Kolb-Archive.digest.vol-jc
December 21, 2009 - January 13, 2010
      [quote="John Hauck"]Wow!
       Thanks for the info.
       Where do I get the numbers to plug into the  formula?
       Anybody else got a simple explanation to answer my  question, "Will the degausser
      damage my electric engine  instruments?"
       john h - Getting ready to exercise my right to  flight, this afternoon.
      >       Yes, as the following formula    shows, it will affect your ionization
      calibration gauge, especially if placed    between, or right next to the photon
      mass emitter;
      > From the basic k-space formula, it follows immediately that we    reconstruct an image     simply by taking the inverse Fourier transform (http://en.wikipedia.org/wiki/Inverse_Fourier_transform) of the    sampled data, viz.
      >                 Mike Welch
      >  [b]
      Yeah, right - what he said...
      I hadn't thought of that John, but I bet it would. Especially the compass. Which
      means that you might be facing a fair amount of hassle to demagnetize the front
      end of the airplane.  [Crying or Very sad]
      Richard Pike
      MKIII N420P (420ldPoops)
      http://forums.matronics.com/viewtopic.php?p=278480#278480
Subject: Re: Card Compass Question
Date: Dec 21, 2009
>Anybody else got a simple explanation to answer my question=2C "Will the > degausser damage my electric engine instruments?" >john h - Getting ready to exercise my right to flight=2C this afternoon. >mkIII Okay=2C okay=2C I'll be serious. Electric temperature instruments are designed to reflect the difference i n resistance and current=2C i.e. the electrical current generated by two di ssimilar metals when exposed to temperature. The sending units are "thermi sters"...temperature dependant resisters". The higher the temperature the lower the resistance=2C (due to the electrical current flowing between to d issimilar metals) The gauge simply displays the present resistance=2C but it does so on a s cale that is calibrated in temperature degrees. It is very doubtful a demagnetizer can have any effect on electrical engi ne gauges=2C unless the demagnetizer is on=2C and momentarily passing near an instrument=2C affecting it's electrical activity....but the gauge would not experience any after effects. IMHO. Mike Welch _________________________________________________________________ Hotmail: Trusted email with Microsoft=92s powerful SPAM protection. ________________________________________________________________________________
Date: Dec 21, 2009
Bro. Richard=2C I was kidding=2C of course=2C about the ionization=2C etc.=2Cetc..... But=2C John's question was about engine instruments. I don't think a dem agnetizer will hurt or affect them. However=2C I wasn't referring to "any" electrical instruments (or a compa ss). It may very likely effect these things....only a true labratory test would tell. As usual=2C the safe thing to always recommend is=3B check with the manuf acturer!! They're the people that would know what is safe for their instru ment to get next to=2C or not. Mike Welch _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Subject: 503 FireStar 2 cold cht fixed
Date: Dec 21, 2009
Thank you all for your comments and observations on 503 running temperatures. Since first running the 503 on FireStar 2 cht has been too cold. The result has been too fast build up of carbon in rings, piston, and head. The problem has been solved by installing a fairing in front of the fan intake. Warm holiday wishes to all, Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278490#278490 Attachments: http://forums.matronics.com//files/img_0964_248.jpg http://forums.matronics.com//files/img_0963_712.jpg ________________________________________________________________________________
Date: Dec 21, 2009
an old fashioned magnetic tachometer might be compromised. BB On 21, Dec 2009, at 3:05 PM, Mike Welch wrote: > >Anybody else got a simple explanation to answer my question, "Will the >degausser damage my electric engine instruments?" > > >john h - Getting ready to exercise my right to flight, this afternoon. > >mkIII > > Okay, okay, I'll be serious. > > Electric temperature instruments are designed to reflect the difference in resistance and current, i.e. the electrical current generated by two dissimilar metals when exposed to temperature. The sending units are "thermisters"...temperature dependant resisters". The higher the temperature the lower the resistance, (due to the electrical current flowing between to dissimilar metals) > The gauge simply displays the present resistance, but it does so on a scale that is calibrated in temperature degrees. > > It is very doubtful a demagnetizer can have any effect on electrical engine gauges, unless the demagnetizer is on, and momentarily passing near an instrument, affecting it's electrical activity....but the gauge would not experience any after effects. > > IMHO. > > Mike Welch > > > > > > > > > > Hotmail: Trusted email with Microsoft=92s powerful SPAtarget='_new'>Sign up now. > > > > ________________________________________________________________________________
Date: Dec 21, 2009
John/Gang: When I degaussed my MK III I had the compass out because I would put it in the dash area and it would be of by 90 deg but all my other instruments were in the dash. It did not affect any of them, did not think it was a good idea to leave the compass in since it works on magnetic field, also after I was done when I held compass inside where it mounted it now read correctly so it was a good before and after test. Tom -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Hauck Sent: Monday, December 21, 2009 11:24 AM Subject: Re: Kolb-List: Re: Card Compass Question cheapest one cost around $30.00. > > Rick Lewis Rick L/Gang: As Richard Pike suggested, Ebay has a couple dozen Realistic High Power Video/Tape Erasers, for 10.00 or less. http://shop.ebay.com/i.html?_kw=Realistic&_kw=Tape&_kw=Eraser&_ckw=Audio If it works for you, I will probably try it on my mkIII. Wonder if it will damage engine instruments? Anybody know? john h mkIII Checked by AVG - http://www.avg.com 19:13:00 -- We are a community of 6 million users fighting spam. The Professional version does not have this message ________________________________________________________________________________
Date: Dec 21, 2009
Tom I wouldn't be so sure about it not affecting a Tach I had to replace that one because it was not reading correctly It might not have been affected by the degaussed you did to it, it may have been an inferior Tach I woul d rather believe Ellery in Maine -----Original Message----- From: Tom Longo <tclongo(at)att.net> Sent: Mon, Dec 21, 2009 6:25 pm Subject: RE: Kolb-List: Re: Card Compass Question John/Gang: When I degaussed my MK III I had the compass out because I wou ld ut it in the dash area and it would be of by 90 deg but all my other nstruments were in the dash. It did not affect any of them, did not think t was a good idea to leave the compass in since it works on magnetic field , lso after I was done when I held compass inside where it mounted it now ead correctly so it was a good before and after test. Tom -----Original Message----- rom: owner-kolb-list-server(at)matronics.com mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Hauck ent: Monday, December 21, 2009 11:24 AM o: kolb-list(at)matronics.com ubject: Re: Kolb-List: Re: Card Compass Question cheapest one cost around $30.00. Rick Lewis ick L/Gang: As Richard Pike suggested, Ebay has a couple dozen Realistic High Power ideo/Tape Erasers, for 10.00 or less. http://shop.ebay.com/i.html?_kw=Realistic&_kw=Tape&_kw=Eraser&_ckw =Audio If it works for you, I will probably try it on my mkIII. Wonder if it wil l amage engine instruments? Anybody know? john h kIII hecked by AVG - http://www.avg.com 9:13:00 - e are a community of 6 million users fighting spam. The Professional version does not have this message ________________________________________________________________________________
Date: Dec 21, 2009
When I degaussed my MK III I had the compass out because I would > put it in the dash area and it would be of by 90 deg but all my other > instruments were in the dash. It did not affect any of them, Tom Thanks, Tom/Gang: That is the info I was looking for, someone that had actually degaussed their fuselage and instrument panel, and the results they obtained with electric engine instruments installed. My mag compass has always been about 90 degrees off, but changes in size of error as the aircraft is rotated around its axis. I've flown the mkIII with an inop mag compass for nearly 3000 hours. Would be nice to be able to use it to maintain my heading on long cross country flights, rather than contantly looking down at my thigh to read the GPS. If I am lucky, I can pick out a terrain feature, water tank, tower, barn, etc., and stay on course that way. I'm getting antsy to take a trip in my little bird. john h mkIII ________________________________________________________________________________
Date: Dec 21, 2009
A degaussing coil can kill engine instruments that incorporate DArsonval meter movements (most do) as this mechanism depends on an internal magnet which you really would not want to de-magnetize. Digital meters? I dunno. The DArsonval movement is a DC moving coil-type movement in which an electromagnetic core is suspended between the poles of a permanent magnet. -------- Jerry King Deer Park, NY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278521#278521 ________________________________________________________________________________
Date: Dec 21, 2009
A tachometer is usually using an aluminum disc, activated by "Eddie Currents", induced by rotating magnets. Sooo, degaussing that thing, could of course ruin the accuracy. Herb Graff Mark III N246KT In a message dated 12/21/2009 6:45:00 P.M. Eastern Standard Time, elleryweld(at)aol.com writes: Tom I wouldn't be so sure about it not affecting a Tach I had to replace that one because it was not reading correctly It might not have been affected by the degaussed you did to it, it may have been an inferior Tach I would rather believe Ellery in Maine ________________________________________________________________________________
Date: Dec 22, 2009
Hi Ellery, That 2" tach always read too high the whole time I owned the MK III that is why I put the tiny tach in there. I did not degauss the cage until the last 15 hrs or so I put on plane because I kept trying different compasses only to get the same result, even borrowed one that was fine in another plane and it was off too, that is when I degaussed the cage and it read correctly. How many hours do you have on it now? Probably too cold to fly now. Tom in warm Florida -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Ellery Batchelder Jr Sent: Monday, December 21, 2009 6:44 PM Subject: Re: Kolb-List: Re: Card Compass Question Tom I wouldn't be so sure about it not affecting a Tach I had to replace that one because it was not reading correctly It might not have been affected by the degaussed you did to it, it may have been an inferior Tach I would rather believe Ellery in Maine -----Original Message----- From: Tom Longo <tclongo(at)att.net> Sent: Mon, Dec 21, 2009 6:25 pm Subject: RE: Kolb-List: Re: Card Compass Question John/Gang: When I degaussed my MK III I had the compass out because I would put it in the dash area and it would be of by 90 deg but all my other instruments were in the dash. It did not affect any of them, did not think it was a good idea to leave the compass in since it works on magnetic field, also after I was done when I held compass inside where it mounted it now read correctly so it was a good before and after test. Tom -----Original Message----- From: owner-kolb-list-server(at)matronics.com [ mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Hauck Sent: Monday, December 21, 2009 11:24 AM Subject: Re: Kolb-List: Re: Card Compass Question > cheapest one cost around $30.00. > > Rick Lewis Rick L/Gang: As Richard Pike suggested, Ebay has a couple dozen Realistic High Power Video/Tape Erasers, for 10.00 or less. http://shop.ebay.com/i.html?_kw=Realistic&_kw=Tape&_kw=Eraser&_ckw=Audio <http://shop.ebay.com/i.html?_kw=Realistic&_kw=Tape&_kw=Eraser&_ckw=Audio> If it works for you, I will probably try it on my mkIII. Wonder if it will damage engine instruments? Anybody know? john h mkIII Checked by AVG - http://www.avg.com 19:13:00 -- We are a community of 6 million users fighting spam. The Professional version does not have this message <http://www.buildersbooks.com> <http://www.homebuilthelp.com> ________________________________________________________________________________
Subject: Re: Was Kolb Mark II for sale - Names Suggestions Needed
Date: Dec 22, 2009
Clare Waters ,would fit , you Americans probably would find another way to spell it . Any way good luck and congratulations. Our young people are our future . Downunder MK111c ----- Original Message ----- From: "cristalclear13" <cristalclearwaters(at)gmail.com> Sent: Tuesday, December 22, 2009 2:52 AM Subject: Kolb-List: Re: Was Kolb Mark II for sale - Names Suggestions Needed > > > > ulflyer(at)verizon.net wrote: >> Congratulations Cristal. >> >> Ok folks, >> >> We need some names here. Not sure if it's a boy or a girl. Must be >> aviation orientated. Can't be like Stick, Aileron, or Rudder, those >> are already taken by our dogs. More like Blue Sky, etc. Just might >> be fun to see what we can come up with while trying to stay warm over >> the Christmas, New year holidays. If nothing else we might use them >> for naming our airplanes. >> jerb > > > Funny jerb! Most everyone is of the opinion I am going to have a girl, > but they could be biased since I already have a boy. > > We already have two Misty Waters in the family, so that name is out. > > -------- > Cristal Waters > Kolb Mark II Twinstar > Rotax 503 DCSI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=278416#278416 > > > ________________________________________________________________________________
Date: Dec 22, 2009
Thanks Jack for the info. Next time I'm visiting the Kolb Factory I will see if I can get there welder, Dennis, to rotate his fixture, welding unit, and himself violently while making our cages. This would have to be video-ed of course for U-Tube. [Laughing] He's a pretty good old boy and would do most anything for us but this may be asking to much. You just don't really know though until you ask. Rick Lewis WHAT ABOUT IT DENNIS??????????? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278607#278607 ________________________________________________________________________________
Subject: Winter mods
Date: Dec 22, 2009
Tom the tach was reading to low compared to the tiny tach so I replaced it with a better quality tach I have logged 137hrs since I got it home I am in process of installing 2 ten gallon Fuel tanks, 4 point harnesses, building a new bigger panel, an d I have to rewire everything to get it where I want it, installing a inf light trim system ,changing the horizontal stabilizer position, installin g nav & wing tip strobes installing a heater System, inclosing the bac k and working on my skis as well I will be making a ceiling fan out of th at warp drive 3 blade for my shop, I willl be flying comfortable in Main e Winter soon no matter how cold it will be I got some ice fishing trips planned way up north in the wilderness where I will need most of my mods Ellery in Maine -----Original Message----- From: Tom Longo <tclongo(at)att.net> Sent: Tue, Dec 22, 2009 12:30 am Subject: RE: Kolb-List: Re: Card Compass Question Hi Ellery, That 2=9D tach always read too high the whole time I owne d the MK III that is why I put the tiny tach in there. I did not degauss the cage until the last 15 hrs or so I put on plane because I kept trying different compasses only to get the same result, even borrowed one that was fine in another plane and it was off too, that is when I degaussed th e cage and it read correctly. How many hours do you have on it now? Probab ly too cold to fly now. Tom in warm Florida -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com]On Behalf Of Ellery Batchelder Jr Sent: Monday, December 21, 2009 6:44 PM Subject: Re: Kolb-List: Re: Card Compass Question Tom I wouldn't be so sure about it not affecting a Tach I had to replace that one because it was not reading correctly It might not have been affected by the degaussed you did to it, it may have been an inferior Tach I woul d rather believe Ellery in Maine -----Original Message----- From: Tom Longo <tclongo(at)att.net> Sent: Mon, Dec 21, 2009 6:25 pm Subject: RE: Kolb-List: Re: Card Compass Question John/Gang: When I degaussed my MK III I had the compass out because I wou ld put it in the dash area and it would be of by 90 deg but all my other instruments were in the dash. It did not affect any of them, did not think it was a good idea to leave the compass in since it works on magnetic fiel d, also after I was done when I held compass inside where it mounted it now read correctly so it was a good before and after test. Tom -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Hauck Sent: Monday, December 21, 2009 11:24 AM Subject: Re: Kolb-List: Re: Card Compass Question cheapest one cost around $30.00. > > Rick Lewis Rick L/Gang: As Richard Pike suggested, Ebay has a couple dozen Realistic High Power Video/Tape Erasers, for 10.00 or less. http://shop.ebay.com/i.html?_kw=Realistic&_kw=Tape&_kw=Eraser&_ckw =Audio If it works for you, I will probably try it on my mkIII. Wonder if it wil l damage engine instruments? Anybody know? john h mkIII Checked by AVG - http://www.avg.com 19:13:00 -- We are a community of 6 million users fighting spam. The Professional version does not have this message -- Please Support Your Lists This Month -- -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on November is the Annual List Fund Raiser. Click on the Contribution link below to find out more about this year's Terrific Free Incentive Gifts provided by: * AeroElectric www.aeroelectric.com * The Builder's Bookstore www.buildersbooks.com * HomebuiltHELP www.homebuilthelp.com * HowToCrimp www.howtocrimp.com List Contribution Web Site: List Contribution Web Site: --> http://www.matronics.com/contribution --> http://www.matronics.com/contribution Thank you for your generous support! Thank you for your generous support! -Matt Dralle, List Admin. -Matt Dralle, List Admin. - The Kolb-List Email Forum - - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - - MATRONICS WEB FORUMS - --> http://forums.matronics.com --> http://forums.matronics.com ======================== =========== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com -= * HowToCrimp www.howtocrimp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== ======================== =========== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com -= * HowToCrimp www.howtocrimp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== ________________________________________________________________________________
Date: Dec 22, 2009
Subject: Seat tanks
Has anybody used (or seen) a seat tank in an UltraStar? Currently I have three tanks: the two original 1.75 gallon tanks in front of the seat, and a 1.5 gallon tank behind the seat. I want to replace all of these with a single tank, and use the space currently occupied by the original tanks for storage of small items. I originally looked at a single tank above the engine and gravity feed (with the added benefit of eliminating the fuel pump), but there's really not enough room there. I next looked at the space behind the seat, but that's pretty limited as well for any off the shelf tanks (I have a plastic tank a friend gave me, and it's 1/2" too wide to fit... grrrrr). The only options remaining are a custom tank (too much cost or work) or a molded seat tank like these: http://www.calumetair.com/tanks.php -Dana -- CanYouFixTheSpaceBarOnMyKeyboard? ________________________________________________________________________________
Date: Dec 22, 2009
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Seat tanks
- Dana- A seat tank showed up on E-Bay a few months ago.- I seem to rem ember that the ad said it was from Aircraft Spruce, and it gave a part numb er.- I just tried to look it up in both the book and on line, and no luck .- You might try calling them in the morning- maybe it is not a catalogue d item.- Good luck. - ------------------------- ------------------- Bill Sullivan ------------------------- ------------------- Windsor Locks, Ct . ------------------------- ------------------- FS 447 ________________________________________________________________________________
Date: Dec 22, 2009
Ellery Sounds like well thought out improvements, send me some pictures when you get done. Tell Wayne from Maine I said hello, have a Merry Christmas. Tom -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Ellery Batchelder Jr Sent: Tuesday, December 22, 2009 7:56 PM Subject: Kolb-List: Winter mods Tom the tach was reading to low compared to the tiny tach so I replaced it with a better quality tach I have logged 137hrs since I got it home I am in process of installing 2 ten gallon Fuel tanks, 4 point harnesses, building a new bigger panel, and I have to rewire everything to get it where I want it, installing a inflight trim system ,changing the horizontal stabilizer position, installing nav & wing tip strobes installing a heater System, inclosing the back and working on my skis as well I will be making a ceiling fan out of that warp drive 3 blade for my shop, I willl be flying comfortable in Maine Winter soon no matter how cold it will be I got some ice fishing trips planned way up north in the wilderness where I will need most of my mods Ellery in Maine -----Original Message----- From: Tom Longo <tclongo(at)att.net> Sent: Tue, Dec 22, 2009 12:30 am Subject: RE: Kolb-List: Re: Card Compass Question Hi Ellery, That 2=9D tach always read too high the whole time I owned the MK III that is why I put the tiny tach in there. I did not degauss the cage until the last 15 hrs or so I put on plane because I kept trying different compasses only to get the same result, even borrowed one that was fine in another plane and it was off too, that is when I degaussed the cage and it read correctly. How many hours do you have on it now? Probably too cold to fly now. Tom in warm Florida -----Original Message----- From: owner-kolb-list-server(at)matronics.com [ mailto:owner-kolb-list-server(at)matronics.com ]On Behalf Of Ellery Batchelder Jr Sent: Monday, December 21, 2009 6:44 PM Subject: Re: Kolb-List: Re: Card Compass Question Tom I wouldn't be so sure about it not affecting a Tach I had to replace that one because it was not reading correctly It might not have been affected by the degaussed you did to it, it may have been an inferior Tach I would rather believe Ellery in Maine -----Original Message----- From: Tom Longo < tclongo(at)att.net <mailto:tclongo(at)att.net> > Sent: Mon, Dec 21, 2009 6:25 pm Subject: RE: Kolb-List: Re: Card Compass Question John/Gang:=C2- When I degaussed my MK III I had the compass out because I would put it in the dash area and it would be of by 90 deg but all my other instruments were in the dash. It did not affect any of them, did not think it was a good idea to leave the compass in since it works on magnetic field, also after I was done when I held compass inside where it mounted it now read correctly so it was a good before and after test. Tom -----Original Message----- From: owner-kolb-list-server(at)matronics.com [ mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of John Hauck Sent: Monday, December 21, 2009 11:24 AM Subject: Re: Kolb-List: Re: Card Compass Question > cheapest one cost around $30.00. > > Rick Lewis Rick L/Gang: As Richard Pike suggested, Ebay has a couple dozen Realistic High Power Video/Tape Erasers, for 10.00 or less. http://shop.ebay.com/i.html?_kw=Realistic&_kw=Tape&_kw=Eraser&_ckw= Audio <http://shop.ebay.com/i.html?_kw=Realistic&_kw=Tape&_kw=Eraser&_ckw =Audio> If it works for you, I will probably try it on my mkIII.=C2- Wonder if it will damage engine instruments?=C2- Anybody know? john h mkIII Checked by AVG - http://www.avg.com 19:13:00 -- We are a community of 6 million users fighting spam. The Professional version does not have this message =C2-=C2-=C2-=C2-=C2-=C2- -- Please Support Your Lists This Month -- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- (And Get Some AWESOME FREE Gifts!) =C2-=C2- November is the Annual List Fund Raiser.=C2- Click on =C2-=C2- the Contribution link below to find out more about =C2-=C2- this year's Terrific Free Incentive Gifts provided =C2-=C2- by: =C2-=C2-=C2-=C2- * AeroElectric www.aeroelectric.com <http://www.aeroelectric.com/> =C2-=C2-=C2-=C2- * The Builder's Bookstore www.buildersbooks.com <http://www.buildersbooks.com/> =C2-=C2-=C2-=C2- * HomebuiltHELP www.homebuilthelp.com <http://www.homebuilthelp.com/> =C2-=C2-=C2-=C2- * HowToCrimp www.howtocrimp.com <http://www.howtocrimp.com/> =C2-=C2- List Contribution Web Site: =C2-=C2- --> http://www.matronics.com/contribution =C2-=C2- Thank you for your generous support! =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2- -Matt Dralle, List Admin. =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- - The Kolb-List Email Forum - =C2-=C2- --> http://www.matronics.com/Navigator?Kolb-List =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2- - MATRONICS WEB FORUMS - =C2-=C2- --> http://forums.matronics.com <http://forums.matronics.com/> =_blank>www.aeroelectric.com m/" target=_blank>www.buildersbooks.com =_blank>www.homebuilthelp.com ank>www.howtocrimp.com _blank>http://www.matronics.com/contribution rget=_blank>http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com This Month -- Get Some AWESOME FREE Gifts!) on <http://www.aeroelectric.com> www.buildersbooks.com <http://www.buildersbooks.com> <http://www.homebuilthelp.com> <http://www.howtocrimp.com> -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2- -Matt Dralle, List Admin. Kolb-List Email Forum - -=C2-=C2- - MATRONICS WEB FORUMS - ________________________________________________________________________________
Date: Dec 23, 2009
Subject: flight simulator question
Hey Folks, Anyone here have a flight simulator for a Kolb MKII or MKIII? I hear that there is one that plugs into the Microsoft program, but don't know where to get it. Any info would be appreciated. Thanks, Duane ________________________________________________________________________________
Date: Dec 23, 2009
Very similar to your aluminium ones>> Very good Russ. LOL i used to know a skipper who had a place to put his beer right next to the compass. He said that he had swung the compass with the beer in place so the deviation was known and built in. Cheers Pat ________________________________________________________________________________
Date: Dec 23, 2009
At 09:29 PM 12/22/2009, william sullivan wrote: > Dana- A seat tank showed up on E-Bay a few months ago. I seem to > remember that the ad said it was from Aircraft Spruce, and it gave a part > number. I just tried to look it up in both the book and on line, and no > luck. You might try calling them in the morning- maybe it is not a > catalogued item. I know, I should have grabbed it then, but I was still looking at other options. I'm pretty sure it was the same as the one I posted the link to. -Dana -- Newton's Seventeenth Law of American Life: For every action, there is an unequal and moronic overreaction. ________________________________________________________________________________
Subject: Names!. Dont do it Crystal.!
Date: Dec 23, 2009
How about Cold Waters, Rusty Waters, Muddy Waters, Sandy Waters,Falling Waters, Boiling Waters?>> Enough already! Crystal, think I beg you before you inexorably warp the entire life of your poor unborn child. I read lately that research has shown that names influence many things. Career for instance. From the `allitirative affect` there are more dentists named `Dennis` and more lawyers called `Laura` than statistically there should be and likewise more shops selling sea shells are owned by Sheryls and Cheryls. There are more women named Georgia, in Georgia and more men named Louis in Louisiana.. Those with initials at the beginning of the alphabet are more likely to work in prestigious university departments or ne Nobel winners. Unusual spelling such as `Ashlee` instead of `Ashley` should be avoided. Children who have common names that are traditionally spelt learn `spelling and grammar` faster. The name is one of the first words we learn and if teachers etc. constantly have to ask if they are spelling the name correctly it causes loss of confidence in spelling ability. A third of teachers claimed that they could spot trouble in names like Callum or Chardonnay or Crystal. A study in 1960 found that those with unusual names were more likely to be diagnosed as psychotic and boys with the least popular names are more likely to commit crime. Remember the poor girl who was named `Talula does the Hula from Hawaii`. She has now changed it by deed poll. I remember hearing a mother during the war calling to her child `Come here, Bardia`. Bardia was a town at which there was a battle in the North African Campaign and the name was topical then and maybe had family connection. Even as a kid I pitied that poor child going through life explaining why she was called `Bardia` One last thing. People with surnames at the end of the alphabet are less likely to be succesful than those with surnames at the beginning. I would rate `Crystal` as an oddish name.( nice but oddish) so that combined with your surnames position in the alphabet, you should , statistically and from the career point of view be dead in the Water(s) Cheers and a Merry Christmas Pat (who reads too much rubbish) ________________________________________________________________________________
Date: Dec 23, 2009
- Dana- I typed into web search "ultralight aircraft seat tanks", and cam e up with this: - www.quicksilverultralight.com/other/fuel_tanks.htm#6gallon - P.N. AC#397 - price- $450 (!!!!!!!) - - See if this is what we were looking at.- Maybe you can find it at a ( much) better price. - ------------------------- ------------------------- ------ Bill Sullivan ------------------------- ------------------------- ------ Windsor Locks, Ct. ------------------------- ------------------------- ------ FS 447 ________________________________________________________________________________
Date: Dec 23, 2009
- Dana- Also Calumetair.com - 7.4 gallons, $259 ------------------------- ---------------------- Bill Sul livan ________________________________________________________________________________
Date: Dec 23, 2009
At 09:34 AM 12/23/2009, william sullivan wrote: > Dana- Also Calumetair.com > >7.4 gallons, $259 Bill, the Calumet is the one I'm looking at, and which I posted in the first message. The Quicksilver tank is way too expensive. -Dana -- Sometimes you're the windshield, sometimes you're the bug. ________________________________________________________________________________
Subject: Re: Frapper ( gone )
Date: Dec 23, 2009
Hey Guys, Is "Earl Zimmerman" still around ? He's the one who set up the map with all the Kolbs on it.... There are quite a few... http://www.frappr.com/kolbaircraft It's gonna be lost soon... . . Hey I think I saw his plane switched over to Floats... . . Gotta Fly... Mike & "Jaz" in MN . . . -------- . . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278750#278750 ________________________________________________________________________________
Subject: new videos !!
Date: Dec 23, 2009
Merry Christmas all ! Here are a couple of new videos if you have nothing else to watch ! http://www.youtube.com/watch?v=hBPBgiXT3hk http://www.youtube.com/watch?v=kfyKjEvqTC4 chris ambrose M3X/Jabiru 89.0 hrs N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278756#278756 ________________________________________________________________________________
Subject: Kolb fly'in back in '94
Date: Dec 24, 2009
http://www.youtube.com/watch?v=LG7uLf6RNlE http://www.youtube.com/watch?v=sPI3_E6vSX8 http://www.youtube.com/watch?v=AHLim1FWkK0 Enjoy .... Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 970 hours 23 years flying it Kolbra 912UL N20386 1 year flying it 110 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278791#278791 ________________________________________________________________________________
Subject: Re: Kolb fly'in back in '94
Date: Dec 24, 2009
That's Toooo cold for me to Fly in my Kolb.... My cockpit isn't closed up yet... . . I have a Picture of that Field that you were flying in July... Now there's some flying weather... . . Gotta Fly... . . -------- . . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278797#278797 Attachments: http://forums.matronics.com//files/jaz__mutt_muffs_006_156.jpg http://forums.matronics.com//files/northern_lights_airpark_01_148.bmp http://forums.matronics.com//files/northern_lights_airpark_148.jpg ________________________________________________________________________________
Date: Dec 24, 2009
Subject: Re: new videos !!
