Kolb-Archive.digest.vol-jx
June 27, 2010 - July 16, 2010
Subject: | Re: We now Have another Kolb Pilot |
Vic,
GOOD for you. And you are fortunate to live in such a wild and beautiful area.
I landed our Cherokee 140 at Millinocket due to low oil pressure on my first x-country
trip in it, on the way to Presque Isle, ME. I learned at that stop that
my new-to-me engine was using oil at the rate of one quart per 3 hours flight.
It turned out that the cylinders were glazed from poor break-in technique after
major overhaul by previous owner.
I sure am glad Millinocket was where it was when the oil pressure went south. Lots
of forest in all directions with no good place to put down a Cherokee.
I know you are going to enjoy your Kolb.
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
If life gives you limes, make Margaritas.
- Jimmy Buffet
http://forums.matronics.com/viewtopic.php?p=302659#302659
----- Original Message -----
Sent: Saturday, June 26, 2010 8:45 PM
Subject: Re: Kolb-List: Re: Full Moon
> > > I don't mind other pilots being confused as long as they see me.
> They will see you alright. And fly straight into you under the
impression that they are behind you. Someone with your ingenuity can surely
come up with a green light for the starboard strut. There are enough
confusing things going on without adding to them on purpose.
Lovely pic though!
Cheers
Pat
> On Jun 26, 2010, at 10:11 PM, Richard Pike wrote:
>> Gene
>> [quote]
>> Why do you want red lights facing forward? Or to put it another way,
>> why do you want other pilots to be confused. (I can understand
>> doofus Elton John screwing up, as in "I can see the red tail
>> lights, heading for Spai -ai-ai-ain" but - why are you doing this?
>> Confused Richard Pike
>> MKIII N420P (420ldPoops)
Checked by AVG - www.avg.com
11:35:00
From: | william sullivan <williamtsullivan(at)att.net> |
- Gene- Nice photo.--I am very surprised at how much those little LED
's stand out.- Color aside, how much power do they draw?- Expense?- D
efinately attention getting.- Probably don't weigh much, either.
----------------- Bill Sullivan
----------------- Windsor Locks, Ct.
----------------- FS 447
LOL
THAT confused, eh ?
I guess I could always fly lower but then I'd be a risk of being run
over by an amish buggy.
Lots of forest in all directions with no good place to put down a
Cherokee.
> Thom Riddle
In addition to a lot of treess, is a lot of water. I remember seeing a
moose and a what I thought was a J3 Cub on floats on my approach to the big
paper mill and Millinocket AP right at dark. Turns out the J3 Cub was
actually a J3 or N3 Kitten ultralight. Looked like a full sized Cub in the
air.
Gene:
I think you previously posted this one, or one nearly like it.
Tugs at my heart strings and makes me want to land right there next to you
all and the gang.
Tremendous contrast in one respect, yet similar thinking and interest on the
other.
Here is something similar to what I actually used.
http://cgi.ebay.com/24-10mm-RED-HOME-DECOR-CARS-Led-Light-Bulb-Pre-Wired-/150460493805?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item230824efed#ht_4461wt_1066
Gene
On Jun 27, 2010, at 8:12 AM, william sullivan wrote:
> Gene- Nice photo. I am very surprised at how much those little
> LED's stand out. Color aside, how much power do they draw?
> Expense? Definately attention getting. Probably don't weigh much,
> either.
> Bill Sullivan
> Windsor Locks, Ct.
> FS 447
I want a big sign that flashes "IRON CITY BEER"
-anon
On 27, Jun 2010, at 3:04 PM, Eugene Zimmerman wrote:
> Bill
ht_4461wt_1066
> Gene
LED's stand out. Color aside, how much power do they draw? Expense?
Definately attention getting. Probably don't weigh much, either.
>> Bill Sullivan
>> Windsor Locks, Ct.
>> FS 447
href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics
>> href="http://forums.matronics.com">http://forums.matronics.com
href="http://www.matronics.com/contribution">http://www.matronics.com/co
ntribution
....Not to beat this already thoroughly dead horse any more than necessary
(do y'all realize we
are approaching SEAFOAM territory with this string...?)...
But...
Both military and civilian aircraft were widely equipped with "passing
lights" in the 1930's and all the way up through the early
1950's. These were powerful, high-intensity red sealed- beam lights about
like landing lights... usually installed in the port wing or the nose,
designed to be turned on during bad visibility, or in high traffic areas to
prevent collisions with approaching head-on traffic. The standard
rule was to clear the oncoming traffic showing the light by turning to your
right, his left.
I can recall them installed in the landing light housings of C-46, C-47,
AT-6, BT-13, Fairchild, Waco, Beech, and many others... Was unable
to find any reference to their use in the current FAR's, but they were
certainly in wide use around airport traffic areas as a safety device
when I was a kid back in the stone age...
Unless the regs have changed, showing a red light in the forward aspect
should not be a problem...been done before.
Worth what ye paid fer it...
beauford
FF-076
Brandon, FL
[quote="Eugene Zimmerman"]Tom,
I stuck a couple of small LED lights on the top of my lift struts.
They are mounted in a small piece of lexan inserted into the top of
the strut. They are clear when off, and RED when turned on.
Gene
Why do you want red lights facing forward? Or to put it another way, why do
you want other pilots to be confused. (I can understand doofus Elton John
screwing up, as in "I can see the red tail lights, heading for Spai
http://forums.matronics.com/viewtopic.php?p=302637#302637
Greetings,
Gene that is a great picture of you and the moon.
I have using LED position lights on my FireStar for about 4 years, the GA
pilots wish they could install them on their airplanes. I posted this vid
eo about 3 years ago, 2 minutes into the video it shows my LED lights very
well.
http://video.google.com/videoplay?docid=-1089406573728651489#
Will Uribe
FireStar II
El Paso, TX
BTW; If John Williamson was still with us he would have posted the FAA Reg
s for us by now.
Sec. 23.1385 - Position light system installation. and Sec. 23.1387 -
Position light system dihedral angles
do y'all realize we are approaching SEAFOAM territory with this string...?
But...
to
r
right, his left.
beauford
FF-076
Gene
do
Subject: | Yamaha powered MKIII for sale |
Hello All,
It is with mixed emotions that I am listing my MKIII for sale. If everything works
out, I will be purchasing another aircraft. I have it listed on Barnstormers
for $18,000 if you would like to see the details and pictures.
Jason
MKIII Yamaha powered
Portland, OR
http://forums.matronics.com/viewtopic.php?p=302779#302779
Will,
Thank you for filling in for John Williams. and for sparing me the
castigation of my >>> good Kolb friends. <<<
>>> NOTE: 91.33(c)(3) of the FAR also applies to anticollision light
installations and allows the color to be either aviation red or
aviation white. <<<
And Thank you for sharing the video. I really like your LED position
lights and I wonder what kind of flasher your system uses?
> FAA Regs for us by now.
> - Position light system dihedral angles
>>> GOOD KOLB FRIENDS <<<
Ooops, Sorry!
My BAD.
I forgot to reduce the size of the picture.
Will, Except for one small detail:
23.1 Applicability.
(a) This part prescribes airworthiness standards for the issue of type
certificates, and changes to those certificates, for *airplanes in the
normal, utility, acrobatic, and commuter categories*. (my underline, RG)
(b) Each person who applies under Part 21 for such a certificate or change
must show compliance with the applicable requirements of this part.
While I don't deny there are lighting standards, or the need for them, this
isn't where to look.
Rick Girard
On Sun, Jun 27, 2010 at 11:18 PM, wrote:
> Greetings,
> pilots wish they could install them on their airplanes. I posted this video
> well.
> Regards,
> Will Uribe
> FireStar II
> El Paso, TX
> Regs for us by now.
> *Sec. 23.1385 - Position light system installation. and **Sec. 23.1387 -
> Position light system dihedral angles*
> do y'all realize we are approaching SEAFOAM territory with this string...?)...
> But...
> right, his left.
> beauford
> FF-076
> Gene
> [quote]
I'm sure glad this doesn't apply to our Kolbs
Rick
23.1 Applicability.
(a) This part prescribes airworthiness standards for the issue of type cer
tificates, and changes to those certificates, for airplanes in the normal,
utility, acrobatic, and commuter categories. (my underline, RG)
s isn't where to look.
Rick Girard
-----Original Message-----
Sent: Mon, Jun 28, 2010 7:32 am
23.1 Applicability.
Rick Girard
Greetings,
well.
Will Uribe
FireStar II
El Paso, TX
s for us by now.
But...
to
r
right, his left.
beauford
FF-076
Gene
do
Thom/John
Your right Trees and Water. We do have the "Golden Road" and 95. Neither one
very
busy. That's probaby not where crap would happen though.
Parachute and some but protection would be the next choice.
Anyone know what happens when a Kolb lands on water?
The guy that gave you a ride to the restaurant here in Millinocket is now
the airport manager.
The N3 Pup is in eastern Maine being rebuilt after running out of fuel.
I was not here in 94' but bought my first part of the Kolb kit then after a
visit to Oshkosh in 92'.
Where you there? Didn't build until 07-08.
Yawl come visit again Y'hear
Vic in Maine
still grinnin
I should have added, unless it's incorporated into the operating limitations
of the aircraft. That's always the kicker.
Rick Girard
> Thanks
> Rick
> 23.1 Applicability.
> this isn't where to look.
> Rick Girard
> From: Richard Girard <aslsa.rng(at)gmail.com>
> To: kolb-list(at)matronics.com
> 23.1 Applicability.
> Rick Girard
>> Greetings,
>> well.
>> Regards,
>> Will Uribe
>> FireStar II
>> El Paso, TX
>> Regs for us by now.
>> But...
>> right, his left.
>> beauford
>> FF-076
>> Gene
>> [quote]
>> _blank">http://www.matronics.com/contribution
> ator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
> ibution">http://www.matronics.com/contribution
Subject: | Re: Yamaha powered MKIII for sale |
Jason,
I pm'd you and sent a message throught barnstormers.
Rich Klarich
Very Interested in both a Kolb for the folding wings and the economical 4 stroke
installation.
http://forums.matronics.com/viewtopic.php?p=302846#302846
Subject: | Tach / regulator problem |
I'm having a bit of an electrical problem on my UltraStar.
The plane has a Westach tach/EGT combo; the tach runs directly off the
lighting coil on the Cuyuna and always worked fine. I just added a Key West
regulator so I can have 12VDC power for my strobe and radio. The tach and
regulator are wired in parallel to the lighting coil (unlike the Rotax, the
Cuyuna has a single lighting coil). No battery. However, with the regulator
connected, the tach reads low.
Here's the weird part. When I first installed the regulator, the read low,
no more than about 2500 rpm indicated at full throttle (6500 rpm). However,
when I switched on the strobe, it read correctly, except for a momentary
blip as the strobe fired. Figuring I needed a load on the regulator, I
added a 50 ohm resistor to the output to draw a constant 1/4 amp. Now it
indicates about 5000 rpm when the engine is actually doing 6500, regardless
of whether the strobe is on or off. I then disconnected the resistor, which
made no difference (still reads 5000). Finally, I disconnected the
regulator, and the tach again reads correctly.
I went up to the airfield yesterday with some other components and test
leads, etc=85 figured on trying a capacitor across the output instead of the
resistor, or a smaller resistor on the input between the tach and
regulator, but it was too hot to fiddle with t=85 much nicer to go up a
couple thousand feet and cool off.
Has anybody else seen this problem?
-Dana
If aliens are smart enough to travel through space, why do they keep
abducting the dumbest people on earth?
Amen, Brother!
Will Uribe
FireStar II
El Paso, TX
PS, We all miss John W who always had a big smile.
Subject: | Re: Tach / regulator problem |
I had a similar situation several years ago when I went through months of weirdness
with my tach and my Key West regulator. Ended up buying a Tiny Tach and have
had no more problems. You wrap a sensing wire around the spark plug lead and
it counts the actual pulses. Simple, reliable and a digital readout.
Richard Pike
http://forums.matronics.com/viewtopic.php?p=302863#302863
Subject: | Re: Tach/regulator problem |
- Dana- Was the base of the regulator grounded?- I don't have experienc
e with your particular hardware, but I have run across situations where a c
ouple of extra ground wires will fix things.- Is your engine grounded to
the airframe?- Regulator grounded to the engine?- Gauge cases grounded?
- Just my first thought.
Bill Sullivan
Windsor Locks, Ct.
FS 447
>weirdness with my tach and my Key West regulator. Ended up buying a Tiny
>Tach and have had no more problems. You wrap a sensing wire around the
>spark plug lead and it counts the actual pulses. Simple, reliable and a
>digital readout.
>Richard Pike
>Read this topic online here:
Why doesn't the fattest man in the world become a hockey goalie?
>digital readout.
>Richard Pike
>digital readout.
I use the Tiny Tach or the similar but better ENM tach on my PPGs, and it's
one alternative I've considered (since I know it will work). Before I do,
though, I'd like to try to get the existing setup working.
At 03:20 PM 6/28/2010, william sullivan wrote:
> Dana- Was the base of the regulator grounded? I don't have experience
> couple of extra ground wires will fix things. Is your engine grounded to
> the airframe? Regulator grounded to the engine? Gauge cases
> grounded? Just my first thought.
Nothing is grounded... the lighting coil is not grounded to the engine, nor
[I think] should it need to be. The engine isn't grounded to the airframe
(it's on rubber mounts), and there's nothing in the Key West instruction
sheet about grounding it (two AC lines in, two DC lines out).
-Dana
From: | "George Alexander" <gtalexander(at)att.net> |
Dana wrote:
> Nothing is grounded... the lighting coil is not grounded to the engine, nor [I
think] should it need to be. The engine isn't grounded to the airframe (it's
on rubber mounts), and there's nothing in the Key West instruction sheet about
> -Dana
Dana:
Couple of thoughts.....
Grounding... since it is your intent to use the KW Reg/Rect to power your radio,
you may want to do what most with a similar set up do. Ground strap from the
engine to the airframe. After strap is installed, check to see if the case
of the KWR/R is grounded through its mounting hardware to the engine block.
It should be, but if not, add a strap to make it so.
Wiring.... you had said in your first post that you wired the tach and the KWR/R
in parallel. Don't know what the input stage of both the tach and the KWR/R
are and even if I did, don't remember enough of my basic electronics to mean
anything, but that configuration just doesn't sound right to me. May be pulling
too much of a load for the lighting coil.
I have a vague recollection that instructions with the KWR/R called for wiring
it in series if you were using a lighting coil driven strobe. I know that this
is not what your situation is, but the circuitry might be similar enough to warrant
doing it the same way.
Another alternative is to connect the tach to something other than the lighting
coil. If you don't have a tach lead on the Cuyuna, maybe the kill switch?????
Westach can give you information that is far more valuable than mine.
George Alexander
FS II R503 N709FS
http://www.oh2fly.net
http://forums.matronics.com/viewtopic.php?p=302912#302912
Subject: | Sport Pilot license |
From: | Duane Ransdell <radiobluebook(at)gmail.com> |
Hi everyone,
Just wondering how many of you have earned your Sport Pilot's license or did
you find it easier to just get a Private Pilot license? I'm finding that it
is a real hassle to get certified.
Duane
>radio, you may want to do what most with a similar set up do. Ground
>strap from the engine to the airframe. After strap is installed, check to
>see if the case of the KWR/R is grounded through its mounting hardware to
>the engine block. It should be, but if not, add a strap to make it so.
Shouldn't matter, but it's one thing I'll try if nothing else works. It's
only power to a handheld radio and GPS, so they don't need an airframe ground.
>KWR/R in parallel. Don't know what the input stage of both the tach and
>the KWR/R are and even if I did, don't remember enough of my basic
>electronics to mean anything, but that configuration just doesn't sound
>right to me. May be pulling too much of a load for the lighting coil.
>wiring it in series if you were using a lighting coil driven strobe. I
>know that this is not what your situation is, but the circuitry might be
>similar enough to warrant doing it the same way.
Lighting coil strobe is a different animal. The tach (according to
Westach, who also suggested some things to try) needs at least 7VAC to
operate, and unlike a strobe, it won't pass enough current to the regulator.
>lighting coil. If you don't have a tach lead on the Cuyuna, maybe the
>kill switch????? Westach can give you information that is far more
>valuable than mine.
No tach lead on the Cuyuna; the lighting coil is where it's supposed to
go. Hopefully tomorrow's weather will be good enough to spend some time at
the airfield.
-Dana
I started out with nothing. I still have most of it left.
Subject: | RE: Kolb-List Digest: 20 Msgs - 06/26/10 |
Congratulations Vic on your first flight in the Kolb. That is wonderful and encouraging.
I had the privilege of flying out of Millinocket airport several years
ago in a Cherokee when visiting a friend who started and established Tri-Town
Baptist Church in E. Millinocket. Was impressed with Catoddin Mtn. (spelling?).
Beautiful area. He has moved on to bigger planes and flys out of Sanford.
I am still working on my Mark III X. To take delivery of the VW engine
from Great Plains this month while at EAA. I did not get a copy of photo of
your plane. Can you post it again?
Subject: | FireStar Tail Wheel Rod/Spring |
Hi Guys,
My Original FireStar has suffered some damage. In January a severe wind
storm caused an 80' tall pine tree to snap off at the 40' high point, which
then fell onto my hangar. The hangar is one of those instant car garages,
consisting of round metal roof rafters and a canvas cover. It is 12' wide
X 24' long and I fold the wings on the Kolb to park it inside. The tree
fell onto the hangar longitudely, that is, it did not fall directly on top of
the Kolb (well a few branches did) because it hit slightly off the center
line on the left side. But, the hangar rafters were bent down and they
contacted the left folded wing, destroying the aileron, leading and trailing
wing spars, bent some ribs and the bow tip was crumpled. The main spar was
ok. Since the wing was pushed downward really hard, it tore out the wing
support cross tube that goes thru the boom tube. Both of the outer ends of
the elevators were damaged. Rudder was OK. The tail wheel, which was
sitting in the tail wheel dolly, was broken at the welded joint and the
fiberglass tail spring rod was broken where it exits the steel tube on the plane.
Some other damage was: Dented muffler, but still usable; Fuselage fabric
support bent down and fabric torn on left side.
I have already rebuilt the wing, built a new aileron and repaired the
elevators. Also have stripped all the fabric off the fuselage (it was 15 years
old) and will recover it.
Question. I got a new 3/4" aluminum tail wheel rod/spring from Travis.
It fits kind of loose into both the tail wheel bracket and the steel
fuselage tube. What is a good way to shim this to make a better fit. (The
original fiberglass rod was epoxied in place and was a bear to drill out. I
don't want to do that to the metal rod.)
Bill Varnes
Original Kolb FireStar
Audubon NJ
Subject: | Re: FireStar Tail Wheel Rod/Spring |
Bill,
I had a similar problem with a gear leg repair. I used some aluminum tape to take
up the slack. It worked fine for me.
Sorry to hear about the damage report, good luck with it.
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
http://forums.matronics.com/viewtopic.php?p=302955#302955
Subject: | Re: Sport Pilot license |
Duane,
I don't mean to piss you off but risk doing so by the following statement/question.
I apologize in advance if you take offense.
Logisitics and expense asside, if you "already know how to do what they require"
why is being tested to that standard frustrating?
I am no longer a practicing CFI-SP and am letting my certificate expire but can
tell you from my experience that there are lots of sport pilots (as well as private
and commercial too) flying around the skies who are not well prepared for
anything out of the ordinary. Learning to fly better is a life-long experience
and being prepared for the unexpected is a big part of that learning.
So, rather than looking at the need to get certificated as being a hassle, I suggest
you look at it as a forced opportunity to learn more/better/different ways
to do things. The only tests you need to take are the written and the check-ride.
The rest is learning new/better/different things which will make you a
better/safer pilot.
My BFR is due next month. I'm going to get my BFR in a Pitts S2 because I want
to learn more about recovering from unusual attitudes and some basic aerobatic
maneuvers. I've had a private ticket since 1966 and still consider myself a student
of flying.
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Jimmy Buffet
http://forums.matronics.com/viewtopic.php?p=302961#302961
Bill, you could try cleaning out the tube ends and smearing a coating of
epoxy inside and then drilling or honing to a good fit.
I think someone makes epoxy with little metal particles in it.
Since it's not a safety in flight area a little experimentation wouldn't
hurt.
BB
On 28, Jun 2010, at 10:55 PM, WhiskeyVictor36(at)aol.com wrote:
> Hi Guys,
wind storm caused an 80' tall pine tree to snap off at the 40' high
point, which then fell onto my hangar. The hangar is one of those
instant car garages, consisting of round metal roof rafters and a canvas
cover. It is 12' wide X 24' long and I fold the wings on the Kolb to
park it inside. The tree fell onto the hangar longitudely, that is, it
did not fall directly on top of the Kolb (well a few branches did)
because it hit slightly off the center line on the left side. But, the
hangar rafters were bent down and they contacted the left folded wing,
destroying the aileron, leading and trailing wing spars, bent some ribs
and the bow tip was crumpled. The main spar was ok. Since the wing was
pushed downward really hard, it tore out the wing support cross tube
that goes thru the boom tube. Both of the outer ends of the elevators
were damaged. Rudder was OK. The tail wheel, which was sitting in the
tail wheel dolly, was broken at the welded joint and the fiberglass tail
spring rod was broken where it exits the steel tube on the plane. Some
15 years old) and will recover it.
Travis. It fits kind of loose into both the tail wheel bracket and the
steel fuselage tube. What is a good way to shim this to make a better
fit. (The original fiberglass rod was epoxied in place and was a bear
to drill out. I don't want to do that to the metal rod.)
> Bill Varnes
> Audubon NJ
(The original fiberglass rod was epoxied in place and was a bear to
Bill Varnes
Audubon NJ
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>if you put a small amount of
silicone rubber on the tail rod, and inside the socket, bolt it in
place and wipe off the excess, let it sit a couple days till the
silicone sets up before putting on the ground. the rod will be much
more solid. but if you need to get it out you can twist and break the
silicone looseand pull it out. it will also keep the rust out.boyd
young mkiii
Boyd:
I did that once, used silicone seal on the tail wheel strut.
Upon removal, some time later, I discovered extensive corrosion.
I don't use silicone seal on 4130 anymore.
if you put a small amount of silicone rubber on the tail rod, and
inside the socket,
bolt it in place and wipe off the excess, let it sit a couple days till
the silicone sets up before putting on the ground. the rod will be much
young mkiii
Duane, 4 years ago it was difficult getting the certificate as there were few aircraft
to get the training in. I had to drive many miles to find a CFI who would
do it for me. I had been flying the Firestar for 19 years and just needed
time in a larger aircraft to pass the checkride. I did this before the grandfather
period ended. I thought at the time that I would only be flying the single
seat Firestar. Since then, I've bought the Kolbra and I'm having a ball taking
my wife along and giving rides. I think getting the Sport license is easier
now as there are more Sport CFI's and aircraft to train in. It shouldn't be a
problem except that it takes time and money.
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=302981#302981
Bravo Thom! Like the examiner told me as he handed me my ticket, "It's a
license to learn". And one helluva great classroom, to boot.
Rick Girard
On Tue, Jun 29, 2010 at 6:29 AM, Thom Riddle wrote:
> Duane,
> statement/question. I apologize in advance if you take offense.
> require" why is being tested to that standard frustrating?
> can tell you from my experience that there are lots of sport pilots (as well
> as private and commercial too) flying around the skies who are not well
> prepared for anything out of the ordinary. Learning to fly better is a
> life-long experience and being prepared for the unexpected is a big part of
> that learning.
> I suggest you look at it as a forced opportunity to learn
> more/better/different ways to do things. The only tests you need to take are
> the written and the check-ride. The rest is learning new/better/different
> things which will make you a better/safer pilot.
> want to learn more about recovering from unusual attitudes and some basic
> aerobatic maneuvers. I've had a private ticket since 1966 and still consider
> myself a student of flying.
> Thom Riddle
> Buffalo, NY (9G0)
> Jabiru 2200A #1574
> - Jimmy Buffet
Bill,
Seems like all of them fit a little loose.I tried this and it works really
well.first hacksaw 2 cuts in the tube end,one vertical and one horizontal
,which lets the tube end compress around the new rod.Also drilled a new ho
le through the tube and rod, (near the old hole) for good register at that
attach point.Its a 2 piece aluminum clamp using counter sunk cap screws.
G.Aman MK-3C
Sent: Mon, Jun 28, 2010 10:55 pm
Subject: Kolb-List: FireStar Tail Wheel Rod/Spring
Hi Guys,
ch then fell onto my hangar. The hangar is one of those instant car garag
es, consisting of round metal roof rafters and a canvas cover. It is 12'
wide X 24' long and I fold the wings on the Kolb to park it inside. The
tree fell onto the hangar longitudely, that is, it did not fall directly
on top of the Kolb (well a few branches did) because it hit slightly off
the center line on the left side. But, the hangar rafters were bent down
and they contacted the left folded wing, destroying the aileron, leading
and trailing wing spars, bent some ribs and the bow tip was crumpled. Th
e main spar was ok. Since the wing was pushed downward really hard, it to
re out the wing support cross tube that goes thru the boom tube. Both of
the outer ends of the elevators were damaged. Rudder was OK. The tail
wheel, which was sitting in the tail wheel dolly, was broken at the welde
d joint and the fiberglass tail spring rod was broken where it exits the
steel tube on the plane. Some other damage was: Dented muffler, but stil
l usable; Fuselage fabric support bent down and fabric torn on left side.
I have already rebuilt the wing, built a new aileron and repaired the elev
It fits kind of loose into both the tail wheel bracket and the steel fuse
lage tube. What is a good way to shim this to make a better fit. (The or
Bill Varnes
Audubon NJ
john
when i pulled mine apart i found no corosion at all.... as i remember
i had run some epoxy primer on the inside before assembly. i may
recheck for the fun of it.
boyd
Boyd:
inside the socket,
young mkiii
Non acetic acid silicone is likely less reactive with cro molly steel.. Herb
At 12:54 PM 6/29/2010, you wrote:
>john
>remember i had run some epoxy primer on the inside before
>assembly. i may recheck for the fun of it.
>boyd
>Boyd:
>john h
>mkIII
> inside the socket,
>let it sit a couple days till the silicone sets up before putting on
>the ground.
>the rod will be much more solid. but if you need to get it out you
>can twist and break the silicone loose
>boyd young mkiii
Subject: | construction oddities |
I've found a few oddities in the construction of my UltraStar, mostly in
the control system. A few were scary and all have been corrected. Today I
was looking at the drawings to identify the tailwheel strut tube size
(since mine is bent), and I noticed that the lower tail brace wires go to a
bolt on the rear vertical tube of the lower fin. That's funny... mine go
to the forward of the two bolts holding the tailwheel strut into the
fin. I did some careful poking and sure enough, the proper holes are in
fact there, under the fabric.
Considering the loads on the tail wires, it's probably not a big deal,
unless landing loads were to fatigue the bolt in question. Still it will
be fixed.
Fortunately the distance is the same, within the add/remove washers
adjustment method, so all I have to do is dig up another AN3 bolt of the
proper length.
-Dana
If there was any logic in this world, it would be men who ride
side-saddle, not women.
Thanks for the reply Ralph. I spoke with the EAA and got a few of my
questions answered. They guy who answered the phone was most helpful. If
anyone else has questions about Sport Pilot's license you can call them at
920-426-6527. The gentleman I talked to was Tim.
Turns out I can't use any of my ultralight time as dual instruction as I
originally thought. You can still use ultralight time for the solo portion
of your training, but that's it. 'What that means is that I will need to get
9 more hours of instruction from another CFI and then go back and take my
check ride. You also need to have the written passed and a recommendation
from the other CFI before you go back to do the check ride.
As much of a hassle this is turning into, I think I will get my private
pilot's license instead.
Duane
> few aircraft to get the training in. I had to drive many miles to find a CFI
> who would do it for me. I had been flying the Firestar for 19 years and just
> needed time in a larger aircraft to pass the checkride. I did this before
> the grandfather period ended. I thought at the time that I would only be
> flying the single seat Firestar. Since then, I've bought the Kolbra and I'm
> having a ball taking my wife along and giving rides. I think getting the
> Sport license is easier now as there are more Sport CFI's and aircraft to
> train in. It shouldn't be a problem except that it takes time and money.
> Ralph
> Ralph B
> N91493 E-AB
> 1000 hours
> 23 years flying it
> Kolbra 912UL
> N20386
> 2 years flying it
> 120 hrs
Sincerely,
Duane
www.amateurradiobluebook.com
Note: If you forward this email, please delete the forwarding history, which
includes my email address.
Thanks for the reply Thom. No offense taken and that is exactly the attitude
I'm taking with this. I'm always game for learning how to fly better. The
test doesn't offend me either and in fact I welcome that. It's the waiting
for an instructor and expense that goes along that is frustrating.
Duane
> Duane,
> that learning.
> Thom Riddle
> Buffalo, NY (9G0)
> Jabiru 2200A #1574
> - Jimmy Buffet
Sincerely,
Duane
The second time is the charm, I guess. The first time I shot this video I
didn't see the streaks on the wind screen until I watched the video footage
so yesterday I was extra thorough in making sure the lexan was spotless.
Anyway here's the link:
http://www.youtube.com/watch?v=BtZEOa1h_bc
Rick Girard
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Looks good Rick. Now all you need to do is a touch and go on every sand
bar, or stop and do a little fishing.
Larry
which includes my email address.
Sent: Wednesday, June 30, 2010 3:44 PM
Subject: Kolb-List: New Video
video I didn't see the streaks on the wind screen until I watched the
video footage so yesterday I was extra thorough in making sure the lexan
was spotless. Anyway here's the link:
Rick Girard
Some of the sandbars certainly look long enough, but I'd have to get out on
them to look them over before I'd try it. Sure would be fun, though.
Rick
> Larry
> *From:* Richard Girard
> *To:* kolb-list(at)matronics.com
> *Sent:* Wednesday, June 30, 2010 3:44 PM
> *Subject:* Kolb-List: New Video
> Rick Girard
> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
> href="http://www.matronics.com/contribution">http://www.matronics.com/c*
outstanding! Now we know what IFR really means.
BB
> Rick Girard
Rick,
Here in Ohio the dawn is before 6:00 this time of year.Absolutely my favor
ite flying time.It's just tough to get any of the other guys out of the sa
ck that early so it's a solo most of the time.Nice video!
G.Aman Mk3-C Jabiru 2200A
Sent: Wed, Jun 30, 2010 5:44 pm
ge so yesterday I was extra thorough in making sure the lexan was spotless
Rick Girard
Those sand bars look very doable to me. Some look like they have a lot
of gravel in them, which makes them even more suitable.
Before one lands out, they must accept the fact that if they break the
airplane, it may be very difficult to retrieve for repair.
out on them to look them over before I'd try it. Sure would be fun,
though.
Rick
From: | "Gene & Tammy" <zharvey(at)bentoncountycable.net> |
Retrieving a plane off the sand bar looks simple to me. Do it by
water. In Alaska we land on sand/gravel bars all the time. You just
need to look them over carefully before you set down.
Gene
Sent: Wednesday, June 30, 2010 7:36 PM
Subject: Re: Kolb-List: New Video
though.
Rick
Hauck and Herb,
Regarding my Question: I got a new 3/4" aluminum tail wheel rod/spring
from Travis. It fits kind of loose into both the tail wheel bracket and the
steel fuselage tube. What is a good way to shim this to make a better fit?
Thanks to all of you for giving me some good ideas to modify the tail rod
installation. I am leaning toward using metal tape wrapped around the rod
for a snug fit. In fact I already tried it on the tail wheel end and it
works great.
Bill Varnes
Audubon NJ
Well...I have been fortunate enough to make quite a few off field and
sand bar landings in my mkIII, in Alaska, my self, Knik River, a spot
somewhere near the Dalton Highway south of Cold Foot, an unknown river
30 miles east of Deadhorse, and on the beach of the Arctic Ocean 12
miles south of Barrow, where Wiley Post and Wil Rogers were killed in
1935, to name a few. Some of those would have taken a helicopter and a
lot of money to retrieve me and my mkIII.
Many of the sand bars on the Tallapoosa, Coosa, and Alabama Rivers are
very landable, but to rescue a broken mkIII would be very difficult and
expensive.
I had my Ultrastar rescued from a swamp 1/2 mile from Wetumpka Airport
08A by an old H-19, in 1985. Lucky for me, my buddy owned and flew the
H-19. It didn't cost me more than a six pack. Without the helicopter,
it would have been a very difficult mission to accomplish.
Gene
From: | TheWanderingWench <thewanderingwench(at)yahoo.com> |
Subject: | Are SkiDoo Rotax parts the same as from CPS, Lockwood, etc? |
I'm being told that you can get genuine Rotax engine parts (e.g. pistons - with
the same part numbers as in CPS, LEAF or Lockwood catalogs) from Ski Doo dealers
- at a significant savings.
Anyone know whether this is true or not? They probably won't sell to someone who
says they're for aircraft use. But I'd like to know if anyone knows if Ski Doo
uses the same parts we use.
ArtySandy, Oregon
www.LessonsFromTheEdge.com/uladventure2009.htm
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
I made my statement tongue and cheek, about the touch and goes, but if I
was going to do it, I would use the same technique that works in snow.
Touch it down lightly with lots of power, let it settle a bit, then go
around and see what kind of a rut you made. One thing that seemed
noticeable to me was that it seemed to take a lot of ground for you to
take off on the grass. Once in the air it climbed pleasingly quickly,
but I thought that it took a lot of runway to get off. Hard to tell on
video. My point is don't short your self, because sand if it is fluffy
will cause a lot of drag. I have never had the guts to do a water skiing
routine with mine, so I don't know how fast you need to be to "walk" on
water.
On my trip back from Texas with the Firestar, I touched down on the
Great Salt Lake. It felt gooey, so I pulled all the throttle I could get
and got back on top of it and got off the ground. I almost needed a
change of pants afterward realizing what would have been if I had slowed
too much to get back airborne.
Have fun, but do it carefully,
Larry
Sent: Wednesday, June 30, 2010 10:07 PM
expensive.
Gene
John,
Sounds like you had a great vacation in Alaska. Knik River has good
gravel bars and lots of time the biggest danger is staying out of the
other aircrafts way as they land and takeoff. It's a great one to
practice on, being so close to the Anchorage, Palmer, Wasilla and
Birchwood Airports. Lots of streams with-in 30 miles of Dead horse, but
the only river I can think of with-in 30 miles of Deadhorse, is the
Colville River, but it is to the West, towards Barrow. The Helmericks
have a very nice house on the Colville and know the area better than
anyone else and are a good source of local knowledge. A lot of the bars
on it can be a real bear to land on, as a lot of it is soft sand (had a
landing craft stuck on one for several days) While you were up there I
think you received some misinformation on the Wiley Post crash, as he
crashed on a small lake (he was on floats) and not on the beach. Most
of the beaches are great to land on. The biggest problems I've had in
that area are the mosquitoes and the Arctic Fog. Most anywhere you bust
up a plane in Alaska is going to be pricy. I have a friend that all he
does is recover downed planes and he makes a really good living.
