Kolb-Archive.digest.vol-ib
March 11, 2009 - March 25, 2009
      Yes, if you make a sharp turn when turning fast... same as the difference
      between the sports car and the SUV in a sharp turn (that IS due to the
      higher CG; a separate issue from wind effects).  It doesn't effect how you
      use your controls for crosswind taxiing; if anything it _reduces_ or slows
      the immediate felt effect of a gust (but may require more correction if you
      let it go farther).
      -Dana
        A seminar on Time Travel will be held two weeks ago.
Subject: Re: 'Vertical' CG
Date: Mar 11, 2009
Hey Rick: Way over my head. Do we have a problem with "vertical CG" on our Kolbs? I don't think I have ever encountered the phenomenon. john h mkIII I do know that to say categorically it has no effect is ridiculous on it s face. Rick ________________________________________________________________________________
Date: Mar 11, 2009
Y'all; Now let me see this from that, All this vertical CG mess. Seems to me we are strictly hypothetical in what a vertical CG does. In referring to Bro John's MKIII, of where his fuel tank is located and the effect of a vertical CG, seems to me is not relevant at all. Comparing a Cessna with the fuel tanks in the wings to The MKIII Classic with the fuel tank located on the center line is totally out of kilter. The fact is that John's fuel tank is located below the wing level and inboard of the cage. A Cessna has its fuel tanks outboard of the fuselage and at wing level. I can see where the fuel tanks being located outboard of the fuselage would make a difference in ground control, but not with the fuel tank located on the center line below the wings. If the fuel tank was located above the wing some distance and outboard on the center of the fuselage, then I could see where the weight of fuel would effect ground handling. So if vertical CG is so dang important, How do you compensate for it when you have a full tank of fuel or an almost empty tank. Maybe I ain't edumacated enough to figger this out:) Jim Hauck ________________________________________________________________________________
Subject: Re: Fuel tax credit for MOGAS burned in aircraft
Date: Mar 11, 2009
Jon, Are either you or your wife's cookies going to be in MV this year? Larry ----- Original Message ----- From: Jon LaVasseur To: kolb-list(at)matronics.com Sent: Wednesday, March 11, 2009 1:43 PM Subject: Kolb-List: Fuel tax credit for MOGAS burned in aircraft Dear Flying Friends, Tax time is here again and I just thought a reminder about fuel tax would be a good idea. If you use mogas in your plane, the federal folks will issue a tax credit which means that each dollar of credit reduces your income tax by one dollar. You just fill out form #4136 and enter the amount on line 68 of your 1040 tax return. If you live in Minnesota, the state will refund you $.15 for each gallon you have burned in your plane. The Minnesota form is "PDR-1 AV." Fill our PDR-1 AV and send it in with the ACTUAL receipts and the nice folks in St. Paul will send you money back. Be sure you have your form in by April 15, 2009. Other states probably have similar refunds. Hope this is helpful to someone Jon L. ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/11/09 08:28:00 ________________________________________________________________________________
Date: Mar 11, 2009
Larry C: Great minds think alike. ;-) john h mkIII Jon, Are either you or your wife's cookies going to be in MV this year? Larry ________________________________________________________________________________
Date: Mar 11, 2009
Russ; Naw you ain't opened no can of worms. But If I remember the center of gravity is the center of mass as applied to a none moving object or a moving object, but in this case it is a none moving critter. So in reality, John's center of gravity is at the lower portion of his fuel tank and should just fine. Jim Hauck ________________________________________________________________________________
Date: Mar 11, 2009
Jim, Thanx reply. But the CG is the point that the aircraft rotates around -- unless i'm nuts (possible) that's the same, moving or not. The aircraft rotates in, any axis, around the CG. Only way to change the CG is to move weights around. Fuel tanks & passenger seats are often located on or near the CG, so no major changes when they're full or empty. But you know all this. And I'm sure no problem with John's or any other(?) Kolb . Russ On Mar 11, 2009, at 8:35 PM, Jim Hauck wrote: > > Russ; > > Naw you ain't opened no can of worms. > > But If I remember the center of gravity is the center of mass as > applied to a none moving object or a moving object, but in this > case it is a none moving critter. So in reality, John's center of > gravity is at the lower portion of his fuel tank and should just fine. > > Jim Hauck > > ________________________________________________________________________________
Date: Mar 11, 2009
Gyro planes are sensitive to vertical cg vs thrustline. It really effects the stability of them. They really need centerline thrust to be considered stable. Many of the old ones like the original air commands and the RAFs have high thrustlines. The gyros can be flipped forward in flight due to an effect know as a power push over. That is where the thrust is so offset above the vertical cg that it pushes the nose of the gyroplane down thus getting air on top of the rotor and thats the end of that flight and pilot. Think of the vertical cg location as the pivot point as the thrust pushes the nose over. high thrust lines coupled with no horizontal stabs have contributed to many gyroplane fatal crashes. Even with the addition of H stab they are still not stable but better than without. I dont think fixed wing has a problem with vertical cg. If our thrust line gets to high we offset it with tail incidence. Plus our tail is a lot further back than a gyro. The newer center line thrust gyros have some ground handling issue due to the mass being so high up. Check out http://www.rotorflightdynamicsinc.com Dominator or ultrawhite. Its actually a low thrustline design which is very stable in flight. On the ground though it can be easily rolled over. Airplane generally sit low so I dont see it as an issue there. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234295#234295 ________________________________________________________________________________
Date: Mar 11, 2009
It's true! In Michigan we got .16 a gallon back from the state ...you had to send the original receipt with a form the state gave you then they send you a check! Feds gave back .14 at tax time for the year.Just put in what you claimed for the state. It's the road tax you are getting back...don't get caught putting it in your car though... chris ambrose m3x-jab N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234299#234299 ________________________________________________________________________________
Date: Mar 11, 2009
I'm surprised that Boyd didn't chip in as well. Larry ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Wednesday, March 11, 2009 6:29 PM Subject: Re: Kolb-List: Fuel tax credit for MOGAS burned in aircraft Larry C: Great minds think alike. ;-) john h mkIII Jon, Are either you or your wife's cookies going to be in MV this year? Larry ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/11/09 08:28:00 ________________________________________________________________________________
Subject: Re: Fjuel rtanks
Date: Mar 12, 2009
John I should have been more specific. I found (boat) bow tanks for a couple hundred that look like they would fit pretty well up top behind heads as mine doesn't turn around that far either. I can barely reach the flap handle. Just your oppinion, would an 19 gal wedge shaped tank HAVE to be baffled? I don't know yet if it is. Vic Xtra 912 3.5hrs legal insruction ________________________________________________________________________________
Date: Mar 12, 2009
> Just your oppinion, would an 19 gal wedge shaped tank HAVE to be baffled? I don't know yet if it is. > > Vic Vic: I don't know that I can answer that. I don't know how much a "baffleless" tank would affect flight and handling characteristics. If it were my airplane, I'd spend the bucks, have an aluminum tank built to order with baffles. john h mkIII ________________________________________________________________________________
Date: Mar 12, 2009
Subject: Trailer (Kolb) Dolly discounted
Good morning all, I want to give a heads-up to anyone who may be interested about a sale on trailer dollys from Northern Tool. There's been talk and kidding about moving our Kolbs by hand on the ground, getting old, etc. The dolly I have now I got with my US and the wheels are solid wagon-type wheels spaced very close together. As a consequence, the dolly tends to want to roll on its side when doing a sharp turn. Northern Tool has an _email subscribers only sale_ for a trailer dolly with 10" pneumatic wheels with a wider, more stable spacing. It's marked down from $60 to $40, plus shipping. It comes with a ball for moving trailers, but it looks like it will be a simple job to remove the ball and replace it with the tailwheel cradle that's on my dolly. I may even try to find a way to alter the cradle so I can "scoop" the tailwheel, rather than lift the tail into the cradle. What's that about getting old? I'm not sure if it will work if you're not presently a subscriber, but you may want to go to northerntool.com and subscribe for their email promos, because this sale price is good until 3/17. Getting my FF prepped for flying weather here in PA and find myself frequently whispering thanks as I work, to Don, the genius builder, for putting together such a fine - and beautiful - FireFly. His workmanship is meticulous. A huge thank you, Don!! Dave Kulp Bethlehem, PA FireFly 098 ________________________________________________________________________________
Date: Mar 12, 2009
I do believe that any tank over 10 gallons has to be baffled. Jim Hauck ________________________________________________________________________________
Subject: Re: Trailer (Kolb) Dolly discounted
Date: Mar 12, 2009
Dave, Harbor Freight has the same thing. Sometimes on sale for less. I have one hooked to my tail right now. BB On 12, Mar 2009, at 11:43 AM, Dave Kulp wrote: > Good morning all, > > I want to give a heads-up to anyone who may be interested about a > sale on trailer dollys from Northern Tool. There's been talk and > kidding about moving our Kolbs by hand on the ground, getting old, > etc. The dolly I have now I got with my US and the wheels are > solid wagon-type wheels spaced very close together. As a > consequence, the dolly tends to want to roll on its side when > doing a sharp turn. > > Northern Tool has an email subscribers only sale for a trailer > dolly with 10" pneumatic wheels with a wider, more stable spacing. > It's marked down from $60 to $40, plus shipping. It comes with a > ball for moving trailers, but it looks like it will be a simple job > to remove the ball and replace it with the tailwheel cradle that's > on my dolly. I may even try to find a way to alter the cradle so I > can "scoop" the tailwheel, rather than lift the tail into the > cradle. What's that about getting old? > > I'm not sure if it will work if you're not presently a subscriber, > but you may want to go to northerntool.com and subscribe for their > email promos, because this sale price is good until 3/17. > > Getting my FF prepped for flying weather here in PA and find myself > frequently whispering thanks as I work, to Don, the genius builder, > for putting together such a fine - and beautiful - FireFly. His > workmanship is meticulous. A huge thank you, Don!! > > Dave Kulp > Bethlehem, PA > FireFly 098 > > ________________________________________________________________________________
Date: Mar 12, 2009
Interesting Info Grant, Which is exactly why I will never be flying a Gyro Plane [Wink] The performance is pretty incredible but having to depend on moving rotors to keep me from falling like a rock just does not sound fun... I know John H spent many hours hanging in the air by rotors and lived through it, but there is a big difference between a helicopter developed by Bell Helicopters and flown for millions of hours, and a home made gyrocopter designed and tested by people with limited resources and funds ! Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234344#234344 ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Mar 12, 2009
Vic Would you share with us what you found? I'm still looking for a larger tank that I can put in my MKIIIC. I have been told the New Kolb tanks will not fit. If a alternative tank looked good and priced right I would consider one. If the tank didn't have baffles I would install a small header tank 1-2 gallons below it. The header tank would supply a constant flow of fuel in spite of any sloshing of fuel in a unbaffled main tank. Again worth what you paid for it. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: Vic To: kolb-list(at)matronics.com Sent: Thursday, March 12, 2009 10:23 AM Subject: Re: Kolb-List: Re: Fjuel rtanks John I should have been more specific. I found (boat) bow tanks for a couple hundred that look like they would fit pretty well up top behind heads as mine doesn't turn around that far either. I can barely reach the flap handle. Just your oppinion, would an 19 gal wedge shaped tank HAVE to be baffled? I don't know yet if it is. Vic Xtra 912 3.5hrs legal insruction ________________________________________________________________________________
Date: Mar 12, 2009
On Thu, Mar 12, 2009 at 11:50 AM, JetPilot wrote: > ...home made gyrocopter designed and tested by people with limited > resources and funds !.... > Yeah, sort of like a home made Kolb MkIII, built and tested by people with limited resources and funds !.... Oooo, that's scary! ;-) -- R ________________________________________________________________________________
Date: Mar 12, 2009
Rick -- TNK 6 gallon tanks do fit in the MkIII Classic... They did in mine, at least. -- Robert On Thu, Mar 12, 2009 at 1:05 PM, Richard & Martha Neilsen < NeilsenRM(at)comcast.net> wrote: > Vic > > Would you share with us what you found? I'm still looking for a larger tank > that I can put in my MKIIIC. I have been told the New Kolb tanks will not > fit. If a alternative tank looked good and priced right I would consider > one. If the tank didn't have baffles I would install a small header tank 1-2 > gallons below it. The header tank would supply a constant flow of fuel in > spite of any sloshing of fuel in a unbaffled main tank. > > Again worth what you paid for it. > > Rick Neilsen > Redrive VW powered MKIIIC > > ----- Original Message ----- > *From:* Vic > *To:* kolb-list(at)matronics.com > *Sent:* Thursday, March 12, 2009 10:23 AM > *Subject:* Re: Kolb-List: Re: Fjuel rtanks > > John > I should have been more specific. I found (boat) bow tanks for a couple > hundred that look > like they would fit pretty well up top behind heads as mine doesn't turn > around that far either. > I can barely reach the flap handle. > Just your oppinion, would an 19 gal wedge shaped tank HAVE to be baffled? I > don't know yet if it is. > > Vic > Xtra 912 > 3.5hrs legal insruction > > > * > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Subject: Re: Wing Center Section
Date: Mar 12, 2009
From: "Kirby, Dennis CTR USAF AFMC MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
"icrashrc" wrote: << We made the shape we wanted over the plane, then made our center section, then made a mold over the center section. There hasn't been a part pulled from the mold yet. If we decide to offer a few for sale then that would be next. Scott >> Scott, and All - Nice work on your center section. I have always suspected that this junction on the stock Mark-3 - where he top of the windshield meets the gap seal - was a MAJOR source of aerodynamic drag. I noticed that on the Mark-3 XTra, there is a nifty little fairing that attaches at this spot, smoothing out the airflow coming up from the windshield and over the top of the gap seal. When I called Travis at New Kolb if I could order one, he told me that it only fits on the Xtra, not the "Classic." Bummer. I have zero composite/fiberglass building skills. And so ... Scott - if you do decide to make more than one of these little beauties, I for one will be happy to buy one from you! Dennis Kirby Cedar Crest, NM ________________________________________________________________________________
Subject: oldest in-flight video?
Date: Mar 12, 2009
Not Kolb related.... 'cuz it was made before Homer was born. Watch the whole thing because the last half contains perhaps the oldest in-flight video. http://www.europafilmtreasures.eu/PY/322/fiche_technique.htm?ID=322 -------- Thom Riddle Buffalo, NY http://riddletr.googlepages.com/sportpilot-cfi http://riddletr.googlepages.com/a%26pmechanix A complex system that works is invariably found to have evolved from a simple system that works. - John Gaule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234373#234373 ________________________________________________________________________________
Date: Mar 12, 2009
Rick N: I think the major problem with a larger unbaffled tank is shift of weight m ore than a problem with fuel starvation. I may be wrong, but that is my theory. john h mkIII The header tank would supply a constant flow of fuel in spite of any sl oshing of fuel in a unbaffled main tank. Rick Neilsen ________________________________________________________________________________
Subject: BRS CANISTER or VLS ?? Which one would suit Mark III Xtra??
Date: Mar 12, 2009
BRS Canister is the oldest model and has been used on Mark III Xtra yet on BRS website, they say that: VLS is "Built specifically for aircraft with limited interior space, the VLS (Vertical Launch System) installs on top of the wing or fuselage. Upward firing works well with pusher designed aircraft." Mark III Xtra is a Pusher Aircraft? your kind comments / recommendations? Thanking in advance for your kind responses. Faisal. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234376#234376 ________________________________________________________________________________
Date: Mar 12, 2009
Rick=2C A couple of minutes ago I got home from having some heli-arcing done from a welder I just met. This guy is awesome when it comes to aluminum weldin g. His quality is excellent=2C and he specializes in aluminum. I had him remount the intake and outlet tubes on my intercooler=2C plus h eli-arc all the pieces that make up the TBI intake assembly. Almost 1 1/2 hours of welding....$80. He has welded aluminum for over 25 years. The point is: If you need someone to make an aluminum tank for you...he could be your guy. I have a MkIII fuselage=2C same as yours=2C and could f urnish the dimensions he'd need. Also=2C I have found an aluminum supplier that's about 100 miles from me (n ear Valley Engineering in Missouri)=2C that carries 2024T6 sheets.(any thic kness) This offer to build tanks is also to The New Kolb Company=2C if they don' t have an official custom tank builder. I'm NOT trying to take away busine ss from TNK. If they have tanks that suit your needs=2C by all means go th rough them. But=2C if someone is looking for a great aluminum welder=2C I just found one. As usual=2C just let me know if I can help. Mike Welch MkIII From: NeilsenRM(at)comcast.net Subject: Re: Kolb-List: Re: Fjuel rtanks Date: Thu=2C 12 Mar 2009 14:05:25 -0400 Vic Would you share with us what you found? I'm still looking for a larger tank that I can put in my MKIIIC. I have been told the New Kolb tanks will not fit. If a alternative tank looked good and priced right I would consider on e. If the tank didn't have baffles I would install a small header tank 1-2 gallons below it. The header tank would supply a constant flow of fuel in s pite of any sloshing of fuel in a unbaffled main tank. Again worth what you paid for it. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: Vic Sent: Thursday=2C March 12=2C 2009 10:23 AM Subject: Re: Kolb-List: Re: Fjuel rtanks John I should have been more specific. I found (boat) bow tanks for a couple hun dred that look like they would fit pretty well up top behind heads as mine doesn't turn ar ound that far either. I can barely reach the flap handle. Just your oppinion=2C would an 19 gal wedge shaped tank HAVE to be baffled? I don't know yet if it is. Vic Xtra 912 3.5hrs legal insruction href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _________________________________________________________________ Hotmail=AE is up to 70% faster. Now good news travels really fast. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_03200 9 ________________________________________________________________________________
Subject: Re: oldest in-flight video?
Date: Mar 12, 2009
Controlling pitch looked like a busy task. On 12, Mar 2009, at 4:03 PM, Thom Riddle wrote: > > Not Kolb related.... 'cuz it was made before Homer was born. Watch > the whole thing because the last half contains perhaps the oldest > in-flight video. > > http://www.europafilmtreasures.eu/PY/322/fiche_technique.htm?ID=322 > > -------- > Thom Riddle > Buffalo, NY > http://riddletr.googlepages.com/sportpilot-cfi > http://riddletr.googlepages.com/a%26pmechanix > > A complex system that works is invariably found to have evolved > from a simple system that works. > - John Gaule > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=234373#234373 > > ________________________________________________________________________________
Date: Mar 12, 2009
Mike; I wouldn't use 2024 aluminum for a fuel tank. Use 5052 aluminum. 2024 corrodes real easy and with today's fuel you would be looking at severe corrosion problems with 2024. 5052 is a marine grade aluminum and is very resistant to corrosion. Just my 2 cents worth. Jim H (I have been welding aluminum for 60 years and still no expert) ________________________________________________________________________________
Date: Mar 12, 2009
Subject: Re: BRS CANISTER or VLS ?? Which one would suit Mark III
Xtra?? At 05:08 PM 3/12/2009, faisalasif wrote: >Mark III Xtra is a Pusher Aircraft? Yes, all of the Kolb aircraft (except the new Laser) are pushers. -Dana -- Capital punishment: people in the Capitol need to be punished... ________________________________________________________________________________
Date: Mar 12, 2009
At 06:12 PM 3/12/2009, Jim Hauck wrote: >Mike; > >I wouldn't use 2024 aluminum for a fuel tank. Use 5052 aluminum. 2024 >corrodes real easy and with today's fuel you would be looking at severe >corrosion problems with 2024. > >5052 is a marine grade aluminum and is very resistant to corrosion. Also 2024 is not generally considered a weldable alloy. -Dana -- Capital punishment: people in the Capitol need to be punished... ________________________________________________________________________________
Subject: Fuel tanks
Date: Mar 12, 2009
Jim=2C (please note corrected spelling of the subject) Jim=2C Exellent point re: 5052. I hadn't done any research for the proper alumi num alloy to use. I had just recently purchased some 2024T6 from these fol ks=2C and was simply passing that information along that they carried 2024. My apologies for making it look like I was suggesting 2024 for tanks. Yo u are correct that the best aluminum alloy for fuel tanks is 5052. Since Jim points out 5052 is the best alloy=2C anybody care to advise the best thickness. My guess would be about .0625. Anyone have a tank and kn ow what thickness you used? Mike Welch MkIII From: jimh474(at)embarqmail.com Subject: Re: Kolb-List: Re: Fjuel rtanks Date: Thu=2C 12 Mar 2009 18:12:44 -0400 Mike=3B I wouldn't use 2024 aluminum for a fuel tank. Use 5052 aluminum. 2024 corro des real easy and with today's fuel you would be looking at severe corrosio n problems with 2024. 5052 is a marine grade aluminum and is very resistant to corrosion. Just my 2 cents worth. Jim H (I have been welding aluminum for 60 years and still no expert) _________________________________________________________________ Windows Live=99 Contacts: Organize your contact list. http://windowslive.com/connect/post/marcusatmicrosoft.spaces.live.com-Blog- cns!503D1D86EBB2B53C!2285.entry?ocid=TXT_TAGLM_WL_UGC_Contacts_032009 ________________________________________________________________________________
Subject: Re: Fuel tanks
Date: Mar 12, 2009
.050" john h ISince Jim points out 5052 is the best alloy, anybody care to advise the be st thickness. My guess would be about .0625. Anyone have a tank and know what thickness you used? Mike Welch ________________________________________________________________________________
Date: Mar 12, 2009
Mike; I use .050, 5052 on all aluminum tanks that I weld up. John's 25 gallon tank is .050. and cross baffled. Jim Hauck ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Date: Mar 12, 2009
Rick, Please don't put words in my mouth. No one said 'categorically it has no effect'. To an engineer, perhaps. To a pilot, it's a moot point. Fore-and-aft CG change is of primary concern to aircraft, then lateral, then last (and I would conjecture least) vertical. (We are still discussing aircraft, not SUV's.) Never heard of an aircraft going out-of-control due to displaced vertical CG. You're correct in the engineering sense, but waaay too concerned about something that's not even touched on in general aviation texts. I will hand it to you, I could not detect the handling difference in models of 172's, so perhaps 3,000 hrs. of dual given hasn't properly prepared me. Never had a check airman bring it up in the CFI, CFI-AI, MEI, or ATP oral or checkrides. I should get my money back. And I must've been sleeping through all the and initial and recurrent training at FlightSafety Int'l. and SimCom in the Cessna 400-series, King Air 200, 300, 350, Merlin IIIB, Piper Cheyenne I & II, Citation I, II, V, Bravo, obtained over 30-odd years and 15,000+ hours. The only vertical component available to me is the seat height, and my comfort trumps the slight concern over handling effect. So vertical component is (A) never discussed, (B) something we have little-to-no control over, and (C) of concern in only the most arcane sense. Vertical CG certainly exists, but is of concern when we have some control over it. With my RC planes, I can move components to change it, but in full-size aircraft it's fixed. If it's so windy that control becomes a concern, I don't fly. I'll respond BC in the future so's not to further bore our Kolb brothers and sisters. Ed in JXN MkII/503 ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Wednesday, March 11, 2009 5:55 PM Subject: Re: Kolb-List: Re: 'Vertical' CG Since the effect of having 300lb of fuel weight 7' above the roll center of the aircraft (while on the ground the roll center is between the tires and at the surface) was mentioned repeatedly to me by my instructor, and on my check ride by the DPE, it seems I was meant to know about it and take heed. No, you won't find it in flight manuals, those decisions were made for you by the designers and engineers and you can't change them like you can fore and aft weight changes in relation to the aerodynamic center. By experience I can tell you that on the ground a "K" model 172 with long range tanks handles differently in a crosswind than a "P" model with standard tanks (20 gallons and 120 lb. difference). The extra weight and the difference in landing gear track makes the "K" model more sensitive to gusts while taxiing, even though there are no other differences between the aircraft. Yes, the extra mass has more inertia, but given that both aircraft have the same size ailerons and the pilot has to have more force to stop the movement of the greater mass once it's started, the only way to get it is more aileron deflection. By analogy consider the roll characteristics of an Alfa Romeo Spider and a GMC Yukon. What happens to either vehicle when they are hit by a 40 mph side wind as when driving out of the wind shadow of a hedge row along side the highway? Which has the more severe response? Every object in an aircraft has a center of mass and a moment arm from the roll, pitch and yaw axis. How those masses are arranged will effect the handling of the aircraft whether on the ground or in the air. Whether it is critical to the aircraft depends on the aircraft's mission. For instance, how many competetive aerobatic aircraft have you seen lately that are not a shoulder wing design? If you want fast roll response you put the center of mass of the wings on the roll axis of the aircraft. Now, the question is, does moving the fuel tank upward have an effect on the aircraft's ground handling? Yes, you've changed the moment arm through which a mass acts. Will you notice it? I don't know. Will it be critical? I don't know. I do know that to say categorically it has no effect is ridiculous on its face. Rick On Wed, Mar 11, 2009 at 2:56 PM, Ed Chmielewski wrote: Hi Rick, I've neither heard of 'vertical' CG, nor found anything in any manuals. How would one calculate it, and where does this term come from? CG is just that, a point around which the aircraft rotates in any axis. Some aircraft are more prone to being displaced during low-speed taxi, but the most susceptible would have to be light weight coupled with lots of exposed surface area, which means a Kolb or other ultralight. Control displacement during taxi in a wind is the same for high- or low-wing aircraft, but varies if nosedragger or conventional gear. Ed in JXN MkII/503 ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Wednesday, March 11, 2009 6:51 AM Subject: Re: Kolb-List: Re: Fjuel rtanks John, While pilots rarely, if ever, calculate the vertical CG position, it is a component of aircraft ground handling. This is one of the reasons why GA pilots, particularly those flying high wing aircraft with tanks in the wings, are taught proper positioning of the controls during taxi operations. Rick On Tue, Mar 10, 2009 at 7:58 PM, John Hauck wrote: I've wondered why you have yours so high? It must reduce the power needed to get fuel to the engine, but must also raise the CG. Are there any noticeable handling differences between yours and a 'stock' Mark III? Russ Russ: My fuel tank is high because where it was located was empty, open space in the standard mkIII. 25 gals fits that space perfect. Homer left this space open to have 360 deg visibility. My neck won't twist that far around. Getting fuel to the engine with less power had nothing to do with the location of the tank. I don't understand "raising the CG". There are no noticeable handling differences between my mkIII and a stock mkIII. Location of the tank did not affect fore and aft, or lateral cg. john h mkIII ========== arget="_blank">http://www.matronics.com/Navigator?Kolb-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ==== get="_blank">http://www.matronics.com/Navigator?Kolb-List a>http://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 12, 2009
Hi Gang: Highly recommend sloshing the tank after fabrication. Will eliminate futur e headaches. Jim welded up an 18 gal tank for my FS. That was 1987. We did not know ab out sloshing the tank. Water tested, pressure tested, thought we had it, b ut down the road it sprung a leak in the most in accessible place. 1991, Jim welded up a 25 gal tank for my mkIII. Water tested, pressure tes ted, sloshed, and never looked back. That was nearly 2,900 flight hours, a nd three crashes ago. This tank just keeps on ticking. john h mkIII .050" john h ________________________________________________________________________________
Date: Mar 12, 2009
If I may add a humble point: the vertical CG affects the pitch axis=2C too =2C doesn't it? I've always assumed that the high CG of my Firestar II (re sulting mainly from the engine way up there) is a major factor in its tende ncy to nose over if not handled carefully in some situations. Lee From: edchmiel(at)mindspring.com Subject: Re: Kolb-List: Re: 'Vertical' CG Date: Thu=2C 12 Mar 2009 18:56:08 -0400 Rick=2C Please don't put words in my mouth. No one said 'categorically it has no effect'. To an engineer=2C perhaps. To a pilot=2C it's a moot poin t. Fore-and-aft CG change is of primary concern to aircraft=2C then latera l=2C then last (and I would conjecture least) vertical. (We are still discu ssing aircraft=2C not SUV's.) Never heard of an aircraft going out-of-contr ol due to displaced vertical CG. You're correct in the engineering sense =2C but waaay too concerned about something that's not even touched on in g eneral aviation texts. I will hand it to you=2C I could not detect the handling difference in models of 172's=2C so perhaps 3=2C000 hrs. of dual given hasn't properl y prepared me. Never had a check airman bring it up in the CFI=2C CFI-AI =2C MEI=2C or ATP oral or checkrides. I should get my money back. And I m ust've been sleeping through all the and initial and recurrent training at FlightSafety Int'l. and SimCom in the Cessna 400-series=2C King Air 200=2C 300=2C 350=2C Merlin IIIB=2C Piper Cheyenne I & II=2C Citation I=2C II=2C V =2C Bravo=2C obtained over 30-odd years and 15=2C000+ hours. The only ver tical component available to me is the seat height=2C and my comfort trumps the slight concern over handling effect. So vertical component is (A) nev er discussed=2C (B) something we have little-to-no control over=2C and (C) of concern in only the most arcane sense. Vertical CG certainly exists=2C but is of concern when we have some control over it. With my RC planes=2C I can move components to change it =2C but in full-size aircraft it's fixed. If it's so windy that control be comes a concern=2C I don't fly. I'll respond BC in the future so's not to further bore our Kolb bro thers and sisters. Ed in JXN MkII/503 ----- Original Message ----- From: Richard Girard Sent: Wednesday=2C March 11=2C 2009 5:55 PM Subject: Re: Kolb-List: Re: 'Vertical' CG Since the effect of having 300lb of fuel weight 7' above the roll center of the aircraft (while on the ground the roll center is between the tires and at the surface) was mentioned repeatedly to me by my instructor=2C and on my check ride by the DPE=2C it seems I was meant to know about it and take heed. No=2C you won't find it in flight manuals=2C those decisions were made for you by the designers and engineers and you can't change them like you can f ore and aft weight changes in relation to the aerodynamic center. By experience I can tell you that on the ground a "K" model 172 with long r ange tanks handles differently in a crosswind than a "P" model with standar d tanks (20 gallons and 120 lb. difference). The extra weight and the diffe rence in landing gear track makes the "K" model more sensitive to gusts whi le taxiing=2C even though there are no other differences between the aircra ft. Yes=2C the extra mass has more inertia=2C but given that both aircraft have the same size ailerons and the pilot has to have more force to stop th e movement of the greater mass once it's started=2C the only way to get it is more aileron deflection. By analogy consider the roll characteristics of an Alfa Romeo Spider and a GMC Yukon. What happens to either vehicle when they are hit by a 40 mph sid e wind as when driving out of the wind shadow of a hedge row along side the highway? Which has the more severe response? Every object in an aircraft has a center of mass and a moment arm from the roll=2C pitch and yaw axis. How those masses are arranged will effect the h andling of the aircraft whether on the ground or in the air. Whether it is critical to the aircraft depends on the aircraft's mission. For instance=2C how many competetive aerobatic aircraft have you seen latel y that are not a shoulder wing design? If you want fast roll response you p ut the center of mass of the wings on the roll axis of the aircraft. Now=2C the question is=2C does moving the fuel tank upward have an effect o n the aircraft's ground handling? Yes=2C you've changed the moment arm through which a mass acts. Will you notice it? I don't know. Will it be critical? I don't know. I do know that to say categorically it has no effect is ridiculous on its f ace. Rick On Wed=2C Mar 11=2C 2009 at 2:56 PM=2C Ed Chmielewski <edchmiel@mindspring. com> wrote: Hi Rick=2C I've neither heard of 'vertical' CG=2C nor found anything in any ma nuals. How would one calculate it=2C and where does this term come from? CG is just that=2C a point around which the aircraft rotates in any axis. S ome aircraft are more prone to being displaced during low-speed taxi=2C but the most susceptible would have to be light weight coupled with lots of ex posed surface area=2C which means a Kolb or other ultralight. Control displ acement during taxi in a wind is the same for high- or low-wing aircraft=2C but varies if nosedragger or conventional gear. Ed in JXN MkII/503 ----- Original Message ----- From: Richard Girard Sent: Wednesday=2C March 11=2C 2009 6:51 AM Subject: Re: Kolb-List: Re: Fjuel rtanks John=2C While pilots rarely=2C if ever=2C calculate the vertical CG positio n=2C it is a component of aircraft ground handling. This is one of the reas ons why GA pilots=2C particularly those flying high wing aircraft with tank s in the wings=2C are taught proper positioning of the controls during taxi operations. Rick On Tue=2C Mar 10=2C 2009 at 7:58 PM=2C John Hauck wr ote: I've wondered why you have yours so high? It must reduce the power needed to get fuel to the engine =2C but must also raise the CG. Are there any noticeable handling differen ces between yours and a 'stock' Mark III? Russ Russ: My fuel tank is high because where it was located was empty=2C open space i n the standard mkIII. 25 gals fits that space perfect. Homer left this sp ace open to have 360 deg visibility. My neck won't twist that far around. Getting fuel to the engine with less power had nothing to do with the locat ion of the tank. I don't understand "raising the CG". There are no noticeable handling diff erences between my mkIII and a stock mkIII. Location of the tank did not affect fore and aft=2C or lateral cg. john h mkIII arget="_blank">http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com le=2C List Admin. ="_blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ==== get="_blank">http://www.matronics.com/Navigator?Kolb-List a> http://forums.matronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _________________________________________________________________ Windows Live=99 Groups: Create an online spot for your favorite groups to m eet. http://windowslive.com/online/groups?ocid=TXT_TAGLM_WL_groups_032009 ________________________________________________________________________________
