Kolb-Archive.digest.vol-jw
June 15, 2010 - June 27, 2010
      inspected your plane.
      > Bob
      > Building MKIIIX
      > A&P
      > From: Frank Fanelli<frankf@flying-models.com>
      > Subject: Kolb-List: Help with elevator cable
      > Hi:
      > Bought a used, high time (740 hours) Firestar back in January, and have
      > been attending to the usual maintenance issues, all non-airworthy items.
      > Flew the plane three times so far and it is a real delight compared to
      > the Quicksilvers I flew for about 12 years.
      > During the preflight check before the fourth flight Friday (6/11), I
      > hear a scraping noise under the seat during the preflight check of the
      > controls. Thought at first it was something under the seat rubbing
      > against the cable, but nothing there. The visible part of the cable
      > looked and felt okay. Discovered that one of the elevator cables was
      > slightly frayed just aft of the pulley. Couldn't see it, but could feel
      > it. So, no more flying until the cables are replaced.
      > Called Kolb and got the part numbers for all the cable components but I
      > don't have a set plans, just the building instructions. Nothing much in
      > there about the procedure for re-installing the cables, so I'm asking
      > for some guidance. I do know they need to be taut, and each cable must
      > stay that way when the stick is moved forward and back. Also know that
      > one cable can't go slack when the other is taut.
      > Also need to know if the economy swaging tools (the screw type) can be
      > used easily when doing this. Welcome your insights.
      > Frank Fanelli
      > New Jersey
      > ________________________________  Message 6  _____________________________________
      > From: "b young"<by0ung(at)brigham.net>
      > Subject: RE: Kolb-List: Help with elevator cable
      > Frank
      > Can't help with plans....   but seems you have one to copy.   If you tie a
      > small rope to one end and pull it through...   make a new cable the same
      > length as the old. Then pull back in place with the rope to  reinstall.
      > The only problem with this is if there had been any major stretch to the
      > cable.  In which case you would make it a bit shorter,   you could check for
      > this by seeing how much adjustment is in the turnbuckle. Middle of the
      > adjustment make the same length,,,  adjustment all the way in,,, make it a
      > bit shorter, so you will have room to adjust again.
      > The economy swaging tool seem to work ok for me.
      > Boyd Young
      > MKIII 640 hours
      > Utah
      > Subject: Kolb-List: Re: Help with elevator cable
      > From: "Richard Pike"<richard(at)bcchapel.org>
      > Yep, one like this is all you need. http://www.aircraftspruce.com/catalog/topages/no2swageit.php
      > Doesn't hurt to practice a bit with some extra cable and waste a few sleeves
      if
      > you've not done any before. IMO, a box end wrench is easier than a socket and
      > ratchet. Run one bolt down a bit, then the other, then back, etc. Clamping the
      > tool in a vise while you are doing things also helps. If you are having trouble
      > keeping the wires the tension and position you want, small split bolt grounding
      > clamps are useful to keep everything in position and won't hurt your cables.
      > http://www.summitsource.com/product_info.php?ref=1&products_id=7768
      > I like to use two sleeves per thimble and also cut the ends off the thimbles
      first,
      > makes them fit better and they will not get loose.
      > Richard Pike
      > MKIII N420P (420ldPoops)
      > http://forums.matronics.com/viewtopic.php?p=301248#301248
      Hello Bob:
      The tip about the masking tape is good. had heard that once before but
      forgot about it. Instead of using the old cable to drag the new one
      through I was thinking of attaching a rope to the old one and using it
      to pull the rope through. That way I can use the old cable as a template
      for the new one. That's the plan but as I always seem to find, the best
      laid plans, etc.etc.
      Frank Fanelli
Subject: Re: Middle Tennessee Home with Airstrip
Date: Jun 15, 2010
Thank you for your kind words, David. Yes, I've already posted to Barnstormers... and every where else I can think of. I just hope that somewhere I will find that someone who is interested. I thought places where home-builders hung out would be a good place to spread the word, thinking how great it would be to have a BIG garage to work in.... anyway, if the posting is unwelcome, the powers that be need to delete the thread. I cannot find how to get rid of it myself. Again, thanks. Blue Skies.... Tina Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301336#301336 ________________________________________________________________________________
Date: Jun 15, 2010
Subject: Re: Fuel Lines
At 01:55 PM 6/15/2010, b young wrote: ...i could not keep it from leaking. i was using the black plastic clamps that attach with a pair of pliers... I would blame those clamps before the tubing... those things never seemed remotely safe to me. I use safety wire instead of hose clamps. -Dana -- Of all the forces in the world, only the Federal Government has enough power left to destroy America. ________________________________________________________________________________
Subject: Re: Elevator trim
Date: Jun 16, 2010
I'm wanting more down trim. CG is in range. With one person, forward pressure on the stick is needed for level flight. Even with two people, up elevator trim has never been needed. I don't have any specs for the plane but hor. stab is attached at center of boom rear and top of boom forward. I can check and find out how stab incidence compares to wing. K. Toney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301393#301393 ________________________________________________________________________________
Date: Jun 16, 2010
> I'm wanting more down trim. > K. Toney Kolb guys=2C Looks like it was me that misread what he was after. I read it that he n eeded more "up" trim. Apologies to those who got it right. Mike Welch _________________________________________________________________ The New Busy is not the too busy. Combine all your e-mail accounts with Hot mail. http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4 ________________________________________________________________________________
Date: Jun 16, 2010
> I'm wanting more down trim. > > K. Toney If it was mine (I think we are talking about a MKIII) I would droop the ailerons and flaps a litttle at a time until I got the aircraft trimmed up in pitch. Normally, MKIII's require a lot of nose up pitch trim, especially under power. john h mkIII ________________________________________________________________________________
Date: Jun 16, 2010
Subject: RE: Kolb-List Digest: 21 Msgs - 06/15/10
Tina: The Kolbers are really a bunch of nice people. We are a little jealous over the Kolb list... Frank: You are on the right track with the cable change. Enjoy your plane. Bob ________________________________________________________________________________
Date: Jun 16, 2010
Subject: Re: Help with elevator cable
Frank, Since you have no way on knowing how much, if any, stretch has taken place with your old cables, don't try to duplicate them. Instead, fully fabricate the end of the cable that attaches to the control surface end and use a cable clamp to set the turnbuckle end (leave two threads showing on the turnbuckle to allow for tensioning). When you are satisfied that all is correct remove the cable from the aircraft and finish the fabrication on the bench. If you've not made cables before you might want to review FAA Advisory Circular AC 43.13-1B, "Acceptable Methods, Techniques, and Practices Aircraft Inspection, Repair and Alterations", chapter 7-148, page 7-33. Notice that it shows only a single sleeve and how to swage it properly. Despite old hangar tales to the contrary using a second sleeve to tie down the loose end of the cable does absolutely nothing for the strength or safety of the cable and only offers the opportunity to make a bad cable by introducing bubbles and twists into the termination. Last, be sure and get yourself an inspection gauge so you'll know you have the correct amount of compression on the sleeve. See: http://versales.com/ns/nicopress/gogauge.html <http://versales.com/ns/nicopress/gogauge.html>as one source. Rick Girard On Tue, Jun 15, 2010 at 4:12 PM, Frank Fanelli <frankf@flying-models.com>wrote: > On 6/14/2010 2:52 PM, b young wrote: > > Frank > > > Can't help with plans.... but seems you have one to copy. If you tie a > small rope to one end and pull it through... make a new cable the same > length as the old. Then pull back in place with the rope to reinstall. > > > The only problem with this is if there had been any major stretch to the > cable. In which case you would make it a bit shorter, you could check for > this by seeing how much adjustment is in the turnbuckle. Middle of the > adjustment make the same length,,, adjustment all the way in,,, make it a > bit shorter, so you will have room to adjust again. > > > The economy swaging tool seem to work ok for me. > > > Boyd Young > > MKIII 640 hours > > Utah > > > >>>>>>>>>>>>>>>>>>>>>>>>>>. > > > Called Kolb and got the part numbers for all the cable components but I > > don't have a set plans, just the building instructions. Nothing much in > > there about the procedure for re-installing the cables, so I'm asking > > for some guidance. I do know they need to be taut, and each cable must > > stay that way when the stick is moved forward and back. Also know that > > one cable can't go slack when the other is taut. > > > Also need to know if the economy swaging tools (the screw type) can be > > used easily when doing this. Welcome your insights. > > > Frank Fanelli > > * > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > * > > Boyd: > > Thanks for the quick reply. You're right. That's what I was going to do. > Just wasn't sure if there was a guide of some kind inside the boom tube. > Also wasn't sure if there was a spec for cable length on the plans. I deal > with radio control planes and the larger ones have gone to cable systems for > the rudders especially and know that the cable need to be equally tensioned, > the same situation with the Firestar > > Well, ordered the bits and pieces today and hopefully will get into it by > and during the weekend. Those first three flights to get the feel of the > plane definitely whet my appetite for a lot more flying. > > Frank Fanelli > > * > > * > > ________________________________________________________________________________
Date: Jun 16, 2010
rickofudall wrote: > > Despite old hangar tales to the contrary using a second sleeve to tie down the loose end of the cable does absolutely nothing for the strength or safety of the cable and only offers the opportunity to make a bad cable by introducing bubbles and twists into the termination. > Rick Girard > [b] Back in 1979, I built my first motorized hang glider, it was a Quicksilver, built it from plans, and my wife sewed the sails on her sewing machine in our living room. I took a Yamaha dirt bike engine, sawed off the transmission and welded a big flat washer to the primary gear where I bolted on a direct drive prop - which is still hanging on the wall of my workshop. At that time North American Rockwell had an aircraft factory at Albany, GA, they built Thrushes and Aero Commander 112's & 114's there. A friend of mine worked there, and was helping with the project, and when it came time to fabricate some cables, he checked out one of the factory's big bolt cutter type nicopress tools. But not a gauge. Hey, it was the same tool the factory used every day, it would be good, right? We made up a couple test swages on a short length of cable and they looked pretty good, and it occurred to me to wonder how strong they were. So I hooked one thimble over a nail in the garage roof, stuck a screwdriver through the thimble on the other end and attempted a chin up. (I never claimed to be smart...) The cable pulled through the swaged sleeve and (naturally) I smashed myself in the bridge of the nose with a screwdriver blade held crosswise as hard as I could. He took that swage tool back, got a different one, and I have double sleeved ever since. Yes, I know what AC 43-13 says, I have one on my shelf, I also know that sleeves are cheap, and if you practice a bit, double sleeves will turn out ok. If not, I also know how to split a sleeve with a sharp cold chisel and redo that end. Or throw it away and start over, which is better than having a cable pull out, like happened on a local Kitfox a few years back. Fortunately it was only the single sleeved cable that went to his tailwheel for steering, and although the groundloop nearly totaled it, he walked away, along with his little daughter who was riding with him. Interesting that I was the EAA Technical Counselor who looked at his airplane, and I mentioned to him that all his cables were single sleeved. He said that was what AC 43-13 called for, and we left it at that. Also, you might want to take a look at page 122 of Tony Bingelis' book "The Sportplane Builder," the drawing at the bottom of the page shows how to - in his words - "use double sleeve application for extra strength." Tony's old hangar tales are good enough for me. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301436#301436 ________________________________________________________________________________
Date: Jun 16, 2010
>> Despite old hangar tales to the contrary using a second sleeve to tie down the loose end of the cable does absolutely nothing for the strength or safety of the cable and only offers the opportunity to make a bad cable by introducing bubbles and twists into the termination. >> Rick Girard Rick G/Gang: I will continue to use two sleeves on each cable connection, especially 3/32" and smaller, 7X19 cable . Smaller the cable, finer the wire, means less area for grip. I did very unscientific pull tests with 3/32" 7X19 many years ago. Used an 8,000 lb winch on my old Toyota Land Cruiser. Single sleeve connections always failed before the double sleeve connections. The results convinced me to keep on doing what Homer Kolb told me to do. I still do. BTW: All sleeves were squeezed with the same tool and checked with the same GO-NO GO gauge. john h mkIII ________________________________________________________________________________
Date: Jun 16, 2010
John: What's your recommendation for a swaging tool? I couldn't justify spending over $100 for a swaging tool and the economy bolt press looked somewhat unwieldy. So I found an 18-inch long swaging tool at Home Depot that handles a few sleeve sizes including the 3/32 I need for the 7x19 elevator cable. Do you think it will be strong enough? I guess the go-no go gauge will be the final judge. Frank Fanelli On 6/16/2010 3:24 PM, John Hauck wrote: > > > >> Despite old hangar tales to the contrary using a second sleeve to > tie down the loose end of the cable does absolutely nothing for the > strength or safety of the cable and only offers the opportunity to > make a bad cable by introducing bubbles and twists into the termination. >>> Rick Girard > > > Rick G/Gang: > > I will continue to use two sleeves on each cable connection, > especially 3/32" and smaller, 7X19 cable . > > Smaller the cable, finer the wire, means less area for grip. > > I did very unscientific pull tests with 3/32" 7X19 many years ago. > Used an 8,000 lb winch on my old Toyota Land Cruiser. Single sleeve > connections always failed before the double sleeve connections. The > results convinced me to keep on doing what Homer Kolb told me to do. > I still do. > > BTW: All sleeves were squeezed with the same tool and checked with > the same GO-NO GO gauge. > > john h > mkIII > > ________________________________________________________________________________
Date: Jun 16, 2010
I'll do that John. Thanks. Ailerons and flaps are neutral, or in line with the bottom of the wing now. Should drag stay the same since I won't be having to add down elevator? K. Toney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301464#301464 ________________________________________________________________________________
Date: Jun 16, 2010
> I'll do that John. Thanks. > Ailerons and flaps are neutral, or in line with the bottom of the wing > now. Should drag stay the same since I won't be having to add down > elevator? > > K. Toney K.Toney/Gang: What the airplane components look like on the ground (what their positions are) are not necessarily what they look like in the air. Have no idea about drag, but if it were me, I would not be concerned about it. john h mkIII ________________________________________________________________________________
Date: Jun 16, 2010
> What's your recommendation for a swaging tool? I couldn't justify > spending over $100 for a swaging tool and the economy bolt press looked > somewhat unwieldy. So I found an 18-inch long swaging tool at Home Depot > that handles a few sleeve sizes including the 3/32 I need for the 7x19 > elevator cable. Do you think it will be strong enough? I guess the go-no > go gauge will be the final judge. > > Frank Fanelli Give Travis a call at Kolb Aircraft. He can get you one in the mail. GO-NO GO gauge is critical. Make sure the nicroprees sleeve is inserted into the tool correctly. They can be inserted 90 deg out and give the inexperienced cable maker the impression it is the correctly positioned to press. I did just that on my Ultrastar in 1984. Every connection was the same. Every connection had the potential to fail. Brother Jim picked up my mistake before I had a chance to kill myself. I can do it correctly now. john h mkIII ________________________________________________________________________________
Date: Jun 16, 2010
I'm not sure I understand. We're talking about changing the length of the control rods so ailerons and/or flaps will have a little down in them? Wouldn't that be noticeable on the ground with the stick centered? K. Toney Sorry if I'm not following protocol with quotes and all. I'm not sure how all that works... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301473#301473 ________________________________________________________________________________
Date: Jun 16, 2010
At 01:35 PM 6/16/2010, Richard Pike wrote: >.....he checked out one of the factory's big bolt cutter type nicopress >tools. But not a gauge. Hey, it was the same tool the factory used every >day, it would be good, right? I'll go so far as to say the gauge is even more important than the swaging tool. Regardless of what kind of tool you have (I use the cheap bolt type), checking the swages with a gauge is an absolute MUST!!! However, if you don't have a gauge, you can make the same check with an accurate micrometer or dial caliper if you have the max size specs. I have a copy somewhere; can't find it at the moment but a web search should turn it up. A properly installed swage should hold the full rated strength of the cable. Using two sleeves adds nothing, unless one of them is not installed properly. Still, it can't hurt, as long as the short end is very slightly looser than the primary cable. Otherwise it can cause a bending load that may actually weaken the connection. -Dana -- The gene pool could use a little chlorine. ________________________________________________________________________________
Date: Jun 16, 2010
> I'm not sure I understand. We're talking about changing the length of the > control rods so ailerons and/or flaps will have a little down in them? > Wouldn't that be noticeable on the ground with the stick centered? > > K. Toney Yes, you will see some position change on the ground, but the control surfaces will not be in the same position when the mkIII is flying. If they are drooped a little on the ground, they are going to fly a little higher in the air. Same thing occurs when playing with engine thrust lines. The engine takes on a different position in the air when under power than when sitting static on the ground. john h mkIII ________________________________________________________________________________
Date: Jun 16, 2010
So if the control surfaces are flushed up with the wing on the ground, they could all be pointing up a bit in flight? Either way, I think this will solve my problem. K Toney Mark IIIc SC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301488#301488 ________________________________________________________________________________
Date: Jun 16, 2010
clrprop wrote: > So if the control surfaces are flushed up with the wing on the ground, they could all be pointing up a bit in flight? > Either way, I think this will solve my problem. > > K Toney > > Mark IIIc > SC Yes, if they are flush with the wing on the ground, they will be reflexed up in the air, the airplane will act tail heavy in cruise, and you will need forward stick. Adjusting aileron droop is the best way to fine tune a Kolb in trim, just like John said. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301489#301489 ________________________________________________________________________________
Date: Jun 16, 2010
Good to go. Thanks all for your help. K Toney MarkIIIc SC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301490#301490 ________________________________________________________________________________
Date: Jun 16, 2010
Just one more question. What is best, adjust the ailerons, the flaps, or both? K Toney MarkIIIc SC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301498#301498 ________________________________________________________________________________
Date: Jun 16, 2010
> What is best, adjust the ailerons, the flaps, or both? > > K Toney K Toney/Folks: I don't think it matters. One way to get an idea of how much nose down trim you will require through drooping the ailerons and flaps is fly the airplane at cruise speed, reach up and start slowly pulling flaps in until you get close to your pitch trim. Look over at the flap, note and remember about how much it is drooped. john h mkIII ________________________________________________________________________________
Date: Jun 16, 2010
I'll do that. I think adjusting both might be best to have smoothest airflow over the wings. K Toney MarkIIIc SC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301515#301515 ________________________________________________________________________________
Subject: Flight photo, Memorial Weekend
Date: Jun 17, 2010
List, I did a lot of flying on the Saturday of Memorial Day weekend. Took off early and got home late. I took this photo of the Fred Hartman bridge which crosses the Houston Ship Channel. It's not huge or famous in the world of bridges, but I like it. Sorry for the too-big file size on the photo. HKS continues to perform well, turned 100 hrs on it recently. Jimmy Y FS II, 320 hrs HKS 700E, 103 hrs. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301522#301522 Attachments: http://forums.matronics.com//files/dscn0677_407.jpg ________________________________________________________________________________
Date: Jun 17, 2010
Subject: Re: Flight photo, Memorial Weekend
Very nice, Jimmy! For those who don't live in the area, off in the distance is the San Jacinto Monument, which commemorates the site of the Battle of San Jacinto, the decisive battle of the Texas Revolution. It's even taller than the Washington Monument, topped by a big Texas star! On Thu, Jun 17, 2010 at 5:30 AM, Jimmy Young wrote: > > List, > > I did a lot of flying on the Saturday of Memorial Day weekend. Took off > early and got home late. I took this photo of the Fred Hartman bridge which > crosses the Houston Ship Channel. It's not huge or famous in the world of > bridges, but I like it. Sorry for the too-big file size on the photo. > > HKS continues to perform well, turned 100 hrs on it recently. > > Jimmy Y > FS II, 320 hrs > HKS 700E, 103 hrs. > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=301522#301522 > > > Attachments: > > http://forums.matronics.com//files/dscn0677_407.jpg > > ________________________________________________________________________________
Date: Jun 17, 2010
A most excellent photo. This is what I like about this list. We may differ on how to build or even fly our Kolb's , but we can not disagree that the places they take us to or the things we see from them have no equal . From one side of the world to the other Kolbs are veiwing the best there is to see on this planet . Fly safe MK111c Down under 0 deg c until 10am today. clear skys no wind , only work to get in the way ----- Original Message ----- From: "Jimmy Young" <jdy100(at)comcast.net> Sent: Thursday, June 17, 2010 10:30 PM Subject: Kolb-List: Flight photo, Memorial Weekend > > List, > > I did a lot of flying on the Saturday of Memorial Day weekend. Took off > early and got home late. I took this photo of the Fred Hartman bridge > which crosses the Houston Ship Channel. It's not huge or famous in the > world of bridges, but I like it. Sorry for the too-big file size on the > photo. > > HKS continues to perform well, turned 100 hrs on it recently. > > Jimmy Y > FS II, 320 hrs > HKS 700E, 103 hrs. > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=301522#301522 > > > Attachments: > > http://forums.matronics.com//files/dscn0677_407.jpg > > > ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Jun 17, 2010
Great photo! Where do you fly out of? I'm headed to Houston this weekend for cancer treatment and in my spare time I'd like to check out an airport or two. I have just bought a Kolb Firestar KXP, but haven't flown it yet (too sick with Chemo). Gene in Beautiful Tennessee ----- Original Message ----- From: "Jimmy Young" <jdy100(at)comcast.net> Sent: Thursday, June 17, 2010 5:30 AM Subject: Kolb-List: Flight photo, Memorial Weekend > > List, > > I did a lot of flying on the Saturday of Memorial Day weekend. Took off > early and got home late. I took this photo of the Fred Hartman bridge > which crosses the Houston Ship Channel. It's not huge or famous in the > world of bridges, but I like it. Sorry for the too-big file size on the > photo. > > HKS continues to perform well, turned 100 hrs on it recently. > > Jimmy Y > FS II, 320 hrs > HKS 700E, 103 hrs. > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=301522#301522 > > > Attachments: > > http://forums.matronics.com//files/dscn0677_407.jpg > > > ________________________________________________________________________________
Date: Jun 17, 2010
Hello all! Nice Pix Jim! I love seeing everyones pictures and there is no better place to see this beautiful earth than from out little airplanes ! I took a 350 mi trip with my M3X that weekend too.It was the first long X country with the airplane and she performed great ! Here is the link if anyone wants to see... Have a great weekend everyone! http://www.facebook.com/album.php?aid=49673&id=1651000323&l=ec62c0b91c chris ambrose M3X/Jabiru A-2200 138.0 hrs N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301542#301542 ________________________________________________________________________________
Subject: service bulletin
Date: Jun 17, 2010
Rotax 912 Engines Draw FAA SAIB Thu, 17 Jun '10 Fuel Pumps May Cause Engine Flooding, Fuel Leaks Due To Overpressure The FAA has issued a Special Airworthiness Information Bulletin (SAIB) for certain part number fuel pumps installed on, but not limited to, Rotax 912 series aircraft engines. The pumps cause a possible unsafe condition on special light sport category aircraft (SLSA), experimental light sport aircraft (ELSA), and experimental amateur-built aircraft with the engines installed. In some cases, if the input pressure to the mechanical fuel pump is high (e.g., due to an electric fuel pump upstream), the output pressure from the mechanical fuel pump could be excessive. This high fuel pressure may cause the engine to malfunction from flooding and/or cause fuel leakage. The fuel pumps affected by this issue are 892230, 892232, 892540 (standard version), and 892235, 892236, 892545 (version including flexible line). Pumps with part numbers 892542 and 892546 are not affected. The engines likely to be affected by this issue are: 912A S/Ns 4,410.684 through 4,410.727 912F S/Ns 4,412.913 through S/Ns 4,412.925 912S S/Ns 4,923.282 through 4,923.461 912UL S/Ns 4,407.646 through 4,408.361 912ULS S/Ns 5,646.084 through 5,648.164 912ULSFR S/Ns 4,430.267 through 4,430.500 and S/Ns 6,374.028 through 6,374.054 Rotax 912ULS The FAA says ff your aircraft is affected by this issue, replacement of the fuel pump part numbers listed above is recommended following ROTAX Service Bulletins SB-912-053 and SB-912-053UL. The FAA says it is taking airworthiness directive action to address this issue on the type-certificated aircraft and engines. FMI: www.faa.gov ________________________________________________________________________________
Subject: Re: service bulletin
Date: Jun 17, 2010
BB/Gang: Rotax first published an SB, April 2007, reference fuel pump over pressure. Took the FAA over 3 years to come up with theirs. john h mkIII Fuel Pumps May Cause Engine Flooding, Fuel Leaks Due To Overpressure The FAA has issued a Special Airworthiness Information Bulletin (SAIB) for certain part number fuel pumps installed on, but not limited to, Rotax 912 series aircraft engines. The pumps cause a possible unsafe condition on special light sport category aircraft (SLSA), experimental light sport aircraft (ELSA), and experimental amateur-built aircraft with the engines installed. In some cases, if the input pressure to the mechanical fuel pump is high (e.g., due to an electric fuel pump upstream), the output pressure from the mechanical fuel pump could be excessive. This high fuel pressure may cause the engine to malfunction from flooding and/or cause fuel leakage. The fuel pumps affected by this issue are 892230, 892232, 892540 (standard version), and 892235, 892236, 892545 (version including flexible line). Pumps with part numbers 892542 and 892546 are not affected. The engines likely to be affected by this issue are: a.. 912A S/Ns 4,410.684 through 4,410.727 b.. 912F S/Ns 4,412.913 through S/Ns 4,412.925 c.. 912S S/Ns 4,923.282 through 4,923.461 d.. 912UL S/Ns 4,407.646 through 4,408.361 e.. 912ULS S/Ns 5,646.084 through 5,648.164 f.. 912ULSFR S/Ns 4,430.267 through 4,430.500 and S/Ns 6,374.028 through 6,374.054 Rotax 912ULS The FAA says ff your aircraft is affected by this issue, replacement of the fuel pump part numbers listed above is recommended following ROTAX Service Bulletins SB-912-053 and SB-912-053UL. The FAA says it is taking airworthiness directive action to address this issue on the type-certificated aircraft and engines. FMI: www.faa.gov ________________________________________________________________________________
Date: Jun 17, 2010
John, As long as we are dealing in anecdotal evidence I can count personally at least ten different aircraft I have flown, and four that I have built that used cable structural bracing and all had but a single compression sleeve to terminate those cables. Not one ever slipped or distorted in any way no matter how badly I abused them. Then there is the experience of Wills Wing, who have manufactured literally thousands of hang gliders using the standards set out by the National Telephone Supply Co, the inventor of the Nicopress process. To my knowledge, in almost 40 years they have not had a single failure reported due to the Nico sleeve failing in any way. <http://versales.com/ns/nicopress/inst32pg4.html>A single sleeve properly installed is as strong as the cable itself, that you have applied an 8,000 lb winch to a cable with a 960 lb breaking strength is as you put it "a very unscientific test". Until someone comes forward WITH a scientific test that disproves both the manufacturer of the process and the guidance given to EVERY certified mechanic by the FAA I will continue to contend that the only thing a second Nico sleeve does is introduce the prospect of a reject able cable assembly. Rick Girard "Two wrongs don't make a right, but three lefts do" On Wed, Jun 16, 2010 at 2:24 PM, John Hauck wrote: > > > >> Despite old hangar tales to the contrary using a second sleeve to tie > down the loose end of the cable does absolutely nothing for the strength or > safety of the cable and only offers the opportunity to make a bad cable by > introducing bubbles and twists into the termination. > >> Rick Girard >>> >> > > Rick G/Gang: > > I will continue to use two sleeves on each cable connection, especially > 3/32" and smaller, 7X19 cable . > > Smaller the cable, finer the wire, means less area for grip. > > I did very unscientific pull tests with 3/32" 7X19 many years ago. Used an > 8,000 lb winch on my old Toyota Land Cruiser. Single sleeve connections > always failed before the double sleeve connections. The results convinced > me to keep on doing what Homer Kolb told me to do. I still do. > > BTW: All sleeves were squeezed with the same tool and checked with the > same GO-NO GO gauge. > > john h > mkIII > > ________________________________________________________________________________
Date: Jun 17, 2010
Jimmy, Nice pic! That is a beautiful bridge and the angle of the camera and your streamlined strut brought a tear to my eye as it was a very familiar sight ,that I miss desperately ! Thank you , Chris Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ----- Original Message ---- From: Jimmy Young <jdy100(at)comcast.net> Sent: Thu, June 17, 2010 6:30:17 AM Subject: Kolb-List: Flight photo, Memorial Weekend List, I did a lot of flying on the Saturday of Memorial Day weekend. Took off early and got home late. I took this photo of the Fred Hartman bridge which crosses the Houston Ship Channel. It's not huge or famous in the world of bridges, but I like it. Sorry for the too-big file size on the photo. HKS continues to perform well, turned 100 hrs on it recently. Jimmy Y FS II, 320 hrs HKS 700E, 103 hrs. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301522#301522 Attachments: http://forums.matronics.com//files/dscn0677_407.jpg ________________________________________________________________________________
Date: Jun 17, 2010
Frank, I bought a model 32 VC VG tool back when they were less than $35 in the early seventies and it's still giving good service. The bolt tool works well for a few swages, but is unwieldy beyond that. You might check with your local EAA chapter and see if a member has either the 32 VC VG or the 64CGMP tool. Rick Girard On Wed, Jun 16, 2010 at 3:52 PM, Frank Fanelli <frankf@flying-models.com>wrote: > > John: > > What's your recommendation for a swaging tool? I couldn't justify spending > over $100 for a swaging tool and the economy bolt press looked somewhat > unwieldy. So I found an 18-inch long swaging tool at Home Depot that handles > a few sleeve sizes including the 3/32 I need for the 7x19 elevator cable. Do > you think it will be strong enough? I guess the go-no go gauge will be the > final judge. > > Frank Fanelli > > On 6/16/2010 3:24 PM, John Hauck wrote: > >> >> >> >> Despite old hangar tales to the contrary using a second sleeve to tie >> down the loose end of the cable does absolutely nothing for the strength or >> safety of the cable and only offers the opportunity to make a bad cable by >> introducing bubbles and twists into the termination. >> >>> Rick Girard >>>> >>> >> >> Rick G/Gang: >> >> I will continue to use two sleeves on each cable connection, especially >> 3/32" and smaller, 7X19 cable . >> >> Smaller the cable, finer the wire, means less area for grip. >> >> I did very unscientific pull tests with 3/32" 7X19 many years ago. Used >> an 8,000 lb winch on my old Toyota Land Cruiser. Single sleeve connections >> always failed before the double sleeve connections. The results convinced >> me to keep on doing what Homer Kolb told me to do. I still do. >> >> BTW: All sleeves were squeezed with the same tool and checked with the >> same GO-NO GO gauge. >> >> john h >> mkIII >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 17, 2010
Hi Jim, Good to hear that you are getting a lot of flight time . We are in Los Lunas , New Mexico I am flying every day.We were fortunate enough to get a house with an attached hanger that is about 50 yards from the taxiway.Sure is different here , the density alt so far is from 5000 to 9000 ft.depending on the time of day.Until I get really used to that I don't intend to fly when it's any hotter.Afterwards (we'll see) Takeoff rolls are long and landing speeds are high at 9000 ft. DA, also can't climb much over 150 ft. a minute --a guess-- I haven't been far enough to get a good handle on the rate of climb. So far I haven't been over 10 miles from the home air port. Have a good summer and I will see you in the fall. Frank ________________________________ From: Jimmy Young <jdy100(at)comcast.net> Sent: Thu, June 17, 2010 5:30:17 AM Subject: Kolb-List: Flight photo, Memorial Weekend List, I did a lot of flying on the Saturday of Memorial Day weekend. Took off early and got home late. I took this photo of the Fred Hartman bridge which crosses the Houston Ship Channel. It's not huge or famous in the world of bridges, but I like it. Sorry for the too-big file size on the photo. HKS continues to perform well, turned 100 hrs on it recently. Jimmy Y FS II, 320 hrs HKS 700E, 103 hrs. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301522#301522 Attachments: http://forums.matronics.com//files/dscn0677_407.jpg ________________________________________________________________________________
Date: Jun 17, 2010
Sorry List, Was supposed to go Jimmy Young.Fingers are too big for computers. Frank Goodnight ________________________________ From: frank goodnight <frank.goodnight(at)att.net> Sent: Thu, June 17, 2010 12:27:09 PM Subject: Re: Kolb-List: Flight photo, Memorial Weekend Hi Jim, Good to hear that you are getting a lot of flight time . We are in Los Lunas , New Mexico I am flying every day.We were fortunate enough to get a house with an attached hanger that is about 50 yards from the taxiway.Sure is different here , the density alt so far is from 5000 to 9000 ft.depending on the time of day.Until I get really used to that I don't intend to fly when it's any hotter.Afterwards (we'll see) Takeoff rolls are long and landing speeds are high at 9000 ft. DA, also can't climb much over 150 ft. a minute --a guess-- I haven't been far enough to get a good handle on the rate of climb. So far I haven't been over 10 miles from the home air port. Have a good summer and I will see you in the fall. Frank ________________________________ From: Jimmy Young <jdy100(at)comcast.net> Sent: Thu, June 17, 2010 5:30:17 AM Subject: Kolb-List: Flight photo, Memorial Weekend List, I did a lot of flying on the Saturday of Memorial Day weekend. Took off early and got home late. I took this photo of the Fred Hartman bridge which crosses the Houston Ship Channel. It's not huge or famous in the world of bridges, but I like it. Sorry for the too-big file size on the photo. HKS continues to perform well, turned 100 hrs on it recently. Jimmy Y FS II, 320 hrs HKS 700E, 103 hrs. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301522#301522 Attachments: http://forums.matronics.com//files/dscn0677_407.jpg ________________________________________________________________________________
Date: Jun 17, 2010
Does anyone, instead of swaging, use the old cable splicing technique per http://thevintageaviator.co.nz/reference/cable-splicing ? I can recall in an earlier life as a young apprentice having to do it this way. Sure was a strong bond with virtually no chance of it coming loose. On the contrary, it held tighter under tension. Swaging would be much quicker but splicing looks better (subjective). Just curious. David. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301576#301576 ________________________________________________________________________________
Date: Jun 17, 2010
FWIW: I recently used a piece of 3/32 cable to make a tow-cable to pull my kaput VW home. I used one nico sleeve and didn't take any particular care swaging it. While the cable was easily strong enough to pull the car, it broke during after one of those slack times when things get tight very quickly. The loop at the swaged end broke - the swage held. It appears the swage portion is stronger than the cable itself. But . we always used 2 swages, if for no other reason than it provides a convenient way to tidy up the end of the cable. Dennis _____ From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Thursday, June 17, 2010 12:00 PM Subject: Re: Kolb-List: Re: Help with elevator cable John, As long as we are dealing in anecdotal evidence I can count personally at least ten different aircraft I have flown, and four that I have built that used cable structural bracing and all had but a single compression sleeve to terminate those cables. Not one ever slipped or distorted in any way no matter how badly I abused them. Then there is the experience of Wills Wing, who have manufactured literally thousands of hang gliders using the standards set out by the National Telephone Supply Co, the inventor of the Nicopress process. To my knowledge, in almost 40 years they have not had a single failure reported due to the Nico sleeve failing in any way. <http://versales.com/ns/nicopress/inst32pg4.html> A single sleeve properly installed is as strong as the cable itself, that you have applied an 8,000 lb winch to a cable with a 960 lb breaking strength is as you put it "a very unscientific test". Until someone comes forward WITH a scientific test that disproves both the manufacturer of the process and the guidance given to EVERY certified mechanic by the FAA I will continue to contend that the only thing a second Nico sleeve does is introduce the prospect of a reject able cable assembly. Rick Girard "Two wrongs don't make a right, but three lefts do" On Wed, Jun 16, 2010 at 2:24 PM, John Hauck wrote: >> Despite old hangar tales to the contrary using a second sleeve to tie down the loose end of the cable does absolutely nothing for the strength or safety of the cable and only offers the opportunity to make a bad cable by introducing bubbles and twists into the termination. Rick Girard Rick G/Gang: I will continue to use two sleeves on each cable connection, especially 3/32" and smaller, 7X19 cable . Smaller the cable, finer the wire, means less area for grip. I did very unscientific pull tests with 3/32" 7X19 many years ago. Used an 8,000 lb winch on my old Toyota Land Cruiser. Single sleeve connections always failed before the double sleeve connections. The results convinced me to keep on doing what Homer Kolb told me to do. I still do. BTW: All sleeves were squeezed with the same tool and checked with the same GO-NO GO gauge. john h mkIII ========== arget="_blank">http://www.matronics.com/Navigator?Kolb-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Questions about Firestar Gross Weight
Date: Jun 17, 2010
I have a 5-rib Firestar 1 with a 447. It weighs 335lbs empty. I have seen the gross weight listed in several places, it's just never the same figure. 550 lbs, 650, 725, and 750 can be found. Is there a consensus on the list? Any advice is appreciated. John Tempest Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301611#301611 ________________________________________________________________________________
Date: Jun 17, 2010
> Great photo! Where do you fly out of? I'm headed to Houston this weekend > for cancer treatment and in my spare time I'd like to check out an airport > or two. I have just bought a Kolb Firestar KXP, but haven't flown it yet > (too sick with Chemo). > Gene in Beautiful Tennessee Gene, I hanger at a country grass strip airport called Bailes Field (7R9) about 30 miles due south of Houston. I'd be glad to show you around this weekend while you are in town. Give me a call at 832.309.1730 or email me and we can figure out the details. To everyone else, I'm glad so many liked the photo. I'm sure I could take better ones with the right lenses and filters, but advanced photography is really not something I'm interested in at all. I just point & shoot & occasionally I get lucky. It is a great way to share with others what we get to see from our Kolbs. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301615#301615 ________________________________________________________________________________
Date: Jun 17, 2010
Thanks Jimmy, I'll give you a call on Sunday (I should get into Houston late Saturday). Gene ----- Original Message ----- From: "Jimmy Young" <jdy100(at)comcast.net> Sent: Thursday, June 17, 2010 7:14 PM Subject: Kolb-List: Re: Flight photo, Memorial Weekend > > >> Great photo! Where do you fly out of? I'm headed to Houston this weekend >> for cancer treatment and in my spare time I'd like to check out an >> airport >> or two. I have just bought a Kolb Firestar KXP, but haven't flown it yet >> (too sick with Chemo). >> Gene in Beautiful Tennessee > > > Gene, > I hanger at a country grass strip airport called Bailes Field (7R9) about > 30 miles due south of Houston. I'd be glad to show you around this weekend > while you are in town. Give me a call at 832.309.1730 or email me and we > can figure out the details. > > To everyone else, I'm glad so many liked the photo. I'm sure I could take > better ones with the right lenses and filters, but advanced photography is > really not something I'm interested in at all. I just point & shoot & > occasionally I get lucky. It is a great way to share with others what we > get to see from our Kolbs. > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=301615#301615 > > > ________________________________________________________________________________
Subject: Re: Questions about Firestar Gross Weight
Date: Jun 17, 2010
There are many versions of the Firestar. The first was the Original Firestar with a 5-rib wing and a gross weight of 550 lbs. The 7-rib Firestars have the higher GW's. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 23 years flying it Kolbra 912UL N20386 2 years flying it 120 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301628#301628 ________________________________________________________________________________
Date: Jun 17, 2010
That is weird They named my Farther in law after that Bridge Fred Hartman is his name I'll have to tell him about that Ellery Batchelder Jr. -----Original Message----- From: Robert Laird <rlaird(at)cavediver.com> Sent: Thu, Jun 17, 2010 6:48 am Subject: Re: Kolb-List: Flight photo, Memorial Weekend Very nice, Jimmy! For those who don't live in the area, off in the distan ce is the San Jacinto Monument, which commemorates the site of the Battle of San Jacinto, the decisive battle of the Texas Revolution. It's even taller than the Washington Monument, topped by a big Texas star! On Thu, Jun 17, 2010 at 5:30 AM, Jimmy Young wrote: List, I did a lot of flying on the Saturday of Memorial Day weekend. Took off ea rly and got home late. I took this photo of the Fred Hartman bridge which crosses the Houston Ship Channel. It's not huge or famous in the world of bridges, but I like it. Sorry for the too-big file size on the photo. HKS continues to perform well, turned 100 hrs on it recently. Jimmy Y FS II, 320 hrs HKS 700E, 103 hrs. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301522#301522 Attachments: http://forums.matronics.com//files/dscn0677_407.jpg arget="_blank">http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jun 17, 2010
Subject: Bolding going where a few have gone before; the HKS
Kolbers, Bob Dresden here. Getting ready to 4 cycle the Firestar II with the HKS. I'd like to keep the trial and error part to a minimum if I can. Soooo, I'm hoping I can tap into this great knowledge base we've got here. I've talked with Larry C about his install, got some great insights into this endeavor. I'll be doing the type II exhaust and horizontal carbs, 3.47 gearbox. I'm fishing for photos, hints, what I'd do different next time, all this good stuff. Where do all those oil lines go, any mounting options for tank and cooler, anyone with a type II setup care to comment on noise level? I certainly appreciate all replies. Thanks in advance. Bob Dresden Firestar 646F ________________________________________________________________________________
Subject: trip pics
Date: Jun 18, 2010
Nice set of pics. I like the `D-Day` black and white on the wings. My father ran a hardware store and a couple of days before 6th June `44 a lorry from the local airfield turned up and the squadies bought all the black and white paint we had in stock. It was used for painting those stripes on the wings and fuselage of the Horsa gliders and Stirlings. (It was a bomber but downgraded to glider tugging.) at the local airfield. Of course we didn`t know what it was for at the time. A couple of weeks ago I attended a get together of veterans from RAF and Para`s and one guy came up and introduced himself and said that he was the squaddie who had come to the shop to buy the paint. .Talk about the long arm of coincidence. Incidentally most people don`t seem to know why the stripes were put on. It was just because the standard of aircraft recognition was so low (Particularly the Navy who always shot first and asked questions after). Cheers Pat ________________________________________________________________________________
Subject: Re: [Dixielandjazz] Where did it go?
Date: Jun 18, 2010
----- Original Message ----- From: "M J (Mike) Logsdon" <mjl(at)ix.netcom.com> Cc: "Dixieland Jazz Mailing List" Sent: Thursday, June 17, 2010 9:45 AM Subject: Re: [Dixielandjazz] Where did it go? >>>> The fact that "jazz clubs" still exist in the UK to this day, is still >>>> something that wows me.>> Yes they do and I am off to one tonight. Trouble is that there will be very few there because there is a football match on the TV (I understand). Some people have strange priorities. Cheers Pat > > _______________________________________________ > To unsubscribe or change your e-mail preferences for the Dixieland Jazz > Mailing list, or to find the online archives, please visit: > > http://ml.islandnet.com/mailman/listinfo/dixielandjazz > > > Dixielandjazz mailing list > Dixielandjazz(at)ml.islandnet.com -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 04:33:00 ________________________________________________________________________________
Date: Jun 19, 2010
From: william sullivan <williamtsullivan(at)att.net>
Subject: Kolb Flyer
- There is a Kolb Flyer on Barnstormers.- While I am not interested in buying it, I would like to know if anyone has ever flown one.- It looks l ike a twin engine Ultrastar.- I think the ad said 180 pounds.- Any comm ents?- John?- Dennis? - ------------------------- -------------------- Bill Sullivan ------------------------- -------------------- Windsor Locks, Ct. ------------------------- -------------------- FS 447 ________________________________________________________________________________
Subject: re: Help with elevator cable
Date: Jun 19, 2010
http://thevintageaviator.co.nz/reference/cable-splicing ? I can recall in an earlier life as a young apprentice having to do it this way. Sure was a strong bond with virtually no chance of it coming loose. On the contrary, it held tighter under tension. Swaging would be much quicker but splicing looks better (subjective). Just curious. David.> At Northrop part of the course was to make this fixture (and the poking awl) by hand, using nothing but hacksaw, file, and hand die. The thimble fit in the little base receiver and the block went in a vise. We then had to do one splice, also for a grade. If you want to correctly restore an antique airplane this is the only way. BB (prefers swage) DSCN2274 ________________________________________________________________________________
Date: Jun 19, 2010
Subject: A Thank You From the Family of John Ratcliffe
I have just gone to the Kolb List site and un-subscribed, but I just want you and all the people at the Kolb Aircraft Co., in London KY to know that John loved reading all your emails and advice, and on his behalf I want to thank each and everyone of you. Jane Ratcliffe ________________________________________________________________________________
Subject: rotax 447 gear box oil plug
Date: Jun 19, 2010
The oil plug on my gear box was frozen when I attempted to change oil and in spite of using a quality box end wrench the hex head was rounded out during removal. The replacement plug from Leading Edge Air Foils cost me $27 plus shipping. Now I don't want this to happen again so I am looking for advice on preventing re-occurrence. Pete ________________________________________________________________________________
Date: Jun 19, 2010
Subject: Re: Rotax 447 gear box oil plug
- Ellery suggested a product called Nickle Seize for steel to aluminum co ntact.- I had asked about something for the gear leg sockets. - ------------------------- ------------- Bill Sullivan ------------------------- ------------- Windsor Locks, Ct. ------------------------- ------------- FS 447 ________________________________________________________________________________
Subject: Re: rotax 447 gear box oil plug
Date: Jun 19, 2010
Anti-seize compound! john h mkIII The oil plug on my gear box was frozen when I attempted to change oil and in spite of using a quality box end wrench the hex head was rounded out during removal. The replacement plug from Leading Edge Air Foils cost me $27 plus shipping. Now I don't want this to happen again so I am looking for advice on preventing re-occurrence. Pete ________________________________________________________________________________
Date: Jun 19, 2010
A soft gasket,(copper) and a six point socket or box end wrench G.Aman -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Sat, Jun 19, 2010 4:53 pm Subject: Re: Kolb-List: rotax 447 gear box oil plug Anti-seize compound! john h mkIII The oil plug on my gear box was frozen when I attempted to change oil an d in spite of using a quality box end wrench the hex head was rounded ou t during removal. The replacement plug from Leading Edge Air Foils cost me $27 plus shipping. Now I don't want this to happen again so I am loo king for advice on preventing re-occurrence. Pete ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jun 19, 2010
Subject: Re: Bolding going where a few have gone before; the HKS
So much for BOLDLY going anywhere.. 1 more question. What is the minimum clearance for prop to boom tube On Thu, Jun 17, 2010 at 9:54 PM, Robert Dresden wrote: > > Kolbers, Bob Dresden here. Getting ready to 4 cycle the Firestar II > with the HKS. I'd like to keep the trial and error part to a minimum > if I can. Soooo, I'm hoping I can tap into this great knowledge base > we've got here. I've talked with Larry C about his install, got some > great insights into this endeavor. I'll be doing the type II exhaust > and horizontal carbs, 3.47 gearbox. I'm fishing for photos, hints, > what I'd do different next time, all this good stuff. Where do all > those oil lines go, any mounting options for tank and cooler, anyone > with a type II setup care to comment on noise level? I certainly > appreciate all replies. Thanks in advance. > > > Bob Dresden > Firestar 646F > > ________________________________________________________________________________
Date: Jun 19, 2010
Subject: Re: Kolb Flyer
From: william sullivan <williamtsullivan(at)att.net> There is a Kolb Flyer on Barnstormers. While I am not interested in buying it, I would like to know if anyone has ever flown one. It looks like a twin engine Ultrastar. I think the ad said 180 pounds. Any comments? John? Dennis? ................................ Bill, Years ago one was built by EAA Chapter 373 at Hagerstown, Indiana as a Chapter project. They were unsuccessful when trying to fly it above ground effect. Many prop changes and no luck. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jun 19, 2010
Bob, I don't know if you got much response. Not too sure that there are all that many HKS's out there. My prop clearance is only 5/8th of an inch, would like more, probably quieter, but that is what I have. Not real interested in cutting my Warp drive prop. So far I have 82 hours on the engine. If there is anything else that I can tell you, I would be glad to do so. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: Robert Dresden To: kolb-list(at)matronics.com Sent: Saturday, June 19, 2010 4:53 PM Subject: Re: Kolb-List: Bolding going where a few have gone before; the HKS So much for BOLDLY going anywhere.. 1 more question. What is the minimum clearance for prop to boom tube On Thu, Jun 17, 2010 at 9:54 PM, Robert Dresden wrote: > > Kolbers, Bob Dresden here. Getting ready to 4 cycle the Firestar II > with the HKS. I'd like to keep the trial and error part to a minimum > if I can. Soooo, I'm hoping I can tap into this great knowledge base > we've got here. I've talked with Larry C about his install, got some > great insights into this endeavor. I'll be doing the type II exhaust > and horizontal carbs, 3.47 gearbox. I'm fishing for photos, hints, > what I'd do different next time, all this good stuff. Where do all > those oil lines go, any mounting options for tank and cooler, anyone > with a type II setup care to comment on noise level? I certainly > appreciate all replies. Thanks in advance. > > > Bob Dresden > Firestar 646F > > > > > ________________________________________________________________________________
Date: Jun 19, 2010
Jack and gang, I was looking on the internet about a week ago just looking up Kolbs on another rainy day here and ran across this old picture of Homer in a Flyer. I sent this picture to John Hauck and asked if he knew anything about this one. John says he thinks it was a prototype from the mid 80s and is hanging in Homer's hanger. Doesn't look like it had a very good view out the front. Must not have worked out. Good for us Kolbers. Jack Carillon Akron Oh. FS II ________________________________________________________________________________
Date: Jun 19, 2010
- Jack- The Kolb Flyer that is listed on Barnstormers has twin Solo engin es.- I have no idea what your photo shows.- I did find references to th e twin engine Flyer from an old Ultralight News article.- Interesting rea ding.--I have no idea how common, or how successful they were. - ------------------------- --------------------- Bill Sulliv an ------------------------- --------------------- Windsor Loc ks, Ct. ------------------------- ----------------------FS 447 ________________________________________________________________________________
Date: Jun 19, 2010
william sullivan wrote: > Jack- The Kolb Flyer that is listed on Barnstormers has twin Solo > engines. I have no idea what your photo shows. I did find references > to the twin engine Flyer from an old Ultralight News article. > Interesting reading. I have no idea how common, or how successful they > were. > > Bill Sullivan > Windsor Locks, Ct. > FS 447 > > * > > > * > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > Bill and gang, I'll try and send the link for the picture. http://www.ultralighthomepage.com/PICS/flyer.gif Jack Carillon Akron Oh. FS II ________________________________________________________________________________
Date: Jun 19, 2010
- Jack- I went to the FAA web site and looked up the N number of the plan e in your photo.- It is a Kolb Feather, circa 1984.- I never heard of i t.- It is also mentioned as a Twinstar.- No idea why, maybe experimenta l. -Very informative. - ------------------------- -------------------- Bill Sullivan ------------------------- -------------------- Windsor Locks, Ct. ------------------------- -------------------- FS 447 - ------------------------- ------------------------- ________________________________________________________________________________
Date: Jun 19, 2010
Pete As others have said "never seize" or what ever name you buy it by will work but as im sure you know I always drilled a hole in the plug and safty wired it so when the "never seize "was doing its job you didnt loose the ne verseized plug! yours C.-Chris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0AD isabled from crash building Firefly =0A=0A=0A=0A=0A________________________ ________=0AFrom: lhaggerty <lhaggerty(at)tampabay.rr.com>=0ATo: kolb matronics =0ASent: Sat, June 19, 2010 4:34:45 PM=0ASubject: Kolb-List: rotax 447 gear box oil plug=0A=0A=0AThe oil plug on my gear box was frozen when I attempted to change oil and in spite of using a quality box end wrench the hex head was rounded out during removal. The replacement plug from Leading Edge Air Foils cost me $27 plus shipping. Now I don't wa nt this to happen again so I am looking for advice on preventing re-occurre ============ =0A=0A=0A ________________________________________________________________________________
Subject: Kolb Flyer
Date: Jun 19, 2010
Bill, Yes - definitely a Flyer - but highly modified. This one with the geared Solo's would have enough power to fly very well; this is what Dell Cross had for power as I recall. In addition to the engine changes, it has a modified landing gear and of course . that nose! We never did that either. Dennis _____ From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of william sullivan Sent: Saturday, June 19, 2010 10:06 AM Subject: Kolb-List: Kolb Flyer There is a Kolb Flyer on Barnstormers. While I am not interested in buying it, I would like to know if anyone has ever flown one. It looks like a twin engine Ultrastar. I think the ad said 180 pounds. Any comments? John? Dennis? Bill Sullivan Windsor Locks, Ct. FS 447 ________________________________________________________________________________
Date: Jun 20, 2010
Bob, I've got an HKS on a Firestar. I bought it from Jerry Olinek @ Greensky Aviation & had him install it for me. I have the Type 5 exhaust and it's a quiet engine. the oil tank on mine is mounted above the fuel tanks. I would prefer to have it somewhere else, but the way my FS is set up with a BRS there is no other place it would work. If you have not purchased an engine yet, you may want to consider buying one from Jerry. He has done a few Kolb installs, is very knowledgable, and has advised a few other Kolb owners on doing their own installs. The prices are all the same whether you buy one from him or somewhere else, so you may as well get one from a dealer with Kolb installation experience. I've got about 103 hrs. on mine to date and it runs great. I've got some photos I'd be happy to send you off-line, and if you need any other info on my set up I'd be glad to share. Just email me direct, jdy100(at)comcast.net. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301795#301795 ________________________________________________________________________________
Date: Jun 20, 2010
Subject: RE: Kolb Mk lll doors
Have been flying with Bob my neighbor in his newly acquired Kolb MK lll, he is progressing very good....did some stalls, slow flight, 360 deg. turns around a point, climbs at full power maintaining a cetain airspeed and descents with different power setting maintaining a certain airspeed.... and one day just let him fly around the area looking at stuff he had a interest in.....I just enjoyed the ride...thanks to all for your input on proper use of flaps...the problem with the lexan popping in on the doors was because it was to thin....we riveted a extra bow in each door which solved the problem...will take a pic and post...was easy to do....when lexan needs replacing will replace with thicker and remove the extra bow....The Mark lll with the 912 80 hp performs very well and is easy on gas....I am very impressed....tis a joy to fly...to help support the Kolb Company we could give a demo ride to those that might have the need....jim swan Do not archive FIRESTAR ll 503 Michigan jswan ________________________________________________________________________________
Subject: Re: RE: Kolb Mk lll doors
Date: Jun 20, 2010
Jim S: 1/16" is normal thickness of Lexan for doors. 1/8" for windshield. john h mkIII .the problem with the lexan popping in on the doors was because it was to thin.... ....jim swan ________________________________________________________________________________
Date: Jun 21, 2010
Subject: RE: Kolb-List Digest: 3 Msgs - 06/20/10
Jimmy, what is a "type 5" exhaust? Sorry for my ignorance. Bob ________________________________________________________________________________
Date: Jun 21, 2010
Subject: Non certified fabric at ACS
Does anyone on the forum have experience with the non certified 2.7 oz. dacron Spruce is offering (part no. 09-00300). Better yet, anyone compared it with the 2.7 oz. Polyfiber fabric? The cracks in the Aerothane are starting to turn to peeled areas and at less than half the cost it makes doing a re-cover on Zulu Delta possible sooner than I had hoped. Rick Girard ________________________________________________________________________________
Subject: Re: Non certified fabric at ACS
Date: Jun 21, 2010
This is by no means a scientific response, but has been my understanding for many years. Manufacture and sales of virgin (unshrunk) polyester-dacron aircraft fabric is limited to one or a couple mills. A certain amount of lubricant is necessary during weaving to prevent burning the threads. The lighter and tighter the fabric, the more lube necessary. Thus HS90X was a very difficult to seal and fill all the damn pin holes. Biggest expense with polyfiber is its certification, just like other aircraft parts. That polyfiber stamp costs as much as the fabric. I have used generic virgin polyester-dacron with success. Would use it again if necessary. john h mkIII Does anyone on the forum have experience with the non certified 2.7 oz. dacron Spruce is offering (part no. 09-00300). Better yet, anyone compared it with the 2.7 oz. Polyfiber fabric? The cracks in the Aerothane are starting to turn to peeled areas and at less than half the cost it makes doing a re-cover on Zulu Delta possible sooner than I had hoped. Rick Girard ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 3 Msgs - 06/11/10
Date: Jun 21, 2010
Kolber's I just wanted you to know that on Saturday I finally had a chance to take my Kolb Firestar to the airport, and after about three or four taxies, the first being a bit squirly, I finally got to feel what it is like to take off and land a Kolb. I did several touch an goes, and buzzed a local corn field, and I also got to see what aileron flutter is like also, didn't care for that much. My landings were pretty good, the transition wasn't too bad and it was really incredible, I loved it and am now looking forward to getting back out again soon. I remember all the advice you guys give me and I remember what Mike Fisher told me about aileron flutter and it was like you were all in the plane with me. Thanks and happy flying. Greg ________________________________________________________________________________
Date: Jun 21, 2010
I remember all the advice you guys give me and > I remember what Mike Fisher told me about aileron flutter and it was like > you were all in the plane with me. Thanks and happy flying. > Greg What do you intend to do about the aileron flutter problem? john h mkIII ________________________________________________________________________________
Date: Jun 21, 2010
At 10:05 AM 6/19/2010, william sullivan wrote: > There is a Kolb Flyer on Barnstormers. While I am not interested in > buying it, I would like to know if anyone has ever flown one. It looks > like a twin engine Ultrastar. I think the ad said 180 pounds. Any comments? Bill, the Flyer was the predecessor to the UltraStar. Twin Solo engines, though I believe earlier versions had some different smaller engines. It didn't fold like the US, had a two spar / two strut wing design unlike the single large spar and single strut of the US. I've seen a few but never flown one. I'm told it couldn't quite maintain level flight on one engine, but could cover a lot of ground in the shallow descent. -Dana -- Never write device drivers on acid. ________________________________________________________________________________
Date: Jun 21, 2010
Rick I always use uncertified...works just fine.. You can scrub it with mek or acetone to clean the mill goo ... I have used the 1.7 or 8 and the 2.7... Herb At 12:36 PM 6/21/2010, you wrote: >Does anyone on the forum have experience with the non certified 2.7 >oz. dacron Spruce is offering (part no. 09-00300). Better yet, >anyone compared it with the 2.7 oz. Polyfiber fabric? The cracks in >the Aerothane are starting to turn to peeled areas and at less than >half the cost it makes doing a re-cover on Zulu Delta possible >sooner than I had hoped. > >Rick Girard > > ________________________________________________________________________________
Date: Jun 21, 2010
Herb, John, I was more concerned about the quality of the weave and if it shrinks uniformly. As it turns out this is the same stuff that they sell for use as peel ply in composite lay ups. I've used a bunch of it for that and it's free of any kind of sizing, at least all that I've ever gotten from them. I'll have to check what I have in stock. I may have enough to cover the wings left over from vacuum bagging projects. Herb, did you use the lighter weight for ailerons and flaps? Rick Girard On Mon, Jun 21, 2010 at 4:34 PM, Herb wrote: > > Rick > > I always use uncertified...works just fine.. You can scrub it with mek or > acetone to clean the mill goo ... I have used the 1.7 or 8 and the 2.7... > Herb > > > At 12:36 PM 6/21/2010, you wrote: > >> Does anyone on the forum have experience with the non certified 2.7 oz. >> dacron Spruce is offering (part no. 09-00300). Better yet, anyone compared >> it with the 2.7 oz. Polyfiber fabric? The cracks in the Aerothane are >> starting to turn to peeled areas and at less than half the cost it makes >> doing a re-cover on Zulu Delta possible sooner than I had hoped. >> >> Rick Girard >> >> >> >> > > ________________________________________________________________________________
Date: Jun 21, 2010
Herb, did you use the lighter weight for ailerons and flaps? Rick Girard =================================================== Realize you asked Herb. Flaps are vulnerable to FOD and prop drumming, plus scrw drivers and other tools and stuff. I use heavy fabric on flaps and ailerons. I have 18 year old/3,000+ dacron on my flaps that are still serviceable. john h mkIII ________________________________________________________________________________
Date: Jun 21, 2010
Rick I used the 2.7 for all surfaces when I rebuilt my Kolb MkIII back in the mid 90's. Used 1.7 or 1.8 (which is it?) for all surfaces on my Firefly..Same for my N3 Pup...and Ultra star...Herb At 07:27 PM 6/21/2010, you wrote: >Herb, John, I was more concerned about the quality of the weave and >if it shrinks uniformly. As it turns out this is the same stuff that >they sell for use as peel ply in composite lay ups. I've used a >bunch of it for that and it's free of any kind of sizing, at least >all that I've ever gotten from them. I'll have to check what I have >in stock. I may have enough to cover the wings left over from vacuum >bagging projects. >Herb, did you use the lighter weight for ailerons and flaps? > >Rick Girard > >On Mon, Jun 21, 2010 at 4:34 PM, Herb ><herbgh(at)nctc.com> wrote: ><herbgh(at)nctc.com> > >Rick > > I always use uncertified...works just fine.. You can scrub it with > mek or acetone to clean the mill goo ... I have used the 1.7 or 8 > and the 2.7... Herb > > >At 12:36 PM 6/21/2010, you wrote: >Does anyone on the forum have experience with the non certified 2.7 >oz. dacron Spruce is offering (part no. 09-00300). Better yet, >anyone compared it with the 2.7 oz. Polyfiber fabric? The cracks in >the Aerothane are starting to turn to peeled areas and at less than >half the cost it makes doing a re-cover on Zulu Delta possible >sooner than I had hoped. > >Rick Girard > > >========== >arget="_blank">http://www.matronics.com/Navigator?Kolb-List >========== >http://forums.matronics.com >========== >le, List Admin. >="_blank">http://www.matronics.com/contribution >========== > > ________________________________________________________________________________
Date: Jun 21, 2010
John, Good point, I was thinking of making them as light as possible so I could decrease the balance weight. Plan B, use tubing instead of steel rod and pack one end with lead. I understand the flaps and ailerons on the B-36 were framed with magnesium. I suppose that's a little extreme, though. :-} Rick On Mon, Jun 21, 2010 at 8:07 PM, John Hauck wrote: > > > Herb, did you use the lighter weight for ailerons and flaps? > > > Rick Girard > =================================================== > > > Realize you asked Herb. > > Flaps are vulnerable to FOD and prop drumming, plus scrw drivers and other > tools and stuff. > > I use heavy fabric on flaps and ailerons. > > I have 18 year old/3,000+ dacron on my flaps that are still serviceable. > > john h > mkIII > > ________________________________________________________________________________
Date: Jun 22, 2010
I experienced it on my first flight around the patch as I was turning final, and when it happened I remembered what Mike Fisher tokd me about it being caused by air speed. I looked at my asi and it was at about 90 mph, (I don't know how accurate that 90 is), but I just did what Mike said and cut the power and pulled back on the stick and it went away instantly. After that for the rest of my flights I kept it at about 75 max in a dive and had know issues at all. I may put counter balances on in the future but as long as I control the air speed it is not an issue. Greg ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Monday, June 21, 2010 6:12 PM Subject: Re: Kolb-List: Re: Kolb-List Digest: 3 Msgs - 06/11/10 > > > I remember all the advice you guys give me and >> I remember what Mike Fisher told me about aileron flutter and it was like >> you were all in the plane with me. Thanks and happy flying. >> Greg > > > What do you intend to do about the aileron flutter problem? > > john h > mkIII > > > ________________________________________________________________________________
Date: Jun 22, 2010
Aileron counter balance weights make the problem go away permanently. They are available from Kolb Aircraft. Give Travis a call. They are simple to install, and excellent insurance.. Aileron flutter is not always initiated the same way. Excessive air speed is the most common, but turbulence, power settings, and attitude may initiate aileron flutter at much slower air speeds. I can speak from experience based on my three Kolbs that all suffered from aileron flutter until I installed counter balance weights on the mkIII. Prior to installation of counter balance weights, I was changing out rod end bearings constantly, snugging up linkages, and praying. The present rod end bearings on the mkIII have nearly 2,800 hours, are a little sloppy, but never a hint of aileron flutter since the addition of counterbalance weights. john h mkIII ----- Original Message ----- From: "Greg" <gtaylor35918(at)roadrunner.com> Sent: Tuesday, June 22, 2010 5:55 AM Subject: Re: Kolb-List: Re: Kolb-List Digest: 3 Msgs - 06/11/10 > > I experienced it on my first flight around the patch as I was turning > final, and when it happened I remembered what Mike Fisher tokd me about it > being caused by air speed. I looked at my asi and it was at about 90 mph, > (I don't know how accurate that 90 is), but I just did what Mike said and > cut the power and pulled back on the stick and it went away instantly. > After that for the rest of my flights I kept it at about 75 max in a dive > and had know issues at all. I may put counter balances on in the future > but as long as I control the air speed it is not an issue. > Greg > ----- Original Message ----- > From: "John Hauck" <jhauck(at)elmore.rr.com> > To: > Sent: Monday, June 21, 2010 6:12 PM > Subject: Re: Kolb-List: Re: Kolb-List Digest: 3 Msgs - 06/11/10 > > >> >> >> I remember all the advice you guys give me and >>> I remember what Mike Fisher told me about aileron flutter and it was >>> like you were all in the plane with me. Thanks and happy flying. >>> Greg >> >> >> >> >> What do you intend to do about the aileron flutter problem? >> >> john h >> mkIII >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jun 22, 2010
Subject: RE: Kolb-List Digest: 11 Msgs - 06/21/10
I was interested to know about the type five exhaust... but also about the answer to the question presented by John about what would be done about aileron flutter??? Thanks... Bob ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 11 Msgs - 06/21/10
Date: Jun 22, 2010
> I was interested to know about the type five exhaust... but also about the > answer to the question presented by John about what would be done about > aileron flutter??? > Thanks... > Bob My experience to kill aileron flutter: A-Immediately reduce power to idle. B-Pull back hard on the stick to help kill air speed. C-Try to load the ailerons with left or right stick. Now...depending on how rapid and violent the aileron flutter, you may not be able to accomplish B and C. Why? If the ailerons are fluttering violently, so is the control stick. The stick will be wiping out the cockpit laterally from lock to lock, or from thigh to thigh. You probably will not be able to grab it until you get slowed down a bit. Kolb pilots should always be aware of what their airplanes are doing. Despite the draggy nature of Kolbs, they accelerate quite rapidly when the nose is dropped with power. Install aileron counter balance weights and you will not have to remember A, B, or C. john h mkIII ________________________________________________________________________________
Subject: fluttering control surfaces
Date: Jun 22, 2010
> My experience to kill aileron flutter: > > john h > mkIII (subject line changed to reflect the proper discussion) Hey John=2C On the subject of flutter=2C do you have elevator balance? Have you ever experienced elevator flutter in any way? Plus=2C same thing for rudder=2C any fluttering or looseness? Mike Welch _________________________________________________________________ The New Busy is not the old busy. Search=2C chat and e-mail from your inbox . http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_3 ________________________________________________________________________________
Subject: Re: fluttering control surfaces
Date: Jun 22, 2010
For some reason those big ole elevators have not been a problem. However, many Kolbs of all models seem to experience rudder flutter. Normally, rudder flutter starts very subtly, barely noticeable, until one looks at the wing tip and sees it shuffling fore and aft. It can and will get violent if allowed to progress. Normal preventive procedure is keep feet on the rudder pedals with a little pressure. I have my own theory of why, and how to fix, but will not go into it now, typing with two fingers. john h mkIII On the subject of flutter, do you have elevator balance? Have you ever experienced elevator flutter in any way? Plus, same thing for rudder, any fluttering or looseness? Mike Welch ________________________________________________________________________________
Date: Jun 22, 2010
Bob, HKS offers 5 different configurations. Here's a link http://www.greenskyadventures.com/EnginePricing/HKS/optionDecissions/FactoryExhaust.htm Bob Dresden Firestar 646F On Tue, Jun 22, 2010 at 11:32 AM, Bob Green wrote: > > I was interested to know about the type five exhaust... but also about the > answer to the question presented by John about what would be done about > aileron flutter??? > Thanks... > Bob > > ________________________________________________________________________________
Subject: New guy with repair questions
Date: Jun 22, 2010
Hi, my name is Chris I recently purchased a Firestar and have been spending a fair amount of time on the list gleaning information. Well all was fine with the plane until last Friday when I hauled it on my open trailer down the freeway. I have been hauling it about 15 miles on the weekends to a small uncontrolled airport without issue. But on this longer and faster trip I managed to break the fuselage tube just behind the support stand I built. I have ordered a replacement from Kolb (Travis is a super guy to work with). I was just wondering if anyone has any tips or tricks when it comes to replacing the tube. Here are the pictures of the damage. Thanks Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302108#302108 Attachments: http://forums.matronics.com//files/rightside_175.jpg http://forums.matronics.com//files/leftside_109.jpg http://forums.matronics.com//files/bottom_180.jpg http://forums.matronics.com//files/top_993.jpg ________________________________________________________________________________
Subject: Re: New guy with repair questions
Date: Jun 22, 2010
I was just wondering if anyone has any tips or tricks when it comes to replacing the tube. Here are the pictures of the damage. > > Thanks > > Chris I'm guessing you never built a Kolb. Removing the damaged tailboom is a major task. Replacing the tailboom is a major contruction project: -cutting to correct length. -fitting to fuselage and installing the H brace. -rigging and installing the tailsection. Recommend you obtain a Contruction Manual and Plan Sheets for that project. Good luck. Still scratching my head how a tailboom could be destroyed like that. john h mkIII ________________________________________________________________________________
Date: Jun 22, 2010
Hi Chris How about a picture of your support stand. I agree with John...I'm scratching to figure this out. L On 6/22/2010 7:59 PM, John Hauck wrote: > > > I was just wondering if anyone has any tips or tricks when it comes to > replacing the tube. Here are the pictures of the damage. >> >> Thanks >> >> Chris > > > I'm guessing you never built a Kolb. > > Removing the damaged tailboom is a major task. > > Replacing the tailboom is a major contruction project: > > -cutting to correct length. > > -fitting to fuselage and installing the H brace. > > -rigging and installing the tailsection. > > Recommend you obtain a Contruction Manual and Plan Sheets for that > project. > > Good luck. > > Still scratching my head how a tailboom could be destroyed like that. > > john h > mkIII > > ________________________________________________________________________________
Date: Jun 22, 2010
-- Chris- Two years ago I crashed my original Firestar on landing.- M y fault, ignorance.- The first thing I can suggest is to take lots of pho tos of everything from all angles.- including parts that are not damaged. - Next- never throw anything away until the job is completely done.- Me asure and draw all items- make your own "blueprint" in terms you will under stand quite a while from now.- Pretend you are doing it for somebody else . - I drilled all of the rivets carefully, so as not to do any further dama ge.- Take a magic marker, and mark the tail up, down, front, rear, right and left.-Mark the front, as well as the tail. -This sounds like overki ll, but some markings may be erased or confused later on.- - Get help to hold the various parts when removing, as they could twist. - Take the tail feathers and landing skeg off first.- The cables can be pulled to the front, and tucked out of the way.- Drill the front support ring rivets before pulling out the cross bolt.- There is an "H" brace wh ere the cross bolt is- you can see the rivets.- Remove the rivets after t he tube is out.- I poked the brace out with a 2 x 4.- - I cut the tube with a circular saw and a carbide blade, and was able to use the old tube parts for a template.- Remember that the template now h as offset holes due to material thickness.- I found that the holes were a bout 1/2 the rivet diameter high, due to material thickness.- The "H" bra ce was inserted with a 2 x 4, with a couple of pieces of scrap wood screwed to each side.- A rope was passed around the brace, so I could pull it ba ck if needed, and the wood scrap was for turning it.- - The rear was drill by leveling the cage, and centering the template to top dead center.- Again, the side hole were about 1/2 hole off.- - This may not be the factory approved way to do it, but it worked well f or me.- Good luck, and wait for others to check in. - ------------------------- --------------------- Bill Sulliv an ------------------------- --------------------- Windsor Loc ks, Ct. ------------------------- --------------------- FS 447 ________________________________________________________________________________
Date: Jun 22, 2010
John, Larry, I've written on this before in advice to those bringing a new-to-them Kolb home. The answer is quite simple, excessive G loading on a point. In another life I was the junior engineer at a company that produced collater / stackers for the printing industry. I got tagged to spend two days at the Yellow Freight packaging lab in Kansas City filming the results of typical stresses involved in over the road transport. One of the things that struck me and stuck with me is that a simple tar strip, that tha-thump, tha-thump seems innocuous when riding in a car but it's murder on packaging. It can represent a 6G load if the package isn't properly damped. Apparently in this case it wasn't. Rick Girard On Tue, Jun 22, 2010 at 6:41 PM, Chris_A <50calibercruiser(at)cox.net> wrote: > > Hi, my name is Chris I recently purchased a Firestar and have been spending > a fair amount of time on the list gleaning information. Well all was fine > with the plane until last Friday when I hauled it on my open trailer down > the freeway. I have been hauling it about 15 miles on the weekends to a > small uncontrolled airport without issue. But on this longer and faster trip > I managed to break the fuselage tube just behind the support stand I built. > I have ordered a replacement from Kolb (Travis is a super guy to work with). > I was just wondering if anyone has any tips or tricks when it comes to > replacing the tube. Here are the pictures of the damage. > > Thanks > > Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=302108#302108 > > > Attachments: > > http://forums.matronics.com//files/rightside_175.jpg > http://forums.matronics.com//files/leftside_109.jpg > http://forums.matronics.com//files/bottom_180.jpg > http://forums.matronics.com//files/top_993.jpg > > ________________________________________________________________________________
Date: Jun 22, 2010
Thanks for the replies. No I have never built a Kolb, but I have plenty of experience with similar projects. I bought the firestar out of an estate sale and this plane was the love of the owners life. I have all the original plans and manuals and have been studying them. I will take a picture of the support and post it ASAP. Travis said the same thing regarding the damage, first time he has heard of it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302120#302120 ________________________________________________________________________________
Date: Jun 22, 2010
Hi Chris, Those are some sad shots of your a/c. As I haul my firestar 6 or 7 thousand miles a year on a open trailer @ 65 to75 mph I would sure like to see a picture of your boom stand.Depends, I might even want to pull the paint off and dye check that area. Sorry I don't have any tips for you but I think it should be simple job to replace the tube. Frank Goodnight Brownsville ,Tx ________________________________ From: Chris_A <50calibercruiser(at)cox.net> Sent: Tue, June 22, 2010 6:41:22 PM Subject: Kolb-List: New guy with repair questions Hi, my name is Chris I recently purchased a Firestar and have been spending a fair amount of time on the list gleaning information. Well all was fine with the plane until last Friday when I hauled it on my open trailer down the freeway. I have been hauling it about 15 miles on the weekends to a small uncontrolled airport without issue. But on this longer and faster trip I managed to break the fuselage tube just behind the support stand I built. I have ordered a replacement from Kolb (Travis is a super guy to work with). I was just wondering if anyone has any tips or tricks when it comes to replacing the tube. Here are the pictures of the damage. Thanks Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302108#302108 Attachments: http://forums.matronics.com//files/rightside_175.jpg http://forums.matronics.com//files/leftside_109.jpg http://forums.matronics.com//files/bottom_180.jpg http://forums.matronics.com//files/top_993.jpg ________________________________________________________________________________
Date: Jun 22, 2010
Subject: Re: Ko lb-List: New guy with repair questions
Hi John and all, Just idle thoughts , could someone tell me why it would not be ok to sleeve the broken area with an inside and a outside sleeve , say 18to 24 in long, T4 or T6 , plenty of rivits and whatever thickness you are comfy with. Frank Goodnight Firestar 2 Brownsville, TX ________________________________ From: John Hauck <jhauck(at)elmore.rr.com> Sent: Tue, June 22, 2010 6:59:28 PM Subject: Re: Kolb-List: New guy with repair questions I was just wondering if anyone has any tips or tricks when it comes to replacing the tube. Here are the pictures of the damage. > > Thanks > > Chris I'm guessing you never built a Kolb. Removing the damaged tailboom is a major task. Replacing the tailboom is a major contruction project: -cutting to correct length. -fitting to fuselage and installing the H brace. -rigging and installing the tailsection. Recommend you obtain a Contruction Manual and Plan Sheets for that project. Good luck. Still scratching my head how a tailboom could be destroyed like that. john h mkIII ________________________________________________________________________________
Date: Jun 22, 2010
No way I would ever be comfortable with a spliced tailboom. May be an acceptable method of repair, but I would not go that route. Too much riding on it for me. Where I play is very unforgiving for dumb mistakes. john h mkIII ----- Original Message ----- From: frank goodnight To: kolb-list(at)matronics.com Sent: Tuesday, June 22, 2010 8:50 PM Subject: Kolb-List: Re: Ko lb-List: New guy with repair questions Hi John and all, Just idle thoughts , could someone tell me why it would not be ok to sleeve the broken area with an inside and a outside sleeve , say 18to 24 in long, T4 or T6 , plenty of rivits and whatever thickness you are comfy with. Frank Goodnight Firestar 2 Brownsville, TX ------------------------------------------------------------------------- ----- From: John Hauck <jhauck(at)elmore.rr.com> To: kolb-list(at)matronics.com Sent: Tue, June 22, 2010 6:59:28 PM Subject: Re: Kolb-List: New guy with repair questions ________________________________________________________________________________
Date: Jun 22, 2010
-or just chop it at the break and use a short tail :) Seriously, if you could find tubing that telescoped internally in a perfect fit, stuck in about a foot, it would be strong enough. You might run into a little problem with the legal angle even though it is experimental. BB On 22, Jun 2010, at 9:50 PM, frank goodnight wrote: > Hi John and all, > Just idle thoughts , could someone tell me why it would not be ok to sleeve the broken area with an inside > and a outside sleeve , say 18to 24 in long, T4 or T6 , plenty of rivits and whatever thickness you are comfy with. > > Frank Goodnight > Firestar 2 > Brownsville, TX > > From: John Hauck <jhauck(at)elmore.rr.com> > To: kolb-list(at)matronics.com > Sent: Tue, June 22, 2010 6:59:28 PM > Subject: Re: Kolb-List: New guy with repair questions > > > > > ________________________________________________________________________________
Date: Jun 22, 2010
Frank and all, A properly designed spice could provide 100% of the tube strength. The Laser had a spliced wing spar. The root spar was 5=94 x =BC=94 wall. The middle spar was 5=94 x 1/8=94 wall and the outer spar was 5=94 x .049=94 wall. The 5=94 x 1/8=94 wall spar was turned down at the end so the 5=94 x .049 was a nice slip fit. A splice could be made in a similar way. A short section, say 12=94 would be turned down on both ends leaving a short ridge in the center to butt the fuselage tube against ' this would ensure the splice was centered. Stresses at the tail are much less than further forward ' except for improper trailering! The very end of the turned down section would need to be rounded so as to not stress the fuselage tube ' that is how we did the Laser. The rivets would transmit the torsional loads and the splice tube itself would take up most of the bending strength even without rivets. The length of the splice would need to be determined, 1 ft might not be enough, but 2 ft would be too much =85 so somewhere in between. This is an easy problem to solve using Cosmos FEA and Solidworks. The splice would be made of 6061-T6 and the turned down section would be stronger than the 6063 alum the fuselage is made from. The rivet pattern would need to be engineered properly, another task for Cosmos. Dennis _____ From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of frank goodnight Sent: Tuesday, June 22, 2010 9:50 PM Subject: Kolb-List: Re: Ko lb-List: New guy with repair questions Hi John and all, Just idle thoughts , could someone tell me why it would not be ok to sleeve the broken area with an inside and a outside sleeve , say 18to 24 in long, T4 or T6 , plenty of rivits and whatever thickness you are comfy with. Frank Goodnight Firestar 2 Brownsville, TX _____ From: John Hauck <jhauck(at)elmore.rr.com> Sent: Tue, June 22, 2010 6:59:28 PM Subject: Re: Kolb-List: New guy with repair questions ________________________________________________________________________________
Date: Jun 22, 2010
The biggest problem would be finding telescoping sizes of tubing. For an internal splice you'd need 4 7/8" .058 or .065 wall. Not exactly a common size. Same for an external sleeve, 5 1/8" .058 wall isn't listed anywhere I can find either. Better to just go the route you've started down and replace the tube. Since you've already been in touch with Travis, have him send you a new "H" frame. You'll play hell trying to match up the rivet holes in the old one and leaving them unfilled and drilling new ones is just asking for a place for cracks to start. Rick Girard On Tue, Jun 22, 2010 at 9:02 PM, robert bean wrote: > -or just chop it at the break and use a short tail :) > > Seriously, if you could find tubing that telescoped internally in a perfect > fit, stuck in about a foot, it would be > strong enough. You might run into a little problem with the legal angle > even though it is experimental. > BB > > On 22, Jun 2010, at 9:50 PM, frank goodnight wrote: > > Hi John and all, > Just idle thoughts , could someone tell me why it would not be ok to sleeve > the broken area with an inside > and a outside sleeve , say 18to 24 in long, T4 or T6 , plenty of rivits and > whatever thickness you are comfy with. > > Frank Goodnight > Firestar 2 > Brownsville, TX > > ------------------------------ > *From:* John Hauck > *To:* kolb-list(at)matronics.com > *Sent:* Tue, June 22, 2010 6:59:28 PM > *Subject:* Re: Kolb-List: New guy with repair questions > > * > > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > * > > > * > > * > > ________________________________________________________________________________
Date: Jun 22, 2010
Rick: The biggest problem would be to find 5" tubes that were precisely sized. These tubes are manufactured primarily for irrigation pipe. Circumference of a 6" tube can change a lot from one end to the next. Getting a tube to fit a ring can be a pain in the butt, when factoring in the ring can also be a tad too small The biggest problem would be finding telescoping sizes of tubing. For an internal splice you'd need 4 7/8" .058 or .065 wall. Not exactly a common size. Same for an external sleeve, 5 1/8" .058 wall isn't listed anywhere I can find either. Better to just go the route you've started down and replace the tube. Since you've already been in touch with Travis, have him send you a new "H" frame. You'll play hell trying to match up the rivet holes in the old one and leaving them unfilled and drilling new ones is just asking for a place for cracks to start. Rick Girard ________________________________________________________________________________
Date: Jun 22, 2010
Hit the wrong darn button before I finished writing my response. What I was trying to say was no two tubes, 5" and 6", are created equal. No two ends of one of those tubes will be the same size. john h mkIII ________________________________________________________________________________
Date: Jun 22, 2010
Hi Frank, I saw a Drifter that had the boom tube spliced...looked good...was done by a experenced repair man....but it was a neat square cut on the boom tube with a sleeve inside that was quite long.....looked to me like it would be ok....but in Chris's case the boom tube looks to bad to be spliced....I agree with John H. best to replace the whole boom tube....will be interesting to find out how this happened.....bad deal....Jim Swan Do not archive FIRESTAR ll 503 Michigan jswan GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825 ________________________________________________________________________________
Date: Jun 22, 2010
Hi John and all, Just idle thoughts , could someone tell me why it would not be ok to sleeve the broken area with an inside and a outside sleeve , say 18to 24 in long, T4 or T6 , plenty of rivits and whatever thickness you are comfy with. Frank Goodnight Firestar 2 Brownsville, TX Hi Frank, I saw a Drifter that had the boom tube spliced...looked good...was done by a experenced repair man....but it was a neat square cut on the boom tube with a sleeve inside that was quite long.....looked to me like it would be ok....but in Chris's case the boom tube looks to bad to be spliced....I agree with John H. best to replace the whole boom tube....will be interesting to find out how this happened.....bad deal....Jim Swan ________________________________________________________________________________
Date: Jun 22, 2010
Subject: re: fly in lunch planned for thur (24th) Plainwell, Mich.
