Kolb-Archive.digest.vol-kw
November 19, 2010 - December 07, 2010
              Livermore CA 94550
      Thank you!
Subject: Re: Fuel pressure question
Date: Nov 19, 2010
Good question. No clue. I'll try and get a treasure gauge and check the accuracy of the eis reading. Sounds like if it keeps running, and not flooding, it's probably ok. Any other thoughts? Anyone know a good source of a not too expensive gauge? Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320102#320102 ________________________________________________________________________________
Date: Nov 19, 2010
Oops! I meant "pressure gauge," not "treasure." Damn spellcheck... I already know my Kolb is a treasure! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320103#320103 ________________________________________________________________________________
Subject: Hoerner wing tip design?
Date: Nov 19, 2010
Hello Folks, Haven't posted much in the past few years but keep a eye on the list and read almost daily. I have a MK 3 Classic that I bought from Jeremy Casey about 6 years ago and worked on for awhile then sort of lost interest. This summer I have discovered 4 or 5 neighbors within 10 miles or so that are flying that wasn't a few years ago. I have probably put more hours on my FS II flying with them this summer than I have put on it the past 3 years combined. This and the fact that I ran into James Tripp at Ronnie Smith's fly-in has rekindled my desire to finish the Mark 3. James has a beautiful MK-3 that he has just finished. He had been flying a Firestar like myself. He has also installed the "Hauck Special" landing gear as I have done to the MK 3 I have in progress. Now to my question to the group. I have been doing some reading on Hoerner wing tips and would like to hear some comments or thoughts about installing these on the MK 3 Classic. I know that TNK makes some for the Xtra out of fiberglass but was thinking of building my own out of aluminum tubing as some other Kolb copy cat kit builder has done. Would this be worth the effort on the Kolb wing? Would the span need to be reduced any due to the effect the Hoerner tips have of lengthening the effective span? Here is some information on the web from another well known STOL aircraft sight about these tips: "For a long time, Ive said that Hoerner wing tips should be used on most light aircraft designs, since they increase the effective wing span from 8" to over one foot without having to carry any additional weight: As we all know, there is low pressure on top of the wing, and higher pressure on the bottom of the wing, with the pressure difference creating the lift that allows us to fly. Toward the tip of the wing, the high pressure feels that there is less pressure on the top of the wing (just around the tip), and wants to go there to equalize the pressure, thus creating a secondary flow out toward the tip of the wing. This secondary outward flow generates a vortex (a circular motion) behind the wing." Any and all information or thoughts are appreciated. Thanks, John Cooley -------- Be Safe, John Cooley Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320108#320108 ________________________________________________________________________________
Subject: Re: Kolb Firestar Winter storage
Date: Nov 19, 2010
by0ung, Our Midwest Winters are very bitter, I prefer not to fly open Cockpit in them. I admire the pilots that do. Dennis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320119#320119 Attachments: http://forums.matronics.com//files/bitter_cold_winters_115.jpg ________________________________________________________________________________
Date: Nov 19, 2010
Thanks, Boyd. I'll check. The position of the sensor could also affect the reading. It's about three feet below the engine. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320137#320137 ________________________________________________________________________________
Date: Nov 20, 2010
Subject: Re: Hoerner wing tip design?
John, People say a lot of things, with and without a clue as to what they are talking about. Hoerner tips on most light planes? It would depend on th e mission the plane is flying. Hoerner tips, properly implemented, work in th e low speed regime where they help with induced drag at high lift coefficients. Great for crop dusters, STOL, and like missions, not so great if you spend your time in cruise flight. Good on a Kolb? Maybe, if you have a comprehensive plan to clean up drag sources of all kinds. Personally, I think you could do as much or more by cleaning up and sealing the wing root s to get rid of that unwanted extra set of wing tips. That hurts performance in all regimes so it's probably more bang for the buck, but you won't know until you do the work and document it. Rick Girard On Fri, Nov 19, 2010 at 11:31 AM, John Cooley wrote: > > Hello Folks, > > Haven't posted much in the past few years but keep a eye on the list and > read almost daily. I have a MK 3 Classic that I bought from Jeremy Casey > about 6 years ago and worked on for awhile then sort of lost interest. Th is > summer I have discovered 4 or 5 neighbors within 10 miles or so that are > flying that wasn't a few years ago. I have probably put more hours on my FS > II flying with them this summer than I have put on it the past 3 years > combined. This and the fact that I ran into James Tripp at Ronnie Smith's > fly-in has rekindled my desire to finish the Mark 3. James has a beautifu l > MK-3 that he has just finished. He had been flying a Firestar like myself . > He has also installed the "Hauck Special" landing gear as I have done to the > MK 3 I have in progress. > Now to my question to the group. I have been doing some reading on Hoerne r > wing tips and would like to hear some comments or thoughts about installi ng > these on the MK 3 Classic. I know that TNK makes some for the Xtra out of > fiberglass but was thinking of building my own out of aluminum tubing as > some other Kolb copy cat kit builder has done. Would this be worth the > effort on the Kolb wing? Would the span need to be reduced any due to the > effect the Hoerner tips have of lengthening the effective span? Here is s ome > information on the web from another well known STOL aircraft sight about > these tips: > > "For a long time, I=92ve said that Hoerner wing tips should be used on mo st > light aircraft designs, since they increase the effective wing span from 8" > to over one foot without having to carry any additional weight: As we all > know, there is low pressure on top of the wing, and higher pressure on th e > bottom of the wing, with the pressure difference creating the lift that > allows us to fly. Toward the tip of the wing, the high pressure =91feels =92 that > there is less pressure on the top of the wing (just around the tip), and > wants to go there to equalize the pressure, thus creating a secondary flo w > out toward the tip of the wing. This secondary outward flow generates a > vortex (a circular motion) behind the wing." > > Any and all information or thoughts are appreciated. > > > Thanks, > John Cooley > > -------- > Be Safe, > John Cooley > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320108#320108 > > =========== =========== =========== =========== > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unabl e to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 20, 2010
Boyd, Ship it down to Rick Neilsen in Fla.He'll keep it warm for you. G.Aman guess if i were not a scardi cat... and most of all if i were retired and had the time... I would fly it down and keep it warm with rick... should have done it last year when my son was in the keys. boyd ________________________________________________________________________________
Date: Nov 20, 2010
Boyd Hey just a bunch of short hops strung together. It is certainly nice to be retired so time isn't an issue. It's been in the low 80s and sunny in Florida. Come on down. I will miss not having my Kolb down here this winter but not that $300/ month hanger charge. I think it will be cheaper to rent this winter. Tuesday I'm scheduled to get checked out in a Sport Cruiser (this is the new Piper LSA). It will not be anything like a Kolb but it is flying and a bit faster. Gary when you get down here we will need to schedule a flyin. If we can get Buford to leave his home airport again we may be able to talk George A in to joining us???? Rick Neilsen Redrive VW Powered MKIIIC On Sat, Nov 20, 2010 at 12:02 PM, b young wrote: > B > oyd, > Ship it down to Rick Neilsen in Fla.He'll keep it warm for you. > G.Aman > > guess if i were not a scardi cat... and most of all if i were retired > and had the time... I would fly it down and keep it warm with rick... > should have done it last year when my son was in the keys. > > boyd > > * > > ________________________________________________________________________________
Date: Nov 20, 2010
Rick, You'll like the Piper. Very light handling. I wonder how they set the prop. The Sport Cruiser dealer in Wichita had both his aircraft set so that the 912 could only turn 5200 RPM on take off, but the EFIS showed a nice 138 kt cruise. Not exactly LSA legal, but it sure was fun. Rick Girard On Sat, Nov 20, 2010 at 4:48 PM, Richard Neilsen wrote: > Boyd > > Hey just a bunch of short hops strung together. It is certainly nice to be > retired so time isn't an issue. It's been in the low 80s and sunny in > Florida. Come on down. > > I will miss not having my Kolb down here this winter but not that $300/ > month hanger charge. I think it will be cheaper to rent this winter. Tuesday > I'm scheduled to get checked out in a Sport Cruiser (this is the new Piper > LSA). It will not be anything like a Kolb but it is flying and a bit faster. > > Gary when you get down here we will need to schedule a flyin. If we can get > Buford to leave his home airport again we may be able to talk George A in to > joining us???? > Rick Neilsen > Redrive VW Powered MKIIIC > On Sat, Nov 20, 2010 at 12:02 PM, b young wrote: > >> B >> oyd, >> Ship it down to Rick Neilsen in Fla.He'll keep it warm for you. >> G.Aman >> >> guess if i were not a scardi cat... and most of all if i were retired >> and had the time... I would fly it down and keep it warm with rick... >> should have done it last year when my son was in the keys. >> >> boyd >> >> * >> >> "_blank">www.aeroelectric.com >> .com/" target="_blank">www.buildersbooks.com >> ="_blank">www.homebuilthelp.com >> _blank">http://www.matronics.com/contribution >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> ttp://forums.matronics.com* >> >> > * > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 20, 2010
Boyd, Just rubb'in it in a little.Packing up the Mk3 and heading south in about 1 0 days.Tell Becky, Marj says hi. G.A. -----Original Message----- From: b young <by0ung(at)brigham.net> Sent: Sat, Nov 20, 2010 12:04 pm Subject: Re: Kolb-List: Kolb Firestar Winter storage Boyd, Ship it down to Rick Neilsen in Fla.He'll keep it warm for you. G.Aman guess if i were not a scardi cat... and most of all if i were retired an d had the time... I would fly it down and keep it warm with rick... sh ould have done it last year when my son was in the keys. boyd ________________________________________________________________________________
Date: Nov 20, 2010
Rick, Sounds good to me.See you in a couple weeks G.A. -----Original Message----- From: Richard Neilsen <neilsenrm(at)gmail.com> Sent: Sat, Nov 20, 2010 5:56 pm Subject: Re: Kolb-List: Kolb Firestar Winter storage Boyd Hey just a bunch of short hops strung together. It is certainly nice to be retired so time isn't an issue. It's been in the low 80s and sunny in Flori da. Come on down. I will miss not having my Kolb down here this winter but not that $300/ mon th hanger charge. I think it will be cheaper to rent this winter. Tuesday I 'm scheduled to get checked out in a Sport Cruiser (this is the new Piper L SA). It will not be anything like a Kolb but it is flying and a bit faster. Gary when you get down here we will need to schedule a flyin. If we can get Buford to leave his home airport again we may be able to talk George A in to joining us???? Rick Neilsen Redrive VW Powered MKIIIC On Sat, Nov 20, 2010 at 12:02 PM, b young wrote: B oyd, Ship it down to Rick Neilsen in Fla.He'll keep it warm for you. G.Aman guess if i were not a scardi cat... and most of all if i were retired an d had the time... I would fly it down and keep it warm with rick... sh ould have done it last year when my son was in the keys. boyd "_blank">www.aeroelectric.com .com/" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?Kolb-List ttp://forums.matronics.com ________________________________________________________________________________
Subject: Latex paint
Date: Nov 20, 2010
Forget it. Did the weight and balance today and what a disappointment it turned out to be. Latex is not lighter than the other systems, and it is a lot harder to work with. Ended up using 4 different spray guns, and was not happy with any of them. The airplane will probably look good after the details get touched up, but what a pain this has been compared with using Stits, Randolph, or Certified Coatings. Never again. Hope I have not led anyone else astray, if so, please accept my apologies, this has been a real soup sandwich. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320214#320214 ________________________________________________________________________________
Date: Nov 21, 2010
Subject: Re: Latex paint
Richard I'm just now finishing painting the fuselage on my Pietenpol with Behr gloss exterior latex. I too tried several spray guns, having some success with a Harbor Freight touch up gun for small areas, and a Lowes Kobalt Latex spray gun for large areas. I do not have an HVLP system, but I think one might work. I thinned just a touch more than the instructions on the paint can which said 1/2 pint per gallon. I brushed on 3 thinned coats of Glidden gray primer, and sprayed 3 or 4 coats of color. I came out better than I was expecting, but not a professional job for sure. I will post some pictures in a few days. For me, it didn't seem too difficult to work with. The cost, and above all no stinky fumes have me sold on the process. Also I'm painting in my basement. Malcolm Morrison Kolb MKII (for sale) Pietenpol Air Camper ASW-15 http://home.comcast.net/~mmorrison123 ----- Original Message ----- From: "Richard Pike" <richard(at)bcchapel.org> Sent: Saturday, November 20, 2010 7:48:03 PM Subject: Kolb-List: Latex paint Forget it. Did the weight and balance today and what a disappointment it turned out to be. Latex is not lighter than the other systems, and it is a lot harder to work with. Ended up using 4 different spray guns, and was not happy with any of them. The airplane will probably look good after the details get touched up, but what a pain this has been compared with using Stits, Randolph, or Certified Coatings. Never again. Hope I have not led anyone else astray, if so, please accept my apologies, this has been a real soup sandwich. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320214#320214 ________________________________________________________________________________
Date: Nov 20, 2010
Richard, I'm just about to start on the tail feathers of Zulu Delta so I'm interested. Can you give some more detail on how you did the painting? Sealers and primers? What you'd do different? TIA. Rick Girard On Sat, Nov 20, 2010 at 6:48 PM, Richard Pike wrote: > > Forget it. > > Did the weight and balance today and what a disappointment it turned out to > be. Latex is not lighter than the other systems, and it is a lot harder to > work with. Ended up using 4 different spray guns, and was not happy with any > of them. The airplane will probably look good after the details get touched > up, but what a pain this has been compared with using Stits, Randolph, or > Certified Coatings. > > Never again. Hope I have not led anyone else astray, if so, please accept > my apologies, this has been a real soup sandwich. > > Richard Pike > MKIII N420P (420ldPoops) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320214#320214 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 20, 2010
John C, I like the way my plane flies with its Hoerner type wing tip modifications. It is very good at slow flight and very stable and controllable even in a deep stall mush. But would I do it all again, or recommend it for others? Probably not. The plans built Kolb is already very good at all that, and any improvement is merely a tweek of what is already every stock Kolb plane's strong point. On Nov 19, 2010, at 12:31 PM, John Cooley wrote: > > Hello Folks, > > Haven't posted much in the past few years but keep a eye on the list and read almost daily. I have a MK 3 Classic that I bought from Jeremy Casey about 6 years ago and worked on for awhile then sort of lost interest. This summer I have discovered 4 or 5 neighbors within 10 miles or so that are flying that wasn't a few years ago. I have probably put more hours on my FS II flying with them this summer than I have put on it the past 3 years combined. This and the fact that I ran into James Tripp at Ronnie Smith's fly-in has rekindled my desire to finish the Mark 3. James has a beautiful MK-3 that he has just finished. He had been flying a Firestar like myself. He has also installed the "Hauck Special" landing gear as I have done to the MK 3 I have in progress. > Now to my question to the group. I have been doing some reading on Hoerner wing tips and would like to hear some comments or thoughts about installing these on the MK 3 Classic. I know that TNK makes some for the Xtra out of fiberglass but was thinking of building my own out of aluminum tubing as some other Kolb copy cat kit builder has done. Would this be worth the effort on the Kolb wing? Would the span need to be reduced any due to the effect the Hoerner tips have of lengthening the effective span? Here is some information on the web from another well known STOL aircraft sight about these tips: > > "For a long time, I=99ve said that Hoerner wing tips should be used on most light aircraft designs, since they increase the effective wing span from 8" to over one foot without having to carry any additional weight: As we all know, there is low pressure on top of the wing, and higher pressure on the bottom of the wing, with the pressure difference creating the lift that allows us to fly. Toward the tip of the wing, the high pressure =98feels=99 that there is less pressure on the top of the wing (just around the tip), and wants to go there to equalize the pressure, thus creating a secondary flow out toward the tip of the wing. This secondary outward flow generates a vortex (a circular motion) behind the wing." > > Any and all information or thoughts are appreciated. > > > Thanks, > John Cooley ________________________________________________________________________________
Date: Nov 20, 2010
by0ung Have to admit...this does look like fun Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320230#320230 Attachments: http://forums.matronics.com//files/kolb_on_skis_190.jpg ________________________________________________________________________________
Date: Nov 20, 2010
Ohooooo....... Gasp... Is that frozen water????? Some time in my past I remember bone chilling Michigan winters. I have a pair of frozen water skies that I built for my MKIIIC. I used water skies that I glued and screwed a chunk of 2X4 to with blocking for support. The hinge is a standard door hinge with the hinge pin replaced with a bolt for easy (sort of) removal. The skies were attached just inside the wheels just above the ground so that the plane would roll on a hard surface yet slide in deep snow. The pictured restraining cables keep the skies restrained to a limited movement yet allow rotation and movement over snow banks. The bungee shown was doubled and kept the ski tips up in flight. The aluminum tangs shown fit in front and back of the lower wing strut fittings on the fuselage. Rick Neilsen 1st Redrive VW Powered MKIIIC On Sat, Nov 20, 2010 at 10:57 PM, Dennis Thate wrote: > > by0ung > > > Have to admit...this does look like fun > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320230#320230 > > > Attachments: > > http://forums.matronics.com//files/kolb_on_skis_190.jpg > > ________________________________________________________________________________
Date: Nov 21, 2010
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2010
I am also on the Challenger list. There has been a lot of discussion on that group about latex. Several guys have used it. Maybe a latex paint list should be started. Jerry ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Saturday, November 20, 2010 8:37 PM Subject: Re: Kolb-List: Latex paint Richard, I'm just about to start on the tail feathers of Zulu Delta so I'm interested. Can you give some more detail on how you did the painting? Sealers and primers? What you'd do different? TIA. Rick Girard On Sat, Nov 20, 2010 at 6:48 PM, Richard Pike wrote: Forget it. Did the weight and balance today and what a disappointment it turned out to be. Latex is not lighter than the other systems, and it is a lot harder to work with. Ended up using 4 different spray guns, and was not happy with any of them. The airplane will probably look good after the details get touched up, but what a pain this has been compared with using Stits, Randolph, or Certified Coatings. Never again. Hope I have not led anyone else astray, if so, please accept my apologies, this has been a real soup sandwich. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320214#320214 ========== ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. ========== arget="_blank">http://www.matronics.com/Navigator?Kolb-List ========== http://forums.matronics.com ========== -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 21, 2010
it is Dennis that's my old Firestar & the skis I built for it winter flyin g is the best Ellery Batchelder Jr. -----Original Message----- From: Dennis Thate <retroman(at)frontier.com> Sent: Sat, Nov 20, 2010 10:57 pm Subject: Kolb-List: Re: Kolb Firestar Winter storage by0ung Have to admit...this does look like fun ead this topic online here: http://forums.matronics.com/viewtopic.php?p=320230#320230 ttachments: http://forums.matronics.com//files/kolb_on_skis_190.jpg -======================== ======================== =========== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== ________________________________________________________________________________
Date: Nov 21, 2010
A couple months back I was touting Latex as being a good alternative because I used it years ago on a couple Hummers, and it went on easy, looked good, and was light. Used Sears Weatherbeater and thinned it with water. This time around used blue from Sherwin Williams, and the yellow from Lowes because those were the brands who best matched the color. Used black for the underbase and fabric sealer, that worked ok, the rest was hard to spray, none of the various guns I tried wanted to cooperate. If I had it to do over, I could have used Certified Coatings brand for about the same cost, (or Stits for twice as much) and shooting it would have been a lot less complicated and frustrating. Maybe if you have the right gun it would be different, but that didn't happen for me. And the weight turned out about the same, which was the main reason for doing it - was expecting it to be lighter. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320330#320330 ________________________________________________________________________________
Date: Nov 21, 2010
Sorry you had problems. The unfortunate fact is the formulations of the various house paints are not well revealed which makes divining their properties difficult unless you buy one of each and test them. The top rated exteriors now incorporate some urethane in the blend. From what I've read, California, Pratt and Lambert, Behr and Sears Weatherbeater Ultra are among the better brands. It would be tempting to try a clear water based urethane and add a tint to create your own flex coating. BB On 21, Nov 2010, at 9:18 AM, Richard Pike wrote: > > A couple months back I was touting Latex as being a good alternative because I used it years ago on a couple Hummers, and it went on easy, looked good, and was light. Used Sears Weatherbeater and thinned it with water. > > This time around used blue from Sherwin Williams, and the yellow from Lowes because those were the brands who best matched the color. Used black for the underbase and fabric sealer, that worked ok, the rest was hard to spray, none of the various guns I tried wanted to cooperate. > > If I had it to do over, I could have used Certified Coatings brand for about the same cost, (or Stits for twice as much) and shooting it would have been a lot less complicated and frustrating. > > Maybe if you have the right gun it would be different, but that didn't happen for me. And the weight turned out about the same, which was the main reason for doing it - was expecting it to be lighter. > > Richard Pike > MKIII N420P (420ldPoops) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320330#320330 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 21, 2010
by0ung Have to admit...this does look like fun >>>>>>>>>>>>>>>>>>>>>>> have to admit,,, i have never tired skis..... thought about it a bunch. boyd young mkIII utah ________________________________________________________________________________
Date: Nov 21, 2010
Richard, Did you thin your latex paint with water and methyl or ethanol alcohol? Since I was attaching fabric to foam fairings, I applied non cut latex with a brush to hold the fabric to the foam. It worked like a charm. The only problem I had was that, due to the high surface tension very small bubbles floated up to the surface, and they did not break out of the surface. In Googling about how RC modelers use latex, I found that they thin latex with windshield wiper fluid. The alcohol breaks down or lowers the surface tension and increases the wet ability of the mixture, and the water thins out the mixture. I believe you could expect better spray gun performance with the addition of the alcohol. One can check this out by dipping a straw into the latex paint and observing the drop size as on slowly rotates the straw to form a drop on the end of the straw. Next take a sample and cut it with water and alcohol and perform the same test. The drop size should become smaller indicating surface tension reduction. FWIW Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: non Kolb but
Date: Nov 21, 2010
I too would like a copy. Thanks in advance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320351#320351 ________________________________________________________________________________
Date: Nov 22, 2010
Date: Nov 21, 2010
http://www.cdsg.org/forums/viewtopic.php?t=381 OR MAYBE THIS Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ----- Original Message ---- From: Dennis Thate <retroman(at)frontier.com> Sent: Sun, November 21, 2010 12:40:56 PM Subject: Kolb-List: Re: non Kolb but I too would like a copy. Thanks in advance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320351#320351 ________________________________________________________________________________
Date: Nov 21, 2010
jbhart(at)onlyinternet.ne wrote: > Richard, > > Did you thin your latex paint with water and methyl or ethanol alcohol? > > > > Jack B. Hart FF004 > Winchester, IN Used a flow agent I bought from the Sherwin-Williams store, it is supposed to thin the latex, make it flow out smoothly, but not slow down the tack/drying process. After I got home and read the can, it is about the same stuff as windshield washer fluid. Costs a lot more... And it helped, but the results are still - well - I will be spending the day in the garage tomorrow dealing with the blemishes. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320396#320396 ________________________________________________________________________________
Date: Nov 21, 2010
Thanks for the post....that's great aviation history. I was there there in the 1980's...what a dramatic change from how I remembered It. When will they make public the the Roswell crash UFO ! [Wink] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320398#320398 ________________________________________________________________________________
Date: Nov 22, 2010
Subject: Contributions Down By 17%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 17%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash or worse, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Wite, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2010
have to admit,,, i have never tired skis.>> Hi, I have a friend, a CFI of a local ultralight school who told me that in his youth he tied the bumpers (fender?) of a car to the undercariage. This was in a particularly hard winter and he wanted to visit his girl friend on the other side of the valley. Of course this was in olden times when they were a separate item which could be easily unbolted from the car, not moulded into the body as they are now. Cheers Pat ________________________________________________________________________________
Subject: A bit of humor ...I hope !
