Kolb-Archive.digest.vol-jt
April 09, 2010 - May 03, 2010
A year later, during modification and repairs of FS, decided I probably
didn't really need that capacitor, so I did not reinstall it. First flight
I could not use my radio to receive or transmit. The ignition and
alternator noise overwhelmed the it. I reinstalled the capacitor and the
noise went away. Additionally, I had to run resisitor plugs (against Rotax
recommendation not to)(no change in performance or reliability was observed)
and shield the plug wires and run metal resisitor NGK plug caps.
The capacitor has a + and - terminal. + goes to the 12VDC positive wire,
and the - goes to a good ground on the airframe.
john hauck
Subject: | Former Kolber Will Tatham |
Will used to be on this list several years ago, he sent me a link to a Kolb video
he and his wife made. Very nice, enjoy!
http://www.youtube.com/watch?v=r0kSwK60o0o
Richard Pike
MKIII N420P (420ldPoops)
http://forums.matronics.com/viewtopic.php?p=293693#293693
From: | Charlie England <ceengland(at)bellsouth.net> |
Subject: | Re: Looking for help to fix radio noise? |
On 4/9/2010 11:28 AM, John Hauck wrote:
> --> Kolb-List message posted by: "John Hauck"
> I've heard of this remedy before ( I think from you a couple of years
> ago). Exactly how would a person hook up this capacitor? IIRC, it hooks up
> between the +& - posts of the battery, correct?
> Aslo, is this something everyone should do (that uses a radio), or do you
> think only on a "as needed" basis?
> Mike Welch
> MkIII
> Mike W/Gang:
> Like a lot of things, I learned it by chance.
> Put lights on a dirt bike without a battery. Bought a kit from JC Whitney.
> Kit included a small capacitor (battery replacement).
> Wanted to take advantage of the alternator on the 447 on my Firestar,
> remembered the JC Whitney kit and stole the capacitor from the old dirt
> bike.
> john hauck
> mkIII
> Titus, Alabama
To add to what John told you, if you hook up the capacitor at the
battery it isn't likely to help you much. (The battery itself does a
pretty good job of filtering noise at its terminals.)
Try putting it as close to the noise generator (typically the alternator
or generator) terminals as is reasonably possible. You can add another
one as close to the radio's power terminals as possible, also, if the
1st one doesn't do the trick.
Having said all that, it's possible that the radio station's transmitter
could just be overwhelming your radio's 'front end'. If that's
happening, think about that HEE HAW TV doctor's advice: "If it hurts
when you do that, don't do that" (go near the radio transmitter) I know
that's not much of a solution, but it might end up being the only one
that's not financially painful.
Subject: | Re: AEROSHELL OIL SPORT PLUS 2 |
From: | "albertakolbmk3" <cheriebraun(at)xplornet.com> |
What ratio is the phillips good for?
Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
http://forums.matronics.com/viewtopic.php?p=293701#293701
I premixed at 50:1 in former years, and now with the 582, just let the oil pump
do it's thing.
Richard Pike
http://forums.matronics.com/viewtopic.php?p=293718#293718
If you use it at 100:1 in a Rotax 277, the engine will actually rattle, and when
you hear it in flight, it is not a smiley face moment. However, it did make
it back to the field, and after replacing the 100:1 premix with 50:1, the noise
went away. Apparently it gives a really good oil film, but at 100:1, not as
much as Rotax intended.
Must not have hurt anything, replaced the Amsoil that same year with the much cheaper
Injex, and last I heard, the engine had about 750 hours on it, the only
internals I ever replaced in 13 years was one piston and 2 sets of rings.
Richard Pike
http://forums.matronics.com/viewtopic.php?p=293719#293719
Subject: | Re: Former Kolber Will Tatham |
video he and his wife made. Very nice, enjoy!
Richard Pike
Richard P/Gang:
Wonderfully done video.
Thoroughly enjoyed it.
Noticed they were at Arches National Park, 2009. So was I. Probably passed
on the highway. ;-)
john hauck
Well, I can now say I've built a Kolb, .... sort of.
Hope you like.
http://picasaweb.google.com/110121065651098215036/KolbBuildPics
Keath T
http://forums.matronics.com/viewtopic.php?p=293790#293790
Hope you like.
Keath T
Keath T/Gang:
Very nice.
Who build the full size MKIII. Looks familiar, but can not remember the
gentleman's name that built it.
john hauck
Now you need to clip the lawn a little shorter.
Looks good, Any W&B problems?
BB
> Hope you like.
> Keath T
john hauck
Gang:
Answered my own question.
Could see the N number.
TNK built the MKIII.
I was thinking somebody else had built it, but I was wrong.
john hauck
Titus, AL
John H.
I got it from a gentleman in Ohio by the name of Mark Peterson, but I don't think
he was the original builder.
Slyck
The grass mowing is not my job. :)
It's tail heavy. I'm going to have to put some lead in the nose before the maiden.
http://forums.matronics.com/viewtopic.php?p=293794#293794
From: | william sullivan <williamtsullivan(at)att.net> |
- Nice piece of work, Keath.- Flyable, or just a stationary model?- W
hat powerplant?
Did you downsize original plans, or measure up the full size one?
-------------------- Bill Sullivan
-------------------- Windsor Locks,
Ct.
-------------------- FS 447
She'll fly, at least once... There will be video in case it's the one and only.
It has an OS 35 motor, which I hope will provide enough thrust.
Someone on the list sent me a three-view but when I had them printed, the scales
were off from one view to another so I tossed them and did it all by eye.
Keath T
http://forums.matronics.com/viewtopic.php?p=293797#293797
> Keath T
By eye? Rats. I was gonna ask for a set of plans. And make Ed wait on his FSII
while I build one of them!
Richard Pike
http://forums.matronics.com/viewtopic.php?p=293798#293798
Keath,
VERY
http://forums.matronics.com/viewtopic.php?p=293799#293799
What a soul touching video.
jerb
>a Kolb video he and his wife made. Very nice, enjoy!
>Richard Pike
>Read this topic online here:
Thanks!
It was a fun build, definitely different than anything I've done before. I'm anxious
to see it fly...
Sorry Richard. It's a one-off.
Keath T
http://forums.matronics.com/viewtopic.php?p=293805#293805
From: | Ellery Batchelder Jr <elleryweld(at)aol.com> |
Thal looks real great ,How does it fly?
Ellery Batchelder Jr.
-----Original Message-----
Sent: Sat, Apr 10, 2010 9:36 pm
Subject: Kolb-List: build pics
ope you like.
eath T
-= - The Kolb-List Email Forum -
-= Use the Matronics List Features Navigator to browse
-= the many List utilities such as List Un/Subscription,
-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
-= Photoshare, and much much more:
-= --> http://www.matronics.com/Navigator?Kolb-List
-= - MATRONICS WEB FORUMS -
-= Same great content also available via the Web Forums!
-= --> http://forums.matronics.com
-= - List Contribution Web Site -
-= Thank you for your generous support!
-= -Matt Dralle, List Admin.
-= --> http://www.matronics.com/contribution
Hi All,
following the chat here about supressing radio noise.
I have been digging through the usual pile of `may come in handy one
day` equipment and I found a block of plastic about (1" 3/4 X3/4"X1/2")
with a wire protruding. The packet is marked `Suppression capacitor
4.7mFD for Alternators`
The plastic block has a fairly substantial metal tongue with a hole in
it. About quarter of an inch dia.
The protruding wire is green and has, on the end, a metal tag of much
thinner material , also with a hole through it.
Apart from the fact that it obviously meant to be bolted to something at
either end and that at a guess mFD means microfarads i am totally at a
loss.
Does this sound as though it might be what is needed to cut engine
noise.? i have a 4 stroke Jabiru. If it will work , where do I fit it?
As you may have guessed I am totally ignorant of electrical stuff, and
most engineering if it comes to that.
Help!
Pat
Subject: | Looking for help to fix radio noise? |
Mike Welch
MkIII
Yes... everyone should consider it. It will smooth out the electrical
noise in the system. One other thing that you can do is to take an old
film canister, or pill bottle. Cut a small piece of tubing that will run
from end to end, wrap a wire around the tubing, and slide it into the
canister. This will work as a resistor to voltage spikes by preventing a
spike from going straight through. And when there is a voltage drop, it will
try and keep the electricity flowing more evenly. A lot of your high end
car stereos will have these installed on the main power lead.
Boyd Young
From: | "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> |
I just looked at the video it is great. The MKIII at the end, is that Gary
Aman's current plane?
Rick Neilsen
----- Original Message -----
Sent: Friday, April 09, 2010 6:29 PM
Subject: Kolb-List: Former Kolber Will Tatham
> Richard Pike
Subject: | Re: engine noise |
Pat,
That little "m" stand for "milli". What you have is a 4.7 milliFarad (4.7mFD) capacitor.
This equates to 4700microFarads (4700FD), still shy of the 20,000FD
recommended above.
Roger in Oregon
1992 KXP 503 - N1782C
http://forums.matronics.com/viewtopic.php?p=293881#293881
Rick,
Yes it is.
G.Aman
From: Richard & Martha Neilsen <NeilsenRM(at)comcast.net>
Sent: Sun, Apr 11, 2010 1:43 pm
Subject: Re: Kolb-List: Former Kolber Will Tatham
cast.net>
Rick Neilsen
----- Original Message ----- From: "Richard Pike" <richard(at)bcchapel.org>
> Richard Pike
Subject: | MkIII antenna location |
Hi gang=2C
I'm currious where those of you with aircraft radios located your antenna
. I will be using an Icom A200 panel mount radio=2C and I'm pondering wher
e the best place would be to locate the antenna.
It seems like everywhere I think of=2C there is a logical reason NOT to p
ut it there!!
I have an idea where I might install it=2C but I wanted to hear where oth
ers have put there's=2C first.
Oh yeah. I made one of those dipole antennas that Scott shared with us.
(actually=2C I made three. I figured it isn't that much trouble to make
more than one=2C while I was at it.)
Although I mentioned the MkIII in the heading=2C as long as you have a pe
rmanent mount antenna on any Kolb airplane=2C I'd like to hear from you. (
even you lurkers....if your radio works good. If your radio doesn't work w
ell=2C keep lurking :-) )
Mike Welch
MkIII
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H
otmail.
http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=
PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5
Subject: | Re: MkIII antenna location |
Mike W/Gang:
Was trying to keep this a secret, but will share it with you and the
rest of the herd.
On my Firestar and my MKIII the antenna is mounted under the nose pod
with a 45 degree bend aft.
Worked on the FS and continues to work on the MKIII.
The antenna is a stainless steel whip ELT antenna. Back when I bought
these antennas they could be had for about 15.00 each. Now they are 3
to 4 times that much.
I upgraded from an A3 to an A6 ICOM, a little over 200.00, because the
A6 had adjustable side tone volume. After installation, discovered the
side tone was picking up all the cockpit noise and transmitting it as
well. My transmissions were unreadable. After much frustration and
experimentation, discovered if I turned the side tone volume completely
off, and used the side tone on my intercom, my transmission problems
were solved.
As I get deafer I was also looking for more volume from the radio. The
new A6 did the job. I can hear again.
I also bought a mic muff cover from Oregon Aero. It is a foam muff with
a snug fit naugahyde slip on cover. There is a small hole on each side
for voice and ambient sound. Not sure if it is working or not because I
did the no side tone volume and mic muff upgrade at the same time.
James Tripp has some also. We plan to experiment with them to see if
they, in fact, do reduce cockpit noise being picked up by the mic.
john hauck
antenna.
Mike Welch
MkIII
> antenna. I will be using an Icom A200 panel mount radio, and I'm
> pondering where the best place would be to locate the antenna.
> It seems like everywhere I think of, there is a logical reason NOT to
> put it there!!
> I have an idea where I might install it, but I wanted to hear where
> others have put there's, first.
I remoted my Icom A24's original rubber duck antenna, mounting it under the
cockpit (between the UltraStar's stock fuel tanks) pointing straight
down. I can hear everybody and others report they can hear me just fine.
Haven't figured out what I'm going to do when I move change the tank
configuration and put a cargo box where the current tanks are.
-Dana
A rolling stone .... kills worms
I flew my Mark 111 Xtra for the first time tonight. I need to do a few adjustments
but it was a great flight. I plan to be at Sun n Fun Friday and Saturday.
Hope to see some of you there...
Craig Spoke
Mark 111 Xtra
VW Redrive
Lillian, AL
cspoke(at)gulftel.com
http://forums.matronics.com/viewtopic.php?p=293904#293904
http://forums.matronics.com//files/p4094693_582.jpg
Subject: | Re: First Flight |
congratulations. Tell us about the VW.
BB
MkIII
suzuki
> Craig Spoke
> Mark 111 Xtra
> VW Redrive
> Lillian, AL
adjustments but it was a great flight. I plan to be at Sun n Fun Friday and
Saturday. Hope to see some of you there...
> Craig Spoke
> Mark 111 Xtra
> VW Redrive
> Lillian, AL
Craig:
Congrats, my friend.
john hauck
This seems to work ok.
http://www.bcchapel.org/pages/0003/pg9.htm
Richard Pike
MKIII N420p (420ldPoops)
http://forums.matronics.com/viewtopic.php?p=293913#293913
Craig
Congratulations. We are going to want details on your flight. Bring photos
of your plane to Sun-N-Fun.
I'm heading for Sun-N-Fun some time in the next few days. We have some nasty
weather popping up so it is all dependant on getting a break. It is looking
like the weather is good after Tuesday for the rest of the week but the
weather people are being challenged more than normal.
Rick Neilsen
Redrive VW Powered MKIIIC
Sent: Sunday, April 11, 2010 10:06 PM
Subject: Kolb-List: First Flight
> and Saturday. Hope to see some of you there...
> Craig Spoke
> Mark 111 Xtra
> VW Redrive
> Lillian, AL
Subject: | Re: VG's............... |
> But it also had eight VGs spacer out on the wing ahead of the flaps. What do
you make of that?
Just a FYI type update. I was at the AERO 2010 expo at Friedrichshafen in Southern
Germany last week and got talking with VG manufacturer 'Micro Aerodynamics'
who explained that the VG's ahead of the flap area on the Boeing are to counteract
and delay the onset of a shock wave which in turn sets off a Dutch Roll
type instability that all swept wing aircraft are prone to. Apparently the venerable
B52 bomber had them also, and with a bit of poetic license there were
52 per side.
The ones ahead of the ailerons are for keeping the airflow attached at low speeds,
relatively speaking, just like in a Kolb. (there, now it's Kolb related).
David.
http://forums.matronics.com/viewtopic.php?p=293930#293930
Mine sits in the middle of the pod pointing upwards. Its connected to a
hand held and works well. No noise . It was fitted by a RNZAF aircraft
fitter so I have no details of its instillation.
Downunder
MK111c
503
Sent: Monday, April 12, 2010 12:35 PM
Subject: Kolb-List: MkIII antenna location
Hi gang,
to put it there!!
with us. (actually, I made three. I figured it isn't that much trouble
to make more than one, while I was at it.)
Although I mentioned the MkIII in the heading, as long as you have a
permanent mount antenna on any Kolb airplane, I'd like to hear from you.
(even you lurkers....if your radio works good. If your radio doesn't
work well, keep lurking :-) )
Mike Welch
MkIII
with Hotmail. Get busy.
still shy of the 20,000FD recommended above.>>
Thanks for your help.
Pat
Would that be uncle Craig of breakfast fame at MV?
G.Aman
Sent: Sun, Apr 11, 2010 10:45 pm
Subject: Re: Kolb-List: First Flight
> Craig Spoke
> Mark 111 Xtra
> VW Redrive
> Lillian, AL
Craig:
john hauck
>G.Aman
Gary=2C
No=2C this Craig is not Uncle Craig. Uncle Craig has been flying his MkI
II Xtra for quite a long time now.
Last I heard=2C he was installing an EFIS=2C or some kind of electronic mon
itoring system=2C plus=2C as usual=2C
more fiberglass parts. (frankly=2C I miss seeing his latest projects)
Craig Spoke is a new MkIII Xtra builder/pilot. He posts on the Kolb-list
every once in a while.
Mike Welch
MkIII CX
Hotmail is redefining busy with tools for the New Busy. Get more from your
inbox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O
N:WL:en-US:WM_HMP:042010_2
Subject: | Lakeland Weather |
Morning Gang:
Monday, Tuesday, and Wednesday weather in Lakeland looks good, except for
wind.
Tuesday weather:
Tuesday: Mostly sunny, with a high near 83. East northeast wind between 6
and 15 mph, with gusts as high as 21 mph.
Today and Wednesday are much the same.
I'll plan on getting out of here at first light in the morning. Hopefully,
beat most the wind before it gets up in the afternoon. Right now at 0800,
it is dead calm. I I can get up and get loaded, get in the air by 0500,
I'll be at LAL before noon. It is a 412 mile flight direct, but I will
deviate a little to pick up fuel in Perry, FL. Other than that stop, I'll
only land when the urgent need arises.
Looking forward to seeing you all at Lakeland.
Save me a good spot by the gate to put up my tent, Rick. Getting too old to
push the mkIII through the grass. ;-)
john hauck
Craig,
That is a great accomplishment! Looking forward to hearing more about your engine's
performance. What type VW, redrive, carb, etc.?
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
http://forums.matronics.com/viewtopic.php?p=293947#293947
I have a dipole made from the end of the piece of coax. The dipole is on
the inside of the nosecone, the center part of the coax runs up the left
side and across the top, while the braid runs across the bottom. The
location was changed a few times to get the best swr with an antenna
analyzer.
www.brigham.net/~byoung/antenna.html
Boyd Young
Boyd=2C
Interesting=2C yet simple antenna. I noticed you didn't mention a balun
=2C though. Is there a reason why you don't have one? Is a good SWR readi
ng sufficient information to say you don't need one? I don't know=2C I'm j
ust asking.
I'm still not too pleased with my choices of where I have to locate my an
tenna on my MkIII. I'm considering a) the nosecone area b) way up hi
gh=2C above the wing's center section c) mounted on the wing's leading
edge d) under rear portion of cabin surface
a) if I mount it (the dipole antenna) in the nosecone=2C one of the rods
poke out in my view through the windscreen. Not acceptable=2C IMO. I mig
ht be able to tilt it to where the upper rod is completely contained inside
the nosecone=2C and the lower rod would point more horizontally toward the
rear=2C but I give up reception in this configuration.
b) up top=2C this might be one of the better locations=2C but a dipole ant
enna's dimensions don't seen to work well. If I go with this location=2C I
would be better to go with a simple mast & and groundplane. The problem i
s...there may not be sufficient area to locate a proper ground- plane. hmm
mm?
c) mounted on the leading edge of a wing=2C whiskers pointing rearward. t
his would be the easiest & work the best!!! No modification to the antenn
a at all. may also look the dumbest place to put it. since the whiskers
could point rearward=2C they wouldn't be likely to be walked into=2C etc.
=2C but how dumb would it look to have an antenna on a wing? more hmmm?
BTW=2C if I did locate it here=2C I'd make a special rotatable mount=2C w
here the antenna could be rotated out of the way for storage. I've got a d
esign in mind where you remove a pin=2C spin the antenna out of the way=2C
and lock it in place with the pin. Still not my favorite spot!!!!!
d) under rear fuselage area. this may be one of the best places to locate
it. the question is whether I can fit it in properly. I may not be able
to stay with the dipole if I go here. If I can create a decent groundplane
out of 1/2" wide copper foil=2C and place the groundplane correctly on the
inside of the center of the cabin=2C then I could extend the one
antenna mast out and rearward. I think I'll investigate this one more.
Time to join the Matronics aeroelectrics forum and bug Bob Nuchols. He'd
know what to do.
Thanks for your input=2C guys.
Mike Welch
MkIII
Subject: RE: Kolb-List: MkIII antenna location
Date: Mon=2C 12 Apr 2010 08:35:57 -0600
the inside of the nosecone=2C the center part of the coax runs up the le
ft side and across the top=2C while the braid runs across the bottom. T
he location was changed a few times to get the best swr with an antenna ana
lyzer.