The only reason I suggested recovery by water is that the river he was
flying over appeared to be large enough to get a boat and barge to the
sandbar if needed. I thought that would be a whole lot cheaper than
trying to get to it over land. I don't know the area, so I could be
dead wrong.
Sounds like your Alaska trip was a trip of a life time. Where did you
start from? Any chance you wrote something up? Bet it would make
interesting reading and I would be very interested to read it. How did
the Kolb do and what engine did you use? Any changes you'd make to the
plane/engine if you were to do it again?
Sounds like you're a really high time Kolb pilot/owner. When you have
the time, how about a write up on each Kolb you have owned or flown,
with what engine and any other info for a Kolb newbe like myself? I'm
the new owner of a previously owned Firestar KXP, but have been too sick
with Chemo to fly it. Any info would be greatly appreciated.
Thank You
Gene
Firestar KXP N71RB
For most of the sand bars the way into them from land is footpaths so the
only real access to get a plane out would be the river and that bridge at
the beginning of the footage has neither height nor span enough to take a Mk
III. Still, on the right day I could give any bush pilot tendencies I might
have a good try out......
Rick
> john h
> mkIII
> Rick
Excellent video, Rick. I especially liked your near redline dive towards the river
and the hard slip on final approach. That yaw string was really out there.
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Jimmy Buffet
http://forums.matronics.com/viewtopic.php?p=303235#303235
I have had many great trips to Alaska, three flights from Alabama, in my
Kolb mkIII.
The gravel bar I landed on was 30 miles (aprx) east of Deadhorse on the
Canning River, south of Brownlow Point.
I know Jim and Teena Helmericks. Have stayed with them the last two
flights to the North Slope.
I didn't say Wiley Post and Wil Rogers crashed on the beach, I said I
landed there, beside the monuments on the sand dune between the lagoon
they crashed in and the beach I landed on. Problem with the beach there
was extremely dry soft sand laced with many large river rocks.
I wrote an article about my 1994 flight. You can pull it up on the EAA
archives. I think it was published in the May, June, July, August, and
September 1995 issues of the EAA Experimenter Mag.
I have written a lot about my Kolbs and flights since I joined the Kolb
List in 1998. That stuff can be retrieved from the Kolb List Archives.
Are you still in Alaska? Where?
Sent: Thursday, July 01, 2010 2:59 AM
John,
dead wrong.
Thank You
Gene
Firestar KXP N71RB
Subject: | Re: Are SkiDoo Rotax parts the same as from CPS, Lockwood, |
etc?
Hi Arty,
There could easily be some subtle differences and I'm sure part numbers are different.
Use a part from another application may prove disastrous and more expensive
in the long run if it is different. I don't think this one is worth the
risk.
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=303270#303270
The url for my Alaska web site is on my computer at my house.
Anybody got that one handy they can give Gene.
Sent: Thursday, July 01, 2010 8:51 AM
my Kolb mkIII.
etc?
Hi Arty, back when I was using a 532, there were occasions when I needed something
simple, like the seal that runs around the head to cylinder joint, cylinder
base gaskets, o-rings, stuff like that and I would get them at the local Seadoo
dealer. Couldn't tell any difference between them and the parts I was replacing.
If I could look up the part number online, I could see that for some parts, the
aircraft engine part and the Seadoo/Skidoo part was the same except that the
aircraft version had an extra prefix. If it was something simple like a gasket
or o-ring, I would get it locally for much less and never had a problem. Would
not consider doing that for anything like wrist pins or pistons, but the boat/sled
prices are sure a lot better.
For the 582, it has been all "approved" parts. But then, I haven't had to work
on it much, just check the rings at each annual, verify that they are still free,
look at the underside of the head and verify that there is no carbon, and
button it back up. (Love that Phillips Injex!)
Richard Pike
http://forums.matronics.com/viewtopic.php?p=303288#303288
> john h
> mkIII
John et al:
There is the material that your son put on the web......
If that's what you are talking about, it is at:
http://webpages.charter.net/kawasaki1/Hauck/
or..
through my web site at:
then
"Kolb Related Web Sites"
then
"John's Jaunts"
George Alexander
FS II R503 N709FS
http://forums.matronics.com/viewtopic.php?p=303289#303289
> or..
> then
> then
> "John's Jaunts"
> George Alexander
> FS II R503 N709FS
Thanks, George.
You da man.
Dennis did a good job on that excursion.
We get into a lot of situations we do no like, but I feel is all part of
the exciting game of building and flying Kolb airplanes.
I would not take a million dollars for all my good and bad experiences
with Kolbs. Sure don't want to repeat a lot of my episodes.
Hi my extra project got the wammy put on it by a tornado.
I'm trying to source a new boom tube localy. If anyone knows
the size, lenght ect... I would greatly appreaciate it.
http://forums.matronics.com/viewtopic.php?p=303310#303310
Subject: | Re: Xtra boom tube specs |
- I got my boom tube from Travis at Kolb.- Prompt service, factory supp
lied, reasonable price, and delivered right to my door.- Also, where are
you?
----------------------Bill Sull
ivan
--------------------- Windsor Loc
ks, Ct.
--------------------- FS 447
From: | "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil> |
Kolb Friends -
I have decided to buy a new com radio for my Kolb, and seek the
collective advice of this List.
For the past 9 years, I have been using an old (ealy-90s era) Terra
handheld, and it finally died on my last flight, earlier this week. Not
worth repairing, I suspect. And so, I am in the market for a "real"
aircraft radio (not a hand-held) that I can mount permanently in (or
maybe under) my panel.
I have narrowed my choices down to three non-certified models: the
Microair-760, the Icom-A210, and the MGL-V10. All 3 feature a built-in
intercom. Each is about a thousand bucks.
Do any of our Kolb flyers have any experience with either of these
radios?
Pros/cons?
Features you like?
I'm especially wanting to know how well the intercom works in the loud
cockpit environment of our Kolbs.
Any/all advice offered will be helpful.
Many thanks -
Dennis Kirby
Mark-3, 912ul, "Magic Bike"
Sandia Park, NM
From: | "Kolb Aircraft" <customersupport(at)tnkolbaircraft.com> |
Subject: | Re: Xtra boom specs |
The tube should be 6 inch Diameter X 058 wall thickness.
The alloy is 6061 T6
The length of the Boom is 14 foot,6 inch.
If you do find a source please let us know because I am now having to have
them extruded for Kolb as a special production run.
Kind Regards
Travis
Kolb CO.
Sent: Thursday, July 01, 2010 12:07 PM
Subject: Kolb-List: Xtra boom specs
> Thanks
Hey Dennis=2C
Regarding radios=3B I have my Icom A200 (I assume the A210 isn't too muc
h different).
Sure feels sturdy=2C and from me playing with it on the dining room table
=2C it sure works great!
So=2C I'd say go for the Icom. I like it. It's attractive=2C it's simple
=2C it has standby for the second frequency (flip-flop). What more could y
ou want?
There are a couple of other radios you could consider. I also have a Nar
co 810 com radio. I bought it for my GlaStar. It also would make a great
panel mount radio!! It is TSO'd=2C for what it's worth. I bought it off e
Bay for $825 from an avionics repair center=2C and it came with a yellow ta
g. It is virtually the same size as my Icom A200.
I used to have a complete Terra avionics stack in my first Cessna 172. I
had the old Terra bush-button panel mount radio. It worked great=2C no co
mplaints=2C but I think I'd recommend the Terra digital panel mount radio
=2C compared to my older version.
I think you have lots of good choices=3B
1)the Icom A210 (or A200) (my personal favorite)
2)the Narco 810 (digital w/flip flop feature) ( another excellent choice!)
3)the Terra digital (not a bad radio!)
4)the MGL (no experience with this one)
5)the Microair ( I knew a guy that had one=2C it was ok)
This would be my recommendation....in that order.
Just my opinion.............
Mike Welch
working on my radio stack/pod=2C lately
Subject: Kolb-List: Radio Advice
Date: Thu=2C 1 Jul 2010 10:58:21 -0600
Kolb Friends '
I have decided to buy a new com radio for my Kolb=2C and seek the collectiv
For the past 9 years=2C I have been using an old (ealy-90s era) Terra handh
eld=2C and it finally died on my last flight=2C earlier this week. Not wor
th repairing=2C I suspect. And so=2C I am in the market for a =93real=94 a
ircraft radio (not a hand-held) that I can mount permanently in (or maybe u
nder) my panel.
I have narrowed my choices down to three non-certified models: the Microair
-760=2C the Icom-A210=2C and the MGL-V10. All 3 feature a built-in interco
Do any of our Kolb flyers have any experience with either of these radios?
Pros/cons?
Features you like?
I=92m especially wanting to know how well the intercom works in the loud co
Many thanks '
Dennis Kirby
Mark-3=2C 912ul=2C =93Magic Bike=94
Sandia Park=2C NM
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H
otmail.
http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=
PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5
I think the Flightline FL-760 is the best buy for the buck. I have one and
it works great and has a built in intercom!
[mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Kirby, Dennis Civ
USAF AFMC AFNWC/EN
Sent: Thursday, July 01, 2010 12:58 PM
Kolb Friends -
I have decided to buy a new com radio for my Kolb, and seek the collective
aircraft radio (not a hand-held) that I can mount permanently in (or maybe
under) my panel.
Pros/cons?
Features you like?
Many thanks -
Dennis Kirby
Sandia Park, NM
Do you have a slow PC? Try free scan!
Thanks Travis. I'm just trying to save on the shipping cost, and potential headache
if it gets damaged.
http://forums.matronics.com/viewtopic.php?p=303385#303385
John,
Just read the article and must say I'm impressed!
Gene
Sent: Thursday, July 01, 2010 9:03 AM
my Kolb mkIII.
Subject: | Thanks Travis and Bob! |
This is a little late but I just wanted to say that Travis went above and beyond
to get me my replacement boom for my Firestar. Story goes like this: I really
wasn't in too big of a hurry to get the boom to replace my trailer damaged one
and I'm cheap so if I can save on shipping I'll wait. In any case, Travis was
going to haul the tube to Oshkosh and meet up with my uncle who would stop
by on his way out west after the show. Well, last week I was talking to Travis
about rivets when he said "hold on where are you again?" Well, as it turns Bob
Niebrugge was at the shop picking up a tube for his firestar and preparing to
haul it back to California, Travis got the ball rolling and Bob agreed to haul
my tube as well. Heck Bob even delivered it to my door! I think I owe him a
favor or two!
I have to say that Kolb owners are a great bunch of people and I'm glad I joined
the club!
Thanks again Travis and Bob!
Chris
http://forums.matronics.com/viewtopic.php?p=303432#303432
I used this for mine loctite 660 press fit repair
http://www.loctite.sg/sea/content_data/93755_Loctite_660_Quick_Metal_Retaining_Compound.pdf
http://forums.matronics.com/viewtopic.php?p=303434#303434
George,
Thanks for posting your web site. I really enjoyed it and bookmarked it so
I can easily return to it.
Gene
Sent: Thursday, July 01, 2010 10:10 AM
Subject: Re: Kolb-List: Re: New Video
>> or..
>> then
>> "Kolb Related Web Sites" then "John's Jaunts"
>> George Alexander
>> FS II R503 N709FS
> Thanks, George.
> You da man.
> john h
> mkIII
Subject: | inspiration for "old" pilots |
Not specifically Kolb related but should be an inspiration to all pilots who think
they are getting old.
http://tinyurl.com/27a5vlx
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Jimmy Buffet
http://forums.matronics.com/viewtopic.php?p=303447#303447
Hi,
3 pics taken by a friend who bummed a ride with me a couple of weeks
ago. For those with strong stomachs there is a pic. of me in close up.
Delete Now.
The intersting pic is that of the Caen Hill flight of locks, 19 in all
(I think) which lifts the Kennet and Avon Canal which runs from Bristol
to London , from the valley floor up to Salisbury Plain.
Cheers
Pat
Subject: | Re: Radio Advice |
Dennis,
The absolute best radio reception I've ever had in any airplane (GA included) was
an iCom A-200, predecessor to the A-210. It was in the Allegro (factory installed)
that I used to own part of. I know nothing about installation issues but
can tell you if installed properly this radio's performance was outstanding.
I now use a hand-held iCom A6 (no room for a panel mount, nor in my budget) with
boom tube mounted antenna and its performance is adequate.
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Jimmy Buffet
http://forums.matronics.com/viewtopic.php?p=303455#303455
I would do exactly the same thing. No problem at all.
Please keep me posted and let me know if you need anymore information.
I wish everyone on the wonderful list a safe and happy 4TH Of July weekend.
Kind Regards
Travis
Kolb CO.
Sent: Thursday, July 01, 2010 7:41 PM
Subject: Kolb-List: Re: Xtra boom specs
> headache if it gets damaged.
Finally...a M3 with a REAL engine on it ...lol....just kidding Rotax guys....lol
chris ambrose
M3X/JABIRU A-2200 138.8 hrs
N327CS
http://forums.matronics.com/viewtopic.php?p=303474#303474
Subject: | RE: Kolb-List Digest: 26 Msgs - 07/01/10 |
Howdy gang...
Just read the note about Travis getting a boom tube delivered... Just want to
say how much I appreciate the extra special effort Travis and the others at Kolb
put into helping us build, repair and operate our Kolb products. They are
a great bunch of people. Every thing we can do through them such as purchasing
parts ,etc is really to our benefit. Hopefully we can all help them stay in
business and help ourselves and future Kolbers in the process.
I have the photo of John H.'s Mark III parked at the edge of the glacier in Alaska
as the background photo on my desk top. It is a constant reminder of what
a great little plane the Kolb really is. By the way, it is to our benefit to
have people like John and others to advise us. Thanks John. Only thing that
would make it a better photo would be if you were in the photo. Guess you took
the photo...
Really looking forward to picking up my VW, re-drive engine from Great Plains Aviation
later this month when at OSH. I am sure I will be asking for some advice
and input from the guys such as Rick Neilson that have VW conversions, etc..
Anyone heard from Cristal? The MKII or the new baby?
Building MKIIIX N830PB
Subject: | Source of Fuel Cells - Tanks |
Hey Folks,
Here's a source of fuel cells that might be considered for fuel tanks.
There sold by Summit Racing. Summit racing sells direct on their web
site and on eBay. I have made purchases from them several times on
both eBay and direct Online. No problems and great service.
jerryb
http://www.summitracing.com/search/?keyword=fuel%20cells&dds=1
Subject: | Kolb would be a thing of the past... |
Chris,
I am glad to hear that you too have had the pleasure of working with Travis.
Travis and the crew shipped my Kolb parts and pieces to me here in Palmer,
Alaska. Every piece and part arrived in prefect condition. Kolb would be a
thing of the past without Travis!
Greetings to all and thanks to Travis,
Nick Cassara
Proto type Kolbra
(under slow reconstruction)
Subject: | Re: inspiration for "old" pilots |
Hi Thom,
I don`t think `built in his shed` adequately describes his facilities.
Pat
Sent: Friday, July 02, 2010 3:20 AM
Subject: Kolb-List: inspiration for "old" pilots
> who think they are getting old.
> Thom Riddle
> Buffalo, NY (9G0)
> Jabiru 2200A #1574
> - Jimmy Buffet
11:35:00
From: | "Jerry Deckard" <flypoker(at)windstream.net> |
Thanks for sharring, what a wonderful story.
Jerry
Sent: Saturday, July 03, 2010 8:29 AM
Subject: Re: Kolb-List: inspiration for "old" pilots
> Hi Thom,
> Pat
> From: "Thom Riddle" <riddletr(at)gmail.com>
> To:
>> Thom Riddle
>> Buffalo, NY (9G0)
>> Jabiru 2200A #1574
>> - Jimmy Buffet
> 11:35:00
> This has nothing to do with Kolbs other than interesting things to see
from the air in a Kolb.
> Thom Riddle
This pic does have something to do with Kolb aircraft. Homer Kolb at the
Kolb Aircraft Homecoming, 2007, in front of John Bickham's mkIII, after John
B led John Williamson and I from LA to London, KY.
This is what some of us like to do best, fly cross country and camp out with
our Kolbs.
Greetings,
Here are some pictures of LED lights installed in an ultralight, the owner
purchased them on www.superbrightleds.com used an old bicycle marker ligh
t.
Here is a sort video I took on the 4th of July
http://www.youtube.com/watch?v=N1cX3e7GOWw
Will Uribe
El Paso, TX
FireStar II
In a message dated 7/2/2010 12:56:08 A.M. Eastern Daylight Time,
50calibercruiser(at)cox.net writes:
Chris,
Thanks for the suggestion.
Bill Varnes
Audubon NJ
Like my LED's?
Subject: Kolb-List: LED lights
Date: Mon=2C 5 Jul 2010 12:15:50 -0400
Greetings=2C
Here are some pictures of LED lights installed in an ultralight=2C the owne
r purchased them on www.superbrightleds.com used an old bicycle marker ligh
t.
Regards=2C
Will Uribe
El Paso=2C TX
FireStar II
Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb
ox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O
N:WL:en-US:WM_HMP:042010_1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: | What a difference a few days makes |
We had a bit of Alex park over the middle of Kansas for the holiday weekend
so I decided to see what shape the Arkansas is in this morning. All the
sandbars are under 3 to 4 feet of water. NOAA says the peak came early this
morning with flooding farther down stream at the town of Oxford. Looks like
it's going to be another wet summer on the Great Plains.
Rick Girard
A friend of mine - Carl Hoffman - is putting his MKIII up for sale because he is
in his 90's, has had some joint replacements, and is no longer able to get in
and out of it without help.
Here are the pictures on Barnstormers -
http://www.barnstormers.com/listing_images.php?id=451075
It has 110 hours, the finish is fantastic, a lot of the work was done by Kolb.
It has a 582 and a 3 to 1 C box with a 3 blade Warp Drive, and it is possibly
the quietest Kolb I have ever heard. Electric start, hydraulic heel brakes.
It is built exactly to plans, no extra bells and whistles, I have flown it and
it flies exactly the way a light MKIII with no extra stuff ought to, no "All it
needs is..." stuff. With that being said, the tach doesn't work right, it reads
too high. I suggested a TinyTach, I think he will just let the buyer fix it.
He wants $14,900, and there is a new trailer available, $5,000 for it. The airplane
comes with covers for all surfaces.
Here are some pictures I took of it last summer when some friends & I got it out
of the trailer & put it together for him. Not much detail, but you can see how
good the finish is.
Phone number is 423-863-4466, ask for Ed Athey, Ed is selling it for him.
Richard Pike
MKIII N420P (420ldPoops)
http://forums.matronics.com/viewtopic.php?p=303921#303921
http://forums.matronics.com//files/100_0273_large_675.jpg
http://forums.matronics.com//files/100_0272_large_804.jpg
http://forums.matronics.com//files/100_0269_large_878.jpg
http://forums.matronics.com//files/100_0268_large_182.jpg
Subject: | Re: Sport Pilot license |
From: | "cristalclear13" <cristalclearwaters(at)gmail.com> |
radiobluebook(at)gmail.co wrote:
> Thanks for the reply Ralph. I spoke with the EAA and got a few of my questions
answered. They guy who answered the phone was most helpful. If anyone else has
questions about Sport Pilot's license you can call them at 920-426-6527. The
gentleman I talked to was Tim.
> Turns out I can't use any of my ultralight time as dual instruction as I originally
thought. You can still use ultralight time for the solo portion of your
training, but that's it. 'What that means is that I will need to get 9 more hours
of instruction from another CFI and then go back and take my check ride.
You also need to have the written passed and a recommendation from the other CFI
before you go back to do the check ride.
> As much of a hassle this is turning into, I think I will get my private pilot's
license instead.
> Duane
Duane,
Sorry, I'm a little late in replying. I don't check the forum as often since I
am little out of commission right now.
I know your frustration with trying to get the SP. Three years ago I had a hard
time finding anyone who would teach SP and there was no LSA to rent (it's still
that way around here). By the time I got my own ELSA I had already went ahead
and gotten my medical so I could at least solo in the C150. Since I had
gotten that far it was really just a few more hours to go ahead and get the PP.
I upgraded the software I had bought from Gleim and that was good enough to
get me through the written test.
I don't regret one minute of the extra training and now extra freedom (to fly more
types of planes or at night) of getting and having the PP. It was worth the
extra time and expense.
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=303982#303982
From: | Duane Ransdell <radiobluebook(at)gmail.com> |
Hi Cristal,
My sentiments exactly. It will not cost much more to get my PP, so that's
the route I eventually intend to take. So far all my training time will
count towards that and I don't know why it all won't count. All I will need
is 5 more hours training, another check ride, a medical and a cross country.
I'm pretty close to that right now.
> Duane,
> since I am little out of commission right now.
> hard time finding anyone who would teach SP and there was no LSA to rent
> (it's still that way around here). By the time I got my own ELSA I had
> already went ahead and gotten my medical so I could at least solo in the
> C150. Since I had gotten that far it was really just a few more hours to go
> ahead and get the PP. I upgraded the software I had bought from Gleim and
> that was good enough to get me through the written test.
> fly more types of planes or at night) of getting and having the PP. It was
> worth the extra time and expense.
> Cristal Waters
> Rotax 503 DCSI
Sincerely,
Duane
www.amateurradiobluebook.com
Note: If you forward this email, please delete the forwarding history, which
includes my email address.
> Hi Cristal,
> My sentiments exactly. It will not cost much more to get my PP, so that's the
route I eventually intend to take. So far all my training time will count towards
that and I don't know why it all won't count. All I will need is 5 more hours
training, another check ride, a medical and a cross country. I'm pretty close
to that right now.
The only thing you may have to watch out for is who you got your training from
to start with. If he was only a SP CFI then the hours may not count toward the
PP (some new ruling they came out with recently). You may want to ask EAA Tim
about that one.
Cristal Waters
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=304013#304013
Subject: | RE: Kolb-List Digest: 4 Msgs - 07/06/10 |
Cristal: Good to hear from you. How is the family. Any Kolb time?
Cristal is correct except that it is not a new ruling. BUT the FAA did issue a
statement which made this clarification... clear. This is one of the reasons
I'm letting my CFI-SP ticket expire.
This ruling makes no sense whatsoever, but it is what it is.
Training by a CFI-SP does not count toward any higher rating. The solo work does
but not the instructional hours.
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
If life gives you limes, make Margaritas.
- Jimmy Buffet
http://forums.matronics.com/viewtopic.php?p=304025#304025
From: | william sullivan <williamtsullivan(at)att.net> |
Subject: | Firefly Slide Show |
- Jack- How are you doing with the MZ34 engine?- Haven't heard anything
for a while.
---------------------- Bill Sul
livan
---------------------- Windsor
Locks, Ct.
---------------------- FS 447
Not to worry. The only instructors in my area are for private pilots. All my
time so far counts.
BTW, Tim is a great resource if anyone needs answers about Sport Pilot.
Duane
> > Hi Cristal,
> from to start with. If he was only a SP CFI then the hours may not count
> toward the PP (some new ruling they came out with recently). You may want
> to ask EAA Tim about that one.
> Cristal Waters
> Rotax 503 DCSI
Sincerely,
Duane
re discussion about landing lights etc there is an American company from
Idaho getting a write up in one of my mags. LEDS are used and are
expected to last 50,000 hours. Fit and Forget. Starting price =A3195.95.
www.aeroleds.com
For what its worth
Cheers
Pat
Subject: | Re: landing lights |
Hi all,
I haven't been keeping up on the list lately but caught a discussion about
landing lights. Just an FYI on the set (2) that I have. They are LED an
d mega bright. I hardly ever fly at night but have come in a few times as
the sun dropped from the sky; and the lights lit up the field like a nigh
t game at your favorite stadium. I think that I got the first set that Di
ck Kuntzleman (Kuntzleman Electronics, Pottstown, PA), made about 3 yrs ag
o. Mine are square & I should have them changed to the newer streamlined
ones, but they ARE very bright. I've had more than a few "bumpy" landing
s and fly from a hard, grass strip & the lights have worked without any pr
oblems. Dick has been doing strobes & nav lights for year. I haven't spo
ken to him since Homer's funeral, but I assume that he is still making the
landing lights. I know that they are bright, less expensive then others
and you can't beat his personal service.
Also wondering if his MK II is still in mothballs or if he's flying lately
. His Kolb is a beaut!
Jim
Loves Fld, FL
-----Original Message-----
Sent: Thu, Jul 8, 2010 7:02 am
Subject: Kolb-List: landing lights
Idaho getting a write up in one of my mags. LEDS are used and are expec
ted to last 50,000 hours. Fit and Forget. Starting price =C2=A3195.95.
www.aeroleds.com
For what its worth
Cheers
Pat
-= - The Kolb-List Email Forum -
-= Use the Matronics List Features Navigator to browse
-= the many List utilities such as List Un/Subscription,
-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
-= Photoshare, and much much more:
-= --> http://www.matronics.com/Navigator?Kolb-List
-= - MATRONICS WEB FORUMS -
-= Same great content also available via the Web Forums!
-= --> http://forums.matronics.com
-= - List Contribution Web Site -
-= Thank you for your generous support!
-= -Matt Dralle, List Admin.
-= --> http://www.matronics.com/contribution
Subject: | MarkIII for sale - West Coast |
A friend of mine is selling his Mark III. He asked me to post it here. This is
a very good deal on a 912 powered MarkIII.
For Sale-The complete package: 1998 Kolb Mark III. Nice clean airplane, always
hangered, needs nothing. 157hrs airframe and engine (ROTAX 912UL 80hp). This plane
is flown weekly, so total time will be slightly higher. 72" Taper tip Warp
Drive Prop with Stainless leading edges. Custom 20-gal fuel tank. Kolb full
swivel tailwheel. Dual controls. Hydraulic brakes. Icom handheld radio w/external
antenna, two headsets and intercom. Kolb built dolly for easy moving while
folded.
Custom 26' Dual-axle Haulmark trailer/hanger with extra D-rings built into the
floor, 12" extra height for three blade prop and outside spare tire mount to save
space inside. Very clean. $9000 when new in 2007. Asking $25,000 for the
package. If you have been waiting for a deal on a MarkIII package, this is it.
Call Keith Anderson 541-892-0808
email: kandersoncon(at)gmail.com
Roger in Oregon
1992 KXP 503 - N1782C
http://forums.matronics.com/viewtopic.php?p=304286#304286
http://forums.matronics.com//files/kolb_002_001_117.jpg
http://forums.matronics.com//files/kolb_001_001_447.jpg
http://forums.matronics.com//files/two_guys_fit_001_103.jpg
http://forums.matronics.com//files/keith_at_pelicanpoint_001_489.jpg
Subject: | Off Kolb Topic - Recommendation for Airport Web Cam |
This is off Kolb topic but we have a very broad experience base on
this list which I hope to tap.
Please reply directly to the sender to keep the others happy, Thanks.
I'm looking for a outdoor (web) cam solution for our hangar apron at
the airport, some thing like a dock cam. Doesn't have to have pan
and tilt but might be desirable, Infra Red night vision may also be
desirable. Motion detection might also be a useful feature. Also
know of any small dedicated computer or web based
processor/controller. Oh ya, cheap is good but functionally,
reliability, and easy configuration is better.
Anyone have any experience with this and can make some good
suggestions I would appreciate it. Do's, don'ts, what works, what
doesn't, IP based, wireless ....
jerryb
From: | "Larry Cottrell" <lcottrell(at)fmtcblue.com> |
Gang,
I need a bit of help. I bought a new camera for the Kolb, a Countour
HD by Vholdr. While the camera takes good movies, they can only be
edited in Quicktime. They are finished as a mov. file rather than a AVI.
file that I have been using before.
My question is, if I use this, will it be viewable by other computers.
I read the reviews on the editing software, and it reads like a horror
story by 2/3 rd of the reviewers. (Quick time Pro) Any one having any
experience or thoughts would be welcomed.
Larry
which includes my email address.
Larry, if youtube will accept the format it will be viewable by anyone.
If they can't take it try Streamclip.
Beautiful flying weather today in Noo Yawk. I got in a good ride this
morning to my favorite sunday morning destination,
interrupted only by buzz jobs on a friend and my daughter's place.
Coffee and conversation were offered.
Little Kolb performed perfectly and brought me back home.
BB
On 11, Jul 2010, at 12:36 PM, Larry Cottrell wrote:
> Gang,
Countour HD by Vholdr. While the camera takes good movies, they can only
be edited in Quicktime. They are finished as a mov. file rather than a
AVI. file that I have been using before.
computers. I read the reviews on the editing software, and it reads like
a horror story by 2/3 rd of the reviewers. (Quick time Pro) Any one
having any experience or thoughts would be welcomed.
> Larry
Most people have Quicktime viewer on their PC, so, yeah, it's viewable by
other computers. If not, it's a free download. So many videos out there
are MOV, so it's one of the many standards.
On Sun, Jul 11, 2010 at 11:36 AM, Larry Cottrell wrote:
> Gang,
> I need a bit of help. I bought a new camera for the Kolb, a Countour HD
> by Vholdr. While the camera takes good movies, they can only be edited in
> Quicktime. They are finished as a mov. file rather than a AVI. file that I
> My question is, if I use this, will it be viewable by other computers. I
> read the reviews on the editing software, and it reads like a horror story
> by 2/3 rd of the reviewers. (Quick time Pro) Any one having any experience
> Larry
Larry, I purchased Quick Time Pro a few years ago and as soon as I got past the
short learning curve, it was ok.
But if you want to use the software that comes with Windoze, download Next Video
Converter 3.5 (free)
http://www.nextvideosoft.com/
and then you can convert Quick Time to whatever you like.
My Lumix Digital camera films in Quick Time, but here is a sample of converting
it to a much smaller bandwidth movie that I could post on our web page. The original
Quick Time clip out of the camera was somewhere around 40 or so mb, but
this is a conversion to a mpeg-4 (mp4) 10 mb clip that doesn't look too bad.
(Grand daughter at swim class )
http://www.bcchapel.org/pages/0003/Page12.htm
Richard Pike
http://forums.matronics.com/viewtopic.php?p=304488#304488
Thanks guy's, I appreciate the responses. I will bite the bullet and
give it a try. This camera is pretty small, takes high def movies, but
somehow my computer doesn't recognize it, so it will have to go back.
Not too impressive, although they are sending me a prepaid shipping
package.
The camera does not have stabilization, so it is going to be a bit of a
challenge to keep the shakes out of it, but the color and clarity are
superior to what I have been using. I really think at this time I should
have listened to John Bickham however.
Larry
----- Original Message -----
Sent: Sunday, July 11, 2010 12:56 PM
Subject: Kolb-List: Re: new camera
past the short learning curve, it was ok.
Next Video Converter 3.5 (free)
converting it to a much smaller bandwidth movie that I could post on our
web page. The original Quick Time clip out of the camera was somewhere
around 40 or so mb, but this is a conversion to a mpeg-4 (mp4) 10 mb
Richard Pike
From: | "lhaggerty" <lhaggerty(at)tampabay.rr.com> |
What did John have to say. Pete
Sent: Sunday, July 11, 2010 3:54 PM
Subject: Re: Kolb-List: Re: new camera
package.
a challenge to keep the shakes out of it, but the color and clarity are
Larry
got past the short learning curve, it was ok.
download Next Video Converter 3.5 (free)
Richard Pike
http://www.matronicp; via the Web
_p; generous bsp;
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: Firefly Slide Show |
Date: Wed, 7 Jul 2010 07:29:18 -0700 (PDT)
From: william sullivan <williamtsullivan(at)att.net>
Jack- How are you doing with the MZ34 engine? Haven't heard anything for a
while.
Bill,
Finally, I believe, I have the Tillotson carburetor problem resolved. The
last time I disassembled it, I blew out all the galleys with compressed air.
Some white stuff blew out, but I could not find it afterwards to see what
it was. They use a Eastman product to help seal the press in plugs. I
have found some of it loose on the control diaphragm side of the plug. This
carburetor was designed before ethanol, and may be the sealer is not
compatible with ethanol. After blowing it out I checked the high speed
check valve action and it was better than what I thought it was on previous
attempts. To make it easier to start carburetor adjustment from scratch, I
brought some adjuster tubes forward and under the wing crossover beam so the
I could adjust the needles with the engine running.
Any way the engine is running, with good and seemingly stable EGT and CHT.
Too early to be sure. Tomorrow I will start unwrapping the Tiny-tach lead
to get a good tach reading. Then I can set the propeller and go fly.
Jack B. Hart FF004
Winchester, IN
Jack,
Good to hear a report on the MZ. Are you using a
Mister Funnel when you pump fuel. Two different times I have found white
stringy stuff in my gas. I dont know if that is related to the alcohol or
not. I dont have a clue what it is. Hope things go your way!
Ed Diebel FF( 062)
In a message dated 7/11/2010 6:31:53 P.M. Central Daylight Time,
jbhart(at)onlyinternet.net writes:
This
previous
attempts.
Subject: | Homer Kolb - It was a year ago today he passed... |
From: | "marcuskolb" <marcus.kolb(at)videoray.com> |
It was a year ago today that I lost my excellent dad, we lost a very loving grandfather
and the world lost a great aircraft designer.
I don't know who, but someone was circling the farm this morning and I just wanted
to say thank you! I didn't get out in time to see what it was but it sounded
like a Kolb. Nothing could top the funeral tribute John Hauck and Dick Rahill
flew, but it's really neat to know people remember dad and continue to honor
him.
Travis I'm so sorry to hear of the loss of your dad.
Marcus Kolb
http://forums.matronics.com/viewtopic.php?p=304594#304594
http://forums.matronics.com//files/dadbytree05580029_160.jpg
Reading Homer's mind:
who let this buffoon in the gate?
DSC00338 copy
Subject: | Re: Homer Kolb - It was a year ago today he passed... |
loving grandfather and the world lost a great aircraft designer.
> Marcus Kolb
I lost a good friend that believed in and supported me through good times
and bad. No matter how many airplanes I broke, Homer was ready to
help/support me, get me back in the air to head out for another adventure.
He would often remind me I was his best test bed.
Homer, Clara, Marcus, and the rest of the Kolb family and Kolb Aircraft
folks have been a lot more than good friends over the last 26 years.
I miss Homer. It is difficult to accept the fact he is not out in his shop
working on an antique JD or his new electric powered airplane. I miss not
being able to call and get his valuable advice on airplanes, antique JD's
(he never accepted my other tractors that were not green), or life in
general.
When I would call, Clara always told me, "Homer is in the shop. He'll come
down to feed before dark."
You know...I still have the feeling he is close by.
Thanks John!
I hope you get all fixed up and stop by some time!
http://forums.matronics.com/viewtopic.php?p=304619#304619
REMEMBERING HAPPY TIMES WITH HOMER
> I just wanted to say thank you! I didn't get out in time to see what
> it was but it sounded like a Kolb. Nothing could top the funeral
> tribute John Hauck and Dick Rahill flew, but it's really neat to
> know people remember dad and continue to honor him.