Date: Mar 12, 2009
That is more directly a function of center of thrust, referenced to either the wing or center of drag whichever most concerns you. Any vertical CG effect caused by the engine location would have little influence on the nose down with power tendency. -which, BTW,I pretty much automatically compensated for by the time I had an hour on my MkIII. It turns out to be a beneficial effect for me anyway during landing. Old antique, high wing tractor taildraggers exhibit quite a nose up pitch with power added at the last second, sometimes to your detriment. The Kolb properly points you in the right direction :) BB On 12, Mar 2009, at 8:24 PM, LEE CREECH wrote: > If I may add a humble point: the vertical CG affects the pitch > axis, too, doesn't it? I've always assumed that the high CG of my > Firestar II (resulting mainly from the engine way up there) is a > major factor in its tendency to nose over if not handled carefully > in some situations. > > Lee > > > From: edchmiel(at)mindspring.com > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: 'Vertical' CG > Date: Thu, 12 Mar 2009 18:56:08 -0400 > > Rick, > > Please don't put words in my mouth. No one said > 'categorically it has no effect'. To an engineer, perhaps. To a > pilot, it's a moot point. Fore-and-aft CG change is of primary > concern to aircraft, then lateral, then last (and I would > conjecture least) vertical. (We are still discussing aircraft, not > SUV's.) Never heard of an aircraft going out-of-control due to > displaced vertical CG. You're correct in the engineering sense, > but waaay too concerned about something that's not even touched on > in general aviation texts. > I will hand it to you, I could not detect the handling > difference in models of 172's, so perhaps 3,000 hrs. of dual given > hasn't properly prepared me. Never had a check airman bring it up > in the CFI, CFI-AI, MEI, or ATP oral or checkrides. I should get > my money back. And I must've been sleeping through all the and > initial and recurrent training at FlightSafety Int'l. and SimCom in > the Cessna 400-series, King Air 200, 300, 350, Merlin IIIB, Piper > Cheyenne I & II, Citation I, II, V, Bravo, obtained over 30-odd > years and 15,000+ hours. The only vertical component available to > me is the seat height, and my comfort trumps the slight concern > over handling effect. So vertical component is (A) never > discussed, (B) something we have little-to-no control over, and (C) > of concern in only the most arcane sense. > Vertical CG certainly exists, but is of concern when we > have some control over it. With my RC planes, I can move > components to change it, but in full-size aircraft it's fixed. If > it's so windy that control becomes a concern, I don't fly. > I'll respond BC in the future so's not to further bore our > Kolb brothers and sisters. > > Ed in JXN > MkII/503 > ----- Original Message ----- > From: Richard Girard > To: kolb-list(at)matronics.com > Sent: Wednesday, March 11, 2009 5:55 PM > Subject: Re: Kolb-List: Re: 'Vertical' CG > > Since the effect of having 300lb of fuel weight 7' above the roll > center of the aircraft (while on the ground the roll center is > between the tires and at the surface) was mentioned repeatedly to > me by my instructor, and on my check ride by the DPE, it seems I > was meant to know about it and take heed. > No, you won't find it in flight manuals, those decisions were made > for you by the designers and engineers and you can't change them > like you can fore and aft weight changes in relation to the > aerodynamic center. > By experience I can tell you that on the ground a "K" model 172 > with long range tanks handles differently in a crosswind than a "P" > model with standard tanks (20 gallons and 120 lb. difference). The > extra weight and the difference in landing gear track makes the "K" > model more sensitive to gusts while taxiing, even though there are > no other differences between the aircraft. Yes, the extra mass has > more inertia, but given that both aircraft have the same size > ailerons and the pilot has to have more force to stop the movement > of the greater mass once it's started, the only way to get it is > more aileron deflection. > By analogy consider the roll characteristics of an Alfa Romeo > Spider and a GMC Yukon. What happens to either vehicle when they > are hit by a 40 mph side wind as when driving out of the wind > shadow of a hedge row along side the highway? Which has the more > severe response? > Every object in an aircraft has a center of mass and a moment arm > from the roll, pitch and yaw axis. How those masses are arranged > will effect the handling of the aircraft whether on the ground or > in the air. Whether it is critical to the aircraft depends on the > aircraft's mission. > For instance, how many competetive aerobatic aircraft have you seen > lately that are not a shoulder wing design? If you want fast roll > response you put the center of mass of the wings on the roll axis > of the aircraft. > Now, the question is, does moving the fuel tank upward have an > effect on the aircraft's ground handling? > Yes, you've changed the moment arm through which a mass acts. > Will you notice it? > I don't know. > Will it be critical? > I don't know. > I do know that to say categorically it has no effect is ridiculous > on its face. > > Rick > > On Wed, Mar 11, 2009 at 2:56 PM, Ed Chmielewski > wrote: > Hi Rick, > > I've neither heard of 'vertical' CG, nor found anything in > any manuals. How would one calculate it, and where does this term > come from? CG is just that, a point around which the aircraft > rotates in any axis. Some aircraft are more prone to being > displaced during low-speed taxi, but the most susceptible would > have to be light weight coupled with lots of exposed surface area, > which means a Kolb or other ultralight. Control displacement during > taxi in a wind is the same for high- or low-wing aircraft, but > varies if nosedragger or conventional gear. > > Ed in JXN > MkII/503 > ----- Original Message ----- > From: Richard Girard > To: kolb-list(at)matronics.com > Sent: Wednesday, March 11, 2009 6:51 AM > Subject: Re: Kolb-List: Re: Fjuel rtanks > > John, While pilots rarely, if ever, calculate the vertical CG > position, it is a component of aircraft ground handling. This is > one of the reasons why GA pilots, particularly those flying high > wing aircraft with tanks in the wings, are taught proper > positioning of the controls during taxi operations. > > Rick > > On Tue, Mar 10, 2009 at 7:58 PM, John Hauck > wrote: > > > I've wondered why you have > yours so high? It must reduce the power needed to get fuel to the > engine, but must also raise the CG. Are there any noticeable > handling differences between yours and a 'stock' > Mark III? > Russ > > > Russ: > > My fuel tank is high because where it was located was empty, open > space in the standard mkIII. 25 gals fits that space perfect. > Homer left this space open to have 360 deg visibility. My neck > won't twist that far around. > > Getting fuel to the engine with less power had nothing to do with > the location of the tank. > > I don't understand "raising the CG". There are no noticeable > handling differences between my mkIII and a stock mkIII. > > Location of the tank did not affect fore and aft, or lateral cg. > > john h > mkIII > > ========== > arget="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > href="http://www.matronics.com/Navigator?Kolb-List">http:// > www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > ==== get="_blank">http://www.matronics.com/Navigator?Kolb-List > a>http://forums.matronics.com _blank">http://www.matronics.com/ > contribution > > href="http://www.matronics.com/Navigator?Kolb-List">http:// > www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > > Windows Live=99 Groups: Create an online spot for your favorite > groups to meet. Check it out. > > ________________________________________________________________________________
Date: Mar 12, 2009
I was actually thinking of the time I was taxiing down a rather steep hill (shortcut from runway to barn) at about 1 mph with the engine idling=2C whe n the world slowly rotated around me and the plane put its nose on the grou nd. From then on I went the long way around. Lee From: slyck(at)frontiernet.net Subject: Re: Kolb-List: Re: 'Vertical' CG Date: Thu=2C 12 Mar 2009 22:27:58 -0400 That is more directly a function of center of thrust=2C referenced to eithe r the wing or center of drag whichever most concerns you. Any vertical CG effect caused by the engine location wo uld have little influence on the nose down with power tendency. -which=2C BTW=2CI pretty much automatically compensated for by the time I had an hour on my MkIII. It turns out to be a beneficial effect for me anyway during landing. Old a ntique=2C high wing tractor taildraggers exhibit quite a nose up pitch with power added at the last second=2C sometimes to y our detriment. The Kolb properly points you in the right direction :) BB On 12=2C Mar 2009=2C at 8:24 PM=2C LEE CREECH wrote: If I may add a humble point: the vertical CG affects the pitch axis=2C too =2C doesn't it? I've always assumed that the high CG of my Firestar II (re sulting mainly from the engine way up there) is a major factor in its tende ncy to nose over if not handled carefully in some situations. Lee _________________________________________________________________ Windows Live=99 Groups: Create an online spot for your favorite groups to m eet. http://windowslive.com/online/groups?ocid=TXT_TAGLM_WL_groups_032009 ________________________________________________________________________________
Date: Mar 13, 2009
Rick The tank I found was West Marine, Moeller bow tank. Sender,fill 1 1/2",return and vent $209. To good to be true. You bet I just went out and removed a side cover on the Xtra. It wont fit. O so close. Not baffled. Thanks for every ones input. to whomever was asking, I used a bag BRS much shorter, left room in front of the 912 for the oil tank. You can make a lexan cover to protect it and fasten it to your gap seal. (rivets and velcro?) Vic ________________________________________________________________________________
Subject: Re: Static rpm - warp drive/912ULS
Date: Mar 13, 2009
JetPilot wrote: > I set my prop based on John Haucks advice, which makes perfect sense, to adjust the pitch so that the engine is running at 5500 RPM wide open throttle, at max level flight speed. My RPM's are just a hair slower than Johns, I see around 5200 RPM on climbout, and about the same static. > FWIW, I got to do some high speed taxi tests last night - it was too windy and dark to actually take the plane up. but my jaw dropped when I saw how far the RPM's went down as soon as airflow started going through the prop disk. At 5300 or so static, by the time the ASI started indicating, it'd loaded down to nearly 4900 rpm.... good thing I didn't actually try to blast off. Took 2 degrees of pitch out and tried again. Now it loads down to about 5290 or thereabouts on the roll, so that's probably reasonably close to where it should be. If I can ever get daylight and reasonable winds to coincide, I have it set well enough to fly at this point I think. I should add that once the blades start to "catch", the thrust is significantly more than I got with the IVO. So it'll be interesting to see what I get once I get airborne.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234437#234437 ________________________________________________________________________________
Date: Mar 13, 2009
Here is the company that made my 8 gal tank. The tank is working great. No leaks. http://www.alumiworx.com/cart/index.php?act=viewProd&productId -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234442#234442 Attachments: http://forums.matronics.com//files/tank_586.jpg ________________________________________________________________________________
Subject: New Engine Concept
Date: Mar 13, 2009
http://engineeringtv.com/blogs/etv/archive/2008/07/01/opposed-piston-oppose d-cylinder-engine.aspx ________________________________________________________________________________
Date: Mar 13, 2009
That seems like a good place to start Lucien. That RPM is pretty typical for many different aircraft climbing out on the 912-S with a fixed pitch prop. Once you get in level flight, open the throttle wide open level flight it gets going as fast as its going to go, and that should be 5500 RPM. Since your Titan is fast, your RPM will increase with speed more than ours do on the Kolbs. My guess is that you might have to pitch the prop a bit more ??? But I would fly it the way it is now and see what you get, the RPM you have now sounds great for a flight test. I have experimented with different pitches quite a bit on my 912-S / warpdrive setup. If you dont get it right, the cruise performance can be very bad, but you would have to be way way off for the plane not to fly well and scare yourself [Wink] I have heard of some airplanes being around 5100 RPM or even a bit less on climbout. Hope you get a good flying day soon, I am anxious to hear your report on how the Warp compares to the IVO. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234477#234477 ________________________________________________________________________________
Subject: Re: BRS CANISTER or VLS ?? Which one would suit Mark III Xtra??
Date: Mar 13, 2009
I have the VLS on my Kolb MK III Xtra, and although I have not tried it yet, it seems very good good for the airplane [Wink] The fit of the VLS pack is PERFECT for the top of the MK III Xtra, I like it much better than the canister ! I will post some pictures of it in a little while so that you can see for yourself. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234481#234481 ________________________________________________________________________________
Date: Mar 13, 2009
[quote="rlaird"] Yeah, sort of like a home made Kolb MkIII, built and tested by people with limited resources and funds !... Oooo, that's scary! ;-) -- R > [b] Yes, its true of our Kolbs also, But I feel much better with big aluminum tube spars, ribs and fabric, Even I can get this right ! Hanging by a whirling mass of very highly stressed rotor components, bearings, and linkages just seems more problematic than the big aluminum tube spar we hang by. I am just as happy to leave the rotors to Bell Helicopter ;) Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234484#234484 ________________________________________________________________________________
Date: Mar 13, 2009
JetPilot wrote: > That seems like a good place to start Lucien. That RPM is pretty typical for many different aircraft climbing out on the 912-S with a fixed pitch prop. Once you get in level flight, open the throttle wide open level flight it gets going as fast as its going to go, and that should be 5500 RPM. > > Since your Titan is fast, your RPM will increase with speed more than ours do on the Kolbs. My guess is that you might have to pitch the prop a bit more ??? But I would fly it the way it is now and see what you get, the RPM you have now sounds great for a flight test. I have experimented with different pitches quite a bit on my 912-S / warpdrive setup. If you dont get it right, the cruise performance can be very bad, but you would have to be way way off for the plane not to fly well and scare yourself [Wink] I have heard of some airplanes being around 5100 RPM or even a bit less on climbout. Hope you get a good flying day soon, I am anxious to hear your report on how the Warp compares to the IVO. > > Mike Well tomorrow we might get a break in the winds, so perhaps I can go around the patch with it. Part of the complication is my altitude (7000'MSL), which turns the motor into about a strong sea-level 582 rather than a 912uls. A regular kick around the patch sightseeing has me close to 10,000' and the houses and mountains are sometimes still too big. So even with the IVO when I had it flatted out to 5400 in level flight it could barely do 100mph indicated (tho about 110 true). So the speed range isn't too terribly much more than even a Mark III. But I did go with a 68" to start with, so it would run more pitch and hopefully have more cushion for speed range. I'm less concerned about cruise than I am climb, but I don't want the engine to be able to overspeed in level flight (i.e. if the throttle cable breaks). So I'll just have to work on it until it's right. I'm blazing a little bit of a trail since a 68" diameter warp drive hasn't been tried on a titan yet to my knowledge (only the SS has room for more than a 64"). The thrust when the blades unstall on the ground runs I did last night is significantly more than the IVO, which starts off strong but then fades as you gather speed. So hopefully it'll be more efficient in the air also. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234487#234487 ________________________________________________________________________________
Date: Mar 13, 2009
Subject: Re: New Engine Concept
At 04:27 PM 3/13/2009, David Key wrote: ><http://engineeringtv.com/blogs/etv/archive/2008/07/01/opposed-piston-opposed-cylinder-engine.aspx>http://engineeringtv.com/blogs/etv/archive/2008/07/01/opposed-piston-opposed-cylinder-engine.aspx I'm not holding my breath... Whenever somebody publicizes a "new" engine concept (which in this case is _not_ new) before constructing a working prototype, a working prototype somehow never gets built. -Dana -- The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson ________________________________________________________________________________
Date: Mar 13, 2009
Thanks Mike, I look forward to the pictures. and thank you for taking time to respond. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234494#234494 ________________________________________________________________________________
Date: Mar 13, 2009
Here are three pictures showing the BRS, the VLS pack just sits in the top of the MK III like it was built for it ! Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234503#234503 Attachments: http://forums.matronics.com//files/ultralightmikekolbdetail12_20_2006_068_175.jpg http://forums.matronics.com//files/ultralightmikefloridaevergladescity06_15_2008_24_200.jpg http://forums.matronics.com//files/ultralightkolbdetailvg02_18_2008_06_436.jpg ________________________________________________________________________________
Date: Mar 13, 2009
That was cool, I have never seen a video from that period that was shot from inside the plane. Good find . Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234504#234504 ________________________________________________________________________________
Date: Mar 13, 2009
The bigger diameter should be much more efficient at that your speed than a 64 inch prop. I have a 70 inch on my prop. How much clearance do you have left to the tail boom tube with the larger prop ? Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234505#234505 ________________________________________________________________________________
Date: Mar 13, 2009
JetPilot wrote: > The bigger diameter should be much more efficient at that your speed than a 64 inch prop. I have a 70 inch on my prop. > > How much clearance do you have left to the tail boom tube with the larger prop ? > > Mike There's still a good 4 or 5". I measured it a while back and found that a 72" could fit and there'd still be like 2 inches of clearance. I don't know what the limits of flex are on the mounts and the rest of the plane tho so I'd say 70 is the max safe diameter. I was thinking about going with a 70" but opted for 68" to allow a little more pitch for the wider speed range. I'll have to fly it and see how it does. I actually had this exact same prop on my FS II (tho it was right hand instead) and it worked great. It was my first warp drive prop and it was about as perfect as you can get for the 3.47 C box and that plane. Still miss it which is why one day I'd like to do a firefly/447.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234517#234517 ________________________________________________________________________________
Date: Mar 14, 2009
Out Allegro was pitched so that typically the 912UL ran around 4900 rpm during take-off run. In straight and level flight at full throttle at our typical density altitude it would top out at 5500 rpm and about 125 mph TAS. I expect your Titan will be in this speed range too. The faster the airplane the more difference you can expect between the take-off run rpm and Vh rpm. Our RANS has a fixed pitch (66x52) Tennessee climb prop so we get a lot higher take-off rpm and can easily run past redline during cruise if not paying attention, even at high density altitudes. Thom in Buffalo ________________________________________________________________________________
Date: Mar 14, 2009
> Our RANS has a fixed pitch (66x52) Tennessee climb prop so we get a > lot higher take-off rpm and can easily run past redline during cruise > if not paying attention, even at high density altitudes. > > Thom in Buffalo Is there a reason for leaving that prop on the Rans? john h mkIII ________________________________________________________________________________
Date: Mar 14, 2009
Thom Riddle wrote: > Out Allegro was pitched so that typically the 912UL ran around 4900 > rpm during take-off run. In straight and level flight at full throttle > at our typical density altitude it would top out at 5500 rpm and about > 125 mph TAS. I expect your Titan will be in this speed range too. The > faster the airplane the more difference you can expect between the > take-off run rpm and Vh rpm. > > Our RANS has a fixed pitch (66x52) Tennessee climb prop so we get a > lot higher take-off rpm and can easily run past redline during cruise > if not paying attention, even at high density altitudes. > > Thom in Buffalo Eeeyikes, 4900 strikes me as really lugging it.... That can't be good for the motor..... Tho I guess if you have that wide of a speed range you probably don't have much choice ? My problem is our altitude so I need as much climb as I can possibly get for safety reasons, even with our mile plus long runways. With my FSII, I had that sucker turning 6300 on the takeoff roll and in climbout about 6400. The plane was actually trimmed to fly at about 70 but I kept it at 60 to 65 with about 5200 to 5400 cruise. It could have easily overspeeded in level flight, but with a climb rate of about 300 fpm max, I was happy to have that baby putting out max power in a Vy climb (which IIRC, was about 40 to 45mph?). At approx 377 power levels, that was ok with me ;). My current plane I'm perfectly content to cruise along at 90 or even 80 and don't care a great deal about going really fast. I think it's the UL'er/Kolber in me.... So I'll just have to see what I get in flight. Winds look low today so I may head out and have a go here in a bit. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234554#234554 ________________________________________________________________________________
Date: Mar 14, 2009
Just in case anyone's interested in a PIREP on the Warp Drive, I finally flew around the patch with the new WD. It really does work like a CS prop! I don't recall this affect as much on my FSII, but on the 912uls it's very noticeable. Everything in climb between 65 and 80 mph stayed between 5350 and 5420 rpm or thereabouts. The pleasant surprise was on downwind, when I noticed I was at almost 95mph at my usual throttle setting but was still only turning just under 5000. (normally 5100 with the IVO unless I add in more pitch). I'd usually just be breaking 85 if I held 5000. So the speed range is quite a bit wider than the IVO which is really nice. The performance is slightly better too, especially over a wider range of airspeeds where it maintains a good load on the motor and good thrust. The less rotating mass over the IVO is very noticeable, especially at idle which is much smoother now. Overall a very good upgrade so far. Still have to do more flying at cruise to see what I got there... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234623#234623 ________________________________________________________________________________
Date: Mar 15, 2009
John, We plan to change the climb prop eventually for an adjustable pitch. We've been doing a lot of other refinements that were more critical but the prop change is getting closer to the top of the list. -------- Thom Riddle Buffalo, NY http://riddletr.googlepages.com/sportpilot-cfi http://riddletr.googlepages.com/a%26pmechanix A complex system that works is invariably found to have evolved from a simple system that works. - John Gaule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234647#234647 ________________________________________________________________________________
Date: Mar 15, 2009
Lucien, You are right about the speed range not leaving us much choice. That is the bane of most fixed pitch props on aircraft with a wide speed range. However, 4900 rpm is not really lugging the 912. At full throttle and 4900 rpm, the 912UL is producing about 92-93% of max continuous cruise power. Based on what I keep reading about the Warp taper tip, I'm inclined toward that to replace the Tennessee woody climb prop on our RANS. -------- Thom Riddle Buffalo, NY http://riddletr.googlepages.com/sportpilot-cfi http://riddletr.googlepages.com/a%26pmechanix A complex system that works is invariably found to have evolved from a simple system that works. - John Gaule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234648#234648 ________________________________________________________________________________
Date: Mar 15, 2009
> We plan to change the climb prop eventually for an adjustable pitch. We've been doing a lot of other refinements that were more critical but the prop change is getting closer to the top of the list. > > -------- > Thom Riddle Which Rans are you guys flying? Flying at extreme altitudes will pull my WOT rpm down to 5,000 rpm. This usually happens out West doing mountain flying. Propped correctly for 410 MSL, I'll be over propped by the time I reach West Texas. I've never flown my 912 powered airplane with anything except a taper tip Warp Drive. I did fly the 582 with the GSC Prop. It flew good, but was not the most durable prop I have ever flown with. john h mkIII ________________________________________________________________________________
Date: Mar 15, 2009
John, S6-S 912UL taildragger. With the climb prop in the eastern lowlands it gets about 105 mph TAS at 5500 rpm in straight and level flight with some throttle left. During one of the rare clear sky days we had several weeks ago I took it to 10,500 msl and it would still pull over 5500 rpm but that was a cold day so it was probably only about 7,000' density altitude. It is beginning to warm up here with today forecast around 55F so pretty soon we'll have some close to standard days. I want to see at what DA this prop is optimized for before we switch it out. -------- Thom Riddle Buffalo, NY http://riddletr.googlepages.com/sportpilot-cfi http://riddletr.googlepages.com/a%26pmechanix A complex system that works is invariably found to have evolved from a simple system that works. - John Gaule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234657#234657 ________________________________________________________________________________
Date: Mar 15, 2009
John When I called and talked with Darrell when I ordered my warp drive... he told me that at my altitude he recommended the 68 inch standard tip for my 912 ul. So I guess I don't know what difference the taper tip would do for me. Interesting he also mentioned the standard tip was a better choice for sea planes. Boyd MKIIIC Utah. 4226 ft Msl >>>>>>>>>>>>>>>>>>>>>>>>>> I've never flown my 912 powered airplane with anything except a taper tip Warp Drive. I did fly the 582 with the GSC Prop. It flew good, but was not the most durable prop I have ever flown with. john h mkIII ________________________________________________________________________________
Date: Mar 15, 2009
Thom Riddle wrote: > John, > > S6-S 912UL taildragger. With the climb prop in the eastern lowlands it gets about 105 mph TAS at 5500 rpm in straight and level flight with some throttle left. During one of the rare clear sky days we had several weeks ago I took it to 10,500 msl and it would still pull over 5500 rpm but that was a cold day so it was probably only about 7,000' density altitude. > > It is beginning to warm up here with today forecast around 55F so pretty soon we'll have some close to standard days. I want to see at what DA this prop is optimized for before we switch it out. For what it's worth, good friend of mine back in TX (hmm.. I should call him and see if he'd consent to be part of the possible MV Posse) has an S6ES with the 80 horse 912. He runs a WD 2 blade, tho I don't recall if it's the taper tip. As for altitude, when I moved here to northern NM, I brought the FSII with me. The only thing I had to change out was the main jets, it still ran at the same rpms without having to adjust the prop. It also had the WD 68" 3 blade. I don't recall what I had to change pitch-wise on the titan when I flew it here from nebraska. Both planes, tho, experienced huge drops in climb of course. The FSII went down from about 800-900 fpm to about 300fpm. The titan now does about 900 fpm down from almost 1800fpm near sea level. Once in the FSII I made it past pattern altitude to almost 8500 MSL (a typical kicking-around-the-area altitude of 1500 to 2000 AGL), cliimb was down to about 100 fpm. Still pretty good given that the plane was a little heavy.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234662#234662 ________________________________________________________________________________
Date: Mar 15, 2009
Lucien, When you think about lugging the 912, remember, 1, this is a four stoke engine, much more robust when dealing with prop loading than a 2 stroke, and 2, Rotax designed the 912 series engines to be capable of using constant speed propellers. Just make sure you keep the CHT's below max. A new set of heads is over half the cost of the engine. Rick On Sun, Mar 15, 2009 at 9:50 AM, lucien wrote: > > > Thom Riddle wrote: > > John, > > > > S6-S 912UL taildragger. With the climb prop in the eastern lowlands it > gets about 105 mph TAS at 5500 rpm in straight and level flight with some > throttle left. During one of the rare clear sky days we had several weeks > ago I took it to 10,500 msl and it would still pull over 5500 rpm but that > was a cold day so it was probably only about 7,000' density altitude. > > > > It is beginning to warm up here with today forecast around 55F so pretty > soon we'll have some close to standard days. I want to see at what DA this > prop is optimized for before we switch it out. > > > For what it's worth, good friend of mine back in TX (hmm.. I should call > him and see if he'd consent to be part of the possible MV Posse) has an S6ES > with the 80 horse 912. He runs a WD 2 blade, tho I don't recall if it's the > taper tip. > > As for altitude, when I moved here to northern NM, I brought the FSII with > me. The only thing I had to change out was the main jets, it still ran at > the same rpms without having to adjust the prop. It also had the WD 68" 3 > blade. > > I don't recall what I had to change pitch-wise on the titan when I flew it > here from nebraska. > > Both planes, tho, experienced huge drops in climb of course. The FSII went > down from about 800-900 fpm to about 300fpm. The titan now does about 900 > fpm down from almost 1800fpm near sea level. > > Once in the FSII I made it past pattern altitude to almost 8500 MSL (a > typical kicking-around-the-area altitude of 1500 to 2000 AGL), cliimb was > down to about 100 fpm. Still pretty good given that the plane was a little > heavy.... > > LS > > -------- > LS > Titan II SS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=234662#234662 > > ________________________________________________________________________________
Date: Mar 15, 2009
> When I called and talked with Darrell when I ordered my warp drive... he > told me that at my altitude he recommended the 68 inch standard tip for my > 912 ul. So I guess I don't know what difference the taper tip would do > for > me. Interesting he also mentioned the standard tip was a better choice > for > sea planes. > > Boyd I tested both Warp Drive taper and straight blades on my FS. At that time I was still playing around with aerobatics. I didn't like the way the Warp Drive, either blade, felt, compared to the Jim Culver two blade fixed pitch wooden prop. When I tested the straight blades on the 582 on my mkIII, they did not give me the "perceived pitch change" I got with the tapered blades. The straight blades were "straight down the middle" right up to max rpm. Never flown with anything but tapered blades on the 912 engines. I've flown 70 and 72 inch props on my 912's. The 72 climbs better and may cruise a little better, but is much noisier. That is why I went back to a 70 when I changed props last. It is a little quieter. I have been playing around with going back to a 72 for the Alaska flight. It gives me a little more performance, which might make a difference if I make a mistake and get myself into a situation I don't want to be in. I did this on my first flight to Alaska with the 80 horse. That is why I was so bent on getting a 100 horse for the next flight to Alaska. It does make a difference when the situation gets tight. After all the hours with the taper tip blades, it would be interesting to see what kind of perception I got with staight blades. Getting closer to MV every day. I'm ready!!! john h mkIII ________________________________________________________________________________
Subject: Re: Any KOLBs in South Florida?
