, russ kinne wrote:
> List
> FWIW - rats & mice W ILL get 'in' anywhere, no matter what you put up as a
> barrier. Most often the tailwheel area. Electric zappers do work, but get
> the biggest one you can. It would be fairly easy to make one
> self-resetting; there was one like that a long time ago. Shoved the dead
> ones over into a sealed & concealed container & readied itself for the next
> one. Rats are smart-- if they see a dead one they may stay away.
> Rat/mouse urine is very corrosive to alum. Most expensive to repair too.
> Peanut butter is a good bait. But if you use a Havahart trap with a 1/2"
> wire mesh, mice will enter, trip it, eat the bait & then squeeze out thru
> the 1/2"mesh.
> I had a boa constrictor as a pet for years, NO mice/rats in the house. But I
> Good luck.
>> Beauford:
>> I like that idea.
>> john h
>> mkIII
Subject: | trying a new prop |
Kolbers,
I got a new prop delivered today from Valley Engineering. I hope to
put it on Saturday and if the weather is cooperative I plan to fly.
In my last post I mentioned my plane handled "superb". I need to re-
qualify that remark...it still has marginal climb out performance with
my new Generac engine. It's about half what my old 503 had, at best
about 400 fpm, but probably the average is more like 300. I'd call
that marginal at best. I currently have an IVO 72" 3 blade, set so I
get about 3700 rpm on take-off WOT. Once I'm up to cruise altitude, it
does handle and perform the same as it always did, with the exception
of the climb rate.
The new prop is a 78" 2 blade Culver Prop, pitched at 41. I'll still
have a good 2 1/4" from the tip to the boom tube. I'm going to also
change the spacer from a 3" to a 1 3/4" spacer, since the new prop is
2 1/4" thick at the hub and the IVO is only 1" thick. That should be a
better set up for maintaining prop balance since the prop will be
closer to the engine, and will still keep the prop tips 3 3/4" from my
aileron tubes. The larger spacer was used to allow for the clearance
required between the prop and the aileron tubes for the IVO, which has
a lot of flex. I have a prop thrust tester I can use, and I plan to
check the IVO on a static run up, record the thrust, then change out
to the new prop and see what it produces on a static run up.
I have a question to throw out there for review. If one prop produces
more static run up thrust than another, regardless of whether it is a
2 or 3 blade prop, would it not therefore be a better all around
performing prop in both climb and cruise? If the new prop, which is
not ground-adjustable like the IVO is, allows the engine to reach 3700
RPM on a static run up test, which is where the max HP and torque
values meet on the Generac engine, and if it produces more thrust at
that RPM level, it seems to me it would out-perform the IVO in both
climb out and cruise.
I know no one here know much about the engine I'm using, but wouldn't
these facts hold true for any engine/prop combination?
Thanks for any input,
Jimmy Young
FS II, Houston TX
Subject: | Re: trying a new prop |
No, it might, but it's just as likely to be worse. A prop has to be
optimized for a particular airspeed, which is why we have "climb" props
which are less efficient at cruise speed, and "cruise" props which don't
climb as well but are more efficient during cruise. Or it could be a
compromise. A prop that's optimized for static thrust would have lousy
cruise (and even climb) performance. Taken to the extreme, consider a
helicopter rotor... it's optimized for static thrust but would make poor
(if any) thrust if used as a prop at 60 mph.
-Dana
I support drug testing. I believe every public official should be given a
shot of sodium pentathol and asked "Which laws have you broken this week?".
Hi Jimmy,
Oh I think you are going to open up a can of worms here.
Static thrust is only a partial measure of how a prop may perform. Another
part is velocity of the same air. Basically you could have a huge amount of
thrust by swinging a twelve foot diameter prop that the engine is properly
geared for but, you would have such low velocity that a plane would never
gain enough speed to get off the ground.
It is finding the proper balance between engine speed, thrust and velocity
that has to overcome the weight and drag of the airframe to make a good
flying plane.
Basically, I think that your performance issue is a lack of horsepower. It
takes power to lift anything into the air rapidly. Once the plane has
reached a steady cruise, power is typically reduce for economy and
conservation of engine life.
You might have to re-pitch the prop so that on the ground you might be below
peak rpm/torque but, once the engine unloads in the air, the peak torque is
reached. Usually though most people pitch their props for maximum horsepower
and that is usually at a higher rpm than peak torque.
Oh there are so many trade-offs! Basically you are going to have to find
whats best for your application by good ol' trial and error. Two blades are
more efficient than three. One blade is best but, has its own practical
problems of balance issues to say the least. Good luck with the plane and
please be careful.
Carlos G.
Just My $0.02
Sent: Wednesday, December 10, 2008 6:45 PM
Subject: Kolb-List: trying a new prop
> Kolbers,
> I got a new prop delivered today from Valley Engineering. I hope to put
> qualify that remark...it still has marginal climb out performance with my
> new Generac engine. It's about half what my old 503 had, at best about
> 400 fpm, but probably the average is more like 300. I'd call that
> marginal at best. I currently have an IVO 72" 3 blade, set so I it > does
> handle and perform the same as it always did, with the exception of the
> climb rate.
> The new prop is a 78" 2 blade Culver Prop, pitched at 41. I'll still have
> a good 2 1/4" from the tip to the boom tube. I'm going to also change the
> spacer from a 3" to a 1 3/4" spacer, since the new prop is 2 1/4" thick
> at the hub and the IVO is only 1" thick. That should be a better set up
> for maintaining prop balance since the prop will be closer to the engine,
> and will still keep the prop tips 3 3/4" from my aileron tubes. The
> larger spacer was used to allow for the clearance required between the
> prop and the aileron tubes for the IVO, which has a lot of flex. I have a
> prop thrust tester I can use, and I plan to check the IVO on a static run
> up, record the thrust, then change out to the new prop and see what it
> more static run up thrust than another, regardless of whether it is a 2
> or 3 blade prop, would it not therefore be a better all around performing
> prop in both climb and cruise? If the new prop, which is not
> ground-adjustable like the IVO is, allows the engine to reach 3700 RPM on
> a static run up test, which is where the max HP and torque values meet on
> the Generac engine, and if it produces more thrust at that RPM level, it
> seems to me it would out-perform the IVO in both climb out and cruise.
> Jimmy Young
> FS II, Houston TX
From: | TheWanderingWench <thewanderingwench(at)yahoo.com> |
Subject: | Re: choke or primer |
Hi Cristal,
I removed the choke on my 503 a few years ago and have been using just the primer,
without any difficulty. However, I did read somewhere that you can troubleshoot
your engine via the choke (don't remember the details) so am not sure if
I did the wisest thing - although, as I said, it's been fine for several years
and several hundred hours without it.
Arty Trost
Sandy, Oregon
Maxair Drifter
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
--- On Wed, 12/10/08, cristalclear13 wrote:
> From: cristalclear13 <cristalclearwaters(at)gmail.com>
> Subject: Kolb-List: choke or primer
> To: kolb-list(at)matronics.com
> Date: Wednesday, December 10, 2008, 2:39 PM
> "cristalclear13"
> the corrosion, finished my annual inspection and re-mounted
> my Rotax after Gerry Olenik from Green Sky Adventures did
> not been closing all the way. If I manually move the cable
> back where it splits into the two cables it'll close and
> choke and am thinking perhaps I could just replace the
> cables.
> LOVED it of course. What fun!
> Cristal Waters
> Rotax 503 DCSI
> Jimmy Young
> FS II, Houston TX
Jimmy,
For the problems you've discussed, these are the reasons why I opted for the
in-flight adjustable, electric motor option, for my Ivo Prop.
I expect it should give the best of both worlds. At static thrust I can decrease
pitch
substantially, allowing the engine to acheive a higher RPM (into the power band).
Once I'm cruising along, I can crank in quite a bit of pitch, for better dynamic
thrust.
Although I haven't flown with this combination, yet. I have had it operational
a few
years ago. It was quite impressive to me. The pitch change is quite subtantial,
and takes
maybe 7-10 seconds to go from a flat pitch to really steep.
Although this combination may not be for everyone, it seems like a good way to
go for me.
Mike Welch
MkIII
You live life online. So we put Windows on the web.
It depends on how he has the plane registered. If EAB he can use it,
other wise no.
Larry C
Sent: Wednesday, December 10, 2008 10:47 PM
Subject: RE: Kolb-List: trying a new prop
produces
a
> Jimmy Young
> FS II, Houston TX
Jimmy,
for the
I have farmed and ranched for 28 years and dealt with a lot of troublesome small
gas engines. I have kept a lot of those engines running (momentarily) using
the choke, at least, I can determine if the problem is fuel starvation.... If
my 503 ever starts coughing and running rough during flight, one option would
be is to choke the engine slightly. It might work and get you to a safe landing
spot. You can also diagnose fuel mixture problems with it....You may be able
to do the same thing with the primer but I havnt tried it.....Just my thoughts
on the matter.
The next best thing to playing and winning is playing and losing!...Mike Hillger
http://forums.matronics.com/viewtopic.php?p=218864#218864
Subject: | Kolb Ultrastar: How to take-off |
Hi all,
I am at the very beginning of my experience of flying a Kolb Ultrastar. I
only have spend two hour of running the runway (grass) in little cross wind,
and i have two take off and hopefully two landing too :)
I am reading Jack Firefly WebSite , very interesting:
http://www.thirdshift.com/jack/firefly/howtofly.html
And Jack says:
"I always take off with the *stick centered and full back*."
I did not that. I gradually put full throtle and put the stick forward
(surely glider pilot habit), rapidly the tail go up and I control it moving
the stick a little back (still up), maintain the axe with the foot and
ailerons. The plane accelerate and take off, accelerate again in the air -I
kepp the runway axe- and gently pull back to climb at the good speed.
It is not concrete runway, it is gentle grass.
How do you do, with your Kolb? Am I wrong somewhere?
Jean
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
Jimmy
This sounds like a good test. Of the composite props on the market the IVO
has the least thrust. That two bladed wood prop should give you alot more
thrust.
Horse power is always important but it is thrust that moves you. A long two
bladed prop turns more HP into thrust. The problem is that there are
compromises. As you get closer to the limit of how big a prop your engine
can handle the smaller speed range your prop work in.
If you configure your prop for best static thrust at max RPM you might over
RPM your engine or limit your cruise speed. The 41 pitch on your prop might
be just right but only testing will tell. I recently cut my prop from a 72
inch to 71 inches to get a wider speed range which it did but it also
increased the HP necessary to maintain the same cruise.
Let us know how it works.
Rick Neilsen
Redrive VW powered MKIIIC
Sent: Wednesday, December 10, 2008 9:45 PM
> Kolbers,
> marginal at best. I currently have an IVO 72" 3 blade, set so I get about
> 3700 rpm on take-off WOT. Once I'm up to cruise altitude, it does handle
> and perform the same as it always did, with the exception of the climb
> rate.
> Jimmy Young
> FS II, Houston TX
Subject: | Re: Kolb Ultrastar: How to take-off |
Hi Jean:
I don't think you are wrong.
I take off in all models of Kolbs, normally like this:
1-Full Throttle
2-Neutral Stick - No pressure on the stick to keep the tail down or force t
he tail up. It will come up by itself when ready.
3-When the tail starts coming up, input control pressure to keep it level.
4-When it is ready to fly, a little aft stick pressure and you are flying.
All this takes place in a matter of a few seconds time.
This would be an ordinary takeoff on good surfaces.
Jean
If my 503 ever starts coughing and running rough during flight, one option would
on the matter.
You can with the primer and it's the same troubleshooting process. You can hit
the primer with the engine running to enrichen the mixture in the same way as
activating the chokes.
The primer is the way to go. The cost is just the extra small tubing you have to
run to the carburettors, the plunger and the fuel pickup, but it eliminates
the cabling and etc. associated with the chokes. The primer generally leads to
quicker starting as well, one shot of gas and usually the motor starts on the
first pull of the rope....
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=218887#218887
You can hit the primer with the engine running to enrichen the mixture in
the same way as activating the chokes.
> LS
Lucien:
I can't find my chokes. Don't think I have them on Bing carbs, two or four
stroke.
mkIII - Waiting on the snow, soon as New Orleans and St Francisville, LA,
finish with it. John B: Got your snow shovel handy?
John Hauck wrote:
> Lucien:
> stroke.
> john h
Er, you are kidding, right? ;).
Technically, our bings have enrichener circuits instead of the chokes of yore that
just had a butterfly that closed off the venturi.
I have to admit to not having had much trouble with the enricheners on the 2-stroke
bings. The original builder of my FSII used them and after I bought the plane
I never saw the need to eliminate it in favor of a primer. That engine had
the clutch, tho, so it was a lot easier to start anyway...
My 912uls fires up fairly quickly with the enricheners unless it's really cold.
The system works pretty good...
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=218909#218909
Hi Cristal,
I think i would fix the enrichener's what you called the choke. On my
firestar with the 503 i disabled the enrichener's and use a primer and it starts
and works fine. But some of the primers including the one I am using is of
poor construction and not up to general aviation standards, I had to replace my
primer as the old one was leaking a that meant to me it could be causing a
air leak which you do not want in the suction line on your gas line. So if I
was to do it again I would use the enrichener's (choke) and not the primer for
that reason and because engine temps are so critical on a 2 cly in case of
high temps one could use the enricher to lower the temps until the problem was
cured. So i would rebuild the enrichener's and make sure they were closing
correctly. just my 2 cents worth... jim SWAN
jim swan FS ll 503
michigan
**************Make your life easier with all your friends, email, and
favorite sites in one place. Try it now.
In cold weather the 503 required 4 hard pulls to light off with enrichener only.With
1 full shot of prime and enrichener,it fired and stayed running on the
first pull.Even in mild weather that was the case.On the Firestar,the primer was
located on the fuel pump mounting angle below the pump,which required only
a few inches of primer line but was obviously out of reach from the cockpit,but
the enrichener was right where it was in the plans, above and slightly behind
your left shoulder.There are some good reasons to keep all your options open
in my opinion.
? ? ? ? ? ?? Welcome? to Fla.Nielsons
-----Original Message-----
Sent: Thu, 11 Dec 2008 7:13 am
Subject: Kolb-List: Re: choke or primer
small gas engines. I have kept a lot of those engines running (momentarily)
using the choke, at least, I can determine if the problem is fuel starvation....
spot. You can also diagnose fuel mixture problems with it....You may be able to
do the same thing with the primer but I havnt tried it.....Just my thoughts on
the matter.
run to the carburettors, the plunger and the fuel pickup, but it eliminates the
LS
LS
Titan II SS
Jean, the FF has a top mounted engine so full power will push the
nose down.
Since the US has center thrust the stick position required will not
be the same.
I agree with John H., neutral stick will do the job until you become
more familiar.
BB
On 11, Dec 2008, at 9:14 AM, Jean PILLAUDIN wrote:
> Hi all,
> Ultrastar. I only have spend two hour of running the runway (grass)
> in little cross wind, and i have two take off and hopefully two
> landing too :)
> And Jack says:
> "I always take off with the stick centered and full back."
> forward (surely glider pilot habit), rapidly the tail go up and I
> control it moving the stick a little back (still up), maintain the
> axe with the foot and ailerons. The plane accelerate and take off,
> accelerate again in the air -I kepp the runway axe- and gently pull
> Jean
Ho yes sure I understand, the design is really not the same, Jack take care
about the nose over!
Thank's Robert and John for your incomes!
Jean
2008/12/11 robert bean
> Jean, the FF has a top mounted engine so full power will push the nose
> down.Since the US has center thrust the stick position required will not
> be the same.
> I agree with John H., neutral stick will do the job until you become more
> familiar.
> BB
> Hi all,
> And Jack says:
> Jean
> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
> href="http://forums.matronics.com">http://forums.matronics.com*
I do pretty much as John says, but I use a touch of forward stick to lift
the tail as the US doesn't have that high engine helping to pitch
forward. On grass I hold the nose a bit higher so it lifts off by itself
when it's ready.
-Dana
>1-Full Throttle
>the tail up. It will come up by itself when ready.
If it were truly the thought that counted, more women would be pregnant.
The mouse-size unit runs on AA
> cells... the rat unit feels a lot heavier and uses C cells... I assume
> from
> the weight that the capacitor in the rat unit has substantially more
> punch.
> You might consider trying a small damp door-mat at the entrance of
> yours...
> curious beauford
Bro Beau:
Went by Lowes on the way home from MGM. All they had was the little bitty
mouse zappers. Had they had the Rat Zappers, I would have gotten one or a
couple.
However, I did buy two big old rat traps at 1.97 ea. Gonna bait'em up with
a little peanut butter and see what I can catch.
I haven't had time to get back over to Gantt International Airport to see
how my glue traps have done. I also left them 4 trays of Decon to munch on
while I was gone. Too dark and too cold to set the traps tonight.