Date: Nov 22, 2010
I have a feeling this was built by someone who would prefer to live in south Florida if they could afford to do so. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320534#320534 Attachments: http://forums.matronics.com//files/minnesota_fish_house_730.jpg ________________________________________________________________________________
Date: Nov 22, 2010
Subject: T.R.'s engine spacer blocks
Thom, Almost finished with the engine spacers. All that's left is to radius the corners, deburr and alodine. All are .25" base, although I had to spot face the front 2 holes on the forward blocks when the angle over ran the boss, but an extra washer should keep you from having to replace bolts, same with the AN6's through them, too. Aft blocks are counterbored so their should be no problem with the bolts through them. I made sure of the 9.5" dimension by cleco'ing a pair to the engine mount of my Firestar so I could scribe a line to pick up when I drilled the forward blocks. Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 22, 2010
Subject: emergency landing
Looks like a Kolb? http://www.fox43.com/news/wpmt-aircraft-crash-east-earl-township,0,5538875.story -Dana -- The problem with telling a Lawyer joke is that lawyers don't think it's funny and the rest of the people don't think it's a joke. ________________________________________________________________________________
Date: Nov 22, 2010
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: emergency landing
- It certainly looks like an FS2.- Doesn't look familiar.- Anything f rom the FAA on it? - ------------------------- --------------------- Bill Sulliv an --- On Mon, 11/22/10, Dana Hague wrote: From: Dana Hague <d-m-hague(at)comcast.net> Subject: Kolb-List: emergency landing Date: Monday, November 22, 2010, 10:00 PM Looks like a Kolb? http://www.fox43.com/news/wpmt-aircraft-crash-east-earl-township,0,5538875. story -Dana -- The problem with telling a Lawyer joke is that lawyers don't think it's fun ny and the rest of the people don't think it's a joke. le, List Admin. ________________________________________________________________________________
Date: Nov 22, 2010
it is a Kolb Glad to hear there was no injuries, Who is the guilty one ? come on fess up,what was the problem ? Ellery Batchelder Jr. -----Original Message----- From: Dana Hague <d-m-hague(at)comcast.net> Sent: Mon, Nov 22, 2010 10:00 pm Subject: Kolb-List: emergency landing Looks like a Kolb? http://www.fox43.com/news/wpmt-aircraft-crash-east-earl-township,0,5538875 .story -Dana -- The problem with telling a Lawyer joke is that lawyers don't think it's funny and the rest of the people don't think it's a joke. ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Nov 23, 2010
Love that guy who said "I thought the pilot was going to die, basically" How else? Pat ________________________________________________________________________________
Date: Nov 23, 2010
Subject: Re: T.R.'s engine spacer blocks
Thanks a bunch, Rick. Sounds like you did exactly what was needed. Email me off-list and let me know how much I owe you and where to send the check. Thom in Buffalo ________________________________________________________________________________
Date: Nov 23, 2010
http://piloteditor.dotphoto.com/CPViewAlbum.asp?AID=5970587&IID=225349545&Page=1 Here is a friend of mine....who's inexperience in strong winds caused this media frenzy. No injuries fortunately..... Extremely damaged ego , I'm sure. -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320658#320658 ________________________________________________________________________________
Subject: Mark III wings on a Mark II
Date: Nov 23, 2010
I have a Mark II that I wish to install a set of Mark III wings on. The spar tab to drag strut fitting measurements are the same, but the spar tab on the M3 wing is welded on lower which would increase the angle of incidence. My question is, does anyone happen to know the M3's wing angle of incidence sitting on level ground ( specify stock or tall gear ) or the angle between the fuse tube(or horizontal stab) and wing bottom. thanks, Rob Cannon ________________________________________________________________________________
Subject: Re: Mark III wings on a Mark II
Date: Nov 23, 2010
Mike Welch is the numbers repository in that category. Mike, put down that beer. BB On 23, Nov 2010, at 5:19 PM, rob and jennifer wrote: > I have a Mark II that I wish to install a set of Mark III wings on. The spar tab to drag strut fitting measurements are the same, but the spar tab on the M3 wing is welded on lower which would increase the angle of incidence. My question is, does anyone happen to know the M3's wing angle of incidence sitting on level ground ( specify stock or tall gear ) or the angle between the fuse tube(or horizontal stab) and wing bottom. > thanks, Rob Cannon > > ________________________________________________________________________________
Date: Nov 23, 2010
Bob=2C That's the funniest thing I've seen all day!! I was just getting ready t o shoot him off an email=2C and had to finish reading all my unread mail=2C w ith yours being my last one. My beer=2C as a matter of fact=2C was the root variety. A&W diet root beer . : ) BTW=2C I've been working on my overhead panel/front panel/console. I had to take a detour to build some electronic circuits (that install into the p anels). Best regards=2C Mike From: slyck(at)frontiernet.net Subject: Re: Kolb-List: Mark III wings on a Mark II Date: Tue=2C 23 Nov 2010 19:23:05 -0500 Mike Welch is the numbers repository in that category. Mike=2C put down th at beer. BB On 23=2C Nov 2010=2C at 5:19 PM=2C rob and jennifer wrote: I have a Mark II that I wish to install a set of Mark III wings on. The sp ar tab to drag strut fitting measurements are the same=2C but the spar tab on the M3 wing is welded on lower which would increase the angle of inciden ce. My question is=2C does anyone happen to know the M3's wing angle of inc idence sitting on level ground ( specify stock or tall gear ) or the angle between the fuse tube(or horizontal stab) and wing bottom. thanks=2C Rob Cannon href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 23, 2010
Well at least it wasn't that ghastly Dr Pepper. My plane is back in the corner of the basement, safe from the elements and the vermin. It wasn't until the very end of the season that I solved a vexing problem with my carb. I flew it once and pulled the wings. -tough to do but here near the arctic circle things need to be placed in the proper shelter until spring. I hope to get a few little things done to it while near the toolbox. I had been using one of those Harbor Freight type switches for a battery disconnect. They work... and then they don't. I have a different switch coming and may also install a regular key switch for start. I had replaced the old gas tanks in the spring. I was unhappy with them so have two new ones from another source to install this winter. If they are gooduns I'll post after the fact. same with this new disconnect switch. I might do more.... but then again, I may not. BB On 23, Nov 2010, at 7:48 PM, Mike Welch wrote: > Bob, > > That's the funniest thing I've seen all day!! I was just getting ready to > shoot him off an email, and had to finish reading all my unread mail, with yours > being my last one. > > My beer, as a matter of fact, was the root variety. A&W diet root beer. : ) > > BTW, I've been working on my overhead panel/front panel/console. I had > to take a detour to build some electronic circuits (that install into the panels). > > Best regards, Mike > > From: slyck(at)frontiernet.net > Subject: Re: Kolb-List: Mark III wings on a Mark II > Date: Tue, 23 Nov 2010 19:23:05 -0500 > To: kolb-list(at)matronics.com > > Mike Welch is the numbers repository in that category. Mike, put down that beer. > BB > > On 23, Nov 2010, at 5:19 PM, rob and jennifer wrote: > > I have a Mark II that I wish to install a set of Mark III wings on. The spar tab to drag strut fitting measurements are the same, but the spar tab on the M3 wing is welded on lower which would increase the angle of incidence. My question is, does anyone happen to know the M3's wing angle of incidence sitting on level ground ( specify stock or tall gear ) or the angle between the fuse tube(or horizontal stab) and wing bottom. > thanks, Rob Cannon > > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.homebuilthelp.com">www.homebuilthelp.com > href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics .com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > > > > _blank>www.aeroelectric.com > /" target=_blank>www.buildersbooks.com > =_blank>www.homebuilthelp.com > =_blank>http://www.matronics.com/contribution > arget=_blank>http://www.matronics.com/Navigator?Kolb-List > ttp://forums.matronics.com > > ________________________________________________________________________________
Subject: heading to Geneseo
Date: Nov 23, 2010
at least a dozen balloons in the way DSCN1381.JPG copy after 60 missions.... Gooney bird wanted a push DSCN1980.JPG ________________________________________________________________________________
Date: Nov 24, 2010
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal, or a personal check: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 24, 2010
My beer, as a matter of fact, was the root variety.>> That jogged a memory. On my first visit to the US, to see Apollo 17 launch, root beer was available from a dispenser at my Cocoa Beach hotel. Almost everything I knew about America had been gleaned from reading the Saturday Evening Post, particularly the advertisements,cartoons etc, Shlitz, the beer that made Milwaukee famous` I remember 60 years later. Also ads. for gleaming great cars with tail fins. They had engines of incredible horsepower,were bigger than any truck then in the UK and, I discovered later, steered like the Nimitz. they also used more fuel per mile than my car did in a month. But Root Beer! That was THE American drink, next to Coke, I learned. It was therefore with glee that I put my coin in the slot and obtained a can of root beer. Ir was one of the great disappointments of my life. Never had I encountered such a horrible tasting drink. I passed the can to my brother who took a swig and was almost sick on the spot. We looked at each other in disbelief and solemnly poured the remainder down the lavatory. Yuck! Cheers Pat ________________________________________________________________________________
From: "Nelson, Craig" <craig.nelson(at)heraeus.com>
Date: Nov 24, 2010
Subject: cowl mold
Gang Im selling my cowl mold. Anyone interested make an offer Uncle craig [cid:image003.jpg(at)01CB8BBF.56AAA730] Technical Manager HERAEUS 300 Heraeus Way South Bend IN 86614 USA Direct 623-764-0680 craig.nelson(at)heraeus.com www.heraeus-kulzer-us.com ________________________________________________________________________________
Subject: Re: Mark III wings on a Mark II/Home And Ready To Fly
Date: Nov 24, 2010
----- Original Message ----- From: Pat Ladd Sent: Wednesday, November 24, 2010 8:40 AM Subject: Re: Kolb-List: Mark III wings on a Mark II My beer, as a matter of fact, was the root variety.>> That jogged a memory. On my first visit to the US, to see Apollo 17 launch, root beer was available from a dispenser at my Cocoa Beach hotel. Almost everything I knew about America had been gleaned from reading the Saturday Evening Post, particularly the advertisements,cartoons etc, Shlitz, the beer that made Milwaukee famous` I remember 60 years later. Also ads. for gleaming great cars with tail fins. They had engines of incredible horsepower,were bigger than any truck then in the UK and, I discovered later, steered like the Nimitz. they also used more fuel per mile than my car did in a month. But Root Beer! That was THE American drink, next to Coke, I learned. It was therefore with glee that I put my coin in the slot and obtained a can of root beer. Ir was one of the great disappointments of my life. Never had I encountered such a horrible tasting drink. I passed the can to my brother who took a swig and was almost sick on the spot. We looked at each other in disbelief and solemnly poured the remainder down the lavatory. Yuck! Cheers Pat Kolb Friends: Seems the Kolb Aircraft Builders and Flyers List has turned to BS, with little or no resemblence to its intended purpose. The individual members of this List are responsible for the quality of the List. It will be what we make it. I haven't flown my Kolb in more than 6 months. Have not seen the MKIII in more than 3 months. Hopefully, I can get over to the airstrip today to see if I still have an airplane. I got my my medical renewed while I was still in physical therapy, back in August, but did not have time to get my BFR prior to departing West. Got a lot of catching up to do. Been walking without a cane for two weeks now. Life is getting much better. Maybe I will be able to get my MKIII out of the hanger by myself. If not, I can call of friends to come help me push. I think I can get in and out of it by myself. I know I can operate the rudder pedals with no problem. Flying should be a piece of cake. Happy Thanksgiving everyone! john h mkIII hauck's holler, alabama ________________________________________________________________________________
Date: Nov 24, 2010
Hello all,=0A=0AJohn thanks for bringing the recent content of the list to everyones atten. Seem =0Alike its all about=0Awho can think of the --cutest -- one liners , and verry little meat and potatos =0Aabout Kokbs and flying them.=0A- Am planing to move to north Arkansas in Dec--Fayettville or Mo untin Home most =0Alikely. If there are any=0AKolbers in that area please E mail me with contact info. Would like to get =0Aaquainted. Thanks.=0A=0AFr ank Goodnight=0A=0A=0A=0A=0A________________________________=0AFrom: John H auck =0ATo: kolb-list(at)matronics.com=0ASent: Wed, Nove mber 24, 2010 9:37:10 AM=0ASubject: Re: Kolb-List: Mark III wings on a Mark " <jhauck(at)elmore.rr.com>=0A=0A=0A----- Original Message ----- =0AFrom: Pat Ladd=0ATo: kolb-list(at)matronics.com=0ASent: Wednesday, November 24, 2010 8:4 0 AM=0ASubject: Re: Kolb-List: Mark III wings on a Mark II=0A=0A=0AMy beer, as a matter of fact, was the root variety.>>=0A=0AThat jogged a memory. On my first visit to the US, to see Apollo 17 launch, =0Aroot beer was availa ble from a dispenser at my Cocoa Beach hotel.- Almost =0Aeverything I kne w about America had been gleaned from reading the Saturday =0AEvening Post, particularly the advertisements,cartoons etc,=0AShlitz, the beer that made Milwaukee famous` I remember 60 years later. Also =0Aads. for gleaming gre at cars with tail fins. They had engines of incredible =0Ahorsepower,were b igger than any truck then in the UK and, I discovered =0Alater, steered lik e the Nimitz.- they also used more fuel per mile than my =0Acar did in a month.=0ABut Root Beer! That was THE American drink, next to Coke, I learne d. It was =0Atherefore with glee that I put my coin in the slot and obtaine d a can of =0Aroot beer. Ir was one of the great disappointments of my life . Never had I =0Aencountered such a- horrible tasting drink. I passed the can to my brother =0Awho took a swig and was almost sick on the spot. We l ooked at each other in =0Adisbelief and solemnly poured the remainder down the lavatory. Yuck!=0A=0ACheers=0A=0APat=0A=0A=0AKolb Friends:=0A=0ASeems t he Kolb Aircraft Builders and Flyers List has turned to BS, with =0Alittle or no resemblence to its intended purpose.=0A=0AThe individual members of t his List are responsible for the quality of the =0AList.- It will be what we make it.=0A=0AI haven't flown my Kolb in more than 6 months.- Have no t seen the MKIII in =0Amore than 3 months.- Hopefully, I can get over to the airstrip today to see =0Aif I still have an airplane.- I got my my me dical renewed while I was still =0Ain physical therapy, back in August, but did not have time to get my BFR =0Aprior to departing West.- Got a lot o f catching up to do.=0A=0ABeen walking without a cane for two weeks now.- Life is getting much better. =0AMaybe I will be able to get my MKIII out o f the hanger by myself.- If not, I =0Acan call of friends to come help me push.- I think I can get in and out of =0Ait by myself.- I know I can operate the rudder pedals with no problem. =0AFlying should be a piece of c ake.=0A=0AHappy Thanksgiving everyone!=0A=0Ajohn h=0AmkIII=0Ahauck's holler ====================== ________________________________________________________________________________
Subject: Kolb Relocating
Date: Nov 24, 2010
Am planing to move to north Arkansas in Dec--Fayettville or Mountin Home most likely. If there are any Kolbers in that area please E mail me with contact info. Would like to get aquainted. Thanks. Frank Goodnight Frank G/Gang: Recommend looking into a little town called Mountain View, AR. I usually land their for fuel on my return flights from Oregon. Seems to be a nice little airport with a lot of really friendly builders and flyers there. Mountain View is located 36 air miles south of Mountain Home. john h mkIII Titus, AL ________________________________________________________________________________
Date: Nov 24, 2010
Better move over John. I now have 14 lifetime solo landings. If you stay out of your Kolb I figure in 2 or 300 years I'll have as much time as you! Thanks for the holiday wishes. Right back at ya! Just one problem, Thanksgiving isn't quite here yet and I've already gained a gallon of fuel! Vic Extra Maine ________________________________________________________________________________
Date: Nov 24, 2010
Ah, Pat, that hurts. One of the great memories of my life is going to the A & W drive in to get a gallon of their root beer to take home. My Grandpa and I had mugs that we kept in the freezer just for a frosted drink on a hot afternoon. Nothing finer. Fifty years later it's still one of my favorite treats even though he's not here to share it with me. Rick Girard On Wed, Nov 24, 2010 at 8:40 AM, Pat Ladd wrote: > My beer, as a matter of fact, was the root variety.>> > > That jogged a memory. On my first visit to the US, to see Apollo 17 launch, > root beer was available from a dispenser at my Cocoa Beach hotel. Almost > everything I knew about America had been gleaned from reading the Saturday > Evening Post, particularly the advertisements,cartoons etc, > Shlitz, the beer that made Milwaukee famous` I remember 60 years later. > Also ads. for gleaming great cars with tail fins. They had engines of > incredible horsepower,were bigger than any truck then in the UK and, I > discovered later, steered like the Nimitz. they also used more fuel per > mile than my car did in a month. > But Root Beer! That was THE American drink, next to Coke, I learned. It was > therefore with glee that I put my coin in the slot and obtained a can of > root beer. Ir was one of the great disappointments of my life. Never had I > encountered such a horrible tasting drink. I passed the can to my brother > who took a swig and was almost sick on the spot. We looked at each other in > disbelief and solemnly poured the remainder down the lavatory. Yuck! > > Cheers > > Pat > > * > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Serious and to the point comments only ,Please.
Date: Nov 24, 2010
I have yet to fly my 2006 Kolb Firestar that I just purchased. Winter like weather have grounded it until Spring, which is fine by me. I'm a Private Pilot with four hundred hours in mostly Piper Warriors and Cessna 172's 152's 150's. I plan on getting some tail dragger dual time this Spring and then a lot of Crow Hopping in no wind conditions any on a 6000' runway before I take my plane home to my grass strip. I would like some pointers, but only from 503 Rotax Kolb Firestar pilots with considerable experience in that airplane about flying this airplane safely. Things to do ...things not to do ! Serious and to the point comments only ,Please. -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320827#320827 Attachments: http://forums.matronics.com//files/kolb_eis_314.jpg http://forums.matronics.com//files/kolb_181.jpg ________________________________________________________________________________
Subject: Novice Kolb Pilot
Date: Nov 24, 2010
I have yet to fly my 2006 Kolb Firestar that I just purchased. Winter like weather have grounded it until Spring, which is fine by me. I'm a Private Pilot with four hundred hours in mostly Piper Warriors and Cessna 172's 152's 150's. I plan on getting some tail dragger dual time this Spring and then a lot of Crow Hopping in no wind conditions on a 6000' runway before I take my plane home to my grass strip. I would like some pointers, but only from 503 Rotax Kolb Firestar pilots with considerable experience in that airplane about flying this airplane safely. Things to do ...things not to do ! Serious and to the point comments only ,Please. -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320828#320828 ________________________________________________________________________________
From: "Perry Rhoads" <prhoads61(at)frontiernet.net>
Subject: Re: Novice Kolb Pilot
Date: Nov 24, 2010
You'll hear many support the idea, but crow hopping has been the demise of many over the years. Especially new tail wheel pilots in new to them airplanes. These airplanes have very little inertia and speed bleeds quickly. Crow hopping on hard surface with a new Kolb guy will probably get something bent. Perry Rhoads 503 Firestar N2407A ----- Original Message ----- From: "Dennis Thate" <retroman(at)frontier.com> Sent: Wednesday, November 24, 2010 10:55 AM Subject: Kolb-List: Novice Kolb Pilot > > I have yet to fly my 2006 Kolb Firestar that I just purchased. Winter like > weather have grounded it until Spring, which is fine by me. I'm a Private > Pilot with four hundred hours in mostly Piper Warriors and Cessna 172's > 152's 150's. I plan on getting some tail dragger dual time this Spring and > then a lot of Crow Hopping in no wind conditions on a 6000' runway before > I take my plane home to my grass strip. > > I would like some pointers, but only from 503 Rotax Kolb Firestar > pilots with considerable experience in that airplane about flying this > airplane safely. Things to do ...things not to do ! Serious and to > the point comments only ,Please. > > -------- > "?oEveryone is entitled to his own opinion, but not his own > facts.? Daniel Patrick Moynihan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320828#320828 > > > ________________________________________________________________________________
Date: Nov 24, 2010
Subject: Re: Serious and to the point comments only ,Please.
Dennis, Just one comment, pithy and to the point as requested. Crow hopping is a bad idea, IMHO. You have enough to do on takeoff without adding making an instant transition to landing. How many crow hops have you done in the G A aircraft you've flown? If you're like me, the answer is zero. You say you want to know how to fly your Firestar safely, so fly it. Take off, go aroun d the pattern, set up for landing, land. You won't have any of the muscle memory and sight picture recognition in your first flights so why compound your lack of experience with having to make split second corrections in an abnormal transition from climb to landing. While you're getting prepared this winter I'd recommend you read "Stick and Rudder" with particular attention to the concept of "the spot that does not move" for landing spot aim point recognition, and "The Compleat Taildragger Pilot" by Harvey S. Plourde and his arguments as to why high speed taxiing a taildragger is a dangerous thing to do. Rick Girard On Wed, Nov 24, 2010 at 10:50 AM, Dennis Thate wrote : > > I have yet to fly my 2006 Kolb Firestar that I just purchased. Winter lik e > weather have grounded it until Spring, which is fine by me. I'm a Private > Pilot with four hundred hours in mostly Piper Warriors and Cessna 172's > 152's 150's. I plan on getting some tail dragger dual time this Spring an d > then a lot of Crow Hopping in no wind conditions any on a 6000' runway > before I take my plane home to my grass strip. > > I would like some pointers, but only from 503 Rotax Kolb Firestar pilo ts > with considerable experience in that airplane about flying this airplane > safely. Things to do ...things not to do ! Serious and to the point > comments only ,Please. > > -------- > "=93Everyone is entitled to his own opinion, but not his own facts. =94 > Daniel Patrick Moynihan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320827#320827 > > > Attachments: > > http://forums.matronics.com//files/kolb_eis_314.jpg > http://forums.matronics.com//files/kolb_181.jpg > > =========== =========== =========== =========== > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unabl e to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 24, 2010
Date: Nov 24, 2010
Subject: novice Kolb pilot
I agree with Perry. It is my opinion that it takes more skill to crow hop a Kolb then to just fly one. I would tie the Firestar down, and make sure it will develop full power. Then I would look for a nice grass strip on a calm day, and give it a go. When you land, approach fast and hold the FS one or two feet off the ground until it slows down and lands. Lanny FSII 503 DCDI ________________________________________________________________________________
Date: Nov 24, 2010
HINTS TO SAVE YOUR BUTT 1 Fly off of a grass strip, at least in the beginning. Grass helps immensely in keeping the tail in its preferred position (behind you). Fortunately, the Firestar has a fairly long fuselage and is not overly sensitive for a tailwheel airplane. 2 Push stick forward. The Firestar has a high thrust-line for its pusher prop. When you come back on the throttle, the nose will want to come up; so immediately the get stick forward to maintain airspeed or bad things will happen. 3 Get some dual time in an airplane absolutely as close in configuration to the same plane as you will be flying. For you, this will be a Kolb Mark III. If your intended dual time is in a Cub or Aeronca type airplane, FORGET IT. The Kolbs are wonderful airplanes but are extremely draggy and with very low wing loading they react MUCH differently than Cubs or Aeroncas. 4 Practice stalls and engine out landings with an instructor in the Mark III. 5 Congratulate yourself on choosing a fine airplane. You are going to have a lot of fun, come spring. P.S. Steps 3 and 4 saved my life. When I was in the beginning stages, a crow hop scared the crap out of me. I drove to PA for a couple hours of dual instruction in the factory demonstrator that I credit for saving my butt when things began to unravel on my first solo flight. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320848#320848 ________________________________________________________________________________
Date: Nov 24, 2010
Thanks All who responded so far Racer Jerry...I'm told this airplane is very easy to fly but has a peculiar temperament with it's freewheeling prop to really slows down quickly when you pull the power back on approach and it takes a steep approach 'stick forward' to keep the speed up. I did ride in a two seat Demo Kolb at Oshkosh...so I know it's sink rate is fast. So does a Kolb Firestar 503 need right or left rudder in take-offs & Climbs? Regardless of it' idiosyncrasies I think it's a great design and I'm eager to master it and fly it safely. -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320852#320852 ________________________________________________________________________________
Date: Nov 24, 2010
Dennis, Besides the other good comments, suggest you download a copy of AC90-89A from FAA.gov. Both they and the EAA in their manuals on flight test for homebuilts recommend you do a series of low and high speed taxi tests. This is *not* crow hopping. You slowly add (very small amounts of) power on repeated runs. The idea is to be comfortable with accurately raising the tail and controlling direction with rudder as well as having an idea of what your landing sight picture will look like.. Suggest you follow closely the Advisory Circular through First Flight as this will also have you checking your aircraft condition as well as your piloting practice for First Landing. The only other point I would reemphasize is general aviation pilots are not ready for how fast these high drag/low inertia airplanes slow down when power is reduced. The remedy is to carry significant power all the way to touchdown. For example, the Zenith CH701 crowd say to use 3000 rpm on the Rotax 912S for the first several hours. Tom Kuffel Whitefish, MT EAA Flight Advisor ________________________________________________________________________________
Date: Nov 24, 2010
Subject:
So does a Kolb Firestar 503 need right or left rudder in take-offs & Climbs? I have only ever flown my FSII, so I don`t speak for all Kolbs. I never noticed that I need one or the other (left OR right rudder) on take-off and climb. I use BOTH right and left, whatever inputs it takes to keep the aircraft in the middle of the runway. Lanny FSII N598LF ________________________________________________________________________________
Date: Nov 24, 2010
The remedy is to carry significant power all the way to touchdown. For example, the Zenith CH701 crowd say to use 3000 rpm on the Rotax 912S for the first several hours. Tom Kuffel Tom K/Gang: Don't know about the CH701, but my 912S powered MKIII turns about 2600-3000 rpm in a steep approach at idle power. Been so long I don't really remember. ;-( Your points are good. I would like to add one thing. After you take off and climb to about 1,000 feet AGL, check your stall speed, then on your first approach keep at least 10-15 mph above this indicated stall speed all the way to the ground. Hard to stall a Kolb and drop one in under those conditions. There are a lot of bent Kolbs because the pilot did not maintain airspeed above the stall. We have experienced Kolb pilots that have let themselves get into that situation. I like to keep a good cross check on my ASI during approach. Just got back from Gantt International Airport. Other than a lot of barn dust, carpenter bee and bird crap, several nice sized mud daubers nest, and a couple small bites in the top edge of the right seat back, Miss P'fer (P fer Plane) is good to go. I need to replace the battery, pulled it and kept it charged while I was gone. Must also check the carb float bowls and add some fresh fuel to the tank. I left it stored with some avgas and mogas, plus Marvel Mystery Oil. The MMO seems to do about the same job as Stabil. My Nissan V6 that sat for 3 months cranked right up and ran like it did when I parked it. The Nissan did the same thing last year and the year before that. Have the same sort of luck with Suzuki dirt bike, ATV, lawn tractor, and antique tractors that spend long periods in storage. Good to be home, john h mkIII Titus, AL ________________________________________________________________________________
Date: Nov 24, 2010
Thanks again, ..........To all who contributed good information and especially the AC90-89A from FAA.gov. . Looks like I'll have it all right in my 'minds eye' when this Spring comes around again. -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320858#320858 ________________________________________________________________________________
Date: Nov 24, 2010
Thanks again, ..........To all who contributed good information and especially the AC90-89A from FAA.gov. . Looks like I'll have it all right in my 'minds eye' when this Spring comes around again. -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320859#320859 ________________________________________________________________________________
Subject: Re:
Date: Nov 24, 2010
I use BOTH right and left, whatever inputs it takes to keep the aircraft in the middle of the runway. Lanny FSII N598LF Lanny F/Gang: Took the words right out of my mouth. I do as you do, fly the airplane keeping it right down the middle. That's the secret to flying a Kolb, "fly the airplane, whatever it takes to be in control". john h mkIII Titus, AL ________________________________________________________________________________
Date: Nov 24, 2010
John ,Glad to hear you made home and all was well Hope you and missPfer get back =0Ain the sky soon watch out for those bugs !Im sure you know about t hat. your =0Afriend CChris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisable d from crash building Firefly =0A=0A=0A=0A=0A______________________________ __=0AFrom: ope John Hauck <jhauck(at)elmore.rr.com>=0ATo: kolb-list(at)matronics. com=0ASent: Wed, November 24, 2010 4:04:13 PM=0ASubject: Re: Kolb-List: Ser ious and to the point comments only ,Please.=0A=0A=0A-=0A-The remedy is to carry significant power all the way to touchdown.- For =0Aexample, th e Zenith CH701 crowd say to use 3000 rpm on the Rotax 912S for the =0Afirst several hours.=0A-=0ATom Kuffel=0A-=0A-=0ATom K/Gang:=0A-=0ADon't know about the CH701, but my 912S powered MKIII-turns about 2600-3000 rpm =0Ain a steep approach at idle power.- Been so long I don't really remem ber.- ;-(=0A-=0AYour points are good.=0A-=0AI would like to add one t hing.- After you take off and climb to about 1,000 feet =0AAGL, check you r stall speed, then on your first approach keep-at least 10-15-mph =0Aa bove this indicated stall speed all the way to the ground.- Hard to stall a =0AKolb and drop one in under those conditions.=0A-=0AThere are a lot of bent Kolbs because the pilot did not maintain airspeed above =0Athe stal l.- We have experienced Kolb pilots that have let themselves get into =0A that situation.- I like to keep a good cross check on my ASI during appro ach.=0A-=0AJust got back from Gantt International Airport.- Other than a lot of barn dust, =0Acarpenter bee and bird crap, several nice sized mud daubers nest, and a couple =0Asmall bites in the top edge of the right seat back, Miss P'fer (P fer Plane) is =0Agood to go.- I need to replace the battery, pulled it and kept it charged =0Awhile-I was gone.-- Must al so check the carb float bowls and add some fresh fuel =0Ato the tank.- I left it stored with some avgas and mogas, plus Marvel Mystery =0AOil.- Th e MMO seems to do about the same job as Stabil.- My Nissan V6 that sat =0Afor 3 months cranked right up and ran like it did when I parked it.- T he Nissan =0Adid the same thing last year and the year before that.- Have the same sort of =0Aluck with Suzuki dirt bike, ATV, lawn tractor, and ant ique tractors that spend =0Along periods in storage.=0A-=0AGood to be hom ================= =0A=0A=0A ________________________________________________________________________________
Date: Nov 24, 2010
........She's a pretty one ! My new bird...http://www.airport-data.com/aircraft/N49WR.html I just became the legal owner today according to the FAA -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320863#320863 ________________________________________________________________________________
Date: Nov 24, 2010
Date: Nov 24, 2010
Rudder on take off and climb? Because there's no prop in front of you, you can use a yaw string to determine, well, yaw. Just a small piece of yarn an d a reference line (tape, Sharpie line, just has to be dark and thin) and you r there. Ignore it on take off and keep to the center of the runway, after lift off it will be the opposite of what you've learned to do with a ball (step on the ball). Which rudder pedal you need to press depends on your prop, your redrive, whether the previous owner put a trim tab on and if there is a trim tab, how much it's bent. The nice thing about a yaw string, besides the cost, is that you don't have to think about it a lot, just keep it on the reference line. Rick Girard On Wed, Nov 24, 2010 at 2:28 PM, Dennis Thate wrote : > > Thanks All who responded so far > > Racer Jerry...I'm told this airplane is very easy to fly but has a peculi ar > temperament with it's freewheeling prop to really slows down quickly when > you pull the power back on approach=85=85=85 and it takes a steep approac h 'stick > forward' to keep the speed up. I did ride in a two seat Demo Kolb at > Oshkosh...so I know it's sink rate is fast. > > > So does a Kolb Firestar 503 need right or left rudder in take-offs & > Climbs? > > Regardless of it' idiosyncrasies I think it's a great design and I'm > eager to master it and fly it safely. > > -------- > "=93Everyone is entitled to his own opinion, but not his own facts. =94 > Daniel Patrick Moynihan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320852#320852 > > =========== =========== =========== =========== > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unabl e to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 24, 2010
I was in the same shape back in May. I have a Firestar with 503. My prior experience, 0 taildragger hours, 350 in a Challenger II, 50 in a Quicksilver 50 in GA planes and 2000 in Army helicopters. I would recommend grass instead of hardsurface. The GA taildragger may help with the tail dragger part, but not a bit in the landing an approach. The Kolb glides like a rock. If you get a little slow and flare at 10 feet, it will drop. Get some time in a Kolb Mark III if possible, next after that may be a quicksilver, then a challenger or hawk. I don't about the hawk, but the challenger glides much better than a firestar. I did fast taxi on grass untill I was confident on the ground handling. The I took off. The first few landing, keep up the speed, keep and power in it and fly it to the ground. Good luck, these are fun planes to fly. Jerry ----- Original Message ----- From: "Dennis Thate" <retroman(at)frontier.com> Sent: Wednesday, November 24, 2010 10:55 AM Subject: Kolb-List: Novice Kolb Pilot > > I have yet to fly my 2006 Kolb Firestar that I just purchased. Winter like > weather have grounded it until Spring, which is fine by me. I'm a Private > Pilot with four hundred hours in mostly Piper Warriors and Cessna 172's > 152's 150's. I plan on getting some tail dragger dual time this Spring and > then a lot of Crow Hopping in no wind conditions on a 6000' runway before > I take my plane home to my grass strip. > > I would like some pointers, but only from 503 Rotax Kolb Firestar > pilots with considerable experience in that airplane about flying this > airplane safely. Things to do ...things not to do ! Serious and to > the point comments only ,Please. > > -------- > "?oEveryone is entitled to his own opinion, but not his own > facts.? Daniel Patrick Moynihan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=320828#320828 > > > ________________________________________________________________________________
Date: Nov 24, 2010
Subject: Kolb Related In That It Flys
Have a good day tomorrow. http://www.youtube.com/watch?v=uGUnTsunNOA Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Next time you camp in your Kolb
Date: Nov 24, 2010
Keep this story in mind....it's True ! http://www.alaskadispatch.com/dispatches/news/3370-an-appetite-for-revenge http://blogs.timeslive.co.za/wanderer/2009/11/10/bears-just-one-more-flying-hazard-in-alaska/ During a private "fly-in" fishing excursion in the Alaskan wilderness, the chartered pilot and fishermen left a cooler and bait in the plane. And a bear smelled it. This is what the bear did to the plane. The pilot used his radio and had another pilot bring him 2 new tires, 3 cases of duct tape, and a supply of sheet plastic. He patched the plane together, and FLEW IT HOME ! -------- "Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320884#320884 ________________________________________________________________________________
Date: Nov 24, 2010
Dennis, The only thing I would add to those previous comments is make your first fl ight a longer one.It takes time to get the feel of something this light.The best place to practice approaches is at altitude,and stall it if you are c omfortable enough,or just fly it as slow as you can and maneuver it a bit.Y ou're gonna like it,I think it's Homers"Most fun to fly aircraft".I put 600 hrs on my FS2 and have almost that much on the MK-3 now. G.Aman MK-3 C Jabiru 2200A 600hrs -----Original Message----- From: Dennis Thate <retroman(at)frontier.com> Sent: Wed, Nov 24, 2010 11:53 am Subject: Kolb-List: Serious and to the point comments only ,Please. I have yet to fly my 2006 Kolb Firestar that I just purchased. Winter like weather have grounded it until Spring, which is fine by me. I'm a Private P ilot with four hundred hours in mostly Piper Warriors and Cessna 172's 152's 150 's. I plan on getting some tail dragger dual time this Spring and then a lot of C row Hopping in no wind conditions any on a 6000' runway before I take my plane home to my grass strip. I would like some pointers, but only from 503 Rotax Kolb Firestar pilot s with considerable experience in that airplane about flying this airplane sa fely. Things to do ...things not to do ! Serious and to the point comments o nly ,Please. -------- "=C3=A2=C2=C2=9CEveryone is entitled to his own opinion, but not hi s own facts.=C3=A2=C2=C2=9D Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320827#320827 Attachments: http://forums.matronics.com//files/kolb_eis_314.jpg http://forums.matronics.com//files/kolb_181.jpg ________________________________________________________________________________
Subject: Zinc Chromate?