Boyd Young
The New Busy is not the old busy. Search=2C chat and e-mail from your inbox
N:WL:en-US:WM_HMP:042010_3
Boyd,
Interesting, yet simple antenna. I noticed you didn't mention a balun,
though. Is there a reason why you don't have one? Is a good SWR reading
sufficient information to say you don't need one? I don't know, I'm just
asking.
antenna on my MkIII. I'm considering a) the nosecone area b) way up
high, above the wing's center section c) mounted on the wing's leading
Mike Welch
MkIII
No I did not mention a balun, (Balanced to un balanced antenna adapter)
every piece of wire will have a resonant frequency. And if you can cut the
wire to make it resonant at the frequency you want, keep the band width
wide or narrow enough for the desired application, make it reject unwanted
signals or noise. You have done a good job. The process of antenna
building can be as much of an art as it is a science. Go to your browser
and type in fractal antenna if you check out several of the links you will
see many different designs, they all work well. You could probably design
one that would be 6 inches or less in any dimension, and place it in the
front of your nose cone. You could start with a piece of circuit board,
strip all the conductor off one side, then start masking the other side
into one of the designs you could find links for. You may have to try
several in order to find one that tunes to the proper frequency, and has the
band width and swr you need. The links I followed showed the 50 ohm coax
connected at the center with no balun. One note, if you painted the
nosecone with polly fiber silver paint, put the antenna on the outside.
Instead of a full surface ground plane, the braid on my coax antenna is the
ground plane. You can use the metal structure of the plane as the ground
plane, and only use a wire whip. If I were to use an outside antenna on the
kolb it would be a whip antenna mounted on the rear part of the nosecone in
the center pointed down for about 6 to 8 inches then bent back on about a 45
to 60 deg angle. You could mount it further back but would have to come up
with something for support. Someone mentioned a rubber duck mounted on the
bottom. should work fine. If the antenna whip parallels too close to a
metal structure you will get too much radiation resistance, and not be able
to tune the antenna for best swr. The other antenna location would be on
top of the gap seal. Making sure the antenna was not too close to the
engine and could not get tangled in the prop. I am just thinking out loud
here. You could probably take an antenna like mine and hot glue it to a
piece of cardboard in one of the designs you fine in one of the links. In
the early days the designers would put up as loooong a wire as they could
fit in the property. Thinking that if they were to put electrons in the
air,,, the more surface area in the air the better, and later
discovered a resonant wire, different length for different frequencies,
worked much better. And this works for the transmitter as well as the
receiver.
All you wanted to know and then some.
Boyd Young
ham radio N7WFM
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Mike,
I have done a bit of playing around with antenna's on both a Mark III
and my current Firestar. The first Mark III that I had, had a 1/8 th
wave ( I assume since it was very short ) on the top of the nose cone.
It worked some of the time, but was never good enough to keep the tower
operators happy, and it had a regular aircraft radio in it. Nav com, I
believe. I sold that aircraft, so its not a problem any more. I kept my
Firestar and only run an I Com hand held in it. My antenna system is
the same set up as that made by R Pike, although both were developed
independently. My ground plane is riveted to the bottom of the cage
tubes, and is in a V shape. If I had talked to Richard I would have
glued a round plate to the fabric and possibly would have had a more
efficient antenna. I have also experimented with the location and found
that mine seems to work the best on the bottom of the cage. I put it on
top of the wind screen just below the level of the wing and the
performance was bad enough that I immediately put it back on the bottom.
As you can see (a bit fuzzy ) I put a bend in it so that it wasn't
dragging on the ground, but the length is 23 1/2 inch. That is good
enough that I can talk to the wife ( last trip ) at 29 miles. She can
hear me better if I am flying away from her, remember my ground plane is
in a V with the widest end pointed to the rear. This is not by the way
line of sight, the house is down in a low spot. Now John told you about
his placement and antenna in an earlier post. Last year when he was
flying in we talked at 60 miles, He was up I think 9000 feet, and I had
no trouble hearing or understanding him.
I personally liked the antenna construction that was sent to you, The V
type with the balun, but I can find no where to put one on my plane that
I like. So I guess I will stick with what I have. Almost anything will
work well enough to talk to a tower at the normal 5 mile range, even a
rubber duck.
Larry
Note: If you forward this email, please delete the forwarding history,
which includes my email address.
Subject: | Invitation from George RAndolph |
See my latest photos, updates and friends on Bebo.
Click to view my profile.
http://www.bebo.com/T/2.2Bafl2JiTgmc9xjMQ0QT4A/inv/10507319515a106017233b10507306604c0d0e141
Please note: if you are not yet a Bebo member, you must register first.
This email was sent to you at the direct request of George RAndolph .
You have not been added to a mailing list.
If you would prefer not to receive invitations from ANY Bebo members please click here - http://www.bebo.com/T/2.2Bafl2JiTgmc9xjMQ0QT4A/unsub/10507319515a106017233
Bebo, Inc., 795 Folsom St, #250, San Francisco, CA 94107, USA.
Mike, Boyd, all, Another great source of strictly antenna information is Bo
b
Weir, who writes a regular monthly column in "Kitplanes". He publishes a
manual for building dipoles for aircraft. It comes with a roll of copper
foil and a bag of baluns.
Rick Girard
On Tue, Apr 13, 2010 at 10:42 AM, b young wrote:
> Boyd,
> asking.
p
g
> Mike Welch
> MkIII
> Mike
he
ed
r
> will see many different designs, they all work well. You could probabl
y
> design one that would be 6 inches or less in any dimension, and place it
in
> the front of your nose cone. You could start with a piece of circuit boa
rd,
the
ax
he
d
the
in
45
up
he
> bottom=85 should work fine. If the antenna whip parallels too close
to a
le
d
In
> receiver.
> Boyd Young
> mkIII
> ham radio N7WFM
Subject: | lost my subscription |
Kolb people=2C
I mentioned yesterday I was going to sign up for the Matronics aeroelectr
ics list. I did=2C but I didn't realize that when you check your favorite
boxes to join=2C you also have to be sure to check the boxes of lists you a
re already on!! Didn't know that=2C so consequently
I got dropped from the Kob list early today!!! ( I thought it got awful q
uiet)
Now that I've found the reason why I haven't been getting any emails from
the Kolb list today=2C I'm too fall-down tired to deal with it (10:30 pm).
I do NOT like to be rude and ignor people's responses that try to help me
. I'll catch up with the replies to my antenna questions in the morning.
Thank you for understanding.
Mike Welch
thump!!
Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb
ox.
N:WL:en-US:WM_HMP:042010_1
- Does anyone have any idea of how many Kolbs have been-produced of eac
h type, both by Old Kolb and New?- And about how many are still-under c
onstruction?- Just curious.
------------------------ Bi
ll Sullivan
------------------------ Wi
ndsor Locks, Ct.
------------------------ FS
447
Boyd and Larry=2C
Thanks for the detailed responses. All this information is helping me co
me to a final decision where to locate it.
As I said before=2C I'm leaning toward the fuselage=2C underneath and rea
rward (below the front of the boomtube). This seems to be pretty close to
where Richard Pike located his=2C and confirmed by Larry that it worked pre
tty good.
Presently=2C my plan is to build a dipole antenna=2C and make the groundp
lane out of 1/2" wide copper foil strips=2C in the shape of an "X". The BN
C bulkhead fitting will be centered on the X=2C where the 1/8" steel rod ma
st is fastened.
My final design seems to be a combination of a couple of other typical ai
rcraft radio antenna designs. (mast of the dipole Scott showed us=2C groun
dplane of common base station type design=2C etc.) Unless new and better i
nfo comes along=2C this is what I'll likely go with.
Locating the antenna at the top edge of the windscreen may not be a good
location for me. I had planned on putting my Garmin 296 antenna there=2C a
nd I understand there may be RF interference problems having two different
antenna types near each other. Belly mount antenna seems to be the best ca
ndidate=2C so far.
Putting a dipole out on the wing's leading edge would be the easiest=2C a
nd would probably work the best=2C but it would also look the dumbest=2C IM
O.
Thanks again to you guys that have responded to my request. You've been
very helpful=2C and am helping me get this figured out.
Mike Welch
MkIII
otmail.
Presently, my plan is to build a dipole antenna, and make the groundplane
out of 1/2" wide copper foil strips, in the shape of an "X". The BNC
bulkhead fitting will be centered on the X, where the 1/8" steel rod mast is
fastened.
Mike what you are describing is a quarter wave antenna with an X shaped
ground plane. A di pole ( di meaning two) is a radiating element with
one ground element usually mounted in a straight line, and in our case as
vertical as possible.
_________________ co _________________
where co is the coax feed point.
- Boyd- Does this mean that using an oversize capacitor won't hurt?
----------------- Windsor Locks, Ct.
Boyd=2C
Yup=2C you're right. I got too loose with my labels. I meant quarterwav
e.
On the aeroelectric list=2C a guy suggested checking out Bob Weir's (from
Kitplanes fame)website. I am very familiar with Bob Weir's designs=2C and
in fact=2C I built of the copper foil antennas already=2C back in 2001. I
built it with the intention of using it on my MkIII=2C but then recently s
ort of changed my mind. Now=2C I'm back to using it. It seems like it wil
l be the best one for me=2C after all.
Thanks to everyone for their help.
Mike Welch
Date: Wed=2C 14 Apr 2010 08:56:32 -0600
Presently=2C my plan is to build a dipole antenna=2C and make the groundpla
ne out of 1/2" wide copper foil strips=2C in the shape of an "X". The BNC
bulkhead fitting will be centered on the X=2C where the 1/8" steel rod mast
is fastened.
Mike what you are describing is a quarter wave antenna with an X shaped gro
und plane. A di pole ( di meaning two) is a radiating element with one
ground element usually mounted in a straight line=2C and in our case as v
ox.
Bill Sullivan
Windsor Locks, Ct.
FS 447
No it will not hurt. The installation manual on the 912 says to install a
22,000 uf 25 volt capacitor between the positive output on the voltage
regulator and ground. That should be enough to smooth out the power. if
you went 40,000 uf it would it make it smother than smooth,, it wont
hurt but it may not do any additional good., going too large should not
hurt unless you are cramped for space and weight. If a person wanted he
could install one near the voltage regulator and one near the radio. If
you can only find a capacitor of half the desired amount,,, put two in
parallel, that will cause the values to add. On the electrolytic type
capacitors they are marked with a + and - make sure they are installed
correctly.
Two capacitors of the same rating mounted in series will give you the value
of 1/2 of a single capacitor.
Boyd Young
Subject: | Fwd: Allison birthday flyin |
---------- Forwarded message ----------
Date: Tue, Mar 16, 2010 at 1:16 PM
Subject: Re: Allison birthday flyin
i got the e-mail of your.
In a message dated 3/16/2010 8:04:18 A.M. Eastern Daylight Time,
greg(at)skyelink.com writes:
Some people had problems opening last email maybe this one will work sorry
Date: Tue, Mar 16, 2010 at 7:51 AM
Subject: Allison birthday flyin
Your invited to my second annual birthday fun fly weekend. Located at Ace
Airfields in Farnham Va. Camping under the wing fun with food ,music &
great fun with other pilots like yourselves. The fun starts on July 9-10.
My airfield is located at GPS 76*36.071w & 37*56.500n close to the bay. The
runway is a north< south orientation it is a 2000 ft grass strip with a line
of trees on the west side of the field. When you approach from the north use
left traffic from the south use right traffic. Stay over the trees on the
west side of the field.I will be useing craf ch#12300 to help if needed. If
you choose to drive use GPS king ln farnham va or give me a call
(GREG) (804)450-6200 Hope you can attend.
Subject: | Fire Fly with everything you need. |
A friend of mine needs to sell his Fire Fly due to health reasons. Below
is a description of what he has.
Trailer two year old Hallmark 26 foot, oversized, insulated, finished
interior with cabinets, AC/DC lighting. Soft-Ride suspension, Low Miles.
Excellent tires. Easy to heat with a Coleman Camp heater or electric
bathroom heater.
Firefly first flown two years ago. Wings built by Dennis Souder
(Original Kolb) and dry-stored.
Fuselage built as Oshkosh Display Demo -- serial number UL 001. Before
the FF production series. Travis and Brian says no changes were made in
the production. This is the original.
No damage except a very small neat smooth patch on one wing. I dropped
the wing in the wind.
Icom Radio with PPT and Lynx Headset and charger. Lynx helmet.
BRS-VLS chute. Two years since new.
Black Max brakes.
400 X 6 tires, mag wheels.
EIS, compass, ASI. Mounted in instrument pod that brings the panel close
enough to easily reach while harnessed.
Hardware for winter canopy
IVO three-blade
140 hour engine with new rings. I didn't need rings, but I was
encouraged by CPS to replace them.
Recent teardown and de-carbon. (about four or five hours on de-carbon)
Five and ten-gallon tank with frame fitted to match either.
Recently ramp-checked as LEGAL Part 103, I have the papers.
Rigged straight and level.
I have flown at Reno-Stead a few times since I lost my strip, and I
don't feel safe with the amount of traffic over there. On last flight it
took almost forty minutes to get airborne.
I must sell it or park it, as the nearest other alternate field is
outside my affordable driving range.
If you are interested contact him at WrenchWilson(at)aol.com
Larry Cottrell
Subject: | finally a bit of flying weather |
http://share.findmespot.com/shared/faces/viewspots.jsp?glId=0siAoTNYTZD
6KPbiDncNLfKZruRqx5nUO
The above link is to my spot tracking page. I prefer to use the hybrid
feature since it shows roads. There isn't much reason to have good sat
pictures here so you won't be able to get in too close.
The wind and weather finally moderated a bit or at least enough that I
felt like flying for the first time in almost a month. My interest was
to find a "two track" down into the Canyons that frame the Owyhee River
that would allow me to take a quad from this side of the river. If I go
the way that the roads are good I end up driving about 100 miles before
I can even get on my quad. This way it is only about 50 miles of two
track, and 15 hwy. It is very difficult here however because the roads
are not signed, and the land is so featureless as to not be much help.
So my plan was to press in GPS readings at the turns. Here in ranch
country all the roads lead to water, generally a stock pond, so it can
be a bit confusing actually trying to get somewhere.
I flew 103 miles in an hour and 34 minutes. I used 4.7 gallons of fuel
for 21.9 mpg average speed was 62 MPH There was a pretty good headwind
and it was a bit bumpy over the canyon coming back home.
My feet were cold by the time I got back on the ground, but it was nice
to get out for a while.
Larry
Subject: | Re: finally a bit of flying weather |
Larry,
Good photos! I'm particularly curious about that partial circle feature in the
second photo. Any ideas of what that is or was? Is it a meteor crater or dead
volcano? Have you ever landed there or 4-wheeled to it to inspect/explore?
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
An ounce of action is worth a ton of theory.
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=294400#294400
Gang,
The area here is volcanic and that picture is of Scotts Butte, and to
my untrained eye appears to have been one of the spots that lava poured
from the depths, over the landscape. I have been up there on my quad.
Very interesting country.
Larry
Sent: Friday, April 16, 2010 4:36 AM
Subject: Kolb-List: Re: finally a bit of flying weather
Larry,
feature in the second photo. Any ideas of what that is or was? Is it a
meteor crater or dead volcano? Have you ever landed there or 4-wheeled
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
- Friedrich Engels
Subject: | Re: Kolb-List Digest: 2 Msgs - 04/15/10 |
> Yes vertical:radio signals can be vertical OR horizontally polarized.
> Boyd Young
thanks Boyd! Great post.
GeoB
From: | "George Alexander" <gtalexander(at)att.net> |
Kolbers:
Attached is a picture of Kolb folks who gathered by the Kolb display in Paradise
City on Friday, April 16.
Left to right:
George A., Rick N., Beauford, Sam B., Dave W., Gary A., John H.
Rick, Gary and John had their planes there. A couple of other Kolbs.... not sure
who they belonged to: Firestar II (For Sale/Sold), an Ultrastar (burning
up the circuit) and a Kolb on a mono float.
Overall a good day.... crowd was light.... weather was outstanding.
George Alexander
FS II R503 N709FS
http://www.oh2fly.net
http://forums.matronics.com/viewtopic.php?p=294516#294516
http://forums.matronics.com//files/snf2010_004_small_163.jpg
I just got to this one.
Very good. I knew there had to be a way to get down there.
We need to pack up enough stuff for a few days survival, hit the trails
and make some gps tracks while looking for ways to get into the canyon,
the shortest ways.
john
Sent: Thursday, April 15, 2010 3:03 PM
Subject: Kolb-List: finally a bit of flying weather
nice to get out for a while.
Larry
Sorry about this personal post to the Kolb List.
I did not look and realize it was addressed to the List when I hit the
send button.
Got back from Lakeland today. Came home a day early to prevent possibly
weathered in at Sun and Fun.
Had a good flight. MKIII and 912 performed flawlessly. Started getting
in shape again during the flight home.
850 sm round trip. Head wind and rough air going south 5.9 hours, 415
sm. Tail wind and smoother air flying north, think it was 5.0 and 435
sm.
Ready to fly to MV next month.
john hauck
Sent: Saturday, April 17, 2010 8:01 PM
Subject: Re: Kolb-List: finally a bit of flying weather
trails and make some gps tracks while looking for ways to get into the
canyon, the shortest ways.
john
hybrid feature since it shows roads. There isn't much reason to have
good sat pictures here so you won't be able to get in too close.
I felt like flying for the first time in almost a month. My interest was
fuel for 21.9 mpg average speed was 62 MPH There was a pretty good
headwind and it was a bit bumpy over the canyon coming back home.
Larry
history, which includes my email address.
Subject: | Good news and bad news |
The wind finally stopped whistling down the plain long enough to get around
the patch a few times this evening. The air was smooth as glass and just the
thing after a day of being Grandpa.
Good news, replumbing the primer line seems to have fixed the rich running I
found on the trip down to Ponca City for the monthly breakfast bash two
weeks ago. And the fluorescent dye in the coolant helped me find the leak at
last.
Bad news, the coolant leak is in the radiator core. I guess I'll find out if
they recore motorcycle radiators (thank God, it's pre plastic tanks) or if I
have to have one custom made.
If I have to go the custom route, anybody know of a shop that's good and
inexpensive? Inexpensive being relative, like under $300?
Rick Girard
Subject: | Re: Good news and bad news |
What kind of M/C radiator are you using? I have used several different sorts of
M/C radiators with good success, and they can usually be found in junkyards for
under $75.
Richard Pike
http://forums.matronics.com/viewtopic.php?p=294614#294614
Richard, I used a radiator from a Honda Sabre 750. $20 bucks plus shipping
off eBay and $35 to have the inlet and outlet changed to accommodate the
sizes needed for the 582. If I'd known how easy it was to get reducers from
Sport Hoses I could have eliminated the rework.
Rick
> sorts of M/C radiators with good success, and they can usually be found in
> junkyards for under $75.
> Richard Pike
Another nice day with promise, so after waiting for the temps to warm up
to tolerable, I decided to check the area South East of the house. The
terrain climbs quite a bit, so instead of my usual tendency to hug the
ground, I took the plane up to 7500 feet. The only problem of course to
waiting for the temps to climb is that it generally only occurs around
noon and the thermals start to kick in.
I am still working on developing parameters of my HKS and the Hacman
fuel system, so this time I planned to dial the EGT's up to near 1400
degrees or lean of peak which ever came first. I had a headwind so my
ground speed was about 56 MPH.
The first picture is looking South West into Nevada, and the next is
South East also in Nevada. The water course is the South Fork of the
Owyhee River and flows into the main stream of the Owyhee at 3 Forks, of
which I had written and shown video last year. At about this point (33
miles from home and still in radio contact - Mike W) I decided that the
day was just going to get rougher and I would rather be typing than
flying.
The Steen's is in the background, about 80 statue miles away.
As I approached the lower terrain on the final leg home I decided to get
closer to the ground to get out of some of the thermals and I began to
dial back on the Hacman to keep my EGT's within the proper range.