Chris, Watched your lake videos and some of your previous postings. Good job. Keep them coming. Merry Christmas everyone! Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 12/23/2009 10:37:37 P.M. Eastern Standard Time, ces308(at)ldaco.com writes: Here are a couple of new videos if you have nothing else to watch ! ________________________________________________________________________________
Date: Dec 24, 2009
Ralph, Yes, I did ENJOY your video postings, even tho they are from 1994, 15 years ago. Thanks. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 12/24/2009 10:21:31 A.M. Eastern Standard Time, ul15(at)juno.com writes: --> Kolb-List message posted by: "Ralph B" http://www.youtube.com/watch?v=LG7uLf6RNlE http://www.youtube.com/watch?v=sPI3_E6vSX8 http://www.youtube.com/watch?v=AHLim1FWkK0 Enjoy .... Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 970 hours 23 years flying it Kolbra 912UL N20386 1 year flying it 110 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278791#278791 ________________________________________________________________________________
Date: Dec 24, 2009
Wow! That is one nice field. Won't matter much which way the wind is blowing. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 12/24/2009 11:46:21 A.M. Eastern Standard Time, planecrazzzy(at)yahoo.com writes: --> Kolb-List message posted by: "planecrazzzy" That's Toooo cold for me to Fly in my Kolb.... My cockpit isn't closed up yet... . . I have a Picture of that Field that you were flying in July... Now there's some flying weather... . . Gotta Fly... . . -------- . . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278797#278797 Attachments: http://forums.matronics.com//files/jaz__mutt_muffs_006_156.jpg http://forums.matronics.com//files/northern_lights_airpark_01_148.bmp http://forums.matronics.com//files/northern_lights_airpark_148.jpg ________________________________________________________________________________
Date: Dec 25, 2009
Thanks, Ralph, for the unexpected Christmas gift. I enjoyed them BECAUSE they are from 15 years ago... back when keeping it light was a higher priority that it seems to be today. -------- Thom Riddle Buffalo, NY Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x31 I have reached an age when, if someone tells me to wear socks, I don't have to. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=278851#278851 ________________________________________________________________________________
From: Chas Knightsbridge <cknightsbridge(at)hotmail.com>
Subject: How are you doing? 5
Date: Dec 25, 2009
Z My friend: I have a wonderful electronics shopping experience on www.eoffar.com I have already bought a lot of goods from it Currently the company is under sales promotion MSN: eoffarservice(at)hotmail.com Email: eoffarservice(at)188.comB _________________________________________________________________ Looking for a great date? Meet singles at ninemsn dating ________________________________________________________________________________
Date: Dec 25, 2009
Subject: Re: How are you doing? 5
Chas, Same message I sent on the Rotax list. Take your spam and stick it. Rick On Fri, Dec 25, 2009 at 1:20 PM, Chas Knightsbridge < cknightsbridge(at)hotmail.com> wrote: > Z > My friend: > I have a wonderful electronics shopping experience on www.eoffar.com > I have already bought a lot of goods from it > Currently the company is under sales promotion > MSN: eoffarservice(at)hotmail.com > Email: eoffarservice(at)188.com > B > ------------------------------ > > * > > * > > ________________________________________________________________________________
Subject: FW: RotaxEngines-List: How are you doing? Z
Date: Dec 25, 2009
Hey Rick=2C I might say the same to your polite comment! Regrettably this is spam that has been generated without my knowledge or pa rticipation. To all others on the group my apologies=2C have a great day and a Prosperou s New Year Chas I use AVG professional as my internet spam protector! Date: Fri=2C 25 Dec 2009 15:54:11 -0600 Subject: Re: RotaxEngines-List: How are you doing? Z From: aslsa.rng(at)gmail.com Hey Chas=2C take your spam and stick it. Rick On Fri=2C Dec 25=2C 2009 at 1:20 PM=2C Chas Knightsbridge wrote: p My friend: I have a wonderful electronics shopping experience on www.eoffar.com I have already bought a lot of goods from it Currently the company is under sales promotion MSN: eoffarservice(at)hotmail.com Email: eoffarservice(at)188.come Check out the latest features today Get more out of Hotmail _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com nk">www.howtocrimp.com _blank">http://www.matronics.com/contribution ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com Check out Domain Radar NOW! A world FIRST in property search has arrived! _________________________________________________________________ Get more out of Hotmail Check out the latest features today http://windowslive.ninemsn.com.au/hotmail/article/878466/your-hotmail-is-ab out-to-get-even-better ________________________________________________________________________________
Subject: winter flight suit
Date: Dec 27, 2009
If anyone is interested, I have a almost brand new helo flight suit. Very, very warm. I used it for a very short time in a Cobra (almost a quicksilver). I stand about 5'7" and it fit perfectly until I got heavier. Still that tall but not 170 lbs any more. It is a 40R for whatever that maters in military terms. Will let it go for a hundred bucks. That is a bargin. It is a whole lot more comfortable and classy than a snow mobile sit and a whole lot warmer. Let me know and I will send more pics or pics if these dont get through. Ted Cowan, Slingshot, 912 ul. ________________________________________________________________________________
From: "Steve Simmons" <stevesimmons(at)charter.net>
Subject: FWD Battery Location
Date: Dec 28, 2009
Does anyone have a good drawing or photos of a fwd battery instillation on a Kolb mark III Classic? ________________________________________________________________________________
Date: Dec 28, 2009
Date: Dec 28, 2009
>Does anyone have a good drawing or photos of a fwd battery instillation on a Kolb mark III Classic? >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> When I first built my mkIII I put the battery forward of the rudder pedals in order to get the cg closer to the center,,,,, found out that it flies better at the aft edge of the cg range. And when I had 2 people on board and the forward cg battery location I would run out of elevator authority. So I moved the battery to just behind the passenger seat. If I were a light weight pilot, I would build a small compartment in the floor to put in a 10 lb bag of shot when flying solo, and take it out if I had a passenger on board. Just my $0.02 worth. Boyd Young Mkiii 912 ul ________________________________________________________________________________
Subject: Re: FWD Battery Location
Date: Dec 28, 2009
I'd never add weight to the nose of a mkIII unless I weighed 75 lbs and flew solo all the time. The weight and balance for a mkIII is not exactly exact..... I'm flying with a 12 lb Maule Tundra Tail Wheel, 150 lbs of fuel in a 25 gal tank behind the cg, plus 125 lbs of personal gear behind cg in the cargo bay. I have aft cg, but it is still within the acceptable, safe flying range. john h mkIII When I first built my mkIII I put the battery forward of the rudder pedals in order to get the cg closer to the center,,,,, found out that it flies better at the aft edge of the cg range. And when I had 2 people on board and the forward cg battery location I would run out of elevator authority. So I moved the battery to just behind the passenger seat. If I were a light weight pilot, I would build a small compartment in the floor to put in a 10 lb bag of shot when flying solo, and take it out if I had a passenger on board. Just my $0.02 worth. Boyd Young Mkiii 912 ul ________________________________________________________________________________
Date: Dec 28, 2009
You guys putting ballast in is why I added the ability to micro-adjust the flaps. By raising or lowering the flaps a very minute amount, you can easily compensate for trim changes that fall outside the factory spring loading arrangement. Here's the link to the pictures, and obviously I radically changed my flap mechanism, but I was also using this same method of setting the flaps before I totally redid the cross tube. http://www.bcchapel.org/pages/0003/pg3.htm Skip the first two pictures on the page and the associated info, that is only for those who want to relocate the whole arrangement. Notice on the next four pictures that I ground off the original side notches and bolted on a curved piece with holes in it for the pin to lock into. You can put the holes where ever you want, and as many or as few as you want. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279048#279048 ________________________________________________________________________________
Date: Dec 28, 2009
-just to be different.... My battery is in front of the rudder pedals and I like it just fine. If you want a pic I would have to dig up a photo CD. BB faked out with a nice day yesterday but woke back up to (white) reality this morning. On 28, Dec 2009, at 10:53 AM, Steve Simmons wrote: > Does anyone have a good drawing or photos of a fwd battery instillation on a Kolb mark III Classic? > > > > ________________________________________________________________________________
Subject: Fwed battery location
Date: Dec 29, 2009
I have attached a .xls file for the weight and balance for my Kolb Mark III, if I put the battery in the aft location it go's so fare aft I don't think I would like to fly it. The problem comes in because of the weight of my Verner 1400 engine. ________________________________________________________________________________
Subject: de gaussing
Date: Dec 29, 2009
Hi, regarding the de gaussing posts of the last couple of weeks. By coincidence, over Christmas, I was reading a book by a pilot in our Fleet Air Arm. Having finished off the war in Europe the Royal Navy were sent to help the Americans wrap up the Pacific. Consequently Victorious, Formidable, Indomitable, Indefatigable, and Illustrious, all carriers, joined the Pacific Fleet and were to carry out a solo operation against Truk. This pilot was just ducking under the wing of an aircraft as it was capulted off when its wooden prop hit the deck, split into pieces and one took nearly all of one leg off. Two years later, in 1947 he was still an outpatient at hospital and had been fitted with an iron caliper.In `48 he was learning to fly again in an Airspeed Oxford, a twin engined trainer, the only plane he could get into with his game leg. To fly he cocked his right leg, with caliper, up on the instrument panel and operated the rudder pedals with his left foot. After getting lost on a couple of simple cross country flights it dawned on him the the caliper was upsetting the compass. Quote. " While I lay on a bed the caliper was taken away and put in a magnetic field. After it had been de-gaussed, all was well and I had no further trouble" A gutsy guy In the Service from the outbreak of war. Involved in Dunkirk, battle of the Med. Taranto raid, Greek campaign, Malta. crashed on a top secret mission trying to land a couple of spies in North Africa. Due to faulty intel. he landed on a salt pan and went through the crust. P o W of the Vichy French (who were supposed to be neutral)but the prisoners were treated terribly with little food or water, thousands of PoW`a together in a camp designed for a couple of hundred in the middle of the Sahara. Ended as Commander with DSO, DSC. Very good read if anyone is interested. Cheers and Happy New Year to all as I am closing down until Jan 5th 2010 Pat ________________________________________________________________________________
Date: Dec 29, 2009
vinyl bag that would hold a 40 lb bag of play sand>> Jeepers! If you really need that much ballast i would suspect that something is seriously out of kilter. I have the battery just behind the passenger seat and about 4lbs of lead in the nose. Lateral inbalance caused by flying without a passenger is taken care of by the Hauk bungee design. Pat ________________________________________________________________________________
Date: Dec 29, 2009
Subject: Re: cowl
Hey Craig you got fancier stuff in your Kolb than I have in my Sierra, (the new GPS 696 is a loaner). LOL. Ron @ Sierra Vista. =========================== ---- "Nelson wrote: ============ <> Uncle Craig/Gang: Get that MKIII put back together and flying. MV will be here before you know it, 5 months on my Alabama calendar. John Good to hear from you Its going together John... I've messed around 4 8 years and it is time to fly. I know I don't need an artificial horizon in Arizona or any where I would fly ..but it just looked aircrafty. Had to have it. My exhaust is the titan one you had before. mine has a different muffler. Ya I did have trouble with it... it was welded up by a motor cycle guy rather than the welder that did my tank, he was too busy to weld the muffler and I should have waited for him... the welds the motor cycle guy did not penetrate and he ground most of what was, off... the back of the muffler and exhaust tube went through the prop slamming it into the flap. ... I wonder if the new titan one would fit under my cowl...I admire Rick for his project those things get a guy going... I had fun doing all the stuff I did to my plane, the reason I did it was because I can..... Not really to improve the design....I did it because I like the way it looks. The kolb design to me is the spirit of true flight. Great visibility!!!closest thing to a helicopter without the maintenance or disk, slow enough to have fun, fast enough to go across the country and almost vertical takeoff and landing...but john I have to tell ya, you and lots of other guys are doing it...FLYING AND ENJOYING Your Kolbs .....it's time to stop the tinkering and fly!! I like your KISS rule I could have been flying...let's see what we can do at MV... I'll race you for breakfast....if I don't fly to MV this year I'm not going Uncle craig 15 hrs flying 2,000,000 hrs fussing, tinkering and building--enough is enough -- kugelair.com ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Dec 29, 2009
I have my battery installed in the nose of my MKIIIC. My VW required by the numbers that the battery be moved. My battery is a light 12AH lawn mower battery. When I installed my first redrive VW engine it was mounted so high that I had seven inches of clearance between the 72 inch prop and the boom tube. My first 150 lb. passenger required me to hold full up elevator to climb with power (not good). For a while I added a steel weight to the tail wheel strut. Later on a cross country I found that the aft CG caused by the tail weight caused the plane to be almost uncontrollable in heavy turbulence. Removing the weight made a significant improvement. I have since lowered the engine but haven't flown with more than a 160 lb. passenger yet. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: pj.ladd To: kolb-list(at)matronics.com Sent: Tuesday, December 29, 2009 12:01 PM Subject: Re: Kolb-List: FWD Battery Location vinyl bag that would hold a 40 lb bag of play sand>> Jeepers! If you really need that much ballast i would suspect that something is seriously out of kilter. I have the battery just behind the passenger seat and about 4lbs of lead in the nose. Lateral inbalance caused by flying without a passenger is taken care of by the Hauk bungee design. Pat ________________________________________________________________________________
Date: Dec 29, 2009
I have attached a .xls file for the weight and balance for my Kolb Mark III, if I put the battery in the aft location it go's so fare aft I don't think I would like to fly it. The problem comes in because of the weight of my Verner 1400 engine. From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Steve Simmons Sent: Tuesday, December 29, 2009 10:11 AM Subject: Kolb-List: Fwed battery location I have attached a .xls file for the weight and balance for my Kolb Mark III, if I put the battery in the aft location it go's so fare aft I don't think I would like to fly it. The problem comes in because of the weight of my Verner 1400 engine. ________________________________________________________________________________
Date: Dec 29, 2009
Subject: Re: Fwed battery location
Date: Dec 29, 2009
we have the message steve. On 29, Dec 2009, at 5:06 PM, Steve Simmons wrote: > I have attached a .xls file for the weight and balance for my Kolb Mark III, if I put the battery in the aft location it go's so fare aft I don't think I would like to fly it. The problem comes in because of the weight of my Verner 1400 engine. > > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Steve Simmons > Sent: Tuesday, December 29, 2009 10:11 AM > To: Kolb List > Subject: Kolb-List: Fwed battery location > > I have attached a .xls file for the weight and balance for my Kolb Mark III, if I put the battery in the aft location it go=92s so fare aft I don=92t think I would like to fly it. The problem comes in because of the weight of my Verner 1400 engine. > ________________________________________________________________________________
Subject: Re: de gaussing
Date: Dec 29, 2009
I remember reading a book about Douglas Bader (Dogs Body) when I was back in middle school. Wasn't him, by any chance? (Been too long, forgot the details) Richard Pike MKIII N420P (420ldpoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279184#279184 ________________________________________________________________________________
Date: Dec 30, 2009
No ,Ii don't think so , Douglas Bader lost both legs in a flying incident doing something he had been told not to in a bulldog I think . He over come that and carried on to fly spitfires and hurricanes, he was POW and continued to be a PITA for his captors , ended up in colditz. As fare as I know he never served on a carrier or in the Pacific conflict Sorry some may not see this as kolb related but these are the aviators that gave us all the inspiration to test flight Downonder Kolb MK111c Regards to all Have a happy and prosperous new year and may the weather gods be kind to you all ----- Original Message ----- From: "Richard Pike" <richard(at)bcchapel.org> Sent: Wednesday, December 30, 2009 5:55 PM Subject: Kolb-List: Re: de gaussing > > I remember reading a book about Douglas Bader (Dogs Body) when I was back > in middle school. Wasn't him, by any chance? (Been too long, forgot the > details) > > Richard Pike > MKIII N420P (420ldpoops) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=279184#279184 > > > ________________________________________________________________________________
Date: Dec 30, 2009
YUP. If you try to compensate for a high thrust line (nose down-force) with added tail weight, you can quickly get into big trouble. When doing modifications, skipping W & B is not an option. What was that old saying about tuning 2-cycle racing engines? That they sound best right before they blow up? Yes, the plane flies better with aft CG but going too far brings on stability and stall recovery problems. Dont exceed the aft CG limit. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279214#279214 ________________________________________________________________________________
Subject: Re: 447 problem
Date: Dec 30, 2009
John Hauck wrote: > > No one is questioning your experience, but 10 years is not relative when it > comes to operating an engine. If you want to impress the Kolb List with > your experience, then you need to express it in hours, not years. > > I have no desire to verify your experience, but it would help if you express > it so we can understand it. > > john h > mkIII All, I've resumed monitoring the list as there's too much good information here and good folks to ignore it. John H., whatever problems you have with me and my experience, I'd suggest being adult about it and take them to PM with me. I won't respond to the comments anymore on the list. Plus, to make this Kolb related, I'm still kicking the idea of a Firefly around as a second plane. But it appears Rotax has quit making the 447, even tho the distributors are still listing them Rotax themselves don't post it as an engine they sell anymore. Anyone know the scoop on this? Thanks, LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279227#279227 ________________________________________________________________________________
Date: Dec 30, 2009
Subject: Re: 447 problem/stopping production..
Date: Dec 30, 2009
> I've resumed monitoring the list as there's too much good information her e and good folks to ignore it. > Lucien Lucien=2C Glad to see you're back. Now=2C don't piss me off. hehehe : ) Happy New Year!!!! BTW=2C can't help much with your 447 question. I'm one of the non-Rotax heretics. Mike Welch MkIII CX _________________________________________________________________ Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. ________________________________________________________________________________
Date: Dec 30, 2009
Happy New Year - You too Dennis. i don`t know how deep you went in but this guy threw a bicycle from where it was lashed to the interplane struts and in sank beneath the surface. I know you are just begging to know what a plane was doing with the bike tied on the wing. The plane was a Swordfish, a radial engined torpedo bomber with a top speed of about 90. A biplane with a crew of 3, in 2 open cockpits. The mission was to insert an Arab sheik and a Frenchman into North Africa as spies. The bike was for their use. Both of them turned up at the PoW camp some months later. The Swordfish was affectionately known as the `Stringbag`. Accent on the first syllable NOT String Bag`. The book is `To war in a Stringbag` by Charles Lamb. A fascinating insight into a very different sort of war than we have now. Note that the top speed was about that of a flat out, balls to the wall, Kolb Mk3. Hows that for a Kolb connection? Cheers Pat ________________________________________________________________________________
Date: Dec 30, 2009
Douglas Bader (Dogs Body)> Hi Richard, no it wasn`t. Bader was RAF and started the war with no legs. Also I don`t thinkthere is enough room to put your feet up on the instrument panel in a Spitfire. Bader was shot down by ground fire attacking ground targets in France. He was a PoW in `Colditz`. I am surprised that the German visitors do not know anything about the castles use as a high security camp. Perhaps Americans don`t either. Anyone interested contact me off list. The guy in my story was Navy and flew an obsolete torpedo bomber called the Swordfish. He was wounded after VE day. Cheers Pat ________________________________________________________________________________
Date: Dec 30, 2009
Lucien, like a moth returning to the flame? :) Jack Hart is your source for FF opinions. -at least I would consider him so. Also, like him, I don't think the FF really needs all the power that the 447 has. Getting over the trees is good enuf. I would contemplate one of them too if regulations for experimentals suddenly became too onerous. BB On 30, Dec 2009, at 11:19 AM, lucien wrote: > > > John Hauck wrote: >> >> No one is questioning your experience, but 10 years is not relative when it >> comes to operating an engine. If you want to impress the Kolb List with >> your experience, then you need to express it in hours, not years. >> >> I have no desire to verify your experience, but it would help if you express >> it so we can understand it. >> >> john h >> mkIII > > > All, > > I've resumed monitoring the list as there's too much good information here and good folks to ignore it. > > John H., whatever problems you have with me and my experience, I'd suggest being adult about it and take them to PM with me. I won't respond to the comments anymore on the list. > > Plus, to make this Kolb related, I'm still kicking the idea of a Firefly around as a second plane. But it appears Rotax has quit making the 447, even tho the distributors are still listing them Rotax themselves don't post it as an engine they sell anymore. > > Anyone know the scoop on this? > > Thanks, > LS > > -------- > LS > Titan II SS > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=279227#279227 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 30, 2009
[quote="mdnanwelch7(at)hotmail.co"]>I've resumed monitoring the list as there's too much good information here and good folks to ignore it. > Lucien > > Lucien C Glad to see you're back. Now C don't piss me off. hehehe : ) Happy New Year!!!! BTW C can't help much with your 447 question. I'm one of the non-Rotax heretics. Mike Welch MkIII CX Your E-mail and More On-to/171222985/direct/01/' target='_new'>Sign up now. > [b] Hey Mike, Ok, was just wondering if anyone knew offhand. no biggie as I need to order parts for the upcoming annual on my plane from lockwood and titan so I'll ask at that time. Last I spoke to lockwood, they said Rotax intended to support any of the engines they may discontinue for 10 years. But if the 447 is out of production, I guess I'd have to make a decision fairly quickly and snap one up before they disappear. I want a 103 plane and the Firefly looks like it's about at the top of the heap. The other choice is my beloved fun racer trike, but it has some drawbacks the Kolb doesn't have.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279236#279236 ________________________________________________________________________________
Date: Dec 30, 2009
[quote="slyck(at)frontiernet.net"]Lucien, like a moth returning to the flame? :) Jack Hart is your source for FF opinions. -at least I would consider him so. Also, like him, I don't think the FF really needs all the power that the 447 has. Getting over the trees is good enuf. I would contemplate one of them too if regulations for experimentals suddenly became too onerous. BB On 30, Dec 2009, at 11:19 AM, lucien wrote: [quote] Ok, sounds good. I live at a high altitude where every engine becomes the model under it in terms of power (i.e. a 503 is about a 447, my 912uls is about a 912ul, etc). My 503 powered FSII managed about 300 fpm here before I sold it. I want to go 103 if I get another plane, I already pay too much in insurance and annuals on the big one. Can't think of a better option than the firefly overall, so that's what I'm looking at. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279240#279240 ________________________________________________________________________________
Date: Dec 30, 2009
Date: Dec 30, 2009
> John Hauck wrote: >> >> No one is questioning your experience, but 10 years is not relative when >> it >> comes to operating an engine. If you want to impress the Kolb List with >> your experience, then you need to express it in hours, not years. >> >> I have no desire to verify your experience, but it would help if you >> express >> it so we can understand it. >> >> john h >> mkIII > > > All, > > I've resumed monitoring the list as there's too much good information here > and good folks to ignore it. > > John H., whatever problems you have with me and my experience, I'd suggest > being adult about it and take them to PM with me. I won't respond to the > comments anymore on the list. > > Thanks, > LS Lucien/Gang: Welcome back to the Kolb List. Was the above really necessary? john h mkIII ________________________________________________________________________________
Date: Dec 30, 2009
John Hauck wrote: > > Lucien/Gang: > > Welcome back to the Kolb List. > > Was the above really necessary? > > john h > mkIII Good to be back. Yes, the clarification was necessary. I will only accept PM's if you need to discuss it further. I won't respond on the list and confining my comments here only to Kolb/Kolb engine related material. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279255#279255 ________________________________________________________________________________
Subject: Re: FWD Battery Location....reply
Date: Dec 30, 2009
I agree that the Kolb Mark III will fly better with an aft CG. I have flown it at 33% and 28%. It gets busy at 33% in rough weather. Does anyone know the CG limits? I assume that it is around 25% to 31%. ________________________________________________________________________________
Date: Dec 30, 2009
16.5 FWD 23.1 AFT for Mark IIIC -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of apilot(at)surewest.net Sent: Wednesday, December 30, 2009 1:19 PM Subject: Re: Kolb-List: Re: FWD Battery Location....reply I agree that the Kolb Mark III will fly better with an aft CG. I have flown it at 33% and 28%. It gets busy at 33% in rough weather. Does anyone know the CG limits? I assume that it is around 25% to 31%. ________________________________________________________________________________
Date: Dec 30, 2009
tumultuous air will reveal weaknesses in balance better than any method. A properly balanced airplane will endure a sudden blast upwards with a nice straightforward (level) attitude. I have flown planes like that. My MkIII is not so well blessed. I'm speaking, obviously, of a column that uniformly boosts yer butt upward, not a little dinky thing like ones that lift one wing independently. Aside from any other problem with this is the necessity of messing with throttle settings too much. I'm a lazy pilot who prefers to just amble along and look out the winders. What is the consensus? do you end up with your nose down or up? BB On 30, Dec 2009, at 4:36 PM, Steve Simmons wrote: > > 16.5 FWD 23.1 AFT for Mark IIIC > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of > apilot(at)surewest.net > Sent: Wednesday, December 30, 2009 1:19 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: FWD Battery Location....reply > > > I agree that the Kolb Mark III will fly better with an aft CG. I have flown > it at 33% and 28%. It gets busy at 33% in rough weather. Does anyone know > the CG limits? I assume that it is around 25% to 31%. > > > > > > > > ________________________________________________________________________________
Date: Dec 30, 2009
Here's a bit more detailed spread sheet built up from one offered by another lister (sorry, I don't remember who or I'd credit you) Happy New Year and lots of good flying in the coming year. Even you, JP :-} Rick On Wed, Dec 30, 2009 at 3:36 PM, Steve Simmons wrote: > > > > 16.5 FWD 23.1 AFT for Mark IIIC > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of > apilot(at)surewest.net > Sent: Wednesday, December 30, 2009 1:19 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: FWD Battery Location....reply > > > I agree that the Kolb Mark III will fly better with an aft CG. I have > flown > it at 33% and 28%. It gets busy at 33% in rough weather. Does anyone know > the CG limits? I assume that it is around 25% to 31%. > > ________________________________________________________________________________
Date: Dec 30, 2009
John /list please excuse my ignorance but what does PM mean?=0A-Chris Dav is=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from crash building Firefly =0A=0A=0A=0A=0A________________________________=0AFrom: John Hauck <jhauck@ elmore.rr.com>=0ATo: kolb-list(at)matronics.com=0ASent: Wed, December 30, 2009 12:34:26 PM=0ASubject: Re: Kolb-List: Re: 447 problem=0A=0A--> Kolb-List m essage posted by: "John Hauck" =0A=0A> John Hauck wro te:=0A>> =0A>> No one is questioning your experience, but 10 years is not r elative when it=0A>> comes to operating an engine.- If you want to impres s the Kolb List with=0A>> your experience, then you need to express it in h ours, not years.=0A>> =0A>> I have no desire to verify your experience, but it would help if you express=0A>> it so we can understand it.=0A>> =0A>> j ohn h=0A>> mkIII=0A> =0A> =0A> All,=0A> =0A> I've resumed monitoring the li st as there's too much good information here and good folks to ignore it. =0A> =0A> John H., whatever problems you have with me and my experience, I' d suggest being adult about it and take them to PM with me. I won't respond to the comments anymore on the list.=0A>=0A> Thanks,=0A> LS=0A=0A=0ALucien /Gang:=0A=0AWelcome back to the Kolb List.=0A=0AWas the above really necess =========================0A ==================0A=0A=0A ________________________________________________________________________________
Date: Dec 30, 2009
herbgh(at)nctc.com wrote: > Well I called CPS (only place still open) and they said they hadn't heard anything about the 447 going out of prod. They said there'd have been a press release about it and so on... May still have to think about snapping one up pretty soon tho anyway just to have one ;) LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279305#279305 ________________________________________________________________________________
Date: Dec 30, 2009
Chris I was in the same boat! -- been told it's "Private Message" Russ On Dec 30, 2009, at 5:33 PM, chris davis wrote: > John /list please excuse my ignorance but what does PM mean? > > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly > > > From: John Hauck <jhauck(at)elmore.rr.com> > To: kolb-list(at)matronics.com > Sent: Wed, December 30, 2009 12:34:26 PM > Subject: Re: Kolb-List: Re: 447 problem > > > > John Hauck wrote: > >> > >> No one is questioning your experience, but 10 years is not > relative when it > >> comes to operating an engine. If you want to impress the Kolb > List with > >> your experience, then you need to express it in hours, not years. > >> > >> I have no desire to verify your experience, but it would help if > you express > >> it so we can understand it. > >> > >> john h > >> mkIII > > > > > > All, > > > > I've resumed monitoring the list as there's too much good > information here and good folks to ignore it. > > > > John H., whatever problems you have with me and my experience, > I'd suggest being adult about it and take them to PM with me. I > won't respond to the comments anymore on the list. > > > > Thanks, > > LS > > > Lucien/Gang: > > Welcome back to the Kolb List. > > Was the above reallnbsp; * AeroElectric www.buildersbookres > =========== > > ________________________________________________________________________________
Date: Dec 30, 2009
Russ , thank you I thought it might be some aircraft or pilot lingo I was i gnoant of!=0A-Chris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled fro m crash building Firefly =0A=0A=0A=0A=0A________________________________=0A From: russ kinne <russkinne(at)mac.com>=0ATo: kolb-list(at)matronics.com=0ASent: Wed, December 30, 2009 6:30:45 PM=0ASubject: Re: Kolb-List: Re: 447 problem =0A=0AChris =0AI was in the same boat! -- been told it's "Private Message" =0ARuss=0A=0A=0AOn Dec 30, 2009, at 5:33 PM, chris davis wrote:=0A=0AJohn / list please excuse my ignorance but what does PM mean?=0A>-Chris Davis=0A >KXP 503 492 hrs=0A>Glider Pilot=0A>Disabled from crash building Firefly =0A>=0A>=0A>=0A>=0A>=0A________________________________=0AFrom:-John Hauc k =0A>To:-kolb-list(at)matronics.com=0A>Sent:-Wed, D ecember 30, 2009 12:34:26 PM=0A>Subject:-Re: Kolb-List: Re: 447 problem >=0A>=0A>> John Hauck wrote:=0A>>>-=0A>>> No one is questioning your expe rience, but 10 years is not relative when it=0A>>> comes to operating an en gine.- If you want to impress the Kolb List with=0A>>> your experience, t hen you need to express it in hours, not years.=0A>>>-=0A>>> I have no de sire to verify your experience, but it would help if you express=0A>>> it s o we can understand it.=0A>>>-=0A>>> john h=0A>>> mkIII=0A>>-=0A>>- =0A>> All,=0A>>-=0A>> I've resumed monitoring the list as there's too muc h good information here and good folks to ignore it.=0A>>-=0A>> John H., whatever problems you have with me and my experience, I'd suggest being adu lt about it and take them to PM with me. I won't respond to the comments an ymore on the list.=0A>>=0A>> Thanks,=0A>> LS=0A>=0A>=0A>Lucien/Gang:=0A>=0A >Welcome back to the Kolb List.=0A>=0A>Was the above reallnbsp; * AeroElect ric-www.buildersbookres =============0A>=0A>=0A> =0A>=0A>=0A>=0A>=0A>color="#000000" face="courier new,courier">www.aero electric.com=0A>href="http://www.buildersbooks.com">www.buildersbooks.com =0A>href="http://www.homebuilthelp.com">www.homebuilthelp.com=0A>href=" http://www.howtocrimp.com">www.howtocrimp.com=0A>href="http://www.matroni cs.com/contribution">http://www.matronics.com/contributionhref="http://ww w.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kol b-Listhref="http://forums.matronics.com">http://forums.matronics.com=0A> =0A>=0A>=0A=0A=0A=0A ________________________________________________________________________________
Date: Dec 30, 2009
Subject: Electrical Switch Location
I'm trying to decide where to put my elec switches on my Mk III. I don't want to put them on the instrument panel (too far to reach). I like how Steve Green built a box for switches/fuses/accessories on the floor between his legs. Unfortunately, that won't work for me because I've got dual controls and the box would interfere with the control stick. But I'm thinking of mounting something overhead. Anyone had any experience with that? Thanks in advance for your ideas. Mark Rinehart MkIII Indianapolis ________________________________________________________________________________
Subject: degoussing air frame
Date: Dec 30, 2009
>Anybody else got a simple explanation to answer my question, "Will the >degausser damage my electric engine instruments?" >john h - John Thoughts according to Boyd,,, I am not sure but I think I would remove them before trying, this is why. When you pass a magnetic field over coils of wire you have a transformer that will create an electrical current in the instruments, the degausser will be the transformer primary coil and the instrument the secondary coil. If the current is sufficient to slam the gages, it may cause internal damage or change the accuracy, the more sensitive the movement the more chance for damage. The pressure type gages should be ok, but anything with an electrical movement may be compromised as the movements work on a magnetic field. This is my thoughts. The rest of this info came from a friend at an old tv repair shop. (maybe should say old friend at a tv shop) To find out how far away you need to be to not do any damage take an old crt tv and start the degausser at a 90 deg angle to the set at least 8 ft away, turn it at the set and as you get closer watch the set until you see changes in the picture. He said a picture with the most red color showing would be best. When you are finished go back to the 8 foot area and then turn it back to 90 deg before turning it off. When degaussing a tv he mentioned that they were never concerned about destroying the speaker in the set. And a permanent magnet is very hard to degausse. I asked about coils in the engine and HE DID NOT THINK it would be a problem. While degaussing old tv sets he said that he was never concerned with the proximity of the degausser to his electronic equipment. Ie: oscilloscopes, signal generators, digital meters. Although there are some coils in these products the edi currents created have not caused any problems. He has volunteered to do some test with an analog multi meter and let me know the results. Also he will check with some of his students that work at hill AFB and see if they can shed more light on the matter and I will post to the list. Hope this helps.. and sorry it took so long to contact my friend. Boyd Ok my friend just got back with me. He took an old analog meter and tested it against an extremely good digital meter using a known voltage supply with a good voltage regulator. After recording the first set of data he proceeded to degauss the analog meter with a quote " heavy magnetic field" multiple times. He then retested the meter against the digital and known voltage source and could see no differences. From his testing it is his opinion that degaussing the airframe should cause no damage to analog or digital devices. Ok now go back and erase the first paragraph, thoughts according to boyd. Guess my thoughts were a bit cautious. Boyd Young KOLB MKIII Utah ________________________________________________________________________________
Date: Dec 30, 2009
I'm trying to decide where to put my elec switches on my Mk III. I don't want to put them on the instrument panel (too far to reach). I like how Steve Green built a box for switches/fuses/accessories on the floor between his legs. Unfortunately, that won't work for me because I've got dual controls and the box would interfere with the control stick. But I'm thinking of mounting something overhead. Anyone had any experience with that? Thanks in advance for your ideas. Mark Rinehart MkIII Indianapolis >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>. http://www.brigham.net/~byoung/gapseal.html not a very good picture,,, but the last picture. boyd ________________________________________________________________________________
Subject: Merry Christmas ?