Date: Nov 24, 2010
I have some abraded areas on my fuse frame (FS1). The paint/primer/sealer stuff on there now is a greenish color. Is it safe to assume this is zinc chromate? I need to touch it up- where do you suppose I should go to get some more paint? What kind should I use? Will spray on one part stuff stick to 2-part? Should I get 2-part zinc chromate primer? I really only need a very little and didn't want to invest heavily in the stuff. Maybe if you-all concur it is zinc chromate, maybe a local flier has some left over. I unnerstan this stuff costs lots to ship as it is a hazardous material. Thanks GeoB ________________________________________________________________________________
Subject: Kolb FS1 fuse floor
Date: Nov 24, 2010
I notice in pictures that many/most Kolbs have a floor from the nose cone extending back past the pilot seat. It may just be fabric, not sure. Mine has only a short sheet of aluminum which extends back a short ways and ends before the control stick. I 'spose this is nice and light, but it seems vulnerable to every pen and flashlight I might ever drop. Do most folks just use fabric? I was thinking painted aluminum would be less vulnerable, plus more immune to weeds scratching it too. What do you think? GeoB ________________________________________________________________________________
Date: Nov 25, 2010
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2010
Subject: Kolb floor
George, My FSII cockpit is covered with fabric on the outside. On the inside there is an aluminum plate that extends to about my hips when seated in the pilots seat. Not only does this protect the fabric, but it also allowed me to mount my radio and other accessories to my floor using rivnuts. Lanny N598LF ________________________________________________________________________________
Date: Nov 25, 2010
Get your dual time in an Ultralight or light sport tail dragger and fly it to the ground when landing. Al -------- Al Bumhoffer, Elkton, MI, Aerolite 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321000#321000 ________________________________________________________________________________
Date: Nov 25, 2010
Subject: RE: Kolb-List Digest: 33 Msgs - 11/24/10
John H. Glad you are back and preparing to fly. Sure do miss your input on the list when you are down. Bob VW MKIIIX builder ________________________________________ ________________________________________________________________________________
Date: Nov 25, 2010
Subject: Re: Zinc Chromate?
George, The problem with any one part paint is it is easy prey for solvents. If you have to do a fabric repair the solvent in the glue will ruin the paint and the fabric won't stick. Almost any epoxy primer is resistant to solvent once it is fully cured. O'Reilly's Auto parts stocks a line of epoxy primers that can be bought in qts and is about half the price of Polyfiber's epoxy primer. When I talked with the engineer at the company whose products O'Reilly's sells he assured me of its ability to withstand even MEK. Rick Girard On Thu, Nov 25, 2010 at 12:32 AM, George Bearden wrote: > > I have some abraded areas on my fuse frame (FS1). The paint/primer/sealer > stuff on there now is a greenish color. Is it safe to assume this is zinc > chromate? > > I need to touch it up- where do you suppose I should go to get some more > paint? What kind should I use? Will spray on one part stuff stick to > 2-part? > Should I get 2-part zinc chromate primer? I really only need a very little > and didn't want to invest heavily in the stuff. Maybe if you-all concur it > is zinc chromate, maybe a local flier has some left over. I unnerstan this > stuff costs lots to ship as it is a hazardous material. > > Thanks > GeoB > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 25, 2010
Subject: Re: Kolb FS1 fuse floor
I used 1/4" Birch plywood in my Mk IIIC and made it just big enough to rest my heels on comfortably. Cheap, light, easy to replace, and I attached it with MS21919 (Adel) clamps so there's no need to drill holes in the fuselage tubing. Rick Girard On Thu, Nov 25, 2010 at 12:53 AM, George Bearden wrote: > > I notice in pictures that many/most Kolbs have a floor from the nose cone > extending back past the pilot seat. It may just be fabric, not sure. Mine > has only a short sheet of aluminum which extends back a short ways and ends > before the control stick. I 'spose this is nice and light, but it seems > vulnerable to every pen and flashlight I might ever drop. Do most folks > just > use fabric? I was thinking painted aluminum would be less vulnerable, plus > more immune to weeds scratching it too. What do you think? > > GeoB > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 25, 2010
Greetings George, The floor installed on each side of the pilot is used on the FireStar II, it is used for the rear passenger to put his/her feet. I notice in pictures that many/most Kolbs have a floor from the nose cone extending back past the pilot seat. It may just be fabric, not sure. Mine has only a short sheet of aluminum which extends back a short ways and end s before the control stick. I 'spose this is nice and light, but it seems vulnerable to every pen and flashlight I might ever drop. Do most folks ju st use fabric? I was thinking painted aluminum would be less vulnerable, plus more immune to weeds scratching it too. What do you think? GeoB ________________________________________________________________________________
Date: Nov 25, 2010
HINTS(cont.) 6. Perform a weight and balance check with you in the airplane. Buy / borrow three cheap bathroom scales, weigh the airplane, calculate the center of gravity and verify that the CG is within limits as specified by the manufacturer. Take care to eliminate any sideways bind at the main wheel scales that could distort readings. I hope that you received the builders manual with the airplane. CG limits and W&B procedures are in the manual. OR YOU CAN WING IT If you dont have enough up elevator authority to flare for landing below 70 mph, you are probably NOSE HEAVY If you enter a non-recoverable stall, you are probably TAIL HEAVY -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321024#321024 ________________________________________________________________________________
Date: Nov 25, 2010
HINTS(cont.) 7. Insure that your airplane has the mass balance rods for the ailerons installed. Flexing of the long torque tube for the ailerons opens the possibility of encountering aileron flutter. During a high speed dive, it is often impossible to slow the airplane quickly enough before one or more ailerons separate from the aircraft. The Firestar operates much better with ailerons attached. Properly installed, and adjusted to balance the aileron, the mass balance rods eliminate flutter concerns. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321027#321027 ________________________________________________________________________________
Date: Nov 25, 2010
GeoB wrote: > I notice in pictures that many/most Kolbs have a floor from the nose cone > extending back past the pilot seat. It may just be fabric, not sure. Mine > has only a short sheet of aluminum which extends back a short ways and ends > before the control stick. I 'spose this is nice and light, but it seems > vulnerable to every pen and flashlight I might ever drop. Do most folks just > use fabric? I was thinking painted aluminum would be less vulnerable, plus > more immune to weeds scratching it too. What do you think? > > GeoB If you use fabric, you can pick up a small piece of carpet that compliments the paint scheme and cut out 2 triangles to fit in around the diagonal crossmember, and that will protect your fabric from dropped sharp objects. Also it is easy to take out and clean. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321032#321032 ________________________________________________________________________________
Date: Nov 25, 2010
>Buy / borrow three cheap bathroom scales=2C weigh the airplane=2C calculat e the center of gravity and verify that the CG is within limits as >specifi ed by the manufacturer. > Jerry King Jery=2C Important point about the W&B. I don't think you need 3 scales=2C tho. If a guy can determine the scale's thickness=2C and then come up with 2 "whatevers" of the same thickn ess ( blocks of wood=2C telephone books=2C kid's textbooks) a guy could get away with just one scal e. Example=3B my relatively accurate digital (bathroom) scale is 1 3/4" thi ck=2C and so are a couple of parts catalogs I've got. By jocking the scale from one wheel to the other=2C tra ding catalogs as you go=2C you could come up with a pretty darn good W&B. (plus=2C using only one sca le helps reduce error factors from using multiple scales.) The primary concern is=2C of course=2C making sure the plane is always si tting in the same position per reading. I still think you brought up an important point about the W&B. Mike Welch ________________________________________________________________________________
Date: Nov 26, 2010
If you enter a non-recoverable stall, you are probably TAIL HEAVY>> And dead. Cheers Pat ________________________________________________________________________________
Date: Nov 26, 2010
Hi Dennis, everyone else seems to be putting their five eggs in so here is my tip. Remember what your first flying instructor told you "Open the throttle SLOWLY on takeoff" If you do it too quickly, particularly with the tail still on the ground she will stand on a wing tip and dash off the side of the runway. Hope you remember all these jewwls of wisdom come the Spring. Good luck Pat ________________________________________________________________________________
Subject: HAC carbs for sale
Date: Nov 26, 2010
I have two high altitude compensating carbs for a 582 on a Talon XP that I never used. Great shape low time carbs. Long tubing for in cockpit adjus tment. $350. Jim Van Laak jvanlaak(at)aol.com ________________________________________________________________________________
Date: Nov 26, 2010
Subject: Re: Kolb Relocating
Date: Nov 26, 2010
Subject: Re: Fw: Cracked spar on fire star.
Is that a corrosion crack? It being a long the seem does not look like fatigue crack. ---- frank goodnight wrote: ============ ----- Forwarded Message ---- From: Jon Lockhart <jonlock2(at)gmail.com> ft.com; kolb-list(at)matronics.com Sent: Tue, November 16, 2010 6:02:16 PM Subject: Cracked spar on fire star. Please review the photos.=C2- Thanks, Frank Goodnight -- kugelair.com ________________________________________________________________________________
Date: Nov 27, 2010
Subject: No "Black Friday" For List Fund Raiser...
Dear Listers, Curiously, even though the number of List subscriptions are significantly up this year, support during this year's Fund Raiser is still substantially behind last year. There are only a couple more days left in November and the end of the Fund Raiser is quickly approaching. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid, other sources of income might be required including some sort of advertising. Please don't let that happen! Your personal Contribution of $20 or $30 goes a long ways to keeping the operation a float. Please make sure your name is on this year's List of Contributors published in December. The Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 27, 2010
Subject: Just when I thought it was winter
I keep telling myself that this is the last good day and I'll put the Mk III up for the winter so I can get started on the work I want to do. Then another day like today comes along that's just irresistible and well, what the heck, it's only a little gas and two stroke oil. Almost an hour of Kolb therapy going around the patch, even a trip down to Oxford for one landing on the new asphalt. Okay, I'm ready for winter. Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: First Flight
Date: Nov 27, 2010
Hi Folks: First flight today. Well, first flight since the first of May 2010, for my MKIII and me. All went well. I haven't forgotten how to aviate, neither has Miss P'fer. I got 1.2 hours today. Miss P'fer has 3,010.9 hours on her airframe and 441.4 hours on her 912ULS. The airplane flew well, despite all the barn dust, bird and bug crap, and dirt dauber nests. Got about a half teaspoon of water out of the fuel tank before the first flight. Both carb float bowls were dry with evidence that there had been a little moisture in each of them. Engine fired right up and ran like a top. While she was sitting for so long, she had two Titan exhaust springs break. First time I have had exhaust springs break when the engine was not running. Must say it was good to get back into the air again. I am looking forward to making some long flights this year. The only one I got last year was a flight down to Sun and Fun in Lakeland, Florida. I had my doubts if I was going to be able to make the flight to Monument Valley next year, but after today's flight, I think it is doable. Reckon she will really fly good if I get a warm spell so I can wash her. Maybe tomorrow. john h Titus, Alabama ________________________________________________________________________________
Date: Nov 27, 2010
Subject: Re: First Flight
John , So very glad to hear you got back in the air ! Im jealous but it was very moving to hear your "rehab"was successful . Hope you get the weather to fly every time you want you have earned it . Your friend Chris Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ----- Original Message ---- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Sat, November 27, 2010 7:04:53 PM Subject: Kolb-List: First Flight Hi Folks: First flight today. Well, first flight since the first of May 2010, for my MKIII and me. All went well. I haven't forgotten how to aviate, neither has Miss P'fer. I got 1.2 hours today. Miss P'fer has 3,010.9 hours on her airframe and 441.4 hours on her 912ULS. The airplane flew well, despite all the barn dust, bird and bug crap, and dirt dauber nests. Got about a half teaspoon of water out of the fuel tank before the first flight. Both carb float bowls were dry with evidence that there had been a little moisture in each of them. Engine fired right up and ran like a top. While she was sitting for so long, she had two Titan exhaust springs break. First time I have had exhaust springs break when the engine was not running. Must say it was good to get back into the air again. I am looking forward to making some long flights this year. The only one I got last year was a flight down to Sun and Fun in Lakeland, Florida. I had my doubts if I was going to be able to make the flight to Monument Valley next year, but after today's flight, I think it is doable. Reckon she will really fly good if I get a warm spell so I can wash her. Maybe tomorrow. john h Titus, Alabama ________________________________________________________________________________
Date: Nov 27, 2010
----- John , So very glad to hear you got back in the air ! Chris Davis Thanks, Chris/Gang: I'm still recovering, but it is definitely getting better each day. Was happy the 912ULS performed so well after nearly 7 months down time. It was just as though she had been flown regularly. I was also surprised I had no more moisture in the fuel tank, which was at about 5 gal, or 20% capacity. The fuel was a mixture of 87 octane mogas w/ethanol and 100LL, plus Marvel Mystery Oil. I have no idea what the ratio of the two fuels was, but probably more 87 than 100. A good bath and the bird will be as good as new. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Just Three Days Left & Some Very Nice Comments...
Dear Listers, There are just three days left in this year's List Fund Raiser. Won't you take a monment and make a quick Contribution today to support the continued upgrade and operation of these Forum services. I've received some more really nice comments from Listers along with their List Support Contributions, and I've share a few below. There are some sweet gifts available this year, so browse the selections and pickup a nice item along with your qualifying Contribution. Contribution Web Site: http://www.matronics.com/contribution Or drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ------------------------------------------------------- Great resource, keep it coming... Marten V. Thanks for maintaining these essential lists! Rumen D. Great Service! Douglas D. Thanks for this great service! Peter T. Thanks for your enduring support of homebuilding communications! Daniel M. You do a great job and provide a valuable service. Mark B. It's really a great source I have used a lot. Robert K. Reading the RV-10 list is part of my morning routine... Perry C. Great job running these lists. Edward T. Thanks for doing a tough job. Mic T. Your List was such a great resource for me when I built in "98". Ron V. Its a very useful forum. Dave F. Really enjoy your list... William D. Great service, Gerald T. The list still is a valuable source of information and there are many worthwhile postings. Graham H. The list has seen me through an RV-9A, RV-10, and now an RV-12. Albert G. Thanks for a great resource! Barry H. Thank you for maintaining this excellent site. Bill W. The Matronics Email list are an invaluable service. William C. I appreciate the RV-10 list. Vijay P. Thanks for a great list and all of the work you do. Ian W. Thanks for keeping up this very useful list. George R. The list is excellent and I find it very handy for any problems I come up against during construction. Greg W. The lists are an important part of my day. I've met lots of people and made lots of friends. Dave S. It's really a great source I haved used a lot. Robert K. I read the Pietenpol List everyday. PF B. ________________________________________________________________________________
Date: Nov 28, 2010
welcome back to the skys John after a long recovery period Ellery Batchelder Jr. -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Sat, Nov 27, 2010 7:04 pm Subject: Kolb-List: First Flight Hi Folks: First flight today. Well, first flight since the first of May 2010, for my KIII and me. All went well. I haven't forgotten how to aviate, neither as Miss P'fer. I got 1.2 hours today. Miss P'fer has 3,010.9 hours on he r irframe and 441.4 hours on her 912ULS. The airplane flew well, despite al l he barn dust, bird and bug crap, and dirt dauber nests. Got about a half easpoon of water out of the fuel tank before the first flight. Both carb loat bowls were dry with evidence that there had been a little moisture in ach of them. Engine fired right up and ran like a top. While she was sitting for so long, she had two Titan exhaust springs break . irst time I have had exhaust springs break when the engine was not running . Must say it was good to get back into the air again. I am looking forward o making some long flights this year. The only one I got last year was a light down to Sun and Fun in Lakeland, Florida. I had my doubts if I was going to be able to make the flight to Monument alley next year, but after today's flight, I think it is doable. Reckon she will really fly good if I get a warm spell so I can wash her. aybe tomorrow. john h itus, Alabama -======================== ======================== =========== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== ________________________________________________________________________________
Subject: Affordable Safety !
Date: Nov 28, 2010
Insurance question? As a Private Pilot can I insure my Experimental aircraft ELSA Kolb Firestar II for hull damage, but more importantly, for liability damage to people and all things on the ground. I have yet to check on this very important point, if so how much can I expect to pay? Thanks in advance Dennis -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321383#321383 ________________________________________________________________________________
Subject: Re: Affordable Safety !