( As I mentioned it is still pretty cool outside and I was of course
wearing gloves. My Mag switches are just above the Hacman dial. As one
gets closer to the ground the effect of the Hacman system is such that
the EGT's climb. As you throttle back they also rise. )
Well, my EGT's kept raising no matter that I was dialing it back and
eventually off. I put the choke full on to keep the fuel as rich as I
could get it, and had to throttle up to keep it below 1400. ( If the
EGT's get high enough the engine eventually leans out to the point that
it stops from fuel starvation.) I happened to be over the road that you
can see in the last picture and you can be sure that I stayed there
while I was trying to get a handle on what was happening. First I called
the wife and informed her of my location and the possibility that I
might have to set down, but that I had a good spot to do it. About that
time I looked down at the Hacman dial and discovered that with the
gloves on, I had switched off one mag switch. :-/ Interestingly enough
I had not heard the difference in engine noise. I flicked it back on and
the engine began cooling immediately. I must say that I felt quite a bit
cooler as well. I informed the wife of the improved condition and again
cut back across country to go home. From that point the rest of the trip
was uneventful.
Flight was 1 hour 18 minutes, fuel burn was 3 gallons, covered 72 miles,
average speed was 60 MPH.
Conclusion one:
The Hacman system works and helps conserve fuel, but you need to
constantly monitor it, and be aware of what it can do to you if you do
not. The EIS alarm is very helpful, and saved me from an engine out. The
flashing light alerted me to the problem before it became critical. ( I
had it set to 1400 degrees. ) As in most things concerning aircraft, and
our ability to survive flying them, is influenced by ones actions or
omissions. If you snooze you are going to have trouble. On most flights,
if fuel is not a problem, and I am flying close to the ground, I will
not use the Hacman system. It will save you fuel at altitude. So on a
trip, you bet! Otherwise no.
conclusion two:
The HKS isn't going to run for very long on one mag.
conclusion three:
I could use more panel space.
Here again is the track that I flew today.
Larry
Larry/Gang:
Looks good.
Be careful.
john hauck
From: | "lhaggerty" <lhaggerty(at)tampabay.rr.com> |
Subject: | Vertical speed indicator |
If any one has a VSI for sale, Let me know please. Pete
Subject: | short video of today's trip |
Here is a short You Tube video of today's trip.
http://www.youtube.com/watch?v=1DHcx3hxfzk
Larry
Subject: | Re: back in the air in michigan |
got the firestar out of the pole barn today and pre flighted it....gased
her up and the 503 fired up on the lst pull of the rope....smoked a lot from
being fogged last fall but cleared up and run so good that even thou it was
a bit cold I could not resist taking off for a about a half hour of flying
around the runway here on the farm...was good to get back to flying after
the winter and should get in 2 or 3 days before we get some
showers....looking forward to a summer of fun flying in the firestar.....Jswan
jim swan firestar ll 503 michigan
Subject: | 503 on a Firefly |
Kolbers , Anybody on the list ever put a 503 on a Firefly?They still make t
hem and they have dual ignition, A single carb ? =0A-Chris Davis=0AKXP 50
3 492 hrs=0AGlider Pilot=0ADisabled from crash building Firefly =0A=0A=0A
From: | "cristalclear13" <cristalclearwaters(at)gmail.com> |
clrprop wrote:
> John H.
> Slyck
That is so cute (hope you don't mind me calling it cute)! I love it! Those are
some great shots too.
Would a couple GI Joe dolls add enough weight? :) jk
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=294762#294762
Arksey(at)aol.com wrote:
> got the firestar out of the pole barn today and pre flighted it....gased her
up and the 503 fired up on the lst pull of the rope....smoked a lot from being
fogged last fall but cleared up and run so good that even thou it was a bit
cold I could not resist taking off for a about a half hour of flying around
the runway here on the farm...was good to get back to flying after the winter
and should get in 2 or 3 days before we get some showers....looking forward
> do not archive
Sounds like a good time. Makes me almost wish I had a pull start. Couldn't fly
yesterday because of a dead battery. It has been so windy this winter in GA...not
very many good flying days. I'm hoping for good weather next Saturday
to be able to fly to the Vidalia airshow again this year.
Cristal Waters
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=294775#294775
Subject: | Re: short video of today's trip |
Larry/Gang:
We are going to have a population explosion in Malheur County, Oregon,
next month. The population will increase by 4 or 5, maybe more. The
coyotes and antelope won't have a chance when confronted with the Kolb
Air Force.
In 4 weeks, I'll be hitting the trail for Monument Valley, Utah, and The
Rock House, Burns Junction, Oregon.
My little MKIII did great on my flight to Lakeland and back. I have a
few small maintenance matters to take care of and I will be ready to go.
Times a wasting!
john hauck
mkIII - 3,005.5 hours
The county that I live in, Malheur, (Spanish for bad water) is the
least populated in Oregon. Just right!
Larry
Sounds good John, the freezer is full.
Larry
Sent: Monday, April 19, 2010 7:14 AM
Subject: Re: Kolb-List: Re: short video of today's trip
Larry/Gang:
Air Force.
The Rock House, Burns Junction, Oregon.
Times a wasting!
john hauck
Larry
Subject: | Re: 503 on a Firefly |
I have an Original Firestar that is a sturdier machine than the Firefly. I was
told by Dennis Souder not to use any engine larger than a 40hp Rotax 447. I'm
a 200 lb guy and that 447 shoots me up in the air with no problem. It has plenty
of power. A 503 would be too much power and use more fuel. I'm sure the 447
is all the Firefly can handle. A 503 would also make the Firefly an overweight
ultralight.
Ralph B
Ralph B
Original Firestar 447
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=294845#294845
Subject: | Re: back in the air in Michigan |
Hi Rick,
have a safe trip home.....give me a ring when you are at Grand ledge
and maybe I can meet up for a visit......glad you had a good time at Sun and
Fun, saw the pictures of the group...I sure enjoyed the times I spent
there.... it was there that I saw a firestar being flown every day that
convinced me to buy one....find a place we can camp out for a few days up near
Hart and we will organize a get together to fly the lake michigan shore line
this summer..weather good here today, will fly some this evening.......jswan
Subject: | Re:back in the air in Michigan |
Cristal,
hope you get good weather for the Vidalia air show next
weekend....last year some of us kolb pilots here in michigan got together at the
fly
ins.....was fun....we have a email group to keep each other informed on when
and where we plan on attending, worked good....plan on the same thing this
year. Weather is always a concern and cancels some of our plans...yes there
is benefits to simplicity....my 503 starts so easy I see no need for a
electric starter.....and I am 79 years old...I do have a small battery for the
electric fuel pump and to power up my GPS but that is all of the modern
stuff I have on board.....fly safe....jswan
Things seem to be a bit slow, so here goes.
I tried really hard to keep my nose to the grind stone and get some
stuff done around the house. Yesterday was gorgeous and today is even
better. The temp started climbing at an unprecedented rate, (79 now ) so
I turned off the news got my rake and went to where I left off on the
runway. It sure funny but ground that won't grow anything but tumble
weeds and Goats heads (nasty caltrops type of plant) can sure grow
rocks. They just pop up every where you don't want them, but I digress-
There I was raking up a sweat and the wind just wouldn't blow. Finally I
couldn't stand it any longer so back I go, Tell the wife where I intend
to go, turn on the Spot tracking and roll out the Firestar.
I decided to follow the old ION Hwy to Rome and then see what interested
me. That is the Idaho,Oregon and Nevada Hwy. It was in use in the early
days of settlement here in the West. It lead into the mining camps of
Silver City and the like. (Yes there is one in Idaho, and probably most
every other state in the union.) The road goes down into Rome where one
of the early families built a Toll Bridge to cross the Owyhee River. I
then flew upriver dodging Ducks and Geese and then turned along the
Pillars Of Rome. ( settlement of a cafe with some gas pumps named Rome
because the early settlers thought that was what Roman Pillars should
look like.) I then took a better look at Scotts Butte, since some who
saw yesterdays post and pictures were curious.
As I mentioned it was the orifice where most of the Lava in this area
probably spewed out of.
Here is the URL for the Spot tracking if you are interested-
I also took a video that is about 8 minutes long that I will try to
upload to You Tube. When I get it done,I will supply the URL.
Flight was 45 minutes, burned less that 2.2 gallons. Did not use the
Hac-man system.
Larry
From: | "Mrs. Michelle Cole" <apilot(at)surewest.net> |
Are there any Kolbers near Chattanooga or LaFayett, Georgia?
---- Original message ----
>Date: Sun, 18 Apr 2010 17:10:34 -0600
>From: owner-kolb-list-server(at)matronics.com (on behalf of "Larry Cottrell" <lcottrell(at)fmtcblue.com>)
>Subject: Kolb-List: short video of today's trip
>To:
> Larry
> forwarding history, which includes my email address.
Subject: | video of todays flight |
http://www.youtube.com/watch?v=7RCwu2jGmi0
I apparently screwed up in that I use copy written music, so there is no
sound. Sorry!
Larry
Subject: | Re: video of todays flight |
> That is your best video yet, in my opinion, not because of the lack of
music track but because of the captions telling us what we are looking at as
we fly over it with you.
> Thom Riddle
Thom/Gang:
I especially enjoy Larry C's vids.
Being an Alabama boy, I feel extremely fortunate to have spent a lot of time
on the ground and in the air traveling the same routes that Larry shoots.
Most of the trails Larry flies, we ride on the quads in the Fall. It is a
very harsh and unforgiving part of the world.
Looking forward to renewing my aquaintence with the area next month and
relaxing at the Rock House.
john hauck
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: Firefly slide show |
Date: Tue, 20 Apr 2010 05:28:05 -0700 (PDT)
From: william sullivan <williamtsullivan(at)att.net>
Jack- How are you doing on the new engine? Haven't heard from you lately.
Bill,
Initially thought that the engine quit on the maiden flight due to
electrical problems. Did not like the way I had mounted the voltage
regulator and magneto kill switch. The regulator leads wiggled loose and
shorted. Reworked the whole works to come up with a better mounting and in
doing so saved a little weight. Also insulated the lead clips with shrink
tubing and then wire tied them in a way to prevent the clips from ever
coming loose. Also, to get the engine up to speed I purchased new set of 54
inch IVO ultralight blades.
Mounted the whole works and tried starting the engine. Found that the
engine would run a burst after the engine was primed and that was it. I
took the carburetor off and looked at the lower end to see if the metering
needle valve was stuck, and replaced the regulator diaphragm and the pump
parts. After this I have been able to get the engine to run, but now I am
having trouble with the engine loading up on fuel upon closing the throttle
after a high rpm run on the high speed jet. Upon cranking the engine
without priming, the engine floods. This indicates that the metering needle
is not seating, or very high flow resistance through the air filter.
Tomorrow, I will remove the air cleaner and see if the flooding problem
continues. If so, I will remove the carburetor and blow out the fuel
galleys up to and through the metering needle seat. And the try again.
The trials and tribulations of changing engines and learning about the
Tillotson carburetor.
Jack B. Hart FF004
Winchester, IN
Jack, here's a couple of sites that might have some useful
information. It's a ppg site but engines are engines...
http://aerocorsair.com/id27.htm
http://aerocorsair.com/id28.htm
http://www.aerocorsair.com/id150.htm
-Dana
When I was young I was told that anyone could be President. I'm beginning
to believe it.
Jack, I had many of the same problems with the Mikuni pumper carb on a
Zenoah engine. In my case, the problem was a very small tear in the pump
diaphragm. The solution was real simple, dump the pumper carb (Mikuni had
stopped making the carb and repair kits for it) and replace with a
conventional slide carb and separate fuel pump. Started first pull and never
had another problem.
Rick Girard
> Bill,
> 54
> needle
> Jack B. Hart FF004
> Winchester, IN
Date: Wed, 21 Apr 2010 07:48:00 -0500
Rick,
Supposedly there are several engines out there using this carburetor. I am
still on the lower end of the learning curve, so I will keep working with
for a while to see if I can master it.
Jack B. Hart FF004
Winchester, IN
Subject: | NEED MORE BRAKING POWER? |
I finally got back to working on the brakes. The c-90 brake calipers now being
used on the MK-3x and others require a brake pedal ratio of 4:1 to have really
good braking power. The pedals being used on our Kolbs have a ratio of 1:1
or less, according to Matco. If you don't seem to have good braking power, this
is probably your problem. I have been thinking about this for a while, trying
to find an easy way to modify what we already have. The picture should answer
any questions you may have to modify your existing pedals. This arrangement
should give you a ratio of 3:1. You could improve even more on this by raising
the top of the pedal another inch giving you the full 4:1 ratio called out
for the the instructions.
Rick Lewis
Rick Lewis
(VW Watercooled Engine)
http://forums.matronics.com/viewtopic.php?p=295180#295180
http://forums.matronics.com//files/pic00026_247.jpg
Subject: | Re: NEED MORE BRAKING POWER? |
could you press one of the pedals in a pic to show how this system works
from what I see in the pic all it would give you is more dead linkeage
but I could be wrong
working to much to get any flying in
Sent: Wed, Apr 21, 2010 8:35 pm
Subject: Kolb-List: NEED MORE BRAKING POWER?
being
lly
or
is is
to
any
uestions you may have to modify your existing pedals. This arrangement sh
ould
ive you a ratio of 3:1. You could improve even more on this by raising th
e top
f the pedal another inch giving you the full 4:1 ratio called out for the
the
nstructions.
Rick Lewis
ick Lewis
ttachments:
Yeah=2C Ellery=2C that's what I thought=2C too. It must work better in rea
l life than it looks like in the picture.
I'm going to be installing my brake cylinders and fluid tomorrow!
Mike Welch
MkIII CX
Subject: Re: Kolb-List: NEED MORE BRAKING POWER?
Date: Wed=2C 21 Apr 2010 21:17:13 -0400
could you press one of the pedals in a pic to show how this system works f
rom what I see in the pic all it would give you is more dead linkeage but
I could be wrong
Sent: Wed=2C Apr 21=2C 2010 8:35 pm
eing
lly
or
less=2C according to Matco. If you don't seem to have good braking power
=2C this is
probably your problem. I have been thinking about this for a while=2C tryi
ng to
any
questions you may have to modify your existing pedals. This arrangement sh
ould
give you a ratio of 3:1. You could improve even more on this by raising th
e top
of the pedal another inch giving you the full 4:1 ratio called out for the
the
instructions.
Rick Lewis
Rick Lewis
rget=_blank>http://www.matronics.com/Navigator?Kolb-List
_blank>http://www.matronics.com/contribution
The New Busy is not the too busy. Combine all your e-mail accounts with Hot
mail.
http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P
ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4
Subject: | Best Kolb video... |
Larry,
My vote for best Kolb video goes to Pillars of Rome. I watch everything you
post and am impressed with all your productions. Keep them coming!
Nick Cassara
Palmer, Alaska
This arrangement will give you a 3:1 ratio at the pedal. Look closely at the attach
points and you will understand how it works. The lower two bolts are 1"
out from the pedals plate, and the top of the pedal is 3" up from this point.
This give you the 3:1 ratio. After making the initial prototype you could instantly
feel the difference. Try to think of this as a crowbar pulling a nail,
only this is pushing a rod.
Rick Lewis
http://forums.matronics.com/viewtopic.php?p=295240#295240
Depending on the bore of the master cylinders you have (I seem to recall
that Matco only makes them in 5/8") you could change to a 3/4" (Grove makes
them, I checked) and increase your hydraulic leverage.
The other thing to consider is that increasing leverage, whether mechanical
or hydraulic, can get you to brake lock and a quick flip over on your back.
Just a couple of thoughts.
Rick Girard
> from what I see in the pic all it would give you is more dead linkeage but
> I could be wrong
> *Ellery Batchelder Jr.*
> From: Rick Lewis <cktman(at)hughes.net>
> To: kolb-list(at)matronics.com
> good braking power. The pedals being used on our Kolbs have a ratio of 1:1 or
is
> probably your problem. I have been thinking about this for a while, trying to
> find an easy way to modify what we already have. The picture should answer any
> questions you may have to modify your existing pedals. This arrangement should
> give you a ratio of 3:1. You could improve even more on this by raising the
top
> of the pedal another inch giving you the full 4:1 ratio called out for the the
> instructions.
> Rick Lewis
> Rick Lewis
Richard,
<< bore of the master cylinders you have (I seem to recall that Matco
only makes them in 5/8") you could change to a 3/4" (Grove makes them, I
checked) and increase your hydraulic leverage >>
Am I missing something? I thought the hydraulic leverage was the ratio
of the area of the two pistons involved. Increasing the size of the
master piston reduces this ratio.
Tom Kuffel
Subject: | Re: Need more braking power? |
- Increasing the cylinder size from 5/8" to 3/4" will give you a quicker
responce, because it will move more oil for the same stroke.- It will als
o give you less applied force at the brakes for the same pedal pressure.-
The pedal will move less, and need to be pressed harder to achieve the sam
e braking force.- Changing the pedal geometry allows you to apply more le
verage against the master cylinder, and down to the wheel.- It's a balanc
ing act.
This drawing, from Matco, is were I got the idea on the configuration I'm presenting
to the group. Going to there site will clear up anyone having a hard time
understanding how this pedal configuration increases your braking power. What
I was trying to do is come up with an easy way that everyone can increase
there braking power with a simple modification. It really does make an incredible
difference. I did a similar method on my previous home built, a Cozy.
Rick Lewis
Rick Lewis
http://forums.matronics.com/viewtopic.php?p=295329#295329
http://forums.matronics.com//files/2_140.bmp
I am pretty good at working with mechanical things and I just dont see ho
w that setup will do what you say it will you can send a pic of a pedal pu
shed and that will tell the story much better than your explanation
Sent: Thu, Apr 22, 2010 6:54 am
Subject: Kolb-List: Re: NEED MORE BRAKING POWER?
the
ttach points and you will understand how it works. The lower two bolts ar
e 1"
t.
nstantly feel the difference. Try to think of this as a crowbar pulling
a
ail, only this is pushing a rod.
ick Lewis
Date: Thu, 22 Apr 2010 14:01:19 -0500
Rick,
What is important here is the force that can be applied to the brake. The
higher the hydraulic pressure developed the greater the braking force. If
one assumes a 100 pound force is applied to the cylinder piston rod, the
hydraulic pressure developed will be force/piston area. For the 3/4 inch
diameter piston = 100/(3/8x3/8xpi) = 226 psi. For the 5/8 inch diameter
piston = 100/(5/16x5/16xpi) = 326 psi. So for the same pedal effort the
smaller bore cylinder will give 44% increase in pressure and braking.
Jack B. Hart FF004
Winchester, IN
I agree with Jack's figures
"The drawing you submitted to the list" if you have your Points as the dr
awings show you will only have changed the length of your pedal and not
gained anything by adding the extra linkage
because both both setups are doing the same thing with the same arm lengt
hs pushing the plunger down to make pressure in the brake system where yo
u are Gaining on braking power is having longer brake pedals that is all
it boils down to You changed the length of your brake pedals from 1X to
2.5X that is what your drawings show
I have heal brakes that worked good with small tires on ,when I went with
the 800-6 tires I lengthened my brake pedals 1.5 inches longer to make th
em as good as with the smaller tires I didn't change anything else on the
pedals other than the length from the pivot point north
Sent: Thu, Apr 22, 2010 9:51 pm
rom: Richard Girard
Rick,
r
e
Jack B. Hart FF004
inchester, IN
Oops! My only excuse is that I was six hours into watching my 3 year old
grandson, blaring Wallace and Gromit video going in the background and
trying to think all at the same time.
Rick
> drawings show you will only have changed the length of your pedal and not
> lengths pushing the plunger down to make pressure in the brake system where
> you are Gaining on braking power is having longer brake pedals that is all
> it boils down to You changed the length of your brake pedals from 1X to 2.5X
> the 800-6 tires I lengthened my brake pedals 1.5 inches longer to make them
> From: Jack B. Hart <jbhart(at)onlyinternet.net>
> From: Richard Girard <aslsa.rng(at)gmail.com>
> Rick,
> Jack B. Hart FF004
> Winchester, IN
Thom Riddle wrote:
> Larry,
I agree! That was great!
Cristal Waters
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=295359#295359
Subject: | New intercom and Waycross Sun N Fun video |
I broke down and bought the intercom that Jim Kmet said worked well in his Mark
III, the Sigtronics SPO-22N. It worked really well with just me and my radio
this evening. Now I have to find a guinea pig for a passenger to test out communication
in the cockpit. :D
I did not get to go to Sun N Fun but our airport did serve BBQ, hot dogs, chips
and sweet tea to those who stopped by to fuel up, so we got to see a lot of different
planes. I was able to go out to the airport a couple of those days and
took some pictures and video. I also got some pictures from a friend who served
up BBQ everyday, and so I combined them and made this video. The first
minute or so is a slideshow of just pictures and is silent. Then you will see
and hear some takeoffs and some T-34s doing some formation flying over our airport.