Date: Mar 15, 2009
Nice to hear there will be another Kolb in the area. I'm shopping for one, preferring an already assembled MK3X, or earlier model if it has a 912 to keep at Pompano airport. Haven't seen the right one yet by googling, but will be looking at Sun and Fun. Wish me luck! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234672#234672 ________________________________________________________________________________
Date: Mar 15, 2009
aslsa.rng(at)gmail.com wrote: > Lucien, When you think about lugging the 912, remember, 1, this is a four stoke engine, much more robust when dealing with prop loading than a 2 stroke, and 2, Rotax designed the 912 series engines to be capable of using constant speed propellers. Just make sure you keep the CHT's below max. A new set of heads is over half the cost of the engine. > > Rick > Quite true.... And I tell you what, if I was rich and it was legal for me to do it, I'd go ahead and fit a CS prop. Yeah, it's more complexity, weight etc., but they really make life easy as far as prop loading and etc. What I try to do on my motor in the meantime is what John suggests, which is to keep it spun up as much as possible. 5400 rpm for takeoff and 5000 minimum at cruise. The sweet spot seems to be about 5080 rpm, or it was with the IVO. If I ever get the weather again, I still need to go out with the WD fitted and see where th sweet spot is. I had heard in the past about when the flight schools first started using the 912's they weren't used to the higher rpm regimes and were trying to run the motor like the continentals and lycomings lugging them at low RPMs. Apparently, the motors were coming down with major problems well before TBO. Once the instructors got trained on the proper rpm's for the 912, all that cleared up and they're going as long as 3000 hours out in the field. As far as major repairs, truth is it looks to me like something like repairing from an overheating event or etc. would cost in the neighborhood of a new motor. With those parts prices, if I had to do something major I'd probably be better off buying new and not doing whatever broke the thing again ;). Fingers crossed that nothing ever happens to this one as I haven't saved up replacement cost yet. Been too busy buying props ;). LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234676#234676 ________________________________________________________________________________
Date: Mar 15, 2009
Thanks for the tip. It resides in Rochester, NY. I'm in sunny south Florida. I spoke with the seller, and he seems like a good guy. However, you're right about the need for upgrades on the 912, and he says it needs sails, too. It currently has stits(sp?) covering, and he says there's some hangar rash and a poor paint job. There's also a bit of frame repair needed, which he says is minimal. It's not currently flyable, so I'm inclined to pass on it. Thanks again! dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234694#234694 ________________________________________________________________________________
Date: Mar 15, 2009
> My info, sketchy as it is,.says that the early 80 horse 912 engine > had problems ...and would cost a bunch to bring up to current AD's.. > Anyone have the skinny...Herb Basically, the same engine today as it was before I bought my first 912 in 1993. Like most new products on the market today, user testing detected a few things that needed changing, i.e., rocker arms and there was a recall on alternator stators. Rotax picked up the tab on most all the updates, right on through current editions of the 912UL, 912ULS, and 914. The stator update was not an absolute necessity, as far as I was concerned. I already had over 800 hours on my 912 when it came out. It was a precaution because of a possibility of fire due to type insulation used. I never heard of anyone experiencing a fire. The 912ULS, early ones like mine, greatly benefited from the updated starter and slip clutch. That one was 600.00, but well worth it. Newer 912ULS's were equipped with these updates. A lot of stuff has changed on these engines since 1993, but we were still able to put a lot of hours on them configured the way they were back then. I'm sure there are some 912's out there that never had a thing done to them since day one. The 912 on Bruce Chesnet's Bucaneer, the one he got off Ebay that sits in the hanger at London, is a prime example. ;-) john h mkIII ________________________________________________________________________________
Date: Mar 15, 2009
I believe Michael Bigelow made reference he is considering selling his...Miami based. You may wish to check with him directly to be sure. ------Original Message------ From: Watkinsdw Sender: owner-kolb-list-server(at)matronics.com ReplyTo: kolb-list(at)matronics.com Sent: Mar 15, 2009 11:41 AM Subject: Kolb-List: Re: Any KOLBs in South Florida? Nice to hear there will be another Kolb in the area. I'm shopping for one, preferring an already assembled MK3X, or earlier model if it has a 912 to keep at Pompano airport. Haven't seen the right one yet by googling, but will be looking at Sun and Fun. Wish me luck! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234672#234672 Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Mar 15, 2009
Dave are a member of the Pompano EAA? I recently joined but have been traveling unable to make a meeting yet. I am about to take the plunge on a kit.....gulp! ------Original Message------ From: Watkinsdw Sender: owner-kolb-list-server(at)matronics.com ReplyTo: kolb-list(at)matronics.com Sent: Mar 15, 2009 12:53 PM Subject: Kolb-List: Re: Any KOLBs in South Florida? Thanks for the tip. It resides in Rochester, NY. I'm in sunny south Florida. I spoke with the seller, and he seems like a good guy. However, you're right about the need for upgrades on the 912, and he says it needs sails, too. It currently has stits(sp?) covering, and he says there's some hangar rash and a poor paint job. There's also a bit of frame repair needed, which he says is minimal. It's not currently flyable, so I'm inclined to pass on it. Thanks again! dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234694#234694 Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Mar 15, 2009
Thanks Mike, Beautiful bird you have there.... Thanks for taking time to post such excellent pictures. faisal. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234732#234732 ________________________________________________________________________________
Date: Mar 15, 2009
Hey, you guys and gals, This is a great conversation, thanks! First of all, the hangaring issue at PMP is indeed an obstacle. A typical hangar is $625/month, however, I'm in a flying club that has two Piper Archers based there, and we have a 1/2 "T-hangar" that's under-utilized. I can store the Kolb there, folded up. Thanks to the person who supplied the info on the upgrades to the 912. ...and no, I'm not in the Pompano EAA. I may join later, but right now my monthly dues in the club and other flying related dues keep it from being my priority. Did I understand the post about the Kolb in Miami correctly, that it has been sold? If not, how do I contact the person? Thanks again, everyone! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234738#234738 ________________________________________________________________________________
Date: Mar 15, 2009
Hello Dave, This is Fran in Boca Raton. Michael's email is orcabonita(at)hotmail.com. To my knowledge it is not sold, I would send him an email directly. Fran Losey Fran.losey(at)alber.com ------Original Message------ From: Watkinsdw Sender: owner-kolb-list-server(at)matronics.com ReplyTo: kolb-list(at)matronics.com Sent: Mar 15, 2009 6:02 PM Subject: Kolb-List: Re: Any KOLBs in South Florida? Hey, you guys and gals, This is a great conversation, thanks! First of all, the hangaring issue at PMP is indeed an obstacle. A typical hangar is $625/month, however, I'm in a flying club that has two Piper Archers based there, and we have a 1/2 "T-hangar" that's under-utilized. I can store the Kolb there, folded up. Thanks to the person who supplied the info on the upgrades to the 912. ....and no, I'm not in the Pompano EAA. I may join later, but right now my monthly dues in the club and other flying related dues keep it from being my priority. Did I understand the post about the Kolb in Miami correctly, that it has been sold? If not, how do I contact the person? Thanks again, everyone! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234738#234738 Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Mar 15, 2009
Maybe this should go to another thread but... The NM Posse to MV potentially increased by 1 today. If ya'll dont mind another titan, the other titan, a II S, on our field may be an additional member. I spoke to his owner this morning, as he has it down for its annual and he expressed interest in going to MV. Guess I better put in for my vacation ASAP.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234748#234748 ________________________________________________________________________________
Date: Mar 15, 2009
Thanks, Fran, I'll email him tonight! dave What are you flying in Boca? I live in Deerfield. d. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234752#234752 ________________________________________________________________________________
Date: Mar 16, 2009
I used to fly a PA-28 201RT (84 Arrow IV TC) but was way too expensive for a hobby.... I am without air transportation at this time, which is why I am considering building the Kolb. I do miss flying greatly, and hope this potential project will stop the withdrawals... Fran ------Original Message------ From: Watkinsdw Sender: owner-kolb-list-server(at)matronics.com ReplyTo: kolb-list(at)matronics.com Sent: Mar 15, 2009 8:38 PM Subject: Kolb-List: Re: Any KOLBs in South Florida? Thanks, Fran, I'll email him tonight! dave What are you flying in Boca? I live in Deerfield. d. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234752#234752 Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Mar 15, 2009
I understand, Fran. Hey, if you're interested in getting access to a couple of nice Archers, you might consider joining our club at PMP. Let me know and I'll send details. I'm signing off now, but will check in tomorrow. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234755#234755 ________________________________________________________________________________
Date: Mar 15, 2009
Your first flight sounds very promising ! Many of the new LSA airplanes with the 912 S and fixed pitch prop take off very close to 5000 RPM, its very normal for the engine, it just does not develop that last few HP. Guys that fly Air Cams, including Phil Lockwood I was talking to one year, cruise the with both the 912-S with less than half power with no problems. The 912 series has undergone a bunch of changes over the years, many of the early problems don't happen anymore. I cruise at 4200 RPM and 70 MPH in my Kolb when solo, and around 4300 with my wife, it feels and flys great, using just a bit over 3 GPH. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234756#234756 ________________________________________________________________________________
Date: Mar 15, 2009
JetPilot wrote: > Your first flight sounds very promising ! Many of the new LSA airplanes with the 912 S and fixed pitch prop take off very close to 5000 RPM, its very normal for the engine, it just does not develop that last few HP. Guys that fly Air Cams, including Phil Lockwood I was talking to one year, cruise the with both the 912-S with less than half power with no problems. The 912 series has undergone a bunch of changes over the years, many of the early problems don't happen anymore. I cruise at 4200 RPM and 70 MPH in my Kolb when solo, and around 4300 with my wife, it feels and flys great, using just a bit over 3 GPH. > > Mike Well when I had the IVO I at one point had it set to about 5000 to 5100 on climbout (this was when I was experimenting and starting to discover that it was a little overpropped) and it was a pretty anemic climbout of about 500fpm. At 5400, I do almost twice that at nearly 1000fpm. So the climb is significantly better for me when spun up. I was doing around 1000fpm with the WD last night also, so the performance there is similar. I think with the warp drive I'll be able to get away with this or perhaps another 1/2 degree of pitch added back in. I'll just have to see how it does in cruise set the way it is. Also my speed range really isn't that wide. At this altitude, I hit a wall at 100mph indicated pretty much. I climb at anywhere from 65 to 80 depending on the conditions so top speed is only 20mph away. So I'm hoping I can probably get away with a fairly flat setting, as climb is paramount for me up here in the stratosphere.... And if I can still cruise at 90 to 95 at 5000 rpm I'll be a happy camper as that was what I was doing before with the IVO. But I'm less concerned about that, I happily cruise around at 80 if I have nowhere to go and am just sightseeing. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234765#234765 ________________________________________________________________________________
Subject: How many gallons per hour with VW Redrive
Date: Mar 15, 2009
Rick, and any other VW redrives, How many gallons per hour do burn with your VW Redrive. I read about your creation in the archives, but I did not see anything regarding GPH and what type of fuel do use? I am try to narrow engine choices. that I can afford. Thanks, Nick Cassara Proto-type Kolbra Palmer, Alaska ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Re: How many gallons per hour with VW Redrive
Date: Mar 16, 2009
Nick I burn 4 gallons per hour of regular automotive fuel. I had my engine built for a 7.8-9 to one compression ratio. Higher compression requires higher octane. I have been told the VW engine mount that Kolb makes is too wide for the Kolbra. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: Nick Cassara To: kolb-list(at)matronics.com Sent: Monday, March 16, 2009 12:47 AM Subject: Kolb-List: How many gallons per hour with VW Redrive Rick, and any other VW redrives, How many gallons per hour do burn with your VW Redrive. I read about your creation in the archives, but I did not see anything regarding GPH and what type of fuel do use? I am try to narrow engine choices. that I can afford. Thanks, Nick Cassara Proto-type Kolbra Palmer, Alaska ________________________________________________________________________________
Subject: Repairmen Inspection
Date: Mar 16, 2009
Hello fellow Kolb drivers....I an enrolled in a Fixed Wing Airplane 16 hr repairmen inspection class on March 20-21 in Dallas, Tx given by Rainbow Aviation. I was wondering if any of you has taken this class and what to expect....Do any of you have any advise about what I need to be prepared for? Thanks, Mike -------- The next best thing to playing and winning is playing and losing!...Mike Hillger Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234811#234811 ________________________________________________________________________________
Subject: Re: Repairmen Inspection
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Mar 16, 2009
ropermike wrote: > Hello fellow Kolb drivers....I an enrolled in a Fixed Wing Airplane 16 hr repairmen inspection class on March 20-21 in Dallas, Tx given by Rainbow Aviation. I was wondering if any of you has taken this class and what to expect....Do any of you have any advise about what I need to be prepared for? Thanks, Mike Hi Mike, I took this class with Mike Huffman. He is an excellent teacher. If you pay attention he stresses the points that will be on the test so if you take good notes (you can use your notes and books for the test) you can pass it. You probably already have the handouts/requirements for the class...he is good about emailing those to you ahead of time. There was one guy in my class of 6 or 7 that didn't pass but he seemed to be struggling with a lot of the concepts and didn't take any notes. Mike has probably told you to review the AC 43-13B (here's the link in case you don't have it: http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument&Highlight=ac%2043.13-1b ) You don't have to read everything. Open the contents document and find on the word "inspection" and review those chapters/sections. But like I said he will stress in the class the ones you need to know for the test. I really liked the hands on practice toward the end of the class. Don't get hung up too long on one workstation so you can get around to all the workstations (some take longer than others). Have fun and enjoy it! -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234816#234816 ________________________________________________________________________________
Date: Mar 16, 2009
I took that class. The instructors are excellent. Take lots of notes though. For some reason the binder they give you does not contain all the material they show you via the projector. Perhaps they don't want you to be able to give the entire course away to someone else who hasn't paid. I don't know why because you really are paying for the certificate not the knowledge. I don't think you need to prepare for anything. They go over everything in the class you will need to pass the test. You may want to bring your airplane documentation with you, airworthiness, registration, weight and balance. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234817#234817 ________________________________________________________________________________
Date: Mar 16, 2009
Rick Sounds as if you are running at near 50 horses...? What redrive ratio and cruise rpms? Cruise speed? Thanks Herb At 08:02 AM 3/16/2009, you wrote: >Nick > >I burn 4 gallons per hour of regular automotive >fuel. I had my engine built for a 7.8-9 to one >compression ratio. Higher compression requires higher octane. > >I have been told the VW engine mount that Kolb >makes is too wide for the Kolbra. > >Rick Neilsen >Redrive VW powered MKIIIC >----- Original Message ----- >From: <mailto:nickc(at)mtaonline.net>Nick Cassara >To: kolb-list(at)matronics.com >Sent: Monday, March 16, 2009 12:47 AM >Subject: Kolb-List: How many gallons per hour with VW Redrive > >Rick, and any other VW redrives, > > >How many gallons per hour do burn with your VW >Redrive. I read about your creation in the >archives, but I did not see anything regarding >GPH and what type of fuel do use? > > >I am try to narrow engine choices=85 that I can afford. > > >Thanks, > > >Nick Cassara > > >Proto-type Kolbra > >Palmer, Alaska > > >href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List > >href="http://forums.matronics.com">http://forums.matronics.com > >href="http://www.matronics.com/contribution">http://www.matronics.com/c > ________________________________________________________________________________
Date: Mar 16, 2009
Herb Since it is a custom engine the power is a bit unknown but I cruise at a greatly reduced power level. I assume you extrapolated the 50 HP from the fuel burn. You are assuming a lot but might be close. Climb and cruise are very close to a 80 HP Rotax. The redrive ratio is 1.6 to 1 and I cruise at 3200 engine RPMs. The cruise is 75 MPH. I'm currently turning a 71 inch three bladed F model PowerFin prop. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: herb To: kolb-list(at)matronics.com Sent: Monday, March 16, 2009 11:16 AM Subject: Re: Kolb-List: How many gallons per hour with VW Redrive Rick Sounds as if you are running at near 50 horses...? What redrive ratio and cruise rpms? Cruise speed? Thanks Herb At 08:02 AM 3/16/2009, you wrote: Nick I burn 4 gallons per hour of regular automotive fuel. I had my engine built for a 7.8-9 to one compression ratio. Higher compression requires higher octane. I have been told the VW engine mount that Kolb makes is too wide for the Kolbra. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: Nick Cassara To: kolb-list(at)matronics.com Sent: Monday, March 16, 2009 12:47 AM Subject: Kolb-List: How many gallons per hour with VW Redrive Rick, and any other VW redrives, How many gallons per hour do burn with your VW Redrive. I read about your creation in the archives, but I did not see anything regarding GPH and what type of fuel do use? I am try to narrow engine choices. that I can afford. Thanks, Nick Cassara Proto-type Kolbra Palmer, Alaska href=" http://www.matronics.com/Navigator?Kolb-List ">http://www.matronics.com/Navigator?Kolb-List href=" http://forums.matronics.com">http://forums.matronics.com href=" http://www.matronics.com/contribution ">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 16, 2009
12 hp per gal per hour is a little high for the 912UL. My experience with the 912UL is 4 gph at 5,000; 4.25 gph at 5,200, 4.5 gph at 5,400 rpm. These figures are based on many hours of cross country flying, not around the patch fuel consumption figures. The 912ULS is not nearly as efficient as the old 80. 5 gph at 5,000 and 5.5 gph at 5,000. Got to pay for the extra kick. I can not remember what type bearing is used for con rods. Give Ronnie Smith a call. john h mkIII My assumptions are based on a burn of 12 hp per gal per hour . Herb ps anyone know if the rods on the 912 use needle bearings ? ________________________________________________________________________________
Date: Mar 16, 2009
Knew it was going to be better... Sounds like 16 or so hp per gal per hr...? Could not find a hp/torque curve in the CPS catalog for the 100 hp engine.. Thazzz purty gud... Who is flying the Geo Metro on the list? Might make a good comparison...Herb At 12:21 PM 3/16/2009, you wrote: >12 hp per gal per hour is a little high for the 912UL. > >My experience with the 912UL is 4 gph at 5,000; 4.25 gph at 5,200, >4.5 gph at 5,400 rpm. These figures are based on many hours of >cross country flying, not around the patch fuel consumption figures. > >The 912ULS is not nearly as efficient as the old 80. 5 gph at 5,000 >and 5.5 gph at 5,000. Got to pay for the extra kick. > >I can not remember what type bearing is used for con rods. > >Give Ronnie Smith a call. > >john h >mkIII > > > My assumptions are based on a burn of 12 hp per gal per hour > . Herb > > >ps anyone know if the rods on the 912 use needle bearings ? > > ________________________________________________________________________________
Date: Mar 16, 2009
> I believe the 912 rods use "regular old" sleeve/bushing type bearings > which are supported by oil pressure. I don't think they use needle > bearings. > > And I don't want to have to find out. Ever.... ;) > > LS The main bearings are "inserts". I remember that from 912 course, but can not remember the con rods. Guess I could do a little research in the heavy maintenance manual, but don't have time now. john h mkIII ________________________________________________________________________________
Date: Mar 16, 2009
Herb, because the geo is only 1 liter and high compression it does very well at being frugal. It also burns low octane gas with no protest. I did notice a slight loss when they started putting ethanol in it. I can't give any numbers because I haven't done a real test. As with any engine though, it gets thirstier if I push it harder. Same goes for rate of climb. Never measured it but I think I would need to look at the hour hand instead of the minute hand. Been beautiful flying weather here for the past three days but spring is a busy time around here so that's wishful thinking. -besides, I still have to change my legs over to the new steel jobbers. Something new every year. BB On 16, Mar 2009, at 1:54 PM, herb wrote: > > Knew it was going to be better... Sounds like 16 or so hp per gal > per hr...? Could not find a hp/torque curve in the CPS catalog for > the 100 hp engine.. Thazzz purty gud... > > Who is flying the Geo Metro on the list? Might make a good > comparison...Herb > > At 12:21 PM 3/16/2009, you wrote: >> 12 hp per gal per hour is a little high for the 912UL. >> >> My experience with the 912UL is 4 gph at 5,000; 4.25 gph at 5,200, >> 4.5 gph at 5,400 rpm. These figures are based on many hours of >> cross country flying, not around the patch fuel consumption figures. >> >> The 912ULS is not nearly as efficient as the old 80. 5 gph at >> 5,000 and 5.5 gph at 5,000. Got to pay for the extra kick. >> >> I can not remember what type bearing is used for con rods. >> >> Give Ronnie Smith a call. >> >> john h >> mkIII >> >> >> My assumptions are based on a burn of 12 hp per gal per >> hour . Herb >> >> >> ps anyone know if the rods on the 912 use needle bearings ? >> >> > > ________________________________________________________________________________
Date: Mar 16, 2009
>> Who is flying the Geo Metro on the list? Might make a good comparison ...Herb Herb=2C Currently=2C there are two gentlemen presently flying the GEO engine. Bo b Bean=2C who has his set up with a carburetor=2C and Vic (I think Gibson) =2C who more than likely has TBI (throttle body fuel injection=2C which pro bably retains the ECU computer for engine controls). I am in the final stages of attaching all the extraneous engine items on my turbocharged GEO 1.0 liter. So far=2C I've got the turbocharger=2C radi ator=2C intercooler and oil cooler fabrication completed and mounted these items. Right now=2C I'm working on the finishing touches on my turbo exhau st. The exhaust is all built=2C I'm just putting on the O2 bungs=2C etc. I'll most likely have these exhaust pieces cermicoated. Recently I received my high performance cam and reworked cam gear back fr om the Teamswift.net GEO engine guru. This guy has a machine shop=2C and k nows quite a bit about high performance GEO modifications. There are dozen s=2C if not hundreds=2C of people that have installed his performance parts =2C and every one of them rave about how much better their engine's power i s improved. My engine now has his "mild" street cam=2C and 6+ degrees advanced cam ge ar (to be repositioned to the new 6+ degree setting). It is the opinion of three people I've corresponded with (on that high performance chat group s ite) that my engine should be putting out around 95-100 HP=2C and around 12 0+ ft lbs of torque. I make absolutely NO claim whatsoever as to whether it will or not have t hese perofrmance figures=2C until I fire the engine up and do some testing. I don't claim a thing until it is proven!!! I expect I will do a thrust test at some point. Oh yeah=2C there is one more guy who is building a GEO 1.3 L engine. His =2C also=2C will be fuel injection=2C but I think it's multi-port=2C IIRC. Mike Welch MkIII _________________________________________________________________ Express your personality in color! Preview and select themes for Hotmail=AE . http://www.windowslive-hotmail.com/LearnMore/personalize.aspx?ocid=TXT_MS GTX_WL_HM_express_032009#colortheme ________________________________________________________________________________
Date: Mar 16, 2009
> The durn picture on page 46 of the CPS catalog seems to indicate > that the crank is multiple pieces using big end needle bearings. ??? If > it used replaceable rods, then it could be re buildable which I think it > is not..? Herb Picking up the phone, calling Ronnie Smith, was quicker than looking in the book. 912 series crankshafts are press fit. Main bearings are split inserts and the con rods are whole inserts. Crankshafts are not Service Center rebuildable. john h mkIII ________________________________________________________________________________
Date: Mar 16, 2009
Thanks John Interesting concept...not sure that I have seen that before? Makes me think that at 4k or so for the assy the after market could make money rebuilding them with different rods with split big ends.. Herb At 03:27 PM 3/16/2009, you wrote: > > > > The durn picture on page 46 of the CPS catalog seems to indicate >>that the crank is multiple pieces using big end needle >>bearings. ??? If it used replaceable rods, then it could be re >>buildable which I think it is not..? Herb > > >Picking up the phone, calling Ronnie Smith, was quicker than looking >in the book. > >912 series crankshafts are press fit. Main bearings are split >inserts and the con rods are whole inserts. Crankshafts are not >Service Center rebuildable. > >john h >mkIII > > ________________________________________________________________________________
Date: Mar 16, 2009
> Interesting concept...not sure that I have seen that > before? Makes me think that at 4k or so for the assy the after market > could make money rebuilding them with different rods with split big > ends.. Herb Does anyone know why Rotax when the same route with cranks for 4 strokes as they did for 2 strokes? Not being an engineer, I have to rely on what little bit of good ole common sense I inherited. A cursory glance at the crank tells me it may be lighter and cleaner for turning higher speeds. Might reduce drag, increase performance. Just guessing. I don't know. I do know that the only problem Rotax has experienced with a 912 crank was oil starvation. A few seconds of oil starvation and the engine is toast. What is the primary cause of oil starvation? Losing an oil line. Jim Lee, Sharon, PA, lost his life near Lakeland, FL, when he was flying a Kolb MKIII with floats. Lost an oil line on a 912, stalled and crashed. Losing an oil line on a 912 should not happen. The intake line is under vacuum, pump is pulling oil. The outlet line is under 3 to 5 psi (crankcase pressure) to push oil out of the crankcase, back to the oil tank. john h mkIII ________________________________________________________________________________
Date: Mar 17, 2009
The answer is weight. A built up crankshaft weighs less. It also allows the use of a "folded" (Eric Tucker's terminology) design of the crank throws, which makes the crank shorter, which makes a smaller, shorter crankcase which also reduces weight. Incidentally, the folded crank throw doesn't allow room for rod bolts, so no after market rods are likely.Okay, Dana, jump in and tell every one weight has absolutely nothing to do with it. :-} Rick On Mon, Mar 16, 2009 at 4:15 PM, John Hauck wrote: > > > > Interesting concept...not sure that I have seen that > >> before? Makes me think that at 4k or so for the assy the after market >> could make money rebuilding them with different rods with split big >> ends.. Herb >> > > > Does anyone know why Rotax when the same route with cranks for 4 strokes as > they did for 2 strokes? > > Not being an engineer, I have to rely on what little bit of good ole common > sense I inherited. A cursory glance at the crank tells me it may be lighter > and cleaner for turning higher speeds. Might reduce drag, increase > performance. > > Just guessing. I don't know. > > I do know that the only problem Rotax has experienced with a 912 crank was > oil starvation. A few seconds of oil starvation and the engine is toast. > What is the primary cause of oil starvation? Losing an oil line. Jim Lee, > Sharon, PA, lost his life near Lakeland, FL, when he was flying a Kolb MKIII > with floats. Lost an oil line on a 912, stalled and crashed. > > Losing an oil line on a 912 should not happen. The intake line is under > vacuum, pump is pulling oil. The outlet line is under 3 to 5 psi (crankcase > pressure) to push oil out of the crankcase, back to the oil tank. > > > john h > mkIII > > ________________________________________________________________________________
Date: Mar 17, 2009
Thanks Cristal and Scott. My instructors will be Carol and Brian Carpenter. I am looking forward to the class. -------- The next best thing to playing and winning is playing and losing!...Mike Hillger Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234961#234961 ________________________________________________________________________________
Date: Mar 17, 2009
ropermike wrote: > Thanks Cristal and Scott. My instructors will be Carol and Brian Carpenter. I am looking forward to the class. Oops, sorry Mike. I was thinking Sport Aviation Specialties, not Rainbow Aviation. Hopefully it'll be as good. :) -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234962#234962 ________________________________________________________________________________
Date: Mar 17, 2009
At 07:23 AM 3/17/2009, Richard Girard wrote: >Okay, Dana, jump in and tell every one weight has absolutely nothing to do >with it. :-} Are you kidding? Weight is EVERYTHING! :) -Dana -- The first rule of intelligent tinkering is to save all the parts. ________________________________________________________________________________
Date: Mar 17, 2009
I thought the Carpenters were very good indeed... I won't dare to speak for Mr. George T. Alexander, eminent member of this list, who sat next to me and managed to keep me conscious for most of the class, (and allowed me to copy from his final exam paper to prevent my total humiliation) but I thought they were competent and skilled presenters. Time well spent. beauford FF-076 Brandon, FL ----- Original Message ----- From: "cristalclear13" <cristalclearwaters(at)gmail.com> Sent: Tuesday, March 17, 2009 9:29 AM Subject: Kolb-List: Re: Repairmen Inspection ropermike wrote: > Thanks Cristal and Scott. My instructors will be Carol and Brian Carpenter. I am > looking forward to the class. Oops, sorry Mike. I was thinking Sport Aviation Specialties, not Rainbow Aviation. Hopefully it'll be as good. :) -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234962#234962 ________________________________________________________________________________
Subject: Re: Look! It's Chitty-Chitty-Bang-Bang for sale!