I might ought to tack a 1/16" cable to the rat traps in case I catch
something that is too big for them and decides to walk off with one on its
nose or paw.
I am gonna get'em.
Take care,
mkIII pilot and rat killer!!!
yore that just had a butterfly that closed off the venturi.
> 2-stroke bings. The original builder of my FSII used them and after I
> bought the plane I never saw the need to eliminate it in favor of a
> primer. That engine had the clutch, tho, so it was a lot easier to start
> anyway...
> cold. The system works pretty good...
> LS
Lucien:
Yes, they call them chokes because that is what they do.
Enricheners work on the same principle as the primer. There is an enricher
well and enricher jet located in the float bowl. Important to insure the
throttle is on the idle stop. Enricher full open. When the engine turns
over, it sucks in the charge of fuel stored in the enricher well. From
there on the engine is running off the enricher circuit through the enricher
jet.
If operated correctly, the enricher system on Bing carbs works well for two
and four stroke Rotax engines. I have operated the 912 series engines in
the Arctic at temps well below freezing with success. It also takes a hot
battery to turn the engine over to start.
Big problem with the two stroke Bings is the plunger style system they use
to control the enricher. After they get some age on them, they will leak,
causing an over rich condition without the operator realizing it. It is an
easy fix to remove and replace with new parts to correct the problem.
I prefer the enricher over primer. Primers introduce more plumbing,
carrying fuel, especially in the area of the cockpit.
Take care,
John Hauck wrote:
Lucien:
jet.
Take care,
mkIII[/quote]
A bit of trivia on the enrichener for parties..... If you need to replace a float
bowl, be sure to order the jet as well or save the old jet from the old bowl.
Just ordering the bowl and you get the bowl with no jet in it.
The enrichener circuit works WAY too well without the jet. You can probably guess
why I know this but I'm not going to admit anything anyway......
In any case, I've used both the primer system and the stock enrichener systems
for many years and both are very trouble free and work very well.
The only concern I've ever had with the primer is a leaking primer plunger. This
can result in extra gas getting into the carburettors just like when the rubber
stoppers fail on the 2-stroke carbs.
Which I use simply depends on which is easier to deal with on that particular plane.
On the 912 the enricheners are the only choice, I believe. Mine work perfectly
so far even in temps as low as 10F.......
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=218989#218989
In a message dated 12/11/2008 5:11:14 P.M. Central Standard Time,
jhauck(at)elmore.rr.com writes:
John,
If that doesn't do it, try getting some corn kernels, like they feed
deer. Take a 1/16 th inch drill bit and drill through about six kernels and
wire them together on the rat trap trigger. It is hard for them to get it off
without tripping the trap. Another option is to get some bird seed that has
sunflower seed in it. Put a small amount into a piece of plastic window
screen, making it into a little ball and wiring it onto the trap trigger. Another
choice is to wire a peanut in its shell ,to the trigger If necessary you
can modify the trigger to where it will trip easier. I have had rats lick all
the Peanut butter off and not get caught!
Ed Diebel FF 062
This discussion of the choke (enrichener) raises an interesting question.
As others have pointed out, the enrichener is sometimes used as a
diagnostic tool, to see if the engine's running lean (or correct it if it
is). However, the enrichener also supposedly is only effective near
idle... so will it have any significant effect at cruise or max throttle?
I have a plunger primer and it works great, but I've considered adding a
remote cable to the choke for inflight emergency or diagnostic use... now
I'm not so sure...
-Dana
We are sorry, you have reached an imaginary number.
Please rotate your phone ninety degrees and try again.
> -Dana
Dana:
The primary reason for starting the engine with the throttle closed is to
have maximum suction to pull the initial charge out of the enrichener well.
If the throttle is opened above idle, on start up, it doesn't do a good job
of scavenging the fuel out of the well.
At cruise rpm, if the enrichener is opened, there is more than enough
suction to pull the charge out of the well, then run richer from the extra
fuel being drawn from the enrichener jet.
Clear as mud, huh?
Thanks Ed D:
These Alabama rats are big and clumsey, I hope. They are field rats with t
eeth like bolt cutters.
I'll try peanut butter first. If they can get the peanut butter with out g
etting caught, I will try some of your suggestions. We will prevail.
eed deer. Take a 1/16 th inch drill bit and drill through about six kernels
and wire them together on the rat trap trigger. It is hard for them to get
it off without tripping the trap. Another option is to get some bird seed
that has sunflower seed in it. Put a small amount into a piece of plastic
window screen, making it into a little ball and wiring it onto the trap tr
igger. Another choice is to wire a peanut in its shell ,to the trigger If
necessary you can modify the trigger to where it will trip easier. I have
had rats lick all the Peanut butter off and not get caught!
Ed Diebel FF 062
>Clear as mud, huh?
Quite clear... I should have thought of that.
-Dana (brain dead tonight trying to fix a Vista printing problem...)
Please return stewardess to original upright position.
the enrichener works at any engine speed
Sent: Thu, 11 Dec 2008 6:17 pm
Subject: Re: Kolb-List: Re: choke or primer
This discussion of the choke (enrichener) raises an interesting question.?
idle... so will it have any significant effect at cruise or max throttle??
I'm not so sure...?
-Dana?
?We are sorry, you have reached an imaginary number.?
Please rotate your phone ninety degrees and try again.?
I may be misunderstanding what John H was saying but my 912 ul 80 hp does
not have enrichers in the carbs. They have full butterly chokes in them. I
know for sure because I looked in there. Butterfly type is way better than
the rubber based enricher valve. I used my enricher valve to save my butt
once. I had icing (I believe it was) and pulled the enricher lever and it
coffed and stumbled and lit it back up. It actually blew the ice off the
jet and away I went. Really sounded bad from the ground according to my
friend down there but I told him it sounded worse when a plane hits the
ground. I have had a recent chance to find out if the plunger style gas
unit works the same in an emergency on a challenger -- it does not keep the
engine running!!!!! Did a really great two point landing. Had to take the
nose wheel out to stop in time but thanks to the fragil nose wheel of a
challenger, it folded just as I thought it would and I stopped in plenty of
time. Limited damage. My Kolb would have stopped in plenty of time. Ted
Subject: | Re: 912 enrichers |
Ted
Ted:
Check to see if your choke butterfly vavles are connected to your throttle cables.
The Bings on the 912 series engines use a rotary valve system for enrichener, rather
than the plunger valve used by the two stroke Rotax. There are a couple
o ring seals in them that need to be checked periodically. They could possibly
leak if they go bad.
Subject: | Re: VG affect on stall |
Grant R,
I have about 140 VG's on my MK III Xtra, from the Center of the wing all the way
to the wingtips, the stall is very gentle, as gentle as any Cessna I have ever
flown. My stall speed was lowered 10 MPH, and the handling of the plane
improved immensely. I have a video posted of stalls, and flow flight with VG's
on my Kolb, You can see it at:
http://www.youtube.com/watch?v=EjI7-kBptrA
To see how the VG's help keep the Kolb from landing firmly at low landing speeds
watch this video:
http://www.youtube.com/watch?v=L508itf3oy8
I use VG's from www.landshorter.com. Making your own VG's will probably help, but they are CRITICAL. If you don't make them the right dimensions they wont work as well as they should. Its important to place the VG's in the EXACT place on the wing to be effective, and the PRECISE angle of the VG's in relation to the airstream is even more important if you want to get the full benefits of VG's.
Just imagine building a wing using the " That looks about right " method, and then
putting the wing of by guessing where it should be, and then wondering why
your plane does not fly well ??? Some people have done this with VG's, and
then reported to the list they are not very effective.... Hmmm, I wonder why
have !!!
http://forums.matronics.com/viewtopic.php?p=219074#219074
the stall is very gentle, as gentle as any Cessna I have ever flown.
> Mike
Mike:
Most all Kolbs, without VGs, I have flown, fly much better than any Cessna I
have flown, which is limited to a couple of old tired 152's, it took to get
my Private Ticket in 1990.
In fact, based on my limited experience, Cessnas have a rather sharp stall
compared to the Kolbs' mushie stall characteristics.
Cessnas also lose much more altitude than Kolbs in a spin, and much quicker.
Never spun a Kolb with VGs, and have a couple flights in one FSII equipped
with VGs.
I am neither pro or con VG. However, if I start wearing a flight helmet, I
will mimic Brother Beauford's helmet, complete with appropriate VGs. I may
even go a step further and put them on top and bottom.
HShack(at)aol.com wrote:
> When I designed & installed my VG's some 7 or 8 yrs. ago, I put 7 on each wing
[these were the aluminum flashing kind]. My stall dropped from 41 to 36.
The stall was still very gentle; in fact it didn't really want to stall.
> I added 13 more per wing. Stall dropped another 4 mph, but when she stalled
it was rather violent & scary. I hated the way it felt, so went back to the
original 7 per wing. Happy again.
If you put VG's on only part of the wing, you only get part of the benefit. Being
that you guessed where your VG's should go, and that you guessed on the design
of your VG's, its no wonder you ended up with some bad characteristics and
scared yourself. If you put anything on the wrong part of a wing, including
VG's, they can go from being a benefit to being dangerous very quickly. I
would not want to be the test pilot on an airplane with poorly place VG's [Shocked]
Here is a video of some guys that put VG's on their airplane the right way, using
precise measurements to get them in the correct place on the wing, and getting
the exact angles of the VG's to the airstream using templates. These guys
also did a lot of work so the rest of us can see the effect VG's have on the
airflow on the wing.
http://www.youtube.com/watch?v=YQO7SoULc3U&feature=related
The research has already been done over many years. I prefer to use the design
and placement that a lot of aeronautical engineers have developed over the years
than try to guess on VG placement.
have !!!
http://forums.matronics.com/viewtopic.php?p=219080#219080
> design and placement that a lot of aeronautical engineers have developed
> over the years than try to guess on VG placement.
> Mike
Mike:
Looks like we are getting a lot of VG manufacturers out there all over the
world.
Do you believe each one of these VG manufacturers has done the research and
testing to provide precise guidance on where to place their VGs on your
Kolb's wings?
mkIII-Slick wing!
>world.
>and testing to provide precise guidance on where to place their VGs on
>your Kolb's wings?
Well, as long as the _first_ manufacturer did the R&D... everybody else is
probably just copying them...
-Dana (still VG-less in CT)
If we wish to "restore" respect for the law, a good start would be to
pass only laws that people will respect.
is
Dana:
Do you think any of those vg manufacturers ever went so far as do testing on
a Kolb wing?
How do we know what precise is, when placing those little buggers on our
wings and under our tails?
I bet if you get right down to the real nitty gritty, you will discover
there is very, very little serious flight or simulated flight testing on any
UL or experiemental homebuilt.
mkIII-Who did his own testing, good and bad.
I doubt that any manufacturer did testing on the Kolb wing, but they have on many
other wings. For the type of airplanes we fly, and the speeds we fly at, VG
placement on wings is pretty much universal. In the video below, you see these
guys carefully placing VG's right where they should be, at about 10 % of the
chord of the wing behind the leading edge, and equally spaced at about 1 %
the span of the wing. On my Kolb, I placed my VG's at slightly less than 1 %
of the span because it is desirable to put each pair of VG's in the rib valleys,
all VG's evenly spaced, 2.5 inches spacing between all VG's on my Kolb. Even
more important than the spacing is that VG's be EXACTLY 15 degrees "Nose In
" to the relative wind, that is where they create the most efficient "tornado"
above the wing without adding excessive drag. It is necessary to use a template
to get the correct angle on VG's. The video shows how its done :)
have !!!
http://forums.matronics.com/viewtopic.php?p=219134#219134
on many other wings.
For the type of airplanes we fly, and the speeds we fly at, VG placement on
wings is pretty much universal. In the video below, you see these guys
% of the span because it is desirable to put each pair of VG's in the rib
valleys, all VG's evenly spaced, 2.5 inches spacing between all VG's on my
Kolb. Even more important than the spacing is that VG's be EXACTLY 15
degrees "Nose In " to the relative wind, that is where they create the most
efficient "tornado" above the wing without adding excessive drag. It is
necessary to use a template to get the correct angle on VG's. The video
> Mike
> could have !!!
Sorry, Gang:
Looks like I fired a blank.
Was thinking about replying and changed my mind.
----- Original Message -----
Sent: Friday, December 12, 2008 6:03 PM
Subject: Re: Kolb-List: Re: VG affect on stall
> > have
Subject: | Re: xtra wingtip mods |
> We've finished modifying our wing to accept fiberglass wingtips.
> Scott
Scott/Paul:
Looks good.
I believe you told me what the length of the wing panel was while at the
Homecoming, but I forgot. ;-)
mkIII 31F and cold at hauck's holler.
Hi Jean,
I have not flown a Firefly but to take off `stick fully back ` is
dangerous in any plane
I dont know who Jack is but I am surprised that he is alive.
If you take off as he suggests you will get airborne as soon as you hit
flying speed. THAT IS NOT FAST ENOUGH. A slight drop in the wind or
power from your engine and you will stall., just off the ground and you
will at best bump heavily or at worst you will crash. You will also be
stuck in ground effect until you build up some speed.
It CAN be done that way but only when you have some experience.
I never look at the ASI on takeoff. You do not fly small aircraft by the
numbers with a co pilot calling V1, V2. Advance the throttle smoothly
with the stick forward, the tail will come up in a few yards and you can
ease off on the stick to balance the plane on its wheels. Smoothly push
the throttle to full power. The plane will tell you when she wants to
fly. Hold it like that for a couple of seconds as the speed builds and
then ease the stick back and you will climb away with no trouble.
You have gliding experience you will know that you do not pull into a
steep climb until you have some height. Cables break and engines pack
up.
Good luck
Pat
John,
The wingspan is the same as with the stock wingtip bow. Total wingspan including
the glass tip should be within a few inches of the yellow and white factory
Xtra.
Scott
31f? that's a heat wave! It's 14f here.
[/quote]
Scott/Paul:
Looks good.
mkIII 31F and cold at hauck's holler.[/quote]
http://forums.matronics.com/viewtopic.php?p=219183#219183
> discover there is very, very little serious flight or simulated
> flight testing on any UL or experiemental homebuilt.
John,
I bet if you get right down to the nitty gritty you will discover
that most experimental planes are never actually involved in any real
experimental testing. "Experimental aircraft " is in that case a
misnomer.
The actual testing in most cases is not a testing of the plane, but
most often the real test is a test that reveals whether a person
is, or is not, a real pilot.
How many Kolb "planes" ever proved to be unsatisfactory as a flying
experiment?
How many Kolb "pilots" ever proved to be unsatisfactory as a flying
experiment?
In most cases it is the pilot that is ,,,,,,,,,,, "EXPERIMENTAL"
It is always true in my case anyways ,,,,,,, because the EXPERIENCE is
always mine.
I am always "experimental" ,,,,,,,,,,,, every once in a while my
plane is also.
From: | "Jean PILLAUDIN" <jean.pillaudin(at)gmail.com> |
Yes you're right, but I think Jack just want to take care of nose over, and
as an experienced Pilot he let his firefly accelerate before beginning to
climb.
Thank you for your income.
Jean
2008/12/13 pj.ladd
> Hi Jean,
> flying speed. THAT IS NOT FAST ENOUGH. A slight drop in the wind or power
> from your engine and you will stall., just off the ground and you will at
> best bump heavily or at worst you will crash. You will also be stuck in
> numbers with a co pilot calling V1, V2. Advance the throttle smoothly with
> the stick forward, the tail will come up in a few yards and you can ease off
> on the stick to balance the plane on its wheels. Smoothly push the throttle
> to full power. The plane will tell you when she wants to fly. Hold it like
> that for a couple of seconds as the speed builds and then ease the stick
> steep climb until you have some height. Cables break and engines pack up.
> Good luck
> Pat
Scott:
How and where are you all going to attach and rig your aileron counter
balance weights?
> always mine.
> I am always "experimental" ,,,,,,,,,,,, every once in a while my plane
> is also.
Gene Z:
Good point.
True in my case.
Was and still is a big learning curve flying these little airplanes.
Up until 1990, I flew the single place Kolbs. Never had any professional
instruction. Never had a check ride. Never had another pilot ride along to
see if what I was doing was right or wrong.
In the Army it was a constant series of check rides and standardization. I
enjoy the freedom of my sport, but it can lead to some serious problems if I
let it. Sometimes I don't know if I am letting it or not.
This morning I am going to the airstrip to see if I caught anything. Put
out two big rat traps with peanut butter. Used safety wire to secure them
in place, in case I get a really big one that wants to walk off with my
traps.
I notices yesterday the four trays of Decon were cleaned out. I put them
out and did not have a chance to check them for 48 hours.
The glue traps had caught some pretty big grass hoppers, but that's all.
Brother Jim has volunteered to sew me up some more seat belts and shoulder
harnesses.
