Kolb-Archive.digest.vol-ia
February 25, 2009 - March 11, 2009
Subject: | Re: Another *$#(% prop strike! |
Go to this URL:
http://www.eaa.org/video/homebuilders.html
then, under the "General" tab, scroll down to find Composite Propeller Repair.
-- Robert
On Wed, Feb 25, 2009 at 11:26 AM, John Bickham wrote:
> I've done it again! Something went through the prop. I haven't figured what it
was yet. This happened after a carb sync was completed. I was fiddling with
some stuff and may have left something loose up there.
> Now I have ding in my warp and a hole in the top of my right flap to patch.
> As far as the Warp, I'm not sure how to proceed. I think I can just press the
bulge back to shape under the tape and be OK. Any experience or suggestions appreciated.
> Working on patch on Aerothane. Just trying to getting "patches" ready for MV.
Need to get some extended butt time. Hopefully that will be the only weak link.
> Thanks too much,
> John Bickham
> Mark III-C w/ 912UL
> St. Francisville, LA
> Landing a plane and being married - a few smooth moments mixed with a lot of
rough ones.
> http://forums.matronics.com/viewtopic.php?p=232048#232048
> http://forums.matronics.com//files/img_1628_199.jpg
> http://forums.matronics.com//files/img_1626_167.jpg
> http://forums.matronics.com//files/img_1625_110.jpg
it was yet. This happened after a carb sync was completed. I was fiddling with
The carb sync is proving to be hazardous to props [Evil or Very Mad] That makes
3 of us now victims of this, You, John H, and Myself. If you call Daryl
at Warp Drive, he is the expert and will tell you the best way to repair that
prop.
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=232087#232087
Subject: | Re: xtra wingtip mods |
The idea of a little air-turning gizmo sticking out could work>>
What about fitting a few VG`s?.
Pat
Subject: | Another *$#(% prop strike! |
Follow this link
scroll down to Composite Propeller Repair
watch video
Enjoy
George
-----Original Message-----
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Bickham
Sent: Wednesday, February 25, 2009 11:27 AM
Subject: Kolb-List: Another *$#(% prop strike!
what it was yet. This happened after a carb sync was completed. I was
fiddling with some stuff and may have left something loose up there.
the bulge back to shape under the tape and be OK. Any experience or
MV. Need to get some extended butt time. Hopefully that will be the only
weak link.
Thanks too much,
John Bickham
Mark III-C w/ 912UL
rough ones.
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
I put a few VGs on the side (rear edge of the doors) of my MKIIIC a few
years ago. I didn't effect the speed but it did reduce the noise from
turbulent air hitting the side of the rear cage. My cage is fully enclosed
like John H's plane.
Rick Neilsen
Redrive VW powered MKIIIC
----- Original Message -----
Sent: Wednesday, February 25, 2009 3:42 PM
Subject: Re: Kolb-List: Re: xtra wingtip mods
> Pat
my kolb is ugly enough now. That would elevate it to creepy.
BB
> Pat
Subject: | Re: Nauga Field NOTAMs (LS35) |
Boy these guys are getting soft. Next they will want "hot" water for
their shower, then bunks in a building, followed by mattresses,
coffee each morning, and finally a little golf cart to haul them out
to their little airplanes.
jerb
At 11:38 AM 2/25/2009, you wrote:
>Sounds great.
>I know you wish that damn power line was out of there. Looks high
>enough to land under it now that those tall trees are gone. Really
>opened up that area.
>Water sounds good. Can we take a shower at the cabin now instead of
>the fire house?
>john h
>mkIII
> their shower, then bunks in a building, followed by mattresses, coffee
> each morning, and finally a little golf cart to haul them out to their
> little airplanes.
> jerb
We have all the rest of that stuff already. Actually, the ATV ride to the
fire house was the only inconvenience we had to endure during the last two
Nauga Flyins.
We'll be living high on the hog this year.
Y'all enjoy your trip and please be careful.
jerb
>>out to their little airplanes.
>>jerb
>to the fire house was the only inconvenience we had to endure during
>the last two Nauga Flyins.
>john h
>mkIII
Subject: | wrinkled Poly Fiber |
Kolb people=2C
I purchased my Kolb MkIII just over 10 years ago. Around the time I purc
hased the plane from the old Kolb Co.=2C I purchased the complete Poly Fibe
r covering kit=2C including most of the Poly Tone paint=2C from Jim and Don
di.
One of the problems with not building your plane in a timely manner is th
at some things "go bad". Examples of this are Poly Tak that turns brownish
=2C rendering it useless. All the solids in the Poly Spray and Poly Tone s
ettle on the bottom of the can=2C making a very solid mud. Lots of work to
get them remixed.
My Poly Fiber fabric=2C which may or may not have been on a 5 foot tube r
oll=2C has been folded=2C and taken on wrinkles that are virtually impossib
le to get out. When I try to glue these wrinkles down with (new) Poly Tak
=2C it still won't hold them down. What a pain!
I figured out a way to fix the wrinkles. I made a big ironing board on a
blanket over a sheet of plywood. I got my iron out=2C and ironed and iron
ed=2C till those lines were gone. I found it took a fairly high setting=2C
but eventually all those suckers were gone.