Date: Dec 31, 2009
Hey Guys, Best way to git whatcha want fer Christmas...? Git it yerself.... Ho ho ho I got Mine.... Found a 0-235 Lycoming ( 118 HP ) and all the "Logs" since new... 900 hrs before TBO Only 4 hrs away in Iowa.... ( $3,300 ) . . Gotta Fly... Mike & "Jaz" in MN . . PS Also Got a Spinner as a Bonus... . Everything is off a Cessna 152.. . . .. -------- . . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279369#279369 Attachments: http://forums.matronics.com//files/lycoming_0_235_l2c_005_186.jpg http://forums.matronics.com//files/lycoming_0_235_l2c_012_199.jpg http://forums.matronics.com//files/lycoming_0_235_l2c_013_135.jpg ________________________________________________________________________________
Date: Dec 31, 2009
This was where the prisoners managed to construct a 2 seat glider to be used in an escape attempt.>> Hi Dana, that glider was rebuilt for a BBC programme and it flew with several of the Colditz glider builders looking on. They were tickled pink that it had actually worked. IThe design was in fact very like the German `Grunau` on which I went solo on 21st March 1965. 3 whole minutes flying with 4 minutes on my second flight. You can tell what the glide angle was like as those launches were on the wire probably to 1000 ft. About the same as a Kolb i guess. Any glider pilot before the war would have known of the Grunau so not really surprising that they built it that shape. Happy New Year Pat ________________________________________________________________________________
Date: Dec 31, 2009
I'm speaking, obviously, of a column that uniformly boosts yer butt upward, not a little dinky thing like ones that lift one wing independently.>> Hi Robert, How do you find those nice big, fat smooth thermals that lift the whole plane on the level?. I have found those condition in the middle of a thermal (sometimes) but I have usually had to go through the `one wing lifting` bit to get there. Cheers Pat ________________________________________________________________________________
Date: Dec 31, 2009
apilot(at)surewest.net wrote: > I agree that the Kolb Mark III will fly better with an aft CG. I have flown it at 33% and 28%. It gets busy at 33% in rough weather. Does anyone know the CG limits? I assume that it is around 25% to 31%. My Firestar II builders manual states that CG limits are between 20 and 35 % of wing chord. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279380#279380 ________________________________________________________________________________
Date: Dec 31, 2009
I have two locations for my switches in the Mark 111. Some of them are loca ted overhead in the foward part of the gap cover and the others that I use most are in a long narrow panel (3" wide alum U shaped extrusion) which con nect to the dash and cable guides between the seats. The master=2C 2 fuel p umps (main & reserve) and switch to show the fuel levels in each tank are i n the ceater all other are located over head and easy to reach. > Date: Wed=2C 30 Dec 2009 19:49:28 -0800 > From: capt_riney(at)yahoo.com > Subject: Kolb-List: Electrical Switch Location > To: kolb-list(at)matronics.com > > > I'm trying to decide where to put my elec switches on my Mk III. I don't want to put them on the instrument panel (too far to reach). I like how Ste ve Green built a box for switches/fuses/accessories on the floor between hi s legs. Unfortunately=2C that won't work for me because I've got dual contr ols and the box would interfere with the control stick. But I'm thinking of mounting something overhead. Anyone had any experience with that? Thanks i n advance for your ideas. > > Mark Rinehart > MkIII Indianapolis > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: degoussing air frame
Date: Dec 31, 2009
Regarding degaussing, I had some success degaussing the airframe on my titan with my Radio Shack soldering iron with the tip removed. It's a big gun-style of about 100 watts, the main coil makes a fairly big 60hz alternating magnetic field. It's also a lot weaker than tape erasers or the big industrial degaussers, so I was able to keep it away from my instruments, just running it over the tubing. Took a while, but since I already had the iron it was free and it seemed to work pretty good. Just a thought, LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279385#279385 ________________________________________________________________________________
Date: Dec 31, 2009
Pat, if you fly low through the big hills south of here in the summertime you will definitely get more than one or two big lifts. You will be busy opening and closing the throttle to avoid overspeed, followed immediately by near stall and cranking the stick like a butter churn. Yes, I know, fly higher, but you have to start low to get there. I experienced my first aileron flutter in those conditions three years ago. Airspeed can leap to 90 in an instant. BB On 31, Dec 2009, at 7:40 AM, pj.ladd wrote: > > I'm speaking, obviously, of a column that uniformly boosts yer butt upward, > not a little dinky thing like ones that lift one wing independently.>> > > Hi Robert, > How do you find those nice big, fat smooth thermals that lift the whole plane on the level?. I have found those condition in the middle of a thermal (sometimes) but I have usually had to go through the `one wing lifting` bit to get there. > > Cheers > > Pat > > > > > > ________________________________________________________________________________
Date: Dec 31, 2009
Hi Boyd/Gang: Thanks for the info. Would be nice to have an accurate mag compass, but I doubt I will ever do anything with it. I can keep myself on a straight heading, without knowing exactly what that heading is, and eventually find a land mark to get me to an airport or some other suitable landing site if need be. john h From Ok my friend just got back with me. He took an old analog meter and tested it against an extremely good digital meter using a known voltage supply with a good voltage regulator. After recording the first set of data he proceeded to degauss the analog meter with a quote " heavy magnetic field" multiple times. He then retested the meter against the digital and known voltage source and could see no differences. From his testing it is his opinion that degaussing the airframe should cause no damage to analog or digital devices. Boyd Young KOLB MKIII Utah ________________________________________________________________________________
Date: Dec 31, 2009
Probably need to qualify my comment below. My mag compass is correct at one heading of the compass rose, then gets progressively worse, up to a 90 degree error. However, unless in extreme turbulence, it is relatively steady, allowing me to fly an unknown heading without flying in circles. john h mkIII I can keep myself on a straight heading, without knowing exactly what that heading is, and eventually find a land mark to get me to an airport or some other suitable landing site if need be. ________________________________________________________________________________
Subject: Re: Electrical Switch Location
Date: Dec 31, 2009
From: "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil>
Mark Rinehart wrote: << I'm trying to decide where to put my elec switches on my Mk III. Anyone had any experience with that? Thanks in advance for your ideas. >> Hi, Mark - You are not the first Kolb builder to discover that your panel space is limited! For my Mark-3, I built an auxiliary panel located on the aluminum floor panel just beneath the passenger's knees. It was simpler than one would think. Just forward to the front edge of the seat is the aluminum sheet metal floor pan. It slopes at approx 45 degrees at this location, then becomes level for the rest of the floor area up to the rudder pedals. It was in the sloped portion of the pan where I built the auxiliary panel. I cut out a recess - approx 4 x 10 inches - and reinforced it to hold a panel containing all my switches. On this panel are my master switch, starter button, elec fuel pump switch, strobe switch, a 12v power jack (cigar plug style, to power my GPS or handheld radio), and a fuse panel. For that, I used a 2 x 3 inch automotive fuse panel that has six slots for blade-style fuses, which I bought at Pep Boys. That was all the fuses I needed for my Kolb. Because the panel face itself is recessed, the switches are safely out of the way of feet, as your passenger climbs in & out of the airplane. I cannot actually see this auxiliary panel from my seated position in the plane, but I can reach all the switches easily with my right hand. I know all the locations of the switches by feel. If I had a picture of it, I would attach it with this message. Picture = a thousand words, etc. Next time I visit my Kolb, I'll take a picture of my auxiliary panel and post it here. It was a VERY worthwhile modification, and it works great! Dennis Kirby Sandia Park, NM Mark-III, 912ul, Powerfin-72 (the "old" style black variety) ________________________________________________________________________________
Date: Dec 31, 2009
Do not have a picture of the forward battery box, but the task was made easier by cutting an access hole in the top of the nose cone with a removeable hatch cover. It is handy for servicing the antenna wiring, the nose ballast and the back of the instrument panel. Vic Mk IIIC ________________________________________________________________________________
Date: Jan 01, 2010
My two mag switches, aux fuel pump switch and starter switch are located at the front of the seat just below and outside my legs. The two separate mag switches I reach blind with my left hand. The aux fuel pump switch and momentary contact starter toggle switch are operated blind with my right hand. Everything else in on the tiny SS panel which I don't need access to in flight except the landing lights which I can reach with harness on. The EIS controls and elevator trim as well as PTT are on the stick. -------- Thom Riddle Buffalo, NY Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x31 I have reached an age when, if someone tells me to wear socks, I don't have to. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=279581#279581 ________________________________________________________________________________
Date: Jan 01, 2010
Mark=2C There are lots of places where you could locate some switches=2C such as overhead=2C below your knees=2C and on some center console=2C but how about the following?.......... How about considering another very easy accessible place for those switch es=2C etc? Why not mount them on a custom made pod on the door? Back when I had a MkIII Classic front end (before my Xtra conversion)=2C I had mounted the engine throttle on the flip-up door. It worked perfect =2C felt comfortable=2C and swung out of the way when you get in and out. Ok=2C but those doors are now gone! Now that my (new) doors are the Xtra style doors=2C I remade the "door-mo unted throttle" to work with my new style doors. Still works great=2C and everything swings out of the way=2C to get in and out. Now=2C regarding your question: Why not make an instrument/switch pod th at mounts to your door? You could make it out of fiberglass (real easy pro ject)=2C or aluminum (not my preference). This pod could incorporate an ar mrest=2C door handle=2C and flow into an instrument pod. The above door pod suggestion is something I've been kicking around for a while. I just got back home a couple of days ago from Minneapolis=2C visit ing with my oldest son. I used our brand new Garmin Nuvi=2C and I made a s pecial note of where the GPS is most useful and comfortable to use. For me=3B A) I need it low=2C so I can see it properly with reading glasses. B) I need it close=2C about 20" max. Anything further than that=2C and I can't push the touch-screen with ANY accuracy. Therefore=2C with these parameters in mind=2C I've decided to build (out of fiberglass) a custom GPS pod/armrest=2C that will place the GPS where it w ill be the most useful=2C on the door. The GPS's final location would be a bout centered in front of me=2C about 15" in front of my stomach area. (abo ut where you'd hold a magazine to read) The pod would hold one of those GP S panel docks=2C the kind that the Garmin 296 just pops into. (the brand es capes me=2C at the moment). Just a suggestion=2C Mike Welch MkIII CX _________________________________________________________________ Hotmail: Powerful Free email with security by Microsoft. ________________________________________________________________________________
Subject: Monument Valley 2010
Date: Jan 01, 2010
Morning Gang: Time to start thinking about the 8th Annual Kolb Unplanned/Unorganized Flyin, Monument Valley, Utah, 2010. How's that? The title is as long as the flyin. Mother's Day 2010 is 9 May. Memorial Day is the last Monday, 31 May. Normally we plan on having our flyin the weekend between Mother's Day and Memorial Day. However, this year there are two weekends in between. If you plan on attending, let me know which weekend you prefer: a. 14-16 May b. 21-23 May Based on that info, we'll make a decision on which date to go with. A lot of us shoot to arrive on Thursday before the official start date on Friday, depending on the flying weather. If you haven't attended one of our flyins, you should. You are missing out on what we feel is the best flyin anywhere for Kolb aircraft and Kolb people. Monument Valley is a perfect place for this kind of get together. If you flyin, there is a 4000 foot paved airstrip, auto fuel across the road from the airstrip, beautiful RV Park with a designated area for tent camping, where most of us camp. If drive, there is a nice lodge and also individual cabins and duplexes. There is also a nice restaurant and a grocery store for food and supplies. The convenience store also has fast food available and less expensive than the restaurant. If we luck out, maybe Uncle Craig and Tim will bring their rolling kitchen and cook breakfast for us. ;-) Take care, john h mkIII ________________________________________________________________________________
Date: Jan 01, 2010
Mike W/Gang: Wish I had the motivation to make all those changes. I kept all the switches along the bottom right of the instrument panel in front of me. Circuit breakers on the left side along the bottom of the instrument panel. I wear my shoulder harness loose enough to be able to reach the switches. If I need to pull or push a circuit breaker, takes a second to loosen the shoulder harness a little more to reach them. Normally, never have to recycle a breaker. I did fabricate a sheet metal panel which I shock mounted an inch or so nearer the seats. My Garmin GPS is worn on my left thigh with a 2" velcro leg strap because I did not have room on the panel to mount it. Glad I didn't have room on the panel because I like it better on my leg. I wear bifocals and can easily see the gps and operate it. A slight disadvantage of wearing on my thigh is having to look down farther than if it was panel mounted. As my vision slowly deteriorates, I doubt I could see it well enough to use if it was mounted on the panel. Being comfortable in the cockpit and keeping it simple is of primary importance to me. Weather is lousy in Alabama, cold and wet. When the sun comes out it will be cold, low 40s. Happy and healthy new year, folks! Yippee! 4.5 months until time to fly to MV. john h mkIII There are lots of places where you could locate some switches, such as overhead, below your knees, and on some center console, but how about the following?.......... A) I need it low, so I can see it properly with reading glasses. B) I need it close, about 20" max. Anything further than that, and I can't push the touch-screen with ANY accuracy. Just a suggestion, Mike Welch ________________________________________________________________________________
Date: Jan 01, 2010
Subject: A little humor for the New Year
I don't particularly like crash videos, but this one had a good outcome for the pilot, or so I've been led to believe, forgive me if I'm wrong. I can't help but wonder if BRS will put this one up on their site as a "save". Probably so since they counted Brad Koji and he did have a bad outcome. http://liveleak.com/view?i=391_1259184903 Cut and paste if the link doesn't open. Rick Girard ________________________________________________________________________________
Subject: Still More MV2008
Date: Jan 01, 2010
Subject: More MV 2008
Date: Jan 01, 2010
Subject: And Still More MV2008
Date: Jan 01, 2010
This is the end. john h mkIII ________________________________________________________________________________
Subject: MV 2008
Date: Jan 01, 2010
Hi Gang: Here are some photos from MV2008. john h mkIII ________________________________________________________________________________
From: "frank.goodnight" <frank.goodnight(at)att.net>
Subject: Re: Monument Valley 2010
Date: Jan 01, 2010
Hi folks, Happy to see that someone else is thinking about MV. Last year it was the highlight of my flight exp. Wouldn't miss it for anything. This year I pan to fly.[ last year I trailered ] If anyone is planing to fly along the interstate 10 route in a slow a/c ,I"m in a---55-60-- mph firestar & would love to hook up. Will leave from Brownsville, TX. If someone knows of a better route than Interstate 10, I sure would like to hear about it. This will be my first really long x country with overnight stops along the way and I'm not too sure about the best route. It looks like there will be some long legs and I will have to carry an extra 5 gal gas can and stop somewhere to pour it in my main tanks. I would like to avoid that if I can. If I can't ---at least it is doable. John, either date is fine with me . Count me in. Frank Goodnight Firestar 2 Brownsville ,TX On Jan 1, 2010, at 9:42 AM, John Hauck wrote: > > Morning Gang: > > Time to start thinking about the 8th Annual Kolb Unplanned/ > Unorganized Flyin, Monument Valley, Utah, 2010. How's that? The > title is as long as the flyin. > > Mother's Day 2010 is 9 May. Memorial Day is the last Monday, 31 May. > > Normally we plan on having our flyin the weekend between Mother's > Day and Memorial Day. However, this year there are two weekends in > between. > > If you plan on attending, let me know which weekend you prefer: > > a. 14-16 May > > b. 21-23 May > > Based on that info, we'll make a decision on which date to go with. > > A lot of us shoot to arrive on Thursday before the official start > date on Friday, depending on the flying weather. > > If you haven't attended one of our flyins, you should. You are > missing out on what we feel is the best flyin anywhere for Kolb > aircraft and Kolb people. Monument Valley is a perfect place for > this kind of get together. If you flyin, there is a 4000 foot paved > airstrip, auto fuel across the road from the airstrip, beautiful RV > Park with a designated area for tent camping, where most of us > camp. If drive, there is a nice lodge and also individual cabins > and duplexes. There is also a nice restaurant and a grocery store > for food and supplies. The convenience store also has fast food > available and less expensive than the restaurant. If we luck out, > maybe Uncle Craig and Tim will bring their rolling kitchen and cook > breakfast for us. ;-) > > Take care, > > john h > mkIII > > ________________________________________________________________________________
Date: Jan 01, 2010
John H/Everybody else=2C Yeah=2C I admit=2C most of the changes I've done are NOT for the faint of heart. Plus=2C after all the delays=2C mods and postponings=2C it's time for me to finish the plane. I'm not going to begin any further stuff until I have the plane finished. Things like "door pods" and other less important paraphernalia will be le ft for later. Mike Welch From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Electrical Switch Location Date: Fri=2C 1 Jan 2010 09:16:12 -0600 Mike W/Gang: Wish I had the motivation to make all those changes. I kept all the switches along the bottom right of the instrument panel in f ront of me. Circuit breakers on the left side along the bottom of the inst rument panel. I wear my shoulder harness loose enough to be able to reach the switches. If I need to pull or push a circuit breaker=2C takes a secon d to loosen the shoulder harness a little more to reach them. Normally=2C never have to recycle a breaker. I did fabricate a sheet metal panel which I shock mounted an inch or so nearer the seats. My Garmin GPS is worn on my left thigh with a 2" velcro leg strap because I did not have room on the panel to mount it. Glad I didn't have room on th e panel because I like it better on my leg. I wear bifocals and can easily see the gps and operate it. A slight disadvantage of wearing on my thigh is having to look down farther than if it was panel mounted. As my vision slowly deteriorates=2C I doubt I could see it well enough to use if it was mounted on the panel. Being comfortable in the cockpit and keeping it simple is of primary import ance to me. Weather is lousy in Alabama=2C cold and wet. When the sun comes out it wil l be cold=2C low 40s. Happy and healthy new year=2C folks! Yippee! 4.5 months until time to fly to MV. john h mkIII There are lots of places where you could locate some switches=2C such as overhead=2C below your knees=2C and on some center console=2C but how abou t the following?.......... A) I need it low=2C so I can see it properly with reading glasses. B) I need it close=2C about 20" max. Anything further than that=2C and I can't push the touch-screen with ANY accuracy. Just a suggestion=2C Mike Welch _________________________________________________________________ Hotmail: Powerful Free email with security by Microsoft. ________________________________________________________________________________
Subject: kolb in the distance
Date: Jan 01, 2010
A neighbor with a perverted sense of humor caught me on his cell phone: (the interceptor is a bird) no I didn't crash. http://www.youtube.com/watch?v=bPA1w7FcdiE BB, devoid of ambition today. ________________________________________________________________________________
Date: Jan 01, 2010
. > This year I pan to fly.[ last year I trailered ] If anyone is planing to > fly along the interstate 10 route in a slow a/c ,I"m in a---55-60-- > mph firestar & would love to hook up. > Will leave from Brownsville, TX. If someone knows of a better route than > Interstate 10, I sure would like to hear about it. This will be my first > really > long x country with overnight stops along the way and I'm not too sure > about the best route. > Frank Goodnight Frank G/Gang: In 1994, I landed at Brownsville on my way around the border to Alaska. >From there I flew generally up the border to Sanderson, Alpine, Fabens, and on to El Paso. Wil Uribe has flown his FS from El Paso to MV several times. He will be able to help you out on the best recommended route from there. Congratulations on your planned attempt at a flight that look like about 1,200 sm. Should be a good one. john h mkIII ________________________________________________________________________________
Subject: Trailer challenge
Date: Jan 04, 2010
Kolb guys=2C I should be getting back to work fairly soon on my MkIII. I think I coul d finish it in about two months. Once my plane is finished=2C I have a trailer dilemma. Here's the story =3B I live 1200 feet from my local airport. Less than a 1/4 mile. This airp ort is at the end of my street=2C and I'm the third house from the end. There is almost no traffic on my street. I can go hours between seeing veh icles. I plan on keeping my wings and tailfeathers in flight position all the ti me...that is=2C I do NOT plan to fold the wings=2C since I have my 40 x 48 hangar I built last year (on my property). I only have ONE obstacle between my hangar and the taxiways...the airport entrance gate. It's a set of swinging gates=2C that are always open. The gap is around 20-22 feet wide and the gate posts are around 9 feet tall. Simply put=2C I need to get my assembled plane from my hangar to inside the airport. I am looking for trailer ideas. A) I plan on towing this trailer with my ATV. B) The trailer does not need to EVER be towed on the roads (except for my road). C) The MkIII must clear the 9' X 20' gate opening D) I can use the 12 volt electrical supply from the ATV (for a winch=2C et c) My initial thoughts are to build a very wide U-shaped frame unit with a t owbar. The plane would roll into this "U" shape gap=2C and a movable sciss or mechanism would rise to lift the plane slightly by the wing strut attach points (or by the axle legs). I could tow the plane about 6" of the ground=2C and when necessary=2C rai se it 10' briefly to get through the gate opening. Any engineering type guys have any thoughts=2C ideas=2C suggestions?? I know I can build a very workable trailer=2C but I am always open to ideas I may not have thought of. Waddayathink?? Mike Welch MkIII _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Subject: Re: Trailer challenge
Date: Jan 04, 2010
Mike Welch wrote: > I live 1200 feet from my local airport. Less than a 1/4 mile. This airport is at the end of my street C and I'm the third house from the end. Some Wise Guy is going to say...... "1200 feet approach to the gate?..... fly it over!" Otherwise.... if you are talking about hoisting the plane high enough to clear the 9' posts, I wouldn't be crazy about doing that. I would rather keep it close to the ground. Tow it to the gate. With a well designed, good wheeled dolly of some design, wing first through the gate by hand. "K" turn it through the gate if necessary. How much longer is your plane (nose to tail) than the gate is wide? Can't be much. And what, if any, obstacles are on either side of the gate opening. Do/can the gates swing all the way back against the fence? Lots of planes go through hangar doors that are narrower than the wing spread. Worth what you paid for it....... -------- George Alexander FS II R503 N709FS http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280049#280049 ________________________________________________________________________________
Date: Jan 04, 2010
Mike, Cheaper and simpler than a trailer, might be to offer to rebuild the airport gate so your plane fits through it, at your expense... and then just taxi it from your hangar. Otherwise, build a trailer to tow the plane sideways, and lift just the tail if necessary to clear the gate. -Dana At 11:44 AM 1/4/2010, Mike Welch wrote: >Kolb guys, > > I should be getting back to work fairly soon on my MkIII. I think I > could finish it in about two months. > > Once my plane is finished, I have a trailer dilemma. Here's the story; > > I live 1200 feet from my local airport. Less than a 1/4 mile. This > airport is at the end of my street, and I'm the third house from the end. >There is almost no traffic on my street. I can go hours between seeing >vehicles. > I plan on keeping my wings and tailfeathers in flight position all the > time...that is, I do NOT plan to fold the wings, since I have my 40 x 48 > hangar I built last year (on my property). > > I only have ONE obstacle between my hangar and the taxiways...the > airport entrance gate. It's a set of swinging gates, that are always > open. The gap is around 20-22 feet wide and the gate posts are around 9 > feet tall. Simply put, I need to get my assembled plane from my hangar > to inside the airport. > > I am looking for trailer ideas. >A) I plan on towing this trailer with my ATV. >B) The trailer does not need to EVER be towed on the roads (except for my >road). >C) The MkIII must clear the 9' X 20' gate opening >D) I can use the 12 volt electrical supply from the ATV (for a winch, etc) > > My initial thoughts are to build a very wide U-shaped frame unit with a > towbar. The plane would roll into this "U" shape gap, and a movable > scissor mechanism would rise to lift the plane slightly >by the wing strut attach points (or by the axle legs). > I could tow the plane about 6" of the ground, and when necessary, raise > it 10' briefly to get through the gate opening. > > Any engineering type guys have any thoughts, ideas, suggestions?? I > know I can build a very workable trailer, but I am always open to ideas I > may not have thought of. > >Waddayathink?? > >Mike Welch >MkIII > > >---------- >Hotmail: Trusted email with powerful S' target='_new'>Sign up now. > ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List ><http://www.matronics.com/contribution>http://www.matronics.com/contribution > -- Suicidal twin kills sister by mistake! ________________________________________________________________________________
Date: Jan 04, 2010
Hi George=2C I'll answer your questions one at a time...... > Some Wise Guy is going to say...... "1200 feet approach to the gate?..... fly it over!" Interesting that you said that previous statement. Last summer=2C I was standing at the end of my driveway=2C eyeballing the path of a possible lan ding on my front yard( while my neighbor mowed his lawn). The next day=2C he planted a line of trees along his property line. Obviously he was think ing "don't get any ideas!! > Otherwise.... if you are talking about hoisting the plane high enough to clear the 9' posts=2C I wouldn't be crazy about doing that. I would rather keep it close to the ground. Tow it to the gate. With a well designed=2C g ood wheeled dolly of some design=2C wing first through the gate by hand. "K " turn it through the gate if necessary. See=2C I knew some sharp guy was going to suggest something I hadn't thoug ht of! Build a turntable mechanism=2C or better yet=2C build the trailer t o allow the plane to roll on and off diagonally (providing the plane will p ass through diagonally) Hmmm??? I'll have to make some measurements to s ee if a diagonal pass will work. > How much longer is your plane (nose to tail) than the gate is wide? Can't be much. And what=2C if any=2C obstacles are on either side of the gate op ening. Do/can the gates swing all the way back against the fence? I measured the gap of the gate last summer=2C but I can't remember now. The posts allow for two normal width lanes of traffic to enter the airport =2C so I'm guessing a gap of around 20 to 22 feet. I know it is close to t hese figures=2C I just can't remember exactly. My plane is real close to 2 4 1/2 feet. The left gate swings inline with the road=2C just enough to clear the asp halt. The other gate swings more out of the way=2C but not ALL the way. Your idea of raising the tail to go through the opening is an idea I pond ered awhile back. This MAY be the best idea=2C yet. I haven't "designed" any trailer structure to go this method=2C but it definitely has merit. > Lots of planes go through hangar doors that are narrower than the wing sp read. One thing to consider is whatever I come up with=2C it has to allow for a lmost NO "slowdown". In other words=2C I can't pull up to the gate=2C and start farting around with some gizmo that takes a minute or two. I'll lose friends rapidly if I block the entrance. I will need to pretty much drive through unimpeded=2C slowing down for no more than a few seconds. > Worth what you paid for it....... Actually=2C worth more than I paid for it. Both of your suggestions will get more investigation! Thanks=2C George. Mike Welch > -------- > George Alexander > FS II R503 N709FS > http://gtalexander.home.att.net _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Jan 04, 2010
Mike Forget the trailer spend the money on a wider gate. Offer to pay or do it yourself????? Also The FAA has recently stated that they want to eliminate through the gate operations at airports. The latest ruling states that any airport that has or will get federal funds must stop allowing airplanes to enter. Can you imagine the government mandating that a persons car must be parked on a expressway to be able to use it. Go figure. You may want to check on this. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Monday, January 04, 2010 11:44 AM Subject: Kolb-List: Trailer challenge Kolb guys, I should be getting back to work fairly soon on my MkIII. I think I could finish it in about two months. Once my plane is finished, I have a trailer dilemma. Here's the story; I live 1200 feet from my local airport. Less than a 1/4 mile. This airport is at the end of my street, and I'm the third house from the end. There is almost no traffic on my street. I can go hours between seeing vehicles. I plan on keeping my wings and tailfeathers in flight position all the time...that is, I do NOT plan to fold the wings, since I have my 40 x 48 hangar I built last year (on my property). I only have ONE obstacle between my hangar and the taxiways...the airport entrance gate. It's a set of swinging gates, that are always open. The gap is around 20-22 feet wide and the gate posts are around 9 feet tall. Simply put, I need to get my assembled plane from my hangar to inside the airport. I am looking for trailer ideas. A) I plan on towing this trailer with my ATV. B) The trailer does not need to EVER be towed on the roads (except for my road). C) The MkIII must clear the 9' X 20' gate opening D) I can use the 12 volt electrical supply from the ATV (for a winch, etc) My initial thoughts are to build a very wide U-shaped frame unit with a towbar. The plane would roll into this "U" shape gap, and a movable scissor mechanism would rise to lift the plane slightly by the wing strut attach points (or by the axle legs). I could tow the plane about 6" of the ground, and when necessary, raise it 10' briefly to get through the gate opening. Any engineering type guys have any thoughts, ideas, suggestions?? I know I can build a very workable trailer, but I am always open to ideas I may not have thought of. Waddayathink?? Mike Welch MkIII ------------------------------------------------------------------------- ----- Hotmail: Trusted email with powerful S' target='_new'>Sign up now. ________________________________________________________________________________