> Marcus Kolb
Greetings,
I purchased some LED lights from http://www.superbrightleds.com to replace
the burnt halogen light bulb. The LED lights are not very bright much le
ss super bright.
Here is a video I took of the landing lights flashing, you can see right
away which is the halogen light and the LED. The Superbrightled does say
it's not for use as driving lights.
http://www.youtube.com/watch?v=FcJt8pkI_9U
Will Uribe
FireStar II 407 hrs
El Paso, TX
Subject: | UltraStar tailwheel strut |
The mention a few days ago of a fiberglass rod for the tailwheel strut got
me wondering.
I'm having a problem with the tailwheel strut on my UltraStar. It was bent
a bit when I got the plane, looks like it had been bent and straightened a
few times. It bent, and the 5/8 tube crinkled a bit, right at the end of
the 3/4" tube it slips into. I've straightened it out twice myself, but it
keeps bending=85 the crinkled are weakens it, of course, but I don't know
how
much it tends to bend when straight. One solution is to cut it and splice a
new piece of 5/8", but will it bend again? Was this a common problem with
the UltraStar? It tends to get bent not on landing, but when moving the
plane around with the wings folded (at least that's where I felt it bend
the last time). One problem may be that when I got the plane, the 3/4" tube
was cut off straight rather than angled per the plans (I've since corrected
this), which makes a much worse stress concentration on the inner tube,
contributing to its bending (and weakening) the first time.
I could extend the 3/4" tube farther back which would make it quite a bit
stronger, but it would also be less springy, which could lead to damage
elsewhere; damage which would be harder to repair. Or go to a fiberglass
rod (is that original on later Kolbs or is it an owner mod?). A 5/8" solid
fiberglass rod is slightly weaker in simple bending than 5/8OD x .035 steel
tube, but it's less prone to local crippling which seems to be my problem.
Or perhaps somebody's come up with a better solution?
-Dana
Government cannot give you anything it does not first take away from
someone.
Will,
The video show quite dramatically the difference in light output. Do you
know the current draw of the halogen? I'm considering replacing the broken
LED landing lights on my Slingshot and the halogen sure look like a better
solution if the price and current are not too high. If you could let us know
your supply source too that would be very helpful.
Thanks, Will. BTW, when are you coming to Buffalo again?
Thom in Buffalo
Subject: | Re: Ultrastar tailwheel strut |
- Dana- Which way is the tube bending?- Sideways, or up (from bouncing)
?- Next, do you know if the factory specified tubing of that particular g
rade, or having it hardened?- Is it original? -My Firestar does have a
fiberglass rod tail spring.- No bends or cracks, but I'm careful to lift
it when going sideways around the yard.- I worry more about bending the t
ubing on the "skeg", or doing some kind of damage to the main fuselage tube
.- I seem to remember that the Ultrastar tail spring was longer, though.
- Could be wrong.
Bill Sullivan
Windsor locks, Ct.
-FS 447
From: | "Watkinsdw" <david.watkins0(at)gmail.com> |
Gentlemen,
Here is a picture that I just received from Steven Green. Homer had just finished
applying his autograph to one of his children. It was taken at the Kolb Homecoming
in 2004.
I look at that signature every time I fly. I feel grateful and wish I'd had a chance
to meet him.
Dave
http://forums.matronics.com/viewtopic.php?p=304651#304651
http://forums.matronics.com//files/im001390a_105.jpg
Subject: | Re: UltraStar tailwheel strut |
Dana:
Normalized 4130 steel tubing makes a very poor spring, unless heat
treated, of course.
The tail wheel strut should be a spring.
I use .120" wall 4130 heat treated to 48 RC for my tail wheel strut on
the mkIII. An US could use something with a thinner wall, like .090".
I have also shortened tail wheel struts dramatically on all three model
Kolbs I built, US, FS, mkIII.
A 5/8" solid fiberglass rod is slightly weaker in simple bending
than 5/8OD x .035 steel tube, but it's less prone to local crippling
which seems to be my problem. Or perhaps somebody's come up with a
better solution?
-Dana
Hi Tom,
I don't remember where I purchased the halogen light set, it could have be
en at an auto parts store or Walmart. JC Whitney sells a set that look jus
t like the ones I have.
http://www.jcwhitney.com/optilux-driving-light-sets/p2003717.jcwx?skuId=
151320
I don't know how much current they draw but I have to charge the battery
after I land because they do suck the life out it if they are on for too
long. This is why I'm trying to replace the bulbs with the LED lights
I have one more set of LED lights I need to experiment with, will post the
results as soon as I have one mounted.
I think Dick Kuntzleman's landing lights are the best way to go. I don't
fly much at night or else I would buy a set.
http://www.kestrobes.com/beacon.htm#LL1
Will Uribe
FireStar II 407 hrs.
El Paso, TX but in Tucson, AZ this week.
I don't know when I will be in Buffalo again, now that GM is owned by we
the tax payers I am slowly starting to do work for them again. Ford and
John Deere are keeping us very busy. Next month I plan to be in the Detro
it area for 3 weeks. Later this year the FAA may send me to the Miami, Orl
ando, Memphis and Los Angeles airports but everything is subject to change
Will,
n LED landing lights on my Slingshot and the halogen sure look like a bett
er solution if the price and current are not too high. If you could let us
know your supply source too that would be very helpful.
Thom in Buffalo
I have used a KC Off Road Halogen Running Light for a long time.
Primarily, it does a great job at night with its 100 watt halogen
replaceable bulb, which is guaranteed for 10,000 hours.
don't fly much at night or else I would buy a set.
Will Uribe
From: | "George Alexander" <gtalexander(at)att.net> |
After moving to a field with more traffic, much of it training and private jets,
felt the need to increase my visibilty. Found LED light strips (12V) on ebay
that are switchable between flashing and steady on. No substitute paying attention
or Dick Kuntzleman's stuff, but made me feel a little better and the price
was right (about $12).
Video at: http://www.youtube.com/watch?v=pkfVSAQbkIs
George Alexander
FS II R503 N709FS
http://www.oh2fly.net
http://forums.matronics.com/viewtopic.php?p=304661#304661
I like them George. Details?
BB
attention or Dick Kuntzleman's stuff, but made me feel a little better and the
price was right (about $12).
> George Alexander
> FS II R503 N709FS
Subject: | RE: Kolb-List Digest: 6 Msgs - 07/12/10 |
Thank you Marcus and also the Homer Kolb Family. You have helped us all. Thank
you for the Christ honoring testimony. It is always a help to me to know that
people like your Dad (very special as an individual, as a designer, a mechanic,
an aviator, etc. and oh yes, as a family man) also have/had a daily walk
with Christ.
God bless you all.
MkIIIX builder
*Kolbers,
I tried to access George Alexander's website to browse the fly-ins, but I was unable
to connect. Does anyone know the status of this
wonderful account of numerous fly-ins at Homer's?
Dave Kulp
Bethlehem, PA
FireFly 11DMK
*From: * */Eugene Zimmerman <etzimm(at)gmail.com <mailto:etzimm(at)gmail.com>>/*
*Subject: * /*_Re: Homer Kolb - It was a year ago today he passed..._*/
> Marcus Kolb
Check out the Show Me units - Their a Wig-Wag flasher unit like used
on emergency vehicles like police cars. I have one of these on my
plane which drives a pair of driving lights for the purpose of
recognition lights and it works good. The unit I have allows you to
select flash both, alternate flash, or both lights on. Also check
the wattage of your landing lights and what a unit can handle. They
can be purchased with wire pig tails or screw terminals, I got the
one with screw terminals. Also there is flash rate, I got the
slowest I could get which comes out to be a second on, a second
off. I think mine cost me around $45 dollars a few years back - I
use it for switching recognition (driving) lights on my ultralight.
http://shop.store.yahoo.com/bcssales/shomranheadf.html
Do a search on Google.com for Able 2 & Show ME wig wag
flashers. There is a lot of price variation between places that sell
them, I got mine from the manufacturer - they had the best price.
jerb
>private jets, felt the need to increase my visibilty. Found LED
>light strips (12V) on ebay that are switchable between flashing and
>steady on. No substitute paying attention or Dick Kuntzleman's
>stuff, but made me feel a little better and the price was right (about $12).
>George Alexander
>FS II R503 N709FS
>Read this topic online here:
George , Those look very interesting !` Are they avail all the time on ebay?
thanks C
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Tue, July 13, 2010 9:20:29 AM
Subject: Kolb-List: Re: landing lights
George Alexander
FS II R503 N709FS
I was out flying my Original Firestar yesterday not realizing it was the anniversary
of Homer's passing. As I was flying, I thought of the little plane and how
much pleasure it has given me over the years. Thanks again Homer!
Ralph B
Ralph B
Original Firestar 447
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=304676#304676
http://forums.matronics.com//files/in_flight__796.jpg
> thanks C
> Chris Davis
Chris, BB et al:
They are on eBay Item No. 160446437334
They have gone up since I bought them. Now $19.99 under Buy It Now.
George Alexander
FS II R503 N709FS
http://forums.matronics.com/viewtopic.php?p=304679#304679
undoctor wrote:
> [b]Kolbers,
unable to connect. Does anyone know the status of this
> Dave Kulp
> Bethlehem, PA
> FireFly 11DMK
Dave et al:
You may have the link to the old address.
Valid address is:
Also in my signature file below.
George Alexander
FS II R503 N709FS
http://forums.matronics.com/viewtopic.php?p=304680#304680
Homer Kolb - Boundless encouragement and inspiration.
Dave
http://forums.matronics.com/viewtopic.php?p=304694#304694
http://forums.matronics.com//files/austin_in_the_j3_cub_115.jpg
I use Media Player Classic. I get the version listed with k-lite. Get the full
version. I play everything from RM, WMV, Quick Time, h.264, DVX, etc.
It is freeware and about 14 - 16 meg download. It works fine with all of the Winders
stuff.
http://forums.matronics.com/viewtopic.php?p=304697#304697
I was about to give up on recommending SUPER video converter when I ran into
a run around trying to download the latest version. Turned out it won't
download with Chrome and even with IE it was rather arcane to download. You
have to hit three separate buttons to get the download going and you have to
be careful or you'll get an evaluation version of another editor called AVS.
That all said, it is a good translator program that made changing from .mov
files from my little Nikon point and shoot cameras into .avi files that
Movie Maker could digest. It, too, is freeware.
One thing I don't like about these helmet cams is that you never really know
if you're shooting anything. I have an AT2K from Oregon Scientific and more
than once I've returned with nothing. I only use it as a backup now or to
take a second POV.
If you shop around you'll find there are many of the little point and shoot
or better cameras that will take good video, I use a Fuji S1500 now, and
having that LCD display on the back with the big red dot and REC in the
corner is nice reassurance that everything is working.
Rick Girard
> full version. I play everything from RM, WMV, Quick Time, h.264, DVX, etc.
> the Winders stuff.
> Tim
In a message dated 7/13/2010 3:48:45 A.M. Eastern Daylight Time,
d-m-hague(at)comcast.net writes:
Or go to a fiberglass rod (is that original on later Kolbs or is it an
owner mod?)
Dana,
FYI
Fiberglass tail rod was standard on my original FireStar and also on my
buddy's KXP. It worked great on turf, but was too springy on pavement. When
I taxied on pavement, the spring would start oscillating and the nose and
tail would start going up and down. This would get worse and I would have
to stop to get it to settle down. Then as soon as I started to taxi it
would start doing it again.
Bill Varnes
Original Kolb FireStar
Audubon NJ
Well guy's it has been an interesting afternoon. The makers of the
camera that I bought (CountourHD Camera by Vholdr) sent me an
authorization to return the camera for repair. The computer would not
recognize the camera, none of the software would work without that.
I actually liked the camera and thought that it took good pictures,
however my problems with the camera were compounded by having to use
Quick time to edit the movies. I managed to retrieve them by using a
card reader adapter. I could not edit them without purchasing Quick Time
Pro, which with much trepidation I did. The program has little in the
way of a manual, but after most of an afternoon of trial and error I did
get enough of an edited movie to use. Unfortunately Quick Time was not
able to read any of the music files or CD's that I possessed? so I
couldn't add a sound track. I spent another two or three hours trying to
find a fix for that and after three phone calls and quite a bit of time
waiting on hold I could find no help at all. I finally tried to get a
refund for a program that did not work, they of course refused, but gave
me a number where I could talk to an , undoubtedly cute, Filipino gal
who suggested that I needed to buy yet another program so that Quick
Time might know what a music file was. Understandably, I declined.
I am returning the camera to Amazon rather than sending it in for a fix.
Geeez, I thought Microsoft was bad, but Apple is worse, perhaps the
translation from Mac to windows is the problem.
Sent: Tuesday, July 13, 2010 2:28 PM
the full version. I play everything from RM, WMV, Quick Time, h.264,
DVX, etc.
of the Winders stuff.
I forgot to add that I did download two or three programs that would
convert the programs to an AVI file, however the quality of the result
was no better than the little spy camera that I have been using,
therefore it is much easier to just use it than do all that other crap.
I am going to try another camera, hopefully I will have better results.
Thanks to all of you for the suggestions on the downloads, I at least
picked up a couple of good programs that did work just fine, unlike the
ones that I paid for.
Larry
what is this?
Chris Davis
KXP 503 492 hrs
Glider Pilot
Sent: Wed, July 14, 2010 7:44:59 AM
xV[o6~8Ma,q5zs..q4PY"}:l@v$/R9O5;'LqSKl8~}1/-MM-I]X9
hqqzL[<[^$uVuL29CbeoLP)aomMmH=z[S'Y(vMGCG
AJ\2cPeQg@P5
Thom/Larry /Kolbers I dont know what happened to my email but this is what i
said that came out as Gobledegook. I said "Apple, Microsoft, Kolbs ! What a
wonderful world we are so fortunate to have "Grown up in" ///////life goes on
and just keeps amazing me ,
Chris Davis
KXP 503 492 hrs
Glider Pilot
Sent: Wed, July 14, 2010 7:58:47 AM
what is this?
Chris Davis
KXP 503 492 hrs
Glider Pilot
AJ\2cPeQg@P5
Greetings,
I'm also having problems editing my videos. Wish I can find an editing pr
ogram that will do the job.
Here is a video from my camera without editing.
http://www.youtube.com/watch?v=I9R3S9xp3UI
This is the same video after editing using the program that came with the
camera, lost the HD quality, screen size and sound.
http://www.youtube.com/watch?v=99pVVRF7aX0
Will Uribe
El Paso, TX
Shorten the fiberglass rod considerably. This should reduce
springiness.
It worked great on turf, but was too springy on pavement. When I
have to stop to get it to settle down. Then as soon as I started to
taxi it would start doing it again.
Bill Varnes
I don't do a lot of videos, but, usually I convert whatever I've got (from a
variety of devices and formats) using a video converter program to WMV, then
I edit it with Windows Movie Maker.
I do have at least 2 other professional-level video editing programs, with a
lot more features, but I've realized that I very rarely use any of the other
features, and that WMM usually does 100% of what I need (for these brief,
flying videos, anyway).
After I get it edited and saved as a WMV file, I use the video converter to
change it to FLV, then I publish it on my own web site. That way I have
more control over it. But I realize that most people don't have their own
web site, and just use YouTube, and that's fine. YouTube will pick up a WMV
just fine.
The video converter program I use is: Aimersoft Video Converter (
http://www.aimersoft.com/video-converter.html)
-- Robert
On Wed, Jul 14, 2010 at 8:28 AM, wrote:
> Greetings,
> program that will do the job.
> Regards,
> Will Uribe
> El Paso, TX
Will, I use Windows Movie Maker and it does all the things you want and it
came free with Vista on my laptop. It's available as a free download from:
http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx
All I can really say about it is that it works for me and is fairly well
documented. Any thing I ever needed to know I found in the help files.
Rick
> Greetings,
> Regards,
> Will Uribe
> El Paso, TX
Anyone heard from Cristal the Kolb Mark II flyer? Been wondering about the birth
of her baby and if she
Still has the MKII???
Also John Hauck... How did you make the switch from the round landing gear spring
to the flat required by the new Maule type tail wheel? You may have posted
pictures at an earlier time??? How are you doing with therapy? Recovery? John,
I enjoy having the photo your plane in Alaska as the background on my office
desk top. It encourages me to keep working on mine.
Subject: | Re: RE: Kolk list |
gear spring to the flat required by the new Maule type tail wheel? You may
have posted pictures at an earlier time???
> Bob
Bob:
We fabricated a short tailwheel strut from .120" wall 4130 (don't remember
the OD, probably 3/4").
Welded a .250 4130 plate at the correct angle to make the pivot axle
vertical when the mkIII was sitting in the 3 point position.
A short piece of 3/8" ID bushing stock was welded to match the single bolt
hole on the Maule TW mount.
Maule TWs can be bought for 1 1/4" and 1 1/2" springs. I use the 1 1/4".
This is the last tailwheel I installed last May:
http://www.aircraftspruce.com/catalog/lgpages/maule_sfsatw.php
There are some photos of the tailwheel and strut floating on the internet or
in someone's computer. I am still at Nell's with lap top. Most of my stuff
is at hauck's holler in my desk top or CDs.
mkIII - 3,000.0+ hours airframe
400.0+ hours Rotax 912ULS
Will,
I haven't had any problem when using Movie Maker. Its all pretty
easy and the sound is there. Of course the quality is going to suffer,
but that is You Tube, not the program. If it didn't it would take
forever to upload to You tube.
Larry
Sent: Wednesday, July 14, 2010 7:28 AM
Subject: Re: Kolb-List: new camera
Greetings,
editing program that will do the job.
the camera, lost the HD quality, screen size and sound.
Will Uribe
El Paso, TX
From: | "George Bearden" <gab16(at)sbcglobal.net> |
Hey! Suppose I had an early Firestar. Suppose I had no engine, so I lashed
on my Zenoah 242cc G25-B, rated at either 22, 24, 26 hp (depending on state
of tune and whim of rater) with 2.5:1 reduction turning a 54x28 2-blade
wooden Arrow prop. Do you suppose a 200 lb feller could get off the ground
with this setup? If so.. what kinda performance should he expect?
GeoB
Subject: | Another newbie question: |
I have a United sensitive altimeter sitting on my shelf. It confuses me.
When I use it in my car in the mtns it seems to work right, so I assume the
problem lies with me.
When the weather man says high pressure my altimeter starts reading high
altitude. This last coupla weeks of high pressure has shown the highest
'altitude' I have ever seen on it, while on my shelf. Seems to my pea-brain
that it should have been opposite that! Please someone help me unnerstan
this fee-nom-e-nom.
Subject: | 3rd Nubie question... should I buy? |
Here'sa deal: A feller has an early firestar, ~250 hours. Some nice
instruments, a 40 hour 503 DCDI, intake silencer, TN wooden prop. Trailer.
8.50 x 6 tires plus smaller tires. Think older Icom radio. Fuel totalizer.
New set of floats. VG's. Needs wings and tail feathers covered. $3500. He
has been trying to sell it for a while now. Came down from $5500. Has >
$7500 invested. I thought it was a killer deal but I'm not sure.
I am actively soliciting your opinions please!
The attached photo may help see how the flat leaf spring type tail wheel mount
is installed on my Slingshot. This replaced the original standard Kolb installation
after it broke. The Slingshot tail is very heavy compared to most Kolbs
so this extra heavy duty spring arrangement is warranted.
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
We are the people our parents warned us about.
- Jimmy Buffett
http://forums.matronics.com/viewtopic.php?p=304861#304861
http://forums.matronics.com//files/tailwheel_lower_res_217.jpg
Subject: | Re: 3rd Nubie question... should I buy? |
Here is my opinion:
If you like it, why change the engine out? As set up now, you have plenty of extra
power. A Firestar with a 503 is a great performing plane.
I do not have a lot of flight hours or years of experience, but I do have over
100 hrs in an underpowered Firestar. The last thing you want to do is fly a marginally-powered
aircraft, no fun & dangerous. I'd stick with the way it's set
up now, it's a proven design.
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
http://forums.matronics.com/viewtopic.php?p=304862#304862
Sorry, I meant for my previous post to apply to this comment.
> with this setup?
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
http://forums.matronics.com/viewtopic.php?p=304863#304863
- Thom- How much weight is on the Slingshot tail wheel?- My Firestar we
ighs in at 61 pounds.
- Bill Sullivan
- Windsor locks, Ct.
- FS 447
Bill,
I've never weighed it but would guess by what it feels like when I have to lift
it that in 3-point stance it is 100-110 lb. Current empty weight is about 530
lb. so about 20% of the total weight is on the tail in 3-point attitude.
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Jimmy Buffett
http://forums.matronics.com/viewtopic.php?p=304866#304866
Bill,
I just checked my W&B and noted that the current empty weight is 526 lb and in
correct weighing attitude there is 105 lb on the tail.
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Jimmy Buffett
http://forums.matronics.com/viewtopic.php?p=304867#304867
GeoB,
If want a lighter engine, I would look for a Rotax 277, it has about 5 more
hp than the Zenoah which is actually 22 HP I think. (I presume wanting a
legal UL is the reason for the smaller engine.) We flew a FS with a 277 and
it did ok ... as I recall it had about 700 fpm climb on a good day; less on
other days. It think you would be disappointed with a Zenoah, but you need
to determine what your climb requirements are. We had the 277 on a KXP; if
you have an early FS with 5 rib wing, etc., and it is lightly built with not
too many weight adding options, you'll probably do a little better than we
did with the KXP.
Dennis
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Bearden
Sent: Wednesday, July 14, 2010 11:59 PM
Subject: Kolb-List: Nube question
GeoB
The early Firestar doesn't meet Part 103 limits even with a Rotax 377 engine. In
fact, a Rotax 503 is too much power for that 5-rib airframe although a later
model 7-rib wing can handle it. The 377 provides plenty of climb performance
for a 200 lb pilot. I don't think you would be satisfied with the 277 performance,
but it would fly.
Just my opinion ...
Ralph
Ralph B
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=304887#304887
Subject: | Re: Another newbie question: |
The lower the pressure, the higher the altimeter should read. I'm not sure what
kind of altimeter you have, but when the pressure is high, it should read lower.
Someone please correct me if I'm wrong ...
Ralph
Ralph B
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=304889#304889
Subject: | RE: Kolb-List Digest: 15 Msgs - 07/14/10 |
Thanks John Hauck. I printed the note you sent about the tail wheel conversion
to a Maule assembly For the MK III for future reference. Hope your therapy
goes well. Keep us posted.
sure what kind of altimeter you have, but when the pressure is high, it
should read lower.
Ralph
Ralph you are correct... with one possibility. if there is a
altimiter setting window ( kallsman ) window that is adjusted for the
proper barometer setting... the altitude should read equal... if not
adjusting the altimeter for the proper barometric reading. your
statement is correct.
boyd
Subject: | Fw: Oshkosh Airventure 2010 |
Sent: Thursday, July 15, 2010 10:46 AM
Subject: Fw: Oshkosh Airventure 2010
Could you post this email on the Kolb list for me?
It keeps bouncing back to me.
Travis
Kolb CO.
Sent: Thursday, July 15, 2010 10:16 AM
Subject: Oshkosh Airventure 2010
Hello everyone.
I wanted to let everyone know that Kolb will be at Airventure at space
931 in the UL display area.
Please come by and say Hi.
July 26-August 1, 2010
Travis
Kolb CO.
Subject: | Critique my Fuel System. |
Hello all, his is my first post. I recently bought a Kolb FS II and since have
been spending a lot of time browsing this forum and some others. It seems the
fuel system is kind of a weak point and many people have a lot of good ideas on
what the best setup is. I thought about it and kind of decided what I would
like to do.
The Firestar i bought has a very simple fuel system, which is good....but id like
to add a little more with a few changes. Currently it has the original Kolb
tanks w/pickups made from fuel line w/weights and pickups on the end. Then it
just goes to a Y fitting outside the tanks to join the two, then to a aircraft
spruce glass fuel filter...and to the pulse pump. Simple and works...however
id like to add a back-up pump, not have fuel line in the tanks and eventually
a gascolator.
What i would like to do:
Kolb Tanks w/ "TNK" all metal top feed fuel pickups -> gascolator -> fuel pump
-> fuel filter -> Pulse pump. Using NAPA black auto fuel line throughout the entire
systems.
Here is another thing....instead of having the main fuel line pulling from both
fuel tanks (doubling the chance to suck up air for some reason)...i would like
to have it only pull from ONE tank, and then have another facet pump to be able
to transfer fuel from the 2nd tank to the "main" tank. I like this idea because
it eliminates a top-feed that might be problematic and if the pump fails
(which it prob wont) you will just have less fuel and can land sooner. And later
on i could add an aux tank to the pax seat with the same concept...
A simple picture of all this should be at the bottom.
Now for my questions:
1. It is ok to mount the gascolator and facet pump ABOVE the tanks as they are
top-feed. I realize the gascolator and pump are best suited at the lowest points.....but
they should still be able to help above the fuel tanks as well...right?
The gas still flows through the lines to collect any water that might of
been in the tanks, and the pump should still be able to function. (However the
only issue is i wont be able to sump the tanks themselves.)
Will the fuel pump still be able to serve as a backup from this elevated point?
2. Which Facet Fuel pump should i order? What PSI level? And where do you guys
get the fittings to screw in that the fuel line plugs onto? What are the best
fuel line clamps?
So thats it basically. Id really just like to have the absolute most reliable system.
I know that some really like bottom fed systems, but as long as they are
plastic tanks with the feeds held in by some push-fitting pieces...ill be a
little uneasy about it. Im just going to try to work with what i have for now.
Let me know what you think, thanks!!
http://forums.matronics.com/viewtopic.php?p=304944#304944
http://forums.matronics.com//files/fuel_sys_800.jpg
Boyd, isn't adjusting the altimeter for field elevation the same as adjusting the
pressure in the Kollsman window?
There were some comments awhile back about setting the altimeter for zero elevation
or field elevation. As an ultralight pilot, I didn't go anywhere and would
set it to zero at the field I flew from. I did this for many years and got used
to it. I continued this habit when I got the Kolbra and justified that I wanted
to know exactly how high I was above the ground. All is fine and dandy until
I go a few hundred miles to the next airport. Then I'm wondering why the
altimeter is reading wrong when I land. Needless to say, I have changed my ways
and adjusted my altimeter for field elevation before takeoff. I still zero it
out on the Firestar because I don't go anywhere with that.
I also notice airshow pilots do the same thing. They adjust it for MSL field elevation
to fly to the airport they are performing at and then zero it out before
they perform.
Ralph
Ralph B
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=304953#304953
Subject: | Re: Nube question |
OK.. the deal here is that I am not a pilot. I don't know diddly about tail-draggers.
I have had a few lessons in tricycle gear planes. I am *playing* with the
idea of using a Generac engine on this plane. Generac is not quite ready yet.
I might sell the existing 503 for funds, though it is a fairly remote possibility.
Positing such an action, I wondered if I could install one of my Zenoahs
just to learn ground handling of the tail-dragger. Which led me to try to imagine
what would happen if I was doing crow-hops or fast taxiing and ran out
of runway. Would the Zenoah have enough power to do a gentle go-around, or should
I just crash into the woods for a fiery screaming death?
GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers,
so we could identify their corporate sponsors"
http://forums.matronics.com/viewtopic.php?p=304959#304959
Ralph, Adjust the Kollsman window for barometric pressure and it should read
field elevation, conversely, set field elevation and the Kollsman reads
local barometric pressure. Setting field elevation at zero is only good so
long as barometric pressure remains the same. It you fly to another field
where the barometric pressure is the same, you get the difference between
the two field's elevations. If you take your Kolb into class alpha airspace
the kollsman window is set to 29.92" regardless of local elevation or
barometer reading.
Rick Girard
> adjusting the pressure in the Kollsman window?
> elevation or field elevation. As an ultralight pilot, I didn't go anywhere
> and would set it to zero at the field I flew from. I did this for many years
> and got used to it. I continued this habit when I got the Kolbra and
> justified that I wanted to know exactly how high I was above the ground. All
> is fine and dandy until I go a few hundred miles to the next airport. Then
> I'm wondering why the altimeter is reading wrong when I land. Needless to
> say, I have changed my ways and adjusted my altimeter for field elevation
> before takeoff. I still zero it out on the Firestar because I don't go
> anywhere with that.
> field elevation to fly to the airport they are performing at and then zero
> it out before they perform.
> Ralph
> Ralph B
> N91493 E-AB
> 1000 hours
> 23 years flying it
> Kolbra 912UL
> N20386
> 2 years flying it
> 120 hrs
> more hp than the Zenoah which is actually 22 HP I think.
I have read various hp ratings. I have two different size carbs which were used
on this engine right from the factory... a Mikuni pumper and a reg'ler Mikuni
slide-valve. I have a round fat short muffler and pipe, and I also have a tuned
pipe (expansion chamber) with a rudimentary muffler on the end. I assume that
the hp is not the same between all the models because of the various stock
equipment like this.
GeoB
http://forums.matronics.com/viewtopic.php?p=304962#304962
get a bigger runway or saw the trees down. :)
BB
the idea of using a Generac engine on this plane. Generac is not quite ready
yet. I might sell the existing 503 for funds, though it is a fairly remote possibility.
imagine what would happen if I was doing crow-hops or fast taxiing and ran out
> GeoB
That's what I thought I knew till it looked like it was working backwards.
> I'm not sure what kind of altimeter you have
No Kallsman window, just a knob to set the altitude. Which I haven't touched for
several months, as I watch it fluctuate. It is sensitive enough that when driving
down the freeway it moves up and down as I go on overpasses and such.
GeoB
http://forums.matronics.com/viewtopic.php?p=304963#304963
Subject: | Critique my Fuel System |
Per the Facet Installation Instructions (P/N 42664 01-04):
*Required Item:* In-line fuel filters need to be mounted on the pump's *
inlet* port.
Think about it, especially when using a rebuildable filter like the
Clearview, if you mount the filter on the inlet side and it leaks you get a
few air bubbles in the line. Mount it on the pressure side and you get a
stream of gasoline spraying about your airplane.
Using a second Facet for a transfer pump. I have one on my removable long
range tank. It flows 6.8 gallons in 38 minutes, barely faster than my 582
consumes fuel. For my regular system I use a single Facet (low pressure unit
P/N 40105) and a modified 3 way Weatherhead selector valve between tanks
that gives me Off, Right, Left and Both to control which tank I draw from.
Of course it's experimental aviation and you can do as you like.
Rick Girard
From: | "Steve Simmons" <stevesimmons(at)charter.net> |
Subject: | Mark III C landing gear replacement |
I finally got the Kolb Mark III ready to fly. Before I did the taxi test I
noticed the wheels were slightly canted in at the top. As I had never flown
a Mark IIIC before, I thought this was normal. I taxied around for about 15
to 20 minutes and got the tail flying 4 times; main wheels never left the
ground. When I got back to the hanger I did a post flight inspection on the
aircraft and the first thing I noticed was the wheels were very noticeably
canted in at the top about 15 degrees. It is obvious that the previous owner
dropped the aircraft in for a hard landing and attempted to straighten the
axles. Anyway, I have ordered a new set of landing gears from Travis at the
Kolb Company. My plans do not have instructions for replacing the landing
gear. Does anyone have any advice or instruction on how to replace the
landing gear on the Mark III C?
I know it has one bolt that goes through the main tube in the bottom of the
cage and the new legs do not have the holes drilled. M y problem is how to
index the gear and drill the holes properly.
Steve Simmons
Subject: | Re: Mark III C landing gear replacement |
Steve, aluminum legs or steel?
Fly it with what's on it first. Then the new ones will stay straight
longer :)
If the "bent" legs are aluminum and you are replacing them with the
same, all the final alignment is done at the axle socket.
You will need a string line (or chalk) to determine straight ahead then
two parallel lines at the wheel width splitting the difference
to the front. Tail boom for guide.
Most builders, myself included, put in a little toe-in. Perfectly
parallel is ok. This is not a race car.
The stock aluminum legs get the alignment adjusted by rotating the axle
socket. Doesn't take much to change a lot.
BB
test I noticed the wheels were slightly canted in at the top. As I had
never flown a Mark IIIC before, I thought this was normal. I taxied
around for about 15 to 20 minutes and got the tail flying 4 times; main
wheels never left the ground. When I got back to the hanger I did a post
flight inspection on the aircraft and the first thing I noticed was the
wheels were very noticeably canted in at the top about 15 degrees. It is
obvious that the previous owner dropped the aircraft in for a hard
landing and attempted to straighten the axles. Anyway, I have ordered a
new set of landing gears from Travis at the Kolb Company. My plans do
not have instructions for replacing the landing gear. Does anyone have
any advice or instruction on how to replace the landing gear on the Mark
III C?
of the cage and the new legs do not have the holes drilled. M y problem
is how to index the gear and drill the holes properly.
> Thanks:
> Steve Simmons
Subject: | Re: Critique my Fuel System |
Rick,
Did the math.Can that 582 really burn 10.8GPH?
Sent: Thu, Jul 15, 2010 4:31 pm
Subject: Kolb-List: Critique my Fuel System
Required Item: In-line fuel filters need to be mounted on the pump's inlet
port.
Think about it, especially when using a rebuildable filter like the Clearv
iew, if you mount the filter on the inlet side and it leaks you get a few
air bubbles in the line. Mount it on the pressure side and you get a stre
unit P/N 40105) and a modified 3 way Weatherhead selector valve between
tanks that gives me Off, Right, Left and Both to control which tank I dra
w from.
Rick Girard
ralph
yes that is the same.... and if you adjust the kollsman window the the
proper barometric pressure.... the needle will show the elevation.....
if there is a barometric pressure change and you don't change the
kollsman window. the as the barometric pressure rises, the altitude
indicated should decrease.
I always set the kallsman window to show the correct barometric
pressure.... when talking with other pilots and trying to remain free
and clear of their paint. all the pilots I know use altitude readings
of msl.... not agl... I could see a benefit of using agl if doing
aerobatic at an air show. but that is usually in a closed airspace
environment
Boyd
Subject: | Re: Fw: Oshkosh Airventure 2010 |
I'm glad that Kolb will be there and I will stop by and say hi. I will be trailering
my MKII to Airventure in the toy hauler Monday night and staying until Friday.
I hope to camp in the Ultralight camping area in the trailer. Hoping to
meet other Kolber's out there so stop by. I'll put some updated pictures of the
trailer on the web site this weekend.
Malcolm Morrison
http://home.comcast.net/~mmorrison123/kolb.htm
Sent: Thursday, July 15, 2010 12:18:16 PM
Subject: Kolb-List: Fw: Oshkosh Airventure 2010
Travis
Kolb CO.
Hello everyone.
I wanted to let everyone know that Kolb will be at Airventure at space 931 in the
UL display area.