It was fun!
http://www.youtube.com/watch?v=eLOC-dadR34
Cristal Waters
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=295360#295360
everyone can increase there braking power with a simple modification.>>
I can see that just increasing the pedal length will increase the leverage
available to the pilot and thus increase the pressure he can apply. Are
there any limiting factors `downline? Joints and pipes premumably have an
upper pressure limit.
Pat
Subject: | for sale - Kolb Firestar II |
Kolb Firestar II - Estate Sale. Hirth, Powerfin. Built by A&P. Engine with
run-in time only plus less than 1 hour. Entire aircraft less than 1 hour
TTSN. Includes trailer. My father built this airplane and I am handling his
estate. The airplane is in Sequim, WA.
Larry E. James
Redmond, WA 98052
425-638-3133
From: | "Jerry Deckard" <flypoker(at)windstream.net> |
Subject: | firestar measurements |
I will be picking up a firestar and hauling it. I need to know what
height the bottom of boom tube is from the ground at front of the tail
feathers, also about mid way and at the fuselage. I plan to support the
tail with stryrofoam blocks in a few spots.
Jerry Deckard
Sent: Friday, April 23, 2010 10:48 AM
Subject: Kolb-List: for sale - Kolb Firestar II
with run-in time only plus less than 1 hour. Entire aircraft less than 1
hour TTSN. Includes trailer. My father built this airplane and I am
handling his estate. The airplane is in Sequim, WA.
Larry E. James
Redmond, WA 98052
425-638-3133
Subject: | Partnership Mark III-C |
From: | "Watkinsdw" <david.watkins0(at)gmail.com> |
Sadly, my partner Jeff needs to sell his share of our Mark III-C. We're based in
Pompano Beach, FL (KPMP,) have a hanger that costs $60/month, and a great Kolb
built by Steven Green. Rotax 912 ULS (100hp), 600 hours on the engine, 630
on the airframe, fresh annual. We meet the requirements for the 1500 tbo.
Price is $11,000 for 1/2 ownership.
Anyone interested should call Dave Watkins at 954-608-5423.
http://forums.matronics.com/viewtopic.php?p=295447#295447
http://forums.matronics.com//files/2001_kolb_mark_31_112.doc
Subject: | Re: Partnership Mark III-C |
Apologies: I inadvertently included the information page that Steven provided when
he originally sent me the photos he took of our Kolb. Please contact me at
954-608-5423 if you're interested in more information on the aircraft.
We have made some changes in the equipment list:
Sigtronics intercom
Garmin 196 GPS
Two DRE ANR headsets
Transponder w/ Mode C
New gel battery
http://forums.matronics.com/viewtopic.php?p=295449#295449
Dave
Sorry that 'change' mandates a sale of 1/2 of your Mark111. That must
be sad for all concerned.
Does that mean the total ownership could be sold for a single payment
of $22K?
Russ K
> We're based in Pompano Beach, FL (KPMP,) have a hanger that costs
> $60/month, and a great Kolb built by Steven Green. Rotax 912 ULS
> (100hp), 600 hours on the engine, 630 on the airframe, fresh
Good question, Russ.
I see that as the very last resort.
Price-wise, 11k is a discount to encourage
an investor. A sale of the aircraft would require
a bit more.
Dave
http://forums.matronics.com/viewtopic.php?p=295482#295482
Subject: | Re: BNC bulkhead connector |
Jimmy,
Show this to your local Radio Shack sales clerk.
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=bnc%20connector&origkw=bnc%20connector&sr=1
or
http://tinyurl.com/22o95ly
I suspect this particular clerk was selling underwear at K-Mart last week and will
be flipping burgers next week.
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=295613#295613
Subject: | Kuntzleman SC 103 strobe |
Hey Kolbers,
I just bought a Kuntzleman Electronics SC 103 self-contained strobe
rather than installing rear view mirrors to reduce the danger of getting
rammed in the butt by some 150 kph GA pilot who didn't see me. I'd
appreciate any Shirleys from posters with experience. Shirley do this
and Shirley don't do that. You know the drill. I'm mounting it on a
FireFly with a 447 and a battery, so any advice at all.
Mr. Alexander, my son and grandson, Dave and Goober, went to Sun 'N
Fun. Told him to look up the Kolbers gathered there. He said it's so
big he never even got sight of a Kolb. Well, at least my son _almos_t
got to meet you and the other Kolbers... Also, George, I got your email
about pics and captions about the trailer I converted into a hangar.
Spring's BUSY, but as soon as I get a break that doesn't take away from
my time in the sky I'll get it done and email it to you.
Thanks in advance for any hints, advice and Shirleys re: mounting my strobe.
Dave Kulp
Bethlehem, PA
FireFly 11DMK
Subject: | Re: Kuntzleman SC 103 strobe |
Shirley you jest. The number one reason people turn left in front of fire
engines is that they didn't see them. Be thankful it's a real big sky. :-}
Rick Girard
On Sun, Apr 25, 2010 at 2:19 PM, David Kulp wrote:
> Hey Kolbers,
> I just bought a Kuntzleman Electronics SC 103 self-contained strobe rather
> than installing rear view mirrors to reduce the danger of getting rammed in
> the butt by some 150 kph GA pilot who didn't see me. I'd appreciate any
> Shirleys from posters with experience. Shirley do this and Shirley don't do
> that. You know the drill. I'm mounting it on a FireFly with a 447 and a
> Mr. Alexander, my son and grandson, Dave and Goober, went to Sun 'N Fun.
> Told him to look up the Kolbers gathered there. He said it's so big he
> never even got sight of a Kolb. Well, at least my son *almos*t got to
> meet you and the other Kolbers... Also, George, I got your email about pics
> and captions about the trailer I converted into a hangar. Spring's BUSY,
> but as soon as I get a break that doesn't take away from my time in the sky
> strobe.
> Regards,
> Dave Kulp
> Bethlehem, PA
> FireFly 11DMK
Run it every time the engine's making noise. And if you are having to play hangar
queen for a while, go turn it on and run it anyway. The more you tickle 'em,
the happier they are.
Other than that - if you mostly fly real low, mount it on the faded side.
Richard PIke
MKIII N420P (420ldPoops)
http://forums.matronics.com/viewtopic.php?p=295668#295668
Here is where I placed my strobe. It seems to work pretty well and is visible from
mostly every direction. It is always on when the engine is producing electricity.
Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/
http://forums.matronics.com/viewtopic.php?p=295671#295671
http://forums.matronics.com//files/strobe_203.jpg
Subject: | remembering Dave Bigelow |
Firestar pilot
http://tinyurl.com/2eu3bqa
Subject: | 180 turn back to the runway video |
Hello All,
One of the things I have always wanted to test was the height required to get back
to a runway after take off. On Sunday, I got a chance to do some testing
and I got a video of it. The runway I am flying from is about 2500 feet long.
I found that it required about 500' for me to make the 180 and get back to the
end of the runway. I tried it at 400' but the ending was not pretty (nothing
bent). The interesting thing is that at 600' I could not make the runway because
I had traveled further away from the runway than the extra 100' in altitude
allowed me to make up. My engine has a clutch, so the prop windmills at
engine idle just like it would windmill if the engine failed.
http://www.youtube.com/watch?v=Pn6T8ynRDLk
FWIW
Jason
MKIII Yamaha powered
Portland, OR
http://forums.matronics.com/viewtopic.php?p=295752#295752
Subject: | Re: 180 turn back to the runway video |
interesting info jason.....my advice for what it is worth that with a
engine failure on take it is best to go forward rather than trying to turn back
around to the runway. keep us informed on any future tests....jswan
the end of the runway.
FWIW
Jason
Portland, OR
Jason O/Gang:
Thanks for sharing your experiences.
What is the name of your airstrip?
Where is it located?
Does it have an identifier?
GPS coordinates?
Would I need prior permission to land there?
If I make it to the West Coast of Oregon, I will probably come through the
Portland area next month after I depart The Rock House the end of May.
john hauck
MKIII - 3,006.2 hours
912ULS - 437.7 hours
Titus, AL
I agree Jim,
That is why I am interested in this learning about this envelope of my airplanes
performance. I now know that on a 2500 foot runway, I should not attempt to
return (factoring in the reaction time if the engine actually did quit unexpectedly).
If I am flying out of a 3500 foot runway, I have a window between 600'
and probably 800' that returning is an excellent option. My next testing is
how high can I get and still land straight ahead on the same runway and getting
a technique down. I believe that if I have this knowledge that before I take
off from any runway, I can make my emergency procedures before take off. For
instance, I can make up the emergency procedures for a 3000 foot runway that
says below 200' land straight ahead, between 600' and 700' return to the runway.
Between 200' and 600' neither of those are an option and find the best landing
spot. I then call out these altitudes (to myself) and if the engine does
quit, I know what to do without wasting precious seconds thinking about it
or making a bad decision and trying to turn back or land straight ahead when it
is not physically possible.
Jason
[quote="Arksey(at)aol.com"]interesting info jason.....my advice for what it is
worth that with a engine failure on take it is best to go forward rather than
trying to turn back around to the runway. keep us informed on any future tests....jswan
> [b]
http://forums.matronics.com/viewtopic.php?p=295759#295759
Jason=2C
Very interesting exercise. For you and your plane=2C under these identic
al conditions=2C
you feel that 500' agl is a safe u-turn height to make it back to the field
. That is good.
However=2C I want to point out that these are narrow parameters to duplic
ate. For instance=3B if you add a little headwind (which would then becom
e a tailwind on a 180 deg turn)=2C or if you add a passenger=2C or the dens
ity altitude is different=2C the outcome may be quite different.
I'm not trying to rain on your parade=2C Jason=2C I just want to make sur
e we all remember this particular scenario has limited value.
Being proficient at 180 degree turns (after take-off) is great!!!! But
to be truly proficient=2C you'd need to practice in ALL wind conditions=2C
several weight conditions=2C and various density altitude conditions=2C and
combinations of all of these.
Practicing proficient flying techniques is ALWAYS good advice. Especiall
y those techniques that deal with emergency proceedures!! But=2C unless a
pilot were incredibly confident he could make the field on a u-turn landin
g after an engine failure=2C the best advice is to always land straight ahe
ad.
BTW=2C keep in mind that practicing low level u-turns amount to acrobatic
flying. More than a few pilots have died finding out that what they thoug
ht would work....didn't!!!
Okay everybody=2C now you can beat me up.
Mike Welch
MkIII
> Subject: Kolb-List: 180 turn back to the runway video
> From: jason@trek-tech.com
> Date: Mon=2C 26 Apr 2010 09:26:33 -0700
> Hello All=2C
get back to a runway after take off. On Sunday=2C I got a chance to do som
e testing and I got a video of it. The runway I am flying from is about 250
0 feet long. I found that it required about 500' for me to make the 180 and
get back to the end of the runway. I tried it at 400' but the ending was n
ot pretty (nothing bent). The interesting thing is that at 600' I could not
make the runway because I had traveled further away from the runway than t
he extra 100' in altitude allowed me to make up. My engine has a clutch=2C
so the prop windmills at engine idle just like it would windmill if the eng
ine failed.
> FWIW
> Jason
> Portland=2C OR
ox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O
Hello Mike,
I am not going to beat you up and I agree that someone should not try to apply
my experience to their plane, they should get out there and practice themselves.
Go to altitude and practice power off 180's. See how much altitude you loose,
find the best glide of your aircraft. Then , if you have a safe place to
practice them at lower altitudes and feel you are proficient enough, go ahead
and try them out.
I agree that the plane will perform differently (and everybody's planes are different)
under different wind conditions and weights, but I do believe this gives
ME a valuable base line from where to take all of the variables into consideration
before I start my take off roll.
This is just like the "practicing dead stick landings" everybody's. Some people
say more planes are bent practicing than in actual situations. In my plane,
I can have the engine at idle and it performs exactly like when the engine is
no longer running.
You stated "unless a pilot were incredibly confident he could make the field on
a u-turn landing after an engine failure, the best advice is to always land straight
ahead" I agree, but how is one suppose to know if he can make the field
on a U turn? Thats just like saying, unless a pilot were incredibly confident
he could shoot an ILS landing the best advice is to always fly clear of clouds.
If this were true, no one would every learn how to fly on instruments.
That is why you practice under a hood with a safety person in the cockpit. I
believe that is what I was doing, practicing this maneuver with my safety person
(fully functional engine) in the cockpit.
As I stated before, for me, it is good to know ahead of time what my emergency
procedure is. If I do my call outs in my head, I will not fool myself into something
that is not possible and try to turn back below 600' no matter how uninviting
the terrain ahead may be, I know and have experienced that I will not
make it back to the runway.
I am not a high time pilot so no one should take this as the voice of experience.
Always fly your airplane in a manner in which you feel safe.
Jason
[quote="mdnanwelch7(at)hotmail.co"]Jason,
Very interesting exercise. For you and your plane, under these identical conditions,
you feel that 500' aglis a safe u-turn height to make it back to the field. That
is good.
However, I want to point out that these are narrow parameters to duplicate. For
instance; if you add a little headwind (which would then become a tailwind
on a 180 deg turn), or if you add a passenger, or the density altitude is different,
I'm not trying to rain on your parade, Jason, I just want to make sure we all
Being proficient at 180 degree turns (after take-off) is great!!!! But to be
truly proficient, you'd need to practice in ALL wind conditions, several weight
conditions, and various density altitude conditions, and combinations of all
of these.
Practicing proficient flying techniques is ALWAYS good advice. Especially those
techniques that deal with emergency proceedures!! But, unless a pilot were
incredibly confident he could make the field on a u-turn landing after an engine
failure, the best advice is to always land straight ahead.
BTW, keep in mind that practicing low level u-turns amount to acrobatic flying.
More than a few pilots have died finding out that what they thought would work....didn't!!!
Okay everybody, now you can beat me up.
Mike Welch
MkIII
> Subject: 180 turn back to the runway video
> Date: Mon, 26 Apr 2010 09:26:33 -0700
> Hello All,
back to a runway after take off. On Sunday, I got a chance to do some testing
allowed me to make up. My engine has a clutch, so the prop windmills at engine
> FWIW
> Jason
> Portland, OR
> &g========================>
> Hotmail has tools for the New Busy. Search, chat and e-mail from
your inbox. Learn more.
> > [b]
http://forums.matronics.com/viewtopic.php?p=295763#295763
Just a note. Had the 447 ice up on take off from Painton Airport, and the
engine started to droop very badly. Dropped the nose on the FireFly and
kicked it around and back to the runway down wind. I had not prepared my
self for which way to turn, and automatically turned left in the normal
pattern direction. But there was a strong cross wind from the right and it
blew me off into a much larger turn than I would have hoped for.
I made it just fine, but it taught me a lesson, to always think before take
off about which way to turn if the engine quits on the initial climb out.
Jason, I think it is great that you are preparing your self for the
possibility of engine failure after take off. Another exercise that may be
helpful is to practice spilling altitude to land at a spot directly below or
to make high approaches and still touch down at the usual spot. Having
practiced this with the FireFly it really helped me when the MZ34 quit on
its first flight. I was able to zip back to the airport, turn over the end
of the runway at 1,000 agl, and forward slip it down the runway so that
after touch down, I did not have to push the FireFly far to get it off the
other end of the runway. When I initially practiced this, I over shot my
aiming point. I found I could be much more aggressive with the forward
slip, and forward stick and I could hit my aiming point. It looks and feels
a little weird but the FireFly is so draggy the airspeed does not climb too
high, and one can spoil a lot of altitude in a hurry. One nice thing about
this manuver is that when you pop it out of the slip you have plenty of
excess air speed or energy that can be used to make a nice landing.
FWIW
Jack B. Hart FF004
Winchester, IN
Subject: | Flying the Kolb Ultrastar |
From: | Jean PILLAUDIN <jean.pillaudin(at)gmail.com> |
Hi Kolbers,
I read the list here in France with a big interest!
I am very pleased to show you my second fly with my 20 years old Kolb
Ultrastar (Pulsar in France).
It was a great fun. This ultralight is very easy and funny, it give a lot of
pleasure for low cost!!
Here are the pictures :
http://picasaweb.google.com/Jean.PILLAUDIN/2010_04_24?authkey=Gv1sRgCKmypMaFycfksAE&feat=directlink
Bye
Jean
Q' importe le frelon pourvu qu'on ai l'ivresse!
Subject: | Re: Flying the Kolb Ultrastar |
Cool..... :D
2000 Firestar II
R503 DCDI
VLS 750
2010 Waiex
Jabiru 3300
1980 Quickie 1
Electric?
Needs restoration!
http://forums.matronics.com/viewtopic.php?p=295798#295798
OK, now you can beat me up too.
Esp since I'm a non-Kolb pilot.
But all this recent talk about minimum altitude to make a 180 back to
the runway after an engine failure on takeoff -- the early posts, at
least, and the video, indicate that the trials were done right off
the runway, at an altitude of 500' AGL or so.
IMHO, THIS IS ASSININE!
For the luvva Pete, and your loved ones, do these trials AT ALTITUDE!
The graveyard's full of people who didn't.
So beat me up if you want to. I only hope this will save a life &
avoid a crash or two.
Russ K
On Apr 26, 2010, at 1:48 PM, Mike Welch wrote:
> Jason,
> the field. That is good.
> duplicate. For instance; if you add a little headwind (which
> would then become a tailwind on a 180 deg turn), or if you add a
> passenger, or the density altitude is different, the outcome may be
> quite different.
> sure we all remember this particular scenario has limited value.
> great!!!! But to be truly proficient, you'd need to practice in
> ALL wind conditions, several weight conditions, and various density
> altitude conditions, and combinations of all of these.
> Especially those techniques that deal with emergency
> proceedures!! But, unless a pilot were incredibly confident he
> could make the field on a u-turn landing after an engine failure,
> acrobatic flying. More than a few pilots have died finding out
> Mike Welch
> MkIII
Jason Omelchuck wrote:
> Hello All,
the end of the runway. I tried it at 400' but the ending was not pretty (nothing
because I had traveled further away from the runway than the extra 100' in altitude
> FWIW
> Jason
> Portland, OR
Wish I had that many open fields to choose from for emergency landing spots.
Please be careful. Do you know your stall speed on a steep turn?
Cristal Waters
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=295812#295812
Russ K
Russ/Gang:
Would be a good idea to get some flight experience in a Kolb.
What Jason was doing was normal Kolb flying in my book.
I believe he has learned a great deal more about his airplane.
john hauck
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Not sure why you want to get beat up, but if it make you feel better
have your wife do it for us. In actuality the way that he did it was the
safest way to have done it at all. If you recall, he has a clutch, so
whether the engine is running or not, and his was, his prop is going to
spin and slow him down a lot. All he had to do was to apply throttle and
he is running again, so the danger that he put himself into was no worse
than any power off landing, whether it be straight in or not.
Now I don't have a clutch, but you can be sure that if you are not going
to make the runway, you are going to know it a long time before it gets
critical. If you have to pull start the engine, then you are engaging in
risky behavior, with a starter it is doable without too much risk.
Now the following may be only applicable to myself, if you do not react
this way, then by all means feel free to disregard the following. I have
had at least two situations that could be qualified as an emergency. The
first one was an engine malfunction wherein a spark plug cap disengaged
from the spark plug. I had noise, but no real power. I reverted to the
type of landing that I would normally make. Muscle memory if you will. I
picked a spot to land that was the best choice open to me, throttled
back and set it down. There was a large rock that I could not see, ended
up on my back with gas dripping by my ear. Besides the damage to the
landing gear, and a crushed nose cone, I had a prop strike when I
flipped, and a bit more damage than necessary. What would have been
better would have been to shut off the engine, master switch, and made
my approach as slow as I could, even to pancake it in if necessary. I
had never faced the possibility of an off field landing, so I reverted
to what I did each time I landed. No emergency practice or even thought
of what I would do in an emergency, nothing.
Now after that and early last year there was the original discussion
about how much altitude one needed to make a unpowered turn. I went out,
( I did use more altitude however) and found that I could make a full
turn within 200 feet. One of my misadventures with a HAC-man wherein I
neglected to turn it off as I was coming in for a landing. ( I ascribe
no blame to the HAC-man system. It operated as it was designed to do.