Date: Jan 04, 2010
Hi Dana=2C If I thought the airport types would let me relocate the gate (only one g ate would need to be moved)=2C I'd ask. But=2C seeing as how this gate is less than a year old=2C and built with federal money=2C I can safely say "d on't waste your time"=2C to myself. Example: Since this is a county airport=2C I see a county commision hear ing=2C environmental review=2C traffic study to determine the community ben efit=2C review process=2C public hearings=2C more review process=2C approva l=2C conditions to approval=2C permit=2C soils report=2C engineering review =2C insurance policy=2C post a construction bond=2C do the work=2C reinspe ction. In the meantime=2C I died of old age. : ( I think I'll go out to my hangar=2C and take some measurements. Plus=2C I'll run down to the airport gates and take a new accurate gap reading. Yeah=2C I think you're right. Either the diagonal method=2C or the lift a tail method=2C or a combination of the tow is going to be the way to go. Back in a while........ Mike Welch Date: Mon=2C 4 Jan 2010 13:03:17 -0500 From: d-m-hague(at)comcast.net Subject: Re: Kolb-List: Trailer challenge Mike=2C Cheaper and simpler than a trailer=2C might be to offer to rebuild the airp ort gate so your plane fits through it=2C at your expense... and then just taxi it from your hangar. Otherwise=2C build a trailer to tow the plane sideways=2C and lift just the tail if necessary to clear the gate. -Dana At 11:44 AM 1/4/2010=2C Mike Welch wrote: Kolb guys=2C I should be getting back to work fairly soon on my MkIII. I think I coul d finish it in about two months. Once my plane is finished=2C I have a trailer dilemma. Here's the story =3B I live 1200 feet from my local airport. Less than a 1/4 mile. This airp ort is at the end of my street=2C and I'm the third house from the end. There is almost no traffic on my street. I can go hours between seeing veh icles. I plan on keeping my wings and tailfeathers in flight position all the ti me...that is=2C I do NOT plan to fold the wings=2C since I have my 40 x 48 hangar I built last year (on my property). I only have ONE obstacle between my hangar and the taxiways...the airport entrance gate. It's a set of swinging gates=2C that are always open. The gap is around 20-22 feet wide and the gate posts are around 9 feet tall. Simply put=2C I need to get my assembled plane from my hangar to inside the airport. I am looking for trailer ideas. A) I plan on towing this trailer with my ATV. B) The trailer does not need to EVER be towed on the roads (except for my road). C) The MkIII must clear the 9' X 20' gate opening D) I can use the 12 volt electrical supply from the ATV (for a winch=2C et c) My initial thoughts are to build a very wide U-shaped frame unit with a t owbar. The plane would roll into this "U" shape gap=2C and a movable sciss or mechanism would rise to lift the plane slightly by the wing strut attach points (or by the axle legs). I could tow the plane about 6" of the ground=2C and when necessary=2C rai se it 10' briefly to get through the gate opening. Any engineering type guys have any thoughts=2C ideas=2C suggestions?? I know I can build a very workable trailer=2C but I am always open to ideas I may not have thought of. Waddayathink?? Mike Welch MkIII Hotmail: Trusted email with powerful S' target='_new'>Sign up now. http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - http://forums.matronics.com - List Contribution Web Site - -Matt Dralle=2C List Admin. http://www.matronics.com/contribution -- Suicidal twin kills sister by mistake! _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Jan 04, 2010
Rick=2C The new FAA rule doesn't apply in my case. The FAA wants to stop AIRPLAN ES from coming through fences to get to an airport=2C like at some of those airport communities where you can taxi from your hangar to the active runway. Nope=2C can't forget the trailer idea. It's gonna have to be that=2C but thanks=2C though. Mike Welch From: NeilsenRM(at)comcast.net Subject: Re: Kolb-List: Trailer challenge Date: Mon=2C 4 Jan 2010 13:21:06 -0500 Mike Forget the trailer spend the money on a wider gate. Offer to pay or do it y ourself????? Also The FAA has recently stated that they want to eliminate through the ga te operations at airports. The latest ruling states that any airport that h as or will get federal funds must stop allowing airplanes to enter. Can you imagine the government mandating that a persons car must be parked on a ex pressway to be able to use it. Go figure. You may want to check on this. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: Mike Welch Sent: Monday=2C January 04=2C 2010 11:44 AM Subject: Kolb-List: Trailer challenge Kolb guys=2C I should be getting back to work fairly soon on my MkIII. I think I coul d finish it in about two months. Once my plane is finished=2C I have a trailer dilemma. Here's the story =3B I live 1200 feet from my local airport. Less than a 1/4 mile. This airp ort is at the end of my street=2C and I'm the third house from the end. There is almost no traffic on my street. I can go hours between seeing veh icles. I plan on keeping my wings and tailfeathers in flight position all the ti me...that is=2C I do NOT plan to fold the wings=2C since I have my 40 x 48 hangar I built last year (on my property). I only have ONE obstacle between my hangar and the taxiways...the airport entrance gate. It's a set of swinging gates=2C that are always open. The gap is around 20-22 feet wide and the gate posts are around 9 feet tall. Simply put=2C I need to get my assembled plane from my hangar to inside the airport. I am looking for trailer ideas. A) I plan on towing this trailer with my ATV. B) The trailer does not need to EVER be towed on the roads (except for my road). C) The MkIII must clear the 9' X 20' gate opening D) I can use the 12 volt electrical supply from the ATV (for a winch=2C et c) My initial thoughts are to build a very wide U-shaped frame unit with a t owbar. The plane would roll into this "U" shape gap=2C and a movable sciss or mechanism would rise to lift the plane slightly by the wing strut attach points (or by the axle legs). I could tow the plane about 6" of the ground=2C and when necessary=2C rai se it 10' briefly to get through the gate opening. Any engineering type guys have any thoughts=2C ideas=2C suggestions?? I know I can build a very workable trailer=2C but I am always open to ideas I may not have thought of. Waddayathink?? Mike Welch MkIII Hotmail: Trusted email with powerful S' target='_new'>Sign up now. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _________________________________________________________________ Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. ________________________________________________________________________________
Date: Jan 04, 2010
Why did you build the hanger on your property, rather than the airport? Before I threw out the suggestion to build a wider gate, I'd take time to investigate the probablity of doing so with local officials. Trailering is not the ideal way to enjoy an airplane. Some folks have no other alternative. The more hassle it is to get ready, before and after flying, the less the Kolb will be flown. How are your neighbors and city officials going to feel about you trailering 30' wide cargo down the street a couple times a day. And I thought I had problems flying with cows and cow manure for the last 25 years. ;-) john h mkIII - 31F at 1255, hauck's holler, alabama. Too cold to play with the airplane. The airport is a local public (municipal??) airport. Mike Welch ________________________________________________________________________________
Date: Jan 04, 2010
Mike It seems that in some of the magazines there have been stands that you can buy to put in a hanger that can raise a plane off the floor so another can be parked under it. If you could buy one of them and mount it on a trailer,,, pull up to the gate raise it up, go through, let it down. Make sure the base of the trailer is secure enough so it won't tip over if a gust of wind hit it. Seems like someone has already done the engineering, but maybe it is only for nose draggers,,, you may have to check. Boyd Young ________________________________________________________________________________
Date: Jan 04, 2010
Why not just fold one wing? It would then easily slip through the gate, at no cost to you, and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert ________________________________________________________________________________
Date: Jan 04, 2010
John H.=2C Because the hangar/shop is 50 feet from my house=2C and I built the hanga r on my property because it is my hangar=2C and I didn't want to get involv ed with airport leasing=2C etc=2C etc=2C etc. Besides=2C I built an apartment in the back of the hangar=2C where my wif e and I lived for a year=2C while I built my house=2C which is almost done. Trailering=2C when it is rolled onto a metal frame=2C pulled 1200 feet=2C and rolled off the metal frame is hardly "trailering". This the point why I want it to remain 100% together=2C wings spread=2C gassed up=2C whatever . Not trailered in the normal sense of the word. Roll in on=2C pull it to the airport=2C roll it off. Simple plan. (just got to get through that d arn gate) Don't care much about what city officials say. I live well south of town and I can move the plane quite easily without worrying about an traffic. I haven't had a car drive past my house today in three hours. Mike Welch From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Re: Trailer challenge Date: Mon=2C 4 Jan 2010 12:58:43 -0600 Why did you build the hanger on your property=2C rather than the airport? Before I threw out the suggestion to build a wider gate=2C I'd take time to investigate the probablity of doing so with local officials. Trailering is not the ideal way to enjoy an airplane. Some folks have no o ther alternative. The more hassle it is to get ready=2C before and after f lying=2C the less the Kolb will be flown. How are your neighbors and city officials going to feel about you trailerin g 30' wide cargo down the street a couple times a day. And I thought I had problems flying with cows and cow manure for the last 2 5 years. =3B-) john h mkIII - 31F at 1255=2C hauck's holler=2C alabama. Too cold to play with th e airplane. The airport is a local public (municipal??) airport. Mike Welch _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Jan 04, 2010
Boyd=2C Your idea of the "airplane lift" is close to what I would design=2C if I were to go that route. I considered the U-frame=2C with the inner scissor mechanism platform=2C wh ere the platform "scissors" by way of a winch cable=2C raising the inner pl atform. Still=2C I like the idea of the diagonal position. I'm going to run down and get some measurements.... Thanks=2C Mike From: by0ung(at)brigham.net Subject: RE: Kolb-List: Trailer challenge Date: Mon=2C 4 Jan 2010 11:58:50 -0700 Mike It seems that in some of the magazines there have been stands that you can buy to put in a hanger that can raise a plane off the floor so another can be parked under it. If you could buy one of them and mount it on a trail er=2C=2C=2C pull up to the gate raise it up=2C go through=2C let it down. Make sure the base of the trailer is secure enough so it won=92t tip ove r if a gust of wind hit it. Seems like someone has already done the engi neering=2C but maybe it is only for nose draggers=2C=2C=2C you may have to check. Boyd Young _________________________________________________________________ Hotmail: Powerful Free email with security by Microsoft. ________________________________________________________________________________
Date: Jan 04, 2010
Robert=2C I thought of that=2C too. I think this has to be one of the front runner s. You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design)=2C and it has these padded wing pockets=2C this may not be a bad idea. Thanks Robert=2C Mike Date: Mon=2C 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com Why not just fold one wing? It would then easily slip through the gate=2C at no cost to you=2C and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Jan 04, 2010
Kolb guys=2C Okay=2C I just got back from taking some measurements. Here's what I got =3B The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap w as closer to 20-22'...hmmm=2C maybe I measured the old gate opening. My wingspan is around 31 feet (14' for each wing=2C plus 36" for the cent er section). However=2C if only ONE wing is folded=2C you'd have to add ab out 3 feet for the landing gear=2C i.e....14' for one wing=2C plus 3' cente r section=2C plus 3 feet for exposed landing gear = 20' wide overall (if one wing were folded) This would be slam dunk easy trailer to build=2C if I went with a "one-wing folded design". I'm going to have to pull out some graph paper=2C scale the MkIII's outer dimensions=2C scale a 27 foot opening....and see if a diagonal trailer mou nt will work. More on this one later.. Thanks for everyone's input. Mike Welch From: mdnanwelch7(at)hotmail.com Subject: RE: Kolb-List: Trailer challenge Date: Mon=2C 4 Jan 2010 11:41:52 -0800 Robert=2C I thought of that=2C too. I think this has to be one of the front runner s. You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design)=2C and it has these padded wing pockets=2C this may not be a bad idea. Thanks Robert=2C Mike Date: Mon=2C 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com Why not just fold one wing? It would then easily slip through the gate=2C at no cost to you=2C and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. _________________________________________________________________ Hotmail: Free=2C trusted and rich email service. ________________________________________________________________________________
Date: Jan 04, 2010
At 01:21 PM 1/4/2010, Richard & Martha Neilsen wrote: > >Also The FAA has recently stated that they want to eliminate through the >gate operations at airports. The latest ruling states that any airport >that has or will get federal funds must stop allowing airplanes to enter. >Can you imagine the government mandating that a persons car must be parked >on a expressway to be able to use it. Go figure. You may want to check on this. This only applies to people who own property directly adjacent to the airport, and cross the property line through a private access. It does NOT apply (yet) to people who trailer their planes through the public airport gate from another location. -Dana -- If at first you DO succeed, try not to look astonished! ________________________________________________________________________________
Date: Jan 04, 2010
Subject: Comedy act for all Kolbers
Everyone! My bro sent me this link. What a hoot!!! You'll love it. Dave Kulp Bethlehem, PA http://www.franklinairshow.com/Video/Comedy%202010%20Net.WMV ________________________________________________________________________________
Date: Jan 04, 2010
Mike, take into consideration the plane is a little tippy with one wing on. I like the diagonal approach ---or maybe knife edge? :) BB On 4, Jan 2010, at 3:19 PM, Mike Welch wrote: > Kolb guys, > > Okay, I just got back from taking some measurements. Here's what I got; > > The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap was closer to 20-22'...hmmm, maybe I measured the old gate opening. > > My wingspan is around 31 feet (14' for each wing, plus 36" for the center section). However, if only ONE wing is folded, you'd have to add about 3 feet for the landing gear, i.e....14' for one wing, plus 3' center section, plus 3 feet for exposed landing gear = 20' wide overall (if one wing were folded) This would be slam dunk easy trailer to build, if I went with a "one-wing folded design". > > I'm going to have to pull out some graph paper, scale the MkIII's outer dimensions, scale a 27 foot opening....and see if a diagonal trailer mount will work. More on this one later.. > > Thanks for everyone's input. > > Mike Welch > > > From: mdnanwelch7(at)hotmail.com > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: Trailer challenge > Date: Mon, 4 Jan 2010 11:41:52 -0800 > > Robert, > > I thought of that, too. I think this has to be one of the front runners. > > You know what? Since I already have that handy dandy boom tube support > (from Uncle Craig's design), and it has these padded wing pockets, this may not be a bad idea. > > Thanks Robert, Mike > > Date: Mon, 4 Jan 2010 13:05:00 -0600 > Subject: Re: Kolb-List: Trailer challenge > From: rlaird(at)cavediver.com > To: kolb-list(at)matronics.com > > Why not just fold one wing? It would then easily slip through the gate, at no cost to you, and time spent of about 5 minutes setting up the wing and gap seal. > > Seems to me that's a WHOLE lot simpler and cheaper than any other solution. > > -- Robert > > > > > ttp://www.matronics.com/Navigator?Kolb-List > ronics.com > ww.matronics.com/contribution > > > Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. > > > ttp://www.matronics.com/Navigator?Kolb-List > ronics.com > ww.matronics.com/contribution > > > Hotmail: Free, trusted and rich target='_new'>Get it now. > > > > ________________________________________________________________________________
Date: Jan 04, 2010
Hello... I looked at a M3C last year on floats ,and it had a pretty neat trailer to get it a short way to the water....take a look and imagine ! The neat thing about this was the tongue ...it had a hitch on both sides and it slid from one end to the other so he could run it up on the trailer ...pull it up on shore then push the tongue all the way though ...pin it ...tie the tail to the tongue and tow it home....then it's all set to put back in the water ! good luck ! chris ambrose M3X/Jab N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280155#280155 Attachments: http://forums.matronics.com//files/100_2548_521.jpg ________________________________________________________________________________
Subject: Re: MV 2110 Trip
Date: Jan 04, 2010
My x country time is zero , I'm excited about the > upcoming trip , but also nervous . Anything that you or anyone else can > tell me that would make the trip > safer or more enjoyable I would sure like to hear. > Frank Goodnight Frank G/Gang: I've been flying Kolbs cross country for a while. When I decided to start flying extremely long, multi-day/week cross countries, I decided to do an overnight flight to check if I had everything I needed and determine things that I did not need. This first overnight flight confirmed what I needed to take with me on the longer flights. The primary requirement for me is to be comfortable and get a good night's sleep. I have to have a good tent that has been tested in wet and windy weather, a good Thermarest air mattress, pillow, sleeping bag, etc. I have the luxury of more cargo space than you do, so you may not want to bring a pillow, but use your dirty clothes bag for a pillow. The best way to know what it is going to take for you is to get out there and do overnight cross country flights. If you can be comfortable for one night, you should be comfortable for a month or more. It takes as much preparation for a one night flight as it does for a 30 night flight. john h mkIII ________________________________________________________________________________
Date: Jan 04, 2010
Hey Big Bob=2C I realize that if I were to go with the "one wing folded" approach that i t would be VERY side-heavy. What I would have done is incorporate a cushio ned cradle to support and brace that one extended wing. [ In other words =2C I would have allowed for that : ) ] After measuring the new gate opening width=2C and finding out it is 27 fe et wide=2C I'm real tempted to try to go with the sideways tow idea. Here' s why=3B Remember=2C my main preference is have the plane stay 100% flyable at all times. Folding even one wing is more than I would prefer not to do. I'd do it=2C but I'd rather not=2C if something else will allow the plane to st ay fully "flight ready". I really would like it to simply roll onto a trai ler=2C secure it with bungies and velcro straps=2C and roll home. Since the gate opening is 27 feet=2C and the overall length nose to tail is around 24 feet=2C I'm tempted to make an executive decision=2C and just go with that sideways tow idea. This would allow me to make a trailer that the plane would roll onto from the side. (onto runners=2C most likely) It could allow me to keep both wings fully extended (and everything=2C for th at matter). The plane would tow fairly easily between the 27 foot gap. Now=2C I need to come up with a decent=2C very low=2C trailer=2C with run ners for a side loading. Thanks for everybody's input=2C Mike Welch From: slyck(at)frontiernet.net Subject: Re: Kolb-List: Trailer challenge Date: Mon=2C 4 Jan 2010 17:25:36 -0500 Mike=2C take into consideration the plane is a little tippy with one wing o n. I like the diagonal approach ---or maybe knife edge? :) BB On 4=2C Jan 2010=2C at 3:19 PM=2C Mike Welch wrote: Kolb guys=2C Okay=2C I just got back from taking some measurements. Here's what I got =3B The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap w as closer to 20-22'...hmmm=2C maybe I measured the old gate opening. My wingspan is around 31 feet (14' for each wing=2C plus 36" for the cent er section). However=2C if only ONE wing is folded=2C you'd have to add ab out 3 feet for the landing gear=2C i.e....14' for one wing=2C plus 3' cente r section=2C plus 3 feet for exposed landing gear = 20' wide overall (if one wing were folded) This would be slam dunk easy trailer to build=2C if I went with a "one-wing folded design". I'm going to have to pull out some graph paper=2C scale the MkIII's outer dimensions=2C scale a 27 foot opening....and see if a diagonal trailer mou nt will work. More on this one later.. Thanks for everyone's input. Mike Welch From: mdnanwelch7(at)hotmail.com Subject: RE: Kolb-List: Trailer challenge Date: Mon=2C 4 Jan 2010 11:41:52 -0800 Robert=2C I thought of that=2C too. I think this has to be one of the front runner s. You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design)=2C and it has these padded wing pockets=2C this may not be a bad idea. Thanks Robert=2C Mike Date: Mon=2C 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com Why not just fold one wing? It would then easily slip through the gate=2C at no cost to you=2C and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail: Free=2C trusted and rich target='_new'>Get it now. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution _________________________________________________________________ Hotmail: Free=2C trusted and rich email service. ________________________________________________________________________________
Date: Jan 04, 2010
Mike, Harbor Freight sells car dollies that have castering wheels for about $40 a pair. If you made a tail boom dolly from one of their mover's dolly, usually on sale for $10, which also has casters, you'd be all set to go through that gate sideways for less than $100. Just a thought. Rick Girard On Mon, Jan 4, 2010 at 6:38 PM, Mike Welch wrote: > Hey Big Bob, > > I realize that if I were to go with the "one wing folded" approach that > it would be VERY side-heavy. What I would have done is incorporate a > cushioned cradle to support and brace that one extended wing. [ In other > words, I would have allowed for that : ) ] > > After measuring the new gate opening width, and finding out it is 27 feet > wide, I'm real tempted to try to go with the sideways tow idea. Here's why; > > Remember, my main preference is have the plane stay 100% flyable at all > times. Folding even one wing is more than I would prefer not to do. I'd do > it, but I'd rather not, if something else will allow the plane to stay fully > "flight ready". I really would like it to simply roll onto a trailer, > secure it with bungies and velcro straps, and roll home. > Since the gate opening is 27 feet, and the overall length nose to tail is > around 24 feet, I'm tempted to make an executive decision, and just go with > that sideways tow idea. This would allow me to make a trailer that the > plane would roll onto from the side. (onto runners, most likely) It could > allow me to keep both wings fully extended (and everything, for that > matter). The plane would tow fairly easily between the 27 foot gap. > > Now, I need to come up with a decent, very low, trailer, with runners for > a side loading. > > Thanks for everybody's input, > > Mike Welch > > > ------------------------------ > From: slyck(at)frontiernet.net > Subject: Re: Kolb-List: Trailer challenge > Date: Mon, 4 Jan 2010 17:25:36 -0500 > To: kolb-list(at)matronics.com > > Mike, take into consideration the plane is a little tippy with one wing on. > > I like the diagonal approach ---or maybe knife edge? :) > BB > > On 4, Jan 2010, at 3:19 PM, Mike Welch wrote: > > Kolb guys, > > Okay, I just got back from taking some measurements. Here's what I got; > > The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap > was closer to 20-22'...hmmm, maybe I measured the old gate opening. > > My wingspan is around 31 feet (14' for each wing, plus 36" for the center > section). However, if only ONE wing is folded, you'd have to add about 3 > feet for the landing gear, i.e....14' for one wing, plus 3' center section, > plus 3 feet for exposed landing gear =* 20' wide *overall (if one wing > were folded) This would be slam dunk easy trailer to build, if I went with > a "one-wing folded design". > > I'm going to have to pull out some graph paper, scale the MkIII's outer > dimensions, scale a 27 foot opening....and see if a diagonal trailer mount > will work. More on this one later.. > > Thanks for everyone's input. > > Mike Welch > > > ------------------------------ > From: mdnanwelch7(at)hotmail.com > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: Trailer challenge > Date: Mon, 4 Jan 2010 11:41:52 -0800 > > Robert, > > I thought of that, too. I think this has to be one of the front runners. > > You know what? Since I already have that handy dandy boom tube support > (from Uncle Craig's design), and it has these padded wing pockets, this may > not be a bad idea. > > Thanks Robert, Mike > > ------------------------------ > Date: Mon, 4 Jan 2010 13:05:00 -0600 > Subject: Re: Kolb-List: Trailer challenge > From: rlaird(at)cavediver.com > To: kolb-list(at)matronics.com > > Why not just fold one wing? It would then easily slip through the gate, at > no cost to you, and time spent of about 5 minutes setting up the wing and > gap seal. > > Seems to me that's a WHOLE lot simpler and cheaper than any other solution. > > -- Robert > > > * > ttp://www.matronics.com/Navigator?Kolb-Listronics.comww.matronics.com/contribution > * > > > ------------------------------ > Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. > > * > ttp://www.matronics.com/Navigator?Kolb-Listronics.comww.matronics.com/contribution > * > > > ------------------------------ > Hotmail: Free, trusted and rich target='_new'>Get it now. > > * > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > * > > > * > > ttp://www.matronics.com/Navigator?Kolb-Listronics.comww.matronics.com/contribution > * > > > ------------------------------ > Hotmail: Free, trusted and rich target='_new'>Get it now. > > * > > * > > ________________________________________________________________________________
Date: Jan 04, 2010
Hello All Kolbers, If nothing else, this has been a very entertaining discussion. This is the kind of stuff I like to read. Some funny and some serious. With all the input, it sounds like Mike is closing in on an answer to his dilemma. Bill Varnes Kolb FireStar (sitting in its hangar/cold & windy) Audubon, NJ In a message dated 1/4/2010 1:52:58 P.M. Eastern Standard Time, mdnanwelch7(at)hotmail.com writes: I am looking for trailer ideas. A) I plan on towing this trailer with my ATV. B) The trailer does not need to EVER be towed on the roads (except for my road). C) The MkIII must clear the 9' X 20' gate opening D) I can use the 12 volt electrical supply from the ATV (for a winch, etc) ________________________________________________________________________________
Date: Jan 04, 2010
Yup=2C Bill=2C I think you're right. Luckily=2C when the airport people replaced all the fencing last year at th e airport=2C they widened the gate a few feet. With a clearance of 27 feet =2C this makes it very possible to just tow the plane sideways. This also lets me keep the plane 100% assembled=2C ready to fly. Rick G. also just suggested a real good idea=2C too. Since I already have that heavy duty tailboom dolly I built a couple of years ago=2C and I don't need to raise the plane into the air=2C all I need is a dolly to carry jus t the main wheels. He thinks I could get by with a couple (maybe more) of those Harbor Freight wheels=2C and some steel tubing=2C etc. I think he's right. Thanks for everyone's input=2C I appreciate it a lot. Mike Welch From: whiskeyvictor36(at)aol.com Date: Mon=2C 4 Jan 2010 23:37:39 -0500 Subject: Re: Kolb-List: Trailer challenge Hello All Kolbers=2C If nothing else=2C this has been a very entertaining discussion. This is t he kind of stuff I like to read. Some funny and some serious. With all th e input=2C it sounds like Mike is closing in on an answer to his dilemma. Bill Varnes Kolb FireStar (sitting in its hangar/cold & windy) Audubon=2C NJ In a message dated 1/4/2010 1:52:58 P.M. Eastern Standard Time=2C mdnanwelc h7(at)hotmail.com writes: I am looking for trailer ideas. A) I plan on towing this trailer with my ATV. B) The trailer does not need to EVER be towed on the roads (except for my road). C) The MkIII must clear the 9' X 20' gate opening D) I can use the 12 volt electrical supply from the ATV (for a winch=2C et c) _________________________________________________________________ Hotmail: Trusted email with Microsoft=92s powerful SPAM protection. ________________________________________________________________________________
Date: Jan 05, 2010
How about building your trailer with one side higher than the other, if you need to clear 9 ft on one side only the other wing only needs to be 18 inchs off the ground , with a wide undercarrage on the trailer,trolly it should still remain stable for towing. Downunder MK111c Regards Tony ----- Original Message ----- to give a comfortable clearanceFrom: "ces308" <ces308(at)ldaco.com> Sent: Tuesday, January 05, 2010 3:26 PM Subject: Kolb-List: Re: Trailer challenge > > Hello... > > I looked at a M3C last year on floats ,and it had a pretty neat trailer to > get it a short way to the water....take a look and imagine ! The neat > thing about this was the tongue ...it had a hitch on both sides and it > slid from one end to the other so he could run it up on the trailer > ...pull it up on shore then push the tongue all the way though ...pin it > ...tie the tail to the tongue and tow it home....then it's all set to put > back in the water ! > > good luck ! > > > chris ambrose > M3X/Jab > N327CS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=280155#280155 > > > Attachments: > > http://forums.matronics.com//files/100_2548_521.jpg > > > ________________________________________________________________________________
Date: Jan 05, 2010
Mike, Take a look at the mechanism employed on pontoon boat trailers. G.Aman -----Original Message----- From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Mon, Jan 4, 2010 1:19 pm Subject: RE: Kolb-List: Re: Trailer challenge Hi George, I'll answer your questions one at a time...... > Some Wise Guy is going to say...... "1200 feet approach to the gate?.... . fly it over!" Interesting that you said that previous statement. Last summer, I was standing at the end of my driveway, eyeballing the path of a possible lan ding on my front yard( while my neighbor mowed his lawn). The next day, he planted a line of trees along his property line. Obviously he was thi nking "don't get any ideas!! > Otherwise.... if you are talking about hoisting the plane high enough to clear the 9' posts, I wouldn't be crazy about doing that. I would rath er keep it close to the ground. Tow it to the gate. With a well designed, good wheeled dolly of some design, wing first through the gate by hand. "K" turn it through the gate if necessary. See, I knew some sharp guy was going to suggest something I hadn't though t of! Build a turntable mechanism, or better yet, build the trailer to al low the plane to roll on and off diagonally (providing the plane will pass through diagonally) Hmmm??? I'll have to make some measurements to see if a diagonal pass will work. > How much longer is your plane (nose to tail) than the gate is wide? Can' t be much. And what, if any, obstacles are on either side of the gate open ing. Do/can the gates swing all the way back against the fence? I measured the gap of the gate last summer, but I can't remember now. The posts allow for two normal width lanes of traffic to enter the airpor t, so I'm guessing a gap of around 20 to 22 feet. I know it is close to these figures, I just can't remember exactly. My plane is real close to 24 1/2 feet. The left gate swings inline with the road, just enough to clear the asph alt. The other gate swings more out of the way, but not ALL the way. Your idea of raising the tail to go through the opening is an idea I pon dered awhile back. This MAY be the best idea, yet. I haven't "designed" any trailer structure to go this method, but it definitely has merit. > Lots of planes go through hangar doors that are narrower than the wing spread. One thing to consider is whatever I come up with, it has to allow for al most NO "slowdown". In other words, I can't pull up to the gate, and star t farting around with some gizmo that takes a minute or two. I'll lose fr iends rapidly if I block the entrance. I will need to pretty much drive through unimpeded, slowing down for no more than a few seconds. > Worth what you paid for it....... Actually, worth more than I paid for it. Both of your suggestions will get more investigation! Thanks, George. Mike Welch > -------- > George Alexander > FS II R503 N709FS > http://gtalexander.home.att.net Hotmail: Trusted email with powerful SPAtarget='_new'>Sign up now. ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jan 05, 2010