I discovered the DRE 6000 ANR headsets are coming back. Aircraft Spruce has
them for 359.00. Wiring in my old set got chewed up, plus they are getting
on in age and hours. I ordered some new ones last night, but they were back
ordered. I like the DRE6000 because I can plug them into the aircraft 12VDC
system and not have to worry about batteries, just rats. ;-)
Was 24F this morning. Must have been the nearness of the full moon last
night.
mkIII - Putting another log on the fire.
> Every plane/kolb is a little different. I never really thought
> about how the
take off process works in my mongrelized MkIII but here is what I can
put together from memory:
1. taxi to the end where the wind is hitting me in the face
2 wait until the water temp gets near a boiling
3. check all two gages
4. see if those flappy things are working on the wings.
5. advance the throttle fully, the mighty geo wheezes to full power
6. lumber at a slightly increasing rate over the undulating terrain
7. start bouncing from hummock to hummock at increasingly large
increments.
8 doesn't much matter where the stick is, can't remember anyway.
9. some kinda magic makes it leave the ground. -thank goodness, I was
was getting tired of all that bounding.
10. free as a bird. Hope it keeps running.
I won't even go to the landing process, much too frightening for me
to review.
BB never had a lesson in a Kolb either, and it shows.
From: | "Richard Girard" <aslsa.rng(at)gmail.com> |
Ted, I'm going to assume you have the stock Bing 64's on your 912 and you
haven't hung a Holley double pumper on it.That butterfly you saw when you
looked in the carb throat is NOT a choke, it's the throttle. In the 64 this
sets the vacuum level in the carb which pulls the piston up and sets the
mixture. Unlike the two stroke Bings, the throttle cable is NOT connected to
the piston. In the 64 the piston is suspended from a diaphragm inside that
big cover on top of the carb.
What may be confusing you is that the linkage on the throttle cable should
be set up so that the throttle butterfly goes full open should the cable
fail. The throttle cable pulls the butterfly closed, not open.
NOTE: this could be changed as the 64's on my HKS do not have this linkage
setup. On the HKS the throttle is closed by the spring, just like it would
be on a BMW motorcycle, but a 912 should have the aviation linkage that
fails open.
Rick
> does
> I
> than
> Ted
> Ted:
> cables.
> enrichener, rather than the plunger valve used by the two stroke Rotax.
> There are a couple o ring seals in them that need to be checked
> periodically. They could possibly leak if they go bad.
> john h
> mkIII
If you take off as he suggests you will get airborne as soon as you hit flying
speed. THAT IS NOT FAST ENOUGH. A slight drop in the wind or power from your
engine and you will stall., just off the ground and you will at best bump heavily
or at worst you will crash. You will also be stuck in ground effect until
Pat,
I am the "Jack" and I referred Jean to my how to transition to a FireFly page.
I have copied out My Standard Take-Off
"I always take off with the stick centered and full back. This approach has
several advantages. In cross winds it keeps the FireFly stuck to the runway
until lift-off and it makes it easier to keep the FireFly straight down the
runway. It lets you get off soft tall grass fields with out a nose over, and
it can get you off the ground as quickly as possible. A nose over experience
on a soft tall grass runway and water in tall grass experience brought about
always using the stick back against the stop.
The throttle is teased forward until the FireFly is bouncing. Throttle
teasing reduces the effect of P-factor and helps you to keep up with rudder.
Each time the FireFly bounces the throttle is jigged open a little more
lengthening the next bounce until the FireFly flies off into ground effect.
During the bouncing phase and if the tail comes up on its own when taking
off from grass, you are on your way to a nose over. Jig the throttle back to
get the tail to come back down or abort and try again. If there is a cross
wind, one lowers the up wind wing and adds rudder to keep the FireFly
straight with the runway. As the FireFly rises up in ground effect, back
stick pressure is released and the throttle is advanced more aggressively.
When the indicated airspeed reaches 55 mph and the FireFly continues to
accelerate, the stick is slowly pulled back to maintain 55 mphi. If at any
time during the climb out the engine rpm droops or you think it is drooping,
push the stick forward to maintain or increase indicated air speed."
At the time I wrote the avove, the FireFly was powered by a Rotax 447, and
riding on the original 4 inch Azusa wheels. By chocking the wheels, I found
that the tail wheel would leave the ground at 4,000 rpm with the stick in
the full back position. At 4,300 rpm the FireFly was over balanced on the
main gear and would have fallen on its nose if I had not looped a safety
rope over the tail wheel spring. I added a gap seal between the horizontal
stabilizer and elevator, but found no improvement.
After mounting the Victor 1+ and VG's on the bottom of the horizontal
stabilizer and lowering the thrust line there is less of a nose over problem
upon throttle opening. I have not repeated the wheel chocked test. I have
added it to my things to do list.
My first concern to be able to safely nurse the FireFly off wet, soft, tall
grass strips with out a nose over. And so I continuously practice. Now
that I have infinite choice of flaperon settings, I usually set the
flaperons at five degrees down. The reason to tease the throttle is to
ensure that the FireFly can only lift in to ground effect. At this point,
stick pressure is released and the ground effect flight is stabilized and
then the throttle is advanced and climb out initiated. With this procedure,
if things are not going well, all one has to do is back off the throttle and
ease the FireFly down few feet.
The field that am flying out of has only one runway, and it is very rare
that the wind matches the runway direction. If the wind is not gusting over
20 mph, I like to fly. This makes for interesting cross wind takeoff and
landing with hangars and tall trees within less that 100 yards of the runway.
The advantage of using ground effect is that it moderates the cross wind
effect. If one wing gets low, ground effect pressure helps to push it back
up. Upon advance of the throttle, the FireFly accelerates rapidly in ground
effect to a speed that gives very good control surface response. From this
point one can initiate climb out with out having to worry about PF, heading,
or stall.
I find that I do better with above approach, in that it reduces the pilot
load and minimizes multi tasking. It allows one to leave the ground at very
low speed with virtually no pf effect. Next, slow speed flight is
stabilized relative to the runway which is similar a glider at the beginning
of an aircraft tow. This is followed by power addition to bring the ias up
to best rate of climb speed. Then climb out is initiated up through the
unstable air with very effective controls.
It works for me.
Jack B. Hart FF004
Winchester, IN
> Hi Jean,
> I have not flown a Firefly but to take off `stick fully back ` is dangerous
in any plane
your engine and you will stall., just off the ground and you will at best bump
heavily or at worst you will crash. You will also be stuck in ground effect
Er, I don't understand how this is dangerous - this is just standard soft-field
takeoff technique, at least according to my training.
I did this literally all the time in my FSII when I felt like doing a soft-field
takeoff (unfortunately I never flew it off grass, but soft-fields were fun anyway):
- Stick full back
- slowly advance throttle
- keep tailwheel glued to the ground
- lift off in ground effect
- release back pressure as needed to remain in ground effect
- when safe flying speed is acheived go fly.
Works in all the other planes I've flown as well including my titan....
A standard takeoff in my FSII tho was the way John described, with neutral stick
instead letting the tail come up...
PS: I'm thinking now about building a firefly, so I may be back in the Kolb saddle
again after a while.
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=219221#219221
In a message dated 12/13/2008 5:28:56 A.M. Eastern Standard Time,
pj.ladd(at)btinternet.com writes:
in any plane
Hi Pat,
We're talking about a Kolb here, specifically a Firefly. I fly a Kolb
FireStar, which is pretty much the same model, but with slightly more wing area.
I always take off with the stick fully back, because otherwise you risk
pushing the nose over onto the ground. I add throttle slowly at first, but as
soon as it is moving, I go to full power. It accelerates very quickly and I'm
off the ground in a matter of seconds. Then I relieve the back pressure just
enough to maintain a normal climb. I don't know about other Kolb models,
but the Firefly and FireStar accelerate so quickly that ground effect is almost
meaningless, they practically jump off the ground and climb like a bat out
of &%#$@.
Merry Christmas Everyone,
Bill Varnes
Original Kolb FireStar 500 hrs +
Audubon NJ
John,
misnomer.
experiment?
experiment?
always mine.
plane is also.
_____|_____
*=======================R=======================*
\___/
Eugene Zimmerman
Oooops,
Looks like I just posted a duplicate.
Sorry.
Gene
> John,
> real experimental testing. "Experimental aircraft " is in that case
> a misnomer.
> flying experiment?
> experiment?
> is always mine.
> plane is also.
> _____|_____
> \___/
> Eugene Zimmerman
Subject: | Re: Trying a new prop |
Richard Gerard wrote:
>>>With Rotax engines that means 300 to 500 RPM less than full HP
RPM.<<<
Richard,
I got the new prop on today, but it was just too windy to fly. I did a
static run up test with a thrust gauge, and was getting 255 lbs. with
the new Culver prop. With the IVO, it was making 195 lbs. The with the
new prop, the engine RPM would top out at 3300 rpm. But, with the IVO,
the engine would hit 3600 rpm on a static thrust test. Since I didn't
get to fly, I have nothing to compare yet regarding performance.
I am at a new airport now, and it's a good airport to test stuff at
because it has 2800 ft. of grass runway. The first good calm evening
this week I hope to take the plane up and see what the improvements are,
if any. At least the new prop is producing more thrust and I hope that
translates into better climb performance. I'm leary of any speculation
on my part just because of the improved thrust #'s. I guess it is better
than finding out it has less thrust than the IVO though. I'll post the
results after I go fly it.
Jimmy Young
Houston TX
Jimmy,
With those numbers it sounds like you should experience a significant
performance improvement.
Please keep us posted.
Gene
> RPM.<<<
> Richard,
> a static run up test with a thrust gauge, and was getting 255 lbs.
> with the new Culver prop. With the IVO, it was making 195 lbs. The
> with the new prop, the engine RPM would top out at 3300 rpm. But,
> with the IVO, the engine would hit 3600 rpm on a static thrust test.
> Since I didn't get to fly, I have nothing to compare yet regarding
> performance.
> are, if any. At least the new prop is producing more thrust and I
> hope that translates into better climb performance. I'm leary of any
> speculation on my part just because of the improved thrust #'s. I
> guess it is better than finding out it has less thrust than the IVO
> though. I'll post the results after I go fly it.
> Jimmy Young
> Houston TX
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Hi,
I managed to get every thing squared away today and fired up the HKS.
I pumped up the oil pressure yesterday by removing sparkplugs and
cranking it until the pressure came up. Then I tried to start it and
found that my battery would not turn it over. I brought up the quad and
used jumper cables and that wasn't enough either. I spent the evening
trying to figure what was up. This morning I called Jerry Olenik to see
what he could tell me.
I put the prop on it and brought up the truck and hooked it to that,
and it fired, but was running crappy and backfiring. Called Jerry again
and we went through the electrical hook up. I went back and ran a ground
wire from the battery to the starter housing to make sure that it had a
good ground. (apparently extremely important) I had run a ground wire
from the starter housing to the ground block. Then he assured me that
not being able to turn the prop over by hand was normal. (takes two and
the power required is extreme) After that I got it running, actually
starts pretty easy if you have the proper power to turn it over. Then it
was backfiring. Another call to Jerry, found that I had hooked up the
spark plug wires wrong. The wires in each module goes to different
cylinders. DUH! (the only problem with the way the way I had it hooked
up is that when you turn off one mag the other cylinder didn't have any
power to it) Then I found that I wasn't showing oil pressure. Another
call to Jerry, he suggested things to look at. I asked how tight the
plastic fittings on the oil hoses could be tightened. Turns out they are
painted alum and I didn't have them tight enough. Another DUH! That
solved my pressure problem, but it was still running rough and
backfiring. Jerry suggested that it might be denotation due to me using
89 octane. Off Karen and I went to Jordan Valley to buy premium, over
icy roads. She is getting to be one of those old ladies like on the
commercial "You are driving like a bat out of Hell"! :-) When we got
back I fired it up again, no back firing, runs pretty smooth. The best
is that it is half the noise of a 503. I plan to submit to Jerry a HKS
for dummies type book, since I am quite sure that I made every possible
mistake (misteak) that was possible.
Larry C
mea culpa, mea culpa. I guess I had a brain fart. dont know what I was
thinking when I posted that. I know the butterfly is for the throttle, yet
I stated otherwise. I know and understand how the carb works -- is a bitch
to set up from 582 linkage. I am old and getting older I guess. maybe I
should go back to a razor scooter. my data bank is working good, my
rememberance is wrong. I still like the enricher circuit on the 447 and 503
better than a plunger style on any kolb. you can troubleshoot it better.
ted cowan, idiot, alabama, slingshot.
We're talking about a Kolb here, specifically a Firefly. >>
Hi Bill,
I wouldn`t like to try it on any plane but if it works and keeps on
working safely I guess thats good enough.
I fly the Extra and have her up to full throttle more or less as soon as
the tail rises. Never had a problem with the high thrust line except
when I dropped a wheel in a rut while taxying and stood her on her nose
and wiped the pitot off.
The Challenger was the same. Obviously not on the ground because of the
nosewheel but if you went to full power on a go-round it was something
to watch for. No great trouble, just be aware.
Still don`t like the idea of being nose high at marginal flying speed
though.
How does JH do it? Comments John?
Cheers
Pat
Remember, an UltraStar is unique among Kolbs because of the high tailboom,
low engine arrangement. The tailwheel has to be about 3- 4 feet off the
ground to level the wings for flight configuration.
To takeoff, open the throttle with all controls centered. Adjust for P
factor and crosswind as needed to keep the machine going straight as speed
builds. When you feel the tail get responsive, a slight forward push on the
stick will raise the tail to flight position. Center stick again to build
speed for takeoff. When you achieve that speed, slight back on the stick and
you
are airborne.
Taking off with the tail still on the ground can be done, but you're
'mushing' along, flirting with a stall.
Landing the UltraStar is sort of opposite takeoff......... meaning, fly
the main wheels onto the ground, and as your speed reduces, let the tail
settle down. I tried 3 point landings, but putting the tail that low while flying
slow results in a stall and a rough and bouncing landing. Only after
putting Vortex Generators on the wings, could I do a 3 point landing.
In a message dated 12/13/2008 4:28:56 A.M. Central Standard Time,
Hi Jean,
in any plane
flying speed. THAT IS NOT FAST ENOUGH. A slight drop in the wind or power from
numbers with a co pilot calling V1, V2. Advance the throttle smoothly with the
stick forward, the tail will come up in a few yards and you can ease off on
the stick to balance the plane on its wheels. Smoothly push the throttle to
full power. The plane will tell you when she wants to fly. Hold it like that for
a couple of seconds as the speed builds and then ease the stick back and you
You have gliding experience you will know that you do not pull into a steep
Good luck
Pat
(http://www.matronics.com/contribution)
(http://www.matronics.com/Navigator?Kolb-List)
Subject: | Kolb high thrust line. |
Gretings fellow flyers.
I have been enjoying the reading of the posts, mostly I sit on the sidelines and
look through the window of the postings.
Reading the topics I am stirred up to comment on one of my fears, that is giving
advice on flying technique and in particular the latest one on take off procedures.
I suppose that my recent poor performance has brought me to the position of relearning
some things, which has been a good thing, and in particular the review
of reading all the postings has been a value.
I recently changed my plane from a Poorboy to an Ultrastar and the takeoff power
is quite different so I got into a bit of a scare several times because my
bad habit of holding the stick back and taking off with lots of thrust available.
A big engine like a 503 with a 70 prop made a lazy pilot out of me and I
frequently violated the rules of common sense because with lots of power you
can transition from not flying speed to flying with a steep takeoff angle and
climb out and hardly realize you are doing it. WWEEEEEEEEE, lots of fun but
potentially dumb! This has the potential of putting me in the position of no
thrust with steep angle of attack (and quickly no airspeed), if this happens
close to the ground (under 100 ft) it may do more than just bang up my planeouch
to me
When I started back flying an Ultrastar (this is my second Ultrastar) I quickly
saw that my tactics were wrong. Now I was flying a 50 propeller with UL202
35hp, in the air this is adequate power and is a good flying plane but is marginal
on a 700ft runway, I dont like being marginal and it scares me. A good
portion of the problem lies in my poor takeoff procedure as holding the stick
back on this plane actually slowed down the takeoff, increased the takeoff roll
and the plane staggered into the air. I needed additional lesson from an instructor
and review to get straightened out. This turned out to be quite nice
flying plane, the engine ran flawlessly but the marginal performance (50 inch
warp drive with adj. Experiments showed it was pitched very close to optimum)
still it left me discontent for this runway has obstructions and I have sold
the airplane and am now building a 1993 Firestar kit that was not finished.
This is my second firestar (1st one 1991 rotax 377) and I had a mark III (1997
rotax 503).
The point of my comment is that I seem to acquire patterns or habits that meet
the experience necessities of the plane I am currently flying and in so doing
my judgment and comments to others becomes skewed, that means I prefer to be
careful when giving advice as I have lost the objectivity of view required for
folks who have an other frame of reference from their last flying experience.