Travis
Kolb CO.
It is easier than you can imagine. Go to Lowes, and buy a long bronze grounding
rod, it is the same diameter as your axles. Jack up the fuselage so that the
landing gear is off the ground, do it by placing something under the fuselage,
not under the gear. Remove the old gear, insert the new landing gear legs with
the lower gear leg fittings already attached to the new legs, minus the axles
and wheels, etc. Force the bronze rod through the axle tubes. It will take quite
a bit of bending into a curve, and will require lubricant and a rubber hammer,
but it will go. The axles will now be perfectly aligned. Mark the holes
on the legs. Take the legs to a friends house who has a drill press. Drill the
holes, put it all back together. That's how I did it back in '95, and it still
tracks as straight as a string.
Now take the bronze rod back to Lowes, tell them (something) and get a refund.
Or you can do what I did, I still have my bronze rod hanging on the garage wall,
with the Lowe's receipt rubber banded to it. Some day my kids can deal with
it...
Richard Pike
http://forums.matronics.com/viewtopic.php?p=305026#305026
From: | Ellery Batchelder Jr <elleryweld(at)aol.com> |
Malcolm
I really like your Trailer Camper / Kolb Hangar idea
Ellery Batchelder Jr.
Sent: Thu, Jul 15, 2010 10:09 pm
Subject: Re: Kolb-List: Fw: Oshkosh Airventure 2010
trailering my MKII to Airventure in the toy hauler Monday night and stayi
ng until Friday. I hope to camp in the Ultralight camping area in the tra
iler. Hoping to meet other Kolber's out there so stop by. I'll put some
updated pictures of the trailer on the web site this weekend.
Malcolm Morrison
Travis
Kolb CO.
Hello everyone.
Travis
Kolb CO.
all the pilots I know use altitude readings of msl.... not agl...
I could see a benefit of using agl if doing aerobatic at an air show.
but that is usually in a closed airspace environment
Boyd
Hi,not in the UK.QNH is usually used X country above 3000ft. QFE is
normally given by the field you are going to land at, together with
usual landing info. wind,runway in use, circuit direction etc.You then
can fly the circuit on your altimeter without mental arithmetic. Circuit
height usually 1000ft for light a/c etc and 800 or 600 for
microlights.Not sure if there is a `best` way, probably what you are
used to but at that stage of the flight the height above ground is
paramount and if you land with zero alt. on the clock it seems simpler
to meCheersPat
Checked by AVG - www.avg.com
07/15/10 11:35:00
There is an FAR that covers altimeter settings.
=A7 91.121 Altimeter settings.
top
(a) Each person operating an aircraft shall maintain the cruising
altitude or flight level of that aircraft, as the case may be, by
reference to an altimeter that is set, when operating-
(1) Below 18,000 feet MSL, to-
(i) The current reported altimeter setting of a station along the route
and within 100 nautical miles of the aircraft;
(ii) If there is no station within the area prescribed in paragraph
(a)(1)(i) of this section, the current reported altimeter setting of an
appropriate available station; or
(iii) In the case of an aircraft not equipped with a radio, the
elevation of the departure airport or an appropriate altimeter setting
available before departure; or
(2) At or above 18,000 feet MSL, to 29.92" Hg
The system is set up to operate per the FAR. Terrain and obstacle
clearance are set up for MSL, and is field elevation of each airport.
Setting the altimeter to zero at home field is a bad habit introduced by
ultralight instructors that did not know any better, or because they
were not going to fly much further than the airfield perimeter.
The ultralight folks at Oshkosh and Lakeland still hold on to this
ultralight policy of setting altimeter to zero while flying their
traffic patterns.
Boyd
John=2C
Interesting that you point it out that there is a regulation for it. Exc
ellent point!
It often looks like the "small airplane" crowd asks what others are doing
regarding lots flying habits and practices=2C but we seem to forget that t
here's a "real" airplane bunch
that would run us over when we don't adhere to proper flying ettiquete.
Even though the light airplane person may not see himself as part of the
"factory" crowd=2C he is expected to follow the federal rules. Experimenta
l Catagory aircraft are aircraft=2C and they share the same air as 737s and
Piper Arrows. Maybe we experimenters should look to the "regs" more often
=2C rather than rely on annecdotal advice.
Mike Welch
MkIII
Subject: Re: Kolb-List: Re: Another newbie question:
Date: Fri=2C 16 Jul 2010 07:08:52 -0500
=A7 91.121 Altimeter settings. top
(a) Each person operating an aircraft shall maintain the cruising altitude
or flight level of that aircraft=2C as the case may be=2C by reference to a
n altimeter that is set=2C when operating=97
(1) Below 18=2C000 feet MSL=2C to=97
(i) The current reported altimeter setting of a station along the route and
within 100 nautical miles of the aircraft=3B
(ii) If there is no station within the area prescribed in paragraph (a)(1)(
i) of this section=2C the current reported altimeter setting of an appropri
ate available station=3B or
(iii) In the case of an aircraft not equipped with a radio=2C the elevation
of the departure airport or an appropriate altimeter setting available bef
ore departure=3B or
(2) At or above 18=2C000 feet MSL=2C to 29.92" Hg
The system is set up to operate per the FAR. Terrain and obstacle clearanc
e are set up for MSL=2C and is field elevation of each airport.
Setting the altimeter to zero at home field is a bad habit introduced by ul
tralight instructors that did not know any better=2C or because they were n
The ultralight folks at Oshkosh and Lakeland still hold on to this ultralig
ht policy of setting altimeter to zero while flying their traffic patterns.
all the pilots I know use altitude readings of msl.... not agl... I
could see a benefit of using agl if doing aerobatic at an air show. but th
Boyd
The New Busy is not the old busy. Search=2C chat and e-mail from your inbox
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O
N:WL:en-US:WM_HMP:042010_3
Thanks you are right, it does sound simple. However I do have one last
question, what is the proper way to jack up the aircraft without damaging
the fabric on the bottom of the cage?
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike
Sent: Thursday, July 15, 2010 11:40 PM
Subject: Kolb-List: Re: Mark III C landing gear replacement
grounding rod, it is the same diameter as your axles. Jack up the fuselage
so that the landing gear is off the ground, do it by placing something under
the fuselage, not under the gear. Remove the old gear, insert the new
landing gear legs with the lower gear leg fittings already attached to the
new legs, minus the axles and wheels, etc. Force the bronze rod through the
axle tubes. It will take quite a bit of bending into a curve, and will
require lubricant and a rubber hammer, but it will go. The axles will now be
perfectly aligned. Mark the holes on the legs. Take the legs to a friends
house who has a drill press. Drill the holes, put it all back together.
That's how I did it back in '95, and it still tracks as straight as a
string.
refund. Or you can do what I did, I still have my bronze rod hanging on the
garage wall, with the Lowe's receipt rubber banded to it. Some day my kids
can deal with it...
Richard Pike
MKIII N420P (420ldPoops)
How else would you regulate VFR and IFR cruising altitudes, terrain, and
obtacle clearance?
Excellent point!
Mike Welch
Force the bronze rod through the axle tubes. It will take quite a bit of
Drill the holes, put it all back together. That's how I did it back in
'95, and it still tracks as straight as a string.
or a piece of 1/2 inch copper pipe (5/8 od) and instead of bowing the
pipe, i cut it in half and yd used some duct tape to hold the ends
together while marking the hole. slid in easy.
boyd mkiii
Steve=2C
I've attached a couple of pictures of me adjusting my axles. I made litt
le wooden jackstands=2C with cushioning on top. There is a tube that runs
between the axle sockets=2C and you want to catch just enough of it on each
side for a secure mount......no fabric damage.
I had some chromoly tubing left over from my frame modification. I think
it was 5/8"=2C but I can't recall exactly=2C in it worked great.
After you center the tubes (by measuring how much is slid in each axle tu
be)=2C you can see whether the axles are toe-in=2C toe-out=2C or straight.
Once you get everything lined up where you want it=2C drill through the u
pper part of the axle and the axle tube.
Mike Welch
MkIII
> Thanks you are right=2C it does sound simple. However I do have one last
> question=2C what is the proper way to jack up the aircraft without damagi
ng
The New Busy is not the too busy. Combine all your e-mail accounts with Hot
mail.
http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P
ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4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uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDxm1b+
HPJ5rsfC1yz6TLGwDGGcjn0PNcVank46jvXSeDJt11qNv64cfnWWHdplV1eJ226THHy/QVGUkY5Y
k/jVheUBP50hdQfmNelY4CuYQeooCvHyhxjtUjSoTxUbTLjFFhEqyLIVWRAD0yK881S3W1126jUD
mQkHHrzXdo3OGGD1xXLeJYAmtBwP9YgaubFRvC504d2mZMc3luoPPpW3G++NWAH5VhYwM4FadlIN
u0547V5dj0jTj+5tx9aVE2yZHQ01XBUgEir1rP8AZ8qU3byBTUU3qTeyuOTCFd2BnrVuMJ5e49By
arDG/dgHOeKmjYbTnpmpsURFB9tjI5BzV+31bS7SeSK5vYoiBgqW5Gaoby17F8wI3cflWPqekRX2
uXGyJpJ3jUqBwAemTUufJqlc0pxhOVpuyOoQW9zFIbe7glUuMBZAW/Ktm0h2yRlm+6MVwlhY3Gka
qtveYjYrvU54IrrV13R4Ekmm1S2RIl+ZjIMLk8U43l0sbYulCi0oSumrm9a/NHIjfwscVfC7opFx
nABrlbLxZ4cM3l/21Z73+6PNHNdPDKCZATwRVWa3OK6exPHBDJBuManv0qUWNoUbMYznscVUhm22
LEf3TU9vMhVvm5IHBNJN9BtDJLKBE3BnHzYPOeKbJZbYg6TZB7EVKCJJZEJyvFVdRZ47dRFLtIYH
NP2kl1DliczL4rsLdpUuFZGhYow78HrSWvjbw/dR7luiozjDIQa8l8QapPe6hdtC3lh5T8w68Gn6
RpK6rEWN7Lbsr7QI++Rk10xqRa1exHItNNz2i31/RLvHkalbuTwBvAzWmPL65FeVHwBBOiNBqM0T
IQyllB/rXTf2f42SBUg162kjXB/e2xJP1OaSqxfUp0v6/pnYDI6NTt7DqAa5+x0PxBFDHI9/CzYY
FCWAJPeqXii28aaHYy6za39q9hAAXRxluTj0qvaRvZGfJJK7OvEg+lPBU9xXhtx8XtYsYS0tha3B
U4ONy/40+0+O1qSBe6DNGT1MUwb9CBVrUzuke2uBUPAbpXnNp8ZfCdwAJpLq1J6iSEnH/fOa3rb4
geELz/Va7aqf+mjbD/49igfMjqWUVKhGKzLbV9Nu1Btr6CYHukgYfpV6KRDwpGPakNFmgYpBgj7w
xSkdufwFMY3n+7zTSH/uj86lCH0zShJCceXx9aAIfnz9wU3apzmPFWDFJ7CgQyE/eGKaGVtioDtB
H4U1o4pVKuqn2Iq55DH+Omtan++aBGPNpFmwLJH5b+qHFVDY3sQ/cXO4f3ZB/Wt82YI5dqjay9JX
B+tAznGnvYMBonGOrIcipE1mEPteXaf9oYrYexbr5z/pWddaN5w/eEkeu0UXFyoDfFiCjKy/Wke9
UHk8ntWZPo0kCn7LcbH9+9Yeq6hd6PYz3l2gZokPlrnAdu1UnfQlxa1Oke0+1XMRncLEf0qh438O
X9/DOunSIzSqsY7gLgDr+FeNz+Idfvbr7TPqcwZudiNhFHoF6V2HhXxfrUFy8l3PJcQKvKAD04wO
BWsY9jJyvuesfCqwtvDXhWe3aVWulk8qUgHAI5xz9RXVzXfmOSTgHms251XTr/wxompWisFljYbV
HfIPP/fQrCuWu5x/o9rduSeNoNJ6GkdVoblxqMCDBYce9c7rXiCxt4Nz3ESjPdhVCTwr4gvZNw0p
/m53TS4A/DNQX/wt1q8sJHuJrS3WJS+I1LE4HSpK5Wed61rEU2oTTpMAHORg1zV/ru2WICQnbnCq
au6f4T1nXNR8u32RxEnMzH5eP616FafC600nSn1uTUoWkhXcWliL446Y/So5UncfvPQ8evdVu7mN
UgtWcZ3McZ3AetXIRcPGP9HWyVuWOMk13sLBNSgs1js7mFlWbFrlnIbPDKehA6gdMg810lzH4e8R
6A9tDY3FjdNax+ZD9nIIAYfOrYHGOvrS0exSg1uzzfSZrewyySkSE7jIx5JrsNT0Twb4l1RNc1DV
Xglu0UyIz4AbHauch8M6NbpIXjluwjAtucgqPTg+vtXdHVbbwtoa4gt0OQqbUWTEoPIJ2grweh/A
0RSXUGnsck1m3hUPcWWpi8sJDtEM4JY5OODXc+BVs9c2peAQGCZJHjOP3gGeBn612lp4osplhiuN
I06/guY18p1CkRAYyWyPlwf5Vev/AAXoXiq6F7aXA0u9zhjbp8kmSTnHXPPWk4rvqWnbyPRdH0+E
27yRDZGxwmBglclhn3+bH4VsLZRddhY+p5rL+HPh660Lw02i3DtdXVvI0jSZIDhmOME+1d+mmpgb
mx9BWm2hzt66nLCyQfdgUfhSm0fstdE8Ij1KG2W1eSJ0ZnlJ4UjGB+NYXxCmGm/DvWbq3YwSrBhZ
EYqykkDgjoeaad3YV+hWliigQyXE0cKDq0jhQPxNYp8V+EFv47AeJLCa6kJCwwSiRif+A59K+Ttc
me/lL3NzLLKTkvIxY4/Grfw5sJG8f2jOcxoskm4fQ/40SdkNan0N4p+KfhTwndQ2l1DeXVxPD56L
Cgxt3FeSSMcqa891H9o2NZjDpfhdehIe5uM/oo/rXC/GKX/i5C2oB/0XTraLj1K7z/6FXA2mk3d/
BqF/CF8q0jy2Tz1qKc3LcqcbOyPQNX/aD8dTq32JrHTx/wBMbcMf/H815xrPxW+IGqyn7Z4q1DYf
4IpTEv5JgVgXMmdw54rKdDJ+HNVzGbR9EfCSS5uvBlzeXUzzSzXTEu7ElsKvc0Vd+FEHkfDe0yAC
7yP/AOPY/pRWieg4rQ8bhkCuSD171reDJtviby2bPmoy/wBazrWy+16St5byA7xwCMZqlpBvI9et
kgmFrP5u3e6btvbpXFTdpouesWe1opMe3OeKwtYuNQjuFSG48qMpnGwE5/Gte0t54YQbjVFdscsk
YX+ZNZ+qaadSikmtr9ytrjzXwCACeOn0NepO6joedG19Tm5bu/VGd9UmAUEnaqjp+Fcq3jNpI2Al
v3UH5pNwH8q6XVvChuNHlu01WSTbGXVUbaG4zXmMf2m3t/KHnCMn5owDg1zvmW5t7reiPa9AuftG
kIxkaVlJG5zk+tUvF11b5tI4yHuwpyPQds15qniK6srfyraS5iLdEzgVZsNYv7ie5a4YyJLgF5AC
wwcgA1lXqv2LR6WW4aFXFKM9UXNP1aa51GTT7uFY5Ebh16GtT+1LS3vVtmkPnEdAM4rjrq8QazPM
RgBhnb9KfY31qmuidywT5TlvyNZKmpRT62HUajXdP7Klb5XPSmu4Utt4MhOPvY4BqCbWLh9PSLS9
k97vAwx4UdyaZ4l12y/4QmDStM09ppzMJ3uM8jgjaMdjx+VcPbajBak3EV01vcMu1iBkiuWNPnjz
xep6WKthKroyjeL1T6nq+nKiJHPqk7NJwCq8Jk1wus+L7W6vrrRhOtjZRXDN5iZkZuegI7VnnWxe
aUdMurw3Cs24uFOfpmsv7J4dUkyKAR6sRSo4ZxfNUZji8fGcPZ0VZdf8i9pPjOay1TzfMaS0Q/NG
+ASBxkYruYPGOlS3i3UcJ3yRFN2c8ZzivPVi8MySL5aKzdlWQitU6dbx28cSWF2iN3hzk598V1tJ
O60PLpt2tudHceJrhtXc3IF9bCAoqbBmMHqDVbxJpminwHdT6TCqmXy2OOCCD0I/GqGm2ttp7yH7
HeMGBUrMDj+XNSSW1rPatA0l0kLHlM4H8q3jUpqPuhWjVcvfPPFa3FxaG5maGSEBl2pu3Hdn8K9a
8CfEs3N9c6Rq1y8iOWNvcSdQM/dauWk8O6JKyvIt1vjGAdwH9KoWvh+2h1VH06aVCDy0pGKynaUb
MiN07n0HFqkU0K+XcKUHGFYc1bS9Q7lDfxV4fd2Nglwk8F1J9tPGyByiE+pxWi2r6hpdigfVI1um
boVLoo9+cmsfZeZr7RvoeieJNam0zTRNbzOshlRSFPUVkr4l1W5iu4LmNkgitTMrsfnJ9CfauSll
13VW86G8srzbg4AaM5+hyK349VjTSbi21TQZ1uLhPKe5ixIAvHQA8flVwpxcWrlVJSg7SjqeewSm
WMZ4GeRXU+F3KpI/GDKwHHoooi8EzO6yR6jGsEnzKAhVgD6g961rbw4LPTvKj1Y27iQyCRVDFiRj
HNRKjy7O4Kqna+h1NhdxSr5bfK3ua3bdwgC7jnGcZrzE6H4hN0Cuu7lPAYRrW1FaeKonEi6zGzBd
oDWykf8AoQqFSY3VSPQBfMgixLg88GsL4i6qyfD68RnGJWSPHr8wrIjg8WXMkMjXdiyRk/8ALEgk
+431e1/Q7/WPAN/YzzQTaiJIzbRRAoDg/MWLHHT3pxpSuKVSLR86asS1o5I/izXMsSDuHrXeeKfD
GtaJp3m6naeSkrYQ71bJA9jXBsPkz710R0MJEo67j3q5GoazkbH8RqiSCorQtyfsDDtzT2QnuK4M
QRkYqeOR1rU0fXtZtdTjWHVr2NMfcE7Y6emazZh+6UH2/lUdkQNTQ+gNCYNHomk+OvFA8T2FnJrE
r2skyo6OqnIJ9cZ/WveFup1iJEvzAZA618q20/l+IbOXP3Z0OfxFfTKzYtHlzyEJz6cVvSSe5nNt
bHO6L8RNSvddtNLvIYI/tEoi8wZAUk4HBzXrmi6Zc6t4c1XWDdxRf2WJDPAFLSDZktwOvSvjwyX1
ndS3907CXfvTJ6DOfwr62+CWsR3niaVZPnt9ZthK4PQsV2sP++gaFFWY+dpnP6Z408MareCzstdt
Jblm2iJy0bE+gDAZ/Cun8idQG8k7fUYIrxzQ/AVlY/GvWvD19CTLpepeZE2D80WW2/gdyGvdn1Oz
sUtbA6lbpIbgSFXYEgKpGSPSqdJdBqo+pkF9vBVs/Sl8xa2r6ezlWTfc6Y/ylg8cnlt19OeOlcgd
TdZHiFxbysrYxHJuGOOenvUOmzRTTNXcvQUh2ntVUznGSI3qMXUR4aHP+4azcWi00y6ApPPAqOUp
jHeo1ltnXhnU/Wq08m5SkDtkjggZpXGhkypyTgk+1ec/Ei0uD4fF2YyLdGClscE9v616xY6TujVp
2LMOuTn+lcP8aytp4TsbUbh9ouM4Poo/+yoW4PY8IhQGRAeneu40mxWPTNyD55WwP5CuOtU33CgL
kk9K9Q0K2D3uk2zj5XnXcPYHJ/lXVTRyM9g8HaR9i8LWltNFny87cjp0/wAK6hIVUfdArgJ/iTp8
Y2WlhcygcDeyxj9N1Y9x8RNSkB+z2VvF/vszkfyrmc1e5tzJI9dURjqVH1Nc74u8SR+H9PDxshdx
kkjOB64ryL/hLvGWrapHYWN8UeVgqrEipj/gRHA981k+PdRuLEpZ3Gtf2i8a7XnO51Y9wM84B+lR
7S+xrFX3KF54ntJLh4raY2dqQTstoxuJznj8f51FqHjvVx4ekln1F2tLcrCqSxIzMx/hGB1wSeT0
FcTq981vo0BgI+13hIBVcYB9B27frWZPsuNQtdGtXd7SwGZGYY8yU8u30zwPYZ74pJdWOU2nodHo
/jfWdJV4YkhjgnK5RoVbgNuAyRn8sV2UXje6a4mv7HVpbJhiRbVVXYz5/wBWTjAVh6YAPavPlt1n
lDkfIvAqokZbUJ5IpmSKBdoweC1HoJSfU7LVfE99rOsNIIfssNxKAUK7dinnHGcjPOfetiS52g+V
BFcQyNn50+Yrj1ORwRXA2094k0UskiOyjcFdASf8itrTtStY7tJZ4p4cOzyeUw2kY4AXjvSLUrnp
FndQlhcXnl20SgDLrggDuBxuOe47V3dv440WHxFd26OZ4FhhjtmwFZnB+9kDgbTyOea+frjXdXur
CPfOwkDNtY4/dgjBAHqfWuI+239rqxilupTtbKkseKtXsS52P0g8M+JbSa3WKK6juLhl+fYcqpHb
PrXcwuZIlc4yfSviz4SeLrwXVtp8c8cAfvtxuI9819aeG9Sju4AqsXc/eJNEZX0ZE49UdEeleTft
CXTWvwP1tkco7tCikHB/1qn+les14b+05fCz+EsSGNZRPqESFHzg4V27EelaR+JGa0dz5HiuJpLJ
JZZCzNjrXpHwij+1eKJZVYERWzH8SQB/OvEzqdzHCIVZdg6cc17Z+zust9q+rySANtEES/8AAmOf
5VM00tRKSbRifGCeL/haWuTq+4q6REeyRqv9Kg8N3Wn2/wAOdTuLnzUS6zF5mzI3Hp05xVfx/a3U
/jfXrye3cxy3kzrtG7I3nb07YxXOXXiGeDwZa6Ilp5BjkYuzHliQR0+hNOnHlijWcvfOTuWO5unX
tVWMF5gq9TxTppM9auaBCtzrdtGy5BkB59uaibsriirux9M+CLX7J4E0yDuIyfzJNFamkRpBoFlG
ucLCv8qK0i9EU1ZmELLwCIo0QWyJCoVFWQDA/Oqg0vwG14s4hgEqnIfzB1H415/Y+DZ2ZAbUAnpl
ax9R8IXUNy8RhJIbggVj7Hy/Mn2j7ntcq+E54WACSKSclZgMn86qwyeD4dPuNMiR44Z3V5E8zklQ
QOc/7Rrxq38LSwxtM1qWC8nAre03wxDqRISz2MRgE5/xodNvv97Fzen3HoUcPhGKJkt5bgHoA0u4
fqafbL4U8rF0yu+7AIAFeS674Vk0l4o2Dq0rYHzEcDv/ACqhb+HJplH72Yk9MSGp5ZXsm/vKTVr2
R7XLoHgm8u47woWmgRtrJg4B4NZD+DPh/M7FpblG+8f3mK8uu/DtzDIALiZRtB5lIz+tJb6JG8wS
W6lwf+m5/wAaynSk9JM2pVnTd4aM9Pt/h18PY7hrlbm43HJO6TI5/Cprv4deAb+JN11MNrZBjbB/
lXnmoeE0tVQwapKVZc4Nx/8AXp2leHWuWML6nMOCQPtRGP1pezl/MxOpe97HpMXw68IRwi3j1K5K
7cDc+ePyqOL4WeCLaz+yx6jIFcEbiwLc984rzgeGb4XRjTW51UdxdHp+dSJ4Z1Rm2f25cY/6+T/j
Uqg1szWeKnUSU3e2x6Zpfwu8IaarpbajI+/qXYH+lVtS+EPhLUpN51aaHI+YIVGfc8Vwy+FNeOBF
r12wHO0XR/xqz4i8JeLtA8KNrr63foqMvyrck5U9SeeK29nN9TBzS1sjeT4FeD45Q0XiW6Rhz1X/
AAq6PhTpIYRxePb9AowAJFwKr6N4es9d8NW2qW/iPV2aSPkfamO1u4q1pPg5nvQ1xqt8YsZObptx
PpT9jPuHOuxOnwvteRH4/u+PVlNI/wANQn3fiHKBj+IJ/jWy/hu2iJ8q7vSqjqblic1TbTYggR3n
YrnJMpodCQ/aoyX8CGKVIx8SE3OcKCkZyfzrhtdsvEuk61c2MGsTXccTbRKLdcNx9Kg8YXOr6Rra
C3kkaFl3I2Acc+tZCeMvEwO0Ty4x6CsXBp2K5kzMvtQ8S6dcG5jcyTHHDW4J/lUUfjDxLcFkv9oj
A/htFJz+VaFx4x1pJI45rnmThQUHNPPinXFUmKCOXJwdqDOarpqibK+7M+L4i+J4GWN/sojU9Dar