John, That was back in the day when BS was naturally generated.The new Federally generated kind is more difficult to navigate. G.Aman -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, Jan 4, 2010 1:58 pm Subject: Re: Kolb-List: Re: Trailer challenge Why did you build the hanger on your property, rather than the airport? Before I threw out the suggestion to build a wider gate, I'd take time to investigate the probablity of doing so with local officials. Trailering is not the ideal way to enjoy an airplane. Some folks have no other alternative. The more hassle it is to get ready, before and after flying, the less the Kolb will be flown. How are your neighbors and city officials going to feel about you traileri ng 30' wide cargo down the street a couple times a day. And I thought I had problems flying with cows and cow manure for the last 25 years. ;-) john h mkIII - 31F at 1255, hauck's holler, alabama. Too cold to play with the airplane. The airport is a local public (municipal??) airport. Mike Welch ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jan 05, 2010
Mike, Can you put the plane on a trailer at 45 degrees to the center line? G.Aman -----Original Message----- From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Mon, Jan 4, 2010 3:19 pm Subject: RE: Kolb-List: Trailer challenge Kolb guys, Okay, I just got back from taking some measurements. Here's what I got; The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap was closer to 20-22'...hmmm, maybe I measured the old gate opening. My wingspan is around 31 feet (14' for each wing, plus 36" for the cente r section). However, if only ONE wing is folded, you'd have to add about 3 feet for the landing gear, i.e....14' for one wing, plus 3' center sect ion, plus 3 feet for exposed landing gear = 20' wide overall (if one win g were folded) This would be slam dunk easy trailer to build, if I went with a "one-wing folded design". I'm going to have to pull out some graph paper, scale the MkIII's outer dimensions, scale a 27 foot opening....and see if a diagonal trailer moun t will work. More on this one later.. Thanks for everyone's input. Mike Welch From: mdnanwelch7(at)hotmail.com Subject: RE: Kolb-List: Trailer challenge Date: Mon, 4 Jan 2010 11:41:52 -0800 Robert, I thought of that, too. I think this has to be one of the front runners . You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design), and it has these padded wing pockets, this ma y not be a bad idea. Thanks Robert, Mike Date: Mon, 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com Why not just fold one wing? It would then easily slip through the gate, at no cost to you, and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution . -- Robert ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail: Free, trusted and rich target='_new'>Get it now. ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jan 05, 2010
Mike=2C Can you put the plane on a trailer at 45 degrees to the center line? G.Aman Gary=2C After I measured the new gate opening=2C and finding it is actually 27' w ide=2C I think I can just make a simple dolly device to carry just the main wheels. I already have the tailboom dolly. I would need to connect a sim ple brace to tie the main wheel dolly and the tailboom dolly=2C and it woul d act as the towbar=2C too. My tailboom dolly has castors. The main wheel dolly will not=2C because I need the plane to track directly behind my ATV. When I experimented with a model airplane=2C it appears that the best cle arance is 90 degrees (sideways). As I rotated the model plane=2C the hor. stabilizer forced the airplane to have a wider clearance requirement. From all the information I have thus far=2C it looks like I'm A-OK with a simple sideways mount trailer or main wheel dolly. (24' long plane going through a 27' gate opening.) Still=2C I do like the idea of raising the tail really high (over 10')... .if I ever needed to. Then I could go through the gate without having to j ust squeeze through. Mike Welch _________________________________________________________________ Hotmail: Trusted email with Microsoft=92s powerful SPAM protection. ________________________________________________________________________________
Date: Jan 05, 2010
I'm going to have to pull out some graph paper, scale the MkIII's outer dimensions, scale a 27 foot opening....and see if a diagonal trailer mount will work. More on this one later.. Thanks for everyone's input. Mike Welch >>>>>>>>>>>>>>>>>>>>>>>> Years ago while visiting in Washington state, I saw a kolb on a hand pull trailer. The plane sat on the trailer sideways, left wing to the front right wing to the rear, nose to the right,,, well you get the idea. I don't know the dimensions of your mkIII classic/extra, but that may just be to easy. The kolb info packet shows the length of the original mkIII as 22'6" Boyd Young ________________________________________________________________________________
Subject:
Date: Jan 05, 2010
Still, I do like the idea of raising the tail really high (over 10')....if I ever needed to. Then I could go through the gate without having to just squeeze through. Mike Welch When you get to the gate take some chalk and mark your tire position,,, when you are happy with the location, take a can of spray paint and paint a small dot, or row of dots. I would envision a trailer with a long c channel for the tail wheel. lift the tail wheel into the c channel.then push the plane back to the ramps for the main gear, have them mounted on a pivot, or teeter totter 5 ft on one side 1 ft on the other. with the plane on the ground the ramp ends would hit the ground,,,, when the plane is on the trailer, the wheels would be just past the pivot point of the ramp and hold the ramps off the ground. You may only have to roll the plane up 4 inches or so for clearance. Boyd ________________________________________________________________________________
Subject: Re: FWD Battery Location....reply
Date: Jan 05, 2010
Yes, I know, fly higher, but you have to start low to get there.>> Hi Robert, I do the opposite. On the theory that thermals start at ground level and dont start to build until they get a bit of height and are strongest at cloud base, I tend to go low. I think we have different thermals here in the UK. Average say 3/4knots, a real stonker would be say 8/9knots wheras I have flown in Texas and the bastards seem to start at 10 knots and then build.. I have never throttled back in a thermal here unless I am trying to maintain a fixed height. If I hit a thermal I just pull back and stick a wing down if I feel lucky. Amazing how we fly in a different style to `real` pilots. I took a `Red Arrows` (RAF airobatic team) for a ride in my Challenger. As usual my speed varied by a bout 10 knots and the height wandered up and down 50 ft. I offered mt passenger the stick and the speed and the height indicators just stopped moving as it they had suddenly become stuck. I did feel amateur. Cheers Pat ________________________________________________________________________________
Date: Jan 05, 2010
Hi Boyd=2C Sounds like that trailer would be exactly what I need. In a previous email=2C I stated it looks like the narrowest method to tow a completely assembled Kolb MkIII is to go totally at 90 degrees sideways. Any skewing appears to require more clearance. Since my MkIII has a TNK Co.'s OEM Xtra nosecone=2C and all the fuselage tubing was built as precisely as I could measure to a genuine Xtra's dimens ions=2C my MkIII will reflect almost identical dimensions of a factory buil t Xtra. I just went out to my shop and measured the length=2C from nose to tail. I come up with VERY close to 23' 6". (this is with the rudder swung over as much as possible=2C shortening up the overall length a couple of inches .) This all appears as good news to me. I've got to get a 23' 6" airplane t hrough a 27' wide gate opening. Sounds fairly easy to me to plan on buildi ng a "main wheel dolly" that tracks directly behind my ATV. Time to sketch out some ideas for dollies. (Where is Uncle Craig when you need him? ha ha) Mike Welch MkIII CX Years ago while visiting in Washington state=2C I saw a kolb on a hand p ull trailer. The plane sat on the trailer sideways=2C left wing to the front right wing to the rear=2C nose to the right=2C=2C=2C well you get the idea. I don=92t know the dimensions of your mkIII classic/extr a=2C but that may just be to easy. The kolb info packet shows the length of the original mkIII as 22=926=94 Boyd Young _________________________________________________________________ Hotmail: Powerful Free email with security by Microsoft. ________________________________________________________________________________
Date: Jan 05, 2010
Mike, I would be considering a Lift Strut extensions that would raise the wings to 10 feet, at 10 feet out from center. Maybe even a fancy telescoping Lift Strut, that is electrically driven between transport and flying condition? Herb Graff Mark III, 246KT In a message dated 1/4/2010 11:52:35 A.M. Eastern Standard Time, mdnanwelch7(at)hotmail.com writes: I only have ONE obstacle between my hangar and the taxiways...the airport entrance gate. It's a set of swinging gates, that are always open. The gap is around 20-22 feet wide and the gate posts are around 9 feet tall. Simply put, I need to get my assembled plane from my hangar to inside the airport. ________________________________________________________________________________
Date: Jan 05, 2010
Hi Herb=2C Doesn't hit me as a good idea to modify the plane like that=2C Herb. If a wing were to be raised that high=2C I'd have to unhook the aileron contro l=2C etc. Plus=2C the wing mount wouldn't allow for such a high angle. Al l these things are what I'm trying to avoid. Fortunately=2C as it turns out=2C the gate opening is 27' and in the side ways position=2C my plane is 23' 6". So=2C sideways it is!! Now=2C all I have to do is come up with a very nice design=2C well-built trailer to tow the plane sideways. Mike Welch From: HGRAFF(at)aol.com Date: Tue=2C 5 Jan 2010 13:00:35 -0500 Subject: Re: Kolb-List: Trailer challenge Mike=2C I would be considering a Lift Strut extensions that would raise the wings t o 10 feet=2C at 10 feet out from center. Maybe even a fancy telescoping Lift Strut=2C that is electrically driven be tween transport and flying condition? Herb Graff Mark III=2C 246KT In a message dated 1/4/2010 11:52:35 A.M. Eastern Standard Time=2C mdnanwel ch7(at)hotmail.com writes: I only have ONE obstacle between my hangar and the taxiways...the airport e ntrance gate. It's a set of swinging gates=2C that are always open. The g ap is around 20-22 feet wide and the gate posts are around 9 feet tall. Si mply put=2C I need to get my assembled plane from my hangar to inside the a irport. _________________________________________________________________ Hotmail: Free=2C trusted and rich email service. ________________________________________________________________________________
Subject: Trailer challenge
Date: Jan 05, 2010
Go to Harbor Freight and purchase a motorcycle/ATV lift for less than $100 put one wheel on it while on the trailer then jack it up and drive in with one wing over fence. Then let it down as soon as you are in, will take just a few seconds to do so. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of zeprep251(at)aol.com Sent: Tuesday, January 05, 2010 8:58 AM Subject: Re: Kolb-List: Trailer challenge Mike, Can you put the plane on a trailer at 45 degrees to the center line? G.Aman -----Original Message----- From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Mon, Jan 4, 2010 3:19 pm Subject: RE: Kolb-List: Trailer challenge Kolb guys, Okay, I just got back from taking some measurements. Here's what I got; The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap was closer to 20-22'...hmmm, maybe I measured the old gate opening. My wingspan is around 31 feet (14' for each wing, plus 36" for the center section). However, if only ONE wing is folded, you'd have to add about 3 feet for the landing gear, i.e....14' for one wing, plus 3' center section, plus 3 feet for exposed landing gear = 20' wide overall (if one wing were folded) This would be slam dunk easy trailer to build, if I went with a "one-wing folded design". I'm going to have to pull out some graph paper, scale the MkIII's outer dimensions, scale a 27 foot opening....and see if a diagonal trailer mount will work. More on this one later.. Thanks for everyone's input. Mike Welch _____ From: mdnanwelch7(at)hotmail.com <mailto:mdnanwelch7(at)hotmail.com> Subject: RE: Kolb-List: Trailer challenge Date: Mon, 4 Jan 2010 11:41:52 -0800 Robert, I thought of that, too. I think this has to be one of the front runners. You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design), and it has these padded wing pockets, this may not be a bad idea. Thanks Robert, Mike _____ Date: Mon, 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com <mailto:rlaird(at)cavediver.com> Why not just fold one wing? It would then easily slip through the gate, at no cost to you, and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert ttp:// www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> ronics.com ww.matronics.com/contribution _____ Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. ttp:// www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> ronics.com ww.matronics.com/contribution _____ Hotmail: Free, trusted and rich target='_new'>Get it now. =================================== ator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List =================================== ttp://forums.matronics.com =================================== ibution">http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Jan 05, 2010
Pat, you have a good point there. If I maintain 30 ft above the ground the thermals should be mild. Unfortunately where I was flying that absurdly boisterous day, the terrain was too vertical to allow. I'm more a fair weather flyer now although I know one needs some bumpier air to keep your reactions up to par. BB nippy here in the northeast US. On 5, Jan 2010, at 11:54 AM, pj.ladd wrote: > > Yes, I know, fly higher, but you have to start low to get there.>> > > Hi Robert, > I do the opposite. On the theory that thermals start at ground level and dont start to build until they get a bit of height and are strongest at cloud base, I tend to go low. > I think we have different thermals here in the UK. Average say 3/4knots, a real stonker would be say 8/9knots wheras I have flown in Texas and the bastards seem to start at 10 knots and then build.. > > I have never throttled back in a thermal here unless I am trying to maintain a fixed height. If I hit a thermal I just pull back and stick a wing down if I feel lucky. > > Amazing how we fly in a different style to `real` pilots. I took a `Red Arrows` (RAF airobatic team) for a ride in my Challenger. As usual my speed varied by a bout 10 knots and the height wandered up and down 50 ft. I offered mt passenger the stick and the speed and the height indicators just stopped moving as it they had suddenly become stuck. I did feel amateur. > > Cheers > > Pat > > > > > ________________________________________________________________________________
Subject: Re: Trailer challenge
Date: Jan 05, 2010
Wouldn't the other wing hit the ground? Or have I missed something? On Jan 5, 2010, at 6:09 PM, Tom Longo wrote: > Go to Harbor Freight and purchase a motorcycle/ATV lift for less > than $100 put one wheel on it while on the trailer then jack it up > and drive in with one wing over fence. Then let it down as soon as > you are in, will take just a few seconds to do so. > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list- > server(at)matronics.com]On Behalf Of zeprep251(at)aol.com > Sent: Tuesday, January 05, 2010 8:58 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Trailer challenge > > Mike, > Can you put the plane on a trailer at 45 degrees to the center line? > G.Aman > > > -----Original Message----- > From: Mike Welch <mdnanwelch7(at)hotmail.com> > To: kolb-list(at)matronics.com > Sent: Mon, Jan 4, 2010 3:19 pm > Subject: RE: Kolb-List: Trailer challenge > > Kolb guys, > > Okay, I just got back from taking some measurements. Here's what > I got; > > The gate opening is 27 feet. Posts are 9 foot tall. I thought > the gap was closer to 20-22'...hmmm, maybe I measured the old gate > opening. > > My wingspan is around 31 feet (14' for each wing, plus 36" for > the center section). However, if only ONE wing is folded, you'd > have to add about 3 feet for the landing gear, i.e....14' for one > wing, plus 3' center section, plus 3 feet for exposed landing gear > = 20' wide overall (if one wing were folded) This would be slam > dunk easy trailer to build, if I went with a "one-wing folded design". > > I'm going to have to pull out some graph paper, scale the MkIII's > outer dimensions, scale a 27 foot opening....and see if a diagonal > trailer mount will work. More on this one later.. > > Thanks for everyone's input. > > Mike Welch > > > From: mdnanwelch7(at)hotmail.com > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: Trailer challenge > Date: Mon, 4 Jan 2010 11:41:52 -0800 > > Robert, > > I thought of that, too. I think this has to be one of the front > runners. > > You know what? Since I already have that handy dandy boom tube > support > (from Uncle Craig's design), and it has these padded wing pockets, > this may not be a bad idea. > > Thanks Robert, Mike > > Date: Mon, 4 Jan 2010 13:05:00 -0600 > Subject: Re: Kolb-List: Trailer challenge > From: rlaird(at)cavediver.com > To: kolb-list(at)matronics.com > > Why not just fold one wing? It would then easily slip through the > gate, at no cost to you, and time spent of about 5 minutes setting > up the wing and gap seal. > > Seems to me that's a WHOLE lot simpler and cheaper than any other > solution. > > -- Robert > > > ttp://www.matronics.com/Navigator?Kolb-List > > > ronics.com > > > ww.matronics.com/contribution > > > Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. > > > ttp://www.matronics.com/Navigator?Kolb-List > > > ronics.com > > > ww.matronics.com/contribution > > > Hotmail: Free, trusted and rich target='_new'>Get it now. > > > =================================== > > > ator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > > > =================================== > > > ttp://forums.matronics.com > > > =================================== > > > ibution">http://www.matronics.com/contribution > > > =================================== > > > - The Kolb-List Email Forum - > --> http://www.matronics.com/Navigator?Kolb-List > - MATRONICS WEB FORUMS - > --> http://forums.matronics.com > - List Contribution Web Site - > Thank you for your generous support! > -Matt Dralle, List Admin. > --> http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jan 05, 2010
Depends on how high the fence is, he said opening is 27 feet wide, so if it is on a trailer the wing is up fairly high already, should not take much lift on one side to clear and the other wing should have plenty of room before it hits the ground. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of russ kinne Sent: Tuesday, January 05, 2010 7:36 PM Subject: Re: Kolb-List: Trailer challenge Wouldn't the other wing hit the ground? Or have I missed something? On Jan 5, 2010, at 6:09 PM, Tom Longo wrote: Go to Harbor Freight and purchase a motorcycle/ATV lift for less than $100 put one wheel on it while on the trailer then jack it up and drive in with one wing over fence. Then let it down as soon as you are in, will take just a few seconds to do so. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [ mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of zeprep251(at)aol.com Sent: Tuesday, January 05, 2010 8:58 AM Subject: Re: Kolb-List: Trailer challenge Mike, Can you put the plane on a trailer at 45 degrees to the center line? G.Aman -----Original Message----- From: Mike Welch < mdnanwelch7(at)hotmail.com <mailto:mdnanwelch7(at)hotmail.com> > Sent: Mon, Jan 4, 2010 3:19 pm Subject: RE: Kolb-List: Trailer challenge Kolb guys, Okay, I just got back from taking some measurements. Here's what I got; The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap was closer to 20-22'...hmmm, maybe I measured the old gate opening. My wingspan is around 31 feet (14' for each wing, plus 36" for the center section). However, if only ONE wing is folded, you'd have to add about 3 feet for the landing gear, i.e....14' for one wing, plus 3' center section, plus 3 feet for exposed landing gear = 20' wide overall (if one wing were folded) This would be slam dunk easy trailer to build, if I went with a "one-wing folded design". I'm going to have to pull out some graph paper, scale the MkIII's outer dimensions, scale a 27 foot opening....and see if a diagonal trailer mount will work. More on this one later.. Thanks for everyone's input. Mike Welch _____ From: mdnanwelch7(at)hotmail.com <mailto:mdnanwelch7(at)hotmail.com> Subject: RE: Kolb-List: Trailer challenge Date: Mon, 4 Jan 2010 11:41:52 -0800 Robert, I thought of that, too. I think this has to be one of the front runners. You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design), and it has these padded wing pockets, this may not be a bad idea. Thanks Robert, Mike _____ Date: Mon, 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com <mailto:rlaird(at)cavediver.com> Why not just fold one wing? It would then easily slip through the gate, at no cost to you, and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert ttp:// www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> ronics.com ww.matronics.com/contribution _____ Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. ttp:// www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> ronics.com ww.matronics.com/contribution _____ Hotmail: Free, trusted and rich target='_new'>Get it now. =================================== ator?Kolb-List"> http://www.matronics.com/Navigator?Kolb-List =================================== ttp://forums.matronics.com =================================== ibution"> http://www.matronics.com/contribution =================================== - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?Kolb-List blue; text-decoration: underline; ">http://forums.matronics.com style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 05, 2010
Tom=2C Thanks for the suggestion=2C but here are some key points to consider. I don't have any trailer to carry the Kolb at this time=2C so whatever I come up with=2C I have to make. That wouldn't a problem=2C I've made a couple "car carrier" trailers in t he past=2C but I don't want something that large. (actually=2C I have a 5 ton flatbed trailer for my backhoe=2C which I used to move my plane here=2C but it's waaaay too heavy for my ATV!!) Remember=2C I'm not trying to "tow" the plane very far=2C only 1/4 mile =2C to at the end of my road. What I'm looking for is more like a "dolly" than a true airplane trailer. When I thought the gate clearance was 20-22 feet=2C I considered building a trailer pretty close to what you have in mind. Doesn't look like I need to go this route=2C though. While I believe what you suggest will work=2C it would be MUCH more compl ex to build than necessary. Especially=2C since I've mentioned my plane is 23' 6" long...going through the 27' wide opening=2C and it can be towed si deways. So far=2C it appears as though Boyd has the best towing solution for me. Thanks for the suggestion=2C though. Mike Welch From: tclongo(at)att.net Subject: RE: Kolb-List: Trailer challenge Date: Tue=2C 5 Jan 2010 21:11:18 -0500 Depends on how high the fence is=2C he said opening is 27 feet wide=2C so i f it is on a trailer the wing is up fairly high already=2C should not take much lift on one side to clear and the other wing should have plenty of roo m before it hits the ground. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com]On Behalf Of russ kinne Sent: Tuesday=2C January 05=2C 2010 7:36 PM Subject: Re: Kolb-List: Trailer challenge Wouldn't the other wing hit the ground? Or have I missed something? On Jan 5=2C 2010=2C at 6:09 PM=2C Tom Longo wrote: Go to Harbor Freight and purchase a motorcycle/ATV lift for less than $100 put one wheel on it while on the trailer then jack it up and drive in with one wing over fence. Then let it down as soon as you are in=2C will take ju st a few seconds to do so. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com]On Behalf Of zeprep251(at)aol.com Sent: Tuesday=2C January 05=2C 2010 8:58 AM Subject: Re: Kolb-List: Trailer challenge Mike=2C Can you put the plane on a trailer at 45 degrees to the center line? G.Aman -----Original Message----- From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Mon=2C Jan 4=2C 2010 3:19 pm Subject: RE: Kolb-List: Trailer challenge Kolb guys=2C Okay=2C I just got back from taking some measurements. Here's what I got =3B The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap w as closer to 20-22'...hmmm=2C maybe I measured the old gate opening. My wingspan is around 31 feet (14' for each wing=2C plus 36" for the cent er section). However=2C if only ONE wing is folded=2C you'd have to add ab out 3 feet for the landing gear=2C i.e....14' for one wing=2C plus 3' cente r section=2C plus 3 feet for exposed landing gear = 20' wide overall (if one wing were folded) This would be slam dunk easy trailer to build=2C if I went with a "one-wing folded design". I'm going to have to pull out some graph paper=2C scale the MkIII's outer dimensions=2C scale a 27 foot opening....and see if a diagonal trailer mou nt will work. More on this one later.. Thanks for everyone's input. Mike Welch From: mdnanwelch7(at)hotmail.com Subject: RE: Kolb-List: Trailer challenge Date: Mon=2C 4 Jan 2010 11:41:52 -0800 Robert=2C I thought of that=2C too. I think this has to be one of the front runner s. You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design)=2C and it has these padded wing pockets=2C this may not be a bad idea. Thanks Robert=2C Mike Date: Mon=2C 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com Why not just fold one wing? It would then easily slip through the gate=2C at no cost to you=2C and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution Hotmail: Free=2C trusted and rich target='_new'>Get it now. ator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List ttp://forums.matronics.com ibution">http://www.matronics.com/contribution - The Kolb-List Email Forum - --> http://www.matronics.com/Na vigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forum s.matronics.com - List Contribution Web Site - Thank you for y our generous support! -Matt Dralle=2C List Adm in. --> http://www.matronics.com/contribution style="color: blue=3B t ext-decoration: underline=3B ">http://www.matronics.com/Navigator?Kolb-List blue=3B text-decoration: underline=3B ">http://forums.matronics.comstyle= "color: blue=3B text-decoration: underline=3B ">http://www.matronics.com/co ntribution _________________________________________________________________ Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. ________________________________________________________________________________
Date: Jan 06, 2010
FAA has recently stated that they want to eliminate through the gate operations at airports. Can you imagine the government mandating that a persons car must be parked on a expressway to be able to use it. Go figure.>> Do you think that the natural `authority must be wrong` attitude is a bit overdone in this case. Given the present security mad atmosphere would you be happy that anyone could just roll up and push their plane through a hole in the hedge and fly away. No control by the airport authority. If someone did that and turned out to be an `evildoer` (lovely phrase, could only have been invented by an American) all hell would break loose and we should have more rgulations imposed than you could shake a stick at. Just a thought Pat ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Jan 06, 2010
Mike I would ask if you can widen the gate. Be nice but what is the worst they can say? I have hanger in Michigan that is about 6 inches wider than my plane. I pull the plane in very slowly watching the wing tips and I scrap them occasionally. You will be pulling the plane with a atv. You can do some real damage if you get too close. How about setting some kind of flag or something about a foot ahead of the nose and tail (on the ground or mounted on the trailer) that will warn you that you are too close. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Wednesday, January 06, 2010 12:55 AM Subject: RE: Kolb-List: Trailer challenge Tom, Thanks for the suggestion, but here are some key points to consider. I don't have any trailer to carry the Kolb at this time, so whatever I come up with, I have to make. That wouldn't a problem, I've made a couple "car carrier" trailers in the past, but I don't want something that large. (actually, I have a 5 ton flatbed trailer for my backhoe, which I used to move my plane here, but it's waaaay too heavy for my ATV!!) Remember, I'm not trying to "tow" the plane very far, only 1/4 mile, to at the end of my road. What I'm looking for is more like a "dolly" than a true airplane trailer. When I thought the gate clearance was 20-22 feet, I considered building a trailer pretty close to what you have in mind. Doesn't look like I need to go this route, though. While I believe what you suggest will work, it would be MUCH more complex to build than necessary. Especially, since I've mentioned my plane is 23' 6" long...going through the 27' wide opening, and it can be towed sideways. So far, it appears as though Boyd has the best towing solution for me. Thanks for the suggestion, though. Mike Welch ------------------------------------------------------------------------- ----- From: tclongo(at)att.net To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Trailer challenge Date: Tue, 5 Jan 2010 21:11:18 -0500 Depends on how high the fence is, he said opening is 27 feet wide, so if it is on a trailer the wing is up fairly high already, should not take much lift on one side to clear and the other wing should have plenty of room before it hits the ground. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of russ kinne Sent: Tuesday, January 05, 2010 7:36 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Trailer challenge Wouldn't the other wing hit the ground? Or have I missed something? On Jan 5, 2010, at 6:09 PM, Tom Longo wrote: Go to Harbor Freight and purchase a motorcycle/ATV lift for less than $100 put one wheel on it while on the trailer then jack it up and drive in with one wing over fence. Then let it down as soon as you are in, will take just a few seconds to do so. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of zeprep251(at)aol.com Sent: Tuesday, January 05, 2010 8:58 AM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Trailer challenge Mike, Can you put the plane on a trailer at 45 degrees to the center line? G.Aman -----Original Message----- From: Mike Welch <mdnanwelch7(at)hotmail.com> To: kolb-list(at)matronics.com Sent: Mon, Jan 4, 2010 3:19 pm Subject: RE: Kolb-List: Trailer challenge Kolb guys, Okay, I just got back from taking some measurements. Here's what I got; The gate opening is 27 feet. Posts are 9 foot tall. I thought the gap was closer to 20-22'...hmmm, maybe I measured the old gate opening. My wingspan is around 31 feet (14' for each wing, plus 36" for the center section). However, if only ONE wing is folded, you'd have to add about 3 feet for the landing gear, i.e....14' for one wing, plus 3' center section, plus 3 feet for exposed landing gear = 20' wide overall (if one wing were folded) This would be slam dunk easy trailer to build, if I went with a "one-wing folded design". I'm going to have to pull out some graph paper, scale the MkIII's outer dimensions, scale a 27 foot opening....and see if a diagonal trailer mount will work. More on this one later.. Thanks for everyone's input. Mike Welch ------------------------------------------------------------------------- ----- From: mdnanwelch7(at)hotmail.com To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Trailer challenge Date: Mon, 4 Jan 2010 11:41:52 -0800 Robert, I thought of that, too. I think this has to be one of the front runners. You know what? Since I already have that handy dandy boom tube support (from Uncle Craig's design), and it has these padded wing pockets, this may not be a bad idea. Thanks Robert, Mike ------------------------------------------------------------------------- ----- Date: Mon, 4 Jan 2010 13:05:00 -0600 Subject: Re: Kolb-List: Trailer challenge From: rlaird(at)cavediver.com To: kolb-list(at)matronics.com Why not just fold one wing? It would then easily slip through the gate, at no cost to you, and time spent of about 5 minutes setting up the wing and gap seal. Seems to me that's a WHOLE lot simpler and cheaper than any other solution. -- Robert ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution ------------------------------------------------------------------------- ----- Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution ------------------------------------------------------------------------- ----- Hotmail: Free, trusted and rich target='_new'>Get it now. ator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List ttp://forums.matronics.com ibution">http://www.matronics.com/contribution - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?Kolb-Listblue; text-decoration: underline; ">http://forums.matronics.comstyle="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution ------------------------------------------------------------------------- ----- Your E-mail and More On-the-Go. Ge85/direct/01/' target='_new'>Sign up now. ________________________________________________________________________________