The fault was entirely mine.) I was on final approach to my cross wind
runway, which is a bit uphill. I was probably under 300 feet, the engine
quit. Straight ahead there was nothing but sage about two feet high.
Behind me was a clear patch of dirt that was as smooth as one could ask
for. It was also on down sloping ground. I knew I had altitude enough to
turn, the question was whether I had enough altitude to make the
clearing. Well I did, skimming the last piece of sage between me and the
clearing. I shut off the HAC-man, started the engine and went home to an
ass chewing by the little lady.
Now I will not deny that there was a large measure of luck, but I knew
how much it would take to turn, I knew what my best glide was, and I
pulled it off with no repair, other than my britches. Had I gone
straight ahead, I would have been replacing the nose cone, and probably
recovering.
My point is if you do not know how the plane will react, you will have
no other choice than muscle memory. Yes straight ahead is probably
safest if you don't know, but its most likely gonna hurt. Any exercise
that you are going to attempt should be carried out with as much safety
cushion as you can get, but knowing what to expect from your plane and
preparing yourself for it is priceless.
Now I thought that this should be classified as gentle, but I think he
did as he should have done. An emergency is no place for guesswork.
Larry
Note: If you forward this email, please delete the forwarding history,
----- Original Message -----
Sent: Monday, April 26, 2010 6:25 PM
Subject: Re: Kolb-List: 180 turn back to the runway video
Russ K
good thinking Jason.....let us know your final results i am sure we will
find them interesting and helpful.....jswan fly safe .....
Hello Crystal,
In a descending (power off) turn at constant airspeed your airplane will stall
at the same speed it does straight ahead with power off. The risk is keeping
the turn coordinated so that remains true for both wings. The tendency is to
try to put in too much rudder to tighten the turn and you then run the risk of
the inside wing stalling. when I first started practicing at altitude, I noticed
I could feel the wing start to bobble at stall and that it would increase
the bank and start the beginning of a spiral. It was a little unnerving at first,
but I noticed I could keep it from developing by a little opposite rudder
and of course getting the nose down ever so slightly to keep the airspeed up.
I did practice (at altitude) going from a full throttle climb to a descending
180 turn while trying to keep a constant airspeed. One of the things I think
I have learned while doing this close to the ground is that the fear of hitting
the ground is a very ingrained in my brain. It is an un-natural act to put
the nose down to save yourself from hitting the ground. I believe this has
caused many an airplane accident because it is just does not make sense, your
instinct really wants to pull back on the stick to extend the glide just that
little bit more. This sensation does not get triggered when flying at altitude.
I believe this is the reason that many a Kolb landing gear has been bent by
people who are used to flying GA aircraft. To the pilot of a faster airplane,
the angle of approach that must be kept close to the ground before round out
is alarming until you do it many times.
My $.02 worth
Jason
> > Hello All,
to the end of the runway. I tried it at 400' but the ending was not pretty (nothing
altitude allowed me to make up. My engine has a clutch, so the prop windmills
at engine idle just like it would windmill if the engine failed.
> > FWIW
> > Jason
> > Portland, OR
http://forums.matronics.com/viewtopic.php?p=295828#295828
stall at the same speed it does straight ahead with power off. >>
Sorry but that is not true.
Two things happen when you turn.
1. Your apparent weight will increase because of the `G` force engendered by
turning.
2. Your generated lift will diminish because lift is always generated at
right angles to the wing and if you turn part of the lift will be used to
turn you.. The steeper your turn the worse both of these effects become.
You MUST increase your speed to compensate.
Cheers
Pat
> Hello All,
> get back to a runway after take off.>>
Neatly done and a good video.. The cut back of the engine and the lowering
of the nose were simultaneous. In a real emergency you will lose a couple
of seconds at least wondering `What the *******has happened`. Also there
was no or very little wind. A few knots on your nose turning rapidly to a
few knots up your tailfeathers will reduce your flying speed and INCREASE
you ground speed and the length of your landing run considerably.
You took off from pretty well down the runway and consequently had a good
length of runway behind you to land on. My Xtra would have been at 500 feet
while you were still on the ground and in the event of a 180 degree turn
back there would have been considerably less useable runway.
I dont know how much difference there is in the glide produced by a stopped
prop as opposed to a windmilling one., perhaps someone has the figures.
Thanks for doing the experiment. I shall make sure I do not turn back at
500ft or less.
Cheers
Pat
turning.
Cheers
Pat
Patrick L/Gang:
I think we did this argument some time ago. And....I think Tom Kuffle
presented a good explanation of this, but I am probably wrong.
Don't we have to take into consideration this is a descending turn?
john hauck
Hello Pat,
I believe this is true. A descending (power off) turn at constant airspeed is
a 1G maneuver. If you bank steeper you descend faster and you are still at 1G.
Jason
> turning.
> Cheers
> Pat
http://forums.matronics.com/viewtopic.php?p=295856#295856
Jason,
Took some data from your video. I recorded the time of lift off, point of
throttle pull back, approximated after completion of 180 turn, and touch
down.
You were getting to 500 feet in about 30 seconds for a climb rate of 1,000
ft/min. Your 180 degree turn took about 17.5 seconds for a good turn rate
of 620 deg/min. Glide time was about 32.5 seconds for an average decent
rate of 923 ft/min. The latter is very good considering the wind milling
propeller. In your case there has to be an optimum ias that gives you the
best glide for a wind milling propeller. You may want to consider VG's to
increase lift to help off set the wind milling propeller drag. Also, I have
found they will greatly reduce twitchyness felt during steep turns with the
FireFly.
Keep up the good work.
Jack B. Hart FF004
Winchester, IN
john hauck
John and the gang
Back in my training for private ticket,, when doing a power off left turn
from base to final, especially if there was a bit of a left cross wind on
final , I would bank the plane a bit more than usual to stop the drifting
from the cross wind in order to line up with the runway. That precipitated
a long lesson on accelerated stalls, with special emphasis on base to final
turns. Long story short I think Pat was right.
Boyd
FireFly.
Jack B. Hart FF004
Winchester, IN
Jack H/Gang:
Do VGs increase lift? The reason I ask is I do not know.
I thought VGs decreased stall speed.
Also, could you explain "twitchyness" during steep turns with the Firefly?
john hauck - Twitchy after operating the "bush hog on a pole" (weed eater)
all morning.
I found in my experiments with this situation that a slow flat turn was
better than a steep quick turn. Keeping that in mind if there is any
increase in G forces it was negligent, therefore the stall would not
increase. Of course I had VG's :-)
Larry
Sent: Tuesday, April 27, 2010 10:20 AM
Subject: Re: Kolb-List: Re: 180 turn back to the runway video
engendered by
turning.
at
used to
become.
Cheers
Pat
Patrick L/Gang:
john hauck
his prop is going to spin and slow him down a lot. All he had to do was to
apply throttle and he is running again, so the danger that he put himself
into was no worse than any power off landing, whether it be straight in or
not.
Have you ever heard of an accelerated stall. It usually happens when
yanking and banking. Maybe I am out of place because I have not seen the
video. But I have not seen these thoughts expressed in this thread. If the
turns are less than 30 deg and the g load less than 1.5,, you may be ok.
if the turn is 60 or more deg bank and g load 2 or above. You best know
what the stall looks and feels like, and at what speed, in that
configuration. In these conditions the stall can occur well above the
straight and level stall speed. And a stall at a high bank angle at 500 ft
and under can cause a sudden end to a very good day. Even if your engine
is running.
Boyd Young
Hello Pat,
The wind would have to be blowing on the order of 10 to 15 knots (an estimate)
down the runway to be in danger of running out of runway on the landing roll.
I recommend you not taking this information and applying it to your airplane.
From your description of the way you plane can take off, it obviously has much
different flight characteristics than mine. I would highly recommend you go
to altitude and practice full power climb to descending 180. If you get comfortable
doing them at altitude, you may want to work up to finding a nice safe
place and doing some testing yourself. Just hearing about someone else doing
it will not replace training or practice.
Best Wishes
Jason
> > Hello All,
> 500ft or less.
> Cheers
> Pat
http://forums.matronics.com/viewtopic.php?p=295873#295873
Hello Boyd,
Again, a descending (power off) turn at constant air speed is a 1G maneuver.
Jason
[quote="by0ung(at)brigham.net"]his prop is going to spin and slow him down a lot.
All he had to do was to apply throttle and he is running again, so the danger
that he put himself into was no worse than any power off landing, whether it
Have you ever heard of an accelerated stall. It usually happens when yanking
and banking. Maybe I am out of place because I have not seen the video.
But I have not seen these thoughts expressed in this thread. If the turns are
less than 30 deg and the g load less than 1.5,, you may be ok if the turn
is 60 or more deg bank and g load 2 or above. You best know what the stall
looks and feels like, and at what speed, in that configuration. In these
conditions the stall can occur well above the straight and level stall speed.
And a stall at a high bank angle at 500 ft and under can cause a sudden end
to a very good day. Even if your engine is running.
Boyd Young
> [b]
http://forums.matronics.com/viewtopic.php?p=295874#295874
>stall at the same speed it does straight ahead with power off...
Jason,
This is simply not correct. I suggest you review "accelerated stalls". In
a coordinated turn, the stall speed increases as a function of the bank
angle. The effect is small for shallow turns, but, for example, in a 60=B0
banked turn when you're pulling 2g, the stall speed is 41% higher.
Trying to turn too tight at low altitude, whether it's a flat skidding turn
leading to the inside wing stalling, or an accelerated stall, is what does
in a lot of pilots.
-Dana
Illegal aliens have always been a problem in the United States. Ask any
Indian.
Another ultrastar!!! I dont feel so alone now.......even though he is on
the
other side of the planet...
Hello Dana,
If you are not descending and under power you are correct. If you are power off
and loosing airspeed, you are correct. If you are power off and descending
at a constant airspeed, it is a 1G maneuver.
Jason
Jason,
This is simply not correct. I suggest you review "accelerated stalls". In a
coordinated turn, the stall speed increases as a function of the bank angle.
The effect is small for shallow turns, but, for example, in a 60 banked turn when
Trying to turn too tight at low altitude, whether it's a flat skidding turn leading
to the inside wing stalling, or an accelerated stall, is what does in a
lot of pilots.
-Dana
Illegal aliens have always been a problem in the United States. Ask any Indian.
> [b]
http://forums.matronics.com/viewtopic.php?p=295881#295881
Kolb pilots,
Another thing that I always try to make a habit when I take off is
whenever I reach the point where an abort straight ahead back to the
remaining runway becomes doubtful or unlikely is to drift off to the
downwind side of the runway from whatever crosswind there may be, so
that a turn back to the runway is into the wind and also requires less
degree of turn to reach the runway again.
I like to stack the deck in my favor as much as possible when I am
taking off.
Also being aggressive in air speed and bank angle in a turn back
reduces the time required to make a 180 and shortens the distance back
to the threshold.
IOW Control the airplane, don't let the airplane control YOU. YOU put
the airplane down, don't let the airplane put YOU down.
Gene
On Apr 26, 2010, at 11:00 PM, Jason Omelchuck wrote:
> Hello Crystal,
> will stall at the same speed it does straight ahead with power off.
> The risk is keeping the turn coordinated so that remains true for
> both wings. The tendency is to try to put in too much rudder to
> tighten the turn and you then run the risk of the inside wing
> stalling. when I first started practicing at altitude, I noticed I
> increase the bank and start the beginning of a spiral. It was a
> little unnerving at first, but I noticed I could keep it from
> developing by a little opposite rudder and of course getting the
> nose down ever so slightly to keep the airspeed up. I did practice
> (at altitude) going from a full throttle climb to a descending 180
> think I have learned while doing this close to the ground is that
> the fear of hitting the ground is a very ingrained in my brain. It !
> is an un-natural act to put the nose down to save yourself from
> hitting the ground. I believe this has caused many an airplane
> accident because it is just does not make sense, your instinct
> at altitude. I believe this is the reason that many a Kolb landing
> gear has been bent by people who are used to flying GA aircraft. To
> the pilot of a faster airplane, the angle of approach that must be
> kept close to the ground before round out is alarming until you do
> it many times.
> My $.02 worth
> Jason
>>> Hello All,
>>> required to get back to a runway after take off. On Sunday, I got
>>> a chance to do some testing and I got a video of it. The runway I
>>> am flying from is about 2500 feet long. I found that it required
>>> about 500' for me to make the 180 and get back to the end of the
>>> the extra 100' in altitude allowed me to make up. My engine has a
>>> clutch, so the prop windmills at engine idle just like it would
>>> FWIW
>>> Jason
>>> Portland, OR
>> landing spots.
Every thing and every plane is different, and I intend to pursue my
findings further, but the turns that I did last spring in testing this
theory proved to me that I lost much more altitude in a steep turn than
what I did in a slow flat turn. Of course I have VG's and that made my
findings different from most of you. I tried it both ways and I found
that clam, slow and easy worked the best for me. Your experience may
be different!
Larry
Sent: Tuesday, April 27, 2010 6:19 AM
Kolb pilots,
to the threshold.
Gene
In my early days, I use to practice this 180 turn back to the runway. First few
in a Cessna 150 I lost about 600 ft. Then, using a more aggressive dive, turn
and bank, I got the Cessna around with only 150 foot loss of altitude. About
10% of the time, I could get it down to 100 footloss. Later, in my PA-11 Cub,
I could consistently get it back to the runway with a 50 foot loss of altitude.
It just takes practice with a sound technique. Vic
>Date: Tue, 27 Apr 2010 17:05:57 +0100
>From: owner-kolb-list-server(at)matronics.com (on behalf of "pj.ladd" <pj.ladd(at)btinternet.com>)
>To:
>> Hello All,
>500ft or less.
>Cheers
>Pat
Hello All,
Here is where this very topic was discussed in detail on this list before. FWIW.
http://forums.matronics.com/viewtopic.php?t=38477&highlight=descending+turn+stall
Jason
http://forums.matronics.com/viewtopic.php?p=295922#295922
>Jack H/Gang:
>Thanks,
John,
You are correct in that VG's reduce stall speed. Therefore it stands to
reason that if one flys at the previous stall speed or faster, the VG's will
generate more lift than the wing did before the addition of VG's. Also when
in level flight the AOA will be less and the drag associated with that IAS
will be less too.
When I installed the VG's, the 447 was mounted on the FireFly and after I
had changed from 15 inch chord ailerons to 9 inch chord ailerons. The
description of what happened when I installed them can be found at:
http://jackbhart.com/firefly/firefly18.html
What I mean by twitchy is the feeling one gets through the lower cheeks that
things are not going well or as one expects. I had the feeling that if I
pushed the FireFly on a downwind to base bank that it felt like it wanted keep
right on going over onto its back. As a result I never made very steep left
banks. I had no problem with banks to the right. After I mounted the VG's
this sensation disappeared, and flying enjoyment increased.
Jack B. Hart FF004
Winchester, IN
I usually read the responses to a post before I offer my 2 cents. BUT, unless
you a re a really low time Kolb pilot
you should eventually pick up on how your wing is feeling. Smooth, low pull turns
like we saw in that excellent video
would not cause a problem. -that is as long as the driver has a good feel for
load inducement and keeps his buttocks
free from excessive compression. Lowering the nose will do just fine.
Once again, you cannot stall an airplane at zero Gs.
BB
On 27, Apr 2010, at 1:15 PM, Jason Omelchuck wrote:
> Hello Boyd,
> Jason
lot. All he had to do was to apply throttle and he is running again, so the danger
are less than 30 deg and the g load less than 1.5,, you may be ok if the
turn is 60 or more deg bank and g load 2 or above. You best know what the
stall looks and feels like, and at what speed, in that configuration. In these
end to a very good day. Even if your engine is running.
> Boyd Young
>> [b]
>power off and loosing airspeed, you are correct. If you are power off and
>descending at a constant airspeed, it is a 1G maneuver.
People argued with me in the previous thread you referenced, but I stand by
what I said: It is impossible to maintain a turn at constant airspeed
without exceeding 1G, unless your rate of descent constantly increases at
an acceleration rate corresponding to the loss of lift due to the bank.
Take a 45 degree bank, for example. In a normal, coordinated, level turn,
you pull 1.41G. If you put your aircraft into a 45 degree bank and hold
1G, the vertical component of lift will be only 0.707g; thus you'll have a
downward acceleration of 0.3g, or 9.4 ft/s/s, or 566 fpm/s. This means
that after one second, your rate of descent will have increased by 566
fpm. After four seconds, you're descending at 2264 fpm, which is a pretty
steep dive, and you WILL pull more than one g pulling out of it.
-Dana.
Wernher von Braun settled for a V-2 instead of a V-8.
The most ignored indicator that indicates stall independent of the ASI and
angle of bank is the AOA meter. Few have them mounted in their
aircraft.
Jack B. Hart FF004
Winchester, IN
Jason,
That was a great video you did on returning to the runway in the event of an engine
failure. The lesson to learn here is not to take a piece of advice like
" Never try to return to the runway if your engine quits " and apply it to every
situation. Many times Kolb pilots are flying from 5000 foot general aviation
runways that you would be close to 1000 feet at the end. If you had houses,
or trees in front, 1000 feet of altitude, and 5000 feet of general aviation
runway just behind you when the engine quit, only a fool would take the common
advice and land into a house or a tree in this situation. As the runway gets
shorter, it becomes more dangerous to turn back, and one should look for the
best place ahead or even 90 degrees left or right. On a super short runway, the
only option will be straight ahead. A good pilot should know about what runway
length and altitude will allow a return to the runway if the engine quits
in his airplane.
Its needless to say brand new Kolb pilots should not practice this until they know
their airplanes well and can do a banked power off turn without stalling.
Again, its just a matter of being smart. For most of us, practice like this
will make us safer in case of an engine failure. There are always a few new
or poorly skilled pilots that are safer never testing the limits of their planes.
Trying to apply one rule to everyone, or one rule for every situation just
shows a poor understanding of aviation.
"NO FEAR" - If you have no fear you did not go as fast as you could
have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=295942#295942
"Show this to your local Radio Shack sales clerk. "
Your link is pretty much what the local Shack clerk showed me... Lots of BNC stuff,
but no bulkhead fitting like Jimmy is looking for. It's not in their system
at all. The Shack ain't what it used to be.
Roger in Oregon
1992 KXP 503 - N1782C
http://forums.matronics.com/viewtopic.php?p=295978#295978
a flat skidding turn leading to the inside wing stalling,>>
Hi Dana,
reminds me of an incident I saw just around the end of the war.
An Albemarle, which was a twin engined light/medium bomber reduced to
glider tugging was struggling into the sky from my local field pulling
a Waco glider. The glider got out of position and pulled the tail of
the Albemarle to starboard. The Albemarles port wing stalled and she
dropped into a straight down nosedive with both engines flat out.
Unfortunately there was not enough height and she hit the ground about
10 degrees from vertical. The pilot had obviously realised what was
happening and dumped the tow line as his plane dropped out of control
thus certainly saving the glider pilot from filling his pants or as a
worst case causing the glider to crash with its full complement of
squaddies aboard.
Sports gliders with their long wing span are prone to this on final turn
when they are close to the ground and skid into a flat turn instead of
banking properly.
Cheers
Pat
estimate) down the runway to be in danger of running out of runway on the
landing roll.>>
Hi Jason,
working the accurate math for that is beyond me but a 10knot windspeed and
say 35knot airspeed at take off is going to produce a ground speed on
takeoff of 25knots. Landing downwind is going to require at least 45 knots
ground speed and to keep proper control, a bit more. That will certainly
take a lot more runway than you expect.
I will tell you how I know. I flew to a fly in last weekend. Viz was not
great and I was non radio. The wind was light and I couldn`t see the
windsock. I saw another a/c in the circuit and decided to follow him around
the circuit. As I turned I lost him in the haze and the next time I saw him
he was on the ground having (I assumed), just landed. I tracked round to
follow and landed in the same direction. I realised that something was not
quite right when the hedge wizzed under me a bit faster than I expected.
Then the plane plonked herself down a bit more solidly than usual and I
found myself charging down the grass and applying brakes hard. I taxied to
the clubhouse where I was given a (richly deserved) b*******ing from the
CFI.