nFeh6F4l8OeMryLT5tMkN0qFyzAKB6/drz628Tazq+oNZW+m2ksxJB8wDr+Ndj4S8NeJdL1U6tLF
ZwRTsVuEBywXOcL6c1UrJaqwo3lLR/eO8TaXaWTXJtEkiCAbQsrf41yFlJM9ykct1PgsB/rW/wAa
7/xcQyT89QK4iC1U3Ub88HNZpuxVlc9FstBs1iieSa6+cgkidv8AGr95p1tb2DS295exsEYj9+xw
e3Wp7NTNpMEpGCqj9DTb/m0ZT/CjZrPnae5bimtjg49a11Jfk1W52g9yD/SpvE3ivX9I1GCC11B1
V03HcoY9vaq+0K3ArK8cMz6hZyHndApB/AV2zurO5yxS10MrxF4i1XW7ZY9SuvNEZ+QbQOv0riGH
7l/UMK3LtiEb6isZgCsw5yMH9acRO1tBmflWtO3H+gfWspFcjOMD1PFacLD7ERnOOlNiRJKf3K8+
lQWxIvkx6GpHG+Ag5xgVBZsDeBeTjPWpQy077b6J/wC66n9a971jUZY/C5eNvvbVYj0NeAXbYnyP
UV7vcQfavBT7eT5CuPwANb0upMjyvW5BPIqJ0YhRivZ/gdrEulraTzTDFpcADP8ACjHofbI/WvG4
7KXUdVgtosBsliT2Ar1z4VaDLBrtxa6lk2rxABUPyyMCDg1av0M3Y+i/iFbaR4dn1HxrbwD7bqsE
IZ8Z3CPoB+GM/QV8hafqV1Pf6hdNKwkKu273J/8Ar19l+O9LTWfgvcfZsCWwi8yPOTwByPyr4ztt
E1O1W5kltpMtjAAJLc023yjSuyCW8u/MZ2nfJHPznmtjwzqUtvfMWmPl4y/pgGsOW1v3OPsM5PtG
au6Rpt6xuB5UkTtGyIrDZuO08ZPFQm7lNHbXnj22fT7mXRfL1C6t4jL5Stj5FIBPv1/SuSuviJ4s
SRfP0GBGZQy7WPQ8joaqeH9E17SfEFhOLdZIoWKtEZYyTG/DgYYjkZrrdUstIsfDU9zPd27S2aus
aq4LuP4OM+hA/CvRw/s5wvPRmFTmjKy1Op0XXZbnTbea4ZCJkVstxjjkZ9jXq1hpWk6Z4F1Txdqs
ey2sbaSYM54kYL8qj6nA49a+SvCWvavBqSabbsssLHeySDO1jyceleg+L/EvibxFpdv4XluhYeHh
iSQW4GZmHQtk5IHp7VwRgpT1eh0c7UdDm7H44+K1vVS+jtnjY4IhUxkfSpviXrja1/YsgnMqPF5v
L7up/wDrVw83hdy+43UaYPBOf8KdOhjFrbtJv8pG57cselb1ZU2vd38jOKknqTaaha8QAZ5r07TQ
Yry3kyQ0MTuP++GrznRIy18oxxXpUpWGBHUgERlCO/Ix/WpjpFsl7mb0HB6U0nB5PBHFLlSMA1a0
60F9qUML8IG3OfRAMsfyzXmmiNGGMaJocTIP9O1LBeRScxRHop+uAfxFcL4tdri6S3R4zz2Vq7HV
LiO5v0Yv5Matu2IvQfwgDvXC6xPBProTbOWLD5t+PzA/lT2OyKsrHK6xcq+t3FyyhlsYlVFbp5h5
6fn+VV9IilML3Eh/fXLEs2MYHc0uoKZLYx4Bn1G7eX6ICQP8+9X1hH2Z1B2quEGPaq6GXUlnuo7W
1k2/eAwKhtLVnSO1H3j88p9zVKVS96sQ+ZYcFz6nsK9f+C3g3/hKPiFp1rcxb7dH+1XWRx5Sc4P+
8dq/8CppBc8l+1keIG3KVSM7ACOwroZYVjkjZAMZ69q9Z/aY8EW2iePbTxBp1qkFrqUWWEahVEi8
NwPUFT+deU24M9hjqU+U+1OStsWiAq294zjDDcPrXM+IbfY8N4gx/C1dUTuiRz1Q4NUdVtRcWM8I
543L9aUXZhJXRd8EXypeQSFthjcNuzg9cda+9PA17BcaHZ3CvCWaIZaMgg9uvevzn8LXBjvNhIBH
HNfYHwa8R3E6W1k8hdBwoPUd+nal8MgXvQ9D6Rr5u/a3uzD4E0G1VsGW/Zz/AMBjI/8AZq+kFO5Q
R3FfNH7VBgmXwzbToJFX7RJtJx/cGa2T5dWYxi5OyPjKSSTPWvpf9mW3C6VquoOcZvFGfZI939a+
f7uC0ExWOEKAetfRvwdCaT8GtV1JBgKl7ck+m2EjP6CsKlROLsVGk1JXPnHU/EurXer3d292zGWV
n59yTSXly01hBNJkswySawZZiMBR7cgGtqWNGht43zhYwcCt3LlhqRGPNPQyJWJrpvBFrK+t+cyE
LGmRuGMk8fyzWWLOBiPkySe5ru/CFqWWWUDBLBQT/n3riq1Vy2R3UqLUrs92VJUtYE84KgRQAq9B
j1NFY9/Hb65CDpZSZYJHglbB4dSMjp2oraLdtyZR1O4g0u3jlDGMHn0qnqeh2jyeZhU5yTjJreU5
fg8jqKiuo0lDKwzx0r0WedE4QWNu6G3jtST6n69a2vDui2lvcFnj+f7x9Kjw1tcESJ8qqVXA/U1q
6e4OZAeuAKlG9VcuiW589ftCagR46stOs5DElraZbYcfMx/wArzjTNM1W+0a41OHWGiSA4ZTIwNa
vxR1Qar8SdWuQ25RMY1Psvy/0rI0E3M2k6hY28q7Lh0QqTwMnr/Sskk3qc6ulodCPBGuzIC2uCRS
ARlmNNbwDrGRnV0H4tXf6as0Gl20NywMqRhWx64qSeQiM45rb2ULbEc7Wx5FcaDqVvcPA19uKHGc
nmqh0y/Vsfbef9411eqSj+1JQOq4rJdyXP0rzptqTSOyKTSZlHT7/d/x/HPsxqZdO1HAJvDg99xr
QQA/N6jFTRsNm3d+FRzMvlRT+x6vDC00OoSJsUkbJGBNYp1zWrizezn1a8lh6+W87FfyziutglUb
kZhgiuKv4BaarJGp+Qnj6GrjK5MopHrvwX8QqLubw9dy7VmG+LJ/iHUfjXtdlE0V2/OATxXx/pmo
TaVq9ve27FJImDAivrHQtWj1rSrLUIG/4+E3H/ZYdRW8H0Jfc1LobckHk9q5+6mKyYPUjr9K6m5j
DRb8Z4zXJas6RKr7MZOOK1ION8b2YutIS6XG6FuT7V50qJhm3DIX1r0bVWmu7GfT3hJguUZN+eEJ
HFfPk6TQXEkEkkgZGKkE+lc86d3ctTaVjorpBN4kt4QciKPcfrWg3+i2c82RlATXK6ZfR2F008gk
kJXb2q/e67Hc2jwRxOnmYGWxWbpu41NJHR/DmPZqM944BLfICex6mvWbe4f7LKhPXn9a878F6eYN
Khnb5XclgPWu3MmNwU4HXFYVHeRvBWjY5/xHO00Mp2lQSAPesCxKPqEcROfatjXp2NuXYDav3awd
OOL2GbH8WT9KQ+p67pzJHp7Rg/Ko4/Ks6/k2O0itjdGeKfbShIDg8MoNUruZJrZcn94BjHpWRZzs
ifOcetYPjEktprE9YcfkcV0zqGy3XJNcv4xz5Gnkdtw/XNeg9Yo41o2cleti3fHJ4NY+9yzjeR8p
PHFdFBYvqd2tnG4V5BgFugqtqvhy40eOOae4jkDkphM+lEUxM53cx5ZiT7mtKJj9k5GAKzB1ArSV
gYwpHGKbEifP7jPqBVSy/wCQgv41YziAfSoLP/j+B+tJFMkvGJkwOxr6L8PbbjwvZhx8slsoOfda
+cbkkyGvoTwnOG8F6c/XFuP0Fa0dyKp5zp1s/wDwnMVqhYBS4bacZAzXr2gSLp2pWhWd9yThsF+M
EYNeb+G7dptY1vVzHujtoiC2OAWP/wBauw8IWcb6XDfOfNmVzhmJJ64rWMraWMnG+p9deE3j1TRr
vS5iDFcRMh+hGP61816zp13pHiux0i9hkjjuTKMk8kJkH9a9s+HuqbJ7cMc/wNn8q4X43kxfGrw3
GFKx/ZHYehLF8/yoerLWmh53q3hXU5phJpGoeQv91wG/mKpR+EtZeSM3mqrEP4mAHP4YrvN205zx
VSefJxu4ocELnZ41431K80PXoINHvXjjEKsXKjJYkgnke1c7capd3elIt3ctK7uWb5QBtGMdB1Jr
d+JamfxKu0cmNFHv1rnFg828jt4xuXIXjuB/iayS94tvQ67wNpjoJL6Rfmf5QSPz/Su3mgik5dN1
RaRai0so4yuNq4+p6k/59KnkYAHp1qxMxbu2iLf6pMe4rgNQYPqlwQcBAAMV39+X8h2VguBnIrze
QlpZmOfmel1DodJ4Xg8y+UnkAiux1UrHceXG25SD7d//AK1c94Oh3XCkD+Kuo1+HyriM4GGUN+ea
6HpSZl9oz7O2uLy7itLWJpp5WCIijJYntWx5sWkQvYLtbUJm2yOGPyIP4PxPJ+grDgOJ0bJHOQR2
pkMDjxBftdXKB0GwAHO0k+leYjppJbllJJZ7uV3SI2xUhXDbSCD1OOmK4u/EcV+9zG0ZKK7bVYno
voevaut+1w6NpNw8UTO7ZA3Lgn864HV7u6j0O4vLieRrm5wEUnhct1B9eDR1Oi9kZlri51We5HMN
qogi/DjP55NX7mcWlpkDLdAPU1FYwLa2NtbkgFvneoppFutSyCDDAM+xbtVmK2L+nWiny4nG5ifM
lPqa+u/2bNMs4NG1LVQwa7uZhBgYJSNBnB9Mlv0FfJ2lJxLMf4RX0n+zre3VvII7qCZVuiwVyvyb
lOOPqP5U09RtXR6D+0B4bk8R/D2QwIDLpoa/zjJKrhWH02sT/wABFfGenloZ2iY8OMfiK/R67ggu
2a1uYxJFPC8Tqe6nqPyr8/PGegTeGvGWp6RICHtJ2RT6gH5T+IwatrQI7GR5cfnSR5+VuarsqlB/
eUkH3FW5UysdwAcN/Wo3hKSkcFXHb1rOxV0cbAv2HxK8Y4VmyPpX1J8F74WV5FG7KAckgrnqTz9c
fzr5g1cGLUYbrurYNe6/CeUf21bFkZwcYUA9/X0pT6MdNatH2zaSCW0ikAIBAxmvk39rK/aPxJol
usm0x2TPjPdnI/8AZa+q9LYNp8WOyivi79q65a4+K1vaD/ljYRKPxZz/AFrdK+5gna9jxGa2by1k
81izAE19GaEF0j9lXVJ9+120u4BYess20foRXzxdSbLdTmvoHxYP7I/ZSMRJD3Vrp8Zz6sQ7f+g1
hUStZGlNvmVz5Vk+edFDZBatHU2ZLtVDsAqKMA+1ULZd99EvXLVa1Te987KpIU44FdDt1MFe+gaY
JXvWZnZlVcjNeu+ErZktdPzgLJcxg++XH9K8v0uEmPJUhpGAAPpXtXh21kWfRrdozhrkMD67FLf+
y15mIknJJHrYaNo3Z6Fc2osjtsbSCKMsXcmEfMx5J4/nRW4khD+S0TMHXI3DGT6CiulPQzdr6mhB
MTMQRxildszH6VTifDnAxTmkPmEV6h5BHdxFskEHPXNVLmZdK0C5vWYBYIXlz7gE1pSEMu0ntXC/
FO+lsPhtfrE+1pwsC8+pyf0BqHsVKcmrM+brHSo/Ees3bXVxJEwBl3AdcnmtHwpoa/adQjurdxC+
0wSdwAex/KquhXZVTJHLGmI2DZ5ZuDxXe2RW2jVeMCNQOPQUoJWuTJtGijnpk/jTZCWU4BNM+1AD
g4/Cmtd8dWNbaGZw/iJjbarvC53oDj6Vz7XsjSY2qD0rp/FafNBMAepU1xUzlZOB7V5lZWmdtL4S
0tzNz8wHOOBUYupo3OZO9QI5xwfrSScnnvWJsWHu337t5qjfMZsSkkkcc0/jgUxhujKEfjTWjJex
E2HjWTPIHavYfg74qEU/9g3DAhm3Qk9jjkV41ENwaInGP1rT0PUJdH1a2v4TteFww962vYhH2d5i
GAq+M1zes20XlY25GRj2qXTtTi1bRrfULVgwmjDgA9D3FSXIM1oS/D4xXQiGcfNZqGZWXivJ/EWl
QQay8hgQib5sle/eva5U5+YYJrgPGNj5nzoBlfnH06H+lZVdUXDc8qWCBfEKI0KbCn3ccVf1m3s4
tHMkcUaOHAGFx3qK7iMfiCzB/iUjPrRr0TusVqrdFMx+grnV7ot7M9C08R/2Dauq/dRCMfSrV1dY
hkaM4OMLXPaXdyNoNnGfu+WDWuf9WByOAcVzz3OiOxiapOzwIjNy2AR6YqnYuiXaK7YHSn6ngTKD
waqWyeZeruHAoWwranocM+y3jDvnHQ1DchZHMgyjg5YetUlkL2icYK9qUyurEMcrsGPepKZNBta3
B9zXOeNkRNLsZc4YSsP0Fb2nN5kLjsGrB8cBjpMDY+VJfy4r0Y6wRxSVpMwPD7ga9bnOMk/yNWvG
zbdLtzkZE2f0NczK8iQl43KkDqOCKx57ieU7ZZpHAPRmJpReliWiNfvjNaCMGjJ9qzc8GrsDfIfp
QwRPn90PpUVsf9LzTmP+j9e1V7Vj5y46k0kNk9ycyk17j4Uugvw5tpSf9XC36Zrl9P8AhDrGqW6X
P9p2kIdQ21t2RkZx0r07TPh7ead4PXTZdRt2JDLlM9DW1JNEVNTkNDja2+Hl9d7iv9oXW3H95V/y
a7vR7Aab4ctHEJyQhbPbcQTWFqOmLZWmieH4nBUZckDAOTn/ABrspZ3urRYY4QkYdTuz/dYcU+r9
B9Edz4YZ4LOC5DYDnP41sfGbQzqlp4U8XW6BjZSmGds87HXj/wAeH61wGjeMoLaKLRpbMtmXas3m
D5efTFe128H/AAkvw61HRV+adY90Qz/EOV/UVomrJkPdng88uAeeO2Kz5JcdcEVR8f6f4o8J3sVu
biFmeHzSiAMV5PBJ78V5S/jHxJLMY0YFumPLH9KbaRNmaPjHEniKSUf8s4xt/wB48D/H8Kg8Had9
r1M3LLuWPCoD0J6D9aztRub24EZux/pMg+bAx8x4H5D+dbN5O+iaLp9taDZNM4kLey9P1rGRqj0F
kMDGB3UtHwTnrUMpQo3zqPxrmtZ1XUZp/tdvGjiRFJyuOcfWuWufFWsQMQ9rb4HqD/jVKSaJaszs
NXlEdhMc5+XFeffeVc/xMTUh8S3+rJLHJHHHAq5JQHk54pbePzJYY8ZPFLqHQ9D8FW53RnB456Vv
eKPmlh47bc+wA/xNWvAOmwtDcyzBgkcWUIOMt0A/XP4Vna8zG6EbYwGYj6E//Wrao7UmZpe8Ztki
C6Rn/wBXGC7fQDNYdnqMT3er3qATXQi80rJkIfnAx7/e/Sta4YwaRdSLy0g8sfTqf5Vx1iZUvXtg
AwbDSA9TznH6V5Ll71j0aULU79zrdQjnutIP2dAhlbh2HIyPSuL1NoLm7tdLvImZbUDdLE/UjPUE
c9T6VvC4njk8xJ2WKLLewNcZeXLJdSH+NsljnoTWyXYicrIv3Gn/AG+cSWNws8QO1o/uyf7uD1z7
E1XeCaN/Jkj2SscsuOnt+AqhZbiwk3Fdzbs/yrpdPM94/mXDs4j+VC3J/OrMYS5mdH4R0m2unNjO
jb7uJkiJONsuMqPxxt/4FX0f+z7qVqdAvtJuE/0m1uVKg4wFcH16fMrfiRXzxZyiKFCmYpYn+Vx2
I5B/lXq3w/1f+xfi1pt7xFYa8mxxjhXY8j8JUx9DmpW9zoa92x9O3kyw6hY7uA8mz81P9cV80/tK
+Gfs3iKw8Swx4jvYvJlIH8adD+KkflX0R4mcxWNtdIMmO4TB9yRt/wDHtv51zvxc8PJ4o+F+oJCu
+e2T7XAR6qMn81zW6MY7nw/GfM094MZZGyPoaily0CyF8MP4QamAMN0RyM/KaiePy5XU49azLsc3
rUSu5UD744+te3fBa5soL+3tpiDcEBg23JJ6YGenf8q8U1IkuDj7hr1j4VaxZaZ4tg1C6DMGjKoo
XcQxXjPbqaiTKgtT7d0x2aEZi2LtGOa+Jv2iL5bn416vGMt9lihQ4Gcfu1P9a+yvDly0+nQSuxLO
o4x0r4U+M9y1z8bPF0zsBGLvyd2f7qhQP0NbNcyM4y5Ls82eaORsEnLcCvo744q1h8ENI00MFL38
MeDxkRwH+rV4DYWcV5r+k2aqMz3MaH6FwK92/aQn/wCKe8LWKjG+e5nIHPTYo/rXNJWskaRfM232
PmzTYiuoJngkirLX9osj7nO7J7U60AW63f3VJrHij+0amiDoX5raSUo6mUJOL906/S4TJqFuuzdy
Dj9a9w0KJofFGg2r9Ujkl/8AIZH82ry3wbZm68QAhcrGmT7ZIH+NewaWUPxDtlYgLFYzEZPQl0H+
NeTJ3qxR7MVanJneTmFGikmLIqHO8D5R9failuJZo12wqhLDAVxndz25/HH8qK9RbHBLcpRt1ODw
eaUMTKSTTo4hsk3OM1EzYY4r0UeWWFO6Q815N8cdREWj2FgG4Z3mYfQYH8zXrFs+W6Dpk18+/Ga+
FxrtzEX/ANTGsSL7/eP86iewHlXh1fO1eC3JIVny3uOuK9WZto4HFeWaHm21OOVnAUOCT7V6RHfW
kzBI7iNmPYNU09EOepMXPpigO1G30zSBW/umrJMXxGhbTN39xga4O4+/Xo2rQPLps8e3nbkV5zdZ
BxXHXWtzopPSxAGwKaZCfwpo5JGaAPm65rnsdAu4mlJOaToM4pVYZ5oERFcXQPQNU32beT2psoyq
svVeauI2MN2IzmrvoQtz2D4R68wgl8P3DZZP3kOT19RXr0iRGNiwGcfrXyzouoy6Zq9rqFuxVonB
yO4719N2NzFf6RHexP5kcqblPpW9KXQU1oYlwf3AB5xxmuZ1yNWtgWAKBtrH0VuP8DXWXMY2NgYB
5rDvLX7RaTxkgl1K8/StJLQzR4f4uAs/LIYpcxvhSP1rHgvby5imnnhec+V5W9Ow+lWNcJ1LUWOo
apEkkRKMBG/Xv2qzp95pGnWogN2ZTnJZYm5/OufkaWiK5k3qdH4Ult7vTYITKpkjTaVB5HPpXQzF
drYOCDx/KvNom0GGG4mS7uhdyPujkjj27P15rQt/FDxReVLM94vADFNrfzrOdFvVGsKyWjNLUGB3
ccrzVSzf/Szg1NeNudXPGeoNVbXicjpXP0Og7FGUwIevtVG8lkO0Rk/KPz5ot3/0ZcvkjvQ6hUUs
elTuNmhoDF1uEPVWFZ3jeMnw+zY4WRTVrw0+6+ukz1ANS+MYQfC14em0Bv1r0aa/dnDP4jymcn7M
wHcVkSjDAVomeMx43c1QkGeQQc1mhshPStG2gLrhWHNZ5GBg9a2NNbhapiQ17Z0TZkHFZ4Hk3G3d
kjFdwbWCLS1uGSPzHzjd6Y/nXDz5+1uRQkDt0PfvAkxbw5becJZWIJ3O2O9dq0kIiLNbDAHGZK8C
0/xpeWHh+O3ikBuh8iArwqjuaXw/quoaz4otxcXtzcspMjFpCEGB2WtYy0sQ1qevzTvqPiVJHRXE
EW3bnGP85rftSTaBC4jCvxGGz+NeJ+JX1m68Q21jYeaLl2yGjYrn05r0rwulzb2lvp94GN4jBpAT
u7560k3Z3Ktqhv2qW3u3X7EzTq5PmDbz+Zr6d+FWrC6gjEqFHuIRkHqGHUV8Q+Lm12PxbeWgMpju
Hwir2BPGDXvvwIu9f0W1NrrscqmGcSQvK24sjdR17H+dVT1Vial77D/iNZa5o/iW/n1WFtStllaK
BpHUtszlT69K8je8hS+LHTfLLc8KnT619J/H9Fgs7W+jhkleZQyhEJHHBye3GPzr5iu9U+0xxNNA
bR4l3TRkdD6e/rVNJ63HzNbGz4Y8JP4o8ZWsLkNFCS04Hr6fSue8TeJNKuPEN0unxCe1gkMcHCkF
QcZ/HFek2Guf8If8LptUgtfM1fWT9ntlc/MIyPmP/fPT/eFeSv4Vs5pU1bSG8uJjmSCQ/c9cVLV0
O9jUS7mutLhmjkjhEjFcMuce1cnrEcst+LQyiTjc5UYwPSuk1O3Nv4cuEjJ/cFZgfQd65fS54G89
7mXMrkEMx6iojorClumbU+nQWmnWsUY/ezDLkdhkYq7oOmy3l65GQYxuAIPIq7pUQ1B1uV+dY/kT
Fei+BNDkmvJrq5JiWQ7cgdBx/wDXrRK7DZHU+FbCQeHUlSN87GcYHcHAB/CuF1xw+o/KBjHGPqT/
AFr6T03QILfQcRoAkcRPy98186a1Ai+KLmzjJKwyeWSRjoBn+tXXfuGaV3oNt9Ka7t1Rh8qrnHuf
/rVzGpWEVpqMwjRQQdgI7FeCfzBr0myL2OkyX08WAqNMM9Onyg/oPxrzm6kSdkePkhMHPds5Jrw6
N5VHNns1PcpqBg6hMILVgTyx3N9B/kVx0++Qqv8AHOcn1Gf/AK3NbmvXPmN5S8eYcD/dHU1j2knm
37TsuQPkUD9f8K9CK6nm1ZW0LsVuBtVB7Y9BXsvwb8EJ4w8Xx2FwhNhawvcXDDjthRn1LEfgDXmV
jbgyO+MIeK+r/wBmmxWDSdevCuHmeFenYB8fzp7sIrkieAa5p9xoPifUrCSP5txwD/C6nB/pWza3
ktxpTeTkTac4vIT3UFlVv/Htjf8AfVeh/HPw6LLxeNSijCx3YEpIHfo36jP4155p08GmalBO6lrY
ZjnUDOY2BD499pOPfFS7J2Ola6o+wbG4g8ZfD23uVbC6jaBgQfuOR/Rh+laOkLNJoUEN6uZfLCSA
jhuOa89+Ct66eHL/AMOXEm6bSbpoxzwUYkgj2yGr1Tp0rVO5zPR2Pgr4i+Hm8NePNT0fZtjjmJiJ
7oeV/QiuVn+ZY5VXqMH619FftL+HdtzpXiaCP/WKbeYj1Xlf0yPwr57jVZYHTjPDL/WlLR3Nd9Tn
tUgYTAMMBuK7HwTHIdWtI2jZvLIzgjCgNwT37Vj3Vul3Ei/xr1IrW0C7srbUopmmW3CsPnk4X8eD
isp6qyLho7s+w5tbOi+FYrqCUB2jAiKjPPHr7Zr43+MGk3H/AAm762rN5Oplrltx483P7zH44Ptm
ve9a8RWuowW1nBIjyW8Y8wRuGXkZFef+N9Ok1rwldRREtPaKbqFNuclR8w/Fc/iBRKbTsi40046n
lXgSxe9+I3h1SFZFu42bJ/und/SvS/2jr97a/wBAs4Thhp7SZB6b5WP8gK4f4Os958VdMjdMLCsk
px7IcfqRXYfHm1tdQ+IEUV2zK1pY28H3sBfk3HP/AH1TgpSmkznfKlJo8F015HNzli2FwO/WrGn6
fNDeNNOm0Kpxn1NPu4LfR9RvIbaeO6jim2rLGSVcDuCQDz9Ks2t1LeJ5pTZG3GM5zTrNrRDoRTep
6l8M9MMem32qOGYzSbEJ9FB5/Mmu28Lot74+v5XGfs1lGv0LOT/7LWf4Xtk074d2CAFWuFErHGMB
snr+IrU+Hg87X/Etz/twxD8FY/8As1eVD3q7Z7D93D+rPQLi4MAjHkNNvO0BCN2fYHH86KhvYomu
LVnllidmMavECWGR9COw68UV6aOB2IskoxIx6VVHKse+TViP/UsD26c8mqu5VQjPc4z3r0zyWieF
jFbPN29a+QfiBqk1/wCJ7mYSkrJI7j6ZwP0FfVmr3jWvhu4lDbcRt/gK+ab7RdN1N7q4bc00JKcN
0xWclcOp54LhvugtuPcGvQ9D0aFba1vLh2Eow4C/1rgWhVbkA9M44r1O1UJYwCMfKEGPyqIK7Lbs
jRNyOzH8KPtKjux+prLkZ896jLyZGc1bkQompI0UoKsvJB6mvNdRi8u4kTH3WNdm8sijIzXL61GU
uZGxy2Grnqu6NqaszCA5pF4anqCRnFNPBPFc50DmGAD61Gc56UuSxHFLjPeiwrjJZPLRST1NaNp+
8gAxnaSKxmRrm42L90d629PXypgh6EYFaWsrGd9bl22VfLzjpXtvwn1tbzTJ9Dnf95DmSEHuvcV4
wBtBHStnwvq8mi6/a6ghOInw49V7j8qmLs7mu6PfZ0KlkZckGucugwkKgEHP0rqnmilWO4iIaKdQ
yt7Gsi+hBfcozjjNdfS6OfyPmz4gac+neMLkgbY7nEyenPX9aseEobW7sWFxCjNG+Mlck13XxI0F
9T0iO+gj3T27Y46kHtXE/D+G5ub26tIIJJZMBtiKWP5Vz1NUy6ekjpdQ03T7rTprc26JuTIZVAIO
a5jTdAkcPbwyL5kbhpEfrgdGHtXpA8I+J7x5BB4f1J124BFq5zz9KZL8PfHK+XNa+FdWW4iOY5Ba
Pz7HjkVjSvF2ktDepFSV4vU4rWIpbWXZJwwPUd6oW7HzQc9a7TxH4c19lt7S90K7sdUcZW2liKs+
Tj5QeozU1n8GfifIVb/hEL1RkH5wq/zNVOi09FoKnU5lruc5b3OyNo8dCOadd3RliVFyCPvY7V3E
fwV+Ipumgl0ZLdnXOZrmNQPc/NU83wS8XCFhc6loNo7cZl1OIf1rNUZdi3OPc4rwtKP7bdR/FGf5
1ueI18/w5fxkA5iJ/KnxeHPC/hae6tbzxJNfeIoJPLjSxjWWzkQgHPm568nt1FMuJYZ7aaJ2DK6l
SM4rrguWNjlnZu6PESqdMU0hfStm/wBMY3JFpEFjHTOeaqHSrvrtrMdjNZRV3T3wVHvUn9k3Z6of
yqSHTbyI5ETEZzTCzLcs8rIIzIxUdBmsCTL3TKBk5xW2IrmTOyEkA4OD0NQx6ZPH50ksRDHkH0oF
YySxAx0J4r0LwDYrElzfseViIH41wZi33W08cgV6nocX2PwzOw4LEKKb0CK1Ne1ujLcQTzyrAsa4
aXHzHHoa6/QIZpNSa4nb77KEHcDr1rzPWLyO303ylBFwygqfTBHNeheATLLp2kiZnaSTlix5PJq0
/duF/eSC/s7661pI2aF3ViyEgblXPHOOldp4fn1KLUUkuZVMZYptQjAXH+OK8+0nxDDN4z1PT7hj
56TOkTMByoJ4rtraRIQojIUA5wK0hG2oTrc2lkeu/EyUal8CxrB5fTivmH0XIU/0r4ysGn1vXIw6
ny3l3Oq8bhnp+VeufEX4tEeCp/AuiziQ30gN7IOdijHyD3JAz9PeuA8OxRWGizag/E7ny4xjpx1p
y0Mo6k3inxB/aHiWzSJttppyiKFVPA/vH8/5CqL3jJLJJanLy5Drj5frWNLIZtWkxggMR1q8ImOF
GcHuaxUtTRq6NeRDe6c8CqSJoni4HU44FeTxtNaXfllSVBwQa9Osr5Ld1snlw6yKUHUk/wCTVJ/D
cL389wVyMlzkYAp/aG/hR03ha1Y6Mi2rhJmXcBxkE8gc9CR617z4C0+8ntx5tpGDK3EWd2F9CfWv
BfCC3Q8SJZQsRbqgkkyOrMBgfhX1x8P9Ne3EDOSx2jPGOlax0JbO2i0cRaO1qqqpCYUdhXyWILrV
/H2qqYQqPduikHJxvPb6Cvsu5njtrSa5lIWOJGdiewAya+bvAuli8v7vV3TId2kH1Y5/lXPXm3TZ
rRgudMwviNIul+FbexjXD3soXH/TNBk/+PFP1rx+7k8uElW5I249K9E+LOqLP40/s5G/dWEQhPpv
+8x/NgP+A15Jq90IYGO7BP8An+XNctOPLGx1VJXdznbktd3UnlN8zMIUHoO5q1a2AihWZW+VchRj
rVLJSNQB82P1PJrWs2d4YVdeFG7Ht2ra9kcCtOVje0q2ZmiibgN1/rX198BbaOLwnqUyLjfdBP8A
vlBj+dfKWlQ+YscrHAaQRg+uBz+v8q+vPghHs8ATPjG+8f8ARVFEX7xc+iE+Nei/2j4JW/SPdJZS
ZOOuxuD+oWvmP/lkysPu5Bz3wf8ADFfb2r6fHquiXmnSAFbiJo+exI4P518ZapZtZalcQMu1lbGP
Qjgj/PpTqLqb0XpY9H+Eut/YvF+lyyOfL1WBrCX/AK6x42H6ldn/AH0a+lK+J9BvJ7SOc25InsJI
9Rg9coQGA/4Cwb/gFfZml38Oq6PZ6lAcxXUSyr9CM1UHoZ1Vqcl8V/D/APwkfwz1W1RN88CfaYhj
ncnP6jIr4XikEFx5b8FGxz6V+j7KroyMAVYYIPcV8C/FPw63hP4h6lp2wiBJS8XHWNvmX9D+lU9g
hqjI8jyZif8AlnJ39KGs4N0sJXIlHH1xVWxv0kg8vJKjhge3vWuLWSSw3D78R+X3qVYq5H4EW+i8
SzaeC58wg89+3+H519CQ+H7LR9Nu9Yvz5y2VtJdMrcKNiMx/lXmHw/Fn/wAJbbmdVEky/u2bs45x
+Iz+IFenfE/UV0/4TeIZQSHniW0THfewUj/vndWLj7+ptF6WR4D8CYBL8RLy4X70dhJtx6llFY/x
21m5n+M/iKKG4YRRXCwYHbYiqf5V3v7O+nRL4ovrkqxZ/IhGecAvk/yrxb4gagb/AOJ3iO8DBhPq
Nw4JGeDI2P0rSDvUuu3+RzyVou/c53cfsxycksa6Wztj9mgs04d9sY/3mOP5msOztxP5YJwFw315
rt/C9qb7xlpFqE3fvvOYeyDI/lUV5fgXh1bU9v1Aw2uhWtoilEhVY1JHXGAP5Cq/woPm2WuXY583
UWA/BFFW/F0otrJYyAxhXpj0HNQfB9T/AMIObnH/AB8Xk0v/AI9j+leZhdZuR6+I92nGJ6EbWaWa
OSG6aJkbdgqGX0PH0PrRVy265xRXqI86W5zqTKsZLY6mqsZD5GMZJ4/GrFwi/Zyo4zWeGngUHqBj
AAzxXpX0PLM3xyTb+FpI0yTI6qNoyTjk4/KvmzRdSI1m8t7ndH57MSH4w2a968feJrrTtKtb7TpT
bXdoxmjk2Btr5wDggg/iK+adV1W/1TVLrULyUy3VzK00spwC7k5J4rJ9GHkVbpok1GRRnCuf516L
pV5BJpVuzSKvyYwx54rzQNJuz1P0qzFLdA/IpPGOhqYuzG9VY9W8hJEDDBB5yKje3VBniua0eTVr
iyWNJ3iWP5QNv+Nay6bqEv8ArL6XP4Cr5kxWZYaJP4sZrqNJ+Eq+M9MXVm8YaHosYJiMd9OFkOO+
305rkDoE78veSn/gZpw8PShQDduw7Akmodnuik2up3Uf7PvhqMYvfjH4aj/3HDf+zCuC174eaHpf
j+00Cw8cWGo6ZKitNqioVjhJJyuATkgAHj1p48PMOs7H8acvh/DbgQx96my7FqT7noMfwl+BcC/6
V8WLqcjr5Fnj/wBlNedfFDw38O9G/s+0+HmtarrVxKWN01zDtRF427TtByeatJp17F/q1gIH96pf
K1UfdjtFPrjNPTsLVnaeHfDX7PUHh/TzqsXiW51EwI1ztwq+YQNwGMcA5FZPxGtvhDbeFFPgPQdW
t9USdGa4upSV8vncMFj7dqxRFrRHFxap9FqG60/U7q2khmv4yjLghVHNN6iuzjsBwsmMBqdHHtkJ
XueadbI3l+S/34nKH8DVrytsmK5ZHRE9Q8FeIlvdBfRZj+/tz+6Pqp/wNdVLuNou/lmGM+9eLaHf
nR/EdveFQ0QYBx6qeDXvckMEtik8eNn3l29CDyK3pvQmSKWjX2p6FJLfaVJFHeiMhWkiWQDPswIr
z3wv/b/hPxrqXizTtfMOpaiZDcMIo8MXbc3BGBz6AV6RhFZsjjqfWuC1fT7Kx1m4hNmu3duXOTwe
RVszaOul+JnjyVcP4tuh/uMF/kKz5vG/jGbhvGGqnPYXsgH6GuVAtQ2FtY/++aN8efltUH/AakEJ
4km1PVoxqFxqd1c39spaGaadnYd8ZJ6H0rN0fxG/iJBHO832lRh1kkJyR9a0S7FcC2T/AL5psaSR
sTFapGT1KqBmlfSwJa3HSabGxyYYyfeoH0yID/j3j/KrOb1uNmPxpTBet1IqGjRXM5tKhPP2eLP0
qnLotuxJaKMVufYbzGPMUUw6TcuPmnA+gosh6nOyaeq8DaAPaqclqR0fH4V076HIx5uGI9hTl8Mp
IMtcP9MYpcrGcY8DAcSk1SvJHtrSWbcSVHHPevQf+EY08D99cMPctVO78N6HLbyQvfxoGGMs1HKx
XPM9O11jBDpptUD7yfPUHccnPOOtdZqemiCWS2tL+21SPYCJrSTehyuT78ZwfpUCeCvD9pIHfX1k
IOQQSprH1DQNPt5Wew1tdn9zBJ/OqaT3IV1sZ0WjP9rjkN1BIzOHZEOSoz0NdvdzLb6WkIbb3Irn
NDs7UX1xtklYKikFsZJ7/hW7qGJb2GJcYCZNRIuJR/tDfKsryRHaMDIB/pXq3ge5gKafI5XCKWGB
3wTXkFxJ5eMxKY9xXNeq/D6OB5dMZztWRCCp7cGlF7o0cGkmZt54WuLrUJtTtb6OMTSGRGCEEAmo
JdH1CygeeXXiEjBYk7u341jahcarL4lvLNNWuLe2Fy0UaK3RQe3tUOqaPq1y0dlpl3e38k3VGbIx
Tjd7CmlHdHP2kcupaq0hyxlfcT+Nelv4WOtaPv0bUvtEenQ5u4olIMDliCDnG44AORxWe/g2+8Ht
YquoWl3qd3FDIkUbf6iaQ4WOTdwGHUjtXQ+CJfEEvhz4gtPqAttXkb/SJzIE+YsfMGRwMjI49a0n
poY01d3OKh0CC1nMn20Oc9GIqxPCthiOW4TJG4ZI79q4ndtmnMo3bckZqpFFK8BnwTI53Z9BWav3
Kcl2OtlNl9uF4bpBKMfxDHHSuje4FzosjRnb552kjsD1I/DNeaGYXQUSKPMTrxjNdtDchNFiIUtu
AQe3v+lXFtO4fEju/AkbXmvxJbNthhYLt25yfc19h+E7ZobRSycbeDXy98G7AXF9GCuASCDjpX15