Subject: Good winter gloves
Date: Jan 06, 2010
Got a question for you Kolbers who live up Nawth and have more experience with serious deep-freeze weather than we do here in Tennessee. Was out in the hangar for a bit today, and could not keep my hands warm. Have several pairs of work gloves, ski gloves, etc. and none of them are worth beans. Have about quit flying during this part of the year because it's my hands that always get too cold first. Suggestions? Online sources to buy them? Thanks Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280410#280410 ________________________________________________________________________________
Subject: Re: Good winter gloves
Date: Jan 06, 2010
Richard, These rechargeable gloves work pretty good. http://www.herringtoncatalog.com/cs215.html Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 970 hours 23 years flying it Kolbra 912UL N20386 1 year flying it 110 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280414#280414 ________________________________________________________________________________
Date: Jan 06, 2010
Richard For really cold weather wear mittens. Don't know exactly why but cheep mittens work better than even the super insulated gloves. Better yet buy a big pair of mittens and ware gloves under them. When you need to do small work take the gloved hand out get it done them back in the mittens. Rick Neilsen Old fart but young enough to know how to keep warm in a cold Michigan winter. I found the really best way is winter in Florida. ----- Original Message ----- From: "Ralph B" <ul15(at)juno.com> Sent: Wednesday, January 06, 2010 3:33 PM Subject: Kolb-List: Re: Good winter gloves > > Richard, > > These rechargeable gloves work pretty good. > > http://www.herringtoncatalog.com/cs215.html > > Ralph > > -------- > Ralph B > Original Firestar 447 > N91493 E-AB > 970 hours > 23 years flying it > Kolbra 912UL > N20386 > 1 year flying it > 110 hrs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=280414#280414 > > > ________________________________________________________________________________
Date: Jan 06, 2010
If you are flying a two stroke, why not put a heater in it. With the heat captured out of the shroud of a 447 or 503 I could fly in 24 degrees with only the front enclosure and nothing behind me. If you go to Cabela's for gloves I used the Kangaroo shooting gloves because I didn't have to take them off to push buttons either on my radio or GPS. I ran a heater (SCAT)tube in at the top of the windshield, and was comfortable. Since I no longer have a two stroke, I bought a Chili vest and use the Roo gloves, along with a silk scarf, (wild rag) and a stocking hat over my headset. Mittens do work because the mittens allow trapped air to warm. Larry C Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: Richard Pike To: kolb-list(at)matronics.com Sent: Wednesday, January 06, 2010 1:20 PM Subject: Kolb-List: Good winter gloves Got a question for you Kolbers who live up Nawth and have more experience with serious deep-freeze weather than we do here in Tennessee. Was out in the hangar for a bit today, and could not keep my hands warm. Have several pairs of work gloves, ski gloves, etc. and none of them are worth beans. Have about quit flying during this part of the year because it's my hands that always get too cold first. Suggestions? Online sources to buy them? Thanks Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280410#280410 ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 01/06/10 07:35:00 ________________________________________________________________________________
Date: Jan 06, 2010
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
I use insulated mittens with chemical handwarmers in each mitten. In really cold weather, I use one chemical handwarmer in my palm and another on the back of my hand. They last up to 6 hours and cost 99=A2 a pair here in Oreg on. Arty TrostSandy, Oregon www.LessonsFromTheEdge.com/uladventure2009.htm =0A =0A"Life's a daring adventure or nothing" =0A Helen Keller =0A =0A"I refuse to tip toe through life just to arrive safely at death." --- On Wed, 1/6/10, Richard Pike wrote: From: Richard Pike <richard(at)bcchapel.org> Subject: Kolb-List: Good winter gloves Date: Wednesday, January 6, 2010, 12:20 PM Got a question for you Kolbers who live up Nawth and have more experience w ith serious deep-freeze weather than we do here in Tennessee. Was out in th e hangar for a bit today, and could not keep my hands warm. Have several pa irs of work gloves, ski gloves, etc. and none of them are worth beans. Have about quit flying during this part of the year because it's my hands that always get too cold first. Suggestions? Online sources to buy them? Thanks Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280410#280410 le, List Admin. ________________________________________________________________________________
Date: Jan 06, 2010
Richard=2C Since you're such a nice guy=2C I'll tell you which gloves are the best g loves in the world. Neoprene gloves!! I bought a pair about 10 years ago=2C for working on my house in the snow. They are the most comfortable gloves you can buy=2C the good quality ones are "form fitted"=2C and keep your hands very warm. I just bought a pair=2C and they arrived last Monday. Get a pair=2C and I guarantee you'll love 'em. http://cgi.ebay.com/SNORKELING-SCUBA-DIVING-GLOVES-neoprene-3MM_W0QQitemZ2 80444702971QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item414bce90fb Mike Welch > Subject: Kolb-List: Good winter gloves > From: richard(at)bcchapel.org > Date: Wed=2C 6 Jan 2010 12:20:24 -0800 > To: kolb-list(at)matronics.com > > > Got a question for you Kolbers who live up Nawth and have more experience with serious deep-freeze weather than we do here in Tennessee. Was out in the hangar for a bit today=2C and could not keep my hands warm. Have severa l pairs of work gloves=2C ski gloves=2C etc. and none of them are worth bea ns. Have about quit flying during this part of the year because it's my han ds that always get too cold first. > > Suggestions? Online sources to buy them? > > Thanks > Richard Pike > MKIII N420P (420ldPoops) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=280410#280410 > > > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ Hotmail: Free=2C trusted and rich email service. ________________________________________________________________________________
Date: Jan 07, 2010
another good word, picture Doctor Evil stroking his cat and laughing hysterically while plotting world domination in his Kolb).>> Hi Dana, glorious picture. LOL Don`t really want to start a big thing over this. I know that the American thinks automatically, that anything which government or `authority` does is suspect, and I have a certain sympathy with that stance but in view of 9/11 etc., if |I was in charge I would certainly want some control of aircraft and pushing an unregistered plane through a hole in the hedge without any say so from the control tower would worry me. If in the first instance I could only do it for airfields which were receiving government funding, that would be the first step.. What damage they can do is largely irrelevant. I remember having to get a Million pounds worth of insurance to fly my glider into an RAF airfield because they maintained some stores there. Cheers Pat ________________________________________________________________________________
Date: Jan 06, 2010
We try to suppress misleading and inflammatory news about aviation because of our exasperatingly ignorant press and politicians. How many of us have groaned at the reading of a news report that has but the slightest relation to reality or common sense. -Stuff like: "the pilot took off without clearance" . Yikes! we all do that every time we fly our Kolbs, but the common public thinks we are on some kind of a leash like in Russia. Problem is, dimwits like our very own NY senator Schumer would like to have it that way. So we quietly wait one more time for the nonsense to blow over. BB On 6, Jan 2010, at 7:04 PM, pj.ladd wrote: > another good word, picture > Doctor Evil stroking his cat and laughing hysterically while plotting world > domination in his Kolb).>> > > Hi Dana, > glorious picture. LOL > > Don`t really want to start a big thing over this. I know that the American thinks automatically, that anything which government or `authority` does is suspect, and I have a certain sympathy with that stance but in view of 9/11 etc., if |I was in charge I would certainly want some control of aircraft and pushing an unregistered plane through a hole in the hedge without any say so from the control tower would worry me. If in the first instance I could only do it for airfields which were receiving government funding, that would be the first step.. > What damage they can do is largely irrelevant. I remember having to get a Million pounds worth of insurance to fly my glider into an RAF airfield because they maintained some stores there. > > Cheers > > Pat > > > > ________________________________________________________________________________
Subject: Kolbra pilots...how tall is you plane?
Date: Jan 06, 2010
Hello Kolbsters, Kolbra owners. My hanger plan is to buy a shipping container, fold my wings, and roll in my Kolbra, when it is finished. The container width is seven and a haft feet, so that is ok. But what I don't know is how tall this plane will be. I know that on a three blade prop, the tips of the blades will be the highest points. Your engine chooses, redrives, and tires sizes will be variables, but I would be interested to know how tall you plane is . Thank you for your help! Nick Cassara Palmer, Alaska Working on putting the Proto-type Kolbra back in the air! ________________________________________________________________________________
Date: Jan 07, 2010
What control tower?>> Hi Dana, Of course you are right. I tend to forget the basic difference between the USA and the UK which is SIZE. I think it would be difficult in the UK to find even a farm strip which is not overlooked by someone . A change in the pattern of use would probably be remarked on and noted. Also we have no `flying communities` where you could taxi from your house to the peri track. Cheers Pat ________________________________________________________________________________
Date: Jan 07, 2010
Not to prolong things>> Hi Russ, I am quite sure there are ramifications of which I am not aware. I was really just noting that just because` authority` wants something done it is not automatically bad. I think the American `stand on your own feet` philosophy is wholly admirable and the idea that `guv`ment interference` should be treated with suspicion is great. The trouble is that at the other end of the spectrum this means that a National Health Bill, which means that you don`t have to sell your house before you can go into hospital, and which most of the rest of the world accept as a basic tenet of a civilized country is looked on as rank Communism in the USA. Never mind, its the differences between countries and attitudes which help to make this life interesting. Off next week to Bangkok, and Cambodia, down the Mekong and then Australia and then a month on the beach in New Zealand. That ought to turn up a few different attitudes to life. Money for one with the Cambodian Riel at 6,618 to the =A3. Finished my anti cancer course of treatment last week so there is nothing to be done before I get back to the UK in March. Then there will be a biopsy and, depending on the result, I shall have some more treatment or not. All without paying a penny. The plane is laid up, drained, plugs out and `winterised`, wheels off the ground and everything covered up. All ready to start flying again in April, I hope. Wx has been bad in the UK for the last 3 weeks. Scotland and the north have had snow and temps below freezing. Not much by the standards of some of your States but because we don`t get it very often we do not have the infrastructure of machines standing by to deal with it. We have been lucky locally. About 8 inches of snow a couple of nights ago but today is cold and bright sun. Everything looks like a picture. Very icy, last night temps down to 10 dgrees C below.. Wendy has bought a small `netbook` portable and various `dongles` which I hope will mean we can stay in touch with the list while we are away. All the best Pat ________________________________________________________________________________
Date: Jan 07, 2010
Stuff like: "the pilot took off without clearance" . >> Hi Robert, Yea! Shock, horror! No flight plan? No radio? This must be stopped! The trouble is that the ignorant, particularly the press, is not interested in improving their knowledge. Many years ago when I was Secretary of my gliding club I got fed up with every away landing being reported as a crash. I contacted the editors of all our local papers and told them that if they wanted the pukka gen on anything happening just give me a ring and I would give them an update. None of them ever did. It is just too easy to run a headline about `Crashed glider" than to check on the facts. People! Cheers Pat ________________________________________________________________________________
Subject: cold
Date: Jan 07, 2010
If your body is cold for winter flying (actually, flying all the way to Miama is cold) I have a great solution. Dont wear one of those overblown puffed up snow mobile suits. I have what I think they call a helo artic suit. It is designed exactly as a normal flight suit only it is packed with some special ingrediant that keeps you warm no matter what. It is think, maybe 1/4 inch thick and zippers all over it. Wind does not go through it. Warm stays in. I used it when I had a Kobra (almost a quicksilver) rag and tube plane. Flew down to 32 degress or more and NEVER got cold. Hands are something else but there are lots of skiiing mits to fix that. If you want pics, let me know. I stand about 5'7" and it used to fit good until I got paunchy. I would say for someone up to 170 lbs or so. The first hundred bucks takes it and I will ship it for free. Dont like it just hanging in my closet. Let it get out there and fly again. Ted Cowan, Alabama, Slingshot 912ul. (yes, I still have my rum rum) ________________________________________________________________________________
Subject: Apology
Date: Jan 07, 2010
General apology to the list. Mistakenly I sent to the entire list what was supposed to be a personal post to Russ.. Grovelling apology. Pat ________________________________________________________________________________
Subject: Re: cold
Date: Jan 07, 2010
Ted, diverging slightly from the string, re: the rum-rum. I also had a similar effect which I have partially blamed on a personal hearing defect. I have a blocked right eustachian tube which makes background noise pulse in time with my heartbeat. The sound became detectable long before the blockage. I do intend to eventually see a doc about it. BB On 7, Jan 2010, at 6:49 AM, Ted Cowan wrote: > > If your body is cold for winter flying (actually, flying all the way to Miama is cold) I have a great solution. Dont wear one of those overblown puffed up snow mobile suits. I have what I think they call a helo artic suit. It is designed exactly as a normal flight suit only it is packed with some special ingrediant that keeps you warm no matter what. It is think, maybe 1/4 inch thick and zippers all over it. Wind does not go through it. Warm stays in. I used it when I had a Kobra (almost a quicksilver) rag and tube plane. Flew down to 32 degress or more and NEVER got cold. Hands are something else but there are lots of skiiing mits to fix that. If you want pics, let me know. I stand about 5'7" and it used to fit good until I got paunchy. I would say for someone up to 170 lbs or so. The first hundred bucks takes it and I will ship it for free. Dont like it just hanging in my closet. Let it get out there and fly again. Ted Cowan, Alabama, Slingshot 912ul. (yes, I still have my rum rum) > > > > > ________________________________________________________________________________
Date: Jan 07, 2010
Richard, Contrary to the appearance of my overweight body, I have very skinny hands and fingers which are super sensitive to both heat and cold; same for my feet and toes. In any case, for hands and fingers the best no hassle solution I've found is to wear knit glove liners when it is cold and then put good gloves over them when it gets really cold. I also have very good pair of mittens but they are not as good as knit glove liners plus good gloves. My mittens have internal finger holes in them which helps a bit. However, I once tried combining the knit glove liners with the mittens. Bad idea. When removing the mittens the finger hole lining in the mittens came out stuck to the knit liners and I had a hard time getting them back in side where they belonged. Glove liners plus mittens without the finger holes would probably work too but liners inside gloves gives you more dexterity. When working in a cold shop/hangar if I don't want the noise of a big torpedo heater, then I use the washable knit gloves and a little milk-house heater for warming my hands occasionally, when doing work that requires the better dexterity. Thom in Buffalo Balmy 25F this morning -------- Thom Riddle Buffalo, NY Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x31 I have reached an age when, if someone tells me to wear socks, I don't have to. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280490#280490 ________________________________________________________________________________
Subject: FSII covering continued
Date: Jan 07, 2010
Since some of the Kolbers asked for me to post pictures of the ongoing repair job, here is the fuselage covering in it's almost finished condition. Something I learned last night is how to get rid of those annoying little brown bumps of sharp or prickly glue that form along the tubes after you work the fabric down smooth with the hot iron. Just go over them quickly with the brush full of MEK, just enough to wet the surface, and then rub them with your fingers. They either smooth down or rub off. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280516#280516 Attachments: http://forums.matronics.com//files/plateinside_157.jpg http://forums.matronics.com//files/side2_162.jpg http://forums.matronics.com//files/side1_484.jpg http://forums.matronics.com//files/plateinside2_111.jpg ________________________________________________________________________________
Date: Jan 07, 2010
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: FSII Covering continued
- Keep the reports coming, Richard.- You are progressing nicely.- Wha t weight fabric are you using on the cage? - ------------------------- -------------------- Bill Sullivan ------------------------- -------------------- Windsor Locks, Ct. ------------------------- -------------------- FS 447- Can't do Stits on the cage until spring. - - ------------------------- -------------------- ________________________________________________________________________________
Subject: Re: FSII covering continued
Date: Jan 07, 2010
Using 2.7 oz. Stits on the fuselage because we had some left over, and because the fuselage gets the most abuse. Used double thickness on the floor where you might put your feet and weight getting in or out. Using the last of the Poly-Tak to attach it. The rest of the airplane will be covered with uncertified 1.6 oz. dacron, attached with Certified Coatings Sure Seam cement and then the tapes and any doping overlaps etc. will be with Certified Coatings nitrate dope. Then it all gets painted with latex. We are going for minimum weight and minimum expense this time around. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280528#280528 ________________________________________________________________________________
Date: Jan 07, 2010
- Richard- Is the FSII experimental class?- I wasn't aware that you cou ld put 2 full layers on a wear surface.- How much weight difference betwe en that and an aluminum floor plate?- By the way, how is Ed doing? - ------------------------- ------------------- Bill Sullivan ------------------------- ------------------- Windsor Locks, Ct . ------------------------- ------------------- FS 447 ------------------------- ------------------- 36 degrees, beaut iful day - - ________________________________________________________________________________
Subject: Kolb Mark III for sale
Date: Jan 07, 2010
I have put my Mark III up for sale on Barnstormers. Plane has about 130 hours on it, Rotax 503 DCDI, C gearbox, 64" 3 blade IVO prop and basic instruments. Climbs 650 FPM solo and burns 3.5 GPH.Cruisee 60 mph. Also has a enclosed trailer to go with. Asking $15,250 I will sell it without the trailer and or engine if someone is interested in the airframe. If anyone is interested Email me for more details, videos and pictures. grant_richardson25(at)yahoo.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280538#280538 ________________________________________________________________________________
Date: Jan 07, 2010
Ed is pretty much back to normal, his ankle is still swollen, but he is getting around ok. Yes, the FSII is Experimental. In it's first life it weighed 488 with the 582 and all it's other assorted bells and whistles. (transponder, full day and night vfr, bulletproof lexan floorboards, funky gap seal, etc) This time around, we are hoping for MUCH less. It flew great before, can't imagine what it would do if it was much lighter, but we plan to find out. What I did to double layer the floor was just to apply one layer of fabric and shrink it, iron the edges smooth around the tubes and then put a couple coats of glue over the edges. Then laid another piece of fabric over the first, glued the edges just like any other, just like when you lay the overlap from the upper surface fabric of the wing over the fabric of the lower surface of the wing. Then iron it and shrink it tight, and then lay the dope into it. The dope will bond the two fabric pieces together and give you a flexible but very strong surface. Then when you lay some floor carpet over it, you're good. Not sure what it weighs, but I would guess less than aluminum, it's just two layers of fabric and some dope. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280554#280554 ________________________________________________________________________________
Subject: Pilot Cert Expiring ( Paper ) March 2010
Date: Jan 08, 2010
Hey Guys, I don't know if you have already talked about this...? Just thought I'd pass it along... My Repairman's Cert is Plastic ( No SSN ) But My Pilot Lic is Paper ( With SSN ) The paper is expiring March... You need to replace it with Plastic... Here are the links that talk about it... and the one to file for a new one ( FREE )... . . Gotta Fly... Mike & "Jaz" in MN . . Here's the link, you need to do this! http://www.faa.gov/licenses_certificates/airmen_certification/expiring_paper_certificates/ Dave Conrad On Jan 7, 2010, at 8:03 PM, sstanroberts(at)aol.com wrote: Anybody heard about the paper pilots lic expiring in March?? Stan 9052C http://www.faa.gov/licenses_certificates/airmen_certification/expiring_paper_certificates/ pilot certficate expiration march 2010 - Google Search -------- . . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280655#280655 ________________________________________________________________________________
From: "frank.goodnight" <frank.goodnight(at)att.net>
Subject: toe-in
Date: Jan 08, 2010
Hi all Too cold here in the valley to do much of anything except set in the house and whine about the weather.--no heat in the shop-. I put a 3/4 windshield on my firestar but still don't enjoy flying when it's below 50F. Started mounting the steel gear legs and large wheels and tires --a la Larry Cotrell-- , I've had them for about a year , too lazy to put them on. It is a fairly large project what with adapting the A/C wheels to the little matco brakes etc. also mounting a maule tail wheel. Bent and straightened the aluminium ones often enough that it's time to change. My question is-- Anyone know what is a good toe in for a firestar 2 ? Frank Goodnight cold in Brownsville ,TX ________________________________________________________________________________
Subject: Re: toe-in
Date: Jan 08, 2010
> My question is-- Anyone know what is a good toe in for a firestar 2 ? > > Frank Goodnight Frank G/Gang: When it comes to toe in, like a lot of things on our Kolbs, I believe it is a matter of dealers choice. Several things to remember when setting up main gear: 1 - Because of the design and material, there will be some slop in the installation. 2 - When brakes are applied, the mains will tend to twist the legs and toe in. I set mine up with just a tad of toe in. How much is a tad? Not much. Just enough to realize it is not neutral or toe out. I have been pretty lucky and never suffered from adverse tire wear. My buddy, John Williamson, used to scrub the tread off his tires in a short time. However, the gear legs on the Kolbra were much, much longer than the gear legs Brother Jim came up with on my MKIII. Total length of my legs is 24" with 18" exposed and 6" inside the gear leg socket. I don't get near the twist and flex a standard MKIII leg gets. I'm pretty much confined to the house. Beautiful clear blue sky and 23F. Was 17F when I got up this morning. Too dad gummed cold for the Heart of Dixie. john h mkIII ________________________________________________________________________________
Date: Jan 08, 2010
Subject: Re: : Kolb-List:
Or, you can move the gate about 600 ft and then you can T.O & L all within the front yard. (if you got the frontage). Anyway for my next home that's my dream! :-) Ron @ KFHU =============== ---- b young wrote: ============ Still, I do like the idea of raising the tail really high (over 10')....if I ever needed to. Then I could go through the gate without having to just squeeze through. Mike Welch When you get to the gate take some chalk and mark your tire position,,, when you are happy with the location, take a can of spray paint and paint a small dot, or row of dots. I would envision a trailer with a long c channel for the tail wheel. lift the tail wheel into the c channel.then push the plane back to the ramps for the main gear, have them mounted on a pivot, or teeter totter 5 ft on one side 1 ft on the other. with the plane on the ground the ramp ends would hit the ground,,,, when the plane is on the trailer, the wheels would be just past the pivot point of the ramp and hold the ramps off the ground. You may only have to roll the plane up 4 inches or so for clearance. Boyd -- kugelair.com ________________________________________________________________________________
Subject: Thanks
Date: Jan 08, 2010
I would like to publicly thank Travis of TNK for his efforts on my behalf in getting the CM gear legs heat treated. He went out of his way to help me. The folks at Kolb really try and treat their customers right, or better than right. especially considering, they know that I have already spent most of the money I will ever spend with them. Frank Goodnight Brownsville, TX ________________________________________________________________________________
Date: Jan 08, 2010
Snowmobile gloves will take care of that. I had the same problem with the Harley. Even at 45f flying that Pterodactyl scare machine got my hands numb with border line hypothermia for the rest of the body. ---- Richard Pike wrote: ============ Got a question for you Kolbers who live up Nawth and have more experience with serious deep-freeze weather than we do here in Tennessee. Was out in the hangar for a bit today, and could not keep my hands warm. Have several pairs of work gloves, ski gloves, etc. and none of them are worth beans. Have about quit flying during this part of the year because it's my hands that always get too cold first. Suggestions? Online sources to buy them? Thanks Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280410#280410 -- kugelair.com ________________________________________________________________________________
Subject: Re: Thanks
Date: Jan 08, 2010
Frank, I concur. Unfortunately, I've spent very little time at TNK, but the folk I met there are top-notch; the very best of people. The world doesn't have nearly enough like them. All the best to you and TNK for 2010 and beyond. Fair winds, Russ K On Jan 8, 2010, at 12:02 PM, frank.goodnight wrote: > > > > I would like to publicly thank Travis of TNK for his efforts on my > behalf in getting the CM gear legs heat treated. He went out of > his way to help me. > The folks at Kolb really try and treat their customers right, or > better than right. especially considering, they know that I have > already spent most of the > money I will ever spend with them. > > Frank Goodnight > Brownsville, TX > > ________________________________________________________________________________
Date: Jan 08, 2010
Subject: Re: Comedy act for all Kolbers
Wow,Wow & Wow again ! That guy can really fly that Cub. I've watched it at least a dozen times now. AV Web Flash, Jan 4, 2010 also has a link to that video including an interview with Kyle Franklin about how hard it is to fly that routine. Go to: _http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_KyleFranklin_A irShowComedyAct_201761-1.html_ (http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_KyleFranklin_AirShowComedyAct_201761-1.html) On a Kolb note, I just finished installing a much larger trim tab on the aileron to counter a tendency for the left wing to go down. I had a small metal tab before, but it just wasn't up to the job. I followed the Kolb plan and used a piece of .063 Lexan. Now, if I can just get some decent weather to test it out (it's 20F, light snow on the ground and windy). As per the Kolb plan, If the tab is too large, I'll just trim some off until it flies true. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 1/4/2010 7:01:34 P.M. Eastern Standard Time, undoctor(at)ptd.net writes: --> Kolb-List message posted by: David Kulp _undoctor(at)ptd.net_ (mailto:undoctor(at)ptd.net) Everyone! My bro sent me this link. What a hoot!!! You'll love it. Dave Kulp Bethlehem, PA http://www.franklinairshow.com/Video/Comedy%202010%20Net.WMV ________________________________________________________________________________
Subject: Re: toe-in
Date: Jan 09, 2010
Frank, If you pulled your plane into a trailer often,a little toe-in becomes a lot of toe out when going backward,and it gets hard to pull like that.So I tried for 0 when setting it up and it still handled fine. G.Aman -----Original Message----- From: frank.goodnight <frank.goodnight(at)att.net> Sent: Fri, Jan 8, 2010 10:18 am Subject: Kolb-List: toe-in t> Hi all Too cold here in the valley to do much of anything except set in the house and whine about the weather.--no heat in the shop-. I put a 3/4 windshield on my firestar but still don't enjoy flying when it 's below 50F. Started mounting the steel gear legs and large wheels and tires --a la La rry Cotrell-- , I've had them for about a year , too lazy to put them on. It is a fairly large project what with adapting the A/C wheels to the litt le matco brakes etc. also mounting a maule tail wheel. Bent and straightened the aluminium ones often enough that it's time to change. My question is-- Anyone know what is a good toe in for a firestar 2 ? Frank Goodnight cold in Brownsville ,TX ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Subject: lawsuit against Kolb owner widow
Date: Jan 09, 2010
http://www.chattanoogan.com/articles/article_166175.asp Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280811#280811 ________________________________________________________________________________
Subject: Re: lawsuit against Kolb owner widow
Date: Jan 09, 2010
Seems the wrong brother died in the crash. ----- Original Message ----- From: "grantr" <grant_richardson25(at)yahoo.com> Sent: Saturday, January 09, 2010 11:57 AM Subject: Kolb-List: lawsuit against Kolb owner widow > > http://www.chattanoogan.com/articles/article_166175.asp > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=280811#280811 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 09, 2010
Subject: MV date decided yet?