(61D) Gang, some of us are planning on meeting thur. the 24th at 12 noon mich. time for lunch at the restaurant on the field at Plainwell, Mich 61D weather looks ok....everyone welcome..there will be several Kolbs there..Jim Swan Do not archive FIRESTAR ll 503 Michigan jswan GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825 ________________________________________________________________________________
Date: Jun 22, 2010
When splicing a tube like that, a common method is to use a piece of the original tube, split lengthwise just enough so it will squeeze down into the original tube. Not as strong as the original in torsion, but a similar outside sleeve 180=B0 apart would handle that and then some... though close to the tail where this damage should normally be much lower stressed than farther forward. Based on the pictures, it appears that it's cracked around the bottom.... correct? In this case it looks as though the tailboom was forced upwards aft of this. Where was the support relative to the brek? Rick, I feel stupid. I've wondered how one would replace a tailboom and match the rivet holes. I never thought of the obvious, replace the H-section with a new undrilled one along with the tailboom. -Dana At 10:36 PM 6/22/2010, Richard Girard wrote: >The biggest problem would be finding telescoping sizes of tubing. For an >internal splice you'd need 4 7/8" .058 or .065 wall. Not exactly a common >size. Same for an external sleeve, 5 1/8" .058 wall isn't listed anywhere >I can find either. >Better to just go the route you've started down and replace the tube. >Since you've already been in touch with Travis, have him send you a new >"H" frame. You'll play hell trying to match up the rivet holes in the old >one and leaving them unfilled and drilling new ones is just asking for a >place for cracks to start. -- Why did the chicken cross the Mobius strip? To get to the other, er, um.... ________________________________________________________________________________
Date: Jun 22, 2010
Here is my boom support. When I loaded the firestar the pipe insulation was still intact. The way I secured it was: wrap a towel around the tube then with the tube in the straddle I would wrap a ratcheting strap around the tube and straddle and tighten it up to the point that the foam would start to compress slightly. Then ratchet the base of the straddle to the floor of the trailer. The break occurred immediately after the rear straddle arm. It's pretty clear the tube was bouncing enough to chew through the towel and foam. But the straps were not loose at all. Thanks for the input, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302162#302162 Attachments: http://forums.matronics.com//files/sdc11758_215.jpg http://forums.matronics.com//files/sdc11761_102.jpg ________________________________________________________________________________
Date: Jun 22, 2010
I did toy with the idea of repairing it and my thought was to take a piece of 5" O.D. .125 wall 6061 T6, and make a "coupler" out of it by turning the ends down .052 so they would slide into either end of the cut tube and leave the center of the coupler untouched so that when everything was slid together the O.D. would be flush. Then rivet the ends. But I've already got the new one paid for. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302163#302163 ________________________________________________________________________________
Date: Jun 23, 2010
Greg, Whilst not (yet) being a Kolb owner/flyer, I would suggest you take this 'flutter' problem real, real seriously. Flutter can lead to structural failure, and not just of the aileron but of the whole wing ! That's going to really spoil your day ! There are plenty of videos on YouTube that demonstrate how quickly it can escalate and it doesn't take much imagination to see the potential consequences. If it were mine, I'd get those control surfaces balanced so that any flutter potential is way outside your flight envelope. David. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302176#302176 ________________________________________________________________________________
Date: Jun 23, 2010
I don't see any problems with the boom support design so the reason for this odd break is probably one of two things. 1- The trailer is designed (sprung) for a much much heavier load than the Firestar weight which will result in the "springs" not actually springing at all. Like a hard tail Harley, no springing but the seat coils (boom tube foam). 2- The boom was stressed and strained already from repeated "hard-tail" trailering or some other incident before you acquired the Firestar. If the trailer is at fault, you need to fix or change the trailer before hauling your Firestar again. Ideally, the trailer should be a light duty one with a load capacity of not over about 1,000-1,500 lbs. max, less is better. If your trailer is a heavy duty one, then at least reduce the trailer tire pressure to get some extra springing from them. When I hauled my second purchased Firestar from SC to NY it was in a big heavy dual axle trailer but I reduced the tire pressure to help compensate. I also supported the tail boom as close to the ventral fin (tail wheel rod/spring) as possible to reduce the "overhung" load arm to a minimum and the boom support had about three inches of foam rubber before compression and about 2" thick compressed from the static boom weight. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302181#302181 ________________________________________________________________________________
Date: Jun 23, 2010
Thom, Chris, Looks like the point that generated the failure is the weld where the saddle tubes attach. Even with the pipe insulation the design has a very small contact area. Then consider that the attach tube for the folded wings is 2 feet or more behind the end of the boom support. Say each wing is a 25 lb load at that point, X 2 is 50 lb., add the tail weight as another 15 lb., say, and you have 65 lb acting on a 2' or greater arm. Now multiply times 6 and you've got 790 lb cyclic load (that tha-thump from the tar strip, expansion joints or washboard (concrete or asphalt acted on by big trucks will washboard just like a dirt road)) acting on that small contact point. Once a dent is created (you can see dents in the picture bottom_180 at both the failure point and also at the forward saddle contact point) failure follows rapidly. Rick Girard On Wed, Jun 23, 2010 at 5:45 AM, Thom Riddle wrote: > > I don't see any problems with the boom support design so the reason for > this odd break is probably one of two things. > > 1- The trailer is designed (sprung) for a much much heavier load than the > Firestar weight which will result in the "springs" not actually springing at > all. Like a hard tail Harley, no springing but the seat coils (boom tube > foam). > > 2- The boom was stressed and strained already from repeated "hard-tail" > trailering or some other incident before you acquired the Firestar. > > If the trailer is at fault, you need to fix or change the trailer before > hauling your Firestar again. Ideally, the trailer should be a light duty one > with a load capacity of not over about 1,000-1,500 lbs. max, less is better. > If your trailer is a heavy duty one, then at least reduce the trailer tire > pressure to get some extra springing from them. > > When I hauled my second purchased Firestar from SC to NY it was in a big > heavy dual axle trailer but I reduced the tire pressure to help compensate. > I also supported the tail boom as close to the ventral fin (tail wheel > rod/spring) as possible to reduce the "overhung" load arm to a minimum and > the boom support had about three inches of foam rubber before compression > and about 2" thick compressed from the static boom weight. > > -------- > Thom Riddle > Buffalo, NY (9G0) > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > Tennessee Prop 64x32 > > > I am always doing that which I can not do, in order that I may learn how to > do it. > - Pablo Picasso > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=302181#302181 > > ________________________________________________________________________________
Date: Jun 23, 2010
Hi Cris, One thing you might want to consider if your tail boom has not already shipped , is to have kolb position the new H section and drill a few pilot holes in the boom like they do when they ship a new kit.save a lot of work. Frank Goodnight firestar 2 Brownsville , TX ________________________________ From: Chris_A <50calibercruiser(at)cox.net> Sent: Tue, June 22, 2010 8:14:13 PM Subject: Kolb-List: Re: New guy with repair questions Thanks for the replies. No I have never built a Kolb, but I have plenty of experience with similar projects. I bought the firestar out of an estate sale and this plane was the love of the owners life. I have all the original plans and manuals and have been studying them. I will take a picture of the support and post it ASAP. Travis said the same thing regarding the damage, first time he has heard of it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302120#302120 ________________________________________________________________________________
Date: Jun 23, 2010
As John says, the only way to stop the rudder from fluttering is to keep your feet on the pedals - or build yourself a counterweight for the rudder similar to what Kolb sells for the ailerons. Here's mine - takes a LOT of weight to balance that big ol' rudder. Especially if you stick the rear nav light on it - which I would put somewhere else if I had to do it over. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302203#302203 Attachments: http://forums.matronics.com//files/rudderbalance_174.jpg ________________________________________________________________________________
Date: Jun 23, 2010
Subject: Re; Fluttering control surfaces
- Question:- Could control flutter be moderated or corrected by adjusti ng the ailerons slightly down.- For example, when neutralized adjust the tail end of them to be about an inch down, to tension them against the air flow.- I realize that it would create a little drag, but a 103 spec aircr aft doesn't need extra weight. - ------------------------- ---------------------- Bill Sul livan ------------------------- ---------------------- Windsor Locks, Ct. ------------------------- ---------------------- FS 447 ________________________________________________________________________________
Date: Jun 23, 2010
Rick, good point. I hadn't considered he might have supported the wings on the tail. That is only a convenience for pushing it into a hangar, not for transport. In a trailer you should either remove them and hang from straps on the walls or, if left attached, hung from the ceiling. Put a buffer strip on the nose to take the shocks. I trucked my wreck, including one good wing, in a big Uhaul truck from Phoenixville, PA to Rochester, NY. No damage. BB On 23, Jun 2010, at 7:46 AM, Richard Girard wrote: > Thom, Chris, Looks like the point that generated the failure is the weld where the saddle tubes attach. Even with the pipe insulation the design has a very small contact area. Then consider that the attach tube for the folded wings is 2 feet or more behind the end of the boom support. Say each wing is a 25 lb load at that point, X 2 is 50 lb., add the tail weight as another 15 lb., say, and you have 65 lb acting on a 2' or greater arm. Now multiply times 6 and you've got 790 lb cyclic load (that tha-thump from the tar strip, expansion joints or washboard (concrete or asphalt acted on by big trucks will washboard just like a dirt road)) acting on that small contact point. Once a dent is created (you can see dents in the picture bottom_180 at both the failure point and also at the forward saddle contact point) failure follows rapidly. > > Rick Girard > > On Wed, Jun 23, 2010 at 5:45 AM, Thom Riddle wrote: > > I don't see any problems with the boom support design so the reason for this odd break is probably one of two things. > > 1- The trailer is designed (sprung) for a much much heavier load than the Firestar weight which will result in the "springs" not actually springing at all. Like a hard tail Harley, no springing but the seat coils (boom tube foam). > > 2- The boom was stressed and strained already from repeated "hard-tail" trailering or some other incident before you acquired the Firestar. > > If the trailer is at fault, you need to fix or change the trailer before hauling your Firestar again. Ideally, the trailer should be a light duty one with a load capacity of not over about 1,000-1,500 lbs. max, less is better. If your trailer is a heavy duty one, then at least reduce the trailer tire pressure to get some extra springing from them. > > When I hauled my second purchased Firestar from SC to NY it was in a big heavy dual axle trailer but I reduced the tire pressure to help compensate. I also supported the tail boom as close to the ventral fin (tail wheel rod/spring) as possible to reduce the "overhung" load arm to a minimum and the boom support had about three inches of foam rubber before compression and about 2" thick compressed from the static boom weight. > > -------- > Thom Riddle > Buffalo, NY (9G0) > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > Tennessee Prop 64x32 > > > I am always doing that which I can not do, in order that I may learn how to do it. > - Pablo Picasso > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=302181#302181 > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > > ________________________________________________________________________________
From: "Kolb Aircraft" <customersupport(at)tnkolbaircraft.com>
Date: Jun 23, 2010
We are unable to install the H section in the boom here without the matching fuselage cage on hand. New wing spars we do but not tail booms. Travis Kolb CO. ----- Original Message ----- From: frank goodnight To: kolb-list(at)matronics.com Sent: Wednesday, June 23, 2010 8:48 AM Subject: Re: Kolb-List: Re: New guy with repair questions Hi Cris, One thing you might want to consider if your tail boom has not already shipped , is to have kolb position the new H section and drill a few pilot holes in the boom like they do when they ship a new kit.save a lot of work. Frank Goodnight firestar 2 Brownsville , TX ------------------------------------------------------------------------- ----- From: Chris_A <50calibercruiser(at)cox.net> To: kolb-list(at)matronics.com Sent: Tue, June 22, 2010 8:14:13 PM Subject: Kolb-List: Re: New guy with repair questions ________________________________________________________________________________
Date: Jun 23, 2010
New Guy, If you measure the distance between the forward most axle of the trailer and the rear axle of the towing vehicle,you will have found the smoothest riding spot in your trailer at the halfway point.Arrange the load so you place the boom support as close to that point as possible.The gear legs protect the rest of the load from shock,(if you anchor the tires, not the frame, to the trailer floor) and spring the trailer as close as you can to the actual weight you are carry ing Anything placed over the axles will take a beating. Take a look at George Alexanders trailer section on his web site. G.Aman Mk3C over 20,000 miles trailering Kolbs damage free -----Original Message----- From: Chris_A <50calibercruiser(at)cox.net> Sent: Wed, Jun 23, 2010 12:38 am Subject: Kolb-List: Re: New guy with repair questions Here is my boom support. When I loaded the firestar the pipe insulation wa s still intact. The way I secured it was: wrap a towel around the tube then with the tube in the straddle I would wrap a ratcheting strap around the tube and straddle and tighten it up to the point that the foam would start to compr ess slightly. Then ratchet the base of the straddle to the floor of the traile r. The break occurred immediately after the rear straddle arm. It's pretty clear the tube was bouncing enough to chew through the towel and foam. But the strap s were not loose at all. Thanks for the input, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302162#302162 Attachments: http://forums.matronics.com//files/sdc11758_215.jpg http://forums.matronics.com//files/sdc11761_102.jpg ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jun 23, 2010
> As John says, the only way to stop the rudder from fluttering is to keep your feet on the pedals - or build yourself a counterweight for the rudder similar to what Kolb sells for the ailerons. > Richard Pike Hi Richard/Folks: Nope. Keeping feet on pedals and counterbalance weight is not the only way to cure rudder flutter. I said I wasn't going to explain how I corrected my rudder flutter problem because I am still typing with two fingers until the bone heals in my right hand, and it takes me 90 forevers to knock out a short email. Rather than use an oversize counterbalance weight, my fix is clean and simple, and allows me to fly my mkIII with feet on the deck and off the rudder pedals if I wish, and I do quite often on long cross country flights when I get tired and/or uncomfortable. I use two rudder peddle springs on each pedal. This effectively does the same thing that additional foot pressure does to prevent rudder flutter. Quick, cheap, and clean. john h mkIII ________________________________________________________________________________
Date: Jun 23, 2010
Thanks for input everyone, I did trailer it with the wings attached to the boom. How do you guys with open trailers deal with the wings? The trailer is pretty light weight, I'm not sure what the rating is though. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302218#302218 ________________________________________________________________________________
Date: Jun 23, 2010
HI Chris and list, Sorry for the misinformation. Travis thanks for the correct info. Frank Goodnight ________________________________ From: Chris_A <50calibercruiser(at)cox.net> Sent: Tue, June 22, 2010 11:38:05 PM Subject: Kolb-List: Re: New guy with repair questions Here is my boom support. When I loaded the firestar the pipe insulation was still intact. The way I secured it was: wrap a towel around the tube then with the tube in the straddle I would wrap a ratcheting strap around the tube and straddle and tighten it up to the point that the foam would start to compress slightly. Then ratchet the base of the straddle to the floor of the trailer. The break occurred immediately after the rear straddle arm. It's pretty clear the tube was bouncing enough to chew through the towel and foam. But the straps were not loose at all. Thanks for the input, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302162#302162 Attachments: http://forums.matronics.com//files/sdc11758_215.jpg http://forums.matronics.com//files/sdc11761_102.jpg ________________________________________________________________________________
Date: Jun 23, 2010
Morning Bob B/Gang: Trailering a Kolb ain't rocket science. July 2000, Nell and I pulled a 24 foot box trailer 3,742 miles from Titus, AL, to Muncho Lake, British Columbia, to retrieve my broken mkIII. Before I left home I had to visualize what it was going to take to get my airplane to Oshkosh, and then to Titus, AL. I loaded up with 2X4 studs, hand saw, deck screws, drill motor, carpet remnants, and tie down straps. When we got there we had to rig temporary gear under the mkIII because I had wiped the main gear off in the crash. Hung the wings on the trailer walls with the leading edges in carpet lined cradles, loaded the fuselage, built a cradle for the tailboom out of 2X4's and secured about midway with the tailwheel on the deck, chocked mains and secured everything with ratchet tie down straps. Pulling on the Alaska Highway and northern Canadian roads was dusty and rough. The trailer sucked in glacial dust that ate up the brand new lexan, but there was no other damage from trailering from many, many miles. If secured and towed improperly, you can tear one up in a matter of miles. john h mkIII - Bored in Alabama. I trucked my wreck, including one good wing, in a big Uhaul truck from Phoenixville, PA to Rochester, NY. No damage. BB ________________________________________________________________________________
Date: Jun 23, 2010
> Thanks for input everyone=2C > I did trailer it with the wings attached to the boom. How do you guys wit h open trailers deal with the wings? The trailer is pretty light weight=2C I'm not sure what the rating is though. > Greg Greg=2C I've been listening to everybody's advice opinions=2C etc. All seems lik e pretty good info. Rick G. analized the math behind what happened. Thank God your boom broke on the trailer. That concentrated stress he mentioned could have set up a weak point that may well have broken in flight!! Did you get the "H" frame? You absolutely positively need a new one! Tr ying to use an old one will possibly set up your plane to a potential crash . IMO! When you trailer your plane=2C as has been said=2C the weight of the wing s should NOT be joined onto the boom tube. For trailering=2C here is the boom support I built. Note=3B each wing ha s it's own cushioned=2C pivoting=2C long pocket. The boom support itself is a 36" long piece of 8" diameter of PVC water pipe (available free from 99.9% of your local water department). The PVC pipe was cut lengthwise=2C and closes firmly with som e latches. I padded it in a couple of layers of carpet foam rubber=2C then wrapped in some nice upholstery fabric). My boom tube is support by 36" o f tightly fitted foam (and NO wing weight). My design is taken from Uncle Craig (on this list)=2C with my own modific ations. If you need more photos=2C let me know. Mike Welch MkIII _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAUEBAQEAwUEBAQGBQUGCA0ICAcHCBALDAkNExAUExIQ EhIUFx0ZFBYcFhISGiMaHB4fISEhFBkkJyQgJh0gISD/2wBDAQUGBggHCA8ICA8gFRIVICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICD/wAARCAHCAlgDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDgkmvR G4kl1lUxyJrKOdc/8AGfxqmwsmDG5XT275vNGdD/AN9djVmCxmUNs0e5Xjraau/6BmAIqSEX0JcK viGAAdUkhmA/A7s1ialK3Om4ZIJNH3dlt9Rktm/Ifyq7bJd+U5gXUMDo1tqSTj8pKBdXJDLNf6iV x/y96V5g/HaoqkW08sxnk0J2/wCnrTGhb/vonigLGhJ9se3InbU2welxYRXA+n7vmqLxWCxh5LfT UYHlptLltj/30KSBrJtywf2QxI4Frqktux/Afyq9At4Ym8mPUgMZBt9SSf8A9GGgCos1uVUwXVqG xjbba1LH/wCONxV//iaMFZX1Voz/AHZLa4U/nyaa8t0YCtw+sEL2nsoJl+nyCqjw2TRhmt7PIP35 dEljJ/4EppDsTSQIbjFxZxuxPW40EsfzT+lKGs4VO2XT4fYG4s/5EiofNs1CmO5sVI42pqtxbEf8 BPSr8L3nmq1vcXRVu9vqcUo/8iDn8adwOp8J6XdPGviCYZ021DSI66lJOk7D+EK45GfftXSaHbSe OJZNd15zB4atHztYY+0sDwo9R/OtvTtAGpvbvquswz+H7OFQdrgPckKMoQMY56469utR+JNYW4jW 2tYVs9Pt8+XBGgCj3wO9O6irsybuzE8S6uLuNbe1i+y6fbArBBGQAo9T6k1f8E6BBHBHrk6B5JuY QcHaPU+9efajdSXN00AQKinrjBNeveDFRvCdgGBOAw/8eNYptyux2sjeYldzMQCfambmKAsRhhUj DfE5IwT+tV2KllXI+XFasktQQAylZZCF9Rz+VU59Z0uHxGNBi3G7eMvuOMAgZ2j3xzVt7i3t4Wlu JEgjxnzJWABx9a8ol1eyk+K8d/LexxWcRZfOLYX7mOtJ6B5Hpu35dv3iR+ZrJ1pXZAirMyshBWNJ PmHcHYGBHsyMK07TUdMv2B0/ULa7YdRFICR+FZ3iK3sLyxkFzdRW+0cEiNiT/wACH9RQ1oF0eG/F GYR6FYwecjCNmUQllJQZHAUElR7bY1/2a8i1PUWnk3RTyqSArRS9TwM5b+LoOuDwPQV6n470e/1C 0jgsrm1eMSFpFW7OI8cZZMBUB9RXBR+Brpt08+pwLAoy0yo7J7jcQMn6ZqLNkNamFCX8zcei/wBz GD+Aom3bmCQbs84xmuytvAulskNxPrc5Lp5iRLFtkdB/GFOcL7nFdBex6T4YtpbS8ty9wxCeROdz o3YMwGF9MYP51hKlNu8f8irLqzzjSdLbUhM73MUCwrly5+YdsFTzz6jinW1hFNeXENzcxJDEhCuo 3b2Y8BR64/LH0rubmCGzEVzf6FEk5JBtYo1m2cZBdz047Dn6dK6TRdBvprG2u3gR5pEM7RW1u6iC Ikqo8vB3ytgkKcADBOc8WqUrtt/IejWiPKbXRrxGkkg0i7uEY8PIDEnXjk49u9RzeCtbKm6upLSx iPO6aboPbGc17paeCvE1/pFtLH4d1A315M4/0qH5bWADCkj7u5iScHGAvbINV9F+DPi6TWLjUdet Y7aaNsx7tUzFMcnllBLYHXbkZ78cHeMUhOL7Hjdr4MS9tv7Sk1yztbTdsWds7T22jOM/gK6Ox8FW 02mpDd6nevaKzSI+zy1kyBuKDJyMIOeBwOeK9Yufgpc6pra3PiXxVpMmn8H7OI2eRB3VGG3aP0Hp XRar4E8HXEk7P4uubFJ2USrZ7Fby14jhVmztjUAAKBzjJzWgrJbtHjOm+CdFJe4tbEvbW5AmuLuY lYyc7RgdSSOByTz6GtW31DSPP/suw0oyvuSOPzYgA7kNjanfqRz/AHq9XtdL+GGl6QdKiimvInff KzMFaVx0ZigHI5xjHU+prkPG76Vp3hiwtfAnh7yJ1vY9zqrzSLGEYYUsSQN23pQo63C62TuWLO1b TtPRtRk33MULHyoolMSvk7V24xnkD0BB612GgaSF0WG7aPTroMoZxcR/dJ6gNzjnjpTtO+H+teKf C1j9p037BP8Au5JPteUUkYzwPm9a73SPhTpFjqj6nf311eTu6yGMOUjyMYyM5bp3NDTb02Kjotdz M07TLaRYoltptNd5BtMDFl+62Nu3IHXnIFSaRpniE61rOnqYpxb3CNmX925R4wQeBjse1enW9tBb RiOCFY1AxhRUa6farqUuorGVuZo0ikcMRuVSSuRnHG4/nVqPcLo5GXwQl0/mXFtarL/z0XIYf8CA zT7bwVd274GsM0X9yQbyPo3X8812uB6Un6Vasuhm9dzl38NTJESLtW2g/wAB5rK8P2d3rPhqw1eL yk+1RCUxtkFT3H55rvc9Kw9A0u60LRLXSRLFcRW+4B8FDtLFgMc9Acde1O67BbTcyjpGpxsR9mDZ 7q4qjcQXUBJuLaZF7kISP0ruWkHTPNQSTAd6LQe6F7y2Z494h8L6Drql2MdrenpIvDMfcd/515Vr vg/U9EkLzwmS3P3Z4+VP+H419QXttY3akXNrFLn+8oNczd+EvD8ocJamLeMHy3PT05zxVKnTfVr8 f8iXKp2T/D/M+Xb5TFZSOoXcgyGKg7fz+gqvuuxbwyzzzSnYOWxuI+gr3jV/hdpd5DJHbzlFcYKu v9R/hXI6r8ONWhG6CJZtvG5DuyPp1pSwza9ySf4fmEa1vji1+P5HnFt9mN4HM3nhDu2j1+h5rbkv Gj8P3ExcrPqN2saAD+GNcsOPd0/Kob3wvdrJtubM+YOAfusKpXltrFnaxwyrK8MWTEjjGCep984H 5VzTo1IfFFo3hVpy+GSZZgj1CVD50sKRDIPnMDj8Ov6UyS6s7SVBBN5wBy4wVT6D/HI+lZRvYnkC Ts0Un92Tj8qftNc92jeyZ1tv4oCxBbKGKyb+/Eu5v++jlv1r3P4aaZY2ttpmqXbmS81O1mnaRl6g SIFGT7YP518tGP5idvPqK9g8NSPF4Zsb/S7+Swu7dAGQktHIf4mKMcHII5XHQ1vSldmc42Wh9LNe 2caZyuBXN6x4htb1pNCtYYbiSZMTeaMxxIe7DufQV5S/ji6ghaPVYwjHpNCd0bf1X8fzqro2txW1 vJPJIHlnkMkj7vvenNdHumGp22kW50mxivvC2oeRKYwk1pdkywsR1AP3k5z0OPatWD4kQpMlnrFs +l3ROP3hzE5/2XHB/HFeZ2/iEWt1cIbhRFId4AHTPX/GmXXiCxnR7ec+cjj5lYDBpOSLtfc9K1rx OF+z3cfJgmBPf5T8p/nn8K4R9bvvDV1qSWEg+yPG9wkTHACnqR7qe3piuWnuzZQD+zZm+zkc207b kx7Hqv8AKsvVtbttT0cWc8LQ3KsBHhjzzzyOowP5VLqIpQ6Mx/B2six8cwXUina7SoxI65XHP1rq NFa/0rXbhtJ1D7KrE5DDMbjqAR/hXCpasIXuEjcPEwk6cgHg/wAhWpHqV2bdArYI5JHeoVS5bp2P UY/GjI4h1Jfs8wb7wbdG30P9DTrjxhaxx/NN0bNeP3d1dSKd1weexNZpun2eXK5dQeMHkVXORynq Oo+MITd215ExMkBIbp8yHqP5GrT+NIYIEdnIZxkZbtXkILA745DIoPI7gVWvr0XN47QMWQHC89BR zhyHo+oeLLG9VorpFmTPG45I+lclcNZzSE20m1T2audJnLAhT+AqzFbXkifu4nzjIGOpqW0ykpLY 2pdb1m0s49OZxNp0jBZSzcxoTyynsR19KwLe2M1xLEsTuzIcZOSSORyfXFadnZaxgr9jd0/ukZq/ /YurIY7m0tpYpQwPI4GDWcnc0jG3QyjdXAthZyZCr0DdqfBd3FurKkhAbkiodQiun1B5LomLI5JH TFSQaV9pSF4pJ3E3MZSBzvHTj8qpSJcNR7X87dZj+dN+085Z92fetuDwfDhWudU8g/3ZLeYH/wBA q8PCGkAx41pZmZsELE4IHc8gZp3DlZzKurco2fbPNPfUYfJWEH5o/vD0Jrobvw5odv532LUoLlol PM06wfMP945I/CpdD8FDxRaNf2Mtmk8AxJDJMQ0mPTjp25/Oi4+XzOUW+iBwRz2or3rTfhj4Vgso Xvo0e5KAuNxIB7jjrRTFZHzzBZ27NmPSvD85IyPIuTGSfbCGpobCQMQmgTL72uquvr0G5ajjEM7k OfDFzkdGXYW/H5sURacrONug6HLnj9zetGf0TrWYyxHBcxvxY6/CfWO8jkx/305z9KVJ7yN/+Pvx DEMfx2cUo/Hah4pq6ZIkgx4cuRj/AJ4aow/mwpBDNHNgaZ4gjweNl6jH9ZDQANeAsRLqYIPa90aQ g/UjbVVH0t3YSTeGXJH8dqYD+eTir6yXKTZ+0+JYj728b/yQ046g8cvz63foM/8ALxpDEfoq0DKt tBYuWFvbaW7Hp9l1eWIn2AAxVqC2uwriCw1RR/0w1NXH/j7VC13aSSET6zosq9xcaWy/zkpi/wBk 7yfN8LSHpwfJP5gmgC8x1IQkOPEKAe1rMv8AImqLQRvkXKJIfW80BnP/AH0mBVmPSwF8+PSrHZt3 eZa6vMgx0zwmMe/SrktollEuW1KFpEEuBfPtCdmy2ePrgntmgTaRhu+nxf6ubRI37qsk1ifyByKt 2l5Dc2zWjXbW8iTLJHMl7LfI/BBGWGQM4/WtG2F7LfxWInvLz7UpdEn2SJHF3csAMDrjPJx0HWrs Xh3X5SY9N0S5lhTiIR2zKr9sliMKvsMn3HWna5N/IihguAc3MqzPnh16MO1et+F9T02w8K2gu7+C 3lUv8juAfvE9OtcZY+AvEP2eNr21ityIgzGa4WMNIRwo+ZiFBPPchTyMjEkPg6DS3guLnxZpVrMp 3vIZi7LzyqAAAcd85/qKJm2zt5PFuhpE/lXclwRjiOJj1+7zjHPauW1Xx5Gm61023mS8bIzLGAVH c7SePq2BUp13wFYOguPE8V40MYjijgts7MDqMswzuywwB1A6ACsOS/8Ahtp1jJO2keINQikcb5pQ 6K7HsWCrn1xmmyd+pztzPd6p5t1c3Us6owV5DJkbjnCjjk8HgccdabPoXkeRvtRLPcjMcDP845Iy 2eE5B45P0rqLDxfbzIi+FPhm08cTsY2dTJhgATySctgZ9cCtefxL8Qk0y51C20/w/pqwR7miMo87 6bQM5+uKnlRV7L+kcfa+HNcnZV0vSZZ5dvMsEJWJD6A4+b6sce3eu403wTftJc2+oaYEtMCJJZZT E8vXMhw3HsuMdM9zXCQ+NfiVrEct0b+5S0hk2SyW1s0gjPXqOP5V0FppcGtSeefihLerzutJT9hk /BiHBPtj8RVJX2Fe2ti5ffDmxlaM3Op2trGmT9la5JiB7Y2jJHrnkj+LPNZ0vgHwWb+3vde8a28i Q8i3tofLUYOdqkOAF9gtYjeE4tS8V3Gm/bL6LT4JtktxNI02xQcE7k+U55wTgV3Fv8L9A0ueHWdH e28Q26kh7G5KsJFwc4dcjcPTbzimoi5vQzPtPwv0+6lu5tZvdTu5JmuJXcofMfduUHC52qcYXOOO Qayodd+Gen3Rn0/wrcX9y7b99xNNLls53YZsZzznFd14qt/Blr4Uu7238LrYXbQH7Pc24XY7sQv3 kPTBP3wPpXN/CrTVTUL7WithPeLGiIlwCdqsWzhgTsPy8/KeD271yi5nfcit/iQgkjTRfB9pEzEI hMSKR6cnpW9e698WINNe9GkQWtuitI2JkO1QMk4DVseILTw9qYkTU9CWwumClJ7dQyM2TkMyYbB4 GSox1rMHhuaKzkbTbu+gsJ02m1upwdxPUDA5FUosxnUUdG7nJ6f4m8d6/qcdgusw2gf78sh2on4n qfQCuq1L4e+LTpjXK+Lpb25I3CFItgYdTggnt7c1f8N2+qaODYWWgi/jkJLqBncT6nkdh1r0Cz8H 3ExjuU36C+DmO2cH0/g5T9KfL3Y4SUlovvPHtO8CXSXYbxJdXcthMmYLyzk8xM8feGCcYyeg6Vnv 4H8Qapr8tv4V0ue5s45Si3dz8sRQHgknAb8K+mdP0CwsEIVWlcuZC0hz8x6kAcDJyeB1JrVCADAA AHalY1tHseb6N8LbOxDG+uUmJwQI7eMEcc5LA121joek6cyvZ6fBFIo2+YsYDY+uK08CjNOw7sQL S8UZ5pCQKYhaTIppamlwKLAPLUwtUTSj1qu82O9MCy0gHeoHnAqo8/vVSW47ZpgXJblVye9YOr+I LXS7GW8u5NkcY6DksewA7knjFJc3saOkckqq8pKopOCxwTgevAJ/CsHWII723McwztIdT3Rh0Yeh FAkzQ0jUNSudMS41eJLe6lYuYEOREuflUnucYJ9yaumXIrzGXxBqsmv2vhyKeOBoyJ7y7c7R5IPC r6O2CPoDXRXniq1tvkt0adsfeI2qP60XSHqdQxzWZdahawNsaUNJ0CJ8zH8BXJvqeq6tEdrOkZkS MuCEiTccDcevPuexroovGEHhFzpb+GYbO9hG13mlDO/+1kDoevBqbh6nj3xX+ImseHvEukWVrBLa xRMJruC5t1PnxkjAwwyBjd0NdbdfDnX9Ztf7Sm0m6XcoZdpTODyMKCePyqt8TrvT/iZpdvbajbW1 pc2r7obyFC0ij+JOTgqfT15roNK+IevaRoVhpFtcRyxWVulukjx7ncIoUFjnrxQ5trluCjFPmscF bfD4X2q/2dqWo22nQ/xPeRsMH0xjGfqRXar+z9ctZB9N8UW1ymPkSSAlG+jhiR+oqLU/HOpanE0N 8I5Aev8AoyZ/PGaz7DxTcaY5aylubbPXymIB+o6Guflibc7I0+GWm6PPJD41XVNPjDfu7u0VJYHH pnGVOfUU3WtAsbHSbW58J3l3caZB/o881yowrlmbcMAcEcDHHA9a6K38ZXGopNaXNzeXK3MRhEfn sgVm6Nhsg8/hzXl+n2/iS71x9KsIbdrZWJ5nCcZxkAnk+woaUdik+bRlz7O0qLI2ojZnHAxmozZw EuIr1YH9mGG+orK8QWlxp2pmyvp7nTpdxWJ7y2aKOYgZ+SQgKfz7VzGoWWpW5JmMxU/xo5Kn8RRz A4OLsdbL9miiljmcSSsjbZIH3DPbI6jn61oWGr+GZbFZJHZJ1HzRuCCp7g5rze2vLuFHt4b64gZz kSJMynPoSD0qkNQu4ZmdiHOckOKlsEemX/ifSdhiBij/AN5gDWE2v6MTsa9g598/yrl768itNOst 0aT/AGmNpmjQBjGPMZdp9+Mj2IrGM+m3iC3t9Oe1lZi3nOzPkemM4A/M1XKyeY7ObxJo8OHi1CR8 AqUVGwwP1q3p17BdWwFtdRyxsRjJwwya87vNPurNA00R2MMq45B/GnWplhZHhdkcYAKnBqC7vqek aqbfSrQXd4CYd4XI9SD2APpWI3iPw6V5gct9X/8AiBVKS7u7+0S01KV2jU7lZSOD6kd6oPo8vLQy JLH6r/UdqaBvsbB8Tacv+ogtFPYvBM38mFW9Fkt766uLxUtXZNu4JC6KM8c7jz0965YWDd5Yx/wK u48IeH7650O6uLW3aeKS5jgMkfIDcHH5Gqik3qS2+hoS388VwUURwgjp5KcH0zj0x3pFvb9gAt1I p/2G2/yrp5fCWp6xrNy1vYNDaPKxSaUbIwg4Vs/QDpXRaJ4NsdK1JY9WQ3qSDMFyv+qz3Vx2PoTw frVJJDd2cjoHh7WdYmf7KZVjdgZJnchTx39a9I0nwBpNivm3pN/OOfn4Ufh/jXWRiG38u0BVFClg qkBQBgf1qVGjyNpL/wC6M5ouK1jC1PwvpGtWJtr+zAYLtSSP5WX6EdvauLh8L3/hjWo7qSaeTSlD ZmtFy8LdmKenXOK9Wb1xu9MCmQk/aAOcDqMUrFc2lmcwdcbyxPeSx3tpj5by3GVb2YdjWHP8RvDi SeVPcSjHGwxnC+1afiXRbe3sdR1TTZ5dNl2uZREB5cw54ZM4z7jFeMyy6fewCK/WSS4zjzUQAoPc 5+b8qTY7K1z0TTPFHhy+vLjTLffcWVyMeWy7SmTg45+7zn2rh7PU7Xw74lvdS0yd5PIkMYjIG2RN /Kt9QB8w7gcek2j6bpdtrEF2sE8tvEkkzTfaV2/IjNhlCA87cYz3qjd2S3mnm9stPYSyH97tY/Ie v3fQ9apJtBpsei/8LW0DC4tLrOM4IHHt1orzCwsr+5gUWehfbChwzCOR2J98Nj9KKVpAkjF/4TrS JMCTT5mHQkwqR/Og+JvDMnMmmRAf7dsvNcE45LIgHPAYdP0p20qeQcepxio1Isd9/bHg5hlra2TP pEQf0FSLq3hF87Zthx/DNKn+Fec7j13E446//XqULEUOWw237mM5/GjULI9MW/8AD7oGXUplGOv2 5v6tVlLnTZD+612YEDotxGx/UGvKcRbDiNmfnLDoP0qa2AZSAvODwByf0o1A9bjewMTz3Pi42aIQ AZgjlj7BUJNWUv8AwebWL7TqOpX8oViws7HHmE9Dkjj8hXjcqsRxGUwc9P51KftHAmjd1XpnKkfQ 0XE+Y9Yh8U+D7eCS2tPCGp6mWbc/2uQEvj+8Bjj2xRJ4zeVFl0zwTokUowALhgzgDOOGHAGTxnjt XlccoDAiS4ibBwScn8xzVlJr6ZSp1Lzx/dkkJP5Hmmrkv1PSJPiB43MYWC7sNPK4HkxwFWP+7xg/ nWfqPiHxfe24nm8S3YiY7XyDEMnoAQpB6E9e1chbS6t5bK1zNbwR8szkkD0Az1J7D+gNO/tAvKds jBAuFXoT7nHBNPYlq53fhzQrzWbSbWtTutRv7eGUAWxZpkkUD5shHVs8gjoOOTzxa8Z6B4Og0VLz TbW3jui+3/RbtpAPXfFINy9PU4rkNO8Ty6XCVRY2z0JUqx7cOuCOPequr+JXv40EzybS27bI+8Zx jOeucUc0diXfZHc6FoZ0q3i1Wyu9Ke73OrRXcUlq+QduEkHU8DoRjn3rQ8TeLdUvdDj0/UbWeziM nSWRbiPK9RkDcOo+8x9e9eZ2/ifUbSEQQ3UwQ87D86n3IPr9KgutauGKh7dhnkmNSAfwo9ologab PbNK1/wsNGW0trURsoBElhdGJyy/ddlbapP4tVPxf4ym1DwzLp099HeMzhAZ7Xy5CuchlYYGflAI A/HmvHJrq7KIHtn2gAK/KkDtycj8qCNUlgUxgzL3UsCf50/aWE02eo+DPFtnoemSW32m8sndvM3R 4dWOApypB7gnoOCKs6jrej6jK93dWum6k+wpIUQxSMBnaQecMM9cj0PbHlEsGrQ2cVwI2Ecykqox KOpBBXkqeDxgHFRxW1zcW8kscgQD5WcBgEJ9c9KnnY7M6yx1Wazu2k0/VbiybGV2v0YHgHJGR17m tWTxpfC4U6ikcsoOROqmGU/8CGD+tc9eeBfEGm6DDrV5NFLYyv5YePJGcZ64xj3zWx4Z+Hmu+IPs UekC5uIJ2xNJ5WI7fscscqcehwT29armaEoN7DtT12e7s/swuJTbs/mlJG3fN1OD19z19a0vC2i6 zq80UVhHImxSgmC4wCSRg+oJP4GvT/CPwDNoTceLNVS6duDa2qkRke5b+QGK9l0rQtK0W1W302yj gQegyT+NaRV9yJReyPPdB8CX9vDG1yxu7kDHnXTHan4dT/Kupg8D6e8qz6tNJqEg6K3yRj/gI/xr rMUtW2EacYkEFrb2sKxW8KQovAVFwKmxS0nWg0CkzxQTTc0AOzSFh2pufWkzTAUmmlqaWqNmoAez 1C7nFBaoJHwKAGvIQKqSzhEZ3YKqjJJ7Ci4uYoYy80qRIP4nYKPzNcT4u1y1ufDWpWOm6hi6ngeN JY1LKmRgndwOmec0NgtTe0rW7XXNJTVLLJtZWcROf41Viu4exxRcSkKzdAOSa5e8vNT0LwjprWWn xWdn9nAgRWEshjVM5A6dMfiR61i2l8dS8Wvp0szXKRRsVEnzAEYGdo465qXIdiO31JX8YahrurPI Ba5s7C2Rgy7OC0uemWPHB4AxUl54lupiRbRpGD3JBP5n/CugvdBsLwpM0apMgxuVRgj0I7j9feuS v9Js4r9NPlmSxvJVJhySYpuezHlT7H8CajnG49mQyLdy2y6hJhhI7RCTO7kAEjPb7w/OjTlSS62y ruUq2cDPaursdIa38FzabemJpYbvzJsH/j0DKBknOM8cjnrjrXNzx/2XbzmQgzDgBTxjI71qpLl1 Is7kN5aQ/ZC/2Z1y5G5ZDsYYHUdM+9XptL1LxXpkmozXUVzNpkQRkdQZfK7HIHzAc9TkVmXupXuw W1zfO0X+sWFX3qC3PrgHnn3qfw74hfRdZhvV+aMfLLGejoeorByV7FruY6aesWd6Ej1QCnqYFO3D qfcAV1HivTYtM1GO6sW36dfJ59tIOhU/w/UVz3nIwwwDfUVLsUNZYtoyGYZx+NIEiYfJCGx15qRn DoqeYwVMhRnIHOeAaEDk7RKrfU7aLvoOyNLSbFbrTdWnjhCyWsaSAjt84H9aw1sBPIjW6RhpnYsX 4C45P8ia7rwjPYWtnrlvqNwlsbm2CRmU4DEEnGenpXFhwYXjUZ/eEqR+NXrYVkUi4kszZXUQubY5 zFJ8y/keKz5tIhjgVdOm+xxjpAUDR/THUfgRWg9uRJuB781HNKhfa2cDjIrHmZRyl/oFoiNJJpcs 0jktm2kPH0zx+GK5218P22ra1NaW+opaqirIft2ImAzhhz1I68Z4r0pGUB2DcAVTv9P0/U7LGoQJ J2U45H0PUVSkuozzbX9DlOr3t5ommyjSTMy2zIfMyinbu6k84z+Nc8klxbTA8o6cbWFep29vrWj2 32bS5be/slztt51AdBnPysMH8+PasnV7+PULc6fNpTw6jKVSMTKoGSQOGP8AOr0eqZPqjnrTVX/s /wCzvb/aoWO3Y4wF9s0JqEZVLX+x7KCQHl1ibeuPdmPXvxXX6f8ADjUrzTZ9Kk1nTdLvrKZrieO4 mOV4UIMqCMnk9cYYVjvoF9FYm6utLmtpIh94J8sgPcfzx+XpWbaTNEm0ZOoeKLeeGWxXwto0ZgSN ftCxSebIRnJJL47dh3rmW1+8tJfMs7WwtXAI3x2ke78yCavz2d41tPqP2Sb7IZjGLjYfLZsZwG6Z rj9XnYT+RE23HLEfyrVamTbSOktvEyyReRdotrIST9rtoU3k+rAjn86+kfg9qVjZfDCZL3Wlu7h7 ye5WUggtGI1GFyOSCp4GcGvkG0Z5MxOdxxkH+lfa3wh0a2n+BPh6y1CySdZjcytHImes8gB9uMVd rISd2rmn4b8W6dewR6XcmO1uIogDvcBGAA4Ge/I4roroWUul3K3EKT2uws6DBDAf5/lWKngxtKu5 bvTLeCeGRcPbXwGMZz8rnofrmqptPCF5HcW1wlvo99gqyONrL7rt+Vx9DWdma6LqeZeOLzV4782a 308lnEm6ATKGZQccEjrgDr716/4MuBP4Q0wSXIuJ1t03nOSMjIB/DFcFqtv4Ej1eOa91C7nSKfy3 iSUndFsOGycn7xH4Vp2Xjnwj4dtWtPDuhzGJjnDMzAt070lBJ3CUr2semMBt469hUlvBIZgVicgc 5CnFcQPEPxBvf+PDwylmh/jndEI/DOaP7L+Impqft3iC0sk/uwhnb+gq9BWZ0PiHR5tR0O5sFnht HlG3fNJgAZ5J715fJ4D8KaS+/WfF6ySOeIbWLn8yenuad4p8P3+maf8AarjxFeXbs+3GAg7+hP8A OvOkXz3Yy/vMHq5JpKzeiG7panTamdA08zf8I5qaTSSqYvLuTkx8j5gwABOAeCO/Wrnh/wAWQWWl SRz6bEb77Skgddwb5Mf+OsCy4z3NUvDOgf2vqiWEBjgLgksV6ADPau3f4VyS43akisOjLGcj9auz TuTdM5S/8c67DqgudJijskdTCdzcMN7MpIA4I3EUVo6r4FvdPYxalPv05h/x+wxFvKPq6jkfUZFF DbuPkufNJmEg5Cqc/wAI/wDr1IlyyoVZtynHG48frSLNHtz5Sg8dGOT+tML7/uxBBjoGJz+tYiJV uFRWCDDY++Cc/lmo2LEZIJzyTTCQRlST149KQoWAD5LHsOKAJfNXA3fgcf8A1qmiVSchsD6cnjtx VRY9zhd209SSvt9KsxyLE+x9kisc5Cj+ooAswNlmIZtvox46d+lUxqOpQ71F5MOeCJT0qeIx+ZgZ UHpu6fjWfcJ80hUA/PwBVJESZ7j8ELe18QWnidNZiW/mtoYJYGm5MY3MGx9flr0FfC3hy4Vlk0yI kEqQc/415p+ztMR4k8QWZH+u0p2A9drr/jXr0c0f2jzUJKSHaTg4yOKfKgcnoZA8BeFkmWa3sBby rkq6MTtOMZ2tle/pVG58E6krBtL8Syw9wkkSr/49Htx+VdkHXjk/lTgyeoosTc5u103WYNIitta8 JQeI4FlZvNS881u38E2P0NZFzZfD2DVLW4vdMvPDlzHKrqt3A0UZYHI4YFCP0r1vSiG00EHIEjD9 BTryJZGRXUMuMHI61DRSZ4J49sIpp7ZtMW2vbZleRmtFOAS2ecEgfhge1cLJa+TZBxEysAxztwQc eo4P416T8UtD02DUbGe10+G0kkjYsbdBGWIPU7cZNcMg1NbIvFqc5Xa2UkO4HjpQkjNtmTaNK7sJ JFQFsKduMj1OPw7Vsf2ZewoWkhhliB3YVlb8cAg/pWh4c8K+JfFdyUsNAa5RWG6eJEjVfq5A9ehN e96B8HmQJNr2pvxg+RaO4/BmZj+gH1rVBys8KuWtZNP0qCx0q9S9uQVYRbmSYBjghWzk9Bgehr0j wd8NPFd3OJtR0uCwsjGI0kvJHWcJuDbQinsRnDcdeOTXvelaDpWi26QadZJCq5w3LNz1yx5Oa0sU WK0OE0j4U+EtMuPtMtiLyY8lZT+6z6+WPl/MGu5igighWKGNYo0GFRFAAHoAKfRmqSSC7DFFGaQm mIUmm5pCaTNFgHZpCabmkyKdgFLUlITSE0AOJqlBqVtc6neafE+Z7NY2lGRxvBK/+gmrBcYPPSvN rbxRo2jeMvFd1d3G+SeWBYhCN+9Vi7EcfeJ6mk2NJanpLNjvVa4uYLaFpp5UijXqzsAB+JryHXfi 6FjdrKS3sY1P3ncSSE9MY6Dr3rijq2t+MbaW8svF2hWTJIYs6rdN5nAByqAYA596Lom9z2jU/Hmi WKv5UjXTKOdnCj6sa81174xNFL5EEywb+ggTecf7x4/KuOm8Ga1e20ttqfxG8KTrKpXct4ylcjHA CY/SsvVvBKxapBIPGGhm2WIRtLFcNJgj1VRu/Q0rsGvP8Ubn/CXPff6ZeZlyQoeaZjls9AWXHTBr 0Twl4u1S71OCwgvfM0+B1E6CzQrsYgLhsDAJIGeT1rxjw9YWd/rEdjL4h060hhQyB7yZ1SQ7gMDH IznPbpX0PBoVj4S+Hmp3E09utzdhZpLmHcqFuPLxuOcDr+JqXqEbrcwfEHiS51LWp4NNt4buG0tU gBMRkZHYgl0AHBGDz14HFclog1Gy8QzR2nh7R9ae4hErefPvCqp2nY2FKkkjIOa6TRjoGgm7li8c aHeyXJ3OJJnjI9gQSD+K965fxJrun22uDWdH1e1TUCFg8qIiUSjOSSVypHGMHDdKiVzRPzOyk1M2 sW+9+HFwmPvCw1Bm/IK1TrBoaXf9sXFlc2clt80kk900rWKbRiMbiR5pO499uexHFmy1qS28Ox32 uKmnzRLuuijH92eyL/00Ixn+5n16YdhrnhHxDp86a5q2m6daBysFk7kFR1LEDuT368VSTtcHLWxL Z+MPBep2H2K4GrpFCWxDDbs6DJOGY9WY5Jyce2BUVvqnhq7sriyvWkk2xsbaUxYaTbwNy5yv8PPN O04+CtEnmk0bx1pYWbaXhn3MOM4wwwR175qrrGq6RfWepajDPb3MlpEqtNbSCRRkkg54IBCsOQOQ tLXqGnRlY6F4c1GGOa08bWMF8UHm2twDhW7jcOR+Rrn7/TdR02RhKkc8I6T28gljP4jkfiBTfD2r 6Nf2tjqGs6hpryWN+S9kyANKpTG75hyMseM9VrRuvBvg4T+a3j3TrLeNwjaBoyPwyKlxvqhp92dD 4Tu4/E2gXHg67kAuVzPp0jH7sgGTH9D/AI1xM4mtp3hmDJJGxVlI5BHUVt2Hh7w3p97De2XxN05J oHDxuEOVIOfWul8beGNO8UWp8W6L4lsoY2AjumDERNMMc5H3c8daiUZWvYqPLe1zzwXJH8Qpwu/V h+dUr7TYLDSJZZdTll1BSojt0jDpKN2CVkViMDrzjpWFLPcLGwWTlTzxUa9R2Pd/hjb2uqWGvx3M UcyCONRuAO3O/keh4rzxp1tNQMbOMJIcg9xXbfAmWWXS/ETSNn54B+kleU+J5jaeL5FkkZYskMAe nJ5rb7NxGvqmoW2mF3uZQkeRgnvnpWXNqsLKj4Cq5wpcFck9uapeKEuJ9JtNRs72WJoQYH24IJ4K tgjtj9a4G2uvE0d2DfaoskQzwiKC3HfjismPzR6VFdgrIvGSMcUt1ciMIgxgCuc0aS4kKyzTMRJM I1GBzgEn+lYvizUL261FbPTrpreCA4dkYhnbv07UugI7YXnPKrTnuI7iPybi1juYz/Cy5rzb+0NS AIfUHjI/hLknHOPfoOtZ9rrOum5S0/tCZDg/PuJ3N2AI5rn9oug72PSxp1vbv5unztblsAxSkleO 2eoqO51CV1uLJ5Y459vPzBgpPTp+mcVgX1zdR6YYHujOYSEuZd5YmVgSUx6DGPbNUD4guZ08mbyy 8aYHYtkgcep5FTKrBv3uhadjpPA8Gl/2+LfxXqM9naeU7GNY0/eNxt3BgQM89vTmtK2sPg9pa79Q 8P8A9tam7M7ymSRIm5JG1NwAAGB+FcFFqV0bnM8Ue3aSAG2sqA9efbPAq9utNWBk0phJdKoY2hUn O3gnI9vzrpjWTXuoi2trnotv8R/DOhuI/D3gvSNOk+ba0Vqu/gZPIUn9a9AsJ/HviPRrHVF1qzsb S+gW4jCIxcIwBGRgYODXOJo/wRghDX93qRkdQWhkkKMmR90rt4rodL+Ifwj0O2+y6fLeFQApO4En ACjt6AD8K3g6j+Ih2X9Mm/4Qu9uW3ap4pv5wf4IgsY/rUM3hPw5pmp6VbvYSahJfTtEXuLliUCxO 5bHQ8qB+NWZfjL8NYVBMV8wY8fNjPb0qjdfGL4YSXtreS6VdTXFoWMLmYgpuGG4Ht61du4+ZLY4j xLoum/8ACwYvDnh0sbmVHeQSv8iOqhtgY8k7WB9siufhttUtvErWF5YCOGEAyCT7zNn7uPTHNegJ 8UPg9ba1JrkHg8f2k5YtdGQ7yW+9znvTrn4u/DKeSeeTwUkslxt8yRiSzbRhec54HAoskDknudXP qa+CzbwX0pfRrmQRQSsctasRkI3cpxweo7118LobcyIQylcgryCD3r5n8Z/Eiz1+wjsdODm1gkd0 S5XdIhIxjfn5gOcZGeeprofBnxvi0DwxbaHJ4etrmS23KJZCcsuSRnJ7ZA/Ci1xN2O0+I2f7LgG0 8sT+QryO1glKj9yefeu/m+PU8lysieFtKMXTDopI9Tyaki+Pt6GBi8P6WqjqFjVaai07jck1YufD FJIdUvJhAQwhCg5Hdh/hXqYvZx1Df99V5K37QGtdItH04emNpqJvj94oY4jsbFMeig/0rTUjQ9e/ tCQg/K+P94UV443x68Y9Qloo/wBz/wCtRRYZ80ebAqEI5XIHzDOfyzUTSgIYzKec/Lt60ySWNjjd 5pAPzDgVGBuOApyTjHrWBRPEJSNyLkjvjpU0kjiLJiwG/iIHPH0qq7ShVSTt/DgZH6U1MtgKfTjH /wBagQ8dQcHtxjp+lSLBIMbYzg88jOf0qNUaMlWt3Y9cAj/CqQupRevFswpXgY5/lRYLmvGjmUDZ 0xwVz+fFZlxdRW1zLtJZ2bJ2nAH0q7CJXdfLUjHqM4/Ss26tri51R7WCEyyuwwEXG447DFC0Jaue y/AS/H/C2IbVJNyXdhcIRn/ZDAf+Omvd5LePyjEqBVJJ47E8/wA6+Zfgha6hp/xs0CS4tZIlMskL 7h03Ruv8yK+pp02zSJjoxH6073BppK5BCR5Y4GRwfrU34CoVBWTPZv51etrK6u3CW0DyHPYcD8aZ JpaaSdOIXAxIf5CpZC7bcKd3oK2NJ8OTw25W7cJlt21OT0roLbTrW15ihG7+8eTRytjueTeJPhzq /i27sWjkitIIlYPLL1GSOijr+ldD4d+EXhXRIkN3C2qzr1a5HyZ9kHH55r0MClxT5UK/YZDDDBEs MEaRRoMKiAAKPQAdKkxSUGrEL0pCaM00nNADs0mabn8aTOOtMB2aTNAIIyDkUZoAQ1Th1K1n1W70 yKTN1aJHJKuPuq+7b/6AatFhXm6alp+ifGTxFdahcC2judMtGVnJw5VnUgDuRxQB6Rmmlvxrz7Uf iRC4MOiWUlxK3AkmGFH4Dk/mK5jUtV8UalbOb3UDEgjz5UR2Kfrj+tK6IlNR3PTNU8W6FpJeO6v0 MyjPlRne36dPxrzbxF8ZoLIMluILTPRpm3yH3Cj/AOvXm3xHeXQVgs7O5X7SDEJQzFVkcrudMjBA 7dR9a8al3+czupVix3Bs5U+hzSlKwoy51dHrPiD4uavquVSSeeNuB5h8uP8A74Xg/jXm2v8AiDVb 7TLkTXbhPlGyP5F5PoP617J8L9D0vV/ArjUrGG6AuZNhdclflUHB7V5L8RtHt9B1jVNNtWYwIY2T dyQGwcVkpOT1LlGyPMEmckZduvrU/nS44diB71SQ8/jVmIqGG7kdxWpFi1Dd3CAhJCM8n/OK7XVb eC31iGKGBIx5akhUHJPfpXDmMK+dpAPTNd7rI3eI0XDcRL0+n1osiWd/8IPCH/CQ+MoobmIPYWbm 6mLIDlQchTkd2OPpmvcPiVrUJ1Gx8PmFrhFU3E8SOi5J4UHeCCMZ4x3FVvhN4eHhbwguoXsbQ3F6 rzzljysYVWjByeOCT/wKvI/EPiG51fxnd6l5lwnmSEI8RcHb0AGGGelJJNltuMT1Pw02l38kyf2X bpthyN8dsSPmHZEDDrXK+IdW0zw/4lvNTslgE4t1ij8qMZVsg/KcY3cDntz3roLF7nTIZbWbU53u GRD591M4WEsOEIJIEpyAN3C4J64x4d4r8TWz+Jr6O1RhZp+5CuMMrJ1OMkHknn+dYTnCD1L5ny7n c+CbC68XahNJq2oO9hbuJDZmUkMx5wFJ4Hqa9aNlYqxxZ247f6ta+TtP8beJLSWz+dWt7M/KpBG8 Fw5ViCCVyAMZ6cd61V+JHiZbuG8k1Gc+SyusTfd+UYxj065OcnNZTxEW9RRny7H0fqN3pNjC8720 DsMKI0RQxPAwPzHXoOa0UWwksIY4Et2jmmeSQoAVbyxtAPr8zn8q+SZPE93qDPazXEubmZp3JJfM pGOQT93H8sdq+jtN1zR/D1tpWh6vfLb3sOnxGQSDAR3zI+49AS8hH/ATRTqKTeli1NsuajZWQ8b+ Gh9lgxm7cjyxg4gNeSXl1A10bW+hWWAfdIHzR/T/AAr0y+1q2n+Jmi2EalTBbXT7yRhiYW4HPXAB +jCvJNQIN++Rz/8AWrVtcuhad2LPpscIEsSRzQN0kC/ofQ12fw31yxsNUufD2sKh0PWV+z3CMMBG P3X9sHv+PauJtLqa3YlDlD95GGQ1WGiin/fWfysOWhPUfT1qU7aopl3xZ4buvC3iK60m4X/VN+7c DAdDyGH1FYSvsfDD5TwR7V69KB8RfhkJz+88ReH02yf3p7f19yP6H1rx+ZSG9xQ1Zj3Vz3b4HKIN D8QPIcBZ4gT7BWP9a8j8ehW8SyyjO1ixH0ya9P8AhNcK/g7UrSNsXN5eJBjvtCZLfka86+Jtutt4 smhQYVJHUfTNav4CVuVrEJcaCumyHm5iOzP94cj+VcJMhEm0jkEgiumuLhrWw0uZPvRkNTLmzjfx JHcAAW0g+1Z7Y6n9axe5S2GwoItW03TB/wAsImeT/fKkmuT1ZkGp3JJ2gzMo/Oui0ic3fihrhurK 7fTiub1Eobq5dpApMjYGM5yf/r1MnZXAxroj7YJBFEyohw2C20gYKgDvnnPPTitXRQbZZNauoyPs bmG1ikbG6QrnHbIUcn3qmFW+1VLO0MUc0uFCKWwuOPc56kknt26UusSrqc/9mWF7Hb22mQukQlUq Jum5h7s2QO1c8X9ogxYtXBv3kvXZ8sZAsQBOcZzzzn2qSTVYJ2jlhbybhsxlw/Udc46Anp171z10 skN0WglKg5QSocbjjBweuDn9aguYBE0ar95gDgHJ5/z+ta+yg9TO7OuUXV7cw/Z4riVzIWeRCdyZ JGB7DucV6f4M8bD4bwSXdtbQR6vehRJcuu9/KHJUL2BOCTgduRXmmm+In0Twy8kUBF2yeVECeFx1 Yj06Y965VryaYm4upWeRsjfnJc9wfaqjTS1iW3pc9N1/xhpuuapearcCSWa5kLyMHIVmJJwATkis B7zTbeZbuWwVt+GVEwQqkYG7n1559axYEjvtPdYwAkac7k3Y9+MHipbO8sbDUGhLSMqJhXYcSHHo R0/wo53r1Y7s7/T7Tw/fyi21E2toD91jF5o9slW4GeK7TTfhfpuratFa2msWbW4tpJJHjg4V9yqF xu54J5z2rxu31aMjylRSVHGBwmcZ+o7V9YfDSWwm0Bl0uVTao4A3D96/A+Z/Qk5PAxjFKnKbfvFK SOci+CFns2NqkH1+wj/4qra/Be3xt/tiPHtYqP8A2avWFAC8c/pS7h0PT0FdQ7ngUfwcnbQ5NVjv Xe6WWUm18kfNH5jD5c/xFRkcd/xrW0v4K+H59Nh1Oz1idknGUIgTOPQ5zg549q9nODn5e3rWJcr/ AGBdG8T/AJBly+biNRxBIf8AloPY/wAX5+tA7nhvirwpB4dvjaQX80wCqTuRF5P0FY0GmBl/4+ZV z6bf8K7P4jTrN4klCAbQyrx7LXP2wBCiqgrkz0Ow8I/DPTtd0aS7u9Tv4z5hRREyAEYB5yp9aZ4X +HWl6hLaQ3t7fKZbN5n2OqkSLMYyOVPGMfjXongRJx4TgMYRVLueVPPP1qloXnw+K1gAT5Fvou4/ 5bo//s1aWRMW+Upn4R+GRIqm61JgQSczr/RaK9CUSGTdIFGBgbeaKLIV2fnnvs2HlxN5ZIxl2yT+ QqclUZPs8yshABz3PcdKyWg8x1wxwpzTwvlOxywJO6ue/Q0stzRj+zyKSGiIHUbz/hTWjRRuM8Sj IGeeD6dKzljT5gWJ3Db07VbWMzKRGX+Ubm2jOAOM/rRdhyolb928couISEYE89Rn6VvXEukprVlN BsBibEqsp6Mp9uexrHbSJF0qK/RXNu2YvMH8JHb+VXJNEki0q01lGeW3kJQsR9xxwQf0P4ii7E0j r5LvSU01rzyVWHAIk8vjOeP1qe01LRricLbFPN5xiPB4/CsfS/Cus6v4fs00jTXvEmkaLdbxl5I2 U5JOCTjGDkjGDXpvgD4CTajBpmua7rNpZWN02LeKP97JKTnjsqng+vTpT1Y0ktbnHeB76LTvi9YS u+/dqEY25wULMPUHjHUdfcV9WDQNSvdSudlv5UPmttkkOAwz1HetHw18M/BfhWUXGl6JD9rzn7TM PMkB9ifu/wDAcV2QUDtVxhYic1LY5ux8I2UBD3bG4cc4PCj8K6KGCKGMRwxrGo6BRgVJxS1drGVw xRRmjNMA4opM0lAC5x3pM03NITTAdmgmuc8Z6rdaN4M1HVLJsXFuiuvGf4wD+ma0G1iyQKDJmRgD 5afOw9uM0WFdI0s0yX5onTPJUiuQ1HxnFbyeVGFDZxj/AFj/APfIOB+J/CsC+8T3xUySyG2QjA85 uT9EH+Bp2Jcje8G61DB4B006heK0sCvAzHt5bsgB98KPrVfVfiRpVqrRWEEt9c9AANqfn/8AWrgL TSEule6mupfIndphGo2g7jnd+Oc8Vdjt7eyuwsESorrxxk5+v4D86TMZVknYLjxt4h1zVJtMhu00 10UO8UYKsqnODk884NVYdIszK81zI91PnDM570zVIi2o2l9buqTwna4I+/Geo/MAj8fWo7i7aObe hBDgEj3HWpfmZOpKS93QuTuixlYUAMRDBVGOallU311YWqcrcToj/wC5nc36A1QmkXeko5WUYPuK it7po5ZnZtv2G1ncnpyVEan/AMf/AEqkYTu4njnxU1OS/wBZKjcxeaSdu/GcA/zrh4b12h8mdBKA MKx+8o9M9x9ata3rN6PEcs9reTQOqhN8TlDzyRx7moofEetE4fUZZf8ArqRJ/wChA1EtWd1FWgj6 F+D748BnDfKZ5G6ewryr4tx+d4z1VcgDEXU+i5x+leofDJru7+HjyxFPtUksrrhQqs3HBAwADjFe LeIPtms6/dwy8TvOFIcgbAD3PTisYbs6J7I8wWMq+M5FTqMOOOBV+40HULa+kgKidUcr5sIZlPPU cZxV2Dwtr09k12mmyiAAkOw2hscnGepA7VtczsV7XZJKv2g/ux1wT+HTNeraHYRaj8TbC3uo3ls0 KSTopxlFAJH49PxryiCyu45FzEwBIyK+vPhj8PI73TbjxJcSPDcXcnkw/LkGNQBn8W3D/gNDYlFs 7PVdT0/W/D82nC8lsJZZGJcJwqkEAce2K4DTPBDaVHfy6HJFrd+BsjkljXyrU+ucfNJ7DhRzySMe iyeCbiMlVu4nGfQiqA8L65ope508+bGWLOkDc/ip6/rSfkaJN7ng9/4N+INn9ra4lR2uSN5BKscE twzAY59/5V5/qXhvxRa3jyXmjTTBzlpI18zHHOSue5r7Bg19XIt7pcyHgxyoVbP15B/SlurHQblA 11YNbMT1MZQ/mODXJLDpu9yuWJ8RyPPayXMLIwlQlQMkdOD2zzUUctzHCHCbvMBHIzgYr7A1Pwxo 6gubm3ZQCQl5AJAfpkf0rjpfB/hO9Qi48NJGCf8AWWTtEc+uOV/Ss5YdpaC5EzxTwJpM2qePtF09 HjMM9wivhR8q5y/1woNWPiDrt3dfE3WNXKq1s85RFDdFXHGB+npXtHh3wNpGiaxda5pV3cYtLWSO GK6x8kkv7sEsAOgLflXmOr/CTxlbpd6hAlpq5n3OxtrjOM9c5IpOE4x1Qcj2NXw/4lXVvEOk3gjk heKxuPMEO0qjiHBf5SCQSRkHsPaql4c3khPQHH6VymmReJ/CXiB9Xt9HmjiNs0UiPHuDK42OMpkA jJI9gD7VvPcpdSySxk7SehBBHFaxfu2LhfqSl8EgUgmkWQMhIYHqKjJJc8UwuSSKZqdt4L8VPoHi W11TgMp2TqPuzRnhlP8AnqBWj8TvDEGja1Hqek4fR9VX7TbOv3Rnkr+GfyIrgLWK4urhLa1hkmmk YKkca7mY+gA619BeF/DWoXPhG18I+IYYLoxzm42uSxsVI+5kHBYnJxyBn8tF7ysT8L8it8EtAlh0 G71y5RlE0pS3B7rgbmH8vwNebfEyGe+8S3l1bwtIiSuWKjOBng/pX0vdNbaF4akW3RYoYE2xoPXG BXjGnIk3iHUhKNwKLweeuatrSwJ63PG9RP8AxLbJf9n+gqUSTP4Slbb86fIrd9mRmuk+IWhnT5ra a2ixbysRx0VuwrnGuYraOztn/wBSzPFJjuCFz/OsirWsUPDIxrDt6RN/MVzFwFllkZ2wCxJrq9Dh a11m9ifkxRsCfxFc1aWovbwRM22IAtIx6Ko6mpaugKbMdH0SW8SaSK5v1+zqQc7Is5dx+PA9ya42 e8udQvRLcDM0gCbssRtAwOpPpXS+I5V1G8eULst0QwxAA/IgHGce/P41zUU12Zo7WX92sbLExAwc 545PSoje2hlJFi5ke5uJYNh+zx/vGEafd9Qc844Jx+npWnvLNrlpVkkiCw/KpG/e2MEHOMA88/Sq 9zNcxi5hlu3ZWcOME7ZCPlB/InnFZxG6TPX3J61pGKILMMU91Ohk3CNjy3ZRnFW4LO3FrLdSShlx iNDwT0yc8ZIyfyqubyT7LHbpGiIuckHO/nPIPpVdppXkJd8kcc9AKdpMNjTa+uIUQRJGuflIBGWH +1SQXTR4QJuZ1IPc5/z2qjF+9c+YfxPeui8N+GdZ8R6itjolhLdzqu8iMDCj1JPA/GlyoFd7D9K0 6/v9Zt7eKMTXM77I40UZJ9h68dO9fT3wt8O+KLKzS7vY5bOEfKPtMrb5OTnMfbkdSR9Kw/hz8F77 TrmHVvEFxLp2oW8u6JbWVWLLgEEnBAIOcjvntjn3vYVAUZwPU5pxjfVmqVtwA2qARzSgEkUuwkZN OGVFalDW3Z2dqW7jV4xE6BlZSCG6EHtilLgsF5/Ci5baMkdFz+lMD518URCHXZoImzFHKwTc2SBn AH4dKgtQcjgfnS69/pGsSZP3snP1NM05i03kSjEq/wDjw9acBVNz6F8MtNB4W06NPlAhU4DevP8A WsOynmi+JMsW4g7534P9+OA/zU10uk6RaW+jWcEixl0iUMcHrjmuYmtLWH4uW9vgBLi28wYLDkI4 P8hWhMfhZ3P2uQddx/EUVCtna+ZlAzbT/fYjj6mimI+A5tP+zhGMRTJK4aqMsaPkbOR711l1ba5q 6Rpa6Pc3O09UgY0i+GPE5xu8N3a85ybdh/SsuXUd3Y4soq/8szn610nhYLb3Emprsc2xAkgc8SRM Crn8PT3rvvDHwb8c+J5g7aYmmWjH5ri7GwY9lxub8Bj3r6B8E/Afwp4YZbu8ibWL/GGkuFxEPXEf T880Wsx3dtTwHw/8PvFGqpqel2Gj3Fxot2PNgnHEaPxtIyfzx6CvUPD/AMCZ9J8Ny2+oSvq8ksiS tZY8uE4PzAHO7JHGeOgr6KgtIoY1jjRURRgKowAPQVYVAO1VYi+ljhP7Gh0PTbM+H/Da2Isn3rb2 6hQ4Iwy8cEkdyawrJSljrXhyeyuYES4+3ae4hLBNx3BcqCAVbP5162BxTHt4ZRiSJX+op3IavqcX Y6tHJ4g0/UIpl8vUofs9zGGzsmTJGRng/eHv+VdHfaraadNZRXTMpvJhBGwHG8gkA+mcY+tZl/4I 0q4jc2KCwuGfzBNAoVw2c5zj19c1zXifStet/D9x5t61+ICtxF56AsGQ54ZQB+YzVaC1R6MDml6V yVh4rTU7nS57PBtrtCssR+/E5GVP04I/+vXUlvegY7NGaYWrnrfxBJJ471Dw5PCqJDaRXULjOXBJ V89uDtoA6MsKxbHxDb33ifWNBCeXcaaImJLZ8xZE3ZH0OQfw9akn1zToHaIXAllHWOL5yPrjp+OK 8n13xGNO+Jp1iCZktL6xW1mW3dWbzFclcnoMg44J6U7EOSPZp7q3t03TzJGP9pgKwL/xVbQq32fb tHHmSnaM+gHVvwFef3ep6k5BZ4tKWTo0jebO30Hr9KyJJYUvI0ks7m6eYgNeXrZjViCRlc57dwOo 9adktyOZvQ6LX9buNf0W806JpZxOhQso8uNT79z+OK5+y1y61KN7KSZ/Nh+SS3tAAv1LdMH3NV7p NR1CB5InN3CM+UMhEwAjo20dQfmXBz1FXoYofty6oYIbdDGQrqu2R1YKcMMdsf8A6qXN2M5TUVcm ijvPPMWz7JF13o28kemT0Ofb8auxxW8H7xVzIf425Y/iajkYsOMHsfpVdZm2yJyWUce9M45TlPc2 rVEurD7GoCzQ5aEeqk5K1iXrkqHXhojzn9fy4P4UsN8A8UsT7W7fWrWooku3UYgAk3yyqP4X9foa k0S5ld7ozZpNyLMF6jBB9/8A69ZOxpZGRTnHzZPpV2E/LLbOxJUnr1x/kg/jT2xGwTAwRj60rXJU uXQhYKLZYVbJ52n3HaoriNh4c1O7KsvnLHb5KkAjcW69D9wdKIyMSRAnjlfr2rqYrWDW/DOm6fAo KXNw4k7HKjBH/j9UhSvsfFF3fx3Wp3Mq8FpWO3HQZqWBwW4NaHj/AMC3vgHxtcaXMCbN2MlpK/8A HGegz6jofz71jwM8U6xhlRnA5z0+p7Vi3Z2PSUbJH0d8NNXax+HbMrMoheVmIgMgXvycgKOOpryn WLxr7Vb7VmZDG8hlYou3gnjHJxn616Z4AvoLP4exadfuqZmcMpG/zAzYGF7j1rj/ABamn3WrXFnY TJJZw/vmSGHCK2xVCqO+MZJ44zjpXDOs4vQ35bnGjUp2864hlUCEK7IW5IPp612v/CVwXvggaT9k +y6is/kSbASJNoJwVOSGJ256HGRk9K4zW9Fs7G0gmjDSzyTeXP8AKcRYBLKFAzgEYzg9PepLazht tRNzqdq7h4TIipGSZJt+FG8fOhOQPXOMip9u2tBclj074dafN47vbbwxASlumJbqRF5jVerEkZ56 AA9T6V9Q6xeweGPDhj0yBI1tY0t7aPqAThV+vrXAfC7TtL8N6Re/ZrQ219fy/abgvjeCeRHxxhST 09TV3xjq6F9Pt5WYqZGnfaCfujC9Pdv0rtgny3YrrZD28a65bnEhtJD7w4z+Rp6ePtU+8bWzbHor D/2auVe4s7pD5M6OR6HkVBsIzg5q7iOn1PxdJqlk8E+i2TSH7shLZX+tYX9sa1CGitGjjgPSNpC2 381qrkgjNGaB7gLy9Dq09olwVORulJH0xxVnUfEeuS2SR6TDHpsqHOdiyKw9MHpVfNRyOI42dugG aAKsmua9Onl3lzFLcDBKfZxszjuB19s9KoyXmqNKkipZqF6qtvIob64b+VXY0KzoW++yszfXIq1b jESH1GaGgRhXOtX1rauXOnW8AHzb0favv8xOKzZLqG6iTMGnSEjJbz8hvwI4rsruztry38u5t450 PJSRQwP4GqLaVpu7cNPtg3r5S5/lU/IpX7nD3FtbtIFFpbLk8mO46D8qsWvhi1unDHUEgGeQWz/h XYx28duzGBBFuGDs4zSEYz0OfVQf5ilZdh3ZueGI9I8N2Lx6fJa/aZBh7rgykem7sPpiussPFdrp 9t5UMMRYclhJyx9TXlk1nDK2WRQfVUVf5Cqb6fFGC3nOqjnrVppbE6noGseKL/W7ryJtkUEZyI4z kH3NY+jsH1zUD6BFJ/Osexk+zWTytn5RxnrWj4cJC3czffkZSf1/xpyHE29a0qDV7HyJlBGcr7Ed DXiHirw3qGlBWCtNbo7MZAOmcdR+Fe9OxMHpmsKV0O+K4XfGcjnnFYtGqfc8b02RZrSa/DDzPs5i k+q9D+WPyrlbiUWWleQuRPdfNJxgqg6D8ev5V6Z4g0S10dpdQsTthlVmlhXlcAZzjtXkN9cvc3ck 