Date: Nov 28, 2010
----- Original Message ----- From: "Dennis Thate" <retroman(at)frontier.com> Sent: Sunday, November 28, 2010 10:11 AM Subject: Kolb-List: Affordable Safety ! Insurance question? As a Private Pilot can I insure my Experimental aircraft ELSA Kolb Firestar II for hull damage, but more importantly, for liability damage to people and all things on the ground. I have yet to check on this very important point, if so how much can I expect to pay? Thanks in advance Dennis -------- ?~?~Beware of false knowledge; it is more dangerous than ignorance.?T?T George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321383#321383 ________________________________________________________________________________
Date: Nov 28, 2010
Insurance question? Dennis Check out EAA endorsed insurance from Falcon. I have used them for some time now. Premiums will be based on total flight hours, time in make and model, and past pilot history. I pay 1,200.00 a year for 30,000.00 hull coverage and liability (1,000,000.00), based on 5,000+ hours in Kolbs, plus 3,000+ hours in make and model. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 28, 2010
Hi Gang: Sorry about this one. Had a round cook off and computer fired before I was ready. BTW, the subject line should be "insurance". Don't think insurance buys an aviator "affordable safety". john h mkIII Titus, Alabama ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, November 28, 2010 10:24 AM Subject: Re: Kolb-List: Affordable Safety ! ----- Original Message ----- From: "Dennis Thate" <retroman(at)frontier.com> Sent: Sunday, November 28, 2010 10:11 AM Subject: Kolb-List: Affordable Safety ! Insurance question? As a Private Pilot can I insure my Experimental aircraft ELSA Kolb Firestar II for hull damage, but more importantly, for liability damage to people and all things on the ground. I have yet to check on this very important point, if so how much can I expect to pay? Thanks in advance Dennis -------- ?~?~Beware of false knowledge; it is more dangerous than ignorance.?T?T George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321383#321383 ________________________________________________________________________________
Subject: Kolb Aircraft Insurance
Date: Nov 28, 2010
Insurance question? Dennis Here is the url for EAA insurance: http://www.eaa.org/insurance/ Forgot to paste it in previous. ;-( Getting old ain't easy. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: any kolbers west coast canada
Date: Nov 28, 2010
looking for some kolb hours, any kolbers west coast Canada or PNW in general? I live Vancouver Island ! Cheers, Sean :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321398#321398 ________________________________________________________________________________
Date: Nov 28, 2010
John, A couple things.First,how long are the springs on the Titan exhaust.If they are close to the Rotax 1-5/8 I think,you can get stainless springs from JB M that are forever.Second,get Miss P'fer washed because Rick wants to have a get together in FLA.again this year and we will give you fair warning thi s time .Good to see you back in the air. G.Aman MK-3C Jabiru 2200A 600hrs Hopefully in Lakeland by Dec. -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Sat, Nov 27, 2010 7:10 pm Subject: Kolb-List: First Flight Hi Folks: First flight today. Well, first flight since the first of May 2010, for my MKIII and me. All went well. I haven't forgotten how to aviate, neither has Miss P'fer. I got 1.2 hours today. Miss P'fer has 3,010.9 hours on he r airframe and 441.4 hours on her 912ULS. The airplane flew well, despite al l the barn dust, bird and bug crap, and dirt dauber nests. Got about a half teaspoon of water out of the fuel tank before the first flight. Both carb float bowls were dry with evidence that there had been a little moisture in each of them. Engine fired right up and ran like a top. While she was sitting for so long, she had two Titan exhaust springs break. First time I have had exhaust springs break when the engine was not running . Must say it was good to get back into the air again. I am looking forward to making some long flights this year. The only one I got last year was a flight down to Sun and Fun in Lakeland, Florida. I had my doubts if I was going to be able to make the flight to Monument Valley next year, but after today's flight, I think it is doable. Reckon she will really fly good if I get a warm spell so I can wash her. Maybe tomorrow. john h Titus, Alabama ________________________________________________________________________________
Date: Nov 28, 2010
A couple things.First,how long are the springs on the Titan exhaust.If they are close to the Rotax 1-5/8 I think,you can get stainless springs from JBM that are forever.Second,get Miss P'fer washed because Rick wants to have a get together in FLA.again this year and we will give you fair warning this time .Good to see you back in the air. G.Aman MK-3C Jabiru 2200A 600hrs Hopefully in Lakeland by Dec. G.Aman/Gang: They seem to be a little longer than the Rotax springs. I put a couple Rotax springs on it yesterday to fly. They were stretched pretty tight. I'll have to measure the gap between the hooks to decide on the size spring I need. Do you have a url for "JBM"? I can not find them with a Google search. Set a date and get some good weather. I'll be ready to go. Anywhere in Florida is less than a one day flight, normally... john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 28, 2010
jbmindustries(at)att.net Gary Jindra --- On Sun, 11/28/10, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: First Flight Date: Sunday, November 28, 2010, 1:08 PM - - G.Aman/Gang: - - Do you have a url for "JBM"?- I can not find them with a Google search. - john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 28, 2010
this will work mo betta: http://jbmindustries.com/ BB On 28, Nov 2010, at 2:41 PM, GARY JINDRA wrote: > > jbmindustries(at)att.net > > > Gary Jindra > > > --- On Sun, 11/28/10, John Hauck wrote: > > From: John Hauck <jhauck(at)elmore.rr.com> > Subject: Re: Kolb-List: First Flight > To: kolb-list(at)matronics.com > Date: Sunday, November 28, 2010, 1:08 PM > > > > G.Aman/Gang: > > > Do you have a url for "JBM"? I can not find them with a Google search. > > john h > mkIII > Titus, Alabama > > > ollow target=_blank>www.aeroelectric.com > /" rel=nofollow target=_blank>www.buildersbooks.com > ofollow target=_blank>www.homebuilthelp.com > llow target=_blank>http://www.matronics.com/contribution > =nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List > et=_blank>http://forums.matronics.com > > ________________________________________________________________________________
Date: Nov 28, 2010
sorry about that,that was his email.the .com is correct Gary Jindra --- On Sun, 11/28/10, robert bean wrote: From: robert bean <slyck(at)frontiernet.net> Subject: Re: Kolb-List: First Flight Date: Sunday, November 28, 2010, 3:52 PM this will work mo betta: http://jbmindustries.com/ BB On 28, Nov 2010, at 2:41 PM, GARY JINDRA wrote: jbmindustries(at)att.net Gary Jindra --- On Sun, 11/28/10, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: First Flight Date: Sunday, November 28, 2010, 1:08 PM - - G.Aman/Gang: - - Do you have a url for "JBM"?- I can not find them with a Google search. - john h mkIII Titus, Alabama ollow target=_blank>www.aeroelectric.com /" rel=nofollow target=_blank>www.buildersbooks.com ofollow target=_blank>www.homebuilthelp.com llow target=_blank>http://www.matronics.com/contribution =nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List et=_blank>http://forums.matronics.com ________________________________________________________________________________
Date: Nov 28, 2010
John, His web site,JBM industries.com.He makes rubber products,carb sockets etc t hat are less expensive and far outlast anything on the market.I fly with hi m all summer -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Sun, Nov 28, 2010 1:11 pm Subject: Re: Kolb-List: First Flight A couple things.First,how long are the springs on the Titan exhaust.If the y are close to the Rotax 1-5/8 I think,you can get stainless springs from J BM that are forever.Second,get Miss P'fer washed because Rick wants to have a get together in FLA.again this year and we will give you fair warning th is time .Good to see you back in the air. G.Aman MK-3C Jabiru 2200A 600hrs Hopefully in Lakeland by Dec. G.Aman/Gang: They seem to be a little longer than the Rotax springs. I put a couple Rot ax springs on it yesterday to fly. They were stretched pretty tight. I'll have to measure the gap between the hooks to decide on the size spring I n eed. Do you have a url for "JBM"? I can not find them with a Google search. Set a date and get some good weather. I'll be ready to go. Anywhere in Fl orida is less than a one day flight, normally... john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 28, 2010
His web site,JBM industries.com.He makes rubber products,carb sockets etc that are less expensive and far outlast anything on the market.I fly with him all summer Thanks, Gary/Gang: I ordered 6 each from him tonight. I'll stick the two extras in the airplane just in case they are not quite as good as you guys say they are. ;-) Thanks for the info. Got another .7 late this afternoon. Recalibrated my airspeed indicator. Feels better to be indicating 85 mph cruise at 5,000 than 90 mph. Now is indicating 38 mph stall clean and 30 mph stall at 30 mph. Shooting my approaches at 50 mph is comfortable. For Tom Kuffle: I was wrong when I said my 912ULS indicates 2,500 to 3,000 rpm with the throttle closed gliding. It is more like 2,000 rpm. It idles 1,600 rpm on the ground static. Pulling the nose up to 35 mph from 5,000 rpm cruise, not touching the throttle, she was climbing 1,800 fpm at 1,500 msl with about 1/2 tank (12.5 gal) fuel. That was clean of course. Thought the engine oil temp gauge had gone belly up on me while flying. On the ground I discovered I had knocked the clip loose from the oil temp sender. The stiffness of the wire was holding it up againt the contact, but it was not clipped on. Was ready to buy a new sender or gauge. john h mkIII Titus, Alabama ========== tor?Kolb-List">http://www.matronics.com/Navigator?Kolb-List ========== tp://forums.matronics.com ========== ________________________________________________________________________________
Date: Nov 28, 2010
Got another .7 late this afternoon. Recalibrated my airspeed indicator. Feels better to be indicating 85 mph cruise at 5,000 than 90 mph. Now is indicating 38 mph stall clean and 30 mph stall at 30 mph. Shooting my approaches at 50 mph is comfortable. Hi Gang: I need to proof read my msgs before I hit the send button, instead of proofing them when they come up on the Kolb List. "Feels better to be indicating actual airspeed rather than 5 mph plus. Today it was cruising 85 mph at 5,000 rpm instead of 90 mph at 5,000 like it was yesterday. Now it is indicating 38 mph clean stall and 30 mph stall with full flaps. Shooting approaches at 50 mph indicated is comfortable and more familiar to me." john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: rotax 582 and firestar 2 question
Date: Nov 28, 2010
Frst off thx for a very informative site here. I recently obtained my advanced ultralight pilot permit here in Canada which is very similar to your lightsport in the united states. Ideally for me a Kolb Mark 3 xtra with a mono float and 912s would do the trick ! Can someone lend me $15000 - $20000 ? In the event that the xtra cash doesnt materialize plan B is a firestar 2 with a Full Lotus monofloat ! My question is why I dont see very many firestars with 582's and what the pro's here think the difference will be between the 2 engines with the mono float application ? Cheers, Sean Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321453#321453 ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Re: rotax 582 and firestar 2 question
At 07:44 PM 11/28/2010, sean wrote: >My question is why I dont see very many firestars with 582's and what the >pro's here think the difference will be between the 2 engines with the >mono float application ? My friend has a FSII with a 503 and it's delightful, great performance (on wheels). He put Full Lotus amphib floats (two floats, not the monofloat) on it and said it flies like a cinder block. I only flew it with wheels, and it makes me (as a Cuyuna powered UltraStar owner) jealous. Without float, it doesn't _need_ a 582. -Dana -- Chaste: why virgins run. ________________________________________________________________________________
Date: Nov 28, 2010
The main problem with a 582 is that it burns about 5.5 gallons of gas an hour while only producing 65 hp. The extra weight is a problem as well. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Nov 28, 2010
The reason you don't see many FSII's with 582's is because the vertical fuselage tubes at the back end of the cage were not designed to take the extra torque the 582 makes. When I was talking to the guys at Kolb several years ago prior to putting together our 582 powered FSII, they told me that if I hit a sharp thermal or turbulence in a full throttle climb, they couldn't guarantee that the tubes at the rear of the cage (supporting the motor mounts and rear spar carrythrough) would maintain integrity, because they were of a lesser wall thickness than the MKIII tubes. Which would probably result in the classic slow cars and sad music ceremony. So that is why the motor mounts on N582EF have extra braces on them independent of the normal upper rear cage structure. And all is good. And for Larry: compare the weight between the 503 and the 582. Quite an eye opener. According to the CPS "Rotax Engine Comparisons" on page 27 of my 2005 catalog, the 503 with C box, dual carbs and electric start is 113.9 pounds. The 582 with the same stuff plus radiator is 110.6. After you add coolant, they will not be different enough to matter. The bonus comes at cruise, N582EF in it's previous incarnation cruised at 60 mph at 3 GPH at 4800 rpm. This time around it's a bit slicker. And for those who think Rotax 2-strokes must be run at 5800 rpm, um... can't do it - the airspeed is pushing redline by that point. So you can only use the extra power in climb, but at cruise, a loafing engine becomes a very good (and quiet) thing. Richard Pike MKIII N420P (420ldPoops) And for a bonus - was planning to wait a few days until the final touches were done, but today we had it all together getting ready for the inspector and a couple more details, so took a few pictures and here she is. Before and after pictures. Haven't even pulled the plastic sheet off the Lexan yet... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321470#321470 Attachments: http://forums.matronics.com//files/1_837.jpg http://forums.matronics.com//files/p1130313_large_213.jpg http://forums.matronics.com//files/p1180917_large_933.jpg ________________________________________________________________________________
Date: Nov 29, 2010
Subject: Make Sure You're Listed!
Dear Listers, The List of Contributors (LOC) is just around the corner with just two more days in this year's Fund Raiser! Later in December I will post a list of everyone that so generously made a Contribution to support the Lists this year. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2010
"Don't think insurance buys an aviator "affordable safety"." I could not agree more, it was was a poor choice of words. Thanks for the link of EAA. Dennis -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321601#321601 ________________________________________________________________________________
Date: Nov 29, 2010
Dennis, I have a Firestar II, and it's insured for hull & liability thru EAA/Falcon. For insurance purposes I have the plane valued at $28K, and I have $500K liability coverage. I don't get the deal John does, but I don't have his experience either. Mine costs $1350/yr, I that was based on 350 hrs in the plane & 410 hrs total, and hangared inside. It's pretty easy to get if you are ready to write the check. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321611#321611 ________________________________________________________________________________
Subject: Firestar for sale
Date: Nov 29, 2010
Hi guys, It is with an extremely heavy heart that I must sell my Firestar. I have put 2.5 hours on it since the tailboom replacement and it flies like a dream. If anyone is interested please call me at 405-426-2014 or email me off list at camp405(at)gmail.com and I will give you all the details. Thanks Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321613#321613 Attachments: http://forums.matronics.com//files/kolb_122.jpg ________________________________________________________________________________
Subject: Fw: Kolb Construction Videos
Date: Nov 29, 2010
Hi Folks: Travis asked me to forward the following Kolb Aircraft videos with the Kolb List. He also told me the company is doing well. They are building and selling Kolbs. Kolb Aircraft is oriented to building Kolb kits the way Homer Kolb did it, integrating improvements of the kit without changing the type kit and purpose of Homer's designs. http://www.youtube.com/watch?v=ORocgOyFuRk http://www.youtube.com/watch?v=Nfa8GN208s4&feature=related http://www.youtube.com/watch?v=c4pS8vEERKg&feature=related http://www.youtube.com/watch?v=yh0RNJjLPRE&feature=related john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Rotax 912 Idle
Date: Nov 29, 2010
John Hauck said: << 912ULS indicates 2,500 to 3,000 rpm with the throttle closed gliding. It is more like 2,000 rpm. It idles 1,600 rpm on the ground static. >> My Zenith CH701 friend has a 912S. It has the characteristic on the ground of stopping when the throttle is pulled to full idle. As his friendly Flight Advisor I find this worrisome if not downright unsafe. I've tried to get him to increase his idle stop screws but he views it as a deliberate design "feature" to replace the absent mixture idle cutoff. Any comments or experience to assuage my fears or convince him of the error of his ways? Tom Kuffel Whitefish, MT ________________________________________________________________________________
Subject: Re: Rotax 912 Idle
Date: Nov 29, 2010
My Zenith CH701 friend has a 912S. It has the characteristic on the ground of stopping when the throttle is pulled to full idle. As his friendly Flight Advisor I find this worrisome if not downright unsafe. I've tried to get him to increase his idle stop screws but he views it as a deliberate design "feature" to replace the absent mixture idle cutoff. Any comments or experience to assuage my fears or convince him of the error of his ways? Tom Kuffel Whitefish, MT Tom K/Gang: The 912 operators manual indicates the idle speed to be 1,400 rpm minimum. No mention of "deliberate design feature to replace the absent mixture idle cutoff." I believe if Rotax wanted a mixture idle cutoff, they would have equipped the 912 with a mixture control. Never lost a 912 with the throttle closed during an approach, and don't want to. For that matter, never had a 912 quit running in flight, except when I screwed up and tried to fly with contaminated fuel. I didn't know the fuel was contaminated because I did not drain fuel after I obtained it from an unreliable source, even though I thought, at the time, both places were reliable aviation fuel suppliers. I have found with my one 912UL and two 912ULS's, they all like to idle around 1,500 to 1,600 rpm. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Pneumatic tail wheel for FS-2
Date: Nov 29, 2010
Jimmy, Thanks for sharing the pictures! Mahesh FS-2 -Ashland,OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321653#321653 ________________________________________________________________________________
Date: Nov 29, 2010
John, Good to see you back in the air. Roger did mention that you were healing, but the best healing is in the air :-)) :P Wish you wonderful flights ahead! Mahesh FS-2, Ashland,OR "The joy of flight....nothing comes closer....It's a romance for life!" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321654#321654 ________________________________________________________________________________
Date: Nov 29, 2010
Subject: kolbs in michigan
my wife and-I are heading up the cub club flyout to sun fun 2011 any kolb ers =0Athat want to tag along- or- maybe leade- should- call--m e- -mal=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM- A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A________________________________ =0AFrom: miyer2u <miyer2u(at)yahoo.com>=0ATo: kolb-list(at)matronics.com=0ASent: Mon, November 29, 2010 7:02:05 PM=0ASubject: Kolb-List: Re: First Flight=0A ,=0AGood to see you back in the air. Roger did mention that you were healin g,=0Abut the best healing is in the air :-))- :P =0A=0AWish you wonderful flights ahead!=0A=0AMahesh=0AFS-2, Ashland,OR=0A"The joy of flight....noth ing comes closer....It's a romance for life!"=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=321654#321 =========================0A ==0A=0A=0A ________________________________________________________________________________
Subject: HKS Engine on a KF
Date: Nov 29, 2010
I was not aware this HKS700e engine was being used on a Kolb Firestar. "Here are some photos and a video of my Kolb Firestar with HKS engine. The aircraft is being flown from my 600 foot pasture air strip at the 4,000 foot level on the west slope of Mauna Kea on the "Big Island" of Hawaii. The engine is running well. Regards, Dave Bigelow" http://www.youtube.com/watch?v=wbrTNuS9yVY -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321682#321682 ________________________________________________________________________________
Date: Nov 30, 2010
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means at least two things. For better or worse, its my 47th birthday! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been drooling over one of the really nice gifts that are available this year with a qualifying Contribution, then now is the time to jump on one!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. Hopefully everyone feels the same. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Kolb Construction Videos/Testing Your New MKIII
Date: Nov 30, 2010
My plane is "near" finished. Mike Welch Mike W/Gang: Was curious how your power plant and reduction drive development are progressing. Have you made any test runs with your new engine? john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Slingshot thrust line/angle/HKS
Date: Nov 30, 2010
I completed the installation of the new 72" 3 blade Warp drive prop last week and was able to get about 2.5 hours of flying in over the weekend. Daryl recommended 13 or 14 degree initial pitch, I set it for 13, which had the motor at red line(6200 two minute) on full climb. The overall impression I got was very positive, climb was around 900-1000fpm+ and the max continuos speed was around 80, but this was on a non standard day, about 40 degrees F. I believe resetting the prop to 14 degrees will give me a better cruise and only take away a little climb. A few surprises I encountered were how much smoother the longer prop was and even felt quieter overall. Also the higher thrust line required by turning the gear box around had no ill affects on the stick pressure at higher RPM's. Just a couple more notes for the record. The ridiculous claims of fuel burn in the 2.25-2.5GPH are exactly what I am getting. I'm not sure I'll be able to fly off a tank (10 gal. usable) in one sitting, but look forward to trying. I forgot to mention this earlier, but the motor came with a MGL engine monitor included, and was found to be very inaccurate for RPM's. I installed a tiny tach and verified it with a hand held digital tach to find that the MGL reads 500RPM,s too high, and changing the program one step causes it to read 300 rpm's low, so moral of the story might be to verify your tach. My next order of business is to get heat to the cockpit for winter flying, which should not be too hard with the oil cooler mounted above the rear seat area. For those of you that have not landed on frozen lakes, it can be quite fun. Another 1st for me was winterizing and folding up the Firestar for storage. My hanger is too small to leave all three together. If you know anyone interested in a nice Firestar & trailer, feel free to email me. I'll probably advertise it in the spring. My work has finally slowed to a crawl, just in time for the winter. I am hoping to do some visiting down in Texas and SW Florida in the upcoming months, trying to find retirement properties and visit family, but mostly try to avoid cold and snow. Tom McCarthy N514 TM Zenith 601HD N414 TM Kolb Firestar N863 GB Kolb Slingshot ________________________________________________________________________________
Date: Nov 30, 2010
Lately, I've been building the three electronic circuits that go into the plane; the IvoProp current limiter circuit, the trim tab LED indicator circuit, and the Dynon AOA alarm detector LED circuit. I hear a soldering iron calling me...gotta run. Mike Welch Sounds like you are building a very busy airplane. Hope you get it finished soon. I am anxious to hear and see how it flies. john h mkiii Titus, Alabama ________________________________________________________________________________
Subject: Kolb Construction Videos/Testing Your New MKIII
Date: Nov 30, 2010
John=2C Busy?? Yeah=2C I guess you could say that. Some guys build planes as stripped as they can. They only want the bare essentials=2C and not an ounce more=2C and this is ok. Some guys build planes with lots of bells and whistles=2C the more the me rrier. They opt for more doo-dads=2C lights=2C switches and what-nots. I'm more i n this catagory. "To each his own"=2C as the saying goes. But what is most important is=3B we get to build what WE want. The (remaining) freedoms we have in this country allows us all to build our own plane=2C whether they be stripped as a kite=2C or crammed full of crap. In "experimental" airplanes=2C we can truly say "I did it MY way!!" Back to work=2C Mike From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Kolb Construction Videos/Testing Your New MKIII Date: Tue=2C 30 Nov 2010 10:02:17 -0600 Lately=2C I've been building the three electronic circuits that go into the plane=3B the IvoProp current limiter circuit=2C the trim tab LED indicator circuit =2C and the Dynon AOA alarm detector LED circuit. I hear a soldering iron calling me...gotta run. Mike Welch Sounds like you are building a very busy airplane. Hope you get it finished soon. I am anxious to hear and see how it flies. john h mkiii Titus=2C Alabama ________________________________________________________________________________
Date: Nov 30, 2010
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: HKS Engine on a KF
=C2- Dave- I've seen your plane before, and it still shows quite a bit of dihedral.=C2- Did you make it that way?=C2- How about cross winds? =C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2- Bill Sullivan =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2- Windsor Locks, Ct. =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-FS 447 --- On Tue, 11/30/10, Dennis Thate wrote: From: Dennis Thate <retroman(at)frontier.com> Subject: Kolb-List: HKS Engine on a KF Date: Tuesday, November 30, 2010, 12:42 AM I was not aware this=C2- HKS700e engine was being used on a Kolb Firestar . "Here are some photos and a video of my Kolb Firestar with HKS engine. The aircraft is being flown from my 600 foot pasture air strip at the 4,000 foo t level on the west slope of Mauna Kea on the "Big Island" of Hawaii. The e ngine is running well. Regards, Dave Bigelow" http://www.youtube.com/watch?v=wbrTNuS9yVY -------- =C3=A2=82=AC=CB=9C=C3=A2=82=AC=CB=9CBeware of false knowledge; it is more dangerous than ignorance.=C3=A2=82=AC=84=A2=C3=A2=82=AC=84 =A2 George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321682#321682 h -- EE Gifts!) on om =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. S WEB FORUMS - ________________________________________________________________________________
Date: Nov 30, 2010
They opt for more doo-dads, lights, switches and what-nots. I'm more in this catagory. "To each his own", as the saying goes. Mike Mike/Gang: Didn't intend to get you stirred up. Was only interested in how the engine/redrive project was progressing. I fully understand we have a lot of freedom in how we build our airplanes in the US. I guess I am from the other side of the spectrum. I try not to put anything into my airplane that is not necessary for safe and comfortable flight. The more stuff I cram in there, the more stuff can go wrong. As it is, when something fails/goes wrong, I am uncomfortable until I get it sorted out and working correctly again. I'd fly without a radio if it weren't for talking to my friends when I fly with them, and the safety of listening to other traffic and announcing my intentions when I land at "real" airports. Without the radio I could get by with a good set of noise attentuators instead of expensive ANR headsets. Loss of hearing is one of my major problems when it comes to communicating in my airplane. That is not going to be a problem though. I can do a lot of flying in the US without a radio. The only time I need a radio is to land at controlled airports in the US. However, if I ever get back to Canada I am going to have to have a radio to land at any of their uncontrolled airports where commercial/passenger carrying aircraft land. In that case, I could carry a handheld and headset until I got into Alaska. We are under a tornado warning here in Elmore County, Alabama. Guess I better keep an eye open and stay close to home today. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 30, 2010
Dave- I've seen your plane before, and it still shows quite a bit of dihedral. Did you make it that way? How about cross winds? Bill Sullivan Windsor Locks, Ct. FS 447 Bill S/Gang: Dave died in the crash several years ago in Hawaii, attempting to set a world altitude record in a motor glider. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 30, 2010
> The overall impression I got was very positive, climb was around 900-1000fpm+ and the max continuos speed was around 80, but this was on a non standard day, about 40 degrees F. Tom, That sounds like pretty good performance. I only get a climb rate of about 6-700 fpm on the Firestar, but that's enough for me to safely fly around here in the flatlands. Do you have the 3.47 - 1 gearbox or the 2.58? -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321810#321810 ________________________________________________________________________________
Date: Nov 30, 2010
- I forgot about that, John.- Sorry- probably the medication.- What h appened to that plane?- Still wondering about the dihedral.- That video gives me a little more confidence in my plan for a field up in Vermont.- I have around 700 feet by around 200 feet to play with, with a clean drop- off at both ends.- Lined up with the prevailing wind, too.- I have to h ave it cleared, filled, and graded.- The timber might pay for it. - ------------------------- ------------------ Bill Sullivan ------------------------- ------------------ --- On Tue, 11/30/10, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: HKS Engine on a KF Date: Tuesday, November 30, 2010, 12:01 PM - Dave- I've seen your plane before, and it still shows quite a bit of dihedral.- Did you make it that way?- How about cross winds? - - - - - - - - - - - - - - - - - - - - - - Bill Sullivan - - - - - - - - - - - - - - - - - - - - - - Windsor Locks, Ct. - - - - - - - - - - - - - - - - - - - - - - FS 447 Bill S/Gang: Dave died in the crash several years ago in Hawaii, attempting to set a world altitude record in a motor glider. john h mkIII Titus, Alabama le, List Admin. ________________________________________________________________________________
Date: Nov 30, 2010
I would be curious to know what became of this plane and HKS engine, Anyone know ? BTW.. This is a great website with great feedback, for a Kolb rookie like myself who has some catching up to do. Of all the times I ran in to Homer at Oshkosh I wished I had taken the time to take a snapshot. -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321824#321824 ________________________________________________________________________________
Date: Nov 30, 2010
Subject: Construction