The safe way out of this for me is to recommend them to an instructor; never-the-less
these pages of comments are great and with that in mind allow my summarization
of what I remembered differences in Kolbs.
Ultrastar procedures. 1000 to 1200 ft. runway is adequate (unobstructed preferred),
throttle up, stick forward or neutral to pick up the tail, take off roll
is shortest with the wing angle of attack at close to zero until flying speed
and gentle ease back on stick to lift off in ground effect or close to that
height (ground effect generally one wingspan range of ground height) and let speed
build a bit before entering climb out angle and rate. A great flying airplane,
no handling surprised and it generally just does what you tell it to, very
nice landing approach control. 35hp. UL202 has limited power as compared
to some of the other Kolbs but is well suited to the plane, if a landing go around
is required there is the need to recognize it early and add power soon enough
if obstructions are part of the equation. My take offs are 500ft range
for the best short ones and 700ft isnt long enough if Im doing it wrong. This
is my experience with the two Ultrastars I have had, others may be better
pilots or have other variables of weight and power that give different results.
Firestar and Mark III. My experiences as I remember them were similar with these
models as far as takeoff and landing are the subject, generally they are the
same configuration. I have flown (owned) the short cab Firestar, flown a borrowed
Firestar 2 long cab, and owned the Mark III. I have not flown a Firefly
that has the most in common with the old short cab Firestar, the Firefly has
a 22ft. wing and a flaperon control mixer. I will use the Firestar in general
as a descriptive airplane subject as the high mounted engine configuration
is present in all of these models.
The Firestars need a modified procedure and awareness from many other airplanes,
particular to Firestars is there high thrust line. Tractor airplanes and
pushers with the prop thrust line even or below the line of the wing have much
less of the tendencys that Kolb Firestars suffer from. My opinion is that they
SUFFER from this feature as well as have the benefits of getting the prop
high enough to allow efficient prop length (and the additional benefit of excellent
aircraft fold up ability with the engine and prop out of the way of the
folded wings), this is a reasonable trade off as Kolb sales have demonstrated.
The down side of this high thrust line is substantial and should not be (in good
flying practice) safely ignored.
The 1st issue of high thrust line is adding power at takeoff, with the stick
at neutral a quick throttle to full will put the Firestar on its nose often with
damage, this is not a tendency present in most other aircraft. In order to
compensate for this resultant action I hold the stick full back at early power
addition and early roll for takeoff, but then I need to more neutral the stick
as the tail becomes effective and in control, if the stick is left full back
you encourage early takeoff and hard climb right into early flight, this is
potentially dangerous and unnecessary. A safe and normal takeoff does not include
a risky maneuver like early hard climb, this is special procedure for short
field obstructed takeoff and good pilot judgment will try to avoid that.
It takes a bit of practicing combinations of adding power more slowly and stick
position for reasonable lift off speed and speed addition at low angle of attack
before climb out. I notice that practice is what I need to keep from bobbing
down the runway trying to balance that high thrust line and input stick
control power issues, in actual application I tend to get lazy and just blast
off with the stick too far back and allow the engine to haul my dumb butt up.
The 2nd issue of high thrust line is quick throttle changes in flight will result
in nose up with quick decrease power and nose down tendency when quickly
adding power. The tendency is not serious in normal flight with altitude but
certainly can be an issue during the landing cycle. The first answer here is
not get caught in a situation when large power setting changes are quickly required,
the faster you make those throttle changes the more pronounced the result.
In particular note that on approach if you find out a bit late that you
need to adjust the glide path angle a throttle adjustment will complicate the
issue and without experience (practice) you are in for a surprise. I will stick
my neck out here and say that the most common BAD landing incidents here
is an approach that is judged for correction late in the cycle and a quick power
addition will drive the aircraft right into the ground, this has damaged lots
of Kolbs.
How does that ring with you guys.
Well that was a mouthful anyway, hope it was enjoyable if not viewed as accurate.
Jim
http://forums.matronics.com/viewtopic.php?p=219324#219324
Subject: | Fw: UL: Chuck Slusasczyk - CGS Hawk |
Hi Kolbers,
This was sent out to the UL list by Steve Bensinger, and knowing that many of you
may know Chuck, thought I'd pass it on.
Arty Trost
Sandy, Oregon
>Chuck's wife, Pixie, asked me to let you all know that Chuck had a
>stroke a little over a week ago. After some time in ICU he's now in
>the rehab center and doing very very well. He's up and around and
>almost back to his old self. No word yet on when he'll be going home
>- he could be in rehab for a while.
>Cards can be sent to Chuck at:
>Parma Community General Hospital
>Rehab Center, Room 453
>7007 Powers Blvd.
>Parma, OH 44129
>The shop is open for business as usual, with Chuck Capaldi and Nick
>holding down the fort. Pixie is now checking Chuck's email (their
>computer was down for the last week, too), and will forward your
>questions to the guys in the shop.
>Please keep the ol' chicken thief in your thoughts this holiday
>season.
- Steve Bensinger
The NASA research on VGs which I read over 30 years ago concluded the best
spanwise spacing occurred when the vortices generated just met at the
training edge of the wing. The vortices spread from each generator at an
included angle of 15 degrees. Thus, the farther forward the generators, the
farther apart they can be and still be fully effective.
Don't remember the details about chordwise location but they ended up at
10% - 15% of local chord.
Whenever I get my FireStar flying I'll use these numbers as a starting point
for my VG experimenting.
Tom Kuffel
Whitefish, MT
Subject: | Re: Fw: UL: Chuck Slusasczyk - CGS Hawk |
In a message dated 12/14/2008 4:46:08 P.M. Eastern Standard Time,
thewanderingwench(at)yahoo.com writes:
Hi Kolbers,
of you may know Chuck, thought I'd pass it on.
Arty Trost
Sandy, Oregon
>7007 Powers Blvd.
>Parma, OH 44129
>season.
- Steve Bensinger
Thank you for the heads up on "Chuck", Arty....Although he was just an
acquaintance of mine I always felt that I knew him more than I did as he was so
homey and open in the way he carries himself. Besides, his hawk was the main
contender of the Firestar that I ultimately purchased from Homer, back in "90
as Chuck's business was only a few miles from where I lived in Warren, Ohio.
I will send a card and wish him well.
George Randolph
Firestar driver in The Villages, Fl
Kolb people,
I have an expertise question for someone who knows their stuff about applying
Poly Tone paint.
For me, at the present time, it will be difficult to spray my Poly Tone paint.
Too lengthy to go into, but it just would. I CAN spray, but I'd have to do it
outside.
My question is: Is it possible to brush on Poly Tone paint (with a very high
quality brush), and it turn out with very good results.
Is there anyone out there that brushed on their paint, and were pleased with
the results? Or, should I just forget that idea, and plan on spraying it on?
Mike Welch
MkIII
Send e-mail faster without improving your typing skills.
http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed_122008
Subject: | Re: Poly Tone paint |
Mike, I doubt you would be happy with the result. I would buy a HVLP
system. Combined with a couple of
portable exhaust fans and a good mask you should be alright.
These systems are now available at a reasonable price from sources
like harbor freight.
If I were not near the end of my project career I would get one myself.
BB
On 14, Dec 2008, at 6:45 PM, Mike Welch wrote:
> Kolb people,
> about applying
> Poly Tone paint.
> Poly Tone paint.
> have to do it outside.
> a very high
> pleased with
> spraying it on?
> Mike Welch
> MkIII
Patrick:
I fly the airplane.
My MKIII, landing gear configuration and location being different from stan
dard Kolb configuration, doesn't suffer from the dreaded nose over. It als
o has a little aft cg, so it sort of flies off by itself.
When I fly other Kolbs, I usually fly them the same way. I tell the airpla
ne what I want it to do and do it.
I have no standard procedure for takeoffs. Conditions are constantly chang
ing. This dictates changes in how I fly.
Cheers
Pat
Hi gang,
Here is my 2 cents worth.....I fly a firestar ll 503, but I was taught
to fly in J-3 cub and my instructors had me hold the stick full back when
going to full power, the plane would start rolling forward, then going forward
with the stick until the tail came up, then holding the stick so that the tail
was up in a wheel landing attitude until flying speed, than back on the
stick and climb at speed correct for climb out to altitude. I do the same in
the firestar and it works just fine for me...I sure like the firestar and it
sure has good traits on takeoff and landing...well just my 2 cents worth....a
bit of snow on ground up here in michigan and sort of cold...so have not been
flying....Jim Swan
jim swan FS ll 503
michigan
Hi Larry,
keep us informed of the HKS ....it should be a excellent engine for the
firestar.....jim swan
jim swan FS ll 503
michigan
> Not a chance Mike...The poly tone would melt the poly spray -poly
> brush and make a mess...Herb
> its the acetone and mek....
Yup!! I think you pegged it, Herb. I hadn't considered that. That's
all I needed to know. Thanks
Mike Welch
Send e-mail anywhere. No map, no compass.
http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anywhere_122008
> Mike Welch
I've seen a few cars and tractors painted with a brush, but would not be too
proud of any of them.
john h - None of these were painted with a brush. ;-)
mkIII - 1993 OSH Grand Champion Light Plane
1993 Sun and Fun Reserve Grand Champion Light Plane
Firestar - 1989 OSH Grand Champion Ultralight
1988 Sun and Fun Grand Champion Ultralight
John H.,
I was curious if it was possible to do a nice paint job with a brush.
Evidently not! I won't do anything but a professional looking job!!
However, my friend Myron, (you met him last spring at Monument Valley)
"TOLD" me he painted his entire plane with a brush Using Poly Tone Paint.
And it looks DAMN nice!!! But, the fact is, I don't think he was entirely
truthful. The airport regulations forbid ANY spraying of paint products.
He may have told me he used a brush, so that I would think he was obeying
the law in his hangar.
My curiosity was if this scenario was possible. I would say "not likely."
I am not in contact with him any longer.
Mike Welch
PS. I bought a car once that was painted with a brush, or a roller. 1961 Falcon.
They used kitchen latex paint. It had about 30 lbs.of Bondo to cover the rust,
spread by hand. It was a junker while I lived in Okinawa for a couple years 1971-1973.
Ran like a champ, tho!!
this is just standard soft-field takeoff technique,>>
Hi Lucien,
I would quite agree, but that is a technique to deal with a particular
situation. If it is imperative that you get off the ground as quickly as
possible then you are willing to trade something else, in this case safety.
I once had to put the Challenger down in a small, very rough field when the
teeth came off the drive belt when I was on the approach.Next morning I
changed the belt, pushed the plane back as far as I could into the hedge,
and went for it. I bounced into the air off the first of a series of
hummocks and arrived with a crunch that rattled my fillings on the next one.
I just grazed the third hummock with a heavy jolt and was airborne. I
wouldn`t describe it as flying. I managed to struggle high enough to get
over a 4 foot hedge and settled down again into ground effect as I crossed
the next field building speed to pull up to about 50ft to cross a road.. By
then I was flying properly and I chopped the throttle and landed on my own
strip, quite surprised to find the wings still attached and the undercart
in one piece.
The short take off technique worked but I was very familiar with the
Challenger, knew what to expect, and dealt with the situation accordingly
BUT it was not a technique I would teach a guy with very little experience
as a standard take off procedure. That was the situation with the guy who
sent the post which started this thread.
Cheers
Pat
I fly the airplane.>>
Thanks John.
Pat
It works for me. >>
Hi Jack,
Fair enough but is that a technique you would recommend to an inexperienced
learner? Would you be happy to be told that was the way to do it with only a
few take offs under your belt. Messing about in ground effect just above the
stall is not something most instructors would suggest.
You obviously have had experience of soft field, long grass flying and have
evolved a technique to deal with it which works.
If I ever have to deal with water hidden in long grass on the runway I will
remember the way you do it and be profoundly grateful.
Alternatively I might leave the plane in the hangar.
Cheers
Pat
2 wait until the water temp gets near a boiling>>
Hi Robert,
Love that bit.
LOL
Pat
Subject: | Video Camcorder Editing Help. |
From: | "grantr" <grant_richardson25(at)yahoo.com> |
I got a Sony DCR-SR45 30GB Handycam Camcorder
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921665291488
So far I like the camcorder. It takes very clear video and is fun to use!
The problem I have is what to do with the video when I put it on the computer.
My camcorder records in MPEG-2 format. Windows movie maker, real player, quicktime
and win amp will not play these files or edit them.
Real player will start playing but the picture freezes. The files can be converted
to WMV files but that takes a while an decreases the quality of the video.
I am not looking for any thing real elaborate for editing. I just need to be able
to dub over some background narration or music, Cut out sections of the video.
I believe this is called video trimming. The software that came with the camera
will trim but it saves each trimmed section as an individual video file
and there is no way to merge the file with another video file to make a movie.
Windows movie maker seems to be ok but it does not work with my file type.
Any suggestions? I prefer freeware if it is available.
http://forums.matronics.com/viewtopic.php?p=219414#219414
Subject: | Re: Video Camcorder Editing Help. |
Grant, when I have nothing better to do and the nordic elements
hereabouts are forbidding I intend to
embark on the same pursuit. I bought a Toshiba player/recorder that
will dub either way.
It will play several formats so I will dub the disc to tape which is
easy to edit, then back to disc.
I haven't tried that routine yet but so far it has done a good job
converting VHS to disc.
BB
> to use!
> the computer. My camcorder records in MPEG-2 format. Windows movie
> maker, real player, quicktime and win amp will not play these files
> or edit them.
> can be converted to WMV files but that takes a while an decreases
> need to be able to dub over some background narration or music, Cut
> out sections of the video. I believe this is called video trimming.
> The software that came with the camera will trim but it saves each
> trimmed section as an individual video file and there is no way to
> merge the file with another video file to make a movie. Windows
I'm lucky enough to have access to commercial software, but, for free
video editing, you could try this:
http://fixounet.free.fr/avidemux/
I've not tried it, but it looks decent.
-- Robert
On Mon, Dec 15, 2008 at 7:35 AM, grantr wrote:
> I got a Sony DCR-SR45 30GB Handycam(R) Camcorder
able to dub over some background narration or music, Cut out sections of the video.
camera will trim but it saves each trimmed section as an individual video file
Subject: | Re: Kolb Ultrastar: How to take-off |
> Hi Lucien,
Sorry, but I'm just not understanding how proper soft-field takeoff technique is
a compromise in safety.
I was never trained that way and it has never been my experience that correct technique
involved a safety hazard.
If done correctly, there's nothing unsafe about a soft-field takeoff - you take
the same precautions there as you do with any takeoff.
So I'm confused.....
> in one piece.
> Cheers
> Pat
Er, yeah I wouldn't teach a takeoff like that either! No offense, but instead I'd
teach how to dismantle and trailer the plane out of that field rather than
try to actually fly out of it.
An integral part of takeoff training is learning when not to attempt it. If you're
bending metal or close to it like this, you made a mistake long before you
put the coals to it.
No safe SF takeoff involves whacking the airframe on not one but multiple dirtbars
on the takeoff run........
I don't consider this a typical soft-field takeoff situation and certainly nothing
a student should ever be exposed to......
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=219432#219432
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Pat
No, I do not recommend an inexperienced learner try this technique. But
anyone can learn this technique by using a long runway under no wind
conditions, and then progressing on to low cross wind winds, etc. The time
to learn it is when you don't need to use it. After you land in tall grass
or water puddles in grass is not the time to make your first attempt.
What I recommend before flying a FireFly and taken from the top of the page
that I recommended to Jean:
http://www.thirdshift.com/jack/firefly/howtofly.html
"If you have had little to no flight instruction, I strongly urge you get
flight instruction before attempting your first flight in the FireFly. You
need to understand the basic rudimentary physical principles of flight, so
that you will be able to analyze what is going on and so that you can react
appropriately to the normal unexpected things that happen during any flight.
During slow flight, you need to understand, experience, and practice how to
recover from stalls and spins. In addition, during landings you must be able
to initiate forward slips and side slips to enable you to lose altitude, and
to handle cross winds. When all of these skills have been developed to the
point that they are almost automatic, you will have little trouble
transition to the FireFly.
The following observations come from several years experience getting the
FireFly and myself ready to fly. Hopefully, these comments will be helpful
but I am sure they are not all encompassing."
>Messing about in ground effect just above the stall is not something most
>instructors would >suggest."
I agree, but few, if any instructor is used to flying a 500 lb gross weight
aircraft with four inch wheels off of grass. One other point. There is
nothing wrong with flying in ground effect if you keep tabs on your ASI.
The problem comes when one is overcome by the illusion that ground and
air speed are the same.
It is unfortunate the most hazardous part of flight, the transition to and
from flight through ground effect is ignored by most instructors and yet, I
feel, it is one of the most important to learn for very light aircraft. I
taught my self by flying a 4,000 foot runway at progressively lower speeds
on a no wind day with the wheels no more than three feet above the ground.