8nVjnHp6CkBVlbJXIzg7sHofrWLcaMryoYmYIxJYk52+mK1ZGGRmgNmhIhoz4dEt5nk893c4AGDj B9axJ7Z11Ge3iQv8+1No6c4rrITlJeuc8GmiBIrS0k2gPcXIdjjsDkf596fWwrKxyL2k1sxE0RG0 7WyO9QkxhiGJB+nSuj8QzCO2jYAZaXJ98A/41yjymR9zVUY33Jloeq/CbwTpnjzxmmlXsk8NitrL cyvEQHO35RgkHqxHavrXwl4P0fwppNtBYWkMdx9mihmmiTYZtuTkj1Jc5P8AgK+fv2ZrVX8W6pcs oKwaQ3XnlpFP9DX1ISRtAHAGMelVKKVioa3FwOMDFO+9jHao+p4PT361Io+UVJoPO7YOBTc596dy V60hGF96YiMAGTkVDqjGK0uZGPCRnA/CrK/60AjJz6Vl+JJzHpF8ynHyED+VIpbngN+fM1V/YAVb srN7q/tlgX9/5gCds5OMH61WKNJqUpxn5sV6d4K+HfiK9vbXUpbb7Daxusge4GCwBzwvU/oK1hsZ zerPRNLvY7+xEiIY5EPlyxN96Jx1U1SuPC+rX/j7R9ZtYB9lt4JY5pHYKBkELjueT2rrHtPDvhp5 NT1G4jS5lUK7ueZNucYQdTz1xmuT1j4mzTP9k8P2ZUsdqyyLlj9F/wAaptLcIp7I6a50ix0+1afW NX+zQ85CMI8+2ep/DFFedx+Htc12f7Zrd3IuT/y0O5segHailzS6IfLHqzt4LSacf6vYvqa07bS4 1wSuT6mtSOFV7VMBikomdyGO3Ve1TBRS06mSJjBpwFGKWgAxSikJpKQC0jBWUqwBB6g0hIphegDn 9e0GS402c6SIo7vAMZcdCDkYI5/CuW1LxBr2n6I7SQ7bi3kjZictuUONwz9M9cEV6M0oFcj4y0u4 1fR5otPnEU7gBgQCHGe/vVITRPc6+6oTbxKsf/PSY4H5V5b4kub+PXbTxNKxv1jhe3uQqmJChO5c YOSAazfFfi7xDoJS2n02OCXG0Tt84Y+q54A9sV5lqPiTUdUnEl7fSToTjazZVT/k1Dqxi+V7mM5O zaPWpPEmmStHbR3DXxc/LBar5cIJ9ScD+ZqxLFNf2ZhvvJgtGHzW0KdR2DMefyxXmNpd4kiIfJAD ZHY969QjuReWAngAAkTIB7H0/OtVK+xwyqylG6J4LSzghMMNuiIy7W45Ye56msuytJGkFsHKW1lM yCNk4cZV0Kn/AGRhe44rRtpvNt1bGDjkGpdw45GaGrmam4XQ6OOKCMRwxJEgOdqKAPyFRXIMsDKv 3uq/UdKcWzwTims20fXoPWmZpu9yvaybrcI6ldo24Pp2/SqskpEnnjJUNkZ7+opynyb4qFASXnP1 /wDr5/MUy43KTGOQxyo/z71PQ3XxFN5Ak7PHkbjvUfzrbhuFNuRJkwzLtcenv+FZsNqpTzZFJ2ks q1YMqrGhJURn5T2xSSZbmk1boVmWTzwwXMsTeXJz1HY/kf5elOuhuiWRDkryCKpXGowRLJdRSC4E Q8qYRnJ/2T/SsiXWNcns2Gm6RmPOPNmk2j8zgfrRdBPRpo15ZVEizR9D154FMs/G+l+HH8Galqjm GwS8mmuGT+ASF4wWGeQMKxrkNS1+4sbd4tV1XS7QOv3U3M4+gB5P51wXi67OoeG7KLSxNcwQttU+ UdznIOAuPbPPrSckkaQi+ZM+rfjB8ObHx34UY25T7Qg8+0uF5w2MjkdVIr4mh06Sx1Cawv7Vor2G X7P5LLnD5wSee2envX1X+zh4+u9V8Mf8IJ4oZkvrQEWDT53yQgfcJPUrzj2+lVPi18MbVfE8XjC1 t490alLtCm4SLj5Wx0yOAT6D2rnqPng5RPSjvY8m0TWNU0fQlEzGeRPMco4xGi7VQEnGcjaRzx8w xVCfWLkaTb3M4w7Yf7PEdkTDcrAEDPG0YI6YweSea6T3ssjWWwyXV2gmlkXDBlUtgcg4HAwB/hVq bw9/aiSC7l8i2hZgw3ZwVQlufQYJP0ry0tbs6FB7nK6n5EdpZRXEnmTTnaZHlI2uXcEnAznk8n1H 1r0D4YWces+MLjX5Iz9gtGVoYX5VrjapyB6K2WHvtrzayuoNZ1BtPtLLMF1lIWdtzmVFZ85924/4 EK988K6amiaJaWcb7/JQAv8A3zjlv89sV20aWupzzeh3L3JtZhLC2Oc1mX+o/btVlnXlI0WEf+hH 9T+lQz3f7sljxjms20JFurH7z5c/ic12sxii9JHbT/62FSfXHNRi0mjObS9cf7EnzD/GgHmpATUm g0Xd5Dxc2m9f78Rz+nWrEN1az8JIA3cdCPwpokYd80jxwzf6yJSfXoRQBa2HHBzVWYF50g7D52+n b9aj8mWIFre6YAfwyfMB/WoI7yWPdPLAz+ZzuXnjtxTQE87YnJ9Ij/OrKfKgHoKx59SgP75tyjG3 DKQevPFTw6kLqMSWsMkiN0fG0H86bBGzGwxUUwVTuzxVFDeyNjKRD/vo/wBKsCwDjM00kntnA/Sk UV5bqGP7ziqj3rP/AKmB5D64wKv/AGOGJuIxn1xzTJ5IreJpZSFReSTS1AypXv8AYXby4EHcnJpo tJLiNDcSuAOQo4z9asxRyXMgubhSijmOI9vc+/8AKrDkKpYngUwKbqEjhsYs8ncwzk4rf0nakE2B xu/wrH0+MytJeSDlzhfZa0YxJBAJ4s88svqDUtlJHRM2YBz2rCvXVAzH8q1lkU2yuDkEVg3ZaR94 6Zwv+NIo5jxQdvhnUXPXyW/lXg8kg35H6V7n45Z4/BWqNGhZhGMAdT8wr5wkvrvILRBAeRnvStdg 3oartk0Bh61jSS6oJAhgYOcbVx1B6GpGfUbaVobhUSRDh45OGU+nHSmkQa6FksLmZP4c4Pv0p+py mN7C34IjHzFeSDt5yPwrWito7P4SnWbmBhNqGqCCH5Qf3Ua7nOe3zMB+FUY7q3vJ4rjyfOiBK7Hy vJ9/pmsalRQTbG9EmYU8zz4LsCnbvz7VWkmHkLHhflPHHPNat7ZSAxy3Kp8+0KiYVSDxuAB745x3 rLurYpdCOySTLAdev4VlCvGRk2ew/ArXdL0FvEb3mt2WmTXC2sUbXjAKyB2MoH/ARj6kV9T291bX kazW8yyRuoYEehGQcdRkHPNfnmiXED+YsZ2oQdxHFdr4f8Q3+i6jYzG6FtKbhZXk8w8oRg7tnz7c HoCOMj3rf2l7BGXKfbgY5PH4mnjCjrxWD4WmvJ/DkF1e3D3Es7NIJXQpvUnIIU8gY6ZAOMfU7nJ4 FXc6FqOGcYB470Oe1SIC2FwxPpjrWvaeH7q4IaYeSnqfvflVJXBuxj26iScZGMU+fwlfa7ZyQySf ZYpTy7DJxnPArbvdT8M+FkP2iZXuQPuL88h/Dt+lcBr/AMTtTuY3TTwNOtum8cyEfXt+H509FuJX ex1Fl4e8B/D+P7TMI5L773mzYkmJ/wBlf4fwA+tYesfEy/vJDa6Fb/ZlbgSOA0h+g6D9a8kufELX cryIzzO3JkkOSf610HgMm58URy3LlhEjMAB3xj+tNNvbQTtHV6nQ2+g3Wpz/AGvWNR3O5yQZN7n6 ntUGvWkfh57PUIrUT6fDeQ3DsvLwleDz1IOc+xHvXofk2jjmMH6oDUU1jprxFJLWGRW4KtEOarls HMTR3L3FvHMqPJE4DK/UEHoaKwx4Q8Mr866RCpOTwWx+WcUVQlY9IxRTgKXFBkIBS4ozSZpAOxQS PWoy1MMmB1oAkZsUxpKrvMB3qnNdhe9OwF9pgB1qrJdAA81lTX/HWs2fUOvzUWFc2Jr4etZ1xfgA /NWJPqPX5qybjUgCfm/WqsTcua9aWGtWElpfwrNE/UHqPcHsa+fvEvhyXQ7iSIEzWrHfDLsxuA6g ++M/zr2GfVDzhqwNVlhvraS3uEDxP1HofUVlUpKevUlnm+m3lmkKRzwTPIBuzG4GD+IOa73QL2K/ 019OLyIHyyOhww9R9f8A69ebXcEuk34ikj3qpwHPRl7Gt3w3qktrqy7o12/fQKTzjqOfas6Un8L6 HnyXJO3c9RtZ4Xg3xLtXJBB656/1ockHcTyDuA/nWIuuaTbSM73SFZhu8tMt5Z64xj1Jpv8AwlNp eubexsLy6fHVIs4/LJ/Sui6MZNKRtzzlIVuE+ZQcOPamvOJlfYcvH8wx3rnLi71QRuJLuz0+Nx8w YmVwPoOAfrisaXV7eBjt1K8vHAx8gCA/gv8AjUuViktNjsru5gNn5stwkQQ5yxxwf8g1C2uWTxiW JZJmUdFUgZ+rYBrz2fXpd+6GxWMggFmX5v8AH9ap3Gp3sr7XumG7svH8uazdWKHvovwO3v8AXbiW JoxKunoSP3hcM4HOeOn61kNd6cRiS7u9QBO7EkmEJH+yP8a4qWf5zuR5G9WBGfxxTGub3aUVBCoy SVPI/GuaeKiaxoyfT7zvbbWbWK48o2cFvaS/JIVHQdjk88HB61ma/fXdpdNFcXMrddoGT0964td6 sTJI8pb7yu+a6uWRtb8KCcBvtVoNj4OSQBwfxX9VrNYhzvGO51Rpe7aTOWhtrSCaS4hsFErnJaRN zj1OaexuGkDpdSphuBGdvT6VF9o+UKwcnody4HWoXaM4Mc8QHTZtIIrilOUt2aKMUbWl63qmnajB dWWoXSzROrK7N0YHI/Cvrvw7rmn/ABF8DpfhEFyF8q6h67JMc/geo9jXxTGBsDPMg3HBCNnn6V6H 8K/GcvgzxOtw0rtYXJWK6hAzuQ/x9fvL1+hIrfD1XCVnsy0WviDpGp+FfEKlVh+xEYhlMKblA/gJ xng/zrhbzW55LZ7WSCCZZd24Mv3d33u+BnvX1v8AELw5pHizws4W4hKTIJYZgw4OMqwr5DudB1Cz 1CSwe3dpEk2sypuQ475HbvV4ik4PmjsyuZ9zR8K6Bpc9xHexafDDLFnaYwwCOcgkfMQflxzgcn2z Xo8EckJCfwYxjtWNoNomnWcVtjL98DqepNa7zqXK+ZtUfrXbSi4w1FuJeys0RjToflJ+tTRnAAHA 6Vn3d1GnlhAWAboozUkF1KxB+zAD/po/9B/jWg0aQarcFneTpuhtpHUdWCnA/HpWb5k8hBMqxj0h XH6nJ/WpnaW4I+0zS3GOnmuXx9M9KBlx41iB826gDD+FX8w/kucfjVbzZCcLEQPVjikVcDAGBUig 470hkEvmuViLgb+CFHbvUhtYmGJNzj3PFLAjyO82wkfdU47VM3y/eIH1qrCRSEES3SpGiqo+bAGK vhRxVQSRi7LM6gBepPvUhvLVes6D8aGhotggGrKNlc1lDUbPHEwP0FWre/sPmM94kEYBJZ1JH6A0 WGTXckUNu00rhFQZyax44pLuVbq5Uqi8xRHt/tH39u1XbI2WpOL7ULieKNG/c2yQF8+jtyOfQdq0 3XSCS26/Yf8AXFE/m5o2BamSfrVC6LT3EdnHyW5f2WtHUZrW2RpYVkEYHAdlJJ/Co9MtmSE3MwxN Lyc9h2FSMl8sw24ReBworQRBtA7AYxVUnfPGo7ZY1dVguWJqbFgm1dLaEt+8Eu0D/Ywf/rCqVwAC BjpXSz6Y1t4cW6mX988i4z/CuDgfrmuauCMmmBy/i4keHZ1XO6R40AUZPLgcZ4z9a8nlvZ3vLbTk top7pjtecwq7AA7kBP3U7k4Az1OTmvVvFO2TR5YmZ1yRgqxBBHPUDOOK8fjurkKZYbuC2tTt3uvz MwbhjnHTKk89ADz68Fe7lYrZXNeJbSOGW5mij1Wd9jhGRUUHoWVjnjgZAHY9q57W5rK+8uaztrUL Pkll4c4+82OABnI/CoNX8UzQXX+gEJJkKJic7McHbgcgjuDnB7VqeGvD114qvIbcfZpdItpY3uLg XIjMQPJUK3PQnI557jJrKnSlFqTDmvoje1231Kx0rQ9BEmzTtO0/dMIz8kks371g3qRgD8K52aW0 iXdOytFsyFXHHIGB3P6Vv+J7me88XaySNlnKsYk8iTKfKew4JwxxkD9K4pJLedZmlke6dV3JEwCF Bu4xx6ep6CuSvF1KjvqZTWpeuoGklQyyxi3iHmIzsRGAPRQCecf/AKqz9Y1WJby3uYrZIxtRRtTG /AAzz68nPTmq1vY3F7JPDHY3Tyyhh8vc56c59u5qaDwp4s1NVK+HtVu2LcNHaSHAI5/h6/jXRSwq XxdCLO2iI7G9s/Iu4bjeJmYFAr5U4zkYOeOF7+uKgltlkuY5rTzJBK3EUhDMnTg+vPsB9a7XQfhJ 4yu7kvJ4U1ZvkLbHt3j3MfugFhj65New+A/2YtWmZNQ8can/AGbbEf8AIPtWVptvo8g+VePTd+Fd MKT5nyEtPqc58OPiVr4uLTw0umS6nO1ykXloxcpEBtIj+baMADHYYOScjH1PYeHbmdFkuj9nUjO0 /eH9KwbKf4c/DTTzp3hjS7cTKNrC2AZ3P+3Kck/mfpWLdeIfFnixjFaD7HZng7DsTHu3U/h+VdyV t9TaKlY7i/8AEPhfwurRiQXF2P8AlnFh3z7noK4nUPGniXxFI1vpUTWdueD5R5/Fz/TFY6eC/ECX 4le90VoB/BIZXJ9+Av8AWuss7W6giWO7vbFVH8NvEygfgTT957Iv3VuYVl4UUxtc6lcGV+uxTxn3 PU/pWB8QlhstFt7aGNYxlmwox2r0gNZRoVN4MEdhj+tcf4t8J+HPFksf9q67qMNvEMLBaSpGp9Sc qSfzoVNvfQftEjxqxIZFAIJOBgV6X8PrSZNZeR4XVRCwyVOOorlde+FvhrTrJ73wtrt1DqESkot3 IrrJ7ZVQVPvzWP8ADb4z6tYasnhfxNcvdQuSlvcStmSJx/CxP3genPIPt07lh0480HexyyqWfvI+ lFRv7ppWjcmPCnAbJ/I1xknjy1Az5o/Oqcvj+EZ2vz9aw5WXc9ClDiHCoWOOgxRXmEnxBb+Ak/Si nyDue+dqQmmF6ieYDvUEExYVG0gHeqcl0B3qjNfAA/NRYDSkuAO9U5bxRn5qx59SxnBrGutUAB+e nYls359RUA4asm41Mc/NXN3WsDBw9YlzrBORup2Fc6m51ZRn5qyLjV+vzVzEupsxPNUpLtmzzVWE bs+qk5+as2W/LHOazGmJPWo95JpBYvPcFu9QNKScE1Du4ppJzSuOxmavpseoW5jYYkXmN/7p/wAK zYNG1W2EUxiTfBhgPOTLDGeme47V0pG4YpIpNqSQuoKuME45rJxV+YwrUvaJW3LEGoWdtowuFtrC 5acfKZGikZM99n3gfrXPrrWry2QsbWZ1t4fkxjBbA6kDjP61eiNpoWnxx3Cs0YcqJDyeSSAfzxWr ZJbTpJJDC8Z3YYOm0k0ncPYxOLuLS+mGWkklYkEqQcfTpUTaXfMQI0WIe6kmu/Nsufuim+Qo6Cs5 Qv1FGjBeZwX9ianJxLdseefk4p0fheUZK3soJ6/IP8a7oxAdqb5QxWX1en1RulbY4tdIht5fKubq fLc5CDBqVtB0uQY88/8AAm2/0rpri3VmXI70ptVI4GPeqVCmvsjs+5gr4WtJQvlwqdoxlJCxP61r 6X4dfTzLstZEilGxiQcA9R1/zzUyqIm/eRj/AHgK6XSfE+t6VGy2GousbncyNhwT071SpwTukNX6 nDnQ7VpCfssZwSvK9MVIugWWdxtoQfXyxWvqlxLEst6qea7AuyDqT3x/OuD1nxTfXiiPR1mE4kXE ITDuvUlfXp0q1Si9bA3bodZFpVmrEw2sbHP3mQAfyq0LFh92QJ7IoFcnpGrasLePz4XVCWV2OTsP HB9DjtW/FFdXTl/7UjjU9FXJP9KvlS2BMvPbXATi8bjswBFUXWWM7pUjkH+y2D+Rqc6TuGZNQlkz /d4p40KzIyxlc+70XHa4kd9aBNnEPYkkdKedS0wDBcEj0Wn2ulaeBg26lgcHJJq39gtVwUt0UjkE KOKV7jtYwzeWC3huE3tuXaVCkg8+lTLcQzyqlppV3IzcBVU8n2rZi+zPfKk8QhQ4DyQryB67eh/A itv+wbsL9r0mePUoo/m32pJdPdkPzL+WPegEjjGOoBiqaVOjA4w77SPzpwTW2Hy2saf78v8AhXoc ep6frYEPiBfs94PlXUI05P8A10Xv9RzUN/oUun7GmjV4ZBmOeJt0cg9Qf6UajdjhRbeIW/5eLWP8 Sf6U2SDX4ioGog7+MRrgk9hzXTNbqsgznaaemjLf3MhSTMMOANw+8xGT+XH50K49Dk77T9et9P3S y3COSBt8vIH1AqCy1CC0Xbq+n3N6CB/qbnyMeuco2T+IpNWuNc03XJVtfKksRIuPLi5Cjhxkd88g 1Hpep6hcQzC5QROZnKqQPuZ4J684xVpSJujQtrjw/PdR/avPsrJw217pjKUYY4PljJB9cdulXnuv DkU7QW/2a5T+GdGwp/B8N+lc7q1ql3bCOV3TJJ3RAKRXLjSZI5gsOsXjZ6K8KP8ArkVVhXZ6ZHc6 SCdph464AOKoyX1o00dzc/6oN/o9qi5aVuzEDt9eB1NcS7GOBraK6LPn5pTFw49MA8D+dFpNqEM6 vE6sw6EZwfqDUaIerPdNC0e41+0lezngW5iG77M7EO4/2eMGmDRNRkjlYRptjZI33SBdrMcBTuxz mvMLTU/Fk8ipBHFp6DrLbTFpW+mQAn6/1qU6Ub3Vkl1SKW4ugwkElzOZmB7HknBpaFq50Ig+26gQ cGC3cjg5DMPQ9xWo56AVBE0cEQiTGe+KY8vU/hUstE0JAZ5Djk4H0H+TWtolodS1mGLGYlO9/oP8 4rC8wEAbgFFdT4QvbaC5uPMuYY8qOXcDv71KGzpPEgH9gyn/AGxj8682uScGux8Ta1pg0nyhqdvI 5YfIkgYj8BXn0+pWjNtWUMfYU2xpGL4jWK4sfImBZGcZAOM/j1H4VyTaBosnyyaerR9oizbBxjgZ ro9TvYpZ1hVs/wARGOlUfMjDGqioP4kRJy2TKV3o2iX83nz6PaiXnDRxhMdOgHA6elX7WKGzs47O 2hEVvGPljU4AoDg9I2P4U8eYekRrZOmtkZ2m+p0ugeIdN0+ZU1Lw1pd/ATks1pH5g9845/H869It /FXhKGNXs9PsYQRx5duiEe3AryrRvDuu69dC30rTZLhv4mUfKv1boPxr1zQPg7Z2MIv/ABZqKFUG 5oIm2ov+85/pj60rw3SC0l1LWn+LBqV0LXSLKS5l/uwx5x9fQe5ruLLTL4xefqs62ygZKK2SPqeg rmrzxz4a8NWhsPDVhFJt4BjXZHn1J6t/nmvMPEPj7UdVkK3d9uTPEMZ2oPw/xrOU0tjRQb3PXtW8 e+H9FVoNOAv7gcfuz8gPu3f8M15d4h+IOp6qWjub3yoT/wAu8Hyr+Pr+NcHPqE1zwHIB7IarC3Zu kDE++az5r7mnLbY3Y9fhhfeLZZWHTzDkflVx/HWpbdqOiKOABXOLZTkfLa5+vFPFvNu2C3Ut6ICx /QVSqJbEunJ7mtJ4x1Zz/wAfBH0Bqu/iTVpP+XiX8BVePT9UlkEa2MoQ9ZPJfA/SrE2kTQJkNdSn /YgP9ef0qvah7IgbV9Tl6yzH8cVC11qD/eeQ/V6sG1eJCzWGqykdlt2H8xXG+KfHEHhuRYJfDWp7 3GUkuD5aN9MdfpSVSUtEV7NJXZr6lPMlqxlfA92Oa8PNylx4ptmtFdj9rBUqOWO/oKs63481bWke 3gtxbI/Hyks30Fb3gTwVf21zH4j1+JtNsrf95CbpdnmN2POOB1z3OK6KdSUIvmMJRUmlE9NAvCP9 Wg/GkYXQ6uo/ClstStNV3/2VdfaUiO15guEB9Ae5+laJ0LUpVZlgnb+6RGcVzOozoVNGZsuO9woH sKK6KHwdflN8s0Kg8hWJyPY4ope1KVM+j5b1Rnms6fUQP4q5ufVwc4b9ay7jVx2auixw3Oln1Lrh qybnVVXJLVzNzrHXDVjXGpM+SWp2Fc6K71onO01h3OpsxPzVjy3hboapvMzGmSX5r1mzg1SaZmPW oSSaMc5oKsO3kmjJpKWkOwGjApaOaljEo/ClpOTxU3GKDxTWXPI604CnYpXHYoaw8c2j7JflaORW DYzkDtTprK7ltze3GotFN5eY4o5AFQYyM+pqxJGrKcjKngj1rkL9ZNN1sFoN1szCUsMAMNwyGJ9i ePakQ0dF4dudSuX33d5HKija4z/F6D/Gumyp71zfhqGK31TVdNwNgkLoPbPH6EVuywSRfNC3H900 hEhHNN+pqAXW07Zl2H17VI0saoXLgKOposFyOX7wHvUq4x1zWVM8mokIu6K2Jxu6M309KqTRPbXf lWl06RAd3zz35quW4XOiZAeozTreyiEyPcXX2OBsndsLl8dQqjqfyHqRWdbTXUsQUSKi/wDPVupH sD/M1cQ28Q/1gLHqWbJNTaxV7kM8kclzKoLJFuxGkgGSO2T0z9KpXumWUk9nfpAomjlBXsoYjGcV oTSWrIQ7qRWbNettAClkDg5xzwaL9x200J9Ci1SKCRNSUBuDkY+Zu5wOlZrSvG13c6hZrGSCAzKQ qnPGCa2/7Ui7RSH8KoPcPdyp9ot/NjQH5D0JPHNCkuocr7ALFbZ1kNxM8bIAWVsYPrV6O3uTGHtb /ep6b1z+oqlaNdW9mls8XnKo2guecdh+FLBHfQTM8AAD9VJyv1pua7jVN9iyZNStn3SWqSg8Exv/ AEOKedWijH+lQyQH1dSB+dMP9qzAqxRR/u1ILbUnGGucD/dFLnj1H7OQxL21lnMkc6EEY61oW900 UqywTFJFOVdGwR9CKzW0YySb5WV29SoqVdLCYAcgeg4o5oj5JHVL4g+1YTWrOLUB/wA9v9XMP+Bj 73/Aga2tKvrWCN49N1SGW2k/1mn6kQm76HO0n3BBrzw6dHjDAt9TTfsELjAjHHHrUc6L5H1PQbmH w7dhrm01mzs/LbE1rd3Cgof9lh98cY45rjrvxIY0nW2fJkZnIjGOSegqrBZRgYKge2KtCygPVQfw FCnboJ0/M5mXUL1mQxRecXID84CD+tTuu9hJFEwcdeK6VbSEYwvT2qQQp2HFX7SQvZxOSeG6mRR5 D/U1H/Y9w6bfL2lvve9dn5XGMCm+XtqeeRXLE5BPD7ZAKCrsOgheSSPoK6QLikdscD7xpaj0MM2B hwqTSA+xqxa2EkcjOG5Y8seSavlR5gH41KCFoSArGExgkuSarOryqUVyvPJFWLmcKhOMnsPWo4zt Uevf602CKj6XEWHmPIx92NdN4d0DTL4utxaG5lUjZHuIAA7kjoMkc+xrFMmTjNeieGkMej21pAo8 65JlmbHIXJCj8cfkDSSKbKVz4b0vT9Dvb37PFuOFjwvA5HTNecape29urDjd6V1PxQ8f6fptuPDe mTRz3asPNYNkRkfw8dTzmvC5NYu5ZBLJcfPyScDNc9SrGLshc6W50DGWW9e5EI3FQvXt16VYjivJ ScQfpU3hvwR428Xyo2jxXJtG4a4kmaOJffPT8ACa9s0L4OeF/DduupeNdU/tS5HzGN3KQA/7ucuf r19KISnPZaC512PLNB8IeJPENx5WnaezoDhpSMIv1J4Feu6H8I9G0aAah4t1JLgpyYlPlxA+56t+ lXNY+JWl6PYi00G1gtLaIbUd1CIo/wBlBwP88V5TqXi7xL4onm/sm0uNRlTpNdbooR/u5Az+HFbt qO47OR67qfxD0XQrM2Ph2yiSKMcNt2Rr9FHJ/SvGfEvxVivbh/tmpSXhQ/diI2J9B0/KqkPgPWNd cv4p1d4U/wCfe1bC49j6++M10+mfDDwNp9uqJpaTuOTLcEyMx9TmsZTnLbQpRsefRa9qWuRFtN8P 3l0pbaCXCIfX5sYrbsfD3iKeIPcWenacWOdrM07KPfbtGfxr0ePSbG0tktrMpbxIMKiKAqj2A6Ux rBh0ug341NpdTVLuznbDw2sKKb6+Mj9xEgRf6n9a3INM0qNRiEP7vk/zqdbMjnIP0NeXa98RNcs/ FOoaFofh+S9ksWAdkheYkcZbCkYGTW9GjKrK0SZzUVdnrEcFouNkMQx02oBUpjTps/KvG7P4zCGb 7PrOitBIOGCkxsP+AuP611un/FHwjeAFryS2Y9pYj/Nc10SwdeP2b+mpkq9N9TtwqjjaaXCfQ1k2 XiTRtUISw1O2uGP8CSAN+R5q+0jD+H9a45RcXaSsbxaezJmO1flAb9KgubW2vbZre8tYbmF/vRyo HU/UHg0gMh/hGPc0FmxjIqSilaeH9D06TztP0XT7KQfxwWyRn8wKsySlVYgcAE5p4YE/NmrFvbx3 twloekp2HB6Zp7sW2p5GYi+pwr/z0lA/M16mrsozn8zXAR2jw+MLWzkX5opiGB/2T/8AWr0AMM42 qa1qWTSIhd3JBO+MfIfwoqFmAHT8qKyuaWObm1NjnDGqEt8xz8xNZhuCf4qiMua9O55ZckuiT1qs 0pNQls96QH6mpuh2Hkk0YpufWnBh3IqXJDsLilA9aTcuODTgSeisfwpcyHysXv0opwWT/nm35Ypw jlP8H6ipc13K5WR8UVMIJM/dX/vr/wCtSi3f/ZH5ms/aIrkZBS1ZFse7r/3z/wDXpwtx3dvwAqfa IrkZVGcUYq4LdP4mY/jSiCIfw5+pNT7QrkKW9BxkfTNYmuR291ZNETyWAXgHBPHf611IgiXpEg/4 DUNwilANq4J9KXtH0D2aKWhLaWd097fWFzcXBjVAUnVFOFAyRt68ev4V0Y1ey2j/AIp4N/v3TH+Q FZcajFXEgzHuAp80mTyxIZbyR7vzoNLs4o9u0wvvkXPry2c/jTjeysCq6ZpsSn+7b5/mTQVx1pMD rS5pdx8qIJ/tFwm1jEg/6ZxKv8qrjT8nJlY/jV/pUbyog5PPpRd9wsuxXGnQA7iCT6k0/wCzQJ2F SAyP90bR6nrUqQqpyeT70aj2IBCGGFQAeppgtgZCPStDAA6VGn+talYLkIiUH515qZYYuyipCARg 4qPYVPyn8KpILgYFLVKEA4qISEPhhj37VKHzTQEgX1p+AKjDUpcDvQIfgYqN2HYUhYtRgDNAyu5Y nAqxFHhelRfelGBwKsqe1JIYhXuKep4waKawOeKoRLmnLUSt60/PFMB+RQSCKi6EmkLY5oELJII0 JPaoYs5Lv94/oKbnzZN5+4vT3PrSs+M0AAbMhPpTZJcA81EHHJzWfeXRXCIcuxwBVkkpczT5P3U6 e5pzzYYIvPqfSq8eI4woPQVDc3kFnA09xIEXPU9SfQVDZaRe8xV5ZgqjkkngCqniH4j3lpbf2H4W zgqFuNQLBWYYGRHnoOgz6DjGTWDPa654it2jhR9LhJ4My8sMccA10fg/wp4a0PU7a61uJ9V8ol3U 9HPYbScYyB1rFxqT+DRdyZu2iKHhD4da94yVHg0EQ2mTuvbpdiMD6Hq34V7Dpfwg+G/g4x6l4i8r UbxPnVJs+WG/2Ysnd+ORUl78RtYv4za6LZJYxAbQyfMwH1PA/KsFLOa7mNzqdxJPI3LAsSfxPWiF GFPXdgoN7nW6h8RJ5F+w+GrAQxqNquUBIHsvRfxzXMz2eo6hN9p1e9kkduwbcfzPT8KtJEkceyGI Rr/s1IocDhjVuTZsopFFdK0oMjSWcEzocq0qhyvuMiroIAKrkD26VKIi/Y81KsAGBgYqVYbRTaB3 AKuffNKLaXHT8qulEUZ5FJkgcE07hYqfZwflcnNAsxnqSKtkrjLAflSG4UcBvwNFwsV/sg9DUdnH ZeHL+88Q2tnBDcmFjcTKgDSoo3YJ/AVO9yR0wa8T+MnjSa2J0aGQhIVDSKvG9zyAfYAg/jTi3fQG tNT2Wz+JOg+KHWzuvD1tfrKDlJHhlKgH+NG5A/OsEeF/hJ4immmuvA50+ZW2lrZ2iH1AjYL+lfPP w40C6ufH2n6rd3ZDWKnUZNp/u42pnPHzMgI9Ca+krGKOKxTOJGk+dmHOSa6HUnDZmUEpHPX3wQ0Y 6ffX3g7WJppI4iwtNRRZFL4yqhzt25xjJzXG/C3VZ/D9vrH/AAmWs28D+esUNtcXqlYwudxUBjjJ IH4Vc+MfhjX7/QLfW9He4azRjBdRozFU7q5UcY5Iz9K+fZdHNtC091cmRV52L/F7Zr0IQniaXvS0 OebjSloj6nvPir8PbRP3mrpIR2tw7/0xVzwv428L+MHu10aa5JtSu8SIASGzggenBrwu3+EF1NZW 89zqkdnLKgdoTa7/ACyeduS3OK3dP+FE1jG5tdf1SN5FAc2SiEP9cZyK4ZUqCVk9TaNSo7O2h76I oG5E5H+8taWh2wOtQssquFyePpXhHh/wBrOn+J7CaHVdYS3ik864ae4O2RQPuYGAcnHXtmvf/C8e 7U3b+5Gf5iuZRipJRdzdybi7nH67pvlfFljGoIeH7RjPqCD+ta5hmx/qWIHpWbr1zGPiZqMjrI5i t0iRIl3MTgH/ACTxQsuozZ8+T7JCTxFE2ZCP9pug+i/nRU1kOJNcXiWzGIRtLPjIhjGWP9B9TgUV Qu/EWiaFDi+1Sz0+P0mmVS35nJNFQovoi79zivsifxSv+n+FOFpEP4nP41ZC8Ubfwp8z7nPyori2 h9Cf+BGni3h/uD8c1LilAqWx2Ivs8H/PJP8AvmpAiL91FH0FOxQAaVxij24peaMUuKLhYMcUDmjr Sii4C0tJmlxSuMUUvtSClpAGKKKWkMTpzVeU7pQP7tTkgc5qkj5JY9Sc00JllOKv20gA2k8VmbwB nNOE+Ohya0uQXJwFY45qq0oBwOT6CnoHnXLNj2FIYwnGKAI/nbqcD2pyoo6D8aUnFJmmA8e1SA+t Vw3PNPDg0CJieKjj++x96QsAvWmo4BJz1pgWfxoJwOKiDjPWneYD3oEOxkU0rjocUu8U0uKYEckr J6/hQjFjljQ2GphIXoaRRbVhTnI29aoicBsE4NSrJvYDPApgWYl2qM9amHFQBwAKUyr60xEwNB61 D5y+oo85f7woAe3HQ0ocdM81D5ynuKY8qDkMM0wLRaq8jlz5Y4Hc+1V/tYwR1PanK2xeTknkmgRO WCrgcAVWklO0mmPNnjNUru52xnHJ9qYD5rpY4+WrMtJjdTNc5yg+Vfp3NcpqusyXd2ulwSGC4kfY BIrDOOuOPTPNdNbCO3tljZ8KgwAKrcm5p7y3C9f0q5E4ii2DaCfvMB8x/H09hVC0xc3Ag+0QWpOD m4kCZB9AeT+Fdrpvh6xjVZJn+1t1DH7g+gqXKKLUZMxrW2u7sD7NAxT++RhfzrdtdCRQGuX81v7o 4Uf41sD93gKTtHAA6VKjKTyo/Koc29ylBLYrpbrHgJ8gHQAYFTxxbBkgGnsE6hAaUSKExkjtU6Fa j1YHgGn+aq9W5+lRvIuABg/lQfIYYYn696NA1Brzb0Gaja+JJBjb8BSNbxsRtkH4mopbZ0GQTj1q bMq6LIulYfOCuPWlM8eOH5NZpaVOjGm+dP2UflSsx6F9nY8lifrSFCTkNmqPnsDluTTxcE9sfjSG WGgyM4Br5O+LEkkXxIv7e5yAs6uR3K4BH6Yr6r+0cAA5+hrzz4gfDTT/AB1NFeJdf2dqMY2NcCLf 5qdgRkdPWnGVndhKN4tHlmgXVzba2dCsIPMvdZVbeNtwYJCxy8nHT5QDn/Zr6OWJYY1jQgKoCr9B Xjnh34O6/wCFr973SvFMCXDp5fm/ZQzBT1AznFb918ONc1aVJdY8WNMy8AragH9GFaVJKT3M6cHF anufhzVdMs9Ma1vJdrO5JypKkEAY4p83hP4b6uQ03hzQ53BBBECK3ByOmDXi9p8NWsUVrTxNqNvI OrRfKD+GaS8HjTSHYWd5qOpIvQS2Mcob8Ufd+lONWyshunfU6jx5p4j142tqsdtbRAFUVSQ4ODyc /UVNol9danqdvppgtoTIdquZGCjjpjafSvMo/ivLHdG21nw+k8itsbYxjKH33AgfiRXWaNr9ld6h HqAhOnLA29DHLG6H0LOHI/AD8ad19pBZ9D1d/C9/EhaJYZyBkKj4J9ucVe8Nadq1rLcvqVolruCi ONG3nvnLdD24H5muGm+NGiWDFbq/s7gjtblmJ/75yKu6R8a/CGpfLcM9i+cBbhlXPvkmqjyboiXN syjc7X8W65MzfOZ9uPQDgV5d8c5r218A289jcTQEXqB2icqSpR+DjtX0XaeL/DOohkttTt5GI5Aw xH5ZFeTa+Jzc3dpdFL23Zip8xA6SL9DwafKnLmTLUrJpo+NFtNRvD5iRSOD/ABnp+Zor6IvvCHhi YMV0z7N7W0rRgfhyB+VFelGdC3vXucDpzvoZi+P74Bd1lbMScZJZf6mtK18btMpaXTUQc/MJTgn0 6da4aO0MZE8rRnDkAkdvb3/xpu/ZtiiUB3ztHUcHr+XFfHqrPubc8j0FPGtsyK7afIFY9VcED9Kn i8Z6XJIENtdIT32gj+debLNdIjM5DH+Je/HTPanLdMH2yPJCpA+UpjPAI6e5/WtFWl3D2rPUk8Ua Q7EBphgZPyZwPXgmnp4m0NjgXh7/APLJ/wDCvK49SuYV/cSYKk7u+eOme/8A9elXUXeNIWCooJLY XPQgkfzqvbSH7Vnq48Q6Gf8AmIxjJxyrD+YqRdc0VsganBwe7Yrx03EkgRPNOCc4HHHSpop/JkCv nGSw4yfp/Sl7eQ/avsewHWNIUZOp2oHvKBSrq2lOMpqVqwxniZT/AFrzNbqG5kIY+XuGeB3z1x9f 1zVH77loAwQg/MRz/nrT+sMftfI9d/tLTyARfW5BGR+9XkevWganpx4W9gJ6f61ev51495E06bgd 0o4xnGR2H05P50kjxsEklk8sZbJ9f8g/ypfWGHtfI9jGo2Rzi6h4/wCmgpRf2jfduIj9HFePbULq sAaRNwBfI6A96UmPJkVOFwzsei545o9u+we18j2IXdvnAlX/AL6FO+0w4++MfWvFYnsniMqys7Jn 5cd/wpRNBHG58ou/y4B9OffrSeIa6D9sux63qWqWtlZtJNMsYbgZPWsZfEFjgeXcI2emDmuAN1tU CFQXCjahOM+vP4A1UErSRA7kjkGOhxx7+ppPEy6EOr5HoMvirT43KPO24HGAh60h8YadGSB5jEDJ wh4rgPJ8hPNkkHmuwKhGztPUH644/pVeaJ5Hyzsruewzk9Tz3NP6xMn2rPSU8fWMDf6qTGM7iuAf zqzD4wjv7uO2tbOeeeVgsccSbmcnoFAPJry8WyRFdj+a7gLhh69hX1/4B8MeF/hr4Xsbq48mfW7m BZJrhgDsJUHYnoP510UZTqOyY1Nsy9N+F3iW902O7vZrbTZH58iYlnUds7RgfSpZfhZqMfL65Zj6 Rsa6S/8AiBbnIifP0rlb/wAZ3M2RETzXocsUtSuZlW48Cy2oJl1+2wPSE/41gXemR2pIXWI5CP7s P/16lutSu7olppiB6ZrLdgecmofKUrsgmMiKx+0LtUcsy4A/WuWn8a2Fvd/ZzIDzgEkLu+gJ5pPH epjT/DjjO0zNt4PJA5P9B+NeP3/g+S5sxqM1/wD6XKd7gr8qr7H2pJJg20e+2Wp/2haLc2twjI3t yD3Bq3qbvp+gw3z3YN1cORFAFHKDgsee54H0NePeCPENvoumXR1C7e5tlKsjLje/OCMdjj19K7PS dfuvGes3OtyweRYQsIbWP0VRhV/AYJPqfal0uUt7HTQSXzW6NPL5chGSoXOPapM3Df8ALw3/AHxT VPOBUoIAxgn68UrjsR7J92ftbj2wKxte1K80oQNFMZBKGyH7EYrQ1DVbLTYfMuZVDEHZGPvP9K89 1PXodS1AzT3UTRgbRB12gg/h+Nc1asoqy3Jk7Fm48X6s0oS2jhOehkzg/rUS+O9dtVVLqziR5Gwn lHdnOMHGenNc7JBq9zffZtN0a6ulQg5hhODz0Bre0n4f+OryQrFpTWo3ZL3fyZzx7npmsYSqPchc 72I2+IWpTYWO5TJ5wBggemKhuPGuoliDqDQAEZZuMZz/AIZrrD8Ab28ka7vNbhinOP3UcRCHA9c/ 0resfAVhoWwat4UN8IlwJrdhMD7lDjn8K15JvZlqE+rPIrrxJ4xuLX7TpctzJH1LLESMeucYxVrw 9D8QfFd19ittX+yzhSwEpA3Y9MCvaI/FOnFJNG07QzAhHllJtsPHoFH+NecXEV/4b8RhvLa3kjbe oBAJU+4z2rqpwdrMGlHW5Fc+GfiDooMmqXd9Ig/jj2sg/Fc1Lp/iK8szturWO/TPImZwfwKkV61D pUeu6PFdSTW3kzqG3Sb5iP8AvpgB+VI3hXw5IvlXCrc46rDAifqig/rV3S3L5X0OMsvFHhmYn7dp d7ZMSCGt7kuB/wB9cj9auzat4UMQe11/UFdjjy2AP5kqAPzrTv8A4caPdgtp8dzZt7uGX8jz+tcx e/DDXoAXtJre5HUAtsb9eP1prkB83Y6Kx0yW8bePEliqN91A6yP+OCKTVvDet2dq93Fcw3kSDcwC lGA9RnIP5155NYeKNEyJIbu3jU8kZMf6ZBq7Z+M9Qsxtms7Of3EflN+aFafK90ybrqjntS8WaZFr A0o30kM7SrG97sDJb5YAnn0H5V9BaZ4b0i0SOZALmUgESyndn3A6CvmHxzY6TqDLqeiaW1hLgm5h EhkRznO5c8j3FdL8L/iLqoNr4Qv9VSG2/wBXayz8BfRC+QQOw59vSiSuiYySep9LyJbtCVuhG0Z6 h8EfrXNXkfha3lJhtriKUtjOnRyjn6x8Zp6adqnlqRLb3K458md42b/gRDE/nV2GWWyiCros8aqO WR0f9SwJrA6Stbw68DGdPvH+zk8jUV3MB7YCt+ZrQFxrkB/eadBcr/et5trf98uAP/HqYutWxJEi XMXuYHIH4gEfrSrrNi7hE1W13n+FpADRdhYcdfgjH+m2l7at3MkDMg+rrlR+dWbbUtPvlJsryG47 Hy3DfypgneM72nXB5G05z9KwtQ1XTJ3xNoMupurbdwtuQfYtg/lSvcdjqSWHTj3ppBHU1zkWm6hO scljc3ejpnJjkk87j02szAVoCHXIP9XdWl4v/TWMxMfxUkfpQI0GwOM/nQC+ODxWb9vvYpALzSbg L3eArMPyB3fpU0esaQziNr9IZT0jnBib8mANLUdkaCzHoTn60plH8SKT/u0m1XAZCGXsQaTY2CPS jmYcqFDwk8oD7Cl22xGQCD9aZ5TY5ppTB+lHOHKTeTBjIOPqKaYdxPlun54/nTFQv0b86c0SIpd5 FUDkkmne4rWBLSZlzH8w9RzUgtph1P59KyTqzXDFNGt3vCOPO3bYQf8AfPX/AIDmkS21CdgdXvvt Cf8APtGoWH8c8t+Jx7VXqGpabVI2keDToX1CdDhjF/qkP+054/AZPtUUtpd3i41a6zGf+Xa2yifQ t95v0q7FdeRGIUgjWNRhVVQAB7Yp5vYnGHgH4Eik2gVzndU8OW2o2ptYL6706AjHk2j7Iz9VxzXC XHwdtGc+Vrcij/agB/8AZq9a8y1c8B0/I0eTbk488Z/2sihXWwN9zyW3+D1kiN5+sXDvn5TGgUD8 DnNWbfwDe6S+61/srU8dPt9s2fzDEfpXprQt0jkVvowrOv8AULfSIvM1O8htkPTzCAT9B3/CneQa HOxap4g02PZN4RRol4zp9whH4I201QvPiTFp+RfeFtXgHrLEFH5k1HqfxN0a0LLZQy3rDuBsX8zz +lcbqHxQ164DLaQwWSHjhd7fmeP0pqL7A5JdTprv4jaE9sbiXQo5EPUfaoC//fIYt+lFeO3UjXty 80hUyOcsQoHP0FFaqJm5mlaz27KYlQpJ1JTlQB2+tTwXccay71bdwCSV5xjn3/OqaoVD+WEUZ4BP OfT1z9aa8rxSMZDuIHXgZzznFeBaxxWJBcsMlPkzkkhR37fp/nFMj2yNtiDlxxheAP8A69PaeJtu xGDDDY4I6HnFSCWCeINBG29HKsAmO3XP49KkZTFtIrhVcSAggK3X6/59amWEyxtGCu7oqg4IP1pq 2ubhmMQG8gswP3vT/D8KsKYo8mZMs5GAvHGenHvj86G9dBEcUdvEkcYJ4O75jgEZx/PP5VPH9inX dujUjI5/hween8/eqiukIkuFBYjJAP0xj6HNRbv3LvCOFzuzz1/rVCRalkiMhKNkoPuk9AOv49Kr y3S/aQIQ+H+6WbOB/hzUZdJZWlkG15GztUAj8+1SFgrhXRiSP3YxwowOe2f/AK1LqBaiuXhPzTEg r0DDByMdPy/SmiNJZVtnmCbslX7cDOAfoP1qOeRkSPdaqZVJPzLycADIB9qX7TcSAFllL7vnUMAA pH065qlJWuDZPbWzSXMYhZ/IYbSpG3ndjaSemc+9WJ7Y2SPFOV8skeZuHLdu3pzWU0zoyMZ/KGT8 oOM4/wD11bgP2qSQ+ZII2CjBOc+v8qV76gRfuiEeJgEPRFHOMdTRvkaIMIQuPlJKhTz9f8ipf7Pw W5k4f7qtk4/DioogN6q0jBlAB352j1PWoC4xopCTJKWBwB04+o9uKWK3ikwgdmkBweOnSplnEcZP mBomJG5TzgfyFTx/ZlGTukd1GCrcA0AU44SkzySjzF+8qhgCBjkjtVoMt1ZiJEKyKB1bO3JHIHc8 jinyIyQ52qrKc4bqCO+e45+lV4FZjIEcnLAgquMjnJFHXQZZYraiPKFkjUbWyBk4x0HPcj869E8N eNDqEFtpmrXDNLCiwxSucggDAUn1xXm/9nzlJHiQlzg4QEDPbn16+tSrbTxRjbNG7REq2Mbiwzkj PXjFbQlKDumVGTTPcWizzioHix0OK828O+Mr3SkFvexy3NkuTl2BZB22n09q9JsNS0/V7VbiynBB 4KP8rA8ZBB+o/Ou+FZS9ToTT2IHDAYPSqxq/cPBDxJLGuf7zAVmzXunRjc97Ag95QP61tcqxwPxE tJ7+0EcMJlFunnEL1+8D078LXl2seJtTZRZJF5KDGCU2sc4IGPTpXvyTwTzST29xAyPwGU7i2OBg g+u6vA/GrRv411BriAsfN/vckAACiE7ytYJwsr3JYvDWuvJY6ZNYS20txIweR0IG7PzZ+g6/Svct K0230zTLewtl2wQqFX1PqT7k815pp7+G9Ph0TUNU1S7juIlaeOHzGdSxJxkAE/dI9K77w3rkHizV TpOg75JljMrySIVRFGOp69SO1VJ31QoxtobLzJD1PPYDqarX1v4nnjEei6M08zjhpm2Inuc9T7V3 2j+F7PTXFxeN9rux/Gy/Kn+6P610GNwyDx9ahp9C9Dw2z+EfiDVJvtPiLWkWSQfvFQbiPYNn8OnH aun0/wCCfg+ziP2n7RdyFt3mPKQRx0yOcV6V+5TGWBJ/GnZDDO3j3qVTSBJLZFHStE0vRrQQadAk Ef8Asjr7k9609nHyMKqPNsPChaYbhiAdxrRJIZdYZyC2KYY0x3aqQaUtneMVIsj5x0ouOwy+06yv ovKu7WGeP0kQN/OvNPHfg+xsNK/tPS4Gj8tv3ibyw2+oB6V6qF7nJ/Coru1gvbKa0mQGOVSjAjsa ak0JpM8Y8DeIL+GQ6Xa6ZbXzcuglYIw9QpNehf8ACV29uMavaXWlkf8APWAlfwYZBrx+5trzwr4s ZUJ820lyrH+IdvzFe/6be2+saRBeJtaKdAduM89wac7bkw7GZYa3YatGXsPPnUfx4KCr/wBnmcZW HJ9SQP1OTVW68IaFcSiZbP7LP/z2tmMTA/8AAcVn3Gi+I7IE6X4jeaNekV8of/x9cH86zujSzL91 oh1CWJryG2KRnJWXMwP1BwKoX3hjwncARXVhalv7tvEEb/xzmqB1XWrNgdX8NTXZX/lray+cv12n kVZi8aaO+Va8gsivVLhWRh+BAo5n0Dl7nO6n8LtJuAW0ya5ti38MxDL+Rwf1rxXx/wDDHWfCCrqu 1Z9OlfaZIs/um7AjtntX0BL4301pStnOL5x1K4iUfi5/kDUdzK3ibTprG6CmznUpJFbQSXDOP94g IPY44NWpyIlTi0fPfhfxTqUO2G3vpre5j5VkkK7x616RY/EjxNbKFuJYb1R2mjH81xXlvjPwdqXg nXwGhuYbOZi9nPKAGKg9GwSAw7j8e9ev+AtK0bx9oCzTx2+mXNuds0Fsjb2/2wzu3yn6cdK2fK1c wjzJ8psQfFa3MSrcaMI5e7xvlfrjGf1q0/jDTNclSw/tRtsw+cFfKVfbcxB/WqurfC/SlyNO1yRJ AP8AVzKH/wDQcY/KuQu/h54ntwzQ2Ju0H8ULZz+B5rO0HsbXmj1Ox8IabHCjRL8vXfBKVdvqwrRi 8P21oCbG5vLNjzlZi+f++9wrwITeINDmKLLe6c46qGaPNdBp3xN8S2IVLiWK+ReD56fN+YwaiUJd GUprqj2UWmsLgx6uk49J7dW/9A21KZdcjHNvZXGO6yPF+mG/nXAWHxa06WVV1TS5Lcf89ImD8/Ti upsfHHh+/Pl2eoxBj2nbZ+h/xrNqS3Rqmnsao1DUF/4+NEuP96CSOQf+hA/pUNzrmjrGYtRWaAEf cuLZ8H9MGoppxqZCw6yXA6x2cqfrgEj/AL6FTW+kzRyebLeNbxY/1aIuT9WwT+RqRnMw6r4ZvL9r TRbea2uP71vvtwffClR+dblpY+JII2kOvJLk/LHNbhwB6FgQT+dbRsLGaIxtbQTJ6MgbPuc1l3+m eHbCIz3MI0+MdZIJWgH5xkVQiX+0Ndt/9fpsF4P71tNtP/fLjH/j1Mk8T6bbKH1VLnTATjdcwlUz 6bhlf1rD8y/vpBD4a1G6tY1IzcX0glUj/ZRwXb65X61cPh3UPtX2ue+ttSkByv2y3JCH/ZAfav8A 3yT700l1FfsX4NcfWHePw9FHPGhw1zM+2MfQfeb8Bj3qf+xvNYPqdw2oyDnY3yxL9E6H/gWayLyy nf8Ae33h/TZyvPnRTeW4+hKjH/fVYFx4gtrCOWSyu9YtTGcFVljuYs+mWLfkDTv2DlfU9Gy6gLtw o4Ax0oPI6V5/oXj6RpJU8Q6jY2gXlFkR4pGHqQePypNT+Lfh61LLZrNfyDui7EP4nn9KLMWh35QY 61XnaKFDJJIqIOSzHAH514lqfxd1+63Jp8NvYIejBfMf824/SuK1DW9U1aTfqF9PcnPSRyQPoOg/ CqVNvcTqJHu+peP/AAxpu5TfrdSj+C2G/wDXp+tcbqHxbmYlNL0tE/2533H8hj+deb2en3+pS+TY 2c9y57RIW/lXZaX8K/EV7te+MWnxnr5h3Pj6D/EVfLCO5nzyeyMm/wDHPifUSRLq00SH+CD92P8A x3k/jWNAl9e3OyGOa4lc5wgLMa9p0r4X+H7Da155uoSjr5h2p/3yP6k12FrY2FhEIbO1it4x/DEg UfpT9olsg5JP4jxDT/h/4nvtrS2y2cZ53XDYP5DJrrtN+FmnRYfVb6S5b+5CNi/mck/pXpBC+9NK 46A/nUOrJlqlFGZp3hrwxpgH2PSIY5B0lI3P/wB9HJoq8VJJ4oqeYtRR80rLHcrEHm8oPwx++QAO D19O1Uxayt/rpVCjBDkYJGBV1bCcx+ZvO1QCwA6Hoev1608OXaWLykQbgxkkGQfbArxjzSqtrGzn Enz4VUKHOTjGMfh1qz84YJHKHIJCr0z+HT15pI2jW7IhbABIGGIU9OmfoefemrczWspjVBJNluhz tBH/ANiPzptXGL5zKGEbfvRlm5zk+mT9f51HDcTSOYTG3zDlQcBsc8/TGar3TPbzJDkrJw27jn60 y3+2M0gjUAFiPNbgLx6+mDzT5UiLliOaXzmIO9ckfMvANTwC0EZmmwk5xhMn5genTknNYct1cIYm AKeZwCerD1xUkMt3LeGSZm3Icg7eD1NVy2A15I7aJvOcBCwOd3OSOMfzFRTXMgX5HRCTtwTyo75O cfSlis/OBkuHkRUG4Jnpz/PPPalu1tZR+6DRMmAwbkg8jn3qbICJr2eBsF1lIBXhecE561Ebpgqj 543LbZC/BOO5z6VXkVWEjHcW2/xJt7gc/hUMwQszG4MkeMAHoM8fnS0Fc0ZljVFxgk7i+8dW5/Lr 0q1E9na2QZnbew3K+717n0H4fzrnj9ojQFnMnzH/AB/+tVqNnjWWRhv3J/EeMDt+lVp3Fc05Zmkn S3jUwsw2rI5OOT14Gfx56VDH5jWvl/ukYHkg5MmP0NO+0HyoZJdijZkleTz14Pfj8zU8KWzgvbTb ywIPHKYAHUkc9/wqXtcZLH5KxLmGaISIQfLIPGOOO3T9amxaW04jVhE5O3bgnoPUcc8547VFBqLW xjOYixGMSAuCTkDj0OenrRLe2iF0W23zeZuc44GPQe2Samwxf3GFVHVcE+ZubJ78f5FC6usEjI0I cIp68HBUjGR9c01Z7UZ8oCB5MsinsvuOnPFVnvbae9eOC2lu7hu0fzEkDAzxntSS8ikuxegv1fbD PfZhI2mM/wAR7Y9Oc0gjghnbY0qyk5HzhsD3xz71Z0XwH4l1aRGtNL8mNcK8twcbjzyPQZ//AFV6 XoHwikixPrWppJIRyLZCpH/Aief++RW6pyexqqcn5Hmk97b25a3eNZhtDkxg4DEDOMnrxz+NW7U6 tqVpBb6To1xcFgwyyZVsnOSwHBzjvxXt9p8PvDFkyudNW4dDuUzsXx9AeBXRRxwW4CRoiIOiBcAf St44d/aLVNdWfIXijwF4q0iB9Z1DR5IbVm+dk+ZY8+uCcCuajVJICHHIHpX2/PcI0DwPbiSNwVZG GQw7gj0r4/8AiZBo9l41uY/C0CRWyAb1ikLpv/iAyOAPQEj+Q9Gm9LEzjbY5sS3wgCW95OqoMLGJ DtA9hVUw6jMxaQ4J6sTyaWO/k2bWtnVu5AyKXz7hhhUb8a1sjK7JYLQWymRsEj3r2z4Z+LfBXgrw 8811cTzaxendMYIc+Wo+6gLYHufc+1eICK6mb94xC+gq7DZuPWpkk9y4trU+i5/jbogfEGnXcyk8 s21Dj8zn9Kzb341wLcMLHQJZYsfLJJOFJ/4CAf514wtncxIsjxOEPAYggE1tWGh3d6FYXNlbof4p 7uNP03Z/SoskaqUmd8fjTqrH9xplnH/103E/zFRSfFjxTcfc+yQ/9c4if5k1V07wPojbTqvjPS0B 6rAwk/UkfyrsrDwv8K7WHbJqSXMh/wCWj3W3H0C4FTzRXQ05ZM5K38YeP9XuBBY3M80h/hgt14/8 d4rsdK8K+Ob5lm1zxFcWSnny4pCz/pwP1rurXxB4Qt7dYbTU9Lt4x0VHSP8AlitOLVdFuVBttUtp CR0jnRv61LqdkNU31KGmaTb6Xb+Ul1dXBPLSXExkY/n0/CtNRABnrUnk7hlZUZD3YcGonjVVwwZQ OQYznNRzF8pIXTHDD8aiEig/eHFQqls3LXJA9G4qlqWq6FocIuL6+jTg7V3bmb6CjmYrJHBfFbTI zDb65Ewyn7qXb1x2P9Kq/CvxZ5dxJoM4LRy/vIS3Y9x/X8Kq+J/iRY6jZXFhZ6UWhlUoWmYdPUAD r+NeZxXJgnWa3keKRDlWU4IrVXaszNtJ3R9ZyXEECF7qdIoz3dgo/Wsi68YeE9PU+bqsTsP4Y/m/ lXzRcand3bbri9mlY/33LfzqqXfP3i31qVTXUbqPofQN18UvDiZFvbzSkdCcKP61z2qfEbRdQTy7 nw5b3I9ZHBI/8drx/wDefxNx6UFyKrkiRzSOuudesLe5+1aDZSaZNnPySb1/Jga1rT4r+IraMRzQ 2lyR/E8ZB/QgfpXnnnqB2/OpoCkkgDSKg9SafKuouZnWeJ/Gdz4w0GTSNXtLdYXIZXjiJaJh0YEn g/04rjdK8Q3GkT2y20Kpqth8ibAdlzH/AHSO4I/zmuie/wBPgtUtYpkIY4ZwM1ual/wrSXQIvst3 s1m3XdFcJDJlm/utkYwf0pwko+gnFz1PVvC/ibTNf0GHUNL04x5+WWLCqYXxyp5/XHIrae8ccMiQ +33ifw4r55s9XubO2XUNJvXs5Lr9zcLHwGbqreg7/r610mh/EvT7RfI1iyvXdeGljlDE/h8v86mp TcXdbGtOomrPc9TvFivISl1bGeI9ROFVPy615/qXgjS9U1XZDJDaRY4+w25fPsfnI/SrJ+KXgpG3 Jpt8zDuYUP8AN6cfjJ4djGI9N1Ajt8kYH/oVYpSWxveL0ZhX/wAJrrAOm3ryZHS5jCfqCf5Vy+o+ BPFemI0kumPJGP4oGD/oOf0rtrn4z2zHbaaVNGP70hBP5A/1rOl+K+nkb7rTru4Po9wqL+QU1onU M37M4G01nWtFlP2O9urNu6qxUZ9x3rqbL4ueJ7NP9KktrxR3mjwfzUipL74o2Oo2ckCeELZcjAlu HEv81B/WvPriWxmUkWWJixbfvJA9gvQD8zWqjf4kZOVvhZ6z/wALZ07U4Y1fTEs52OHuGBcIPUbc MfpkV0Ok6p4Wvp4pU8SjUL8D5TeYwv8AuowGPwOfevn7g0uQKTproNVH1Pp+/wBRS2Qm8NrNIV+Q qpL/AIJg/wA68sPjvxFoWqSG4vEu7WbJRW2tsHrtDZH0JrzmPUr2GJ4oryZEfhlWQgMPQ4qsWBOd 3NTGnbcp1VbRHU6n4017VLl5J9SlZDnbHtAQD/d6VzzyM5LFuTVXJ9aN+e1bJJbGTk3uTl2PU1GW J9qZ+dKPc0yQ3HNdDoOt6PpcgfUPDkOpuDndJMy4/DkH8RXPZGcYpepwO1FrgnY9y0r4oeF/JWE2 MmmqBjYiAqPyxUeq/FrS4MppNtJdyY4eQbFH9TXieePel7c1n7KJr7Vo9Q0zx5471q/KaXaRXA7x iH5FHuc/1roZPiFq+iXCW/iXw8tuW6SRSjB+g5/nXiMUs0DB4JnjYd0Yg/pT3up5JxNPI0z56ykt n65p8iF7R9T6FsPiJ4WvyE+2NbyH+GaMj9RkfrXQw39jdANb3EUv+4wNeB6V4rtFdRq1tbPAnAt0 sY8H6P1Bqp4g8R2OpzL/AGZpjWSr0YzuzfkTgVn7PWxopq12fRxZT0HH0orx7whpHja8ijuI9cks 7M8/PJ5pI9lORRUuNupSlfoedGee3nWSaDactuKtuxjr0PvTvtHmrvjVTgkYIIGTgDJ7f/Wqsdwn MiArE3Iz2Hp61ci+yupuQ8kWAWAHAyfQ/wD1u9eS0tzzbkZuGczboJHYpwRwEz1wOneqflKCkSSS ee6ZwOc89+ODg1b80vGOkka4wX4wCOcZ9z+tQCeRS8YjWKVBksBkjHv+VJNiFaS5muJClv50ikP0 GQo6HNO+33IUwRxhix4hU43k56469KlWRLcqLu5kAI8zcF3BnxkKR36mnDUY3tcw7IJ43YpLswST jJz7Dt7mqWuoEBuZfMZfskfyDYWZeQB0wOvX1pE1CZIthkwXPKrgDGOB+v60sf75kw25Gwrg5Gee /tUFvBb/AGbddx5PzMobg9cHp9DT3DUkmkDNHLHMJjLy2Mj2I9OwP40jl3UO2QHPUdm9gKSJrN1C xKiJs+VBnAOB61I2qRWKgvbkPGSpJOQDwc1L1Gl3GNHE3DKzOSBtA6k9P5VLHpzKQBaum8YHJHHc nPI5A7VB/wAJDKHcbREqkYIHqMgfWqd3qd1cx/ZoUDTnglnw2f8AdHTv1Hakqcm7ILI2TaSyM8Al iDHoXPzDpzxmnNp8TFwzLLsUs7Hnnoe/X8KwLG11/V7o2ulabeXMhUARohJ57nviu/0H4L+Mb9Wk 1IpZRvGwHnSfcJ/2VyT+OK0WHaGoN7I4yS4g8qRxIwXdt3EYBI//AF/qKnWS5luUjFr5w2NtibAU bv5Dnqa9t0f4E+H4Asmvalc6nKoxt3eWij2HX9a7qz8M+F9DkVdO0K0iJGPMWIFuPUnn9a3WHsaq l3Z806f4X1rWpQtnoV2UVgEkZTHHwDjDHGR7+1dxoXwV1do5P7W1O3tFlGH+zDzX9cZIAHbp155r 3bECLkEAEg4FNaWLoq4/Sto0UtzRQgjgbP4ReFbdg9wl1eMMHEsuBx7Lj0rpLLwvoOmrHHZaNawh Punyxkfiea2VnIbGR+FKZc9c4rRU4paFLTYSCERrsQkKO3b9KkLFSBnGagLt1Bx+FKC7Dn5qvYZO ZMH5zmoZGU/dA5pwjI6jFG3JwFpMaMrVbBtQ0u4sRdS23noUMsJ+Zc+leYP8D9OlbcdcuGHp5Az+ ea9kKYHUCmlRztIpJtbA0nueSQ/Azw6uPN1C8kP+zsX+hrTg+DXg6AjfDdT4/vzYz+QFejfd4LAe 4pu8jAHJpOb7gorschbfDTwdakFdDhbH/PVmf+ZrbtvD2iWQH2PSbKAjukCg/wAq0syOcr+tO8gn 7zZGeanmuXypFeeztLi2Nvc28c0R4KOoYfkaht7KwsYfJtLGCCMc7I4wo/SrptVI5LEU5LURjdt9 +vNS2NJFZQzMFWAAd+BxUq2BkcAlRz0A4qQxNncuD/vZqwoVRjkH6YpWLuQfYVQ7XiikT0Kiqd14 f0O5JFxodo+e5hX/AArRZiD8pA9a5rXvG2n6MGUTw3Uy9Ylbp9SMgUITfcf/AMIroMEm21E9g56f Zbp4/wBN2P0rntf1NPD0bG08b3bXK9IJAk5z7nHH4muJ8SfEXUdZRoEjS3gPGxDnP1PU1wctw0js WZs1pGLe5m59j0O7+J/iG502eyke2dpMYuY49kq89iDj9K4Sa4uJpGkmdnLHJYtk5/GqQmfPDcd6 QzMD13VqrLYzab3LBAZsbsj1PFNaFyflXcPY5qH7Q2fSjzyTT5hcoFFBOcg00sw9eakNw/c7v97m o/Oj6NGp/wB04ouMYZXXrSecW6ipCIGHLsv1GRSeWcfIyN9D/jQIiyGpMH1pzIw6qR9absOfm6Uw AZz97j3p2fzpuPQUoDHtQBt6DICLq0fbtljJXd03AZH8qzrwZuWfKneAxKnIJxzg/WoofP8At0EM aEu+4rj1AP8Aia9I8CfB7xl4ysrS6Sx/s6wKAfarvKKwHdV6tx6DHvXRa8EY3tJnmwiz7/SgoFIB +8eg7mvsXw7+zz4O0pEk1mSfWbgckO3lRZ/3VOfzJr0nTPC/hzQ0CaRoljZAcZhgVT+JAyaFHuNy Z8AQeG/FF6u6x8Pai8Z6OtrI2fpgU9vBniaAb7jw5qoYc7pLOQAfmtfoW5jHYVTmki9qrlEfnhPa XVs225t5ImHaRSp/WoCpHY/jX6B3TWcqFJoo5EPVXUEH8647VfBXgLVc/bfDdhuP8cUYib80walw KTPizDdBSEHGOtfTWrfA3wbdhn0u+vNNc8gbxMg/BsH9a4DVvgX4ktSz6Vf2WpoOi7/Jc/g3y/8A j1Tysd0eQkdsUwj26Vv6z4W8Q6Af+Jvo91ZrnAkkjOw/Rvun8DWGw9RUjGDpnnigE85peM5zzRkY 9TTEBPoTQTxzTevSkx7UAOB59Kfvx71Ecg+lKCaAJN/rRuBHBNJgjqKTHrTAfvOOKTee+DSD8qQ0 CsPyDmjPpTBk80c/5NMC7aajfWEols7uW3cd43K/yoqlyTRSsiuZosTSwFQsbZYgbwpzt654/r70 l0ZUQhWLDcwTJyFUdD/n1qwbSOIskEizR/NudFJwOTz1PQVLHJDFYl5HVkPBQjG0e/OSeOleFoc1 jMhuLnyY4LlmK480Ljg84HP1qKOSWWT5jKq+ZwV6Edq3BcwGGMCzbaBgKw7dcjOf/wBdU98EbCRl BYEkGXO5cH/6/wClF472ArCQJN5MrrsLdOcgnnNWsW6f62RGUpkseAO+P0/Sshdbhluw0turszcF h933zW3pVvaaw8w+xyTsWGFSPC5wR0A/ljvVez7oEm9jO+1QhAYZXeTOS4PQ5PAGPSqdxPJFeGN1 dCcgoRjkjHTsa9OtPhNrd+tt5N3Y2sbLl/PBfHsFxkH2/Wur0b4C+G7RI21q9udTdMZRP3EZP0GT +oreFK+pp7N9Tx3T0Mqo1oYZ5I/uxzSKwXjuM8+vpkV0Gn/DXxZq7xXNrp9wkUil3e6IiV29snOP 519HaT4Y8P6Io/srSLOyfaF8xIh5hA6AsfmP51qMUXk/Pj1rRUO7NFBI8R074FNdSyza9qkccciE eTa7pNrH+IM2MH6D2rvtG+F/gXQrfy4tGS5JZXY3bGUFgOG2n5QevbvXWGXuPyzxULSFjwQAeK2j BR2KSS2LEQt4kEcMccaLwFRcAflVhJVA4OTWd5hXjIolk3GMRK2T99i3T6DHNVoitTRklQ4HGKrS uG5PTrVcBscnP1p4TOMtx6ZouAhfPI60mQ3HORT1UfSnBY8553D0ouFhip+tSeSwHC/hSh1ODtKk etPLyPgK2fxqeYqwqIqjLYx6UF40+6CKa0cpPINL9nJA3cClcLCZeTkUOCnJ4+pqVbbaBl8jrT1j RQdx3fWlqPQolpCTxxSASu3A4FaBWMfdwD60NtUA54qWUZ6xqXYM/I6g9quQ28a/OOpoL4ONnHvx UR2CTfuIyMYBOPyqbjsW/wB2p55+lM/ds3SoOnTPPrTWkIHJAA70uYdiyyKed3HvUeY0JA6+1ZF/ 4g0nSYt9/qEMAPZ3Gfy61xupfFrRLV3js4Jb7A+V1+VSffIz+lG+w7HoctzEhHmSKhP95utc3rXj bRtIR1F0tzN/zzjbOPqe1eOa/wDEPXNb3RfJbWx/5ZR9x7nvXHyTySEljVKDe5Dl2O68Q+PNQ1V2 WGRraI8bImKgj39a4uW4lkOWkLZ9TVbzSvfNNaRm68CtEktjPV7jmkIOKjL89MU0kcn+tMLjtTGS EjrSFh0pu/8AGmnBzkUDH5PY8emKaWI64JppJ6Dimk4GQKABmbqcgUm7600v1460mQehFMQ7ec5o 35POR/OmAH6mgrg5JpkliObHG8/nUgm55IPbkVTx0LYFBnjQ7FyznoBzVWE2aG9eflB/GtTQdF1L xFq8Ok6HZSXl7MfljjHQdyT0AHcnirHgXwFr/j3xAmmaZFsX700p+5Cn95j/ACHU19weBPh94e+H 2hix0i3DXDgfaLxx+8nYep7D0XoPrk1tGPcycn0OF+G/wG0bwx5GseJvL1bWlG5VIzBbE9lB+8f9 o/gBXsxZUGFAAFRyTACqM12q55rQlItvMB3qjPeKoPNZl3qkcYOXrlNT8SRRhv3gpjOlu9VVM5eu av8AxGkWf3g/OuJ1LxLNMxWImufmnubhsu559TRew7HW3vi5gWCvn8aw5vFV0zHbyPrWQYe5LH8K QxRjqD+IqXURSgag8V3irtIPPQ5qW38R3IGMyAepFY4Rf4dvtinGNj/+us3ULVM3JPFFyqMpcsrD BBAwR6V4f8Rhpx1uGewtIbV5EJlSFAik5+9gcAn+legavfQaXYyTysFOMg+leK6nqT6jfyXLk/Mf lHoKnncinFRRR3H6GlDUhOaQdKZmOJHHSl49aYD2/lTgcUAOIz3BpKTI9MH2oBGOtMD0nwLrek3a x+H/ABHaQXMJOIJJU5Q+meuK7m++Fvhe8y1sk1k56GKTI/Js14DG5Rgykgg8EV7l4E8c219pH2XV ruKG4tlx5krgB1/HvWE4tao2hJPRnOaj8INSi3NpuoQ3A7LICjf1FcdqHgzxLphJutKn2D+ONd6/ mM17PqHxJ8K2WVS7e6cdoFz+p4rnz8TdS1O5Ft4e0PzHPAaUlvzA6fnRGUy3CB420bo5VlII7Grt vo2qXDJ5Gn3Em/7pEbYP417FJ4QuNbxqPi64gRgM+VbxrHj6t1NZ3/CMn7UF8I6nf2MCn95M0x8r 8PWr9oZ+y6nP2Pw+NtAl34gu1tgSMW6jc7+3FFWbm38caTqklxZzNqxUcXAiEvH45x+FFK8nrcq0 VpYxbTw1pclnANO/eupyXdgWdcn07ep69Oamk0jTbCEszxmU4T58t8/TqOBnn+desf8ACA6TDZxw WOnrbu8IimuJ53dmGQcFF2g8jruHTpW5pnhfS9OjxFaxu+QxYrgE/Qk/qTXmvDzk9WTywSPFbPw3 q2qyRQaXpb+WSHlmlhKpgjp8zAN/9euntPgwLzzjrN+pL42CIs5Ucbsn5Qc49DXrqoVJGenAFTBt o4O010QoRiQ1F9Dh9E+E3hTR3aVLaSeUrt3TPwB7Cup07w/o+jiX+zbOO2Mx3OI84J9cdqvs7Z7U zJK4xk+ordRSAVdsS7VX260hlb1xjtTdjY5OaZsO4liSOwp3Cw7zGJ5bFIzEjrS7DnpgU5YWzkLz SuVYg53D5vypdhI5Ymp/s7ZzjHuKm8tVUdSfepuOxUEbHgA08QsOrfgKthPQdaaqlW2kZ9aVx2Ik h7H+VSCEKMFhU4Awf8aaI0I64ouFiJVJHAFP8nKnHyse9Sbdp4P4Yp4JUcjj1BpDIVtyxBLZp624 HLMCR6cU4yqO9M88EfdP1pXQWZKEweCQfrxTipPVj9KqGfnjP4UwySH7oyPelzFKJa3qOBTGkIHQ D61Vy/GKq32r2Gmx+ZqF5BbL6yyAfzqeYfKX92W3BvqKXIzwAp/OvPdT+LHhuyytksuoP28tdq/m f8DXD6r8Wdeuw6WEVvp6HoQPMcfieP0oSbB2R7vNcRQoXmkjjVerOcAfjXK6p8RPCOnKQ2pLcSr/ AAWw8zn69P1r571HW9U1RzJf389yf+mkhIH0HQVneYh69atQ7k866HrupfGKZty6RpaqOz3D5/8A HVx/OuK1Lx34n1Pcs2pyRI3VIMRgflz+tcoWHY00tiqUUieZlqSd5HLSMWY9STk1Fvx3quZPwpu4 noaoRO0pJ6cUwyZ4yc1DuPr+VJuwMfzoAnD8U0uB1/Wos8Y6UhbFMCTzMkjrTWYDGTx6VH3OOCaa xGOTQIk3kdOBSeYai3ZHA5zSHOaAuSmU9M0m/Prn2qPbxTgOeKdhXHgE8joKOB15pM468VBJcqrb FG9j0AGTVWE2Tlu2cCoXuFU7Ey7+g5NR+XPLzK3lp/dU5P51IgSP5Y0AHc+tPYm9wCTS4MzbF/uq efzrrvBPg7UPGHiO20LRrUNNKcvIfuxIOrsfQf8A1q5dea+v/wBmqx0vT/h7fa0Ahvrq7aKRz95U QDav0ySfxq4q5L0Wh6t4L8G6L4C8NRaPpUYLABp7hh88792P9B2Fa1xfIgOWrkta8Z21vO0SSZI9 K5G88XvLnZurW6Eonf3esxoD89c1qHiRI1OHzXEXOtXU2cEjPvWXLJJKfncmjmRXKzY1HxHNOxVH wKwXmlmbc5J+tG0duKXiocy1EiEYByevrTtoHanU0msmzRISmMOMEZpScUwsKgqxVmVosyRkgDt6 VVfVxCpMkYIHfOKt3NzHbxFn/AeteZeLNfVmNjbMA7f61l6D/ZFG49tTO8W6/Jq960UTYt4zwB/E a5Urk8Gps+jGk2jqRz7GtUrHPKV3cgII5zSZIGcVMwU9yPqKbt6gEH8aYrkO9qUNmn7e201NDaTX DhIYmkY9AqkmgRDninDJHQYrsdK+GviTVEEgtBbRnoZ225/DrXT6X8KhHcKusrcsM/etyu39ef0q XNI0UG9jytFZjwua29L8L61q8gWxsJXU/wAeMKPxNe8ab4G8NaaFaHTI3df45cuf1ro18qGIRxwB FHQAcVm63Y0VJ9TyHTfhDc4STVtRSMdTHEuT+ddjbWuheEoRaacjzXL9Ig25mPv6V090gurZohK8 JYY3RnBFed33w81FL432na2Z5iclLsEbvxU/0rPm5t2aqCjsjTudN1rVLpbjVdQtrW0HItlJJ/H1 rVhtGEYW3i8/b0LoQo+mTj8hWFBqevaEoTVPCQkRetxYtv8A0PP61sWXjnw7eOI3vmtJR1juU2Ef 0/WizHfuXjpl5cxmK8vmjQ/wWyhP160VbGqWLIXivI5x/wBMiH/lRUlGwswMatGNysMgjuKTcQ3p mqtr5ggVDGVx0B5Iq0R3A5NdFzhHBx3wfxp4PQbhn0qKNSHKkce9TKg3GlcYoUHqc+wp4BAyp605 V45xUgAyM5bFS2NEfB+9j604RqSD1qyFG3kAfWmbArfK3SobKSIwnBC4zShMfezSmZcnOaXzVPK4 qWyrCY5H880hGOhBNNZgTx1pN3OTxSuOxIOV5+VhSE85AznrUDygnHWomclcg4qeYrlLm8dCcUhl VTnNVCzMvzHNAyTxwKOYOUtGYZ6j8aa0gYcn8qqBmB5IaorrULSwtzPf3MVvGOrSOFH61Nx2LmeT sx+NJjK4Z+a841n4saJZ7odLhkv5R/F9xPzPP6V5xrHxE8TatuU3f2OE/wDLO3+X8z1qlGTC6R7v q3ifQdFjP9oajDEw/wCWanc5/wCAjmuA1T4yW6OU0rSmlx/HcPt/8dGf514287SEtISxPJJ71GWJ BI/WtFTXUzc+x22p/ErxVqZZUvRZRH+G2Xb+vX9a5G5uri5lMs87yyHqzsWJ/E1UDggY4oLVaSWx Lk2Sb2A9abv68fnUZb1qPzCD04piJC3HBINM3YJzTC/zdabu4oAeXIHHJpC/bkU3K5pCwBz60ASZ AGc03PGajJxzTd57UASluKTeM4xURwe/NAPFAiXjNIfambucZ/KjPGBzTAdkgmkJz70mSeD0oAP4 UWC4gU9QfwFPCnpQOOajkuUQ7Ry/91eTVJE3JuFqB7pFbao3MegAyTTRFPKcyt5aei8t+dTokMQx GmD39TTFqyv5U8zZmfy0/ug5NTRpFECI0x796ftB65oCcUXGkGFJ5zShcnjFAX5sZ5pxwOtIYqrj mvQfh/8AEC88KNNprzFdPu2DP/0zfpuH4dfoK8+BI704etMD6fiuY72JbiKUSq4yGBzmlK+1eFeF /GN5oMiwyFprMnlCeU+n+Fey6Trun6xarNa3CvnqM8is22tzZWa0LpFMIqcjio2FUpXFykJ9KacU 9hUZIp3Cw0nmoLidLa3knf7salj+FSs3HWq0xDxsjHANSykUtK1T+07BbsxmMOSQCCOM8H8qnmuF iQu5xWDe+IdB8P23kXGpW8BXs7jcf+Ajk/gK4PVfiTaXbvBpSyTHH+ucbVH0B5P6UWuK9tzb8UeJ fKJggcGZvT+AV52xZ5GYuWY8kk1Tku3mlaSSQs7HJJ6mm/aMA85qkjOUrltmZeDimGUjtz71BHNG zjzGIX/ZGTWzZapodj8x0V7+QdDcT7V/75Uf1qrsmyZWtra7u222ttLcH0jQtj8qZPDPbyFJ4JIm 7q6FT+tdIPiNr0MXk6ZbWGmRYwBb24z+bE1lXXijxFf5N1rFw4PBAO0fkKE5dgcY9ypazLE+ZIll X+6SR/KvQ/D3xIttGgjtz4dtii8GSMhXP44rmfBXhq58U+Ikt2LfZo/3lxIey56fU9K9kuPhj4Wn BxZy2x9YZT/XIqZTS0ZUIN6os6b8SvBV8qma8udOlI+7cQlhn/eTP611dle6ZqahtM1azvQe0UwJ H4da8xufhBYnLWWsTx+0sYf9QRWPcfCfXoSWtL60mx0G4o38v61naD6mnvroe5PbSLy0BHvURjBH cH6V4M/h74jaWMQrqIUdDbXBf9FNV38Q+PtLP+k3upQY7XCN/wCzCj2d9mP2lt0e+PFgDawJPc8U za4yX5AHbmvDoPih4pgIEzQXPb95EP6YrXtfi9cL8l7pMbD1ikKfzB/nQ6TGqqPVS2een1qneaPp OoRFL6wgmLd2UZ/PrXJW/wAVfD8+PPtryD1+VXH5g5/Ste18d+Fb2T5dWii9RKDHj/voCp5Wi+ZM oXHgHTopPM0a+vNLnP8AzykJX8qK6a31DT71jJa38E4PTy5A38jRRzMdkbqhdmCuB69qcMYwG/Cl w3VSOe1AjcnkhR7CqbOWwm1PM3BcY7+tTKM9QPrTAhQ7skjp1pnnRoeW/DrUtjSLKgL/ABA+w6VK jKFOFAqkZyBwAue1Qy3XPqfalcdjQLqMknNRtNke1ZzXL44XI/WoWku2Y+WgUerHP6D/ABqWykjT 81SeT0qJ5UV/v8+gPNUxavLkzXMhH91flH6c/rVqKGCIYSIDPoOtK47Enms2MDil4c/MeaFK5Pzb R6Ubdxyp5qWUJIBkYOM8elRMSOpAFPdinMnA65zjFcb4g+I2gaIWgik+33Y48uI/KD7tSs2O9jsF I6c1zWteN/D2iF0uL0STrn9zCd7Z9+w/GvG9f+IXiDWy8ZufsVs3/LGD5QR7nqa5BmO7JOSatU+5 Ln2PSdZ+LOq3W+PSbdLKM5Akf53/AMBXB3uqX2pTme/vJrmU/wAUrlsVnM/YU3fxgmtVFLYzcmyf zOeADTDJwc1CWz0oLE9RVEjy4B6UFiep4qIsM00k54oESBh1P0phkweD9BTQeCBzzSArnIyKYIdk 9TTSwFJnnrmkLL3B/GgB24EHtTc+/HpUZcnkdKTdzjFADt4BOaTcT0ppI7DmgE59D6GgQ7OOtKCO v86Zng04duQPrQAEZGcc0h44607vwc0bTjp+dMBMZ70oB7c0vAHLCoWulVtsKl29F5NNITZPtA5Z sD0qN7iNG2qNz9lHJqJYZ5TumfYP7qnn86tRRQxDaiBfX1NVYnUhCXE3Mp8tPRev51NHGkYwiAe4 /rUoGeh/OjAAPTNIaQzGT1o5qTGQA3X2pNvXg0ihoXPJH5U7aPWgDtSlMigY7A6Cl2UnQ8U5S3f8 qQw2k8Y4oEe48VKo9aeSoGQeaAsQFCAcc1b0++u9OnE1tO0LjuD1+tVndgen5VA8x2cdae4Xseg2 vxffTdker2DXUPTzoCNwPuDwfzrWPxp8JeWSYNQB9PJX/wCKrxW5UTRNGw4P6VhyQtG+1j7Z7Gko ITqyR71J8a/DZyYdO1F8eqov/s1Y158bowG+yeH3J7ebcAfoFrxhW2MQeKjlkycVpyIj2rPTbr4v 69eQkW4tbAnuqbyP++uP0rkdV8aa/qCGKbWrqUN9759i/wDfK4Fc0WHao2IHemoIh1JMfu3Ek/nW pa/u4vQtyazYELsGK8D9a041Y4qmQiyCS3tVlDkdeKrxqatKnqKk0Q9SOy5p6gnp+VKiD6VMicji goaqnoTmrtpaTXdzHbwRNJLIwVVUZJJ7VZ0zSb3VbxLSwtpJ5n6Kg/n6CvevBHgCDw3CL69CTam4 xuHKwj0Hv71EpKKLjFydkaXgnwxH4Z8Ppbuqm7mxJO4HVuwz6D/Guoxg/wA6QAAcjmlDE5K5Ncjd 9TsUeVWQ1lVsKFAamGBhkl+ak5HQZ9KUEgkkY/GkMhDPGOmT0pGnOCjqPxqVmAPbHWoWCuck5x7U wMy50TRL3L3mlWs7HoWhGfzrBu/h34VuFZxYvbluhilYD8jkV2HyO2OoH6UFUfO5SAvf1qlJrqQ4 pnmV18I9OZT9k1WeJj2kUPj8sVi3fwp1uBR9l1G2uM9A2VJ/Q17E2S+Qcgc0iZZg5GRnselaKqyX SR4RP4B8W2nzDSTLjvA4Y/kDmivew564PHbFFV7Vk+xNhWVEDqBzzhutRSXcQPUCqbSlyfm5I5I7 VGxTrjLDsOc1BmTtds/yhd38qql5GBDEIB6UqF2+6hHqSeakW3csWeTf3x0qRlbeBxkyY/Op0WRx 1C+3TFThQpAQf0prbCcMwRvapZQpiVfmILH1HFOJUrgMR7CohL5eeN39aPODkZ+X6VIyTBQ4JyKe XC45Of8APaq4dXLJ8zEc8cUuN2WJ2+1IZP5yKef/ANdc/wCIfGOl+HYi13JumI+SFMbj/gPrXKeN fH9vpQfTdHIlvOjzdVj+nqa8Zur66vbl7m6maWVzlnc5JNXGFyXKx1fiPx/reuu0Yna1sz0giOMj /aPU1x7SZ69ajL7m9abuyOOK2StsZt3FJOf6UwsRnDU4A4wTmmFSPpTEGCeSeKaeB7U7npTMk54x QAbscYpd34VHk465pDyCe1AXHE54oDHHHQUzd+NJu5wDzQAoYLyaUncPlOTUZyW7Uhz6GgBxG0cg /hSnaRjvUZZlBwePSk3krjOKZI7GDxikI4pMNxnoKcNpPegYBeMGg+5xTuAMAACngL3osAwBcdMG lEeelIzxIOW/+tVY3UkuVt0L+/QD8adiblstHGPmPNVHvGdtkCbz7f40q2ZdgbqQuM52JwKuJGiD agCgdgKrRC1ZTW2ll5uJNo/uof5mrSxpEm2NQB7CnsvPOc0o7jFK40gAJ5OB9KUYz649aQjnP60o B6nmkVYU9KMU4AkfpSgDvg0DG7ef/r0uO2adj9aUDHHNADAO+KcozmnbePSlxke3rSAQJz15NKfl Xmjb0707BI6cUDFyCM5pu7HT6VYisbuYAx2srqe4Q4ro9O8FPdRiW91S2tFIzsCtI5/ACk2kNJvY 5Ek5PrSx2txdSCOG3eVz0CKTXrXhL4fWl3HctqtnONj/ALqZspuHrtNei6VpA0xDDH9naNfulYAr fiRwazdRLYtU2z5+sfhr4o1QgpYG1Q/xznYPy61f1r4NtpvhPUNVvNY3T2sLTLHDHlTgdCSc19EE ADGO3SsvXLA6l4fv9NGALmB4l+pUip9pIr2Uep8PSRTKeDnFQsXHGwg+1dNc6dJBcyQTRlJI2Ksp HII4xVf7IM/drtTOFxadjnxHK54U1ZisWJzIc+1bQtCOg6VOlm3px9KdxKJmx24XoKuRQnAJFbdj 4e1S+OLLTbm4J/55xM38hXYaZ8KPF9/gnTltUP8AFcSBf0GT+lS5JGigefxwe/5irKQH0Br2qw+C RVQ+rawB6x20Wf8Ax5v8K7PS/hr4U0t1dNP+0uP4rpvM/T7v6Vm6iRsqcmfPmj+GdZ1mUR6Zps1x k8sq/KPqx4FeoaD8G32rPr94EHU29uct+LHj8s16/FEIYliiRUiXgKqgAD2FSjA4IODWLqvoaqku pl6Voml6JALbSrJLaPuQMs31PU/jWkRzxn8qmVEDZDjjsaZKx3YHQVD7s0WmiITnJyOlOByB2pw+ cA5J7UFTSGMx1Pf6U3Yc5NOcMADTTIT1PHsaAGHB4x7Gl8o7CcgDHapAgClmP5ikLBgdvCjtTC5W ddg2pmmHcBtWpsAHkHJ6HrSrtVSc9PWkO5Eytjb3qSONkHPeiMZbceKlx2BxTsBEyjkHPFFS7QxH JyfWiiwJkSxuwwcgGpY4kiALAn3604I5X5e3pT1Kj/a9+wqzlRG4HXcWHtUTOx4U4/2jUrAYyDyf yqAlWbKL93jJ6flUjGuqyDDs2Qcgg8A+tMlcMMbd/wDKmofnbzH3v22il+ztnDkAdfrQBEZGVRuO fYDiphmVBubb/s0qwqhPl8n2pfs+GyScscmlYdwPysNmDxXOeNdbfRvDc0sLETy/u1JPTPeunVAv yZwfQ1yHxH097vwpI0QLGFg5A9O9CWopPTQ8Dld5JGkdyzE5JJ6moD15Oakc88H2qJ/rXQYhjAyM UzuTxR1HB5ppwTyetAx+4elNOT3o+VelNJ5FIBcAdT+VNJGefyo6tTTx0pgO2hulMK8/N+lLk9PX pQx4wTQBGQpPHJpCpHBwPbvT+eCq5NMKueSpANADc44x+dMLHJwCaeU5z0xQQT0INFguMznhu9Lt 9uKeB0BFTMpKjcMY6UWFcrhT0z+VPEf4UPLFCmWIFVvtFzdErawnZ/fbhf8A69OwnImaRI1JJHHv VY3M1x8tvGWHduiiporJM7rljK47dFH4Vb3qo2qAAOwphqyglnnBnbeR/D0Aq0MhQFAwOOKcxB5I ph6jAx/Wi47C7j0zwafu5xmmbT1waXae/PcYpDH78j1p2cDJpgz3Ap4AHXikMepB/CpFxTVxn735 U78KYCgACjBoAz35qRImkYBFLE9AKAGY7Z6UoAxzXS6f4F8UajEZ4NKlEQH3pMJn6A8mu78OfC7T riMS6pe3DuPvW4jMWPxNS5JFKLZ5IkRdgEQsT2FdFpvgjxJq2GtdKmCE/fkGwfrXvFt4I8NW0Spb 6UkTJ0lVjvB/3utbtpC1rH5XnySKOhkIJH41Dqdi1T7nj2mfB26fDatqKRDukK7j+ZrsLL4beFbK EIbN5pP+ejuciu4L5BzgU3buz2Ppniocmy1FIyrLTWsh5cd20sPQI6KNv4gCtAxRqS3BI9qk+cfw gfWglRzwTUWLIiCeWAHFR7cdhj+dTcscL09cUu0BCvc989KVh3InTAzjApgRcYHze9SgBQRuLE/3 qeFfA6fTHSiwHH618PPDGuXLXV3p+25c/PLE5RmPqccH8qxk+DnhBHyy3j+zTcfotekHHcUoyw4B OKtSa2ZLinujjLb4Y+CbUqP7FWVvWSR2/QnFbln4d0Gxx9k0azhx3WBcj8cZra8ssQdpGKQhUyWf Pt1obfVgoxXQiVFQbQpA9O1PCnjjaKXJyMYpeWJGaRRISn3SCTUZPzZI4pRGVGc5HvQB8+Swwfxo AYACxI4IpDuHpj61KAmSNxz7UYj4PINAFcck884pyozEDcDTjtXBwAT71KoJHG0U7AxSAE4UACmC NiPvhT7mnsWUfNn6Go1UnJwcDrVEbDWUD70m4n0FQ5jB+UDPerGYugGCO9MYnG1Y/wAaLBcrfxc5 20YZsEYwO1TEZwhOATT9isvytgjsRSsO5X8sA45HqfSo9oLhVwMfrVlyy/LgZPWmDCgjbtP1oC4b NvGO1I2ccfQ0pYg8MCR2oG7PIHvRYdxEACnnj60Uo4OTRTAmMjsPlHP5CohFuAYtkdT2p+eeoLH2 6UBSD87bh6CqOaxUL/vMKuT0BxTvLYsDI2B9O9XiFxnAGPTqaikXOTnJx0qWNFfYgO4Kue+BilIz 2zj3p6Rgc8mlLoOvQVBRGASeuCe1OBK5G3p3p+xWBMbZqPJHXOfQ8ZoGAxKpEijBH41DcWonglgl 3PDINpQjgDFS+YuCBgN3FI8z9CvXtmi9gsfOHjDw9LoGtyQbcwSEtEfb0rl2HPfHtX094g0Kz8Q6 W9rcLh8ZR+6n6188+INBvNA1F7W7Rl7qw6MPat4TuYyjymJt+bg4oz2ODQcljjccnvSlG6kj8K0s RcbnHQikw3/1zTWIBwBSFmx93Iz3pWHcd8uOM00sB2Ax0oCluTxj0pQigZoAZuYnhaGX+InOaf3p AcHk0CG7iMevqKUMwPIzTsZ4ApxUDkmnYLiEAnnimlU6Lkmo5ruG3HzEGq4e8u+Yk8mP+83H5Cqs TcnluYoFy5UVW867uz+4TYhP+sfgf/XqeOxgjIkcmeT1b+gqzljQKzZVisokYPOxuH/2+g/CrRfH GMfSgjHvSHOPvCkXYQ4YHJ/OojkcE/lUuDnJ5pCOf8aRQxSPxp2eeOv0pdgPA7U5Y/WgBAATgnk0 7ZzxzTlRuKt2thd3kgitreSZz/Cilj+lAymEPIwQKcIxjk13Gm/DbxRfBWNiLWM/xTsF/Tr+lddY fByNdrarqZPqluv9T/hUOaRSi2eOLFkg4JFXrPS9Qv5RHZWc1w3YRoTX0Lpvw+8K6ZtZdOWZx/FO S/8A9aumigtYI/Jt7dIkH9xcCodRdC1TfU8E034YeJL0q9zDHZIeplbkfgK9R8M+Brfw4qSR3Kyz Hl2eFTn6HqK7DbggsetAT5wRz71Dk2aKCRKEAx6/zpQQOOppPn2EJ1z3oUNk5zUFigspPHXuaCC5 yW60GIOeefr0FOCFRg4piGcZwefT2pRtxubk/WnZXHHPvilCbtx65ppEkW4liMcUpzjnp6CnlNqj 1Jpu1cHIX8TRYLgTgDop+tRNk/d5zUjjcARgH2pyptAbdu/ClYpMjRT0PHFPCMRwQB70gmVnI2kE cZIzUh5+8SKAGHanAwxPc9KCzMDghQPQ9aRgoA9qRwd3HyigB29ugGf60hAOQVznpQpwPp6Uu/dw OnbNAxAMcYFNIG4nkj1NDOe6Z9+1O3HZ7e1ACBCc4xg+9OaN9oYn8jTXPHBwT2FAzgbSM0w1GkMr AgcCngjGWU4xwcUvK8huvSjDbcsckdRRYAIUgjg57mmYKk/NTyrbcj5RUTFt21Rn6UCFLZOXO6hZ SWzn5e9N3lRtKZFNPIO3r7U0G46Vg33fpyab5R24DEfzpyIVGScg07gAncNwOeaaJY1E8tDli31N RlwhLFdxPfNPPOXPGOtMJO7djC9qAFBJ5xhj+FLtxjNIiFuWAJFOZMd8980AMLBiM9+9BUnO1hmm uOeOaCWzz+FBQ/LKMnBHTk0U3LYIbge9FMCzNZTWX3huQ/dbrTVcN8uATVKz1HULEeTcKbq1H97l k/xrXSK1v4hcWMoJ/u9xVNHLcq7cdjk+tI6kcjrTpX8t9sgYMOKhkZnONwXNQy0RO4XILYqN1Un7 wPpT5BGAMru7cCqgl8uTAHDcetQykTlnAGw44600yrkBySevA6UmXyN4yPXFNZP17VJQ8yDAOdw9 +tN81jxgHHrTMKD95UHbjmlDr8u2Mv7mlYdxy/vRgknPQYrL13w9p2t2DWt8i7uiOBllNau6dx/r Nq9MKOBThCpChwCfantsJq+583+JPDGo+Hrt45Ii8BJCygcGucKsRhuB6V9YXmn2t5bNbXVtHNC3 DKy5ry/xF8KGcyXGgyDBOfIkP8jXRGpfRnPKnY8dMeDkjI69KXaDwK1tR0TVdJmMd/ZSwnp8ynB/ Gs/ZluVxittzPYgwM4xn6Uhyx6EVY8sg+1IxUNh+Me1FguQbcD1pcADLYFRXN9DD3y3bFVgl/e8/ 8e8fq3U/hTsLmJZ72KJcFgD6VAgvrs4QeTEf4n6n8Ksw2MNu2Qu+Q/xtyatbSuc09hWbKkVlBCQz KXlH8T8//qqby8nIJqbb06GlWJ3bCITn0FK5SViAgj6UAccHFbNt4Z13UMC10u6lHqsZx+ddDZfC 3xTcBS9vHaqe0snP5DNS2kWk2cMOTgjrTvL9ua9esfgzMeb7V1UDkrDHn9TXS2Xwp8NWuDOs90f+ msmB+S4qHUii1TbPn5Y2Ixt/CtGz8PavqDAWem3E3psjJH519L2XhrQNOwLLSbVCOjeWGYfia1hG gGcLx2A4qHV7ItUu5892Hwp8U3YV5reKzB7yuM/kM109h8HIVIOo6oznusSY/U/4V68u/aMDj0pw XOc//qqHUky1TitzjdP+HnhXT8MNMWdh/FOxfP4dP0rprW0tbSIR21vFAvpGoUD8qtEYGBz+FATc vyj8MVDbZaSRFgKeoLU9SfXPpUggOMsAAD6U5mRVGO3THSlYdyLdgANkH+VKQCM9M+gphwzZAOPW lxgAZzQUOCngA/nUgMmQByelR7uMk5p5kIQEde9CEyRtyr8wAz2FIu9xkjg9KAznk896A5zgcH1q iST7vfmjd8uXXOKaAQeTTCWAxw3rg0xEoKnnAx6Gl3v0X5RVcK2cngUM5ZwACR0ouFiQouckljSg Kx+dT09ajTCk4yW9KfuBx/KkMQ7eiqfoe1Nw6qGJJ/GpCpzwevakLEcAZJoAajKCCRye5pWILZVD z3xSFGYjcv41IFC9OT/KgCNeByBml6YLDNOxhxkE+2KceoY0wGEncQVINIUIPDZpx3FsgZ4/KlOB 2waAIR97k/hUpjz1J9xT0TPbGO+KNw3EEZ9xRYLjfLGAO2fWkaMsDg4pSoHfB9Ka2AAecUwBE29D k5pQdrHvn1oLDbwf8KYgzh84FAClgzHDYHYVHskJyhB55JoYGRuox7Uv3CF3HPqe1AAF2nGMnqaX oCTwTSLujJZmP40m7zF3njnHFMQmdoJbr6GmBixOcAetBLMc449aY7AKVUc9CcUhjmbkBSP8afBu ZWOeD6iq4XIG386sxsUj4amhPYe4wcBsUmxSck5qFpS7ZzjHBpybWcBs4NAW0HkqFJGT68VGNzIW UH05qZwFX5ccdajRndxkcU7CuQfOrYZPl9aKnYbyUJwM84op2Y7rqMl2sASdp9c1RkDRTCa0kaKc nJdOh+oqbcT1Utn8qUOpG1nwVHIA6U7nPYsw6nb3uLXU08m5H3XHQ0T2M1u5df3iEcMKz5YRMpZu QOzcClstSubJ1i8wTwkco5+YfQ96NxbEg6ckHJ6d6HhRclNqsRwua0lhttWi83TZVjkA+ZO9U5LI wy/6QGLDtUNWLuUy4wVKFh0JA4zSMk8iuBiPBwMelaEcOQdqgZOQQKbJ8qE984qbFXKiQRqMSsXI 7mpSYlTKjgdqjbmQqyn65pMMJOAeDSKLCMrL0Kj9aVYgzcfnTVIIyRj/ABqbfkZyVA9BSsAhDL2/ LpmmbmL5JJ4/Kp1Qnnt6imsYoiWeRVX3p8orjHtILqEx3EKSo3UOoINYF/4C8IXKtJcaZHAepaJi n8qp674/0vTJBaWbNe3bHasUPzHNZ66L408UMsms3P8AYVh/zxQ7pXHv2H4/lVq6IaT3OH8W6D4R 0wNFpOo3Mt5n5YBiT8MgZrH0v4WeK/EFv9qleLSbZvu/aAfMceu3HA+uPpXu2j+GdC0AbtNsx5/e 4kO+Rv8AgXb8MVr8sM8n1zVe0aJ9mmeHQ/BK/toyU1K2kbuzbif5VZj+DmqscSarbIOvCsa9q+UD o34Uv8I5x6UnVkUqSPIofgyuQ1xrWPXZD/ia1YfhD4ejYG4vLufHXBVB/KvSCJOoHHvSAHIGenYV PPIpU4nI2vw78JWzbl0lZPeZ2b+tblto+lWYUWmn20IH9yNQa0hG33v0ppiLEsWx9Km7e5fKkIAm OAAPSnKqk4KkU7ywFycg9j609VwAxxSKuJgdAPrzUigDg4wTnntTAjPnp161IqKrDLDj2osK6GMq /e4B9RTeNoVRU7SBeQBjpUbSYUjpnsKbQJgiN95jkenpQwTdg5P0pkgO3IGce9R5fcSBlvQmlsPc mDAZAXAHvTi7b8jA9MVGCQcnOe4xSbuOPvZyAaB2H7iRjnj1qNmVs8ce1HO7B604KAMDgYpARhCR hc7QM0/Zxjke1S4AUc9OhzTVlDErjkd+xoHci+UEDBz71IBjqfwpSBklRk0oh43M3PSmJhvYjpgC l3Agd/X1pfK5GWwPrT9gxksMYzxTsTdDQCfUZ/lTWwmcmnFuMA5poLHA4I96YiMK7EEYGetSLyNu cY7il3YO0Ljnink5GeOO9AxhyEAQ/MTTgihcyfMfSmgheBwTSeYob5hikMcuWO3cAvX6UoBXhskm ggcDjApSPlx7549KYAAOgJ3GlyAAMFu3FNLnb0xTAznPBz6igCwrbRhQM1Hls7n/AAqMSYPzZyPa lPzDOTQIcJGIwM5HrTQy7sspyBilUAD5yR6Gg4H3Wz9aYCgnOF6U0MdxGCAD1p2A0fz9fahUUHuM 0AOK7urfjTdhX+I4pC3boc9qRpMgjK5HQE9aYhXACkYI5pioXPt9afl2UDKg9wOmaBhRkHPr2osF xrw7eRkk9Mc01l2jeVO4dM0//VkE55529abnzGJIz2zmnYLkWcsJCQATSyE9jxmnGMFdinqajJAU ruBbODkEUgGSPjKA9e9InPoPqKekIOf3i5HbNLwrEZzjvigd7ihUHGBkdDTdu0tuPHp3oLMp55FK GzycHFIdhNoCjjj2py4XB6+tSBHxlVzmpI7VyMyDAz61SRLZCI/McmNjg+vFPjgcHlsj9KmlZIUI Hbtmqr3MuCNwPGQK00W5Gr2LDRoFO7BI6YWiqcUjH7xOPrRVKVyXGxQaVQAN7HsNvc09fPk+6BEv csOaeIAhBCDI7ntUqBvTNYXAEgDDMjsx9uKeIAS2xAPoKljGP/1VOHAAwOKaEUPsflSC5jd4Zwfv p1P19a04dVjaNbbV41VjwJlHyk/0qFySOn0qNozJFkkccEdQaYrFy5sGQeZav5kfU4PSs0jPHJPc GnxTXVg3mWrFof4o25/KtBJbbU0BUiKbuvQg0NDRkGJmHzfpR5TK2ce1W7m0urY7XU7f71Zt1dW2 mw+fezbUzhepJPoBU8rKuTpF5jYLZ5pzvDCD57eWB61y2reO7Cyb7Nbg3F3JgRww/MzH6Cs2Hw74 u8USedrlydI088+QvMrD39Px59qdgbNDWPH2n6ZN9isQ99dv8qRQDcSfwrMj0Lxh4ofzdZuzoli/ Jgj+aZh6ei/jz7V12laBo/h+MLpdmqSEYad/mkf6sefwHFaBdy+c5GetJsErmbofhnQvDyE6dZqJ iPmuJfnlb6k9PoMVtMzEHcT9Kg3HbjIIpQ+cY+vWpbKSHADOQQM/jTtpD5HT86jLEk4GGPU0BWAw ucdTxxSKJiec7cfWgew5J7UigIAS55p43Y3AcGkADIPI5pRuxnrxyaYCC2Ohp+1hk9O31p2AQk4H y9KDt6FgM9qcT3OM/wAqbjc3CgmiwDiqg+vHNISQAMYxTwpBB/i9Ka2AclvamBGQ7jrjB/ClDYY5 GfcUv4/SoznqQR7UAOZiWwcAUpycA8j3pCRhVIxSghSD79aVhjisijJwQabyW+ZfmPenEgkE9T1o YYVSo56HmgZWneaLHlRGbceecYGKmQKQCVxu9alPON2QxpV2H0BBpWHciKhT1/Cg9c9z0xUpwxwr AkUx/lPPftSC43ZJnr8voaeFyeGH0qIMzN8wwB+lOAIPbpzTAesnVU5GfSl+QAMSCfSofm5AA688 0KTn7oBFMkm8zIPIwO9N8wFSN3zdhSJyDlRn3oDAngdfamA4EEHnB6gUqnK7T1B60m71xkUgfL7c ce1AWH71YAJzjrScsADhV9qUAIpPfPakY7iDnaPbuaAAgrkrjA6+9PChhnqfek24O7Ax1prOewyO v0oAlZFUAhRmoyWbHHA79zTS57DjNIzsVHG3HpQNC8k8Dg/nSckE45qJpSvqM0ocMAUYn1yKQyUg MmSM+9AyV3A0AllJBx60BiY+GBxTEKVxgn0pDtCfLzimeYxTg9vWhS4AzjPfNA7EiPzhufTinbx3 J9hVYv8AMMDFK5yoVhkmi4rEy5PJHNRvChYnGCf1qJgAPl456ineYVwN3XuaYWHlVRPKG7A9+ady sDMd3sDzUG8KA5bce3akRmZtzjCt61SZLQ9XZssxGF4xihmkZ1Ih47c4qMS5baQAD07U7e6ZX70m MhRzilcdiSSURoNwKufXmq0jqqM0il1bqOhpSrTDld2efepBHuhIZtxHY0AJaXMEp2qjIVHRuasM