I realize that each Kolb built it the builder's experiment and you have the right to do as you wish, but you might want to consider this. The two things missing in the construction videos are: 1) No sign of any sort of corrosion protection on all that bare aluminum, and 2) no drain grommets or any way for water to get out of the covering. I know there will be comments from those who've never seen corrosion, or who don't believe in it, but the pictures show what condensation inside the wing of a 15 year old Firestar did to the aluminum. As Poor Richard said, "an ounce of prevention is worth a pound of cure". If you think alodining new aluminum and painting with epoxy before covering is a PITA, add hours and hours of drilling out rivets, sanding and inspecting with a magnifying glass to the point of eyestrain, THEN acid etching, alodining, painting and reassembling for which you get more pains than just those in the posterior. I didn't invent this, it's all right there in the Poly Fiber manual, so do as you think best. Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Re: Construction
Date: Nov 30, 2010
Rick, was this Firestar stored in a trailer? I've heard that corrosion like this can happen when the aircraft is stored in a trailer. I have a 24 year old Firestar and I'm sure there isn't any corrosion on it and I store it in a garage. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 23 years flying it Kolbra 912UL N20386 2 years flying it 120 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321829#321829 ________________________________________________________________________________
Date: Nov 30, 2010
Ralph, I've only owned it for four years so I can't say. The fellow I bought it from had it stored in a workshop when I picked it up. Rick On Tue, Nov 30, 2010 at 2:16 PM, Ralph B wrote: > > Rick, was this Firestar stored in a trailer? I've heard that corrosion like > this can happen when the aircraft is stored in a trailer. I have a 24 year > old Firestar and I'm sure there isn't any corrosion on it and I store it in > a garage. > > Ralph B > > -------- > Ralph B > Original Firestar 447 > N91493 E-AB > 1000 hours > 23 years flying it > Kolbra 912UL > N20386 > 2 years flying it > 120 hrs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321829#321829 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Nov 30, 2010
The climate you have it in has a lot to do with it. I doubt owners in northern VT have a lot of corrosion problems. Dry in the summer and zero corrosion in the bitter cold due to retarded chemical activity. Personally I'm happy my wings have no access holes. there are no moving parts to inspect and no problems with bees, mice, chipmunks and hickory nuts within. The fuselage is in the basement for now but I am planning on a varmint free steel barn within the next two years. BB On 30, Nov 2010, at 3:54 PM, Richard Girard wrote: > Ralph, I've only owned it for four years so I can't say. The fellow I bought it from had it stored in a workshop when I picked it up. > > Rick > > On Tue, Nov 30, 2010 at 2:16 PM, Ralph B wrote: > > Rick, was this Firestar stored in a trailer? I've heard that corrosion like this can happen when the aircraft is stored in a trailer. I have a 24 year old Firestar and I'm sure there isn't any corrosion on it and I store it in a garage. > > Ralph B > > -------- > Ralph B > Original Firestar 447 > N91493 E-AB > 1000 hours > 23 years flying it > Kolbra 912UL > N20386 > 2 years flying it > 120 hrs > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321829#321829 > > > > > > > > ========== > ="_blank">www.aeroelectric.com > ooks.com" target="_blank">www.buildersbooks.com > et="_blank">www.homebuilthelp.com > ="_blank">http://www.matronics.com/contribution > le, List Admin. > ========== > arget="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > http://forums.matronics.com > ========== > > > > > > > -- > Zulu Delta > Kolb Mk IIIC > 582 Gray head > 4.00 C gearbox > 3 blade WD > Thanks, Homer GBYM > > It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. > - G.K. Chesterton > > > > ________________________________________________________________________________
Date: Nov 30, 2010
Thanks all for the " heads up" and Richard ... NICE JOB ... VERY NICE JOB ... U-tube U-tube U-tube !!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321839#321839 ________________________________________________________________________________
Subject: Re: Kolb Firestar Winter storage
Date: Nov 30, 2010
I found this excellent video on Winter Storage of Rotax Aircraft engines. http://www.mefeedia.com/watch/26641749 -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321841#321841 ________________________________________________________________________________
Date: Nov 30, 2010
I forgot about that, John. Sorry- probably the medication. What happened to that plane? Still wondering about the dihedral. That video gives me a little more confidence in my plan for a field up in Vermont. I have around 700 feet by around 200 feet to play with, with a clean drop-off at both ends. Lined up with the prevailing wind, too. I have to have it cleared, filled, and graded. The timber might pay for it. Bill Sullivan Bill S/Gang: I started flying off 600 feet in my Ultrastar 26 years ago. Stretched the field to 750 feet, flying the Firestar, with no brakes, and the MKIII with passenger, off it. Fairly good approach and departure. Elevation 410 MSL. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 30, 2010
BTW, I do agree with you re: stuff to break. The stuff I'm adding isn't stuff that causes the plane to become a glider. They're mainly for my enjoyment, just fancy lights and stuff like that. Cheers, Mike Mike W/Gang: To me, if an item is installed on the airplane and decides not to work, it is an item of concern and will bug me until I get it operational again. It doesn't have to be a flight essential item. An item that is non flight essential, if inop, is still a source of concern (worry) on my airplane, e.g., landing light, position light, strobe light, etc. The tornados passed us by but left us with a lot of rain. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Kolb Firestar Fuel consumption
Date: Nov 30, 2010
For trip planning purposes I'm curious about what kind of fuel consumption I can expect to get with my 503 DCDI Rotax on my 2006 Kolb Firestar II. I typically will be at gross weight and at 2000 ' msl. Ball Park Figures Thanks Dennis -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321887#321887 ________________________________________________________________________________
Date: Dec 01, 2010
Dennis, I burn between 3 and 3 1/2 gal per hour. My cruise RPM is 5600 to 5800. Lanny FSII 503 DCDI ________________________________________________________________________________
Date: Dec 01, 2010
I absolutely agree with you on this. Every piece of aluminum in my plane has been corrosion proofed with the epoxy paint recommended in the poly fiber manual. Its easy to think everything is alright when you can't see it. Rick Lewis -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321906#321906 Attachments: http://forums.matronics.com//files/pic00005_182.jpg ________________________________________________________________________________
Date: Dec 01, 2010
6061-T6 does not need corrosion protection in most applications..It has its own oxidized layer that protects over time.. I would only be concerned if I were flying near salt water... I rebuilt an Ultrastar that had steel rivets and found everything to be in good order...20 some odd years later...it had been on floats at one time.. Herb At 07:41 AM 12/1/2010, you wrote: > >I absolutely agree with you on this. Every piece of aluminum in my >plane has been corrosion proofed with the epoxy paint recommended in >the poly fiber manual. Its easy to think everything is alright when >you can't see it. > >Rick Lewis > >-------- >Rick Lewis > >(VW Watercooled Engine) > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=321906#321906 > > >Attachments: > >http://forums.matronics.com//files/pic00005_182.jpg > > ________________________________________________________________________________
Date: Dec 01, 2010
Subject: Corrosion
I understand that you can`t see the corrosion (if any) on the wing spars, without inspection plates. However, I would think if you had the same amount of corrosion, shown on the gusset in the picture, you could see it though the fabric. I know my fabric is adhered pretty tight to most of my gussets. I would also like to know if the aircraft parts pictured, were outside,exposed to weather most of their lives or near a salt water environment. Anyone have any thoughts about that. Lanny N598LF ________________________________________________________________________________
Date: Dec 01, 2010
Herb, No offense, but that's an old wives tale. 6061-T6's silicon alloy base makes it more resistant to corrosion than a copper based alloy like 2024-T3, but it doesn't give any magical powers. All aluminum gets an oxide layer the second it's exposed to oxygen and it does slow corrosion after that, but inside a sealed wing with a condensation cycle every day, unless of course you're Kolb is somewhere near Davis-Monthan AFB, provides all that's necessary for corrosion to continue. My Firestar came from mid Pennsylvania and now it's in Kansas. Not a lot of salt water around here. Rick On Wed, Dec 1, 2010 at 7:57 AM, Herb wrote: > > 6061-T6 does not need corrosion protection in most applications..It has its > own oxidized layer that protects over time.. I would only be concerned if I > were flying near salt water... > > I rebuilt an Ultrastar that had steel rivets and found everything to be in > good order...20 some odd years later...it had been on floats at one time.. > Herb > > > At 07:41 AM 12/1/2010, you wrote: > >> >> I absolutely agree with you on this. Every piece of aluminum in my plane >> has been corrosion proofed with the epoxy paint recommended in the poly >> fiber manual. Its easy to think everything is alright when you can't see >> it. >> >> Rick Lewis >> >> -------- >> Rick Lewis >> >> (VW Watercooled Engine) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=321906#321906 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/pic00005_182.jpg >> >> >> >> >> > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 01, 2010
Subject: Re: Corrosion
Lanny, The aircraft came from the middle region of Pennsylvania and has been in Kansas the last four years. The pictures were what I found when I took off the covering after I found that it had been done wrong, i.e. no PolySpray for UV protection and the cloth failed the 50 lb. test. No, even with no PolySpray silver coat, and no PolyBrush evident except where the tapes were applied, the White PolyTone hid even the rusted rivet heads. If I could have seen it through the cloth I would not have bought the aircraft. Rick On Wed, Dec 1, 2010 at 8:05 AM, Lanny Fetterman wrote: > > I understand that you can`t see the corrosion (if any) on the wing spars, > without inspection plates. However, I would think if you had the same amount > of corrosion, shown on the gusset in the picture, you could see it though > the fabric. I know my fabric is adhered pretty tight to most of my gussets. > I would also like to know if the aircraft parts pictured, were > outside,exposed to weather most of their lives or near a salt water > environment. Anyone have any thoughts about that. Lanny N598LF > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Re: Kolb Firestar Fuel consumption
Date: Dec 01, 2010
In the range of 15-18 mpg with no winds for a 2-stroke Firestar depending upon how hard you push it. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321921#321921 ________________________________________________________________________________
Date: Dec 01, 2010
Subject: Corrosion
middle region of Pennsylvania Rick, Jeesh, that`s where I live! Say it ain`t so! :-( Lanny N598LF ________________________________________________________________________________
Date: Dec 01, 2010
It may have been stored outside under a tarp. The tarp can hold moisture in working on the metal 24/7. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 23 years flying it Kolbra 912UL N20386 2 years flying it 120 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321930#321930 ________________________________________________________________________________
Date: Dec 01, 2010
I use cruise RPM of 6000 and always use 4 gal per hour for my fuel consumption....have not run out of fuel yet....in rough air I slow it down, makes the ride more enjoyable and less stress on the plane.....Jim Swan Note: have put the plane away for the winter, was going to fly it on good days but had change of plans, looks like I may have them put me in a replacement knee this winter.. Do not archive FIRESTAR ll 503 Michigan jswan GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825 ph. 517-663-8488 ________________________________________________________________________________
Date: Dec 01, 2010
Pretty much my point, Ralph. What's the difference to the aluminum if it's a tarp or the polyester covering? Rick On Wed, Dec 1, 2010 at 10:51 AM, Ralph B wrote: > > It may have been stored outside under a tarp. The tarp can hold moisture in > working on the metal 24/7. > > Ralph > > -------- > Ralph B > Original Firestar 447 > N91493 E-AB > 1000 hours > 23 years flying it > Kolbra 912UL > N20386 > 2 years flying it > 120 hrs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321930#321930 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 01, 2010
At 10:22 AM 12/1/2010, Richard Girard wrote: >Herb, No offense, but that's an old wives tale. 6061-T6's silicon alloy >base makes it more resistant to corrosion than a copper based alloy like >2024-T3, but it doesn't give any magical powers. All aluminum gets an >oxide layer the second it's exposed to oxygen and it does slow corrosion >after that, but inside a sealed wing with a condensation cycle every day, >unless of course you're Kolb is somewhere near Davis-Monthan AFB, provides >all that's necessary for corrosion to continue. >My Firestar came from mid Pennsylvania and now it's in Kansas. Not a lot >of salt water around here. Still, that seemed like _really_ bad corrosion! I have what's left of a project that started out as an ultralight in 1980, then a trailer some years later, that's sat outside my house for 23 years, laying on the ground, getting rained on. All 6061 tubing and AN bolts; it's still nowhere near as bad as that. -Dana -- Beam me up, Scotty, it ate my phaser. ________________________________________________________________________________
Date: Dec 01, 2010
My other point was that I have rebuilt an Ultrastar and a MkIII ...91 MkIII and an older Us. No Corrosion...Herb At 09:22 AM 12/1/2010, you wrote: >Herb, No offense, but that's an old wives tale. 6061-T6's silicon >alloy base makes it more resistant to corrosion than a copper based >alloy like 2024-T3, but it doesn't give any magical powers. All >aluminum gets an oxide layer the second it's exposed to oxygen and >it does slow corrosion after that, but inside a sealed wing with a >condensation cycle every day, unless of course you're Kolb is >somewhere near Davis-Monthan AFB, provides all that's necessary for >corrosion to continue. >My Firestar came from mid Pennsylvania and now it's in Kansas. Not a >lot of salt water around here. > >Rick > >On Wed, Dec 1, 2010 at 7:57 AM, Herb ><herbgh(at)nctc.com> wrote: ><herbgh(at)nctc.com> > >6061-T6 does not need corrosion protection in most applications..It >has its own oxidized layer that protects over time.. I would only >be concerned if I were flying near salt water... > > I rebuilt an Ultrastar that had steel rivets and found everything > to be in good order...20 some odd years later...it had been on > floats at one time.. Herb > > >At 07:41 AM 12/1/2010, you wrote: ><cktman(at)hughes.net> > >I absolutely agree with you on this. Every piece of aluminum in my >plane has been corrosion proofed with the epoxy paint recommended in >the poly fiber manual. Its easy to think everything is alright when >you can't see it. > >Rick Lewis > >-------- >Rick Lewis > >(VW Watercooled Engine) > > >Read this topic online here: > ><http://forums.matronics.com/viewtopic.php?p=321906#321906>http://forums.matronics.com/viewtopic.php?p=321906#321906 > > >Attachments: > ><http://forums.matronics.com//files/pic00005_182.jpg>http://forums.matronics.com//files/pic00005_182.jpg > > >========== >om" target="_blank">www.aeroelectric.com >ooks.com" target="_blank">www.buildersbooks.com >et="_blank">www.homebuilthelp.com >="_blank">http://www.matronics.com/contribution >le, List Admin. >========== >arget="_blank">http://www.matronics.com/Navigator?Kolb-List >========== >http://forums.matronics.com >========== > > >-- >Zulu Delta >Kolb Mk IIIC >582 Gray head >4.00 C gearbox >3 blade WD >Thanks, Homer GBYM > >It is not bigotry to be certain we are right; but it is bigotry to >be unable to imagine how we might possibly have gone wrong. > - G.K. Chesterton > > ________________________________________________________________________________
Date: Dec 01, 2010
Rick, What is the procedure you used for corrosion proofing the inside of the aluminum tubing used on a Kolb? Gene On Dec 1, 2010, at 8:41 AM, Rick Lewis wrote: > > I absolutely agree with you on this. Every piece of aluminum in my plane has been corrosion proofed with the epoxy paint recommended in the poly fiber manual. Its easy to think everything is alright when you can't see it. > > Rick Lewis > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321906#321906 > > > > > Attachments: > > http://forums.matronics.com//files/pic00005_182.jpg > > > > > > > ________________________________________________________________________________
Subject: Kolb Firestar II for sale in Florida.
Date: Dec 01, 2010
Hey all, just figured id post this up here. Its located in west palm beach, details in the ad. It has been a joy to fly. Thanks! http://www.barnstormers.com/classified_496085_KOLB+FIRESTAR+II.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321955#321955 Attachments: http://forums.matronics.com//files/1_332.jpg ________________________________________________________________________________
Date: Dec 01, 2010
What is the procedure you used for corrosion proofing the inside of the aluminum tubing used on a Kolb? Gene Gang: Back in the old days, Kolb used carbon steel rivets with carbon steel mandrels. They loved to rust. I built my Ultrastar with carbon rivets and learned soon how quickly they developed rust. When I built my FS, I got Little Mike, Old Kolb Part Man, to get me SS pop rivets to build the FS Kit. They worked much better, but they still used carbon steel mandrels. I used to put a blob of Stitts 2 part expoxy on the heads, but could do nothing with the tails of the rivets. However, this has never been a problem. I am flying a MKIII I built in 1991, and has been flying since 1992. That's a lot of hanger time, and a lot of time out under the stars and rain/dew when I am flying overnight or longer cross country flights. I haven't had a problem with corrosion. My understanding was most aircraft aluminum is "alclad". That is a thin coat of pure aluminum. If you get aluminum that is not "alclad", it is more prone to corrode. Based on the photos Rick G sent to the List of his Kolb project he picked up in PA, I would have left it right where I found it. Never seen anything in the junk pile out side that looked that bad, except when rodents peed on the aluminum. Rodent urine is highly corrosive, and they love Kolbs, especially the tailboom. Occasionally I shoot some anticorrosion spray into my tailboom to counteract rodent urine and water that gets in there from condensation, and also from occasionally washing the airplane. I am more concerned with the 4130 chromoly tubing. I have used tube seal in all three Kolbs I have built. I do have drain holes on wings, ailerons, horizontal stabilizers, elevators, upper and lower vertical stabilizers, and rudder. Don't know if they do more harm than good. They let out moisture, but allow dirt/mud daubers to come inside. I had some corrosion in the trailing edge tube of the left aileron when I rebuilt it in 2000. Undoubtedly, they have a lot of acid in their nests and larvae. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 01, 2010
In the range of 15-18 mpg with no winds for a 2-stroke Firestar depending upon how hard you push it. -------- Thom Riddle Thom R/Gang: How does the above convert to GPH? john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Adding additional fuel tanks =?ISO-8859-1?Q?=93?= Jump Seat
=?ISO-8859-1?Q?=93?= FS-2
Date: Dec 01, 2010
Dear Kolbers, To enable me to have longers XCs with out a fuel stop , I am planning to add two - Six gallon tanks to the rear of the FS-2 and move the existing two - five gallon tanks tanks to the jump seat. This will give me a total fuel capacity of 22 gallons. I have never carried a rear passenger and I weigh in at 195 pounds and have a Rotax -503. I surely plan to do Weights and Balance for the additional 24 pounds of fuel weight in the rear and 72 pounds fuel weight on the jump seat. I wanted to check and run it through the Kolb list whom I consider the list comprising of the Oracles to know if any of you have flown a passenger in the jump seat in a FS-2 and what are the changes that I should anticipate in handling of the airplane by adding the additional weight. Thanks much for your inputs in advance! Mahesh FS-2, Ashland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321959#321959 ________________________________________________________________________________
Date: Dec 01, 2010
Depends upon how fast you are going. He was asking about TRIP PLANNING so I figured I'd give a number that would give some idea of how FAR he might get on a gallon. He did not ask about endurance which is what GPH tells us. In any case, as you know, there are too many variables to give precise numbers for any of this. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321962#321962 ________________________________________________________________________________
Date: Dec 01, 2010
I use cruise RPM of 6000 and always use 4 gal per hour for my fuel consumption....have not run out of fuel yet....in rough air I slow it down, makes the ride more enjoyable and less stress on the plane.....Jim Swan Note: have put the plane away for the winter, was going to fly it on good days but had change of plans, looks like I may have them put me in a replacement knee this winter.. jswan Jim S/Gang: Always glad to see Jim posting to the Kolb List. I am going to make a special effort to fly to Michigan this coming year. I have not been up that way since I met John Williamson St Ignace Airport, Michigan, in 2003, on our way to Oshkosh. It was on that 2003 flight I flew over Rick N's old house and airstrip, but alas, no one was home. That night I camped out on Snuffy Smith's airstrip a couple hundred miles NE, I think. Alas again. Snuffy was not home either. The next night I spent in Gaylord, MI, with my Army Instructor Pilot that soloed me in the TH-55 helicopter at 10.0 hours, in 1968. This young CW2 was my hero. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 01, 2010
Depends upon how fast you are going. He was asking about TRIP PLANNING so I figured I'd give a number that would give some idea of how FAR he might get on a gallon. He did not ask about endurance which is what GPH tells us. In any case, as you know, there are too many variables to give precise numbers for any of this. -------- Thom Riddle Thom R/Gang: MPG in an airplane means nothing. Works good on the ground though. GPH and airspeed based on current winds gives me how far I can fly. The air is seldom static. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 01, 2010
John The only alclad aluminum that I know is 2024...It is considered to be a primary aircraft metal . .the core metal contains a fair amount of copper..The trick it to lay a pure sheet of aluminum over both sides of the ingot before it goes down the hot roll mill.. this bonds a very thin layer to the core metal... Guys with unpainted GA planes who like to polish will eventually wear the soft cladding of aluminum through... then it is time to paint...Herb 6061 is a high Maganese/Magnesium alloy...from memory..The outer surface corrodes into aluminum oxide which is hard and offers corrosion protection from the normal elements...meaning ,,,no mouse pee or salt water to name a couple.. At 03:11 PM 12/1/2010, you wrote: > > > What is the procedure you used for corrosion proofing the inside of the >aluminum tubing used on a Kolb? > >Gene > > >Gang: > >Back in the old days, Kolb used carbon steel rivets with carbon steel >mandrels. They loved to rust. > >I built my Ultrastar with carbon rivets and learned soon how quickly they >developed rust. > >When I built my FS, I got Little Mike, Old Kolb Part Man, to get me SS pop >rivets to build the FS Kit. They worked much better, but they still used >carbon steel mandrels. I used to put a blob of Stitts 2 part expoxy on the >heads, but could do nothing with the tails of the rivets. However, this has >never been a problem. I am flying a MKIII I built in 1991, and has been >flying since 1992. That's a lot of hanger time, and a lot of time out under >the stars and rain/dew when I am flying overnight or longer cross country >flights. > >I haven't had a problem with corrosion. My understanding was most aircraft >aluminum is "alclad". That is a thin coat of pure aluminum. If you get >aluminum that is not "alclad", it is more prone to corrode. > >Based on the photos Rick G sent to the List of his Kolb project he picked up >in PA, I would have left it right where I found it. Never seen anything in >the junk pile out side that looked that bad, except when rodents peed on the >aluminum. > >Rodent urine is highly corrosive, and they love Kolbs, especially the >tailboom. Occasionally I shoot some anticorrosion spray into my tailboom to >counteract rodent urine and water that gets in there from condensation, and >also from occasionally washing the airplane. > >I am more concerned with the 4130 chromoly tubing. I have used tube seal in >all three Kolbs I have built. > >I do have drain holes on wings, ailerons, horizontal stabilizers, elevators, >upper and lower vertical stabilizers, and rudder. Don't know if they do >more harm than good. They let out moisture, but allow dirt/mud daubers to >come inside. I had some corrosion in the trailing edge tube of the left >aileron when I rebuilt it in 2000. Undoubtedly, they have a lot of acid in >their nests and larvae. > >john h >mkIII >Titus, Alabama > > ________________________________________________________________________________
Date: Dec 01, 2010
Tom, That sounds like pretty good performance. I only get a climb rate of about 6-700 fpm on the Firestar, but that's enough for me to safely fly around here in the flatlands. Do you have the 3.47 - 1 gearbox or the 2.58? -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Jim, The motor came with the 3.47 gearbox, but wish it had the 2.58, If I was starting fresh. I believe the 2.58 with the gearbox down and a 66" 3 blade Warp on a Slingshot would work the best all things considered. I reserve the right to take that back after more testing, however. The Slingshot is a neat little plane. Anyone interested in owning one should understand that there are a few differences between it and a FS or MK3. First is the stall speed, in the high 40's, but still very Kolb like. The glide rate(or lack thereof) is something to get used to as well. It indicated around 700FPM descent at VY, but feels like even more. Also with the gear forward stance, it has close to 100lbs on the tail wheel, which makes it more of a hand full on the ground, and could easily make anyone look like a fool who does not pay attention on blacktop. These differences I've mentioned are not negative to me, just the opposite. I just wanted to let people know. I'm glad it was not my first Kolb. Tom McCarthy Fort Atkinson, WI N514 TM Zenith 601HD N414 TM Kolb Firestar N863 GB Kolb Slingshot ________________________________________________________________________________
Date: Dec 01, 2010
The only alclad aluminum that I know is 2024...It is considered to be a primary aircraft metal . .the core metal contains a fair amount of copper..The trick it to lay a pure sheet of aluminum over both sides of the ingot before it goes down the hot roll mill.. this bonds a very thin layer to the core metal... Guys with unpainted GA planes who like to polish will eventually wear the soft cladding of aluminum through... then it is time to paint...Herb 6061 is a high Maganese/Magnesium alloy...from memory..The outer surface corrodes into aluminum oxide which is hard and offers corrosion protection from the normal elements...meaning ,,,no mouse pee or salt water to name a couple.. Herb/Gang: Thanks for correcting me. I remember reading about alclad somewhere many years ago. I've got old 6061 tubing hanging in the shop that has turned dark and old looking, but when inspected, it is like surface dirt, extremely thin layer. I don't hesitate to use this old tubing when necessary. For items that should not be painted, like aluminum engine mounts on Kolbs with 912's, I use alodine after giving them a phosphoric acid bath. This works good. I learned from my first set of aluminum 912 engine mounts that if primed and painted, where the engine case makes contact with the aluminum mount, vibration and stress will soon wear away the primer and paint, leaving four loose engine mount bolts. Of course one could prime and paint the mounts, but mask off the areas where the engine case makes contact with the mounts. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 01, 2010
We can argue this all day long if you want, John. But it IS meaningful to me. If I know the MPG in static air and know my headwind or tailwind component I can easily determine in my head how far over the ground I can go. With GPH all we know is how long we can stay in the air. That plus knowing your ground speed and a little bit of math we can come up with the same result. Neither is meaningless. Just a different way to approach it. Plus it also gives you a relative efficiency number for comparing aircraft, if anyone cares to do that. In static air my normal cruise speed of 85 mph and 3.75 gph gives me about 22.5 mpg. Your MkIII at 85 mph and 5 GPH yields about 17 MPG in static air. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321969#321969 ________________________________________________________________________________
Date: Dec 01, 2010
Herb, quite right. If you go to buy an old airplane check to see how long it has been painted. Those polished antiques may look dandy but all they are doing is harm. Better to paint it from the get go or leave the surface to chalk. Even then I have heard about older airplanes that looked great on the surface but you could push a pencil through the skin. Mostly the result of intergranular reaction due to dissimilar metals. A friend who refueled Air America gooneys in VN said he had to be careful to not put a foot through the wing skin. :( BB On 1, Dec 2010, at 4:42 PM, Herb wrote: > > > John > > The only alclad aluminum that I know is 2024...It is considered to be a primary aircraft metal . .the core metal contains a fair amount of copper..The trick it to lay a pure sheet of aluminum over both sides of the ingot before it goes down the hot roll mill.. this bonds a very thin layer to the core metal... > > Guys with unpainted GA planes who like to polish will eventually wear the soft cladding of aluminum through... then it is time to paint...Herb > > > 6061 is a high Maganese/Magnesium alloy...from memory..The outer surface corrodes into aluminum oxide which is hard and offers corrosion protection from the normal elements...meaning ,,,no mouse pee or salt water to name a couple.. > > At 03:11 PM 12/1/2010, you wrote: >> >> >> What is the procedure you used for corrosion proofing the inside of the >> aluminum tubing used on a Kolb? >> >> Gene >> >> >> Gang: >> >> Back in the old days, Kolb used carbon steel rivets with carbon steel >> mandrels. They loved to rust. >> >> I built my Ultrastar with carbon rivets and learned soon how quickly they >> developed rust. >> >> When I built my FS, I got Little Mike, Old Kolb Part Man, to get me SS pop >> rivets to build the FS Kit. They worked much better, but they still used >> carbon steel mandrels. I used to put a blob of Stitts 2 part expoxy on the >> heads, but could do nothing with the tails of the rivets. However, this has >> never been a problem. I am flying a MKIII I built in 1991, and has been >> flying since 1992. That's a lot of hanger time, and a lot of time out under >> the stars and rain/dew when I am flying overnight or longer cross country >> flights. >> >> I haven't had a problem with corrosion. My understanding was most aircraft >> aluminum is "alclad". That is a thin coat of pure aluminum. If you get >> aluminum that is not "alclad", it is more prone to corrode. >> >> Based on the photos Rick G sent to the List of his Kolb project he picked up >> in PA, I would have left it right where I found it. Never seen anything in >> the junk pile out side that looked that bad, except when rodents peed on the >> aluminum. >> >> Rodent urine is highly corrosive, and they love Kolbs, especially the >> tailboom. Occasionally I shoot some anticorrosion spray into my tailboom to >> counteract rodent urine and water that gets in there from condensation, and >> also from occasionally washing the airplane. >> >> I am more concerned with the 4130 chromoly tubing. I have used tube seal in >> all three Kolbs I have built. >> >> I do have drain holes on wings, ailerons, horizontal stabilizers, elevators, >> upper and lower vertical stabilizers, and rudder. Don't know if they do >> more harm than good. They let out moisture, but allow dirt/mud daubers to >> come inside. I had some corrosion in the trailing edge tube of the left >> aileron when I rebuilt it in 2000. Undoubtedly, they have a lot of acid in >> their nests and larvae. >> >> john h >> mkIII >> Titus, Alabama >> >> >> > > > > > ________________________________________________________________________________