Date: Mar 18, 2009
cristalclear13 wrote: > Oh to be a millionaire! I'd have my own Chitty-Chitty-Bang-Bang! > > Check it out...This is about the coolest thing I've ever seen. Wonder what Mr. Policeman would think if I drove my Mark II on the road with the wings folded back. :D > > http://www.terrafugia.com/vehicle.html > http://www.airventure.org/2006/thurjuly27/terrafugia.html > > You guys have probably seen this, but I can't believe they're actually taking orders. It sure would make my 90-mile one-way work commute trip a whole lot more enjoyable. > > Anybody got 150,000 bucks I could borrow? Looks like the estimated purchase price of this "roadable aircraft" went up to almost 200,000 since it actually flies. Check it out: http://www.youtube.com/watch?v=EHXnLCIgNug&eurl=http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_TerrafugiaTransition_FirstFlight_199980-1.html&feature=player_embedded -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235073#235073 ________________________________________________________________________________
Subject: prop comparisons
Date: Mar 18, 2009
You may have seen this but for those who haven't : http://www.stolspeed.com/props-comparison BB ________________________________________________________________________________
Subject: Zenith 701 for sale on ebay no engine
Date: Mar 18, 2009
In case anyone on the Kolb list might be interested, I currently have my 701 for sale on ebay without the engine or FWF (I have the hibble to start a new project, and I plan to keep my Rotax 912UL for the next project.) The reserve price is set at well below the cost of the parts. NO engine, prop or FWF included. You can save 1200 hours of building, the cost of tools, and a few thousand over the cost of the kits. You also have the full range of engine options for the airframe (there are several used Rotax engines currently available on Barnstormers for pretty good prices, people are also seem to be having good luck with the VW engines, which are really inexpensive). The airframe flew beautifully, very light and responsive on the controls, straight as an arrow. The ebay number is: 200321407977. George in Milwaukee N701GM 60 Hours flying ________________________________________________________________________________
Date: Mar 18, 2009
Hibble?? What's a hibble? Is that one of those little furry creatures that looks li ke a hamster? Mike Welch Subject: Kolb-List: Zenith 701 for sale on ebay no engine From: george.mueller(at)aurora.org Date: Wed=2C 18 Mar 2009 09:49:17 -0500 In case anyone on the Kolb list might be interested=2C I currently have my 701 for sale on ebay without the engine or FWF (I have the hibble to start a new project=2C and I plan to keep my Rotax 912UL for the next project.) The reserve price is set at well below the cost of the parts. NO engine=2C prop or FWF included. You can save 1200 hours of building=2C the cost of tools=2C and a few thousand over the cost of the kits. You also have the f ull range of engine options for the airframe (there are several used Rotax engines currently available on Barnstormers for pretty good prices=2C peopl e are also seem to be having good luck with the VW engines=2C which are rea lly inexpensive). The airframe flew beautifully=2C very light and responsi ve on the controls=2C straight as an arrow. The ebay number is: 2003214079 77. George in Milwaukee N701GM 60 Hours flying _________________________________________________________________ Hotmail=AE is up to 70% faster. Now good news travels really fast. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_03200 9 ________________________________________________________________________________
Date: Mar 18, 2009
Subject: Re: Zenith 701 for sale on ebay no engine
No, the furry critter is a tribble ( http://en.wikipedia.org/wiki/The_Trouble_with_Tribbles). "The hibble" is a combination of a "hankering" for something, but you know it might mean terrible trouble with the wife. Hankering-terrIBLE trouble... hibble. ;-) -- R On Wed, Mar 18, 2009 at 10:10 AM, Mike Welch wrote : > Hibble?? > What's a hibble? Is that one of those little furry creatures that looks > like a hamster? > > Mike Welch > > ------------------------------ > To: kolb-list(at)matronics.com > Subject: Kolb-List: Zenith 701 for sale on ebay no engine > From: george.mueller(at)aurora.org > Date: Wed, 18 Mar 2009 09:49:17 -0500 > > > In case anyone on the Kolb list might be interested, I currently have my > 701 for sale on ebay without the engine or FWF (I have the hibble to star t a > new project, and I plan to keep my Rotax 912UL for the next project.) Th e > reserve price is set at well below the cost of the parts. NO engine, pro p > or FWF included. You can save 1200 hours of building, the cost of tools, > and a few thousand over the cost of the kits. You also have the full ran ge > of engine options for the airframe (there are several used Rotax engines > currently available on Barnstormers for pretty good prices, people are al so > seem to be having good luck with the VW engines, which are really > inexpensive). The airframe flew beautifully, very light and responsive o n > the controls, straight as an arrow. The ebay number is: 200321407977. > > > George in Milwaukee > N701GM 60 Hours flying > > * > > ttp://www.matronics.com/Navigator?Kolb-Listronics.comww.matronics.com/con tribution > * > > > ------------------------------ > Hotmail=AE is up to 70% faster. Now good news travels really fast. Find o ut > more.<http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70fast er_032009> > > * > =========== ronics.com/Navigator?Kolb-List =========== =========== com/contribution =========== > * > > ________________________________________________________________________________
Date: Mar 18, 2009
Nice to hear there are a few of us Klobers in So Fl. Are any of you planning flying to S&F this year? If there is maybe some of us can fly up as a group. I am located in the Clewiston and LaBelle area. MKIIIC/912UL -------------------------------------------------- From: "Watkinsdw" <david.watkins0(at)gmail.com> Sent: 2009-03-15 11:41 Subject: Kolb-List: Re: Any KOLBs in South Florida? > > Nice to hear there will be another Kolb in the area. I'm shopping for one, > preferring an already assembled MK3X, or earlier model if it has a 912 to > keep at Pompano airport. > Haven't seen the right one yet by googling, but will be looking at Sun and > Fun. Wish me luck! > Dave > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=234672#234672 > > > ________________________________________________________________________________
Subject: Re: prop comparisons
Date: Mar 18, 2009
That is very good information, makes me very glad I got a Warp Drive prop ! Since the performance is so close, the warp has the advantage of being far stronger than all the others. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235179#235179 ________________________________________________________________________________
Date: Mar 18, 2009
Subject: Aero Coatings
Awhile back I posted a request for information from anyone who had a working knowledge of Loehle Aircraft's Aero Coating fabric finishing system. There was only one response. About the same time I called Loehle, spoke with Sandy (she didn't give a last name) and ordered their book, paying by debit card. After almost three weeks of waiting to see it grace the mailbox, I emailed them to request that if the book had not already been sent, please just cancel the order and refund my money. I never received any sort of reply and after checking tonight, I see that they never even bothered to take the payment. I can only wonder what might have transpired if I were deep into using their product and found I needed another quart of one of their reducers. Not very impressive customer service. Rick ________________________________________________________________________________
Date: Mar 18, 2009
That thing is UGLY! [Laughing] -------- Kip Firestar II, N111KX Waiex, N111YX Quickie 1, N111QX Atlanta Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235188#235188 ________________________________________________________________________________
Date: Mar 18, 2009
Rick=2C Therein lies the problem of every company on this planet. Some are fanta stic=2C some are absolutely useless. Thanks for alerting everybody about L oehle's business practices. For what it's worth=2C you can't get better service for Poly Fiber and Ae rothane products than Jim and Dondi Miller. "Best there it!!" When I recently painted my entire plane (two weeks ago)=2C Jim gave me so me pointers that helped solve a couple of "issues" I was having. BTW=2C Beaufort=2C you were right. A glass of warm MEK each night really helped me get past the arduous painting project. I might have to argue ab out the "kid" comment. At 56=2C I ain't no Spring Chicken. Mike Welch Date: Wed=2C 18 Mar 2009 20:22:35 -0500 Subject: Kolb-List: Aero Coatings From: aslsa.rng(at)gmail.com Awhile back I posted a request for information from anyone who had a workin g knowledge of Loehle Aircraft's Aero Coating fabric finishing system. Ther e was only one response. About the same time I called Loehle=2C spoke with Sandy (she didn't give a last name) and ordered their book=2C paying by deb it card. After almost three weeks of waiting to see it grace the mailbox=2C I emailed them to request that if the book had not already been sent=2C pl ease just cancel the order and refund my money. I never received any sort o f reply and after checking tonight=2C I see that they never even bothered t o take the payment. I can only wonder what might have transpired if I were deep into using their product and found I needed another quart of one of th eir reducers. Not very impressive customer service. Rick _________________________________________________________________ Windows Live=99 Contacts: Organize your contact list. http://windowslive.com/connect/post/marcusatmicrosoft.spaces.live.com-Blog- cns!503D1D86EBB2B53C!2285.entry?ocid=TXT_TAGLM_WL_UGC_Contacts_032009 ________________________________________________________________________________
Date: Mar 18, 2009
Subject: Re: Aero Coatings
Rick Have a story also...but since it happened to a friend I will not relate it here... I would not deal with them on that account.. Sandy is Mike Loehle's wife... She holds the fort down.. The paint system is a first quality product...judging from a plane that I saw ... Two part Poly urethane... as I recall... The system is not their invention to my mind...The all in one sealer/uv paint is latex perhaps? I am thinking someone out west...Wash state or Montana? may be the supplier? The best finish I have ever seen was on my Z Max...Automotive Base coat-Clear coat...Tremendous gloss and depth... UV protection goes into the clear coat...The plane I had was 5 years old and showed no signs of cracking or ring worm. sherwin williams ultra 7000 ..... Naturally I did not paint it....:-) Herb At 08:22 PM 3/18/2009, you wrote: >Awhile back I posted a request for information from anyone who had a >working knowledge of Loehle Aircraft's Aero Coating fabric finishing >system. There was only one response. About the same time I called >Loehle, spoke with Sandy (she didn't give a last name) and ordered >their book, paying by debit card. After almost three weeks of >waiting to see it grace the mailbox, I emailed them to request that >if the book had not already been sent, please just cancel the order >and refund my money. I never received any sort of reply and after >checking tonight, I see that they never even bothered to take the >payment. I can only wonder what might have transpired if I were deep >into using their product and found I needed another quart of one of >their reducers. Not very impressive customer service. > >Rick > ________________________________________________________________________________
Subject: Anyone have experence with Hirth F-30?
Date: Mar 18, 2009
Hello Folks, Does anyone have experience with a Hirth F-30 2 cycle; it is now available with "85hp fuel injected, dual ignition, with high torque version, fan cooled, G-40 gear box". It sounds like some of the small Hirth are not well liked, but there is a bit of a cat fight out there on the web between Rotax and Hirth owners! I am all ears! Thanks your thoughts, Nick Cassara Proto-type Kolbra unpowered ________________________________________________________________________________
Subject: Re: Anyone have experence with Hirth F-30?
Date: Mar 19, 2009
Bradley Stump has a Hirth of some sort on his newly finished MK3X, he was flying it at TNK homecoming last Sept. I don`t have his contact info, but I`m sure Travis or Donnie would . Jim ----- Original Message ----- From: Nick Cassara To: kolb-list(at)matronics.com Sent: Wednesday, March 18, 2009 11:56 PM Subject: Kolb-List: Anyone have experence with Hirth F-30? Hello Folks, Does anyone have experience with a Hirth F-30 2 cycle; it is now available with "85hp fuel injected, dual ignition, with high torque version, fan cooled, G-40 gear box". It sounds like some of the small Hirth are not well liked, but there is a bit of a cat fight out there on the web between Rotax and Hirth owners! I am all ears! Thanks your thoughts, Nick Cassara Proto-type Kolbra unpowered ________________________________________________________________________________
Date: Mar 19, 2009
Nick, There is a nearly new CGS Hawk at our airport that has a Hirth in that power range. I've not seen the owner/builder recently but will keep an eye out for him when I'm there and try to get an email contact for you. The one time I talked to him about the engine he had nothing but great things to say about it. Of course since it is nearly new, that says nothing about its reliability etc. BUT he did say that its fuel economy was outstanding for a 2-stroke in that power range compared to the Rotax. All hearsay so this may not have much value. -------- Thom Riddle Buffalo, NY http://riddletr.googlepages.com/sportpilot-cfi http://riddletr.googlepages.com/a%26pmechanix A complex system that works is invariably found to have evolved from a simple system that works. - John Gaule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235216#235216 ________________________________________________________________________________
Date: Mar 19, 2009
I stand corrected. Donnie has retired from TNK, Travis or Dennis may have brad Stumps contact info. Jim ----- Original Message ----- From: Jim Kmet Sent: Thursday, March 19, 2009 7:17 AM Subject: Re: Kolb-List: Anyone have experence with Hirth F-30? Bradley Stump has a Hirth of some sort on his newly finished MK3X, he was flying it at TNK homecoming last Sept. I don`t have his contact info, but I`m sure Travis or Donnie would . Jim ----- Original Message ----- From: Nick Cassara To: kolb-list(at)matronics.com Sent: Wednesday, March 18, 2009 11:56 PM Subject: Kolb-List: Anyone have experence with Hirth F-30? Hello Folks, Does anyone have experience with a Hirth F-30 2 cycle; it is now available with "85hp fuel injected, dual ignition, with high torque version, fan cooled, G-40 gear box". It sounds like some of the small Hirth are not well liked, but there is a bit of a cat fight out there on the web between Rotax and Hirth owners! I am all ears! Thanks your thoughts, Nick Cassara Proto-type Kolbra unpowered ________________________________________________________________________________
Date: Mar 19, 2009
JetPilot wrote: > That is very good information, makes me very glad I got a Warp Drive prop ! Since the performance is so close, the warp has the advantage of being far stronger than all the others. > > Mike Interesting that he complained about how heavy the warp drive was. I suppose compared to the others its MOI is higher, especially with the square blades. My taper tip seems to be light as a feather compared to the IVO medium. perhaps the removal of the material at the end of the blades reduces the MOI even more. Still settling in the adustments on mine. I must say, with all those bolts, I do kind of miss the easy pitch adjust of the IVO (tho that's the only thing I miss about it). LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235244#235244 ________________________________________________________________________________
Date: Mar 19, 2009
The Warp Drive prop takes longer to adjust the pitch on, but once you get it right you probably wont have to do it again for years. I have not touched mine since I put it on the plane and got it dialed in. I like the strength, the simplicity, and the ability to adjust each blade to perfection on the Warp Drive prop. Like a lot of things, what you get out of it depends on the effort you put in. Any updates on your testing Lucien ? Have you done any flying out of the pattern with it yet ? Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235248#235248 ________________________________________________________________________________
Date: Mar 19, 2009
JetPilot wrote: > The Warp Drive prop takes longer to adjust the pitch on, but once you get it right you probably wont have to do it again for years. I have not touched mine since I put it on the plane and got it dialed in. I like the strength, the simplicity, and the ability to adjust each blade to perfection on the Warp Drive prop. Like a lot of things, what you get out of it depends on the effort you put in. > > Any updates on your testing Lucien ? Have you done any flying out of the pattern with it yet ? > > Mike No, still havn't left the pattern ;). The windows where there's flyable winds and I have time are tiny little slivers in the late afternoon here and there. And when I do get to go up I like to concentrate on landings to keep the rust off.... I went up again yesteday and recorded between 5350 and 5450 on climbout (that's varying between Vy of 65mph and about 80mph). But I did try straight-level on downwind by flying a larger pattern. At 5100 or so I only get a little over 90mph indicated and it's easy to tell it'd definitely overspeed if I tried WOT. Seems like that's a little underpropped so just went out over my lunch break and added 1/2 degree of pitch. So I'm pretty close to a good pitch setting, hopefully I'll find the sweet spot soon. The climb rate is pretty spectacular at Vy with it the way it was, tho. between 900 and 1000fpm sustained at a density altitude of around 8500' MSL.... I'll have to give a little of that back with the additional pitch but it's still good climb for where I'm at. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235265#235265 ________________________________________________________________________________
Subject: Owyhee Canyon Pictures
Date: Mar 19, 2009
http://www.facebook.com/album.php?aid 12888&id=1002056194&l=358dc 9273a The weather was good today even though the lighting was a bit flat, so I flew again in my attempt to break in my HKS before I have to try to keep up with a bunch of Mark III's this May after MV. To keep from getting bored with the scenery I went to the Canyon, which always holds fascination for me. I flew for 1hour and 18 minutes traveling 79 miles. I flew the first 45 minutes at 5000 RPM's on one tank and then switched to the rear tank and flew at 5400 RPM"S. The weird thing about it is that there is no noticeable difference in fuel burn. Temps are still high and I had to fly with the choke on to keep the temps under control on my way back. I have 18 hours on the engine now. At 5000 RPMs the temps were 316 tops. The only trouble with that is that I don't like to fly that slow. :-) Larry ________________________________________________________________________________
Subject: Re: Owyhee Canyon Pictures
Date: Mar 19, 2009
Folks, The photos don't compare with flying the Owyhee. First time I flew it I had Arty Trost on board. I think John W had dropped down in the canyon ahead of me. We were up on the lip. I asked Arty if s he was game for flying the canyon. Her reply was go for it. We dropped in and she grinned and yelped the rest of the flight. As big as the canyon i s, it still feels like your wing tips will hit the sides, once down in the bottom right over the river. Had the opportunity to fly it every year since then. Think that was 2006. john h mkIII To keep from getting bored with the scenery I went to the Canyon, which always holds fascination for me. Larry ________________________________________________________________________________
Date: Mar 19, 2009
> Striking similarity in the two pictures here? Could Miss P'fer be a distant cousin? :D > Cristal Waters She ain't no relation! ;-) john h mkIII ________________________________________________________________________________
Date: Mar 19, 2009
At 12:56 AM 3/19/2009, you wrote: >Hello Folks, > >Does anyone have experience with a Hirth F-30 2 cycle; it is now >available with "85hp fuel injected, dual ignition, with high torque >version, fan cooled, G-40 gear box". It sounds like some of the >small Hirth are not well liked, but there is a bit of a cat fight >out there on the web between Rotax and Hirth owners! > >I am all ears! We got a 70 HP - with problems - at the farm. But I wouldn't want to comment on that particular engine on this list. Oil leaks, gear box problems - engine out (frame damage - lot of work). But, they say they have fixed them........ I don't like Hirth's, (the old ones or the new ones) so I shouldn't comment anyway. ________________________________________________________________________________
Date: Mar 19, 2009
> We got a 70 HP - with problems - at the farm. > But I wouldn't want to comment on that particular engine on this list. > Oil leaks, gear box problems - engine out (frame damage - lot of work). > But, they say they have fixed them........ > I don't like Hirth's, (the old ones or the new ones) so I shouldn't > comment anyway. Possum: Thanks for not commenting on the Hirth reputation. Like a some of the Rotax and Cuyuna engines I owned and flew in front of, they quit making noise at the most inopportune times. Uncommanded silence. I don't know anything about them except what I hear or happen to see at a flyin somewhere. We do not have any in my neck of the woods. Someone mentioned a mkIIIx at last year's Kolb Homecoming flying with a Hirth. I did see that one fly. However, I believe it was trailered to Labhart Field, and trailered home. Good looking Kolb. john h mkIII ________________________________________________________________________________
Date: Mar 20, 2009
Larry This just doesn't sound right. Your going to have problems when it warms up. I'm sure you told us before but are you running too lean? What do your spark plugs look like? What temps are the other Kolb HKSs running? My VW guru has me jetting my VW on what I would say is on the rich side. A bit richer than I see on a water cooled engine. Seems like running a bit rich lowered my VWs oil temps but not my cht. Go figure. My VW CHTs run on the cool side but when pushed beyond cruise power they warm up. Are you running with too much prop pitch. Do you notice a large noise reduction when pulling power back to cruise power? Do you need to fashion some cooling scoops around those cylinders. My VW needs to have cooling air forced all the way around the cylinders and thru the heads. But a HKS has only one cylinder on each side so cooling should fine but? Most HKSs run with a big fan in front, do you need something extra in pusher mode. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: Larry Cottrell To: kolb-list(at)matronics.com Sent: Thursday, March 19, 2009 9:26 PM Subject: Kolb-List: Owyhee Canyon Pictures http://www.facebook.com/album.php?aid 12888&id=1002056194&l=358dc 9273a The weather was good today even though the lighting was a bit flat, so I flew again in my attempt to break in my HKS before I have to try to keep up with a bunch of Mark III's this May after MV. To keep from getting bored with the scenery I went to the Canyon, which always holds fascination for me. I flew for 1hour and 18 minutes traveling 79 miles. I flew the first 45 minutes at 5000 RPM's on one tank and then switched to the rear tank and flew at 5400 RPM"S. The weird thing about it is that there is no noticeable difference in fuel burn. Temps are still high and I had to fly with the choke on to keep the temps under control on my way back. I have 18 hours on the engine now. At 5000 RPMs the temps were 316 tops. The only trouble with that is that I don't like to fly that slow. :-) Larry ________________________________________________________________________________
Date: Mar 20, 2009
Subject: Off list - Hirth reputation.
John This is a new engine with less than 40 hrs. 70HP? - maybe - Water cooled. Oil leak...seals fixed Reed values ..runs hot - fixed Gear Box - bolt sheared - engine quit - plane crashed. The old ones were the same way, they work great on those little race cars that can run them up to 10,000 RPMs and have gears, but can't handle the constant prop load on a plane. A lot of engines have the same problem. Just between you and me and the fence post-- Screw Hirth engines. Bill has tried them several times over the last 12 years. Along with AMC engines and a few others. I've got way over what I should have on my 503 "1997 Rotax" engine without a rebuild and it still runs like a Toyota. > > We got a 70 HP - with problems - at the farm. >>But I wouldn't want to comment on that particular engine on this list. >>Oil leaks, gear box problems - engine out (frame damage - lot of work). >Possum: > >Thanks for not commenting on the Hirth reputation. > > ________________________________________________________________________________
Date: Mar 19, 2009
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Vapor Pressure and E-10 mogas
In this month's issue of Ultraflight magazine, in Rotax Talk by Ronnie Smith, he says (for those of us using two-strokes and E-10 mogas): "Remember also that there will be an altitude limit on the use of this 10% [ethanol gas]. I think it's around 7500 ft. MSL. Why? Well, car gas will start to vapor lock at higher altitudes so you have to watch this." He goes on to say that if we're flying about 7500 ft MSL we should use 100LL which has a lower vapor pressure than auto gas. Anyone heard of this? Had this happen? I know I'll be flying above 7500 MSL on my flight to Florida and am curious if any of you other two-strokers have ever experienced this or heard of it. Arty Trost Sandy, Oregon www.LessonsFromTheEdge.com/uladventure2009.htm ________________________________________________________________________________
Date: Mar 19, 2009
----- Original Message ----- From: Richard & Martha Neilsen To: kolb-list(at)matronics.com Sent: Thursday, March 19, 2009 10:25 PM Subject: Re: Kolb-List: Owyhee Canyon Pictures Larry This just doesn't sound right. Your going to have problems when it warms up. I'm sure you told us before but are you running too lean? What do your spark plugs look like? What temps are the other Kolb HKSs running? My VW guru has me jetting my VW on what I would say is on the rich side. A bit richer than I see on a water cooled engine. Seems like running a bit rich lowered my VWs oil temps but not my cht. Go figure. My VW CHTs run on the cool side but when pushed beyond cruise power they warm up. Are you running with too much prop pitch. Do you notice a large noise reduction when pulling power back to cruise power? Do you need to fashion some cooling scoops around those cylinders. My VW needs to have cooling air forced all the way around the cylinders and thru the heads. But a HKS has only one cylinder on each side so cooling should fine but? Most HKSs run with a big fan in front, do you need something extra in pusher mode. Rick Neilsen Redrive VW powered MKIIIC Rick, I agree, I think that what I am going to try when my first oil change comes up in7 or so hours is to take the oil cooler off the top of the wing and install it upside down at the rear of the cage. Perhaps the cooler is blocking enough air off the engine that it is causing it to over heat. As for the pitch of the prop, it is set so that I get 6150 at WOT, that is 50 off the max RPM's. As you can see the muffler and oil cooler block a lot of air. I am just not sure if moving the cooler will make that much difference however. Oh if you are wondering this was the set up that was sucessful on a Slingshot. I am not convinced that it is going to work on a Firestar however. Larry ________________________________________________________________________________
Date: Mar 20, 2009
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Kolb List: Anyone have experience with a Hirth F-30?