Then I repeated the same process in a light cross wind etc and finally
progressed to gusty cross winds. I would bump a wheel once in a while, but
I improved. With practice and no wind or flaperons, it is possible to
fly/taxi the FireFly with the tail planted and main gear off the runway
surface.
Fly Safe!
Jack B. Hart FF004
Winchester, IN
> surface.
> Jack B. Hart FF004
Jack:
I'm curious. What is the purpose of this exercise?
How do you control pitch attitude with the tailwheel on the ground and the
mains flying.
I'm not sure I understand why all this concern about ground effect. Kolbs
and other aircraft, fixed as well as rotary, require less power to fly in
ground effect. Our Kolbs fly so well, most of the time we don't know when
we are in it or out of it.
anyone can learn this technique by using a long runway etc..>>
No disagreement there Jack
Cheers
Pat
Easiest way to prove it is to make a foot square test frame Mike.... Herb
>John H.,
John Hauck wrote:
> Jack:
> mains flying.
> john h
> mkIII
Don't mean to butt in again, but I'm with John on this - my FSII and thereofre
I should think all Kolbs, fly just fine in ground effect.
I'm still a little mystified about these claims that flying in ground-effect is
dangerous and not something students should be exposed to, etc.
This is very basic training in fixed-wing airplanes, you're exposed to it pretty
much right away when you start on landings and takeoffs. I got hours and hours
of training in this as a student in both GA and light a/c from my various instructors.
I submit problems with flying in GE are training issues rather than problems with
the plane. I did this literally all the time in my FS II when practicing landings,
low approaches and takeoffs.....
Someone help me out here ;).....
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=219447#219447
take the same precautions there as you do with any takeoff.
So I'm confused.....>>
Sorry that you are confused Lucien.
I just don`t see that dragging a plane off the ground before it is really
ready to go is good technique.
If there are special circumstances , short field , soft field, standing
water, tall obstructions close by then of course you would use techniques
evolved to deal with that situation. I have flown from a field which is
steeply sloped. The only way to land is to land uphill through a farm gate
entrance and to take off downhill the opposite way.. Wind direction is not
in the equation.
That is a technique to deal with a specific problem and is as safe as it can
be made but presumably you would not advocate teaching it to a low hours
pilot or contend that landing and take off down wind is a desirable thing in
normal conditions..
All I am saying is that taking off while holding the tail down CAN be done
and in specific conditions MUST be done but it is not normal take off
technique.
I read once that Gann, the pilot and author, was once by mistake overloaded
with fuel. He just made it into the air but could only just stay airborne.
His speed was OK so he cleaned up the plane, retracted flaps and wheels.
Then to his horror he found he was headed straight for the Taj Mahal getting
close enough that he could see the fearstricken workmen scrambling off the
scaffolding which surrounded it. Being unable to climb over it Gann dropped
his flaps and achieved that extra bit of lift we all experience when
lowering flaps. This just bumped him high enough.
Now that was a technique to suit a particular situation but I presume that
you wouldn`t teach it as normal.
Good. Now we can have a thread about wether it is possible to increase your
height by dropping flaps.
Cheers
Pat
Cheers
Pat
thereofre I should think all Kolbs, fly just fine in ground effect.
ground-effect is dangerous and not something students should be exposed
to, etc.
it pretty much right away when you start on landings and takeoffs. I got
hours and hours of training in this as a student in both GA and light
problems with the plane. I did this literally all the time in my FS II
when practicing landings, low approaches and takeoffs.....
LS
LS
Titan II SS
Lucien, I think I can bring some clarity into Pat's problem with this
technique. You are basing your observations on how a Kolb acts and
reacts, while he is basing his on a Challenger. :-) Did you think the
name was by chance? (The devil made me do it)
Larry C
>> surface.
>> Jack B. Hart FF004
>Jack:
There is none, except that it can be done.
>mains flying.
Throttle
John,
I do not believe there is much reason to worry about it in heavier and
faster aircraft. Think of risk management and cross wind speed versus stall
speed. Assume you are going to take off in a 20 mph cross wind. Comparing
wind to stall speed, this would give 44% for 45 mphi and 74% for 27 mphi
stall speed. Also comparing 1,000 lb to 500 lb gr wt, which is going to get
blown around more on takeoff and which pilot is going to be the busiest and
who is at greater risk?
Control surface effectiveness is greater in ground effect and cross wind
shear is less close to the ground, so it is better to stabilize and
accelerate the aircraft at this point before moving on up into the full
effects of the cross wind.
Before I changed out the ailerons, modified the control system and added
VGs, I would not have attempted to takeoff in a cross wind of more than 5 mph.
This is the best I can do.
Jack B. Hart FF004
Winchester, IN
Assume you are going to take off in a 20 mph cross wind. >
> Jack B. Hart FF004
Jack:
Kolbs do not have enough yaw attitude authority to overcome a 20 mph cross
wind.
Somewhere below 20 mph the Kolb will begin to weather vane. Rudder becomes
pretty much useless.
VGs or no VGs.
More than once I have had to find some place to land into the wind because
the wind overpowered the rudder, at the risk of wetting my pants because my
bladder was full. Full bladder was reason for landing in the first place.
circumstances when you would want to get into ground effect early:
1. long draggy grass or brush which would otherwise prevent
attaining flying speed.
2. rough plowed ground
3. wet snow.
done 'em all
BB
> takeoff - you take the same precautions there as you do with any
> takeoff.
> really ready to go is good technique.
> standing water, tall obstructions close by then of course you would
> use techniques evolved to deal with that situation. I have flown
> from a field which is steeply sloped. The only way to land is to
> land uphill through a farm gate entrance and to take off downhill
> the opposite way.. Wind direction is not in the equation.
> as it can be made but presumably you would not advocate teaching it
> to a low hours pilot or contend that landing and take off down wind
> is a desirable thing in normal conditions..
> be done and in specific conditions MUST be done but it is not
> normal take off technique.
> overloaded with fuel. He just made it into the air but could only
> just stay airborne. His speed was OK so he cleaned up the plane,
> retracted flaps and wheels. Then to his horror he found he was
> headed straight for the Taj Mahal getting close enough that he
> could see the fearstricken workmen scrambling off the scaffolding
> which surrounded it. Being unable to climb over it Gann dropped his
> presume that you wouldn`t teach it as normal.
> increase your height by dropping flaps.
> Cheers
> Pat
> Cheers
> Pat
I have been using a free program called "any video converter". Google it up
and give it a try.
Bill Eslick
> computer. My camcorder records in MPEG-2 format. Windows movie maker, real
> player, quicktime and win amp will not play these files or edit them.
> converted to WMV files but that takes a while an decreases the quality of
> the video.
> be able to dub over some background narration or music, Cut out sections of
> the video. I believe this is called video trimming. The software that came
> with the camera will trim but it saves each trimmed section as an individual
> video file and there is no way to merge the file with another video file to
> make a movie. Windows movie maker seems to be ok but it does not work with
> my file type.
At 08:35 AM 12/15/2008, you wrote:
>I got a Sony DCR-SR45 30GB Handycam=C2=AE Camcorder
>when I put it on the computer. My camcorder
>real player, quicktime and win amp will not play these files or edit them.
I use Studio 10 - but the new version is Studio 12 - not free - about $50
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Vid
eo/Studio+Family/
You might click on "see what's new with Version12" and run the tutorial.
It supports Video: DV, AVI, MPEG-1, MPEG-2,
DivX=AE*, MPEG-4*, 3GP(MPEG-4)*, WMV, Non-encrypted DVD title
After editing, I always save it as a MPEG-4 file
& upload it that to goggle or youtube.
Or burn it to HD disc for the TV.
If you're just trying to play the MPEG-2 - copy
it from the chip to your desktop & play it from there.
That will keep it from sticking while you play it
on your computer most of the time.
Sample of one done pretty quick & dirty.
http://video.google.com/videoplay?docid=-3487102474967847487&hl=en
I've never heard of anything like that being taught. I've never encountered this
in any training situation I've ever been in regardless of plane, instructor
or situation.
No soft-field technique I've ever been taught involved anything close to that and
I don't recall ever doing this personally.
What you described in your particular scenario - bouncing over at least 3 large
dirt mounds, then clearing a hedge and then a road after a major, but untested,
repair to the prop drive system - is not in any PTS for any rating I'm aware
of.
But it's quite right to say that that's definitely not safe takeoff practice!
> technique.
> with fuel.
Here again is another training item I'm not familiar with. Knowingly taking off
over over gross is just plain verboten under all circumstances the way I was
taught. Or at least, doing so puts you in test pilot territory and at your own
risk.
Actually, I wouldn't teach this technique of dodging buildings and people while
over gross as normal or safe under _any_ circumstances at all, so yes, you're
quite right.
Again, I'd be instructing some other method than flight as the alternative here,
such as a vehicle for the pilot and a trailer for the plane.
You're right - you're definitely not talking about good training or safety here....
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=219523#219523
lcottrell wrote:
> Lucien, I think I can bring some clarity into Pat's problem with this technique.
You are basing your observations on how a Kolb acts and reacts, while he
is basing his on a Challenger. :-) Did you think the name was by chance? (The
> Larry C
I appreciate the attempt but this doesn't help me too much. Every plane I've flown
so far flies just fine in ground effect, even the one or two trikes both single
and double-surface. The Kolb is in large company in this regard....
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=219524#219524
Scott,
<< If the best location chordwise is when the vortices meet at the trailing
edge then couldn't you calculate backwards from the TE to find the sweet
spot for mounting the VG's? >>
kuffel(at)cyberport.net wrote:
<< best spanwise spacing occurred when the vortices generated just met at
the training edge of the wing. The vortices spread from each generator at
an included angle of 15 degrees. >>
Not really. There are two independent variables, spanwise spacing and chord
location. Once you decide on a given chord location then geometry does tell
you the minimum useful spanwise spacing. Any more generators than this
minimum spacing will not improve matters and might make things worse. Don't
remember how NASA (actually it might have been a NACA report) decided on
10% - 15% of chord for subsonic wings but that range seems to be what is
used by all the VG vendors, both experimental and certified.
Tom Kuffel
Whitefish, MT
Building Original FireStar
From: | "Dave Bigelow" <up_country(at)hotmail.com> |
The important thing about your camcorder movies is to end up with a product that
you or anyone else can play and enjoy without special equipment. For most,
that means getting your movies into DVD format. Also, it is nice to be able to
convert your videos to a format that you can upload to YouTube, etc.
I've tried a lot of editing applications, and have had very good luck with Ulead
Visual Studio 11. You can edit just about any format, and go as simple or elaborate
as you wish. You can convert your edited videos to just about any format
known to man.
It's not free, but is worth every penny. Why go to all the trouble of taking videos
and then not get good tools to share them with the world? Visual Studio
(and most other editing apps) need some computing power to work well. I'd recommend
a duo core processor, lots of memory, a big hard drive, and a good graphics
card.
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
http://forums.matronics.com/viewtopic.php?p=219563#219563
Why go to all the trouble of taking videos and then not get good tools to
share them with the world? >>
Hi Dave,
All that presupposes that the world actually wants to see them. Judging from
the general standard of filming displayed on the net the perpetrators would
be well advised to keep their productions to themselves until they have
mastered some basic technique.
A few are superb but most....yuck!
Cheers
Pat
Sorry Lucien, either we speak different languages or you don`t read very
carefully. I specifically said "loaded by mistake" nothing at all about
`knowingly taking off etc`
>From what I remember of the story the refuelling crew were instructed to put
in a specific amount of fuel but instead filled the tanks.
I am not going to get into the question of whether Gann should have checked
the amount. It is just the story as I remember it and its years since I read
it..
As for my `take off with an untested repair`. Replacing a faulty drive belt
with a new one hardly calls for a major investigation. In any case that is
entirely beside the point. The object of the story was to illustrate that in
that instance there WAS a case for dragging the plane off the ground as
quickly as possible as it was a small very rough field and a NORMAL take off
run was impractical.
That encapsulates what I have said all along. You CAN take off with the tail
on the ground but unless you need to what is the point?
I think this has been hammered to death. Let us just leave it. I shall
continue to take off in what I consider a safe manner and no doubt you will
do the same.
Incidentally if you have never come across Ganns books I think his initials
are D.W and there was at least one film derived from one of his stories.
Well worth reading.
Merry Christmas
Pat
Regardless of why, taking off over gross is a training issue and thus has nothing
to do correct takeoff technique. Negligence of this type doesn't say anything
about the technique used to get in the air, at that point you can't and shouldn't
rely on the results you get.
The way I see it, no takeoff at all, regardless of technique used, could have been
the correct method to use in that situation. Dirt bars, bushes and roads directly
in the path of the takeoff and clearly too close to clear safely is only
a case for not attempting flight period and don't support the use of any takeoff
method.
Trailering techniques, OTOH, could have been effectively taught in a situation
like that.
> do the same.
Well, good luck to you,
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=219578#219578
On Dec 16, 2008, at 3:44 AM, Dave Bigelow wrote:
> . I'd recommend a duo core processor, lots of memory, a big hard
> drive, and a good graphics card.
Dave, sounds like an Apple Mac advertisement.
> read very carefully. I specifically said "loaded by mistake"
> nothing at all about `knowingly taking off etc`
>> instructed to put
> checked the amount. It is just the story as I remember it and its
> years since I read it..
> drive belt with a new one hardly calls for a major investigation.
> In any case that is entirely beside the point. The object of the
> story was to illustrate that in that instance there WAS a case for
> dragging the plane off the ground as quickly as possible as it was
> a small very rough field and a NORMAL take off run was impractical.
> the tail on the ground but unless you need to what is the point?
> shall continue to take off in what I consider a safe manner and no
> doubt you will do the same.
> initials are D.W and there was at least one film derived from one
> of his stories. Well worth reading.
> Merry Christmas
> Pat
Subject: | Re: choke or primer |
From: | "cristalclear13" <cristalclearwaters(at)gmail.com> |
> [quote="beauford"]On the Bing enrichment circuit:
> The small enrichment piston which is raised by either a lever on the carb,
or by a cable to a remote
> "choke" lever has a small nitrile rubber insert set in a cavity in the base.
The rubber insert will gradually
> deteriorate and deform with age, thereby allowing additional (excessive) fuel
to leak through the enrichment circuit and dump into the engine.
> This occurs gradually over many hours and may not be detected until excessive
carbon shows up in the top end
> of the engine, possibly causing stuck rings and potentially serious problems.
> Some of you Listers may recall Beauford's fun with this problem in the Nazi
447 a few years back... In my ignorance about what was happening, I ended up
chasing back and forth with metering rod adjustments, jetting changes,
> fouled plugs, etc.... I had repeatedly checked the enrichment piston's function,
verifying that it was bottoming into the seat properly...the problem was
that the rubber insert had receded up into the base of the thing and I did
not notice it. because it looked fine...the rubber was not obviously cracked
or split.
> Long story, short... The guys over at Lockwood took one look and immediately
diagnosed the problem...said that they had seen a number of Rotax 2-strokes
trashed with this... and that the Bing enrichment piston ought to be replacd
every 2 years or so as a matter of routine maintenance....especially with
PREMIXED fuel which attacked the nitrile faster than straight gas... One can
only wonder what the ethanol is doing to these things. As I recall, the part
cost under $10.... which was certainly substantially less than the two new
pistons I had to buy after the carbon had seized the rings...
> I now keep an extra enrichment piston on hand...
> ...worth what ye paid fer it...
> beauford
> FF-076
> Brandon, FL
Beauford,
Is there a website or article in the CPS catalogue that talks about replacing the
parts you are talking about (or did you just get the information by word of
mouth from Lockwood)? I would like to read more about it. Can you look at your
old receipts and tell me what part(s) I would need to order?
All,
We got my choke cables working correctly now. The choke wasn't stuck on...it was
never opened. There was a washer (that prevented the cable housing from sliding
into the metal tube) that hadn't been replaced when we put everything back
together. (But this doesn't help me solve the mystery of the excessive smoking
when we first started it up...but that could be another thread on the forum.)
Thanks for everyone's input and advice.
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=219590#219590
(But this doesn't help me solve the mystery of the excessive smoking when
> Cristal Waters
Cristal:
Two strokes tend to load up with excessive oil in the crank case when run
slowly for long periods of time. As soon as rpm is increased, it will clear
it out, along with a lot of smoke.
Another reason not to let a two stroke idle any longer than necessary.
Another reason the run a two stroke in the power band and not lug them down
at lower rpm.
From: | william sullivan <williamtsullivan(at)att.net> |
Subject: | re: choke or primer |
- John- Considering that taxiing and parking may involve low engine speed
s, what would be an appropriate shut-down procedure?
---------------- Bill Sullivan
Subject: | Re: re: choke or primer |
Bill:
I don't know.
I'd keep low engine speeds to a minimum though.