What I had seen was not the other plane landing, but BACKTRACKING after he
had landed. A stupid error whch to salve my pride I shall put down as being
due to the first away flight of the season and not being really switched on
yet.
Take it from me. Down wind landings take MUCH more runway than you expect.
Cheers
Pat
If you bank steeper you descend faster and you are still at 1G.>>
Hi Jason,
If that were the case then any bank angle would not increase the `G`.
Ascending, descending, power on or off. None of these is germane to the
case.
Cheers
Pat
> expect.
Ok,
You perhaps. What do you expect?
Unrealistic expectations inevitably make pilots unsafe.
Gene,
Mike,
I posted before checking your second link. Mouser has many options for BNC bulkhead
fittings. I can't speak for Jimmy, but they have what I have been looking
for.
Thanks for the tip,
Roger in Oregon
http://forums.matronics.com/viewtopic.php?p=296001#296001
Hi, Gang,
Just for fun, and since it doesn't seem to have been mentioned, when safely practicing
at altitude, perform a 270 degree turn to establish your altitude loss.
Unless we take off sideways across a football field, it takes a 45 to return to
the runway, and another 45 to line up for landing. All that is after the initial
180.
http://forums.matronics.com/viewtopic.php?p=296002#296002
Here is a very good video about the "Impossible Turn" as performed by two guys
in a C172.
http://www.aerobats.com/seminar_02-07.html
Richard Pike
http://forums.matronics.com/viewtopic.php?p=296028#296028
Hello Boyd,
Jason
Jason
Just visited a cfi, and I asked the question "could you remain in 1 g
during a descending turn at a constant air speed" his reply was "you could
for a short while, but it would be the start of a death spiral."
Straight flight at a constant speed and power setting, is considered 1g.
If 1 g is lifting the aircraft and you put it into a turn, You will
require additional energy to cause the plane to change direction, I.e.
TURN 180 Energy is needed to stop the plane from traveling in one
direction, and accelerate it into another direction. Thus more energy/lift
is required from the wings, to make the direction change and also lift the
aircraft. I guess it could be argued that there is still only 1g apposing
gravity, but additional lift is required to cause the change of direction.
Thus 1 PLUS g maneuver, the greater the bank angle the greater the PLUS.
Boyd
Any turn of an airplane will require acceleration to change its direction, you
can not turn the direction of any moving object without putting force on it, its
a law of physics that can not be broken. What can be done is that the turning
forces can be temporarily kept near one G by initiating a descent, and using
more of the lift component for the turn, and less for lifting against gravity,
TEMPORARILY. But any descent incurred by this will have to be arrested sooner
or later by additional lift from the wings, additional G loading somewhere
before hitting the ground. You can not change the laws of physics by being
a good pilot.
What a good pilot can do is manage these forces so gradually, and smoothly that
any increase in G loading is minimal and not noticed by the humans inside the
plane. This is very good and important technique, as the return to airport would
be done at minimal airspeed with no power... Horsing the plane around and
being abrupt with the controls and the resulting G forces could cause an accelerated
stall and be disastrous in this situation. So while you can not change
the laws of physics, you can manage them so smoothly as to give yourself every
chance of completing this maneuver without stalling.
have !!!
http://forums.matronics.com/viewtopic.php?p=296079#296079
Subject: | Angle of Bank vs Stall Speed |
Sent this two hours ago. So far it hasn't appeared on the list. My
paranoid side says there must be censorship of my ideas somewhere.
Sigh. My conscience won't let me ignore this.
pj, boyd, Dana:
Dang it, ignore what I say, fly the maneuver and see for yourself. Go
to
altitude, reduce power if you wish, enter a 30 degree bank and hold
absolutely constant airspeed for 180 degrees and then roll level.
Repeat at
5 miles/knots slower. Repeat again until you are as close to Vso as
your
ability to hold a constant airspeed allows. You will not stall.
For more details as to why this is true review my messages in the thread
linked by Jason:
g+turn+stall
Now:
<< If the turns are less than 30 deg and the g load less than 1.5,,
you
may be ok. if the turn is 60 or more deg bank and g load 2 or above
<< In a coordinated turn, the stall speed increases as a function of the
bank angle >>
These out of context statements are exactly the misconception which
kills
pilots every year. I know, it almost killed me during my primary
training.
I know, base to final turn accidents are a major source of aircraft
fatalities every year. They are true *if you maintain (approximately) a
constant vertical component for your lift vector.* The only way to do
this
is to increase your total lift, in other words maintain constant
altitude,
in other words increase your load factor.
But don't believe me, go out and fly the maneuver yourself at altitude.
Look at the AIM diagram we have all had drummed into our subconscious.
As
the angle of bank increases, the total lift increases to keep the
vertical
component the same. Now with your hands block out all but the first
airplane. Rotate the entire manual. This is the case of a constant
airspeed in a turn. Some of the lift is now used to make the turn and
less
lift is available to oppose gravity and you will *start* to descend
faster.
But since the total lift is unchanged so is the stall speed. In other
words, stall speed increases with load factor, not angle of bank.
<< Take a 45 degree bank, for example. In a normal, coordinated, level
turn, you pull 1.41G. If you put your aircraft into a 45 degree bank
and
hold 1G, the vertical component of lift will be only 0.707g; thus you'll
have a downward acceleration of 0.3g, or 9.4 ft/s/s, or 566 fpm/s. This
means that after one second, your rate of descent will have increased by
566
pretty
steep dive, and you WILL pull more than one g pulling out of it. >>
The math here is wrong. After one second you are descending at 9
feet/sec,
2 seconds you are now at 19 ft/sec, 3 seconds = 28 ft/sec, 4 sec =
38 ft/sec
or so. In addition it ignores the vertical component of drag which is
significant.
The above statements as well as the "death spiral" of Boyd's CFI are the
result of misunderstanding the context of what I and others are trying
to
fix. The problem is the turn from base to final. Most pilots initiate
a
bank of about 30 degrees. Half way through the turn they see they are
overshooting the runway. What they should do is increase their angle of
bank to 45 degrees or even briefly 60 degrees at constant airspeed to
finish
the turn. Instead, because "increased angle of bank means increased
stall
speed" (in a different context) has been fixated in their minds they try
to
fudge the situation with rudder and/or tightening up (pulling on the
stick)
instead. This brings them to experience the other four fundamentals of
flight: stall, spin, crash and burn. What we must fixate instead is
"constant airspeed = constant load factor = constant stall speed".
Now just because I have an evil nature let me mention one more context
besides turns at low altitude for landing. This should start another
thread
in the Seafoam mode. The concept of constant airspeed control is also
paramount in mountain search and rescue reversing turns and box canyon
escapes. What I teach is no change in power, smoothly increase your
climb
rate and bank until you reach your desired bank and airspeed, say Vs1 +
10.
Maintain this bank and airspeed until you have reversed direction. You
will
now be in a decent but at a higher altitude, smoothly pullout and you
are
now going in the opposite direction at roughly your starting altitude
and
airspeed. This method allows the pilot to concentrate on airspeed
control
and situational awareness without the distraction of power control. The
reduced airspeed during the turn also creates a very small radius of
turn.
Let me finish with an irrelevant appeal to authority. Every, and I mean
every, CFI with whom I've had the above discussion and then taken flying
has
adopted my emphasis on constant airspeed control for maneuvering close
to
the ground.
Good luck and have fun,
Tom Kuffel, CFI
EAA Flight Advisor
Subject: | Re: Angle of Bank vs Stall Speed |
>linked by Jason:
I did. I stand by what I said there, as well as in this thread.
>bank angle >>
Correct.
>constant vertical component for your lift vector.* The only way to do this
>is to increase your total lift, in other words maintain constant altitude,
Correct. Note that if you don't maintain "a constant vertical vertical
component for your lift vector", you will accelerate downward (or upward,
as the case may be, though that's not what we're talking about).
>...This is the case of a constant
>airspeed in a turn. Some of the lift is now used to make the turn and less
>lift is available to oppose gravity and you will *start* to descend faster.
Correct. "You will *start* to descend faster." And if you maintain 1G in
a banked turn, you will *continue* to accelerate downward.
>turn, you pull 1.41G. If you put your aircraft into a 45 degree bank and
>means that after one second, your rate of descent will have increased by 566
>The math here is wrong. After one second you are descending at 9 feet/sec,
>2 seconds you are now at 19 ft/sec, 3 seconds = 28 ft/sec, 4 sec = 38 ft/sec
>significant.
What math do you say is wrong? Sounds like you're agreeing with me, as I
said after one second you're descending at 9.4 ft/s, etc. You rounded the
numbers off but they're approximately the same as mine (after four seconds,
38 ft/s is 2280 fpm).
The vertical component of drag is zero at the start, and then yes, it
becomes significant. However, it doesn't affect the math, because
regardless of the drag, you _have_ to accelerate downward as described
above or you won't maintain 1G.
>...Half way through the turn they see they are
>bank to 45 degrees or even briefly 60 degrees at constant airspeed to finish
>the turn. Instead, because "increased angle of bank means increased stall
>speed" (in a different context) has been fixated in their minds they try to
>fudge the situation with rudder and/or tightening up (pulling on the stick)
>instead...
Both are the wrong thing to do. Increase the bank angle in coordinated
turn and you risk an acelerated stall; add rudder for a skidding turn and
you risk stalling the inside wing.
Constant load factor = constant stall speed, yes. Constant airspeed has
nothing to do with it.
Don't get me wrong; i understand (or I think I understand) the technique
you're advocating: steepen the turn but don't pull back, instead letting
the airplane fall off into a descent. But saying that you're OK if you
maintain a constant airspeed is fixating on one aspect of the problem, and
can get a pilot into trouble. Fly at 1.3Vs and enter a 60 degree
coordinated turn and you either get an accelerated stall, or end up in a
dive which also requires more than 1G to pull out.
"But don't believe me," do the math yourself.
-Dana
P.S. A conventional pitot tube airspeed indicator is only accurate when
the pitot tube is aligned with the airflow. At high AOA, the airspeed
indicator will read less than the actual airspeed, i.e. you're actually
going faster than you think you are... which may explain why you're not
stalling even when the indicated airspeed is less than the stall speed
corresponding to the load factor corresponding to the bank angle.
Life is a sexually transmitted disease.
Good stuff Tom. Can't say I've studiously done exactly what you
describe but sounds 100%.
In my younger and bolder days, on occasion I used a method to bleed
altitude that I would not recommend:
not S turning, not slipping, not the Kolb dive...
I would, on a high final, deliberately stall the old crate, or pretty
close to it. Sure would lose a lot of altitude
and the wings would stay nice and level. Then I'd toss a touch of
throttle at it and squeak it on nice and short.
Obviously this would be solo. Gusty conditions would be a no no, as
would hedgerows or any extraneous
turbulizers. Very exhilarating. Last time I did it for funsies was on
a near zero day in a field near where a neighbor
was operating a McCulloch J2 gyrocopter. I siloed it a touch too
aggressively and bent a few tubes
and cracked the windshield. It needed a new one anyway. Only landing I
did that short after that was
with a power failure in a neighbor's champ on take off with nothing good
ahead. (wires and houses)
Silo descent to plowed ground aside the runway. Zero roll out. No
damage. Old neighbor never asked me to fly his
areoplane again though.
I wouldn't try it in my Kolb. Too old. Back might break.
BB
> pj, boyd, Dana:
to
Repeat at
your
thread
> linked by Jason:
+turn+stall
> Now:
you
the
> bank angle >>
kills
training.
a
this
altitude,
altitude.
As
vertical
less
faster.
altitude.
level
and
you'll
This
by 566
pretty
feet/sec,
38 ft/sec
> significant.
altitude.
the
to
initiate a
of
finish
stall
try to
stick)
of
altitude.
thread
climb
+ 10.
You will
are
and
control
The
turn.
altitude.
mean
flying has
to
> the ground.
altitude.
> Tom Kuffel, CFI
> EAA Flight Advisor
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Date: Wed, 28 Apr 2010 14:39:28 -0600
Tom,
Sounds like you are advocating flying a powered aircraft much like flying a
glider or sailplane. Sailplane instructors emphasize coordinated turns and
constant speed and never mention constant altitude. When I started flying
sailplanes, one of the things I had to unlearn was the desire to maintain
altitude through out a turn, and learn to fly at constant speed. You are
correct in that I never fell into a spin while thermalling while flying at
constant speed no matter how steep the bank or the speed.
With an engine as the energy source, one can easily recover any altitude lost after
a constant speed turn. I believe it is a less stressful way to fly on both
the pilot and the machine, since one does not have make power changes during
a turn to maintain constant altitude.
Thanks.
Jack B. Hart FF004
Winchester, IN
....Here is a very good video about the "Impossible Turn" as performed by two guys
in a C172.
Richard Pike
MKIII N420P (420ldPoops).....
Richard,
Thanks for posting the "impossible turn" video. Very good indeed. It was missing
only two things to complete the picture. An AOA gauge and and G-meter.
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
An ounce of action is worth a ton of theory.
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=296119#296119
Ooops!
Actually there is a third thing missing in this video. The engine was running at
idle power. With idle power the relative effects of various degrees of bank
on turn time and altitude loss are correct but what is missing is the effect of
stopped prop. But still a very good informative video.... just not complete.
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=296126#296126
Hello Tom,
I have a clutch on my engine so the prop windmills (and my airplane behaves) with
the engine at idle just like it would with the engine stopped.
Jason
Thom Riddle wrote:
> Ooops!
at idle power. With idle power the relative effects of various degrees of bank
of stopped prop. But still a very good informative video.... just not complete.
http://forums.matronics.com/viewtopic.php?p=296141#296141
From: | "Jmmy Hankinson" <jhankin(at)planters.net> |
Thanks for the reply's on the BNC connector I was looking for. The one I
wanted was the one that went through the floor of my Firefly to attach a
external antenna to my radio.
Only use my radio to listen to air traffic. Do not have a tower airport
near me. Ones near me are Savannah and Augusta Georgia. I am halfway
between each one. Sixty miles each way.
Thanks again for the help.
Do Nor Archive
Jimmy Hankinson
Firefly N6007L
Georgia
pj, boyd, Dana:
Dang it, ignore what I say, fly the maneuver and see for yourself. Go to
absolutely constant airspeed for 180 degrees and then roll level. Repeat at
5 miles/knots slower. Repeat again until you are as close to Vso as your
linked by Jason:
Now:
<< If the turns are less than 30 deg and the g load less than 1.5,, you
may be ok. if the turn is 60 or more deg bank and g load 2 or above >>
bank angle >>
These out of context statements are exactly the misconception which kills
pilots every year. I know, it almost killed me during my primary training.
Look at the AIM diagram we have all had drummed into our subconscious. As
the angle of bank increases, the total lift increases to keep the vertical
significant.
result of misunderstanding the context of what I and others are trying to
fix. The problem is the turn from base to final. Most pilots initiate a
besides turns at low altitude for landing. This should start another thread
escapes. What I teach is no change in power, smoothly increase your climb
rate and bank until you reach your desired bank and airspeed, say Vs1 + 10.
Maintain this bank and airspeed until you have reversed direction. You will
now be in a decent but at a higher altitude, smoothly pullout and you are
now going in the opposite direction at roughly your starting altitude and
airspeed. This method allows the pilot to concentrate on airspeed control
reduced airspeed during the turn also creates a very small radius of turn.
every, CFI with whom I've had the above discussion and then taken flying has
adopted my emphasis on constant airspeed control for maneuvering close to
the ground.
Tom Kuffel, CFI
EAA Flight Advisor
Subject: | Re: 180 turn bact to the runway video |
Hi gang,
in regard to this subject....when I was young and before I had soloed
in a J-3 I had a world war ll navy pilot for a instructor....he seemed to
understand what a teenager might have in mind....we were quite high and he
had me do a circle using a house with a big porch as a point to circle
around....he said for me to imagine my girl friend standing on the porch in a
swimming suit waving at me, he had me do a steep bank and keep bringing
the stick back to keep the girl in sight all the time and adding more top
rudder to keep from losing altitude, I forgot what we did with the power
setting but am sure is was cruise or wide open, I will never forget what
happened.....we stalled very abruptly and the plane went over the top and down
into a very tight spin....was very impressive......after solo I am sure I
buzzed some girl friends house's but never made that mistake....just thought
you might find this piece of old history of interest....not sure how a kolb
would react...jswan
jim swan firestar ll 503 michigan
Kolbers,
Viewed Richard Pike's recommended video yesterday evening. For those of you
with out a high speed Internet connection, I recorded the data, and here it
is. C 172 flying at a constant 65 ias making full 360 degree coordinated
turns.
Bank Lost Decent
Angle Altitude Rate
(deg) (feet) (fpm)
15 879 600
30 450 650
45 390 900
60 350 1500
The video displayed the instrument panel. The rate of decent did not
increase during the turn. The stall horn came on during the 45 degree bank
but there was no buffeting. There was some buffeting during the 60 degree
bank, but no stall horn.
Also the performed some 180 emergency turn arounds by setting their
altimeter to zero at 100 feet agl. They flew the airport runway at 100 ft
agl and initiated a climb at over the runway and climbed to 600 feet agl and
pulled the throttle. They could not get back to the airport using a 15
degree bank.
Good video!
Jack B. Hart FF004
Winchester, IN
Tom and the gang:
Ok I don't think we are really that far apart. What I think we need now
is a definition of terms. Example: is a 1 g turn anything between .7 and
1.3 or .8 and 1.2...... give me your definition of 1 g maneuver.
I had given an example of a steep bank turn to emphasize the situation.
And my definition of 1 g plus is 1.01g and above. I am probably taking
things to literally.
Any time you turn a plane there is going to be more energy required. And
you can trade the energy needed to turn by unloading the wings momentarily
and remain at a literal 1g . But as soon as the plane returns to a steady
state and you remain in a turn, greater than 1g will be required. In a
shallow bank turn it may be as small as 1.05g total. In my definition that
is 1 plus g. If that is a 1 g maneuver by your definition, then we are
still on the same page.
When given the terms power off descending turn. It left the parameters a
bit too open. Now I had mentioned that I had not seen the video. So maybe
everyone else had a better idea of the parameters used.
Sorry if I misled anyone.
Boyd Young
Dana said:
<< << In a coordinated turn, the stall speed increases as a function
of the
bank angle >>
Correct. >>
Not correct. This is only true in the special circumstance of
maintaining altitude, ie increasing total lift, aka load factor. The
emphasis on this without equal emphasis on the special circumstance is
*why* pilots in the stress of landing still stall by trying to increase
their rate of turn with rudder alone (uncoordinated flight) and/or
pulling back (increasing load factor). The certain antidote to this
error is constant airspeed during landing maneuvers.
Once again, go up in the air and test my statements. I don't dispute
holding a constant airspeed in a turn will increase your rate of decent.
But we are not talking about turns which last for minutes or even more
than a few seconds. I strongly dispute the notion that any technique
other than constant airspeed and coordinated flight independent of (less
than aerobatic) bank angle is the proper way to avoid problems during
the turn from base to final, particularly in situations of no or steady
power or practicing same, which should be almost always.
Boyd said:
<< I had given an example of a steep bank turn to emphasize the
situation.
taking
things to literally. >>
Not really. I wasn't worried about 1 g +/- 10% or so. The problem is
the emphasis on bank angle materially increasing stall speed (I call
double a material increase) without equal emphasis that the real cause
is via increased load factor, and that this doesn't apply in a
descending turn has resulted in pilots killing themselves year after
year in the turn to final. And the absolutely, positively sure way to
not increase load factor in this turn is constant airspeed.
<< Any time you turn a plane there is going to be more energy
required. And
momentarily
steady
state and you remain in a turn, greater than 1g will be required. >>
This is not true. The lift vector on the wings has no idea what the
gravity vector is doing. Go up and set a bank angle of 20 degrees and
constant airspeed. You will find yourself in a steady state turn of 1
g. What will also happen is your rate of decent will increase. But
this decent is not in a vacuum. The increase in your decent is actually
slowed by the air such that several full circles are easily possible..
I've demonstrated this many times for people, even disbelieving fellow
CFIs. (Are CFIs really people?) Now when doing the same thing at 60
degree bank things get real exciting very soon, even at only 1/4 circle,
which may be Dana's point. But my point is this fact doesn't apply to
the problem, its cause or the proper solution to avoid it.