- Larry- Have you tried flying without the gap seal?- Maybe it's just t he angle of the photo, but it looks like almost 1/2 of the cooler's air flo w os blocked. - ------------------------- ------------------------ ------------------------- ------------------ Bill Sullivan ------------------------- ------------------ Windsor Locks, Ct. ________________________________________________________________________________
Subject: Re: Vapor Pressure and E-10 mogas
Date: Mar 20, 2009
Arty Trost wrote: > In this month's issue of Ultraflight magazine, in Rotax Talk by Ronnie Smith, he says (for those of us using two-strokes and E-10 mogas): > > "Remember also that there will be an altitude limit on the use of this 10% [ethanol gas]. I think it's around 7500 ft. MSL. Why? Well, car gas will start to vapor lock at higher altitudes so you have to watch this." > > He goes on to say that if we're flying about 7500 ft MSL we should use 100LL which has a lower vapor pressure than auto gas. > > Anyone heard of this? Had this happen? I know I'll be flying above 7500 MSL on my flight to Florida and am curious if any of you other two-strokers have ever experienced this or heard of it. > > Arty Trost > Sandy, Oregon > > > www.LessonsFromTheEdge.com/uladventure2009.htm I've heard this too, but havn't tried running E10 in anything yet except my pickup. I often drive in it up to the local ski area, tho, which ends up at a little over 10,000' MSL once I get to the top and havn't had any problems with vapor lock (tho it's fuel injected which may help?). In the plane, 7500' MSL is approx. pattern altitude for me and I often bump right up against 10,000'MSL when I do have time to leave the pattern.... I've been lucky and able to find pure unleaded autogas in town and have no problems with it at those altitudes. But I'd be a little worried about E10 way up there. I flew my FSII here for a while before I sold it and didn't have problems with vapor lock, but again we hadn't been infiltrated with E10 at the time. I'd say 100LL would be the safest route for flying at high altitudes if you're worried about it.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235349#235349 ________________________________________________________________________________
Date: Mar 20, 2009
> He goes on to say that if we're flying about 7500 ft MSL we should use 100LL which has a lower vapor pressure than auto gas. > > Arty Trost Arty: During my two stroke cross country days, I used 100LL primarily because that was normally all that was available. It costs more, but two strokes as well and four strokes operate well on it. Only drawback during a long cross country my be lead fouling, which can be remedied in a few minutes by pulling the spark plugs and cleaning the lead off the plug with a pen knife or piece of safety wire. It is usually soft and comes right off. With dual ignition now days, a plug will let you know when it starts to get loaded up. Then again, today's two strokes may not be affected. john h mkIII ________________________________________________________________________________
Date: Mar 20, 2009
Wondering if a mix of MO. and AV. would do the trick? by the way...Av gas is a really good degreaser...beats those spray cans ...Use carefully...and in the open... Works in a chemical sprayer...Herb and ...I have two buds who run Hirth engines sucessfully...Twin opposed model.... At 07:56 AM 3/20/2009, you wrote: > > >Arty Trost wrote: > > In this month's issue of Ultraflight magazine, in Rotax Talk by > Ronnie Smith, he says (for those of us using two-strokes and E-10 mogas): > > > > "Remember also that there will be an altitude limit on the use of > this 10% [ethanol gas]. I think it's around 7500 ft. MSL. Why? > Well, car gas will start to vapor lock at higher altitudes so you > have to watch this." > > > > He goes on to say that if we're flying about 7500 ft MSL we > should use 100LL which has a lower vapor pressure than auto gas. > > > > Anyone heard of this? Had this happen? I know I'll be flying > above 7500 MSL on my flight to Florida and am curious if any of you > other two-strokers have ever experienced this or heard of it. > > > > Arty Trost > > Sandy, Oregon > > > > > > www.LessonsFromTheEdge.com/uladventure2009.htm > > >I've heard this too, but havn't tried running E10 in anything yet >except my pickup. > >I often drive in it up to the local ski area, tho, which ends up at >a little over 10,000' MSL once I get to the top and havn't had any >problems with vapor lock (tho it's fuel injected which may help?). > >In the plane, 7500' MSL is approx. pattern altitude for me and I >often bump right up against 10,000'MSL when I do have time to leave >the pattern.... > >I've been lucky and able to find pure unleaded autogas in town and >have no problems with it at those altitudes. But I'd be a little >worried about E10 way up there. > >I flew my FSII here for a while before I sold it and didn't have >problems with vapor lock, but again we hadn't been infiltrated with >E10 at the time. > >I'd say 100LL would be the safest route for flying at high altitudes >if you're worried about it.... > >LS > >-------- >LS >Titan II SS > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=235349#235349 > > ________________________________________________________________________________
Date: Mar 20, 2009
I don't know the comparative vapor pressures of ethanol and mogas but auto gas is blended with higher vapor pressures in the winter for easier cold weather starting -or at least it was. Summer blend should be ok at 10K as far as vapor pressure. My concern is moisture content which can condense out as carb frost. The quality control of 100LL would probably be the important factor to consider when flying over those craggy rocks. BB On 20, Mar 2009, at 1:11 AM, TheWanderingWench wrote: > > > > In this month's issue of Ultraflight magazine, in Rotax Talk by > Ronnie Smith, he says (for those of us using two-strokes and E-10 > mogas): > > "Remember also that there will be an altitude limit on the use of > this 10% [ethanol gas]. I think it's around 7500 ft. MSL. Why? > Well, car gas will start to vapor lock at higher altitudes so you > have to watch this." > > He goes on to say that if we're flying about 7500 ft MSL we should > use 100LL which has a lower vapor pressure than auto gas. > > Anyone heard of this? Had this happen? I know I'll be flying above > 7500 MSL on my flight to Florida and am curious if any of you other > two-strokers have ever experienced this or heard of it. > > Arty Trost > Sandy, Oregon > > > www.LessonsFromTheEdge.com/uladventure2009.htm > > ________________________________________________________________________________
Date: Mar 20, 2009
Looks like more than half of your oil cooler is blocked by the gap seal. With the muffler positioned where it is, that may also be degrading the oil cooler's performance. The oil cooler placed under and rear of the muffler may be kicking air off of or blocking cooling air from the cylinders. A couple straight stacks out the rear of the engine would eliminate that bi g "can" muffler. Got to be disrupting air flow and increasing drag. I know you want your airplane quiet, and I don't blame you. Wish mine coul d be put into stealth mode, as my hearing quickly fades away. Very fatigui ng flying all day in a snare drum like mine. john h As you can see the muffler and oil cooler block a lot of air. I am j ust not sure if moving the cooler will make that much difference however. O h if you are wondering this was the set up that was sucessful on a Slingsho t. I am not convinced that it is going to work on a Firestar however. Larry ________________________________________________________________________________
Subject: DHS Initiatives Could "Lock Out" General Aviation
Date: Mar 20, 2009
March 19, 2009 General aviation is under attack on several fronts in the name of national security. While the U.S. Department of Homeland Security (DHS) and its divisions adopt a whatever it takes posture, the people who fly aircraft for fun, education, philanthropy, and business are asking whether severe restrictions on freedoms are worth marginal enhancements to security. When the cost of lost liberties are combined with the significant dollars required of aviators and airports to comply with these initiatives, an unfavorable cost-to-benefit ratio becomes strikingly evident. DHS is throwing several security initiatives at general aviation at once, challenging aircraft operators not only to differentiate them but also to understand how they interrelate. Accordingly, EAA has posted an analysis that sorts out the issues and identifies common themes. The combined effect of these initiatives would be stifling to general aviation. Imagine security requirements that would: o Force aviators to acquire government approval before each flight in certain general aviation aircraft. o Require private citizens to develop and implement costly security-compliance programs. o Hamstring historic aircraft operations such as EAAs B-17 tour. o Limit our military-veteran aviators freedom to fly historic airplanes like the ones that, ironically, they flew in service to defend American freedoms. o Restrict access to the airport for pilots, owners, and their guests. o Make it difficult or impossible to conduct certain Young Eagles events. o Force pilots and passengers to stay in the aircraft when arriving as a transient flight at an airport until an authorized person becomes available to escort them from the aircraft. o Limit the publics access to engage in and support general aviation activities. o Limit the interactive and social elements of participation in flight that are so important to a thriving general aviation community. Members of EAAs Regulatory Affairs staff remind EAAers that these and more consequences could result if the general aviation community fails to rally to protect its interests. They encourage you to stay informed, spread the word, and be prepared to act. -------- Ralph B Original Firestar 447 N91493 E-AB 22 years flying it Kolbra 912UL N20386 almost 1 year flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235355#235355 ________________________________________________________________________________
Date: Mar 20, 2009
> I often drive in it up to the local ski area=2C tho=2C which ends up at a little over 10=2C000' MSL once I get to the top and havn't had any problem s with vapor lock (tho it's fuel injected which may help?). -------- > LS > Titan II SS Lucien=2C In your truck=2C you will likely never have a problem using E10 auto gas =2C even at 18=2C000 MSL.(providing it was built to handle E10) This is be cause your truck/car is run by a computer ECU=2C using a miriad of sensors to keep the engine in tune. It uses: 1) a coolant temperature sensor (colder engines get more fuel than warmer e ngines) 2) MAP (mainfold atmospheric pressure) for incoming combustion air 3) O2 sensor (to determine the Air/Fuel ratio) 4) MAF (mass air flow) to determine the volume of air being consumed 5) FPR (fuel pressure regulator) the computer uses this information to det ermine the pulse width that the ECU tells the fuel injector to pulse fuel. (i.e. lower pressure gets more pulse width) There are many other sensors=2C including those that the engine uses to a djust the ignition timing=2C fuel enrichment=2C etc. Comparing an automobile engine's reaction to E10 has nothing to do with h ow an airplane engine will react=2C unless=2C of course=2C your airplane's engine is governed by an ECU (electronic computer unit) The ECU monitors a ll the necessary engine parameters dozens of times a second. Comparing an airplane engine with a carburetor=2C and a truck using E10 a utogas=2C is much like comparing an apple with an orange. Mike Welch MkIII _________________________________________________________________ Get quick access to your favorite MSN content with Internet Explorer 8. http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid=B037 MSN55C0701A ________________________________________________________________________________
Date: Mar 20, 2009
> >Summer blend should be ok at 10K as far as vapor pressure. My >concern is moisture content >which can condense out as carb frost. The quality control of 100LL >would probably be the important factor >to consider when flying over those craggy rocks. >BB Bob, Given equal handling and storage of E-10 and non E-10 fuel, I would think that the E-10 would reduce the ice tendency. With the alcohol in the fuel, it would take up the water and pass it on through to the engine. Any additional water that can not be held in the alcohol will fall out and remain in the bottom of the tank or carb bowl and have no effect on carb icing. I believe the greatest threat of carb icing come from high humidity air and not the fuel. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: AirVenture 2009
Date: Mar 20, 2009
May I suggest Oshkosh July 27-Aug 2 for another Kolb flyin. Its been real lonely in the UL/LSA camp ground the last few years. Last year there was for the first time was a Port-o-let in the camp ground. John's friend Karla (head of the ultralight council) made it clear that it wouldn't be allowed ever again. In spite of the cold reception we get there it is a good time. It is important that we fly in and show the EAA that there is still some interest in ultralights and LSAs. I have tried to get it across to the EAA that Sun N Fun still has a strong showing of ultralights and LSA. Maybe they are doing something different. Last year there were only three to four planes in the camp ground and at times there was no one flying. We were being told the ultralight vendor area would be changed to antique plane parking. At the risk of sounding negative I don't want the bastards to win and completely close down the ultralight area at Airventure (Oshkosh). Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
Date: Mar 20, 2009
Bill, At least half of the coolers air flow is blocked, but I still have the rest of the exposed top part taped off to get the oil temps up above 170 degrees. I will remove the tape when I fly today. The oil is plenty cool, the heads are not. Larry ----- Original Message ----- From: william sullivan To: kolb list Sent: Friday, March 20, 2009 5:28 AM Subject: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? Larry- Have you tried flying without the gap seal? Maybe it's just the angle of the photo, but it looks like almost 1/2 of the cooler's air flow os blocked. Bill Sullivan Windsor Locks, Ct. ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/19/09 12:26:00 ________________________________________________________________________________
Date: Mar 20, 2009
herbgh(at)nctc.com wrote: > Wondering if a mix of MO. and AV. would do the trick? > Blends like this seem to be acceptable by Rotax as they recommend it to get the octane rating correct if part of the gas is 87 regular. By that time tho you may as well just run 100LL period as a convenience measure. I ran my 447 on my trike on pure 100LL for about 100 hours. Turned out the plugs lasted almost 50 hours before I began to notice any problems. So I think the fouling issue might not actually be that bad. It wasn't for me. I ran 100LL a fair bit in my 503's as well (more than 30% of the time for sure on the one I put on my trike to replace the 447) and didn't start getting a mag drop for at least 40 hours. So I'd just run 100LL and install a fresh set of plugs at the start of the trip to zero them out. When I go places underneath my 912 I usually put at least some 100LL in the tank if not a full tank. Gives an extra bit of insurance against vapor lock as I climb up towards the stratosphere..... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235366#235366 ________________________________________________________________________________
Subject: Engine monitoring
Date: Mar 20, 2009
Kolbers=2C Question: Doesn't the Rotax 912 use altitude compensating carbs? It see ms like I remember hearing that from years ago. Or was it Bing carbs=2C in general? Regarding engine monitoring: Are you guys aware that there a slew of gau ges and sensors "out there" that you can use to know exactly what's going o n with your engine? These "gauges & sensors" are stand-alone monitoring devices. That is=2C they work all by themselves=2C and not dependant of anything else. Example: a Wideband O2 sensor and digital gauge will tell you EXACTLY wh at your fuel/air ratio is. The digital gauges have an alarm mode=2C in the event your engine becomes too lean. http://cgi.ebay.com/ebaymotors/PLX-DEVICES-SM-AFR-DM-5-52MM-GAUGE-WIDEBAND- KIT-BLACK_W0QQcmdZViewItemQQcategoryZ6763QQihZ022QQitemZ350177800390QQrdZ1Q QsspagenameZWDVW You can also get a digital EGT gauge ( with preset alarm parameters): http://auberins.com/index.php?main_page=index&cPath=5&zenid=cfe62dc03 26887ee2f3a93405677be5b I have BOTH of these gauges=2C along with several others=2C to provide de tailed engine monitoring. Maybe some of us don't care too precisely what i s going on inside our engines=2C but I do. Mike Welch MkIII _________________________________________________________________ Hotmail=AE is up to 70% faster. Now good news travels really fast. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_03200 9 ________________________________________________________________________________
Date: Mar 20, 2009
Larry=2C If your cylinder heads run cool(ish)=2C and the EGTs run hot=2C this may be a result of too advanced timing. Is there any way to adjust timing to r etard about 2-3 degrees? Mike Welch From: lcottrell(at)fmtcblue.com Subject: Re: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? Date: Fri=2C 20 Mar 2009 09:04:43 -0600 Bill=2C At least half of the coolers air flow is blocked=2C but I still have th e rest of the exposed top part taped off to get the oil temps up above 170 degrees. I will remove the tape when I fly today. The oil is plenty cool=2C the heads are not. Larry ----- Original Message ----- From: william sullivan Sent: Friday=2C March 20=2C 2009 5:28 AM Subject: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30 ? Larry- Have you tried flying without the gap seal? Maybe it's just the a ngle of the photo=2C but it looks like almost 1/2 of the cooler's air flow os blocked. Bill Sullivan Windsor Locks=2C Ct. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c - Release Date: 03/19/09 12:26:00 _________________________________________________________________ Hotmail=AE is up to 70% faster. Now good news travels really fast. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_03200 9 ________________________________________________________________________________
Date: Mar 20, 2009
The cylinder heads are bumping redline at any rpm over 5200. (max is 6200 allowable) the EGT's max is 1400. They are 1150. Larry ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Friday, March 20, 2009 9:23 AM Subject: RE: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? Larry, If your cylinder heads run cool(ish), and the EGTs run hot, this may be a result of too advanced timing. Is there any way to adjust timing to retard about 2-3 degrees? Mike Welch ------------------------------------------------------------------------- ----- From: lcottrell(at)fmtcblue.com To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? Date: Fri, 20 Mar 2009 09:04:43 -0600 Bill, At least half of the coolers air flow is blocked, but I still have the rest of the exposed top part taped off to get the oil temps up above 170 degrees. I will remove the tape when I fly today. The oil is plenty cool, the heads are not. Larry ----- Original Message ----- From: william sullivan To: kolb list Sent: Friday, March 20, 2009 5:28 AM Subject: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? Larry- Have you tried flying without the gap seal? Maybe it's just the angle of the photo, but it looks like almost 1/2 of the cooler's air flow os blocked. Bill Sullivan Windsor Locks, Ct. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ------------------------------------------------------------------------- --- - Release Date: 03/19/09 12:26:00 ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution ------------------------------------------------------------------------- ----- Hotmail=AE is up to 70% faster. Now good news travels really fast. Find out more. ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/20/09 06:59:00 ________________________________________________________________________________
Date: Mar 20, 2009
Subject: Re: Engine monitoring
Frugal Herb here... Mike. I wonder if any of the O2 sensors are "less" succeptible to leaded gas? 100 octane is the minuimum analysis...I recall accepting the delivery of a truck of av gas at a local airport that had an analysis of 119 octane... . High Octane gas is regular gas with additives...to slow the burn mainly...everyone knows this I guess? Maybe the O2 sensor can be brought back to life with a blow torch? burn the lead off. In our application...all that is needed is a single wire sensor with the calibration curve--ie: micro volts output indicates O2 ratio... This output could be easily amplified and sent to an analog gauge , calibrated to indicate the ratio. The Zirconia sensor crosses to 14.7 ratio at about 400 micro volts ... an analog meter...0 to 1000 micro volts would suffice.. In some applications of auto engines to planes; the O2 sensor is replaced by an adjustable voltage source on the instrument panel... Poor mans Mixture control...set by using the EGT gauge.. Feed the signal into the computer on the O2 input lines.. Herb Ps.. Bro Pike Discovered a good use for our 20 buck noise reduction head phones...from the aviation dept at Wally.World... When mowing ,,, no input ..just turn it on...stick the cable in your shirt pocket...:-) Good pair of noise muff's cost that much... At 10:18 AM 3/20/2009, you wrote: >Kolbers, > > Question: Doesn't the Rotax 912 use altitude > compensating carbs? It seems like I remember > hearing that from years ago. Or was it Bing carbs, in general? > > Regarding engine monitoring: Are you guys > aware that there a slew of gauges and sensors > "out there" that you can use to know exactly what's going on with your engine? > > These "gauges & sensors" are stand-alone > monitoring devices. That is, they work all by > themselves, and not dependant of anything else. > > Example: a Wideband O2 sensor and digital > gauge will tell you EXACTLY what your fuel/air > ratio is. The digital gauges have an alarm > mode, in the event your engine becomes too lean. > ><http://cgi.ebay.com/ebaymotors/PLX-DEVICES-SM-AFR-DM-5-52MM-GAUGE-WIDEBAND -KIT-BLACK_W0QQcmdZViewItemQQcategoryZ6763QQihZ022QQitemZ350177800390QQrdZ1Q QsspagenameZWDVW>http://cgi.ebay.com/ebaymotors/PLX-DEVICES-SM-AFR-DM-5-52MM -GAUGE-WIDEBAND-KIT-BLACK_W0QQcmdZViewItemQQcategoryZ6763QQihZ022QQitemZ3501 77800390QQrdZ1QQsspagenameZWDVW > > You can also get a digital EGT gauge ( with preset alarm parameters): > ><http://auberins.com/index.php?main_page=index&cPath=5&zenid=cfe62dc0 326887ee2f3a93405677be5b>http://auberins.com/index.php?main_page=index&cPa th=5&zenid=cfe62dc0326887ee2f3a93405677be5b > > I have BOTH of these gauges, along with > several others, to provide detailed engine > monitoring. Maybe some of us don't care too > precisely what is going on inside our engines, but I do. > >Mike Welch >MkIII > > >---------- >Hotmail=AE is up to 70% faster. Now good news >travels really fast. ><http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_0320 09>Find >out more. ________________________________________________________________________________
Date: Mar 20, 2009
Herb=2C Nope=2C I don't think ANY of the O2 sensors will work very well with a st eady diet of leaded gasoline. Eventually=2C you'll get lead buildup. As far as cleaning them goes=2C I doubt a blow touch would be a good idea . I haven't done a google search to see if anyone knows how to remove lead deposits from O2 sensors. The O2 sensor I have says to mount it at least 24" away from the cylinders. It will burn up if exposed to high heat (blow torch). Again=2C I haven't done the research=2C but I think some sort of chemical bath may clean them. Just guessing=2C tho. It's entirely possible that o nce they clogged with lead=2C they're shot! For very precise AFR (air/fuel ratio) readings=2C a person would want the Wideband O2 sensor/gauge. The standard O2 sensor=2C with a voltage range of 0 to 1 volt=2C just isn't accurate enough for rapid determination of AFR . The wideband O2 sensor ranges from 0 to 5 volts. (The sensitivity is muc h greater than a standard O2 sensor.) The Wideband gauge likely contains a ll the electronics you mentioned. Mike MkIII Date: Fri=2C 20 Mar 2009 10:59:08 -0500 From: herbgh(at)nctc.com Subject: Re: Kolb-List: Engine monitoring Frugal Herb here... Mike. I wonder if any of the O2 sensors are "less" succeptible to lead ed gas? 100 octane is the minuimum analysis...I recall accepting the d elivery of a truck of av gas at a local airport that had an analysis of 119 octane... . High Octane gas is regular gas with additives...to slow the burn mainly...everyone knows this I guess? Maybe the O2 sensor can be brought back to life with a blow torch? burn th e lead off. In our application...all that is needed is a single wire sensor with the calibration curve--ie: micro volts output indicates O2 ratio... This o utput could be easily amplified and sent to an analog gauge =2C calibrated to indicate the ratio. The Zirconia sensor crosses to 14.7 ratio at ab out 400 micro volts ... an analog meter...0 to 1000 micro volts would suffi ce.. In some applications of auto engines to planes=3B the O2 sensor is replace d by an adjustable voltage source on the instrument panel... Poor mans Mi xture control...set by using the EGT gauge.. Feed the signal into the compu ter on the O2 input lines.. Herb Ps.. Bro Pike Discovered a good use for our 20 buck noise reduction head phones...from the aviation dept at Wally.World... When mowing =2C=2C=2C no input ..just turn it on...stick the cable in your shirt pocket...:-) Good pair of noi se muff's cost that much... At 10:18 AM 3/20/2009=2C you wrote: Kolbers=2C Question: Doesn't the Rotax 912 use altitude compensating carbs? It see ms like I remember hearing that from years ago. Or was it Bing carbs=2C in general? Regarding engine monitoring: Are you guys aware that there a slew of gau ges and sensors "out there" that you can use to know exactly what's going o n with your engine? These "gauges & sensors" are stand-alone monitoring devices. That is=2C they work all by themselves=2C and not dependant of anything else. Example: a Wideband O2 sensor and digital gauge will tell you EXACTLY wh at your fuel/air ratio is. The digital gauges have an alarm mode=2C in the event your engine becomes too lean. http://cgi.ebay.com/ebaymotors/PLX-DEVICES-SM-AFR-DM-5-52MM-GAUGE-WIDEBAND- KIT-BLACK_W0QQcmdZViewItemQQcategoryZ6763QQihZ022QQitemZ350177800390QQrdZ1Q QsspagenameZWDVW You can also get a digital EGT gauge ( with preset alarm parameters): http://auberins.com/index.php?main_page=index&cPath=5&zenid=cfe62dc03 26887ee2f3a93405677be5b I have BOTH of these gauges=2C along with several others=2C to provide de tailed engine monitoring. Maybe some of us don't care too precisely what i s going on inside our engines=2C but I do. Mike Welch MkIII Hotmail=AE is up to 70% faster. Now good news travels really fast. Find out more. _________________________________________________________________ Express your personality in color! Preview and select themes for Hotmail=AE . http://www.windowslive-hotmail.com/LearnMore/personalize.aspx?ocid=TXT_MS GTX_WL_HM_express_032009#colortheme ________________________________________________________________________________
Date: Mar 20, 2009
I set my old teakettle solex up with a one wire sensor. They are reasonably accurate but don't have any preheat function (reference stabilized voltage) like the gooder ones. -So to get a reading you have to set up an rpm, wait for the voltage to stabilize, and write it down. Maybe not too handy for everyday flight. In my case I was only using it to set up the three frustrating variables of the idle, main and economizer jets. THere was also a full throttle gas-dumper that I blocked off. -A time consuming, stress inducing job, tail tied down, repeated throttle range runups, airplane jumping around, but, once done, zero maintenance from then on. The sensor is now on a shelf. BB On 20, Mar 2009, at 1:54 PM, Mike Welch wrote: > Herb, > > Nope, I don't think ANY of the O2 sensors will work very well > with a steady diet of leaded gasoline. Eventually, you'll get lead > buildup. > As far as cleaning them goes, I doubt a blow touch would be a > good idea. I haven't done a google search to see if anyone knows > how to remove lead deposits from O2 sensors. The O2 sensor I have > says to mount it at least 24" away from the cylinders. It will > burn up if exposed to high heat (blow torch). > Again, I haven't done the research, but I think some sort of > chemical bath may clean them. Just guessing, tho. It's entirely > possible that once they clogged with lead, they're shot! > > For very precise AFR (air/fuel ratio) readings, a person would > want the Wideband O2 sensor/gauge. The standard O2 sensor, with a > voltage range of 0 to 1 volt, just isn't accurate enough for rapid > determination of AFR. > The wideband O2 sensor ranges from 0 to 5 volts. (The > sensitivity is much greater than a standard O2 sensor.) The > Wideband gauge likely contains all the electronics you mentioned. > > Mike > MkIII > > Date: Fri, 20 Mar 2009 10:59:08 -0500 > To: kolb-list(at)matronics.com > From: herbgh(at)nctc.com > Subject: Re: Kolb-List: Engine monitoring > > Frugal Herb here... > > Mike. I wonder if any of the O2 sensors are "less" succeptible > to leaded gas? 100 octane is the minuimum analysis...I recall > accepting the delivery of a truck of av gas at a local airport that > had an analysis of 119 octane... . High Octane gas is regular gas > with additives...to slow the burn mainly...everyone knows this I > guess? > > Maybe the O2 sensor can be brought back to life with a blow torch? > burn the lead off. > > > In our application...all that is needed is a single wire sensor > with the calibration curve--ie: micro volts output indicates O2 > ratio... This output could be easily amplified and sent to an > analog gauge , calibrated to indicate the ratio. The Zirconia > sensor crosses to 14.7 ratio at about 400 micro volts ... an analog > meter...0 to 1000 micro volts would suffice.. > > In some applications of auto engines to planes; the O2 sensor is > replaced by an adjustable voltage source on the instrument > panel... Poor mans Mixture control...set by using the EGT gauge.. > Feed the signal into the computer on the O2 input lines.. > > Herb > Ps.. > > > Bro Pike > > Discovered a good use for our 20 buck noise reduction head > phones...from the aviation dept at Wally.World... When mowing ,,, > no input ..just turn it on...stick the cable in your shirt > pocket...:-) Good pair of noise muff's cost that much... > > > At 10:18 AM 3/20/2009, you wrote: > Kolbers, > > Question: Doesn't the Rotax 912 use altitude compensating > carbs? It seems like I remember hearing that from years ago. Or > was it Bing carbs, in general? > > Regarding engine monitoring: Are you guys aware that there a > slew of gauges and sensors "out there" that you can use to know > exactly what's going on with your engine? > > These "gauges & sensors" are stand-alone monitoring devices. > That is, they work all by themselves, and not dependant of anything > else. > > Example: a Wideband O2 sensor and digital gauge will tell you > EXACTLY what your fuel/air ratio is. The digital gauges have an > alarm mode, in the event your engine becomes too lean. > > http://cgi.ebay.com/ebaymotors/PLX-DEVICES-SM-AFR-DM-5-52MM-GAUGE- > WIDEBAND-KIT- > BLACK_W0QQcmdZViewItemQQcategoryZ6763QQihZ022QQitemZ350177800390QQrdZ1 > QQsspagenameZWDVW > > You can also get a digital EGT gauge ( with preset alarm > parameters): > > http://auberins.com/index.php? > main_page=index&cPath=5&zenid=cfe62dc0326887ee2f3a93405677be5b > > I have BOTH of these gauges, along with several others, to > provide detailed engine monitoring. Maybe some of us don't care > too precisely what is going on inside our engines, but I do. > > Mike Welch > MkIII > > Hotmail=AE is up to 70% faster. Now good news travels really fast. > Find out more. > ttp://www.matronics.com/Navigator?Kolb-List > ronics.com > ww.matronics.com/contribution > > > Express your personality in color! Preview and select themes for > Hotmail=AE. See how. > > ________________________________________________________________________________
Date: Mar 20, 2009
Subject: Warp Drive bolt torque
- Does anybody know the torque on the bolts that hold a Warp Drive prop t o the hub flange on a 447?- I called Warp Drive, and they are closed this week.- Thanks. - ------------------------- ------------------- Bill Sullivan ------------------------- ------------------- Windsor Locks, Ct . ------------------------- ------------------- FS 447 ________________________________________________________________________________
Subject: Headsets & intercom selection for Mark III Xtra!