ptsbayjQ8HGa2TtG5lJO9jnfiVfvYeAL9Ym2y3eLZfox+b/x3dXH+HILXQ/CBvpwEjhia6l9lAzj
8hVv4mSTavrGi+H7ZgGDtcSgjPGSqnH4PXEfFTVLzRfA8tiyLGuoutsm1udo+Z+PwUf8Crkq6tRO
ykrRbPnvV9Ql1LVrzUJ23SXMryuT7nJ/nXGag7X2qJaKcheX/P8A/VW/fzrBaySscDr9aw9KTDyX
E3+sf529vSkiZu25ObKF5wpAwgy3vVqCNhGHVQzSOFQfoKYu5ot3Rpm/If8A6q29FgWfVATgxWwy
Pc9qGyIpRVzeghm0+K3j8tZI4h26k9zX1T8HzeR/DSwljtWUXFxJKd46pkjjng5Ar5lE0cqOitva
M4YY6Hrj8q+vfhxGIfhpoaD/AJ9w35kn+tTTT5iZao6YzyhM/Znz6Ej/ABr5g+Kum/2d4zvJXh8m
Gc/aAMjgHOT+e6vqKOVJoFlRgVYZBr5D8Y65P4g+JOvzyuGtDJ5NqhcH5Ixt49iefxrWRdN2Zy1j
erZarbXvEkWf3gH8aEEMv4qWH417B4S+KF54a8IafpS2CahFBcy2rXBlK+WoXzIzjByCN3p92vF2
t0jg8lMrtOOvfPH9Pzrc8PXUNzFfaYqsWnsyybv+e0asykf8A3r+NYczSZ0SgpG5q37W+r6fqE9p
b+E7OZY5CoeS4YZAPoBXlXjT4p3nxS1gahqGk2mn3FtCIwLdmPmLknJz3Ga8t1uUzarcMDgCRvxO
aZpE7RapGzZCONjfQ/5FdSXuK+9ji5mpux0to7x3jRL/AMthgc9Dn/Cu60ycyRzQlslMDmuAkJjl
Ei/eibNdDb37RSC4jcLnGR6iskb2Op0+6nt9SVUbbPbus0R9wcj+Vdb8ffEUD/DfQLS2k51K4+1l
QeQqx8Z/GT9K80fUxJdR3cQO5RyB3FV/iRLcX+heH7sndbWokt+OzMd4J+oyP+AVUdWNuyZ6j+zV
Csenanqs2flnY7mPQRxb/wCZr5w1KW2utRu7lvkZ2LgAZySa+jPhMW0r4E+IdTHybbC+nBz32bBX
zXp9hNqmo/Z4yQvV29BRD42Yy+BFiwbbPxwqqAa9h+C2l/2l41v9UlGIbGBYwcH7znPX6Ifzrg5t
KtNPtmKxgY6s3fFe9fBXTYLD4XXOsId0upXEjjIP3UOwD8w/51jiNIORvQ3UCn8QrmKG1uU3Eklm
De2P/r1b+HM09l8N9Hjt7XzmkiaU84xukYgn2xXDfEi8mSW6debZoypB6qc9a9N8CpFH4G0WJNrF
bOIEj/dB/qa48JG0Wz08W/ejHsddpOow30hjjDKyjlSPfGaKl06CCKVXjjVGOAWA5IBJxn8T+dFe
gvI8+T1M54EkjKnANRxWe0q2dpAxg9xUsltIHWRWwVHTsRVtGj8hnl42rnP0ruvoee11PF/HjwTX
0luiqyK+0r245/nXBjT7Tki1i/74FdNrG++1CaVclWdm49zWYbKXoEJ/GhLQzb1M9bGBSMQxr9FF
PW3jU4AX8qvR6ddTZ8uHj3NOXRb7JwsS57HJpOw9SqqhejDFODHPDjFWTomo8YkjX6LUi6HqJHM8
Y/4DU3Q7FLex/wCWn6UeY/Y1f/4R+/6mdD+FB0C/OMOgougsygZJOpNMMzrkfe/GtD+w75SoLx88
cil/sS+Q4wp+gpXQ7GX9pI6oc0jXLn/ljJ+VbA02/Vf+Pct9KZ9gu2U/6E7c/wB6lcfKZK3EvaF+
PWk+2ybsbMY9TWsNOu+n9mN+L0DSrwnP9ngfhmlcdjj7ixaO8lvQwxKwyg7H1qUxr8rdfauqOjea
kiTW8inbwcYAP4VnQ+H1fIn1FEwegGTWcoOT0NYyS3OdulXzFPTivXPh7qc2q+G7i0Z98lkBxnkr
2/wrmodI0eOMLOyXDf3mA/xrQ0y5tdC1GK8siscRPlzKgwGQ9fy61cYOOonNPQ9DurUExyhdoYcg
9q5PxjZSNNa3aNuBTyycenSu4Q/aYkA+ZWUMGxWPrsAn0xo1/wBYh3bTTuO2h5usUnXmpVjfFWp4
5IonkZG2oMn6Vg/2/aO+0eaB64qZyUPiFGMpbGwFIHXilDKpySB+NZKatp7g/NKPwqxFdaTMcNPM
D9BWXt4dzX2My6ZoxyW9+tNe+QdD0pixaS5x5tz/AN8gVMun6NIu83V2B7KKh4in3K9hPsVn1UAd
cVTm1ggZU81ptp3h5SPMur0ZOOFWh9G8N97m/OfZRS+sw7j9jM52XWLjPyyFc1Qn1W+bOLhgPY12
B8P+GCufO1An22VGPDfhp3w0mobfX5Kl4mHcaoS7Hn093dyZ3XD/AJ1nSmd+rk/jXqp8LeEDyZdS
/EJTW8KeEyPkm1DB9VSp9vDuV7GXY8mKHvzWt4e8N3PiO/e0t7m3tii72edsDHtgV6LB4b8MW5JW
W7LZ6vDG2PwNbFrBodph4JJI3HDFLONdw98GolXjb3XqVGg76o5yx+D2rJMJF8QWAHfbvOR/3zWu
3wlu5JpJW8QWiMy7RhJDj/x2ugi1u2VcR6ncqPQWq/40p1yAkhtXvl+lvHXP9Zq+Rt9Xh5nPP8HG
a3ELa/amPHOInz/KtjQfBcvhs27LqsFz5JONysMggj+tTSa/YoAp1e/b/tilU5vFGnRDAvrqZh2a
MDFR9Yq9LF+xjaxkzfDy8k1m51ODUI5pJ3LAMhAQE5wK1vCNrq9vq2kyWckZguLlx9rRchljOG2n
2P64rOu/iGtvA0cAdiQQBtq34L1Q2Xwz0W+DY+x6vdWxOM7RJEjjj6g124apUalJvZHPiKcbxR3V
/wDDLTdaWeHUNZnZJ2MjusQ37ic5yWqbSPhJ4d0jQNR0dNRupLbUChl3Iu75TkYOeOazZ/EOo8NH
Ps+gAqeLxJqpt1P2gEj1A/wrl+t1Hq2a/VorYmi+CHw1ETm7g1Wd26st4EGPptP86tR/Cb4XQwBV
0O+kAGMNqB/otVzrut4JF2uMdAB/hVa013W5WR3uSqMM7cYP8qj6zUfUpYePYnvPhl8I9N0651i4
8LSqltE0rltQlI2qMnofavm+41GKeRViiW2h3ErGCSEGemTycCvXPiv4x1K18IjSTfOWv22umcfu
1wT+uP1r59Erz3EcSAtz0Hc134eUpw5pM466jCXKkfQPwwvr5df+0WCyTw20ap5UTcMzNjJ7cDJ/
CvtDRrh7rSIJnVlblfmGDwSM/pXyX8ENCura+mjmTaGKsOOor6l1XV4NA8K3OoMR+4hJRf7zdFH4
nFeg1aCRyu8pHHQ/8TP4h6zqhO6O1YWsfsVGD+ua8N+O2uG+8aW2iRNuj06EKyg/8tXwzf8AjuwV
7n4eRdL8Mrc3z7SUa6uJD9CzH+dfIeu6xJqev6hrlwCZLqZ5Bn+FmJI/IH+VcV+ZuR2Wtocj4inV
p47MMCCcvj0H+JrOiuHMhRePM+UmobhzdX0k38JO0fQUzocrwQe9aJaHnVp3nodCsg8wkcCJePqa
m0TUfJ8TC2ZsIIirf75wT/h+FUrJxJCHfGOXb6DoKfBei1uvtH2O2nYncfMTGfxUg1UYOVzXnXKd
/aeXFLcOsm/z33Y9OMV9oeBtw8CaNF6WkfOP9mvhrS/GHh0XUMWoeEZCrMFMlpqLRbeeuGR8/Svr
Hw/8WfANtpFrZxanNDHAixKJIHJwBjkhaPZOLuF7nR+P9aPg74V6perNuuI7cwwsRgmR/lU/gTn8
K+ENGePTPEdrdk8F9rsT2PB/xr7Q8c6t4V8W/D/7V+71K2EoeKKUyxB25HbByMnrXg3/AAgvhTUJ
mc2d3bq7HCRXPC/TKk/ma2hB6ik9E7mVdxeXOTn5XGePbr/P9KqWN1LputW19EPnglWUDscHOPzB
H41sazaCxuZ7clykO2RCxySuMHP4ZrGuEZHDDkqcZ9f8kfrXHJWdjvi7o8v8c6QdB8b6pp0OGtRL
5tszqDuhcB4j0/uMtc4rANloIz74I/kRX134c+HXgz4j6LbarrtvcS39iosnMUxjDRj5oyR/usFz
/s111n8A/hdDgnw4Zz/01upT/JhXbBc0Uzz5pKTPjdnE0ImAyHUE47djToGmaBl4IjOB2OK98+OP
w70Pw1pmk3/hvSo9PtWL28yRZI3feU8k8n5vyr58VClyElcqp4bnr6VlKFmbp6Jmnau6Okqk9c7T
3rsrLTZvE+iXXh6wiWa8uFWW0hZguZVOduTwMqXHXvXEx3CKw2ggDpW9oesSafqEF3GQGikWVfwP
T8az2ZSZ6td6dqPg39nPWdN1iwezvRZpA8BI6yz84I4PA7V4b4TjtoYZ5wmxie5z0/8A116z8UPF
txefDVbCaYzrNcxRRO6gFo0TcCcd/mH414VBPLAhWE7VPXFXThzOTRlOXKoo1PE10TEkKnhjz9BX
1z4b0b/hHvhDotjIAskVmhYD++y72H5ua+RtJ0648Q+IdN09QzPc3CQHjPDMAf0Oa+2/EqwQeGNj
OIRCmQG44xgY/Ss8Wvd5TXCa1Lny/wDEy4Q2s8ag5kYV694cCW2g2ESY+WFAcf7orwzx0xmvILfd
kyzBevb1/WvXNMvktilukoYNgqAenTP+fasKEeWmjuxEuarbsj0S2lVEZ2PAUn9KK5rV9Ta10OR1
G6RxsCg9zRXZBKxzM6XZm234zkcis/UCv9lzehQgDNRDXYvIKR2lzISMD92f61Uu55L2xNvDay25
z99sVurnnvY5BtOtYcR7IUJ6DPWqMmnLcybTIkcY/hTgmtyLwsou2up55pnOMByPl57U6Hwdbx6v
NqUc8yPMMNHkbPyxWj5nsZxSW5lR6faIi7Su3oMNS7LAD/WRAHjrXRp4dRdo8+TaBgLkAD9KD4Ss
3aNjLLtRg20vkGs+Rl8yMBFs2UlXRtvBxzipI0tHBKMHAODtGefSuqj8M2BneYR/PIQWwxGcdO9X
rbw1aQMWijCFjuOGPJ9aORhzo4kJatEZc5jXOW2nAxwaVktowhdSqv0O08136eH7FY2TyU2N1HY1
P/Ymnsgje3RlHIBXgUezDnR56otPNaIRkug3MMdKkVImClbZzu6dOa9BTRNNTPl20Yz1+Uc1OumW
i/djQfQCj2fmPnR5y1q+/b9hkHOMnFZqTl7iSI6TdIY/4jH8rfQ166LGA/wil+x2/TaBR7MOc8t8
hhIoFo7AnGdjYH6VLJY3CEGK1Ljn+Bv8K9N+y24HOPwFNNrb9duRR7NBznm1lZXr3gabT1ELLhgQ
R/OoZ/Bmn3Eu77CEGTwOM16iLe2P/LMCkNvD2QU1GwnK55dJ4G06TG+xjJ/GoT8O9IkGGsyAfRzX
qZijxgJSGFQOY/0p2C5xkGhm3gSCOWURoNoBc9KSTRFd97gsfVmJrtfs8f8AEAKU2sJXPBpcqK5m
ee3fhlbq3khPyb1K5HvXHx/CIo+86oxPceV/9evbzaRg9CfpSrZRs3C4+prOVOM/iRUZyjseKJ8K
BGcpqBAP/TLr+tPX4WFWJGpNtP8AD5X/ANevbfsSD7xGPpTltIsdOfpWf1en2NPbz7niy/DVlOP7
Tl2+hT/69Zuv+E5tB0OfUI7oymPGFKYBycete9GyQn7nX1rlPiNpqDwDqEqqMpsbp/tCs54emotp
FwrTbSufOQ1TUN3/AB7oTn++f8KkbUtRcYFpGDnOd5/woBU5I24pBIobtivFb8j1EiZL2+HzfZos
+pkb/CpjqGo7MBIFHrkk/wAqqtMuOopouM8AildlWRYtX1RLppZtQSSI9IhF0/HNaP8Aa5UkNHu+
lYpmYc5GKVWDYZjkdeKT3uwtpY2Bq5aMnywD6Uw6y2/BXA91z/WsppO4NQGX5vvGhWHqbseqKhOG
P/fH/wBeq11rD8+SWY/T/wCvWSfmPU/gTT1gVTv3807IFce93dS/MWINLH9nLbrq4Mfbp/8AXppK
7c7iSKrARBsMFB9+TRdD1J2TS5JDtu5iBySIxj+ddT4SeE/DPxFFkyxWOr2d1gdSrLJGfzwK5u3W
Is2a6LwL5Z0fx/pYGVOnx3Sj/rlOh/k5r0MFbnce6OPF3UU33Op0vxD4U1PTluJ47y3diRsX5sfr
V5b/AMJGLJv9Qix0AQGvPIRFCgRMDb0ANWN2Icbmzn061wt2lsdUU7LU7qLXPC6xsDd3+MZ3PGf/
AGXNUbnWNEDFrfWblA3QNGePzFca8yqMcGsTWNRFtp8sgGGxhfqapS5mkkhNcqu2c9431uTVdemI
unuIYf3UTtxlR1P55rAsFBuFcngHP1qpNIXnPetrR0BOCoO7jkV7MI2SijxpScm2z6s+CGLfR7qd
2OVVIldjn5myx/Ja7TxBqkmt6lYaKJmxPKty8Y6LEmVT8zuP4CuI8CQSaV4Os4ZBsabM8rd/nx/7
KB+Zra8IXUuq+ItT14L+7JEUAI6IBtUfkPzzV4mfJCy3ZeHjzPmO+1+C0vvCd7pdzqi6Wl5GLdZS
MkLkbgB9Bj8a+SfiZpmleGdROl6PrB1REiUNLs2gSsTkdTnjaa95+Ieti2eKGZhiztzLIB/fbnH5
Bfzr5T1u8n1TVpXY5YFpGz/eP/1q86lJym10R11UoQv1ZkICi4JIAGKFJwR3PalbPmMp7HpVqytp
by+it4ELySOEVRyWYnAA/Gu9HhN3NK3s7mLSkkS3laOZvvhCRge/1/lVdxt6qRn1r608K+IdL8O+
FdO0OTwzfbLWERs4izvbqzficmo/EN54L13T5YZtDuIpGU4ZrPkH6it43S0OpR0SZ8kAgTL7HtXq
ngLwfrvie7hOmWCXKRkl/MkKrn+6ffFcjqHhW/03Up5bW1nltyxCHymzj6V7/wDAR77R7Z1uFdIZ
JGmKMpyCQABj1OKqzauwtZ6FnU9Y1YaXJ4Y1jwnF4fbTmUxGOYSiZW/iBCjH3aoadEJCrEfKDmva
Ljw/FrbyXuqaFPLLLwMsVIUE7RjPufzqp/whtjCcw+HbjI/6a/8A16anZWHy+Z454qsFaC3vFXP/
ACyfjsa4J428sxEfMvyZPqOn9K+jPEHha7k0G6jt9Amj2KZAxlU4xz0z6V8+6gRDesGGA4z9CP8A
61clZXdzro6Rsdx8HtWFpr9zpUrYjvYsoP8AbTLD9Cw/CverCVLxpI7R0meLiRVYEoff0r5N0W7l
03xBb6hEebeVZcA9QDkj8tw/GvWvhd4U8T6P8XNX8RXUd0dEmt3jik2sRc7nUow9sDOfetaM/daM
K8NeY6T4zaY0/wALtSWe2YtGUkiPo4P/AMTur4g1OA7y6jDA5r7q+LmrFtJsdK8p0Wd2lcPxkAYH
H4n8q+L/ABHYGz1K5tSP9W5A+nb9KU58zsaQhamcu0kqkENwfatmwbd5RK4z1qjb7gNjEFVPINdB
bWzeX5gUYxnjtWb1EkeyeCvhpovj7w1e6tqLy3lzpTCMWLXDQxlMbg+VBOeo6D7vWut034VaDDbs
bTwpZRzg5Vhay3HH1lyM/hWf8C71LTxh/Zc8jpHqVqQNrFcunzDp7Fq+lDpNgxzJCZM/33Zv5mum
FTlVrGM43Z4pbeG9ZsgipaRwRocgO0MK/wDfIIx+VbGs+G9W1/w8bNgpkdNokVtygegPevWI9OsI
sGKygQjuIxU/loOiioqyVRWaKpydN8yZ8kX3wD1WeUTS3TSSLwp9Kr/8Kt8daaytYtFKyZAMkYJ/
PIr6/wDLT+6KQwxHrGv5VGlrGntbu7R8Zaj4Z+J0gWO60qJ4kO4eQpzn86K+yzawHrEv5UU9Owe0
PmyNpDg4IqYBj1P61WSWJurH8KmGf4GP5V2WOEnEfcsfwoFuhOSWP40iOxGGJH071LvT+JiPrSAB
HChzg8ds09biH+7+dMLQkj5gad5kC/8ALMn6UAkWFmQDKqfwpwlD8bWFRpKhHyoR9TTmkA58vH40
h2JQxxgFhUikDkymqomOOQBn3pwaJR15Pai4WLD3Wxflyaat25AOB+dQGUH+HP0pNzdBHxSuOxoJ
ckjJUH8aVrtW+Up+VZ25/wC4KcPtJHyIM+uaLhY0RLFjkAU4OjHAAIrOCzrzIxz6dqmjwT8xyaB2
L+xWGPu49KOn8X61UBwec4pwKvwpIpAW8KfQUozn75P0qONcDk1MNo5L/lSGIyhjk5NKIwSOKcHj
AySTQGU9zigYcKflA/nTgpkyWTFBMeOnNAdF5yBSuOxJGAhztz9TVgdjhapfaUzQ15t6CgDQCA/e
Ap72tvPA0U8SSRsMMrjII9xWR9uI6dKGvmC80AY3jK18K+HfDFzqL6FpolP7uLdbpjeenb8fwr52
i8N+HrnMzTx7mOT+9I5P416X8cb4v4OsI952G9UkeuFavAzcXKOJeiHriuOvvY7KG1ztf+ET8OF1
QXC7j2+0f/XpzeEvDgQsl3gjgYlJ5/OuQEhfDqSoPTmphOQEw5Qj1Pf61y2OnmSOj/4Rzw7wkl3s
cnbgyH/GopPD/h+Mso1PBHHEp6+lcxeNI0itMPMZV3ZHf60xJI9x/eHJ/hJ/Wjl0D2mptXGiaMDh
dSkB95TUaaFo2Ru1JgxPI801mSJ5iEkZGOM0loDMnzRsNvXPahRBzR1lr4b0KTcG1GTAHJ88DH1p
zeFNIkI8vxFtGM480VgFTEmPmbdx17VWkCI3IBPUGnyLsJVDoV8K6G6kf8JJcMefuspHFQx+FdCl
AaHxOzqeAQ46/lXMteNBKAr43DovFPDHbvxwf4aXIuw+c7GHwnoqqVPiKRHDbedvX0PFW/BVimn/
ABI1nQorn7VHqGi3kAf+8xgLj/x5K4gzpuA3HOeR1zXQfDu9W3+MnhmWT7k90lu+P7smYz/6FW9B
KM0zCvLmptF610CK50q2vpdfW3M65EZA4PfrTG0GRpFS11+GZ2GVVdpJH4Vz8yTWjT2coy0TNEQT
joSDVSGQb1Yybs9McHFZ1KUVJ6G0Kr5UbM2lX6syrqMbFeo2jIrifE880M62bzCQqN7bRjntW/cX
m2Nmy5UDJJPSuA1C5a6vJJWPLnP4dqKVNc1zOtV92xDCC8vI5rvvCWlfbdYt4SPlLANiuM02EyTg
4yBzX0B8LPD4E8mpXACx2cJmJI6t0UfmR+tehSWt2ee+x3fibU/7J0WO0iB86fEKAHkEjn8lGPyr
t/B2nrp/hu0imIjBXzZWPpjJP5DNeY3FrJrnjrSkEgkh2b8qc7WMhVs+/wAor25dLOp2h0qMGOO5
227kcbYz9/8A8cDD6kVx137Srbsd1NclPU8F+KtyR4W0/Xrqd4bvX3kuxZkcxWynEZJ/2htwMdq8
BSUo0khb943JH1/yK9M+M3imPxN8Qr1rZh9gtSLS2VfurDFwMexbJ/GvLZS7P83DdORTjCMdEcuI
qSaSY5WLuzHvXu37N3g7+3fiKus3MW6z0VPPO4cGU5EY/Dlv+A14bCmWUfia++vgT4S/4Rb4V2Lz
Q7L3VP8ATZ8jkBh8gP0XH5muhHHBXkel/ZLdvvQof+AilFpajkQIP+A1MAfWjafWi51jVgiX7saj
8KkAA7CgAjvmlpCCiiigBGAZSrDIIwQa+QviJob6T4ju7dVwLeVmT3Tt+hr6+rw742aQq3Vtqir8
s6GNz7j/AOsf0pNXRtSetjwNLhYQpJxnjNfV/wAJNZTV/hzZKJN0lkTbOCeQB93/AMdIr5EuUI3R
knjK5P8An6V6n8DfGtpo2u3+l3s4it7u2Mqb2wBJGC2PqVz/AN81lHRmtRXidL8S9T/tDx5Pbqcx
2cawjnvyT+prxD4maDLa/YtZVcxXimMkdmXH8wR+VdumozavrlxeSfNJczM5+pOf613/AIw8FnXv
hJqLrGfM02MXEOP4mUZf8NpP44qY+/PQ1dorlZ8dhFWdW7Nwc13FpAJNNAjwPl6fhXHXULJK3GCD
XYaBIk9jGu45Thq2SOfqdf4avn0nUdH1eFsSWk6tgfXkV9p288d1aQ3MLbo5kDqfUEZFfDmntkT2
p4Gdw9R719X/AAs1n+1/ANorPultCYG+g6focfhVvYymjuaKKKRAUUUUAFFFFAHyyNi/dyKmSQ9s
0LHkcDJ96lWJhzgflXaYXFV/Y5p3mP2Q07YxPFPEbj+L9KLBcYu5fmMeakDTseIwo+lTxxvxk1OE
IOc0gKwinJ5IH0qZIiVwQM+9T7scU4NkUrARCI45xUirCpAcgn2FKyM2MZI9KcrMhxtAP0pDLMao
R8qk/WpfJB6ACqwlmHQYp4mmH8GaBkv2dTznJFMEBLYIOKcJH6kGniVhxgj8KQyu8JHABNPijzgs
hFS+Ye6k08bj0G360hjxCp6Gn/Zi3RsD2qECQMQWFSrIyHkmkA77NtHJpRAc9M0CcHsc08XCqcFi
PwpDFWAk4x+lPFs30FKl0ucHOfapUuVY4xQBEbTd3pDYoepyatiRcU4MvoKdguUDZxgYxTGs0xgL
+ta2VPUU8JH12ilYdznJbJ8fIhrMubG8PKbvzrtzGp/hFNMAbpRYdz5w+MUN7B4bsTcsBF9p4Ldj
tNeONIrw7V5yucd6+jP2hbdF8B2BPP8ApyjA/wBxq+bUQQ7CuTu7VyVV7x0U5e6SfafLvLa1PWZg
g77ecZr15fhC7pvOpuXYAcRcfzrx6RUfxPYMoYLvjPJ56193wadF5EZCgZUU6cE1qKU3c+c/+FO3
TDi/b6eV/wDXob4LXowVunbHTEYr6S/s9QchM1MlsDwyEVryR7E87Pl+T4N6vHuC3Uu08jKDj9ar
n4Xa3E6sskm0dR5fB/Wvq+OyhzkjNTiyh/hQfjRyR7BzM+Pbn4da6OV3kYIxsOK8vu9Rmt9Sn06V
BHJBK0bswzg5wa/RI6Zak5eJfyr8/PiRZpZ/F7xNbINqLqEmB6AnP9aicEloNSbKMqwvOjkkOUC9
fvc9R7Gty18O63ND9rs9Kmu4HGBt4zj0Nc3BZfvVk3NIQeMjjGa+9/AGj2afDrw+Fs41LWUbkAdy
uSfzNZxhd6luVlc+HZNE8awtn/hG7lgDkbVzn8qfp02s6R4k0vUtU0yexe2uY5U81Cu7a4Y4zX6F
LptmOtvGfwrwb9pvTYk8JaDfQwKhivHjJUdmjJ/9krdQSd0ZNt6Hifjy2vLP4leIraw0+e7jXUbg
4hjZsKZCV6A4yDXOQWetMwI0HUMnsLZz/Svpr4T6hFc/FbWWkAYanpVreZbu3lxk/q7V74qwgjCL
+VXUpx5ndEQnLlVmfm74it7vTbFVubK6tJLkkKJ4Wj3AYzjI57fnXEfflPp0r2n9o/xiPE3xVu7W
2kDWOjL9ghCnguDmRv8AvokfRRXjdtHvkAxWXKloglJt6nZ+EdKF7qFtbqDukYFhj+EcmvoaTyPD
ngTzivlm5zM/rtHCj8eT+IrgfhJ4YF9aXupPE+wlbWKQHARm6sfYDJrb+IerfbriDSLZsQGRVRB2
jTgD+X5V0N8kLiguaVjrfhXbzXsrapdc+THsQn1JJJH1JY/jXp3jbX18G/CTUNYEm2/vQbW1OcEM
/GR9FBP4Vz/gjTBp3h20tVAEk2CfqeB/j+NeW/tFeNU1HXLPwzYORa6RHtbnhpnAyfwXb+JNeZRd
7yO6rpoeHPOslzJPIQRnA/D/AOvmqsjGa5LEYzTQ6D5OpB6U1WJywOST1roR5dSbkzvfhV4Rfxn8
R9K0Z4y1qZBLcnsIU+ZvzA2/Uiv0Qj2JGscaBVUAAAcAV82fsxaBZaR4e1DxRfkJd3zfZoCVOREp
yx/Fsf8AfFfRA1Kzb7tyhre2g6asrl3f2xS5B6VWW5gY8Sqfxp4ljz/rF/OlY2JxinVEJEP8S/nT
w6nvSsIdRSZFLSAK4v4naT/avgO92rmS2/fr9B1/Qmu0qK4gjurWW2mXdHKhRge4IwaBxdnc+FL2
PfIcDlhk/UcGuevbadUnjhJVyCQVOD6/412fiS1/sPxffaTK3ME7RnPpnrVCWBfOjmIz2Yfj/wDW
P51lJWZ2JnWfCuM6rDBdy8vGPmU8bmHbP1FfWlvYwJpC2LRgwtHsdTyCCOfr1rx74ReH7E6BbT2S
qp88tOCM8qeR+PB/GvbqVNWbZlVlsj4C8ceGjofjTUdJZMLDM8a+46qfyxWL4bzFeywMTkDIBr3/
APaD8PC38S2etxphL2La5A/jTj9VI/Kvn5j9j1mGdeFk+UkVvLe45aq51yN5GpQTD7rna1e2/BXW
vsniK80SQ4iu08yMHsw5x+Wa8Vji+0WRC8Ecg966nw1qsmm6xpWqxNiSCRS3uAeR/n1qlsZyWh9f
0VHDLHPBHPE26ORQykdwRkVJUGQUUUUAFFFFAHzMnTOcU45zkPVUOB/FS72PINdpgWtx9aekmDg1
VEmBzikEjMeopAaIlbHBFSK7EdTWegbPEhqVdw/jNFx2L43cc1ID7mqYlIwCc+9Sed/tYpBYuCQD
vR52Gx1qiZuynmhXb+9QBpCbjtiniYHFZwk+XG6no3djSGXJLmYL8ihvxxTPtkuRuRV9zTFcE9ac
GRgRxn3pDJxdYGTICPYUv9oR9jVERE5JZT9BiozaFzjzcfSgZp/bYSwIY5qQXUZ5PNY/2FRyXJNS
pbDPLHH1pAan2uDPX9aet1F2GTWaIY1PAyfXNTLtH3cZoGaKSg/d4/Cp1Y+9Zqs6nt+dWUlPcD86
LisaMYJHzGpxtHGTWcs5x1qdJCRmlcZbyD/EQaeoYdHJqsGGOadvx3FIZZOeu4igSBfvDPvVXee3
FNMpzjeKAseX/tAlT8PbNwOVv06/7rV81BwWKZ/pX0f8e9z/AA5gJ5xexnj/AHWr5ejeYsR5ZZye
CfSuarubw2NKbC+IdNcgYIQnH1r73tJFNpCQeNi4z9K+BLkuupaZK6eW5AJX05r7u0+cvplqeBmJ
D19hV09iJGuHUD7wp4mAIA5qjvBPUfjT/PIBI25rUkvCXuAMU4TA99tZf2wKfmxmkF4hPLACgDXE
iufv5xXwP8Xth+OPifZwDdj/ANBWvuIXi44Jr4L+IpDfF3xJuZnDX8mT0J5rOexS3Ibc7MYP+Ffe
vgS4QfDvw/vJ3CwhyffYK/P63eQnJY4Q4K4r7h8Gal5fgHQkLZ22UQB/4CKinuVI9EFzFjAcZPvX
kP7RUK3XwlaUEFra9hk/A5X/ANmrqBqNtbuWJBlY5aRvvE/0rgvi1rEOofDXWLJZAzGNXA91YH+l
bMlLU4/4Q6kg+IPhqd22/adNNscd9oZR/wCgivf/AIgeK7fwZ8PdZ8RM4821gIgU/wAUrfKg/wC+
iPwBr5H8Cak9pcaFfxZ32csn5A7v8af8c/iXceI4LHw5A7LawsbqYf3mxhB+ALH8RVSd9SIqyPDr
25kurx5JnLyOxd2bqzE5JNW9Oiy27v296y0Bd8+prq9EszNdwwgZJ5NRFXkJ7H1FpEdh4X+Euk6d
Fbu15NGL03KMDG+8MMDHUgflXlNreQX/AIwF1cShYVkCI7cjr1/PmtTxLqH/AAjXgeOzVyJljwBn
pI3p9Ov4VwVtDDHo8D3s86Tbd6mNyrAn/wCtWWMnZcp04WN3c+qovFGhWWi3GspeQm20+I4VXHzP
ghVHuccV8f8AiHU59V1m4vbl9808rSyH1Zjk/wCfepY9SvWS4invXltgQ+GGMkA4zjqRk/nWFK5k
lLMeT29zXPTWhWIlZOw3d97B61paPZPqGq21lEvzzSBR7ZNU47d2AkYAKBWzaRGy0x7lWK3Ep2K3
cdzj8MD8a2vY8+NNyZ9gaFc2mi6NZ6XbSp5dtEIxz+Z/E5NbcOvQAZaYA9eDXxB/bGqQ48u9kwP9
o1KniDWiMC9k4/2j/jWvtTp9mj7lTxRapybjJHvTm8b2ijb5w4718ON4m1pfk+1y7vXzD/jT4fEu
uk83Up+sho9oPkR9uSfEHTY0y0y7vfFZ0/xW0m3YBpFbOeR0H618ejxJq2Pnd3P+9VmHXL1/vwse
3NHOPkR9Sz/GvTYjhRnH1rKuvj75bH7Lp7yY6fPivnn+2ZF/5di31ApRq+fv2Y/BaXO+w+RHtl1+
0P4g+7babHH7s5aucvv2gPH7bvs+oRW47bYFYj/vrNecLqVtJgPbFPwprS6XLnfE270WlzNhyroZ
+reLdW1jxHLq2rXJuLm4YGSTYFycYzgADtXdWdwt5aRTAFjIgcfUcH9QD+NcdJp2hzffeRCe2f8A
61bOnXNlp1uttFdMY4ydhYZxnHHH0rOV2awdtz6Q+BesJHd3+iyMB5yieME/xLw36bfyr3avjfwL
4vs/D/iODUv3lzKDsSOMBQS3HJ545r7FVjtBIwSK0jsYVN7o87+M+h/2z8NbuaNN0+nsLlPoOG/Q
5/CvjG+QTWzMg+ZDu+lfoXeW8N9Y3FncANDPG0Tj1BGDXwd4j0mXRvEeoaZOu17eZoifoTVvYuGs
bGnpciy6bC6KSXXgirliWiklikOMHctYHhq4dbSW3zzA+Bn0PIraeXbKkuCRjBo6XQl2Pq/4a69/
b3ga0kfAntf9GkA/2QMH8iK7KvAfglrP2bxBfaO7ER3kQmjB/vL6fgT+Ve+ZqTOSs7DqKSloJCii
igD5LF2mQQRmpRdZHOK5KO/OMYOfrVqO9BAO7Ofeuq5nynRi655YVKt1j+IYrmxdL1Bpwuwe5pXH
Y6dLtBnmpBeqBXNpcrweal+2D1pcwWOh+2KSMkCj7UOzVzovI/xqRb1e1HMHKdCLjJ5YU4XJzxWA
t7gdacL7nlhS5h2OgFz0JNSi6UCubN6TwKcL08ZP50XCx0X2oA8Gni4H96ueN8gH3hmmtfD1z9KL
hY6UXKgY61Kt2PUCuXW/PQcZp63jnjfkUrjsdR9pVjnP5U5bjn2rm0vCPvPx9alS9AHykH6mi4WO
kWdT1bAqRHh/vc1zf28diM0ovsjk0h2Om82MHA6etSLLbIv3+a5b7dx1pUv8GgDrUvIscMPxqUXq
KOorkPt2T0H1NA1Buf3mKLhY7D+0IyPvZxTf7TQds1yYv8DJbNM+3cnD4+lFx2OuOpL2z+VRNfZP
GMe5rlhqEin7wI96il1Jh6fnSKsY/wAZrhZfh6q5Df6XHx+Yr54BA3BOAOa9i+Jl49z4QMecjz4z
jPvXizEAqwPGeOetc1Xc0gJq0pW5sZWPO3P619CeE/jhoCeH7a28QSS213AgjLIhcPgcHjpXzrrC
vJb2soBxtP8AOsNpXBxk04t20Jk9dT7Hb44+AFGf7Xk+n2aT/Cmn46eAsgf2pLj1+zv/AIV8cb3I
5NLu5xnitOZk3R9jH42eAHODreB1yYJMf+g1C/xt8Ag5GtMfpbSf/E18eMfxzUe9s4JNPmYj661L
48+CLSzeW21Ca9mAykMcLgsfTJAAr5Z1XXJtf8VXut3WFlvJ2mYDouT0/AVjyAleOtFop+0KD61n
KVykdxbRoIVKgYbrkV7N4W+KGiaXoVrpGrXf2aS3HloSCQw7dB1rx2L5VRsjapFc/qsjJqc454ck
UoOzuXK1j6UvviT4Zcjbq6HP90Hj9K5TXfFXh/VbK4tINSEs0qFFTB+YkYFeDGZvf86kt7h47qKV
WwUcMMexq22yOY9G8D3sMIhe5kEcENwGdm6KpHJP4V5lr2onU9Yurw9JpCVB7KOAPyxWtJfmz0i9
tYz80z+Wv071y7fNNgdBxVN6EPexd063M044+UcmvV/h9pAm1VbuZR5UQMr59ug/lXnuj2x8sDB/
en9B/n9K9jsnh0HwZLcudrzDJPQhAOa6KSsrmTd3Y5bxhqJ1rxdb6aDujjPmOPc9PyHP/AqydYuQ
sjAYCgYFVPDkkl5e6hrE/wB5yQPYk5wPoKr6uxeQJ3c4/OvHry56tj1qC5abZXG77IiAZeYliP1/
wqZ7dI3WFSHbqzYpEx9o8znbH3p8LZVpm6vyPpz/AIVstDlklJkhXzLiK3UDCjJH8q9El+GXiG5t
7ZwPLQRAhCO55Oeff9Kw/hzoj614wtUkj3xhvPk9NidvxJA/GvppreSReVPPStoQvuK6R82zfDLx
BGTkgjP93/69UJfAmuRHHyg+6GvpaTS53HzHj0qhLoO9yXjPNW4DTR82v4L1vduJj/HIpg8Ka3GO
BD/30f8ACvot/DRdvkiOPcVCfCMkmf3FTyMfunz6vhzW1YMI4ifZ/wD61X49H1oKoNmHx3Vxya9z
/wCEIkOP3WfwqzD4NKctFnHtRysNDw1dI1nGf7LmJ9mX/Gg6brCRH/iUXWT6LnivoWDwqiqMpWjB
4ag+60YqlAm6PmT7HqiFQ2k3o9cQMf6UvlXi8tpd0nY5t3/wr6qi8M2TcbMEVfg8Maf0dA1PkFzH
yEERc+bBMpPJzGw/pTY5IfMwwCjGfmOBX2hF4X0hfvWiN9auJ4f0Neumwkj1UGjkDnPlrwRYLrPj
TRLK0K7jdxF/LP8ACGBY/kDX2+0uK5eztbCzINraQwn1VADWh9p4+9VctiW7moZhnlfyr5e+Pehi