What does your operators manual say?
speeds, what would be an appropriate shut-down procedure?
Bill Sullivan
From: | "beauford T" <beauford173(at)verizon.net> |
Sister Cristal:
I initially discovered what was going on from the Lockwood mechanics... I
have never seen a discussion of this problem
in written form anyplace... The mechanics I talked to were certainly
familiar with it...
Per your question... Reference the 2009 CPS catalog, page 143, pertaining to
the Bung...er...Bing 36 mm...
I assume from your reference to the cables that you are using the
cable configuration to work your enrichment/choke... In that case the part
is Bing "starting piston" # 963-740.
If you were using the lever type choke, it is called Bing "choke piston"
part # 268-847.
Hope this helps...
beauford of Brandon
FF -076
Brandon, FL
----- Original Message -----
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Beauford,
replacing the parts you are talking about (or did you just get the
information by word of mouth from Lockwood)? I would like to read more
about it. Can you look at your old receipts and tell me what part(s) I
All,
on...it was never opened. There was a washer (that prevented the cable
housing from sliding into the metal tube) that hadn't been replaced when we
put everything back together. (But this doesn't help me solve the mystery
of the excessive smoking when we first started it up...but that could be
Cristal Waters
Rotax 503 DCSI
Subject: | Darndest thing I ever saw!! |
Kolb guys and girls=2C
A few weeks back=2C a guy from Bonaco Inc. offered to send for free (yes
=2C free!!!) a complete set of brake lines to the first person to furnish t
o him the necessary dimensions for said brake lines. The person who respon
ded to his request was me. It also just happens that I am just about ready
to install such brake lines=2C but I didn't have any=2C yet.
Well=2C lo and behold=2C guess what showed up in the mail today. My very
own FREE=2C custom-made complete brake line set=2C including all appropria
te AN fittings to complete the installation. Whoa!! No way!! Yes=2C way!
This complete brake line set is some of the nicest looking parts I do bel
ieve I've ever seen. The quality is impeccable. The attached photo does n
ot do the parts justice!! The stainless steel braid has a clear plastic co
at. The AN fittings are anodized and are aircraft quality. Truly good stu
ff.
This set of brake lines was free=2C cost me nothing=2C but the time to fu
rnish measurements=2C and was otherwise at no charge at all. Can't beat th
at with a stick!!!
My guess at the approximate value would be just over $100.
I will be purchasing more items in the future from this company. I need
a flexible fuel line=2C
rather than the solid steel tube fuel line I was using. I will be ordering
it from them. Not only because of this excellent marketing plan=2C but be
cause I have the parts in my hand=2C and they are top notch quality!!
Evidently=2C the old addage "there ain't no such thing as a free lunch" i
sn't completely true!
At least in my case=2C there is such a thing as a once in a lifetime free o
ffer. I've got the goods to prove it!!
Mike Welch
MkIII
PS For your own quality hoses I highly recommend giving Brett at Bonaco=2C
Inc. a call. He can be found at 909-985-3429. Their products are featur
ed at www.Bonacoinc.com
d_122008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Subject: | Re: Darndest thing I ever saw!! |
This complete brake line set is some of the nicest looking parts I do
believe I've ever seen. The quality is impeccable.
Mike Welch
MkIII
Mike:
Wonder how much more those lines and fittings weigh than what I have been
using for the past 17 years on my mkIII?
Mine are 1/8" ID X 3/16" OD plastic. Weight is negligible.
Fittings are tiny. Believe they came with the MATCO brake kit.
Proven to be effective and reliable.
Costs: A couple dollars.
mkIII - 2,800+ hours since 1992.
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: Kolb Ultrastar: How to take-off |
> Assume you are going to take off in a 20 mph cross wind. >
>> Jack B. Hart FF004
>Jack:
>Kolbs do not have enough yaw attitude authority to overcome a 20 mph cross
>wind.
John,
On take off you do not need all that much yaw authority. If you move the
stick into the wind and back to keep the up wind main wheel and the tail
wheel planted until it leaves the ground, there is no need for a rudder.
After it leaves the ground, you can let it weather vane into the wind, level
the wings and crab into the wind on climb out.
Landing is different. You can hold in as much side slip as the rudder will
permit. If the wind blows you off, then you have to decide whether to use a
combination of side alip and a crab to get to the runway, and at the last
second lower the up wind wing and plant the up wind wheel. In this case, I
land into the wind. The landing roll is very short.
Jack B. Hart FF004
Winchester, IN
> Jack B. Hart FF004
Jack:
You have written of flying in 25 mph cross winds in the past.
I'd like to watch you demonstrate those maneuvers for me, as soon as I
finish making double tie downs on my mkIII.
John H.,
The brake lines furnished to me for free from Bonaco, Inc were their
offering, not my choice. He asked for dimensions and these were what I got.
I agree these would be more appropriate to put on my GlaStar (when I get back
to working on it someday).
The truth is I intended to use plastic tubing, like you have, until this offer
came about.
I have looked for the 1/4" plastic tubing, but I'm not sure what I have found
is
appropriate for brake lines. Icemaker water line just doesn't sound right!!!!
Does anyone know where to get the CORRECT 1/4" plastic tubing, that would work
well
for brake lines on Matco calipers? (Yes, I need 1/4", that's the size of my fittings).
Mike Welch
MkIII
Still, it was a hellava nice present for free.
Suspicious message? Theres an alert for that.
http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_broad2_122008
Subject: | Re: Poly Tone paint |
From: | "Kirby, Dennis CTR USAF AFMC MDA/AL" <Dennis.Kirby(at)kirtland.af.mil> |
Mike Welch asked: << Is it possible to brush on Poly Tone paint (with a
very high
quality brush) >>
Hi, Mike -
I applied the Poly Tone trim colors on my Mark-III using a roller brush,
with excellent results.
What I discovered after a few tries was, when you first roll on the
paint, tiny bubbles form on the surface.
But those get smoothed out with the subsequent passes of the roller.
The trick is to get the timing right on the last pass of the paint
roller: if it's too SOON, the little bubbles keep forming, and if it
dries this way, you'll see all the tiny circles. If it's too LATE (too
dry), the roller will leave a textured finish in the paint, like orange
peel. If your last roller pass is timed JUST RIGHT, the bubbles are
eliminated and the paint settles out perfectly smooth. But you gotta
discover the "right" timing all on your own - it'll depend on your
temperature and humidity.
But the short answer is, "yes," you CAN get an acceptably smooth and
attractive Poly-Tone finish using a roller.
Dennis Kirby
Mark-3, 912ul, "Magic Bike"
Cedar Crest, NM
At 07:41 AM 12/16/2008, pj.ladd wrote:
> From what I remember of the story the refuelling crew were instructed to
> put in a specific amount of fuel but instead filled the tanks.
>I am not going to get into the question of whether Gann should have
>checked the amount. It is just the story as I remember it and its years
>since I read it.
I don't remember the details from when I read it, either, but also IIRC it
was during wartime... when people often must do things with a much lower
margin of safety than they'd otherwise find acceptable.
>Incidentally if you have never come across Ganns books I think his
>initials are D.W and there was at least one film derived from one of his
>stories.
Ernest K. Gann... all of his numerous flying books are worth reading. He
also wrote several sea stories but I haven't read any of those.
-Dana
"The difference between death and taxes is death doesn't get worse every
time Congress meets." -- Will Rogers
> found is
> would work well
>my fittings).
No, icemaker tubing is usually polyethylene. You want the hard nylon
tubing, which is rated for much higher pressure... I got mine from
McMaster-Carr. You need to know the inside diameter too; they have it in
several different ID's.
-Dana
> -Dana
Dana,
Yeah, I know icemaker tubing wouldn't do. Polyethylene and polyurethane tubing
are not strong enough for the job. I was being facetious.
I have found a few sources that do sell the high pressure nylon tubing. Thanks
for the McMaster-Carr tip. I'll check with them.
Mike Welch
MkIII
Send e-mail faster without improving your typing skills.
http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed_122008
Aircraft Spruce sells the stuff you need, line & connectors. You are
aware that most aircraft brake assembles use red transmission fluid
not the very corrosive clear hydraulic fluid like used in
automobiles. They package cans labeled for aircraft use.
jerb
>> I have found is
>>sound right!!!!
>> that would work well
>nylon tubing, which is rated for much higher pressure... I got mine
>from McMaster-Carr. You need to know the inside diameter too; they
>have it in several different ID's.
>-Dana
> jerb
Thanks Jerb for the Aircraft Spruce reference. I looked and looked for it there,
but could never seem to come up with it. I found it, thanks.
Yes, I'm very much aware of the differences in brake fluid between an airplane
and a car. I still have some of my red brake fluid left over from topping off
my
Cessna's brakes.
Mike Welch
MkIII
Subject: | Re: Engine Installation |
> I've added a couple pics of the engine installation on me Xtra.
> Scott
Hi Scott:
You mentioned oil temp and water temp on your engine installation web page.
The 912ULS (and 912UL) are concerned with oil temp and cylinder head metal
temp. Don't believe there are limits for water temp since it is not a
required parameter to measure.
There are three temp three temp senders on the engine. They are identical.
One is for engine oil temp, and the other two measure #2 and #3 CHT (one for
tractor and one for pusher configuration).
I discovered the engine runs better is the CHT is kept above 180F. Nothing
in the book about that.
You will probably have to block part of the coolant radiator to get the CHT
and engine oil temp up to the minimum of 190F (to burn off condensation in
the oil system).
John W kept each end of his radiator taped year round.
> Scott
Scott:
Missed the location of the oil cooler. Will be interested to see how well
it cools in that location. Probably will be ok.
I piggy back my oil cooler on the radiator. My oil temps run higher than
average, even with the largest size Rotax cooler, except, of course, during
the winter months.
Ernest K. Gann.!
Of course. Stupid me. Senior moment. Thanks Dana
Pat
I'm sure you're talking about Ernest K. Gann,>>
Hi Russ,
quite right. Just me being thick. The High and the Mighty was the film
which I had in mind,. Thanks for the list of books, there were a few there
I hadn`t read.
Cheers
Pat
Agreed. If you haven't read it, do it. So real you will feel you are
there.>>
Hi Robert,
I remember there was a passage in one book describing a flight into a fijord
in Iceland(?) during a transatlantic flight. Clag closed the top and the
Airforce base was right at the inland end . There were a couple of bad
direction changes to be negotiated and the it was straight into the
airstrip with no room to turn round and try again. One try only. It had me
on the edge of my seat. great stuff.
thanks for putting me right on the initials, everybody
Pat
Subject: Re: Kolb-List: Kolb Ultrastar: How to take-off
John,
I am some what puzzled by your cross wind problem. I have thought about it
a little and may be I can help out a little.
You have said you are self taught and I wonder if you are proficient at
cross controlled flying especially side slipping? I assume you are.
Not all Kolbs are the same and this includes your MKIIIC. There are several
changes that you have done to your plane that make it more yaw sensitive.
First, you have moved your main gear forward. This moves the cg further
behind the main gear. What you gained in nose over prevention you lost in
making the plane more squirrelly in yaw on the ground. To compound this you
have added additional fuel capacity and weight. If you do not have baffles
in the tank, fuel sloshing while making a take off run in a gusty cross wind
will cause yaw problems.
With your admitted aft cg and flying heavy, you will lose some roll
authority at low speed, and this will reduce ones ability to hold the plane
steady in gusty cross wind on take off. VG's can help overcome this
situation, in that, they will improve aileron effectiveness at low speed,
and they will move the center of lift back from the cg.
A couple of other factors that can make your plane less ground yaw stable is
incorrect toe in, camber and tire pressure. If the toe in is not neutral
and/or camber is not positive under load, the plane will be squirrely on a
gusty cross wind take off. If you are running low pressure tires the
rolling resistance is a function of the load, and so as the plane rocks from
side to side it will want to turn in that direction.
For what it is worth.
Fly safe!
Jack B. Hart FF004
Winchester, IN
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
Jack
I think you have misunderstood John's message. First let me assure you John
and his plane are more than up to the task of handling the upper limits of
any Kolb cross wind landing.
Two things. First, we all need to be very careful not to overstate the
capabilities of our airplanes so that less experienced pilots will not try
to handle weather they think is safe because someone has said it was safe.
Second, less experienced pilots tend to over estimate the actual cross wind
component that they have landed in.
I think we should follow John's lead in reporting accurate limits of our
aircraft. Pounding our chests and stating "I can land in a higher cross
wind" isn't a good thing to do here.
Rick Neilsen
Redrive VW powered MKIIIC
----- Original Message -----
Sent: Wednesday, December 17, 2008 8:44 AM
> From: "John Hauck" <jhauck(at)elmore.rr.com>
> John,
> it
> several
> you
> baffles
> wind
> plane
> is
> a
> from
> Fly safe!
> Jack B. Hart FF004
> Winchester, IN
> it
> Jack B. Hart FF004
Hi Jack:
All aircraft have a ultimate cross wind component limit. I don't know what
Kolbs limits are, but probably around 15 mph in a direct cross wind. After
that there just ain't enough rudder to align the aircraft with the runway.
Landing is much more critical than takeoff in high cross wind conditions,
probably because there is much less air moving over the rudder, and other
flight controls, during landings. I have found it helpful to use short
burst of power to help align the aircraft just prior to and during touch
down, especially on paved strips. Grass and gravel strips are much more
forgiving when touching down or taking off while crabbing.
If all cross winds were steady, it would make operating in them much easier.
But, normally, they are not. Gusty wind conditions play havoc on very light
aircraft. Many times we find ourselves, momentarily, in a "along for the
ride" condition.
I find my modified Kolb as good or better handling rough air and cross winds
than the standard Kolbs I fly. Maintaining runway alignment during takeoffs
is not a problem, normally.
I do a lot better negotiating rough air and cross winds the more I fly.
Lately, I haven't been flying much. In fact, I'm pushing three months since
my last flight, returning from the Kolb Homecoming in Kentucky.
From: | "Richard Girard" <aslsa.rng(at)gmail.com> |
Subject: | Re: choke or primer |
Cristal, Get yourself a free copy of the Rotax Illustrated Parts Catalog
at:
http://www.rotax-owner.com/
Click on support, find engine manuals. While it won't necessarily give you a
procedure, the break down drawing should give you a good idea about how it
all goes together. You'll certainly get all the current part numbers, at
least.
Rick
On Tue, Dec 16, 2008 at 9:16 AM, cristalclear13 <
> > [quote="beauford"]On the Bing enrichment circuit:
> > The small enrichment piston which is raised by either a lever on the
> carb, or by a cable to a remote
> > "choke" lever has a small nitrile rubber insert set in a cavity in the
> base. The rubber insert will gradually
> > deteriorate and deform with age, thereby allowing additional
> (excessive) fuel to leak through the enrichment circuit and dump into the
> engine.
> > This occurs gradually over many hours and may not be detected until
> excessive carbon shows up in the top end
> > of the engine, possibly causing stuck rings and potentially serious
> problems.
> > Some of you Listers may recall Beauford's fun with this problem in the
> Nazi 447 a few years back... In my ignorance about what was happening, I
> ended up chasing back and forth with metering rod adjustments, jetting
> changes,
> > fouled plugs, etc.... I had repeatedly checked the enrichment piston's
> function, verifying that it was bottoming into the seat properly...the
> problem was that the rubber insert had receded up into the base of the
> thing and I did not notice it. because it looked fine...the rubber was not
> obviously cracked or split.
> > Long story, short... The guys over at Lockwood took one look and
> immediately diagnosed the problem...said that they had seen a number of
> Rotax 2-strokes trashed with this... and that the Bing enrichment piston
> ought to be replacd every 2 years or so as a matter of routine
> maintenance....especially with PREMIXED fuel which attacked the nitrile
> faster than straight gas... One can only wonder what the ethanol is doing
> to these things. As I recall, the part cost under $10.... which was
> certainly substantially less than the two new pistons I had to buy after
> the carbon had seized the rings...
> > I now keep an extra enrichment piston on hand...
> > ...worth what ye paid fer it...
> > beauford
> > FF-076
> > Brandon, FL
> Beauford,
> Is there a website or article in the CPS catalogue that talks about
> replacing the parts you are talking about (or did you just get the
> information by word of mouth from Lockwood)? I would like to read more
> about it. Can you look at your old receipts and tell me what part(s) I
> would need to order?
> All,
> We got my choke cables working correctly now. The choke wasn't stuck
> on...it was never opened. There was a washer (that prevented the cable
> housing from sliding into the metal tube) that hadn't been replaced when we
> put everything back together. (But this doesn't help me solve the mystery
> of the excessive smoking when we first started it up...but that could be
> another thread on the forum.)
> Thanks for everyone's input and advice.