Date: Dec 01, 2010
We can argue this all day long if you want, John. But it IS meaningful to me. If I know the MPG in static air and know my headwind or tailwind component I can easily determine in my head how far over the ground I can go. With GPH all we know is how long we can stay in the air. That plus knowing your ground speed and a little bit of math we can come up with the same result. Neither is meaningless. Just a different way to approach it. Plus it also gives you a relative efficiency number for comparing aircraft, if anyone cares to do that. In static air my normal cruise speed of 85 mph and 3.75 gph gives me about 22.5 mpg. Your MkIII at 85 mph and 5 GPH yields about 17 MPG in static air. -------- Thom Riddle Thom R/Gang: I am sure your system of mpg works for you, but not for me. I never heard the term mpg in military or civilian flight training I have attended. It has been a long time since I have been to school, so maybe current aviation is not using GPH, but MPG now. Let me know when you find some static air. ;-) Most of us are flying with GPS now days. Mine is an old Garmin 196, but it does give me constantly updated info like "time to my next waypoint", etc. Much better system than the old E6B. I don't need to know wind speed or direction, at my altitude, and where I am located. Knowing my accurate fuel burn, I know immediately how much fuel and time it will take me to get to my next. MPG is for automobiles. GPH is for aircraft. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 01, 2010
For those interested in painting the inside of tubes: Years ago we built a float FS that was intended to be flown on the Chesapeake where the water is brackish - somewhat salty. We have always urged strong caution in flying Kolbs on salt water because there are so many dissimilar metals. John Pitre in HI flew a TS for many years but he went to great pains to protect and to rinse thoroughly with fresh water after flying. Getting back to the FS on the Chesapeake: We made a shallow pan and soaked the ribs in lacquer thinner and swished it around to remove as much of the oily coating on - and in - the tubing. Then we immersed the ribs in a shallow pan of epoxy chromate primer and hung them up to drip dry. For the spars we cleaned them inside and out with lacquer thinner and then poured epoxy chromate paint thru them with the ends capped off with plastic. The spars were then rotated and tilted to get the inside thoroughly covered. Then when the wing was assembled we sprayed epoxy chromate paint to paint all the rivets and any missed areas. The tail surfaces, etc got even better treatment because the tail typically receives spray from the floats. I don't know how much of that was necessary, but we thought we were being as thorough as we could. I lost track of that FS, so ultimately I do not know how successful or unsuccessful the preventative measures were. Dennis -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Wednesday, December 01, 2010 4:12 PM Subject: Re: Kolb-List: Re: Construction What is the procedure you used for corrosion proofing the inside of the aluminum tubing used on a Kolb? Gene Gang: Back in the old days, Kolb used carbon steel rivets with carbon steel mandrels. They loved to rust. I built my Ultrastar with carbon rivets and learned soon how quickly they developed rust. When I built my FS, I got Little Mike, Old Kolb Part Man, to get me SS pop rivets to build the FS Kit. They worked much better, but they still used carbon steel mandrels. I used to put a blob of Stitts 2 part expoxy on the heads, but could do nothing with the tails of the rivets. However, this has never been a problem. I am flying a MKIII I built in 1991, and has been flying since 1992. That's a lot of hanger time, and a lot of time out under the stars and rain/dew when I am flying overnight or longer cross country flights. I haven't had a problem with corrosion. My understanding was most aircraft aluminum is "alclad". That is a thin coat of pure aluminum. If you get aluminum that is not "alclad", it is more prone to corrode. Based on the photos Rick G sent to the List of his Kolb project he picked up in PA, I would have left it right where I found it. Never seen anything in the junk pile out side that looked that bad, except when rodents peed on the aluminum. Rodent urine is highly corrosive, and they love Kolbs, especially the tailboom. Occasionally I shoot some anticorrosion spray into my tailboom to counteract rodent urine and water that gets in there from condensation, and also from occasionally washing the airplane. I am more concerned with the 4130 chromoly tubing. I have used tube seal in all three Kolbs I have built. I do have drain holes on wings, ailerons, horizontal stabilizers, elevators, upper and lower vertical stabilizers, and rudder. Don't know if they do more harm than good. They let out moisture, but allow dirt/mud daubers to come inside. I had some corrosion in the trailing edge tube of the left aileron when I rebuilt it in 2000. Undoubtedly, they have a lot of acid in their nests and larvae. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 01, 2010
Subject: Replacing UltraStart Red battery
Kolbers, I was about to purchase the second replacement battery for the FireFly. And then I thought I would look at finding something different that may not be so expensive. I stripped off the adhesive label and found that the battery was made by GS Battery, a Portalac PX12050SHR. I went to a local battery shop and purchase an equivalent battery and modified it to replace the UltraStart Red. The dollar savings were substantial. If you would like to see how it was done, check out: http://jackbhart.com/firefly/firefly160.html Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: Adding additional fuel tanks =?ISO-8859-1?Q?=93?= Jump
Seat =?ISO-8859-1?Q?=93?= FS-2
Date: Dec 01, 2010
I think your weight and balance would probably come out better with the six gallon tanks where the jump seat used to be, and then put one five gallon tank just behind them where the original front tank was, that will give you 17 gallons, and with a 503, that is a lot of fuel. Here's how the two six gallon tanks fit in N582EF. No current pictures, can get some if you want. (Tomorrow) Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322018#322018 Attachments: http://forums.matronics.com//files/normal_1_760.jpg ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Dec 02, 2010
John, not to beat a dead horse to death but after 40 odd years being around airplanes in Alaska and other out of the way places, I too have never seen MPH associated with airplanes. I couldn't imagine planning a trip using MPH. What you had better think about is TIME you can stay airborn. I'm still looking for that static air. Gene -------------------------------------------------- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Wednesday, December 01, 2010 4:19 PM Subject: Re: Kolb-List: Re: Kolb Firestar Fuel consumption > > > We can argue this all day long if you want, John. But it IS meaningful to > me. > > If I know the MPG in static air and know my headwind or tailwind component > I > can easily determine in my head how far over the ground I can go. With GPH > all we know is how long we can stay in the air. That plus knowing your > ground speed and a little bit of math we can come up with the same result. > Neither is meaningless. Just a different way to approach it. > > Plus it also gives you a relative efficiency number for comparing > aircraft, > if anyone cares to do that. In static air my normal cruise speed of 85 mph > and 3.75 gph gives me about 22.5 mpg. Your MkIII at 85 mph and 5 GPH > yields > about 17 MPG in static air. > > -------- > Thom Riddle > > > Thom R/Gang: > > I am sure your system of mpg works for you, but not for me. I never heard > the term mpg in military or civilian flight training I have attended. It > has been a long time since I have been to school, so maybe current > aviation > is not using GPH, but MPG now. > > Let me know when you find some static air. ;-) > > Most of us are flying with GPS now days. Mine is an old Garmin 196, but > it > does give me constantly updated info like "time to my next waypoint", etc. > Much better system than the old E6B. I don't need to know wind speed or > direction, at my altitude, and where I am located. Knowing my accurate > fuel > burn, I know immediately how much fuel and time it will take me to get to > my > next. > > MPG is for automobiles. GPH is for aircraft. > > john h > mkIII > Titus, Alabama > > > ________________________________________________________________________________
Date: Dec 02, 2010
Semantics! To each his own. The challenge is to not let the earth smite thine ass before one reaches point "B" how ever that may be done. If one can flap his wings or pull gas from the clouds, who cares? On Thu, Dec 2, 2010 at 5:51 AM, Gene & Tammy wrote: > zharvey(at)bentoncountycable.net> > > John, not to beat a dead horse to death but after 40 odd years being around > airplanes in Alaska and other out of the way places, I too have never seen > MPH associated with airplanes. I couldn't imagine planning a trip using > MPH. What you had better think about is TIME you can stay airborn. > I'm still looking for that static air. > Gene > > -------------------------------------------------- > From: "John Hauck" <jhauck(at)elmore.rr.com> > Sent: Wednesday, December 01, 2010 4:19 PM > To: > Subject: Re: Kolb-List: Re: Kolb Firestar Fuel consumption > >> >> >> We can argue this all day long if you want, John. But it IS meaningful to >> me. >> >> If I know the MPG in static air and know my headwind or tailwind component >> I >> can easily determine in my head how far over the ground I can go. With GPH >> all we know is how long we can stay in the air. That plus knowing your >> ground speed and a little bit of math we can come up with the same result. >> Neither is meaningless. Just a different way to approach it. >> >> Plus it also gives you a relative efficiency number for comparing >> aircraft, >> if anyone cares to do that. In static air my normal cruise speed of 85 mph >> and 3.75 gph gives me about 22.5 mpg. Your MkIII at 85 mph and 5 GPH >> yields >> about 17 MPG in static air. >> >> -------- >> Thom Riddle >> >> >> Thom R/Gang: >> >> I am sure your system of mpg works for you, but not for me. I never heard >> the term mpg in military or civilian flight training I have attended. It >> has been a long time since I have been to school, so maybe current >> aviation >> is not using GPH, but MPG now. >> >> Let me know when you find some static air. ;-) >> >> Most of us are flying with GPS now days. Mine is an old Garmin 196, but >> it >> does give me constantly updated info like "time to my next waypoint", etc. >> Much better system than the old E6B. I don't need to know wind speed or >> direction, at my altitude, and where I am located. Knowing my accurate >> fuel >> burn, I know immediately how much fuel and time it will take me to get to >> my >> next. >> >> MPG is for automobiles. GPH is for aircraft. >> >> john h >> mkIII >> Titus, Alabama >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 02, 2010
cheee, I know mine's not fast but I sure would like at least some MPH :) BB On 2, Dec 2010, at 8:51 AM, Gene & Tammy wrote: > > John, not to beat a dead horse to death but after 40 odd years being around airplanes in Alaska and other out of the way places, I too have never seen MPH associated with airplanes. I couldn't imagine planning a trip using MPH. What you had better think about is TIME you can stay airborn. > I'm still looking for that static air. > Gene > > -------------------------------------------------- > From: "John Hauck" <jhauck(at)elmore.rr.com> > Sent: Wednesday, December 01, 2010 4:19 PM > To: > Subject: Re: Kolb-List: Re: Kolb Firestar Fuel consumption > >> >> >> We can argue this all day long if you want, John. But it IS meaningful to >> me. >> >> If I know the MPG in static air and know my headwind or tailwind component I >> can easily determine in my head how far over the ground I can go. With GPH >> all we know is how long we can stay in the air. That plus knowing your >> ground speed and a little bit of math we can come up with the same result. >> Neither is meaningless. Just a different way to approach it. >> >> Plus it also gives you a relative efficiency number for comparing aircraft, >> if anyone cares to do that. In static air my normal cruise speed of 85 mph >> and 3.75 gph gives me about 22.5 mpg. Your MkIII at 85 mph and 5 GPH yields >> about 17 MPG in static air. >> >> -------- >> Thom Riddle >> >> >> Thom R/Gang: >> >> I am sure your system of mpg works for you, but not for me. I never heard >> the term mpg in military or civilian flight training I have attended. It >> has been a long time since I have been to school, so maybe current aviation >> is not using GPH, but MPG now. >> >> Let me know when you find some static air. ;-) >> >> Most of us are flying with GPS now days. Mine is an old Garmin 196, but it >> does give me constantly updated info like "time to my next waypoint", etc. >> Much better system than the old E6B. I don't need to know wind speed or >> direction, at my altitude, and where I am located. Knowing my accurate fuel >> burn, I know immediately how much fuel and time it will take me to get to my >> next. >> >> MPG is for automobiles. GPH is for aircraft. >> >> john h >> mkIII >> Titus, Alabama >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Dec 02, 2010
Hello Richard, Thanks for your input and the picture posted. I will surely take your suggestion and calculate the W and B and move the two 6 gallon tank accordingly. Will appreciate if you can send me additional pictures info, if you have them. What is your present configuration of the tanks? Did you find the FS-2 flight characteristics change after adding the additional fuel tanks?? I do anticipate a longer roll during take off. Thanks, Mahesh FS-2, Ashland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322070#322070 ________________________________________________________________________________
Subject: Re: Firestar for sale
Date: Dec 02, 2010
I didn't list the details because I was pretty bummed out about selling it and I still am but here's the specs Rotax 377 (35hp), engine was decarbed at 150hr, starts on the first pull. Fabric is in outstanding shape except a small patched area on the underside of the right aileron. Tach,EGT,CHT, Altimeter, Vertical speed indicator, Clock, Compass Garmin GPSIII Strobe Brakes TTAE 415 Tail boom damaged on trailer but repaired to new. I'm asking $5500 OBO Thanks, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322076#322076 ________________________________________________________________________________
Subject: =?iso-8859-1?Q?Re=3A_Kolb-List=3A_Re=3A_Adding_additional_fuel_t?=
=?iso-8859-1?Q?anks_=93_Jump_Seat_=93_FS-2?
Date: Dec 02, 2010
Mahesh, Unlike Richard Pike, I have two six gal tanks in the conventional location behind the jump seat as my main tanks, and use two auxiliary six gal. tanks as needed depending on the length of the trip, on the jump seat location. I transfer fuel in flight from the auxiliary tanks to the main tanks with a second pulse pump by simply opening a valve. I'd really hate to permanently give up the space behind the pilot's seat for carrying "other freight" by putting my main tanks there. If your plane flies like mine does, you will notice only a very slight difference with the extra tanks. Slightly longer take-off roll, slightly less climb performance, slightly higher fuel burn, slightly greater turbulence stability, slightly greater risk of bending the landing gear on a hard landing ,,,,,,,,,,,, and a significantly greater urgency to empty the bladder. ;-) Gene On Dec 2, 2010, at 12:09 PM, miyer2u wrote: > > Hello Richard, > Thanks for your input and the picture posted. > I will surely take your suggestion and calculate the W and B and move the two 6 gallon tank accordingly. > > Will appreciate if you can send me additional pictures info, if you have them. What is your present configuration of the tanks? Did you find the FS-2 flight characteristics change after adding the additional fuel tanks?? I do anticipate a longer roll during take off. > > Thanks, > Mahesh > FS-2, Ashland, OR > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322070#322070 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Kolb Aircraft Insurance
Date: Dec 02, 2010
Here's another insurance carrier to check out if one is comparing prices and coverage. They saved me considerable money, as a new Kolb owner. Dave Joseph R. Cacho Aviation Insurance Resources-FLA Ph: 407-770-0240 Fax: 407-770-0241 www.Air-Pros.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322093#322093 ________________________________________________________________________________
Date: Dec 02, 2010
There is another insurance (liability) that you can get from a ultralight group. Someone on the list sent me a link a few years ago when I was looking to keep my plane at a airport that required liability insurance. It was way less than the big insurance cariers. It seemed like it was around $400/yr for a 1/2 million liability. Check the archives for the post. Richard Neilsen Redrive VW Powered MKIIIC On Thu, Dec 2, 2010 at 4:11 PM, Watkinsdw wrote: > > Here's another insurance carrier to check out if one is comparing prices > and coverage. They saved me considerable money, as a new Kolb owner. > Dave > > Joseph R. Cacho > Aviation Insurance Resources-FLA > Ph: 407-770-0240 > Fax: 407-770-0241 > www.Air-Pros.com <http://www.air-pros.com/> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322093#322093 > > ________________________________________________________________________________
Date: Dec 02, 2010
At 04:48 PM 12/2/2010, Richard Neilsen wrote: >There is another insurance (liability) that you can get from a ultralight >group. Someone on the list sent me a link a few years ago when I was >looking to keep my plane at a airport that required liability insurance. >It was way less than the big insurance cariers. It seemed like it was >around $400/yr for a 1/2 million liability. Check the archives for the post. usua.org or aerosports.org... ~400 for $1M coverage. -Dana -- Income tax: capital punishment. ________________________________________________________________________________
Date: Dec 02, 2010
Subject: Dual Stick set up for sale
Anyone out there interested in a used dual stick set up for the Mk III? I'm tired of dragging my leg over while I catch my big feet on things around the panel. Very good condition. New $475, yours 300 OBO. Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 03, 2010
I have the First Flight liability insurance on my Slingshot, which is the agency that USUA and some other groups use for insurance. http://www.firstflightinsurance.com/associations.htm You must be a member of USUA to get this insurance. Here is a link to the particulars, including coverage, limitations and cost. http://www.firstflightinsurance.com/documents/USUAWebsiteWording_006.pdf -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322149#322149 ________________________________________________________________________________
Date: Dec 03, 2010
Since FSDO has not yet returned the Airworthiness Certificate (which was collected after the crash, pending the rebuild) we haven't flown it yet, so no info to share. But here is what it looks like, the only mods were a couple diagonals welded from what was the front sling seat mount/cross brace to the side vertical tubes, and a length of 3/8" tubing between the two tanks and up to the upper cross brace to help secure the tanks. The original gas tank tray now sits on those lower two diagonal tubes. Also added a cross piece to attach to the carrying handles on the top of the tanks. Works well, hardly any wiggles, very secure. Since I wanted the fuel tank pickups to come out of the top of the tanks, the primer bulb was necessary. The Facet pump (visible below the tray, center) will not pull fuel without a prime, hence the primer bulb. Downstream of the primer bulb is my "poor man's gascolator" (details here: http://www.bcchapel.org/pages/0003/pg13.html) and you can sort of see the line going to the quick drain valve off to the left of the fuselage. The right tank in the picture has a JC Whitney gas gauge sender in it, after we take the film off the Lexan I take a picture of how it is installed. The black thing on the front of the left tank is the battery box for the ANR headset. More pictures later. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322171#322171 Attachments: http://forums.matronics.com//files/6gallonmod_227.jpg ________________________________________________________________________________
Date: Dec 03, 2010
That looks very nice Richard. Almost makes me want to clean up my floor :) My Facet will pull from an empty line through a top pick up in a matter of seconds using the 40105 lowest pressure output pump. -Located below the tank bottom. BB On 3, Dec 2010, at 11:03 AM, Richard Pike wrote: > > Since FSDO has not yet returned the Airworthiness Certificate (which was collected after the crash, pending the rebuild) we haven't flown it yet, so no info to share. > > But here is what it looks like, the only mods were a couple diagonals welded from what was the front sling seat mount/cross brace to the side vertical tubes, and a length of 3/8" tubing between the two tanks and up to the upper cross brace to help secure the tanks. The original gas tank tray now sits on those lower two diagonal tubes. Also added a cross piece to attach to the carrying handles on the top of the tanks. Works well, hardly any wiggles, very secure. > > Since I wanted the fuel tank pickups to come out of the top of the tanks, the primer bulb was necessary. The Facet pump (visible below the tray, center) will not pull fuel without a prime, hence the primer bulb. > > Downstream of the primer bulb is my "poor man's gascolator" (details here: http://www.bcchapel.org/pages/0003/pg13.html) and you can sort of see the line going to the quick drain valve off to the left of the fuselage. > > The right tank in the picture has a JC Whitney gas gauge sender in it, after we take the film off the Lexan I take a picture of how it is installed. > > The black thing on the front of the left tank is the battery box for the ANR headset. > > More pictures later. > > Richard Pike > MKIII N420P (420ldPoops) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322171#322171 > > > > > Attachments: > > http://forums.matronics.com//files/6gallonmod_227.jpg > > > > > > > ________________________________________________________________________________
Date: Dec 03, 2010
Subject: =?windows-1252?Q?Re=3A_Kolb=2DList=3A_Re=3A_Adding_additional_fuel_tanks_?=
=?windows-1252?Q?=93_Jump_Seat_=93_FS=2D2?
Richard/All I looked at your poor man's gascolator again and noticed you use one of those rubber bushings that you refuse to put in your fuel tanks. You seem to be inconsistent. Properly installed (maybe I have been lucky) they don't leak. I carefully drill with a step drill and debur the holes. Any way you can get a certified style gascolator at Great Plains Aircraft for under $40 and not have to use those as you say leaky rubber bushings at all. I also use safety wire clamps but I have a tool I picked up at Oshkosh that makes a fine safety wire clamp and doesn't have as much of a sharp pointy end. I have been replacing all my clamps on my airplane with them and have been real happy with them. They end up being much lighter than the traditional clamps. It is surprising. I have been throwing the old clamps in a box as I replace them and I have saved a few pounds already. I likely have more clamps than normal but every bit helps. Rick Neilsen Redrive VW Powered MKIIIC On Fri, Dec 3, 2010 at 11:03 AM, Richard Pike wrote: > > Since FSDO has not yet returned the Airworthiness Certificate (which was > collected after the crash, pending the rebuild) we haven't flown it yet, so > no info to share. > > But here is what it looks like, the only mods were a couple diagonals > welded from what was the front sling seat mount/cross brace to the side > vertical tubes, and a length of 3/8" tubing between the two tanks and up to > the upper cross brace to help secure the tanks. The original gas tank tray > now sits on those lower two diagonal tubes. Also added a cross piece to > attach to the carrying handles on the top of the tanks. Works well, hardly > any wiggles, very secure. > > Since I wanted the fuel tank pickups to come out of the top of the tanks, > the primer bulb was necessary. The Facet pump (visible below the tray, > center) will not pull fuel without a prime, hence the primer bulb. > > Downstream of the primer bulb is my "poor man's gascolator" (details here: > http://www.bcchapel.org/pages/0003/pg13.html) and you can sort of see the > line going to the quick drain valve off to the left of the fuselage. > > The right tank in the picture has a JC Whitney gas gauge sender in it, > after we take the film off the Lexan I take a picture of how it is > installed. > > The black thing on the front of the left tank is the battery box for the > ANR headset. > > More pictures later. > > Richard Pike > MKIII N420P (420ldPoops) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322171#322171 > > > Attachments: > > http://forums.matronics.com//files/6gallonmod_227.jpg > > ________________________________________________________________________________
Date: Dec 03, 2010
Gene and Richard, Thanks for all the information. Richard, appreciate that you have a good web page and you help share lot of useful information for Kolb builders. PS: Gene, I am in full synch with what you said.Longer XCs call for more biological needs and I suppose I need to add Little John as listed on the Sportys catalogue to my shopping list :-)) Wish you all a good one! Mahesh Iyer FS-2, Ashland,OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322179#322179 ________________________________________________________________________________
Subject: safety wire clamp
Date: Dec 03, 2010
Rick, What size wire are you using with the safety wire tool? I bought one too but haven't used it yet. PCKing ----- Original Message ----- From: Richard Neilsen To: kolb-list(at)matronics.com Sent: Friday, December 03, 2010 12:47 PM Subject: Kolb-List: Re: Kolb-List: Re: Adding additional fuel tanks ?" Jump Seat ?" FS-2 I also use safety wire clamps but I have a tool I picked up at Oshkosh that makes a fine safety wire clamp and doesn't have as much of a sharp pointy end. I have been replacing all my clamps on my airplane with them and have been real happy with them. They end up being much lighter than the traditional clamps. It is surprising. I have been throwing the old clamps in a box as I replace them and I have saved a few pounds already. I likely have more clamps than normal but every bit helps. Rick Neilsen Redrive VW Powered MKIIIC On Fri, Dec 3, 2010 at 11:03 AM, Richard Pike ________________________________________________________________________________
Date: Dec 03, 2010
Subject: Re: safety wire clamp
I don't remember the wire size. It is the safety wire that Kolb sent with m y kit. My plane is back in Michigan and I'm in Florida for the winter so I can't check. The tool is a pain to use in spite of the how easy they make i t seem. Depending on the need you can vary the number of wraps to get most an y strength. It works well but you need enough clearance around the fitting to swing the tool to get it to lock. Rick Neilsen Redrive VW Powered MKIIIC On Fri, Dec 3, 2010 at 1:37 PM, PCKing wrote: > Rick, > > What size wire are you using with the safety wire tool? I bought one too > but haven't used it yet. > > PCKing > > > ----- Original Message ----- > *From:* Richard Neilsen > *To:* kolb-list(at)matronics.com > *Sent:* Friday, December 03, 2010 12:47 PM > *Subject:* Kolb-List: Re: Kolb-List: Re: Adding additional fuel tanks =93 > Jump Seat =93 FS-2 > > I also use safety wire clamps but I have a tool I picked up at Oshkosh th at > makes a fine safety wire clamp and doesn't have as much of a sharp pointy > end. I have been replacing all my clamps on my airplane with them and hav e > been real happy with them. They end up being much lighter than the > traditional clamps. It is surprising. I have been throwing the old clamps in > a box as I replace them and I have saved a few pounds already. I likely h ave > more clamps than normal but every bit helps. > Rick Neilsen > Redrive VW Powered MKIIIC > On Fri, Dec 3, 2010 at 11:03 AM, Richard Pike > > * > =========== =========== =========== ============* > > ________________________________________________________________________________
Date: Dec 03, 2010
FWIW, .020" safety wire tends to cut into flexible tubing and is easy to break. .041" is over kill. I don't have any .025 which might be okay but use .032 on most things and it works well for hose clamping. I've never seen a special tool for this nor felt a need for one. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322204#322204 ________________________________________________________________________________
Date: Dec 03, 2010
Tom I obviously don't know as much as you but... Check out this web site http://www.clamptitetools.com/Instructions.html The tool is a pain but does allow for a very uniform clamp as tight as you want. It is a bit over priced for what it is. It has never cut into any tubing I have used it on but don't think I have ever used .020 safety wire. As always the information is worth what you paid for it. Rick Neilsen Redrive VW Powered MKIIIC On Fri, Dec 3, 2010 at 5:01 PM, Thom Riddle wrote: > > FWIW, .020" safety wire tends to cut into flexible tubing and is easy to > break. .041" is over kill. I don't have any .025 which might be okay but use > .032 on most things and it works well for hose clamping. I've never seen a > special tool for this nor felt a need for one. > > -------- > Thom Riddle > Buffalo, NY (9G0) > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > Tennessee Prop 64x32 > > > =93Everyone is entitled to his own opinion, but not his own facts.=94 > Daniel Patrick Moynihan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322204#322204 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Dec 03, 2010
Rick, .....I obviously don't know as much as you but... That is not obvious at all. You have no idea how little I know about lots of stuff. But I have done a fair amount of safety wiring and use it for lots of things, including hose clamps when I don't have the right size on hand. When I get the right size I usually will replace the safety wire, not because it does not work but I prefer to use good hose clamps designed for the job. I'll check out the tool link. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322211#322211 ________________________________________________________________________________
Seat =?ISO-8859-1?Q??