John H -I think you were asking folks which weekend would work best for the MV fly-in this year. Have you had any responses? Has a decision been made? I'm hoping to be there - and want to be sure my calendar is clear for which-ever weekend is decided on. (Right now it makes no difference.) Arty TrostMaxair DrifterSandy, Oregon www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Subject: Re: MV date decided yet?
Date: Jan 09, 2010
Hi Arty/Gang: The 2010 Unplanned/Unorgnized Kolb Flyin Monument Valley, Utah will be held from Friday, 21 May until Sunday, 23 May 2010. Normally, we get there sometime on Thursday. If you want to get there a week early, that's ok too. If you want to stay late, that's ok, but most of us will be heading out for other places, and home, on Sunday morning. I'll be flying to the Rock House, 7 miles south of Burns Junction, Oregon, along with anybody else that wants to tag along. Last year there were four of us that flew from MV, and joined up with three more Kolbs at Larry and Karen Cottrell's. Needless to say, we had a grand and exciting time. Amazing at the varied inclement weather conditions that can be handed out by Mother Nature in the SE corner of Oregon. On the other hand, she can also hand out some beautiful flying days to take advantage of that part of our great country. Glad to hear Arty is going to join us again, even though she flies one of those other ultralights. ;-) BTW: Everyone is welcome at our flyin, no matter what you fly or how you get there. Remember though, some of us fly as much as 20 hours to get there, so if we aren't ready to jump back in the air and fly circles around MV, it is because we are getting old and lazy, and still have 50 or more hours to fly before we get back home. I am looking forward to this year's flyin. Hope to see all of you there. john h mkIII I think you were asking folks which weekend would work best for the MV fly-in this year. Have you had any responses? Has a decision been made? I'm hoping to be there - and want to be sure my calendar is clear for which-ever weekend is decided on. (Right now it makes no difference.) Arty Trost ________________________________________________________________________________
Date: Jan 09, 2010
I want to add that if anyone is so inclined, they are also welcome at the Rock House afterward. There is plenty of space for planes and people. Larry Cottrell Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Saturday, January 09, 2010 5:48 PM Subject: Re: Kolb-List: MV date decided yet? Hi Arty/Gang: The 2010 Unplanned/Unorgnized Kolb Flyin Monument Valley, Utah will be held from Friday, 21 May until Sunday, 23 May 2010. Normally, we get there sometime on Thursday. If you want to get there a week early, that's ok too. If you want to stay late, that's ok, but most of us will be heading out for other places, and home, on Sunday morning. I'll be flying to the Rock House, 7 miles south of Burns Junction, Oregon, along with anybody else that wants to tag along. Last year there were four of us that flew from MV, and joined up with three more Kolbs at Larry and Karen Cottrell's. Needless to say, we had a grand and exciting time. Amazing at the varied inclement weather conditions that can be handed out by Mother Nature in the SE corner of Oregon. On the other hand, she can also hand out some beautiful flying days to take advantage of that part of our great country. Glad to hear Arty is going to join us again, even though she flies one of those other ultralights. ;-) BTW: Everyone is welcome at our flyin, no matter what you fly or how you get there. Remember though, some of us fly as much as 20 hours to get there, so if we aren't ready to jump back in the air and fly circles around MV, it is because we are getting old and lazy, and still have 50 or more hours to fly before we get back home. I am looking forward to this year's flyin. Hope to see all of you there. john h mkIII I think you were asking folks which weekend would work best for the MV fly-in this year. Have you had any responses? Has a decision been made? I'm hoping to be there - and want to be sure my calendar is clear for which-ever weekend is decided on. (Right now it makes no difference.) Arty Trost ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 01/09/10 19:35:00 ________________________________________________________________________________
Date: Jan 09, 2010
Will the ice be melted at the Rock House by May? I am going to have to take an ice pick with me to Gantt International and chip my mkIII out of the hanger if I am going to attempt aviation tomorrow. If it stays in the 30's, I ain't gonna go. john h mkIII DO NOT ATTEMPT I want to add that if anyone is so inclined, they are also welcome at the Rock House afterward. There is plenty of space for planes and people. Larry Cottrell ________________________________________________________________________________
Date: Jan 09, 2010
I will guarantee that the ice will be melted and the wind no more than 6 to 10 down the runway! Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Saturday, January 09, 2010 8:09 PM Subject: Re: Kolb-List: MV date decided yet? Will the ice be melted at the Rock House by May? I am going to have to take an ice pick with me to Gantt International and chip my mkIII out of the hanger if I am going to attempt aviation tomorrow. If it stays in the 30's, I ain't gonna go. john h mkIII DO NOT ATTEMPT I want to add that if anyone is so inclined, they are also welcome at the Rock House afterward. There is plenty of space for planes and people. Larry Cottrell ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 01/09/10 19:35:00 ________________________________________________________________________________
Date: Jan 10, 2010
This is an amazing tale - and unless someone went to an awful lot of troubl e to doctor the pics, probably true.- www.thehulltruth.com/dockside-chat/260677-duct-tape-story.html Enjoy! Arty www.LessonsFromTheEdge.com/uladventure2009.htm =0A =0A"Life's a daring adventure or nothing" =0A Helen Keller =0A =0A"I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Subject: Re:
Date: Jan 10, 2010
Hi Arty, I hope this new year find you and yours happy and well. Unfortunately the Iink you have provided doesnt seem to work. :( Best Regards Carlos Grageda Enjoying life at the edge of Washington, ... well sorta... maybe... LOL ----- Original Message ----- From: TheWanderingWench To: Arty Trost Sent: Sunday, January 10, 2010 9:57 PM This is an amazing tale - and unless someone went to an awful lot of trouble to doctor the pics, probably true. www.thehulltruth.com/dockside-chat/260677-duct-tape-story.html Enjoy! Arty www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Jan 11, 2010
John Hauck wrote: > > > The 2010 Unplanned/Unorganized Kolb Flyin Monument Valley, Utah will be held from Friday, 21 May until Sunday, 23 May 2010. > > With the discussions concerning this year's Monument Valley gathering, it was a good time to update the material from past years. Take a look.... might be the incentive to go if you hadn't planned on it..... Added the miscellaneous material received from a couple of people for 2006. Not very organized (goes with the event). Also added material that John Hauck sent me for 2009. A little better organized. If any of you have material from any of the years and want it added, send it on to me. Pictures with words to go with them would be great. And for those of you that do make it this year, send the stuff and we'll put it up too. Click on http://gtalexander.home.att.net and then "Monument Valley Gatherings" -------- George Alexander FS II R503 N709FS http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=280993#280993 ________________________________________________________________________________
Subject: Re: Kolb Mark II for sale
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Jan 11, 2010
Husband said, "Are you SURE you want to sell it?" I said, "No! I'm not sure!" He said, "You won't be pregnant forever." That meant I had the green light from him to keep it (and my son had been begging me to keep it). When I went to mom's her preacher preached about being careful not to make permanent decisions for temporary situations, not sure what he was alluding to but I applied to it to my situation. So Merry Dawn was officially taken off the market yesterday. I'm keeping her! :) -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281008#281008 ________________________________________________________________________________
Date: Jan 11, 2010
cristalclear13 wrote: > Husband said, "Are you SURE you want to sell it?" I said, "No! I'm not sure!" He said, "You won't be pregnant forever." That meant I had the green light from him to keep it (and my son had been begging me to keep it). When I went to mom's her preacher preached about being careful not to make permanent decisions for temporary situations, not sure what he was alluding to but I applied to it to my situation. > > So Merry Dawn was officially taken off the market yesterday. I'm keeping her! :) Whew.... excellent idea ;). You'll hear that right now is a particularly bad time to try to sell an aircraft, but actually, I don't think there's ever going to be a good time to sell one come around again for a very long time. If ever. Particularly for really high quality planes like the Kolb - the replacement costs are simply skyrocketing and don't show any signs of reversing and coming back down. It's cheaper to just keep it even if you have to store it for a while - that didn't used to be true but it is now. Unless it's got a problem, is a real mismatch for your mission or you have/want to give up flying, selling kind of doesn't make any sense anymore.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281022#281022 ________________________________________________________________________________
Date: Jan 11, 2010
> With the discussions concerning this year's Monument Valley gathering, it was a good time to update the material from past years. Take a look.... might be the incentive to go if you hadn't planned on it..... > > Added the miscellaneous material received from a couple of people for > 2006. Not very organized (goes with the event). > Click on http://gtalexander.home.att.net and then "Monument Valley > Gatherings" > > -------- > George Alexander George/Gang: A special pat on the back for the time and hard work you volunteer to do to keep Kolb history. If you all have captions for the photos George has posted to his web site, please send them to him. I am the laziest of that bunch, but through George's goading, I have gotten captions for last year's MV Flyin, and will have some more soon for the 2006 MV Flyin. Those captions are as important as the photos. john h mkIII - 11F with a warming trend on the way. ________________________________________________________________________________
Date: Jan 11, 2010
YAY!! I am happy for you in BOTH ways !! :D chris ambrose M3x/jABIRU N327CS 89.0 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281031#281031 ________________________________________________________________________________
Date: Jan 11, 2010
Subject: Re: Weather
- John- You mentioned that it was 11 degrees down there this morning.- What is the freeze temperature on your coolant?- 912 series engines are t oo expensive to have freeze. -Don't forget the other vehicles! - ------------------------- ------------------------ Bi ll Sullivan ------------------------- ------------------------ Wi ndsor Locks, Ct. ------------------------- ------------------------- FS 447 ------------------------- ------------------------ 34 degrees and clear ________________________________________________________________________________
Date: Jan 11, 2010
Hope it is higher than 11F. ;-) john h mkIII John- You mentioned that it was 11 degrees down there this morning. What is the freeze temperature on your coolant? 912 series engines are too expensive to have freeze. Don't forget the other vehicles! Bill Sullivan Windsor Locks, Ct. FS 447 34 degrees and clear ________________________________________________________________________________
Date: Jan 11, 2010
John=2C You mean "lower" than 11F. You hope the coolant will freeze lower than 1 1F. We knew what you meant=2C tho Mike Welch Drained ALL coolant out of my diesel air compressor just to make sure it di dn't freeze. It got down to zero a couple days ago. From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Re: Weather Date: Mon=2C 11 Jan 2010 14:13:56 -0600 Hope it is higher than 11F. =3B-) john h mkIII John- You mentioned that it was 11 degrees down there this morning. What is the freeze temperature on your coolant? 912 series engines are too exp ensive to have freeze. Don't forget the other vehicles! Bill Sullivan Windsor Locks=2C Ct. FS 447 34 degrees and clear _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Jan 11, 2010
Subject: Kolb List Refusal to Accept E-mail
Kolbers, Evidently matronics.com uses a service provided by barracudacentral.com called "Barracuda Reputation" than rates IP addresses and offers a service that lets one block IP address that pass too much spam, etc, etc. This may seem like a good idea to block IP addresses that pass a high rate of spam etc. but it is some what insidious in that when you block an IP address you shut down all other communication. In this case I could not email the List or Matt about the problem. I Googled and called Barracuda. I asked it they directly contacted the owner of the IP address that was causing problems, and the answer was no they do not. They just compile the data and let their customers decide what to do. They are only providing information and a means for others to take action there for they can suffer no liability or responsibility. The upshot is that when Matronics and others, who use this service, they also close down the passage of legitimate information as well as the spammers etc. that pass through a problem IP address. If you get a message like the one below, call Barracuda at 408-342-5400. They will give you a case number and call you back. When they call, express some displeasure at the ham fisted approach to knocking you off your favorite list and ask them to notify the owner of the offending IP address. In a couple of hours the block will be removed. Also contact your email provider and let them know that one of their IP addresses is being blocked. This gives the provider a chance to check and clean out the server. I know the internet pipe line is under attack. Since it does not discriminate between the spam, and the legitimate user, IP address blocking is not the answer. It is much like blocking the flow of water or electricity because one person on the system did not pay their bill. Jack B. Hart FF004 Winchester, IN Date: Fri, 8 Jan 2010 11:23:37 -0500 (EST) From: MAILER-DAEMON(at)s6mqueue.hosts.gabmidwest.com (Mail Delivery System) Subject: Undelivered Mail Returned to Sender Auto-Submitted: auto-replied This is the mail system at host s6mqueue.hosts.gabmidwest.com. I'm sorry to have to inform you that your message could not be delivered to one or more recipients. It's attached below. For further assistance, please send mail to If you do so, please include this problem report. You can delete your own text from the attached returned message. The mail system : host barracuda.matronics.com[64.81.74.21] said: 554 Service unavailable; Client host [s6mqueue.hosts.gabmidwest.com] blocked using Barracuda Reputation; http://bbl.barracudacentral.com/q.cgi?ip=69.89.182.162 (in reply to end of DATA command) Reporting-MTA: dns; s6mqueue.hosts.gabmidwest.com X-Postfix-Queue-ID: 88C674202CD X-Postfix-Sender: rfc822; jbhart(at)onlyinternet.net Arrival-Date: Fri, 8 Jan 2010 11:23:35 -0500 (EST) Final-Recipient: rfc822; kolb-list(at)matronics.com Original-Recipient: rfc822;kolb-list(at)matronics.com Action: failed Status: 5.0.0 Remote-MTA: dns; barracuda.matronics.com Diagnostic-Code: smtp; 554 Service unavailable; Client host [s6mqueue.hosts.gabmidwest.com] blocked using Barracuda Reputation; http://bbl.barracudacentral.com/q.cgi?ip=69.89.182.162 Received: from y6s7o5 (unknown [69.89.182.162]) by s6mqueue.hosts.gabmidwest.com (Postfix) with SMTP id 88C674202CD X-Sender: jbhart(at)mail.onlyinternet.net Date: Fri, 08 Jan 2010 14:45:52 -0500 From: "Jack B. Hart" <jbhart(at)onlyinternet.net> Subject: Re: Kolb-List: toe-in In-Reply-To: <028EBFA3-247C-4587-99B0-9EEB9753BB57(at)att.net> Mime-Version: 1.0 Content-Type: text/plain; charset="us-ascii" > >My question is-- Anyone know what is a good toe in for a firestar 2 ? > ________________________________________________________________________________
Date: Jan 11, 2010
Have hope. Four days ago the temps here in SE Kansas were in the minus single digits with wind chills at almost minus 30. Today it's almost 50. Rick Girard On Mon, Jan 11, 2010 at 2:29 PM, Mike Welch wrote: > John, > > You mean "lower" than 11F. You hope the coolant will freeze *lower*than 11F. We knew what you meant, tho > > Mike Welch > Drained ALL coolant out of my diesel air compressor just to make sure it > didn't freeze. It got down to zero a couple days ago. > > ------------------------------ > From: jhauck(at)elmore.rr.com > > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Weather > Date: Mon, 11 Jan 2010 14:13:56 -0600 > > > Hope it is higher than 11F. ;-) > > john h > mkIII > > > John- You mentioned that it was 11 degrees down there this morning. > What is the freeze temperature on your coolant? 912 series engines are too > expensive to have freeze. Don't forget the other vehicles! > > Bill Sullivan > Windsor Locks, Ct. > FS 447 > 34 degrees and clear > > ** > > * > > ttp://www.matronics.com/Navigator?Kolb-Listronics.comww.matronics.com/contribution > * > > > ------------------------------ > Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. > > * > > * > > ________________________________________________________________________________
Date: Jan 11, 2010
Subject: Re: Kolb List Refusal to Accept E-mail
I can understand your frustration, but you might want to contact your ISP, too. They control what flows through their IP address. If Barracuda is right about the amount of spam coming from that IP address, I'd be concerned about using them for my email service. Serving abusive spammers doesn't say much for the ISP's ethics. Charlie On 1/11/2010 3:07 PM, Jack B. Hart wrote: > --> Kolb-List message posted by: "Jack B. Hart" > > Kolbers, > > Evidently matronics.com uses a service provided by barracudacentral.com > called "Barracuda Reputation" than rates IP addresses and offers a service > that lets one block IP address that pass too much spam, etc, etc. This may > seem like a good idea to block IP addresses that pass a high rate of spam > etc. but it is some what insidious in that when you block an IP address you > shut down all other communication. In this case I could not email the List > or Matt about the problem. > > I Googled and called Barracuda. I asked it they directly contacted the > owner of the IP address that was causing problems, and the answer was no > they do not. They just compile the data and let their customers decide what > to do. They are only providing information and a means for others to take > action there for they can suffer no liability or responsibility. The upshot > is that when Matronics and others, who use this service, they also close > down the passage of legitimate information as well as the spammers etc. that > pass through a problem IP address. > > If you get a message like the one below, call Barracuda at 408-342-5400. > They will give you a case number and call you back. When they call, express > some displeasure at the ham fisted approach to knocking you off your > favorite list and ask them to notify the owner of the offending IP address. > In a couple of hours the block will be removed. Also contact your email > provider and let them know that one of their IP addresses is being blocked. > This gives the provider a chance to check and clean out the server. > > I know the internet pipe line is under attack. Since it does not > discriminate between the spam, and the legitimate user, IP address blocking > is not the answer. It is much like blocking the flow of water or > electricity because one person on the system did not pay their bill. > > Jack B. Hart FF004 > Winchester, IN > > > Date: Fri, 8 Jan 2010 11:23:37 -0500 (EST) > From: MAILER-DAEMON(at)s6mqueue.hosts.gabmidwest.com (Mail Delivery System) > Subject: Undelivered Mail Returned to Sender > To: jbhart(at)onlyinternet.net > Auto-Submitted: auto-replied > > This is the mail system at host s6mqueue.hosts.gabmidwest.com. > > I'm sorry to have to inform you that your message could not > be delivered to one or more recipients. It's attached below. > > For further assistance, please send mail to > > If you do so, please include this problem report. You can > delete your own text from the attached returned message. > > The mail system > > : host barracuda.matronics.com[64.81.74.21] said: 554 > Service unavailable; Client host [s6mqueue.hosts.gabmidwest.com] blocked > using Barracuda Reputation; > http://bbl.barracudacentral.com/q.cgi?ip=69.89.182.162 (in reply to end of > DATA command) > Reporting-MTA: dns; s6mqueue.hosts.gabmidwest.com > X-Postfix-Queue-ID: 88C674202CD > X-Postfix-Sender: rfc822; jbhart(at)onlyinternet.net > Arrival-Date: Fri, 8 Jan 2010 11:23:35 -0500 (EST) > > Final-Recipient: rfc822; kolb-list(at)matronics.com > Original-Recipient: rfc822;kolb-list(at)matronics.com > Action: failed > Status: 5.0.0 > Remote-MTA: dns; barracuda.matronics.com > Diagnostic-Code: smtp; 554 Service unavailable; Client host > [s6mqueue.hosts.gabmidwest.com] blocked using Barracuda Reputation; > http://bbl.barracudacentral.com/q.cgi?ip=69.89.182.162 > Received: from y6s7o5 (unknown [69.89.182.162]) > by s6mqueue.hosts.gabmidwest.com (Postfix) with SMTP id 88C674202CD > Message-Id:<3.0.6.32.20100108144552.007dc7c0(at)mail.onlyinternet.net> > X-Sender: jbhart(at)mail.onlyinternet.net > Date: Fri, 08 Jan 2010 14:45:52 -0500 > To: kolb-list(at)matronics.com > From: "Jack B. Hart"<jbhart(at)onlyinternet.net> > Subject: Re: Kolb-List: toe-in > In-Reply-To:<028EBFA3-247C-4587-99B0-9EEB9753BB57(at)att.net> > Mime-Version: 1.0 > Content-Type: text/plain; charset="us-ascii" > > At 09:18 > ________________________________________________________________________________
Date: Jan 11, 2010
I was having the same problem, I sent Matt an E-mail and he fixed it for me. Lanny FSII ________________________________________________________________________________
Date: Jan 11, 2010
Matt ran his weasel message a short time back, wonder if that had something to do with it. I don't recall seeing it having been run for some time. It is a operation to detect bogus email addresses spammer have used to subscribe to his mail list so they can post spam messages - because the weasel message bounces back if it is a bogus address it deletes that subscribed address from the list. It tells you not to replay back, if you did you may have had your address automatically deleted. jerb At 03:47 PM 1/11/2010, you wrote: > >I was having the same problem, I sent Matt an E-mail and he fixed it >for me. Lanny FSII > > ________________________________________________________________________________
Date: Jan 12, 2010
Cristal, Great news there! The world needs more Kolb flyin' Mamas. Good for you! -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281145#281145 ________________________________________________________________________________
Date: Jan 12, 2010
Kolb flyin' Mama...........yeah.........sounds good to me Where can I git me wunna dem ? [Wink] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281173#281173 ________________________________________________________________________________
Subject: finding Kolb photos
Date: Jan 12, 2010
This may be old hat to some of you but it was a great find for me. I just discovered Google Images http://images.google.com/ is an easy way to find photos and other images of Kolb aircraft that have been posted virtually anywhere on the internet. Go to the link I just provided and type in Kolb Aircraft and to see what I mean. I then typed in Kolb Slingshot and got a lot of Kolb Slingshot photos but also some slingshot weapons so I then put Kolb Slingshot inside quotes "kolb slingshot" and it narrowed it down to only the aircraft, including several of my slingshot. -------- Thom Riddle Buffalo, NY Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x31 I have reached an age when, if someone tells me to wear socks, I don't have to. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281175#281175 ________________________________________________________________________________
Subject: Kolb Technical Site
Date: Jan 12, 2010
The SeaRey community has a myfamily.com webiste that is specifically used f or technical questions=2C photos=2C advice and information that is useful t o aviators that own a SeaRey or a SeaRey kit. It is a great tool for anyone with a SeaRey. I highly recommend that the Kolb community uses this websit e. It has helped me a whole lot. It is approx $100 per year=2C but is quick ly paid off with small donations... Fly safe! Daniel Myers FS II (sold) SeaRey _________________________________________________________________ Hotmail: Free=2C trusted and rich email service. ________________________________________________________________________________
Date: Jan 13, 2010
John Happy 2010, and I hope your 'warming trend' has arrived. Nothing colder than a warm state that gets a sudden cold snap. I've near-fruz in Pensacola more than once. I feel sorry for the many people, and kids, who don't have warm clothes or any insulaion in their houses. But you have thoughts of MV10 to keep you warm! Fair winds, Russ ________________________________________________________________________________
Date: Jan 13, 2010
Subject: 582 fuel system
I've got a series or parallel question about installing a facet boost pump. I'm planning on intalling a facet pump between my fuel tank and the he mikuni engine pump. I'm doing it in series just to keep it simple. If the facet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow the boost pump fuel to get to the carbs? Those of you with similar systems I'd appreciate your advice. Mark Rinehart ________________________________________________________________________________
Subject: Re: 582 fuel system
Date: Jan 13, 2010
> I've got a series or parallel question about installing a facet boost pump. I'm planning on intalling a facet pump between my fuel tank and the he mikuni engine pump. I'm doing it in series just to keep it simple. If the facet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow the boost pump fuel to get to the carbs? Those of you with similar systems I'd appreciate your advice. > > Mark Rinehart Mike R/Gang: You'll get all kinds of responses to this one. I started using two mikuni fuel pumps on my first Kolb, an Ultrastar. The Cuyuna ULII02 had two crank case pressure ports, one for each cylinder. I ran the Mikunis, one off each port, in series. Used a back up Facet Electronic boost pump in my 447 powered Firestar plumbed in series with excellent results. The Mikuni pulled fuel through the Facet when the Facet was shut down, normally at all times except during take off, landing, and low level flight. For the last 3,000 hours (minus 12) I have used a Facet and Mikuni or engine driven pump plumbed in series on my MKIII with no problems encountered. Usually, if a Mikuni pulse pump fails, it will be one of two little ears on the diaphragm that serve as the intake and outlet valves. I know of no Mikuni diaphragm that has failed to allow fuel to be pumped through it and outside the pump. I like the fuel pump plumbed in series. Works for me. You'll have to choose which way you want to go. john h mkIII ________________________________________________________________________________
Date: Jan 13, 2010
Yes it will, the Mikuni will flow through if it fails to pump also and let the boost pump keep you flying. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of mark rinehart Sent: Wednesday, January 13, 2010 12:06 PM Subject: Kolb-List: 582 fuel system I've got a series or parallel question about installing a facet boost pump. I'm planning on intalling a facet pump between my fuel tank and the he mikuni engine pump. I'm doing it in series just to keep it simple. If the facet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow the boost pump fuel to get to the carbs? Those of you with similar systems I'd appreciate your advice. Mark Rinehart Checked by AVG - http://www.avg.com 07:35:00 -- We are a community of 6 million users fighting spam. The Professional version does not have this message ________________________________________________________________________________
Date: Jan 13, 2010
At 12:05 PM 1/13/2010, mark rinehart wrote: > >I've got a series or parallel question about installing a facet boost >pump. I'm planning on intalling a facet pump between my fuel tank and the >he mikuni engine pump. I'm doing it in series just to keep it simple. If >the facet fails it should still flow thru so the mikuni will be able to >draw fuel from the tank. But what if the mikuni fails? Will it flow thru >and allow the boost pump fuel to get to the carbs? Those of you with >similar systems I'd appreciate your advice. If the Mikuni pump's check valves fail, the boost pump will pump fuel through the pump and keep the engine running. OTOH, if the Mikuni's diaphragm fails, the boost pump will pump fuel back up the pulse line and fill the crankcase. -Dana -- No trees were harmed in the transmission of this message. However, a rather large number of electrons were temporarily inconvenienced. ________________________________________________________________________________
Date: Jan 13, 2010