BjIGfWs+3hkjuwyIAjdcnitDdGSVzg9OaAGbAU46k96Z8w/hHXtT3VgQCAcUANg5pDLkUqeVlR07 HtUFxcs5KZIHtUYUnL78fX1p0sYYblOW7itLtoiyTIC5x8+ajOCDycetIxbuD+dRl+QOntUXLsNc SA5QY/GipBjg9+mKKALGwudx/KnbcDOAB6U/7o5ORTW3YyCCMc0GJEZACRzSo5OAxP8AjTliXliT ketJzj5Qcdc0gFGetSjc4wW2ioRuYEbuPpTkTblicY6Z6VSEyXapYrjI7VUuoghEgZo2XkMDg/8A 16j1PXbPSrcy3M8aBRk5OK40614g8VyMnh638izJwb24BVffaO/4Vol3IZ1cnxB0jTInttcuoUkC kpuBBcjtj1rzfS9E8SfEG9l1G4uDYacXbCggyleCAFzxxxyfXg13Oj+B9JsJ/t18X1LUmHNzcc7f 91eg/n71qrp/9m3TXVhiNnHzAnhznqR6+9O2gX1K+ieFNF8PEmztGW4Iw083zSN689h9MVtZzgA5 Bp0OrWWop5dwwWfbhee/r7iq83m2TRpcXMcjMdoKDqfp2qdGtB2aepYaNAhOQM9aquEc42hfRgKf lwfmOfrQy5Oc59cVDLRWaPZwpzTkONxBwfT1qYIE6Hr3pCm3JHQ9qkoT+HJyM+tOG0rjnA6AU1M8 FhkipGwJC4P1zSsUIInKqW5x7dKVdw3A8D19aUy7VOc5PpTRh+QBu7mkBIoTIBHFPJVU6ZFRE4UF s4HcDinD5ugOOw9KoAYEDI6+gpoLg/OMZ9qd/EwwAPT1ppIznJyeM0AL5mFBNRklmyeVNSKuV+UD 8aTK79pGfX2pAIRuBJGAPXim4CoBnilI3Y+bOOaQ9AByaAFCZAP4U4jIORgDjilUMQFK89eO1OAA HXB9CKdhkXVzkHnoRTwqhQe49KkMYxuDYzUZkSM4ZiM+1IY5RleuMU1gQBgde1O8yMpwd30qNWDD cuMGkIVV2nqTz0FPEbkZY8djTdpyDnIHagZdiTwOw96AGthcAcZOKMkPgjpSnIche57UKwjyVAP1 FAxPmJwfl/rSgcHLf/Wpocs2cHPqaRpATyM0wsOwpU5c496GO0YXp1yaTBLAE5z6dKk2qoC5BoAY o3BiTk+1Luw2OOPSlGOuMYNHKtu4znIzSAcuChDMR9KjYcZ+8M/TFIGZnbLYP86jaVApDOAcjPNA x+4lCWPOelCs75A/KmtyAS2e9OTcMMvHPQimL0EIYP16+9ICQ/XJ7CpNwZjkAH6UzA3HPHNMNR+S w+Ygn0xRkgEKOP0pHUYBySfagBlTLDqemaQxQcjDYGKVuDhRkGoyzHIzj+tKG7jv2FADgFAzinBR ngjBpSSBk88VFvXOOc+npQBFIG8zjIGecUkSSNJ8/T1qxlSAQevv1qIsS3yjH0pgOmUiPYgAzxUA HlBl35fp61PnHzE5wePamOpYhz8p/nQIh2OV3MzHaewpjF2YL5QK+h6/WpnaRy23I9PSkCLG2Tnz CO3agY5pDGmSMt39qh3h33MD7DH9aBEzv94q565NWxEgXaoIPTrTFcA6heVzn1PSgsGXhcCkKckq QCPTnFMDBcDbjpzikOw4Fh93r1JppMpfLLR5hAOeM1Krt5eHODjuKYhVJdTn5aaQ/pkflRuY45zn r3BqRWweuRjmna5JGpOQWKg0MdgLFuO5NSkqygbRj6VEeWAyAPSq2FuRtIsikOF3f3hx+lR+W6g5 /D0qSQKpO4gg9OKgJJJ43e1T6loj3knkbvpRTlHcqf8ACigZffr+FOH3RRRSRzkSk+ZjJx6VL0Ax 60UUDJYgNx4rNv3dVl2sRgcYNFFaxM2eNn/TPibaW15/pEDXCgxy/OpHpg8V7YoCRbUAVVyABwAB 0FFFDEWE5GTzxU0gBjbIFFFNAzlb2KOOWby41TaVYbRjBJ5NdJZASWTeYA/yZ+bntRRWf2jX7JAh JgYk9GNOBOW5oookESaJVEZwoHTtUR5LA9N1FFSUQ9yfaorhiJLcAkAnn34NFFQUifA29O1PTgHH HFFFMQ9uGYDpxxSn/XMPaiimMd1jbPPNRjmXB6ccfgKKKBIWT/W/hTB94/h/KiihggTlcHpzU0fH 4UUU0NjXJ+U55/8Ar0yT79FFJgiUfcFQyAZ/E0UUhoewAxgAcil6McUUUgFH3abITt60UUAOUDy2 OBnFVH5HPPNFFIoCSJWAPGKlj6miijqInj6moST5jjPGaKKaAVP9UPxpW+/JRRSGJGALdSAM1AVU suVB6dqKKYEDE/bY1ycelXATuXntRRTEx+BuHHrUXr9aKKYEkfJbPNSAA5yM9aKKQFYcwsT1zUsX +roopDF7GoiAW5GaKKaBjpOOnYVEoBCZHeiigBsPMoB5HNS3BIiwDRRTERN90fWmsT5uMmiihAJH weOOKtKSW5PaiimAjcO2OOlRN/rgKKKQE7Kok4AFLMBkDHFFFWSRDoaOjjHHFFFIZZUAg5HaoyAU bjpRRV9DMqXpPkS8niNv5VUQkxrkk9KKKh7mq2J8n7O7Z59aKKKYj//Z /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAUEBAQEAwUEBAQGBQUGCA0ICAcHCBALDAkNExAUExIQ EhIUFx0ZFBYcFhISGiMaHB4fISEhFBkkJyQgJh0gISD/2wBDAQUGBggHCA8ICA8gFRIVICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICD/wAARCAHCAlgDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD5SOsa ip+bUJs/75qSLXNUzhNRlPsWqSNNObe39nBivbe5yfzp8kVmixsun2+XzhHaRT/6FzWeh1fWKid7 l228Ta1APmlMq/7RP/6qnn1ODUbWIpCyXSk+YQiruz3+UZPTvWak0LjYtnAAACCASD+ZNTx3Uiec iJCNq7vljXjB69PrWdkma1Kzqws2TCy1JlyLOUqed2xjUdzp2ovEd0cUfHR2RD+uDVYXBllJKKcg nJGcH0qvJLMcFcpkchYwcVaZxcqLEUkrJGs0u9wM5DbuvPPvz0rsrJTPpzYPJiQ/+ymuIgZxLgE7 iuc4wc13nh1DPbxxOCWkidB9ecfzFJ7ja0OLUiNpleN2kKgIQ3CkMM5H0zT1dVcnBPsQDzVy7tfL 1CXOArMSPpmqskIxwwH40DWwwyMXVjgEY6cfhUkcgjnWQZAVgw5yR+NVShHVh+dJkAfeBpWHcs5H nFztIyePUH1pAdoADbfQiq2QBy1G4H+KgdztPh5P5PjvT8vzLujPvlWxXZeI4PJ166U9Mhh+Kg15 34TaKHXdOvzLh4b+3j8v+8rFsn8No/OvVPGkHla2GHHmRK3XPt/SpexMtbHB6th9FuExnKZH4MDV bw/p17c2qy21uz7Ofl+td54HtNMvPE8Ueq2Ud9EofbFI7KpbHGdpB/Wvoux1XRYbOOxk8OWK20a7 VjWIbQO/BBrVPTQysup8weNo/L8V3LYK5umb/vpj/jWd4uTOoQXHXz7dHz610/xN8u88bahLYW/l x/aFKxgfcA29hXner395d6nDbXkqxwW5WFMABmXjj3xms5u25O5SjAFzmvRvDiNceB9Zi4wokP5x 1wtvfWd5fQWEFh5UZfEkxO+RhjsOw9vwzXo/hW1a10bVLa5YQi4ACBmB/hI5rnWIgtJ6eo+Xqjyp 1D2R3AMoRlI498Vx0qlGKkEfWvUoPDk40x72e4VIU+8FOd27lV45GcN2x8vuK4TWdLmt5ZJ5blZ8 sBvUEhic9/wNaU69ObtFjs0tSNvL2hoCxiYZQvgEj3A6U0nioYioiUKCBjv607NdKJZNEea7rwW4 ivLAyDEbXXLHgD7veuCjPzV2nh0Z05SOpcihoSdihfRSR2lqJUKN5eMMMEYNZkGl/wBq668LHZGi eY7H0ArpvEEQ8uBwACxIJJxk/wCRV6KKy0+xlkgt/wDTWjwxLBs5AOfwGRxXFi8R7KFo7vYGtTnm sWs4oI7S1aZJ0K8DPzbzyMDJ4U8e9V7q3mkkjFxLuV2G5ouR745wCMjin3N9aPeQuZGjeEbgy7WX fgnp154H51QtbySAT2ctskcj8lmYhsEglcHjqAa4oKfxPcjzLmqatbTXCR2MUiJAoT7xYMgAH16A 98Vas2E9zbw2QRfnx5r5IJY4ywPpj9ar6baRC0voYmLSeYuNjcqvJIPsAM5Hp71ptceVbqzzMhIZ kONoYYO08843Y46YqJtL3Igc66Xxv5XWHzHZS293JYg98555zXb2cOy1jEqAu0QR9wzngZB9elcn bfZBqscc8EctqeZInZg2QP4mC8c8Djgn8a7WPaUXagjXHCA5C+3NelQd3ZroVE3NTlkj+FV3NGwD wXqNuzjAO0Ejpz8x6V5C0o8xXhctu5MTcAqP9r/PSvXrlpW+GOtrFKIZInjnVwcbSHQg/wDjteHs RBKp87duUl2TPQ9ug5rSUE5XKmjr9M1VYtLRxEkDO7RLN5qFlOMkhTyvVBngYBHc13OhXp1DSxMx UYYrtUnCkYzgdB68cV4rb3IjkHykIDnIwG6eteu+CJHn8ItcSBd3nuNwGC3AOT+dEaajK6Jjubei Teb4LvR2Zt1c9CQVxWh4WnL+D51zjcvT8DWdbqzsqDkkgDFbT3NI7Grep5em2UOMZQPz7jd/7Mam viToNiOdqswGfzpdXGdRFvGeI0wMDOB1/wDQcUXZ/wCKet9udolI5HsaroC3Mccml6k0gPPSlHzE Ack9BUFFi1iZp1Zc7lOVIPftXpXhm0WzjjlP3+p+tcv4f00O/muMqhwCe5rurWNIowq8AVu1b3SF r7x0Y1A7RzStfO3eshXAFOMlFhmj9pdz1oYkjLNWespHIpxuDigZmeKZjB4b1CaM4eOB3B9CFJFf PHiOaOw8EwwWVtLbPrNwt3dbk2gKqAxIv+zl3f3yvpXv+uyWz6bcQ32/7LJGyzbDhtmPmwexxmvn S81yTxF4g1BdSPk2F+cRr/BaAcRbR2CjAx6ZrN73G9rM452LDOc+tdH4OVo/EEby22fNjdEZsjac ZJHqccfjVJrC3tNXaCYzYth+8DR5HmDtwfuk9/0rS8LyyN4mgzIxWQOSCOvynp2qVLsZWsUNfZV8 R6mwdo28w4wev+c1ighhtU9+eK1/EyhfE2oOQD+9zisgKQVdTg56UDluIfvdOB3q8s/2QmQQ7ZWU FcrjbnuPwqmzseqc013kYkuSScCk1fcQSzvNNuccn0AA/SlG5smMHCrlvShEDMGkIA9O1SIsbykb RtA9OtG2gyNW2qwxyRgZFTidxDt3knjJPXgYAprq0hwRjHHy9KYqKHGSAMjr0FLR7iJkAIxIu1c5 rSty3lgDDRgnHtms5VZ2bH3T3A61ftoyiDGdvv3qbalInbBJwMUL0pKVegrZDJF4r2b4I2219ev8 f6uKOMH6lif/AEEV40o4r6A+C9rs8G39wRzc3wiHuAq/1Y1cSWdtehIpmLAYX5WxjJA9Py/SmQtk +YQE29AOo/8Ar81JeNJJNJI7DarE7SQdhpiIViAO072xhuMd/f8A/XUGwqqrq2ZFx/e3E801snES ybsDhVGAfTmpYRIkRO0Mrfdx82DzTWR3kBKYbtzk/wCA/WmA0qqRqcHC5OTyfr7cfzxRR5Ab5cGR s4wODnuf/r+9FAWPkEW5jiDLwPbtUMjSMqg7mCfdBOdv09K21vFiP7q2iOPUE/1p8tyQx2RxruHJ CA0uQjnMDDA8Jye2KULLzsiYkDoFrSS8na4DMMt6hRkfpUQ1C9EuxpG2N1wKXKPmKgSdm2LE270x TltruViqxMCvXPGKsPNeySKsbyY7kE1pWmi6/duZLPTr65THWOJmxRyDUmzOh0u4N/FE52b8jOfa ux8PqLC/slaTftm5/T/ClsfhR8RdVdJLXwteqMht0yeUD+L4Fa+reA/E3g2K1fxHZxW7XTFoRHIr kFcZzgnB5FDirCu1ucz4ltY7W9ZMhWjlZOfQHA/lWC0EbFm+0IO+MV6Zo3gDUviRqk8VvqNtBNbq JZGuGYbgcDjapz0/Wu5s/wBmXIBvvFUa+ohtmf8Amy0K3UEnY+dJre3AH7/k9RtqlLFGjfLIfxFf X+n/ALOfgm3VGvrrUr2VfvHesat+GCR/31W9H8F/hlax8+HGlbsZbiXGffBouhpeZ8PpGrPhd7eo VcmtGx0WW/yYGICjo4wSfYV9nXPgz4b6Havd2/h3SYHhQvvuMuAR3+ZjxXiXijxXAJZU0vRbW0g8 vfGY1RSBuByeMgkZ/PviuarNr4SlY4mx06e2ht0vAsVulyjxhFRmRgM9Sc91JGfwzXe65qWnX/ka nLcxxwLHHlG4dixPyjpnAya89vdXnjs4LyK3C291GfvHcXKNknHoGU9evXODxJY3MV8tsViGyIyC KKZ9nmMmCQjZyH2spAPfnnJrmamw66nbQQgec2jTwyxqATKgAftzkgEc8YHPFC+I9a03Mk+r3NvC o+Z5HLheOp3Agdh1zk9OK4u51oPrwudP0uUJAQsqlCGlbuSB8oPbI9B61n69fC41O7t7rzLC1RX+ WMF/MBPGR2bPBbOOMY71VNST5biqPS50z3ralJJfvKJTOxYvkfMfXisDVrHSNRuI7K4W4inRDKZk KiNEH97JAHAwPfHXgVd0LLeH7MlCuExg9sZHqaoa0ks1zFZSXotLO4VmuZAm4lEG7AHc9f8AHrXb YxexgIi6bqMEun3vmzqSuGXIGc9CrEk+1b/hrxnLpeuE6ratqMat92Nipfc3TK9QSeep9KrWMVnI lzLpghRbMrDm4kLPgkjcFPQdzjuffhusa1Y2ekJbWGkiBZm83zJpPnL7srIoXBwMEAHI/GsZU4VH Zq7C7RsX2o6ld6tbWCaVcRyO+YzbRErncASVOM4KkHnueRXJeILa3LwrDeB0L7RGhJYNgAsRuIGS B35J44HFZvEUsU02Y3d5Nzb2crlj/EQPcLxnt7ms1b94b17qKQlnOG+ULnPJ4HH4dOKdOgqfw6Bq 9w2+WCo3YBOC3UjPGfT6Um7nk1Zur+71CJIbi6d0Vt6iVyzZPU5759/pUKRxPEFUymbkkbRgD88+ tb3EIjc12/hw/wDEr3ZyN54rizIYYDFiaPfw2eA2PUd67rwnbi4sYra1fzDLLtDMNoyccfrRzIEa dytvcpuvh+6iQ4Gcc4IB/Mg/hXPeIZbaC7mhtWDWpXdGyR8njjk9s559K2pZ4SGhjDCUxLOQeMo3 QexOK5C9vpX0+B0eKOIs0JBO8g8EnnOOoH515laDddPp2CTKNhZRTxzX05xFCygYwPmOSAc9uD+d asdjYR7prmVRgso2g4GT0zjr97jjt1rCso3ME8kjyC3A2jZnliRx0x0z6VJNp97KVPzzGRN67/vN jj3/ACzWk4tt3lZEl221u6069MnnGSUhgecDPOCcjDfjWbJqUs7lTK0ce0IqZ3DH/wCvmqziRS8M sZjZGwQ3UH0qHaschxIGHUcVtGlBO9tR2LL3tw1yZd5Uv94An5vXPr616tbuGClVYHzFh4/vHp/+ uvIAdzqM5zxXssDJBoms3RIBtDLMv1G9R+uK3StsVFFqK6ivPh/4iMJJjezDIT3xuOfzFeKidiSW 5B9ea9g8ERi5+H1/AcEtp86889C+P5145zjOPlIp2HLWxet5bP7PJDcBgxy0bqM4OOARkd8c5454 NeueCkYfDb7Rjkyzv+QH+FeJgn8B0r3TwsjQfBkSgfMYbuQD/vv/AAo5bCitSp4MRpfC86qOFVif yp2ip5mqWo64cP8Alz/StL4WxJcaDqcci5P2ZyPY5A/rSeEIPN1pWPKxrn9QP5ZpyKjsLOf9L1Sf tGPJX89v8ga1Lyy/4t8l8O12E/8AHaxJmCaSGJ+a6uGf8F4/mx/Kuumj3/CCZ8n93eIfplV/xoXU bPPxwMZrU0m3eR3dY0O4bAW6rk8ke/b8az4YWldY16nv6V6F4S8PvfvlRtCj5SR+tXBW95kvV8pc 0yyMcKwxDdityK0nYgBPzrW0DRJUnnF0jKycAevvXSWmmwicgxg0tWaaHJx6TdP3Aq9F4emf7zkj 2Fd1HZRr0jA/CrC24HanZhc4yLwyP4gx+pq7H4chUfcWuqEIHalKAAk9KLBc8Z+I2mvZaHqd0gXy IbKQsfcq1fIX2u6itJrOOeVYJirSRKxCuVztLDvjJx9a+2PirGz/AAz1plXLzROBj6ECvjq30K6n jWbKqpbGD1FTezJmrpDJt2q6MLzB+2WSiObHWSPor+5HQ+2Kd4TDf8JRaAjjD/8AoJq5a2N3psq3 Sx+cQxRoQMiRDwQfYirmkaaLLxtbeW5e3lDvCe5XaeD7g8H3FSnZkuLsYPiP/kab7IyN/T8BWK7E yEgbSPWt3xOgXxLfHP8AGP8A0EViFMEfKdxPfmmEtxfLYqOcEjPPFKoOSDwR04zThAxXzGHA6n1p zRMQXXq1TcSIkGJNjAjP61afHlkKuGHQ4p8drIzISpGeR3FXksSql5FDNjhfU1L1GkZAI3Z5b5vS rMUUUz+Uucc4dhyeeOO351dS0EcyZ54JOBxmp2RcggYxTQ7FdbZFXDHd+lPPpinvnPNRmrSsMQn8 aUe1MJ9KeCfxq0ImQ8ivpf4YW7Wvw10pguXuJZZsZxkhmA/9AFfNEfXFfVnhQQWnhrRdOhIlMGmx zOUcZDugJHty5qlohLVoutbBSF8tW25ChB+uenXPP/18o9sSDvDscElxjOPRf8/n1EpJWTaAIxgc s2cfTqP5fWmofk3BiOT1HT8uazNhYlccBDgHGcfr/nNMk3CX5cgZxgdaeH24wcljnHvTkyGZgRuO CWY8L/n0phYlC749rAbDwQQQT7DvRSLB+5VSWIXJz68ccDk/p160UwPJLD9nHx1Ph7q90qxB6hpG cj/vlSP1rprD9mN1bfqHi7BPUQW2f1LD+VfRh44JOKaR6Yp8zM9Ox45Z/s6eC4cG+1DUbxh1/eqg P4BSf1ro9P8Ag38OLHBXw3HOw7zyO/8A7Nj9K77cf8ikMqoN0sgUf7TYqW2O9jLsvCfhfTQPsHhz Trdh0ZLZAfzxmtgAKu1FVAOy1kXfinw1YyCK81uxgc8bXnUH+dYV78UvAdgcS69G5HaKN3/kKlyS 3ZPP5naeaw4xn3FeQfHeFZvD2k3YG4xXTRn23Ln/ANlqTXPjToP9nuuhJc3F1kFPMQLG3PIPOcYz 0rxfVfEWravc3n2i9SS1u5FmMLSFnV1BHH4H2rL28FJRTJbvsdV8HL9bL4lQW56XtvJCR0GQNw/9 Br6ZKMeV/KvjDTtQu9I1a01Kwl8m6tpA8cjDKg9OR3HtXWt8RfHNzMv2jxuY48jKW1kqE/jinKpG HxM0voj6fFvN16fjWffMunQz3V5exCHaWxI4ULgfrmvnSXXNQv4Y5bzxrqEm48pvcKOe46Gp7dLg 6K9tYXGlXTyhhm7JMnbkE8+vcdqzVaEtgO58V+KNKitbjbfW2oRxxb44osPyOMt2HI6deR9R8x67 Ks3iRJpCPLyZJE2cKo6d/mzgHHHXGa9murDxPqOgNG1nGIomVRb221tyIw2jKEkn8q8g1Nre31OS CeCZCnMryqy5U4wCpAI5B61i5NO7RfQyL/WtQ1zVmnuzLKCFjiEQ5jjAAG1ewAH+c16S3gW9mihu NTkaErMbhFmYZ3SDkse3AB59Py87srJ1LajDDIojYFCmGzjkfK3OOB8w6fjXfS67q9rY3cgie2u7 uHOZpN7sDyxAxgAnHPb1rKreTVnZFxXu6LUx77RhoPmPpDRalIGKsXGFX+95Z4cn7oGeDyAK81ud SN1qpkvmbYknCMuePQ9PQfrXoWm3eo2Xg7V76N/KMsiASjkkjJHIHA4BH1ry+S4E12ftEhELvvfY OQfatMPfnldbGM1tc7vw9qVnZ+GlkvLkIi3Dx+ZyQzH5uPwpviqMTWcQg8xpQ6sABzhlJGee4xXO KFPgOUKdwi1NSCeMgxtXXao12df1K308sbqOG1ZApIPCAMOOcEE/nXZcVjh7JtR0fWZLWVTavLGY 5UeMMwRl9+hwfr+NP1P+z2sLS4tkMN+q/wCkqwPzNk4KjbgAADuSevsLOn6bFeSXM13dLa+TEzFQ BkqehBJ55NY19PcXM/mXEgZlwAFUKFHsBwKFJOTS6GdioWLrhn5HAzzxT7aKNrlVnlMcY+8wXcen YetLcJFEV8oluASSQe1OGxlDjAPYe9aNlIv2QtsATtMU8wZiXGCnc7ux6du55GOYpFxK/lsSFz8w Oc0Q7llRETex7AZzU9zExjMcSqWQbpGB4x7/AI8Vn1EZxmeThjnnrXpnw2AaSAngC8P8krzHAUEj tXpnw4y1nuAyRcOw/AJTexUdxs80A8Z6vA4SRIbdI1RuMhUHv61zWnx6Q73X22KffvV0Ma7ggByQ SeORkflW9p8CXXjy81Ke3kktpZ5kGB8pXeevtjj61m6hZQ6ZKsMcm63nBl2AZYYY4V2BAJxnkdM/ WuCs4uVk9f8AIl9zLdJLgAaXKsSKzHaF2lNqg5Yj15x9KzoL67tXDI7rNHJ8rjjYfY9c8VdhmFl5 8qjyo25CsdxOTkA/Tr71HDPafZs+ZmV2berAnbwMEdATndWkdFa10SZk001xK0kmd3QnHOaaYgsR LPz+dEpCOUTkDoemaiBwpHbpXWlpoMlhQPNGoU5JAr03XZmtvB2syAn/AEi4Nuo9czux/RDXm9oV N1CnJy6jPfrXovi3YPhwjn70mryHPsDL/XNPqUtjovhMBdaPJb8E+XNHj8Qf/Zq8VOVJD4JXqK9o +CLbnCAcCeUH6FE/qK8h1GIwaxeQMMGOd0/JiKYPZFUIMZGSc+le9aSFi+CFsCOXsrg/mzj+teC8 ZODg/wAq93Mb2vwXsZXbEbacFB7Fmc8fXBFAolv4MKszXMDdHgkGPxWpfBqiG2vL1+Nu1Mn8j/6F +lVPgnIy6yqFSpeOXBIwDxn+hrSslXT/AAwPN3Dzbl87RnhdwP8A7LTkUtjA1XEb2lp/zwt0Df7z fOf/AEIflXdwLv8Ag3qX+zNE3/oFef30nm67cSFflMx28fw54H5Yr2f4a6BF4m8OajpV5J5dkJ45 LhumyJcMwH1xj8aSQ29TD0/wTZ6d8NYNZ1NJP7Y1mYCwizjy4FPzOR/tdvbHrXpXhXRY7HS4/kwz DJNZdxOfFXiybUo4/L0y1UW9pGOFSNeBge/Wu5sYwLYDFW+weZXaERTJMBx901NboPtRqw8QkgdT 3qtYsXm56jg0wNZVp+2lUcU7HFADCKr3RKwFR95vlH41aIqq48y8VOyDcfr2oGcH8UgI/AN2mBja BXy5KwzwOK+ofi6xXwLc+5FfLUh5zUPcb2IyT6VB4fntl8QC0m3bYXeWBjzglSGX6HOfwqxDbz3V zHa2yGSeVgkaD+JicAVneH4N2vBn6gMCfepF5mX4ntZh4gup8AK7rtJ7/KKrppRuLeFw2xicnI7V va5ZNN4gldz+6AUYzz0HFRxRrDGI487R0BOaSE1qV47KGFSn3x/tc0ptbcY2xgY5qZutMY8+lFkM YFCIEA4FMY0paombmmAhPOKjJ56Upb0qJiKYhrHk0zNIzgVCZO1UIkp6nmotknDEYB96eqsSckDH vVJCLUILuFUZJOAK+xEgjsIBbxIgaKJIAenA/wDrLXyb4UtTfeMNHtMbllvIUP0LjNfWtx85fPJL 9M9eM/1pv4Qj8RnqwLkqVO7+JcOcDrn6nt/kNYOCqbm55zx0HoAePxqfyy824ZL9Nqso4H64pkan zvmAkY5LBWzs9Dg+v9KyNxIwCyg4yOqqMYPGTwanX5Cp7gdBnk/n+tNO1ZSuFHoAevPr9f5VLxuy ApULnOc9egpgKWKKNxVzwMKePz/LtRSxiMKC6AkHOQueaKYHA3Px+8Y3G4WnhzS7Jc4BmneUn3wu Kx7j4vfEK5TJ1a3s16EW1qv833VwAlwTlgGB6d8UrOQCCCyjsa8aWLqPY5Dop/HnjG5ctP4p1OQ9 9s3lj8kArLuta1a7f/SNQurjPJMsrP8AzNZjRoMHOMnpmowqg4G4HHvWLqzluxFkzlyQ0uT0IJ6U 7zYRwwVmAyMj/GqgbkB03A8YBwTTiynJCbR0I61F+4Fx7khhkIAeCBwKSKVmuFKgAse3PFVUDMo8 x8A847E475qVEWNFYSbSuOOp4qoqzTQJ6mw8CvojXzSMrBlG3AwOR/Ws/wC0pEzI4bI6HFdDa24m 8NakjHGxXccf3STXNyqgIPzZccEDjP8A+quvEe8tTSZajul2goM5ORStcTLhwRk+hxisuMhCTyVH T0p++dvuuVD8AegNec46mfMzpLDX9ZtowLa6mQZ4wc4/Srt1471S6jit9QSG9VBwk0Kvz6+1ci0z RKAxccHIakFxG7fvgFP+yOTVKpUjs9AudofE2iXMnm3GgRKcggRykAY7YORiqeraxoeosITY3EaS YEo8wbDgHtj1JP41zCz25A2EN1OAMc/Smlcn7u1h6j9M1XtZ9TRVJdzp77TfC1xoNzBZXDxXDS7i syD525yuR91QWJ/H2ryO+8LahYa2LWa2N3GfmIs235GCcA49PrXaFnVFdZBj1ySfypyXtzbShopW Ix8w3FQfX+dbU8U4vVDdTm3ON0yAy+DtRgKkFb2BsHrzkV6NrNrp32rUngMkly58qSTGwodpGxBw WACKc9ievNamla3HcRi3bT7VIITtWKNQynewGcH3I5qDxBqWlT67PaposUVzFI8RuYyQ0hUkZYA4 ORntXa6qkk0XzRSPFr24jW8vY2twivlAsbbQuDxnHDYx+fNUcr0IBxySep9q9Zu/B/w/u7fzINS1 SydGAZpdsxc55bGB69Pas64+HGjzskeneLLcbflPn27qWPqcMwHp2FbKpBdSNO55q+wEbDuJGSew /OpYmVFOT82a7iT4W6uspMWpabcwAbg0VwASMZyA+3NYuo+DPEmj3GLnSLlkQ/fVdyn8VyK1Uk9E FjPt7x7QsLY7Z5eDKOsYPUL6E9z6cdzUTRqhK+ZuCrnI78VBJG8cjBwcrknPBzVyKZ1ETxRDdD+9 ZsZzjkZ9uAPxot2FsZ7fKSrDDHrmvTvhcQwhiA4e4kB/75SvLnk812fpzxzXqHwuHkkTuSqpM4B7 ZZUUfqaJLQqG5qx+GTZus1sSirukPmsqtKNxDYx1Gc/LyRjk54Hmusu/2ieF5T5aSHYmMAc9B6c1 3un3CzC/sI7jy5lu2kmxGGZxuwPmPQALtCjvkntXOapo01z4laFFjMczFxJM3yJ3OfTr0+lcTj7O TlImRyE1xNdTqZ53lbbtzIc4HQdfao5kEe0R5wRkkNmrt3p7w3Dr5kYUHALOFz+Garm1hRQZL1PT CAt/SuuNrJoRVzxhj70hQ5yRx1q0RYIAAJpWH0T/ABpXuovlVLNT2y7McflirANOQSapaRnjMyfh 8wr0HxeWm8LQWUKO5juFb5VzyfNY/wDjzEfhXEaRcSf25YqRGqmZOkYH8Q74zXoWuavZ6TZRte6B ZaxFNIB5Ny8qqmA3Ty3Xn5qfUpHU/Cu1tbHVbRLeIxedGJJASSS+wep4ryfxfaQ2/jrXomuY0Av5 /lAYkDzD7Y/WvTvhxr9lq3iu3Sx0xNOjjKj7PGzMkYPACliWI+pzXI+O/CuvX3xP18aVot9dq12z 7oYGYHd83UD3poN0cTD/AGfHMhkaedcjcFATI9M5P8q+jtF0y31PwPpzQqIbECNEgncSPJhA2duM YHGScZPSvG7H4YeLrmeOK5soNOD8lry4SMqBySVJ3cDnpXufhqXTbjy9JsbtZLiC3SOGPoRGnAOO xY5Y/wC8BQ9EEVrqV/C0C2nxOtoBLI6uJCEfGI8xt8q+3HSq/iQvYXUdjAxQQpNI5HQAybefxX9a q+H7mUfGnbdFoWS78oIw6qYsAj2PX8ak8azj/hJvE3l8rbxxQr9S6sf1Jo6FdTHg8TalYtJZRQWE kauw/f2EMj5ycncyFs/jXt1tbXfhL4Z2WhKDHrniLFxcqBgww4G1PY46+7H0rhPht4Vttc8YP4k1 ZANC0yBL+4Zh8sj4+VPxYEkegPrXpeiLc+JfEl54n1AE+a58lSPuL2A+gprTUNzV0nSU07SY4AuG Ay31retAPIomj2w1JaD9zTQxyj5WrPtMLqTp681qBflNZLgx3wmH8J5+lMRvKOKXFIhygI70/FAx h4/Cq9qNwkmP8bcfQdKfdsVt2C/eb5R9TT41CQqg6AYoA8y+MrbfA03uy/zr5bkbDE19O/G1wnge QsQB5i8k/wC0K+V5ry2Q83Ef/fVR1G9kdR4SgtJNVur3UN/2TT7Oa7kKcH5VwvPb5mWub8PAf2gj 8jezEZPsauzeUPhnqGoQzrm6vo7QANyyohkcY9MmP8qx9A1CE6paW2SZORnHH3TS6ib0saOrtnVZ f+A/+gis8nvSeINSFvr1xAIWJXaM5wPug1kS6jMH/wBVsIHAP86QN6moWxURYdzWUdQum6RqvvUT 3F2eC3PtQK5qs4zgGomasktdt/y2I+lMKTH70zn/AIFTsBqsw9aryTxg/fA/GqXkjPOSfc0eUoHA pgOkuY+zZ+lS2OyaUk9ume9VzEO1IqSRuHjJOKpMTRp3SMTnOxOxpIkPDySHYeB7/SmxXokURTAk Hg7hitMC0e3wGVQMDcTjHtVknU/C6zW4+JWlLjHlO83/AHyjH+YFfSs3zICrMrZYfL1POP6V4N8F oI5fGtxKBn7NZyMD6ZZV/kTXu8wfyIXRmUsAcgZ65P070p7FQ3bItoWLL/KqHIUAD8T054qGKZN7 eRgN2TP3T3J7E4IP4/Spm3niMHjknBOfx/8ArU3YQ2JmwxAAYDBOM/41kbggkfJ2kEnLEnGaXY7x Y3ED/eyAe3XPrTo0OOcEZHzZz39aYcF0ZmUEDI3Hgdf5UALuaBBvZwB8qnbnPPIX9BxRUojEKs7k FyNo4+b6A0U7hY+ZY4s5ZjnHc9ae9qUkGZCW4/KnFDGCWGWHp0p6h2O0Qn1IHPHtXzmr2OIgChOr KB6HnNHmJtCnZxxgdzTyY2JBCDHQEdfahzECqgZ44IHUUWEJsVicsAQOuaftUD5W3seAcD3phYsu 3y+vUk8DNNCkkmPJU+tCEKxBASZCX4ALHjHpinMg+UiXGRyepHqKFCt99iPY/wA6UASspZdjKPm5 61Wg7ndeFUF1BqNsTkNEfyZAK4t5tsKlGBXIz36e1dp4DcLqVwpyVMKfX7+K47ULQJc3VuykCKZl wfY4ruk/dNp7JlTzFBD/ACbQ2SD/AICms8oChiVOR83cZqJljAJk3DimLcKrbUhLbunJFcRgWJGJ LFpGCkk8nOf85pCEljAPODn3pPtUKYZkYcemccUMwk24R1XPUdKkAMcLHO0DOSRuJpY145cSegNI 6RMCRyVOCxNMV0Hy4WP+LK849s07XGWRDvGRFkk55A5+n5U0IHYBQdwOCgJPt0qMTEsQ5AwOpYU+ FWeJpFwxYcheuM/yzS5e4G34YgQ6ukG3DPJHkY6fOvFU9SaCbX7qfjJuHbP1YmnaDdjTtcS6kgke OJhlN4XOGB9D6f8A16rxMqX7hjlmz8vv1rq5G4xSZe6RDNZI0zHzNuex+lVJYvLBC7SM8nvV+/mS KZQ4diy7uvBPT86oG8KoFMSAdyeTWU4tSdyWViLwlTHcsAowpJ6c56fnVtL/AMSwIJLfU2UMTu+T Jbjue9It4ykEIozkjIA3CkN48z7Z0Geo29auNWUPhFoU9QtbnVrqJ7+QySBBGoBALe59TSadpHh+ KSX+1opZ4Sm0CKQxlT6k45/+vV5ZEVH+aMMwxjnI9cValaAQNAyMzF8ltuQABkVosRPqxpkL/DrQ rpZ59P1CcBDHHHBHiVpZHJwqnjgAZJNaVt4U1fwfLHp+p2f2e4kcSookD7lJABJB4OVNN0y9uNK1 FLy0dQYyDGJE5HbpXUXmsS+Jm/tW/bbcWyqihBwQDlv5k10U8Tzvle5spXOZFnoNprWoS2PiVby4 kldZLRrIwvHhjk7gSGx061yfih9+uzJHMqNHErKu5mMgKrnsQPvHH+6e+K+kfEvgPwZ45s2mt7SK xvmB/wBNt8Lls/xAD5v5+9ec6x8K4l055bi7CNZE2010IGcfu1AHT7oIOcnit5Wauy+Tm2Z4Jcyh 3Ksu0E9OpHtmq4XBI3YzXbTeCLqKJ3FzbhWCOtyzskao27rleenOPUeoriHXa23hsdx3qoNPRGco uO45cs3zDIHXNMbgghhj+VNVWwT/ADpCpPWtbCsbXh3974l00E5H2qIfX5hXr1nfeANI0uG48W6Z cajbja1ssSB8swJbIJA7Dr715H4TXPizS0/6e4j+TCu/8SQrN4C021CAyyQtcIcc/JHCSPyZqS0Z XTQ7rw/458G6/wCIbHSvC3hBNFEEizNcbY0aQbgu0hB755JrvPEPh3xpr2o3H2XWrDTNIVV8hxG7 yn5RuLDO087gPwr5u+Fchj8dQHnmM5Pb7yn+le0/ENPEF948Tw5YeILnSrKW0SSIJKyDcWIIARSx zg+g55IxVXsCTe5vaB8KbOyuWu9W8T3GoNNH5ZBVIkAJBOByRkDHXoSO9dbp3hjw3oXiH+2dNtUF yCH+07i+G6DA6fpXkGn6zpvgnTprHXbm5uZ7P5ll25+2ysT8qEk9OMk9K6/4h+J9V8JSaPHoUcbz 3F0I5Yp/mRl2nIIHIOSDkY+73zRfqNdjodWk2eLLRrJreMTPGZy0ADtmVQCr9euVx0wT3rzDxNYz y+IfE1tBG0s9xqEESKoyWLBjgD6gV0Ol6tpfjDUrC8F3NpOo29wkrWhlDI5VlY46ZB2jrg8dK9C0 vSvD+leNNc8XatdQvLaSx3VtZs43PcCHYp25ycbs9OpHpST5thvTcddaUfDXhHRvhtZtvvGC3Opy LyC5OdmfQdB7D3rt9KsI7Kyjt41wEGK5jwrZXN5dXGvagd91duZCT2z6e3au4RcCqAr3QxEaS0/1 NSXX+qNR2n+ppgTD7rVSWMPO6noRV5R8pqtEP9LagCazY+VsbqhwauVTx5V4P7sg/WrgzigCrL+8 vY07IN5/kP61YPSoLZd7SzH+NuPoOKnNAHjH7QQ3fDyVAcZlj/8AQxXyIbQZ5ya+vfj0Yf8AhDAs z7UMqZPXHzDt3r51g8G3d9H5mn3C3I8sP8inOT2x1P1xWMqkYuzKavYr63bwab4B8O6aIh9quzLf yNjlUZtiD8QmfyrH0GNU122IQZyeR2+U10XxHEq+O5dDjYNDotrHZxhRjCogz+pNcvoEpOv2q5Oc nI/4CaXMZzdtCbxQAfEF6VGWATp2+QVgSzNtyz732r1rW8WXMsPiW6jVyB+7LAH/AKZriueKMwZ8 8Yz1pJdyZPUsPOSuF4I70RTEkD7xPGB61VD9EYVOZFZUTARR3AwaGSTO/lYXfuZvvAcY9qkjKyKW 6CqTKoB+YBgT1OaWJ1ICNng5+tCdhptF4KpGRzTvLFQwyAkqpCkcknFXl+ZQQBz3FUnc0TuVvLFL 5Q96s7eemPpTggPY1YymYvzpRCc/dq6EHTrTxCxPSi4WPV/gdB9nXxBesrZ8uKJSBnqWY/ToK9xu VEYgHQIoXg45wO1ePfB6O4j07VLZlISeSMr7nOP5Zr164Ia4yADjJY5wMk56U5PYcEVGWKWbfLIC R935f5GiRIwqJGRgjpnIFKsKB3Py7mxkgbnb8T2qRo/McNIe/BQcfj+tZmpEcZ2tg4/HH09KQbAw DyL9Ac9Py/wqwqozgBcHvuOePpn/ABFOZ2jUIMkHuEzk0DBFhKbkIJxk4H9aKVc+UCdxAPf/APX/ ACop3Cx8zyShSAmcY70ySZ3H3vlAHznqfpVbDKuCqknjGf161IZ5WiSI8KVzwvQfSvBaOAXa4GwK wYYJBGMU11Z9gc5VR6/jU0U0jI0bLkDuBwPw70j53fLtwRnIPb0pdR2EjGGCswIbP5UkjhdgIKgZ AwaFXMZLZY8YHH1oZVGN+7Gc4XqaWtwsMLsU+ZQRg7QOcn8KQFGXLPnHIzxn2qVVHIG4AdCeKasc alSzfP6kdKdibHUeFL37CGnkP32iiDYPUzqT+hNQeI7OWDxDqrHAjaUup3Dv83Tr3qhZ35hR1jCk k5EoHzJ69wDx6/41s69Jc3V3Fc30AhubqCOZk24xldvr32mvSjBSgjbdI49po5FILknI7daegHl5 2l3PTjpUW8CTZtChTjIGcGpUuZYSpLs+3kADGTxivP5UtDEY4uizZiCqT8pIAoBkVsSusbEcdT/K pReyTDZsUgHptyM+5p4mCMGEaoo68cA+1Da7AVtwABLE5PYbc+9PjzLyIAU5PLcYA9sVO8i28xxs YMMgk5H6VEJZsqqMu5uMkZ6/5FAWGM2SwSPbuHGMccUYmGA7PuAzgcgj8+1TI0rSeUwBcggBRjnP WpDb/Ku5Wx35zj6/rRdoLCWMdz5xaQSKQO559e3tzWj/AMJDqMNpPpEhs2tB8qlrKMyAZyMSbd+f fNO0cB/EEAiOEmDqEPXlT/WsiTz3bbsJJA4Izg+ldCm1D3ehXQk1KMXKW90G2E7lwRjoazxArSgo 67VGDnNazozaRvCs5jmIOQehHNUFjYsnmEKHb+tZTk279xMiNlHJiQSEHBY44wMVIsMAdQZCMZye tAcMrSbiM/Kx7dfT8qesy+YyFWXI5DHr/hUeoCnT99vuVzlT3I4ANO+z3Q3MpAJx8+ec+3tQty28 qNsasTkj8quIGkbMM43cgruwTx19qQaESWsxbDMu4cdyTx6V1fhq2EkMiOxkDvgnGMZQ8VybRzeb zIF3EjcGzk46V2nhO1vAgNwrjbJjMi7QcI3c4rShG1RM0jbsJYeI9Y8JarLY+cJIbWdo3hLHkh/m A/EGvUvBvirTtUuNQ+0GO3a8m86K3kPXKgMB642/rXjXiaBLnxfrLy3aQIL+4bLKST+8YgYHQ47H FII4bXT4Wje5maGQqCmIjkgH/arfnlTnK2xcWz2PxT4F0DxdKtrJDNbv8zH7NJ5ecgD5iQR2U4/2 a8N8VfAfWNESa4sbi4vLdVLZ+y7vw+RmP47QK7Sw+Imu26osjRiJVwQ4+bjpk8evYV6Vo/ivw9rC Rie88idwG2SkspOOx54GK6IV4SfuuxqpK3vK58df8IzeLb5nge3PUNOywqeP9vFVDpNnFzd6zZpj qkIaVv0G3/x6vtW6j8M6mFt7u1sbyKXPzLlWIzg8jB68Vx9/8IvA2q3hFnYm0uVl8xgfmQf7JUY+ X24710KbDli9j5y8Kpoy+LtKSA3d1IbhNrMqwhTn0BbP5iu88RR3en2HhiQ6UTDE7QTnBk8omOIE E5x69ucV3J8A6B4NvFkW4tJtRu5GFtFHnzACckKuCVXtkn8ea43x7F4oubG2TT9M1E2iyStcpaxv Ikb/ACDazKMZGD1oUru9hcpheE7bXovGS+aXXT4JZIidohjYgHGAMBj0OBk966D9oqEp450e8BKm bSkGR14kk/owrFheA694X1ITMlzdEJPBIp4YfJkeh9R7V6t8XvBdn4otfDeoT+IbXSJktGRRcj5Z R8p65zxn0PWrUkrthyczSR4H4Ni0O41JE1me4Z43X7NCBuVmJ+vrjj6nnGK+jPiasEE8c7qJZo7j zFQruDDaQwJzlRg9Rn+teOaP8N/sviLTpf8AhLdBuEW5jYLFdHe+HHyhSoOT2r0j4t3Ie5s1zG3m mZgWOAMBcfzx9aznaSbTK5XBpNHNaDaX11qFpZWemOkt46vH5SuzTfMQG4A4wDnPbNelWsd14l8Z 3FzcQmIeZgoRygHGD78UfCzTJ/Cnga/8eX4ZdR1FTZ6ZExzgZIaX88gewPrXWeEbA2486XmWU7mY 9TVUYuEX5kztJ+h3VhAsFukaLhVGAK0BxUMK4UVYA4rUkrXf+qNRWn+pNT3f+pPHaq9qcQEmmItJ 901Wh/4+zUsDMwYngelRQ/8AH41MZYuoy0O5fvIdwpzy5tN69XGB9TU5KheSMVwllr8g8cXlhdXa rZW+/apwACDx/M0CO6iQRxKg6AYocjFcnqvxC8N6UpM2oxHA6BhXITfF2C9leHS7KR/SSQFV6dj3 o1C5F8ZGd9LtYYY0lfzQ+2RSy/Lz8wAPHFeJ6TN4kbW2u/7OXyY5EMYVDhUTnavYAgnt14+nYeI/ G19dXZnvYfNKN5SIsgjXkZ5JZfT1rFu/EdpY3DxXsxgLRnaIx84YjAOPvEZOfcA8968bGSgpavXy V2W2uWzMi+8MX+o6rNrOrWzmW6kdpRuELuGySfm75OfoMVkWXhGDTtQTVdQv1xEv+otkL7jjHLMB t69gai1bxOL1nhs23pLGQx5jC4OclTyeOOtV9O1i7u5DpkMUq2sRCSSOwJJ5YcAcfcPfGKxoSmne Kb9WZ3jfU4/xeM+Lrs4G0iM9cf8ALNaxyCzhE3DHTPIrZ8XtGfEt3kDIMfP/AGzXise3n2SghU5G CWGcfSvWu7EyXvEUijzxvG0ADI96dK2QABuA6+woZwzbiARuJJ61HvWEAA5J6r7elG5NiVfLfA25 YjB561HuMbEjI7fSpAVcE7BHtyTjtUZlAcKg3E45PajqInt32/OQM4wQe1a0BdoxxjArEWORm4HX kY6VoW0jAGJTyf4s9KE7MpM1FRu4z9KlEaH7wI+tQwySDhscVYWZu1ap3NETRpH14P0qK/vDp0Md xFEjkOMrIMgil+duQgPuKjlt5ZhtKbh1x96mB63D4lttD/s7yFVR5sckqr3UYJrv7Xxv4VvCyRax b7um1yqMPwY5H61852mgeLtUIXTtHvrwnvHAxH54rtNP+DXxAfTPtk1jbxu2f9HknAk/LoPzqJO2 7Noxbdkj3S3kSeESxIkkRyQ6hun0wfWtGMK5QeXtHQKp3H8QBxXzfL4N8d6K/mPouow7D/rLbLgf ihNSWvjTxfpbmM6xchwcmO5UOfx3jNZc5t7Nn0dKEUEMzccAbeT/AJxVYoMlowDxjjrn8evT1rxq 1+K/iCGQi9trS+U4JI3xt+YbH6VvW/xisCR9s0e6hOeWimWX9CF/nT5kLlaPSgqqNqJg4wSMj8Ol FcfZ/EzwjcFRJfzWpPUzQt1/4DkD86KrmQrNHhCW7R7VwQjdSM4FP8tdx2SKWx2OcflUO9cuoDKu cHPPIpfLiVSsYLKWyAwwQO2a8jQ865MH2ru8w4zjIGefxpW+Rud5K9QeOv0qFbcsVCpt65I9aeIJ wyru24z1J69ahyXQV2SbmXcVCx5/E0m/dH88jY45Hao41kUFpckZztGBzjqameIKVkDbl3ZAz096 XN5gJFHwWaViCeMj/OakZFAw5GC3Uen4U5trSb5JGkbjcNw44/8ArY/Cq68gfJ5igkDcDyc0mIeg 81XSIElB94Dgdv54rsfEywWGi+HHtEMVvqFmLlk5YGZgu9uehOF6elc5pTmSWeAhGLRSNgDuACOf +A10/iN0vPh14bnKAtZSTWbrnv8AKR/46AfxrvpyfsnboaL4TjrlIllmjEeH3ZDdOuKqlLhNhSNZ FAOFwD+NXrtXLRSFdpkjGe/PeqbRXRfcJQh+uMccGuKTtNkPcRIHkdVBxyMhSF6kdal8hZVYyXBV cc7u5HYVA0ZRVRS+3p8p4HfNAkLR+S8rAYB2DOAcEZ/WmrMRKgRFBEiuzMeFPP1P+e1OeOMF0XKh mwSOoxTIYC0KyMViywU9z3OQPwqZIZyRIoBZCAGOMnnrnPrmlyjHw/uxsVFDKcl/X0xnvStNOkgZ LV4pNmJMHLMDjkj0x/MU6RW8ku+7ft+YheAetENvfXjhYo32hRgxxk7BnPQDvk/nQmFifws7t4x0 5GKlTdKjMw5bJqu4lRZIxgbXIIDdcZ7/AI1qaZY38OrWMt20CCGWM/NIoYAEcbRk9vT1pL+2trbV 7uHz2kDTuCqoflw3TJ9v1reG1i7aFG3aaTTLwbfKI2kFeh5x/LFZ5ieOOR2kPYFSuCc+30rdsbnT 98qwWsjYjZnE0mc45xgAYqvNrV1CsZgSK3DZwIYgCBxjDYz+tZtKyE0ipDp91KN8FhKwYEtIEO1R 7k8Cp20wqvmXN3ZWwYEcy+YfyTJ6VWuLy4unD3E8s6kd23E+meaqITJII4ySF9V6D39ulZi0LhTR lJae9kuiDgCCLYM467ic/wDjtNbU9NtVk+waYsjDpJcSM4+uBtH6VViZDNm4iPlnlc9PrSlI5LfK xbWc8P7Zqk0GpcGv6oVKRSfZweMW6rD7cEDPrXVeEpWkSWWR3kkaYMCzFv8Alm/c1x7W+2OIBVOz o3Az7muv8LGR413xldkoUADoBHIBmtqL99FRWoviyCD/AITTxEqKGH9oXBwQQM+Yx/kR+tUYiW0l xN8yrNGy4bOAQRz+NWPEBVPHusyAtITezyE4zgFyfy6VDb/vLPUoGAwiq4LNjIDgdex5pz1k/mUi AfZmuHQRgs2VJJJXPpx+HFTxskExfbIhZWI2ZOMnGPpnP61nou7dglsHBC/59qVIpbeRnxtUjBJO SD161x7DuX2uJI2LxysTGMpz8+c54+h5q3aeL9c0+6knj1JYppSMh+ePX3NYwt5JGLRtx2Q5yTTF tpBGGEbFicZJz+VOMmtUO73Ol03WjE9xK0QnurkESXjvvlGMH5fReOB05rtvB/i3T9E0FoJ7qSMt I06EZPmcBccd+P1rzGy03Ubi5S20+0nuXYni3jLH8cV6N4e+Fmt6hArX13a6MOdsdyDuyTzwo4/H mvQoc8oO25XM73NfUNb8N3upXMzfYrr7VbK2+aMZhmUkDBPRvmUcd1rr5rLTdQ8JaHJqMayYTYuU VsHjjDAg/dHHsPSuE1T4b/2I0Y1O/idJDhZoBlH57H1zjqK9IsFg/wCEG0154FmMMjKH9/mrtpqT VpIfM73OVHg/Q11FbiIwzPBKDGhtlVlPHAK88Dt71jXfw71nxxr+kqsUllYgkXU0h2MkRILHaRzw OPc130VxFbRiKyt44U5+WNQvNa3iS/HhjwAwkkaPVdXUxoF+8iEfpx1+orSNNLRDlNvVnK6nJFr/ AIkjsNOjEWjaSgtrZF6BVGM/pW/p8YiuQgGMVh+DGtjprxoR5yn5x3rchuIor/LuFGe9VuSdTEOB VgDiucufFmjWQCNdK8nTZH8xP4Cs+48VarJF5lrpD21uTgXF8wt4/rlsZoA6q8IEDGsmO/tYbV/N uET13GvO9e8VXRgZY9eS7lyAYLCJsY7/ALxgB+QNc6+su9ttj0iGOU9Z72drhgfULhU/NTVqLZLk keq/8JfpMUht7Z5Lub/nnApkJ/AVzE/xDhWWSaCezhUEqRNOGkU+8SbpP/Ha4O71e9uYDb3erzyQ EYNvDiGI/wDAEwv6VmxzQQjba2yRj1xzVqn3J5+x1uo+OfEF9uWxkkx/f2eUn4Zyx/IVyFxb6hdz PPqOrupc5ZIeCfqetDTTyHl2PsKVVZuOv05p8sUK8mJFa6VbfNFZCSXvJKdzGpWuJJBtH3fQDApy Wjk9PzqylmOrH8KTkkNQbOW1/S4NUsfIuWKbGEiuOSp5GRjqQCeKpazpmlW9lbRy5vLhYVZp5VGJ ZOcoxznoAQT9K6TVbSeUxRxQ/LnLk91BB59uP1riPEoW91Hc9zLZQT4Xy5gIyYwRkgEAjkepya8j HQjUam2/kaWaRycEdydOlMF558asSuMgqNpORuOQPw/pWV4YuJ18TwxcssrEMcZPAPftVjzTa6lP G6/6NNtYQ20wfYDh1w2GxgHB79j3FPs7e0i8dW8WnXH2iENuEuxkyTHlgA3OAcgHvjPerpR5ZPzM yHxOiy+K7jdKsSpsGdv/AEzXJOOTXL9Zcg7vp6V03iiUSa3dRpIqbCpYEDJJRQcnGSOBxzisPzIY 9saMcAk7setbJ2HL4mMfYQG2FAw796dJbQqBKXBXHC5yc1HNIsm1t2/H8PQU5BwWAAA5yOgo13JE DFl2shx978KaCMglCNucCplkAQo4VvSoZSzEFunbBzTW4hySPkjAIHO3NXrVJmYHaG43YUdhyaoR bd4b8D9K6nwdo+o6zrqLpVwYHt8TPJtLFFDDLBQCTjOemPXApSGtTb8MeCdd8Sor6VCjQtIU82V/ kVsZwcZxxzz17V6Zp3wLvm2nU9agh9Vt4y5/M4r2HRdNu9N0qO2vNSbU5lzi5aIIzLn5QQOOBxmt D5h/Caz52jujSSWp59pvwc8JWWGvDdagw7SSbFP4L/jXZab4a8NaVtNjodnCy/xiMFvzPNXctn72 KeNw75o5mzTlS2L63AGAhKqOwqYXIIw21x6EVQDtik3tnnFIDUjaHbwu3/d4qreaTpOpRGO/s7a6 Q9pog/8AOoFkKnIYjPvUouH6Eg/hRZFKTRyuofCbwXfO0i6WbZm720hQfXHSuVvvgRYPubTNbmgP ZJ4w4/MYr1hbhc9MfSpRcke/1o5R8/c+dtR+Cniy2Ja0Nnfgf88pdjfk2B+tFfRJnVusQP0NFPUL rsfF+0FgrSsMDOAThvUUsYSORiCHAAJzz+f5UJCVcGSUICSMkYC8+gqvKwy00aD7x68c+v615lmz x2WgpByrBh3wetPMql9pLPg8kg5qjCz5XfwpyeuA1TJPu52gBWA5Ptnv07VLgBcDQNG7K2SgBywx n2FPjMXJ80SZwMHoD1qmJjL8qnDHlvQ47UK7qroCFz1yOahxVhFzeiyEbBgHIOP8+1N+1/djjUHJ GWPTP+c/nVSb7UBxhUBx06nvSxRqu1ZSY2OAO4NUoK12M1NJmEetwIQCJDsLBs4yCP61s3dyv/CG 3lm/GbiC6iLcZIQpIP8Ax6P8qx9O08m8hM3mW0ay53shCgevPX8K6XVNHVdDvrJZPPfTblC0ybdo EgIIIzngqn65wa7qCbi0VZ8pyFwztpltOq7tu5Dt5J6EVEkrGct5bLlcnA4rVgj01LArMs86ROJG HCfNgjjrxj6UqXkYXZaaZbwecTh5BvJ7gncSAMe1ctRJpMVkZSxzSMpggMu49I85J+g5rQGhXUQM kyeQSMk3Egj5/wCBEUsmrapgIl2yp3SPCrj6DiqEq3UxQY3gnt1GTz9KxTSDRF9INNiDrLqkTttH FvGzsPXBOB096Tz9JtDvW2nuCRwZ3Cg9ugBIP41SlikSBZFEZG4j5SSQf8OaleFJiuJw3y5LPkFv lz/9b8qrmHcsNrDiMw2kFtaoo/5ZxAn16vk/jUNxql7LLtluZZAQABI2MD1wKqmJlO50BTAHIycn PalISXKCIKXOM5wFAPcf0pczYncns9QmFwsSPtjLq+0AdRnvj61b1to18Tai/mg7bh2wD0O7ODWX GpikYAgox+XH16itXX4lOsXMj8+Yyvg+4HSqUrR+YWGac0aa5Eu5RHNwMZ+fcP8A69Z0kSRucAAr /Cozk5xVyNkV7S5iPEbhQMcEDnr+dP1mJhq91EUx+8ZQQBgg8jj6GtZ6q6/q5VikFeR3QgEIMDHy 05rdwEV9se4YB7c1FvRXBaQsT8vzHvj+VWWZTEJUdU42gE5yfasepOhAI3RgVBAyM4Xp68/lUqQs oOQFI4Ax1pv2lhNuLMGC7cgjr0FWbPTtVu4pbi3s7iWGBC7vHGxVAO7N0HHrVW7DRE9soYRo5JwO uOfr7ZFbGiajHZnc6MQsoLKp5+4wJx35ak0zwv4j1lM2Gj3lyT1KRkKee7dP1rutJ+Dvim6AfU5L XTk4BV2DOB9F4/WumhCXMnYpJnCa8rtqt7exj5ZJmOc+pzn1PrxUmnRG5a/4G2605nH+8oBI/wDH a9+tvhX4GgsxBc3uoRXIX/WmRSrH3UL0+h/Osc6Voeg6sLSCziaaMghjGrB1OchWIzg9T9ea6/q7 Um+4JLueLaD4Y8Qa5erDpVsxQjL3AVtijHcjv9M11Fv8IPGNzcOJ2tra2EhxLcSHc2D97aMnnrzX qq+ObGWzSazkCwkcJjBT2x2rIvPHJcbVySeK1jgY/aJ5ooo6V8JNLsJEuNX1+a6YEFooF8tW46En Jx19K6+eLw+lmlgkRS0R1c24I8psdMpjafyrhxrmo30hRA3Wr1rYXV3ei1llZZmXeFOeRXRHD06e yBSb2O0Gu20MQhto444x0SMBQPwFRNqE1ypxkA1kxadDp0gS+vLeAnp5siof1NdtofhuHVI/NttU spUH3jDKspH4Kadn9lF6X1Z5p4nTXFsJDBGbiE43KOo9CPzP51veHNbtG+GFpa6lew2ciTOx81gh JDEd/rXrCeEtHWHy7p5Zx/EA5QH/AL5wf1rmde+Ffw/1W1eNdNewnI+W4tpnDKfXDEqfxFbUoxb/ AHjaXkTK6+EyvC02hajfNdHVrKW1s1M022UEkDnGM/5FcP4z8QX3jLxO8+nWtxc28I2QJFGWwvdi B0z/ACxXj3xH8Max4B14RXLtLZSMTa3qnCy47Y/hYZ6V0fw91bQvGNlL4f8AEHijUNM1Uvm2XePs 064AA28fvOPXke9dVbCRjHmpSujGFaV7TVmb8F7daTd+bNqlpp8gH3Gk81z7bI9xH/AsVHbeIZbi 4eW7sptQz08y4MKfiqjJ+m4Vl674fm8OXOxZIbuI/dmjPX6jqDWJNc3/AJW6IA+gziuZU4pXbNHO Teh3Z8TX8IItJbXR1PUWEIR/+/hy/wD49WPPqEU0xmnaS7mPWWdy7H8TWJZpcSW6NcEGQj5tvSrq QelO8VsFpPcmfUJmGEAUewquWmlb5mJq1HbE9QB9eanECAZPNQ6lilC5RSAse/4c1ZjtD/dA+tXE XsoqVYmbg1jKqbRplZLWPHzfN7VYSJF+6oFSvGIUDyska+sjbf8A9dEDec2LW2mu29QNifmef0rJ 1GzRQSHJECcZGanKwRLvmdYkH8TcVfttH1K4/wBa62y/3YVyf++j/Sta08NRI4UxlmPJZ/mJ/Oo1 ZWiPP9T1a1giMkbk7yqBguVVSwHPuTiuB8ZwWs0VpcRQOzGQn93EWZsjllGcE8Z564r1DxTpmhaV eS3Go6laWJXaYRcKHyxz8yqVZTjA6jjNc3rdtfanpFjGtxNI1uAhjmRk3o64SQnAYBOSduCO3Irm qwblfsaWUonh006RapH9mig3BfmjnX5cbQe+OevTH61b8N3E2p+M1uLh2eRIpGJ5IIWIgdcn061Y 1Twb4os9PuNeu9PjNlbyGH7Qki4yScEc7m5P3j7Vq/DzRWni13WPMXyrOz8ssW6PI4UD8g1bU4q9 zicWnZnJ65c2y65qKSw+cd+FO7btZcD8Rx0rCdZBclWUb2IJH6ip9QuBPqFxNtX97IzAj0JzVdFV G3+Z06CrUbaky3GhWaRg4yOnHakQEHbu2jPNWZNgi81XHz5Jxng1AsgVAeG74NUm2ItoyMSoAORj JNReQuGKN+8B78AVCr5zu+XPQipJJPlBx83fHep5WhDdpSQ4YAY+92zW54U8RT+GNdt9ZtF8y5t1 cx5OArlCoYj+IDOcHg9KxC3yq0YA55FQh2DZ/wAitErjPpr4ZfErw/ZpeS+K/Geo3dzesHZLmH9z buOSEwxPOccALx0r0C6+KPgGK2adfEEUgHREUlz9Fxmvi2KQhfmHWrCFi4AJXPTNQ4I2jUktD6z/ AOFw+C2nKLLeFB0k8jg/hnP6Vt6b498L6pKyWWolyo3MTE6hR6kkYA+tfIFveXEMbINr56M2SV/X H51bt9ZnhypjZGbgsjEZHpT9ki1Wl1PsqTxLocMXmPrdiF6/8fCHP61ctb6G+txPbyb0PQ4xXxrb 3lvIR5sU4GeWUZx+H/160bTULm3lkm0q+uLcqMlllMbEfgetHsezKVY+vd2D1p4fjvXylY+PPF+n HNrrl2cnJEzecD/33muqi+LXiSWALNBaSyIOTJK0e78FZRmp9k0UqqZ9Ay3EUI3TTLGD/fYCm/bF wCjO+RkbEPP4nj9a8P074yeRJ/p/h6DPQvavsP5HOfzrorP4v6BcvEJ4prIE/vDIC4H029fypcrX QrnT6npv2i4ZjiNVX1d+fyH+NFcnD4+8J3BAh1ZGY8BSjKT/AN9AUUtV0Kuu546+k+HJGLyW+uWh PZkjnA59thqA6HoSsDB4ikj4Ixc6c6Dn12s1dBF41SGMm8ubWVt2AttDI2Rjpl3UZ/OkbxvZXM5R ND85cZyzoOfxQ/zrHmoPeJ5rUe5zj+GEmI+y+JdJZTgYMjxHH0ZAP1ofwlrDc262t0o4HlXkLE/+ PZ/Stx/F3hl223GjsCccRxqx5/4EuKeuqeCLpVMtm8G7oWVl/wDQd1JwoPyDlXcx4fAuv7DPcWD2 8Z5zgufyQMaYdItLWRjdS3Jkxkr5JT9W5/SulRvBbFTbarJbMeBsnZMH/gSrWjBFbsAbPxjdAgYA Nyj8f99mpdCk9pDs+hwTzWcfywacgyOGuJGcjPsu0fpUTXEzKQsggLdBGgTJ/CvR20vVGU7dXtrs Htc2KyfrsP8AOqM2lXLf67TdBuT04jaBv/HWWl9VfSaCz7HnzRy+cZJZtzgn5c5br1/lXoumgXFl q8DZ8uW2Lge4VXH6saoNoce4eZ4Yi3etpfNkf99bq1rQwWRYyaLq8W6PyjhklBGMei9q2o0Zwlds fSx59CWM91CE3ssW4L2OCCf61RWQElkUR5Y7drZwf6V3MGiaSt4t1FfXSSxpgxXFr5e/gj724jvX EXdtNBeSRBGVlkwp6ADpn8eK56mHn0RD0sN+1SNEEC89Dg9P/wBdOQsBjdn5dobkcVfXQNUyHgig uEXr5NxGxP4Bv6VC2jaxE/mzaTdqO7eUxHt0965HSmnqrARSW3AHV2GV+lKLWRYxtBKOu7PQA4/+ tUirNBC2+NlfG4GRSp+nPpimXV4dwdpdgAHCDdyfX0qORrRgKYDJLIBIA3Ubjw3+eaZs2ysrbAcY yff/APVUM1whQbc+ZjnPPqfXrn2qNrxGUpgs+NoIXcTnBHajlbHoWVxtCufuDCLjjd/k1o38b3l7 9pigFyhROVOTkAduo5FXdH8FeL9fWN9N8N3gjH/LSWPYjc9QXwP1r1Pwx8Erl5vO8UXy2sI6RWzh nJ92IIH611UcO5JpodmeLW0U0tjNHLGFbqik+lX9ehEt8ssSAyTQxSAA8/cUH9Qa971X4WeGNFgO oDU7jULROGV0BdM9uByD6jFT+Hn8PaVbSlLCzMsMrLDL5Q3LH1VQTk8Z9a6lhW1yXHstTw/Qfh5r 3iSSN4bCW3iPzPM8J2fh0yeM9a6ax+B+vXkrNfalBY2isQiy5LgZPOwEgfTca9Wv/HEcMeBIoB7Z rk73x5knYxOfSuqGBjbXUzc12Esfg34LsAv9rardahIvJUERIfwGT/49XWpD4S0vTRptrp1utqg2 7CSePqTmvM7jxJf3pYRK2DVa2XUr+eOBpGDSBio6Z2jJH1wDXVChTp7IXO3seqXPjS0hTYsqhQMd elY1x47jx+7cyKevtXO23hC9uCpfeQfWuq0v4cXMwGy3ds98cfnVvkQ0pM5+/wDF11dLshhccda5 0XWrvr9jJchmiWRWz6DdyK9ttPhOzbTcXEduvcAbz/QV1tn4H8O2USrPB9qIGMydPyFS3pZIpR1u 2eC6b4DvZZiscLhGbjHcV1Nt8JdUnwUjSMf3pTtH+Ne3I1jZxhIIY4lUYAUYqvPrEcYOGFF5BaJx eifCu0sGEuoX/mt/ciTAH4nr+Vdcmg+HrO4juhp0D3ESlUldQzKD1wT0rMu/EcUYP7wD8a5u/wDG tvErAzD86fLd3HzWOz1GDQr2Fob3TLO4Q8ESRKf1xxXi/jTwo+i3H9v+D72a2MPzNbo5DRj1Q9SP Y07UviEgJWOTP0rkb3xrfXDEITg+9bQTjqZSalozuvC3xXm1C0+xa2yrexjiUDAmHuOxqfU/iDBG G2y5P1rxQh3uGlVdhJz8vaphC7nLEk0S5b3Gos1PHusQ+MfD82l3EQcj95DIRzG46EfyPsa+YjdX NnqG5XkhmhfscFWB7ehzX0glqSPu14Z8QdPTT/Gl0seNsyrNgepHP6g0lU6Ibh1Z6z4f1STxFo0N +8jyMflfP94dfz6/jW2tmccgD681xnwtuYx4UlhOd8dwwIx6hTXd+c7nEaZJP1rlnUs7HRCF0Njt 40HPNT4VewHuaBa3LJ5s8q28f95yFqqLzTlkaOCKW/lU4JPyIPxPJ/KsHUbNVBIthk/vZ/3RmpiI Yl3TyJCD/fODVHzb2Zyu8WqHokQ6fiat2um24cPIPMc/xOcmou2XogF6jkpY2st0/Y42L+Z5/SrK Wet3brGHS2z/AARDn8WOT+WK6/Q9JhnjDYAA7CtewsohqzhV+UfLTURNnP6X4OhXbLcRGaY9XkJb +ddbaaDHEoGwADsBW/HDGijgU55EjXPArRRIvcpxafFGB8oFK8cUTbiQMVWu9WiiBwwrl9R11yrB W5PSmLchubSLUfE93fW8MEl1axhImmiEqruB3fKevb3rz6XQb7QxPdz6ZYSNkkvEhPmqUKnII2rx 6Ad/Wq3iLxVqGhahGLNmD3GNxXnOCMA/qPxq9pfxJgubuOG7RYYACsjzED7vXj37D/8AXXJOaUmj VVIr3ZFe3th9mu01LwWl1FNGftE1w0JdEyMGNFfPPXAY4x71R8TaJZ+F/Aq6bpsElu+sO+pXHmx+ UypykK7R06uQPevQ/BKWOq3N1CZzFYWYM9zKSSqW45yT/eABT8BxWR4ju7rW/Ex1W4ka2t7ot5No 7NuWBVCxrhegAI4/vMfrVLRXNHaTPlzX9Intb6WBrJ4WthtlyAeeOeMgD05NYPkHbjlce3WvqCPw lp+q3hvtMu54p54/Ikl85DuVMfdQKRtAGDuLdDnFczf+AtBW5tlvdQCXF5GQ7NGGAIyWZRHkqc8A dOfSqjPlVjJ0L7HgvlSL8pBHIyKs/ZkdQQvJHNe2a38OfDV7CJNDvnF4URFhSNnRyeAXycq2ASeu T0AFY0XwR8dXUojtNNYo3BlciJfqN5Bx+FUppkujKJ5O9v7nA96VYmwxJwFGQSK7nxN8LfFPhR/+ J1YokLEKsySB1JxnjHpXP/2bhVDyFgvAHpWyV1oYyVtzHMKgqSvXoRwKRosFBtB4zjHWt37FEFA2 A47GnhFUcCq5SbmHFa3DOCqFfc1cjsJG5eXb74rQIPYVG27vT5UFxqWsKfeZm+tTARgYESgVFzxS gH8adgLSShIhGF6dCScj2qcXQFuYTBGxJzvx830z6VRCnrTxQBIS38JZR6ZoBkOOd1AY4A9KeOtF wsOJ2hdwYZ9s/wAqVXQtgOpP1pOaMA4LIrfUZosUWFJU5Vip9qKgAA+6zJ9DRS5UO5oiOSXILIRG cEnp+GP8805VaCYlpsErhSDtxn1H9KS2UXMiR5EQxyev+eKkkCMpUou98AKp3ZHXnHSvAuY20IWh aZWeRFyDjIBHpg/p+tWVNzJDAsjhUjBC7eQB15HrnvUDO4dgFDHjGDgCmJKxbZLKFXHAXk+55ou3 uSWPJgL/ADy/eJDZBzjjmnGWJSUSXIIIAPy8kcj6f5xUBAJClCSASSzcH/OKcwBVFESmRs/IDnBH elbQCxFPgSFXaPA2gg49OlWbW91W2BX+07lFHRRMwBPTPB5qksfCR+V5bEZy2RuzkA81IxIlKHCE Dbzznj1pNtaIC6PEusJJlb2SQAciSNWz7/MPX+VdXoOuzXEdt9rMZdtwbHyEsGAH3cdj+lcMskZY qY1BwA2en4fkK19Hiub65htrO3ku2Dq0caqZCWB6gfX0rpoTblZlJs1dX8RalHc31m2CkTkKAzH5 c+5PtTNV16ey1Vg8UckMgjZMqM7Su7uD6mtu+8AeJpNTmu7zRLq1mnADrLGQp4/h7849+9a2n/DM eI7yys9Q1610q9t4BBJAQJJJCpOdvODgFe+a62qj0iNXtqYHhbUY9Y16GxihSBpsjfGAuSBuxx1H HpXq9p4TmL75JQMuDgxg8Y5Gat6J8I/C3hqSPUVuru8vrcFo5HYRruA67VHP4k12I8vJ46c1cFUi v3hcbM5T/hGZRAI2EErBO+5QzZ+p4xVO88I2EsbhtIgYPuB2MAx5GOSARkZPXt3ruHmVRjjjue9Z 11qEaZAwMVZVkeVXfgbT4d0cdtdW8bOHOVikGclQecnpz9G9c1d0J28OuDpb2MI2790+jjcOCxyy 7T0HrWrrOrYcgMOtYS6tIZTmTg9q1jBb2Mm7bHo48boXWG5lhDbTlo2PUHB47c+9ZWoeN7KLpPu/ GuN1+6S50qIbjlZAflGSfbiqX9iwiIOWDNjLLvDMv1A6fTrW8Uramcm76FrxN47uXtXXTi0iOv7x XHHXnpXN2N3eX+mCSGVw6TMGA9GAI/lV7ytM3EecpHRsnj0/rWHr/i6y8K3Ii0S2iuJpolLpITtj YZBJ9aqMXKSjDcV9LyOhtNFvbp1Mpc59q6K18FPczIkULsSOAFyTXjKfEbxHfDEl9tycGO0Plkfl /Wnx+Ktb0nUFuIr69s7pdsiOHeN/mAZSe/IIPuD6V6cMvlNXdRJnO66i9In05o/wxvGUGS08pf70 h2/p1/SulHwp0iZreS+upFa3lEqi3+XnBGCT1HNcH8Kfjs/iKf8A4R/xZLFFqRH+i3WAguT3Ruwf 09ee+M+r3OvxpnMg/OvNqUZU5csjqjOLV0U7nwtd2Ja40LXAkw5EN9bxyxn2yFDL+Gap6X8QzFqo 8P8AimwXSNU6ROrZguPdG7Z9D/Piq974rhQH96Pzrz3xnrFhrumGCZ1E0Z3Qyd1b/A04pbNClLqj 2241uNP4x+dYd54nijBzKPzrwe18c6iunLbXTtJLGNofPLD3rLuvEeoXTHDkA+9PkDmZ7JqHjeCL OJh+dcdqXj8kssbkmvOne4nOZJGanLbnI4pXigs2bN34r1G6J2uVB96x5Li7uDmSVm/GpVtgBknG PWnYhjBLnGOtS6nYvkKywk8nk1YW0JOdv5037dB8og/fZ7xjI/PpQWvZcj5YR/tfMf8ACs3PuWo9 ifyok6sM+1QvfW6BhCPMcc4Ubs/j0/Wmi1QqnnyPO6j+M5H5dKlG1M7FAz6Vk5migRGW8lchVWFC Or/MfyHFeUfE6OO31CwcEtdSKxMh6hQeAPTqa9b5I6Z+leFeNNRbXfFsi2x82GACCPHQ46n8804S uxTXKjrPhpqthYaVfvqPnTzS3A8tF7nb1JJrrR4uvLhGksRb26xsreUql2K55BP4153o1rFZfZ4x NvZSMjHGSeea6bQntXv47GYBnkBj2sAuevUjnOcV5dWs5TdtiYydkrnSa5qd5byySQjzPnBUkZOx hkVQs9e8uX7M0SvKwY7kOMsOSKs65b7oDCHOfJ2gjvtOQfy/lXEwTtDfwr5EjiN9oZm79+foRSqz lGorbFOTTO1TxbbiZo3tpsoSpK7T/X/Oa1LbxVZMHJdk8oAtuU8AkDqOO4rzi8hmS/kWQnbktnrg HkVYtJbZLjdNN8jAxuobIIKnNZ/WJKVmHO07M9j0rx1DbFTDcROknGA4J/AV1Nh4z0v7UkjsUXHJ wa+YpN1prcEEmTsnVVBPuMED0561FFqUsOpyQwSSGQPwEJXBB6nHbiumFaTV2g5z7EbxfpkpBguU bI6ZrPvPEAlBCSDB968P0q9e50uK4jlZvNZgMncFYj7vPoentVSDUfFNw00+lQ/bYvKxFHGm6RpD gKuF5J69K6ec0XdHr9xfM+SXzWc0pfLE5rm9E0n4m3arLqfhuKxhx8zS3io/4R8n88V2EHhbVntY pjdQAsoYodwIyOnSjnRai2eS+PNQ+z6vbQB0G+M/K+eeawfDlveeKfEVvo+ltEJZ3GW4yBnkqOrH 0A5Nel+IPDWnQ33neJ4Le6jA2iEXShuo5C5zn8K6DQdM0jSdHE/hrw3qGlzTYRtShgM8vlfxKhIG 0n+9WLpRlLmZlKm2yt8QbdfDOhWHg7wvZzXV+i+VeXECZbzMEmIsODjLOw6Fj6Lw7wXYeKJrILrF iUO/OLht/GfTBrtLXxP4W0u2S223EIX+GWI7vcnrk9c0/VfH/hXTbGaaGb7XNHA86xwozfKo5LEA 7RyOSO9VKLepqoxTRND4Xsn8yS6d3Eh+5GgQL7e/5VftvC+gwyvJ/Z4leUAOZpGbcAc4x0H5VL4b 1yHxF4ZsdaghWJLyJZRGsiybcjOCVOM/r6gHitQqpOSAp96appF+0bCG3tbVcW8EcK+kaBf5VIZt o+QD69aiww9RQrMOtWkkTdsinPnIUnjWVGGCrDIP4Vw978MPB1zcPONEhgkfJbYSB+AzgfgK74vk fMOBTBsbkZ/EYp3CzPE1+BumyzXElzfyr5jfJtAO0fhjn8KxdU+Al9Gm/RtZhuTnlLiMxYHsRnP6 V9Csg9BTcAewpc7Wwcie6Pk26+Efja2WVjpHm+X/AM8pA24eo9a5K60LULWfyLiwnilH8EkTA19u nJHAqtPY2tySZ7dHZhtLYwcfWn7WQvZRPiZ9D1JLg27adcrMOTGYm3Y+mM1V+zoFIYMrg8DHH4+l fc32OHyfKdFKYxhhkY9Oa5zU/AnhbUUbfotmjnOHjTyyD65XFP2r6oXsl0Z8e+RhsKSw+lKluzkY UjPrX1rbeB7C1sFslWKSENk+enmMfo2citmDw7odspVNLtMldhxCvzD0PHNHtfIPZeZ8exabfM5W OzeRwN20RknH0rR07wvq9/PtXTLsKD8zLATt+vp9TX1bbeG9CspHe006KENyYxnZn1C9AfoKvxwW 8Y2LAgA5A7Cl7XsP2S6nyfb+DPEF5rsmkwWJ+1Ku4hyoBX1z0P4VoXHwy8XW7bW0aaXHUx7WB+hB /nivqBreBpxM0Q8wcBvSn4H8Jo9ox+zieC6F8K5Z4la8u/sj5BMcttnaPQllwT+NFe8kN/CeaKnm ZagkfHcqxEkq4Jf7qjH9KfnaT8ylQACQCMnv/n2p8UX7kCCDDsTleAT6ewFTLYM26NlXzDyMZO3p jpXjnnGTMsccyyO78fex29jTgVYSBYmJbB4+n616J4b+Fus667PLY3VjbbTuuzbO6sexCnGRjuOn pXYad+z1rMjK97rOn2kBO5JbcNMzrnqM7cZ9z+FdKozkrpBZniMcDxBlVWIk5IPOcnPNSWcaBgfL AYErleq+49+2K+otL+C/gfSo4/7Rlu9UdRz5svlqfwTB/Wuw0+18I+HUH9kaLp9mw/5aRwKHP1bq fzraODm93YLI+cNF+FPiDxBpRuYI1t5ZseTDclozNx2JXbk9gSK6bTf2fdcuCG1zVLTT1HWONWld Tn1yB+teyX/jCzSN0lMbIwwynvXn8vxLu4NXvLLULwXEOFNrKFwSgGCGPds9T3rqjg49dRc0TT0v 4HeA9P2vqdxearKo586Xy0J+iYP4Emuys7Pwn4YjxomkWdlgctDGFY/Vup/E15HefEeVmIhyT65r nLvxdq97uCswB44rqjQjHZC5+x7xrvjWxudCkgmdEbJCSA4MbYPzD69CPfNeCeK9Un1G1j1KKQi6 tLgAyIcMCV4OR/uCsi4l1O7jeOWZsH1OaXRrK8kims7pWInKlMjqwYY/QmqceV3BNy0Oy0Hx3qmq W0NreybpFOHJON3v9a9KXVIxCh3/ADbcEe9eYWHhxbZxMsiLtOCQc4PpSTeIXilktzIryI5HyHPB PBrCpvoaxO/vNbAXGQAO9c3f65HgkyfrXI3Oo387cKwUgHJ4781neRfXcyxoXllbAEcS7iT7CoVi 9SbVdVWe5jAXzMFsDPU7Tj9a5DU/EN9Gm22Zi56ba9AT4W+OJ4I72Hw7eeWpVi0i4YgHspOeme1V tH0Lwnb6qYfGCai0aPhktQqFf97dz+VdEYTl8KMZOMX7zOP0O9nt4JtVlgOp6hHJ5Sq0m4pnIyo7 dDyfTFd54X8FfETWbkSx6VKlncsHZpBseHGeFZhgZJycYzX0N4M0P4cafpa3/hPTrR0l5adsySE/ 7RfJB5PHFdNca3DEPvgYqeSVrSLvBO6PLbL4NX138+s6jDao2SUjHmvyQSMnA7D16Vtad8Evhppt 9JqF5pJ1i7kbe0moSGRfps4XH1BrZvvF1tCDmVRj3rjdV+I1rCGCzgn2NaRi1sQ5o6Txb4I8CeId AOk3WiWdqsa4gmtYUie3PqpA6ex4NfDPjXQ9Q8I+LL3Sb6QSeU37mdFwJY+isPwGPYgivoTV/iRd TBlt8/WvEfiDeXutoLu5+aSEHae+O4rrozdN7mE/e1OCj1SeFt8cxSQHKspwVPrXvnhb4nal4g8N RNdSl7yD91M3TcR0b8R+ua+aXJ3kjj2zXZfDvUBbeImtZGxHdJt/4EOR+maKlVy36FRh2Pa59Z1C 5JzKRmqZEspzI7N9TVoRInJYcUSSwwIWchcDPJxmud1OxooLqRR2/tU4hVeuBUYuJJCvkQyOD/Fj YP15p0dtdSqPtFwIiSflRRkj0yayc/M0Uew+SSG3TfKwRRxljgVH9sLPtgieQ9sDaCfYmpksraPO U3MerEkn8zU5cL0rNzNFAqeXePJl5RApXGFG4g/U/wCFL9gt/MDylpWH8UhyalaQn6VEJRLKI4/m Y9AO9Q5stRRIAiKFQYApNxbgdfaoL4zWUAuJR+6BHmbeSq9zVODXrbUNQmtbCNoFVN6SOwJYeuBw OvTNZSml1HonZmqUwpdyEUdSxqhLrmj2z+V55upT0WIZH59K881XUb5ryW3uryWaZMgqx+XdwMY9 P8aq2F6DqCxSMPNxkLnGeuR+lcrrNuyRn7XWyR0OteJ7zVbaWxtALK3cbXMZy57YLds+1Yel6fp9 o2zHzS5ibng57e/Q1R1S6W2vRapKqDdvVg2cqenHtVGW5uE3MCHVSQFjbLZ9c+n61nerLRvQybbe p0CvbpciMRkMHCdhtOefr0qpJrkVlfAwkLJG5OD7HqKa1pf317p15DYXA+2bHYRxsfmzg59s/wA6 6PS/hT4w8SyyX9lp9sLZyzJJcsVDgk9O340lQS3KUJPY0INVn1QGe5dXXakibRjCnIYfgetcPqGq yQapNbyl08hyAcZ6H0969b034Q+IvC/hWbUtYlt38osRBASxiRgNwLdxuAP1+tWfD+g+DJpINa8Q aPFeNMTbmSVCQjgfLgDg5GB0yCBzg8dUqcZL3uhr7Ny3PJ9bvHntLmS2bzprFwkqrwRG2dpx7MSD 9VrC07S/EOqXxeDTLq4ZjllSEnK9eMD6V9V+HvB/h240FNQh0uK3urnzVMrJnfiUgbh0ONoGK7ax tIlsUaPT0t3YEMsagDI69O1KMV0RTpRvdnzVpPw38TaumkSahbDTbgNtMk+QZEABXPB+bjGD6CvQ NB+CPhS802DVr25vrm4u41nZRII0G4Z27VGT165r0PVtc0PTS1rq9+sDLhwijc3HQjHeuAtviLdL oljpOh6W09zHAkXmNlySBjgCtFEtKK2Rs3vwz0nT9A8jw/ax2UiOrlnlIDY65LHrXI3t3H4bvbb7 NcWd+9u/mbYZSSoDjCnjBPTv2NaUfhXx54kAOuanLa2x6JM5JA9NoP8AM11WjfDjQNNUNPE97L3M p+X/AL5H9c07IrXqYFp468S6zeQrpHh+NkU/OpJYHju3AFbaeH/EmstIde1pLCGUAPbWC4LD0Lf/ AK67SG3itYVito1iiXoiDAH4CpSgchm5NOzAw9J8IeH9JdXs7BXlX/lrN87/AJnp+FdAoYOcZB96 XYAeDzUq46HkUWAaCXyJI1kTpgjNch4z8D+DNe0ma61iyFmbZGkNzbYjdVAyc8Ybp3BrsdnXB4rl fiLaXtx8NNfhsFLzm0cqq9SByQPwBoBbnxbDruoWEOpaNpt9PDpl3J80BYMHAbKk8Y3cDkYP4V9D /s8eLdV1W01bw9qd1LdR2KpNbtKxZo1JIZMnnH3SB25r5ieLEgbnI9K+q/2ePCl1o3he+8R6hCYp dXZRCjDB8lM4b/gRJ/75B71u9Ecqu5HtJ5HUigjjrT2aJuc0zcqnIrI6LDNpPekwM9wacZCRzx71 HuBztakUSAgHk5p2U7VX34zkigyg44/KkBMzeiVC5zwf0o3N028Um456AUDsHGMHP40z5gelSErj k03IAxjFAhu1mPI4qNoz2JqQkluelIQRklsfWiw7kW325qJ0Y852ipWIGOSaY3zcdB70rDuQFSDk MTTd7D6n3zTmQZ4bB9OtMKtuwc/XNOwxDI/b9elFLsRcknpRQBnaX8GfA+mLv1Ke81WQ4yJZfLQ+ gwmDj6k11NnbeEvD6n+ydHsLN+8iRKHP1bqfxNeLW/xM1AWH2a+YPdw/I0oPEvo341jXvjXULlz5 bE5rsjQjHZHluZ77eeMrWEN++UY75rzfWPHk2neJIL+2v5pdNkV4pbTedkTsQfMVemSVwfx9TXmc l9q14SS7AZ9akg0i7u23SFmPeteVdSLyex3WofEhj/qWP51y95401O4J2MwHXjtU1t4TmZctHwOu RWzb+GIEixNIo454zUucUChJnI79Vvmy8rHPvmrUPh64uPml3H610PhuKztbWe1mLTzQSspJ9iQP 0AP41syajDEhVRHHUe2NFSOdt/CwRQWXg+oq42k6fYwtJcMFUDOfpUsusLkhXL+y1fsPD/i3X9p0 zRZ2jPSWQbE/76bArN1ZPY0VNIx5orIk+TbsSrbCSMDpnPPas/UdRmaG1t3SGNYnXCry2cEc+2GH 5V6xpvwW1S5xJr2tx2yHkxWyl2+mTgD9a7TTPhh4F0eQTtpv2+dcfvLx/M/8d4X9KVpyHaKPC4tJ 1bUAbey0y5vxOu0xxKzLjrz279a6jRvg34muyJLxbTR4WOSpO9v++V4/UV7t9us7OERW8ccMa8BU UKB+ArMu/EcEYOZAPxqlT7i50tjnNL+DnhWzUSanPcapIOqu/lx/kvP6119nZ6FoUXl6Xp1rZDuY owpP1PU/jXG3/jq1tskzj864nV/iTEHZYH3+mDWqp2M3Uuex3WvwxZ/eAfjXkXxMttH8QWbXsWyL U4RlZF480f3W9fY1wl/421K7JEZKg1gTXt9dtmWZ2z6GtY+67mcryViXw34k1Lw3ftLayt5L/LLE Tww9fqK6PUPH9/dEiHIB71yS2jHkjH1qdLZB6t9BSlUV7jjBjrjVdRvGJknbnsDVXyJH+Z8n3Jq+ sJHQBRSmNM5JyfesXVNFTM82ydzknsK5rxBZ77VwExlTXYyMqjggfQVy/iG6VLORieAD1rP2juaO CseJXNuy3RhjUlhzwK0vDs9rp+sR3t1O6yQkGOONd3mE8YJ7Csm5laW+lkGfmJ6VPpQZ9asgv3jO gH13CuqTvqYxVj6MhsriWAC6uWUMcbIxsz+PWrUNhawDiNWc9XI5P40/e5HPH1pVR5DgKWNcLmzr UR4aNQAO3pSGQ+yj35qK5aGyjMl3KqdxGvzO30ArE0/X11TUZ42tWstNtx88s+FMjHooHp3/AP11 F+pWhuB9+ditIR3HQUxo7gzRoykK5wWUZ2jHX0qW1vLfyJI7NzIiuykseh7ineaxGd1Cd9hiTnS9 Oh828nRB/emfr9B/gK5fU/G2h2SNd2sRvZYX8sMPlCkj1P8AhWjN8IfFHiM3mr/2lBBDJiS2gdST MCemR93A575NVf8AhRHiLTfDt3dahfW7QNH5ksCAtJFhuT74XJ4/Ksk23qS+forHGa34x1DU7WOM hUglQyERD0J781h6ZrmoWWpLeK3zbjiNV3bgTjGO3evoDwr8GNBi1ifTtZmGpQ2ltG8RU7VIkLHO B1xs65H0r07S/hx4I0fH2XQbQkDGXQP+POcHgdKXIm72J9nrds+X49D1PxYt/HDZmHUreb5pCpEc 6E/d3YypH1wfqBW/bfAnX9L0xte1PVbZTawvMYI0d2wFPyliQBx9fxr6GGmWela9PaRWscdjqo3p hRhZgMMmfRlAIHqretRaq/2LQtR06/n2QvayiGZ24IKkbT7jP41oolKMb3seMz/AmxkurCz1DU7l 43jZbeaIKpJHzbGzn+Ekj/dNd34Z+CfhjRXE7+dczMAHDt8jfhXaQ241bwpYkSbJWginik67JNoI P59fYmtWwvTPYJKbZklB2yR4ztYcEf57Uct9y9F0KNzollpEVtqGl2ixpZEiWCNRh4SctgDuCAw+ h9am8GpCfBel+WQypD5YI7hSV/pVm51iw09tl/ew2zEFsSttyPUZ615nF8UtE8N6PNp1rE99PHeX WwR8RhDM5TB9MEdPWqUQ5j164hhntpLaSNWhlQo6nnII5r541DwpeeHoJ7i6ubKJUDqsUs/zSjPy 42g44/nU0vib4j+Mp3XQrO4toJRtPlZWP6lm4B+mK0tH+Dd5PILrxTrbyyE5MNuSx/77b+godnoC uc9oPxJu9MsU0+PSEmOZCMysRuZ2bJHQ9ewFazf8LN8SW6yzrLpmmM3LFTGoB74HzEe9esaT4T8O aFCP7L0qCKYf8tnG9/8Avo5I/Ct1EUoCWG71zS1DTqeS6V8LdM2LdanqMmqFuf3bbYz+XJ/MV2+m aNpmlwCDT7KK1QDGI1Az9T1P41pyaTD55mtWa3mJ/wBZDwG/3h0P8/emO93a4W6sWuUyB51tj5fd lJz+WaVi79hfLHpml8pcZANWYfKnTzLaRZU9V7UrYGc/yqiSoYwRwKPLOfSpSVBxjp1pQygEkUhk fk5IPFKFxxSGRRk7+KZ5iBsAnp65pXQ7E2SBkCjeM4wMVVM/zFcHdWPq/ijRtDj36tqVvZk/wSP8 5+ijk/gKV+w7GdL8L/h9JrR1d/C1obotvPzP5Zb1Me7Z+mK64YUBFG1QMAAYAFcUvjh75R/Yfh3V 9UB+7Ktv5EZ/4FKV/lXnmr/HnUrC7ktB4Qa2mjJVhdXByD7qEH86aTeiB2WrPd8j6ikL4XoK+an+ PXi2aRUg03TI1JxgRSO34fPXqHhq/wDFPibRl1J9RuNN+baI5tNVCfdcscj3puLirsmMlJ6HoBLE 4UcUuOOSRXPCy8Srjb4gibH/AD2sgwP/AHyy0pHieFc+fpl8fTZJbZ/HMn8qgs3woLZB6etP4HPA rkrnxHd6dGRq2lGBe7293FIB/wB9lG/IUtn4/wDCc0Kb9U+zbjtBuY3iBPoGYbT+BqkmJnUNKMY3 gGgOG43c+tVbW+06/XzLG8t7lfWGRX/lVkqVPp9KBDxt6bs0Fj6Z+lMEgxzmjzVzgYzTuAbyfur8 vqTTCsjd6lMgIwRTGnOdqrk/WgCMROc5HTvio5YX4wMn61ZjnYDEgGf9k0/zFzycCiwXKCwy4z93 6U14pO7Z7da0WIIyDn8ahcLjJwe/SjQLszfLYuc/L7GirjBT1yfeijQep4FbaAbqVpoUzGzEqfbN blr4XiBHmsB7d6raFemO1ktncYibA/l/StN9TOcJlq6HVdjhVNIvw6Tp1uBuG7t0FW1mtLZfkRR7 4rMs7XXNYl8nTbCe4JPPlRlsfXHSux034R+Jr/D6nPDp8Z7O+9/yXj8yKi8pbF8qW5zFxq8Y4EmA eoWqUd7NcTeVZ2zzSMeAAWJ+lezWHwh8L2kX/EwuLm+kxyd3lr+AHP61zPiLTtd+HE41rwjdNcaY Dme3kRWKD37ke/atIUXN2bsZyqRh0OU0T4aeOdTv7i5+wGwguG3eZdN5fbH3fvdvSu/0v4JafGVl 17WZbpu8duuxf++jkn8hW94Z+I+n+JtJFzGfIuUGJoGPKn1HqKnvfFcEQOZgPxqlSs7MTqdjU0zw t4T0AA2Gj26SL/y0kXzH/Ns4/CtGfV4oxgMBivLNU+IFrCGxMM/WuI1P4jyyErBk1qoGbnc9vvPE 0EQOZQPxrlNS8eWsAP78fnXiN54m1S9Y5lKg9s1ls1xOxMjs5+tVZLcm7Z6ZqnxILFlgJY+1che+ LtVvCQrlAfesVYBjLcVMsSgfKhY+9LnSKUGyKSa7uWzLK7E+9KtqerYH1q2sTkYyFHtUqwoOvNZS qmiplVYIx0BY+1TrC3YBBU25FGB+QpPMOcAY+tYuoaKAgiReWy1G9VHAAqWO3nm4CM314qnfXuma YhN7qEaYOCkXztn0OOB+JFYyqJbl2S1ZIXZjgcUwqApZj8o6knAFVNK1uxv7iURWrtDGrFmEi5XA PLZIAHB4GTWhrXws1HV7JLyx127ttSWFGktLkkxqxUH7vBUH159qujFVXvZEymoq61OP8QeM9H0U NAZjPcY/1cS5x9T0/WvK9a8XXurs0SRiCA9s5Y10vivQb7SoYrbxNaeRdBiqzRkMGXsw9uvBwa5e 38NT3RL21xBLH3YMQR+GK9BYVb09Uc7qvaWhhAkuT3rsvh3ob6l4stbqXdHZ2L+fLLgYUjlRyR3A rQ0Twpo9tqFvJrUk11bBwZEhIXI9s/8A1q+pPBOjfDee1V/C9vZ9Dvt2kLPz/eRjn8cYqsXQr0I6 x3ChOFR6M4ESx3F3HbabZXF1JLJ5SFxgM3Pp9M0L4a+J1/m1TSLbT4ZCoWTcOPXd/EufpXoHiCzs 9J1+KCWNFtLu7tbyNAowHWRYpVx7o6t+Br0YlIwNi4x3NeQ4t6M721Y+ff8AhT3iK1s7nUZb6OSW FHbyIiWMmOwJ6H+dUdH0bStZ8WafousSs1vc4cGKQqHOzK8jBwcj86+jhKp/g29q+e/GNlJ4R8bi e3XbH5ourUt0C5zt+gII+gFXCmkuUi67G54o8Maf4YuLa00xSIXi3sT3fccn8sflXNA/IcHpXc6/ qtp4n0bTtRtg0cjxsskL/eicbTtP4NkHuCDXBMdrODwQatRS2Fc958Hv5ng3TjjnytpJPoSP6Vsu kb5VmD5GCCM8Vx/w61FLrw2tnkrLbE8H+JSSQR7ZyPwrsjx04PrSGcNocFxpPje90qY/uEsEFs5/ jiWRto+qiTb+ArrCztIQFYD19awNVsXm8d6JPHMY2+zXA3diA0ZKnPtuqTXfGXhjw4rrfasjyjIW OL52P4A07CbNS/sxf2D25YpICHjccFHHKt+dcNf6Zr+seZLqClWibagchQW6YQHr+HrXP3Xxm1O7 UWug6InnsSqynLbvQhe30/nVaPwh8SvGjrNrd09paMQdtw2wD6IOfzFQ7FK/Y29I+Knh/SvDdtYX 1teC+s4VhaPauHKjHDAnHTocGsqf4n+LfEErWPhjRmgVjnKIXf6nsK6/RfhH4b00LJf79Sm6nzPl TP8Auj/Gu4trCzs4BBZ2scEQHCxqFH6U7sdu54vbfDXxVr8y3fijVzCDzsLeY4/AcD867jRPhv4U 0VVZbH7ZMCW826O/B9h0/Su4EQK8jn6UGPC9AD0wOaXqP0K6BUUIihUAwFAwBTuck1IU2kcH8KcC mKLhYrsWHbH40+3Rw2ShIPqaeZB/zz4pfNxwBj6Uhl1JEA29KkMiKB3rKMnORk0faSp5NHMPlJp7 C0uH81GME46SxNtYf4/jVMLqFrK5uF+2wHpJGNrj/gPf8DUv2nJzgUj38UJXzZ0jLcDewGaV0Go0 SWcsTywyiTYMsoGXX6r1pNsToGGR/OsvxBrPhzTLZbzWtUt9P2jKPvAkb/dA+ZvwBrxvxF8R77xJ e/YvA6a1c3sPEM0I2+YCed6DqB1DHHfNNJsTsj2q6ksLOI3F1cx20QOC8rhV/EniuQ1L4hWUrPY+ D7WXxBqQIG21hLQLzzukyAOO4Jry2DwB8QPHHnXuv6iRc20hj+xX8rRSkAA5QbSu056jrg13Gi/2 n4I0w2a/D25ijzukksJ1uDKQOuMlifqAKfKgTbNOXTPiHr8Stqmr2mgWx+9a6cSZiPQykHaf93NX NJ8I6BojmaHRJJrsnL3kzC4kJ9dzHdn6AVSj+KHhldial9t0Z2ONt/aPHz6ZAIH4mpbbxzZ6xcva +FoG1h4zh5fMEMSH3ZvmP/AVaoaZaaOnN7bBlRrhYj6TAxk/TdiuL+I/ijSND8PvBLFb3up3aFba B4xJkHgsfQe/r074y/G3ibUtGs0gu9VDapd/JbaZpaYYk8ZaRgWIz6BSe1M+G3hK00+WXV9YuVvv ETDMkchJazDZ4IPO488/l6lJLdjbeyOL8LfDyS2tU1KO31S71gqJbaWzxbxWj9RuaUDf/wAByOo9 69l0o+MDp0Ueprpkd0F+eYO75P8AuAKP/Hq3NwIOeOe4rM1LXdK0qRYLq53XT8x2sKmSaT6IuT+P Sm58zEoJbEzafqcozca66D0tIEjH/j+8/rWdqVvoWnQCbWtSnYNwBcXb/OfQIpAY+wWoPM8T6t9x V0C0P8T4luWH05RPx3Gr2naBpunTG6jiae8b711cMZJW/wCBHoPYYFK47GPbwXl63/Eh0K10a2P/ AC+3kAErD1WIc/i5H0rXsfDNhbXS3100mpX46XN2d7L/ALoxtQf7oFao4GBx9KXPfG2i47FW60TR 7xt91pVrNJ/fMS7v++sZqsPD9ugH2K/1KxI7RXTOP++ZNw/Sp31OEsVs917IONsHzDPu33R+Jqaz F6Vd71ow7tlY4+kYx0z3PvRcLFE2HiCA/wCj65Bcj+7d2mSf+BIyj/x2qL6z4itb2Kzv9BhYy58u SzvARJjsBIq4OOxNdPkDpVDVbJr6xZIjsuIz5kLj+FxyKdxWKKeJoEJW9sdQtCOu+2MoH1aLeP1q xb6/ol2+yDVrZpP+efmgP/3yeam0m8W+sVnMIjcfI691YdQfxqa5s7G8Qpd28E6/3ZYw386LjEvr z7FprXaWtzesvPl26qzEe2SM1l6N4q0TXpGitLox3ScPazr5cqfVT/So5NA0OJt1tG9g3Y2k7Qj8 lIH6VxmufDjSdWv2v08RXVvecfvHZGOfwCn9aaa6iadtD1Pp0pplwTkc15JpWk+MPCdw5sdesNbs nO54rmcpJ/wEknB/GrcPxc8PrctbapFeWE0Z2uGjDgH6qTkfhT5ewr23PTTKhGAMfSiuU0zxp4d1 bjT9Wgcgchz5Z/JsUUW8guu5o+GvgVqED+dr+sQQq3JitlLsP+BHA/nXpVh8OvB2jhJP7PF5IOd9 02//AMd6fpU9z4hijBzIB+NYeoeMbeO0OZlyvvXYqaRwOozs/tlraRCKBI4o14CoAoH4Cs6516KM H94K8h1T4hwx7gkoJ+tcZqHj28uCRCTg+9aqBi5nuN/4ughBzMB+NcXrHj+08qSJ5FkRgQynnIrx 651jUbtiXmYA+9U9rucuxP1qrJC1ZdTUn0zWpbrSnMcbMcL7Hsamudf1O8J3TMB6ZrPWIVOkZP3U zSlUGoEREsrZdmY+9SLAAOaspbMcbjj6VOkCL1GfrWMqpqoFVIwT8q5qwkLEcnaPapiVTpyfQUwy kDkAfWsXNmiiOWBF68+9P3Iox39KiXzZDhULZ6dq2dK8L6rq8hSBFVVxuywGM+tZOZaiZPm49B9a dGkszhUjdye2P6V2lj4HRPEJ0e8nVJDbC5jkUFg43bWA6cjj8xXQXHw702a8tPPuLmS1jjbzYllM au2RtJC4z/F1z0FS2yrHj+o6vouinbqmqQxSDrDGd7j2IXOPxxWf/wAJdEQjaXpu4SPtD3PUjaTu Cg+3rXu1l8OPBem3guoNAtC5jMfzxhhz1bnufWsrxd4U8P2GlR6pYaTaW4t5Atx5UQGYXBRjgf3d wYem2lyyYHiunP468Q6bNKtnfXlrMCgW1hKjJOCrKF4wDnPpjmtrT/hF4pvrea1Sxjs4ZGyz3UrK D1BKqDkHrjI7g17t4RuEuvBmlXC43NbqrY7so2n9RW2sgDhWYbj0BPJqfZKWrBxitzxay+DjeGbG +v1vDcJ5GXgEa8kNyAfTGT2rQ/4XJZPEbDxnpC3k9u7Kl3brsliI7jkdfYj8a9ckVJYHjlGUcFWH TII5r5u+Ivheym0+60qzKw+IYJpQnGDdxH50J9yjbfqh9a3pLk2M57Gld65pmva9Y6hZL9t06dJb cPJtff0OCB0wV6HmsvU/h/o73Emp6PH9iuAh3QRgeVL3wV7Hp0ry34eeI5bK/j0S6CLbpcfaVkPB jP3WH0IOfbFe431n9usZbdJ3ikYZjmRipRhyCCDnr+laKpJSYcqcTw3xlqN1psNnHHYrZzXEW9jG dyMucAg5znrkYGMVu/s9XRk+NVg1w7s5trjZjpnyyefbGfxxXWXfhTTtS02K38U2yPcRx/aI5lco Bk4kXIxxu5x70zQvGHgj4e6nHcWiI2wMrx2gBZ8qRyx68n1rulWq14curOeMIU5XPd/iHp41Lwld XMeBc6cDeRHuCgJI/EZ/StW717SLPSYtXvNWtrWymQSJLNIFDAjIxnr9BXy34o/aG13WfNsNLtod OsJsxvgeZI6HggsemR6AV5/4me81KwOqwTSutm4tbqPcSIv+ebgdgw4+o965/Ycskpv7jV1br3Uf RniT9ofwlpBeHR4ZtXnXgPjyos/UjJ/KvINW+Kmp+P8AXYV1OGCCCJG8mGFTwTgnJPJ4FeRQ29zd zrFbwyTSuQFRFLEn2ArqtL0KTQdWtr3X7+10zym3m2kYyTMB1Uomdpx2crXQoRtaMTLmd7tnuuha /YalY2trDaPHfWVskNzOSNs4DMEwPUKACfw7VX1TCai46BgD9a5jwj4o0TUPEdxZ6ZaTKzxAmeVw MgHGAgzjlu7Guh1fel6u7P3Rg+oya5ZR5XY2Ur6npfgvXPDmkeFIL3WNRitZoJpUUFsMykA4x3Ge fwrO8QfGvTRFJZ6FYz3DkbRO7FMH1Heue8L/AA2h8btJqN1qTW1vauImijXLv36ngdfevW9G8AeF /DyIbPSopJ16SzjzHJ9RngfgBXPJ2ehuo3PGhH8UvHktoziWO2hDbLlh5AwRgkHjOR6V1+hfBSwj K3OvahJeP1McPyr+LHk/kK9eWEyNlsqR7U9bfyzuVtqnkr2H0qFd7lWSMnSvD2iaJEsel6ZDbjH3 0X5vxPWtZQeqninZUMdp2+1G47vlqhCbFY8ttb+dNMZXAzwPSnZLdRQVIGAfwNACEg8A5ppUdzim syqcn5cd6b5q9cg+9Syh5GT1qN0OMjGKVpYyMg5Iqu0hJwDSbGkOLAdWzTGOc4HFRNkdByapajqt lpNm13qd/BZQj/lpM4UfqefpU3HYvF8cZpjE7WYIXIGQoxz7c14VP8dr1JHtrTR4L6UsyRsgZFJz 8pAyxbPpwa5HUvEvi/xZqYsfEmvr4fspOGiZTCoHoUHLf8CNVyMXOuh7Fq3xZ8LaSJI7kzm7TINt GquwYdVJBwPrnHpmvO9U8ceNvHgNpoGjxWNiSds0hUNx6SvhQ3+7zXUeE/AXw8sjDI13DrN4wypu 2AB91i7/AI5r08BI4hEgCxgYCgYAHpip0Q9WeNaD8KdIhcX/AIx1S5urhvmaPDRRZ95D978CK9U0 nTtL0exWLQTFZWp6CNVZGPuepP41ga94m8I+GVkOrXcNncjkQ2bnzXHbITBH48e9eLeJPi7fXlxL H4ftzYxHgXEoVrj6hgAV/Mn3qlzS2B8sT6H1rWrXR7H7Trt3p6QD7rySGJif9kckn6V5dqnx4sYZ pLfS9OuLu3MLqslyQGSTHysvcgHrmvAr7Vb/AFK6a61C8mu526yTOXY/iaq+Ye9bRprqYup2NfW/ EWra/efadY1K4uZR90TN8q+ygcD8KyvMaJwykow6Ef400tuGGGRTVBGQp49DyK2SMG23c2NL8R6t pOtxaxb3Hm3kY2rJP+8IGMY59q75Pi/cXyj+2rCPzohmG5tkxKjd8NuXbn8foa8qyOpXZ7jkUdOQ Mj1FS4J7lKpKOx7bZ/Ea61SFI9Q8UR2lmVIaO0/d3Y44BkkUIffaQa7vw7qvgyGADStfgt2n5Zpg qSyn1LOMsfxNfLCn3NdDpOvaXY2YtbzwxZ6ipbLyySypKR6Aq2B+VZypLoaxrPqfW6RPKoePUpWU 9CojIP8A47Ugs3PIvbjP/AP/AImvnzR9c8GXRzaeIda8KXXYPL58R4x94Ddj6kVPqnxJ8TeFtVWz tPE1h4ltTGGEvlg/gSpzn8TWPs3exv7RWue4HT9QkbB1OSNc/wAABP6ilbQLWY7rq5u7thxiaYlf ++R8v6V5Vpfx2tGVU1fSJEb+Jrd8j8Af8a7bTPin4I1IKF1f7JIeNt0hjx+PT9aThJdAU4vqdalh EEA82dQBgASsAP1qQ2Nsq72lmwOuZ3/xos9Qsr+ES2V5Bcof4oZA4P5VbwT1496kq5T+x2RAIMrZ 5/1zn+tNbT7Rhjyzg+rsf61cMYGDwaRiOR37UwOUXSbPRde3JAPsl+cEOSwST156Zrof7KseptIf xQVHqlst3p0kLuqZGVYnG0joa5mDx1pcNsttc3RuNQQmNre3UyOxHHAFML9jqTptkPu20Q+kY/wq GS2t4ImkaOKNFGSWAUCvNfEvxVv9LjaO302OykI+UXTgy/8AfAyR+OK8g13xn4l8RsRqOrTeQf8A lnGfLX8hWkYNmcp8u56v4w+LOk6KZLLRlS7vOV8wY2Kf614bqmtaprd+97e/vZ3/AIn+UD6CrWj6 FqOsXP2bRtPeeQ/eYL/MmvZ/Cvw78OaVFDdeII5f7QXki4UrED+Ix+tarlgY3lU0Wx5n4f8ABni3 XEiMdvNHYucFxiMY+p5NFfTsPkC3UWrRtF2MZBH6UVm6rNVSXU8pvvHGoXTERsQD3rCn1TULknzJ 2we2arLGBUyREnAWu5zSPOUCDy2bliT9akWMCrSWxP3jVlIEXtn61k6pooFJIWPRasJaseWIq1lE 4OM0hcnkDA9TxWTnc0UREgjXtz71JlF49KYAznaNzn0XgVZezmtrZLm6H2W3dggkcEAn0zWbkWok O844XA9TSqHk6Bn+nAr0XTfhqpKy6leg99kXP6mutsvDmj6YVNvZozD+OT5j+tTqyrJHklj4Z1rU ADbWbKh/jI2j8zWbqNsNC8RRadqsTPhlMjq/AU4PH4V9AkgLha8m+K2lhGtNaSPBf91IR3I5U/lk fhTUe4r2Om1rwvpcXgzVYrGBRM1q7JKTliwXIwe3QdK5v4V6kDcKjtkz2wz/ALy9f611nhDUU1bw bZyMwdlTyJAeeV45/DH515n4IY6V4qFi7YNpfSWxz6Ekf+zVLVkmWnq0eq+KZPscmmeIYz8unz4m P/TCTCP+Xyt/wGuiySgBkx71TurSG+sp7Kdd0NxG0Tr7EYNUPCc09zof2G7YG+0yQ2c5P8RT7rf8 CUq341oQuxoQW92l1PNdXgmgb/VRrHt2D3OTmprm1g1Cwns5o90M8bRuvsRg1aEe3BZvbinAL2Xp RcLHG/D+KWx0G70W5bM2m3kkJ91OGB/HdXYAAn3rhGu5NE+L80LKfsWr2sTMeySglFP442/8CFd/ 5ZYDAxS20HvqAxn39K+cfjxLK3i62is28q/hs1ngZOCxVmJ/H0r6QET4+Y14J+0PoF9CdE8Z2KF1 sW8i4wPugnKk+xJYfiPWnHcmS0PFZdOj1a7tfF9pGLeK9V476HG0R3JUjIH91/vD3yKitviVqWha QNKtZftbwkrHNOuWjX+774969P8ACnhzTZ9HutYsLiW4GrLkwlvkiAyCo9w2eevAA9/EbbwZrmue Ib2zsII4xFvlea5lWGNUGdzbmIzjB4GTx0rqpyhzNJX9TCUZJLUkXxfqOvamLbxFqMstpcKYcseL ck5V1HQYbBOO2axLvRtVt9am0u6t5Fuom2spB/Aj1BGCPXNLHDptrdOk3mak8bY2QApG34kbiPwB rsp9d8feJVtFtrf7ElpbrawypGI5FiX7qGVv3jAZ6Fj6V03Sd5v5GVr7IwrfwbchXl1bULXSIUOG N4+1+meIwC569lrpNC8ZeHPCd1eXdjYz+IL6/iktZ4rnCWcsTcANFgs/GG6rg9KjsPhxPcyefrep szMclIeT+LH/AArvtJ8O6JoyKLGwijkH/LVvmc++48/lxWc60PsouMJdTg0j8eeIrY2mnafHoWlO ADDbxi2jYdt2Pmk+rbj71bsPhhAkwbVb57hh1SP5V+mev8q+jtC8A3NxaJPf3aQI4D7IxufBGec8 D9a7DT/CuhaW/m29kjzDnzZfnb9eB+ArnniJPQ2jS7ngGm+CTpOnSahYaKbW1TAa4KYJyeOTyead rDF/ssrHqhU/UEf41714zTzfBWocZIVWyPZ1r5+1XOYT25FRF33KkrHqnwdnU2OrQkkbZI2/MMP6 V6hvGNu0fXNeOfB+Qfa9WhY/eSNuvoSP6168DtPTisp/EzWOw9pJF27F3L3GcEU4uT1ByKhZ8d6a ZTj1rMoskKU64/pRlFXiqZ3HnNcj4w+JPhTwLb/8T3Uf9LZdyWcA3zOP93Pyj3YgVSu9hPQ7jzSR UbPg5B574r5y8LfHXVfF/wAZNL0y2s0sdDuVkgFs7BndthZXZscHKgYHGCevWvoFZZHB3oq+m1s/ 0FEk47ii09iVncnJP41FjP8A9asP/hMPDQLhteso9hZSJZQnK9fvYziuD8Q/HDw7prPb6NBLq9wO A6ny4gfqeT+A/Gps2XdI9TEsJY+VKjsDghSCQfeuU8Q/Efwt4b3x6hqaPcrx9ng/eSA+4HT8cV48 ulfEr4gXj30dlHodhOdxKqbeI853beWYn+93rrtH+CegWKLLq13cajdZByAEiB/3TnP4n8KLJbiu 3sjl1+JfjzxBfy2Hgu2u5YSTiSaJJZFB/vNjao9P5mr1r8IvE2uXUep+Mtca5lJy8AnLSY9A5BVf oARXpkWivpcWzSkt4IwchLbNsB77RuQn/gIqC98RS6HB5+r3KW0AOBJeIFBP/XSMkf8Ajgo5uw+W +4/Q9B8NeFogun6C1jKBhp2j852+sg3HH5D2rYlbS9TtmSX7LeQjllkCyKPqD0ryHxF8c9KW2ktN J057yfODK0rJF9RjDMPb5a8g8R+NvEXiibfql9ujHCQxKERB6YHX8c0KEpasTnGJ614y1P4R6b5s cGmW13fj+DT1ART7n7g/AE15RP4311Hli0nUr3TLJxtW2hupNqj8+vuAK5ctkUma2UEtzGVRvYe8 zyOzO7OzHJZjkk1GSfWkNdF4d8F+I/FEwXSdOkeLOGnf5Il+rH+QyavRIjVnPZNLhwgcghTwD2Ne ial4f8K+BL+Oy8SQ3HiC/aPe8NtP5EUWegJxuJ/L6VwFzcedK3lq0cAZjFCXLCIE5wM0lK+xTjbc hDGnq3rUfalqiCwNpHvTGQDlCVPtUQYj0p4k+tVcLBuwfnX8V/wqRSNuRhge4pnBNL5O455B9RxT QhSc0cjijEg6qHA7jrQDn7pyfQ8GgLjlbtyKcHI6VGAfcUxpo1GA+W9FGaAuX7a/ubSbzLeaSBxy HjYqfzFdbpnxO8aaYF8nXJpkH8NziUH8Wyf1rgPMmZsqqp7scn8qUqX++7P+OBSaTGm0e1WH7QOo QusWq6Rb3h9bZjG365Faen/GW81KZ0urvTtIjc4QvBLKUHqcdT+VeCqQgwoA+lO8zHfmodOLNFUk j6VudV8IPprahrfjB9cGMiBJ/KjJ9PLQg/mTXmU/i7V76/uU8KWcOi2LjY/2WMRgj1Zsdf1rzjzW x1zUgvLkQmATOsR6puOPypKmkN1W1Y2bqCN7nyoriTUb125ZMkE/zNegeFfhTf6iUvPEDG2t+ohH 3m+vpXC+F/F9x4XuDNb6bZXRbq06EsPoQeK9S07446e4C6los8B7tBIHH5HFKXOtEOHK37x6fpWj 6TolssGm2aW6jglBgn6+tagdmPU/WuK074leDNRAA1hLVz/DcIY/1PH611NlqOm36B7C/t7kDvFI rfyNczT6nUuXoTvYWUrktAqyH+NBtb/voYNFWBnPeigo8PSFF7ZqXci00DIwXLeyCrMWn3Eyeb5X kwqQGkc4AycDJPHWtnI4VEhDlvuj8TTgjP03N7KP616Bp3w1uWQy30yRY5253N+nH61reHNL0j98 rWSPPA5Qljnp7UtR2POdP0TUtSn8m0tyWAyR3A9TntXaaX8NZGxJqd2qDuqfMf8ACtnW0/srxFom uxoscLSHT7jAwNkn3CfYOB+ddcFboc1XKK5k6f4Y8P6bgxWSyOvR5fmP+FY/xJtFv/AV2qoB9mZJ hgdADg/oTXXlcGquoWcd9pt1YyDKXETRH8Rj+tVyktmL4S1Wa98K2vnndc2pNpNxn50O3P4jB/Gu hy7feH515/4EuXtry0ilBWPVrQHB7XNv+6kH1Kqrfga9J8o4+tJFy3KqrJvI4CY49c1i+LdH/tnw rfWuN0gjMkeP7y8gfj0/GujERB5ORTxGPqKexJ478ItRVpL/AEaV8HAnjB9uG/p+Vc/4pU6H8U9V WP5VnEV3H9ccn86qav8AbvB/xGuv7MUCaCbzIEPR1bkL9CDtrR+JNza6nqPhnxPZqyQ31vJbuG+8 jqclG9CCSPwqJLdFqWqZ7tbGOe3injxtkQOPoRkVh3af2P4vt9TXi01QLaXWOiyj/VP+Iyv5VN4L vFvvBOlzg5KxeUef7h2/0rU1Oxh1PS57GcEJKuNw6qeoI9wcGhaoHoy6FGelO2jHvWVod7Pc6f5N 9gXtsfJnH95h/F9COa0nEkuUgbDdjtzj8KQzkPEllBc+KNHS4O2K/iuLBpAMFSVEsZ+oaLI966LR b2e6sAl4Al5bnyph6sP4h7Ec/jWN43xpuhWuqX11Eh0++trnacBtvmBH4/3Xaue1340eFtJV4dKi fU7jOd33UyBjNFmK6selgFpNi5dsZ2j09awfEmq+FLHTbi18S39qbWZCkluxD71PbFeEan428ceO tSg/suxeN4STF9kjIZARgjcO36VoaT8F9e1eb7Z4l1VLUE5ZA3my/wA8D86d4oVpMgi+IvgzwNZS 6Z4C8PySo7lmlv5WlDZIyMHoOO2PxrwrxX4r1G9Z7JnMNukkrwWy/dt1kfcUXPIXnp9T3r6k1L4I eH5dGW30i/ubG+Q5+1SASeZ7EcYH0x+NeS6v+zp4nilluIJbK+GC37mZldvwZRz+Na052fMzOcW1 Y4j4b2MY0+81GRQWZ/LBJ6ADJ/n+lel6FpsOu3DxWeo2oKHDL5gZ/wAFHWvLdQ0K/wDDk50i63x7 MSNASw2sR3BxzUEE0tvMssLMrqcqynBB9jSlq7jWmh9P6F4W8OWE8b6vDc36g/NskCfpg/zriNT0 2+ivGcqFiVjgJ2GScfrWZ4S+KPlQJp3iGMyIgwt2jEytk8Ag8N165XgdzXqWpaVcGIXkG26tpF3C WA71YeuRUc1tC+W+qJdC8ezLaxW+oos2wbfNBw34jof0rsrDXNM1V9ttdRmQD7jHDfl3rxi6tY2c svyN6rXd/D/TPCX7u41R472+Df6q6YwohB/hIyGPT722q5YyC7R1viJVl8L6jHxzAxx9BmvnvV0A ijYf3q+ofE994St9Inh1OT+yZ54H8pCBmQYwMbMqeT2NfMOsnNmWHZhVRi47kyd0dX8J5NviS9i/ v2pP5Ov+NexZZSQTxXhnwxn8vxmq5/1lvIv8j/SvbGuAvzNgADJ+lY1PiNaexYGDyDmqGq61pWha e9/rOowWFqnWWZwo+g9T7DmvGfiH+0DpHh+aXTPCqxavqK5Vrjdm3hP1H3z9Dj37V8weIvFmv+Kt RbUNe1Oe+mJO3zG+VB6Ko4UewFVGk3qyZVEtEe7/ABA/aPmkMumeA4jBH91tTnT52/65oeFHu2T7 Cvne+1G91K+mvr+6lurmZt0ksrlmc+pJqmWzRXRGKjsc0pOW5t+GNck8O+LdK1xFLmxuY5ygONwV gSv4jI/Gvou8+PGreJLtdL8B6IyzynCNKvmzn3CD5R+O4V8w2kMc1wqSzrBHn5pGUkKPXA5rtdN0 3RYUBjlaWRhxMWKH6rjGK66OCeJejS9TN1/ZI6bWpbW21Oe58b+JGl1CRy8tlYBbiYN/ttkRp+BJ GPu13vwy0DSPEllNrOhWN/ZSWso8qe+OGYkc7JVGwgY5BjJGeteQp4a0w3CPiVo9wLrv6rnkA9iR 35xXudv8avCuh6HHaLo0tq1vGI4bSB08sAcAZyCB+BqcVl9ejH4b+aNKOIpze53E1/450kZe2h1W Jevy7WPsGT+qCshvjF4dtJpLXXLS90y7jHzRlBKCfQEc5+oFeOeIvjJ4p14vHYXA0q0bjZat85Hu /X8sV53LNLNK0s0rSOxyzMSST9a8xUn1Op1V0PZvEfx41C4MkHhqwWzj6C4uAHkPuF+6PxzXkuq6 3qut3TXWq3893Mf4pXJx9B0A+lZpOTmjNaqCWxk5uW4DBNLmhVLkBQSScAetXdOtbSfUYoNRuzY2 5bEk3lGQoP8AdHJqtiUiooz9TXaeGvhp4q8TlZLOwNvann7Tc/u0I9u5/AGvW/BWg/CyzWKXTL+3 1vUOqtcEb8+0bY2/iPxra8U/EbRNCV7e41T94FwLWxw8v0L/AHV/nWEqj2SOiNJbyZwl18Ofh34W 09LXxf4guhqsqb8WoJC/7oCnI+v6Vy83jWbwwUg8F+LtSubRDgW97arsUexLH+QrP1r4g3V5NcDR tPh0iOfIeRMyTyD/AGpW5/AYrimJJJY9eSaqMW/iFKUVpEt6tq17rWqz6nqMvm3M7bnYDA/AVRIO AcU7aMZpcf7NapdEYt31ZHk55pacV9fypcc47UxXGYzTgM0rFEXJYCoRcxF8Juf/AHRmnYVyYDFS qxHXge9QZnfoqxr/ALRyaPKUn53aQ+/AoAle5TOxWLH0UZpp8+TgIsa+rctSg7BhVAHtTt5B+tMC KS3ZUUKxkx2boaRGT7rL5beh4qx5vGCOKRhHIMMB+NMQ3bxwOKacUeUyHMUmR/dPSm+ZhgsqFD6n oaQxf5UuM04KD93rTgCB0oAi6GlzipFRyeFBFaNtomqXmBa6ZdS56bImYH9KWwzLz6U4cjrXX23w 18ZXYHl6HOg9ZSE/ma3LX4LeL5gDP9ktu+Hmyf0Bpc8V1KUJPoebgN2qWGe4gcSQysjjoysQR+Ve v2vwKvTj7XrkCeoijLfzxWza/BDR4zm61S6m/wBxVT/GpdSJapSPK9P+IHi7TCFt9cudo/hlPmD/ AMezRXttv8JfBsGN1nLcEf8APSU/0xRUc8OxooT7mx4m8Ipp3hqS60fe11EcsWGcj0A7V1GpWVtr XgG5trIxmO6tN8JjAwTt3KR+OK6G6tVubSS3YcSKVz6VwXw61J7e+1Twldbw1jMz2xcYyh5ZPqpb p6H2p2szG7asdl4W1Ear4U03UeC00Clyf7wGG/UGs6Zl07xYAYlEN6vLKP4v84qDwUDZ/wBt+HmI X+ztQfy1PaKT94n82rT8T2fmaULiM5lt2Eq4Hp1/SlbQd9b9yTXtMj1jw3eaX5mHmiIRv7rjlT+D AGjw1q/9r+GrO9kG2cp5c6nqsi/K4/MGpbO5+02MNwoz5ig8ViaTGdJ8a3+lyHZa6ov262HbzBgS qP0b86afUTWtjqydw6U5VOOT0p3lnHXNKVwuSadyTzZrW4h/4SG2s0ze6LqY1S1A7pIocoPYjzBX odjeRahYQXlu+6GdBIh9iM1zMp+w/E+3Y8R6rp7RH3kibcP/AB1jVnQT/ZOpX3h6TiJSbmzOf+WT H5l/4C2fwNSV0OlBDdyMU7O3vkVAzegNN3kYpsEeSfGDTETUdM15F4cG2lPuPmX9C35V534w1ldQ spHtQ0cUc8V3MjAEGbaFkdMdAx2kjuea+ifEvhaXxT4dmsCBEGZXSZztCMD1yfbI/GvCviH4Y0zQ NPkgt/E1nd3MkBW4tgpJyvI2MOp7YIHSpd2F7aHonwf1EzeF7mwZjvt7gkA+jAf1Br0ySJ4oGlup Y7WH/npM2wD86+VfD3jPW/DFlHe+H7ny5p0VJ0ZAwPHv0IPpWgun/Efx5N593LdSW7/xysUix7et QmktTR3b0PZ9a+KPgnw6ssSXf9q3RIJS3XjI46/56CvKfEHxa8ReI7qCPQdN/s5onzDJb5833GR1 B7jnNdJonwX0632y63fm5bGTHD8q/TJ5P5V6No+g6PoahNOsYIDjG5FySPdutHO+iEod2eJ2vw68 f+LpPtWt3ctqjkEvduc49k6/oK9D0H4PeF9NVJdQWXVJwOfN+VM/Qf416FvxwGH41IJRwMHNTvuV ZLYjtbOzsoFtrO2itoV6JEgUfpVgs2cDFR+YRnim7ifrQMWRzs+UYPvTWbI2sM54pdhYkk4+lLsA Hbj3oAxda8L6D4htDa6vp8N0uOGYYdPdW6iuE1j4LeHLrSJYNNiMN5HEVt5CwRQ3YvtXLdK9RGAc KOvpTlwDljtHpQm0DSZ8Y+I/A/ibwpOf7W02RIc4W4j+eJv+BDp9Dg+1L4e8b+IfDSvFpeqS20Tj DRcOmfXa2QD719l3HkyxNHLEksbDDK4BDD0IryrxT8FfDGt+Zc6O/wDY123OIxuiY+6dv+A/lVcy e5PK1scj4I1/w3q6yxeKvElz/aVwfkebakS+nzY6/wC9geldnP4Y1LTZTLasL22fkGP73sdvf8M1 4J4q8AeKfCDPJqNgz2inAu4PniI9z/D+IFP8G/EbVvC2owCa/vJdLX79qjgg+wDggfhijXdBdPRn q2ss0irLIW3RfIQ3VR/n+dczezNLbvCMEnoTWD4q+LuqeIJSLXTrSwhGAG2+ZKw9Cx7fQV5vrPjn XJjLaRvHbIcDdEuGxj1PSt4NvczlZHcXHjM+DtUjvILofb4clIoyG4IxhuwGD3rm/Gfxj8X+MrIa fc3EdjY874LQFBL/AL5zkj26e1ecPIzMWYkk8kk9ajJJraVm72ME2la49nJpvWgD1pwGfpRYQnFS JG7uEVSzMcBVGSa1NK0G+1RwY4/Kt/4p3GFH+NdbbXOneGo/L0i0EupDh725XJT/AHFPT60OSiUo 33Mo+B9YtfC91ruoRi1ijRSkbkBmywHQ9+c4698Yq7p3hC/1DSYr63vFR2HEbgr+RoFzda9qkMWq 3c0wlPl7mbO0H07Cu+0TTX02y+xvO0oDfKzdcYGB+lVCo0r9RuCbseeXOl+KdLQhoZpEwfmj+cAe vHIrl4mVr4fbC23d8/rX0G4SCFpZpFWNRlmbgCqlzomiaxGJLmzt7oOOJVAJ/Bh/jW31mUrXd7E+ xS2PPLCXR9gS3EQGMc1ZfT7OYZCBfdDitq6+FMNwTLo9+9s/aOUbl/Mc/wA6wb7wf450IbzYSXkH /PS2zJ+g5H5V7FPHUai5asEcUqE4u8WVZtHIyYZQ3swwa7bwR8KLrxVturrV7O2twfmiilWWfHuo Py/j+VcBDrzwyGG9gaOReGDDBH4Gte11m1YgxTbHBzkHBFKeCwtdfuZcrHCvUpv31dH0z4f8D+Ff DICaVpYubtetxIA7g/7x4X8MVf1Twdomv861pNrM3X5Iwr/i4wxrwrR/iJ4p0dFW31Rp4E6RXH71 cenPI/AijxZ8VfEut2f2eG5i0qArtkW2JVpPXLEkge1ePXyjE09U00ehTxtGWmxZ+IPhn4aaAsia Zql2mpjpaW7CZVP+0T9388+1eSM2T60pcvlt+7nrnNNxmuKMHHRlympbCZ9BQASetPLAR4ZgFByD UHnqWxGpkP8AsiqIuTBT68UpdQOfzqI/aX/uxD35NKtsp/1haQ/7Rpi9BDJlGZBuA64pmbl+gEY9 Tyas+WFACjAqa2tLq8uFt7O3knmc4WONSzH8BQBQFuGOZWMh/wBrp+VTKoUcAAD0FdpafDHxxeEb dAniB7zssf8A6ERXRWfwO8WzkfaprKzXHeQuf/HR/Wp54rqWoN9Dysbs9c0u3vXutl8Ak4N/4i+o hg/xNdFa/BPwdarvvJ7y5x1LyhB+QA/nUurFFKlJnzRg+lGOK9x8SXPww8JB7bTdDttSvhxiRjIF Pvk15w9jd6/cNqN1BbaXZdcpGI1A9h3oVS+thunbTqcssckrhIkZ2PQKMmlkhlibZKhRvRhiuqW9 htf9A8OWbyzNwbgpudvoO1dh4N+H+m6ndC48Ual5NwxyLSXMbt/31jP4UOVtWLkvojyQLz9KlVc8 Mcj3r6ivfhL4LvLcImntbMBw8MhU/wCFcZqfwJ+82ka19EuU/qP8KUa0Rui0eGG2xl4WaP8AVa9O 8IeJfh7YaVBB4n8LxveLw9yitIrehIJ4NUNS+GHjHTAzHSzdRj+O1YP+nX9K5C5tLy2mMN3bSwSd 1kQqfyNaXUtmZ8rjq0fSmh6/8LNQURacdMt2fjy5YVjz+YrqxpVgsYbTZmtkPK+U+U/AHIr41MI3 ErlG9R/hWvpXinxFoLZsNTuIUHZGJX8VPFRKlfZmkatt0fWaJqkXUwXS590b+op7X0aHF3bTW3uV yv8A30MivDNE+N+qwbBq1lDfR9C8R2P+XSvSdI+KvhDVlVHvfsEzdUul2jP16Vi6bXQ3VSLOwiaC Yb7edJAe6sDUhz3496qJBpV+guIDDLu6Swtz+Yo+yTJ/x73kmPSUbx+fWosXclOBk9KKrma/hBEl qsnvC4/kcUUFHZbXIrzvxBaTaN8Q7bWYFwdQTAPbzox0/wCBJkfhXoPnHjAzWN4n06TVdBlSA7by Ai4tmH8MiHI/Pp+NdG5wbamVbXkcXxLt7yFR9n13TuPeWFs/mFbH4V2so8yIqV4+leQ6hq0dvaaJ rcaiOCK8ju0H/PJXJjni/An9PevWjMgHDZ96XUt7GBo0sdpPc6S5w8TmSIdyh9B6DNHia2uJNPj1 OyUm90yQXUIH8QH30/Fciq93qUOn+KrWdrd2Wci3kl24UK5wMn2OPzrqPKKSFWIIBpR00CWqTEsb 2G/sYL62JaKdA6H2NT/Oev51naBo95p63ltBH5tmJt8AU8xhuSuPTOan1/UrTw3Zpe6w/k25cLIy EM8YP8RXOSPpzVakaHOeMQLNdF1nBJsL+MuxP/LOT923/oQre/sk6jqVncqrxPbSZ8xVzhSMMD7V 5946+J/geXw5qWi6ekuoz3EJRJ+io3VWH0IBrgb/AOLHjzxSkVjp7tboVC7LRPmY49qT03GvI+gd W1TRNDt2l1rXba1IBwqncx/DNeWXHx4t7K0eCw0WK5vUZlFySSjjPDBTyufT9a5HTPhZ4q1yb7Xr dwbRG5LXDl5D/wAB6/nivQ9G+F3hfStrzwNqU4/in+7n2Uf1zS5uyCz6nm154t+JXj65aG3e7eNj jZbqVRR7ntWtovwVv7mQT6/qAg3cmOI73P1PQfrXs8EcNtGsEEKQxLwEjUKo/AVZV8HBPI6VLu9y 0ktjndG8D+G9CjjW109ZZY+klx+8K/TPA/ACumPHIANLvyPemgc9MVJQ1c4IPfvjpSkED39qecLz zimHceFG33NAxcceuKeeBndUYY/xNn6cUocKeOlSMeMsO9OAI/zmombv1pyucbieO9AEm7np+VIM 4xyfrTQQPU0hfnB60AKXzjBprNzntTR1yOteHfF+58faPcHUbbW5YtDlYRxi0PktESPusRyc4POf yppXBux6rrnivw74cjL6zq0Fs2MiItukb6IOf0ryTxF8fIYy8PhnSi55Hn3hwPqEX+p/CvCJ55Jp XkkkZ3Y5ZmOST71UZiT71SgRz9jpfEXjnxP4nYjV9XmmizkQKdkQ/wCADA/HrXKvzTwGY4AJ9q7v wv8ACnxT4lCT/Zv7OsW5+0XQK5H+yvU/y96rRE6yPOzkVj6oh81ZMdRg19f6P8EPB2n2oF/9o1K7 4PnSNtVD7J0I9m3VlfEH4a+EZdKkutROn2O1cC5tytnLx/sf6uQ/QIfeiNVJhKk2j5CIzS4rX1fS obK/lj0+6N9ag/JN5RjJHuuTj8zWYiHdgDJ9K61Z6nM00Ogt5Z5ViijaSRjgKozXoHh7wOcJeatG XXPyx/w59z3+grIsrmHT9MjgtItty4zNOfvHPRV9AK27DxhqlpCttPILu3HRZfvL9G/xzWcpvZGk YrqdNd6cWCiEgIgwEAwB9B0rMn023myLiIFvXoR+NaFn4i02+AUyeRKf4JOPyPStBo1fgqD9amL7 ltHN2NvFZXsMEUUcgZtxd/vDnsfau8gCSWuScPGR+IrB/s+PzVlQ7WBzitWN8dK1draERT6i63DL c6HdwQRPNK8RCoikkn2AqD4caT4FaVZ9e8US218DzZMTbKPYufvfQYrd0yKK81eztZndI5ZkjZkc owBIBIIwQfcUfEKz8DaEssc+v3Wr6iVwLWZluZF9jKRlPxJPtXK21ojpST1Z7JpfgvRdTaO60ufy ldwFhVwxkXH31DEEj6E/Sumuvh+1vE26Lcij/WIMg/h1H5V8aeE/EdzYy3cFrdTQKSJYIvMJVcEn oeM9O3avQ9D+P/jTQbqbz9TN/FnctvOgK9eQD/CPYVtCTSszGVnqj03xB8PdO1KDzbjTrS/RejPG r4/GvFvE/wAI9HMjSaf5ulTdgvzRk/Q8j8DXq+l/tQeEfEdxFYa5p0mk3JOPtahDE3bBLHKj8e1O 8X6nHqGqi103T47e0VFbzFnWUS5GQ4ZSRgg9ATWrq2VyVC580X1z4n+HnkWbXUN1BOzSKjrvjbGB kqe/X864ea/ubnJlkOD1A4r0/wCMKD7VpEBP7xIpGP4sMfyry2G2klbYoGR156V0RrScb8xjKCi7 WNOCfFtGkaE4A6Cpf9IfguE+nJp0abEVeuABVhI2c4Vc1yN6miQ/StCv9Zv0stNs5r25c8Io3fj6 AV7RofwEuZbWOXW9X+yysMmG3QNt9ix4/Suf+HGk/EOO8M3hdXtYGIMslwgEL49dw5/Dmvpqz+2/ YYP7QaH7VtHm+TnZu74zzisJza2N6cE9zzSz+B3g+32/aDe3bd/Mm2g/98gVv2nwx8D2R/d+HbeQ jvNmT/0Imu2HJ6c088YDYK+orHml3N1FLZHNP4P8NyWptZNBsDCf4BbIB+grkdT+DHhC9Jlso7nT ZeoMD5A/Bv6V6cRljsY/j2qMgt35pczRXKnuePL4H+I3h47vDviz7dAvSC6J6emGyP5VKvj7xvoA 2+KfB8skK9bi0HGPXjI/UV6jqF/Y6VatdX9ykEaDJLnFeL+MvjIsiyaf4bi4OVa4cdfoKpNy6CaU Ve51KfGHwhLYtObiaOZRnyJIyGz6Z6V5j4j+I/iHxbdHTtKzaWrcYU4JHua89lZ57h57uQ73O5ge Cav6Vo+qa5dLa6RZySv6qMY+prVU0tTB1W9EaIh0nRCXumGpah12A5RD7+tb+h+DvE/jm5Se5DW1 hnhmGFA/2RXe+CvhHZ2gS819Gluhz5TD5V/xr1uGCK2hEUKCONRgKtJzS2KjFvyOa8MeBNE8L2yi 1t1ecj5pn5Jro7iytLqExXVvFPGf4ZFDD9anyfXH4UxznHt2rFu+5sklsZB0K3thnTbiewP92J8p /wB8tkflTN2uW4+ZLfUEHdP3T/lyD+la4Y5PH50hI6gUhmSur2yMFu0ls3J6Tpgf99dP1qxPaaZq cG25tre7jYdHQOKuNtdcFQQeoPes99HsmYvCjW0n96Bin6Dg0DOU1P4VeDdR3Mli9lIf4rdyo/Lp XFaj8DZzubSNZV/RLhNp/Mf4V695GqW/MV1HdKP4Zl2t+Y/wp39pGLi8tZbY/wB4Dev5irU5LqZu nF9D5o1X4V+L9O3SNpTTKP8AlpbMH/Qc/pXIXNlqVhKUuraWNhwQ6FW/I19ow3sNwuYZ0kHsabc2 dhfIY720guYz1EsYYfrWyrdzJ0V0PjnTNd1LTJfM07UJ7Vwf+WbkfmK9A0j4yeJbHal+kOoxDglh tb8x/hXq+s/CjwPrEbN/Zv2KU9JLZtmPw6V5Rrnwgv7K+8rw7f8A9pp1MUoEbj23fdP44q7wluRy zjsegaR8V9O1kC2g0+5jvG6IV3KPxFFangXwvpWmaXGDaNa6lj95FcLtcH+tFZSir6G0ZStqerBV x70pKbcZxUPOeauQ2F1MN/l+XF/z0kO1fzNXc52u55N4y0iWK31PS7fi2uybqIBOUcghgD6FgCRX ZeENSXV/BOmajIQHeBVkP+0vynP4im+KvEngTQzD/bmpLqEkT5NvaHLe46j/AD61893ni64t11PR tGeSXRnvWnsmmGHjUlsjHTDBsEH0B4qba3YJq1j6hutFleJZbp4LKAcl7ogYHqB1POKwdY+JngXw 7GsL3j6veRrt2w8KSP8APrXgFnD488VwRWcMt/d28Y2Luc7EHoWP9TXZeHvg8JLop4gvzGQnmCO3 G7cM4I3HgY+h60cyWw7N6Dtb+OnifUd1toFnHpkDcDy1y5rnbbwj4+8Yyi5vzceW/Pm3blV/Ad/w Fe56T4P8O6CqtpumRBwP9bJ87/men4Yra8wdCRmm23uSkjy3Rfg3otmqy6vdSX8g6xp8kf09T+ld /p2k6XpMAh02wgtU6fu1AJ+p6n8aus4ZtueRUZ3Hk4AFTYsdk9s0h3dd2B6UzJAxuo+maTGiQkE9 M0qktgbSCKQN2HFLuI4zSuFiQMQcE5p+8dBge9Qlh94Ac00vnA5pNlJFgOD8pNBbb9DUBJwMZyO1 IxJ+bdSuBOzZI2459KbncOQKjSQkeoPpVTUtX0/SIYZdSultVmkEUe4E7nPRRjPPFIovgkDaDxRk ggE9aw7rxR4etLH+0LrXLKK3B+8ZhyfQAck+3WvOtf8Ajtotruh8P2EupSjIE0x8qMH1A+8f0pJN 7DbS3PUNW1yw0NLd9QeVFuZPKj2RM+W7A4HFYWrfEzwbpEDS3Wro8ikqbeNS02R2K4yp+uK8Pm1j 4mfFES2lsrvYBgJI4FEMCHqNzE5PY4JNdX4f+A9uNk3ifVzM55NtZ/Kv4uwyfwA+tW4pbslSvsiv rfx01O/lNl4T0fyS52pLOPNlb0wg4B+u6sq2+HvxI8cXKXviW9ktITyGvnJYA/3Yh0+ny167pngu DwvvfwrHbRBzl4LqPcT7CUfOv47h7Vqx+IIbciHW7aTS5egeU7oWPtIOP++tp9qnmS2Got7s8xm+ AGjtp5SHXbxbwD/WOitGf+AjBH/fRrjb/wCCOuWed92pXtLFE0qfjt+cfghHvX0xNd2kGnm8ubu3 gtwMmWSQKuPXJ4rzDxH8bvCujl4dKEms3AP/ACy+SIH3Y9fwBoU5dAcIo4bwy2hfD11uNZ8NLqSb +NWhImMR7DachcfVW9RXpd18WPAltpQv11lZw3SCJCZfoVPT8a+evFvxE1zxbdtJcLb2ceCuy2jC Fl9Gb7zD2Jx7Vxxb8qrkvqyfaW0R7J4l+PGsXwkg8OWcemwngTygSSkew+6v6/WvItR1TUNXumu9 SvZryc9Xlcsf1qoTg8Um4mtFFLYhzbGnPeozEmchBu9cVKOTU9vaz3VwsFtBJNK5wqIpYk+gApit cp7D6UbSD7V7F4T+BXiTWnSfWpE0a1ODtkG6Zh7KOn4n8K9dT4NfD200htLbTZryd8brjzD52fUE YC/TGPrUuaRSg2fIkcbO4Awue54FereDtZ+H2m6SLLxFb6itxJwbpJjLGv8AuqMbfyatPxV8APEG nq934anXUoASRbSMFnUfXhW/T6V43e2t5p13JZ6hby21zEcPFKpVl+oNHxbME+XdHvaeFbbWYHvP B2t2mqx9RbGZVnA9x6/XFczOJ7O7ls7uNobiFtskbdVPvXkK3rW8qyQzNHIvKsjEEfQihb+988zR ySLKxyZGY5J/rWkW1uTJxex6tqup2VrpkonnVTLGVVepOR6V5KzxKcFhn260spnuW8y6uHkc9aRY 0Q/IgFNEN3HQTzRSCWAujocrn1qbU7lpY0MOPMufl2A/dPcf4fWoeTVK4JN5scHG3jnHXnNMkpXE ctvM0M6FJFOCrDBFfRfw58QQ614MtYEVVuLCNbaRAf7owrfiB+ea+dLiSSefdKzO44JY5JrsvBev zeFtZheWDFpJ8k7AclT3/Dr+frUtXRUJcrPVfHnhqHxDZ2kck3k3SOUhlI+Xc/AU+xIA+v1rwmCG a01KW0nTZLCzRuvoQcEV9MXT2t5DEHkUoxWRGB9CCCPxxXlfhrwvbeNfjZqmmySPHZma5mkkiIBA BOCMjn5iKzi7LU1qRu7mV4b8K634ovhbaRZtNtI3yHhE9ya+ifBfwm0Xw+I7rUgupaiMHc6/u4z/ ALK9/qa4+T4U+NPC873PhHxB5ked3l7/ACmPsR901LF8T/HHhlxb+LPDjXEanHnbDGT75GVNTKTl 8JcYqPxHu2wAYxx6DjFRlljZRhvnbA4z2zz+VedaX8YPCmrbY3u20+YnlLkYH/fXSu40u6W8iM8E 0c0LDhkYMDWNmtzdNPY092c8ilGec/pUBbA3MdoHrXE+KviboXhqN4TMLq7xxFGc4Pue1CA7iaWO 3jaWaRERecscCvMfF3xg0nSBJa6SFvbwcZH3FP1rx/xJ8QfEXimVkac21oTgRRnA/E1yeIov9Z+8 k/unp+dbRpP7RlKqvsmzrniXXvFFy0+pXjtHnhAcKv0FZCArIIrRDLK3AIGc/hWlaeHfEGqQxzwW MrW7NtEhGFH41738O/hxDoVot5qMcE94/Knbkr7c1s2oox1mzxjRvh94i1bU4bWS2+zB/m3SjGB9 K998PeHtS8Laelva2VleBfvGHMUh/PIP6V0Gq6Y0ipc2oCXcHKkcZ9qsaZqCXtvvPyyLw6d1NYSm 2bxpqOpDHrluMJfQy2MnTEy4H/fQ4/WtBGSVN8Tq6noVORT32SAoyhlIwcjNZ0mjWYYyW2+0kP8A FA239Oh/KszQusCDjtSZwMtWXs1e1P7qeK8QfwyDY35jj9KX+2I4iFv7aa0bpl1yv/fQzQOxosaY CV696SKaCVQ0MiSL6q2ak27sd/wpD2EwCMU0AgcdPSnE85PAFIWAOaBChhj0pjYC5J4oJUimgj1p gVp7G2nO54AG/vL8p/MVCbWWBC0WoyIq9pQHA/rVue4htoTLMwVRWCxu9cnKRborMHk/3qA9THv4 dV1zUUt7bVpY7dD87Qrsz+Ndlpdpb6bbqisWcDBduSaW1s4bKERQoFAHX1qUleqg1dyWrlmWK1ux iZFIHTI/ziiqe4gZHFFVcnlOAf4/pp1m9taaJb3F/G7KLsZ2SDPDBWyV+lcRqPj74h+OLs26XF06 v0gtlIAH4V6NoPwc8P6cRLqcsmozd1+4g/Acn869Ds9OsNOhEGn2kVrGONsKBR/9eq5n0Ofl7nhW ifB7XtQlS41u5SwRjkqx3yH8B/U16jo/wz8KaUgD2Rv5cYMlwcj8AOP512AC7ufrUhbgDAFK19w2 G2tnZ2VqtvZ20VtCOQkahRn1471mak72ri64zEdxx/dPDfpz+FaoOWBODUd0iSRMpAzgg57g0eQX 6j1VAgIO7cAQahJw/v8ASq2nMiWfksxMsLFGHqOx/WrLKfvMOvrVJ3QmrMCQV4wOfTrUbkDPHSnA HOd2R6U1l56Z9akaGlgDzwaUEHAGD9aQ4PAP500buRjnpSZSHAsG5IpCOuOe9N+bOe9KD2J61A0K hyMZwT7Uqg5yDyPSmchhg9/Sue1/x14T8NhhqOrw+eOtvCfNkz6FV+7+OKe4zpGcRgB5VXdwMkAn 6U2WSG3jea5mWOJRlnkYBVHuT0r5Z8bfEO48Va/FcWthCtpbLJFbpNHuZ1fAJYZIzxxjpXKahP4l Frb2msTagLcDdDFdM4XHqob+lX7Nke0R9K698X/B+il47e7fVLhePLtBlc+7n5cfTNeW6/8AErxb 49R9E0nR1jt5D/qbeIzynnIJbHGPUAfWm+AfDngS8j+067NcagynLLC2EiH/AE0jH7zA/vDK+9fQ mjQ6Fa6cg8PQ2aWLj5TaBdrfiOtS3GJVpSPBtH+C/irWrgXviW/FgH5bzH8+dvrzj82/Cu60n4Va f4Yu/tVlZWuuMMZTUOHU+qkZT8Cv/Aq9ObOdpPXp3qK4ure0t2uLu4jgiQfNJKwVQPcnioc2y1BI 5yT/AIR++vU+1wT6Fq33Ec/6PIfQB1+SQe2WHtWgq+IdObBji1u3HQrtguAPofkf80riPE/xi8F2 MMlnbp/bzngxxqPKP1ZuD+ANeLan8T/EtyZ4NLvJdI0+Xpa20rEIPZjyPoMD2pqDkDnGJ9JX/wAR PCOlQyyapqYs54jte1ljYTg46bMZ/Hp715Z4l+PbzRyW3hrSVjQjHn3oDE/RAcfmT9K8KlnlnkaS SRpHY5LMckmoSx/vc1oqaW5m6r6GpqOuanqjMby8kkQsWEQO2NSf7qjgfgKzC/rTMnPQ0EZFaWsZ N33Hb/yozk+tNC/pTwme9OwrjcZzk5q/pmjalrF2tppdjPdzN/BEhY/jjpXb/DrwXo3iPWLR77W7 No0JkubBzJHKUHo23afwNfRNrf8AhPw/aCx0GK0hiXP+pwo/E9WNZynbQ2jBvU8Hsfgr4kgjivtb sneD/lpa2UyG4Uf8Cwv6k13HhXW/CvhJ10+w0pVuTkH7VAba649WfKN+DD6V1KeNRqc8kekaZe61 KjYxDCfKU+5OB+ZrE8Q6R4luNLkl8W+KdN0LS3yTDcRJI8fXAUg8sOOhFYuTluaqKjsd1ZeJtC1G EyS6zFGEGXhDbCv1zyfqOKzNV+LXhHQozDBN9qdV+7Au4fn0r5p8Q6n4Ts5RB4da/wBVlUMsl5fn ZG+e6RrgjHufwrj7i9ubggzTPJgYGT0q1TZDqJHs3if4++I7y6K6BFFp9vgqfMxIx9D7H8a8b1O9 vdY1CXUNUvJLq5lOWdz1qsX96bkk1oopGMpNibEQ4VQKcDR/Ojp6CrIFwaUAk0DH1NOBPTHFMY9Y yegJHqKqa/AIb9NowGhjPLZ52Dv/AJx07Vp21w1vKHTgg9xmqevzNe3i3B5LKM4UAZ6dB+FK+oW0 MW2Ctcxh/ulhn866tbUqxkuGkFskhDjdjaAexI6+3NcgMo/oQa7zTtR8J6tGsniS+vbZoUH7qPLr IR1xgHGfwpq19STT0/WDceGSt1dfZ7exfbG8rY8xOoXIByR6Y5wOleq/AbSobm813xjFZta29yy2 luj8k4wZG3e7Y6d8+lfP/ibxBa6tPDY6PZmy0u24hjb77nuze9ezeGPjZoPhfwzp+hab4WuGgtIg pdrkKZH6s5G09Tk9e9Z1F/KbU3d+8fRuA3J5FMkt7eaIxzRJIp4w6gg15Lpvx/8ACt06pqGm39hn +MBZVA/Ag/pXdWfjzwdqOmPf2OuWsscYy6ltjr9UbDD8q5+Vrc6k09jM1n4Y+DdY3PPpKwTN/wAt bc7D+Q4rzPxF4Wf4eoNQ0PxlLCobi1ZvnP0xwfxFX/F3xm3l7HwzGWJ+Xz2H8q5nQfh94o8a3w1H WJpYYHOTJN1I9hWkVLrsZycVtuVZ/iP438QRjSbe4aUv8oMUeHb6kU8/D+/03TzrPiW2upQRu8qI FmP+8a948NeCNF8NW6pZ2qmbvK3LGumKggq6hlIxyKfOl8KDkb+JnxzBZXmu6t9h0PT2jDnHlg/z r2bwf8HrOyVbvxABcz8ERfwj/Gu/vfB+i3l19rS1+yXQPFxany3H4jrUa2vifTGzDeR6vbj+GYCO UD6jg0Op2BU9bsvSaLYR6VLZWluIIyvyqvQH6U3Qbwy2Bt5cie3Owj2qO38TWYlEOoRy6dMeNtyu 0E+zdD+dVp2TT9eiu42BtrrhiDkZ+tZXNbHSCQOQrA8dKw9TtZdPuv7VsRuX/ltH6j1rc2BgGHPo aaRkFXXcp7UXHoQ2l1FdQLPCwZWHbrVrAPPrXOZ/sTUCVGLKc/8AfBrdVwQGU5BHBoAk8s44A/Cm lExh+c9utBY9zigFcn1oAoSaTZyP5scZhf8AvRkqf061GYtUtx/o90k4H8MwwfzFaRyvIOKbnd2x 6mgRmm/lT/j/ALKWD/bX51/MVYt54LgBoZUkHsasMCo9apT6dZzne0ah/wC8nyn8xTAtMwUEtz61 QvNVs7WMsZVd+yqcmsfV2W2iNvFfXLStwFDZxVHQPCMNtO2o3jSTTuc/vGzihAy9Fb3eszi4u1Mc A6J610cUYiiCxKFRRjAoGVUAABRxxS7hg8de9AChuM/e9qYxz0BFLzkEHv1o3ZHPQ98UAMIDdc/h RTmxiimO5sBsjPTNODdeKiXPenb8N7VZzDg5wMH86Us+wnHP1pn04pwA7nimiGhUZjjcMHPY1KSM cL+dNwD0FNZcnrjFJjRSgK2+oE7D/pR8puTjIyV4+mefatRU3xAuMEds5xWPqduJbV0D7XflCcHD DlcZ75Fb0Usd1axXCYKSoDketOO4PYqlQOpwRSAZ4xn3qc7c7Qv41jeJNZbw5oE+qraPdLCV3Krb Qqk4Lk4JCjqcA07E3NBlXf8Ad+tNZM/dzXn138YfD2mb4dQHmzhA6fYZkuUkz0G4Y2n2YCvPtZ+N PibWJTY+GrBbASHanlp507fTjAP0GfejlbHdLc901PU9N0a2N1q1/b2cHZ5nC5PoPU+wrwS4+L9/ p/2iKyvptTuo7hgk8qILeaLdwdm0OpxxjNYsfgnxRrWtRS+Mb2fSVuQMXuqb23H+7k8A+zFa9i0D 4PeD9FVJ7mFtWuBg77ogp+CDjH1zRaK3C8nqjxrUfFfxG8Z28skb3S6cpxJ9jjMcCA/33Hb/AHjX W+FvgYL+CK91zXIngkG9Y7Bg+7/toePyB+te8RRpBGkEUaxwqNqooACj0A7VjXHhyCK6ku9HuJNJ vGO5mt/9XKf9uM/K314PvS5uw+XuM0HwT4X8NKDpOkwRTL1ncb5T/wACPP5YrU1DTLDVbN7PU7KK 7tn5McqhgfzrHuvEs+hIreKYI7W2JCDUISWgJ/2gfmQ/mPeuL8R/HHwxpivDo6S6tcLwCnyRD/gR 5P4Co1b0L0S1IfEHwR0iac6j4WvJNHvV5VCxaMH2P3l/X6V5Fe3njT4deJZIW1Lybsne/kzLKko9 WH+IBp3iP4teL/EIeH7edPtW/wCWNn8mfq33j+dcC0ju5LMWZupJzWyi7e8YuSXwnsF18evEUulL bQabZw3mMNdct+IXoD9c15rrXibXNfuTPq+pz3bZyFdvlX6L0H4VjnNHB4PBpqCWwnNsCxPNNyd3 WlxgA9qNuT3A96uxFxvOcZpMD3p26JM7mzULXkZOI0JPSgCcA4xiggDG9lAqt5l1JwI9o9TxVmx0 a91W9js7SOW5nlOFiiXJJoAFuLJD+8LOPVeAK6PQfCPibxZcY8OaLcT22cfaCuyIf8DbA/DrXrvg T4G2Vl5WpeK41lnHKWYO4L/vnv8AQcV7lDHBbW0dvbRrDFGNqJGMBR6AVhKolsbxpN7ninhj4D3u nTLeav4ghglxytorOwz2DHAH5Gu4vNG+Hfg+yW81sQyFOQ+oS+YXP+zH0J+i12bNwfX0ryP4w+H/ AA1qVhDqeqa7HpN9boUjLDf5w67do5/EVlfmepvblWhg+Jf2gZEU2fhLTEiiTIE864GP9lB0/H8q 8S1zxFrPiG9N5q9/LdzE8F24X2A6D8KzX4YgHK54PrUf410xgkcsqjeghJppPJFOOfWk5NXYzEFO 74xmgKacBSAbzTwBgZpQoqQRknNMYwAZ68VatLK5vbpLWzt5J5pDhY41LFj9BXX6H8MfF2u6YdRt NLYW/VTKwQyf7oPWvZPA174S8H28dle6NNompsMST3gyZD7P2HsKzlNI0jByOR8M/Aa/vrFrnxDq B02R1zFDEodlP+12/CsDxR8FvFemb2sbddYtlGQ9sPn/ABjPOfpmvqO2ura8iWe1uI5kYdUORTn+ U5xxWHtHudHslY/PbUrGexunguInglQ4aORSrKfcHpVAbycAV9C/tB+G9TfxHaeI/KebTntltzIB kROGY7T6Z3cfjXhwgAOMfpXRB3VzknHldirDCQdzdavRkjg0CL2qRVqySVSRU6Oc8HFQAe1amiaa dX1m20/7XbWgmcKZrmQIiD1JP8u9A0e8/BrwhoGo+G11+6tDNdrO8Pz8gFcHI/Aiva1ESAIqqqKM AAYrF8L6JZeG/DNlpGnnzIIkz5nH7xjyW/EmtR1cgZbHPpXHKV2dsI2RaUoRnI+goYox47VBwFBH p1NKZDnpzSuXYfsPJ6j6Uh5GMZoDDHpSZGc0hkU8MFxGYriBJFPBV1zmucv/AAhaXEX+g3M2nkHI ET5TP+6eK6aRhtbAGe2ajUts+ZdrY5AOaAMWK81nTIVivbX7ZEgx51ufmx7qf6VetNYsL5tkc4Eg /wCWb/Kw/A1d25GehFUrrTrG9AW6gVz1Bxgj8etAye6hiurdoZVyrj8qx9OvZdPvDpd5yo/1T+o9 KedL1CyydNv2ZO0M/wA4/A9az9Tmnkt9t/ZSW0qcpMnzrn60AdYGHB3dqYTgnGR9a5/QtfguwLSS aP7Wgxtz96t/zSxO8DNAgz749QaXeCpHUUm0HBB6/rUUsiQxl3bao65NMCRiBjJ4HWsPUdXDSfZN PXdNnBYdqpXmo3OpSm0sgyxnguBWlp2nwWUO0jdL/eI5oGkRWOkC2b7RckyzNznritcqQOB+VKgc rxnFOCgN1OaBEfO3Dde1OHPIxT8jdzxUTsVGBxn2piELYYAj6mms4A4GB60hkwNxGfYUxyTkYJB9 qaAduVhkOD9KKSJUU8jk+lFMDW3kHJpwbdx/SoQ2TuGT2qXDZySFFFzCxIAd3rUgUjnFRKwyCGzT 8ndkn8KaJZOi7mxkAZ9akcKBgjP0qrLcw2ts9zczRwQoMtJIwVVHuTXnHiT4z+FNMhmtdPkl1e62 lQLf5Ywcf89D/QGqV2S9D0CS4guNyQ3EUjKcEI4Yqaz7TXdP0BL6LV7tbWygXzllmPQE/dHqc5AA 5r5EfV7wra/ZdtpLbKUWe2BjkcEk/MwPJGcZ9KuXujeJ7LTrK71KSWLTL9o7gSs/mK6k/eOM8jOS OtPks9xc6se3eI/j3pVu0kPhzS3vHHAnuj5aZ9Qo5I+uK4GS9+J/xLcxxi6lsnOCkQ8i2A9zwG/E k16p4J8B/DUW63mmNFr1wgBMt0d+0/8AXPgL+IJ969H2+UoSNFVFGAoGAo9BV8yWxPLLZnimgfAa 3j2z+JtTMx6m3s+F+hcjJ/AD616BbeA9H0lkn8MltDukTYJoPnDj0kVs7x+vuK6oMzA44xVW8vLW xtHub27itYE5MkrhVH4ms3JstRSMCXXLnT42tPFmnp9ncbTewrvt3H+2pyU/HI96iGjPYxC78I6o tvbsNws5SZbSQf7POY/+AnHtXIeKPjZ4c08SW+jQtq8+CC33IfzPLfgPxrwvU/Gmu38l0Le5OmWl wdzWdkzRRfln86FBsbkkfRN58VtA0dprTXxJZahbgE28LCcP/usvH4NtPtXnHiL496rdBoPDtglg nQTz/vJPwH3R+teLMTySck9zSc5rRU0jN1GzU1XX9Z125Nxq+o3F7IenmyEhfoOg/Cs0qepNGQpx jrTGkVTgtnFaJWM73ClB4xioGuUU8mkDXExxFExHuMUaAWD/ALTAU0vEoyWzXoHhf4L+MPEiRXV1 5elWMgDCWf7xHqF6n8cV7P4f+CvgLw7ElzqUR1i5XkveNlM+0Y4/PNQ5pFxg2fM+laTrevTi30LS LrUH6HyIiwH1PQfjXUXvwh8dWNml9q2mPbWhBMhgKzvEPUorf1r6yt7kRwrb6Vp8dvbJwuUCIv8A uqK5vxb4z0LwvbmbWb1rq5IzHaJjJP8Au9h7ms/aN7Gipd2fK1toMVtcLc6fcwas8A8yS3nQx4x6 qT8w/GtfWPEvhPVtC2J4Pt9M1dMKkthiGLHqy9WP1q7qlzrnxR8Uf8SnQoLck4228YUAf3pH711S /BCSwsWOqme9dhnfYON0J/3GHzj6EH2qm0txJN6JHLeDfhTrnixIb15IrLTZDzMx3MR7KP619E+F vBXh/wAJWvk6VaqJyMSXMnMkn49voK+eEsvGfgS6e78PalJcWqHLrGDlf+ukR5X8q9E8L/HTTboL b+J4GsZgMGeIFkP4dRWM+Z+hvDkXqe0ZA4JzWZrPiHSPDlmbvWL+K1i7bzyx9AOprxjxb8duZLTw laheo+2XC8/VU/x/KvFdU1jU9bvXvdUvpbudurytn8vSlGm3uEqiWx7D4u+O13ceZaeFbb7LH0+1 zqC5/wB1eg/HNeMX+oXup3b3d/eS3Vw/LSSuWY/nVXnFJiumMFHY5pTctxpFIeadjBpcDiqII9uR 704LUgXv2rd8PeEtc8UXgttHsXn5+aQ8In1boKNh7nPhRjOKeq8Gu61H4U+N9MTfLojzrnGbdhL+ OAc10Pgn4O6vrVwLjXopNLsVPKuuJJPYA9PqaXNHe4+VvQ4bw14P1zxXei20ixeUD78p4RB6k19E eCvg5oPhwR3msKmragMH5x+7jP8Asr3+prvtG0TTdA0qPTNKtxDbxjhckk+5PetMMB9449xWEqje x0RpJascEjA2pgAcYHFUbyxs76Jra+tYriEjlZUDCre4bwVO4mnyINmQOfesjU4Ob4e2VrI114b1 C70SbOQIJCYz9UORQuo+M9HXGqadFrNuv/LezO2QD1KHr+Brqr7U7HS7Z7m9nSGIDJLtivGfGPxo QK9l4biDnBUzt0H0oV5Mb91ana3/AMQ/CL6NcC/nRkZSstpcJyfUMp618yeIhomqa+58MaVLaQSN xCHLgn/ZB5H0zXR6L4L8TeN9SN5OrrHK2XnlGM/Svd/Cfwz0Lw0iSiIz3WOZZMHn2rVWh1MZXqaJ HhGkfBnxfq9oLlEtrVSMhblyp/QGsDxF4F8R+F9p1XTpI0Of3qKWj9vnHHNfZ3lIFCoMY6ZprwCW N43VWjcYKsAQw9DS9rK4exjY+ENh+lOUYr6s8RfB3wlrheW2gbSLs/8ALS1xsJ90PH5Yrhrn4GXI RbW3UGU7Qb43g8sDPzN5Plbskdt5x61qqkWZulJHnvhTx3q3ha2uIbS6ul3gGICbMcbe8bAqQe/Q +hr6L8HeP9D8SaVZiTVLUaq0Y863yYzv7hQ3UfTNeOeIfgj4i00NNosyaxAP4FHlyj/gJOD+Bz7V 5pPa3VjdPb3UMkE8TYZHUqyn3B6UnGM9UUpyhpI+4xtJ+vH0pdqrnJFfKHhv4qeLfD6pAL3+0LRe BBd5cAezfeH549q9h8N/GPw/rc0NpqEFxpt5IwRU2mVGY8YBUZ/MVk6ckbRnF9T0wkGkY5HTB708 hccE47UwjPCkk1BYw4xmm7mBGBkegpxVchu4pDkdsUDDJOOCKQgA80p65XikxngmgBeOcMB9TTSF IO4Ag0BD1JGKRlBGQMYpiMTU/Cuj6m5lnthHMPuywnY4P1FZ8Wl+JNKlC2mqDUbQf8srkYcD2b/G urDgDb97NNIzyDx0xTEZJ1W5jQD+zZ9/oMEVSltNT1eb9+DbwDnb61vbSoPGafjCjufUUhla20+G zgEcahRjk96ey4HDZxxmpgTt+ZvwpuF+8uOOxpNDTsRiR1wVbg+lSFy3zY5PTNQuvycHB9qaC+MZ xg96SuN2ZPvPRvw9qY5JGQeKBnJWnBVwecH0qiSNIxjIyM0h+8AD09amVgBtYZH1pNqg5Uc/rTAi YjPAwR2opxA6AAGimM0VbHB4x609jnBBzXjuvfHLRrQPFoFjLqMvQTS5ii+oH3j+IFec3fi/4i+P LhrSze6kjPBt7BCiAf7RHb/eNNRfU5XJHqF38V2sDqjzz6bHLZ3cluumPHL50iqcBhKpK889VwPW uc1n486hMhi0DSIrMsOZrh/NYH2UYA/HNU9A+B2sXe2fxDqEWnxnloYv3sn0J+6PzNeo6b8M/BOl WD2y6Ol27rtea5Yu/wBQei/gBVNwRNps8YtdB+JHxDnW5uvtc8BORPeP5UK+6jp/3yDXo2g/A3Rb Rkm8RajJqUo5MEAMUY9ifvN/47XSj+3vC21ofO1zRQPufeurZfb/AJ6KPz+tdVpWpWOr2KX1hcLc QMOWB5B9COoPsal1H0Gqa3ILbwz4ctNPbT7XQrKO1cbWTyVIYe5PJ/GuZ1LwHJaaZc2mg3LTadKC TpVy+6ND6wueY2B5GcjPpXeM8UMBkd1RFGSxIwB7mvPvEPxf8IaGWgguDqtyv/LO0wVz7v0/LNCu NpHFibVZ9IjuF1aC41XTwYxcWeIr632kjbLEP9avqByPetDw18cLdVey8Ww4kiBAu7VciTHqvY/5 4rzfxN4+0jWIrk2mhR6fqd/cCZ5xhmUKP4XwDk4H5H1rg9zMzEnJPXJraMLrUyc7PQ9v8R/Hu7lL QeGNMW2Xp9puvnc+4UcD8Sa8i1rxDrWvXZuNX1Ka8fOR5jkhfoOg/CsximPvdKqvcpH3AxWiikZu TZY+8xqMrgnnFVDePIcRIzUCC5k5eQIPTqRTJJmkjXOTULXi/diBZvYZp62Uecvl/wDeNdZ4c8Ce JfEbL/ZOlP5H/PeQbIx/wI9fwzSbtuNK5x4F3Ic7dgPc1oaX4c1TWbtbaxtbi9mb+CFCcfX0r33w 38DbWzvhceI7uPUIAgPlQlkG/PQ+o/KvVbKDR9Itls9HsIYlT/llbIP1P+NZOolsaxpt7ng/g74F Xt87T+JDJpkMbYMKKGkk+jZIA/OvaNJ8HeDvDNqbex0mESMu1mlXzZJB+Of8K3447q5/10nkx9Nq HJ/E/wCFTx28UCkRxhT3bqT9TWUptm0YRRTiFy8KRW8KWVug2qMAkD2UcCmTS6dpFtJfahOqogy8 87fd/wAPwrkvGfxP0Twoj20UgvtR7QRNwp/2j2rw+S48cfFXWxEpd4N3CjKwQj3/AM5pKLepTklo dv42+NUkryaZ4PQ4Pym8Zck/7i/1NY/hL4Ua54pul1nxTczW1tId58wlppvz6CvSvA3wt0fwwiXF 5Gt9qXXznUFUP+yD/Ou61DUdP0i2a51G7htYEGTJIwUCq5rfCSouXxEOi6BpPh2wWy0iyjghH90c sfUnual1S+03TLF77Ur2KzgjGS8rYH0ryDxV8erG0WWx8L2i3knT7XOCEB9VXqfxxXhmveJ9b8R3 pudX1GW6fPyqx+VfoOgpKm3qNzjHQ9T+IPxX0LUkkstA0tbibBUahKChX/cA5P44+leJO7PIzs2S xyT60rA5ycmmdq3jBR2OeU3LcN3agUEZ9hSj8qskO/Slx0ox6U4LjpQAg61c0/TLzUrtLSwtZbmd zhY41LE16F4A+Fd14tRL+8vI7PT8/wADBpX+g7fU19G+G/CGgeF7RbbSrKOEkYeUjMkn1as5TS2N Y02zx7wd8DCwjvvFshUdRZwn/wBCb+g/OvbtP03TtKsEsdOs4rWBRhUiXaK1CiBcgc/WoD1I4XHQ g9a55Sb3OiMVHYjxhs+v40q8dqXJYY7etIy7SGdutZmg7dtYAHIPapM/KSo6elQ4WNdxwRjuelcb 4o+JGh+G4HhM4mucfLHGc81S7Cfc6+WeO3Tz55FRF5JJrzbxh8YNK0hHs9KYXtyOMr91TXk2ueN/ FHjK9NpZiVYpDgQw9SPeur8JfBm5umS98RSGJD83kDqfqa0ULK8jNzu7ROIkufGXxE1PapklRmwF GRGor1nwf8G9P0wJea4wurgc+Xj5Vr0nSdE03RbVYNPto4VUYwBzWuSrjjjHPNJy6RGo31lqVYLS C1gENtGscSjhVHSpCF2Z3Z9venFPmOD+tKVUjIPtgd6zLGchiWHB9qQ9Tn8ql3DjOT6gioyoPPQU DuISCBuGPrS8Beo6UzaNvJJz29KPp+JIyaAFxk9KwNf8IaB4lhK6xpkUz4wsy/LIv0Yc/gcit8HA 7j/Cj+Ic5H501psD13PBte+BUgdpfDWph0z/AKi94IHs6jn8hXZ+AfhlY+E0S/1BkvdWI++BlIfZ M9/evRCFB4bI60zk9GyPWrdSTVjP2cb3JCw6HqKT5ccdxTdpYDn8Kau5Scc+1QaEm0j2ph6E579+ 9OUsV+cUhwc8mmA3AB64qNuX9TUpySBwPrTccjjHODiiwXE5BI6U0t2J/Og5HJz7U0LxxxQAnqAA PSlG4HpgCjPrTSWUZJBHTFMQ8MB8uP0pHOBgMOewppdW6DJppyRtJwc96AFVj0I60wrg5DdOxpQn 7w/McemajcMueMenegBw2gfMM+/SkJA5FMAY8Owx2xSlAq7+c+9ACmTIwec1Hu4wO1OIZjkAGk2h shhyf0pDDzDnrkVJHIxfA64znGP1qAJznPbpjg08HGMDGPWmBLIFIJJ59qKa3znHQetFA7HlfhL4 V+BtQ0n7S2oT6xKw2udxh8pvTYOQR7k101n/AGp4Dgjs57b+0/D0YwtzbQ4nth/00Rfvj/aHPqK2 NU8J/abw6tot1/ZWrgczRj5Jv9mRf4h79ahsPFkMdy+l+KI49H1CMElpHxDMo6sjngj26ih3ZgrL bc6CxvbPU7KO70+6jureQfLJG2QatMmRwcA14d4o8c+FPDmrtqHgvUna/dwbi3gTNpcc87s4w3+0 tcV4h+MXi7Wg0VtcJpVsRgx2gwxHu55/LFCptidSKPo/WfFnhzw6hfWdWt7Zh0jzukP0Ucn8q8V8 SfGCyj1P7T4L097OZmzNcSgBZ/rGOPx614tPeNLI0s0jSO5yWY5JPvmqzXkYOANxrZU0tzGVVvY7 DXfGniXxI5Or6tNMnURA7Yx/wEcVz+/nJOKzRJdyt8ke0ercU/7LI/8ArZ/qFrZLsYtt7j727jwu GG9DkYpTNczNuhQEN0z0p0dtDGDtTOR1PNPtFCl4D/Acr9KdhEYt7iQ4mm2j0WpUtbdMHbuPq3Jr UstMvdQultrG1luZn4WOJCzH8BXqXhv4Fa9qKrc69Ouk25/5Z/flP4dB+JobS3Gk2ePquWCou4no BzXdeDvhpr3i52kSSGxs0ba8szfMD6BBzn64rr/FPwZ1Xw3t1fwrfvdLagSFXIWVCOcr2P0rLtPi QyyK2sWUun63GQpvrcbd3/XWPHzVnKTt7ppCKvaR6j4c+EnhTw9smu4f7Uu058y5A2A+oXp+ea7f 7WrKI9Pt/NCjaCvyov4/4V594e8f6Rq08drreow/aSQI2U4hk/DsfrXpsTKyDYR5eOMdCK5m29zp SSWhTFpcSnN7Pkf88o8hf8TVuGGGJdiIFQ9AvSnOUQbmIUAZLE9K8s8a/GDS9DWTT9EZb+/GQXU/ u4j9e9JK+iG3bc9D1nXdJ8PWMl5qt3HawAfxHlvoO5rwbxh8YdY8QyHSfDMctpbudgdBmWX6Y6Vz On6N40+J2sG7uJJJId2DPLxHGPRR/hXtXh7wj4R+H9g19dSxSXca5kupyBj1xnpWllHczu5bHA+D Pg3f6q6an4rke2hb5vs+f3j/AO8e1eymXw94O0cfPbaZZQr03Bf/ANZryvxb8cbeLfa+GIPOY8G4 kGFB9QOprxDWvEGr6/eG61a+luZD03HhfoOgp8sp7hzRhse3eK/jvCm+38L23mvnBuZwQv4L1/Ov F9c8Ua34jujcaxqEt04PALfKv0HQVh54pDjritowUTGVRyHk85Ipd3GO9M68ilXjvVmY7oAMfWjt QAOuKeE5pjI9p4Ap+zPArpPDXg3XvFV0INJsXkQHDTMMIn1Ne++EPg1oeheXd6ww1S+GCA64iQ+y 9/xrOUlEuMHI8Y8I/DDxF4rdJYYPsdj3uZwVBH+yOrfyr1S8+AWlNpCrY6ncLfKOXlAKufoOleyQ xImEVFVAMDHFSZIJGODWDqS3R0KlHqfJ934e8c/Dy++0wieJFP8ArYctGfqP8a7/AMLfHMEJa+Jb XHY3EQ/mK9ukhinRkliWRCMbWGc1wfiT4T+HNdDSwwfYLo/8tIRgZ9xTU4y+JByyjtqdfpPiDSNb tln06+iuYzzhW5H1FaJUYyAWFfMmp+AvG3gi7a+0qaSaFDnzLcnp7rXTeH/jRf2MCReJLFpUHBmj 6/iKmUX01KjJbPQ9wIOOu0DvmsDxB4v0Pw5ZmW+vE8wD5Y1IJJryPxZ8aZ72I2ugQ+TGRjzHHP4V x2j+EfFPjW++0zCUxsctNLnGPakqber0G5paLVm34o+K+ta45stIVrWB+PlGWaofDPwv13xFOt5q u+1gb5maTO5q9Y8LfDDR9AjWWeJZ7ocl3GcGu+RAiBUCgDgAcUc6jpEXK5azOd8O+DNE8N22LG2U yY5crkn3rpMYQEHPtTshuMcjtTQnHBOfSo1ZokkJuG7jgDvRk7iCCPcc04qDncuR0HNNUqOclecA GkMEZiGVuT69KCflBBFPdwOC24eoqIEMMtkH2pgKrHdtY7f1pzbsDtnofWmqcHnOD0p4YEbSRjPf tQIaANxB4PrTWCgEDk9z3obcozn8aMHcN3I7e9FgEGckYOfalAG0DcQMZPTrRuQHORz2xSkYH096 AGlFIFN2sgxjIzzjBp29scHIHpSb92c4I7YFACHAUsDgigkjGM888jFN+96n60BiCVLcgZxTGOyR jOPwoHJA71HkkAkde1KMc55AoESAcY7e9NdWLblPTrTPMIY4PHbjNL1U7vyJpgGQeOmPWmHHQcj1 p3yHgZ5pucZXg8flSGIyErlTnHWoypcYzgipt2B1BzSH5hnBBpiIjG31o2nuOamAYA55HSm4B/8A r0AMYcelRsPXoamJGcdce9M6j1oAaq4HQCmkKCAQePWnn+7jIzSEAAtjPtTAYsTE8sVz2ApXcABW x7GmmSTADcYH50Z3KMgj1BoAY4PByKRcc9SaduIG1WHHQEUzIGOeep7UDHliFO3qexopoYjr+nJo pWA8U8R/HudjJb+GdOWFOgubr5m+oUcD8Sa8h17xVq/iC6+06zqct24+6Hb5V9go4H4CsHypSMSS 49lpywRqc7QT6tzXWopHnOTe4pu2biNWf6Cm4uJBklUH5mpe3Apc5pkjFt1zl2Z/rUyqifdUL9BT e9PVS7BVBJ9BTAdmnqM11HhfwBr/AIn1JrS2hFrsAZ3ucoFB6HHU17h4a+CnhzSyk+sSPq1wOdrf JEP+Ajk/iahzSKUGzwTQvDOteI74Wmj2Et1JwDsHyp7seg/Gu+PwQ8QWV9pV1dywTRSXCRXccLEt FGTy2Twcc9K+grPS9B0SSSWzsYLOSUAFYUALAdBgVauBc3sDoIVhiI/5aDLH/CodRvY0VNLVk9jo nh/wtYiLS7K3sYSB9xfmb6nqxpzXF1OcW8O1D/y0l4/If/qo0ZlvdOM86A3MLGNs87QOP1xn8auS swICJx0OM1nuabMpJZxbxLdu1w47v0H0HQVzHi/wDoHjCE/arYQ3YGEuoxtYfX1H1rr22qNhGSex 9KcDEkRLlUUDJLHGKE7bA4prU+atR8O6j4Gc2viLRU17QieLiNcSRD1B6irln8QB4RiiutK1ddZ0 SQ4WzuHxcW/tz1Fb3xE+L9lYpcaJoCR3dxgpJO4yi+wHevG/D/grXPFcst5Gi21kpLTXk3yRIO9a cqavIzUnHRHQeJ/ij4m8ZyjStOia0t5GwsFvy8n1Nb3hP4W2tnB/bXjOZEhjG/7Oz7VX/fb+leZa j5HhfxCBoOtx35hx/pEKELnuBnrUGueKtd8QujarqMk6IMJH91F+ijj8arle0RKS3luey+IvjFpW k2/9l+E7VJgg2CQLshX6Dq36V41rfiXWfEF0bjVb6S4OeEzhF+i9BWJnIpMmqjBImU2yTec9Tg+t ITgHmm59elKMdDVkCE8UDrRj2pQO4oAADu6U/Z9asWdjd6hcpbWdvJPM5wqIpYk17X4M+BN1eol7 4quGtITz9liI3n/ePak5JbjUWzx3SdH1TWr5LHTLKS6nPaNc4+vpXu3hD4FwQpHe+KZhO/B+yRHC j/ebv+Fev6R4d0Xw7ZraaRp0VpGO6ry3uT1P41q4JCqfu1hKo3sdEaaWrKdjZWOn2kdpZW6W0Ufy rHGoVQKsFGDHv6VJsAAxn2JpdxHGcVibLyIsEcnJpxAPVgO9BG7qOagmuIbeN5LmYRqo6k9allom DgnGfxqtfajZafA015cpCi8/McZrzHxT8X9J0nfa6Z/pdwvQr0B9zXjmoa54s8dah5WZpgx4ijyF H1qowbJlOMT1Dxh8Z7SKOWx0KIXDnIMrdBXkWnaNr/i3Une3gkkMrZZ8YQV6h4Q+DBLR3niF89xC On417PpmjadpFusNlbJEgHG0VopRh8Jm1Ke+iPMvCHwf03TViu9ZP2q467D0X8K9TtrWC0iEFtEs aL2UdKtlAzZXj8aUgEkA1k25bmsYqOxF8wwCD+NLjb99c+nNOIb6gUDgZYhj1AqShgPO3BBpwxjA J+lDY3D5cGmsxKAliSeMAUwHblCn5eaaRkj07cVGdxbDDBH607HPPp1oEHC5zk9qA20c5APtQygn g4A9TRkMpB6D8hTC4uQcAgYpNvl4wetLlOh+UD0pfNRtoyOnegQ3OT8w6e9NIGCc/L/KoVlZ55AY vKRSAsm8Hf68dqlZ/nwQD24oGA2jOOQajbdhsYBHSnEALxwvrQT3AyTwaAI13BeV/wAKUg7gNxI9 fSkzyQxOc9emKBksCvQUAKG7DHpmjKsCCSfwppPBz1prFeVJ4I5zQMYzOrfJ+tSb12jJAqFVEa7R uOOmTnFIQDg46c/WgCwWGBsHf600jDEZP48UwSKQMsQfSnAtk8k57+tAD1KhSR19TTQylueOOKd8 pJ4/ClwdoyDg9D6UxDMAgnPHWnEEAetBQDI4z796ZtK88/nQA/IA5Bx603Gc459jSE8cdSOabzjJ 49u9MB7crjgZFR528Dg0/npwfxqNlDD0oEVZvPKEwvz6HpTombykLAYPf3qQoOSGI3eozUe0g8tn FAx42qw5yfWlwRlgRjpTXyibsqGI+lJHI2V689qVx2Dbkcnv+NMJXoV3Htg9KmZjyAOOoqIgsRtH NMCIkgjk80U+Tk/dyfWimB8Qklm5opO1bmheFPEHiO4WLSdMmuATgyYwg+rHiups8xIxM5qzY6ff alcC2sLSW5mbokSFj+le4+G/gXbw+Xc+Jr8zN1NtbcKPYseT+AFesadoek6Darb6Rp8FlHjkqoBP uT1P41k6qWxtGk3ueAeC/hBqHiKJrvVLo6bbo5Qx+WTKSOvXAH15r2vw58PPC3hvY9npyy3K/wDL xcfO+fUZ4H4Ct/7ahxFaxtcyf7PCg+56VILa4uGJup9if88ouPzPWsnJs1UEid7q2R8L88391Fyf /rUqre3B+ZxbR46Ly5/HoKktoo7dTHFGqr7DrVpTjtz71JQW1tDAhMI+bqXY5Y/iasbVbIYnJHQU xB83JwKlymMYz2zVEMydNmNj4nkgkUi3vEGDjgMM5z+GPyPtXQTKFDRnPHcVzuuRn7J58YAlhYSK M4zivP8A4m/FmfQbK00/RkRr6eHfJK3IhB6dOp61UVd2Qm7K7O78T+MdC8K2Rn1S7VXxlYlOXf2A r5x8Z/FbXPFk0lnYFrDTzwIo2wWH+0a891PWNQ1e+ku9QupLmduS0jZ/KqO47SK3jTS3MZVG9jqL GTw5pAF3qKnWL0craoSsKn/bbq30H51W17xhrevgQXVz5NknEdnbjy4UHso6/U5Nc9nmmsT61XKt 2TzdhHIHJOPekDehpHXehTsaYo2qFHGKZJLnjNGc8U3nFAJ9OtADwTjFKM0AHiu78G/DTW/FpW5Q paafnDTyck/7q96G0txpN7HExwSTSKkSM7McBVGSTXqng/4M63rYjvNZJ0uyOCAwzK49h2/Gva/C Hw88NeFI1e2tPtF2R811OAzZ9h0X8K6/G18DoPWsJVf5TojS/mMLw14M0Hwpb+XpNiiyH70zjdI3 Hdv6V06H1/God3OD0qVWA7ZHoawvc3SS2JA4dM55FRHKdevpQ7LHht2Cf85p+UMe/ICdcmmIQHcM FhiiRkiQvK4ULzuJxxXE+J/iL4f8No6yXCzzqMCJDk14X4q+KfiDxC7Q28ptLbPCoeSKpQctgclH c9q8VfFTQ9AjaG2mF3d4wFTkV4F4n+IXiDxJK6yXDQWxPESHH51W0Lwlr/ia7H2a1kZXPMr9K9r8 MfBjTdO8q71lxdyjkp2Fa8sY76sy5pSfu6Hjvg7whf8AiDVIxLYzNak/M44FfSnh/wAJ6foUSR2t skZUenNb9rYWdhF5VpbrEgHG0YqcZPGMGsZycjWEVHcUfdwOaedo5HIpgBC4PPPUUoVsZPT0FZ2N BDkcjkUo3FsAHmlyOnBqM7t2VJX8aBjiSjbSSCOtNwQSC35mncBxvzz19aaSgB6sD0NADXYKPlY+ hIFPGRxnGDnjmo3BYELxSqCgIz2zQICWXPTJPelO4feHX2pAccEjcaRieCM5HegA3At8o6deaMsq Fgc5PINRgnO8sRSFxuC559aYDzIBwqZz+lNRuhIwB6Uu47cZ3HuKZgAknPI4wadwsOZI9xwpG7nJ o+XdkAbh+tIN2zkjb6d6QuBx1WgBxzwR2oOWwQOpqPeg6EDGOvenbzg7MD0PWkAMATuzjB/GoycH BBU1IwLcqCCOfpTdq5B60ARRxvGgVpGk9WbGf0FObG7B6j2qRlP5461HKXChtgOT82KBjd2QFx25 xTJWJG1F/DPSnBScsrYwe/WnBQMlsc0AMRNvXkn2p2DkfNgDgU5xkHH8qaV4wRzTESBgAQTge/FG cruyff2qIw5yxqVSVXjmmIQ4Ay2QB3pMoQckkds0/r2H0pjZJOABgZ5oATA6DGKUNke3XJPFMVh1 Pfr607AbkEigAIBIK4570mcLk4ZScUxHLFhnpk7Qe1KJFYYI2455FIdhxGSMjC007V7AAjOafgH5 snkU0jcAAcZ/WmIqywwXKgyNuX+EjofpRHFFH8sSbR3x3NTEBRjHU9KXIXPycHnFBREx2HleKXKg DPANLt3An+dAUMvH40ANkAOAv60U5ieTkYHXiigD590bwVoXh24s9b1KNPEOjzKMzIDthY9yueR9 a9306bTBpkMtiYY7PHyeXgKB+FfKcGp+K/A9y9lKskUT/egnUmOQeuDXR+HfG8mk3kN5NYzvpsjZ kjPMcbHuoHSrlFvU54Shsj6Ja/knYpZQGT/po3yoPx6mka2iEJuNUuRIigsVLbI1Hqf/AK9ZEvjf w3beGjrsmowLalcoC3zMccKB1Jr5y8XfEzxD4qElrLMLTT2bItoeAw7bj1b+VRGDkVKSjud742+M k1vqcdj4PeJbe3b95cFAwlPooP8AD7961PCfxw0+6Edp4nhNpOePtUY3Rn6r1H6187luacGxXR7O NrGCqtM+7LC+tNQtkurK5juIHGVkRgwP5VdVlC5yDivirw1428QeFbnzdKvWSMnLwP8ANG/1Fe6e GPjTo+sbbbVmXR7kr80rndGx9j2/GsnBo1UlLY9geeNV3M4A965TxV8QNI8MWhlupl80j5Iv4nPs OteXeMfjJb2yyaf4ZIuZuVa8ccD/AHR3+teI3+pXup3b3d/cyXEznJdzk1cYN7mc5pbHY+LPiVrv iTUDL9qltbZD+7hjbbj64rjrrVrzUNRdr+4aaR1AVm64FVM56VBOGXZMOqH9K3SS2MHJssMMMc03 cac3zgODncM0zB3GmyQJOOKQ5p3NJj8qBiDNKfpShexrW0Tw5rHiG+FnpFjJdSE87R8q+5PQUthm QAc9K6nwt4C8Q+LZwum2RFuD81xJ8sa/j3/CvXfCPwUsrB0uvErC9nHIt0/1an3PevZbO1gsrZYL eJIo4xtCIMACsZVLaI1jSb1Z5jofwS8PafpzJqRe/vHXmUnCof8AZFZdx4Y8XeCbk3nh2Rr2zByb c9QK9ryQpzx9KOCwLAEEYNZc19zZQtscJ4W+IdhrDiw1FTYagOGilG059q9BQrLGCpBPXIrlPEng TRvEMfmvF5N2vKTxfKyn61yMOo+K/AEwj1QnUtJBx56D5kHvSt2L5u561nPHHP40hYIM5x6k1xup fEnwzY6UuofbFYuuQgPOfSvGfFXxg1bV2e30oNawNxuz8xpKLY21Hc9s8S+P/Dvh6Jxc3KTTAcIn Jrw7xT8Xdc1rzLXTSbO2bjKn5jXP6J4P8TeLbsSeXJsc8zS16Jp3wuXwxfRX2qQjULcctgZ2e+K2 UYx31MXOUtI6HmukeD/Evii7V4IJXDnLSy5wfxr2vwn8GdM07Zc6u/2qcc7SOB+FekaHcaRJYB9L SNUA+6g5FarkZBPQ9ql1W9hqlZ3ZXtdPs7CHy7W3SJRx8oxVkMzLgjjHJ9aQMCORnPpTSAG+Y4z0 rM1sJ9/gZ2noM03lXPBJ96ecbhn9KTaDuP8Ak1JQu48c/mKZvA5OSKCRwPzxQ3PHG30pDHbhtDYI J5x2pNwz0AphJ+8eSOMU844O3NAwzu5U8Y9aTGQQAMjuKQcADbxg4oAG04OPagBzE7cnjPFNjDY4 xz1NJvJAOB6DHU0mCADnqeRQIQ8MO/ocdaZ5jPuiJKkYbkEDv3qRDwwx17mmsWwM/wAPQetMCtPc RW8Xz5YjsOSeamAyquq44545pHXfk7QB29qVEPKKuR60AMYq2CADz1pVXDDByO/FPKiI5Ix+tKHV o8ZXr+NAxAgzgbj6k0cKTjkilywJy3ymoz5vngqwKgcDFADWRQwbd09eadksSuBtz1HenBgBtbk+ p/lSgEpkEfSgBNrM391fWlx1GMHsR6U4MOAW69ulC4568nigRGSd2Cck+tIFOAGP407qOmecZowc 4PbpQMawGeuCegFIeuOjDmpCm3GRwentTCoBLk8/0osFxqltx56U4qo+YnA96bnkkYx7UYGeBkdK aEOJHbBHbNNxzgEZxxnvQQM9MioyhPHX6UAIkpZdrxFHHUZzinbiw+bPp9aNihhxyOuKcYxnJzx2 NMBhZckYJU+1KASclsYHfkUrKQAVUc9ulKFYEZ4+lAETYJBRdxzyRxT3QhRnB9xT9mwMq/jg8UmS wOcLkfnQA3O3OCR3x1pFLFC27BByBmnbFXAJPtQ2SwIAGKQyLLbiT1PvTQzdOoNT8FASc+3pTQAc FfzpiIzzwDzntQ25CARj6dalKnqOCO9M2kMWfgetMCBgx3cHB7+tFTMe3JHY4ooC5geIfDOkeJNM a11O3VuDtkx8yn1Br5uvr5vAfiK90zS9QtdXsyCGRvnQH0OO49qt+NPitrfiYPaWRbTNNPHlRt88 g/2mH8hx9a83JOa1hBrc45yV7xLFxcy3EzO5ABJYKvCrn0Haq5P40elNPWtbGIueKUMc03NH1pgS g04N+VRD2p2aYiTdRx3pvbrRQBIOaVgGUq3Q8Gmg47U7qOeKoCO1JCvA33kPFTHIHNV3zHOkw9dr fSr4t3lmCxIWLdABkmgCvgEZGas2djd39yltZW8k8znCpGpYmvTfCPwZ1zWxHeavnS7I4OHH71x7 Dt+Ne9eHPBWheF7cQ6TYrHIR807/ADSP9TWUqiRpGm2eP+EPgbcT+VfeK5jbxHkWsZ+Y/wC8e34V 7jpej6Xoenx2el2cVtCnG2NcZ9ye9aOw4we1NJY8NzXPKTludEYqOwyYAYYDt3FKpyOelNHQrzgd Kblg3XAPeoNB5BPCgU9SFQluOxJrF1fxFpmhwNNf3caBf4dwzXi/i34zXFyZLbQk8tOnmmqjFvYG 0tz2XW/GOi+HoGa/u0DL0UHk14T42+K91rqSWGmx+VbNwWbqwrirXTfEni+/3qk907Hl2zgV6/4R +D1tZlLvWv38uMiPsDWvLGOsjFzctInlHh/wfr3ia4WK2t5PLJz5j9BXtfhf4PaZpWy41Qi5uB2I yBXpdhYWthbrDZwJEFGBtFXXwwLdSOwNKc29hxglqyC0s7awgWK3hVEXoqjFWCFmBRlBU8EGmFoz hQDn+dKucYxgr61ibWsZUOgQ2N/9osHaAucsg6GtpQS/YnHSo2Py4zke9OBw+GNMLEoAAycZ6U4h WXbyD60wq35UgIByaAJAoJ5AzTioZeMfQ1HwWySSAOuMYp4bJxx+NAELBwThOT6VHkq2MfnVk5LK AcMPTmoJF55Bx3qWUhGOTuGM4+lKuWPJCn34qMdSuRgc9elOGWQKRxnqKQxQ+QSUOR3X0pc4yCQQ e9I24ptLjA6UHKgsGHpg0CEUlR8xHTHSnBgBgYPvikQsue+D0o7ntzmmAoyV4PFGWA25FOwM5GT3 6UPjAxg89KAI+CvB5FNHIPI9c9KkY7ZDyDxioS28c8Z469qAE8ts7uSQe9NKoVXj5h1I71MFAXaj HH+0aZswQ2Rj1oGNc4YLtI9adk788jNKdrYGBn1pFKklQQTn8RSANoIIzgnp600xnvjHTB70/OGI xk+oFGN+cnFMCMMdy9h+lPA3EEdfrSheAD26UEbWABII9KAEbIbGOM+tIW+b5jTwSSFahlG7p0qh XAgAA54qNmJz6mpCRtyPmB9KCP4lAI7igRCNo5z+FHX7owOpFAVzvKrkg+vFDZKk5CnGB6ikUIFc 8qgxnNNgnguFYwSq+w7Sy9M/XvVc6eJQRc3M8wP8BfYCPT5QM/jV2NYoY1jjQKijConAFAhQAp24 DGkwWfgcZ49qXCggkfrTiwUH1NMBRkcd+9IRu7An36UhYDqOaM8jvnqPSgQmPl24xjueKQja3Ax+ tSMoxkdRzVC+lvoVR7WNXHcFSSKBlzIOARkD86Q8sCcciorWWSW2R54xGx6ipQoLfd+bqDQAhG4k Y6d6RlZec/XFSE7eP8iopN23MfBpiEJwepz9KYScYPA9Kx7f+247vzLlA8R4IJAx71e+327SGKN1 LA8gigZKSwzjn2op6hiTk8H0ooA+FD0ph6UUV1nmiDoKTtRRTAa1HpRRQgHr0Bp4+9RRTQmOoFFF ADx92pKKKYEdx/q3/wB017t8AbO0uL+6muLWGWSNF2O6Biv0J6UUVE/hZUdz6FYDzlGOKc4AAwMc 9qKK5Oh1kYJ88jtimS9WoopFEJ++KzdZZktpCjFTg9DjtRRSGtz5X8eXNxLr8iyzySLnozkiuf0t Ee/iV1DAt0IzRRXXD4Tlq/EfVngm2t4tLhMUEaHZ/CoFdSv3j9f6UUVzS3N4bErcdOOnSmIx3Nye lFFMZIn3XPcDj2p4J3DntRRUlIcep9hRL/qaKKkpEkZPk5zzQeh+lFFULqEpKxDBx06fWpX7HvRR SQwXpSMAZVzRRSArL99ql/woooQ2V2/1oqdetFFADmA8w8VDLw6/SiijoIIOlSn7n4CiihbDe4x/ uGmLwCR2oopMBV5YZ5oPUjtRRTW4CoBjp60wAZJxyep9aKKYmNXt9DU20fZjwOtFFIYnpTZuIkI4 PrRRQAgJO3PP1qR+c5ooqkSQRcu4PIqfoeP7tFFIobJwGx3xUS8k55+WiihAOH+rBpIQCXyM9aKK b2Ab6fU0/t+VFFIBIvvt+H86lbqR7CiimhDE+9+FKelFFMCI8yYPanZO0n3oopAOcDCnHPrTVA3D j/OKKKYEFx/qSOxzkfhXJ2SqutTBQAFZwAO1FFBS2OqXhVx/dFFFFUSf/9k /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAUEBAQEAwUEBAQGBQUGCA0ICAcHCBALDAkNExAUExIQ EhIUFx0ZFBYcFhISGiMaHB4fISEhFBkkJyQgJh0gISD/2wBDAQUGBggHCA8ICA8gFRIVICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICD/wAARCAHCAlgDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDS+JVs kvk3cI5KYJHqpzn9a7/SdU+26LZXpbmeFXP1I5/Wuc8R2gvdJ2scbW5OCcA8dBzVvwrYy2nhi2hk kSZIywV42zgZJAPoRnFc1243NEkm0y552PFskqnBa1A/8erbWZprKderw4mX6fdYfk2f+A1gMoHi RBxhrc/+hVuWJSO8j8z/AFbZR/8AdYYP6GlzaofLoZerW5v9OeFcLKCJI2z0cdP8PoafpmoPeafH MeHxtdCOjDqKtvC0TvFJ9+NijfUHBrFUfYNdK5IgvuR6LIOv5/41F+hVupc1gNNo1yAPmVd4A9Rz /SrcMvmQI+chlB/SkIEkbRuchgRVXSW3aVAHOCq7D9Rx/SlfQdtTPkGfHduev+iN/wChVDqcf9ke KbTW0G2C7Atrnnv/AAsf8/wipZRjxxAM5/0Rv/Qq1tQsk1DTJ7NwMyLhSf4W6g/nTbtYEtGXSecg iuP+Ibt/Zuj7CQU8/kdjvU1uaBeG60pUm/19uTDKD13DisPxyGl08GNPMFpHJK4Xkqp2846/wmta LtOxnWV43PILCdofiFoHl5O7f06g5bmvr/Tbsahp0N2CCZFDHHvzj9a+OLS1kvvH/h9XzFFKjurB N/GWxwO5Ixz6ivqbwTcv5NzYTSK7RtvQomxdp5wB25JGBwMV1J6nOloR/Ea0S48MwO6BljukJBHq GX+ZFcT8OYLyz8S3cUDICwkASUHaw+Vuo5H15+lek+NVX/hDb12XIiKSk9AArqST7YrlfCN3pt5q MN9bTwjDY2oQScqQc46fjTYaXPI/jC81z4na0KCOa7uVh2A7uuB1/CvT/CcKN8NpmQDaL1sY7ABV FcV48tY5/FOo387gC3lfyWEPmNG+7AYevbitrwut5FpmoWkOqm3ggiEgjcAxMxdckrxjPqCD/Kpv rYaVonr+j/No9qf+mYH5VwPxXjA/subHaRf/AEE1t6N4u0i006K21K7hgkTI3RyCRevGccr+I/Gu a+IfiHRtV06x+xXBmMc23IU4O4Y4/IU5bAnqcz4PbGvbTxvglX/xwn+leveFv+PCZfST+grxjw5c iLxZbQmKRdxaNTtyGJjbPTsPWvZ/C3+ouF9GB/SohsXI6ILVm0fZJs6A9PrUIFHQgjqK0IN+aFL/ AE54XGcjFeaXUBtLqS3lXBU4/CvRrGcHafXr9awvFmmZxexrnHDVhUjdGtOVmeW+MHA8Oyqo/wBY 6r+uf6V5nMmPKQLgRw9Pdmr0nxdtOnQRjvLuPthT/jXnVw22SRj1AjX8h/8AXqaekBz1mejSzfYf DFmir8y24bHqdoAH5sK27GBbPT7e0AH7qNUJ9SByfzrDuB9p1ezsQfljddwH92Nd3/oTAfhXSAN6 msZbJG63bMrxFz4evF2kgqOn1FQ+GZdvhmxXy3ICEcD/AGjVrXh/xT95wf8AVmoPC4z4XsvlJO1u f+BGp6BfU1FkUuFEbgn1Bqbb7cU4RHrj8zT16DLp+NLlK5hpVAoKkn61KkuF2P8AOn91qjLRZJMo 4HQKTSebDnhnP4VS0J0ZJ9nt5v8AVPsb+63SongeE4ZTUyNFnIjfA9atrcqI9gUHj+LkVVkxXaMv Ge1IVPpmtdBC6gbV3+461WmU/NGYwmeDxg0uUfMZ5Q+lGwntVlAY2OwsD0PJNPLynjc1JLuO/YpC Jz0B/KuU8VyNHMkb5/dwFufVjgf+g12pLDvn61514tuP9Kncv96RIR+Azj8wa1ha9yJ3tY5oLzj2 owBmmeYAeaY07PKIYIjLcPxHCpG5z2AqLFECwvFfTXDzM4kAATsoH/669n0m2ji0WyjL7SsKZHvg V47c2t9HrNloN4rWl7qCqF24byw7bd34HP5V7bFaiGCOFXJVFCgnk8VT8xEiwQdiTUgWFOdn60xU VTmn4T1pDsPNxGB8qfpTRcLu5DfhxQEGM9aMYOcCi47ImVwepkA9sUxhas2X3/iaDIemBTC5PcUx A4tsYVmx9TVcbEbkhhnuOlOfa+RuwfpVZ1KnkZHqTTEX1MZGQoIHpR5ijoAR7issmQMGVh/n3p4m nbd8m/1I600xWPnf453+uSeLYob+yih06AH7FKkf+sUgbst3OR07fjk+Y6bftZX0N7EqO8LBwrjI yK+xNTstL1qwk0/V7WK5gbrFOv6g9j7jmvHvEHwJtrhpLrwjq4t88/Zbolkz6BxyPxB+tbQmloZz p82qOQXXfDuvSwx6rb/ZZNg8y4zyWyBgHnjaWPPcAepZIU094ZksvF1xBbRZVRJN5XmYxyFzwDnj Poc1zGu+CfGPhos2qaJcLCv/AC3hHmR/99LkD8cVzyXQIwc+9bJp7GDUo/EjqNSl8Pw2VxFaPNdX Tybo5ycbV3HAbI5JXGcd65sqScn86YZlGT1+tVp9QCx4Tk/yp3sLcS9uFhQqMFjxj0rBYFmyc5NT SyF3LMdxNRd+lS2Bq6OvlLNMPvbQn5//AKqLsZh3ehptjd28Foyyk7t2QAOvFXNLiGua1Z6XDGUW eUK7E9F6sfwGTR1DoeseCdMTT/CNrvTbLKPPb6t0/TFdPCu8ojAZLZ6elRxxqkCIuAowBjoAK1dH g8+/Mrf6oc/8BFb7EJHI/FzWTpHhi20qJtss+FIHUDqf6CvG/DUMmt+J7G2kG9EfzDnsB/8AXxW7 8VtaOr+NpolbdFaDyx6bjyf6D8Kv/CfSxJe3mosvCDykPv1P9K55M1t0E+LN+Eh07SYzgczMPYcL /WvJzXW+Or/+0fGN9IGzHC3kp9F4/nmuXKZ61JUuxHmin+XRSJP0Dlf7JBLOWAKIxBB74NedfDO7 vbfVtVsZJ3im4lVC25cZwRjoQciu31nd/Z7Rr1kIX8yBXE2yjSPiXbqPljkd7f8AAj5f6VyrSGhv vPU7uSUv4hgLxrC5iYdflbkdP8DWmWdTg5BHY1lXip/bdikgDK6SKQeR0zV/LwDAJnh/uk/Ov0Pf 6Gpdpb7jV1saN+5keG7H/LxGCx/2x8rfyB/GsfUYPtVm0attlUh4z6MOn+H41qgpPo7ukoYW77xj srfKwI7HOys1ruBThpVz6ZpSTTKi00Ftd+fbRyFWLEYYAdD3osfkNxERwsrEfQ8/1qFHNvdhlQmG 4bqOQrYzz6dKtBJUu2cBDE6gk55DDjGPp3o5XqCktDMkGfGtuT/z6N/6FW7wepP51gyZ/wCEzgPb 7I3/AKFW6Pc1L6FR6mGQNK8Vq3S21JcH0Eg/x/qa5f4g3l7pGvabq9pEsqQriZDn5lzgAkdBk12e uWTXmkSCMETRESxN6OOn+H415p4t1S41mORMbQYkjCj1yM/rWtNXdzGrKysbTawJbqG5MUUsccgm iJAZoiDkFT6it6znvNSWWTSNaNpcGNU3hiCp3Z5GDgYLDp3zXguoarqWiSWEVtJhSpDxuMq2MflX Q6J4tge/jd5DaStw2SQM9sH86607HKe3nw142Oj3U1z4pW+t/LZ2Tzd24AElf9Xjn3rzVjqNt4kt odIZo9RndVQOUMTkkDkbRg+4xXXWPie9jjCmYkMuCyHBIPqOhqpBpskuuWeq6dcxyCAgNFJwcAg8 H1471Tba0BJX2KN4buKC6l1CWKzuQzLKzjcsbk4I688nitTRPDejapdXL6sXleGIG3jzhN+Tz9az dS1uO31PXLm5jWSzjkaUbVLMcuxye2MYrZ8P+HdW8TeFYvEmlavBbTqDiIBtrEdVb+72I65z2rKz uaJ6aHoPhrw7oS2Am/sq3aUMQXkQOf1zR4t0DTrjRmMcIgIbfiL5VLbSASvQn3xn3riNN8Y63ob+ TrdjLAM485BmNz/KumuPHOh6npflG5USMRyoJH48cVorPYTk+p5BobtZ/Fa2MsjlVQgqisRyCuQO fXtXunhGaKdLloZFdfl5U59a8la3EHxF0y8A6hOn/XRf8a9S0CwgmvLhwXhm2jEsLbW69+x+hBFS h9DtB0oIqgJNSteJYhfRf34gFkH1U8H6gj6VZtry1uwwt5QzJ95CCrL9VPI/EVYi5aSbJdhOAa2p I0vbB4nGcjBrnjwcj8K2LK5HDE9eDUsZ4l8QLf7BPHByCokYD16V5nePGNQjjkZQst6iE+gyAa7r x14kTxF4rljhiVba3k8hH7uN3JP+eleW3e2/8UaTpqSE+fd+bLg9I1Jdj+QqZRtoEZ3dz2bQCbnU brUJU24UIBj7rOfMcfgWA/CujZ02lfX3I/lWJoitHpEcsikSXBM7fVjkfpgfhWlkkfTmuKUtTsUd CDXCW0C+wODETVHwyc+F7PjHD/8AobVLqNz5mlahblCrLGRyfvAjg/zH4VB4YYDw1aqexcf+PtTv oFtTZEhHHJ9qN27+ACmFh60wSDoG3YqblWLa46dDS7VzniqwkB65BFO80AUAWgVFPBX1/KqgbIyK cpJGM0XCxcSbB+4cepqysynh1BHv2qihwMN0qMwybyVcjJ/vVaZLRoNEJOYTn/ZPWoGBVuRyO1NV nRVByX7t61ZjlEw2ygN6HuKrcnYqs4Ay2AK85tdEtPFGrmS/eUw2x+1KqNt+eQkj8hmvQdcVrbQr yaNgf3ZVfUE8D9TWB4SgVbK7uOR5k5VeP4VAA/XNNaRbC95IuQeG9Es03x2UQxzvk+bHvzXn/g6w OvePdQ8USpiBWYW/H8P3V/8AHQfxBrvPFEsiaBJZ2z7Lm+YWsZ9N33m/BAzfhTPC+nRWOjL9nj2p KcpnrsHC/wAs/jTWkW+4N80kjjruEXfxviLc/ZYYlHscM9eogHHXIrzrS7cy/FLU70kk+aUHsEiC fzJr0LDD1qWNA6570z517A4p54/+vQQpPWpKGBsnP3fpSiXBHz59qd5YPQ1G8LeoqgJTKpHAqFiD yKiKSAZV8frTGMw+8of6UrhYezHuuPfNRM8oTcuJAD0zmhZwQQMg1IpjK4Zcj1FUhNFUXMTnI+X1 PpUq3NvuGGBY+hwabMkTpmM9PWqqwksMqV9OM0wLbxiQbgcj35quYfKl3xRqD7Hr9RS+RIB8kp5p PNlUYk+YetADvt4U7ZLcgdyOR+X/ANesDV/A/gbxID/aGhWjzt/HCvkyfmuCfxrcaSI4ySKrybxn btk9M4BqriV1seUav+zroV0WbRtevrEnkJOFmUfltP6muG1H9nPxbAzGy1TT7xe252jY/gQR+tfR r6lcwBXIwBwQw3Z/rVhdZgnCNvMAzzmPdn8e35VSm0JxT3R8lT/A74hwnC6PHN7x3Mf9WFQp8FPi K7Af2Bt92uYv/iq+zNtvdw7gCUJ6kY/WoTYOeuNqjgK2c/XNVzsjkj2PhPW/BviXw7Kyaxo1zagH HmMhKH6MOD+db/wzsc6zcai6/LBH5a8fxN1/QH86+sPFHhpvFWhyaLPPLp1pMwM7QkCSQA52g5wA e+Qfp3rySbw1o/he9uNK0YytDCfneVtzO+MHPb2/CtacrvUyqQSV0K0gZHVFwMbQfet2BZrLw/cv bxtLKsRCovU4GT+tZtpGoiRZIAWLeZv74Hb8at62t0dPisIp2gR2Xz8fecA7iv4tj8q1nKyuZxV5 JHjlr8PNQ1G7lvtbvUgaVzI8cQEjkk5OT0H613lhZ23hjQmt9NgwiZcsxy7n1LdvwArYCquTjmuc 8Z3psvCl24OHkHlL9Tx/LNcXM5Ox2KCWp4dqVwbvUbi6YDdLIzk/U1RIGelWCOcUwit7HI2RgCin EUUWA+4o9T0/WtISfT5/PCnr15HODj6Vy/jlTDf22qQjDARzqfcH/DFeK+GNfv8ARdUt2tbx44jI C0e4lW+o717JePca1oE1wLeNhHI6tJE2cAjO0r1GOBmsOS2ho5dTqtevJI10y/sGjcklvm7KQPz6 1UXU9QuRxO30UAVmpq41D4d6MzZEtuxgcY6bcr/ICu78A21rYabL4hvoVmk3eXaxtzyOrke3AHvU xjdWKk9X2M5NB1GKNbjU5jaiUZVHy0jj129vxxVyK1swpQxSvj+JiBWrd3LX07TzNudup71UUKQw