Date: Dec 03, 2010
neilsenrm(at)gmail.com wrote: > Richard/All > > I looked at your poor man's gascolator again and noticed you use one of those rubberbushings that you refuse to put in your fuel tanks. You seem to be inconsistent. Properly installed (maybe I have been lucky) they don't leak. I carefully drill with a step drill and debur the holes. > > Any way you can get a certified style gascolator at Great Plains Aircraft for under $40 and not have to use those as you say leaky rubber bushings at all. > > I alsouse safety wire clamps but I have a tool I picked up at Oshkosh that makes a fine safety wire clampand doesn't have as much of a sharp pointy end. I have been replacing all my clamps on my airplane with them and have been real happy with them. They end up being much lighter than the traditional clamps. It is surprising. I have been throwing the old clamps in a box as I replace them and I havesaved a few pounds already. Ilikely have more clamps than normal but every bit helps. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > [b] Don't remember saying anything about leaky rubber bushings, maybe I did, didn't see it anywhere. The reason we put them up top is because the six gallon tanks seemed to be a bit thinner wall thickness than the five gallons tanks that were in there before. Maybe not, but they seemed that way to me. Don't remember refusing to use rubber bushings on the bottom of fuel tanks, we used the rubber bushings in the underside of the previous five gallon tanks and they worked fine, but somehow I just didn't feel too good about doing the same thing with the six gallon tanks. And besides, doing the safety wiring on the plumbing is so much easier when things are up top... Roger on the box full of heavy old hose clamps... Me too. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322224#322224 ________________________________________________________________________________
Date: Dec 03, 2010
Subject: Re: Adding additional fuel tanks in the jump seat area
Hi Gang, My Firestar II has been flying for years with two 5 gallon tanks in the standard rear position and two additional 5 gallon tanks in the jump seat area. The two tanks in the rear area feed out of the bottomin series so the rear most tank empties first. The two tanks forward which feed out of their tops are in a custom aluminum box. The box mounts with four bolts and thereis a quick disconnecton the fuel line coming out of the box so it can be removed quickly for a passenger. It is also secured by the rear seat belt. Another quick disconnect is in-line between the two tanks in the box so on short trips only one tank need be filled. The whole setup is controlled by an A-B valve mounted within reach in-flight so fuel can be taken from the front or the rear at will. The standard pulse fuel pump handles the system nicely and weight and balance is manageable for a 150 # pilot. I do not have any readily available pictures but if anyone is interested in the setup some could be posted. Jon L Minnesota N503KF ________________________________________________________________________________
Subject: Ran the 582 today
Date: Dec 03, 2010
Did a bit more work today, it is supposed to snow tomorrow and then be colder than a bear, so had to get it while we could. Engine ran good, but got a wire connected wrong somewhere, the water temp gauge doesn't work, neither do the kill switches. Ya think I got em' switched? [Rolling Eyes] Here's some pictures- Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322227#322227 Attachments: http://forums.matronics.com//files/p1190016_large_889.jpg http://forums.matronics.com//files/p1190018_large_121.jpg http://forums.matronics.com//files/p1190020_large_334.jpg http://forums.matronics.com//files/p1190023_large_103.jpg http://forums.matronics.com//files/p1190025_large_114.jpg http://forums.matronics.com//files/p1190027_large_940.jpg ________________________________________________________________________________
Subject: red tape
Date: Dec 03, 2010
Here are some of the legislative initiatives on the horizon: http://tinyurl.com/2bbnpsf in my not so humble opinion this anti-terrorist bs has gone too far. If they get too ambitious with said bs, even at my age, I will go Jack Hart's route. If they come up with more restrictions after that they can KMA. BB ________________________________________________________________________________
Date: Dec 04, 2010
Richard, Your photo shows your fuel tanks just above your battery/electronics box. Is that right ? Perhaps it might be wise to consider some sort of cover over the electronics such that if there was a leakage or spillage of fuel it doesn't go directly down onto those items but is drained off safely somewhere else. Just a thought. David. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322243#322243 ________________________________________________________________________________
Subject: Re: Ran the 582 today
Date: Dec 04, 2010
Very nice, Richard. Perhaps you should dub this Firestar II Lazarus. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322246#322246 ________________________________________________________________________________
Date: Dec 04, 2010
The Phoenix nose art was not very obvious in the pictures, but it's now a Firebird. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322257#322257 ________________________________________________________________________________
Subject: Re: red tape
Date: Dec 04, 2010
Nice post......."regulation for the sake of regulation" or " New World Order". Aviation will surely become ever more elitist. :( -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322261#322261 ________________________________________________________________________________
Date: Dec 04, 2010
Something like cut the bottom off a plastic milk jug and drape over it? Sounds good to me! Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322284#322284 ________________________________________________________________________________
Date: Dec 04, 2010
Subject: RE: Kolb-List Digest: 15 Msgs - 12/03/10
Thanks Rick (Neilsen). Great stuff. I looked up the tool and it is impressive. Richard Pike: Are these recent photos on your web site? I appreciate all the help. Bob Green Building MKIIIX, N830PB ________________________________________________________________________________
Date: Dec 04, 2010
Richard, Will it have a cockpit heater? Gene On Dec 3, 2010, at 11:03 AM, Richard Pike wrote: > > Since FSDO has not yet returned the Airworthiness Certificate (which was collected after the crash, pending the rebuild) we haven't flown it yet, so no info to share. > > But here is what it looks like, the only mods were a couple diagonals welded from what was the front sling seat mount/cross brace to the side vertical tubes, and a length of 3/8" tubing between the two tanks and up to the upper cross brace to help secure the tanks. The original gas tank tray now sits on those lower two diagonal tubes. Also added a cross piece to attach to the carrying handles on the top of the tanks. Works well, hardly any wiggles, very secure. > > Since I wanted the fuel tank pickups to come out of the top of the tanks, the primer bulb was necessary. The Facet pump (visible below the tray, center) will not pull fuel without a prime, hence the primer bulb. > > Downstream of the primer bulb is my "poor man's gascolator" (details here: http://www.bcchapel.org/pages/0003/pg13.html) and you can sort of see the line going to the quick drain valve off to the left of the fuselage. > > The right tank in the picture has a JC Whitney gas gauge sender in it, after we take the film off the Lexan I take a picture of how it is installed. > > The black thing on the front of the left tank is the battery box for the ANR headset. > > More pictures later. > > Richard Pike > MKIII N420P (420ldPoops) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322171#322171 > > > > > Attachments: > > http://forums.matronics.com//files/6gallonmod_227.jpg > > > > > > > ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 11 Msgs - 12/02/10
Date: Dec 04, 2010
> I too have never seen MPH associated with airplanes. I think you guys are making a big deal out of this when it sounds to me like a fella just wants more info. Maybe, like me, he wants to look at things from more than one way. Maybe he wants a broader outlook, a variety of ways to analyze things. > I'm still looking for that static air. He didn't say anything about static air. He can make use of mpg info without static air. Give him a break! GeoB ________________________________________________________________________________
Date: Dec 04, 2010
Won't need one. By the time FSDO gets around to inspecting it, it will be warm again. :P Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322309#322309 ________________________________________________________________________________
Subject: winter skis !
Date: Dec 04, 2010
Well guys, the shooting gallery is open ! What do you think of the new skis ? The Right ski will go much better now that I know what I have the left one done....Can't wait for snow ! These are made for going on snowmobile packed snow on Houghton Lake,,,no glacier hopping...lol chris ambrose M3X/Jabiru A- 2200 168.7 hrs N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322313#322313 Attachments: http://forums.matronics.com//files/left_ski_2_119.jpg http://forums.matronics.com//files/ski_attach_146.jpg http://forums.matronics.com//files/left_ski_112.jpg ________________________________________________________________________________
Subject: Hat Cam !
Date: Dec 04, 2010
Ok ...I stoled someones idea with the hat cam,but it works great ! Thank you ! Here is the link if you get the chance , http://www.youtube.com/watch?v=t3qNi2m7yh0 Have a great weekend ! chris ambrose M3X/Jabiru A-2200 n327 cs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322318#322318 ________________________________________________________________________________
Subject: Re: Hat Cam !
Date: Dec 05, 2010
Hi Chris, nice video . >From another Jabi/Extra flyer. (We also have snow on the ground. Temps down to -7C ) Pat ________________________________________________________________________________
Subject: Re: Novice Kolb Pilot
Date: Dec 05, 2010
<> Not so! The Kolb glides perfectly well at an approptiate speed. What you are describing is a stall. In that way it is unlike the Challenger which is much more forgiving and just mushes if the speed drops off Pat ________________________________________________________________________________
Subject: Nice day doing some Texas Kolb cruisin'
Date: Dec 05, 2010
Kolb folks, I had a nice, semi-X country flight Saturday to an EAA #1347 BBQ at Fayette County airport, just outside of La Grange TX. Ran into Gary Haley, a friend that many of you know. He still has a Mk III, but it's currently benched. WX was great, 80 degrees at mid afternoon, winds WSW @ 12. Met a lot of new experimental builders, mostly RV flyers, & had one of those days that makes me glad I'm fortunate enough to own & fly a Kolb. Flew 277 miles round trip, engine was on for 5.1 hrs, burned 14.1 gal fuel. Did a lot of low flight river meandering on the way home and had a great day. Here's a photo of Gary & I standing in front of my Firestar. Oh, forgot mention that would be 2.76 gph, or if you prefer, 19.65 mpg. [Wink] -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322335#322335 Attachments: http://forums.matronics.com//files/100_0099_552.jpg ________________________________________________________________________________
Subject: Re: Nice day doing some Texas Kolb cruisin'
Date: Dec 05, 2010
Enjoyed your report and photo. What engine? I have noticed on some past photos, from others, that some of the Kolb owners have prop shaft extenders on their Rotax engines. Just wondering why? Gene -------------------------------------------------- From: "Jimmy Young" <jdy100(at)comcast.net> Sent: Sunday, December 05, 2010 6:53 AM Subject: Kolb-List: Nice day doing some Texas Kolb cruisin' > > Kolb folks, > > I had a nice, semi-X country flight Saturday to an EAA #1347 BBQ at > Fayette County airport, just outside of La Grange TX. Ran into Gary Haley, > a friend that many of you know. He still has a Mk III, but it's currently > benched. WX was great, 80 degrees at mid afternoon, winds WSW @ 12. Met a > lot of new experimental builders, mostly RV flyers, & had one of those > days that makes me glad I'm fortunate enough to own & fly a Kolb. > > Flew 277 miles round trip, engine was on for 5.1 hrs, burned 14.1 gal > fuel. Did a lot of low flight river meandering on the way home and had a > great day. Here's a photo of Gary & I standing in front of my Firestar. > > Oh, forgot mention that would be 2.76 gph, or if you prefer, 19.65 mpg. > [Wink] > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322335#322335 > > > Attachments: > > http://forums.matronics.com//files/100_0099_552.jpg > > > ________________________________________________________________________________
Date: Dec 05, 2010
Prop shaft extenders do two things: 1. They keep the ultra-flexible Ivoprop out of the aileron tubes. 2. They get the prop further from the trailing edge, which reduces "prop chop" noise as the prop cuts through the airflow coming off the wing. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322339#322339 ________________________________________________________________________________
Date: Dec 05, 2010
Thanks Richard. Makes sense now. Gene -------------------------------------------------- From: "Richard Pike" <richard(at)bcchapel.org> Sent: Sunday, December 05, 2010 8:22 AM Subject: Kolb-List: Re: Nice day doing some Texas Kolb cruisin' > > Prop shaft extenders do two things: > 1. They keep the ultra-flexible Ivoprop out of the aileron tubes. > 2. They get the prop further from the trailing edge, which reduces "prop > chop" noise as the prop cuts through the airflow coming off the wing. > > Richard Pike > MKIII N420P (420ldPoops) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322339#322339 > > > ________________________________________________________________________________
Date: Dec 05, 2010
Richard Does the lack of chop noise improve performance? Vic Maine 912 Xtra ________________________________________________________________________________
Date: Dec 05, 2010
In that way it is unlike the Challenger which is much more forgiving and just mushes if the speed drops off Pat Thanks for that info. That explains why it is so easy to identify a Challenger pilot that has a bit of a hard landing. They usually are sporting a cast on one or both legs from their toes to their crotch. The injuries are usually the result of the hose clamps failing that attach the nose gear, followed by the pilots feet going into the ground as the nose of the Challenger is wiped off. I have never flown a Challenger. I have to rely on your expert advice. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: winter skis !
Date: Dec 05, 2010
Chris, it looks like you did it right with the skis. I like your "hat cam" and the video you made. I would like to do the same. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 23 years flying it Kolbra 912UL N20386 2 years flying it 120 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322348#322348 ________________________________________________________________________________
Date: Dec 05, 2010
Maybe my term flair was a bit much. My point is that the kolb airspeed bleeds off quickly. I am not one of those one plane is better than the other kind of people. Each has it's plus and minus. I didn't mean to imply that the challenger is better. I had a challenger, now have a kolb. Not because I thought one was better than the other, just ready for something different. I also have a Rans S12 I am building. However "My" kolb glides like a rock compared the challenger I had. I do like the kolb, I am not cutting it down. Jerry ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, December 05, 2010 9:54 AM Subject: Re: Kolb-List: Novice Kolb Pilot > > > In that way it is unlike the Challenger which is much more forgiving and > just mushes if the speed drops off > > Pat > > > Thanks for that info. > > That explains why it is so easy to identify a Challenger pilot that has a > bit of a hard landing. They usually are sporting a cast on one or both > legs > from their toes to their crotch. The injuries are usually the result of > the > hose clamps failing that attach the nose gear, followed by the pilots feet > going into the ground as the nose of the Challenger is wiped off. > > I have never flown a Challenger. I have to rely on your expert advice. > > john h > mkIII > Titus, Alabama > > > ________________________________________________________________________________
Date: Dec 05, 2010
Maybe my term flair was a bit much. However "My" kolb glides like a rock compared the challenger I had. I do like the kolb, I am not cutting it down. Jerry Hi Jerry/Gang: No problem. You have a "flair" about you. Could not resist. ;-) I was responding, primarily, to Patrick L, former Challenger owner/pilot. I have been flying Kolbs since the first one I built in 1984. I fly them because I have found nothing better that suits my style of flying. Crashworthiness is also high on my list of requirements for my aircraft. Comparing Kolbs and Challengers...., as far as I am concerned, there is none, especially on the Kolb List. I don't imagine Kolbs get high marks on the Challenger List either, if there is a Challenger List. Too cold and windy to fly today for fun. BTW: I took advice from the List and bought the SS exhaust springs from: http://jbmindustries.com/ROTAX.htm I installed them a couple days ago with a good band of silicone seal from hook to hook. They fit the Titan Exhaust perfectly. Looks like they will outlast the old springs that are better at producing rust and failing than keeping the Titan silencer on the pipes. Only operational hours will tell if they are as good as advertised. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 05, 2010
From: william sullivan <williamtsullivan(at)att.net>
Subject: JBM industries
- John- Thanks for the link to JBM.- Last year I put a new throttle cab le grommet on the Bing 54, and it's cracked already without even running it .-It was a Rotax part out of Lockwood.- Looks like I'll try the JBM par ts. - ------------------------- ----------------------- Bill Sullivan ------------------------- ------------------------Win dsor Locks, Ct. ------------------------- ----------------------- FS 44 7 ------------------------- ----------------------- 30 de grees, clear and windy- ________________________________________________________________________________
Date: Dec 05, 2010
Chris The quality is good on that hat cam. Could you post a photo of your hat mount? What camera are you using? Rick Neilsen Redrive VW Powered MKIIIC On Sat, Dec 4, 2010 at 11:58 PM, ces308 wrote: > > Ok ...I stoled someones idea with the hat cam,but it works great ! Thank > you ! Here is the link if you get the chance , > http://www.youtube.com/watch?v=t3qNi2m7yh0 > > Have a great weekend ! > > chris ambrose > M3X/Jabiru A-2200 > n327 cs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322318#322318 > > ________________________________________________________________________________
Subject: Re: Rotax 912 Idle
Date: Dec 05, 2010
Tom, It,s like teaching a pig to whistle,it wastes your time and annoys the pig. G.Aman -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, Nov 29, 2010 4:40 pm Subject: Re: Kolb-List: Rotax 912 Idle My Zenith CH701 friend has a 912S. It has the characteristic on the groun d of stopping when the throttle is pulled to full idle. As his friendly Fligh t Advisor I find this worrisome if not downright unsafe. I've tried to get hi m to increase his idle stop screws but he views it as a deliberate design "feature" to replace the absent mixture idle cutoff. Any comments or experience to assuage my fears or convince him of the error of his ways? Tom Kuffel Whitefish, MT Tom K/Gang: The 912 operators manual indicates the idle speed to be 1,400 rpm minimum. No mention of "deliberate design feature to replace the absent mixture idle cutoff." I believe if Rotax wanted a mixture idle cutoff, they would have equipped the 912 with a mixture control. Never lost a 912 with the throttle closed during an approach, and don't wan t to. For that matter, never had a 912 quit running in flight, except when I screwed up and tried to fly with contaminated fuel. I didn't know the fuel was contaminated because I did not drain fuel after I obtained it from an unreliable source, even though I thought, at the time, both places were reliable aviation fuel suppliers. I have found with my one 912UL and two 912ULS's, they all like to idle around 1,500 to 1,600 rpm. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 05, 2010
I was in the same situation. I am a commercial pilot / fly a learjet 60 for a living and always wanted a small experimental type airplane. I got my tailwheel in a super cub, which is still completely different. I read up on the handling characteristics a lot, then just gave it a shot. As mentioned crow hops are a bad idea, as is starting from pavement. Keep your speed up, fly it to the ground. Come in with a little power each time (enough to make it seem like a normal approach in a cessna or something) and literally just fly the mains on. As you get better start reducing the power untill you can land at idle. Do not flare at 20 feet over the numbers, you will most likely stall. Keep you approach attitude untill 2 feet off the ground and go from there. Hope this helps. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322362#322362 ________________________________________________________________________________
Date: Dec 05, 2010
Thanks Go Time....What a contrast a Lear jet to a Kolb Firestar. If it wasn't for this Firestar popping up on an add, I doubt I would have returned to flying at age 62. I also ride Honda Gold-wings , I always said; If I could only put wings on my GL1800, it would be a perfect world of thrill, reliability and performance.... The Kolb Firestar seems to fit the bill. A best of both worlds. -------- Beware of false knowledge; it is more dangerous than ignorance. George Bernard Shaw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322372#322372 ________________________________________________________________________________
Date: Dec 05, 2010
Thanks Ralph ! I had a good teacher ! lol Can't wait to try them ! chris ambrose M3X/Jab N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322373#322373 ________________________________________________________________________________
Subject: Merry Dawn is a few steps closer to being airborn again
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Dec 05, 2010
Hey all! It's Cristal. The article on the front of the AOPA training magazine inspired me. It said, "No Excuses! Find a way to fly!" So I saved up my change (and hubby even donated his for my cause!) and I finally got my BFR! I also found some time (had a few days off from work and found a sitter) to see what damage my Kolb Mark II has from setting up so long without flying since the baby came 6 weeks early I didn't get a chance to prepare the plane to set. I've taken apart my carbs and will have to replace some things. That ethanol loaded gasoline really gunked up the carbs and fuel filter. What a mess. My battery is also corroded. I'll be saving up some more change to get my replacement parts. Going to clean out the plastic gas tanks I have, take off the exhaust and check the rings and pistons. Now I only have Saturdays to work on it (if I find a sitter) so it may be a while before Merry Dawn is back in the air. (I can tell she's missing it! :D) On a better note, my newest little family member, Abigail, is doing just fine and is growing like crazy! -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322381#322381 ________________________________________________________________________________
Subject: Re: Merry Dawn is a few steps closer to being airborn again
Date: Dec 05, 2010
Hey all! It's Cristal. The article on the front of the AOPA training magazine inspired me. It said, "No Excuses! Find a way to fly!" -------- Cristal Waters Hi Cristal/Gang: Where there is a will, there is a way. Good on you!!! Now I will have an excuse to fly over to Georgia when you all have your next flyin. Take care, john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 05, 2010
Congratulations and Merry Christmas to all of you, and a Happy FLYING New Year to you. Rick Girard On Sun, Dec 5, 2010 at 4:17 PM, cristalclear13 wrote: > cristalclearwaters(at)gmail.com> > > Hey all! It's Cristal. The article on the front of the AOPA training > magazine inspired me. It said, "No Excuses! Find a way to fly!" So I saved > up my change (and hubby even donated his for my cause!) and I finally got my > BFR! I also found some time (had a few days off from work and found a > sitter) to see what damage my Kolb Mark II has from setting up so long > without flying since the baby came 6 weeks early I didn't get a chance to > prepare the plane to set. > > I've taken apart my carbs and will have to replace some things. That > ethanol loaded gasoline really gunked up the carbs and fuel filter. What a > mess. My battery is also corroded. I'll be saving up some more change to > get my replacement parts. Going to clean out the plastic gas tanks I have, > take off the exhaust and check the rings and pistons. Now I only have > Saturdays to work on it (if I find a sitter) so it may be a while before > Merry Dawn is back in the air. (I can tell she's missing it! :D) > > On a better note, my newest little family member, Abigail, is doing just > fine and is growing like crazy! > > -------- > Cristal Waters > Kolb Mark II Twinstar > Rotax 503 DCSI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322381#322381 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 05, 2010
<< My Zenith CH701 friend has a 912S. It has the characteristic on the ground of stopping when the throttle is pulled to full idle >> << It,s like teaching a pig to whistle,it wastes your time and annoys the pig. G.Aman >> Actually he has been pretty responsive to most of my suggestions and did a thorough and careful AC90-89 style preparation to his successful first flight. After showing him John's response to my query he has agreed before his second flight to increase his idle set screws 1/2 turn at a time until he gets a stable idle above 1400. However since he is an (anti)snowbird, the next flight might not be until spring given the recent weather here. Tom Kuffel Whitefish, MT ________________________________________________________________________________
Date: Dec 05, 2010
Well guys, the shooting gallery is open ! What do you think of the new skis ? The Right ski will go much better now that I know what I have the left one done....Can't wait for snow ! These are made for going on snowmobile packed snow on Houghton Lake,,,no glacier hopping...lol chris ambrose M3X/Jabiru A- 2200 168.7 hrs N327CS Chris, I did the same thing with my Firestar about 5 years ago, but only flew it a couple of times before removal. The first thing I found out was the plane felt a like flying tank in the air, scary to bank at any angle, so be prepared. I also found out the importance of putting some runners on the bottom of the ski's to keep the plane going the way you want it and not being blown sideways in any light crosswind. My only suggestion would be to install maybe (3) boogie wheels on top of the ski's that go thru the ski, so that pavement landing or taxi is possible. I ended up making wheeled carts like whats found at HF, just to push it from the hanger to the snow. My conclusion was to just land on the beat down snowmobile trails with my wheels, hoping for no engine outs over the large farmland areas we have here. If anyone wants to try my ski's, they are available. Pick up in For Atkinson, WI. Tom McCarthy N514 TM Zenith 601HD N414 TM Kolb Firestar N863 GB Kolb Slingshot ________________________________________________________________________________
Subject: Type certificate for KOLB MARK II TWINSTAR/ Rotax 582
Date: Dec 06, 2010
Hallo Boys! Can somebody send me a type certificate by copy for my KOLB MARK II TWINSTAR/with Rotax 582/? It would be the best from Deutschland or USA. Please to help for a poor kolb pilot!!!!!!!!!!!!!!!!!!! Thank's. Zolt=E1n Tibor Hungary KOLB Twinstar zetebete@t-online.hu ________________________________________________________________________________
Date: Dec 06, 2010
It improves Hearing Performance. 19.65 mpg is good, Jimmy :-). So is 2.76 gph. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322439#322439 ________________________________________________________________________________
Date: Dec 06, 2010