Tom Kuffel
Subject: | Re: Angle of Bank vs Stall Speed/Approach Technique |
Robert,
<< I would, on a high final, deliberately stall the old crate, or pretty
throttle at it and squeak it on nice and short. >>
A slight variation of this is very common when landing on short, no
go-around strips like in the mountains. The difference is choose a
speed slightly higher than Vso but lower than normal. And return to
normal approach speed before touchdown. By flying within this back side
of the power required curve you can greatly change your approach point
without drastic maneuvers by simply modulating your speed. It is
counter intuitive to shorten your touchdown point by slowing down
(raising the nose slightly) and lengthen by speeding up (lowering the
nose slightly) but is quickly mastered. This is much easier on
passengers' nerves than a sideslip and easier to judge than S-turns.
Relating to prior discussions, this airspeed changing is done only on
final after the last turn is over.
Hesitate to mention but for really short strips a related but different
and risky procedure is required. Get level with your touchdown point.
(These strips seem to always be on the sides or tops of mountains so
level approach is possible. If not, get as close to level as you can.)
Put the airplane as close to stall as you dare. Control altitude with
lots of engine power. When you get to the strip threshold smoothly
reduce or cut the power as required and plop down the final, hopefully
less than 6, inches. For a Kolb can't think of a strip where this
extreme technique is necessary.
But try the first technique, initially with lots of margin, then closer
to maximum. Even us old fuddy-duddies can use it safely if we don't
wait too long to return to normal approach over the threshold.
Tom Kuffel
The link is a video of a Zenith 701 or 750 using the "level" approach method that
Tom described.
http://www.youtube.com/watch?v=s0gXSk_f250
Note the ASI during landing and take-off. Unfortunately, you can't see the power/rpm
setting nor hear the engine due to music and the commentary audio track.
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=296275#296275
This always turns (pardon me) into such a lively discussion about angles,
constant speeds and gee loads and then somebody finally says something like,
"What will also happen is your rate of decent will increase"
and we get to the true crux of the matter. Something had to give among all
these constants and it seems to be that the ground will come up at a faster
rate to smite thee. How about that.
I read somewhere that there was a sign in the Curtiss Flying School office
that said, "Flying is simple, to go up pull back on the stick. To come down,
pull back farther". That was around 100 years ago and seems to be, amazingly
enough, still true today.
Rick
On Thu, Apr 29, 2010 at 11:25 PM, The Kuffels wrote:
> Dana said:
> << << In a coordinated turn, the stall speed increases as a function of
> the
> bank angle >>
> Correct. >>
> Not correct. This is only true in the special circumstance of maintaining
> altitude, ie increasing total lift, aka load factor. The emphasis on this
> without equal emphasis on the special circumstance is *why* pilots in the
> stress of landing still stall by trying to increase their rate of turn with
> rudder alone (uncoordinated flight) and/or pulling back (increasing load
> factor). The certain antidote to this error is constant airspeed during
> landing maneuvers.
> But we are not talking about turns which last for minutes or even more than
> a few seconds. I strongly dispute the notion that any technique other
> than constant airspeed and coordinated flight independent of (less than
> aerobatic) bank angle is the proper way to avoid problems during the turn
> from base to final, particularly in situations of no or steady power or
> Boyd said:
> << I had given an example of a steep bank turn to emphasize the situation.
> Not really. I wasn't worried about 1 g +/- 10% or so. The problem is the
> emphasis on bank angle materially increasing stall speed (I call double a
> material increase) without equal emphasis that the real cause is via
> increased load factor, and that this doesn't apply in a descending turn has
> resulted in pilots killing themselves year after year in the turn to final.
> And the absolutely, positively sure way to not increase load factor in this
> << Any time you turn a plane there is going to be more energy required.
> And
> constant airspeed. You will find yourself in a steady state turn of 1 g.
> What will also happen is your rate of decent will increase. But this decent
> is not in a vacuum. The increase in your decent is actually slowed by the
> air such that several full circles are easily possible.. I've demonstrated
> this many times for people, even disbelieving fellow CFIs. (Are CFIs really
> people?) Now when doing the same thing at 60 degree bank things get real
> exciting very soon, even at only 1/4 circle, which may be Dana's point. But
> my point is this fact doesn't apply to the problem, its cause or the proper
> Tom Kuffel
At 12:25 AM 4/30/2010, The Kuffels wrote:
>the
>bank angle >>
>Correct. >>
I see your point, but... it's correct if you're maintaining altitude, but
it's _also_ correct for a constant rate of descent, i.e. no vertical
acceleration... which isn't happening in your 1g turn.
> The emphasis on this without equal emphasis on the special circumstance
> is *why* pilots in the stress of landing still stall by trying to
> increase their rate of turn with rudder alone (uncoordinated flight)
> and/or pulling back (increasing load factor). The certain antidote to
> this error is constant airspeed during landing maneuvers.... I don't
> dispute holding a constant airspeed in a turn will increase your rate of
> decent. But we are not talking about turns which last for minutes or
> even more than a few seconds. I strongly dispute the notion that any
> technique other than constant airspeed and coordinated flight independent
> of (less than aerobatic) bank angle is the proper way to avoid problems
> during the turn from base to final, particularly in situations of no or
> steady power or practicing same, which should be almost always.
OK. I'm not saying your technique isn't valid; I'm just speaking as an
aeronautical engineer precisely defining the situation. In aero
engineering most flight conditions, other than stability and control
calculations, are analyzed steady state, which your 1G increasing rate of
descent gliding turn is not. Letting the airplane slide (not slip; by
"slide" I mean keeping the ball centered) out of a turn by letting the nose
drop is indeed a good way to manage a gliding turn. Reducing the load
factor also maintains energy since you're not holding high AOA which causes
drag and slows you down even more.
I simply take exception to the notion that all will be well if you maintain
constant airspeed. You say that avoidance of steep bank angle kills pilots
who, trying to avoid an accelerated stall, instead spin out of a skid, and
that's true, but it's only one side of the problem. On the other side,
believing that all will be OK if you only maintain a constant airspeed can
also get you into trouble... if a pilot does a 60 degree bank at 1.3Vs and
_doesn't_ back off on the stick and let the nose drop, he _will_ experience
an accelerated stall, which can be just as bad as the stall out of a skid.
So: Stall speed is a function of load factor, not (necessarily) bank
angle. Load factor IS a function of bank angle, but only in coordinated,
level or constant vertical speed, flight.
-Dana
Puritanism: the haunting fear that someone, somewhere, may be happy.
This is not true. The lift vector on the wings has no idea what the gravity
vector is doing. Go up and set a bank angle of 20 degrees and constant
airspeed. You will find yourself in a steady state turn of 1 g. What will
also happen is your rate of decent will increase. But this decent is not in
a vacuum. The increase in your decent is actually slowed by the air such
that several full circles are easily possible.. I've demonstrated this many
times for people, even disbelieving fellow CFIs. (Are CFIs really people?)
Now when doing the same thing at 60 degree bank things get real exciting
very soon, even at only 1/4 circle, which may be Dana's point. But my point
is this fact doesn't apply to the problem, its cause or the proper solution
to avoid it.
Tom Kuffel
Tom you said "Now when doing the same thing at 60 degree bank things get
real exciting very soon, even at only 1/4 circle," ok would you like to
explain in further detail just how ex citing and in what way?
Boyd
Subject: | Nose down at higher speeds. |
Both myself and a buddy who fly a Firestar and a Twinstar have the same is
sue, when we get to around 75 mph indicated the planes start to nose over a
nd begin to get a strange shuffling feel as if the wings are alternately sh
uffling forward, kind of a tail wag maneuver. This continues to become more
pronounced if we allow the speed to increase and it becomes necessary to a
pply substantial back pressure to stay level. I feel it is a shift of the A
C due to the airfoil but if so how do the faster Kolbs avoid this?
Mark
The information in this email and attachments hereto may contain legally pr
ivileged, proprietary or confidential information that is intended for a pa
rticular recipient. If you are not the intended recipient(s), or the employ
ee or agent responsible for delivery of this message to the intended recipi
ent(s), you are hereby notified that any disclosure, copying, distribution,
retention or use of the contents of this e-mail information is prohibited
and may be unlawful. When addressed to Takata customers or vendors, any inf
ormation contained in this e-mail is subject to the terms and conditions in
the governing contract, if applicable. If you have received this communica
tion in error, please immediately notify us by return e-mail, permanently d
elete any electronic copies of this communication and destroy any paper cop
ies.
Think Green - Please consider the environment before printing this email.
Subject: | Re: Nose down at higher speeds. |
Glad we got led astray from the circle turning version of seafoam.
Also good to see another observation of the sensation
felt when going over 75, in my case a MkIII. It is uncomfortable. It
may have something to do with CG. Lots of owners
with higher HP planes seem to be doing just fine at higher speeds. I
feel that subtle differences like full enclosure canopy
and fabric covered rears may be playing a part. In my case I have the
open area behind the seats (gas tank area)
and, more importantly, a really wide windshield that is shoving my nose
I have drilled another set of front spar holes (set no. three) and may
get around to trying them this year.
BB
MkIII, Suzuki
strip is freshly mowed, tractors moved out of the shed, just have to
retrieve the bird.
same issue, when we get to around 75 mph indicated the planes start to
nose over and begin to get a strange shuffling feel as if the wings are
alternately shuffling forward, kind of a tail wag maneuver. This
continues to become more pronounced if we allow the speed to increase
and it becomes necessary to apply substantial back pressure to stay
level. I feel it is a shift of the AC due to the airfoil but if so how
> Mark
legally privileged, proprietary or confidential information that is
intended for a particular recipient. If you are not the intended
recipient(s), or the employee or agent responsible for delivery of this
message to the intended recipient(s), you are hereby notified that any
disclosure, copying, distribution, retention or use of the contents of
this e-mail information is prohibited and may be unlawful. When
addressed to Takata customers or vendors, any information contained in
this e-mail is subject to the terms and conditions in the governing
contract, if applicable. If you have received this communication in
error, please immediately notify us by return e-mail, permanently delete
copies.
email.
Hi Boyd,
<< Tom you said "Now when doing the same thing at 60 degree bank
things get real exciting very soon, even at only 1/4 circle," ok would
you like to explain in further detail just how ex citing and in what
way? >>
Sure. In any 1 g turn the amount of lift used to make the turn is then
not available to resist the force of earth's gravity. This means you
will increase your rate of descent. In shallow bank turns the effect is
small and not very apparent even after a full circle. At 60 degrees
however the rate of descent increases to a dramatic amount by at least a
half circle, sometimes sooner depending on aircraft aerodynamics and
your personal definition of exciting.
But this is not the situation which kills pilots. Here we are talking
about the descending quarter circle turn to final. Half way through the
turn the pilot sees he is overshooting the runway path. What he should
do is concentrate on maintaining the same airspeed, briefly increase his
angle of bank, even up to 60 degrees if needed, and smoothly roll out.
Doing this maintains a 1 g turn, ok a 1.1 g turn on rollout if one wants
to quibble, which does not increase your stall speed for all practical
purposes. You are at the increased bank angle for at most 1/8 of a
circle.
But because "increased bank angle means increased stall speed" is buried
in the back, dark recesses of our training too many pilots try to save
the situation by fudging the turn, either with rudder (uncoordinated
flight) or by pulling back (increased load factor).
My solution to this problem is the following basis for landing
approaches. Opposite the approach end of the runway reduce power and
set configuration (flaps and trim) to your desired approach speed.
Maintain this speed *constantly* until at least you are established on
final. Turns should normally be 20 - 30 degrees of bank. On turn to
final the bank can be increased as described above for the time needed
to complete the turn. This is guaranteed to not produce a stall or
breathtaking rates of descent.
Within this framework there are lots of variables such as adjusting
power or adjusting airspeed along the back side of the power curve after
being established on final. But from the start of the approach descent
until at least established on final the sure and certain way to avoid an
unintended stall is constant airspeed control.
Again, go out to altitude and try some example quarter circle turns for
yourself. Even at speeds unreasonably close to Vso you won't get even a
nibble of a stall at angles of bank below aerobatic flight. Or come
visit us in Whitefish and I'll demonstrate in an airplane easier to
stall than a Kolb.
Best,
Tom
Mark,
To prevent, or stop the tail wag/wing shuffle keep both feet on the rudder pedals.
Full wind screed "shape" affects nose down moment at increased speed.
Narrower and round is better than wide and flat.
The goal is to have the wind deflect around to the sides of the wind screen and
fuselage rather than up over the top of the wing.
I've tried both shapes, and while wider and flatter is more roomy, narrow and
round is more efficient and makes the plane pitch neutral which is a much safer
flight characteristics at higher speed.
attached is a photo with the narrow rounded wind screen which increased my top
speed about 10 mph.
My other wind screen was the full width of the wing gap cover and approximately
flat along the leading edge of the gap cover.
Gene
http://forums.matronics.com/viewtopic.php?p=296347#296347
http://forums.matronics.com//files/landing_195.jpg
Mark,
Are you sure your are not experiencing aileron flutter?
Greg
----- Original Message -----
Sent: Friday, April 30, 2010 3:16 PM
Subject: Kolb-List: Nose down at higher speeds.
Mark
copies.
email.
> Hesitate to mention but for really short strips . . . .
You have to be really desperate to consider this option . . . i.e. the level approach
to a sloped strip. ! ! ! ! So your 'hesitation' is well noted !
Used to do a lot of Jungle flying in Papua New Guinea many years back in which
we used to fly into strips some of which had around 15% gradient and gouged out
of terrain of a much steeper gradient. Yes, it was in 'spam cans', C185, 206's
and the like, but the principle still applies.
If you fly this 'level approach' technique, you throw away all your safety margins.
Given the sloping terrain all around and the high probability of optical
illusion in such scenarios, what you 'think' is level may not be and until you're
on shortish final and finding that your putting in more and more power to
get to the threshold (and you're probably committed by this stage), it's only
then that you realize that in actual fact you're climbing and on the back of the
power curve to boot and maybe not enough power to get there anyway, if for
example, you get caught in a downdraft, not uncommon in mountain flying.
Stalls with high power settings whilst climbing usually produce a fairly dramatic
maneuver which will probably take more altitude to recover than you have available.
So you really are courting danger considering this option.
We had it drummed into us to do a 'normal' descent profile (which allows you to
steepen up if your a little high or shallow out if your a little low) and to
either carry a little more speed or power to cater for the increased energy required
to flare to a higher than normal attitude. (On the steeper strips we then
had to apply full power just to get to the top of the strip !)
You just had to get used to the new 'apparent' steep profile during your approach.
Once you got used to that it was all OK. I think the only time I did one of
those 'level' type approaches was because of low cloud base where there was
no other option other than divert and looking back I think that would have been
the wiser option, but I was young then (ahem).
David.
http://forums.matronics.com/viewtopic.php?p=296363#296363
...But because "increased bank angle means increased stall speed" is buried in
the back, dark recesses of our training too many pilots try to save the situation
by fudging the turn, either with rudder (uncoordinated flight) or by pulling
back (increased load factor)....
Tom is correct here and I believe that the primary reason for the last part, "pulling
back (increased load factor)" is the more common and due largely to the
pilot's noticing the increased descent rate when banking steeper and his natural
response to halt the higher descent rate. If the approach trajectory is higher
then the increased descent rate would not be so "scary" and thus less likely
to elicit the "pulling back" response resulting in increased load factor and
higher stall speed.
This brings me to one of the reasons that over the years I've adopted the practice
of always (whenever possible) making a high approach and kill altitude only
after I'm on stable short final. With my Slingshot this is very easy to accomplish.
When I was flying an Allegro with rather high aspect ratio wings, it was
a lot more difficult to get down in a short distance, but achievable though
to a lessor degree.
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=296365#296365
Tom
But this is not the situation which kills pilots. Here we are talking about
the descending quarter circle turn to final. Half way through the turn the
pilot sees he is overshooting the runway path. What he should do is
concentrate on maintaining the same airspeed, briefly increase his angle of
bank, even up to 60 degrees if needed, and smoothly roll out. Doing this
maintains a 1 g turn, ok a 1.1 g turn on rollout if one wants to quibble,
which does not increase your stall speed for all practical purposes. You
are at the increased bank angle for at most 1/8 of a circle.
I guess there is still one other option not yet discussed... ,go ahead
and overshoot the centerline, stay at your current angle of bank and
speed, make the turn to final a 100 to 105 deg turn and angle back to the
centerline, then straighten up when on center. At the base to final turn
you should be 400 to 500 ft agl and plenty of time and altitude for another
few deg of turn.
During ppl training I did exactly what you recommend, and that is when my
cfi deemed it necessary to do an extended lesson on accelerated stalls.
Or come visit us in Whitefish and I'll demonstrate in an airplane easier to
stall than a Kolb.
That is the best offer I have heard all day. Hope you are not surprised
when I take you up on that. Is my waypoint in the gps still good?
Boyd
Subject: | N-Number question |
Hey guys, great forum. I have a question concerning N-Numbering. I have been looking
at a Firefly that is for sale. It is a very nice aircraft but during my
inspection of the rudder I noticed a faint outline of an N-number. I later came
home and run the number through the FAA N-number query and out came the number.
It says that it was a reserved number that was cancelled/not assigned. It
seems somewhat obvious that the number was never officially assigned to the aircraft
but I wanted to check here first. I believe if an N-number is assigned
that you can't later un-assign it. I just want to make sure I can keep the aircraft
in the Ultralight catagory.
http://forums.matronics.com/viewtopic.php?p=296425#296425
Subject: | Re: N-Number question |
Steven, The number was cancelled because the owner never renewed it or
completed the process of getting an experimental airworthiness certificate.
Had the certificate been issued you might have some difficulties getting
that undone but since it wasn't you should be fine as long as the aircraft
itself meets the ultralight standards.
My advice would be to make sure the fuel system has a 5 gallon capacity,
since this is the easiest violation to spot other than a second seat,
and have the aircraft weighed prior to buying it so you know that it truly
falls within FAR 103 limits. If the owner has completed the worksheets from
AC 103-7 all the better, but verify the weight so you know exactly where you
stand before the aircraft is yours.
Rick Girard
> been looking at a Firefly that is for sale. It is a very nice aircraft but
> during my inspection of the rudder I noticed a faint outline of an N-number.
> I later came home and run the number through the FAA N-number query and out
> came the number. It says that it was a reserved number that was
> cancelled/not assigned. It seems somewhat obvious that the number was never
> officially assigned to the aircraft but I wanted to check here first. I
> believe if an N-number is assigned that you can't later un-assign it. I just
> want to make sure I can keep the aircraft in the Ultralight catagory.
> Thanks
Steven,
It is more probable that the N-number was reserved by the owner or builder who
had plans of registering it as an airplane. Regardless of whether it was "assigned"
or "reserved" or even actually used by that aircraft, as long as it meets
the part 103 limitations, it can be de-registered and flown legally as an ultralight
vehicle.
If it was me contemplating flying it as a legal ultralight, I would make sure it
complies with the weight limitations before committing to its purchase. If the
owner was planning on registering it and getting an experimental airworthiness
certificate, then there is a good chance that was because it was/is overweight.
All this assumes you care about flying legally. If you live way out in the boonies
you may not care and perhaps get away with it. In my area that would be quite
risky, especially since the owner of the airport where I fly out of is an
FAA inspector.
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=296451#296451
If you can check these two items on the AC 103-7, Appendix 4 form, you can
ignor what is under the paint.
"AIRWORTHINESS CERTIFICATION:
(v) no U.S. or foreign airworthiness certificate is currently issued to this
particular ultralight unit
(v) this ultralight has not been registered with the U.S. federal
government."
Jack B. Hart FF004
Winchester, IN
...(v) this ultralight has not been registered with the U.S. federal
government." ...
Jack,
You are correct. I forgot about the "never has been registered" clause. My agin
memory rears its ugly head.
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
I prefer the company of peasants because they have not been educated sufficiently
to reason incorrectly.
- Michel de Montaigne
http://forums.matronics.com/viewtopic.php?p=296455#296455
From: | frank goodnight <frank.goodnight(at)att.net> |
Subject: | M V who will be there ? |
Hi All,
Just courious . Who plans to be at MV this year? Are you planing on flying or driving?
I hope to fly in (first time flying)
Pulled my plane in on a trailer last year, had a great time. Met a bunch of interesting
people, looking forward to more
of the same this time.