y8Ypq0A/d6hCH4/vrw39D+NfRn2nsSK8z+NOmDVPAn25FzLp0olBH91vlb+YP4UWKhvY+YdMm+za
2iknbcrt/wCBDpXVbtyMx2jYeM9K4m6Yq6SqfniYMMe1dZFIskKy7zsYDANTF9CmjpPC+uPo3ibT
tWDkrBMu7/dPBFfXUd5HJGsiPlWAII7iviO2DOZIlbecE7R1C19NfDjXTq3gOwklfdPbL9mkJPdO
B+mDRF62Jmtmei/aVz1pftA7Gsc3Ix1pv2kHvWljM2ftBorIExz14oosB8Wrcxkcn8qlS6UfdH61
z63WB1qQXZB9qXMTY6A3R7NilF4x6vXPfa1zzxTjdDtS5gsdGt8398Ypw1E5wdpArnRdY/ix7U43
SjnPNHMOx0Y1Fuwo/tI+hJrnftfOMmlF2emanmHY6Nb9yOMfjTxfEfxAVzXnnruxQJSRw5o5h2Ol
+38cyZ/SozqJDYBrnxKcctTw5PXmi4rG7/aHPU1J9vJI5x+NYSk4GOKe0jdsUXHY3hetgEtxS/2k
QcA1zvmPj5mP50nmEdKXMFjpf7QfqW4p66oScB65r7Rgctmm/bgvfNHMOx1a6kc8uTUo1Rc53E1x
x1NR95hUL6uoPDZo5g5TtzqozkcUw6uM/fx9DXDNrR24UHmq/wDas2flSlzgonff27Gsnl79zU4a
yf4TzXnUmo3Ryd4Q+1QNe3Tf8tmx7GjnHynpR1hlPzSL+JqCTxJbwZL3CenWvNWmdjy7H6moWfjr
+dHOHKejyeMrROj7yPQZrNufHoCkRxE/XiuELH1qB2CjJo5mFka/iHxbPqumSWZiCgsGzn0NceoM
q+YrZA5xjpSX0p38HA6jmooULEncQD0GelYzdy4mjvjuLMxS8Fc8+grOk09N5G4ZChue4qWVlCEs
SWxz6GhWXKlT0HrSvYbVyolgGwFcZIyBUZsiMtuBGcdO9aGV25xg56jinMMoQo54INPmZPKZb2TA
nLAbTg01tPkBABB3HA+vpWqw5wDye1MAVJMMCf7mPWi4cplnTJi5AKkg4ODVi10mRg0m9QVbbitC
MYbesrcnJDYJqZG8uYjpuwORgGk2NRLETBIxGc9Pm96XUYbG8HmTBoZVABPUMMdajaJniVkdQx5x
606CMqX8xvkA4VuvPSi5XL0ZSl0SOKNpTMNgIpv9iApvEwwK0EiVSW8sPzkjOQPwPSkv7k2tg9zE
vllQBnPU5o5tQ5Fa5yN/IVldSRlMk8Y5NUrWJpZlRRkk4ps03mvyxZmJYn1NbWmWqwIt08qb2B2J
nkHpzXQuiOV66nUeHtONzqcUEeSMhQfp1NdN8RbmY6aulWnzZG1iP7q8n+n61N4KtBZ28t/Iv3Rt
U+9YurXsWq6mbbazZl9SAR3+vGa1rT5IaBRhzS1KenwCw8PQQFcPJ+8b8f8A62Kwr1i+qqOnloX/
AD4H9a6bUCwOMYA4HFclbyfadXnlP+r8zbk+g4/xrxaT55uR61X3KaiWsfu1hIxvO5vYen8qdj7s
IHU449KkuCiM0kh5YjpVvw7pk+ueI7WwtVLNLIsYPuTiuxHEz6D+CvhgW3h6bXJ4f3l63lxZ7Rpx
+rZ/IV64tkuelLpdhBpmkWmm2q7YbaJYlwOwGM/WrhPPrXVHRGe5XFkP7gxUy2EZGCoqUN7VIrDb
71ZJW+woB8uKRbLHPBq2ZMDgUzzOfvUDIxAq9VxSmOIgkqBTjMM/M3HvUEkinJoCwhjTPBpRGucj
pUIJA4brUyHcOQB70gLUSLvxzmrQAHaqyMoAzzU3mgduKYDyzA54p6sTyG5qsZAeADmm7mBwM0wN
BZOeTzU3mYHTP41liRx1qUTZ4LUCsXvN56YqjqttHqmkXmmzAGO5iaJj6ZGM08YPVqXFID4r1W0k
sr+e0mUrJEzRsPRgcGremTs9lFGGwYzsPpXWfGHR/wCzPHFzNGu2K9UXKfU8N+oP51wGlSBL94m+
7IM496xlozoe50Ls0GoRSRYHBB9817H8GdVaG61PR5MgSItzGG9vlb+a/lXksc5+wzRRsTK64JI5
AAOa1vBeryaX4p0/UC2ESQLL6bD8rZ/A5pJ2Ymrqx9TNMewFN8055Wq4mBXcCMe1L5pJ4NdJgWDK
AeRRVcsT3ooA+FiSOeaeHbjIpFPHJNSAgjArnuOwnmYPT86cGYnrilCE9VGKcY9ozmlcdgDL3zTw
wqE4Vs9fpTSxGSAAPrSuFizu47Y9aPNAGBk1TLOSfm6ULITkHNFx2L6yA+pqYSEDkVnLIRgKMU/f
IeelHMFjQEg5JyKkWdTx0Pasvc3Uk/hTlfLYUUXHY1fPyeDTGuGB4qoHKjNI0u4YBFFwsWBdOcgU
nmSN1P61VC++fpUiildhYsDzMdaQpu6saaiuTwv4mpwgyMuM+wzTCxX+zqaeLRSPu1OAE7D2pPMJ
4JpDIjaRKPmwx9BTTbKegC/Sp+COaUZJwBQIpNZBu5qJtP44YitcIc5xzSmIkUWAxGsW6K/6VGdN
lPRga3xCR1I/AU8xgelMZzL6ZPjqoFUZtNumPGMexrrmhBJAGT7U02gPBU1LHocFc6PdOhCoDxxz
WU2ma2rfKFJHTNepfY8n5V596gfTJOoTn34pA0eYGw8QMCDDGw+lJ/Z+vbdohQfhz/OvTv7OA++M
H/ZFOGnLkHYSKYrPueYpYeIUAAijP1FS/wBn+JmAAhjI+lenfYSB8sYU/Snrp7nhulOwreZ5f/Zn
ibOSkK/UimnSfEbvu2xZznivWotKDdV/OrK6GrHAUU7DS8zyNNI8SsSQsIzxzSnRPEhGGEJI9TXs
SaECfu1YTw8CelHKFvM8aOj+KmQ4aJfpipP7I8V+WoP2dgO5717ZH4bjY8/pVkeHIVUHJ49aOUPm
eGPpPilgu1LaMr3XPNZGqWPiHEVldRNKpO/dFGWwM45xX0YNCtgMtTxo+mKMPLCmf78gH8zTsDV+
p8wTQQvbrapbh2QgmXdj613vwz+HUfjPxZp1pCWijWVXuN53IY88/SuZa0jg164s0K+WkroDnjAJ
Fej/AA01BLQajFuAJMcROOxbH+Fb00paHNLQ6XxRDpkU+uWPgaMvpyXDxWZJLLwMEg9SoIOPbFcP
4c8J6/FrDS6y8ca7CVwvfIBNe7eAPBq2WgD7d5USRTSxxb22ZTzWIPPXqB+FaGreEbe71Q3H9uWF
rAqhFVS0jep4Uetc9eSatc6qMWnc8t1iwsI9Fu7qdEkjtbd5cAYYhVJ4P4V4EiT29uhwynqWB7mv
rHW/h7oWr6cNNl8aS2yzOqu0Fl95R/DlnXAPFYdz8GvhzpiZn1bWNXlUf6q2kiXP4KjGuKlGFO9m
dNZzqWujwKEfaYo/PGSEDHtXtnwA8MSXHiS98QTxqLOwQRQZ53yt1P4L/wChCp10LwvZAjTvhRqF
9jjzL6a55+owgrutC8Q63pOlxWWk+AbfS4GAkKxNCFDHqfmmJ6AdRmtlVgmZOjKx6iSoBGM/SmiO
aThInP0U1wcviTx27HyksIkJzzcFCP8AviI/zqoZ/E91GPtWtRxszlgoSSYD8S6fyqniV0QKi+rP
SGSeLJdQoHUuQuPzqNpHjKkrwwyCDwR7V50kWoI6ia8jmA6lYdmfwLN/Ot2TXblYVjit4tsa7V3E
nAoWJ11G6PY6f7Se6moXuwOoJrl5dZvpUADpEf8AZHT86y7i71CZ+NRnXsNrbQPyp/Wl2EqLO588
nnnn2pr3EKD97KqfU4rhB9oI+a8mZR3Zyc1G8aH7+MAdW71DxfZFKgurO7Gr6VF1vrfI4x5qg/zq
F/FegQZ8y+Q467Mt/LNeeyNatMctGSB65rIvb+2hUoh3EfwrgZqfrUnsi1Qj1Z7lBPDcwRzxMDHI
oZSeMg8ipjIAfvDArB8Ov9o8L6c5wSYF/litUAnvjHrXop3Vzie5aLA9/wAqcrY/i4qoVJ6MCfSl
3YONw/OmIvZU9Tij5M8ZwKptI4HykGlSWQgFlUHvz/8AWpDLgfA60pkOODUPmtzlQPxpAzMcACgR
5V8cdKa78L2uromZLKXa5/2H/wDrgfnXzqkxjuYph/Awz9OlfZXiXTP7a8MajpZCsbiFlUY/i6r+
oFfFU4aN3jfIKkqQexrOa6mq2O8sZQhliYZadBsz0zmprQMLmWNsLn5tp7HoRWBp14JLSCdl37fl
Zc+laFrdL/aoLNuD/wAJ6jP/ANesX3NEz6h8Ian/AGt4Usrkk+YiCKUHruUYP+P41vb8cY/OvJ/h
jqvlz3mlbiA6ieNT6jhv5j8q9P8ANOOa6IO6MJKzLPmD1FFVTgnPB+poqybHxn5ODyuBSBduMKDV
so7dcfSnCLOOlc5RTBbBAT2phjmY/wCFaYhT0Bp/lYIwopWAyDDKVxg0htWIwxraK9RgZ+lN8k55
TIpMZki2wRgk/hSNb5B5wfatfYBwY8CmtGxztQYqSjKSAouCdxNOETA8itFYHP8ADUiW8jMECZLU
AZvlHutPW2YYYgDPTFaf2QlsY4X9akSFFXJB49qaQGV5J6EZJpfs7F+EzitfyS4yqgAe1J9ldhwc
n1oBFBIGB5AFSbVU/KOati1dRzn6UvkE+pFMCjhyfvHFLtOMAflWmLUsQMHJqZbFjxsH1pbgYZUk
/wAVKEOCcYreGlvkHoPapBpZznbkinYDCRHIxjBqwkbLgMOa2k018/cxUp05+pQ4p2DQyVjOOQBT
/LwOma0DYOXz0HoakW1ZRz81CCxlmHjuKUQ9h9cmrzoQhJQAVVeW1HS4iH1cVLkhqL6F208O6peR
LNa6dczRt0aOIlT+NaKeDvEL9NFm5/vYH8zVay8e3WlWS6fbamBFHnCxRb8ZPsDSt8RtUkXCz6hI
fRLd1z+O0Vk6r7Gns/M008CeJ3A/4lyx/wC9Kg/rVhfh1rz8yCBf96Uf0rnv+E18QTNiO31Nsf3p
FX+bU0674nmI/wBBmPb97cj+maj2z7fiV7PzOqT4a6jjMt3aRjHOWP8AhT/+Ff2sIJudfsYj356f
mRXItN4mkQN9jtl4wN1wx/8AZajEHiOcZ86wjwMco7/1FHtn5Aqa8zsv+ER8PRf63xRbsR2QA/1p
x0PwjBkPrTPjrtT/AOsa4yXT9aCgDV4Y8jBEduP0yTWTe22qRxlm1y6LDqAka/yWo9u+5fs12PSD
beEIwQtzcy7fb/61NL+G4uUgunx1P+TXkIinupfLbV9QcjqPtLKPfgGpl0fTY08y4R7g5DHz3Z+/
Tk1DrtdfwLVJdj0a98QeF7PIkZIWH/PWZV/maxpfGnh12K29wZjnH7hvMz/3yprFXStMQCe0soYt
3JVUAFaESALgKB7CsnXb6stU12GT+KImBFvbX/P/AEykA/VRWfJqmrTZ8uwvGz0yyj+bVuRWhJ3H
r3PtVpbA8EdPao9o31Lslscn/wATWVWMtq8fHHmSL/Qmub1HTrq7nKGNPwJPP5V6hNZKItz8gVnn
TolG7ZljyaXO7ha6PELy3ey1JYXBBTK+nc11nhR0S4vQhwxjjkxn0dayfGSLb+ISAMDdn8wv9c1Z
8PTTpeM0RXD28icqD2yP5V7uHldJnjVo2bR9EyXbyLFjIBClip9QDn9agmcqgUL5rSDruzn1PPYE
fp71UsbhptNhLOFdVCkgYxxwfyqx5ixqd4LrzwOScjH9K8XEKSqySPUotOmmzRs4o4o0dI0jaIZV
gmCWPc4q9LcysiwhndmIzg5A+tUbRgQGIK57Y5//AF1cUlFJOOO9JJvcb8iWcSSRhVbAJy574p4j
ACA/PjvimrKOhfLcjio2nfzCMAD61aiTctcnOeMjp7UhZMYPXGM1Du/2uaQh2IwBiqsSSkA9Dg/z
pNvBwMGkKP0Y455IPWgfMdqc+poAi2hiQVBz3Ip5Rd2BgCrCRD35pfKXdn2qSisYsgKmQfWopLKB
/mkBcnsTV/CopIwDVCWYkkrwe2TU3ZaRQnsrXGBGEHsK53UILCJGOAzV0tzPGqMc5x3NcteRvd3Q
igYNI3AjQ5Y0oJtmjskddomrTw6JZxxSFVCcK3B6mtM6xfpyxyBz8pzSeDdJs28MxC8tvMmSR03O
TkgMf8/hTdX8MXyq8+k3G8DnyZOv4H/GvWhKyR5zV2yYa/Nt53A/7XFV5fERA5faw75rzq91e/tp
3t7pXidOCrqQRWPc625H+s/nWnOLkPVH8WvFlvtCr9DWbP8AEVrZ+ZGcDnivIrjV3OQHwPqaw7q/
dyf3jH8aOcTij2O6+L0kDExRyD/eNYt38eNXhH7q3if6mvI52D8liePes51myQXDjNHM2S7HqVz8
ffF7AiD7ND7+WD/OvLLvV5b7Vbq8nAD3EhlYKMDcTk4HbrVaWFz0AFUZo5EboPqDSvcVzuNCmLb4
sjaTuwfWtabdFNHOnBQ1xeg3hW5RCcE8Gu3mKy2yx+2DWbNIu56F4S1NrXWNO1IOGhMoRjnlA3BB
9ev6V9AbeeK+SNB1Ga3R4XO5R8rA/wA6+pfDmoR6r4bsL0NlpIhuP+0OD+tbQZEkaWQp6UVJtB70
VqQfIYQL97qKdtLdFH1xQyM49BUkYJIB7dvWue4yDbIGI6elSDdgdc1cEJY7jwPenFYVTDKSfYcU
DKoDnnH4YpwJGDj2qyGjZcBQB7UHYFxxipGVN8YOcHPbmlQGRvuYye1StHG4wY8n2pgS6D4jcgUD
J0tiy4JK49TV+CCJYztPzdPwqOFZyAHXPbJ71eUBRgpTRNygI5xIyrbAoe5NPhtmeNjPGEOeB14q
/t+XgflSAMOhIPvS5ddx3K32ReMd/wBKiaLaQo+lXAJGYhse2Ka8ToMswA9zTAqtCR1GM+lOS2AI
JBINS74gRklv0qRJtvKqCPU80hliK3A+6matx22eoVR71CtyzKFHHuKkDMXGGOPSmIs+VCDtZ930
FO/dAYCAY7mq6hmb0x709lYD7240XHYsiQlgAuOOwxSlNxPNQxqWIYDafrVjO3nIzTuKxA8AA3VD
JbIOemass+QST+FCrvB3fhmpuUkY2o2x/su62feELEc+xrldOmt5oV3EBz0r0F4VaB1YcMCDXkds
GTBBII6g9q5qqN6bsdfGVRjtUDnjPer0UsLjaVANc9b3O5AJMbqtCYjkEnFcjNzbWVFbkAd+lXo5
Uki5YBu3Nc0Lgty351KHlU7lJx7U0FjpY7uNQY2OBjnJqL7SgyykYPp3rE+0S4+YcY61C10Sdykj
8Kq6DlNmW4DZde1cvrl/shkYOeATx9KvSXZCnOBnpXM63/pFvNljuKnBqLK5VrIr2d+kW6XYS7Y2
Ae/augZFms1WQ4BXsOScf41y2jxzXKxXBideFVARjnu3t7V3Fvaq0SBhu6cHvUziWmMsVcxKTk5U
celaqRoTyKs2+lSHaNuAPfrW5b6Wqjc4HrwKlRRLkZlvCp2gg4J7d60EiRGDbM9j9K0Bajb8gxxg
GmNEqJygDDvmq5SbmTeFpPkVeOlUDZzE8uwOf4e1bLtHuLEqAOpzWdN4g0O2ci61azh29Q86gj9a
nluVzHjfxMtDbeI4mIJ8yJWyfxH9KzdEnEV/bc8F9p/EV1fxCez8V6vpg0C6ivCIyjlG4XBJ5PTo
a4yDX/Cui3SpKJ9VkjIJaIbEDD0OQTg98Yr18O7RVzy6yvJn0LoESXdhCV+cvBGxX8Mf0rcazlZt
3l5I6ZNcf4C1zTtb8FT614dZrvUNOAjuNHaRVm2FvlkVjgFctg+mB61qjW/G8+Ra+D7eDPRrnUMn
8lX+tY4iF53XU3oS9yzOiS0n5PA47t0qRrWdpM70X1GM1zyt8SrghEtdCtN3GT50p/QitFvD3jv7
Nuu/EFhbO33Ut7An6/fc1kqbaNXNF42IkYF7mRgOu1to/TmrkFvDCoCr06k8k/jWCvhXxLNHtn8a
XSj0hhgj/XZn9aa3gKVyGufEWq3ODyGv5EH5IVFLltuO9zenuIASGlVcDPJrKfxBomnM323WbSDn
kSTqP5mqKfDvw0rb7nS0uTn/AJbO8v8A6Gxq/D4e8J6XtZNDtIB6pAgpXguo7PsZlx8QPCxLJHrE
UxA/5d1ab/0EGki8d2boRZaPrN6e3l2DqD+LACupF14btgAvkLj0I/pQfEOiRfcC/wDAUJqXKC6j
UZdjlf8AhLfEEqYs/BOosx/57yRxD+Z/lT/t/wAQbof6N4csbb/rvdl/0Vf610Z8VWIB8uB2x0+X
/E0xPFssgxBZuxzj5SP6ChTj0Q3GRzg0P4pXpBfVdMslPaG2ZyP++jQ/w48YXnzX3je5weqwIkf8
hW5J4tuySvlhMHncxOKg/wCEkvJG2iSPPsv/ANel7VLoHI+5Rh+DWmuA+r+INTuz1IlumxW/pPw3
8DaLMtxbW4aVeQ7SEnNZU2u3EaNJcXGxFGSTgAU5L26mDFBKQo3MeQAPWrjVb+FEumluz0ZbyxjT
Akzj61E+q2SDJz+Necm5eXlbhQfdiary28kgObocjHAFL20ivZI63W28L65bGLUgFONqTRkB0Psf
8eK8I8TaXfaB4iutLnmEixtmN8KRIh5VsjI5HvXokdjD5sYeUvgjvj9a4/4il4/GEqou+MQQ7W2j
keWvUjr+NaU5ucrMmcVFHJ/6zl41b8Ka1vAchogPxpY7hRhXUDHUgU8TxAsdwDZxzXSos5rlY2UD
EKAQT2BqtPZ2seA0xBIzjqf5VpM65OZIxk8kGs64lhWbKlWy3JznAq7WRF7me9pG7bYldjUL6OcF
jx/vVLdXvkDaMsWPAHb64p0M/mL5rOu8dh0NZtu+haS6lBdKkjnSa3OGU9+Aa6WK8uMKpsmYnuHG
KrQXMbY45NXkniQAuwx2A6mpbfUpKK2Ok8NadoVzebtX1aSwQ/eYJuAr6B8G3vheOyTSNE12LUJE
XO3cN+BxnH5V8uktMFL/ACRnoqn+derfBS1X/hLLqZU4js2GfQl1/wDr1rTeuwprTc95I454opWo
rqOc+TVt+eRgVKqInIwvuamCEnqKR48ggDJrAZAXwSM5pVIK8jI9KaqnPzRsB61Zj2DGMc96TGNR
EOAFwaUxqc9BVgeWE4O73pjRjOcE+lKwxEhj+tTBQBhU4qNUORgc1YQj+JRQkO4KsjdGxirEaSE/
cJqPJPU7acJioAJYqPemInQIMh1IPoKJXRBlIyT7mozINuQT7ZqIFzIcgbR0ouFhzTOSMceoFM4b
qM1IV49AaYyqPX8akYjxxLyM/wD16QSKpwBQgcnHBGeKlEBLZBHHtSHYWE7uc4qcNIPp700KF78C
lUjOBnrzmnqBKsr9On1qcODjPAqsvl7uTk+9OaRS2EX60AXVl2kYGTSmQsfmHNUw43Acj3qYOCRj
igZYXaSS1OaUgfKw+lVyT649aapycg/h60gJHdmXkde1eXzRtFqd3Eqbgsrge3Nenhd45Bri/E+k
X1osl7psSzXNxMAkbZA5BLEn8KyqJtaFwdncpW+8oCI+3c1eWIEAghTXNR6Z46ucANZW4P8AdQkj
8zV5fDPi+RALjxAIfUpAo/U1yOL7nSpeRuhMfeYgHuOacpROS+Vz1B6ViL4KvpiTc+Jb6Ve+JxGP
0pR4C0j/AJebqWb3kuWbP5Godluy1d7I2pL2yiG57mJQP77gcVQm8QeH0BL6naAjkgSgmoF8F+GI
fmMELH/aBP8AOrtvp3h6wYPClsjgf3EOD7Uk49xtS7GOnirSJbkRQx3MqE/fjgdh+gqe6vLd03vp
motEeCfsUg/mBXUW+u6fZ4KKkpAxkjkn+lSy+KEmUqIBg8YAzmtOal5k8tXyOUsb0Rufsmg6k+eu
9EQf+PPXTQXetyW5+y+GUQ4xmW7VfzChqrpqkII225Y1oQay8J3pGVPbms/aR7F+zfct2dv42uce
Ra6XbcDq0kv8gvetj/hHvHE6DztctLdTjH2ewwf/AB92H6VjjxPfqPlbn0yf8aH8QancP8sixj2B
P86r2kexDpvubH/CG65Lxd+MdQIzyIhBEP8Ax1M/rTZPhzpbrnUNf1G4PcPqU2PyVgKzl1DUmyDc
uT64xVK+a/uB81zJj/fpe18g9n5msPh94Et12zQwSgHrLvkP/j5NWI9C8CWRxBbWSY/uxRg1wUlr
cNIQWZh3JartpZqg5I/Kl7WRfs4lb4prZpocX9hKpklhlhLJwVJAwBj1G6vmYoQxBGCK+r57S0uL
YwToGQ9sfr9a4jUvh7oFxcmc3XlEkk71GT+ORXXRxEVG0jir0JSd4nHfBu7vtL8fQ31uZBb+W6T7
eA6cZU+vOK+mn8cwqP3emt/wJwP5CvK9OTw3oEeyCeCNiMF2kXJH4dKWfxd4diPOpQZ/3s1jWqSm
/dNqNJU42mejv4xu5SRHEIx2+ckf0qifFOqOxVgnXrgn+tecSeP/AAzASRdlzjokZOaqz/FTQkQr
Fb3EhPcKFrJU6kujNXUpx6o9Wj8QasIiVmQOOmVFWpNf1YDHnLnuFQevXmvC2+KtsjFrXRXdiess
vH5Cq83xd16T/Uafawj2Uk/zrVYeo+hlKvT7nvcmuebbvHG9+ZgceY5RE/75AJP/AH1WY7rNzNlW
/vE5H5V4FP8AEfxVPn/SRGCeiRgVny+Kteuf9dqdxz6MRWjws5dkZ/WoR7s9+upJEiby2XAHLoQd
vvg/4VCmt2UcBWae1PGNx4YcdevWvnt9Rv5Wy1/M3rlzUDSSMTmRm+rE1ccJJfaIeLi/snvc3inQ
rcESapFj2bP8qym8feG7NQkN3I6g8ImcZ69K8VaPdyw/CrMVvCwJYc9lHWtFhIr7RDxcntE9Vf4m
6U8x8mznmPvxVy28e3t5JsstDyx6ebMF/ma8zszBbfOqjrj5hyPwrpNP1mBIlN1Grrnow/z/AJFa
RwlK+pDxVVnefa/F94mW0eyjRiOGkJ/pWnDoPiyRPlgtY2I6J2/SufsdasIWEtteSabu7rLlD/wF
uK7Ow8ZXsMYknS31OLvLana/5E4P4EV1RwlDsZvE1e5i3PhT4jEHybmNR/sxf4Ma5+80H4kWpZpt
VkjA9LcED8cGvX9M8Y2V6f8AQbw+bn54JOGH1B6V0kPiWF5YobiBBvPzsx4Ax9PWr+q0+iI+sT6s
+ZZLHxu5yfELHPbBX+VVpdH8ZTSF5dRinbgZcsTgdK+p73RfDesrmWyiEh6SRjaw/Lr+Ncze/D+B
GL2FyZU/uSDBH49D+lQ6Fti/aqW7Pno6N4tH8Fm/0JGaadO8UKPm062fnPyyYr3I+FXjkKOjKc9M
VJ/wiatzjJ6ZqeQq/meDGHxEmN2iqwH92UVDPFrkpDDw/Ksg6Mrg5r6BXwgM4VffpUo8IIWAbpRy
BfzPnKO2vo2D3GiXuf4sLmpwFJw+nXsY7nyCSa+ik8IWhyGyPepV8H2Wcbd1L2aC/mfOT3cUWEjt
J4wv9+Fv8Kmiv7FSGkmYv/tRsMfpX0hH4N0wkGSJifXPFXIvBejjBNoH470vZIfOz50h1KzlZVFy
hxwOcV9B/BvR5rXSdQ1KeFojcOiR7hjKqCcj2y36VuWvhLQlZWOlwZHdkB/nXVW8a28SxxYWNRgK
OwqlTSBzb0LRU89KKiaU46E0VoTc+XWUheD+NNJODkn8KshCeMZpRHWQXKKqX4x+dPaIqmduBmro
hG0lRSBQOGX9amwXIYlHRxge1WNqr0UmnIvz4WPrUyr0zxRYdyi+QflQj60ZbcNxrUKRnB2g1HLb
r1ROaTQ0ytG6sPmwMe9TeWGU8YHbNLHEgPKjPpVtIkOMjPFIZVQbVw3SpAu48ipHTa+OntTiAo68
/WgBNgOOajKIc5OakYBhjcce1R+S2epH9aLDBUQtwCal8tVPy5xUZh7ZNTIgPG4miwXHGCMLnP61
E0kAO0AZ9fWpjCXzhTgetItluJ3Y/CiwJkMYDtjG01KsLn0AFSJaMCdvb3qZYvl28k+9TYdyuI1y
MkMQaGbB44x7VKICrYXn6VIqM33lOR60JDuRLGSBgGpo4EyAF561YSM4wBnPrU6W2cZ+XNVYm5AY
wPauS+IBntfDtvdwysjQ3SEspIOCCP6iu6S3GdoOSPWsrxToUuseFr6wgA891DRg92UhgPxxj8aT
jdWGpW1PLIPEF/tG+V2b1LmpG1e+cZEi/wA6gh8OeImIH9iXgYjGGj2j8zWnD4I8US4J0coPV54x
/wCzV5TpTfQ9FVY23MyTVL3/AJ7t+HFRJd3crEPPIR/vV1cXw68RSYLmwhHo8rE/oprUg+GWosMS
6tbx9/3cDN/NhVLDzfQTrQ7nDKHbk5P15pDhD8+EGO5Ar0VPhjAE/f63dN7xRqn881Yi+GHhsNvm
e8uW9ZJyP5AVosLMz+sRPN4yh5VgfxqfzI4xmSZFHXk16fH4H8L2x40qORcdJXZv5moNRtPDek+H
rjV7HS9NzCPl3QDDsDgJkDOSeO/PrVrCPqxPELojzsajpkK73voQM/8APQUq+INNY7YJWuD6RIz/
AMhW/dQRXU8V3qtrE1y/3YQoKWy/3VH8z3/KtCCWwgIEUcahRkYFdEcAurOeWNfRHP21xe3ZC2uh
384PT9zsH5sRW3aaN4nldYYNFWJjz/pF0gwPU7dxFbdjqIkYEyZB7ZrZ8PXqyaQLxGVprqR3JY4A
wxULn2AH61tHA0+pi8ZUMr/hDvFTbRHNpik8Y82Rz/6CKpal4J8YxRgxajp+7+LbCxAH/fVenW82
yOaYMdwwBz61DJKMEydT+tbRwdFdDF4qq+p4Rf8Ah/xhGoZNZtjuGQVt8Aj1zmuWvtK8fojNHqod
B/zz4r6SnsTLD5jIJQoJKhcnHsO9YVvo6anFbvY2rLdToHa3YgNAf4g/ptOQfcGtfqtFLYz9vVf2
j5hu4fGG8rc3t3yccORVGPQ/E16hdYryaMceY7EJ+ZOK+vo/A9mjrNPBFdzjnc6fIp9l7/U1pp4M
+1PuniTCjjcOFH8hUeygth88n8TPiweFdWcgNA5b/ZUn9asR+CNYY/LYSsT6nFfZz+G9FsEObdJn
6424H+J/SsLU5YYv+PeCOCNeMogHP160/ZW6he58tx/D/W2yfsOwDru4/nRJ4KvrcAyyQpn0Of5V
7Pql2BNI2FZh6muLvrlN5CY49q552WxrGHc4r/hGQp+a8B/3VNM/sW1QEvPIR3wK1bu9Ma4AYD6V
jtdl3wX4rPmL5UTpYaYjDzDL+dX4LTQBjzFlyOuOayUk5BLZqwHTbgHpTUmLlR0dvpvhOVPnllTP
+yaur4W8K3mRb6nGrH+F9q5/MCuQ83BO08Y5FJ9p2fec88nNaKfkS0juD8KJbmEvZeVKOxVmTP45
YfpWJffC7xDaJI/2W4AznOwSr+afN/47WLba7qNlMHsL+e3b+9G5X+Vdvofxe8R6cyrqDJqcPQiQ
bWx/vD+uarmj1Fy3PPbnQ9VtCxNsZkU/MYDuK/VfvL+IFUhKmNu4jHY19Kaf4l8D+PUW3uLaKO9x
8sUwCyA/7Ljr+GDWD4l+FaPHJd2Uf26Pr5bttnX/AHZP4vowP1p26oVrHiVu8jXBBcCM4IYsQwx6
VvQXsls5mspmgf1Xp0/KqGqeHrvTGkuIC89vE22XcmyWA+ki9vqMg+tZvnlE+STPqKV2gsdtZ6tB
eyJ9sma0vVOEnjOM12mi+LSblbHV5VaY48u4GcSfX3rxZJzLxkY6jFdHYySahpe12JdP4h1UjvW0
Ju5DSPoHTtdksmG9t8B6FSDtHqP8K7GHUkkjjZiJFfDoynhh2NeKeHbuS50S2mnJB2hSB7df1r0b
w/cxS6XcRsrBLfEqMTgAE4I/PFdS1MjtVKMvMYYdx2FN8mAn5Fxz0NQWc0RAKPk4xt9DVoLHcr53
lNGwJAzxn3x/jUuCY1JojFvx97nPSm+UT0XmrCQuWCSsNvZqsrAYyA3QdjzWEotHRGSZnCBicYx9
KsraHIOM1oKi54AB9qcIwen6VI7lVLdQORirCxKuDjpUm1s/40/BA5wRQAIw64z9RUu7cDjgVGoB
z/KpAvHWgBRgjAJopM4ooA+a485+ZTUqbRn5SM+lBUjBNSJtBzWQxMbiOKdtRfvDJ9PSnYYNnPFK
U6nofakMTC9UGKGIyMqTQsbEhTke9WFgAAB5NFguMjKgfNmnj5hxyKlWJd27HTinBtpwi5FFhXIP
KO7ecAVE1xtOEGfU1o+X5oA52nsKBp6Nz92lYaZmhs/MwJNSIPMGQD9CKvC1jXgZx7Cpo1jQbTkZ
7kUuVlXRnBJD1QhenSpUt3dccYq5tG44OR/KngOeAMUWsBDHZhRzyT3oMUgboMVaQPjnk1ILeRyS
eM/hTsBRGRxz9KURyZxgnPrWh9nCn1PqKsxxKAMrjPc0rDuZKRTHotWRazFMM4z6YrQYRr0wSKEW
V3GyMH3osK5RTTty4bLDvVlbQBs9SK0FhkVgCnB64qf7MhxyRTSFcz0h6cfkKGUKclTn0zWl5O0A
A9qZsIU7lB+tOwFNQvysUwf5VIPmYjgUTQSEbkOW9O1IjtGQHXa1IZKEUnDYJzU6Rg9F5psRWQ5x
VxIRuzg0wuR+WBjKk0uCR8oxjpVoRj1yaNm3hadhXKhtyykscH2pv2X1Oav7M4GTmkMJJyKAuUjb
gHJGa8g+IutmTxvpPhwSKIID9pkVe7Y+UH6Dn8a9sdFRS7sAoGST2r438SeJpLz4h3HiAco9wxXP
ZM4A/wC+cUmJvQ9CutQzq6Osjbo1I5brnrURv5C5AYqD0yOvtWRNOryQ3aNuSRc5B7Ypqssu2RH7
dwc5zXRc5zsNM1IK6qzE8gcN1ra0bVDp16+juNsUrtLaM3AbJyyfUEk49D7V59bzGNlYHoeR71sy
XdteWhgugSnBBBwynsQexrRMlnsOm6qquyXB2iQYJPIBraiKSvhip+nQ+9eH23iK406IRag/2i2/
hul5Kj0kX+orotP8ZRWcPnSXXmwAZV4mzx7ev0qyT1xQtvG5JzGoJzj05NQeDWjufCVrrJA+060i
3szDqFYAon0VSq/h71V0fxFp+oRrDMcHpkj+dZXge9j0YSeBL25RpNPZlsJ1YFbi2ydgyOjrgqV6
/Lms53Lij0G1tftFwiK+CxwPar2pOtvEUXhEGAOlULaYwzpJjkcg56Gszxtq8Wn+HrvUWbYkcZZi
e3FZN21LSvoc9ret2scQ2zDzAeTu6CvOdX1+FmbfcKewywAFcHL4wvprqWZGX5/mCHmqk3iLT5ZM
6hpEUjd9rFSfyrCVTmOhRUdi9rut2iQs8N1E0hGFVWyc+tbWhXEfifRXtdVljkusl4phAsZO1The
PU/yrmYbzwHckC70adGJ42zE16Pp2l6PZW0KabbyQEp5ixyMxZR6nJOKhaj1ucsnhO3uVaKWPCSD
bvHVT615Tq+nXeiazdaZersngfafQjqGHsRgj619AyyWds0iFwSuGIAOQK5nXpPD90F1LWdMjmjh
AiFxKDwB0X369KdrhZniwmI6HFP+0lR96vQor74eXUwhSwtQSdoyWTP0Nakvgfwhexlo7W4s2K5H
lzE/iN2akmz6HlAvgM4P6017kuuCa6zUvhpcpOx0vU0lHXy7lPLbH1GQf0qnF4BvY03Xep28f+ym
W/nigVmc+JccDkDtTPPOeM102g6pL4fvZIbLUUjgkbbMZE3iQDPbB9aj8XJpcmtPe6aVUXeZXjVd
oRic8e1SVyswobt45lkjcoynIIOCK+mfhN4sk8TaPLpuoOWvLNRh+8ie/uK+XwnPFfS3wY8KXmha
HPruqwPBNfgLBE3DCMfxEdsmtad+bQzk9NTY8d+HYWtzrenRr9stUJdSMi4j/ijb1BFfPninRoNH
1rybQn7JdRJc24PZXzx+HSvqvWTK+ny20QBkmUxrkdMjGfoK8G8T2Vrq/iVBZ/vLLTrdLOFgf9aV
zkj2Gf0raUbgtjzixsLi6k8tFIwTyK7XQ9Bljt9uSZJmO0D+v860dP0VLUGSXDSN7ZA9hWwkLK8X
lR5ZiA59u+PetKdN9TGUkXrO1jsLSK0jkXao6nue9d3pllbxeF3bUl3teuhjQkjCKSd2Pc/yrH0z
w8lmBf65kFuYrLoznsW9B+tbEtxd3dyZpdrHG0KDgKAOBjtiuuKMbnSaeEMYdW9MCtRZAueTuJ4w
O1c5aTSCJSMk/wAWD79607a4VHxI3Tj3FDQXNPcWAO/aeuD6VooXks42VGchtrMuOB6n/PeseWKC
6tWilVXDfeDj8hXR+GLaOC0MCxBIDwFB6ComroqLsyFR0x+tSD6DFX5IFUkFOnFQmBexIrlOkgDB
c56U4MufSntbtzjFRmNwTkHimA0nLev0oye3FG3PXg04DFACB8DBGaKTKknI4ooA+eE+Y9M0/hTz
yKYoJHXB+lTKMNyMj6VkykIpXI4x9asqBjJwfWkAAXJ7fSnnaRjGAeOKQCBd33cfWlQHfyQaaY5B