The injuries are usually the result of the hose clamps failing that attach the nose gear,>> Very good John. I had a good chuckle. I think the hose clamps are like any other part of any construction which is used for something it was not designed for. (Like trying to move rocks with the front wheel of your bike). I always landed my Challenger on the mains and held the front wheel off as long as possible.It was fine. In fact on two occasions when the rubber band failed it was OK. The first time, I landed fast and very untidily and a bit heavy after everything went quiet at about 800 feet. The second time the landing was OK but getting her out from a small, ridged field nearly shook my teeth out before I scraped over the hedge. She leaped from ridge to ridge in a series of controlled crashes but everything held together. The CAA distributes a monthly list of mishaps and it is surprising how many Cessnas etc come to grief from front wheel failure caused by wheelbarrowing in on all three wheels Good to have you back, John. Good flying. Pat ________________________________________________________________________________
Date: Dec 06, 2010
> > Well guys, > the shooting gallery is open ! What do you think of the new skis ? The Right > ski will go much better now that I know what I have the left one done....Can't > wait for snow ! These are made for going on snowmobile packed snow on Houghton > Lake,,,no glacier hopping...lol > > chris ambrose > M3X/Jabiru A- 2200 168.7 hrs > N327CS > > Chris, > > I did the same thing with my Firestar about 5 years ago, but only flew it a couple of times before removal. > The first thing I found out was the plane felt a like flying tank in the air, scary to bank at any angle, so be prepared. I also found out the importance of putting some runners on the bottom of the ski's to keep the plane going the way you want it and not being blown sideways in any light crosswind. My only suggestion would be to install maybe (3) boogie wheels on top of the ski's that go thru the ski, so that pavement landing or taxi is possible. I ended up making wheeled carts like whats found at HF, just to push it from the hanger to the snow. > > My conclusion was to just land on the beat down snowmobile trails with my wheels, hoping for no engine outs over the large farmland areas we have here. > > If anyone wants to try my ski's, they are available. Pick up in For Atkinson, WI. > > > Tom McCarthy > N514 TM Zenith 601HD > N414 TM Kolb Firestar > N863 GB Kolb Slingshot ________________________________________________________________________________
Date: Dec 06, 2010
Tom, Didn't sound that promising in your first post.Johns advice carries a lot m ore weight than most.My friend has a Savannah /912S.We set it mechanically, closing the throttle plates completely, then use a feeler gauge for base a djustment ,then 2 vac gauges on the crossover tube ports to get a very smoo th idle at 1600.We also have a dynamic balancer we purchased as a group tha t made his 912 incredibly smooth at RPM. G.Aman -----Original Message----- From: The Kuffels <kuffel(at)cyberport.net> Sent: Mon, Dec 6, 2010 1:35 am Subject: Re: Kolb-List: Rotax 912 Idle << My Zenith CH701 friend has a 912S. It has the characteristic on the g round of stopping when the throttle is pulled to full idle >> << It,s like teaching a pig to whistle,it wastes your time and annoys the p ig. G.Aman >> Actually he has been pretty responsive to most of my suggestions and did a thorough and careful AC90-89 style preparation to his successful first flig ht. After showing him John's response to my query he has agreed before his seco nd flight to increase his idle set screws 1/2 turn at a time until he gets a stable idle above 1400. However since he is an (anti)snowbird, the next flight might not be until spring given the recent weather here. Tom Kuffel Whitefish, MT ________________________________________________________________________________
Date: Dec 06, 2010
We also have a dynamic balancer we purchased as a group that made his 912 incredibly smooth at RPM. G.Aman Gary A/Gang: What kind of "dynamic balancer" do you have? I am assuming this is a prop balancer. I bought a pair of good quality, viscous dampened vacuum gauges, a couple years ago, to balance my carbs on the 912. However, there was some discrepancy in readings between the two. After a couple tries at using the gauges to balance, I chucked them, and use mechanical balance only. Seemed I was doing a better job mechanically than with the vacuum gauges. The mud daubers have built nest in my prop hub while I was recovering from my injuries. I got most of them out before I flew the other day, but need to remove the prop and extension in order to do a proper job of cleaning. Then I have to decide how to block the empty prop hub holes to prevent them from homesteading on my engine again. 28F, clear and cold in Titus, Alabama. john h mkIII ________________________________________________________________________________
Date: Dec 06, 2010
- John- For plugging/blocking stray holes, try spray foam in a can.- Ma rketed under "Really Great Stuff", or a similar name.- Available at Home Depot, Lowe's, or a hardware store.- Expands to fit, can be trimmed with a saw or knife, weighs nothing, and won't hurt anything if it falls out.- Cheap, too. - ------------------------- --------------- Bill Sullivan --- On Mon, 12/6/10, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: Rotax 912 Idle Date: Monday, December 6, 2010, 9:08 AM - -We also have a dynamic balancer we purchased as a group that made his 91 2 incredibly smooth at RPM. G.Aman - - - -Gary A/Gang: - What kind of "dynamic balancer"- do you have? - I am assuming this is a prop balancer. - I bought a pair of good quality, viscous dampened vacuum gauges, a couple y ears ago, to balance my carbs on the 912.- However, there was some discre pancy in readings between the two.- After a couple tries at using the gau ges to balance, I chucked them, and use mechanical balance only.- Seemed I was doing a better job mechanically than with the vacuum gauges. - The mud daubers have built nest in my prop hub while I was recovering from my injuries.- I got most of them out before I flew the other day, but nee d to remove the prop and extension in order to do a proper job of cleaning. - Then I have to decide how to block the empty prop hub holes to prevent them from homesteading- on my engine again. - 28F, clear and cold in Titus, Alabama. - john h mkIII ________________________________________________________________________________
Date: Dec 06, 2010
John, web site for balancer is RPXTECH.com G.Aman -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, Dec 6, 2010 9:11 am Subject: Re: Kolb-List: Rotax 912 Idle We also have a dynamic balancer we purchased as a group that made his 912 incredibly smooth at RPM. G.Aman Gary A/Gang: What kind of "dynamic balancer" do you have? I am assuming this is a prop balancer. I bought a pair of good quality, viscous dampened vacuum gauges, a couple y ears ago, to balance my carbs on the 912. However, there was some discrepa ncy in readings between the two. After a couple tries at using the gauges to balance, I chucked them, and use mechanical balance only. Seemed I was doing a better job mechanically than with the vacuum gauges. The mud daubers have built nest in my prop hub while I was recovering from my injuries. I got most of them out before I flew the other day, but need to remove the prop and extension in order to do a proper job of cleaning. Then I have to decide how to block the empty prop hub holes to prevent them from homesteading on my engine again. 28F, clear and cold in Titus, Alabama. john h mkIII ________________________________________________________________________________
Date: Dec 06, 2010
John- For plugging/blocking stray holes, try spray foam in a can. Marketed under "Really Great Stuff", or a similar name. Available at Home Depot, Lowe's, or a hardware store. Expands to fit, can be trimmed with a saw or knife, weighs nothing, and won't hurt anything if it falls out. Cheap, too. Bill Sullivan Bill S/Gang: Think that would work in bolt holes in the prop hub? I used silicone seal to fill holes in the gear box. Hesitated to use it on steel after some severe corrosion using it on a 4130 tail wheel strut. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 06, 2010
Might try the non acetic acid silicone sealant...I am guessing that that was why you have corrosion? Never bought any so not sure of brands etc...The Long ez guys use it to make fiberglass lay ups which they mold around their engines for cooling baffles...Herb At 08:43 AM 12/6/2010, you wrote: > John- For plugging/blocking stray holes, try spray foam in a > can. Marketed under "Really Great Stuff", or a similar > name. Available at Home Depot, Lowe's, or a hardware > store. Expands to fit, can be trimmed with a saw or knife, weighs > nothing, and won't hurt anything if it falls out. Cheap, too. > > Bill Sullivan > > >Bill S/Gang: > >Think that would work in bolt holes in the prop hub? > >I used silicone seal to fill holes in the gear box. Hesitated to >use it on steel after some severe corrosion using it on a 4130 tail >wheel strut. > >john h >mkIII >Titus, Alabama > > ________________________________________________________________________________
Date: Dec 06, 2010
Subject: Re:non corrosive sealants
replying to my own message. Just googled non acetic acid silicone...Dow corning makes several...listed as non corrosive or non acetic acid... Home Depot or Lowes...etc...Herb At 08:51 AM 12/6/2010, you wrote: >Might try the non acetic acid silicone sealant...I am guessing that >that was why you have corrosion? Never bought any so not sure of >brands etc...The Long ez guys use it to make fiberglass lay ups >which they mold around their engines for cooling baffles...Herb > >At 08:43 AM 12/6/2010, you wrote: >> John- For plugging/blocking stray holes, try spray foam in a >> can. Marketed under "Really Great Stuff", or a similar >> name. Available at Home Depot, Lowe's, or a hardware >> store. Expands to fit, can be trimmed with a saw or knife, weighs >> nothing, and won't hurt anything if it falls out. Cheap, too. >> >> Bill Sullivan >> >> >> >> >>Bill S/Gang: >> >>Think that would work in bolt holes in the prop hub? >> >>I used silicone seal to fill holes in the gear box. Hesitated to >>use it on steel after some severe corrosion using it on a 4130 tail >>wheel strut. >> >>john h >>mkIII >>Titus, Alabama >> >> >> > > ><http://www.buildersbooks.com>www.buildersbooks.com ><http://www.matronics.com/contribution>http://www.matronics.com/contribution ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List ________________________________________________________________________________
Date: Dec 06, 2010
Actually he has been pretty responsive to most of my suggestions and did a thorough and careful AC90-89 style preparation to his successful first flight. After showing him John's response to my query he has agreed before his second flight to increase his idle set screws 1/2 turn at a time until he gets a stable idle above 1400. However since he is an (anti)snowbird, the next flight might not be until spring given the recent weather here. Tom Kuffel Whitefish, MT tom while pulling a mixture control to kill most aircraft engines is a design feature,,, it is done by a separate control, and can't be done by accident while adjusting the throttle in an emergency or normal routine. if he wanted a way to kill the engine if the mag switches failed... have him fix up a control that will shut the fuel off either at the tanks or just before the carbs. it would take a bit longer to kill the engine because of the fuel in the float bowl.. but it would be better than killing the engine on short final only to find that because of wind, you needed a bit more power to make the runway. maybe because he has agreed to 1400 rpm at idle... this may be too late to be of help... if he created a stop on the throttle quadrant that would keep the engine at a good idle speed... and have a way to disable the stop by depressing another control at the same time. then he could, only after overcoming the throttle stop, be able to pull the throttle to stop the engine. the idle stop screws would be the best way to control the idle speed... as cable stretch would alter the settings if using a throttle stop. boyd young mkIII 912 ________________________________________________________________________________
Date: Dec 06, 2010
John, web site for balancer is RPXTECH.com G.Aman >>>>>>>>>>>> Garry.... does the balancer change any between flights,,, and therefore take a little time to rebalance upon start up... or is it quite stable between flights. boyd ________________________________________________________________________________
Date: Dec 06, 2010
Subject: Re: Type certificate for KOLB MARK II TWINSTAR/ Rotax 582
Zoltan, No Kolb aircraft is type cerificated. They are either flown as ultralights under FAR 103, or they are licensed in the experimental categor y under FAR 21.191(h) or 21.191(i)1. Rick Girard 2010/12/6 zetebete <zetebete@t-online.hu> > Hallo Boys! > > Can somebody send me a type certificate by copy for my KOLB MARK II > TWINSTAR/with Rotax 582/? > > It would be the best from Deutschland or USA. > > Please to help for a poor kolb pilot!!!!!!!!!!!!!!!!!!! > > Thank=92s. > > Zolt=E1n Tibor Hungary > > KOLB Twinstar > > zetebete@t-online.hu > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unabl e to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 06, 2010
That's good info Herb. I used silicone to plug all the unused holes in my suzuki engine. They were subject to the same mud plugs. I would hesitate to use great stuff. -once made a vehicle rust out twice as fast by injecting it into all the hollow panels. Turns out it wicks moisture -and salt. :( For a temporary fix on the prop hub a patch of duct tape stays on fine. Not very high tech looking. I don't use the back up disk on my two blade warp hub so I found a rubber plug that fit the center hole perfectly Sometimes it pays to save old stuff. BB On 6, Dec 2010, at 9:59 AM, Herb wrote: > > replying to my own message. Just googled non acetic acid silicone...Dow corning makes several...listed as non corrosive or non acetic acid... Home Depot or Lowes...etc...Herb > > At 08:51 AM 12/6/2010, you wrote: > >> Might try the non acetic acid silicone sealant...I am guessing that that was why you have corrosion? Never bought any so not sure of brands etc...The Long ez guys use it to make fiberglass lay ups which they mold around their engines for cooling baffles...Herb >> >> At 08:43 AM 12/6/2010, you wrote: >>> John- For plugging/blocking stray holes, try spray foam in a can. Marketed under "Really Great Stuff", or a similar name. Available at Home Depot, Lowe's, or a hardware store. Expands to fit, can be trimmed with a saw or knife, weighs nothing, and won't hurt anything if it falls out. Cheap, too. >>> >>> Bill Sullivan >>> >>> >>> >>> >>> Bill S/Gang: >>> >>> Think that would work in bolt holes in the prop hub? >>> >>> I used silicone seal to fill holes in the gear box. Hesitated to use it on steel after some severe corrosion using it on a 4130 tail wheel strut. >>> >>> john h >>> mkIII >>> Titus, Alabama >>> >>> >>> >> >> >> >> Month -- >> Some AWESOME FREE Gifts!) >> www.aeroelectric.com >> www.buildersbooks.com >> www.homebuilthelp.com >> >> http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> Email Forum - >> >> http://www.matronics.com/Navigator?Kolb-List >> - MATRONICS WEB FORUMS - >> http://forums.matronics.com > > ________________________________________________________________________________
Date: Dec 06, 2010
Cristal that's great. Glad to hear you are doing well and have the drive in your heart to continue flying and maintaining your Kolb with all you have going on. Still look forward to meeting you one day. Best wishes! -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322477#322477 ________________________________________________________________________________
Date: Dec 06, 2010
John, The balancer tells you how much weight to add and where to add it.I put on ly a few grams under the prop attach bolts (washers in my case)or nuts.I ha ve the info in the certificate holder in the airplane so I can't recall exa ctly how much weight total we added,but it was a few grams.We left the refl ector tape on on as well,,just a small spot..The chart in the plane is a se gmented circle showing degrees and the weight added at those locations. G.Aman -----Original Message----- From: b young <by0ung(at)brigham.net> Sent: Mon, Dec 6, 2010 11:13 am Subject: Re: Kolb-List: Rotax 912 Idle John, web site for balancer is RPXTECH.com G.Aman >>>>>>>>>>>> Garry.... does the balancer change any between flights,,, and therefore take a little time to rebalance upon start up... or is it quite stable be tween flights. boyd ________________________________________________________________________________
Date: Dec 06, 2010
Try the auto parts store; look for 'sensor safe'. (meaning non-corrosive) Charlie On 12/6/2010 8:59 AM, Herb wrote: > > replying to my own message. Just googled non acetic acid > silicone...Dow corning makes several...listed as non corrosive or non > acetic acid... Home Depot or Lowes...etc...Herb > > At 08:51 AM 12/6/2010, you wrote: > >> Might try the non acetic acid silicone sealant...I am guessing that >> that was why you have corrosion? Never bought any so not sure of >> brands etc...The Long ez guys use it to make fiberglass lay ups which >> they mold around their engines for cooling baffles...Herb >> >> At 08:43 AM 12/6/2010, you wrote: >>> John- For plugging/blocking stray holes, try spray foam in a can. >>> Marketed under "Really Great Stuff", or a similar name. Available >>> at Home Depot, Lowe's, or a hardware store. Expands to fit, can be >>> trimmed with a saw or knife, weighs nothing, and won't hurt anything >>> if it falls out. Cheap, too. >>> >>> Bill Sullivan >>> >>> >>> >>> >>> Bill S/Gang: >>> >>> Think that would work in bolt holes in the prop hub? >>> >>> I used silicone seal to fill holes in the gear box. Hesitated to >>> use it on steel after some severe corrosion using it on a 4130 tail >>> wheel strut. >>> >>> john h >>> mkIII >>> Titus, Alabama >>> >>> >>> >> ________________________________________________________________________________
Date: Dec 06, 2010
For a temporary fix on the prop hub a patch of duct tape stays on fine. Not very high tech looking. I don't use the back up disk on my two blade warp hub so I found a rubber plug that fit the center hole perfectly Sometimes it pays to save old stuff. BB >>>>>>>>>>>>>>>>>>>>>>> if you get the aluminum duct tape,, available at hvac (heating vent air conditioning) locations... cut to fit, pull the backing and it stays put well and looks good. boyd young mkIII utah ________________________________________________________________________________
Date: Dec 06, 2010
if you get the aluminum duct tape,, available at hvac (heating vent air conditioning) locations... cut to fit, pull the backing and it stays put well and looks good. boyd young Folks: Thanks for all the recommendations. I like Boyd's idea of aluminum duct tape. It is light, can die cut enough to cover the holes, and should not affect balance. Darn mud daubers are a pain in the butt. They have several places around the cylinder bases on the crank case they love to build homes. On top of that, where they build their homes is difficult to access and remove. Clear, sunny, and cold. Still too cold to fly comfortably, unless I get serious, get out the Chillie Vest and long drawers. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 06, 2010
John, If your hub has the small, 1" hole a plastic cap off a Blitz fuel can fits perfectly. It's been in the hole of my trike's Power Fin for almost three years now, weighs little and I always have a gas cap handy should I need it. Rick Girard On Mon, Dec 6, 2010 at 3:57 PM, John Hauck wrote: > > if you get the aluminum duct tape,, available at hvac (heating vent air > conditioning) locations... cut to fit, pull the backing and it stays put > well and looks good. > > boyd young > > > Folks: > > Thanks for all the recommendations. > > I like Boyd's idea of aluminum duct tape. It is light, can die cut enough > to cover the holes, and should not affect balance. > > Darn mud daubers are a pain in the butt. They have several places around > the cylinder bases on the crank case they love to build homes. On top of > that, where they build their homes is difficult to access and remove. > > Clear, sunny, and cold. Still too cold to fly comfortably, unless I get > serious, get out the Chillie Vest and long drawers. > > john h > mkIII > Titus, Alabama > > * > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 06, 2010
Boyd, Sorry,After reading my first post it sounded like an accessory that bolted on .It's a procedure using this equipment.I thought my Jabiru was fairly sm ooth,but I could feel the difference after we balanced the prop. G.Aman MK3C Jabiru 2200A 600hrs -----Original Message----- From: b yIt's oung <by0ung(at)brigham.net> Sent: Mon, Dec 6, 2010 11:13 am Subject: Re: Kolb-List: Rotax 912 Idle John, web site for balancer is RPXTECH.com G.Aman >>>>>>>>>>>> Garry.... does the balancer change any between flights,,, and therefore take a little time to rebalance upon start up... or is it quite stable be tween flights. boyd ________________________________________________________________________________
Date: Dec 06, 2010
John, If your hub has the small, 1" hole a plastic cap off a Blitz fuel can fits perfectly. It's been in the hole of my trike's Power Fin for almost three years now, weighs little and I always have a gas cap handy should I need it. Rick Girard Rick G/Gang: I have the large hole covered with a prop spinner. It is the unused bolt holes exposed on the forward side of the prop hub that need plugging. I need to pull the prop and extension, clean everything up good, then take care of plugg/covering to prevent the little rascals from homesteading again. I also need to make a cover for the aft end of the tailboom. Probably out of hardware cloth or screen wire. Something that is easy to slip on and off. Probably end up with something that is two piece, protected with duct tape to prevent scuffing up the paint when removed and installed each day I fly. After the rodents have gotten in and done their dirty deeds, it is too late. All it takes is one trip in and they can destroy seat belts, shoulder harness, seat covers, wiring, and plastic brake lines. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Merry Dawn
Date: Dec 06, 2010
> My battery is also corroded. I'll be saving up some more change to get my replacement parts. I have a feeling that many aircraft batteries are damaged by sulfation, and may not really need replacement. I stopped at a yard sale down my street a month or two ago. Bought a TV stand (oak, nice!) and asked about a red-top battery sitting there. It looked like it had been lightly used (but you can't really tell). The guy told me it was no good, but I could have it if I wanted. Apart from the $7.00 the recycler gives for batteries, I had different aspirations. I took it home and put my battery rejuvenator on it. At first the battery would not take a charge at all. Now it is taking and holding a charge. Not sure the % capacity yet, haven't done more tests. Process not finished. One of my 4x4 buddies had an expensive yellow-top that was new, but had sat with no charge for some years. I put a rejuvenator on that, coupla months later I gave him back a like new battery. My cousin was moving and I was helping. He was going to leave a deep cycle battery sitting there. I took it, rejuvenated it, and it works like new. It had very few actual working hours on it, it was just sitting for a few years with no charge that allowed the sulfur compound that was deposited on the plates from solution during the discharge process to change form with time into a form of sulfate that is much more stable and resistant to the charging current. This builds up over time until you have no 'bare' plate left to carry on the chemical reaction and produce current. There are several ways to eliminate or discourage the formation of sulfate, but the older methods are a little harsh on the battery and/or not suitable for domestic life in the suburbs. Selected chemical bonds can be 'excited' by certain frequencies of of.. uh.. excitation. The desulfators use spikes of electricity that are safe for electronic circuits, yet 'ring' the molecule's bonds (not sure which ones) at a harmonic frequency. So without a huge current, out-gassing, adding water, or any hassle one can safely re-claim certain batteries. This won't help a worn out battery, a damaged battery, shorted, with warped plates, etc, but a good battery that has simply been allowed to sit discharged is a good candidate. I used to go to a motorcycle shop that threw away a lot of batteries. They sit too long in crates, on ships, on the floor, etc. I have a buncha good batteries for my various projects and vehicles. I have- uh, twelve pieces of equipment around here, including my vehicles, that use batteries. My diesel PU and 5th-wheel each use two batteries. The rejuvenators cost between $25-$75 on-line. My setup: I have 100 watts of photovoltaic on my RV. Most of the time the RV is parked. I attach the bad battery to the charging circuit. I attach the 12v powered rejuvenator to the battery also. I let the mix work for a month or so. The manufacturer of the device says that doing it this way is the fastest way to fix a battery. It charges during the day, and the rejuvenator is said to operate on one plate, then at night the rejuvenator operates on the opposite plate, living off the residual charge in the battery. Thus both polarity of plates get whacked. They have these circuits in many RV power supplies now, stock. GeoB ________________________________________________________________________________
Date: Dec 06, 2010
John, A lot of cold air and exhaust fumes blew up my tail boom,so I made a plug o f 6" thick foam rubber, 7"in diameter with 4 slits cut for the cables at 12 ,6.10 and 2 o'clock approx,placed it about a foot up the pipe.Seems to work OK. Cut it on a band saw. G.Aman -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, Dec 6, 2010 7:22 pm Subject: Re: Kolb-List: Re:non corrosive sealants John, If your hub has the small, 1" hole a plastic cap off a Blitz fuel ca n fits perfectly. It's been in the hole of my trike's Power Fin for almost three years now, weighs little and I always have a gas cap handy should I n eed it. Rick Girard Rick G/Gang: I have the large hole covered with a prop spinner. It is the unused bolt h oles exposed on the forward side of the prop hub that need plugging. I need to pull the prop and extension, clean everything up good, then take care of plugg/covering to prevent the little rascals from homesteading agai n. I also need to make a cover for the aft end of the tailboom. Probably out of hardware cloth or screen wire. Something that is easy to slip on and of f. Probably end up with something that is two piece, protected with duct t ape to prevent scuffing up the paint when removed and installed each day I fly. After the rodents have gotten in and done their dirty deeds, it is too late . All it takes is one trip in and they can destroy seat belts, shoulder ha rness, seat covers, wiring, and plastic brake lines. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 06, 2010
John, A lot of cold air and exhaust fumes blew up my tail boom,so I made a plug of 6" thick foam rubber, 7"in diameter with 4 slits cut for the cables at 12,6.10 and 2 o'clock approx,placed it about a foot up the pipe.Seems to work OK. Cut it on a band saw. G.Aman Gary A/Folks: That may be a good idea. No telling what is being blown up the tailboom and into the cockpit. The important thing for me is to insure the rodents won't chew through the foam to get into the cockpit. I have to be careful. I do not want to trap condensation, rain water, etc., inside the tailboom (a very intergral part of the aircraft). Need to do something positive though, before the rodents start looking for new nesting areas. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 07, 2010
John=2C Regarding rodents=2C etc. Try putting a "mothball" puck (toilet bowl han ger) in vulnerable areas. If you are concerned about the puck harming any surround ing airplane parts=2C make a little basket for it to sit on out of aluminum foil. Be sure to list them on your pre-flight inspection=2C to remove them and set aside during flights. I would think three ought to do it. Your experience may v ary. No self-respecting mud dauber=2C or mouse=2C rat=2C squirrel=2C chicken =2C etc=2C could stand the fumes! Guaranteed to last 90 days=2C depending on use....they say. Might be worth a try=2C supposedly works for deer in your garden=2C altho ugh I can't say if it's true or not. Awhile back=2C I was walking in my shop=2C when across the front of my ey es flew a small "wasp" looking insect. It was really small=2C missed me by about 4". I turned my head to watch were it was headed. It landed on the open fuel line to my GEO engine (which was disconnected so that I could remove the engine). Then it proceeded to walk inside the fuel line!! Evidently=2C it had a nice nest going on in side the fuel line. I disconnected the fuel line completely=2C and removed it altogether!!! I have since replaced it with automotive high pressure rubber fuel hose....with a filter !! Mike Welch MkIII From: jhauck(at)elmore.rr.com Subject: Re: Kolb-List: Re:non corrosive sealants Date: Mon=2C 6 Dec 2010 21:25:40 -0600
November 19, 2010 - December 07, 2010
Kolb-Archive.digest.vol-kw