B6dDW3IjJSIX05J7R4YpJFyOzYI+hFQQSuLr7NLlHPA96tSyR2xTzZVhdyAiucFs+g71HOIrqSEz b0khdXDocE4OcH2NQ46FJ6lTyXTxnFtJJNmTzjj5q20tNuSZJAWOfmlY/pmqBZH8cWzLgqbJuP8A gddAYPtLLDGAJCflJIGPxNYNGyehx/i2BLDQ2mjhjJklCs2ASM55HuTgfjXCW9ubq9td7SMcopRi CE+b+HAHt1zz3r2K40Ua5ZzaVHd208uzc3lPkoAwGckY4OO9YXi/w1p/hTWdDsrBHZpIi80jtkuw PX0Fb042WxhN3d7nI6l8HL+SS28T6vLHBZ+a3k2yYZ5A2WBbsBgdOtcLrvgu2kTzbFhA54CkZU/4 V9d+Jntb/wCHcN5aYNuFikTA6Dpj8M189XkG4TB2aOKGTLyBc+Wu7qfxI/OtPNkPeyPV9B8Dabrv w40OS+svs16lmkRurXlsoNvzD+Lp/wDXFeT35/sPW7qzkuMNBLJEsq8b9rFc+2cdK9P+HHxO0qFb DwjfI4ZiVtrsfdcMdwDA8r97FeefGizEPjDUAq/K04Yf8CjRz+pNMJO+qM+C2F5YXssmGWZFVge+ f/112vwut7rwzct4XvZfMhv7Rby1cjG7g5H1xkf8A965rRot9hOCmQWVf5V6N4kslt/Ceg+JNMdJ bnQ/KMqoeRGwAZT+OPwJpIo2dEghuILu1uYUmhYjdG6hlPXsa47xf8JtLuLWfUNAuX0q6UE+WCWi b+q/hn6V2nhyaK5mmlgbdFKgkU+oPT+dbeoR7tOuFx/Af5VQjwXVY3tNT0x5iBNGm085yRtJx+Ve q+Hfl1Kdf9k/zrzXxRbrJf5lQMEcbGPVSFPT8q9G8Nvu1Hd/fjJ/lUoaOvFQXNjbXRVposyJ92RS Vdfow5FWQKXFWBlsmpWozGwv4h/C5CSgex+6347frU9jqdtLK1tuaGZgf3Mo2P8AgD1HuMirZFVL y1t7qEx3EKSKOQGGcH1HoaAPne5VoNSniz912cn6DNcp4NtZNU8dajcEHEEQtEPo0rcn8EDV02rB YNb1LDMUiVuWOcDAHWo/hFbwNatq11cQwm7mkuEEjhTJz5aAZ6n75xUTbsxU0rnrqJswqqMKMDHa ngN0I4qcLj/GjaK4LHeeaajreo3UjKWSJRuT5F5weoJNb/g4yPoJinuRLKkz9OMKTkcfia5SdD9o lH+0f512fhOCP+xxMVG9ZXAbvggcfSqfYlGwy8YI/SovLfz95kAixjZt7+uc1dKZHQUmAMg0rFXI 1iP3gCRSiPPOMGnqVXAxgCnZU96dhXEVMYA/GniMduvpRnjGM/SnhiPakA8RK3BOe2KeI8HimD5u hwaeC3Qj8aYDguF4xRg9Q35UvHHP5U3gnAoAwvFF3JFpaQl+JJQT9FBb+YFXvDUMUPhqyidfmZPM J92Jb+tc74vYzX1tYxnLeXgD3kYKP/QWrrSEtrbptiiXr6ACtG7RRCV5M57xBHJcazHbwHIVBBGf +msp5P8AwFF/KSukjgSCJIY12oihQPYVz2mNJca4k7Kf3EZmbjpJJ0H4LxXWCdCm+VOgzuHFOXYU e5594XQ3HirUrjJxumbI/wBqXI/QV3BX5uAfqa5HwJC0j6hcAE5CD35LGuzA5xSluOL0K5Un+H5v pxSYJHzJj6VZAPIBwKZg5OSPyqbF3K+GHKtxSFmxtJ4+lWdseDg8/SmsFUZY8etOwXK7RnGRSCI5 wyk1YKkjg/nRz0LAGnYVyE26uOFG73qKW0aNSwORjpVzaRzuNI0bMMMTj60wuYUp527GpqO6nG7P tWpLEy9V+X86qtCpGV49qS0K0YyOVWUhxhqkKoRzzULIyn1A9KUbs4X8hRcdhGtlfkA4qM2TY+Uc 9geKvwbiQWQ4q+qZbORjHShMlmAbTjkAVWOmwqWZtxB7A5FdO0SHIOKqS2Sj5lOD6VQjnEt57eRn s7l4Qeq5+U1ZTUL+LJmRXA/iQYq88AXO5CMVVkXJ2qxAznk4peg/UmuNWiTTZrpbiMiFDIysMNwM 4wf6V4jPL9oeSWXLSzybifrya73xnfC30YWygCSdsH6Dk/0rhUjAAL42ovWuqitLs5qrV7I0NLQN eDcDsU5IPQgf5FSX7GS5cHnb8v49/wBak0/MNpJO3U8D8Of54qFlBAyeamvLZDox3ZUZOBgVleIf h/rnjHQ1fSZrdfs8pJhlYqZDjscY4z3x1rdJVc+1epaHpT2mg2qEAOyB2+p5rCO9zeXY+Kdd8HeI vDs2zWtIuLTnAdkyjfRxkH8DWA0XPSvv+4tfNhaGaGOWNxhldQVI+hrz3X/g14O1tXkis20q6bnz LM4XPuh4/LFb83cxdNdD4+MeO1Fex+I/gT4p0wtLpHl6xb9f3RCSAe6sefwJoqroj2cuxx1lfXFm GFu4jLdXUDd+Br0jQvE39iahFNiRl1FELxt9xuADkdvrXnCx2E91GkUrwRtwzSAsV/75FeqeFNOk tJrGN9Os9SVwwhN4piUr1JG4Hnr2rKTS1FGLZ117BBa+FrptLTfbz3IuEVuPJYjDKf0resdVdoIb UZWK2t0VV/2myWP+fWuK1aS80u5ltvuQXIMckedyhh8ykH14xmrumX0SxeYjOzuFLqeRgDGR+R/K iLSehErtancC8/dMWYhicDFalreW1lYLJHsudTuCRbxMcpEoOGkcegPQVzEF1C6QhSAd2GNLb3r3 fn6h/HcNtQZ+7Gpwqj8s1q9diIuxsLJHFPJM0pubhz89w/3m9QPQe1WEkVwTkVhlzuGWwB0Ga6Ce L+yIYoECXGrTJ5m1uUtEPRnHdj2H+QnZFq7M7c8Piq3kJODbNgnuN1b+5bqJk8z7wwVPQ1x8X7nx NE7SvcPJEzSSSH7xyenpXSxtk78BB2zxUOKkNSsdB4StUs9bVoLfAWFo22Lwq8Hn2+UVgfEHUba/ 8b6ZHb3Cyi2gaOQI4ba2CwBx35FWZrq1uLA2eoTFLckNxJtwQcg1xd8ljH4vj+xTrNFKjMzIP4tj ev0FEfdVgm+Zpnqekma18L6z4Yu33mK2+3WzH+KNgGI/Bv51yng+xsNV8VXujahGJbS/t3hkX2K7 vz+WpfEXiZ/7Ntb+ztwtxbRG2O5v9ZG67GHHoCSPeuf8AfYtN8T6XNaTSq0lyiyPI5cuDlcEnp97 tTvoJL3j1a/+D/hK6ntZrOOXTmgURsIG4lQADBBzg8dRivK/ib4bksNXj0y41ASR+VE1vNNkkqAy 4kYk8/JjP0r6SSTNeNfGu1Ml1p9wBw0JUn/dYH/2aqSCT0OH0mMnSJiudzTDp7ba971TT9Dk8KQp rSKq/ZliDjiT7vQEcn6dK8F0kMloHSXbmY8Ef59K9I0GXUvGGq/ataSO3trYhIxGxKFP7wB6EkY5 9+TgULuwv0RzXw7ufEdrrl1YWmjf2nYWy+XIyyrHJFySD8xAbOOmRXqYvLG/SW2jkaG6CEtbTKY5 FHrtPOPcce9Zl5BD4Y+JemX1vGsNjrEX2OUKMKJB9w/U8D866XXotLuoY7S9sUvZ3OYYh98H+8G6 pj+8MUDtoeEeLIQqJMvIaXOfwIrsPCrbprNv70A/9BrC8a6XNplr9knO545Vb75fAY5A3Hk4Bxk1 a8IanbR6rpdhdTCCWWEGNZRs3jBAK5+8OMcU7akp2PTAKdjipzAy9uKj247UFEZFQyDg1YI4qJx6 0wPmjVFkuNQ1lYWQM8rR5dQ2FLnPB74FM8P/ALy2vYLS6Yae58j7Oi+XGqr1XH8Qzk+lWo18y4un xzLPu+vU/wBa09D0afWLuz068uDbefdIsht+MoX+7k+3BNYyZUEdPdXOj+H5ZYNP16JliYKYjIZ4 +fcElPwOB6U0eKI/KLvZTpjgyBcxk+zcfriu7v8AwD4f0HTI20bS4okh+9xkkevNYrIpTb07YxWM 0ovY3jeXU8lup57hr1oI/IdZG2NN0K5+9x+P5V2ng2V5vDhmeMIGncphgwZeADx64NO1zS7e30DV ZbUtalrWXzEjACyDYcggjAPuMGqPhO5+w+FrSGe2kSFVIEy/OOvcDkfliobutC0rM7FX5yG+tLgM BmqkUsUkYlikWRG5DKcg1L5yjjdUFkmFzgUv3foO9MWRfrTtwpiHqemScUucc96Zu9+PSjPHrTET A5Gd+36VIpGAOmKqg+1ODYoAmLAUu89hx61EG49KQtx1zSGclK5vvHaqeUjlXH0jTP8A6ETXQ6xc Zs0tS3/Hy4jb2QAs/wD46CPxFcz4WY3ut3l/jIVSwyOhkYt/Kr2pSNe6vJbRnlAtopHZnw8n5II/ zNbW963YyXw37mtoaMLA3L/6y6czH6Hp+gFXryfy9OuWBwFiY9fY1GilFCYwoGB7CqmsuI9BvD38 oqPx4/rWV7s1tZFHwOTDp1y4/ilA/JR/jXYiaOXG489/WuU8JoqaErEH55GP64/pW6GUEkAg+9W5 akJaF97diu6Mhx6d6quGQY6H3FCTyxsDnHuKtefHNxKPxFGj2DVblRXYKMkZHpT3OU3A5HoKkltC FMkTeYnsOlVdwV+WxRqPRilmKBljbnsRTVU5JZdpqRpSMY5p24MvWgBg+X1p4cA/MM1EwY9ODTPL kJyzkVVxFp1WUACqs1txkDNBzGflY05bkH5S2adrgnYpkMv3kqIhcdMVauJFB6n6EVXZBIMjFKxS YkRfOVOR6Zq5HMMfPlTWcWEIwB+I5pv2kLnGTk9xRYNzWEpP3WGKjkZj35+tUkkcZzwKVT+8+8fp RcLFrY+3nkUnkROBujBpwxxwwpt1KsFpLPKfkjQuT7AZpgeSeOZkn8UeREd0VqgUgf3up/pXOpvc rGRwxyR61Zu2NxdT3LnMszkk/U5qbTot975hGBHz+VdsdEcU3dtl66KRRQ2ikAgZI9cdT+ZqoT83 AyM1I8CNqk12SWYqIgSeAAcnH45pQMn2riqSvI7KcbRsJBYtqV7BYrI6JLIBIU4Oz+IA9uM17LHd WqxqpdYsDAVzjA+vSvOfDVl5t3LOoOIlwCPU11W2Tbh/mHcGiOwPc6Q+VKuQRg/rTDDkcEGufilM BIimKr124yv61fXUiFyYjkf88zkH8DVXCxbaHnkEUVXGqQH/AFgKZ/vgiincVj5H8L6FNq1yJhap OUxtjldY0f8AEsM/gDXrt1pGsadpEOpPpq2hsnWUGOdDgdMBUQfnmruh6Xf6Paxxy6BFYzE4VbS6 YhQem4A5Y11EFvqd5YXNlqRiaOVCo2KRjI96xlO7Eocq0Ob8U2cWrabHqNsPkliSdTnJ44I/LFef Wdzf6DPBBqcJEEg8yCTqHQ9cHoeR+YxXo3hfmybQ745CsxTPZd22RfwOG+jVwE1qLm6vdKuSfOsZ nQA85Tccj8Dz+dUneOpi1aXqdPDKosp7uGYPGRvUg+3/AOqr2kXWdFsd52t5Kgg+uOa88tPtemas 1gJt1tcRuw7hxtOMH14rrtK1O11SxJtHAljO5ojwwz1/WrjJrchxXQ623ureFnu7pBJDbxmRkI+9 6D8TirlvLcSkrcSF7u5bzZ37sx7fQdK5Ga6C20UbE7ZrqKNgfQtyK6i1kHmSy7xuVDs+prdNMz1R V1y4+z6rbS2AXKKUcseg56Dv2qi2oX8zjNxIc+hx/KjVcLcREnGVx1967TwRpum2lifEWrorruKW kLjIdh1bHcDoPf6VEr3sioJNamFbeGL9rdbvUG+yRyDK+Z99x6genuaz5reC18SW0UJYr5bHL9Sd jV2upXk2p38lzIT8x4yc4FcdqZMfi63AAwsOT+TCq5bITd3odUkNvJZm3ltI3VxyH5H615/qJvfD niG0VbYxwpKrxMg+VgCDgfSvSYzEYVMrYIGaqzDw9runyWt7LDd2ZYqWWQfIw64YdCKnlsVc9ftN UimUMjgg9K434qiObQbO5OCY3dP++lz/AOy1zltcXejxg2N0L+zQfeRsug/2lH8x+VM8Wa9Hq/g5 lVsssisCDn1H9aal0YpLQ5iwQtp8YTqz5Fe++DtOjsvDMXygmf5jkdV6L+gB/E14Bpcuyzt9xHUV 9FaDcI2gafg8fZ4//QRT6DRm+NNItrrwtcNJcPbpa4uUZQCUZehXPftj37ViW3ieOx0GPxCP+Jrd 3rENKqlEjUcY5HAz29a6TxIVvH0vSTyl3cgyL/eRBuI/QV4xrpufDPjO/wBJtLh44oXM8CA8BH5x joR2x7U4rUmT6mr411i31+1a+gVkBRQ6t2YEZq54O+HOjeI9HtNW1sC4RSwWJGxnaxHJ6jp2rn/P stW0maOTy9OnJOXAPlMSOpH8PTtx7Cuo8Lx+J/Dmkm6trdZrQyNvRSHBGc7uOcYPUU3vZaAtr7ne f2Ff6WmNDvjJAOlneu0ij/dk5Zfx3D2FRpqtv5y2upQSaZdMcKk/3HP+y4+Vv5+1WNH8V6ZqoWMv 9muDx5ch6n2PetueCC6gaC4hSaJxhkdQwP4Gpd1uUrPYyHgYcjkVnag5t7C4nPHlxs/5DNXZNDu7 I79DvvLQf8ul1mSI/wC6fvJ+ZHtWB4l1YQeGNVh1Syl067a1lSPd80cjFCBtccH6HB9qaBngVnPH G0ELhy0zOQwXhQAOSe1df8OYI5PEkMdpDK1vaT5eZiWBJBbOfqawtFsVvLadJF3gQlefc/8A1q3f hlZ3XhnXzo10flv4BLF79Sv8mFZ2Kjoj6EKi5tWiYA5GOa811Kyksb2SAjjOVPtXoNq8iqgfk9DW T4l077RB9oVf3keencUpx5kVCVmed6tB5ujXsRHDwSKfxU1meGE/4p+FcYALD9a2L9s6bdYGP3Lf yNZnhnnQIfTc3865Oh09SS40iCRmkgaS2lbrJA20k+46H8RUKfbLIbbi3a5jH/LWLJI+qk5/In6V tMhyeeKTYccHNK5RUhmhlUm3dWx19QfQjtU4Uev5VXnsYpSZCDHL082I7WH49/xqAPqVo3zKL6L+ 8gCSD8Oh/DH0pgaQ7ZBpw4PTPtVeK5hnkaNJFMi/ejJ+ZfqKsbfl4agQuCeVo5AxjmlAwM5oOeM0 DEA9qo6xM1vol5KnDCJgv+8RgfqRWh65rB8TSlNKSEH/AFko49hlv6CqirtEydkVfCQhs9Cu76Yh IjIzlvRFGP6GpPD0UlxcfbJ1KybTK4PaSU7iP+ArhfoBVO7223hPTtLPBvSokA4/d8ySfplf+BV0 OixNFpqvIP3s5Mzn3PT9MD8KtvRvuSlql2NDaM5P61keJHC+H5xx8xRf/HhW2CMfX2rn/FzBdJiU dGmA/DBP9KiK1Lk9C34fXZoFoAOqlvzJP9a1tp6gVT06LytKs4+hEKD9BVrcRg4pMa2H8j0oJI7Z phYMO4pOc9KALEVy0ZBBP1zUzfZbkjzowH/vAVQyQPmFLvf+E01IXKWpLZkG5cMnqKjG0LwR+VEV w6HJarJaCbl1CN/eX/CrVmS7rcq7ucijd8m7880s0bxjcE3x/wB5eag80HG3nPagAkmGAVx9ah88 55Ax69KR0EpwrFT6A0rWSsoO4n607isMeRTzg0juHQDoPTpQtsF4HX8qcyMBgjPvnNPcCs0w2hQM YqJnUrnbVs2w6qMGqkkTDkpn1pjVh8To3U4x7VOojzkgg+tVFKgAEYPpSrMA+PSkMvqWHo1Y3iy+ 8rQJIFb5pyE/Dqa0llib+LBrjfFFybrUltoz8sC84Pc8mnFaik7I5FbcqNxH3cn8as2iCC1ebjk8 cen/ANelkJW3JA5J4pZwyRRwn6k/59810t2i2c0VeSRXJwvciq9zNIjwwxRFzI3LdlHfNTP8o6Zz UbNJIY44ImmnlYIiJ1JP+etcJ2Hpnhezjt9BR2X5pyZD9Og/QVpvArA8DHtSRRm3to4IwAsahRj2 oLN13AVdxWK0lmSSVOaqGNkPzAqR6HFarBnjxyp9RTAGUbZMSDr0q0xFONuCrN5gP8LDNFPdYyfk +U+lFOyEXUUEkYH41JsXqF/GmIATleKkZPTI+lc4jhNTs5LTxBcm3jzK3+nW6/32A2yp/wACXB/C uDn0y+1Dxncalp8kS28s0RaWVsAGTOAQAT/Cc+9et+ILOYWcWoW2WuLF/OQd2H8S/iM1Q0XSNKuP EV1aoqGHXLFpbQ45Ey4baPfBc1cVd2M3pr2OH1jQIrPUIoblNpgy0TRdOVIx9Mmuv8LeEfDcOk2W oRacrXM0Cs0ruxOSOe+B3qXWbGbUtB3Sx7dQs8pIMclh1/Pr+NSeCdQW60Q2HSaycxkf7OSVP5cU SCO7MHxPoiWt7Zw2xZxJIZY1xyGRS39BUCu8XltvZl6h/UehrovF8k1pcaZeQuqSo0qo7A4VjGQM /iRSp4ReDw/aQxyu93HEol3tne+OcE+9NStqS43uchrNxlrQhWYSOEDqMhc9Sfau5XUYJbeG1jH7 qxHlJ+Qz/j+JrhtWia18lZFZGSXJU9jWrpkubZlZvnMjk8/7Rx+mK2jJXuYNNKx1STjaDjOfSue1 GQf8JIZpD8qW4yT25q/b3S42v/D0rnPGVw9rpuq3q/LItogT3LSoo/ma1ZKOb8eeL7rxJrQ8G+C5 Dd26nyp7mMfLO/cL/sD179eldV4Q+G8ei2iPqt1Je3THe0e8iND/AF/lVv4deFodF0CC9uLaNL6e ME7VxsQ8hfqep/8ArV3nB68L7UXuUko+o20it4cCK3iQj0UVi+KLCzGnTXMERgmON/lnCvyOoreS F2R5EUkIu5sHAA9TnpXOa7qiXWnTQ21vLLAu3fcEbVzuHAz1/Cs2kVe6OchdBFZKzBc5JJNeveE/ EcY0yCzmkAkiG0c5DL2IPevH7CNJNW0tZVDoSQVJxkZGa6u60SW1U3WiSswzueBjnH0Hf8OaUnYa R6rdX0b+IdDuS48tGmUnPQmM4/ka8e8d6tbat4uOs2qELFiHd/fToSfx5p76/NdWq2lxM1tKj7lL HjPTr26nr+dZl1bF4mjlUZYY+tCmhOLJLdt9lcDdnIHH516/8LlWXwnMMlXjuWAYHsVU/wBa8Bn1 620SwVb0SGWc+SqohYsw/wARzXtXwb1Jbjw/do3yS7o5TE3DKCmOR1H3TVy1FHQ6vWPC1jfFpSn2 S57XEI+Vv95f61jR6r4i8KusWpxfbbHosgORj2bt9DXoIcMKhltUZGVVUo4w0bjKN+FNSa0YOKeq Kek6/pmsxg2k48zGTE/Dj8P8KxPiRf29n4D1COWRVluFEcaHqxLDOPoKy9f8IQxxy6jpM7abcwgy eWSdjYGTtI6f56V5F4i12/1ZFbULtp5Ewg3HkD6VXKmnJEuTWjNLwhb+ZYTykddoH6n+tdB4hnns 59C1t9Iu7GbT5fLJkT5JogeGDDgZweDg/N0qp4RgZdHRcfNJMFA/ACvYfEmlrq3ha+04LlnhPlj/ AGhyv6gVn0NETIyOiyRsGjcAgjuD0NWHVZoCrYJxg1w3gq3vrrwna3emam3mx5iltbvMkRKnjB+8 nGOmQPSumtNUdboWt/aS2VweAsnKSf7jjg/Tg+1Azz3xPpM1o98Ipf3MkbkxOMjBBzg9q57wvPb2 2hW9tI7JtJCs/Rhn1r1XxlY+fok9zCNzpGxIHcYOa8aivtOtfCCDVzBDaEsPMuZAqsc9AOpP0FYT g27Jbm0JdzsWZF6sAD71H9ptun2mP/vsV5BJ8SNG0jZBpsdxqaJwHlXC49Bv+YV1nh74i+GdaZLd yNPumO0RzgAMfZun54rSWCxEY87g7AsRSb5eY7I3Nn3uoh/wMUgngf7k8bfRgamCREAhBj2pGggP BjT8VFcZ0XIZrS3ugN6biBww4YfQjkVEI7u2VikhuV6qr4Dj2z0P41cRUjXagVR6AYpeO36UxFeK 5WQLuVonb+CQYOf6/hU+CRg02RI5BiRQQOBkdOKr+XJEP3MpZQOEfnn609Balnv61y3iZjPf2loh wSD0/wBo4H8jXQrc5JV1aNh1yOPz6Vyt7cp/wk013LgQWgLs3sibj+pNVFWZMtrBdD+0vFptUOYb RFthjoC2Hk/8dCCuwXC8A4xXI+EIZXtm1G4X99MTK/8AvSHcR+AKiusDAgEflRPsOPcmLgDcSAB1 Oelcj4s1XT2tUQXSMsW5n2HOOOP61peJX26DMAeWKj9R/hXAsnmYjIzu46VCdtSmro9YtZVmsoJo wyq8asoYYIBGRmpST3qvG4jREHYAAU25vVtYTI0bSMTtSNPvOx6Af54oHYsggcgU7dnqKiRmZFLr tcjkA5ANOPOOeaAsOPI9TTSuMc0dqNxxzxigYv1pQzL0NJxTuPSgRLFclD6U9o7e4PKmJvVeh/Cq u4U3cRyDj8atSJ5ew+azkXkcj+8ppF4UA8n1p8d4yHHNTsIZxkgIfUU1YWpDyRyAKChI4FOW2kzw 2U/vLyKdhljyR0qhEBQgcDioGuoyDGcZ6YIq4ZBjtUZRZBgii4WMqfceGjH1xVYnaORitprXCkjn 0FK1sGUAxcVVguYLzeVGzs2FUEnmuGZzLLLcSHmRi1dj4xeDT9BPlpiWdxGMHt1P6D9a8/8AtWBt IJwMmtYIxqS2ROfnuBj7sY3kfy/Wq086vK7Z4HA/CtGztHuEhRZBDLdSbd7c7V9fw5NUvG8GleF/ Byafp7ST318fJE0inOzq5Gfy49aVTW0UOlpeTMWW+S7tb8Wt0qfZYHleVRuCY6DPqTxW38Kklu5p 9TvMCOGNYYlxkZPU/XA/WuZ1ayHhb4Z2trPD5d1rM6lnLAYjXnGPrivXfAuiLpvhCzQTJH5y+ccJ knPTkn0xWbikaXbsdKPJcZjyTUMrQxDMjog9SQKma3iA+dpJPq20fpShoo+UhRfcDmpui7FMEMcx h3/3Qf50CO5YnCiMH+83P6Zqw9wc4HP1qFpSSSCM+lJy7FKI17Uk5Nxhf9lefzNFRmds4NFTzl8h bQYOM81KuSPf3qsOQMsaeGA45NBzkkg3AqRxXnWswT6bNHbwTtby2N0t5Zy/3EZhu/75bH4NXoJJ PHb61geKNKOpaUxjX9/Dl09x3X8RTJ8y7qOvaTP4mt5EnSG41KJBdW+D+6uADxnGOcH68GvPTdv4 a8eXbIGNv5g3Ad1YdP0z+FekeGLi21zwc9jdyCORoxEz4+YSofkb65OP+Bj0rjNW08ahr720wCXF xalf+2qcg/iAauWquZ7OxN4o1iK41nTLSECeKAx3srAZAHmLt/Mbj+Vd0rtjGa8l0mCF9F161kEi X7qOX9E4wPYV6baXsdxpsN87BY5IllJJwACM1mzWJyHxLTy9BivUiBkSUZYDnFcfpeqxSPmJvkmA cf7LYAYfpn8639d8Z6Fr0tzoUumXs9rHJg3GzbHJjIba3t1B6HFeb31n/Y+oTW9pcyyQRvlHZdjE dmxz61S0Mmrs9OjmwFLHHv2NZV2h1uYWUpJinuoonOONkbq7D8kP51h6T4hhni+xXbhZ8fL2DH2/ wrb0u4mjtomeNCsc8km8DkBlOM/qPwFaxmZuNnc9Kiulk2qnCjoBV6DazpucIGYLuPRcnqfpXH6f qAdBjhv7takt+5hhsopCkl42xmBwVjHLH24FbJmfU6i7lt9Qg8q3DR6VEcD+9duP4j/s+3+Tznir C6FJgADKgKO3NasN0uFSMBY4xtRR0ArF8VMzaQqJH5jPIAF3bcnBOM9qLWG3c4vR761m8TaTbrOp mCthAR1AH+Br0o3UFuPMlnWIr/ebFec6V4a0rSHS7tbFILwjLSbi7hj1wx5HeuitNGvdWlkFvHtj QZkmf7ifU1DaLSsS6zfaPqJJAY3GOJEXAP1z1rDWZraMxgkIexOR9R6VvyaHa2ZCopvJe7k4QfQC mtpznAEKYPbbS5AuchLexw3okMj75QECY+XjJz04Pv8ASuu8BeKv7F1W8fyBLHcKgk28NwTgj16m qV54ZjvYG8kiCf8AhIHyn2I/wrjNKuruw1y4s5k2XCKQ0bD0I/xFPZB1PrPS9bstTtlntJ1kU9R3 X2I7VsJNnvXzJpviOexv0lgke3c8dePxHcV63oHja3vQkF6VhnPAOflaiM0xtWL3xL1mXTfDUUVr K0U9zMAHU4KhfmJB+uPzrw/XNUXUba3aezijvDJh7iL5fNXH8S9M5I5GK9F+K1w00elbDlAJTx/w GvIruT9/bL6HJ/MVq7cpi73PWvB0Sta6WQCQJt5C855NeyRzRzLmNgR/KvHvCOlx3B022E09uzx5 LwuUYfKTkH1r1C2t7qziUXk5upVyPtaoFZhnjeo46dx+QrM2Oa8Kj+yPGmveHz8sTv8Aa4F7AHqB +BA/Cu2mhiniMUyB0PUGuE8STNpnjPQNfwohkJtZZFPykHp/M/lW3418Xaf4L8L3GsXzqXA2QRZ5 mkI4UfzPsKcYuT5Y7sUmoq7OA+K+ur4fW0sB4iuEmvGWOPToVXLISAXkc5IXr9fzI+a/HFxdzavD bSTu0EEI8tC3CZ5OB2zUdzrd/r/i1NU1G5a4uJ7lXZmOT94cfQdAK6o+C9T8Z/EK30nTUALwI0sp +7CgJyx/zyTXv0aEMLUi5Po2zz5TlVi7dzgdH8P6v4g1OHTtHspb25kPEcQyfqT2HueK908P/s13 0lus/iPXEs5CM+Rap5hX6scD8ga908G+CND8EaOtjpNuPNYDz7lh+8mPqT6eg6CumrlxGYzm7U9E b08PGKvLVnjlt8LNX8PWvl6F4omulT7tvqKbkx6bl5X8PyplxJdabxrVmbHkDzCd0RPs3+OK9kZA 1VbiyinjaOWNXRhgqwyCPcV5NRe0d3udkJcp41da/oFkwW61i0hZugaZQf51oRSxzRLLBIsiNyGU 5Bq/qfwg8JTXz6jYaTbWt0Tkjy90ZP8AudB+GKpT2F3o6CO7s/KhXgSwjMePw+7+Nc0qdtjeM0+o YprBcg0I8bpuDhl6grSYz349qxNSNwhUjqDwQa8t1S5SWMaehxJqcwXAP3Yi29//AB0AfjXpGrzf ZtIu5lwGWM7f97GB+teb33mRXSQNPMI7lVgiWFBmLqWJP49a2hormU9XY7W01Cy02G3tLxxbSTZK l+FJJ6bugPIwCa2uwIP4iuO0vUNK0p5Df3SRvIAqI3LP+H4Cr41xJbiSKwtrkyIRlVXcrD144pcr epXMloT+JnxpKDP3pR/I1ytogk1C2j/vSqP1rT8QnWbiK0iit4yHl3srP86qAc/KOp57ZrH0O3e6 8ZxxxXBVrX5542H3QOg9jlhU8tiuY9Imnit4DJK3sqgZLH0A7n2pltFO0v2q6ULIRhY85EQ9Pc+p qcKm8SEAsuQCe2accnmoLJBnOcUu4jqetQ/NjuDTlJxg5pkkm4epoDAHgChBzjH40/HPQflTENZj kEDik+YjipMccMBSKDu9aBkRUmmlODg1aCMxOI+fSlEL4+YBcepAp2FcqqpHtVld3GDigrBxm4DH +7H8x/SnDG35IJGP+0Qo/wAapJ9SWyaOUo3JpZpkAGfkB79s1DmY44iiz1GC5/XFDwpLGVmleQHq M4/LFMAEsDSNGGDMvXHQVU+3Ikk0cKrI8bD5Q24kH2/P8qtpaWyKBGAoUYAPP86mjjSacr9nMbKN objaw9sf1p3CxAl4zIw8pnOeMKF/maieW6kHSJB7sWP8hU86sny8/hVKc7I2lLbQqkk+1LmBI8+8 a37T61FYearrbJuIC4AZuf5YrmPKkkCbVGGbqKLyd7vULq9JyZnJ/Dt+lS6YqtcvIchUUnGemP8A P6V0Q2OWbvI7XwzbA3j3GMpbxiJD/tHr+n864y73+NfiZJMTv0/TWFvF6Mw6n88n8BXT6pqL+GvA Et2mVvLkbYlHUyPwPyHP4Ung3SY9I0FJZR5ZhjJkY9S5GXJ/l+FRzbyN+XRQ7nMeLIf+Eh+JFrpC AG102JI9uMjcxBx/L8q9ciJjhSJAAiKFAHYAV5j8P4zqes3OtzKS9zK9yfUDJCj8s16bJkNuA/pW UtNDSOrbFZmx83FM3D+InNKJWHVcj3pBtc5H5VBoNKow4NRkIOMGpHjkHIOOaNhK5JFS0UmRbIyc gfUUUELziikXcsKuOxNOwCfu0pLkEKd3pmmhXx83UelbHCPK57YqJ09eRU21upYkY6YppTgjGAfw pAczH5ei+IngLCO11EboyfurKOq8eo/kKg8SR3MOnWWvG4he/s3UXDBNgyRhjjP3SMn8a1tc0pNV 0uS2wAw+aM9ww6V5TqGsandXMcWqOwW3G1lLYwRx83HPGeTTTsS1c6fxDpv9nXEOoWTny5FCO3XJ xjJ+ornLiHx7c+Gb+Wy1Syi0q0hlVImBMjogI2kAY5Ax1rtNFePUfCosrpt6JmFn6lCPuk/hg5rJ s5dRt7fWPDtu0YvZ4Wa2Moyhk2FcH2OM0tUPS54f4au7k+JhBdTwmS4jZVjGVcHYW6Yx6jrniu+m MWo6Kl8Y989qvlyADJaP/wCt/WvObOO80rXJItShWO6srpVk2sWAKsRwTn0Ne6eFdFsoBAZSbj+0 IpwTLj5GV8bR7YDe/NVO0dRRbloeZ2Gh6ncari1sZriCFxIZVQlVUc8noOK7nSLPVIdMlvb5Im04 qxV0bLhAxHzD25NaFjOvhzU73TryXyrKVGyx6Lwdp/oabp2oa9feHZNC0bQPMiUSxzX11JsiwzMc IByxwfzqNWVZFuC3McQaJ9ykAqw70Q3xbxGyM3+qtcD6lh/hUenQS6f4Pk8SarrM92qW4VLby0RI 9p2qnAyTnjOah0+MXGoz3gVkdwI9rcFflDAH9RWkZ2MpQ10OrstQQXBgZvmA3Y9RTdcmD2lsCePP B/Q1lRStCxJXnkVBq2or/ZqzOWVImJbIORgHtW/NdGFrHRaDpB1zWI7USbYwN8r9kQdTXe6rc2MN oNKsItlvHgKq4A92OOrH9K4Tw5qH2Lw2XtnC3GoOFDHqFGf5YJ/AVvwsuxQp6DqTkmiMerLk+giI ucFB14xU5RcDAFOUqGUZAzxnHWnvGpOY88jIzVtEpme8WXyFII71DfaVo99Gs19Ckc6qVW5UYcD0 PqPY1c1Um0jjgCvJfvylumMgerk9B/nisOXQb67m8/V75nHUW8Hyxp7Z6n68fSpaRab6HP6z4cu9 PUy4E9v2lQZH4+lZUNxdWuGhbcndG6V6rbbI4BCmNgG3aeQR6HNYuoeGdOuJfMtj9lJ+8gGV/D0r CUTRM5yXxEdTtIbC8dt0THy9/bI6A965+9Rv7Yt4wOBjP5k/0rrLvwH9qgdUv0G4YBKHg/nWBLp0 mmeJFsJ5hNIFUbgDjJwcc/WlGV3YU4WVz2bwftXW4FXpFESPyxXpayg968d0PVLfS9T824mCeaPL XPr1xXotnqsM6gq4OfetyA8WadaXPhu8le1E/kr53lhiuSvUgjocZ5r53+KsOp+PWtZtEkF5baXb DdpyMftELsMtJs/iBAHK5xjp1r3Lx74us/C3gXUtSnuI0maForZG58yUghQB39T7A18w67qtiNG0 zXYkmt70r+4v7VyrxN1CNz0OX56gr6V24WMozU0t9DGq004s4DTEurfXbOKVGdBOgJx8y/MOor7c +GWlWVp4WXUYYQLq8P72TuQpIUfQc/ma8w8L6Bb+L9SstS1ezsdYeK1W8bV7bELFwOYpo+khBHDY GdvU8ivXvBVtHb+FraG3vI5XUud8ZyrjcccH/wDXWuOr+1lFdhUIcqbOroqETbWCTLsY9D2P41NX mnQFQ3Nzb2drJc3UqwwxKWd3OAoqUkAEk4A714B8SPGkuu3zaVp8pGmwNjKn/XMP4j7en51rSpup KxnUmoK5P4y+Ll7czSWPhkfZbcHabplzI/8Aug/dH6/SuG0iLxf4h1jy7KW8vLo/MzPITgerE8Af Wui8N+DpJpbUSQrLqd4N8EEgytvH/wA9pB/6Cvfr9fefD+gWXh7TBZ2oLux3yzN96V+5P+eK7J1I Uo8sUc0ITm+aTPPtM+H2tw2oe81SGC4I5WFSy/jnH6Ul5pGp6arG7g82EdZoQWH4jqK9XKg1E8AP avNlCMtT0IzcdDwPxNOj6TDFDIGE86qCpz0+b/2WubkeU6hHarauyMhdpj91TnhfcnmvQviTbWdt r2mxwwxxSeXJPKwAGeQFJ/Jq4lkMWpbpLtdkqYjhx3HJPvWTjyqxalzO5Z0Twxayf8TbUo1urxmZ UJGFRAxwAP8AGuoSFYl2xoqKP4VGAKWxVFsYY1YMVUBsdj3/AFqwUyMisXdm6sVjBGxDMo3AYBIr kfDBuLzXtZupX3BbmWOMkDcEVsAZ6kcHg5xXahfWud8IWvl212/HL5LZxySzH+dNLRik9UbjMY8b 1JBHJA6f409GR1yjBx045p+YOVM6s3ovzGohGoLGC2k3MDzjZz680WDmJgvHAqINh8Nn2pf9ORF3 pH7tyxH4ZxT1jkkXcLw/RQF4/nT5Rcw5UlCFiCq+p4/nTxLbrw86FvRPmP6VAbNfMJklMg9G5/nU oMcPC8H86NA1Jg4PMVrK57Zwo/WplS4K/wCrgi/8eNVlueeWJFTecOlO6FYDbzeZue9lIxjYuFX9 Bn9aclvCOTGHPq/P86Z5uR1o3nHXilcqxI23PIHtTS5PHpSBiR2pGPrSuOwm7HU5NIX5p2FxgikA XtSGMBfJJzzThIRjB5pTnJzSbQSaALUdyD8syhx6Gub8b3MVj4XneCTbJORCq9+ev6ZrXPBrzjx/ qLTarbaapJW3TzGAP8Tf/WH61a1dmRJ8qujkQhUBeAQuc59a29GsvOkhtwMm4kCt/ujk/wBaxkVi RkfM3I/pXY6SU0vTNT1+UgwaXb7FB/jc9h79B/wKuhu0bnLTV5IkvZf7R8VuFUPb6QnlRr2a5kH8 1T8i1T+LJ20zwLc21v8A6+4UWqY6lnOCf1JpfC2nTRRQm8P+kDNzcsf4p5OT+Q4/AVS8dTiXVdK0 8sBHFvu3/D5V/Uk/hWMlZqB1Re8zT8F6dHZaQxRcZIjHH8KjH88107RgjI/Gs3T7c2mm28JJyqDO PU8n9auiQhsBs1Dkm9S4xaQoXJwDzTvKC8g4NMDgNnofapFlyvPzfXrSTQ3cad4BzyKjOCcAipww 6mmHAblc+9DsNXIGVj06UVIVDHIGR9aKmxVyVZUA4xR5oJyKp7mPRaVN3Yn8a0OQuCQn7wx+NNcs R8uKiw/ripsZT5u3pUjIGUlQT19BXDeNPDbXCNq9jDukQfv41H3l/vY9R3r0AKoQk9zURA3Fc9ee lS9B2ueXw6bcaRcW11HfSNb3SiOG4tuVdv4Qy/mPyqvqUl1bvBq0jr5kUrRsE4dMHjI7HgfnXWaz olxb2twdPRpbSX53tUPzRv2kj9DntVWKO18S+GroGNI9URf3x24LsBwxHvj8DxTUugmup498Q7S3 uNQv9X0rzDPqSwvLbBDmOUcNj1zwePU13f8AbP8AwjmixS3wzeadcO5tx95w0Y3fhuLVesltzpcq Xlot1CycIRnawOP0IIP0zXD+IoWs445j8kYDRuoycjkgc89/0q3rZMja9jW0i81vxV4Zutf1ZIwx uGNuEGN0WBuUDuARwevWu/8AAsok0i5iVifLnJx7MqnP6mvl2x1q/wBN1W1uop5WayfMaOxKgZ5X HYHJB+teoTapPBeQ6/4amcERpcxxhsCRATviYd/T6inOARmj1G0ksbtLjwu/lyTC7ZpIXXO2Ld5m 78/l+prkfFL3VhFe6nbSvEbPVkMpU4yjDBB9uKwbb4kyaLrVzr9z4fWWTV8eX/pO0QqvBGdhJGcZ OO1bt1d3WtaR4hUW1rdQ3tn9oaO0nEjBgSQyE43Ad+AelKzW47pndXentHGtynzwuoO/HUHpmsDW E2ac8iA5HQ56fWp/BOuDxR8MZLV2Jure3a2kGeQQvyn8sVDdILj4fWupiU7jAol3HOWHysc/UGkn Z2CUbq5NpVzG0sUauA0MOAvuSP8AA11EF2wO054615/pJUy29yhyXiA/EHkV0theEzMsyFQDwfXg V0Qlc55Raep2NvOSCFI4HANaNvfxWcJkWIy3pIjtomXCliPv5x0H4/pXLxXRd0MbAbm24q1Z3pu7 ya+yfLT/AEa3B7KPvH8T/I+taMlGt5SxO58zz7mT5ppj/G3oPYUgy4we1NDAjjqetSLjaAcDPSrS QrsgZWQ5ANCuCcH8qs7Cy4xwKp6kr2WyJEMl4/K26jnH+1/d/wD1dKlpFJstI4j4K5Q9RXnN4wuf Hd8y5KpMiq30UZ/ka7Oyg1CFJJNQuklkkORHGPlj9gTyfrx9K4yyHna3c3OeGu5MfQA1m4pO5XNf Qq+OPGUfhnTYoTpsN/LeFtvnE7Y9uOeOc89iK4/wt8Z9U0qZYtTXz7fPDJnKj8etdz4n+HkPjbTF kh1I2eo2pYQiQZikzgkNjkcgcjP0r598QeGNa8N6k1jrdjJazDlc8q49VYcMPcVVosNT1z4vePrD xR4X0L+z5lm2zyO/PK/KoAI/E/lWD4dlj1b4eX8O0NNp7mULjPYsp/LzBXlm4BMHnFd18LtSjtvE s2nztmG/gZMHoXX5lB+uCP8AgVezT/3VNbxdzjf8Wz6n1t8NfC1nZ/BzSY7uAG5aB7oSAlXQvluG HI4xx3rY8Hm9i8J2rLapd24eTiM7Zk+c8jPDfmPxrW0praLwdZxWrA28dkiIfYIAKreA5lfwnEAR lZZAw/uncTg/gRXkzlzycn1OtKysjbtr6K4Rgj/aEXh1K4kT2ZTzVhQyqGt3Dp/cY/yPamz2dvcO sjptmXhZUOHX8f6dKytUvLvRNOub+bbcQwxl/MDCNuBwGB4P1GD7VmM5z4l+LE0nQf7OgkMV1eAq +eCid/z6fnXiFiWbUInSBZ33DajDIY9uO/0pfEelP4xu59b8K6q+pzzDM2m3EoFwmCM+X2ccHoc+ 1d38LfDwW9iF3aGRtLYyTOMHDn7idedvOe+a6qNeMU1Y56lKUpXPVPCmgf2NpYluj52p3X7y5nbl ix/hz6DpXRU1HSRdyMGHtTq5m23dnQlZWQUUUUhnk2uaTbeLfitJpl6GayijWOQIxGVVd+M/7zAV SsNC0+0+NVxpdzaxz2ot8WwlXdsyobr35BrofAwGo+K9c1r7yuxCH2ZiR+iimeKY/sHxS0HVAMLM FiY/RiD+jCm9xo6fUPDtjesZGi8ub/nrH8rf/X/Guav9B1G1H+jqk8Y6sR8w/Doa9FIB7VG8QIpN JjUmjyS7heGznmmu2QRIzEKAgGBnnvWT4YtrY6W00sauTIcbuRjAr0fxjp9qfC2ozywqzCFgCR68 f1rkvD3h25j8K2c9uoZHDME7gbj+fSs5QaWhopJsfmJeEUKPQCmtJTngZG2yIysOxFRsgJHHSsG2 bJCMc1EwDMGI5HSpCPQn6UY6cVI7EGbhSePMXtzg/wCFOwrOU3bWHUZ5qXANMaNX+8o9fSmAyG2K MSZSwPY9vpUxULnA5qPMqNxh19CeR+NPEqk7ScN/dP8AnmiwCh/VgKfk9j+NRYPI60odgPugj2oG Pzzg0bvnGce9MZx0pu5QxIUDPXtmgZNzkihZGDfd5pivj60HfkHPNAiQsScCkzjk/lTCfWmFiD0y KLjsOeXYpZug5JPavF9RuG1DWbu95DTSHbnsOg/TFel+KtR+w+G7hlOJJcRL+PX9M15V3Bx7kVpB dTnrPZFiwUtdln4WIFz9B0/X+Vbdw5mOjeHTzGM6vfAdwD+6Q/U4yP8AZrLsUhfakr7IppMSOeNs aAs5/INWz4Nik1i9uNduUKnUpjOFx9yBPliX+tbvT5EQWnqel6Rbww6YkdwgMrnzHPfca8+ni/tf 4jXccQ3xJKtuvH8KDLfruru7i6W0tJblx8sSFz+AzXIeBomOpTahIxLqpYn/AG3OT/WsE76s3asr I7F4hxkYNQmMD1rbLQ3AxIAD/eFV5rF1+dDuX2qHEtSMnZzz0pRgHOcVYdGHbiojjHIqbFjTjPUn 3pQ6jIPWmF2DYxijcDycUhg3qD+VFGGHQUU7DuMAIGc/pSgrk/N+FQeYF7gehNJ5mSAD+NWcxcyW Ix+NKGweuagVuh+Y+tO3cg7iBQIeWO3r+lJuJHXkUEI+CRnHIJFOyTjjHvU2HcYzHPNc7r2kXJA1 LRv9H1CPk7eBMP7rDvXRHI5yM+gpCOhOTU2GeUi7uLcvevEjid2eNY4y/lzDrGVwSMjg8e4ODmov Dmjw3PhKXxHqxaW8/tEefbyfdihX5cYPfkn8RXY674cW9la6sn8i5YgsoOBJjofZh2NGnXaanbya TqTrb6gqlHiK48wf3h6j+VNS7k8hg6h8GvCJ1R57yO9jEzbgYJwEbPPdTj86o6x4TsNCu7Sw0aJo ofs8nlJJIWLPncRk+oBrvtM1qT/hHm0i4iFxqVtILKNHOAxzhGJ64C8k/wCyayfEFi+m3VhLfTC7 a0nSSaXZhY0Y7emT23kfStXrqQtPdOd0bTND8QfYdO1jToHSK2KlF4+ZXVgQRzyC2fXFLceDp7Tx FHpnhTVZdDeGB5Ys5kVwSuUbJ5XJJ5zVucReHvFqXcKie33NgIQcZGGX2PIP5Vq3wvJfFelXUrCy WcNCDA4dgpViMkjGScdM/WsrtGlk7HnEs/jTwD4sbXta0+CWxuyI7lrEjy5sfxBc8N+AFdYms6Of Bd/o9veRC5QPPBbyNhzG48xSB3+8enpXfQaTp0G/EPnyOMNLOfMdh6Fm5x7V5J4k8P8A2HxlLNba YktilukHmDO62yjBSP8AZIG3n2ppqT1FJcqsc/oGuSWbfZrj7udyN6N0/I16PY3tvqMG+CUBxwQe x9DXkEZjGGNXbLUrqyuRNaPtbpzyD7Gr2ehGjWp65LO1lC8rnaqqTn6A1c0K6xpNgjZBaFZGz/eY bj+pNcjDrK69o5tGBiuCyo64yBuIXIP410FmjxW1soJBWIL9CBgj9K1jPYxcdzroLoO45yTWgsu8 gDFcja3RV2ZuGArWtr1SB2Pet0zJnWWlzFZWxn8rz76RvLtoj69357D+h9Kg+zCIyOG86ZzmaY/x H0Ht/nvWTpN413JLqTnhiYYB/dQHB/Mgj8M962ml4G3he4oSu7lX0sVZFUqcjgd68v0R2kmLk/KT JJ+ZFen30iR2VxMBtKRs30wM14nqEPiJ7ezg8PvHG0iEzSSMBtXPUDr19B2pS3QkemWPmrbiRScZ PSq2vXfh2/046V4nNtJDJyscp/eA+q4+YH3FZNjc3+n+FYNLmnJulU+ZcqckkknjI464rJs9Lee4 cafamWduXlPLH3Zjz+ZovEpXPP8AXPheVvg/h7U0uLGUni4VkeIe/wAvzD34+laegeArDSruC9ub ue4uoWDKE/doCPbkn8xXpNvpT2qgzXAkf+4gyBUy2UMkmXtyM9xxVqtUjHli9A5It3aCy1e++yfY bm/aaJCTHHnAjTPAxn9a9Y+H7RxeGnWNVXdcOxx3JAya8gvtHFhnU7eLepULI2PmUZOAfbk/nXce BtciTSjbtIN3mk4z7CsVuadD1pJM1xHxY1EWXgCc8nzZUjAHfP8AnP4Vv2+oI6ghsivPvjJqUX/C Oafp6Orzy3Il8rqSiqwJx6ZIonpFsSWp4RY6VA+prPaRPaSli7ywna3yDefb7wTn3NfUHgj+3bPw lZ3mssLye5QSvPHHhip+5vHUnbjnn8K8I8LaZPqcus3EN3izikWCMIciTMgz9ckj8MV9UW8aW9vF bxjCRqEUewGBWVFOzbKnpZEcUtvc4khkCSMOqnIb+hqYTNGdtwu30cfdP+FQXFjHMTJExgmPO9R1 PuO/86hF3cWnyX8YMf8Az2Tlfx9Px/OtzM06z9cvP7P8PajfA4aC3kkX6hTj9cVPGAU8yzkBU87C flP09K5L4j6otr4JnhOY5riWOIK3cbtxx68KaEgF+GlmLfwn52P9fKSD6hQFH8jUXxJgYadp1+g+ e3uMZ9MjP/stdH4Xs/sPhPTLbGGWBWYe5GT+pqn43tvtPg69wMmMLIPwIz+maHuUjoIJRPbRTL92 RQw/EZqSsbwtc/avCemy5yfJCH/gPy/0rZpCOW8fS+X4MulBwZHRP/Hgf6Vo6BaCHwzpsJHIt0z+ IzWF8R3J0C1tx1lul/RW/wDrV2MEYitooh0RAv5CmBnXmmW9ypEsYPvXOXvh2VAWtm3Adj1rtyAe opjRg0mlLcpSa2PLJoJYZCs0ZRh/eFRnPWvSrrT4bhCskat9RXN33hojLWrf8BNYypPobRqp7nLH GcHmmsMDgZNWp7Se1fE0ZT3xwarnbn1rJ6bm24wN8vzrj9aCqPjcoODkZ5p5UkfL+VRkMueCaVws GCCAhAGOjEnn+Y/WmBwHAb5GboCev0qTqOoz70oBI5Ue+ec0ANb6VE4k2nylVmz0diB+YBqYR8kh wB6HkD/P4/SmnKgnadoxkjkf5+tAyJGvNw86KFE7lZSf5qKsrkHBOfpSK/ByOlG/qCOKBDiU6UzI 6AGkCDPQkdqMhQWJyB19qBnn3jy883UbTTs4WIeY/wBT0/T+dchI/wAhKqd2eB6noP1xWtrDrqGs XN6JVcTN8hHQL0H6VnwxBLsGXAjiBlY9sDp/j+FdEI2OKb5pFHVJGllg8PWj4nuwtqWH8EZw0rH/ AICFH0Y17H4esY7PS4/LjCKygIv91AMKPy/nXjfw10+bxB4g1HxDc5InlMUOf4U6t/47tH/Aq96T EahcDaOBiio7K3c1pq7v2MLxZOYtAliU4aciMD2J5/QGk8K2hg0gS4A81ifwHH9KoeLJxPe2dnG3 3QZCvqeg/rXV2dsLaygg4AjQLx34rO1omt7yJkLKOAMCrcc74wMrn9aq7SMsuKceV+9j6VK0HuXD 5cuA4Cn1FUpoQrlVYE9eKRX2Hrn3zUizsDkYWnuGxRMXzHnB9xURUA8d/WtMrA/MrfN/ePT8arTW gPzQncBwSKhxLUioC2OOhop4iHIOQ3uKKWpWhmBg33sE08bc/dOfcU1UYAYXI9KkCvtGDVnOOC55 wfzqdVXHH1qBQQeTgVOMcfxUCJfl24prgmLIfaADn296QZzlsfjTiYyuJFBB7EZFIENUptUoPlxw e1OwWxt5p7EbeDjNMz8ny/nUtFXIJSoZR5i85zkVia54dh12zWRHEN9Ccwy9/wDdOOcVtSK4OS4H OAKIbaUyBy5X0wOCKjW5Wljzq9vJtJkW9QXH9px4S4hnIJTssgOBuXkj155qhZ61NO2oxag7SLqi +XL5jckj7rD6e3YmvUdU0Gw1a3Ed4hZ1+5IPvJ+Pp7V5dqegSaV4jt9PlSWW3mbMUsUe4kdwB6+1 aJtIyauzsbuzg1XwVp96JUS6l+QKTy065DgD6qc+3NYw1Hfotq0x/eaZcRy89fLDDI/DGPyqfSIx p/iuSCHUrmwF1Hm1aeEFWJwHUqw74U8EZxUfiTRZ9MvI2uCssd9mN2gB27jkE47Ajn8DVaMSbTO/ aPn5G/wrlNZWOPU79ZCF+0WGcse6Ngf+hVyl/wDFKSx02C1trKVrxEEchKb2MgGGwM4xnODz9Kwb a21rxnrFvp+uSTWl9Ddeegk+d0VU3bWAwASccADHORmpUbaspyvojiLi8tLRpBLLkoxXG054OOlZ E/iSQEi0gCns8nJ/Kvo7wj4Y0KXQ3v7uytnllmmWVrk7lHzkcA8DjHOM15n4/wDhZa2gk1jwjcC+ t85ks7cGRo/Urjqvt2raMo3szKUZJXRzWg6ndzeENeuJZnM8SqUkHBTnjGOnIrpPBnxNimK6V4ml VHY/u73GBn/b9Pr+dcb4bkc+FvE9qY3X9zG/z8ZIJH9ayPDnh++8Q6ubSCWKJY4nnkds7URFycnt 2H1IrTlTTM02j6cCb14YHcMhhyGqlfXj2GlXdw3WOM4+vSvGfC/xDvtAvDa3e680rOBET80Xuh/o ePpXpuqanZ6/okD6RdLcQTtkleowCxBHY4HSpV4bjaUtju9Pf7La29tvBEMaxg+uBjNbEN2DJjdk CuSildCQeoOfrV23vSGCg8HrWsZGbVjb1yYL4ev3zjMDjP1GP61xemxxLCsoVRJtCFsckDpz6cmt nxFd58LXQB+8FUD1y4FYVgXuLiCxiTc7sBgd80pscNzqNC8M3HiG7YFjFaRjMkp6KP8APaunvNPt bS2WysIfs9sOgyC8v+0xHr6VuwPBo+kpYR7GiRMybRgzS9/+AiseRjPIZHOSe/pRCPVlSfRGRJaK CSF5J5J6k+9UpbZkYADPrXQtHuBGPxqrLADkGtjMzIXRQY5VDxtwykdRXK634d1rT5zq3gyVbmED MumthXzkksh/iPseeOM12PkAS5lQtH6KcH86g+aFwVOPSpcSlI53wt8ToLmU2d6XtrqM7ZIpRtZC OoINdN4pk0/WdHW/SONrqMeX5o+8I2yCv05rA8T+F9F8WRbr+E2mpov7u9hwsg9M/wB4fX8CK8wu 9R8X/D6X7NryNqeiSHYl9FyB6BvQ/XH41nYtNHrngy2tbLS7qGNNv+mWrdc4XzOf1A/IV7pHMCM5 r5k8NeKLC9ikezuVdZlHfkMCGXI+or3LTNchuoElRwVYA0Rtaw33OwV81Jw1ZUF4jgc1dSQHoaok hbTvLcy2En2Z+pUDKN9R2/CvN/iXdXF/qnhvw9PD5TzXW9iDlSMhAQf+BNXqgcV5dqKRa58eLW1k xJFp1upZCMjO1n5/Flpre4rHpyCS3jVU/fQgYAH3gP61HfxpqGjXluh3ebC6Y9CQaqy6Zdx3tvc6 fqUsMURPmWrANHKD2yRkEcYwfare6OV/nDW8/r6/0NQM5v4d3Hm+F2hJ5gnZcegOG/qa7GuB8Fyr p2ta3pcxIEcu4NjjhmXPt2rvQQRkHINA2cT43zPrPh2yHPmXBJH4oP6mu3riNd/f/EvQbfqI0MmP ++j/AOy129NiCiiikAmAaY0YPapK4bx34ybRIBpel/vdVnHAHPlA9z71cIuTshNpK7GeMfF/h/w8 ht7sfa7wji3jwSP949q4fSNU1jxHctLp3h8taA4Lo+Av1LcH8KpeCvA9x4s1STVtZdzYpIS7Mfmn fuAfT1Ne8W9lbWlrHa2kKQwxjakaDAUfSt6sKcVy7szpzm3fZHmVxaXdqo8+Ex/qPzqAHccDmvUJ rSOVSroGB9RXO6h4Yhly9sTE/t0rglS/lO2NVdTjmGOwpmdvU8VcvNJvbV/3kZKj+IdKoNGehrBp o3Vn1H7sjApu5lzgkZ4+opNpQZGeKTIxgnmgBUxnPKDuQMj8v8MUFyFLMpAH8Q+6P8PxpmSTt6e9 PDMnIGD65p37isKHGODWR4jvxY6BdSK213XYuPU8fyzWsw3szBiGY5OAMfl/+quF8c3REttYghgo 8xtp9eBn9aaVyZSsmclCXjiJXB2DP4npVDxNcvaeGJlTP2m+IgXA5IPHH6/nWgiOfLjQ5Eh3HHrn AFR/ZG1r4hWOnIN0GloJX7jzD90fyP4GuqKOOPc73wHoK6N4ct4SBvVdpx3bqx/Pj8K62a5itrd5 n6IMkUyGFIYEiToihaztflCWKRDrI4H4Dn/CuWUru52wjypI5+/V9eumgUm1FyRG7Ifm2dxn6Zrv YyI41QdFAAHpXJaDCG1EyN0jU4+p4rqgB6ZxSux2RKW545puM5OcHvmmg85pQdx54pgGQeOB70u0 twx4pegGBmgAfQUAB3KcqMj1qaObaemP5VDvx06e9N81ckYzTuFiy8ccqZfhx39aKrrKq5OCBiin YWqMYDGAvfuaXaobA/PrUYypznrT/lVgWYY9qRmSADH3sVKseQDu596ZGwJ3KM/pUwfcM9CKQaiK vOScgU4JgbsEUR9RlefapxE7EAZ/EUAVAWLFVOT6UOr7B8pBzVtreONSZZkjI/vNisy81mytlCQz xTvnlVYk/wAqWg1cvogxxj/gXWp41bGMA896zYNXlnlMdrol3IoxiR1Ean86t/8AE8dlBitbQN03 ZdvypX7BbuSTvPANy2r3K/3YhyPzNUtR0631WxeC8jECk7ldzsaNh0I9DVx9JvZlH2rWZyDyUhAj H+NPj0XTYzuaIzN1zIxY/rT1DQ8q8U3WsrJaWDPBJcWxZodSjYE5x8uVIIyehz7Vs6Pe6r4m8MOm p6VLbRgZiuS6yAkHGTgDByORgCu5udK0q6hEM9mjxA5CAYXOCOn41xmrrqnguSSfRdsmlXZw8Uxy IJDxvz2HrmjVCsjkb1U/s6/0i602KSZZPMSVlB2K4O4c99wbB965LwndW9h8QNLs47h8POsBRZOV 3EjOeveuk8Szaxa6VLd3VqY73y2idQch0JG1g2BkggdK7nwD4E0JPA2m3Hlo+qXCrdzXBHzmQncB 7beBj1B9aduYlNp3JvDcOn2keuW9+Iwtresd0p+VUKLgnPHUNWqNVmvFEWh2LSR/8/EuYoR9OMt+ Ax71iJYQWfxAuIdUWO4kuYBLE8qjG5WPQdM4brjPFdU8hHBOMCok7OxcVdJnmXjHwXbWukaprULK dQvk8qZIYxHET1BC9QcjqSc5rzL7Hc+CvhzqUl9A9tq+szGzSNxhkgQ5c/8AAm4/CvbPE+q2OoaB f2llI1zJHGzM8SFo0IHQv0z7ZzXM+KtB0jxqjXN3qVw12Y8WNvaxh2Vf7zD0Y88lR71rCdl7xnKF 27Hzizc+9dz4e1m60LwYNStChkTUPuuuQwKAEH6jNc54i8La14Yvha6vZtCWG5H6q49iOKvRk/8A CtJMdFv/AP2UVs2mjFKx7j4f8T6XrUjWMbiC/t/laBzy69iPUVvmIhldAcZ6V8x6+91p3iJZ43eC fZHKjocEZUEEGvUfBHxThvTHpniSRYLnhY7zokns/offp9Kys0ro00ejPQ9S8y5sBbL95nBPPGBk n+VQeELhV1i6umRla3JRN3c9MitO9gWazdlcjjflTw3f8RXN6RIUjbH8cp5/GtFJMzcWrnp8N81x 88jZA4UH09fxrQiw+AhA4zzXKwSnYqqfujArVtrojbk81vczNsOpchQVHbPWgoAuTg/XvUCTCQAs eRU4kUnDkbcgD6mmBGtu8sgWJQzN2xXP38t415PZ6QIZ5BgNcMCEg65Gc/MemMfoOa6y+w5fRtNk IIXN7dL/AAD+4p9f/wBZ7A00tbaCEW9ugjjX7o/qfU+9K9yrWOOt9D+y3LXlzdz3d4wwZHbCj1AQ cAfXJ96tnyyrxXESTxONskUqBlde4IPBFdA9sMnjNZ89p82cde9VZMWqPL9e+E0bSPq/w/ujY3I+ Z9Okf5GP/TNj0/3WyPcdKwtE+I+seHtROl+IreWzuIW2uJFK4+oPI/UV7D+9hfchIx3qnrmh6D4w shaeILTdIoxFdxYWWL6N3HscioatuUmbPhzx1ZajCjpcIcjs2a76z1aOVQQ4NfIet+BPF/gK9F/p M0upaWWys9spOPZ0GSp9+R79q9t8KT3WqeHodd0S5lns2JjaG6TZKkq/eTjhj9MUtSj2aK5V8YNe f+BV+3/EPxNrpwyu5jRvbdgfolQReMI4rC6kZik0ETNsbg5APFTfDYra6HNIx+eaXB9woA/mTTA9 SV80kipKu11DCqUVwrAc1ZWT3pCOUint9P8AiDLbLZn7RPF8sit/rFwGO4euQeRXUROjEm0kCOPv Qv0/Lt+Fcf4kYWfjfQdR6K0ixMfqSv8A7OK7Oa2inwxG1x0deCKQ2ccshuvi6m9dht7U8E/7P/2d d5XAWH2X/hONSucS3M8UZimRhxjKgOp7fcxg/nW5q2vppGjy3kUyTEYRI5jtZWPTPt1/LrQDOjor yO28ea5eT3OyWR4rddw+z2m7zeRkDPTjJ/CvR9B1i31vRoL+CVX3KN23se4qU09gaaI/EmuQ+H9E lvpMNJ92JP77HpXk8OkX99exQSsX1zWP3s0jc/ZYD/IsPyGB3q74n8RWmoeJ3ubgiax007YIM8Ty +/tnr7D3rtvBejXNvby67qkhk1LUgJHyMeWvZR+GP0HauyP7qF+rOd+/Kx0em2EGl6Zb6fbLiKBA g4xnHf6mrdFFcrd9TZK2ghGaaUBp9FIZUltlkGGUEe9c1rek6Va2kl5d3kFhEvWWVwij6k8Vi/E3 4p6d4FtPstt5d5rUi5jts8Rj+8+Og9up9utfI3inxjr3ivUnv9a1CW4kJ4TOI4x2Cr0FejhsDPEL mlojGddU9tz3e5+IPg6HVn09dbinA4E6I3l5+uP/AK1aMviDQIEt5JNZskW4z5RM6gPjrjmvlHez fNk8cfWjzioO5uD69K7ZZNSduWTRCx0+qPr4PHLEJEcMjDIKnII9RT1X5fvDjvXynoXjLU9DuFXT NXnhReTCP3kZ/wCAnj+tfRng7W5te8J2ep3T25uJQRKsHRSCRjB6HGMivFxeDeHe90d1HEKpo1Y6 HPqM4ryPWtSbUdTmlyfLaQhD/sg4H6V6Rrt8LPQ7lw+xnXy0b0J4z/WvLnhcOTCpcgZwK5ILqVWe lie1xDNJdSMpihUuW7AAcf1rM0XXn8NpFrt1Yuz6rM0/mP8ALGF6JGT/ALvPBB571oXdmZfDcwe4 it4Z5Fikd2wTGOWCjudoPtz1qv4t1L7bo2l6PYJDZxTfdkuE3bVGCTjoD0x6VrJ2RNONz07QNbGt 2qXBVYy6B2i53Ju+ZevUFSDmq2uzobpV3ArGuTzx/niuU8G3ZW6uLZrVLiSVvMAt4/JlhDcnLAbC DkcEE8DBAxWte2Tajc3Vpb3iTKVVfLU7JUXoWIzyOexPFYNJ6o6E2tGdJoEY+wvPwPMbg+wrbzkc c1S0uyhsNMgs4ZGlSNcb2OS3qatjCk5PTtip2GScjGOBTtwzycfWmZzxmmTxyywMsM/kyHo20MPy NAExbHTkUm7PbmqtrbNbg75WZiPmXOVz6gHpVvjHApgROoJ4qPvipjnnApmCMkikUNyR15ooIxwT x9KKYGSkcz4Rc09oxCAZpUUe7AGqMekXk8hN7r8pGOFhjEYP4nNTLoFimBPA8pPUyysc/lgUjPYl bVtHtzh7re391Rk06TWGeJ107RLyeQqShdPLQntksQKvW9isMZEFvBCOB8igGpzbSorNu355wTmh IltFCJvEElrGZEs7IlQWJO4hscjuP1qxHpV9cbjcazK49I08sfrmrtvhzhmA9RjFaKAL0IwKdibs y4vDelphpoWuGPVpWLfzrQtrGC33LDbxRjt5ahf6VOCcetPLggHp+lOyDUjwqcs20U2WVWX5ULMK VmiPZQTyTUbOmeDn60rgMDyEDcMUxmAGcnmhpTnAPFRM4YHnOOvNTcqw1pMEgfpUE0cVxbvDPGrx uNrK3IIpW6nHFM+YHAXiobLsed6v4el065DXl5e3OhrE8USI2Vtd395cEke4OR+lb/g++VdFhis2 xLZgRSJvLbx1Dgn+8Ofrkdq6kqHj2tggjBBFcfrujXWjE614aQJLGP31vjKyp1OB7Hnikmwsupd8 XXCtcaRrkNr57wzG3ki3BdwcbQMngcnP4UzUNEv4Y3m8QCW9iVQVsrZsRg+jZI39erHHHSucfVNU 8XabGsGhXSREnMka7EJGV3bnwCBzwMmvTvDetQa/4ctze7RcqvlTZ7OvDfyz+Nbq09GYu8djidQj vhpbx3cNvZ20yeVBZQDcQcZyzcAYUHgDHuaueFre2h8Lae9raxwiSBGfYoGW2jJPqc1cmtlury7l t9slpaBrdQGyQ7AFj7YG0fiareEpFPhuOHOWtpJImAPTDnH6YqJxsrFwldtkur6JYeItKl07V7NJ oWJ288r6MD2NeDeNfBcvg/wpdWKXAuraW6E0L4+YLgDDe4xX0Vd3lnY2sl1d3EVvAgy0krhVH1Jr ynxR4z03XI5G8PRpeyabKqHz4j5UhfIAwcEjr6UU20wqJM8W8ZZaXRrjr5umW5z9EC/0rmA2K9N8 R+E9Z1bTdLksLVLqW0smaZbZlZQokYfLgndjgYXNeaMjRkq4KsDgg9q6YNNHPJWep6V8O/G+rwX0 Phy4f7XZXAZIxIfmg+Un5T6cdP5V6DpN7HNY7kYNscnjqK8a8AqP+E703OOr/h+7avVdFtpjYXGo +Gj5si/8fFhMNzhf76/3vfHIqJLXQparU761nkMWT8jc4PY8nH9K1be55McnyspxXFaF4ls7kCyu VENwo+4TnI9a6peFDqPOjPfPIz7/AOf6VSlYmUOxvR3BUfe4qdtUFvYbkiWW5nbyYEcZG49/w9e3 XtWAJ9kRYtmMd/Smafc/atalmckpYoIV9PNYZb8QCPwatk7mVrHaWiC0s1tkcsSd0sneRu5p+Sxx VKC4Gwc+9WY5M5xjJrRCvcnC8YGaimTdwKlQnOB1qRoiT0xTAxri1OMLkVSezfaWQAY5JzXUR2od JJJSEhjGXkYcD29z7Vz0+nf2rO1wFa0sXwPkOJLgD1PYe/5epXN0HbqUrLVAsksUMyTqh2SKDkDI 6EfQ1V1nStUu9GktvCOqrp26c3T6dcKDBNISCSrY3RkkZ4OM9hkmtU6fBbR+Va20dvCOixqFH19z 71VYSxvlM8elJxuNSscSviy91GWXw74k0aWz1yIK26Zfm2Bhkhx99SM9fwJrutCbVLbT4ZbMJe2z Dc4hPzRE84ZTz+PQ1i6/eteGxtZlXzULMr7csOi4z6Hd+gqpp3/CS/C+w1iSwik8R6RqDqy3Qb97 p4ydxZOSQM5ypxxyBWdrGidz1PTfEMUp2F9rqcMp6g+ldLb36SDhq8okls7lY7u9BtpnAK6harlX yOsiD+Y5rQt9U1HS0SS82XFm5+S7gO6Nvx7H2OKSkmU4tHQ/ELe2iW99Af3trJuXH4N/7JXdwXCz wRzIcrIoYfQjNea6rqMWp+HZolcN909ffH8ia6DwpqwuPB+nSufmS3CN9UG0/wAqoki8GkTeJvEd 0Tnc8ag/VpD/AFFZXxB1mzstQisrnTxcWSqJJiCVZHJ+XY3QHjp0OeaufDuWN7TVZRIrSNdDcoOS BsXGfTvXOfEaaebXnt4YZLiNVi3ovzAFgwPy98jbz7CsqrtG5UFdnP2Vvf6fa3Gr+FL9tUhQeeIQ MTxtgp88f8QG9juGQdp4FdNpet3mkfD67v57WC0uL1zHDHbdIyeu7JzuArhdPsWPir7Dp94tnqDT J5SWspkICggYK8KMvISCcjjOa9C8UWGk+JvEyeH52vI7myj3LfW0gBX5cuHU8Ef1NRh0pS5mh1bp WRyvg3RX1zxXbwzITbp++kyOqj/E4FfQYAAwOBXm/g+xu9Im1DUn+zTwXEgW3ls/nXyQPl3LjIPq RnpyBXfW19BcquGALDIwQQ30I4NdtafO9DlhHl3LdFFFYGoVwHxP+Ilt4E0AGEpLq92CtrCf4fWR h6D9Tx612mo6haaVpdzqV/MsFrbRmSR2PAAr4W8deKrrxZ4uvdXuGcpI58hGJ/dRg/Ko+g/rXoYH De3neWyMa1TkjfqYWqand6nfy3t9O9xcTOXklkbLMT61lyMGJcL+A6VI0gJHHA9RSMQIfl+YnoO5 NfWWUUeXdtlR5FRSW49h1NUZRPLtMqsoJ+VD6e/qa9f+Fvwd1H4gXZ1C9key0WF9slwB80x7pHn9 T2/Svq/w78O/B/hS3WPRdCtoZAOZ3TfK3uXbJrxsTj4xlyxOqlRctWfnbMGtIc3AkikZgVRkKkqO cjPvivQfgprWoQePxpyzPJaanE5mRjwrqpYOPQ8EfjX2v4h8HaB4msGsdb0u3voG/hlQHb7g9Qfc V4q37PyeGfGlh4l8IaiUht5SZbK5+b92wKsFf6E4BH415dTEKrFqaOuNLlacWZnjvUHW8s9NhPzc yv8AyH9a5iBnkmwM7SOR/Kn61eG+8Q310OV8wxp9BwKs6PZvLcxhx94559B/9bNeZBG9R80iW901 y+nLEibYgTK784B5OB6nj8qmg8Ff8JNqFvql1ctBp8Kj7P5Rw8gPU/Tp+VakVjPe6jcxzspglxGi L265NdtBBHBDHBCoVI1Cqo4wAMAVnKWtzpjHSxDa2NtYQ+TbRhBj5ixyW4xkk8mvPvCcI1Xx1qmu EfuI5GSEDpgfKCK7nW7h7fR7p04cxlEPueB/OsnwZpYsNGwuMk//AFz+ppLa5UuiOrL7+HXdnuDh vz/xzTMMF+Uhsds8/l3/AApDkkEfjSgEHINIdh2cE5JB6FTUm7I5HNMadmXbKBJgYBPVfof8aeqq wBikL8/cIww/x/8ArdKPQLjXlSGIPI2FzjJGacHVwCCCD0x3poKsDg5FOyNoHT0oAfjOf84phU+2 KN2Kdyw4pgQ5RwdrA49OaKUoA33RnuaKRRCEcOGVMKBkjqc0jXE7zBPIIJ7nsal80KOR19Bmk+0O ycDAHaqsc9yfzwq/MByOQaY9zmH5EKgHnjtUYOWyCOP0qMuVzjJHT0odw0Brpd42qc9zViK+yNrg Bh2FQYHAIHPUVFIGBygxmod0PQvDUcOyqpJHZuKnjufNAJGP5VlqmcSEZapwkwYtGSOOhNF2OyNI 7SOCd31qNlY85H40yHeFyx5qRySMAZ9OaLCG7dvAaoHAIKmnySKpC9SfSm8Hr19KllITPQE/pS8Y 6gZ9KeVJGD0pCn90ZxxipsO5HjgEc0hHc9KlKuB7Y7UiruGScUrDucrcWV7oF7JqWjQmeymO65sR 1B7vH7+o7/y5HWdak095bjQZc2epMXkYHDQyAYK4/hJ9/QYr1goAMhq5vXvCmm6qskwQW9zICDIg +8e2R3579aa0E9ThPCPihtDubj/R1lNzHultjIAPMIO1iTx14J9M10+hWd7FfeIIrC8gmnVkmUp8 8D7lI3Lg5Iyp71xmkeGb291q702fylkteWilcoZVPcEA/L2yK6WHSxbaxojPDdeHEnD2rLZzAbH5 KcjIILDp/tVpF9GQ11RwmqW3xE8ReIZtMt9NMT27ANfXJBVAehQ42r/wBd3qTW/a/D608JaIJ7m7 bUbq5uIGu2kGY2w4yAD1HJ5PWvRbnQPFtg32qz1C11aMdRLH5UhHoSOD+Nc94h1Wa90K8sLvS7iy u1QupYBk4GfvCm072Wwk1bzNhYxD4wUKoVXs2wBx911/xrivH3wosvEiy6powSz1XBZl6JP9fQ+/ 51o/8JnZ3njGylhyLFInUyLGXeYsvAUAZxuA+uK6Mf25qx+UNo1n6sA1w4+nKp+p+lZpuLuaNKS1 PmTwnpl7pnxItLC+t3t7mLzQ6SDBH7p67TwpqL2uoIyMVYNjIOCPT9a9V1bwpo8UP9pR2QF9alpI 7vcTI5I2nexOTwT1rxm2dbS4dpmEQX7xY4xW3NzamXLyuxJ4kW7t7qe6SX5o594kB5ZW5Bz6810n g/x0vnJZau4jZhhZv4X+voara5aRat4VsdZ064VoZ2MMpUZBxnj25B/SvHL/AFG8817R3EQiYqVU Y5zVqPNsS3yn1jfywx2AnV/kJHA6Nzn+WayvC7zNpLTygiW4nlmkVhg/fKqff5VWvJfAPiW/fQNT t9Su2l0+wjV038lM5BAPpjPFex6NeWGoactxps6SwKxKFD/C3I+h5Iou46CspHQwXJ4GeK1FmVWX DA4AOfesSJSSNx57SdmJ7Y7f/XFEU7r5qvndGOvTdW0ZXMXGx00dx5rFj97uavxSCe4htwwVpDjJ 6cDJP0ABNcrpt6Z7RJXURu45XPSrdzeuY4rC3IW4uzt38ExoPvEf59B3rRvQlbnRXE1vqr+VDkaX attA/wCfhx1z7ev5etIV35Y9KijMUUEMEI2RRrtUegFXF2nGeB2xRFWKbuU5YA/GOtU5bRRW1NGF xg9aqtGMFduSaoR53exG48WrAp4jVRweh5c/+y1vRXNzZyfIxX2Pes7Ro/tniXVLzqod1H5hR+im ti4twil3IA9SelJK+4XsWoHs7xNqKkMn93GFP4VnTlNC1KykWQ20V1cLFOgwY2Q9SQeDWNeavb2e fKbzGHTHArKuL/UNdi8ifzWiU5ULwornlBJ3R0Rm2rM6LxnrXhuyeWDQGLbBgiEDynBHOD2wfY15 pceLNRn0s6d5zW9mpJEUbHDE8nJ78k+1ac3h2/nUpbyIxPRS2Ca47WLDULC5+z3qyxFRgI3Qd8j8 6adw22Pdvg/drD4TuJGwGnu3Y++FVf6Vf8Wr5evNrEskUFvDELgF3ANw6KR5YHUnkYAHvXPeB/Du pwfD/TdVsLhg0wdjBKMBzvYfKfoBV66u7PxFZLp+os1tLE+Q46qehH405xUlYUXZ3NH4U6WkUep+ J72FBcTOwVhyFXqwB781R066lbTfE/iEkma6P2SL3Mjc/piuxvNSgt/Cd4luQqx2rKgXjHy1yWhq r+H/AA7acEXepmZx6hP/ANVaU0oqyIk3J3PWNP0yC00e0sR8rW8SoHXg5A5P51WutNYMZEdoXJyZ YxlWP+2vQ/Xr7itFJRxz1qdXFLzEYa6teaYcanDutu1zGdyAe56r/wAC4/2jW5b3VvdwiWCVXUjP BqMwgNugIQ9x2Nc9c6daw3cqaRfJpGqGMy+UvzxsCT85iz0znJGPeluFjxr9oXx5vZfBOnyHamJr 1lb7x6rH+HU/hXzc7EkAtn3r0P4g+B/F/h241DW/EKHUo7iTeNRhYtGxLfeOBj1GDg+gOK80UsxI IOR1r6vAumqXLA82vzc12Wl2E4APoBXZfDfwHd+PPFyadFujsofnup8f6uMHn/gR6D/9dcSrF8Jk 7zwABzmvuL4ReCl8F+A7aG4h2anegXF2T94Ej5U/4COPrms8fifZQ5Y7smjT55Ha6Xpdjouk22l6 bbrb2lsgjjjUcAD+vvV2iivltz00rCEA1zPjjVRoXgnVNRBxKsRji/32+VfyJz+FdPXjXxt1YtHp mgRPy7G5lHsOF/8AZvyouUmeImI+UMEbm/ma6/w9APsk07SbflOwn+f+fWucihZ5gi4yxwPx4qyL nUB4wt9LhtgltOBAkrDIdS3z4HTrwT7UJaChvc7TwtaxfY0mgd5UG4iRursScn+ddKwzwRivS20S wWzS1itY4oUUKqIoUAewFc5f+GXTc9q3H901nKm+h0QqLqeWeLrtlfTtNVwGnkZ291UdPzI/Kt+x i+zWEMAHKrzXPalYG+8blLiHP2QrGvtj5j+px+FdLyCeSMdKzasrGi1dyUuOmOtIXYtg44qIbgTh sGlyejjB9akslPzLjOBTclSccg0D1zQSM+4oAlDBl+YEnsc8jr/jUyRedxGxMn904BP09e/p0qqP rikIPXcVbsc07isTEEMVbIYdQRTlJAPODSJcSbNsqq2R/EM4+h6jrQi7pAqEY6neQP1otfYL23FO c8mikzggFcd8GiiwymCQduOP5VIpJ9waiAEbYUcdetIHLchcCmc5MRtYetHQcn34qIyFTgrx3o5b 7j7RTsK5Lgk5A6frSk8cLz19aaSwXGTSZO3GeaTGiaMkqRyv4VKm4EDd8vTgYJqCMhl9c9cmpUDD gDA+tQWWUIAwOe2KkAAGMZAqujuGwfyFOLMVIAJHrmncQvlbU4IxTkwoIHJ9aagZl3N8tOVGU4Y7 ifWpGIx3dBgUoBAIOc1NsG3I60GPIwTRYdyHblOvNMIC8kHjrV1VUDAFMdVJPy4pAUw5YZxgeppj oz9COlWdpJ5yRUZXDYAP40mho5/WNBOoGK8tJfsmqWvMNwo/8dPqDWPf351rSptI1CMadrkIEkQP R3XkNGe/I6da7gBQcdao6ppGn6vb+Rf2qyrn5W6Mh9QeopLQGJ4b8RNeaVbXMnST5XX+644ZT9CD Wf4qvLfUGa0sUUquRNIMHdkdB7Vwuu6Je+HNUt7iBhdW9w+xXkY/uHPG8DO0ORgFsfTFaGjS3dvr SQX1nIqxqZHjljO1gOO4wevStOZ7Ecqepzfg7Tbu28R6ffi2Kwo7QtIe4BZeB1PP5V7MDxyAAay/ CdjZXT67o7BHa3u/tUBPeOQAqR/wJSfxpdYt9egKWlncQWqMSHu5ULtGO21ehPuTgehpuHVDUujI tfvbO20ySCe6SKW4ysSFvmkbrgDvXB23h621bwdDb6tb2Ok6KY1eWRFVp5yP4y5GIwT9T7ittF02 Oa5j0e3n1m+ZSl3qUrhtg7gyHj/gCDHsKf4X0G0u9HstQ1CWS9eMsIYpiDHBhyPlQcZ4+8cn3qNk V1OR8N+GprTR9a0W08+40eZvOsLmZNm58Zxg8kZVecYOTXiHi6yMGs/aQpCzru/EcGvrfXJmtbKG ZBkieNT24Zgp/nXhPxH8Nzz6pLFZQM7yOJ4YwOSH6qP+BZGPat6cu5jUj2Mr4f6TJqvhTVrKKRIZ L24jtxI/3V4ySfwNYOmeMNV8K+IHfTJ1aCM+U8ROY5gD/nBrW04TWHwf1GcgxzNqOADwVwqj+ea8 7zznOa1Wu5ltsfV3hHxppvimwEto3lXC/wCtt36qfb1HvXSzJsiaSPdIOuOpA9B68/zr5d8IXU9r Z31xbytFLCysrqcEHDf4V634T+KFpdzQaVrjrb3rqNkx4SU/+yn9DWTTT0NdGtT0PzDboH4K9sev TFN0e78/Ub2/PKoRbRHPQDBb/wBlH4VBqs8UVkZkxl2y3vgZB/QVS8LecPD0BkQpLIXldH6/M5P4 9RWsZdzJxtsd7ay+bKEB+Y9BnFaSSlDw3tXM6cczby5B6c9BWisziUnfu57VuncyOhVZGjWYkYOc YPPFQXlwtpYT3TcLHGzn3wM1XjvZHi2E4UnOKzfE9wYvDV0qn5pdsQH+8wB/QmmBzvhm7jgs7qCA iScFDKxBwhIzjPc8549RU948874DGZxyRkAKPXFXrKLzYYbdF+baAT/Wuz0bw1aRQf2jcxho15RW H+sPqfb271zOTehuklqefW/hd3jF5qIKxtyqHq/v7CntYSuVWCNYrcZBK8Yx/Ou1u4xd3ksrq277 pIdsH225wMeoFVJYQV2kYA7CtoozkzjTZRQkkktngk8Zqpquh2+v2Ytnm8uaP5opH+bafTnsa6ua 0Q87aptAFzt6im4oFI8O8S+JvHvgx4tA1J5ZtCQh4Y8YikbGSVcAHOSeD09Kj0zxLdarfLeaJetP dyNmawuGxJJnqynufpnPcV7jdQ2WqWD6dqtpHd2sgw0cq5B/wPvXivjj4M3dgr6x4H829iX5zYFv 30f/AFzb+L6Hn61Djc0Uj0ZtX1bT9L+z6tbm3+1RlVVmDc46HBrU8P6tC3/COoSEa2nkUjPqOK+P dV8Y67dTJBq1xeSS2p2hJ5G3RkdsHkEfnXoPw38b65rOu2WhWOnXN5es+83AnGI0HJZht6D1Jyen JpqE1uJzg9j7dttQSQDkGtSK4Dd68kOq6xpenmaS1iup1A+SOXy93r94YrXsPHNgI4jqDNYM4GPO I2/99KSP1pgemrICOtfInxy8T3EHxhkk0i7ltrjTIIoVlhcqytjecEf7+K+n7PVra6iD288cqkfe RgRXwz8QNSfVfH+u3zJ5YkvJBs54wcDr9K9DARTqNvsYV3aB6h4X+NCXbC08T3EumXjDYdWs0DJL 7XNufkkB6EgbsdMVpeK/B3h7XdIgu82Wis5JttXsCZdKuSf4XxlrYk9jlQema+csFsbMn1rqvCPj HxF4VvJJNIvgsbgme2mHmQTL6Oh4P1647131MLb36TszmjVv7s9TR8O6Glh44gu9d1az0u1sJBLE WIuFuCPulQMblyATnHHUc197Wsm+0hcyCQlAd4GN3HWvjDRLX4dfEHXLO6gj/wCEX1d7hPOsGJa1 uxu+YRN1jYjPy9OgFfYtnPCYESHCooChfQDoK8rFScmudu/mdNNJbbGhS1Gr5707dXFY1Fr5f8b6 t/bnjjUbtGDxq/kRf7q8DH6n8a+gPGesjQ/BmpairYlWIpH/AL7cD9Tn8K+WonJUuT85PX3PepB7 Gro9oZ70Mql9vIA6k9hXa6poS2XxQ8KaWFBa1tY/NYdGkaRmY/iSTTvhhpH23WYp5E+SM+c2fQdP 1xXTahH9q+ONt38kJ+ibv61p5Djsz1ErUFwY4beSeQ4SNSzE9gBmrVcz44vvsXhK62nDz4hX8ev6 ZqUwRxngrTU1nU9V1i5jDK7ELkd2OT+QA/OtrUfCvLPbEeu1hkVseCtPFj4TtQVw8+Zm/Hp+gFTe KNesvDehzaldsPlGETu7dgKrlUtBqTWp55c2s1q+yVCje/eoCuTknn2ryLXfFOsaxrjanJeywyg/ uxGxAQemK3NC8bX8lxFZ6hZNds5CrJbr85+q96qpgakVzLUcMXCTsz0DBXL9acM4ywxUr21zGitN A0eRkBxg0zAx61wNW3OxO43HPrS7OOKMEADI5pcH3xQA0Ifoe1SdB2B74ph3A8E0pBwOQKYiYSHC q43qpyEJOP0OR+FFQjIyPvUU7hYrs6gg9KhDYckElc07LHhh8oodRt+Xg1RzijdkkYwemaXBUjLU i7yA3r60As3BJPPWgB4GTknFKJMMVI4x1pBtA+YHPanwhd3zEY7Z71LKRYjRdoC4p5Vc5LYNMyqH g5qYCMKXDYx6UhjkRGBYHGP4j0pQkxYAOox7GlLKEBC5zxjGakXewJYEc4xSsFxGLBwFXnHXtTt2 UyeSOwoVDuOZAMenenKAGwFPWgB0aAKADT8Hg0nzAluBk8d6A5IwaBhyxwDSiNQepNNwg5DDI7Yp Q5K5CZ7/AFoAXCE4zUUoQe+KcwbPDcfSoZXSNC0jKo7EnFJgiGV0AyMnntSByybsYNA/ejcqMAO5 XGajwS5DEc9agsr6hYW+qWU1hdoHikGCMfrXNadd3Gj3ieH9fYlT8tpeP92Zeysf7w9e/wBevZqc dOMVVv8AT7LVrJ7S+gE0TevVT6g9jTJObu7tfDfjnTtQjcCK8Q2sqg8jJGw49NwA/E16QrWer25R tu8j868S1fwTqFnc3cySXGq2lzGI927MsQH3cggkheeFI9cVr6Xrlk/g6TTIblbDU4YGtJIAGGG2 4DL9RyPr7VpGViJRubEF2ZXuItO02SXRULRreDCqzDg7F6sucjP5Zqv4MIOizQnJMF3LHj8dw/8A Qq7nQpdLutIisrV4/LhjWJFXGECjGK4nR7a50zxb4k09BvSKZJxH6hgRkfkKco3V0KMmnZljxQm3 Q5JMcRuj/kwNcv4+sDCtvqkZ2tbPyw7Kx4P4MB+ddD4r1CyOgXdr9oT7W8EkiQlvnIUEnj2xXPjV rjxJpt5PqsaWOn3f+jWcRQ73JUktuON2OOgxxwTUw3LkeXeJRLc/Dm7uXmjmub3UWmkSEfcYn7uP pg49CK8kltnglMc0bRupwVIwQa+ivDOi299a2WmXLTJG164k2OVbKxnIyORnGD3rsvEnw/8ADmu6 FHpX2CK18kfuJoECtEf6j1zWnPyuzM+TmV0fNfhK2NzY6nCrYYmPH5PWTr1pPZXyW867ZFjGcV6A ng7WPBd3qcF/HmF1RoLhfuyAbvyPPSuP8aOX1iGQ877eNvzWtE77ESTS1O28DeIr1vCeoPrN281h YlAjMNzqpPzDPU8dK9f0S7sb7TILmwuI7iEDbvjPbsfY4rwPT/8ARvg3qUwODPebM+oAWsHwx4v1 fwrfedYS74Wx5sDnKSD+h96lxvqhqVtGfXS5Clt27I4k4UZ9x2/lUkFw3ylzgnrxxXFeEvHOkeJr QG2kEdzt/e20hGV/xHvXWFmVd0WZFYj5Cfuj2/nz704ytuEoX2NdZyoC9G/nWR4nvN9rYW+cbpzI 3uFU/wBSKmW4JOOGX1HauX8U3qxTKzlmEcYC7RkkuwGP/Ha25tDFR1O28JQnUL5RKSsQ+aUjsv8A dH1r0HUtVXC20A2tt+UD+Bemfr2H4ntXm2i6jDpmiKd/zv8AMxHUiuhspWKh5jmZzufHY+n0HT8K UYdSnI1FiyvHGOBTZbcY570hlx0NPRvMbk/jWhJSe2/vdPSqc1qD0Xmtp+pGarspI4FAHPTWxA4G CarbpImxzXQTQgjPesm8EUPD5LHkKOppjOI8afDjwj4+t3k1NP7N1ZV+TUoFG72Eg6SD64PoRXK/ CvwJc/Da/wBV1G61K1vrq6T7PGYEbCRhs5y2DlsLxjjHU16Pd2tyGUyptDjcq57VU+wsQSd2aA03 I7q+luZC8spLduaoMQ25X2up4II6itEaY8jA/wAxUjaOxPTg+lLlHzGEkJtHMulXsmnyE5wvMf8A 3zxj/gJFcjrOgaHdXEk2saSYHlYlr2xdmXJ5LMvUd8khvrXpaaHkkFh9al/sFAuFZST25zWkW4u6 ZL13R4bN8M0u7dbrw7rSXUb52+chwR/vqPb0rnr7wb4m0wut1YXBU8brY7tw7ggcgH3Ar3fSdL0a 91C8u9AvjYXED+UbiJQ0Nw38QKdGUdNwwc5weOdw6pFbBbbxVYJar91b2EGS2f6k8xn2bj3rpjjK iVr3MnSi+lj518ByQWvxO8OxyP8ANHfxsVwBtwwIz3zX2/bTpKBJBIEbrjsa8zn8E6PqckV9FDDK 6kPDOm1iO4Kk5/StO3bWNKOxXSdV/hcFD+fP8q569V1ndmlOHJsemQX+GWOYFW/nWgkoIyDmvPrf xRCVEd/azRD1271/NckflW3ZapFIN9jdpcx90DAsK5tUanEfGrWv3Om6BE/Lk3Mo9APlX/2avJbd POKQgZzgfn/9bNX/ABbrTeIfGmoX6nMO/wAqLn+BeP16/jTdFh869TA5ZlRR6sxwB/L86lasmW57 78N9LFl4eN2yYe4PH+6P8/pWZYxif4yXU2Qdu4fkgFd5p1sljplvZpjEKBfqe9cD4WxP8UdZuOu3 zcf99gVXUpbM9Nrzvx7K9/rek6FCcl23sB6sdo/rXoea880hTrPxKu9Rb5obbds/4D8i/wBT+FJC XVnfKsVpaKowkUKAfQAV8z/ErxXJ4j114oXP2G2JSJR/Ee7V6z8U/E39laGNLtpMXV4CCQeVTv8A n0r51mXc5rvwtP7bOatKy5UZxj3Nx3r3z4SeCI7PTx4i1CEG4nH7hWH3F/vfU15p4K8NP4i8U2tj tPkg75j6IOv+H419Uwwx29vHBCoSONQqqOgArXFVuVcqMKFO8uZlK4sIZ0KyRhgfaua1DwwOXtW2 H+72rtcZqNkBFeY7Pc9FNrY8oubK5tHIljK+46VWJBH3frXqtxZQzoVkjDA+ormr7wujMZLY7T6d qylS7GyqdzjiCOfWm5J5PFXrzT7q1kKzQso/vAcGqhUJkHmsWmjZNMMjOc5xRSEcDFFAypHuY8cf U0T/ACDO7Ge1CMABng1TWSWSeUncVDBUz06c/rmqOctCRmKxpyx656AetTBcKVJPXPWmRRYGVULn lvrU6qABnH1oYDdvTLZB75qREGchRn3NOyA2Bgn1qZFB54BpDEVATgjpQqttICgKOpqRVbPI4/Wg KoDbmHPalYBEceWGjjcnHJ4H86nDPhTtG88YzkVAMbSQDx6U4LJgbUKe5agZJ5shYqYxkH6ZqZDu +gpkUDbvn+93PoasiOOPqwJp2FciZvQDHp1oKNncRUnmRKcYyT7Uws5cnJ29hQALH3IwKMqGABz7 UoVgSS2Ae3pTxtA4GKAGbGZjg4pGhJGTjI74qcAbeDUbJJ5gZHG3HII5NJoaK7qRxuxVcp8xIGTV 7aOSRTMZ4/KpaGmVQCCBtzTtmHGDj2qdlwcc80zClhnA4pWHcibaDwDn0ridesX0TXE8V2Vp9ogI Ed9CqgsU7OvuP89a7po8MrAkAdc96gdY5DJDw2B86kcYP/6qQyhZzaato2sWMsMcM6+a04IVXA7s fbnrWTpWv6bd/ESw1S1uormz1W2ezaWNsqHX5h+Py4/Gua8X+CbtbGSDS57ttFlmE11YWzANx1KZ BBHt7Cq66ZpSeGG1Lw7ql5d3dgyTiGdwDDsOcCNQAvvgc1pF2IavqemeKPCljd20l2yxrL5bRpMQ AVDjaRn3zj8awtOtUuDsurj7ZJZILcTSjlnx88g7DJOOOmCKoeI/GRGn6VMGSdfKa7itd+DJIVxG Xx0UZY/UDHTjotIgg1zwnZX2nhYpo0EcyKc7JAPmB9c9ffNW1zLQhaPU4uVY9E8QWlxJhI5r7LY6 KzJsP68/jXdbyVILAYrz34hRzR6chlBjdZFJI9QQMj861LXxZPqmnW1volib3UmiXz2YFIbdsYJd v1CjkjFROLtc0g+hS+KcmfByPj7svP8A3y1eB+IPD+r6hpNv4gtLRprGCCKOV05KHYDkj05617f4 x0Bbfwlf6jqt9JfahKhQyE7UQYJ2onQDj6nHWmfCELceDXVlDKSikEZBwgH9KuL5YXJceaVjx66P kfBOxU9Zrx2/Jsf0rz454OTz2FfQvxD8GzX1p/Y3hmxUC3Z7oW6cZHG4KPXLZxXz5PbzQXLwTRNH Ih2sjDBU+hFaQaaMpKzJrK+urC6jurO4aCaM5V1OCK938C/FS21Ly9M1xlt73hVlPCSn+h9v/wBV eAYGfSnghRwappMUW0faaMsiB4mAzycDIP8An1rj9VleXWESRAGEoUrnIO0Z/qa8y+HvxC1Cwiks 9WlaeygUMJG5dBnGPcfrXoa3Ud1rlpcg5SbdKp9Qc4P5AVjflNNzZ0y6N1rSQg/urbDEeuP/AK+K 7m2uzuD/AMPQGuL057dJJnULGThWYA/r6fXpxWwt08ICv0xkGumMrmEotHYJdAuB1rQikG3g1x9t e9Ocn1rZgu87Vz15P0rQg2k+bv1qw6osa45NUIp9vfmray4UHqetMaYxkXaM568+1YGt6dFbnyS0 t3qF2wNtArmNk4++xB6Drz+R4FdFDdW0Fk2oZE7FzFbwj/lpIDj9D+tV7exeGaS9unEt/P8A6yT+ 6P7g9h+v5Vm9XZFrTU5a30u6tHmuNXlae7kbEkiKzIozwFGOB7nr+QrYhsYgNoAc4rbEkyqQTuHc MMioDHpzzieSzWOdRgSxj5gPT6c07ND0ZW/sxBGCE560R6fEsmZF4I9KtwQXC+YsF+LsMxZFmIUr ntwOmfake7W0SE6sI7CWRvL5b5WbJxgkDrSuFiuunIzHavHbivA/jz8SE8OQP4L8P3GNVnT/AE6e M820ZHEYP99h19B9ePYvHnjCXwppIh0e2N/4gvFItLZRkR9jK/YIPfqePWvkbWfhX4vv5rnWLm6g uL64dppUeUlpHJyfmIxnPvik2w2MPwv468SaNLFDaXxaBTny5BkV7ZonxZlni8jU9OR1YYYocgj3 BrzX4Z+CJ7zUdT/tewKG0CxNDOmCGPPA+g6+9ehyeArAORaNLAfQHcufof8AGsHJXsaRg7XOl0nW tPhu3uPDuqtpRkO5rSYZgc/T+H6iu+sPEzTqEvo4km6fLIGVvp3rw2+8L6rYQcGOYE/dDYbH0NVk mvrEiM+bEw7NkVfNIXKj6MF1YSt+9XY3rWP4qa30zw1d6lFcAsq7Ix33NwMfz/CvONK8T6pFCsUs qygdpBmmeI9fl1VbXTvL8tUPmuFbIJ6D+v50Od0JxtqUbQqLdVcfvAPvZ7H/ACa6HQdVtdG8RaXd 3en3d3Z27G7uRbR+Y0QxhGI7gMQeMnisOyQSIEZjvkbByo4GOufpn862LfVrC00HWluZXhmu2MRC RsJDGowACQFCk7ssCT6DNOBCR7fqnj+3ivW07RFW8u4EE10ZFZUt4/8AaPGGPYHFYfwr1NNY1nV9 STuMNjpkuT/SvBdO8dNDqcVuSi6QZJEexRWjbY/BCyAlvwYnOBXdtpd7JNpy+A9eex2uvnQCYxTJ GcZOP4wAc09pW6GmjjofROtah/Z2g3t4D80cR2/7x4H6kVzHgNY7Xw9eavM2EkYgOf7iDk/99Fqx NRfXb3Rzp9zdGeA4O/A3HHTkdar6lqtyPAyeHbG1aCRUEbSE8MOrHpwSauxN9DzjxZrsmveIbq+Z jsLbY19FHSqmgaSNRvZJp+LS1QzTN2wOg/E8VBd6VfQsS0DEeq810+nwyvplr4T0uMSX2oSCS6cf wgchfoOprvjNKNkcko3ldnffCfw+sVvc+IpoyslyxSEeiZ5P5/yr1KqemWUem6VbWMKhUhjCcewq 5muCpLnlc2hHlQYzSUtFZljSM0hUY6U6incZSuLWOZCrKCD6iuYv/DMbZe2JQ+nauzKg1GyA9qrR 7lJtbHlN1p9zZuROhCj+IDiivTJ7SKVSroCDRWfsl0Zqqr6njTAg7c9OhxUZMpfOCF9aXzCx5yTS iQsckHHvxWQiVGxgck1YDrtAY4JqFCCOmMVI0SNFuP3v5UCHiVEOQck8VKkuSB/G/IFUbe3ZAA1x vIJO4gA9elX0dlHUYqbDLTIWHzNj2HFKiRqhyAT/ADqurDdgZHrnvTw2ThefSmBMrLsyoGfSmiQZ HPzds0iLhjuwCT2p7eWg5GT3wKQxUBzg5x3NTBAykADA6c1VEmVCoGJzxVgLIxUlvw74oAlVAFG4 gU4bBzjmmbVVRltw9KUtGV64piEZsHPUe9C7yMqOtO2ZXj0xnFI2VGBkmkMVd2fnOKceBwc/SoJD sw54XuO4p6yK6hlJIIz0oAcQMZqJzn5hx6VOnlsuVIIHHXNM3KcgDPNIZHkbRjGaiw5lwT8vqKlO Fc4xzTC6g5xgevWpKQjnA4HA45qFYik0rk5MhB6YwAMY/n+dTh1YbgScU3c235efpSAjCDgkbsVh 6p4T0rVJGuWiNtdnpcQNtYj3HRvxFdEAHXkUxYgDycUwPnXxfpV7oPiiRLqeaeKRxLE7N95ew/Dp jtiuj+H3iHxVbzudGsorhJCBcLKcRYHIAJI+b05r0fxd4Wh8SaNJbjZHdRgtbysMhWx0Psa838L2 Ov3utXFgY9O06805fKhjmLsLZSMPIkI++7Hkuzdx2rTmViOV3Om8dXt/qujJJqXh2WwETZeQMHjc dcAjIB49axfCPiDT/DLXui6rfJbos5Mckh4J6HJ7ZABGeOtdtr1pc/8ACJT2NzMboCMFpdu3cw6n HbPNed6VDayhbq6sI9RPk5kgdQTM8YKkcjrjgfStFaasTrF3LHxg1eCf4YT3GjX0N0/2mIAwSK/U kdj71X+DN6sPg+7jcoi2ojMszvxuO7PsAAB+przjxDpy3EKXb6Zb6dJuLhISwIU4wpySOPYDqa4W 7v8AUF0saNHfXEVjdXGZ1VsLJtGRkDrjP0qoUeePImS6nLLmaPpkXV3r/iFJvD+qRW0U8Mga7Cbm EYZATGDxuJAAJ4wc+lc34q+H3h7xF/oHhO3luNWhb/SdQaUtHn+LzXOdzn0HI9q5/SdSsNJ0Tw2u ozXcOlzxtDObV9rFCQcE9duQM4IOPyr3vSF05NItv7ESAacyboTAQUI9sVnUpypPX0+41i1UR8Za 7oGqeHtUk03VbVoJ0OeejD1B7isrGCQRX2F4m8IxeLrE2erxo7Anyp0wDF7jv+FfN/jfwDq3g2+K TqZ7Fz+6uVHBHofQ+1VGomZShYzfD8cktrqACnlUjz2ySa9I1jWf7F8ZW6CQNFbwxRvGB0G3k/Xm sD4dQLPpGpoRu8y7tV5HozGo/Fcv2jxPqMpOf3pQH2HA/lSktRrRHrFteQySYhkUrMN6sDwf8jP5 VpR6lKuIjH5pLjKlsYHcjPfvXiNhq1/ZwiGG4IQcgHsc5rtdG8WxX7ra3wW3uxwGH3Zfp6Gpg2tG VJJ6o9Us2ypKMHAPTuK17aR0G8q3415wNZNo8StbmaMkZTO3dg9CevSvQbPxdot891pumq02xFKm RSpQntz1xV+2tLlM/ZXVzaivQxBzxWhFeKSPmwvc+g7muRiuHWXDAAmn3V61w8OnwMVkum2FgeUQ csf0P44rpvoYpanWaSY7q4OopGsMC5S2jUYAHd8ep/x9a2wA/I61gWtysQSFFCxoAqqOgArXhmVg PWmlYd7krg/dxTGgG3JBNSq4I5NOK8cHg0AZ0kJXoMCmm8voYjEJS8ZGNrjcP1rU8pXHNQSwKMjF IaONvrNZ7iW5eMGeQ/M+MlsdOfasaawjZmEiD8RXcXEGQcVzWsNNarHcERNbhsSF2Icjj7owcmm7 WBXuc8LLbJwNqrzuPG38f6Vly61p8NwbaynjaUNh5CQxB9hWtdaTf61zfyyafp+fltYTtkkH+23V R7Dn3HSnwaFpunRCOysYYUH91Bk/U9/xrGUOqNVLozldQv7CDULWDJmmuDy7NzjNaf8AZccqnIEi HqCKhvfCFpc+IIdbt5GinjXaYT/q24wCB/CeT7VrIWt1EUilcfrXM+aG50aS2OXvNAaHM1sDgdUJ 6fQ1zMJEtzLMcne2FB/uivR9emjh0OeTftZ18tT7muKhhgjtY96qSp28HtjJqk7mFRW0LlpDJIGE YJd8Qxj/AGm/+tivQ5/A2lXVnDGDNBJGgXzIpDz7kHIrmvCts8+vWqMm4QRtcSezHgflmvTNp+X5 9y9aJuzsaUloeN+I/h1f6erX0JivbWIh3kC7JEA55Hek067gsviO080gUW0bJHuHBbCr1+ma9N8V O8Hha/Ic/PHs6+pA/rXH6VpOn6j4Yu9UvAYpEmml85eu0HuOhHFEZ21Y5U09F1O8svEm5AzrvjP8 SnJH+NagvraaHzSizRdCyds+o7fjXinhy7vobSW6kjuntEUKzw8hJD8xyPoQPStey8U3UbiRkV/9 pSUb/CtFK2xnynqTWml3SfIQCe1V4tIksbxb7TZvKuFyA6gZx6Vylr4j0y+kCzzPp85/5aMPkP1x 0+o/KtsXGq2QV8CaJhlZEbcrD2NaqZm4nVw+KNetDi5givEHU42N+nH6Vq23jjTJMLeQT2jdyV3L +Y5/SuKg8RAELcx/XIq8t3pV4vUCq0Yj0S01XTr8D7HewzH+6rjP5dau5ryyTR7Kcb4WG7tg1NFL 