kqdi+9TxgADPfuBQBIq7gdpxUnkDPp61FuYDEZJoWZ+QeaYizt8sgHOKnQqB0yDVLzSx9qerkdiF
NIqxbMyZIxg+mKhdnfomB69aekasd2M+9WAij3FIZXhjLfexz7VZS1iA55NIZPLHyrTvMbHIx7UW
Ad5cQPC4NBhZsBTk9s0wyJnLAkVYhdWXhuaYWGxwyLkNgn1qdLZ3PzPhR2BpxZVGDkn0qSNjjI49
qYEgtlAyqD8anQN0AAxTUcBclqlX+8TimSSCMHtS7CvQg/WojMEABfJNIH3HJk4oAsFiR8wGKjKK
x5HJqMyJnrShhnJbp6UCH+UQckdaBGH4YA01peCScDtTUmGMhs+5pFDjakY2ED2qRG2MFJ596dG5
Pp7VI2xwA65B7igLij5nIBx3qUK+cE5HrVcqY+Rlvb0oFxkYGQMc0tRl5U5GMfjTtmDjGT9KijlG
Pu/lUySow6HPvTEcr8Q9T/sT4ca3qIO1xbmJT6NIRGD+bV8UXTGTJ719bfHa5C/CW9jHBkuIF+uH
Df8AstfIjPnikzOTOi8N699neOyv3/cA/K5/g/8ArV2gQRoHXDBuVxzivIWbBre0rxPdWOyOYCa3
HG3oR9PSnGVtyGrnoDSJt3gYIPJqKW64J+6R3B4qCxvNP1aHdZ3OyUDPlng//XonIWTEinkfKa3W
uqILEOqNGwUjt1p1reJG7T2kr2kxOT5YBVj7qeDWURvbKZXJI60xEdTuJKt6U7iO403xLfwxpLdW
ruDyWtmww56lSfT0NdBH4zsLsm3uZEmk7ecvlzJ6FW4YEHoRXmSS3Cs4R9xUZPqBT2u2cBLhRIO4
YAg1dwPonQPGz+SkGoSG4jUY818eYPqRw31wPxropdW8OeINPn03UPIltphseC5OAw9evtnOc18u
RXUUWDa3Etsw7Rv8v5HI/Sr669q3l4NzDOFOP3ibX/MH+lLlTK5j0XX/AIIWkqteeE9WWKN+RbXT
b0HssgycfUH615brvgHxXooc3+h3WxefOhXzU/Nc4/Gt238Y69bKAizrGDkeVcdD6gHFbtl8VtZi
AE805Ve7wlv1ANYypRZops8j0EKniGCW5Xctv+8CHuR0zXqKanINZl1qzie9s7iNEnhiOZYCucEL
3HJrZHxC0TU5lXVtJ0i9LYBe4jVXA78tzWhbXngeTzBp+hJbvLw8lreDd/wEk8Vn7CXRlqoupiXl
g88v9p2ly1k06LmO8hZFlA5XIbBB56j9a5fUPC+p30LWd4Jns2cSeVbyKVUjjjO09z1zXscF/wCH
jpM+lalFqOq2txjfFfyRz4AORg5z1x+Vc2nh3wKJAsdrqdspH8G4D/x1qfsZdB+0i9zzyz+HehxX
Mcs1heShHztnlXb+O012SRxw7gyR527UJ/hHt74471ej0bwfG5MsusRxgE7phIVHv/rDUlrZeG47
xFtra/MRXJuFhXJ9MZJJGO9P2UuwKcEZzwicEyIGfaVAXqDjg1wniXTtLsWQ6hdzxq/QK3Fe1Q2P
h1VK/ZtXnDd3CKP5U250PwbdOJbjwkt5cRg7DeyF1B/3S2D+VL2DY/bLofOcekeH72Xy7Ke6nkbh
Y0BJP4AV02n/AAd8VavJHJBYtZ25x+9vWKYH0PzH8q99tL5NMhSDStD0+wGACIQsYPrwuKa+uay0
67ns4Yx988lhxxgVSw3czdXsc94P+DWg+G5otQ1M/wBrahGdymRB5SH1C9z7mu9v9UtbcM1zOgbH
TvXLT6he3DOkmoLt9EB/xxVWJtLBZrrzZyfVwoBrojSsrIy59blLWNbutVhe3hjezicYcof3jD03
dh9PzrDh0iJEWGztm2gZJXtj3rqre409ZWWG3ViOTvJPH8qnimubhtqOEi/uKNoI/CtFTSJc2zmt
L0i31C3N19sjWEO0ZYAsSR1x2P51uwW0NgQdOtQj8j7TINzD6elXUszEhjVtsYIPHQH3qcRK+MbH
T2OCCKtRIuUIrdpZi8zSTMef96r9uvmEAAhuoDY/I1OsMMWGlClO657Y/SmjYBsiZSATz/SqESGO
CBEXzVVpcoFP8X/6qRLgxuyhQB0z1I9aI94yXUMvp2X2rY07R7jUzvMLRx55c9/agQumJPf3y4GV
Jzu9B9a9Bt1S0tzGVKsvArNtNPttPtzHEVRkGCM8mrrSpLEj8lhx3rGTuXFEkhDNu9femmJSOuah
Vy0zrnOMGpAeeM59q53udC2Dyz/eFO2kZzz9KQP7UpfJBHT3pDGtGrLkrURhjz3HtUxl44GaYGXJ
NCAga2BPynAoqwGHSimM+bVxgcY/CpV4AIPHvVGSVsYRSD3zQkzkd/8AgVYXLsaJbPGAfU4p6BlG
AQKopc/3l/LvUn2kM3yjH1ouBbL84JBHrTt4LYY1UEysw3Lipg+CMDIoFYtKYyOQAfWkZUCnAqr5
pDcd6cAWHUmgZZRgOrc+lTKyZ+9kn34qhuAIUcn3p25oxj+I9gKGxmj54BwentVlJY8DLjpWV5jA
crj9ai83HOeCelK47G6Z4mG1cZFV5ZMHJOPrVNHAXgkk0ySRihViaALPnA5G4ZpBcbDwSAKoncFB
JIp4B27iSRSGa1vc7hkvkmryy8YGR7Vzivhfl4q1bXDs21mJwM0JiaOgWbHOamNyoX5TmsUXACHc
4DH7uTUSXMrMAVAX+9TuKxrGUSHLdP5U4zBACSTjtmsp5DuB3n2AqdZkCFieT6U7hYufaBgsykH0
9KkE5I46e9UhOCcA5x3NKZMsAKLhYteZzknFTRum7Gcn2qihOccYpwbjAG0+oouM1RKoTrTluwik
9RWUJCEz2oE5Hpg00xWNcXIPOaRp0OQePQ1kGZhkgZFNEpfJY8UXFY1VvJIySSCvtTo9QDj74A9c
1lCRgmwYANREKcsrfMenGRQUcX8dLwH4fW8asCJL6NT9Njn+lfLjZDY9OlfQ/wAZ5SfBUEe05W9Q
7vfY/wDSvnZzmpZlLcaSD1ozg+3pTCfzpM80iCxDLJFIJIZDG4OQQcYroLTxbewDZeItwMYBbqK5
nPFGaadtgPS7DxBpF6gRpBbSH+/wP8K1Ps5kj8yJkkQn7wx+FeQBiDkcH2rRtdY1G2l3W9wyljyA
cA/h0rVVO5PKegzxJDLvRSrn5WYnt1x9KgdWyu188dawLbxdc523lukmTy2MH9K1YvEOkTEmQSQ+
mOQK0U4k8rLAimcguuAOhBqYSsBxuB74GcVHBdWEoKW94rKzZ2s3fjnBq2kEpU7Np+lCYECzyRvz
IAT69vrU4uHABLED/Z7mni0dsB0YMTgN2FOSyZyyjKZGBkZ3EdRnFWIjjucu4m3bjxyOOanCRFGd
I0DZ6PGDk1NHZSOjO2HYkMh6fMCOD+dXFshJBGx+UqAME+n9aoRGlszquy3RSQOcc9PwrRtbJg2X
nZAoyCrkfpmnwRhdshAQgYAbHH4VegtzMqy5EgJx8rdxx1HHt+FJjRLHZrPC8R1G7UONpMc20/Xv
xW+hWGFDHvXBVBGsjcYA46ms6IRpAu1VjdTnLd/YVJNNeNA32do0dgMO/K7gPQVcFZCbNHzW2Irl
mOWcgkn06fjTpNRlSJFijKjG45Pvx9KpI1zFBALhQZY0HmMg2lm4yf8APSoftLyqN5QBgwXtg56Z
9K0JL0F9dyogKgjknOcr+H5fWlna4z54IMeOcnJ46Gs2CXYrJIwfaNwAyT7j0A71LY3cN2ZY4nSe
KI7GYbsbupAyPmxntTEXonZnbDlmbpxkY9KuraShCLiMjA2YI5zyT9ajsHIRHDGMqDjdyDyen60+
QF2UxyKQuTk/L0/rTAv2+3CxkDpyMYzV+Lb5e5ogob+Ju3FYyyIud0/yADkkKR6/Wln8Q6NaW4SS
98zJxsHzbfehtdQSb2N95R8xCl/7mOM9qrQXOoNNIZVhiiPEax8s4z1YnGPoBXJS+NNPRWFgkrzE
kAtwo9OKxp/E2rTypE0htyBwFGM0ubsVy23PRdQvFgsZJGILIudrMAWPpWHba6bjbAkTWxzlctVL
TdIvtTHmX12IscfvCST9K6l/DmjeQYEknMuV+fA6/Sh3BNG1pU1nGZUndGu4SuRjjnpkV3C6nBbw
LGhUZxwOOa8vgW8fUbez+0PPHH8zM/B2gYGf0rqopAzL5h2Z5I61LQG6bua4Mj7wABzTtkswEcd0
9t8wJdADkAgkc569Kp280ZLqVCq3B96FutpaGPkHIY9gPQVAzXtLhGuXBbmQ/Jx94Cr/ABnIPIqj
pnMvGMBOgrTYL6c1hLc2jsQEtn+VN5C+lSeWwJORg9KawYLxgH0qSyPkdBgUgLBuRx7VKrEqQVo2
nqOtMQ3d0op231xRQB8rNK284cgVIsoVABkGkUK+dw5HQ0piA+6a5jUVJjnheAakMkpIMb4FVihA
yGOM84qyjJ5XIz7UASo527mGce9TLIx5xjPvVUEbsKv/AOunjgEEE0XAsiUE7Tkkc/SnGdhwA1VA
235sYzTo3GeetK47FmGUysSVGRU7OVGAKqqwC5BxQZM8Zz9aVxlhZdoOMigyseVA+pquHOMY59aQ
Mc8mlcZbilw2Sae8y9S2KoNIB0Xn0qMGcy5ZUK54yckUJhY1FkDJhx14waVZDjaB9MVXRyVG1hn3
qWMEcsfyouOxOqqw6VIHihGXcAe9VXLOCvKioSIlIwgJ9fSi4i0Jk3M6uH9s5qeO6XygWH4dKoRG
QMTIwZM5HGKfMQ/QduoNFwsX47hGBwS3fOKmEm4bztIPvWIs4hUeYAR3x2qcXMKrkEEHtmmFjXDK
cEAexpfM5BAOe3NZUd2oGd2fQUjXfIJbJPp0p3A1xKQSA5+maf52VDFuR2rBbUUTIJPX1qGTVAw+
WQrincR0n2javJyKja5UgHdt9TXJ3GtFInYAuRyFB5b6VTGvF4hJllyM4cYP5Ucw7HaPeRjqwz6Z
qL+0FUfMVz7cVw767gk78n61Qm184OHx7ZpcwWPQ21VUAKvx3B7VXbXhjOQOcAn0rzeXX36bj7+9
UptZlI+ViafMKxc+K2ri68NW0KsWBulY+3yNXiDcOcdDXeeJ7pr3R2DOcxsG/p/WuAY56jvyKV7m
M9xGGeaYc04nHfimmggUGlzzxUZozQBIR3pckDGSKYG9aXPrQBMjE/LUoJbJOKrKR1NP3YIINAE+
cH5cr6c1Yh1C7tyRHcSJxxtaqayZwC3FO+VjntRcZvQeKNagUFLtmAP8QBz+dbCeOdQiCoiRyRg5
2svPv0rjEIBAGfQ/Shjx8pP0qlOSE0d/b+PSZEMumRNhs7UOP8a0Y/iBp8iLDJpkvy84WQHn0xiv
MI2/2iM9vWpWbZkcAdjiqVWSDlR6lF4+0ONQk2lzbG5BO08e1XB8QfDQiWO2tJ7eIMcIiqMA/Q+u
fzryRSHAyT64PFKrrkE9qr2rFyo9kXx74aSMCJbgttwRIgAyTzjmkX4heHYXQpDctjgjAwR+f1ry
N3WRhkIwA5ZRjcaliWFSxki5Ujg/XmrVaQuVHsE/j7QUnLSQ3KAgMF2jBGO/PPas5/iBo3zKllLg
8ZUgZrzWS4JRVCKdg2hduT9KW3lIkQywKFU4YYFV7Zi5Uehf8J/aGPamnjPPJcZPH06VMnj64+YW
OlqBntubGe1cV55IeQqiZB5VQAR6VctrmUyear7lfIJ6fyqlVYuU6Ofxvrzxh1QRInYJ/jTv+Eh1
y9yTdugx037a5wz7iwYHzOgLfoelaVg08oZXjG2PdvOcbfyquZsNjWEcs1r5018rSf3Q24nnmrsG
mz3FjEziCKY5+67YIHTII6kYrJgG4iONCnkqGyhBH6mtyGeJIY2TeAONxOR1zwfarVibssWnhySW
ZZ/PSNlXe6RksQvXn9K6SK0tfs8TyM8jINiiRRlSOefwOfpXOWupKsuyPLNnke3Gc/lV6K63D7UH
jC8FyxJwenP+FaryJZ0SXTJIYZYzEGIztwT7H8sGujsp/tNisiEsp3HJTGee2P8APFeepr1tFCIo
dksvB5TJPr+Fa+gy6ncpJE0X2eHdkFjjj8aGFjqba6CazPubLCMKpXjjvW5bXDyR4TIQN95ugHf6
dq42KS0tpnlE4vLgt/dO1fbNbC3V3cqjkBIwRhVHH1pWA6FLsyKY4M5ZuXPB/D0+taCxfJHEBgnj
aTWVaqyqqH5pPQdTWwrLFCYz/rDwWJyF9gahlG5pDIruVxt+6PfFazSBuMflXO6XOryR+Uu5FBOR
+VaxmIUYTBrCW5tHYtg4GAc00oCQ+48dh0qoszE/MpHtUyyjvkfWoLJSBnvTc4PBJpCzcc9aTk8D
IFAClh+VFGR6UUwPmYQBRgZ5prITgYwPeraI3Ibp0o28lTz+Fc7RoVRCrAgikaELGTjP0qwyMCSO
PrUDuMbQ5LE9qkCNTtA4xk08cHLNz6U9AdmCAKXC55xSGhEDZOfSlCY5/WkLfNnzM1G0ygkZ5NSN
EhwcnPTH40wMgJ3ZFReeinPWhrmPPQUXKsTBlwCrEHPNP4YjBNUzdDHAye1RNdO4IC7fqam6HYuF
lViM5PpUwlwODgYrM85z95goPpTN67iDKzLSuVY0/tEan73PtU6XBbGCQPesLzVz8rHiiS7YDaGP
4GldhobhuG3Ejk/Xio2mbpIgA64B61ix34DbS34mp/7RUL98Z9zTuKxoNdj5VC4U9Kc1yCuM/Uis
SfVEwAZV46gHms+XWI1VgqsR7HmncR0c94nC7gfUVVnuo45GKNkZ4zwD74rmTqc4+6gVf9o9KfJq
SmPmQFh7UnIEjokvycZfJ7ikl1DYpIZsmuOa+lYFoyAR61Uk1WdmCM2c9SKTkUlY6i41go4ycn2q
jJrSOCN5GOfSuea4JG4yMPWoWlLcZJx2o5hWNyTVmOfnU/jVOTUHkIG/9azDjGGjUe9Qndklf/1U
XCxfNy2SC/HsaRroKhy/071n5beMnA74qOT7x+cNTuSXmuQRkHI9Kha5VsgOAR2qmzAcZxxUTOME
su73poTE1Qh9PkjjkUEDJ9wOa49+pI/GummYFWBAw3Fc7Iu0lTwR0q0YzK+fxoxzxR3yB+FGAenW
qMxv14NLj8qeG7MMigoMfI3PoaAGDntTtuORwaQEocMuKXIOSDQA3ke9OALdsEDuaXGKKAHKrFSQ
M0uQoGQRTMsB14pQ7YweR70hkqEFc1IGAGe/qKrBsY5NBYZ4wKALG7HO4DJ6e1SmbMe3IIJ61VVk
J544PNNyCwweKYF1XGTl8gcHvUmFKgkjHTPpVEDPIPSl5wF3GgC+rjaBkY9R3FWFKyr+7LMQOmPz
4rOXeBgOR+FOQSjlX4NNCL/mruBTK+4NSrIdoAyfYnqazlSVQcZ568VZSOR12gN8vXjrTQGq1y8T
MUCjcCpQcjBqS2uW3BJDnPIycDP51lRwyMMthfTkCrK2kexWku4UB7b8la0RLLyXG4EM4AHZeaux
6k6krvCAjrjJ/SsqKOzjG43ocjBACkg1ea50eIiRIrh+OgwBnitESy+l+zARx/MM/MxGCfpWtpoV
7oyNLJM2cLFj5cE9cDvXPRazZxgCPS4nPXMhzU6eIdTiUC0At1YZ+Ve345rReojsoLG8n3XARoot
vJYhcHPUZ7VbSLTLK3UX2srK3Uxx5Yc844964E3Gp6hk3NzM46/MxxV/TLcPMA2TtPpngVfMhHYw
61YRTp/ZtgN54DSdOvpW8Ly8mKh5MK3UKcCuZsI42uNywZ5Cpgd66qCwu90Utwot4/4Xk4Bq0tQb
NC2CrAQjJvLYG7pXV6cDJZGIDy1QjdIw+X1rMtbfToYEO4XMgGATwoPqO5rSjnZrMfu9xcYU9h+H
aqEdGgXZvJ2R4GWPVvb2FS3M5hsZ53UtHBGX2oOTgdvemRQ+YVeZ8gqPk6CrDzxy+VEisq5wF/vH
/CoGiXwveXl8vnXelTWDGMFVkdWOD0+6eD9a6cj5vUelU9NtwplyeeOn0q6UZT1GK55u7N4bDCR6
VEHZM7iD6YGMCpXHG4Nt9absLg4wo9fWpLAT5PpTvNwODgVBNaK6ZfqOhFJHB5eRuLA9iaALCyHd
z6UVCTt5AGB6UUxHgDEZyeKgkkB+VTyPSmPKCvBOPemblxk56dqwZaEZZduGcke9JtVRnPzU1nP9
7FVpHP8Ae981LKLHm+pzzUTXGOc1WaUY4NVJZnx25qGxpFp7vGQGzn1qu12d3T8c1SeZQcE5Jqu1
zkkbc/jUMpGgbkbslufSomvlU8H8azTNu5yBUBJY43D86m5Rrm9IG7JP0pFvy2c8fjWK7iMfe/I1
C07HocE1Nxm81+BwMn3qD7fI6kKGX3FY5JzksOe2aQOy8g4/GlcZr/bZ9oBIz6kYqCS/YEYIJ9Kz
WuWHVi1V3lIO7PPai4F6a6kLZ3/N6DioBdvINrMSx9TWezMxyevYVGRuxjg+tO5Jq+eqblcnPoDS
I7MSxOPSs1W/vD8amMjKAAcUOTGkWyW5HX6VVkZxxyAaQsx5zz9ajd3Y5NTcYK7D5g2f0oZ8jJFR
biOO1NLdSufxoCxLkgn5c+3agMpYkgjNRgsRknH0pGwQDigCRnVsY/I0hYDv1FQ9D1I59aRpMEDu
PSmIk3KD8w4qGQqD6ZoaQYzjkVXbeSWYjB9qokJFdhkdOtVmJI5wf0qR5GHG849qgc/LgH86pEMY
T0Hf1zWNdj94w6EHNarAlT05rLvgQyv36GtEZSKWATjv/OkI9eD61Iu1j0yD+lNcEHDcj1qjMQ5A
+YZHqKMAjIOaBuX7vIoIUnONp9RQAu9lGM5HoaP3ZBBBB9qUK+NxUSD2pg2nnpQA7acfKwPpR8wP
zKaQA4yOaUMwoGNLDoKUdKeWH90GjCk5CY/GgBoG47QMmkxTsYI4I+tBzkcgigBp+lHenfgc075M
HIOe3FAhn8qXPOaX5QO9O2jHUUANyfWnLuz94jj1o2D1wakSE8sSBjn8KAAo+3duOB60KGx3zUxQ
465BGOBSrAxzhiMdjxmqAjCk9KtRALjNPW2YKD5qdcYJxirEUaY5mjXPXJz+WKpITJLe3UyIAxwa
vzWyx46EVFCkABP2joR0WrhudMUo32WZwOuWrRITK0cMaoQY9xx6c896u2tu7BkjWTBwCCucYP6V
Nb3J2iS1tEBUbWLEkgE9604Xvnkjje5aMMASEQL1Pc/jWiSJuyzDpV4yssipEMhcu2CAfatq10iz
tZlJuWlBGXMa42nuPcVQj8uJmWSVnfoJT8wz9a0La4NwRuYHOAQRnP8AhWqsJo3ba5itV8m0jWMq
wPmEZKn2qzdapNNta4kklfd1zxj1H5Vk28LybFZwoRsBujN7V0NnaWqyKcqirg4kPzL9BWibZOiN
OzS5ni3YCkDAxz/n/wCtXQWHkx6bi7m3uy4eQcY+grIgnt0k8uCQtjrjkjPt2qaa5drVII8jLrwO
SQCOppgdV9qWWTyo2yV425z+ZFatjE8t0rNn5eMn19KybGMptwFUv0GK6i1Tyh5jjARTgZqGx+hY
01NQS8nmlnQ2ToBFEF+YNk7iT+XFahLE1GgKRKuO1SbuOuPeuZvU6EtBmxzlSq7D75pAHUYAyPQ0
/cMHb0PpSqDtGKQxhck7SBSkjbwvSlAIYhhketJsOew46jvTC5CeuV6d+aKVsoTgcmiiwHzCbroM
8e1O+0BuFOD71QE427T274qMv3BJ+tcxoX2mOfvCqjzsQe1QsW6g4+tQtkdRn2qRoc8hPOTn64qv
I+4MMn86kxuO1lIx7UjpkYH41DKRSYkc569MVHtZuelWjGBkn9ajK8YXpUspFFztIXP5iopBnnfg
/WrUkZyRnNVih6Y4rNlIrhjk8k49abk9wTUzIuKZjHbipGMdmJ3ZJ9qaWIGS1OOScDGKZ1ODge9I
YmA3INMYEn0WpWBxTduTjtQFhgUc5FIEPYCpSyjPGSetRM4z2oCwMqgYIx6UhPGDz71BLdRiRUT5
mNPbLDr+HrQMXd0xg+tNO4knoMUm3bw3T1qQc9BxQBGq5BJHFMYKvOcf0qwc49aiCgH1+tMRHvUg
UwsSScdO1SuEZeE5+tIoXGGXmmIjLD+LAJ6VGRg8dPQ9asMBgADHtTCgAwo696YiIMo+nvTJmVhh
VA4pHA3/ACg880EMp+YAelUiSsy571EUAzuODVk/OTyOPT1qKQDaeM1RLRVb/IrPvBuQjHI5rSfp
WZNksSBVXM2jOBKtxz7U4/N0/KhlCvz0zSNkYZetWZBtZTlT+BpwZGO1xsPrQHDcN8p/SnFT6ZFA
DCpTlWyPUGoyc+lBXn5ePakzg4YZoAcoyepWnhW56MPakUKTgNj60pXHIOfpQANgDBBFAcEYJ4pQ
Xx14phGTzimA8HL/AEHQ0rbMdMfSo1yDxS5bqKAHccAGjJyMimA5PSnMwJG1ce2aBDvfPFKAcbhj
mmggA5B+lKHBz/hQMeg3sBuC5OMmpMYXnnBqM7RjDd+2aXcMk7s+2KYiyjM2OMAjoRUyjAJPOBki
qas3ZsAVKu443MfWgCVQr4PHvk1ZAUdRg4yKrqrFM5UfjU8Kxhivnge+KtCLscpUABEBYDIqQOqf
MI8nP8Q6fhUKLbleJWJ9atxPaEgYKle79DWiEaVpM8UeLcbWHK+7cc4/Cr9lFPd3T3qM9w0eA43f
KoPqO1VBdbUMSYTsSowB/nFOsIEtLl2tiY3lGXdmxuHuK0QmjoVgd8rJGFC4JDt/TvWnbfZotm9t
wA5UHZ+VYPmOzSIs7PnHKLj6itXTNPmLmVxk8EM/OK1T7Em5HqSPIqQx+WACMAY3e+TWhbvNd7gW
Aifj5OD+Jqna28ctyTkysB0z09z6Ct+C3hidVRwe4VR8vbv/AJ6Vpq9xF200+JJAy7tzKAwHQitx
lRPJUDaysGAUZDfU+lRWfl7RtGM+nNdFa2kLzRzvGWMQ49B70noBo2EQjhilmALda0STPLDChwGf
B98ck1kxXH2lnAUiNR8xNa+kIZZDOTgY2qprN7XKS1Nk5ZetIpwpyelOyV4Bzn1phG41ibixuFJV
W/CpVkB4zjvzVIAqxJJqQsdoO4nNAiyzITycmm5+bIwKqNIM8jGO9SK5wOCaYEkzELkdqKidzgDG
AfWigD5TAJH3R04pQrbcHrUiRu75I/CniIrjJwc9jXKzREaROwAIA9aRkEbAdWq0qnAAP61FKGBy
i5PqamxRA65OSSKhdBnIxVkxuwCuWJNJ5QX5SCfrSY0UXjYjkVEYyuCQRmtQ7Qu0Lg+pqjcBuSTz
UFlKXrkVTcleCBg+tXyNo55Jqu6nOTx9KhjRS25OSTxTX+nHvUkny9G4qPIC5HWoZSIXJziowSM+
tSMwx83eo+M8HNIYobcR3pHJxzx9KaTgYApM8YPSkMcA3OTVSS0aSQs8z7Cc7Rx+tWtrEcE4oCgY
/WgFoV1hWPGxQPepcZIyCaeRn/GlU44PPvQBEy9scU0Hb6kVPjIA5FGwEkE59qAsyDfuwF6HpTwF
PBzTthQ/LjHpTlZOehIoGIkMYA5Bx0pJIkbp19QcUpKEZz+uKQqSMZ49qokrsmw4bH40hYAYwKke
PPBaoiME7ulMTI2VcngVXkUg4Pf9Kssp5NQuMDJFUiWVm64xxUTc9Dge9WWAPQDP0qu/DEEcetUi
GVZmUA9jWfIDz3rRlAPfNVXAA4FBLRmSpjBIqMArkYyD2q5KuRVcABtp6HoatMyaItgPTkU0M8R+
U5HoalaMg5zg0xm7OMH1FUSBaN+T8jVGQe1Iwxznim5x0yKYDu1KAR91iKbv7YzT1KngnFAiRWkB
HAagup4ZCKXaeowaBkHBFAxnyHoaNpzkGlOD2FJt5+nvQIMMOhpSWbggUYxjBzR83XPFAAegGOaU
dMYNBJ9KUHjkYoGO545bFKB83U00sMYXOaeHJICjn3oAdwc8kD3qdF3RhQTmoN5PRMkVLHI+/wC4
AMcUxEsezbtYsT7VOirvyVyvtxmkTewxlQfpVmJV2FZNxYkcr6d6pALFh5eE2t7VqxRZG05weefr
/jVKNFEiuNxGehPJq5ujVxlTkc4HatEIsgcsAd+eSFrStrb5iWgKspwd5xVW3Ach0c884UdauyKZ
lAj+Vh/Ea1VibGxa7VTdmNWHAHJ/WujsHjAVnQTkAgBunPtXJWlleSYBLMAOoFbsMRjwvnknptX+
tbRZLOghjeZvKQCJMjcFXFbNvCIpkHUdAOua5e3u5bZwNzHj7q9fpmti3uri5kjCoIhksMElsdsm
r9Reh1ltLiRYMEP1AA7etatr9tupWheRltxyyjgMaytLt/LYvs5rprVXuJIxGfkbHIGCf8KlsZYL
GKJreFfnbAz6e1dRZK0FsiBcYHfuayYLdFud2zcsfAHqa0w7dE4GehrKTvoaxXUvZGMGk2Fcle9Q
CVjxjd25qdWxjKlazLGY3Y3DpRtG7jj1p/BbnPPfFIRmgCF42HJ6HtUO87go+X61aVxnae1RylTz
gUwELkpzRVWSXYuDwKKdgPm4cDinAAhsj+KiiuXoaIaeo+lPQAynIzxRRQgY+XhAR61C4G40UVDK
REwG5eKo3AG0cUUVBRTcDniqcn3R9KKKzkUio/3lphABOBRRUPYspy/epCAM4FFFSwFT/WY7ZpzA
ZY45zRRTGhw6UJ98UUUhjT/rGp6AGNsjtRRSERHrTh3oopghX/1Y+lVJOIzj0oooH0CHlRn0qyKK
KpkisBheO1Vz940UUEsgJPP0pjgZ/CiiqQiEgbenaqs3UfWiirJZUb/WGopQOOO1FFIllWbofpVK
XpRRVozkBJMKkmoTyeeaKKtGbGD0pp6GiimxDf4aeOV5oooBAhIY4NW4uRzzRRQMCBk8VG33qKKQ
CClPeiimAGj+9RRTEOX7ppT92iikNksfUfjUg6n6UUUCJ8kBcGra/wBKKKtDLCE/Lz6VcABEhI9a
KKpCNOzA2rW5aqpflQfl9PeiitkJl9mb+0Ujydmfu9vyrWufkFuE+XI5xxmiit4fCYv4iWHo574r
f0IAuSQM4FFFBZ18fDxqOnPH5V1mm/6lT3x1/CiilIImta/cU96tL97HsaKKwN0Pi5c5qZSd5570
UUAPP+r/ABoXp+NFFMQjAZHHeq8v3DRRSKRl5JJyaKKKsR//2Q=
Subject: | Re: Another newbie question: |
Circuit height usually 1000ft for light a/c etc and 800 or 600 for
microlights.Not sure if there is a `best` way, probably what you are
used to but at that stage of the flight the height above ground is
paramount and if you land with zero alt. on the clock it seems simpler
to me
Cheers Pat
>>>>>>>>>>>>>>>>>>>>>.landing may be easier,,, but if you encounter
another aircraft in route are looking for him in the air in an effort
of not trading paint... altitude above sea level should be more
consistent way of knowing where to look.boyd
Subject: | Re: Critique my Fuel System |
Is irony an unknown concept in your part of the world?
Rick
On Thu, Jul 15, 2010 at 8:48 PM, wrote:
> Rick,
> Did the math.Can that 582 really burn 10.8GPH?
> -----Original Message-----
> From: Richard Girard <aslsa.rng(at)gmail.com>
> To: kolb-list(at)matronics.com
> Sent: Thu, Jul 15, 2010 4:31 pm
> Subject: Kolb-List: Critique my Fuel System
> Per the Facet Installation Instructions (P/N 42664 01-04):
> *Required Item:* In-line fuel filters need to be mounted on the pump's *
> inlet* port.
> Think about it, especially when using a rebuildable filter like the
> Clearview, if you mount the filter on the inlet side and it leaks you get a
> few air bubbles in the line. Mount it on the pressure side and you get a
> stream of gasoline spraying about your airplane.
> Using a second Facet for a transfer pump. I have one on my removable long
> range tank. It flows 6.8 gallons in 38 minutes, barely faster than my 582
> consumes fuel. For my regular system I use a single Facet (low pressure unit
> P/N 40105) and a modified 3 way Weatherhead selector valve between tanks
> that gives me Off, Right, Left and Both to control which tank I draw from.
> Of course it's experimental aviation and you can do as you like.
> Rick Girard
> ator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
> ttp://forums.matronics.com
> ibution">http://www.matronics.com/contribution
From: | "Jack B. Hart" <jbhart(at)onlyinternet.net> |
Subject: | Re: Mark III C landing gear replacement |
One other thing my may want to consider after following Richard's advice.
That is to load the plane with the average amount of fuel you will be
carrying and pilot and passenger load too. Then roll the plane backwards
and forwards on a hard level surface to seat the gear. Then check to see if
you have the desired camber and toe-in, If not, you may need to do a little
bending.
Jack B. Hart FF004
Winchester, IN
>It is easier than you can imagine. Go to Lowes, and buy a long bronze
grounding rod, it is the same diameter as your axles. Jack up the fuselage
so that the landing gear is off the ground, do it by placing something under
the fuselage, not under the gear. Remove the old gear, insert the new
landing gear legs with the lower gear leg fittings already attached to the
new legs, minus the axles and wheels, etc. Force the bronze rod through the
axle tubes. It will take quite a bit of bending into a curve, and will
require lubricant and a rubber hammer, but it will go. The axles will now be
perfectly aligned. Mark the holes on the legs. Take the legs to a friends
house who has a drill press. Drill the holes, put it all back together.
That's how I did it back in '95, and it still tracks as straight as a
string.
June 27, 2010 - July 16, 2010
Kolb-Archive.digest.vol-jx