Mike Welch
MkIII
Access your email online and on the go with Windows Live Hotmail.
http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_AE_Access_0220
09
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: wrinkled Poly Fiber |
Date: Fri, 27 Feb 2009 15:27:11 -0800
blanket over a sheet of plywood. I got my iron out, and ironed and ironed,
till those lines were gone. I found it took a fairly high setting, but
Mike,
No way to say it but this was not a good solution. You have just pre shrunk
all of your cloth. Do not use it.
Jack B.
> shrunk
> Jack B.
Jack/Mike W/Gang:
That was my first thought, but before I sh-t canned the "FABRIC" (airplanes
don't use cloth for covering), I'd ascertain how hot the iron was when I was
busy ironing out the wrinkles. If it was no more than 250F or so, I would
feel comfortable using it.
This would have been a good time for Mike to call Jim Miller, before he took
the iron to his fabric.
Most of the fabric I see on our Kolb airplanes are not shrunk tight enough,
primarily for fear of bending something. All my stuff is bent, but the
fabric is tight as a drum. Maybe that is why it flies faster than most of
its contemporaries???
When I am shrinking fabric, my fabric is smoking. ;-)
Mike:
Take your dope and paint to wal-mart or lowe's. Those folks in the paint d
epartment will be more than happy to shake your cans. ;-) That is what I
do with paint that has been hibernating for years.
that some things "go bad". Examples of this are Poly Tak that turns brown
ish, rendering it useless. All the solids in the Poly Spray and Poly Tone
settle on the bottom of the can, making a very solid mud. Lots of work to
get them remixed.
Mike Welch
MkIII
> Fabric is a noun - a cloth, made by weaving, knitting, or felting
> fibers. -
> dictionary.reference.com
> Jack B. Hart FF004
Jack:
Forget the dictionary.
Calling aircraft covering cloth is like calling the instrument panel the
dash board. ;-)
Or.........calling aircraft tubing pipe.
>dash board. ;-)
As bad as calling it "canvas"???
-Dana
The most valuable function performed by the federal government is
entertainment.
From: | william sullivan <williamtsullivan(at)att.net> |
Subject: | Re: Kolb List: wrinkled Poly Fiber |
- Mike- About how many hours to cover a wing?- Not including paint.
-------------------- Bill Sullivan
-------------------- Windsor Locks,
Ct.
-------------------- FS 447
You should be able to cover a wing thru Poly brush in a couple of days.
The problem Mike is having is that he does some work, and then sits in the
airplane making VROOM noises chasing the red baron!!!
I found out early if you count those hrs in the build time you have a 10,000
hr airplane!! HAHAHA
I'm one to talk, I've been working on my MK III for 10 years also.
Oak Grove MO
Do No Archive
_____
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of william sullivan
Sent: Saturday, February 28, 2009 9:50 AM
Subject: Kolb-List: Re: Kolb List: wrinkled Poly Fiber
Mike- About how many hours to cover a wing? Not including paint.
Bill Sullivan
Windsor Locks, Ct.
FS 447
From: | "Aaron Gustafson" <agustafson(at)chartermi.net> |
Subject: | Kolb intro dates |
Can someone tell me the date of the first MK 3C kit built or sold and
also same for original Firestar. Thanks Aaron Gustafson building MK 3C
& previously Firestar 2
Bill=2C
In my experience=2C on a MkIII wing=2C it will take a week or so of dedic
ated work to completely finish it. Subtract a day of so for the paint=2C a
nd I'd think you'd be around three days=2C and likely into the 4th day=2C t
o get to the Poly Spray being on.
A smaller wing=2C like an UltraStar=2C would be quite a bit easier. Mayb
e knock a day or two off.
Boyd=2C
You're right. Most of my computer time is because I'm taking a "fume bre
ak".
Even though I have a respirator=2C the job is intensive. Back to work....
Express your personality in color! Preview and select themes for Hotmail=AE
http://www.windowslive-hotmail.com/LearnMore/personalize.aspx?ocid=TXT_MS
GTX_WL_HM_express_032009#colortheme
Subject: | Re: firestar first flight |
Great job on flying that Firestar only 10 months after you bought the kit !!!
You also chose the perfect engine for it, you will have a really great time with
that plane.
have !!!
http://forums.matronics.com/viewtopic.php?p=232452#232452
Subject: | Can you help out a guy down on his luck? |
Hmm=2C Jerb.
I think I might give that a check out. After all=2C I only need the tape
for the lower surface.
I had enough to do the top.
I think the bottom has much less demand placed on it=2C compared to the t
op.
Mike Welch
Windows Live=99 Groups: Create an online spot for your favorite groups to m
eet.
http://windowslive.com/online/groups?ocid=TXT_TAGLM_WL_groups_032009
Subject: | Re: Can you help out a guy down on his luck? |
I have two rolls to use on my next
project...and I am perfectly satisfied that it
will work just fine.. That said...I haven't
checked to make sure that it will burn through with a soldering iron...Herb
ps I will use it top and bottom...
At 12:40 PM 2/28/2009, you wrote:
>Hmm, Jerb.
> all, I only need the tape for the lower surface.
> I think the bottom has much less demand placed on it, compared to the
top.
>Mike Welch
>your favorite groups to meet.
><http://windowslive.com/online/groups?ocid=TXT_TAGLM_WL_groups_032009>Che
ck
>it out.
I apologize for not scaling that pic down. My mail even kicked it back.
The support tubing is fastened to the engine so they shake in
unison. Reasoning is so that
the hose nipples won't fatigue as early. The whole works is now
behind a fairing.
The oil cooler, hoses and integral filter mount/thermostat are from
Summit.
BB