4g07/jz1KYoOiSHePyOcUuXsI9OpK4ODxnq9vhb/AExJwOrxEofy5rYtfGuiz4E7y2jntMmB+YzU 8rA6Siq9veWl4m+0uYp19Y3DfyqxSGMK0U+incZ4Krlsd/wqQlYyWLYBqBS4BXIBPfFPXuCDisDQ mjcBAAMj+dTRTMzMm0AfwnrVRI22gxgk+54q0ImC7iMEelAEwUseSAc9KmWMhvnHH161CgDxhj0P QA1ZAUqMHAx1pACBSxGCPpT/ACSWyMKKSMqHIB3cVMgz8xpDEACtlmz7Um5WPIK47U5h83Bzx0NR ys6AMU+XoaGNFguzEbEBTH+eaYu9X3Nt5GSeuPpUJnm5SJMsBu2tUEcl9cL5kk8VqP4kVS5A9mOB /wCO1DaGkaX7pirl3GegH/1qmVUQgbuM9COv51kR2YuJMzXc8qA7gCxUY9PlwD+VaUNvaxybls40 Knh9gz+fWhO42iYh1HyLtUngk00ggkF847VPuJUMPug854prqjA8EGquSRKgOWK4J6+tKqgE5Hf1 pB93acDFNAjkTch3AHHWpuUSho4+BgZ7U1ym0hV9z2qBfnkKGJwB0PY1MwbcMEL9OaLhYrMGC8D9 KQrkDB57VOcZ+6T61G4yoA4GaRQ1QM9cZ7VIPlIxjJqMjByD0pVJySDx3pAKJQzsgJ3LjtxTyzYp hCqcDqaQrhckkv60AGDnb2rwj4reLJLHxva2Vhara39pGJBeZKu4IBwMcFRnvnvXu5Py4INcx4s8 HaR4s094ryBUuxGVhulHzxE9OnUZ7GujDypxneoroyqKbj7u5wnhv4xWN5Atj4pt2tZ2G0zrzG/b kdvw/Ksh9TOia1LawhXKyM0MhOFIPT9eT/vVwOteFNb0gXCXkPnrZER3TRciIno3rtYcg++OtSaf qU95YGyRIRcWyHyW8v8A1i55DAYyfcYJ+ozXrVcDBR9rQd4nJCu2+Se5PpFvP8UfibH4atJ2hs3k Lu//ADyiA3Px69hnuRXpfjf4C2K6creHStvc2qnylZeJM9Qx69uv1ryD4ceIZvBXxUuNau7by7K6 R4nZGyY9zA5P4ivsvQvEOn69aBhKkqOo2spzmuRxqUJJ2sWrVEfIHiO3vdM8HaNa39uYbi3d4njb qp5p3g3x9q3hSUR2z+fYSHMtox4PqVP8Lfoe4Ne0fEzwRBr/AIrj0gymAzxGaGRBnDhGPTuPlNfO XiLQ9U8J381pqsBjZASsgHyyAdwa9bBzpVqcqVXq2zmq89OSlE+qPD/ijSPE9mbvSbvzQvEkTcSR H0Ydv5VqX+n22padLaXtvHPDKu1klXKmvjzwbqt/odxHqmn3DQXrne7jneCc7WHce1ex6p8apIvD KtZaYV1Yja7Mcwx/7Q5yfp2968jE5dOkvaQV4v8AD1O6liYz0loy7F4OsfCGsyW9hcF7a7nW4WM9 Ygqn5c9x6V5bfj7Rf3M2cl5C35nNdT4E1K+1az1DWNVupLmdp5Gd2OT/AKsdOwHPSta/+F+vf8Is 15YXEK6kRv8AsuN2F9N3Td+GK427WTLSvseayy2tlHuuZgp7L3P4Vh6hrD3DbYE8lPX+I/4VU1C2 vLe9lhvYpY7lGIkWUEMD75qsEfr+tWokOR6V4E8Q3moPPpeozboYIDMtyzfNGFx19Rz9a9Q8M2sN tb3ksjQ3X2tg3mpghh/IV5L4K8K6ld+GdU15J0t7cOlqokHM5LAsFPtx9a9d01bW002Kzh+WONAA w6/X8avkvqJSOpFy3ktuG8bRtYn5t3Tn1z61R0W4FzrN/c7iVtgtojehwGf+afkaw7fVN1nNIk29 IQSQRgg9hVnwhKy6YWyd1y8kjof4m3HHPbpSTsDVzvILvaxycj1rWtr7BGGziuWjlJAZQwUjkMME VYiuCrDaeK2jK5i4tHbW9yH5zWiJQVBBzXI212M7ehHUVswXI471YGuHpSc9aqRyBu9TxzW73YtH mCOEMz5/hjBwT+ZA/Gh6DWpDcLFFavc3GfJU4wOsh/uishdMee4XUL9R52P3UX8MI+nr/Kt8bb+Z Lwrtt4xttovQf3vrTnTJPFQtdS3poc1c2QbJxWVLbuhII47V10sHHFUZrUEZK8VZByMkGMkdaqyF JE8uaPPv6fQ10k9ocNtHFZ81qGXDKBjnJqJRTLjJo8/8QEPf2+nmTzI0UykkdD0Gf1/OsoW+HW3y CrOSWH90cn9APzqWecXWoz3Q5E0hCf7g4H8qltraS8uZYo8b2AtlJOBk8sfbggVhFJPQpvmd2cvq PxFv/B2u20tnBFOl0hluIpBglC2FAPY4Un8a9U8KfEvwv4qgVbe9Fpd4+e2uCFYfQ9CK+a/iPb6h beN7xL21aCNdscGejRqAAVI4I4z+NckkxVtykg+tN01JF87iz7a8TxLN4fePeNkkkfI7jeD/AErA F0um+AbG3SHzGv7gx7AMnaXZmOP90H868c+Hfi3xDcyyaVdX7XFhbxiYLOc7MEADceg5PFei/wBq R6mmnWVlki2zAjgkFyxwx+hrJx5dzRTUtT0Dw5bQWmi5tkXbLI8jFRwSWPH4Yx+FUNW8I6fqO65s iLK7brsHyN9V/wAK6C1t47SyhtIl2xwoEUD0Ap+3b83B9u9Z3d7mqirHk9xp2oaRfRR6rb7IS4Hm rkoRn17V6lZ3sH2VfsrrcWzDBjODx/Wp5YkuIDDKA6N95WGQa5q68NS2cxufD139lfqbaQkxN9O6 1rGfRmModUdGmjWF+zPaahJak/8ALORRKi/gcMPzqG48K6xCN8NtFdL/AHrWXDf98tj9Ca5628RN DcrbatC+nXo4DH7r/Q9DXZ6b4iMe1J2Az0cfdP8AhWy8jJ36nMPNfafKElaW2f8Au3CFD+vWr8Pi C8jx5i7h6jkGvQ4ry3u4vLmRJUYfdYBgf8apXHhHw9d5eO1No5/itn2f+O/d/SqQtDAt9etJxtmj Ab8qnYaZcjllGetLc+BLpctY38VwOyToUb/vpc5/IVg3mgaxZBjNZXEYH8cY8xf/AB3JH407isW0 0CP7a11A/lsPuSROQcfhVttT8YabIhsrz7XBnBScbyPx6/rXG6Zc3lheyKtxKyN/ASGUH2PUfQ10 cHiJ4TtliI98Vd0KzR1Vt43vYQF1TScnu9u3/sp/xorKh1iyuV2yjbmilZAc40LNgDbxxTTCEA3b sgcnPWrCAADGQBUjCMjOMAe1chqUljdc89eatlnVAGBPbnmhY8tuPfpk04KScOOO460CGneAAigE evSngsOG69eBUnlgxg4UYOOeppIbiAzvbpNGZl5ZAeQPpSGKuS+QOTVlAwADcCoFEhdgFAANWAST tx07+tFx2G5ywyOAe1Kyq+QQCD36mpMHG3GfrQqtzgED1xUspFP7MBJ8rt83VicU4QxqPmOD2CDr +dWmjOWLHIPPSqkgQMuDjP3TnpWbRaJI3aKRWwFxjAc9B71OL3dP5aBnyewqEwIvzS75ATgc8U/7 IPM3RsYyB91Bzn60rPoPTqXEkdUJyT7EUjMr8l8AdahXzAQswUuRgYqaO2iiUDjnuTn+dXZkXREw lODGueercVFJBJNMhaUJbrhtqZBdvf0A9O/855mVVPzkY6CmrzECw3miwXJAFUDDZx2zQM4+Y857 CogeeBtzwAKkJG09jTAYwGe5H0prBlwTkZ9qeHG3Cj61GJCx2MnHrUjDaW+Yj2qMEK3U8ce1Ttlf u5AFRFTyQ+T6YpDFVhxg5GO1KSDnANRKyg8cn8qf5jnIA/8Ar0DHZ+6pbBJwM1G0iL04xwaTYfMO T/8AWqQbVQ/Lz6+tAii1va/bDdtapK7RGKQMOJYz/C2RyOfwrw3x18Obnw5dT+I/Dab9J3+a9uvL 2nr/ALye/bv6172SitzjB4+tQygD5SoMbAgg8gj0Irsw+LnQlpquxjVoxqLsz5F1C2XU4TqGnAeb /wAtYR6+1aHgvx9qXhHUAod5rAsPMhPVD3K+/tXbeO/hzcaHLP4i8KqzWIy89mvLQDuyjunqO306 eXvcWV6xe9tTGSOLmDqP95T1r36bjVp+770PxR5sk4S10l+Z9F33jrTJZtG8ZxMby3s1bzFj+8QQ QRz0Pzmrt98KY/F+gNq3i4SXOoahHv8AKjkKrYqwyEQDuBjJPf8AXwnwjYXSXlzBaXkF5p88LbmS YAo/8OYzznqOBX1F4R8dadqllHD9tgkuRGrSwrIGaPOMhh1HJ714tVRpVGoO53RvOOqPk3xj4C1X wXebZY2l08/LFcAcY9G9D/OuftpwwKNjJHfoa+79b8O6fr2mSRSwxzwyrhkYZBFfKnxC+Fl/4YuZ NQ0uJ7jTclmUDLQ/4ivcwmPU17OpucFWg4+9Es+DYLe38I3UgAhjd3Zj2AJUE19AwywtDHJA6vC4 ysiNkMp6EY7V896VC3/CnriUvtM0Uy59PmxVXwD8Q4/Bv2TSdRnZtGldYl4Ltbk9WUdSO5H5e/kY jCyqzqTp7RZ3UqqhGMZdT13xp8OtG8aW7EKtrqQH7u5VeSewYdxXBaZ+zT4sbS7nU9YuLW1SA5S2 D5eZR1OcYX2B5+lfV/hzTtIXToNR0+4jv0nUOlypDKwPdfSsrx9rUtpp66dYxPPeXBCpFGMs7H7o x+v4VyU4uO5pNqT0PnvXIrPTbe08NaWojstNXB29HkPLH361jQXMkO5C3GK9f8VeFtLg8Ove+I79 LXW2iC2tpagFYlA4U92Pqx714XcvIspRwVIPSunmSjYy5W3c05ZWsfCD3SNiW4nAU/Q//Wq54c8Q WUMiWd/cJA7uREWIUEnsD6+1Y/jGV9O8GWbxBf3ESzMrHqzNgV4heX91fXJnuZTI3b0H09K5Hqza 9j7LjIlkRyw3hduQeo96kV/mjEmI5GyoBPDH29M+lfO/gv4pXeleVp2uM91ZjASfq8X1/vD9frXv 2l39pqtlDdW8qXEDgOjqcg1Kk0PlUkaEcroSMYOfzrUtb/kBjg9qyGBhjZ5XaSPfwQBlFPr6gfn9 aTc8TFjyO1bxmYShY7GK8VULs2FUZJqNJor/AFGO3VF37d9xKB8yp2jz/nvXH6nqbw2sNusg3SNu c+iLyT/Kt/QHaLTxcSEia6PmvnqAeg/AY/HNa3voStDtlkDEDgKOAB2qQYb5fWsmG6DKCDmr0Fwf MXPT1qrBctiEMdtOks7dFPmAt+NIJWLEjvUzxfICTnNQyjAlto/Ob5cL2rlPGNxFpfh65m53y/uU A6ktx/LJ/CvQJYUY9AK8h+KF0H1ex0pGDLChnkA7MeFz+AP50pOyBLU4uz2C0eZ1wIV2j35P/wBa sfxTdvpWhW9vG5FxO+XIPf7zfqQK17VBuSNz+7UmV89Aq8kn8cV594h1d9Z1fdApMSjZGuMk8+nv mppR5gbSVzTtfEllq+njSPEtot9a9FZvvxn1B65rG1T4VzxTw3mnX4k0m4+ZTIMTKPTb/F9eBXS+ HPCb2066hqduGl6xW7jIB/vMP6fnXotnpTKTe37uzt0XOP8AIqp2T0CN2tTyC0hg0+IWVpCYIVPz Z+859WPc/oK67wZqFh/wlFodQuYbSHJMYkfG58fKAfXv+Fd1JBo19bS2s2kw5cEbwvOfrXgfxD0f UdGuLWCe2K2py0dwvKyH0z2IHasmuY1Wi0PrJQGj3Zz6EGnfKGIPp3FfKfg74seIPDJjs7uRtS04 ceVK3zIP9lv6GvoPwv468PeLIVbTrsCfbl7aX5ZF/Dv9RXPKDidEZqWx1IRjt3HaD0yaOC+GAyOl OVRIAGPToKkMa4wD3qSileWNrfwNbXkCTxnsw6fT0rmbzQdV0gGXRZDeW45a0lb5gP8AZb+ldido GFFcz4u8TW/hjQ5ruV/nwQozyTTTa2FZS0Kmi+MkWQxLI0TqcPbzfKyn6GvRdJ8R294g2SfN3Unk f418WQ6/ret+KjPbSM09w+AnUAV7lb6Z4n0mxgu932obQWWM/On4d66r2+I5bXb5T6Etr1ZBnNXk mB7141oHjlXKxXjYZeC3Rh9RXodjq8U8aukish/iXp+VVck2rvStL1Ef6bYQzN/fK4Yf8CHNYV34 FsJgTZXk1sf7smJV/Xn9a3IrkMAc5B6Yq0kue9AXaPObvwTrFvkxwxXS9jbybW/75bH6E0V6Wr0U Dv5Hjalgf3iA9+uKmR8EHyy30OagVjG6FSCSOWxuxT2eUvjzfl7461zllwoQNz4UZ9elRFmI2owP v6+1MjuGxsUZUfxHk/jUokhV+24dgaAFjDl9zJgL1+tShVMqtsBwDyByP84pBJ5uOmB196eXwSeM emaQDhnJx0z9akyDggEg96hUscg446GpY8bMN1HekMnU54znilyxODjB7mo9wU8UK0Z6nOT270hj 3BIzu6e1ReWWwu3HuRU25QmcZpQyFs8fShoExqRHAeRguOmRU4KhOG2qeScYzUW6Jlbdj2HpTkRV B3DAI6UthkTEk5jiLdh833qeHAYqzcnggiozAFlMqRszY4Bbik5HDMvqAKEx2JmRSc7Bj1NMBOCN pX8KcjY4YdKgluJUbCqAexx1o8xeQrZYZVST6inRI4H71h14zVlUDIC7YJ7Ck+UHgbiKLDuREYzh ecUhwq5Zhu9qU7jngDB6+tGE+8w4NAEe4kEf0poTcO/FTgjdtAxn2qvMhkAAdkIOSU4zUspCeSM5 2inKqAADBpxwF+XHFZWu+I9F8O2YuNZ1CK1Uj5FY5d/91RyacYuTtFag3bc1yoPG0YHOKrXVzbWl u9xc3EdvBHy0kjhFH1J4FeIeI/jrKUkg8M6f5Z6faboAn6hBx+ZP0ryHWfEOt6/c+frGpT3jA5Al fIX6L0H4CvXo5VWqaz91ficlTFwjtqe8eKPjToenP9l0GL+07gDBmyRCp9j1b8OPevHr/wCIPim+ 8QLrf9pSQzxMDEqcIg/u7ehHrnrXI/eweOetGSPmx7V7lHAUaK0V35nBPEzm97H1X4E8e2HjLTyh VbXVoVBntieo6b09V/lnnsTxvjz4UNLLNrfhOACU5efT14D+pj9/9n8vSvGrS51OxaC+sme3lSRR FMh2uGOcAd+QDX1R4J1e81/whZalfw+VdOGSQDozKxUsMdjivFrxlgantKL0fQ7YNYiPLNanygsL WupwXsUZS7tJQ4BypVlPQ/j2rrNQv7jRdbg8V6DIYY7wCRgPuk9CrjvjGK9i+IPwyg8TFtW0dktt ZC/Op4S5/wB49m9+/f1rxWzLW5uvDGuRPayiQ/LMMGGT39jXb7SniYqtBardeRzcsqT5JddmfQXw 3+KlrrkC287iG8jGJIWP6j1Feq3VnZa1ZFkCksOR618F3EN9oWpqyu8E8bZilQ4Of8a9++GnxbF7 5OmarKIb5flDE4Wb3Hv7Vx18MkvaUtYm1Ord8styf4i+Gk0PwzeWthAIoJI5GSJeFVicnHpknNfL tvN5uuq0vKWqcDsGPevrvxd4lh8Va3d6XHbLJp2leRHcSno8sh3FfoEA/HNY/wASfgnYTrLqHh+1 hsL1RysSBElA6Agd/ejB11Tm4z2bTCvByinHocX8KfiV4p8OavFomkIl/aXr7fskxO1GP/LRSOVx 1PYgfjXrj+PCus6i9pNFcalHiBpiQTFxliF7E8D2Arxnwnp0ngXwxq/i3WbcwX/NnZQyDBDHhm/k M+gNcBBq14l8dQhumS5ZyxkB5Oetd1XDRxVSTp6W692YwqunFc+p7b4h161tIpdS1m/25PMkjZLH 0A6k+wrw/X/F9x4i1OOx0uI21vLIIgxPzvk459PoKyvEE2qatdtf3l09z1wOyD0A6AUeC7M3njnR 4NmQLlXIPop3f0rxatGdKXLNHaqikrxPSvii6weG5oI8hRPDbL9EQsf5ivFAN2cCvd/Geiy+JYRY 2XmvfS3UktvAibvNIIQ5P8IAB5rxrVNJv9G1GSx1O1e2uIjho3GMVzJmklsUFyFwOa6nwp401bwn fB7SQy2rHMlsx+V/ceh965knPakG4HkUbiTsfXfhXxdpHinTxc6dP+9Ufvrd+HjPuPT3HFb0kRXz ZYstuGfLJ4J/pXxtpup3+kahFfaZdPb3MR3CRDgj29x7V794N+KVtr0I0/UkFrqwU7No+ScgdvQ+ 1TZrYu6e50VzcLd6nFGVK/aZBHtb+FF+ZwfyI/EV16Xnz8Eg+lcTYW7Tak18GbNtGYgA3BBI3E+v K10m8SLGJCFkPRgMBj/TPpmt1MxlBs6i2vjwH4YVtWtwHcAkYrhopnUhXOCOjVrWl4Y8iRv/AK1b qVzFqx3EbFYw7cDOOateYWjBDZrnba9MkW3cWI5FaEN0NmO9MdzUbbs3EhfrXzhrmonWfEN/qKMz rNIShPXYOF/QCvY/G+t/2Z4KvHRv306/Z4/UFup/AZrwi3ByNq5OMCsZ72L6FwafqGpadPa6fAZb m4PkDnAVR98k9hnI/KtXRvANl4eiFzO4uNTPJcplV9l54+v8q7vwvY3On6dCGLPbyJnZwAD3Ynuc Afr6112jaAuoztqVxHm3jP7pT/G3r9BSU2tEVyppNnEWGgeRGt7ex/vH/wBXGf5mnSWTXLsrqoQ9 SRyv09D/AENdvqWmR3Mw+1wLJhtyOR8yEdwe3TFQT2ibAoXj6VpFdxN9jiJbHaCqoFX9TWde6dZ3 VlJZX9ql3ayjDRSLkH/A+9dvNZDptxWZeacUGNvvVabE6nz34t+Dd3DC+qeEy17bjLPZMcyx/wC7 /fHt1+teUxzXmnXYeOSS3uIW6glWRh+oNfY4WS3k3Jwfaub8WeBvDnjWJpLqMWGq4+W9hHLegcfx D68+9S0Pc878HfG+9sjHZeJ42u4RgLdRj94v+8P4v5171o2u6Zr+npe6Zfx3ULfxI3K+xHY18ieL PAuveD7vZqVtvtXP7q7i+aKT8ex9jzWVo3iDV9BvxeaTfS2swxkoeGHoR0IrGVNPVGiqNaSPtvUN QttN0+a7nkVI41ySTXyb4/8AGlx4n1xwjkWcbEIueD70/wATfFXXPFOixaddJHARxI8XHmfh2qp4 B8KTeKtfijI/0WIhpW/pRCNtZFTmmuWJ6X8HvBoWD+372PJf/VAjoK9u2jaCOMVWsbC306xitIFV I4wAAOKsZ5yCTj3rnlLmdzaEeVGRqvhzT9TBl2/ZrkdJo+Dn39a55bnXvC0wMp+02uf9ZFz+Yrt8 ZPz/AP6qZJH8hjblT1GOtOM3EcoKW5LoPjK0v4xsmVHPVT0J9xXaW2oxygAkI3oTwfof8a8i1Dwr bSP9q0uY2d36L91qgs/E2q6FKttrUDBOnmDlSK6IzTOeUGj3SO5ViQGGQcH2ori9I8S291CrQyq6 H+Enp9DRWl/IzOWikdGbcQT2BPSrP2iNYgr5ckVGWQbgIyWA9KiUFFfjYGHJxzXOyyW5MuNsbAHG efWord2kx5ysZPUNwfpSlIwUMpd2IyQcirMEalQAANp446UrASoSPvcZ7VZjeN8hcHHy/jVZpNm4 g9eOBk02AgyNIMnd29T60AXUYBvmPFO3YOQDj1qIsSeoAx6U4cDBY57CpZSJxllx0pyKoAUcFeBi mK/G5iaUOp5Xj+dFx2ANwQeefWnLIegUeuajAiGSOpPelYgZzg49KVxjmAUBi2R0yacplYnDBf8A e5qEtuUNs3Ac/SjzHCErEpIGCfSoZRPH5jxswkBYHAHr/hUdwjtLGwiKso5AfH1+tVI+ZSkkmzjc CBtLf41ahT915hZySO/QUkx+ZP5mxgiNkN04/SnZkdP7p6VCjyDhI0yOhA/rUokkJ2tjPpirJEt7 cRBsOXOep7VKQx/iAJ9OtR+YEBIVnOORnigzK4BRdueOtAbkgVB1P50Eg9Bx6CovMRVLMw4rN1nx LoHh+0NxrGpwWaYyFdss30Ucn8BVJOTskG25p4J5UgVm6zrWl6FpzXuq38VrCOjSHBY+gHUn2FeM +Kfj1Kd9p4RsAi9Ptl0uT9VToPqc/SvGNU1rU9cv2vdVvpry4bq8jZx7D0HsK9XD5XUqa1NF+JyV MVGPw6nsPiv45TzK9j4Vtzapnm7nUFz/ALq9B+OT9K8dv9SvtTvJLy+uprieQ5aWZyzH8TVLce1A YBTk8ivoaGGpUFaCPOqVZ1HqxwYk9c/jTHJJGfy9KhluEiUFiOlUJb6a5uFt7VHldiAqqMkmrqVo wWrIjBsvS3Ucf3m5HanWmo2ryZfzpZmOEiij3En25rqtF+E2pXxW41y8NkjDPkxYaT8SeB+teleH /Beh+HCXsLbdMRtM0p3Pj2Pb8MV5FbML3UTshh31PJkt9f1rxjYeH7S1uIXuPKinVAD5UZIyxIGF 7k+9fYWn2FtpunwWFnEIra3QRxxr2UDArgtIW0tNUiuHEcCBt0khAHQdzXQ3ni+xWE/2bm5k/vkE KPfnk14VVyqNI9CmlBNm/cXUdrCZriRIkXpnv/jWV40+E2m/EDwvDrujXcf9spH8sqjhwP8Alm/f jp6j9K5621n7axttXIkikOVmA5iP+HtW7pGtap4P1EGJhLay4LJnKSr6j0PvW1GMqL54vUyqSVRc r2Pmy+a7snm0PxDpzfabc7Gjl+V1x79/Y1k/2Wlz82jXkYuQRtguZBC4Ps3Q/pX1v8VfDXgrxnp1 temT7Nq8kYaKeJfmUMMjf7V8p+KPDV74e1Z9I1lVdioeKZOUlTsQa9uhKFe/s3yy6rocM1KFudXX c9K8C2fiKx8MatF4hnszd38/2pFWcPKxCAHIHHAXPBPevpK18QWGoeGIr24ZWZ4VYDuWIHH5mvhD w9NFoHiex1MqSYnwzsxY7GG1hz/sk17R/a15aRSadFePdRo4kjAG0RhlxtB7jBPPuQK8jFUZUJXn 1O2jJVFZHc+KPA8Xjzww1z9qwqyN9mkhfKoykqSQODzkYr5k1zQdV8L6q9hqcGxs/I+PlceoNfS3 gfx7o+gadLp+p7zYSyDyjCm7Y/Rhj0OP0qfxc3w98Xaa9rcX6nPKlonVkPqDjg1rg8c6Oj2Jr4fm 1R8sRSDYSq8kcgV6D8LtSis9YudLj06033KNM1yyfvlCAHaG/uk44rl9c8I6joepmOxf+0rQ8pND 8xx6MByDWn8N4LpfF2u3txbzQR2untHH5iFclmXJ5+letjK9Krh29zjownCpY9r8E3ulxXhtJru3 XUriBZIoWceYyFnYlR3HPP0rQ8Y+A9J8Z2LR30flXKDEVyigMp9/Ue1cJ4XhtdV+MFncW0BSLS9M 4kP35P4AW7Dl2OB2A69a9oAydwXkfrXyVRcrTT3PajqrM+MfF3gnWfCOom21C3zCx/dToPkkH9D7 VzBDn2x6V90axpOm65pzabqVutzbSjlXHQ+uexr5p+IPwp1DwsZNR0ove6WepC5aL/e9R71UZp7m coW2PLQOeTiu/wDhdZLN4muNRf8A1dhbtID6MeB+ma4Ahi4BBHvXpvhP/iU/DPXtWJw1w4hjb6D/ ABJrVGe5f8MfFL+zteubbVkMmmSysqSoPmhGeMj+IfrXs1tc2lzBFdWksdxaSDckiHcD7ivkA9wO feu78DeJtQ8OWd9do5ltEK5tmb5WJ649DjvUNW1RcZX0Z9JFtsBZy0qA9RjcF/TOOffHHNOO+I/K d0frXPeF/FWleJLEXWlz5dcebbvxJEfcenuOK6HA8ySeI/Oy4KE/KSOhNOM7BKF9TSsrtgAyt0re gvFaNSvXv7VyCY+UqNjMNxQkZx3rQgvFU/NkADkV1Rlc5nGxzvxH1Uz6ha6UjfJCvmOB/ebp+n86 5zSbUT3kSZGA2T9P8/yrRvdKN9qNxqFy7F5GL8HoOw/AUzTkMTAICWkbavqB/nH51ne7uXY9Y0SN tVmi0yEbYFAMrjsor0OSAwLAIJfIgg4MYH3hjgVx3hLy9OskUn97LhpG/pXQ3V+LjhDhB096aiDd yK6ZZnL45P8AnFUHjHJxVvcNu79KiOWHFaWsIzntyTnFVLi3D5yM1uxhOQ4qKW2G0lfyNAHHXNiS ScYrMltNueCD/Ku0nt+Dkdayri04OBnNUSczIIZ7WSxv7eO7tZRteKVQysPcGvHfGfwVDrLqfgty 68s+nSN8w/65sev0P59q9wns9uTg1SzLE+UyKTj2Hfoz4uuba5s7mS3uYZIZoztdHUgqfQg9K3vC fjLWfCN+bjTJVaN/9ZDIMq4/mPqK+lPFPg/w74ztiuqwfZ70LiO9hAEi+mezD2P4YryjTvhPpun3 082vamt1awOf9SxijKDu7HkfQfnUPsx2a1R6Z4T+K2geJTHbTP8A2dqBx+5mb5WP+y3f6V6D553Z Cg56mvj/AMdHwnH4gUeDgyWixgSDczLvB6qWycYx3rZ8IfFvXvDrR2t6x1OwHHlyt86D/Zb+hrnl T6xOhVLaSPqcse4yPSmggnOTiuc8N+NvD/iu3EmmXq+bj5reT5ZEP07/AFFdCAS+C2cenNY2NU0P 27Rnp9KhuILe6haG4hWRG7MM1MXUDZ+pFNwCBnvTA4+68N3enTG70C4ZO5gbkGiuvJx1GBRWim0S 4plGMsj7ncbGHaiQBg22Qjb1Ap4miIEhyGPAGKdKoTEi9TwBmncwsVYnR+Crqf4c9evWrYlUA9Bn 1qv91skbSec5oJImUIp2N1Y9jSbGkWwQw2nHNSqiIMY5HcVGkeGAyDipH3NgDilcdgBJyC3PvUvA AzjOO1QujHHJz3xUmBjJIHbjikNEgdQOhzSkZHQ49aYjAnCDdjqR2p6IxOGbknqakY5dgPBGaYQW YYb5f5U4RYYkkEU4ZZclePYUDETdjG8c+1NaPdLuA+4OeetSbBnqT/Sl2Lj5AuOpNDQJ2GOryAKq bwOoA/rVo7o4NrLwPxI96j3RwwtIsm1ME59PWi2cNbCVN0nmAHJHrSSBkioSiszb1wMdjUcplZlU AIO+09KR7WVySzME6jnkfhXL+IvHXhrwrDINS1ES3OMC1hw8hPuO34kVUacpvligcklds6beCcgl weMM2Kxtf8UaD4agNzq19Fa8cRfeeT/dUcn69K8J8SfG3XdRD22hwppVvjAcANKR9TwPw/OvLbu+ u76d7i7uJJ5n+ZnkYsSfqa9mhlU5a1XZHFUxcV8Op6/4o+OV9chrbwzZCwTkfarjDykeoXop/E15 FfaleaneS3mo3Ut1cOctJKxYk/U1T4wDnr15oGB04r3qOGpUFaCOCpVnP4mOOcY60Dg9PpRkDrjg etQzXUMC5kYFgOFBrSc4w1ZmotkjSbASxCj37VnXF+FYxxtuPqO9b+ieCvEnikrcRwixsG5+0Tgg Ef7K9W/Qe9er+Fvhno2i3EcqQPqeocbZZVztPqq9B+p968mvj7aROqnQb3POfDHw11TXtl7rLPYW LDKoOJZPwP3R9fyr2DSfDmkeH7Arp9gkUUIy8u3LemWbrXf6d4WJxLqLFB/zyQ8/ie1W/FVvBb+C b+KCNIkVF4UYz8wrxJ13Ulqz0I0lFXPM5tWLErbDA/vHrXUw6dKkEEkxwzorkH0Iz/I1wlqhkuEj XkswAFeweII1t9WnhQYEZCADsAAP6UNWBO5x+sRxQ2ErBOMDj15rlrS+unvmRo8QYwAO9dVriu+m uFUszsqgAZJOelbfh7w7p2hxJqGuQreX5G6KxP3IveT3/wBn8/Srg1bUmV76GXoehXWrOX3LbWkf +tuZfuIP6n2FdVcXGnW2nrpunQNNHHz9oufmYn/ZXooqvfX9xeHMpVI1+7FGoVEHsBxXmHiz4n6f o++y0cJqF6OC4P7qI/X+I+w/Os51L7FxhbVnX61rum6HYte6rdpDH2BOWc+gHUmvH9X+ImmeJr/+ zdY0tk0blYrhTm5t2/56DsR6p+ua4XVdW1DW757zUrp7iVu7HhR6AdhVOC2kuZ0ggjeaRztVUGWJ 9AO9ZxnKL5ouzKlaSszq9U0SbS5UjuHS4tJ13W15DzHOnqD+hHUdDXX6HqMU3h5WkfM1hiGTAJLJ 0Rvy4/D3rsPhz8ONYh8N3Nj4rdG068G9NNPzPC/aQN/A3sM57+lcP4l8Nap4E8TsY5YpbR0LwuxA EqZwVYevqPxFex7WGPp+ynpNbHGoyw8uZbMr2Hj5tJ8Sx3SafHLZR5RlZR5gHdhn+VfSXhbXPCvi PT4p/sFhdRSDqYEJHseODXy9dWWma7+90+UWt4RloJD1/wAfr+eKNBvvFfg/WYZNPtLibzpAn2dF LrOScADH8R7VDoUpQ5Ye7Jbplc8lK8tU+p6b4+v7bWPHy+FPAem2sc0BKSzRovzvjLAk8BVGcn60 9LCTSvDl9YTXAu7hYyZboIF3seyjHCDtnk9T1wI/B+ip4Xs3knZbnW7z5ru4zu2knJiQ9xnqf4j7 AV3+teH0h0qxlMoa5v5gkyj7qfMuBx9a8qTTdonUk7XZ8w3vibWfDXj6e70q5kt57dEiYOvEg2hi GXuDn/8AVXvHgP4qaV4rCWV2F0/VQMeSzfJL7oT39jz9a5z4qfCDUpp5te0xjPdjAlh/56KBgEe4 A6ewr5/YT2txhg8M0Z9NrKR/I1E4XHGpZn3UASuFzyaytf1vSNA0Wa+1qdI7VQQUYZMh/ugd68F8 H/G+/wBMtFsPElvJqMcYwlwjASgdgwPDfXg/Wop7jWPifr0bAreSsC0Fij4hs4843yt6+w5NY8rv qb8ytc8+1dk8ReKrqTQtIaCKdy0VrApYgfT9a6vXQdL+E2jad0e5JmYYweTnmu90DwxayzXPh/wz MRbRjbrOuKMNL6wQ+g9SKu6h8OYfGGn3NrDdG0k09Y4rXPK525Ib9K2UlYxcXe582dfXB7mupnsp tP8Ah/aXEkeE1CZ2Vh3Cnb/7Kaoa94b1Tw5qb6fqtq8EyHjPIYeqnuK6j4if8S/S/DugL8ptLNWk H+0QM/rmm9SFocTpuq32j38V/p1zJb3EZ+V0OPwI7j2r3zwX8T9P8RLHp+qmOw1TGAc4jnPsex9j +HpXzqQOeRSA7R8pwfaqcbgpWPs7YjvG8i5ZDlT3FWCQQ6spAAyHXnj8uD+dfPngb4sXOmmLTPEb Pc2Y+VLn70kQ9/7w/X617xY39re2yXVpPHcQyLuR42yGHtUpuLLspaor30pFs6AhZGAUHH3x/eHr 79OT0rL0tpE1V5JVUQRALH67urH+n4UaxLFYrKY2Yog8zYTkKfQfXj86qW63DWMO0FsAFj7nk1qn dmbVkepaVqH2jaqtx1Y+1dNFOGA5rz7Ri9tZI2cueWrpIb7KhgcH3ro3OdHSCdScZqZHBQ+orBhv OxbrV+Gb3oaKTNJSAeeTTiCevNVVkGRnrUysCOTikURyx5yAKpSwdcitMcjNMZSRyKAOemtQQeOa x7u3SJC8mFUdWPSuumhUAk8DrmuY1NRcbUa3WeNzhIXXIkPqR6U7iscnfyFsRRAtv6BerfSqsWkR kbtRRJ0I2m3IzHjvkfxH611tvocdnGfkXzD12jAX2HtUM9pszheP5UrX3C9tjxfxj8GrPUEl1Lwc RBP959Pkb5W/3GPT6Hj3FeF31he6beS2V9bSWtxEdrxSLtKn8a+ypEaH5kJ3CsnxB4Z0HxhY/Ztc s/36jEd1HgSx/Q9x7Hik1YNGfJVreXNlOlxazyQTIcq8bYI/EV7D4P8AjZeWhjs/EsX2mEfKLqLi QD/aHf8ACuS8Z/DLW/CTtcqn2/S8/LeQj7o9HX+E/p71wh4OTUuKluClKJ9saRrWma1ZC90u9juY m53I2SPYjqK01BC+u7oc18TaR4h1bw/erdaVeyQSDrtPB+o6GvdPB3xpsb/ZZeJUFlMcAXCjMbn3 /u1hKm47HRGopbnsbA7QT0NFRW88N1DHcW0yTRMMh0bII/CisjYqeWsrKyqVIGeeM0ySQFwGIIUY xnPNSXTlnTy+Ao4zxUKgu5YIFx1NWc5IriU5b8M1MqnI5IA6CmJHuOWBA9amChRzxj1pASoduCTS mRiRsG76dqhbAIbkj1qVc4yTx7UDJRucZzgg04KnJLZz1qHLHkDgU5QxBIAUnpQBPvUEFDj8OKlU 59PrVaNSR8x+uOlSAEAknjHYVLKRKSzdB0oEjBsE5B9O1CLuAIOKkVVA2g9epoGLktHgDrxTGXCj ABqVY1DdzThEpTaBgUgKbnAKswCY6YrjvEnxK0jwy7WpMk11GB+6iXheOMk8V2VxBkACQYHUntXz H8Rnjn8daqUdiFZU+fHVUAOMe4r0cvwscRV5Z7WObE1nTjeJb8TfGTxNrAe3sZRptu3B8r75H+9/ hivMZ55LiUyTO7OTlickk+tTywMASDwD2qvIhRSx6DtX1dPDwpK0FY8iVSU3eTICcjmlVSuSScUx 3CfMACKgku0X5ice1U5JbiSbLJYYZj+naqs1wi5JbjrT9NtdX168+w6NYS3cp6+WOF92PRR7mvXv CnwRjE0V54ouRdOMN9jhyIwfRm6t9Bj8a8+rjEtIm8afc8z8PeGvEHi2by9HsilsDh7uUFY19ee5 9hmvYfDPwo0TQlF5qi/2ldryZJwPLT3C/wBTmvQbe5021vE0TRbI395GNotLNOIvZiOF+nX2rsrP wFqF3plxeeInhmvCrG201CVgjOPl8wjlzn8K8qpVlPWTOiMUtjkdK0f+2I3uLMMbGJwhnEZCMfRW xg49q7S0srHTYhHbRBC3G7GSx9zVzSpLzQfDA0vW7i3e9wdltAchF9T6df5VF97DAtwOBXmVd9Dv hsLKuflPJxwa5nxwWj8GXo3A52bgO3ziui2yoxZiDuOfpWH4sudAg0Cay1zVYNNS6GEeaQAlgcgg d8EVjGydzR3a0PLPDMH2rxJptuv/AC0uY1/8eFep+IsP4huzzgyN9TXn3gSCI/EbSreO7gu0S4Vh LbyB0YAbgQR9K9E8QSRRa5eEsAQx3Me3+FdkmmjCKszLiBhkWc4VlHyDHIPr9ay9a8Q6X4fsTd6p dLED91OryH0Ud/5VxHiv4p2On+ZZaFsvboZBnPMSH2/vH9K8W1DVb/V797vULl7iZuruf0HoPYVi 32NNtzsfFvxH1TX99raFrHTzxsQ/PIP9o/0HH1rgnDMeOKnjt5LmVIYo2ldyAqKMliewFe3+BPgi 90Y7/wAXboIiMrYocM3++R936Dn6VDYtWeZ+EfAeveL71Y9PttlqpxLdygiJPx7n2HNfS/g74c6F 4Rtg9vELm9xiS8lUbj/uj+EfT8Sa66z0+z0qyisLK2S3tohhIoxhV+gFPYuZCcDB7Vm3c0jG24xi E6dBXLeNfCkHizR/spZY7mPLRSN0GeoOOx4/IV07xE8n8vWkJVMDOCxwPeiE5U5KUd0VKKkrM+Jv EenX2l6tdadeI0M9qxT73Ix3B7+tGi+OPGGlxebYXqzBUaF1m5JBGMhuoODjrX1h4t+HXhzxmyS6 rDLDdIu0XFuwVyOwbIII+teW+LvgTb6bov2vwpLc3c0IJltpmDNKPVMAc+3ftXqyxVKqr1FqcKpV Kb91nGad8XtSt9QtnuvDcUiREF1Fzjd6c7Tj1r2TSviDpnirw/HNaOYrmzlWWS2kPzpgg59xx1H6 V8wyQmJykilHU4IIwQa674b3aweLfsrnC3kEkP443D/0GuBqKfuqx0KTfxH3dNFaatasCFLGvCPi b8HbbW/NvtOQWupAEh8fLL7N/jWn4G+J1tf6i/h/UXFrqts2xVJwJ1HRl98ckV69Fc2+ow7JAucd TWidyWj879R0m+0nUZNOv7WSC6ibDRsOfbHqDXqfw50u8v7eTw5o7y2zXvz6xqaD/URD7sCHpuPO fr7V7p8Q/hjp3iW1DTQ+XOnMdzGBuT8e49qq+C4vDlnog0rw/LFJFZtsl2sGYyd2YjqT6/4VlUVk VTvc0otOsNA8Mvp2mQLb28cRjVV568ZPqTnrVfwpGF0aW55zcXEknTsDtH/oNWPEMxg0aQ7vlznH 05/pVnQ4Et/Denxlfn8hSw9yMn9Sax6G/Up+KPDei+ItGeLU7VZvKG9XxhkI6YNfNnxV0TWv7bGv S2j/ANmzjy4Zl5A2kgg+nOa+nNZuTDpcjY2gjr6gc/0rN1e70bSvBiw+IIo2tlhWMxOMmVsdAO5J zRGVtQcebRHxOQVbpUZyDzxXqniP4V69FpUviWx00xWsrGQWSktJBH2z6/0rzFkb7pU56HNdKdzl aaIsBeTXV+EPGes+Gb1Y7CQz20zjfaP0c9OPQ89R+tcrtA+9zXV/D7S/7Q8a2Zdcw2ubh+P7vTP4 4qrX3EnbVHvj2/8AburWmkNKIrm7cYB6cckfy/KtmKzuLQPZyQkSmTb+H/6q4fVNE1+e9l8WaNdI 9tpjLDKVk2GBs5bOf9o4z7Vd034nXVve2mn6vIkr2z5UyLh8EEYz36+9RY0PRYyzBQilHHVT6j09 RWZqMt9BvuYrp1YEMqH7uO4qY6jY6sBJbkgHB4GCh9vT61NIRKWhliyuMq45B9Qf6fjWkZdyJQ7B o3iq11B3hZhFLGSNrHng9a6u01FJEBDhhnrXkGq6BPZ3Muo2rvIW52L19vqKzrXxle2PlWczFZFc 5yMAD0rdO5jsfQyXAYDLVZjnzwTXFaNrKX+nQ3KPuDDqP1rdgvFI+9TsCZ0aShlx0xUgPasqO4GO opt5e3qWU32C3FxdBCwjJxwO+allpl26QPA8khItozhsf8tG7KKr21iVc3MwzM4xj+4PQVcgn/tG OC48ryraJcRR+/djVvywzEnAFSvMZlS2gwWxyay7m0yCCMGundOMbaqS2oYHiqTE0cTdWXz7ugIx 0qnLaoqZJwy+3WuxnszgjHFZNxY5Ull/KruQc4HZFZZFDxsMMrDII9xXnviH4ReGdYae70mJrG5l B/dI+Iw3qowcfTp9K9LmtXTKYPHRietUtjRuSSVqXHsUn0Z8catpGo6LqMun6nZy2tzH95JFwfqP Ue44qiG296+w9d0LRfFFgbDXLNZlAOyZeJIj6q3Ufyr5+8afCfWfDIl1DT92p6UMnzo1+eIf7a+n uOPpS9RNdUZXhX4ha/4TnH2C5MltnLW0p3If8PworjG4PvRUuCY1NrqfcOCxyR8x9aljhxwTx6dq UR7AMLhh70/GRyM9q5TYmRTsALA59KMRgtkbh71A7sgAXio8sWPJx6CgGWAgcZLEDtinomFPHfvV dH+VlNLHKQ5Q8igCyo4OOhp24KmMZI9ajDemcU/BaPdjCj36UDJFOR7ehqVXCnjIzUCHGDjH4dak 3A/w5pNDTLC9RwMVN8owMiq8eTwTUq46ZyaVhkob5htX8TTmU5A3fXFRkjgMeaHcn5QD83egBCiE HKg+oNfOPxZ0abTvG8l9gm31BRKjD+8FAYfmAfxFfRgik25Lkk1yXjfwVbeK9OjAleK9tQ7W7j7u SOVYdwSB+Vd2BrqhWUpbM5sRT54abo+WwPkYkEDvjoKo3scf2YyPcCIBwgXHr1P4f1q9q6SWCzwT xtBcQyFJIz1Vh1BridS1KS6AjDkIuePWvp8TX5Ie6eVThd6lqS/eYrDAgkkJwAq5JOe3513nhH4U 6nrkwvvEvmWdquCLVeJJPr/dH6/Ssb4QRPJ44kkEIdY7V2Zm5KDcoz+Zx+NfQVw91bQZgxhhhmHU D2rwKlebdjvjTVrk+j2+maQsWjaXpxaQD91ZWUW5298D+Z/Ou8sPAetazHnxFM+jWLDmztJAZpB6 PIPuj2FXtN8PaBo2kadrljrkvhyyuYVNwLh0R7luTlpH5B69D06V5n4//aX0TwzDLo3g2VvEF+hK /brhswxewIwZMev6msHO2xfJfc9qC+Efh94fdo0tNE0+Jcs/Rnx6nqxrwzxl+0RNdGW08IQNaWvI N9MP3sn+4v8AD9TXzdqfxK8X6/rU9/rmtzXn2lfLeOTHlhfRV6L+FMWV3O5zk+tZOVy0ktjvtN+J fiPTdabUhdG5WU5mgn+cS/7xPP4ivfPB3xC0jxTphl85LO9tofNuYnyFiGcZ3Hgj+Wa+SVODxyKs LdKiEZOSMYz1rKUb6m0Z9Ge8eNPjPb2Zex8KMLm4Bw164/dqf9kfxfU8fWvGr7xXqmoRXf2/yb66 unBe7uYxJMoH8Kk/dH0xWBJKzsSDgUwPjjP6VKgkDm2dJ4T8Xan4O8S2muaaqPLbtkxSDKSKQQQf wJ57VqeNfiRrXjG7nkkA0+zmbcbWBjg/7x6t/L2rh85Oetbml+GtX1TSrvVrWxlm0+xwbiVMfIOp 4J5454piTMTLfd4xXU+EvA2ueL7zydNtSIEP7y6k4jj/AB7n2HNe7eH/AIW+ANW8J6bPBZSXSTAT /aXkZZJD3VsEYGeMD0r0rTrK20u3SwsrWO3toRhI41Cqv0FRzLoXyO+pyngn4b6L4PVZYFF3qO35 7yUfMPUIP4R+vqa7xVWMYHfrUXm87QApPvTXAkQKxOM9j0NZ7mqVi0pXgE/j6VHIAg5P4Co9zopE g3Ds2KUOWG1sY7eooAjOSfXNNEYGCcelTmMr9OxphQdQ3IpWGGF9eBQBzkDgelOIHJAoXdtKjvQB 478WvhzZalpt54n0qAxalAvmTxxrkTqOpx/eA5z3xXzvZXM9hqEF5b4EsEiyKT6g5r7p27eDjJ68 da881f4O+DdW1ltRaKezLndJDasqRufpjjPtitYy6MylHrE8a13RbzxDqGm6x4Zt5ZprwBkWE4ZS Oc57FSCCe2K998DzeMrDRIY/FkMJnjGBLFJucj/bAGM+4JouPBemWmk29v4et002azO+Bo+59yeT n1NPs/FHlEWOvwtZXY4LFfkf3H/1qXN2Go9zS8ceIby+03T/AAnpL7b/AFuXyDKP+WMI++35fpmt BPAlj4e0iG30SLy1hXmQD5pD3LeuawJH0weILTW4JvNnhjaMKPugHv7Hr+degaHr1pqVkrxzLIjc ZByK2jJNWM3Fpnmniq6mm0sWsibJj8h9CTgDH511CGONNuR8owoWqHj6xR9d0W2tzj7TcRjj/fH+ FJeXI0uCR9QBRYVLmUDOQB/OsZxaWhrGWupmeLtVtrLSTc3khS2iYGTjtkZrD0HSr7xTrEfivxHC yW6fNp9g/SMf32H94/pVzT5oPF9rZXN7a7baR3uVhlHJRWxGSPf71dihVQFj4HotZvQ03Hj5kKsP lPY15H8RPg/Z66kureHo0tdRHLwjhJv8DXrmN4bnaAKQF1QrgD0zSTcRtKSPhDUNPvNMvpLO/tnt 54jh43GCK9U+F1iLLw9fa1KuTO+xM90QZP5nj8K7nxnodv8AE3xQNJ0WCCNNNz9t1Xbna2OIh/e5 61RnsU8PeGrTQ43DmBREzKMB2zuc/nj866VO8TmcLSsX/Cuo6jpkkt9p8+2SZyssbgMkynqrqeGB 9K4b4qDw3aaxDdaZayWM1zCJZbQcxxyZIPl9wpxnB6V3nhi3S5gmdHUiKTawU9GwDg/hivL/AIyI V8W2Ua9fsi/+htQnfQbVk2Hgj4g3dleCz1EGS1HAlX70Y9D6j9a96sNQgvLdXjkV1cZBHcV4pH8O ToFv4ce8vEkvdScvcWZXDRqBu69xjg+5q7r3jC90DxTbQ2Ox4sBZYW6EHk/QgDj60SsnoKDbV2ev vC1rbE28XnJnd5RPQdwv9B61xuteCIbu4lv7SaRZmO4xu3H09q1vDXi/SvENkzWdyPNj4kibh4z7 juPetwxl281JCjYwQOA49D61UZWFKKZg6DqNxpwFlNCYYY1AA7A9/wDGuysNXhuSDBMHx1Ga43Ut MuNQO2INC5G1sdj6j1FS6BpzaPb+XI++RzlmFdMZXOeUbHpEd+qIXd+R1FTJeyTSCzViskuGmYdV XstcUdSAu9jvlYV8x8foK39HlKQmaU/vpzuY+noKb10BaK53drN5UYQYCAYA9KvxyK33uABxjvXL wXa8AtmtWKclQVOfek0Uma4+fk0pjxVaCYkjNXVO/nOM1BZUkgVuSM1SmtQT0/CtraCKjeDcM00x WOSvdP3DKrhgaw7rT2HO2u8mgPPFZtxZhlK44PpVpktHndxA4faAQPX0pscskB46V1F3pgUHapIr KmseDiq0ZOqPKPGXwk0XxMsmoaF5ek6mfmKBcQzH3A+6fcflRXf3TfZRnndngDvRUNPoXo9zcZdq EnJ9hSAnK7lI9qlDqc9zTScAv39M1xGwyQB2wxOfpUSbg/TCnrnjNToezHn60yVE3KWdjjtnrTEy FkLMWDbVHakRAPmbin7hn7uSaUgkjB/CgCaM8A+tTsPMGB8o9qrxrs5J5/lVhWBAHJpDCFCCVH61 J8q45GRQgG7LMQaedpxtApDHAZbABxTgMck/SmcZB6+1SgblyD8woCwoCgcZJ+lO+9jnrUfzAjJz 70uecCkMV5vLQbxwOMmkZyxOc47YNDBWUq4yO/FKqoqgbCPagDyj4m/DFPEtvJqehwxrqjA+dFna LgeuTwGHr3rzXwL+z9qmp+OdN07xVbvFYPE11c/ZpASiKcbC3IDElBgdAc54r6gZR5eCQgPINRWd 8ula1DcymVrcKVdE7nrn6jH866liqnKoPZGDoRu5Iwr/AOD/AIY8J241Dwhoq2oEPk3GHeR2XOck sSTzjP0rnrWzke5jtMZLuEXPucV7Z/wkOmy6T/bElwlvZMSN0hwc+mPX2FeC+NdcstZjv59AebT1 ibaVVfmf1P8AsA/jWsIyqbGUpKnued/tTeI4tW8Y6VpOm6itzYaXbGMxxHMccpbB9idoUe1fOYVn lCIGklY4AHevXvEGjtqGg/NbCGa23SMSjZYEqMhuhH65zXIWGn2trP5gkEcmDtkdc4/oKia5XYSf NqZEmjX9gIrkwpO2M7FJO01ctJ3e3HnfK4OCvTFazBFSWG3kkY9TKw3DP16H8KwA8aXLpGCy/wB8 n7x71kaI09+VwDTc8f7VVFLdzUiiRmyGINAyfdzz+VOySwwOKt6PpVxqurWmnxMsT3UqxCSVtqrk 4yT2A6mupT4d69ceKLjQdK8jVHg277q2k3QKCM5L9vp1pDszkI4izcjJPQV7x4A8H+Mb/wAHyaLq c39k+Hbp/MdPKAuZgcZC/wB1Tgcn8q3PBfww0vwyINRum/tHV85BdB5cR9FU9/c/pXq+5tuWUg55 xWEpp6I6Iwa1I9IsrPStKt9LsIfKtrZAkag5wP61cPykkjPHFRK6K4zwacXU88HNSXYasiM+3jf3 FOCgHjg9agaMGdZfNK7T0XvVoge+T3pDGsSVwRnJ/OlUbS3fpgelKuCMEnP86l8sYyemO1NCYxGb ZhzuH8qaVwTg5FARhnn5M8Cj+IE5x3oAFAzkHHrQ3zcLkD2pzEZyq9adnK46H0FMCLbjuTn1NIRu JGD7VNgdDSHIG0DmkBFtIXkcdqguLa1uYvJu4UlQ/wAMihh+tWjjB9RUe3IJJwaBlO10zTrHL2tr FEfVRzUzfIytbgRsvoMBqkOBweR2pGBOQCf60ru4WRi6lfGfxj4deX/llcICD25NegX+lwXtvvRA xxXjniDXLEeI44llKyaXJE1wwGdobJ/HgGu58H+NLXXNLgvbRpPIk6eYhQ/kf6V0RlfcylGxUl0w aXqZuSGELJswBnZz/KrTneqshGMdR3FdhPb2+oW52gZxXk97rtxaePD4c0exN/DAN164bAgz6H19 u9KVO+qCM7bnULhR8zcelcJ4s8Qajf6mngvwu27U7lc3Nz2soj1J/wBojp/+qp/GHi6bTo7fSNCi +169qB2W0IH+r9Xb0A5/KtPwZ4Vg8M6W4nl+06pdt5t5dNy0rn39B2rBLubuVttx2m6PZeEfCRsr JcRwqS7n70jnqzepJrzHXBJq01pZWD+dqF7uSCFcgp8xDSseygAY9SK9G8cXn2XQ/JiJ3St+eP8A 69UfAnhH+xbZtT1Aedqt2Mljz5SdkHp71S0VyfJGV4W8GzeC7C7sJ7z7Z9onFwsmME5UAg/iDXlf xVgEnjm3lbhIrNfxO5q+hdVI+0xjr8v9a8b+IHgzxD4ju77UtHtxKlrDGhXOGk4JIX1wCPzrSEur M5KyaRzvgS8vta1S71W/uZbiOwgFpbmQ52qTk4/AfrXK+IFvP7evtVuomWI7vKJ6HP8A9YCu28M2 kmg+AleZTFcXDs7hhgqc4AP4Csb4h30dv4X0+xUBXum80g9QAM/1H5Va1ZG0Tzmw1O9029W9sbiS CdDkMhx+B9R7V7t4H+J9rq5i07WNlrfHAVs4SU+3ofavnktx05pUZtw2nBrRpMxUmj7TeOG6Rdxb AIYMhwynsQexqrdzm0Z3miBgCk+YOqn3rwnwP8VLnR2j07Xne5shws3V4vr/AHh+v1r2G91K21a2 t2srlJrIjz5JYzlWUdB+JqVdOxro1cdZZkuI4nJ3SkXEvtn7qn/PauphkZSMHP0rk9KFy6zT8+dc Nvw38K9APyx+Oa6GNmjAwc+1bRkYyidBbTkfePHr6VuWtwcDsK5O0m3Pw2BnnPataKd0OAOoyAe4 rS5Fjq7eXd9084q/b3OCMniuYtrvcowcY/MVfiufmwePf1qWi0zp1kB5qbKkc1j29yQoDHj1q/G4 bBz1qGi0yZ4lYcVTktyM7RWioyOacUBGCOaVwOdnt1YHjB96wdVWOztJLjyyXA+VB1duwFdpcQxo ju5CqoySewrjLtJ766V0UlnOLeM/wju5rRMTRwxivdRvJI7i0e3uFP70kqVUdeNpIor0BNJS2t/K UZY8sx6sfWimiGc2pJBLFQB3zVeaVlY4OSajllRRtB/KofmkI61wnSSqzk5ZvegjLcNn3qE7wwXO PwqSPOcYwPagCVdyqGJAzVhORniq4yctkADjFSBweOntTEWcr2OT39qehwo4JqvGRk8c1KCc7eQe wpAT7xzkcnvShyMenpUW4g/NjinFWXkkY96BlgbTjrupdwb5RyPXNVVc+vHrU0e0DI/OlcZMM529 T6VJ/DvIwB1poDEBulNK7hjBGaQDlIJ3hTj1p4bcSC2CPSkjKImxcsD6U9VIOVJB6Y64pgM2vgMM A/7VV5kRACw8w55UdPrVzyZWzkZJ5JqOWJWTMhPoBnFHoB4b8Y9H1uxe11uxu5zpSNkwIx2W0hGN wHTDY6+vHcVleFdT/t1lu7eSGPU4wEubOZiI7tPXjlT7847g17zfWKahZSafdQi5t5VKSIw4Za+c PGnw91bwdejU9PaRtPZsxzRt80JzwrY6H371vTqOOxz1IJ77Hd+LntYvCl3FHpMVhCyfMSwZmY8A A+mfpXz5gx3ZAK8Hq4yK6K+1/XNUt1t9Rv5biFDuCse/qfX8awGBW4z+uM1U5uTuyIwUVoRTSbJU EkqRqchYk53f5+lc2GY6jIcAhBjA6D/69bd7cbSQrqpJ5EaZJ+vpWZHGDO74+ZmJrHqaWHKrP2Aq 3b5QnK7vr2pqIWPYV1Hg3wbq3i/XVsNMh4ABmuGzshT1Pv6DvVX0BHW/CrwQni3W5rnVbZpNItUI kwxUNIR8qgj8z9PevpTS9H0/RNNSw0myjtrdORHGMZPqT3Puag8O+H7HwxoVto2mxlYohlmx80jn qzH1NbQUqM7sH0rFu50RVhoijEmdi5PGe9BYAFc5x2FEhOAF61Xuorryv3DqrHuahlok2hxnJ9/W l2DapBAYdjUaI67FZ9xUHJPGakALr0zjnFIYMNuDkAZ64qVJQ2YznP6VGAD249PWoyfLwSxbHUYz TEWIw2cEg/SpiRiooX3JuGeecYpxck47U+gAxJz2HpUMcTLctJ5zEMB8vYVJnJI/SkYjnH/6qQxW 6cUB8fhxTeQpbGD3pVxJzyMdsUAO35wcdKXeRzTWVsjB5NAZSADyfWgQYyc5wf50hbI6e1IWyOCP zpoRipbd+GKBifeGBnj9aaCSvTGKTeVQrkDdSg/NgEZNIZx3iTwrpoi1HWrKBkv7na0zbiQ+3odv Suk0q7tdS0O0nhRUVkHyqMeWwGCB6YOatmJpFZJQMEEY9RXGNFqXhLUpZra3e80iZtzIoy0R9aLs LI6+78QXOhaVd3bfM0MTNGezNjgfnS/DXQYYfCRvrz95qmqubu4lb7zFuVH5c/UmsE+KdA1Cykjl dZBIpVoZMDPsa09G1q4tTb2wtpRAVwkgU7UUdATW8J6amM4F/V/D/wBm1BdTtoI/tKKUDlQTtOMj PUdBWTdazaWVjPfXsn2eK3XdJvP3a9AtrmDUbby5jya5fxb4PsdVsJbe5tlmhccoe/eqlDmFGXKz yrTtUuPFur6ZcTwmOGaczojDBESklc/Xbn8a9OUtjK9RXFaAkA8V3TbVQQxeWiDgdR0/AGu0mY7M L1PCj3rCS1SRsn1Zjao6tdAE/Mq446U7Sm8uyuZCflEhPT0UVQ1IyfaV2fc28HuxzyajS6Nt4XnK Md0sjKPf/OKqSsrCi7u55X41uzcXdtYKRuupgDj/AGjgn8smvMPiRLcyeJwkkMkUEUSrCWXAcdyP Xnj8K7vc2sfEuKCP5hbhiBnv90fqWr2bxX4Q8N614RFhrUcaR2sP7u6HDQ4HUGqTUbESTk2kfFPX NH61av7eC31CeC3nE8MblUkxjcM8Gq2OOBWxzNW0JLeKW4uY4IkLySsEVR1JJwBXt2rapD4B8I2G mQxJPM5UOucbgOXP4n+dcP8ADPR/tviZtRmj/caenm5PTeeF/qfwqh471s6t4nmCtuitv3SYPHHX 9aN9Co6e8fQPhjxTpHiOzW702ULMoHm27HDx/UenuK6pDuTceGHpXxtp2p32l3yXun3L288f3XQ/ ofUV734H+KFlrSx6dq5Sz1E8Bs4jm+nofb8qVmik1I9Q6YcHafY9atw3Jbhjg9uaoGWMgbqVW5Iz 8o6HuKuMiZRN61vA7lcFXA5B7+9akNwG6muXikwBngjoc1qwT7xjPzfzrZMysdNDdNGQDyK17a5w Qc5FclDcBxkZyPvKTWjaXaqdpbJ7HNA0ztIZ1cZzVkHNc3b3ZB54Jp2p6tdRWTW+nIr30qnYD0Ud 2rNotMt35F2X3kiygP7zH/LV+yCnWOnmLdc3CAXEvUdkHZRVbw/LNqOmWc9xbG2SFR+5PeT+I++D nFb/AB3xS8itzNntgwOV/KitFogV46mincLHhduZ5bZZZ7dYmOTsDZK+mT6/SpMkNz09aaz7MnoO mKbvyT+7yvqfWuaxdxeFbB5qQStwgPynocUgUg5xxUgQY6D8aAANuOVHFKQQOSMmlV0EoiJXeRkD PJAqUY3cLz60AbMepwRWojgtsEAjOeB71ml2LE8knv61AW2+gyalUggDrQ3caSRMhHVuMU4tlgTg e3rUajecucVL8o6VIxwwTk1IDkhtwI9qi4z3+lPjCKhA780hlpG/gxjNNUE5BaoRJg/Lipl3OdxO BQgJF2qKkVpCcI2B6njFRqBxj5vY1ZXlQAPrTEJEXT/loPmPNMZI1clyTzkVKY/lDEjI7YqCVsHn J/lQBGW/eNkYU9OarXCRzwtDPCrwt8rqwyCD2I9KsEgpyx/z71CwjKgtI+0DnvmgZ5Z4k+EdtdCW 88OyrbSPybeT7g/3WHI+hzXkuseAPF2iyu0ug3dwiJ5jNbJ5qgfVc19UfJtyMp7dKsLmSPe4x2B6 Zpc5Lp9j4SuNO1ie8zNp12ssmWUPEwJHqAfofyrY0fwB4t1iVF0/w/fSq5wJWiKR/wDfTYH619sp uztZiPcd6jczG5VQCYz1P+eavmXYn2b6s8F8M/AO4aWOfxTfpCmMm1tTuY/V+g/DP1r3PRtE03w/ pq2GkWcVpbJzhByx9SepPuan3eXMCeY+RzVkkPjHK9cYqea5aikRecxlC7OD05qUnJIAyac6KFyr Ae1NhUoqlwu7HOKksUqgAG3pTS+VIAPy9KdI2/kLwOxqIhgQGJ5Pbmkx2DJZdzAg+hpyR4QsD1py htm18k+pHWk2llx2HakMYMKTyST0xSSK7eicdakYFeO1IzFkO1TQAitwF3/nQHIJJpFYBDvUZIzU eScnJC0BYk8wtg8EUowOSM571AyNuUjpUgLZPJH1pDJEODw2eelP28cDGahBwOmMHrVgv+7Cnr1q kSNyzfLyMVEW2EqMt7+lGcMcDIHqaafvYx+VK47DXkC98j2p2/cRgcY7Ux0U4wAGB6gUudh2nkel K5VgPPJHWkGwA7Rj607z1kyo+XFNUj5hjP1oCw4tnDnrimMWI3Dg5zxTgd2eOKUFV980AUmtYJJB I9tEz9Q5QZz9atAYXlc+1B/1YyvIPFAAUggEk9qAMq58T2GieIdO0ZpnN1fbjHEqklQvOTjoK7aD WIpLCRpSrKqFh+AzXzzqHhr4hX/xG1m8s7aC0S6H2eHUZWB8iD/YAOcke3r0r0Cw0Kbwx4MexTUr i88mB8vcNknjt6D0FbRk0tTKSTeg/wAKaI+oaNqOpFMu91sVu2VUH/2ar7yPEqQTzDzHOwMB91e5 Pv2zVLwh4h+xeFhpkDjzruWaR2J4jjUgM59Ow+p9q3NE/s7X9GvrxCI0jmMRaRsFlAGG56A5Na6M z1Of1weTdxxhcDywAPauI8Q6/BpejbZCCYIpZ35+7y2M/gP1roWvBfapcwxF3gtZDCjt/EB3Htkn FeF/Eu7lmv8AUtItVcTXM0cbSHhVTCn+dZcvRmnN1Oh+CcDa54gv9fmT9ykgRWPc4JAHvxmp/jP8 QPN3+FNJmIVT/pcinqf7n+NV/CWof8Iv4Ei0vQw13quoyGCyTPQsB5kuOw4Xn/ZHpXmPiu3tLDVD pkNz9svICfttwG3B5ifmA9h0+uaLKUhJuMb9Wc3gs2K7m7+Ffii28GW3ib7P5kMy+Y0CA+ZEvYke 45rR+E3gc+K/E63V3CTpdiRJLkYEjfwp/U+31r6ovHis9OldkBVF4B49gKuU7OyM4Q5j5n09R4S+ F5uXBS7vF8859W4Qflg/jXkDszOzucljkk96+jPFHgXWPGnh+e7025RWtpDstyMCXA5APbHavny+ sbvT7ySzvYHgniO10dcEGqWpMlZWKgOO+KFcqc55ppBzRVGZ6n4N+KV1p6xaZ4gd7mz4VLjrJEPf +8P1r2mw1uCaOO4hnS4t5RlJEOQRXyKv1rpPDXi3U/DdxiB/OtHP7y3c/K3uPQ+9FuxSn3Pq+G4E q7lIIParMdwUOByPTuK8x8P+LrPVIBPp85A/jic/NH7EenvXcWmoRyrv3YcdDTTsU0mdLDdNIm7O G7Ed61bO4DN8/Brl4ZOh6HP51p28+91BOG6ZrVSMmjrWuora0aeU7VQZOf6VnWdxPe3R3Ntkn5cj /lnH6Vzt9q3n3S2K/NFb/M/u3YV0Wjobe2BkwJZTuJz09BQxnd2k0a26RIAqqMACrwkyBzXL29ww IB4Na0FyWwGNS0Wmayt+NFRRvkcniioKPCrj/Vj6/wBKlH+rX6UUVg9wJ4/9QpqT+BfrRRQixBHG blZCilwhAbHIFTD/AFn4UUUkAwdj70+OiigEWezfSli+9RRSZQ5v9X+NSj0ooqUHQkhA54FWU5T8 aKKYh4AwOKtp/ql+lFFC3BkEn3j7A1BL0P0ooqmBDH0cdhSXBP2Zvr/WiipWxQ7avkbtoyFGDjpU DMyqQpIHoPpRRUMtE9uSXbJ9KvYARyOKKKqOxD3Kc4GM470tvyDn1ooo6gUtT4fI4yBWjCScZOfl FFFZr4maP4UPH3/xqN/4aKKslFpeRk1E5P60UUAgb7y/WkX75HaiihgiA/cX2zR0gXFFFT1KAk+Y eaRSSj57dKKKQdB68q2aG+8tFFX0EO70kf3jRRUsYw9TUT/xfWiikykIgHk5xSx/fA7UUUCF/wCW +O1KeCMUUUxC/wAa0x+Jhj0oooBFhv8AVg96o6p/yB7r/ri38qKKYHjekO407WiHYEfZ48g/wl5S V+hIBx7CpQT9tjGTxE5/UUUVt1M1szo9DA+zSn/b/oK8v8WKr+OLvcobbEpXIzjp0oooZHQi+HpL eJddkYlnt9OmMTHrGfm+6e34V4wCTesxJLNkknuaKKUAnt8/0PrT4LRxx/C6xZEVGeaUsVGCx3Yy fWus8VMw8PHDHmRR1+tFFS/jNIfCO8LADwpZ4GMhifruNeJftAW9ulzYXCQRrM4IaQKAzD3NFFNf GS/gPAj1pG6j6UUV0HIOWndqKKpAbHhaWWPxRp3lyMm6ZVbaSMgnkH2r6F04nIGTjdRRQaLY6y0J MZyc4FaEJOKKKIgzG0MlruUsdxNz3/CvRrXoBRRVrczZoQf6xBWxa/cb6UUUxo1ISdh57UUUVBZ/ /9k ________________________________________________________________________________
Subject: Re: Ko lb-List: New guy with repair questions
Date: Jun 23, 2010
As Dana said, When splicing a tube like that, a common method is to use a piece of the original tube, split lengthwise just enough so it will squeeze down [tightly] into the original tube. But STRESS CONCENTRATION problems have been overlooked, which would be of critical importance when splicing a fuselage boom tube. Chapter 4 of AC 43.13-1B is useful as a guide. A split sleeve could be used if the ends were cut off at a large angle (about 30 degrees from lengthwise axis) in order to spread the load along the tubing and prevent stress concentration in one spot. Such a repair should work fine at the tail end, but is just too scary near the highly loaded fuselage pod end of the tube. Also, since it would be impossible to buck solid aircraft rivets, self plugging Cherry aerospace rivets (CR9163 available through Aircraft Spruce) should be used for the repair. A repair using pop rivets would not be nearly as strong and the pop rivets would be subject to loosening after repeated load cycles. I am very glad to hear that you ordered a new tube. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302227#302227 ________________________________________________________________________________
Date: Jun 23, 2010
Subject: Re: Re; Fluttering control surfaces
The simple answer is no. Balance is balance. You can save a little weight by using steel tube instead of the solid rod used by Kolb and the making a lead plug for one end as the balance weight. One thing that will help a 103 compliant aircraft is build those ailerons light. If using the Polyfiber system read and reread Appendix A of the manual. Somewhere I have a very short piece of film showing the ailerons on my Mk III going lock to lock during a flyby. Scared the ****** out of me. I had Travis send the counterbalance hardware that day and put them on the minute they arrived. IMHO this just isn't the place to skimp. Rick Girard On Wed, Jun 23, 2010 at 8:27 AM, william sullivan wrote: > Question: Could control flutter be moderated or corrected by adjusting > the ailerons slightly down. For example, when neutralized adjust the tail > end of them to be about an inch down, to tension them against the air flow. > I realize that it would create a little drag, but a 103 spec aircraft > doesn't need extra weight. > > Bill Sullivan > Windsor Locks, Ct. > FS 447 > > * > > * > > ________________________________________________________________________________
Subject: Re; Fluttering control surfaces
Date: Jun 23, 2010
>The simple answer is no. Balance is balance. >Rick Girard Rick=2C people that know more than me=2C I don't have much (any?) experience with control surface fluttering. That 's why it is important to me. I don't want to overlook something=2C and ha ve the whole thing come crashing down because of something I didn't inquire about. Regarding control surfaces=2C all of them=3B Will a perfectly balanced a ileron=2C rudder=2C or elevator=2C etc=2C be immune from fluttering during flight? In other words=2C is it that simple? Balance the flight surface and you will have NO problem with flutter. If that's all it is=2C it seems pretty easy to make sure I don't have an issue with fluttering=2C by making sure e verything is balanced properly. Mike Welch MkIII=2C unbalanced at the moment _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jun 23, 2010
Subject: Re: New guy with repair questions
if anyone has any tips or tricks when it comes to replacing the tube. Here are the pictures of the damage. Thanks Chris Chris, I'm not an engineer and can't recommend what to do, but I feel the repair I did after my fuse tube bent from an engine out and rough landing in my Ultrastar was actually stronger than original. I conferred with a number of knowledgeable people and was told only to keep alert for any movement between the pieces as time went on. In essence, all's tight, all's OK. I got a tube and cut it the same length as the damaged section I was replacing. Then I cut a piece about a foot long from the damaged tube and had a kerf cut length-wise so I could slip it into the existing tail section and the new tube. It fit nice and tight; had to tap it in with a block of wood over end of tube. Then I riveted it as shown in the photo. That was my fix, you may choose to do it differently, but the time saved was significant and when it's all painted the same color not too many people would know it was different from the kit. Best, Dave Kulp Bethlehem, PA FireFly 11DMK ________________________________________________________________________________
Date: Jun 23, 2010
Subject: Re: fluttering control surfaces
John -- You need to buy Dragon Naturally Speaking, and then you can just talk to your computer and have it type for you. :-) -- Robert On Tue, Jun 22, 2010 at 4:03 PM, John Hauck wrote: > > I have my own theory of why, and how to fix, but will not go into it now, > typing with two fingers. > > ________________________________________________________________________________
Date: Jun 23, 2010
Yes, that would cure all your flutter problems. However, "perfect" balance is not necessary in my humble opinion. Close is good enough, again my opinion and personal experience. Elevators have not been a problem, and I fly my mkIII without elevator counterbalance weights and gap seals. Rudders will shuffle and flutter if allowed to progress, but a little pressure on rudder pedals prevents this. You can install a counter balance weight on the rudder, or a couple additional rudder pedal springs will get the job done. I have no gap seal on rudder. When I built my mkIII I knew I would probably encounter aileron flutter based on aileron flutter experienced with my Ultrastar and Firestar. I designed a pair of beautiful counterbalance weights which were mounted on the inboard end of the ailerons. On my first flight to my local airport, as I banked and entered downwind, I experienced severe aileron flutter, well below the 85 mph that it would flutter with no counterbalance weights. I landed quick, borrowed a screw driver and promptly removed my counterbalance weights. As long as I kept it under 85 mph I stayed out of flutter. I could not convince Kolb Aircraft that their airplanes were prone to flutter because factory airplanes had not been there. 1993, I made flights to Lakeland, Pennsylvania, and Oshkosh, fighting flutter all the way. In smooth air the ailerons fluttered at 85 mph, but in turbulence the rough, unpredictable air would trigger it at lower airspeeds. It was not fun to fly long cross country flights with aileron flutter lurking to kick my butt. Can't remember the year, but it was at Lakeland, Dick Rahill was flying back from Lakeland South to Paradise City trying to outrun a thunder storm. He was flying the factory FS in rough air and wide open throttle. Suddenly he got into severe aileron flutter. The man was white as a ghost when he landed. That must have been enough to convince Kolb Aircraft that there was the distinct possibility that Kolbs could experience aileron flutter. Very shortly after they returned to PA the had a pair of aileron counterbalance weights designed and fabricated for the FS. Little Mike sent me the second set of counterbalance weights for my mkIII. Although they were a little light for the mkIII, they were all I had. I installed them and have never come close to experiencing aileron flutter again, although I am flying with rod end bearings and aileron control components that have about 2,800.0 hours, and are loose as a goose. Do what you want to do, but the above is what works for me, and I don't mean a couple times around the patch, but thousands of hours in every kind of weather and geographic condition you can imagine. john h mkIII Regarding control surfaces, all of them; Will a perfectly balanced aileron, rudder, or elevator, etc, be immune from fluttering during flight? In other words, is it that simple? Balance the flight surface and you will have NO problem with flutter. If that's all it is, it seems pretty easy to make sure I don't have an issue with fluttering, by making sure everything is balanced properly. Mike Welch ________________________________________________________________________________
Date: Jun 23, 2010
Robert: That would be cool, but the Yankees on the Kolb List would have a difficult time interpreting my Alabamanese... You guys would get Hauck overload with all that capacity for words. ;-) john h mkIII ----- Original Message ----- From: Robert Laird To: kolb-list(at)matronics.com Sent: Wednesday, June 23, 2010 11:32 AM Subject: Re: Kolb-List: fluttering control surfaces John -- You need to buy Dragon Naturally Speaking, and then you can just talk to your computer and have it type for you. :-) -- Robert On Tue, Jun 22, 2010 at 4:03 PM, John Hauck wrote: I have my own theory of why, and how to fix, but will not go into it now, typing with two fingers. ________________________________________________________________________________
Date: Jun 23, 2010
> That was my fix, you may choose to do it differently, but the time saved > was significant and when it's all painted the same color not too many > people would know it was different from the kit. > > Best, > > Dave Kulp Dave: Good looking job on the tailboom splice. I'm sure it will pass muster with our resident engineers. However, I wouldn't fly it because that splice would be nagging me in the back of my mind the entire time I was in the air. Right or wrong, I have to be comfortable with what I am flying, or it takes the fun out of it, and that is what flying is all about for me. john h mkIII ________________________________________________________________________________
Date: Jun 23, 2010
On Jun 22, 2010, at 11:16 PM, Dana Hague wrote: > Rick, I feel stupid. I've wondered how one would replace a tailboom > and match the rivet holes. I never thought of the obvious, replace > the H-section with a new undrilled one along with the tailboom. > > -Dana Kolb Rebuilders, The best way to exactly match rivet holes and reuse the H-section is to make a paper tube template. After removing all the rivets and the H-section, wrap the tube tightly with a large piece of paper and tape the paper together so that will remain together in the shape of a paper tube after it is slid off the undamaged end of the boom tube. To secure the paper to the boom, temporarily tape this paper tube to the boom over the rivet holes and the bolt hole and then drill all the holes in the paper. Now you have made an exact template. Carefully slide the paper sleeve from the old boom and slide it in place over the new tube and tape it securely. Carefully center punch and drill the holes in the paper for the main bolt first, and then do the four rivets at the ends of each leg of the H-section. Now carefully reinsert the H-section in place and insert the main bolt. Then rivet the ends of the H-section legs in place, MAKING SURE the H-section legs are WEDGED TIGHT against the inside of the boom tube before riveting. Then center punch, drill, and rivet the remaining holes. p.s. Make sure all burrs are removed from the rivet holes in the H-section before sliding in place. A 2x4 on either side of the boom with a C clamp to squeeze the tube a slight bit will make a tight fitting H- section much easier to install. Gene ________________________________________________________________________________
From: "Kolb Aircraft" <customersupport(at)tnkolbaircraft.com>
Date: Jun 23, 2010
Frank No problem Sir. I wish we could install cage h sections. If Brian had the fuselage here he would be happy to install it. Thank all you guys for the support. Travis Kolb CO. ----- Original Message ----- From: frank goodnight To: kolb-list(at)matronics.com Sent: Wednesday, June 23, 2010 10:48 AM Subject: Re: Kolb-List: Re: New guy with repair questions HI Chris and list, Sorry for the misinformation. Travis thanks for the correct info. Frank Goodnight ------------------------------------------------------------------------- ----- From: Chris_A <50calibercruiser(at)cox.net> To: kolb-list(at)matronics.com Sent: Tue, June 22, 2010 11:38:05 PM Subject: Kolb-List: Re: New guy with repair questions Here is my boom support. When I loaded the firestar the pipe insulation was still intact. The way I secured it was: wrap a towel around the tube then with the tube in the straddle I would wrap a ratcheting strap around the tube and straddle and tighten it up to the point that the foam would start to compress slightly. Then ratchet the base of the straddle to the floor of the trailer. The break occurred immediately after the rear straddle arm. It's pretty clear the tube was bouncing enough to chew through the towel and foam. But the straps were not loose at all. Thanks for the input, Chris Read this topic online here: ________________________________________________________________________________
Subject: Re: fly in lunch planned for thur (24th) Plainwell, Mich. (61D
Date: Jun 23, 2010
Hi Guys ! I will not be able to make it either...I have to work thursday.I am planning on going to Hastings though if anyone else can make that one. chris ambrose M3X/Jabiru a-2200 N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302250#302250 ________________________________________________________________________________
Date: Jun 23, 2010
Thanks Eugene, After spending at least 50 years as a mechanic it never fails to amaze me how little I know . One reason I love the list is that I learn so much from it . I'll remember that little gem you gave us , hope I never have to use it but it sure will be handy if I do. Frank Goodnight ________________________________ From: Eugene Zimmerman <etzimm(at)gmail.com> Sent: Wed, June 23, 2010 12:10:14 PM Subject: Re: Kolb-List: Re: Ko lb-List: New guy with repair questions On Jun 22, 2010, at 11:16 PM, Dana Hague wrote: > Rick, I feel stupid. I've wondered how one would replace a tailboom and match the rivet holes. I never thought of the obvious, replace the H-section with a new undrilled one along with the tailboom. > > -Dana Kolb Rebuilders, The best way to exactly match rivet holes and reuse the H-section is to make a paper tube template. After removing all the rivets and the H-section, wrap the tube tightly with a large piece of paper and tape the paper together so that will remain together in the shape of a paper tube after it is slid off the undamaged end of the boom tube. To secure the paper to the boom, temporarily tape this paper tube to the boom over the rivet holes and the bolt hole and then drill all the holes in the paper. Now you have made an exact template. Carefully slide the paper sleeve from the old boom and slide it in place over the new tube and tape it securely. Carefully center punch and drill the holes in the paper for the main bolt first, and then do the four rivets at the ends of each leg of the H-section. Now carefully reinsert the H-section in place and insert the main bolt. Then rivet the ends of the H-section legs in place, MAKING SURE the H-section legs are WEDGED TIGHT against the inside of the boom tube before riveting. Then center punch, drill, and rivet the remaining holes. p.s. Make sure all burrs are removed from the rivet holes in the H-section before sliding in place. A 2x4 on either side of the boom with a C clamp to squeeze the tube a slight bit will make a tight fitting H-section much easier to install. Gene ________________________________________________________________________________
Date: Jun 23, 2010
I am going to be making me some counter balances, but the only time I had the issue was on my first go around the patch, and was on base and I let my air speed get to high. I flew around the patch several more times after that and had no problems, as long as I keep my airspeed in check the aileron flutter is not a problem. Thanks Greg ----- Original Message ----- From: "David Lucas" <d_a_lucas(at)hotmail.com> Sent: Wednesday, June 23, 2010 5:43 AM Subject: Kolb-List: Re: fluttering control surfaces > > Greg, Whilst not (yet) being a Kolb owner/flyer, I would suggest you take > this 'flutter' problem real, real seriously. Flutter can lead to > structural failure, and not just of the aileron but of the whole wing ! > That's going to really spoil your day ! There are plenty of videos on > YouTube that demonstrate how quickly it can escalate and it doesn't take > much imagination to see the potential consequences. If it were mine, I'd > get those control surfaces balanced so that any flutter potential is way > outside your flight envelope. David. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=302176#302176 > > > ________________________________________________________________________________