> Cristal Waters
> Kolb Mark II Twinstar
> Rotax 503 DCSI
> http://forums.matronics.com/viewtopic.php?p=219590#219590
That install looks good. i had a chute to contend with up front. I don't
know about the 100 hp
but John was right when he said the 912ul runs cool. Just before that i
had removed my oil cooler
and saw 190 deg for the first time. He also mentioned (John H.) quite
awhile back that the 912 didn't like conical filters. Maybe he could
comment on that again as I have forgotten.
Vic
Xtra 912ul
conical filters
Hey Jack,
As a novice with 3.5 legal hrs. with Instructor and only 6 seconds of
solo I don't under stand Why you would crab into the wind on take off
if you already weather vaned into it.
"After it leaves the ground, you can let it weather vane into the wind,
level
the wings and crab into the wind on climb out."
How do you slip and crab simu, simul, together?
"If the wind blows you off, then you have to decide whether to use a
last "
Thanks in advance for the free instruction.
Vic
Jack
That reminds me of another question, Pats brain cramps are catching.
I noticed while taxying with a cross wind if rudder input was not
enough, aileron in the opposite
direction would bring it in line. Soooo how would you (I) be able to
keep a wing down into the x wind?
Vic
Mike, You'll need to put a UV shield over it where it's out in the light and
it's good for 20 years.
Rick
On Tue, Dec 16, 2008 at 2:34 PM, Mike Welch wrote:
> John H.,
> got.
> back
> offer came about.
> found is
> right!!!!
> work well
> my fittings).
> Mike Welch
> MkIII
> Suspicious message? There's an alert for that.
Hi Vic:
The 100 horse generates much more heat than the 80.
My understanding is the Bing carbs on the 912's were not designed to operat
ed in the pusher configuration, air stream blasting the air filters and car
b intakes head on. Frank Reyen designed a way to reverse the intake manifo
lds and fly his carbs on the back side of the engine. On BMW two cylinder
engines, the carbs are mounted on the back side of the cylinders. The Bing
has two static ports is it reading to decide where the piston will be loca
ted, in conjunction with the throttle valve, to adjust mixture. One port i
s what is commonly referred to as the float chamber vent tube and the other
is a port on the lip of the carb intake. These ports need to be reading u
ndisturbed static pressure in order to do their jobs correctly. John W ove
rcame this by running the flat (cake pan) type K&N filters. I did it with
filter covers that came with a carb heat system I purchased some time back.
Before I installed the covers, airflow would blown the fuel vapor stand o
ff at the mouth of the carb out the side of the filter and on the carb and
engine. My 912 engines ran ok with conical filters, but made a mess of bro
wn fuel stain on them. One of these days I will remove the filter covers a
nd see if I can detect any difference in performance.
but John was right when he said the 912ul runs cool. Just before that i h
and saw 190 deg for the first time. He also mentioned (John H.) quite awh
ile back that the 912 didn't like conical filters. Maybe he could comment o
Vic
Rick:
If you are referring to the clear plastic brake line like I am using, mine
has no UV shield and it is pushing 18 years service.
and it's good for 20 years.
Rick
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Subject: | parts needed for sync of dual carbs |
I notice that Lockwood has a dual carb sync kit for around $79.00, Seems
like a lot of money for a one time use. Would it be worthwhile to build
one from available parts? Any body done it?
Minus 6 this morning. BRRRRRR
Larry C
Why Choke (enricher) OR Primer? Why not both, each performing a separate function?
When I bought my FS1 w/447, it was very hard starting. It had only the enricher
circuit, which for reasons I'm still not sure of, was not much help in getting
it started when cold. It would take 6-8 pulls before it would get rich enough
to fire. Yes, it has an electric fuel pump used to make sure there is fuel in
the float chambers before attempting a start.
My hard starting fix was to install a squeeze bulb primer teed off the main fuel
supply line and plumbed to the nipple (designed for this purpose) just downstream
of the butterfly valve. To start I give the bulb one squeeze to give the
carb throat a little raw fuel, shut off the valve to this branch of the line
and start it with a single pull of the rope. The squeeze bulb primer is used only
for a starting squirt and then isolated from the rest of the fuel system during
running. The shut-off valve is important because this branch is located
on the suction side of the mechanical pump. Without the shut-off valve, the mechanical
pump could draw air thru this branch from the carburetor if the check
valve in the squeeze bulb failed.
Once started, the enricher can be shut down as the engine warms up. It is simpler
than it sounds when I read this description and works perfectly.
Thom Riddle
N1208P RANS S6S, Tailwheel, 912UL
N197BG FS1/447
It is by universal misunderstanding that all agree. For if, by ill luck, people
understood each other, they would never agree.
- Charles Baudelaire
http://forums.matronics.com/viewtopic.php?p=219793#219793
function?
> Thom Riddle
Thom:
I've had excellent results with enrichers on two and four stroke Rotax
engines.
If the engine and carb is set up correctly, and the enricher circuit is in
good shape, it'll fire right up in many different climatic conditions. If
not, then there is something wrong with enricher system and/or engine.
johnh
I'm sure you are right, John. I didn't take the carb apart to check out the enricher.
Instead I did what I said, which is something I had intended to do anyway.
Thom Riddle
N197BG FS1/447
http://forums.matronics.com/viewtopic.php?p=219800#219800
the enricher. Instead I did what I said, which is something I had intended
to do anyway.
> Thom Riddle
Thom:
I'm sorry. I misunderstood your msg. Thought you put the primer on because
you couldn't get your 447 to start with the enricher.
"When I bought my FS1 w/447, it was very hard starting. It had only the
enricher circuit, which for reasons I'm still not sure of, was not much help
in getting it started when cold. It would take 6-8 pulls before it would get
rich enough to fire. Yes, it has an electric fuel pump used to make sure
there is fuel in the float chambers before attempting a start."
I was trying to emphasize enrichers work if set up and operated correctly.
Subject: | Re: parts needed for sync of dual carbs |
Larry:
Its 66F at hauck's holler. Sun is trying to burn off this crud and I'm goi
ng to commit aviation.
After all the talk of sync'ing carbs with vacuum gauges, I purchased to hig
h quality, viscous dampened vaacuum gauges. Made me a carb sync board and
did a job on the 912ULS. My mechanical settings were as close as the vacuu
m gauges could get. Accidently broke one gauge, put it into the prop ;-(,
and am back to mechanical sync'ing again. I am satisfied with the results.
I bet you can sync the HKS carbs mechanically using the procedure in the 91
2 maint manual.
Don't intend to spend any more money on vacuum gauges.
like a lot of money for a one time use. Would it be worthwhile to build one
Larry C
Narssarssuaq (sp?) in Greenland.>>
Yeah. Well I knew it was partway across the Atlantic
Thanks. Must 30 years since I read that book
Cheer
Pat
Subject: | Re: Kolb Ultrastar: How to take-off - Cross Wind Landings |
Richard,
If I have not made my self clear on this List, then I apologize. I feel
like I always recommend practice and training. I make no apology for
recommending that fellow FireFlyers and/or Kolbers practice cross wind
landings. I have gotten caught on return trips where the wind was too high
to make a cross wind landing. It is easily detected by setting up a side
slip on final approach. If you drift off you have to take a different
approach. I assume the FireFly has the advantage in this case because one
can turn into the wind and land on a cross taxiway or a ramp with very low
ground touch down speed. The MKIIIC can be flown the same way but the roll
out would be longer due to the higher stall/approach speed.
I do worry about inexperienced pilots being told that all Kolb models fly
the same, they don't. I worry about the inexperienced being told that aft
cg is unimportant. Is this chest pounding? Well, I guess it is.
This List is a good forum for telling it like it is. Several people on this
list have had accidents, and they have come forward and told it like was, so
that we all could learn from their experience. In the last few years some
"good and experienced" Kolb pilots have been killed. The last was John W.
Several people on this list were present, but we have not seen a good
description of what they saw, if they saw anything. Was he flying through a
down draft on the back of a mountain? Did he have medical emergency? Since
he was camping was he flying with an aft cg? Most likely we will never
know. Most likely what will injure or kill you is what you didn't know until it
is too
late. So practice and practice.
So lets keep it safe.
Jack B. Hart FF004
Winchester, IN
>Jack
>Rick Neilsen
If I had a steady 30 MPH crosswind to land in there would be little
trouble. The key word is STEADY.
The problem here is 30 MPH translates into gusts over 40 and sudden
calm thus setting up the
clenched grip, sweat-inducing, heart-palpitating hope for good luck.
I was the grateful recipient of a piece of that luck one time this
summer in my stubborn insistence
to land back at my home field. If I had it on video you wouldn't
believe it.
Drive a man to drink. (or at least one reason)
BB
On 17, Dec 2008, at 2:44 PM, Jack B. Hart wrote:
> Richard,
> feel
> too high
> a side
> because one
> very low
> the roll
> models fly
> that aft
> people on this
> like was, so
> years some
> John W.
> through a
> emergency? Since
> never
> know until it is too
> Jack B. Hart FF004
> Winchester, IN
>> Jack
>> you John
>> limits of
>> the
>> not try
>> was safe.
>> cross wind
>> of our
>> cross
>> Rick Neilsen
At 05:42 PM 12/17/2008, ElleryWeld(at)aol.com wrote:
>Aircraft Brake fluid is not transmission oil it is MIL-H-5606 A not
>anywhere near the same stuff just because it is red in color, some brake
>systems have seals that cannot take to oil like ATF it will swell the
>seals up and make them fail
>Use the right fluid for manufacture recommendation with the brake system
>you have
Part of the confusion may be from the fact that some non certified aircraft
brakes (like the Free Bird brakes on my UltraStar) do indeed specify Dexron
II or III automatic transmission fluid, which is also red. ATF must also
be compatible with the Hegar master cylinders that control the brakes on my
plane, since I've had no trouble. I can't speak for other types.
-Dana
Clothes make the man. Naked people have little or no influence on society.
> My Rotax 912 operators manual has specs for coolant temp.
> Scott
Hi Scott:
Must be something new.
I can take a gander at the manual on Kodiak.
t brakes (like the Free Bird brakes on my UltraStar) do indeed specify Dexr
on II or III automatic transmission fluid, which is also red. ATF must als
o be compatible with the Hegar master cylinders that control the brakes on
my plane, since I've had no trouble. I can't speak for other types.
-Dana
Dana:
I have always used ATF in Hegar and Matco brakes. However, recently I saw
a spec sheet that called for aviation red fluid for Matco. I have never ha
d a problem with the ATF, but that is what both systems called for when I i
nstalled them some time ago.
John H.
I really like your conical covers for the K&N air filters that come on the 912.
I also have the fuel stains you describe on my engine. I wonder even more what
going through heavy rain would do to the filters, if flying through heavy
rain could get them soaked enough to induce an engine failure ? Do you know where
I can get a set of the covers that you have ?
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=219893#219893
Scott,
I really like what you did with the radiators on your Kolb, I have always thought
about moving my radiators away from behind the cage, and putting a sharp V
aluminum fairing back there like John H has. I was just not sure where to move
the radiators to... On front of the engine would be almost no drag, and keep
clean air in the prop. Where did you get the hardware to mount the radiators
on the front of the engine ? I looked at your pictures, could you post a few
pictures showing more of the mounting details ?
have !!!
http://forums.matronics.com/viewtopic.php?p=219895#219895
Jack:
Have you flown all the Kolb models?
Except for a little difference in size, weight, and power, they all fly the
same. If I remember correctly, you have only flown your FF. However, you
could crawl in a MKIII, FS, US, or Kolbra, and feel right at home after a
few take offs and landings.
Who said that?
On several occassions I have stated paper weight and balance and reality are
not always the same when it comes to Kolb aircraft. If it was, my airplane
would not fly. I didn't put the 11+ lb Maule Tundra Tailwheel on my mkIII
to prove this point, I needed a better tail wheel, but it sort of
demonstrates that paper and actuality do not agree.
John Williamson was my best flying buddy. We spent some great time together
flying cross country all over the lower 48. Our flight last May was the
best yet.
Here is the final NTSB report on John's accident. It was compiled from what
Larry Cottrell, Roger Hankins, and I saw and heard that Sunday morning, 25
May 2008. However, probable cause was determined by the NTSB agent. The
four of us have flown extensively together in this part of Oregon. To
understand what a unique experience this was, one would have to have been a
participant. We have been doing this since our first on the Alvord Desert
in 2005.
http://www.ntsb.gov/ntsb/brief.asp?ev_id 080530X00757&key=1
[quote="John Hauck"]
Accidently broke one gauge, put it into the prop ;-(, and am back to mechanical
I bet you can sync the HKS carbs mechanically using the procedure in the 912
maint manual.
John,
That is funny, just because I thought I was the only one to have ever done that
[Wink] Thank Goodness I have a Warp Drive prop, anything less would have
shattered into a million pieces. The guage was less fortunate...
I am also back to mechanical adjustment, but I am not sure how close I am getting.
Given your accuracy with mechanical sync, could you post your technique
have !!!
http://forums.matronics.com/viewtopic.php?p=219897#219897
the 912. I also have the fuel stains you describe on my engine. I wonder
even more what going through heavy rain would do to the filters, if flying
through heavy rain could get them soaked enough to induce an engine failure
? Do you know where I can get a set of the covers that you have ?
> Mike
Mike:
I have spent days flying in heavy rain with never a hint of engine miss fire
or failure with the conical K&N filters.
Did nearly lose the engine on my FS, Rotax 447, after flying through a rain
storm. It did result in a precautionary landing and I was losing power when
I turned to final in a drainage ditch south of Crystal River, Florida, in
Hernando County. Also ate up an unprotected wood prop. ;-(
I paid 385.00 for a hot water carb heat system which included the covers. I
flew with the carb heat system for a few years, then uninstalled everything
except the filter covers.
I bought them through a guy that was selling 912 powered trikes at Lakeland
about 2001.
Should be able to lay up a couple in glass if you have that particular
expertise.
First may I say "Mike...I'm happy you now have your lines. And Thank You for your
help.
I have been providing brake/fuel lines to home builders for years now, and now
and then I like to "fill in the blanks" (as it were) so that when a builder calls
me with a build I am not familiar with i can lend a hand.
Now I know full well that there are those who prefer the poly tubing due mostly
the weight (FYI: the -3 Teflon lines Mike has weigh .055 lbs per Ft.), and there
are those who use the poly line as that whats what was provided in the build.
And lastly there are builders who when they see what is given to them for
brake lines say "I'm going to trust that to stop me"?.
Now as holder of a SEL lic, I am well aware of weight and its affects. But when
I see builds like say a CH701 that are to be built and then flown in to some
rough areas.....well if it were my build I would not want poly lines (but this
is just my personal thought).
So if you are happy with the lines you have great....fly till you drop. Because
that is why you built your baby in the first place right?
But there are options. And I am always seeking those who are willing to help me.."fill
in the blanks"
Again "Thank you Mike"
Best regards to all....
Brett
Bonaco, Inc.
brett at bonacoinc.com
http://forums.matronics.com/viewtopic.php?p=219901#219901
Subject: | Antifreeze vs Waterless Coolant |
Scott:
Looks like they made a change to the Op Man:
Antifreeze: Monitor coolant and cylinder head temps.
Waterless Coolant: Monitor CHT.
Antifreeze is red lined at 245F and Waterless at 275.
John W and I chose to use Antifreeze. It is much cheaper than Waterless
Coolant and cools better. I've been using antifreeze since 1994 in the
912's. No problem and no coolant temp gauge. If this requirement had been
initiated back when I mounted the first 912, I probably would have stuck a
coolant temp sender in the system somewhere. I think the book said measured
at the pump outlet, but I may be wrong.
getting. Given your accuracy with mechanical sync, could you post your
technique ?
> Thanks,
> Mike
Mike:
It is in the maintenance book on the Kodiak web site. I do it like the book
describes. It works for me.
fire
Mike:
Need to add: The K&N filters were not covered when I was doing the flying
in heavy rain. Most of that was in Yukon Territory and British Columbia
during my 1994 flight to Alaska.
> But when I see builds like say a CH701 that are to be built and then
flown in to some rough areas.....well if it were my build I would not want
poly lines (but this is just my personal thought).
> Brett
Hi Brett:
My Kolb MKIII was built specifically to fly in very rough, sparsely
populated areas.
It has 2,800+ hours on the airframe, flights to the northernmost point of
the North American Continent in the US and Canada, Point Barrow, Alaska, and
Tuktoyaktuk, North West Territory, plus another flight to Dead Horse/Prudhoe
Bay, and numerous adventures all over the lower 48 landing in the desert,
gravel beds, roads, and even dirt airstrips.
Poly lines have been working well for me the last 2,800+ hours.
How much would a set of lines for my MKIII cost?
What is the OD and ID of your lines?
How much do Mike Welch's MKIII lines weigh?
>had a problem with the ATF, but that is what both systems called for when
>I installed them some time ago.