Frank Goodnight
Firestar 2
Brownsville Texas
Subject: | Re: M V who will be there ? |
or driving? I hope to fly in (first time flying)
time. Met a bunch of interesting people, looking forward to more
Frank Goodnight
Firestar 2
Brownsville Texas
Hi Frank G/Gang:
Time to get ready for the 8th Annual Kolb
Unplanned/Unorganized Flyin, Monument Valley, Utah.
The dates are 21-23 May 2010, Friday - Sunday.
I am flying. Will depart, either the Monday or Tuesday
prior, depending on the weather. Usually, I encounter foul weather some
where along my 1,500 mile route of flight through Alabama, Mississippi,
Arkansas, Texas, New Mexico, Arizona, and Utah. Spend the first night in
Sherman, TX, and the second at Los Lunas, NM. That leaves a half day flight
for the final day. Normally takes about 20 flight hours, broken down into
two 8 hour and one 4 hour day. By the time I get to MV, I am ready to sit
under the wing on the airstrip and listen to flying stories.
Everyone is welcome. It is a Kolb Flyin, but we try to
make everyone feel at home with our group.
From MV I plan to fly to the Rock House near Burns
Junction, Oregon. After my visit there, if I feel spry enough, I will fly
over to the West Coast and back down through California before I turn East
and head back to Alabama.
Looking forward to visiting with old friends and making
new ones at MV.
john hauck
Subject: | In-flight Electric Adjustable IvoProp |
Kolb guys=2C
For those of you that have Ivo Props=2C and especially those of you that
have them equiped with the electrical adjustment motor=2C the discussion ca
me up about their control on the Aeroelectric list.
A guy that has the electric operated prop mentioned he sure would like to
know when the motor is drawing it's limit of amps=2C BEFORE it has to pop
the circuit breaker. (If you change the pitch in flight=2C about the only
way to find out where the pitch is=2C is to twist the prop all the way flat
=2C until the circuit breaker has been maxed out=2C and pops! Not a very g
ood way to go!
So=2C after a couple of suggestions=2C and one preliminary design=2C Bob
Nuchols (the Aeroelectric guru!!) came up with this design (see attahment).
Now=2C when a person changes pitch in flight=2C an electrical circuit wil
l notify him of the increasing current draw=2C and light an LED at a preset
current=2C rather than exceed this limit and pop the breaker.
Much better way to go!!
Bob included an email with his design that identified the intended parame
ters. If anyone is interested=2C let me know=2C and I'll copy it and send
it to you.
Mike Welch
MkIII
The New Busy is not the old busy. Search=2C chat and e-mail from your inbox
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O
N:WL:en-US:WM_HMP:042010_3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From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Subject: | Re: M V who will be there ? |
Karen and I will be driving in, currently planning on arriving Thursday
afternoon.
Larry
Note: If you forward this email, please delete the forwarding history,
which includes my email address.
----- Original Message -----
Sent: Sunday, May 02, 2010 7:39 AM
Subject: Re: Kolb-List: M V who will be there ?
Who plans to be at MV this year? Are you planing on
flying or driving? I hope to fly in (first time flying)
Pulled my plane in on a trailer last year, had a
great time. Met a bunch of interesting people, looking forward to more
of the same this time.
Frank Goodnight
Firestar 2
Brownsville Texas
Hi Frank G/Gang:
Time to get ready for the 8th Annual Kolb
Unplanned/Unorganized Flyin, Monument Valley, Utah.
The dates are 21-23 May 2010, Friday - Sunday.
I am flying. Will depart, either the Monday or
Tuesday prior, depending on the weather. Usually, I encounter foul
weather some where along my 1,500 mile route of flight through Alabama,
Mississippi, Arkansas, Texas, New Mexico, Arizona, and Utah. Spend the
first night in Sherman, TX, and the second at Los Lunas, NM. That
leaves a half day flight for the final day. Normally takes about 20
flight hours, broken down into two 8 hour and one 4 hour day. By the
time I get to MV, I am ready to sit under the wing on the airstrip and
listen to flying stories.
Everyone is welcome. It is a Kolb Flyin, but we try
to make everyone feel at home with our group.
From MV I plan to fly to the Rock House near Burns
Junction, Oregon. After my visit there, if I feel spry enough, I will
fly over to the West Coast and back down through California before I
turn East and head back to Alabama.
Looking forward to visiting with old friends and
making new ones at MV.
john hauck
Subject: | M V who will be there ? |
Weather permitting I will be flying down
Boyd young
Mkiii
Brigham city ut.
Subject: | Loud X-country flights |
John H.=2C and others=2C
John=2C a while back you asked about insulating material that you could i
nstall in
your MkIII=2C to help reduce cabin noise.
The last I heard=2C I think you said you found the material you wanted.
I'm curious if you ever got around to installing this material=2C and if
you've had a chance to go on a long enough flight to be able to judge how w
ell it works.
Mike Welch
MkIII
Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb
ox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O
N:WL:en-US:WM_HMP:042010_1
Subject: | Re: Loud X-country flights |
I'm curious if you ever got around to installing this material, and if
well it works.
Mike Welch
Mike W/Gang:
Haven't completed the task.
Flew to Lakeland without it, about 11 hours. Could still hear, a little,
when I got back to Alabama.
If I get energetic before time to go to MV, I'll pull the center section and
stick some insulation in there. I probably need to take the time to do
that. I also have a new set of Lord Mounts for the engine. The center
section needs to be pulled to lift the engine enough to do that job.
Hopefully, I will get all enthused and "get'er done".
john hauck
John=2C
From the looks of all the thunderstorms headed our way=2C there ought to
be lots of time for indoor projects. : )
I'm looking forward to a flight report! If the improvements sound good
=2C I'm close to a point where I could include them in my plane's completio
n.
Mike W
Subject: Re: Kolb-List: Loud X-country flights
Date: Sun=2C 2 May 2010 11:18:10 -0500
well it works.
Mike Welch
Mike W/Gang:
Flew to Lakeland without it=2C about 11 hours. Could still hear=2C a littl
e=2C when I got back to Alabama.
If I get energetic before time to go to MV=2C I'll pull the center section
and stick some insulation in there. I probably need to take the time to do
that. I also have a new set of Lord Mounts for the engine. The center se
Hopefully=2C I will get all enthused and "get'er done".
john hauck
Titus=2C Alabama
The New Busy is not the too busy. Combine all your e-mail accounts with Hot
mail.
http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P
ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4
I'm looking forward to a flight report! If the improvements sound good,
I'm close to a point where I could include them in my plane's completion.
Mike W
Mike W/Gang:
Removing the center section from my mkIII is a major undertaking. That is
the only reason the insulation is not already installed. If I was in the
building and completion phase, I'd already have the insullation stuck in
place. No doubt that any insulation would be an improvement in noise
control in my mkIII.
john hauck
From: | "Mrs. Michelle Cole" <apilot(at)surewest.net> |
Subject: | Re: In-flight Electric Adjustable IvoProp |
I find that I almost never need to adjust the prop. After going through much thrust
testing. I found that the difference from 5000 rpm to and through 6300
rpm only gives an additional 40 lbs of thrust. Since I do not like to run over
5000 because of the fact that 4 cycles (Geo Metro Suzuki G10 engine) have more
service life than when operated in the higher rpm range. I do believe that
the windage tray and the re-ground cam have given me more power. As for popping
the breaker, it has only happened once on the ground when I over pitched it.
Also, for reasons that I do not understand, I get more thrust from cutting
the 3-blade 72" dia down to
70" dia. I fly with a friend in a Maxair Drifter with a 582 Rotax. We have about
the same climb and cruise and he burns around 4 gallons per hour and I burn
slightly over 2.5 gallons per hour. His engine weight is 135 lbs and mine is
145 lbs with electric prop, exhaust and radiator.
Vic Kolb Mark III Classic
---- Original message ----
>Date: Sun, 2 May 2010 07:47:59 -0700
>From: owner-kolb-list-(at)matronics.com (on behalf of Mike Welch <mdnanwelch7(at)hotmail.com>)
>Subject: Kolb-List: In-flight Electric Adjustable IvoProp
>To:
> Kolb guys,
> For those of you that have Ivo Props, and
> especially those of you that have them equiped with
> the electrical adjustment motor, the discussion came
> up about their control on the Aeroelectric list.
> A guy that has the electric operated prop
> mentioned he sure would like to know when the motor
> is drawing it's limit of amps, BEFORE it has to pop
> the circuit breaker. (If you change the pitch in
> flight, about the only way to find out where the
> pitch is, is to twist the prop all the way flat,
> until the circuit breaker has been maxed out, and
> pops! Not a very good way to go!
> So, after a couple of suggestions, and one
> preliminary design, Bob Nuchols (the Aeroelectric
> guru!!) came up with this design (see attahment).
> Now, when a person changes pitch in flight, an
> electrical circuit will notify him of the increasing
> current draw, and light an LED at a preset current,
> rather than exceed this limit and pop the breaker.
> Much better way to go!!
> Bob included an email with his design that
> identified the intended parameters. If anyone is
> interested, let me know, and I'll copy it and send
> it to you.
> Mike Welch
> MkIII
> The New Busy is not the old busy. Search, chat and
> e-mail from your inbox. Get started.
>________________
>IVO-Prop_Pitch_Controller.pdf (106k bytes)
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: 180 turn back to the runway video |
Kolbers,
Riding the mower mid-week, I had some time to think about constant velocity
and 1g turns, and so when the rain started, I started running some numbers.
I picked numbers that were suitable for the FireFly and looked at constant
level turns and descending turns. I did not discover a one g power off
descending turn. But I found that increasing the rate of descent while
keeping the same speed, did decrease wing and g loads and stall speed. This
may not be practical in that it may require a device to increase the drag.
I don't know if flaperons will do the trick. The numbers indicate that if I
keep the FireFly over 40 mph in a coordinated level and/or descending turns,
there is no danger of a stall. If I increase the margin to 50 mph there is
little chance of stall due to an uncoordinated turn.
What follow is my attempt at non-powered flight dynamics. It will be
interesting to get back into the air and to check out some these
calculations. More rain coming tomorrow.
Jack B. Hart FF004
Winchester, IN
Sailplane Aerodynamics
Centrifugal Force -> F = WV^2 or R = WV^2
gcR gcF
Where:
W = FireFly gross Weight = 500 pounds
gc = gravitational constant 32.2 ft/sec2
F = centrifugal force in lbf
V = Velocity in ft/sec
^ -> indicates the number trailing is an exponent
R = radius of turn in feet
F = W x tan()
Where:
= angle of bank in degrees
Substituting into:
R = WV^2 = WV^2 = V^2
gcF gcW tan() gc tan()
Constant G-Load = 1/cos()
Find new stall speeds
Given L = CV2 or C = L/V^2 and V = (L/C)^0.5
Where:
C = coefficent of lift
L = Lift in pounds
V = Velocity in mph
Solve for C at FireFly stall in level flight
C = 500/(27)^2 = 0.686
Using this value of C, calculate the new stall speeds for banking turns.
Turn Radius in Feet While Maintaining Altitude
Bank _________Air Speed______ Constant New FireFly Stall
Angle |mph->| 40 | 50 | 60 | Altitude Wing Stall Speed
(deg) |fps->|58.7 |73.3 | 88.0| G-Load Load (mph) Increase
| radius in feet | (lbf)
0 | ---infinite--- | 1.00 500 27.0 0%
15 | 399 | 623 | 898 | 1.04 518 27.5 1.9%
30 | 185 | 289 | 417 | 1.15 577 29.0 7.4%
45 | 107 | 167 | 240 | 1.41 707 32.1 18.9%
60 | 62 | 96 | 138 | 2.00 1,000 38.2 41.5%
Time to Turn 180 Degrees in Seconds
T = ?r/V
Where:
T = time is in seconds
? = pi = 3.1416
V = velocity is in feet per sec
Bank Air Speed
Angle mph-> 40 50 60
(deg) fps->58.7 73.3 88.0
15 21.4 26.7 32.1
30 9.9 12.4 14.9
45 5.7 7.2 8.6
60 3.3 4.1 4.9
Turn Rate in Degrees/Second
Turn rate = 180/T in degrees/second
Bank Air Speed
15 8.4 6.7 5.6
30 18.2 14.5 12.1
45 31.6 25.0 20.9
60 54.5 43.9 36.7
Now what happens if one lowers the nose, reduces power and flies at 50 mph
with 500, 1,000, 1,500 fpm or 8.33, 16.67, 25.00 fps rates of descent.
If one lowers the nose and flies at the same speed and constant velocity in
a circular spiral path, the time to turn 180 degrees increases with the
increase in descent rate. This is because the total distance flown will
increase to complete the turn. This in turn lowers the centrifugal force as
the distance traveled to complete the turn increases. This change in
centrifugal force can be found by calculating the path length for 360 degree
turn and from this determine the effective radius that generates the
centrifugal force. Or by finding the new velocity vector component in the
horizontal plane and applying it to original radius of turn. Calculating
for a 50 mph coordinated(?) turn. I don't know if these assumptions lead to
coordinated turns or not.
Bank Descent Horz Horz Wing New FireFly Stall 180 180
Angle Rate Vel Turn G Wing Stall Speed Turn Altitude
(deg) (fpm) (fps) Rad Load Load (mph) Increase Time Loss
(ft) (lbf) (sec) (ft)
15 0 73.3 623 1.04 518 27.5 1.9% 26.7 0
500 72.8 627 1.03 517 27.5 1.9% 27.1 177
1,000 71.4 639 1.03 515 27.4 1.5% 28.1 369
1,500 68.9 662 1.02 512 27.3 1.1% 30.2 602
30 0 73.3 289 1.15 577 29.0 7.4% 12.4 0
500 72.8 291 1.15 574 28.9 7.0% 12.6 82
1,000 71.4 297 1.13 567 28.7 6.3% 12.8 168
1,500 68.9 307 1.11 555 28.4 5.2% 14.0 279
45 0 73.3 167 1.41 707 32.1 18.9% 7.4 0
500 72.8 168 1.40 700 31.9 18.1% 7.2 47
1,000 71.4 171 1.36 681 31.5 16.7% 7.5 99
1,500 68.9 178 1.30 649 30.8 14.1% 8.1 162
60 0 73.3 96 2.00 1,000 38.2 41.5% 4.1 0
500 72.8 97 1.97 985 37.9 40.4% 4.2 27
1,000 71.4 100 1.87 936 36.9 36.7% 4.4 58
1,500 68.9 102 1.76 879 35.8 32.6% 4.7 94
Conclusions:
1. If you react well, the FireFly should be able to return to the runway
with an engine out at 300 feet agl by dropping the nose and banking at
30 degrees or higher.
2. Drop the nose and fly at best glide speed -> 50 mph
3. Dropping the nose will lower the wing g-load and stall velocity in a
turn.
4. Make coordinated turns, but at 50 mph there is some built in margin of
safety.
5. Constant velocity flying is not such a bad idea.
6. Be gentle with the stick in pitch.
7. When in doubt push the stick forward, it increases ias and distance.
That sounds pretty good - would you be willing to post your various numbers for
your airplane?
Climb out at what speed & rpm -
Cruise at what rpm -
What rpm do you consider normal - too high - and optimum?
Anything else you can think of so that us 582 users who cannot afford a Rotax 912
can have something to relate to - give us as much context as you can.
Also what reduction ratio you are using, who makes your reduction drive system,
type of prop, number of blades and anything else pertinent - all in one post.
(This is your chance to brag on your setup -WEAR IT OUT!)
Richard Pike
MKIII N420P (420ldPoops)
http://forums.matronics.com/viewtopic.php?p=296560#296560
Jack,
Thanks for the math. Looks like the math jibes well with my experience and that
of others who have used this technique.
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
I prefer the company of peasants because they have not been educated sufficiently
to reason incorrectly.
- Michel de Montaigne
http://forums.matronics.com/viewtopic.php?p=296567#296567
Just FYI, I saw this ad for sound insulating material recently.
http://www.soundexproducts.com/
David
http://forums.matronics.com/viewtopic.php?p=296568#296568
Also just FYI, I saw this 'new' prop at the AERO 2010 expo in Friedrichshafen in
Southern Germany last month. It's called the QD2, a four bladed prop with a
difference. That being that the two sets of two blades are both angularly and
axially offset and that apparently reduces the noise signature and they also claim
some performance improvements too. It's currently being test flown on a
trike.
See this site. http://www.e-props.fr/EP_RD.html Info is about 2/3rds down the page.
David.
http://forums.matronics.com/viewtopic.php?p=296569#296569
Subject: | In-flight Electric Adjustable IvoProp |
Mrs. Michelle Cole (I really know you're Vic G. he he)=2C
Thanks for the feedback regarding your IvoProp. I am glad to hear you do
n't fiddle with it much. That's one of the things I did NOT want to do (ad
just it much). I'd be happy if I could just set it...and forget it.
I think I'll still build the circuit=2C tho. With my very limited experi
ence with adj. props=2C I think knowing roughly where the pitch is will be
better than nothing (at least for me).
My Ivo is already cut down to a 70" diameter. I bought it that way.
I second what Bro Pike said. How about a full run-down on your engine...
.performance=2C numbers=2C noise levels=2C as much as you can fill in the b
lanks.
Regarding GEO engines=2C and their performance=3B it shouldn't be too mu
ch longer before I can fire mine up again. I had it 100% complete and runn
ing at one time=2C prior to installing the turbo=2C but then decided to add
my own turbocharger and hi-po cam.
Adding a turbo should put the power around a Rotax 912=2C maybe more...ma
ybe less. I won't know exactly=2C until I can measure thrust and other stu
ff. We'll see.......
BTW=2C my installation includes a host of gauges that monitor all the cri
tical things to watch for=2C i.e. boost gauge=2C EGT=2C AFR=2C Manifold Pre
ssure=2C etc. To install my turbo package (turbo=2C gauges=2C new muffler
=2C cam=2C etc.)=2C I have spent a total of around $1500. Add this to my e
ngine and prop costs of $6500 and I have a grand total cost of $8000 for ev
erything.
Mike Welch
MkIII
> From: apilot(at)surewest.net
> Subject: Re: Kolb-List: In-flight Electric Adjustable IvoProp
> To: kolb-list(at)matronics.com
> Date: Sun=2C 2 May 2010 19:42:54 -0700
t>
uch thrust testing. I found that the difference from 5000 rpm to and throug
h 6300 rpm only gives an additional 40 lbs of thrust. Since I do not like t
o run over 5000 because of the fact that 4 cycles (Geo Metro Suzuki G10 eng
ine) have more service life than when operated in the higher rpm range. I d
o believe that the windage tray and the re-ground cam have given me more po
wer. As for popping the breaker=2C it has only happened once on the ground
when I over pitched it. Also=2C for reasons that I do not understand=2C I g
et more thrust from cutting the 3-blade 72" dia down to
e about the same climb and cruise and he burns around 4 gallons per hour an
d I burn slightly over 2.5 gallons per hour. His engine weight is 135 lbs a
nd mine is 145 lbs with electric prop=2C exhaust and radiator.
> >Date: Sun=2C 2 May 2010 07:47:59 -0700
> >From: owner-kolb-list-@matronics.com (on behalf of Mike Welch <mdnanwelc
h7(at)hotmail.com>)
> >To:
> > Kolb guys=2C
> > For those of you that have Ivo Props=2C and
> > the electrical adjustment motor=2C the discussion came
> > is drawing it's limit of amps=2C BEFORE it has to pop
> > flight=2C about the only way to find out where the
> > pitch is=2C is to twist the prop all the way flat=2C
> > until the circuit breaker has been maxed out=2C and
> > So=2C after a couple of suggestions=2C and one
> > preliminary design=2C Bob Nuchols (the Aeroelectric
> > Now=2C when a person changes pitch in flight=2C an
> > current draw=2C and light an LED at a preset current=2C
> > interested=2C let me know=2C and I'll copy it and send
> > it to you.
> > Mike Welch
> > MkIII
> > The New Busy is not the old busy. Search=2C chat and
> >________________
Hotmail is redefining busy with tools for the New Busy. Get more from your
inbox.
N:WL:en-US:WM_HMP:042010_2
Subject: | Re: N-Number question |
April 09, 2010 - May 03, 2010
Kolb-Archive.digest.vol-jt