Mark and Kolb guys=2C I'm curious. I don't have much experience with diaphram pumps and all=2C but it seems odd to want to design a series fuel pumping system. I mean =2C I know a series system would work great and all....but how would you kn ow you lost one of the pumps=2C if the other pump can do all the work? Let's say=2C for example=2C the last flight you had=2C your primary pump blew out=2C and the backup kept you flying=2C how would you know??? You'd be toolin' along thinking you had both pumpers up to snuff=2C but you would n't. Unless you verified each and every flight that BOTH pumps were operating fine=2C you could be relying a false sense of security. Wouldn't you? If it were me=2C and maybe that's just my way of thinking=2C I think I wo uld like a parallel fuel system. Here why I think this=3B if my primary s ystem failed=2C it would kick on the backup system (and a big bright red pa nel light). The light would alert me that the primary pump needs attention =2C and when I landed=2C I could take care of the problem=2C but in the mea ntime=2C my backup is doing it's job. For a parallel design=2C a primary system could easily have a low-pressur e switch ($30 McMaster Carr) that if activated (due to a zero or very low f uel pressure)=2C it would turn on the backup pump. This method is close to how my turbo "high fuel delivery" fuel system is designed and operated. I realize a series fuel system=2C with two fuel pumps=2C CAN work. I kno w that. But=2C how would you know that every flight both are working prope rly? Just some thoughts on the matter....... Mike Welch MkIII CX > I've got a series or parallel question about installing a facet boost pum p. I'm planning on intalling a facet pump between my fuel tank and the he m ikuni engine pump. I'm doing it in series just to keep it simple. If the fa cet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow t he boost pump fuel to get to the carbs? Those of you with similar systems I 'd appreciate your advice. > > Mark Rinehart _________________________________________________________________ Hotmail: Free=2C trusted and rich email service. ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Jan 13, 2010
Mike Your system sounds great and should work well but I like to keep things simple. My fuel system requires a electric fuel pump. I have two electric pumps in series, one is driven by the ignition circuit. The secondary pump by separate switched circuit. My starting routine is prime the fuel system using the back up pump. I watch the fuel flow through a short piece of transparent fuel line till the float bowls are full. I then turn off the secondary system and start the engine. I can see fuel flow and hear the faucet pump running when I turn on the back up pump. I know the back up pump test works because the faucet pump died a few years back and its need for replacement was very noticeable. I can hear the primary pump running when the ignition is turned on. I also know if the primary pump fails the engine will quit fairly quick and while still on the ground. I had to disconnect the primary pump power wires to test this. Before takeoff or landing I turn on the back up pump. It works for me. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Wednesday, January 13, 2010 2:04 PM Subject: RE: Kolb-List: 582 fuel system Mark and Kolb guys, I'm curious. I don't have much experience with diaphram pumps and all, but it seems odd to want to design a series fuel pumping system. I mean, I know a series system would work great and all....but how would you know you lost one of the pumps, if the other pump can do all the work? Let's say, for example, the last flight you had, your primary pump blew out, and the backup kept you flying, how would you know??? You'd be toolin' along thinking you had both pumpers up to snuff, but you wouldn't. Unless you verified each and every flight that BOTH pumps were operating fine, you could be relying a false sense of security. Wouldn't you? If it were me, and maybe that's just my way of thinking, I think I would like a parallel fuel system. Here why I think this; if my primary system failed, it would kick on the backup system (and a big bright red panel light). The light would alert me that the primary pump needs attention, and when I landed, I could take care of the problem, but in the meantime, my backup is doing it's job. For a parallel design, a primary system could easily have a low-pressure switch ($30 McMaster Carr) that if activated (due to a zero or very low fuel pressure), it would turn on the backup pump. This method is close to how my turbo "high fuel delivery" fuel system is designed and operated. I realize a series fuel system, with two fuel pumps, CAN work. I know that. But, how would you know that every flight both are working properly? Just some thoughts on the matter....... Mike Welch MkIII CX > I've got a series or parallel question about installing a facet boost pump. I'm planning on intalling a facet pump between my fuel tank and the he mikuni engine pump. I'm doing it in series just to keep it simple. If the facet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow the boost pump fuel to get to the carbs? Those of you with similar systems I'd appreciate your advice. > > Mark Rinehart ------------------------------------------------------------------------- ----- Hotmail: Free, trusted and r01/' target='_new'>Get it now. ________________________________________________________________________________
Date: Jan 13, 2010
capt_riney(at)yahoo.com wrote: > I've got a series or parallel question about installing a facet boost pump. I'm planning on intalling a facet pump between my fuel tank and the he mikuni engine pump. I'm doing it in series just to keep it simple. If the facet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow the boost pump fuel to get to the carbs? Those of you with similar systems I'd appreciate your advice. > > Mark Rinehart There's generally little advantage to adding the electric pump and a couple of disadvantages. The mikuni pneumatic pumps are exceedingly reliable and, in a Kolb installation, provide plenty of vacuum to draw the fuel up from the tank to the engine. The primary disadvantages are, in my view, enough to decide against adding the boost pump: - the electric pumps add a small amount of drag when off from the check valve. - additional complexity is added in the form of the electrics, the switch, the additional procedures to follow for its use. - more troubleshooting needed when there is a fuel draw problem, as you've already pretty much correctly alluded to here ;). As I said, the pneumatic pumps are exceptionally reliable and when simply used by themselves yeild the simplest and easy to use/maintain system. I've used them for years and many hundreds of hours and have never had one fail. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281325#281325 ________________________________________________________________________________
Date: Jan 13, 2010
Rick N.=2C The design of your system sounds like I was asking about. Your ability t o verify each pump=2C prior to each flight=2C is the kind of assure I was w ondering about. It appears as though you have everything covered. But=2C Rick=2C is your fuel delivery a true "series" design? Mike Welch From: NeilsenRM(at)comcast.net Subject: Re: Kolb-List: 582 fuel system Date: Wed=2C 13 Jan 2010 15:12:13 -0500 Mike Your system sounds great and should work well but I like to keep things sim ple. My fuel system requires a electric fuel pump. I have two electric pumps in series=2C one is driven by the ignition circuit. The secondary pump by sepa rate switched circuit. My starting routine is prime the fuel system using t he back up pump. I watch the fuel flow through a short piece of transparent fuel line till the float bowls are full. I then turn off the secondary sys tem and start the engine. I can see fuel flow and hear the faucet pump runn ing when I turn on the back up pump. I know the back up pump test works bec ause the faucet pump died a few years back and its need for replacement was very noticeable. I can hear the primary pump running when the ignition is turned on. I also know if the primary pump fails the engine will quit fair ly quick and while still on the ground. I had to disconnect the primary pum p power wires to test this. Before takeoff or landing I turn on the back up pump. It works for me. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: Mike Welch Sent: Wednesday=2C January 13=2C 2010 2:04 PM Subject: RE: Kolb-List: 582 fuel system Mark and Kolb guys=2C I'm curious. I don't have much experience with diaphram pumps and all=2C but it seems odd to want to design a series fuel pumping system. I mean =2C I know a series system would work great and all....but how would you kn ow you lost one of the pumps=2C if the other pump can do all the work? Let's say=2C for example=2C the last flight you had=2C your primary pump blew out=2C and the backup kept you flying=2C how would you know??? You'd be toolin' along thinking you had both pumpers up to snuff=2C but you would n't. Unless you verified each and every flight that BOTH pumps were operating fine=2C you could be relying a false sense of security. Wouldn't you? If it were me=2C and maybe that's just my way of thinking=2C I think I wo uld like a parallel fuel system. Here why I think this=3B if my primary s ystem failed=2C it would kick on the backup system (and a big bright red pa nel light). The light would alert me that the primary pump needs attention =2C and when I landed=2C I could take care of the problem=2C but in the mea ntime=2C my backup is doing it's job. For a parallel design=2C a primary system could easily have a low-pressur e switch ($30 McMaster Carr) that if activated (due to a zero or very low f uel pressure)=2C it would turn on the backup pump. This method is close to how my turbo "high fuel delivery" fuel system is designed and operated. I realize a series fuel system=2C with two fuel pumps=2C CAN work. I kno w that. But=2C how would you know that every flight both are working prope rly? Just some thoughts on the matter....... Mike Welch MkIII CX > I've got a series or parallel question about installing a facet boost pum p. I'm planning on intalling a facet pump between my fuel tank and the he m ikuni engine pump. I'm doing it in series just to keep it simple. If the fa cet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow t he boost pump fuel to get to the carbs? Those of you with similar systems I 'd appreciate your advice. > > Mark Rinehart Hotmail: Free=2C trusted and r01/' target='_new'>Get it now. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Jan 13, 2010
Mike, Richard, et al, I run a Facet in parallel in both my aircraft. I know it's running when I turn it on before start up by its thumping. I turn it off to taxi and if the engine dies I know I have a problem with the pneumatic pump. Once I do a runup and check the mags, I turn the Facet back on for take off. When I reach my cruising altitude I turn it off until I'm back in the pattern. I turn it on again for landing. If I'm just staying in the pattern I leave it on. Never had a problem with either aircraft. Rick Girard On Wed, Jan 13, 2010 at 3:29 PM, Mike Welch wrote: > Rick N., > > The design of your system sounds like I was asking about. Your ability > to verify each pump, prior to each flight, is the kind of assure I was > wondering about. It appears as though you have everything covered. > > But, Rick, is your fuel delivery a true "series" design? > > Mike Welch > > ------------------------------ > From: NeilsenRM(at)comcast.net > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: 582 fuel system > Date: Wed, 13 Jan 2010 15:12:13 -0500 > > Mike > > Your system sounds great and should work well but I like to keep things > simple. > > My fuel system requires a electric fuel pump. I have two electric pumps in > series, one is driven by the ignition circuit. The secondary pump by > separate switched circuit. My starting routine is prime the fuel system > using the back up pump. I watch the fuel flow through a short piece of > transparent fuel line till the float bowls are full. I then turn off the > secondary system and start the engine. I can see fuel flow and hear the > faucet pump running when I turn on the back up pump. I know the back up > pump test works because the faucet pump died a few years back and its need > for replacement was very noticeable. I can hear the primary pump running > when the ignition is turned on. I also know if the primary pump fails the > engine will quit fairly quick and while still on the ground. I had to > disconnect the primary pump power wires to test this. Before takeoff or > landing I turn on the back up pump. > > It works for me. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > ----- Original Message ----- > *From:* Mike Welch > *To:* kolb-list(at)matronics.com > *Sent:* Wednesday, January 13, 2010 2:04 PM > *Subject:* RE: Kolb-List: 582 fuel system > > Mark and Kolb guys, > > I'm curious. I don't have much experience with diaphram pumps and all, > but it seems odd to want to design a *series* fuel pumping system. I > mean, I know a series system would work great and all....but how would you > know you lost one of the pumps, if the other pump can do all the work? > Let's say, for example, the last flight you had, your primary pump blew > out, and the backup kept you flying, how would you know??? You'd be toolin' > along thinking you had both pumpers up to snuff, but you wouldn't. > > Unless you verified each and every flight that BOTH pumps were operating > fine, you could be relying a false sense of security. Wouldn't you? > > If it were me, and maybe that's just my way of thinking, I think I would > like a parallel fuel system. Here why I think this; if my primary system > failed, it would kick on the backup system (and a big bright red panel > light). The light would alert me that the primary pump needs attention, and > when I landed, I could take care of the problem, but in the meantime, my > backup is doing it's job. > > For a parallel design, a primary system could easily have a low-pressure > switch ($30 McMaster Carr) that if activated (due to a zero or very low fuel > pressure), it would turn on the backup pump. > This method is close to how my turbo "high fuel delivery" fuel system is > designed and operated. > > I realize a *series fuel system*, with two fuel pumps, CAN work. I know > that. But, how would you know that every flight both are working properly? > > Just some thoughts on the matter....... > > Mike Welch > MkIII CX > > > I've got a series or parallel question about installing a facet boost > pump. I'm planning on intalling a facet pump between my fuel tank and the he > mikuni engine pump. I'm doing it in series just to keep it simple. If the > facet fails it should still flow thru so the mikuni will be able to draw > fuel from the tank. But what if the mikuni fails? Will it flow thru and > allow the boost pump fuel to get to the carbs? Those of you with similar > systems I'd appreciate your advice. > > > > Mark Rinehart > > ------------------------------ > Hotmail: Free, trusted and r01/' target='_new'>Get it now. > > * > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > ttp://www.matronics.com/Navigator?Kolb-Listronics.comww.matronics.com/contribution > * > > > ------------------------------ > Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. > > * > > * > > ________________________________________________________________________________
Date: Jan 13, 2010
Mike W/Gang: We used standby fuel pumps in series with the main pumps on UH-1 and AH-1 helicopters, when I was flying them a few years ago, like 35 years ago. We checked both during engine start and run up. We left the standby pump off and started the engine on the main fuel pump. Noting the fuel pressure on the main, we then turned on the standby. Usually, we would get a couple pound increase in pressure to let us know the standby was operational. The fact that the engine started and was running on the main fuel told us it was operational. My MKIII is plumbed the same way as the Hueys and Cobras, minus the fuel pressure gauge. Before engine start I turn on the Facet boost pump to prime the carbs. I can listen to it and tell when the bowls are full. Turn it off and crank the engine with the engine driven pump. If the engine runs on the engine driven pump while I am getting ready to taxi and takeoff, I am happy with it. To be more exact, I should have a fuel pressure gauge, but I don't like running a fuel line to the instrument panel. john h mkIII I realize a series fuel system, with two fuel pumps, CAN work. I know that. But, how would you know that every flight both are working properly? Just some thoughts on the matter....... Mike Welch ________________________________________________________________________________
Date: Jan 13, 2010
Subject: Fuel pumps in series
Hi All, This is how I know both pumps are working on my FSII. I flip on the facet while the engine is NOT running. I can hear the pump running and watch fuel fill the fuel lines running to the carbs, thus verifying that pump. Then I shut the facet off and start the engine for my warm up this verifies the diaphragm pump is working. Before I take the active runway I flip the facet back on for take off and climb out. When I reach my cruising altitude I flip the facet off again. When I`m ready to land I flip the facet back on until I shut down the engine at my trailer. In the past I would let the facet run during the entire flight but my flight instructor didn`t like that. He felt that if either pump failed in flight, I wouldn`t be aware of it. I know there are two schools of thought about turning the facet on and leaving it on and turning it off after climb out. All I can say is I trust my instructors opinion and do what he advises. Anyway this procedure works for me. Lanny N398LF ________________________________________________________________________________
Date: Jan 13, 2010
> There's generally little advantage to adding the electric pump and a couple of disadvantages. The mikuni pneumatic pumps are exceedingly reliable and, in a Kolb installation, provide plenty of vacuum to draw the fuel up from the tank to the engine. > > As I said, the pneumatic pumps are exceptionally reliable and when simply > used by themselves yeild the simplest and easy to use/maintain system. > I've used them for years and many hundreds of hours and have never had one > fail. > > LS Lucien/Gang: I think the major advantage of having an electric boost pump is when the Mikuni fails, gives you another chance. Back in my two stroke days I had a Mikuni fail. Had a cheap Facet copy I bought from JC Whitney for backup pump, which failed a few hours after I departed Alabama for the Flight Farm, in Monterey, NY, in 1989. The Mikuni failed while flying low level around the Flight Farm a few days later. Lucked out and landed in one of the many hay fields in the area. Murphy knows when to strike. He is very patient. Might be complex for some, but pretty simple for most to cut a fuel line, stick a Facet in there, run a couple wires to the battery and a switch. On my Firestar, I did not have a battery. Connected the pump through a switch to my 12VDC buss. Got a Facet to replace the Chinamanese pump when I got back to Alabama. Trying to save a few dollars cost me a forced landing. Not much maintenance to a Facet pump. I have had one in my MKIII for a few hours less than 3,000. Haven't done anything to it since installation in 1991. These pumps were used as primary lift pumps in many small pickup trucks, Mazda for one. They have a great track record. Almost as good as Mikuni. My first little Kubota diesel was built in and around 1975. It uses a Mikuni pulse pump for a lift pump. It has several thousand hours and 35 years of pumping without failure. If that pump was in my airplane, it would probably fail next flight. ;-) john h mkIII ________________________________________________________________________________
Date: Jan 13, 2010
John Hauck wrote: > > Lucien/Gang: > > I think the major advantage of having an electric boost pump is when the > Mikuni fails, gives you another chance. > > Seems like we've kicked around the electric fuel pump issue in the past, but my memory is a little foggy on it. To the OP I'd say it's ultimately a matter of personal preference as my reasons for not liking and thus not using an electric pump (unless it's specifically called for by the installation) tend to be just matters of my own personal opinion. I personally prefer the simplest possible systems in critical areas like fuel systems because they're easier to maintain, less stuff for me to worry about in flight, easier to catch goofs on and yeild the simplest possible checklists in the plane. I.e. fan stops turning: - go to landing spot - land fan gets rough - go to landing spot - land without having to hit extra switches, etc. etc... Though I will admit that some of the terrain I've flown over in a couple of my recent trips did once or twice cause backup systems like an aux. fuel pump to pop into my mind for a moment. It did prompt me to go hug a road, which did quite enjoyable extend a flight I made the other day. If the WX is good this weekend I'm going to repeat it but this time using that new route with the road under it ;) LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281354#281354 ________________________________________________________________________________
Subject: Tech. problems with Matronics Kolb list
Date: Jan 13, 2010
Jack and All, I am at wits end . I have not been able to get to the Matronics list but once in a blue moon. Something has changed this winter. I have been a member for over a year as I am 19 Yahoo Groups. I have spent over $100. Trying to figure out why my computer times out ( tcp) message 0r Internet Explorer can't display the page. Site unavailable or other BS. All other connections work fine just can't get to Matronics the last few months without all kinds of BS notices. I e-mailed Matt got no where. Called Wild Blue Dish myIP bought software that didn't WORK. Had A Tech. come out. Cleaned almost everything out of my computer. I use Yahoo as the web brouser. Can this also be a case of Barracuda screwing things up? What can I do next? The Matronics Kolb Site is my favorite place for aircraft related topics. It is getting ridiculus to try to get here. Sorry for all my ranting but, I may not be able to get on for a week . Carl Tosh -------- mongsterone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281355#281355 ________________________________________________________________________________
Subject: Re: Tech. problems with Matronics Kolb list
Date: Jan 13, 2010
Hi Carl, I'm sorry to hear of your troubles. I think that I did respond to your email from last week, but I answer a lot of list-op related email and I might be remembering something else. I'm not sure why you are having such issues connecting to the site. I'm off the Matronics net right now and am connecting in and viewing the Matronics Forums without issue or delay. You didn't specifically describe the methods you were trying to access the Lists. Are the problems with WEB access to the forums site? Or with posting and/or receiving email via the traditional email lists? What about accessing the traditional List search engine and/or List Browse? http://www.matronics.com/search http://www.matronics.com/listbrowse Best regards, Matt Dralle Matronics Email List Administrator -------- Matt Dralle Matronics Email List Administrator Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281357#281357 ________________________________________________________________________________
Date: Jan 13, 2010
> Though I will admit that some of the terrain I've flown over in a couple of my recent trips did once or twice cause backup systems like an aux. fuel pump to pop into my mind for a moment. > It did prompt me to go hug a road, which did quite enjoyable extend a > flight I made the other day. > If the WX is good this weekend I'm going to repeat it but this time using > that new route with the road under it ;) > > LS Lucien/Gang: Based on altitude and terrain, I will turn on the boost pump is necessary. The Facet is rated for continuous duty. Could leave it on all the time. If I am scared the engine is going to stop at any moment, I'll follow a road or other suitable forced landing area, if there is one. Normally, flying with a 912UL or a 912ULS, I fly direct. Aren't you flying a Titan with 912? john h mkIII ________________________________________________________________________________
Subject: Re: Flying the lazy river on Youtube
Date: Jan 13, 2010
undoctor wrote: > Sent them to Don G., who built it, and he emailed back that looking out under those stars and stripes made him "giddy." I understand why; he did one heck of a fine job building it. The paint job alone is a labor of love! > > Dave That paint job is amazing. I really like it. -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=281386#281386 ________________________________________________________________________________
Date: Jan 13, 2010
Mike Yes the system is true "series" design. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Wednesday, January 13, 2010 4:29 PM Subject: RE: Kolb-List: 582 fuel system Rick N., The design of your system sounds like I was asking about. Your ability to verify each pump, prior to each flight, is the kind of assure I was wondering about. It appears as though you have everything covered. But, Rick, is your fuel delivery a true "series" design? Mike Welch ------------------------------------------------------------------------- ----- From: NeilsenRM(at)comcast.net To: kolb-list(at)matronics.com Subject: Re: Kolb-List: 582 fuel system Date: Wed, 13 Jan 2010 15:12:13 -0500 Mike Your system sounds great and should work well but I like to keep things simple. My fuel system requires a electric fuel pump. I have two electric pumps in series, one is driven by the ignition circuit. The secondary pump by separate switched circuit. My starting routine is prime the fuel system using the back up pump. I watch the fuel flow through a short piece of transparent fuel line till the float bowls are full. I then turn off the secondary system and start the engine. I can see fuel flow and hear the faucet pump running when I turn on the back up pump. I know the back up pump test works because the faucet pump died a few years back and its need for replacement was very noticeable. I can hear the primary pump running when the ignition is turned on. I also know if the primary pump fails the engine will quit fairly quick and while still on the ground. I had to disconnect the primary pump power wires to test this. Before takeoff or landing I turn on the back up pump. It works for me. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: Mike Welch To: kolb-list(at)matronics.com Sent: Wednesday, January 13, 2010 2:04 PM Subject: RE: Kolb-List: 582 fuel system Mark and Kolb guys, I'm curious. I don't have much experience with diaphram pumps and all, but it seems odd to want to design a series fuel pumping system. I mean, I know a series system would work great and all....but how would you know you lost one of the pumps, if the other pump can do all the work? Let's say, for example, the last flight you had, your primary pump blew out, and the backup kept you flying, how would you know??? You'd be toolin' along thinking you had both pumpers up to snuff, but you wouldn't. Unless you verified each and every flight that BOTH pumps were operating fine, you could be relying a false sense of security. Wouldn't you? If it were me, and maybe that's just my way of thinking, I think I would like a parallel fuel system. Here why I think this; if my primary system failed, it would kick on the backup system (and a big bright red panel light). The light would alert me that the primary pump needs attention, and when I landed, I could take care of the problem, but in the meantime, my backup is doing it's job. For a parallel design, a primary system could easily have a low-pressure switch ($30 McMaster Carr) that if activated (due to a zero or very low fuel pressure), it would turn on the backup pump. This method is close to how my turbo "high fuel delivery" fuel system is designed and operated. I realize a series fuel system, with two fuel pumps, CAN work. I know that. But, how would you know that every flight both are working properly? Just some thoughts on the matter....... Mike Welch MkIII CX > I've got a series or parallel question about installing a facet boost pump. I'm planning on intalling a facet pump between my fuel tank and the he mikuni engine pump. I'm doing it in series just to keep it simple. If the facet fails it should still flow thru so the mikuni will be able to draw fuel from the tank. But what if the mikuni fails? Will it flow thru and allow the boost pump fuel to get to the carbs? Those of you with similar systems I'd appreciate your advice. > > Mark Rinehart ------------------------------------------------------------------------- --- Hotmail: Free, trusted and r01/' target='_new'>Get it now. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ttp://www.matronics.com/Navigator?Kolb-List ronics.com ww.matronics.com/contribution ------------------------------------------------------------------------- ----- Hotmail: Trusted email with powerf/01/' target='_new'>Sign up now. ________________________________________________________________________________
Date: Jan 13, 2010
Rick=2C Rick=2C John=2C Lucien=2C etc=2C and others=2C Like I said=2C I don't know much about the 582 delivery systems=2C but it sounds like you guys have it figured out. My concern was not knowing if you had a failure in a two pump system=2C b ut as long as you can easily verify each pump is working properly=2C then i t sounds like you're in good shape. Mike Welch
December 21, 2009 - January 13, 2010
Kolb-Archive.digest.vol-jc