Both MIL-H-5606 aviation hydraulic fluid and Dexron III ATF are petroleum
based fluids (the MSDS's list them as "highly refined oils" with
additives). Both are compatible with Buna-N seals (the most common generic
seal material), although there may be other reasons not to use one or the
other. However, there are other types of ATF (ATF+4, Ford Type F, and
others) that may have a different base, I don't know. OTOH, DOT3 and DOT4
automotive brake fluids are a mixture of various glycols, which don't like
Buna but are compatible with EPDM rubber seals (but EPDM doesn't like
petroleum oils), while DOT5 brake fluid is a silicone base fluid (I once
owned a surplus postal Jeep that used DOT5). Older British cars used a
mineral based brake fluid and you could screw them up by using DOT3.
-Dana
The greatest threat to western civilization are people whose fear of
other people's liberty exceeds the love of their own.
John,
Well sir you have an outstanding aircraft there, and with the TT you have on her
I would assume that she is well taken care of as well.
I can only provide you a cost based on the lengths that Mike gave me for his build
(so I am not certain that that they would apply to yours).
-3 Teflon w/clear coat St to St 103" OVL $38.20
-3 Teflon w/clear coat St st St 90" OVL $33.30
The OD of this hose is .2995. The ID is 3/16".
Now I gave Mike several adapters (816-3D and 822-3D) not knowing just how He would
be routing the lines. If your build (or others) have -4 fittings, I can build
-3 lines with -4 nuts (with this you would not have change anything on your
build). As I had said the hose weights .055 lbs per ft.
I hope that you found this some what helpful, if you have any questions at all
please feel free to ask, or drop me a line.
Brett
http://forums.matronics.com/viewtopic.php?p=219909#219909
Hey Guys:
Got an hour flight time in today, first in nearly three months. Felt good.
Airplane did good. OAT was 70F at 2,500 feet.
Now have 301.2 hours on the new 912ULS. It is running good.
While I was roaming around out West, we had two new additions to the Gantt
International Airport family. The two resident mama burros had two little
baby burros. It is worth the effort to go over to the farm just to watch
these two clowns perform. Don't know how old they are, but not more than
two months.
These are genuine airport jackasses. They fit right in.
I to have used the K&N filters in rain. No problems while at cruse RPM. I
have had trouble after sitting on the ground waiting on light rain or misty
weather to clear with the engine not running up to full take off RPM. This
has happened on two occasions. Both times I removed the filters , the engine
ran to correct RPM. On these occasions I returned to my home airport without
problem. When the filters dried out I put them back on , no problems . The
way I see it when the engine is pulling plenty of air it will keep the
filter pods clear. When left sitting the water build up will prevent
sufficent air to pass though the filters reducing HP . Flying in rain is no
fun and it chews up those wooden props fast.
Tony
Downunder
MK111c 503
Sent: Thursday, December 18, 2008 4:28 PM
Subject: Re: Kolb-List: Re: Engine Installation
> fire
> Mike:
> john h
> mkIII
Thanks for the jump. It helped to explain what happened.
Jack B Hart FF004
Winchester, IN
Here's a very simple, accurate, gage you can build in ten minutes for about 5 bucks.
Buy about 6 ft of clear plastic tubing, sized to fit the nipple on your
carb or manifold. Fill the tube about half way with some oil (I used pretty blue
two stroke oil) Form a low loop with the ends attached to the carbs and tape
the whole affair in place with the part with the oil in it parallel and touching
each other (make sense). If you are working on a hks you can remove the
prop to make things easier and much safer.
The hks doesn't mind being run with no prop ( I keep the revs below around 3500)
The carbs should be mechanically synchronized before you start the engine or
the oil will quickly get sucked into the weaker carb. As you adjust the carbs
the oil level will move toward the weaker carb. It is quite easy to get the
carbs perfectly balanced ! By the way, I did it without the prop, then checked
it with the prop and it made no difference, other than the engine ran much smoother
with no prop.
cheers, Rob
http://forums.matronics.com/viewtopic.php?p=219945#219945
Subject: | Re: Video Camcorder Editing Help. |
Possums wrote:
> I use Studio 10 - but the new version is Studio 12 - not free - about $50
Pinnacle Studio 11 is the best video editing program I have ever used. It does
everything, simple to elaborate, and is super easy to use.
I have tried others, Adobe does everything, but you need to spend a month figuring
out how to use it, everything is a hard with that program. Sony Vegas is
much to limited in what it can do.
Windows Movie maker that comes with Windows XP is good, and free, for simple editing,
and most importantly, easy and quick to use.
have !!!
http://forums.matronics.com/viewtopic.php?p=219949#219949
From: | william sullivan <williamtsullivan(at)att.net> |
- Thanks for the pictures, John.- Brings back a lot of memories.- Wha
t was the ground temp?- 31 degrees, going to 40 today.- Heavy snow tomo
rrow, so I have welding to do.- The front frame of the Firestar is done,
except for the small brackets.- I ordered the fuselage tube from Travis y
esterday.
----- Bill Sullivan
----- Windsor Locks, Ct.
Bill:
I don't know what the ground temp was, but today they are forecasting 77F.
So far it is rats - 3 and me - 0. That have tripped the rat traps three ti
mes, liked the peanut butter off clean, without getting caught.
Glue traps didn't work, except to catch broke crickets.
Decon rat poison, put out four trays, was gone the first night.
I was able to salvage enough undamaged parts to make up seat belt and shoul
der harness for the pilots seat. That is why I got to fly yesterday.
As far as I know, the only damage was the seat belt/shoulder harness, 12VDC
power wire to my ANR headset, power socket for my electric vest, and the 2
" wide velcro strap I use to secure my GPS to my leg. Still have my finger
s crossed they didn't cut wires I could not see. My strobes, nav lights, e
lectric fuel pump, mag switch, all performed normally. The radio and inter
com also were operational. First time the rats got me I lost radio and int
ercom. They even tried to chew into the kevlar bridals on the parachute.
Thanks for the pictures, John. Brings back a lot of memories. W
hat was the ground temp? 31 degrees, going to 40 today. Heavy snow tomorr
ow, so I have welding to do. The front frame of the Firestar is done, exce
pt for the small brackets. I ordered the fuselage tube from Travis yesterd
ay.
Bill Sulliv
an
Windsor Loc
ks, Ct.
> Scott
The last time I visited with LEAF about water temp, I was interested in
putting in a thermostat to control min. water temps so my heater would work
better in cool temps.... I was told that there was no minimum water
temp... only a maximum temp. that is why there was no provision for a
thermostat in the system.
Boyd Young
MKIIIC
Utah
First time the rats got me I lost radio and intercom. They even tried
to chew into the kevlar bridals on the parachute.>>
Good grief John, that is serious business. The worst I have had, so far,
in spite of being hangared on a farm is a bug up the pitot. Mind you
that nearly gave me heart failure as the ASI wound backwards in the
middle of the climb out. Trouble is that the first thing that happens
when the apparent speed drops off is to stuff the nose down without
thinking . Not until I looked for an horizon did I realise what was
happening.
77 degrees.? Very comfortable. Here it is just above freezing and we
have had torrential rain with which the fields have been unable to cope
so there have been floods all around the area. Joys of winter.
Cheers, and a ratfree Christmas
Pat
Yeah, Larry I did it. two inexpensive vacuum gauges @ $20 + two inline
valves @ 10 + plus fittings and lines $10 to $15 depending on application. +
shipping.Who said it was a one time thing? After I got my carbs set the
CHT's and EGT's were dead even at all times 5 degree spread for the CHT's
and 25 for the EGT's, but always in that range. When the carb boots started
to leak the temp spreads grew. I went back to the vacuum gauges to get a
reading and reset. Temp spread grew again. Time to look elsewhere. Found
rotted carb sockets.
Even if you don't use it as a diagnostic tool, what about every annual?
Having balanced carbs is paramount for the best fuel economy and engine
performance, why would you not include it as an item on your annual?
Rick
> Larry C
Sent: Thursday, December 18, 2008 12:18 PM
Subject: Re: Kolb-List: parts needed for sync of dual carbs
application. + shipping.
Who said it was a one time thing? After I got my carbs set the CHT's
and EGT's were dead even at all times 5 degree spread for the CHT's and
annual? Having balanced carbs is paramount for the best fuel economy and
engine performance, why would you not include it as an item on your
annual?
Rick
Thanks guy's, I appreciate the help. I have a new baqttery on order
and will give it a try as soon as I get it. It is much too cold to do
much now.
Larry C
>three times, liked the peanut butter off clean, without getting caught.
Dear Investors,
This is of the utmost urgency. The following is the "sleeper of all
sleepers." Please send your check in the amount of $50,000
immediately. We are limiting each participant to one unit. You can
understand after reading this once in a lifetime offer.
A group of us are considering investing in a large cat ranch near
Hermosillo, Mexico. It is our purpose to start rather small with
about one million cats. Each cat averages about twelve kittens a
year; skins can be sold for about 20 cents for the white ones and up
to 40 cents for the black. This will give us twelve million cat skins
per year to sell at an average price of around 32 cents, making our
gross revenue about $3 million a year. This really averages out to
about $10,000 a day (excluding Sundays and holidays, of course).
A good Mexican cat man can skin about 50 cats each day, at a wage of
$13.15 a day. It will take 663 men to operate the ranch, so the net
profit would be over $8,200 per day. Your $50,000 investment would be
recovered in 6.1 days, which beats the stock market don't ya know.
Now, the cats would be fed on rats exclusively. Rats multiply four
times faster than cats. We would start a rat ranch adjacent to our
cat farm for the rats. If we start with a million rats, we will have
four rats per cat per day. The rats will be fed on the carcasses of
the cats that we skin. This will give each rat a quarter of a cat.
You can see by this that the business is a clean operation;
self-supporting and really automatic throughout. The cats will eat
the rats and the rats will eat the cats and we will get the skins
Time is of the essence. Any hesitation on your part would be sheer
disaster. Become a millionaire with us through knowledgeable investments.
Send your cashier's check today to:
Possums Inc.
Kennesaw,
Georgia, USA, Earth
From: | william sullivan <williamtsullivan(at)ATT.NET> |
- Russ- You have to get really close for the plastic capsule birdshot to
work- 15 feet or so.- the advantage is that you can work around animals,
people, and equipment with almost no worry.- Lots of sport, and you have
to be quick with a second shot.- At 15 feet, they won't go through both s
ides of a cardboard box.- I know it won't hurt the tires, but maybe the p
lastic brake lines.
- Finished all the welding today- including control brackets.- The aile
ron control rods will be made up when I mount the wings.- The main engine
mount tube was replaced, and I made up a new front cage.- Cost so far -
including rivets for the wings (completed minus Stits)- is just under $200.
- Labor overall is about 20 hours.- No problems, so far.-
- Bill Sullivan
Possums,
What a wonderful business opportunity (unless, of course, you happen to be a
cat or a rat).
This plan has all the promise of your finest government program. Highly profitable,
self-
supportive, tremendous positives all around. Promises abound!!!
I'll run down to my local Post Office tomorrow and submit my tax payment...er,
investment.
I can't wait to see the millions and millions of dollars roll in.
I beg your indulgence to make a special allowance in my case, (you know..."just
for you"),
Please allow me to purchase four units immediately ($200,000).
Mike Welch
Can't wait till the money rolls in!!!
PS. BTW, have you considered locating near Detroit? If I'm not mistaken, there
are about to be
a huge unemployed work force very soon. I'm sure they'll work cheap, then!
Dear Investors,
This is of the utmost urgency. The following is the "sleeper of all sleepers."
Please send your check in the amount of $50,000 immediately. We are limiting each
participant to one unit. You can understand after reading this once in a lifetime
offer.
A group of us are considering investing in a large cat ranch near Hermosillo, Mexico.
It is our purpose to start rather small with about one million cats. Each
cat averages about twelve kittens a year; skins can be sold for about 20 cents
for the white ones and up to 40 cents for the black. This will give us twelve
million cat skins per year to sell at an average price of around 32 cents,
making our gross revenue about $3 million a year. This really averages out to
A good Mexican cat man can skin about 50 cats each day, at a wage of $13.15 a day.
It will take 663 men to operate the ranch, so the net profit would be over
$8,200 per day. Your $50,000 investment would be recovered in 6.1 days, which
Now, the cats would be fed on rats exclusively. Rats multiply four times faster
than cats. We would start a rat ranch adjacent to our cat farm for the rats.
If we start with a million rats, we will have four rats per cat per day. The rats
will be fed on the carcasses of the cats that we skin. This will give each
rat a quarter of a cat. You can see by this that the business is a clean operation;
self-supporting and really automatic throughout. The cats will eat the
Time is of the essence. Any hesitation on your part would be sheer disaster. Become
Possums Inc.
Kennesaw,
Georgia, USA, Earth
Send e-mail anywhere. No map, no compass.
http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anywhere_122008
I tried to tell you... drown 'em. No rat can swim for very long.
-- R
Hi,
A little advice from a "never failed yet" trapper. If the rats are
licking the P Butter from the pan, there are two ways to handle it.
Firstly it may not be rats, it may be mice that are not heavy enough to
trip the trap. I would put lots of mouse traps around or a live trap
that will take care of the little ones. The other thing you can do is to
dig enough ground out to bury the trap. It would need to be by a wall
where you could hang your bait high enough that the rat would have to
stretch to reach the bait. You, I assume have a steel trap with a pan,
if so tear off a small piece of cloth and lay over the trigger and pan,
but not over the jaws. The idea is to keep the dirt from sifting under
the pan and keep the trap from springing. Sift the dirt over the jaws
just enough to conceal the trap, but the bare minimum necessary to hide
it. What you are trying to do is to lure the rat into walking up to the
wall and trying to reach the food that is dangling just out of reach,
thus stepping into a trap that it does not know is there. Rats generally
run along walls and natural corridors, so even if they don't smell the
bait, (unlikely) they have a chance to step into the trap. If there are
isolated points of entrance bury a trap there. If they run the walls,
such as on a 2x4, place a trap there where they can't avoid it.
Karen and I put the wings on the Firestar today, wind is howling, cold
as a well diggers butt!
Larry C
Carb sockets from rotax just don't hold up .The JBM rubber sockets, boots replaced
the originals at 150 hrs and were still on it and in good working order when
I sold it at 600+ hrs, plus they cost less!? 503DCDI.
??????????????????????????????????????????? G.Aman mk3-C Jabiru 2200 400hrs
-----Original Message-----
Sent: Thu, 18 Dec 2008 11:18 am
Yeah, Larry I did it. two inexpensive vacuum gauges @ $20 + two inline valves @
10 + plus fittings and lines $10 to $15 depending on application. + shipping.
Who said it was a one time thing? After I got my carbs set the CHT's and EGT's
were dead even at all times 5 degree spread for the CHT's and 25 for the EGT's,
but always in that range. When the carb boots started to leak the temp spreads
grew. I went back to the vacuum gauges to get a reading and reset. Temp spread
grew again. Time to look elsewhere. Found rotted carb sockets.
Even if you don't use it as a diagnostic tool, what about every annual? Having
balanced carbs is paramount for the best fuel economy and engine performance,
Rick
$79.00, Seems like a lot of money for a one time use. Would it be worthwhile to
build one from available parts? Any body done it?
Larry C
From: | "grantr" <grant_richardson25(at)yahoo.com> |
John,
I started having the same problem with them licking the peanut butter off.
I found a way to fix that. Get a jar of roasted peanuts and take a half peanut
and push it through the trigger mechanism between the catch for the rod and
the bait holder. You need a nut that is a little big then push it through.
This will shave off part of it so it fits snug. Then put peanut butter on it.
The mouse will lick of the PB and then it will get greedy and try to get the nut
and pow! I caught two tiny ones on mouse traps with this method.
Are you using Victor traps which have the brass colored metal trigger catch?
These are the best snap traps.
The Black Cats from Lowes with the plastic trigger that looks like cheese are terrible.
They will not snap if I touch the trigger.
http://forums.matronics.com/viewtopic.php?p=220122#220122
Thanks everyone,
I downloaded Video Spin by Pinnacle for free and I really like it. Its very easy
to use and does what I need it to do.
http://forums.matronics.com/viewtopic.php?p=220123#220123
Subject: | Re: What is your Altitude loss in a 180 degree turn? |
John,
Did you get a chance to see what your altitude loss was with the engine off?
http://forums.matronics.com/viewtopic.php?p=220125#220125
I will be sending a check immediately drawn on my Madoff Investor's
account.
BB
>> caught.
> Dear Investors,
> up to 40 cents for the black. This will give us twelve million cat
> averages out to about $10,000 a day (excluding Sundays and
> of $13.15 a day. It will take 663 men to operate the ranch, so the
> net profit would be over $8,200 per day. Your $50,000 investment
> would be recovered in 6.1 days, which beats the stock market don't
> ya know.
December 08, 2008 - December 19, 2008
Kolb-Archive.digest.vol-hw