Date: Mar 20, 2009
Dear All, Please can everyone give their feedback with their Headsets, commonly used Intercom, recommended intercom and recommended Headsets Please Let me know of the best cost/product compromise. I have selected ICOM IC-A24 NAV/COM as my radio. Comments/Experiences? Regards, faisal (at) Scaled.com.pk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235402#235402 ________________________________________________________________________________
Subject: Re: Warp Drive bolt torque
Date: Mar 20, 2009
175 inch pounds for the hub, 120 for the blades. Larry C ----- Original Message ----- From: william sullivan To: kolb list Sent: Friday, March 20, 2009 1:47 PM Subject: Kolb-List: Warp Drive bolt torque Does anybody know the torque on the bolts that hold a Warp Drive prop to the hub flange on a 447? I called Warp Drive, and they are closed this week. Thanks. Bill Sullivan Windsor Locks, Ct. FS 447 ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/20/09 06:59:00 ________________________________________________________________________________
Subject: Seeking instructor in FL
Date: Mar 20, 2009
Greetings. I'm hoping to acquire a Kolb in the very near future. Does anyone know of a CFI with Kolb experience who can provide training and a tailwheel endorsement in the South Florida area? I live in Deerfield beach, near Pompano apt (KPMP). My Cel # is 954 608 5423. Thanks! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235408#235408 ________________________________________________________________________________
Subject: Re: Headsets & intercom selection for Mark III Xtra!
Date: Mar 20, 2009
faisalasif wrote: > Dear All, > > Please can everyone give their feedback with their Headsets, > commonly used Intercom, recommended intercom and recommended Headsets > > Please Let me know of the best cost/product compromise. > > I have selected ICOM IC-A24 NAV/COM as my radio. Comments/Experiences? > > Regards, > > faisal (at) Scaled.com.pk I have an A24 handheld that I use as a handheld currently (not in the plane). Has nice big letters on the display that make it easy to see the current frequency. It also has a queue-like thing that stores the last 10 entered frequencies and you can rotate through them with the buttons. The external power jack is a smaller one than the one used on the A22 and others, so you'd have to rig something up for external power or get Icom's cigarette lighter adaptor (which would surely be $$$). It should work ok in a plane, tho turning it on requires pressing/holding the power button for 3 secs. Stupid, IMO. This may have to be done each time instead of simply coming on when power is applied (I havent' tried this with mine yet). As for headsets, I use the Telex stratus 50 digital. Expensive, but still way way cheaper than a bunch of hearing loss. It has a digital sampling type active NR, which is VERY effective and over a pretty broad range of frequencies. It's easily the quietest headset I've ever tried. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235415#235415 ________________________________________________________________________________
Date: Mar 20, 2009
Larry, =C2- Have a friend with HKS on a hawk. The cooler is mounted on the fusela ge tube right behind the bulkhead. That leaves the heads unobstructed and st ill cools the oil well.The oil tank is just below engine level and about ove r the rear tank if it was in a Kolb FS.Get as much air to the heads as you c an. =C2-=C2- G.Aman -----Original Message----- From: Larry Cottrell <lcottrell(at)fmtcblue.com> Sent: Fri, 20 Mar 2009 10:54 am Subject: Re: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? The cylinder heads are bumping redline at any rpm over 5200. (max is 6200 allowable) the EGT's max is 1400. They are 1150. Larry ----- Original Message ----- From: Mike Welch Sent: Friday, March 20, 2009 9:23 AM Subject: RE: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? Larry, =C2- =C2- If your cylinder heads run cool(ish), and the EGTs run hot, this may be a result of too advanced timing.=C2- Is there any way to adjust timing to retard about 2-3 degrees? =C2- Mike Welch =C2- From: lcottrell(at)fmtcblue.com Subject: Re: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? Date: Fri, 20 Mar 2009 09:04:43 -0600 Bill, =C2-=C2-=C2- At least=2 0half of the coolers air flow is blocked, but I still have the rest of the exposed top part=C2-taped o ff to get the oil temps up above 170 degrees. I will remove the tape when I f ly today. The oil is plenty cool, the heads are not. Larry ----- Original Message ----- From: william sullivan Sent: Friday, March 20, 2009 5:28 AM Subject: Kolb-List: Re: Kolb List: Anyone have experience with a Hirth F-30? =C2- Larry- Have you tried flying without the gap seal?=C2- Maybe it's just the angle of the photo, but it looks like almost 1 /2 of the cooler's air flow os blocked. =C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2- Bill Sullivan =C2-=C2-=C2-=C2-=C 2=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2- Windsor Locks, Ct. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.c om/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c - Release Date: 03/19/09 12:26:00 ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail=C2=AE is up to 70% faster. Now good news travels really fast. Find out more. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.c om/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c - Release Date: 03/20/09 06:59:00 === ====== ________________________________________________________________________________
Date: Mar 20, 2009
At 04:00 PM 3/20/2009, faisalasif wrote: > >Please can everyone give their feedback with their Headsets, >commonly used Intercom, recommended intercom and recommended Headsets > >Please Let me know of the best cost/product compromise. > >I have selected ICOM IC-A24 NAV/COM as my radio. Comments/Experiences? I have the A24 with a Comtronics helmet and and am happy with the combination. The Comtronics won't plug directly into the Icom but it's a straightforward adapter; I wired a homemade one into my plane with a PTT in the control stick. No intercom; there's nobody to talk to in a single seat airplane. :) The only issue is that you can't use the A24 with a headset or helmet unless you remote the antenna; you get a horrible RF feedback squeal when you try to transmit. Moving the antenna only two feet away (I mounted the rubber duck antenna that came with the radio under the cockpit floor, pointing straight down, with a 6' cord and adapter from Radio Shack) solves the problem. I've heard that only certain David Clark headsets don't have this problem, but I already had the helmet so moving the antenna was the simplest thing. With an intercom in the circuit that may not be an issue. I can hear just fine and everybody in the pattern says they can hear me just fine. I did need to go to resistor plugs for the engine. -Dana -- "Very funny, Scotty. Now beam down my clothes." ________________________________________________________________________________
Date: Mar 20, 2009
The Bing 64 is altitude and temperature compensating. How much? I don't know. John W and I both topped out at 15,000 feet MSL with the 912ULS engines. I use basic engine instruments on my 912 engines: Tach Oil Press Oil Temp CHT Volt Meter These basic instruments have been all that was necessary to operate the 912 engines safely. I like to keep my airplane as simple as possible. john h mkIII Question: Doesn't the Rotax 912 use altitude compensating carbs? It seems like I remember hearing that from years ago. Or was it Bing carbs, in general? Regarding engine monitoring: Are you guys aware that there a slew of gauges and sensors "out there" that you can use to know exactly what's going on with your engine? Mike Welch ________________________________________________________________________________
Date: Mar 20, 2009
John=2C Using the basic gauges you stated is probably all that's necessary in a w ell-proven engine like the 912. But=2C if a person has unique tuning problems=2C like AFRs causing lean m ixtures=2C overheating issues=2C and such=2C then there are some excellent guages available. For a select few=2C who aren't sure about how their engine is running=2C additional gauges may be helpful to allow them to dial-in their engine's ad justments. A Rotax 912 does it own density altitude adjustments. A valuable feature =2C indeed=2C but few other engines are so sophisticated. Even my Cessna 172 didn't do "automatic leaning". I had to turn the mixt ure control manaully=2C if I wanted to lean out the engine at altitude. I sold it last June. Can a 2 cycle or 4 cycle motor=2C tuned at sea level=2C become way too le an=2C if a person were to fly it at 10=2C000+ feet? If it is possible for this to happen (climb into a lean condition)=2C at least there are gauges t hat may help them take a different tuning approach. Mike Welch From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Engine monitoring Date: Fri=2C 20 Mar 2009 18:44:05 -0500 The Bing 64 is altitude and temperature compensating. How much? I don't k now. John W and I both topped out at 15=2C000 feet MSL with the 912ULS eng ines. I use basic engine instruments on my 912 engines: Tach Oil Press Oil Temp CHT Volt Meter These basic instruments have been all that was necessary to operate the 912 engines safely. I like to keep my airplane as simple as possible. john h mkIII Question: Doesn't the Rotax 912 use altitude compensating carbs? It se ems like I remember hearing that from years ago. Or was it Bing carbs=2C i n general? Regarding engine monitoring: Are you guys aware that there a slew of gau ges and sensors "out there" that you can use to know exactly what's going o n with your engine? Mike Welch _________________________________________________________________ Hotmail=AE is up to 70% faster. Now good news travels really fast. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_03200 9 ________________________________________________________________________________
Date: Mar 20, 2009
I doubt you'll ever find an engine leaning out at altitude. Normally, they get richer because of less oxygen/air. john h mkIII Can a 2 cycle or 4 cycle motor, tuned at sea level, become way too lean, if a person were to fly it at 10,000+ feet? If it is possible for this to happen (climb into a lean condition), at least there are gauges that may help them take a different tuning approach. Mike Welch ________________________________________________________________________________
Date: Mar 20, 2009
Oops! Didn't think that one through. Yeah=2C I guess they would get riche r. Duh. From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Engine monitoring Date: Fri=2C 20 Mar 2009 19:47:07 -0500 I doubt you'll ever find an engine leaning out at altitude. Normally=2C th ey get richer because of less oxygen/air. john h mkIII Can a 2 cycle or 4 cycle motor=2C tuned at sea level=2C become way too l ean=2C if a person were to fly it at 10=2C000+ feet? If it is possible for this to happen (climb into a lean condition)=2C at least there are gauges that may help them take a different tuning approach. Mike Welch _________________________________________________________________ Hotmail=AE is up to 70% faster. Now good news travels really fast. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_03200 9 ________________________________________________________________________________
Subject: Homer Kolb
Date: Mar 20, 2009
Folks: Thought Homer and Clara Kolb were going to be with us at MV this year, but alas, something has come up that takes precedence over MV. Homer will not be there. I told him how special it would be for our small MV group to have the previlege of spending some quality time with the man that is responsible for our sport. Hopefully, he will be able to make it next year. john h mkIII ________________________________________________________________________________
Date: Mar 20, 2009
I knew what you meant. ;-) How is your mkIII coming along? Do you have someone lined up to teach you how to fly a mkIII? john h mkIII ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Friday, March 20, 2009 8:01 PM Subject: RE: Kolb-List: Engine monitoring Oops! Didn't think that one through. Yeah, I guess they would get richer. Duh. ________________________________________________________________________________
Date: Mar 20, 2009
MkIII is coming along very well=2C thank you. The entire plane is painted=2C except for striping. I'm waiting to put on all the wing & hor. stabs.=2C before I get around to any decorative stripe s. All Lexan is cut and ready. Just waiting on brakes to get done=2C before I can even think of locking myself out of easy access to the front end. Doors are finished=2C painted=2C and Lexaned. Engine is mounted. Prop is remounted=2C and properly torqued the bolts. A ll miscellaneous thinks like radiator=2C intercooler=2C etc=2C mounts are m ade=2C items are secured in place. I may be a week or so away from firing up the motor. What's really weird is=2C I can almost see light at the end of the tunnel. After 10 years=2C I'm treading on new ground. Kind of neat to finally see an "almost airplane". No=2C I haven't got anyone lined up yet=2C for training. I talked to Jim K met last summer. I doubt I need much training=2C just an orientation type flight. I've got 700 hrs in Cessnas=2C and about 15 hours in dual ultralig ht trainers (QS MX II=2C and FlightStar). Youngest son is on his way home (right now). Heading to Gulf Shores=2C AL =2C next week. Visiting the grandkids. Mike Welch MkIII From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Engine monitoring Date: Fri=2C 20 Mar 2009 20:14:39 -0500 I knew what you meant. =3B-) How is your mkIII coming along? Do you have someone lined up to teach you how to fly a mkIII? john h mkIII ----- Original Message ----- From: Mike Welch Sent: Friday=2C March 20=2C 2009 8:01 PM Subject: RE: Kolb-List: Engine monitoring Oops! Didn't think that one through. Yeah=2C I guess they would get riche r. Duh. _________________________________________________________________ Windows Live=99 SkyDrive: Get 25 GB of free online storage. http://windowslive.com/online/skydrive?ocid=TXT_TAGLM_WL_skydrive_032009 ________________________________________________________________________________
Subject: Re: AirVenture 2009
Date: Mar 20, 2009
I should keep my mouth shut,but the UL-LSA just doesn't turn enough money for Uncle TOM for them to bother with us! I used to like and even belong to EAA,but since Uncle Tom took over it's turned into this GIANT money making machine / party for the rich and famous .Maybe we should start our own UL/LSA flyin ,invite the MFG's to come knowing there will be no charge for them to try and sell their wares and have an affordable weekend for all! Sorry.....just not fond of the King Tommys EAA chris ambrose m3x-jabiru Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235456#235456 ________________________________________________________________________________
Date: Mar 20, 2009
> Maybe we should start our own UL/LSA flyin ,invite the MFG's to come knowing there will be no charge for them to try and sell their wares and have an affordable weekend for all! > > chris ambrose Chris/Gang: We have had an annual Kolb Flyin for the past 6 years. Next one is a couple months away. Beats anything EAA can put out at S&F or OSH. The price is right. Also the Kolb Homecoming is an annual and also beats anything anybody else can come up with. That puts one in the West and one in the East. Most of us are interested primarily in Kolbs because that is what we are building, flying, or wishing for. We tolerate "others" and find most of them pretty darn good folks too. They are my two favorite flyins, along with our annual flight to the Rock House in SE Oregon in conjuction with MV. john h mkIII ________________________________________________________________________________
Date: Mar 20, 2009
Subject: Re: Off list - Hirth reputation.
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: From: possums <possums(at)bellsouth.net> Subject: Kolb-List: Off list - Hirth reputation. Send reply to: kolb-list(at)matronics.com > A lot of engines have the same problem. > Just between you and me and the fence post-- > Screw Hirth engines. Bill has tried them several times > over the last 12 years. Along with AMC engines and a few others. > > I've got way over what I should have on my 503 "1997 Rotax" engine without > a rebuild and it still runs like a Toyota. 450 hrs on my Hirth without problems. Guess I didn't listen to the fence post..... Jim Baker 580.788.2779 405. 426.5377 cell Elmore City, OK ________________________________________________________________________________
Date: Mar 20, 2009
> 450 hrs on my Hirth without problems. Guess I didn't listen to the > fence post..... > > > Jim Baker That's great. May be a record. What airplane are you flying it with, Jim? And which one is it? I never got any where near that much time on one of my two strokes. Something would break or wear out, except the 582. It didn't have time to wear out. It simply seized. john h mkIII ________________________________________________________________________________
Date: Mar 20, 2009
This sounds really cool ! I wish I could make the MV tour,but there is no way..However,when is the Homecoming in Kentucky? I would sure like to plan on that one .... chris ambrose m3x-jabiru Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235470#235470 ________________________________________________________________________________
Date: Mar 20, 2009
> This sounds really cool ! I wish I could make the MV tour,but there is no way..However,when is the Homecoming in Kentucky? I would sure like to plan on that one .... > > chris ambrose Last year it was held the third weekend of September. Have not heard if and when the Kolb Homecoming will be this year. john h mkIII ________________________________________________________________________________
Date: Mar 20, 2009
Thanks John,I hope so...that would work great for me...anyone interested in coming up to northern Michigan ?? 5Y2 Houghton Lake State airport to be exact.... chris ambrose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235474#235474 ________________________________________________________________________________
Date: Mar 21, 2009
> Thanks John,I hope so...that would work great for me...anyone interested in coming up to northern Michigan ?? 5Y2 Houghton Lake State airport to be exact.... > > chris ambrose I'm pretty sure I have been into 5Y2 on one of my flight up north, just south of Grayling. john h mkIII ________________________________________________________________________________
Date: Mar 21, 2009
Wow. It's too bad that OSH has sunk to this level regarding ultralights. In the mid-eighties and nineties there was such a buzz over in the UL area. To me, it was about the only reason to go to make the 8 hour drive... Kip -------- Kip Firestar II, N111KX Waiex, N111YX Quickie 1, N111QX Atlanta Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235507#235507 ________________________________________________________________________________
Date: Mar 21, 2009
John Hauck wrote: > > Thanks John,I hope so...that would work great for me...anyone interested > in coming up to northern Michigan ?? 5Y2 Houghton Lake State airport to > be exact.... > > > > > chris ambrose > > That's the one John....best little airport in the north! > > > > chris ambrose > > > > > > I'm pretty sure I have been into 5Y2 on one of my flight up north, just > south of Grayling. > > john h > mkIII Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235508#235508 ________________________________________________________________________________
Date: Mar 21, 2009
Mike. I wonder if any of the O2 sensors are "less" succeptible to leaded gas? 100 octane is the minuimum analysis...I recall accepting the delivery of a truck of av gas at a local airport that had an analysis of 119 octane... . High Octane gas is regular gas with additives...to slow the burn mainly...everyone knows this I guess? >>>>>>>>>>>>>>>>>>>>> >From what I know.. Which I will admit is not enough... may not be totally accurate. My friend drives a gas delivery truck and has done so for over 40 years. he has been in the refineries, as well as the pipeline terminals... and he has told me that there is what is called " house gas" which comes in regular "house gas" and premium "house gas" . Example, Texaco refineries do not refine Texaco gas. They refine "house gas" when the gas hauler pulls up to the loading dock and inserts his load card and enters the amount to load.. The computers will mix in the additives into the house gas specified by Texaco then it becomes Texaco gas. Auto fuel does not sit in tanks for months and months... it is designed to run through the system and be consumed within a couple weeks. Av gas on the other hand because it sits in the tanks for much longer times has to be refined in such a manner that more of the impurities are removed. This extra refining is in large part responsible for the additional cost. That added to the supply and demand at the local airport,,,, the fbo has it and you need it,,, and generally there is not an av gas station on each and every corner,, so the competition or large volumes discounts is not there. Boyd ________________________________________________________________________________
Date: Mar 21, 2009
Please can everyone give their feedback with their Headsets, >>>>>>>>> I use the sigtronics spo22 "N" intercom the "N" is for high noise environment My headsets are Telex Echelon anr 150 the mikes on these headsets are real sensitive, and picked up too much background noise so I called telex and they gave me instructions to turn down the mike gain now they work quite well. Boyd ________________________________________________________________________________
Date: Mar 21, 2009
Does anybody know the torque on the bolts that hold a Warp Drive prop to the hub flange on a 447? I called Warp Drive, and they are closed this week. Thanks. Bill Sullivan Windsor Locks, Ct. FS 447 >>>>>>>>>>. I am not sure if there is different torque values for different engines,,,,, My instructions say to torque the =BC inch bolts to 120 inch pounds or 10 foot pounds,,, in increments of 20 inch pounds up to the full recommended torque. Torque the 8 mm or 5/16 mounting bolts to 175 inch pounds or 15 ft pounds Torque the 3/8 mounting bolts to 35 ft pounds Re torque after 1 hour of operation then every 5 to 10 hours as a part of regular maintenance. I am just guessing here,,, I think the difference between the 5/16 / 8mm and the 3/8 mounting bolts will depend on what hub you have. Boyd ________________________________________________________________________________
Subject: 100LL fuel additive
Date: Mar 21, 2009
Kolb people=2C Is anyone familiar with this product that reduces lead deposit buildup=2C when using low-lead fuel. http://www.skygeek.com/73122.html My engine is designed to run on auto gas (it oughta=2C since it came from an auto!). It is NOT designed to run on low-lead. Yet=2C I can imagine i t is possible that the only fuel available on a long distance cross country flight might be airport fuel....100LL. Has anyone ever used this stuff=2C and can give a report on it's effectiv eness? Mike Welch MkIII _________________________________________________________________ Internet Explorer 8 ' Now Available. Faster=2C safer=2C easier. ________________________________________________________________________________
Subject: Re: 100LL fuel additive
Date: Mar 21, 2009
I have heard that Marvel Mystery oil used in the gas and the oil prevents lead build up. Have not been able to confirm if it will make the use of 100LL practical in engines designed to use auto fuel. ________________________________________________________________________________
Date: Mar 21, 2009
Afetr using several different intercoms, I`ve had the best luck with this same model, the SPO-22N, with any kind of headset, works well. Jim Kmet Cookeville, TN MK-3C now 912 powered & condition inspection done as of today! ----- Original Message ----- From: "boyd" <by0ung(at)brigham.net> Sent: Saturday, March 21, 2009 10:16 AM Subject: RE: Kolb-List: Headsets & intercom selection for Mark III Xtra! > > Please can everyone give their feedback with their Headsets, >>>>>>>>>> > > I use the sigtronics spo22 "N" intercom the "N" is for high noise > environment > My headsets are Telex Echelon anr 150 the mikes on these headsets are > real sensitive, and picked up too much background noise so I called telex > and they gave me instructions to turn down the mike gain now they work > quite > well. > > Boyd > > > ________________________________________________________________________________
Date: Mar 21, 2009
Warps website has a page that has this info. Jim ----- Original Message ----- From: boyd To: kolb-list(at)matronics.com Sent: Saturday, March 21, 2009 10:16 AM Subject: RE: Kolb-List: Warp Drive bolt torque Does anybody know the torque on the bolts that hold a Warp Drive prop to the hub flange on a 447? I called Warp Drive, and they are closed this week. Thanks. Bill Sullivan Windsor Locks, Ct. FS 447 >>>>>>>>>>. I am not sure if there is different torque values for different engines,,,,, My instructions say to torque the =BC inch bolts to 120 inch pounds or 10 foot pounds,,, in increments of 20 inch pounds up to the full recommended torque. Torque the 8 mm or 5/16 mounting bolts to 175 inch pounds or 15 ft pounds Torque the 3/8 mounting bolts to 35 ft pounds Re torque after 1 hour of operation then every 5 to 10 hours as a part of regular maintenance. I am just guessing here,,, I think the difference between the 5/16 / 8mm and the 3/8 mounting bolts will depend on what hub you have. Boyd ________________________________________________________________________________
Date: Mar 21, 2009
Reading on the net...appears that MMO has phosphorous as its active ingredient... Dump a few ozs in the tank and carbon and sticky rings are a thing of the past...I also toss one oz over my left shoulder... :-) Herb WHAT IS IT? My own understanding from earlier articles on the subject is that Marvel Mystery Oil is a light viscosity oil, roughly equivalent to an SAE 3W, containing (among other things) about 20 percent solvent (probably mineral spirits), dye, wintergreen for smell, and 790 PPM of a phosphorous additive. At 01:40 PM 3/21/2009, you wrote: > >I have heard that Marvel Mystery oil used in the gas and the oil >prevents lead build up. Have not been able to confirm if it will >make the use of 100LL practical in engines designed to use auto fuel. > ________________________________________________________________________________
Date: Mar 21, 2009
Subject: And now for something completely different
http://www.fanwing.com/ Rick ________________________________________________________________________________
Date: Mar 21, 2009
Can a 2 cycle or 4 cycle motor, tuned at sea level, become way too lean, if a person were to fly it at 10,000+ feet? If it is possible for this to happen (climb into a lean condition), at least there are gauges that may help them take a different tuning approach. Mike Welch >>>>>>>>>>>>>> If tuned for sea level.. And you go to 10,000 ft. it will be running rich,,,, however if you are at 5,000 ft and tuned up nice and go to sea level. then you will be lean. Boyd ________________________________________________________________________________
Date: Mar 21, 2009
Boyd, The primary reason that avgas costs more than mogas is due to shippin g costs. Mogas can go through the pipeline system, avgas has to be transporte d by truck because of the lead. Rick On Sat, Mar 21, 2009 at 10:16 AM, boyd wrote: > Mike. I wonder if any of the O2 sensors are "less" succeptible to > leaded gas? 100 octane is the minuimum analysis...I recall accepting > the delivery of a truck of av gas at a local airport that had an analysis of > 119 octane... . High Octane gas is regular gas with additives...to slow > the burn mainly...everyone knows this I guess? > > >>>>>>>>>>>>>>>>>>>>> > > > From what I know=85. Which I will admit is not enough=85.. may not be > totally accurate. My friend drives a gas delivery truck and has done so > for over 40 years=85 he has been in the refineries, as well as the > pipeline terminals=85.. and he has told me that there is what is ca lled > =93 house gas=94 which comes in regular =93house gas=94 and premium =93house gas=94 > . Example, Texaco refineries do not refine Texaco gas. They refine > =93house gas=94 when the gas hauler pulls up to the loading dock and in serts > his load card and enters the amount to load=85. The computers will mix i n the > additives into the house gas specified by Texaco then it becomes Texaco > gas. Auto fuel does not sit in tanks for months and months=85.. it i s > designed to run through the system and be consumed within a couple weeks. > Av gas on the other hand because it sits in the tanks for much longer tim es > has to be refined in such a manner that more of the impurities are > removed. This extra refining is in large part responsible for the > additional cost. That added to the supply and demand at the local > airport,,,, the fbo has it and you need it,,, and generally there is not > an av gas station on each and every corner,, so the competition or large > volumes discounts is not there. > > > Boyd > > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Mar 21, 2009
Not a scientific test you understand, but when Arty and I took our Texas trip a couple of years ago. I had a 503 and used MMO in my fuel. We flew for 40 some hours, using 100 LL when it was available which was most of the time. Just a WAG on my part but I believe we used in excess of 120 gallons of the stuff. We flew for 2600 miles total. I changed the spark plugs when we returned and there was enough lead on the plugs that my mag checks showed a noticeable change. Not enough to be concerned about, but there was a small build up. Of course the recommended change time frame is 25 hours I believe, so it was no real surprise that they were showing wear. Now having said that, that same engine when I sold it at 185 hours showed no carbon at all on the pistons and no wear on the cylinder walls. It had never been decarboned. I had always used MMO in my fuel, and will continue to do so. It damn sure doesn't hurt and I believe that it helps a lot. Larry C ----- Original Message ----- From: apilot(at)surewest.net To: kolb-list(at)matronics.com Sent: Saturday, March 21, 2009 12:40 PM Subject: Re: Kolb-List: 100LL fuel additive I have heard that Marvel Mystery oil used in the gas and the oil prevents lead build up. Have not been able to confirm if it will make the use of 100LL practical in engines designed to use auto fuel. ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/20/09 19:01:00 ________________________________________________________________________________
Date: Mar 21, 2009
Subject: Re: Anyone have experence with Hirth F-30?