Subject: Kolb list -Reusing H-Brace
Date: Jun 23, 2010
I replaced the tailboom tube and reused the H Brace inside and hit every hole right on the money and they was not originally drilled in a perfect straight line, How I did it was mark the old tube so I could get them in exact placement and cut that area out of the damaged tube and place on the outside of the centerline of my new tube then insert the Long bolt through the new tube centerline with original H-brace installed and snug bolt ,"remember which side is which and top and bottom of H-Brace" ,with these pieces on the bolt and through original H-Brace lining up the cente rline of my old pieces to the centerline to my new Tube but to get rid of the rivit pieces inside the original H-Brace I cut the weld on the ends of the tubes and dumped out the rivit ends and rewelded the ends back tog ether this was on an original firestar and yours might not be welded close d I drilled and clecoed the holes on each end both side first and clecoed th em in place then drilled through the rest of the holes clecoing as you dri ll to keep everything snug in place ,this worked for me and this is how I did it I hope this is help to someone Ellery Batchelder Jr. -----Original Message----- From: Dana Hague <d-m-hague(at)comcast.net> Sent: Tue, Jun 22, 2010 11:16 pm Subject: Re: Kolb-List: Re: Ko lb-List: New guy with repair questions When splicing a tube like that, a common method is to use a piece of the original tube, split lengthwise just enough so it will squeeze down into the original tube. Not as strong as the original in torsion, but a simil ar outside sleeve 180=C2=B0 apart would handle that and then some... thoug h close to the tail where this damage should normally be much lower stress ed than farther forward. Based on the pictures, it appears that it's cracked around the bottom.... correct? In this case it looks as though the tailboom was forced upwards aft of this. Where was the support relative to the brek? Rick, I feel stupid. I've wondered how one would replace a tailboom and match the rivet holes. I never thought of the obvious, replace the H-sec tion with a new undrilled one along with the tailboom. -Dana At 10:36 PM 6/22/2010, Richard Girard wrote: The biggest problem would be finding telescoping sizes of tubing. For an internal splice you'd need 4 7/8" .058 or .065 wall. Not exactly a common size. Same for an external sleeve, 5 1/8" .058 wall isn't listed anywhere I can find either. Better to just go the route you've started down and replace the tube. Sinc e you've already been in touch with Travis, have him send you a new "H" fr ame. You'll play hell trying to match up the rivet holes in the old one an d leaving them unfilled and drilling new ones is just asking for a place for cracks to start. -- Why did the chicken cross the Mobius strip? To get to the other, er, um. ... ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jun 23, 2010
Greg, I felt the same way. Between laziness and .... well laziness was it I guess. Then I went on a long leg tour with a FS and an Escapade to a guy's camp in southern NYS. Good ride down but got caught up in strong rollers from the big hills. Airspeed becomes something you can't control. 90 one minute followed by 40. I had serious flutter and was happy to make it to a flat valley where things became normal again. The balancers have kept me happy since. BB On 23, Jun 2010, at 5:36 PM, gtaylor wrote: > > I am going to be making me some counter balances, but the only time I had the issue was on my first go around the patch, and was on base and I let my air speed get to high. I flew around the patch several more times after that and had no problems, as long as I keep my airspeed in check the aileron flutter is not a problem. > Thanks Greg > ----- Original Message ----- From: "David Lucas" <d_a_lucas(at)hotmail.com> > To: > Sent: Wednesday, June 23, 2010 5:43 AM > Subject: Kolb-List: Re: fluttering control surfaces > > >> >> Greg, Whilst not (yet) being a Kolb owner/flyer, I would suggest you take this 'flutter' problem real, real seriously. Flutter can lead to structural failure, and not just of the aileron but of the whole wing ! That's going to really spoil your day ! There are plenty of videos on YouTube that demonstrate how quickly it can escalate and it doesn't take much imagination to see the potential consequences. If it were mine, I'd get those control surfaces balanced so that any flutter potential is way outside your flight envelope. David. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=302176#302176 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 27 Msgs - 06/22/10
Date: Jun 23, 2010
> It's pretty clear the tube was bouncing Do you have pretty stiff suspension on the trailer? Did you hit any pot-holes? A nice list feller was helping me with my two-piece spars on my Kasperwing. He suggested that I slot the inside end of the telescoping spar. Drill and de-burr the end of each slot. This eliminates the stress concentration at the end of the sleeve... er.. spar. GeoB ________________________________________________________________________________
Date: Jun 23, 2010
Eugene Zimmerman wrote: > On Jun 22, 2010, at 11:16 PM, Dana Hague wrote: > > > > Rick, I feel stupid. I've wondered how one would replace a tailboom > > and match the rivet holes. I never thought of the obvious, replace > > the H-section with a new undrilled one along with the tailboom. > > > > -Dana > > > > > > > Kolb Rebuilders, > > The best way to exactly match rivet holes and reuse the H-section is > to make a paper tube template. After removing all the rivets and the > H-section, wrap the tube tightly with a large piece of paper and tape > the paper together so that will remain together in the shape of a > paper tube after it is slid off the undamaged end of the boom tube. To > secure the paper to the boom, temporarily tape this paper tube to the > boom over the rivet holes and the bolt hole and then drill all the > holes in the paper. Now you have made an exact template. Carefully > slide the paper sleeve from the old boom and slide it in place over > the new tube and tape it securely. Carefully center punch and drill > the holes in the paper for the main bolt first, and then do the four > rivets at the ends of each leg of the H-section. Now carefully > reinsert the H-section in place and insert the main bolt. Then rivet > the ends of the H-section legs in place, MAKING SURE the H-section > legs are WEDGED TIGHT against the inside of the boom tube before > riveting. Then center punch, drill, and rivet the remaining holes. > > p.s. > > Make sure all burrs are removed from the rivet holes in the H-section > before sliding in place. A 2x4 on either side of the boom with a C > clamp to squeeze the tube a slight bit will make a tight fitting H- > section much easier to install. > > Gene Gene, Thank you for posting this. This is exactly what I came up with after racking my brain last night. My plan was to do this for both ends of the tube and verify with the plans. Is that an unrealistic expectation? Thank you guys for all the advice, none of it has fallen on deaf ears. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302303#302303 ________________________________________________________________________________
Date: Jun 23, 2010
Dave, your repair looks sharp! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302305#302305 ________________________________________________________________________________
Date: Jun 23, 2010
mdnanwelch7(at)hotmail.co wrote: > > > Thanks for input everyone, > > I did trailer it with the wings attached to the boom. How do you guys with open trailers deal with the wings? The trailer is pretty light weight, I'm not sure what the rating is though. > > Greg > > > > > > Greg, > > I've been listening to everybody's advice opinions, etc. All seems like pretty good info. > Rick G. analized the math behind what happened. Thank God your boom broke on the trailer. That concentrated stress he mentioned could have set up a weak point that may well have broken in flight!! > > Did you get the "H" frame? You absolutely positively need a new one! Trying to use an old one will possibly set up your plane to a potential crash. IMO! > > When you trailer your plane, as has been said, the weight of the wings should NOT be joined onto the boom tube. > For trailering, here is the boom support I built. Note; each wing has it's own cushioned, > pivoting, long pocket. The boom support itself is a 36" long piece of 8" diameter of PVC water pipe (available free from 99.9% of your local water department). The PVC pipe was cut lengthwise, and closes firmly with some latches. I padded it in a couple of layers ofcarpet foam rubber, then wrapped in some nice upholstery fabric). My boom tube is support by 36" of tightly fitted foam (and NO wing weight). > > My design is taken from Uncle Craig (on this list), with my own modifications. If you need more photos, let me know. > > Mike Welch > MkIII > > Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. Mike, I really like your set up. How do you tie the wings down? My email is 50calibercruiser(at)cox.net if you want to email me photos direct. Thanks Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302306#302306 ________________________________________________________________________________
Date: Jun 23, 2010
I am not trying to make anyone mad but have you ever tried to use Paper fo r a template working with Metal I have been a Welder Fabricator most of my life and Paper does not work very well other than to make drawings on Ellery Batchelder Jr. -----Original Message----- From: Chris_A <50calibercruiser(at)cox.net> Sent: Wed, Jun 23, 2010 7:49 pm Subject: Kolb-List: Re: Ko lb-List: New guy with repair questions ugene Zimmerman wrote: On Jun 22, 2010, at 11:16 PM, Dana Hague wrote: > Rick, I feel stupid. I've wondered how one would replace a tailboom > and match the rivet holes. I never thought of the obvious, replace > the H-section with a new undrilled one along with the tailboom. > > -Dana > > Kolb Rebuilders, The best way to exactly match rivet holes and reuse the H-section is to make a paper tube template. After removing all the rivets and the H-section, wrap the tube tightly with a large piece of paper and tape the paper together so that will remain together in the shape of a paper tube after it is slid off the undamaged end of the boom tube. To secure the paper to the boom, temporarily tape this paper tube to the boom over the rivet holes and the bolt hole and then drill all the holes in the paper. Now you have made an exact template. Carefully slide the paper sleeve from the old boom and slide it in place over the new tube and tape it securely. Carefully center punch and drill the holes in the paper for the main bolt first, and then do the four rivets at the ends of each leg of the H-section. Now carefully reinsert the H-section in place and insert the main bolt. Then rivet the ends of the H-section legs in place, MAKING SURE the H-section legs are WEDGED TIGHT against the inside of the boom tube before riveting. Then center punch, drill, and rivet the remaining holes. p.s. Make sure all burrs are removed from the rivet holes in the H-section before sliding in place. A 2x4 on either side of the boom with a C clamp to squeeze the tube a slight bit will make a tight fitting H- section much easier to install. Gene ene, Thank you for posting this. This is exactly what I came up with after rack ing my rain last night. My plan was to do this for both ends of the tube and veri fy ith the plans. Is that an unrealistic expectation? Thank you guys for all the advice, none of it has fallen on deaf ears. Chris ead this topic online here: http://forums.matronics.com/viewtopic.php?p=302303#302303 ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jun 23, 2010
On Jun 23, 2010, at 8:34 PM, Ellery Batchelder Jr wrote: > I am not trying to make anyone mad but have you ever tried to use > Paper for a template working with Metal Yup, Worked perfect for me on the boom tubes and the wing spars on the three major rebuilds that I have done. Nothing wrong with your way though if you don't mind the extra work of cutting apart the old tubes. Gene ________________________________________________________________________________
Date: Jun 23, 2010
Cris, I used a inner tube that I would blow up to provide support for the wings and take the weight off the tail. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: Chris_A To: kolb-list(at)matronics.com Sent: Wednesday, June 23, 2010 8:29 AM Subject: Kolb-List: Re: New guy with repair questions Thanks for input everyone, I did trailer it with the wings attached to the boom. How do you guys with open trailers deal with the wings? The trailer is pretty light weight, I'm not sure what the rating is though. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302218#302218 ________________________________________________________________________________
Date: Jun 23, 2010
Ellery=2C Maybe Gene used stiff paper=2C I don't know. His method seems to work we ll for him. I recall needing to match rivet holes on something once=2C I can't rememb er exactly what it was. If I needed to match all the rivets holes along a line (like a boom tube) =2C I would do this method again=3B 1) First=2C drill out each end rivet completely (just the end rivet!). 2) Then cut a piece of Lexan big enough to cover every rivet hole in the li ne sufficiently (say=2C 2" x 16"). 3) Drill a hole near one end of the Lexan=2C and secure it in place with a cleco=2C to that one drilled hole. 4) Now=2C with the Lexan taped firmly=2C visually line up and drill throug h the other end rivet hole=2C and insert your second cleco. 5) Now=2C you've got a rectangular piece of Lexan stuck in place with a cl eco at each end of the line of rivets. 6) Since it is transparent=2C you can now drill a 1/16" hole perfectly cen tered on each rivet. You do NOT want to drill out the rivet.....it's only a locating hole for every remaining rivet. 7) Next=2C after you've drilled a tiny hole centered on every remaining ri vet=2C remove the Lexan. You can now drill out all the rivets=2C and remov e the "H" brace. 8) When reinstalling the H brace=2C all you need is to do is locate the en d rivet holes=2C and hold the H brace in place with clecos=2C but you'll wa nt to make sure you include your Lexan when you put your clecos in. 9) All that's left is to drill each locating hole deep enough into your bo om tube with that 1/16" drillbit to where when you drill the holes bigger t he 1/8" drillbit doesn't wander. If you've got a good=2C sharp 1/16" drill bit=2C you could probably go ahead and drill each hole all the way through. Lexan may be an alternate for some cases where paper might not work. Just an idea I did once........ Mike Welch MkIII Subject: Re: Kolb-List: Re: Ko lb-List: New guy with repair questions Date: Wed=2C 23 Jun 2010 20:34:14 -0400 From: elleryweld(at)aol.com I am not trying to make anyone mad but have you ever tried to use Paper for a template working with Metal I have been a Welder Fabricator most of my life and Paper does not work very well other than to make drawings on Ellery Batchelder Jr. -----Original Message----- From: Chris_A <50calibercruiser(at)cox.net> Sent: Wed=2C Jun 23=2C 2010 7:49 pm Subject: Kolb-List: Re: Ko lb-List: New guy with repair questions Eugene Zimmerman wrote: > On Jun 22=2C 2010=2C at 11:16 PM=2C Dana Hague wrote: > > > > Rick=2C I feel stupid. I've wondered how one would replace a tailboom > > and match the rivet holes. I never thought of the obvious=2C replace > > the H-section with a new undrilled one along with the tailboom. > > > > -Dana > > > > > > > Kolb Rebuilders=2C > > The best way to exactly match rivet holes and reuse the H-section is > to make a paper tube template. After removing all the rivets and the > H-section=2C wrap the tube tightly with a large piece of paper and tape > the paper together so that will remain together in the shape of a > paper tube after it is slid off the undamaged end of the boom tube. To > secure the paper to the boom=2C temporarily tape this paper tube to the > boom over the rivet holes and the bolt hole and then drill all the > holes in the paper. Now you have made an exact template. Carefully > slide the paper sleeve from the old boom and slide it in place over > the new tube and tape it securely. Carefully center punch and drill > the holes in the paper for the main bolt first=2C and then do the four > rivets at the ends of each leg of the H-section. Now carefully > reinsert the H-section in place and insert the main bolt. Then rivet > the ends of the H-section legs in place=2C MAKING SURE the H-section > legs are WEDGED TIGHT against the inside of the boom tube before > riveting. Then center punch=2C drill=2C and rivet the remaining holes. > > p.s. > > Make sure all burrs are removed from the rivet holes in the H-section > before sliding in place. A 2x4 on either side of the boom with a C > clamp to squeeze the tube a slight bit will make a tight fitting H- > section much easier to install. > > Gene Gene=2C Thank you for posting this. This is exactly what I came up with after racki ng my brain last night. My plan was to do this for both ends of the tube and veri fy with the plans. Is that an unrealistic expectation? Thank you guys for all the advice=2C none of it has fallen on deaf ears. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302303#302303 rget=_blank>http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution _________________________________________________________________ The New Busy is not the too busy. Combine all your e-mail accounts with Hot mail. http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4 ________________________________________________________________________________
Date: Jun 23, 2010
8) When reinstalling the H brace, all you need is to do is locate the end rivet holes, and hold the H brace in place with clecos, but you'll want to make sure you include your Lexan when you put your clecos in. 9) All that's left is to drill each locating hole deep enough into your boom tube with that 1/16" drillbit to where when you drill the holes bigger the 1/8" drillbit doesn't wander. If you've got a good, sharp 1/16" drillbit, you could probably go ahead and drill each hole all the way through. Lexan may be an alternate for some cases where paper might not work. Just an idea I did once........ Mike Welch MkIII >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> i used something similar..... before building the first time i asked a friend with a mil to help by building me a jig, (any machine shop should be able to help build the jig) i had him drill a line of holes 1/2 inch apart in a perfect line in a piece of 1/4 inch thick alum. i would drill one hole then position my drill guide over the piece with a cleco. then using the guide would drill the other end and fasten with a cleco. then i would have a guide to drill the rest of the holes ... all perfectly in line..... all perfectly spaced... and using the guide eliminated the need for center punching migrating drills etc. when re building a part.... just locate the first hole and use the jig. boyd young mkiii ________________________________________________________________________________
Date: Jun 24, 2010
From: "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil>
<< From: "Chris_A" How do you guys with open trailers deal with the wings? >> Hi, Chris - I have an open, flatbed trailer that I use to transport my Mark-3 occasionally. For ground handling and for transporting, I built a tail support dolly, which also contains padded saddles for the wings when they are folded. The wheel assemblies (2) on the dolly have some shock absorption in the form of springs, and this is plenty for the usual in-and-out of the hangar. But for trips on the trailer, I place an old car tire, with partially-inflated inner tube, under the dolly. This provides superb shock dampening for the airplane. I designed the dolly specifically to be able to straddle a car tire for this purpose. Check out George Alexander's excellent website, where he has a folder with a collection of various Kolb trailering ideas. Good luck with your boom tube repair! Dennis Kirby Mark-3, 912ul Sandia Park, NM ________________________________________________________________________________
Date: Jun 24, 2010
Dennis, I found the pictures of your rig on his site, I like the tire idea. But I still don't understand how you keep the wings in their saddles going down the road. Thanks, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302372#302372 ________________________________________________________________________________
Date: Jun 24, 2010
I agree with- Ellery on the paper. I cut the old tube and sectioned it fo r the rivet location. Drilled the two end holes, clecoed it used the sectio n as a template for the rest of the holes. I had to warp my new H section s lightly to be able to use the old boom tube. Just opposite of what has been discussed, and cussed. My H section was very poorly fabricated by original builder. - Carl Tosh Ultrastar Rebuilder, Micro Mong Builder Machinist, Welder, Millwr ight - --- On Thu, 6/24/10, Ellery Batchelder Jr wrote: From: Ellery Batchelder Jr <elleryweld(at)aol.com> Subject: Re: Kolb-List: Re: Ko lb-List: New guy with repair questions Date: Thursday, June 24, 2010, 12:34 AM I am not trying to make anyone mad but have you ever tried to use Paper for a template working with Metal- I have been a Welder Fabricator most of m y life and Paper does not work-very well- other than to make drawings o n Ellery Batchelder Jr. -----Original Message----- From: Chris_A <50calibercruiser(at)cox.net> Sent: Wed, Jun 23, 2010 7:49 pm Subject: Kolb-List: Re: Ko lb-List: New guy with repair questions Eugene Zimmerman wrote: > On Jun 22, 2010, at 11:16 PM, Dana Hague wrote: > > > > Rick, I feel stupid. I've wondered how one would replace a tailboom > > and match the rivet holes. I never thought of the obvious, replace > > the H-section with a new undrilled one along with the tailboom. > > > > -Dana > > > > > > > Kolb Rebuilders, > > The best way to exactly match rivet holes and reuse the H-section is > to make a paper tube template. After removing all the rivets and the > H-section, wrap the tube tightly with a large piece of paper and tape > the paper together so that will remain together in the shape of a > paper tube after it is slid off the undamaged end of the boom tube. To > secure the paper to the boom, temporarily tape this paper tube to the > boom over the rivet holes and the bolt hole and then drill all the > holes in the paper. Now you have made an exact template. Carefully > slide the paper sleeve from the old boom and slide it in place over > the new tube and tape it securely. Carefully center punch and drill > the holes in the paper for the main bolt first, and then do the four > rivets at the ends of each leg of the H-section. Now carefully > reinsert the H-section in place and insert the main bolt. Then rivet > the ends of the H-section legs in place, MAKING SURE the H-section > legs are WEDGED TIGHT against the inside of the boom tube before > riveting. Then center punch, drill, and rivet the remaining holes. > > p.s. > > Make sure all burrs are removed from the rivet holes in the H-section > before sliding in place. A 2x4 on either side of the boom with a C > clamp to squeeze the tube a slight bit will make a tight fitting H- > section much easier to install. > > Gene Gene, Thank you for posting this. This is exactly what I came up with after racki ng my brain last night. My plan was to do this for both ends of the tube and veri fy with the plans. Is that an unrealistic expectation? Thank you guys for all the advice, none of it has fallen on deaf ears. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302303#302303 rget=_blank>http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution =0A=0A=0A ________________________________________________________________________________
Date: Jun 24, 2010
What I forgot to say is I used the sectioned old tube to drill holes to reu se old end hoops of the wings to install new tubes on false spars on Ultras tar. Sorry for the confusion. I think I confused my self. I have old timers you know. I just used original boom tube holes to locate rivet holes for n ew rear H section on the Ultrastar. Carl, Ultrastar Driver in Kansas --- On Thu, 6/24/10, carl tosh wrote: From: carl tosh <carl.tosh(at)yahoo.com> Subject: Re: Kolb-List: Re: Ko lb-List: New guy with repair questions Date: Thursday, June 24, 2010, 6:56 PM I agree with- Ellery on the paper. I cut the old tube and sectioned it fo r the rivet location. Drilled the two end holes, clecoed it used the sectio n as a template for the rest of the holes. I had to warp my new H section s lightly to be able to use the old boom tube. Just opposite of what has been discussed, and cussed. My H section was very poorly fabricated by original builder. - Carl Tosh Ultrastar Rebuilder, Micro Mong Builder Machinist, Welder, Millwr ight - --- On Thu, 6/24/10, Ellery Batchelder Jr wrote: From: Ellery Batchelder Jr <elleryweld(at)aol.com> Subject: Re: Kolb-List: Re: Ko lb-List: New guy with repair questions Date: Thursday, June 24, 2010, 12:34 AM I am not trying to make anyone mad but have you ever tried to use Paper for a template working with Metal- I have been a Welder Fabricator most of m y life and Paper does not work-very well- other than to make drawings o n Ellery Batchelder Jr. -----Original Message----- From: Chris_A <50calibercruiser(at)cox.net> Sent: Wed, Jun 23, 2010 7:49 pm Subject: Kolb-List: Re: Ko lb-List: New guy with repair questions Eugene Zimmerman wrote: > On Jun 22, 2010, at 11:16 PM, Dana Hague wrote: > > > > Rick, I feel stupid. I've wondered how one would replace a tailboom > > and match the rivet holes. I never thought of the obvious, replace > > the H-section with a new undrilled one along with the tailboom. > > > > -Dana > > > > > > > Kolb Rebuilders, > > The best way to exactly match rivet holes and reuse the H-section is > to make a paper tube template. After removing all the rivets and the > H-section, wrap the tube tightly with a large piece of paper and tape > the paper together so that will remain together in the shape of a > paper tube after it is slid off the undamaged end of the boom tube. To > secure the paper to the boom, temporarily tape this paper tube to the > boom over the rivet holes and the bolt hole and then drill all the > holes in the paper. Now you have made an exact template. Carefully > slide the paper sleeve from the old boom and slide it in place over > the new tube and tape it securely. Carefully center punch and drill > the holes in the paper for the main bolt first, and then do the four > rivets at the ends of each leg of the H-section. Now carefully > reinsert the H-section in place and insert the main bolt. Then rivet > the ends of the H-section legs in place, MAKING SURE the H-section > legs are WEDGED TIGHT against the inside of the boom tube before > riveting. Then center punch, drill, and rivet the remaining holes. > > p.s. > > Make sure all burrs are removed from the rivet holes in the H-section > before sliding in place. A 2x4 on either side of the boom with a C > clamp to squeeze the tube a slight bit will make a tight fitting H- > section much easier to install. > > Gene Gene, Thank you for posting this. This is exactly what I came up with after racki ng my brain last night. My plan was to do this for both ends of the tube and veri fy with the plans. Is that an unrealistic expectation? Thank you guys for all the advice, none of it has fallen on deaf ears. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302303#302303 rget=_blank>http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution =nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution =0A=0A=0A ________________________________________________________________________________
Date: Jun 24, 2010
Mike W Laxan works great as you explained I use it my self when I feel the nee d being transparen is a plus Ellery Batchelder Jr. -----Original Message----- From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Wed, Jun 23, 2010 10:15 pm Subject: RE: Kolb-List: Re: Ko lb-List: New guy with repair questions Ellery, Maybe Gene used stiff paper, I don't know. His method seems to work wel l for him. I recall needing to match rivet holes on something once, I can't remembe r exactly what it was. If I needed to match all the rivets holes along a line (like a boom tube ), I would do this method again; 1) First, drill out each end rivet completely (just the end rivet!). 2) Then cut a piece of Lexan big enough to cover every rivet hole in the line sufficiently (say, 2" x 16"). 3) Drill a hole near one end of the Lexan, and secure it in place with a cleco, to that one drilled hole. 4) Now, with the Lexan taped firmly, visually line up and drill through the other end rivet hole, and insert your second cleco. 5) Now, you've got a rectangular piece of Lexan stuck in place with a cle co at each end of the line of rivets. 6) Since it is transparent, you can now drill a 1/16" hole perfectly cent ered on each rivet. You do NOT want to drill out the rivet.....it's only a locating hole for every remaining rivet. 7) Next, after you've drilled a tiny hole centered on every remaining riv et, remove the Lexan. You can now drill out all the rivets, and remove th e "H" brace. 8) When reinstalling the H brace, all you need is to do is locate the end rivet holes, and hold the H brace in place with clecos, but you'll want to make sure you include your Lexan when you put your clecos in. 9) All that's left is to drill each locating hole deep enough into your boom tube with that 1/16" drillbit to where when you drill the holes bigg er the 1/8" drillbit doesn't wander. If you've got a good, sharp 1/16" dr illbit, you could probably go ahead and drill each hole all the way throug h. Lexan may be an alternate for some cases where paper might not work. Just an idea I did once........ Mike Welch MkIII Subject: Re: Kolb-List: Re: Ko lb-List: New guy with repair questions Date: Wed, 23 Jun 2010 20:34:14 -0400 From: elleryweld(at)aol.com I am not trying to make anyone mad but have you ever tried to use Paper fo r a template working with Metal I have been a Welder Fabricator most of my life and Paper does not work very well other than to make drawings on Ellery Batchelder Jr. -----Original Message----- From: Chris_A <50calibercruiser(at)cox.net> Sent: Wed, Jun 23, 2010 7:49 pm Subject: Kolb-List: Re: Ko lb-List: New guy with repair questions ugene Zimmerman wrote: On Jun 22, 2010, at 11:16 PM, Dana Hague wrote: > Rick, I feel stupid. I've wondered how one would replace a tailboom > and match the rivet holes. I never thought of the obvious, replace > the H-section with a new undrilled one along with the tailboom. > > -Dana > > Kolb Rebuilders, The best way to exactly match rivet holes and reuse the H-section is to make a paper tube template. After removing all the rivets and the H-section, wrap the tube tightly with a large piece of paper and tape the paper together so that will remain together in the shape of a paper tube after it is slid off the undamaged end of the boom tube. To secure the paper to the boom, temporarily tape this paper tube to the boom over the rivet holes and the bolt hole and then drill all the holes in the paper. Now you have made an exact template. Carefully slide the paper sleeve from the old boom and slide it in place over the new tube and tape it securely. Carefully center punch and drill the holes in the paper for the main bolt first, and then do the four rivets at the ends of each leg of the H-section. Now carefully reinsert the H-section in place and insert the main bolt. Then rivet the ends of the H-section legs in place, MAKING SURE the H-section legs are WEDGED TIGHT against the inside of the boom tube before riveting. Then center punch, drill, and rivet the remaining holes. p.s. Make sure all burrs are removed from the rivet holes in the H-section before sliding in place. A 2x4 on either side of the boom with a C clamp to squeeze the tube a slight bit will make a tight fitting H- section much easier to install. Gene ene, Thank you for posting this. This is exactly what I came up with after rack ing my rain last night. My plan was to do this for both ends of the tube and veri fy ith the plans. Is that an unrealistic expectation? Thank you guys for all the advice, none of it has fallen on deaf ears. Chris ead this topic online here: http://forums.matronics.com/viewtopic.php?p=302303#302303 rget=_blank>http://www.matronics.com/Navigator?Kolb-List p://forums.matronics.com blank>http://www.matronics.com/contribution ttp://www.matronics.com/Navigator?Kolb-List onics.com w.matronics.com/contribution The New Busy is not the too busy. Combine all your e-mail accounts with Ho tmail. Get busy. ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jun 25, 2010
Subject: RE: Kolb-List Digest: 5 Msgs - 06/24/10
Concerning the installation of the "H" bracket in the boom tube: I preferred not to clamp or put bending pressure on the outside of boom tube... What I did was put the "H" bracket in place and using either 1" or 2" think boards I placed one on the top leg of the "H" bracket and the other on the opposite leg. I then pushed a wedge shaped 2x4 between the two flat boards causing the two bracket legs to flex to a tight fit against the inner walls of the tube. Not much pressure was required and this insured a snug fit between the two ("H" bracket and boom tube) for riveting purposes. As Richard Pike says... "For what it is worth"... Bob ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 5 Msgs - 06/24/10
Date: Jun 25, 2010
> Concerning the installation of the "H" bracket in the boom tube: I > preferred not to clamp or put bending pressure on the outside of boom > tube... > Bob Cabinet maker's/carpenter's wooden clamps work well. Only slight pressure is required to get the job done. john h mkIII ________________________________________________________________________________
Date: Jun 25, 2010
>The best way to exactly match rivet holes and reuse the H-section is to make a paper tube template. I shouldn't even pipe up as I am not a pilot and don't have a Kolb. However, fine points of etiquette have always escaped me so... I have JUST retired after a long and glorious career in GIS. Think automated mapping, spatial analysis, aerial photos, GPS, HUGE plotters and scanners. We quit using paper for critical drawings years ago as it is not dimensionally stable. Paper stretches, humidity affects it, John down the hall leaves it lying around with coffee stains... Maybe use mylar, eh? GeoB ________________________________________________________________________________
Subject: Full Moon
Date: Jun 25, 2010
My wife took this picture of me on final approach Friday evening. ________________________________________________________________________________
Subject: Re: Full Moon
Date: Jun 25, 2010
From: "Eugene Zimmerman" <etzimm(at)gmail.com> > My wife took this picture of me on final approach Friday evening. Nice, unusual photo. john h mkIII ________________________________________________________________________________
Date: Jun 25, 2010
Nice Pic ! Makesme jealous. C. Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ----- Original Message ---- From: Eugene Zimmerman <etzimm(at)gmail.com> Sent: Fri, June 25, 2010 10:41:12 PM Subject: Kolb-List: Full Moon My wife took this picture of me on final approach Friday evening. ________________________________________________________________________________
Date: Jun 26, 2010
Gene, Great photo, indeed. But now you got me wondering. I assume the bright white light at the nose is a landing light but I don't get the orange lights about mid-span on each wing.... sorta makes it look like a twin. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 If live gives you limes, make Margaritas. - Jimmy Buffet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302560#302560 ________________________________________________________________________________
Date: Jun 26, 2010
Tom, I stuck a couple of small LED lights on the top of my lift struts. They are mounted in a small piece of lexan inserted into the top of the strut. They are clear when off, and RED when turned on. Gene On Jun 26, 2010, at 6:01 AM, Thom Riddle wrote: > > Gene, > > Great photo, indeed. But now you got me wondering. I assume the > bright white light at the nose is a landing light but I don't get > the orange lights about mid-span on each wing.... sorta makes it > look like a twin. > > -------- > Thom Riddle > Buffalo, NY (9G0) > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > Tennessee Prop 64x32 > > > If live gives you limes, make Margaritas. > - Jimmy Buffet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=302560#302560 > > ________________________________________________________________________________
Date: Jun 26, 2010
----- Original Message ----- From: "Eugene Zimmerman" <etzimm(at)gmail.com> Sent: Friday, June 25, 2010 7:41 PM Subject: Kolb-List: Full Moon > My wife took this picture of me on final approach Friday evening. Very nice. In the UK ultralight flights are strictly VFR so everything stops at sundown. Officially. a shame this time of year when it is light until around 10 pm Cheers Pat. > > -------------------------------------------------------------------------------- > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 11:35:00 ________________________________________________________________________________
Date: Jun 26, 2010
Pat, "Officially" ? ,,,,,,,,,,,,, simply a man in an office ,,,,,,,, with bigger things to worry about. Unfortunately "Laws" are sometimes out of sync with reality. "Laws" exist for the purpose of the benefit of mankind, not the other way around. ; ) Gene On Jun 26, 2010, at 8:03 AM, Pat Ladd wrote: > > > ----- Original Message ----- From: "Eugene Zimmerman" <etzimm(at)gmail.com > > > To: "Kolb list" > Sent: Friday, June 25, 2010 7:41 PM > Subject: Kolb-List: Full Moon > > >> My wife took this picture of me on final approach Friday evening. > > Very nice. In the UK ultralight flights are strictly VFR so > everything stops at sundown. Officially. a shame this time of year > when it is light until around 10 pm > > Cheers > > Pat. >> >> >> > > > -------------------------------------------------------------------------------- > > >> >> > > > -------------------------------------------------------------------------------- > > > Checked by AVG - www.avg.com > 11:35:00 > > ________________________________________________________________________________
Subject: We now Have another Kolb Pilot
Date: Jun 26, 2010
Congradulations Vic Peters He Soloed His Mk3X this morning in Millinocket Maine Congradulations Vic it only gets better from here on out get right back in and Keep going Ellery Batchelder Jr. ________________________________________________________________________________
Subject: Re: We now Have another Kolb Pilot
Date: Jun 26, 2010
Way to go! I spent the night in the FBO at Millinocket in 1994. Beautful place to fly. john h mkIII Congradulations Vic Peters He Soloed His Mk3X this morning in Millinocket Maine Congradulations Vic it only gets better from here on out get right back in and Keep going Ellery Batchelder Jr. ________________________________________________________________________________
Date: Jun 26, 2010
> Very nice. In the UK ultralight flights are strictly VFR so everything stops > at sundown. Officially. a shame this time of year when it is light until > around 10 pm > > Cheers > > Pat. Patrick: Sun sets at 9:23 PM BST in London tonight. In the States ULs can fly 30 minutes after sundown if they have appropriate anticollision light. john h mkIII ________________________________________________________________________________
Date: Jun 26, 2010
it sure is a nice place to fly I like to head north every time I fly Ellery Batchelder Jr. -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Sat, Jun 26, 2010 8:46 am Subject: Re: Kolb-List: We now Have another Kolb Pilot Way to go! I spent the night in the FBO at Millinocket in 1994. Beautful place to fly. john h mkIII Congradulations Vic Peters He Soloed His Mk3X this morning in Millinocket Maine Congradulations Vic it only gets better from here on out get right back in and Keep going Ellery Batchelder Jr. ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jun 26, 2010
Why thank you men. You can train an old dog new tricks. If an over 60 carpenter can build a Kolb and fly it anyone can. Fact is I can't remember being that scared. I really didn't need the Xtra pair of under garments though. I'm on the ground but I'll be high all day! Vic ________________________________________________________________________________
Date: Jun 26, 2010
----- Original Message ----- From: "Eugene Zimmerman" <etzimm(at)gmail.com> Sent: Saturday, June 26, 2010 5:23 AM Subject: Re: Kolb-List: Full Moon > > Pat, > > "Officially" ? ,,,,,,,,,,,,, simply a man in an office ,,,,,,,, with > bigger things to worry about. > Unfortunately he not only has an office, he has a big stick as well and we don`t have the space to hide in that you have Cheers Pat > .com> >> >> >> ----- Original Message ----- From: "Eugene Zimmerman" <etzimm(at)gmail.com >> > >> To: "Kolb list" >> Sent: Friday, June 25, 2010 7:41 PM >> Subject: Kolb-List: Full Moon >> >> >>> My wife took this picture of me on final approach Friday evening. >> >> Very nice. In the UK ultralight flights are strictly VFR so >> everything stops at sundown. Officially. a shame this time of year >> when it is light until around 10 pm >> >> Cheers >> >> Pat. >>> >>> >>> >> >> >> -------------------------------------------------------------------------------- >> >> >>> >>> >> >> >> -------------------------------------------------------------------------------- >> >> >> >> Checked by AVG - www.avg.com >> 11:35:00 >> >> >> >> >> > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 11:35:00 ________________________________________________________________________________
Date: Jun 26, 2010
Vic, I was considered an old man when I soloed at 29 in 1968. My contemporaries were late teens and early twenties. john h mkIII ----- Original Message ----- From: Vic To: kolb-list(at)matronics.com Sent: Saturday, June 26, 2010 8:47 AM Subject: Re: Kolb-List: We now Have another Kolb Pilot Why thank you men. You can train an old dog new tricks. If an over 60 carpenter can build a Kolb and fly it anyone can. Fact is I can't remember being that scared. I really didn't need the Xtra pair of under garments though. I'm on the ground but I'll be high all day! Vic ________________________________________________________________________________
Date: Jun 26, 2010
----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Saturday, June 26, 2010 5:53 AM Subject: Re: Kolb-List: Full Moon > > >> > Patrick: > > Sun sets at 9:23 PM BST in London tonight. > > In the States ULs can fly 30 minutes after sundown if they have > appropriate > anticollision light. Hi John, you are right . that is the official position. The sun hadn`t set where I was at 3000 feet officer. Honest! Cheers Pat > >many List utilities such as List Un/Subscription, > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 11:35:00 ________________________________________________________________________________
Date: Jun 26, 2010
Vic, excellent! I remember the scared part myself. -and the jubilation of survival. BB On 26, Jun 2010, at 9:47 AM, Vic wrote: > Why thank you men. You can train an old dog new tricks. > If an over 60 carpenter can build a Kolb and fly it anyone can. > > Fact is I can't remember being that scared. I really didn't need the > Xtra pair of under garments though. > I'm on the ground but I'll be high all day! > > Vic > > > > ________________________________________________________________________________
Date: Jun 26, 2010
From: william sullivan <williamtsullivan(at)att.net>
Subject: re: We now have another Kolb pilot
- Vic- Nice going!- Now you get to spend some gas money. - ------------------------- ---------------- Bill Sullivan ------------------------- ---------------- Windsor Locks, Ct. ------------------------- ---------------- FS 447 - ________________________________________________________________________________
Date: Jun 26, 2010
[quote="Eugene Zimmerman"]Tom, I stuck a couple of small LED lights on the top of my lift struts. They are mounted in a small piece of lexan inserted into the top of the strut. They are clear when off, and RED when turned on. Gene [quote] Why do you want red lights facing forward? Or to put it another way, why do you want other pilots to be confused. (I can understand doofus Elton John screwing up, as in "I can see the red tail lights, heading for Spai -ai-ai-ain" but - why are you doing this? Confused Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302637#302637 ________________________________________________________________________________
Date: Jun 26, 2010
LOL, Reverend, pray for me. I can't deny it, I'm a hopeless renegade. But my tail lights are red too. : ) I'm not pretending to be conventional. I don't mind other pilots being confused as long as they see me. The speed I fly they they may just think I'm backing up. Red just happened to be the only color I had on hand when I got the inspiration to increase my visibility. I apologize to any pilot I may have succeeded in confusing with my little red LEDs. Gene Z On Jun 26, 2010, at 10:11 PM, Richard Pike wrote: > Gene > > [quote] > > Why do you want red lights facing forward? Or to put it another way, > why do you want other pilots to be confused. (I can understand > doofus Elton John screwing up, as in "I can see the red tail > lights, heading for Spai -ai-ai-ain" but - why are you doing this? > > Confused Richard Pike > MKIII N420P (420ldPoops) ________________________________________________________________________________
Date: Jun 27, 2010
Subject: parting out an UltraStar
I guess I have to be realistic and say I won't be rebuilding my UltraStar, and might as well part it out now. I'd love to sell intact, but it's a bit overweight, and I missed the deadline to grandfather into Sport Pilot. Here's what I got: wings need fabric. Rotax 447 with B gearbox. Point ignition. Probably time for a rebuild, I put on 300 hours, after I got it used with no record of hours. It's got the 2:1 gear ratio in the gearbox, and I have the other gear that makes it 1.56:1 (i think that's what it was) Matco hydraulic brakes, not differential. BRS chute. Flaperon function, my own design. This cannot be separated from the airframe. 2 props........a 2 blade wood Precision adjustable and a 4 blade UltraProp adjustable. Instruments: dual cylinder temp. dual exhaust temp. tachometer. speedometer. altimeter. Original set of 2 gas tanks, holding 3 gallons between them. 5 gallon seat tank. Com helmet. Delcom handheld radio. Open trailer custom fit to the UltraStar. Make me offers for parts, or all of it together. Machine is located in Central Wisconsin. _Masqqqqqqq(at)aol.com_ (mailto:Masqqqqqqq(at)aol.com)
June 15, 2010 - June 27, 2010
Kolb-Archive.digest.vol-jw