I fly a mk3 with a Hirth 3503 EFI,so far,35hrs.The engine performes well.The only issue Ive had is oil leaking out air filter.The reed valve was not sealing correctly,replaced with a new one,still have a small leak.I don't like having to wipe oil off the prop every time i land.Can't afford to replace engine,I hope that time and use will solve this neusance. > -----Original Message----- > From: jhauck(at)elmore.rr.com > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Anyone have experence with Hirth F-30? > > > > > We got a 70 HP - with problems - at the farm. >> But I wouldn't want to comment on that particular engine on this list. >> Oil leaks, gear box problems - engine out (frame damage - lot of work). >> But, they say they have fixed them........ >> I don't like Hirth's, (the old ones or the new ones) so I shouldn't >> comment anyway. > > > Possum: > > Thanks for not commenting on the Hirth reputation. > > Like a some of the Rotax and Cuyuna engines I owned and flew in front of, > they quit making noise at the most inopportune times. Uncommanded > silence. > > I don't know anything about them except what I hear or happen to see at a > flyin somewhere. We do not have any in my neck of the woods. > > Someone mentioned a mkIIIx at last year's Kolb Homecoming flying with a > Hirth. I did see that one fly. However, I believe it was trailered to > Labhart Field, and trailered home. Good looking Kolb. > > john h > mkIII > > ____________________________________________________________ FREE 3D MARINE AQUARIUM SCREENSAVER - Watch dolphins, sharks & orcas on your desktop! Check it out at http://www.inbox.com/marineaquarium ________________________________________________________________________________
Date: Mar 21, 2009
At 12:23 PM 3/21/2009, Mike Welch wrote: >Kolb people, > > Is anyone familiar with this product that reduces lead deposit buildup, > when using low-lead fuel. > ><http://www.skygeek.com/73122.html>http://www.skygeek.com/73122.html > > My engine is designed to run on auto gas (it oughta, since it came from > an auto!). It is NOT designed to run on low-lead. Yet, I can imagine it > is possible that the only fuel available on a long distance cross country > flight might be airport fuel....100LL. > > Has anyone ever used this stuff, and can give a report on it's > effectiveness? I've never used it, but it was quite popular and a lot of guys used it religiously in older airplanes when 100LL first came out and 80 was hard to find... a lot of aircraft engines had trouble with lead fouling the valves. Me, I just ran mogas instead (leaded regular and no ethanol then). -Dana -- Ever notice how fast Windows runs? Neither did I. ________________________________________________________________________________
Date: Mar 21, 2009
Subject: Future Kolb pilot
We had the grandson over for the afternoon and he just had to see grandpa's airplane. Almost took tools to pry him out when it was time to go home. There are PIC issues in my future, I'm sure. Rick ________________________________________________________________________________
Date: Mar 21, 2009
Mike: TCP was developed during WWII to control lead fouling in high performance Av-engines using 115-145 octane heavily leaded high-test gasoline.... I believe Shell Oil marketed it first after the war. I ran a 165 hp. Franklin on 100 LL for 9 years...This engine was low compression and was designed in the 1930's for 80/87 octane gas. The Alcor TCP was the only way I could keep from having to pull and scrape the bottom plugs every 20 hours (the Franklin used 14mm automotive type plugs and the electrodes were prone to fouling.) With the TCP, they would go 100 hours plus on the 100 LL. TCP makes the lead ball up into globules and blow out the exhaust, vice depositing on the plugs, valves, piston crown, or whatever. Not sure what it would do in a 2-stroke or Rotax 4 stroke engine... Worth what ye paid fer it.. beauford FF-076 Brandon, FL ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Saturday, March 21, 2009 12:23 PM Subject: Kolb-List: 100LL fuel additive Kolb people, Is anyone familiar with this product that reduces lead deposit buildup, when using low-lead fuel. http://www.skygeek.com/73122.html My engine is designed to run on auto gas (it oughta, since it came from an auto!). It is NOT designed to run on low-lead. Yet, I can imagine it is possible that the only fuel available on a long distance cross country flight might be airport fuel....100LL. Has anyone ever used this stuff, and can give a report on it's effectiveness? Mike Welch MkIII ------------------------------------------------------------------------- ----- Internet Explorer 8 ' Now Available. Faster, saferrget='_new'>Download FREE now! ________________________________________________________________________________
Date: Mar 21, 2009
Me too! In fact I use it in everything I own, except the weed eater and chain saw two strokes. Got sponsored by Alcor TCP on my 2001 flight to Alaska. It worked well, but was hard to handle. Warnings on the can was enough to scare me. It is very expensive. No sponsorship in 2004 when I flew back to Alaska. This flight I used MMO. It worked well, smelled good, and had not scarly warnings on the can. Was relatively cheap, available at Walmart, so resupply was not a problem. Did not have to haul enough for the entire flight. Does it work. I think so. It has been used by aviators and a lot of other folks since 1933. I have seen miracles happen with some of my old tractors that are a few years older than me. Back in the old days, I have watched crop dusters dump it in the fuel tank by the gallons. john h mkIII Now having said that, that same engine when I sold it at 185 hours showed no carbon at all on the pistons and no wear on the cylinder walls. It had never been decarboned. I had always used MMO in my fuel, and will continue to do so. It damn sure doesn't hurt and I believe that it helps a lot. Larry C ________________________________________________________________________________
Subject: Broken exhaust bracket
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Mar 21, 2009
I don't know how many of you read the Rotax forum also, but if you do you'll remember that I have an exhaust leak. Here's the thread: http://forums.matronics.com/viewtopic.php?t=55938 I first tried to simply replace the outside exhaust gaskets. That didn't stop the leak. So today I replaced the inside exhaust gaskets. Since Lucien also mentioned checking the support and since I had been noticing lately that the rubber bushings on my exhaust mount were looking pretty worn AND since I had it all apart anyways to replace the inner exhaust gaskets (those were a challenge to scrape off the cowl), I decided to go ahead and take the mount apart and inspect it. Should have done that sooner! I attached a picture of what I found. The rubber bushings were useless and the bracket (or plate? whatever it's called) on the exhaust has cracked all the way through. I've also attached a picture of my exhaust with the mount with some letters pointing to various places. The male rubber bushing was currently where letter A is pointing (actually inside the exhaust bracket or plate). The female rubber bushing was currently where letter C is pointing. The people helping me say that the male bushing should be where letter B is pointing (between the exhaust bracket and the exhaust mount). If it is currently set up wrong that might have further aggravated and caused the crack (besides the bushings being rotten). I know there aren't many of you out there that have a 503 anymore and probably don't even have the same set up for the exhaust if you do have a 503, but if you have something similar could you please post a picture and/or diagram? The CPS catalogue shows a mounting kit that uses a bolt-driven mounting clamp...does anyone use that? -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235582#235582 Attachments: http://forums.matronics.com//files/exhaust_mount_rubber_bushings_188.jpg http://forums.matronics.com//files/crack_in_exhaust_bracket_195.jpg ________________________________________________________________________________
Subject: Re: Broken exhaust bracket
Date: Mar 21, 2009
Cristal, a couple of things I see in the pictures: 1) the reason it cracked is that you have the old style single-jointed muffler with one set of 3 springs. These older mufflers are prone to cracking. 2) it looks like the previous owner may have welded a washer to the muffler where it cracked. Maybe the weld job had the opposite effect and weakening it instead of making it stronger. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 22 years flying it Kolbra 912UL N20386 almost 1 year flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235584#235584 ________________________________________________________________________________
Date: Mar 21, 2009
So, for those who use it, what is the mix ratio? When using the MMO . 1 oz per gal, 1oz per 5gal?? And do you add it over and above your regular oil mix or substitute the oz or so of MMO for part of the oil?? I've used it as a fogger for winterizing boats etc for years and had great results with it in that application. Thanks Dwight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235585#235585 ________________________________________________________________________________
Date: Mar 21, 2009
John Hauck told me to use 2 oz per five gallons in addition to the regular oil. I also use two oz of Sta-bil as well. If you don't fly that often mixed gas goes bad quicker than regular gasoline. Keep in mind that if you are using Ethanol there is a Marine grade of Sta-bil for Ethanol, and that is one oz per 5 gallons. Larry C ----- Original Message ----- From: Dwight To: kolb-list(at)matronics.com Sent: Saturday, March 21, 2009 10:54 PM Subject: Kolb-List: Re: 100LL fuel additive So, for those who use it, what is the mix ratio? When using the MMO . 1 oz per gal, 1oz per 5gal?? And do you add it over and above your regular oil mix or substitute the oz or so of MMO for part of the oil?? I've used it as a fogger for winterizing boats etc for years and had great results with it in that application. Thanks Dwight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235585#235585 ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/21/09 17:58:00 ________________________________________________________________________________
Date: Mar 22, 2009
Good morning Cristal; Yes, the rubber bushings should be on the muffler bracket and not on one side of the muffler bracket and on half on the back side of the support angle. The cracked bracket could be contributed to the set up and also could just be fair wear and tear from vibration. I would suggest grinding the washer off the muffler bracket and welding an 1/8" thick plate the full length of the bracket where the washer is located now. Just weld the sides of the muffler bracket, not across the top or bottom as that will cause a stress point where the bracket bends. Ha, you live to far away or I would weld it up for you.:) Jim ________________________________________________________________________________
Date: Mar 22, 2009
Ralph B wrote: > > 1) the reason it cracked is that you have the old style single-jointed muffler with one set of 3 springs. These older mufflers are prone to cracking. > Ralph B This is a good point. These older style mufflers had only one point in the tubing where they could flex. A common area of cracking on these is in an almost perfect circle right at the seam where the main expansion tube goes into the can. I had an eipper style one of these older mufflers on my quicksilver that gave this exact circle-wise cracking in that area. Got a friend to TIG weld a new bead around there which fixed it. But you have to pay very close attention to the tension of the springs and the muffler mounting with the old style. They can't be too tight to where they prevent movement of the joint, a common installation problem. Anti-sieze on the parts during assembly helps a bit as well. But the new style with the seperate elbow is a lot better as it has 2 joints where the whole works can move and better isolates the vibration of the motor from the muffler. The Kolb mounting design with the bracket bolted to the heads is actually very secure and gives good support for the can (mine would hold the muffler can perfectly in place even with no elbow installed yet) so repairing the bracket may be all you need to do. But if it keeps cracking, you might want to replace the muffler with the new style...... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235618#235618 ________________________________________________________________________________
Date: Mar 22, 2009
I just visited the MMO website http://www.marvelmysteryoil.com/index.php/site/products/ and they have multiple products, or at least it seems that way. Which of these are you MMO aficionados using? The first one listed on their site comes in 16 oz to 55 gallon sizes and they suggest using this one in gasoline and oil. The 2nd is for diesel. The 3rd listing is called Marvel Super Gas Treatment and it shows only 12 oz containers. -------- Thom Riddle Buffalo, NY http://riddletr.googlepages.com/sportpilot-cfi http://riddletr.googlepages.com/a%26pmechanix A complex system that works is invariably found to have evolved from a simple system that works. - John Gaule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235626#235626 ________________________________________________________________________________
Date: Mar 22, 2009
The MMO FAQ has a lot of info pertinent to its use, including the following excerpts: Can I use MMO in 2-cycle engines? Yes, MMO is safe for use in 2-cycle engines. Replace 25% of the 2-cycle oil with MMO. For example, if use 8oz of 2-cycle oil, replace 2oz of 2-cycle with 2oz of MMO at oil change. Can I use MMO for winter storage as a fuel stabilizer? Yes, you can use MMO as a fuel stabilizer. Use 4ozs of Marvel for every 10 gallons of fuel. Can I use MMO in my air tools such as a nail gun? Yes, you can use MMO in your air tools. However, we recommend you use Marvel Air Tool oil for longer term use. The formulation of the Air Tool Oil is nearly identical to the original MMO but also includes a heavy-duty corrosion inhibitor to protect the tool in the high-moisture environment of air tools. -------- Thom Riddle Buffalo, NY http://riddletr.googlepages.com/sportpilot-cfi http://riddletr.googlepages.com/a%26pmechanix A complex system that works is invariably found to have evolved from a simple system that works. - John Gaule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235630#235630 ________________________________________________________________________________
Date: Mar 22, 2009
> and they have multiple products, or at least it seems that way. Which of these are you MMO aficionados using? The first one listed on their site comes in 16 oz to 55 gallon sizes and they suggest using this one in gasoline and oil. The 2nd is for diesel. The 3rd listing is called Marvel Super Gas Treatment and it shows only 12 oz containers. > > -------- > Thom Riddle The one I use is the only one available at stores I frequent, the first one listed for gas and diesel engines. I believe it recommends one quart for 80 to 100 gals. That is normally the ratio I mix, sometimes more than recommended. I am not too particular. Never had a fouled plug or stuck valve in a 912 while using MMO. In 1994, I flew 232 hours in 41 days with a 912UL. I did not use MMO. About every 75 hours, operating on a steady diet of 100LL, at least one plug will start fouling. Indication was a slight thumping/tapping felt in the airframe. Really gets your attention when flying over inhospitable terrain. I'd land at the next available airport, pull the plugs, clean them with my knife and the wire on my spark plug gap gauge. Good for another 75 hours. The 912 was being operated at 5,000 rpm cruise. Don't have that problem with the 912ULS, normally. I did go through some engine missing and power problems last year on my flight out West. I think some of that was carb icing. Was flying with John W. His 912ULS was not experiencing any problems. May have been a gremlin. Have not had that problem since. john h mkIII ________________________________________________________________________________
Date: Mar 22, 2009
Subject: Max Gross
Can anyone explain to me how the maximum gross weight is set for a MIII? I'm told it's set by the builder, not Kolb. Thanks, Dave ________________________________________________________________________________
Date: Mar 22, 2009
> Can I use MMO in 2-cycle engines? > Yes, MMO is safe for use in 2-cycle engines. Replace 25% of the 2-cycle > oil with MMO. For example, if use 8oz of 2-cycle oil, replace 2oz of > 2-cycle with 2oz of MMO at oil change. > -------- > Thom Riddle I would not replace two stroke oil with MMO, but add it in addition to the recommended amount of two stroke oil. Personal opinion and gut feeling only. I use regular MMO in my air tools. Haven't worn one out yet. john h mkIII ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Re: Max Gross
Date: Mar 22, 2009
Dave The builder does set the maximum gross weight along with a bunch of other stuff. The same regulations are there for original designs. The Kolb MKIII has a factory recommended max gross weight of 1000 lbs. set by a structural engineer. It was based on the design limits of the standard airframe with some leeway for less than quality workmanship. At least one of our group has increased the limit by making a bunch of structural changes and has proven its strength. If you do quality work and built the plane exactly like John H built his it would appear the limit can be safely increased to 1200 lbs. If your not a structural engineer any deviations from John's proven modifications could put the airframe at risk at this higher limit. John is the test pilot of his design modifications and continues to be. Another way of answering the question would be to say you as the builder can set the limit at 2,000 lbs and are killed in a crash you will not be cited by the FAA for violating experimental regulations. As always worth what you paid for it. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: david watkins To: Kolb messages Sent: Sunday, March 22, 2009 10:18 AM Subject: Kolb-List: Max Gross Can anyone explain to me how the maximum gross weight is set for a MIII? I'm told it's set by the builder, not Kolb. Thanks, Dave ________________________________________________________________________________
Date: Mar 22, 2009
Thanks, Rick. I'm in the process of buying a 2001 MKIII powered by a 912s. The builder, who is described as a very meticulous craftsman, has set the max gross at 1050#. I can live with that, but since I weigh 190, and my partner 170, we'll have to carry less than full fuel in the 20 gal. tank. The empty weight is 594#, probably in part due to the 912s, and the BRS. I'd heard about John's increase, and wondered how much flexibility I had, especially since I fantasize about installing floats, down the road. Are you there, John, and do you have any suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235657#235657 ________________________________________________________________________________
Date: Mar 22, 2009
Thom, I use the original MMO in the HKS in the gas only since HKS specs a full synthetic oil and I don't want to mix. Rick On Sun, Mar 22, 2009 at 8:33 AM, Thom Riddle wrote: > > I just visited the MMO website > > http://www.marvelmysteryoil.com/index.php/site/products/ > > and they have multiple products, or at least it seems that way. Which of > these are you MMO aficionados using? The first one listed on their site > comes in 16 oz to 55 gallon sizes and they suggest using this one in > gasoline and oil. The 2nd is for diesel. The 3rd listing is called Marvel > Super Gas Treatment and it shows only 12 oz containers. > > -------- > Thom Riddle > Buffalo, NY > http://riddletr.googlepages.com/sportpilot-cfi > http://riddletr.googlepages.com/a%26pmechanix > > A complex system that works is invariably found to have evolved from a > simple system that works. > - John Gaule > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235626#235626 > > ________________________________________________________________________________
Date: Mar 22, 2009
Ricks msg reminded me I probably should have indicated I do not use MMO in the crankcase of the 912ULS. However, it might not be a bad idea to add some just prior to oil change to help stir up and get more lead into suspension. On antique tractors, as soon as I get one, I put a quart of MMO in the gas tank and another in the crankcase. I helps loosen up a lot of sludge and crap from years of nondetergent oil. However, that ain't got nothing to do with airplane engines. ;-) john h mkIII Thom, I use the original MMO in the HKS in the gas only since HKS specs a full synthetic oil and I don't want to mix. Rick ________________________________________________________________________________
Date: Mar 22, 2009
> I'd heard about John's increase, and wondered how much flexibility I had, > especially since I fantasize about installing floats, down the road. > > Are you there, John, and do you have any suggestions? I can't tell you what to do, but I, personally, would not hesitate to fly this particular mkIII at more than the recommended 1,000 lbs gross weight. As far as floats are concerned, I have no ideas and can not comment on them. There are no major improvements on the fuselage of my mkIII from a standard mkIII. Most of the changes Brother Jim made to my fuselage at the Kolb Factory, were automatically incorporated in standard mkIII fuselages, little things most folks don't know about. I guess the biggest change I made was reinforcing the noses of all main ribs and the tails of the four outboard main ribs, additional bracing on the bowtip and increased lateral bracing on the leading edge of the wing. Redesigning the main gear did nothing for increasing gross weight capability. Flight characteristics and capability don't change much with Homer's big straight wings. They love to haul stuff! The main reason I upgraded the wings was based primarily on the type flying I knew my mkIII would be subjected to, and personal preference of the way I like things to be in my airplane. If anyone chooses to fly a Kolb aircraft over the recommended maximum gross weight, it is their decision to do so, not mine. I don't recommend other folks fly their Kolbs the way I fly mine. john h mkIII ________________________________________________________________________________
Subject: MKIII Performance
Date: Mar 22, 2009
Got out and enjoyed an hour of wonderful last light flight yesterday. Perfect day for flying. Spring is bursting out, air was clear and cool, about 65F. 912ULS was turning 5,500 RPM WOT straight and level flight. Climbed 1,500 FPM at 70 mph indicated, 5400 RPM. Climbed 1,800 FPM at 50 mph indicated, 5300 RPM. Floated halfway down Gantt International Airport in ground effect with 40 degrees of flaps. Demonstrated no threat of deadly Kolb Quit. Had 10 gals fuel on board, solo. john h mkIII ________________________________________________________________________________
Date: Mar 22, 2009
> Climbed 1=2C800 FPM at 50 mph indicated=2C 5300 RPM. > john h > mkIII John=2C Can't say I've ever heard of such climb out perfromance on a Kolb!! Must have felt like an elevator!! 1800 FPM?!! Must have been a sight to watch from the ground. Mike Welch _________________________________________________________________ Windows Live=99 SkyDrive: Get 25 GB of free online storage. http://windowslive.com/online/skydrive?ocid=TXT_TAGLM_WL_skydrive_032009 ________________________________________________________________________________
Subject: Re: Muffler fix
Date: Mar 22, 2009
Rick; I would never use silver solder on that type of repair, unless I was 40,000 miles from no where and that was all I had. No again on brazing. If a plate was welded up the way I suggested it will last a very long time. I do agree with you on making sure that there is no stress points from misalignment of bolts and etc. Jim H ________________________________________________________________________________
Subject: Re: MKIII Performance
Date: Mar 22, 2009
Not bad for an old bird. Those are "indicated speeds and climb rates". How accurate are they? I don't have a clue, but probably pretty close, close enough for me. I thought they all climbed like that with 912ULS. John Bickham has a mkIII that climbs like that with a 912UL. I had a hard time keeping up with him last year at the Nauga Flyin. -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235678#235678 ________________________________________________________________________________
Date: Mar 22, 2009
Thanks, John, Your comments are accepted in the spirit in which they were offered-"information", not "recommendation". I appreciate your steering me to the Kolb in question. I've been very impressed with the integrity of the the builder, and look forward to flying the plane. Finally, I look forward to learning more from you as time goes by. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235679#235679 ________________________________________________________________________________
Date: Mar 22, 2009
John Hauck wrote: > Not bad for an old bird. > > Those are "indicated speeds and climb rates". How accurate are they? I don't have a clue, but probably pretty close, close enough for me. > > I thought they all climbed like that with 912ULS. > > John Bickham has a mkIII that climbs like that with a 912UL. I had a hard time keeping up with him last year at the Nauga Flyin. For what it's worth, my FSII would do around 900fpm sustained at sea level, which was pretty good considering it had come out at a rather heavy 440lbs empty weight for the original builder. Part of that was the C box with clutch he'd opted for for the 3 blade warp drive prop. This had prompted the addition of 10lbs of ballast to the nose to get the CG to come out right. Even out here before I sold it it could do between 300 and 400 fpm climb. Again pretty impressive given the 503 is about a 377 at this altitude. The Kolb wing is definitely made for lifting. As for the 912ULS, I think it's about the best you can do for a 100hp engine period. The only other aircraft motor Rotax made that could beat it (and smoke it too) was the 618 and (unfortunately IMO) it's not in production anymore. And it couldn't do it for 2000 hours + either besides. Since this is the Kolb forum I don't want to brag about other planes, but my 912ULS gives me similar performance, I'll just say that. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235688#235688 ________________________________________________________________________________
Date: Mar 22, 2009
jimh474(at)embarqmail.com wrote: > Yes, the rubber bushings should be on the muffler bracket and not on one > side of the muffler bracket and on half on the back side of the support > angle. > > Jim I found what I think is the rubber bushings that was used originally. In the CPS catalogue I found part numbers 9406 (male bushing) and 9408 (female bushing): http://www.rotaxparts.net/scripts/prodView.asp?idproduct=838 However a friend mentioned that I should probably use barry mount isolators: http://www.greenskyadventures.com/Installation_items/vibmntimages.htm However it looks like there are various ones to choose from (according to the chart at the bottom of that webpage). Has anyone used these and if so, which ones (what series and color)? -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235691#235691 ________________________________________________________________________________
Date: Mar 22, 2009
cristalclear13 wrote: > > > - - - snip- - - > > I know there aren't many of you out there that have a 503 anymore and probably don't even have the same set up for the exhaust if you do have a 503, but if you have something similar could you please post a picture and/or diagram? > > - - - snip- - - > > Cristal: Know you've gotten lots of input since the posting..... but here's a picture of my set up on my FSII. (R503). If you go with the recommended bushings from CPS, don't forget the backing washers. -------- George Alexander FS II R503 N709FS http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235696#235696 Attachments: http://forums.matronics.com//files/503_muffler_mount_003_small_423.jpg ________________________________________________________________________________
Subject: Re: Rotax 912 UL for sale
Date: Mar 22, 2009
Hey, George, What kind of airplane are you putting the floats on? I'm fantasizing about the same modification on a Kolb MKIII w/ 912s. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235698#235698 ________________________________________________________________________________
Date: Mar 22, 2009
There are different grades of silver solder. If the right one is used it is as good as a weld. Brazing has low strength and prone to cracking easily under flex. There is a big difference between the two. BB, lots of experience fabricating hi-vac ultra thin wall stainless lab equipment with it. The stuff I used cost big bucks and had to be bought from a specialty manufacturer. -But then the department of energy has deep pockets :) On 22, Mar 2009, at 2:03 PM, Jim Hauck wrote: > Rick; > > I would never use silver solder on that type of repair, unless I > was 40,000 miles from no where and that was all I had. No again on > brazing. > > If a plate was welded up the way I suggested it will last a very > long time. > > I do agree with you on making sure that there is no stress points > from misalignment of bolts and etc. > > Jim H > > ________________________________________________________________________________
Date: Mar 22, 2009
> I've also attached a picture of my exhaust with the mount with some lette rs pointing to various places. > Cristal Waters > Kolb Mark II Twinstar > Rotax 503 DCSI Cristal=2C It seems to me Jim H. has suggested the best way to repair the bracket. A TIG weld as he described should last a long time. If you have the room on your support bracket=2C you might consider adding a duplicate bracket=2C while the muffler is being welded=2C anyway. By distributing the vibration load between 2 mounting locations=2C you ma y not have a problem for a very long time. Just an idea.... Mike Welch MkIII _________________________________________________________________ Get quick access to your favorite MSN content with Internet Explorer 8. http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid=B037 MSN55C0701A ________________________________________________________________________________
Date: Mar 22, 2009
Its always possible to have good results with a bad engine, but that makes it an exception. When choosing an engine, I would consider the record of the all of the engines of that make and model, not ONE... I would never make an engine choice based on just one exceptional case. That being said, I have seen from many sources the same as posted earlier, Hearth engines are horrible for reliability and don't last long. I would never use one. From what Jim reports ,his experience is very good, but that does not change the MANY with bad experiences with Hirth engines. Do your research before deciding on an engine for an airplane ! Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235713#235713 ________________________________________________________________________________
Date: Mar 22, 2009
Gang, When I used it in my 503 I added it to the regular amount of two stroke oil, My plugs showed no indication that it was getting too much oil. Larry C ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Sunday, March 22, 2009 8:30 AM Subject: Re: Kolb-List: Re: 100LL fuel additive > Can I use MMO in 2-cycle engines? > Yes, MMO is safe for use in 2-cycle engines. Replace 25% of the 2-cycle > oil with MMO. For example, if use 8oz of 2-cycle oil, replace 2oz of > 2-cycle with 2oz of MMO at oil change. > -------- > Thom Riddle I would not replace two stroke oil with MMO, but add it in addition to the recommended amount of two stroke oil. Personal opinion and gut feeling only. I use regular MMO in my air tools. Haven't worn one out yet. john h mkIII ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/21/09 17:58:00 ________________________________________________________________________________
Date: Mar 22, 2009
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > When choosing an engine, I would > consider the record of the all of the engines of that make and > model, not ONE. ...and a great deal of grief can be heard from Rotax, Lycoming, Continental, AMW, MZ, VW, , etc....Very seldom do we routinely and continually hear about the successes, just the failures. "Hey, didja hear that so-and-so made an entirely uneventful flight?" > That being said, I have seen from many sources the same as posted > earlier, Hearth engines are horrible for reliability and don't > last long I've also heard that Hearth engines suck..... ; ) . I would never use one. From what Jim reports ,his > experience is very good, but that does not change the MANY with > bad experiences with Hirth engines. Do your research before > deciding on an engine for an airplane ! Absolutely, do your research. Consider the source, talk to owners, don't just listen to detractors, get facts...... That said, I'm not an advocate for or against Hirth. All I know is that my engine, appparently the only known success story for this marque, has served me well, without problems. Were it not for Hirth (or at least my model of Hirth), I'd most likely have a Rotax. Are Hirth without problems? Nope. The 2706 was a problematic engine that had several vices, none of them forgiving. Are there bad Hirth engines? Some of the reputation is undeserved because Jim Bede ordered a boat load of short block Hirth engines (without intake, carbs, or exhaust) for the BD-5 and when that didn't pan out, untested and incomplete engines were dumped on the market. Some can still be obtained. Cobbled up two stroke engines, particularly with unknown lineage exhaust systems, aren't pretty. On the other side of this equation are owners, some of whom should never own two stroke engines. They don't understand them, aren't willing to learn how to make them happy, treat them like four strokes, and just generally cause havoc through ignorance. As the Bard once said, Ignorance is the curse of God, Knowledge the wing wherewith we fly to heaven. On that note...... Jim Baker 580.788.2779 405. 426.5377 cell Elmore City, OK ________________________________________________________________________________
Date: Mar 22, 2009
I flew ultra lites for a lot of years with Cyuna engines,two engine outs,one right after take-off,If not for my first flight instructor beating in my head emergency procedures,it could have been a nasty outcome.All engine outs were from cold seizure,The Hirth engine is suppost to be immune.As for longevity only time will tell. > -----Original Message----- > From: jlbaker(at)msbit.net > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Off list - Hirth reputation. > > > X-SpamReason %%SpamReason%%: > >> When choosing an engine, I would >> consider the record of the all of the engines of that make and >> model, not ONE. > > ...and a great deal of grief can be heard from Rotax, Lycoming, > Continental, AMW, MZ, VW, , etc....Very seldom do we routinely and > continually hear about the successes, just the failures. "Hey, didja > hear that so-and-so made an entirely uneventful flight?" > >> That being said, I have seen from many sources the same as posted >> earlier, Hearth engines are horrible for reliability and don't >> last long > > I've also heard that Hearth engines suck..... ; ) > > . I would never use one. From what Jim reports ,his >> experience is very good, but that does not change the MANY with >> bad experiences with Hirth engines. Do your research before >> deciding on an engine for an airplane ! > > Absolutely, do your research. Consider the source, talk to owners, > don't just listen to detractors, get facts...... > > > That said, I'm not an advocate for or against Hirth. All I know is > that my engine, appparently the only known success story for this > marque, has served me well, without problems. Were it not for Hirth > (or at least my model of Hirth), I'd most likely have a Rotax. Are > Hirth without problems? Nope. The 2706 was a problematic engine that > had several vices, none of them forgiving. Are there bad Hirth > engines? Some of the reputation is undeserved because Jim Bede > ordered a boat load of short block Hirth engines (without intake, > carbs, or exhaust) for the BD-5 and when that didn't pan out, > untested and incomplete engines were dumped on the market. Some can > still be obtained. Cobbled up two stroke engines, particularly with > unknown lineage exhaust systems, aren't pretty. > > On the other side of this equation are owners, some of whom should > never own two stroke engines. They don't understand them, aren't > willing to learn how to make them happy, treat them like four > strokes, and just generally cause havoc through ignorance. As the > Bard once said, > > Ignorance is the curse of God, Knowledge the wing wherewith we fly to > heaven. > > On that note...... > > Jim Baker > 580.788.2779 > 405. 426.5377 cell > Elmore City, OK > > ________________________________________________________________________________
Date: Mar 22, 2009
While I have flown behind a Hirth for 15 minutes or so and, it ran fine, I'd hate to be a dealer that has to sell the "2000 hour TBO" I see in the ad's... [Rolling Eyes] -------- Kip Firestar II, N111KX Waiex, N111YX Quickie 1, N111QX Atlanta Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235753#235753 ________________________________________________________________________________
Date: Mar 22, 2009
Mike and all, Some time back I had much the same opinion as you regarding Hirths. My wing man went down twice - the second rebuild they changed both the crank & the case. That seemed to cure the problem. Matt at Recreational Power Engineering has made a lot of progress with Hirth improving the quality of engine they turn out. Last I new my friend has run it well over 400 hours and it's still going. The new model engines appear to be much more reliable. There are some advantages of running their lower RPM, higher torque engine, not as noisy and better fuel economy. jerb At 05:08 PM 3/22/2009, you wrote: > >Its always possible to have good results with a bad engine, but that >makes it an exception. When choosing an engine, I would consider >the record of the all of the engines of that make and model, not >ONE... I would never make an engine choice based on just one exceptional case. > >That being said, I have seen from many sources the same as posted >earlier, Hearth engines are horrible for reliability and don't last >long. I would never use one. From what Jim reports ,his experience >is very good, but that does not change the MANY with bad >experiences with Hirth engines. Do your research before deciding on >an engine for an airplane ! > >Mike > >-------- >"NO FEAR" - If you have no fear you did not go as fast as >you could have !!! > >Kolb MK-III Xtra, 912-S > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=235713#235713 > > ________________________________________________________________________________
Date: Mar 22, 2009
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: >All engine outs were from cold seizure,The > Hirth engine is suppost to be immune. If there were a consensus about what precicely constituites a cold seizure, I might agree. As for immunity....perhaps better than an iron sleeved cylinder that grows at a rate lower than the piston's growth....but still subject to the vagaries of overly lean mixture and lubrication film failure. Shoot, Rotax said it best in their literature...... "This engine, by its design, is subject to sudden stoppage." Jim Baker 580.788.2779 405. 426.5377 cell Elmore City, OK ________________________________________________________________________________
Date: Mar 22, 2009
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > I'd hate to be a dealer that has to sell the "2000 hour TBO" I see in the ad's... [Rolling Eyes] I'm more than a bit skeptical, as well. Examples of 1200-1500 hrs have been reported for other UL two stroke cranks, so perhaps the margins are reachable.... Jim Baker 580.788.2779 405. 426.5377 cell Elmore City, OK ________________________________________________________________________________
Date: Mar 23, 2009
In a message dated 3/22/2009 10:09:15 P.M. Central Daylight Time, jlbaker(at)msbit.net writes: Shoot, Rotax said it best in their literature...... "This engine, by its design, is subject to sudden stoppage." Jim, I think that statement was made to cover their hind end. If something happens to a Rotax you cant say they did not warn You! I have been around Ultralights since the early 80.s I never met a happy Hirth owner! As long as they have been around they should get it right. Hopefully the guy that was flying at the New Kolb Homecoming is happy! His Hirth sound ed fairly good from the ground Ed Diebel FF 62 **************Feeling the pinch at the grocery store? Make dinner for $10 or less. (http://food.aol.com/frugal-feasts?ncid=emlcntusfood00000001) ________________________________________________________________________________
Date: Mar 23, 2009
George Alexander wrote: > Cristal: > Know you've gotten lots of input since the posting..... but here's a picture of my set up on my FSII. (R503). > If you go with the recommended bushings from CPS, don't forget the backing washers. Thank you for the picture George. The more I think about it the more I think perhaps me and my friends remembered incorrectly. I wrote down everything I did as I took everything apart and laid things out in order as I took them apart, but when I took this piece apart it drew a lot of attention and I believe things may have gotten out of order (physically and in our minds). From now on I'll be taking pictures before I take things apart. :) I have a friend of a friend welding it for me since I don't weld. I'm sure he'll do a good job. Thanks for everyone's input and help. Again if anyone has used those barry mounts please let me know how it goes and what type/size should be used. Otherwise I suppose I'll go with the male/female rubber bushings I found in the CPS catalogue (with the backing washers). It may be time to replace my muffler springs as well. They are looking pretty rusty and I saw in the CPS catalogue where it says to replace them every 75 hours (Mark II manual says 100 hrs). My engine has almost 70 hours on it (don't know how old the muffler or springs are however). That doesn't look like an easy job. Maybe I should wait until after my Rotax class in a couple weeks to tackle that. I don't know how much anti-seize to put on the joint or where exactly. I don't suppose I'll be making it to that Ashburn fly-in this weekend. :( -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235789#235789 ________________________________________________________________________________
Subject: Do you have to have a current chart and AFD for X country?
Date: Mar 23, 2009
I do not recall seeing any requirements in the FAR/AIM regarding having a current chart and AFD when flying cross country. I am planning on making the short hop over to Ashburn to the fire ant festival on the 28th. I just want to be legal just in case someone is checking. I have an old chart that went out of date 6 months ago and an old AFD from September 08. In my area things pretty much stay the same so I don't see a need to update that often. Grant Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235792#235792 ________________________________________________________________________________
Subject: Re: Do you have to have a current chart and AFD for X country?
Date: Mar 23, 2009
> I do not recall seeing any requirements in the FAR/AIM regarding having a current chart and AFD when flying cross country. I am planning on making the short hop over to Ashburn to the fire ant festival on the 28th. > > Grant My understanding to be current for cross country VFR flights is either a current sectional or a current Jeppesen Data Base in your GPS. If you have an outdated sectional in the cockpit, then have a current Jeppesen Data Base. If the current Jeppesen Data Base is outdated, then have a current sectional. All my sectional charts are outdated, so I keep the Jeppesen Data Base current in my GPS. Currency is important. Over the years I flew into two airports that were indicated as uncontrolled fields on my outdated charts, when in fact they had been changed over to tower controlled fields. Greenwood, MS, was one. The other was Galveston, TX. I was flying my FS when I went into Greenwood about 5 minutes before time for the tower to close at 1800. Tower operator was kind enough to come down to the ramp to chat with me. Tower had recently been opened. Galveston was another story. There were four of us in that flight. John W was leading. We had checked NOTAMS, which did not include recent opening of the tower. John W went up to the tower to talk to the operators. We were not bound and gagged, and hauled off the jail, but continued our flight low level down the beach to Mexico. Probably clear as mud, but I have only had one cup of coffee so far this morning. john h mkIII ________________________________________________________________________________
Date: Mar 23, 2009
> In my area things pretty much stay the same so I don't see a need to upda te that often. > > Grant Grant=2C A person takes a mighty big gamble flying cross-country with old charts. Example: When I was on my "long distance cross-country" several years ag o=2C for my private pilot license=2C I used old charts to plot a 300+ mile course=2C dropping in on various northern California airports. Imagine my surprise=2C when I did an airport fly-over=2C prior to landing =2C and saw bulldozers=2C and graders on Nevada County Airport. (they were extending the runway) So there I was=2C 1500' AGL=2C can't land=2C and fully unprepared to fly toward some unscheduled airport (and this was a scheduled fuel stop for me) . Very sobering for a very low time pilot. Thankfully=2C I used to live n ear this airport=2C and I knew the proper highway to follow that would lead me to Auburn Airport 17 miles away. I landed there=2C and said I'll NEVER ASSUME that all the airports ahead of me are just waiting for my arrival. This was a big learning lesson for me!! Said all that to say this!! Not only should you have current charts=2C b ut you should also check the NOTAMs for your intended route. To say "thing s stay pretty much the same" is a hellava big assumption. What happens if you're wrong? What if the airport a person planned on stopping for fuel is having their fuel pumps replaced that day? What if the runway is being seal-coated=2C and closed for the day? There can be all kinds of reasons that ruin your d ay=2C and they don't all have to be catastrophic=2C some may be just inconv enient. For safe flying=2C with less worrying=2C be prepared! A proper flight pl an=2C with current information=2C allows you to enjoy the cross-country fli ght as it should be....a fantastic event-free flight!! Just my thoughts..... Mike Welch MkIII _________________________________________________________________ Get quick access to your favorite MSN content with Internet Explorer 8. http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid=B037 MSN55C0701A ________________________________________________________________________________
Date: Mar 23, 2009
cristalclear13 > > > It may be time to replace my muffler springs as well. They are looking pretty rusty and I saw in the CPS catalogue where it says to replace them every 75 hours (Mark II manual says 100 hrs). My engine has almost 70 hours on it (don't know how old the muffler or springs are however). That doesn't look like an easy job. Maybe I should wait until after my Rotax class in a couple weeks to tackle that. I don't know how much anti-seize to put on the joint or where exactly. > > Cristal, On the muffler joint, clean it with lacquer thinner and apply a thin coating of anti-seize compound, on each side of the joint. It's easy to install the springs. Just don't use any pliers when putting them in. Hook one end of the spring to the muffler and hook the other end with a small screwdriver and pull it over the other muffler hook. Using pliers can create stress points on the brittle spring steel and it can cause it to break. After the springs are installed, be sure and use safety wire between the muffler hooks. After that, clean the springs with lacquer thinner (to get rid of the oil on the outside) and apply two beads of the red high temp gasket sealer along the side of each spring. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 22 years flying it Kolbra 912UL N20386 almost 1 year flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235797#235797 ________________________________________________________________________________
Date: Mar 23, 2009
cristalclear13 wrote: > > It may be time to replace my muffler springs as well. They are looking pretty rusty and I saw in the CPS catalogue where it says to replace them every 75 hours (Mark II manual says 100 hrs). My engine has almost 70 hours on it (don't know how old the muffler or springs are however). That doesn't look like an easy job. Maybe I should wait until after my Rotax class in a couple weeks to tackle that. I don't know how much anti-seize to put on the joint or where exactly. > > I don't suppose I'll be making it to that Ashburn fly-in this weekend. :( The muffler springs can be easily replaced but it's crucial that you use the right tool. Never use pliers - they gouge the spring, increasing the likelihood of future breakage. A tool is easy to make, tho. A piece of safety wire in a loop with the ends attached to a screwdriver or other metal rod (something strong that's easy to grip) works fine (I got em kind of all over the place in the hangar still). You can then thread the loop into the hook of the spring and pull, easily popping the spring off. Same with installation - put the loop in the hook and pull the sucker over the fitting on the muffler. As for anti-sieze, put a thin film around the area on the elbows where they make contact. You don't need much, a very thin film on both surfaces is all you need. Once heated, the stuff will boil off but a kind of dust will remain and act like a lubricant. Stays there quite a while, I've seen the lubricant dust still there after 100 hours in some cases. So a good interval is every 50 to 75 hours I'd say. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235799#235799 ________________________________________________________________________________
Date: Mar 23, 2009
I thought you were supposed to have alternate air fields in your planned flight just in case. Vic ________________________________________________________________________________
Date: Mar 23, 2009
It is well worth it to buy a "spring hook" or to make one out of a piece of coat hanger & a short piece of broom handle; makes the job a lot easier. Howard Shackleford FS II SC In a message dated 3/23/2009 10:04:00 A.M. Eastern Daylight Time, ul15rhb(at)juno.com writes: Hook one end of the spring to the muffler and hook the other end with a small screwdriver and pull it over the other muffler hook. **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DMarchfooterNO62) ________________________________________________________________________________
Date: Mar 23, 2009
Subject: Aero Electric Connection CD
Folks, I contributed to the Kolb list and signed up for a bonus Aero Electric Connection DVD. After receiving an apology from Matronics about taking so long, it finally arrived. Breathless, I rushed to my DVD player, put it in the drawer and hit play... only to discover what is behind the Aero Electric Connection label is an audio narrative of Thomas Paine's _Common Sense_. Although it was written in 1776, it is certainly applicable even today. But it doesn't help me with adding a strobe, etc., on my FireFly. Has anyone else had the same experience; or does anyone know how to get a response to a question from the list's administration? I've tried on a couple of occasions about a couple of things and, except for donating, have never been successful connecting with them. A safe and fun flying season to all!! (And for rainy days, you might want to pick up a copy of _Common Sense_ and enjoy that.) Dave Kulp Bethlehem, PA FireFly 098 ________________________________________________________________________________
Subject: Re: Aero Electric Connection CD
Date: Mar 23, 2009
Please use dralle(at)matronics.com to contact Matt Dralle off-list. The AeroElectric CDs are produced and shipped directly from Bob Nuckolls. Did you try putting the disc into your computer and looking for the PDF document(s)? Matt Dralle List Admin -------- Matt Dralle Matronics Email List Administrator Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235810#235810 ________________________________________________________________________________
Date: Mar 23, 2009
The stainless springs from JBM last forever. ? G Aman -----Original Message----- From: lucien <lstavenhagen(at)hotmail.com> Sent: Mon, 23 Mar 2009 9:09 am Subject: Kolb-List: Re: Broken exhaust bracket cristalclear13 wrote: > > It may be time to replace my muffler springs as well. They are looking pretty rusty and I saw in the CPS catalogue where it says to replace them every 75 hours (Mark II manual says 100 hrs). My engine has almost 70 hours on it (don't know how old the muffler or springs are however). That doesn't look like an easy job. Maybe I should wait until after my Rotax class in a couple weeks to tackle that. I don't know how much anti-seize to put on the joint or where exactly. > > I don't suppose I'll be making it to that Ashburn fly-in this weekend. :( The muffler springs can be easily replaced but it's crucial that you use the right tool. Never use pliers - they gouge the spring, increasing the likelihood of future breakage. A tool is easy to make, tho. A piece of safety wire in a loop with the ends attached to a screwdriver or other metal rod (something strong that's easy to grip) works fine (I got em kind of all over the place in the hangar still). You can then thread the loop into the hook of the spring and pull, easily popping the spring off. Same with installation - put the loop in the hook and pull the sucker over the fitting on the muffler. As for anti-sieze, put a thin film around the area on the elbows where they make contact. You don't need much, a very thin film on both surfaces is all you need. Once heated, the stuff will boil off but a kind of dust will remain and act like a lubricant. Stays there quite a while, I've seen the lubricant dust still there after 100 hours in some cases. So a good interval is every 50 to 75 hours I'd say. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235799#235799 ________________________________________________________________________________
Date: Mar 23, 2009
Cristal It seems obvious, but many people seem to forget that with a pusher aircraft, ANYTHING that gets loose will go thru the prop. And usually cause some damage. Replace anything that looks iffy, no matter how many hours it has. You can hardly go wrong with anti-seize; simply put it on threads or mating surfaces, just enough to coat the surfaces. Any excess will just paint a stripe on your prop, if you don't wipe it off. Russ On Mar 23, 2009, at 8:53 AM, cristalclear13 wrote: > > > > George Alexander wrote: >> Cristal: >> Know you've gotten lots of input since the posting..... but here's >> a picture of my set up on my FSII. (R503). >> If you go with the recommended bushings from CPS, don't forget the >> backing washers. > > > Thank you for the picture George. The more I think about it the > more I think perhaps me and my friends remembered incorrectly. I > wrote down everything I did as I took everything apart and laid > things out in order as I took them apart, but when I took this > piece apart it drew a lot of attention and I believe things may > have gotten out of order (physically and in our minds). From now > on I'll be taking pictures before I take things apart. :) > > I have a friend of a friend welding it for me since I don't weld. > I'm sure he'll do a good job. > > Thanks for everyone's input and help. Again if anyone has used > those barry mounts please let me know how it goes and what type/ > size should be used. Otherwise I suppose I'll go with the male/ > female rubber bushings I found in the CPS catalogue (with the > backing washers). > > It may be time to replace my muffler springs as well. They are > looking pretty rusty and I saw in the CPS catalogue where it says > to replace them every 75 hours (Mark II manual says 100 hrs). My > engine has almost 70 hours on it (don't know how old the muffler or > springs are however). That doesn't look like an easy job. Maybe I > should wait until after my Rotax class in a couple weeks to tackle > that. I don't know how much anti-seize to put on the joint or > where exactly. > > I don't suppose I'll be making it to that Ashburn fly-in this > weekend. :( > > -------- > Cristal Waters > Kolb Mark II Twinstar > Rotax 503 DCSI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235789#235789 > > ________________________________________________________________________________
Date: Mar 23, 2009
Just ordered the rubber bushings from Travis at Kolb (he's so nice). Gonna pick up my muffler from the friend who welded it for me tonight. Talked to Ronnie Smith at South MS Light Aircraft and he said it would be ok to bring my muffler along to the Rotax class I'm taking the weekend after next and we'll change out the springs right there in his shop. -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235830#235830 ________________________________________________________________________________
Date: Mar 23, 2009
grantr wrote: > I do not recall seeing any requirements in the FAR/AIM regarding having a current chart and AFD when flying cross country. I am planning on making the short hop over to Ashburn to the fire ant festival on the 28th. > > I just want to be legal just in case someone is checking. I have an old chart that went out of date 6 months ago and an old AFD from September 08. > > In my area things pretty much stay the same so I don't see a need to update that often. > > Grant Grant, I knew I read something about this before and I found it again on the AOPA Flight Training website. If you have trouble getting to it let me know: http://flighttraining.aopa.org/cfi_tools/publications/inst_reports2.cfm?article=5846 -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235840#235840 ________________________________________________________________________________
Date: Mar 23, 2009
I always check DUATS prior to going out. So i get an update on the notams. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235854#235854 ________________________________________________________________________________
Date: Mar 23, 2009
> I didn't know I could do that. I thought you were just trailing in > formation, holding back. You and John W always stuck me out front so you > could hang back, laugh, and keep a good eye on me. > > John Bickham Folks: Meet John B, the new flight lead for our flight to MV, the Rock House, and other far flung parts of the world. ;-) Better watch out now. I talked to Daryl at Warp Drive this morning. We were going to recondition my blades, but I asked him for new 72" blades instead. Now you gonna really see old Miss P'fer climb her heart out with the big prop. It will be somewhat noisier, but will climb and cruise a little better. Adding an inch to the tiny taper tips doesn't make much difference in weight, but it does in performance. john h mkIII ________________________________________________________________________________
Date: Mar 23, 2009
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > > It may be time to replace my muffler springs as well. snip..... > The muffler springs can be easily replaced but it's crucial that you use the right tool. Rid yourself of the springs. http://www.rotaxparts.net/scripts/prodView.asp?idproduct=324 You'll never look back and wonder if a spring is going to go thru the prop (well, at least for pushers). A bit pricy but well worth the expense. I've had two for several years. Jim Baker 580.788.2779 405. 426.5377 cell Elmore City, OK ________________________________________________________________________________
Date: Mar 24, 2009
The stainless springs from JBM last forever. G Aman Gary, What and where is JBM? Denny Rowe ________________________________________________________________________________
Subject: Alaska 2009 Flight Plans Postponed
Date: Mar 24, 2009
Decided to postpone plans for a return flight to Alaska this Summer. Instead, Nell and I are going to pull the 5th wheel to Alaska, something we have not been able to do since 1997. Plans were already made to make a long flight to and from Monument Valley with Gary H, John B, and Bruce C., prior to making the decision to fly to Alaska this year. To complete that flight, fly back to Alabama, turn around and head out for Alaska, was more than I wanted to do this year. In 2004, I flew to Monument Valley and directly back to Alabama before departure to Alaska. That worked out pretty good, cutting my time in the air by many hours. I'll consider flying back to Alaska next year, if I am up to it. If it does not look like fun, I doubt I'll make the flight. john h mkIII ________________________________________________________________________________
Subject: Arty's Trip
Date: Mar 24, 2009
I just read about Arty's trip in Sport Pilot. In case you missed here is a link. http://www.lessonsfromtheedge.com/uladventure2009.htm Hopefully we can "meet up" if/when she comes through Georgia. Sounds like lot's of fun...! Kip -------- Kip Firestar II, N111KX Waiex, N111YX Quickie 1, N111QX Atlanta Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235936#235936 ________________________________________________________________________________
Date: Mar 24, 2009
Find JBM on e-bay .He is a custom rubber molder,makes carb mounting boots for all rotax applications including HKS, 912 and some special stuff like a rotax to mikuni socket.He is one of the founders of our club, North Coast Lite Flyers.He flies a Chinook 2 with 582.He ships next day.330-678-9537,is his phone. ??????????????????? G Aman MK-3C Jabiru 2200A- 430 hrs -----Original Message----- From: Denny Rowe <rowedenny(at)windstream.net> Sent: Tue, 24 Mar 2009 5:38 am Subject: Re: Kolb-List: Re: Broken exhaust bracket ? ? The stainless springs from JBM last forever. ? G Aman ? ? Gary, What and where is JBM? ? Denny Rowe ________________________________________________________________________________
Subject: Re: Alaska 2009 Flight Plans Postponed
Date: Mar 24, 2009
John, Just think of all the wear and tear you will be saving on your 912. Alaska is a pretty place to fly, but very unforgiving as you well know. Another way to think of it is you can have a lot of fun traveling on the ground without the worry of the weather, and be able to show Nell some of the places you've been. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 22 years flying it Kolbra 912UL N20386 almost 1 year flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235950#235950 ________________________________________________________________________________
Date: Mar 24, 2009
> Just think of all the wear and tear you will be saving on your 912. Alaska > is a pretty place to fly, but very unforgiving as you well know. Another > way to think of it is you can have a lot of fun traveling on the ground > without the worry of the weather, and be able to show Nell some of the > places you've been. > > Ralph Thanks, Ralph: The engine can take it better than I can. ;-) The Alaska flight in 2004, was fully funded by hauck's holler aviation (me), as the 2009 flight would have been. Rather spend the money on Nell and I and a summer in Alaska this year. If I get fired up about it next year, I'll hop in Miss P'fer and make my fourth flight to Alaska. Nell will get to meet most of my friends on the way and in Alaska that were made because of the Kolb airplane. We plan to drive the Dalton Highway to Deadhorse/Purdhoe Bay. Jim Helmericks will fly over in his 206 and take us the 40 sm back to Colville Village, his home on an island in the Colville River Delta on the Artic Ocean, NW of Deadhorse. I have spent time with Jim and Teanna Helmericks the last two flights to Alaska. Jim's Dad was Bud Helmericks, an accomplished Alaska Bush Pilot and Author. Him Mom is also an author. They both wrote about Alaska and the North Country around the Brooks Range and the North Slope. Then there is Jack Reakoff, a trapper in Wiseman, Alaska, north of Coldfoot, AK, in the Arctic. I met Jack on the 1994 flight. I have been fortunate to visit him every flight. Nell and I stopped in to see him at Wiseman in 1997, but he and the family had gone south to fish commercially for salmon. Sure was sorry we missed him, but did get to visit with June Reakoff, his Mom. There's a string of other folks from Alabama to Alaska and back that I want to stop and visit with. Folks that were friendly and hospitable to a guy from Alabama in a little bitty airplane a long way from home. Not upset or disappointed I am not going this year. Just could not get that "fire in the pit of my stomach" urge to go. Maybe next year. john h mkIII ________________________________________________________________________________
Date: Mar 24, 2009
grantr wrote: > I do not recall seeing any requirements in the FAR/AIM regarding having a current chart and AFD when flying cross country. I am planning on making the short hop over to Ashburn to the fire ant festival on the 28th. > > I just want to be legal just in case someone is checking. I have an old chart that went out of date 6 months ago and an old AFD from September 08. > > In my area things pretty much stay the same so I don't see a need to update that often. > > Grant I've gone places before without current charts and I'll never do that again ;). Even local flights you want the updated chart or GPS database. My GPS database is something like 3 years old, and I lost the connector thing to update it. So I always have a current chart at the very least and a current AFD if I can find one (that's needed to be legal as well). One of the local airports suddenly became towered just recently. I was flying with a friend of mine in his RV on a trip and on the return trip we noticed a tower directing traffic there on the comm.... My chart in my plane had expired only a couple weeks before, so after we landed I went and got an updated one. Sure enough, there was the towered field on it..... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236017#236017 ________________________________________________________________________________
Date: Mar 24, 2009
country? At 05:06 PM 3/24/2009, lucien wrote: >...So I always have a current chart at the very least and a current AFD if >I can find one (that's needed to be legal as well). > >One of the local airports suddenly became towered just recently. I was >flying with a friend of mine in his RV on a trip and on the return trip we >noticed a tower... Still, lots of changes will take effect _before_ the next chart cycle shows it. That's why you're always "supposed" to get a briefing before every flight (yeah, I know). When I had the T-Craft, I didn't always bring along a chart (which may or may not have been the very latest). However, whenever I bought a new chart I would stick the next oldest one beneath the seat cushion, so I'd always have _something_ just in case. -Dana -- A truly wise man never plays leapfrog with a unicorn. ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Mar 24, 2009
The compact disc offered from the AeroElectric Connection website is an electronic text (Adobe PDF) version of the book . . . plus a bonus pak of articles from our website and other references. For a more complete description see: https://matronics.com/aeroelectric/Catalog/pub/pub.html#CD-Book This product is designed to be read in a Windows compatible computer using Adobe Reader which is free at: http://get.adobe.com/reader/ Some DVD players will find and play a collection of free audio books MP3 files that are on the CD but a small part of the total data package. I don't monitor this list-server so any questions or responses to this posting should be sent to me directly at: bob.nuckolls(at)matronics.com Hope this clears up any misunderstandings! Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236060#236060 ________________________________________________________________________________
Subject: Flying videos thermals!
Date: Mar 25, 2009
I guess I am hard headed but I always wind up going out to fly in mid day conditions. I hate getting up early and I hate going out late and getting home late especially with the time change having it get dark around 8 so I choose to fly in mid day conditions. I don't know how rough it is in larger planes but it sure gives me a workout keeping the wings level and the airspeed and altitude constant. The winds were not bad at 5 to 10mph but thermals were! Its fun though and I can climb over it. It has helped me flying in these conditions to become more comfortable with the airplane. The rough air still makes me a little nervous at times especially low on final when I get a good toss. I have posted 21 videos! WOW I didnt realize I was enjoying this camera so much.:D http://www.youtube.com/watch?v=i83zmWxqpZM&fmt=18 http://www.youtube.com/watch?v=3Gvs3PaElJM&fmt=18 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236075#236075 ________________________________________________________________________________
Subject: Re: Flying videos thermals!
Date: Mar 25, 2009
That kind of air brings up my only complaint regarding my Kolb. Strong up/down drafts involve what I consider to be excessive pitch changes and corrections. Whether it is a symptom of only my individual airplane is open to question. I would prefer that the result of a sudden boost from below would involve less noticeable speed and pitch changes. Wing leveling corrections are understandable and are common to all craft but watching the ASI go from 40 to 80 in a matter of seconds is not comfortable. BB, always bitchin about sumthin I On 25, Mar 2009, at 8:33 AM, grantr wrote: > > > I guess I am hard headed but I always wind up going out to fly in > mid day conditions. I hate getting up early and I hate going out > late and getting home late especially with the time change having > it get dark around 8 so I choose to fly in mid day conditions. > > I don't know how rough it is in larger planes but it sure gives me > a workout keeping the wings level and the airspeed and altitude > constant. The winds were not bad at 5 to 10mph but thermals were! > > Its fun though and I can climb over it. It has helped me flying in > these conditions to become more comfortable with the airplane. The > rough air still makes me a little nervous at times especially low > on final when I get a good toss. > > I have posted 21 videos! WOW I didnt realize I was enjoying this > camera so much.:D > > http://www.youtube.com/watch?v=i83zmWxqpZM&fmt=18 > > http://www.youtube.com/watch?v=3Gvs3PaElJM&fmt=18 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236075#236075 > > ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Subject: Re: 100LL fuel additive
Date: Mar 25, 2009
Hi, I used Marvel in the fuel of British sports cars in the '70's. Seemed to prevent sticking valves, didn't seem to hurt. I use their Air Tool oil as an after-run oil on RC 2-strokes, works great. Ed in JXN ----- Original Message ----- From: herb To: kolb-list(at)matronics.com Sent: Saturday, March 21, 2009 4:49 PM Subject: Re: Kolb-List: 100LL fuel additive Reading on the net...appears that MMO has phosphorous as its active ingredient... Dump a few ozs in the tank and carbon and sticky rings are a thing of the past...I also toss one oz over my left shoulder... :-) Herb WHAT IS IT? My own understanding from earlier articles on the subject is that Marvel Mystery Oil is a light viscosity oil, roughly equivalent to an SAE 3W, containing (among other things) about 20 percent solvent (probably mineral spirits), dye, wintergreen for smell, and 790 PPM of a phosphorous additive. ________________________________________________________________________________
Date: Mar 25, 2009
> Wing leveling corrections are understandable and are common to all > craft but > watching the ASI go from 40 to 80 in a matter of seconds is not > comfortable. > BB, always bitchin about sumthin Hey Bob! Might be that unconventional power plant. ;-) Seriously, and I'll try my best to be, that is not a common problem with Kolb aircraft, of any model, that I am aware of. I don't like rough air either, but in most cases, if you are going to get where you are going, ya gotta fly... John W and I had a unwritten law of anything over 25 mph ground speed was reason for staying on the ground. We demonstrated that May 2008, when we spent three days waiting for the wind to subside at Ontario, OR. The wind averaged about 45 mph for all three days and nights. Got used to walking around at odd angles. john h mkIII ________________________________________________________________________________
Date: Mar 25, 2009
> John W and I had a unwritten law of anything over 25 mph wind speed on the ground was > reason for staying on the ground. We demonstrated that May 2008, when we > spent three days waiting for the wind to subside at Ontario, OR. The wind > averaged about 45 mph for all three days and nights. Got used to walking > around at odd angles. > > john h > mkIII The above is what I meant, but not what I wrote in my original post. john h ________________________________________________________________________________
Date: Mar 25, 2009
I am guilty of flying too low also. 25 mph wind over the flatlands is fine. When the terrain is bumpy it's time to climb. The lumpiest part of most of my rides is when I descend to the rolling hillsides returning to my home strip. BB On 25, Mar 2009, at 10:32 AM, John Hauck wrote:
March 11, 2009 - March 25, 2009
Kolb-Archive.digest.vol-ib
